RV10-Archive.digest.vol-mj
October 13, 2016 - December 02, 2016
      Smith Mountain Lake, Virginia
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Sent: Thursday, October 6, 2016 4:26 PM
Subject: Advice
What altitude? What off airport options are there? I am a chicken when it comes to short runways.so I know I would not do it, but we all have our own comfort zone. I also don=99t believe that you want to add any risk factors you don=99t have to for your first flight. Rene' 801-721-6080
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Boyd Sent: Thursday, October 06, 2016 2:08 PM Subject: Re: RV10-List: Advice Just curious - how many of you would make your first -10 flight off a 2100 foot grass strip? Been flying my 6A out of the back yard for 900+ hours now, but did my first flights out of LWB with 7001 feet of asphalt and crash trucks available. Daydreaming of the day I finish the 10 and whether I would be foolish not to disassemble it and truck it 40 miles on a roll-back for the big day. Insurance company might have their own thoughts on the matter. -Bill Boyd On Thu, Oct 6, 2016 at 1:10 PM, Danny Riggs > wrote: > Yeah, make sure your elevator is centered before take-off. Won't say how I know THAT one! =F0=9F=98=9C Sent from my iPad > On Oct 6, 2016, at 9:45 AM, Ron Walker > wrote: > > > > Posing the question for any sound advice you may have to offer prior to first flight of my 10 ? > > I've been through first flight once already with my 7a. The 10 seems different though. I've already done 6 hrs training in the factory 10 with Mike. > > Anything specific to be aware of ? Any recommendations from those that have been through this already ? Anything you would have done differently ? > > Thanks ! > > --Ron > > -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Oct 13, 2016
Subject: Marking acrylic windscreen
Before I do something I regret with a sharpie, does anyone know if it's safe to use directly on the windscreen? Or, is there an alternative that I could utilize? I'm looking to fair in the windscreen and need to mark the windscreen with the 7" radius so I can lay the electrical tape down. Thanks, Phil Sent from my iPhone ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Oct 13, 2016
No. Do not do it unless you are marking a line that will get cut out. If you want to make a radius, just use the edge of the tape. No need to mark to do this. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Thursday, October 13, 2016 11:46 AM Subject: RV10-List: Marking acrylic windscreen Before I do something I regret with a sharpie, does anyone know if it's safe to use directly on the windscreen? Or, is there an alternative that I could utilize? I'm looking to fair in the windscreen and need to mark the windscreen with the 7" radius so I can lay the electrical tape down. Thanks, Phil Sent from my iPhone ________________________________________________________________________________
Subject: I Hate Leaking Fuel Tanks!
Date: Oct 13, 2016
Hmmm There I said it! Anyway, over the past few months I have developed rivet line leaks in both my QB tanks along the inboard line of fuel tank rivets on the tank bottom. I am hoping that it is the rivets that are leaking and not between the flange and the bottom tank skin. Is there something special about how these inboard flanges are sealed that makes them prone to leaks. To date my only leaks have been on the rivets on the top of the tanks. If the leak(s) are between the skin and the flange, is there a good (and simple) way to correct the problem? Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461241#461241 ________________________________________________________________________________
Subject: Re: Marking acrylic windscreen
Date: Oct 13, 2016
You can use 1/4 vinyl masking tape like this: https://amzn.com/B00IOQ3J9Q Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461242#461242 ________________________________________________________________________________
Subject: Re: I Hate Leaking Fuel Tanks!
Date: Oct 13, 2016
The only thing I've heard of to seal really small leaks is green Loctite. You need to clean the hole with acetone. Pull a small vacuum on the tank and suck the acetone through the hole .... the more the better ..... and then let that evaporate. Then apply the loctite so it get sucked into the hole. Linn On 10/13/2016 4:41 PM, kearney wrote: > > Hmmm > > There I said it! > > Anyway, over the past few months I have developed rivet line leaks in both my QB tanks along the inboard line of fuel tank rivets on the tank bottom. I am hoping that it is the rivets that are leaking and not between the flange and the bottom tank skin. Is there something special about how these inboard flanges are sealed that makes them prone to leaks. > > To date my only leaks have been on the rivets on the top of the tanks. > > If the leak(s) are between the skin and the flange, is there a good (and simple) way to correct the problem? > > Cheers > > Les > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461241#461241 > > ________________________________________________________________________________
Date: Oct 13, 2016
Very frustrating indeed! Real fun thing is they did not become an issue unt il after I had the airplane painted. I actually had pretty good success using the green Loctite (penetrating) oth ers had recommended in the past. It took a lot of applications but no surger y. Marcus > On Oct 13, 2016, at 4:41 PM, kearney wrote: > > > Hmmm > > There I said it! > > Anyway, over the past few months I have developed rivet line leaks in both my QB tanks along the inboard line of fuel tank rivets on the tank bottom. I am hoping that it is the rivets that are leaking and not between the flange and the bottom tank skin. Is there something special about how these inboar d flanges are sealed that makes them prone to leaks. > > To date my only leaks have been on the rivets on the top of the tanks. > > If the leak(s) are between the skin and the flange, is there a good (and s imple) way to correct the problem? > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461241#461241 > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Subject: Aero Classic Leak guard inner tubes - do not purchase
Date: Oct 14, 2016
After struggling with the straight tube OEM Vans inner tube, I decided to go to the Aero Classic from Desser Tire TU15/600-6. My experience with this tube has been awful. I went to this tube due to the nice 90 degree bend in the stem that allows easier filling with air. By removing a small bit of metal on the wheel bearing cover, you can easily fill this tube with air. My left side failed after only 6 weeks leaving me with a flat tire when I was ready to dispatch the plane for an important flight. Since I was inside of 90 days, Desser gave me an RMA and I got a credit (not refund) on the defective tube. My second tube failed just this last week after about 5 months of flying. These tubes (made in Thailand) are just no good. I reinstalled my old Vans tube on the new Michelin tire on the left side, but I have yet to put the old tube back on the right side. These tubes are just crap. Any suggestions or comments on this issue will be appreciated. -------- See you OSH '15 Q/B - flying 6 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461260#461260 ________________________________________________________________________________
Date: Oct 14, 2016
Subject: Re: Aero Classic Leak guard inner tubes - do not purchase
That's odd- I've used these same tubes for three years without any problems. Sent from my iPhone > On Oct 14, 2016, at 11:54 AM, AirMike wrote: > > > After struggling with the straight tube OEM Vans inner tube, I decided to go to the Aero Classic from Desser Tire TU15/600-6. My experience with this tube has been awful. I went to this tube due to the nice 90 degree bend in the stem that allows easier filling with air. By removing a small bit of metal on the wheel bearing cover, you can easily fill this tube with air. My left side failed after only 6 weeks leaving me with a flat tire when I was ready to dispatch the plane for an important flight. Since I was inside of 90 days, Desser gave me an RMA and I got a credit (not refund) on the defective tube. My second tube failed just this last week after about 5 months of flying. These tubes (made in Thailand) are just no good. I reinstalled my old Vans tube on the new Michelin tire on the left side, but I have yet to put the old tube back on the right side. These tubes are just crap. Any suggestions or comments on this issue will be appreciated. > > -------- > See you OSH '15 > Q/B - flying 6 yrs. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461260#461260 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 14, 2016
I'd like to know what/where the failures were. I suspect poor assembly rather than inherent failures of the tubes. Or poor assumptions relating to the mod. If you used the same hole in the wheel that was used for the straight stem .... there's your problem. The 90* stems line up with the parting line in the wheel and require a hole in the parting line and another hole in the side of the outside wheel half. I converted my Vans wheels to 90* stems. I flared the inside and outside of the original stem hole and filled it with flox. Not flying yet so don't know if my 'mod' is successful. Linn On 10/14/2016 12:54 PM, AirMike wrote: > > After struggling with the straight tube OEM Vans inner tube, I decided to go to the Aero Classic from Desser Tire TU15/600-6. My experience with this tube has been awful. I went to this tube due to the nice 90 degree bend in the stem that allows easier filling with air. By removing a small bit of metal on the wheel bearing cover, you can easily fill this tube with air. My left side failed after only 6 weeks leaving me with a flat tire when I was ready to dispatch the plane for an important flight. Since I was inside of 90 days, Desser gave me an RMA and I got a credit (not refund) on the defective tube. My second tube failed just this last week after about 5 months of flying. These tubes (made in Thailand) are just no good. I reinstalled my old Vans tube on the new Michelin tire on the left side, but I have yet to put the old tube back on the right side. These tubes are just crap. Any suggestions or comments on this issue will be appreciated. > > -------- > See you OSH '15 > Q/B - flying 6 yrs. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461260#461260 > > ________________________________________________________________________________
Date: Oct 14, 2016
I had an issue where an inspection sticker inside the tire wore a hole in the tube - I thought I got a bad tube...until I wore a hole through the patch as I put it back together the same way it came apart..... -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike Sent: Friday, October 14, 2016 12:54 PM Subject: RV10-List: Aero Classic Leak guard inner tubes - do not purchase After struggling with the straight tube OEM Vans inner tube, I decided to go to the Aero Classic from Desser Tire TU15/600-6. My experience with this tube has been awful. I went to this tube due to the nice 90 degree bend in the stem that allows easier filling with air. By removing a small bit of metal on the wheel bearing cover, you can easily fill this tube with air. My left side failed after only 6 weeks leaving me with a flat tire when I was ready to dispatch the plane for an important flight. Since I was inside of 90 days, Desser gave me an RMA and I got a credit (not refund) on the defective tube. My second tube failed just this last week after about 5 months of flying. These tubes (made in Thailand) are just no good. I reinstalled my old Vans tube on the new Michelin tire on the left side, but I have yet to put the old tube back on the right side. These tubes are just crap. Any suggestions or comments on this issue will be appreciated. -------- See you OSH '15 Q/B - flying 6 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461260#461260 ________________________________________________________________________________
Date: Oct 14, 2016
I have the same TU15 Desser tubes, and probably have the longest life on mine as I got some of the first ones released. I have gone against the" replace tubes with tires" minds and reinstalled the tubes on the new Monster tires, to date I have had no issues of leaking at all, that's is after 4 years of flying. I'll assume the tire pressure is more than 42psi? I run mine at 48psi and never let them get below 44psi, I am concerned with lower pressures pinching the tires or rubbing and my pressures seems to work as my tires look pretty good for tread, I have no shutter (unbalanced rim still) with solid traction. I can only think they changed manufacturer since I got my tubes. Unfortunately, I really like mine thus far and would buy them again. How are the Vans tubes working out? Was it only on the left side? Both times? What about the right? Is that side fine? If so, there may be something on the left causing the issues, and your Vans tube may be the next to go on that side... just thinking.... -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike Sent: Friday, October 14, 2016 9:54 AM Subject: RV10-List: Aero Classic Leak guard inner tubes - do not purchase After struggling with the straight tube OEM Vans inner tube, I decided to go to the Aero Classic from Desser Tire TU15/600-6. My experience with this tube has been awful. I went to this tube due to the nice 90 degree bend in the stem that allows easier filling with air. By removing a small bit of metal on the wheel bearing cover, you can easily fill this tube with air. My left side failed after only 6 weeks leaving me with a flat tire when I was ready to dispatch the plane for an important flight. Since I was inside of 90 days, Desser gave me an RMA and I got a credit (not refund) on the defective tube. My second tube failed just this last week after about 5 months of flying. These tubes (made in Thailand) are just no good. I reinstalled my old Vans tube on the new Michelin tire on the left side, but I have yet to put the old tube back on the right side. These tubes are just crap. Any suggestions or comments on this issue will be appreciated. -------- See you OSH '15 Q/B - flying 6 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461260#461260 ________________________________________________________________________________
Date: Oct 14, 2016
I had 2 tubes fail from Desser, not all that many flying hours apart, also. But, mine weren't the 90 degree valve stem tubes. One of them was a pinhole leak that just came out of nowhere. The other was a leak that was along a little slice-like scrape, that I have no idea how it got there. Admittedly, I didn't thoroughly inspect the tube when I pulled it out of the bag. I wasn't happy in either case. Both wheels now have new-ish 90 degree stem tubes in them. I've always run my pressues at the standard 42/40 rear/front pressures that Van's put in the original manual, however I think I will start raising the pressure slightly just because we have such large temperature swings here, so if I check them in the fall I'll go maybe 48. Linn, I think you're mistaking his issue for the nosewheel tube. Yes, on that one Van's sends the wrong wheel, and then they have to re-machine the hole on the other side, and all the things you said. But he's talking about the 15/6.00-6 main tubes. Those don't require any drilling or anything else. Other than these 2 tubes, I've had good luck over the past 10 years. I've replaced tires a few times and always put in new tubes. So I'm not sure I'm ready to ditch them yet. I WOULD be interested to see what the BEST tube available is. I would prefer to buy a US made tube if at all possible, and would pay a small premium for that ability if it's a quality tube. Tim On 10/14/2016 11:54 AM, AirMike wrote: > > After struggling with the straight tube OEM Vans inner tube, I > decided to go to the Aero Classic from Desser Tire TU15/600-6. My > experience with this tube has been awful. I went to this tube due to > the nice 90 degree bend in the stem that allows easier filling with > air. By removing a small bit of metal on the wheel bearing cover, you > can easily fill this tube with air. My left side failed after only 6 > weeks leaving me with a flat tire when I was ready to dispatch the > plane for an important flight. Since I was inside of 90 days, Desser > gave me an RMA and I got a credit (not refund) on the defective tube. > My second tube failed just this last week after about 5 months of > flying. These tubes (made in Thailand) are just no good. I > reinstalled my old Vans tube on the new Michelin tire on the left > side, but I have yet to put the old tube back on the right side. > These tubes are just crap. Any suggestions or comments on this issue > will be appreciated. > > -------- See you OSH '15 Q/B - flying 6 yrs. > > ________________________________________________________________________________
Date: Oct 14, 2016
Tim, I had to machine both my mains. That might be due to the tube manufacturer being different. I'm guessing from your post that you used the same hole as the straight stem?? Linn On 10/14/2016 2:16 PM, Tim Olson wrote: > > I had 2 tubes fail from Desser, not all that many flying hours apart, > also. But, mine weren't the 90 degree valve stem tubes. > One of them was a pinhole leak that just came out of nowhere. > The other was a leak that was along a little slice-like > scrape, that I have no idea how it got there. Admittedly, > I didn't thoroughly inspect the tube when I pulled it out of > the bag. I wasn't happy in either case. > > Both wheels now have new-ish 90 degree stem tubes in them. > I've always run my pressues at the standard 42/40 rear/front > pressures that Van's put in the original manual, however I > think I will start raising the pressure slightly just > because we have such large temperature swings here, so if > I check them in the fall I'll go maybe 48. > > Linn, I think you're mistaking his issue for the nosewheel > tube. Yes, on that one Van's sends the wrong wheel, and > then they have to re-machine the hole on the other side, > and all the things you said. But he's talking about the > 15/6.00-6 main tubes. Those don't require any drilling > or anything else. > > Other than these 2 tubes, I've had good luck over the past > 10 years. I've replaced tires a few times and always put in > new tubes. So I'm not sure I'm ready to ditch them > yet. I WOULD be interested to see what the BEST tube > available is. I would prefer to buy a US made tube if > at all possible, and would pay a small premium for that > ability if it's a quality tube. > > Tim > > > On 10/14/2016 11:54 AM, AirMike wrote: >> >> After struggling with the straight tube OEM Vans inner tube, I >> decided to go to the Aero Classic from Desser Tire TU15/600-6. My >> experience with this tube has been awful. I went to this tube due to >> the nice 90 degree bend in the stem that allows easier filling with >> air. By removing a small bit of metal on the wheel bearing cover, you >> can easily fill this tube with air. My left side failed after only 6 >> weeks leaving me with a flat tire when I was ready to dispatch the >> plane for an important flight. Since I was inside of 90 days, Desser >> gave me an RMA and I got a credit (not refund) on the defective tube. >> My second tube failed just this last week after about 5 months of >> flying. These tubes (made in Thailand) are just no good. I >> reinstalled my old Vans tube on the new Michelin tire on the left >> side, but I have yet to put the old tube back on the right side. >> These tubes are just crap. Any suggestions or comments on this issue >> will be appreciated. >> >> -------- See you OSH '15 Q/B - flying 6 yrs. >> >> >> > > ________________________________________________________________________________
Date: Oct 14, 2016
Subject: Weird Broken Wheel Pant
The other day, my buddy was pushing the 10 back into the hanger when he heard a cracking sound from the left main wheel pant. (See attached) We checked the clearance from the tire and it was fine and the WP was still very firmly attached. Tire pressure was also good. Any ideas on what may have caused this? Shannon ________________________________________________________________________________
Date: Oct 14, 2016
Yes, same holes. You have Cleveland? That's what mine are. Tim > On Oct 14, 2016, at 1:27 PM, Linn Walters wrote: > > > Tim, I had to machine both my mains. That might be due to the tube manufacturer being different. I'm guessing from your post that you used the same hole as the straight stem?? > Linn > >> On 10/14/2016 2:16 PM, Tim Olson wrote: >> >> I had 2 tubes fail from Desser, not all that many flying hours apart, >> also. But, mine weren't the 90 degree valve stem tubes. >> One of them was a pinhole leak that just came out of nowhere. >> The other was a leak that was along a little slice-like >> scrape, that I have no idea how it got there. Admittedly, >> I didn't thoroughly inspect the tube when I pulled it out of >> the bag. I wasn't happy in either case. >> >> Both wheels now have new-ish 90 degree stem tubes in them. >> I've always run my pressues at the standard 42/40 rear/front >> pressures that Van's put in the original manual, however I >> think I will start raising the pressure slightly just >> because we have such large temperature swings here, so if >> I check them in the fall I'll go maybe 48. >> >> Linn, I think you're mistaking his issue for the nosewheel >> tube. Yes, on that one Van's sends the wrong wheel, and >> then they have to re-machine the hole on the other side, >> and all the things you said. But he's talking about the >> 15/6.00-6 main tubes. Those don't require any drilling >> or anything else. >> >> Other than these 2 tubes, I've had good luck over the past >> 10 years. I've replaced tires a few times and always put in >> new tubes. So I'm not sure I'm ready to ditch them >> yet. I WOULD be interested to see what the BEST tube >> available is. I would prefer to buy a US made tube if >> at all possible, and would pay a small premium for that >> ability if it's a quality tube. >> >> Tim >> >> >>> On 10/14/2016 11:54 AM, AirMike wrote: >>> >>> After struggling with the straight tube OEM Vans inner tube, I >>> decided to go to the Aero Classic from Desser Tire TU15/600-6. My >>> experience with this tube has been awful. I went to this tube due to >>> the nice 90 degree bend in the stem that allows easier filling with >>> air. By removing a small bit of metal on the wheel bearing cover, you >>> can easily fill this tube with air. My left side failed after only 6 >>> weeks leaving me with a flat tire when I was ready to dispatch the >>> plane for an important flight. Since I was inside of 90 days, Desser >>> gave me an RMA and I got a credit (not refund) on the defective tube. >>> My second tube failed just this last week after about 5 months of >>> flying. These tubes (made in Thailand) are just no good. I >>> reinstalled my old Vans tube on the new Michelin tire on the left >>> side, but I have yet to put the old tube back on the right side. >>> These tubes are just crap. Any suggestions or comments on this issue >>> will be appreciated. >>> >>> -------- See you OSH '15 Q/B - flying 6 yrs. >>> >>> >>> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Oct 14, 2016
VW5sZXNzIGhpcyBoYW5nYXIgaGFzIHBvdGhvbGVzIHRoZXJlIGlzIG5vdGhpbmcgSSBjYW4gdGhp bmsgb2YuDQpJIGRpZCBoYXZlIHRoZSBzYW1lIHNpdHVhdGlvbiBleGNlcHQgaW4gbXkgY2FzZSBJ IHdhcyB0YXhpaW5nIGFjcm9zcyBhIGdyYXNzIHN0cmlwIHRvIGdldCB0byBydW53YXkgYW5kIEkg d2VudCBpbnRvIGEgc2xpZ2h0IGRpdGNoIHRoYXQgd2FzIGVub3VnaCB0byBjYXVzZSB0aGUgZmFp cmluZyB0byBjcmFjay4NCllvdXIgcGljdHVyZSBsb29rcyBsaWtlIGEgZmFpcmluZyB0aGF0IHdh cyBjcmFja2VkIGR1ZSB0byBhIGhlYXZ5IGxhbmRpbmcgYW5kIHRpcmVzIGhpdHRpbmcgaXQuIElz IGhlIHN1cmUgaXQgd2FzbuKAmXQgdGhpcyB3YXkgYmVmb3JlIGhlIGhlYXJkIHRoYXQgbm9pc2U/ IEFzIGZvciBjbGVhcmFuY2UgaXQgbmVlZHMgdG8gYmUgYWJvdXQgwrwgaW5jaCBvciBtb3JlIGF3 YXkgZnJvbSB0aXJlIHRvIGJlIGZpbmUuDQoNCkZyb206IG93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJA bWF0cm9uaWNzLmNvbSBbbWFpbHRvOm93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNv bV0gT24gQmVoYWxmIE9mIFNoYW5ub24gSGlja3MNClNlbnQ6IEZyaWRheSwgT2N0b2JlciAxNCwg MjAxNiAxMTozMyBBTQ0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSVjEw LUxpc3Q6IFdlaXJkIEJyb2tlbiBXaGVlbCBQYW50DQoNCg0KVGhlIG90aGVyIGRheSwgbXkgYnVk ZHkgd2FzIHB1c2hpbmcgdGhlIDEwIGJhY2sgaW50byB0aGUgaGFuZ2VyIHdoZW4gaGUgaGVhcmQg YSBjcmFja2luZyBzb3VuZCBmcm9tIHRoZSBsZWZ0IG1haW4gd2hlZWwgcGFudC4gKFNlZSBhdHRh Y2hlZCkgV2UgY2hlY2tlZCB0aGUgY2xlYXJhbmNlIGZyb20gdGhlIHRpcmUgYW5kIGl0IHdhcyBm aW5lIGFuZCB0aGUgV1Agd2FzIHN0aWxsIHZlcnkgZmlybWx5IGF0dGFjaGVkLiAgVGlyZSBwcmVz c3VyZSB3YXMgYWxzbyBnb29kLg0KDQpBbnkgaWRlYXMgb24gd2hhdCBtYXkgaGF2ZSBjYXVzZWQg dGhpcz8NCg0KU2hhbm5vbg0K ________________________________________________________________________________
Date: Oct 14, 2016
The wheel pants were off for condition inspection just 3 weeks ago and there was no sign of damage and we have about 1/2" of gap between the tire and WP at this point. I can't imagine how hard of a landing it would take to bulge the aft portion of the tire 1/2". We are hangered at EFD so have smoothish asphalt everywhere.... Shannon On Oct 14, 2016 2:02 PM, "P Reid" wrote: > Unless his hangar has potholes there is nothing I can think of. > > I did have the same situation except in my case I was taxiing across a > grass strip to get to runway and I went into a slight ditch that was enou gh > to cause the fairing to crack. > > Your picture looks like a fairing that was cracked due to a heavy landing > and tires hitting it. Is he sure it wasn=99t this way before he hea rd that > noise? As for clearance it needs to be about =C2=BC inch or more away fro m tire > to be fine. > > > *From:* owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list- > server(at)matronics.com] *On Behalf Of *Shannon Hicks > *Sent:* Friday, October 14, 2016 11:33 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Weird Broken Wheel Pant > > > The other day, my buddy was pushing the 10 back into the hanger when he > heard a cracking sound from the left main wheel pant. (See attached) We > checked the clearance from the tire and it was fine and the WP was still > very firmly attached. Tire pressure was also good. > > Any ideas on what may have caused this? > > Shannon > ________________________________________________________________________________
Subject: Re: Weird Broken Wheel Pant
Date: Oct 14, 2016
The damage does appear to be from the tire. The reason I say that is the break down the middle and the oval breaks around the outside. Also notice a black mark to the left of the center crack at the wheel cutout. How it got there .... I haven't got a clue. Linn ....... might have been an accident investigator in a previous life On 10/14/2016 2:32 PM, Shannon Hicks wrote: > > The other day, my buddy was pushing the 10 back into the hanger when > he heard a cracking sound from the left main wheel pant. (See > attached) We checked the clearance from the tire and it was fine and > the WP was still very firmly attached. Tire pressure was also good. > > Any ideas on what may have caused this? > > Shannon > ________________________________________________________________________________
Date: Oct 14, 2016
So, I think I may have figured this one out. I recently spent a week at another airport and the FBO had to park me in a remote location. When I showed up to leave they had chocks on the pilot side main gear. I think they may have been too tall and point loaded the rear part of the WP. I never noticed since in was on the underside. Does that sound plausible? Shannon On Oct 14, 2016 2:08 PM, "Shannon Hicks" wrote: > The wheel pants were off for condition inspection just 3 weeks ago and > there was no sign of damage and we have about 1/2" of gap between the tir e > and WP at this point. I can't imagine how hard of a landing it would take > to bulge the aft portion of the tire 1/2". > > We are hangered at EFD so have smoothish asphalt everywhere.... > > Shannon > > On Oct 14, 2016 2:02 PM, "P Reid" wrote: > >> Unless his hangar has potholes there is nothing I can think of. >> >> I did have the same situation except in my case I was taxiing across a >> grass strip to get to runway and I went into a slight ditch that was eno ugh >> to cause the fairing to crack. >> >> Your picture looks like a fairing that was cracked due to a heavy landin g >> and tires hitting it. Is he sure it wasn=99t this way before he he ard that >> noise? As for clearance it needs to be about =C2=BC inch or more away fr om tire >> to be fine. >> >> >> >> *From:* owner-rv10-list-server(at)matronics.com [mailto: >> owner-rv10-list-server(at)matronics.com] *On Behalf Of *Shannon Hicks >> *Sent:* Friday, October 14, 2016 11:33 AM >> *To:* rv10-list(at)matronics.com >> *Subject:* RV10-List: Weird Broken Wheel Pant >> >> >> >> The other day, my buddy was pushing the 10 back into the hanger when he >> heard a cracking sound from the left main wheel pant. (See attached) We >> checked the clearance from the tire and it was fine and the WP was still >> very firmly attached. Tire pressure was also good. >> >> Any ideas on what may have caused this? >> >> Shannon >> > ________________________________________________________________________________
Date: Oct 14, 2016
Yes, they're Cleveland. However I have a tube with 90* stem in my shop that has the offset to fit the straight stem wheel. It would point to the outside of the wheel, not parallel with the axle. I think the tubes I have came from Desser, but were not the Leak Guard. The stem is in the center of the inside of the tube, and when mounted the stem is naturally parallel to the axle, so that drove my mod. Linn On 10/14/2016 2:48 PM, Tim Olson wrote: > > Yes, same holes. You have Cleveland? > That's what mine are. > Tim > >> On Oct 14, 2016, at 1:27 PM, Linn Walters wrote: >> >> >> Tim, I had to machine both my mains. That might be due to the tube manufacturer being different. I'm guessing from your post that you used the same hole as the straight stem?? >> Linn >> >>> On 10/14/2016 2:16 PM, Tim Olson wrote: >>> >>> I had 2 tubes fail from Desser, not all that many flying hours apart, >>> also. But, mine weren't the 90 degree valve stem tubes. >>> One of them was a pinhole leak that just came out of nowhere. >>> The other was a leak that was along a little slice-like >>> scrape, that I have no idea how it got there. Admittedly, >>> I didn't thoroughly inspect the tube when I pulled it out of >>> the bag. I wasn't happy in either case. >>> >>> Both wheels now have new-ish 90 degree stem tubes in them. >>> I've always run my pressues at the standard 42/40 rear/front >>> pressures that Van's put in the original manual, however I >>> think I will start raising the pressure slightly just >>> because we have such large temperature swings here, so if >>> I check them in the fall I'll go maybe 48. >>> >>> Linn, I think you're mistaking his issue for the nosewheel >>> tube. Yes, on that one Van's sends the wrong wheel, and >>> then they have to re-machine the hole on the other side, >>> and all the things you said. But he's talking about the >>> 15/6.00-6 main tubes. Those don't require any drilling >>> or anything else. >>> >>> Other than these 2 tubes, I've had good luck over the past >>> 10 years. I've replaced tires a few times and always put in >>> new tubes. So I'm not sure I'm ready to ditch them >>> yet. I WOULD be interested to see what the BEST tube >>> available is. I would prefer to buy a US made tube if >>> at all possible, and would pay a small premium for that >>> ability if it's a quality tube. >>> >>> Tim >>> >>> >>>> On 10/14/2016 11:54 AM, AirMike wrote: >>>> >>>> After struggling with the straight tube OEM Vans inner tube, I >>>> decided to go to the Aero Classic from Desser Tire TU15/600-6. My >>>> experience with this tube has been awful. I went to this tube due to >>>> the nice 90 degree bend in the stem that allows easier filling with >>>> air. By removing a small bit of metal on the wheel bearing cover, you >>>> can easily fill this tube with air. My left side failed after only 6 >>>> weeks leaving me with a flat tire when I was ready to dispatch the >>>> plane for an important flight. Since I was inside of 90 days, Desser >>>> gave me an RMA and I got a credit (not refund) on the defective tube. >>>> My second tube failed just this last week after about 5 months of >>>> flying. These tubes (made in Thailand) are just no good. I >>>> reinstalled my old Vans tube on the new Michelin tire on the left >>>> side, but I have yet to put the old tube back on the right side. >>>> These tubes are just crap. Any suggestions or comments on this issue >>>> will be appreciated. >>>> >>>> -------- See you OSH '15 Q/B - flying 6 yrs. >>>> >>>> >>>> >>> >>> >>> >>> >>> >> >> >> >> > > ________________________________________________________________________________
Date: Oct 14, 2016
Plausible! I would think the lineboy (or linegirl :-)) would have heard it crack though and didn't want to get into trouble. I've never let anyone else park and tie down my plane and I have always carried 1 1/2" aluminum angle for chocks. I also hold the hose when refueling. Linn On 10/14/2016 3:20 PM, Shannon Hicks wrote: > > So, I think I may have figured this one out. I recently spent a week > at another airport and the FBO had to park me in a remote location. > When I showed up to leave they had chocks on the pilot side main gear. > I think they may have been too tall and point loaded the rear part of > the WP. I never noticed since in was on the underside. > > Does that sound plausible? > > Shannon > > > On Oct 14, 2016 2:08 PM, "Shannon Hicks" > wrote: > > The wheel pants were off for condition inspection just 3 weeks ago > and there was no sign of damage and we have about 1/2" of gap > between the tire and WP at this point. I can't imagine how hard of > a landing it would take to bulge the aft portion of the tire 1/2". > > We are hangered at EFD so have smoothish asphalt everywhere.... > > Shannon > > > On Oct 14, 2016 2:02 PM, "P Reid" > wrote: > > Unless his hangar has potholes there is nothing I can think of. > > I did have the same situation except in my case I was taxiing > across a grass strip to get to runway and I went into a slight > ditch that was enough to cause the fairing to crack. > > Your picture looks like a fairing that was cracked due to a > heavy landing and tires hitting it. Is he sure it wasnt this > way before he heard that noise? As for clearance it needs to > be about inch or more away from tire to be fine. > > *From:*owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com > ] *On Behalf Of > *Shannon Hicks > *Sent:* Friday, October 14, 2016 11:33 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Weird Broken Wheel Pant > > The other day, my buddy was pushing the 10 back into the > hanger when he heard a cracking sound from the left main wheel > pant. (See attached) We checked the clearance from the tire > and it was fine and the WP was still very firmly attached. > Tire pressure was also good. > > Any ideas on what may have caused this? > > Shannon > ________________________________________________________________________________
Date: Oct 14, 2016
WWVzLCB5b3VyIMK9IGlzIHBsZW50eSBzbyB0aGF0IHdhc27igJl0IGl0IG9uIGxhbmRpbmcsIGp1 c3QgbGlrZSBteSBwb3Rob2xlLCBwdXR0aW5nIHByZXNzdXJlIG9uIHRoZSBXQiBieSBhIGNob2Nr IGNvdWxkIGRvIHRoaXMuIEkgY2FuIHNlZSBmb3Igc3VyZSB0aGF0IGEgY2hvY2sgY291bGQgYmUg dG9vIHRhbGw7IHRoZSBwbGFuZSBtYXkgaGF2ZSByb2xsZWQgYmFjayBhbmQgdGhlIHdlaWdodCB3 b3VsZCBhYnNvbHV0ZWx5IGNhdXNlIHRoaXMuIExvb2tzIGxpa2UgdGhlIHByZXNzdXJlIHdhcyBy aWdodCBiZWxvdyB0aGUgZHJhaW4gaG9sZS4gSSBoYXZlIG15IG93biBBbmdsZSB0byBzZXJ2ZSBh cyBjaG9ja3MsIHRoZXkgZml0IHRpZ2h0bHkgYW5kIGFjY29tcGxpc2ggdGhlIOKAnG5vIG1vdmXi gJ0gZ29hbC4NCg0KSSB3YXMgdG90YWxseSBraWRkaW5nIGFib3V0IHRoZSBwb3Rob2xlIGluIHlv dXIgaGFuZ2FyLCBidXQgcm9sbGluZyBhIHBsYW5lIGJhY2sgaW50byBhIGhhbmdhciB3b3VsZG7i gJl0IGNhdXNlIHRoaXMgbXVjaCBkYW1hZ2UgdW5sZXNzIHRoZSB3aGVlbCBwYW50IOKAnHNhdOKA nSBvbiBzb21ldGhpbmcgYWZ0ZXIgYmVpbmcgZHJvcHBlZCAoYWthIHdvb2QgYmxvY2tzIGhvbGRp bmcgdXAgZ2VhciBhbmQgaXQgc2xpcHBpbmcgb2ZmIG9udG8gdGhlIGJsb2Nrcy4NCkkgdGhpbmsg eW91IGhhdmUgdGhpcyBvbmUgc29sdmVkIGhvd2V2ZXIuDQpFYXN5IGZpeC0gMiBwbHkgb24gb3V0 c2lkZSwgZmxveCBvbiBjcmFja3Mgd2lsbCBlYXNpbHkgcmVzb2x2ZSB0aGUgaXNzdWUgd2l0aCBw bGVudHkgb2Ygc3RyZW5ndGggYW5kIGVhc3kgdG8gcmVwYWludCBzaW5jZSBubyBvbmUgc2VlcyBp dCENClBhc2NhbA0KRnJvbTogb3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFtt YWlsdG86b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2Yg U2hhbm5vbiBIaWNrcw0KU2VudDogRnJpZGF5LCBPY3RvYmVyIDE0LCAyMDE2IDEyOjIxIFBNDQpU bzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6IFJFOiBSVjEwLUxpc3Q6IFdlaXJk IEJyb2tlbiBXaGVlbCBQYW50DQoNCg0KU28sIEkgdGhpbmsgSSBtYXkgaGF2ZSBmaWd1cmVkIHRo aXMgb25lIG91dC4gSSByZWNlbnRseSBzcGVudCBhIHdlZWsgYXQgYW5vdGhlciBhaXJwb3J0IGFu ZCB0aGUgRkJPIGhhZCB0byBwYXJrIG1lIGluIGEgcmVtb3RlIGxvY2F0aW9uLiAgV2hlbiBJIHNo b3dlZCB1cCB0byBsZWF2ZSB0aGV5IGhhZCBjaG9ja3Mgb24gdGhlIHBpbG90IHNpZGUgbWFpbiBn ZWFyLiBJIHRoaW5rIHRoZXkgbWF5IGhhdmUgYmVlbiB0b28gdGFsbCBhbmQgcG9pbnQgbG9hZGVk IHRoZSByZWFyIHBhcnQgb2YgdGhlIFdQLiBJIG5ldmVyIG5vdGljZWQgc2luY2UgaW4gd2FzIG9u IHRoZSB1bmRlcnNpZGUuDQoNCkRvZXMgdGhhdCBzb3VuZCBwbGF1c2libGU/DQoNClNoYW5ub24N Cg0KT24gT2N0IDE0LCAyMDE2IDI6MDggUE0sICJTaGFubm9uIEhpY2tzIiA8Y2l2ZW5nMTIzQGdt YWlsLmNvbTxtYWlsdG86Y2l2ZW5nMTIzQGdtYWlsLmNvbT4+IHdyb3RlOg0KDQpUaGUgd2hlZWwg cGFudHMgd2VyZSBvZmYgZm9yIGNvbmRpdGlvbiBpbnNwZWN0aW9uIGp1c3QgMyB3ZWVrcyBhZ28g YW5kIHRoZXJlIHdhcyBubyBzaWduIG9mIGRhbWFnZSBhbmQgd2UgaGF2ZSBhYm91dCAxLzIiIG9m IGdhcCBiZXR3ZWVuIHRoZSB0aXJlIGFuZCBXUCBhdCB0aGlzIHBvaW50LiBJIGNhbid0IGltYWdp bmUgaG93IGhhcmQgb2YgYSBsYW5kaW5nIGl0IHdvdWxkIHRha2UgdG8gYnVsZ2UgdGhlIGFmdCBw b3J0aW9uIG9mIHRoZSB0aXJlIDEvMiIuDQoNCldlIGFyZSBoYW5nZXJlZCBhdCBFRkQgc28gaGF2 ZSBzbW9vdGhpc2ggIGFzcGhhbHQgZXZlcnl3aGVyZS4uLi4NCg0KU2hhbm5vbg0KDQpPbiBPY3Qg MTQsIDIwMTYgMjowMiBQTSwgIlAgUmVpZCIgPHJ2MTBmbHllckBsaXZlLmNvbTxtYWlsdG86cnYx MGZseWVyQGxpdmUuY29tPj4gd3JvdGU6DQpVbmxlc3MgaGlzIGhhbmdhciBoYXMgcG90aG9sZXMg dGhlcmUgaXMgbm90aGluZyBJIGNhbiB0aGluayBvZi4NCkkgZGlkIGhhdmUgdGhlIHNhbWUgc2l0 dWF0aW9uIGV4Y2VwdCBpbiBteSBjYXNlIEkgd2FzIHRheGlpbmcgYWNyb3NzIGEgZ3Jhc3Mgc3Ry aXAgdG8gZ2V0IHRvIHJ1bndheSBhbmQgSSB3ZW50IGludG8gYSBzbGlnaHQgZGl0Y2ggdGhhdCB3 YXMgZW5vdWdoIHRvIGNhdXNlIHRoZSBmYWlyaW5nIHRvIGNyYWNrLg0KWW91ciBwaWN0dXJlIGxv b2tzIGxpa2UgYSBmYWlyaW5nIHRoYXQgd2FzIGNyYWNrZWQgZHVlIHRvIGEgaGVhdnkgbGFuZGlu ZyBhbmQgdGlyZXMgaGl0dGluZyBpdC4gSXMgaGUgc3VyZSBpdCB3YXNu4oCZdCB0aGlzIHdheSBi ZWZvcmUgaGUgaGVhcmQgdGhhdCBub2lzZT8gQXMgZm9yIGNsZWFyYW5jZSBpdCBuZWVkcyB0byBi ZSBhYm91dCDCvCBpbmNoIG9yIG1vcmUgYXdheSBmcm9tIHRpcmUgdG8gYmUgZmluZS4NCg0KRnJv bTogb3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tPG1haWx0bzpvd25lci1ydjEw LWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20+IFttYWlsdG86b3duZXItcnYxMC1saXN0LXNlcnZl ckBtYXRyb25pY3MuY29tPG1haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5j b20+XSBPbiBCZWhhbGYgT2YgU2hhbm5vbiBIaWNrcw0KU2VudDogRnJpZGF5LCBPY3RvYmVyIDE0 LCAyMDE2IDExOjMzIEFNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnJ2MTAt bGlzdEBtYXRyb25pY3MuY29tPg0KU3ViamVjdDogUlYxMC1MaXN0OiBXZWlyZCBCcm9rZW4gV2hl ZWwgUGFudA0KDQoNClRoZSBvdGhlciBkYXksIG15IGJ1ZGR5IHdhcyBwdXNoaW5nIHRoZSAxMCBi YWNrIGludG8gdGhlIGhhbmdlciB3aGVuIGhlIGhlYXJkIGEgY3JhY2tpbmcgc291bmQgZnJvbSB0 aGUgbGVmdCBtYWluIHdoZWVsIHBhbnQuIChTZWUgYXR0YWNoZWQpIFdlIGNoZWNrZWQgdGhlIGNs ZWFyYW5jZSBmcm9tIHRoZSB0aXJlIGFuZCBpdCB3YXMgZmluZSBhbmQgdGhlIFdQIHdhcyBzdGls bCB2ZXJ5IGZpcm1seSBhdHRhY2hlZC4gIFRpcmUgcHJlc3N1cmUgd2FzIGFsc28gZ29vZC4NCg0K QW55IGlkZWFzIG9uIHdoYXQgbWF5IGhhdmUgY2F1c2VkIHRoaXM/DQoNClNoYW5ub24NCg= ________________________________________________________________________________
Date: Oct 14, 2016
That makes sense =93 I carry my own made of PVC From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Shannon Hicks Sent: Friday, October 14, 2016 3:21 PM Subject: RE: RV10-List: Weird Broken Wheel Pant So, I think I may have figured this one out. I recently spent a week at another airport and the FBO had to park me in a remote location. When I showed up to leave they had chocks on the pilot side main gear. I think they may have been too tall and point loaded the rear part of the WP. I never noticed since in was on the underside. Does that sound plausible? Shannon On Oct 14, 2016 2:08 PM, "Shannon Hicks" > wrote: The wheel pants were off for condition inspection just 3 weeks ago and there was no sign of damage and we have about 1/2" of gap between the tire and WP at this point. I can't imagine how hard of a landing it would take to bulge the aft portion of the tire 1/2". We are hangered at EFD so have smoothish asphalt everywhere.... Shannon On Oct 14, 2016 2:02 PM, "P Reid" > wrote: Unless his hangar has potholes there is nothing I can think of. I did have the same situation except in my case I was taxiing across a grass strip to get to runway and I went into a slight ditch that was enough to cause the fairing to crack. Your picture looks like a fairing that was cracked due to a heavy landing and tires hitting it. Is he sure it wasn=99t this way before he heard that noise? As for clearance it needs to be about =C2=BC inch or more away from tire to be fine. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com ] On Behalf Of Shannon Hicks Sent: Friday, October 14, 2016 11:33 AM Subject: RV10-List: Weird Broken Wheel Pant The other day, my buddy was pushing the 10 back into the hanger when he heard a cracking sound from the left main wheel pant. (See attached) We checked the clearance from the tire and it was fine and the WP was still very firmly attached. Tire pressure was also good. Any ideas on what may have caused this? Shannon ________________________________________________________________________________
Date: Oct 14, 2016
You think 1/2" is plenty? I personally don't think so. I'd go with more like 5/8-3/4" Tim On 10/14/2016 2:37 PM, P Reid wrote: > Yes, your is plenty so that wasnt it on landing, just like my > pothole, putting pressure on the WB by a chock could do this. I can see > for sure that a chock could be too tall; the plane may have rolled back > and the weight would absolutely cause this. Looks like the pressure was > right below the drain hole. I have my own Angle to serve as chocks, they > fit tightly and accomplish the no move goal. > > > I was totally kidding about the pothole in your hangar, but rolling a > plane back into a hangar wouldnt cause this much damage unless the > wheel pant sat on something after being dropped (aka wood blocks > holding up gear and it slipping off onto the blocks. > > I think you have this one solved however. > > Easy fix- 2 ply on outside, flox on cracks will easily resolve the issue > with plenty of strength and easy to repaint since no one sees it! > > Pascal > ________________________________________________________________________________
Date: Oct 14, 2016
Tim, I'm redoing the fiberglass now, so will look at the gap. Thanks for the tip. On Oct 14, 2016 3:23 PM, "Tim Olson" wrote: > > You think 1/2" is plenty? I personally don't think so. I'd go with more > like 5/8-3/4" > > Tim > > On 10/14/2016 2:37 PM, P Reid wrote: > >> Yes, your =C2=BD is plenty so that wasn=99t it on landing, just li ke my >> pothole, putting pressure on the WB by a chock could do this. I can see >> for sure that a chock could be too tall; the plane may have rolled back >> and the weight would absolutely cause this. Looks like the pressure was >> right below the drain hole. I have my own Angle to serve as chocks, they >> fit tightly and accomplish the =9Cno move=9D goal. >> >> >> >> I was totally kidding about the pothole in your hangar, but rolling a >> plane back into a hangar wouldn=99t cause this much damage unless the >> wheel pant =9Csat=9D on something after being dropped (aka w ood blocks >> holding up gear and it slipping off onto the blocks. >> >> I think you have this one solved however. >> >> Easy fix- 2 ply on outside, flox on cracks will easily resolve the issue >> with plenty of strength and easy to repaint since no one sees it! >> >> Pascal >> >> =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Oct 14, 2016
I did not put a new hole in the rim as the tube stem lined up fine when installed. The leak on the left tube that I returned to Desser was in the side wall of the tube. There was no abrasion on the tube, but it appeared as a "casting" flaw in the tube where the leak originated. I have not taken the leaking right tire tube off yet to diagnose the issue. Desser will not give me a refund after 90 days. Has anyone ever used that slime stuff to stop a leak?? -------- See you OSH '15 Q/B - flying 6 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461285#461285 ________________________________________________________________________________
Date: Oct 14, 2016
I contemplated the slime thing when I was AOG recently. I'm split on what to do. On one hand, it could work. On the other, if it leaks out of the tube you'll have a mess inside your tire and you probably will plan to re-use the tire. So that would kind of suck. On the other hand, if you're stuck out in the boonies and have no jack, the slime could be a quick fix. On the 3rd hand (must be an octopus)... If you did use slime, there are caveats. One being you have to roll the tire to distribute it. Not a big deal if you have a jack but if not it wouldn't be convenient. Also, you'd want to let it sit for a good amount of time to ensure it indeed was holding. Otherwise, your next experience with that tire is going to be when you land somewhere...not the time to have an issue. I would feel comfortable with an actual tube patch, and now I carry multiple tube patches in each plane. 2 tubes of cement, and about 5 patches. I never want to be stuck due to a tube again. Personally I'd only use the slime in an airplane as a last resort, but in a car I'd perhaps consider it quicker. Tim On 10/14/2016 3:51 PM, AirMike wrote: > > I did not put a new hole in the rim as the tube stem lined up fine > when installed. The leak on the left tube that I returned to Desser > was in the side wall of the tube. There was no abrasion on the tube, > but it appeared as a "casting" flaw in the tube where the leak > originated. I have not taken the leaking right tire tube off yet to > diagnose the issue. Desser will not give me a refund after 90 days. > Has anyone ever used that slime stuff to stop a leak?? > > -------- See you OSH '15 Q/B - flying 6 yrs. > > ________________________________________________________________________________
Date: Oct 14, 2016
Good thoughts on the subject. Gotta get my patch kit. Yes, you definitely want to turn the tire to distribute the material. Another thought is that if you cannot spin the tire vigorously as in jacking and spinning then you want to taxi quite a bit to distribute the stuff and see that it covers the interior of the tube. In the mean time, it looks like "Aero Classics" has changed vendors and the QC is not so great, or that I just got a bum batch. Either way, it is a pain to mess around with the tires that much after spending $400 on new mounts. PS did you or anyone else put air access doors in their wheel pants? -------- See you OSH '15 Q/B - flying 6 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461289#461289 ________________________________________________________________________________
Date: Oct 14, 2016
I didn't yet but am interested now. Jesse, you had a cirrus part that looked good. Any pics or details on that? Tim > On Oct 14, 2016, at 4:27 PM, AirMike wrote: > > > Good thoughts on the subject. Gotta get my patch kit. Yes, you definitely want to turn the tire to distribute the material. > > Another thought is that if you cannot spin the tire vigorously as in jacking and spinning then you want to taxi quite a bit to distribute the stuff and see that it covers the interior of the tube. > > In the mean time, it looks like "Aero Classics" has changed vendors and the QC is not so great, or that I just got a bum batch. Either way, it is a pain to mess around with the tires that much after spending $400 on new mounts. > > PS did you or anyone else put air access doors in their wheel pants? > > -------- > See you OSH '15 > Q/B - flying 6 yrs. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461289#461289 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 14, 2016
Any cirrus parts house (service center) will sell you a plastic wheel pant plug. It's 2" in diameter and made out if white plastic. It can be painted. Center of the hole works well 2-2.5" aft of the axle screw and 1/2" down. Pretty simple mod. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 Sent from my iPhone > On Oct 14, 2016, at 6:01 PM, Tim Olson wrote: > > > I didn't yet but am interested now. > Jesse, you had a cirrus part that looked good. Any pics or details on that? > Tim > >> On Oct 14, 2016, at 4:27 PM, AirMike wrote: >> >> >> Good thoughts on the subject. Gotta get my patch kit. Yes, you definitely want to turn the tire to distribute the material. >> >> Another thought is that if you cannot spin the tire vigorously as in jacking and spinning then you want to taxi quite a bit to distribute the stuff and see that it covers the interior of the tube. >> >> In the mean time, it looks like "Aero Classics" has changed vendors and the QC is not so great, or that I just got a bum batch. Either way, it is a pain to mess around with the tires that much after spending $400 on new mounts. >> >> PS did you or anyone else put air access doors in their wheel pants? >> >> -------- >> See you OSH '15 >> Q/B - flying 6 yrs. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=461289#461289 >> >> >> >> >> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Oct 14, 2016
I used this: http://www.aircraftspruce.com/pages/lg/wheel_wheelaccess/accessdoors.php I paint a line on the tire such that when the line is pointed to the ground the door lines up with the air valve. You need to have an extension like this: http://www.cleavelandtool.com/5-Valve-Stem-Extension/productinfo/VSE5/#.WAFj s-grKUk Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: Friday, October 14, 2016 6:35 PM Subject: Re: RV10-List: Re: Aero Classic Leak guard inner tubes - do not purchase Any cirrus parts house (service center) will sell you a plastic wheel pant plug. It's 2" in diameter and made out if white plastic. It can be painted. Center of the hole works well 2-2.5" aft of the axle screw and 1/2" down. Pretty simple mod. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 Sent from my iPhone > On Oct 14, 2016, at 6:01 PM, Tim Olson wrote: > > > I didn't yet but am interested now. > Jesse, you had a cirrus part that looked good. Any pics or details on that? > Tim > >> On Oct 14, 2016, at 4:27 PM, AirMike wrote: >> >> >> Good thoughts on the subject. Gotta get my patch kit. Yes, you definitely want to turn the tire to distribute the material. >> >> Another thought is that if you cannot spin the tire vigorously as in jacking and spinning then you want to taxi quite a bit to distribute the stuff and see that it covers the interior of the tube. >> >> In the mean time, it looks like "Aero Classics" has changed vendors and the QC is not so great, or that I just got a bum batch. Either way, it is a pain to mess around with the tires that much after spending $400 on new mounts. >> >> PS did you or anyone else put air access doors in their wheel pants? >> >> -------- >> See you OSH '15 >> Q/B - flying 6 yrs. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=461289#461289 >> >> >> >> >> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Oct 14, 2016
I'll chime in and offer up what Mark Cooper did. Here's his blog entry about it. https://myrv10factory.wordpress.com/2014/02/04/wheel-pant-modification-cowl- hinge-pin-retainer-and-an-unexpected-surprise/ More pics here. https://myrv10factory.wordpress.com/2014/02/05/wheel-pants-are-wrapped-up-pr eparing-cowling-and-additional-fiberglass-finese/ -Ben -----Original Message----- Good thoughts on the subject. Gotta get my patch kit. Yes, you definitely want to turn the tire to distribute the material. Another thought is that if you cannot spin the tire vigorously as in jacking and spinning then you want to taxi quite a bit to distribute the stuff and see that it covers the interior of the tube. In the mean time, it looks like "Aero Classics" has changed vendors and the QC is not so great, or that I just got a bum batch. Either way, it is a pain to mess around with the tires that much after spending $400 on new mounts. PS did you or anyone else put air access doors in their wheel pants? -------- See you OSH '15 Q/B - flying 6 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461289#461289 ________________________________________________________________________________
Date: Oct 14, 2016
I converted my straight valve stem to 90*. I had to modify the wheel but there are tubes out there that use the same hole as the straight stem. I ordered 6 1/2" extensions from http://www.eezrvproduct.com/ ...... $6 ea. A 3/8 hole in the wheelpant for access and a plastic plug to cover the hole. A spot of paint on the inside of the tire when the stem is lined up with the hole makes it easy to line up. Linn On 10/14/2016 5:27 PM, AirMike wrote: > > Good thoughts on the subject. Gotta get my patch kit. Yes, you definitely want to turn the tire to distribute the material. > > Another thought is that if you cannot spin the tire vigorously as in jacking and spinning then you want to taxi quite a bit to distribute the stuff and see that it covers the interior of the tube. > > In the mean time, it looks like "Aero Classics" has changed vendors and the QC is not so great, or that I just got a bum batch. Either way, it is a pain to mess around with the tires that much after spending $400 on new mounts. > > PS did you or anyone else put air access doors in their wheel pants? > > -------- > See you OSH '15 > Q/B - flying 6 yrs. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461289#461289 > > ________________________________________________________________________________
Date: Oct 14, 2016
I have to think you got a bad pair of tubes. I bought the exact tubes that were recommended on Tim's web page, probably around 3 years ago when I was mounting the gear legs. They are the Desser Leakguard variety, inside Desser standard recaps. I have been flying since April, and most add air every 6 wks or so, which is aggravated by our major temp changes. I suppose I should get a patch kit to put in the airplane spares kit. -sent from the I-droid implanted in my forearm On Fri, Oct 14, 2016 at 11:48 AM, Tim Olson wrote: > > Yes, same holes. You have Cleveland? > That's what mine are. > Tim > > > On Oct 14, 2016, at 1:27 PM, Linn Walters wrote: > > > > > > Tim, I had to machine both my mains. That might be due to the tube > manufacturer being different. I'm guessing from your post that you used > the same hole as the straight stem?? > > Linn > > > >> On 10/14/2016 2:16 PM, Tim Olson wrote: > >> > >> I had 2 tubes fail from Desser, not all that many flying hours apart, > >> also. But, mine weren't the 90 degree valve stem tubes. > >> One of them was a pinhole leak that just came out of nowhere. > >> The other was a leak that was along a little slice-like > >> scrape, that I have no idea how it got there. Admittedly, > >> I didn't thoroughly inspect the tube when I pulled it out of > >> the bag. I wasn't happy in either case. > >> > >> Both wheels now have new-ish 90 degree stem tubes in them. > >> I've always run my pressues at the standard 42/40 rear/front > >> pressures that Van's put in the original manual, however I > >> think I will start raising the pressure slightly just > >> because we have such large temperature swings here, so if > >> I check them in the fall I'll go maybe 48. > >> > >> Linn, I think you're mistaking his issue for the nosewheel > >> tube. Yes, on that one Van's sends the wrong wheel, and > >> then they have to re-machine the hole on the other side, > >> and all the things you said. But he's talking about the > >> 15/6.00-6 main tubes. Those don't require any drilling > >> or anything else. > >> > >> Other than these 2 tubes, I've had good luck over the past > >> 10 years. I've replaced tires a few times and always put in > >> new tubes. So I'm not sure I'm ready to ditch them > >> yet. I WOULD be interested to see what the BEST tube > >> available is. I would prefer to buy a US made tube if > >> at all possible, and would pay a small premium for that > >> ability if it's a quality tube. > >> > >> Tim > >> > >> > >>> On 10/14/2016 11:54 AM, AirMike wrote: > >>> > >>> After struggling with the straight tube OEM Vans inner tube, I > >>> decided to go to the Aero Classic from Desser Tire TU15/600-6. My > >>> experience with this tube has been awful. I went to this tube due to > >>> the nice 90 degree bend in the stem that allows easier filling with > >>> air. By removing a small bit of metal on the wheel bearing cover, you > >>> can easily fill this tube with air. My left side failed after only 6 > >>> weeks leaving me with a flat tire when I was ready to dispatch the > >>> plane for an important flight. Since I was inside of 90 days, Desser > >>> gave me an RMA and I got a credit (not refund) on the defective tube. > >>> My second tube failed just this last week after about 5 months of > >>> flying. These tubes (made in Thailand) are just no good. I > >>> reinstalled my old Vans tube on the new Michelin tire on the left > >>> side, but I have yet to put the old tube back on the right side. > >>> These tubes are just crap. Any suggestions or comments on this issue > >>> will be appreciated. > >>> > >>> -------- See you OSH '15 Q/B - flying 6 yrs. > >>> > >>> > >>> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Another windscreen Q
Date: Oct 15, 2016
I used an aluminum windshield fairing, instead of fiberglass. I really like it, and it turned out great. Can't remember the name of the company I bought it from. John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461300#461300 ________________________________________________________________________________
Date: Oct 15, 2016
Disclaimer: I have some slowly seeping rivets on y 20year old 6, but have not yet performed this repair. I have read about it and thought about it quite a bit. Pulling vacuum on the fuel tank is inherently risky, as atmospheric pressure can distort and crease the tank if it should partially collapse. It takes surprisingly little vacuum, I am told, to accomplish this. Since the idea is to create a pressure differential across the leaking area to migrate solvent and Loctite into the area, I believe a suitable and completely safe alternative is to apply local higher pressure to the outside of the tank, instead of pulling vacuum on the inside. A syringe attached to a suction cup, or with the tip cut off to leave a straight cylinder, ringed with a bead of RTV(cured) to allow a press-seal against the tank skin, should suffice to apply gentle pressure. This should let you push the acetone and the green Loctite in without risking any structural damage. Pressure should only be needed for a few seconds, not for the entire Loctite curing time. With a suitable seal on the hose end, you could use the pressure side of your shop vac to accomplish this. My opinion only, FWIW. Bill B On Thu, Oct 13, 2016 at 5:02 PM, Linn Walters wrote: > > The only thing I've heard of to seal really small leaks is green Loctite. > You need to clean the hole with acetone. Pull a small vacuum on the tank > and suck the acetone through the hole .... the more the better ..... and > then let that evaporate. Then apply the loctite so it get sucked into the > hole. > Linn > > > On 10/13/2016 4:41 PM, kearney wrote: > >> >> Hmmm >> >> There I said it! >> >> Anyway, over the past few months I have developed rivet line leaks in >> both my QB tanks along the inboard line of fuel tank rivets on the tank >> bottom. I am hoping that it is the rivets that are leaking and not between >> the flange and the bottom tank skin. Is there something special about how >> these inboard flanges are sealed that makes them prone to leaks. >> >> To date my only leaks have been on the rivets on the top of the tanks. >> >> If the leak(s) are between the skin and the flange, is there a good (and >> simple) way to correct the problem? >> >> Cheers >> >> Les >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=461241#461241 >> >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Oct 15, 2016
sportav8r(at)gmail.com wrote: > Disclaimer: I have some slowly seeping rivets on y 20year old 6, but have not yet performed this repair. I have read about it and thought about it quite a bit. > > Pulling vacuum on the fuel tank is inherently risky, as atmospheric pressure can distort and crease the tank if it should partially collapse. It takes surprisingly little vacuum, I am told, to accomplish this. > > > Since the idea is to create a pressure differential across the leaking area to migrate solvent and Loctite into the area, I believe a suitable and completely safe alternative is to apply local higher pressure to the outside of the tank, instead of pulling vacuum on the inside. A syringe attached to a suction cup, or with the tip cut off to leave a straight cylinder, ringed with a bead of RTV(cured) to allow a press-seal against the tank skin, should suffice to apply gentle pressure. This should let you push the acetone and the green Loctite in without risking any structural damage. Pressure should only be needed for a few seconds, not for the entire Loctite curing time. With a suitable seal on the hose end, you could use the pressure side of your shop vac to accomplish this. > > > [/quote] This procedure has been used successfully. I first heard about it from Dan Landry who successfully cured seeping rivets on his RV-6 tanks using a syringe as you describe. He used Plio Bond instead of green loctite. I tried this on two long time seeping rivets on my RV-10 last spring prior to the airplane being repainted. It has been successful for me at this time. Airplane repainted in May and so far, no more seeping on the offending rivets. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461303#461303 ________________________________________________________________________________
Subject: Re: I Hate Leaking Fuel Tanks!
Date: Oct 15, 2016
Great thoughts Bill! The more options there are, the better the choice that fits the circumstances. The vacuum method allows you to treat many leaks simultaneously without damage if you're careful. A really slow leak will take longer to see results. Actually, a shop-vac loosely in the fuel filler generates enough 'suction' to get the liquid through the hole. If the drop(s) don't disappear loosely fit a rag around the hose. The drawback is the noise. A Mighty Vac hooked up to the vent line will work also. You'll run out of gripping power before you pull enough vacuum to deform the tank. Either way, if your method of choice starts to deform the tank .... quit! That's too much and unnecessary. Work slowly and carefully. Linn On 10/15/2016 8:57 AM, Bill Boyd wrote: > Disclaimer: I have some slowly seeping rivets on y 20year old 6, but > have not yet performed this repair. I have read about it and thought > about it quite a bit. > > Pulling vacuum on the fuel tank is inherently risky, as atmospheric > pressure can distort and crease the tank if it should partially > collapse. It takes surprisingly little vacuum, I am told, to > accomplish this. > > Since the idea is to create a pressure differential across the leaking > area to migrate solvent and Loctite into the area, I believe a > suitable and completely safe alternative is to apply local higher > pressure to the outside of the tank, instead of pulling vacuum on the > inside. A syringe attached to a suction cup, or with the tip cut off > to leave a straight cylinder, ringed with a bead of RTV(cured) to > allow a press-seal against the tank skin, should suffice to apply > gentle pressure. This should let you push the acetone and the green > Loctite in without risking any structural damage. Pressure should only > be needed for a few seconds, not for the entire Loctite curing time. > With a suitable seal on the hose end, you could use the pressure side > of your shop vac to accomplish this. > > My opinion only, FWIW. > > Bill B > > On Thu, Oct 13, 2016 at 5:02 PM, Linn Walters > wrote: > > > > > The only thing I've heard of to seal really small leaks is green > Loctite. You need to clean the hole with acetone. Pull a small > vacuum on the tank and suck the acetone through the hole .... the > more the better ..... and then let that evaporate. Then apply the > loctite so it get sucked into the hole. > Linn > > > On 10/13/2016 4:41 PM, kearney wrote: > > > > > Hmmm > > There I said it! > > Anyway, over the past few months I have developed rivet line > leaks in both my QB tanks along the inboard line of fuel tank > rivets on the tank bottom. I am hoping that it is the rivets > that are leaking and not between the flange and the bottom > tank skin. Is there something special about how these inboard > flanges are sealed that makes them prone to leaks. > > To date my only leaks have been on the rivets on the top of > the tanks. > > If the leak(s) are between the skin and the flange, is there > a good (and simple) way to correct the problem? > > Cheers > > Les > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461241#461241 > <http://forums.matronics.com/viewtopic.php?p=461241#461241> > > > =================================== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > ________________________________________________________________________________
Date: Oct 15, 2016
Whoaaa, hold that shop-vac! "a shop-vac loosely in the fuel filler" with fuel or just fuel vapors in the tank is a surefire way to blow yourself up... as the vapors travel right through the motor that sparks at the brushes. Lenny flying-nut(at)cfl.rr.com wrote: > Great thoughts Bill! The more options there are, the better the choice that fits the circumstances. The vacuum method allows you to treat many leaks simultaneously without damage if you're careful. A really slow leak will take longer to see results. > > Actually, a shop-vac loosely in the fuel filler generates enough 'suction' to get the liquid through the hole. If the drop(s) don't disappear loosely fit a rag around the hose. The drawback is the noise. > A Mighty Vac hooked up to the vent line will work also. You'll run out of gripping power before you pull enough vacuum to deform the tank. Either way, if your method of choice starts to deform the tank .... quit! That's too much and unnecessary. Work slowly and carefully. > Linn > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461305#461305 ________________________________________________________________________________
Date: Oct 15, 2016
First off, the blowing up shop vac just doesn't happen (myth busters really tried hard to make it happen .... they loved blowing things up!) .... and I give the RV-10 crowd enough intelligence to not work on a tank with fuel in it. However, if you don't feel safe using the shop vac then do things like Bill pointed out. YMMV!!! IMHO, Linn On 10/15/2016 12:14 PM, Lenny Iszak wrote: > > Whoaaa, hold that shop-vac! "a shop-vac loosely in the fuel filler" with fuel or just fuel vapors in the tank is a surefire way to blow yourself up... as the vapors travel right through the motor that sparks at the brushes. > > Lenny > > > flying-nut(at)cfl.rr.com wrote: >> Great thoughts Bill! The more options there are, the better the choice that fits the circumstances. The vacuum method allows you to treat many leaks simultaneously without damage if you're careful. A really slow leak will take longer to see results. >> >> Actually, a shop-vac loosely in the fuel filler generates enough 'suction' to get the liquid through the hole. If the drop(s) don't disappear loosely fit a rag around the hose. The drawback is the noise. >> A Mighty Vac hooked up to the vent line will work also. You'll run out of gripping power before you pull enough vacuum to deform the tank. Either way, if your method of choice starts to deform the tank .... quit! That's too much and unnecessary. Work slowly and carefully. >> Linn >> >> > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461305#461305 > > ________________________________________________________________________________
Date: Oct 15, 2016
Lenny You are a spoil sport. I was looking forward to a big bang event! Actually, if I was going to pull a vacuum, I would use a shop vac attached to my compressor. On of those small compressed air vacs used when building. I said "if" because I wouldn't try to pull a vacuum as too much negative pressure would quickly collapse the tank - it wouldn't take much. I once say a pic of a heavy walled refinery vessel that collapsed after a hydro test. The water was allowed to drain but the relief valve didn't open so the draining water caused a partial vacuum. Simple pressure physics took over and the vessel was toast. Now what I would be interested in is how to "inject" locktite between the inboard skin and flange if that is what is leaking (rather than the flange rivets). Perhaps RTVing a syringe on to the leaking portion of the seam. Cheers Les [quote="Lenny Iszak"]Whoaaa, hold that shop-vac! "a shop-vac loosely in the fuel filler" with fuel or just fuel vapors in the tank is a surefire way to blow yourself up... as the vapors travel right through the motor that sparks at the brushes. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461306#461306 ________________________________________________________________________________
Date: Oct 15, 2016
Yeah, but, at least the explosion will be in the shop vac, so it probably wouldn't destroy the plane unless the flames also got near the filler opening and caused them to ignite too. So it would only cause serious injury or death, but wouldn't total the airplane necessarily. :) tongue in cheek of course. Tim On 10/15/2016 11:14 AM, Lenny Iszak wrote: > > Whoaaa, hold that shop-vac! "a shop-vac loosely in the fuel filler" with fuel or just fuel vapors in the tank is a surefire way to blow yourself up... as the vapors travel right through the motor that sparks at the brushes. > > Lenny > > > flying-nut(at)cfl.rr.com wrote: >> Great thoughts Bill! The more options there are, the better the choice that fits the circumstances. The vacuum method allows you to treat many leaks simultaneously without damage if you're careful. A really slow leak will take longer to see results. >> >> Actually, a shop-vac loosely in the fuel filler generates enough 'suction' to get the liquid through the hole. If the drop(s) don't disappear loosely fit a rag around the hose. The drawback is the noise. >> A Mighty Vac hooked up to the vent line will work also. You'll run out of gripping power before you pull enough vacuum to deform the tank. Either way, if your method of choice starts to deform the tank .... quit! That's too much and unnecessary. Work slowly and carefully. >> Linn >> >> ________________________________________________________________________________
Subject: windshield service life?
Date: Oct 15, 2016
Having owned a C177RG for 29 years I recall only one windshield change. Anyone have any idea about the service life of the windshield as provided by Vans for the RV10? Obviously it will be a pain to replace. David McNeill N46007 8 years and 1100tt --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Plexus and Plexall
Date: Oct 15, 2016
I bought a case of Plexus back in 2007 for about $60 ($7 per can). The current price is a minimum of $15 per can and can range to $20+. I found 37 Plexall at $7 per larger can and going to test it. David McNeill --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: Plexus and Plexall
Date: Oct 15, 2016
There is a two pack of cleaner plus protectant that works very well from Avi ation labs. I pick it up at Oshkosh every year. It comes to about five dolla rs a can and works better than plexus. Usually they are in the south east ha ngar. The cleaner works very well for removing bugs and everything else. It 's worth a shot before anyone stocks up on a case of anything else. Tim > On Oct 15, 2016, at 3:15 PM, David wrote: > > I bought a case of Plexus back in 2007 for about $60 ($7 per can). The cur rent price is a minimum of $15 per can and can range to $20+. I found 37 Ple xall at $7 per larger can and going to test it. > > David McNeill > > > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > ________________________________________________________________________________
Date: Oct 15, 2016
I use LP Aero plastics Got good reviews on aviation consumer Alan n668g Sent from my iPhone > On Oct 15, 2016, at 5:00 PM, Tim Olson wrote: > > There is a two pack of cleaner plus protectant that works very well from A viation labs. I pick it up at Oshkosh every year. It comes to about five dol lars a can and works better than plexus. Usually they are in the south east h angar. The cleaner works very well for removing bugs and everything else. I t's worth a shot before anyone stocks up on a case of anything else. > Tim > >> On Oct 15, 2016, at 3:15 PM, David wrote: >> >> I bought a case of Plexus back in 2007 for about $60 ($7 per can). The cu rrent price is a minimum of $15 per can and can range to $20+. I found 37 Pl exall at $7 per larger can and going to test it. >> >> David McNeill >> >> >> >> This email has been checked for viruses by Avast antivirus software. >> www.avast.com >> >> ________________________________________________________________________________
Subject: Re: windshield service life?
Date: Oct 15, 2016
A lot of it depends on how you treat it. Keep it hangared and clean, and it=99ll last a long time. The windscreen on my RV-6 is 15 years old and in excellent condition. I=99d expect it to go another 15 years, easily. From: David Sent: Saturday, October 15, 2016 4:08 PM Subject: RV10-List: windshield service life? Having owned a C177RG for 29 years I recall only one windshield change. Anyone have any idea about the service life of the windshield as provided by Vans for the RV10? Obviously it will be a pain to replace. David McNeill N46007 8 years and 1100tt ------------------------------------------------------------------------- ------- This email has been checked for viruses by Avast antivirus software. www.avast.com ________________________________________________________________________________
Date: Oct 15, 2016
Amazon had Plexall at $14.95 for a 16oz spray bottle. https://www.amazon.co m/gp/aw/d/B01EM5J9T6/ref=mp_s_a_1_1?ie=UTF8&qid=1476579125&sr=8-1&pi =AC_SX236_SY340_QL65&keywords=plexall&dpPl=1&dpID=41SFzC1jMHL&ref= plSrch Marcus > On Oct 15, 2016, at 5:00 PM, Tim Olson wrote: > > There is a two pack of cleaner plus protectant that works very well from A viation labs. I pick it up at Oshkosh every year. It comes to about five dol lars a can and works better than plexus. Usually they are in the south east h angar. The cleaner works very well for removing bugs and everything else. I t's worth a shot before anyone stocks up on a case of anything else. > Tim > >> On Oct 15, 2016, at 3:15 PM, David wrote: >> >> I bought a case of Plexus back in 2007 for about $60 ($7 per can). The cu rrent price is a minimum of $15 per can and can range to $20+. I found 37 Pl exall at $7 per larger can and going to test it. >> >> David McNeill >> >> >> >> This email has been checked for viruses by Avast antivirus software. >> www.avast.com >> >> ________________________________________________________________________________
Subject: leaking fuel tanks
Date: Oct 16, 2016
My 15 year old RV8, with QB tanks had been leaking on the left tank for the last 10 years. Every method to fix it, including the ones mentioned in this thread were employed, with mixed results. Some even worked for awhile, only to start leaking again a few months later. I lost count of how many times that tank came off the wing. The biggest problem was the lower inboard flange. I was slowly beat down where I was willing to live with the small seeps from rivets. But that flange, good grief! Anyway, I finally bit the bullet and sent the tank off the =9CWeep no More=9D. Please do yourself a favor, and just skip to that step. The tank will not leak when he is done. Nothing else short of duplicating his method (good luck with that) will work as a permanent solution. Go ahead and flame away, as I no longer have a dog in this fight. My tank doesn=99t leak anymore. If you want to know how I build my shipping box, send me an email. Chris Hukill RV10 sold RV8, high and dry ________________________________________________________________________________
Date: Oct 16, 2016
I think this is what Tim is referring to. The cleaner melts the leading edge bugs off in seconds. It was $5/can (15oz) at Osh. Lenny Tim Olson wrote: > There is a two pack of cleaner plus protectant that works very well from Aviation labs. I pick it up at Oshkosh every year. It comes to about five dollars a can and works better than plexus. Usually they are in the south east hangar. The cleaner works very well for removing bugs and everything else. It's worth a shot before anyone stocks up on a case of anything else. > Tim > > On Oct 15, 2016, at 3:15 PM, David wrote: > > > > > > > I bought a case of Plexus back in 2007 for about $60 ($7 per can). The current price is a minimum of $15 per can and can range to $20+. I found 37 Plexall at $7 per larger can and going to test it. > > > > David McNeill > > > > > > (https://www.avast.com/antivirus) > > This email has been checked for viruses by Avast antivirus software. > > www.avast.com (https://www.avast.com/antivirus) > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461357#461357 Attachments: http://forums.matronics.com//files/img_0813_431.jpg ________________________________________________________________________________
Date: Oct 16, 2016
Subject: Re: Now bug cleaner, was Re: Plexus and Plexall
Does this product have a name and/or source besides OSH exhibit? -sent from the Note 7 burned in my forearm On Sun, Oct 16, 2016 at 4:53 PM, Lenny Iszak wrote: > > I think this is what Tim is referring to. The cleaner melts the leading > edge bugs off in seconds. It was $5/can (15oz) at Osh. > > Lenny > > > Tim Olson wrote: > > There is a two pack of cleaner plus protectant that works very well from > Aviation labs. I pick it up at Oshkosh every year. It comes to about five > dollars a can and works better than plexus. Usually they are in the south > east hangar. The cleaner works very well for removing bugs and everything > else. It's worth a shot before anyone stocks up on a case of anything else. > > Tim > > > > On Oct 15, 2016, at 3:15 PM, David wrote: > > > > > > > > > > > > I bought a case of Plexus back in 2007 for about $60 ($7 per can). The > current price is a minimum of $15 per can and can range to $20+. I found 37 > Plexall at $7 per larger can and going to test it. > > > > > > David McNeill > > > > > > > > > > (https://www.avast.com/antivirus) > > > This email has been checked for viruses by > Avast antivirus software. > > > www.avast.com (https://www.avast.com/antivirus) > > > > > > > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461357#461357 > > > Attachments: > > http://forums.matronics.com//files/img_0813_431.jpg > > ________________________________________________________________________________
Date: Oct 16, 2016
Going out on a limb here... http://www.avlab.com/ProductDetails.asp?ProductCode=AVL%2DCV%2DPROMO Sent from my iPhone > On Oct 16, 2016, at 9:01 PM, Kelly McMullen wrote: > > Does this product have a name and/or source besides OSH exhibit? > > -sent from the Note 7 burned in my forearm > >> On Sun, Oct 16, 2016 at 4:53 PM, Lenny Iszak w rote: >> >> I think this is what Tim is referring to. The cleaner melts the leading e dge bugs off in seconds. It was $5/can (15oz) at Osh. >> >> Lenny >> >> >> Tim Olson wrote: >> > There is a two pack of cleaner plus protectant that works very well fro m Aviation labs. I pick it up at Oshkosh every year. It comes to about five d ollars a can and works better than plexus. Usually they are in the south eas t hangar. The cleaner works very well for removing bugs and everything else . It's worth a shot before anyone stocks up on a case of anything else. >> > Tim >> > >> > On Oct 15, 2016, at 3:15 PM, David wrote: >> > >> > >> > >> > > >> > > I bought a case of Plexus back in 2007 for about $60 ($7 per can). Th e current price is a minimum of $15 per can and can range to $20+. I found 3 7 Plexall at $7 per larger can and going to test it. >> > > >> > > David McNeill >> > > >> > > >> > > (https://www.avast.com/antivirus) >> > > This email has been checked for viruses b y Avast antivirus software. >> > > www.avast.com (https://www.avast.com/antivirus) >> > > >> > > >> > >> >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=461357#461357 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/img_0813_431.jpg >> >> >> >> >> ========================= >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= >> >> >> > ________________________________________________________________________________
Date: Oct 17, 2016
For bugs and general cleaning I use Wash Wax All. I do a quick wipe down of the leading edges after every flight. It takes me about 10 minutes total. My wife and I even washed the whole plane in the hanger in about an hour with it. http://www.aircraftspruce.com/catalog/cspages/washwax.php On Sun, Oct 16, 2016 at 11:10 PM, Phillip Perry wrote: > Going out on a limb here... > > http://www.avlab.com/ProductDetails.asp?ProductCode=AVL%2DCV%2DPROMO > > > Sent from my iPhone > > On Oct 16, 2016, at 9:01 PM, Kelly McMullen wrote: > > Does this product have a name and/or source besides OSH exhibit? > > -sent from the Note 7 burned in my forearm > > On Sun, Oct 16, 2016 at 4:53 PM, Lenny Iszak > wrote: > >> >> I think this is what Tim is referring to. The cleaner melts the leading >> edge bugs off in seconds. It was $5/can (15oz) at Osh. >> >> Lenny >> >> >> Tim Olson wrote: >> > There is a two pack of cleaner plus protectant that works very well >> from Aviation labs. I pick it up at Oshkosh every year. It comes to about >> five dollars a can and works better than plexus. Usually they are in the >> south east hangar. The cleaner works very well for removing bugs and >> everything else. It's worth a shot before anyone stocks up on a case of >> anything else. >> > Tim >> > >> > On Oct 15, 2016, at 3:15 PM, David wrote: >> > >> > >> > >> > > >> > > I bought a case of Plexus back in 2007 for about $60 ($7 per can). >> The current price is a minimum of $15 per can and can range to $20+. I >> found 37 Plexall at $7 per larger can and going to test it. >> > > >> > > David McNeill >> > > >> > > >> > > >> (https://www.avast.com/antivirus) >> > > This email has been checked for viruses >> by Avast antivirus software. >> > > www.avast.com (https://www.avast.com/antivirus) >> > > >> > > >> > >> >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=461357#461357 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/img_0813_431.jpg >> >> >> >> >> =================================== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/ >> Navigator?RV10-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> > ________________________________________________________________________________
Date: Oct 17, 2016
That's the stuff. At OSH you can buy it for $5/can and get the cans individually so that if you need more of one than the other you can have it. I've really liked the stuff. Tim On 10/16/2016 11:10 PM, Phillip Perry wrote: > Going out on a limb here... > > http://www.avlab.com/ProductDetails.asp?ProductCode=AVL%2DCV%2DPROMO > > ________________________________________________________________________________
Subject: Transition Training
Date: Oct 17, 2016
I seem to be striking out on transition trainers. Anyone have leads on transition trainers. I have tried Alex and David, both are not training right now and was told Oregon was a bad place to fly over next few month by tech crew at Vans and they did not know of any others that could train. Any thoughts or suggestions or should I just shut down after airworthiness inspection for next several months. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461407#461407 ________________________________________________________________________________
Date: Oct 18, 2016
When I did my training with Alex in June he suggested I get recurrent training with a pilot in San Francisco area, since I was a few month away from my first flight. I ended up flying in November, no issues. If I was in your situation I would find, as a minimum, a RV-10 near you that will allow you to fly with them and get some stick time in return for gas and a burger, when Alex is free again to do training get it, I assume you need it for insurance? I was lucky to fly with a good friend in Texas before my training, 1 hour with him saved my 2 hours with Alex, actually I needed to beg Alex for another hour for insurance we did max cross wind component landings in Midland and I have used that training to land a few times already.. Its worth the training, but don't "shut down after airworthiness" get in the mindset by flying. Pascal -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of mhealydds Sent: Monday, October 17, 2016 6:46 PM Subject: RV10-List: Transition Training I seem to be striking out on transition trainers. Anyone have leads on transition trainers. I have tried Alex and David, both are not training right now and was told Oregon was a bad place to fly over next few month by tech crew at Vans and they did not know of any others that could train. Any thoughts or suggestions or should I just shut down after airworthiness inspection for next several months. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461407#461407 ________________________________________________________________________________
Subject: Looking for Tips
Date: Oct 18, 2016
I have recently gotten partners in my RV-10, and we are converting it from my old LS1 engine, to a new IO-540 from Van. I'd like to get some input on several areas. First, The Red Cube - Tunnel or on the engine? Next, Remote Oil Filter - AirWolf, B&C, or the standard? Would like to know how messy it can be with any of them. Cables or Actuators - Any comments on these for the Oil Cooler, and the heat deflectors would be appreciated. Tips on what not to do on baffling also appreciated. Fire away! John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461420#461420 ________________________________________________________________________________
Date: Oct 18, 2016
Subject: Re: Transition Training
Where are you located? -----Original Message----- From: mhealydds <mhealydds(at)gmail.com> Sent: Mon, Oct 17, 2016 6:47 pm Subject: RV10-List: Transition Training I seem to be striking out on transition trainers. Anyone have leads on transition trainers. I have tried Alex and David, both are not training right now and was told Oregon was a bad place to fly over next few month by tech crew at Vans and they did not know of any others that could train. Any thoughts or suggestions or should I just shut down after airworthiness inspection for next several months. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461407#461407 ________________________________________________________________________________
Date: Oct 18, 2016
Subject: Re: Looking for Tips
I prefer the fuel transducer on the engine - much more accurate. I didn't like the inaccuracy when the electric fuel pump is on. No opinion on the rest... On Tue, Oct 18, 2016 at 12:39 PM, johngoodman wrote: > > I have recently gotten partners in my RV-10, and we are converting it from > my old LS1 engine, to a new IO-540 from Van. I'd like to get some input on > several areas. > > First, The Red Cube - Tunnel or on the engine? > > Next, Remote Oil Filter - AirWolf, B&C, or the standard? Would like to > know how messy it can be with any of them. > > Cables or Actuators - Any comments on these for the Oil Cooler, and the > heat deflectors would be appreciated. > > Tips on what not to do on baffling also appreciated. > > Fire away! > John > > -------- > #40572 Phase One complete in 2011 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461420#461420 > > ________________________________________________________________________________
Date: Oct 18, 2016
I'm not flying yet, but I'll give my reasons ...... On 10/18/2016 1:39 PM, johngoodman wrote: > > I have recently gotten partners in my RV-10, and we are converting it from my old LS1 engine, to a new IO-540 from Van. I'd like to get some input on several areas. > > First, The Red Cube - Tunnel or on the engine? Engine. Too many people have had fuel flow inaccuracies due to turbulence caused by the boost pump. > Next, Remote Oil Filter - AirWolf, B&C, or the standard? Would like to know how messy it can be with any of them. I stayed with the standard oil filter since I didn't see a need to change. I've been changing them a long time and don't make any messes. > Cables or Actuators - Any comments on these for the Oil Cooler, and the heat deflectors would be appreciated. I have a problem with dumping the oil cooler air into the dead space in the lower corner of the cowl. I have thought about a collector plenum that dumps into the exit air, but the muffler mounting gets in the way. The deflector would be a good idea ..... > Tips on what not to do on baffling also appreciated. I modified my baffling and cowl to accept a Sam James plenum. I did not make the baffling according to Sam James, but modified his plenum to fit the Vans baffling. We'll see how well I did in the coming year. > Fire away! Bang!!! Linn > John > > -------- > #40572 Phase One complete in 2011 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461420#461420 > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Oct 18, 2016
- Red cube. Both places work. The tunnel is easier but will reflect some error when the boost pump is running. I have it in the tunnel and use the boost pump for takeoff, landing and when shifting tanks. Total fuel used is always within a half a gallon on fill up (400 hours on the plane). - Standard oil filter. Put a cup under it when changing oil filters and you don't lose a drop. - I greatly prefer the standard push/pull throttle, vernier prop and vernier mixture controls - and others prefer a quadrant. For cabin heat, oil cooler butterfly valve and engine alt air I used these cables: http://www.aircraftspruce.com/catalog/appages/a730.php For a smaller footprint on the panel these work as well: http://www.aircraftspruce.com/catalog/appages/buttondashctrl.php - The stock oil cooler mount is, in my opinion, a poor design. The air needs to first change direction by bounding off the firewall, then change directions again when exiting the cooler. I mounted an AirFlow System 2006X cooler horizontally on the firewall on the left side. It gets the standard 4" hose from the left side of the engine baffle via a 4" butterfly valve. This cooler works well. I have never had an oil temp problem. The butterfly valve is required however even on mild days to keep temps about 180. - The stock cabin heat valves are horrible for blasting hot air back onto the engine right where you have your mechanical fuel pump. I put a piece of this stuff between the valves and the firewall (holes cut out for cabin air flow) and draped the material over the top and front of the valves: http://www.aircraftspruce.com/pages/ap/insulation/koolmat.php This way on your hot day when these valves are shut the heat muff air is deflected down and away from the engine. - For cabin heat cut one 2" hole in the rear baffle for a single hose, then a Y to run the separate hoses to each heat muff. Even then you might find a need to put a restrictor in line as you get a boatload of cabin heat. So less air is fine for cabin heat and on a hot day you are stealing less air from engine cooling. - If using the standard cowl, then get the stock Van's baffle kit. I made my own as I'm using a plenum. - On first flight leave the air damn off the front of #1 and #2 cylinders. Add them once you get some CHT data. Cut them down as needed to get the right CHT balance. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Tuesday, October 18, 2016 1:39 PM Subject: RV10-List: Looking for Tips --> I have recently gotten partners in my RV-10, and we are converting it from my old LS1 engine, to a new IO-540 from Van. I'd like to get some input on several areas. First, The Red Cube - Tunnel or on the engine? Next, Remote Oil Filter - AirWolf, B&C, or the standard? Would like to know how messy it can be with any of them. Cables or Actuators - Any comments on these for the Oil Cooler, and the heat deflectors would be appreciated. Tips on what not to do on baffling also appreciated. Fire away! John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461420#461420 ________________________________________________________________________________
Date: Oct 18, 2016
John, I prefer the red cube on the engine. Here are a couple pictures of a bracket I make for the red cube. It just mounts to the studs that secure the servo. Made from steel similar to Van's other brackets. I like the B&C 90* filter. If I have time, I punch a couple holes in the top and then let it sit for a few hours. Then I can unscrew the filter and it doesn't even drip. We just replaced our baffles after about 1200 hours--long story but we went from soft silicone baffles, which worked great, to some pretty expensive material that was supposed to reduce vibration to the cowl since it's teflon coated and theoretically not as "sticky". It was kind of hard to work with compared to the silicone, and I don't notice any improvement in smoothness. --Dave On Tue, Oct 18, 2016 at 10:39 AM, johngoodman wrote: > > I have recently gotten partners in my RV-10, and we are converting it from > my old LS1 engine, to a new IO-540 from Van. I'd like to get some input on > several areas. > > First, The Red Cube - Tunnel or on the engine? > > Next, Remote Oil Filter - AirWolf, B&C, or the standard? Would like to > know how messy it can be with any of them. > > Cables or Actuators - Any comments on these for the Oil Cooler, and the > heat deflectors would be appreciated. > > Tips on what not to do on baffling also appreciated. > > Fire away! > John > > -------- > #40572 Phase One complete in 2011 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461420#461420 > > ________________________________________________________________________________
Date: Oct 18, 2016
John, Just completed my -10 in the last 9 months, 36 hrs TT, so to paraphrase Stein my .02 worth. Red cube under the front of the engine above the fuel servo. Easy to mount, service, no issues etc and one less set of connections in the tight inaccessible tunnel, and in the cabin where the smell of fuel is a bad thing. I have a 90 degree oil filter adapter so no opinion on the remote mount. I had to re-buy 2 of the 3 engine control cables from MacFarlane due to placement of my F/W penetrations and ease of routing. Highly recommend mounting the engine and then measuring for the required lengths. Vans cables don't appear to be as high a quality as the MacFarlane cables, but just my opinion. I bought an oversized oil cooler, Air Flow Systems 2007X model. I think it is supposed to have 17% more cooling. I have no issues with oil temps. My baffling is per the plans. Close off every little hole you can find. >From the very first flight I have had no problems with CHT's and I have 9:1 compression so I probably make a little more HP. Good luck. Rick #40956 Southampton, Ont -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: October 18, 2016 1:39 PM Subject: RV10-List: Looking for Tips --> I have recently gotten partners in my RV-10, and we are converting it from my old LS1 engine, to a new IO-540 from Van. I'd like to get some input on several areas. First, The Red Cube - Tunnel or on the engine? Next, Remote Oil Filter - AirWolf, B&C, or the standard? Would like to know how messy it can be with any of them. Cables or Actuators - Any comments on these for the Oil Cooler, and the heat deflectors would be appreciated. Tips on what not to do on baffling also appreciated. Fire away! John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461420#461420 ________________________________________________________________________________
Subject: January Wx Advice
Date: Oct 18, 2016
Hi In early January I am thinking of flying from Alberta Canada (think Montana) to Orlando Florida. The north west weather I am familiar with (that's why I going to Florida). What I am wondering about is the weather enroute. Typically is the weather that time of year reasonable? Somewhere along Nebraska / Kansas / Arkansas / Alabama / Georgia etc. Also, are there any short term hanger options that anyone can recommend near WDW (Orlando)? Cheers & and thanks for the advice. Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461435#461435 ________________________________________________________________________________
Date: Oct 18, 2016
Subject: Re: January Wx Advice
Typical weather in FL is very nice unless a front is coming through. I could probably tuck you in the hangar at X35 for a little while. How long are you thinking? Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Oct 18, 2016, at 6:50 PM, kearney wrote: > > > Hi > > In early January I am thinking of flying from Alberta Canada (think Montana) to Orlando Florida. > > The north west weather I am familiar with (that's why I going to Florida). What I am wondering about is the weather enroute. Typically is the weather that time of year reasonable? Somewhere along Nebraska / Kansas / Arkansas / Alabama / Georgia etc. > > Also, are there any short term hanger options that anyone can recommend near WDW (Orlando)? > > Cheers & and thanks for the advice. > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461435#461435 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 18, 2016
My advice is to follow a front down. Good tailwind and low humidity typically produce some nice flying. I fly back and forth fro St. Louis to Ft. Myers typically 5 times over the winter. You can expect some marginal wx at some point on your route that time of year. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461438#461438 ________________________________________________________________________________
Date: Oct 18, 2016
Wichita KS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461439#461439 ________________________________________________________________________________
Date: Oct 18, 2016
The CDA meeting is in may ,I am a two time rv-10 builder and cfii ,I would be willing to help out a fellow dds-I can be reached at pilotdds(at)aol.com -----Original Message----- From: mhealydds <mhealydds(at)gmail.com> Sent: Tue, Oct 18, 2016 7:58 pm Subject: RV10-List: Re: Transition Training Wichita KS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461439#461439 ________________________________________________________________________________
Date: Oct 18, 2016
Matt, I am a Wichita native and was there for almost two weeks this summer with my airplane. We should talk. David Maib > On Oct 18, 2016, at 10:57 PM, mhealydds wrote: > > > Wichita KS > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461439#461439 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 18, 2016
Subject: Added ADS-B
We recently did some avionics upgrades to add ADS-B functions and a few other bells and whistles. I installed a Garmin GTX345 and a Flightstream 210. The shop I bought it from helped me configure the new goodies once it was fired up. It works very well. We have ADS-B traffic and weather displayed on a 530. The transponder and Flightstream each bluetooth to Foreflight so we have the ADS-B products there as well. One cool thing the Flightstream does is to transfer the flight plan back and forth--change it on the 530 or the iPad and it's just a few clicks to update the other. It's even relatively intuitive. The wiring was a pain but now that it's done I'm glad we did the upgrade. --Dave Oh and I have a 327 for sale... ________________________________________________________________________________
Date: Oct 19, 2016
Subject: Re: Added ADS-B
What was the total cost of this upgrade? Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 Sent from my iPhone > On Oct 19, 2016, at 12:30 AM, David Saylor wrote: > > We recently did some avionics upgrades to add ADS-B functions and a few other bells and whistles. > > I installed a Garmin GTX345 and a Flightstream 210. The shop I bought it from helped me configure the new goodies once it was fired up. > > It works very well. We have ADS-B traffic and weather displayed on a 530. The transponder and Flightstream each bluetooth to Foreflight so we have the ADS-B products there as well. > > One cool thing the Flightstream does is to transfer the flight plan back and forth--change it on the 530 or the iPad and it's just a few clicks to update the other. It's even relatively intuitive. > > The wiring was a pain but now that it's done I'm glad we did the upgrade. > > --Dave > > Oh and I have a 327 for sale... ________________________________________________________________________________
Subject: tips
Date: Oct 19, 2016
Two things struck a remembrance for me. The control cables from Vans seem to be of lower quality; I believe the cable cores are made of a material with a lower melt point. When your engine is shutdown, the temperature under the cowl rises very rapidly before cooling; the cores partially melt and become "sticky" or difficult to move; one solution is opening the oil filler door to allow air out. Secondly higher "melt point" cables are available from (1) California Push Pull (2) Aircraft Spruce (special order with melt point (Teflon) of 650 F). I have not tried McFarlane but they may also have Teflon core. Baffle sealing: the spark plug access hole for cylinders 5 & 6 needs to be sealed with a small piece of aluminum tape each time access to the spark plug is required. Curling a corner of the tape cover makes access easy for the next time. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: transition
Date: Oct 19, 2016
Transition training can be accomplished, gratis, by a CFI who owns or has built his 10; I have done several where a simple checkout flight (1-2 hours) is required. The trick is to ask your/his insurance company to cover the special flights. My insurance has approved these on a case by case basis. I proposed a waiver to the feds but the response that "I could not sign a high performance or complex endorsement for the trainee because the higher HP and controllable propeller could be accomplished in a certified aircraft", was not acceptable. Rather than respond emotionally I dropped the matter. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 19, 2016
About $5500 for the hardware (incl CA sales tax). I had about 40 hours in labor. I had to mount a new transponder can and run a few wires to the back of the 530. That was *almost* the worst part. The worst part was I was anxious to test the whole thing out, so I went flying and painted myself into the ADS-B landscape a week before the rebate was finalized. That made me ineligible. Doh! --Dave On Wed, Oct 19, 2016 at 4:59 AM, Jesse Saint wrote: > > What was the total cost of this upgrade? > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > Sent from my iPhone > > > On Oct 19, 2016, at 12:30 AM, David Saylor > wrote: > > > > We recently did some avionics upgrades to add ADS-B functions and a few > other bells and whistles. > > > > I installed a Garmin GTX345 and a Flightstream 210. The shop I bought it > from helped me configure the new goodies once it was fired up. > > > > It works very well. We have ADS-B traffic and weather displayed on a > 530. The transponder and Flightstream each bluetooth to Foreflight so we > have the ADS-B products there as well. > > > > One cool thing the Flightstream does is to transfer the flight plan back > and forth--change it on the 530 or the iPad and it's just a few clicks to > update the other. It's even relatively intuitive. > > > > The wiring was a pain but now that it's done I'm glad we did the upgrade. > > > > --Dave > > > > Oh and I have a 327 for sale... > > ________________________________________________________________________________
Subject: Re: tips
Date: Oct 19, 2016
Actually when I was talking to California Push-Pull earlier this year they said the difference is in the outer sheath only. Maybe they mis-spoke at the time, but the core itself is the same from what I understand. The outer sheath on the black/grey ones is higher temp. Tim On 10/19/2016 8:09 AM, David wrote: > Two things struck a remembrance for me. The control cables from Vans > seem to be of lower quality; I believe the cable cores are made of a > material with a lower melt point. When your engine is shutdown, the > temperature under the cowl rises very rapidly before cooling; the cores > partially melt and become sticky or difficult to move; one solution is > opening the oil filler door to allow air out. Secondly higher melt > point cables are available from (1) California Push Pull (2) Aircraft > Spruce (special order with melt point (Teflon) of 650 F). I have not > tried McFarlane but they may also have Teflon core. > > > Baffle sealing: the spark plug access hole for cylinders 5 & 6 needs to > be sealed with a small piece of aluminum tape each time access to the > spark plug is required. Curling a corner of the tape cover makes access > easy for the next time. > > > ------------------------------------------------------------------------ > Avast logo > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > ________________________________________________________________________________
Subject: Re: tips
Date: Oct 19, 2016
Instead of ordering cables with 2" throw, order 2-1/8". I ended up making it work with the 2" ones but a bit longer would have been perfect. Also like Tim, i put a firesleeve over them, and wrapped them in a reflective aluminized jacket. I don't care what they are made of, they are not going to melt anymore. It's really nice to have smooth controls again. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461460#461460 ________________________________________________________________________________
Subject: Re: tips
Date: Oct 19, 2016
The standard baffle kit from Vans should have included some back to back washers, nuts and bolts, to seal the access holes for the back two plugs. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461461#461461 ________________________________________________________________________________
Date: Oct 19, 2016
FWIW I went with the NAVWORX ADS600-EXP, total cost of $1471 including the w iring harness. To be honest I have very mixed feelings about their customer service, more recently was much better. Installation took me about five hou rs connecting to the GRT EFIS and Garmin 327. My timing was valid for the FAA rebate, but the experimental version is not e ligible at all, only genuine TSOd models count. I just had my first cross country flight with it, and the traffic display on my iPad was dead on. I switched to WingX pro because ForeFlight only wo rks with the Garman products. Marcus > On Oct 19, 2016, at 9:18 AM, David Saylor wrote: > > About $5500 for the hardware (incl CA sales tax). I had about 40 hours in labor. I had to mount a new transponder can and run a few wires to the bac k of the 530. That was *almost* the worst part. > > The worst part was I was anxious to test the whole thing out, so I went fl ying and painted myself into the ADS-B landscape a week before the rebate wa s finalized. That made me ineligible. Doh! > > --Dave > >> On Wed, Oct 19, 2016 at 4:59 AM, Jesse Saint wr ote: >> >> What was the total cost of this upgrade? >> >> Jesse Saint >> Saint Aviation, Inc. >> jesse(at)saintaviation.com >> C: 352-427-0285 >> F: 815-377-3694 >> >> Sent from my iPhone >> >> > On Oct 19, 2016, at 12:30 AM, David Saylor wrot e: >> > >> > We recently did some avionics upgrades to add ADS-B functions and a few other bells and whistles. >> > >> > I installed a Garmin GTX345 and a Flightstream 210. The shop I bought i t from helped me configure the new goodies once it was fired up. >> > >> > It works very well. We have ADS-B traffic and weather displayed on a 5 30. The transponder and Flightstream each bluetooth to Foreflight so we hav e the ADS-B products there as well. >> > >> > One cool thing the Flightstream does is to transfer the flight plan bac k and forth--change it on the 530 or the iPad and it's just a few clicks to u pdate the other. It's even relatively intuitive. >> > >> > The wiring was a pain but now that it's done I'm glad we did the upgrad e. >> > >> > --Dave >> > >> > Oh and I have a 327 for sale... >> >> >> >> ========================= >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= >> >> >> > ________________________________________________________________________________
Subject: Re: transition
Date: Oct 19, 2016
The key word, as far as the FAA is concerned, is "gratis". Most of the FAR prohibitions are "...may not, for compensation or hire,...". So as long as there is no compensation for yourself or the airplane, you're okay with the FAA. Now, dealing with your insurance company is another matter. Some will ammend your coverage to allow instruction, on a case by case basis, as you have indicated. But some will not. My current insurer will not. Mostly, they didn't want the paperwork cost and hassle. And their rates reflect that cost savings. The FAA will issue you a Letter of Deviation Authority (LODA), allowing you to give instruction for hire in your EAB airplane. But it will be restricted to transition training only. As you indicated, anything that can be done in a certified aircraft (Flight Review, High Performance endorsements, etc) are explicitly not allowed. Even though in the course of transition training you might accomplish all tasks required for a Flight Review you may not sign it off. I agree this is a harsh interpretation. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461463#461463 ________________________________________________________________________________
Date: Oct 19, 2016
One piece of this interests me. Bob, maybe you know the answer. Suppose my daughter does her private training in my RV14 and RV10. She flies them both with me now and can complete full flights without me touching anything. What does an instructor do about the high performance sign off? Can they sign you off in YOUR RV, even though its experimental? It would suck to have to have her go fly a 182 that is a completely different animal just to get HP signed off when she's all done. The RV14 is 210HP and the -10 you already know. Tim > On Oct 19, 2016, at 12:37 PM, Bob Turner wrote: > > > The key word, as far as the FAA is concerned, is "gratis". Most of the FAR prohibitions are "...may not, for compensation or hire,...". So as long as there is no compensation for yourself or the airplane, you're okay with the FAA. Now, dealing with your insurance company is another matter. Some will ammend your coverage to allow instruction, on a case by case basis, as you have indicated. But some will not. My current insurer will not. Mostly, they didn't want the paperwork cost and hassle. And their rates reflect that cost savings. > The FAA will issue you a Letter of Deviation Authority (LODA), allowing you to give instruction for hire in your EAB airplane. But it will be restricted to transition training only. As you indicated, anything that can be done in a certified aircraft (Flight Review, High Performance endorsements, etc) are explicitly not allowed. Even though in the course of transition training you might accomplish all tasks required for a Flight Review you may not sign it off. I agree this is a harsh interpretation. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461463#461463 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 19, 2016
The FAA will not let you utilize an experimental aircraft for hire. There's no prohibition against doing any sort of training in any experimental aircraft (including all signoffs), so as long as you're not also offering the aircraft for hire. You can hire an instructor to fly in your aircraft for any training, and an instructor can provide any sort of training (including all signoffs) in his/her own aircraft as long as (s)he's doing so without compensation. Now, Insurance is a totally different question. On Wed, Oct 19, 2016 at 12:07 PM, Tim Olson wrote: > > One piece of this interests me. > Bob, maybe you know the answer. > > Suppose my daughter does her private training in my RV14 and RV10. She > flies them both with me now and can complete full flights without me > touching anything. What does an instructor do about the high performance > sign off? Can they sign you off in YOUR RV, even though its experimental? > It would suck to have to have her go fly a 182 that is a completely > different animal just to get HP signed off when she's all done. The RV14 > is 210HP and the -10 you already know. > Tim > > > > On Oct 19, 2016, at 12:37 PM, Bob Turner wrote: > > > > > > The key word, as far as the FAA is concerned, is "gratis". Most of the > FAR prohibitions are "...may not, for compensation or hire,...". So as long > as there is no compensation for yourself or the airplane, you're okay with > the FAA. Now, dealing with your insurance company is another matter. Some > will ammend your coverage to allow instruction, on a case by case basis, as > you have indicated. But some will not. My current insurer will not. Mostly, > they didn't want the paperwork cost and hassle. And their rates reflect > that cost savings. > > The FAA will issue you a Letter of Deviation Authority (LODA), allowing > you to give instruction for hire in your EAB airplane. But it will be > restricted to transition training only. As you indicated, anything that can > be done in a certified aircraft (Flight Review, High Performance > endorsements, etc) are explicitly not allowed. Even though in the course of > transition training you might accomplish all tasks required for a Flight > Review you may not sign it off. I agree this is a harsh interpretation. > > > > -------- > > Bob Turner > > RV-10 QB > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=461463#461463 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 19, 2016
Agree with Bob Turner. My insurance company will not allow instruction on a case-by-case basis, either. Buying a years worth of insurance for a handful of transition training customers a year simply doesn't work financially. One minor thing in Bob's post is the "no compensation for yourself or the airplane" statement. I believe a CFI is allowed to accept compensation, as a CFI, just not allowed to accept compensation for the airplane unless you have the LODA. I have heard of CFI RV owners who simply charged a very high rate for their service as a CFI, and included the use of the airplane at no charge. I imagine if there was an accident or incident, the FAA might take a dim view of this, not to mention your insurance company. Restrictions on providing anything other than transition training, ie. Flight Review, Instrument Competency Check, High Performance Endorsement, etc., are clearly not permitted in the LODA. Does not make sense to me either, but that's the way it is. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461466#461466 ________________________________________________________________________________
Date: Oct 19, 2016
Coop, Log into the ap with your iPad and set the port to 4000 and it will work wit h ForeFlight. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Oct 19, 2016, at 1:12 PM, Marcus Cooper wrote: > > FWIW I went with the NAVWORX ADS600-EXP, total cost of $1471 including the wiring harness. To be honest I have very mixed feelings about their custom er service, more recently was much better. Installation took me about five h ours connecting to the GRT EFIS and Garmin 327. > My timing was valid for the FAA rebate, but the experimental version is no t eligible at all, only genuine TSOd models count. > I just had my first cross country flight with it, and the traffic displ ay on my iPad was dead on. I switched to WingX pro because ForeFlight only w orks with the Garman products. > > Marcus > >> On Oct 19, 2016, at 9:18 AM, David Saylor wrote: >> >> About $5500 for the hardware (incl CA sales tax). I had about 40 hours i n labor. I had to mount a new transponder can and run a few wires to the ba ck of the 530. That was *almost* the worst part. >> >> The worst part was I was anxious to test the whole thing out, so I went f lying and painted myself into the ADS-B landscape a week before the rebate w as finalized. That made me ineligible. Doh! >> >> --Dave >> >>> On Wed, Oct 19, 2016 at 4:59 AM, Jesse Saint w rote: >>> >>> What was the total cost of this upgrade? >>> >>> Jesse Saint >>> Saint Aviation, Inc. >>> jesse(at)saintaviation.com >>> C: 352-427-0285 >>> F: 815-377-3694 >>> >>> Sent from my iPhone >>> >>> > On Oct 19, 2016, at 12:30 AM, David Saylor wro te: >>> > >>> > We recently did some avionics upgrades to add ADS-B functions and a fe w other bells and whistles. >>> > >>> > I installed a Garmin GTX345 and a Flightstream 210. The shop I bought i t from helped me configure the new goodies once it was fired up. >>> > >>> > It works very well. We have ADS-B traffic and weather displayed on a 5 30. The transponder and Flightstream each bluetooth to Foreflight so we hav e the ADS-B products there as well. >>> > >>> > One cool thing the Flightstream does is to transfer the flight plan ba ck and forth--change it on the 530 or the iPad and it's just a few clicks to update the other. It's even relatively intuitive. >>> > >>> > The wiring was a pain but now that it's done I'm glad we did the upgra de. >>> > >>> > --Dave >>> > >>> > Oh and I have a 327 for sale... >>> >>> >>> >>> ======================== =========== >>> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Nav igator?RV10-List >>> ======================== =========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ======================== =========== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> ======================== =========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contributi on >>> ======================== =========== >>> >>> >>> >> ________________________________________________________________________________
Date: Oct 19, 2016
Tim Olson wrote: > One piece of this interests me. > Bob, maybe you know the answer. > > Suppose my daughter does her private training in my RV14 and RV10. She flies them both with me now and can complete full flights without me touching anything. What does an instructor do about the high performance sign off? Can they sign you off in YOUR RV, even though its experimental? It would suck to have to have her go fly a 182 that is a completely different animal just to get HP signed off when she's all done. The RV14 is 210HP and the -10 you already know. > Tim > > > > > > On Oct 19, 2016, at 12:37 PM, Bob Turner wrote: > > > > > > > > The key word, as far as the FAA is concerned, is "gratis". Most of the FAR prohibitions are "...may not, for compensation or hire,...". So as long as there is no compensation for yourself or the airplane, you're okay with the FAA. Now, dealing with your insurance company is another matter. Some will ammend your coverage to allow instruction, on a case by case basis, as you have indicated. But some will not. My current insurer will not. Mostly, they didn't want the paperwork cost and hassle. And their rates reflect that cost savings. > > The FAA will issue you a Letter of Deviation Authority (LODA), allowing you to give instruction for hire in your EAB airplane. But it will be restricted to transition training only. As you indicated, anything that can be done in a certified aircraft (Flight Review, High Performance endorsements, etc) are explicitly not allowed. Even though in the course of transition training you might accomplish all tasks required for a Flight Review you may not sign it off. I agree this is a harsh interpretation. > > > > -------- > > Bob Turner > > RV-10 QB > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=461463#461463 > > > > > > > > > > > > > > > > > > > > > > > > > Tim, I checked in to finishing Mary's Private in our RV-10 a few years ago. It was doable from an insurance perspective, but the cost was going to be huge. We determined that it made more sense to get her finished in a 172, since she had already soloed in one, and then transition her to the -10 once she had a license. The high cost of insurance was based on having a student pilot solo the RV-10. I am pretty sure if a CFI is giving primary instruction in a privately owned RV-10, where there is no charge for the airplane involved, the CFI would be free to put the endorsement for High Performance in the student pilots logbook. The prohibition we have been talking about is only for holders of the LODA that are providing transition training in their aircraft and charging for the use of the aircraft. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461470#461470 ________________________________________________________________________________
Date: Oct 19, 2016
Dave - Yes, I should have made clear that I meant my reply to be to the previous post, where the CFI provides the EAB airplane. FAR 91.319 is pretty clear - but can always be argued, I guess - that EAB aircraft cannot be used for compensation or hire. If a person is getting paid for flight instruction in an EAB aircraft that he provided "for free", then the plane is in fact being used for compensation - it's furthering his flight instruction business. The FAA, I'm sure, takes a dim view of this sham. As would the insurance company. But if someone else provides the airplane for no compensation - either because he is an owner, or is a really good friend, or as in Tim, a parent who does not charge his daughter- then there are no FAR restrictions on paying a cfi in that airplane, nor on the type of instruction, sign-offs, etc. Tim - As others have said, there are no restrictions on paying a cfi to give any type of instruction in your airplane(s), assuming you do not charge your daughter for its use. Note that when it comes to the private flight test, the FAA allows its designated examiners to decline flying in EAB aircraft, at their option. Some will, some won't. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461471#461471 ________________________________________________________________________________
Date: Oct 19, 2016
That's what I was thinking as well, Berck. If you are in YOUR airplane, you can hire an instructor to teach you and to sign you off for anything. Because you are the airplane owner. When the instructor or someone else owns the airplane then things change a lot. Regarding the insurance for training in the RV, the only thing I see as a problem is that the instructors will either have to meet the open pilot qualifications, or be named insured. In my opinion I'd rather have them named insured either way. This may require them to get some time in the RV first. In my RV14, you'd be required to have 25 hours in an RV, plus I think it was 500 hours total time. So I may have to fly with the instructor for a few hours first to get them RV Time. Tim On 10/19/2016 1:20 PM, Berck E. Nash wrote: > The FAA will not let you utilize an experimental aircraft for hire. > There's no prohibition against doing any sort of training in any > experimental aircraft (including all signoffs), so as long as you're not > also offering the aircraft for hire. You can hire an instructor to fly > in your aircraft for any training, and an instructor can provide any > sort of training (including all signoffs) in his/her own aircraft as > long as (s)he's doing so without compensation. > > Now, Insurance is a totally different question. > ________________________________________________________________________________
Date: Oct 19, 2016
Thanks David, Yeah, I originally built the RV-14 partially with the intent to have a lower hull value plane to put my daughters on for training. It sounds like I'll pay a higher premium for sure, but it doesn't sound like it's going to add much for me anymore, considering I just added Andrea on both planes this summer. They indicated at the time that adding the daughter won't add much more additional now. My biggest issue is probably going to be getting the instructor enough RV time to meet the insurance requirements, unless they allow me to cut it to 5 hours or something by being named insured. I'm glad that I no longer need transition training though, considering the apparent market situation these days for it. And I may as well add the reply to Bob's recent post too....thanks Bob. Yeah, that's my final headache for 2018...finding a designated examiner who will do the checkride in an EAB. I'll just have to find one that will be willing. Worst case, the poor kid has to spend some time in a 150. That would suck, given how much nicer these planes are...and, she can fly it wonderfully now. 16 in May so no solo until then...but by that time, she'll even be doing her own aerobatics and spins. Tim > > Tim, I checked in to finishing Mary's Private in our RV-10 a few > years ago. It was doable from an insurance perspective, but the cost > was going to be huge. We determined that it made more sense to get > her finished in a 172, since she had already soloed in one, and then > transition her to the -10 once she had a license. The high cost of > insurance was based on having a student pilot solo the RV-10. I am > pretty sure if a CFI is giving primary instruction in a privately > owned RV-10, where there is no charge for the airplane involved, the > CFI would be free to put the endorsement for High Performance in the > student pilots logbook. The prohibition we have been talking about is > only for holders of the LODA that are providing transition training > in their aircraft and charging for the use of the aircraft. > > -------- David Maib RV-10 #40559 New Smyrna Beach, FL > > ________________________________________________________________________________
Date: Oct 19, 2016
My CFI rules knowledge are a little foggy here in the Mediterranean, but take a look at the rules for complex sign off. Doesnt say a word about certified or not.horsepower, prop and/or retract gear. > On Oct 19, 2016, at 9:07 PM, Tim Olson wrote: > > > One piece of this interests me. > Bob, maybe you know the answer. > > Suppose my daughter does her private training in my RV14 and RV10. She flies them both with me now and can complete full flights without me touching anything. What does an instructor do about the high performance sign off? Can they sign you off in YOUR RV, even though its experimental? It would suck to have to have her go fly a 182 that is a completely different animal just to get HP signed off when she's all done. The RV14 is 210HP and the -10 you already know. > Tim > > > >> On Oct 19, 2016, at 12:37 PM, Bob Turner wrote: >> >> >> The key word, as far as the FAA is concerned, is "gratis". Most of the FAR prohibitions are "...may not, for compensation or hire,...". So as long as there is no compensation for yourself or the airplane, you're okay with the FAA. Now, dealing with your insurance company is another matter. Some will ammend your coverage to allow instruction, on a case by case basis, as you have indicated. But some will not. My current insurer will not. Mostly, they didn't want the paperwork cost and hassle. And their rates reflect that cost savings. >> The FAA will issue you a Letter of Deviation Authority (LODA), allowing you to give instruction for hire in your EAB airplane. But it will be restricted to transition training only. As you indicated, anything that can be done in a certified aircraft (Flight Review, High Performance endorsements, etc) are explicitly not allowed. Even though in the course of transition training you might accomplish all tasks required for a Flight Review you may not sign it off. I agree this is a harsh interpretation. >> >> -------- >> Bob Turner >> RV-10 QB >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=461463#461463 >> >> >> >> >> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Oct 19, 2016
Tim, As David said, the real insurance cost is likely not to be for a cfi; it will be to insure your daughter for solo flight. BTW, no person with any assets to lose would, if in his right mind, fly under an open pilot clause. He has no protection. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461475#461475 ________________________________________________________________________________
Date: Oct 19, 2016
Regarding that rebate, I read some info that was in one of the weekly emails last week. Turns out that the $500 rebate is taxable, and there are all sorts of strings attached...including a fairly specific flight test that you have to do, where you fly a specific flight profile in specific type of airspace. The tax you pay on the rebate cuts its value quite a bit...but then if you're forced to fly that specific flight profile for testing, that will cost you time and fuel as well. So the value of the rebate is at best, half of the $500 that they give you. For that little bit of money I really don't think the hassle of even dealing with the FAA is worth it. Your cost of $1471 wasn't too bad. I paid more by being an early adopter. The guts of your -EXP model aren't any different than the TSO'd model either, so you'll be in good shape. Oh, and regarding WingX.... I agree with Bob. I find it great to use in the cockpit. Yes, I do like Foreflight for filing the plans and preflight weather planning, but after that I'm very happy with WingX. And just because I'm a bit nuts, I have: A Foreflight Subscription A 3-year WingX subscription 1 lifetime FlyQ subscription An 18-moth Aerovie subscription One thing people don't talk about much is the subscription model. I have 2 pilots now and soon enough to be 3 in my family. Foreflight limits you to 1 iphone, 1 ipad, and 1 backup ipad. This sucks totally...I can't even have my own wife and I both have foreflight on our iphone. Yes, they would charge me another $75-100 for a subscription for her, and then for my Daughter too. It's a royal screwjob for families like me. With WingX, FlyQ, and Aerovie, my subscription covers all of the devices on my family's iTunes account, so we can all have the apps. FlyQ doesn't have an EFB for the iphone but they have a mush less nice companion app. Aerovie and WingX both work on both platforms, including with my iLevil 3 AW AHRS. Aerovie is my hopeful app for the future for preflight weather briefing. It has some weather planning features that the others don't have, including skewTlog charts and overlay prog charts. Seems to be very nice. If they refine the app a bit, I won't subscribe to foreflight again at all. But of all of those, right now, WingX would be the hardest for me to let go of. Tim On 10/19/2016 12:12 PM, Marcus Cooper wrote: > FWIW I went with the NAVWORX ADS600-EXP, total cost of $1471 including > the wiring harness. To be honest I have very mixed feelings about their > customer service, more recently was much better. Installation took me > about five hours connecting to the GRT EFIS and Garmin 327. > My timing was valid for the FAA rebate, but the experimental version is > not eligible at all, only genuine TSOd models count. > I just had my first cross country flight with it, and the traffic > display on my iPad was dead on. I switched to WingX pro because > ForeFlight only works with the Garman products. > > Marcus > ________________________________________________________________________________
Date: Oct 19, 2016
gengrumpy wrote: > My CFI rules knowledge are a little foggy here in the Mediterranean, but take a look at the rules for complex sign off. > > Doesnt say a word about certified or not.horsepower, prop and/or retract gear. > > > > > > > > > > > > > The thread became 'mixed topics'. The issue was that cfi's instructing in their own planes, for compensation under an FAA issued LODA, are not allowed to do these sign offs. If instructing for hire in the 'student's' airplane there are no issues. BTW, "complex" = CS prop, flaps, retractable landing gear. Does not apply to RVs. "high performance" = over 200 HP. Does apply to RV-10 and -14. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461479#461479 ________________________________________________________________________________
Date: Oct 19, 2016
You can't get a better overall summary than that, but keep in mind that not everybody needs as many devices as Tim's family. I use the Foreflight Logbook now since LogTen went to subscription-based. All of my eggs are in the Foreflight basket, and I am very happy with it all around for preflight and inflight. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 Sent from my iPhone > On Oct 19, 2016, at 4:08 PM, Tim Olson wrote: > > > Regarding that rebate, I read some info that was in one of the > weekly emails last week. > > Turns out that the $500 rebate is taxable, and there are all > sorts of strings attached...including a fairly specific > flight test that you have to do, where you fly a specific > flight profile in specific type of airspace. The tax > you pay on the rebate cuts its value quite a bit...but then > if you're forced to fly that specific flight profile for > testing, that will cost you time and fuel as well. > So the value of the rebate is at best, half of the $500 > that they give you. For that little bit of money I really > don't think the hassle of even dealing with the FAA is worth > it. Your cost of $1471 wasn't too bad. I paid more by > being an early adopter. > > The guts of your -EXP model aren't any different than the > TSO'd model either, so you'll be in good shape. > > > Oh, and regarding WingX.... > > I agree with Bob. I find it great to use in the cockpit. > Yes, I do like Foreflight for filing the plans and preflight > weather planning, but after that I'm very happy with WingX. > > And just because I'm a bit nuts, I have: > > A Foreflight Subscription > A 3-year WingX subscription > 1 lifetime FlyQ subscription > An 18-moth Aerovie subscription > > One thing people don't talk about much is the subscription > model. I have 2 pilots now and soon enough to be 3 in my > family. Foreflight limits you to 1 iphone, 1 ipad, and 1 > backup ipad. This sucks totally...I can't even have > my own wife and I both have foreflight on our iphone. Yes, > they would charge me another $75-100 for a subscription for > her, and then for my Daughter too. It's a royal screwjob > for families like me. > > With WingX, FlyQ, and Aerovie, my subscription covers > all of the devices on my family's iTunes account, so we > can all have the apps. FlyQ doesn't have an EFB for the > iphone but they have a mush less nice companion app. > Aerovie and WingX both work on both platforms, including > with my iLevil 3 AW AHRS. > > Aerovie is my hopeful app for the future for preflight weather > briefing. It has some weather planning features that the > others don't have, including skewTlog charts and > overlay prog charts. Seems to be very nice. If they refine > the app a bit, I won't subscribe to foreflight again > at all. > > But of all of those, right now, WingX would be the hardest > for me to let go of. > > Tim > > >> On 10/19/2016 12:12 PM, Marcus Cooper wrote: >> FWIW I went with the NAVWORX ADS600-EXP, total cost of $1471 including >> the wiring harness. To be honest I have very mixed feelings about their >> customer service, more recently was much better. Installation took me >> about five hours connecting to the GRT EFIS and Garmin 327. >> My timing was valid for the FAA rebate, but the experimental version is >> not eligible at all, only genuine TSOd models count. >> I just had my first cross country flight with it, and the traffic >> display on my iPad was dead on. I switched to WingX pro because >> ForeFlight only works with the Garman products. >> >> Marcus >> > > > > ________________________________________________________________________________
Date: Oct 19, 2016
So just yesterday I started paying for my $1100 ADSB plan. Of course, I didn't count any equipment I already own!! I will report in due time on the outcome. Equipment already owned: GRT HX, Garmin 420W, Garmin GTX-327 transponder, Skyradar D2 ADSB in. Upgrades: GRT HX software - free Garmin 420W firmware - $100 Trig TT22 remote mode S-ES transponder with RS232to 422 adaptor - $2200 Gains: $500 from FAA sell 327 for about $700. Net cost: $1100. To be honest I lucked into the FAA rebate. I would have done this earlier but wanted to wait until my transponder certification was nearly due anyway, to avoid that extra cost. Yes, I will need to go fly the FAA's 'profile', and it appears that must be done in ADSB required airspace, so that means above 10,000' for me. But, in my acounting scheme, flying is free! As to the tax status of the $500, I believe this is a cya from the FAA. Certainly Ford gives out tax free rebates all the time, although not from public funds. Besides, I'm not in a high enough tax bracket to worry about it. And-part of my strangeness-I derive some pleasure arguing with the IRS. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461481#461481 ________________________________________________________________________________
Date: Oct 19, 2016
I'm getting old, so bear with me ..... I thought there were a limited number of rebates and that they were going to pick the winners from the pool of applicants. I'm sure y'all will let me know if I'm wrong ..... ;-) Linn On 10/19/2016 4:45 PM, Bob Turner wrote: > > So just yesterday I started paying for my $1100 ADSB plan. Of course, I didn't count any equipment I already own!! I will report in due time on the outcome. > Equipment already owned: GRT HX, Garmin 420W, Garmin GTX-327 transponder, Skyradar D2 ADSB in. > Upgrades: > GRT HX software - free > Garmin 420W firmware - $100 > Trig TT22 remote mode S-ES transponder with RS232to 422 adaptor - $2200 > > Gains: > $500 from FAA > sell 327 for about $700. > > Net cost: $1100. > > To be honest I lucked into the FAA rebate. I would have done this earlier but wanted to wait until my transponder certification was nearly due anyway, to avoid that extra cost. > > Yes, I will need to go fly the FAA's 'profile', and it appears that must be done in ADSB required airspace, so that means above 10,000' for me. But, in my acounting scheme, flying is free! > > As to the tax status of the $500, I believe this is a cya from the FAA. Certainly Ford gives out tax free rebates all the time, although not from public funds. Besides, I'm not in a high enough tax bracket to worry about it. And-part of my strangeness-I derive some pleasure arguing with the IRS. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461481#461481 > > ________________________________________________________________________________
Date: Oct 19, 2016
flying-nut(at)cfl.rr.com wrote: > I'm getting old, so bear with me ..... > I thought there were a limited number of rebates and that they were > going to pick the winners from the pool of applicants. I'm sure y'all > will let me know if I'm wrong ..... ;-) > Linn > > On 10/19/2016 4:45 PM, Bob Turner wrote: > > > > > > > So > > GRT HX software - free > > G > > > There is no lottery. The money goes to the first people to apply. Rules: You must not already have purchased the equipment. You apply for the rebate first. The FAA gives you a number. Then you buy, install, and flight test the equipment within a specified period of time, not to exceed 3 months, I think. The equipment you buy has to be on the 'approved' list (non-TSO equipment is excluded). If you pass the test within the specified time period, then you finish filling out the FAA paperwork, and they should send you a check. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461483#461483 ________________________________________________________________________________
Subject: Cheap Led light alternative.
Date: Oct 20, 2016
I saw a thread on Vansairforce about landing lights and I committed to give a more detailed review and pictures on this forum. So Here it is. In short my planelights HID bulb broke and I needed to replace it. Couldn't find a bulb and when I did it was way too expensive. I considered a commer cial LED solution, but that too is ridiculous for pricing, In the end I dec ided to build an LED alternative and it runs about $40 I took some pictures in the middle of the (bright) day- I realize its not r eal testing in darkness but this is to give an idea of light potential unti l I have a chance to take night pictures. The actual install is a Cree XHP35 350Ma LED 3X star with a MeanWell LDH-4 5A-350W, 350Ma driver. I landed the other day in Northern California at an airport campground alth ough I didn't take a picture, as you can see (in my 10 foot distance to han gar door on a bright day!) the HID is more focused beam versus the LED but the LED puts out a good amount of light 125 degree with about 1800 or maybe more Lumens. The effect was like a bright flashlight on the side of the LE D probably a good 20-30 feet ahead is completely covered in white light (th is is easily adjusted with a cheap lens that would make the flood into a sp ot light). The mount was literally built from scratch, aluminum piece shap ed to HID mount and three new nut-plates riveted on- the angle needs to be created to beam the light more upfront versus the 45 degrees off the wingti p that naturally occurs. If one used the original bracket and put a flat pi ece on the rear mount (the one that held the bulb) it would work just fine. I wanted the light right on the hole to avoid the light spreading all over the wingtip as it used to do with HID. I think if one wanted to make this easy, it could be all done in a few hour s from start to finish. Power and LED connections; rivet on a plate to curr ent HID bracket and connect- but to do this right, time should be spent mak ing the bracket flush and as forward facing as possible- and that does take a while to do. I plan to eventually get an optic to bring the beam more to 70 degrees, but truthfully it works really well "as is" and actually take a picture on my next night flight to give a "real world" picture of this solution. When my other HID goes out I'll do this project again. By the way this setup has no RFI/EMI in my radios. (Meanwell driver has bui lt in EMI filter) I also have a LUXdrive but that is not a good solution at all. Although I worked with their tech support they admitted that RFI nois e from their drivers was a known issue, they have a snubber built-in but th at is not for RFI apparently.. They had no solution for resolution either. Pascal No light test area with bright day outside [cid:1731B1EA-CA1C-4059-8C8B-B70E1043653F] Planelights HID [cid:9A0D34D6-E4A1-4792-BDFE-B6743065E03C] DIY LED Taxi light [cid:2C1454F1-8425-4DBE-912F-7FC74C510F40] ________________________________________________________________________________
Date: Oct 20, 2016
Red cube: I moved mine from tunnel to engine. I like the more accurate date f rom the engine side location. Both the red cube installation manual and APS recommend suspending the red c ube in a fuel line between servo and spider, not attached directly to crank c ase. I did that, wrapping cube in fire sleeve. It works well. Direct mounting to engine was advised against, although many folks seem to t ake that route with good results. Sent from my iPad > On Oct 18, 2016, at 11:06 AM, Kevin Belue wrote: > > I prefer the fuel transducer on the engine - much more accurate. I didn't l ike the inaccuracy when the electric fuel pump is on. No opinion on the rest ... > >> On Tue, Oct 18, 2016 at 12:39 PM, johngoodman wrote: > >> >> I have recently gotten partners in my RV-10, and we are converting it fro m my old LS1 engine, to a new IO-540 from Van. I'd like to get some input on several areas. >> >> First, The Red Cube - Tunnel or on the engine? >> >> Next, Remote Oil Filter - AirWolf, B&C, or the standard? Would like to kn ow how messy it can be with any of them. >> >> Cables or Actuators - Any comments on these for the Oil Cooler, and the h eat deflectors would be appreciated. >> >> Tips on what not to do on baffling also appreciated. >> >> Fire away! >> John >> >> -------- >> #40572 Phase One complete in 2011 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=461420#461420 >> >> >> >> >> >> >> >> ========================= >> -List" target="_blank" rel="noreferrer">http://www.matronics.com/Navi gator?RV10-List >> ========================= >> FORUMS - >> _blank" rel="noreferrer">http://forums.matronics.com >> ========================= >> WIKI - >> lank" rel="noreferrer">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> target="_blank" rel="noreferrer">http://www.matronics.com/contributio n >> ========================= >> >> >> > ________________________________________________________________________________
Date: Oct 20, 2016
Hi Jessie I'll be in FLA for 2-3 weeks and plan to do a bit of flying. I'd like to be close to Orlando but I do appreciate the offer though. Perhaps I'll get to drop by. Cheers Les jesse(at)saintaviation.co wrote: > Typical weather in FL is very nice unless a front is coming through. I could probably tuck you in the hangar at X35 for a little while. How long are you thinking? > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > > > On Oct 18, 2016, at 6:50 PM, kearney wrote: > > > > > > > > Hi > > > > In early January I am thinking of flying from Alberta Canada (think Montana) to Orlando Florida. > > > > The north west weather I am familiar with (that's why I going to Florida). What I am wondering about is the weather enroute. Typically is the weather that time of year reasonable? Somewhere along Nebraska / Kansas / Arkansas / Alabama / Georgia etc. > > > > Also, are there any short term hanger options that anyone can recommend near WDW (Orlando)? > > > > Cheers & and thanks for the advice. > > > > Les > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=461435#461435 > > > > > > > > > > > > > > > > > > > > > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461498#461498 ________________________________________________________________________________
Date: Oct 20, 2016
Hmmm Just for giggles I thought I'd comment on the high performance / complex rules in Canada. In Canada it is wing loading that determines whether or not the a/c is high performance. Although I did transition training with David Maib a while back, I didn't need the HP sign off for Canada. Interesting. Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461499#461499 ________________________________________________________________________________
Date: Oct 20, 2016
Tim, Ever consider getting your com/cfi? You'd have to rent an RG for some of it, but, given your daughter needs 20 hrs dual, the net cost might not be that great. Bob -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461500#461500 ________________________________________________________________________________
Date: Oct 20, 2016
I actually am entertaining that thought right now. Curious as to how quick I could make it happen. If I could be done by the end of the year or for sure by spring it may just work. Could save me a lot of headaches too. The kid flies real well. Would love to help her get it done. Tim > On Oct 20, 2016, at 11:47 PM, Bob Turner wrote: > > > Tim, > Ever consider getting your com/cfi? You'd have to rent an RG for some of it, but, given your daughter needs 20 hrs dual, the net cost might not be that great. > Bob > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461500#461500 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 21, 2016
There's been a notice of proposed rule making that, if accepted, would likely get rid of the requirement for the retract. An aircraft with a PFD and MFD would qualify as complex. Don't know the timeline of when t would be accepted, but most of our fleet would qualify. Anyone know when a decision is expected? Phil Sent from my iPhone > On Oct 20, 2016, at 11:59 PM, Tim Olson wrote: > > > I actually am entertaining that thought right now. Curious as to how quick I could make it happen. If I could be done by the end of the year or for sure by spring it may just work. Could save me a lot of headaches too. The kid flies real well. Would love to help her get it done. > > Tim > >> On Oct 20, 2016, at 11:47 PM, Bob Turner wrote: >> >> >> Tim, >> Ever consider getting your com/cfi? You'd have to rent an RG for some of it, but, given your daughter needs 20 hrs dual, the net cost might not be that great. >> Bob >> >> -------- >> Bob Turner >> RV-10 QB >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=461500#461500 >> >> >> >> >> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Subject: Re: Looking for Tips
Date: Oct 21, 2016
More of the same.... On 10/18/2016 1:39 PM, johngoodman wrote: > > I have recently gotten partners in my RV-10, and we are converting it from my old LS1 engine, to a new IO-540 from Van. I'd like to get some input on several areas. > > First, The Red Cube - Tunnel or on the engine? I don't have the Red Cube but rather the GRT(?) transducer. First had it mounted in tunnel and experienced the inaccuracies when the pump was run. Mounted it engine compartment - very accurate. Don't put it in the tunnel. > Next, Remote Oil Filter - AirWolf, B&C, or the standard? Would like to know how messy it can be with any of them. I went with the stock mounting - no problem. Easy to mount and remove - only challenge is dripping during removal. I have a plastic angle (roughly 2"x2"x4') that I stick under the filter during removal. Drips right into waste container. Many simple solutions to drip problem. > Cables or Actuators - Any comments on these for the Oil Cooler, and the heat deflectors would be appreciated. The stock cables melt and are slightly too short for quadrant. I replace them with longer ones from California Cable - recommend them and their product highly. Very fast turn around on well priced custom cables. > Tips on what not to do on baffling also appreciated. Silicon baffling material is great stuff in all respects. I used stock oil cooler. I occasionally had problems with oil being over cooled in NC winters. Running less oil (7 quarts at change - add to maintain at least 6) and adding a small fixed baffle fixed it. Never any problems with overheating oil. I have never calibrated my oil temp sensor. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 21, 2016
Hadn't seen that. You currently can get a two fer or a three fer if you go for a single engine sea with a plane that has retractable water rudders, and possibly over 200 hp. Yes, being able to retract water rudders does qualify for complex if the plane has constant speed and flaps. A C180 on floats could meet all three needs. The rating would also substitute for flight review, complex and hp endorsements. When I got my commercial there was the requirement for complex, but no HP endorsement existed, so flight schools mostly had Arrows, Cardinal RGs, a few Mooneys. Now a 182RG would let one get HP, complex at same time. Personally, I think allowing glass panel to substitute for complex misses the point. There is nothing about viewing a glass panel that adds any skill. Where would they draw the line? There is a huge difference between a G1000 aircraft (complex only in Garmin's menu structure) and a Grand Rapids or Dynon glass panel. Would 2 screens be required, or just one that you can split? Consider the Dynon Skyview or AFS units that allow display of six pack or EFIS at any time. Does IFR certification of the GPS make the plane complex or the ability to input a flight plan? Is IFR even considered as part of the proposal? -sent from the I-droid implanted in my forearm On Fri, Oct 21, 2016 at 4:31 AM, Phillip Perry wrote: > > There's been a notice of proposed rule making that, if accepted, would > likely get rid of the requirement for the retract. An aircraft with a PFD > and MFD would qualify as complex. > > Don't know the timeline of when t would be accepted, but most of our fleet > would qualify. > > Anyone know when a decision is expected? > > Phil > > > Sent from my iPhone > > > On Oct 20, 2016, at 11:59 PM, Tim Olson wrote: > > > > > > I actually am entertaining that thought right now. Curious as to how > quick I could make it happen. If I could be done by the end of the year or > for sure by spring it may just work. Could save me a lot of headaches > too. The kid flies real well. Would love to help her get it done. > > > > Tim > > > >> On Oct 20, 2016, at 11:47 PM, Bob Turner > wrote: > >> > >> > >> Tim, > >> Ever consider getting your com/cfi? You'd have to rent an RG for some > of it, but, given your daughter needs 20 hrs dual, the net cost might not > be that great. > >> Bob > >> > >> -------- > >> Bob Turner > >> RV-10 QB > >> > >> > >> > >> > >> Read this topic online here: > >> > >> http://forums.matronics.com/viewtopic.php?p=461500#461500 > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 21, 2016
Kelly, I think there's a little confusion in your post. HP and complex are endorsements given by a cfi. If going for a new rating, e.g. single engine sea, you are expected to show up for the flight test already having the endorsement (if required). I too am from the old days. But you have it backwards. 20 years ago there was no complex endorsement, only a high performance one. The latter applied to both over 200 HP and/or RG aircraft. You only needed one endorsement. So I got endorsed flying a 182, and was then go to go in an RG. Around 1995 when the rules changed, I was grandfathered in, so I have never gotten a complex endorsement although I may fly RG aircraft. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461507#461507 ________________________________________________________________________________
Date: Oct 21, 2016
Here's the article on the NPRM.. https://www.aopa.org/news-and-media/all-news/2016/may/12/proposed-part-61-ch anges-would-benefit-ga Sent from my iPhone > On Oct 21, 2016, at 10:30 AM, Bob Turner wrote: > > > Kelly, I think there's a little confusion in your post. HP and complex are endorsements given by a cfi. If going for a new rating, e.g. single engine s ea, you are expected to show up for the flight test already having the endor sement (if required). > I too am from the old days. But you have it backwards. 20 years ago there w as no complex endorsement, only a high performance one. The latter applied t o both over 200 HP and/or RG aircraft. You only needed one endorsement. So I got endorsed flying a 182, and was then go to go in an RG. Around 1995 when the rules changed, I was grandfathered in, so I have never gotten a complex endorsement although I may fly RG aircraft. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461507#461507 > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Oct 21, 2016
Here's the actual NPRM: https://www.regulations.gov/document?D=FAA-2016-6142-0001 The part of the proposal regarding complex aircraft is to allow the 10 hours of "complex time" currently required of commercial pilot applicants to be acquired, instead, in a TAA (glass cockpit). If implemented as proposed, it would change nothing about the endorsements required to fly complex or high performance aircraft, just to those to get a commercial certificate. The idea is that if you're training to become a commercial pilot, time in a 1970's 172RG is probably not as beneficial as time in a modern aircraft. I suspect a big part of the motivation is the fact that so many modern, high performance aircraft are now fixed gear, and maintaining a fleet of 172 RGs (what most flight schools use for "complex" training) is a bit of a silly burden. I think it's all a bit silly. Little of the training I did to acquire my ratings and little of the thousands of hours I spent flying around as an instructor in a single engine aircraft did much to prepare me to fly jets for the airlines. The fact that I'd spent a few dozen hours in an airplane that required me to flip the gear lever after takeoff and before landing certainly didn't do much to prepare me. And, yes, it might have been nice to have seen a glass cockpit at some point in my career before the CRJ simulator, but learning to read the glass was easy. Learning to think at 10 miles per minute was the hard part, but fortunately, the airlines (with serious FAA oversight) did a pretty good job of preparing me for that. On Fri, Oct 21, 2016 at 11:13 AM, Phillip Perry wrote: > Here's the article on the NPRM.. > > https://www.aopa.org/news-and-media/all-news/2016/may/12/ > proposed-part-61-changes-would-benefit-ga > > > Sent from my iPhone > > On Oct 21, 2016, at 10:30 AM, Bob Turner wrote: > > > Kelly, I think there's a little confusion in your post. HP and complex are > endorsements given by a cfi. If going for a new rating, e.g. single engine > sea, you are expected to show up for the flight test already having the > endorsement (if required). > I too am from the old days. But you have it backwards. 20 years ago there > was no complex endorsement, only a high performance one. The latter applied > to both over 200 HP and/or RG aircraft. You only needed one endorsement. So > I got endorsed flying a 182, and was then go to go in an RG. Around 1995 > when the rules changed, I was grandfathered in, so I have never gotten a > complex endorsement although I may fly RG aircraft. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461507#461507 > > > http://forums.matronics.comhttp://wiki.matronics.com==========================; - > List Contribution Wnbsp; -Matt Dralle, List > Admin.<======================================================== > > ________________________________________________________________________________
Date: Oct 21, 2016
I don't recall, but I don't think there was a high performance endorsement at the time I did my commercial, which required 10 hours of "complex" time. I think originally 180 hp was sufficient, as both Arrows and Mooneys came that way. Later I think 200 hp was required. It was NOT over 200 hp. When I got my private I could step right from C150 to C207, PA-32 or DHC 2 or DHC3 with no endorsement. (Beaver or Otter) that were tailwheel and 450 hp or ~600? hp. Insurance and common sense were the only restrictions. I was signed off, not as a formal endorsement for complex, never for tailwhell, HP etc. Grandfathered for all of that. Have flown PA-23 with pair of C4B5 250 hp engines and Mooney 231 with TSIO-360 (210 hp). Commercial and multi-engine rating in a 150 HP Apache or 160 hp Twin Comanche was enough to make you legally eligible to fly right seat in Part 121 airliner at that time. Kelly (don't need no stinkin endorsement) Yes I know you need sign-off for checkride. Checkride gets you flight review and the training in right aircraft gets you HP and complex endorsements, all without having any wheels, much less ones that retract. -sent from the I-droid implanted in my forearm On Fri, Oct 21, 2016 at 8:30 AM, Bob Turner wrote: > > Kelly, I think there's a little confusion in your post. HP and complex are > endorsements given by a cfi. If going for a new rating, e.g. single engine > sea, you are expected to show up for the flight test already having the > endorsement (if required). > I too am from the old days. But you have it backwards. 20 years ago there > was no complex endorsement, only a high performance one. The latter applied > to both over 200 HP and/or RG aircraft. You only needed one endorsement. So > I got endorsed flying a 182, and was then go to go in an RG. Around 1995 > when the rules changed, I was grandfathered in, so I have never gotten a > complex endorsement although I may fly RG aircraft. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461507#461507 > > ________________________________________________________________________________
Date: Oct 21, 2016
It seems to me that an EFIS could easily be tied to a switch, and read "gear up" or "gear down", depending on the 'gear switch'. And if you landed "gear up" the EFIS could put out horrible scrapping sounds. Close enough to the real thing? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461514#461514 ________________________________________________________________________________
Subject: Strutting my stufff - or doors
Date: Oct 23, 2016
Hi I have been reading past threads regarding higher strength door struts. With the weight of my doors, they do auto close more than is desirable. Till now I have been using stock Vans struts which fit quite well - they bottom out before the hinges are fully open. So what I need are drop in replacement struts that are about the same length or slightly shorter than stock. Will the A1A1F50-100-286-600N struts meet this requirement? My read of the threads is that they will but I'd like to make sure before I order them. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461551#461551 ________________________________________________________________________________
Subject: Re: Strutting my stufff - or doors
Date: Oct 25, 2016
Les and fellow builders, especially the Australian ones! My upholsterer put me onto a local supplier of gas struts (strutspecialists.com.au) based out of Perth in Western. Australia (Tel: +61 8 9445 9119) of all places and I was able to source two identical gas struts to the ones Vans supplies, but these ones are rated at 700N, for a very kind price of AU$38.00 for the pair (equates to about US$28.00). For those enquiring minds, my doors are upholstered and a tad heavier than the norm, thus the 700N. I hope that this helps guys Warm regards Patrick > On 24 Oct 2016, at 08:06, kearney wrote: > > > Hi > > I have been reading past threads regarding higher strength door struts. With the weight of my doors, they do auto close more than is desirable. > > Till now I have been using stock Vans struts which fit quite well - they bottom out before the hinges are fully open. So what I need are drop in replacement struts that are about the same length or slightly shorter than stock. > > Will the A1A1F50-100-286-600N struts meet this requirement? My read of the threads is that they will but I'd like to make sure before I order them. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461551#461551 > > > > > > > > > > ________________________________________________________________________________
Subject: PCU5000 Prop Gov recall
Date: Oct 25, 2016
According to my propeller shop the makers of the PCU5000 prop governors just issued a service letter for replacement of their balance weight assemblies exactly the same as MT. AT 2016-1 -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461607#461607 ________________________________________________________________________________
Date: Oct 25, 2016
Subject: Re: PCU5000 Prop Gov recall
Myron, anybody know where we can access this service bulliten/letter? Deems On Tue, Oct 25, 2016 at 9:14 AM, woxofswa wrote: > > According to my propeller shop the makers of the PCU5000 prop governors > just issued a service letter for replacement of their balance weight > assemblies exactly the same as MT. > > AT 2016-1 > > -------- > Myron Nelson > Mesa, AZ > Flew May 10 2014 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461607#461607 > > ________________________________________________________________________________
Date: Oct 25, 2016
Vic just posted it on VAF -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461610#461610 ________________________________________________________________________________
Date: Oct 25, 2016
While on a tour of the MT facility in Deland FL., I mentioned the prop gov problem. Office Manager Sarah said just call when you have questions. They also take care of the mod in their shop. Phone: (386) 736 7762 Linn On 10/25/2016 1:22 PM, Deems Davis wrote: > Myron, anybody know where we can access this service bulliten/letter? > > Deems > > On Tue, Oct 25, 2016 at 9:14 AM, woxofswa > wrote: > > > > > According to my propeller shop the makers of the PCU5000 prop > governors just issued a service letter for replacement of their > balance weight assemblies exactly the same as MT. > > AT 2016-1 > > -------- > Myron Nelson > Mesa, AZ > Flew May 10 2014 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461607#461607 > <http://forums.matronics.com/viewtopic.php?p=461607#461607> > > > =================================== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > ________________________________________________________________________________
Date: Oct 25, 2016
SSBsb29rZWQgYXQgbWFudWZhY3R1cmVyIHBhZ2UgYW5kIGxhc3QgU0Igd2FzIGluIDIwMDUtIGh0 dHA6Ly93d3cucGN1NTAwMC5jb20vDQoNCkZyb206IG93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0 cm9uaWNzLmNvbSBbbWFpbHRvOm93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0g T24gQmVoYWxmIE9mIERlZW1zIERhdmlzDQpTZW50OiBUdWVzZGF5LCBPY3RvYmVyIDI1LCAyMDE2 IDEwOjIzIEFNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6IFJlOiBSVjEw LUxpc3Q6IFBDVTUwMDAgUHJvcCBHb3YgcmVjYWxsDQoNCk15cm9uLCBhbnlib2R5IGtub3cgd2hl cmUgd2UgY2FuIGFjY2VzcyB0aGlzIHNlcnZpY2UgYnVsbGl0ZW4vbGV0dGVyPw0KDQpEZWVtcw0K DQpPbiBUdWUsIE9jdCAyNSwgMjAxNiBhdCA5OjE0IEFNLCB3b3hvZnN3YSA8d294b2ZAYW9sLmNv bTxtYWlsdG86d294b2ZAYW9sLmNvbT4+IHdyb3RlOg0KLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBv c3RlZCBieTogIndveG9mc3dhIiA8d294b2ZAYW9sLmNvbTxtYWlsdG86d294b2ZAYW9sLmNvbT4+ DQoNCkFjY29yZGluZyB0byBteSBwcm9wZWxsZXIgc2hvcCB0aGUgbWFrZXJzIG9mIHRoZSBQQ1U1 MDAwIHByb3AgZ292ZXJub3JzIGp1c3QgaXNzdWVkIGEgc2VydmljZSBsZXR0ZXIgZm9yIHJlcGxh Y2VtZW50IG9mIHRoZWlyIGJhbGFuY2Ugd2VpZ2h0IGFzc2VtYmxpZXMgZXhhY3RseSB0aGUgc2Ft ZSBhcyBNVC4NCg0KQVQgMjAxNi0xDQoNCi0tLS0tLS0tDQpNeXJvbiBOZWxzb24NCk1lc2EsIEFa DQpGbGV3IE1heSAxMCAyMDE0DQoNCg0KDQoNClJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZToN Cg0KaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD00NjE2MDcjNDYx NjA3DQoNCg0KDQoNCg0KDQoNCj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0K LUxpc3QiIHJlbD0ibm9yZWZlcnJlciIgdGFyZ2V0PSJfYmxhbmsiPmh0dHA6Ly93d3cubWF0cm9u aWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQo9PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0NCkZPUlVNUyAtDQplZmVycmVyIiB0YXJnZXQ9Il9ibGFuayI+aHR0cDovL2ZvcnVt cy5tYXRyb25pY3MuY29tDQo9PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCldJ S0kgLQ0KZXJyZXIiIHRhcmdldD0iX2JsYW5rIj5odHRwOi8vd2lraS5tYXRyb25pY3MuY29tDQo9 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCmIgU2l0ZSAtDQogICAgICAgICAg LU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KcmVsPSJub3JlZmVycmVyIiB0YXJnZXQ9Il9ibGFu ayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09DQoNCg0KDQo ________________________________________________________________________________
Date: Oct 25, 2016
Aero Technologies, LLC SERVICE LETTER AT2016-1 October 20, 2016 SUBJECT: Flyweight design change. MODEL AFFECTED: All PCU5000 and PCU5000X SERVICE MANUAL AFFECTED: Maintenance/Overhaul Manual AT1431299 Rev. 2 This service information is to be added to the appropriate Aero Technologies Maintenance Manual until the next manual revision is released. NEW FLYWEIGHT DESIGN TO REPLACE CURRENT DESIGN REQUIREMENTS 1) Current Flyweight assembly part number AT1438426 is still able to be overhauled until the supply of Safety Spring part number AT1430591 is exhausted. 2) New Flyweight Assembly part number AT1438504 (drawing page 2). a) AT1430685, Flyweight head b) AT1430522, Flyweight (requires 2) c) AT4420170, Needle (requires 2) d) AT4402020, pin (requires 4) AT1438504 is a direct replacement for the AT1438426 Flyweight assembly and does not change fit, form, or function of the PCU5000 governor. APPROVAL: FAA approval has been obtained on technical data in this publication that affects product type design. To obtain satisfactory results, procedures specified in this service information must be accomplished in accordance with accepted methods and prevailing government regulations. Aero Technologies cannot be responsible for the quality of work performed in accomplishing this service information. Aero Technologies, LLC 595 Telser Road Lake Zurich, IL 60047 -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461617#461617 ________________________________________________________________________________
Date: Oct 26, 2016
The way I read it, it's just for overhaul shops working on PCU5000s, if they get one. It's not a recall. John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461633#461633 ________________________________________________________________________________
Date: Oct 26, 2016
MT governors were not a recall either, just a service bulletin with some misleading information as to what governors needed upgrade. BTW my MT governor is noticeably more responsive and a little more sensitive since the upgrade, as the new flyweights are a little heavier. Kelly -sent from the I-droid implanted in my forearm On Wed, Oct 26, 2016 at 7:03 AM, johngoodman wrote: > > The way I read it, it's just for overhaul shops working on PCU5000s, if > they get one. It's not a recall. > > John > > -------- > #40572 Phase One complete in 2011 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461633#461633 > > ________________________________________________________________________________
Subject: PCU500/x Service Letter
Date: Oct 26, 2016
Hi I just spoke to Aerotechnical about this service letter. Here are the facts as given to me: 1. The MT prop flyweights and PCU500O flyweights are made by different manufacturers 2. This service letter has been in the works for a year - it is not the result of technical issues 3. The service letter is a result of the company standardizing parts between their turbine and reciprocating engine design / parts. 4. This does not affect the PCU overhaul requirements (7 years TIS or TBO whichever occurs first). I suggested that they post a note on VAF as peiople seem to be inferring that this letter is related to the MT recall (which it is not). In short, nothing to see here.... Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461641#461641 ________________________________________________________________________________
Date: Nov 01, 2016
Subject: PLEASE READ - Matronics Email List 2016 Fund Raiser During
November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 24 different gifts to choose from! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Corbin Glowacki of My Pilot Store http://www.mypilotstore.com George Race of Race Consulting http://www.mrrace.com/ Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product line. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 03, 2016
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Quick Question
Date: Nov 03, 2016
We are getting ready to hang our engine, and I'm wondering about the control cable pass throughs on the plans for the F1007K Recess. They seem to be off to the side, because it would otherwise hit something. You folks that have already completed one, what's the story - can another pass through be located on the recess, and where? Any caveats? We are not doing anything funky, such as relocating the IO-540 oil filter. John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461991#461991 ________________________________________________________________________________
Date: Nov 03, 2016
Subject: Re: Quick Question
I've never tried a different location. Part of the issue is the length of the cables and how they attach to the bracket that goes between the fuel servo and the engine sump. If you locate them differently, you need to make sure your lengths will work fine and that the cables can enter the bracket at the correct angle. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Nov 3, 2016, at 7:30 PM, johngoodman wrote: > > > We are getting ready to hang our engine, and I'm wondering about the control cable pass throughs on the plans for the F1007K Recess. They seem to be off to the side, because it would otherwise hit something. > You folks that have already completed one, what's the story - can another pass through be located on the recess, and where? Any caveats? We are not doing anything funky, such as relocating the IO-540 oil filter. > > John > > -------- > #40572 Phase One complete in 2011 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461991#461991 > > > > > > > > > ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Nov 03, 2016
I used the provided holes. They worked. Note, while the Van's recommended mixture and prop cables worked, the recommended throttle cable was too short. I sent it back to Van's and exchanged it for the 50.5" cable the list for the RV-7. That one fits well. Carl > On Nov 3, 2016, at 7:30 PM, johngoodman wrote: > > > We are getting ready to hang our engine, and I'm wondering about the control cable pass throughs on the plans for the F1007K Recess. They seem to be off to the side, because it would otherwise hit something. > You folks that have already completed one, what's the story - can another pass through be located on the recess, and where? Any caveats? We are not doing anything funky, such as relocating the IO-540 oil filter. > > John > > -------- > #40572 Phase One complete in 2011 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461991#461991 > > > > > > > > > ________________________________________________________________________________
Date: Nov 03, 2016
I found that all 3 passing through the factory holes was too close and severely disfigured the small sliver of stainless between each of the holes. I instead covered those holes and made 3 new holes, where I wanted them, in the recess. They're finished out with eyeball pass throughs. I wish I had never drilled the original holes to size. I had to build a stainless plate to rivet over them with pro-seal to seal it. It would have been easier and better just to drop a rivet in the holes and move in with real holes where they worked better with the material. Sent from my iPhone > On Nov 3, 2016, at 6:30 PM, johngoodman wrote: > > > We are getting ready to hang our engine, and I'm wondering about the control cable pass throughs on the plans for the F1007K Recess. They seem to be off to the side, because it would otherwise hit something. > You folks that have already completed one, what's the story - can another pass through be located on the recess, and where? Any caveats? We are not doing anything funky, such as relocating the IO-540 oil filter. > > John > > -------- > #40572 Phase One complete in 2011 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=461991#461991 > > > > > > > > > ________________________________________________________________________________
Date: Nov 03, 2016
Perhaps you drilled the holes too big. I remember needing to strip the control cables of all hardware and rubber fairings to fit through the grommets. Carl > On Nov 3, 2016, at 8:07 PM, Phillip Perry wrote: > > > I found that all 3 passing through the factory holes was too close and severely disfigured the small sliver of stainless between each of the holes. I instead covered those holes and made 3 new holes, where I wanted them, in the recess. They're finished out with eyeball pass throughs. > > I wish I had never drilled the original holes to size. I had to build a stainless plate to rivet over them with pro-seal to seal it. It would have been easier and better just to drop a rivet in the holes and move in with real holes where they worked better with the material. > > > > Sent from my iPhone > >> On Nov 3, 2016, at 6:30 PM, johngoodman wrote: >> >> >> We are getting ready to hang our engine, and I'm wondering about the control cable pass throughs on the plans for the F1007K Recess. They seem to be off to the side, because it would otherwise hit something. >> You folks that have already completed one, what's the story - can another pass through be located on the recess, and where? Any caveats? We are not doing anything funky, such as relocating the IO-540 oil filter. >> >> John >> >> -------- >> #40572 Phase One complete in 2011 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=461991#461991 >> >> >> >> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Nov 03, 2016
That's what I did too, but didn't have much success with my Installation. Sent from my iPhone > On Nov 3, 2016, at 7:46 PM, Carl Froehlich wrote: > > > Perhaps you drilled the holes too big. I remember needing to strip the control cables of all hardware and rubber fairings to fit through the grommets. > > Carl > >> On Nov 3, 2016, at 8:07 PM, Phillip Perry wrote: >> >> >> I found that all 3 passing through the factory holes was too close and severely disfigured the small sliver of stainless between each of the holes. I instead covered those holes and made 3 new holes, where I wanted them, in the recess. They're finished out with eyeball pass throughs. >> >> I wish I had never drilled the original holes to size. I had to build a stainless plate to rivet over them with pro-seal to seal it. It would have been easier and better just to drop a rivet in the holes and move in with real holes where they worked better with the material. >> >> >> >> Sent from my iPhone >> >>> On Nov 3, 2016, at 6:30 PM, johngoodman wrote: >>> >>> >>> We are getting ready to hang our engine, and I'm wondering about the control cable pass throughs on the plans for the F1007K Recess. They seem to be off to the side, because it would otherwise hit something. >>> You folks that have already completed one, what's the story - can another pass through be located on the recess, and where? Any caveats? We are not doing anything funky, such as relocating the IO-540 oil filter. >>> >>> John >>> >>> -------- >>> #40572 Phase One complete in 2011 >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=461991#461991 >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Nov 04, 2016
I really appreciate the replies, but I was wondering about the fourth cable to the alternate air. If we use a cable pass through instead of the specified grommets, is there a good place for the fourth one? Also, IF we use Actuators (instead of cables) for the heat, could a pass through for electrical wires work in the recess? We are actually thinking of a single actuator for the rear seat heat control. John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=462000#462000 ________________________________________________________________________________
Date: Nov 04, 2016
John, as Carl and Phil mentioned, I too used the original holes. I made custom SS fittings for my firewall/cables and wished I had spread the fittings out a bit. If you're using fire sleeve etc, getting a gear clamp secured is a bit more difficult. Why not spread them out a bit? Of course you may end up with cables that are too short. I replaced my throttle cable with the RV7 length, and bought a McFarlane cable for the mixture. All in all, it worked out well. Rick #40956 Southampton, Ont On Fri, Nov 4, 2016 at 7:50 AM, johngoodman wrote: > > I really appreciate the replies, but I was wondering about the fourth > cable to the alternate air. If we use a cable pass through instead of the > specified grommets, is there a good place for the fourth one? > Also, IF we use Actuators (instead of cables) for the heat, could a pass > through for electrical wires work in the recess? We are actually thinking > of a single actuator for the rear seat heat control. > > John > > -------- > #40572 Phase One complete in 2011 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=462000#462000 > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Nov 04, 2016
John, I did not like having the other controls mixed in with the engine and prop controls. I moved the Engine Alt Air to the left side of the panel apron, next to the Oil Cooler Air butterfly valve control. The two cabin heat controls on mid way on the right side of the apron. I replaced the provided piece of angle for the engine controls with a new piece of aluminum (I bent a piece of 0.050). In the attached photo the far left red control is for Engine Alt Air. The black control next to it is for oil cooler air. One other thing I did was to add a piece of 3/4" x 3/4" .063 aluminum between the apron (near the engine controls) and the firewall. I did not link the apron flex when moving the controls - the angle provides a much more solid feel. Note - this is the second panel in the RV-10. The first one lasted about 18 months. Since this photo the panel has again been twice modified to add the Dynon Knob Panel (I don't know how I lived without it) and breakers and light for a B&C aux alternator. My point being make sure you plan on panel changes and modifications. You will not know what you want until after you have some hours in the plane. For me replacing a panel is a new $27 panel blank from Van's, cutting some holes and paint. If you get one of the really nice custom panels your may find a modification harder to perform. Carl RV-8A (sold 2012) RV-10 (sold 2016) RV-8 (waiting for all the kits to arrive next month) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Friday, November 04, 2016 7:51 AM Subject: RV10-List: Re: Quick Question --> I really appreciate the replies, but I was wondering about the fourth cable to the alternate air. If we use a cable pass through instead of the specified grommets, is there a good place for the fourth one? Also, IF we use Actuators (instead of cables) for the heat, could a pass through for electrical wires work in the recess? We are actually thinking of a single actuator for the rear seat heat control. John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=462000#462000 ________________________________________________________________________________
Subject: Lord -20 vs -28 vibration mounts
Date: Nov 05, 2016
I recently balanced my prop, and it's down to 0.01 IPS now but i still get some vibration that makes the sun visors shake more than I like. Turns out my VIP mounts have compressed some and there's a gap between the vibration mount and the engine mount. Unfortunately I didn't take a picture but it looks similar to this: http://i60.tinypic.com/2vkxq2u.jpg Has anyone had this issue before? I was looking into getting new Lord mounts. Van's sells them for around $125 a piece, they are J-3804-20. Lord also has a J-3804-28 model with silicone filled spacers that supposedly help startup and shutdown engine shaking. Sounds great, but the price is $246.95 at AircraftSpruce. Is anyone using these 28s, and are they worth double the money? Thanks, Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=462015#462015 ________________________________________________________________________________
Date: Nov 05, 2016
Subject: Re: Lord -20 vs -28 vibration mounts
We have a -8 with a 540 on it in the hangar now for annual. The mounts on it were in need of replacement too. We talked to Lord about this same question and they initially gave us replacement part numbers with the updated elastomer and isn't realize it. We were confused because the parts we had in hand were a different part number. After placing another call to Lord, we realized that we had the old elastomer part (and numbers). He said that, when they could, they're directing people to the new elastomer because of longevity. Apparently it doesn't break down as quickly with heat and chemicals; where the rubber apparently does. I have no real world experience with it beyond that. But did find the exercise enlightening. Whether it plays out in the long run or not remains to be seen.... Phil Sent from my iPhone > On Nov 5, 2016, at 11:22 AM, Lenny Iszak wrote: > > > I recently balanced my prop, and it's down to 0.01 IPS now but i still get some vibration that makes the sun visors shake more than I like. > Turns out my VIP mounts have compressed some and there's a gap between the vibration mount and the engine mount. Unfortunately I didn't take a picture but it looks similar to this: > > http://i60.tinypic.com/2vkxq2u.jpg > > Has anyone had this issue before? > I was looking into getting new Lord mounts. Van's sells them for around $125 a piece, they are J-3804-20. > Lord also has a J-3804-28 model with silicone filled spacers that supposedly help startup and shutdown engine shaking. Sounds great, but the price is $246.95 at AircraftSpruce. > > Is anyone using these 28s, and are they worth double the money? > > Thanks, > Lenny > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=462015#462015 > > > > > > > > > ________________________________________________________________________________
Date: Nov 05, 2016
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Another Source - Heavy duty gas struts
Date: Nov 06, 2016
Hi My hanger mate finally shamed me into replacing my door gas struts that would auto close when open. When googling suppliers I came across a Canadian company who made drop in replacements for the Van struts. The cost was $30CDN ($22.50 USD) each plus shipping. I had them in 3 days from order. The company is LS Technologies (www.lstechnologies.ca) and can be reached at (306) 683-5000. I was speaking with Nolan Fehr who was most helpful. Below is the part # label showing what I ordered. They are 600N struts that hold my heavy door door up quite nicely - the end of stroke dampening is excellent. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=462114#462114 Attachments: http://forums.matronics.com//files/img_5931_844.jpg ________________________________________________________________________________
Subject: Slick 6300 Series Mag Timing (made easy)
Date: Nov 06, 2016
Slick 6300 Mags ohm Lycoming D4A5 IO-540 engines are driven by a pair of dogs 180 degrees apart. The dogs fit into (2) slots in the engine magneto drive shaft. The mag will fit on the engine magneto mount only one of two ways, 180 degrees apart. Before removing the mag(s) take a center punch or felt marker and mark adjoining places on the mag and its mounting bracket. This will give you a nice reference when you put the mag back on the engine. Make note of what position the distributor cap is on the back of the mag. Remove it with a T20 Torx tip and 1/4" wrench. It has to be put back on the mag in the same relative position (It will fit in any of (3) 120 degree positions). Make sure the ignition switch is off. Remove the number one cylinder plug and turn the prop in its normal direction placing your thumb over the spark plug hole until air comes out. The piston is on the compression stroke approaching TDC. Timing marks are on the back side of the starter ring gear plate and or on the front side of the ring gear plate. The back side marks align with the top split in the crank case and the front side marks align with a hole in the starter (see Lycoming's service manual). Turn the prop until 25 degrees BTC aligns with either reference. To tell what 180 degree position the mag shaft needs to be in when putting the mag back on the engine, poke a timing pin (a number 12 ga copper wire works well) in the "L" hole in the distributor block. You will note that the "L" hole and "R" holes are 180 degrees apart. There is an "X" hole between the "L" and "R" holes for a laser setting of the timing. Turn the mag clockwise (looking at the engine side of the mag--opposite to the left hand rotation of the mag) while gently pushing the timing pin in the hole. The timing pin will drop down into a hole in the distributor gear preventing the mag shaft from turning further. Be careful not to damage the gear by turning the mag shaft too hard against the stop. This places the mag shaft in the right 180 degree position for timing the mag. The marks (center punch or felt marker) will let you put the mag back on the engine close to its original timed position. You can finish timing the mag with a timing light, buzz box, ohm meter, etc. Remove the timing pin. Put the mag back on the engine taking care not to turn the mag shaft so much that it would be 180 degrees out of the timing pin position you determined. Make sure the black hard rubber blocks in the engine mag gear slots didn't come out when the mag was removed. You can put them back in with a little grease to hold them in place. Gently snug up the mounting blocks and nuts on the mag to hold it from turning while you check the timing. The points open at 25 degrees BTC. Set the timing by gently turning the mag. Turning the mag into its left hand rotation (counter clockwise looking at the back) advances the time. Clockwise reduces the time. Check the timing by removing the ignition wire from the P-lead and connecting your timing device to the P-terminal of the mag. Make sure the ignition switch is in the "off" position so you can't have a hot mag. You can time the mag with an ohm meter. The meter will read a few ohms and then increase an ohm or two when the points "open". It will not go to infinity, etc. as one might expect. Check the timing either side of 25 degrees BTC by bumping the propeller back and forth while watching your ohm meter, buzz box, timing light, etc. Once you think it is timed, rotate the prop two full revolutions and check the timing again. If the timing is right, tighten the mag mounting nuts and check the timing one last time. Reassemble the mag, distributor cap, ignition wire, spark plug, etc. If the engine will not start or will not run on either mag, the mag(s) are 180 degrees out of time. You can get specific mag repairs and internal mag adjustment information from the Slick Overhaul Manual. Doc RV10 #41087 N123CV ________________________________________________________________________________
Date: Nov 06, 2016
Subject: Re: Slick 6300 Series Mag Timing (made easy)
I agree with most of this except "It has to be put back on the mag in the same relative position (It will fit in any of (3) 120 degree positions)." All the mags I have installed the harness cap can only fit in one position. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 Sent from my iPhone > On Nov 6, 2016, at 6:46 PM, Doc wrote: > > It has to be put back on the mag in the same relative position (It will fit in any of (3) 120 degree positions). ________________________________________________________________________________
Date: Nov 06, 2016
The RV-10 is the first airplane I've owned with mags - and reading stuff like this I pray it will be the last. Just turned 400 hrs on the from the factory Slick Mags and keeping my fingers crossed that Brad at pMag sends me the new six cylinder ignitions before I need to do the 500 hour check. Carl > On Nov 6, 2016, at 6:46 PM, Doc wrote: > > > Slick 6300 Mags ohm Lycoming D4A5 IO-540 engines are driven by a pair of dogs 180 degrees apart. The dogs fit into (2) slots in the engine magneto drive shaft. The mag will fit on the engine magneto mount only one of two ways, 180 degrees apart. > > Before removing the mag(s) take a center punch or felt marker and mark adjoining places on the mag and its mounting bracket. This will give you a nice reference when you put the mag back on the engine. Make note of what position the distributor cap is on the back of the mag. Remove it with a T20 Torx tip and 1/4" wrench. It has to be put back on the mag in the same relative position (It will fit in any of (3) 120 degree positions). > > Make sure the ignition switch is off. Remove the number one cylinder plug and turn the prop in its normal direction placing your thumb over the spark plug hole until air comes out. The piston is on the compression stroke approaching TDC. Timing marks are on the back side of the starter ring gear plate and or on the front side of the ring gear plate. The back side marks align with the top split in the crank case and the front side marks align with a hole in the starter (see Lycoming's service manual). > > Turn the prop until 25 degrees BTC aligns with either reference. > > To tell what 180 degree position the mag shaft needs to be in when putting the mag back on the engine, poke a timing pin (a number 12 ga copper wire works well) in the "L" hole in the distributor block. You will note that the "L" hole and "R" holes are 180 degrees apart. There is an > "X" hole between the "L" and "R" holes for a laser setting of the timing. > > Turn the mag clockwise (looking at the engine side of the mag--opposite to the left hand rotation of the mag) while gently pushing the timing pin in the hole. The timing pin will drop down into a hole in the distributor gear preventing the mag shaft from turning further. Be careful not to damage the gear by turning the mag shaft too hard against the stop. This places the mag shaft in the right 180 degree position for timing the mag. The marks (center punch or felt marker) will let you put the mag back on the engine close to its original timed position. You can finish timing the mag with a timing light, buzz box, ohm meter, etc. > > Remove the timing pin. Put the mag back on the engine taking care not to turn the mag shaft so much that it would be 180 degrees out of the timing pin position you determined. Make sure the black hard rubber blocks in the engine mag gear slots didn't come out when the mag was removed. You can put them back in with a little grease to hold them in place. > > Gently snug up the mounting blocks and nuts on the mag to hold it from turning while you check the timing. The points open at 25 degrees BTC. Set the timing by gently turning the mag. Turning the mag into its left hand rotation (counter clockwise looking at the back) advances the time. Clockwise reduces the time. > > Check the timing by removing the ignition wire from the P-lead and connecting your timing device to the P-terminal of the mag. Make sure the ignition switch is in the "off" position so you can't have a hot mag. You can time the mag with an ohm meter. The meter will read a few ohms and then increase an ohm or two when the points "open". It will not go to infinity, etc. as one might expect. Check the timing either side of 25 degrees BTC by bumping the propeller back and forth while watching your ohm meter, buzz box, timing light, etc. Once you think it is timed, rotate the prop two full revolutions and check the timing again. If the timing is right, tighten the mag mounting nuts and check the timing one last time. Reassemble the mag, distributor cap, ignition wire, spark plug, etc. > > If the engine will not start or will not run on either mag, the mag(s) are 180 degrees out of time. > > You can get specific mag repairs and internal mag adjustment information from the Slick Overhaul Manual. > > Doc RV10 #41087 N123CV > > > > > > ________________________________________________________________________________
Date: Nov 07, 2016
Subject: Re: Another Source - Heavy duty gas struts
Date: Nov 08, 2016
I got similarly priced gas struts from a local company here in Australia. Warm regards Patrick > On 7 Nov 2016, at 09:35, kearney wrote: > > > Hi > > My hanger mate finally shamed me into replacing my door gas struts that would auto close when open. > > When googling suppliers I came across a Canadian company who made drop in replacements for the Van struts. The cost was $30CDN ($22.50 USD) each plus shipping. > > I had them in 3 days from order. The company is LS Technologies (www.lstechnologies.ca) and can be reached at (306) 683-5000. I was speaking with Nolan Fehr who was most helpful. > > Below is the part # label showing what I ordered. They are 600N struts that hold my heavy door door up quite nicely - the end of stroke dampening is excellent. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=462114#462114 > > > > > Attachments: > > http://forums.matronics.com//files/img_5931_844.jpg > > > > > > ________________________________________________________________________________
Date: Nov 08, 2016
Hi Patrick, What was the name of the company and the part number of the gas struts. I literally broke on on the weekend. :-( Regards, Andrew. On 08-Nov-16 9:18 PM, Patrick Pulis wrote: > > I got similarly priced gas struts from a local company here in Australia. > > Warm regards > > Patrick > >> On 7 Nov 2016, at 09:35, kearney wrote: >> >> >> Hi >> >> My hanger mate finally shamed me into replacing my door gas struts that would auto close when open. >> >> When googling suppliers I came across a Canadian company who made drop in replacements for the Van struts. The cost was $30CDN ($22.50 USD) each plus shipping. >> >> I had them in 3 days from order. The company is LS Technologies (www.lstechnologies.ca) and can be reached at (306) 683-5000. I was speaking with Nolan Fehr who was most helpful. >> >> Below is the part # label showing what I ordered. They are 600N struts that hold my heavy door door up quite nicely - the end of stroke dampening is excellent. >> >> Cheers >> >> Les >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=462114#462114 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/img_5931_844.jpg >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Nov 08, 2016
Subject: Caulk around windows?
Have any of you ran a bead of caulk around the interior side of the windows to make a fillet that transitions the glass to the cabin top? I'm staring at a mixed pot of pro-seal (my current plan) but really don't want to string that oooey gooey stuff all rebound the inside of the windscreen. So before I did, I thought I'd ask the caulk question first. My specific concern about caulk is crazing after long-term application. So if you have used caulk, what type did you use and how long has it been applied to the glass? Otherwise I'll just continue down the proseal path.... Thanks, Phil Sent from my iPhone ________________________________________________________________________________
Date: Nov 08, 2016
SSB3aXNoIEkgaGFkIGJldmVsbGVkIHRoZSBlZGdlIG9uIHRoZSBpbnNpZGUgb2YgdGhlIHdpbmRv d3MgLi4uLiBidXQgZGlkbid0LiBUaGVyZSdzIG5vIHJlYXNvbiBub3QgdG8uCkxpbm4KCgpTZW50 IGZyb20gU2Ftc3VuZyB0YWJsZXQgY3J1aXNpbmcgb24gdGhlIE9hc2lzIE9mIFRoZSBTZWFzLgoK LS0tLS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLQpGcm9tIFBoaWxsaXAgUGVycnkgPHBo aWxwZXJyeTlAZ21haWwuY29tPiAKRGF0ZTogMTEvMDgvMjAxNiAgMjo1MyBQTSAgKEdNVC0wNTow MCkgClRvIHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tIApTdWJqZWN0IFJWMTAtTGlzdDogQ2F1bGsg YXJvdW5kIHdpbmRvd3M/IAogCi0tPiBSVjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IFBoaWxs aXAgUGVycnkgPHBoaWxwZXJyeTlAZ21haWwuY29tPgoKSGF2ZSBhbnkgb2YgeW91IHJhbiBhIGJl YWQgb2YgY2F1bGsgYXJvdW5kIHRoZSBpbnRlcmlvciBzaWRlIG9mIHRoZSB3aW5kb3dzIHRvIG1h a2UgYSBmaWxsZXQgdGhhdCB0cmFuc2l0aW9ucyB0aGUgZ2xhc3MgdG8gdGhlIGNhYmluIHRvcD8K CkknbSBzdGFyaW5nIGF0IGEgbWl4ZWQgcG90IG9mIHByby1zZWFsIChteSBjdXJyZW50IHBsYW4p IGJ1dCByZWFsbHkgZG9uJ3Qgd2FudCB0byBzdHJpbmcgdGhhdCBvb29leSBnb29leSBzdHVmZiBh bGwgcmVib3VuZCB0aGUgaW5zaWRlIG9mIHRoZSB3aW5kc2NyZWVuLsKgwqAgU28gYmVmb3JlIEkg ZGlkLCBJIHRob3VnaHQgSSdkIGFzayB0aGUgY2F1bGsgcXVlc3Rpb24gZmlyc3QuwqAgCgpNeSBz cGVjaWZpYyBjb25jZXJuIGFib3V0IGNhdWxrIGlzIGNyYXppbmcgYWZ0ZXIgbG9uZy10ZXJtIGFw cGxpY2F0aW9uLsKgIAoKU28gaWYgeW91IGhhdmUgdXNlZCBjYXVsaywgd2hhdCB0eXBlIGRpZCB5 b3UgdXNlIGFuZCBob3cgbG9uZyBoYXMgaXQgYmVlbiBhcHBsaWVkIHRvIHRoZSBnbGFzcz8KCk90 aGVyd2lzZSBJJ2xsIGp1c3QgY29udGludWUgZG93biB0aGUgcHJvc2VhbCBwYXRoLi4uLsKgIAoK VGhhbmtzLApQaGlsCgoKClNlbnQgZnJvbSBteSBpUGhvbmUKXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09Cl8tPcKgwqDCoMKg wqDCoCAtLSBQbGVhc2UgU3VwcG9ydCBZb3VyIExpc3RzIFRoaXMgTW9udGggLS0KXy09wqDCoMKg wqDCoMKgwqDCoMKgwqAgKEFuZCBHZXQgU29tZSBBV0VTT01FIEZSRUUgR2lmdHMhKQpfLT0KXy09 wqDCoCBOb3ZlbWJlciBpcyB0aGUgQW5udWFsIExpc3QgRnVuZCBSYWlzZXIuwqAgQ2xpY2sgb24K Xy09wqDCoCB0aGUgQ29udHJpYnV0aW9uIGxpbmsgYmVsb3cgdG8gZmluZCBvdXQgbW9yZSBhYm91 dApfLT3CoMKgIHRoaXMgeWVhcidzIFRlcnJpZmljIEZyZWUgSW5jZW50aXZlIEdpZnRzIHByb3Zp ZGVkCl8tPcKgwqAgYnk6Cl8tPcKgwqAgCl8tPcKgwqDCoMKgICogQWVyb0VsZWN0cmljIHd3dy5h ZXJvZWxlY3RyaWMuY29tCl8tPcKgwqDCoMKgICogVGhlIEJ1aWxkZXIncyBCb29rc3RvcmUgd3d3 LmJ1aWxkZXJzYm9va3MuY29tCl8tPcKgwqDCoMKgICogSG9tZWJ1aWx0SEVMUCB3d3cuaG9tZWJ1 aWx0aGVscC5jb20KXy09wqDCoMKgwqAgKiBNeSBQaWxvdCBTdG9yZSB3d3cubXlwaWxvdHN0b3Jl LmNvbQpfLT3CoMKgwqDCoCAqIFJhY2UgQ29uc3VsdGluZyB3d3cubXJyYWNlLmNvbQpfLT0KXy09 wqDCoCBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZToKXy09Cl8tPcKgwqAgLS0+IGh0dHA6Ly93 d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24KXy09Cl8tPcKgwqAgVGhhbmsgeW91IGZvciB5 b3VyIGdlbmVyb3VzIHN1cHBvcnQhCl8tPQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4K Xy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoCAtIFRoZSBSVjEwLUxpc3QgRW1haWwgRm9y dW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJv d3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0 aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBG QVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT3CoMKgIC0tPiBo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdApfLT0KXy09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09 wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09 IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8t PQpfLT3CoMKgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20KXy09Cl8tPT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPcKg wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC0gTkVXIE1BVFJPTklDUyBMSVNUIFdJS0kgLQpfLT0g QWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNzIEVtYWlsIExpc3QgV2lraSEKXy09wqDCoCAt LT4gaHR0cDovL3dpa2kubWF0cm9uaWNzLmNvbQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPcKgIFRoYW5rIHlvdSBmb3Ig eW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4KXy09 wqDCoCAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpfLT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQoKCgo ________________________________________________________________________________
Date: Nov 08, 2016
SXMgdGhlcmUgYSB3YXkgdG8gZnJldCB0aGUgd2luZG93cyBsaWtlIHRoZXkgZG8gaW4gYXV0b21v dGl2ZSBhcHBsaWNhdGlvbnMsICBJIGtub3cgb25lIGlzIGdsYXNzICwgYnV0IFNJS0EgbWFrZXMg cHJpbWVycyBzbyB0aGUgd2luZHNjcmVlbiBjYW4gaGFuZGxlIHRoZSBjYXVsa2luZw0KDQpGcm9t OiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1ydjEw LWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBMaW5uIFdhbHRlcnMNClNl bnQ6IFR1ZXNkYXksIE5vdmVtYmVyIDgsIDIwMTYgMzoxMSBQTQ0KVG86IHJ2MTAtbGlzdEBtYXRy b25pY3MuY29tDQpTdWJqZWN0OiBSRTogUlYxMC1MaXN0OiBDYXVsayBhcm91bmQgd2luZG93cz8N Cg0KSSB3aXNoIEkgaGFkIGJldmVsbGVkIHRoZSBlZGdlIG9uIHRoZSBpbnNpZGUgb2YgdGhlIHdp bmRvd3MgLi4uLiBidXQgZGlkbid0LiBUaGVyZSdzIG5vIHJlYXNvbiBub3QgdG8uDQpMaW5uDQoN Cg0KU2VudCBmcm9tIFNhbXN1bmcgdGFibGV0IGNydWlzaW5nIG9uIHRoZSBPYXNpcyBPZiBUaGUg U2Vhcy4NCg0KDQotLS0tLS0tLSBPcmlnaW5hbCBtZXNzYWdlIC0tLS0tLS0tDQpGcm9tIFBoaWxs aXAgUGVycnkgPHBoaWxwZXJyeTlAZ21haWwuY29tPG1haWx0bzpwaGlscGVycnk5QGdtYWlsLmNv bT4+DQpEYXRlOiAxMS8wOC8yMDE2IDI6NTMgUE0gKEdNVC0wNTowMCkNClRvIHJ2MTAtbGlzdEBt YXRyb25pY3MuY29tPG1haWx0bzpydjEwLWxpc3RAbWF0cm9uaWNzLmNvbT4NClN1YmplY3QgUlYx MC1MaXN0OiBDYXVsayBhcm91bmQgd2luZG93cz8NCg0KDQotLT4gUlYxMC1MaXN0IG1lc3NhZ2Ug cG9zdGVkIGJ5OiBQaGlsbGlwIFBlcnJ5IDxwaGlscGVycnk5QGdtYWlsLmNvbTxtYWlsdG86cGhp bHBlcnJ5OUBnbWFpbC5jb20+Pg0KDQpIYXZlIGFueSBvZiB5b3UgcmFuIGEgYmVhZCBvZiBjYXVs ayBhcm91bmQgdGhlIGludGVyaW9yIHNpZGUgb2YgdGhlIHdpbmRvd3MgdG8gbWFrZSBhIGZpbGxl dCB0aGF0IHRyYW5zaXRpb25zIHRoZSBnbGFzcyB0byB0aGUgY2FiaW4gdG9wPw0KDQpJJ20gc3Rh cmluZyBhdCBhIG1peGVkIHBvdCBvZiBwcm8tc2VhbCAobXkgY3VycmVudCBwbGFuKSBidXQgcmVh bGx5IGRvbid0IHdhbnQgdG8gc3RyaW5nIHRoYXQgb29vZXkgZ29vZXkgc3R1ZmYgYWxsIHJlYm91 bmQgdGhlIGluc2lkZSBvZiB0aGUgd2luZHNjcmVlbi4gICBTbyBiZWZvcmUgSSBkaWQsIEkgdGhv dWdodCBJJ2QgYXNrIHRoZSBjYXVsayBxdWVzdGlvbiBmaXJzdC4NCg0KTXkgc3BlY2lmaWMgY29u Y2VybiBhYm91dCBjYXVsayBpcyBjcmF6aW5nIGFmdGVyIGxvbmctdGVybSBhcHBsaWNhdGlvbi4N Cg0KU28gaWYgeW91IGhhdmUgdXNlZCBjYXVsaywgd2hhdCB0eXBlIGRpZCB5b3UgdXNlIGFuZCBo b3cgbG9uZyBoYXMgaXQgYmVlbiBhcHBsaWVkIHRvIHRoZSBnbGFzcz8NCg0KT3RoZXJ3aXNlIEkn bGwganVzdCBjb250aW51ZSBkb3duIHRoZSBwcm9zZWFsIHBhdGguLi4uDQoNClRoYW5rcywNClBo aWwNCg0KDQoNClNlbnQgZnJvbSBteSBpUGhvbmUNCl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0NCl8tPSAgICAgICAtLSBQ bGVhc2UgU3VwcG9ydCBZb3VyIExpc3RzIFRoaXMgTW9udGggLS0NCl8tPSAgICAgICAgICAgKEFu ZCBHZXQgU29tZSBBV0VTT01FIEZSRUUgR2lmdHMhKQ0KXy09DQpfLT0gICBOb3ZlbWJlciBpcyB0 aGUgQW5udWFsIExpc3QgRnVuZCBSYWlzZXIuICBDbGljayBvbg0KXy09ICAgdGhlIENvbnRyaWJ1 dGlvbiBsaW5rIGJlbG93IHRvIGZpbmQgb3V0IG1vcmUgYWJvdXQNCl8tPSAgIHRoaXMgeWVhcidz IFRlcnJpZmljIEZyZWUgSW5jZW50aXZlIEdpZnRzIHByb3ZpZGVkDQpfLT0gICBieToNCl8tPQ0K Xy09ICAgICAqIEFlcm9FbGVjdHJpYyB3d3cuYWVyb2VsZWN0cmljLmNvbTxodHRwOi8vd3d3LmFl cm9lbGVjdHJpYy5jb20+DQpfLT0gICAgICogVGhlIEJ1aWxkZXIncyBCb29rc3RvcmUgd3d3LmJ1 aWxkZXJzYm9va3MuY29tPGh0dHA6Ly93d3cuYnVpbGRlcnNib29rcy5jb20+DQpfLT0gICAgICog SG9tZWJ1aWx0SEVMUCB3d3cuaG9tZWJ1aWx0aGVscC5jb208aHR0cDovL3d3dy5ob21lYnVpbHRo ZWxwLmNvbT4NCl8tPSAgICAgKiBNeSBQaWxvdCBTdG9yZSB3d3cubXlwaWxvdHN0b3JlLmNvbTxo dHRwOi8vd3d3Lm15cGlsb3RzdG9yZS5jb20+DQpfLT0gICAgICogUmFjZSBDb25zdWx0aW5nIHd3 dy5tcnJhY2UuY29tPGh0dHA6Ly93d3cubXJyYWNlLmNvbT4NCl8tPQ0KXy09ICAgTGlzdCBDb250 cmlidXRpb24gV2ViIFNpdGU6DQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5j b20vY29udHJpYnV0aW9uDQpfLT0NCl8tPSAgIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBz dXBwb3J0IQ0KXy09DQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFs bGUsIExpc3QgQWRtaW4uDQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgLSBUaGUgUlYxMC1MaXN0 IEVtYWlsIEZvcnVtIC0NCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmln YXRvciB0byBicm93c2UNCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3Qg VW4vU3Vic2NyaXB0aW9uLA0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJy b3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCl8t PQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0 DQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0N Cl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1z IQ0KXy09DQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQpfLT0NCl8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 DQpfLT0gICAgICAgICAgICAgIC0gTkVXIE1BVFJPTklDUyBMSVNUIFdJS0kgLQ0KXy09IEFkZCBz b21lIGluZm8gdG8gdGhlIE1hdHJvbmljcyBFbWFpbCBMaXN0IFdpa2khDQpfLT0gICAtLT4gaHR0 cDovL3dpa2kubWF0cm9uaWNzLmNvbQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAtIExpc3QgQ29u dHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1 cHBvcnQhDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExp c3QgQWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlv bg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0NCg0KDQo ________________________________________________________________________________
Subject: Re: Caulk around windows?
Date: Nov 08, 2016
I used SikaFlex 295UV, without primer. Most of the stuff is on fiberglass and it sticks to that without primer. I used 1/4" 3M blue vinyl tape to mask it, and pulled the tape immediately after applying the Sika. Practice pulling the tape on a test piece first. You can clean up with mineral spirits. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=462231#462231 ________________________________________________________________________________
Date: Nov 08, 2016
I filled with micro and glass taped over the edge of the window Jeff Carpenter 40304 On Nov 8, 2016, at 11:53 AM, Phillip Perry wrote: > > Have any of you ran a bead of caulk around the interior side of the windows to make a fillet that transitions the glass to the cabin top? > > I'm staring at a mixed pot of pro-seal (my current plan) but really don't want to string that oooey gooey stuff all rebound the inside of the windscreen. So before I did, I thought I'd ask the caulk question first. > > My specific concern about caulk is crazing after long-term application. > > So if you have used caulk, what type did you use and how long has it been applied to the glass? > > Otherwise I'll just continue down the proseal path.... > > Thanks, > Phil > > > > Sent from my iPhone > > > Westcott Press 1121 Isabel Street Burbank, CA 91506 jeff(at)westcottpress.com 818-861-7300 ________________________________________________________________________________
Date: Nov 08, 2016
Thanks. I'm talking about the interior side specifically. The outside is a lready completed. Sent from my iPhone > On Nov 8, 2016, at 4:10 PM, Jeff Carpenter wrote: > > I filled with micro and glass taped over the edge of the window > > > Jeff Carpenter > 40304 > > >> On Nov 8, 2016, at 11:53 AM, Phillip Perry wrote: >> >> >> Have any of you ran a bead of caulk around the interior side of the windo ws to make a fillet that transitions the glass to the cabin top? >> >> I'm staring at a mixed pot of pro-seal (my current plan) but really don't want to string that oooey gooey stuff all rebound the inside of the windscr een. So before I did, I thought I'd ask the caulk question first. >> >> My specific concern about caulk is crazing after long-term application. >> >> So if you have used caulk, what type did you use and how long has it been applied to the glass? >> >> Otherwise I'll just continue down the proseal path.... >> >> Thanks, >> Phil >> >> >> >> Sent from my -- Please Support Your Lists This (And Get A eroElectric http://www.matronics.com/co -Matt Dr alle, List - The RV10-List --> http://www.matronics===== ===================http://www.matronic s.com/co================ >> >> >> > > Westcott Press > 1121 Isabel Street > Burbank, CA 91506 > jeff(at)westcottpress.com > 818-861-7300 > > > > ________________________________________________________________________________
Date: Nov 09, 2016
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 11, 2016
Subject: Make Sure You're Listed! List of Contributors Published in
December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 13, 2016
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that ilk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Subject: Re: MT P860-3 Prop Gov fail.
Date: Nov 14, 2016
According to my insurance adjuster they just received a brand new claim for another PG failure. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=462541#462541 ________________________________________________________________________________
Date: Nov 15, 2016
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 16, 2016
Where can I access the SB on this? The Van's website directs to MT website but the list of MT SBs doesn't seem to include this one. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=462641#462641 ________________________________________________________________________________
Date: Nov 16, 2016
If I understand what you posted, if your serial number is not on the service bulletin then you are good to go... Good Luck On Wed, Nov 16, 2016 at 6:40 AM, bob88 wrote: > > Where can I access the SB on this? The Van's website directs to MT website > but the list of MT SBs doesn't seem to include this one. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=462641#462641 > > -- Thank You, Craig Rufi Email craigr60(at)gmail.com Cell 805 402-6480 ________________________________________________________________________________
Date: Nov 16, 2016
Bob88 try this link http://www.mt-propeller.com/en/entw/serviced.htm or google MT prop service bulletins. I just tried it and they are there. Rick C-GDMH -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 Sent: November 16, 2016 9:40 AM Subject: RV10-List: Re: MT P860-3 Prop Gov fail. Where can I access the SB on this? The Van's website directs to MT website but the list of MT SBs doesn't seem to include this one. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=462641#462641 ________________________________________________________________________________
Date: Nov 16, 2016
Note: Ignore the languag about higher compression and electronic ignition. IIRC none of the failures had either feature. If your serial number is there, regardless of model, contact MT-USA. Even if your serial number is anywhere close, talk to them. My model was not included, but my serial number was. they said send it in. It cost me shipping both directions, but no charge to modify to latest design parts. It was worth it for peace of mind. -sent from the I-droid implanted in my forearm On Wed, Nov 16, 2016 at 4:56 PM, Sandra & Rick wrote: > > Bob88 try this link http://www.mt-propeller.com/en/entw/serviced.htm or > google MT prop service bulletins. I just tried it and they are there. > > Rick > C-GDMH > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 > Sent: November 16, 2016 9:40 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: MT P860-3 Prop Gov fail. > > > Where can I access the SB on this? The Van's website directs to MT website > but the list of MT SBs doesn't seem to include this one. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=462641#462641 > > ________________________________________________________________________________
Date: Nov 17, 2016
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some point, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 23 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 19, 2016
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 19, 2016
Subject: Fatal RV-10 accident
Anyone know anything about this crash? https://www.aviation-safety.net/wikibase/wiki.php?id=191188 -sent from the I-droid implanted in my forearm ________________________________________________________________________________
Date: Nov 19, 2016
Subject: Re: Fatal RV-10 accident
Read about it the they day. =46rom what I've collected. It was in Phase 1, about 4 hrs in. On departure a door opened and the pilot was seen wrestling with the door d uring the takeoff roll, rotation, and climb out. I think I recall a pilot witness saying it got to around 30 AGL before it de scended back into the ground. Sent from my iPhone > On Nov 19, 2016, at 5:58 PM, Kelly McMullen wrote: > > Anyone know anything about this crash? > https://www.aviation-safety.net/wikibase/wiki.php?id=191188 > > -sent from the I-droid implanted in my forearm ________________________________________________________________________________
Date: Nov 19, 2016
That's what I heard secondhand too. "Fly the airplane" sounds like the prim ary thing that was not done. Additionally it doesn't sound like the door was latched all the way....with t he handle still pointing up. But this is all second info hand for me. I hav e no knowledge of it directly. Tim > On Nov 19, 2016, at 6:22 PM, Phillip Perry wrote: > > Read about it the they day. =46rom what I've collected. > > It was in Phase 1, about 4 hrs in. > > On departure a door opened and the pilot was seen wrestling with the door during the takeoff roll, rotation, and climb out. > > I think I recall a pilot witness saying it got to around 30 AGL before it d escended back into the ground. > > > > Sent from my iPhone > >> On Nov 19, 2016, at 5:58 PM, Kelly McMullen wrote: >> >> Anyone know anything about this crash? >> https://www.aviation-safety.net/wikibase/wiki.php?id=191188 >> >> -sent from the I-droid implanted in my forearm ________________________________________________________________________________
Date: Nov 19, 2016
It was Bruce Stamper, from Dubois, WY (and summers in Alaska as a salmon fisher). He was on VAF quite a bit (as "Stamper"), but I don't recall seeing him on Matronics. Sad deal... The NTSB Prelim is out: http://www.ntsb.gov/_layouts/ntsb.aviation/brief.aspx?ev_id 161105X23019&key=1 NTSB Identification: CEN17FA035 14 CFR Part 91: General Aviation Accident occurred Saturday, November 05, 2016 in Dubois, WY Aircraft: STAMPER RV-10, registration: N924WY Injuries: 1 Fatal. This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed. NTSB investigators either traveled in support of this investigation or conducted a significant amount of investigative work without any travel, and used data obtained from various sources to prepare this aircraft accident report. On November 5, 2016, about 0756 mountain daylight time, an experimental amateur-built Stamper model RV-10 single-engine airplane, N924WY, was destroyed during a postimpact fire following a loss of control shortly after takeoff from Dubois Municipal Airport (DUB), Dubois, Wyoming. The private pilot, the sole occupant, was fatally injured. The airplane was registered to and operated by the pilot under the provisions of 14 Code of Federal Regulations Part 91 as a test flight. Day visual meteorological conditions prevailed for the presumed local flight. A witness, who was also a pilot, reported that he saw the accident airplane takeoff from runway 28 (6,100 feet by 60 feet, asphalt). He stated that he saw the right-side gull-wing door open immediately after liftoff. After the door opened, he saw the pilot reach for the fully open door with his right hand and heard a momentary reduction of engine power. He saw the airplane descend momentarily before he heard an increase in engine power and saw the airplane level off over the runway. He reported that the pilot continued to reach for the open cabin door as the airplane overflew the remaining runway about 35 feet above ground level (agl). The witness then observed the airplane's left wing and nose drop suddenly. He surmised that the airplane had entered an aerodynamic stall/spin. The airplane descended below his line-of-sight before he observed a large explosion. The accident airplane was an experimental amateur-built Stamper model RV-10 single-engine airplane, serial number 40146. An experimental 260-horsepower Aero Sport Power model IO-540-D4A5 reciprocating engine, serial number 1542, powered the airplane through a constant-speed, three blade, Whirl Wind Aviation model 375RV composite propeller, serial number 375-106. The airplane had a fixed tricycle landing gear, was capable of seating four individuals, and had a certified maximum gross weight of 2,700 pounds. The airplane was equipped with two composite gull-wing cabin doors. The airplane was issued a special airworthiness certificate on April 23, 2016. According to available information, the airplane likely had accumulated 10-12 hours since receiving the airworthiness certificate. The last condition inspection of the airplane was completed on April 23, 2016, in conjunction with the issuance of the airworthiness certificate. A postaccident review of available maintenance records found no history of unresolved airworthiness issues. The airplane had a total fuel capacity of 60 gallons distributed between two wing fuel tanks. A review of fueling records established that the airplane fuel tanks were topped-off before the accident flight. According to FAA records, the pilot, age 44, held a private pilot certificate with airplane single engine land, airplane single engine sea, and instrument airplane ratings. His last aviation medical examination was completed on September 17, 2015, when he was issued a second-class medical certificate with no limitations or restrictions. A pilot logbook was not recovered during the on-scene investigation. According to recent insurance documentation, provided during October 2016, the pilot reported having a total flight experience of 1,500 hours, of which 40 hours were completed in Vans Aircraft RV-6 airplanes, 4 hours in Vans Aircraft model RV-10 airplanes, and 2 hours in the accident airplane. At 0755, the DUB automated surface observing system reported the following weather conditions: wind 270 degrees true at 6 knots, visibility 10 miles, sky clear, temperature 0 degrees Celsius, dew point -8 degrees Celsius, and an altimeter setting 30.29 inches of mercury. The initial point-of-impact was in an open field about 1,675 feet past the runway 28 departure threshold and 183 feet left of the extended runway centerline. A 67-foot-long debris path, oriented on a 210-degree magnetic heading, was observed between the initial point-of-impact and the main wreckage. A ground impact crater, containing propeller fragments, was observed about 44 feet from the initial point-of-impact. The main wreckage consisted of the fuselage, wings, and empennage. The cabin, including the cockpit instrument panel, was destroyed during the postimpact fire. Both wings exhibited damage consistent with ground impact. The empennage was relatively undamaged. A flight control continuity check was not possible due to the extent of damage; however, all observed flight control separations were consistent with fire and impact related damage. The right-side gull-wing door was located in a ravine about 600 feet northeast of the main wreckage. The door was located about 1,500 feet past the runway 28 departure threshold and 200 feet right of the extended runway centerline. The door had separated from the fuselage hinges. There was no evidence that the door had struck any portion of the airplane after it had separated. The door was equipped with forward and aft door latch pins and a center latch mechanism. The center latch consisted of a rotating semicircular cam that worked in conjunction with the two door latch pins. The door was not equipped with the safety latch mechanism that was provided by the airframe kit manufacturer. Before the door was recovered from the ravine, the door latch handle was observed to be about 20 degrees from a vertical position or about 110 degrees from the fully latched position. The forward and aft door latch pins were found extended about 1/8 inch outside the door. The curved portion of the semicircular center latch was found facing aft. A functional test of the door latch mechanism did not reveal any anomalies. The door latch handle rotated 180-degrees between the open and latched positions. When the handle was in the latched position, the forward and aft door latch pins extended 1-1/4 inches outside the door and the curved portion of the semicircular center latch faced down. The latch pins were equipped with embedded magnets that interfaced with position switches installed in the fuselage door frames. These position switches, which were destroyed during the postimpact fire, were part of a door latch annunciator circuit. A functional test of the door latch annunciator system was not possible due to fire damage sustained after the accident to the fuselage and instrument panel. The engine remained partially attached to the firewall by its mounts. Internal engine and valve train continuity was confirmed as the engine crankshaft was rotated. Compression and suction were noted on cylinder Nos. 1, 2, 3, and 5 in conjunction with crankshaft rotation. No compression was noted on cylinder Nos. 4 and 6 due to thermal damage to the valve springs. The engine was equipped with a traditional magneto and an electronic ignition system. The traditional magneto exhibited extensive thermal damage and could not be tested. The electronic ignition was not recovered and likely was destroyed during the postimpact fire. The upper spark plugs were removed and exhibited features consistent with normal engine operation. A borescope inspection revealed no anomalies with the cylinders, valves, or pistons. The propeller hub remained attached to the engine crankshaft flange. Two of the three composite blades were destroyed during the impact sequence. The remaining composite blade exhibited thermal damage from the postimpact fire. On Sat, Nov 19, 2016 at 6:32 PM, Tim Olson wrote: > That's what I heard secondhand too. "Fly the airplane" sounds like the > primary thing that was not done. > Additionally it doesn't sound like the door was latched all the > way....with the handle still pointing up. But this is all second info hand > for me. I have no knowledge of it directly. > Tim > > On Nov 19, 2016, at 6:22 PM, Phillip Perry wrote: > > Read about it the they day. From what I've collected. > > It was in Phase 1, about 4 hrs in. > > On departure a door opened and the pilot was seen wrestling with the door > during the takeoff roll, rotation, and climb out. > > I think I recall a pilot witness saying it got to around 30 AGL before it > descended back into the ground. > > > Sent from my iPhone > > On Nov 19, 2016, at 5:58 PM, Kelly McMullen wrote: > > Anyone know anything about this crash? > https://www.aviation-safety.net/wikibase/wiki.php?id=191188 > > -sent from the I-droid implanted in my forearm > > ________________________________________________________________________________
Date: Nov 19, 2016
QnJ1Y2XCoFdhcyBvbmUgaGVjayBvZiBhIG5pY2UgZmVsbGEuIEhlIHdhcyBhIHNwZWNpYWwgZnJp ZW5kIG9mIG1pbmUgYW5kIEknbSBzdXJlIG1hbnkgb3RoZXJzIGluIHRoZSBSVjEwIGNvbW11bml0 eS7CoEhlIHdhcyBhIGdyZWF0IGZpc2hlcm1hbiwgZGFkLCBidWlsZGVyLCBhbmQgcGlsb3QuIEhl IGZpc2hlZCBTb2NrZXllIHNlYXNvbiBpbiBoaXMgYXdlc29tZSB0d2luIGVuZ2luZSBib3ctcGlj a2VyIGFuZCB0aGVuIGZsZXcgYSBDdWIgYXMgYSBzcG90dGVyIGZvciBlaWdodCBmaXNoaW5nIGJv YXRzIHRoZSByZXN0IG9mIHRoZSBzZWFzb24uSGUgYWxzbyBzcGVudCB0aW1lIHByYWN0aWNpbmcg cmVhbCBidXNoIGxhbmRpbmdzIHdoaWxlIHNjb3V0aW5nIGZvciBhbmQgY29sbGVjdGluZyBFbGsg YW5kIE1vb3NlIGFudGxlcnMuIExhc3QgeWVhciBoZSBldmVuIGZsaXBwZWQgdGhlIEN1YiBvdmVy IGFuZCBtZXNzZWQgaXQgdXAgYSBiaXQuUGljdHVyZSBvZiBCcnVjZSBvbiB0aGUgbGVmdCBhbmQg YSBwaWN0dXJlIG9mIG1lIHJhaXNpbmcgYSB0b2FzdCBvZiBteSBmYXZvcml0ZSBiZWVyIEFsYXNr YW4gQW1iZXIsIG9uIHRoaXMgYmVhdXRpZnVsIGV2ZW5pbmcgaW4gQmVuZCBPci5QYXVsIEdyaW1z dGFkwqAKLS0tLS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLUZyb206IEVkIEtyYW56IDxl ZC5rcmFuekBnbWFpbC5jb20+IERhdGU6IDExLzE5LzIwMTYgIDY6NTMgUE0gIChHTVQtMDg6MDAp IFRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbSBTdWJqZWN0OiBSZTogUlYxMC1MaXN0OiBGYXRh bCBSVi0xMCBhY2NpZGVudCAKSXQgd2FzIEJydWNlIFN0YW1wZXIsIGZyb20gRHVib2lzLCBXWSAo YW5kIHN1bW1lcnMgaW4gQWxhc2thIGFzIGEgc2FsbW9uIGZpc2hlcikuIEhlIHdhcyBvbiBWQUYg cXVpdGUgYSBiaXQgKGFzICJTdGFtcGVyIiksIGJ1dCBJIGRvbid0IHJlY2FsbCBzZWVpbmcgaGlt IG9uIE1hdHJvbmljcy7CoApTYWQgZGVhbC4uLsKgCgpUaGUgTlRTQiBQcmVsaW0gaXMgb3V0OsKg aHR0cDovL3d3dy5udHNiLmdvdi9fbGF5b3V0cy9udHNiLmF2aWF0aW9uL2JyaWVmLmFzcHg/ZXZf aWQ9MjAxNjExMDVYMjMwMTkma2V5PTEKTlRTQiBJZGVudGlmaWNhdGlvbjrCoENFTjE3RkEwMzUx NCBDRlIgUGFydCA5MTogR2VuZXJhbCBBdmlhdGlvbkFjY2lkZW50wqBvY2N1cnJlZMKgU2F0dXJk YXksIE5vdmVtYmVyIDA1LCAyMDE2wqBpbsKgRHVib2lzLCBXWUFpcmNyYWZ0OsKgU1RBTVBFUiBS Vi0xMCwgcmVnaXN0cmF0aW9uOsKgTjkyNFdZSW5qdXJpZXM6IDEgRmF0YWwuVGhpcyBpcyBwcmVs aW1pbmFyeSBpbmZvcm1hdGlvbiwgc3ViamVjdCB0byBjaGFuZ2UsIGFuZCBtYXkgY29udGFpbiBl cnJvcnMuIEFueSBlcnJvcnMgaW4gdGhpcyByZXBvcnQgd2lsbCBiZSBjb3JyZWN0ZWQgd2hlbiB0 aGUgZmluYWwgcmVwb3J0IGhhcyBiZWVuIGNvbXBsZXRlZC4gTlRTQiBpbnZlc3RpZ2F0b3JzIGVp dGhlciB0cmF2ZWxlZCBpbiBzdXBwb3J0IG9mIHRoaXMgaW52ZXN0aWdhdGlvbiBvciBjb25kdWN0 ZWQgYSBzaWduaWZpY2FudCBhbW91bnQgb2YgaW52ZXN0aWdhdGl2ZSB3b3JrIHdpdGhvdXQgYW55 IHRyYXZlbCwgYW5kIHVzZWQgZGF0YSBvYnRhaW5lZCBmcm9tIHZhcmlvdXMgc291cmNlcyB0byBw cmVwYXJlIHRoaXMgYWlyY3JhZnQgYWNjaWRlbnQgcmVwb3J0Lk9uIE5vdmVtYmVyIDUsIDIwMTYs IGFib3V0IDA3NTYgbW91bnRhaW4gZGF5bGlnaHQgdGltZSwgYW4gZXhwZXJpbWVudGFsIGFtYXRl dXItYnVpbHQgU3RhbXBlciBtb2RlbCBSVi0xMCBzaW5nbGUtZW5naW5lIGFpcnBsYW5lLCBOOTI0 V1ksIHdhcyBkZXN0cm95ZWQgZHVyaW5nIGEgcG9zdGltcGFjdCBmaXJlIGZvbGxvd2luZyBhIGxv c3Mgb2YgY29udHJvbCBzaG9ydGx5IGFmdGVyIHRha2VvZmYgZnJvbSBEdWJvaXMgTXVuaWNpcGFs IEFpcnBvcnQgKERVQiksIER1Ym9pcywgV3lvbWluZy4gVGhlIHByaXZhdGUgcGlsb3QsIHRoZSBz b2xlIG9jY3VwYW50LCB3YXMgZmF0YWxseSBpbmp1cmVkLiBUaGUgYWlycGxhbmUgd2FzIHJlZ2lz dGVyZWQgdG8gYW5kIG9wZXJhdGVkIGJ5IHRoZSBwaWxvdCB1bmRlciB0aGUgcHJvdmlzaW9ucyBv ZiAxNCBDb2RlIG9mIEZlZGVyYWwgUmVndWxhdGlvbnMgUGFydCA5MSBhcyBhIHRlc3QgZmxpZ2h0 LiBEYXkgdmlzdWFsIG1ldGVvcm9sb2dpY2FsIGNvbmRpdGlvbnMgcHJldmFpbGVkIGZvciB0aGUg cHJlc3VtZWQgbG9jYWwgZmxpZ2h0LgoKQSB3aXRuZXNzLCB3aG8gd2FzIGFsc28gYSBwaWxvdCwg cmVwb3J0ZWQgdGhhdCBoZSBzYXcgdGhlIGFjY2lkZW50IGFpcnBsYW5lIHRha2VvZmYgZnJvbSBy dW53YXkgMjggKDYsMTAwIGZlZXQgYnkgNjAgZmVldCwgYXNwaGFsdCkuIEhlIHN0YXRlZCB0aGF0 IGhlIHNhdyB0aGUgcmlnaHQtc2lkZSBndWxsLXdpbmcgZG9vciBvcGVuIGltbWVkaWF0ZWx5IGFm dGVyIGxpZnRvZmYuIEFmdGVyIHRoZSBkb29yIG9wZW5lZCwgaGUgc2F3IHRoZSBwaWxvdCByZWFj aCBmb3IgdGhlIGZ1bGx5IG9wZW4gZG9vciB3aXRoIGhpcyByaWdodCBoYW5kIGFuZCBoZWFyZCBh IG1vbWVudGFyeSByZWR1Y3Rpb24gb2YgZW5naW5lIHBvd2VyLiBIZSBzYXcgdGhlIGFpcnBsYW5l IGRlc2NlbmQgbW9tZW50YXJpbHkgYmVmb3JlIGhlIGhlYXJkIGFuIGluY3JlYXNlIGluIGVuZ2lu ZSBwb3dlciBhbmQgc2F3IHRoZSBhaXJwbGFuZSBsZXZlbCBvZmYgb3ZlciB0aGUgcnVud2F5LiBI ZSByZXBvcnRlZCB0aGF0IHRoZSBwaWxvdCBjb250aW51ZWQgdG8gcmVhY2ggZm9yIHRoZSBvcGVu IGNhYmluIGRvb3IgYXMgdGhlIGFpcnBsYW5lIG92ZXJmbGV3IHRoZSByZW1haW5pbmcgcnVud2F5 IGFib3V0IDM1IGZlZXQgYWJvdmUgZ3JvdW5kIGxldmVsIChhZ2wpLiBUaGUgd2l0bmVzcyB0aGVu IG9ic2VydmVkIHRoZSBhaXJwbGFuZSdzIGxlZnQgd2luZyBhbmQgbm9zZSBkcm9wIHN1ZGRlbmx5 LiBIZSBzdXJtaXNlZCB0aGF0IHRoZSBhaXJwbGFuZSBoYWQgZW50ZXJlZCBhbiBhZXJvZHluYW1p YyBzdGFsbC9zcGluLiBUaGUgYWlycGxhbmUgZGVzY2VuZGVkIGJlbG93IGhpcyBsaW5lLW9mLXNp Z2h0IGJlZm9yZSBoZSBvYnNlcnZlZCBhIGxhcmdlIGV4cGxvc2lvbi4KClRoZSBhY2NpZGVudCBh aXJwbGFuZSB3YXMgYW4gZXhwZXJpbWVudGFsIGFtYXRldXItYnVpbHQgU3RhbXBlciBtb2RlbCBS Vi0xMCBzaW5nbGUtZW5naW5lIGFpcnBsYW5lLCBzZXJpYWwgbnVtYmVyIDQwMTQ2LiBBbiBleHBl cmltZW50YWwgMjYwLWhvcnNlcG93ZXIgQWVybyBTcG9ydCBQb3dlciBtb2RlbCBJTy01NDAtRDRB NSByZWNpcHJvY2F0aW5nIGVuZ2luZSwgc2VyaWFsIG51bWJlciAxNTQyLCBwb3dlcmVkIHRoZSBh aXJwbGFuZSB0aHJvdWdoIGEgY29uc3RhbnQtc3BlZWQsIHRocmVlIGJsYWRlLCBXaGlybCBXaW5k IEF2aWF0aW9uIG1vZGVsIDM3NVJWIGNvbXBvc2l0ZSBwcm9wZWxsZXIsIHNlcmlhbCBudW1iZXIg Mzc1LTEwNi4gVGhlIGFpcnBsYW5lIGhhZCBhIGZpeGVkIHRyaWN5Y2xlIGxhbmRpbmcgZ2Vhciwg d2FzIGNhcGFibGUgb2Ygc2VhdGluZyBmb3VyIGluZGl2aWR1YWxzLCBhbmQgaGFkIGEgY2VydGlm aWVkIG1heGltdW0gZ3Jvc3Mgd2VpZ2h0IG9mIDIsNzAwIHBvdW5kcy4gVGhlIGFpcnBsYW5lIHdh cyBlcXVpcHBlZCB3aXRoIHR3byBjb21wb3NpdGUgZ3VsbC13aW5nIGNhYmluIGRvb3JzLiBUaGUg YWlycGxhbmUgd2FzIGlzc3VlZCBhIHNwZWNpYWwgYWlyd29ydGhpbmVzcyBjZXJ0aWZpY2F0ZSBv biBBcHJpbCAyMywgMjAxNi4gQWNjb3JkaW5nIHRvIGF2YWlsYWJsZSBpbmZvcm1hdGlvbiwgdGhl IGFpcnBsYW5lIGxpa2VseSBoYWQgYWNjdW11bGF0ZWQgMTAtMTIgaG91cnMgc2luY2UgcmVjZWl2 aW5nIHRoZSBhaXJ3b3J0aGluZXNzIGNlcnRpZmljYXRlLiBUaGUgbGFzdCBjb25kaXRpb24gaW5z cGVjdGlvbiBvZiB0aGUgYWlycGxhbmUgd2FzIGNvbXBsZXRlZCBvbiBBcHJpbCAyMywgMjAxNiwg aW4gY29uanVuY3Rpb24gd2l0aCB0aGUgaXNzdWFuY2Ugb2YgdGhlIGFpcndvcnRoaW5lc3MgY2Vy dGlmaWNhdGUuIEEgcG9zdGFjY2lkZW50IHJldmlldyBvZiBhdmFpbGFibGUgbWFpbnRlbmFuY2Ug cmVjb3JkcyBmb3VuZCBubyBoaXN0b3J5IG9mIHVucmVzb2x2ZWQgYWlyd29ydGhpbmVzcyBpc3N1 ZXMuIFRoZSBhaXJwbGFuZSBoYWQgYSB0b3RhbCBmdWVsIGNhcGFjaXR5IG9mIDYwIGdhbGxvbnMg ZGlzdHJpYnV0ZWQgYmV0d2VlbiB0d28gd2luZyBmdWVsIHRhbmtzLiBBIHJldmlldyBvZiBmdWVs aW5nIHJlY29yZHMgZXN0YWJsaXNoZWQgdGhhdCB0aGUgYWlycGxhbmUgZnVlbCB0YW5rcyB3ZXJl IHRvcHBlZC1vZmYgYmVmb3JlIHRoZSBhY2NpZGVudCBmbGlnaHQuCgpBY2NvcmRpbmcgdG8gRkFB IHJlY29yZHMsIHRoZSBwaWxvdCwgYWdlIDQ0LCBoZWxkIGEgcHJpdmF0ZSBwaWxvdCBjZXJ0aWZp Y2F0ZSB3aXRoIGFpcnBsYW5lIHNpbmdsZSBlbmdpbmUgbGFuZCwgYWlycGxhbmUgc2luZ2xlIGVu Z2luZSBzZWEsIGFuZCBpbnN0cnVtZW50IGFpcnBsYW5lIHJhdGluZ3MuIEhpcyBsYXN0IGF2aWF0 aW9uIG1lZGljYWwgZXhhbWluYXRpb24gd2FzIGNvbXBsZXRlZCBvbiBTZXB0ZW1iZXIgMTcsIDIw MTUsIHdoZW4gaGUgd2FzIGlzc3VlZCBhIHNlY29uZC1jbGFzcyBtZWRpY2FsIGNlcnRpZmljYXRl IHdpdGggbm8gbGltaXRhdGlvbnMgb3IgcmVzdHJpY3Rpb25zLiBBIHBpbG90IGxvZ2Jvb2sgd2Fz IG5vdCByZWNvdmVyZWQgZHVyaW5nIHRoZSBvbi1zY2VuZSBpbnZlc3RpZ2F0aW9uLiBBY2NvcmRp bmcgdG8gcmVjZW50IGluc3VyYW5jZSBkb2N1bWVudGF0aW9uLCBwcm92aWRlZCBkdXJpbmcgT2N0 b2JlciAyMDE2LCB0aGUgcGlsb3QgcmVwb3J0ZWQgaGF2aW5nIGEgdG90YWwgZmxpZ2h0IGV4cGVy aWVuY2Ugb2YgMSw1MDAgaG91cnMsIG9mIHdoaWNoIDQwIGhvdXJzIHdlcmUgY29tcGxldGVkIGlu IFZhbnMgQWlyY3JhZnQgUlYtNiBhaXJwbGFuZXMsIDQgaG91cnMgaW4gVmFucyBBaXJjcmFmdCBt b2RlbCBSVi0xMCBhaXJwbGFuZXMsIGFuZCAyIGhvdXJzIGluIHRoZSBhY2NpZGVudCBhaXJwbGFu ZS4KCkF0IDA3NTUsIHRoZSBEVUIgYXV0b21hdGVkIHN1cmZhY2Ugb2JzZXJ2aW5nIHN5c3RlbSBy ZXBvcnRlZCB0aGUgZm9sbG93aW5nIHdlYXRoZXIgY29uZGl0aW9uczogd2luZCAyNzAgZGVncmVl cyB0cnVlIGF0IDYga25vdHMsIHZpc2liaWxpdHkgMTAgbWlsZXMsIHNreSBjbGVhciwgdGVtcGVy YXR1cmUgMCBkZWdyZWVzIENlbHNpdXMsIGRldyBwb2ludCAtOCBkZWdyZWVzIENlbHNpdXMsIGFu ZCBhbiBhbHRpbWV0ZXIgc2V0dGluZyAzMC4yOSBpbmNoZXMgb2YgbWVyY3VyeS4KClRoZSBpbml0 aWFsIHBvaW50LW9mLWltcGFjdCB3YXMgaW4gYW4gb3BlbiBmaWVsZCBhYm91dCAxLDY3NSBmZWV0 IHBhc3QgdGhlIHJ1bndheSAyOCBkZXBhcnR1cmUgdGhyZXNob2xkIGFuZCAxODMgZmVldCBsZWZ0 IG9mIHRoZSBleHRlbmRlZCBydW53YXkgY2VudGVybGluZS4gQSA2Ny1mb290LWxvbmcgZGVicmlz IHBhdGgsIG9yaWVudGVkIG9uIGEgMjEwLWRlZ3JlZSBtYWduZXRpYyBoZWFkaW5nLCB3YXMgb2Jz ZXJ2ZWQgYmV0d2VlbiB0aGUgaW5pdGlhbCBwb2ludC1vZi1pbXBhY3QgYW5kIHRoZSBtYWluIHdy ZWNrYWdlLiBBIGdyb3VuZCBpbXBhY3QgY3JhdGVyLCBjb250YWluaW5nIHByb3BlbGxlciBmcmFn bWVudHMsIHdhcyBvYnNlcnZlZCBhYm91dCA0NCBmZWV0IGZyb20gdGhlIGluaXRpYWwgcG9pbnQt b2YtaW1wYWN0LiBUaGUgbWFpbiB3cmVja2FnZSBjb25zaXN0ZWQgb2YgdGhlIGZ1c2VsYWdlLCB3 aW5ncywgYW5kIGVtcGVubmFnZS4gVGhlIGNhYmluLCBpbmNsdWRpbmcgdGhlIGNvY2twaXQgaW5z dHJ1bWVudCBwYW5lbCwgd2FzIGRlc3Ryb3llZCBkdXJpbmcgdGhlIHBvc3RpbXBhY3QgZmlyZS4g Qm90aCB3aW5ncyBleGhpYml0ZWQgZGFtYWdlIGNvbnNpc3RlbnQgd2l0aCBncm91bmQgaW1wYWN0 LiBUaGUgZW1wZW5uYWdlIHdhcyByZWxhdGl2ZWx5IHVuZGFtYWdlZC4gQSBmbGlnaHQgY29udHJv bCBjb250aW51aXR5IGNoZWNrIHdhcyBub3QgcG9zc2libGUgZHVlIHRvIHRoZSBleHRlbnQgb2Yg ZGFtYWdlOyBob3dldmVyLCBhbGwgb2JzZXJ2ZWQgZmxpZ2h0IGNvbnRyb2wgc2VwYXJhdGlvbnMg d2VyZSBjb25zaXN0ZW50IHdpdGggZmlyZSBhbmQgaW1wYWN0IHJlbGF0ZWQgZGFtYWdlLgoKVGhl IHJpZ2h0LXNpZGUgZ3VsbC13aW5nIGRvb3Igd2FzIGxvY2F0ZWQgaW4gYSByYXZpbmUgYWJvdXQg NjAwIGZlZXQgbm9ydGhlYXN0IG9mIHRoZSBtYWluIHdyZWNrYWdlLiBUaGUgZG9vciB3YXMgbG9j YXRlZCBhYm91dCAxLDUwMCBmZWV0IHBhc3QgdGhlIHJ1bndheSAyOCBkZXBhcnR1cmUgdGhyZXNo b2xkIGFuZCAyMDAgZmVldCByaWdodCBvZiB0aGUgZXh0ZW5kZWQgcnVud2F5IGNlbnRlcmxpbmUu IFRoZSBkb29yIGhhZCBzZXBhcmF0ZWQgZnJvbSB0aGUgZnVzZWxhZ2UgaGluZ2VzLiBUaGVyZSB3 YXMgbm8gZXZpZGVuY2UgdGhhdCB0aGUgZG9vciBoYWQgc3RydWNrIGFueSBwb3J0aW9uIG9mIHRo ZSBhaXJwbGFuZSBhZnRlciBpdCBoYWQgc2VwYXJhdGVkLiBUaGUgZG9vciB3YXMgZXF1aXBwZWQg d2l0aCBmb3J3YXJkIGFuZCBhZnQgZG9vciBsYXRjaCBwaW5zIGFuZCBhIGNlbnRlciBsYXRjaCBt ZWNoYW5pc20uIFRoZSBjZW50ZXIgbGF0Y2ggY29uc2lzdGVkIG9mIGEgcm90YXRpbmcgc2VtaWNp cmN1bGFyIGNhbSB0aGF0IHdvcmtlZCBpbiBjb25qdW5jdGlvbiB3aXRoIHRoZSB0d28gZG9vciBs YXRjaCBwaW5zLiBUaGUgZG9vciB3YXMgbm90IGVxdWlwcGVkIHdpdGggdGhlIHNhZmV0eSBsYXRj aCBtZWNoYW5pc20gdGhhdCB3YXMgcHJvdmlkZWQgYnkgdGhlIGFpcmZyYW1lIGtpdCBtYW51ZmFj dHVyZXIuIEJlZm9yZSB0aGUgZG9vciB3YXMgcmVjb3ZlcmVkIGZyb20gdGhlIHJhdmluZSwgdGhl IGRvb3IgbGF0Y2ggaGFuZGxlIHdhcyBvYnNlcnZlZCB0byBiZSBhYm91dCAyMCBkZWdyZWVzIGZy b20gYSB2ZXJ0aWNhbCBwb3NpdGlvbiBvciBhYm91dCAxMTAgZGVncmVlcyBmcm9tIHRoZSBmdWxs eSBsYXRjaGVkIHBvc2l0aW9uLiBUaGUgZm9yd2FyZCBhbmQgYWZ0IGRvb3IgbGF0Y2ggcGlucyB3 ZXJlIGZvdW5kIGV4dGVuZGVkIGFib3V0IDEvOCBpbmNoIG91dHNpZGUgdGhlIGRvb3IuIFRoZSBj dXJ2ZWQgcG9ydGlvbiBvZiB0aGUgc2VtaWNpcmN1bGFyIGNlbnRlciBsYXRjaCB3YXMgZm91bmQg ZmFjaW5nIGFmdC4gQSBmdW5jdGlvbmFsIHRlc3Qgb2YgdGhlIGRvb3IgbGF0Y2ggbWVjaGFuaXNt IGRpZCBub3QgcmV2ZWFsIGFueSBhbm9tYWxpZXMuIFRoZSBkb29yIGxhdGNoIGhhbmRsZSByb3Rh dGVkIDE4MC1kZWdyZWVzIGJldHdlZW4gdGhlIG9wZW4gYW5kIGxhdGNoZWQgcG9zaXRpb25zLiBX aGVuIHRoZSBoYW5kbGUgd2FzIGluIHRoZSBsYXRjaGVkIHBvc2l0aW9uLCB0aGUgZm9yd2FyZCBh bmQgYWZ0IGRvb3IgbGF0Y2ggcGlucyBleHRlbmRlZCAxLTEvNCBpbmNoZXMgb3V0c2lkZSB0aGUg ZG9vciBhbmQgdGhlIGN1cnZlZCBwb3J0aW9uIG9mIHRoZSBzZW1pY2lyY3VsYXIgY2VudGVyIGxh dGNoIGZhY2VkIGRvd24uIFRoZSBsYXRjaCBwaW5zIHdlcmUgZXF1aXBwZWQgd2l0aCBlbWJlZGRl ZCBtYWduZXRzIHRoYXQgaW50ZXJmYWNlZCB3aXRoIHBvc2l0aW9uIHN3aXRjaGVzIGluc3RhbGxl ZCBpbiB0aGUgZnVzZWxhZ2UgZG9vciBmcmFtZXMuIFRoZXNlIHBvc2l0aW9uIHN3aXRjaGVzLCB3 aGljaCB3ZXJlIGRlc3Ryb3llZCBkdXJpbmcgdGhlIHBvc3RpbXBhY3QgZmlyZSwgd2VyZSBwYXJ0 IG9mIGEgZG9vciBsYXRjaCBhbm51bmNpYXRvciBjaXJjdWl0LiBBIGZ1bmN0aW9uYWwgdGVzdCBv ZiB0aGUgZG9vciBsYXRjaCBhbm51bmNpYXRvciBzeXN0ZW0gd2FzIG5vdCBwb3NzaWJsZSBkdWUg dG8gZmlyZSBkYW1hZ2Ugc3VzdGFpbmVkIGFmdGVyIHRoZSBhY2NpZGVudCB0byB0aGUgZnVzZWxh Z2UgYW5kIGluc3RydW1lbnQgcGFuZWwuCgpUaGUgZW5naW5lIHJlbWFpbmVkIHBhcnRpYWxseSBh dHRhY2hlZCB0byB0aGUgZmlyZXdhbGwgYnkgaXRzIG1vdW50cy4gSW50ZXJuYWwgZW5naW5lIGFu ZCB2YWx2ZSB0cmFpbiBjb250aW51aXR5IHdhcyBjb25maXJtZWQgYXMgdGhlIGVuZ2luZSBjcmFu a3NoYWZ0IHdhcyByb3RhdGVkLiBDb21wcmVzc2lvbiBhbmQgc3VjdGlvbiB3ZXJlIG5vdGVkIG9u IGN5bGluZGVyIE5vcy4gMSwgMiwgMywgYW5kIDUgaW4gY29uanVuY3Rpb24gd2l0aCBjcmFua3No YWZ0IHJvdGF0aW9uLiBObyBjb21wcmVzc2lvbiB3YXMgbm90ZWQgb24gY3lsaW5kZXIgTm9zLiA0 IGFuZCA2IGR1ZSB0byB0aGVybWFsIGRhbWFnZSB0byB0aGUgdmFsdmUgc3ByaW5ncy4gVGhlIGVu Z2luZSB3YXMgZXF1aXBwZWQgd2l0aCBhIHRyYWRpdGlvbmFsIG1hZ25ldG8gYW5kIGFuIGVsZWN0 cm9uaWMgaWduaXRpb24gc3lzdGVtLiBUaGUgdHJhZGl0aW9uYWwgbWFnbmV0byBleGhpYml0ZWQg ZXh0ZW5zaXZlIHRoZXJtYWwgZGFtYWdlIGFuZCBjb3VsZCBub3QgYmUgdGVzdGVkLiBUaGUgZWxl Y3Ryb25pYyBpZ25pdGlvbiB3YXMgbm90IHJlY292ZXJlZCBhbmQgbGlrZWx5IHdhcyBkZXN0cm95 ZWQgZHVyaW5nIHRoZSBwb3N0aW1wYWN0IGZpcmUuIFRoZSB1cHBlciBzcGFyayBwbHVncyB3ZXJl IHJlbW92ZWQgYW5kIGV4aGliaXRlZCBmZWF0dXJlcyBjb25zaXN0ZW50IHdpdGggbm9ybWFsIGVu Z2luZSBvcGVyYXRpb24uIEEgYm9yZXNjb3BlIGluc3BlY3Rpb24gcmV2ZWFsZWQgbm8gYW5vbWFs aWVzIHdpdGggdGhlIGN5bGluZGVycywgdmFsdmVzLCBvciBwaXN0b25zLiBUaGUgcHJvcGVsbGVy IGh1YiByZW1haW5lZCBhdHRhY2hlZCB0byB0aGUgZW5naW5lIGNyYW5rc2hhZnQgZmxhbmdlLiBU d28gb2YgdGhlIHRocmVlIGNvbXBvc2l0ZSBibGFkZXMgd2VyZSBkZXN0cm95ZWQgZHVyaW5nIHRo ZSBpbXBhY3Qgc2VxdWVuY2UuIFRoZSByZW1haW5pbmcgY29tcG9zaXRlIGJsYWRlIGV4aGliaXRl ZCB0aGVybWFsIGRhbWFnZSBmcm9tIHRoZSBwb3N0aW1wYWN0IGZpcmUuCk9uIFNhdCwgTm92IDE5 LCAyMDE2IGF0IDY6MzIgUE0sIFRpbSBPbHNvbiA8VGltQG15cnYxMC5jb20+IHdyb3RlOgpUaGF0 J3Mgd2hhdCBJIGhlYXJkIHNlY29uZGhhbmQgdG9vLiDCoCJGbHkgdGhlIGFpcnBsYW5lIiBzb3Vu ZHMgbGlrZSB0aGUgcHJpbWFyeSB0aGluZyB0aGF0IHdhcyBub3QgZG9uZS5BZGRpdGlvbmFsbHkg aXQgZG9lc24ndCBzb3VuZCBsaWtlIHRoZSBkb29yIHdhcyBsYXRjaGVkIGFsbCB0aGUgd2F5Li4u LndpdGggdGhlIGhhbmRsZSBzdGlsbCBwb2ludGluZyB1cC7CoCBCdXQgdGhpcyBpcyBhbGwgc2Vj b25kIGluZm8gaGFuZCBmb3IgbWUuIEkgaGF2ZSBubyBrbm93bGVkZ2Ugb2YgaXQgZGlyZWN0bHku VGltCk9uIE5vdiAxOSwgMjAxNiwgYXQgNjoyMiBQTSwgUGhpbGxpcCBQZXJyeSA8cGhpbHBlcnJ5 OUBnbWFpbC5jb20+IHdyb3RlOgoKUmVhZCBhYm91dCBpdCB0aGUgdGhleSBkYXkuwqAgRnJvbSB3 aGF0IEkndmUgY29sbGVjdGVkLsKgCkl0IHdhcyBpbiBQaGFzZSAxLCBhYm91dCA0IGhycyBpbi7C oApPbiBkZXBhcnR1cmUgYSBkb29yIG9wZW5lZCBhbmQgdGhlIHBpbG90IHdhcyBzZWVuIHdyZXN0 bGluZyB3aXRoIHRoZSBkb29yIMKgZHVyaW5nIHRoZSB0YWtlb2ZmIHJvbGwsIHJvdGF0aW9uLCBh bmQgY2xpbWIgb3V0LiDCoApJIHRoaW5rIEkgcmVjYWxsIGEgcGlsb3Qgd2l0bmVzcyBzYXlpbmcg aXQgZ290IHRvIGFyb3VuZCAzMCBBR0wgYmVmb3JlIGl0IGRlc2NlbmRlZCBiYWNrIGludG8gdGhl IGdyb3VuZC4KCgpTZW50IGZyb20gbXkgaVBob25lCk9uIE5vdiAxOSwgMjAxNiwgYXQgNTo1OCBQ TSwgS2VsbHkgTWNNdWxsZW4gPGFwaWxvdDJAZ21haWwuY29tPiB3cm90ZToKCkFueW9uZSBrbm93 IGFueXRoaW5nIGFib3V0IHRoaXMgY3Jhc2g/Cmh0dHBzOi8vd3d3LmF2aWF0aW9uLXNhZmV0eS5u ZXQvd2lraWJhc2Uvd2lraS5waHA/aWQ9MTkxMTg4Cgotc2VudCBmcm9tIHRoZSBJLWRyb2lkIGlt cGxhbnRlZCBpbiBteSBmb3JlYXJtCgoKCg= ________________________________________________________________________________
From: "John MacCallum" <john.maccallum(at)bigpond.com>
Date: Nov 21, 2016
I would think that 30ft AGL wouldn=99t result in a loss of the Aircraft if it was a controlled or semi controlled descent. Anyway it is very sad and sobering to read about a fellow builder passing. Let us learn from the incident and say Vale=99 Bruce Stamper. John MacCallum VH-DUU RV 10 # 41016 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Sunday, 20 November 2016 11:32 AM Subject: Re: RV10-List: Fatal RV-10 accident That's what I heard secondhand too. "Fly the airplane" sounds like the primary thing that was not done. Additionally it doesn't sound like the door was latched all the way....with the handle still pointing up. But this is all second info hand for me. I have no knowledge of it directly. Tim On Nov 19, 2016, at 6:22 PM, Phillip Perry wrote: Read about it the they day. From what I've collected. It was in Phase 1, about 4 hrs in. On departure a door opened and the pilot was seen wrestling with the door during the takeoff roll, rotation, and climb out. I think I recall a pilot witness saying it got to around 30 AGL before it descended back into the ground. Sent from my iPhone On Nov 19, 2016, at 5:58 PM, Kelly McMullen wrote: Anyone know anything about this crash? https://www.aviation-safety.net/wikibase/wiki.php?id=191188 -sent from the I-droid implanted in my forearm ________________________________________________________________________________
Date: Nov 21, 2016
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Fuel Valve Mounting Bracket
Date: Nov 21, 2016
My quick build fuselage came with the mounting bracket F1048C-1 installed facing down. There was a tag attached saying that it should be reinstalled face up (the U facing up). They also sent me a new bracket in case I messed up the installed one removing it. I am now in the process of installing the fuel valve, an Andair unit. I have made a mounting plate to rivet to the F1048C-1 so that mounting holes will match the Andair valve. I am ready to flip the mounting bracket but find the flush rivets on the aft end of the bracket are 1/4 inch from the vertical panel of the seat mounting structure. I do not have a drill that will fit in that close of an area and my rivet gun is too wide to drive a rivet in that space. How have others made this change? Dave ________________________________________________________________________________
Date: Nov 21, 2016
Subject: Re: Fuel Valve Mounting Bracket
I cut the sides off the bracket and riveted two pieces of angle aluminum to get the width I need, got the Andair extension, mounted valve as low as possible, then cut the extension to required length. I did not want the valve up near the top of the tunnel, as that creates potential for vapor or air lock. I got the right angle fitting from Van's catalog to make the connection at the bottom of the valve. -sent from the I-droid implanted in my forearm On Mon, Nov 21, 2016 at 10:52 AM, David J. Fritzsche wrote: > > > My quick build fuselage came with the mounting bracket F1048C-1 installed > facing down. There was a tag attached saying that it should be reinstalled > face up (the U facing up). They also sent me a new bracket in case I > messed up the installed one removing it. I am now in the process of > installing the fuel valve, an Andair unit. I have made a mounting plate to > rivet to the F1048C-1 so that mounting holes will match the Andair valve. > I am ready to flip the mounting bracket but find the flush rivets on the > aft end of the bracket are 1/4 inch from the vertical panel of the seat > mounting structure. I do not have a drill that will fit in that close of > an area and my rivet gun is too wide to drive a rivet in that space. How > have others made this change? > > Dave > > ________________________________________________________________________________
Date: Nov 22, 2016
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Nov 22, 2016
Kelly, The only right angle fittings I can find in Van's catalog are tube/pipe. Both my valve and filter have male tubing connections. I would need a right angle with female tube connections on both ends. Dave ~~~~~~~~~~~~~~~~~~ David J. Fritzsche Professor, Retired Penn State ~~~~~~~~~~~~~~~~~~ On 11/21/2016 12:51 PM, Kelly McMullen wrote: > I cut the sides off the bracket and riveted two pieces of angle > aluminum to get the width I need, got the Andair extension, mounted > valve as low as possible, then cut the extension to required length. I > did not want the valve up near the top of the tunnel, as that creates > potential for vapor or air lock. I got the right angle fitting from > Van's catalog to make the connection at the bottom of the valve. > > -sent from the I-droid implanted in my forearm > > On Mon, Nov 21, 2016 at 10:52 AM, David J. Fritzsche > > wrote: > > > > > > My quick build fuselage came with the mounting bracket F1048C-1 > installed facing down. There was a tag attached saying that it > should be reinstalled face up (the U facing up). They also sent > me a new bracket in case I messed up the installed one removing > it. I am now in the process of installing the fuel valve, an > Andair unit. I have made a mounting plate to rivet to the F1048C-1 > so that mounting holes will match the Andair valve. I am ready to > flip the mounting bracket but find the flush rivets on the aft end > of the bracket are 1/4 inch from the vertical panel of the seat > mounting structure. I do not have a drill that will fit in that > close of an area and my rivet gun is too wide to drive a rivet in > that space. How have others made this change? > > Dave > =================================== > br> fts!) > r> > /www.aeroelectric.com" rel="noreferrer" > target="_blank">www.aeroelectric.com > w.buildersbooks.com" rel="noreferrer" > target="_blank">www.buildersbooks.com > p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com > " rel="noreferrer" target="_blank">www.mrrace.com > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > =================================== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > ________________________________________________________________________________
Date: Nov 22, 2016
It is called the F Swivel Tee. There is only one female fitting, as the other two are intended to have female flared fittings connected to them, like virtually all of the fuel system connections. -sent from the I-droid implanted in my forearm On Tue, Nov 22, 2016 at 1:29 PM, David J. Fritzsche wrote: > Kelly, > > The only right angle fittings I can find in Van's catalog are tube/pipe. > Both my valve and filter have male tubing connections. I would need a > right angle with female tube connections on both ends. > > Dave > > ~~~~~~~~~~~~~~~~~~ > David J. Fritzsche > Professor, Retired > Penn State > ~~~~~~~~~~~~~~~~~~ > > On 11/21/2016 12:51 PM, Kelly McMullen wrote: > > I cut the sides off the bracket and riveted two pieces of angle aluminum > to get the width I need, got the Andair extension, mounted valve as low as > possible, then cut the extension to required length. I did not want the > valve up near the top of the tunnel, as that creates potential for vapor or > air lock. I got the right angle fitting from Van's catalog to make the > connection at the bottom of the valve. > > -sent from the I-droid implanted in my forearm > > On Mon, Nov 21, 2016 at 10:52 AM, David J. Fritzsche > wrote: > >> >> >> My quick build fuselage came with the mounting bracket F1048C-1 installed >> facing down. There was a tag attached saying that it should be reinstalled >> face up (the U facing up). They also sent me a new bracket in case I >> messed up the installed one removing it. I am now in the process of >> installing the fuel valve, an Andair unit. I have made a mounting plate to >> rivet to the F1048C-1 so that mounting holes will match the Andair valve. >> I am ready to flip the mounting bracket but find the flush rivets on the >> aft end of the bracket are 1/4 inch from the vertical panel of the seat >> mounting structure. I do not have a drill that will fit in that close of >> an area and my rivet gun is too wide to drive a rivet in that space. How >> have others made this change? >> >> Dave >> =================================== >> br> fts!) >> r> > /www.aeroelectric.com" rel="noreferrer" target="_blank">www. >> aeroelectric.com >> w.buildersbooks.com" rel="noreferrer" target="_blank">www. >> buildersbooks.com >> p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com >> e.com" rel="noreferrer" target="_blank">www.mypilotstore.com >> " rel="noreferrer" target="_blank">www.mrrace.com >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> -Matt Dralle, List Admin. >> =================================== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navig >> ator?RV10-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> > > ________________________________________________________________________________
Date: Nov 23, 2016
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Subject: WTB: Cleveland brake parts
Date: Nov 25, 2016
All, I'm looking for the backing plate and pressure plates for my Cleveland 3059E wheel brakes. I'd like to get 2 ea 063-03400 and 2 ea 064-02900. Short of that, if you upgraded your RV0-10 brakes and have the old brakes for sale as a complete kit I may be interested in that. Let me know ~Marc Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463101#463101 ________________________________________________________________________________
Date: Nov 26, 2016
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2016
Date: Nov 28, 2016
Subject: Installing engine mount bosses to the engine
Guys Since it is not in the Van's RV-10 manual, does anybody have a drawing that shows the hardware used to install the 4 engine mount bosses to the Lyco 540 engine? I suppose that I have to use 16 nuts + 16 flat washers + 16 star washers, but I want to be sure which, and in what order. On the other hand, what is to tool to use to tighten the 2 inner nuts of each of the 4 mount bosses? Specially the ones on the engine bottom? Best Carlos Enviado do meu iPhone ________________________________________________________________________________
Date: Nov 28, 2016
Subject: Fund Raiser Behind By 28% - Please Contribute Today!
Dear Listers, The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 28%. Please take this opportunity to show your support for the Matronics Lists and Forums! Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List and Forums Administrator ________________________________________________________________________________
Subject: Grease guns
Date: Nov 28, 2016
I finally got frustrated enough this weekend to ask a question of anyone who has a good answer. For grease guns, I went to the local farm and barn type store and got a couple of what looked like pretty good guns. But, while I've had good luck with the grease gun that I use for my wheel bearings and nose swivel area, which I use a different grease for, I have HORRIBLE luck with my grease gun that I use with Aeroshell 6. The gun that is giving me issues is basically this one: http://www.mastertectools.net/image_atus/31004.jpg It's got the loader fitting on top that I never use, and a bleed pushbutton to purge air. I tore it all apart this weekend again and it appears that just a spring pushes the plunger up to force grease up to the top section where if it enters a hole, squeezing the handle will push a piston forward and inject the grease. Stupid simple. The issue mainly seems to be that Aeroshell 6 is just so thick that it doesn't flow up into that cavity. I was able to work around it this weekend by repeatedly unscrewing the top a few threads, which would help allow the spring to push grease up, then crank the top back down on the gun. The added pressure on the grease made it flow into the orifice and then it would pump. But, I had to repeat this every pumping. I'm about to throw this thing out the window. Is there something I'm missing? (The seal on the plunger does also seem to seal into the grease tube BTW...it's a rubber sealed plunger head.) Or does everyone have a problem with this thick Aeroshell 6? If someone has a great grease gun that works real well, send me a link to it...I'd be happy to just buy one if it will give me a much more enjoyable greasing experience. Tim ________________________________________________________________________________
Subject: Re: Grease guns
Date: Nov 28, 2016
You need to get all the air out of the upper chamber. Take the hose off, squeeze the handle and hold it while you put your finger over the outlet so air doesn't go back in. Repeat as often as necessary. Make sure there isn't any air space in the hose, put it back on and it should be OK. Linn .... lots of foul language at grease guns. > > I finally got frustrated enough this weekend to ask a question of > anyone who has a good answer. > > For grease guns, I went to the local farm and barn type store > and got a couple of what looked like pretty good guns. > But, while I've had good luck with the grease gun that I use > for my wheel bearings and nose swivel area, which I use a > different grease for, I have HORRIBLE luck with my grease > gun that I use with Aeroshell 6. > > The gun that is giving me issues is basically this one: > http://www.mastertectools.net/image_atus/31004.jpg > > It's got the loader fitting on top that I never use, and a bleed > pushbutton to purge air. > > I tore it all apart this weekend again and it appears that > just a spring pushes the plunger up to force grease up to the top > section where if it enters a hole, squeezing the handle will > push a piston forward and inject the grease. > Stupid simple. > The issue mainly seems to be that Aeroshell 6 is just so > thick that it doesn't flow up into that cavity. > > I was able to work around it this weekend by repeatedly > unscrewing the top a few threads, which would help > allow the spring to push grease up, then crank the top > back down on the gun. The added pressure on the grease > made it flow into the orifice and then it would pump. > But, I had to repeat this every pumping. > > I'm about to throw this thing out the window. Is there > something I'm missing? (The seal on the plunger does > also seem to seal into the grease tube BTW...it's a > rubber sealed plunger head.) > Or does everyone have a problem with this thick > Aeroshell 6? > > If someone has a great grease gun that works real well, > send me a link to it...I'd be happy to just buy one > if it will give me a much more enjoyable greasing > experience. > > Tim > > ________________________________________________________________________________
Date: Nov 28, 2016
Subject: Re: Installing engine mount bosses to the engine
Are you talking about the fittings on the engine? Those would be in the engine overhaul manual. If you are talking about bolting the engine to the engine mount with the shock disks between the two, that is in the plans. Firewall forward section 1 page 5. -sent from the I-droid implanted in my forearm On Mon, Nov 28, 2016 at 10:26 AM, Carlos Trigo wrote: > > Guys > > Since it is not in the Van's RV-10 manual, does anybody have a drawing > that shows the hardware used to install the 4 engine mount bosses to the > Lyco 540 engine? > I suppose that I have to use 16 nuts + 16 flat washers + 16 star washers, > but I want to be sure which, and in what order. > > On the other hand, what is to tool to use to tighten the 2 inner nuts of > each of the 4 mount bosses? > Specially the ones on the engine bottom? > > Best > Carlos > > Enviado do meu iPhone > > ________________________________________________________________________________
Date: Nov 28, 2016
Hi Kelly I am talking about the fittings on the engine, each with 4 nuts, and I don't have the engine overhaul manual... Thanks Carlos Enviado do meu iPhone No dia 28/11/2016, =C3-s 22:48, Kelly McMullen escreve u: > Are you talking about the fittings on the engine? Those would be in the en gine overhaul manual. > If you are talking about bolting the engine to the engine mount with the s hock disks between the two, that is in the plans. > Firewall forward section 1 page 5. > > -sent from the I-droid implanted in my forearm > >> On Mon, Nov 28, 2016 at 10:26 AM, Carlos Trigo wr ote: >> >> Guys >> >> Since it is not in the Van's RV-10 manual, does anybody have a drawing th at shows the hardware used to install the 4 engine mount bosses to the Lyco 5 40 engine? >> I suppose that I have to use 16 nuts + 16 flat washers + 16 star washers, but I want to be sure which, and in what order. >> >> On the other hand, what is to tool to use to tighten the 2 inner nuts of e ach of the 4 mount bosses? >> Specially the ones on the engine bottom? >> >> Best >> Carlos >> >> Enviado do meu iPhone >> >> ========================= >> br> fts!) >> r> > com" rel="noreferrer" target="_blank">www.aeroelectric.com >> w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersboo ks.com >> p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com >> e.com" rel="noreferrer" target="_blank">www.mypilotstore.com >> " rel="noreferrer" target="_blank">www.mrrace.com >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> -Matt Dralle, List Admin. >> ========================= >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= >> >> >> > ________________________________________________________________________________
Date: Nov 28, 2016
I'm guessing there's a problem in translation ..... Sounds like his question is about the ears that the isolation mounts attach to. I forget whether there are studs or bolts there. Linn On 11/28/2016 6:37 PM, Carlos Trigo wrote: > Hi Kelly > > I am talking about the fittings on the engine, each with 4 nuts, and I > don't have the engine overhaul manual... > > Thanks > Carlos > > Enviado do meu iPhone > > No dia 28/11/2016, s 22:48, Kelly McMullen > escreveu: > >> Are you talking about the fittings on the engine? Those would be in >> the engine overhaul manual. >> If you are talking about bolting the engine to the engine mount with >> the shock disks between the two, that is in the plans. >> Firewall forward section 1 page 5. >> >> -sent from the I-droid implanted in my forearm >> >> On Mon, Nov 28, 2016 at 10:26 AM, Carlos Trigo > > wrote: >> >> > >> >> Guys >> >> Since it is not in the Van's RV-10 manual, does anybody have a >> drawing that shows the hardware used to install the 4 engine >> mount bosses to the Lyco 540 engine? >> I suppose that I have to use 16 nuts + 16 flat washers + 16 star >> washers, but I want to be sure which, and in what order. >> >> On the other hand, what is to tool to use to tighten the 2 inner >> nuts of each of the 4 mount bosses? >> Specially the ones on the engine bottom? >> >> Best >> Carlos >> >> Enviado do meu iPhone >> >> =================================== >> br> fts!) >> r> > com" rel="noreferrer" target="_blank">www.aeroelectric.com >> <http://www.aeroelectric.com> >> w.buildersbooks.com <http://w.buildersbooks.com>" >> rel="noreferrer" target="_blank">www.buildersbooks.com >> <http://www.buildersbooks.com> >> p.com <http://p.com>" rel="noreferrer" >> target="_blank">www.homebuilthelp.com <http://www.homebuilthelp.com> >> e.com <http://e.com>" rel="noreferrer" >> target="_blank">www.mypilotstore.com <http://www.mypilotstore.com> >> " rel="noreferrer" target="_blank">www.mrrace.com >> <http://www.mrrace.com> >> rel="noreferrer" >> target="_blank">http://www.matronics.com/contribution >> -Matt Dralle, List Admin. >> =================================== >> -List" rel="noreferrer" >> target="_blank">http://www.matronics.com/Navigator?RV10-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" >> target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> ________________________________________________________________________________
Date: Nov 29, 2016
That=99s right, I am talking about the =9Cears=9D that the isolation rubber mounts attach to. Each of these 4 =9Cears=9D are attached to the engine (which has 4 studs) with 4 nuts and washers, and that=99s what I don=99t know the order. I suppose it=99s first the flat washer, then the star washer, then the nut . Right? Carlos De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Em nome de Linn Walters Enviada: Monday, November 28, 2016 11:47 PM Para: rv10-list(at)matronics.com Assunto: Re: RV10-List: Installing engine mount bosses to the engine I'm guessing there's a problem in translation ..... Sounds like his question is about the ears that the isolation mounts attach to. I forget whether there are studs or bolts there. Linn On 11/28/2016 6:37 PM, Carlos Trigo wrote: Hi Kelly I am talking about the fittings on the engine, each with 4 nuts, and I don't have the engine overhaul manual... Thanks Carlos Enviado do meu iPhone No dia 28/11/2016, =C3-s 22:48, Kelly McMullen > escreveu: Are you talking about the fittings on the engine? Those would be in the engine overhaul manual. If you are talking about bolting the engine to the engine mount with the shock disks between the two, that is in the plans. Firewall forward section 1 page 5. -sent from the I-droid implanted in my forearm On Mon, Nov 28, 2016 at 10:26 AM, Carlos Trigo > wrote: > Guys Since it is not in the Van's RV-10 manual, does anybody have a drawing that shows the hardware used to install the 4 engine mount bosses to the Lyco 540 engine? I suppose that I have to use 16 nuts + 16 flat washers + 16 star washers, but I want to be sure which, and in what order. On the other hand, what is to tool to use to tighten the 2 inner nuts of each of the 4 mount bosses? Specially the ones on the engine bottom? Best Carlos Enviado do meu iPhone br> fts!) r> > com" rel="noreferrer" target="_blank">www.aeroelectric.com <http://www.aeroelectric.com> w.buildersbooks.com <http://w.buildersbooks.com> " rel="noreferrer" target="_blank">www.buildersbooks.com <http://www.buildersbooks.com> p.com <http://p.com> " rel="noreferrer" target="_blank">www.homebuilthelp.com <http://www.homebuilthelp.com> e.com <http://e.com> " rel="noreferrer" target="_blank">www.mypilotstore.com <http://www.mypilotstore.com> " rel="noreferrer" target="_blank">www.mrrace.com <http://www.mrrace.com> rel="noreferrer" target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Nov 28, 2016
Hey Carlos, I've searched the manual, no pictures of the "ear mounts", but basically "yes" always install lock washers next to the nut. The purpose of the lock washer is to grab the nut to keep it from backing off. Hope that addresses your issue. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Fly off completed ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463407#463407 ________________________________________________________________________________
Date: Nov 28, 2016
I just took mine off today to attach a better ground path to the block. Mi ne only had 2 studs per ear. I need to check the torque in the manual to confirm it's 100% correct, but I torqued the nuts to 15.5 lbs per Vans Section 5 torque specs. Sent from my iPhone > On Nov 28, 2016, at 6:02 PM, Carlos Trigo wrote: > > That=99s right, I am talking about the =9Cears=9D that t he isolation rubber mounts attach to. > Each of these 4 =9Cears=9D are attached to the engine (which h as 4 studs) with 4 nuts and washers, and that=99s what I don=99t know the order. > I suppose it=99s first the flat washer, then the star washer, then t he nut . Right? > > Carlos > > De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ma tronics.com] Em nome de Linn Walters > Enviada: Monday, November 28, 2016 11:47 PM > Para: rv10-list(at)matronics.com > Assunto: Re: RV10-List: Installing engine mount bosses to the engine > > I'm guessing there's a problem in translation ..... > Sounds like his question is about the ears that the isolation mounts attac h to. > I forget whether there are studs or bolts there. > Linn > > On 11/28/2016 6:37 PM, Carlos Trigo wrote: > Hi Kelly > > I am talking about the fittings on the engine, each with 4 nuts, and I don 't have the engine overhaul manual... > > Thanks > Carlos > > Enviado do meu iPhone > > No dia 28/11/2016, =C3-s 22:48, Kelly McMullen escre veu: > > Are you talking about the fittings on the engine? Those would be in the en gine overhaul manual. > If you are talking about bolting the engine to the engine mount with the s hock disks between the two, that is in the plans. > Firewall forward section 1 page 5. > > -sent from the I-droid implanted in my forearm > > On Mon, Nov 28, 2016 at 10:26 AM, Carlos Trigo wro te: > > Guys > > Since it is not in the Van's RV-10 manual, does anybody have a drawing tha t shows the hardware used to install the 4 engine mount bosses to the Lyco 5 40 engine? > I suppose that I have to use 16 nuts + 16 flat washers + 16 star washers, b ut I want to be sure which, and in what order. > > On the other hand, what is to tool to use to tighten the 2 inner nuts of e ach of the 4 mount bosses? > Specially the ones on the engine bottom? > > Best > Carlos > > Enviado do meu iPhone > > ========================= > br> fts!) > r> > com" rel="noreferrer" target="_blank">www.aeroelectric.com > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbook s.com > p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com > " rel="noreferrer" target="_blank">www.mrrace.com > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > ========================= > -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navig ator?RV10-List > ========================= > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========================= > > > > > ________________________________________________________________________________
Date: Nov 28, 2016
Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Nov 28, 2016, at 7:20 PM, Lew Gallagher wrote: > > > Hey Carlos, > > I've searched the manual, no pictures of the "ear mounts", but basically " yes" always install lock washers next to the nut. The purpose of the lock w asher is to grab the nut to keep it from backing off. Hope that addresses y our issue. Later, - Lew > > -------- > non-pilot > crazy about building > NOW OFICIALLY BUILDER #40549 > Fly off completed ! > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=463407#463407 > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Nov 28, 2016
Hey Carlos, Jesse's diagram is boss! Here's a picture from Tim's build. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Fly off completed ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463410#463410 Attachments: http://forums.matronics.com//files/rv200510270006_175.jpg ________________________________________________________________________________
Date: Nov 28, 2016
I got back to the house tonight where I can see the Lycoming overhaul manual. The correct torque for the 3/8" bolt is 300 in/lb. My 'ears' only have 2 studs to put nuts on and they're 3/8. If you've got 4 studs, then I'm not sure what yours are. So here's the entire torque limit chart in the manual if yours are different. Phil [image: Inline image 1] On Mon, Nov 28, 2016 at 6:53 PM, Phillip Perry wrote : > I just took mine off today to attach a better ground path to the block. > Mine only had 2 studs per ear. > > I need to check the torque in the manual to confirm it's 100% correct, bu t > I torqued the nuts to 15.5 lbs per Vans Section 5 torque specs. > > > Sent from my iPhone > > On Nov 28, 2016, at 6:02 PM, Carlos Trigo wrote: > > That=99s right, I am talking about the =9Cears=9D that the isolation rubber > mounts attach to. > > Each of these 4 =9Cears=9D are attached to the engine (which has 4 studs) with > 4 nuts and washers, and that=99s what I don=99t know the orde r. > > I suppose it=99s first the flat washer, then the star washer, then the nut > . Right? > > > Carlos > > > *De:* owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list- > server(at)matronics.com ] *Em nome de *Linn > Walters > *Enviada:* Monday, November 28, 2016 11:47 PM > *Para:* rv10-list(at)matronics.com > *Assunto:* Re: RV10-List: Installing engine mount bosses to the engine > > > I'm guessing there's a problem in translation ..... > Sounds like his question is about the ears that the isolation mounts > attach to. > I forget whether there are studs or bolts there. > Linn > > On 11/28/2016 6:37 PM, Carlos Trigo wrote: > > Hi Kelly > > > I am talking about the fittings on the engine, each with 4 nuts, and I > don't have the engine overhaul manual... > > > Thanks > > Carlos > > Enviado do meu iPhone > > > No dia 28/11/2016, =C3-s 22:48, Kelly McMullen escr eveu: > > Are you talking about the fittings on the engine? Those would be in the > engine overhaul manual. > > If you are talking about bolting the engine to the engine mount with the > shock disks between the two, that is in the plans. > > Firewall forward section 1 page 5. > > > -sent from the I-droid implanted in my forearm > > > On Mon, Nov 28, 2016 at 10:26 AM, Carlos Trigo > wrote: > > > Guys > > Since it is not in the Van's RV-10 manual, does anybody have a drawing > that shows the hardware used to install the 4 engine mount bosses to the > Lyco 540 engine? > I suppose that I have to use 16 nuts + 16 flat washers + 16 star washers, > but I want to be sure which, and in what order. > > On the other hand, what is to tool to use to tighten the 2 inner nuts of > each of the 4 mount bosses? > Specially the ones on the engine bottom? > > Best > Carlos > > Enviado do meu iPhone > > ======================== =========== > br> fts!) > r> > com" rel="noreferrer" target="_blank">www.aeroelectric.com > w.buildersbooks.com" rel="noreferrer" target="_blank">www. > buildersbooks.com > p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com > " rel="noreferrer" target="_blank">www.mrrace.com > rel="noreferrer" target="_blank">http://www.matronics.com/contributio n > -Matt Dralle, List Admin. > ======================== =========== > -List" rel="noreferrer" target="_blank">http://www.matronics.com/ > Navigator?RV10-List > ======================== =========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contributio n > ======================== =========== > > ________________________________________________________________________________
Date: Nov 28, 2016
Tim, I fought the same problem for years - couldn't reliably burp all the air out of the gun, so it would stop pumping. Then somebody showed me that it is possible (at least on my gun, I understand this is a common feature) to turn the plunger handle to just the right location so it will engage with the grease puck, allowing the operator to push on the end of the plunger handle and apply extra force to the grease column. Then you can operate the lever (or use the air burp fitting, if so equipped) to get a nice air-free column of grease flowing. In practice: rotate the plunger handle a little, push on it, see if there is resistance. If not, turn more and try again. Repeat until the plunger handle is locked to the grease puck. Tim -- Tim Lewis -- HEF (Manassas, VA) A&P RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 740 hrs Tim Olson wrote on 11/28/2016 10:01 AM: > > I finally got frustrated enough this weekend to ask a question of > anyone who has a good answer. > > For grease guns, I went to the local farm and barn type store > and got a couple of what looked like pretty good guns. > But, while I've had good luck with the grease gun that I use > for my wheel bearings and nose swivel area, which I use a > different grease for, I have HORRIBLE luck with my grease > gun that I use with Aeroshell 6. > > The gun that is giving me issues is basically this one: > http://www.mastertectools.net/image_atus/31004.jpg > > It's got the loader fitting on top that I never use, and a bleed > pushbutton to purge air. > > I tore it all apart this weekend again and it appears that > just a spring pushes the plunger up to force grease up to the top > section where if it enters a hole, squeezing the handle will > push a piston forward and inject the grease. > Stupid simple. > The issue mainly seems to be that Aeroshell 6 is just so > thick that it doesn't flow up into that cavity. > > I was able to work around it this weekend by repeatedly > unscrewing the top a few threads, which would help > allow the spring to push grease up, then crank the top > back down on the gun. The added pressure on the grease > made it flow into the orifice and then it would pump. > But, I had to repeat this every pumping. > > I'm about to throw this thing out the window. Is there > something I'm missing? (The seal on the plunger does > also seem to seal into the grease tube BTW...it's a > rubber sealed plunger head.) > Or does everyone have a problem with this thick > Aeroshell 6? > > If someone has a great grease gun that works real well, > send me a link to it...I'd be happy to just buy one > if it will give me a much more enjoyable greasing > experience. > > Tim > > ________________________________________________________________________________
Date: Nov 29, 2016
Subject: Just Two Days Left! - Still Behind...
Dear Listers, There are just two more days left in this years List Fund Raiser. We are still way behind last year in terms of the number of contributions and total contribution amount. I really want to keep providing these services to the homebuilt community, but it take resources. Since there's no advertising budget or deep pockets to keep the operation a float, its solely your generosity during the Fund Raiser that keeps things going. Please make a Contribution today. If you've been putting off showing your support for the Lists, now is the time to do it! Make a contribution with a Credit Card or though PayPal at that Matronics Contribution web site: http://www.matronics.com/contribution Or, drop a check in the mail: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2016
Thanks to you guys who replied on my grease gun question. What I did was this: I purchased a new Lincoln 1134 gun, that runs about $40. It was reviewed and rated pretty high and is supposed to have a pretty heavy duty spring. I definitely could be not getting all the air out of it. Given that there's a relief button on top, this SHOULD be pretty easy to do. But I think the root cause of the issue is that the Aeroshell 6 is just so thick that the spring isn't enough to get it to flow up into the gun, even to release air. Being in Wisconsin with temps in the 30's doesn't help, although I did try to warm the gun with my heater last week. Also, I did read your thing, Tim, and after tearing apart my gun, there definitely wasn't any handle orientation that was possible on my existing gun. It was a straight shaft that just slips thru 2 plunger items. One is a backing plate/stem for the rubber plunger, which keeps the plunger level, and the other is the rubber plunger itself. Above that it's just a flat washer and cotter pin. So nothing that you can twist to make any difference. The grease isn't slipping past the plunger, either. So really the only thing that would make the grease not be burpable is if it were just too thick for the plunger spring to force upwards. That's why I just went for a new gun. With the new gun, I'll burp it out well and see how it works, and report back. I'll tear it apart first. Maybe I'll even tear them both apart and show internal photos. If the new gun works well, it may help others to document it. My old gun I'll relegate to using a different, less thick grease, for just doing wheel bearings and chassis stuff at home. More to come in a week or so. Tim On 11/28/2016 10:12 PM, Tim Lewis wrote: > > Tim, > > I fought the same problem for years - couldn't reliably burp all the air > out of the gun, so it would stop pumping. > > Then somebody showed me that it is possible (at least on my gun, I > understand this is a common feature) to turn the plunger handle to just > the right location so it will engage with the grease puck, allowing the > operator to push on the end of the plunger handle and apply extra force > to the grease column. Then you can operate the lever (or use the air > burp fitting, if so equipped) to get a nice air-free column of grease > flowing. > > In practice: rotate the plunger handle a little, push on it, see if > there is resistance. If not, turn more and try again. Repeat until the > plunger handle is locked to the grease puck. > > Tim > ________________________________________________________________________________
Date: Nov 30, 2016
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 53! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2016
Subject: Installing the "Red cube"
Guys Those of you who installed the fuel flow sensor (aka the "red cube") below the engine, between the throttle body and the fuel distribution "spider", you had to order a small fire sleeved fuel line, right? Can you please tell me where did you order it, and the specifications (length, diameter and type & size of the fittings) of that extra fuel line? Thanks Carlos ________________________________________________________________________________
Subject: Re: Installing the "Red cube"
Date: Nov 30, 2016
You'll need two lines, one from the servo to redcube and the other from the redcube to the spider. The dimensions depend on how and where you are mounting the redcube. Some fuel line makers can chop your original fuel line in two and put two new ends on them. If you already have your fuel line that might be a good option. I got integral firesleeved hoses from Stratoflex, but I think the ceramic fibers in the red firesleeve keeps the hose a bit cooler than the brown integral silicone. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=463602#463602 ________________________________________________________________________________
Date: Nov 30, 2016
I have lots of JIC fittings for the braided steel/teflon hose. So, I cut the kit hose from the mechanical fuel pump to the fuel servo. Bad move. The teflon liner wasn't the correct size for my fittings so I made up two hoses and used the firesleeve from the kit hose. I mounted my FF sender on a plate attached to the lower, fwd engine mount tube with Adel clamps. I wanted as much straight in/out as I could get. Different from the vertical hose you want, but the idea is the same. You can get the braided/teflon hose with 37* fittings at most any hydraulic shop ..... tell them it's for a race car or airboat .... they don't like to hear 'airplane'. Linn On 11/30/2016 1:39 PM, Carlos Trigo wrote: > > Guys > > Those of you who installed the fuel flow sensor (aka the "red cube") below the engine, between the throttle body and the fuel distribution "spider", you had to order a small fire sleeved fuel line, right? > > Can you please tell me where did you order it, and the specifications (length, diameter and type & size of the fittings) of that extra fuel line? > > Thanks > Carlos > > ________________________________________________________________________________
Date: Dec 01, 2016
I made my own two hoses (servo to cube, cube to spider): 4 ea Eaton Hose Fitting F66000-4 (ACS part 05-01320) Aeroquip clamps for hose ends, and to clamp firesleeve to red cube - Aeroquip Clamp 900591B-2C, -1C, and -3C. Aeroquip Firesleeve AE102-8 (5 feet) Aeroquip Firesleeve AE102-24 (1 foot) Aeroquip Hose #666-4 (6 feet). Aeroquip publishes instructions on how to assemble. -- Tim Lewis -- HEF (Manassas, VA) A&P RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 740 hrs Carlos Trigo wrote on 11/30/2016 10:39 AM: > > Guys > > Those of you who installed the fuel flow sensor (aka the "red cube") below the engine, between the throttle body and the fuel distribution "spider", you had to order a small fire sleeved fuel line, right? > > Can you please tell me where did you order it, and the specifications (length, diameter and type & size of the fittings) of that extra fuel line? > > Thanks > Carlos > > ________________________________________________________________________________
Date: Dec 02, 2016
Thanks a lot Tim That's exactly the information I needed! Cheers Carlos -----Mensagem original----- De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Em nome de Tim Lewis Enviada: Friday, December 2, 2016 3:54 AM Para: rv10-list(at)matronics.com Assunto: Re: RV10-List: Installing the "Red cube" I made my own two hoses (servo to cube, cube to spider): 4 ea Eaton Hose Fitting F66000-4 (ACS part 05-01320) Aeroquip clamps for hose ends, and to clamp firesleeve to red cube - Aeroquip Clamp 900591B-2C, -1C, and -3C. Aeroquip Firesleeve AE102-8 (5 feet) Aeroquip Firesleeve AE102-24 (1 foot) Aeroquip Hose #666-4 (6 feet). Aeroquip publishes instructions on how to assemble. -- Tim Lewis -- HEF (Manassas, VA) A&P RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 740 hrs Carlos Trigo wrote on 11/30/2016 10:39 AM: > > Guys > > Those of you who installed the fuel flow sensor (aka the "red cube") below the engine, between the throttle body and the fuel distribution "spider", you had to order a small fire sleeved fuel line, right? > > Can you please tell me where did you order it, and the specifications (length, diameter and type & size of the fittings) of that extra fuel line? > > Thanks > Carlos > > ________________________________________________________________________________
Date: Dec 02, 2016
Subject: Built-in Oxygen (Mountain High)
For those of you who have installed the EDS-4ip system from Mountain High, have any of you found a method to shove the tubing over the barbs fully? I've never given birth to a child, personally, but I'm pretty sure this is what it's like. Hopefully there is a well-known lubricant out there that won't damage the electronics inside the distribution units. Or perhaps you can give me a tip to become more dilated. Either way, something has to give. Phil Sent from my iPhone ________________________________________________________________________________
Subject: Re: Built-in Oxygen (Mountain High)
Date: Dec 02, 2016
I don't have that system but I've always slightly warmed the tubing with a heat gun....carefully. I bought some of that tubing type and I think that would help a lot. Don't warm it too far back or it gets too flexible on the pushing area. Tim > On Dec 2, 2016, at 10:35 AM, Phillip Perry wrote: > > > For those of you who have installed the EDS-4ip system from Mountain High, have any of you found a method to shove the tubing over the barbs fully? > > I've never given birth to a child, personally, but I'm pretty sure this is what it's like. > > Hopefully there is a well-known lubricant out there that won't damage the electronics inside the distribution units. > > Or perhaps you can give me a tip to become more dilated. Either way, something has to give. > > Phil > > > > Sent from my iPhone > > > ________________________________________________________________________________
From: "Gautier, Thomas N (3262)" <thomas.n.gautier(at)jpl.nasa.gov>
Subject: Loehle aircraft and airplane paint
Date: Dec 02, 2016
RV-10ers, After some years of building and lurking on the list I am ready to pain t my =9210. I have been using Loehle Aircraft primers for the fiberglass pa rts and I would like to do the same for painting the metal. However I have been unsuccessful in contacting Loehle Aircraft by telephone nor e-mail aft er repeated attempts over the last two weeks. Does anyone know if something has happened to Loehle Aircraft? Also, do you listers have suggestions (of course you do) for a different , easily usable paint system in case I can=92t get more Loehle material? Regards, Nick Gautier N363TG reserved ________________________________________________________________________________
Date: Dec 02, 2016
That's the secret. The heat worked. We don't plan on having any more kids. But just in case we do, I'm going to keep a spare heat gun behind the seat of the truck. It's way cheaper and faster than medication.... Sent from my iPhone > On Dec 2, 2016, at 10:58 AM, Tim Olson wrote: > > > I don't have that system but I've always slightly warmed the tubing with a heat gun....carefully. I bought some of that tubing type and I think that would help a lot. Don't warm it too far back or it gets too flexible on the pushing area. > Tim > >> On Dec 2, 2016, at 10:35 AM, Phillip Perry wrote: >> >> >> For those of you who have installed the EDS-4ip system from Mountain High, have any of you found a method to shove the tubing over the barbs fully? >> >> I've never given birth to a child, personally, but I'm pretty sure this is what it's like. >> >> Hopefully there is a well-known lubricant out there that won't damage the electronics inside the distribution units. >> >> Or perhaps you can give me a tip to become more dilated. Either way, something has to give. >> >> Phil >> >> >> >> Sent from my iPhone >> >> >> > >
October 13, 2016 - December 02, 2016
RV10-Archive.digest.vol-mj
