RV10-Archive.digest.vol-mn
April 14, 2017 - Present
      >> Bill
Date: Apr 14, 2017
Subject: Re: LSE Plasma III - Timing
I did. It wasn't as confusing as I thought it would be. I will try and type something up and send it out in the next day or so. Pretty straight forward. The most difficult part was finding/marking TDC for each coil. Sent from my iPhone > On Apr 14, 2017, at 7:58 AM, rvdave wrote: > > > Did you ever find a procedure for verifying timing? Almost to that point and want to be ready. > > -------- > Dave Ford > RV6 for sale > RV10 building > Cadillac, MI > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=468381#468381 > > > > > > > > > ________________________________________________________________________________
Date: Apr 14, 2017
Subject: Re: SB 14-08-29 and life of nose shock disks
N312F 800+ hours hard surface runway, 6 years, no cracks, 1 washer Jim C On Fri, Apr 14, 2017 at 9:47 AM, Kelly McMullen wrote: > Now that those flying have a few more years, any feedback on how much the > shock disks are compressing over time? Early achievers are over 10 yrs now? > I'm curious, as the exact same disks are used on all three gear legs of > Mooneys. On the older, short body style (2575 gross) they seem to last 20+ > years. > On intermediate body (F,J&K models)(2740-2800 gross) they seem to last > 10-15 yrs. On newer long body models with up to 3200 gross they are only > good for 5-7 yrs. > IIRC only a few doing the SB found cracks? Should the retaining bolt at > the top of the hat be tight or free to rotate when the plane is on gear > with weight on nose? > Trying to complete condition inspection. > Kelly > > -sent from the I-droid implanted in my forearm > > On Wed, Sep 17, 2014 at 1:15 PM, Linn Walters > wrote: > >> >> I would think this comes under the heading of 'if it ain't broke .... >> don't fix it'. >> They will continue to compress, but the rate slows down over time. They >> should last for 10 years or more. I'd keep adding spacers until you see >> cracks in the elastomer. >> Linn >> >> On 9/17/2014 4:06 PM, Bill Watson wrote: >> >>> >>> - I don't know about replacing the nose wheel elastomers. Afterall, they >>> are already compressed and 'set'. Thoughts? >>> >>> Bill >>> >>> ________________________________________________________________________________
Date: Apr 14, 2017
Great, thanks -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468388#468388 ________________________________________________________________________________
Date: Apr 14, 2017
Here's how I checked the timing on the LSE Plasma III. The most difficult part was locating TDC on the flywheel for each of the coils. 1) To start the process, you can put Cyl #1 on TDC of the compression stroke. You can locate TDC one of two ways, first there is a hole in the starter and a stamp on (the front of) your flywheel showing TDC 1. You can align the TDC 1 stamp to point directly at the hole on the starter. The second method is look on the backside of the flywheel and you will see the same TDC 1 stamp. The line on that stamp should be aligned with the top of the crankcase split. NOTE: Since the engine will be running, you will check all Plasma III timings from the backside of the flywheel. 2) Now that you know where TDC is for cylinder #1 (really for the coils attached to 1 & 2), you need to segment the flywheel into equal 3rd. This will allow you to locate TDC for the coils serving 3&4 and 5&6. That's the challenging part. I took a long piece of blue painters tape and, starting at the TDC 1 mark we identified earlier, I pulled it around the flywheel laying it on the teeth. Then when it wrapped back up around to TDC 1 again, I marked it and cut it. That gave me the full circumference of the teeth on the fly wheel. I peeled the tape off and stuck it to a table. The I used a ruler and marker to segment it in to 3rds. Then I put the tape back on the flywheel again being careful to start the tape on TDC 1 again and wrapping it around. The marks on the tape were transferred over to the flywheel. I now know where TDC exist for Coils 1&2, Coils 3&4, and Coils 5&6. (If TDC 1 is 0=C2=BA then the next third o ver would be 120=C2=BA and the next third over would be 240=C2=BA before anothe r third passes and we're back to 0=C2=BA). Hopefully that makes sense. 3) Now the next step is to figure out how much advance we should be seeing at the time of ignition. If you look in your LSE manual, there is a recommendation from them depending on the manufacturers suggested timing (stamped on your data plate). I have 9:1 pistons and Aerosport Power recommends a 20=C2=BA advance on the Mags. If I look at the LSE manual, I can see that I should have 35=C2=BA advance +/- 2=C2=BA (with the manifold pre ssure line connected) and 16=C2=BA +/- 2=C2=BA with the manifold pressure line disconn ected. Those are the metrics we are looking for. 4) Now we need to mark 16=C2=BA and 35=C2=BA advance of TDC on the backside of the flywheel. We will have to add them for each of the TDC marks we put on the backside of the flywheel. Using a piece of tape and the existing stampings on the backside of my flywheel for TDC, 20, 23, and 25, I made my own measurement tool to extrapolate where 16=C2=BA and 35=C2=BA would be prior to TDC. Then I meas ured it off for each of the TDC markings on my flywheel. I put a mark at 16 and another at 35. You want these marks to contrast really well since you're going to be looking for them with a timing light. 5) Once all the marks are made, you need to make a pointer to show where the crankcase split is relative to the marks. The pointer needs to be long enough to get right behind the flywheel to reduce error (since you're going to be standing off to the side looking at it). Here's a photo of the pointer I made. I also tipped it with a red marker to make it easier to see. You can bend your pointer to align with the crankcase split. [image: Inline image 1] Now that your marks are made and your pointer is setup, you just have to check it. You'll need a regular old induction timing light. (IE: Not one of the new fancy ones with the computer dial on it, etc. Just a light that will pop when there is a spark detected.) I ran mine in the sunlight and it was very difficult to see and I feel like it was a little more risk than I really wanted to take because I had to get the light right up there close to see it. Shade or late evening would be even better. The test should be performed between 600-900 RPM according to LSE. I chose 800 because the engine seems really happy and smooth idling there. The first thing you want to check is the timing with the manifold pressure line connected. Put your induction coupler over the spark plug lead on #1 or #2 (doesn't matter they're both attached to the same coil) and shoot the light at the pointer. You should see your mark for 35. Then slip it over to the spark plug lead for #3 or #4 and shoot it again. You should see the other 35=C2=BA mark. Then slip it over to the spark plug lead for #5 or #6 and shoot it again. Once again you should see the 35=C2=BA mark. Thats good, everything is right. Now we need to check it with the manifold pressure disconnected. I have my MP going to the manifold with the oil pressure and fuel pressure sensors on it. For me, disconnecting MP is as simple as pulling off a rubber hose at that manifold. But somehow you need to pull the MP from the electronic ignition box. When you do pull it, the engine will change in sound. LSE says it will stumble a bit, but I thought it still ran pretty well; just changed the sound a bit. While your lead is still on 5/6, shoot it and you should see 16=C2=BA. Switch over to 3/4 and shoot it. You should see 16=C2=BA. Switch over to 1/2 and shoot it. You should see 16=C2=BA. If you saw it, then the test is complete. Keep in mind that you have +/- 2=C2=BA variance on those numbers, so it's p retty forgiving. 2=C2=BA is quite a bit when you start measuring it out on the flywheel. I'd also point out that LSE mentions changes for density altitude. What I referenced was sea level and there is a 1=C2=BA change to be added for each thousand feet of DA. So check your DA can adjust accordingly. It's mentioned in their manual on page 36. Here's a link. http://lightspeed-aero.com/Manuals/Plasma_CdiManual_20130317.pdf If your timing is off, the way to change it is to adjust the direct crank sensor be loosening screws and sliding it around. That looks to be a painful process on my engine. I think I'd have to take the prop and flywheel off to do it. Fortunately mine was spot-on. Hope that helps. It really wasn't that big of a deal but the details could be helpful for you or someone else later on down the line. Good luck! Phil ________________________________________________________________________________
Date: Apr 14, 2017
Excellent write up, Phil. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468398#468398 ________________________________________________________________________________
Date: Apr 14, 2017
Hey Phil, Just a question since I=99ve only rebuilt auto engines. You went to a lot of trouble to find TDC for the other cylinders. Unless there is a way to adjust the trigger mechanism for individual coils, why would you need to know anything other than the standard cylinder #1 ? Assuming #1 was correct, how could the others be off, and how would you correct it if they were? Later, =93 Lew From: Phillip Perry Sent: Friday, April 14, 2017 4:49 PM Subject: Re: RV10-List: Re: LSE Plasma III - Timing Here's how I checked the timing on the LSE Plasma III. The most difficult part was locating TDC on the flywheel for each of the coils. 1) To start the process, you can put Cyl #1 on TDC of the compression stroke. You can locate TDC one of two ways, first there is a hole in the starter and a stamp on (the front of) your flywheel showing TDC 1. You can align the TDC 1 stamp to point directly at the hole on the starter. The second method is look on the backside of the flywheel and you will see the same TDC 1 stamp. The line on that stamp should be aligned with the top of the crankcase split. NOTE: Since the engine will be running, you will check all Plasma III timings from the backside of the flywheel. 2) Now that you know where TDC is for cylinder #1 (really for the coils attached to 1 & 2), you need to segment the flywheel into equal 3rd. This will allow you to locate TDC for the coils serving 3&4 and 5&6. That's the challenging part. I took a long piece of blue painters tape and, starting at the TDC 1 mark we identified earlier, I pulled it around the flywheel laying it on the teeth. Then when it wrapped back up around to TDC 1 again, I marked it and cut it. That gave me the full circumference of the teeth on the fly wheel. I peeled the tape off and stuck it to a table. The I used a ruler and marker to segment it in to 3rds. Then I put the tape back on the flywheel again being careful to start the tape on TDC 1 again and wrapping it around. The marks on the tape were transferred over to the flywheel. I now know where TDC exist for Coils 1&2, Coils 3&4, and Coils 5&6. (If TDC 1 is 0=C2=BA then the next third over would be 120=C2=BA and the next third over would be 240=C2=BA before another third passes and we're back to 0=C2=BA). Hopefully that makes sense. 3) Now the next step is to figure out how much advance we should be seeing at the time of ignition. If you look in your LSE manual, there is a recommendation from them depending on the manufacturers suggested timing (stamped on your data plate). I have 9:1 pistons and Aerosport Power recommends a 20=C2=BA advance on the Mags. If I look at the LSE manual, I can see that I should have 35=C2=BA advance +/- 2=C2=BA (with the manifold pressure line connected) and 16=C2=BA +/- 2=C2=BA with the manifold pressure line disconnected. Those are the metrics we are looking for. 4) Now we need to mark 16=C2=BA and 35=C2=BA advance of TDC on the backside of the flywheel. We will have to add them for each of the TDC marks we put on the backside of the flywheel. Using a piece of tape and the existing stampings on the backside of my flywheel for TDC, 20, 23, and 25, I made my own measurement tool to extrapolate where 16=C2=BA and 35=C2=BA would be prior to TDC. Then I measured it off for each of the TDC markings on my flywheel. I put a mark at 16 and another at 35. You want these marks to contrast really well since you're going to be looking for them with a timing light. 5) Once all the marks are made, you need to make a pointer to show where the crankcase split is relative to the marks. The pointer needs to be long enough to get right behind the flywheel to reduce error (since you're going to be standing off to the side looking at it). Here's a photo of the pointer I made. I also tipped it with a red marker to make it easier to see. You can bend your pointer to align with the crankcase split. Now that your marks are made and your pointer is setup, you just have to check it. You'll need a regular old induction timing light. (IE: Not one of the new fancy ones with the computer dial on it, etc. Just a light that will pop when there is a spark detected.) I ran mine in the sunlight and it was very difficult to see and I feel like it was a little more risk than I really wanted to take because I had to get the light right up there close to see it. Shade or late evening would be even better. The test should be performed between 600-900 RPM according to LSE. I chose 800 because the engine seems really happy and smooth idling there. The first thing you want to check is the timing with the manifold pressure line connected. Put your induction coupler over the spark plug lead on #1 or #2 (doesn't matter they're both attached to the same coil) and shoot the light at the pointer. You should see your mark for 35. Then slip it over to the spark plug lead for #3 or #4 and shoot it again. You should see the other 35=C2=BA mark. Then slip it over to the spark plug lead for #5 or #6 and shoot it again. Once again you should see the 35=C2=BA mark. Thats good, everything is right. Now we need to check it with the manifold pressure disconnected. I have my MP going to the manifold with the oil pressure and fuel pressure sensors on it. For me, disconnecting MP is as simple as pulling off a rubber hose at that manifold. But somehow you need to pull the MP from the electronic ignition box. When you do pull it, the engine will change in sound. LSE says it will stumble a bit, but I thought it still ran pretty well; just changed the sound a bit. While your lead is still on 5/6, shoot it and you should see 16=C2=BA. Switch over to 3/4 and shoot it. You should see 16=C2=BA. Switch over to 1/2 and shoot it. You should see 16=C2=BA. If you saw it, then the test is complete. Keep in mind that you have +/- 2=C2=BA variance on those numbers, so it's pretty forgiving. 2=C2=BA is quite a bit when you start measuring it out on the flywheel. I'd also point out that LSE mentions changes for density altitude. What I referenced was sea level and there is a 1=C2=BA change to be added for each thousand feet of DA. So check your DA can adjust accordingly. It's mentioned in their manual on page 36. Here's a link. http://lightspeed-aero.com/Manuals/Plasma_CdiManual_20130317.pdf If your timing is off, the way to change it is to adjust the direct crank sensor be loosening screws and sliding it around. That looks to be a painful process on my engine. I think I'd have to take the prop and flywheel off to do it. Fortunately mine was spot-on. Hope that helps. It really wasn't that big of a deal but the details could be helpful for you or someone else later on down the line. Good luck! Phil ________________________________________________________________________________
Date: Apr 14, 2017
Hi Lew, I asked myself the same thing and simply followed the published LSE procedur e in checking all 3. I can think of a few reasons to check them though. First, the Mag is a mech anical device and if #1 is correct (and you have the correct mag installed) t hen the rest have to be correct. The LSE is software and there is the possibly of a bug or botched processor. Checking all 3 stops that. Another is validating your firing order to make sure you didn't swap out A&B or B&C and so on. This would only work if you could mark is TDC with a 1, 2 , or 3 so you know which timing mark you should be seeing in the flash. The final one I can think of is checking the integrity of the coax cables be tween the box and coils. This gives you insight into what's happening betw een the two devices to know they're correct. Ultimately though, I just did it because LSE said to do it. They didn't ela borate on why but I can only suspect they have a reason for the extra effort . Phil Sent from my iPhone > On Apr 14, 2017, at 7:03 PM, w rote: > > Hey Phil, > > Just a question since I=99ve only rebuilt auto engines. You went to a lot of trouble to find TDC for the other cylinders. Unless there is a wa y to adjust the trigger mechanism for individual coils, why would you need t o know anything other than the standard cylinder #1 ? Assuming #1 was corre ct, how could the others be off, and how would you correct it if they were? > > Later, =93 Lew > > From: Phillip Perry > Sent: Friday, April 14, 2017 4:49 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: LSE Plasma III - Timing > > Here's how I checked the timing on the LSE Plasma III. The most difficul t part was locating TDC on the flywheel for each of the coils. > > 1) To start the process, you can put Cyl #1 on TDC of the compression stro ke. You can locate TDC one of two ways, first there is a hole in the start er and a stamp on (the front of) your flywheel showing TDC 1. You can alig n the TDC 1 stamp to point directly at the hole on the starter. The second method is look on the backside of the flywheel and you will see the same TD C 1 stamp. The line on that stamp should be aligned with the top of the cr ankcase split. > > NOTE: Since the engine will be running, you will check all Plasma III timi ngs from the backside of the flywheel. > > 2) Now that you know where TDC is for cylinder #1 (really for the coils at tached to 1 & 2), you need to segment the flywheel into equal 3rd. This wi ll allow you to locate TDC for the coils serving 3&4 and 5&6. That's the ch allenging part. > > I took a long piece of blue painters tape and, starting at the TDC 1 mark w e identified earlier, I pulled it around the flywheel laying it on the teeth . Then when it wrapped back up around to TDC 1 again, I marked it and cut i t. That gave me the full circumference of the teeth on the fly wheel. I p eeled the tape off and stuck it to a table. The I used a ruler and marker t o segment it in to 3rds. > > Then I put the tape back on the flywheel again being careful to start the tape on TDC 1 again and wrapping it around. The marks on the tape were tr ansferred over to the flywheel. I now know where TDC exist for Coils 1&2, C oils 3&4, and Coils 5&6. (If TDC 1 is 0=C2=BA then the next third over wou ld be 120=C2=BA and the next third over would be 240=C2=BA before another th ird passes and we're back to 0=C2=BA). Hopefully that makes sense. > > 3) Now the next step is to figure out how much advance we should be seeing at the time of ignition. If you look in your LSE manual, there is a recom mendation from them depending on the manufacturers suggested timing (stampe d on your data plate). I have 9:1 pistons and Aerosport Power recommends a 20=C2=BA advance on the Mags. If I look at the LSE manual, I can see that I should have 35=C2=BA advance +/- 2=C2=BA (with the manifold pressure lin e connected) and 16=C2=BA +/- 2=C2=BA with the manifold pressure line discon nected. Those are the metrics we are looking for. > > 4) Now we need to mark 16=C2=BA and 35=C2=BA advance of TDC on the backsid e of the flywheel. We will have to add them for each of the TDC marks we p ut on the backside of the flywheel. > > Using a piece of tape and the existing stampings on the backside of my fly wheel for TDC, 20, 23, and 25, I made my own measurement tool to extrapolate where 16=C2=BA and 35=C2=BA would be prior to TDC. Then I measured it off f or each of the TDC markings on my flywheel. I put a mark at 16 and another at 35. You want these marks to contrast really well since you're going to be looking for them with a timing light. > > 5) Once all the marks are made, you need to make a pointer to show where t he crankcase split is relative to the marks. The pointer needs to be long e nough to get right behind the flywheel to reduce error (since you're going t o be standing off to the side looking at it). Here's a photo of the pointe r I made. I also tipped it with a red marker to make it easier to see. You can bend your pointer to align with the crankcase split. > > > > Now that your marks are made and your pointer is setup, you just have to c heck it. You'll need a regular old induction timing light. (IE: Not one o f the new fancy ones with the computer dial on it, etc. Just a light that w ill pop when there is a spark detected.) I ran mine in the sunlight and it w as very difficult to see and I feel like it was a little more risk than I re ally wanted to take because I had to get the light right up there close to s ee it. Shade or late evening would be even better. > > The test should be performed between 600-900 RPM according to LSE. I chos e 800 because the engine seems really happy and smooth idling there. > > The first thing you want to check is the timing with the manifold pressure line connected. Put your induction coupler over the spark plug lead on #1 or #2 (doesn't matter they're both attached to the same coil) and shoot the light at the pointer. You should see your mark for 35. > > Then slip it over to the spark plug lead for #3 or #4 and shoot it again. You should see the other 35=C2=BA mark. > > Then slip it over to the spark plug lead for #5 or #6 and shoot it again. Once again you should see the 35=C2=BA mark. > > Thats good, everything is right. Now we need to check it with the manifol d pressure disconnected. I have my MP going to the manifold with the oil p ressure and fuel pressure sensors on it. For me, disconnecting MP is as sim ple as pulling off a rubber hose at that manifold. But somehow you need to p ull the MP from the electronic ignition box. > > When you do pull it, the engine will change in sound. LSE says it will st umble a bit, but I thought it still ran pretty well; just changed the sound a bit. > > While your lead is still on 5/6, shoot it and you should see 16=C2=BA. > Switch over to 3/4 and shoot it. You should see 16=C2=BA. > Switch over to 1/2 and shoot it. You should see 16=C2=BA. > > If you saw it, then the test is complete. > > Keep in mind that you have +/- 2=C2=BA variance on those numbers, so it's p retty forgiving. 2=C2=BA is quite a bit when you start measuring it out on t he flywheel. I'd also point out that LSE mentions changes for density altit ude. What I referenced was sea level and there is a 1=C2=BA change to be ad ded for each thousand feet of DA. So check your DA can adjust accordingly. It's mentioned in their manual on page 36. Here's a link. > > http://lightspeed-aero.com/Manuals/Plasma_CdiManual_20130317.pdf > > If your timing is off, the way to change it is to adjust the direct crank s ensor be loosening screws and sliding it around. That looks to be a painful process on my engine. I think I'd have to take the prop and flywheel off t o do it. Fortunately mine was spot-on. > > Hope that helps. It really wasn't that big of a deal but the details coul d be helpful for you or someone else later on down the line. > > Good luck! > Phil > > > > ________________________________________________________________________________
Date: Apr 15, 2017
Just a minor note - I don't believe the LSE ignition boxes are microprocessor/software driven. I believe I heard this from Klaus at OSH but it's been a long time so I could be mistaken. Bob On Fri, Apr 14, 2017 at 7:30 PM Phillip Perry wrote: > Hi Lew, > > I asked myself the same thing and simply followed the published LSE > procedure in checking all 3. > > I can think of a few reasons to check them though. First, the Mag is a > mechanical device and if #1 is correct (and you have the correct mag > installed) then the rest have to be correct. > > The LSE is software and there is the possibly of a bug or botched > processor. Checking all 3 stops that. > > Another is validating your firing order to make sure you didn't swap out > A&B or B&C and so on. This would only work if you could mark is TDC with a > 1, 2, or 3 so you know which timing mark you should be seeing in the flas h. > > The final one I can think of is checking the integrity of the coax cables > between the box and coils. This gives you insight into what's happening > between the two devices to know they're correct. > > Ultimately though, I just did it because LSE said to do it. They didn't > elaborate on why but I can only suspect they have a reason for the extra > effort. > > Phil > > > Sent from my iPhone > > On Apr 14, 2017, at 7:03 PM, > wrote: > > Hey Phil, > > Just a question since I=99ve only rebuilt auto engines. You went t o a lot > of trouble to find TDC for the other cylinders. Unless there is a way to > adjust the trigger mechanism for individual coils, why would you need to > know anything other than the standard cylinder #1 ? Assuming #1 was > correct, how could the others be off, and how would you correct it if the y > were? > > Later, =93 Lew > > *From:* Phillip Perry > *Sent:* Friday, April 14, 2017 4:49 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Re: LSE Plasma III - Timing > > > Here's how I checked the timing on the LSE Plasma III. The most > difficult part was locating TDC on the flywheel for each of the coils. > > 1) To start the process, you can put Cyl #1 on TDC of the compression > stroke. You can locate TDC one of two ways, first there is a hole in th e > starter and a stamp on (the front of) your flywheel showing TDC 1. You > can align the TDC 1 stamp to point directly at the hole on the starter. > The second method is look on the backside of the flywheel and you will se e > the same TDC 1 stamp. The line on that stamp should be aligned with the > top of the crankcase split. > > NOTE: Since the engine will be running, you will check all Plasma III > timings from the backside of the flywheel. > > 2) Now that you know where TDC is for cylinder #1 (really for the coils > attached to 1 & 2), you need to segment the flywheel into equal 3rd. Th is > will allow you to locate TDC for the coils serving 3&4 and 5&6. That's t he > challenging part. > > I took a long piece of blue painters tape and, starting at the TDC 1 mark > we identified earlier, I pulled it around the flywheel laying it on the > teeth. Then when it wrapped back up around to TDC 1 again, I marked it a nd > cut it. That gave me the full circumference of the teeth on the fly > wheel. I peeled the tape off and stuck it to a table. The I used a > ruler and marker to segment it in to 3rds. > > Then I put the tape back on the flywheel again being careful to start the > tape on TDC 1 again and wrapping it around. The marks on the tape were > transferred over to the flywheel. I now know where TDC exist for Coils > 1&2, Coils 3&4, and Coils 5&6. (If TDC 1 is 0=C2=BA then the next third over > would be 120=C2=BA and the next third over would be 240=C2=BA before anot her third > passes and we're back to 0=C2=BA). Hopefully that makes sense. > > 3) Now the next step is to figure out how much advance we should be seein g > at the time of ignition. If you look in your LSE manual, there is a > recommendation from them depending on the manufacturers suggested timing > (stamped on your data plate). I have 9:1 pistons and Aerosport Power > recommends a 20=C2=BA advance on the Mags. If I look at the LSE manual, I can > see that I should have 35=C2=BA advance +/- 2=C2=BA (with the manifold p ressure line > connected) and 16=C2=BA +/- 2=C2=BA with the manifold pressure line disco nnected. > Those are the metrics we are looking for. > > 4) Now we need to mark 16=C2=BA and 35=C2=BA advance of TDC on the backsi de of the > flywheel. We will have to add them for each of the TDC marks we put on > the backside of the flywheel. > > Using a piece of tape and the existing stampings on the backside of my > flywheel for TDC, 20, 23, and 25, I made my own measurement tool to > extrapolate where 16=C2=BA and 35=C2=BA would be prior to TDC. Then I me asured it > off for each of the TDC markings on my flywheel. I put a mark at 16 and > another at 35. You want these marks to contrast really well since you'r e > going to be looking for them with a timing light. > > 5) Once all the marks are made, you need to make a pointer to show where > the crankcase split is relative to the marks. The pointer needs to be lo ng > enough to get right behind the flywheel to reduce error (since you're goi ng > to be standing off to the side looking at it). Here's a photo of the > pointer I made. I also tipped it with a red marker to make it easier to > see. You can bend your pointer to align with the crankcase split. > > > > > > Now that your marks are made and your pointer is setup, you just have to > check it. You'll need a regular old induction timing light. (IE: Not o ne > of the new fancy ones with the computer dial on it, etc. Just a light th at > will pop when there is a spark detected.) I ran mine in the sunlight and > it was very difficult to see and I feel like it was a little more risk th an > I really wanted to take because I had to get the light right up there clo se > to see it. Shade or late evening would be even better. > > The test should be performed between 600-900 RPM according to LSE. I > chose 800 because the engine seems really happy and smooth idling there. > > The first thing you want to check is the timing with the manifold pressur e > line connected. Put your induction coupler over the spark plug lead on #1 > or #2 (doesn't matter they're both attached to the same coil) and shoot t he > light at the pointer. You should see your mark for 35. > > Then slip it over to the spark plug lead for #3 or #4 and shoot it again. > You should see the other 35=C2=BA mark. > > Then slip it over to the spark plug lead for #5 or #6 and shoot it > again. Once again you should see the 35=C2=BA mark. > > Thats good, everything is right. Now we need to check it with the > manifold pressure disconnected. I have my MP going to the manifold with > the oil pressure and fuel pressure sensors on it. For me, disconnecting MP > is as simple as pulling off a rubber hose at that manifold. But somehow > you need to pull the MP from the electronic ignition box. > > When you do pull it, the engine will change in sound. LSE says it will > stumble a bit, but I thought it still ran pretty well; just changed the > sound a bit. > > While your lead is still on 5/6, shoot it and you should see 16=C2=BA. > Switch over to 3/4 and shoot it. You should see 16=C2=BA. > Switch over to 1/2 and shoot it. You should see 16=C2=BA. > > If you saw it, then the test is complete. > > Keep in mind that you have +/- 2=C2=BA variance on those numbers, so it's > pretty forgiving. 2=C2=BA is quite a bit when you start measuring it out on the > flywheel. I'd also point out that LSE mentions changes for density > altitude. What I referenced was sea level and there is a 1=C2=BA change to be > added for each thousand feet of DA. So check your DA can adjust > accordingly. It's mentioned in their manual on page 36. Here's a link. > > http://lightspeed-aero.com/Manuals/Plasma_CdiManual_20130317.pdf > > If your timing is off, the way to change it is to adjust the direct crank > sensor be loosening screws and sliding it around. That looks to be a > painful process on my engine. I think I'd have to take the prop and > flywheel off to do it. Fortunately mine was spot-on. > > Hope that helps. It really wasn't that big of a deal but the details > could be helpful for you or someone else later on down the line. > > Good luck! > Phil > > ________________________________________________________________________________
Date: Apr 14, 2017
LSE has no microprocessor and no software. That's one of the reasons I picked it over the other available EIs. Regardless, it's good to check everything out before you get that 50k engine going. Lenny philperry9 wrote: > > The LSE is software and there is the possibly of a bug or botched processor. > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468405#468405 ________________________________________________________________________________
From: "Greg McFarlane" <grbcmcfarlane(at)gmail.com>
Date: Apr 15, 2017
Not directly related to the Mooney/RV10 shock discs compression question, but related to SB 14-08-29....... Has anyone considered replacing at least one of the washers under the top hat collar assembly retainer with a more forgiving material ? The compression/suspension of loads from the front wheel are taken care of by the compressing of the rubber shock discs (elastomers) but when that compression is unloaded the whole movement back down is metal to metal hammering between the isolator washers and the engine mount dyna cup. I haven't tried it, but maybe a washer made from some sort of tyre rubber would stand the load and soften the hammer blows. Any ideas/comments from the brains trust? Cheers from Western Australia Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468409#468409 ________________________________________________________________________________
Date: Apr 15, 2017
Subject: F-10108A Support Bracket Fracture
As I thought I was closing up from my condition inspection, I discovered that the rear cowl support, F-10108A (page 47-11&12) had fractured at the bend where it attaches to the firewall. I'm thinking about using some angle aluminum to replace that bend, at least for now. I'm guessing that the bend when the part was made weakened the aluminum, and the vibration/fiberglass flexing and stress from removal and reinstall of cowling made the failure inevitable. Perhaps the fact that I used quick release fasteners instead of piano hinges may focus more stress on the part. Just wondering if anyone else has had a failure there Kelly -sent from the I-droid implanted in my forearm ________________________________________________________________________________
Date: Apr 15, 2017
Subject: Re: F-10108A Support Bracket Fracture
This is very common and your proposed fix is exactly what I do. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 Sent from my iPhone > On Apr 15, 2017, at 9:15 AM, Kelly McMullen wrote: > > As I thought I was closing up from my condition inspection, I discovered that the rear cowl support, F-10108A (page 47-11&12) had fractured at the bend where it attaches to the firewall. I'm thinking about using some angle aluminum to replace that bend, at least for now. I'm guessing that the bend when the part was made weakened the aluminum, and the vibration/fiberglass flexing and stress from removal and reinstall of cowling made the failure inevitable. Perhaps the fact that I used quick release fasteners instead of piano hinges may focus more stress on the part. Just wondering if anyone else has had a failure there > Kelly > -sent from the I-droid implanted in my forearm ________________________________________________________________________________
Date: Apr 15, 2017
I used screws and plates and mine has never fractured that part. Frankly I surprised of that. Just a data point. Tim > On Apr 15, 2017, at 8:15 AM, Kelly McMullen wrote: > > As I thought I was closing up from my condition inspection, I discovered that the rear cowl support, F-10108A (page 47-11&12) had fractured at the bend where it attaches to the firewall. I'm thinking about using some angle aluminum to replace that bend, at least for now. I'm guessing that the bend when the part was made weakened the aluminum, and the vibration/fiberglass flexing and stress from removal and reinstall of cowling made the failure inevitable. Perhaps the fact that I used quick release fasteners instead of piano hinges may focus more stress on the part. Just wondering if anyone else has had a failure there > Kelly > -sent from the I-droid implanted in my forearm ________________________________________________________________________________
Date: Apr 15, 2017
I don't know that the impact is all that hard. I agree in concept though. If there was a huge gap maybe but as long as you have the gap mostly taken up when compressed the drop isn't that far so the shock can't be that bad. To me the part of the design that concerns me is that the metal strut tube that goes thru the elastomers rubs on the metal plate in the engine mount, at least on mine, and could eventually wear thru that strut tube. Maybe just enlarging that hole would work....but that could also result in the stack of elastomers being able to move more. I don't know. Tim > On Apr 15, 2017, at 5:47 AM, Greg McFarlane wrote: > > > Not directly related to the Mooney/RV10 shock discs compression question, but related to SB 14-08-29....... Has anyone considered replacing at least one of the washers under the top hat collar assembly retainer with a more forgiving material ? The compression/suspension of loads from the front wheel are taken care of by the compressing of the rubber shock discs (elastomers) but when that compression is unloaded the whole movement back down is metal to metal hammering between the isolator washers and the engine mount dyna cup. I haven't tried it, but maybe a washer made from some sort of tyre rubber would stand the load and soften the hammer blows. Any ideas/comments from the brains trust? Cheers from Western Australia > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=468409#468409 > > > > > > > > > ________________________________________________________________________________
Date: Apr 15, 2017
I've noticed that mine will fold up under the cowling if I'm not careful when sliding the lower cowl on. Then it takes some effort to get into out of a bind and into the right position. It's certainly a bracket prone to eventually failing on my plane at least. If I'm careful it will be fine, but it's hard to be careful when you're wrestling that lower cowling around 3 blades and a nose gear. Practice makes closer to perfect anyway. Phil Sent from my iPhone > On Apr 15, 2017, at 8:36 AM, Jesse Saint wrote: > > > This is very common and your proposed fix is exactly what I do. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > Sent from my iPhone > >> On Apr 15, 2017, at 9:15 AM, Kelly McMullen wrote: >> >> As I thought I was closing up from my condition inspection, I discovered that the rear cowl support, F-10108A (page 47-11&12) had fractured at the bend where it attaches to the firewall. I'm thinking about using some angle aluminum to replace that bend, at least for now. I'm guessing that the bend when the part was made weakened the aluminum, and the vibration/fiberglass flexing and stress from removal and reinstall of cowling made the failure inevitable. Perhaps the fact that I used quick release fasteners instead of piano hinges may focus more stress on the part. Just wondering if anyone else has had a failure there >> Kelly >> -sent from the I-droid implanted in my forearm > > > > > ________________________________________________________________________________
Date: Apr 15, 2017
Never even installed it on my 10. =C2-Looked like the weak link to me. =C2-So I made my own. =C2-A little wider at the small bend end, and sli ghtly heavier gauge.Don McDonald From: Phillip Perry <philperry9(at)gmail.com> To: rv10-list(at)matronics.com Sent: Saturday, April 15, 2017 9:29 AM Subject: Re: RV10-List: F-10108A Support Bracket Fracture I've noticed that mine will fold up under the cowling if I'm not careful wh en sliding the lower cowl on.=C2- Then it takes some effort to get into o ut of a bind and into the right position.=C2- It's certainly a bracket prone to eventually failing on my plane at least. =C2- If I'm careful it will be fine, but it's hard to be careful when you 're wrestling that lower cowling around 3 blades and a nose gear.=C2- Pra ctice makes closer to perfect anyway. Phil Sent from my iPhone > On Apr 15, 2017, at 8:36 AM, Jesse Saint wrote: > > > This is very common and your proposed fix is exactly what I do. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > Sent from my iPhone > >> On Apr 15, 2017, at 9:15 AM, Kelly McMullen wrote: >> >> As I thought I was closing up from my condition inspection, I discovered that the rear cowl support, F-10108A (page 47-11&12) had fractured at the bend where it attaches to the firewall.=C2- I'm thinking about using some angle aluminum to replace that bend, at least for now.=C2- I'm guessing that the bend when the part was made weakened the aluminum, and the vibrati on/fiberglass flexing and stress from removal and reinstall of cowling made the failure inevitable. Perhaps the fact that I used quick release fastene rs instead of piano hinges may focus more stress on the part.=C2- Just wo ndering if anyone else has had a failure there >> Kelly >> -sent from the I-droid implanted in my forearm > > > > > S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Apr 15, 2017
+1. And slightly modified for the James Cowl. Carl > On Apr 15, 2017, at 10:45 AM, Don McDonald wr ote: > > Never even installed it on my 10. Looked like the weak link to me. So I m ade my own. A little wider at the small bend end, and slightly heavier gaug e. > Don McDonald > > > From: Phillip Perry <philperry9(at)gmail.com> > To: rv10-list(at)matronics.com > Sent: Saturday, April 15, 2017 9:29 AM > Subject: Re: RV10-List: F-10108A Support Bracket Fracture > > > I've noticed that mine will fold up under the cowling if I'm not careful w hen sliding the lower cowl on. Then it takes some effort to get into out of a bind and into the right position. > > It's certainly a bracket prone to eventually failing on my plane at least. If I'm careful it will be fine, but it's hard to be careful when you're wr estling that lower cowling around 3 blades and a nose gear. Practice makes c loser to perfect anyway. > > Phil > > > Sent from my iPhone > > > On Apr 15, 2017, at 8:36 AM, Jesse Saint wrote : > > > > > > This is very common and your proposed fix is exactly what I do. > > > > Jesse Saint > > Saint Aviation, Inc. > > jesse(at)saintaviation.com > > C: 352-427-0285 > > F: 815-377-3694 > > > > Sent from my iPhone > > > >> On Apr 15, 2017, at 9:15 AM, Kelly McMullen wrote: > >> > >> As I thought I was closing up from my condition inspection, I discovere d that the rear cowl support, F-10108A (page 47-11&12) had fractured at the b end where it attaches to the firewall. I'm thinking about using some angle a luminum to replace that bend, at least for now. I'm guessing that the bend w hen the part was made weakened the aluminum, and the vibration/fiberglass fl exing and stress from removal and reinstall of cowling made the failure inev itable. Perhaps the fact that I used quick release fasteners instead of pian o hinges may focus more stress on the part. Just wondering if anyone else h as had a failure there > >> Kelly > >> -sent from the I-droid implanted in my forearm > > > > > > > > > > > > " target="_blank">http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > <= Add some info to the Matronics Email List Wiki! > -Matt Dralle, List Admin. > http://www.matronics.com/contribution > > > > > ________________________________________________________________________________
Date: Apr 15, 2017
I had to make a new one, because my James cowl has a slightly taller exit area. Used a bit thicker aluminum and angles on both top and bottom. Much sturdier and so far no signs of issues in 280 hours. Here's a picture. I also have camlocks on the bottom of the cowl, the floating ones too. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468426#468426 Attachments: http://forums.matronics.com//files/img_2028_165.jpg ________________________________________________________________________________
Date: Apr 15, 2017
I copied Tim's solution during the build. No problems at 900hrs other than a smoking rivet. On 4/15/2017 9:43 AM, Tim Olson wrote: > > I used screws and plates and mine has never fractured that part. Frankly I surprised of that. Just a data point. > Tim > >> On Apr 15, 2017, at 8:15 AM, Kelly McMullen wrote: >> >> As I thought I was closing up from my condition inspection, I discovered that the rear cowl support, F-10108A (page 47-11&12) had fractured at the bend where it attaches to the firewall. I'm thinking about using some angle aluminum to replace that bend, at least for now. I'm guessing that the bend when the part was made weakened the aluminum, and the vibration/fiberglass flexing and stress from removal and reinstall of cowling made the failure inevitable. Perhaps the fact that I used quick release fasteners instead of piano hinges may focus more stress on the part. Just wondering if anyone else has had a failure there >> Kelly >> -sent from the I-droid implanted in my forearm > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 15, 2017
Subject: Matronics Internet Connectivity Upgrades April 17-18 2017
Dear Matronics Email List an/or Forum User, The Matronics Internet connectivity will be upgraded on April 17 through April 18, 2017. During the upgrade connections to the Matronics and AeroElectric web servers may be unavailable. Additionally, Matronics Email List email will not be redistributed. Internet Connectivity bandwidth will be significantly increased by a factor of 7X for downloads and 50X for uploads, which represents a significant increase in performance. Reliability should also increase in terms. I will send out a follow up message when the upgrade has been completed. Best Regards, Matt Dralle Matronics Email List and Forum Admin. Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Apr 16, 2017
> > I had to make a new one, because my James cowl has a slightly taller exit area. Used a bit thicker aluminum and angles on both top and bottom. Much sturdier and so far no signs of issues in 280 hours. Here's a picture. > I also have camlocks on the bottom of the cowl, the floating ones too. What are the two lines adelled to the bracket? -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468519#468519 ________________________________________________________________________________
Date: Apr 16, 2017
Fuel pump overflow and FAB drain line. rvdave wrote: > > What are the two lines adelled to the bracket? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468521#468521 ________________________________________________________________________________
Date: Apr 17, 2017
Subject: hail damage
I parked my aircraft in TX from March 30-April 5 in TX. Very windy arrival and departure. The FBO was asked and agreed to hangar the aircraft if a storm appear eminent. I even called on April 1 to repeat the request since the My Radar app showed a large area of precipitation (yellow/red). Apparently their internal lack of communication failed to get the aircraft inside and hail damage resulted. Because of the very inclement departure I did not notice the damage and it was not discovered until April 16. Primary damage is to top of control surfaces due to thinner metal. I plan to reskin them; other areas of thicker metal had minor paint marks; even the cowl top had small faint marks in the paint. The aircraft is insured and someone else will probably do the work. Any comments or suggestions? either dealing with the insurance co or techniques to smooth the metal? ________________________________________________________________________________
Date: Apr 18, 2017
Subject: Re: hail damage
Sorry to hear about the damage. That scares me the most about traveling with the plane here in TX. Which city were you in? We just replaced a damaged wing control surface on a friends -10. I'll point out that QB control surfaces are already built and you can order them from Vans individually. Phil Sent from my iPhone > On Apr 18, 2017, at 12:15 AM, dlm wrote: > > I parked my aircraft in TX from March 30-April 5 in TX. Very windy arrival and departure. The FBO was asked and agreed to hangar the aircraft if a storm appear eminent. I even called on April 1 to repeat the request since the My Radar app showed a large area of precipitation (yellow/red). Apparently their internal lack of communication failed to get the aircraft inside and hail damage resulted. Because of the very inclement departure I did not notice the damage and it was not discovered until April 16. Primary damage is to top of control surfaces due to thinner metal. I plan to reskin them; other areas of thicker metal had minor paint marks; even the cowl top had small faint marks in the paint. The aircraft is insured and someone else will probably do the work. Any comments or suggestions? either dealing with the insurance co or techniques to smooth the metal? ________________________________________________________________________________
Date: Apr 18, 2017
Unless they have changed, Vans QB facility uses some sort of squeezer to do the double flush rivets on the trailing edge. It unfortunately dimples the skin on the underside, quite significantly. I exchanged my original set for some that weren't quite as bad. Any conscientious builder can produce better double flush riveted trailing edges. While there is the aesthetic issue of dimples in the skin, I have never seen them affect the flying qualities, besides reducing drag (VBG). Not sure whether golf balls or hail make better dimples...............Almost all the courtesy airport cars in Texas have hail dents. -sent from the I-droid implanted in my forearm On Tue, Apr 18, 2017 at 5:41 AM, Phillip Perry wrote: > > Sorry to hear about the damage. That scares me the most about traveling > with the plane here in TX. Which city were you in? > > We just replaced a damaged wing control surface on a friends -10. I'll > point out that QB control surfaces are already built and you can order them > from Vans individually. > > Phil > > > Sent from my iPhone > > > On Apr 18, 2017, at 12:15 AM, dlm wrote: > > > > I parked my aircraft in TX from March 30-April 5 in TX. Very windy > arrival and departure. The FBO was asked and agreed to hangar the aircraft > if a storm appear eminent. I even called on April 1 to repeat the request > since the My Radar app showed a large area of precipitation (yellow/red). > Apparently their internal lack of communication failed to get the aircraft > inside and hail damage resulted. Because of the very inclement departure I > did not notice the damage and it was not discovered until April 16. Primary > damage is to top of control surfaces due to thinner metal. I plan to reskin > them; other areas of thicker metal had minor paint marks; even the cowl top > had small faint marks in the paint. The aircraft is insured and someone > else will probably do the work. Any comments or suggestions? either dealing > with the insurance co or techniques to smooth the metal? > > ________________________________________________________________________________
Date: Apr 18, 2017
Another option is to call Wally over at Synergy Air. They do quick builds for Van's and do impeccable work. http://synergyair.com/ Shannon On Tue, Apr 18, 2017 at 8:11 AM, Kelly McMullen wrote: > Unless they have changed, Vans QB facility uses some sort of squeezer to > do the double flush rivets on the trailing edge. It unfortunately dimples > the skin on the underside, quite significantly. I exchanged my original set > for some that weren't quite as bad. Any conscientious builder can produce > better double flush riveted trailing edges. > While there is the aesthetic issue of dimples in the skin, I have never > seen them affect the flying qualities, besides reducing drag (VBG). Not > sure whether golf balls or hail make better dimples...............Almost > all the courtesy airport cars in Texas have hail dents. > > -sent from the I-droid implanted in my forearm > > On Tue, Apr 18, 2017 at 5:41 AM, Phillip Perry > wrote: > >> >> Sorry to hear about the damage. That scares me the most about traveling >> with the plane here in TX. Which city were you in? >> >> We just replaced a damaged wing control surface on a friends -10. I'll >> point out that QB control surfaces are already built and you can order them >> from Vans individually. >> >> Phil >> >> >> >> Sent from my iPhone >> >> > On Apr 18, 2017, at 12:15 AM, dlm wrote: >> > >> > I parked my aircraft in TX from March 30-April 5 in TX. Very windy >> arrival and departure. The FBO was asked and agreed to hangar the aircraft >> if a storm appear eminent. I even called on April 1 to repeat the request >> since the My Radar app showed a large area of precipitation (yellow/red). >> Apparently their internal lack of communication failed to get the aircraft >> inside and hail damage resulted. Because of the very inclement departure I >> did not notice the damage and it was not discovered until April 16. Primary >> damage is to top of control surfaces due to thinner metal. I plan to reskin >> them; other areas of thicker metal had minor paint marks; even the cowl top >> had small faint marks in the paint. The aircraft is insured and someone >> else will probably do the work. Any comments or suggestions? either dealing >> with the insurance co or techniques to smooth the metal? >> >> ===================================== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/ >> Navigator?RV10-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> > ________________________________________________________________________________
Date: Apr 19, 2017
In Germany we use a practice called "Dent-Repair". The "Dent-Doctor" glue little pulling tools on the dents, and pull the sheet metal with a pulling impact hammer. Or if there is a access hole somewhere, then they entering a long pushing tool to push the dents out. If done properly you cannot see anything from the dents after finished. Sorry for my bad English.... Peter Aringer RV-10 build startet 2017-01, finished the VS, started with the HS Mit freundlichen Gren With Kind Regards Peter Aringer > Am 18.04.2017 um 20:23 schrieb Kelly McMullen : > > conscientious ________________________________________________________________________________
Date: Apr 19, 2017
Subject: Inlet baffling very baffling
Hi list, Does anyone have pictures or other good pointers on how baffling should work around the sides of the inlet ramps? I understand how the lower portion of the inlet ramp baffling is supposed to work, but the ramp upper/side portions have me stumped---in particular the outboard ramp edges. It almost seems like the plans say "put some baffle material on the edge of the ramp and then just stuff it up into the front of the cowl". If possible, I'd like to make it work better than that. Your insight would be greatly appreciated. David ________________________________________________________________________________
Subject: Re: Inlet baffling very baffling
Date: Apr 19, 2017
I also wrestled with this. Fortunately my cowl lined up pretty close to the inlet ramps so I didn't attach any baffling material to the cowl. For the sides I pretty much followed the plans with the baffling stuffed behind the cowl. I'm getting cruise temps around 325 to 345 depending on conditions. I did get very CHTs on the first few flights, however these have settled down without any modification. Regards Martin Aerosport IO540. Plasma iii and 1 magneto.[/quote] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468617#468617 ________________________________________________________________________________
Date: Apr 19, 2017
SSB1c2VkIDQiIHNjYXQgZHVjdGluZy4NCkF0dGFjaCBpdCB3aXRoIHBvcCByaXZldHMgdG8gdGhl IGFpciBjbGVhbmVyLg0KSSBDb21wcmVzcyBpdCB3aXRoIHNvbWUgdGllIHdpcmUgYWdhaW5zdCB0 aGUgYWlyIGNsZWFuZXIgd2hlbiB0aGUgbG93ZXIgY293bGluZyBpcyBvZmYuDQpKdXN0IG5lZWQg b25lIHdpcmUgdG8gaG9sZCBpdCBiYWNrIHdoaWxlIGluc3RhbGxpbmcgdGhlIGxvd2VyIGNvd2xp bmcuDQpJbnN0YWxsIGxvd2VyIGNvd2xpbmcsIGN1dCB0aGUgdGllIHdpcmUsIHJlbGVhc2UgdGhl IHNjYXQgaG9zZS4NCkl0IGNvbXByZXNzZXMgZ3JlYXQgYWdhaW5zdCB0aGUgbG93ZXIgY293bGlu ZyBmbGFuZ2UuDQpBaXIgdGlnaHQgYW5kIGVhc3kuDQoNCjQwMiBob3VycyBSViAxMCBubyBwcm9i bGVtcy4NCg0KDQpUaGFua3MsDQpKaW0gVmlsbGFuaQ0KQnJva2VyLCBTYWxlc21hbg0KR3JlYXQg UmVhbCBFc3RhdGUNCk1hbW1vdGggQ3JlZWsgRXhjYXZhdGlvbg0KNzAyLjM3OS41NTI0DQpKaW1A U29sZDcwMi5jb20NCg0KDQotLS0tLS0tLSBPcmlnaW5hbCBtZXNzYWdlIC0tLS0tLS0tDQpGcm9t OiBtZGFuaWVsbCA8bWFydGluLmRhbmllbGxAYmlncG9uZC5jb20+DQpEYXRlOiAyMDE3LzA0LzE5 IDI6NDAgUE0gKEdNVC0wODowMCkNClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVj dDogUlYxMC1MaXN0OiBSZTogSW5sZXQgYmFmZmxpbmcgdmVyeSBiYWZmbGluZw0KDQotLT4gUlYx MC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAibWRhbmllbGwiIDxtYXJ0aW4uZGFuaWVsbEBiaWdw b25kLmNvbT4NCg0KSSBhbHNvIHdyZXN0bGVkIHdpdGggdGhpcy4gRm9ydHVuYXRlbHkgbXkgY293 bCBsaW5lZCB1cCBwcmV0dHkgY2xvc2UgdG8gdGhlIGlubGV0IHJhbXBzIHNvIEkgZGlkbid0IGF0 dGFjaCBhbnkgYmFmZmxpbmcgbWF0ZXJpYWwgdG8gdGhlIGNvd2wuIEZvciB0aGUgc2lkZXMgSSBw cmV0dHkgbXVjaCBmb2xsb3dlZCB0aGUgcGxhbnMgd2l0aCB0aGUgYmFmZmxpbmcgc3R1ZmZlZCBi ZWhpbmQgdGhlIGNvd2wuIEknbSBnZXR0aW5nIGNydWlzZSB0ZW1wcyBhcm91bmQgMzI1IHRvIDM0 NSBkZXBlbmRpbmcgb24gY29uZGl0aW9ucy4gSSBkaWQgZ2V0IHZlcnkgQ0hUcyBvbiB0aGUgZmly c3QgZmV3IGZsaWdodHMsIGhvd2V2ZXIgdGhlc2UgaGF2ZSBzZXR0bGVkIGRvd24gd2l0aG91dCBh bnkgbW9kaWZpY2F0aW9uLg0KDQpSZWdhcmRzDQpNYXJ0aW4NCg0KQWVyb3Nwb3J0IElPNTQwLiBQ bGFzbWEgaWlpIGFuZCAxIG1hZ25ldG8uWy9xdW90ZV0NCg0KDQoNCg0KUmVhZCB0aGlzIHRvcGlj IG9ubGluZSBoZXJlOg0KDQpodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBo cD9wPTQ2ODYxNyM0Njg2MTcNCg0KDQoNCg0KDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgLSBUaGUg UlYxMC1MaXN0IEVtYWlsIEZvcnVtIC0NCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1 cmVzIE5hdmlnYXRvciB0byBicm93c2UNCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNo IGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQs IDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2gg bW9yZToNCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/ UlYxMC1MaXN0DQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIg Rk9SVU1TIC0NCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBX ZWIgRm9ydW1zIQ0KXy09DQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQpf LT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09DQpfLT0gICAgICAgICAgICAgIC0gTkVXIE1BVFJPTklDUyBMSVNUIFdJS0kgLQ0K Xy09IEFkZCBzb21lIGluZm8gdG8gdGhlIE1hdHJvbmljcyBFbWFpbCBMaXN0IFdpa2khDQpfLT0g ICAtLT4gaHR0cDovL3dpa2kubWF0cm9uaWNzLmNvbQ0KXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAt IExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdl bmVyb3VzIHN1cHBvcnQhDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBE cmFsbGUsIExpc3QgQWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2Nv bnRyaWJ1dGlvbg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0NCg0KDQoNCg= ________________________________________________________________________________
Date: Apr 19, 2017
Unfortunately the name of the town and airport is DENTon(KDTO). https://www.youtube.com/watch?v=SmV8-tHFciw Note the windsock at the left of the screen at 30 seconds into the video. dlm --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 22, 2017
Subject: Ignition wires seal
Guys I cannot find the 2 seals which are to be installed into the Baffles (cylinders' #5 and #6 baffles) where the ignition wires pass trough these baffles. The plans indicate that those 2 seals are supplied with the engine. This engine was bought more than 5 years ago... Where can I obtain these seals? Thanks Carlos Enviado do meu iPhone ________________________________________________________________________________
Date: Apr 22, 2017
I purchased a pair from ?????I can not remember????. It was one of the normal suppliers. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Saturday, April 22, 2017 7:11 AM Subject: RV10-List: Ignition wires seal Guys I cannot find the 2 seals which are to be installed into the Baffles (cylinders' #5 and #6 baffles) where the ignition wires pass trough these baffles. The plans indicate that those 2 seals are supplied with the engine. This engine was bought more than 5 years ago... Where can I obtain these seals? Thanks Carlos Enviado do meu iPhone ________________________________________________________________________________
Subject: Re: Ignition wires seal
Date: Apr 22, 2017
http://www.aircraftspruce.com/catalog/eppages/enginebafflem376.php On 4/22/2017 7:01 AM, Rene Felker wrote: > > I purchased a pair from ?????I can not remember????. It was one of the > normal suppliers. > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo > Sent: Saturday, April 22, 2017 7:11 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Ignition wires seal > > > Guys > > I cannot find the 2 seals which are to be installed into the Baffles > (cylinders' #5 and #6 baffles) where the ignition wires pass trough these > baffles. > The plans indicate that those 2 seals are supplied with the engine. > > This engine was bought more than 5 years ago... > > Where can I obtain these seals? > > Thanks > Carlos > > Enviado do meu iPhone > > > > > > > ________________________________________________________________________________
Date: Apr 22, 2017
Aircraft Spruce has them. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 Sent from my iPhone > On Apr 22, 2017, at 10:01 AM, Rene Felker wrote: > > > I purchased a pair from ?????I can not remember????. It was one of the > normal suppliers. > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo > Sent: Saturday, April 22, 2017 7:11 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Ignition wires seal > > > Guys > > I cannot find the 2 seals which are to be installed into the Baffles > (cylinders' #5 and #6 baffles) where the ignition wires pass trough these > baffles. > The plans indicate that those 2 seals are supplied with the engine. > > This engine was bought more than 5 years ago... > > Where can I obtain these seals? > > Thanks > Carlos > > Enviado do meu iPhone > > > > > > > ________________________________________________________________________________
Date: Apr 22, 2017
Thank you guys I did look into the AcS catalog but didn't find them. They're on their way now Thanks Carlos Enviado do meu iPhone No dia 22/04/2017, s 15:17, Jesse Saint escreveu: > > Aircraft Spruce has them. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > Sent from my iPhone > >> On Apr 22, 2017, at 10:01 AM, Rene Felker wrote: >> >> >> I purchased a pair from ?????I can not remember????. It was one of the >> normal suppliers. >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo >> Sent: Saturday, April 22, 2017 7:11 AM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Ignition wires seal >> >> >> Guys >> >> I cannot find the 2 seals which are to be installed into the Baffles >> (cylinders' #5 and #6 baffles) where the ignition wires pass trough these >> baffles. >> The plans indicate that those 2 seals are supplied with the engine. >> >> This engine was bought more than 5 years ago... >> >> Where can I obtain these seals? >> >> Thanks >> Carlos >> >> Enviado do meu iPhone >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Apr 22, 2017
They should be with the engine. Did you look in the throttle body box? Carl > On Apr 22, 2017, at 12:10 PM, Carlos Trigo wrote: > > > Thank you guys > > I did look into the AcS catalog but didn't find them. > They're on their way now > > Thanks > Carlos > > Enviado do meu iPhone > > No dia 22/04/2017, s 15:17, Jesse Saint escreveu: > >> >> Aircraft Spruce has them. >> >> Jesse Saint >> Saint Aviation, Inc. >> jesse(at)saintaviation.com >> C: 352-427-0285 >> F: 815-377-3694 >> >> Sent from my iPhone >> >>> On Apr 22, 2017, at 10:01 AM, Rene Felker wrote: >>> >>> >>> I purchased a pair from ?????I can not remember????. It was one of the >>> normal suppliers. >>> >>> -----Original Message----- >>> From: owner-rv10-list-server(at)matronics.com >>> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo >>> Sent: Saturday, April 22, 2017 7:11 AM >>> To: rv10-list(at)matronics.com >>> Subject: RV10-List: Ignition wires seal >>> >>> >>> Guys >>> >>> I cannot find the 2 seals which are to be installed into the Baffles >>> (cylinders' #5 and #6 baffles) where the ignition wires pass trough these >>> baffles. >>> The plans indicate that those 2 seals are supplied with the engine. >>> >>> This engine was bought more than 5 years ago... >>> >>> Where can I obtain these seals? >>> >>> Thanks >>> Carlos >>> >>> Enviado do meu iPhone >>> >>> >>> >>> >>> >>> >>> >> >> >> > > > > > ________________________________________________________________________________
Date: Apr 22, 2017
Hi Carl The throttle body was installed many moons ago, but i'll try to find the box. Cheers Carlos Enviado do meu iPhone No dia 22/04/2017, s 20:20, Carl Froehlich escreveu: > > They should be with the engine. Did you look in the throttle body box? > > Carl > >> On Apr 22, 2017, at 12:10 PM, Carlos Trigo wrote: >> >> >> Thank you guys >> >> I did look into the AcS catalog but didn't find them. >> They're on their way now >> >> Thanks >> Carlos >> >> Enviado do meu iPhone >> >> No dia 22/04/2017, s 15:17, Jesse Saint escreveu: >> >>> >>> Aircraft Spruce has them. >>> >>> Jesse Saint >>> Saint Aviation, Inc. >>> jesse(at)saintaviation.com >>> C: 352-427-0285 >>> F: 815-377-3694 >>> >>> Sent from my iPhone >>> >>>> On Apr 22, 2017, at 10:01 AM, Rene Felker wrote: >>>> >>>> >>>> I purchased a pair from ?????I can not remember????. It was one of the >>>> normal suppliers. >>>> >>>> -----Original Message----- >>>> From: owner-rv10-list-server(at)matronics.com >>>> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo >>>> Sent: Saturday, April 22, 2017 7:11 AM >>>> To: rv10-list(at)matronics.com >>>> Subject: RV10-List: Ignition wires seal >>>> >>>> >>>> Guys >>>> >>>> I cannot find the 2 seals which are to be installed into the Baffles >>>> (cylinders' #5 and #6 baffles) where the ignition wires pass trough these >>>> baffles. >>>> The plans indicate that those 2 seals are supplied with the engine. >>>> >>>> This engine was bought more than 5 years ago... >>>> >>>> Where can I obtain these seals? >>>> >>>> Thanks >>>> Carlos >>>> >>>> Enviado do meu iPhone >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >> >> >> >> >> > > > > > ________________________________________________________________________________
From: Vernon Franklin <vernon.franklin(at)gmail.com>
Date: Apr 22, 2017
Subject: Prop Problems
I started the engine for the first time today :) Everything was in the green, and looked really good. But when I went to test the prop, it would not cycle. I have a hartzell gov, and the arm swing is good. Everything from the outside looks like it should work. Everything is stock from Van's FWF or Lycoming. I definitely pulled the plug on the crank case, that isn't the issue. I just don't know the first place to start looking. The only thing I can see from the outside, is this spacer between the governor and the engine, maybe the teeth on the gear cannot reach far enough. See picture. [image: Inline image 1] Anyone ever experience this? -- Vernon Franklin ________________________________________________________________________________
Subject: Re: Prop Problems
Date: Apr 22, 2017
I can't answer about the spacer. It should be easy enough to tell if the splines are meshing. But I can tell you it make take a short bit of running time before there's enough oil in the hub for the prop to cycle. You didn't mention how long you ran it for but maybe you just didn't wait long enough? Tim > On Apr 22, 2017, at 8:55 PM, Vernon Franklin wrote: > > I started the engine for the first time today :) > > Everything was in the green, and looked really good. But when I went to test the prop, it would not cycle. > > I have a hartzell gov, and the arm swing is good. Everything from the outside looks like it should work. Everything is stock from Van's FWF or Lycoming. > > I definitely pulled the plug on the crank case, that isn't the issue. I just don't know the first place to start looking. > > The only thing I can see from the outside, is this spacer between the governor and the engine, maybe the teeth on the gear cannot reach far enough. See picture. > > > > Anyone ever experience this? > > -- > Vernon Franklin ________________________________________________________________________________
Date: Apr 22, 2017
It was probably between 3 and 5 minute. How long should it take? Vernon On Apr 22, 2017 9:13 PM, "Tim Olson" wrote: > > I can't answer about the spacer. It should be easy enough to tell if the > splines are meshing. But I can tell you it make take a short bit of > running time before there's enough oil in the hub for the prop to cycle. > You didn't mention how long you ran it for but maybe you just didn't wait > long enough? > Tim > > > On Apr 22, 2017, at 8:55 PM, Vernon Franklin > wrote: > > > > I started the engine for the first time today :) > > > > Everything was in the green, and looked really good. But when I went to > test the prop, it would not cycle. > > > > I have a hartzell gov, and the arm swing is good. Everything from the > outside looks like it should work. Everything is stock from Van's FWF or > Lycoming. > > > > I definitely pulled the plug on the crank case, that isn't the issue. I > just don't know the first place to start looking. > > > > The only thing I can see from the outside, is this spacer between the > governor and the engine, maybe the teeth on the gear cannot reach far > enough. See picture. > > > > > > > > Anyone ever experience this? > > > > -- > > Vernon Franklin > > ________________________________________________________________________________
Date: Apr 22, 2017
Vernon, Have you considered having an a&p looking over you engine Install prior to first flight.? On Apr 22, 2017 9:53 PM, "Vernon Franklin" wrote: > It was probably between 3 and 5 minute. > How long should it take? > > Vernon > > On Apr 22, 2017 9:13 PM, "Tim Olson" wrote: > >> >> I can't answer about the spacer. It should be easy enough to tell if the >> splines are meshing. But I can tell you it make take a short bit of >> running time before there's enough oil in the hub for the prop to cycle. >> You didn't mention how long you ran it for but maybe you just didn't wait >> long enough? >> Tim >> >> > On Apr 22, 2017, at 8:55 PM, Vernon Franklin >> wrote: >> > >> > I started the engine for the first time today :) >> > >> > Everything was in the green, and looked really good. But when I went >> to test the prop, it would not cycle. >> > >> > I have a hartzell gov, and the arm swing is good. Everything from the >> outside looks like it should work. Everything is stock from Van's FWF or >> Lycoming. >> > >> > I definitely pulled the plug on the crank case, that isn't the issue. >> I just don't know the first place to start looking. >> > >> > The only thing I can see from the outside, is this spacer between the >> governor and the engine, maybe the teeth on the gear cannot reach far >> enough. See picture. >> > >> > >> > >> > Anyone ever experience this? >> > >> > -- >> > Vernon Franklin >> >> >> =================================== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/ >> Navigator?RV10-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> ________________________________________________________________________________
Date: Apr 22, 2017
I'm not exactly sure but it would probably depend on the RPM also. If you we ren't up to maybe 1800 rpm or so I don't know that you'd get enough pressure to get the oil flowing and make it work. I just know that when I did my IO -390 start last year it did take a bit of time. Tim > On Apr 22, 2017, at 9:49 PM, Vernon Franklin w rote: > > It was probably between 3 and 5 minute. > How long should it take? > > Vernon > >> On Apr 22, 2017 9:13 PM, "Tim Olson" wrote: >> >> I can't answer about the spacer. It should be easy enough to tell if the splines are meshing. But I can tell you it make take a short bit of runnin g time before there's enough oil in the hub for the prop to cycle. You didn 't mention how long you ran it for but maybe you just didn't wait long enoug h? >> Tim >> >> > On Apr 22, 2017, at 8:55 PM, Vernon Franklin wrote: >> > >> > I started the engine for the first time today :) >> > >> > Everything was in the green, and looked really good. But when I went t o test the prop, it would not cycle. >> > >> > I have a hartzell gov, and the arm swing is good. Everything from the o utside looks like it should work. Everything is stock from Van's FWF or Lyc oming. >> > >> > I definitely pulled the plug on the crank case, that isn't the issue. I just don't know the first place to start looking. >> > >> > The only thing I can see from the outside, is this spacer between the g overnor and the engine, maybe the teeth on the gear cannot reach far enough. See picture. >> > >> > >> > >> > Anyone ever experience this? >> > >> > -- >> > Vernon Franklin >> >> >> ========================= >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= ________________________________________________________________________________
Date: Apr 22, 2017
Vernon, I had a similar problem with my Hartzell prop. I checked all the same items, talked to 2 A&P's, and finally called Hartzell. They immediately told me what was wrong. At what speed were you running the engine when you tried to cycle the prop? I was used to doing a 1800 rpm run up and cycling the prop. That will not work. You need to be at least 2000 rpm. Bruce Hoppe Sent from my iPad > On Apr 22, 2017, at 8:55 PM, Vernon Franklin wrote: > > I started the engine for the first time today :) > > Everything was in the green, and looked really good. But when I went to test the prop, it would not cycle. > > I have a hartzell gov, and the arm swing is good. Everything from the outside looks like it should work. Everything is stock from Van's FWF or Lycoming. > > I definitely pulled the plug on the crank case, that isn't the issue. I just don't know the first place to start looking. > > The only thing I can see from the outside, is this spacer between the governor and the engine, maybe the teeth on the gear cannot reach far enough. See picture. > > > > Anyone ever experience this? > > -- > Vernon Franklin ________________________________________________________________________________
Date: Apr 22, 2017
Yup. Had two of them out there with me today. We were all stumped. Vernon On Apr 22, 2017 10:00 PM, "Shannon Hicks" wrote: > Vernon, > Have you considered having an a&p looking over you engine Install prior to > first flight.? > > > On Apr 22, 2017 9:53 PM, "Vernon Franklin" > wrote: > >> It was probably between 3 and 5 minute. >> How long should it take? >> >> Vernon >> >> On Apr 22, 2017 9:13 PM, "Tim Olson" wrote: >> >>> >>> I can't answer about the spacer. It should be easy enough to tell if >>> the splines are meshing. But I can tell you it make take a short bit of >>> running time before there's enough oil in the hub for the prop to cycle. >>> You didn't mention how long you ran it for but maybe you just didn't wait >>> long enough? >>> Tim >>> >>> > On Apr 22, 2017, at 8:55 PM, Vernon Franklin < >>> vernon.franklin(at)gmail.com> wrote: >>> > >>> > I started the engine for the first time today :) >>> > >>> > Everything was in the green, and looked really good. But when I went >>> to test the prop, it would not cycle. >>> > >>> > I have a hartzell gov, and the arm swing is good. Everything from the >>> outside looks like it should work. Everything is stock from Van's FWF or >>> Lycoming. >>> > >>> > I definitely pulled the plug on the crank case, that isn't the issue. >>> I just don't know the first place to start looking. >>> > >>> > The only thing I can see from the outside, is this spacer between the >>> governor and the engine, maybe the teeth on the gear cannot reach far >>> enough. See picture. >>> > >>> > >>> > >>> > Anyone ever experience this? >>> > >>> > -- >>> > Vernon Franklin >>> >>> >>> ========== >>> -List" rel="noreferrer" target="_blank">http://www.matronics.com/ >>> Navigator?RV10-List >>> ========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ========== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> ________________________________________________________________________________
Date: Apr 22, 2017
Agree with others. You need to be at over 1700 rpm, prop control pulled back, for up to 45 seconds or so, to get enough oil in there. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468696#468696 ________________________________________________________________________________
Date: Apr 23, 2017
This is a common question I hear. Get it to at least 1800rpm, 2000 is better, then pull the prop control and leave it out. It can take 30-60 seconds to get a reaction in the prop the first time. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 Sent from my iPhone > On Apr 22, 2017, at 9:55 PM, Vernon Franklin wrote: > > I started the engine for the first time today :) > > Everything was in the green, and looked really good. But when I went to test the prop, it would not cycle. > > I have a hartzell gov, and the arm swing is good. Everything from the outside looks like it should work. Everything is stock from Van's FWF or Lycoming. > > I definitely pulled the plug on the crank case, that isn't the issue. I just don't know the first place to start looking. > > The only thing I can see from the outside, is this spacer between the governor and the engine, maybe the teeth on the gear cannot reach far enough. See picture. > > > > Anyone ever experience this? > > -- > Vernon Franklin ________________________________________________________________________________
Date: Apr 23, 2017
As I mentioned last night, the governor supplied by Vans with the Hartzell prop needs at least 2000 rpm to control the prop. That is what Hartzell told me and is absolutely true. 1700 rpm does not work, 1800 rpm will not work. You must be over 2000 rpm, which seems high, but your prop will cycle. Bruce Hoppe Sent from my iPad > On Apr 23, 2017, at 6:52 AM, Jesse Saint wrote: > > > This is a common question I hear. Get it to at least 1800rpm, 2000 is better, then pull the prop control and leave it out. It can take 30-60 seconds to get a reaction in the prop the first time. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > Sent from my iPhone > >> On Apr 22, 2017, at 9:55 PM, Vernon Franklin wrote: >> >> I started the engine for the first time today :) >> >> Everything was in the green, and looked really good. But when I went to test the prop, it would not cycle. >> >> I have a hartzell gov, and the arm swing is good. Everything from the outside looks like it should work. Everything is stock from Van's FWF or Lycoming. >> >> I definitely pulled the plug on the crank case, that isn't the issue. I just don't know the first place to start looking. >> >> The only thing I can see from the outside, is this spacer between the governor and the engine, maybe the teeth on the gear cannot reach far enough. See picture. >> >> >> >> Anyone ever experience this? >> >> -- >> Vernon Franklin > > > > > ________________________________________________________________________________
Date: Apr 23, 2017
One more thing to check. Have two of you try to change the pitch with your hands manually. This is easily accomplished with two people. Make sure the prop moves full range to the stops. If you can't move it or it is really hard there might be hydraulic lock in the prop due to a bad seal during construction. This happened to me. Usually it's something simple but make sure. In my case it was a prop overhaul and the oring was nicked. The prop cycled at first and then slowly went to a fixed pitch prop in flight. It was bad because it wanted to over rev the engine and I had to limp back to the airport. Luckily, I was close and didn't have to add more power. Just a thought. Usually it is something more simple but an easy check with two people. -------- 40936 RV-10 SB N801VR Flying 780 Hours SuperSTOL 60 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468700#468700 ________________________________________________________________________________
Date: Apr 23, 2017
I may be wrong but you said you pulled a plug from the crankshaft, did you mean it had been set up for fp prop before? -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468701#468701 ________________________________________________________________________________
Date: Apr 23, 2017
If it's a new engine, it will just come that way. Tim > On Apr 23, 2017, at 11:53 AM, rvdave wrote: > > > I may be wrong but you said you pulled a plug from the crankshaft, did you mean it had been set up for fp prop before? > > -------- > Dave Ford > RV6 for sale > RV10 building > Cadillac, MI > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=468701#468701 > > > > > > > > > ________________________________________________________________________________
Date: Apr 23, 2017
> If it's a new engine, it will just come that way. > Tim > Do you mean set up for fp or with a plug in the end? -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468705#468705 ________________________________________________________________________________
Date: Apr 23, 2017
rvdave wrote: > > > If it's a new engine, it will just come that way. > > Tim > > > > > Do you mean set up for fp or with a plug in the end? Mine was all set up for CS except that there was a plug an inch or so from the forward end of the crankshaft. There are various ways to pull it. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468709#468709 ________________________________________________________________________________
Date: Apr 23, 2017
Mine came with a plug in the rear but only a plastic cap in the front which I removed. I know to change a crank from cs to fp which I did on our 6 was to pierce the plug in the rear and add a plug to the front, that's why I was wondering. -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468710#468710 ________________________________________________________________________________
Date: Apr 23, 2017
Thanks everyone for the suggestions. All of you were correct, it came down to RPM. Alex DeDominicis dropped by earlier as I was outside trying to get things to work. I told him the situation and ran it up with him outside. He said there was no way the engine was running at 2000 RPM, so he proceeded to jump in and pushed the throttle up beyond were I had gone yet. At around 3800 RPM... The prop finally engaged. After nearly having a heart attack, he said that was closer to 1900 to 2000 RPM. So it seems my Dynon EMS is doubling the RPM for some reason, need to do some more research. Prop problem solved, on to the next one! Thanks for the input, you guys nailed it. Vernon On Sat, Apr 22, 2017 at 8:55 PM, Vernon Franklin wrote: > I started the engine for the first time today :) > > Everything was in the green, and looked really good. But when I went to > test the prop, it would not cycle. > > I have a hartzell gov, and the arm swing is good. Everything from the > outside looks like it should work. Everything is stock from Van's FWF or > Lycoming. > > I definitely pulled the plug on the crank case, that isn't the issue. I > just don't know the first place to start looking. > > The only thing I can see from the outside, is this spacer between the > governor and the engine, maybe the teeth on the gear cannot reach far > enough. See picture. > > [image: Inline image 1] > > Anyone ever experience this? > > -- > Vernon Franklin > -- Vernon Franklin ________________________________________________________________________________
Date: Apr 23, 2017
If you go into settings, then to calibration (bottom option on the main sett ings list), then to EMS Calibration, then to RPM, change the pulses per revo lution. Depending on your ignition system, there will be different pulses pe r revolution. If it's reading double, then double your pulses per revolution and that should fix it. Easy peasy. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Apr 23, 2017, at 7:52 PM, Vernon Franklin w rote: > > Thanks everyone for the suggestions. All of you were correct, it came dow n to RPM. Alex DeDominicis dropped by earlier as I was outside trying to ge t things to work. I told him the situation and ran it up with him outside. H e said there was no way the engine was running at 2000 RPM, so he proceeded t o jump in and pushed the throttle up beyond were I had gone yet. At around 3 800 RPM... The prop finally engaged. After nearly having a heart attack, he said that was closer to 1900 to 2000 RPM. So it seems my Dynon EMS is doub ling the RPM for some reason, need to do some more research. > > Prop problem solved, on to the next one! > > Thanks for the input, you guys nailed it. > > Vernon > > >> On Sat, Apr 22, 2017 at 8:55 PM, Vernon Franklin wrote: >> I started the engine for the first time today :) >> >> Everything was in the green, and looked really good. But when I went to t est the prop, it would not cycle. >> >> I have a hartzell gov, and the arm swing is good. Everything from the ou tside looks like it should work. Everything is stock from Van's FWF or Lyco ming. >> >> I definitely pulled the plug on the crank case, that isn't the issue. I j ust don't know the first place to start looking. >> >> The only thing I can see from the outside, is this spacer between the gov ernor and the engine, maybe the teeth on the gear cannot reach far enough. S ee picture. >> >> >> >> Anyone ever experience this? >> >> -- >> Vernon Franklin > > > > -- > Vernon Franklin ________________________________________________________________________________
Date: Apr 24, 2017
How are you getting RPM, a sensor on the mag? On Sun, Apr 23, 2017 at 8:08 PM Vernon Franklin wrote: > Thanks everyone for the suggestions. All of you were correct, it came > down to RPM. Alex DeDominicis dropped by earlier as I was outside trying > to get things to work. I told him the situation and ran it up with him > outside. He said there was no way the engine was running at 2000 RPM, so he > proceeded to jump in and pushed the throttle up beyond were I had gone > yet. At around 3800 RPM... The prop finally engaged. After nearly having > a heart attack, he said that was closer to 1900 to 2000 RPM. So it seems > my Dynon EMS is doubling the RPM for some reason, need to do some more > research. > > Prop problem solved, on to the next one! > > Thanks for the input, you guys nailed it. > > Vernon > > > On Sat, Apr 22, 2017 at 8:55 PM, Vernon Franklin < > vernon.franklin(at)gmail.com> wrote: > >> I started the engine for the first time today :) >> >> Everything was in the green, and looked really good. But when I went to >> test the prop, it would not cycle. >> >> I have a hartzell gov, and the arm swing is good. Everything from the >> outside looks like it should work. Everything is stock from Van's FWF or >> Lycoming. >> >> I definitely pulled the plug on the crank case, that isn't the issue. I >> just don't know the first place to start looking. >> >> The only thing I can see from the outside, is this spacer between the >> governor and the engine, maybe the teeth on the gear cannot reach far >> enough. See picture. >> >> [image: Inline image 1] >> >> Anyone ever experience this? >> >> -- >> Vernon Franklin >> > > > -- > Vernon Franklin > ________________________________________________________________________________
Date: Apr 23, 2017
Sensor on the P-lead of each slick. Vernon On Apr 23, 2017 8:00 PM, "John Trollinger" wrote: How are you getting RPM, a sensor on the mag? On Sun, Apr 23, 2017 at 8:08 PM Vernon Franklin wrote: > Thanks everyone for the suggestions. All of you were correct, it came > down to RPM. Alex DeDominicis dropped by earlier as I was outside trying > to get things to work. I told him the situation and ran it up with him > outside. He said there was no way the engine was running at 2000 RPM, so he > proceeded to jump in and pushed the throttle up beyond were I had gone > yet. At around 3800 RPM... The prop finally engaged. After nearly having > a heart attack, he said that was closer to 1900 to 2000 RPM. So it seems > my Dynon EMS is doubling the RPM for some reason, need to do some more > research. > > Prop problem solved, on to the next one! > > Thanks for the input, you guys nailed it. > > Vernon > > > On Sat, Apr 22, 2017 at 8:55 PM, Vernon Franklin < > vernon.franklin(at)gmail.com> wrote: > >> I started the engine for the first time today :) >> >> Everything was in the green, and looked really good. But when I went to >> test the prop, it would not cycle. >> >> I have a hartzell gov, and the arm swing is good. Everything from the >> outside looks like it should work. Everything is stock from Van's FWF or >> Lycoming. >> >> I definitely pulled the plug on the crank case, that isn't the issue. I >> just don't know the first place to start looking. >> >> The only thing I can see from the outside, is this spacer between the >> governor and the engine, maybe the teeth on the gear cannot reach far >> enough. See picture. >> >> [image: Inline image 1] >> >> Anyone ever experience this? >> >> -- >> Vernon Franklin >> > > > -- > Vernon Franklin > ________________________________________________________________________________
Date: Apr 23, 2017
Perfect thank you. Vernon On Apr 23, 2017 7:52 PM, "Jesse Saint" wrote: If you go into settings, then to calibration (bottom option on the main settings list), then to EMS Calibration, then to RPM, change the pulses per revolution. Depending on your ignition system, there will be different pulses per revolution. If it's reading double, then double your pulses per revolution and that should fix it. Easy peasy. Jesse Saint Saint Aviation, Inc. 352-427-0285 <(352)%20427-0285> jesse(at)saintaviation.com Sent from my iPad On Apr 23, 2017, at 7:52 PM, Vernon Franklin wrote: Thanks everyone for the suggestions. All of you were correct, it came down to RPM. Alex DeDominicis dropped by earlier as I was outside trying to get things to work. I told him the situation and ran it up with him outside. He said there was no way the engine was running at 2000 RPM, so he proceeded to jump in and pushed the throttle up beyond were I had gone yet. At around 3800 RPM... The prop finally engaged. After nearly having a heart attack, he said that was closer to 1900 to 2000 RPM. So it seems my Dynon EMS is doubling the RPM for some reason, need to do some more research. Prop problem solved, on to the next one! Thanks for the input, you guys nailed it. Vernon On Sat, Apr 22, 2017 at 8:55 PM, Vernon Franklin wrote: > I started the engine for the first time today :) > > Everything was in the green, and looked really good. But when I went to > test the prop, it would not cycle. > > I have a hartzell gov, and the arm swing is good. Everything from the > outside looks like it should work. Everything is stock from Van's FWF or > Lycoming. > > I definitely pulled the plug on the crank case, that isn't the issue. I > just don't know the first place to start looking. > > The only thing I can see from the outside, is this spacer between the > governor and the engine, maybe the teeth on the gear cannot reach far > enough. See picture. > > [image: Inline image 1] > > Anyone ever experience this? > > -- > Vernon Franklin > -- Vernon Franklin ________________________________________________________________________________
Date: Apr 23, 2017
With Dynon it is usually a wire to the p-lead with a resistor. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Apr 23, 2017, at 8:54 PM, John Trollinger wrote: > > How are you getting RPM, a sensor on the mag? > > >> On Sun, Apr 23, 2017 at 8:08 PM Vernon Franklin wrote: >> Thanks everyone for the suggestions. All of you were correct, it came do wn to RPM. Alex DeDominicis dropped by earlier as I was outside trying to g et things to work. I told him the situation and ran it up with him outside. He said there was no way the engine was running at 2000 RPM, so he proceede d to jump in and pushed the throttle up beyond were I had gone yet. At arou nd 3800 RPM... The prop finally engaged. After nearly having a heart attack , he said that was closer to 1900 to 2000 RPM. So it seems my Dynon EMS is d oubling the RPM for some reason, need to do some more research. >> >> Prop problem solved, on to the next one! >> >> Thanks for the input, you guys nailed it. >> >> Vernon >> >> >>> On Sat, Apr 22, 2017 at 8:55 PM, Vernon Franklin <vernon.franklin@gmail. com> wrote: >>> I started the engine for the first time today :) >>> >>> Everything was in the green, and looked really good. But when I went to test the prop, it would not cycle. >>> >>> I have a hartzell gov, and the arm swing is good. Everything from the o utside looks like it should work. Everything is stock from Van's FWF or Lyc oming. >>> >>> I definitely pulled the plug on the crank case, that isn't the issue. I just don't know the first place to start looking. >>> >>> The only thing I can see from the outside, is this spacer between the go vernor and the engine, maybe the teeth on the gear cannot reach far enough. See picture. >>> >>> >>> >>> Anyone ever experience this? >>> >>> -- >>> Vernon Franklin >> >> >> >> >> -- >> Vernon Franklin ________________________________________________________________________________
Date: Apr 23, 2017
Agreed. The Dynon default is 1 for four cylinder engines. You need 1.5 for six cylinder. Not sure why you would be getting double actual if you had the default 4 cyl setting. Make sure you have the approx 30K resistor in the line between EMS and P-lead. Can need higher if there are some spikes seen. On 4/23/2017 6:13 PM, Jesse Saint wrote: > With Dynon it is usually a wire to the p-lead with a resistor. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > On Apr 23, 2017, at 8:54 PM, John Trollinger > wrote: > >> How are you getting RPM, a sensor on the mag? >> >> >> On Sun, Apr 23, 2017 at 8:08 PM Vernon Franklin >> > wrote: >> >> Thanks everyone for the suggestions. All of you were correct, it >> came down to RPM. Alex DeDominicis dropped by earlier as I was >> outside trying to get things to work. I told him the situation >> and ran it up with him outside. He said there was no way the >> engine was running at 2000 RPM, so he proceeded to jump in and >> pushed the throttle up beyond were I had gone yet. At around 3800 >> RPM... The prop finally engaged. After nearly having a heart >> attack, he said that was closer to 1900 to 2000 RPM. So it seems >> my Dynon EMS is doubling the RPM for some reason, need to do some >> more research. >> >> Prop problem solved, on to the next one! >> >> Thanks for the input, you guys nailed it. >> >> Vernon >> >> >> On Sat, Apr 22, 2017 at 8:55 PM, Vernon Franklin >> > wrote: >> >> I started the engine for the first time today :) >> >> Everything was in the green, and looked really good. But when >> I went to test the prop, it would not cycle. >> >> I have a hartzell gov, and the arm swing is good. Everything >> from the outside looks like it should work. Everything is >> stock from Van's FWF or Lycoming. >> >> I definitely pulled the plug on the crank case, that isn't the >> issue. I just don't know the first place to start looking. >> >> The only thing I can see from the outside, is this spacer >> between the governor and the engine, maybe the teeth on the >> gear cannot reach far enough. See picture. >> >> Inline image 1 >> >> Anyone ever experience this? >> >> -- >> Vernon Franklin >> >> >> >> >> -- >> Vernon Franklin >> ________________________________________________________________________________
Subject: FYI update on NL Starter, rebuilt mags (and fresh plugs)
Date: Apr 23, 2017
I was never happy with the light weight starter that shipped with the Vans configured Lycoming. As others have reported, getting the first blade to turn over always seemed in question. I have two batteries which I can apply separately or together to the starter. Replacing the light weight starter with NL starter made a world of difference. It turns a bit slower but with authority. And though I always intend to use both batts for the start, I accidentally did a 1 battery start today and got the same slower but authoritative start. Confidence boosted - Dollars well spent. I also swapped out my original Slicks at 860 hours for rebuilts. Everything was running fine but some recommend overhaul or replacement at 500 hours. Though I didn't expect it, the engine runs noticeably smoother (the old mags had just been timed before they were replaced so the the comparison was meaningful). Again, confidence boosted - dollars well spent. Back at 700 hours I completed replacement of all the original plugs with new ones (the final 5 of 12). The engine ran noticeably smoother and possibly with more oomph. Up to that point, I had cleaned and gapped the plugs at every Condition Inspection. Going forward, I plan to change plugs at 500 to 600 hours. Just FYI, YMMV. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 24, 2017
Not having studied the Dynon manuals, my guess would be that two pick-ups (one on each P-lead) are combining to double the reading. Neal George Sent from my iPhone > On Apr 24, 2017, at 10:03 AM ________________________________________________________________________________
Date: Apr 23, 2017
I was thinking the same thing. If the setting is 1 and needs to be 1.5, then 2,000 rpm would read as 3,000. If it was set at .5, then it would be triple instead of double. Either way, it should be made correct by adjusting the pulses per revolution. Also, in my instructions, I was assuming it was Skyview. The D120/D180/D10 would be different. Give me a call tomorrow or the next time you are at he plane and I can walk you through the setup. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Apr 23, 2017, at 10:03 PM, Kelly McMullen wrote: > > > Agreed. The Dynon default is 1 for four cylinder engines. You need 1.5 for six cylinder. Not sure why you would be getting double actual if you had the default 4 cyl setting. Make sure you have the approx 30K resistor in the line between EMS and P-lead. Can need higher if there are some spikes seen. > >> On 4/23/2017 6:13 PM, Jesse Saint wrote: >> With Dynon it is usually a wire to the p-lead with a resistor. >> Jesse Saint >> Saint Aviation, Inc. >> 352-427-0285 >> jesse(at)saintaviation.com >> Sent from my iPad >>> On Apr 23, 2017, at 8:54 PM, John Trollinger > wrote: >>> How are you getting RPM, a sensor on the mag? >>> >>> >>> On Sun, Apr 23, 2017 at 8:08 PM Vernon Franklin > wrote: >>> >>> Thanks everyone for the suggestions. All of you were correct, it >>> came down to RPM. Alex DeDominicis dropped by earlier as I was >>> outside trying to get things to work. I told him the situation >>> and ran it up with him outside. He said there was no way the >>> engine was running at 2000 RPM, so he proceeded to jump in and >>> pushed the throttle up beyond were I had gone yet. At around 3800 >>> RPM... The prop finally engaged. After nearly having a heart >>> attack, he said that was closer to 1900 to 2000 RPM. So it seems >>> my Dynon EMS is doubling the RPM for some reason, need to do some >>> more research. >>> >>> Prop problem solved, on to the next one! >>> >>> Thanks for the input, you guys nailed it. >>> >>> Vernon >>> >>> >>> On Sat, Apr 22, 2017 at 8:55 PM, Vernon Franklin >>> > wrote: >>> >>> I started the engine for the first time today :) >>> >>> Everything was in the green, and looked really good. But when >>> I went to test the prop, it would not cycle. >>> >>> I have a hartzell gov, and the arm swing is good. Everything >>> from the outside looks like it should work. Everything is >>> stock from Van's FWF or Lycoming. >>> >>> I definitely pulled the plug on the crank case, that isn't the >>> issue. I just don't know the first place to start looking. >>> >>> The only thing I can see from the outside, is this spacer >>> between the governor and the engine, maybe the teeth on the >>> gear cannot reach far enough. See picture. >>> >>> Inline image 1 >>> >>> Anyone ever experience this? >>> >>> -- Vernon Franklin >>> >>> >>> >>> >>> -- Vernon Franklin >>> > > > ________________________________________________________________________________
Date: Apr 23, 2017
Make sure you have the 30k ohm resistor inline on both the white/green and w hite/blue wires close to where they tie to the p-lead, then follow this (6-c yl should be either 1.5 or 3.0 based on this): Increment or decrement the PULS/REV R and L values to correspond to the numb er of pulses put out by your tachometer source for each engine revolution. Y ou may select the pulses/rev for both the left and right tachometer inputs i ndependently. If they are both p-lead inputs, these will likely be the same n umber. However, if you have connected two different types of tachometer sour ces, you will likely have to input different values into these fields. If yo u are using a p-lead connection, the PULS/REV value will typically be set to 1=81=842 or 1=81=844 of the number of cylinders in the engine. If you find that the onscreen tachometer reads double or half what you expect, adj ust the PULS/REV value until you observe the expected value. If you do not h ave anything hooked to one of the tachometer inputs, the PULS/REV setting fo r this input can be set to any value. The FlightDEK-D180 will automatically i gnore this unused input Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Apr 23, 2017, at 9:12 PM, Vernon Franklin w rote: > > Sensor on the P-lead of each slick. > > Vernon > > On Apr 23, 2017 8:00 PM, "John Trollinger" wrote: > How are you getting RPM, a sensor on the mag? > > >> On Sun, Apr 23, 2017 at 8:08 PM Vernon Franklin wrote: >> Thanks everyone for the suggestions. All of you were correct, it came do wn to RPM. Alex DeDominicis dropped by earlier as I was outside trying to g et things to work. I told him the situation and ran it up with him outside. He said there was no way the engine was running at 2000 RPM, so he proceede d to jump in and pushed the throttle up beyond were I had gone yet. At arou nd 3800 RPM... The prop finally engaged. After nearly having a heart attack , he said that was closer to 1900 to 2000 RPM. So it seems my Dynon EMS is d oubling the RPM for some reason, need to do some more research. >> >> Prop problem solved, on to the next one! >> >> Thanks for the input, you guys nailed it. >> >> Vernon >> >> >>> On Sat, Apr 22, 2017 at 8:55 PM, Vernon Franklin <vernon.franklin@gmail. com> wrote: >>> I started the engine for the first time today :) >>> >>> Everything was in the green, and looked really good. But when I went to test the prop, it would not cycle. >>> >>> I have a hartzell gov, and the arm swing is good. Everything from the o utside looks like it should work. Everything is stock from Van's FWF or Lyc oming. >>> >>> I definitely pulled the plug on the crank case, that isn't the issue. I just don't know the first place to start looking. >>> >>> The only thing I can see from the outside, is this spacer between the go vernor and the engine, maybe the teeth on the gear cannot reach far enough. See picture. >>> >>> >>> >>> Anyone ever experience this? >>> >>> -- >>> Vernon Franklin >> >> >> >> >> -- >> Vernon Franklin > ________________________________________________________________________________
Date: Apr 24, 2017
Subject: Re: FYI update on NL Starter, rebuilt mags (and fresh plugs)
Did you heard about Mike Busch? I saw that he measured the resistance between the mass electrode and the bottom in the spark plugs where the ignition cabel springs get contact. Many of the standard champion plugs read resistance way higher than it should be (1-2kohms). He recommends to change the plugs when resistance readings are more than 5kohms. Peter Aringer RV-10 empennage started in Germany in 2017-01 Aringer Automobiltechnik e.K. Chrysler, Jeep & Dodge Service Lancia & Brilliance Service Mit freundlichen Gren / Kind regards Peter Aringer Inhaber Aringer Automobiltechnik e.K. Chrysler, Jeep & Dodge Service Lancia & Brilliance Service > Am 24.04.2017 um 09:23 schrieb Bill Watson : > > > I was never happy with the light weight starter that shipped with the > Vans configured Lycoming. As others have reported, getting the first > blade to turn over always seemed in question. I have two batteries > which I can apply separately or together to the starter. Replacing the > light weight starter with NL starter made a world of difference. It > turns a bit slower but with authority. And though I always intend to use > both batts for the start, I accidentally did a 1 battery start today and > got the same slower but authoritative start. Confidence boosted - > Dollars well spent. > > I also swapped out my original Slicks at 860 hours for rebuilts. > Everything was running fine but some recommend overhaul or replacement > at 500 hours. Though I didn't expect it, the engine runs noticeably > smoother (the old mags had just been timed before they were replaced so > the the comparison was meaningful). Again, confidence boosted - dollars > well spent. > > Back at 700 hours I completed replacement of all the original plugs with > new ones (the final 5 of 12). The engine ran noticeably smoother and > possibly with more oomph. Up to that point, I had cleaned and gapped > the plugs at every Condition Inspection. Going forward, I plan to > change plugs at 500 to 600 hours. > > Just FYI, YMMV. > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > > > > > ________________________________________________________________________________
Date: Apr 23, 2017
The standard recommendation on conventional mags is to inspect and repair as necessary at 500 hours, overhaul at 1000 hours. However pricing of parts for Slicks tends to lead to lead to replacement rather than overhaul, or to only do one overhaul. Normal massive plugs usually have worn the electrodes thin enough that they should be replaced at 400-500 hours. Not to mention that Champions tend to have a fair number reach excessive resistance at less than 400 hours. I've had one fail already with less than 100 hour....resistance at 7.5K ohms. High resistance plugs will be somewhat intermittent and stress the mags because a higher voltage is needed to create the spark. -sent from the I-droid implanted in my forearm On Sun, Apr 23, 2017 at 7:12 PM, Bill Watson wrote: > > I was never happy with the light weight starter that shipped with the Vans > configured Lycoming. As others have reported, getting the first blade to > turn over always seemed in question. I have two batteries which I can > apply separately or together to the starter. Replacing the light weight > starter with NL starter made a world of difference. It turns a bit slower > but with authority. And though I always intend to use both batts for the > start, I accidentally did a 1 battery start today and got the same slower > but authoritative start. Confidence boosted - Dollars well spent. > > I also swapped out my original Slicks at 860 hours for rebuilts. > Everything was running fine but some recommend overhaul or replacement at > 500 hours. Though I didn't expect it, the engine runs noticeably smoother > (the old mags had just been timed before they were replaced so the the > comparison was meaningful). Again, confidence boosted - dollars well spent. > > Back at 700 hours I completed replacement of all the original plugs with > new ones (the final 5 of 12). The engine ran noticeably smoother and > possibly with more oomph. Up to that point, I had cleaned and gapped the > plugs at every Condition Inspection. Going forward, I plan to change plugs > at 500 to 600 hours. > > Just FYI, YMMV. > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: Apr 24, 2017
Champion plugs used to be manufactured with a resistive element that was inserted into the center of the plug and held in place with a spring and a screw cap. This design was flawed and allowed the assembly to fail over time from either the contact resistance increasing or the spring tension failing. The result was an excessive amount of series resistance through the plug. On several occasions this assembly has failed by opening up and then taking out a magneto with it. When the resistor opens up, the magneto starts to arc internally. The Tempest plug has an internal resistor that is integral to the assembly and is bonded in place. Champion has redesigned their plug in a similar manner to eliminate the aforementioned problem. You can identify the old plug design by looking into the center section. You will see a screw cap that can be removed with a conventional screw driver. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468729#468729 ________________________________________________________________________________
Date: Apr 24, 2017
OK, so if Champion has "fixed" the problem, why would a CSOB RV builder choose to spend $4 more per massive plug, or $24 more per fine wire plug the buy the C brand over the T brand?? They also have shown problems with their fine wire plugs in turbo-charged and turbo-normalized engines, such that GAMI/Tornado Alley Turbos issued a service bulletin to not use Champion fine wires. (ceramic around center electrodes were cracking and failing) I don't know if it could be a problem or not with normally aspirated engines running higher than stock compression. I just don't know what would compel making a switch back to Champion. -sent from the I-droid implanted in my forearm On Mon, Apr 24, 2017 at 6:05 AM, bill.peyton wrote: > > Champion plugs used to be manufactured with a resistive element that was > inserted into the center of the plug and held in place with a spring and a > screw cap. This design was flawed and allowed the assembly to fail over > time from either the contact resistance increasing or the spring tension > failing. The result was an excessive amount of series resistance through > the plug. On several occasions this assembly has failed by opening up and > then taking out a magneto with it. When the resistor opens up, the magneto > starts to arc internally. > The Tempest plug has an internal resistor that is integral to the assembly > and is bonded in place. Champion has redesigned their plug in a similar > manner to eliminate the aforementioned problem. > You can identify the old plug design by looking into the center section. > You will see a screw cap that can be removed with a conventional screw > driver. > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=468729#468729 > > ________________________________________________________________________________
Date: Apr 24, 2017
I pushed the numbers out a bit because I had complied with Slick SB2-08a and SB3-08a at 205 hours which required new carbon brushes and cams. I believe those are the main wear items that might be inspected and repaired at the first 500. Having acquired the basic knowledge and tools to do the most basic inspect and repair, I considered self overhauling but as a few more hours ticked by, I decided to get rebuilt-to-new spec replacements. Going forward I will be swapping them out at 500 hours. Thanks all for the Busch/resistance check thing. I was replacing plugs as needed through 700 hours due to electrode erosion and then just replaced the remaining units at 700. Going forward when 1 or 2 need replacement, I'll probably just do the whole set. On 4/24/2017 1:09 AM, Kelly McMullen wrote: > The standard recommendation on conventional mags is to inspect and > repair as necessary at 500 hours, overhaul at 1000 hours. However > pricing of parts for Slicks tends to lead to lead to replacement > rather than overhaul, or to only do one overhaul. Normal massive plugs > usually have worn the electrodes thin enough that they should be > replaced at 400-500 hours. Not to mention that Champions tend to have > a fair number reach excessive resistance at less than 400 hours. I've > had one fail already with less than 100 hour....resistance at 7.5K > ohms. High resistance plugs will be somewhat intermittent and stress > the mags because a higher voltage is needed to create the spark. > > -sent from the I-droid implanted in my forearm > > On Sun, Apr 23, 2017 at 7:12 PM, Bill Watson > wrote: > > > > > I was never happy with the light weight starter that shipped with > the Vans configured Lycoming. As others have reported, getting > the first blade to turn over always seemed in question. I have > two batteries which I can apply separately or together to the > starter. Replacing the light weight starter with NL starter made > a world of difference. It turns a bit slower but with authority. > And though I always intend to use both batts for the start, I > accidentally did a 1 battery start today and got the same slower > but authoritative start. Confidence boosted - Dollars well spent. > > I also swapped out my original Slicks at 860 hours for rebuilts. > Everything was running fine but some recommend overhaul or > replacement at 500 hours. Though I didn't expect it, the engine > runs noticeably smoother (the old mags had just been timed before > they were replaced so the the comparison was meaningful). Again, > confidence boosted - dollars well spent. > > Back at 700 hours I completed replacement of all the original > plugs with new ones (the final 5 of 12). The engine ran > noticeably smoother and possibly with more oomph. Up to that > point, I had cleaned and gapped the plugs at every Condition > Inspection. Going forward, I plan to change plugs at 500 to 600 > hours. > > Just FYI, YMMV. > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > =================================== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > ________________________________________________________________________________
Date: Apr 24, 2017
Or, just use Fine wire plugs. I'm guessing those will run to TBO with minimal issues. They won't have electrode erosion, so if they are replaced early, it will likely be for some other purpose. Tim On 4/24/2017 1:02 PM, Bill Watson wrote: > I was replacing plugs as needed through 700 hours due to electrode > erosion and then just replaced the remaining units at 700. Going > forward when 1 or 2 need replacement, I'll probably just do the whole set. > ________________________________________________________________________________
Date: Apr 24, 2017
Economics are such that you only come out ahead if all of your fine wires make it to TBO. Drop one, have it develop high resistance or break an electrode, and you come out about even with having massives. I've seen them dropped, I've had Champion fine wires develop resistance of over 100K. So far haven't broken an electrode, but I know it is easy to do. If a cylinder is using some oil, fine wire on bottom plug might make sense, but an REM37BY does same thing for 1/3 the money. -sent from the I-droid implanted in my forearm On Mon, Apr 24, 2017 at 1:36 PM, Tim Olson wrote: > > Or, just use Fine wire plugs. I'm guessing those will run to TBO > with minimal issues. They won't have electrode erosion, so if > they are replaced early, it will likely be for some other purpose. > Tim > > > On 4/24/2017 1:02 PM, Bill Watson wrote: > > I was replacing plugs as needed through 700 hours due to electrode >> erosion and then just replaced the remaining units at 700. Going >> forward when 1 or 2 need replacement, I'll probably just do the whole set. >> > > ________________________________________________________________________________
Subject: SureFly Electronic Ignition
Date: Apr 25, 2017
SureFly is now delivering 6 cylinder experimental ignition units. surely.aero or 817-373-5161 Thanks! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468775#468775 ________________________________________________________________________________
Subject: 2017 AirVenture RV-10 Dinner/Social
Date: Apr 25, 2017
Sticking with tradition, we will again be hosting the annual Oshkosh RV-10 dinner/social on Sunday 7/23 this year. Location will be in Camp Scholler (in the area of 55th & Lindbergh) as in the past but we won't know the exact area until we get on site, about a week before. We will also acquire an additional site as in years past for a hangout area during the week. Start time will be 5:30, feel free to show up early if you'd like to be put to work setting up! We've had best luck just taking care of the food rather than doing pot luck so we'll stick with that approach and have a container for a free will offering to help offset cost. If you'd rather bring something that's ok, it's just difficult for a lot of folks to do much if they flew in and/or are camping. Not sure what the menu is yet, but food is always good and plentiful. This is intended to be RV-10 focused, but as always, those still in the planning stages, vendors, etc. are also welcome. More details when the date gets closer, as of now there isn't much more known. If you are planning to attend I'd appreciate a heads up so we have some idea of head count. Standby for more info... Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468778#468778 ________________________________________________________________________________
From: Moses Adrian USDM <adrian.moses(at)syngenta.com>
Date: Apr 26, 2017
Planted some early sweet corn. See if it doesn't get frosted off! Adrian Moses RV10=closing in on 575 hrs This message may contain confidential information. If you are not the designated recipient, please notify the sender immediately, and delete the original and any copies. Any use of the message by you is prohibited. ________________________________________________________________________________
Date: Apr 26, 2017
Subject: Logbook Entries
Does anyone know of a site that has sample language for logbook entries? For example, I need to add my MT-Prop gov SB entry. I need to show that I checked AD's for my engine. I need to show that I've started the conditional inspection... I don't have much info on how those entries should be formatted and I'm hoping there is a site or FAA doc in existence that outlines the format for those entries. I'm a logbook rookie. Phil ________________________________________________________________________________
Date: Apr 26, 2017
Subject: Re: 2017 AirVenture RV-10 Dinner/Social
Excellent! Bob On Wed, Apr 26, 2017 at 9:04 AM, Moses Adrian USDM < adrian.moses(at)syngenta.com> wrote: > adrian.moses(at)syngenta.com> > > > Planted some early sweet corn. See if it doesn't get frosted off! > > Adrian Moses > RV10=closing in on 575 hrs > > This message may contain confidential information. If you are not the > designated recipient, please notify the sender immediately, and delete the > original and any copies. Any use of the message by you is prohibited. > > ________________________________________________________________________________
Subject: Re: Logbook Entries
Date: Apr 26, 2017
I think for many of them you can just use your best common sense and try to provide enough detail that someone in the future could look and understand what was done and why. The language for the annual condition inspection is in your operating limitations and is pretty standard, so that one is easy, but I don't think there is any need to show that you've STARTED the inspection, just do an entry when you are done with it. The start date of an inspection isn't the relevant date...it's the completed date that matters. That log entry usually looks like: "I certify that this aircraft has been inspected on X/X/2017 in accordance with the scope and detail of FAR part 43, Appendix D, and was found to be in the condition for safe operation." I personally when doing the ACI, don't log every individual task, such as "repacked wheel bearings", but only list any that are significant for some reason. I also log all of the cylinder compressions for historical reasons. Here's an example of what I did for a recent fuel pump log entry. Someone like Kelly may be able to confirm if it's adequate. "Replaced fuel pump model 62B26931 s/n RC4214036826 with s/n RC12161697 per Lycoming SB-621B." Generally, if you are supposed to follow a procedure, you may want to reference it as "per XYZ" or something that shows where you got the guidance. Other than that it's pretty much up to you. I try to include part and serial numbers for anything I can, and if there was a reason why something needed to be done due to wear or damage, I note that. Here's another entry for a while ago: "Replaced Slick Harness M-2961 (Left) with new Aero-Lite Skytronics A18-11AS-II harness (Kelly KA16014) due to loose spring on #5 wire at cap end and blackening of rotor cap on old mag. Replaced AN900-10 gasket on Oil temp housing plug." And another one: "Performed SB 14-8-29 per SB instructions, installing doubler above nose gear elastomers on engine mount." An A&P like Kelly McMullen would probably have good info on a reference to use for examples, and maybe he can comment on if what I've done above is even adequate. I personally don't feel they're too inadequate, but wouldn't mind a second opinion. The important thing is to show what parts went in and out, any relevant info on those parts, and what procedures were done and why, as far as I'm concerned. Then you're doing a good job trying to provide a traceable history of the aircraft and engine. Tim On 4/26/2017 9:04 AM, Phillip Perry wrote: > Does anyone know of a site that has sample language for logbook entries? > For example, I need to add my MT-Prop gov SB entry. I need to show > that I checked AD's for my engine. I need to show that I've started the > conditional inspection... > > I don't have much info on how those entries should be formatted and I'm > hoping there is a site or FAA doc in existence that outlines the format > for those entries. > > I'm a logbook rookie. > > Phil > ________________________________________________________________________________
Subject: RE: SureFly Electronic Ignition
Date: Apr 26, 2017
I'll chime in to say I replaced my right mag with the Surefly unit a couple of weeks ago and am very pleased with the results to date. I left the Slick mag with the retard connection plus SlickStart installed, since it had just been IRAN'd, and removed the grounding jumper on the ignition switch so both sets of plugs would be firing at TDC on startup. So basically it is like having two electronically boosted sparks during the time the starter is cranking. RV-10 now does cold and hot starts in the first turn of the prop; verrry nice. Wish I could have had that for the past ten years! No appreciable rise in CHTs that I can detect, and don't know what it will do to ROP and LOP cruise up high yet, since the Pacific northwest weather has been nonstop scuzzy for the past couple of weeks. I can say that cruising down low, am seeing same indicated airspeed at 18-19 inches MP that I used to see with 21. So maybe a little more spunk also. Will post again when I get some cross country engine monitor recordings and can compare with previous configuration. -Dan Masys N104LD 965 hrs. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV10-List Digest Server Sent: Wednesday, April 26, 2017 12:04 AM Subject: RV10-List Digest: 2 Msgs - 04/25/17 Subject: RV10-List: SureFly Electronic Ignition From: "SureFly" <jason(at)surefly.aero> SureFly is now delivering 6 cylinder experimental ignition units. surely.aero or 817-373-5161 Thanks! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468775#468775 ________________________________________________________________________________
Date: Apr 26, 2017
What is needed is listed in Part 43.9: 1. description of work performed. 2 Date of completion of work 3. Name of person performing the work (if other than the person approving the work) 4. Signature and certificate number of person approving the work. #3 isn't needed for OBAM. #4. no certificate number is needed for OBAM aircraft, although you could put your repairman number. You can put total time, if you choose to track it for maintenance purposes. Additional guidance in AC43.9C Maintenance Records Note that inspection records are a little different in contents and approval. Tim's suggestions are right on track. Including part numbers is excellent. Serial numbers are not so important unless it is major item that you want to track replacement..engine, prop, perhaps major accessories like governor, mags, alternator, starter. It helps if say an AD were to be issued on certain Skytec starters, so you don't have to go find the physical serial number later. On 4/26/2017 8:02 AM, Tim Olson wrote: > > I think for many of them you can just use your best common sense > and try to provide enough detail that someone in the future > could look and understand what was done and why. > > The language for the annual condition inspection is in your > operating limitations and is pretty standard, so that one > is easy, but I don't think there is any need to show > that you've STARTED the inspection, just do an entry when you > are done with it. The start date of an inspection isn't > the relevant date...it's the completed date that matters. > > That log entry usually looks like: "I certify that this > aircraft has been inspected on X/X/2017 in accordance with the > scope and detail of FAR part 43, Appendix D, and was found to > be in the condition for safe operation." > > I personally when doing the ACI, don't log every individual > task, such as "repacked wheel bearings", but only list any > that are significant for some reason. I also log all of > the cylinder compressions for historical reasons. > > Here's an example of what I did for a recent fuel pump > log entry. Someone like Kelly may be able to confirm > if it's adequate. > "Replaced fuel pump model 62B26931 s/n RC4214036826 with > s/n RC12161697 per Lycoming SB-621B." > > Generally, if you are supposed to follow a procedure, you > may want to reference it as "per XYZ" or something that > shows where you got the guidance. Other than that it's > pretty much up to you. I try to include part and serial > numbers for anything I can, and if there was a reason why > something needed to be done due to wear or damage, I note > that. > > Here's another entry for a while ago: > "Replaced Slick Harness M-2961 (Left) with new Aero-Lite Skytronics > A18-11AS-II harness (Kelly KA16014) due to loose spring on #5 wire at > cap end and blackening of rotor cap on old mag. Replaced AN900-10 > gasket on Oil temp housing plug." > > And another one: > "Performed SB 14-8-29 per SB instructions, installing doubler above nose > gear elastomers on engine mount." > > An A&P like Kelly McMullen would probably have good info on > a reference to use for examples, and maybe he can comment > on if what I've done above is even adequate. I personally > don't feel they're too inadequate, but wouldn't mind a > second opinion. > > The important thing is to show what parts went in and out, > any relevant info on those parts, and what procedures were > done and why, as far as I'm concerned. Then you're doing > a good job trying to provide a traceable history of the > aircraft and engine. > > Tim > > > > > On 4/26/2017 9:04 AM, Phillip Perry wrote: >> Does anyone know of a site that has sample language for logbook entries? >> For example, I need to add my MT-Prop gov SB entry. I need to show >> that I checked AD's for my engine. I need to show that I've started the >> conditional inspection... >> >> I don't have much info on how those entries should be formatted and I'm >> hoping there is a site or FAA doc in existence that outlines the format >> for those entries. >> >> I'm a logbook rookie. >> >> Phil >> > > > > ________________________________________________________________________________
Date: Apr 26, 2017
Subject: Chelton white screen
Thought I'd let you guys know the results of my Chelton display problem. I have one screen that comes up with only the background light on; it never boots up. I disassembled it and reseated all the cables and board connectors, but it won't boot. I then swapped individual boards with the display that works and found that the processor module doesn't work. I disassembled it and reseated the board connectors, but it still doesn't work. I sent an email to Robert Durall from Tim's chelton board, but that email was bad. I'd like to find another module or get this one repaired, but don't want to spend too much on it. I've read that Chelton will work on them but charges a flat fee ($4000 - $4500). I don't know if that's correct, but I'd rather buy a new system from another company than spend that much on obsolete equipment. Anybody got any ideas? Thanks, Kevin Belue ________________________________________________________________________________
Subject: Re: Chelton white screen
Date: Apr 26, 2017
Kevin, Robert is still working for Cheltons and they worked over one of mine a year ago for about 1k. I included Roberts last known email address for me in the cc line. They were great about fixing mine. The kicker is the unit has to be shipped back to them from an avionics shop. Give Robert a shout. grumpy > On Apr 26, 2017, at 6:51 PM, Kevin Belue wrote: > > Thought I'd let you guys know the results of my Chelton display problem. I have one screen that comes up with only the background light on; it never boots up. I disassembled it and reseated all the cables and board connectors, but it won't boot. I then swapped individual boards with the display that works and found that the processor module doesn't work. I disassembled it and reseated the board connectors, but it still doesn't work. I sent an email to Robert Durall from Tim's chelton board, but that email was bad. I'd like to find another module or get this one repaired, but don't want to spend too much on it. I've read that Chelton will work on them but charges a flat fee ($4000 - $4500). I don't know if that's correct, but I'd rather buy a new system from another company than spend that much on obsolete equipment. Anybody got any ideas? > > Thanks, > > Kevin Belue ________________________________________________________________________________
From: "Bart van Ruth" <bart.van.ruth(at)upcmail.nl>
Subject: Landing Gear problems
Date: Apr 28, 2017
After a 2 yearlong battle, trying whatever solution I could think of or find on the internet, I surrendered and did the obvious, put some dampers on. It feels strange to land and wait for the big shake, both wheels dancing synchronized back and forward https://youtu.be/p0zAVvPMCIg, and nothing happens. The whole ground operation feels so much better and stable. Two gas springs dampers for less than 120$ did the trick. Stumbled over another method that works 75%, put =BD a gallon of water in the rear compartment of the wheel fairing. Does little for light vibrations but sure does cure the big shakeouts by counter phase movement of the water. All other things such as: tire pressure , balancing, rotating tires, new tires, reinforcement of the legs, adjusting camber- toe angle by elongating cross holes, where tried in every amount and combination with only temporarily small improvements. I still do not understand why the problem did start after two years of flying and not @ the beginning. Somehow over time there was a loss of damping in the system. Now I finally can ship several parts of my avionics that did not survive the shaking for repair and modify the gear leg fairings. Bart PH-USN Sept 12, 350 hours. ________________________________________________________________________________
Subject: Re: Landing Gear problems
Date: Apr 28, 2017
Hey Bart, Nice. Were brakes ruled out as a factor? Warped rotors, dragging pads? Later, =93 Lew From: Bart van Ruth Sent: Friday, April 28, 2017 10:24 AM Subject: RV10-List: Landing Gear problems After a 2 yearlong battle, trying whatever solution I could think of or find on the internet, I surrendered and did the obvious, put some dampers on. It feels strange to land and wait for the big shake, both wheels dancing synchronized back and forward https://youtu.be/p0zAVvPMCIg, and nothing happens. The whole ground operation feels so much better and stable. Two gas springs dampers for less than 120$ did the trick. Stumbled over another method that works 75%, put =C2=BD a gallon of water in the rear compartment of the wheel fairing. Does little for light vibrations but sure does cure the big shakeouts by counter phase movement of the water. All other things such as: tire pressure , balancing, rotating tires, new tires, reinforcement of the legs, adjusting camber- toe angle by elongating cross holes, where tried in every amount and combination with only temporarily small improvements. I still do not understand why the problem did start after two years of flying and not @ the beginning. Somehow over time there was a loss of damping in the system. Now I finally can ship several parts of my avionics that did not survive the shaking for repair and modify the gear leg fairings. Bart PH-USN Sept 12, 350 hours. ________________________________________________________________________________
Date: Apr 28, 2017
Q2FuIHBvc3QgcGljcyBvZiBob3cgeW91IG1vdW50ZWQgdGhlIHNob2Nrcz8gVGhhbmtzIQ0KDQpT ZW50IGZyb20gbXkgaVBob25lDQoNCk9uIEFwciAyOCwgMjAxNywgYXQgMTA6MDIgQU0sICJsZXdn YWxsQGNoYXJ0ZXIubmV0PG1haWx0bzpsZXdnYWxsQGNoYXJ0ZXIubmV0PiIgPGxld2dhbGxAY2hh cnRlci5uZXQ8bWFpbHRvOmxld2dhbGxAY2hhcnRlci5uZXQ+PiB3cm90ZToNCg0KSGV5IEJhcnQs DQoNCk5pY2UuICBXZXJlIGJyYWtlcyBydWxlZCBvdXQgYXMgYSBmYWN0b3I/ICBXYXJwZWQgcm90 b3JzLCBkcmFnZ2luZyBwYWRzPw0KDQpMYXRlciwg4oCTIExldw0KDQpGcm9tOiBCYXJ0IHZhbiBS dXRoPG1haWx0bzpiYXJ0LnZhbi5ydXRoQHVwY21haWwubmw+DQpTZW50OiBGcmlkYXksIEFwcmls IDI4LCAyMDE3IDEwOjI0IEFNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnJ2 MTAtbGlzdEBtYXRyb25pY3MuY29tPg0KU3ViamVjdDogUlYxMC1MaXN0OiBMYW5kaW5nIEdlYXIg cHJvYmxlbXMNCg0KQWZ0ZXIgYSAyIHllYXJsb25nIGJhdHRsZSwgdHJ5aW5nIHdoYXRldmVyIHNv bHV0aW9uICBJIGNvdWxkIHRoaW5rIG9mIG9yIGZpbmQgb24gdGhlIGludGVybmV0LCBJIHN1cnJl bmRlcmVkIGFuZCBkaWQgdGhlIG9idmlvdXMsIHB1dCBzb21lIGRhbXBlcnMgb24uDQpJdCBmZWVs cyBzdHJhbmdlIHRvIGxhbmQgYW5kIHdhaXQgZm9yIHRoZSBiaWcgc2hha2UsIGJvdGggd2hlZWxz IGRhbmNpbmcgc3luY2hyb25pemVkIGJhY2sgYW5kIGZvcndhcmQgaHR0cHM6Ly95b3V0dS5iZS9w MHpBVnZQTUNJZywgYW5kIG5vdGhpbmcgaGFwcGVucy4NClRoZSB3aG9sZSBncm91bmQgb3BlcmF0 aW9uIGZlZWxzIHNvIG11Y2ggYmV0dGVyIGFuZCBzdGFibGUuDQpUd28gZ2FzIHNwcmluZ3MgZGFt cGVycyBmb3IgbGVzcyB0aGFuIDEyMCQgZGlkIHRoZSB0cmljay4NClN0dW1ibGVkIG92ZXIgYW5v dGhlciBtZXRob2QgdGhhdCB3b3JrcyA3NSUsIHB1dCDCvSBhIGdhbGxvbiBvZiB3YXRlciBpbiB0 aGUgcmVhciBjb21wYXJ0bWVudCBvZiB0aGUgd2hlZWwgZmFpcmluZy4NCkRvZXMgbGl0dGxlIGZv ciBsaWdodCB2aWJyYXRpb25zIGJ1dCBzdXJlIGRvZXMgY3VyZSB0aGUgYmlnIHNoYWtlb3V0cyBi eSBjb3VudGVyIHBoYXNlIG1vdmVtZW50IG9mIHRoZSB3YXRlci4NCkFsbCBvdGhlciB0aGluZ3Mg c3VjaCBhczogdGlyZSBwcmVzc3VyZSAsIGJhbGFuY2luZywgcm90YXRpbmcgdGlyZXMsIG5ldyB0 aXJlcywgcmVpbmZvcmNlbWVudCBvZiB0aGUgbGVncywgYWRqdXN0aW5nIGNhbWJlci0gdG9lIGFu Z2xlIGJ5IGVsb25nYXRpbmcgY3Jvc3MgaG9sZXMsICB3aGVyZSB0cmllZCBpbiBldmVyeSBhbW91 bnQgYW5kIGNvbWJpbmF0aW9uIHdpdGggb25seSB0ZW1wb3JhcmlseSBzbWFsbCBpbXByb3ZlbWVu dHMuDQpJIHN0aWxsIGRvIG5vdCB1bmRlcnN0YW5kIHdoeSB0aGUgcHJvYmxlbSBkaWQgc3RhcnQg IGFmdGVyIHR3byB5ZWFycyBvZiBmbHlpbmcgYW5kIG5vdCBAIHRoZSBiZWdpbm5pbmcuDQpTb21l aG93IG92ZXIgdGltZSB0aGVyZSB3YXMgYSBsb3NzIG9mIGRhbXBpbmcgaW4gdGhlIHN5c3RlbS4N Ck5vdyBJIGZpbmFsbHkgY2FuIHNoaXAgc2V2ZXJhbCBwYXJ0cyBvZiBteSBhdmlvbmljcyB0aGF0 IGRpZCBub3Qgc3Vydml2ZSB0aGUgc2hha2luZyBmb3IgcmVwYWlyIGFuZCBtb2RpZnkgdGhlIGdl YXIgbGVnIGZhaXJpbmdzLg0KDQpCYXJ0DQpQSC1VU04gU2VwdCAxMiwgMzUwIGhvdXJzLg0KDQoN Cg= ________________________________________________________________________________
Date: Apr 28, 2017
Looks like they are mounted to damp up and down motion. I always thought the shimmy motion was fore and aft. -sent from the I-droid implanted in my forearm On Fri, Apr 28, 2017 at 9:56 AM, Danny Riggs wrote: > Can post pics of how you mounted the shocks? Thanks! > > Sent from my iPhone > > On Apr 28, 2017, at 10:02 AM, "lewgall(at)charter.net" > wrote: > > Hey Bart, > > Nice. Were brakes ruled out as a factor? Warped rotors, dragging pads? > > Later, =93 Lew > > *From:* Bart van Ruth > *Sent:* Friday, April 28, 2017 10:24 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Landing Gear problems > > > After a 2 yearlong battle, trying whatever solution I could think of or > find on the internet, I surrendered and did the obvious, put some dampers > on. > > It feels strange to land and wait for the big shake, both wheels dancing > synchronized back and forward https://youtu.be/p0zAVvPMCIg, and nothing > happens. > > The whole ground operation feels so much better and stable. > > Two gas springs dampers for less than 120$ did the trick. > > Stumbled over another method that works 75%, put =C2=BD a gallon of water in > the rear compartment of the wheel fairing. > > Does little for light vibrations but sure does cure the big shakeouts by > counter phase movement of the water. > > All other things such as: tire pressure , balancing, rotating tires, new > tires, reinforcement of the legs, adjusting camber- toe angle by elongati ng > cross holes, where tried in every amount and combination with only > temporarily small improvements. > > I still do not understand why the problem did start after two years of > flying and not @ the beginning. > > Somehow over time there was a loss of damping in the system. > > Now I finally can ship several parts of my avionics that did not survive > the shaking for repair and modify the gear leg fairings. > > > Bart > > PH-USN Sept 12, 350 hours. > > ________________________________________________________________________________
Subject: Re: SureFly Electronic Ignition
Date: Apr 30, 2017
I am a beta tester for SureFly and do not work for them. I installed one of their first units a little over a year ago in my RV-10 and have about 120 hours on it. It ran in parallel with a Slick mag in a configuration similar to my RV-6 which had an Electro Air electronic ignition and a mag. The unit runs well and I don't have to think about it. No change was noted in CHTs. I can aggressively lean it, more so than with 2 mags, and it continues to run smoothly until a noticeable roughness. No change was noted in starting - it was just as easy as with the 2 mags and Slick Start. I wish I had better data on fuel flows from before the switch because my experience is only qualitative. It is very difficult to compare performance without hard data. I always run lean of peak in cruise and with the mags I found that I needed to bump it a little richer from the point where the average EGT showed a 25 degree drop. With the electronic ignition it runs smoother at that point. I am now running with 2 of the SureFly units and it appears to run even smoother under aggressive leaning. This is noticeable during taxi (where I lean a lot) and in flight where it runs nicely at 25 degrees lean of peak. I have limited time with the 2 units installed. -------- Dave Moore RV-6 flying RV-10 QB - flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468894#468894 ________________________________________________________________________________
Subject: Seat Upholstery
Date: May 01, 2017
I don't ever remember seeing a discussion on upholstery. What are the pros and cons of fabric vs. leather? I hope I don't start and upholstery war. :-) Dave Fritzsche ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: May 01, 2017
Subject: Re: Seat Upholstery
Pros and cons either way. I owned one car with leather and swore I'd never do that again. I got cloth seats from DJ at Cleaveland Tool. The RV-8A seats are 15 years old and look like the day I put them in. The RV-10 seats (also cloth from DJ) are now 5 years old and still look new. So - decide what you want under your butt and build on. Carl > On May 1, 2017, at 6:56 PM, David J. Fritzsche wrote: > > > I don't ever remember seeing a discussion on upholstery. What are the pros and cons of fabric vs. leather? I hope I don't start and upholstery war. :-) > > Dave Fritzsche > > > > > ________________________________________________________________________________
Date: May 01, 2017
I've never met a man who said, "My airplane is too light!" I weighed mine and it slunk down in my chair. That being said, I'm going to press on with leather but modifying my plans a bit. I was planning on covering the baggage bulkhead with leather, now I'm not. My rear seat is a bench and it's heavy! It's designed to be a 60/40 split and I've secured it together as a single bench. Now I'm going to undo that 100% bench in favor of 60/40, so I can occasionally save weight by keeping one seat in and pulling the other if needed. The 60 and 40 will be covered in leather eventually. (Right now they just have a throw cover in them until I can start the upholstery phase full/on.) However I still have materials for Vans stock rear seats standing in a corner. I'm going to go ahead and build them with minimal foam and fabric. They will be my ultra light weight rear seats. Every seat I have has confor foam. Looking back on it, I wish I hadn't used it exclusively and used other lighter foams with it. (I still might). It's comfortable and heavy! I think there is more to be gained in thinking through the foam than thinking through the covering material. You can very quickly drop 3-5 lbs per seat by being smart with your foam selection and that opens the door to being able to use leather with a tad-less guilt. Phil Sent from my iPhone > On May 1, 2017, at 5:56 PM, David J. Fritzsche wrote: > > > I don't ever remember seeing a discussion on upholstery. What are the pros and cons of fabric vs. leather? I hope I don't start and upholstery war. :-) > > Dave Fritzsche > > > > > ________________________________________________________________________________
Date: May 01, 2017
I'm the opposite. I had only had cloth seats and sofas for my whole life. I figured that's what I wanted when doing my -10. Then I got a truck and a car with leather and a couch with leather, and after that I decided I think I'm for leather forever. My -10 seats are vinyl with cloth centers, my RV14 seats are all leather. I prefer the leather now. That said, when you fly an RV10 you will end up happy no matter what because hey, you're flying an RV10. So I would just pick whatever your gut tells you and move on. Both of mine are from Flightline interiors and holding up great. Tim > On May 1, 2017, at 6:15 PM, Carl Froehlich wrote: > > > Pros and cons either way. > > I owned one car with leather and swore I'd never do that again. I got cloth seats from DJ at Cleaveland Tool. The RV-8A seats are 15 years old and look like the day I put them in. The RV-10 seats (also cloth from DJ) are now 5 years old and still look new. > > So - decide what you want under your butt and build on. > > Carl > >> On May 1, 2017, at 6:56 PM, David J. Fritzsche wrote: >> >> >> I don't ever remember seeing a discussion on upholstery. What are the pros and cons of fabric vs. leather? I hope I don't start and upholstery war. :-) >> >> Dave Fritzsche >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: May 01, 2017
I don't think seat weight is a big deal. Is your plane really going to be significantly faster or climb better if it weighs 1590 vs 1640? Only if your butt comes in at 160-170. As well as all your pax and you don't carry baggage. Your typical useful load is going to be between 1050 and 1100 unless you really load up on accessories. Minus 360 for full fuel gives you around 710-760 for bodies, souls and baggage. So either fuel or baggage has to give to stay within 2700 at 4 FAA SOB. For extra performance you need at least one of the rear seats empty, and the front seat occupants to total well under 400. Of course you can certify it with higher gross wt. but that also cuts into performance. But expecting that saving 30-50 lbs in the airframe is going to do much if you are loading up near gross anyway....whatever is left, the family will consume whatever you saved. If you use it as a 2 place plane, the weight won't matter. On 5/1/2017 4:36 PM, Tim Olson wrote: > > I'm the opposite. I had only had cloth seats and sofas for my whole life. I figured that's what I wanted when doing my -10. Then I got a truck and a car with leather and a couch with leather, and after that I decided I think I'm for leather forever. My -10 seats are vinyl with cloth centers, my RV14 seats are all leather. I prefer the leather now. > That said, when you fly an RV10 you will end up happy no matter what because hey, you're flying an RV10. > So I would just pick whatever your gut tells you and move on. Both of mine are from Flightline interiors and holding up great. > Tim > >> On May 1, 2017, at 6:15 PM, Carl Froehlich wrote: >> >> >> Pros and cons either way. >> >> I owned one car with leather and swore I'd never do that again. I got cloth seats from DJ at Cleaveland Tool. The RV-8A seats are 15 years old and look like the day I put them in. The RV-10 seats (also cloth from DJ) are now 5 years old and still look new. >> >> So - decide what you want under your butt and build on. >> >> Carl >> >>> On May 1, 2017, at 6:56 PM, David J. Fritzsche wrote: >>> >>> >>> I don't ever remember seeing a discussion on upholstery. What are the pros and cons of fabric vs. leather? I hope I don't start and upholstery war. :-) >>> >>> Dave Fritzsche >>> >>> >>> >>> >>> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: May 01, 2017
I suggested cloth; the boss said leather. We have leather. I think either choice would be fine. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468914#468914 ________________________________________________________________________________
Subject: Click Bond Cable Ties
Date: May 03, 2017
There are click bond cable tie on an aluminum mount for sale on a popular auction site. 20 for $20. I offered and paid $15 including shipping. They are $2 each from the Flight Shop + Shipping Larry Hope this does not violate the list rules. -------- Larry Rosen #40356 N205EN (reserved) <http> Read this topic online here: http://forums.matronics.com/viewtopic.php?p=468942#468942 ________________________________________________________________________________
Date: May 03, 2017
Subject: cowl heat
just recently discovered (1200TT) that the lower cowl has three areas of delaminated fiberglass. Preparing for the repair I found a thin honeycomb and reportedly 5 layers of glass. The areas of delamination seemed to be directly below the three in one connection to the heat muff and the exhaust tube of #6. Has anyone else experienced this problem? possibly the higher temperatures of the Southwestern USA are to blame. I have been opening the oil door after each landing to keep the under cowl temperatures under control. ________________________________________________________________________________
Date: May 03, 2017
Subject: Re: cowl heat
I have seen this on a number of planes that do not have heat shield in those areas. The inside of the cowl turns brown, then black, then starts to delaminate on the inside, then starts to delaminate on the outside. I have seen all stages of this. Remove the delaminates part, lay up new glass to cover that area with an overlap of the surrounding areas, then add heat shield after it cures. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On May 3, 2017, at 9:57 PM, dlm wrote: > > just recently discovered (1200TT) that the lower cowl has three areas of delaminated > fiberglass. Preparing for the repair I found a thin honeycomb and reportedly 5 layers of glass. > The areas of delamination seemed to be directly below the three in one connection to the heat muff and the exhaust tube of #6. Has anyone else experienced this problem? possibly the higher temperatures of the Southwestern USA are to blame. I have been opening the oil door after each landing to keep the under cowl temperatures under control. > ________________________________________________________________________________
Date: May 04, 2017
Jesse, should this be stick-on reflective foil or does it need some backing layer or a stand-off air gap to be effective? -Bill On Wed, May 3, 2017 at 10:13 PM, Jesse Saint wrote: > > I have seen this on a number of planes that do not have heat shield in > those areas. The inside of the cowl turns brown, then black, then starts to > delaminate on the inside, then starts to delaminate on the outside. I have > seen all stages of this. Remove the delaminates part, lay up new glass to > cover that area with an overlap of the surrounding areas, then add heat > shield after it cures. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > > On May 3, 2017, at 9:57 PM, dlm wrote: > > > > just recently discovered (1200TT) that the lower cowl has three areas of > delaminated > > fiberglass. Preparing for the repair I found a thin honeycomb and > reportedly 5 layers of glass. > > The areas of delamination seemed to be directly below the three in one > connection to the heat muff and the exhaust tube of #6. Has anyone else > experienced this problem? possibly the higher temperatures of the > Southwestern USA are to blame. I have been opening the oil door after each > landing to keep the under cowl temperatures under control. > > > > ________________________________________________________________________________
Date: May 04, 2017
I experienced the burn problem. Once repaired, I used Thermo-Guard FR There is a reflective layer and some kind of insulating padding (air gap). There have been no signs of further damage several hundred hours later. In my unqualified opinion, I beleive that a reflective only shield would work fine. But I have no experience to bear that out. Bill On 5/4/2017 9:34 AM, Bill Boyd wrote: > Jesse, should this be stick-on reflective foil or does it need some > backing layer or a stand-off air gap to be effective? > > -Bill > > On Wed, May 3, 2017 at 10:13 PM, Jesse Saint > wrote: > > > > > I have seen this on a number of planes that do not have heat > shield in those areas. The inside of the cowl turns brown, then > black, then starts to delaminate on the inside, then starts to > delaminate on the outside. I have seen all stages of this. Remove > the delaminates part, lay up new glass to cover that area with an > overlap of the surrounding areas, then add heat shield after it cures. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > > On May 3, 2017, at 9:57 PM, dlm > wrote: > > > > just recently discovered (1200TT) that the lower cowl has three > areas of delaminated > > fiberglass. Preparing for the repair I found a thin honeycomb > and reportedly 5 layers of glass. > > The areas of delamination seemed to be directly below the three > in one connection to the heat muff and the exhaust tube of #6. Has > anyone else experienced this problem? possibly the higher > temperatures of the Southwestern USA are to blame. I have been > opening the oil door after each landing to keep the under cowl > temperatures under control. > > > > > =================================== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: May 04, 2017
The stick-on reflective foil is sufficient to prevent the delamination. Other types of material may protect the fiberglass better, but I can =99t speak to that. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 > On May 4, 2017, at 9:34 AM, Bill Boyd wrote: > > Jesse, should this be stick-on reflective foil or does it need some backing layer or a stand-off air gap to be effective? > > -Bill > > On Wed, May 3, 2017 at 10:13 PM, Jesse Saint > wrote: > > > I have seen this on a number of planes that do not have heat shield in those areas. The inside of the cowl turns brown, then black, then starts to delaminate on the inside, then starts to delaminate on the outside. I have seen all stages of this. Remove the delaminates part, lay up new glass to cover that area with an overlap of the surrounding areas, then add heat shield after it cures. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > > On May 3, 2017, at 9:57 PM, dlm > wrote: > > > > just recently discovered (1200TT) that the lower cowl has three areas of delaminated > > fiberglass. Preparing for the repair I found a thin honeycomb and reportedly 5 layers of glass. > > The areas of delamination seemed to be directly below the three in one connection to the heat muff and the exhaust tube of #6. Has anyone else experienced this problem? possibly the higher temperatures of the Southwestern USA are to blame. I have been opening the oil door after each landing to keep the under cowl temperatures under control. > > > > > ======================== =========== > -List" rel="noreferrer" target="_blank">http://www.matronics.com/ <http://www.matronics.com/Navigator?RV10-List>Navigator?RV10-List <http://www.matronics.com/Navigator?RV10-List> > ======================== =========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com <http://forums.matronics.com/> > ======================== =========== > WIKI - > errer" target="_blank">http://wiki.matronics.com <http://wiki.matronics.com/> > ======================== =========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/ <http://www.matronics.com/contribution>contribution <http://www.matronics.com/contribution> > ======================== =========== ________________________________________________________________________________
Date: May 04, 2017
I've had no issues with just reflective stick-on foil. If you can do that all over and add a patch with the insulated backing near the very closest areas, you would maybe even be better off, but I have no complaints with what I have. Tim On 5/4/2017 11:23 AM, Bill Watson wrote: > I experienced the burn problem. Once repaired, I used Thermo-Guard FR > > There is a reflective layer and some kind of insulating padding (air > gap). There have been no signs of further damage several hundred hours > later. > > In my unqualified opinion, I beleive that a reflective only shield would > work fine. But I have no experience to bear that out. > > Bill > On 5/4/2017 9:34 AM, Bill Boyd wrote: >> Jesse, should this be stick-on reflective foil or does it need some >> backing layer or a stand-off air gap to be effective? >> >> -Bill >> ________________________________________________________________________________
Date: May 04, 2017
I have the adhesive backed aluminum foil on the lower cowl. 400 hrs and no t rouble with delamination or any other heat related defects. It was easy a nd effective. Bob Newman TCW Technologies, LLC 610-928-3420 > On May 4, 2017, at 12:40 PM, Jesse Saint wrote: > > The stick-on reflective foil is sufficient to prevent the delamination. Ot her types of material may protect the fiberglass better, but I can=99t speak to that. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > >> On May 4, 2017, at 9:34 AM, Bill Boyd wrote: >> >> Jesse, should this be stick-on reflective foil or does it need some backi ng layer or a stand-off air gap to be effective? >> >> -Bill >> >>> On Wed, May 3, 2017 at 10:13 PM, Jesse Saint w rote: >>> >>> I have seen this on a number of planes that do not have heat shield in t hose areas. The inside of the cowl turns brown, then black, then starts to d elaminate on the inside, then starts to delaminate on the outside. I have se en all stages of this. Remove the delaminates part, lay up new glass to cove r that area with an overlap of the surrounding areas, then add heat shield a fter it cures. >>> >>> Jesse Saint >>> Saint Aviation, Inc. >>> 352-427-0285 >>> jesse(at)saintaviation.com >>> >>> Sent from my iPad >>> >>> > On May 3, 2017, at 9:57 PM, dlm wrote: >>> > >>> > just recently discovered (1200TT) that the lower cowl has three areas o f delaminated >>> > fiberglass. Preparing for the repair I found a thin honeycomb and repo rtedly 5 layers of glass. >>> > The areas of delamination seemed to be directly below the three in on e connection to the heat muff and the exhaust tube of #6. Has anyone else ex perienced this problem? possibly the higher temperatures of the Southwestern USA are to blame. I have been opening the oil door after each landing to ke ep the under cowl temperatures under control. >>> > >>> >>> >>> ======================== =========== >>> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Nav igator?RV10-List >>> ======================== =========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ======================== =========== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> ======================== =========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contributi on >>> ======================== =========== > ________________________________________________________________________________
Date: May 04, 2017
How did you finish the interior of your cowl before applying foil? On Thu, May 4, 2017 at 1:19 PM, Tcwtech wrote: > I have the adhesive backed aluminum foil on the lower cowl. 400 hrs and > no trouble with delamination or any other heat related defects. It was > easy and effective. > > Bob Newman > TCW Technologies, LLC > 610-928-3420 <(610)%20928-3420> > > On May 4, 2017, at 12:40 PM, Jesse Saint wrote: > > The stick-on reflective foil is sufficient to prevent the delamination. > Other types of material may protect the fiberglass better, but I can =99t > speak to that. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 <(352)%20427-0285> > F: 815-377-3694 <(815)%20377-3694> > > On May 4, 2017, at 9:34 AM, Bill Boyd wrote: > > Jesse, should this be stick-on reflective foil or does it need some > backing layer or a stand-off air gap to be effective? > > -Bill > > On Wed, May 3, 2017 at 10:13 PM, Jesse Saint > wrote: > >> >> I have seen this on a number of planes that do not have heat shield in >> those areas. The inside of the cowl turns brown, then black, then starts to >> delaminate on the inside, then starts to delaminate on the outside. I ha ve >> seen all stages of this. Remove the delaminates part, lay up new glass t o >> cover that area with an overlap of the surrounding areas, then add heat >> shield after it cures. >> >> Jesse Saint >> Saint Aviation, Inc. >> 352-427-0285 >> jesse(at)saintaviation.com >> >> Sent from my iPad >> >> > On May 3, 2017, at 9:57 PM, dlm wrote: >> > >> > just recently discovered (1200TT) that the lower cowl has three areas >> of delaminated >> > fiberglass. Preparing for the repair I found a thin honeycomb and >> reportedly 5 layers of glass. >> > The areas of delamination seemed to be directly below the three in on e >> connection to the heat muff and the exhaust tube of #6. Has anyone else >> experienced this problem? possibly the higher temperatures of the >> Southwestern USA are to blame. I have been opening the oil door after ea ch >> landing to keep the under cowl temperatures under control. >> > >> >> >> ======================== =========== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/ >> <http://www.matronics.com/Navigator?RV10-List>Navigator?RV10-List >> <http://www.matronics.com/Navigator?RV10-List> >> ======================== =========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ======================== =========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ======================== =========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/ >> <http://www.matronics.com/contribution>contribution >> <http://www.matronics.com/contribution> >> ======================== =========== > > ________________________________________________________________________________
Subject: cowl heat
Date: May 04, 2017
Same here. >650 hrs. Rene' 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tcwtech Sent: Thursday, May 04, 2017 11:19 AM Subject: Re: RV10-List: cowl heat I have the adhesive backed aluminum foil on the lower cowl. 400 hrs and no trouble with delamination or any other heat related defects. It was easy and effective. Bob Newman TCW Technologies, LLC 610-928-3420 On May 4, 2017, at 12:40 PM, Jesse Saint > wrote: The stick-on reflective foil is sufficient to prevent the delamination. Other types of material may protect the fiberglass better, but I can=99t speak to that. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On May 4, 2017, at 9:34 AM, Bill Boyd > wrote: Jesse, should this be stick-on reflective foil or does it need some backing layer or a stand-off air gap to be effective? -Bill On Wed, May 3, 2017 at 10:13 PM, Jesse Saint > wrote: > I have seen this on a number of planes that do not have heat shield in those areas. The inside of the cowl turns brown, then black, then starts to delaminate on the inside, then starts to delaminate on the outside. I have seen all stages of this. Remove the delaminates part, lay up new glass to cover that area with an overlap of the surrounding areas, then add heat shield after it cures. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On May 3, 2017, at 9:57 PM, dlm > wrote: > > just recently discovered (1200TT) that the lower cowl has three areas of delaminated > fiberglass. Preparing for the repair I found a thin honeycomb and reportedly 5 layers of glass. > The areas of delamination seemed to be directly below the three in one connection to the heat muff and the exhaust tube of #6. Has anyone else experienced this problem? possibly the higher temperatures of the Southwestern USA are to blame. I have been opening the oil door after each landing to keep the under cowl temperatures under control. > -List" rel="noreferrer" target="_blank">http://www.matronics.com/ <http://www.matronics.com/Navigator?RV10-List> Navigator?RV10-List <http://www.matronics.com/Navigator?RV10-List> FORUMS - eferrer" target="_blank">http://forums.matronics.com <http://forums.matronics.com/> WIKI - errer" target="_blank">http://wiki.matronics.com <http://wiki.matronics.com/> b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/ <http://www.matronics.com/contribution> contribution <http://www.matronics.com/contribution> ________________________________________________________________________________
Subject: cowl heat
Date: May 04, 2017
Several coats of thinned epoxy. Degreaser at the end. Rene' 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Greenley Sent: Thursday, May 04, 2017 11:29 AM Subject: Re: RV10-List: cowl heat How did you finish the interior of your cowl before applying foil? On Thu, May 4, 2017 at 1:19 PM, Tcwtech > wrote: I have the adhesive backed aluminum foil on the lower cowl. 400 hrs and no trouble with delamination or any other heat related defects. It was easy and effective. Bob Newman TCW Technologies, LLC 610-928-3420 On May 4, 2017, at 12:40 PM, Jesse Saint > wrote: The stick-on reflective foil is sufficient to prevent the delamination. Other types of material may protect the fiberglass better, but I can=99t speak to that. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On May 4, 2017, at 9:34 AM, Bill Boyd > wrote: Jesse, should this be stick-on reflective foil or does it need some backing layer or a stand-off air gap to be effective? -Bill On Wed, May 3, 2017 at 10:13 PM, Jesse Saint > wrote: > I have seen this on a number of planes that do not have heat shield in those areas. The inside of the cowl turns brown, then black, then starts to delaminate on the inside, then starts to delaminate on the outside. I have seen all stages of this. Remove the delaminates part, lay up new glass to cover that area with an overlap of the surrounding areas, then add heat shield after it cures. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On May 3, 2017, at 9:57 PM, dlm > wrote: > > just recently discovered (1200TT) that the lower cowl has three areas of delaminated > fiberglass. Preparing for the repair I found a thin honeycomb and reportedly 5 layers of glass. > The areas of delamination seemed to be directly below the three in one connection to the heat muff and the exhaust tube of #6. Has anyone else experienced this problem? possibly the higher temperatures of the Southwestern USA are to blame. I have been opening the oil door after each landing to keep the under cowl temperatures under control. > -List" rel="noreferrer" target="_blank">http://www.matronics.com/ <http://www.matronics.com/Navigator?RV10-List> Navigator?RV10-List <http://www.matronics.com/Navigator?RV10-List> FORUMS - eferrer" target="_blank">http://forums.matronics.com <http://forums.matronics.com/> WIKI - errer" target="_blank">http://wiki.matronics.com <http://wiki.matronics.com/> b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/ <http://www.matronics.com/contribution> contribution <http://www.matronics.com/contribution> ________________________________________________________________________________
Date: May 04, 2017
A coat of thinned epoxy and then I actually just had my painter shoot a coat of white inside the whole cowl. That way any area that didn=99t get foil would still look nice and clean up easily. Works as anticipated. -Bob From: William Greenley Sent: Thursday, May 04, 2017 1:28 PM Subject: Re: RV10-List: cowl heat How did you finish the interior of your cowl before applying foil? On Thu, May 4, 2017 at 1:19 PM, Tcwtech wrote: I have the adhesive backed aluminum foil on the lower cowl. 400 hrs and no trouble with delamination or any other heat related defects. It was easy and effective. Bob Newman TCW Technologies, LLC 610-928-3420 On May 4, 2017, at 12:40 PM, Jesse Saint wrote: The stick-on reflective foil is sufficient to prevent the delamination. Other types of material may protect the fiberglass better, but I can=99t speak to that. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On May 4, 2017, at 9:34 AM, Bill Boyd wrote: Jesse, should this be stick-on reflective foil or does it need some backing layer or a stand-off air gap to be effective? -Bill On Wed, May 3, 2017 at 10:13 PM, Jesse Saint wrote: I have seen this on a number of planes that do not have heat shield in those areas. The inside of the cowl turns brown, then black, then starts to delaminate on the inside, then starts to delaminate on the outside. I have seen all stages of this. Remove the delaminates part, lay up new glass to cover that area with an overlap of the surrounding areas, then add heat shield after it cures. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On May 3, 2017, at 9:57 PM, dlm wrote: > > just recently discovered (1200TT) that the lower cowl has three areas of delaminated > fiberglass. Preparing for the repair I found a thin honeycomb and reportedly 5 layers of glass. > The areas of delamination seemed to be directly below the three in one connection to the heat muff and the exhaust tube of #6. Has anyone else experienced this problem? possibly the higher temperatures of the Southwestern USA are to blame. I have been opening the oil door after each landing to keep the under cowl temperatures under control. > -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: =?UTF-8?B?UmU6IFJWMTAtTGlzdDogMjAxNyBBaXJWZW50dXJlIFJWLTEwIERpbm5lci9T?=
=?UTF-8?B?b2NpYWw=?
Date: May 06, 2017
CkhpLApFeHBlY3QgdHdvIGZyb20gQXVzdHJhbGlhIHRvIEpvaW4uIEFuZHJldyBMb25nIGFuZCBQ YXVsIE1jVml0dHkuClRoYW5rcyBmb3IgdGhlIGVmZm9ydHMuCkFuZHJldy4KCk9uIDI2LUFwci0x NyAzOjQ4IEFNLCBiY29uZHJleSB3cm90ZToKPmFzIG9mIG5vdyB0aGVyZSBpc24ndCBtdWNoIG1v cmUga25vd24uIElmIHlvdSBhcmUgcGxhbm5pbmcgdG8gYXR0ZW5kIEknZCBhcHByZWNpYXRlIGEg aGVhZHMgdXAgc28gd2UgaGF2ZSBzb21lIGlkZWEgb2YgaGVhZCBjb3VudC4gCg= ________________________________________________________________________________
Subject: Lord Adhesive Applicator Gun
Date: May 07, 2017
About to install my windows. Anyone interested in lending, renting or selling their lord adhesive applicator gun? N205EN at gmail -------- Larry Rosen #40356 N205EN (reserved) <http> Read this topic online here: http://forums.matronics.com/viewtopic.php?p=469081#469081 ________________________________________________________________________________
Date: May 07, 2017
Subject: Re: Lord Adhesive Applicator Gun
Larry, I can lend you mine. Just send me your address. -Mike Gregory On Sun, May 7, 2017 at 8:57 AM, LarryRosen wrote: > > About to install my windows. Anyone interested in lending, renting or > selling their lord adhesive applicator gun? N205EN at gmail > > -------- > Larry Rosen > #40356 > N205EN (reserved) > <http> > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=469081#469081 > > ________________________________________________________________________________
Subject: GDU-460 display unit Test
Date: May 07, 2017
Question for those RV-10'ers who have installed Garmin G3X I've been installing a G3X system in an RV-10. Back in 2016 I bought everything except the display units, and have been installing all the boxes and circuits. The installation is not yet completed, I still have some engine sensors to be connected (CHT's and EGT's), but I already completed the CAN Bus and all RS-232 connections. Last week I bought one display unit (GDU-460), which arrived yesterday, and you know how "boys and their toys" are: I immediately made some connections to test the Display unit in the system. When I turned the unit On, I only got Map and Charts information. I was not able to see any Engine Information page in the display unit, nor any Flight Instruments information or Attitude page, or any Auto-pilot information. So the question is: * Why am I not getting the Engine page, or the Attitude page in the display unit? Could it be because the CAN Bus is open in the second Display unit? (Remember, I still don't have the second display unit) Could it be because the Roll servo (which is installed in the Right wing) is still disconnected? (I still don't have the wings installed in the fuselage) Could it be because some Engine sensors are still not connected to the GEA-24? Could it be for any other reason? Best Carlos ________________________________________________________________________________
Date: May 07, 2017
You have a lot of work to do.you need to read the manual and go through all the setup/configurations whilst ensuring everything is properly connected. There are lots of reasons you might not be seeing things from configuration settings to not having stuff hooked up (that is a must before you start messing around with settings), etc.. If your dealer is experienced with G3X installs they should be able to walk you through it easily! Cheers, Stein From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Sunday, May 07, 2017 5:11 PM Subject: RV10-List: GDU-460 display unit Test Question for those RV-10'ers who have installed Garmin G3X I've been installing a G3X system in an RV-10. Back in 2016 I bought everything except the display units, and have been installing all the boxes and circuits. The installation is not yet completed, I still have some engine sensors to be connected (CHT's and EGT's), but I already completed the CAN Bus and all RS-232 connections. Last week I bought one display unit (GDU-460), which arrived yesterday, and you know how "boys and their toys" are: I immediately made some connections to test the Display unit in the system. When I turned the unit On, I only got Map and Charts information. I was not able to see any Engine Information page in the display unit, nor any Flight Instruments information or Attitude page, or any Auto-pilot information. So the question is: * Why am I not getting the Engine page, or the Attitude page in the display unit? Could it be because the CAN Bus is open in the second Display unit? (Remember, I still don't have the second display unit) Could it be because the Roll servo (which is installed in the Right wing) is still disconnected? (I still don't have the wings installed in the fuselage) Could it be because some Engine sensors are still not connected to the GEA-24? Could it be for any other reason? Best Carlos ________________________________________________________________________________
Date: May 09, 2017
Subject: It's ready...
Yesterday Vic Syracuse made the trip to Texas and performed my inspection. It all went well and there were no surprises. The best part of the project is knowing that it went soup to nuts with the original wife... [image: Inline image 1] ________________________________________________________________________________
Date: May 09, 2017
Subject: Re: It's ready...
Congrats. =C2-Where bouts in Texas? =C2-Look forward to another 10 flyi ng in our state. =C2-We have 5 here at Pecan Plantation, 0TX1.Don McDonal d40636 =C2-900+ hours From: Phillip Perry <philperry9(at)gmail.com> To: "rv10-list(at)matronics.com" Sent: Tuesday, May 9, 2017 6:35 AM Subject: RV10-List: It's ready... Yesterday Vic Syracuse made the trip to Texas and performed my inspection. =C2- It all went well and there were no surprises. =C2-=C2- The best part of the project is knowing that it went soup to nuts with the original wife... iVBORw0KGgoAAAANSUhEUgAAA70AAALKCAYAAAD+jTZhAAAgAElEQVR4AVy9ybIuWXag5ac/53bR Z0ZkVylSQoUoSmZlxqSMCYYZTMAM3oYHYMgbFDNGDMBqUhMwGFAT0EA0ZZkSqZIqlMqMzIjIG7c9 fcf3fcv93Kvy//zH3fdee/Vr7cabf+ef/uM/vF9ubpdlZ2e521mW+/v7ZWd/b7m9u13ubil3u1uW vd3d5ebubrm+uV7u7oG9u1+ur26Aued7t+zcL8vu3h5oOOdzL76b++WeNofHR8vjk+PlCLx393fL /u7OAroFcuw5gOYd34P9fdqLe21/D31gY4Gy3b19YKkHB+RsthxKExz38LpnW3Hd3Sx7B3vxfH+z LLeUCb/DRxnFD2jb7s7uskv5LWXS2kUuIeVLXdxRryxQW26Rc/jfW44ODpYraF7eXi37wKQHcQBT O46DB98NcB3vUg/u5R6ZKY8m50fwepgMy/Lxb26W/+6//a+Wn/3kcPnqL/5qufjqZvnxf/DHy8Gf /mBZfvTBcv/FR8vt0QmtDuBIvvwi5PIBR9QvV3z/bjk4/XJZ/vzfLDe/+HrZf7ZH9eHyv/yr58t/ 8V//i+Xf+enny+Wbc1lYMBH620mX8r2LrOpz9xC98lFX++j4+GB/2eW77GInzveQWZvfI+8udlWh N+qCtm7i3Nvdp15/wI7KLKucaeMd9aodV/o4yrKzN21vs4GwNsEW7OUD0tG5B3c4OK29KuWjbbS/ NlW46oSZZsl1K4y41DfmkH/p3ktTXuBtF/ywOTiB1e/1gfH/1ZaU8bdcXF4uV1dX48dya1Nl4UD5 RbvndxMfmLxRmjC4B60T4uMA3e6jRzxpeKG9OvQjX8LGEbvRH3yKlPLbG22wCy7i9vZm5LYZsHfE cU05Ty+VixB0MLezxs/1zU2229nD5uYDNuPZELylTv+9ur7ue30NDfkEsXZ0S96OQYxu9Y0HwkBb b1FlKqnDsMD3Cm+ZSmUT/v1Nv7RGPt7Hpak22NHRiEZh/ElPfw4bx7G1Ig6P9ZzXljYej0xxO7SA cQvHCmOJvpY81lkuM+lltSH15h43fWqf/HVwsLscHR0uj46Pi6MDbY4dUftyvHe0nBzsLI/2rpZP nz5enh0dLJ8+WpYff/bh8uTwAP+/hc7dtMVfjJ9b4wudqZ83by6XlwT0//f1y+UXv3qx3IP77dX9 8ubyGt9V9p3lGv0J75msXeM75UcMZv1ogLwA3qsr2l1fLZfY/5o21iVzEukfm8/hY5Rlh8RFGPDp GbC1qYgzKKgi8KxqwbdwMMEpNQaODg/5HqArchD+p1wH+8iODY0P2xlvN+giOdCBnE+2mryt/eyf kBTE4AHHjsEOnPFoRtHem7+M/4w+zHVELjoBPlj9DhroPSb5p97t89y0694O+Y8t2ZBb398Fv/oS 3wFx+Ya+8j//2afLf/YnP1jevny5vH5zgW6vl08fP1m+eHa4fPLRyfL9H/xg2f3B95bl86fL/T/8 bLn9+COpLXu/+XZZ/vXvluXLb5fbr75dfvXb3y3fnb9d7nY/Wq6w39XtzvLsw6fLN2/Pl//mv//f lv+Xvulj/OwGHuUiWdXxKD9eLZM//99RfkdHWd7j3G3TTf0zUOp9K9/xBEVad3SALz86WQ7wac/3 sFtjAO2i/rItB/yFS/TSXvMGhqr8AJ6ND30qftU5H3PONd97+318UjPEp0pmK+4kgh2yOXQlYZ7Y Re/lSH1X8GEG1t/jDZ7lR5rZETr1ETJfE32KA05vaKdLAQINqXAKYnPW9B/09eLi3FzsJh+hor1+ e8X46Yp40nflV57Ul+2zT+eKA376TElK/EFOysuRwQ0PQaztayYPFMqC7WZMIxT8QpdC/6I5pWPL fcZfx+SlI/qjQ+yxZ24Crj5ktXdxAfbD/SOxVaee9w+nH3Css/mOe/scxwDqYY9Y8Bt31hlr7SEC oWv60ttr+AOftNWJ/rSHL+s71p0Do0q0VeO+/Hbyu/gUfMYPQxP0WEo9Tp67vLzCj27zqYuLC/i6 wccYP0E/HQN95yAxC5tb1c3UWdbGLghlg4D5INttldTqrzsMWNTzDfbODul9cHi+2QLgFTXwZk0b KSV+scWJ2kUL5S/HjcoDhXzRsZh2Kg2BqjiLF9QB7jtk1Ikt3yeXHhKrj48P061lE0/Arn4+Mo1P yIryxZPDOM2DfYRJX7QxxrSJedKcswOiySzYSXujQ1pWBudx5hwi+4k69I4fb5Fj9CN+fccz25t/ JweP3qyLrnalD5l40scOaUEMg6u28k+JuC/P8Z0ry8cH7+lD7tGxPG72yF9tAf3GJRzb58mWtilm kTM4eMgWo5ToxDe+u68Pj/Li35yzkKfF60BWX37ywcnygx99n1gi7wFr/FmvPRwXJiP2GXugV20F XOPLtBhTkxc5lKaxNfMKx5wrD7RTGbGjLld5dHNpsBsZYVG/0kaFAIMS7XgPr0KZF+z3HCs6pxOP sSTf8cW8a+Kccc4hczlkVo58ANhLYtdcbp+os14yNnUO5VzqyeNH9Ifa6ALG75NFPz0jZzoe1b8n HyE/cNuY7oDxwicff7y8fPVq+e67F8sTxk3Krc/ukzd+8MPPw/uXP/9lcfDsydNlXyUpdYECoA5y SxJQQeOwllnKBuNt1KEfpjKjYE5nU5lyJ0oQlMxBLi5bIF+Dc7wBhWjUSON4upPGpL0BIjy83OGU hGm4HYwriAN8E4ETLY2bA9AkZxOPBhYbeJy404RTJtviBb+BbRuNbWA4qndQ4rGGPqB8CCKfZfZw NDXZdyiPyHINvssbB19MAGg/XqLcHFIHWIZB0/EwgU8wiowyA115bUoJE+c9AvNm+fjzZ8vb1+fL 3/3Vy+Wr35wve1e7y4cvXi4ff/MYoGtov1z2Pjpe7o+OwE+A73MMEsvHmXGysxfL8vI1WO+Y3F4u r746XT750x8unx/tLn9I6cvz6+WRMsOnNpgg0U6c+LUwI3hoMBLEW2KAZ52wBCsUoE4c1d0egxZt bhKyU0p/jmkp0ywOWnRcVXwjDhqXuNCzPmYHmB0BVn9ukzjkA0/IYWbyGV15wQca2KxtS2AYCk8Z 3CZF8O87YVcsZN6CUP+yU93sZbKRLlYHsIPa6G9OApz03iKLrNmpXV4x4SWI9bnhx3Jq+StBaVx0 Q0vKhCmFxEa2gvbJ8clyzCD/loRhApGfVfXFiG1MQyKdzoYzZSZxizteWw1gAkMykDeTtVv6lQe2 OmbkiwfaS6PEBm4T3T7xpXqbNGsvAfB5VebE7JDkckhHKd9X2O6SyZB6NR7vGsTdoiOOqXcCDqUW KZo4c5y8yS8vwIiYc0hxHoPx7nEJH77lWVmFv19lkqEZCIyv0HL0kQ1EygYO5RS//FS07sVXwrTe Mr/yQXv1YC7SSmKSrnXGgDjH8h1OXZjnXDywOyc6uAhoZzfkpizXxPc1k9LTs/Pl9d7b5Dwhjp8w 8VHH94fq44DO5RDT4jUsIj06ftpioAGnXVND/1yoE8bJKZ0NNvn2xZvlt28vl+dn+BIw13SyN/oV LBh7DhqU33bmae0/3MkfZfBNNTixJfjOGRTq3y4KtaCiftYWasm42S22bYfvgcM4zdcSX37XPFs7 41W1sJew+kUvTnacOJ2cHAWv904nOgq9vWXyfeNAZhc/PGpgfkvsGr/FB0hv6LP0XRdlXWzawX+K FwjZD7QYl7CbxNCAt3wr2bN4sk++mhgatmlDtbKZa1APp3ywr/qo31IU+fafcnE2iyD3LIxdLSf0 Ex8+Ol5+9+p0+frrUzree2y7v1ztP1pOWcB8iqi7DXqIV5WD7vlXP4FFCELKj46XPfxlOXq63Fzu LxcsSlxcXC6nVF9qb6L2yScfLGffvVk+YdDhoG7ju8nZg5ygjveNVfnVGZRK3+Wcr2Jky9WmxQNy mduPkeXEhWwGLNkKO2ZXMlKKAOOqwYhMv+zhxFYDbWT2zLIrdHS1g+3Qb/pnf4isj8F/RV7Tv/VL B/D2P06khsDwLU3toY3cdjWEcghGeXlkgNZ6bO85f+rCvf1g4xJ0qeJnwrr5rLammM9dYxDxCkdT K9jKlrQ11hgwVHHOIE6/rC/UTwEePMo57cs38iC/tOcoOuJ0UL5rZ2uhbfUN/gQP0cYV5/VfNmKz LxWd4xtjbtO/dV4gEIG63ke/9o3H2pIcr0yOtcRVXyBLEK+PpW1q5fwef3ZTBu2nrvR3j/1Wx785 NlbsW+iT1W0bBYClY/jbx7+Vs3EeOLXX2IxKyu+4YCCt44Oj5RpfM4dNLoMPxJHvOwbILpDt7x8C i3yQKu/BzwW0jcM3b94w+Ca28HVpZ2oH4WzyaL9+Dy7OwOn4Q7occN7EBVz6wEjIsVU5IiUh8Nxy 4TiCT/ddJOBAXPJd3oO4Fx1UV31MkAMjPTe4KM91cQK53YRtsZq9+ozOeB+16N84AdaLSHt8D05O pv9mnGE7Y/qQixriyW7wmjzwOkcrXunwtS5/ss9QfgiaW9tGVdV7eLjHxRjxOMZFj/m4thMHH2nL s36kNPYoxpx01ffmP2M/MELPfqr+2fZ8tgUlyHAGr+UMeZJfkMqwvMoHx/rUDkj0EfvA5hjJIeKB F69/eN3otHLORNA2etj811L9PZzwT6NgG0NA1/4p3vIlxVh1KT5p095+T53s4N+Or+3fpRcvQ7T/ +Qul6ldS6cIYDo/thxcBRmZh0b1MwqO2EGdjMfHrRzQaz5GEcoiEP3TlmPvacQMIGk8Dab61OwkW facHcDlmLW/C/64XeWg3UKrERRbLxxZOjl34cy6l/8ifcWHMSl7bDI9ctASfcjoOkU91I5z6vbm7 ftDhI3LXNfOwi4vzoQW+xvQw68WFQxZlz05fM1a/7sKreWYuRUHcQUvMIkhXTFHSGFxNzMBhDAKU RoV4pkMgk04dPIdu2wBJOJXplVBVfKfVdCpnnrRTKIs0/CQU+XDgSVkxRS3tWzETyihBGWPl2cmD ypObjMSxtNBKODmVFGWrK3nCWfRVp/a3BXQKOGpHbvhc8XSlj/YTXOCm03MAq3Lv7zFO1KCkYysX 52rT4E9nOgdfo1fj2ZFtwT9XeiZB73Jlh9rl5dsLBkkk7r3jZXm6v7y6Y1D44nQ55iru8gJ6T4+X nSdcAnp8wADoPHGWaxL5HcdeTSaZL6/P+L5efv/i1fKrv365/Ic/+QJUx8s/+nc/Wv6HX54v/97n j+o85CuOkV/nVG+rQOn0AH7tDOXbLZn1FcCEV6vieAgg8WAjqlcZdd6Z0A8dJZSEyUv9adQ5tiPL BhoUCCnKkQnQgettfiQ9tQtFyvMFwCcxaFZx6nfsqSZ0Q5Id7GzcqLcDjkdw5BnAyrcDKwhA1wJA aSJu/d2raq10U++qlSvEwwKwoSWhohP9P97SLfxSJw4HtelsxX/EAP6QQE5+r9RCU549z/c4Tj8w qkzGqDw6gG/wAyRiQovYAr8xoNzGkvTTQdJBO78c/Y7daExPqt/Ls3QnGSI7tJIdPauHVmUz+cTm Hlcjj1hwka5JyJU39XlxdTE+j3wOTL2CuCsvjj7k1Y8KY8sSHJoDtIfJ2hqrtYvyyI/HbuOn1o+9 gpVveWVzH27lsZW0wR08uEUuZAse7G2/ekPlcbjyNm3W2vALzRZz79Fb8ctbG3v58HTrHPNimsuV xhIyuQDyKuvV5eny9s0Z8A5CbpePnn64XH/8IfJy5Z2rf1c7Tm7QIQteu/vcFcDgtORPexci8MRl D/2/Jak/P71efv37t8sLEu0+yf78zEkRVxQ5v8XAdlDKUKfGcePyNEF8uXiBvp3knrMinl7xtSZi iT62MzRnMJNQI68yjYSpoQ6UkhnsW2Tbdh5ma3k5wC9OnjxOJgfe7+xmG+xHBywf8qUv2wFeX5+O GegG9hnEHTEI9i6Z5dAFACZG6EF7FN+NlqY/EmMdso7u32pryz3ezqOnTxtr2te+Cl7sZPy40i0v rcVSHG/C4S7FXfgMHy0OIeh5lfwJg0yvov3u96+4InvFQhedNfLfsAByBs/XN3vLk2evlk8YOCys Ze58w2LA3SUrWRB5fspKJd/T0+WUSdS3ry6X33x3wUD+Ah/eWd5e8v/82+WzTz9d/viPfrz8z//7 ny/LIybHm9ITOe3KXfJoLzD3FSyZOJ8ElGBV5tsKR6wdoO/Hjx+3MNzdPi5grviUV/0UVOHTdlIz Ds2HoIug8WHFaMgIF0eTKoq1m8okFMixV+QOB00OCJmYOeHfmasN+sI2mTQ3t4FX6YpfSXDSYoxl 8G+l9cOG+cXjzoSowjOjVBzmyQ13PFMnnDoxv3Vmbss37HbtI7h64QIMNnUx2PNyvz6azMOjg2BJ 6mPm0OFPX5PnkUf+h1ut3Em0zM1Tvu6gb708+nnwZ/WhQCCaCaz9wN5ywgLTEQtM3YXApLcrKPow JEZObaSfSwe88pdHE0sAaZMuKIC/Pga4Jk+oZPKrwTC5OzzYbn+dDMm3+mtsBIw0XGj06pGwTbjL VejOMmiFg/0eMyUH1kzl4MsLD/S/ThyA3y5wXF2Qv24vk1M9ms/sq89YHPIqUxLpjxw0yVYejh2T TR2Sgm89C0b6Ak2fPPotLoQyF7CfCbQ61A5jryZ8nHvXhzCdaxNlpkgcUrdPt535w4rsKABwTdA8 cAPGSYKLwvW9MwuhQn/0Tg3vljngrgtyoovU6LxzyuRJvDfkNV0vOvLmAgc48zl5SCYZlCAbZbMQ 5LgGX21cLgKjZOTKZzisnhrvxMMwtRWR0NJzU7fjk1aTU9QfBYoOhv7ENzEjDLohjtKVqn5orCw2 Gl3YWjqSSf8R1R+RjWN5c7x1Sae3XXnXV8UnreivbSQB1uQbe45NXMgIf8SEED/+aXtkqZhzhxvh VI4SIjWj9PhQp/dcbnRBwosh1jUGkypopOlVUvWbbgczZ4DyjRJ6Mz9ZsO9FhugPD5aFI30N7eEx JWfvbY4n/sal7O0/5UN/KPfJgzpWDnDKj8Qdq9kPeq6cjkfVhjlGHEfwY61l619yKYZjDsd8fu/v WVAHt3d4aZ/iHf+UB/XqgpU4pOWiD27c4qeOnt5p69jyigswF+fn5LSTcpk6l69D5lO61+s3r8Pj pHsP3tCXDBIICNJl53S0w2VnEg5ldkamd3gxS1Am0xgbT/JqwtjUQupIStsARWZVfIM5BJAYHp+Q qs8phzYzoLzCyVEJ1U5AJy0xxstqKK5aTNKRjoM4FaJxgM8wALMZCMJl9AIEzKDYjNzthrTNmaAD G6oop9XYJq8GNnboOp9fBpuYFBjNTAMuv2vmbnfSQLS75mpEAUo1f+994Zdz+fSgyUpK3Gmwpv4N zAP0c3PNVd0PT5Dhevn6/Gp5jc6ddJ6+fLu8vblcvv9if/mYCe/+h1j/C0ZG32OAzK1xOwx+9n/3 dlm+erUsDKIKJBL/7cuz5Q1O+A1Xe//i518v3C+5fPzZJ8vyy7/NsfRkna6OV12wIS5liJjEmjxt pgesC4TSjDzq1M4mOwvHd/RjZw8suJWNbn8cmc6mxRXaBQt9fSbdgLPVROimJ22ClrVtZkJ9XaHy BJwlQfnnI80G4lS5Ci8C7XvjbRnAentUwQtdyx2IbDy3ArcOru0Q8gV4b+IaTUoMfr5OeOXH2/q9 xVddwbX/wjs44agKdWs7dWoc2FkZ6IGzCrVNeIGBTldamZy4cJNM6kZY0CtDg6S1rfUb6RI3YJN8 R7baoLt8XC0aaG7g1IQmaHUG2TBZr3xbJ2x+Vn4HbbNAM/pUNwU/jGUr8LSKSk+4R+LaPzKJDw/X 3EbkIMPY7k4A8G96gPToSD6Mn1VOCosr+fYTrTka+ISwLQfBTEFJVFzlAX1h5AUkucS3ldUYOL1E HJ6v2sEnORKP/FS9HliM7ZTZevX0/taCmfBr4eh1ztVrFdGhhrZKWQ4x0aFn69Xz7f3+8s2L18vv nr9kYHq0fPrho+Vvvn2z/PSTJ8s/+PTJ8n3i91Ni7KOnh0wYd5bz0zdDFTRvTs8ZBO4sH3/yGbf6 nC7fPn9NvIB319XR1a/hoVte4akFJgYUwti5XGIvB4jGRn6DvG5ZAr8xju0fsCYqgCBSbHbqHDua NyybeBaGc2OUGBe+PM3RAQPV48fc4eBKLAMR2zdQUTeQnckuvqe/NiCYPB9ZirSeMeNA2ZVjc6hX gORvn4mlcE5AevwGnOYi87M0vKNm+LfDlkNNCu+0AbQ46nY5TmYSKxC82+t2takmldnADnq0Ya6e AXr4gLCPUIuHTHDPIPaL3367/PDpk+WaMLlE1+f3XAHm1vPHh4/JkUxGvn3RIshn5Pr922fLwgIG M1qMy/ft6fL8+fPl717cLr9gwvv1dy5w0kHQbzgB/YRF0Et4+T0dvJR1rW0g1mCaUuXwYy4x76pb ZchHYbQ6IwM9GbNuLng62fXr4Mirr3blt9zlot9oa3VnPy8ebdxkQmzQKI7DNP+kISVtYjt9vxyv DazTCOzGRugdGleX5/iEV0NcIGTBDb9pAIMf2SdpA2XMf/EJ7Rc2cStf/muPpu8MzfFdT+Bd2nyt E9bBl4xteRI044syy0TDGFJG1acvelueMjiY9oqDA78W9jUCQSGsviYeFBUf6mXr9xLYunVLpwCr n77IQDanFh7RvXQ9tU6dF2PQsMKwnXEK9bRTz15tOSEujDV154TXRwjsu1082PCI3+OQI5d82J5l Bz5VlK/jHUB1q9zxYzVlU8exccG5C8Xawv6e9bvMe0+fMD5JPTBjGamKkz13a4A6fOFHd+rwGr06 huRftMUrcRfsjHV1Yp9zxuKQ8e+jGVf6WT6qbjYdoc2V76SCB3OX8rfrv5IYK6DlizhWVyakm7AW q3/ls2BajexODioE/+Z3FEzOAB7TTftpGB7tWf4AneMFF92aRMKE2CiGH+3q1S70AW7vDHr85AOu avHYHfF5wHl9Ejkr/rFzt/Jyohzpg/5D7/V/XIBHO1ovX1uZjqvvFY/A7DVWMq6CAE7fGHB3EVQL 0AJ8isAR8xTIl2Fh3HjHiPzhAPABfZDKG9JRps5oR1kwIhMfX3GvhZyuuKscPjVFuUk60HZM5eY4 ykWAW29xRtANvz7uGEh+2gSXHDTj64HG4BlehbSPGBuUT+BL1sTNUfUqwbFpj3rGO7RQtDAuNrmp S+ctTqodU2t3/d2rxc6ThBO/j6Gov7bGhKT/8MOJOuZYquE2HwvYP2TX9zlRphZOxEMb5zCN5cSP n0ABOpSpK/hoIkpe22ccMeNEcIBJ3swJ6agEACFjs6+yEez6ncJBWv69Kw0kMEg+lBsQdfszcnd3 cfZ3Eu8C1153MukKjJzr423Q+MW22Ew/PznhTqnXb5LPq7rpHrmk/4Qxxj1zqbO3b5lfcccD366q a/h59gCFwdMYK/3kzAWZRyiiKzcoQznuXYq1gS1gWoWppBSTRINDBfkNFmZ0PDswt1YWplbJNEnK mRWxcQKVmgMD78Brl4jxFqEdjQx5nU4uNHiDUXipjdoSIw63rewUUA3qkNr2qwOM3LBgIgCZSd7A afVwNWx6AF7n0umF81jjqJAmSbTTeCVqYHJa6uRPHThpcr/niI1NfTlQ0nkcsOkTe3RKN6xmfv3i 98vPf/16OQH0+8c+9/lk+eDR4fI9ns399Nnb5XsMlp7+mNsin9iTIOsbvkx0GfUsr15eMCDk1muc 9X7nyXL8yf3ynMFTt3ioaLZWaxB8TAhhRXJnMOqYcO2zBj6zNUlGWcc+GksdNHn0SGXR3jIXDOxw wkMvJ07t53Piwri50+ELVA62RN9EmPYqTD8pYQE7x+DIbQaJvjDIx97izaY0trOWZ3lQrx6DMrka BHE+Awto2xCOWsDoCLqGpIEILyYj2zghVp9Odh0o2GY0afvBou+v0k1RvjiJTFvrJ4IcsdLu8wry dWuC4QOZkuHIZQkoaA9IuBqYbTKvHWNV4HTiOdt7CdKruBDTlvldLAJH3IrXztREqOk2/kuInuHn btrVROzmJEnZ4osj7adOLIs34NSpNvDZ+yNuMdu/Pui8qwy0dzBaTIEqO4gbRNERZ8KKcepXNmQE i6x2HnbmXNkFWttJX1jPLcruG07K/egJ5QloCGv7kr7nbrbVGJSbp8QRDFWp4MHW6maLh2kn3/Hj qV/wmHPcNpydVGB5TEqKDXrECCEXTW9V//I3r5Y/+/I7wvtq+cNP9pZ//OPPl59+8b3lxyx2fXBw vzxhkPMMX3rNleLvzvBPnrN7ybP63756zdUO+Ban+YVZyi4DTf05HilzIOCzhdK5JJf4bLp87Dqx 4MDc7FbO3WIIvyvfUf5Oh5vMY3/1pw9ExzwBHQdc+qC+/+TkMQM0ngF12Rb5hRsF4DvyV4E6GD2o z8JKaMocLG/+Oe1pQPk5kw0TqLnC5xH1QY/NrqzHLI/3T/C9m+XygncemGJoAzax8jX+9AXLxQFN Wg6M/CubjAk3jbO9rWnu88VmxAmmVaaRDArGA+3IhX/261csYNwu3+fW4GNyvJRv8I9T2n/losXv bpfnb26Wz178zfLZN0+Xp8+ectX9ght23nKF92x5wcT3t2dHyzdc6T1jkH98gr8w2ccoyzdnF8tf /uqr5X/8v/56+QHP9zo4+Lc35ZMf9Tc2UrccpxD5N6dzxQjOvFL0iOeserYT+2/yegXzmlUq71Bx QGMfkG5oq542A07c4E+U3zCJUXdezS830862gtcWVreBpzx77AAvTbJ3Qc8cIbzjjFMmNQ3c0Z3+ OQvHTOz0U/BmC1qbr/Xja58Lo10yhPffil3wPFy9SIbYTS9O2iZSx/7Kqyz6s8fbwov69BZ742Ly EJ2Vk36NDE2lSTccA5R36O8emAaFsL8qrmzjl21y49hS/muoZpQD5LYrw3hM9SxwTf0BsXzsnRRM eI9dvCAuzPfmYAez4q6vN6agZY4yr8tHtE4kmywAACAASURBVNiTORgkezVVuzCxhBV9aOUYeCog HG2wOAG1mxaH3Gn/GU9MrKQbrtVut9naUN0rh58WTmivAjxXr3J3h98JyxG4sR85TNv2HCC5a3te UJurdPXuxRHHMPJKQ8pGZ1Yqu4XCxTv7hJMHZNKH8glbRxdo+RxUIouPEIAnfYmReuklU8fTXj24 QTGCLVZwnHzo3yvYjn9c2BHUvGmLGQMAhx86rjLWnegcM+A/JvfPwiFX67UZqFswpN5cp3/0GAB7 35GgHeIPxI3lhDP2+fNWWx+FEUC69hsTw44T0JVXjtYtWdTXMJoeimf5o7XFjn3JTsgkSrSpU4g7 vWPRURRlxgvlxK6TrUFLvMfWqlfiyDg3NmzHITwbh+iEBvWtnb3TWWNG4PUYefCf+5uUxDn7yUFS dBNIMFvIlog54ByKyGit9C0yf6zH+SL2piK2KE9djn3xT+0baoiHl//C7sC4MnkxsP5mxakf6TvT 36h3yDYvgQ/byR/7+kqq8JzsLnfmOHM7f+Ob4JmP9pZnoeRCOfEF0HPBmTS1lmEDCTrVdquvp6yx AG31g7kwRCVtiu3acB5NLb5u6/k4JdXYTZM76dSG6QVejnhkx+fMz8/OyqeOubzya3z4zgt12S3Q 5C7bb2My4/zISlg/p+9zsceFUG3qyuDJ48Pl2ZMn9BXnyxV3rnkRwYXb5gSmFG8/VjkmNZXqKmXP uWIwk5jaUi05Vx40qrOznA/GSKIRfpxpYGTSTqvOFKaVQmXZWag4nwMVv53LHivpumktKVNBVLLX CAioQTDshIZQKn46Q6CohxuVhdFmsK6DUEYEOZjLkcFrIm9iBn0nDHX6oHevUhRRfqW1h6JqB3YA /B//3p6nnkok6MgJpfwMv8rHbXZeHfBPp1qdRNwHyOVD5w1Goa+U3nr36Pgxg5/L5V/+8jfLJx88 WT7mAW0YWV5z2+hbBj/PuUXnV9zevL9/uvz4y+fLn3739fLkT3hwG4lvmOy+5Grvm++ulrcMgM8Y yL49Z89t0uc4wZO7g+XD/ScYn1umefqr9IQu3Lb/8mNyrBKWD+GxDiv+B85+egYqk7CdVOIY8J/k yWqi1S7qMp1CQLlLDBy4iqViXPHTVwyArlTGi5akHceWl2CgIY+e6+clBSdt8F9Qw5++aTsnDrDe Zr02tEC/NnilY3AYNLAdL/PMg03AoE4g4gqxkzTxukLlQMwFDQOxpKUXSV8k0kUu7Sx/W4cq3W1A Nrcp3bEqS0dFh7VlqoJY0umBAFeP4HK1S8Zb0lkFQlMEPl/k2CatcAWf0IUHbTUyq39J0ALeFUk7 qTdK41OSlmOmyuPdE8qUT35Gnkn4Xt1R/4U5//YY+IofZcEl9oKn4p4zeQmVCd1LE/FFe3ToYLwY BV58fq+dNNjA+AOlnYGYYSB7yKdt7chMvLapOv6Nf+Tkq65t6HntBbIxm+cdrgeWamu/8r/50UZz a6dCsjA4B4sl85WOW/payyrwH3Xh95BvfqxR3OSPQr/bCqxA2kfYsCPr8ZPd5afczrmzPGFSer38 8//n2+Xu//5NEP+Qxx7+5I/+YPnghMGPj/ab32jzljs9yKRdCdbHb/FXc6tXaM25uQB68kqjzxY7 aFT+PQbF8pufr/r1fJUUXocz98lFlZ2isk+de7tgZAK0Mp/749hc/JRV18esyvaMD3y6oj39BPHJ uXQkl99wYJxOYjQFagHoQq8BL2d28PpZAzJoNEiTGPxco6s7bg1uoQ2ocov35UHmhFugDNkW7LCH z4iWCyjc4iO54SVzOTLgQN7kY/yTPktSlDXoT6nwRGE5gfMGqOjZaNBfGS7I5PKvuXr76903y0fY 7SPujHjmbc8sXhzT+Z9Rf8ELQpj3csWfjvrtDbdlnnMV/3p5c3a1nF7uLKcsgLxBr2+R846yS97/ 8B19w1/8+qvlF7T50YcfMhDU2qtvr/ZCZbMhTraRJ5St56t9HcPFbwcP3oZ9SL/n4EO7GK/atrhU bmB9UaQNLc+3ww4seLe7d/LmMQlozEX4GjJCki0OO9am2uG2DgE9wzNk/VNl4bdIWupcJ1HX5kHz +/nFPGpkXvcqipM7/cKxhSv+6laZvXutnC518MmPRDqGbycA47fqTrsJNEwUGwDay+gvPu8u7fwo Tocv/Xrkk2+Z3U7XY4kpu7pXJ9Cd42k3ULatafx4uOEqgKsTBweiUxfkUA3iow+P8SGvang1d3sh lbaoN0GmXmwkTscg4NASKUFUHFcSbnxDA6gH/qzRF4KVhwLEavRmP6Ot0L8i9u4OYWwaenWrMlkI BU/xIUboaEttEUpw9gJI9CLemRx7lQj7oG9ZMQ69qm9f7JVdbTA5wrGFehXvSttxGXjMVfKlFrRr cgHSRnnwcsCB+Uthei6cRuETsGrxiYVT/pn/tF8yip3zXmInHnSHSnLitI//uW+sWDv1xBUoZFY1 8t54Mp8wF9tHuqjkC+OIx+NHvcTQY2PRsasDeQXTpvLw4MMxi/5gQC62sUG6XieX1QBg/Lm5QOjY w02Z4TTjqRukAZySeNWC8uvYnYNVD+pOWNivfXhgSh4EdEIGq1aWk4UdBPoA/gvudIN9pLfbLWCg 510OtgscYtkYeyI07WSRGgCmnGPPwWHqduRY3mCvvloUkNaKTeaHD3lhs7l76MmF9lRmbdBxlQLo H9QPYG3yE9uhAHU+z4YDig8CKmSbfcbW14tX+o1txBY928rr6FzZqai9PiGH0vaDCrpTTtooNebF 0V0RlG2LIWNXJaIMg8Qj9U44zUHbBU390DEjHI7dgNE/ZMH03GIkbI2/D654UUdaA9j6CfVPI4d/ M07wbivyL/zbH0/eM1d79RU4gC2zz298ztV4x3xd9XW8wFiyuyuVAHifzfUFsL4Lwrs7vXtlG09I 49Fj3n/BGPr5719w9801/ezcAaYB9lN+vosADlLBaP5UOQpgMlMhKtVkNKqHuSyo0YGlLqMhjANh k+vmAALKpMKpHI3sMo63STBDyZiukPpsRvSkxafBO3gURHWqZROfLzFwgCNlnZwDBtbQA1cJiAJp u2q14dHgGr9gVGrbhLNDUI9UJjsTmatuytULeeDX5yXchnd0Ag/yNYFABTzbIEeFJ/VF9RRnfAYJ lOd4dU7IX8csTxiXul1uHzhCJ8rxf/7lb7mF8dHyxcckOW6NsxM/4hbrR+qM7y16/hb8P//r58v3 vuF2NnC+en26/Pr1xXLO21rvmVS+xdAvmUCf3r3mqiJOwyT8n/A81ueffpQsvhwkW2sc/lSHCx0e ukjwiAHqdruHiUJ7WTdvQfXACbIrwDAiDvRrsLk1YOWwTou6ubVGH8Gj2XTukjBEu0oiXe2DfaEU LhcBDLY6K8pVsGR06BmQ2IkO6+I0iIW1Xj60jf5g52rgdIstx5WzrwPWVsBbhvjYTZt5hYBOlQDV iL65Tlt7m65vs3XL7+BHG8vBDBxUyRo/4oFXB0DiHqe6YzDJy3oYUCqLiyreEmwbO/PiBfgCPUeU F7+rv6dfdQk+fOHeBRXxt4AAjMqBFxep5hDeRbDyN4XwXGzri+gTVZvkil8bIVCaHsK1LxGhnUlK tjFJi2dsqN97NTxKsCbr8QEhV3vhMNJOrdQJjFKC73BoVInfr2JZ7T/P0yl8GI+jG/YcN+gSDH7D F2XRqptN5hXRWpcelC99DKwQbvpShFWE7cVjOd93+IChdLNRfFJS7pRHCuoYVvrWC+smjnwAuTf6 NbDOT+0nZ1nysCGcqeLOW1h9vpfc/AefMGnkzg3bvMEX/6c//6vAebp/ecwFvx9/8Rlvf7YTox3G FS79Io2WvWYRR527+NOgnZMZKKiD4XfjMZ6BFcdoY/gd36+C4uH3nb2MK+rcjCt2h0w4HnO16fj4 3e1RAQGY3tC/bcbzapnusi8VDobKm/G3IodVvCre5uoNPo++igHgfK2BaURo+yL7Dd+aK54Wf4gR c4K3bHnLp1c1jcGu1KE8STUoLx8hBTGqHvxm1xBrs1UzHGjLFpmIoTKllWz1h8DfgsO7k8x7vGeM q/PXLHBeLXtMYvfwPe8EOebFVh885eVN6OoxPDnmu4Vv37h9ymr1+SVX5cF/Tkd/znPeb1gE/frF 2+U78H3I1fOf8oLD3rJNHswJpC9vKRgOOZ6cpUjAgNcYcqLkbctOdrV7rFM+kwORGN8wQ539mDnE yYaw24BmrtwAA60mJ8BrfwOpwZs8NAEBRNVw6s4EJG4H62aGivynE2++YVtq7Uc0bbqGybHFjEv0 QW91V8BLb4dGvu1rf2ScN25gsGRObaLCfhY85FurKTQ8SITNc2m5WITIvbjwmrhrMYn8HU7wDm8r j8CHx1J1z95vGwejWyA4qKX6zptVBTojv9Y3iYVk6vgg/P0fxY3+wL36quODQ/qS3ryMHfVzI8eL GbNQgRTozikXB/XDwkhZhgzjVLzqP3tbIP/6CHZrbCXP8Cuf1E4Z/JrLHTO0iGCz+vmwTx+Dnm3g 3UIuyIh35LIh+PjYb9XXSYPOANDk0C7i9SVUvjzRO1N8hs/+RzvJh2xLUzmmJ1eesYN6HlsHOflO NVKu0LMDUXBTVrlo8SE4S86tPpvWbuxejKCDbQIk3amBrpJx3ovXZA70xoubeNzKsxx65lu274h3 T8yzjhV8Y67PsvuIhDC2MwZ9v4M56pY7+kYOlSCSsWd9U/iND8d1U+/b/wU0F4yc7x3b1q/1ysgH BrH3+GD5FTH0Py8uVM95oeoZ5ca+RlEuUHXMmaTQI/16cGPzWBDY2OMED5Jibd6/+3RCbHSpr/gR D1P/jm+Ik2IG/dkP+Mm/PMcv9Im56xLs0JG35jS0XsnVvskgjMpr3ovKjDH93bGh/GavuLQt3+Dh Jz25UMMxgA8xDCbdn13t+6ceUI4Li07wxCN8MQbubfwsb/qBiyjao/i1EPgWgMeUHMuXdpyxWBDg 0+ZOVK1zsmr/I5/KIb4Zg1OXzhIFObWCHgJQezOJvA/+7ioEqTwCWi70bgPP1dFs6t8cCwfEBkRn XKi6xEYsOLFukRLf7P0IwPfCVPKYv8hz7fO+NN22YoiYH97ps+gfvUp8/oZ3XVCYzrQHmzw+Zv4k rVe8BPiAu6F69NRKeOdRQjUwSngQlkYml5zUgMGRRadSHcyYhLYJDST6E59Sl0xN3CJbNxXs4Fzl S05j4HbIPkAzkFb5GBfhjRYNbK1y216nkFdZiGH+GzoCNUDZnVuLTIa+2ESFC6syGvilMASmDmS8 /oU3eloPnEPzNSdFC/PKgqXwg0zAedzEFXiKKLCzxkGQ2WTlSuM4rRwDy0fDGXzhATrZoL2tXopG J2wgCd57JnrieITBzsD3l/z0iFfUjunUfOmLE+DH/DTAUzruj3g27JbB5OXOrPqdMii+ctWP+xV8 Ec0597L7s0PHeM4e7XjaY/nyu1fL3z5/tfyEqy52QPqjBlG/yp994dMJrs8Yu2peolNlfLTtvrdt 0Gw6vgkcOxV1pB1cQHAynNNnPYWc5KTebax+ldPjgnXF59VvJw8qf5+Xd82AFt2iQ6rGpiu/+VS2 xAXQ1SQPuGCAUgICpzx1F0O31RowTLIZrClzq8lNELUr/g6O/Ai+nJBuk2STo7eCNeFVH9IE3tvq iwGl4Vx/c5MvBTPVmlRiAp0c8TNTx3RgBnL6Vvk1Gf9KL5x3+wfymqS1h3h9fgds0c5PdU7e9Cv9 uS1zEufoU3+iDlv4GRNwTsw6eBk6euRqd4rs3LWNvpp82tGG/M3zcca/zABmHbD6rHvrTa/6hptv 5Q8XLdREASot9OutMXNHyODSB5yAhU+K6IuiWvoYg0f6g/4iv9onPQ+p4rHOnXL9KC/UDiJZd8Pr +LGwlcdXh4AqD8f82/xmFlagqLGkveKyhfTFaSNN2K06HFcGdPxZL6Harm04KyaUBxwtFgkjPupQ bMe2cgsmZidW1Js/O3RD3nHR4Yjn1P+IBSx9pLtmyK+/e84tsldvGACLF3lcaEQG49GfSvK2/Auv jKAvVxnUrZ1hfsTKqqu+Xnkw36crOEuUVY7aJJdy6y/qRvlkfwY0ELayl1M99vZYJpUumglDhZKt e3jomLq1XN8HtOJ0ZSP4r9+QV+jpR4LnFTJnQKCE8EcDPbPXYyw0tsd7Kmxi6wLWHc9Puxou/9J0 crBd2YSDka+YUf8zmJCGJNVXMSMjFOQ3smVfEF0xjOfPkW1szJccLw4n5pf0sV3JPbskDlyd5woi Nvr7LcVAu+KfLE7bY/zOfm2fvP702QfLM6r12atyBvKq2o2vYVEkFI09kShbK6856YBHWMS35Y1g tS0xpaySV8bNJt1NA5/iK+6NE2CiWx4w/0ALRJ4KM7EEjB91ZdvOAAJGi9onFcfko/oSzscPR9/m M3FqMw/qb7P/4BWRfFYnfSd68Sl66rDxtjhFZXim73IgRA5k8Gw/4E0B+rO3RfsiOCdb4um5PHlW JnxVepitAd3EgYIkjJl35XYtkWX1L4/yL5P8eTgTkTnO9sikrI4rpOI2/a1YocfOn+MwXp0YPeLu BUqTXVOYx+1/0hM10lAv+Snn+orEt3p5cpO7/tQ7Rqr/okiqDiT92NfabhYyxh5eUd+FKRfvMwdt 1G94Udb4nTJZbKl9OvXQ8CuDnJJ3qIEV6/yZNONUvbvA4ksSJ2+BBFs2yJXtWBYnJwoq7TbP++ss XmRu2zgcOwBUo2nboucqRBMn6uITKPtgcfpPnxan4wiF9lM5+9HRnI3uaaT+ae54xE39ZlNzDDrZ 7HPM3X6+xb7YZFD/bsHe8QY0bOcjSuQvXbCnDOVplU2ZHuyKPieepKmOsTuwToKzg7AuMFBmG2VI j/y3Xr3UxymEXyFWXqOB6caX1IfV1BMQW7zbYuJ+2qKB6sQluqExPFpwz3gMjNkFCQFY6zhUPC74 shBIrK6ygI3x/MwVWvQkZje+o4V+HL/NlXfmAeD0J3Lcx798iFteaGt+K38oJ2VQ51+Crb4Ce/jm ZnvO5ticQVtb2JeIz7PmDp6AAjLFk7Qdh+0zNp+LHvohjNoC2BZa4Fk7lPs4plCOxZjfx7tyiRj5 JWGdfheYcci8oflKBRQD33ga/uVB+M2GSuicxHF2iyEIoa8WY8AXJ+pZ/UDM8sZl4PQxKeNy/BrM xbQswx1tZM4LW+rRi1476/jcub5jEv3cK7WK6WMUR1yRVfm+kE5ddycV/I1s4w8uBHe3A7ivWPTx nT1esDVnXnPRz7tZnz56wjtPzrrK28I2fZyP5HhBi7tZUajIRcw/V9ZVvArRqRSoWyRZ2fGKg7AK 4kcHs53/ha2jQ2gFdhJYuV7A5rmTW3ELp/NG2+oBSXAAMqS3a6jYCdDhoVuj5BUa+qI21rAZQZ4w gCvdflohoczkYmA6CVWBBmGJAdwaexVgDMuphnLSA5oVTgcw3aHUnEq90Ey4le+YocN0EU39NJBH ueqk3xYG3sl2Awg7pDpfYOHNrSvs4DPQXDE1gMeIBsMOE2BwkvS/4bE1cRjme7tfL4d/s8sVHt+M iL1AdYTTKNvGv4PkM5zijJdiuYLzitsZn7/hjZi8ARZ2kZFG6CT9YSevjvu8yAHPBk7AravZ8GvC 1YatGgLjZQgd1a0AYG/AyN/7kxtp+NExk582Tm4b1IDAyWoBqX9o1DVQHGDX6YCzYIFP/c0BfD4p 7zLAnzaTB+0zE01X8vRDdIoO1KEvz7F9t9DBvtbPT+HNwa91QDeB0G8bGKt3O12++TyojAWVlwrM DGwlSgu0DdXGRj+vZB3FPmzvs9HiLxHoe3YOJDu5a4UROP5WnhWLDzjjC3jjcfifgbo0Tb5YnnIa ugFTQkZmdame/Uktt5HOGOFEBxZ2pamNQqEeq1L3CjIJbnQzOISVXz23pLnG93TIwvBFD7bxGxoK x2/da4O5qjYT3tGfMngbbu1gwvMmoio0zakRNtoqm66ivvF4Eaz4lXK2bS+98Uvb+1lrIrASEkYa +lR6UTfgVUHCPWwc8yeG0RitgDPX6JPuN/Q2iZa4xUtF+uooNKKizWpX4LKlrbSt7SmLJc4JB/DE ZY11w3mR3topAe/VAK/4uCm3g5z5mSSeZb0eOsokz03W0aVxYpl5Wbto33K/NMEhMdXgrWw96pIc sVCddPIa9ymGNxVzR8kHHz3TLPmReXlaSIcjEx2b8KNnePUWfelAzwwXLlsJq15FwabfqzPPY48y bTE8WEwF1e7E54kiBlWVuYDFwVDgi05mOGb+GU1tKK7iCzreItUVszv0Q35RJ8WwGLHHQ+yAI72R K8MJUQcz6Tp+9XvyCYT6bW+uXIlbPh9jt2TiVvbhGSkol0cP0hHn2kcNVWwV357do2T8cfSExNUV S7Tf9rbYZ4XcO5iePDIncUu8PgUicTaA5SA/FkOXzGkFjADKJ+Z8VngGMP4WtEaNhm2EW+3boxi0 6RzBhFFn5Wv0vOlOfU9s0FcDY99UZ8huVV2yi1Yc9kExzHEAlo8bc2CR+MCPvSxw3FG/5ICrwR22 o49Pkyuv+T9ILpjo+miSt9I5uJKefl9cEKH2leogn8sv9b3RWfwhXyiRV5p5E/oRJh0pm5sFa1wE F4y+ivdjRgfq6lmwxk4ctDiBvr1l+Yjb4x0wBqOShISe+vV08+Pkh9vNF7UgQqQbL2pnUYqUaWww dppcFoCMgx+dtQcO/ZdX1Q38ZhNwjky0Jzm1yDrYKVcXUACNuc3YUmu6lZvx0kaBb772+VwX53w5 lfhtI3wLDbEkj8OPvhLfBPFMtmRXaWhBnST8qqEauVOvVJYWqgNp20BCLhks0o/UUZtIEsKdDocs +hZ+Ziy0qCJumJqfbySPaAybyTfyjV6oD87BOuO3Fp947poFDF9KZ5P49z9+Kq2ukONYxk40ye0c zTiR8QuEolN+5MiFFL2Po5G/IB/54HB0xV5nla9iRoyA1P+oAz6j05kkiyjfREGlInQxsQYsdfqe Y1tjyU2+J97lY/AlHMe2Uzf1P2tucEGzvMt5IyNlkmXpcHykrnybPXivvdsNP9vj/EB/A1C68uHW lU2am8J6Lh8WzBtX6p1vdy/QTrwTZ5bR0Hr1km7YgU+8A8M5m/XzcixxAcLXcaILFBaYK7ST84Pm TuIUsG2l6SSNsZl9dPqCjnizH7D6sDTVXzoAn2P8xooWZDMQsndR2cmcHx9x6nE9yOWDgIjLHKyW Ru+bj9lczVHjXpwr/J0Oy1l368m/NIFx8VY4H2Hx7lkYLjc3rhYGP5NGj5boC/AmWI8nNM5WyfKG TqmQN8fXPd4KrI9p2Q+N/JMr0p2kwOumjZvAkiMuWZQ89mWYqh57ymO3NsPXSy7w+ejfAXe62tJF NT9c6eX5RhSvwtBoRhKrTGE7AE2YKlLmfUaGzp8AVwkmjoJ/+mIIj4AxZtAZaBLTYNTFshynHA1s OXTAV1IcaJiHpp5Up8UePNvk3LY6BuaKX/Ww03vUDRQ2VlA0Yx2q/PNxkKPRnchskzWHhgY3M7QJ dA0EjIZkfRH4LdmOIzgBk0edzsGLhnAie230b/zR1p9vEYeDAX+TUzg7Mr8mul6wEtMwMOpZHYM6 2kSHq7S3BLMJ1wmtxvaFDA2asMMtFj7DZi94ZneXe+Vwm5xEdfd7lcjkCp6B+IYHxC+4RfcGXL7x 9Zgf7/bhdW1RcgP3u0GEt1HOmzrl2yCTSa+Oejs2DBUcW4eq/dRzQU5dq5IkWk2M+vjngT5hmb5i IBPs4PSjX0y6AhZT6IV2zvqUEyJhpRma0A20vOkDDRA4FkafdBtaEKepCUMYJ9ZwwprNJKZeTlWA e4WXzkM2+TQJc28CwawGn7fMOfBuRRecJmZ1J03ll54ds0zqD/5uqT4CgCD9nqUvrWpiDxxS5wf9 3i+w+qd6mSSg/cFPQreD3wYW+RAw6U+fZZM3k+XmX7Zzi1eEt2NUbzuMbGQHEfii3/SmNpRjtR/6 pkU6cIAl70IYM/pgMc55iT/ylCcL4YRuYVRl2wy9GcsAh314ncSq7+Cp8O2iTI80wIvJUbnUlfta RpwCearMerkVRgjtKlk6P+LA861ePMX1QCVvLWg42N1Ph6I84m8QBFD6aG9jCCD/8Db60JdkVJ3k x92CL/bRjQzKI0SzTzzJEDTii1owDE32wSpQ9dLwmIqVTrxxWrH+CpL8Y+UhuwZuHa1H8aFQBzzZ Cyuu3g6tVk1pFBi+oJ96K2F0oKt9DIZ8yHwIjolx4g67xYr8Qd9I3AZwLpR12zC+42LdyQl00Z/5 o7t5wmtrJYYv8EpzShg4kzPVp/JV7GCEXBVE/EBNf6PSxcf6knKP+IhBF+DUGceWGPcPuMCivaKt TdnEK650RH5N77TUz81BRBX2w7ccyKoj+BXHZs8GKWFBxuLUvAWcPEsb+AP6SrcmT/Dm1UJziYMg 6UxcyYf5E/myEbmnupFLTuUTdNE2/yPdg38X8yuoEiZX/6WsHpCGNvLvBKlbwpjs+t4G4dWlCpvf CKd1I154UTfys8psnDnhVkbh0506knfcAmuCrYr4lHbyabuOrZt2tgU7pdIzlmbAaFE+QE0+bjs+ 8t9mk/XAEvWmrn0ER/noMVQNugFQWpz4kdo2CZOYOjTbFRTgsd+wPzAn+fvjV0y4vH1ZmY0P+8Ou xHCcNOnGvD8MjceJE6LjgqkiX0nLo0urGweNEIAKPP2h8YaqRo/gnX5NfUzffMSgrdtceTymK9KQ Fj/KSUfFfcFmnzQEinXqM6mwssd5uuW89nKgPahT/27Wy0/H6MPyd3aH3oYHhGQW8Jjr1N8sxg5e c70LSfSdSGWOd9A7vjhwHm96vuDOtI03+wXlkSdxjE/ARDzH1sM/xZrNXAEvwPPXttnFE4+zXUIC QbttQTlgdSZB/3Bo4aUbTog4RlZPZSluFAAAIABJREFUNQdUcNQkMDFAMYz6DLV9rjC0DjSq9ndi QpUuhPtb9z03zy2X9vneraFfeKw4TqCLP9tQkAcjWLgf/AsOaTN5afyFpm310fLMlWCJqst0qMxC qEcRrzaeWNZKKw/IKRm3kYP/5DXHkm6NFT1AdiFauOMovwJnPg5v+aQYOHYbOgIiFzTUMYz5ny9l lE/MqAc4VcnYQK6FuiYu/83ffrmcffTZ8gm/a/8xy937OHcvyQKP759x62IFsWA4TO5QLvID+F1Q i9rD1SrFcOFGGiwqMU8olyBbnMmn+oKP/AF9bnGTv9BIOsojjVHJ0JCOON1v38ZT8GwuNbe46Che cTVmZG/sd3GPVk22ndxTfsecQJiwjSEVkLq0lZ59Qa6+o082b1Bu7YZ8zi3M+8ap/njoI5yUa23V 4dHITmPKLTG/D+0ZQ+ujc1eZcx/sBP30oR2gOxf4yJvAhYv6ZMg2xrv6Q0/Aqh0X8aTUwoCJqxjg jlXeY9EFDxfwKfMCo3J3wSsc2pTfb8cnLDemnHM56T3mTtgPP3gs+9za/KZxe7qFrmKpH7AOQh08 Wal0NVQnkaFDOpXrHSdWXsGjAEU4ebuisZ1qQkNZJh0ENSCRE52lzggBYWi22ZsEfQ6XJo7e4WQC SJM6cdAYlozTu0dIlUVC6NbgOENJ3lJDmV24mEsQgZN0UYAhYw1NZ4OguAU2QYK2426BkxeNDLAy mWRMIAaKckwyHJ3YbppCwxMFcQcvIlbeeQ7CKupWuvJHA1ZjBHawwX3s0Cmo2NeRixh+qW5zEOYq iCUmlq7uwOO+SdTJvrjiRv1TzwDwmvqumjHZPcLZfZW9zldAqGvR0cyWDkCVV9o6lT9p4Ln29Dbn JvAGFsC6qjxoTjvVSSrsDSzwWKGMJV51hiD6rS8cUXPdykD7yENDXAorfFfjqJmBGuWbXOpOdqFn wBrM2yRdU9ZBsDfI3LSXAxZXdQw+KdhOOOm4p3oWejxQGLYrVpWd9PpmcO0ib97ir5ZMTOLZBiPy k01pqjSDYVCZDMgq1Z9wm7o/J5DvgMOFg65+UD2TUnWnPo25sQENxS56/mEHdd2JOhAGeuyTLf0p u7ocPXEGBj7AJevKXMkVHWbHysCFUNnaNh6rC/5EWxKHhVZiVxmHjeFT/eTn0mGQGM2YhWc+8Sy/ fBzwGBslXG1BW+3Vyj00wgXsligpahOd/KmTTQfmpnQHPhcYumUcev5Om8+BJwdZfPwBTnTL1TdE lVrhuf1GZ91bNvSmQKjaUBEXnOgHeprn72/qGibhaeR379aeY/kXvzDbJNtz240NxMkHmQKzjm+8 r23DQbU4KXq3rbQsENdGe/hHzxvk2qZIqSOSneHLfT8hAXB+A6yxOANgMUxcKb2DPH8CSDrH3DVy wm141zxfenF11u22x71UQu7hhXCYPCHfUAaVt50mK/5m3onn/IFSfZkV8BaSjJlsN5OVFIJ+xDci q6/RrTnUYwcU7qccv0MOYaUH4vwfRpACXqgUl/LmU0KldOUd3Zj7bb1dbRvaDEDww3cd+Nhka6Oc 0nWA4O2xPoPom7KHl43foNHqfDR7V3/UEVuw0lZe6izwClvQHcMrfUZ+Z6lyqk9AzcfGVO+C4LcK t2fHfLGXcU1QD06EnStL3OoNf27qTXnDlb5EPOXSzoZAeLV4j0drnLjYV6zNRpdxQTvK5WfeUO9R Vog3beCnXAtcXgodofyKcHyTuvQgX9SI0yC3tTB85o4R6pDLO70AmToOys+cpyfwWGee0J7i8beA t2d0LUNwvjNoE38DYtpALn5H0JVHkBkDm07kRdDijzo/XnFTjq3dtNxkARgY7e6+8QNH+/QTToa8 muHty760pcd35F045Ze2fmyA0dzJu9J2wn/rxal+9VX7IGuFrR9Tp+IjH1vv5hXXYRW/0vbpGRmo dtJmZWitw2IziRiayUipbczrtJrxIkdezbLefvmGZ9HNK96y7CNDvtlbWltfJx9bLLuPYEzN4fin UMKha+iMPiyoGIpT91AQN5yhr3QwYOv/8bPiHDreLiya4oT9xrsS573DarRtk/5pp81bqENG+3QX UXpvAI+cHTMhdoD/9ClvrueNy+I3Pl0Qg6VsOs/yRmH8QeFW/cuobWaxz/4duW3IgTo1PtKLPPBV 1+aT/JLxoG3HPisc526SCIax0qbXxoPUqXLpKLfHLmZmI7BpP5HaRrmzH7DDh221tf6pdeSHSvBk Tw/ZzMBOAsGKbw2xGdOAm8kbI5zaKucNi4Wff/9Hy3/yT/7p8vhX3y5vmPx+fciLXeHjJfK/JAZO zbnAPoWfE+S547jpM7gbfaKQ4YuxnzERdhlJO1MHTKfUybJjDWNKMzhucmushUDxbG4Wj+zXECBo z+Kn4xOoeCFLHdK2CS24zDPpTJ5tt37lNDIC//0D2gsnDir52sQ+S8SWqTu5bSSmT4C7vLyiyhKA b48QOI8w7/SoCu1Ea+7bSzdjmybZjsOpM3akb9rQ7hzypX0xQPn6sc47Yxoxx97oaBTLsb7DJu8T Oy5U2F+x6MCz6wjSufDG18SU/kZOxge9C8d+zfi8fHWx0pcbNcSjoSy4P+UlVpcspPkCq6MDX2CF HcBrf3lLX8yLrEQo8zRh30q0zXWAUKkNhYUJmNPAflNiTqsm+KPt6Md2lK11TqQygEUo+q4XF4xx exkGjDiJCV//MSDCGSitwCKIdXZokAl3g+bytIkVbcGQXJqgmhRjQSfPtoGt5Cu5q0S+BWQVVKGM XXA0yJIOW0mD4ykbPZQUaTuT5lVfouarUyNZPPhPOZv0yhQQdliuuJrgdU4dqGc2EXKfn3ZxMugE U1uUIOTRBojmRFZWdUo7YIPPK+jkhfTxUKZuHbgIR5sLOhTfcNgzGyB1wiGX8tMtEJSVtKBVI2r7 DUaDFFxtBIF0mwBx4PNOMjgJdJqpS+XRidWxVMxhOpplPXAvDXguwbJXl65meQVZx1eHWRB68Yk9 SjjqEVzz0gYOxOsOXpTLK/y+yEG8D5NGlGVy1V+3reQrIuqaoAtjpecUO2AwCXns3s7fDtnzVvlR Ooe0gaYMuLJle/6p00n20ASfdwtomxMmAw3+BaLcFVFve5qE9x5voLGdnaRw6iP9q1d0WIfewGnk jihwwvoxdhINfTrh1jbqR97l0o8vZquJMYn/eQv95uOWG08P0OhOX7Sdgxrpy634LPVYelvy7wQk 8yZVW3FMvTLY3mdovJKHgMmeAcEBhpWuoojVTZn73x5tozPpSRzePaFeaF96cMKVjwYR1F0z0dIX W7zAft5G6ktnTPJ33uNk/qL90FrpAQ/m8OWT+f2UGM3lRHVJXNquHCAv1OknHm68UdjxxAMxo4+j 18CjMnSEU5Y2KrW9W3DJup2MX9g0mwIgDw3GdDDztj6+oRLJhpdCD+VUxNmagrEOepziyvVdt+7K oYHobvHTFtc8JuZtn49Dz2Mnlr7o7mT9yQz97Zyf0/HWWf3eTVp+xJ7uoC9Pfkd3coeO/K9t5GPl dVu9lhdqyqzujXHL3B5ylK4rXj7S829sHBgozVnWj5yWbjqfq662seXYSvz6rTh6I3Y8vY8TWJoo gxMa43Zifrht4UzfY0B7wW/Zpntzfr4nKRqzuVdv7+vV3D514OfTFRkKNnm2CX1AtFUwxdcP9Lve 6k4OOFpvk6zfgW6DI/JW/RJw2UOxaSq/Tq5Y+sfmXi21v9EW/Jnr2EaylQbtt6s92Q09SbsBFDY0 l5TDaSoaaWWr9DX2Swfip119OQSEG/lqZEH8wfXaDw/M1jYWwWH/+LCBR70bu92ZY4Uw4uDwzquI +MNMuJzkz8RDWypkcuMnkAZOPyCOV94seAenyvFd4aSxbtnYYwq1zCxgjX7G51Yc1CqvsukD4vDx myOeReulVLzIrEEs+tz8QyD1M3jRI7SlIp9zFxJ64y9fUCfWywd75fdPO/TMPngnN4ENBC22AC5P +UrH9iX2/7OAIpwyr2RbNJbz9C8z/CmL/mSOR8IYUN8uMrQgj/77VQt9xLEKW34LrPFpe1HJ8zbI Nny3vD/91HauTMqfdNEP4TACDnEOD5bna+Jdyyd/THs7bPu8IQ4P6FEfrh2zYPN/4xTzlDhXtPLI EEcF08dxt52DffolLxwcHz/lYgNjOx8/Y/znQsYH/ISK/J6fnT4stEA4OoMLHSAWBMuJvf03vVuk Rmccoc4C3PihySbXxpvDR1FtsayWHPQPgQ1+9k4WsxP8l4fxj01O/cSFb/1Rq27+ql9qm/iVZfQl re0cz90YsLY621hofjd3QH2+8Sq3Kz8e8jVmfLcHT3cu/+l//B8t/+XP/v3l6Z/9crn/9Ef8ZvlX /DrJ+XLGb5i/4oWt39yfL1/uXi0/P7xfvuSdFi7gOunr4px3XIpb+vow/olYxRbF8VzsypOAtEuO TuUZYDf4yV+N2RBY5LiPOKkhMKtc+nNf2iiL/7SRzu0LFPfxEUQLc4/egS8Lr7qHQvxJT19VX+rP ocy7+Jgc4jhR3opf8LiQmb1o63sBtKX+76Kadm4yLi98m3Qn7ORZ2feFtslhG/niqwbEUw4AaPxN PVIv7USEnrTkkfDe4w6VLWcIN/O9GaMKrs871naM4aZ8/Yyii2TUOYYyLi8uiD/v5uKOC7yR2OIX GDiSL+eXLqLzp4qXp/xcn89L/+ZXv+PuAF4eS07d9ZlfcBnT5qFGw13Gpo1OoaOYXOVchk2z48xZ TsmzlFcARVTPoIGo6FyHAjSn0CFIAhlM/KOZHMrfy2qlGpiQ0sZnaLySt+OqklskVTwkYbaEDPKS tDTk14kEZbATAU1sgioZIiQcJIcTFUgGI/aZVNHW1U3513DDYMrfkp4dfGxLAG/brtQVJOBB5f32 l3QloIPOlT1OaRNN4NSpuLxdSt04oPH5O5/PqbPwbWXQ1/wlIB0HXNLODjmXlSKLmuykQ/XjypML APyRUO1UxEQSEoGHykdyV0Tl11FLQjo8Zb763olE9dikZjJvPW8QUHzrcOWKZERXn0SmfMhttXAA zzPZPgc3gWMcacMWH7x9F1B14d6AVJ82dvDtJLcgRTBt3sAIrl051V7Uokvw0k6dqp86RPb6WnqT YdkflvjPxol3GciDAtESfN7K5iKEXmAQsmDAbROzQg5s5dNW3CYTjSqNtnCOv5YACNLH3H7jz0WM gaRph2HAIZuKYBuZxUfb+EQn8o6fNFhK2drfj7e2Wz649E2/dqQadzrEsCIWNlFnIqWlnD0sbFGX 7wlKnRAwMn4KZAMBzn3Wa+pmr1wTG9NGUwGWbrp9VVWr+2xsm+FJHh0I9KICHRM9l0uAGPtqd8v0 AjhaEXum+batZA+/YvbvkQsKTLB62RqA3VLOQFGZHDTaqYrymlU9J9wmW3/v9BJexJXPqOvourdl 7BWLnXS+0ozHiQkRpxupIbA+s9lSpYjfev2ngS5l1ZurbGN7vypw2zpXPxS8hyM/XWEe9LTSj+dB OBC0VWfirZNEl+ZJvTQfFu/adoSVl+FJVlzVbTEN3zYu1Ihza/3cejdlKxaR2+fPTliZtd3rt68a zH7y8UfkETsh9WzeTKDxaw4Hz4pMXuwo4BkU1OErqQB9WSY/xYsa1ofxQei7iYf5Zm1Xoddy/Ul8 yK2/cdIVMjkRqThEFsaVtmfyWrUDPHDIon2KCl1h6w+IK1eezb/lGHhsNZzGXin1GUQXGvU3IJLH /m8lCi4Px9+TIdyWGq3azePZ3sG9V7jWbf4WDthp4ZcTJ7tHPN/kgq8DKTS1tmCXUFBygIEuzJkq 0r6fl0K30Gzfe+OjMFzFn0GT0qt/lTP60GbX3mpnP63S+PNfMCu1yjvWd7TJ9EPK6FYZhwPHQX+z F5/1Kk8f8uVIwzNlktO2yNDgW7AVjgP+1C02ATBdAmu9tvNuE58VdeHZ2+wml7MYja5G9yt9bBEO y41hcFHTVt/CUbYBd30GlcaXZbmLwOmE9tBORfExWJJZ36SNC6E+p+jbef35DccC0qZyUKx60F7p BKff/C0yCukf8k0DdtopXtCFJm5ADI/RnLgw/4nP7/gB+OG5vsh+QLnhWV5EfdedMyPXyEq5Pp49 hMd3+Sq2/+1D+z1P+iwHtJ4bEyWjGAYQuHTWoS35SpN6abShvzaVSLn82kZ7ZTXAPLeXSz9B2WLy mjhrkywcI1f6ny64dqEeqpCQBjR7tAysjVPoo7FLj+GIWhzuGgMQP0zkvW30mN8BPaIP8qU53r7s 7c7St2+Sdx8tk/ML3ix+w23fmk7a+jPFw1eYOTbHYDtbzEcQ+/9VHjBiIJtVJj/Kpj20Z3kevC7G SSPbEhVitI3YWlB7WPwWV1iQKzBBfBKQtthXvWhfXdOv7iv8mlOk4XjaNm0Q9NDq5hIeJ6zNEwwc VAqgiZFFkfMtTjW/NraNP8v2/Z98sfzxH/7B8jm6ZUazLF98wTsJWFz1zdWXzK5enC7X/B7r87dn y/968Xz5Z3tvlitmh7v4HaiQwf9DbvMhrxqqmG3C5a8jJBI07Q+aE8Gj+UHB5QfPjN+5s2UUZQ7Q 2xqD6juct4AswfV8o6moo7f5LflD3p1TtqKNfZt14w8dCZwOnMB791N6Ue3YNolsp1498y94F9DA ZblA7OVt4Na8qFxUt+xEI2NdOX1hqlKOHmirjdgm17MPp9ICb8VKuz4BPD2fjh+UJ9U59eYQ87L5 wcW5W469eHZwrDahhsPJ3/6xd3Ay6SVH6wczRtNfiD/qvVOiW+zRqc/An16cLXc46BHjQDd1bP/1 6OQxbrW7vHr5ljI0bs70og8wLojKE1mfPf8SloZ+cjaS3fYQM26/KtVJC/UgTXQw1RL5aJoQGk+H 8TZRp98NfJk0+Qyj93w7WW6DeCDpRjVKVzKENwGs0ApR5yYdBxwaj/ZBg9vBtNwXqPEOIMrtyg7n BSL8lpDBpxNO8NJGesBEEx46GAbCb+Io2OVPWEDSjfzTLoNR1xU62LCjvabcKbTt6mRKNLKEHugA eu5gmieHhszJxQ0u/IH20PMYXsXj5uBXfOr2gSd04UtqnIT7EhhXWOXSzsbbtToHoTjjmzrb+1UY nZYddAwAJgt0wDq+ti9AKFfKzAUtX6SQ/utEpWT9yDltBt/obfj3IXIyOHg9lxhfthnMrxM+zuXB Ov2w24OB1wck5Wa9/nDnzwcBZ+ecGahr1Yq9PiGhJm7IYDJyU78NkjyhzGJ1mY/aIesv2O+SgBBO 3SmdgSjWMLtzYy/WavRFjtVBV1jRu4MYrzweste3Sn7u8UEbeQfD+K6JRiy0B4l44h8wdSmPBWzn 03l25XwcA96AtpOROsCji7XdePbYGqxNeIEMRsRSor1tt5fFic9zKsTIIMVb3oCjUZMFdUFdvoey yiW2wUD6WeXgtdz22yDIfYtKjpyAH3xRgp52XA3c2fwbXcgnTfzSzsGv2vLlLo+ecIWRwb2c+sWa 7KVtRIITvTbhosHBPnD0jcrnQtA5t0mdcxuubwYU/porENvgbuIVerQfGygHAsEEYkRLOm3wIS3h LFFOt9FrTVadzLG2BlO2CkN2qElwK9Z4GtriGnzFhm3fw+9ZAyO5kkf2LQh2NDQh9sADxe/8zTwR 3/AOjeFcPxIKvCtv4y+WQUM4gdnUl/KecbXi8vKiVWFvLXdy2fPdwD1cISWebDVNJ3ZD4j982Vws Azu01Yf86qiyoqunXcrMO9rV6uIFhOJUV/kaFV4FtlLLbHiNoXvzvjKIRxx+LBd/eGynF3FOXimq 4Ms80oDG6s4FEgo46DigNNcCSBzNT0BdXjAIMy8gQ7yzD8faLh5Wmg92hZHtWGWN/ZVZGYdv+9At N2+w9QfB+2yYj6X427r2J/gaucx+yQUg7WWum9wNTmwiO+UXCfI1Rzhx8je1jZ0GKcBVLQS6dUXd 897/4aQfuVsUobDY0241iSnomcPBq6JLddJCLuH9rOjV5QxKtQ/HwCubMWsfYBvLag0q+a7Uf2yO RcQlmYGRArZB/isGcerBwZJ3+NSngHfLvcU37exbbOu3DYRl93Qxtgg//CkKTaInzMabthKDIwD9 sHPK7J/lRx8R1gUJrwT6ngcfzXDQFj/oU/nbOI4bTrVfm7RVOJu16sf+Rjsg3fhKtcDVbmTabpk2 Nvegv+lAfxCTbL/LX1pm+Lcu/Ss4COXdrzoLynP0Pj7qOEh4dIyeneC6+DN3iciUMsw4wzZuUzJy xMQUr2JbSwtojB7hgeNNFy6QqSJHobOtNkXXVSDUXGVf6yFqXGRnBe5v8olxjnUQYGilFwbT9tXS 23Rd18vZ+IyParFgwZtmizseIfAOl/rRBEMX+J0yj571gIkzdZTdoOvLghpnjLiJUr9Lv9qdlskB D8Ymx45nBdUCbubqmdxwvsLKp5s77eQVX4SvnYXRQy2N43UU28GHowxvCRbQdhSnX821N8mYeEf+ +B4YgdOQvksD3F5i86XM8/TmcUlnaDThhhdba9dpZubF99qMP/XPT2/yBt5/9MMfLJ8/+3C5//WL ZefVW2Yv5Fnq+F2aZfmI/eefLQcQ+xwefvarv1nu/tX/sdw9YvEbXNKv/40OFIHRd1o8Qg/9BCRt nYztMzmaO/uIVfxl0+W0MX4nzlJOvI8lpj8dziGjSLOBQBn1gXIk4hl25ibtcoCdnYDpU9KIDnnX RRR9NcWIT3tomxCDC7zaUXjxqr/iU7jmSci43qcPyLSlrtgnZzh5RZTwRBOFIG59LMxQLi3aCccH inwtUw6FE57FbXMbfBon9s8285+3dDt3K14ta5sYtY/fJRd1wRMm5EMdedFN+OILePvzOZ+xvwuC b09Pix35uuQihvMA41T/tN0+d1X0e/dc+fcnzrx4On2x+cksybyShaz9lATl6WQmaTXwgwE7dsvH dDCi3CB3y2nYZxAtiTBOICzRFZJVIwU+AtRhoTiZ9puCVa4IgdU56rRVvG1Fx2b91ul7kuLZT8KY CYbgwqcoTmYi7ORZBxCHgcRe41DmQED6Gse99IWawQB4VLrmtoO3jsbSsxlESvDK6WlyOfEEj4Mc 0fXbV2Ucjk1a0PQR3FtWyRU9pxHWgaGTJJxHfMq2DQB1BicGDUpWnaU3jr38j7m5wqAx5Y8yEqpy +NbmTUdaAjOmRB17S6aUcNJ/ftKIQCCJi7tOQFoqi/q5dYLDVmRwZBMyFLuVHNzhhCZ/0155aO/b im2fE0N/OjDlNoSoQJH6i8FtKveY6Xr1MpucsCDrW9LyxKu9BRgE1U+6l1XkT0/gcQDuZAw2aDsJ TTwzQNb1XSTg1hd0p3LqqHu+aFaC4hE8D4oD3jLZlm/tI39OditG764+PWHC6wDUgUa0Iarup2PV PvqGiWLk81hZxLvpfejI7RggO3Io2DDgsQNTpJAfCAktP+rAwYd6MHFu9PShYNUYcCYAt2KBfZMN AOS1yZO4wNEkQJ/no85KmvJlvR/2MYa8dqKyo69rS5+V86VV8SecdQYGW7alrH3l+oEwYFhjZpJ8 0Lp2L3I75vlob8H3vLihWt/pZ6niBQwoSnkaKKAn/ViUPtt+tH+yfMhzVfLnC1POSJxnPnPpW0I5 r/NihVi+ZvCR0rOX+isPrLKsu2QeC6z1lDg4cYDptuXLji0aVXganQYuwI706lUQ+O9ggBtM1YJC CNfRFaBhCae2lqcZZKlrOuloOLAKJP61uRWDf8q14UPnCXWp2uHrJckpMN/iQn9Aofpfv5mJ7eXP 1eg3r9+gU247Z0AvrHHoC/jyYfwmvOIHebpc5XRxTKqbP1CrYOBAVug+6B2aDpjSjwDv1W0xWS3N najdk3Dnp4JGv8We+ntoN7poYVZ6DhikufIlrdVjixXlsK3wXc1yocw4oUz6dubxCq58EIEfBifU u/19HtTI6LiBETBb+yqqe6eX+JQOuvX7iHyzz2DBuPeTDswvGo09GVYMfKUtHm1ifBDNyDJ1DMJY EGqMtMourgInWugDJVgmb+I2B0trmyyJ75argeYy88Q7xwkTdGgPSppEO1z0J7bHbdJRPMmSugfY fnR+0lC6MkAZMoljGyPUHrz203qXi/SXLGxlG2x0ee1VA9oi1wxyJ557eZuUpE+duLVhcQa8eZAC tRBv2UQdA6fcbsYH//vzSMb8uKl5+amEPsarSs+ePa5P9O6mFm1hRXweS8fxiD8/Z6724sBDfq9W PsCnu0KnPLr6gP25plQWfcJNLqSd9kHuOc3rr4p/jqUrHqFUkcctlLNXqNGxiKG9wg6PVLOpBvV/ y1VLF4q9iuKdDuJxYifbWy4Sibylx/RXpSDxJtfpSkYqHfzqx+/43eCbOLEeucVbC5jRXiDMdpx6 srXTl9WFKdOqbSFA3HqOm74bj0Jk3Onv7DvCQ71jpKePnrLoyl1GfF3ca1Mc/YhNnzVO59QK+i4G 7N3RJ49JSiF4x9YyZcwC2j+rhJOu/xij0o8F4Gk1HLBpI+GsE5ebL+u0WZsIVpgN91alLtSJGNVk i+g9epglUsHgkaLM4aPk+lpxvOk2FkXjZjkg4vY4+6CIgY3giCG/qzHmRaLAoDPjRvu2wI9djPcr VPyzn/6D5fvcPbfz/G8X7nWFCP5FTBFYOiezR4BYeFg+/mA5WRh3/Esem+N3y/1ppx0vvKRIGUQW Tu2rZpv4048FUZ+Nbz1GEBdX3OQf1ig0ZxHbwCmfztajLZwAUb00Nj8SJH+lbZFG++hT3i3EBS48 ARgN6Hgsdy7w14eAWJ+Whb7pllwnQ/x116vjwTVu3XuB0bGbOOXLHNjcRf45NjuZT8op4vXDvr4P YubC+llw1Oc4poSp8V1x0db+1UVS6OkfxXq8Cad9lR7c1mOrre/0Uc5D7ohwksvkc7m4nZfYuUBL o+6YMhYnLzK55VdrZlESrPhWHAE1AAAgAElEQVTSIc/o9hJUaBhTjhEwSvO4E36K1bHXi6+fl4tO Tp40Lodh2vC4Ih9x8UyvScqXUcg4dBWGgwJShVCvRuyE1GAGZ+/P22jAkjMV2yVkjZsBExylwIRX fVWEynJTkYfcn21y17HFb70JXBr86S0lIs9a4coxcUIUq5Gc8KlekxI28dA/NnihU2ZUPMYjiGbi w7lg/DPpyafKojJFqAcxZDzqhDNRaFKTgpt0i2h2yljSRF/S9+1qc2sqDBY8QMuDDLuBy/beZqWd nLiowIwrnU2/8NuEHJy2MS66DYHj0RW05ANV1ITD+ABc3CamriwCn8Ci4Suw8B6z679OpLO1SskK SAO4gAe3UNkTexUQtHQF05gXh98Z1A1GfUb6Q1reXVnB4VkR4pB2owvpFITyBLwJsGecwdiVRRld mR+7IK66dOJNzy9eJ3UmBicwBpX4kpGdbRTDrwMg9W5is94OvJdnUKatLXfy29UAjvWVdMQ/J3B1 FuDZbsPwdqWRVh80TvGfVpgIYnxBGnVGImET30zq4aO6qRC3iioxgbDJL7DmWWnpc8aLeq8FdPWl SR6rrwoPzu0jY13xIpk4KQRT8upb+Yjw6mvlbeQQ/3Twxr1uufFpOFqrntR/VG3LQQOe8Y7V59Tz 3ELihDc/5NwwndtiVmrKtDIQHWmuMm6aVRfFIQx06xi3NR3TqflyF/OR9tWV1Ifa1R9WlPCu7WEy HOw849RY1P80kTgPeYu5P6rOr5w26fUKsIO3JuskyGt+t5YeM1tmG0TRAoqvJEmz0eJ8aizX1+Vn SvSF4haY2cTw7kidbpu2FvHgRhur3cQVTWSwA1QqN+uFlj+PtZ/GkbL6Sxcrzoe41OeDDUM6iebG b22Nt9Hp2ErJlXE2V6dnAG4hcLAhnG1uLvkZAW7hQzXo2ashvK2UBTCvbolBWxuD8Y4w0/GqNf19 5IomPG6xL9XoUy+tkdl8NX5tvzH4hg/VIz4Nn4ZkhgPtUt7hxDioj1Bn/Nm+FXgnYzWiLWXp/j1e 7Luu15cfVQ/sxndE5E4E+rRfPsL1lQ70tPnoTEKx2f79fw9t1rYNpMHn3UE+S+2jMS1+gbMJorIC qyz6+fQvTM7NYX7s15E/2sDIW89DoQtV4K8FbDSVOblhSA71Iw+EE/8UuqOQv4lXfQZaDZoAQgfp hQ66SZCIKLbMmC1O4CYYyltc5jzbWys8e7geubSBRZasC2yTy7mSC3/mO18a5rP8wnT7opQa4EqT UnUUYjUSWPSV23GEltGXhO48Z6PCOtuuthhF6J8x+ZCj4xVgutLgXfTZ5zbMJ/xe9Ycffdg4wxiZ d2+wh2/jMjmhpX7FAaHhS/or7Xwdvy5eAFRebxM0zn3Eaya/5GhtZRwxIJ2FX+qFh1cXFrFGfaKL 7tJRpiYZ+AzYMaZ9B7ewuwiojuBI+zkmmVuWp9R630ZeXwp8i57xKnnHNvwpEFjahcnC4Se+OZV+ wFGzgNzgcbqf+hlzWia6Ld+s46SVhnbVW5QlXegtkutj3eqH7PW5+gL4lHr/JE0bxzfy5HOR3nru 5MEr8i4wOb454HlMf19UGjdMqPxJIXs+1e5EprzL+dZvawrf2qx6G0PDjzSMyxZWJR6f7mw3ujP3 dbEE+cy1vpnXehd1G3PTRhnYYXNwiMY98OOr1oysAqVnqiMWHXABr36wbrkbLsNXqXTyzWmifqvP h8BnXyQ+7fQefmn7UT9WRYM2Abmz1ibK5ZnwwvEPq+iBct24ykdGHn/28fKTH36xfKASeHERigPC vhk9eXnaY4t88Bc81+C75mVpj8hDpDQl5R/Gobn8lqPiw3Noq0PGj01ykfd+j2+TXVpqvK5mGj+U q4P0P3tzaneaJLE+hS30BvBKbC4MVaKgyKjM8EKdC4fazxjVb/Qt9aCqHnwIkYZVWqX/0Vm+AR6v FMMB6JzzcLcUNgFMUuDCvrTf8oUsOeGbXI4lAdLXPEc0WeJ89OEEUTkdK1EjsniSVjoRWZxR159S OSYb35Wy5ysD5aRz3sjsxaVdxnDKLYqBgXf0rPxdMAHG3yD3l4LkybGwC7vKbDtzqnl+pIOvcg91 4PWxAuPq1avT2s3YQrlSBGKY4cEnsp4/YG/i8hkk7+zWORocqRG2AispaKgTcVzQ5dCcwaGKKmxS JMaXSZJGDreyqYAJ7bmGSdswpqVSKuAag9M6cykBo0GdIGqAAkq6JkjqnPygn9poOHUv0Zksq1x4 A6EwxQswXh3SgD1zJV0NIS8cMyzk2Kt+xJWJD4Q6p5eMW/XkWCM1gCFQlGfPFfebGeAKgzKLzy3I csRkhAb7BvrQb3Ap/9DSFvIhYThOz/2GGmXqPDmAs2PXLDRPFwaEz6baCbrS3W3f8DA2U+hxfuUR f9jhwcD7/7n6k5/bsvTO7zsRN/o+MyP7lplkkVRVmaySCyIEwZBLkgE3gD30yGNBsKf6B/S3eOaB AQ88MuAayJCEKpWKlKii2BfJzGRGZEZ/I260/n5+6+wbVO3znnfvvdaznn49q937+CmEDUzDHrac zUwzHg4/dEItW4nrTPcHkv3DdA+MZrAHGJ80qMLM6cI563S/8zBXLlzzH0x1XAML12tAo3J8wn06 Dm6z05lhQT8m4JgOwkzf/NiD8JdP020ZB89d9k0ojCafsp252cQa8GMTCiUfxIfeuHdbmq+Df66j Fyz/8DyWFZRNpiS/tB3l83cYN/s2Zo8WyA7daUwEVfjRKZ2OyWz2Kz7wSZcr0IncdCDg8nf3KxvM 8WHFDreKCVb+HtOINjhlxsPEOv6230vlI8qnPno/fnTq9joXkEYXj/xScXX1UQNHDZWgr+5BIB1d /Kszjvn5GBsH8yP2c0evaLrmny/4PdHqFn6mA+qRe4qu3kx+/zpIdVAf+Nqs4/MF0ikKvwGQw6GD +kzPk7zw3AvxheUzMfWwraq28H7cM4D8I5OMB8I+KMAeDtG7WIlyJNzNwhc8Zkqjp2PDwx/Iv2sr Op5I/ZMO1vn63oVS6tS7IQhzdkD32CuiZLi4Gm33wWigURhfB+J6XmuyDfNBOhu7vPPiAv7ZreTV e6TSFbXLc6xRvfM9QvmByYSP+t7eje/sv1WP6ovHKU4dyt7JYAAGi4719HLHi+bho0x6uW4CVl59 xr9jcaF8PKlGU0M84s/3WgPZM1Jq+QCDw394Jo/6NE6Sr87PGsoa4v3cEF4cc5TO6KT8xexwQTM7 ql8+5Yvr6KA/rXd/OjX3uHT3Q2gdd1EWzy/+nn/++b0lW0d89BL41PswxtKxB2J8I31Gy6DtaKv6 h5E778dW8dL9JlMna3WzigBs5em1Ng59XxN9Vuenpu4XQ8nTtbQsOc4PHWkldqzNTQFHcrozgEru PniulYgt9jt0lLniCR3tre93Gu6nw/Apc+JKv3n8QQPdYg6+xaN1ZMmCijLJhK56QWeu/WeL8Qm/ lABFMv413ZXumIylgb8ngd4xfdzTr/6JtmDPVTcpYfePdgGdD3sEQPtk1c451rKBdjw65esQwkHv XVSuVYw++g+XTfF3JmKJw67c/MRgODC4dqFr3OsIw3ts2GpHfZq9VEqdWP3Qb5B/+jkTrDw2ohVf ujYZtN/7NhlYLMTzOtjlcXA+uE57dOcDFOSLv+ziALpVKc0C5gZA9Mpfii11vnwvPF8g0zghq0FL vPVdP4bIlBAOeNgbXvjoYTRKIwM+1pcL16VPePnMJh4qajDs0ZlnbVeuA+2XFzzLu9gULXjO1uqj n8X0+TFSfDok0VZXXPM9seZBfjAZJyetnrZw/dmKzi1ZG66+a5+C3S7E8Do2KMx31G07AnAwWrBN n+gePbiN1dHp3+TyAjE8bEUNjWLb2JEfr+srda3s9DcZ8sv8Eb/kGyuPaeEXZ9nkHis26EkO5fFC n3S2WJWd1q6Mdszl5vT6ID/PAskAPjpx0OV48j6Q7/3ad2/f/+a3bg/e+fAMeoGEYw03+oSYIJ3j 4+MmJBsa314Kyd5UvPqB6VMPXZHVVmYC2daszsOJ7vEb/B/c85HqIBk2gVYGu8umF3DOWJjvs7ui 0Vjd1oYUtzdWYLXKGqDxCYXX36m/zWe0n0S7fHl+PvzYg/V8x0u7mMBNV51ng/BvEY0s6kW63CTK Y50ma76jT3qXevYeXGkCChlM9KzO3B93mS3JwIZKJuNk7ZpfXnTIEpJkZOt0VF1/0CQRWnQhlj2T CFtYHa05aZPiVn2fvL336CHFNeHUTrHokUlceaqJ3jibfvAlnW9Nx5EUC/QVX3r5pY2N3mvQe3bS Hl7EKprbTqzO2zkhyPNgjRuHMHOIybOVVSUTNAh4lHsNiFW8E2gSMmYpREWlpM9bJYHPc4NzMCR8 YtbMEh1TkIeuPTC/NwNTz8mYQ/CkBb5wnKP7Ztc4gEbv47YvXY0h3FN4vH7aw+1Eyr6dOVRKyaEo yZtJZ8TKb3CXXLYlgyFBbZQSfRrEzsgwQRR8OCBWnuP4jV65V0VxbeUR0BU4yEq/ZBSs6GcNxAZG NezhELU+CyfDbLYuXeLF98n2FUhbsC8FL/SsknA8HMzhK2+rs84ZR+OYc4rxnT02KyXQoBIGPMWL CzqW5n7lyjsBGI5ujAw6dAJt8Zk/4Ldk22mn++jgcw1bZzOgW3EPqCHDfIcOvzzoqDs4ruSu8ey2 3F3T837GqkR6TyGKHJ1nO3bbTgWIh/A0cAs4s8VIzNbDa2Yocb9oO55V4I+9YRWvKmxfsh38lYO/ j8Ay3HwnmKWXJwhagTyNl2AQIH2ySrzwZTsilD26DtfdP+Dtpv/8ti/eDej3KSVbTAY2L4uJbCvl +9jx4+sOMtHL0sIx/t3bS+8IAOjootEx/w6/xn6NaQB0gt9NAgW3lcGwkh0ffNxW0ctXrl0F8JoQ MuC1Wq7TuW3W6UFdMBdJLY/rNfp0/XeONQTS44P/yPeSrhdbJRHMJmT5Z8uy+hyNlHXsU8b4P4Ku ceiePojLGu5mNx2cEvEixh284SqN784SntXayv1Tt1deemb+/cib0G1/b/X3Uf7yUZ2/4cFnMeEE +0Mv1Fxg9GMhvafYCIFZTGBIQFKjGajsO7/x0S1+peN5R/I45v+7PPKNFl2k5ye8uAOcCatILHa4 x0zYpoP7fz+Zdvg6OOl/cRRk8LH1JU9dXsfsBmUfDckp191FRizI2NdMN3iwROY3qsKjnrM0ELYj 4ek6PDqi3h7seVS2TpSOU5doBw5JOqeze3jGX2l+9m5xkQ6WHiSduVeXSluZIY3J8X18HlIpwz0b Hb879MW1YmkdRYMC1wYb6oHGmU9fPKj76qpthZCx2OIF7ID6kn18lCRmk4jteQYwrgjOyaol26gH duDYBuY5pT37GbB4T/cU5Zp9dWCZGWfzGPejLy1eyzxt+HJHW9ETK4JA2FeZDul4nv2WLvXwPB8s Df+zTNfaODKvXsU33yPPuC1jvpXeyC4vkF3vnCgcZL6lWBDaA+0b7qWwo4P+DXD3sjC2ySZWfa8J be0zGqtX5Tl04PDiOP/vtwsrpcSf+IT/6fAONDmVl96/1bGucdRpPLHDk3Ve2WZvX+5s0Kve7nm3 cE0MMuD983bARGyd22DmqtUDb/l9sudDt9sJXO3R/C2f0nHkIPB8GS+OPfUlprf40y/C2doZVyE3 KVqpvny+q3D7lrlUFsp5Q5+lRrflMteV2KNa0f/EdvHktKVwE/8wZg46h2dxnY7JCPX9s/oY06Nx MsZDBgqWBh2nzOopZbiPV3Fs/nWUX7Iyck+5K1aNdklf9hn4ybzv+GJ3StCJxZfVA6jy70uX4vfz vYTKYzN2o4j9tmDqG8Jr0UEwueyPCygOf10hEIy2iJH03MSEdazje/2o5LCr0YsVTcIaeHAsH7Ku nqVL4qIDB59bXCE7HsLJt/nB8srvcjoRKxzz02CGA211Tsa9ftHMzFZ60OujK2lV7dbvuetl66eO j8HGk9iGB9ScdhXu+MH/xgsVQPsAQNAVWEn35FHETxm+2x4bM8D2XC0Z06HJWUxadDJQ//73vn/7 9utfvd3+6KdevBJMcD2Ol5G+RF7bsMqU537YLiPPy38e35jg6RbfAnDV/+Tp6wV5xjf4Xp/G/QLB 8Rf9crbHX4iOHOGhP3GGDbUxj4WcwNd9dNCEOx/awXDxrp6q/ya1NvGrLc4p6BgknfLzCx08W4ws jT2HNz75Jj2eEiNVmaM7A5/Vjew++vgI0vVTwYSmAkcyMYwNvRQUuvl5tmVd98x66lv3ZI+7fdKN vLlmvk2X5yABHZFfymmnjB0NrowfTp8QfHJ/3ntBshezmrDQbV3/JP4Wb5QLlf4onHaWYN/k+b0y bExlJ4YXAv78V2+G56MmidvqnJ43CTDpGWucBY+03kgJq4ARe65nFdqAEaGjmMP8cQ4VkqCECeeY 1Rid1UGBvTc7VolW8TOoFUJjpjvv8cnxfFOO9AxzdZKgXTBJuDUcGUOaiscw64hnMfCCB6Pgn69q JN07GEdFF5ilc16ujm8DwzNood2U2f2piPdGspOKp5N6De6vmY/ParQu417bcelTh0yHn5EWBKIL J/2pVJuxi6XxGNE1SKU3kRK+40YMiS8ykHovhbk36sOV/Au+9EauOxwHlMWh8bCZnfCUNMXAy64b kCYTXdG+wa8gz05DNnuEtNw1WHkfJ1vjjVdE7of0ku4rznitYtruXv5UT4gulCE/XZogQPziRf4J lFHcdXywGR7HAxTpI5waLToevu5VzFkLjXQ0x6bHrvkV2BARpTJ8Mzydz4y1gQtb9SbFOt9WyKf3 cAkkO+irC1/0r4bJ2aHSCljP11lR0ba9rHTB4eqgrdIDDuX15kc8kGWrWXfdTEY8hnuNy3TLqnf5 y5tewg3nAjS8+KVngB18RL7vAih9pw0A6uzhPGpkiKe9aKNrdPnb0uG86wD8wXNsGMT0T69YMmGw Z+cKQgaE6yDIg8MnGqjviyc0fKKHhfG+/EObj6Cpw/Hiiy82+PYG2upoxHRWlHHcT5S9O6fTqb74 Syb0kgMNDUxCHnrdX/KBwSmEsb3L/gcnHsR8NNn42X7+4AXPC3HSyqtjHyTve34HrmeC/YagbVTz s3AapODtsW+H0zUzVXx68DMCjittoiy/FDfRBzudKIvv8gcXH+5dX7qc3dfolK6CT0sAskcl98Iy doUHvoOo+sJIR+84hHeqKF85xyWHa3Tcq4dgHfx5DWXXd7SHTvliIRlM1vTv7uPHJ/ggv/G2xg+C NZj0Mw57U2plDIZPvYbu+MjFCz/KSvFfenU7VFSGgy5IgsdFiJU9Wy/FKa1A+siGq9Pgws12fEhx W0/tVrDF63pHA43COfmRmTHIqy50U9wZTP9O2pg5MbqGSmfqpFQ0cPWfmS4drp0og120o1Z2rRZe zyzRtx08Ou5WD9dmpNOz8tuk4n2QdIhgTrU59ZbORFT302Oc0sFiGaY0pLjn38vpRMD+lGHfc50G jorWnq068OOKrX3iSzGwZ9yg84lv1Omdjr0E66p38qXh1hceDpQqO3Xjry8Yz4r6+TF60AeQd870 VYed7oJbHJA5Xar2qB/kKF3+I57ECMaHazzwpT7yLj+/7KPdjvJoHHQNVG3bf/bl82xa8m2yP5yb 9AnaKu4RjBzpYPXy0DgdzQm6zrNn45+uz8W26zf13BraJlKiugHnZgJm01OP/FzWaCWjTxoZ7zNS Am0VOWVOhol67K/vJM0EdqfxeO71V6zqah/F9Hbt2AEFBg0kdt0ZPbqV5m6Zx6/uScEe29KdckBc nuOUn4xlKq+cM5uNn2zNDoq4nx92fTrzd0Ro3L/wKjsc1ZPD0wpHN5/pa+DOkjrE3j5vxd3WZe2z PgLdb7KBEzrCPRkNVubf3IaPxG1554S3bFI9GX2s5VfgItUO3PD2xWcSVsauwfqR5dPH8dAjz8Xz fDbZr/v1V7GD+9ENAr5d0+XRnfqhvrgf/cogct4vEyU+Xxn9WsyvLYADox1rM7uj65VP5tUpsPM9 50OLxcgUqcmuvAkpfrgy8vJ7Mlzxbo9ALnAkCZ9Mns96Oele0AZRB/hexxczp235yY9/7fZVb23+ xVs9z9uOoafLqG9wr9in0GFqen/4sDZZ3SgtqPEg2+FdN+LTWYSLhoCGUDTZYnaKK/WR4e+sBlYM HFwnxfoMZ+WWAP9opGOuVtm1CyUfH5ap3sZikwv6GBCIr/Pn4TOuKj6mezqYbsWTrn1FUn/TWmXB LOaEms+Kg2rLcAalH62Aft6x59HZA0JVVtssZjrQ1Ed0t1qbDIGc70nEYbnBlLGr8a4dPj5wJhYU PDsULFbBKaZ8EixjPN1kBZ7FNT9v+MleTHvamCAKcQf/fmu9RSnt2rNNDuRF66fbvuy3d6cTesI7 OaP5Qo+QuP/VL3vZWZ8zoX5++k1945vGVOg/ZaDAAJstShpKa5GWie6zzmWnnHVc7hUfEYiR/dTD 4hRExwxZhVrFTBka5eethI0xhgl/gyPGz1KDI8ADw/vKswFQ+afR4BTwhr8TErvpv5VhKwORnBEE l70tN3xzrmRQZh1H5QXRIHUcOMQanhzgfPBlb70ORUbtmjEJZrCIiCDQ1a6tsrkuNExfFe7vdPLm PCwYgCBULB3jjLPBEXwd8iqRWwQQ7jPg5XLHodlhDkxpFWEw+9uVc8zV4p8/Sf+4WTDbns8zH2gc ODrDrcC8bQVdM/x5JgxdALTgiDr7d7+7eB2focP/Kpms8sdH56eauZlukl/gEDhVIp1YMGQAf8SM k7v8SxiV829+F9jxHbnBdo89P2W1FeX0xE/Zqt7usT3bEDd5nfDOhs6rROVbETiTJjXo6Uijfn6a IzxRWL8vQpfcFb1fdzGs6S84tNnnmWT2PKjVSJ0kjQj9bAYwyG0dCo6f+akCIhv0q7xuBASTCaeB 6j4boykoHxvc/aDyq2vJTaYFKijGVrDl0yc9Ww3H/4Jl+U8006ShRvuSC3022mROeXiGa9/sNJ+C g48pF1+uvWzi6O/ouP7hXvy0t3TWGQ8yGoKcoBuWrtU1PJ+gLg1UBfviiSpcoLFnnkrTAbG6Zcv9 eI4n7k9PkzOYqzGJxA551LQjItA6XKlTGyB0T0f4McO6utU9ufG1Qp03NlO4Y6sx7BQce6m7QK3q 7Bmv+Pz885enl4/bWfJhs4teiPXR+23DgisfmQwjMHXiaPEIpi/rwclzP9shrrx/0tx34B2zg+ny SjMhZ0Dw87fe6RUe//bxoJdbPtPW7Sa4rJrjaXFB5Cm+3/EgctGhlONHp96iu7oe6sWjyiX0/Ojo CMZKB7eG9t/i+cJ7cJ67QCYPPyGpOiTnUTHs8zotcBkomXQQS1yL9bYsiee5xHhchJsRS8CXA/+d pvvdSwt76evQikdBbHePGZrVOXWvrZs1sqsbNcr35Pkm+clqa+B+X7TMa3UFr3jHxjncoRBqcZ1e +h6/PXqTedlfbOJ3zz5tO6VHTQ4d8RqOalQ6cIV/gz8D7O7D7VCH9/NE8ReZjuDi93puUIoD3svH 3F98bYIzKitKd11sUtm5z367N/6kL16kS/QHt7Suyye185n1ctFxGJquxQ9Q63DDUd5iPruF59Rx MXFW3f3ZUtuk0n3wFdiOxZd8YfIEr46fyR4k7zEn4Jl9bcUpuf/lP7aVhFg9/CfH4kUJFZwEzr6T o5/HKOZvsFQM0I9YvBdDp+/ski2/KO6ebc21DdWTdUjxAmN/i1X8/rA0Hunhiy8+3rPwBkUm/gzE NpgKFk1bQa3GmpAxMaNDqDNHF+ufhWOaM/DAPJol0IF/87/KH0trSw4uut1zuXcZNrkQPD1uxYh8 PsEv7e4jDHEnsys6JNLsupzHIp6Lyl8yK4snH8dstqv+oX1Po/v5XDEgoOMbpYGRftqa7M33Z7t5 5vEFOs32/Fu+/s5LvcTQgPeZJiYNBIh4TEs+8Gj3zTxf1E9d3zE7j576eOcBXwpefC8ORn86JpLs PvpFBljk2Y6RJoqXc5UV2+LNz9HsUYpsz55nkgVZyDIDhPw8maeb0pa3bMSkOqE5dsvvurhBFqsr j3EFQyd4VVxJsivry9f7W3jZwDQdgtUOaKv1h7FFV/2vPN9y2fXKlnKX87zkqdg5SNBiWfVWuTts WHd/+p3Q4DWW4/Gr3/v27bd//IPb8+9+cLv99RslGpjEXLFs4f7yKQw7kuNRfcUvWq0HNl7TweFD 0StOpJQBVIYsCHYMS/8WH+78wbm8ZN+BprId4LRd7sg0vXZ3dliUBm94Fj9W5EDqR3uc5PMCv7io LZmfdL+4D3F/myiLHvHuWqpPi2EqaLIP3e75hURwZhMW/++LUOBWhwYMC8jD1yakpOfbY5V9QoIn uNSRwY6kknwqHZYO5vKh87gLRHcd4za+90lX2KIy48FNRmQHMn+s7esaTj8np1//oIWk6UyZ5DK5 SNH73PXODxd7w6nP8VS/Mf98j8F90Ju+33vvvfq+fGxoZhM6elA/yEDY9VMvtw8ac7lzCj2d2y9a gv8kpp9qhmUj9Wa9h0Ulag0Y85Rk1fQZTjzjaYxjtM86JvGqM6u9Ph3/0pVLwA1aQmA1x6rHkwJT Fd4WXE7GeSh1Hc7KoM0B4Gc2HRYwTz9hr3dHnRfCSBsNglUOfInp0FX5aEVDgOlmzoiuARrMaOB9 g4UarK3QBU9O5fAb6dHSUdmAuJJobvWmn2bCj8qNF1eHNrHIY8Dkzabxc28lOI48ehuvlcIT2Rdo JuBxtgqSYp2A/f5peXuDagMPP7ljhskBpyuddSp97Op3np7qt8504ODyOavXneEfvaEZD0pT3+Sg s2UdfWs8pndKGRCa98Y6eZRZ5ciZH1e80si1cjrPXX9u1Ln06FcR1nnunrJVig0Gpy/lSmMjcoZ3 guKqBDrjgRoOeczMC3tlIbMAACAASURBVARCfESurXGe+zjPJWkRVLgF6VB0O77wxEbTY+kGlGsA U45KuLc3Xit6UZyfjFf84aOz2cbHujrPJsgkN/4Nt/HpDZBBjxZ72WGR0BNrDWEG9NkAPrg1ivDG I5keH/TVgXc8nOvuLy7CmWbWEZt86uL8AfV4Vv78jZfhyBYsbtB7ti4f/Ww1oGdeT1r1pGBCHvpi 21ObDj8XTuh5JfldrUOQr2iQ6Na2QF9Bn+3wyHfB+c6jmxxb57g7PiNerY6kN4OHScueu7rrAqzO Z2cxgT8BkCLon8/hIQEIuHz/Kjmd3VUzrDpS6urze5nJ8fHPn2871Wf9NlKyfFRd9EZoEysffPgw HbEtzqIRbxqlBJ6NkVrHvzN7OlzCv7sKTm9uTvZ1SifKfnp7/41Ht6+9/NTtP/0//4e3X/vB6+nQ itEztzeaGf+T/+nPbn/1Zz+9/e0fP7z9Za/7f/vWTPnw326vPf387eVXe/tviHQYF/fyh9WbGFNv +IcGHDfjI+bUsaterE6AK3N6DfdE6cx+vmAXyzDs2z2bDRA+BeDHw8oE05n2P0qHaoReEzAx1wqw AaKzNLFCHfaB6/i09GjD0gzNoZG+BIBIi3d8B29ir8kbHX802QriEwvxelbvF1uC5b/YNxiH+JKP rPLcK6Pf4gtmZeTt9uh4NMLhmfUXn+slOXTTsdg4PsRMCI4sbOBt1Kvz6HePZwLhdfUlfIv5dQpM Emi72VPnwhnseOk8IchKc9UD9QpPY3LJlDD2uzs2U9ax/8EfX8AM3z6de++T2HZjsSmdfB5vJMej kmdwG5n59rEztHSvfTSoOz93I+Z4PwB9k/HLTqewtTTywE33sFf+qBFCPsn/DsPHnl0TsMTHj4qI Bx0nLLBvN4qnM+X3ltFiPX2alPA2cvbdQDU8+gArW5kTp8gmftErPyCZo3P4jhXy95WLbwx2vUnQ eOOv6w88eR7RCsni1jPaiftAf5NAtd+PHoVP3FtnJDt0zeYI8v/+73sGEsERPXoGzNpE222vlw7i 0EGv4qRB8Yr7d9flgfD/0nP6DefogXMTXRLP3tM/C512nm5L2tf13z3cqjuaef2p/QyJxArwM3rC GzKLO+n29G3KL231g/5yDu2+7ZrP9Zudzz9v63I7SHKM4W3iT4FNgHn5aDjZ+ehLVsji3z05+B9Z HvsYxqUp43u335jA7lj2vwNol2KUnwrTzWFb7fqDJ+sHWrF0cCDAaM9ubtPbnRYQ8l08uOdfIxbM +ksDOn5FV158JX9+TI/dLIZhLX7IZgLqma49Yjgx/Iu+Dxx4hwMveDNVOht09bj+XnmKVkeV5RLK IbuXpEnrXtmrz6H851+IuQZw0Qdzt7MXVr7/3oe3H3zzG7cffKWtzX/x89vtl+9EIMwNXqqMnMBK Aqd57HcxvUePvvD+DrYZD3dfvNvwyQ+rVx69pAP07jqerdPy6iNeoQj10e2X9maTtSPxa/AFCArE QjmhJwe4pDvxS+skK8D+9rw+GaIjg142vrl0X1l6OuaYNSqXhvhksHCOj/hX1mId6xyEYv7YyZTH 59FV5uovGif0Nx0oz27q+357Oq438K7s4pn65MsDg63hjIdDtwxaiLfS7rx4jlrF5Furl+HB63Zl VS+LnouhdGvybjjjfNvJ42OrsenGDjB9rWdaNLVTy3jFhJx491zvX6FsfNnxYiLLhOQb77xdn6vt 7c+8WP5dV6wQ/TOZEJ3KP2XFCmEDv4/7sWeK1dF5VONFeTq2H3MwAsboaUjbKtK9QbktI48Knp/3 xrRTKe0Pf/r22isvtxpmRu0EoCuo6KCsA2/FN2HTzpfOFQ8bnCyQe57uVDJKW5BJSEoXK06jo9Gv 8x6mDWQz3JbqGYAcfdbYJ5+zZ13XyVTFSuMmm0VPsPt83BQpzTOf2xaTDQ3eKc6Wt5k5PtmfIc2o n0BZAk4E1DI5kRSdAccUX8N5Gu9yorkBDFrxq6LgV/uVkJtN2Sxg+pFkhQHvCIM9M72ddRJyBjpa cA02qB3oX8EZb3i2MrSfSEKte459BhqVQqgvHQoKbHt1vFR0GtNwOOA9PJOz6xUWi076QQby5Lvi O6tIlWXn8wIyTNHnsf1kuOdvha1ynjPlK3ToWMAnL7rp5NhUJSDjvYJHy3EFB8+gXs886/AemtFe Gbo4uC99TA/lXZ1IHXIV0u/wWoE6nZlkuOsqiw0XLInSl1+SOVpdzZe7otfj4583AdKK5mCOXvjk 7A9VOZe8B2c6CtYBDr75FHzxyRazjWu2yg4BfilfSI7/lJw28UhFJ6DBzCa2euObXo9v41XwFcHU ISsDnrXxAjCyJNFsv2dcuxPUMAoj+llj12x1krrC25GwldOnC1iepzqz71slv9f7Q7bgWx0xu8iz BXI6/6IG8DMz2PEXq+OF71w6C7A8cYNviW+Hg6sOrUOKhwqT48SDEGGt71YJuuBrGujztlNcpzS9 F2BHjPmmNw7GZDOVTxSEi12BfPLZq9uO89BW6AbCH4uT6vAdL74h0TjAxddkg+Bvm5DBH34qw8Y6 33zVC3wMoH/nd799+4e//f3bP/4HP7j91k++W4NQUC7/ySd+dPv8P/qdnrX+ohnQT29/+4t3b3/0 R392+4u/+Zvb37zx9u3Ntz+5/fKNh7e/+ODddcQj2fHE7RuvvHR7Mf4zSTSbZDBox1B5HGEroTE5 3oKg/NWdaO45P0nAd1Sm49yD49Nk5RdXhivfZO9z5SkpdvL61dfqrLJ2tDxq0gqc77b7Zr/ne+6V TelXB5ftxUh8+6gv6jbf59N2xRg0GmQtL1zi4AbJOJlch/+Q7NhLf/AY/uuYH+WaeCuLGErHBxwH it3UsyQg/OQ6Pn8G75t4CHQdhcGcgnzBUQ2sPM7p5MRf6YuDnfHqi84ndSTpxSMn2yL+VBNJ6U47 TjfgyLujYLOyaQVf+CWx8kHe4wi7zPTRv2zofOCUB0A+CNSn/UwUgJW7C9E1PAhMZ3fhxrOYUtuq fVhcw0uyHBufzhfFqnaZGGGYOmC8+1JXa1suXoLhO1dMGO3DwXBMX/Gqbs2ekwOvdNfKYHqzwurn /OY1ixHpiy3pLf+Szjpwr90QO6sHs2PyWWWx/V47itB0lYyLN3zxLsfSi6fOSRu2Y0uSofIoH330 WfU9HvQfxACw11dsjEx+n28UfyZK/9hcvGZtsXuPYrQbxcseTSycgQvWohkvpBlOasjfThty9H76 dqXjCYGgp1PlJofSd47FMbmDgzq+p6p7uXs6nMo4zdal029D99Ef/vTsOO3yqWizWYWgWceXX3Rv 8PR07YjdQnbjPNPkvnKzEdzZys+jHcbhPTJ3Gq7F3PFewt3PThtHf5RCx8kWLvSkrcw9Hojfq+PB 0SnKzuqsOLNVwRLPynAEYmGDQXbDG7z5zQb1pahLlIOHrVaWN44P4iBCwR+7P3arPFjtZYnkJaX4 aSXx9OCk8Kr4iLfZfndkGUuTjUL2GF1pm9AKr/hx9FDiMUIlj02GAsXstT7R7IP/JHPqq87gab4V bZl8TP85sI5ous6O+jA/+eH3b681lrj99S+9DOJ2e6G+tPsjwnSzYgobHFX23Ycf3j7tDczr9x2k 4xVlcV/Ry3bHj8WAbEk2/Y7pnH58/V+J+ccpm12DF6vEI2VPZJ40s/HssVon1us/4Ec8CyY9arNs rT92jkJ5Bzc/ABPOJjilz+KV4wPjKEV+oQ1QoO9k0fZ2Oy8qbXjBR/co/8AuPflW1DmGpgO+eceX R9RXCtPsm84Sho+qR6OlnBgWD77bQRut+fsEPHpICH+Va3K693iwB11ZIAFrchR7fus6oI0hKWj6 HzOZWpyjO4Ad2gh1CRnjHiwaGxj0wv9OP5mo/2qnDB9Sh9emVN7W+quN6tFORqMbBqe47kp7NuTb Gx+Dym9mpsKq8qcqVLCnUt0b080AlFhxz7q9lY9+61tfuz3nN2DT4QIfxSXgCD3RzCVFUDbm73RV EI3GEtHKEc9PHpVUEMevh6F1aPAtiAkWD2qk5gSlfvFFK09r2HOGBvWwG5zqqFEgpyRPej/OlOzT JH5iL4wNDIMJxxygaGDlewQrb4ZCw7gKWzIDLhAGQFcqgf7WHCEjnG1OJgMi3N8CNbmjR/uckVmv 5xDgWwe4/f9X5+l0uKKFu/SzgTbr+yMQ4R33S6dzGYX4JxfHNbhwPV11cYI6jk+ixnHogt0AXSWb fnPy6LlecOj6CsqC+BOVs/3uUxUQXMQDnVzO6J0GSGf06PtU6OioBFUkXkzuhB4tAnixy2pPKNiO voCsEag2zm9Koz/Ktw2afa5AcgZtfpboPjkQ7tNZDHnXs1t6WAMfig2OYr6czXiTTbC2PcrD8k83 Czkd0FPOe54TobuzIs3H9obEUlbJ8n0VLwGnl5JPMNqZrlfjiLo6mAoq100X9IhHFZjuF7TLdO24 BrnnLlC+LR+SO8y21KubdFSezzm658uCcTLiMa3FW7aJ5lXfQbPN6ksdKNtQpPFZOL2V2oGH8btr 9M/9JoG2LSmR7jKBM8lmgGaG7qzAVhAv8LFvMMffjtyTOf7551N2E/C58OEBPt/JNx0cHfNp+nDM T1wHN96UZf9JI+bwoLDBNdlOmcUr3nWX847usX/Da1Idz16IJkjv2aXs/qDVGQHY78epG+Kin8f6 sIGbHRrbqhjN1cEQ8+bxBmcoq1Hxgy8EwtdA5sMG0I/aQv0bP3r99g//wU9u3//h1/LNXuzQrpwf /vjHPQ/97CYl1NFPspXZUS/8++b3Xrz91t//Zjr6rN/S/eT2t3/97u0v/+Jnt79585e3d9/98PbO +x/cfvXeo9vf/PyXtz/8WZ2M+/HU0y/cvvmVF27PNag3rv/cC+Da0ULo+Yh2Y7rhS7E/30uW5DGA dEy+1L6OgoQlHztM4NW3XR170QU7AOUTgz8TcYpXa5YuDnppoZKez1/bUGOD3uHj2PKaiFMNP2ti V9ug0Vw8iQ5fclwDy/kS9vhKx5eDxPDdZRSH+SJa3gq5wdr898jJnw7/l4cVQ/L3559/YfHhjnry inHnZ01OvVs8r7CSq8/FOR+e4HwmTuUdHvG5eEdPyoXP4xuLO7PHgSOnVS/lPmoXgnpPZ9obx2lr +GHHcLnie+JKSeKCH/TtODQPf2b3j7RlBEg3GME/Hbslh8/a6vKk68T4OrZrJPxbGUqn14v6pu81 SNDgbQKO1xXsH1+brZKFL5q0xy8edqANJl2Eelj203fxsHdRBK9z+nwrCDpa4rc3ikrzcyb8fAgH TxfFntFKM3j2idT8pDZB++QwuS9GW9Fji6ueb5dBahGfrsdSqt1r/5XDuhU6sWSxaMKkz/yNDfR9 Tiea3YP+hE6UFHMiHjO44uMfNdH28OHD9Gxi4TyKshcXBX90eddRdw5t8XxuMpx6wf4bkB3lBXXo TvbRutOEonuxWt7ZeVZ8kxy9+W8wi+VwXEx3zR/cW0UiyupVvIzHwZ78ABcXz8qYlw4a3DbQtQW8 erjBRNsdxT/64pfqw/wwRtZuRWAxIj7L3Hd9JLxHnblnUPkd0/F1Lm22735y3TmkkwiWqoxvvNfv Whud3sSsT3T+2X31LkrTUf2M/InT6Hfi56LHFkMVNqtwx15A6a4jWLyQZf02uC+eKVy9CRaaiZSf n5Js0lX8rd7Eh7o/n4L3PiCD/9j40JIFXhrG8Ok7iUs6MRds32Ckz5rBPD66xuM0lK8qj7Zjg6jq it1RT7/wyu23fuNHt+d7tvz2q7Y3Vy9TZl8lg68OVKJv95IaZ3zUox9vvPuwtrBBDz3Qf+dFrIos fkWLTVZX72w5sfzVj2YfdVM9FTNXb6PpPTBoSZs16LsPdhY7w2P3FXx7xnVyqQ/ZJ1xigK8Y4506 09fK5qfzi3jIlqeulICr2fbEDv3m2TeZ+PTqenomiz5tmlxZYwNjCT5fpFi9YHfszF+6AMMn6/iM 1/0cKD3yrfla1x2TC73SKzw9XT4mH38bTJcX0VIgOSf0pIhjeJx94QoGb3T+oJ2T+pDagQvXGE2+ p8vT9zV2E/PozoQWrPTJd15o4chPwr33/sPbL375dr+f3SRv9icH31uf2TX+yF3p+psnOBLnjKxl UPjxMUKLo9zrbDNNLMKlbGmwEOg0ujqoldY5/ujd24svP9uqwcsJyHhH6TodexNlSFXUcUE7lI1W 6TqLDMxAjPkgnECeaBZTJxLsEz2QtsrzLJopEFwGOC8FwVgswl9aDA/vCX7xmvwnGILR4bg3OCl/ TkbBpdOEGTIP239c2gs6N3sJkgF3lTMjaKR17h5kpCfpIV7L7O8YcgP4kjSkLzQjIajPSSuvIcoa 8Y2hI6OAQgdke/yCkxgeX5QwWY988OjUoncCJP20DSAHsu0GDqhPp6BOa43DZv/Dr2KdGnIcg+5K DdFp0MmxBnAGQqJP9FdsDpTpgJfOAeEy48xf+NEavXSyWbv7KkNdrDGuYm8Cgv5Cwk7KZaXywwN/ xxqqrvFq+8M9sYEwsxIMnMajRo3PlqZi4NEXDwYWyp4VSkHjDDKpkrh8Y6i6nA1KSwXDfyp32ymq aGwnUBm8KLfdAIrjT0WIlnQNR+zs4JNYNEEy2SNKplV+9QHUAPLb0vnnkrKPYw3KZBSb+NqpI9NV OpQvgAji0xUdln5dXzjAxXGweLzjyHcwDNe1o8GAhubYXv3DjjJWKnRK+fuEDM3qEFlHMx3c+Qwg rPB0BtdHcF9g7EyyPet/n0CgYw3TiR/JCEZ9TI7h2cBJ/YSztBAIyjp0m8gKzrPV6NutIZiv49vA GK4N2OOz5GPfxbZu4It3qlGPHs96B7hJGdTokn5KW9AHrFzpK5ie8DL/NxBs8EBDV8OHR0Vm1exn wumZgnK7WW8ftD3czKSt9ROtcjrJ2CT39EmBfdUVavjVG+/evvft126//Y9+ePutH3379tXXXro9 +XzOGn9o+AmiZ72g5fPTMPQTxJNb588jIbb1f9KPvb/79ge3Fx48f/v1n3y/jlj+mHd6S+vbb797 +9nfvnH767998/aLX71/+5vObzbL/ld/+rPbn4b/y+PZ2zdef+n22vMGBk0qqnNVSm8qX72P/3lX rwLd9r9ZXd2+1+GEJCfdOE5d7uJ+P6bpXGZnPjJfn74vePX41IFNTISM31/1aDEmO9HdnoeMR2+2 n611noaar93rUeXFxgWDriN5aO762OPUowrGGL/GnwlZHTB5bCbWuL5sCedzbYnSbnlL5XxHWZXr ftAFvWmHtK1rH8L1WD5X5YktFw9onckGuKapO8+pjN+HD/xxvsoHrxOn83CeB6PT0y5tgre3sX3W gJZUi3vJcWLZPe6UHsry8nO6SdejOhKVkpwuDY4chzeg7Hh4VK/EkY9Wd3X06IpKxEnyQBJ8hDot Ha7J7aJjssrsWB2pPPyn6G4QPUfIR797OgG5bbudAXk8R/vuZ4X2YqrsZKACTvRZHM2vlR1/+Y02 bi+AG02D1qNHBLXth/bR9+FP/dUJP/auuWfsfckidVtQx+k6ZNVGE6jFt8HSHdxHH8eOpSXw2TFH lvLZO93ahfPoPpkg/lAkX3DwJ18Ix1t3xw9pCYD7A+tW7KHq9WGmc3qIj7KABQ3oXuaiQbSD//gh Pxlw6CqsoDqHX3qgx5CyH9n4OW6kKbedF/y4rwUobbH2VH2yEv9sq7ng4fEVj9fwOE+7bNGlPk8X eJewttl1dBa1g+G/hyd8yuTzuxg/S+l+sWX8lTJTnjoyP0aAWB10O+nxHrx6ncuvfzeZI+O5zrPV Pv7SD2rqFr6mg+ixydUWEXULA/gI5ssj2Qyk7nQ22CYGXOmUA3HBg+cwOH7DAydMQRycJZ32GDcy IbrbCV+hOy6cMEuP98EAPf7mkajFs8ojMVrKrq7jGq0VZ5pgKheg+qiv9vrXv3H7/ne/c3vmvX7G 5q0GvUK2b3V19tUXwfTeBltaPvFJ74N42OTn88VZPrKxSIziCd0qyCkTHTXhHsHmd+NxPJ1FDq56 +qN4ywb7RM9BLR1bjKgMuyovY77Pv3xj8YrlCOMD3FbOc3i2OQNXghw6By5ds9f0cq8ngehXU5o6 PuWlOHbCZ9CLkxzs9H8uenG++nhsNL5iggeQkU6vfirexNolR5z35rGT30Ti+E9GtFxPERO8e2d/ yT2fZ57xd+f/QK9v9dRTd58Oh36hlzRSDB/RF8CvLz2FMp2etgjJ+VFpgU0fL71k5+VTtzfe+6CJ 3Ee351586fQyFOzQH9hjtPwhvxJ/n1onPoJWWzjGJ81UrNGrACe031+ltNJ4ZiwzcD0wwcVbucZI /zyr2+3uzywHOU4Drtzl7Dq8M+aCE8Xd4WJOwPmiQE2IUuPjXi41UrKKfBynraE1WKd0NNeXEjAp TEVMKcGqnTP4rDEzh0NwyE1S6H52pU4nPPnXcHMKQSKNTJY5RD8u9Ux8fcJLGpAT1KzPo71JLL7r 3OF7HWAGC6OtsGb21mCkaW/itFL4bLMQa5iswJR/Kkc41iGJ9+nQs7LXoP90VuJuMJkxR3nQ6k3b zpsF4xCe9cG2Sr4flp6u6OMM6CiEujf4yvgGGVNJ/ziFY86VfEfHpc8JOXN07/BnkD+XX+U4g2Kc Hd1xXLbfhIW0bMAcT2j0E0wHsezxjyb4Y89jE9escfgLV/lgGCJJpl/EpFu5PZVCBabz4OaXRxYT NPgw6PWcpZU1nPubsP2brbtFl03X6HbNP891ncIa1c0i5zOHF+4Bpk5HdQK68/ZBsghCwI5ctk/C ffGJ7jqNccw/1pHVEGaCspIvvNGBx4DuOuBjS/UDq4eOEuGjlxoAwZN7bsX8KtgZ1Dpa4ZCvPHte HaE4HRDddBXd8oNNfas7XibjuS94Tx1WU+RXUj1SHHCHHAef3082BOd5QY309JCTntVydTebVrYa O11Pn5yl49jj2P9qeE5HqrwIsjV9FL7m/9t50D0+1nDmd/P9CKgr+BEbJp+B2epWxStjew6jrYMC AJT70OtUnliYvujkcUN7PI4uJ0MKpoGrETRJsPvSKjYa67hr0PPH92uY/Q7wZFK/xKBi7PiJ/sUG X8H3ew2OH7Ut8ff+3V+//YPf+u7tm6+/sm3h6pWGySv6PcfrHQxi1xlMxFP8w2ViTt1/vhj03Bee h3nu9tVv/jDnfu72i5//7e0Xf/3T20svvXj7ez/84e3HrQa98Yu/bvv0O8nw4ParN9+5ve8FEW2n frPrX/zsjdvPfvaL25//q5/d/lW4r6MptX5P8eV4iFY8PE3flJD/kO/8HmI2KmnfFMPOdOBDaun8 YEqjOKlThksXpbFDZdSB4wPHXzWe4NkpBrrmy+pWtKPvOHXx+IY6dX2l+171FmWHtOssLspX5/nb XlKVjOhdgyDsbXKqQiZ2rap6h8O1mhfLi4FJEASZO+50x38JFw8nTminMldgi7XR4kfkcpAfi9OH hG50eIZ96kgmMaOsSyYXJkXhcXxSG2KSee8WSG9XPXmKT9/bpEObDSucv6rzm+x1GzX1xHNXbN3/ 1J+dXXTQv06sAZhJBzp9zH8K2SBlgLgMr0+8zzbiSsnkhGfIuyeTWEZe9U/GZT/lLkDl1h9QcAXi LRn3W9HZhW3ONsNj+/FCL3fcii3mlqR/dK12wLV4yA/5eXzwYbqbsbq/DvwshpBbPa8vdPVjKGn+ L0DHq9phEkp0wbsYupg2e0chPqpNy9dW0LlJBBO99Muusy39TA/hDe7yY4Ltmjr6YLOUsUprrhST t3KuXMaLgz8QMDZKXIarHQffvf6VwruBmGQ+vqZUCSE0yEdXvZi/iX1LGdljX7E2WBOanqX2s12e r2avyRBLeT8Djb/5R7dYZfO1h+VP/7BnG/2+MxkTn9AHf/wPN8eGj3US/FyGApSnx3OxushG61CX LRY50AKj7ahWzHZPtaPxTHr0M21jjm31gcMXHHrT9/7jtzbnrm84Rxftvnid7DI6rmvlZ+/o0/JV fmnKJeze2zLm6iuUxov0/dfnmPTsMQmDHXbKueccWpfO0OWrEQp3eT6luRqt0mfXQGjvsb93N7mD kwNmOqvscKYPvBucfK+tzd999bXbEz/96e32fqu9LW41GLnH9rASFHJOZjBY/fRem4/bxfTsK2J1 +q/IbMFHpuzupSt8WBgOrPOlrXYaVJdv/ICXxXol5sxBhXRk7wiu/jMcfGKyJtcmQ7ufWipw0Ydz ukK/49IfdEeHxxtc8wUMnvSBH32FAxOqo77/FqO616dcW1DdsYsHCTtZ2Pr8xvChMf/IV9Y/qDw9 icl0AO/Fx9WXvOr/YNBOF2sPsVTckTQ7pGOxTpW55JSFzqSiDN8S8WnyFZ5PH9ZP7rNYy07Fgy1O FTsev3MgpBb04BUTxcZnstWLFhLL+6B3lqyfE074fTfpcciFuzbbLEQxoA23rQ6mLA3VOgwxNaUc 2kOIiIrC7p99mjOoDD0MbgV0MvRvHelE87t1gtlHXh1epUKcUuCfMhfgkj36o4e/BF+nkOESxldn dEYp/wxUzyy8ToeVUUHNNStxYg3AUw+8/fJaJa4uzIHRRQvs6QSfxi1elZYZBry5D9Vj+bfiEx9W M8yybKYgHCf42DagUkSfw1Se8j0Xqe9+OsgZ6E73rbd+VeB+cHvlW9+oQ2SmMplvrchQRDjp9oOW 6H1jZ8v4Ok06yU+lRzNnVlNEyo+r3B999OGey1ljXGFOBI//eIGvW+Dda2jNaHtltwmFdCsQ9FmH plKz8SoQXeEpBMnD4dl+jlYqpN2Gr0DTsdlmacDvnzPosX0dP+xSEFJBKbdjwbjzqRga++PwKx9t omzlLdqxEBwb1UHjE30Of8qU2f0YconPGDmD3SYF1gkw8I0unVSJILzok2M66P/QRGfPD4cDRT8b YoWXP9IXIA2nJxhT0wAAIABJREFUMxxXgFsHqALk4ZOHKzY5W0vwjC45rXwZHDkW1CrHn7/YyuRJ OzKfAALHadBxNDTdm+jAeWl0kG7JLXg5FhhCwqdPIJEfdGnroAIKlplJqtN+fFc+vtNZkwRk0Yk6 /Bx7r86WwMemkcijc+oPpOjeGz1k3Hf2QhFbw62onM4cm5RR/pHn6KHC8XNkGf8CZqDXyjp5+fR0 msxkXaDvWlm+YVfG2Xlx+LlsJWao5RU5Abc6LW+d8ZQnRlkRTXAEDt70zOsmR4Tp04SEQSQbrF4G 2+WpS8olFj6g2gAgmlXjZiJb3W0AKUBroPaOgc1LBljrrI6dTx2Q9hK7/mkv8PjNH33/9jt//zu3 n3zvK7eX2z1jlefJHuc48TM/bGLGDPdbb7+dfqOpnu/ZGTYLSzx5To7XvdsLQj787MHt9W98dZ2E X7zzzu3/8f/6f95+9x//e7f/w//pt2/PN/j9JNpv/pv/6faj6G52ORweX/gw3t996/3br3717u2N X73Tu0Ue3t589/3bm13/1Z/9/PbH/9Wf3P4gGv/28fILL91efanOa3HPtnYdBTbToZhxS8Mjf2CP xf3S2P9klFc6f19HqWRu/+Uh7qYHEJUpe7oT6/4u2FUv0HCwzYhWYKVGDh3luRN6YBz4KrVM9l2H N43Ozny0PLxZZXjWQHexNv9ScvTCWz4ev/jiHoNLn4jBoDX7J4cYIy47FiMqs050/8EfXi685x5P u7ozjySfVGBxsoSLR3DkRdPWMs83a7OIOrmivU5NZfBBrs9adqSL0SdUx4lfyXSPqxxM+TOZfHaH iB97SZgy8bMYeISYPtYr1Z+o7AFJD67G/J3PCuLjxP3S1ONwkTHO59dHx+WV4UvmtXHFkg10s4sB lL6JCQn2oW/HPXTUh8GDf/zTT2Mke/ejozKPQXYJd2DaGb88Af/8pPy8Wu7w4mnfO52d0jWC186R 8RkNUhNq8b54LL6WMDm1wdoYE5Ame/UJrvqzXTjlrS9UGbYSf5Wmw8lDQAfRnOLrYD++LItU0vA+ XV5Fwkmf5wCljPJXWuXKt1J3kE6SAx4dMUp8V9ICCrNC95jH4c+O6fK0VfVHe/uubcsmYzxW5NEN /SV0tF/b4YMmKvWf8tK1D1e7c9WZxYr6Y6yo/WPvM7l42GOPw/sdz5Rz5J3M45NsZDh+NP8NHK5j 8wrNVwOWjqtoEThWp6vZoTT1PwHuagLPd5OpMnwbzSODeIjmqdWn3gVPhlG5/uFBjOmsjxX8+K4s 2JAcHC6jNfxdydrjYWjipj8QBhrH71Z08McXLrp8I66zFVnodYPBKo66Io2eIOSzyi6Wu59sdJm9 8kfwI00nEwpflNZjIMn0k9/8jdtr9UdvTbTW8Q6269q0KrCZw2hcEa/L6rUXXD2sv/Leg+ytXedz iystbnnPQXypQ3QUa8WkrkNDF1jWUtLh0d+X/JIDW/2BGFnlHDuHgJzTh2vidL+2bYXg6kKdjxB6 ixfSaLAErQI1qCvrH5bGH+BhX+MffV91RFw+fl2BHadP55I9rgnu9Skro99PwYsX6YeMJc4volDs PnyduhEvd7tpT8+Bvzuf5fHFyRdvx9/iWee++3OUzzZ03/fJLRLStxdQeTywl36G23uITD6S4pMe 9+IXT/fOJfVBjNuu1Mo+qhxcnzfWNKEulGlj2OnZJsKeKzY8rF/y1ltvrc+zBbOppnZIo9ZBArGT F+On2H9mzhgLM3NcbEcM8JnhpBzNtY6hyp/iWxGwFnVeO32cxywag+pMPOo6G2W8lB6Dqeju7F8a izGw5Hsqb/g1aAytBSq/ohOQQxBWGqVrqDdjlvM86J6wOKQV28kUJLRZUAdl4i/WwsMIVlkZsbxw nEF2/Fy8pgsG5pSrqNHgbEhgg9L507PB1AWuXmoA69DVOfDCGg2il2FpDI5zBFOa1dmntk2b45nZ zRj0GQ8cXSeBHHubbVt5Po5PWtK5NpO1hvaB3wvuhTnPtk+ys+cE7Wnn6OwXizuvQnWjg26FeZMA 0VhnzyvTkwOMgfuCUro4g/Vj901azO5pPeATRNiqb/zueduYu4Iz2g64Nghjv+73tm18hMuugZSy dJYhW+DD6Xr2dSIHG5Q3uOjjgZ8OfzjYReGLPr/Yy6qqIFbTVSy/8QhuwWvUTvnQYCO6+EJDBR3Z +eAaW5VS5n587fCcIx2myYZxssQk3reCiOFgDPzlj7dgTgc78PCxu+1rKz9R+X2dsOD2Lc0hX/2c L3V/7IlZdcswJv3kcwtUlFSWf2dbW3IlEHzX4XL36ASnSErtWuCszt+/fnpnW0HFAA1hSkLPMZ7j y/moIqS732nG2qRUsPjdq+LzPc9idLsytKVjLzjiybETgI5cq7LVh+TcKppAXdaRhf7c8oVjA7zI G/5k1snic3QuTSfvdLzLA9fH87diA1/2DC4GNhCtgEcG1EOH+ntto65yoDq9swGaYpIO5xlgHbv4 PVKdrPEZDQ3Iuya0eqbXiufZjq3xIEe8BOs5O4+AiK988c23H95eLAb+x7/3O7e/9+ut7n5dgMdR 5dLPFzXkR5tne9B//4d/cnvjzV/cvv+Db9y+9tprt1d7IZVnXV7seWIvdXmuXSZFytsvG6C++q0f 9QZDL394WEPz5O3f/OG/uD3/zMu3/83/9j+5vfr1r92+9Z3v3J589Nbt1Vdf3XbCR22JpqDnX33l 9tVvP3n74Sb2ikc1Vg97W+K7DXzfCu97/5cPajfoIHn7mYmf/fSN21/9ZVujf/9Pbr//07duf439 +/GdV15pq7eBcNsT+WD+ZfcMPyjqdvZhY3626H1PC+BuQ41qqqr+HvgA3N7zO3fDRiyOf9d8+fKB TeaV0xBHUSA7gspvDvzxK3Xq+D8Q+PjYNQjzrLXG1wSBGMvv2BZex+pMNjuxteiOnf7BjUlt3iEu BrnuLp85dezUNaB45y/qBfgjGTzdPpb18Cfh6rgA5+foHpoooOHf4UP9WHtHPzmudglahfB3aIIv nkdwMbW8reQFT4Nsr72yevyJ3SGbpI0u2vfP2tJg3R+mD050pPzdg/0vX4hQIMnfWWw4HZ/w3GXD 1+kfHFl5hDr5XD/Vpb9iO6wzGrTIFq7JaCB17SChc5+98fjOzCYpS78rbKmDibiYL0bZbTZfoT94 w0mfO9LXuT7xYW1CIY1v7xGmwRebDuWR4doY5Ae0pV37qGfzP+o5/U+LT+tXMHxfvMx26WVlllw6 RoonZBSL8ed6ugTYITa6X9BdEqLL+rf+RUVW8KTS5lwHFOqL4vgdAsClrE8Y7NqE2r4zeajk0QUo vHkO84UX+t3j2lx1QIzc4geeQ/lpj8WtPcmO2qQNpMfDqRNEh3N1pvLwZpzTuHe5Olk+XAFFFHcu wd71gt90oZ9RUvTyooBm1/v5FKdvCeVH49IF3OwwPXd9+rLFjrU1+ckKB685i/40xp8Pt+NdWYCX 7yhyHeRnUod+edxuAsSZvj6vnyKOgtngqcLHSmP+0Ek3p+7c2z2CDg6WL49zdzRzfPDwBObEkrs/ zc/jJdvyeVGP0qoSFDiaG8CFXV1Ga/G3cep0QNcO6RXSBj5b2/QbP/zB7cVewHir3ch4x47lHVjA XR3hep43ZOn93RaC3qhv/KBfJrh9zBdCi79oa5MX5UvTl2HxxaWAsO3lrovD6d6kMvnFr9m/Mtqa 1RU47z4+3+n+TJYdH5qNk8PkLvuiOV1GR59P2U3g8B+yB6f/sdt6FgEf/QR/+qxkOHLzCWmfF2Ox YPFA/FOoYotDuwgZHStHpplF/SSXPiEa8fU4JkTLy7XEMbEJL/Sr/GyXX9lVpq+gfknXJ5q9uw4y FvDbNzq6y+gjNFThNTYy4aiMnT/q73PPvjATsoe6tgU55RLO+y/cP2xy4qjJc9CCZuRgDc9zTYzh ++2f//z2qL7Vcy++PJnAiOlgxHxfcVa8JXvv7cFW+TGGaVoklBkB1UqwGNGRKj+6oUsIz1R4qVqd x4cN5gpKgpEZFh11QW5bb/TNGmB5Xsj2CXvDMaRzkKnDzenCmNAb+AazRigewBzF4yn+8BUNjdBm UiqzBgSfOW1AC/QMcg0k1zG+1xlK8FzT6cifGZM5VkriPCouY1mtpdc5eRd4CPnpqKcn1zNgeHXU ptBppYGIzpBKlUxWrKhX6VO+gM0Ju1NfU23KTF5OPKf54vbyK/2WnJWC8vZbcYJJOD5P1lLDR9Yz W20vPNU9aJDyUdslD5u6Cul3q7bJE79P9oPee7tsvGEIT9wR/VXCLughLY+xsiezQaoO5ToIZcXJ HBIaQy6VvcTjaJCyUefrIf6KDue2F4LV6PkM9uhGeYdAKhjP9yqIrgq7AJUM4y1gFVWZDcK6Zq+r Q2agY4BoEG/gxv/QYu+7cip7eNiMUHTdwb0OEXukO5MJnh06Zen+yHVKxitfqxw7o/1AwOjjWqV3 ni+nD/LwLbLxHPQn45QfbPm6lwLZAjQ7BM/m7ZofLN7mg2UIfPTijemp7J4eWg1w9OBTvqxzjZ5P iaexYy/lCzzBhWE+kMrWgH45USDz8LpAiN//2ZE2ojcxwrEDf/SbgwiwBpEvNOiywotnL1e4jukF k5QTErqlmxN03UmT53vZOXrhmf8oUdnrQyaBVMlLXyNXWS8aspVrq7jdTyMJz074WMMQGcF4K7jD ceopfun2ijNl7TAoEB9n1Ixl4skkEJqb5OnCoMNzJgbR9E3O+V2rQ/Dt1f+50nw9HyPbR72l8tNe KvU7/873b7/9Wz+5fe+br7WFR8yLjxqsu9Ej+8Xtw+r/ew0u33nv3QYZn99+8bdv3/67f/4HTZh9 mv/2PoWXXr195Wtfvb3Um/Rf/+pXbi/l029/8OHtx3/v89vbvd7fysvXv/a12//1P/8v9uPur7ad LJeeLCZBNhGSXp9odpSdvYePvm+fN0nQ8ezzxasGwt/opyXEPfGqCtjLpT5Z59yA+FFxiUwf9Xb/ D1oZ/vM//entn//z//H2//lnv3/7i3eHJj0+efvuN77Sb+2JNUWW2gy2EWUuPxHHOey5Z0PuokaN qaUPG//rA05sWx0uAzb/lFvtHVw3JTwpkB00SyhrZZcGT194Ds5ohkcDvBX16r6dUs+aOBkOdTAl dlTs0D+VJJzuw+ebPtEBxB/5L8TKwLMBddd0A+zLQwxMT3cagE/sTFfDd+rK8ChEzr7woUA3l98v r/tqwvxpbVYFqQMb/p8YV6lkuOSHW/2Oy2KsF6W1mpvdPFpzYgUa3J2mOwYPKeqnnFPSLm1xK1tt pSWIx0qg82jAY7Joz8xCpw1XVPmO1c27rXX+PfrkpxS9zVdfhNSH1tShq6EwSuMHDdfkmq07n0lI tYw946FCdKDcOoJT8JFGGauvsFlJDKTLzuOJDqTx1ZLhkTdj5Ue1Jeyxui1/+qnuVY8+qU9Ft3sJ Ix1HY7jRueOCBn1hUuwHsH4cYt1cE0OEm4yjtav5Ix+QgUO4fVdnpP/PDjkOBKLPNujtIM/Bv/Y5 GegYb+Q58dXkn9W34MrUtzO48eiQX0Og77N98Uv/1ZdUxuB37QpacKJ/15+kMwg7eqX/Y6d40m7f ecEPhrB8BpTkqEwfvntkzsfXZ6tUvnMd8hxkPFbcjYR9l6tduauDHfAkRogNrgM8fc/O2hg6md/G w/q2d52uXQj6aiuPrHc6+Z/08aFfh68jxqmn3Vy6GS/l66fOv+TpSx4FKjZdLu64IctO9HdsS3dk +KS4nhUHz2muer16SIPkw0q+5bw2OgpqDw3TMxmVxbKYxgarR5Wxi8uOifXTWjz62ne+e/t+7dJe YPWL91rJzRaqMTqX3cWWhdloNqmLxsN2l36WXp8u79NGXvoDVz+cbItZMUB/80mJBbu1+ewRv+sH lkwbdOlXImafySHjyLD+XVBw1QsEfb6VIf/nvSNhukhOeplflQC/31XnXXRxyvGN8Ja4ldh8cFvP oQhG2nR6Cpz6QG+MTB+d4F3/ucAL9/Gtypc/n4pPPM+2FZhsV9r8IiT3dpCefUQucVy/Zn3H8R89 fJdGhyH1tzh21TvpJw4EpmMZDn4kTV3uzW2le7dEdmqClH6fbswzO4BRZ1LGh01ibHGytOlgtOjQ iwZ7mXd9HJNh7777bnIdnzo2i8EYd61vhV3jRsoUT56yoiFTIWd+RapYjcEj1DG65Fy/jBn1iU/m XC9+8dxm/A1slLEldypjeMEkgWJnStNzWwWhh5jCUJ4/p3jCbMIMeMplhwI/h2MsvJ10EmwgXvqW r5cPTTWgngTaZnXKXBA1QEzDlYm58bFqP5xRnvHIO/kZK3y6AOjgf1ZHu9J4wccz9f4SazLRl4br QY3U570oZm9wLfPAtlWnJflPG4Bta+4qYVThabsOuSzo22ph1Ulj/WTwL6RDM5/jOJsYEK9TGRfb nhMsC3k+WoX7mI7jw/NAjrPqfTrYT7WS8loD6b0ATPnKTa41vPRWWjLR3Kk0rJg+yLXK2UWHVMcq TTaDQ0U7FE8eR8UP227LfPZOsvhJV+NtRljZUZGRLiK30/Dfb8xYmnG7OmhcY3aPE5/5Q3wYqOyI F9uYP+lFY7bmbsBLjhSzgLtrdiywhcuq9Y7os8N5CURvg+sNnluVrJxKin+xhc+zm+MUTW8hAnPw T4zDXXBg57fRnY5XkjsdjalrMTe/3KwUekV2g/nVx/LtGBhv90HXnWMcLH2aiM6BV8cOf/x8+EGW dL7gIjl+z5kTszlb0tkGbukTlgV1+bMbescf8Y8PQUjHTeD1cQx/xLxN89n7dmazmhSoA0PeA3mv 1xW4eKcvnTryBji+xAP2m8amrq6jvxXsuVJ4CdexgcRk656OpbvHf7ZTv3VMrcicABruQIDtBV13 3fhpMDwd9AcHX+4qGY4++N4CvtilA85P8z3xh395++SjgvlWzBsArhNUjIDD7LFO74m3xybPpFsD 5Td/+f7tB19/+fZP/v1/fPvud19rAuzl24tt9Qv9yuqcqanO77z3/hp5P4dkV4OXuviZlU/b8gP6 Ybsd3nvzk9vP33wjHn/eC18+u/3w+1+/vfq1r9z+xz/4l62AtY053XjmbL8TG50/+qM/Kv2lGrsG rVaT0slT2W8DznDyc/r2cayzOW9IX70xn6W+eKYXdj3/+e3FCn8l3XzeCNZzOWcA/PLtR7/+rds/ /U/+ye0/+799ePvX//pPbv/lf/kHt//m9//49i/+5rwx+sXbs7fvfPfVtrjlAzVoez6aPVNCZplt Rn18lFDe5QN0OiBGHV/aGPWv+/6UZ8P5HAEkdH91mtXTI9qxS/+Dv1+DXZnk7trzoCa7xECNt3KP 63YaHK0hiz7X97lwxA/fC/uhN1lOvSrlsV8ixwbqKJr9mw3mnerUYzmPRdAAv7i1WAAeIbTzTXQT 8XSCQ566Vv9Hv5hOl2ipL5yuY23CLggRntCB+yy76jtcLwebTsVRnZrkGr+YcXSaXP13XnIXWBOL B7D/dx1FG98mXaPWF746hvm98uub3fkjM5rPvdROiPn+2FzfhCxsmjWGay17992NJH3YOuhzxfAR SM7Lp8gMj51lrtdxpONkxcvSSl9fBm+ECn6D2K73ca5/sLhSOQNxXJzJsSOzOAvfZ+n0Uc/ob7eJ SW0+GSxzTreA0sUGK5udCHf0y0xN/BdmfB57UzKbXceu5xtYr1xfk1tJuXKP4Upn5xOP2WqEl33a 5PTRAUUFC7G8Up9DHWQxughm9NXDWCwG7reO69/oj9jeuD5mwNoSuEYHrcly/Iholf4y3x0ywaMV 8M7XtncpiwXDm1z5R5eLzeMN/gpPfhk74l8bn8wOPrrBSrDTwZJp9ugF2cGEZyjS6WxSOviVGYNI HXtsYSn9gLtwaxfnh5WZOGONLruDO4Mdy8g9uHZBhmD0PcGwFd5UjsveJ3aFa3zkX531NegYf5eP rz2t/HCwX6hPHj/W/oCNGhv54OvO567nosGOX/roc8chC30LIcpCzh6LMWV+7jq8VjsNZj5povTX fuOHt683IdILJW49t9OzUZWrzhg/HKXjMQKQ69/rK+vDvGsnlfa8hThBt+v5TSD9nX5naV+2W6GM Pj0X0Xbd5cqxrbHAYml8L3bm43l6cJHrauJI8sY5uhGf84PLtujThb/V48C0FXxeMbidz2Reepl8 d7zljM9wnnYNm39H77NJ9xB0oANetbFIpX+C5lk9t3jEPzpG8FxcuyX4C9vDsv5WdMZbNPoBmdsD wkYILXWaLk1S4efEiGWk+zNBdeph8MjQ1d5ozZfuxNOrsY7DTznyxf304OTj7fC3MFPf5rRHvY+k VV2PR504ye/bPdhOMS/gfNgqr0e8tFlo0hfqaWTX87zpMbmi3UTQaaAt7x8leag4TpMwPe29TZhb ZaGYjGrpuZ3RRwndv/7V125fee3VBnbJmDLef6/fS3qngFk5FRyN+RZEOxgnTcojqLYtFql9VhOe prHyupjD1KHETy59e7I3Nw8+fjgQBZ0ZjVOZn+nZXk7PID5lDwbOBYJKU0SM5bynssbJ8o5zVoDh 6eQu8/hEFT/JPAeEPTQC+Es5sxdXPfRM7vDjsC2BNcQf9ht7HAucmTeD8OnG9RQTZHirt5UoL4bn wKXFxr0S45M+jznpCW8CqYZGw27bGcPbhgC/wcdrbXN83ltWG6jroGXAysyLNzD0Ux9LS6aIp6uj cz5w/KFg4BPtU2Ocohc+MplhNhPEn+mLU+po+sBLTzosWx2Fu89phOQd+6+iJQvYY388HLnpZZVF wnAJQMnet5z5lg66aGfgpoNtwBt0uOg6jYZ7DVHo/QQVngm7yjG+ye0NnudlY9iAX/7VkJ0SlYln gWTiSQyW761idb0OCF7vh87UgpDGiS91HOh4A384dbHr6SAY9NlrjacyMeWr4wcNnQhCDoGIjw82 3vjkEvARMB6UVQ8NLNkIcYNk954R9zjDttqhU+7pBCqTZKWxg2P3XWomAK4Bz75jpX/PFoxsqxWU KtrBr0/nUsNCTgMpdYj/buZvYKfujhZ8yce/1Fc0fddBr0zsDK+LpU8nR0b6pDt02AVjm+TpAuxK hkMN4NknYeDz4XvK6hLf2Zb+gKZ7+mLPcCdUZwzCwCd1KFrZTZcPH1nh9JI5+tJQHx88stGZDLZN RyF7+62PihMPbv/BP/rx7e//xndvX//WKz2/UkNe3nRUPcbXFz1n+H7PA3vrMxM+qNP4cm8v9Hy/ F1ZgRvzgowbWVlPEC9u9lP/l2z1T/PDN6u5bbWc2aCuKWxnLVi++1UAz//+07ZMffPBeOnt0+7Uf fu/27e988/Zqsf2Vl19pZvXFYGu09T8Y4S7+YiR3rr7xnnUk2Kl8cezJBtZ+Uu6ZZxsk1aH/tG2a rzZV+3v/wT+8/d6//+/2jPBbtz/8/X99+6//uz++/cv/4S9v/9Wf/iJu+8m7F1upfr23/+ebBgH0 SeWz/53+BFtCBTrPTwNaJ6WkxQ9Z8eFwv7Rgl+K8b7yWcvxHPb/nkwdRZfte8UC9OZM0pwHmW+or OqsTlWF7aduVclAc/sTFq/JGZ7jZGp1uL7+av6ZX7kw2kOqA9uM07KesSOijsP/n+viONCQUm53K 5xMSzoD20L30AljdXO0IDEvKiRnqEd7Io2M5joLXARqd/h965dB3sEemc3/w5rfBjxeiBHb0z3Zd p0cT5erwYvDQJJHMgz6G7FxqxaSJGjr2noD9TFiwU9KBLA8u9jhfUSpuEZwMncJ74sZpi9Cp8GUL 2syJ+bC67Rbf629UWNl75Dvyopuepv9iHmpkcA8tP9LRpNvtoihxZ/7Nn4odJhLoGU184su5aAFD l8PU+XS+tS3kKIthm9QAN1aX9GV7pCxUx8ed6YV98HXaQkjo5PgOmN1znrCtc34vN5thTQ44OJIy jCNOYrHCwHY7Iarv3pGxzBMY1s/Rf6lo5Q4vs9m0hXIimZSIDl7X9pZ2bHYGbeNjeeNw6Ceowod9 DE4mSfAfXz90B7Z4CS+ucdI1H7jkrkGdBuApT7J2a5OXyXLp6RQEkV2T6++232ILPZzYzO784vCj I45HDJNTOcepn8EM8RFNoQfe/xFd5f1XfP6ivwOWHDEp/7KTTvbgyq5mLX95Q6JOHz/60u9O/fvU gAXKfNYklNg2WHWL3siBHi4jf+1gkEIiHMnX3tl5cSauwlY9OP2mYmQy8z+KDd3txz/6we3VYlwv jlBawDjfcMRGSWGeD3X+tNjjW3/0nXB8Wh8b3k3uRRe/Z0X0oIIPrT1qF3dX/Txwl0/R2zS5X44x pl0cU7e6hmM+eLeLxKlR3CQruuTpcvHSBZMmG/1ePrhdq5XFqwWU7dZLvtVJcOmLFhcHwd2Z2qC6 MlODOOE6mrigS4+cAuVHJ+aieeqX+IT+YW/WqdzpJ4hFxmVE2CRDMck1nzyuNeHT35GBJqTgCx0w 6PrHx4786ViFKT0Jht8qtkU9cul72gpu/KKAvizy8EjBtzHT2Q2SPozrSn/W9uf84VfvvrPFLi/y xCeG95OlYSGde/h2dA2kvumpiFB5URMIs5/4HLP6UhHmazsq5PlSCn0qJ/iiwPZky7/gzxsfe0Or LSsxikGrEp9V4cy1EZqCBPfN/PVPo7XVIvxWJujDJD0Fy0B8iUGs2nJOB1ybYZ+gB49LXwVmqG7U DTNh2foEkfBQpPQNjIMXVIQIjmz1+FQKDhfN0ZdLL/ESf+vshFvj/UU/hF1N3oD2lVdfvr37zntb 1dDYPP9s6xY1yLY4rvOel4YuOhkfH7AWSLaFYro4tgBTgf6xQVyk3PGEowbWY0bF3ufYKQvMyHSy CpeAngt+0QCk7c1sNOWE9skcjg40QZ73uyqG8+yVfegLzq2ml87BlN8LM6JrVo4pNNBsuQa9SsLJ tjd/3Pez2PK2AAAgAElEQVSPPeT3oUP/OHgS7cNOKjk9y/NihFV6tMCXyObKCpgCgYZ+LxCDJTg+ 9KhOsbc0C8jH08bKRD6dFFaO7xBhiX2U3U6AaOpE+c3YMSF9QGGKL7ZSFyZK13jZIeF+XJ28SbV0 djuQdL3AH95j93iZTEmIjz7wn2A0BymdE5xjZaOLl/GAPw1IPsJNhv8OK/2a1Fj9LR3eq1Gbt4+P 2opWCE0YWMXYgBy7dx6xPv2kW+fId1x1J7rLD4bfle/wczkv9eyoiRNJ01SAYoWYMmYHOSkOzEE8 uksFdqdF2KpHch+dz8epp1aCTuht+uQ7DgXTG353e29AYmf+KZv/LI89yYVIMqwhUYNWdgzMD+ll eizdJAEczuuQjId0W8zwG5gfNtD9sE4ru6i9eMNzV4c1fETCNh4++0Fvmvz44Qe33/7xN29//ze/ e/vhD77ValVxdbOgCZ6zagw/rTX56GEvoHr/3W1pxv8zzXx6KYOXYXmc45OP1ZeieP5/9EVHfZPP 1nlSfmLL1Qd8vhda3XpBSHrzYgmTQE8+9bdtg36lQfjnt3fa+vxRk0d//qd/VWPz5F7m9lKTZ6+3 Svy1r712+2rfr3yll2q1Ev18L3p7Nn75Xf9OPSbv7C22F9+ylxUJP9nzRf6BX/XVc58fN2B/9avP 3v7X//G/d/un//Sf3P70z//q9i/+1Z/f/vs//untv/3//Te33//L+Oz48Xe/dXuxjs3eJO5Zq3je KgidpuL5QnCrK535PPuKS1caPJevrn2Y/ZQ95Zwdznym/7sRj9S86TP9yJxtS1ev1KMuR3NbF7Ot dvXqvIK9fHJxgt/d4V2w2fwumuicAVE6C+YJPa7+eJStYvNF6Sy7dqQrD1GFk7VTSjD5QT4qxjjQ 2la/zmIFHPPr5aWf7k9nfEIHX/7KkO/smnG21ZYc0y2m+naH9OrPKV2qtqmbxc5w4wvk3z1qyRXv OLqBd7F77S8+41nHdyWDSUQr61YEnmtW32BqL7c7gYqAazvgHC1xIFnXbuabGyzWD2H3dbip7O4j ZJWvTiu78nSJuzLds6cYAUb/Bb8gSpmsqNIj38Y8v2OLZQarg+eg+7VfnQ10PU6iTcUrP/vSV9Ls Y/uJu8qy/xl8yBp8lTf0+yr72FfDH0uTN+Sjiz77+wy2+9GD3PVd5l3jv0NOqkn5aBxCp24FT/dK DVY7LQS0U+2FFxYTxKizFf20VxOHz6ITMH3xNbGQ/FQEI3ZC1b8zkbRLtMs8A3S5ZKD7uz/KHz+K yTvSsHHWmA/i25cN+AEVXbgVhwvmI5UcjBy7wLmy1VUygtuvWaR/6eu/BKssHtfOAOK43bsER2ds pE6AWd8mBU+3wNkq4NmF3wYbMDbC0ad8H9KRf1JCPgqd6PSuBzIqN1xT/oGbPoI7253zZ/Gn4yxG uOiP7rtUFp41xIA6TtxRV46tTPjGSLDpNZ7Rp4nFlFOi6wPjzIfp84m9x4KfHxqeVf/KN75x+/H3 v3N7uonR2xs9z2slV4NV/TsiIhTSHpe5fVTet795u/3Ob3V+vfah55r/8L9usqWerTpFF/TXcemE T3lJnccfDyIyTLODy0Sp+x4HumafPa4V8UuGkLk7xekV/04wXLHcnYRi9g5sK5fMBqaTgSWnr/gU 6laXhzk4xPXlxJQz3oJHnblTcjc0yJBvPHQznCNLt1xCPUGrm7746N/YOzEwjNppPJK9QseCJUTb yq3dcehefrp+BlqlHia6UTokj/0mhjyyoL6QYbaYHowv0OijPhQzP/+8Uj02Bcb4AY/8+5nK6qPj y8S3Mg+2OOVFnrcWAN4vJf7if7FRnRmnZCKmktwn/DGL1lOI6pRoCFRK++GpfW8LY4mUvhmJMOiA 1mxkxzPzbnYVsk8bbKTetttSZpRahrYv+9MPrb41c/lkM7Exz7kohvJj83AlqYPyORPGiUhQUCqY Mlu90xkMzxrpVTSKqUzCU+EZvEF7N05FlTc45XtxfXeMbmB16kuRBnshmaIOHyDiQIWIX4GSjtDW wVtlwHMwj+axPZhdB/J73/n27e0M4SdGnu1BbY3le+/3XEKqt9WPvs14nUaYg4Q7h+QcZISRb87x 5uAqynEuMykb1CTTXKa9mk/GE94SbnKTJvDNKr74gh9uj1b7E56sw0hRBpWbPUUn/p/NfttGnpwc e88nh85ACD+QffrpI74/h7atbdSvF+mUT5bDb7K5p1M96S4MTulY8GdzcN1Uv7NyBjBAWEdEsOie 7a7Ggc9wOqsKbEWyT9tOAD/9P6rToIOoI+L5Zi+tQgsOPoHUiR3hGdW0VsYawvJm22A9/2jAS6d8 +2lbevqoLQc+HwrRdX34TJp0y+dU6KXFC5kECTLmMZgZPfTljSl58Ywe37qOK6Cg7bMJhyuzszJh CMdli3tANIvLN8saDhf0flcCukhr3NbgdjZB8GGTMfz+NI5q3eF/M4vJi78poavTMHQLVye6Pfpt m30+brVlv6FIntmSP3VN/n3v+JOBvkYz/5sPBB/04T3ZphekKseNxuN0mj9Ff2XLL9v/4ZjPuMVf doNv1bPrAeqc0AdFlLtGZeDH70i1CZf4g38H2L74RVe5sie/rYn88NPqwwcNSM1Ymgybw01eZMkP Pm5ihg9NZ53f/NXD29defOb2H/6vfvv2m7/27QacvXBHA7H4q2zI838vsHm/Z3a9GIqNdfz576Ma /SeetK05nOnGYAt9HoL7dTjwgfb+l16nQLzE82fVP7H70cNWpPlFPL3dy7NAi1lPPtVPAaAT/Q/e +vT2izd+1iD4L5OD/tvC3GSZZ4Vfe+2V2yuvvHr76utfbVD8tdtrX3m51efeS1C+N7DuRVUFBS+y mP+mR2/Zf+b5FyaP9sGq+Edta/Oc9K/9uLdU/8b3b//RW+/c/vJ/97u3P/vTt27/4r/9k9v//f/7 L49N2mH07/yw572yg4HzYr7qxn7hTowZiL7pgdVWJzunlHgPgIPcj2MjRjpxBPzsv4LBrczdx7r2 qMnauDAPr/sd0c8nPu35Zbi0ObEwO9jlYrBGr6XMb7Sj6zzi8I4CyUqPZ4mqcFrr6z8PlSAOdTfW KqgsFMTqnCVHw9U6N/EHNu5KVzXDclicDrW3FxLyQCKe8nmDUG0D/1gzHC6+1v/hAj8dxBOdjd7J gWZot+tkaCWUdPG7m8MzXyXb4gQJyBcClEzibodUZ30KbYJn4hDQdsx+4YIdvGpziCTemAhvaRs8 HCrVoXD13db50k59z0fpOf1cPjR9VGHxc1f46NHFCa/Zuzp32pMzsagNVefwhkcsEPno88sJBDjp Xv5gQmrwR5LplKL6Gw+l4gvcZIRwfY6jswvmlCuvYyCdl5YMa0snf0gen+OUjwpKIRf3pzM8s3XJ 7O1i5zs+usAPGTyLp47b+fVs8cszuudnRI4PiYuzK4aimwCzhfaEPLyyq9Lu8kuUhn601ePd9y+q kZafPHi65zlPB8qUp44XsY/spfEtB5jZEobS+zvl7lysPgazvgwjG7ACusOzF7nhN+E2xwqOe9Cj FSk02PoU6v+9nwN2kyoAyT45aITsyrmurk8vbooh2oLI73G95Npn7PD7cOeETlf9QUNffn3pctRH bgjzvpFGj74is7KLmdoPuiRLOGiMSuChCzHDGa2Fi6HE7elDauZXb2KK/i9+MSkdMj8HZCKU7oZL oehtApswpX/a44Hf7FcKvtPLFJ94y+/z9i12xlz5nZvsvD30m66NA17/zu322z+6ffEP/97tid/8 QW1afcDf/6PbE+/F12tJGe9+wcFPV7IJXzqPHkLVoOouw+VD7mf3cs4243RH9nizSGVgTzasboB1 FLv7ucI9D9rVIYloV+DCK0+7fsUxrsDOUZKxxxUNiPmG3pzJMPbKYNklEODwlQTH2vLiAF/egmDp k5XdQJN751M4sPpATX4z4t22cOJ3fhctu0XPT1fhvcx0sNiO9p0XNOKylFNW+dNvCSL8/DyXnv7s jJsfRfzSdZbJrC0w0Wt4nqrvbSxJbh8LUN6r5HtiYvx2DZZ/vtgq7/NNnj9s0vxXjbVoxpgKR1uw pQd3fDbFra0lfH9gtMJV0hBivE485SMuqIRigBRoMKMIO6kEDLqf1XBdGR/mMzvregKm3C2Zl7Ng EAOU6zvE/V+ju1gvkKaxRRAoM1eoDTSPEyGZ2Cp6Dr6Vx+6JapAR+6Oh3GYO40mj7aB0Myb47DK8 8RMLghx641flClc30Sxgky+8Ggs0pW17B2e568jzf8Kb12vD7bm+5zLIN577WisSZKfb6GIu3ejU ciABhnGOu0e/7D0L46H54E+wV9HYTWWI5lQjIUwNdg0q10jXmXrQa9pVEB3iZ3KYZ4L/Ss/xPt+W ogcL3OxWQbKHb9qfHSZunTGdKvpNl+HVObPl8XPPMVFLq0ktZky/n3za1vG7XnXIzVY7k+HYhP9o zAnFFlGbnuPBZeiuztGZtYoHureNhl2mK7oh++FPB0LgsTWZxsdrEJ+Whr7nAj6uAqyCVIbPKLng mrxDCd9sdxqWktNzDXX2Wuc8XVmtA4y2f3R/GsfDyHa3KCj7ziceM8DqDIOhcclx8Ox/7GRPvtbZ W/x0jQyawUJ50UF9DWLpApbSC5rdP25MS92LXe74Ln5Wf0Lms+d8stNWxNOTeugZ04pMTqs2l2+u fpR/eEnPBaBQDA/cXx6HVwEuV0rWtrAVsHR0dPI3IZN1yBK6DVgZEV68L+DTlcyOI/Oh84Woju/y +t9lPlks0be75L/KrER4jz6PLYYT3qGG6/izpPEaPg3sGDtAK79BUPwKqGKHemriZ/3POBFk8QK/ Z2e3fSt4E0JWHbedPqUiexrTytzrsAkNxR3qq/uPm7R5p8b8H//mt26/22/ufu87X7s9+WwDTbsv 0o1X84sPYsMH738Y7PtNmn1YXluQeykYW31sEipfVV/5X9Uj254XQmyiIXp0psOhrvEHgGLtZ588 7OeDXrm9/vVvbELswwab77Vl2u/wmlDiJ5+0xfnzXk6452wqt8H4g96MSJPJA+eHDbrf/dmj21/9 zc+rb3+ZLwRffX/xxWfbCm1V+PXbN3vB1esGw69bGX613wJ+qQ7ys7P76fCbQHyw3wg2UBbDPvrQ W64f9tNMz93+0e/+5Pa7/+CZ2+/9L3/99n/83/8vbn/252/e/tk/+4Pb//t/+DfT6W98+2u99O+5 PZv8yWfV//TOhgameJzq+7d6fLyK65S303CA2SRqZdY4L/MOlOzqIhuqlyGfbVbPKsd3DpXjO2V/ ae/ghaHPWlVgqyc/sr2x3TEB0ZPrxSP67V6IXH3sfCd1OEY7BthYBhpHBhniTTyWJgZvNbH7q/6t fgV84rqzeBDHp+idDl3Vn9SWbaB7BruorXNfpnxVQzzaJybUh9U5XHU92e/15Nzf6WI3n71i32bx 1RcC3fGsD0DoktR52+zFZBPB18uNZs/xTRfRw0//xk8yK37xg1a38/djEIMHiqO6fCR4ur8GcnCg fSalpujBu0L3Kqs+wa1GCRCPdamelbrYX6H/P1lv1rTHmR7mPSD2HQQJgiAILuAyMxrNaCSPFCmS s5STVDk5SFKV5SgHOUhVfo5PnBw4lUrKVT5IZXHZsSNXnHiJJVuyNnuk0WyaTRJ3EiSxAwSQ67ru 7o900u/3fm/3s9z7fT9rd9dn2dpAz+dppcYVMhWmdES7rQBJ8BINZXEmP2WQ4C+0F4YspYyH2egf aEKkmLq3Cl/TpceT7ED+MRQ0x8egKmCSpAeeKsipbXj1SGnbKfi0n71Nb9IB3RijLOcTVJ2UMLar D/Um2rFH8ACzBYxkPthBPjGOvI7oIg2aepWTyoC8KLSMpEsi8I1vI0JtX8Epk+EluUnrQC0v2yfN Mpb3W6ccnXnsdYVpP6PJbc7H3uRpaDZfGpKeNkHdGZRiUTq6NuCOR3VcrvYvhrEf5SwMBytqYf7k xULWgReO/IJM6RSH9FtRHx/GpEC6tQPzh+ZgbuWluO270F6fmYJ5BL9Uy05ocSgFfwIBkz/KL71S z/ateFL+5mvKQvuHMemyLIREV5O0ljUdJDXnwjS2JZMNELj0caadRn8kw63IqXpovfLatXXxCM+l ePsdn5LLAhrw0fnylsZHDJSuvsjK7utrvfnKWryp4EmLFdgbE/if3LjZzlNpChuyUW4jb2VqHNCG hh9pVf8TTyio38Ef/yEH/6a+u3ii0DyuOzi1TDrd7ChZiolyo1NSEK5jh/loPMQI+nz7xHU6tL50 CJ/6tdnWIE0krbIq5w1P9qgO0I/5jiP0O9Mx7PjRcrJ706mbDejjXPeu2vxNdmfMI665BYw0+uLK TjsUpTt21fNDyuQf0gIu6SzWiNfy/R+71YfzN0lybAnufI5S2qGydbIsWyLFVw/JruINHCjcBSZk F37sf3ihHGGB8kzec+2u2rvcz+viYt6inXC4Qmz5dJ1chcOChOoDDzuoPJNYDJ1Gz46XTPbgBXKa IRyOKqc5uRrce7MkklQbqYd0ggzqCgqUDZyYu8fJgVdHdydEYuz4UpOtW61Q0DGwYff80CNwqyDy EwT4ClYw5CBHATZPo8TLk16XtiVpGiIVojGMPhgY0cHfOz6mSbPXDgiQIQkDy/8Kqq0PCE7DKehQ oyKjMnDBC4Unj0qeQ4DG5UDY2SXpEXjGRwFnrJ0JdEbUCqgPBeroOMIABznX0k0JYfqtHOlHSPeG cGdOVGq2xz9CXp2VCSTAJ+8UT7s7R+fzFPfyaiRUjjaZOMIANqggaaDtFXi6rwS6nU/ROrSHwwYc BgqqappnHuBCo6bUrNOAkw7ysUezQqXeHrBqY8dZO/G6GTbgWj69kq5uAJx+SO4VDDZm0qpO1NEE VssNbss5EaHT6Ag+N8iBm4OOeZjVlLW8EvxiY2ansgP+kwcXBh9Xd90C7v0CyiT/oEABRITA2e3G IB4UiPOjDTTRAGzVJ75Z4R38PY0b2RXE8CvvndSurDerAcodeuBbh53GLjJEPPD41a6UnUcB2joy AT7lKddd23oFL/cPr7mIrPP9CaDe99zgXiFbF6bFPTiUm74twg2pZcRFAW1CX9QW1KETBj5AaWRE OehJjpQxFggzajzheyjbty52S1m/yW0ED1qFPHTZEEnBlpUNKvcaA9KDJw/CxmbgklxlYh7/kNFY i9cTN/JbLnd+hGUZOwj8BEptyH8d1xprL/E96HGiwY+7OJpoYbW8GWDjYbAAQxlnmeu8QZ8kKjMp /JAgfZnB3F/8N768rr/EYPDpM9jeifVI3YFTWWkjd5nE+fjGh/w+ZPWV849vraM8tOGlk9ekDta4 b/r86ej1uid/Q59xzp0KDl6K43awoAfi+E4MuU6n4cXnL6I7tkVD8yefqm9Wk3lgiKWSiHqE8OIZ A2H9q3gNDHXvvZQORk7wFbw23gG8Ozy46zZ0/9nbP1lPvvU9ZPuYQe3xdeX559dr16+vl166tp65 dGFdODtbo6Wup9eDU7s4yxZrV5B9ENjte7fWPT7PXTu3rlw9t772lQfrV37xK+u/eO+j9du//cfr r/wv/zS053n43HPnmRCg8+3c+LyTkUbu4EAnnvOvFT/1suUVk1SSadCv+TQpuuVbMLtBh8UF8ymb HfKb74qTdHEIKsWQUieygKMvYD/ox1IuWNx/6n75UtKTK9kdpRiVgfA9OrcGGTs+08NfbNGHoG+o pj7051NZ0vBTRwjtE8DyDemK/vFP23wnDPNHCjRhI6987eRYVjqgPnrFP7FK/rQ+uR4bOOAd8ov7 JAhX2uVzykkwdbhU9rZbXjvJeuwk92n5uw16Z5bfbNtI5+eFR7tMR2pwkzToyTI+QSew/PUrxoO4 ylX0kfZFmlqxg74Z4APGehT0a+vahCt1PJ7Y6IhQ8vkOnmPT74Gudh7YB/ILb/ph9FJr6J3YwlUw hBmuOfE/9Lpo4DH/PYO8wekFyJMn9PlbVgWwl2xtykxR5G6a5aQ5tMrcdC8GsHxoQvFD/GkiRWNR T9DjLQ7ek+8A1zZO31dH6jQaLJtc0JP0cdXgVB6IH+bZtxu4gzN7QIjFXtFgn1hK/pSsqLrrQV5m 6+3ANsbtfS+1PKmWigqxHhzC0ko99nThqnevRy5jGz6/QR9X52ZoE8a7SiozbFNcxkOtQ7FpX/lp F4M/oCKkjp+R0xAQbvBoPwcqoEyzu1axHpKY1cahMXlIj42hlTjiufONq41e+8D6gAjE+xS7wAYq Nahfmyhd0ba1v8DJBoarbHeuic3YMEVLq29smWE8WsSu3rInCesgVfjSAOzioHrgqy+rkGzYvo/b WpGzNH8GfS9dvbrOSvO77I70dad3iJneC/7qa2v97JtrvX5trctPt5s0WQmP+i443f6UlWFeB+rE jbs6lZX2IX2WkX55Mb2GizyPZGnGZE4a5+rIsYXlLaNfW0PJmua5/2sDt/rxZXnokner6wEWUg62 ywgiVPYp7He70i+dCGFwgVddZyvi6BoewS8dTSQIlHRQ9PWWU+183zotbWaMf1ILPE1iAdd6ZIZP MMYq+TBm24cT3/S/OVFH8iHtG50zpgkDKOBlTodPeQKGYz71IDz7nvl2ekczjPdOPnWqiXo8mTW1 sVlvrx0bZ0xgHERO8tfzgKBN/nwTyDF2Ziq7m6zyuuvHXYbZFozFC5WqJ1b4fgzd0SjfwJvxI9Ay TlxcLWmYeyGF4epfQQZEGo+Bqs4yMNBEhKpLJx809LadQoDnPlKaG7kSKDyEVZi2H+M8ZItMwUEc vEWog0cbPQNPHJBtcLHf7FY5YbQVVwVtxmIDo+1Zz1+/pYVWPqZs9HPRvcR2k1S0ikXBaGniD3XV /j4DruKFFzng1vjaYgDTNoZee4j7CCu2DxzIO8uTwIWrXA3W4FIQWpZM81fNBG4HA0Fah0SdK8NH 7jOTpuHOuapo5QqCfIKms61nz5xCg0/Ycnie5X/veQK88K0jNHnUmTQm6JhOHHLcZG0Zcc/DtkYm ylkHbuYOWFCevOS1rbkMHIWpQ/UwJOigJvMZs/VL2CrVVaRmk3Y5ShdwCxLwnp6BmY1sdObkxgHI yjmlA8G4xcNBiQPeB3Syo2VL6xz8W2J8T75kaLvm8S5nBru+i1cZmCRtdRDMBYf2nTjAPSfKA7un MN5QPe3GbB1NlHDRZ+xRXpBWAxrlbsBn0mEMaOoI2mPDsTusSZ5nUxkCspUmcNc52/PNI21Kjlz2 GTuzGqgBx60/bmf2/jFlKqXCEnHgh/ihV1rQR9mcdlDISZfwU8ftbCfYOu/2WPlSPw4U/IXA6Ckd IGHxV1lwaLfJmnPzkqd1+chHaaTLe8EWee2dEJJHDpTXT7JfzvPxYlOcCRQA1N9gJjsrS0c0GTvA Fq9iQrfSJSxO9Jcm8JCdYCnQcwxaBUWGvisznUetqEaOotBswkMdLcWY9QBctz6+u/7Cl19aX3nj hXX1+TOsiDL5RCfqMRV8QiICojPlVuZbPYL/zOkT62leM3Trzp+td975ybry4ivrLWa/P+ChT8cY 5Onj6sGJrRPY8XGeunyMVwg9gnZ36fiu1DvcL/wIeo8ZR6HDbfyXeOjgOQah3tf0kHuKP/34Yx6O xbvDD7NiygDTF827XT2Zy7jxCCEoIyoVtz+7qy05Wzs7XNRd7zbE1l2RVi8+WOLQU2fImdc5/fBH H60ffP8nxKUj6+q1l7l/+aX1wpXnuCXr2e4TPlEcsfNiM4i90cE+T9o5fP4Bs7nO6DrIfvnCSeo/ vd544/n1l//9X13f/d6frr/1t//x+vvfflvxr0tH2XZ9/hT9JAbkxAjcOr0CBls1lqkYlOTXY/tt 8OtlSZM3OiZN293Lb1XGdowDxnXls9kAVcEQnHBx7mEaBAAGO7edstwW/+7fI/bwkNLZ9kYM2co5 APQJ/btt2g7PhKx8bP7Cb96j4WFDbeGzwkZPbdtwFT7THehm/+hzViGtu/lejYbsRmCMtHIjPD47 XCNd/MkIf62uk5+MKaWviHuPafmq6a2cCH/isSv1PcWXWGI8NgZbx3bD947qUMkfFfQMD5DVzzCM QU526X9lST2g8lUmxmvPoJMPxAaHpOjeZczl2Df52h0/5Rv/1atyUTLGUsXq4GvuFVSdtGvQ6WpQ D1FkUqNVrXQCLdSvb6P58PHPeJIslA2oa4/MSmedRPdOR+KFkeoLl4xiJkXnGBqNriZNu2U50PNJ Ll6UTwl9FLrjX56APRMUWwyEHyftesYFkxCz4s4uHmxRwuS3uK+tZb8FL3iiDoNjv67uJE3y7VPV rzJF5vmNfn4lctpcddxlOBLVxt/Or/LxfPiyrPGdQ9lCl9cenms/6pILdDa/5llm2h7Sgz9y8kIr MSmdU0X7FpmpllWP8UuZHkhFzn5N7uDZcPRMC86Vq/3B7AY48g+0PvO04pkc1ijCYR1kH7whkFPL Dyx564nf4uNcXTsst3KrrsGhPjIfv0NGThbJtxJJFEDjT7uQHtsnj+ABJ56Qn3rR79zN5RZR4Tnx 1a2OAJBOwG14NnsSgWn8AorDf9ApPQjBN7R0YDLZILGT5QsuqMPzJi5csW18YR3yWbA/YtB78vxa X3t1rW++sZ68Qjrt4RMGAGLpPcQBk6mh4yE7oh6JQ9nwUfbetuNdl3BkJWIIt11CX/5cmjKCBPm1 noSbv02slU4Bbce2deBq+/IzeLIZyntQW+0AxzHI1k80TUcmR3lnH/Bsikd2El7phB9Vwo8y3+1B fMZWbzdx3JI/AuExC2G2JyBoMtW+i/E6W88/B5Z8730wUVGstiQ7Ac5uB922hV3It/jkUdKbTKRi djCsSHqHvLXuANHFNG1WGwKnj6QwQjzRD4ghD3mQ5cja25N4pzLyqK0gqEuXOvPVd+KbRST1LXxl QejNgocAACAASURBVL+dxbyT7Hi7y840n6FylG3S1lMH2Z2C469E6ukh8j1tA5AoTB/cjCnnKpv7 qFvppaK/ZI8ihMN1qx504nKyDF/B6yRjZL4/NMPh2pklV+WcLdobLAkcmmQGx8t4ZBbmN8alqHSV jlCkMeVgtCprtgzQMGYU0IVTWl8+0FXcaHCdo4VxMK1MRwevAgT71v+HR+pH1xZYkYN8wn28zJYA qRb5Ris8SYdadgB2iGAv3waLVrYp7ZORDbKPmNp30GhjkqwAYjDyPIWDS6OUOQcl8ioz01FQ4Szx C5ev9xikk2Q+9yU5+DvDlsXnn3+W90X6IDEHvAY5XYiPQQY5KtO2aQN8pAWR4Ak3rMBRsCFgeFGm wiCPYhg/siNPuM6wyD5UI1++/LqNyY5LeLh+xEN5HrMKbKB0gsIGExTNiNupUT/t5ddg1aUy4lxn s9x0mhJxMMWvU9lp8z5K+VZeDYC0E4NzcpnZvoimPNXip2scx+24Dnpz6mSCfOlcJnfKJ3fq9Asd BkAlcAiZOhucbUJ8DwzCObNNhOBstgRqF81067gwol1YRt78euRLG78lmMY1Bfjd7JA60ZUwqAdO a/vN1pBT4HaY1G+gi3xmdXJk7bbceR0R6dVF8ExueMxkinZrjrCH3p2W/Iqi5vo0zlO863Ve1+KA F9vU9pUFspdXZabVqUxhSWuVRYfsFJCymHsexQvN2II6tY7ytYzyEf5MHFEHPYvHoCi7+k0dGn7F sXEDKmgBqMG/wGlmRPDrkf789UJc0umlvDCosxHhCjPKlszTbu9ia27ZczZyaMPO9VXtTVqgrZgo NMBOMF/r5s076+LZQ+uXf/Wldf2V59czT5/r3jcfQuWkFcMO7OroukMQ//CDD9nS/CmrolfXa6+9 zC0KDHzPn6cRuM1DrO6u556+yCuM1vrxD7+3fuufPljXv3F1feWrX14ffXJrvfvO+90b49YfdXSc 2VOIQ34MInVQ8Ny5+2h97/s/Xu+eZTDJBJkPhvBBEGwvwR94kjP32iKCGikHQw/dRk1NO1FHmJGX b+WibO3o32FF2q1J7v5AesWZZuwrNLarLhyG+LCrJ8cu4vv31rf/6Lvrj/7w9/HDU+uFF15aL7/M 96XL66VrL/AWgKe7X9hY3aQmvnSc+399cvQjniPg/b/3jz1Yx5h0eebio3X1yun1S7/46vqvf/rx +idsff4n//dvr9/5gAegcFzlidNnL/jAC7b2u1XO2G9GKlJvnGuAHLvve23cGR3DL3U9xnfHBvc0 Fd0A1jLC2X7zTesAp3uwsg3R8qHopGnuI0/tRSyWt9PR6icFj7AF+r5xxfpO8hDj1Km2ttNQrFT6 dIa0xXmojHi0aIFOvJJO22Hb954VIB3AkoeJdxMDJg6iS+gQQEXoSBYHhB/+Ibj6nNZBCpnyFTA2 hG/UBitPaLGeZuhgqsE8HaD9lTV7J0gR7nGy9hJ8tl3MhCADZY3vWYjvHh8wzqlDOXG3awqee7p0 ZRUCB9WSiXVNJyFdeMa1eerFQ7/e5WZaW3tNlzXaAml0ArEtoMnUvsgm82B4bttGLBpxBF/YeiIU cDJ5tSXQHQ0KjiO6pKcr/u20czJxpQgVHOvFjXiNedUTqXzyw0f9pj9/dcYp2q8oHKgLxVtVmgzm 11fNuQ2/fMRR/wG+sxVgji4AASxty8mAcBArbHtcuZUWdzjZ99s4A9zn9qY9yuz4ofGTulu7IeWj Jwmk3zJROZqVv3ToF9FHvsfIslOrR1vplC82UwdyyVI+nHjBV5uBWr4mTJY49afBsMmPi7ErUwGg L8BvMtE4OK8PIE+A6k0RwRSWehg/Vi7taowHQOFfiDgaNuyRR7FsT2BSl6z40f89ZoIbqsFbWycM 8pXP0I6N0d/x2jZMW/aWRA915SEtHpYZeYdg8JPmUVldQn8kzTrRwG/nA6qyylB5GMPAXho1k7PE lbfhqo0mT727Gvjl11/n+RBPr8c8u/DJL/38Ovzzr6318rNrsatJSFLaYJcL+8EeT21PK1cvNz74 YB3yFX/RQFww35rAt7IyGo6UkzIlK9Kgy0GhIOOJUnNBgkkjw+51rfzIimRg7DIQHnLR7/jqf+bX PoBf3dtncaVSpH4aiEqRMKXHCtIQbcrYC47Sy8iXSiXNj/xpesVDzvUp++zKwHKVceK0/v9wXx76 n7hNCfP1O2DOOEFb0WfmljWYiIbogSbLKjflGc3iigYmhIDllmgxS75l3PnqeRMNnBj/pVN78uGn rqbf8/Ykannbj7q0gh/t2COe+efuTMcYH3JL1p3bd4hTPDgV2bpDRhue7d7UE7f8yCdf258O9HJE kIxVAjrwcVwyLKPAKlt5/ikYSjoISw8M5vS/gnuKpUdGAH38BAYgWoJVxj7zJePVQ0IUH0aAiGT4 U3BCN8M6s5VE1DpaDZGNEfAyEE4bwLnaxABSAYpz8BKcVJSgSLMhl8bu1UO09R226eKj3mMGDT20 iSr8YSAiHcGZ5xEf8iQtChPF+bCn4R8HU2Mc8iXeBlT8OihwloI+id3CJgJUiG15kEF2mC0ZArIs ZELfYYIAK+SyQH7bJVGE5eVvVmnJptpd7n+7d/vueoYVE19NdJIAeESLVFd0Zg0+Kt9goR6UcAQC x46JBqGMxC0G+ay8pTZ99KRm6LOpfXCIFXj0NzoFXrocp3ZmXl0lPkiYIOugF7nh68cZBOsEJwlM zYhDjysEt1k5e8RKsFs9dAa3ryn/Aiu8qDvlLuxHrlje86FVbA+krvRLr3B12IIOMhRnaciy+uhA Tz1+6sTcgwpueaAydZQzsHCEnGOSdzGV172dyGRf0dhtK/uiLqIBnzLUn0bGNtRNzJjP17LWqzO4 64HyHuV5Ij2WDUZg4QWGSJPP/Vd/cNw6chmtGurc5qJdIqrKuwvAbegwD78G9pGxdAaXOjsuYdWJ ViBw4rmdLLk56cMDWCl0lj8m+aeslLEBMjuSIGhM3g7okPn4sbRDL9/BoYVQlsNGgcrgmEBd6iar trpDytjo5zagr6At4E2nyStFKz+KaOQU+HgzbQ59bOwI89K9oncY0gf0U7fOW0Ff9z5oBlnI0IAt 3/oH2BpkqKe5L2bskGToYLWDBvTunTvElAfrZ19/cX3ptUvr8qUz3bva7hDk2z352KYDx49ufLQ+ /PBGW6Yd6PggPAenZ06x0sKK6c/QGSCErecuXVRU69bPf3n96Ts31p+988m6zLbhQ+ud9ePv/QEP kbrCg6k+XW/94K317JVXGTSzfZpOpzhdwX3slmF0cJyG98hT3CeMfk/hi4xvk98jBt+ODR9gPyY8 gY9dZz74x4BTBwsafDBeK4bIbDqb5CHo9Cl/+gK/6slYzGMHsotDxKRTJy6ux4efTb4/+OF76/vf +RGdnVNsYb7CIPj5nmL90stXWOl+JnvLNvQBptiOn+Ip6zzE4jFEu8vjOKtRp07f79VNb7KK/p/+ J//m+pcMqv+ff/bt9Tu//WfrO3/6fpb22ouX2mXxgK3XvVNZ1QMSa4BXLpCFWp9//m5+qBw4N/aM j1rKsvxmWCp9QBxUt7wXHQPni7C1n2qYKFzLbf8mvk9Ma+eMK/LGAhRfnvbHtef6hXryE40UUz8Z Nvbag+vUD9/iKr8ee8yMH+p3m4/x1szaBPkbmDCOfoGLsIrHFVJMxtOARcPIgmvKSouktQIATges DqZsh+302ekpxpFuWW/Z8an61o0veCCilCeeZA/AB+4L588BljueLOtAw8MV8KNcRyN1fB+3fmgM 8oFVHuJyotZqBzG4c/UFLfBuef1erVCU73zsH/hOyBnoukKOfVNOs7QuAJG715teSNP29YEUQhGb ZZFLB5eVTbZcWd1yDQTse5AQf6RbXmOVImsWd4JgHVI2mF4JVx4s3QO/StzkQjrFB780IMejTEb1 jm9+W8GUfmTaCjRljIfCW5/NwNWBMNYUzh4QSntTXwc5+GsMdpEg24SGYje6G15Arhy4jicutM2x Q0nzXN2S70ca5S2FKToqkwaaTE9YLTyYwJ9H7Qv1pcXDOtkUaabkAckgzy+tfoL5FJi+hpND4LHt U6fhJNMCHPXTqFnbSBrg5rY0zynbRx441ybSMdd7fU8hHPuZLaBPWA57woTONJ/gRT7akdUluPZZ 9HyS40ZHvFLG/no0oCfbJytZzmLZuXFY9Po4aXIuLHmdespa8oZ+C3ku/PQDLZox2AVSWeUbe3R8 w6W8gT/MWjbk0MIZefq9acLzcBB+DKKcxMYK+X2yrvOKvIus9j559fx66pe5f5cdSQdHwgCmDHCI TkjJ8sbH64N/9BvrnR9/bx3lyeEuHptHT2TKqYCN/mi2nl8uxk4pj+9HcwWVs33VgaLlxH+44V94 lBv7tH+pvw5dtomzqisN6J5kdaCwXPm0/6S2BDVRxnrEJfxsdLfLnR1XxLQNbDIuDup/ogdPGPk3 /WTtVw1R37zSLTG24YC7g8pjf2DffFu+hWH/R1+fksAiWEp7A2DhwaflhJqfoLMG2SMcyo48jQvT h+caYK60H3ayJTmMXOyTGme75RMms1pphHD5cAyUfKNNLpiUo93wXeyP2Bl1l51zCldzl1dlbuwJ EkilMV/htz4fNNrOHaEw9/SiJEEiTINNKy0Q495zkWb05sfwAHCWSoJV1jiO2x58zynbsfhMJxhh 2/m2w63ggOUgbJxJhSW6gZuqIJeWb3AaaCmRAKwTKv4hPOgKBkw4uLBx0DQLtgSOMdNx6CrsdeWJ z3TEKN82CJ1inFdylLkab888J85mFtDt55MeLvkWr4MOEo+wxVCNPWDlo1UpDEeF2YA8ZgXkDp1f VaYT6WAGUimWjmnYNJRNnsDzo4cp/16NoKEYfMFpR1JZ2Ji7Ku7K010GjG41PduTmilKfcvItoYu LRqUtHn+GbDHDSIrZwPZyM88K8tsX+ikmPxKs1c2pHZ4XZ3T+dX/blxW8bBTY/0aB+AVIA0qfD3c w+/9d+LyHma3ZvvkZW1CmduxADIPy0GmDwwi8AVZ3ud3lxkenywukxq4DXTBGTl5z8GkqhJgU8fG G7Zkgae+nezJkhDHn/qjvvSLgHIODlzh6pB+qVD26g5eDyYEhMnXQ72IwMZRe+jYZKKkC1ykay+z zQvZFUxG1smAfMFVnd8aBhI2aMAHKnj80e/yJXI7jxc7J37pjBHwPgN+K3VsE9HR45f/BiyDmjin U2Ce1uFhumX8aq9TBtNgkHKy1cMZzANtq2LAs5y3Cxg7rLvTpqyomh5SBIAKvKCc4E5ZaI4pyiln fViYsiQs/gamJx2bTBKUusHa4VnZW1Ab9bfYRJJwggK9+tpBYwU8bXloHTo816zcCaL8bZS9R7Yt 4UApDohDOHwL/vm0aIxn47NQw4zz/fX8c0+tr3/5K+vlF6+w2uiDedQfsTHh0aliFuzTu7fXu+9+ sG7d4snM4XAG9PF6770P1nvvvlsMOMpA9KSzm9zz+da7NxqwnuN+WHvvrs4+8+yzyfnir/1b61le 9/DhR5+ub3+Hp1gib1991ETXiIedIGfXi1cu9XTlYic8PmBnzj0Ggu5KuX+f2HWfwtDgtjMnz+Sn 9wlr0/kCg13qOdF40tVXG051oKb1BQ7t/hDPDtDv2vbMNSIrXYgTifF/DOT0mbM0RBcaiP7kxx+v H/2QVxadeLiee54B8Iu8xumVF9cr166ui6xyuxI1DRu6h7eTPjn2EavApx+t06wg3713m5njI+sv XfkL6y/+6jfWd7/zk/XbvPv3X/zxW+vXf+/70fbaZVbLz5wglswD+IzGrebJgXKCh2xq07WV8vXs K2vqupgaxIkF2oTH2MbIoXqkJQfwWLtOhAU9sNvdtOXLItPR0t70J8qTDoVkTF3t2NcYudLRdsED WwSSf3RCbRuKieglfwqZdE7b6WUxeaMZN4oWlbS3jxIDCr7gJ737aDl3EmU6duRDo1wVrzqTG+v5 nRn9U630ue2VdsPy4rBN2/mVhq7lZ5fPwDW2dI+8v9IcPdMvsSNTaHMipnQLKDNtcejO0vQDduF/ ceU5e5VGPsnTGvIIKcaodp2Q5opDrxQiw/ZOW58YIsKx9/QNYfI2vAvVvOFVseyxVlnJA5WTg3nK qST/c65s5Advs2D5nfiP8uEPCPRCj4fyHr8AM3Tp98quuKi8LQTc2jrosr31Sfv+GndFOGQNJQCu 7QsGVe3LqCJxy684pl8Bj+DuybHA3eND6CjnEX8yxDH9Hc6FAQ/m/SuHNmG23w1XUKSvaht+KnXt r7KHh/RI4e67BX52Cwwx2EcRp/iUqrak/kzrnMtwco3QzK09S3IiEgiHvHskx85GjwOPBGAKX+KU XedVlm5iK32V3qJBEdsot4BC3NDIf9HY77NuMUmalb3lqe9vFPBPvm3/7FdYUZ3sfQN5V775peRL i31vPsLeoMTPrp94ot6+yiYPHsLS0fqtKjAcVGwybfIJvsxyks2BpETuPESboobf+kkU3HE5Aarc H1LPNwC88vIr68KlS+sw/eadW9WhLKaF8Tyy1iH620/deH+tt/j+7vfXzf/179E3/Ggdpk18Yl8c xD1ICnrSLdpwNdc49Jh2Pb4Btes0XTeAn74IGYypQCY+Y4WNA1DbaSYvZahHB4rmk+ThLzSbZowy QSsbsrVj9abOjT36Or6kD3LMwBTYxDSnAuxBFV/EKx8WCuaOnXYAGNp/WcjRM1SffYhr4ok0SLtx aepK3wCUVuMaFa1HgXYvAAm2Bz9pUqxMOySRT/SQYBwyBjUWhL6NUitnl1oenDApSdskJHe5aivU dYD8GW2x9uHESPLkXFrtZ9jeaOuuKp48eqpB731ux7r96T3ymEjVP+QFXvO5dOb58CKfs4gBXoXD v24xlOmW5CEs3ssVMaSmYAU5DLsaJsRDDUxGKG7jEO9DH7REtgOrBjyw2tZeVUF9GZoGACGEg2QF g9JMl3i3D+nMDr41Gp25gwHxMKVzI1jwuRTuao9CcwbSekBEiVNFpU9ZFaGwNTXSEDjiDvZjZ48V kDTKPficYddRZFk8c4JRgldypDe55IEaPVApbBwQRFuxGDzJ29Dglkg76QicAZ/ocwgRKHMbUxHp XMCaQAY8+MnwAGqQKZBIKbIywPkAEu93O8Ue99OsYB4l+DjrJ329OzJ507lMtmOMYoxNRKWB742s W5CUio4YUuCbL662qEsf5zqf2yVzGqVKGXlJNtRPr5YRTrBIdDAqe7uAJAJYHsras6PMBOU0duho tO3s+V5PO6efMUDwdSY+ge3oQzq7PFTDWf+bDBZAlFxGs4AFrvCyq35Ne8K7A08yOXAiOxknhRcK NljlV9XNNi81wnW2pPsiB/nGF5xB0xk91H8feBVftsu5+aVrD+RoIgazbEbASLngQ346pzRUcG7e yEgvrFFMRviSjY5w+c2HoM2xkx1k6VSH2RAYBfPZo/t01h4cwAy0dEYoODoBJ3j832W/2E+8qi+e RI78tS19q8ZM6Ft+uKHB8uVRfoL2Dn9+9/hRVWgzSHlkkziCFAz+XYakoHtJHTqRGHza8Hl9QHsC sxQHsumMNHmCIMUsR2VTS+Bcm0ueyeVju9qo/kuynV1vz5gBLxNo4gCnD2QQ2sQS5SUd4BzwiETb PcIqKxNRd2+un/3Kc+vN169z/+zTrKQyAeYkDwjVkUtQTlb5CqL33nuvVfgjvHdUm9Dvm7H0vdqL yTQPYN9l+fWTW3eYGGIww4P+njrkE5Mfrte/9nXu72WrPh3YB588We9/8D7+8pgV36cZwPI0Z6rD XXHyynOX1msvnmf1lxEAfOX7xEDeqClr8eyD4e7d/Wx99NFdVpt5j7ATTnQglEPtA/x6rr21a8b2 gUbL1xpZ9yG7NfTVHuhTOUDjJ8InNLFqbadjZv2PH7OR1K9YeUY+zvie5hVOhw49Qzuy1ttv31s/ /fG31u/88+/yJOgLbIF+gft4X+J+XlaAz59r54EPuKBak5TG1VO8M/jhucds4+bVS0/dWj/3jVfX 17/28vrpWx+tf++Pfry+zeD3b/7d31p/gkyu8s7hC6wkfOa7ktUL7UhRANy73cECB/zq8tA6K4Gb 7MzcDCA/3uoVr8kThtX7taxpwuC3tnQyiw8WnNhe4gH+DTu2o70Z8zvbYKILZWsM0LawkynvDLrt iW6xtRnhN96hBNLFkjeYzqEZW1377oDh4tgUBBYl6H1Ku74R29iAdmBt00vjn79uQTuKTbs7wEnS gbvFRsrueMIrdtsHUYwgkAnEDGkkam/AB1PuYy+4soPLnHgxRkj8Vs8fbaOJ/GqPPIqjIqOAvm+5 xjng0ALu0263s4Pf2jViwrA5OlAuUbrxrl5qa6TZrHAJdZOJ18knovNHk7QT61pOeUw8sc3Ap7zW VgTHkQ0d6AZu1Tt1KQKP/uIHxmgBE0NmEnCrTZL9JFfanSx3oHuM3R1xDkx9UJ8u1m244mnTgTZj u2ykVt8UzTZMs5z9DROVi/2vqTs20cDYuvE38lOXthNOlE7boJwmvspTVFN+bCoGk0GTQdQjBdkM bnF17L/UHj+KJMApE2WruOzrjC0JRNqKZej3czjYGGWCYVnkPHlDuyKZW+mM58jMjpxK8IDw4Yck dDFWEuLJ5P/IRhzinzJNSpGQT3yBj8/tQ1mCR/h8olsA6jkDAJ7pX+AxPOQJo4rA1U6EER7O+zWb Q93tZdM1vCsH4SiL+m1cw8FmB5x3zc8QWvg8oNlsSo/fjn5lbXQ6saXdmU4wU9Dbxy7ynt3LV57v Fh2wu+M7fP4XGCR2HHrACh/bmNd3f7gO/fRt7iGk4J9+QAx/sG7abqIkbdVjdMeJNirtBhAPeVJe aXGjCwT2zxUTiqyu8h29qC/1ICn8o0z9M23KDxntSgsmdh2MsdW9H6eMfVXg+A3yBt7YAIWF7Ye2 E4lHB5cSWmzZ+x+C9Uj01hFfHcFqR+umDkm0ZLR26hXCtk79OUpUH1GJdfpzo5tqUrY+sArisD/v yq8PIyUiBmt8zTfp0FvB9+Ux+eNTEYmQreeYztcSmU8wKk5MLHexxH61bQrnthWU96tuPPZdQdqv b8ZBRfRteVuLt9G2c3HqyMX4BvUDjs6ABxfJSFvQT1wUckkOJPzP+RUiX5TpapEdknEIi2soAIAW r+ZEg0Z5pDvIbSCH9x1lVeIEo/abaMe8nKegrLBcHRoB7YFM6auQmBUBX8R3EMjtjIaT2KiAckTg DuHgUECjG+iFOTphsz3FICw4GeQ3MWZjVAUnafvWpxQiTAqanoPa2UVRwpJu85oIoEC0wqt07QFC 4YkPjusoK48xchRAX7P7PIGSTKHTcnuAlcTNvqLTc+XkzLXr1+LRZpwMkD6d0Vlo78u7cOFis7sO DJwRKVgDv4aFwvItaxl91zqT8iCPX9MHKVgwOBDHh/xaUZ57OAV1XU3sQR42TEkElJwJAnePH4Hp MG43U6LJXX752oGy0WsAuedRYAIU9Ih7o9f6dog0dNa6emKkT5AURlv3MPw7rFJJnw2uW0e8f9VG 30BBsfjwvYEn2Srqw5js2ugUlm+ATooYC5ObbORbHSkLG6XKMXCW32jzv6RRvtOEO41nKkA2ExSB W6XhSXhJJDsRknpUZgJWNtqeMjB4ICPgiMBsz2tklR+UmKMMntAJlVEHG/eYBPGBVa5qWCCZAicy s+2xPf6TKV6NQgyWnU4Lp8jmECvi867V8pQHaR3pXdpGRurLYE24GHwC1NcVBIe69kw7H1uHNNO4 tkh56hz8PQ3b2xqiGTj8WWgG9mgO3NZTE9Ju/MhePaestqbeWn0UeNBHT8pLO01nnY/8tBdrPmJX yj12Eri6WwNmYwIf2Ut6oxhHHa455b8yMPocWp/yaqFLl8+vr37zq+u165ex1dPrvPenHmMQdst3 yTGRs1xNvbfef//jJmzG1Y6ObttSLAI7gEOzvBTP4DM/ZI+wrwY6+fTldYUHQbni+9M/e4v36N5Y ly5cWt/5/nd5MNWHTPCchU/kRrVHThYS/P3yGsR1656zpzZSUIQPKGKFd+Qpn2LO9uFjbqtyoox3 9H5yh3iDDIinNUbAa2AOPfqk9z/fvPt4vfvhpzxg62NutfA+R6UyipWGYlByMi6PHTAWIuVRq9Yn 2Z7shN15/PPcKR62RcP2FAOmo8zqnjp+Dtk8ZDD/6Xrn7XfZrvwHrGafX1/+yvV1/dVX1vOXL6/z 58+2C6EZX+g6dgT6j3Iv7+mz3AZxr3ccv/zKc+vV61fWr3zzxvqVX3pjfedP3l6//td/Y32LLeUv 8iTpc+B+iHBsEEcg6h3JwIa8jF+qAm2PA9vPhr3QzDZ7Niv7kn3tlPTd3qwbcH+otPtHAEnby9U2 UEJ/N81yph20jdUWBrKc4IIri2faCESeTZpfR0Y69AU6mB3QLCnSbxTRds0RV7gpK85WRHBqdyQA iBKkGwP1BfzNa+OoZXugGdBsI060K4QthtKuX1NSuCTwq0zgR3r8WgZ66jgLn4/yNrYMPVbGhmxZ pHcIDbfXFBXE9o8f46H8ibf4QHsV7SNPaZWH8qhmkx4u9O4Dtu7xtT0troZl4LSlXzxQlxyAEx/w JUzTxS1PXVZul9PwIl3qIbqDxTW0KYuBIZgtYzs1Xg3LpBcDkAW8OahSLhaPpx1unUf7X77qyfbQ FV98ndWSY/hUuOOfevDs9cTiwCEb+xtiHLiyAXWkwSdl7a/0rtWDcuSNKSgCyk3b8djdBj7Bxrwv HPHCdTg0KeyLavg7/1Ku+GB1k4Plopk000VwcL3RafKeZr5+ksq1M/ALdgbZ1LWsH07EMe2rEIQ/ 1IWHvIEp7+KkvIX8J0CuRzPQvunBbOF7KCcPr9Xvbmf6wwy81KMxhjIAtz8lLcaw0kmzf6JtFZbC EwAAIABJREFU1qfm+l+xE8BL7+6HEmj/fccvbi8UUbxXdvxKm5I++ZLK6WtwtsUS/f4BdrQDqFTM C3TorR+J4yabSYZe2iogKn/7TOY5GHLX546nX+Rn++whblqm9Yg28YWXrq5nn3+OVAiXEYmnpuIW /SFu23nqfVZ1v/0na33rB7yvhsHvmZNsFSLWQMtt7gnl2YoYIJV5vZG7NQMhOL49m0Z50pZhGRSU /kE1NmH8pA9E4tjGVBwe7fcCWnpK3uyDc/UkhcXnoEo1X/swpOsf4ZEGLnoIHH0p66lTY4DlOqSH a/2nvNoA0gIocPEKnD9lm87Qp4M7QFjOopzVTh/EQSpJg4ftt9K3ORi4eyVoIb02zvETX9y8+Cy8 IBM7RJTNCk8b4KPNlq+MjE2VJy8aWcW1Gv+6nRJCcIMWZexX29d4eGh7DpTUxxMq1B8imjTqH7PP csIFQxa7uJ3TnbW+gUI928/Z5W9bY7tX26N8yct3oEohuGB3ZLbyQCydrRwdQnrPEiu6KsDZie4F QFHwSD3ZlGOBKPApJ9/HdVQoPESAPcerOT5+/PZ6cv80HScwW4u63gu7O12NMTkKRUcRxixXawzA JiEnon6BHobbr16nTCfGgMlrCRzcrvrWEYbpaaydKYA+gqur2UgCKjgHzoQIaALHQ+69c8ZEQ4QU 8Do7bUcPXvwarKhZR5sCM0EgJGApC9MyXDqPwIgh4PhqJ5+u+oSOm1sq7GQqQ2eYa5CkBlotvw+Q g4RhhhuduHXoMPSKG/FBy9CjPB30ei/0UR5eIxkO5OPLiQGNAd66tw548ulgBsY2IwWTuKHcwTUk cDawswPraiRUUTGH2YpiWNAYO0hLF1Ss4w/bXkNqMhNWNAfYyQ8BwS8C8GNBBzOmSpdB34EbFCQf daSx6rjeeJ4+KHMcmT7gV40YVBWKoC0rE8KZmTEdhckXZph63yjZ1tHxdEzpiUbg+zRwHVHsDdKQ tdIQXrYqT9JpHdK4JE8vMHXy4oV88U8nLwjlJ1zOFEWgpUTbTaecB5C8rX7yF27Xw5NFLC92baUP FZ20Ee597nNuhY0064koSqFzbIdrCk5DOWQlM4rKl1VsC3zgkK9x8mFfGEgN1AQy8sEjTPEd8Kie tJVgi3dkJLiAAkPataUGrZRVbgZVnaEgWwqXNivQsPtSIKorKOqBY5d/AVtCqFWapx2UkR8Vqj9g kxRJr8YSDwO/W14MoMYJ773toWjKTnvAPuoMb+WTjUA4BNsBbGdMfQCHryL65Z99ab3+2pV1iVXJ Z9lyfOwYEy08gfnO7U/jxy3EvnLs00/u8r1FmlIYO8uPgHuK9809QJ/79sqdt1lFfbjOnn9mXbpy bZ0H/ike0nTn1k30/nD9+M/fXefOX1wnzpznScw3sydjt7wdxoFv827e7/3gJ+snPz20fCr0+XMn eVfvSV5rdoKt6z4YgteRnKBRYQXoMHaJdzCB8mjd4GFxdx86E6v/zXud1cNjtifdY5B4A74d8N7m AVmPiQ++xuSoN8xYQaGpJESufhTfYWfit3aEx2wGwy3VN3gt04+Ij9qeK+O+bu3ChbPcA32KLdRs YT5ymv7NGXA8ZJL/3vpH/+Bb6zd/43fX81d8ivOX1hvXX2Xr9qV1gRVgH7ImsqdYUT/CLoUTwHAn 0C0mHp554cn6i1fO8/7f6+vX/rWvrG/98Y/W//xX/876A2q8wmDaV3Ddd3Ub8hXi2O3YC+QPT2aZ o6GayGm2uOXXaSU9HzR78wvjmLFBnY89TZ5YtIRkRHnridfDuBwOzi2zn5sXPfyObHdL+kI6UIQj vNqwaNppDaPuB5yxeZnQj8f2vWeVji+2s9Ov7zThAT9OhvuaiFYPac89vI3HNs24MfEH+pWNkerA T+1MgxvZ7e20LUCdpk0oRof9+QnCyd9sy0jXnne+0w86MkHwuxziDF6sOz6MHCjQV4kwuWQc6ovv unLtq6Sa2FZWfCgVjVIfgrB6/vmxxzxTrLMfsuGAOJtAZjOhTKLplrWAv3xrf7kOVqmIHNqysNBZ b+JR8YzzowjEurbz+rhX7jKxD+QDXlxd1w9b5Yhv2kPq4ZV0ECntuf0kPm1jVMD87W3B3seJWsqa Lr6MBZN30K3pm1gHHViuIJs/vGlDLmqMnE3beaYC59q/MEVqpBndKAPxqBeP9OU5ZT3M9zC9FOTT Lh3Sdhz2Q8RhGQvZ57G6102EWnejJ/iWsz5fr2sHufKZNaTUP5F/+wR9IEcfgJrgIMDBJQzKSaP6 Gz//As0SAQR9a8oMvOgl3WehOClxCN0Jx0PSbLuENf0k5VhW/+RNXQmXUfOB3NqRQ9JgGBnIode7 jgQjzP0Y/5R/+BOxiPipnuySNri2c2zAYvblDmiiirxp7+mK6+7jhEb1ZPyIj0RLJoeviiSV32Ps 4LnKDqULIihvjAwK7txch2nf1ne+t9YPfroWz7KIUCZ2ERplIZAHLt5h199TtD2tHGrTRQxki76K 16Q1hiBnsA8a+2H6qqJU794e0iKHvqutWx4mx14m/sy56WRu5NbH4jJeIcky2ZqyEgfl6svCs3FX usauGL+QJiL7wS1YFJiNX9KY5vBhd2cYP0fOhj7r1EaUqm9iEyAqj7RooH50wGA2QR379FbfadTz lJG6t59vueHNUoNPXRuXx0dMpRT0iXOkRNlNINrA9L9QDeWMNpbza99GHArcOKGNe7uivmE8NN/n M+BJm80hc8oe4balY/RLnUy7c4ddjEMB1y6CchFPc/tlu1fcvqMOzDAP2BZzbHBEAWSsgtmIdY+9 jLOSnaLG4BGMXFLBTpocy4ROOTMO8iGpZMH8BR6icuKrb5Jv0GZbG0xNwAAoTKiImHZpQDwGTmkg kOiij+m0aBTjhCRbB+jdb2s69Qy6MkhJHtKy7dMHLtkpX6t50sonCDgK8kAxALZlFz4L0DTc8mR6 Bl4ZjJJqpuss4pXQscdpDHbjUqm28L4LMeSUk1pfqnyO75Xnn2GA6gNkDDRjhFm0RgKQ6fSOgqTU mWbpijYRIleV56y1RiIfXOLrrmq4UsLrd3Qu8iRBsHUsEIQyUh7OPKmfBorgUK7CbLs6NCnDsR7p GxjqXccoGMC+wUD57HqpUanTg2bsPAiTwKFdiDScSk2AHNMB0IjlSXuSDrY+8Cs12pzGKW3yIdeU iDp/CSmV0V4NDjmQuEj1vakk4hxuo+Cmd74+yMfXtKi0ZEzacWB738pMkACV+oWDraOSs0qL9POx Yarhj29kz2foNogPX/tgTp5hJeGZ42Khha1PFjXnEPZ+1WlXQKbcwSsftAuK6V/TEdCmTBsb0Eed JLCz5uqEq7xBBUa4ucoK4XmXvzl2gG0GLDOBGjvNNhjw+lAgVsXVXzsy1Dn1O6jXYNIJp43o8AiP k4khO1dqhIM8yOEY/uXbd7iZqJy1l6QPDwe65Hwa0ymjqWjD6lB/8CgmaNechxc4YsxukIvwsx10 qrys3j3P2FoqwdTvIbMeSoPPu93Y+q50SKMy98Dck2Hn8DHXpknbWp+wunvx2TPrL/8bP7deYQD2 NPfuPuX2QRrjY7zj+iZPYr7JwPQTVkGPMSA4zQDsDvfOatluxZlD+5hnALjS6lGjURzkncBsUz55 +sx6/plL6+Kl59Yp3mPb+4KhR3m8zf2/3o/bapu2Ai/z6kNwJAV1gByQ682bD9i6zNZfiLejfJKZ 0zNMTp5ltvzs2aP4CwMZdlIc4TUAjw95PzATdg0K8DvqK5+HTCDe4InUf857FG/xXsSexssAyMa+ hxGO5tOFsvRjnFBFyRabVdbqTQrVr7ZwhFfXuBLM64J5TdNdHtR1k0buCKvlrsQeoT05Tpw7us6e PMuDrI61vemdd2+vd976rfU7v/W76/r1l9Zrr766rr74AivAz8HPOfwTfTJYP8Kk4MUTbJt+yEQB W5+9F+gcrzW69uK59Re+/hqD37fXX/srf2t9d32yXnr2bJOIjx9is9xCoR0d2Jg8pCH+IX/Ps1XO 9nRq0XHiP43unpYcGgXpDJQtY/RiIfP34+BcxxFHguOU6+BUYS896ftVLSfltXnL719B6MbGXdS4 0Yz9wJ04tPcdvj7hob43N5hrgPgsD+3Mbw9k2XDcvcuqC3SdZJv9yEp4wBUfcOB0i4FeEzdFK0Ge RA8/wJcGj/7zzxhNSJdKaDb1c5rs3JlkuvFe21PifiYOKGeBGydp7/WLGNqed2AboE2LUAzYSniE S4qw90GzPIV+K52swONfNPsrP9StDoUrX36tS3nRaR4V/Y+BcsZHukinePWEaX+je7BJAyr/xg7d xSR9J2j31YN9EzuMrtDVqd/ipPgDm46pA3Pi9xjf2/puXEcLBSZX37SPJJ4Yk8K2NWrXFdJpndGw DPUsX59kg6CcR8/CNPZgD+JW3xzZcdekAcP2sTZyy5N/afz/HQqIo74NMqn9UlZ8xzeEPVyY1qAY /deeWU572Mr6m5yDxzn0UFQApWtL2dOAS8aCdheQv7ZJcQccj7GtTssHYjyJZ4ZddvynT6ddiyrL sDr6q209gLPJjLp7myet4pBP5V2fnPMGVMqSfEGNLPhNfuoQ2vhCsQ6fzWsMO7yy/Ed9C+994KQP o5ZTJvKr3C1nmvrydrPBN5MKPkm5PPnZ6qhz5WS9aOA6m4EYB6i+DeHkhdPrMretnOQp/UiJuIHO PuURzj/987W+/8O1fvQWjS3PxtGgHSDSxjITms+ydYntzp+QxQIHg2felxKuPQYqK/sWj+3MSwEs SBu9mPhV75a1b6sYR+vDp1fGCGO8eXIyclDWyiENgpv8rS+oiQqPgtmwuORdH3f3Xu+6pu7IB/0g q13G/SqnET78cS472yeC1WOHuvVc2FCtvOHT1HxJONBn3zF+gaX7Clu/8FTbGghqiD6YdPNrn3f3 I+1MU3K4rT+4ZOmmYW1aIOnbXwBBQTZK0QaXwn5gDE9l6ItyllGG0nuYGAa29GM/Ih+Mf2jFz8Tb JDmx5jj9+GM8xOomt4X58N7D9LFmUmUG1Y0pIMK3Eyg+wew+Jb4RJJKEHsZAMCx1CO5IK5yU5twA UYNOvoajvUmIwU6lOkOi0BTKg8c+SXfvZI0gVO65507jGAjsEFsIgeFqagGQ+nZ4PWTe7R0q1mBi nxWp0NglngnqcSFD1pGWqdsKNI5jeRUrL/4qvKN0xFSydQrKIkMS4lUYNtpg56uZUNAz8iwjf2MA 0EuavLrV1nOPg0Ed56Qas4DSBdUxOhix6E7LNTpikmyA2pUj6ho71W4dgQiCc7cneRM9fxzSZ4Yi hD9fm4Oe7Nze+viTdYYnnJ7i1R867RNmDHVO5ezAbuBiTCAvYAkGGTkABDnxA/2B1xDsINKAYDDQ BXQW44QGk2wpq5x03IiRJm1HvJtcCsqbDtSecjRQWI9iArNWPI52gQ0OZaPOpNfBt0Vr9CjvRzlY Lh4OZnAsw6wNkyMFHep4b+RhZsRYLGLFjaflstJjx1e4Oqx0+KBs5e72CJ9SO0+nVB6zRbhOFHXk xVmh6FBvUJWMOcth0J+iyFFJqwOl8Dn8P+/TtAPZVTwIS7ggC650jI6hzGLwq70itmRiovpyosLJ o+SnvPENy3vfttuZhTmBSsjzARppArWaNsY1lZKjdAvANPK9z+sUq377S75d6pIfDUKbU49chX8f 8ApLAAU/9RQ87T7gIgCG/A8uZVUZ6mT3ILaz5mGVZoHnqv/ZTrY1uJVJfgxcMe/HyFMY8r15NLRn UxQ0suwTJNqzAd+Vv/s8+beOMNfKLl7SzUAu2G6YhOwOixoAG2p8xVXO69eeXT//9evr+UtssWVg 5SANxbP6eg96gAt/9x/eX++8+85647UvNaPtNurBZxxRFkBXAMB0O6505OcoykHmlWuvrGcvP7+O M/CdzhElqHObwfSNTz9lG/rxdeWN66RxL/L9u+wmoTO8yTXyFYqSgXd3PEzcC0uD/Q8+/ITV01tk s+2ZesfYanyMbUMn6VCrp89Y0VX2NBWsIj9Y737w8brx0W0aM+75ZpLkMwaGDZSAP/ecGy/RmTx1 qOOxbx/ilV6x5ybIqIMEDuKT/kESNLoVfHzwI95L/NYHDFzxyYv48yU6SBd40vNZV6nZgn/4+Jn4 +MM/+vP1h3/4bQa8F9err77O9/q69vK1dfGZ89g3u3mIed4DfJ5Jg4fUu+fgl47TuQtMKLD6+/Wv X12/8U+/s/77v/br66fQcI1VB1eZ3T3h7L/m7UA2a9SJOKZdVH/wAZulqjdtX76stB1NVmq7W9rn 8qHelp4NAyw/pV4d0GSHnyHT6m5i3eHsMWXPN93xiDbUEd0bEfwkbynlry4SNtjqSLY/wFPdhkfm HFy5A6udAMZT9KRnWc5JGZ9w7iq5u5JmBwtYyDM2llYHZqOneshGOQmF5PhWXny0NQ9lq5iN7W1N 9EKalJ8+Y+3yoYPgMtCUGQAo5wT7DHa5OQjduyIgLG06MPDRwIDi0ukhHfK262Y/32Vtuuddb/x5 LjXBlCCO2ngFgP/abkBA8chVEumvT7EzSk2T91jNCXFRHQpX/tE7sNwl5qBJOfttkLvBi2HQtEIp 3ugABmm2mXqVNmU8wjsP+JPWA56sRZn9a4yy9M6rIEfvWzkSlNvwz28fAeIj9iWgu/KyvMkXZFae OpwrB0j83Fa5tm8lrCQqfx6yhDzarRcHgPGzZQ/NLOIzQSe/xk21PBO3I0f5FIz4rKhc/daXM4mP mZbxSvl3aI9bn2f4sU1TLtI5pS3XAAIc1gqWxG02bGq2xvXeh8y2hOAAGJmJIpsXlorbDu1ZOvEs UrRP+VYzfEBhm5q9ijuFk6fPUFo6jCHqojzSpNP07Gqrm46DTh3ShG+kyyahq/62/MzflJEOP8Br scW2nr7X3t8DXOXVuVKy7BEmUe2UM83M5DAliSm2ZZcvPb9e5P28R1j9ePLhW+vwD3/Kyi7fP3mP 2WkmiZn0bLDr7pPkoHzs95P+Eluif+2b69K33lz3/8f/YT06Y9vBB7zGotpsaNyPZAEt/nXAl5pU tjCGHji3blSThEx9uKpH56p/4z0/Rrby57+qcqKovBjf0MZJQKY+GNJdF3Zh910WI2/zB69yanFQ PyBN2H4HizD1G7QTEtKJa+k2/Fv5nRbo1BKSRTasjWEf8Oex/8qPNDrGLq14PWUN0DNonNgoK/KW n8qLX9RRcnCBJTzwNNmAzuq/Us1ry7u7xthsu2K7WF8Jn0038rXFRh+2qX/49hif2qwub928tW7z MNujx7huDKfoZFihWpc6/BRzSJJTedKmW2igHM0U7JLTbCGrOD7IQZOyE1qwRqmH1ZJs8ZeD8ut9 It0QDWE+s1llpWgQaGI5DIBzOlFvRgCA4Bw464ZLIhXKBK4RZttUxalDOaBztkLfgsCjDPxSIPSJ 2sZV4WkcuAI0k4jgqV19DdSXUqssy2jczvgrEDuxCmwaBU63oKHw9gdxOMjkskNaW/XkVyduIACc DAw40pHbKHGMxo5mHf6uaYxxe2FIQwqBL40hA6CmHQyZkm+DU7RJH2mH7BACx9UkX1F07uxpzufd Vsojh+Rnd15XkXyQ0x4IMgPIzrilElrB0qydOpqtSsiSMs2acCJtHvLlmWwPr5RDVtEp/9DqoE2I riBLQ/eBWZ9zYaq8GmBolAY7aJSKT1e4zVNH0is/0uez+ELMb/15L4VlKfD59UZ6OwLawcWLZ9b5 s6xY6sVbOW01+VH2MJ3/o3Tsj3Mu6Ht03Aw0J8Dn+2ztIAHUP/CjK+hs1lja0OUWPw7kMltKpBgd DWGjN9kFf3wCuwARSaN3UB/ASM9c18Dwm21TuXvFYgKpQqMkGzCks1VDaEywIbKesLU/qNlwy2SN tLip32QV9Djo8h5KV2gc+M4hQOAgO3lRZ3YAbHyLCUJW1+hxONaG9PPR3W4rVBPrZueddU1l6so5 v8qXekMbNkBy9Oeh8GljQ6LBroaYsh7iEPd2YQrg9H1+KFuM8py6ykybdJDlw9Ae0Ii6TZLLIAjX I55IqZHUNwVpGf4VQC3H9z5bawyN3/y5N9abrz67Lj3tFmFn8ImBNPrKywctfMh9ttLi1mS3np/i PdqnGEQZB7S1YEKXJupr02wYtNG2lVLvNFuZL156tvuCfZrlI/zYAYID45sffbQ+/ujDYJ8mDjzE fn/64/cYzN9j9Xa29xrE803onxgycpOvfCxHwid8ynIRe3jVrm5+dJOITgfbVV9mYO8jr3cZHL/P YPceD+tyB8sRJt/qkAkfuTnRpqyM98I/0ClKSYalqV/8BxqK6Qoevk2TVuNFsPhvjHEW/BhtEncb y0xbuX/CQ6neeu+jdZGV2lMM+M/wioqLF3j38XFegfToaeR+l3umf3f9/h/8HveJOfh9eb12/RVe hfQcD8o6GR5j0xlWgh0037t/q5XgYycPr//wwi+sX/6Fr6z//e/91vpv/+ZvrsVOujevPjftEoP/ ZIdgtd98DJ53e//cHCHcQ76Vi5U49l/Pd3l4vh+m7enUItn/ynG+ltvz9zr77xfLmLZfWz6n2gru 6UMr8JG9h/NptR1STBV9QPsx7lnHvNjgWlsa3inI4aDXMk5KqMMCDPXloAEr5wNbUoQ3sPZ4Z10h DW9y3ZXqlpDS7Rfs2/iGB8sNfCctxetHmLahttX+dk2aXFaPM2OYuCIV3HY+5YcS0ZnMuPKwzk77 F9P3c/P3wzPLDvV25DwbfgY39OL3k0o6fSr7XO64EIy07rhwouRkH+YI28WPu5Wcr7GxfsMBXuke 2sVlf0nVyU84gWvR0YYS2vow6h36dnxTVtiTLiz9T5mYl3T1T1J2+svd6BB+uzwo4LDHDjmPI61u uAG2txHCEK/fnl4sXIAqr+yH83gI65RVV8UHMqQlGOCwTbaeNHrUXplPfLbdVF7T30NKlrMQZQ/4 Dd5Wj3yPTIGS0lCMIibVL5S+ZF0xwSjCaDd/pyF6rE++8THZwaB9LB/eJBGf41duw9sQ59gO+wRF EzRhFAkJG49hlzYqCl0b0qcw99o4I6jwxevhf21en24SjbxoDSzlYmJkIA71oi2K0v6cAIZe4/vY GhDI9Us9vr5S01ht2ak7flAp8ygjjRuqqgozOyD4XLl6dV2mH7u+9e116Ld+j4dUsbLLGzt5mTzv Spxb9xopcusJ78yc+3hfubbW66+sdf0qZYjr73+ybrLN+eiRE/F0DHKUiSRHE74RARs/2Vss6AfY CfTvsgAzNCMHGDIG2j41Qc217Tuk1yYAKptTHtqo/PuzMRw+6/fh1z5C7d9ul+aVP/qyrMD9qC9X W/V3cdp3sa9gedP2NrZ+WDDsu1CAQ79QdW1FRv5U4noIdGyRPikXv8Kj/PS7rA8+OuX6TbEy6i0s Vf1UX1uYOhsu5GXf2z63O3vNcxxVbGYQreXUzntGugss3or08Z2P8y9tQR7j17Lywp8151YadAwL txjwyol86F/aXX6fDKgiv/ib/Ga+G5xsPpDEVBuThAiGHuACQCtKhJ3jcfwRmAOYY5vxaMSSpCi8 H0ECosqOgNSBzFptn1VrChdBODDhqnONQVwRZKrCcXkavM2cKR9mBWQioVPfI4OoOIL3mo+NSK+y EY8GDD0NZskXT0Ln3I60ytYVm8vMQBykKYfN8IXJebMp8rJ9TRtom7GSZTBVCkd4orAzyrtRSpVl rfuY+6LtsNqxzViqQR4ybFVDGNA7irRzDrXID4r4oQ6QsvwNuziffvrcevobX002R7npNaNOPhuv GJ8rFNJTwI0cBy9GAulH3OCUp71BabAJ7s8Y6Il/wpXIOawgyRpR53Dt6Zb1mfdFMWHiLKt63l/V M3WsUmVKG5S1L++b1mbG4V0lCq54sy1wAUdH6b4ryoovvXAuVxDeQ5R0MAdpPhn26WfO0aFlhdc0 yk+nRn6pD685I+n45/CXTpg0cEaKyYOTXGs3OpJpj+jsKjPT5MGZp3Fk4KkhbJWToV0Wg5dU4k95 5WOUkV/r7quIu71kM5SzrLNWisqj7SrihVI7cU4KOOC9zfZPn2qt+Jp8oSxgI8MTwOQ/0ZKsBDYW mWzxj1Z3Gez6KpxmDx2sKLAO5Tna1y5Nn0GuPM8HKqdk/E2nZtexeUKKH6lHn3ZEUQGw+CoLqhtb DA1awMQZK2moc2T7+LWDjGb5qS9a4Yehc+GNj7g7Qxm3BY2ydQywKweSDj5dCdFGRx9SKBR/twPi 9Hk0ChzliBxIk17p/JSV1WvPnVtf/fKr6zJ29vSF4wy29FLvt7HSZz3M6T0euPHxxx+DD16Ir3d5 ifoLV19kG/LtdePGh8RL5O4sJfC9j/U0Aze5fkKcOMp9K1cuX+W+3eeJSbPjwwH7o0f3eHbH3fXB +x+sR7c/WUcoexJ+H7L66gN45NmZzNkho65pRJw0kEPweCinVqxhqM7gZmg+LE9JFA8oc+rEmZEp 1W58+mC98/4NdpcxuMFnj7GinQ8oN2N9NWdyQhzC1e7GiMVDuUFP0mYz4sdfvdTHzda+POa/CcCa nwM9cDNQrz3QCj/6+LP1/ocP6OTcWs89c6+B7ykmsk5478+py0wK3V/f/+5P1g++98P1+5eeWddf f3l96c031jXeBXz+/OkmM22cT7GC7rapYye8p/cGq9dH1n/1X/4765e++eb6G//TP17/57/84XqJ +4tPcw/07VsO8KSSQ5uDgV220ivRfjrnxxiiZJvk4Nyy/0odq3AcwNjOLbOX+2LeF9NHaNop0gBu Plo94U36LndSomWoG5qTfaRKON9oG1r0U5UTvZwac3Ac/CgCibNOpBqTjEHctsNEy06nulejQh2+ gePDZUoRLBLRmTikU5489t/K4e/aouWEJnqogIehT1y23cZkn1LfZDFwpLPODnRRbfN1YQU+AAAg AElEQVTdTeaUl+Z4omz4irXiH3p2Gg54kUCO/2/6niafFplSI2OiT9d7Z7Q+Ff6lnVvSnzppcrad G6e8MN3ngBwhpuhnPfcDmvMpa1Ne+Qln7Gxo13UGOjAob6qwTB37oF51yaFwZZDBPhCs/CYb0zyi cSujDr54eFU7wonwAZiMrCt/PjAS0aY7ywrR7xflKvzMjAJ20i2nPP3fd6NDmFgQaaTKBPXCLcQu tzzSg095U2TfTn9XFG1yIRjSQip5NHG0SYPbCg6U28ItzvAOHMsqs2SprON3o5nz+qqU9wg3aVQJ h/U8zM6OLMbFLj9l18IAdIyuJg5bLF8KkBfWGzhzuvMpItIRfP0S4Ix8Bn8ykTc+0hIvGgx/+qd6 8DMLTDORAKbShNu55cVNwt5/2iRbfjyaj50LV1wqN3uQ12RAmunY9z5Q1+61lxeuPb/Os/K7fuMH a/0e9+/aOXOwaz1pcLuoD3rk4YbrjWtr/fyXGPC+yIOsGBQD4CEPZ7zhbTu0q8ddFEIGj3gFgLzZ 9/WQV2OK4BSp/cpHGKneUnsmaRJjXdrS+rEW7JgYzn9rp8vKcjUxanjexxtVo6r68JCOuW8V3l1c SEZDh8TUT6Ev5Ftwpi4FOKbPaiuo3J0MAf/u/4KWD/sRJevPxkzsKLTypT1rX9I8Nj82GLONR6bw lLVaky6yzYVxNXuJZ8sor/EF6QhWOsU3zIMO7oriUE4uQLG4hO3MwF+g1OXjGMz+vztaJ57ZZ0O/ +bdcWp/S0O3XWOhzi7wNzT7wUcZa2rjPF9JEYtfy0ECPcqMLPSpMMsPP2DX5IJwjBSeNmoM6MLkJ l9J2CrrZ3BG4HVQKRHrAAAJSgRZQqV9jyK+NjwbggMDyOpSPrW5gt6UFK7R25PeGkEEgqwjC7VU2 0gWA3VkBBS4bRBpb2jUDmRQhiozFwUQGQCoQoXec3UxRCc774VRQLJsObfyV5v1rBwJ04E2dBsk4 s43s0ZwQN5Fv6o7ClJsChS6+4nmKGR0pcCBIZmU1FqmxQE9ElUc64U4CaKS7U1ifSsFsdZjIbJoB 3+sxwgnoNpB2lMXlQN8GP6VTTgVbxy0COrErOLMlCq7s5Ma72hHWOJvO2RY+hQvdn3eMocDyFG/G K1qUpclgxzYse4ogZMfb2XebtDq/wKd4vFO8Q/0+4aE0HgV6xCmXNULKifKW1RGE4TYIeXNQoyx8 z5Y7DVrN1/kg5Cid3UuXeGorA15jZrNcsoqxC3vHLccFek/C40wSds5WxxoNkhuwQxPdj/UUjqnM ky18Sa/22haNfEIf4JvOJmDKgGqfgxNkVBF9QrwU15l13Bp8EvdGUPgRxv9WKOHN+9vdnulDi+7x pMMHznhSpwG9xQ9kNo2YqEWzE9GKgmVIcrDhe51PsILg/cPqz8FlOtnqSGMBzRPxkO+29mhFmXWw KTu0I08Ul5mL0q8X8GpdD31WflUekii/MpzL9xTb9E7dsRfrSrOVgMdXH9JunYSwvvpylUqo7hAJ tz6ArLIXfQw6fLVX8SiZYxSCG9KGP0FwLTbhKdK28ZuGf/pk33u8G+4rb15ZP/fVl9ZFbEzfO8lK qORpKTaon3zyyXr3vQ8Z5Lq92eTZCm2cOnP+fFud7939cD116so6ffzkusq2aB4+zEEA59GTj7n5 Bc0yKLuAPfJEYYM8rwH6lNnNj258tO7xKirjMG+2o4YP32PrLR9Xaw1W83AuYw5yEqz/kL360QOU sxOKHtkZCXbOjVtj38AidnncxcY+/PjT7gH2Pl53xYAqOSp7X/VmfNUGtNMmOikQ3t2GKZfa+ac8 lKt41Sm1o437NTrvelOKdAqnNBTCM6+SixOixhlt5jBT+cZR4d1APuadcMsc/nr+aeTK9mdfgST/ Pjzsd/7Z768//BffXVdfeH599Wuv8dCxV9ezTz/DgM3nTfDAwdNMQJx4dj04fZpV9PfXN3/h2nr1 lf98/eI//IP13/x3/8f66cc315svMphmkgFusRNkIJUyxgHJfPlAfB0A7UJ7M60BvvJSB1NmbzuG 0x3CJh+BJQHlNvVMsR30uuPg5ws0BFuStjpkDb4kudUzcSMbHjz8qWNA/UmBtym26VWOSQCuk0I+ n8K4oc0b7/Wxezw91faF7gnF1HRM8DuTTqP9TT4A3zvCTeZh59Y55o6HYgn0gkczEpI0xZOyzLdt W/FxzvURuSOnMgSafHa3R6pC6/zb9bVdUl4qudpIzTYrvOGjwNAplDmU58GxyW/qIxtsUN3v8Iqt +R52qS2gP5mJjtBa1vdtc7+a9+gqP77G6zkmlvEfUxKvsdLf4fcQ/bPIF6dp5m0015aTqn6M32bN d+xTeQrJo/aQX2UxeCy72R5KcCVv7wsM9gpXRp4sK8XCHH1xpWyMxfzuqzERQDmP+mA7jggRgkQq kzlNlsSE+CJN+HvgVufGAfGHFzqtZnyzPxJPytujepsuD+Bs8trqWzf65Kdzb/eb+vG3lyNT9czA qJLgQ0bgaCBE0j4g6nYhaHRnkf4kYxMbAEA568STYIRPov4gHbN6LG9ItLpVj18hbVSGe+yJvp68 U3hiLGCkHxzG9iYfrdgxacp6dDc6NKvBB/j3FefBLYGUdVyyxWjxaFcyIokNUMYKSCEde5fHdCfz 0pIdypsTOvStgPUU8faFyy+sYzxDoft2vUWI5zB0cGsJDs72ZlaBX39lrW8w2H3j5bXOMvjlUHZS 9pgyN7ndaH9Hs7LBMszB9mxTiVnYhJEiuwCvExxaK6wmG0trvMoqfxEyZI+OtC3LjpyarAe346Py KchlvPJjNWsDS4zAhwYPy0+fdSu12z/t6/SV9Tnr8y/5GQMhCtnJk7Q2uSGhwrN/Ks3wMhNCcAQA bSfuNliOwvSTJEL+6FzYYpI3oNPOaoEWql+FUo0H0kXq2IW/woE20wCw9SHl1igFPHThbsgWKnoo 0txGudsK1TkOsTh/MjqkQT+W72w/+4I2+u3K1rhTPKScW5t9foS7z+agkn+i57Afo7/U3oJD+bsD beDD9wb7iIPLnsolMyhHAenQQmt1RWL2IJKszRumm30QKR8R7VuTJUAnMF2luQLXqjEO3TZh8lRC MxwqDG2q0DhQAX64Nh3IKVJjmQBHJ0v4MKj86uBq1sgh4VDPNIXY6gEnztpItbT44KeZ8SEQbQYu MleU9wBqWZ3D8hM8kQsCU3jyTsERsOU414EKFpS3rvC1WfM876CMdZ2ZqdPuFfD2GSjxuLLnEU6u 7caneAKEk2jJWdmBBPB1OEd20qaskIM02BlE+epS17CMnX634doBd8VLWAargZTED+AbkJrdhz4H zT4VWuw2Xp7liKYBT46Fr0MbKOWZyzrg0qRNOZOmM0JWtHltGXnrsD64pGIkILrJU5fClybfTWoB y54lWD66gCN8+nYzQVd4eqtPpMUwemCY0B7CoDp2MuzA8NVX4PkPPdLoMf4QgfGkkJOzigTOUTrZ duj0jZM86Va5PWTCQbna8fdptjkt0P11RiomKZm8XOrnyIZAPbqWY4uNvUuX58O6+ozdOnZ3eMKP 22SzJ3io0CajBpUAktQaHwLY6BcbQGfyqP84y3iK1V07WWluDCCclpMXD2mkeIc6kh8DnTORIM7W bUzGX6wDNso5YISC5Db2yLlEmeoPX0mWR21R/qznV1hJiN94NB1bzgerr96ghbQGWaRpU4Zm5e+k 0T6zisqT/wO2XuprYCv+iMcjzJwaW+ocQ8/+0W7kwx0qRsPbbGc+ffz++oVfvL6uv3S5Byr5EvV2 dlBOSXtP4/ushn5042PwOgGnnKSXpyDfu7OuvPLGeo7X65xgxeuiW7F4ivHlF86tq89x3/kpqGN6 1Hu2e20KdvIYW3cl3wmoD9gm7WuJ2EG9zrEF9wgwjLPK5YnTqrR60sBlPj/2I3Ponv6DHGsuSVcl pAPzzRnbnI6MhZiwwga0tfe4d/cOryA6wmC3uUTk6MyqW02tqx8oJ3WQ/eYnAARs18hgzMt4pMQ3 m/QMOkxrYk6SDAz+4rv6q0f/gwVZ0T1w0j9yUV7qW1v97AE6OEp8Q96PuVf78RMesPXk1DpyxkGE D7Wjk8UrpB4zMPvRD99aP/7Rn7Gl7tvraz/7M7xP+eV1iSc3u8VfvR2lg+WW/w8/+HBdOnxv/Wf/ 0S+tN197Yf31v/GP1v/FqzK+/CLbnZkQuM8Tv6NLGiU4G/Kk03jMm7Z0+ZVvj+LBcNh1dmlnnyNW t3IHdvqFulNm4FQhONYdmY7szR/CdpybRC2WjD9PJ0f41MhnqYZ0k6t6Lp4XlYVf9cHIebGMerPC OrF2jyEkT13551tnBF0JT/6dNOz1YOhQdpOBVDBpUaeNdKnKxzVuDus9agJr2vehhv/A9dwf+bCj VoeH84HrLxdeR32lrVGKSfn/Lnfl8YXzKvLPtOFlzx9o4dhlVZnhfaByDvxiEw7hpH79LHbYuKBg 3DVNSorf1JfPWkMnp6nctmXSlXex0dJczw80ST958YAM8KK4VJ/TmVY+0OwPx+hZoob+6pE+IDfY Xm9fabd99NpCn8uU9AQLBNKn/0Uc0y/hLb0oS6qBLd0Lwjq7fHd7MH3O7ZtAv8SYllI5l3ZCj2Wk utgxFFUuOqhjMWHHO7+TLg0Dzx/PbVuUTfDiQdhkwqir89pd7f9GB4CCK5Th1X6NXA0/nmumwjB/ qpFmvIReF4Sa+BUucdZDPfv1qJ6/xH5pFF4DXtJaoBCmdItnK88F9VX+8GS+W0zpOGYntfnJC1yU lY76WRKHLQpLWsWj3+7y8NevMlLWYUyByBX52N9AwNmo8qJA3+mHUHeL53vbL4kurNj3lFLjS9ts GRQ9zfvSr12+tHj33VpMFtMxgni+D5iwPMtK7pdeWOtrr6/12rX1mNtYPNSxtMu/grZ/cvsmDz6k TyJr0iNu2zXbvVYgoVlbchJoHno3EyMDZ+SXTVhH/QBI3U0bhZyQhx3YykuEfKAISUiHklO6OZNP pelfbBmubDaII10dRisnxgP1cBCzOJ8BmhVHA7uulLsyF4e0OfFrH0ZNZZfAnqdOS9CuX22OclTi /8QQx3TAsu+kTPQXbcK4DMCNOLHPt8oyy9GOOeyF0DUHVR1jWVKa7DdZUhodG6lPq8YJ+Z6fciKD FG+P8anMmpE707zvW97tHz6ClqO8Am8e/gUYJzoZr4pLe7WOSIqtnkOPtiZZ+yTMWKlcb/g5Y9GM QAohGocEK9y2XyI8Ka/TiEBUjBuTJTgDEAgXAu++x1AN0wYLV0Ytu2/9mCVt6kKpTlZHS+VSX6F7 SLz4OlIuAEjTSSLG/1AffOgBOxfQVifTYMml13Z+dFh52NLihRm3R76eiDLmN3DWQTl68BVpuaUy 2fKb8YJehbavikU7T4KVN9N1joKGciJhAh0SpbfYajfpGlNGCntjwDR220zRzGaoSJRKwNUAVZ7G Z9npSEMnicpIA1aN8ZqelPs+IFCX8GMZvvKtM/iCeiUjPDKAg1Q1XFJ9gJnoJgADmXxXBA0SdkB6 UIE2QkfzIfXlT9k7syLDysj9+8pM2qVL/esoNoQ+XTgDpY48fR48pJRDMilA8TF24EcjRaVdmE/A 4WsQ5FO0RwnubqtTJhcvXuh9nT6F+DDGId3CcpBmWU6hV1sdmoBGCqlm7gcmpijF58ccLc/rsVUT gFFA8Jf+GfqTHjvLx46P/SnfttLqnFTxdVh27qZDr224EkeGADjkzVPrpRtxc61ufNiSW3O9d/ce A946NvGmfWy0Q7M2F93B5EIHMZh6yleZ2Kl3dVc7L9gZNNAXCoacHTe8bGCHb+FqM8idoqhg5C9c aYdWhnjR344CZQGsoYW6O41xKo5Oyvds59lfQDKIApaIEpAlgAED2ry+Y7J8u/2+h3lBgQMx7Y4i lXNQ1rb0do9QX0vU3kOuRpWJOh0/U2TpPQrG1tS/PNzhXYDPPXNyff1nXlsvPO89oMd7aJyjQFkR 562brMJyj+0nn96CDuqzcjmdGuKp/CA0LeH9995fl7nX/Bvf/DUGyB/w5GDu1z3BCqoeaBzgzvX1 hBWfdWJ9wmDzj7/9/fWLv/Kvr+eeu7Qe3vzReuHSZbZuIW8ejPWQVWHtQl98yKrbfSZcjBsPWX29 R/pnKPFJD3jDj6RhDGSTgUL1OzxwNufQfpddBDdY0bxJ5+MzllcP87AI5W1MTq78Zu/KWhkFaPSd EE0lzzhmw1j8UL4IXZkY7w7xJDndUOvxNUfGB+O3PqbNpxcKGHcmvgoAoJthjh7BD2t2+IqB2MZj fRFZ2+d7wPb/txkc3WJF3lfGuZPDlXs7nkdPnoOew+utt26tt/78767f++cX19e+8Y311Z95gxWH Z2qAHz05yjuXL7Nif3N9+OH76xd/4eX14uX/eH35b//m+qv/22+sa8+cpRxPkOZ1S0kREqeDOLIc 35Fm7Wzi7O4TJMp8fJp2cG56l5NmunZqmjz34Xevs/+SJBq+yFM/4Kus93Y3BP3b2rzPwR/Q8MWy Zhs+PIrZ+t1WJ5yei5REr2OBSzvT4pZW0/fz2iBLkyaevd6+NXro39oqctUpHk07zS/w9PU69hRs daYKFIyoz5lxYkaqzK7zqsS4KH6UKF21mlYurxrZUAZZPEPo2bhlpHnnZz/3evIGfm0xuLFqcNnu jEzSA7D1EfsBx4gdxl47cD2lHadwx5rgelCXviN90qzMrQktveYQmOIRNlUsGQ2dmRdf4uWLiDcS g1dR4KkfaVenxT8g4EJQvdvZwJS77I7fGXgO3iIn8D2GRzvPQKCCMEbWnEkjetuhjf0PL7vsxiZG fnvaVCBNBBsDDtpEGd3hNeYSTUkb3xj9iM8juGSWJ6987as0qIBxxTrw58R8efn84BqZU7L+jHY3 Nite4qBxTd42fNazfngAjhVTnhhXmnbrwMJ2Ez2yi8d+kh35ZAIJuxyFI3xlIO1+XYja+96WCy8F OB35NrBUruhHANSPH656YJTtCYd1lU9tPQXHu4Qz313eYK288dQHHjaokFcZSFwDXwK0036FL91W LT6PLaZ/CY0y/B54h+l/9twQET7xhl0nix+uZ69cXpcuXuQpze+s9S5PaL4N3b666OtfWU++dn0d euUqW5+YKKaGhwPYDujUWsTyhLb+NrcQ1c5Z0ski9GF7YnFX2j12XUqrPuNvZdKnutLW974CFQAO t5/rRF69dvDOeToTbn2oGStxaQm+ntiubTZm1Y32/NX2Tvkip7Ikp9644gwx/4GE7WgP098JqAUV f7CbaKCtTNzSZ7pxh1//iX8/ZveMPksatLQDYyrQdkJA8Yof6u16VzRQCs8CVNHk4wcRTTljiK9U dUelhzJUzvPsm60NJ8tseaCnQinbYvaqoX8n8LkhqVTA1M9ogTNoypZnerCd2cDlayWlxnb8ATvg 1L/8Kf/pX5vGFx3ObSXQrJ0AOJ8SPz7J7RdKe9SkLGSOSw4MBkQOyOwwmCYzzuqKSOYKipZ1GZsj oyJPJApW5VITOIqGNAWsQUoavHe/L2k6tNsvxKEJgLY01lPCM+nmjwF4b5ewC3IwkmGhNH9FbTmB pSJ+/UjJEzqNrTSDwCLSQRYNC1uyFA6DE4VjZo2PaVukLF0uJFyIlrEsxwTVoMV3eaTHsXxpCPBi x93aIQWG+crHY1ceCAY2DttUAApVYpGlYXLo3M6EWNZAXBoFdCI7PHUElY9OR7od1uoghXkqobob Hfr+LwO1cCAz3Lv+FKBBoQc7gcRHycNN+gkXsAsAckJe/HHq7JNJSkS4BoeCDL8GFQP6AwaD2p72 1UB/k5PbNxsoUFY7GDkLz6GDsgIwhwObm7x7E0th9e00A1wbKAa6/tvrUjbntR5/2aMda3DNtm8b IPGoC+DS8U9X0LQ3Mm1xgk6f9kzRmbHl2vycn7I6nPcxCVcwvQLI7dJUcPDw1CFWpZtwmQ6cjan1 HQzrCM085iPIgjrOlDuQcWV33tE6EyzyLQ3+2+3P37FNMzzghHz9SdptaFzZ9d27yR48aAM+oC9+ 4VmxcmRnm6zCQ1o+RnkbcPEWkOxZcVgNzQAn6XVt2sAbeqQlWqGnyZPqcU4dy6p/y8j3PO1ZeoYg ksrzWj/kr+01XDVRJyKDWDEJeNqEMhVzHr/5eT4CyGiLvg0H9TdMpFJLmgio/n7GNprXXz+zXn3p hfXCMxfXSZ5q7D3fbvXT9x6yuvsR79v13l2fou2Tw2uYEJP6GO6ZrD57fv3p9/94fe/7r60v/Qf/ 9vrVf/cvrX/49//B+pQnr5/knuDDPpXQ1VpkKjVOup05dW+dPc5KK69teIVXFf3Cmy/QYWaXAfmP GZB1q4h+he1oJw587aQ44L3FKu2tO6R/ps26cisl+xfWqKNj6VtKRC1468Nd7tn1pe/Ms5DstmDt e+JwDwZC+PqtR7ESANqxOhKmWzu9OMEW1dPswrCDL171K55msZGLMQLtlca/0TX1JOspnz5CGf10 Op/qSSh+qEe5sUcqEmO0CWXfg9bg8+bDe4s3RWX7Vrz3EU+lBmSv2iF2Ovlz+tTh6DuJ3E8cfYF7 g++sX/87v7m+9a3vr2/+0s+sr3z59f+XszeL2S1LD7P2Gf8zz0OdqlNTV5fbbrcVmwQ7KLYTB9tR LJCRGIxEsJyrIECJEIgbJCIuUBRunETkIuIiECGhCK4CGHCcmMFucBwTEpvQ3dXVVV1d1dU1nKo6 dab//GfieZ5377+OzQVp7+///m/vtd71zutdw157bXYTvQw9His7eXa5evQUA9/3luvXTyz/2r/8 Y8uzL15b/oO/9N8s51k+fZGdnx/cRW4P5VQOeMrf5ZvzOVL2ep6InKN74Ad28r1O2lFz8Ft+MZkU dW1a7W/w0pnydUbVFem2AWv2Pp6naZoonqeP4UcOzNMz1voB3MarIU4LepTGaVj6xb7loHPalE1+ fVOsrR7idyaFhm9hlMm+g/y6mcljOjQtCc2/hlp1KrmMt+N78QA+6atq+TEg8d+U/vtPKbxSPw08 bAO0k5n553Bd+yAKvtOBHv8TbAbSlAC/OsixwFq7Zj605+vKNh59IN46KaqdnMAxDh9lwGtc3trE rYxtzmcxHJy0JZuN/R3/T4LyFFOp/CYbelIMuwf1yUxdbabgngtOdvbZ6HptnvRN23zL89LJm86u tCZtPw85fEWNAwdzPbCMYMUiT+Iz/NuEx/ivedIy37LJQJptosfGbxeke93Eh7Qo4LV8yL/Hxnc8 c73Jk81UzKoD9QiwCPhWtH8bvi1xy9ZfwmnCemjPDd5fcZnb3U10Ul9HOqaRp6+7wqS7VviF8XBK kJ8j0ZfAH03b6oVaUDfTJ5uVACaI2zumFbME9T4eoWeefTVD9EH6ufr5DHSnD2+6fb50EHcSAbY+ pdShD7/eAMs/09PIIJ/Ttxvd5auUtbx8StS0bmgBMjrS79cJZ/I8rCvU9uk74bOQXK4///xy7DEr lt6hL3fiIjsx/4Hlyfe9tBzgjScHtsEuRIZDaYUqOedMkz7qsS80UN+xtgOaylpskX/bMh+x9AMO 0ehTwdKWbP1m4T1mNaI6mXbGEsVUstXrpkdlHdso2ZSVgByXbt3kVPv4SkjQpUsHuA7W7FPn94yh 9Be6ZGPDbDs2UXZlE0cywp/85j/yF78jqzDS1adcbVE9kSg4tKs3p7x5Se8h+dWFO0D71pPwmWBM 3nySso0jogIWUAlX3BM0jmQAemVKXh5iqjS92yTldSJn9is4xCsUb6++on0YfyD/tjrBVTDuNeJj jOL1laT37u0C74SD+Ix5n9UlzSYvpvl96CrMZKUdos6o4+IBNKgedo6VHDOpaHj1rqSyewfQwwLN 6KzEFKClplQYh3MTBDQ4Vzob+AYTaGHEc42UowAGSMa2Ic9NQKgTpCzyuusHjoSQEQoouBU0o3Jt 5dw6AkCIEHixqe0pk6ZJmvXhcyfOBsn8eAZ2f+MC5ZcxvimUCmvDry6SZnXu8BdBpDNH9ONxdQYt IC4OoTa5Rgfw40AdGAejox3AK6KDKSMX6KRJBBpAvBPNYmDtxN8mp/IPF4PFu7mON00UVt0DMjDa jixl3J7hlYY23yYlqsAQsENQwLS8JKVL4a1CwR2JYfMsnqMLn+Ypendu6AhbeZoUINESBUfyfcBd P9LRmnhR/9CJP3TtAMls/2lrj5wZe6jHPQe9bCy0w52cE7y/84gzYsi+bZCjbnwGuCXZ0G7w7sAZ oi2NBNgGaJbKrgEFXvILGeMrr36VStrm2aDCPumyLrwsoi95dBBZHuU5Me9wAdVnObCVS5c4Cl6A tJQEPq1fnvuL2O2gfptX0txnGWVBeB1k6kdRkIhn/I4+4VFDw4l8Vleg56tnXAY+O3JXIr4xLjZx EgYEyok+k5PLCfrqSHzKIDGpPv1J4uQwVb78pDug1cVoSQxeQ4P6RLDp2eSBG3ix11ETh2qD3taJ l4fK6suo18HZ+KozgvDAagsDec/srpNx0tvnacWJVMm3H4MUDcK4YB1cFSkfvkZBf+A+6vKl77u2 vPwiO/6eOsazu3y5S67PS/8eM5Q3PvxoufHRzdUvnBRY5QHn2BeGnUxDFzvsEvz1r7++/Nqv8w5Y nkf5kLvCH3/nneUGuM/wntwd7sLbSd7BXj3Xt3Nw+d7Pv8KzqK8t7739/nLyGJMmzI671wdcEs+I Ydy9lOdjrDAw2YHpfZb/nOI51k9u31s+vU39YPD7yFcZ+dy/9XyqUTz7LO1DGtpdRrl3eVa813dx N8JVJb7zedO9inKwoq6kZ8zSNYxN+tphn0XEl7yDtcOA1zQbNmOYkxCW1afESxJ5jKrX2LH5r+Yw z1ndOharPNreeC1tPW4GT2Ry5CfgfSJvXA8dYyZ1Fh27EgQO8y1XpFhvZfzIR1etQcIAACAASURB VMSbI7erFxcYtPou71PcgX/nO7eX1//mLy/f//2vLX/0j/yh5dVXX5yJDnBduXoNW3y4nKH8z/zE F5fnn/355d/59//G8nXuiH/+2iWe+XbyCh+q7iFN/oXPR19uTeC/fMjseiiDhz9kcVTQkw71JszU idW/1uuppxvkhnuD3fBNulC1qZb1gl958fB3O5/r0e3vpbvB+usBCnCha9GsuLZf2x1NPANfLIfe pKFvDDjGrsEYfrko37rcEjYdFaMPtxqffEvKfLoaPYrTVmU6/uQFCpwOCq3hcWhKo8Mf8jc9lNzF 4BywiAQzdPGr8IETGsZKj5Wr+HPFgitpWrkATLstC8whB/JoUy6/dqinA2b+2Fi/t78hRPF75T/b JEiFG2hK17YyKfI7iVCeMnJVG0WZzUfEHc+gt/2r/CindE9JHhguNttXvkzK+cvhr3Vf28yga+j6 eJg45uskBp3NPhXbL2t58ZqnP4jDQvYzlCHbSYfvaGO98IdEZdlirUC28zNhIvQAiT8Zwg8l/Unc YPQxPPPUa7qVYRF7mOaP/rOllUw5ruXXw/Pt2DrTySIN/oxl2QB4O+m2O+EO7TrxQoyMB2lxaM9W znGureINZP42WAnIf+bb3tiGW0dWOUiPL9CNb8Evdho8lAFWXhXQ8p3Aq+dJLd8rju0O/shZqshH DkuaxKEa9Gtjun0q4/emm87VF0DBAS+dYkFKYox75vRyiQlGbbL3Ay8tR3/8h5bl2oXlEe9hl8Nu PA1X63+pgke6Kw9e+3jRHVblEPCTd7/+aI/qOjxIm76obbM8+p16PDYvNpEnf+k/QlvdVI+cj7ZX PW71bNU/DFn3PbYJu9wBOraFrUzssah1jIQp1AjVv76/jzJtN03ATN7w7qOKY2/prTnoXHuqguzL iTZPNtPW4uYla3ZQZ06GwCPw1uD61fDnhnlOaKcJy4pPI1Ouvv+aNvLIGgn8qc/K1BcYnVpW37Q/ K99zswidShd8uqAT4k7ie4PCScDqL/05b9JkF36tgz4We4K9T5TNPkn9ZfD36CAMDKzMbSwp29hZ Bh3pyaP+pU2V154p490JQge7e6qBpqLZJjUIUbrRAoWoqFw68hflZhwbhBRMap1/cJZv7eerUFrX Z9bguQZE5iBQPkmk6wUaFoMaCKDTVtpWqgwynS1RjpgKRIeHTpGzFDNTAB0yC3rgSrZ4sMQECGlp tBxD9sjvnOTKySBInG0du4tzFKbUVY5Up4yUsXzX45xVGHjOHUDg3Z/RpToilbRx2DHQuK4koeEg Ua/g8O6EBKz4sBIN9a2hZayHtpWRTCcnDAL7FRMQZ7bsoGdPrm0sLOfyAsIwZZj9MB96dhylj3TA KKN0nFGREysO+OlEeocpPWtvoClNnpKKGjmRr4GUzIBvAqr+ojPb4Z3Or7S9u54/UTa6YKm88gPs TCXc1Jm186wPNWgh28rtDtd3uRt35eLFNv05wDvenEny6K4kvw3uwY6W6JxhJeXlM0FEj5DUzHzp Aw54qqzSgoeWGFFGnTdzGg71oW+AFT1NoEoDoy/yChRShR8bfwSdmTVwpSx5Eicdan3KBv/JE2YB 1T11a9cVB1T4hw8PLJ+wQcNNXsg9OOFX26D/DngAzfgtv/KlPPJ1jI2QTnl30vWeylxAVtPqAy00 eKFurnVX2ckKn4EWrvKtZCVvqyMKQE3mvzqQb+ihr40P9ebHY3xi9JVfk6d8+Rzl8nR+1d40Rlmk gCcFg5SYHOwYvGagSzl8xMbJgY6BU193cqPnPaQ+5NGD+MSu/8mv5xwbgDKjK1/ppSUeshPshfMn ly+8+gqbHLkRkrsz+9oe4osyY8fbt++2nNkl59pXUi7R4YKz0bVp2qiGjGWaLlF86+tfW/7+L/9d fJV2nQHt6ZMnlvc+4R2+n+xmA2c2fd2Qg+IdbleeoAO9w46F7354c9kh7ZTvUXaKkrvCLeeBbycr R9/agMYEbo4j0h6rCu7v8U67ezzTrB5JT4fI30QmzwIjKneE93p2GNUiA49VsUTsgbtkIoe2UV1b h3E0p8/yqjR2mz7hs8kkdgdXLaBLn89xcOuOuvf56mOmV+ewT/EJ3beJibGfYr3uonPivIOejTB+ 7J2JmZTSdmNz2BrdGieg76oQI1CdTmjZxjxgEO8Na0dk1q124jQIS9AvkwHv3WCW+e0Pl6vsxv3i 1VPLRXYUO8rkwle++t7y9tu/tPzoH/7h5Yd/5Ht5R/J53IVXw7G52GHugH/CUvYf/NKLy1/9xX9j +Ut/8T9b/o93P1w+x8D3CRNU8Q7PHurG2Oyhu+mzUz9HFvPHJ20TFKV/yDFlSrEc5Y1qwno87cfj 39Ki9PpNDysK66F4/WgDj3CteLZ6OGWo8fC4X0eAUa9N7IF7Bkuac7UnuIcniMH6umXBlPcaW8wc 39jbuKpvFA9tD9aAMvX+MxnEFT/VJXCjjyaB4SZ5wCuP0SbbNFUzOlaHbrrGZBNpTgTpN0EBoH/p zw3U0yd+Q52aCSHlojz4OvzBZdw0ceKteXNI25qvf/p8v68MPIHvyIT7PNg6etjeiEbXO+wmayof /o5Sh6xnxi/cl/pMUeNHwHaeZ/BgzU1WMkZOaaoS4zOo+B4wJsioOuF6E0E3JDW8W1kB6ObBGF/0 qsRTgOhnvPIKPB5OzHvowurFJY/iK5U0aelXTTjA1D5PlgeXq/jUfQMtEQE7frZqRziR+Stf/JOO LbQJ6lga6tRfVxtWh1CiMc/0NXv1D5GJjl98pFWEwLR3Bvw8Xf+mHHnA6qcyEjrjEGnaovb/qfog 7KYby2/4glv52WD0KXGKK5/jt+e2gVNPI9/oJ58DXB9Rn652qr9Lmm229c5DPdoHsgPvgMD6Mzll j26tK6ySEH/1KtmGVwrkaPaqKil+NQt4+IzPKWHS7WeMvOifc3VqdhPS/HroP098nMfJXc591Kjn z4GvnwJJ5audXMvoZ7aHKIKNT2fQe/jaleXQC6wMwrbKZF8tX4uftWAU518pn/1jtc19+oJ306Fy ZwdAe870AH1W+13AK2+fVU5RbDadVwJRr+FPO5SXKinBhXCtmMR+Dm63iRGrifFJ3NpW/h3IATC+ hd6tIwYd+wO+1x4S8GO/voBQJZOmz+9DSK6iNzWuS3ACW19bpsYftpgxapJmZIGTZyVYj8nKr9XJ xCUSsym/8Ftbzak3SB7Xx5BJDv1m5cf+WDeo8D1vJLYiBXYap5EmSWWr3aPhldP6x/IjjnV8c4h4 aX/twQNWQNS/RrfaiKNHP6IHLR/JpKxtx2PfVkLMNIbs0Y5AKrr6Y+NL+Kzu6PPUoeIHfuYKC9QG T/TDuXZsedidYVWWdvJulIrQKR+55E7iWHU+02hDKoNreBt5qmgBJhWBXWIGkkfsLJpDgbJ6rkQa VKeMZdKhJ/OkVjF0mW7Lcy316dDJmwNCwiEVuiCL4D3ADeI6v0ELj2NoGPJ1SpWuYCNW4YXypMGD nWhl1VEbuMqEJVCixtUE5qlkA9wsz/NOnQLJu6Ts6MAX+Oqs8DudNKGG/kq1SjyNNyjkge9UQtkA FhoelpJugaYEZRYbecC5JLXfaAIXL9oESsgjoWAhoC5d3y45CY4sOBiwBhb53yqqMOk5XpSHAGTi 2viJoUZLFXDkGwBMpxcZgNO1C9QwVWeZX2c6C9zwph1kLr8IWgLwoR9kJ+lO4NBGHuqsPPxNH7Oy 7LGk8w53WezUnDlzdoIQd/02f7Oc/FuhcvoRriAjWr8zMIZj6CF4g0MeGQ5nAUMZ9ANge6H4qtXi UvjjBmtpm5XvFW+N02qIBqH2HLSD7qUvAedgRPzqH2Zlucr7hLtv7MPD855nlgfUQcvdIajrI1Xu aIEvWgbb8T07/yrYjSwcMLmzMKpKN/pI9di6Lh/SlzYAhaNV1zCHPxmIBbMBMEDK7zS4reIAdup4 YOlcP8k3TLJOrfI4IPXcWGE9nS8aW3EUmMjPbuS7s3rM2bDju8InZ4MhtQzfpHuX30YqGBLFowh2 zDyUqtghOuQQySZntEia2KL9gSWX25IsYT2/vPzSM8s5ngU93fuvV9+l/D0GUp98fJPX1tzJp2IM 3mXRzUfkTdz+ys+2DO0RDuMExDEGsGd+6Bx52ESTA4czox/qEOXu0Rjev81IVBuaf+B2HUHj3UEc x8Gwrzmygy2uo77WhA73Dt8aWejUYKlHiNi4ORkRQ05zmU8aGciyt9y55x3dibcOUF06tMuMeZzB j9FI+zv51vJgZDxJJ8VnE90gTHi/PfoAvBMGNmLWOzvtNYrZHtsgs3e3fNbMQbd+p8yqvX8A6FsI ml8aD4TJT5CnDh4MbY/iWK56S+lgwGVxj3Z2xEeMw3agaaV06+p7dzuBkbYDb233zbdvLB8xsXDt MkuZeab31OnLy90H95Zf+Tt/b3nrrXeXH/+JP7B84QvchTjEJBK707vL7gcfvrd88QtXl7/wF//d 5W/8zV9d/vov/ebyyrWLy4EmYVa5+NF/+3DuoV946I3VKa6Ls+pi1UdVALB8H33ktzL61LGPxzIc Xvuddso6PNfjjVMQK8wJGPNTym5w6vPpNCG1f+W58Lr2wjRgLcd/7KIk5GKr8WNS13ZMv93u8gvv u2YPszR/nmkU44oHQsV3YORBPOGHkGLLg3XFNEuRO+0SvyT6v6/ntR3g6KMA5Bh/8zUK166aml7N B0galuHrKoH6F8KAWLrFMi5qRyjngHrH1Q3UR+vF1t7VH8LvMEJp1mNQVjf1STtzxpzaaPiyY2ik ta4M39B0hmbVvOX5o3zSw8/IasfY+jD9IGVGTwgBJ0or+XDIv/7eoL9+EeWKK8CBY1bXMIgSUBKj CH6MNySoGvoHZttWDWvGBZjiaxFIw4s+oMxccEx/ADgYiXf5w5Bxb1GOIDkvrfy1TeC8GGUOQNkF +HwOPagPdVrd58T82Idffz3EqT79nRgTlYEdEGDVi2UptJZbC5OWMuaSfOUQTpwOYD3yCX7HZ/AD zoVTb9qYnGCs2x7laUdoli9O0uMj/KNzJCpdHQM6MJaTPl8/2lkf2GSzP7Hh0kjFE/FEDiQcw+96 Dh7lSHby8g/hQdIEF9imDnrD4bNYIrx23GTPQeDFO7waZp8ul/mPhCmz4VJXSiQdDwfx59jE6sqV qzziwwak8KDQSbkCraDBP31ewlP/9ta9T6yP6mUGp1NCqvqp1WKT2aLy46c6KW/SjC4cmJfPDpw7 xW8xyrI6pB9/W7UBfLGq/pN0P5PDAWboSdUd5GebwMihreeiGgRjZxLSl3Qw5LQV0x7WNpLvp7uY +qUNnOqLMjJxMjXAekG57CaueRxMm3ue7JRqEEwMl3NpiaiJAnEGN3bvESx5BS7ZoQL2vvGLLPZR sz8xzz5nddX2Hh4eeNMTGO/ydtOFeOnkVL4MHge5ln/ExKH6djd/J4P0V23aoy/4jT5v3yZfREfq 0wF1sWjflrCILML464QrEvOl7Rdhd9UQTmRWKgUq6NFJHmcVAaIS2HRuy0wlHytOB9UOtUF8I6Iy VDp4bQywRJ2wFAZ6aBm8NZAFe3ZS51Hz0uJbYLZ8jqHRBOVX/hSBc2dWtYLL4Bpwcr5VeIW0IjTQ wAAa1FccNGsCfssbmJlDGHk4t6yyewu9Z1gjikFoOGBjPcSFQW3sdUpwGqjkyn/qKlAM18w2yRNc 1J/6tSLOuWV0AOHNM920MOAoGRI8GksKBRc6weKLDgUboltppO0vNjLYNPgXJ1/5VefpXR7UKZ9N jq1DGT/iADaFxwzn8uK5NJSdT0uQPYdeAz1rdYc86AfC6QOWIXDAaf4gq6RtUjUa5Gr+yPSE78w+ AYXfabtkQAt76OsOSzgdABxnQDG8TuVIh8rXYZUUH//hBZWkvyo812aZjnRDEZ1MkJa+iVYS8PI9 CP2tURM++UDgzJEVW970c3F7LmX9JerkZ28qqhtyaYOZLKHCqhM+o7mR64M3Pmrpz/GrLE22c+Wy Wwb6yjZ1FK5kDFrq1PMnPCN9hOWxp06dWJ8ls8MEm/IaH/JkIeSRv2SbazuGHvKuXUQISDpXPx7y HL1gWKrM5EfUyXeFwhSjLjH5MBNEDnaRl3xn6upMhFOfmMO8vuB0wKqNxSnJuds8NjWoybN3Rxzw +hxvfi505UKMHcBsWX6sL+IaWvO/bHRIEQ50QIJwJxlEvsCuvNeePU/nnDuuDCQdWGpX+XPDhRs3 PuK5V2YjRE66TLqqQVs3u219BKvbG/hbwDU2rLDGHNP3OwHqU98hzXrqbKl+haegN2bO8SVnNHMi 8Nxlwm8mqtwUzTtElJF/HGer68bAcIHpIc/07qIv7UbVi2fD8G1evXSbZ3fVr/HSDUB65zPMHTrE bWg40s8cFGo/f73brZ7vcXf7E54z9o6uG2npi/InTcvYSNXIIqlxy3dc9AokdcIdgaPIpbwqYvzS KzP9GzwIRTwe29SdpIHQBuObn9lzNCcN+OUrpjptJKUUcWgT6LbczJipgqMNPGUcaHsHXb186112 3755Z3mGXeCfvXSBd/0eWV57/Y3lO9/59vLHf/KHlz/4B3+AzURPsxT9+HLt2nXS31nOXz6+/Omf /6nl5Nmjy3/6X/16d3xZL8D8ibGimpl4SYlcyrF/aHNgSuN39MW15YDrzlr5sRw+y256sNz23cf5 e062/MqQN7Q+A/LaPHXiET/SjGESNC/Xpa+dN30tofiPBAYGivPBlzbx6vTYWxExf06MeOf9EAPG OqYo3LouWf1mDmOSvIhtPwkKn7UZpkq9Njdilhm9zgBNXJRgAkn/0Nzy6Mc/+xritk64SiLZyJCF Jww+ZzA1NLRHdYA6Zf/oMHHVu7oe+Zt6URcoK9s1gTz9kNFRlFYa8mG5wMPRZCiEN1xIgdtqD/oZ dATFoYj+Umx8AhoORGw7aAKLEQ+8Bu4Av3v377G0X34Gr6syXLooHjuxYE4n0lA232Vt+6NNdqrn LCslrkxb7uDBmIMGaX9rp2AkHaFzlSbP6r+dmtGDjzkUbw5Z723nyF/1q5z6yPb4kR11Jcv+6p+P fb/gSbePmX9qnHSBPZDHtK0tqn/D9eajKnazqfj8gErh06MXlvcr3fFrYLZy8CifdaKBeTq9C/5Z ln//X5rqQZ8ARrye6B/qJzrGShLNImP6Nsg49T5weLI/bV9z6qBtwMbP6AVRLEP56a9xDayDH+1r eWk62PBQxpEVmOibyqADW6uTRFz5/Cx2rjLC61Y3t7IzeU0+9FxZl7zQ348JOnnyTW9m9DA6l7Ll xenO/06IXb32zHLm/Fmz4MV6PuVK+P/9hw20L/9v0y7fYy8L+9pgxl/RL/J5yGOyrTopcbWf8tdv Swcyz0E5Y5OG4k/GRo+cjnX5Xdv94XnarfwicNscaevUU1ZerO++OSac4K2rXAdx/NHGKX3FNv8o i5n5jTC1VP9R5uFC1vR/a5E3f+ZQEKBW2ae8eC2qjyAefrDZbQUmT1m1EzDl418ySDmvzdv4Vpb8 IVsNXfMP028ybgg4fVp4Q75WwYHHASuBhj82oKXPbh1z8lw1eUhPNtM9v1ABlf9F6Qa68CY/5pB4 yNUU2gF+fDUsqujmVDc+hcNHhU4fldEWlAMn/SSJUVglgzw7GFFpIQ7Q2dZ+1CN+dTEhSQDOkNeM Psw4yjZPCirW90YeBEcKhFABnnRhpGNgrbECOJxWVCUxT2KcplhpwalUoylcVwNj6RlUDk/NfJDm DTIP87cBJeyLZQb1pEvL4KGSa4C5Hn5HLnm2cZmggY4oAkA4YAr+pSkR8Gg4fh2cCzZORWPPZzaO MojjbDopcMJqHGE3uetgr/gHTtoOFKFlET7aB3anHGU95L0gaEWnYotzawzCIxB8TgVFk/KKgrPD au9mTciYWXhVDR1p6jjovMBBgg6XLcAgnWa5/fWDH+kFNlbdtRESug6AxDWqWu1vBofBwx2WffY2 AP7V2JOnO8iHd1lF5LMBVQh0aNB0i/rT587yPC9LeJFd+eSjgVblQcBRZVJobEP3QK7CqSRKYeMb fxDU1mNL5Vff+J5F0YGWd5BvY1PgBpezR6MI7aJNR64JcmappdHlAKIrax5fOwwtCzFfEbUdneXj DOQvsFOws17ToUN/ULfBEIf6Uaf80HiNPtXP8VMnl9Ns6OVEgHZLH8jg85wUF4TGQJ8bPxw8o/dZ MqV1+ZBk05OfUqaGmOs6ISCJf/RAFtBKJyz/cFLtXuBLoeZ4gFMB18Py+rz63Zboy5z2Vm+my8P8 OnhjoAs9f90FHI1zVCviUbjtsEoqFxqNqeojtNWVtrHOefdfG85rhw4uJ9lc4qXnLrJM/gy6444U Azzv5sUnZdyV2SWtDnx9Zp6+5QRyqcirH/n1y2erExRtyY56rDHnWs5afUHatjRZ9v3W8MwJ5XwM xHJjb8+1SX7ocgGdUg9iYOvgU78OCYIWe1xyJkyFsAkTJ3foFHz08S1i2lF0SX26fzff177HeH0A 1LK1OrOsUdfJCpcq37lzm4Hu7CSulNMpB3ktN/ysh/XVGOrvUTb2amAuDxza5jMv8BwKKokz65n+ OjLLNrnaTTGTlTQbVI/0JaQnKlU7SHNUkD9woR68CzHP1KlgKelj+vL4n/JJQtTGCQcU3/rWu8ud m3eX689dWs6dvbTcenhv+Vu/9L8wyP14+WN/9A8zKL7YUsVrz764fPv9by+nsMe//nM/WYfmF//G ry4vXb1Eo+rz+VKEJjwOdfnTpiaWk//W6TWpDE4Atl54PXfq5tw6PFJjHz75nnCi4hjcc7WPa7JE Xp0bnGCxHL4yA1V9TC1wyIOVhfzpOMm5OI0aHICpV8tPiaf0aj6H0LVJXmgfIEXbxBWdnOJ7aKds YMmBrSxCcp5QGvjgp02CBETX29JHL2s3gBe/5fKx1ZdMk3rpnniQKA3FtY1MTyucURbJoufkkXdz fZeknTTrbcgoa+wFK0j4kmhdkZZp6sUbnulTZjjMOlJ/Z+gaH9SLNZpqSvnxa7EyVq8Du+djB9Q3 J6MesUP449u7PO9PPWX/ipM8AnHqJKtG2ATvBO9bdyKmXeWJY8eY9PT91UcZ1PhYiz5dHLNuEfe0 4h4TV75H/J6PPkD0IXXkJrHhDqs/bt+6ywZ+DB5YEtr+Ccgqp64Eub+32+DXHdKXR3ReeZjCTfQO s8P7wfXxsmPsUeDGi3fB7d4CZ0+z2ghd2lk1rmhXtUkBFAlmKqPq1E1yFXSwtfEZSmjspF63w/P8 b5Resnac9lGc47tgzt7y70dLPG3HDWeY+WeeZFzhuB2jO3xipeWv3w0bRTq2mIdgCDL8rdTidZsE 1vbKqfjCSWmW4KqA2E0/j/GpysiQMYxCLSWVtmkeFqnhBV8+hW7lU9y1o0FxyUdVmMGf/m++R/Ko 3yTymtxwwJuBcoXZ+pPxa5oVaLgf8PginY/+rM3FOn9rH4UL2+8j6068O9zdvX79hepYgDL33RyK IF1kuUUb7ftbD5yCA3RVe7L1FJSHtFZxiD/5hqKXqiKb6ovIVVygL2YwUdWjE+BpGyxqyeLTvn+V FJzp5teWrXj1561t61EzVOe4oleg5i+Ropx8GoP40V6cdB49e5/ELOxT/OTcvtLEJtKtY1w7uSsO dT8yUblA5BhJr62MMtoPBM6vcBFbce77CXDa2SHsk1ZRApZasvJ+WVBM/aa8g28ft3B1mxvLqjvv 0I7Pju8ak9zUz0eQzHMiAADswJf+9CNoGi+lIv36T/C+xyqyoTX8NtYxBmcU07QLB0DC1S9qIsg6 Rz/Jfh9122jLfM0Ib0dglpZgJGpJ6keRKYdCBRGQ2RArvJ1Qz7cdmCUoqx4yBBdVRp0IZP4lCJpf az1pnBtYrGAOEPeNAV2dN0KVHCPLq1R0pAaTQ26FKCuBg0oZ8KnSgdvklEc7eqpIxXpkTPngox4M 0vLlbKi8bUaTUHKQR1XOeVWwsDqPTuXXmSWl9TBfhxPHNpAwp9k5CQNvELQxL98y6QOnxjnTKXkF cxHGtzQpFE2cLcYkNDTDIz5xVQYaazzrDg+2a4LA4ESGAxobcWUIA7/ScyArFnGYU7558sN3nkmg aDT0iXVIAs5Nbzr+OO7o3SWAlF5pqRnZHr5Hh0kzFElXn4pqR0QufGeDA5D7VJrnzrK0mQrkci2s ld60d0t9tQl69HDw4KcBgfzjn90tBN3IFFjoEYu0SlFiytuxMUhVJwTw6xU/yuZGNurDJXzim9ns 0b6NgOXrCJInavXlYN7KqB177Y6J8OUO48cv8XwYcst+s7eWIT+Tc25HEGE5e9zS2XMM/o/zjKiz bTV8lDXPDrV2dHMYacjr/m7HnNtYSl/Zpq6tspOnf/tfudSHgVXegRjbdi48OMiwo/6wciOf2XJh vv0k8XjMzPbgECJO9T+04gTEzFqCUL4J4tna53bjA5vyK6pYlrGnDq+sRy737RlDAdVbnCfNchx/ ceOoWRp8hLt2l5czvOvegHjq5Olmie1AWSc++uTT5UPu8HquHZ2UUCvysgpH+mbbWLYadSQZ/Bnk hdWPN3bzd/DJr+fa1kxt5SH/zpZKZyOVNbgQxLtaPpZCSaCnflgD1tpbfch3cRExHnFH5VNnwHim O9YPGMgdcUdv4pta6U4vcc9XFrkkvSXL6p+0fZ6Bsw6KrwETv4NdqjLFF0GEMabU8dEONDbJyf+t ro1PTTywnHVjuwM08kCHNGOIg9YNXooNgsBlnszVCQCHMOovj/AcWPkIRvb8kO6zlXYWhD3CeXiQ U3rCHmBi48atj5dbr91Znn/+CkuezzKpdmr5e7/52nL31u7ykz/9zywvvHANuEPLc89cYwOst6lf d5ef+9k/Qvknyy/+F//z8vIzl+wBdMeRRD5yI3p1EJn8aOTCbiSOTw1cuZ3oAAAAIABJREFUwCPJ 6LVCoYfPz2Sx3Hb83nNxCxlNgYBNB53qaxs/MgSkukNflkonU2T0aiIwDfA49VAqmSkrWpstyIzJ qSdAQRoZqRjZyAJr2lzrY+O7tUn4zGbTAIHPNk/5t5VfGCcKZWO44QQ8HvHEr/zOoWwzweqgtPZA vPoXCe7KvkOQ8lnbfJfzbbArHfE7aHTgLkZx1PdBp3WmjQ2yglKNv9MnUsETX+euMr6Gn3ln9r4r Jj6+s9zn3aSPWbHke6GPHz+8nL1werly+cxy/tlzy7nzZ9hTgIGsA93jrN6hbXGzOJ/799n+E8Af ZTLLgbm7oZrvHgBOYBo/lEMbbVZvXIRmnNh+yGD6HhvD1Dax+sI9JHYZqN76+NPlPo/S+M7zBtws W3nMBFnPmCK4q41qx6BBDuV4pAG/8dCfjEu7tMuuxnHn+Nffoh5xF85YkK/rX/oh+Pkp1pouivLB Wp0VoTJw3QGMZ5YT2MlV/Xr8h8hnPTc/XODuasUpHWCDsdHIUJPnqV+IATM4ZoC65Q/u8ELXT/aF XnWEshvtsOQrG3G5GD799ajNUgcQ7SYBv57LhPha3i4fKTPGKGodHhnEEj0TQNakLj7VTQt1QBGz tsG1uL0ufeUfBLJCuhmrDqWBDlTvmp1erHetdqANc6AmwNRNTi0BrxseiRQ/ZI1cfT8bDRVEGjmb kGd25yR7KDxD/Nxhk0iPwdPpd/VPn7jLnidNZuOXjx6MLvOVECvlyJkM1lHkUd/pHj2oaWV1vqO+ u6rpGB21V4g6wr5jLvW6+eBAtncOpyOHdq3FjraqdpK9/pYXKFl/kwe/8jOxSp6ewqHOOtTo+L35 FM4PVXPLkEmqf5EfQxtbSWbs74lw/ECLylh586ZPutLjOvn0E2BbDkz9r70FmWQdGClf47RVf/qj Liu8q3UpHb10q/8QS/coMxP49gW9gcgGmkyukc0BbuK4vHAaLlONGQqRzUi/t3uvga8Tg+rMwnAC vLEFOHA8YnAOKGXs57q6kH42KQ6mXbXyiMk5+SUNYJRk50yB6mhh3D7Df53Rgr9L4kCeAHQcZLSN AlQYn2b2wdEdMM0Eb7ZLPkS8ulZKzISUIauKK3MybsB53LIogxTCgKN3cmYQlFvF1PxTseEfeDvM 0hnF+X7aFEgarjS8yxv4eucfcBBSbJTqvzmU3df3wAaBnIEXMN6tsBK0yxiW1WBVFvVl40KacU5J WtbIuQFIbQvnoFAZ9pfLSNcCOrzl6kxPR8MyJHUMa8qrc0+ay1hqdJGjzTdWWI0ore6aYWyvWx6z YrIRpCiG127yiyWMe9LnI3rp+TXPLc1Hw6Rs+okhYNQxPHcpUsuMAtKXuo+YOubIK4CD5bkmXX5W BNhDHxlnt9IbuKqIGx6UhGbrhDuQdfvy3YPu1HcHex5cTnOHau7yugucS2vVw0ze5JuUTb6Vf/1n q+zqqIGRtJCZDMwyldb/2UdGhdNOfpR5lU0Vakfx3+cutHR3drhaBzNVTHLVTx95oGy75DGptN3h EU32Eq/4+XPQYcXt+W1kaJlm9EEhr1Rod/o9ffo0HSM2POJcu0dLhtA3XsBuv9Y7xUMvnFnUAVwD G2cFyWxrdzpC0cPe2oGc/Nh6vu3KacDWfzY28ydk04eKGfwW8NUXeOXTj3Vka4BSAbi1wfiNPJmq 7c3QV7EjEyO+k633O4PHNDtynKU3QQEuPZomQNPVFzVcXsKHOhHO/3ZoXX57nGdSDcTGDTuL1ptP 8aezZy4gM5Dw8JDO3Ed0AD/56BMREYCZ/IJBX56eLaFVAyHR+NauyCI1gmt5q4wkB0JWR5OAlu9q /iu/1UjfEL5/IAPT6BZcSl81QhditI6mfeDTgcVEAqyyucPz3i4D2XtsFsGdm7Pnr/Iu6/PL+QsX 6dDeX77xjW8sH358g7KzE7oTDOpZxuoAwJMDWOnoE35AXayRP/nUh60TbkpXAjxk1zhz0K5GOIAx XRyjjSmvhNagYqpBAv3nNZTzc9hgzHk+Ca3xG3HMIc7tDs9MKggzrDgASUPy3DnpFOvuLn6x6bK3 rqwByrqhDneOn8bej5e33vmA55wfLs/wrO+50xeXr371OzTWX17+xM/8yPLK568De5hJk2vLd558 Z7l9c3f5V372x5a7vMLor/3Xv7Z87tnL1DXupsGQdGfy13OvVnVBSxvLtJ85lW8P/+dtheFmvW0/ TEWf6iK7c27s0RZCh4lzj6mvpFjxKZg1+B1LeKLNR//Cq6cVFNlGzxPH8D1kVWfi0h4eG59uRta1 ZLS1S2JJMH5s8oNawqQlbvBzDjwn4dL+FuRINqUxozLYxvigH5rEeZNbxge9yNkm/ownK4p0Eix8 mGdbony2uz6be+zk8e46HPa5eOr4wIxeFbEJR05cydbKLgBsvooTpKcjroOVJ1ZeWI92uSvaZm68 ZuMxbcMBNjk7f4HB7NmTy2U2yjt3lmfHoX2ejv+F86eYkGLQy2DWu7m+hcA7tw5mvePhJM0OezTM igWuiV3qJn+q7aSDN5aNrybZVKz8YJc8iMv6ZlxNvH2ytKgUvahDb3YIaeyia4OWwEkMfvjwMPo5 hw0eEyNvMUnGABtd3d39CN3yqAd4XYXDhdWUAT17EnDpZj1fe/3D5e13/9Hy6aNb3H3mGT4Nqa3Q q6f6qfzlF+oVHooD2k/2Vxj9/OnD+pn86ME8y2x9EssUexN//OqzsmsHGhg3DbTPW32Bd3kTT+3F Stdyg9/HOEaXpUmErzrx0AQNAuSTv2JwmOVz6sVqjknlolUP9jHBIQ39bCYLp15rCzBh1ckfPYkf 3SC3h/zX11tvzNT/Exf47YOKoTtvAnNhvVLeDmHQvRPh3iQwjlreX6uK9K3jW12UlvqptHgsv3Yi KZacJNWvjGfaSmPC6EUdUd+IH62gYizwhNc4nmcD0nO8n9e4kuKg+k9+6D3ogo8x6w6bSz45ZNus HaUtJqTgfPpOQg68OfkUDMN659mAuuYmb/ZV/Ci/ciq3gBNLtYcYODZVojMVVX+HTH1p04l41Yvl vdvqigiZQzX7dKujq0+bp1zrH2U9lw/KgKeJd/0uvKMv2ck25Muv9IYHZC9WOB7CxrTz7dJMeetL gPLKZ/YSGF61eRM/CNjAUxhp46Oy48ElQBN/lVF81TsEA3N8bDfxxK9feaRb7QO8S5Ld5Grrd9Z+ O1YBzkk2hpf1qw+wIechJvjvu8oPWg+IpeoHgsDik+Cb+CP/RHhw25eUX2MbYOnH+3F7xDdjFDec VB6K0LgKhvEttRndxtTOmIRAuwaLGVgYgHUwfDr4UTYOo7Ix8v6mFVbuPjLL1/PScBbwtvkIa33s jJtneZ3E9eDu3KswbsSSE4BAw4rPWUYDtA1AelUfIvRPmMqZNw5cu2gewjeAAVEDUmS3IZMnB/VV eNIM/KYXDCUqTvBLQiO1ecOaZqdY/Ut7HG+Ckk5tQHvEqLgAA2ODCnnIo3j4+Pldh+lmqPM+FBpp rYjQh1dLO6jQ4SZN+OHRslrW4zOecU7w9JWyhVCKwSla0eN0XxB1YUDEkWjMG2xvDCenF3EqFfDi 9OCcigxfnIsq23DiR11aooamFOBxIgdKeom8WUD9asQqjKfiZWZb37j54Q1mwi/SMfC5SzKBVQeH eVbgAE6vvOpM3tSTOLEiV6OR0dLozkoq761yoIgVy/LxSX3YGjfTAJt08OlDJkz9IT08qlR/lTbA UPR5VztMcuTdgu1Qr9UKeedcH5YEYM1OQYALbagOXYbJ85baC3ncUOfKpYsM2gii7rqODjY/ld8a vjjSvmgCvE0GgdGBxDHfISz70Grmv0GvAYHBL/pT9w680xO2KTAZfJkEGsn4D9KREzyhUp/m6qfW BQhwrd7EWR0qF5rIkT7Rb7TwLQOVMajO4rY9PU5hOWHrbCOLTb5kRqMKAV8kFMbUH4YYPhKdune4 nYbtrOXnw10B3cm5d7719vLyS1fZSfJUPD/gbsant26yZOpWPuU73qTqu3TH5tDYDmR8bL3g2iW/ DfDhVZ/YYpW8FyvgXd3o93qisam6Is/K5696Q/cuJ1LIyUJGTozDdtM2v/TaT5n950q9EoyP0WG+ j+7u0fnefchOzfjqjbe+Geizzz7LRMmJ5fkXX1qOs2z7zTdexz6uGOB2NzQhDy1l5pAHZPTcRkRZ 1LWxFbNMnSPdDbRIjj6ppVtq7poMz8o8DVSYg8fiSWDdNVUbo1F48L2B6tAGW/k3nU5ZWZOOh7zr ixOzwEOyPFrf6wwIhExpijzrxsZHPqi8CgOE/jHPlWHx7Hlo+eCDj/GHO8vnnr+2XL1wfnnj2+8u f+u/+zvLn/yTP7F8z6sv1nZdu/bc8s377y4HeKby53/ujy97tx8sf/1/+I3l5WcvstSTXawlbt2N ijKrGxPlVTnlW13HpZpKOvUstLqwnVNPIisWAr8dtW/kZ59wD60N7+hQmxlNgIsu/zjxKryc136D 1rchiMt4ZdkZSNktwHdlAVmkKZPKMpyMr5jYNf8amCpXcEDu8yxueQSWNOnGq8g5364nf6SUz+FJ Hj4r47l5+pd/Y0llA7cs6huV1SNZtuymckdP1s/ZYaDZBBj5TsZ2p1muKFOfYvVL+0R6VLpDh9z8 bDBrXLtHH+ExS4OP7N1bTi73l9MMYp+9fGG5duXZ5TIx+sKFs8vZc+wEz2tY3H9ix+XHDmRZ1ued WScsD/k8HJNy6lm9GBtgYiYPjLv2QYhDCqgN69DB79QR9CU8x+TZcQYHeuQENCrBc/XDV1k7Hb1V 0H/SqzmBN8q4f8Luk2PLpWdfXt795rvLb3z515cf/5mfWi5df472951l9847yEH8tt9jBxCcxvCj 1KFbd+8tX/0ff3N57/0bPHZzLF7GvvCy+lA7/mr3mJQ89MFRfKw+kmO+LHPM+ZYGLCVnQkU7k45P Kqo68NAL9d2tXImTEc7xX3Hgh8bN8lZinGsL8Y5swKRDMmAof4NOKubfRqO6go/tyxq4OLEVepn2 h0upKRs/Dg5mwirUwY4M6pU0eCiWgUZdxCf/xSWctP0W6wSQvzUteM49xp+Np8CDOD3jV3hcZdql nAKjWQmt9ZOyg2LqHFbOF/O99BP6+EoP+SU62OdhZK/9hp67WNvnuMpk4VlW6kGcsvrB7+dAbuqg EzK9lhQ8hlX58NAeD0nQV+KtukCGxAYk/Ran1HJM6HPAF58326aiCkIBvYtPt+EcmYb/lQ441Fzt Jgb2I1yrSMSfjsUCndXP7QfIkzrzRL9Y/3FC3ppuP9xz67R4Pao34MnW8k176DhD/60fSHXIN4CJ b/oF2V4+pA++zW5a3ze0yGaxBDqWrU/Cr/2qgYG25ey0NwcDTk6TCThhHpAwPBEfXV/vEMMVxNhk D/u70iQVo3f5af8AyimX+ig+MIfmHXT14asVnbBuDGUPWT9TAeDTzpb07R7t+0KfzMcsHDvqH7sM mO/yiIarUO6wnwl3pClMA/+E2TloDwLSVKYBDWwc/ON6On1UCxQ6x3T0DhxG0RBRQY7eXbopE3Y4 ZbJt/FFgwQkizS6S9+A+TbkegoIU1jvCGgAxoDUDNEmb5vNWdjzb5AW2nKWyUYYqJQko4Bdvjemw i/IcAGWfMSIOSmLGVj4z/TWA5OT6AJ/HyKJD7BsAvOpAY0itRpdzkJIOb9DxDjWkACNd8EqD3zOZ 4GQLyBrCjqINWTqTDwEqV4EqUw02eRO88Rv57w9AyfMTbuqCz8aC0uScVG7Utw5j2ojbmVdxpy42 EytJAS+cwklKifQLrkGEBUaGkrnOay0FFCDdNRG3+ZsslDIc6GdSDR95BmEB3bHXRr0ccPhrQ6Bc Vdo6L4ZmbbUsp+jQv/jS9ZZ8ucRrgrA0LUl56Nh5GfzQpXydCTELApI6tsD3eqW0U8lkcAytNaRd g8j1EXTrbHrBItC4CUZ6PlTvDJQDDkmoFgNTHZW142iAyB7qEd9xWYa20TrVM3TUHV9SCi7oxGVy OzsMgBqAcgeKTtqZU+eWCyxnPsbyVGodukNf6HLULeFVt+DZdDKZ2hpbwNzYWvvyoQN2lPfoyIrw SuAEhzvxWnflzecjnAx68OA+PEMgemOj/Xokhm2wxHn8SAs5mkjwnHIGbv1JvI+IOQY7vwYp7+62 RF4bySVIkiFkMGgq+uaP9MkrS0WSIKw6tpydL5cDejfXjq55yghgcQLzAEZaFcBlL3TWWM58k1dE yYN38eTC7IIqPLVMDznsCEWL/MNrZ9mORA2g8NpXeHnhGx11j8W8snZNagzFu36nzzpp0iSBA0mr CMDm1dAptAe/U/e49tY22Ix/9+/dXl5++VU62heXX/3ffn1hNa7ScmeGJYvZ8vHy93/rfyf/6nL9 +eeXZ9lI5JmrV5c333xzeeftt1iCdZxOiRvDgbc/bMYvonAw0cnknXVJfei88ueRXMBh6rkmPzMY V9W7sXIUTr7IxlY1wqVYkHTx4h/6Se/sI83HMRRbfW7xU5zbsY8fnNZrs/Svgfd6bawpb/2V9tTD hMLWejwSkFdZfLHVQ/mUNA8z6L23/M5X3lwevPr8cp33SL730ac85/t3lz/xUz+6fPGLL3M3bGd5 /vq15a0330B/j5Zf+FN/bPnqP/zt5cvfvrF87rkryy3vRCgeBNr0R9+AlZlgcnJL+UZ58g1VOJJT 9cHfsDoqUrEkyG+dJHVNid/bERqcExfFKb7tQMJk9VpqRCLy4Q3Uii256PPPOMjfHADUQQsa3oCc 6D4w6Q9+oiUeZYJXcY/5n+KHfPWRvIrE+UySrE4k9tLnt7jjNR8p+0vpYmWdMuHxGxLLdTJUO4vN u7i+Q9eVQr6ZwnZUetVPCljMcl7Lrbx2Z5QMJ//ucrffNwbwj4lB3sHLZlFnWZX57NVzyyV2oL3K u0afYRn8M1fYV+EUz7EyGHRvBR8h6Jxr9wrYYek8XObHrXhCntxMPXLSHVdo2oGUB1ee1XapS51g NYR6tm+g7mR8+MZWxCL+KwHyaWOuqcsDTxlzwZ9e0EF+Bpw4BhP/LcOVdbz2Hr6J+stHH9xcHrv8 m9VVp87yLtW9D+IBdeY3IrAP4nOLDz+9u3zzrfdpi8FrV1ESHPmhzAgsX9JN5+M/gUme/H74P1au MLDwrN1MJwYrwTgtJVab2r6Jc7KEk5Q6IH3VX3FAArDS4HcNcurc/sLm43ECLt+oIKy0jO3b5pWi yH8F5Ihr5QOH9PxWjn+S1j7Dhz5JbDLOkiEeY4HK2vqiTuYZbz0sox9sh2irl5SsT2p85VCWaYOk HWoKT5tjPknxaJ7HNghvMuuz4F3ZAMCXzpAHzjn/jA5DKnyJtsAPCMUp2vwO6IkblEO++mIIaTxo xQh6fubZa0y+8hjX7/uI2vKQwdCntNv0VEZHvYIDvahPD+jLn30f++ljL/LVi0bh0OU7A+XGr0tl bQeCSbaxYcBei7N2TQxoB1vano0u1NPwp8y9fcHlzepTv9fPrH/Qtw8kpPQt5e/YUL2GmXwJkr/a +SiTZCCLVn0qZG3yl7JOmBmBtZdxRITK1ypKfGrGHOQhf+MJB6Iitxz4qzv6r+VXerUtyis6QOtT g1j+0w/n+gFZY38GAvr61CPp0/e0Zwnek+jBft4dJsYcwx3EJjI69pp2z7vzBM54uP+YvQTgX9/T p/y6XBnuGjzvMqm8y5so7E+60WarbAjSt3ls5J6PauzZ76X+0C4r82GeKT9cBwamVYBCOirXmesL kr4Zt0oHceIOAim4+gQhihyzcU0ElEHEzAkcEHhZ48dJuNQaMmV08sXygEaF1ou0aX6tqN3tWAez mrC/kK9wJNnYHSFNvG6H7R1jQaaTRVDh4wHLo1TwSzdkZnBkOIRq9otrB+o6TrOtgNYQg7/gWAmN qLHJHFHGGbi041nHjHzfF6n0OrkVQWeycZJXmayBsjzX2wBQGtojrknPCZXHhCmW08mGg2Zx+RVO ngxiLusTOP74Lc/yNhLwaMOxbf3tbotwErw0gI7nnpeuUpqoPwAD7+bmo6Q1ybBWXAcOo2vkVUYr tp1sP5YnV+LTEGtNccEnPMcUxDeHtqJYOapMnFdUuwErf9r4e159aRzfyiQt84BtGY6sSsuC4lE6 TtOHopaiJKGePJM5ZGdKWAYMfAdOnZKHbB5ayE6Ly0Kk4/NUlgUgP6kTJl9Ukl7SvpaRmHJ15zeb WWb4lddpBO08wH8N5ELDsLN88fu/x7FADB9jia6NvQPeNisJDgE5Nn+JyxgCvb8qgK/WhngyCW8W bCZnyEnQrgfY0OkwAyDTNrp2utzQxGfSmsjivGc/KaMPe2AB0K+NuaVFTr7yJKi01AvwFnFw6bNj btri7J/8G2f0UYOgNrU+KoN5+RJ5NR6KhSRkgWvs2RJAro/zzK5LBHsRu3zE38BY1/JRSvvnRNsu wdI7zN71gZAFoiH7HsUG/RhYDwdX1mv51C+tFNPYcd4xdbji4JtYiX3BK4TpaCBI/zspcJglXyrb a/3XTq06g1KwijANpWXhEaTdmcrHiTdMGnzupReXl164srz++tvonGWS3NG/dZvXXdEIHAIBoZo7 2hd5f++95bd/+x/wvOr15Tk6H9/7vV9YnuX3ta+9xh3uj3iX8EkGZzTScgt+2wP59lpuVPp0sFcp 4DV9WNPRk9/qdXLo11wrBUXTAchUm1+ximXO9b/P6JW74hiziAO5M4xlpKeexDX69dLOh0cxAxh9 Z7seO4nDtPEfG18bxuKY6CiezaGjLfQL25ff+cob+OX15eUXLrDT8+3lv/3vf7XO9pe+73PUl8PL c88/t7z5jddYhXJ8+Q//4z+3/Jt/+i8s33jn/eWlljqPL09Hc3hWDv28rzxQB+TfAdvKXXKpuy2e V3LEI5WDf+rA9mrquokm81nl9toipm0wnps46UJwmCQDUNfO3YXC9rhA+qqsJdTvqm99o4Ibbq7E aflqgeBCIKuYy/RnDD71BxjtMbgEkk9//WcpY+ZGRSYtjzfKK+WG1oAKbSfLyYUdBp7HGOgan73T ol/qE+Ku3bX9ArFxxXYkcrYpPBe4y916VyqdZEL/4onDy8XLJ5bnrjzHLu9XmSy6sFzkju4pXmt2 xLu0THq6Ocsxnk88Bs2eBwa3k8BIAkfC8IWWtPNb/KqBQz6ciPl+uqbUrApSbviGN+u69hz/11/p 9DEIt//Vijj80xjmHgimtReCd0easLQDz2vPqNO9LxbenAhwUOVSXycCDicDujrCxpDIYvm9R9yV 6zVjj5af/Bd+YnnC5ndvfeNr/N7h7vYd3jXOXVx8VR0qZYOiAzvL+x/cXW58utuEo4NTFVsfgrP6 TtpUQ/Vv1QnXM8BXdjNJ1+jKznV22y+y5YMhPGZ4WMa0rW57jY21bTT5xQDhExb00iquQas4TaL2 sW624hB8bizlkT/zq6zJA7raKcrMfjhmqg9+PcDdjQvsZj/yMQ4xspm+9hXhL360if4of1JKBure KuBWX7ykSHTmps5MEgrnZ4t1DWiib+0YOcmsj2iNNE3Y5Bcp9PJLcpxAaDmDUCqJX/3H8zaOjZZ8 2C6TTL5+26tOkX/shTzKCC77kw70Oji3nlx95morksQthe/6WAs5drh9+3Z1Y3lMXcmuo1sHR+lN WO2bLNPeSE/Z1YE+4gBRdxtuEgpTDpEGksCC9XfxOoNGZFN9fJTbM/HoctZbqg/6HKzhR4+Cubpx 6nUXmoRE/Y5fyun78rvtcTKTpeRx1N+NVlf54thy7Gnq+NC0+VoIs+Tfju/Gp+AY+aq70G41Jz5a fxU+lCc80Klt1yfkb5gP3wFjkn1/mgA3PVbm+mgV1d/nhoa/tm2PBURQd9v2mV5p9ygWIcJ6srXb 6mDPMSG4HQ/c4x3M93e5O+y+A7wy0v6i9cnNbU2/f5dzHuWqPlCJjZPGN/tpO64GpY+s8NmDPhzz ciiWzpa3hpVTAAOsXqDRUz6MKqv2sEE5ADw5o5YEFE5HAzl/2SPDj/GsKCrLT4ZHAXb0MGtOqcN5 NXdYNPYoXcG2Dpd4Jagf1niRID7vmjp441+GtuJqERVgYHKTHgcnfjy624V8da5xqoKFHez4Ez/0 iyprhagY59DSCfsihDHgIUqX7mGfaeNIbuDSm4z6RxkzVLiObXlReu0AVWe08S5QyLqyyw8fAeu4 VClHd09XO/E0AKCc5cVjxRRp8qSv1U7wLCvC98XODXCAF3Y/OEhWFH7DpczoU7n4cB9K7tOH1856 el3jonFJQzMkrYN5rlTWfqfCS64NhMM/CeAoTXspq2XUk8oBtrs9MtQxjbfPLDp411Rm1WklP//C 6dPfGmmd/vBQnvSi7tMHNHIoOxFyMzzrx3aEvdb/EGU9hxDnq8jQ0n9orPG/7GaeoB5mVBC8nKp7 /ylnd5jNkw+CSRMtXBrg9D1ZcWCpguys7dBx886Qr9sSp3TtSPlDcvATLcmjA9MdY9ELxqFtK5LG LSEf4yN2xBI1SHhQZgOc5RWUYKFNpH+YV9qoZ9GyFUUDVp+7Nfg4i1oHQP8QwIAIrKHEA7HhAdk4 F+4Bm0Ld4+6JA07pmJcvyyswfpsEi/HVXmv6IEMD4gNQm9uh0w7e3fUuuJvHNGE1goPPegB1EXfM 9VHunt/g+d1vvPlkuf7sM7yq5txy56Mb4FQOkbPDMxtceX733h1Iox/KT2MBVq7t0FZHFNK8td6o N21ljJL+FtSNfTUe8COJOgeUK41r/Tk+1b+HPFcPwMXHaiGQPHgH3oSLvPrhLJ3wvd1by/e/enG5 /syp5R9/5VvLoecutzPrHRsMdme9Q2Nzj/WZu+jr3W+/s7zzzjvLK6+8srz80vPLP/2H/ime9f3m 8ta33iS23WU5JruI438xAJ1iFzT1YXko5iuAPqERglTSOTe92PKBF6DmAAAgAElEQVS0GNqgfGSx HFf6vD4qXl8xVPxUb+nT9EgAKT5+qmWW9BpeLGvyZHI9/jv+WM74svDotA6CJeaPtgitajquzasz w2UUwCmfTnhY//6f197C5x4sL3IH9za73v7tv/1lVhUcXb7w6kt04k4sL15/efnGG6+zI/iV5T/5 K39u+Zf+7F+m3hzuUQwQ5a/GQnG7L4TPlo4c82os25RimQzxVaTu2FGvlFMf8kMy6fwnbeMzuRU9 YQBArx5CK7dlBthilFNv6oOccIpvtaM4jE3SG9UAIyGxCcex/W64SMF2Ky4BxCUsXwcUPqs1DJj5 FA9PnYtLPOG2nAzzO3UD+eXZwhzRVR/S4CiEWz+AcFPBk9zdPUIPx7utjs2dwDMC5av4yAPu5jza s21DT9TR45Q8Skfp7LlTy9VXTy3PP3NueZEB7vN8L7C7+2F2TT7GIx7euXGC/wixxrhTLICv2gHo ZKPq/jpZa/9DBcgr4lhn1a9fn4l1FYZ9HydW3KXUDp8TjLssm95jBZEx0s2v7PT56+DWRzNMf0Qc 9T2iTrI7CH7IV5X5DJx3P2w7t4Fwz4OqP3hTV4fgybanO+DcvTbs++jDc6xaOH3qODcjuKnw1deZ KGM5ODr89OPby7fffoeVI3faQfrcmdMtzXYHVvcvcRC99+Dw8n/+w9d777j1yE6rbYw86WN65NZp n2cJtQmZHMZ/7dwdtsqM72nnmfATTixWDYxpA6dCtb8wILcOVL9JM6uy4BJEL+kamK0+bP408WyD Nx5Nu2et2fBYH12hVbxSFuQz/nQtv1JAsX62mC7+JlpFotKTjx/tL1Mcyj39UQQgaXhWjqkH4lem YDnvbnCx0RjiQAI9BTs45cSjcq5kgU5yUHaTf3qY1tUA4znewFM7rDPAi/w/RjZ/vVYG+6ckcDHp rnKcvhoA0Jr+g4WnvGleqAcHP9eYYL3KCiPfhvD7P6TPSjH8/D5tmocqcuxi32mfXWgrc3zLHnDK NzsSY2Pz/EOe0THwyigkPiDrgghke6R/VQRam/26joS6Uz8TMdVRmgeJYxRvCDgxT28ze6mTbq6B W1yS8Ssf8lwsFbn52cXz6T/5K8zwp0+gbPD5OkHbvePsqm6+uPyOzw5u+YgOfMrvUJDK0FlJrnyA Fz3UlvKrnmozXHkbD+BEyiZqKUiLwRX+QexpnwRg8j/0iPmJS8NfbaD1h3xXudQnRJj7xLg7d+8U C+9yp3aP1cDuNr/n4xbcIW5FpQyKj/LuVJ9t6aAe5tGRQ80ywI9CiXwVrpWVtgVkHFZp3Rq3sgIQ PmymAnKWSo6iHyFwlYz8likSNHWCglUeJxGQWAH5+AyohrdC6jAqpwruIBF4lxAchkmNgBvwGbry qgFNaebAig2j0ykil3PpOrOEvlC48vHR2Uzja0fTCuDMRTNN5HcXMSXoLIPHmU/Pa1SBkYc40cni g2sHPlx72KDZofYuNsTQt7+KbMBhsEIj5J0tyxbwaQh0Bc8t4h0SeW5igfQZoCjbxgN5m3NR0sZE 4/qcmyx0m7/gqYbGRpurycBwI0fDr8p5RCOtZrWNm3l1GofjwDag2jU7WrGTTWLiGUxi8/nUOoAq HJgmEGAKkQCdIC385jfK5idNcq7O0jsw9gFGoA0/CSTmC9jOsrMEaKzgC6stK58+jO55AQZrOcGh bOZNIECX+qN8wp88JwqyF1AgbWegQYmy0tF+wizsLGchk0ONKZV/nrsEt85VuNQVfm3nh/LjOwMu t/pPwQT6ltlsa+DRLNkx63mhTQbefNXi1yOe5V/5yGtXUOU2z8BcHtyZwJHfwZcTV/kr+X4cuM/g Fs5US4gtIW/6kOh97hy9k6oOqyswkj6RhxgWP83IKRdyH+AuxI7+fegE+T6C4DP5yEPDZsfMQXx1 XxaB93uXO4+3eV7WhmmPu5vys8ltWXUlTW3peTyqEXisLvBrHPAAOi2eYMm7S5jtpNeQki9d8Qgz EzIqSV9Yy2oLkYr78SHe03pr+c77dykjTbvB8Iseq+/HTiwnuKvxkHfa1nFWFuDgMBramhNKOFmC TqXdhAvp2tTOGbIYniIZJHT4q2wUVYQ6NbYiF4qZO4/yQyKHHGsn6ejzzmQ/w/OC504fZVO3Y+xM vbecp4N6nNUB3+bZ051D3K2isXV3apddPnuJ58JBd5slQS7ZvLt7nvfuspPsB+8v/+DGB8vLr3x+ +dwrr7Bk8wq7PN9YPv7oQzrW7i57YjajgaZVymWMxi/tsH93Bt4MS/JPzeJKnuXddO2KfFz2DGU2 1i/HBprZr2W0WQfXyumhH5hv1mRrF2lUKLpS7fGCkE0Zi0+bEZoVz8SGGvFhCV2OjwQPzmIEgopd Dp2htg56B8/Jsf/r/34bOx9ZvvDSleWTGzeXX/6fvswdvlPLyy9eWU7y2rBnn3ueiYNvLl/64gvL X/3zv7D8W//Rf7784Pd9nqV4PMekf1FnbKs2X7ctU5buSDJY8zCviSTu4LsEe/ilQ0e6KCqDMnCZ VUvomAx9R1zmW/ervyRNPLI2CD/6VHF+hAOSS8sQ07wO9+jfO776cbbhPAryMcaQ3Q6hpwQQ5vHd aAnrebHYc/M5BpcVY2SeFPIkuaIRT7FgLcNF17ZX4afsPBJDMYuSzxiNWEAcAQlmgxf45VcfITTh odSLU0eWczxzeoK7mxfOHFueuXh8uXz50nKZO/OXmTQ6xxpmXyFnXBGvkxc7wNrBzHbGgb7GZju0 6g9/se8BD75n20dF9rB7g1g66L5P9Pat22x4dofvPc7vMPnH7skOcN1ln9jpsrw7vLZo9lWYQYva EqeDJX8fs+TWR72YMs0vDyPnDgPXIwzKjx07ziaHw6MTNXfu+LoxXlNGHaRosV1/Ni49YvOth+y0 fOg+53D/wSf3l3fee4PJmLGRfmO/0vbAyVo71fe5e/wQ+t4R927KLgp9wLlLyG989DFxE52eOJXf avWxn3ahnbONRmfKaSxuJQ8wxRN8zzCh76LZ8mMY2SlduneWi6/6BKkTe9E/OGvzSXUiqfqisEFN eS/Vo7aMLa/zKbjMR8QxZYJTZspr64lV4uEQZMVrecNYcYY0vKD6Kd8Tqwey/hUxy02+4h8MyinP DYrFSUzIh8BpJ11bxwd50hCfvIycw3v1vPgFkIPP8E59yV+4zvcnQ7ZABGhtFImrHs3QVq120j74 sCIeoG20yBZPsiF89/gJGVJUtiYOaRwpOvGJMhuvG4wDPuU/w3PuJ2mn5rDuy9x3d2wlrFvuPD7v g9cWVHyWOOsdPe7iAAw+tWv9RMjIl3LX/5Os55QAMv2Yv4LE2Uw6jn7qi1UkhwmXsAqd7fIf7QeH ZpgHlqM+YkUf0/isz6zJwI3Ntn6JYyZftZfuKCmV4hx49UbxVpb0zXfoLHClGFOvpDcTTtP/Ijl8 OZGF5Qt8xUpoWddMa5jAleMydRIeftWm/vAEvbrfw3ajSJ8QpnEAcc6+085BVz1OegNN4oMT2URP bM+mYy05fsibMW4R75jco8/4ABveI67cIwbep29i3HxAXVCVbpjmqrXGjeDytWxqov4nWBvAa/Mn s/K1upS88oNs8k89yubIaFzolUU5ChooEPKb8ejlZjiEUnzfYWVFsWE1wDTggynP1GNqN6jV4VnT jWD8NegEqNktSghvKQOewmxB4BACukOqabOxEEufUYA0VKMdhWYNucpUCGSLBlcIBSEuFWoLrMqj M7lznOHoAe+/VAkh9BdGnI2w0tpQeRCKwWUe3/CS3iVya0zwfUbbZeCYYHUiA7C5KrjOMkaShuUN WpH0WniT0eMWtOqwbMbB+3oGlHIONmoQbLS51hEUte3BwaPutoA8FUceJYHTWAYYy0Es+1r5pT5L P8nQngH87mBaeVVqnhVNnvnTDtshbROsuB3AbwHZa/VicfXluZMrdRIc0HA+tKfBUuehAaUBSEHn br1+qX1HzvgBt79+9S0HGt1tA4GNVHYSh5TlHdvKl/DZmvMmHaBFHU6HM9gZPi2q/IrsIe2NnhXI F1x7rYtswcrlaKZ5uGTMBiidca3s6XhFuC2FmoEDuIBp8oR8SVYfOLEjtfGtjZWlgeSKT1n9dMcN Q6g3ScCeWIY/eJKt0vEBdbzJM5ThD5m2I17sZKsv/TOLDw4ZFXc61QmhYZAWf+l0BrWvu56f4G5r uIDvbiS/srULbkCoozvLhzwb6XMY8ac7KKOMmA+v8hmvkzS+o1wAOCC1c+PmMN7ZnYKWU27y+aZ/ cFVtK8W5Fx767hBKJ4eJEcYO72iL/xHlD9Cxc6+Dr7/x7XTkXZ3j3N0hNf9pUxo6wtalniHUr3UK cBinPFd2fSR/0ec5NzArtH4hjKrUlmM4fwHbLqXG+cTcOXdw8ujR3vLSlVPLD3yB1z6wtMgOtHp9 /PDWcoPn79wd9sXnd7gLz0wpjcmuM6XeCeL6GMvXT7IEfLlwiE13TtPwXAJmlzvZ7y73Ptpbrl1+ brl65czy3sfnlvfYwfjTjz9psqzZZJhVHq2QGomxysLfML1GCEWsA0mG8qYXdK76HcwkpHJudghf SMKjTjY/Gx8Yu82yT0GGvrZuFQka9DBdmMqQN2CmTYPnr/7edYoGZkqu6leylQ9zwGELY/1zolf/ Osos+le/+u5yBNu98sKl5b3v3Fp+5Vd+Y/nn/vkf4TVGF9kp++xy7tb55eadD5Yf+7HvXf7sn/rx 5a/8l//r8kM8pnCf10IRclg2mphDeZiE1Gd61I2axTYGqHP8yPjpYKHBEHpzErKBKuXAlqyiktet Tm8xSUJBAZC8XGSfKblazRy/yAyOOSw1evV3JeVp/FYC/mblDrYgXe+o/qnnASw9vCBQ934/O4zL q2+XTnkyhzK/gHrnzPoiA8nEeY/y8NudJaHRSe2M/FAZfIWb9dB+hneY0Eyb2l25eI7JohPL+ePs Iks9uXjx0nKJd6Ofv8iO+BeYNDrBPV8GlPqfA2af77fuuxngYQa9kppBFf0FOm3GMDuF3om4e4dJ PZ4Bv3X70+XTT9kj4JObPBN+m++tBrxtyAKsO0I7qdXAyI4kk/8nWFHiDqu3b+0tH9/8NFOc4s7r zjHvxtJX0megbR3e7uJa/ggTJUcIXOfPMmhHthMMPh28+NqOD9j08eByh1UJ7phqZxLaBWv1bdzC u8XJv0d2UJF5l84pISPFW1/Jpmy1ABUywYld7ZjfZ0JGP3vMu78PUSe8OXDspPawr2X7YT/FmAgC Dn0q2+PH/k4/bdIkYizwg4U5n/a0SbXqq/6qXUGKr2xIxQ3LHfqmPt2mp6SEpxxw5jfGLvKRGyzj v1zHiyki02P1UXmBnsi3OhSZyQZ6Izo0Lac89i9SL3xqmx4BUhfgngHTlItPFJQ80uCrzUY/+gey kt/KS/lQJ+DYeEksuQW3XNeP5Px3H9BCLAd/4hfHtDnqaGjX5pFevyg8wCG//c6Nt/rt6iNCpK+T QNpKNZicriTBod4tm87plWjDg/i1q2Wss2fZENAdyeewkNb4Jz2itq8LX6PlxGxLWPFJcbnioh3X lVGVqLcYNV+up3+QLhNqZKjPQa46ClLxdGJ+1bM6tDWo/UvXQJW34Zc39eYgTzxEQ+jrD9ZrKbuS w0chjI+OOX6vTR0YktXhT30H9QMeMHJNInzkZ/qpnxL1Q+uiAmM/+xod4zfqoP40PqZwvsZSeWCh 9GwMPCoLH5xxzkB1CGdLog5xlMdIsalwjn0s9xglqw5jtCv4ekduPO0tN3m+/yZxkP3fWYZ8r2d5 73Fnfo/BrTeShnV0Cg61O3suGA/lxT4tNlR+8sSfTzk+4lMf1frmhzz10HPbMsP5qEotIid8jmxM tJlZ4JNpjKXOfAfhtg69SkixBllYr04HBLzr9JgOoa3Z3PGjMwcDNjZWaAmqaE9kRgG8E+U7r7ZX HMiMBlZc+awUwVcnQSRSJ2iKR1QpQRqkj4FnGa1Ich7xkKlKLCs/yufgzzTp4Gko0gNAgUC8OQsk SisYq2DyDjJzUWChnDyieiqveDiHLhRzYHmYzomOYedI/PLFj7OTOiGyCYMFqgQTqARQPngG3o6V bFkp+AM7Dc7aUPn6Ar3Birdlmr8FMk4rayMm3akMDAjRvfzoyPKrvMlkuh/FgS9Zjm9gKj//4luB 1X+aHZbjd5Nf/QqjDE9XQv2hcnaOsUU6oGILY5CfO5BTttYXLM1SFRAAhz957Qxc4/Tq1TKrTzST BARpwnZXFj4MftP5Qu/q00EZGsjfkVWcHtsATz0MDk7UMjD5rmW5sIHwMKZlXthqd0DyJ2COWYQh iS/+boXi2Owb/+CSgvQdDJTGlXasYLJRjvLqrsMCpPdeSErbgB6ko6M/NsiTX4l64E/O2oE5efVV 66h0xJf9BZUP8uT9szz93CkiASyvf0tj6pA4t0ZQ/pXRsh4ubxO3Nlde44B1sDtk1AmrwEVe3QEq OkwHlpu3WWpLh7GOn7rIvik9fNPIQBFc3WFGEAeYvZPSnVfpiCqPAxF51Qfls2WGpEygk2P5G1sP /+odfatDAwZ/ylD84lcZkl/dq3Pkf+RoGDzuBCgqbbVLz4Cc/HroEqSRwcB9FF00GIYr0fSMrPJB TzphQ/loqg55dVY+oCIB86XbgUzN/GPDx4/pjdJJPk6n4YXnL/NcHZtP0UE/c+4cDepuuE7JH8q2 2mh3dbzHUkV3u/cO7z2fj+FOkh10etDcrWdnWQYBlw/xLl86yg/uvsWzSMeWayxfPHPk2vI+d8M+ +vhjnp3SVuhJOfSdYTamPddbulC5fIWdOqAPIYPiqN/VHNmC9OoY+Kp78EhS5+LQ61z1oUKqH2os PXinaGxu7CpuAVYcsrykwhUyfGHuomln6Qzzcy6VVk4MmWwA6yHR9zyU7SBx5tFBX4/G9c7B5Xde +yY8HF4+98LF5etvfmX58q8dWn76p3+Uu2wnW8L3tdde53nq3eVf/Rf/2eUrX3lr+a1//O7y0ueu MJvNqhU/8aGelF2dygDxC17l049/+oH1noW1yW6HxljU3TJ81XN1ILrwxrACqI9Q9G+jOfVVHUy+ 5UZv6EG66ttj+4mXSVrVsfK3gQC40rZMsRDA6QgPPlHGn+l8NxJikIx5/o4OwMF1Cebx9dAv9LAB nF/rsB0xgVwF5VLm4+xEbv1wgz7fxezzqmdPnlmusOnUZZ7FPXOMV/bwrNclzi9eOFcn/OQ5Vosc 17d9xpW44pfOqe/wVR9PiF++vuoTNrq7wzNpt9mcbPfug+VjJoTee/8DBre3l49v8F7aT29y5+J+ dmizSvsK2M8Y57Oy8uagobqtPNoe/C5z3uXZtY9u3LWLgu/a1uAbvIrlEJN79cnWuoKSyMHmXHMK 2MRc66RLTd13wYkgcd7d5U4vr9G6X/2f538pwYHeoW/dc1sYNauvPOrGAPiNHd6NJc+JM++O44nE h1lx5etn9D/rp/2ho3Ra9VELuvGTMfDxGjOJFKtvkq2ho8cP/m580tbavbx8g3Oyt//5BLI9fZjf QXKrG8CjJxlba3ON4ejduiSseg4P8vasuoWh6WfqDrq0YssL9jB2FW8oZ7yTbf3Z9KmvwJPYoHzl edpffVs9jJ/Ly8QtkyzvwNaJ+tGtHfmRmzpIvuWsB5v/y7v48sGVjqxvafu8Y79tMlU+t3yQci5u fpW3C8qrD87rZ1K2dhzhtzo7fjnl5LmYveKyyfTQN0RnmelDwbf1Bnhxawv1291N6OtfB/Hla9ef 43l4HhnKMkr73R9iMybfZ+nr3d27xGV06+oDfNLBmTVEmZNbwnKSffPGeMmeOcfQf9qu9lW22I9W 6j9aT+MZ3Vlv6t+QtKZmO9PtFfgf8qXt22K4SFfziBN8AqOOPLQBWPm1vRz7kJB/qF81Hn0MIE79 Rp9Szx62A1ua59qhPhCwUtAX5Ulbyp/tY+2meUDoS/Yb8lnSDuKjHtLS1o9gVpnDiQ9LqxV9jFm8 Oelz4N6hNUZ+zOse99xTAJzC++y19lKF9vudDHPXeleNqQEHver/CHIbT+AOeeTKiUcnS0af0kxP 1Ot+uW68CQ39u7oPt/XfyCOx72DkPwywTUNaDdiGv9kqiFsZpnHd7o7OTBQy51AO4iRwwIfzYTsH VzlKpXNpfARWYUZX/iesd4yHMRJUJDgcO6sNO3aHwDfhFyWoAHECsy1NGMF0DfnuP2UlhwHlG9oq GoCZ5UERBlbpFBQETgZ+KNM7eDFCHQcKWWndmEJ+GkxYcTUwLO6xrFa3c1a0zp+dbgVTRuR1KTVN MEFfHU1kMEDYOfeOsvT4R+as8YdYlRQMHLqhHZxxjDGo1EAvEXS4DZCCNEt0aVYgeAS3TlsgUxdb nvwjfzzhY/IuLivodijCduhEHlvFkmcbyPiAZ2mYtloB+2hHnBoYG5reWWo+X/mSHweyQwJ7MlgQ tuXvpY4wG92KkT5y2xHBx0hUJ0o8lSEGZYNjcNcZljfVxdcyzmxLdzoNpMGrfqK/VFJd0Dhvqtju oItA+uotP6/yjA8bTCJMIStpXgisXIg1XmFVuulYWtCM/3ibZSj6hryIS37zdc8VU1zaDJ8KRs8j T9txIkBBXJvq234dnKpn/R/zxo86lf+xOW7K+QQxuR66Xu/bGrri6BVHwCqLjX5dMMuufMmBfMm3 /MxvF/mDqWMv2R5+sRyyIQfx0RnBDYe8iVn5rLjpTweJmsnyz66px7mrS2fLjqgD7HhGPumoFovo k9uMuvoMJXnZTOwFS33yKXtQaqhZjfVb8CgQ8pqhHzRhJ28kbTYDHbBjc316ZhmX5e6j++hQTWmD iY0xCB7rt0uwnQiQZ585tHPcwM5BMIkOPOXBxltd+MGNgad8HU+kpIG5xd0bO7nHmAA4ROf+xLHT Y3OYdKftdt1GP74apYkzGyc6sA5+veP0+PEZ5DnIHal7y02e973HRjWzmyQ+zStYDj+8vxxnqeJ1 dqW9dOYIO1vfAY7ZWmZp9YftkC9t6Cf/2vwX3VSH4X/MqUaUQ59dMSio5ai3+uxoc2S18e9OZgYZ WwijWcSkXraO4qxqIU882k+cyOpmRB76henj6+JY60Q0/QdlkXqQZ7HuaMie2NQ9ctWhAVB5j7Cp 3Fdfe4MB1iFeUXN1+a1/9Npy+crF5Yd/+Evcfd9Zrj93ffna17/K5MSLy5/5hZ9d/r1/+y/zTOb5 7kC2I2ydiBEG9NCIQfQznZj821suUNXvtscv1Kkwxh6Fcv8BH1FRdu8sGQu6m4ed7ZQngcJTiepk o4s0aKVSUA5A0+nofxShPa17GHF8HritLldInimYbYFVhv7BX347aExMf8kBH9afDY8yemjL4GQz Tkbn8WAufAiKZdAFA/7iOktq2bDuBO9V9pVkh92winbWpc3Hdw51x9OlvpcvnV2uXTqznHKFA7a6 eOHEcoG0c+fPLafPnmpgDIEm047vHKfuspETj9PcYnD7yYcMZFmC/PGNT5b3P+SZ1u98sHz44XvL TR4HuHnjPfTGDvFHvBvLJlbQ8o7OcZ4ncBWKPaOe/1XPyKQ/OdiYOj3+6YRUGwRy5+X06VPLczyP v3PMAQx3TfEhXv673Kczf/s2SwN53YabVmln46UxTT++zcZSd/d4RRk43mfQfJhJLFc+3eWOisuR 94i1thPerYahBqve/bMKusQwn2YPgyd8vYv8AJzVT/I1f4MWjeTOuIhif6iOs/VTs5EINxhH2Yyr GUpLSW7yBOPY2nIn9zWo/pPl8TEnJ564nBa8+dQgBw684Rm/Gkzzf/xMXSih3gIghzilP7gnzbza LPBazrhVHRMuE8115c1Hv9pLbMmkiNYX8opr+jnX5m0+7coedT8H1NMR8NqeT/1MytjGgmbKr3yp K+uu3NoPHz+Rj9Gpvx7xwm/5VlzP5Yv8ueJU0iCagYwq5EKC4oI9y9o32HgohqNn+25QJL6vuvMX oNpy2rRWuUFPew9/4BoOwqWh5M82LT4hGyy47YcfY+XCufPe6Z03Rijrd38onKWeUCduMxnF+7AR 2K5F7dCqExlqEIpN9mWgIN5dvJvJVGQbVOnK0/qGySzs+JG0xKH9lKvvuAYQSLgK0t1PbF452HRp 7sTg1XfJ08YRVdeUcywFapjnQjzSBoN1xcHeQyaa9B1UWJ7xD2Umm/W0Nhdc/jYRRZk93m/baxYp 0piMtHm3spNWtn3Tf7Lf7rE9eriteHWCTpaa+EKf92lXdn3Uhlji95GPanCH/Q6PfN1nldgdNsd8 yCMO8uBYsI2k4L/JfmLiDitZoFgMbBwGP8qOIpHDuMC5PPmBMNl4GImeE5PkpZhPGVeZTFuo/vBD +NMe+nA3VNWv6NRfJa2jYuCmCWndR9aYajvloXg7hlvnb5sRikER0DGzg+FRJSRDolagniVUAgXi qxzbsQXOLejZIckY0J2Hml30JV6VQUlxcmU1Vjc2JtusRIEm7HajpaXunF0hoNsgwIMOzV/KMF88 8iSM+b5GiYvBq27FUZBzIDqGs5EiNQdxJmN0MEuunfXvtSarowIFJNihmbJh3kChTnQAnV9n7auU 8kS+DXXLnNQpMIfYgS4dwGObi6VrDSp+LQ4Y3yqXCiI/PpMtkdJbEmsLDuXV6FVUyQyncKstobkG 4EkHIGVwtVa6bLk6JLkzqcCv+JppB7cDIyu3yzP0nYI2OrHhcTAg/zTlKy9wZ1DHxh7iX0/RXUn9 m0ZLW1hWL1CWsblXW9Miv0IMDgco5OTH+uUEqW2woDrVx/iC/jA4Z+C0aUYdkSMsfI8nSoN87ahe +bOShYtfMqqs8lXDIQ3h9Q9a1KmAoaSzgR/As50H+VyLpw+DnA2knHHK4e8qA+kO+CtLzviEOgYK GDsL1UXKiNcfD+FtjA10Y2u7OSMH1IXoK02ETK7hybwpb5zWCv4AACAASURBVJ5+lzZM5iuJTb/p xWQLboT5VYbiCsbRR1wd8gCbWG+VdWYprWM2+PBJXFC5BU3KujT9CBsUnD9/hnddHq/RMdBbj6bz n+rFVp23e6c0NX7iTNc6lXqWDvnIMbpNjNK1qQNd/SMp+a3+UlT+zVBXnvqMfPiNfX5EyDG6lHt0 4KwztlLvfoxLBu2efUJGtUQVYOMtOsl03F2i7F2pHTvv9NqtH90phtF8Iuz6MwyRtssy2Te/+R7P pzxann/+Eq+xYidZyjkQ8t3CDnSLichkbPbOwh5lfBWVscx3+NaxhfUzJ3ZY0szrVdjO/9adPZ7r 210+ZWBrh/nh3m049Q4VnXqWPF84f6K73TZ43rF8zHLHjxkUPAKv+lLWZNMXKfmIdbz5RtekWEnV 88qXvunhz3TUtJXxAC0Kykf91h7R2Amt3YXPLuVzToe/NPScgeVCm664N7+s7pDltdj8zylVNMzV cetABfkJKXLVyHZd4QYMDrAOnjiwfIPl70eOHGfDnxPLr375N5eLV84vX3z1RZ5bO86rOZ5d3n7n 7eUHv/Ti8gt/5meWP//Xfmn5oS99fjlkPcbGxpdqMMw7gSLb8jTtr2mrb9HeVI/VH0eyqwPyXW0i v+bP3e9hW0xTG0ZSYaqz/EpDBevH+nR0uC7mk7fZJeWoIP7qnKkzeN6OdKfi13StvpUdnYv7d6cV Ny2xlhN567e4hkwk/ZePkPaIyeYmVUlzaaA7DF9ggOhz7Po5PZl18MQED0uB9efzJw8vV86dWS6e Pc/g10m8h70v9/K1K0xMXOZOE/fNGZwYQ92IyWfuHtx/vLz/0d3lvQ8/WN5lcPvOu+9Tx765fPut NxjgfkjcWrgbfI6B9ukmrk6excastHDpMZbIL20Dp++BjtQZNi3G6UOU91lc40A7LzPgPM5r9679 v5SdyZNmV3qXT+U8z1VZc2lsqaVu94AxxgbMEGAMGFhAAA4HESxYQAQRLAn+ELNg6wWwIxrsIGyM 243b3e2WZHVLLbVUUpVKVap5yKrMyrGyeJ7fe0+WWFl9M7/vu/fcc975fc94z13nOWKWfDrrPDvj DsqRQuTjxi+bj/Zp0G9nZnkTv1Vsbk61te0SaF7VQYPTjpbthQf3H/M6svN5R/DNWw/oULuLsu8I ZtabASz3I3EzGH1/G4Z2eKWHfmInNG/uULdcl5tWDZtBGGxDW4PJ6CV6B5aWoHUZM9MG5IY2YLwx 1T0FvFYW6VhxYuyXB+sg/7U9Z+kDyV+B818AvG/dm9xIuXxWV8lhXo7EHvLlSuABDM6hQdFt0vpP uNWGLDsvf5MD4egPVYsUX2AU/wAnjeeQ6Oy9JeoQhvWH9bCyE496L7xQNZDkSZEsdP6IO7mFXPVF zx3UkH55SZzCppKLm9aRDqgWbuVGruAlhwHTf+gVTiBAo/WHdl7AwS+egSTzAX645gpYwnazH2XN D/zwBV9ACgjvW86PNEqTebV9YRflwvSu+GyPsaEa9c4aM7yLrEry2VB95mc7Cmvh5Zt/N2jUl1J5 IEv1AwmhSVtVqerTgUHbKhZyYKbjll4LCDPMQnOojkxJ4qLqG3gmU/LLLeclU+GVnAQiR9pzbIay usxT6vUaQLUdRoL4bENw35ZA2mLSR2b/FJc0ZAAXmQnX2VHVCxP+J81YDccZ3DZB/8tmp9wecTWl fgUwafExDGdXhSuVYzzY6pG4z2kW7apH6FNeDphnd2SWeGRjPdoCvvpwh2dynxAzjDXaupvg2cex /vNVStqwR3xIfNCoTdUAg6fal9Q+k5ur6BI7gGm/JoO2wFC+9sUEmdlhdUJ67zdEVqRVh1ak6k79 g1cygKXMlGv1UYl74MbyJMrna616SSQgx5FgKI2+dCaroEHLkTk4CNGZGQ5TVkw0VDmX6YxkkE1h S3F+IUeDcRZDYswnHpWmZSj82APwdaoaDYDwYEJAatry1jyAlSeZLgkWDgUZLoEFsjAuCeFHfEIT PmmyUQ1iU6tiyrp7Lh3R8CXHwpBWK1pcOoox4IzzKpAYEjRZWuUI3eCCBcQIIhZkalnhZBbIRKm2 w+8ZsnD01SVZlOSwQmDG1HzIX1qVpabtc5JxYPSjHsxrZ1lICa7kS15wKqB0gqDHQKRcDFzSaNno w2v1iVwAI2juUpK0XkZ5h1DSE5CJAFmmHV0oX8vbaIsWgyeOBr8xWIKMRqxOiqpqYGlXCZw6mHQA o4/+eC59fmJL/GIdIU58Slx+5CX4pSHRgCyc53lZ6ZQfyHeWveQx8MuVDpmygYSM1B+fVPHSQ8HQ 733yKo/Pw9CJlJVEpaLzVF1JF2WlPcFNOHF8ZIze4h9kVSbxJcvLn/YPQOm1s+OBmSWwJFB/jibz BHnvGGtISStatIcKzKE4MlS7NUqmnwmdAqFBrdShlCOT3AJKRu2f8WPObme6lyDACHzLm8/f8v+u v+KtKsvyffAbjC0JkNqoRYIGgBIHHAOkm9BMMJO2usgMzSyzu9hibJDcWblBXnXTRzrLl6UhDBY9 5IltCDc2i61wWjm4p317DD/apHZVHW/tqm5XFi+kQWsXiDzwA+nFjxcF2XxWCnZAtAl1qI/ZOXHl gQ3WzEIC8d59dypERjRa7fBOUXFMMqNt3HATHWeCJzmf8tll4o57P7qBjZWWldA7719rl3kf7PHV OZZrMoPFRkoLS/PIjA4BeYwvE8x6WZOOLkyHRBu44uwb7LhEaYcRWzvmczDthjTtcDo2s7VDQ5rX jzykM7xnzTgKfjp6M1Ps6LqoBfAc5Cw7u9Lx3WK5tBuVKEMrMQd7YgtU8DaoRV4bfME450pLGZsn 9YFFYlzeK1s1BsaOUsQMsEKMta5Qpfpy/5S9YcfCU1f6COd8+Q8y/bzgla1Lv38e6rsq5+B05iu4 LCOdcsUJ9q7vJuYDbxwdqd9LV661V1491e4/3G9//N130cUiOrEjs8p7JO8zS36n/cNf/6vte2+9 0967cp93JfMsNXaQ5+0A6iBOvU4CngaK/HGDlvAHMdIhTV53udgwcfav75uRVU5m5JB31JxYIn8W Ns4kfvGbyE1C7J5ri8W+xVUAEt8oKFH/n5zMq46Nf55HjhJnWQv7ld/6kWYxmjON6NwGt3g44ooW 588ObvyDRHcPn2HwYJqdse1g6hfj+ImxKD7PYMtT/OApfrM4hw+wTPkMs7onmMWdIYbwQjI2dhtt 6+wYu3rqeJuZn84MqnDd6d3GwN17W+2T967wqq9P29WrN9qnn1xpt659kGW9M3PrbQJbXzu1mgFq A4izWM5KKqt0cBObHGSqek27qzqlOri+ls3BpqNXvuF/zqDMsdnT4tIa/uPmL/gQ75bc4FVYB7Q/ 3Bwqg2bES99F+ZCXbj/kkQRnZldWVjBlnhEE39wczwHT8Jyk4/6YDsBH+5fw+dF25swpOufT7caN m7GPHWZhthioUma2bdRBfEjZ8+d17ICKR6mpOtVpmwJ2uNaXTFTffiyll6Exbui3Wo3nploi3+bl Ss2annPgZKUOcrNcz5+6jgzV1tDkCnZK4R+iT33Kr/esK8NHgrB+D1YrpMH20tbhXHv3kD/vhQbz DPALLlSYF5tOLEoJrVF7Jm8qjsEvNNaUH2glT2gHsmU1ZmfOPISnrQojsYg0i+oOUiIP8iRR8Qvk l9g54DVPz295z/0VX+kBuOa1TS7/yQ/cQl+ytRBH2hycI6kj2SZf7lOSC9sJpkmXsISpHUYSwSvP yIpMtgWdyctoOPZbuqEw8JRpdDu0fxzINwassmvzPHW6R/EzEJqUP+9LqBwSJUX8+gobO73spVlx X9+DO9yGb3IZYKhDn7ISwtUwFtWW5dG2Q3gJ2IJduoZzaE2cJFk83u3yFoITF+owtjuUL70Zb0Ua iaWccicj4+DSnNO0G+wTCAth86tNCJM82gZllEw2s5QWPkg4tAg7zFGn7tmfoowJwnYFXXDzmEKe +weK7SQ7vfIqLe4S72/0CjLbO9vURbYJ5Gmf56QfEYd2HRyjvKvSjJPGOgfXptgA0P1OEgOQt/JR 5wrVtKrD2TCKmKQlSHviP9mUl+2MDNBAaWK4tsS56wtcLVKxBS70Rew6q5OAEYmAS7lknwb7qFyL Xzjan8/zqzf3hypBYg/Q6M7OeQuKS6qtbM2scA28NrLCgCg8BUF2j0S4Kdw7EVFOKbaIcEQBARJc LWSjoANQJirCzqawpUciMQ+cFSYlnCvvAyFMuOwuGjBRgZIjy/Uo58is+d04QedLR5xrA57uCQCv +NSpwUQjUtExnLIxaHUXQgyAv+qwF81jrJOw0nnMEsD7vPhaQ5icniUP1YFKkOZkLRwZ7QBXRiWs EMk3CS1jyHSPndBsaNkYsYy0uaGE0/AaoSqMAQ7ExjDBccDyxXSg5Y9cdrw0Z4OvDQ07d2M0gh3B UjzCyO654imyIj8dXCPoDpzACiGAja+kE0sBG0M1UuiJ8vOnZOlvnNFfPsoqIzIYLz4QUSt339sl IGmxTLQAvQks4iRBWaZisBj5AEVjD7iWPyIcy1A2kCKe4A8a86gt4GN/T8hToZmbHN5xljUONujf dMtAWMEHphIt+zT4V6VrDm49O4YLf7RryKj70Cpj0poOrwwJD4FmVi8ZwYCNSEcNWoiRYlynkSjT 8iUMwfElvMpVjVTTLRSZKAgPeE5AFZcSI1P0yS0rvRQwXyRfl8IBNCNy+qd6tPNtJQs28SsX/rwn CPOb0nkucIMulTeVYUbtyOtLxCXTj/ahjalrj86TOgkffHnHRmu9YgPJW2lKH/yJ12sbkwt02HwH pjO7M3T2tLEe3AQynlHiwpvlxeBVzsrEAF76lyZ0o8y5L4Kn+JTnGXkGUCpurmPb0kx5ia3O0lCe lH4MUrBkeJJHT1OM0soBaw9eO7ixXX59r1wfOU0R5J6GELmNKe5IqENK22MqnA06j9q3S6qtcMax JWeEp5jFYtA4S8OcHV5whpiG+8a9/Xb19j1g3snM0SIN+5W5ibZOB2CZ16/M0RF29+lpZsAcjXVA wSXR06SpFUfqD7IhyA4juczgslxpm07wHrGcV5S2VTbYOaSRvUtLYovnDl0KvfHIjXvU4W5b4PnW uamF9mSVeEeD2t003cDiMZWmhx1+HR0Wo+/omq/EP361yQxOcT+vw7AQ5+pPGZc9qkLOgZV3j0Jz /MuR8CjB++gvdo2G+PUw/3A7117kFumpO7gQjjqtOFkFxFWzNbVMT32ZBtrEtx7DNDHrz62tLXbM vtOeP7PMkuaL7U/fPN5+5a98g+W0E+30+sn20cWPeRXMQvuXv/EP2r/497/Vluj0BhP0u2laYoH0 +kHviRVcpHMLEuuWDPLgI9ad2ntG5Slh2RAmq5Sp+o5zkrOaBN6kvQ6lqVy0duuKoTLsacBVLpSM DNVR/EgtSCfl/DyTr3Gj8ie9Spo7vAQXaRQQKT9GAelCbv7yJ3wbYjBI44SBHjukC8zkMivkJnUO 3NhJkhYHylzC58Zte9jpzMxEW+WZ8xWWKZ84vthOr662JZYZ85Qsz4ztt3U6q+tnzrSZRWdo6xlf H2E6YMj/0tXb7Z2fvNvep8N7mQ7v/VsXaagttOk5XlF0itl4/E67FG/4Rc/+Kh873iAJHz5zZkz1 nvHHgZ8dnuXO0mJotXGZzpg8Y0d4ceofknke+B4dUzqizKQYSFxaLY+ZvSJnpISw1J6rArTD+/d5 btiBDujYpNHvqpjH0sAAyQTyGmVV3PLyarv62S0GYTZJn4gvS1dWd8QXY/HQrx2ABTuIrnBWr6Mn 9aVnwFe1G0wfbEf7Q1/xaWViHtL60WOoMI8eGYKJ6J28VmnPLES4JmgN2hi8Ch9ns+0kLAvYVqm2 IlSBOAOa5MvqOYorOw9l7T1xWQ8rPH1HHNJTK61IC1hxCCtFgcE5sPW7SgO/NitRlu62EI2Ypux6 fSz/ZQfVfvHd9uq14r1261HaFGfJTFk7kKsnKmcnLCACm8pCzPi66CMj8tRv4fY7bQzyR2fAhNrw aZwwb49dJCeP8O3c1mC+8lZ4RY+y65CRQAAJo2TApfEHWTrzJt9lA+DGxiyX9g3p/HPNV6iBIvyD XNjlMoNXfefmTqmUfZFDeMHCr3Qf8gy97fOix3aFR+gnq/WaF9IORfFj834+finv6Cpyx55RYWJc IIX92JGxKQMZwIyHkF+Ywi99klfbQK517Q1yIq8s9ebctjpZUsY3Iur/6RtQQlvVPlwFJ01ms+2k f9lZtxJV5tLvKgpjLlmpk10F40CFtvSEmENegEkdYGL3afOoENLiV9JY5AWPnW8H47U5J/7ckM+B AttepgEsakzb0fjFx4pce9MP9RVFgYRiD8pPBA70BSu440+AsU2Ueif+612KIgdjbfB4bXnKJO6S mLcHcK3dCdt0sTkwoY718RoIRSPAlb4ZHlMpG9U2wcPHdpT7IhmPKO9zIiAhaAgwhgGycnwNHmAy ijBVopzE8Uh3GZ9sKD1lIxvmN61URwqEGrCcxvZl7uaKYMhhGYOaCpTxwIAZBawhuCxYh3F0QCFP UCkGN0Yoxi5MDVtZBTdOHAoyzCNEYddIbDZqUHDw43v2LGNuO/Yj43yIm1GAguGzTefX91tOsTTQ 51V9TYvyseHsM6mORCSwkFf6HEGe4N5UgjRyhWc3/VIBPaDWkkcbejgBDcOMCqtEGHaWxffXWVFC FniYpaOTXK6E0YLfpRHhGxwGejurzt4Y3KSxpEpZeUN+CfKmcq19Kitnm6wIMtIID3EGBUWm/Clf ltSlUOSFRE1SwcDUbMTZR8u0mwoW4oHn0K5kKScNBg0NFKLISp7SX5yV/Dqd5zb0/RVH2Yg0S7gy V9bFkzRGDyRIC5dHR+xjuNJea4Ok4tHkshUKKCBBW8noxEOSSHpn23NtkcyhSXiRqTT58Q63vG8A yH3plCrS+2Y74YlcWbovUu7FRzyVBwUWkMooAM3Ch2/ueVvhRwfIKvJMYoQZPR7JC0AGg7INfAma 875qZKv8PQz0yk+k2ph/ltdrgxNE2nMqMXKlcWSw5KOdSZn5/SQIQZ8lQ8Mgl8CXN7EEl/qDBq0Z me7R0KvXbtToI67T1taW0umdoCNoQ9en5KUfBiMjZZMgJg4+qWhoLrikV50dy1t5pIN4Q0dBP/Jj ALYRpe8pREVnA1VRK9rA5b48VCWZ0MYd0SCXCL7yWSirLEijSOAqM+m0MWoDxhkZ9wvIbDa8a/sl +QiK8/oDkuSEHvG6WtOZ3chVXsVPfHaTm+0daKOBO0qH0k12Fnjtwywb8ri80oavsfgh+G9tPmrT xIjZceJtYi7vLKWhMUdHeIXdaVdX55kRnsxrjHyGcYKKbgoYs1OL7enSYuTipj2+I3SPRvVjcD92 h8yRXWZ4WY7J7OUO7+N8xAY5bkb2gFkoO7o+Q+ig6fTydFuYn8lzPo9YDuUs8YGxRF7xtdiYgh+O 1DnIOLZjLs5jX8pUdQ33tGlNQX+0AozOBjgZuCBvXCJwjQ/KFvukXgk84HTf4k7p7RkZsVN1a95J lnPrs8Ycn6uXpDTCpZ4s0Qy/0uboujhu3XzIK3AYcODVUD9889289/n1V84j+0V2Bl5tN65fY5nz C+3f/rNfar/1X7/bvvbaC4nDWVqaWGu8KFuT7sQ95OVgps81+by1r5PQRiGMj3YOz8hEOiRdv3Yg idJ8SbtERiAlFQuQIAyqGXg0M1cYoTCS3wHn5OIrfuuVuAqQvz1ZeSZZ5MIzRgmHc+usxACKqWOz mIer8OOMpsZvg2WGVQgz7Cg+N7/ANR1fPvpDNqbBpn3Vjx3jfQaQdrC5aWZ911mqvMT7c1fmxtpL dJLX13imHTkeMlizxGzvuZdZxszggjOhMwygGQ99XdfFi5fbW2+93370zvvtxrWLDKKNoqOVdvr8 V7DfeiVGeCHmhBfiXWKksuWjoTgYJd/a4j7P3BnLbEO4ecvnB96o+OnE8zxb2lbqwxlqY7KNODea cvf6Sld3CsiYOM07gY1n2rv6TD0iQmSyTwzzNSD6wx6d//IJbkHnrjGabC7Ptu2yZwykEeurjKJb 9J26SFwYgDYWvaAwigW/aeoPqrgHAZVcdoR+rUP82E6ybSGA2IFWxbkDBbEwznuHy3SPjsM2p/bR 03MPfpS7aX4QWeq11NeQER2Qrh9qVyUO8kGsf+rGtNgpcFIfIGPrguQlreIEeNVprvFdyiuO6hxY P0mnMgZ/aFH+ldZps7FgXeZh3WB6yuh3ACA7pi3e4ToEFG+ZaBg6x9JqjAkxlBG3bTJSA1d/8giH 4b1wxQ7Ny8fBEHNoP5BVsiGlH+KITEwwq3xp24C2IzaOvaWtIK2JlWSRX/IelbMs+U0ThwKRZ4+j WCx+0xQmcLTbtNngTzuw7lphGb+bzAGpsxwYX+xLfNBY0o18feuA18J3pjJ7G8gvxGYwRFqTH1qg LW0a7wuGIzGQ30y+kRZbIX/xDT7LeJ8y1Z7hnHymlb2od4HBL3ltLw3YLYQvuGqNjqSv4yF+SYNy MfYlvlOybFkotB/o4NqOEH/2SxA65ySAU56kLciTR0f1kUJ14F5Etku055oMi9WEWPEKR1yZORUW 12UOdmRdEWZ/iJgyskf956vzvKv0yrfojXXG+dUPqZNwf3+FL1nWZRVnjPHIBVqUS9pUCE3aw4dG xIdb5BeP9IkM3hVn7nHf6+TBfmhCAAk+PT+GHTG4Sdmn3JhiVaCdWa/tawWu5fCNPK8MPCdpREWf EhIgzEyyl6AQQcuITlT3rPjBGIWYNc6MxaQBLCQAptfNuRUCV2lgRsnAyYvpLZ9AAChwiuuAxqjc 6Ohy7cPW8p4OpXIhn3j9Cj3SGycnicDpLYUmHZniNkVYQFHA3OVTuFxOLH5BpqMJXgNmEFoCa3ZX NYUuXDNOItg91rC7LC/BlmUDMXZDNnW2wreRqwAnMBwNRC0dWlG77Ern55NRhwJJQxUFMfNmmT4K NIHMfKegrxdJcIduHdJO9D74HdFRRwnk0QvPA5LBXWKps6ENY4O3OC/54tz5RV7miTw0mTJO6QMR +R1NNGAq7JDE3hk23JEDvNX2/+pEXVvp65o16mSAsRNh5ZURZEFAZJxfmWgWODBSN8RHv4pVWutQ dpxRRv1Zefhx1Fk9Cddi/pitfykHZeQtHTk2gsxDC06Xe9CqHuKMKa89YF8Wjo6hj3T1l2Wo2F7g Bp6NHfBDexwyZSxmHmWFPUNf2RI4kJ88pXM2wBdHOSh65Nxr+fLXcp4W8+VzMiptxgJFx8VR3t5o 1/4QZehMgxBYWTFBOQNNKlnoULrkLNkI03vIQpDSJG/mVX6SJj3y1vlTB6nwzGAeYKi/EfCbVzrc kdwjwYx7Vgp6mqRHJ0d4lYOIpYHy5uPSpbyzzDQ6Eq6+Dg932okVnrej0zvKMKgunsYImMNbaJGH +uhz8lUNMNOwTWmDcwOv5W1MT3IipQf7NmblFxrQq0t/7JQqETeoU45pmJYzkbf4kzZP0/igbOwp PAJDm0MW2omVjQNzdhZtnO8JWzmJQcFwFosNH15Ks+lg0hQVXDLXD4R602yUZ7CPODBOReSs1xQd Ap8FE6KutMOOzlniSV55sFbexp82QDzh80RjZOK9eOQm3txi2TTv9aXzusaOzSt0GpZ41+/a8mxb pOPgMuppBhxmiFEzk9g1M+4uNz1gkGx7hyXMeccosxdPd9v4PK9JYRnp/pOJLDO7x6qYx9vs3viA WWL0OiscdDw7d9DubjzmeWE6zvz1xpks6l/axJENokOZ9s/72qr3bNAYk9QzGfjjKAD8qJeCpdTM Uf4xxAJu2ljwCMzgEArXfGwAWt6ZjwwemIb8cr8KlH6G/MJyt1BnSWMnZAx4gF1m6fL09ClmGbfb G2/8uJ3kOejjq4ttdW253eF9yI95DvM3/vnfad/73e+2R8T6CerV+DV49Dt51Bb9KBdH/xNXoMaB K4gNDxIenknXjuRD2yRDqPSVd5pubuSeF3pHSU+2PJSdKYIOQP2FNGUeeAPwgm0JjwGK+AZAxmrL ZVReycGLsSwxLb3y8s16npQBGZbwz2Fvbmgzv1DP66szZeEAqCsjdnlW1aX34sjrtmgrODhz8gzP 6vI+3dWl5bbOplFnWNGwQifxqe/ZwdZPv3y6nXvudJuadzDIBp2zFyz9/eTT9kffeaO99eYP6BA+ ZPXWajux/nz8wefnHTAuuVsX+6m6sUwO+cFWdVgd1EKWyCizMJGJ9YiD+i41dgMq5U/jU1lxnkF/ 4oPlAwg9WUVlgF0ZgoRcgeSXsHx9o3FqhIFud2SOXoht8XzoS9yBZjsTrjazs7my5o7uc+3td95p Y6wyOHHqZLvx2W3AQzyyzcy/Og4mvmULWIlr+oVMctf7Xec5p3wa+/Ci2qXbRnkavMkLIDLGnszj nxk55MVC2oJ+oiVUDOACuGJzoCD2Iy3iCh3WZJ0msuqn/uU9rDGL4LTtUPnFBsxArG/jR9mgOfQx 7ks7OFK/gK+4NYZAL//Fg6KhjOASkiht2QEGUTWyM/6nzQIcl2bKD//B5Qyavhu+ka2/adNw1zpd fNqc6Ylr/DoAb72SdgfopNc2XVCD3XTLFS2lo9SPoYwvD8mUhiFf9+WqL8Vlu9d8xBeUqoTFk844 7aHCpSA4j8KwPWABsHya/B6xmyDTDuh4miX08WsG9Sgi0hy4c8fmNVYgWIfVkVzD+c/2I2/C3GKA NxNWwzvg9NWK9QgB8Kj/SFYmHMlNPWWgUe2XBQhT/7BNqAz4TjtP1tOhkhcvlAmHttX7Hb1vMurk YWygfEzdWubegwfQQptbOVNcOmoCApzmERfp2kviDSncQabCKbqRcuyEyAEs7MQ7lHGlEKU4N69x Qni2YYkd0CK14rRDIX+Wi91qkyTbB1F/NVhnvLGt1VB8ZgAAIABJREFU9IxOz2uwVSDAopy0CVTS xZF0bnstP/Ed7Kz6apYzjx8VIj/4Nm0YacwkoGncMq5MMPLvBCGhO7RZzt3gfTWbCKo/5aOjkgAM 4mPV4Q4ykAi9zgKrG0XhY0PSMUE+dcfYgFn4QLiM6yAy4XrspNsY1JBhQ+dQykGEANNhtIlNRvnO M0nkS8XAdSnTMhAPB92xZTwNUwjpgcDKxiDqTF+EDB2qxA0DKxDgVAQ9lWcHLbARqp1pRzo8pEti vKfiVQCUMepBBcKGDjZSfHaZpNCs8mqGG+ma1zJ+uO8S5bwnEd6thCdtTHIc0tGLUgfH0OHMbyDR kKTBBq+zs7wlwFoyhry7WxW4MoCLLFxyicI8Sw/nmR2wMpdgK3dJ8UF/g6mVqPj82IDUKA5xdvP6 nrzIDbn4/J/mXYZS/GsIKBOemFWG3sgf+nZtSCG3dMIG2MpEA7FxP8JSFYrpIxwyAX6d0QzQb7L0 OILtUjQdzcqvZtEsQ2Hg5z2KqCbyCSk2atRVlBgd6YDJALwRvD4BHgxJD6bSp/j6URQJhb/AEx/3 0a0Vs+fqIUU8Hxoa6TwaLNBTHNV74oBA83jfsZ1UAAEDHcA5cuohTbxWIFZYjnTbIA99IuRjh1hh KsPCLY9lx2bJrtURAfIAfgZNzECa8nlWiQuPZO0KWAIUD0lmhUeCqI5HevktfHCJqCuoYT+Eg+hZ feuX8S7SDQLl15KsHCzDF+cGHOUPdDU50Mg58pHvwCGv/qhNKY8KpCRKH8FGCqOLobzpqThpGKgb Z3Weu3CaTu8+S/zuwuN4W6IBO4qtagNWPAJQlBQNraUXsCGMyEFcRx8wkg9iq4KSAu5l0z3S3N14 uN2O0RmGcvJOhZc9Zi0dGZUul30ZC/VrK5bM8lEeKjiXV/KRVy0oG2OPo7bO8Prsnu8hTiUMbuXr 2EBskfxlk5+n2TT1DWXgFks/uk6UpUubJwn4xlBhGsNSsVMmswLI6akjxAFjDIculKlWd3iWSftF pMQA5ebz3b7X92m7ybOMTy89aONT7KrJ4Psys7OrayvsdLvUziwy60a8mWLp6CSN56kZn6mcRUer 8OrziezYyDOIj5iB23y8xfLm/bZwmiXOwN7dnef5w512/Ta73bLjrfScYIbZjs49llsesiza2OOO m+pLf4wf8qsNGvmVvQWNbxlYIL13kJWZ+lCeyk29qutn8hvucacaidwxHg3yEZt26yevpEGm2rUw PTzX1urChir4KJzy0sotG6Y4f/BTAFsQV2Pme49lzg/aKy8st8sXL7f33ltrC3/p63m+8uSpM+3q jc/ayy+91P7df/jX7V/9x//cvvbl56mb9DX4ZHmer3xw0CT4QZQGNfClTX8MkyHNL3nmL7RBQfJD E9fWzblHWvmIhYET2SlLrzkAE778yrV+IFs1e6LtJMYKR7nAvxqyIFKsRllgejWUU57Aix7x5+iQ x4js4C4uzvDhnbh0dLXrDk0/2mY11fY2z+i5KgM7Sr3PLKo7lRtHlxZ4TdfZ423lOLsus4nVaepO P1N0qvcZkJmfX24XXr3Q5k/O8ejPOIMuDqoxs/vxNTq7P2jf+94f4SM87764yjt6z8R3IgZ4kyMP /Ul3tO50oNrDxxMOWMZvJ3QPuzfuO3usPKy3nSGxLnQVj5u8OMPhn8z5CJWxIf7MdWTNDf1Yy1XP xhL92V2TY+Nk2s8gE11mzp1tzT4Ayhm6HAi3mzc5M0tn17jAgBj4pdkZXQIKM8h7bd4lflzXYIo+ pcUMhzxry/yl08WddLARiLYcfyBPlEpafC1Fn+XXD22vCVV+7eQlBgfJAOMZxqrnuFeWKV+dGM8r dUAROcQ2sB8o18WALQ8WwtdIMD20w7fn1bbQOhU0/5TJwBR8lL9b1rvkFZbsIStlT3gonCbmEAY0 +RnSHEARh3mLXjKKB6YBZ/bITgieV3lge8G/cAQVmpLB8+JdvXuYR1oDnzK6W6oH7qWOJ7/wyUke 79cVp7nfHz2qTENe4BV86zc0RZnQRBktfDSyQIcgUzrqPjy7irPDp87VLpQ6BGZChDMO6IfAyIT0 SqpfbcEkYdgeXlhgxcvSCraPr0QOlf2Lfctn8drzP9khZlAH2YsJ7bQfE59ihOYug7cvkAEiCRav AAa+zOMbEMzqoxS2zYs4dYV9D5d2erUVn4fvOpOvtL+jL3lFOrZdlLfK4V+dWV8e+JgjsKJb5Ze/ Tgu/Cgr5p160EhRv7Je4Dwy7OPpvJgSYFEj1iG88dRKK9LJJ81R7Mn5BnNJnvCe8cojiK/0jErPp qkNzlNvNqpMgVUKB66/xp+wFPWumfhyM0x6kqwImbTdsR7nWf8mZ+rtvaidNllc09mPceFN7HSWG 6dZOsC0tLtLnsV2prPA3Bxep0tSJdtbboMIg2oYtG+2BTTY6KsCHMmwiIiVH2gBQ45/9ujGXxmrK 5IbJWmIqJEeYrfCq8YkAnNUDcTkPGPlXcXZeNRgDrcKtAMvD0OQ3GNtQq0YihICmNnEiI1RbrGKY ioAJvwCizdrQiYPJuOkelPHPq8wscW1Qskx1/mS0ApO8ZGMqytox6Uu3Y1zk75VN6CCPhuUIwDgB lJ8IUf4TSIf7koAAIgONl2ZmxG4DWpp0AmePdAwr6VCt5En3x9maKATeDgkCyl4unZ7fI+2ADq+b aGV0h8peng50GGVPo+HChefYGGWZxqLGXs5w794GsuKZPxryysQKUePQSRwBlodxjGLGipF3TE4o d7xHh9rHEW0caYBqUxq9kY6nnqSR0fnWIYAW+7CD5jND6UAmP/eQuRVuZoWhwcrTjp8jSC7tcLvz jHKRX1x9llSDIHt4Uy46kUc13kue0uroYa8UlEkMB5JjDdxTitKvHaejLxAB50f6+Pfjtb8wKkx1 m6DuTQ5lNZhTMidvYFu+8sRugJ3nQk0CTvRrsBsQVWMCMpGby/OkLYMVlAsO+QF4gid3y+IG3MhR 0qUro6b8ei53tSoBm+d+dCgvOhW0JY83PEiPo3OZoCSdpumjnqJjfVJe7GBLnzoTn+f+a98GpHQw tJfP4SnLRtrwNwyWApf82Isxwvuhn3IecIYtxpuxcZ9bARfBaXqKV3swwHJt/0ZbZBR4jo6VI4pB VWLNufwp52wuAd2pZMMJsAfeg4ivDBiQFr8lbx3wKVAZw+cUYEZZyZdnXCdcbmUZfNBOa2RDNq+x N2OJAxspT7xzhNmNvnxkdZsdjF1i5UoHfdmjV3jiKe4HXUurGWBHjarDbvOmWTr2Dq2uMPE57Ixw 2sh1sA546kP/iR6x18Rv8rsTcKDji9Eb9Igstk45O1SHB2KgQb3jDLeyMj4bx8bg4ZD9C3bax9du sWLlRjs+e5BXvSyzIdMyFdEyO+GuLE+1+el6B/E0y0Wnp+faCjLaYemzL5x/uPmwbfIKiQmWVS/w jt+lRV7bc3qZ16jstKs3b1CWDsLEPLPCu22LmV938q5KvuQrb8rejp/yGUvskQ3sp0QL1coALhCA n8gk0lCnSDNpyZWORdkHdpD8wjFGOJIMQAMeBeLb2pdCAX5Piw0F33AHxMo4fqIi+UgLhpKQpG2x yqp9dvsOMpttJ3k1zps/eL+dPXuhXTi/zhLnFV57cwc5b7Rv/vxL7dd/4Xz71hvX2/On51kKzjI9 /DLtHYEKl6PstpgPz1hJsIVRMiQRHswfXizlqV6XxEoYACZdcKIAT2LgkD8ZlQPAfFetOjBPycx6 gjSuE4MFkfLWdfps1TWRKeXM46NEPo60wPLuOTaZ0ibyjC62avvCWdy+mdo2caEarOVz7DyDv3vO gAx116lTK219fZ6BGTa3Y1n/cexxjQGZEV6rtcuS5dNnz7fzXz7L+6ZJA2cbmWyffnavvfHmW+3b /+f32ubDJ8yCPk/9WJ3V1HFDDPa1QsrZuk45+i5a33m9xQCGcnL2fwp7X5jgXb5Tq+RFvgRWIz6q D6/KWr3s88iSdWQGLxJ/bFcQW9BG10jVt8YbZCe+QY7rbPLjbMan164xAGB7i3iKnIRrw3CaRrn1 aTrRyH/GTi8rM4ShH1n3idu9C5Z4BMEO8R6+nnpEEybUS4MFKEIZqOZEvzNSpkHJr3FPbygvNKdH 1WFCiF2Y4i1gaB/pHHIpDEuX7ShX4pJp6LF8Ef8JSHOEmsEGHbBH/tbB3ocGz6t+4jpJ3ACp7S2Q yk6ubd/ZZihopBUC4H/uGHgWZmg2Zsp3dEROZNfbJvIfWmMMBaPkJg4OysbO5d0E62zqT4BxzvWA WPnLu2WFl8Hw3CRfBF4xJwMglLXulLb4WGjwEj2QbFr+Qn7BkxQP70mGv5ZPGl+eSapEqkvZ4R/9 WoeiF/JqA9b1FK575iOPjJjXo9ohRZfwLecRWOKkhBsxei90Cgv9aJO5jZx97v3k+um8rsjyoTVQ vuhXsJFZTyqcO2zstuPqoThk+VNve5lF6drOlSNlb0yK/rk2X3TP/QwUANn4NgkftfSY+hM2wylM +JuYxsAX3A4yeBYLoyc7j+T1zTDaree2C8bYSHJ8hKW40KTspb7a9NpB2WDsPpRCl7FTpSM/nDl1 omU8bAN5xEfR6wiD+d7Txsqa+B3iWoxRNo70ouT4o4DtUEv5uFomN0iT5tQ/g+3p1+bpPhI7VSbk Va4ewsrKOeniwrrD/Gk/2rIF96QbEDIIaX/QQ3uyPZONpSgzRifXlWsTDK5bR2T1H3hc9bvD4LlN GXHYgfcNF5Y3ZmYQH/pcnSut2pj2Eb8mjVuDDdguReak2b8b0xiKfhutKqqMAw4oA9E6NHmyfDUE 06lEUArP/M6UxoABqBhLUA6+EMBg2BEWsloy58LRQRTgDpWlxOeuwiSNQiFWI3A0olRctAknG0IB cxIBKlhHg3XcMD5wIl4FHPqgvUAWncL0kNoonkuDzf6TPeia5MMsp3icTSVvKn/u11p1RyfcWMeO IIGWitpzjyxL4PdZp5c0G1aRi9VjCd7O3xjKTAdEwcOnMrax64y0o4CmlU0WrQrETTt8TjDylKFA ZGkjz9vd4l2C0qWTuMuzio0ekLOVkMu0fM7YWTRHprO0WlETLGz0KifzqxNj1yg95gSS2AZOS1md Kq9biQUidxqsvSFuQzUVJkRnUIPrCmryUbwYqmKo6ExYadyjBZ03lYy9M/BoDX0zG+3B3DERbkij hu+RQG1e5QtMYbh8PcED8ZRtFB0Uiw3oEPJofh1TW48d0whGCGCKuuoXeCLWliBWgKqBc8txaxhl Km5IED+p4pdnZ4LMrmwzk8dFlo9Q2AaA5axkPy8noYYXqYI2iM39NGS4VC5WJBIitgo+RY9pCU6S KW7wKL1U5J1u6IJSoYcdhRI280U5rsNvchQcC2im9SX7EAI88ctjtMFv0W55zhQQh1FCKVSApQTJ iRxm9z6R6N79+2338SM6RycG2SEZ7FI61BWPpNKgKbotFhsAvvc916b8rcN0z8SvDJUB5HJfnXjk OvCUAvmUsz/8iUV/GLEFpe+aAtFCU3fJiNCdldrgBey37t3lWUMGjvC5Gnwjv/AoLn2KodCaQHEh eJ+LpCdD4fZbfn0PsZvRuN+AHV5jUXQtFYFRshFWZI8+MtBjLSROPsZE6a5KwZzwDSzjmZW98U76 jOPpYG5bOR9mUM4l4W4Qd2tvvN15sI3cHvEc73Ua3CM8b82rjViue4KBtwVfGcPS5xkqKp+vnGEW eIHngZ25f8Rs7n02GJkY22sneHZ4jR1wT7F8+pPrN9rVuw+ZMYZHZtwe3N9k4y6WlkOPgwqalp14 abURmU5QZNV5Nk0bGOQJP+pYmfYOb/jiWu3FQcwKr8Zp5aRMPJSTtqj92OgZ1JO8XhmfCrYKGPBX 0ZT3q0pxPxfQAlYiudnb5U/vtKX5M+x8vdvefutdltEuM9vL5mI8h/rBRxfb669+mWXOf7996wf/ CfthINOWR+xeuNg10NB+6BKD9JW9Sm/dT3onHJkYD6TpiG7LJbFTSgYLKefcq3qS05QJEuApS2WS GJU6pOK/ctf/s2oLG0F0meGyLtzLe6F95pb6jZ0yff/t4jxLbRfn8zytnTU7um7utImN7PAOXH1K u9MlrB+s22xYpm5lioXat62yKdvZ0yxf5jn0ibEpOrxz7fwJbI/O3iFwtJfnXnuJ5czn2viCjwCw FHj3Sfvxj95vv/8H322fXr7YFpdPs7QSesFiY1KRWV/RSoFxr7A9mLETvssAjpuzzdPJPc6rhOZ5 FZg7qrvkTttJzIHfrPCirNVhljhrT/oWdfQOAxgbj3jkAJ88xnt2bSO5m3tm6pGtG8S53FoY+qo8 7/Fe7C+99lUGiubbp+wg/XjH1xnxaADPONtRr846esGGNx89im/UoH7JzZmkg4Mdls/TCYAubeQR jyJsg8fOl0diN7/WUda0DlRoCZm4UAyUi2yO7FwrUV6kwp8/up71EVTTUOWiDAleUaIXkaen3lCv aJZ8XhmDKZF7iY/gqfqMfI7SczOryfQ9ZGn9RY7ADrShfEEuusrfLco19/UbsVTsqLTEBiAlHbr0 bW05JPIlfdJuybQbnNkiTXkJU53HLoe85rSs/AQGpSlKGesZdE7Z8OdNiYWNah8CE9wOdlgvqyN9 VduzvLSbPVKKPKWrjuCS/899bJd7FPUDPchNmOaDmMDCykJn9ksxhfja+YrWyB+8A2zJCRUBIY/K aIDJnfgQNmsbWz1V3YiciBXCkx41l/Y8V9qs7dpFN5PL87zck76f+YAwifOD7Nw88CE2buzIKlBg KsuQz6/xK20n8EQvXPs35IgNeN9DctSLZmiMyoAUsUW7thOpqHtfIziCJCX5Qgb2c4QMXtvDDpRF PwaI0enEG21ImzLmOZiu3CJbWQK/NOQRLW2kWAQmksxN7gNfuLYJjvFaM2VotS8p0hc7pqC6UkTd 3xNjyWNOcVQbU8heEAkEYH4+ysfvbkPVdlOb8AgvNr+ViRHA+tT8XvkIie9K9/GoPGpBfeuA2xyd 2HE36gSx5V2xkhVr2H/xiy9Q3hnHBWJfNilm0EAdpQ1De8zJOVwLTPoWdHsuzRzp3wy67rxJV3gC hrhcQaNvya/90gxt6oiCFBq6QEkwE6cv4QkggiLNBorCScO9KAli80iHkIIQcKUr4ZII/FSmKaOo KjCL1pIyYSPPsgpUYDX6ykwEiaarADd5CmAN0UrDvBzV8NX4VIYIrQyGezQmMnICDA/tMEEaKSUp Do3cMag8b2CnRFyDsakAhStcQTstv0+nr3YMc9QaZ6GyU6hugGJF54YbGTCQXATmx0amcI8a4NA1 wciuBuaIdw9+yU+5BFEQOgI1znNC6czEeKCP3gAkhWbvxwANovC3SwdeOY0wG2Xnx/XzLO7GuHgt gjwLk3w28B2JlC9hxFGtzMhTHWGDiY1nOs0YjzaRTUYGIfpsjRvX2PCAQXCiRwwsgQJ8vjvzwPXp HNwJfxqgON1SPBUTMDMzZZ7u3KSVvaADO3kq38NfPgnYXsYUhKtM5YX7eKXyTImA0dy1NmzEPJaB VvPIszS4SYz8cqfKWn7AY0dEZ9WWSh/aKFYOIOGpUxKqLN/qKNiTZjby4YTpiMCXyckNHeo7gYtf /6CuYCsrU9ISpnygl49CTg6XeUmjARnCkmYAVxWKr/MI1ZGTeOIP3JNuZ27NG5sDBsmBJ4/y7ADL IbOxaRzSaOMmaAjm6E5arRQsJA3VQQAANB1Gd5WujFLxgcu4EZlS3o1m9G0fA9hg1mvB1xKxtJbs iQGHpYqCL1jljZ6kq9OpzSpH75WEBpyklczLV0EbOMaePNMvTf4ppxJs5Bv6AF6yg1b1mmttBlj6 ChhjM8xkarOzvJd1a+uA97DeYaWG+hlwm19mlBm/3V5M0u6Vn+ce4nOgaoLGuitB3FQqz5mTLr6i wcwl5z5z4C3hhz/PyTiArDSTOAo/csqVmIcKlcx9EyOJ8M+GeN9tdAt/sPLSLR5TCY0xE+z7ey9d fkyH9zYzd8y48e7k9RM8r8qMpjObM7xWZpKGurvkLqwu5XmrnYdbvP5gpy0xAzrDc5bnzp5uV67d bZ9d3+IFwcuNm8wQcw6B2mW4hp/Yf5hMUuSFCZTcEJ7VrXLV3tzU50g+8oly5UcbMaZX3K44Z6yK vXLfwbw+8q5tKsuSojIafF5FpfMifeCCztgxyblFmdQV3gsMYiSDpxubD9q1GwvtuXML7eJHH7aX Lp1rr375pcx0LM4ttHt379HxPd9+82//hfbbv/dGe+7M8SwJT4yHhTQngGn8PjpCX13ZIc7SfSiW d+1Xm04H3nISF63L1wAD4o1F1YCWbmzRW34pK+OynVzOLW4+z9N4qozYQ68bmBWgDjxwp08aJZMT T+mY8k5cZh+dzZ1l1YZ1m427HZbNbTIQspOBW+pFaR7kKNjEGn6NRaBLHWOHbnF+qp077qu4mCmg QbXG+z3XmeF1R/FdlkI78/niV15ua+dODGXGeG76Xvved99s3//+H7f9xrPq62dLDPIjX+IVPbic MQ0PLKfuGzueO7veLvDxNUKTdHYRB5lpZWTGtRqtT6Et9TbxTjlZXzuTkF9azXbkYBkWseJ9VlbQ ntihsfeYTnUetQKe+3QoV1fQSdfG/Rtc82gA6Tducd4moZ5d0VkSqrikT3ewvpqgjeG1DX4b2+k8 +4uf5lWLhi7pgTj1qddLZ8UCz7Vj7YK6HvaEj3f4k3veTx6ua9CW+ktaNX5yGYclJnbEdezeW8IQ EYc61p6Cgfx5pEcH5tA79UNzShuFAlM5aIvGWxsoods8KExZxl9JrXoODNCUDmboAeYAT5vyqOdl i9bcJE2c+oDQxaV8nslD45AcckGf9PROeWijFAkUA2/YDNMkmr9swSzynsa4wdNb/lUBfpXRMzkJ V9/t5So+wbnwSIz2uK+0lHfQcmWR3n6wjk0Hi/vdV4UbvYiXvJbFXGMX4VeYyg8c5gt/yt18A/zC Jc7hPmeCc5DIk9TtlLVOskz0kQzSS5wFfg02ApcBFgfAfMTBQ5xdJkn4c79KvzJeZ8eyumibDRSV noMKWamB3vRV+cmAnzcdQOW+5mft66FVRHvyiz5tj6iX7CeQCS9rSvJSCMjxl8AUO22fkr2QSheR dUCrTyBTruxYOnk04sDHfEizroW2HOT33LZUeAL/CLFllHzCcHVqOvPgSFlota6xZ66YbZcaX71A LPBYfAW3+YAan+V+fFb6or/yZfUmqcXm4FdKhnzqz004R2j7qSfjvrOstoP0CSe8jA3GaR+tsK1g 38nXpTmD6+MZe1N7DDgSv8Djq/U2NniUijaOb6vQ1HyMR76B2CZ4s8QsbcBdHsuQVifmfD/wPvq0 4+pRdjr4lnKTePgZV3eeQKd/sX3gQnLoNX44UKBIrDfH0kinkBVBnBlgKitCZGzS2RgJNHgZXBMk uHY5pJtNuLxmyDwYmhvDMOoIQRIgAxKhA3AVAQIqRiGp6TBF0CgihgJx3ueTzhCEyKwMxoigU+bM m0z8WPlrHB49IImvOr3Qj6ANQilP/pizcC0APEdCLB87wTksJ/g0iMCbXc3kgRLeU1nKR2Wno0wj +JANNKyAxgEyTgNgd5SlylRyfUZBusRhRQC5SXcpMtTT4WVnSpc1R/ZRhJQh9xqJtzF4oDNQNjuT hXIDkbOIPritKuEfPuTHHabVmUZo48lgpyyd7VXmGZkGtnKw4ve5RZ99GmF3VmVph96NM9RfBWQ7 vtKO8WCA0lO7LFsBsz04m+I46+OgxSSOoUzk0dcw2MhIQ13hZsdJnBmCuI2MDQyccE/DV6bSFCbU DzLLDFUo4V7yl2Gb2TPhRM+RrdfCwfs5wjt5xBN9YsXi45KDnDhvrwxiY+hPq4i9kqMGKaCM4IPm C786AkcCYqAob1LQDZlyOMCio6k/j9CnQAbcwvdce9HWE/z5Fab3QqNKGw7PHEChFIewFRmp5PU8 oNWnTuwFR1Uo3Mcm4tsDzmdQlb8+NdAZmCk6mJHS9YAeTYsAKL3yFDqwATH5qcqv4D0LzhX841vl msCreKA+THJZ8Nb2Jks/z1RARfU2bgQqFnUh7WGSH4/SHfngSzgKy3wlDuUhRZb3i2/+rfCy8ZNO QV5t3DPpqXjBGXl7oyKjpwFjnLFSoTyyUhbahCjGkafPu05NHCOYb7X7vKc2eg0twMUG0okDv9YY fYFDkuxQVYWhv0zgPz575z3LiJNYQRl1KYzyCS4H+nOLc23OvPIUUXiDAxThJ6Lgwl9ty3R+is7Y C5AtP2TUxjJIxj1npXzcwpFvB5UmoG+C0eXJCTboY/nkXWayPrt5t128dBf6D9vJk4vtzKlTWRK9 xPPAM3Tip+mkPOHZzaWVLTa3esjM7kYbow5Z+hIbCK3Oto8/ecDMNu9TZbb4zj1m/KlPnH2SUkjI Bh2SVjLghIuyaxksntRJxGISsusVpEud3JNBnmMTnvQy+hjgzK/0rNe0BWVDov+5TuPYfPoOKX2J puVim9CTuGFw8T42Yj1JUw97nmofM2O3doIZXmL3n739DjI6xUweuwqfPtN+8tN36fQeb7/6d38h nV5jjHXHUzdkkVYhikdaBP+5Iw2f4HuWaF7LSU94kUL9G5jWO952oMx8nsfW/cWG5NNOnA0SgRiv jKHJC+5wb750EHgenFnIm9dvslsyO4HzbuhTp87yvlkGOZxl1F4p42zJBrP9275aiAZQsQAt8OkM R5YQ6lsw6D19R1/w/BjyOs0gyoV1Nrma53l2BoVO8az5CmkMU7YDGpHWN6987YW2fJJ31mI/RvsP P7zU/uD3/7B98P6P2Q36XPa5qD04qP8JYs62Wrf5jJn1nhtU2knMZmH4wSKz01P4onLc5Tlr6+8x BlLzigsIq5g+PNoDRnWNc4AZCfEr/B0+j5ibxETTAAAgAElEQVRp3qI+v88S/sfb4gIeeOz8ZgAf Xm1HKdkxl9pzvc8u5wv4ygqvGNvZuMzk0IvYMrPjNjyh3Ve92Mm9detO9FcrynyNpIOwkIxS0xgF XgbWga7Py4tfyrdiY8WKlOF+4gLZuM3HLhYHN2NjBELjNwmxI4OCdq99+dcP4cbuYltaC4e3tWfK eyp96dCJgSzaoFVcDcojQ/jwEJu0ap826kMP7Y7apKfgcDc0mj++KR4ZClX4tlRKS1KSy5TEupKT iPmEZ2IoRU2XO9NzBrzQLFzP+Ys8ydPzBiVA5NFCiZ+ChR5BdVl12VR+dUFcGoKW9Bv3bTOkjqBc bxfZ9jH614SN0AaGQpI6sqzUFv3iEYbpHtbF1vH6rfIQvzK3zVHtAuICtAaEX6TnR4Fw5JFACjkY 42FdKGzjiTl6/Zt2jmX5SGXwc566BbVKxxRvGVgiRvRVB53uAP5CX2LkkN1qFLCiYpuBtMcKPINX dtI8lINtlUgM1Yjf0tJV9bhXpjFxZczzErj9TQvRQxBVeuJviSCwBiK4yVmEV/2PyBtg6raej5dY DuBnUglZFFbSNBnbn4M87RckK/rKa1GjO/MlY1BKpm+kcHJJYZddqQuv9TN0r8VkZI8kQXJLcfnx 8VEpMr5rc2kXCYsI1ulywN0JLt8Prx27aaaTYaGJji7gBxuzTqmObzqyxKo8o0tZH8N7xPvq3UR0 dBT6uQZbaJ70bRMMYOZVsUyi2Gcw/i0wgO6E2mNm7xWpnPht38F+T/wPnXqQHZsmB/0J+VGGthGU v4Vjj6Rn0lT7juGrA3BxThthIqMKvh/Ke94QqCOgCuwJHmIHpxu0IxACUxB4YxqBBkuSQlgI9pyy Gk85hsJGrFQ2SVcxptg5SWMPwgDgplRRqGUhgh8YQZkqC+LtgLlZgoY2Bl06bzGsSGROGnR0Sdf5 wgJQIgto1SkkrgKDHbngiBEUntDEfSe3DEiOXFjxuFTJzDVFfxBnOcYuZ460GEAchdShyZn386om K9ds7gS8p8Cp4BWNxjA0Ql91MImy3SgrNHPbAQORJTCCl5GJWhYCnGrkelsmcTbSxvlUfnTHuTKx 8ZcBB64zo2sOwDrDp0HbqjYvjyCZWAE9jXv9kQ48f5nBpnEgzl3eeyj/bjIiz+4kikr40PFFh6+/ 9nKbmKXhBmxHhRJUKRf9aRzDuQ0H+awd1dQ7YFWCeaRCGv3jJAGFclEs5bQ75WxAc47fvOmIyZPF SwwlGmBkVzuAGxy8l4EPLcSC/FohBHzsUSIqYCsXZ8MTPMkgHabJsPykE5u85eDSrv2lE0k5Wand U4UxBF/AS6IwKlCSRzzqkDLC77qN8wLPdKkiE2Urb41oAkk8uYX9FULyKitgmddyOgTn2kNsKpfV qLWsH31I1iovv/CXlQAGYRwpFQZ+WvqwTNFvcDS2SlsOYKShEXgC5PAW940B6bhw7YCRjTP96SGz gMJxljecQoh/aRzp5/4ZjwBnR9UKOyOywIncQngwRaZdrkn5nDz1kWKSH/UZ2y0ZWcbl0wPF+Kg2 oc0oNwe2htUANGZlqMs45SBIS3SjB/XXlxWF8cg+6gYWggpMQJAuzBmWBPu8o53nzLiWsMzAn74v PAiQd+U8pCVBUoDjn6q3hI3pNJa4F1u1CDBylx+yRWYp4D2DJEfvUBYOtQCcVC51v7C4q/whz+ti G+CxczZtp5bluu7yPLk70W7yWrf3L3/QlmZH2vNnV9oFZt/ciXvGHZxZkjrBxkNzS2xwdf8R7xm9 TweG9/9+41y78tn99vHFXToox+lI+/ojZ69oXGEjo/CYagic2ZgpSoIG+NL/jSGp2LDVzChgS/Fx 7qejJ3+wYZ2FBUdOGRjizPh0mGVUykY/jTjCX+woNoIngTOzqOImLTLmPJeUUR6WjagFoc8w8ym9 +zwX+ik75868cILnNO+2jy5fa9/4Kst+2XxphV1Mr12/3l7/0pn2m3/v59tv/84P2wvI7PEmnMFX 6jzwaW/CT33ISWgLdnAOeE1TT2Ys+rQdrQL686vfQDH2JN3WN3aoRhi0Dd0iMDfy88gsIL/KP/Zl XhrqLkff4L2yF1483r75t34OHa9jB9PYBXrLztx0+Ojo5h26dPoyYA6A2DFV/Q6rn+ysQRJy4l+f ggAHSW0U5vWE5F/EVp5bn2EZva8xmmwnWTa/yEyAevQxn2U6wC+//mKbZ5nzKPb1hIfr//SHf9b+ 8A/+NzMFB22VHZndnOaAShwRBo+4t1hut4ttO+ugjfX6JA0rHMTn0t//8Er74EPsjbgzhp9aj6b+ BE4kOvikso7c4UE52RjdIWbtCJ9Or3sXuMOzpVLZRhfEPTr8ie/kq7aW7QI632Rdgs+v/dyX2j/+ J/8mS7N9xcn1GzfpDK+0V197ve1fvtJu3/oxqwVWYxNuUmXDVFvWX1yRcDRYgVy1D+0zjUDIKL1W LNZPvKfM/S1jAo50GttxnCRji7EpOj7KyyXN3T7kn//hkFfKI7c0zIVLim0Y6VAOlq1z6TLN+0UX wENHwTSuItPcF4cffILrqkeqsL5hnRmflmbv59sz8gw4uMghnNz2CsOo9hW/EFNZhcEZ2ZRnBjiV re1ECfYDmzVRY3nxFKXWKTpL7I0YMMpgiXIKKuxWnQefJYDpEZ8OfKhGMMo5JbBF+TB2lbOY11Pg k3Tk45xXvWx051xZUM46M3qHvtwBXUiFxOLDVD4Qq75tC2qDwpI06c4gO/QY633cpeOM3wBfgHaC 48PA0JYr1igX+TGLnacaOJljQGfBpfrcC618Kb0vdigvOSt5lhGxMon32T9mAzsFpSxZK5l6wQFu 6bI9Zol8OPdQZ6pRGNKiPaoP5W87KjZO3KDlTiZojd4G25Riyyvjz8PiPIByb9ATSITtR+X1eknc JolTmiXGtMQE4UDmgf0iDmVoPnWSGGpB4RqnQzjdJ+TrYFunSenafqMUpAOHrGa376VfOoOqChLX iG+pZ328T95px08ygWV/jp6P3NOnUffWx9iKnd7Bz9R3tIJ8nOiiHwtsPyKTZSgCjnQ6oE/gzWod Y6mzxPqscVf6nTidJeb7SOlTJ1Kpl4Qhi9brXtQKKO1J2IP8+VWGoTf9AtvCg4z4yWOF/Grj0l5d ZGSggafTCmDDjIYfgiI9daBSKlB2x1SICZpqBcJUmE4TfFCqYWWpMgjt6NlJsjM7hhNYRDhSl+Iq H8YTvMnfA1OclmuVo9K5o/0V8+Q3GCSoiNSDTAkaWpD5AB6jQpm+x0xnzVJUcPuMq8Sax78RRiPk 2Q2ldFgDTgyRvIAK/fqMDlENSh2+HE0XcIRozwaUS5ATcCQPGQCvZguVBzTTgcyGB4EaFoBJZ5nK y/sGcY/x8aFjhUI1Zg3FXnjkpexMVfGcK+daeqyBaVDyVh0miqbjPcLsQTpQgE/AFi7G1Wdt44CU 8VkEO7rK1eXanosrnZA0hJ09rmUMLv+UFPXUn02IDSgjaMs5eJRvDnXCH7cC39EoKxN14ECCD7Vl 6WysVn1YcWDkFMhsm7gAlADFb61QUAdoQKfvdhs9qUs+2lZ0aEmOwKgyGQlUyWrbPJzbYFBvNqo9 Yov8JpvXJg5HgrwpgMhMADIThgkFg+sYbqV3WBY3n7YpDBQb/vqro46Cn3QArmzUUhzwWEu6sOnA 5j5wwteQlwKRc7IDoHxWu5K2gifeeq5Y65Ie73q/rs1nifJ9r7Q1JCUuzs2vZuWzKhZLW0L4fnMV nWrjyqjKRD4W5nCp44MH91gee5yGMwv5GPWLDiibyj01frICU5uqcupZDxWR512uJfvK379zT3xF VDoveYUYtNuxM1kbVJYpr61JruDRp5I03XzCEp9HbI1f4yAX2D/LdITFpQ1ziIWHutb+1IG2bXCf Jrjb2e3LbpWTupA741fFCyGRIu7EJPDzVwd05HTQmHbnPQiwlLe6TJQbIALbQinGlzzpn+qmbHWI PWYY8qccX6mAKatdSqXldth9+Z4bURHzjE2LbHS1uOwznGPce9w22FzvJx9cb6fPnGovP3+GGcEp nm8dZTfoWXQ9x+98u3H7Lp2QHTpOM21mfL19cuUhYmNkmWcnr9/ZoHPkwGJ1fE33iC44L9+DTypT ByycNavK0frGQQjy8x8f5zfyCl/aZck6stWS0JW7T6rvkmjJT34TP4zbOSqmau8CL/nUubelzU/u ERsP7MUQ2z+9+hkz4GwqdGyivf/ex+2586fbCWZHT68z2/se7/I9sd7+xi+/nk6vIfZY3y7UARVo UK+yE97RZz8Xp+7Y44D8Wic4QC0f1QCNpyT2a3Pp7BpTySMg7e1oNs0yolPLPJICOMq5DG2sfXTx Rnu4v9V+9S+/2s79tZfb6ePsknzhLM98328//ekn7MjNLt50GLfo+LrKKytjELqzm9aNWqYzqnY8 E/cA7oCvkp1h4GSCetN84zwLvIYdXVjhOfCFkbY0M5GNG+dsUaHXfWZeV06sMsP7SpvlNUWjPPe+ xcZpf/J//7h959vf5lniUwyuTGSJ4h6jJX58/t5Z5wPwK07tRb4jSM9LWnxzoIDM+itDZoF5r5Gp 0NYbocTN4dr6EaPB7uCOgEEVROdAXfmYkI1IZvO8p8KQgHHa59atY9VN2lj2NoaO6l/8pV/jcYmF dublV9o/PfNCu3brYfvOH/3PtnryOQaJ7rUf/vDNtsVz0O5QnQFV4KZtBC9ABAXSlC2lPfAon9Kg 7biRnX4Rew/PyB/bTlxTMBz51ggs55++Bh+5FiYiiR2qOBu1shbn0g61f5JJdAAuszOcJwv3jIHW X8HBd/kody2vPABlmnKyTGjn13aLB5RXmQJg5ion7CFH1QeVzzSzlt+UDIp/cCCrxDP0WqsglIvk GR8oRWHEFr0m1uuY6nagMzDJFB+T5sCzzUZ7jFikjCv2PosJ2pAkW7bTFBlIe1BKY9VnvTNWjAmf PJY1q/SZH1o6rT7WlTxhomKc16GjsmMjwggBETlQucx36hyBqrvoT11x2NnZp91pHVlqwC8G+u0z WCbtC2gyXfuwo2GdZoyOLJDNE/xkjkeB5nlFWfoNgf6zfhVNYCpeoX+T99UbZ0edObTDJK+ho/So qCIs8sqXVibPmhwkckUGMpmeHdHR3RMHrOSHPA5cJj4I2IO02JB+IJxKjR7Ea4ZuQ8o+hIYo8gNT 3oVhHU/xyEn8Hn1gNdaun5Bc9Z73+fCvTVleMNZtHm4i6ASldGZgGJo9tN9MXsCTNu6Apis/XXrs oyISEPuFzrwmFoTqUpzhkftZHUosO+R5M21zlPhsuzpPEfJLyyV+AYq0AyRPtl05ox04uSYMY4G2 5GC/5+ELfLaBjGE+JmZHd5MBb+3Gj4yqMzuqtsliy7Q1YnZw62N9wopAFAq0SHd4TVuxZKbc0/6S MAxU8Ywp81T4EGGDxiOGAVARxelFCkCFY82oglMRkEZxNeZ35YFzr3ze1nxpwApWPBaXvsDzx+dh 3QnVSlbBkD8MSJ8BwI6yIw9Fh/dsZEmGAGXQZUpRSPIUHQYNtZ6RL3E7SgjiLLOVAK7tqAkmSgBW de+AalnASEtoAK47qbr0zoayDSwDcS1PIqtCRVZ9AytHX9WMs8M23GwkuYty8kkK4G2K1LS9s6K1 xNHRkHQUlM8gA/uch3QGNCrfCSzvGqoeGTY49/mpeWZSNCBnwfUFR3k0JhlxxMuOcHRKumXT8fWU e095blN+pcOlX9JrGfnJ7DaIDCzVSIZydCLuaEongaFaRFg81YqBok9tpEOLLKtyET7loVt7Cq7c GyqhIVhCTegtSZhX/Ss3eVKhUS8wgQ8NdjSsABSNvOSLX/VfgaJsMXfED275TQNYwFxrC4d6V47S vfbbU46eLSbNZe3C6B2W6pjonPJkKC1aLBv/Il0G/FO30pklF17BW1UcxVcFT3MNvkWeNFLzy9cQ EHDABJ0a5JB2eA1scVmeo9DGPzQ8A1Hk4S1pQs8J6mbm2nviz5/yI9kc4s+SefKlswipVc4y0In8 5S+xQRqiCOnXdmumtHcWtD9jwyM2YzFgr/DMR2KXWNGlR+LG4M/Clq9BhOkg+qobG0dlF6XPZ3Kr 8r0SMUjXIfxAUqCVhMyObEC8IuGeS+nkAa5jv5ayiLrUziwtP32L/tge9CdekbF4Lb9yyc4sz+VN M2NVnd2CLafGkSc2Kozk4K7lVdizMQ088Q9XxyDeLmfFnGWmyksgEJPKh2tp9FpZyFcGfMwz5Ivu uef93pjMckv5RgnpJA6ZY8fqihmevEIHeN638/CE2BBRGeeIDdev32bZ5S1eSTTDIMYSHRU2pGAj rI1L91jCfKudXplqX3ntHMvYGeBgxs4NK6bp+N5nM7C7t263U8dnmAWYbpeu3GufXH3YRlmyeuvO gyx/T+MBpozTo6xKMq7pu7Ff+MoKAFnUdvwfeCcp5+7+qyzVrTEH6fHR1/jFrtWp1+RI+cAFn7/l K9oxf+ogZ9p71X/+Wij1JqcBz7WZ498k2Lh6tPWwLbDT9ZVPP2uXLl3ndT0vs6PlJMu+l9v1Wzfb V7/yUvtHf/1r7b//4ds8A3ySGUc2EEOZ2nD5UvESAqVBYji0G+USvHzVKiUHJl1eXfWmA69VZ1F3 AlOa41N0yLUv5abdaA/ae+zbWEFnd3f3adu6cqP92t/8cvu5r72YpcyivsGGZN//k+/yqirnVnh+ i99R6ro5B5PpxObxGTKuLBAnhSkfzhwcm0odJi5fweWIv3UVoazxpqLs3pkl0+zQvMjqj1WW+s7z +AxOT/2725aPr7ZXv/5Km+EZcvm7c/du+1+/9+32ztvvsxz4PJMJLKtj2f02M7p2XvfQvfFKG6pY AfHqCf/WEqJHTrp+bSQqb3VPJMx9tZ6yuY7YMRvky0BdDWqS5mA+JaiqkadtBBuV+BM0pCPMXeu/ 8AovadNQRiJSdxGHrV9usiHl93/4I2aK2QyO94/OzK5BD693YXDp9s07Ax+0JejIj9BwVWPG3LRr pJi4aPvFakw9ab/dz+VJPpVFxQYykeafDWItOQTRHohdQ2/aT+gu7SnLG4uQT3wy/mapkldKixfE xkF5075yKh7RRfxSwblGx6HvmOJVGrni8QYJVe9wDQ1Fqbbk4IWdVVod8JJ7gW8+c3Fo4/4UJFNC 84A5ZcgCTQXb+5mp5ddYYUlbpGmzONMEjcItSlOwZEjLpx8VKygZAkw1RlBC2mU+h2WhxXYcMhe+ 94u/3IIOeY318WudYB1lJxJcFP883VIKUaHrCIU8+YcRhBYLeJAe6WATufQn8KATPVnGeKLMrY97 U0ib9RlWY64fCaiYWTzJd5bmeslHXv3Ew8xIEWOUr6KxnWqeIK4TL36mIzxIOL61zV4Q2emXx2ts y0h/PcIBBmc2B/k7qGx/xfZI7g8+Xu1D6EMffuTlgDgjfcKSD/0nbSvOq62gvHWu0ivJydf1qBxl zet+xI/MmCaBusGeoCHtbzIpEsQUX6m2g2UDBNic0cs8pE0gffoTrEa+UAFfzLRSJ46w/4CDxFPY ie0DbSt9lMifzmZ4duZeHWsj0Ei8MDarbNjMYSRLHwtidVFXotEJgR9kZ7+J3/gFydqqsW7STf6U V9qXA5zU0U7g0WlG/vIxRcyf9lEUyu0HjmWnWPm0hI1g69QhwpE7ydLe4htc+KccMtCHXclDZBhZ UERakI92lz/5EQh4PbLJrfKjnDUjgnNRrvcLWRyNBJ+LMsBFody3AetOfyrNyrEA8kseiS1Fk5/7 Et4rbGdphJ/gCrMxHlMgwk/KDfCejaoWtWkAShuXflRKBW2Ek8YvNzEm0zwSkPnNjKqCoYzwdTyP olG0Kh4l4jxJTz6uB95qJIfpfirX7DyZxp8jS4RDKiKN0x0rrejiA1Z8kSWjY+xi4QPxyjXw5Bn4 OgskozyXAQ9BDIOAKut1jANDw4jSSIBwlZ4ghLG51KpXFMoyo0XIQqOaZydVGEun11Eq5ayzOhp9 iF56w3CUBrjv280D5NCj/jQCf+XXdw8qsH34EocUO4qk7SjXzK5yUX82ql3+Pd6moS0Rlnzy6yZa Plxe+ndEXNuw4iDDgE/ows1vp4GEOL3ppg1H2aVlq4A0e9tg7FEDEDiFAIdP9AwNyqwgafBwhLiV b4eeYA5vznx7WOllNH7A74/BhtIpKy0JAtLCv9WFHf00LsisbGLK4gi9ABjw6SNlp/JRdMUuvQSG VKWhwGX5nenAk4bwUTyQio6xN/mXIfECI7SmSMkicorz4+Okm0eb1E7zTLb3KGTHJ5SjI+Umj4Ye LdMAK0/iU4echrZUIup0EKS/woydk6ca40WXeLUV5W4AdGObjY2NtkYj1mWyCN0MkTHIRRE6tJ+u L8tDNrNyyMDGjZmUC4i7T4d28nlLm/eoCgZuJIIj+fUR75EUeQ8w+jObKe99/npFI18yC0lJy92U JxeAtBtnqwUqbJ+RnJtlFnPaZcyOaJKKH0u7FRAXoaVeKwZ9wHbFQHBSVlv28Qj92RCh7DMQhULc 6TT+BEjtJOCkN3QMaUksnoVdMgKQmCmXa267CucJeLLSpcMAjpWpsrPzUBv++JgDuEmzbBqoVELG mik6o6Lb2XnSPr58t127+aitn5xvJ9d4DdXkMWYCH7Xv/Mk7dGhPtldfPcss5woV4HRbdeMjNr66 efM6JG63114+zUZIM+0nF+82pvx4TvoRS2V3EuMc1FN3XW7yUQNqn7Mt7YjD2OhRPMJk+GdpPemJ qdZV/NWssD6l9asPedbuq4zl/HhXWELXhpWJz6T2bN4r2qBF2eg8A073g7h351E7sUgnj7SPLl1t L71wjop+oh1fOZ6dnF9aO9m+8dqFdHq1DzxCNg0zIcFGvpoUh39W/MFHoun6hXXz+Li7hBrHqbfx k9AlK+RKXCUOk5VYAD92bjhToupS/fVBkicMZBw83W4n2an7K7/8i+2rr7zAM1dzbMj1cXvvR+/S kat3Ws6yRN/lcbMsMdYeY5NSBDyfp3b1knZsrBC+vqRwqlFmPPC91tg4derMOK8wA55L5idYMn2C 53dnaRB5WB/NsAvoyyz9nWEXcDv1t3me/Fu/+/vtrXc/xobW8nohlz6L64A6K/HCOr9a/nJMTKBh hRL11a4viFZAHHZSoRUbgOrIwjyJH9yPTZjXu/FlQVOGwOD+F/JXdmB9VHqK5QS/cYyy/NtgrFgm bcDFnxzc+ODj99tPP/4xy9tvYCej7Bz9Jd4nvBJ+7BAbQ5SlIb983roEAIBJu4B7siGfkD00QKFg oMs6MjEKmtPoFZZcwW/4pJxwA5B7Fiz+SeIomcG7OhWpaehc+B76lbyEJM5DCbznLzSQRGbhKJJO V375sk7y6L6nH3qv6sNCEn+XTvXKTWEdHSEZ2uTLD7RIvx/PUx91uikkbL5TXD4c8M6cDrrL5I7O 7hG42g3+Atzwj7KJmhJX5gWYyIr7/FNEGks/lol/wZ96ljYPrJ9c0siZNhAfgX4NCbjSZxvWsraf sru15YDTeVPm4pXGyIZTChRz8ANHOZeGdLBJEavZ/JZO2y1urugrRm0bUCC6iL6BVYMLyCT6gT7w dV7jz0JRWd4HsPwZ58Thl7q2A7nIM+lT1IUhljKkVga+v9hR9Crg8MVk2Q77BTix1DeH3OeRgl3i sn0GN1La9ZdrV4ikBZd4UPIPgdAWXiSfv9TLgR/SS79eo6Ooga8u+8TTIz4KTukC+OpPKj1VEHzS z8At0qZJPSNc43HPX/m81CftpAnFQ7g+imnZbCRLO97XkGor+kI6nMQkaZrmEcvQIW/aCn+Wqxgv RBBwqE91o93Uo4Z2lJUBH9I1f7gGRvFi5mxSKqykkwG7sV1jfZRBAvJa/vAJjJJfPtyt29cYahOT 7uxMf2GXQV35cXbXDQ8X2J/hIe1BO60TbAKp3NIhB5Z+pF76hGDFnMEeySgt3E4Zshd/8h4mSwYy Y//KGKAJjNlzd613RoOpLAVqoK/mFyJLqxfGrcm1U8HCQBrd8u2H/JlRBKLXCr+chAtTJJ4ywraR VRSSTJpqJ1KRrxqDjrYaAKQ6sPmKosjroUKd2q6OukrhrsGHfDLlr4FPSejUglYoR0ELGCrGDSQo ODQgyQQPGmsFJZcCEGgkwtjGMqdlNiCZYFZqj1cEbfNag0neMSplW5ubyIPOH7IzQABJMOlIQGxw p4OqDEiXfnG4BCAz7IxOP95ithdDFp3OJ+WOlstyTI5fL1LJQrONVA1EnTm6A2jKcO0mUtTqNbOL cmFcvYnPZWc1WkjFvk0nmnQDoXIRj3K0A7sH3M1D93ouPuRnIARaoMYbHBpxNsqChl2e8zWwesQo 0WpGcKFVx5PnqBi9AT6BI/ljL+oM45VWgSs8HTXQ+lfB9sq8okoDVXpULsCrAkQK6k1dglt78PAy spAOOh5pvA+0eT8sUe4Yusg94Lps3HT9Qy2oD+1VfiKHFMRmyedhEzL3OVc2JQf0SX4byZbxfoKN VzBRFXqK15c0BavlC0aYJf8xNwGTFmWFELkdH7Rg+KWcUrLDXnSSwUzmgwb5sjLgMh3a7EDIub5c JbngLHrQBkFVnTNRApnylpWP8MZF6YJA5wAOR/ghq/ilhR/Jza9lOyY7Mo95qfyLz59PA1HA0lh2 Ap3wWXiqlPIUoLLPwBk8CtcvvaX7VGCESnVW9OV3oFkepFm7sPOtDCwjvZqd90rfRY82HFlS3gaL R2gBh419K0OfiXO1xe4OgR1/mmUJ7wyvOzHAW0FZXuKtPPRty8VegRfuuJ8s2jB/mnM6eOD2uXmX EqlGsU8+YaMf0vlP/EtFMPiTtCoPY81TliPFl0KnFV/hKijFhzq0iMi1H3fQ9VCHNh4iH+AZpzzg GNpAxr+iyLlUhX4bdNDLhn4Odrnc+w9MWqQAACAASURBVMrHt9v9m7fb+dNLbY2dnKeY6fzg0gYz u/faiy+dbs89f5b0hTbJctSzZ8+1OzfvtQeb99uLL6ywdJWO709uhpdZZshdFisHNkwdkFVufmnT 4bMYMTXXfeVFJZRdZTk/uoZM5CHjdaTuiAIG6ciSspFJj8i+7EY5Wc8pm+pYly2VrJVJ4Y+AKOoM yAzL2Z/QS9zk1VYzs3N5jvezG7yXeuE5bGUuS7vu3Pqs/eI3X2xfP7/W3rlyt509tYA+tM2gj6wT 54Ap/dq8jZ3+qIk2Zuw3FqUTA+nqMRxY6UR6g5cbiOU3tBbPwpKHqvef8CztDB3eZZatT/Oc6SzP Il9pH/7Om/gq1ytsHGWsDhWUAZzvkxZgGj7oJI2syNoBNjvpyB27PJbOO7/UqRnAGdGeXWG0jzzo 8OJHs7zL+dzaIhuh2TJgB1DaJmM0nF5+/aW2wAoCXw92jRnz/0GH9wdvX2rjM8vt9v0HVrjxZZsr KkL9ySraIkF5mC6f/HJDuqRdniOM6Fs9p8qPvx/VSfJreQsLG1732YHepGAAhNLuz7HZEVba2mxi NUClR514VKyTFu3HZaC1c7uvHZqf+3IGzHwsTDsTkjjFH/TI0riT0K4O9Ud54KY82TaSB/Upqw6Y eJ6Go7j52Gm3jSW8LivOKFf8F9/eApZwQJK4q/5ANYatWZQoMeAGD4K3vAj0NTfYjJ8J00SRcds8 RVldmxh7ESB3yGImv4cinEuD1yZzkl+gJ9Ff4AeuNsef/CbOFjTuA1IYGgG/R/FfWrg2jgTjIFQp dOZJMjLJYzFkK60mpjNKHmNo58Z75vdTdub9gu8jb9KaeJ3byM98HELVHsybpBhqv1MA5T7tjiGP +eXjiOcYhzALaLfpkoP2oj8ULst55ruoo0V0i/urydAuzJyEGnCQO7tgg1M5aa+W0z4FZfb4Gtfh g9/Um9iI+Szje1gXeV49y2pJK0r8/VkO8ClvEUKvjwpsPNhsN67eaTMjU6wUYVMrHrGw/SN+Y3Wx wi+o4nPykPrRel0RDjRII213TQnQZk55GVQr/dv8sR3oqPqv06/sBl1Dnv5Sh2WREeUSb9CTcobA 0gdmYR1vY4tUfAkZ4psTvOxd38tGjPzapq2lwdVRtAHn4GhMMgiKSuOLfRvpFJ44M9ghXFKMAdLf +dZznIAzFmSVxHDP0mpZGvT7DPQAMCs+gJG4QFkf7bCfZPxy8F4BKpcDB/+hyz2OvIcw8yoj8xpA tNMZHmnxneRuSKh977AvhBsZ2vZRfxlU5jf0kj8da/DZf9TvPLRLD3m17pF38RpPQAIc+ObUOGSs DS8ksJlmLZ2owCmxOIGQVBCFUoDLjAYA0SAqJJVsA0RBOLOnwFV2HA8qal23HbLBAMhfDgUVHghU OCMJlqItmHkXrEL3vlm5r+I8d/RGp/NWKGOkQQXEUjECjatEUEXzbAl4FarCVhjyZq5SHLSZAJ8a nPSnUePoBwKHeTaYwmF91mhxjAbAMkvPptqd+3cD4+SJE+xgOtqu3LgXulSuu4qpoIyg0NhRIQAN DcKvysbpfUZyosAx3qXHO3gZjfIFzi5RTuNFmtCBPFGfFz28HmJ6lmVVgLRL1pXrEnE3JpFPRZAP eTRuR1PSWWAU3HIG4ENmH6YwOpeY2fjY3fNeKAUCxoy8R46x7JyL6E9aEAai1Dw0jXQKVYsd8F3W phn4NLy8SgnnOaCh2oN8OtahDR0By0NjfoLONN8MBgRz3ZdueRCfdhn6tQ/yRsfqVFszOKFXGwfS KSwpRXu5jvPrINKvfWqLnIuvbDFcpWGVhh80peGCQcWeoSn2ZX4FI1Hi4CeXfCesQY90unGWdJXN D7xSNnoibwUb81b+0KzNwJsQY3PypZDFAKJCCZ3KgQtKqomi33wpWjZn5pq1q4onA1Wwr0SgKnDF KT7haYvqzb/QbdDjT7mLS94TjuXf2QyCjv6uXosX7ls+BcgDX5KjmBk/AGrxDqrSo7D5s9Pr+y9n WOqq3MUjXcKJX4qDc+OPePoMeSpaymuXxgftUCSpgHKheisOKVLh+ScPxhdhhT+LmY/f2FF+hzvA K95I5DAAe+0gH8CLV9JSSRAL9YEzp4/zDltevwNE7bqeZwl00ooGaVSrIdjvgd5+LXbEG9t0tjA2 xpeb5Hgu7Kc0JOz4heanPmtTsTixJjTZmbDDOszO4hdIlI+l/RKL5XOq4Bj0Y6d5yjgS7UxoBmj4 tVKFjBzBRyHlaXntR5moHy45BrmgwyzJRQbTbGq3C8x3fnqHztNmO3vuTDvD62f29jfbj9/+oF2/ vdm+/KVz7eyZFd6JOtOO857miYfTvHLmZju1Otlmvn6+/eT9a7z25wGxbro9YqBRO5Z2dzjW9Lvf hExoUcaxR2Ub4rU3C8hv0azekmDicIZxwkscJfzEN7g2rgjHP/k2vWQgvNKmMCKTyAfZA9a4Osky LgckfRWV0frOxjav9JljkHSLZc7XeJb5ZJaFra0db9c/vdrOnTnPJlfPtz+78qc8O0UcRQdSGHLl zdiK3F0hNEnsLr/Rd1QjFKhL/lx1EspMV0/+cb+nyZJ5s6rADhEIqLIyeDPOYzwzvKpnYc5XULDR HMvPr316CeqfttUTZ1hGV8/OHbBxVPbnwGC1f+s7ZZgGF+y6HNcGzBTv1a0VDtThyNFGkgRbv5Gb V/iMtWt3aLQyULTEQNE8cE7wzO4Cs72J0cYtRn1eZKZ5dX0VuUy1q1dvtf/y377V3nj3YptdPJul 4HaycqhDUPAf/9IP5N0D8oCpnXLudc69GGzXG6YPshRKBrq81uf4S83CzuVAwhYG+ydVu6vBZTSA PH1VXxpplH3m5wEf2Zc/1bXfoQUdS6PtLGe+hSlFxjMHFW0ca4+xRezbNpGvkMvBeecp1yHRFGmP yKGXWCGvBmfTFbA8kRb6KRMR8GssVm7p8AlZ9RInEo/xbQ/beQlh3A795Es5rwNZvNYnUkxa7Lli qZMDtjKpgcKf5UAYOMlsedFURc0Jh3RJo+fiiEKxfwcBvKmj+JNM2KV6I6vyc9m/tUBiQO4jFG8q D2Ad2Yg8iZh7totND+18x4PUiXg9gFPtzYAhHZ1Yl5lOHsvbpjM9cADrWyuMT8LPABFwq23kJIzy 4OB+cGLLoQsalLtckjCU77zBFbiST77Ik4kUIAy1HvBIRTaKp+hVsPLDnzLiUrylc++FhOAKHdIj zRz6dx4X4dqyxsNeR4ugD3xo+8bZumYFB23TpcVl5MOKEPAKTWq/2FG4wwj2MlAeH7l95177weUP 2zcXX2TWdyeEI+LwGsbUlQwO9NckE2mA9BEp2xA9ziQeGj+Qte1EfV4DTx1D+bR5DHa4kcFU+XmU bJRlpSlnYeipQZRswqy82oa4JvQjErWZqWwepe3Uylo3m2IeN51Nl5JKgyt5lLl6UufkDm77WWk/ hRfLABac+l46eVwYH8dtuxmnoSs2w1nsJmQaT8qP1I40hWzlYZwRdjgGfngHivaG8LJBFHAr3fY/ GXgsRji+wtAYkc42EwC+kvEAn0idQxnrg1nifmyH+AJ0qVOQ+XgVvNDGCWmDPogdyRKbr1tmSaec MjVpUjC6HJ44e2AShDLLDAA09ZRWau22CGCZ5KYKcuTeZR8CshJJ54DyNnAz6g42HbY3vJwhM69E ma7ANIyE6wigAnQo4LqPylghWRmTmU/uUlaZS18ld1glmEpMxUY58+qEyUPxdOKjGOi3UiQ7KglP EIjRGwzBKaEoyqVddgJS85BZEpTDCq/WWF+bZmMLttJum+3EuZX2wosr7Dj6IcuvDtrz55bZ1OUh jQ1kBhyXUniEH8pX0BUaNERzpdNiDpUiP3mUll06tQf7jFgQyCMGi2mA8KEuHK3QMHwRtLtAOjuz QxlUUSMgLEvDKyiEnuSdvHZqxSWoBHTonGQ5ooWiT/L3Z1R3GVTw3ampSPaAY2VBQWUkXgO2tmKw 0AmVT3SNp0V24DCIHHOgQi9IxUYCtEu5OhGey++0nwQS08mZGEOZjNaYQhkP74mneJAnm3ZDUFff +SOftHlXBH6QVWmRS+lUSMI0k/C4TIcmuufSwZfc45zysSWy2uCIzYuV4g7K6A/jGWUqvVRDWn45 uJ/OWcgoJxWduheuH4mowRtkKl1JUXXkUW5DWemsAAVvwEjwcTWBOKTXBi75/QsOyqmf6Mk07xBY 9FMKxc5SUZFHXDZq4i+5rX9LQwlBqozvyksNaYPajw0Vy0i/hzPgoRGYgaXsbJwN+WU3dNNgllff R33n2sP2+jdeoNFvaC++qwIlmMcG4IE/jwR5NRkG1bz0RBhlF9pRkJTelK+aqHJC4NxC8gAMP4Fg bCJvaAZGYg9GGF6Tp+jOaQzDYpSFrMyekDMxDxhZbaFPBs8AY8guXBvC2kXkEEoAhfzlWZhwJ3nh p1CXb3SauUE+QUjv/yPtzX91u9IDrX2nc8+dB9/rO/h6KLtcrmqHjC26ISFCzc8g8Z8g8SM/IYQQ QgiEBBICCTUC0SI0IY0aKQQlRKLTTdLdlVSqKrFdriq7PF/bd54nnud59z52I6GuiP2d73x7r/Wu d17vGvbaa3M6hAYfCW6cow6sTzao4hbEuuygVl2o0bmbyxl4HrDE/BbLw+4zgHmM3KZZhy1XZwA+ pTl3poe2ScOAJ/DiIMazZDNFO4EHXKbpeyfYtMmlWh+zU/Hjh6eWK+fY0IRnFa9efcju3e8sX147 t3z79Zd7h+MpV9Ogx08/+3g5deTR8jf/+mvLD976aPnhO18Qr1kCdfMG5KdhHU+QuDzANEe64XJ8 vCTSrBtTN/WN7E8FbsnwFINXdQdGfpsIgn8ugNEH87bkMq1YVKr4pa1PgVd9wIDvKPZdlNYP1M6B LsD9lMGSzYuDwZ++98Hy7W+9trz00kVmuk8uXxw51hKw3/j17yz/zd//EyYReUbWNoDPASYtXQrW wIdY1XBB+4oZfvQFz4eT4c9rLa7jlx6AZxzwaNtknbB91jeOEOOc3N1lsM1pm8w9uPeIwecBXhV0 uvbBu9b7EMDXVh3gRbnutunAmOlb4rmz7GwsBS47Nj43dgg59R1389QuzvLXkSNNf/XO9/d/9L5N RLs1n2bp4wXuBh3jrm6cwqPt0ze+89py5WU3qDqyvMMroP7Ob/3u8uc/uMod55fxW9o2oDWX3yqn PxxjtZEZVCgL/fujvrCrmpEvbZpPWMdKM51z9hKxnKvgip8kTRn0Zz6uYawS1nfP7998ZU3T5xrw DmNDFwxbmWjzT9asez1PLAfox2t+GDgbMycmog2Zxd7adr75PgkOoHycowkrcM4d55FHenmIOG0P uPZokL7Vd2wrbocUDaa9QvjihjxCM2wyzZ/4ehsA5YwVxp6JHQDy190lcCQrv7Ykj7i9n00MeSEB S7zb5uN0nBcPgVansUnaHGvch/b4tfHKtOExm0pYu2YH7WIdH16H9zmfwQvl0iJp4gRWWaeznLbQ tn0L9LLJjIzCZteVq3S50hifiEElgLb2Erf6gy9irNKITkT1p0nw+W5BjRHirl0wUAQ89LTn+K2Y xTfXg0yYSVPeUZlQaSpY+bAkzNQvs/wj2v4d9N6yd3w8XWmPTRe26yQaxxqYw//W5o++oUm++nRy SL+Vhv2HWZGITzAg0zcusMrHG0Y9PjecyM1f4VAZHPBW4KL0Q/YRuMvGRyQQW2h7eU1oq5L0C5Br Py2gn2z6ic/0YF2YQ2s3AUGCmzbaJ3KEIimPbAd54exvyYnyb8f4m1foHDuI1zvS1TraP/uONpPW 5QPEye6KAqO/zSpNfdWy09f0N54gYfvZ+631H3mAvuX0GeXSZg5QZ9d7SiF4g9eqswik79dVqF3G u7jsl1Q/1Y+DVggr18CO8E5UyZiepH86TrEt0i96RhZejPHyq+9a7+VPPMYX24BeW6rfWZa0h/Rb PZwYcQOrw9yAu80de3XmCtUmGslXrmfPnEFVDv7yK33L+DK+bdvnOGO7IaGMGm4mW5yEhR/l4uvE rnx7oK/VUAg21XS71hmAVGgUJyLNUY9fIbkquJFvuTGcxvM7CpDB2dkUJlWyjIOC/5aICZVkGTNy JuHCh1FFTLozICrdQ2V4qqKnIzw0TZHdOn8rfvFGSZ7AKl5DmQ4zk6RWEArBgx31fb5qAgfZZLCy +8qN87xf4/oX11hS8WA5//zZ5Sgbbdy4we6jN3n2FcP6bNITdnvctwudZBzeGiyhNw0uTu/CDE9y pYMpj/odZ5kgqh5oaJG7wOlAFlgb+KfPfAicMkgCRa7RIkgyZmWUAZ3jrEo8urIjO3z1mgr1AC/O RD5lF9aCHrTsIPuqiXalXCvPU2dHHFxpG7hQVTJgp24XubWNvK7hDhsB1ReemWLGDdCzs1fwCGzB EyQNzDSiYMgffopihg55zy6U4TReSVgZME3d8Gs3RiJ8hzdwcJ5/mM13ePJUXwhzNIIjJZ8Th4Sg 0TvOvDINGoqsHaSn3vRXG/xWSHAei8oUjrFZNgBmqqbkhhntJL7xL/nxfPLxxC7kUD15WF/MN7AI lsjyzLl+pv4mzZPCrMXSgTQ8Nv6CiwQykFejC1b1YKNq46UtfdVHtCwrv8D6ARBy2FC5sJlJ5UfF ErLvr3LFYWnqV535pUCvHDl+6gDL+I6sMljP4Z/j641qVEVHeZ/Fk15oBeQQrzYZ3xka2dK8IAbG 0wIfidX7AuHwutlB3IPLeoc/4wf6rAqGxNjetBWv5YauTA1e4YplXDfoTKbhJPoDio5WLFxv9Dd8 4soGow7wCUQiv04iRMPr0HqyHStv4NZ/5c3G4CgDiPwfJFrlCPEJoviuz/WzWy6NjPsTXOM9w1O9 sH3sTYwcrxsa2Y9TtI79teXw2q//zEN38ivfTort8rzuYeKnccgJtFvEv3c/frBcOHOQDcxs4PYt b7/90XKP1x19m8HN8+fP8voqBk87LyyfffgZr6N4tLz5nRdxjP0sjf6U/s7J5eZtYi67C0tqZsqk yzcOtNXU1c0X9NUGnfiyfFkHvXZFBJzGs4MrfUMcymDZfH77n19b/1c/5lqbteqJcraD6vIIDbjL jKXjbsXeQT/JhkynWS58+hSz3qSTyTuJb7JCiA2+uMvt5mY2/jfYoff1b764/I1Xzyw//uzpcv6S S3mxgPaQMcpqce9WuDTROgGl8aFsphJcprdOOpOf3i2uzMok3+mB9tlOiJtLUZaxLgNV/IN3zfse Zvuvx+monmRwewB/sn1yFZLyuSHbQd5NXTk6m7NkkY4ENpqJTswFAnWlXeRBGZztlw8jm0uDP/7k c15vdJs4cGw5w4D2hXPP0aawKgn966u+Gu/Cy5eXSy9dYdOvI8snn11bfvt/+YPln3z3neXchefB 8ZB2TrmQD2aMudkQe6gnrZm8nE97yIk1GFhdR/tbL7d9S7KN+eBpiaQThWDSR50UmmNtU0mnKKiw gG03dSl/o7hHurUDZztsbNUnnQjUDpTN00RPnr6yxXLbcmmK187l9i5K0xDL3lp9fuUiiXISHDmt Yj1Kp/5UOHLIdTqocns+/iKv1gG/8t/GW6XZb6Bgh6U3HYJPeip5TbN9Fm2ymEr5ia/ae3xVNMMq ehPe4ise+ZI+OZZON5WSLN/RFOdciFc8+vukjM6SQ75DPG2AS8s9ph4PX5YVRHukbxg33qdHKRGb vJbqlF3Pkddk8Q+ONQbAkxMh9c9W5FvsF39fbcBRWxCNDT/1Aj/gr4HQ2FD/IMFBTfqoZOwUU8M0 vOToKij/IQN7z4S+xEhXVpAbuxNpTdZe8mgdtW/p10fedvnVB1SbOpj9TCS9xkaNLG/U3M2qEytJ ix6DHviuX4D/CmO9xGTlq+MjPMZx9PgJckYn5Pych3S3r0WUzwhyiPd/s2Hd7fvLJTbIyv7ovRgJ v9KRbavH2Fg0q73jedrHTUHCOHlvn646jY7E6bk25lQ1p59EUDaOUEGtfGAGdvjd6Po2AneuNiY4 yeOktFpoYplKi1WrL9JSVHGJ2KrmnVA3uG0SQX/DrtVBMvNj+HDwaNpW9xxPVM/hy3T1YHdNeH3J ttu4Mv4Prerq0JYvb0jJyMhEirygj1aurLCE/Rk/MYjXf/2a33ijttSdmmlfSLt/h00vwejNUIg2 ERIPJLq0WVq3rvvmBnCsd4LVA1SLger00WOeyWYy3FWrTmxoG/24yeDkAg3otYd8K4flvWHrr/HI Pnt3y1HIQZHIlI2lzm1jUMAN2Vqx7VCvxrBCOaCRSUfcbrQCVDhkRuUP5Rl8qNwDBHd3PJQBA4zP 425G0hiyOEGHUwmZxD9pPHpA58TyCDAHWKyk0lnhfOl77xREINlswGQeuLze7lx0B45C8m1eougw KNUlRc5E7bDUwFI+MyDYvXsPuBtxC72A8MDh5bOr15enn1FBeDflIe6Y3nGTjWO8f8zn2ZzxDq86 AQd3TnsRbgMJ9IX3Oah02cs4He+49a4n0G6GEZ9YrkEs5AxG3qV2kwE7ZureVw/0aiUH5zowMNsO 1uqjmeK1grSenmClSke/96t8OoedeoOTzx3aIXVArr59ruoW6+trIEbhWdcKo1OnI5bvNUCp8sM9 9OoQAm9HwgqPycYOpOm4PU9qOl9tEgz0ahRkkGN+xmb6kh/tLm1xGMzAFp/5DZ0rba9PtYU5ED2z u+Kzg2etF1cdi3hbCakrPtJQDNwAvRNQhQ1u5FBv+bx+Di92cH3ftjozvYkNZQKuoIQ/gxp8lt9k mvPxdekIO92FTV+WcXJiZPZqjtGDsIMjkaAlEflULysk1+pneFkT44vCEh17wF+0lRP9NyFBnrz6 DfFKS13XcSPDj5rKDjxf7DYL4VQHVhSPtf6JxnAjWZxalea/pp3nHZu+o9TBkLGnu00WFZYjeTfe QJTtJmvvf/YR1hjA8XV7BZ9eNowrjuQbHcZZOuRMHOu5sm/+abq2GPyDQxuou9EVsN6N03Hkl++E soEpJgK48SOPHnhN+vJqyytjEsAtzhwMdvR9cGt0ywGjz9Wp5HyLZ7N8j3Tgtak8GmMd1ojD2NFO 0/jueN2z5TTvin2O5zNv0HG4yasfhLNOt5JBfWRTmbJOa9/hIT+QH7KKYcqNjbsTSRkbLmNIs6w0 rg521I+jnR3oP0YPH9HI3Xt0iFffnF6O8Zzop59yff8HbHL1Cnc/X2BgtbtcfvFKd4fv3L2z/PU3 rwD3cPnu93+2HOB53+s3eXZr7aBsfGkrO3Lqaw55pxNHvJRZ1e9gy3PrX3cFhCDJTtt2aKcZsGkn cWhDYw/p6Ec83S1CJ2bv0KlxEnCHeGwjb+fpOq9sOsbmgn+NzameO3OCGI9tUICxvzrEc6wffPDh 8sbrL/DOVZZ3s0nTrZvXeYZrWX7zN/+F5YO/9xfo0MlUO+OrLxT7KA1NTaOfFjtWea2D7rYf//KM XwKRnQxuU0eG5wbn8H+YbFimc8DgfNdXSu0sZ84cYRDO3WomNX0my0GufuFdilmBZByxzthn0N8Y 4FOPH/SMKzISjx/SnnqH1Gd43SlZm7jiiCTiAcumr91Yrl+9C51Ty2kmv1587vxyDOGtM+r+IUvZ T7HZ2cssa97l7v+nX9xafosB7x/+0dtMBlwKF2oOr1JqVUIPv/ADr1A0ZZWZu+tsiOWA0pUOru7x DvUh37IAX09bDQHlOurUzmw8HfmUBypQJyc/0dzi3Ubb65lE3AYb0re9jATl+aCnqs36qx/sPX8r fnnGprVTXHvHiYa+WFEMUB7w1TcQH3rMvBajsa19RzZSrZjxWTwAp+V1I1Sw4jM+kA78NtjZkVmO Vj95gtDqpA6q8tXZ1ICDD+boNynjlLP+bXXPGPWURpLIk8zTN6Bu0LdsgqKVbDAuOv+tchdbTdKY 6UN/RqfKKl0VqCx8rXwUWw/OtSXyGP+EcVBq21Y85bp6ocoo1x07FNIqlvwTnzYGUHZ0pbK011rv 1SGUat+tS+TJkWzEqSd86wuYDu0eNyNTfEKPbpSHkuBoIptiTXDzm2aB14+US349Qark8ty02huy JOyP6cYBKAE5uvFy6CkGZdQVOhQqH+S3O3ZOzNFH3e9Ap0JkcOgDXtuPngG1emAyiHovvzN54IQp +uXGSBMalEEMeKUcMnsn0Lc0PODRvSM8vuJeF/+/DlWM3ozFMnPXdus6cYKVRBKeNm/iONKWlg5X osVL03XX1Y/q7yGjq1A0YRNTZNeuisJEju03/WtPyvAXDTgKRgT5p3l8xlfY8M+VP7QR9VGxg2MP v9nFMnxaIrzVP9o1UW83OtSqsNaBrf9ovv18vLy8Brfoxed+tzo/PGIH44jw2t/2Qdq6oHU/+bY0 /UO5/D98AWzJ6rhRNZkjjv848gWnbZ5J0umMC0sf4VGZJ7QD3hD02V3jxCP35kD3B2lr3PfE3bxv s+LsPmMon2NGUngz9qpTviImFrgBr+OObAhPero+F11gZVOdJg6pO8QX/cG4rFTaIulAab+k9/Qa INrcAEAVqHRWQo2tEmp4xUjiM26RSkwkxERZS5EpCjwbsVgSF4SV4amtlNyBp/dgWbntJPO1jKGB PhL/UZnFVieQfgNCOlaO1PcGBuIFcVUNGA9hLWzFsG7If4KvFX5T6JjUPAIGeJWCPc/GuCqP88fO KFHehv0Gu4/eZCkF7rrsXEOROiAdfxut/Qx8L9EQY0/KOcBUc0NbuVpiyK+8akx/1ff9+3dpvB+M MTGEy6LdltyAovzqzXNhsXay2Ui5hOkpnagqA+naZJv9sJx37ZQzbsKFnpWfSuKzv20ANgTS+717 OAmVUi3U8CNFAUt7IXGBALzekWgQjQntRD/S+BRyIF/HFlurf4PiQSoXOVQsccAJMjfRgEwKZ+48 W6QltFspgnaow6mQ5GpLcG/yiQ16ZQAAIABJREFUGgwqpex6IUX3ZtFJy2fXXxvZcXtAUw5l+NMu sg9TyW2ePOgP0jG/xhx59H0Djq7lua/ZqVOM3NpHRJaVw+2QVL5oQiStkONv5sGMddkfAcszf879 WemhS0H0GetFkyAh8NoUXUMJsRNXptpoRlR60LCSh9uAp33Id3Bgw60/ZUbSlW/jufoz7OiG6QOk HQODD1NWEcJjYQ4pZ+vwFQEEoFZgT/xYXo8T7JRvXq81XCPe3rHxANE6ZOkWfrOr8mALVbDpS8+x jPXcND/6jihNnwZa9NpXO/FRnwMQz8mBNOanV/EL4B+45EGc6q6GpzRK5WfQEb14J4ky+sxgBXRy OakOwFPxLhjqCNfCu/LEEvEIbW0kTtPMVxmiVOvJKQ/CkJa0A+gFKidSrXj5CYe/NrzWcUGVtEk2 Cugn6ZA0Y5qHdvVsHg0R6fhI1LCNx2Fnc2lonYE9yFL17ZEH8Ul12g0jgezP9UwSsbHTvcfL+x/d XC6fO7ac5/numzzr+k/+6Q+JoweWl19hF2c6Cy+9eHm5+snHvIbm9vLm61fynz/7i0+Wp+yKff3W nTonMlnd0xHi2ARtxs+wmf6MoxODp1OnDYJb/aZOiCjApr09xCGMhzJpB3HoA3YwXO3iJk4tQSPd zVRc0vX6699YLl86zft5z1KGPRN4T6xLOB9C66ErgugofPjRl8sX1+4y6GUHc5592qGTcO/+neVX f+Xby9/+7/7Bsu8KE6nwYgdMn+iIL3wFG1UPSMRiI4cxEl71DaHzKwvBc3bWJ+ioGEPYomLZxeFO Hd3HHd2d5dTxM7we6AQdU3Yap0PSLs6WRWanxO/D8yN25vbOkI/g2LF1Mvo+HVonJe4zMXz/Pjul 4lt+H7SLKiVTmrrTH3mbEbrZZbnzWTat8lVlPu98gUH/Ue4g+04+9fr4/sN2/Hz5zdeWU2xodf3a 7eXv/M9/sPy7/+nvLL/6y6/NM96YxM5Ukz2UUQdbh7X31juo5au6rHNnTpzi7vQO+mbCmoGvryD0 FSr6xNWrV5nkZdLHmIDBD2pT2rpVi/zCGh+pmK9S0q26xocmQo++iynQ1FzaAdBRYuf6/wwQthg2 fjb+teGdGGGxsWV45AJ7jT8bpyZfnougdlWgZVyTZjEk/sARz/Kx0fHXtgOZQJRE+TWpXDSxUb1Z 4dMLsMZd+g/5P8S06XaXv3ouXYy8+Z32UB9e126uOvC6QZW8Qn18m8Je8lWO9OelZSrHRQBeKjEH Pqj+Ek/+SRUU5COTMq76kKYf6VUYIn7SZxOMZFF27Ae/G94NfkKFVwFGn7Ou47GM+FU/ItNjPK39 MVubkaZM8mPVkPd4NpuEsXVgsTnMev0VoGXNNF6JxGsHsFzVPhnfay/igFTy9TsHOZUNHcys5fMb 8u1XG2u0W/aCYWXQw4rfXOctVirQAlZfyEkuJyB7NI56794QPvNfOoNq4/q//m/+G008/TN6g4+f 7xh9KnT+VKFnvKP39vIle+nsJ5ip7Zb2w79+mj+SZhnjvHLPZIh1SDzkqRocLXtoDKQTx6bfyumI ZKVP0amzDi9WOhlQe6Kr+ibqj3y++nYoUKDPc2tj797aXx5M2o8ob1l02Ct/INmkKhTiW0rYRq82 Nsh78PGlz5APPmOW9L6ysenCy/CUjS/KaUIfQWkcZn9A/awf9eHHsocckFlXOHdjqeRhQJkaoCnd /FBdywgZNquucjrFatgmykg7RHwX7iHtoI9h7Bzh7vdzJ5hs4U7wl6zcsqg06O/WZgD7hH0hrNWo mbIjl/WJLKbyaaOAt6Blm2Dncm+ChjxKUK7i2EMc1pFpN3nLCIYACfkNamzwsAAMf62TRp4zvT5H Sm4Im+yFooMc6NWwOqeQEyG5zwyo3W1mKmUC25Egw4TVytv35cOES6M8b4t2eaOhxl/0BJBz4p9M 8EUESXANX1Y+HRo+t13eNGbBBGApNzjj1xl3BzXmiUil1WgqOjRc135o7YXaufFu6MuvXgT20fLl 1RsMgJnJBse9e7wr7DEz1CwLY3gMn2605WwLPPHPdfyuWTfwaZwJ0kPz0SNeM0Sp+INvZ8Y1lA5v wCh4POEOtAMrBthudvX4AZ0qcNpxfMIMnbPaNiD37rIm3jvp6K6ZF2hHc5MPmdxx0Xf+za7XkeZa y41Tqc39zM6K1zvUOoh/VoD0CC1OcCAcE4PYyBhcqGrdlWjyQNGkjbCeeo4h07uVtgGxBuPQhObb cWiihUtzpGegtag6s6K2KZK2KV3/4Bx3MEU/PJjNVrzRprB/yO9ARZ9ShgnmkqUTBvjqjSuv+sf4 pEt8JlgOrLzKlUeDifVK9UFm/K0KKtOm8ANdK9teJ4a0KiW/6Q4a2yBBG4tdHkduIEiQB/3UTpIJ yuOGUnJTh0kZvVplduM2B5hNGIkQXpKD87gKbnhqIwIC3sg5AHhA1wV5eVll0aeaFQVlO5SDZ5oa tKJeswWZENE3V1X14wTJ5j/Va8qm+WDxWWWRvMkKvx3KQj3w9R/bIR4Pf8PluVT4Uw5Rlw6YfNlA WGQtVlkbPeH07+BJBSrfE4/hUj/Tdh7rz4qDeoTRpV/9GpD+W/cEkpb13kOetsOgP6sftpT1F3hD jcxoX/WsDCJSBh2d/+XHtekrXpeU9p5dsvWzlnvCsY2Ehx0wyzYTDI3sUHyHThD8U2bpeErdNgbp N6PjqQfyY+x8xkDDCscpAyTetUtsyyeh3VJM8ahflceptUlOagMQXm7MM00693lc5GdXGSw9PbU8 z94Jjxn4/On33yP92fKtb17kLuBRJhRfoPzHzOrfWH7xzW8tB4+cWv7BH79No3qQycj7DLIgZUWE JH99lVsW8gV8aCbxrHVaXfmMu5bRF0ZHJid72at20IO8hguNqeOD3JG0g+GytWk3nrGJCjPYDAif v3BseeXVK8sLF8+hpofLg7vX4c33sLPMHLz7gHHgyW13eL/HTs5fLC9dudjOlkcZyN9gUHbx4vnl O794ZbnBM6+73u1l2KkvyK8atAmdNk+7qcip48qymjG9y7P+5uYxrkDS4pKGdQaZ+5ezLCM/y13W kzxTfKK7MEzEMqi5zt0TB7F2Yu+xG+rtuw+Wu+z2f5/HbO7RqX1M/HHp8UM6JZ6P1rArejYmG5dU 7T7qwA5x4+DB0bV7hhxiIuPsaV5Vxa7Q+tPzDHhPIbd+10AQfN5Fvvht7pBfOr/c4S7Ab//OHyz/ zn/yPy3ffOHC8vEHXzABvkVt7fKV7Tjl0L+eLBcvnVtOspIhL2fy+s4Hn5oFHRl0J+37vAf6Wp3c iU/EWOxkPbAd1XNbKYEMqrjC65nxOP1vdqAOzkorwaw3ksBenMifdrPdsX9hkCtfBPHuNWXkfQhx MhejR71VqwuXdzJZ7Dkp6EGP1v4u9dOPUwG/xUIcQO+djv30P4aI/sKEBMD2VdAif+CinDzop1N3 Rl9OcIh45BLEC2j59RM9I6Z2Ada/UKnLKVtbCKxtcc8jbjY0W4LAS96ynsjzFmNJAR8Z5gnaL1ys 5cy3aNJii+q+sqsvmQ45mhqgFbftmbwjO+nFOiG91kyUEx8nU15Zq3gRF9Bi/W59KPUAcur3tAPq x/6OuogItph4PPKZXL82xsZvhPSonyI6WUjo0XP91egMvINds+MnXrmQt2QIFTTxvZGGhICre3qT 9H3Fz0F04aBAF3UPCPsGa6sDlEtD6TMTD54x4eVAxpss9zj31YMPH8xYwXqp36h365I+qW5OslLj DJv1HWLzvZQmCz/3oZYsxsd2RwIeyHqb19nd+OTmcug5doA3mSrVDRHwT1/eUgjE/26u2T9QE/xW z5HL34pap52V42ompIC0fpM/bbJ4yAXEtjV/XvHMne2RO05zUHo4MGXXRbTGw+I+9K0SrUpVs/o5 eO39OQbS7ubbfzDdw/6G/Vc33tIWPd4CbleCCDttvf1l4gC+t63ImJs2jOyUTbmUBXhpYOCYMo64 MlJafkktv/aU8/pf2FIFxysEtz6VyOzrjb+LBxzw6t3daCH4YyZC678yhvKVoMZU93E5zGMzO3x9 Pdw9YrFxyH2FnBz2uer6zJRP19VTeLEuoSPHPz5+pg3UiHVi6rq6IA0hrKve+HNgr/9Xbyirjjx4 pleHV2gUD4EJVAZsKwsHCGpmNIoEaJj86By4Nks9cZsYgBp4vGwmj4swiFuQwKClMEMweiSTCV4r Cul1rOJFY1BxKC+8PDTgEq8eKT47msNkBFS6CvNj46CiQh8R+IJP0CVjwdorGLZySkcFteQS5SiH S4/tSPrqhr/1r36LzVaeLt/73k+W7//5Zzzby12Iz28u//CPfrLc4n3WLnHj4R6cYBwtPkCqXFZC 7wDoADVO8KH+3IlTvaPG+XKlE2kHy/RSarKJMQzoaajgz/d/WgTMyeyrUc5fuMBA1ZlvHK3ZWJfX IBNyeT1pBiXlhwZ8TIMs4XFukeo8DpjyjVQDPGY1uD62o4Ou9Y+5i4W4yOCyhDr58KQSu5uu5eXf SkVyHXlsQrcix9MXyogmfleCQQpoC8y/8HtlA+KulrBSpbeDJY/Ko67kb4KVUgy+/A086VsH1MAU En0+zskE0Tx/eAxGgNyiTiNXNQRVGMo7ISEe7Tsih3H4Si7pK/P4lUnyuQXLOv3ozcLiVIf7fPGl uuF/u2pqf2y9VdI0YybH1shueaNbNUd57atOcPsJGBMYxlfI67PqEya1N9zBr/xBgL/0Jx0u1J10 /NVfHKQL5HV1jHJUD46RWZmkaJjdOlEgMHlgOC+dhGKAeJFTvxBmG8xJ0xlbzSHu/isXEQ3wNX3y 9nA7Y4lNPCymrPHfb8lcowOQqit9yA6vDXzNArxssgotJnGnR/hpphC7bPxoh2QBSnqjaX6Dgb4y 8JUHASyprEJP3kze4NamkC7E+qt+jRuliIsT8oae1yUUZzcZxV0cBXL0uNLf+JGyPPmRL9Jrn0G1 ekE0VGHxh3zjLf8pMY3vMZ6/dCBmp2bXu3PA2pDJlxM67d8glpW/Gkqu5d2/Bvec1GlQ35T38YT3 6bw8eXZ8eeECzz4xsH7nrR/RMD3ifbYvsQz7ODs8X1k+gNnrt28s33njCrQeLv/oH7/FLsNHe8bX sZdiqt34kRc5Vyc5qDbAnxJ4bDF6gAGFU2Y+wykJ8tY15bn0bu4Oy2Gd+D3oYNf6C42HTEQu8PIi A7TLfM+w1O7wLr71+Bbl3NTKnfapSfhYeyVQRnLFWdJ+9v7Pll948xu8kpgNnFgC6IYeJC+/9mvf Wf7u//qP2BX8+epGipJD2Kn+K5eIAFbXxj9Y1nDI7ACSmX++2snOhPFnl/clnzrhO3UPsuT6FG3a cXAfWm4xoP30o2vs1Hxzucld2zssWbrP3VZfFWQPwmde1U2DTWiNh7qEjJ2ZmSQduhBncJtPAVun l/bHx5p8d7d8H2en9jO86/ccO1gfwemf4+7rOZZ173c1DgDuDnz/4YPl+W+8sFx87TLxdFn+j9// x8u/9R/+1vKdK5ezq3Vih1cZSWc7sjEXupx06qMAV4MKbX241Q3oI0PDn0zr1YBnixlUkY/z++oN J5OV2Qn3lsHnDwAHPzZsIsf+h4YAZXWqq7HJMAQWmFJr2mBVFlB2Qodnm6aJieBFiGIraLVzdRsb F2spPv0ZCmQTsOKH8uEjCUmH3JaZWDCsxVy5XCeVks3Z3soVaFhOvU6dHX5nkAY5leufbZU6BtZG ZnjktLJrjeFceL9yXueP3+wAfstKvwM/fsrz+SPh0BjeyJUGh7axrfUOUfoAr+4vP15rRP3COrbJ ENxKJV8BrrhP2cpQltL+S+dFZfHKG8itn2uoiL5ixIOJwOh+tl/pB9gcD3yitS8kmNJHBjjtahmv NxtLS13WDpIjn4kFkHjl07oXjsqh+/iftnrDQ9aKGB3Buzatnys94OXXyVOqInXI+sqXSbe4gyDJ 6MY6Dl0Grg/5OmCzn+NjeN58Ud/3eFWnmx96N7TnflGKZeYmjzGO2Kis/NpWqi9pHGMJ65kzp/Od PWEo9/MfUlFEf/l2uY9VMQ+Wmx+yuex5Jp3gVdzaLt8UflMc5vGoHlJW//4qZgAEoH1u+5cOmLK9 9cn6NwWRhf4vfQX7tE3qQ2zr25qXXqW98mCddtCv/p0gta673s2ystOmgOUPPaOItgd7ZWTdPomH ODrP/0tBv3GGTsf3mwACXNhsnm1I0MeqP6ZDV78mL/+ijyisg2qViulI4I8bbI4PTEMiEwYPsPrq +OvwNxMbpKE/8evkxiiXM9ve6YcN4EHRTubAHHJFGG2D4xjv/N6lzdlhV355rT8vz7Dk2wHUt/V+ G29oN4d0xR05BJ9xpjqtZjmvLiOIaZZN+ZQZGMtQrxzUaWArrg5uwJeoQSJGEN4qMq/X6YxrDZT6 GE0DBzE/DXbJtKPIf8wsNXMMJPxi9AYnXss0nxzGc+C2XRDHKaGJEn1lgc8ZWyGbVQBvuOBZOna2 kI8D54D3DEtCnR5omr7hA5hLgVEkPxp/ghfKFAk8KIO7VKrMOn2IYGdu/4EHy5mzO8uFizvLj/7y 0fL8xZPLLp2I/+33/mD54L2DvENwF3yUY3pHo9hgOiCUvvx6t9gKEkforGWBDnClBd++tFnHV0Zf PC0OPzke6jzEXVoHNMoiDoMYYiAzm8Kcfa6GXVpWbg9Fd4lAyz6Ac3ZeRVVM/TCSVv7tLvScz/PG 9w1w6HsGwN7VYkBNjTYg+CJwZ/hV13ECmnxuy6ZFLn8+fK9PyT0A6QXO1ATlAEIe9T0dAW2ivyiV PjoNjnwWoIRHpkIo9mnQCa6qL0K6RMKy8q/MHtLQd/zI3wQgoUY/2VqyFFiLAIeclNM98n0DCvRA wzE2FX4GeaneDChwUMgy8ui14UI/F3vBE/6nMRUWigDJl4f+X12KeZhSXo4t3/MabouRJe9TUjRS QBP4nbuRy58DSHUB5miJR7sZkdOL1OQH2cQnGw2wSNsHL3moieSNBpFGXfK1PofPPGBl2YDeSg1+ Rahfbnq1DupD0t3sY3l9RL/rMI/PxIxJmv/Ilk7maoItyJF4JtU4Q+fiVR9bMDbfa+2INhUjOZUl fCQg+vrlRBrKB5yHPqkomwzKXQMHLQ9pb7YZmLG5NMUxNIaW58YRy1RvJQz2fIz0OIeeurCjYKv7 jFj39UOcyQh98XnuUT3i15nXJqWkLk5+lMaGVZj0DFmDvdd6zPwiZ7TXu7fEJtPlU1T6q43NcQa6 Lkl3KephJgH16wZ9UgH+mbsgyQf+5aMcymrDF10qix1yFVpdxuSHuPMonzZI8iINV8h8/PE1ni19 tly+yG7P+NY7b3+ML+0s33r98nL21InlpZdfWh7+9CfL7RtXl1/6zitscvV0+ZPvvteS3C94/MRl tdJ0kJK/Q0M54m2LL/KbmqTMwb8mNRJYm5mmDtwFe5YwG7eNzXYOnCABe7srP+XOx4sXTyzf+MYr xN8TTQZYvMk+7mq4OqKYgr2MK3r5Gkzyn10mKz/99Ivl2pe3WVpMW8Jzp3YQHnL3+zss5X7Iq5r2 XXkedtBPura+jT+5qmDjP9+Ucekg+y53ok+xs7J3T+0hHDr4uI2yTvEaohMsOTvOs8a2Q1/6jkte G/UJE7c3eT5OGj7Du5+dQQ/w3sudQ+OX2tPnlKXds2/E/mzMXfl8BdJpk1+llDEna91wRgsfPLDL neQjvIf3IBtCsosrm5ecxmeeo+2YaZ2JGT77d/D47nLl1ZeXoztHlj/+k+8v//6//V/xzt7z8eaS OX14OvQQ2Tu0qYZGT/zCXXovhsuPDFl3Oa362TP1oMJ6ByWuKZcMBgxTqvO0X5bj0HfnTpDXU3/E bH51KceZ2CC8R+kbXbjafNLBQDUGVLVLAwwEmEM/jBYvxCM9bGC9r+MOUOKSp69NsBt6+oBwyi6u vM5y0iCN0/obyuCO8rbbLlE2f4WaMxJqy5RvdVtZq76LA37SCUQU0YhLCwTEVzCqWX6NleJWp6Mv gMobiuaG219PuOquqr/Q8q40ywbMSDYIr/gUyagrXZmyHL+2S6WQHkKvgBNk/VinPJ/+B9mU8PE+ ZXn6VJz2XSgQD+jePnK8TVuazF4bK6gb6iqiJNVxN+7xXVGQxjmF9AHrkXq0DrXyUKc0zS9ptsu1 8UMw2iLa2hzBzTfu5yO0r9I3ZvXIEDo3P18BuA8iyXM3XZBPjdvvf8CdOPuHdxZWpTDA9U7bA2KI e8gYyx/6zJ7PfsOLWnH/Dc8PsreNcvTVvp47YpRa8nBGO+EildMnTrPq4tQe/wD9nIf69/vVj9fG OwRkdc3d5bPl5nJiP31sZPKRkeo+cjZ6raw8calekaO2mDYizCjEWOJA1Njn+GL8YvxYWYpv5Km3 fNe0dG/udowemngSsXbm1z00tK/lbOPUlZOn7rTcHWlomzb1A2z2hywHP/UZ8WOjvHV5u7MZxTpY 0FfPHN4k2c6Vc/MTcUc/GqCWN/BZZ3wEEuImJI/x3diqfvR8qM45tC0oLov7W2whX51sg97okKaT 4A61Y+rOutC+J+Bo0ledUM9OnDzJhomH2Rz4C+qBae7Nw3jEWSD48DN/UpX+qn8utVU6kyfwC6ck 9jlmkAv/FkN/trvKOX06xlVOSMFguzfbmFte4grlYM9Yss0CgGIPkQ4uFV8orwGtct6B8VAJciFT bWQBnMFQw8uYuM3XODKjcWUajRcEDHAuCRBKHJZqpslOIUqu4RA/jmFwKA0DFujFz9eGQGVMwyVq CZjBl1PLdMuBc3ViR8kOfJ1OacoTgA5G7H7Ku0W//PIeHT9v3TM4ZTD5/nsfstnKpeW1b765fP+d P1vOHzlJMQOKgZBnXrnz+pCOkXgLSNz2JxLGF17BoHfW4OuEM0DmqeJkpHPBrx1ZG1pcJ1l1LF/n cJwlaQV7g4oHTrM5u8uyR9PwgA01lXTUzFHedZnTmrgedV7gaRpU9aQun3AXm6VlBsC+s9zZQa+O /Bg5lHKXjrAzTnfu3GbjkTu97uLMk+PZ4BA6clnqfniwIzaWAT+kq0CUsxplmirhKgtp/mVHTppo obSVMa7XCqsIljfdDDlXD3NYGbQC/qg917KThiWRbw6loPC4YkG6dyHq+xzqWB/Kj2CvCozkVTjx R08qfPHFmQkmnTzLqkdz994NSfo0ejZ46xIOALRBgOpEdoDzEEe6It/0JNYRoWUdlE4BwMwmUyaI qikuyRcYfNFSFyy/1x6gD8a8MUB0OkUmaVI4OVEK9ZcC+F51GlyyIkidGs6tpS6xlW+Xk1jFkwGg /BSYsYZotNrXDq7lK+vHr9g90JGlwOl3Blmbj0y+/6cjCbR26tpU5Y5LTkcHMF86qMI3AwXSSh7e J96QpABfYzLMazmxe8hTeuJcXUgv+vwf/W1ymMdBXDA2uuxHt5EdIbJFuDeSyksGmdptkJsweoiO l1zL73bIYxyAv7s/yF2HSP0SR2qobej4K1aCf2yD7DQ2T3xehwUkwjnwEre7Y545c47nId15Elva Nsg8MHredujfBM1gDh48nE9mN0CsM82QI4v8WLPiNScxH38CLm1B4z2W++q7ly9wZ4Do+9Of/ox3 wzIYe/1FBmzHl2+88sry43cd+N5YfuUXX+v52O/+2fvEHjYUZPmzmPwoYzFD4/hV8Cjzw++0Q0CS Jz8UwBVGNvMdkB5zcyoGvMKoF/dfcKmLzyd945Vz3JU+QSzmfcLczc130MEzBnoOXq2jyqsetGOP q9ipwWR0FfhxQM0OpLeeLB9+eI139l6i3JGeNX146xqD4CPs7Hy8tkl51Lm/qm2+YpDT0Z1tpDC+ 8ukkA17WIsbTMZ4VPs573X1W9xjLiK1TnzDI/uzqzeXjj9gdm2fv3DTMzVY2Otqs5brYpRiH/MY2 ZXETRY042oQD9Wc6ZdKktkQP+sqRw0eRiVcb8dqjk8e4y4sfneHObs8Q+7qjcDqFMDFwP4OvV978 JhtYnVje+9nHy3/2X/728ha5f+0oj/aw3DqvgxZ/kk1yz9XoV5oQn3Eb/dN+w8r4OfD6hHapLMGu uJ4kWn78szolTsrZ/npI149lLTz+QEY8kAwT+ZG/FlhhttinPvUf4Tb8+QuGrO9JKeM4tavy+m1l LQPCbAB5aUhU9jzEl0zWRfOQr849EPuJN8ZzYVvxBg/StC+BW4J/xcOvE9pCmq+c805iYMWPDmWi PpSOF06x4hNyC4znZvRMoranHk/bY3wavra6MM/8ji3k32PkAoOklIF0xRk9wB841WG0pc+5FAPy Z/VN+1xmWFbUg37steFMPoDCIa+UtZ+nsqyn078cX5dehIBTW8Vj/MTloGhrsoHZ9Kz+lbOVAZRw +an0/JOOzihPyYYuhe0gXULqwa/p27n2lwc9ywGthW2fxLOV3+ooCstmwk6+bqx9afMt+4xH5Ziw 6rWY/tI/fcDjC27054Rhj1ghm16oTq3D3WjhfNpZc+QHHqgb0eVy7rIjG+Io5/Z1Yu0BN1pO8ey8 r2WL7xFHLD/nof6SSC+fQ13yqMWd23fzZ+Oar1crCrBfgP2pbJKfaDk+6kDd87U99FAn1hfbS+sb UlWHHLwKY8mMp030EY7sYo7Cmk0Rz/NPLqOdjWCRO51HWB10mDhv++mEoZvFpUNg5zWGnMgfviMH 08/J4CIurtpaaBX1Kn0V7YSmYwWKwZT+yI8f8/kTtr6v6eu1fM6NDus6iRs8OpjJjA2HvGzngyC8 nKp66Yh/o9M4BV6Vcds53YlidaZeD6ID6+aD+0xqMtmpvdzUzMkWd+/39auurvHd7t7sKy4g0MQo eME+9WGqn5B1onKVU89QEhWgDkw3q/ruGJFz663iNlxKMPo4X69kSJ8zFHCAVFgDaEitSRz9R4E6 xRNmWHwwW7geoCcthQCMxq29AAAgAElEQVRLCAhWx3LELWG7tzJkWtzhhc16kAcGuS5vo6ThMp7C UIkUUsfCTRPIZRZ1uihqJ1wvGIfnV6GlzaBrvwO/cPAjIwYaAA14XqoRcbt8c48es9V1dggQdxn8 Xb/JTBidQwe8hxjwvf3W24RAOgwu84s05dUDjNiptsPULqbQ2gKUjqBsD1xy7F0Rrh+A7z7vZXz8 5FYyNXGgteQrnehQzHSit5deuswzWMdyWi6BmYpy89ZNNvy4ySYks0ulTqIdXEbgYZByIF1loMzW 6FXZhdEmwY2DHYPuaRLmrokyqS5gcN6H3nWnobQyGlCdob/3AD14d6E0NGkQwS8sb4dIqXVe9V4H QGpchxO8Wl5OFbmBmMx0zIm2sZwNTjKRXAMJjDYWSlmCBi65sIHX+QNnBibl3sessTmpF4AClvz6 MdFGXn+iR0IyaVQyaCB1y6HjWbwBc0I5fcjKVWBREKVRX2QoP06b7qfBMmhEHdqD3xiyMhofw/lK g0xlrKyNEnRB3RdguDLNgEhAJa+hhflc13Fhuah+dpA7wekIfoRTYsA4HzrTsNH5M3/lwjRpWc88 TE93lk8GdcYX2fV9pZLmwMobeoe2h/Dqc+rC6KMCGEis1Y2KcgXs0BlMooxPaXZOPr81vJxoE/U3 VpVnfABY/X38RtjBCWT5XqXL7MVVBECDUQq8MLvV2xp28ouVlveTzr/Cq+xq6Cv9BbhH31zrh2VV ib+WGc/Dx5SBFGmlOe1gHeEKwmXLYg3jgMZnvKoDlbvpV0DSZoCrrsx3ln7oirIQg86OsKnEaZad PqIj4S6bbqrkxn2+Fuckd97m9TRyod9AgnqtrrO2yR1phLORRjjvnEjz8D6fuYJh+Vl5ChodzJKn FRcyumHSuz/9hDi8u1x6nlE4sfGtt39Gw3FweeONlxu8fePVV5e33/kRE23Xl1//F79d/P/jP/9g eXjyNHst3CguqUeP/sNM6vKftubXwYYn5tuBgDPO4JXZ56Ns7OTkbx10fKHHRpD3FDsbX7n43HKJ 74kTO7BEaf0RpNYrY26Tv8hYR5PYaDxwWbD1rzZPaHxS3RmLfMb1w4/ZSOnWPXbSZuk4NG7fZkJ0 /6PltTdfXf7ivS+5Q8reD8RRdapEcqpEtoH6vYOWHQbpp7lb7Cv3WC/FK0IOsjsmg12+DjLtxH7K s7off/pl9NwY8ijLjU/zzf3BZ6e3GX/x4xwOa+rcQtG66bN+6qw4Dl0ZEUq+DtPW1bbQwXHg7eSs AAee3Udv7ubNLtDweBC4Y7yP1420iIy1tdV7JocvfOvK8vyLF5lEvbf83d/5/eXv/8N3lzeuXKJt ZAm5zgpt//Qjf0rxxPNRTv7unYQGXvJqHSU//1uvi0nxP1hsq82fK3wCm1pGCqZtdWaeoSMmkB45 MuQ9eBLqXKm3PZ4GR/0NYw80tNfg1gctgxLxEf4JHLFwAySLdaKxXZNl7I49sYxyM1q2QGWElVE7 tbUFUMHr0C9pq3x28otj5mHriWUYAvrtBYCvT0d5lV5c9O8s55377oJFR71SzHrDUkgP76KNRUwH FiHmd2qWfNvPSzYgNxtoH+vP8I8eGJttMsq38Pr5DO4H97R30/5AhQ/li9nAgk9cGw8bH16PbuAB 5h/7GkjwVxcVZtURzFQ2fNLvMziDhSFpSkSzhV9Zoa8G5LMlycRw+3f2iT2kOR7WJfB6keUH99bO CGOZ2tbwopJBoWIqnGxyIRuxTt2lbrr5lrrwZtTcrHhY7Hnoc7fwosxP8SEn4EJFefnadvz1jr/6 9ituZetGUPyLW45XnQmk6wSLTmJNhmSxf/0YO0+cPc3E2zGiyV/1kB5ff0ApB2MR+s/cgb5FnDh7 /tBy1EHVIXcFpl5IBabUkRvNxhe6RuTqQ7HGRP9kEzm2FTkPSdh8y8zxQ9GtlrNfv/JjUb/+U5f1 HfZsqh9Yp+hzuaEewc54NHEfWAsg0zwqBm4vuZaKfIvTmNSyaeqe4MZc1VCsAqBz6cvbFAkGies/ i28wqjfrGJxT/0LuFb4iP5vf+UimstteqT9tbyyQH/uT6kAObA/ky7u30uiutHoxH/xwC3ZQUM7v DmMj9XvTTSdpB4/xmKivqHMV2gM2QnTPCG/KNZEEbekqvxy7CscYBiKu+OWQZ/HWF4+jqVc+Hejg WR3WV5Uf61y6hj/K2Q9/zKNInrduZGMSSJgHCMQpRMdGWCtpMxPkDxMozkFU7KE8aqbwLQGivMQF 7dY1Cnapk4FbC05lGqVZ5gFfH/LWCdpwBDA4QESCM3nyYzDTCeUTbDU2nGqf1FwbIB1JaTcG6srb 8z0OGFFAuChgeaUqkMqTDiWyNeDWeQdXAxhlQhCDyicf3kBxD2qUr197sty4fmh55y8/YwnIvuW1 F5+nPGXwK+mobIfoDcj5VTbl8FkKPIWO4JFksMPirLqzbT0/gWF0LmVHUX3d0VljP2TjAIOIsyY5 GJXKZ4KtUNL84P2fshU427frlHx0ZKilbztxOrEOe5AlFrt0PlSWd3Wc5TddnTi7Z7705cJ/2rKO BPDGFJcnFuRBjlr5sgumfJNnpdu2QlfP+ZVioOP8SD1zaEsbU++sjqObDoQIwWGjiN/yH23oSJxV kobWBlsdqU91hOipCqAOISWzNZ7KIA2fEYgWUOpr/FB1+bwGA0P4cXJGvyhAUUYYPcaAIAOmi7xG izx5LWO4S8d1oYGxpEedEIqJS72pEzuU8jnHhkNg//gX/9CMrHCW46KK3FXnCUo2XNdxkb94RHl1 UsRHmv7NX8FLCvEAP/maOClvmsfoRZ3HTHYwfcsvkASnn3BQLjzKF53BY1b6I916Xn2iglQPsrNF szT0wyAXJCqa+rGM1WV0Hin0J7ejO8/kEjlWfBWGbTDEi7p3bAIj3fFoggOaLXvZbCKSGQUJCIoQ VH4IzDWZHYJ7iKtOtfoj/kFCgcpLRnXRlXnA2ChjF30n/a++hEirntS5KEyAJfKLeaSNdgaPMNvA Ohjw5evSo254NPiSphys+IeO+nQyBB4oJyEHeq7scLJOeZyousvg0X0C3C+AEVd1Xhnq5Otb4l7l c5Iun4Xfzf6Q5Bj8MqA+mlGXCWIgGMi3wwUv8DGq8zUHu3Rmbi1v/fjHLAV7ZbnMIyPuJfDW2x/Q gB5ZXuNZz8MM0l/95ivLu2+9uzx5cHP59b/5BpOR95fv/fDqcuTAaXboZeDbckjpKH/cxdEWM2CU v7GDfBxlN9+jDMZ85EQYN21xsMVNUjZbOrZcuny+nZiPQ9tIlqWsV8RLgnsTJcaN8XP1j02Qq8EF cbrnx0uTDfiBhnMHh3g+9cvrPE/LjPdZngd2AtVYfPjg0+X1b720/N9//h532xnMMqiwTHWbAas6 ZThO3WZykjuo3tHdz7nsqMNdbLqLPL4z+AbvQP7w4y+XD3jVnksuvTN99DiAq/ymyasx0HrkPhbq zLtC82jM+JT06yTTOXZjLjdobNdu2iCXvrtEXd3sUF8PcFdpF9se23UptY8t4cO08Q58j5B+gDhO JUQVLFNkldDxs6eWK6+8GN7f/d//ePn3/ovfW7558fn0lr4MAXWurBfWpSybHuRdvcifdnVgp493 PerufPwVW5gGp/Nc3PixMVK7q/vQACEF/dI6YaLlTJvycsUXXqStnSHdscHoD+Hit1UelHhU2tB0 jw6RiSfATqg19kP4Nx1l+IF8mwtBQE82pnlsPgYHUx5c8rrVQTHLkmU8MaxN+2PZsXn8VS6UwQk+ uqM8PmXBcGIrZVLObam3cE3SlWjx9aOLcphfm665kckBYbLie+XFL+WoI4qffwO32TT+zdgOaftZ 08zfq8fwIJ8ew//k2Qftrr2F1q+Tqupk6wekH8puGpv2ZCNCuvADpJKlwHeNu6TXFug72MLBhTZK 16u+nFDa7KZ95SMeR4DR7+obDpbcRNbdx6XRxpXQ3GIISiKdOA3OR3wf8Pz9PW6a3OPXds0Bbn3K 6rWxSni1ZqhyBSGPMIAjf8AOyrrdVAFkbMCvqhy5kzx+TfO7d+geJARrQKsdVR/2BaELkVNnzhAf uBkTTuuEZ3+FYyPILy7Isb/nQG8yMXv0uXle1juoj9URVcrughzbJtvGVSfgSw0os22l7Zj13edK ld3Yt7Xnlhameo/+59VhmkzbGuGUT3zK4rUxZWKQepZJ60krptCJ8OpYsaXfpKEcgsNjYhc00yX/ sI06MttNCDU3xUYWLvZTh7yRZ2ll0L8p0Vci0RExaY657N961G+uvDiGhunSUgJpeGTP9Vree4Wt MZWxgnSAkJmxxSqD1pYD32ziYRmzdln5pY4cu6gD7wC7wkkmXU4v77sOuMGnTh2jiD/5Vx42Xfir TA6wLSdccqDjPsoKLUNPkxDm4wzmtQpFP6dtM7ZQD1QK4sllQsymFTJZhQnZZJmdAVs+AxPkWfls wFq7jXJqVmSwyu8sIWTjEUUllAadoDe3xB3IuKQABik/fCRf59EEX3dgdDIaTAVJOPFyLv8972pw 4SPfkNAWCd7W3EG5LHtmzVWiStNxIEzDwsCHWbJnPNekXFWOKs0BKtmj5c++90F3em8zw+Ss2WMG uQ8e30c+3jlF78i7tR7OYth5coaj2X8MpIabOeFX/YzRUD4wVjwr59OnR+pkuPzEZdGucZePZmsp o5g6TJU46cVEBVNm4HYOH8PYUrLj6jKW++iKQsiYTVCIja+zNh7zQ2Vd+ZTWtvnVYXiyAyZ/Vt52 TCM4ADKOZoDnXCe3ozANtANiBtTITtZqx6m88tfdDsvzMSjwo1TDB+nim4LzI4j5xTD41r7yjFsO bWmgN31JKHXhdf4MjLupeoQ3QniGfABjAFAvVg7TrJj0qQIWh/0xNYkT8GcrZZZw/EJrJnfkRfnI R882EMFQxiAY9+nfM/1TJGKK09GPlx3Un3CRh8NXB4CVz/BS0OLqzobNyRLtYn3a7G+9tEJvvOyR k2Pk2yY2xJ0c/FO3+jl/s+Jffv1T3+D7qkMh1+KRBw6RI6MYLKtsStUdiS2bXzTSlbyJK/5MoVBx BP7Fpd5CSV6BjHxLmu5mY8OzOISSGHbX7ypnIzOwG0XLDZxckSq+0kgVp+VIG98JHXDajDx4tcHO R0TDYQfGuysTTEdnotM3ZGnO1Yfl05CELEneyCiQviUNY130hUB59hXiT9G4Fl86o7z1xgR5Vn+j U+AgrO09LOvX5+2NLTXKpvkBV1pIXnigI2u6GaaHE7pObMnrTTdTcsDCktg66zSysJuubHA8gKS8 /2XYhM6iNXomn2N0LBWAEMNd1uVNJ1IX8mYbAKBI4uvkiROsHLm7fMTmVodZDnX25C53dR8vf/EX bxErny4vv/wig7zjy2uvv768/fZb2eRf/htvMiH43eWddz9dDp47wQaD3KkmFtohnwHS+BNM84fM fFxudgjB3GDQgeJBlsbdZSfJh3Qejx3dWV554fTyykvn2/Sp968TEOS3zsxaP4wZTvjJvagVw869 g0Vntkd+87QfHX41Ubyi3RQYfdxj2dfVL75cXrx8DvkO94ylyrr0/OnlGRt37Vsur20AOqZs7QE2 Fte508/xuiEmBh7eRlfc3WVjrx3uqvps7hMmmD7+5Ivlvfc/5FEVZ913uZNPxwX/VA79yrtCviVB fyiOk+ddPydgvfaxGydQvJPrRlvuWC2d6STTdjAhIq79DHjdZ9oNqdj6aTkDH97dMQLfvHcPGJ4z xq5nWCG1y+yyc78eD1m2rN4uMZlx9vyJ5Ydvv7f89//D/1mezbAdejQ3PmMZ/MyPFlS3HrWxnKdr rrf0zVdT85ovsa3uF+O4tr6ANjlCCFr9dYtVXo2M6j+I/9e/oQ2Kygkr7i3mCWxecUDeV14mbWK8 8dl6MyFDBMQH+OIHgPlK2jIT8zghoXrcL5cyJw5+xRc30rLOijI9mqwPTT9r6r78TywznvXcG3Vn ayfFZ5fWj3i9k+JNjvprpOnO4olfhQeX/2bQP9fWiYhIB78LFn5UvLq2ToqnGEYfYou9yrvpS7jp FIc+PA3KUFqxET43m8UzeDa57BeJy5o66jAOQVBUAElX+1itNhFWtZUni/xRXmFlm2AA77W90K98 uGzjbLMBkzgnW/9AOjEkLQn7n7+Wh/IbflmiriiHK2/sB8YnNNyTxXdd3yftDhNy9RG5WdLu2hST bgipw8Yo9yQggKPlejLJZ+ywo1OfwnNZpJQntVtzkX1iiFx9sjYJwdWNsu4dMp0e0Z35XkNRGMv4 ftrTrPywH+lhya+VLu3/+1/IyNY/sZG8SAP87i5/m9WN+4+AjcbTmzoOclmYoFelZu861seghPNL JYoFm2i+2uJsTxnqw772IEAPwUjLY+UBMsYTy2jGqdu5AukrTejV3ybfNG3ooGv6aaRhF7HVh8DR mtjS54CzgDj3M8j11X7WDxWvvZKatoSTDnUhHg+Txn8401Cl0Y8vxpu2QnKaLmRsPTa/nwEnMRle 9/FYIgxlx+gog868Vw5+xCl/tQ/qbe3LkKR+rN8yJmV96qk39Fgpe8zVPrSzDp7l9TqT02quzQJZ 0WXbpv6soz1mmzzogDZIhuRHVYncfrCHNxG0V25Nvmx6Xb0DD+RjZK+fL1PgsCXmUOkTqJ3pV0Ey Y/rEBglJmCS+doaq1ELI3CqkwU0YB4IGTQ8Z0eAtlaGTJoMVsJAsrl6qUFYOK4x4dG9pSVJFiEPQ J9ATpuAvCAaILxXuOdDmSdfxiEbtLkNBUIRk8CfA3ApHsZxbYXyexbxeFo1qXKIifrdlv3bjfsuS nV3b+DT4KGfP5xqgMLDnDnx3GCT2fJe8w2AOoDTQqqMEH+q2YIVS3CxlHzPhPk/2kOcBHvjFWZzh sxHwQftUCmwPoqMPctLhITsn0rE2KziybJsOTJgADGIUUSGcAw2cZex8PeQOcsGMPsg0SPfStbbS 6Tdbt7yBGUgDQK91suOIvMdZp3+azWZ6blSnVzaCUJVXktnGigsubsWrC51cVvcaMh2bT0EAI2j3 vvCb73E9S9yVk4LpVF0QKMDFJfBWmilYcBODGcrKb4OEvWvLoBCu809gWo3ADtwFJkgYyJUlcupN fdCQaHOXeLvEVVkcBE+lBAaa6kkfnI4DnQy1qfKlhZxzTBlxQyHYyV/9G3if40mHwAhVA0iB0R/a Al92lC8rEgaTZtvaO0jDZ+Au/5/gKhshiwU3DBHHLH2Ri1gcP+Ncu08+WDznoxoapPFPnJaJL8/g IcspFIdlO7i0c1r9DOfkybM2iwaA+QJFxDuDIgquehOTHFaf1QHX3bGVAGBwAwIDqgj4ksZfeKzy e3Q6t9DQKZagk403dajv+Euh8OVTFthLEpt881UHWxnJKju/E8RF4CFO0vlOJ1QY7Wgap/LboS3w H+HC7/WKk3zhjIwzgYH80gageAeu1M2/aIlP3MCHXZyW5yvv8mzO6GYat4fsnnvt+ufLhQuX6Pyi A/xDXJsfSEeMICIdW3tZyviGeD2ykekR5t9K2/BqUn7Befj4bXlldVjc3PHlru6dOw+X77/78fKr LPM9vsvrDB7dWd565yfcwTzBZlcX2JCJTaRee2N5+y/fWo6xoeBv/Eu/zLNd3+254OfPn16u8rjH I1755l3fuIpn7qCAyxn0XWJmK2WQ4+6928u9mw8YRJ5fLvKO4MsvnGBZLoNEBnu2EcpppyD/rr4b E+dOqPzqH8bo9p9Av/qv/mSeZesYAOS5sGqrPPIdfH7+5Y3egXuIQX6vBnx2iDu8p3rVh3hrO8Sr 8iyNjzx//txynEHyfV5X54sDHKgfgeeD3IW9c/cey8TfW3724ZcsYz6CrrxjL//6AHzCux1obesS PO02Nsa3SDvFvhG2Q3Y4fE5/h4FuE7nQ9fWAPh94hJh3kgnOw/BzmBGqdyD058N0buzo6WdulHR4 99hyjI29nmOZ9XH1iDyGwEf0RB10P6++X3lhucpky//427+//N6f/nj5hZcv07G/Cxx6RmH6TXLT piiDl/KeOsxaD5LIMK7bLs6k8/QJvBbD/KvedoFtSaoPA79Tb6xHa70q9kCfvANMivwzBL3Efvyh Mycjp+8DNjBas6xjne51BPMDCugf212I7pQCplzit81poELF1DeMkSOx/QBlgxdi6deP4YOSyaQv ej4y21dQrtGNmLS1Xughr8oxXynJG8KESzjzgl+LxMt6PuSEnQRpGFfmUt2MrNLY5LR/KTPqJroI bR8ngsFtPFl2s8ngEt5DvLLu5L5thq2BpbZ+Sr6xAmfTFb72hnPt62HexNo5l3Hl/6pM0kLQP/1N 2RzUwrzfBqgyBU5tis20gXVIOf26QlJ/F0bcxtvZQA1a9ZFUtzdRvGY1AH3Ie0wUPbjvkmTOmfjx +VBXCShGvGPTaQPos3gzQvRr39mNetSHdTE9caXf5UcASl/l5+OWUyYQQ71y4YeOOKTnMXxHRWhS xMl/YmI8wY8rRNpTxhhAPHAFEQsaeRXdGfqItvOW+nkPobfvFEyWfHonfdy/z+s72YneuuAO8PZ5 nECdjciI87RfgkvTFZ+YLT1wFRP2m6YfTnurrqQYk/3LB4wTfjTg5GuDyR/fHFwi9Hpwj5Rzc037 jC024RtiQK8VAdhKfIOT8mUOzQa8oLIfraupcP1S7NNujt20a/aEQ/EMqHRnDNbAEATG5+oZ5T32 aOJ7sLN3ZFN1BTueT/8cAGGcLODHlavy4rn53oTZfET1OI5q4E2hu9jJuuE4wbbIsYorVn2MxTfe yJ9tnJLZP5Hv7r4znjKWNKEBzhkTTkxzgt4+NSyEW+tsdbbf5LHtEH6rK/i4cQZcPNPrIHeeZVUI D4OHQmhSG3JUBlIVp0qHUOekpXMTYf4R6wsMDLBdw6wyU4JlUG74xSFuMvzEOfky9Dh4Uq3g4LNh sLy8SK/KrDVoiMX9KE8WBTMG8gJcLzhGGzZEcmvH0CrdwEbVugaZhjEZDXI4tpDxphh8uyDPK53D IEadZoBoEpWba338IY22S5+BwBF4B654gHdAdJBZDfmnHjYINr1GT8b9A4dpwcPjLAGAY8vwnMIR 7rQ8esDdX4yvU9yBXpvOIPMBnxOQF8FxomX/bPRh5TWQyv/WqVVOHUraNU7rtZXevGa5HCxQaGQf +PArLnA2sQVmdOJd7uRnYxdN4SzOSTaZ8QF1VkoPjabSRo3bBkrT0Rh5m3GUH5QoD7NhGvrlevRC 2XjT7+BKeSBmwFY+iq7+AGMcVgDd253sqhbgMRiMu44+hLPyiRdkQofbQcR+ZjwauIZDrzFXstio E/EJry+6xFw85uNXMWX64CYZWP0f/VYW/9JfYcY6sHVckkuEfPUgcWo/j/LCo83ISy/KDC7kktdZ MgVPBAk7jw2WrCPg8+PugU+5tl5YRvtJiX/xPvyCUycicWq71M3X950dFx94wCnUyGYZ7SAMJVUy Oth8edNLhMhXpPQgX4nn78isLuRVXWVUC3PUkJGm7B0VVEsewo4Mcwl/k6oRgNFqgMiTJcK90R7Z hFInBWzK8FeDnW9IU5mAcaLJ8mM7sJEXOoTabGSCRaRp/XIPBD9NDKrVLXP9zfeBtn6OHIPTbJNM HJ2S4J/fQPkXX6PPQI2PlHBgFlV5JU1/e0o9zd8HqViHyRVX/KN/eY4XMF378ks6K7s8y0tvRQLU J/n3DrJ1HYQlt2MkeenXZGE3PcgDH/GmT9Hog6mUEtZjcFpkPIhr+Jc/083Rdod2D3Dn9hMGYCeW N159ngHqUSYeH3LH90ftH/D8eV4R9Nxzy6vf+ubyk3ff4e7v6eU3f+OXlj/8v/5keZdHUZ5jWfDt 2+4m7TQ/nWMHujSy3sVW9mIanclrn3++fPMbV5bX3+Bu48mjvMPWgaMNMR0pZO6ZI++CgyN9GrPg cpb/zp0Ykvbqv4rTZh7ZkV/L2Q6hiWiPlEIgLfa5+vmXvYJjd/dEK38e8cyay4NfvHJ+uXr7AZ1I 9Km2JQSO8+fPskz5IMvQrzIhsLOcOX2WHTGPkXVwef/jz5d3f/IRd4TYXZ8NZLozi/JbDsndIieK 9GcntY1p8uYkrUvZd7H9Ds8DQBr9aAnzXPL8ZDnM7dkj8OFkwS53BI65GoiOjI+o1AE3xhGLnqGr x9j7ge0EFd93ALsp2EnxOqNPW6ZNbNd22Z/iyhsvQ+XA8nu//73lP/pv/3D5FjtWO9m7PJ1NTYro OlhOhvz5Ttb4WtLoUY024Yh8qwl0S+QYW2h3zVA7ycn44fideX7VjZMwnntEGl/2mA6gVlM3ExvF bhXLNMJrfK77XZnwfOK7lWDwis9zyZQPAuuAyGzvPYo7SkJytQpbDCz1hYJ7/SR4FqJ6FP+TL76Z ONBnnTzR7ye2ib84j42a0JFCONWL6EYH0ouOsQCd+a0fI0/Af72eJzq2x/BQmb4QVOQi2E2n2695 iQeeLR5OWwdyj5WG7FQDoa1OorvqZeDUkVSUCX75FtdM4yv/xUXya4uA1GaWUR5/PaTj4VXtbMni Wp8VLNObJcpknR+d1B8SDwgOMJl0nL6f/R0fHSgWQ9T6Czh+74rCWdo5d2sd3Lrpqc843mslYkv5 kxhroU/bx+QmTcKya7s8v2N7WROGf8mrvyQW//zU/9ZAntOH7Aw86kH+PZws6jFG64hxWihdH7Rz o4dzYB2UtOKFuIHhGNDMikC14hJSN3DaYeLLZfnuNeAKwCisdKT1zzuiHZfwQGHLj9a5683Npnt3 7jBoIlaD+8kzJtkaEEMflhwgISV8cwH/T7iLq39pR/3CQ79wvwUn4Y4IB7y+YN/jq0Ov87BOoEWV pQ75jiirr61+IM5NRHXicl4R7OGtvMXHj41VxmUwrvLhL7InURsfTsSXD8m3F9qlUy281rEtz4KW rZx2WlfemoKM3Wh4cMEAACAASURBVKUFR+IGqEz27UeOikfQ6xFVbPU7wTX9dq+xuZOcFGjACpLG F/i5v429aA+k95CVTPrLDpOehxkgKPNd7CfLB5jkVcwmbla5bEvUV+PO4h18cO1XP1W8RCQeVTc2 HaQbbU98sj+PrrMH+KsXCgI/+je+i3NSObsLBsMyRbFmnNz5r8pGpyeHo1B2g2qGkzwKKNAYqPUd ALpDRQkHgxLSCWXYjSxkSkXZgIB2BJAfvrPTLyfAPqaB1KgqQXnUUmW48Fond1MpTDuBjMZWGg5Q VaT4bLCEZYw7sxwpkQvotySXa/MegTuHtkwF+Uc5ZVfuxnAmkWnA8H21zmQ/zNlFN50faaFV7kbQ eeCOgkHEd6CNcYaGO5WpIw3ioe7SB3o3RafxuQzQLIeZuX/mSJLjNDtfuiOyhzDTKZM3OJw628yg cnSp8QEfRzfFwGeC37UANJoRLs18cJEmIy2z0DOt7Gu+dIdJdL3idym0PqPecmBnHJHRzY2EmYbB YtiSiORLxg0806jozNgR/ENCp0xCrqciFpBll0MYhauhwjLTCZzOiBXQsoqoX40sVnBtKFK+ngNk QPSjbhwUenSXRiHikdyKiGw6IF63nImkPX2I1XRh+JU2Gssv25U4hsW1dqItK7kawYFXn/q5wVsk 0eW32fqCyBChKub/yj6yDd4xKUg4CkAg3HsuXVgZkwayO/M1AVd4vv7FEBwoh/DqB75Hx4IApGIt YuXvUHfa0usgRDS09G3PKDLy6IcapKvO9Yn4Em0oKEEMUq7sxW9BOlnV6EoHYHlTBo9UKZ2QeDKw /c9/ZHl8QOrKlO1W+tGoLLnREsfowV/5mWOVcZVLP98aT/PzUX57ibw6Br9pBd4cUp0CsH2VjwTR C2udGNUKMHSzMTDWk3QXAmMctG0oYSLTiXT+SEdyceM36kai7kaZrgGKpumDMJn1eweEj9lYwl2R L16+zASf+wHo98akVWeyBq+Wtb53INtmC2VNXcorRUBnBYFloE3ZyYnFeCsBWGO29fcxZe0CGA+e 4F/ePfju9/6SAd1xlv+eruDnX9xgE8F36VDwGpzTp5bTz51dXnz86vLxBx+0CdW/9pu/tpz+sx8u f/L9n1LuXHHyARN0th3dgUQf95h9ph+0XGYJ8S+/+fLyMoPLE+zE/JTXBfmIy1MeXWlpr3LwGXlG Jh870WYtYfYcQXHd9ZiOhhcjP3UEejM/hH744Gb4uOfaxTq9j42s7iy379xn1+YTDLoPL3du3GJA +XR58YVTy3v/9MPlKK/Ke4xND9AjunD+FAPUg8vNa58zSD/Ma5MuLscZ8N7jrtKP3726vPPjjxp4 HqPt8E42UYG23J1bibPwbRt8mLbJu1K6lANe74r4fK5cObzWuru0K0d55vgY8EfIc5B7BHvoEX4t 1x0rfEdETpzrj9ruKefu6H+Y54qP0X6doAO4Cy33uMDTDVTLfpTmxlVnnj+7/PCH7y3/+X/8t3tM SL9lU2kO9EOZYowVmqN2VMVuB6f69ObXuSdMNMkoH/q+ftc5wJXVC6ecv4NtrGx5rTKWMW8+dh6N YdHKz2VMfP4AA34y0crglqYdOfPVf/RjbqVrca57Nyjlh3+u4Xde/TK4LV2c4TLswprIoS3RSOcz SF9xa1d8fSUefyM3+NG5rMazfPM13sqneKMF3nl8xzppjOcambfBgP4sZf9TfPS7yU2ak6sitIzE vAwOvmQ5GY1P6kuQeOWEBshBiT5UPBV3NKTm96vDciINh6cgloY2kmwTvNIm0W8r+vjdhx+HLR7N R4r0SD3ExtZLdWnby0XaTRrbEsmLD1kbVCWXqdYa/8uUeYGxysQ4w4D26bzb1gGWk9OPSLvD63Zc pjyDMH0Fffilo+kO+Ci3Qz+2M6POnlHftIg05HOA+OWvNkJrcZ514Hfa+pErri0CcG0vcohjz+8M YOaDXp7scx/yfeT6PHC9n9y6r47S6+DNJ9BTy5cpT1HiCCs9hAPh7gk3LjreqkPRr2JFSm7+eYd6 BSvwnPkHbT+PWN5899YtBk3e5TYffmSedlR/cnVD/RcRUEbd2p61akdoZKq9tyx6VXj7TqM7Ljn0 G9P8VU/Tj7R1kp5l5Mf+raWtH8Z6crGVOhZ+2lFxEVPXG0HqzxhJ4srjaguxWD8pF25470aGY5Tg SUUufVMubKG3wfCIOeXs0wq/Jz/J2rD+tHqAYTc966YAsE7gxC9tQP1mWEsWYnATdaoL3uRXgCY4 lVm/0D/J8t+8OYaZVmUgedOHb4awTu/yyMsB6x/0vcsruvbZUW40n4yr/XxNVnU5XcCf4yh8uvEf tPVRVNoeSlrWP9mQJ9OLc052WwbiWsx85UR67/RawlkPZrYh0gPLOgLJOkeOYINbYRtwmi0VSb4z tlswdGOGfQZ6sG+vqfEVDpBKIGfaZsALHAquEUGdVWiEqJHgWkfKybgja8VVUAkWIBTEc50RvA22 FF4qSGu5VKjkiso1IkRrAp8iqQQqBkF4HNDSfoVLhcmgXI/hReOQUWfhGU5jN4JVJy1BPgQOO0G+ X9hOhRFPdh306vQtj8ZR1Y3XyWCD70cDSRQCOarnHFbQHWbSFWGcdWTy/yzbQk4/ysrX8j6fdoLl fjdu3OXSHfw0ODSUVUTwMJtSKD/lSJN2zgyMxvTjMf+3X5VXsmQ4rEz8B14e9hoNG1qwicNNAR4/ 5s6BilAHzu5bmD9JicZrnc+rPTzgEECt6CfCHKDjJSQXEs/nQDEl8dvkFwJ56uioYz6JLG50KQ3z +fEPJIPHk2kkZ2ZJSDugemyQ4I87eJpKr38JAw0rTzqUB3MtrbhoASI1ONh5+BvfNN/yw720lXQC qxQM6Mo8uPRN05AGOtKUjoFMnU9gd/kK3JImLn1LPQ1WCM2fxJEJOGD4k4tR5wqrstRLdR/+DakV 5n8+q8GFSE5JKPuAxL8cyztwQupfBeOAKMZ1QUr+POBBvOLx3EM8HspuenmlTKrX4VllVRcewYZk ygkTL9Ea5Hs6M089rrRCwDnJiRdN6agD6CiPmebXgEyBvXPhi00hWLGhy2IT8ZJM+LP8epc9nsQ1 NOXDPLQJHOU2PPwWG4CfzpxwI8vwKK31Oh2PHmfZMueVI8YKwj/fvYzYSa0vbUvZ011Fx3+vXbvG 6pLjvZdXnrb45ADaRqROmYjid5NBxHyJB+J24CNvvq5OPkxXxviPNXUa0UkDWsayG7pyMOWfjfIT 7n7AfTH0+2+9z8Du+HKO53v3Pb7Ha36u0oD+aHnj26+z2/Rh3kN7vI23Pvv0Yzpdh5d/5dd/ZTl1 /rnlD//oB9xx5NUZ3vaE9IMDzDrv7Ot52ZcvnuG1Q8/1aIbN3QM6ovLhcir9czQMB8jRkkxYNcb7 7ko7A8Yo63m+TV4+Qymfy50Gf9I224E8nYTXWKe06MwOond8bt2+gyrOM5hnEpH2cZc7uOdYGnjr xlssEWSjKhr+Fy6xc/TRQ8vnn3+6nOPdwC9curCcYGB5hztEb7Gc+f33eA6azaO40TJ6JAbNpifz fJ0DXjvYvi7IgS1qhj7+BtwOcjq4PcydXJd1e3fZrwPdHXRyiDKtGtEHKGiHp04L/Ntx1Fa6vba7 d5dOKTo/x/PVxxnwHiGOG2eKUeqB138eO3tyeeH1l3i26/by9373j5Y/vf5k+YVXLyx3ubOdbwJW TMRuGiP1cTod35KqHyRlt+qrPphDmephXNBOEyP3bCG34VzrepDyPv459QQAZUUv+rA4jJSuYhu8 1E/8IJzoIJOSYyyzYzpvtSih8slULrqTuPqCN5I6xBMMdOwrKbPX21Fbu15Wfs03xkw8dVJDZVGU GPZ1eHFlo8pv8RUdJJ5l0hryWYfnPL5Sunu80J9IQPW21mdKNQkMfHcF1ZP64pBtY4g46vPB17Rh 8EGP2Hx1aQy0H9YBuPXJKzvN9c3Qo/rsj0LyNraUDvojY1gcXZpqOZFs7SGl1wNq6MVJPu0jHfOs f+o5W9DZnolDy6MNYpUw5RNr7TdCgHrrTZmxfXl07B3Qugru2rVny6effUFf7CZ3I+91A8M+kaY2 LrZyBJr2sxuoiRV7G29VWTWJOqmOPJTZR9XI4mu6XKz5CqHezHFAZBnwbP67+UDtDDx3jRzqyL6O Pmc/13jV7xr7nARVL6pSPba5KfDSdRyQblWFaSseq4V9Fl3XCTFjhbvHu6GeMnjIniz/PEdwmxLG Cmsx3i/MncLH7DvgjtPq1HqY3aHjhEf6gVL+pL9RMl8lLV1kVzVKFIbPbryAoxsgAOuzXz/G/tCB H7+1YQKg0/j036pfk9Vr9lz1OwNr0yfPmxLGMYDWWKBuwKsu/fDbAa3OFaAjBMlqUh6pbsXH9Ywj tPPUi4qsZU3LDuGGBtdzh3d4ykLC2j8Bp+zheBDhWkTk7clPvo+D6rfyV30CyLpT/0efwmd9vOU+ j0z5qMwRJnNd8u6z6beYsNh8wjKFQfDbb+zGgU7NEX7so1NtMDJmbIXr+GoywXEaKXaH9MGutAcf /cHYYz6iUBzftCHfU0aSTuM+y/RALiKV4MdoVHEKI6wztzqMjDT7L2bO99HQGYxnR0h5nkCnYyqY B9kxHeuUK2CrOAMkSnOm/Wm7vUqbQAWtQpXBJ+4lZbCwgnEubQ754rLDiuuhEytPNNChM/4a3Y8i 64TTGRWReAeD5SQlnATiGR2oQh5raknKIzosAklVR95lyYXl7Sil1+iM1nJNcDpQTn/wrk6UZy9Q FZRgmnT1YOXpDt5YFNrgckDFr2X92Ai+cOkSz+LNkMXg6zvSfL+hs/yuoX8IzWlgpGXg05GsCOBf PcrZmmQlvcYFGh6qVgnVkWUMkvJX5QCXAFsH3fJ1eg8jG/zvo/Oq0ylfu+QVoIdvZ1XzLXBtAQqp RM13GuBhYKXBRTptAxXh1F0QK4fkU1/SDXJ5bDyPzOqMcvAjkSY+4NfGMP+hSMuCxUBa/gL+Kgp+ K1/TkKi/wa9B9PV8Ulho+syDsqmXfKlyXJDrnX87aPqfRzZZ5ZhlTdiTxsdcG10b2I1flDj8A++0 j7KoAFFZS/SpGWhFMP+xTEEcUJnTPkBmd8t57qAGavE6A9Y5F9ZPgisYRzQos9nbCZDyJ3v9D1Zp WX8sx1c60ovXYTsezFHP+T+g3fXTN/EXbbf5h3oUzjqhrg20Hsqd/bTpxiqwK7srv0ix8iH9DUc+ Lixlvxrkqihw6xN85c+OkvS//lUQr0HHsf7nR37rrJNX3YbD2Sl2YIKmrLOXTupoQiDDoo9K0f/x u+I1czqEAwdqyPNvToCSF9L8xxdNyR6n4h9bN02YncdvUC1+Mfze57UWN67fXF54gd2RGfjIW34O XTAOj+LHJl7Lob6qHaRWSjLZ+Zh6WTJpSJoPpwvzjDWkaW9tF+MwIz/aQV3VMSHBpV/HmMz70Y8+ XM4/d2o5+wtXGJSN/T/6kAEuA8SX2fW35bksoT1/7sJy/csvGJjeXb792gsNCH/y45/RAb3XLsZH WBL8EhthXWS36kM2lMjJlCV13tcVzQaGypbUsPaU2OWzrw9p4/S3J8RV47q69asMtkvbof18nca2 CzSeUNZXfsIlMOpNfTjR4d0dd6i+SUfAetqgFx/313dc7n98hxjxZLnw3GkGvEeW6198xo7NJ7jz fYHOxGHuELPkm92tP/j05nKE10G4e7J8+BwgP7WjbiizSzxuMA7/vjLIR1SJUstRJgl8V6/l3NX/ EP5y2IGud2zo9NhceyenWX3wua/CzNCPplqaJs2cSVl8DpGdr3ncZZf0w9hzh68dU304lYDz0uuX l/3Hd5Y/Zlnzf/Bf/97yLV7Hd//Og3ifugqD0CuuqkV0NdpMpSYUP6zDG4x6tuLkYuZ7jU8J4yGc OnHX60Emxqk7gpYJgKf+2+A3/OYbk504MP55THvUaTxu/ByECTvUHSLnq12kL77iGry2Sgi4vXoT P4MfaIpN3EkC8eiLMs9fcT1urXNDSp/G0lzrB5FFJdArxkxcSDjK7dVdkQOztTPiFV2ycWJd3ybV VCXuyTF606daoqnSkUc+qr8ZwQt0oM5WO1iPvANmXMpnYDLe4bXXY8oKH3kYu61CSFHlFTXkjoNL xqnxao79GGXe+B8+SKAckjddUZsEnHmWl810Bb3J83p8zdVH+o/vH9Wvn/D4nm2SNzPu4uPu7+Jy ZZfq28G3nbjPRqS32NT0GDvC+yoxfXA/r23bzwTSDnUQaZOjdnSlnZ7hEWp9lX8mRoyLfIEzY/Rk mhOCXGsH89Fvd/tJ1c7ejFIm23LF1A+VaXtLirbouUj7Z6R3F41z4RuAY9MGt9pGF4aYug8HdpM3 LosnjglqYygjj0pIikZg47x5P7g4PeT55ztWTawF1MzUBUs/Y1Ltfpt5HTiJXPBjfPIxw2IqNjHO DEXA9SPSpG6a9VY9Wt/Uk2Vq+8nb+AyPApqGrrY+X7oizfK6RhjRvfTGV9EN8NYHYfXzxkXwYH9P 3/FGjHq2TopI+/qr3dR1jyrhb+LJRyo3+FT61EnKoQfLAhVuVeW3Pjcn8piP6xvEBB/LM+Lbt6Qg eNAbj2p6d1yd6vHy7KE+PBdm2Bt+RCr9JoaxabyjCD/egHHiR/q2HcK2ESEITrJK1ed5HRvZNric v2eMV5rKqf4OsD+PenjM6xKNi9abDhSDtJzqq9p7NntThXPAd/aQrJM4oxv7zgiDvKZbH6xZaMEO oAxO5VSZG9woVKmHIQoBV4cORCrD6JdDqSQrjGlNCqosykNB59IpVGudGhK3DmsdXWCaCbEsZSDR rzQVsMEpRjLb6wIlFyoqeNITDGUFJWCi+TvHzMjCi+nSsLxZ4G1ATsknz3x2lowdsADTu80cuCKj FUUZXFLs4SzffYzXZhvwtC2RFavLxDyEP4jxHUhWFiPSXYhuesBplE1etI3m2KtgPSccFi0Uz+rP 5yQcULn1v46xNQJ2PFxGphNWmZD0ibtBg9vd/W7dubt8fvUqQRl5kac7hMBmByqaz+xVsbkrO8vg 0D3knY3U3jP4sILAY+yMPnIidNOgAHj5N9/nTOc9pvgAHaeWf2NPBa0igd3LjA1OLdMBvx6wRtaW ZqJ0vwo+Xk+Q8YwDX4CNzkNHUv4zuWXou3udEIvw7Y436eKwXEu5zJMBeFXnFpYDr/m38mbC1AFj RgEC/tRn5+jBQ/v4LXiRpx6dmUIaMdV4pKsVTvzNyMPM5v/Vz6ATU5DsLGuTpz/WDUr/1Zd0Yd2R 97iPb5DK1QibfpVBGH7lDePJv0cBjV+1gwuNHPH1lUxpDnSqRr6tZwZMqQydoT0aBmeoSQNAvcTO yp91wnpiDOmO+56+R397fFHIc9n0Nx923s2OKNdTJ5Sa+iW9+TfpBkAV19/4ojaZMugXP9KHTVP/ /lp+6H31q2xmbeUkIYxmn/d0Dw1r0cCo49Wb4kdam49s8lBm9YOvHvNQj3NkLmiCxr/1ZOWpTq4U yCuggNvAL5hKhln1q32d4HCWNm7QsTJeZ8B7mGdZ3aFXHuTM+os1OaE8erFj5ASN5erwixydiysd qVTA9zqcwgmdWGICh6B8PdJLiuPCWC6b/iTcUxrIQ2wodannO91s6e0f/OXywrmjy6svn+XutXdb l+WnP30fPR5YLl/ilXGUs5N5jg2errNM2+fjzvFewLO/9AaouftIx9Q45b1ogZONRn+HuxpIQZ4T kQqDDA1s5w7v/8PZn/1st6T5nde9h3e/e945Z1ZmVmZVlgHjllqiJWhogYQ44m/jmBM44LBPoKFb AoFkuY1FGWPjNtgC5KnbQ7oqs3LOPc+7v59frPXurMbG1cTz3Pe9VsQV1xxXDCvWWu4v9ewI9/Ci KU5KqWn+xu5U7Py2kYVQ8cu72sUdQZ5Z5q/RHgqDH9qookXC97tHzeKmCZV27WmiezhM5Sa5X+u1 Pr/51S9W9nvJ60rwe22J/i/+2Z89fvHL9/b+Qzq2kk6fHop1JrGodKU3GZ9LLgPWN5pQv+ZKbn2L gZmdQiT3kBGLHp6x4MEjL7WQIHaZ2NDTJs3BGVi4351oZwCXbVOsh+182MDHhP2N7uF66YWzUwsH Wxygumz35re/9vja97/9+GlPl/5f/q/+o0d3MqdDbyxINxSJmaPm6ayz/Z5JSVLG3waqMRA0Le5D rwZE+kjp7iO0tS0cB7/+h86na3oe6L5WjwOKMfowvPhEhffetJZVxdn7qs+2YP1ahJH42F4JFS0y 6SvkzcfRWN2+ytg9iR2ig2/jpuEg1GLhwX+Us4qDHRBaMcdWa6NAy/M5Kd7DMxmGhjynznxwPJ28 UzEeA9AHwLtY1TF8/PrEtPI7xitdDiaBbp0fYPD0cSZTnluifHj6UuYcL9Nf537pd21k+dVNrhOn y6j23cNoW/MrvMJbRZOFERhW4LDjc1XDb2y0rCNfJ5tgHC4GZAz0WZNcFwo+aoJrIcsOj71WMll3 VbdffKLVqGc+aQz8tNeHvdSOmeVGOy8anckXnCqxvXobF8TLl4uqt24DGEzQ5HLMHzo4VWkgWfuD CL7zUL4O0pVXxezCjv68c2XGiNrvEsY7NFbd5M8EIzj4z06XQwcMu65slPjIlzYy2dT+MXAuJAXf WBJeu1fe7JkCr9anrM0dyv9/fU/maLgQUiDeThIPwtvrM1sA2DNhxITpJFsHZ+zjmQIz9XwiLIJw OfTNd/yJl0+e70JVMPfkGNRxwh2NZ/YbH9GYr82hjq/yzWELZuPoyp4rvtLdJtls1LGn21vUPX0C 2DiGdLgp20mkNbr+mXw4qgd2F2nQOFABnHK8LjbC08di5cYuAIM57fW0tRfqsNdW8VjxeodNMI8s 00s4TrvUdo37A8x3VpYcxhGxNpp4Jj2X8vFsI/MefejeAlDbf7kr/u7phcfWZqp7pfPIMMcSWWsJ 8ea9veQIXLlK9Qun/Zx2rn0q21XiIG4ezxhUv01fp2rcxmf6qF+dUivoSnGGyRAC3B1AjlKCKfET q4czkKulBrb96ZzPEezGPykoVVBW6wq0Gbspg0OM+fI7nsJS2i6DR9NVmuHjFJykiidAV3+Gie0U byLy5YOODs01xmDwdt/IDscdjLflGr6EwAfam8QVsFA1WTVJwHPhYfLsYVF4Kh9MBzt27unM6Ljf TOBjMVtB6ETgf6WB4wY6Cy5NcKdbyuEoKSQe3Nux/OA53O4PoaBo7ml/4aIbwWoLCO+37aLByIye HLaomYg/LwBUf42JzNH4Ak9V+8IDxZLJVQRPgv641xdJgt4cowEGXtjQK4tsEaRL9xQQWaC3pcnH YNGkymrmWUVJlvgdfDjZzgqr+78XxNPTBohd7SeWstOh0+bhWeOJ/IEfZ+drHVtQVrv2Ds/qzjbp 0S9bVJxcOjvET/c3vul3suPo8MIP2O2k86uuI34N3644pU/2t3I7psHUcM72aEKQr7zD/tBZIKG/ QK/2Ax1fl3Fw3+fzR96F3yvgbkUunFuoGOIqVdVHO9yCEJvE6ALY4XrfYUJ0OlmAwBsc0YbC5FGa jobz8MnvMDc+MgAPPzll47uPuqsC547AX7wFNjv0m8fBVBXQ5XecU3QEHv1DU5m0rWJn1jtY1eD1 WbwZFB6Cld+5z7470E7Gx3IPTWwt8Q38yD5FuDhlZbC5hEc4thgwGl9WOHLQo3p4V9Zx/2uL4NUt nw6AHRkC6XjuV5Ubz+Hj1IHkcIALMFo+OfGt/oGjh9PxXnjKFzfoY5aK4OHv0OTELL54Eq6wjNK+ LxoFzsW+07ZQ5XNgzyLN+00O33v/vce3vvWN4oyBvjZlUKBNnDZFpk0ydh6OCXxac6Ivhu433GRF 4zSwQ4dXqCP2knG7XS8QKvDEUfVmxo7oVzx7o4f5vfbq08dXuh/o/a98pauZv+qJxj3VuLyWixuY fvH48b/8V9X4bFuBd8WibT9fb2vzb7sv9u22GHqCufj/cpPAL2rn9LCHtTRLo1Px3yKmAe5zrWlu UaABlXhuQWW/8SPGm8Asro5f7eMkfYs2u4HW2iw7eeXIx+uQyTLeqqeXDHO//VXH0AMf7zcY+KQH 3Dx54n3BDRyKP6/0dNIf/OH3du/ye+++G8w7jx/+6Pd37+v7PaH5X/zLnz5+2mLmS73CaU/LzNZe HmTg6mquPvPl57ta3jZAa+YvPt9EtP5j5/oQ/PSxyGRbtqeuDk9xbQusXQU2oDBpAdN/ch37Pt/9 vhQw361An/hh8ma5s5WtS8kvN/h6YoIsHgS7PrY++Nt/8P0WS154/LW/+ncef/Xv/+Txl7/37a6Q ta2ZXjWJGvLIVOm0p4uOzHi4xymAOt1n/frMwbFG7vB68bgisBrt9avduAKifYsR00eVJ+NhYP2l fl+99W/qK+vD7luoqz5OtFPTEDpdeyl/fYjA5JJk1fif6HjuBDDmMQaonZQvPG/rIzHh7PcEtYmk +vgA6/ie4HVaPlj5h7/FqHS5hd78Xz+8++7IHBx4VU4/Y8ykHgJ9SqPdsXx/CullYOBKdirw4ek0 Ox+90cUBWJ80nPSbn+VHp101QqzuoXn14ZVrHYcGvZz4hM54cfAM77gJWrs62fdim99BRjexKz9j AHrx6iz6/rxteufdx+Q/i2Fe3fVRFzL48EftfPk4m+9KbmOgeyw1TUSPbVyV2qLzaGBCARraghij T6Afn6O3m39wk/PSnRgIQ9yMZ/HMWJn+fE47hZ6dare1bzx4QJSxsW7VeAI/+wSnHDzE/GS+cojM PrFXHhggFraMVw8f9+R4C8rqF78iPD3QqYku1HsAbjTZ28KZ/gJ/T4ozrPlyV/f2ippLuon4F/y6 feh4Ex1WkW4bz77/3ruPz3rLxkvZc/5bodtvpvPhzzNMeIUoF5DosT/6hcPG8vHfsXbiE9Bo0IH2 wVYdEnt4Ki95eQAAIABJREFU58ty6gf0qeCA+WXnVblo07tdSGwiiQcSDdH5ROl87dBJaXZOzxYh tRH90N2fZIBg842InTZGJrT74h/pvMD9rGwxJpnwhhh+9O3Hf45foD0fDGT5Yhak/We6hZ3NF+SH Z/GvA220s3MeXNpYfSUbb7eLxhjGXMa84QW7h1o8fandRsa+H7Y1XX/iNhoXFg/yfvBbUOS36u/1 rPkZXUioHrrR3Bj16OKMrS99cAD8+9pvtdJpmPdHaeLDiwbv7h2ElfA6d/dxEZIvcN5oj+gCeUqu sDKG73MZkVE2jass/6sDizaNSDFwmD6dhMkTzOeqBDyVEhZo/HCiQ/AIQzHqb5LWr8vjPJHjqjrb jy+DmtOB4AePBhwGAS+IDPHBGHDNEfF4tJNuOGRn5BDoQIWY0h0zoFd6UIYHruxSfrW935fOTExt GUmA6nC4nOwgHD1kjh2OsShf0N8EFxsdczofPFs5W3rhmEw+mh997N3A8VbDo2D2s/Kxh7NEYR1L uPFgO/FvexXEu13pXfCtxn21GlMC4WsFpldbiaEKK3S2+ZHnwxzS64zcr2zV0+qY1TtXuG2d8+Tq T3r4ze6HaOBgxazrMwWb+Ip/Cw4a5La/T5cRCB8fm73T7WlkBn6Kzvkml5cv7N3M0d/VJLb0R0/l HRznnGbhhWMBbLJp5MEqC//cvgPngR3fiI5GPLuoG8uLH23v22JE/A8HB6sufwer/gJa51k/3aa9 29crp79Y3FVu9e+V3HVeySHg2EYNjwa84IdDjJZQkWfQOjnLw7/go80MbHWVG5ClcuX5qHrSWdw4 +lgHqHxlB+e2xya9DloNvuBoftlxiCZzGAkexOH35ue2F1oHb2DqwVYbOFUwTJZ0lE/cHe/aFPQI A794ph+DVy2OkBcLx6cCVa6Cdu2PTk6Hww/CX136qUlwvWc0P89XP/6wNpBdn7jhcTEPv/jrMzZN qo89/MIL5xIZzlG0z5EO4fDt3DGadBs6+C54jIC7O8AdX+X9LKkrKaNfn/l4tBQ927KO0VKl+5vP yyDshDjHfPpclU3v/fl+JoFYGn46tADnKq+JkCewnwF6FK+2RCg6uG3OXqO8AI+WNhnuOeaqHR8o f5ynPvTBSeTzCenOb78/DzELdnwN0FftSBxOJ9n9K2+9Xjz75PFnP3/v8frvf21XKcnv1o0f//hP gv3i8fW2QNejqrHVZvcof/Riti+W1cwWG2dSNuwjFnrX+K7s9FvF2ZduFj+rt8WWziVc888YTYTz y9c48haPlfP1gghfPTswuiJhgg2cVpKfnHAdPPlugwC3ooizz71SXb7V32ttx/7RD74V/65uvPt4 8622OLeF2QD9p3/2667w/rYFga826A0+nVrhf5pNdUPb8l08fzVbvVaGBV59nMVE9+gajOLCIMur 9Z62Vdq9g2ysH9vkl5xHvPg2mCfgvH3twan281m46xkfH6ZDg89X2sbp4Vh0NJmDZnLt8M1eUfTm d7/2+If/+J89/hf/s//d47tvfHUxRww1ORjOcE1ffbHF/GS4jv5PC0Q8XqugzmJGtOdjxUE+wy3J c7dZ8PM/B0uH2uo0BmI7OeiZfEqHfgcVkGf+3uleCxdv84P5P9+Gw0AtnovL29mFb7j4/X2cvsRd 29YbLZWNV1J9Kf8dI6tUfoksZBIT4CrdejinnYEpf3GoTPyAGY+VLKasTap/dDXsnW7RIHmwerAc PHShb5nPVnjTBqXN8VV8f2Yh/apLHgm9Z/0J2fFfPrCBrl11hNdgNxFOl6KHhG/wG9NNnujx0ZyJ jBbTN+hNTgtX2pxdcITQB+tA+J92btL/ce3GU5Lfb5Hvwxb7PmqC6/YvOy3UNxZDyxXbGlN1tXNb QsXAGMlHD30cXu14PGrzPOPwO+npPnw4mH3jfzrs1yLQySNlfBIS3GTsPPkSZTsmTp/ZuTbr4k8F 4rVJzEnaCG6yU+19k6pLF9q7e30jdvKrMB/t3E6GEa6uhSn9nT56v5MER9Utj77JbWypX9nYujzx Zr4dvl3BDOP64xoduzwprjxfn7vmUdkzu3f8b06UQWt+kqoDfOA77Nnq457++363nHz46AaKwa1G X/iS9rrO6k6+9HhspST/k0/+ETg8rTxfUePQPsf8FYQRCULGY6YRpz4fY8tT61kbH4ZsIf6lM7ZZ /ArBdoTOh+KpfKafjS6ciIgLG68N74Wf/osrGLxljMx0TM+4xSUexs/Vro7uopEN70UNaNfW8hHl FjX1V9MvPpRfPIyXMvRt4ij82iQwGbNSSPiFeZWHVrn/O67X55oDvNYr6+wis+X5o3d7v3TzBzjE VXbdLXzhl2en0fyPL/YZM747pC9zIrtSb3/HSKfTCXVujhOeKo+HBFndkJd12T4fqG87QIJs4WF0 KIaAlZxKY8+Jxn0admeonfIA6XkNanXBihsmbmcAoZEvEGGKwCSR+pmxcF2dJAqnTtqVt443uQMY LU6o/pWmCAFKxfJvPBtkd26SPCHAdy4AR2UKRmquUr6rpowAlsG5+iYc/RpIb9tKk0Hb1gyQPm1V +vOPekhB23W28ha/WatA+l4IrNYznvubOP4xKHqcI3QlvPbDuc7Bfh3TmTpzvM6fDxe43ayfreSz leprrENjot0TOnvsJRyBpMPnHm+/+/71pLQRnfxh2koLx3ylFRjbop9G09bAaoXHE7Hx3OpdDvxa 732UCnmV1jk0AHN/i0mxK8GuZsjzPscA9pAyCjSQXWPR8LPjHCSebh3jcStZZSnHF8fkdQZcM0df G3SrVLpdRt6EDG6NrwJ+zIXoWOIbR7cHFOkRR6cjg8QgTiFmOgajM0XcoPFuXPPd4Ttw5FzV64C+ 8L8OvoINlOCJPTh81mHMT8qfgYLPl6aH6GqG0N58bzBRe4NzBZVJ6JCfj/MFjOxHSQe3zBuQhFTA u1dsD4IrsB5h50v8DV3p6GmHh88yDs7je3c5Wv78YwBM4k5/2kTQ4xFuuvJ1Bx5N+vC87HPyjM59 engHZ4D5ZYKMDdMD3PCqSwY6Wds4g3ar5R9++uHjzdd6t2tPJX7n3d+2RfTX2badDbDAHbp1JI5l ViIP6sUEWRNyB5eOz/H4qBI89EGHC9pqyLzS+AvpbR9t81wNZ/f4/h38YKfb6s8u4ZBHzmc4O7/b ynjALPoXTWIYQ+PAg+1UPx3NydPu4PqgKxrvvvNu97l+d5OUcn+Hk2kChv1Pv/qIdEr74wmvo3F8 gZkOp/nC9KK09jBfPbQHUDZ+xhiIGFYvsB2IneQ5HTFeTWpqrfnzL3/x88fX33r6+PbXXg9v9xAl u/nqT/7s55Pf5Nji1HgJzxddEVBvHkknyeAhKJ/rPCPoSl9TYj3fGNC5s+H0Fm5dSJ3B5HQIr4Fo JeNpE4wG2vOVyqTdP2XVuoGpie/zxbdtOSOITwlPm+znM7PFB+IpLsSeBorx9mr32ro39lc/+fUm px5W+HL3Cv72N7/pYTm/eHzlq9/YtmMLnp+J1+p0pfvVnu6s74PnpejsQVS2cacPDwERX/Uze0VR /cuTBiQWhslO0MmPSfrCZ4ezT7xPB9WXmRdMDsvIrtQWyMPZYLeZaLv7sjEc+XH1tthaxjd/+HuP 9+pH/9f/m7/x+EcV/7fe6r30LZ6KsSkktCGGm2+NRkDV4xp33KA7vGo34y/A02bykeTzXk76gwP3 57sKV/pz7YgfBqPn4ZPz62f0TZjOgBcMflYXKiflpYArH8/5lL6ubPd105BCPqBtnoVFC8/sjFYy k2Jo8HFkwouE1vhJh8a8A+zn6AY/4s0Khn/2g/Li9X6wHPxbpCvfIuv4wuSFfxrg2KuHJr9voR8s /8TngA7tu6/QfsAeq8GnrR854XJsgB2ToaGXcPugFb7Jgd2SdoQD9TY2DG5xOfxK1ocpJmQ6PpNp 7XsCV8BWLmqcK7cmsmdsol19snsJnZv00j8d65Ph3gUPMjfewdjssoYfk/Ellp0J6akzvqJ3+ofj Z3bXqXsvUHKrlZMzPd2xeQ+nTIayR0c/Lza57cni19qn39qjye30MX+uDh5NduH0F5H5SOXjMVWY 9IYI8nAFf9XVhvhqhSsTz29dn6e8Y+jENnXXv3iK7uBO27jbB1stBl44VnE2PRYku7Ha0+LXmQOE +y+U1H/mBdjpVMu/85sTNNZ8r1tBtHv6sujv0gOYxQO/wPPd6ahvPkj828e0G82UHV/SR3QChi9w U35KprW9jv1NJkep7ZQO5MIpR7Xj49qY+LsFC4rI3vopUNrUbDX8x8fJeW6DPLFhk1S6xccuQA75 Mx8i12wRzMZAgVmclehkfWIy6aXcXijdMU/duy1tF8hKcaDET8jmJ3SRPFuwjXfHoVrsBRbMURWp Dt905L5xvv6RWxniYfd1u20q7F5VZMzr9pel+NeuNmayLTreLQjRt8Ur9HfxKbxrk+nS7/rOdB2H +ZnCIx/7nvHXlYcI+ynvT8xQZ5cTyUk1Y5/AIcL4lDvuKEIDiyAD9jmi9p1gC6OUIJisoYWDA0gH cM6xJ22FVZbGP4N1TLh1UpXNmACiN6cBGy8S5wzgBKvyppSo411iTEJvSwV+CRY1yrBllpNT7JzZ +ZQQqZRvUNUyy5zkSR1WRX2ODgwW3ux9g55AZmucG7S/9fVvTkfVHq+2BO9+qjChke22+gGR+mto kyO+Z5PjZCfw0+lEqFH3YBX16Z8O0icadMHY9CK//8lNh7Y8f9o9Xl981rtzOUt132v7m/3z21Ie PgYfiWTK/BtQvd72QUF2VzCVs2004G7qfa7mNgmW8VkfZWQzmHJ1mHastnLElzSu6DJ7nDZIayAV PvdezD7xSd9MwvXYZHJUKjBbiVVOTh0uXGOkY/qDg07YRH9UbnnZrTocWb5y/vOsg4HjqkcPHmV/ dKc2GsHCg0Zwe9T9szqH3lbgB3f8bbDgVdCa0CVUh8ruNFuRE8hsePheRnnIqFaPt5M15pDw0VsO ROhpzIXLr3PyLcCOGF4u3V701T+TqrRWHXZdUXqkL+1EK/TH1/iYthv2Z/afrfjWVQepUI23g/P4 XxnLUzbjT7CwJzi+nAqua2tkg2f5/O2GyWmWPyzDt3gQ3HynWmBvmDPQE4uq359FKK+A+KItZ694 jUG++ElXHsD98Pt/8PhO73R9861XG/x89Pj7/4+/3xNxPzhtZs5K9hOL4MqTwkvOjtPVHUT5GA3c MYuuAJKPvqUvy3Y63sRDeLZQFTwYg2DpHpAcOQ6e+QScp/a+YR9Pq4WLUT90O6GjtYP4mA9WATzt nQFaknHEYT2VDR7eacvs6105fK04AF6KvRJNdJxvxPwGqarboXkAKx9DR27ApwZ9II72dUxvwW57 JXuKYVJ58+Hg+UMnVz2F5ZW1+6M7+3yzHflncvUnvYv262+9eeI82IA/auL085/9cvcAk+cMtkKC 6eI6WufKa3llmfgeGfDDl9i932hpEy82eTRw0UbElq16p4vb1rsq2hYUg65q9pfnJMJiTwF+V3ku uQyC9J0GO/QL52yeb5w4mL8WZj9poE4PBuFsh75BgH7laYuPVPTrX7+99/p+0RP+bRd7twmvSexX GzS8kt83dt4Chu1jBg6bzKZr+ph86cHr1J6+6B2XbpsRgCK7uEIT/HUqWrvFM5nJM32RNT46ocZs 02Jvi5/v93CZHizdILJBTXVeDMgDJlN+uHt4YzJ89Qfff7zZK6b++v/1P3v8z/+jv/34wVfrQ1tA Jdj5i/5R0HSu9oTuZ4NvfdPyTr4Bk1aJv9gZf7NXubZ+VrLYzAwkw8f0jvc+G8hVMqxkKvET+AzO 2BJeMVs7Mn4ZLYDo9edcVb99xf81vjhY4yQcAxgaDqL24OYr6kmrHn9kxN/ywy82rZwvHk8b/L5i QnW8rH68DN2+BqG9jbcDhpvlq7jBY/ws1qZ3JUkwHNNDtKWR6OvY/5yLB3sdWn6x+lPywWX8TSti 3mEnzos3i4HDkxq0pcsOo4Hx/o2N1l907gLDxomNN2J2vGBJm9Cff97tDdoGW+02rvoAC0Af5ouu OqHN5/kUftjmReOSFmXIuhHExcP8oUw2ueEh4HfTnwql8zDO6qvXHxqSGEEAch09HQry4HhR3Ovz QvS9K/xMUut7K/Nk9GGLV7cV2C3BoOMDviP6l7JUNn7x56/6wwDPgMWQ8pH029/+8VD5/Lo4B/8u PIS/ksOTSqvIb+CD5/Rbx9erJ+/yc1JPx+qIG/2cPu+TvVHEDpKjjwD/ayUWK0F4nLqTbtfr3up3 336n/vu0xfGUjrYi1k/N9MTe8tZ/VevICdWx1+rM35IlR+Zvn6Yb/nTay6FplyJ1kledjXWxtBbJ BpAf/YqfYJYqeGnx9yw88Gltd7G1I3Bi9rFVETI6Pi4sbbw/+wa92Hz51ME8fcwecbH2iwUcZY/5 OKb6iDv6HW+YiRQGhg/smbjHf3x86a+qnXYSyBL868eMEVtsOf0XvvpEj10+bzsze0/HEaJzW9Dh MLl90sU09/SSz6u6plB0Or/HRtrOS43baE9bllamsZcp/4hFkZiTQ56j+7l1fZ8H+G6eQ7fpcjEM dHgshMKBsRcRISoBTTaE1c4GmJkHBHiTrlW6mUAQYV7BcDGCCZ8wYOveSkuZHMWvzuNMlMoJ9pkD wqauiinTFiFPF0utWx1ZwwkEJo3cIOoM5Bg1BqqHnhV859BQJhrSBn+U0edcxY02R+1vTwtTo//n CpZtIJ5RdYqxcpwjPb3YoPrF9qYzJnyTNPuyg8ndBkaCFawNiPAQU33xOo3RZtiyIBW4k5FcgtAe pHLxqnMYfI4B1NYEW4010KdWI7PVVkBQ4HwltPBmoPhug9nfvv32bKLhGOzRq63H4F5p5eWNN3vg Qri2/Tg5P3FPVUCGW0zqIVgbkJnMJimfcK/uJybBlb3Q1QEmtwDyYleM3W/dyzomKZ2fVST8RzM4 op0BL8T9l7lOP/RZZLY8WtIQzwBLnfmLqHFOhmurOyGBgz80PFzjJWSol6/sTqqu/kif/BWvQJk6 8VGDxQN7kj3zzH4LKOWxGzjo7gbX4Ww4v9dZKaXs/ukH3bUqWXwmAm4fGD+VnTyLLqWQrzOsePmT Rn7gV6Pdg8EMjsNKn+I9Me6FkqjOjsoX3MJZMYZDIxQeOWnqtMvyQ2JiPETjU9nRvSvGo9X3Cykm y/Q5ixObi1CI9gasRA8GK9rg6XDLxEPlqCsfxn4dw33SQXD8BXf8XRtf9YFYub79ZnXD+1kT2a9/ 7Ss9uffru4fzz37+iyY0bQ19863Hj/7gR115etogqC2xr770+N53vvV490d/9Pi7f/s/Wxuej2Sk BewomPD620AgQ9EP5escyD6zkfX6E1+m/0t4PH2J68iDcfk6lzvezXcmu/pH16BRow18PVsgvHDL U3YsyKfo8coLB7DFvQ7AzoeDhhTucQMOjuLBB3VA77779uMPf/gHe3gR5LNEfLnyAIe2d8cM+MTO Ieh4NMJ1bHh+1cfRfjEkhc/57dfL64s+xnSlGwwPFKRP5cVHGHabSFn8AC5b+H75i7cfv+pVN9/+ tgfGpBHM5d8f53dvv/3ervB4UqTtUvT7mQdZFAc/qDP2Wjfvd3/rzVeiXwyuo5x9w22w2c/iANtX PR5sA08qMTT8kyqYTUxzCE9+1hd9UYwWlzwssGtLJ553awq5L00808EWoeKcDiUDSP2WLZZbeAyP Muo2eP2k22o+Lg7/8pe/enzysx5UVflLbRlzhcPW5Vde6MFUDS5eKf7vfr8NUOJtsSG5OrdQuTYZ PbtyvF4QrzX+xY4NfjhL/0vRYO+b95llfF32BNS5BbQPWtV3/HwLACa6FkbF5dmmH/3ey6++9vj+ H/3B4xdtp/9P/g9/PBKvvvFibbOF2gO5PHH3d9PO8JI+5gOXzg6Umkh/2RbW/tIZf8DD/DgpBglP n99Np0WI0PhsrNGk3ZY7ur9VEZLqHV2c+of6vuMXyjNYDkeZi4sd7DkXUdbe1/YXZ7NLyGlx9S92 NkBbvKtPRrhCeCduv0frX/oMGdhsfXb6zljFZVe88plxPolWnw7cj37aIIL0cnDhCyRujurJc2Am 8xj483QDViEcQ9LB4eX07/kEviore6AbR3WkvzdOMDyXwCA1cpVrxhizA2IpmdT5JP/6pF1sH7e4 4s0Xxj4W7T76sJ1mTXI/asvrcLF4dfhAo/S1nXtygUbUgvMJf+fHCis4snc4X6p87eEwNnjS6Bdw pvrh78R1x2RH173xV7Wd7yJBE1mLTpuEoRsAWGi4Kn8Yzo61U1QmD5wFofHON5Ltxs3e91Vuchwf O+Vpv/7D4hdcaHXSLzv30z//VjJK0cc/p6swGengjGUPn2O0svEZFF9d/dWBtJrxY2JkHAIXX3ul XSlP6KNysvr9t6dpONh0UDvcGH8N4njpx22Rff+3722X4u0/JkiuoNLNJoLFZVeCjVPYfGNIPMeT dNc7ci3nWd7lGscw1dd/LG/BZ9VhWN7wwD8YOj1j8VjZsXH7tlypFnMbE/eLzzOGHaqjy/qnvWHG 4it7ETfC/qRnC0TlsY8+Ax/rR9O3vGftu3MXwoyjN08Jxca24RVfzfO0NbrZw1w7mv2nn6vtjkbb 5cs7Y8/su37j+Cq8FWxhNSz1ufZLhTdaeFJunvS0fvhMbtsd2s6yuJy8kylYOpTgwNTnLVK7VfTY KJ3lT6yoeCDhNX7RGeD5tNdBrA2Qa/wCB3bjvmKvdrIFKHQV+g5NDFOscx2xToCCapw514FTdoQ7 9+odYW2xOpDOUwq8U+RpPPDOSH77+ENHx77B9eim3DLtB4cPk+OlMkrGE1inR+jDx16hEXf4E2Q3 QRn+s/KKM9tqDCoEZR0TY+DB1VVqs6XEAOyTHvy0Rmz4h7dWoz0S3VNEi7kzCIfChIHD/JOjxt5x 2I6TX5C4rzqfeywBcLhxGcVOJw9dBR99clGdx6mbYG7bS3gMLkazqu4jVrfCI2+Hyj9qcPSbHuDy s1/8LN20ouhqAD2SO6RWn95441zZ8ZARet+lgbBwsnO1tYFd+tW54O6zGiOep/OrcaP6yWcflH3o excX537zNVcPysNcA0oHYDqZXB1MP/SiUZwGSfM0ePkWBZSzeuewurrz8HQOKlGXNhAiAnzl3ROI 478KyosOW+/qe7W2/QxP+dJZXOCLsNbA+oivuz+IbPkHnBI/WdCMP7raVaiZM/4ZLD0dnukSL2fi HtLRj+L4me3TO1/cokK8S+yEko5svilTpTIPvfBcg3L5+L0THi8045dGBQtQtYT59nP8Ne1tOJps Bg4JfniK4XXI/S4/1NodQdDhJnjVkeiEbJ09xTg+x0PUMV4lOvHgkHN88shVSTxCcLWF+KBb9dVZ B9KZYDt4YsLZx24NviLL9yfd3/773cf5P/jv/rvboq9d/Isf/8njH/34J4/f/6M/6j7Vtx4/+9nP Hu/0Dtrv9AAk74szQX5iRFAiI3vowPE01slXcI/DyXj4Sj/RGys4CJDqsD09xauYcyd+IH/BP2el v91ndMjOT1SHZDgnVznhWdu5EckCSJeQ9C+oO8frOipoLjuCpbNV6fvW64gEp5806HP/zdu/+XWv wHm1xYA6pZxnPhyMyueWEu2GjWSWIgjv0cLA9nXsRY4+OsVRPTpSbfpxEHPq+0o1F4JzDOch028H gwtkIne+wabfCj2MyTWcH//kZz3RuPuFemCSScrpnGvT8flhWxg/blv7i8/3Xt4eDPWrd4P/8b8q /6PHn/yrX1Tn6eN/+j/571TeVaLsc9rtaa/3ivbRt6cKp2uK5Y/pabrGW7JSD7944r3qgWSWx8c1 jrPLgrLBXYOE8Hiq6GJu9ZfUAeNXPxsva3GU0L9Bk4HrF/VPn30WL/0aSMRF8O93a8orj2+8/tbj 1ZdeyZXsYhLTT5+Frhgz/lpFdxVBYg/o8TY/xZ/mWF1Ey55cRJ6vBZzkz+wzmNXNxtV919W1FgNs oX4xyxgjbIvmFJJvwp9cb33nm3s379/4T//24z/8P/6Dx4+++Z3dLrT4zO9HIZzaBMPHyY7xG73F 9HDiWYwBQZD9do6cuZItqtP57DYQkP+GpH78VUovYsHpmy+8Ib8hFvcCpCXwpx0etDdP00220Tec SUGrJrPpkelM6PNXjKZ0V/IPMj/kOrpyfDjoe2YDVx3y9tki0Y5lHRxnvBPdcJxIxPZkw23Jz9Ac /dHh/vh1nxXKKX++c5Ec3EiHq9/5f2WqnPpf6i1RKwgoQD9o8mh0z9hQ0YkNt39RQaYCtUV1F2E+ /dj7bWvDjUHcQuXBUnbXmfSKXYub+Yi2aoDs3dwSvhHD5y0HxPRurEd/8pf6OXEjBiT+klFvWwJz vPbPhmWs7URDDeOyteX62ScWm+LHK8Re7naxj+w6QlNbvOy0/riKdAbPC60OjUbYjGMc41+3Pd2U T3dEgvu+5Y9/ri1UfiZZ1R9cfp+MeFu9DlYeYrRJfXjSPvnjGVNyL22XQe8FgfFdPXahMwz5Mf6g B2NtmsbbCKaLxbCAtjAatS/i5WnPi7nvjR/9C7yff0O6ob78jYujj7LIZnv6uz3QbzoZL1oLNvvm R4IZU2fL9b+zw4mLa39zTOTJ0If/Zyd+HbpTP1R6MknexnLJLi7NH8pTT9k9zxAPjGul0I0fvFTl 9E1w9YFVXBf3zviTHtWzhOkCZDxBFnIjN/TgVe/4LmvHyzLQqm5EbOfnVxY4XcgyZ3vBrjf9SjhM 9Lb4VOzhMbMT+xJiCd6jg8OlonTfPIFt8fp8PuvPvzkU/zduXJsZjbMl2W0E5lQvu32yOYF2+s7b LbJ3L/b9lPHFEbZKVvpwK8ZsEB4y0Rs/pvO1h/jkC7ilmTqWzdfAmptpE/P3dAAK7+tbgj/aVbHa 0et+R25SAAAgAElEQVTe6pgOAJBJ1h7CERPr6AMaURrugyyJKX/3LXW8pw3SQmUD6xjzt0HnCMHv ScoBgFR+Gig4xkrIShjldL7nyqlJGoeYoBiuMidbffygE9+MTTM6iHESjDy4v2i523YuA3UygZc0 SnhXI/r3JMXTxhg5Vkg058DDi2Uio5b7sxLgCj4WBgrG+KthbNKgZsDrTNaYPDAlmYKbcdIv7PQY 1GSPhdlEHQ7JEV5oks3gYMSlbevhfOFm2CPraRjuyXU/01vVf+srX18j+FBHEbwBlYHH07ZAv5oj 7mEm5I8+HUx//d5bwPH2whfxqLAvq7Mm/HuIQcfy6ISM7PzRJx+lYw2hgWN/L8U7/bkKHKPJkATB a4jjuzrg1pjZUD365eD9TW/94m72x2c4nE9qLMA12ydH+CQDPvrVyAXF42Nxm+zzhUFVuX+2lC4t Lg9aFqaP6UbL6wMfm8DJSFvJVnN4Diz/yWrlxfPQxNdFJI4Onsq015NNtuOwaBm064SldWpX3QVa fkzv+CpoQbNOdL/Hz7UJeVuskV9j8PTJaax6C0zpkN76H+/zv52M7L7Qox9l80WNqmTADpdC8tGp dPAe+IPv6B2/97lf6darBzrQJzldbDqLFxij++isjR6e1St7lC0LUMseKFE+tL/3rW893mri9nE7 FZ4W5L/9ja89PvPwhNff2ITX9rcf/aUfDVh8sY3GVa51JrUXOOmOHBvETL8hvnjGuTJ//tWbfabL MpSQJ1w6G+2BN97tY1cswaZGKOHi77d+hz+dn61MlV96o2swFxthTC/jgy14LX76BMBmcaABBnf0 zMBX7mlzYH0C4Y+ffvLh4/e++8MmVWehj45PUu/wyR1v+RP65Ccnmvg6/B35yflc9HcVM5C193S1 xYDowqMSL8Lr2rVciKQ5Vb/BcsHIVda/tscv+EuZPoLNL1vc+00P6fvOt94Im/bDpmm+MuHAdtpG w49f/fY3j7/2N/9JOvrk8T/+H/370X/6+OO/8Xcf//6/95d696130R7etv04wh7Ece5Jp4VUGl1c ozue882xHBsGJSdenz6PPsTpL4qVmD9XbuE5MeN+4v5iU7S0AbgTenJ6QBW7z07lWSh5uVttXm1Q /UpXTD7/4qOevPzh45vf/vbjuz/4QfH8tcfH7/Re0F+9M/8/cRO2aELTXz/rC9auOzYoWgmfSa/H hkEBpPjFoCyUHfbHtys6MucD8tko3i1EfpReTHRfrp99rX7We36VefPCnqDagjGdfrMHcv1ZV6r/ +I//fthaBGqe8smHwfSHB/T90I32JaGzMsfX+Z/Lv+od5qofLxvs5AfGJcLrME2A1RxuPgVvbB5/ qoh9z4JHwJXBNWtk7y3AaSAV0ehicm3aw6oiM1zigrQdGtoe2w4PLPz51KPTyRqPYh/46bN8DyRD m06kyR74ztC7aBw/rDLipfWfHcM1/5HZeahmzqNHWWwf/NVfaitwDl81Hd8Dd8fnw+bx0vnk6Hey iSPJuUF/BfS1h0F1vNuTOkc3qv3zp/Owm8/tumhiblee14F5561dbiaKJrr6aWW2se5tHenx8Jce itsvt8Ps4B3myXP0dPxux+Vu4jZd00iyLCgP/OiVckqfplz90jQZz9r06X/4BH00ua0Nktl92veV 2zte74FF6ZGo7r93a9zz3VZmvLJ4FT5+trGD9sW+1/nRY3qiS/nFVn0Qf9NzA8fbqdvo4uLTRIOe EMUfUcBML+A71x8Zd532fOjyWz4etXgzBuOT6Zd9+nML224DCxwPEhQnHb4n1+qVyycqf76FOULA d/yve/pbnHu9WwL1L1DQ9jNUB+G/5fuuRRiyAO9e0Sa9b7/7znRhHHbmIcmhlA77s9A/0XFU+92F O0q60vQEbbLTiXqRmA4NPdQ9fiSf/o0r+f+RDnCuUqJLE0y6yWbxQ0q3ytiRR4XTsXYXjdWuHr+6 k3qSvPGDkXz1jA0RGaEjnzMMhviT+lu+wQYeAsiGi5vOyz7mO/bZzhtyjunDO6p8hr1pDxU+cPPG rxEd13TXR9ke4DvByNknHHf8GL5ii9cFqrl3tbcIBPkHvbuaHZ60QLWNiskBHt9ktcPBRNnrAU3Q yYS2+dqJV/WHxrdTF73f+u6IwBltmorPxZ9wgDltYuzsGK+9Qz0lJvicP8DJV3XAm1RcjIE7HT+C AueZ/HEOEz4K5XACzLOHtCCsMWR0dSGfYdHsdFeXIOs88YNFn0O0el7wIOGhSVJKB9tvyrvfo7fB Vgqb3OHf1eEEE5SOo55B6KlPjadBcxAf5xRBZVYbtppVnkvjtvMuuAXHAfAu8GnI6pHdlVy3Ru+6 aPJaqZwDZwQG9UROK2O7x0x5RvXAEqv656pj/GRMcpNhkgaDM+qDa9uv6ahzfPhSZtVTJyLfwPCV 3hH3atvIPE5/e/HHdIXTffaMJjp76l74px/6DLfPE0KFjJM5tMrKqZ+rE7I4YhCWAJObLvBoQPNi D055qYEe3C90JUZa0AgXvs5V+OgUHNCZk1bXkxGH0oDZeSf8qFrVi4/wgXUf9exFjvxJxzBnJh8b 9gEnz8ek6PDQt7yLn+XGjzqCfpLMpuoHtmAXA8OHzwqrS794Ih9aZe8vu2loB+nhA6F9IPN/4KeL irCvAhsL4s9ZCSmdlS0ydgJhpHcfIx4uatg+0bgcNAIbXvKyRfXYM0UcnaE9OBUvtJOJjo7PwI1H MuPn0MJnJ6tLL0cGpUBvvQ8kPAK9RTP5QwEufnQ90tHZKXF8bBQeWZ3PbjSC91OlsmMzPKwOZ5co qLaEtrJXutL1ek8dXlCMvl81PS2wmo+vfOWttS0T3c+b5PEtTxH0gI33G1RZdTQ4txgz/vF3S0Ee ZXS2Qc3x73vxZFtksIWneBfAPX0Uv9IzuS+98KTpujI8Dnf3wxxbsEn10Vo5tF/q/X4CJ9b47EkH RxWv82jGA7obsOCjtqL81vX8oXNPaP/hH/yoGNsVyv74D30NfvgPzukedkXVW7vSY80e+Dv4Z++Q L+ZUdYPv6MOC2y1qOIOjH3gXe57BpAdw+ROUTrAPuBodwFM/I3a2I8Ikq3W2Xtfzq1619Ob4P1dJ j3+tgjrZxq0e/+D/+Y8f//3/4K/0sKUG0g2stbc//dmvH1/76ndGF0GdvJ0+W7nuHI+SASTb6o9m +84Vsd/hGY8YZkssN+Arnkt3n0cJ8JyKYOHn8/y1FP48rbbUEkxw07U2FEK6eyk7Pm0Q+43v/+Dx P/wP/r3HH/3RDx/vNmH45//iJ49/8bN/uYdIbeA6vPWByR2Fxc89kC88+ugNmtPx6e9GeTon/+hW Z7Q7Hwz9Y5dNrrLJWLk+3bZmfZm3Fz197uOuGNUPtNWaxRaL4uf5Dz95vPLDrz9e6p76v/XH/+Dx 1//j/9vjr/zgu712pNfoYSEa00fyj6PJP2qjjZ/bFriQwC1/Z2D7aIcV4Msf+cnkCzz/caod6m9N 1iTyXABDpA0OLv2jcQoPBgXTU3LJofM8uSN45DgIqHwJ3/owvrLzvoYx2Gd+jb/ODzcHz5+TF82r dPkhONTPrzYjKkC8RVbkHd/1pt+DPbbL52mnzeN/C9EBD7df2IqjqOILLok9jfm0nZ2nby5soWvE L5nX6Vzx5ExKTl/7xecfdd93zxlx1dbDpBpbWJB0X7odOiyziUIEtW8TKeMR46vTv+H9yKE9zmeQ Hjt4jUc86VPjRaxafKrKpHIevONneKo+e4fPuE97Ezt33y/6XXTZRZjqImN8wncW66NFf8Y/cKj/ dFd8m5y2kHZ2I16LL4sr2t1RJvr49TkBhmy6meIM2dOfbdkboYgzAZrE0stuWajs9CcHBzskCYsd nzxkZpa4PXSC0CrWF8T32kdxZT7DXtGvO5qcx7+CKN7Or+Prz/VHF51+qhdN+oEzPsfKZOtKr6c3 G+Bd6WbrPv//9atd0dPwDbDa6fyjfOiDHtCaodJ7Ez964pvZnf0COTx1vAce57PiNt8oq+SLU/QB 06/bsZZ1wRwwvn/mLerRm1axOUt64ttiemyMHnRswO5uy3qyxXXx4Yxtj82HeRcMNt+62pLYtXI4 IhbZ67zxdSd8ViLfLkwtnsQ7f+IL032/MbE+lF3XXrtPOP2vnNzA0cxmNz+bj41stguXfH/jL/y7 MFWeeruocuHRV84vOxcbjn57DpCHxdWuzTGeeKBicG5F8PEMCTQw8sUlFxyjEW9oQ09aC14773gL O+Wic3lYuUcn++WDlWzWhH/84r3x3Z0WC9SqrAVRSo5xjpFlKW2BgIKqSGEAAwstZR3CnviofAPO yjdBmIee4+c5BYUHow4cVokMhinwnoDpiMMesck7x+ZQE6l6jk/g44RwBKfOAahm/HGCKTOhOO4l DxjK0BK0vT1grzwrlPfVQU7MmG5iJ5/L5gLnnhydkkyq1Z+e1BMIgpHSWPIXsKtmFYKSTBJjeA3C AOuzz3vCc7y58d7El+FermFIXnrufif1XupBJeMjWqFdQ/Ykwq12rk9IUkacAjgFnR7e4mq8xx41 nkmqyemlk3PlQjBV6CvAGgZn243o1bIVukyizP5rPMEJKPxBYker93S+7efyJ/Ol085no35NAOZH 1cGfVeAFZwQ6H6WVDXFspT96Ho54HJvH0dczJ/e2g+EpXDqn3KmzQKOFD77il77RBkegBX6Q4Jbi bX/5xZUjyFL98XW6qkSVKe3woQzRPe2w4+kdzo75x2GaGMkaMssteNSGTjp0Xc0bY9U7QSAUsarO 2pz2AUeVD96D3zERpfES9+M3IfGygRyeozc/DE6dA7tqg2MR9O+2aZBMT5yWiAuER6ydH/vjIXpo DZwsOoLDM3tu8tjvUNUe+Iu606FKl30Qs/gDnm7WWZE/kL7vg+EezPLpQnm1yRfcVuFrEwZTm/DW rtz7VbhLf91j3q4Gsn/s/afV0yHtieWtyP/23Z83qBEUIeVTSRId+vpdnd3HawcBOMfvGWDSxqon 2pf+AOYksoSTD8mbTcnccZ3B79Iz0KRP8ZBPKOugrw42Y+oILmhW6PiUOxcP0B1l5Rfwzf94xlQw 2uHTXg4/7m/bKyshOxw783X0Tr5TWg6/VAKXj1r4EmODu3m48YzdgtPkDh5vYvZYLF6yo1HF2oCv 0WTjgwFljdPvYMt/0lbCn//q3cevf/NeV2zfeHzSS3bpY/526cX2SDt3/vK/873Hf/5Pf/r4Z//8 J4+vtwvm+RYFf/rzdx9/+b/RMxqsboZ5i3vVE1fQpaP1KxE99jDA0v7Y5vi0HQvad6F0ttpCGnj8 5f+ftY3QtrPTx01FffEfdqO7fv6/0sn0zV/5xWuvv/74wz/44eN73//e47W3vtWTqt95/NP//J8+ fvmzXz0+eKd7lKMvltvZQQeOt7qPPxEunvRbBdB+O/kduswxv+nA76SXWfI9XdCPsvAe2LYZFlvf a/ICtGvQTczFgWSP5u4DT7hNkl567vGtP/z9x591Vf6v//HffTz9/e9RUP1BtmnRRWLZuBpBfRgP gpd/8G00pR0rA3yYW54yIODWfio/VQCeNL6XH6CRqsuspWe48cAv0St/v+QlB3vr35Wna30FAmDI cpzg9NlqP7nLFPURb9HhT443RDD4XFIG9X+Fn+v88JPMVVq8jrTFkRhoPGAac9LiD8WEbIuWh8XK +Vl8XzQW6+VVDT/KT3w/PKyPv/xz+Ye5S2640sPqJ0n1PaWEz7ln2FsdPm63oL7+kwa/xi9eC7St yV3J3Q6Xyc+PzqDZVdQzBstv+ovT4UdjCX1cXqf0QT5889a10cmWwKvbT3ydaEom+ZmpGKNdqOlf HBH/NynLFM7FJzq2GMiua6fl7bk3/eLhtIE4LSbDN7/Kn86iGZ9nm9qh+hEajfoolt/i+XQbC/CN s9NPOrM7QT4e7q3vdiItboZvZfnNfCKbkp8lJ3l1ho9sF+5+8t/f9asy0scZl3st42m/88nAyPuS GJFc9/NmFvvISiEltOXhabtExW40DhkED0/4mB7pvOzV/rd9gfzyMy/daTghiI6HIb33znuPF9ql gyPjD353xAxuvFQpePqR5gMOawT4n/6qt74qUIsJazNAtIlV0y7Aw1B+H/juJ+7vWD5SfQ6NKjbJ 8J71LSiHa/rQdo3dw2LsJ6aMduBsmiNBXrEv8YLvKONfig7Pys48Iz4CMA1ZDEAf3oAXI05jr17n yqDtY8fr2Sl4WhlZ+YLY4vj41fGjLVQn//ydbx3WsHC1FW0Al4f2MHa6yWqwL7Wr1AMlvQZVH/jh e93PW5vH75n7xS+mxjOfDk9fHr5ovLTx77AfwmiJcWfhOX9MNybU2uDeud25Pm72YhD6qGz6pUdz pfJH43BNYYI2ZfdVmhHLdDbDdswInQ3RLfC2BIZwQQaSksZjheyssKgBCwcQkDu6Omfvnpqy1UkB C0oxZkX/KCEjh+sMSAkQd40w1rEmUETCrMkyGDnPyojRtAGITFcn8brtAIyXB6jhT1CfETDVv0nq Fzo3SVb1Pytwo+tvfHT+eSsZBnvqaiECnU7ROcVzJA8N3b3C0aB4/GzvufNwW4WwHfMzgNHZFvMM sNWUjGlymYficg6Oh1dzIjx92MMbyPCkq6txMb2xw5w41vXpHtzi6YrnJfAFKkbPoTb5lB+ez3vC 7bENfo4OOMqxLTvHT7oRFI5/0kKT93B//txL4cJff9GjmxAex4sBD/ISVNkaz0NwfTvfKh31lYfe nHP1r0ARUoF1g+p+1yGkF3R0tTEyPziNNTzUFa7p0skSOsnuLxrKxws3nk39yhNm4ODj7H/qg4V/ A2JshWcwHZ0gGRxjSuFTa4skZWFBziZHB2C0D2sVhnsyVzY6/fJ/CU3lZ6VKQ3dPX9QrP4P6FR9e LlnDdmScbhtoj3rIJhP/O34IP2npdsGHjVuBY0e6xdM62fBQmOBz/IF52ffgIfWzsmDX/hddkbQi eezeYRmn7tWyzuRcPnmqO5AAb/qrUPF474ev3/pKo4MX5NfZ1WY+6D3U73tqZ4/Ef9JTaZ/rPsf5 pbgU/97FWmRskenDXRl2dfjTP/nJIaPtxwBxJ/ulY+R1IMLI5KaH2oG8w87lG/F9cRSOE5sGcKS6 cAeLwPJgniet07rtuQBNZ5VGcgMXkGCPf7CDeIfXOWMl7JqPwz38wA+8c211dVeujdcmA1mHwv8Z h/Lhk8pTDzjcd7uAs4IDAsZx/+jK3QJURxskatPDHQjlVXfVR6i8ITeou1dhD14LPAgP9lSYf8pY f5Jd7Kz4ZDPM4kHj0g/e64nNP//N4zu9vuilBs8mfV+m+O/85a5q/+D7v/f40//inzxe+/or273y +uuvPt5+58PHOy2WfOOtOuW2VaEh9pIFTezQyhlAHj3Tx3xEPCRHPNGA/MlV1vqwfvnn2jN/Wbr1 Ci/bSGihQgf0dHR1ib88V0u+8Y1vzW9/8qc/ffzD/9c/3sN7XEnQz+3+r/jZ4mk097C32jQ/XfyM Wtpev8frjq2veMsmbBXstkOOr85PjWut5djkxIAjC9180CTG1uYnXlHU+UvtV3b/1/AnEn1+3j3U L//g649Xss/f/lv/78d//L/9e4//9n/v33385E9/Pn2R+sSa0x/RexmhoM8O0++d4jB5Q+xHxQHw 0eP/i0sdGy+AkdQx4dO2wNM7w84vO9Zutb9BXkrnu6e+2uoN1b5G9sqY72PksLxcNr/5sejv+Njh 3AJ1BqZY0C+he0iNr+E5duEHJ+bQfcfgwjV5OjM0YKNNdF2e63ixkx0b5S6mDJp+KibzDmC4YI2R KnqWogNUn7BbjaKgClXyiMWMzi0qWlxGw04zk1rvwfY8EQ+qcUXHrS/weH0J/imRXrfVdfolZ7hX hsDhmUo2CK/sYje5yoRi6eC6HCAeLHCqFN/9jd9wanfrsyu1wPVSMcDuFkTpwYSh/zPA1pYvtNqx cZQJ58Z2yTsbduVWjcX+DoefHOFiF5NEO0Hke3LtHhQXHj5i96BYhz9XI02uiT2/yC6BNU4jRzHN NxuWhxc2NnnqNBMe+yiTuN7aTsdr5+oNcsWLC2s/FzwfgHixdEhAF6zFrvpQW+vl3O189MO5K4P5 q2RMP31U/yx8qlHZ8CUr/Bf/tjd7mCB69HTzerj7130fGqfEMbzqnnZEL3YFmPR+3lhVvCeSJ/ZG lOPivuPqpU9tQ130ycTXYmP8j0bnbPX8K+J+9aLHfmvX1ZtvqlCaXsJjTDMk5I34M/8dDAz5QzjW j4xmPtaYFQZ+TDfrK0PLLFugC+4sHGX/fMPiteRCFZ1pixcbtTt6JE8449k9wIsTUwEuj3+zhwmu xF7YPcfLGJ+JmAjhRuMiABcpwM++6kbT5PLcdkrC0/b5pYt4dOA2hbXF6umHyPla93Of7f5Puo2l q/PZTTsgF7uRHS2xxc7U2z67+FUZPNMnH4C3Sme+dWJLnKUPUlXYvws+PtNZGbcs2jPcB/9R/IuC mZud70Y1DKHCDKKEHNKCpDNGY4h7gLogQjkhD3PKomiDD/AUdIKEQBPEMZhHgwPHUHSkMVZdvipA knUGY+CQOMbrsHQc2Dn0Q4v43Hewc84zUVoHY2Bxlu7PIPiZY91OojhFYYo+wrPGfm17cD7HqGwa WSNJ0U2Aq7D7Zp/7lCQZonOBbhzFx5n0NDD/4GzFWMcX/66UH30doY+sp6P5wtWHYOCmHZqcMaOv AW9lKtwagAYmT1t/ruBsm40/g4An7svtXl8N2bYYSWdEubYuf/H5GRRbgZXgpXsOo87oW2TIBtu2 4bcr1x8r6/hcXRq62dxEKwX3n9wFJvzxFY2aL0zG8hh/HUG8oHI6kbgO5/SV8jRwMpxt4SfguAos PXufHrsnu4n1GQlkQ7wFhxYbHv3DDc6VdY36asSBCu7SeNXYRoPWoTnBT6cgVby8PUxj5+Etk2xc B4Ct3BYLpI7GB55WLBNPeJs/Rv+q52d6v2WM36Mv/P55fmA+fB860LKVQI8f/oAmnnYf9rRMVvDp FdHgcH7+71+YtdmbJq4OjcMDOSGtc9cW4PPfr0NFiwMdk2Ud4Hgto3RHBTYZ9WAOT6GUk5jy1Zsd g5MvoGJ5ODugOq93sdr+WQ+zev7Jq7l594p05Unb+yI/gmm8hrRwk6/mh/k8n3i57c1osPnwJgTe pftZBWeCmVz5/2SfjJ3nC3hevIqGinCht0U+ZfIvnODwLVmlnVyXftBOleXRAwx0efR5MJa/mtHs d/Fv9E571M4ksBCtDpm05xCtreMDkXySzdauypu/95u11V7itrPLqHWsHjzxL5+OyI4r/Mz3L5xB TrbVJ0Q6uXXkt5rVLW+faELd39VUIJv9L1WdutGH6k7Te+fq+XOV6Fe//m0LHt3X/ZWu9vZwPaWk mA9FpA02j9eblb38+nnYzEeffPB44/WvPv7sp796/PpXv3n83te+u+2VYpC+TTyVLONqR6OvTZOn zyZkmBRnE4s8+o71F8GT1cC/0pp6diqWwyF/uxvCjcLZzeQqcBwHsMUyNPrbA43I2cdW8U+aTPzp j/9kT8jUns8zKoqV+bTFpue6aimebnBSmxgOIbEYrNPXDtZH4JdwcHdU0fiaLrPj7HQB8Pm1AbYP fhU7WFsIhr5eri3Zyne2hQM5MccEeldSk/9bP/xe9+C9+/hb/5e/8/jGH34/H9QbnIXhI3fUp2SM HV34vX3G8UnBYVhskjF9nnhEvk/KnOTxdCdyQQ3/4iX9Dg7slDBQtPgLWG0mkU6dZN/4qPLhOBQu HwaMj2CNL9LN3Y9BdNr5OJqe8WgBmo7U21UaeYgOTYj6x5mrbPjdhD07BDY+BkA8Pock+Kr7na92 gs8t3IRst35ZVC8ZEPIW5amw0vL7d34QHd2wtQvJYohFbffwaf/uN+fXJrYWDy3oW3Q8sSsfydYe KrVJXe3S1hp6Pf3GWJjeECV7hAlFlKWN4YKXTajrZ0djcTnkW2gJpnbQIgsfJftkqL7JloUfJERE 44czCam99Cdmrs3AgL/LJ+YD8/lpZm0mkBO7Y3L6DSl+q0aK5ZFvbSG69xhi72iOz/VC4d8bLoor 21yQLtmHP8BDrEYjF/t+j0LE3tHplI3QpyP+wlePjfFx5MCrW/vgmqom18EHxpX4MT/dq5R+Futk SDzzxPYvjVL9ITs0+Ab9+9okhI8WG8dPuOjCxI3XP336yh7sRY7LmqPyb/6C+LD+JUx5U0I5/X7S Qtv7XeX9wvZxPrn2yc7Htoy+sYJ2ma72kNmrL2S3LTD6DS3feN4W5PTEt52fNkvmlYYiQDSqUuWo ZNFobLycDtjllg2oBIeLUc+3GGico887W+5hPX1Lakpn8Zz+8NvBGaeFZLE6WrcfjEblpw8e6MYZ 6ngPvPWYL3ablINjr8NKMlxMLTde4GCrGkF1AscwG0Zv/8GUvYtaK/KFl/s7fCC0qeGpYP2ecm/a OYHlXI3mo+lBW/ykcZmFsTe6HY2PkJk/r7/t1/E9BtKH4eizyRLi+DPhpo9j83i42jzd7K02MU3v cG8eRJz6zQkVx/OJq1yctt92Yt2GXcUYvmw4wwiWu0pAWc3ACyNzFkSlqcVxn8kd0Sm4sglQHXj7 Gqx7JjgCJcFR9izgyuQNd3DjnlIwftMKtGxXVwPPSfqEw986ljUGgb9gmLKmKLyF59DKbGvsrRb1 +8mc2vbiVvwzBkek4FHrd+5PHwsanBWzR2bKxDtDaRlnxeQYx4rzGfSQj9OeK714EBiesw3IpDq8 57H6h6aAjNfRCPmo4b/Px62moncPakevDDLeQZLz6Hxe9MCH6nhHrMa3SW/nrmSTzxM28WLxwlVE 6vUydA5oXz6YMzHnH+NmMHOg6bjGES1/UUn36WBR/eDcICPapzIMyXLEmq3Zi61jYZ9lRnPnRyPJ bk4AACAASURBVPjg8cUSaBy5Z5vyhr+8BYk1moMoFPMVcNJ+d3zkmP3mS0dnaywDrB6HOpTG243j +CK86iRH+BxL4+umpX1c9VfYF5GJwLpHXtq6/KiDWw7OzMdHA/5g7ntl0eObvIFPb9J6wa7zTP5R GI7TGeNscPihL78lvKC5gXr4ThguL3WRkwqG8zKWvFtW9W9eWIQ8d9lpF0fnti6OpfAf+4Uzv9tA P3y7GhUfJxgNKdQbPOBvbZ3vlNRnuWEWxPt3pkN7oZsJ3+yq7SutKNti+aQr1r2u9fFJdY+u05e2 Gx4y73VbHXt34HRwkE0miCc/4B0fnyOvP/oZXzs/euhwabgw/l9JspTBIZFl+ip/flSeWiQEZ9BE OnmjiqZFqjIMFG/fuNv6tl0eSIQwNRn8zoZl0Z3PrgiiEe44ys6oqHJ422QuSO0fqtlXuZMLDuja Ajkw9Yw2fxYpkyO8x2f4RxDlb3EBvf5B+UNkuinnDA7gU0elg5nOhdvhi/f7l20tcj2px/91r7z5 6W8+fLzyxhsb3MJ5+yQG3Fv0xusvP1594+Wu7LZAEo1XX33+8dtfvLOt0Y3jF6cX54O/dcvVhHw2 h7Ov6VQrhHc8HMUcefS2wBTzvwnrZP+XH6c3eFYvWemgOoHE52mJZT2DtT30ww+6etZtMFpqmhwP iNjSJV7xIwOovqcfG3bYHh0Y57/j9+j9yIf/U0bnYzrYTfyH6bISZobj4Dy+UsWyX20x1dz24xYR ztXw6GUTwiXVFpiefv0rj1feeuPx9/7hP3n81f/93318+9/5K1sgnsCjT7+88fAzYn2xM1rI71ge GbTlw9JoHJiowcVREB9yNqPfU3+LXfQ0oYfs0gtvkA78/fsMb/nDG65NQINERRrufOPQLSNE3PKU n3ZONu1CGdttYSMeTnwl842tetfxLTP+xxtCPtW/y+Zn2X6LSNVj0xEB5rOVlHTb8EJP0qgm2vwK zfBs/BNt5/mtcYhJrDEVXbl69lH3a3/44YfZt23KCFsMEIviw32sJpIvdc8evrF+So4C7n5H/jMe O6EPV8t4MpHEkNMeDo61M3WIcfWvzs5CVC3AlaJkNV6yhfTZ4Bs8fVXXdmJ0tS1e7Ars6QvCurgR vh0GlE/gHw/b1ZZMYtXaDUv2v4UWUkfTRMGi4Sb26pbHg9zKcOign25Sxp7bkgzGesbOrOmVZ2tj cPXnn/8YT1Px+O5rPoN8H0zQ0xYLG2PpFuGgq10Fh2Qf4qSjyXh4V/f2KwvEB9/RkzqVTqfIzD/K g+2MayuLzu/ihguf0+NB1kkQ5a29hQgGuwnfqI/dO3qh+AsnyE/C0znr20lymTz9toXKMwb11hW3 D1p4wcAhdGI1yehRO4yf4Oz6WfvvfDE9/o2ltmvBXAKJ6NCDuvOnyyidrV+bD4BcPj6NQ3j+Ds+P Nh/e+Wxw85D8gz+yTVSnPsC2T98T6LRdv6F1EbaEj3wDKbyMQXwoq/EME2YTe5bEBrDpKpB+8Xvs 3wna6WP9Df46XxsTR9SZrQO79MS3T/w67eN5+dVz3712tzYVfXX37KPgtW02Mdbz5OYXW1RgGw+2 Om2GjdJuzBknuEiHDpnui6jGa+yzW1rBZZvb76hhZekJy3BPI9n+WF9uOcHhTz0y0J82eMZX5lsA oKDIjjlNIFXueBUOAiuFSs5KzimD/UwgO8/RXUWjBIwThWIdn6tC6jQheoYzAsGCX0yP7gZYBWxB mnGIoqOYs+KHNKfa4dlJCAQseMEZ5DAC7xUUTiDltrg/AYOCNGg8Rh7inLcV6HBwVkZlhCk1/nc/ T/XPi8lN9uI5JPbpr370NRtB2UYWuppwEwwPiJQ6D914OTfP41cXYCWuBkzoZJizT09w1hguB/ys Ro9gINPZ7151wisdKNMQD9506V6a8p4sYF7BNSRWSed46PWZY+AlWt2RMHbPld/4TZfozrGSceLI ShhXezVcwy44drWrvI8bsIF7agKeDDrTXXUPFzi+xTeks20DH5mND1W+zqC67G9775w43tQ42+Oj WAWNgEar1C8O0zHbkqkz8AIen1pnEQw78w8Qh+/O0exvE98qqUf3YG/9lBVeweNLnW13ABqIZfv5 /uxFjvCGaW2G3HhFl97iaLypyOxBnq0YbCQvutF3SL/qbsILT3l4WqKD5DiUkDt6hBGchSQJTQo5 OtNWeH/15AV4XRBQDdDqTE87It9ZneNndH6vvsF3gY/ebLc82hzJYZBPPoMg9SdjEKlq9eDVXMYf zthI/fLPr7KAw00k/vTCq08fb/SESA8QMWj74ik5svXtJ9XdPegY5IPhhO1l7zgVr67zxbnyjyx4 PPzN9uP50tMlKLjDx+Hx6InfHZ8kEDqD85vPqTJJBDwHdXis5nSJXsrht8+yDnoInvEKlv+vQ6MO uPqgOJ93PAR90V38QzPdQlTw3xOi2VBzKZH38LqKX9KvDE6f086OrXHug44WOdnwUZqf9Qvn6rhs lO5nu+qchEk40DvHkCidm8rCNcQHYpCnbR24Md8VNq9U+9Uv33l8vwdavfS0QUyOTDdEJ7k6r7Uw 8k1P9f75Lx+fNZB//elzPQHZpLl2lV+vQ46WOIviHWsSID7o5hji1hO+4cflJJish1FtfoPFiz69 iikw3XHjGC1Z+UtwexBMtLf1KzSbHAXv9RyeaFvzz1/jJNi1kxkTX1EfH/wjn+h4g3S3vVR260H9 0C/PYux8TL2q088GQPgr797OLS6SDdBwXc4CRqywue75zz98vNRVht2HFXPz5wYgXzS415d98w+/ 83i/SdN/+n/+e4/nvv09rtegCtYzJthA/qZS9h0XDt8YDDI51h6zxTg6TA2Hw0SbbteXsR9BnyW8 w1FG6O6JK0Vm9uIpX8oySAVDF6N3tQ0SnYYDwYFhx1WQdZMSz/pTV4LPABMvZLEW/OWCajCT6dA7 8NXGUx8yQjOeKhxOsaF4ZREGn4cF8QZgvnnVO/10dke/fOWX1mrzZO08Xj0DweAU/Jnktj25K7gW u41L5K9tm8DVvp7YKsl2/WgbR0/jHCtj6FYFvsmB0S/1QbbagHzia9rTWXmdkPngKT/8Jq5n7HEG 2GXGkzGN993yzOAuWx97Zcxlnh9q2QSjetv9MPzpQxyaMSoPD7yUOXZnK22hDxmU5ezK2HB0Ol61 CHiFkPpGgCa69w67jatcAa/Rae/bKh2qM1k+8sy/Zw30T7rb9dFtuCOsrUV8AA4Po9VZgD92kD0x wrexSfbybIXVvdCf/ile4ueWgz63sy7E8z3o+6PHY7fbD42RTlzkO3BtazHCAR986lWR4kva2ZMW xWYrWWN+RX/BL5xgjG/f9Y01P3288867ZVx0THQttK0Ng+Xf/ZZWf0fQdEaflxzafFlVSwfxPfuP EF1XNt24aKU/Ob7F3yaGdpXt98TmtYVrvE+37GKcFE5c+RzNXSfOBcGS9rD222o2XvGxOvRI9Mrt +FmfQU6+GNPg0N/25UAtVJ2rxoEAq3zyTQ9n8m1eQsbtYuuX/8k4MSlm4CzPuGLzqKKqdjC4cQVE Gzi80s8mwM7jc2Ov8syh3P/ueSGv9zpEu+/QfTub6dvoZ3Mo9S99amf0tZ2nyaMdiEnTYfna2fxz Ornkq/4u2tSe6cpXraFvMsngl0Rk89poOJYYvfweQgqYgmU4psgzIF9gKWcPyKCoasyuYTRQvmEJ ALk99wd/DUx0CFjj8zqJzwputkKY1BjEb7J8N8IYiYUpaHyEazjRoEzCT4BwNVComJw1gr4cp9DB T7YaaUwcPhi4K0zw9Fnqd4qprgmLbDTm6OjUia8jSPEcKF2uA3cIjy22gq8600ffu+LCiMNNl5XU QRy6F5Q8nxD5O0HnGIMzS743ya1cZ07/d1LPhHKBdMIlE6akKo6f9XYc62xL0mih3tbOOd2x2e1Q zxw5x2WTj9oqaoVl8pElPBsQkTtS4BGb5OG2RVfjUIiTDeIEvquRepCM4PCKK2s9bVWnSjfSGlDH 9E5vnHhPfQ0XkA2Y+WF0PuVH5epgFsD63QQqOP54NAri5uXYeHjDd+8E2Dmo36FhwUR96yS2Y0Tg 6FKDutLR2n12fucbDglE5ulAHb6EPoe+7JneTLvZ/6SjL3Xni3hka6j4ZEDnnlhboXQ5Tb7ZdiX5 2fyF/cu5PkdDdHHgJmOHJ7DVMYclyabrM/nH9uFDBz0tXud4vO2i/u0v8ievHzzEMjr9zzcFQE/o I+h0dpWd9mWQxn9OOvzhtcpE73CLXuXw69mqzLvO7E7Y4PEmbWEnWAOkTxtMX1THr6tO3us4v2rQ Rs/7VNf9XVYiTS6qHfPhC895kB95Dv04uf9XLi7iyyLOOAlOOjowCLljwPGxuzLZ+Ii6l8PCPJnp TH30b/9U78QayP2fjuHWS7mDvTtEEyKcwDnes81UFU02v5DM/7CwmF+cU+LLrzxHhweHR/c0vbhT 2elY6KpFtOKq8cZw+IZ4A5DjD8vKZ9lt9fOJ49sqZYt+prcYnRzOoYneSaQu0U02AwNgbFY5S2xw +lI6/+Uvf9EV0W88Xn3ljWh1f+5lh1tWV4ZebkL8ve98tRjy0eO/+Uffe7zx5o96r3j3oU5Dp0On A3T4+zpjx9px9Z9LX2Z7cT6ebrvxOenUqWhcaxjXgKpyEMTQ8W+gowLhogffwdlVLFfo+ufersq5 YvLZR5VnX1vw7rLYmYy4mQ4vdOSeLw25OHT6yzvOo33g/R6Z8auetlSX1Zk/dohr8NnPuZyTH0wH 2rTbe7zKrmH22q78wcTrK70P/vUeMPaP/uXPHn/t//Q3H1//7l/awIZjgoNe2iFDXVQO/2hc7aGy tZsg8IS7o898IB6WFxJHsbt6iS2kXDTykwZ9ixlVnI9dPCALF/zjg8Iod7k46i/YU5gN6CK+NgBW B4+XfthfNbjo0/GBzcPKu2WAU+I/FgDRnxTDp16w4QS/xZN8XX3mBzsafQ3P/Ofia7SDLZTrJ22R tvC8bciNy7aA0gI4Peze2475nZjW1PbE0vjeQ5zop5j65SLr0Ym+/vAQnemKDsYyzuJbfKysY/mR nbSOjS9MvLfLTV8WSpPpl/J5fknWvYM6P2QjhIyFxHa0br2esYlzfWNA6IdrtqiaHWxwTffp5578 Quk9o1tYaqIBNzttQRmacDjnQ9WejasyPyfMxmJsE2wtaz6vnI4WM7Td7LY8i1kdmJiMXryuD92Y Ihi2Dyd62hGc8118OyjJ20OLdoK/ytLf7RvepU7G+Rp+xUb1+gxDX7fPDYZP8VV1Jo9W+69JEZ7u mDwci4kXGHzK5CdC6YKFT34F5KKGlxrzsZXc/zoJPNlDeOo6GaP1I/XnH7Rg80L9tzZBZnHLROvw FFPp8+DISsVPPkmlJj6nzY1x6NMdX8Gz3Y1oRqh8utU24Nl5tOCQKx2df6lPuGDlNxYA7/EB2y83 ZYGBb/MmByWinTh8fHb+gApbKcfPnUKw/oHc5eFbMravFU+WG9fiSnDatjG5BBr+G6XJJ3suvPVl LM+G97iafhfT4oQPLBbgqn9zO/OwZ/4Qbsfnino77tqF8fLLrzye9nDevXrMvEU7Tg93HJ4OyRRP 4viJJzg9aRfwwkkmvsZWtKLt3b7md3Y5Jl0+fJs7hObIwyrpafM5eivWjfFq+pugkMckPILcyati yAiMuXtP9djg4SXl3rWELWS8jkZdEyeaprRc8NL+EWCvsgktFDoX7cykWGMZsQkNtvIJiP3OLyVV TIrralYnBQUPkDgr98cQU25gVjCHafyayJ9J7S3LGRCk4Ehsla5fdVEkg98FuAA2+JyiLwNEejzF I57IbSVVpWy2PPz3X+prDnbVqZxzMRRbTL8HcPRVng6rdxwYMZ/Ok13qbHyvUceXoJ8JL7qdBydg Shod50Nrk9SscpzRMPLwzanJvoAcX3jSSdxBzPEm9MEfW6F1AiDnuuGOuA3eOLsAhG88UIHDDgR5 K7/0gg4epqt4nj7S/fQdxKrQgwk8nQ1JNeJR44jl+a16qxs+rWIrvMf7bsKHBtsEcnYoFDrqDIMe peMDR2cIH/uxIS86cnQyOouVVbsnbZMDb9EeTBiJeGQ9OCjAH9t/KV91+p+pqnsWTbz2INnqZjEb +OyOg2Eoz9ZVfqauFeW1N4BJMzYcle2pqgsmbCuP7vtdxxb83sU7G5RZIivKJ932OfWOfvkQGrCA h5e/1F5GP5YwEBWnjk8gTs9X+SrirfNn9mfIcQYn/Je/hoNK+SVhN3AxSJIpJ/zHJ9JhMO5HE5fu QRA7W1G0jf9pW6ItDh1SFiX43sFBHv5/D5YnQyQOL0kYHceoouf8WR4kUr/jZbrZyXg6hfRBkOvX IbtJ+0nmDnXqd6JbSUe4hSjHV53hipvpBd7+tWmyxxpApEp0icQVt9i6jOkPrRWSDW0dW3qprrZ7 OkD5K4QsbPgcwlOngd+5p10hWuE3GAzmLBhUoz7iKP3okO/h12eu67Cs04ZOLMvhyzzwY5EOUO+q ja3yb3/4xeNXb3/8+OpXDRR1rscvz+vczpWYN3p41dMmvl//ytPHV956ZVvi17+FZ7EOA/7xfflT rBx5RxTb+WhhHS98j+7EbTJsUYquq79Y3uEZANIQ/6AFv0eODkFEUpts4tHOGwuO4GyN5IMfd8Xo g7ZkhxQw1KsPh+RXxKLnDUwCYMtnfZk66l66m2IhAXfVX+zcvVcNUONjuKFHY+FTBIjPaOQQy3cl DI+wGNa+ECy04yG+9bVvfftrs/3f+b//f7rd4JubHNs2e/e3URgfdHK4cYqrkyZh5/xguINycPQX TAB3/HJ8VIKPsKlQhrpXtdkY5sWoFrsOHrRlAj/wyy8DPv3m3l1KdrT98I1+MTBfWfUv9XmPk+A5 VyxabsRPH/49H+hAe9xi7GiP3eG0QIQ43OBrgMQrKxqXX+JjfXgAZNwAtmMPlOEve3pys2T5nzaa F/NHuYr6fOO0vY4nGs/1dG3+Twm7neaSHU205c9/OlwePYXHsXHiES2YSdaP2OIHPt8BeJAUGhZQ nvTrlisVbQtePvJB72ppbemud/jS7gBEcQVkyDYX3GpucoGjM3nQliiYDTb2WT0T6HQa3WNjeH3O pGB4ygAqjS8H8SiRQxl9Ty0XJFxHL8qOP4HUlkc7m4mJFe58caPj0MWHsXHtC2L4+00LZfXpWPwN 5Zrd7lG8J9ZsUAH+EcfB0WPwG9yHU92LDt5141/25VVCNDwkPnEqXpY6748M618unyuENK5roZO8 fYyxxfR7wXw8wBZaPD91+0Pwdyr7L5TglsDD6WAxqoNPW6j5be9nX59ylPXMluOXf1dvV2Hh6eTo vuMLL5TSzQ8eayZ5bX1JfpRmV0pe/SkyknxVz1ikgwrOuLnjdLTJbBDahN2m2jwctx1UZq+1737n K+EWj0aj43PxjD2UR3uLM8ce+F9sARyuY5/krS2d+uUgcMm5MTge+pyLkfAcOSYiEYK/0FUtXwDb Z3oPFbksKOkPPWwNVYtWk7e8vVc+pMfPwtWfLe1em+rCAtk/6PYjccmtkuiLRfRqT6yE/h4E7ADt i48p65azIrSfjUHoWxb/y8jEVo6PHa2/O7p/Nnm+6lDPi58COGIGdQIaxz4TR81klI/jYYywdY5j gtJSOpoTfIjPhIRiCzMTas5RR7hB/Ix8hKvrCe8x9otZekEwchxrFUfF4QnMaJxAQUGxorxf/HJJ ncgK/CooaZiMu0l3Dmmga2BkNUa9BYRAKYfyGAr9U13HFS/BLTiSr9PJStkxsb9L6XB5qMUeRAGf QSCWOjbAMvlyOvbCpUHevHN0Ol+6+JoRJ4oAduk8gPGsfnC7IsQOYZ7TVz5DD3/6DcZHILLFWXLV cQLiqc8LtljgtTqu6h+6/CJe+3s2aUgOZRvAXjq7r97S3WRJx1ZsNWA0TDw8HdWT8oaNAkpHV7g2 UD0DyN3vkw507mdSXWF46WVbAAPGz/7WGsl1zuenHUsnoGQfdolPtLbiepUpX4Kvzxk8BSh7lTTM yzfKGq8rrDj/VTYdhffoKE/OljqPC2x10sD0YMAi8NA1rapzvm7c+EivF7YTbI93bbFAZ1cZPWhL OsBJkC1UIaYLUcTaBDoZ1MPMfKUjNpMmS/X8WmjiG3c6K8kH4eF16EdrbbUinKhxB1j1iX3TIQce XaGWLOqrpD7JtS845I9X2OLV0yMFXHUtXK2S847Ocd/VNdn5PD3wSVXXbdNvHw8/2OsWqm/RiY3o Bo7dr17g/aQRy/N1dG5N+ELbPsxjZoejheSVFKOjA5PQnQwV3LpjD5zS2XmpOjtfdao/f5GTX+Nm C3zDl+/CM7wH3/oWGlKvPzV8kWMhHg11jLzyudR28THIHW9grz7bnv/ppmrDCaX8JavaEy7blIeb sEajE/pj3/R9p02+zypVkhwk+LnbIS74+9H6Thb3xD72sNho0H0WSy7a6M7QDnz6H8lzPrVFgw9J dEHXBs/weHLwL3/77uMHn32lrXe1jSuGaUdYges73/luTz3uVRfPfThe7y3Ez3+WL0TzuRZCcI34 9Hvr7pCMrQ4WEw6MhabZznb6fPYwfWGINwPeTxNqE6e7LU4Q9elIO9Gv6G+KzdF/oWddiN27qhsf yl2huwcdz1uUCzc1aN/iFtutJ+II8C4IlDOfPP6zOtPvREgf2iG5V2WxwXU/MtLnBjbPtAFXbXNE g68O1zNQcW8UP8G/+Ouq+GefBd+9XG91Vf2Xv/zt42/21OavfO21bC9mVr36889swtf8n+SgHMgc HUCGXt4db+nrJLIdWx2FlM/Q8bQYEprBRs95X7CmS794Pn0H5kcLUjRLB/M5Qne6zp5fTjqDwAd/ CGx2CM84x3+Z8HuwHl+H/1Atn0+qE4ydtsrGH3JpMctMZv5t8kpG6eP6D3BbDHG/bbuyPEjK1S9P TjY+MKAm6vou9t3Hzi16Cklf/u7+b3nxsAl1J6hh/s6nm7Tk50rx1om2I58gYqlE11uErJ2TiY2N f0x4DXjVcSVoYwl09n/RCpf6+MXBEIeHqbQTbVj56acbj+wc5IHGL7n2C4fs+MTDJmrpHG/TdW+s 4OMSfPQsDX/H7E3ee4cbDYDAy2KfusYeJWV4I5PXGBpXuf+5UdlYu+0Od1jDe+GKx3qn4XBlzR/3 RMfxocXvgWjzDnYyGYy5R3i0jpzbTXPxrtb8SO0pJVdFL1rH9mIGn/Tn4k82TBB6ddWTL+EDvHaN L1/GsGMqP/MeZfeGn3ZEumpkq0Y568df6Uof378T7ofnzvjX/B4JrwK6usZ4uJQ+7p3fb3/Q9mbx WvwtW9t0Ucik7Mgqk26Nlyxmq3va35FDvdP2F+/i17ZpyJ71F8nJ76YD34txJ+8ex8A4PFQiDtB9 sDTgVYlPnzylvoNnLGjXtH7SUSVfw3c6ywTivds/+NR8M1Ay4p8v9RX+Juf5j4LNCNio/JWTdb5y 6qinvqqK6PH0D+L8aU9HU+nj0tlNg8csrgV37yqocsjSafpGb6+GbQx15iZwxH/5Lhawv9Hae++d 10m+/HIyLp6lhqvfPgtSRyPqaf/3FWjtlcs+03G8u2hDDkpkWyfTWTydAjYh7+mzyhw4HIs7DFLl XenlNPzrvodwWCsmDBprkSj1v9VcAvvcZR2cYHFPlgvYKXErmRHEiMUuuDROK27qKxhDw3cuQXOM AZa3wUswmyz2O3rh8LsVs444wRkAHIea4kOxBoq/0gyK3vWJ6uQ4QSxgDptCBS2r7ow7R+IY2PQ1 PBk7IQrH49tgUOMgR1kzQBUTIcOXsbrROhOEEASmZHvrKzxYVT8wzh1L9LMr7p1zDrmfNnl82tYB sq+DUy849LZN567XrwZML9NWTjB8ETgd56mHdyBk4jdIb3FgMnVebbrXAdDHeKOT8o8s9I9XkMc3 bBFe8AiZm95tPTHQvTsNfGg0VkLp+daB+mew1QHnRiAceDor0DEoV+MMx+1v8qaP8rGhMUvTaXA3 DpPoTph6ZQOK+v7WGCI7Zdx10BaU6MaE6kudTQ94kBe5WzcLQmgGT070UN022qGFM71cfqUQlPoQ gcbDwR/u/p75cbDoDWNC7Ah/+Fh91KjmBMHPLz0g4B67qj7TDf0d/qqwFLbK1Vfmdy1fHoWNX5xK wZannQlS6sHV/2zCBhawFBzeTz0wJ0AFWxkqcbq8MAyeH8ub/CiNqeCG/8DwtwMeH+V7KiWzucJt wmAA50rTYkKgruzy+Y8/PX55HlgXj00w3u9VR4sj8byOJ3rrcAjTMX7ZyqQokMmNl1snWMGMFmHS zSe9VocOZqHp6MQBiLkZCYnl69DssL97IGYwNB9BJ8xK1YFzix7hmI8k8+IXDsqD+WDayfAv+Isd yS8hS/foH4mGeWX7ChGq/nZlD/1gj39fdPBFVgWRog/p+IQOvMinUSy7r4g5FAPla/u2XBoMzyfS 2XQ6oGDXdlQfgrUvGM49rZeeLBam25s2P3v37XfbthneJr1jelJkw87uBbgNqtOHgebpNC3waRuH 1piePM6PhthFXPqip9N80SyFnaeWKTEdxIfPBgj85MLFhvR+88iPbl9bPvmqSm9gX2qi+IStOt8C VXkfd2XDouLTnjYub310OmTDE5ODDw8ZHfExA+JJ3ensUDk/INGRKrDxxib5pLYd7GQIbrtewrAr CNUINPyzdiDJwyVLa8Ppip+Uuyt4/POjXhv2xne/8XjlzTcff+Ov/Z3Hj//5v3p87fd/GP/xY6yW rm76cM/f0IcTg1eaT6SLtYDKgdzFdHH72LFSZVzuQnD8/ci9/g5NdgoLmPtDOPbCh7Q4vCPwHVxl Dl3dlqYDOMY5nuLqpjvZ4jmdjuHg0bXTac8TGE46TM/HaGofOhfu6V+d+kwLHtr6x01ypvG/qgAA IABJREFUP+iJyR91f/QeYFbeYml12BASC8ceYLk4g/7BvJ//krE/6bknTfP7vqcqK7Mya+yqHtik BBGyDApeeOGFNn6BfgF+Fd4ZsAABXhCguSBgWwZF2ZxFqMk2yWa32V3VVZVzVvr7+V0n/pkm0DTj ec45Efd9Db9ruKeIOHGG8VXC9892tueTwNzEvjq50ofJOGyo+XgnvqpQ9sF7dxVHPnuAE5naidsa 2b67ALSb3b3ggVOe6UHQxe0Febqe/efEGlfqQ2qg+U78a3v0VuG7sza66Hly6XjCDVwIhyd+euX+ 55+LSZURbMKNKv5n3MYjd5/28M5HxYheutaC+K6yHSePb8hcLlTnz7YWEQ9eyTVdsI8GTzJktpx1 8Hq/eQAJSJOlilQy6MmW69Gqchz/+rH20XybzliEXZo9faUFOR6CdVN0v8OYDD6iVlNB9viHXsLI 1+/4qqL83AWv/GwB+uBrp7bubr/Xz9BM2wyh+K/Yzm/w4J8bFQHSwfySIXty+Ccfo8omwZl1q9/y Gjsb4tvdkb7WVF9xi7J5klFl1M0R1jZLzKe/1LYlPxwnOd0QvHxL8fqdYPEprLBoL71fm0w+X8iF PDp/TnMy/ERraVFZGPIbE8zjPXX7abeLB3FkCgYplKzA+5RNP1fBIJbkbn4Yz/Qn/MrLtHJ7cUuX foiIPWH/xEcvr8z4im+Ctj+b6ZUTF4O19+K6ed9qfGXRU9z5sAtc9U9kebDoRz29mzv9VNH7TgB4 Pk+xgJmcSYY92bvTKb3KxeDmcee/2RgN0GLCF+K2E7fR72SD+sktN9XB7G980eebXQiUpwnwTKac c5ORfUeiQJnkcbg6KJ9ASD4JIxWWTFUveCOPnqMDr6Pm8SXghBB0nZLfg2UcYJJ6l83TtWNkbVgs eB9nL4gPHp880b9RVN1eO8yZXfJaI3f8qiNdAhh5Rwujw2StcfSpM9w2vDJopi8JyGMbZJPV3k0o cMBywVMrIPezEq8OKnlrtNHtdoDOrGFxVRMWyfh0wCAucdEK3jqUZAZHA3puWVjevvwa9MzKV8VM N3cI0SctP+8kQ/Y6XDLNsB2CPd3rQPiAvx7b7CRNwU0cOsSgNFp6d8UqvRK9/+mCe4PCixYhX+FE xwaNhmy0NphvR9lNGm5hVF2M+14ZPREZnJRt4pNdhyUdk3Ninu8lPJPO+fQVv6SNByWINK+v62A2 rfxyikI+uc7wGBZ/7WMbP6A9OTA7UGuauPKEu21wPgj7+ecYDp9OqfYX7xpzTCYABsX5QCdKl7d0 bRKQbH4QSp3YV/t+5uml/LlqJr9AAmTsdPQab+WP348munQNu9zzt2Nld4x3uTBSnbbJEh3qY+81 hYRU9sSG0E1U6Jyy6uNDM1eysZcO65FPHprHJ4/uDSTRfeEqRwte39v9oMmVhz44/qK+54vOln7a YkEMPqv+L3/1q511/rwHGtWoduXB2UiD89df++kwyoITv9wyaVnGhkm8Zsfy8ggXw7BfuzEoXR56 ovSZFd0Me/HyH9aXT45+hxXd4GQxhYY/N/mIfPKPrX7i/My12s8NDPlfHrz8unbYwTf5qgrHyZ4d jtJzcag8S+OYXrq16cN5dNifkE1Sb7nkTrTkk7JveGAma9sUTO2ErE13iN/k3EPc3AHygb6AXV47 K3a4Th+fhaVYLsfaXSxSTtNtYqBP+M7bxz3l2M/C9Vyz2TZb+IY5xLzip7/db9q+3aL75JB3+tYH Ggti+rqf1+Gnp19k3ndbvOlT11YyaO007FDJmeDO/5vM1C8b0HkF5mGCByCc2ZeWyv2yXLcD5hs2 8pe88PRcV/M++qEYcWU68DhpPKlgV+MlKHC0v9j6pCV7Z0tH+sH3yRgbHfqQqGCqHKydUMmflaxf fE5WkyVP9hTw9ogV83bzv6Gmt2S50+knLXp/0W1tf+//9o/fPvjR7wA+OpMpv5vKT0MXHqOqtvJq Lo4SU+kqohq87JVf5Lzbro6tQ5sAY7j4zj5o58foJusY2WGbXEZEt9uQk69drW0VX3I3P4jh8Bb3 BPH87OSL8HBfQQ4bWbZso4/JZKirb5rXsVYl/vu+trtRIna11h1oThBb6H66B031UCl51naLrOSn Y2Ponkh8/uCTG0eq3r58erCkjwy+qcwcJssQzgEPmSiYB/FJKbg8rKWOzEnvLRT7ZLuY76pJ+7s7 wdiVDlMMdPLXYle8POVZe4+0f/O+yz3jmrvt2MX/7rrx/ddlA3+GbwuqviKXmMVh/Og7Nofg26fP WL+X3vXLiyM/nX8Y5Q7CnVCP1xXKBe2pV9Y+tbDsAkMH5hdseOYy/CdO5NIP43KvT/7YHEz+Twq+ SHZxR9vtLxw32efF6pJ91N/gVAavjN7Yn+zFtD5nNlYfrJMXqbrrQ7CJ+yQv1uK8bqYyY2iVpEqh zL/cNg8oOkW/8kgqHvr9mkh755fzuZr14xm2CxZOTLRNb/x4qb+5/Rc7GeLW4UM00v/IG8X3Ouvv 8N0+zhR83ALqN7/5zXwXmC14NDZ6tTDjuU3Mbj5c7vNzvHxzc2u04YxGLuuf7/ueDPBvzNdmdxhl JZWT8Ww7MeWwig1bBJa/nnzMjlvQ1rbLa7dMz+nxa6e+cmOjg01rM5ykrn4CLtvWG2joL49sW6vY d+hDvrTBtq9vdjzbJ4uNr/XRbDD3PtnslRLbEoF/t6IrSwbbbbsIOuPhgO0lLxrtWnvbRYVqbx3V zwP2LIePelCoftSC2JXe9R/JmVg+y8bL1XSwoz+5BtT8Yr/t5kZoi+fivJahYnRw+zO2k7J8pSQD fFx9O7ZMJ1XZ93ZFVgIUoFPf+zo4lLc9zAMx1sonPNpXkKYw5acsHQAtsNFmBJN35ecxOEID7ZIC U/VASUxnZkxKbU/jh4GxZI2S/DpbjczT/pbQOQYdLJs8dDyvkjMMaShgeKjcpfQwLgjs0NGhK2Cw 6yx2lpHa6PFscldvsjMKOXedZJUHLcdHYxM8vJguwcICD3w6bb1PujbQwnu92QZtTccAy980m2i4 jSjkVWg4r0Zc7fmFKPX5Lvl0T65G10kGgykM/L9IAHuSR7eRGNbq6ZRE/HCdNPzJW3Xc8S5hq98k gC9g1TGTORknnw6+xTuc77xDT34oFqBcXbRJuKu9/HI+QEDmJfQl8xpGsh8+eiJazAw+63j51yKG guw5muvoFpvK1T0yDGReV8f38IlRnC+MeX5lZ2M+qiqKyxN6skeM+br/nSASlXoU8CZzvhO//jYh 7dOk4XmIUmyHi66XnMc2+nSgGwAJbJtfKoMtxtWxQa2JAyQ7sVKBcj7mDzi8spSY8vGl91s+Ub72 vbIX5RlSxQ328x+9J2bSyJoe+IdJ3Cqs9I7tHx6fO4lV/Sa7jntRs4mGM5DJYPdBtU9S4S2+X72u +im06Pysxe6nAfikBQOez8r9X/7i128/+tGP3z7/6Ot+m/WXb3/wB7+37/RSwpcEz2fTKY/gvdyA hWsNdGXPclaY+2+799uDH54mRuXN2uqqTw57ZkA0YlX0p0OpuBE1O49qZfNh5Tyf5OFYVgVA25Fn eM8/Pqck2gCzjS6yvShQ7dDb60Bfcr9F/PLFaF/VfYy6MhwTO+OvPV4/VF+ZXrFaiN7pG2sw6BV3 Auz227m9xGmTja4OTTrIlW+MecFb+3jZ9K6Prn1d3F7yEq8NfPrpV2+/+NWnbz///R9P307Iuec/ vLvFVMYMY9r0Z9l//Q9lF//rb9diZ+/GiTo2+C5PXv1CvI73sLn2D+7ZqW09C97ZG7YtEuaHy5Gn XBaLVdJ6CJdF7524cXL0ty12P+unilzZeybDs5ic+fJa1Mo6hnFtqwKfh2m17SePKwSwjT5/8kcf k9tXGuMWIxv/JvOw5anq4UBXGjQ+v0CsrLtnhaT213e1ftR3un7+k7d/+C/+1ds/+yd//PbRj36y sU0sv/Y1GnIIAXAhsVB66Uk/hBsbqyRzhJLnWzbJBTZqF/Jr+d+xPkgfshTB6fIsGb2mzqQNb/0t 5ctNe+eA4mYCnF9yDN3PbeYv9TuhP9+Sx3lk90Gfk/kK1K/9J4AcP/2DxhV7E0S3KVvMmhB+0lWr 6UzvFqck5Cd5Zz72fhPcZxJclVoWb282bw/P6V3+Dpv42Iryaw6iX4LZOEOEmFq2aAN+2/w733F7 vavF5gzNvdiRNvMOlm2ccZwuf/j2Mz3FUN8E941FfX3MAyHzKZq7CwxfReRHB69bn41LuPnLJBoG vhbIjV2g7lV7rW3gk3vopyvixw/aiIs22hC95lM8Rd709Ln5aGXALEY+2ZJchNdq0t3h5nXxbO5V AVl4bqlHSMeVy51386SNVZebo4/muq/oMHSAZ7tyLP1JuTrl/etL2TwQKzjdSNd2ErQ+PXrHIg3T xvZhOf16LZw0zPnR72R3rcZJ+NXN5qrj28mZSIcvWmXw+Vt7qG7+mR+T7ZZ5ZcnAw8/bD7+7qD76 6AcvfYT2+is3xj5bsnYYQ3bqw7XVYSqen/z6N7WbzzqR9v6uLkK0tlv/sTspAjHc4eEUPtkdkNpq G8RZNZy7+y6izflaLF8mHg65PO/qS/rz/8TtmaPQw971QuHcV2Rid5LIHQ/7Tjcfxrt4TXS42GS/ N3N0sSFj/R4n6qj7vFFoZNNz7K+4iI+xInFM1ZFj3ZgX8t35p6DXfVz/Pxq84cI4XM1rLKqfug4r z1PVy8Vq12b5hz/fS9fjQ5j4kZecxI40f7637/VqE7/sN5WdxFPGU+74tAZ5FyOl+RgcbdZP9OkH nSyTc7u7cpE5rDDAdbE4zOgofvDu5Ha+2ZhbzR7CDNfm4Mmp/3V6DcsAv9izZHISNC3nnLxioSdI AjLlnCVIr45s36crORkFvO9y7kxfwDnG/3dNVHVIwOvIkrfUSgyHbBCoUXL2B37Ptz/OxgvnjEs+ Z93gNTQisklIiPVYvcWAvo+dbU+2hBRdZ1XJhV3gTQ5PVtWVPQu7JXX87yYt1T0DhzPgklaC+cHz k0f52WUgTOy9yTF/oquoP3ZEMtu4dQv9aMikF/MNrH3ykUl3/EKyRagBIxmOp6a9nfFQoExhm057 9S99O4tHdoVs/7qBeEKifecPcnuJBQwa2BYm0RPvxafPNtuUx5PE2eTT7YDX0ZKtJHkcM1r0/PGK r70Eb3IEXFoMVsubjuTAGqncSlaq5o+LUbLjWd6hW37pSr7ZSNwVYDttw8rxr32f7A0O5A630Tsd cMo5euiuVm7RYmCXcaU82LdFN1M7lj/zNWywZ+gG2oxQvo50Br2YK0tRss8/dM7fFS+1KZmu8/xs SSZZxNwx/WGDJr75zlH/azvtLDMQyK9wwaHUxm4YnzazBZUqOnyQHZijjut2pus6RTr55lURBrtP jOh4tqomD65nYjF/5df5qXq8cmHa2dOf76r53txn5eIz2HynY18D+KxPzhKT97od75NPPq8D/vNu U/yqn6v5gz1dcDYkmH9tsNndd6azz0mTTdxYOTui1fDb0LkNT5uTt5uoEhPdKCIwtYDzoV++Z9N8 yZZopjseg4c28vhUOfqXxcuZyalELtDxPXyTfm/z305+VXsmRYfGQa/l+8WK3BkB79ph5jYgkLuY tbNeFBnx0eEZ3vLF0fnrHcH6TX7hDxQ4vS+/1iaVlh0VOlHp53i+U4DE/Py8VlU9jRGdoMsNZ8wr e3C/y6uVRJ8Nv/r1r6P9+fUb5RIsbjdPerGQi5GxFcYBhWUIRzu01KprY5/FjJ9BwiwXjXFjRYK3 TxqUg+ylD+tc+up8aAcmV7eINxFTFZ5hPzpnx53w+6zFkHHWYuk3v/r4nY6NBYnHN71Tn4RhIEsO lRNFTX/Dhmc8oFc9W9ePNm5voZoMEjcuRc83a28vv8O3/7VLahmojL7b5U58059hP/7D3+v70e+9 /YP/5z9/+7NffPz2137nd7sr47PwhFvHSc/DQ16gNzaoSiQd77m1yabgIFydY7Zpm2dRn9u9D6Cc BOtq89lRTseJDf3z/pyU+I6fWKj8aY/qDWuO1x/mJz41+dpyZ6E6Oe4smT3FY31VfYU2LKd3kjlf KDdJ3xXcbv1zoseJug0cfNbrcqxbgN+/+MgleX9tOV3zkT7mrIBx7YL9Vc+vLwvFvP8KLx8Wr2gs MF1hv3HoeoPdity4HnHtpbbF725Hrs/U0jbuVQcjkULnTU4cZrRU9QyPkonuXcndAvquAnM5Njxf V778f/Gj1+aVPVeC4D170hM2ftsiNp/sqlO8F7MJTS7pp2NymMNPZCdraAdckZzxefmANHFt/JFe /Xh/xhE4+q8sAp9I45s+KivXpvlhC1cElePdCSG0Lznjq+5knjC8d6EGJlj5/4WEj7U/BadxCDu4 DbB3u3KIbD5s3qhdhOWQZo22NTEni332zDHNA+UnBFzG1F0UYbu/cFTdRiC6k7r5uuMWMMsvtAld eyM9QXRs4ccHL/nbIe6v3Kbs8jz588HAY6gddhLw4376xtzuu9+5dQHFXzuZg779u1p5eGv4k1EV C25u1yeca6/FYCdaKlP/2LJ9ZRiV90J/+LNV21zNFR3ZeQee3Foszif8vayq3CZfpOHNrZaBixmf agsXn8vdaysxpcAf3Mp4FzZrjs1T2odd/Ec7cKdv2AQ42bDRuzluRcajCqa/LJqNuOaHaO27s2Fz f/1EZbvS+5K1Pr/EeeaNLiCS7+6Pj37Qrc1JcFV+J/Na9G4xOjv1LqdHm9TXXjuSy/SyNTvrwzuM MB1sEoKZwW95ZMbZ42uEsOST6NjDF4KhP4PLV0zcP4m2uLebEhOpTQyqmq6wbVGXOAFhHK0639MX VQ5lTOzGGlDGuwVcDesDv9MEDNL49zAiMpIJiFtcxsD4yr5yGxCggMV/Ha7AIBN07/EnC/3wJOdZ kOGzv0YQ3VyCp9dJoCP6FmMbW3ykT+3QP46cTTcgrYiMdnxPwYRE5yJRZ7fJqr/q0VLl1mxC4bfp 5JzrQMnX82fEFrIGygvjIEQxY2frJi/JMXHmLxgIXmeVjgW0st2GRW9//CNUHirydZP/7Wejz0rC mJz+/F/j6ThMS6KX/Oc40nQizKeSvXoI5mOfoyfqEnd1Uaxx01+BR8abSl9Cx7R6MQpPNvhckrez BqlNAJsjl5uVP3rGPbnKxK63NvtoN3nrmNwtIrJbzszO4Nvm6/GGucZoU/+8YghtbSLC5RnhC+oo FbZzcY2wY7Y7USFG2a6Rkdekh59QZxgyjjpf54Otncj+1rYYd8wsKMRb2fmi81PJuc4DOMUt+vIv nPSu48Ofnk3klMNOd9uTj49a2u+qjj2DiTi9cmH0itM/hnKrOjodbvCrzncqKtwkBeb711/ItrDw Z3w7fim+9vjKRzQwrs5nBe0PcvjF5XTSo728TgoVoxrk229qal/iD8tX/TDTV9/54u1XdbZf9kAd Oj05cD+YHo0rLJtsxPM8ZOPbuBbD6uQjzB6o5cESy6uC8sRscc4uqTCcD2Z+iA/+o8mWjsVHWf+T 3V4VL17Y6wf9CPvKBA995XJmct7JXQueHLSTix4tFee8DiubCHF4dFVW4foQGFGTy4Ilp+P63vZx +CkEVNdXtRNZ5s6+tRV19K4sKdqlkwR013iUP77dpOFFNznJ1l4/rN183mLAuOCnrh787CHA8U0y XvkU3R3LiQfL0bl75uOPi3uLxvc+7ME5xqli6USX/uirryvH/5rgB2c+S8z8GFUC9dLziGqCo++Y sh2zSnheC1cY4lv7b1900C5/Shb58a4PYXjsxig5sQG63RhG/9GHP6i6s+H12SZyrgp+/Gs/IRcb 3/IHgdFfFxn1q3+bt5OlP/S8iC308y2FIrRukq42MZFvYBzfK1cdif2u4JydY4juxToeZa+UWx/g 2NiwCXe6fv6Hf+3tz/7sl29//x/8y7fv/7zHaVdGgjFMV2JSwg4yh6W9Z37BV7sqtzkGb7AJLjzE sOZey83w8jkdMO3qHMMm/fSoXRNAu7FIhxGaBG4BiptPbOnKmLjDGuOwygtb5drS9UeeFfDF26fx ffGl37ftREXxsphW7ngPmouNHvbJEQs2vyWtP4GSTU9uXVuhaGa+8/XaZsSbPGYb+vkiOp8wOUnE T17kalv3gv38axGCd/OX+LbQLDHe4cg/11YqSbCf/iFvY1lS0D964LdgEKuv9Y9OHsR2tsRXuYl/ atqfhhsf0Cf7sdlnol40EYtuvlKObk/BHcIi8soJk3V2yxWiXaWalZWd3GmdfvLIGRAy06D/GN/U Ybo8WwIpi2o2x8cOxGK5XDhTpufsEheLj8j43s5L3fzf/MJJPfJy1ixZn7mBZMr29g73AF75RIV1 6Pgk/+Pd968jeXeVL56JQyPH10ccbo6iFeyDTsH5be2KdPw1idmfjG3MmP3k3f6MrP7mfviuzXga /3yjTe9qWtjqw9wF8MxHTuh/6vthPMQim570Gh1/3UlAbUl71V7WHrPBXG8+PqetruLoDvvNW2C+ 2M4f4pUsc0597o2BKYnvFcYOyq2cK7b6mc37X/VVjlCO0I9WtOQs2zk8bYnN3074qF1stI+R1xbj y0R3WlR5tNphMknbQg1tG+zypIwa7htXjAv53YmmAT86vkGrzc6G11gwH1WyfoKR8aDD/71wwrO4 8w19UViH7asI2kL0Fb8+ax9RiMG9SvHstuDVN3hwrWemWLxuqx2cVXdIrxOHJ699a6FI2U3v2pdY dzC3vfwOtng6ITbCji/nfQ6c4e3iZdGeLVu4D2drzlB8zyQ6U2asJLAf5ZyxZbDATJMPCPpPuOST j7ZbrLyc0vE5PTEZ/2wCuVueGVXjsBgy9O0JqrFOBXlZSfYlZANJdHgtANO4xNDRsPgdXpATYKCy wWdbB9NnEnu/hN9Ej53RsFb5OsLX0ejwSBzJktxrXMmL3MCqk9EZnO9YgSw8jEiuhBSIr3VU5HZ8 P91xGk2++VnHuPZiP11rzO1v0kQWPzguOSjfCYaO2b0AJ3c6O6aXj2zTCuCy6GIpiTUYdg9b1dhs 4iU52HqbBLyz5SuPsJLTyVpy29QlZuVPP86XS7K03aL2ME5OtNP/4I75aVwshdw7mej44/CebRfj K1PuCszsj962icGYKzfIJGxS+bZ4sOnd7TLRTwd6GiO8uKbrNUBN9gBp4NHkB3+buHYohmh82jTG w33lq4MzvWK2uPb5Wx0pub0ZMDw9cI27ffITMlmnAR3VvZUvz8+K0INfJqmia/jFhrBj2+fztk6W hvEez/wPX+K0Ddvs7vP8U4VNPf+N5myxzFRLhhyHM0e922eLtmOyhM2+7fzy0jOVUSLY7Dz+EeNZ 5XDYl9fs9fqgByX8yb//y7f/y3//D96+19lFyn1b0MT2/U62eWLop5993O2Erpz9trtGXOlw+3r8 tb+dUIrrOfMJ17c3mg12XIVmllYoxst7NhtwwiX+vnv5LGhOTnpGQ1JC2of7HEQ4qnj7lJeOmbv8 VNXG31r0dJCFHx0x7awda4rjrRCxfqcPuRaLAm/t588+V64gZY7XjyCZjPC0P7/zU3/6nhtMUL/o Xvl1bMk5+JO5PhdWcT9h67/H+8Iw+UTR2ecegPFqH+hWXkWmtPGjvkfBwI0H5+MXDE5g/eVvujr6 WU/P/EH9iMaQo66Pcstl8Xdi4et+Kzy58uDGh7AW57OxJmYCIYdP+ex4pwsatu0TtvwVrROpCbzj 6g34FzvtMyrjyLvtcG+SHD+9HzRZ+GEPqxL7ryyYkvdJ31H+dU+k9nuXG0/4s78Y0h/219h6eORg Wz7Sz9jkFP98t1vFfM7nju0j3d9cdDau7SWFj9X18ZI6/Oiv/bLoaNQnbrLF8MOf/eDtwx/96O0f /b3/8e2f/cP/6e2nHmDVxGP0dLf3xEybMv7xNU17J4zWlHvZfNB45T6V03y6dxjR5lavnKNp/CPt zX8+VXbtQr/EPxczMdi8oAnEd90SH4NfbbCYY7NF7GefdUIlW5yMsLh1pct3CB0v11+YLG49tMU6 cP39/P1gOD3waKXw3CJMfNKaanbZfLLShHrWVqn/62AveS2SHoB2352944QuNzZe8Hn5oM+S//q9 r+sPvy1jFwqS3ZC3PpFc7W250z4k+25msvhwE+DaGjsF5us9TyKRw9Nx8Ol0JdH3DMdP+Av7bGA3 g5X2sd9QddA+uWvvtV2T53NMUvL15kFyPLp9zzE8fChiWhiZhSti3s0fjsuzYQvP4j9/XPzn/wnj SXz993qw7cTxCq4cCVkDgHgF8bKdnDYfbCcI6+IkL4dHjCpr4b7+Zpj0svm7ffFRD81howPuW4yI 4wtpsYpyEOgRv+ry88aSKtA9uO6hZBCEq/HxBTWKRIRtJpJXybJ/eNNcDMjdeByTusWA/MjH0Q4Y uj9LLzrdMeDkhHrC+Wb7jv+Tt0mdbZAbX3/5i19lYwuqZNwDmcwLezZHynd8wa/+chXI+7u4bCxg 7wsMXGKxvjR1/Mh/9zBG9l5u8Y94eFm1PGOr8jmFD9Ake99z35nK6tKjnIcWr4AnJR+95OUrD3ul n2xd8GFbtqSHP/GTf35cPlW+n5dMxWHRXpOzGNJxPLsyS8C2ZMJJZ69t9MXjhNL6w/Ss36hyvoke 7XBgYAvh/Jxtu2NWzlqw1s4++sEPuq39w/qk93dXy6+7+ODiwk5UxbOTE/l3Pkn2RDpI8PXHzeH0 nYS3Qbl+pl9IkF/v+tMXrt+GXczYTsp806d8ndTErCfoZPZ3ci6c/Pg9Dc2EQbIq0Ml/p46M2+3f QHeJ8n5n42d0dIPVm04b6DvG1cvZ4mg2yQaoSp2rPwl7E4yAJZ9OdBy7h2RAG8+uXlY+71b3boIn M8hCX7JI9jX05PR/AaXTMdtyzLNIPNGH8X5IHX3gVGBu9wn29OtMnjrY07VJBWc7h3vMAAAgAElE QVTHYkN/AogoMlUspWqMfgbChEhIXNXVGYZq9uIjxYDydHY6Fbatk0FJ3+Q/PrtPGmGlj+e9noDz bXdKTY7fGLS7rnZMFYfdGW6LA37e4AR3G5/xA79uQjIjkz45r9ilDUYvutaAYn+SNsmz9cHtuw0Q mjAM4ys2O5kRMon8ctiwDvpyMTkvPDCRv5iyh/9LquHtmC55eo2zcvhIG3/gkoeGOTsRIcf704Gx HPXqeifjdH2TswjQP5N4xPNsn/JSvJ8BSUdA2vzSHlwbOFJk4WSiBdZJCFfYnoXFeFRGywRkD+5n cUbPtujWrkw+2t+ZcDh7LZ+2ozykvdj0xSufnraG5HyaJmL7cIz+vg7Hl7RVZoff+tBRX+mqtj// v5NxuFXQq47M8fbG52Kr7NvbdHN2r4vxt2jEu/J1coG14P7X/+bfvf3Jv/y3O7vaUqbFw/tvf/jX //Dtf/Ff/s2eMPpp3/P8xH20DUQ9bdTgFv9vv/SAGIsgDzLSHttgIdt7mJQdllWtTP91S3xl2l0o 5RW+jpcHOtfgP5Pg9mb/9UH6JDkgX/Dwg3pa2/iuznW8yUW89t+Js6i4ZK/1v8uB6vVdx03icJw9 J7uiq3+1bzLHmvhNLOsHlreLQ8RsbIIlH12pEe+1kXbJXwyT+IgdRscKelvMkgF3b+/otfGNBfS/ IK/v78DJhy8q95RHv51sovvki4msTbvb5ByKybg4XW7p4+vH8tNnn3399quPv3j7ec9Oauq1B7zZ 09eJt4nHe9/57FydrDsDDGf4mJu9jz9TM6z6QV2ljKPHuMDWIn1tDst5ZCdHyDg5RMHb5KCckyOe WH0OuLr54ouv3z78qFvCesUYrSu9LbQ+++3br37RQ1ve/6iy6xD03eoE8XJIzC1W+OPy6xs04mHR AO71R9LF4H99k0CAc+Phcrl9Dw1EN1b4B3Kke5ssfBRH67t9lAj5j//677/9pqsm//Cf/tHbZ66s J+iLfptX1xF1VPm/OPmO14CTrV0zqc+n/7v8GcPytL3ZQMZa3Pi4S56pvY38EvYwt3t9SPqjG2m0 i3l9sDsZ9P486ZbkJO0KuTsF5OonbkWOyVclXAnaeBmNK6Xi6ydqlnevSZoc3xwlmvk9YPvjI/Bm JD/RdBtfuhIEwzfl5w/Y9dPyhR5+85wTC5v5oTL2jq79HSWv3fhe/VqU4jufx/d5dm1Rn2ztaT8R KUXyfeIHUTvabZMdW1Bw8OULreV9vKtnVLnEutmBLr2MpbO39TV4vZRtzpX9s+vVJ6U5Oujbornx N9G05bvAVayeDBj5j+yXXn5N930PfLvDs7Kq5t38BuO3N3j4fAvbKoyfHUTPfyjTkV9O58VJ2Wwc VXQv227RdPJh3qKJBRWtXZZd1Ivc2lNCqTj99Q/V6+tWSifbQNj72avW8RC2O386ivDm1mMYvsVk vDMJ8WTfE/nZd/lBx2IHm7N3KyczCZzQS383LD7ZZpGW3bD7PBmxik8yuJF8mMTwLD1s///fY54y wLL7lSM57e2rz758+8Wf/2J9LKna7nSHY4vc9Pm+JuzWBDwor2yPjXLnyVFtnA+ZudBHr10vL5IB yDuPv8qNt7OqE6pkjp4mvoljY1yf+G47631dY/On9N2Gvrrp7zP+vep0p0Ec2DDyo7t463JldFuV q+6YRhcWtlvtdzvjhldu6x8O0dlGjn5Nvi2Os9v8RdvGm+781EcyOk78Ydf+zG+qMD+IdnOFju+u uU501a/7uaYP+o1mD7Daz3TKC3/1P/xsO7t8zoJknVx+tPlko6O1kdZxttW+eDJtJXBwxPkrHY7x R+fEwGKUEU6sMYa88L4MOf0TQBxBWZWAdihqN/qbDE+xTqMp0Zx1MjzKnEMpZNADlS0aD/N3Vpz4 ybhPTpUGBo08UO3R7upndEswQtah1E3CPICRtpHF2HWS6Do+Vyc1Hif9yR9/Nds/xgW5iuFaUCuP g4jxLtFLnJOtkEzMNnbuXfFrsVFCNFHad/8iVH4B4o9wVWBi57ZUg6kTCSSs4ZQV/LnbBE062wTJ 9iTErg4T2iaOgkoJ/y6RAcoX5PARPrcC6MR0E/gNgs82n3ewDu3M28mChT1+sk3E1nmniq+HlVoS y5G7TayYJfcWdtloMJsTzyZ20Pv4fovq5MOfimiTEw1/LwMqs9HLzhGxKOINHBqRxuB4lJdjMmPI Xn5bo1DiODyOs6CS6GYeryDQKVTHvhftu4b0snm8L5v44Hx3+h4Mjp5bhiGbLp3edKGiB5Tz47OY XW5iBuoQBekltQ+6Hn/6dJar5F3cliPSpGN1e91h723xs80Z2MN9nYIqt9DQos2uLtsNWK/Coak2 /sMC3fwejXx7BsVh63j5iOYlzye/wYhWG5iksK6vEA/qZit/GcQPpysqw1Z7x9fb2VIOf9KtTh9/ 8snbz/7a7waijqzJ54edZfyd3/nZzjL2PJphADuPDIPOlZ2f9H1Jt+K816P0tZP3p+98uUloxzaY tRsDwb4WQdbLDyPoGP22F2b77AE8y4rTSqZfPvCB9mJA4hv5mopbdFX38I4Lb33qs51Pib6/0cTr jPxIe98pl+Rs4FqEyFTLtxfjdufvyKqDP5wO7Lavw7pF700tNhBWuQGkajgeGehfh3fLnSChGSLy 6BK9/jJ02h6GdOorLXbdhu7K0AbQMCVifmdpPdZ0yh4+5Vly3rWP9gFy7OFPdLll7CtPX14dntN9 OaCwsirlJh1sXn7WHzkROIh8QlqDfdejx7Lv6umzel18D+t1GfK2MdFBMvnLVULf6/yhx0q/dLZz 3km+hcCPf/Bh3zHv4Sztf973X/UJn3zSky+7vflHP+sKMJwB2hhERrIthGG3OF1fT1Z1HuZWNu1s ++5mOBNmD5vEzud4ASH8Vb5xWxl/HPGqSXb3izieFv0HNrnrPZ91xfGHP/vZ2//8//6zt3/0P/xP bz/7w/98IkZIZD4ZzlzDDtiWRyaQ2hl9sIZn+fZqV4q2TY+9V6629+Bdrpmdhc8Tr4dsZ6uLWj6l 79qc9lyMOt5PriTLZrK6O87CwR0rC8xo4GJn+WQx4zveSHwPFsQ7iiK65YM4vMofu4jY2PbOBhpI 4b+bQMKFzpxnE9WqncTbgoo+Jxpf4HDis81v8YmCE6rNPBYrvtYe1N+tyiZ7XY2rn4x5i/YPansb Vzq2mH1JyUd26aMhGdVtAt3+2kYYJz8WPcRkoHzpo/OejH/6/8N2GtRtG287eMdXKbnL9XS7aLEb NsR29sVY++rM9U7OiOPlgPLyQrtr1/jrIkOF7Z+f6JC/+/7sGXa+O8ntpxvv6ubNlWkn2uNhJPLG hFGyd/yHm90b/1ItPpfC5wN1QxTGudfx/HVxn90y6EXHLhubNlfq+PqVFe9tKIsNnhN+H++OoxqO FC68AUDqRVYuO94KgrIy9l4uDuVi+w7D8iDC+096fIVjMu0T4n9xKa9fOfoN4v+EvTDNlncfCUyB k0+/+uUv74RZ0Dy5eyfUIr7YRjeeO4b+cHbcHyx7mJujV96o93M7i6+Dticn19Pp77Ip8teC0Lz+ 8t0nBbgWR35r//3dWXO+q6LF1s05uMZm7j9EmwOUS7tPnUHlCaJspZvrxMLG/4tp+9ObDPQ2NNqm sdHV1js5psz4g0//cnmABkb9y9rs5qXlT/XmIeZRFXUss/Don+z16tMt9i5iHa6LNxh+oszYeQ+x +mCfHtzHOXQ9435HSTpcCR22EbUP6zMXZqvX4cwXBcCc39qA1XyAdnmqrOMEZAQrokAbnsVl0M+P T5w6sfetAsaVTP72ZE3Jwalrpjk148hcp4x0dRd8FTqanUFR3msNuU9ZwzkWRD63AdOOAOvYw5lh 1Uer47izFMmoniFopxw/ISUkzZPRMSvchChcvrul5umYzwHRJxfDzoxR2IuzBXtJRVi8gmRxasJ6 zvekztdtWjpXHV+8XqcpPhiV9Um9EwLs0WHxILop9x6dScS7y/3pXeckKfQi6b/tZD7JcAn+6Dld aHWuazAvDLM7EEvkF8YDcAl3k+A0sDH7+dgtCDCUTiOdz+ai3tgTLY0OLEbe2a8cAP/5xsJ3Xqkc +RYu7e+2hYoM/vzXNwXyM7ZvYTrxKxsz1S+9tK8BTdX5UyOQc9g0TvG92IwbpPEvp9KZgItL5VPu s206+AnmtnbPL2H1nYanfpW9ORaTG5DjW47nxVQM2eSQlaAwujrgTJP4uU3TxBjx81COJ77zb7zy epMkvun48uUmGlsozhc6cTltQIb58sDBxQnO9tgFiXroRpt9TZBQkm/zAbsORGtaBxPuyxVYCYGf ka+YraiKeJ/clE9y3vb4bbqz3aQjlYeJjClN5wYAbYWPytr0LhbRrs2qp4TvkquP+Y2f9ejs72/7 0TW6f9ytNbtKmI7lcTicXVxfkLwELbNhM4A6G+nq7xctSOT+BD953AEvpG6bBe9O1vGhGM5HqqDp vePXvGz+2Um8bFMrx1Neuc9XbN75oBI2quGL9ucjhWFZ+1jx6UT57bY7hvG2Z2GWjOc71qubPHWO 5EIS4Dow+U3FsoLq2fzki1CRd5gGPlJU8Su3OT6S7FBXPs3q8j0/TSZ90XybZ1J6427k+ik/2ePQ 9oxJ9kmRc+un8vMYVLywwbA2kk36IbcFa2MeIPsdZz4SCrd2/NsmGJe/LymrFpPrp27wLpbSNOfz v0kRtXJMmSmLtvtlunZ1iX0ETIYTma7qVhYeJzUdw2473/LH6VxM6gt+8pMfLve34G2YcQLgF7/s qgZVnOItJfKa0xTBoG2Iux5bFC2MYHxYkB3xfYLJnzeJKFLZRPbkjaS9yjYOp28hrX7j5TDcOJsQ //Obk7uff/X524+7vG5B9U/++b96+6f//b98+y/+t/+r/ZzYhIQTO/3yajgIfxUuDasDFhZVWTvC +TI6vsPn5R3l/LeC2nlHfsbsL/7iF4m9tn5jwU2+0VM3He1cPJPzks0vwZxkJ17WF311bWpsY+Ub Isiq9P7VbIG24+ovx+rjbXPi5Y9D46OrZfqR77WQPnvUb7S+unj0iTcmHyaEfFLU9+f727eAi7c6 8dhTmPuEXVuAW864tZlPdvVtfawrcSyGNblh0RdsrHvxiRMJFuFVFjf9qt0Bmb/Va/e+SrCJcvuz neb2teNnXDhp2vY3YwObAddnpLZNTPfR28laHiTfWKdS5HFMNj8poQ5H+ubvC+RRxrdJ92JGQ9zN X2zD1ufFcgAqM94f3bPwHPHrTfzR63M25yAn+uVTKG5sCBU/EaSeX+y8jq8fzWfF4OZLLx/E/+g8 mpPLuI0Ls/LaIwzEieli1f71B3hefNHvKt15eLaJD19WA9gkPm/rnxI6f1VtboHiGc/tP2PH4gZD dHcLdPbhybeezyAHQ83qbfaq/g82pd/QqBxehu2F57g+//Tzt1/104O7sKIOrdwJwPrXYm5R1kT9 cltQpEy2OnmCeH1j4iYafb4jfrkLx+SiZWd8Oy4m+ekZl5enkU5XMviIDG3Bp69aLabhIv/yybhd ZTT8v1xAPy4xDypbyEknSusP29pmn8Pywntj+M2zLmbi+cQc7dHLh01tHjtQ5YfdgdOdl1evPR6W 52KNPoM8vuez7Q9/hW3ygUhze+tEXyFj5w86sfthX8f5qrt7Pm5+ZtOXkr5FajKefDnZ5yPC+BEN Xy9OmKY/7S5wdaSNuSPD/E/MzTHwitX8m299T5g/Hz9OT/XfPIup/pAi8gnwoBxCn1vb9rh2wUvK k1yELWiVDUQCITKQCgaHaIhPYMi+ZGuvfx31FkJG9BLTGYKgT9bRdrYkgX6weQmSYxmkYUmKDtaw 9l2XFwNHJmZ26Aw9yCM4m7hfssWXzA0U33ZUjQRO+HU2bJuzLiuHCScHn63f2EihhmAaJFAX1G/J wTjRx7PBJ92+4+RHwgVmW3rXqJDDUgV7JCSd1+AYMwvOJ02UqpmfYwe/GJmOAX424F0DpQQvhX4y ov0V3A7Hxx9Ppes8OkJ7Q9M3ZdcZn4/E8x2u+J5GQCQsOtVccz4dnjRWt98pLuYS0dXj4zu8MMH8 LFDX8MQkeYRd43Zgi8ecImWzMzpxfGK9GI43j8CSEI2SXfekbSIN4teg12j42mJtRpSR+26XzCQj VTlTRy4u12bCEP9yT6zaEQv8ywv6Olx+kbmqPu1jivhsujp20HW4rj7k67RPrtq2dO5jMtkMt7i8 /C3xe/Gx/+UUhorhSsN4yPJ6Nn66uMobxP6feKOKs9gtw9Qn29vygs7hqWRg1d12ck+OEngOxw2m dwwTga/JDfHRrSxz4ZDL+oPleQObp9t+2ev7H/yoW0N7eEJXbm2zu/dt+o5NLIuZ2+uLH35X1H74 /oc7EfNlVwb1QYL84lqMDULCJPdsO9PY8a74cs6rbDwvRiYsH/gqT8E9v+jL5t8j3O1OEX8hicWz /eXvCZ1sllhQ8MFseuUMBe9iOj2piAPKfT1kO+nRj/DhZKLpD0By+5hZDtnePz1l8/54Yv5GPVNH WBsiDNYo0NNR7Bf+OPX7Vz+m7ctnUtFTRfEtttpvI3/Sq19bqQzZQYtzTMruwR7MS9KIztf1P+HY 1ucnn7bohWn9jCg0pqXTg3y+YDSflAfyVvu//gE+EtjSCd9efs+WJovK73aCSNvQX7nLYU+WRP2S xwc3AfBAlFtczNftf/B9E8C7bXu2JPYlebjee6/ftf3JjyvrNtvPPq3v7AEgPWn8T//0z/s+bg/k Yn9jpfF1NwUxgTf0L8Ps+LbJd6LnAjXfIVnfQk4Ou3gOfMfGofPDRf78oFec6HTSMT3RKqNrooah kmh83/Kn/QzYv++nwf4ff/+fvf30v/6b840J0ayNxuZ9+Rx2GXu3VPJ5E5juurhcMtG2wRv9MLY7 4GGgfPiiGkn6YQukz9W++lJWDLs3svowso0KYUdSx/FmQe0rc/eLyfPDK9/klNjuM6qZlD7YN7ac 1CkpBJW9vwfaWLjCccjWLLsl3Jzhxu8qhvsZCymlw3eC92yJ7N48DNDqwDYRvvbn83L58csH5QyL fttdDmiciDBuOQHj+91bLEaBxmbepx2QvcVyoTFBdI+EOZfXbmOMRF6gs6Vh8XIjymKkVt2rUS6v XjgVP/2fPF9fRye/iBmRYhgkOtqdGrEazI75hwy+4Rd9eYebCz7xHy/fkZNueh4caGwbe+gKlJdS uXWLQxThEv+BcAxL+l62KN/daPULs5dx7EvQfWXu9CyGV3UyTtBLr3kYmRGQ1x+c4grnFrLRP5gH clIeG1J5Tts8iJwQByOZ+XV+chzGZzstd4LcHHy2052t+PY/OLWFHPteeaOf3B0QhLDvZc9Opndc zzrci+d0s4G0Isee/v7j29kz4S9COG1z63zTQc797ONPd2eXft3Xk3LVya8/todLbv9Whb7FiZLG 1zvBcdaTqY+xabMuxExKFdoYSWXC/PcOOZvz6WIRnvkt+kmRN3TqA5R07Du9T15svMgfGx/i0db4 dojpFIf4yFrsyYONvmwkZ39hfdpP1YEsX9gJx3yErz/0A344tefJQpPdd5IMnmJX/2ajV4/4XKxc LMg31k2+ko5HHV+42EU/3WJv/uQK8IddSPh+i94vPv+qh471pO3mWfJBDMwDYlx/ok+EGL+8n287 FhOY54/0bXytnI4Zlm3LQfrl+WJTFawZtSgzLrTwylN8uXU4WEHU9wSMn9Zo21/ji4/R5dec9XVX eIkSfE4FC92MIjewBn1qOX8gNRwGJ9gkwWfSMoxxlEfNWQTiqZ48x9/tp4o41wRgDiY19nXY8UoA HdyhguflwDn19MOzSRmtMdO+BE0Pjd6/u/3oO57LOkZ3Dmtv1/qPH+bJy9P0IYx8uHYmqYOjsbC9 s7yhKnlPX60w4rPdZGBn59muUcCTL6adb5T4r0yuCCF/XWLyMP1R4YcZjvVv/GCwrtyG7KmXAK+N /2znn/BVN/2ARLYkScaViRPqtL5EfDt+sK5BVq/8yYN3D6d48VlolD7DRi7dz+Z4XoBreg28dWyv ztltG1MOW0yol+jt0y1XbPKDmRrENVg6+e7FJ2A0VeDP99t2O9l8FGOxGq6EiDJHoKXRtlye9sOg 7j0tb2VxpHcPa3v5jr92l51jf2T12iSpMthPPhHqfISrusXwtU83BF7bKl976pPPYV2OJ+8db4Rk eaGJaLkitu2srKr2LhfOL9qV7drQO95KRst/wzYiu2sDgQlbKOqwFoOq5Td+jDupELG6nRA5MSgO H0HtP3k5vckz0YfHpEocJdCu7nfs9pn362R//OMfdxug7+eS8PxUgodbUH15cb5qEuim+w+KRfni Kq/veb5952Oaxju8kBDWi14y9XuRZOvFax2udlbdKuxpfyPOjnaOswLYJeWI2asIuIvx4RYj+q4v mtgRbm+ynvYCIx4C7c+3/HrKp2fa8x0ykLzvkz/pmX2H5RuKEcYfVzhODwkv+vbWzqcbyeUNucPR zr4X1/EGMvSvdjkcYb3yl2zxjIeZaVgd/9KxKwf4r6Y9+mh6sLxArH6VvcVXf+0nrBbvMocpupmv WwD4XrcTpT3Haj7TT8mnmVs5n8CiXLxN+vGuft4zVsm//FaFVic/9PV0rr8CpbIf/vDHbz/rycV/ +u/+bD+jFOnkV/vOBr4w8TBR+PGPfzTMn7bY/eTT33QXQ4vef+uhLT3wxuJLPLLPA/D6eNd2N6gT ns7eB5Yd6/9CeNoO05Wfn5Few80mizL8ETtZrM1paz7HbxLSzvmnneV9Gd6ldH3wd8P3g49++PaD n/7w7R//83/z9nf+z//07X/5v/kvwt1TuUMlFuKLn299BaqizBD/6ji4+QNdzHtOzLR3NjH4pd8n LCvw0Xa5J5d5qC15/+F4tolMzJqdbSJ8EuZAJ32C43+Vv+rBU4jW/tPefMWKn/Pg4oHqeWItey3M 3tGQPX++7K1uYsksl8j2G7MUgHjjUn1pV4TXXuNd+8eUTrcRTsIwtRcfM9iwCxYOnLVrk8Ne5/Hk bZ8qO3xMNrHkjGzYzN38bZ4Wqu1XDeYWnG7LjIaW6e5z87PweYL1I8/TxMk1Bpn8upjh7xmrzRXF 5fq3swP9+hp52AGfR5bMG18d3DgSL/5eo+tzfEP7sn8y7N9YkJThecf3wi+XY37xX+FDQ+Zt8PGZ +F67kANiAtNNzmlQdhwPth2yAe0qH68d4XAng5/UnM40IR/ftaVIVrATFMYLztPG+Ol5oVjZxWYY BvH6Nn3pNza1CMBHFtHt0/duHlmMn3YDKfX6ro2BcaizuHz/FavlFd216YspoX/VRiKtpL5eEuyl kD36Jr79TU/m/81vfr157hOX2Z0uczhlzzyQRNbMFG/yps+NC2SqV95mjLo58rUxWQKJ2uXsYk/W E/uXiyK69dAzZzqZTr4vDw52J5vMO9LTmzF64tp/Tii4cLJxcfSnQ47JspXzpb/mwt/4U7y5hZ/j 78/+CuO0bjJ3tnbKivwjhnQfFjrnM3oWq8vniM8mC7/ZyxeAqVEUplec5Y+vktzcqr6v9vA8G+qT nqXyRWMZv699ExCvv8fX61+U9XIyuul++3xxsZzOxgqqdzGKves78NQvLJ8bt1+42KmpHL7qY0zq /LKTNEl6XPQ9jk1TV97SGqF70J+F8EAGCLAIpVGS5oZARlzddz84w3ZG5eVc9JlQ/TXiJUElHGXi sYVGDrFtIplMm0HydL5k1xCZcokfAfXJuIEi/mGJ9jywOhOSDeIvCNwmMP6GS6JMlDNB50iG74xW Fc93yq5hZZ8g92dh65NOHe459yZJvvujE/oguy+ooBoO6cqC6jRIi91NSKKz8GHLEhefiOBpf3Ob 9PEbrBfOmb83iObLZG6CgicMuWubxjH8lSdSGLbNb+3NjpVk98v3SMnCRzb7bEtEsX/RKZvs6Hyy TYLRs5Mkqyfrseno+f5kigMMFkBkxJcvQNdZyUeNlb/IhxXfJkTVo9vk0476Pp2bQBvIHV+eHga4 njyxe3ouL9XBroNm3gb4nDialywcl89n7/afHHs5d56KaQPQcCSM//pYvpKdHB3q2hsc0amzwX5t JJ4M4vProFd9trVL903+rxxONpsU2CDnj+FP5nyiAo7XQLKO9IURbh2gziHJozvuSZ4/hj86OYUG ruHQUaV2MZUfs6G80RZjnz3teijSg4NdNscrm62n69SH4bVpt6jVPj5TJUa+L1bavf3u7/3u20cf fqQwLNoXTJe7Htpl/3thXP8x5ntze/Pyugn/+h/+2EabSE0kSGdre8P7Iuto1NMV9dOmfb0Cllm0 QFTHX5Frm6JEjlxbHlX2qIZnUr0pn4ajt3t9AclHgH8yHE/mIzcSuh/BmNtET5ynewUXTzWT/dI7 vwd4gyE57zb7MuAI5ZwFzE5MiT/B6VxsYYNpJ7rqH154+EDfNRGRH35sO7h+snFoV6Vqkx7cs4nc crd+oav2fD4EZPYP+/g78AAPZ5mNTcvLMIlNy4T6D7d4bilbv1Ou9Lo2IV7w68vvFiv9z291KqxF pzJd28SJap9rA/Ako/bO5i/S+ZOf/uTtP/sbf2MYvvzjLza2vtyz0JDDv1916/OPf/Y7uzrwSROI 3/z647fPPvVTD1++/cWf/erthz/5yXDdSQBjdP6Ol210AsJ2x5v8hGmy994bkl48YJHxro0rbFss EPVaH84P5Clh75HNdnpGUxl/mYS5Pbcb3N4++r2f9QCrr97+x3/8L97e+8nrZwp1dtr+fHdyT/Kr HSTD/7DXubt6Ix/WP72cZQzJsMguRuiH9oX/4p6eKpYV8q4/tlJrzJgDxnXM2sBsw9a22NG3g/RQ mU793fzMH8anlXcbfj85tKu3o5EDDw/6w88Odwatz9x+FgRIG7FgHS71M3/03PkAACAASURBVIht N6FdTrE5VH3ZaFeEZ0v9ndKZ4UTtCwv6WcAgOLLbMaz4lE1Hevdwupdsovip6pe/X22qen8lwXjR OXw+FpsOzIUmv0pzoUmjL8VUoLt2qegErJ8dJdFdrdvEHN7Lge3gTebiGt9yZwJXO7kezrn+yvwo 3cSLk9ezieadhBKHa9fPuLWYZt83Cz9xyv/x3J1br1wgjBvmdJjPrtlDZv1CqbQx/eJAV5hjq/pe HT9lBOzOBl3J4kDBbeMpluy2P/v7fOjo1pfePOl0IFzu8tc3CmPqoDonP5ZPBGadvmqEaNvwOGH3 vhModMuReBdNIvKvYOo74JjPX/Y8Md3CiS/XPyPX7rSv1gst/o4OgJfSaf6r3tAN7DcEYy0yYfnF X/5lJ1N6FkfPDviO5xbkFO3AyVfq3U/hpwtl8u7Gqf7y9RbD7nio+uWHw2qu/8lnn8yP1g2D+eLL e7P52uzUhYvvL+f0hWy1njm+ZPJXuUSRGD6LcG1lWISgcgzWS1RaN+z4WydexXW58MKE99rbuYYI r/k3GZG/5F69Inm++gh3crTPiwfLUNznZL3a0RbLw/renoVg3NlFSI7rZVG7doa9TRvwvIqvv/qi 53J0a/MPm4tlzseffMxLO6Gqv5VF7DxMiYJ3OuVuOEpGX02j41LpFEDoRPr6tZdOH3Kxt2rHQmUu 6OgpLzH4j9y1zao2hqNKR9+Icwb2BpwNrq8JA/5n4eEpfx2u4emMQx8YSrxOoMMtXWKkcDyVuVVs l9LbB4DSmywwFvackjyNT8MW8D3BMj4Tqt128GpUA8HAMC5J4yNkHWxOtM3Z4TJxMcUhK6WXdMl8 tjXwjteY8VXFfg18VH36m/OUv3jh19H7frN9ib6AxbXvPOPiloS8uy3J/kuWRrPL+xTaIvSHJ6DD eWWO+pveo7XArGh++wbr+RO7jmu+eLDmAzx3tZEqjZSHYLQQ5zOyk/FKfPJt7J5T7PNFAPfX/jq2 6i+JZ9lwLxmj59tnm5zXwe1fZyT27LRNdjwP3yXoYdhJErpfL5jIeb4HCu/k0tnLJNXtFknblZ9D PS298bT0DfNor2N6JzsuutV72cheDNAHerrh7viRPSuUvdvOn2tP+fl8fpU6ZXF4uO0/+NXt34I/ XfOiNtZ2sevzpffuoogjvKyaPPkxEfRXpv3ArXCvPhInL7dT2Z2ouHbU0EfR2oD6tVeUc0VyqhvW 6B5zHfMfucosJh7/PoV8qo375AvbfP6UvXyuPzlfXG4NO/vwpMMAZC6N92c/+WnkOtOzVZ0ru592 e+tHH3WWsQ2eTRbyAx5PZv00v/6q/d/pO0Lk74SVW6CjPa88tsDJd+SEIVoE/KyMvMU3Jf6mTG00 wzvKEaansipmBmrH9QOTfww62zhMTi7vUMD/buJzbptePuJH+DcgANQ2nJNin54UdUwWYTCvned3 scW2+I3mG9LdYRMWk5ib1FZnS9QkahsZsYnfazD7uqf1Di+d9PRRFDXXeC6n6Bten7MBrpH3YT+O 5Fm0biyQD/3B4cFBiNdff8uu7ZLHnnTuLprOrn/36x4MRXZ/f/GLX77983/3l+n86u1v/s7n3U7s N3H5rvyoD1ybirbCnZm32DZI8/G7vkjuhU9+z/9N2l2FfSY2/GLh9mEP5frZz3/ezyZ99PZ7v//7 b79qsvbrX/86udEWQ7xzSvTc+Ds//enbb1sw/urzT95+08L380+/evv//Okvt8AVrxkFGkfyZA0W hj0A8VV/7U0KpWAs8oieMsrMUKH2wcDsWq6XlI7Z54rkoyfi8fL5U79+IHlE2jfmGev3m85h+P7P fvz2J3/+l29/72//X9/+8G/8uIlQJwpedzazAfQ9SGpQtGOQ5KMAqBeNKd6+XW0Gbn8her2UXf89 LNUN4+qjg7EPcdh38NGOlYxoteP2vOToDLLfJu9MWI3Nyj1E6vvdmu5BZM92Ezd5iP1krm/Llo0X Pl+IVeuj/W4nO+UJu/VX5kbXb3EEWfmBOPvb4Rux4+X2115feOc3lHPiOxziLWZwPBPKpx9eDpNX nTY77B27wscb58tzhyL1B0dd3tqBuL3wwoOzursYIF43Lzq+KuUX3jxyOhoDormyFb2zWdmwJnXz l/SIhQXNl27TLqjveSJtiXQegTG50meYzoakJr9iyfPKd8fT6dNf5azbfvQWbvOHJLXFigfN5oKZ PH8w7Hkhbf/x7/gr2BgEozbWn3rbxujk7Mob+TCnxMn2l3sm0IPIqEhh9S86xxGxgXx+9oKfXnnL osc2OY6dpJu3gEpeND566+N4lyvJ7atcw4qgbV8/mdSjOwnnHzpnT5+lYlVyrgVlsvSXGy88JFKO iNF/wnaSv0WYrZcn1STD1w1+2UOs0NUjp8cs4PzvZI72jn53qYhv+xXMvxfvkY/mOZ4P5NijnF2z ObuS4S8h8+VhwXH95cWdisPJ3+Tcojc/xO82bNajfa5UInICVhs07rjTTP3mRNlBznIuWU6a3dh+ GGZB5c8YfzkHkvowj/lyY7EUZXk2OZH1yaIlgU+Y+UqM8Kqt3Tgh5+jZZuNL9sqiGcabiI2Vbs/k 8HNFuD+tz/yshbCTCu/L8eqfRTvZwwd3ttv0WzXs80uxdbwRpk8P6dSX07GT0cbr/Kf708z1B/7W swsCI+NZv5x9dwKbK26+RPZ9y5hv6ozvYR8WnhGVSMla4NaYlTYZcXZfYwX+6aD4RAe/AaaDC4CG GpTXQLzgwwPg2jwJ19lpKM1TMqLEi2cbRyDJAIF6Jnnq7jt4nFYV7AB7xQ+TF6do+PteHO/02mAA gf2K6KKToO91xdrV3l2xVkZuPiHL4devSRdMEoVd1zQqoPp1soDt06+sF3n0nZ70Kstekzr1w87L DtI1jCXD5ioVnfK4kqtxz48AebXNX6vWaPC/Fn1I0kY+8/lvt1pjUxe/hJDUN3DwyzVAJGcb/gRM /phCOqkkj5cfQn9t6eUrA9bJ5Luji2RYxb+d+ciiAZh1AkncoNAxHna6DRU+t0StjKzq5U+7vV4d Rsmt/fCxmK/RjBb0OOaAarKjahrAORmv/cO74vkKzVN2uo5vHRRepHxTJWxo3+E+MTvmfGYGEZi9 FuMKTy6P3h/Zcmd/s+lwUrOTTB1uPzFra1CQ4zhh6ry8kSg3vjLIcfNrgxPt/EtuPt4AFT3dq+d7 MugDPBnDtDgkSBF5I2jP51CsdP57X3u5w9jVR5Gs4aqCrx6u60/o1/cUyxfg+T8cl6N9Vq5OOL/f d2f2oNroF5PoCMTjN/14hW2u/H1WucnBF90S/eVXPWii/DQJ/b7v9JRLdA5iItZ2K7tcgvqwIuBP bUQeMc1rSmF80bFqsXYMU/93ghBtvIHX9um5yLHr1Q9NqJgdnsNULE7LMAllWULYfKhy/s3u0fFB /JP/Moqvh++YXnWon01t23KFnejbkrU49UnrzGl/g+UmSu0vx+A5GWUWtvjO1vmgksunw5F13Dkc dkwW1Nt3ZnlXENiwNnATKHeF3PeQ+CafvBqzCbH46/vwG0v2XdL2JUqkuw3rj//kV28/aD3ze9/7 /tuPfvDDrrKWa3uwlf4iuvJj3/fvbhz97HvVheDyX46EZ5O9dPHTV90twA9sAZ3R7kD4+e/+7ttP W8i6XfKDnsj8o5/86O2LJgC/7aTAV+ViTLPbA1Z+GA6ThV/3c02f9ZvSYvZZP2H0x3/0Z28/qI4e sXaSyp82K/nm31PZ+0TWR4IQrec2RAYTWBA+vp3LhGr1/Osgf/c03PmKs9AnC5+NXsLuaAX73pwn nrt174Ps+6p29D/8k3/89q//yS/f/vp/8/v7uZ+Xm8bnJMZ+6zb/fO7hXhaSYpi4+3kRmmxn2Y19 9h+92RyxCdlNynA+7ecwE6ZuPAtIBUAU2+fkz/q9Fvhyli/3JGN5ErP4uwq7hzk1pln07jdpZ3v1 cmS0kdvHlZzv9ZNN+qXlX/m2RVS1npi8OZH+IvrE93nTLeOcnN/JfeJ6wUbu+Tr51cO1vGvX4cbn YobsACCBy4KKH8ZelZyOh+7KtcHJxyS4833ZslwCLMaXPn3V4r9OTNvix3K73JoPIj0/txPfxmbs dJkTRa//qpc+7PXp+NanJAdWx8vl+LaFZ+qWNBGJx5I1mfLZXzAPS7JfE+nHpvkIz8vO9SfpmK74 vr6zX1N1/WIY4NVe0g2LtuB1Y8/xTmfAQEH9zaa+kny2n5HiT7DbyPKVgW9vaOcfgNrWHtkQbVbt eFiH+Rs9W6B2eCHbtf/2Lz5DlP5vxorw9HumgrLcCdDG0/nEmEkuv79iWhB3K2k2f1n7dHu970Vu gcYzkY8lv4qH/8vJw8+G2Zo88UR8F0fgaH1gbtm45llAd8IyMX/FBpltrT25L1e+PN5x8/LfdOIw pPWF7vZBk33l2+brjsqz50TXxfZyaovwsF1fx4ZXrLP3ix7A98zDtWXbE+esyT8VLLYnfwR8E+lh iH7rAu3j2qCvTYnR8iwB5MGaoGOf3y5GYiF+/XPq8aRvJ034szLzlC/az5v5UTITdR4aX3KrXgzu ajU+NOXVNIoHtugc722ts7IoqlRvV5zkmk1MeYT/xHkElT3tg3R/vsrgROH3P/J1sahS7ms64rI8 Hw8/HY61s3Scny8u7jh4+pzl/B70xx8nT2y0oXftfyCzKNle03NGj46lLxcxi5Ct1zxLweaugPlh HdYWYtzDAc6wnGGbVFSqQ2e8wV9nRxhut21wzM76VbbbRS2+ogP8afBAb7IRl44rvHEnr/IlL+dS Ti6+/QZgxx2YmCuWpKOZ3nQ3SYH4FkyRcg4aAiq/DjL574KnWFL2WT2Zo30l/f0URHJfzoTNEzw1 +HWmY6y+wYRMSTtXsiWMyngt0ZPxkj4bmbZkQtNLIEeIIxaJ4G+YXvx8BiJf2cgPSJArpQbdao6X 7zVWjWXJUK0GatKo4xvuKSCCZOION11oTRaU3WIoWa/yOxMp8ZOTHpPLdRbDM1Elb3jDKGeWL4mj +10WnjUDPstU9bfO6a7jnU3pWN4kNlS9eo92bz7j0TlsAu5QGV/EN7s0jHPMxSRMclrR6qObb7Pt aega5uyB6eWby6toXsfkPy9q2alOGYVH9hxPWbLiqUInwne6HHjZdAPUwd/kbHLwsTmZOkaxy8f0 iC2bTXJtPp46ncewRSRPbjGgw7zvd8iJfWfRyRz1vYY9KSGPdyKL6zdXa29xQUeV/YsBV9t5BorZ vurzDYrFhV/CDR9dJ37cp6j3ya3/WPuPfn/z6fnsncL0G1/oEi/e2cP3Ora/9vQ4Jbm+V+LBQCau 6j786IM66Osr3m/SreyDHrqwLUibFNDvbAKIXnPI2fQMjo0l5/QI5KxucO1hbbmyJhAI/Gnd/CsO m7Ule6Ire3TMhydkeTKBcEyuoS5pmjzvKZzcjvAUg643vvDwZbbOHxjO27CtTcPS/voc8uNlHv9f mwepspw7OXWhG7ioFfT0rX8Sd6KbFZF19r36FjpAhNU2wtulw+3FZD+TJ1R0Tjy76KpMLj7jA/nr G4B9iX3yTU7RsZyg5mWXUyd4Dot+7P23n/a92Q+65WUPEqw//6qTH43L0bR4c/toi3gx/qCrFNrJ 518kV74FaP1ZdeL4+Irz1r6GNhtMHJvo/U5PMf6gq70JbDLQzw29ffD2i7/oNwvDY1EFEzv1wz/o AWwff9LvSbfg/fK3PVG8WcMvf/n525/8mz/trPkPwncnRunyh5mtYgrTcwfO/JctHyT/2/3VczLr nJoEvg/XpJEjX/gqe8m1CGr0uKjQ9dLZfDK553/+OC758cXbD/7gJ29/8fFv3/7b/9Pfefvov/rD t1/95rPs8WR1t5B7evVd1TCGGJXXD6TXrerre9K7voc2dnHQNsi+2XZUweVLbZ8dvW7SWAV4L345 zbZdgarcnVi3OHHl9U7Iohl/SSAfvbZInR96yE0PfdI2vchyu+Z8Hr77ru3l/uA+vgmuxbLNsx0e HHCZS/E//HfVpeNyIAXzeDCniyHo8doKa1vtPDqxqWr1K3bA8L1Wsvrb6z19jzxlxrtn21hP90ue uIoDGyfv1XafvuPao/hAgzKq/L/vhIeDXXADYD6I7myAD1MvdWjabo52x6+ileckZJPP98vZ9MFn 8yFHnv6avIdfnNaZVH95pE4evI4H5faN9bdgeTDcJx3Lh4Suf0mj8Zfea1snc1ZU+MTJJ51OZOxu gTCv309Omt61y6QfXrnwwnNlyl8+xFscYGebWLGTfG29nfTKYweHAUJHIkGjOamF6/pBWdRVtxjG M59GfDqi5otx6sdu3uiCz6TN9pfkVz8B9+bVdCRTlu3KpnwO53hfAeuo2v/4dtJn1uKMQxn7tEnz ml/35OYvO3HYr60v9mKyiyWz6VqJXM41x9vOF/XJm3vOb9eOL076gd2zuny/q+XaOmaab9sdcQmd m7NHvXjsBE56H1Jll6AXI3et7rbg/LETuFXLzZuTv+Ja2caPV1y/yQUuJOc1h8fbsfm2wicnlgth uPyOqA1yubJW38H1gc2t1FS+/E0Rey6nThdO+pM23Y4v128dSM5z16C2YR6xeeEp7Os5/VxddzZ9 2G/0unPO81b0C8vRYnD93OU0X89dyXnarvzLUdnYGKl2WOShNaRcryBdUoq9lUauXZO0qpNV2TpM PiDz1Z7koJOZi32C/JjhrhqBYrJgyyR623IGD3VwA+aaUsn3ShD05dsmigLDGdgw2wmUxOH0S5iA rjGhiShwEe2sqN2nSEPidGAl/ibqZL50TDhnOCPgjBIj00WGCYwIcgo5eNDpASSZTv1sOZBLokRX mCw714DoJVPA93NFySb/ziadXWNLDJwWVOr4ZmdQwwAXOySTWwYl2vcaTHHoZjaQ0Agn4TqN6UlG n4GdjKcRsCVPpqOgw4tk9LyIQZK+zp6vgtnZoVxCtMGE0efzHeOncWwiHI0G9sRiQChq2/ee8wn/ yRAyhg1xx/JsagO/8j6fOwY4FxUeE5WbuLHm9tewWZHNU04i/09P/uMLciu/TTwNAuJ5mLjgfHXl 63CigXeNoP0NpC8/0uNWQTziVPV0y4mCska2ScBLqTjBLy88VAZfDL3IPZsVyZ2rq6Z9ck//8XPU PVQgGVVSO7/0SdxsuJ0rfwai6Zu2d2GZ9mToUPlCLAkkdfvJIdvLpuwmJYdLGb7xRCMnH3qyQ4jk Hf/si87nYhPjUTwDrFzjGzy9+LGDR847v0D48o27Exb/ckSXJurDFN/aIADtf+Hs4eSyxRS64vA6 Q+nqHCM+a6H72Wff77d6P7tFblexflBNVLvC5DuTHjjje6Mf1DHv6aUEwdrkKOgv3DzI/tc2/92R PGAftLXUxfvl9tmLY51y3K6QfN3VCvbHlsze2tirRZqYzN8rTqPy8mPq3mnnY7pPPymw3Wb/eFQ7 uhhXm5DFnbA1znJhNBcPNlxOU/tE6Pgme2XJMHhUoM9Z+yTX/kh7dxzF+lJCX+XUrn1eSe/q5CN9 sLY5sHF8m5wYVvv9rW9sXxvGu/yJhFy2QY1OnVyxkHU10S27X7W4fez7uNvZ/bzV5+/dLfAffNQA XUD0gSaqX3rwUv3vd9/7wRZqAM5eQdP+GiddtdBUXHF2cnST4eqHMSzvf/D9LXh3V0H0f9ITmP/h P/yf3/75P/kXb3/jP//dvuf7e/WHL59k7ud9p/fPf/HZLPion9z6zm/fe/ujf/Fvz57sZd+79lwM pEgfs3MO7Ngnn9wgn9D+8Sy/1ClIoj7XyLNbWiXBtPau3+tok6VoRj5FI1l4+FUb9dwIJ5G+10mE L0vcH/30d9++7rtcf/vv/v23v/v/+pO3//IPf/fts7/IHn7q9bSljYfpsVA1UX2nG1zK4Qnrk6uK lo8rU8/3QFVOKDwRfbPg7TjviLkF7vwRzvdr3/qf+aJjC1+L3s+7jRwtm21rL3zFLW0eJOUKrj5e LI0Nm4/Ew5fPsZODaw/h0Y6NcLIUOLL4bSdmp0dPoTyaytdW9FkHIaXYrt6EeWKqjBSg1ZkEXhtD ezJG95KBXy6OezJqGa+yExih8hM/WTDxkbFyC5kXBnST9dJ9+A7j8h59cmZTwrXb9Vt9Gov46BlL jIfXUl8xZtLwAXJl23uViWYw3m2Oz7NXTtoWc0ueOKNdDIEkaG+XM8upStTbJ3e5tDGnaEW/9vti u/Zyds6ehFs0EwvzTkxXNnwdnx3nd/KNR2tLxzA6d5BsTjGcFLWlf31a/s1VbWfwZKQN/e3f3GU+ 1Ab0g9N7GHE986DdyVdQ4jx5+d0YJf/Xr4ZPn+ZPk6tT6y2RLzssbPhCTp8qkmZIVGEiuxcsNjUM dAX2ey1H7Z+Pw3mVKP4TtuT1H4zJIOfmRafH1yX+4s/7Cbd8JvYn+z743+vGmSklZMeJWW6T8rRx XDC69XbzRvwTaIwON6ZtJ8vdaZcHN9arX5uP+nLq/OVk6vc/rH8h9wVjfn4nj5/zZ/67nKEqWS9f rn8R27bN5bTjBK2cwP7F4rA+GFFXSm4v+6tBP70wXkwPVGNiPtxXdKLWzyDThreIpS8Mx57d0awP S8Z9hfPm4VTthDjsdXx+GcFTmz3j4bN+X95P7uHb+qx6+eIOYbZeDmUOW/miE2RO9sDNH2xgrLE2 AnvLYaBmf7SeLzVfRi/3H38uD6J61hcvocnJ1sYC/To7PYkiPQlMUKXrvCeeTi5WDkf7tgEbOA4J eGDeKe3YGbwtDJFnMHpOdWZ38nbZXSIdEPU6MOReOxPQDhVPZ/QEQcDhWaMj16AR7RyYQx+XiZYJ rPoljoeYROdsPKLDC3dO7Vijt0Ou2zumt+M5Gabs8rL4dTFp9CnWoaBCBy9bzo/taz8v37A80fPL nsDJVir3SfZgdRQ/OUuODqM4LLOc4tkR2cIW23Cto7L/SnwN9RmAfc9Y4ms8FgbPop2uUqePdDjx QbaygF1jfvk/QI9/Pwio5OfGPUyo/dlc/Dwq3h+byJ7BPtvEn/Rb9q52vi/y8TtREBFfBecagUMc 6dHRtXOYkuSgbY10cp1FL3/EuqontgsAuuh1ImK2EwX0VO7q2VfZvNt5yHzxbjd5mwi84vtNHo5z eB4cDuY3umYprGFX3ktO+cxV84482NnURD23cLXH/OlMzMuGO77F3DexXVvhm2TayJMH7L6OU8fU cRM0uFYbrU4Zi5i/m+zlcJg5RM6tvn0dHz0PHY+9syWOJzai6k/U94j9Fya5L8/U2byvH9k+VNXs aoBG0jEjOjF17Yo12aVKua0zOR5G6ja15VICb8LQDpJkyH3tGe7PfI+/GNBJ9/sNROrJ/OSTT7rC 64FHn3eb6w+WEwVk7ZaNTFgOSZBx4zubHZu63gbExcWZaCfmxF3hYpmg5aXj/njjrHm8hr8SfsJm a+cWDAMxvgGqCu8T8ype+2HJrrvjIWT89chShYfw9CxmU/eyq3ITZ/nhtjhR8c/sx/59RjELXrzK /JErFsNMz4sOtTZ9Ppv01XnbibcXnyhvctVnO+eKF/bZyTcxrY2Irb9XvT7BImMDa4Uo6eULr8+7 uqhQDX5XKX3X+72+wvJlF/c/a1H8654EalDWzrVvD0mxIPro+x82hfOFVJgaHrPFw8jIk48G+y+d fNnx3elDzvqW+Leweu+DTrp8+vaP/vE/ffvb/91/+/bz/+y/DqwHqZR3X/5mt/qacHz1ZQvEYH/Y Fd/3v2gx9smXb//2j/99E4iPWDMdVGsXiw+LXhicPNUnLkbF0ef63xyjT9sVkvWJtY1wkbCxmUIn IPH0Mob5X3tKpzYvNu3xwNoN49mzk1Pf/b7m8vZVber93/2Dtz/613/59r/73/8f3n7/9QRqC+KB j8f3MEnRDowz4squpT0VsNCyQgWgdJDNtqc9csTyLkLyVG+yk8wxVy9OHzaxuSuPr6u76wNIxOE5 I+wJV+V7VeN2XlciTLKHI8pnvJSfH3QVQ17Y5us+933c6ixCxQBk/Jo/Hur0xe8mrNUhUrUUxaCM zqsi/uK5YIRpHERFo4y+8eV70x4EFL0+iCPb9vhKbp+ao/O++Umfcv6ho21tDjGN+5yCDqd1ONef pvjiIp8y6LVtfG7fWAsW2Q/dQ+NYP6mNXF95NaOV19mojxBbufrIGJJCMK90IOyHM5+1z89wsjem 5e9yW3lg4Ly20mE+ciHmxosJImzbXfk9Oaymn9YH67zDH2HcfCL5bDqcfDHDdzr2+iZzySF4YX6R BFo7XnxSIYXmq6qdfHiZMd10bp7aVbBulJku+Unqw7NYckTJJAW81m+gCT8btsBRk8CNE5Xh3x0T 6FPKv/sTO1z6idjXTyuInvTzh94GkeL0ZoQ+0MUdbcGVVPmS98eD9K/a6NzAM63PSBnm6dR3f/72 67/8dXF+f3YZt7Y4q/6r7jbBvvG9/FnupEiOrE9W2WuhRP/KK1ckv/5cmzr8kzHbOvaXDf7093if ucTkq6ts+RbN6rLf4k+/AqQTfX42bCenkusuJ4Emk99kqRwwPonvsykblmjXptL1rI9mD58iCdRT j2UNIVCzE4Zh7DNhy6n0fpHt9Mvf9TvR8bY2ucVg+UyXE5sbDxJMtCv39sbbvI1M86cv+rlHWL7f LxDsyfUp92Cr+3k0i/8XRpwDzTXZH075ocx3f3eyJrn7qks8+tshl39hNV/eOBX9fV328jNLqr95 rlhcrF65QYKGNEmQ60+MBa1hlHEKJQy2swlFn0c0s2Nqe3W8u1xt5KtwnUefzwJTgzIYXEOoAWfE BuoFU4DJEbiSAtB4233eTuYMvcmIunU+AdbYkGrA+CzW5IuBDHDJ50qyCfedLTEoteSses5K2CZe 0XL+VUiquOMFzbaErlpCJupFRkhlXulcIsxW9rLlbNtCN0mwop1P/X5PyAAAIABJREFU6crW6cZf xezeAOCYjw5zBynslXtPMV8pWojfYTFAKMlVK9tRNLA42/RuolS9Or+liH6+B2wxuDoiLK6i2gDC d5KDYnpMhGF3Jmfo5pShfDW24MbD1icf3iW8TgZXdqmnWmOFaVcAJKJ4OmYmc9ILU0V7WIx6PncG B6advUL/kq1YOboXqukjx6ZUfm6skEOVb+Is0dv46gZZnRMfnh0wrxMKLxp/Vz+FqpdHyky2Npjg T+be20FjW66yVSW57Vz7uny1L2f4SLuwkTvbkxFHPJdXHCV/5akrN1PxKHI0500EKWcDOvor0TnY xMHAVsmcBL84epDFM3mLYLTDkawNjmRF88h+Frg65WGGNjvhs8EtZRbhtQv1ZLFPPBGKSVmwsquv aDF3tbQhNZrsj5S8OoHRikuCJm+6epNLu/U5fieq2ILs/R4c4fd9v+gnZj7rttKf/+EfLN+/7Ls9 Juj0bePb9tf+K+Q3eBGcfe3t8BUfvhjv+QXGPQxDWfve4iQwPvF67atJto3c4XwF78mBtWPgz/BM XccQ44PlYnIDcHKi9XyByYtHvg27nTY+Xz86fbe/s6ozCMVhW/t3CH88Nxgnj3wypdCwXy6BiJcY L8do5YAJKLOGA9tovXnF07vP7aicj2DN1o7Pe2HdfvXJ2uQiug2iePrXPwS1PHJrm58RclW/VW51 H3b71Qddvfv+Rw3qLX5//fGv9tTkD3w3PNr5Zb6Xh8W1hXPD8dqIk0jazHyaues7ltANsE0UDPiL V/r5TZWTg3/rb/2tt//qf/3fvP3dv/1/f/trf+13Osny/a4y/qp6tzqXb90O9v0P/WyWydz33v7o j/5Vt+Tfb/u6msy982f4+UimaMGwfh5m/qin13pXht7+FmNdNYbBb1FapG2RNznZ159+Q5uCdWFU 9+p3fhu9GNDH5usrI+Tf+gdXCn7YgvcXYfw//nd/J6q3tx//6Af3IEex2HZ+3KgCfIMIW0TzwrXC 7Equ9lNSmSzTS+faBRKWJ/L6wTAhmSByotX2+1vfVr6zU75oLpCw3ZiExxiG1lXeZ8I41dE9d6Dd wr6xbgtdV/STfY4A5oT6CO/6rZce8raFafZ5a4ORgOtrV7ByZkOqW3t5esdMPk5k7bGVfck/yzqS 5LZky8t9B/BFe744CWxe3xvpxCgWxlXDeXRE2ZzIpmf+SsedIDfGiM83tMZfh+/6qHgg4oHfNmHu horsvYXZKnYcw4iMOd/wvjsxEPPmDlW6NRzxyY9YTOmo3Dytt/ngydfzRzz+JXR5j2x5svTqoMrL dXbDq32Fhapt54+TFYbw8yU+zWLm9zafKkjHO+wvCXgvzsUlWlr5+GS1T1pvaPqvXZn/Gu/lL3ry j877+v7ZdPVOXtlm9+SIw6T2mU1n9HyjdHrxj6uSaPcQqBlU68+G6RxFddERN78QUDk8C8eOxM28 /7WwQFz92h46crPFraS7GreEoN3LNqG3u/en7jx9ZHxw80S+wmGsdnuzvqyaSsRE/9LRC4Piw0lW /oJHwPtEI5fy6Et3J8B8jaULAScN/fmeztsIOF6JQ5RjmwtzHj44nMn2Z+6zPqMYLAf61PeQe/mW axJAxPmUwNqWcWCwqlORfvybT9fXxnz0ccoZG30kocNDLqLLBTG6eTxe+WWj97DAc/44nsonGN3h Rb+xNhumi47kuKMOLznukOJTc6obA2tz5dOnH3+G/bCAZZ98+OyvxGHxY98IkplP9b1rX54x0Ua+ E2T8E3l6j+85WL5Xt1wI39pVSvRbsMKlbrGv/PFv04D+MoSgU9guxtAUx/QVvPYxRlhdzq7CQtnv 9zKCURsY45uBLSbm2BkpiFEFxN0UgKWBTTfBJoHstg0iDaQ+t7BdcODiLAEE8+77NmhPSmDJJOGM OtkBXhA4ypkHk4M9qIstyfj/3fAA36LDFbF29Zpw7b5+1Sm/YScyx82EtvAI3BKBg8nlx+lIxLAl bCbP08OEz1mg7zYR+MLkhi2MRF+wiLc9jUoV2U4WbZ0W/Xz1bVteMoZZZ5ZP7PMZXhMgcg2SGi37 dntYZbHOv7tVlC8tfJYsh2T2dPxZk8jlguL42YFzgyQs6ZOINzDVMMjpT3z47G5ZwON121NPlEbA 9TxF/vkSvos9jtGxK9+hw2+Bc2dI0x/O6Y92eGKQ/BHMx8ua5NFTc5psB6Xm/P1g24Af3Tq49OHQ ETyYTjYpt5koc+RyY9SVv6p3h8GrTJzXHqI1IdnAR8QxzlcOr71xQ7FiNLvcpi856xyklIF1SnxG s/abPzT002MCk47KlqOv/LyZYzz+e2Venzrta8f0WwwnaXLGeypmBUxsMtkSp/seq9bRKzsOh/wq niM5WYu/voGCpHvRPX/Av1Y8U1atxN9sXv+vs85v7LMSUWcWbC/b+AwKTwykg+3LzfmmK0EtMD79 9Hv9JMxvMPQ9lA/3Xb3Pv/g0MbBc+13b6XhIOWjyh2T7O043v3BiqAYR/uV5pdKXbhl9XzEIdzJt J/JydcfajMJ1PAjiVZGdW4BVZ6CxzUeJES/O1QYtsG07GYkM/f+Xrjft2STJDuuy9q61u6qr957e pmfjkDPDRRApSBYh2LBkwzD8q+wPFuCv+mz6BxgyYIu0YcDimLQkcwPJGc7SM9PbdFdXVXfte5XP OTfjrR5Czvd9nicz4u73xo2IzMhMIMu57E/OjdzOO/C+Eina6rfrXGEUhq+iyQ42VvnJVrS7ITj8 23cXeCVQRrxScfrpM5AHeupx5tP2Sp2xcBBDAKa1X9R1Nc5dJUdm/zxQHi7H5nvb0wP6JTvLR1zx d/KoW7XTPU52nH/h4vatb765/eQnP2Uwda8lsOYHc+WXfeDEzgu+zf/AtU3J76Gxp1zoXj7QUxqH QvHLm+x74vG5s+e28+fP8xTn09svP728nTjGPcP0uF0RYLLtcuijXL04xnvpr37+xfYLJr1HuUos r7Hg8PCwgZP0cQI/2QK1ylu2rmMUdiUAXXx1x20GZY8YgMzyZSbSlD935gwT72fYR162Jyh3h9dL nKW80Nee/PtUZnfqc8yzljHgJj2Xo0/xVOOH6P+H//Y/bP/Tv/n+9s7LF8tj0py8hZzajL+lyeik HvCFtr/t26FpO+jVdrQ7FbafNmRZEbNo2LqBOii3nZCuFB37ccVFZGlIc4eyf1i5vJw61Hc5Rkpl tu/wfl5z4WNvS0g84tL29ivb0A9HIDd+jYGDOJUex9qhdqpcu66GjH7d0xdyTlt2Yj6sjLPBLy5B 1d9pabi1zxfwmpDebWjDTzzvAe61MYC4MkGDWm5OkMdBTtDx+2bZ6DlWU2ZzvOUH/NiDReVDL7Wz vbKVh4Fx2CqOvgO8tumOfp4aS9c2esYHnm7Ge7kgpIHLDlMbXevTq/ZixYoU9hTSDzByqs/gWP2S i68lv+1YUGHcsdzj8h247c8XtISVIvB8xE1Hihr/cTzVlLOzTrR40aX+yUmOGCAry8TH2EiCQ4+Y KablRpuz3+a/14Yu2cw7bLVR8OqKiyHbTxygRcxz4PN3vB1DvY7yfm2Z2zq9IHTY/tQj+0/w6lfM yfxlM/c0BFt1Cuk+8hnXbk3c+G0MRLVt5zCXaZXdWPZ3NnHXkfvzkb/7SZJsHk6p0Pdv8WR7+uwm uTQcb7PoeTLULV94tXLlTXHT2/HHzq78qR3ZDEFPdt51vLkDJBmwahVvC4I1D2gPeXkiCLnKjxxD aNH3irMnMH0fvDlE/s6cjNHkgoA20+fFrRQjKhe46u+Kxu7q6mabmDYjsPkeuGQYPSavGSP4nfLx kXE3+c6kHa34Ei/NW3Z9oB0XGDve85V/TdRJSkftX207GgtbuFJXmomNKJ4wbfkdBers8mbHKPfu IKH2B9c+cNqSnnVDPsqPkF/tX739SJdoTuvTFVn0/GqL6yS/vOf2jr1fAlEvzyo7Oup9m3avmGP3 +iPk8cSdfacbc0crJ8hl6rY6lDEzBXpD4fjrCZc2CoWjWBF7CJaC++FvnXm0oXtsCPDF3n41kz1p pqQV0oIm45ZdcRszmJRn9DwjCf5sRdQZ5HhJ1BwnfAqmAjJgJGWscUiLxt6k14aASuksfY0BhUn2 aq+8QrhZP/v+rESqI/3MmYQRzvoJOAeqOJ4gnneDiQ8HAAoAVHfsNwlm5NcV4q73UDr586zRkd4t ydlmg0MYMpvUOiut0y1kG5PAg2PrUa46+bXxq33c7PiTg33xdFoDKRsXMi44M76wBnIJERtJfyZa oElOnfnpKiZ7Ez/ahkK3jDYHJVAqhBm5sLP1bNGHeHLhUzGKHHSUgQ3IxF/CsK1ZvvOXl0kg34Nn o3IbXQY/PsLDW9/YIdcgIZL8ERFLvXZ86hwI+15A5WoCoewD1rd0/Qjntn474EuZRlfTn3TGL+qm nX1aYgOkv0c3O3yJtq9GUa/HnJCxUzTupgOYWFOvaUvwRHwtqErysy2LY0wszXaI6tsXODjjy/bF AR9jUlQPlh7jY32tPvIYavIMb7d//igwiXfaqmRM+l61zR+StZQ4U84pi8ou5xBf5fp82iXwdXBe udeqUe53/AQP7KSNHPStQaVXc7EES5uP87CgL7bPP78K7zeza7GF8Pql9gEk3A+26HIkp9mHK3r6 t3gKrB5UpIv40s20ezsKH/PajmwPa9Az5reQfOUPuOqdZjqA/4NlXPhaotrDUJ28hRzacTD2fY7l ATHpzKoK94xhIfnLuezzqwzFCfudgeXXv2DdRy95utTXKwg9+Ilaqa84sePOBpYVH9Tz7wkqc7tb ekHPTeykC2y3R2XWyUfaymBUqiN4dlz+I8shOlUpqacTT/Oi8L6HWYUalGAvB2VzhRIhAL148WL6 Xvn0Cku0OOHBIM2HSGVL8x0J2tDtNTt7vKqjvh75ySDsTy5DP+LRffuc7hHmQWneV/y3P/jh9tln l7Zvf/d72y2uLF98gZUFzKQdbM5SOGQmx39+9cb23k9/jibEa507vtjbUTx3O6hsfWIGyHKdHPas 9gM+N7HD9SvXtis3bm2Xb97abt/mgVLmJvBO0BYu8v7g506f3k6xf4Z3Kp6/8Ox2muW7z6D7Mwwk tWam5Ks8qr0NDPsCV/mg43EGLI95N/b/+ad/tv3LP/jX21svvdBicAcn+sI25J9pxA0Ns9nqkzwZ IVxjA+MJHuJYj3LDd4/xoaRPJbYHkLj8TTxGiZIJC5+EfZyPT042aoKE5uQXcYxxSpNNXLfl0+m/ HNhGu9ytXx1HQF+ZApcuxxZ+6fc/tm8OctOH6lkeNBeECx8b8C7GGo9MPhz6O4uhkU+gFfzirVzG KwPIeBhPT+sOeMNTc2hBea+cNbE8bWZkHVuIZ1vwib7iTd+7/DD4jb+ok52xr/zmDT/abJw8/KSX OxIN7yGrvOU5bWj6b0Mg0L1euHJO/lcm43Pv8yBoWyi/YQN/+U9uQAaPdp+9OF4nDxvfKLS0YLjy ZzEGEXlKyL48WI+FZ/NbebW5E0qjzDpPNs1KEPDE5SON1Ybs96Kw6xF96gspYSmw3RUPCFyuo21I MxpDrj5fef1kGw2GLF2BY9f8q3wxh97IsetEqWpANhjOvVEPD8pto9pJGeSdrFGZPSWCythLftqA v/IucDGCmfQsu82Tlq9/8cV268b1cLwaePrUmTgJ/nRL+f3Q/YSKXjFSzROe3Hy9hyMpY/mVXHUw Hsg3xuTEZXFFWb5L5tFfmR1BzCTKK4DozkWc+lH1Rq/hP3Eh62VLabrZxtz0Z7B8JyftxNu7nkHP 4+Y3aQGiLZykeqC9Jo+J4y1XyAuez+fRmrrN+PZCmRg0joOxts3Qk6P2b8rryiQl0u8Tm7anPT9R o0yOD131or/FTz9PcDT/gU95aPr0pV/+8/5N5Ha1zyHg5wRe0itVshr5TTad5/B3ilVURzlxe+/u g+3GjZvBzfzLOHUE6qbExqeTcZ+1AKYPloQGgpKT1RtLFNvEEcde+JxN/eSE/pQdsj9Hr7H9+Kl2 ucOL5aeTMBLQNuJZyu9RERusW8hHgx8EgEfW6xENjmOXcYXzY6OhaghWMo0vFQw0DSjgXgeLyhYv hdMBEdJDbCkE/BggZGXtuOWYLln0GPom5EN2uCkGnQTDaNZDS+O3A4E54wWseADaJWlIiYsmfGvE 1ZkCg8A6g1I93OdgN3bQOdGG5GfZTd26CgaROgdAtbF8vb/JjwlbN7ZMD/oM0bGTfHF9BlWiGUjY iJQH1jUMhQ1OJSmFGn8kcEVUViZJLvm2c0+Wzi4OjnhuBYn82Pd+Se2oDzyBIY6qjq8JSAOTYwM2 XsKCq2WsmBji2IairtLlI49JRnKU3rKzUgIXdymYSC2JjYDVNMilzIZep0Kc2MEINZ2V0o9tEHL4 UiLf0U8D6AO8DfniCdomvzjs+uOY5FaiOm1gnsoKQTdgTZS/Yj/lVE8TlNoojjTbcZeCRJzYk4yc 9bPx1xM+Ldxx64SzmbE/tLWxjT+ppTXQs2PbQiYTug9ViVmxMvijozznM0qOnZVz8ZPYxKl8JhEq t0lYHZrMUFBMA2HZkk/c6ELW/NBN7+DJNJja/7QNk+8aCMxEQX7aiS9CSjpzvCKDMvnxsXw+xord NL41DClsIGA7Z1MP5fOkhk+UpKD4MQ7tLEyyXjG/znIp7eXDbvTFMWjyU7uUm39KsXKjdfkYfQRd 9SGpL/Xq68f9BqHsdLzTksLYcvCnfSkGCPuPsSGJFOMnG9pRWeYmbDz4FU1/81N6qm7iT5DAqLBe jvV+7K2BcZ0cOLaVqncmwzPtwdXS43Nf/6YNjtj+ba8RTojEqoOrDLj8KTQb+w1Cdpnglo8sW7II pgxL0WIeeVTJr+JGmvJVWStq84Mzok+n6dXd+loTIH5XvSPgOkjwyZIPeYCU72B96dUXGaDd6v6k BiheGWY5Dd0yonhmGXSF5eiR95PvOcZ4Sx5qtKEDMe8Z9qrplaufbydP/aTyn//sg+3y5Ss8ofkz 3g18envuuQvkV/jTVrWuafXTy59vH77/ITmb5zwf52nP/Bq/019MHHrltf5lnxTT4dX5P0S4+9yX du3eze0S8fwF975d/uLGdufGnY2nWHAPM20C+ZSXO5i3D7nafI2r27xAabtw/tz25gsvcy/uye2N C+e2r73ywvb6c89uZ5gEq1ODkext/4K+2OX4sUPbyXNnt3//3ofbf8uE92WeVG30PebeLhocvtH+ Y29dSRXHxI+DGu2J39KI8vJV9l1tJPDgtY3tp0nATidME4hkqVvhZygYM/qjq5Lyh7keLEyUfpdL DkMhMskqpOVOwIyh+SR9fKxThymZOJ42PXJISfr5DOLhI4Cx4jtEhR2bYEdykwIohbEVnXYgcqDb lGsntyWvdq7/Eh8c81514rNpq6cxOW3avmzx15+CrsmtuT/+4io0m3RrrNhE+SsDrv6y/Dp0hZu+ Q920n/FpWV7qJJM0F4/0BUorju5D51f5xi2lRg6Px7Yjs7afsZN4ijo2GfsiyMhUHTJTbxxkJI2V jLY7+w9PvIws1aS+dOQoz/k6bBIjLr5sR+np12IqKssGYwfHSNJfetZuIazM0Vdu9wEvJ2ZzbW/P O3qJK4z1WTQbg0i9m6Xhst/qjvC06fDRfkUsKAO36oxH66BAnXByra/ax4j2n3IRf8zCN7LUdmnH 6ud+sQxcMadiQ7C27uvJ/vB//cPtRz/8cXby4o+3evz2b/8Oedd3uX552/nIbY85a+MtTfaucT/v XR4+x1Wrcq32pYel7A6ieVLTJ6ajl3YCpz9oJRI+NJd68WLEVHdztq+RM8azcPrUD1IiT+3vJg33 tdVBXE5VdhCf1BYtV1PWnxl8bjuc4/4ZS0mPOvg6aXS8XD9nvb4Tj39Za2cPlN1+F4dwKDyw3Dvc lVJ8qS4EPjjAL/2h4+uiGO7kx/RSfkjMfMgcbfxD0iu/8eOLgk4cUw5JYIwbT0xRRxbo9a/x4HiX 1XHWM7xpgDPHXOWd19FFG1rrQX9dBM2e0hmZnG+YH7SRk3/jtLFRr90SSljbQealP1IgbMSnPIO+ ttP0B2blaCfkyiZcJ7vJe8a0o+MZbxMvTRqh3CVz7adxMUSKIoj1ExY0A5VXiqw1g22gYTMJR8rr pueMot8Ugn9xamTg5wQkbkCZ5ICglDxV3gY3774b22qcI5ya0m0FATAaQKJr0FTwU6ZonqGIP3Tk ZeIRz+WV1i+dbd4aTVLynQADguM14RJhDI1xgCm4oKFMNv51z7Cy5E71K0KFgWb0cdA+MZL2QQOQ Dh9ROeeEYAavBWzJK2/tvh+DfBRnyxcBgdVe0gBJRAJd08Re+xpYfIxq7RA8dNdvfiDg9J+bsMrm kbK7/DrSu63tmK2TxWAMXHYIryjcIaxLOxKKeNSBpJhG1FCREAMOdOrskfbSh8poVTKzo5IYwcDV LvHev9SlDyDpC4i/XqVhupgMhL3mGroKAN3u+dwHn8JXT1W0sp2N0Jg0GhWB/Qw7MA7kmiiqCpux jbXhOAnMsjoQfYdOnWmGkknOAaBUfQWUurn8TLHWFr/ddsaytlEum1NLxt0nnuSZDymfxDTx3Xf+ G78rgkp04gDu4vkn0yb56Ghi0o+1UfntroyHB8ln/E9bX3geu3kcrFIis1f3pG/9yChNNbf9QaeY wm7B5DxY1B1jdxMJOiKXG6bnePZtp4umYTHtcHxLldCVKW9tnszva2kOc6aU9TSS7SqbdtQndpja oqSpKvDiqDKppbj2ivhub2lXlpiZZtlTjJEDoF1mKUa4X+wgEF+1zQG2hG18PHhIsesjrFhjewqN V2Rfy5ltq/KQlHKly/5Lpo+uMS775a8EkCXbEsF2Obal3QA/JznFZ9NPnoyznMPxxsJd9hHOj7XS 4hslZG2x7UC59aEl/h107sxSy7+BUWO7U17xoKU8tlEL+qF+fCKsJQDDp6suncH3BBbxZsdN7ZxU cwLHILaJpXFwYjv5DA8+Y8Lqq4MOIcPcY2scjqxxUwE5IICiy9f7H28zyb3HYMynVbpk3lick6aH tnPPnuGK8gvbJ1fubX/6N3+1/dY33mCQxm02yHPz5tyjdu3za1wNuQ1BB27HadtxlRNSKrX5ncFR ejmQVkWXajF5p+yjy19sH39xfbvO4O8Wk/ej3MfrFetnuXfYhjY+n5Nmnrg+/uTkduE0T4nWXPjh zpUr208vPdzee2/b/t8zZ7dvvvXq9ltfe2f7yvlnuWrhEjROAhhb6O2Tzg9D9y9+8cn2B//LH20v MuE9e+bk9hDdvcL6hPyhf92KMSdc/nUCF3bI28ltlWB7hDzlVwSdfhkAWfkHP2n4Nz6W5uDNMbzs 4/GLxZK03lzpwGbCizZPmXyNN5ftuS06qx1Iz33zqfJIzZiMP+VP+c/+9ElPy1f+FV7YeJvHYjTS RUM+/u3lE+uU6WYUWIO2g/o0U+LdYAJql8UjpcFDSWU6gGNvyS72bEPjablyrLr5LY8mvPZYdeqD 7Yg3cesn841jib1u97lIceErraOl/e3bRsZlHzADKv9pcrYlmzBOXoI5sBfaUW4oPoUz3LSzkPxR Gf2ShvoBrAy7MvaPhKQU4Ua5PLUdNPzUVirTzlM/34ECAx66K64+Zzcq4pp/1dNflyAXv9GWvnB8 sZOXFGnvazuxtNMJMIihm5gi8ykuxTuQVxk4Vl6/NMy+Jee+P/YWcWdiIhFUfcNBJvbtj51ErfGW eLb7deKxPheGnUiuQUlH2ZAjKZbMU6a+f/fD97aPPvh03jcOyx/8zQ9YXXJ6+853f3OX7v/vZ9cF GZIfftev87oixmqHOYnnGGzmCZ7MVkbHHnpldHniBTFk1xfh4zFxajdBuerFhwpqlvGPkpB6g9ce fgToQVTaCVjbs7nXAydgsM4f9b3s+2BB+5jhI5w2mZxgajROKoGW7ckTxF4d9rYR5WyMLBr78peO 8Np52h+72CBZ5OMOMgklrD3byEjBiC9EthJIC8lnx4w0RbPFC70T1L7SUZrkzYVSYd9f+PEVrmZx zHecJd1HOFGqbe5z+5D0uw93JAu/9gK86NpcPE8U6781L3I81txDnSyHHx4M1hOqK67TQVpy7Ffd lYlfcJVQ/ctVUhCoX7+nz2HSa6GTHQnxRcehU713zrX5NtUSSkwoB14BsoUBIhM6n3UGMSYGIY1k ggMjYMRuoE8YqnbFxtF26oqjBg7vIecXBn/gsl4OKkMeQkPdMp5sO4u2Wr8VBjrQ7jb4Qa6H3Nvk YHuCWZ1cGgqAW4SlY7JCLju+Bus4VBgIqdc4bQJG5t4vo7julywNaMrmicacRaS8SYH2KYAAZl+S 6twf+mkX7SUN+WVtcDvbYnks0B9zLvtqF/7TMwWEw18Tp8CyA4l8Zn370JmkvHdAFEYDvGjIaR9A pGuDr0ki+nskkefYsadyKjN+Vm4nkHW88M23aKL+btpC+9qeZLP4NaimwMZCCkp3k6z83Lo6kJ4m NjuZsW8JgfqBGgcaZ9rOSZI0ejCNkx3lwX+WuaxWO4mpLYp7efnRXjtN9begiZdl1MulRMhvgMJT PnXSsEIs9KBhDA0LRp+x4DRgT+a4zL5GzBmmZAR0YlubYrcawNha2vGBlnEi3sTC0C+o2k2oJraA BBcPaacceljBgZOZ7r0uPilzEwY/1Ra8aoMuPghIf7pvXWIZOPumvm7a84AXdjbWXaaz6oe25fxL Lz/Icv5WuTmiiQU09WcIfsNTG0hHeR6RCzw7J3yvk8Ceyu3HTRsW78YnHYXxgUgNNo7xECPb5O3b d7cHTHRcZuqkw9URyWmy1UbgHOgOWeWeDz7DD9WvWOE4XH+DmzxmodGT7O0NDXEpVDM+6jaQ5WBy YGfRszN16GQMy1u/1VHkNxUCT79AgGp0tGDarfm0k338Tsc9IXbQAAAgAElEQVRl3dhHG7mJM0XL f8OvHJNs8piOogHXTv8pnoaJEl9DuwGkOhUHEwPa3kO3fkRDP1v92GbldWUnvvn0x6+yP8Y/bkhC Hfq4xBYIc0/65ysh4IoP7tzlPbsPoVDAWs5GPjh56lkGGadp+8YnE8d7D7ePfnl5+8Uv3t8ufXZl ++pbX9ne/MrLuybgqC98zCcQJq6YKDrBvH2b+LnVk8Btiy6pPXX6LO/WfYZJ8yn66HnP68NHLrE/ vl2Aik/R//FP3kOmR9uNa9f7ta91eXNXhnBES89gWRvR/5SVd/QTsiiNluD6xvYB9wD/+MNPsgNT zu0MV1C0aE9KBubJAz1gv0z8IburoYprYOxfXIbnvVW+asQB5TVk+v5f3Nj+7Mfvb9975yvbb3/j re3N5y9gb3wD7we0mb997+PtD/6PP+Z+4W178bnTTdKPdOXGONHn2l8p+COHNHjqpAvy2DT4c9Nv NeEkVs1pT/Uh+Ew6SFl5CNpkx7XOI7f5ZkfbQX/uJbQvoq5wNH484L8gxA/GSrY0row7+3ivHNnH Dk/l8UTZtKvhEjlgHGDaFkbL0PrKZ+xR7ff4sN3pA6CoEJToDyvcW7TVliMOn+ILNPVTCB18qD6L 19Jp9QurXNqj11ylNC/WLiG+dBI2cQTeN+ukr8nKw/jC+D7obzhBEQ/hdltJJDxlRTHrD2z1JQbC rLynVl2Zpl67CEY1dtVXk3e1r+9VX6/XW6YYUYe/dS5RJbI7SXTQ7wK0/L6rloyOD7SDMq6VDKjX ll1gkn7KZY5mWzbRF8oo3U7GJvP06Spsn2N9wRecsQeOY2E39qVR/2V8eQQt7WwcZrc9X/lTXlMO 8PMv8MZkdGBkvY5qCapyRz8gvkZuZU8vDRxHrAqavFY8sCOZxkPaJBshQDEqf+wQbexmHpSvvdvi l88O+MmXE/OM213+fewYz8wgv/kALieuP/rxT7Zv/tq3WTFixtLDxgr0RVJEtqeSzrGToatffJ6N iEQYGB/oLQqftmU3hU63GQsqDJDZXJ1dSmz9euc2RKORj8Xbc45kHStSVHwqqfZTTH89nDjRHdqI MTAn1b2vNSTq1dkVOsaFdOrHHFcju3nGMYnzHQwpUexPrga+2IrLKOdxOgRlrHCCojnNsFIWxzNC TxwBv9tHnmKPrYHo36PZ1/G1Y2WBLqQGBn0sV7fJB8pozHCs7D4IlJOdvgXhNCuYfDe5K5Xus+LH e8fVV3h3xNFuxk5XfM0bVsG7eQv7vl1DP7vZZ9Q2kVEy8hNPej6bKRmgWbsoNqmDwdN2ube3VIIG 1T0nCRjEANQLh+5A0GaocR0Azi9AIlLvZsMIjkboGY06DErmSg0YERUHJInyscGocPSUm33re6AN +53BoNDEk6FGGMHC0zoTBCQ3hFFhDWCQKY8aiSIfjdrgEBzlfkRnG3+ogRUDA8uAMESaXMkImlKR jltXT6iX/JHD8+6xSWgacJzomfaD11pUpgw6F7sgiw7I2fLhzx6+V7rgUBlpE+2gG4QNqhYsV7fh BbG90TDxhqeDogYVGUieux7Aa6semLPTz14GPXgG0dPkN/YycUnGhnEE+ew4ikYn5dBVV+2ofEmq f5VZ3VQCHP+aoCM26T98rZ2S0UY3laV2+U/5kwWcEgD2nxMvxsPQDAcZbAYurfZsno3Eh7LorZZb J/1uA+RCUMrhLg0/HsdbaZRqbC2aEgFaHKvj6Lfrlf2m44UQkJAWQRmiMgSMCRPX2FGdqN/hJ+5H zwf4TD0nJsa/4mYHadPgMTW+tG63DTqacFz9IGt5K2+7lKuX+Lhg/MR+simE+0sOzwyyAda2Ek0M ZWpFONiKA1lgtmJYBGVwk59/OqSBNGeIZkkKbXKnHk9A9HPLYmqbJneRMDKkGkgV5/KSGx/bq04Y VugzeSGelrspI1sdHfG84nGOx6biK+6EAmceQe1eeHawdh/5eJVP7g70XY7apBfY7jkFvwE5cPqw mJNu3BXgYO9X9rOrnZuUVQluQsqpLTXHUmm+29M8qk2ChPb4bXLb2HzQJbqOiwt9Jy/NQ92ItfMm UB6jzMg++ch4y5cYV/nkNwIuXMmYX63ThpYbs2ZKYG2A8YNhBMxv48E6WHHUUWRA6wuEo7ArXuzm JXTtFxixPRkZPGieOHNSaR6/y2sPHj/kXlsEOswVxgYr0LvH66bucJ/Y6XMvb0fPnGOgQX5GttWf SFVJWWW13WXSe5K+otzP92FtgD6PDTD+jY0PPnh/+/f/4a+YCJ/lac5mQDtY40v/GyMPuef3/naX kyN3mOi6xO4ur+6xnzFuLlx4fjvJkuTjPoWZ3xMO5pDZd/7eY0J97RZ4d+5v586fRdbD2xWuzBqY Xu097v3mlD3kHZS2ZQcObtpQ9+JFDYnMTIpzjPvcuwvARyyJfo/7kS0/gd2Mm/IB9vWkp0YwrCbi +IWPhKMDL2P7MfdT9d51jp2APIMOK2b+3d/8aPvhj366/Yvf/0+2t19/tQHrD3/+i+37f/7n22Ou jj/H64m6ih5d5JIXfoJUJ2bUQzs26Pdg34xhZT3slfY7RgCyiMRWOXUTh7YFCtWn36WPOgm80yFn 2qebc9Y9b/JcMOpcm6Js5TLz8GxUwtvjGVR9SY5savXwEX7wkXiXl1rJRyMe7sN5yINXrTD7HkIp V9ItuThu8iIsMkpPDHlBqWNLxggij6/Zi1bQIv297csyrirtKE036wcmS0V++qd1bJ54qvuMt4Z3 ugY2MhpLymEMzck6beAYjSwNjfJoTpy4FksT6jPHf/rfMsd5yRW1kVE2qywkjhfcgVnoBOWXvMms 3bBhOUvTcQyhmViNftLKFtlu9BKfwtm0P58VmxZaZUyP/MaN+8hnrow/FMuZ0NOXkBuSOx3HVdIV 1jSqAl/edgQlSxd9Bbx5oFwsM2WiP01MJ8COGTqoil5HpsBJi+3ALuAJN/qAg0Ecy632LrT2KR2j j3pIXiThbOsdRjbrWhnNZJW+PNULQH37kPz74AE+5r3o3BURDR/Wd5MVKRfOz6QX6MjknxF8RIeW NcrxiKXS11jNUrzIwjEw9ARQNvO5J/aMPeNUt1fNsReLll/r00RD1q4yqj98hHVzLFHkyJv+06hu tKnNA5iYsL/GvZje2FZOfulbfNbBMZ4XYqVeUxHltK/goHbguFWba0/HvE6+HR5Nzpu+R3lmfAhX YJv/JKfSUcs+xcWYdI3TVheBt0McjFd3S4Cl95BpXzo8sU0Rm32DPLMFtOoj1okWJu5qU9xjZ/f1 iW81eNAqIB4OyuqfY0z4n/DIFJe13+M1fCeOnkBu5kjI+gBarkZ/jF2MR6O3+aO+gbGnrHw1VXMr 6vSzsk5e0QTKbjmW5lOb2H3ufADEJuDasP5G+6CHW5qxz3BA7ftWd54uP4aT3jQKmY6ARkKMqPMs Ez7OwBrB905J2wZpYzM0pMF/hrFOA0mzyQHCZ7S9AzZgpK9TDTi4ywSYfaPM6XeygNN9WtQb1HMV bq7aBi0dHCR/O8HIiS/tXQ7MWDCpT+UiApNMRvHOuavP4oArJdf+53qOuwQvTlEvA8IbeuujXdy6 wkJ1NBGgwCfQ3dzXyY+5YdwkY5DZcOd+uN2GRgPyrLMZY4blC5CAt17d6rApUj8/XQ3ShQZZOo1/ G/hqD6ryCdD6ziBwAuN9Ksv6gGUbA4kaWKmn/hHXJm0iHrqCDrA/lGkb/xWuDTnUj+Me5iURPvKq vD1KTK7AGLhtgJUu6BgjKO32qAhGmRItOoufjUU/SMcr0Z4JVoXEV67+Rj7plXAso5Hmxz2RxQsa XWV28riYKRy6N1hRR/BsqBSls3KUtJBDOT0WDALJn2s5Mvzblo05qIOmNcULaEHiA53OGO8213om TTsY9dTd0u87XuyZ9C3Vbjl0jyfglEF5kYJ6LSJ23CzEZh7ZNscmAtce9hgYUxgvxsHoKJ6+P2xH zMd7SiQs9R6i5J6MhIPV+NkC/egHOaW19qlJRL70Qe3aesq1dzZnX6ASJL/FM0VOaA8d9qwjZxdB 0IZ1euYRkrW290FDN1mS6uTF2CtGlMV9edpW+KzjyQdU5S95LZnVYHwwOowc0tBcEkvvjD74c+y+ 9csW7KicSAFwUJBAW9sIV7kwg5iX2LXOWCuWOSgm0GNwbKECje3Uc/KKRU5sw5aCUG2WS1V2cg7i YH/gu3pujZMn5PRp+oo7eT3gneduU+qVt/yAjh7Z/s2pD+7e2o4TL95ne4GHLV248Pr27LPPIcNI dJLBhFdRQe7+20uXPtv+9u9+tH38y59tR09dpI4JMH5UFSeSvSuQifOZM8+AQi5wQga1g3ZKE/Pk xunT51iG/Pz2l0zmzDYP3n2jhz/d555fr+b6TmcfQGXb8wnLJ3ja8gssWT516nT9jfeBex/uEXjb b3im+w5nwK9yX+0nn36xfXrp8+3jjz/ZPvz85nby2EOeQnpku/LRze0Ug4BXvvos+p7LBlrYmDWX aHffV2ij9uTR0ScMIshnR595ZrtD2cdXr20//8XHLCk7Nid2zQk4Vf0cTEyuZV8XMOoyT/cAR/Qt fjgulxCPB74HVr7mSweQF3jq9M2bN7Z//X9/f/vau1/bPvroE+5N/rB7ku2/9Jm5IWnxa30Qvmmp KVfQbd/m4AboxgXSmRPVs1xEzEzeIM5ysbLY2xche9ws7ydaB9OEjJzZnra3yU/SmNjFUHHTDsDX Xow9+HFs+zngv1PzGBT/k2VnEZy6WB7uwvdQfjvgygdqYByWi3be2dn+1QYiggZSmQNNLNM6U6Q/ kYKPelRVk69eP8JX9PS3/kCKkX3Sg7k97MQeGzyFXfIO/bFRtgOpFHhgo6lbk1fHgWO78YOqyCB1 1GHXeflGHS3TBv41OUF2ddEcWRBk84I42sh+zf3xZ4paMMdg2I5Xzlb+NnjMONMjaQ1tiuOfjNTY PkamkUE53A58CaK537GIOiuDwtr/0BsKGf/GphLnePGIxs43/W3D8NNS/qm/6V3/j51SKxvspNI7 mSrgZCA4tp+x+bQQKCDvHtvtz1hV/RVGjk3yreN47CoVhKN9e5ytVl018gBzgnecEyOkga5+yRZp AV1w8oMmYSu3OruBpipOnScxAfA98Pj4Ls8T8JkKbcgAKJtfOxF+lA3keB6C3t3b91kZc7MVM8Kq ndUPjBOP+T3kO7Lgaq5Tr/SFjnnKCWbjAznBUBj1MB8ZQ568MDb1S+1TucibPgwvWZaEsDBytGJ7 xWCnGZCHfMhtJfY94oxeu2939ezDvQBlQ2n+Qnk8KVeviRN0Uy5gbGdd6KIulrU740k9VvsHVdhi yoooxV893SKP1GYwwez3osGXtlKWTuCQ4+SjVbXHES9sAA8IH9oE1fUtwqgjdU7avUfbE46+S9kr scrTK+FAOKyNgJOqfUQrasRXEChIZ/SemNVGxRm16m4MeWLMfksZ7HvGR8tv0yK7R1999a9/2kdP yb/i4bXa0DzIaiQDaTHFvTmHn+om0NKA4xmEDSFxFFx4SlKugTQCaLiCEMt52RugOmZVdp9MkuKy 0IgFCzspRklG5ngFrUoQEwebhlhXMTWqdJZsHWQE6Gll5PTGZoPdj0nLq2wqmEFpCBrZpJw6NlaI 2EB0znTg7CefV05KLTs8spoc5W+UFLDaZ/TKPgSNsroMQMgaq41Puyib9Ai2aTSLp3XjSGlbJ1Ht ZGAawNbKepbr6gFRFHIChZ1gLdMXNUxpCsim7tHUA5VBE4Ic7TDQgSchW7lL3bwHFcmha0Bqd3UG Rrr7n2SzGbSEm0kvcgstSwQQz4HWMRsI/tN2qrhsqQwe2+G47/1a6qAuc4KBSmGkRd0E9djw4Bh5 1Ut9tRZCdlwMIJfNbRL08JjGBYik+ZqGEzJ80HOK++0snFSFZXMw6cPS3Eqk/NaRULZ062EHyKDM VE45V7f0vfKvuNKWUopawnigbuNr47AHpezyuxTZAZ40Rndl2BMZOFM2cWX70sfaAHB4jv3gwAYN ZJkIiLvIq8rag6QFYOXWaif9Fn+PoTkaqCZM9i1Kwu5nqcWLpjahUhyhtbTlHbCvPIvO09cVyR94 EfiMmEPHtuFfZ1XJGYcYjDv4P3zI+06wIb66w9NtTzqBQY95MfrQE++AoMQhrP3Sc6dbrFNneYyt BMJJVkmX4+7ZtjjZ53fAhUsjCkMcEtiinSQMrT1xPGvcAN7GM5LwMzZRH7dSowchKO/AqkLFHud7 j7Su1p69fLm3rXQSm0rrbR92QuolIcvdsvu+Y9nErniDaIhLwbaf7Ozj5hA9mXjnzs3tHFdsv/Gt b20vv3SRKwA8TZhX6pw8eZJlwnSmxa95myXELB3zoWMyv8vV19///d/fPuOhUX/9t3+7/fSn721X r17llWoby4zPcBWXpxh/cWt7/tw58oW3yECDM/FOhl2W5S0Gh7lK/NyFi9vzTGJPnj7PwzhONqH+ 9JNLPDjlWm3Dp46ePfsck+PT3Pt7ihMkvtLB+2+P1dHf52rxDWS5eeXy9jlXIy5/dnm7cunj7YtL 17hyenR7+eXXt3e+983tHA+wOnXu1LQJJqvPsBz6mPYc63C1lxM0LFlzsm0f4WDNGPfEvHnXtn6V J6L+5Gcfbh9zlbf7jjUt9nHlDW6LlvTqf9gxPi10cmq78V7DHIdTnjmBHtig3FS/OQ71TP19/OJT 5V2yfY9XHv3ZH/9fvM/65e21l16rTRqHhw7v+Wrnqk3Kb+YR/owr8zwJKg1pdZVOwEhAmNkMlUSF p9Ar9+uzRWtyCrUlhYnapWe4fB3kBrAatKGfMH6Mw+r5VSSbUPIGa5ufdqyJpu0CYKnEv7R5aCz7 R2Xyopoh3lbOp0rbH+RC27QYwKjPbNLFBjtcuqhvNAOsTllse27ZM3SFGB7GhX1z9MWVhnV7TKxx jeXRqV77KPRT/ZSjtk1ZLPgeWo7n8N4OHw5f9U3YVVjHVMK2pBU4aXm89LO+TR78rb4mnh7vtJNx BfJgRGfZyPrBkT92Mdb2MsEb91Ge7vL3o5nd3N9/HXMcbMArp9EoxAIXPmmpj4x0Nbtk4Sv/tSmT 2/Rj2tQ2h3yUOfGwPjkFAq9+Xp7JpN3ZNyBF3OGl2PgAIt36Vzsa21qnmagJx+MRQVva30Nrkiw2 Ybd6ZVj2V6enctU+gDcbZet01iZ7GwFWm3rsbz6gTDZShOHeljjZTN5KR2h4scE+9Tggjk0fUKeP xHMTczbLkGeVU2E7WNsdX1fE0+gdN01e9MSc/bgTU/SFUuMZUdBDPbMjdY9YReP21EfOP44wUeNZ BJxk1GfKPzKJp/nGv+rWbYwSQDbfWtMtW+A8IEfPHGVsojyu5PFX+vY5EjMflGN3pT1N6El9pxat 2tRBbrJGn5FHNSgQF+89Al7fJFfhutsLmPID45j1+k6bkieM2qShbvuhZhmZ5L1/qpO5x8zRikNi nZO4XkUtZ4Q3fhdu2pfwM9fzeQ7GtCczjKWVAx2zy7xjdsYHSqMuxpZxYzkyQnfyHD61bQFgG7OP akxhpwO55hG0BR+2OzmTcu2A7fV53lQ3ioGak8f8SlLfrDgoI42xR5js4GlijQaBBmfsq6QfEa3i O1AFNLg1Bro3WEg4JEA0SIxy4YLhQFvVU4Zf0DNM9KCjfkopzLgM3pQ3SVQOFPZhUgaEiovvANcr OIaHRm6jvMExh05WLG3Ji4YW20v3MmGbAbKNQP3GIZZLy08GrkCZphO1o8+ICiBFfmzUdTTIZkBq V48NcBsDFMkMyIytXCLt2TgdlI2NWDZ5+ZGeDbiJDDKYCLDw2CLa2vIBkwfq0lnYOfOxgnWO5T+J AsJDR18ptvwpc1N3d8ePyzYKgXzw1i8lYuBmQ2eNaqhR1qQV38xyZPSnJv32wM7mwY9OUtE2dhBB y+qANpU7G1E8+6UMJV10TR4SjxMXN8vXlk840P76yC260PbPf2PPhKlMyu93k2Dgh9Sum6rxpz/m ugbuw5fxQB5j0m0GHiOHsBNHUJWwFOQJYX/FMB9Ype+VxUe3W5EvLMPYFOcrbXxgF/azA4XS4XDa A4RHl73Qn53flE+7VVz1mbYnMXjLQKW15U7fhB796qzy5IRXaoZnirAvUHGxxzlGAmD0l3YPZ4P0 nOEE1thXecEkJhP9UpmyWMQXvOwobaPCZBdlVAH8X6xJBLl83YzEtK0nWZzQCDPCug9PDyBeC6qe K4bo60TjtJNeYmF8pp2MRnDiBbp8obB8rGWgxjY+kG9CxlI+TrTtbCderZM2ovJLrAliLWX9DQFK 5DOUy5+V77aUV0ld3mLNBlXajylc/ZV9fqdDBiqZEgkY5aAI/cJXEOE76bYTFOFLm7CjvYXS1rQ7 UXORa3yiSUfOkdjmlX6Fo9J6c594vjf3MTnrAZM7zfq97353e/Ul7qF9dG97++03tzMsmy0nS4CP V1ab6EJbm7RihqqzXF29dfuz7TRXf//5f/r7291//Lvbp598uv3lX/7l9rc//BH3Gh3nSutn2wu8 kufcszxZEmLmfmPK5XVefdC9n135nKctf7G9/e5XeRCVS92P915d3597gsnpKR765EqAJvzwt00Z M18wob78+XUmujd5v+717dLHv2RN9fXo/O73fnd75ZWXuRp8Jnnvoet9lnyZb3yf4X2e3nyH5dIP HCQQg95zfp+JM+LMmXLjm4853IdVeU+wLe/T659uH1263IOqjG9jyWVl2sQ8al9QnsBuDRaEoZzv bKoO5UPag30K1tzhqefkr33gYWbZxlBXmqHvuyyPX3wxOb2/8hgPLSnmkFUZtIeCG8ulWuW2zvyV Rh64QdvcYBu0ffFr9rVNdUUCp+dy69wRWwdpFDeDiE2q7fMTmFU7kAMvefuOXsUaWOq1QWVz5Tkg Ew1lVEp238CnkWLObKAtywvUVi5RbDYnsnbbElO1OaWAlvtu6oWZGzgqn/lLempRO+V3tVV/y9WT IBBLmgIAzcdjdVDUYKuLkAXFSrSXjYSXv7+Ambvd4udv+3xhg8FDbuLIbdkqGXc6YxO8xfGSVb7+ Td4e+0RZhjAQ3514su+vNrHUOuMTpQVts2zy61KO6lW5wxQrOy2LDuRhX3xtPH3exJIEbO9lR+X9 MkHKh4F4u1zg9zoU6pI1EP39VJC5vWp420anDnz54yDbhlu39HDj4MIsxm1vSyavInJiTrxlL6Ht a7S3/O2jGzNUri/RCx5yEM8xcHyo717fTDd6JQu8Vuwo5+rHwE5u5Zd5OojGx9ztx6Z3ILsKuaWj uOzzpTzarpOZ1lnGr4Qa8+5E7BfUx5xyjxyy4lE54rJ4SZd9SRSbHkDTB/TdvXubZwo85pYVqNkM KS96bMfq71gQ+rZXBXdciKSjM7B5gnJp+ymWxMPGyZos2Fsd+LQyzbhImNihJ5PuJrt4YC8395rP POHTA50cP/JxNaR+nBhXIcWyTL9i493P0p84UimBkNnYAGVOElvIgToIspdHyyrLqZiPuJTBt4tE lDu2Fla9bAvsYjfkS4jxNVWjTjoBbSKnbF38W/Hv7ZueqE127YuOPtjsmA+xcryGDR7Qv8Ml+0qu iS8lxRrH2mTpzFH9UfRsO9QrlvIgcf4tp1ORLcGdPoyTbI4xkQHHZ9PmJdlCe0z7k4+yZDR2li/9 5VaqLzW0vWPXUAJrMoUZByoQ4hR0Eq6iAU1LVgA8hsGEd9A3PlcIg2AaS1SpD4jGYZKycScYvFBr +FJ2X0OmqDS0hM5QHg2EsiidLJoIazkoskUIm5zSA9+HS7GbwRCE35FJi5ik0k8Ylxv7cmaIEnc4 zKvB6G5D0xb74ELeddjwbz088Dp3dWw2WBu+Nsjs8slB/FanVQUZOPfVRUGUu8mFegqDIJpZ2vop W4GQ/skELfGAHSdDJ6nRcUqHV/SGhnAOqPg/wAWpTf4OUJU7mYCxEQPJBxwGizaeNYiwrGQDT+uk Kez86K9dLoLUF4prY5dEuEEmOPVMdunCv8QjISqkbWJ1k6f1nSnDXsaUtvYPjzXojp/Sw1c6q5GJ b4LTjg4yXX4hXj5GTHU0Yc7kmgJIwwFeIY4syKQPrNP+xvU0avApr8OVEVtywt/NTkR7erROAjiI FSYjWB6gX/idxOpksSU2JJnaD4NRE6Yym7CGsujEZYbUJ8imcFQaJxab/LUDRMI13pNfxQKdusqy ZyJEZ+IJfoDoz+IeOtEGQVtK1/QkajrLnDYorLHON+Xe/4HGxMdE/lNYfWgHkUb9wkjaiaU+tnd0 dw9YbQErhRFMSHb9WKR9kJXfOr0pjKcdrmeafWCa5jBf6N+7TGCc1HSligr5RoyfiXv4mjPAszWD yGDW2BsdDtq8eG4S33nUme5xom3UIxnZ12qzWS4xeAQje+jra2TsFUHuKzO5KX57nfhym3yBhNId 9yrpHAsEKwfgbYkHXSH6Hz6Fg3Kw6dY2YMe+xCLtSyE6maaRxAUeEXcYqpVXfMqVA4DyV7pz5vvm rRtcrfU+2PPbm2++sb3zztvbS7zj9W/+6m+2Gzevbd965uugcDKC+2HtSJ3s6pcGMlB2vyeux9vl 6fd4t+1Ptu9859vbxeef257jaclvvvn69hvf+Y3t337/T7e/+7u/RvXH2ztvvc49YTe3O1zlPXvm 9PYJk+Pv/8n/k3w3uXp66bOrXDl+vN24fn376hsvbOfOnuXq81n04T5RYuMhK3Nu3324XeFhKp/w zt0vmCTf5onL9+7c2J5lUvz6a69uv/vdfwrts1yBPbEdZWLre6Jv3Lu1XeHpzJ9z1fje/Tst/z7L FWNPzKijV1JdGvYMNjl7kidgEls3bz7hPYdMiLFxtmfyfY8E4nLmH/7gx8CeqB+aNj3v9NUunmXX tV35AN7BAbUsf54rHfpTik4IhfGKxfHTz3B8pKu512PzvuIAACAASURBVJiEH2WCe5qr3Xd5b/Fd 78XD/jS3ThA8MDYY1Bz1fYzwq4M0TzGZNy6MBds6oRsnDoq/jqznU+60AKDpr4lXyNpt2yJAN3gE mHZonHPYlQD5I7uvGhMuKCrrA6QJerpHQjxzexIdxGVANgaCU1vVFg1g92UPPfm1KTMNQZh48avN 5NzAVTJ+ghNm+gPhIw6fJ/jBjwSk6wovKcwHeuZraNZeoDNvhZAO+7Yl7WS+ww5+KI5/No6/X5bx s/92YogDacKyLR2UC+DsLn0OK9Gmtm1rF4L7O8Fk8VhGX6Jpv2qdOrivTWZMoW8dhxmD9gPaa/w9 DI0FXKnubsolnPT5tnzkJW6rg/Muiz22W7pJ3zjOhhVnA+mUOwcUGZTc7E0BOP6O3tpzypCm8nRF lrVSx3GjZbZLaY5FR96IwHZw1FE5pcMYJ7dCm/4OAZN3/OKkqYaBLCOHdHwYl7cUzPgGGqCaI+Tp OV/Lsy3Ao4985aVK0MmUSKe9Kpt9aWrr7L3XTX3fiDYnej1am75yUwbjIZlQaPlbG3obx+Qf5FIB ysw3QAO/4mDGMLZBx1jaXaKO5xYPsCiVH1T2gFQnYetn2PfoFrdZ3L5106EjnzgWsTPHILbIR47t 5sRC4kAS3Y3J7Oj4YSIMabDp0U449gwg8Nwauyq78sDDiw7qpczaQstqX+Ure7ATqgViPXkwq4DM J+jrm2asqho8ZTFepVQs2e48Fly66N/4UftQWGxKOrkBol4dJR9RZYOm9ix+Kbcp6JdH/MrduUly U9dtheBgDkiCYw4nMCTntnLNXECg34CuOduVVhNX43NPCus/+xvJPFP/daI5kreSAVybXLlY2xlD 097Vczhapo9qawguf/XXNjabViUJyr7+lWe5QZ8CW/wpvXYDzM/6Xu2gtouN13F2BtI8zq1CJxk4 sRTByYADQK4cmPCd7NXgZIiwCaUTTOYqhxPm7I4Gd6KkDCQJGoCD9vUggRqsToLhwChg9iEETZ6e c546B8cm5gJahflTo65kiuzHsoxL48BCNiqXv9nwchZ1Jqp4gWuwOeAUZxzgZXsaEPpZRmHyR9wM IUMDP49Zb3Agnzythn8NSlzpUqZ88u8me8onMRuQ43CPCwqa6yRAkcaOOlQbOcmJV7Rm33IDQR5+ 9TRrjk1oCaMphk2+gBTFT4NrLeFo8IiN8kWoaARcDVDK6FgngnzqaTysIJEvkmKwnRH4gPRZwSi+ k+RMJjw2VWTtBmS+KPA9NEmoE6V6Xj6BWcW2V+ll4KjCl6orhpvU0hkkY1De0mhgQB6ZetMb9SHo dxOOtoFQjQtZwx+qxnsNEYRsAj1tNcsr5TPxrajyLAl5IE3otSkDH1VUZrd028s4sGDk1V4Dgdzj f30UMuVNuCjfpeOXeJQmepTIgVl6Rwam+kK5Rj79wSSLIt5iInDGNLloHxyETcc7TcSVzRp+8iW/ xqybbTqdpMFH/Np+jWF0FlKY9Ke8AVz0qdehfKQrlPjSMf967H2IOzZteepQVBA26XsEBL/S96Xp MsvCtG2lU1bp52dygjhjezvd2e84esb9I5arssRJm7HNkiQlGvlKwuoNTdCjb65TpGQQTyYJqc8H 1tgpfpUvvQTD5hIBxjL9tM5IWzF2mXo45bNWppSLlj+hI2HpJMfYoJNoFC3drE9Gv9iyC4W2xunI KixXZEDUmDy300+PRU+7Tgx6hUGL1/GojLLIQx3ZlX8tPntQXtUIce/eHR7wdHT75te/sb37tXe2 F198gSXDp7gSytOGofvu197CF96TuzU5tGP1oU5OrjxBNk0JOxn75qdD0+G++cZr26u8Z/c+y5U9 w+wyytNMar/7G9/e3vjKa9u/+aMXtv/9j/43rtb6Xkhk4cTRYQYj5uhr16524uvEidPIcW57/6c/ 5Gy9V2Sp5+SCOt3mIVRXrny4XeKK8RWu5nrS5DiTrvPPndm+8c43t+fPX4jnHV53dJd7fz97/4Me wOVAz2V4PhjqLO+0PcN7cM8eeiZT+cTkNRjR7vZT51vSzeSaSeWpk0xqD13brt90CTYTf5Z4X+Wq 8oc8XVpTH2NiOg++Iy7hYc7S9t4e4tVa/TJXmWgD9NOtGMk/XDVH9uPA23y+euH09soLzxL/PByM e7Fu3TzCleRb23UUP3b65HaEJ5uLr3yHbU/g3OdWAN45sn31a29zQoK+1qXYLIeWn0uivYpj/+RH XezvlM2+fPVDhk1thnBy+aN5bQ3gtcfKOXMSeI9N441NWsL7izht0z6xQcsJJyQB8H/ghfWgDXvs /YAnxWzZI85Qc18b1x7F2WPZWuO+/Fs7kPYOHAX5Gv07HXmSc9cgV/vYdpXbwaD0/YihBPJ0G3Zj g3Tc+SelcvFn/rDObcrJgh7zv2Q8qN/hytUmzx2nfnoa1dCEjzkpPfmeXIp0oiTb2PCAArAz3jOP Ti6z7zJXuOVHUaVLWXbrmDLkV3OV1u/KLZPJHYbv0Ijxbhch1HHpoVzZ0OIqh7fqimKZppOv8Sv1 bFI/Jl/4ODpYdPYxhDySSfnWBsyKSelJx7GkuUZYeTaeA0WZUDBM+9YajTykB296+WCmDn2UCzia WTJHWz/ssls6PkauNDNe5INelognGznKn79soBgQcd9a/UFRvqqEiqWLx26jl3zct42BryBt6jyy V59UyE29dBrLQTPVM6o2UV+XNLM65DF5jJzurVjGnuOdL28jJvgJPDrbzlMO2Bs3r3ci7uixw9Di tAK01WvG2sbt2Fya6qHYtb1iaWLQnDxzAuP1aayq8Dz3QIoOcekjIJDdOY5TAka9EumrgTD1i8E/ 7pYc5z4S0haaQloeBOt+VkEH7OItMp5wN092T7C10tIO8hTcn/SdcvnuxelpHEgbN7SFBo019pjY VQZr2KjTL7NCkV9oWzNtnr3+ocivMeRcsLmGNLGbsW6bn3GO43f6C/RYfZ50jEm9gmExgP6YduN8 w3hJDL4a6xln8CokQGmutk/LKAZmrZClEl7CdtENeZSv/kRbawdZyp/PxP/s296m3xnO1HoCmi8E TzibIoL1JMYjmIcOywGaH4XQYBmwgIIbejk5zpAY5ThGEafOidKUpMyOz8Q/E6uxB2wbiDlAMFgM OIPBM1/iTcDopJWgaurxd7KLwHPFzjMGGFaDr+StcTICPKwDssams8awCA6AV1Ktd5LbFV0nsSHq WCY9TqZXI1FX7ZYFAdO4wGLaMUlGR17wnHhCdPQwaD0dx78NjO8D54kbPrqor/J1IkEo6Otgr6hL jj14S9tGJE0+kuMzwS2ONuWLsvGbsDLWNsIaHBHjgHIASzbhuabfe7XA2WnUSQFvZ2Sc0AowVYSS L/aW83Ew54kEg9uJzLDhN/4GtH6IJV+7fW0EFDogz3c1cKrxr1OQloRHnwhbMPoTuOygvYpFiKBj J12gOQ0KAsoR/iRcd/MntGapBjDg6wP9WgMByKSvdYjCSTpUK7ONWx38NHGx1JMBFvBVo2N/Visr W4gjAxDrpEwhJk8+xaDKwl8yxkGWQo/aFmDKZ0uQnP5T9xIMOLY2rdxGfCWjh8Bqp2yBvtoB8GKS n/aH4JRNG8IPKF5SA8boNs5WTMRTXrEbeY2NOjLjkn2jQ/putWGtCM1VliYeoIcyDanxo/ops8B6 BeNaIKXkyFPoYok2zFbaCbjoUN5Zc2OQnPWQK1Yw6eOSOtlqaoX0/kkH6A5gfNe2J3o8P1CHD7Xp hLO6GJRDc/en8S0ty7RbfrcAybRFV43IHVRwXEVwQqSzKlJn7hsbKb02oH7Hk0HHqs6+HaO5a3IO ZXu8FN8SdlNVETW4coCIS+BBuQN+aap8Ztl5gib9eFHkb4SgtLfYYm0BJH8EoS0hNnVITx0jWX6V 486Nz7evvPX29htMRF9/9ZUeRqU7HXhkJ3S6cP4c8swTGL2Se5pJ1wnexyjMEa50qoq9z4qbB3eR Ct2OcCXW9zYeOexEcdopxYj5ZHuJifV/8c//s+0XP/9gu8ZV2YsXL26nuLLqPVpnuJL77lffKWZ8 wvKNmw9YmnZ0O3X2NK8vukpcHNp+/rNfbJc/en+7cPHC9sqLF3l/7Rvb80x2z507sx1jOfxD+F35 /PPtBz95jyXSV8l7D7ZnmeCe5R7i09BxsvvSSy+1dP6zS5e269jB3Hhjv+/JB344EXT1y0e//GD7 6ttvMPE/wUOwWMb3+B5lv6DdclLg0PHtIybdPlTrGa6yuj1hkGT/bHwbu53cwh/rISFOQHWDtnQ7 Tjx58oBT2dt5Jv2vnDmy/c47L28vMhm/76CC+jO8WuR9Jvb/7mOWe986tF09cp2VVgzG6JcfHDkx T6wmz11jOfjDe6/1xOojDEIPHz+Jf+CD/1361wlz4sd+3PudzY3eQ+092E6EmxAjvw/8ugWPB3du caKDdsDHBt0DUNKNk++2A+PWhm404TvzUu0Sfk7ebVqTcSYGzd/8txmnRo3x7CDQY/sYj4OxT3af H8PZcm06eBwbTGzFezTFNV9xIAHg+Wd3Wsmi3fgJuGJST7DsPD7hTL5Yk9fyFu0ynvAzz9qWhie5 m/yQDAhoO5avdfFWJoV2o8zd2pSHycgOOKUfxLBUoB3DIw45kt6+r6mHDrYwXwDdCTj5cpRcyChK Yyn21wnDg3ogywsUmEHkp072E40Dd5ZzdRAO2hnYZIG5OW6O6dmAtTz7LMmjKw8240HGHDUmMBbZ 9KkVmsyVUPZbTWigne3B8y8fSYBP40DgD8YT7QMlEemTo3wl1shk2cjmsb7XHsa/OquA9LVa6LSN GQuPHZK7sWCjWwlJrb57+X/o9x2dkZsYhJe2S+/QbBeqkCGyl1ijlvGEzLRD7Wi+iCL7QQNkuZ/i luOxdWDBPLXHbnN4qlvjtZjoBsfo2nFvC9BbE8hlV+G9Qmif16YAu/wjuccjS/bxELmv87T+ezzJ n4RQvjQemxxiZll64pquYvRf+FRMvzxxqphLDyea5l/lGZ/AqDjSc/pONcCnzLjRHsI5PpjxjwB8 lF260HnsijFsu3ww9ByXuAIFWgi4xijSOmL8KSu/IEUqXhBUVglHHjkcry471VaQsYk7xIUtZ9BW xRcue7PfMQXaSHnkFyxxbKwGnJ1oE8oQ+g6nHPJe/IGe3AipYglsEDyJrHx3eKuBMeCJ48bXrngg Rh1zjR/wufzhAcmJR8b48tgZw1FY24t/8nYuaZwp2NJHZUan6LpPAxWruMW2QGZXNNhpO64vQLKF 9I52RkfCVIxC7OMsREIpF0k93dqH1mGeZGmAuIwLQMX1i29xvD+kpl6D8768xzxdzXshXbqJy4hf hMNpRzgTcI97cR2MqISDz+ggvA5SRe99bcNBOqFcsS/bMoDWJAYS0JskLB6H8RxNLKA0546DlXAt WTL4eioxv+uMBKQmcPBXwQ6C+mVcmE0nJDwy6UCvJOAo/ahhdaiBYeCnCAIVKMD7BwVkB9fOV4D0 1WEzORo9KZeGylChRSqXP8GnL+2bVmOYq83DcGSlHn5uPnzKvya98Nbeyh59GCibn7mqY4cwibWx QSSHDkjgSJGvnfbgWjYNqkk/dVBTs+hmI20iLYge3m3dmRsxdz/XQfZEWDoEjYdMNS7tI02LlNcW tGSuDrvvDUnbu5/ZkMCzqcZOwoDf4AieJiKIjB7ywSbK3NKg5By8JnZO0qoFhb0VB9KEw0HSN9kL Z7kYyrhiQTiYwHc6Ic03cQ89ExAY6uVE1qgAtTZ5hGf+q3edizbkz/90Gm7JZKCEU9tCJmEt47h7 2IsxZZc2cZWNTAoUsHVfH/BuExvCyRg6FO9gHA4fBxTZDGHFmkQr8cF7YnBaXu3wGOrUywc6pix+ 2MSb+NdG8dOu1DiR15bua0Nld8sOlExCplNSz3zIcmbf7aLsHBtHDspdNuPVFpet3uLJzXbC0j7M pOAJN1CaA7BqPtHKYyf5DC/b9cihLONH27C56ld86rE48E1q+Lo5YK+jZV9aM8DR08Cmo+KCQfvI JsCvzks6+YyyfKP2Mkm6p7GQ0PDVgMqlSknBbzHF9GdyiLjKpaZ+z9/kEo53Zwu79o0vRgPRFNut PE2xLCVkC1Ld+9yH9evf+d72m7/5Ha5mnqVUeebVPMat5Ou4YPD4ya3tzKnLPaHYLuD4cSai3Ld7 //FJeHE2HN/hIiZ+4F+g/MYzXF31SiITLSqUzzbqROgJ6+AesXz4Re7n/f1/8o+2f/nf/6vt1a+z dProKSbdDng2fP9w3rdLDFy/dgP8E+Ac2n7wF3+x/YI5+Fe/+q3t29/4x1wNfZ733zKpRi8fYuXV z2s8WOXjS1e2n3/wi57+feH8xe1FJscXnz/PKyuOMYnjnl1ea/Tzjz5swH2NB2z5qqOjKObVTf1r vLpc3f27XCn+jIdTvfPOG9s5+lUnVl79/dnPr7DM+NB2jSXSPjnaycUMTohTBmDHWVrmfcd373n/ u6tS6MyBOX3yVPdX2U68Wn6XpdWHeJrMG8+e3b7N/c3vvsjnlRdZUn2KuJj8d4rXEL392kvbc+ev bN//6/e3E4d4GBh+ucVE9Q6OfXKDq+vY9caVa9sXTHyff+7F7RZP3H7Akl1DwlgzlI54jzEx56cH ktD3HztykqvpPMTLYAHYSbqT3+cvPMcyw7nH7z59k3a76wSZK8p3vI/v1jVkGJquQOuEeTZwgGdb jWJ9uH2J/GyLDgiNLetn9dTEmcE5MWe79WjHj+a0X0U0nrWzOXg2g8oK6dgGjd1pi8JK1Lbsxm51 E9cT78Lor2lD5q4xl40oOAps1+atgYlUZbbIJaeNtywok3j5K670hn82SYiRBaIixVBRHSyUQ2qs I2tXG8Gx3UulGIvujC/kYm5TtmyDTJJ0W/LNRY0plcaUBxKuPLIZRfrO2y3Ku/IVLCWGN1ZIeB/g QzUfMwpw5B3plhct90+boSPWowBbRA89IOptKCsWGjzHA8aNt6Q7+Iu9v8at/ZI6KxgijAnzr/FD q9KmIzW/QQoNT200sef+gY1UIiUDy8++Us4+iRadHpJxteDK77oqFHVi32M5FW8Q1h9dxQbH8qfk 3ZuYSD9qD/p/dFN2zSA+woYLwujNcSsWxaGsMU+E0TnmUAY5dfh1X3sJ3VgMmBUn9hHCqWOTX8+k A2l9t/rJ9Fc2GCnY39ucIF/nthPzv1eKW4EIKSM1WtjZ5crK4fHKCfJSvsZiCLJgLfNCluV+nN3I FWrs6bvB29W2ok08/TnlKKas/E+fw72uzpOQYSFkF2OBuLFPEl7c/MeOYxAzrycHda65rXhBh/yW wQGMlZiSwN4VzfEBL2RuXAGHGUtPe7FeH9g+UBUbmGMqHVkkLq4+NL7ViU0aacJvJ+VRwH4Fl/Yx nh4xyffY9xI7NvehlOvCprSgHD1llqNR0slKT3jU91HifJDaYPnWQs4/9VXzIo49UW/MKvvMS0QQ dmJA/TrA1rYHT4DYBgHe89kANM6iX3C1ljFJTy47Kv0HwX2NIyP+5VEw1eBBFE5dxNK5h3kqpqMo m7kzag0mkINsmWm4ni4G0ekw0Bs8H+bkMqOjTHA0mGehjvFe3AyB0NKxI9AABR1GXp2RgwYDzmY7 DdmOBa4gB49iNgAHCsI0uQFHHga7jxcXYTQHF1qdYUxy6CIr3WcJQxkzgnbSmGZCNs9Er3sHtdHY RHm8LoEwFNg4PfuX3DgZort+wGFLbea/+pnUYay0c/8CZQW5ZfC12olrNoah+iH2AU0KeiASxZWb KCSgHQ8aszg6V3yDi98mPNLnT5majOz6aRdjwM4kftnCgqFZh5McwCk+3FYCGl30nZ2QgkIbvAde DYaoS/IsRqKRz1//jCmIPdHHux/jZxyAVwNAntEBHOGxkbbMjjDJz/jAx9orlTwKDupc8jdJiYEN 9ZECyh3tpMLqyp6o7BMn2Qdc+EjRzZh1q2GrCHVuDU7lCR3ralP7/lDVx9ZhEWR3YJbNgdFZxowf YZXHjjtDuR9/beDEOs9GR7hELz7NKzZraECzRCtN/S0//tZZy/CI5+SsJsniCylwpy7FtAH46aWs bCZIX1VTW87Hmow/RKv9qKRyVApCdjSWLDZBkTsUXLgMPnYB4UBnd7VKdCGs3g6ca7N73lEPdTOe l82lV74RG/rdV6yt2RfWZTkPSN5+vL/y8Q14uBZ810O+0h35qHMQBp6yjezydFKvzEEPKCVt8ZlB ZvpAqriCvjlL0jnc31FyTEAoGcsODKdAOCEFxHbhVcTX2GvkseNVtgQMVnsYS6FYXKmWnBhzz61v 88IuR8LttqyzTF6x/AN+CAFmGWj8ltOpsCU+4L7QF7hC+nv/6B9wj+xpTi7c7enL5u01OekdvSDP rRCPuI/2Pk9Rpq0d80rpc9j6LPZ6iX7EX64S3r8J48+ZmD273TzKEuXrn23HpUf/k/7GMX+mqFYo HX+yfevr72xvvPbi9sd/9aPtu9/5znaBK7ofX7q9/cmf/DmTLO5d5T5j+4ITTKrOseT6tV9/e3v1 lRe2ixdYuoxVbl67xr2817fnnr/Ag1QOb79ksvt3P/3p9smlD7bXv/K17Vtvvb15n66vLrrDMu5P L3/WcrUHTG57CjJtzqXaLe8jdr3eqrHra9DdNnmEp0h/8QVLmnktxws8Tfr06QfbSy+/yIOyHm2X f/5pOceVBYwtGnzMwBQa2No80L3PDCpdhvwMQKd52FT3dXGFkWu521deObu9fPHcdvHsM9u7589v r718YXuOe3ddleUAwIGGcXOSvvG7L53f7nH/8w+u3toOnzy73cKPH/7yl9A8xtJneGKjeyx9/go2 /eijj5j4X2IZ9yniYXKDV1CMKSe/a8BpLNkVqbfx4qqu49yzfeK4r6SaCPRKiPbqCjjt0SXjvi7K vuIeS6h9yNjNGzfx1008jB2x6RFolI/lLW2UqL1CtTyDfW3nBattQl4GLp9ud9rlmXLasn0fbbOT PsRVkpnIROVjTm1Nm8wcA1ROzNluOBC+cQP1Sw79e5AbkFte65jdjvuZ3eoWHeFmHDI40lwfc5/8 n+Ia+0+3siTwhARtB/8GODIKZV7wz/812ZWXW4NW6rMDyYbdKde+IrDV32JHfSzf9KxceGFGnlLY IkCpsOlgn2YlJcrS1o99gxX6dPTO1sKkIOX82s6bYLqPjRVrQKo8oCfJZM7/o392BVgd7HvTOzeP dtTsOEy0lEEa/NoPS8YYaVVFXIwlIaZ8+d+cqUxLtwbiFNTPY+fsb4wVR5OhkwPa9a/QW7yLr8hp W8w2SkW/fnTno4zlPuSpnxfYjR/HqrZzV5dk/70uOyoXn3wFn/HooKpwcgG/q5n+4xvbtfQwnvT4 GELjP+S37YnUWGHsoW7Gyn98G1tOLDnOnScCX7vOSUkI+9FSTnLXmCb5gMtzS0CJy67y4aQsa9xo uTIqtptoK5bMD/5lC+rywU5XcEDZtIV7xqA25vkI5FyfYpzOSkm9t1w4ftd//llXu/FCg+hjsnSR zrQlsxt8k0LamC/7Ba5AxYcXKwYfysogH4nKN93manDpq3GL/nC8rXbsE8uORdzMheHIzniEsDXG hNDS1fbiyAvy+VRderc89a3QBV47HmaictRbhKRhHRdGzaZN/hVVvtAR1l3HkKqYbejnk1DBwXEc 1LQIPOeTwsvfWNZXXexAL/3pKlpbrkDS5hIIu8D5p9xQ7CSMc80xg8BWJukemIIZZgggNwWlxEms NUaNv5YdGJ4DlXAApCajAKJTVm6yo2X/SY0PGGg6ANAQ/spfji7NilsCoWXs4Wc5TrKzVyHpH2EJ WEqpoHDKg4H8dUjq5oMGMFvOa+KAE7nefKDXUd8tqD4MptycFMi6B6pAycnRcpaGqw55D2P8lpeB UzIGzuA4zlUBJ8TKqUMxSPjiOoCx83RJhELGFz1mAu0ABFgYYBI+NlB2wHOwmE0om8maw0uqPNse c+DgGVHpydgGBtYTrkIntHSBqKOw4cBLb3qsDbOfv/nWYKSW4xqZdLDxyCeO9A1MOSiblJWZXz8c Q3bEmQp0HFhv9LdS3jaoaIHjSVjPxlhXkkA+lZzgHbLZQBtJEzI2FnekfDCQhpb6uMx4bcklFuVa RRlBP+Djk4V72AjlXQkGrtcPAVqD1Je0QO0x8WZ50uzqRjXbydOj6QAGxm916mSEfIkJNwcZ6e8+ unhGkwKxk3VO6ux8pIp8Cm4yXLZWPuGs8LvJFbIBvnvGpK/suAy6D2srwu5eg1YWBCeZ0xlCskpH eQEB3KqXPAaY+JFzBRaC5D8f499tTQ5HLo9NurvfHHiA8NQGHMdT+V0hMu0totAqwQ3VncfIri1g ST1tUObGBSQSi3bxkKtKnlmfOKAc+99lmeVdkvJJJi5PLgs79eNfLIW+ypqEEofOsln+iR9f1vFV LMLQDizG+YTdqgFKLLQNfvQ0thsIqDMftVBG0//e4jvWd3aibtpAOeaknsdAxmREKd2Bb5Eo4tq2 3Zb+7VPoce2+WgGH0PhgyS4dCBD/TRyQzJIgwZeGOSj9keXB/dssaf4nLCXmaiI5xCuS5j1DXvw6 Ufhopwc8ufnY4VNMeN7enuGkw5HDz7Gc7WVWPJ9ncvQiSh9vwvuI99U+efDa9sn7PJTq7mddpTfP H2FpLgL0mQETPPCZufZ5rvb+l//Vf7798f/wPyIvudcVRuy99+Ofbaee5R2+HB2h3b/19de2r7z6 MhPvU0zieNjVZze2n/EgrNPAv/uNb2xXmXS9xxOaf/b+T1jifGH73d/7Z9zb+yxLd+8yKbu3Xbl2 fbvNA1fsG8tf6LnixrcKkPiKJYwxv9pYkWk92uIhD+W6y8OyfuPb6EPS8uSmKn3BpPs0D7lSn/o+ DGi/dZyJvuGtvudOnoYQDwpjUniGwcbLXM0+4qN0HgAAIABJREFUeppJPPVfe/Hc9m2uIHv/9GHk eImHiJ3lidf2WY+YoB7m1ysf+tal+xeA+423ePL02evb1SdHtzuPaBd3b2yXkPsUr246xhLsS+9/ zNLlR9urr7/KFeqbXNHnagX4dEOo59X3fVKAjsWWshOQB5OT4taTzuYi2xcTeiaxXjV4hvcxP+R1 SPafZ84wZafNdtL88XnyJqvCuBJ8g9eXqOtNrgDZ3RkD9iT2KTU32wYBb5xNv2jQKaFxqozYdvln lxEFgDeapw2aQ1r1wW8PtaHKMtDz68APXQdlbtWz31UKYLuykZ+nP4m5FCqTz8gibifxv9znWcgm v9orwO4PDXisY4qSW37W2y4DZFdWX/rT3uUNRp+j6+AetP9kV6chYFw2uVDv/WNdJxI5rr8x0Whr x1L4x3EARoe+ttL/MylStpWzpFm/aTIYpaKv9G7Klo/wk3CO1zTxjInGB/Kxv1h98diaHAiOWq++ UPKVECOeFFInmcrDOqk5FKEgf4k+shKZ5nBktUD4bKYdKHC/9i0dCPVUevWHvuPb+FhBWXCQkWG+ xM/2MxUYPMLLFLqi9NEH0bZgQCGaMvkCPpleNBCMPWmOfhGzpvygDVsOzPHTGlWzz9DW6CTTfXM3 XVPcuqkYGPQBx7/5H4qCVCYoRdpcH84oBhrobJa5x20OntiaTaydeAXsJ4ulo8/dO/d7fRwsB8J6 9ru9iMJsAR/jQHsJZp/duENAtsaswvKxnXmxwicNE4XZTP2UT54pGym+qKhfjiY+w+bZkmM5Sd5x zdzux/icGBNmcp12ckymn/nIW3uLZNvwRx/y12o56jyRMs/9kbp0Bk4L6Y9iRpuCx6FkrAhu6pFv LwuAfVeMtQEfvezKARuY6egKHkOr+KEU8vs2bXzu6bVhGGfYCbs4VzHPecvNffrPB7YtcvZhTkSO DdEVKto2WeXvQTafi1le8HCc7X3fjbNoiAd67mKDBZ7tZS7iKLIw2lYfu3pYubJz5dK2DzJ+YMrH XznH3TkbdVAbQjpduGb+igfhJq8JP8HuDHvgHDwoEJVqV5gzIUYQ75V0q5PDmQ7uuxdOu8HAZS1e hvZJz8EpIHDC9+CSDAt/6ieolQnBl+HkmXP0lM1LugaYperAjoFhxa78dCoTxAaqzpOgT6h0yzDA gl1wmDT9FOictTaw535V5aSDhYf3dxz1vmfk6dK+O/xTnD6P3VFXPkopLZoFwa1eLgufZQMKOh1s 4NEAk2KcrXDSnb29cxw9tFl0S7bsYwt2awxAgDb+mcmVFHdZCdICycsBtJLxMXqDKz5iZh9eZxpb
April 14, 2017 - Present
RV10-Archive.digest.vol-mn
