RV10-Archive.digest.vol-mr
June 23, 2017 - August 11, 2017
      >>>> where you closed the gap?
      >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navig
      >> ator?RV10-List
      >> FORUMS -
      >> eferrer" target="_blank">http://forums.matronics.com
      >> WIKI -
      >> errer" target="_blank">http://wiki.matronics.com
      >> b Site -
      >>           -Matt Dralle, List Admin.
      >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution
Subject: Re: Removing cylinder head flashing
Date: Jun 23, 2017
Bruce, if you will recall the Z channel that is used for stringers in the tail cone. I used that, cut one curve off, to have thin, 1/2 right angles. I cut to width of the louvers. then used Gorilla brand duct tape to tape them in place, just as a temporary trial. I noticed about 20-30 degree drop in CHT. On 6/23/2017 3:37 PM, Bruce Hoppe wrote: > > Kelly, > I have looked at the Anti-Splat cowl flap. What caught my interest is your comment about "putting 1/2" deflector in front of the louvers". Please describe this deflector in a little more detail. If you have a photo, that would be very helpful. > > My main concern has been high CHTs, especially on cylinder #6 on initial climb out. It will usually go above 400F especially in the summer in TN, then drops under 400. At cruise, all CHTs typically are 350-380F or lower depending how far LOP, with #6 still being the hottest. I normally have a 30F CHT range between the hottest land coolest cylinders. One theory is that the air for the oil cooler is diverting cooling air from #6. > > I recently reinstalled the air deflector in front of cyl#2 and put RTV between the cylinders. That helped the temperature spread only a little, but every little bit helps. > > It helped to balance my injectors, including on climb out. Now, all EGTs peak within 0.1GPH. Typically, no problems with oil temp. I have an adjustable damper on the oil cooler, but it only lowers #6 CHT 1 or 2 degrees when I partially close it to raise oil temp by 20 degrees. > > Thanks, > > Bruce Hoppe > RV-10 N720JH > Sent from my iPad > > > > Bruce Hoppe > > Sent from my iPad >> On Jun 23, 2017, at 3:39 PM, Kelly McMullen wrote: >> >> >> Very interesting. I replaced my louvers in front of the exhaust pipes with the Anti-Splat cowl flaps. This was first supported by putting 1/2" deflector in front of the louvers, which made a noticeable improvement. >> with the cowl flaps, temps are a bit lower, maybe as good as with the deflector in front of louvers(which would have been a lot cheaper and easier to stick with). However, where my oil temps had been fine, now mine are like yours. I did the flashing removal, but haven't tried the RTV yet. I just need to get my cockpit flow back to where it was flying the Mooney....cowl flaps open for takeoff and climb. Level off, and then close cowl flaps. Open them up as come into pattern to keep CHTs from climbing again. I may eventually decide to install one of the louvers I removed, right under the oil cooler. >> Your IO-390 cylinders should be perfect...they should be perfect. I don't know if you have priced them, but they are almost double the price of regular 360 angle valve cylinders. >> >>> On 6/23/2017 1:29 PM, Tim Olson wrote: >>> I didn't really have a good way to tell, sorry. The problem is, when I attacked the >>> CHT issue, I did everything at once, so I can't say that one thing was >>> far better than any other. The Cylinder flashing issue was a definite >>> problem though...you could just see it. Funny that my IO-390 cylinders >>> from Lycoming didn't need any work at all. Maybe these days they >>> do a better job, or maybe they do a better job than ECI did. >>> My real remaining thing I'd some day like to improve is Oil temps. >>> Interestingly, it used to be my CHT's that were the issue, not oil temps. >>> Then after fixing the CHT's, now if there is anything that limits me >>> from climbs on hot days it's oil temps. I set my alarm at 216F to come >>> on and get me to do something. I don't ever let it get over 225F >>> without great reason. I may have seen 235F one or two times in >>> 1250 hours. By keeping speeds of 125kts in climb I can almost >>> do whatever I want, but I would prefer to be able to have my oil >>> temps stay under 210F even in 115kt climbs...and always be >>> in the 190's when straight and level. >>> I may just have to get into a small cowl mod to add an extra exit >>> scoop or something under that oil cooler. It's not a highly pressing >>> issue, but would be nice to deal with for any flights out West in >>> the warm months, mainly. >>> Tim >>>> On 6/23/2017 3:13 PM, Kelly McMullen wrote: >>>> >>>> I had good luck with one of my 3/32 (#40) drill bits, 6" long. Just made multiple passes and then worked it back and forth somewhat. I can't say I have seen significant difference, but with OAT around 100 for 9 am takeoff, and 80 at 6500 and 70 at 9500..I'll have to wait for some more normal temps to compare. >>>> Tim, did you notice much benefit from the RTV between the cylinders, where you closed the gap? >> >> >> > > > > > ________________________________________________________________________________
From: "Greg McFarlane" <grbcmcfarlane(at)gmail.com>
Date: Jun 24, 2017
I was concerned about high CHT & Oil temps in local RV10s here so I was very lucky to get some details from Deems about his mod when I was fitting my engine, I took his idea a bit further and I'm pleased to say that it has worked out extremely well. I can keep CHT under 350 and oil at 180. (we have mid 30 to 40*C conditions at times) As the pics show I added an intake for the oil cooler to the bottom cowl, a manifold then takes the air to the left of the front wheel slot (1/2" below the fab) and then via a 4" scat to the vertically mounted standard oil filter. Air is regulated by a push/pull butterfly valve at the oil cooler (Not visible) and exhausts out of the oil cooler couple inches from the side of the cowl. No air is bled off the top of the engine so all is available for CHT cooling. CHTs are even on all cylinders. I didn't fit the flimsy louvres or cowl flaps but installed letterbox vents on both sides. I did fit a "cowl flap" on the side of the cowl next to the oil cooler because I didn't know if the air flow through the cooler would be enough, but this hasn't been needed so I've now permently fixed it shut. One downside to the mod is that the scat hose must be removed before taking the bottom cowl off, not a big deal, the scat is a push fit into the manifold and is secured by hand with a -3 bolt into a nut plate. Anyway, not really about CHT flashing but related to the cooling discussion. Cheers from Western Australia Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470436#470436 Attachments: http://forums.matronics.com//files/img_1215_208.jpg http://forums.matronics.com//files/img_1212_397.jpg ________________________________________________________________________________
Date: Jun 24, 2017
Subject: Nose gear leg fairing - tip
I've got 7.5 hours on the plane and about 2 weeks ago I decided to take it down for a bit to put the pants and fairings on. That nose leg fairing was a bear for me. The pin just didn't want to slide into the hinge halves. And when I did get it sliding, keeping the two halves nested wasn't easy..... especially the further down it went. Then it dawned on me.... I could take another hinge pin and slide it up from the bottom as far as I could get it to align that bottom half. While at the same time inserting the pin front the top. I couldn't push the alignment pin out with the top pin, but I could pull the alignment pin out and inch or two at a time and then chase it with the top pin. It's still not super slick to slide in, but it sure did take away the frustration and that's 99% of the battle IMO. Just sharing so others might use it later on to fit their fairings. Nose wheel pant has to be removed to do it. Worked well. Phil Sent from my iPhone ________________________________________________________________________________
Date: Jun 24, 2017
Subject: Re: Nose gear leg fairing - tip
I use Boelube (solid) on my pins for the same reason. One of my cowl pins is tight and the lube helps with the effort. Just another option to help. Sent from my iPad > On Jun 24, 2017, at 1:23 PM, Phillip Perry wrote: > > > I've got 7.5 hours on the plane and about 2 weeks ago I decided to take it down for a bit to put the pants and fairings on. > > That nose leg fairing was a bear for me. The pin just didn't want to slide into the hinge halves. And when I did get it sliding, keeping the two halves nested wasn't easy..... especially the further down it went. > > Then it dawned on me.... I could take another hinge pin and slide it up from the bottom as far as I could get it to align that bottom half. While at the same time inserting the pin front the top. > > I couldn't push the alignment pin out with the top pin, but I could pull the alignment pin out and inch or two at a time and then chase it with the top pin. > > It's still not super slick to slide in, but it sure did take away the frustration and that's 99% of the battle IMO. > > Just sharing so others might use it later on to fit their fairings. Nose wheel pant has to be removed to do it. > > Worked well. > > Phil > > Sent from my iPhone > > > ________________________________________________________________________________
Date: Jun 24, 2017
Thanks for all of the advice on the flashing! This list is a great resource. David On Fri, Jun 23, 2017 at 11:53 AM, Tim Olson wrote: > > I found a small thin file at our local farm store that fits nicely if the > gap isn't completely closed. > I song have the info but it was maybe 6-8" long and maybe at most 1/2" > wide and about 1/16" thick or so. That worked well. > Tim > > > On Jun 23, 2017, at 11:38 AM, David Carr wrote: > > > > Hi list, > > > > What are your favorite techniques/tools for removing the cylinder head > flashing (near the top spark plug)? > > > > So far I've discovered Tim's approach using an extension drill like an > end mill and also a suggestion to try modifying a hacksaw rod blade into > long rotary burr. > > > > Thanks for your input, > > David > > ________________________________________________________________________________
Subject: AOG in Florida--Need an assist
Date: Jun 25, 2017
Folks the Display Unit for my Vertical Power VP-200 has died, at least partially. If I cycle the power I can see the very very faint VP-200 startup logo and the startup systems check annunciations (they are so faint as to be illegible but I know what they are) but then a blank screen with the Soft Key label boxes barely visible but the labels themselves are illegible. The DU seems to still be controlling power pins and the control unit and the switch panel all seem to be functioning fine although it's impossible know 100% for sure without a full-up display. Does anyone have a Display unit I could borrow/rent/buy, at least to get me home? I'll be here at Pompano Beach until July 1st and across the state over in Fort Myers until July 9th (so I'd like to get it fixed by then) I'll pay for overnight shipping. Email me at tsts4us AT gmail dot com or text/call me 703-595-5453. Thanks! -------- Todd Stovall aka Auburntsts on EAA, AOPA, and VAF RV-10 N728TT -- Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470466#470466 ________________________________________________________________________________
Date: Jun 25, 2017
Subject: Re: AOG in Florida--Need an assist
Hey Todd, I don't have a VP-200 screen but I live close by at 64FA. I'll be home on the 28th or so. I have a bunch of tools, if you need anything let me know. Sounds like the backlight in your screen is out. If you can source the lcd screen or even just the backlight I can repair it for you. Lenny > On Jun 25, 2017, at 4:17 PM, tsts4 wrote: > > > Folks the Display Unit for my Vertical Power VP-200 has died, at least partially. If I cycle the power I can see the very very faint VP-200 startup logo and the startup systems check annunciations (they are so faint as to be illegible but I know what they are) but then a blank screen with the Soft Key label boxes barely visible but the labels themselves are illegible. The DU seems to still be controlling power pins and the control unit and the switch panel all seem to be functioning fine although it's impossible know 100% for sure without a full-up display. > > Does anyone have a Display unit I could borrow/rent/buy, at least to get me home? I'll be here at Pompano Beach until July 1st and across the state over in Fort Myers until July 9th (so I'd like to get it fixed by then) I'll pay for overnight shipping. Email me at tsts4us AT gmail dot com or text/call me 703-595-5453. > > Thanks! > > -------- > Todd Stovall > aka Auburntsts on EAA, AOPA, and VAF > RV-10 N728TT -- Flying > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470466#470466 > > > > > > > > > ________________________________________________________________________________
Date: Jun 25, 2017
Thanks Lenny -- if I can't a new DU or backlight I might need some help with some tools and 14-20 ga wire as I'm already working a worst case back-up plan to bypass the CU and get power to all of the necessary systems required to safely get home. -------- Todd Stovall aka Auburntsts on EAA, AOPA, and VAF RV-10 N728TT -- Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470471#470471 ________________________________________________________________________________
Date: Jun 25, 2017
Lenny, If I open the DU's case, is the backlight or screen part numbers something I could identify without an electronic's background? -------- Todd Stovall aka Auburntsts on EAA, AOPA, and VAF RV-10 N728TT -- Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470474#470474 ________________________________________________________________________________
Date: Jun 25, 2017
The backlight is usually inside the lcd frame, on the side. Try to get the part number from the LCD then you can see the size of the backlight, and order an aftermarket replacement. There's a remote possibility of the inverter being bad, which is the driver of the backlight. Usually the backlight burns out though. Lenny > On Jun 25, 2017, at 7:03 PM, tsts4 wrote: > > > Lenny, > If I open the DU's case, is the backlight or screen part numbers something I could identify without an electronic's background? > > -------- > Todd Stovall > aka Auburntsts on EAA, AOPA, and VAF > RV-10 N728TT -- Flying > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470474#470474 > > > > > > > > > ________________________________________________________________________________
Subject: VP-200 Export Software Settings
Date: Jun 26, 2017
Can someone tell me on a VP-200 from the SETUP Menu, after you scroll and select "Software and Settings", which soft-key is the one labeled" "EXPORT"? Mark Olson is sending me his backup DU but it will save me a bunch of time if I can use a thumb drive to configure his DU to my system. Unfortunately, I don't have my settings file with me (just the manuals and my LPW). So I'm going to basically attempt an export in the blind but I need to know which SK is the one for the export as the manuals don't have a screen shot for he Software and settings page. -------- Todd Stovall aka Auburntsts on EAA, AOPA, and VAF RV-10 N728TT -- Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470490#470490 ________________________________________________________________________________
Date: Jun 26, 2017
Subject: Re: VP-200 Export Software Settings
Plug in the new DU and go through the menus on it then plug your old unit in and follow the same process. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Jun 26, 2017, at 6:37 AM, tsts4 wrote: > > > Can someone tell me on a VP-200 from the SETUP Menu, after you scroll and select "Software and Settings", which soft-key is the one labeled" "EXPORT"? > > Mark Olson is sending me his backup DU but it will save me a bunch of time if I can use a thumb drive to configure his DU to my system. Unfortunately, I don't have my settings file with me (just the manuals and my LPW). So I'm going to basically attempt an export in the blind but I need to know which SK is the one for the export as the manuals don't have a screen shot for he Software and settings page. > > -------- > Todd Stovall > aka Auburntsts on EAA, AOPA, and VAF > RV-10 N728TT -- Flying > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470490#470490 > > > > > > > > > ________________________________________________________________________________
Date: Jun 26, 2017
jesse(at)saintaviation.co wrote: > Plug in the new DU and go through the menus on it then plug your old unit in and follow the same process. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > > > On Jun 26, 2017, at 6:37 AM, tsts4 wrote: > > > > > > > > Can someone tell me on a VP-200 from the SETUP Menu, after you scroll and select "Software and Settings", which soft-key is the one labeled" "EXPORT"? > > > > Mark Olson is sending me his backup DU but it will save me a bunch of time if I can use a thumb drive to configure his DU to my system. Unfortunately, I don't have my settings file with me (just the manuals and my LPW). So I'm going to basically attempt an export in the blind but I need to know which SK is the one for the export as the manuals don't have a screen shot for he Software and settings page. > > > > -------- > > Todd Stovall > > aka Auburntsts on EAA, AOPA, and VAF > > RV-10 N728TT -- Flying > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=470490#470490 > > > > > > > > > > > > > > > > > > > > > > > Yes that will work but I was hoping to do this while I've got time to kill before the spare DU arrives. -------- Todd Stovall aka Auburntsts on EAA, AOPA, and VAF RV-10 N728TT -- Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470493#470493 ________________________________________________________________________________
Date: Jun 26, 2017
Todd, Try holding a flashlight up close to the screen. You might be able to read it. David On Mon, Jun 26, 2017 at 8:10 AM, tsts4 wrote: > > > jesse(at)saintaviation.co wrote: > > Plug in the new DU and go through the menus on it then plug your old > unit in and follow the same process. > > > > Jesse Saint > > Saint Aviation, Inc. > > 352-427-0285 > > jesse(at)saintaviation.com > > > > Sent from my iPad > > > > > > > On Jun 26, 2017, at 6:37 AM, tsts4 wrote: > > > > > > > > > > > > Can someone tell me on a VP-200 from the SETUP Menu, after you scroll > and select "Software and Settings", which soft-key is the one labeled" > "EXPORT"? > > > > > > Mark Olson is sending me his backup DU but it will save me a bunch of > time if I can use a thumb drive to configure his DU to my system. > Unfortunately, I don't have my settings file with me (just the manuals and > my LPW). So I'm going to basically attempt an export in the blind but I > need to know which SK is the one for the export as the manuals don't have a > screen shot for he Software and settings page. > > > > > > -------- > > > Todd Stovall > > > aka Auburntsts on EAA, AOPA, and VAF > > > RV-10 N728TT -- Flying > > > > > > > > > > > > > > > Read this topic online here: > > > > > > http://forums.matronics.com/viewtopic.php?p=470490#470490 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Yes that will work but I was hoping to do this while I've got time to kill > before the spare DU arrives. > > -------- > Todd Stovall > aka Auburntsts on EAA, AOPA, and VAF > RV-10 N728TT -- Flying > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470493#470493 > > ________________________________________________________________________________
Subject: Re: Eclipse travel
Date: Jun 27, 2017
Update to my post, above. Grant County airport (John Day, OR) has sold out all its parking spaces. The airport will be closed around the eclipse to all but those with a reserved tie down spot. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470529#470529 ________________________________________________________________________________
Date: Jun 28, 2017
Subject: Auto Response: RV10-List Digest: 1 Msgs - 06/27/17
Thank you for your email! Unfortunately, I will checking email VERY sporadically but I will get back to you when I am able. Thanks, David ________________________________________________________________________________
Date: Jun 28, 2017
Yet another reason that some of us who live within an hour or so of RV-10 flying time from the path of totality are planning to lift off about 1.5 hrs before the event and loiter on the totality centerline at 13.5k or 15.5k for the event. Unless there is one of those pesky 25,000 ft. overcasts in which case we save the fuel bucks and watch it on TV. Good to have ADS-B out and in installed; expecting a lot of traffic on the display that day, but hopefully not too much in the mid-teen altitudes. -Dan Masys Sequim, WA > Subject: RV10-List: Re: Eclipse travel > From: "Bob Turner" <bobturner(at)alum.rpi.edu> > > > Update to my post, above. Grant County airport (John Day, OR) has sold out all > its parking spaces. The airport will be closed around the eclipse to all but those > with a reserved tie down spot. > > -------- > Bob Turner > RV-10 QB ________________________________________________________________________________
Date: Jun 29, 2017
We're back in business thanks to Mark Olson. Not only did he graciously ship me his backup screen and provided me with instructions to assist me in exporting my config file, he's extending me the loan of his DU through Oshkosh if I can't get mine repaired in time. I can't thank him enough!!!!! This is a beautiful sight: -------- Todd Stovall aka Auburntsts on EAA, AOPA, and VAF RV-10 N728TT -- Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470584#470584 ________________________________________________________________________________
Date: Jun 29, 2017
digidocs wrote: > Todd, > > Try holding a flashlight up close to the screen. You might be able to read it. > > > David > > > On Mon, Jun 26, 2017 at 8:10 AM, tsts4 wrote: > > > > > > > jesse(at)saintaviation.co (http://saintaviation.co) wrote: > > > Plug in the new DU and go through the menus on it then plug your old unit in and follow the same process. > > > > > > Jesse Saint > > > Saint Aviation, Inc. > > > 352-427-0285 (tel:352-427-0285) > > > jesse(at)saintaviation.com (jesse(at)saintaviation.com) > > > > > > Sent from my iPad > > > > > > > > > > On Jun 26, 2017, at 6:37 AM, tsts4 wrote: > > > > > > > > > > > > > > > > Can someone tell me on a VP-200 from the SETUP Menu, after you scroll and select "Software and Settings", which soft-key is the one labeled" "EXPORT"? > > > > > > > > Mark Olson is sending me his backup DU but it will save me a bunch of time if I can use a thumb drive to configure his DU to my system. Unfortunately, I don't have my settings file with me (just the manuals and my LPW). So I'm going to basically attempt an export in the blind but I need to know which SK is the one for the export as the manuals don't have a screen shot for he Software and settings page. > > > > > > > > -------- > > > > Todd Stovall > > > > aka Auburntsts on EAA, AOPA, and VAF > > > > RV-10 N728TT -- Flying > > > > > > > > > > > > > > > > > > > > Read this topic online here: > > > > > > > > http://forums.matronics.com/viewtopic.php?p=470490#470490 (http://forums.matronics.com/viewtopic.php?p=470490#470490) > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Yes that will work but I was hoping to do this while I've got time to kill before the spare DU arrives. > > > > -------- > > Todd Stovall > > aka Auburntsts on EAA, AOPA, and VAF > > RV-10 N728TT -- Flying > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=470493#470493 (http://forums.matronics.com/viewtopic.php?p=470493#470493) > > > > > > > > > > > > > > =================================== > > -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List > > =================================== > > FORUMS - > > eferrer" target="_blank">http://forums.matronics.com > > =================================== > > WIKI - > > errer" target="_blank">http://wiki.matronics.com > > =================================== > > b Site - > > -Matt Dralle, List Admin. > > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > > =================================== > > > > > > > > > Thanks David -- the flashlight trick worked, at least enough for me to feel my way through the menu options and get what I needed. -------- Todd Stovall aka Auburntsts on EAA, AOPA, and VAF RV-10 N728TT -- Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470585#470585 ________________________________________________________________________________
Subject: Rv10 yaw damper
Date: Jun 29, 2017
Ever since Dynon came out with the Y/D option for the Rv10, i have been interested. As I have investigated the prospect, however, there is something a bit odd about the issue that I would like to clarify before I commit. Dynon openly markets their part of the package for both the 10 and the 14. Dynon sells the servo and the control arm kit for the package and tells you that you have to get the "bracket kit" from Van's. This is the part where it seems a little strange. When you contact Van's about a bracket kit for the yaw damper, they will tell you that they have a kit and that it sells for $160. That in its own right seems high by Van's standards for a servo bracket when their other servo brackets sell for $118, but that's not the primary issue. What seems odd to me is that Van's will tell you that the bracket kit they sell is for the RV14. Hmmm. They will tell you that the bracket "should" be able to be used for a 10 "with some modification". If you ask if the are instructions included for the 10 modification they emphatically say no. This doesn't seem right to me. There are at least 10 times the rv10's out there than 14's. Because of the whole theory of yaw dampening anyway, it seems like the bulk of the benefit would be for the rear pax in the 10. Even as the most expensive model in the fleet, it stands to reason that the market potential for the 10 is greater for the product. It seems to me that if extensive design and testing work were done to create this for the 14, there must be some artificial reason that it isn't being openly marketed "openly" for the 10. The whole process just seems outside of Van's usual superb way of design and marketing. Like there is something holding them back but they can't say what it is. Hopefully it is something innocuous, but I would like to know before taking the plunge. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470592#470592 ________________________________________________________________________________
Subject: Re: Rv10 yaw damper
Date: Jun 30, 2017
I had the same initial thoughts as you but, two weekends ago I installed it anyway after assurance from Vans and Rob at AFS (who has been flying with ti for over a year he said) that the Vans kits would work. I am happy to report everything worked out well. The bulk head for the -14 and the -10 is apparently the same in that area so it fits OK. The yaw damper works great, but I do have to admit it is a bit pricey after Vans kit, Dynon tiller arm (150.00), and new servo. It added about four pounds to the plane which was not a huge deal for me. Bottom line every thing install pretty easy....the Vans bracket kit essentially bolts onto existing bell crank brackets and you will have to run new ground and power to new servo but can share serial and data lines with elevator servo and then you are good to go and a short calibration procedure. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470607#470607 ________________________________________________________________________________
Date: Jun 30, 2017
SW50ZXJlc3RpbmcgZGlzY3Vzc2lvbi4gwqBEb2VzIGFueW9uZSByZWFsbHkgbmVlZCBpdD8KSSBw bGFuIG9uIHVzaW5nIGEgUkMgc2Vydm8gaG9va2VkIHRvIHRyaW0gaGluZ2Ugb24gcnVkZGVyIChi ZWNhdXNlIEkgY2FuKSAuLi4uLiBhbmQgaGFkIG5vdCBoZWFyZCBvZiB5YXcgZGFtcGVyIC4uLi4u Ckxpbm4KClNlbnQgZnJvbSBTYW1zdW5nIHRhYmxldCBjcnVpc2luZyBvbiB0aGUgQWxsdXJlIE9m IFRoZSBTZWFzLgoKLS0tLS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLQpGcm9tIG1oZWFs eWRkcyA8bWhlYWx5ZGRzQGdtYWlsLmNvbT4gCkRhdGU6IDA2LzMwLzIwMTcgIDc6NDIgQU0gIChH TVQtMDU6MDApIApUbyBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbSAKU3ViamVjdCBSVjEwLUxpc3Q6 IFJlOiBSdjEwIHlhdyBkYW1wZXIgCiAKLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTog Im1oZWFseWRkcyIgPG1oZWFseWRkc0BnbWFpbC5jb20+CgpJIGhhZCB0aGUgc2FtZSBpbml0aWFs IHRob3VnaHRzIGFzIHlvdSBidXQsIHR3byB3ZWVrZW5kcyBhZ28gSSBpbnN0YWxsZWQgaXQgYW55 d2F5IGFmdGVyIGFzc3VyYW5jZSBmcm9tIFZhbnMgYW5kIFJvYiBhdCBBRlMgKHdobyBoYXMgYmVl biBmbHlpbmcgd2l0aCB0aSBmb3Igb3ZlciBhIHllYXIgaGUgc2FpZCkgdGhhdCB0aGUgVmFucyBr aXRzIHdvdWxkIHdvcmsuIEkgYW0gaGFwcHkgdG8gcmVwb3J0IGV2ZXJ5dGhpbmcgd29ya2VkIG91 dCB3ZWxsLiBUaGUgYnVsayBoZWFkIGZvciB0aGUgLTE0IGFuZCB0aGUgLTEwIGlzIGFwcGFyZW50 bHkgdGhlIHNhbWUgaW4gdGhhdCBhcmVhIHNvIGl0wqAgZml0cyBPSy4gVGhlIHlhdyBkYW1wZXIg d29ya3MgZ3JlYXQsIGJ1dCBJIGRvIGhhdmUgdG8gYWRtaXQgaXQgaXMgYSBiaXQgcHJpY2V5IGFm dGVyIFZhbnMga2l0LCBEeW5vbiB0aWxsZXIgYXJtICgxNTAuMDApLCBhbmQgbmV3IHNlcnZvLiBJ dCBhZGRlZCBhYm91dCBmb3VyIHBvdW5kcyB0byB0aGUgcGxhbmUgd2hpY2ggd2FzIG5vdCBhIGh1 Z2UgZGVhbCBmb3IgbWUuIEJvdHRvbSBsaW5lIGV2ZXJ5IHRoaW5nIGluc3RhbGwgcHJldHR5IGVh c3kuLi4udGhlIFZhbnMgYnJhY2tldCBraXQgZXNzZW50aWFsbHkgYm9sdHMgb250byBleGlzdGlu ZyBiZWxsIGNyYW5rIGJyYWNrZXRzIGFuZCB5b3Ugd2lsbCBoYXZlIHRvIHJ1biBuZXcgZ3JvdW5k IGFuZCBwb3dlciB0byBuZXcgc2Vydm8gYnV0IGNhbiBzaGFyZSBzZXJpYWwgYW5kIGRhdGEgbGlu ZXMgd2l0aCBlbGV2YXRvciBzZXJ2byBhbmQgdGhlbiB5b3UgYXJlIGdvb2QgdG8gZ28gYW5kIGEg c2hvcnQgY2FsaWJyYXRpb24gcHJvY2VkdXJlLgoKCgoKUmVhZCB0aGlzIHRvcGljIG9ubGluZSBo ZXJlOgoKaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD00NzA2MDcj NDcwNjA3CgoKCgoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoCAtIFRoZSBSVjEwLUxpc3Qg RW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0 b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4v U3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3Nl LCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT3C oMKgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdApfLT0K Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0KXy09wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtIE1BVFJPTklDUyBXRUIgRk9S VU1TIC0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBG b3J1bXMhCl8tPQpfLT3CoMKgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20KXy09Cl8t PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC0gTkVXIE1BVFJPTklDUyBMSVNUIFdJ S0kgLQpfLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNzIEVtYWlsIExpc3QgV2lraSEK Xy09wqDCoCAtLT4gaHR0cDovL3dpa2kubWF0cm9uaWNzLmNvbQpfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT3CoMKgwqDCoMKg wqDCoMKgwqDCoMKgwqAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPcKgIFRoYW5r IHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC1NYXR0IERyYWxsZSwgTGlzdCBB ZG1pbi4KXy09wqDCoCAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpf LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PQoKCgo ________________________________________________________________________________
Date: Jun 30, 2017
Thanks Mhealy. Nice to know that it's an easy adaptation. Still seems odd that they can't remove the (useless to 10 owners) electrical connection stuff, reduce the price accordingly, and create a bona fide 10 kit. I would hate to think that they see selling unnecessary material as a revenue generator. Hope your tail is less swishy in the bumps. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470610#470610 ________________________________________________________________________________
Date: Jun 30, 2017
Historically on the the RV-10 the consensus is that it isn't needed. Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> on behalf of Linn Walters Sent: Friday, June 30, 2017 11:21:54 AM Subject: RE: RV10-List: Re: Rv10 yaw damper Interesting discussion. Does anyone really need it? I plan on using a RC servo hooked to trim hinge on rudder (because I can) . .... and had not heard of yaw damper ..... Linn Sent from Samsung tablet cruising on the Allure Of The Seas. -------- Original message -------- >From mhealydds <mhealydds(at)gmail.com> Date: 06/30/2017 7:42 AM (GMT-05:00) To rv10-list(at)matronics.com Subject RV10-List: Re: Rv10 yaw damper I had the same initial thoughts as you but, two weekends ago I installed it anyway after assurance from Vans and Rob at AFS (who has been flying with ti for over a year he said) that the Vans kits would work. I am happy to re port everything worked out well. The bulk head for the -14 and the -10 is a pparently the same in that area so it fits OK. The yaw damper works great, but I do have to admit it is a bit pricey after Vans kit, Dynon tiller arm (150.00), and new servo. It added about four pounds to the plane which was not a huge deal for me. Bottom line every thing install pretty easy....the Vans bracket kit essentially bolts onto existing bell crank brackets and y ou will have to run new ground and power to new servo but can share serial and data lines with elevator servo and then you are good to go and a short calibration procedure. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470607#470607 ________________________________________________________________________________
Date: Jun 30, 2017
Needed? No. Awesome? Heck yes! I decided to install a yaw dampener, because I feared cutting my beautifully straight rudder to accommodate an electric trim tab. It was relatively inexpensive ($800) compared to the rest of the gizmos on the plane and has been amazing in use. Last week we encountered some really bad turbulence coming into Houston and the ball stayed centered no matter how much we we're getting tossed around. In the end, this falls into the personal preference realm. If I were to build another -10 I would do the yaw dampener hands down. Shannon On Jun 30, 2017 12:08 PM, "Bob Leffler" wrote: > Historically on the the RV-10 the consensus is that it isn't needed. > > Get Outlook for iOS > ------------------------------ > *From:* owner-rv10-list-server(at)matronics.com matronics.com> on behalf of Linn Walters > *Sent:* Friday, June 30, 2017 11:21:54 AM > *To:* rv10-list(at)matronics.com > *Subject:* RE: RV10-List: Re: Rv10 yaw damper > > Interesting discussion. Does anyone really need it? > I plan on using a RC servo hooked to trim hinge on rudder (because I can) > ..... and had not heard of yaw damper ..... > Linn > > Sent from Samsung tablet cruising on the Allure Of The Seas. > > > -------- Original message -------- > >From mhealydds <mhealydds(at)gmail.com> > Date: 06/30/2017 7:42 AM (GMT-05:00) > To rv10-list(at)matronics.com > Subject RV10-List: Re: Rv10 yaw damper > > > I had the same initial thoughts as you but, two weekends ago I installed > it anyway after assurance from Vans and Rob at AFS (who has been flying > with ti for over a year he said) that the Vans kits would work. I am happy > to report everything worked out well. The bulk head for the -14 and the -10 > is apparently the same in that area so it fits OK. The yaw damper works > great, but I do have to admit it is a bit pricey after Vans kit, Dynon > tiller arm (150.00), and new servo. It added about four pounds to the plane > which was not a huge deal for me. Bottom line every thing install pretty > easy....the Vans bracket kit essentially bolts onto existing bell crank > brackets and you will have to run new ground and power to new servo but can > share serial and data lines with elevator servo and then you are good to go > and a short calibration procedure. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470607#470607 > > > ========== > Email Forum - > ========== > p; - MATRONICS WEB FORUMS - > ========== > p; - NEW MATRONICS LIST WIKI - > ========== > p; - List Contribution Web Site - > p; -Matt Dralle, List Admin. > ========== > > ________________________________________________________________________________
Date: Jun 30, 2017
Does the yaw damper take care of rudder trim without the automatic trim box? On Fri, Jun 30, 2017 at 12:53 PM, Shannon Hicks wrote: > Needed? No. > > Awesome? Heck yes! > > I decided to install a yaw dampener, because I feared cutting my > beautifully straight rudder to accommodate an electric trim tab. It was > relatively inexpensive ($800) compared to the rest of the gizmos on the > plane and has been amazing in use. > > Last week we encountered some really bad turbulence coming into Houston > and the ball stayed centered no matter how much we we're getting tossed > around. > > In the end, this falls into the personal preference realm. > > If I were to build another -10 I would do the yaw dampener hands down. > > Shannon > > On Jun 30, 2017 12:08 PM, "Bob Leffler" wrote: > >> Historically on the the RV-10 the consensus is that it isn't needed. >> >> Get Outlook for iOS >> ------------------------------ >> *From:* owner-rv10-list-server(at)matronics.com < >> owner-rv10-list-server(at)matronics.com> on behalf of Linn Walters < >> flying-nut(at)cfl.rr.com> >> *Sent:* Friday, June 30, 2017 11:21:54 AM >> *To:* rv10-list(at)matronics.com >> *Subject:* RE: RV10-List: Re: Rv10 yaw damper >> >> Interesting discussion. Does anyone really need it? >> I plan on using a RC servo hooked to trim hinge on rudder (because I can) >> ..... and had not heard of yaw damper ..... >> Linn >> >> Sent from Samsung tablet cruising on the Allure Of The Seas. >> >> >> -------- Original message -------- >> >From mhealydds <mhealydds(at)gmail.com> >> Date: 06/30/2017 7:42 AM (GMT-05:00) >> To rv10-list(at)matronics.com >> Subject RV10-List: Re: Rv10 yaw damper >> >> >> >> I had the same initial thoughts as you but, two weekends ago I installed >> it anyway after assurance from Vans and Rob at AFS (who has been flying >> with ti for over a year he said) that the Vans kits would work. I am happy >> to report everything worked out well. The bulk head for the -14 and the -10 >> is apparently the same in that area so it fits OK. The yaw damper works >> great, but I do have to admit it is a bit pricey after Vans kit, Dynon >> tiller arm (150.00), and new servo. It added about four pounds to the plane >> which was not a huge deal for me. Bottom line every thing install pretty >> easy....the Vans bracket kit essentially bolts onto existing bell crank >> brackets and you will have to run new ground and power to new servo but can >> share serial and data lines with elevator servo and then you are good to go >> and a short calibration procedure. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=470607#470607 >> >> >> >> >> >> >> ========== >> Email Forum - >> ========== >> p; - MATRONICS WEB FORUMS - >> ========== >> p; - NEW MATRONICS LIST WIKI - >> ========== >> p; - List Contribution Web Site - >> p; -Matt Dralle, List Admin. >> ========== >> >> >> >> -- Thanks, Kevin ________________________________________________________________________________
Date: Jun 30, 2017
It works independently of the roll auto trim. At least I'd does on the trutrak system. Shannon On Fri, Jun 30, 2017 at 1:47 PM Kevin Belue wrote: > Does the yaw damper take care of rudder trim without the automatic trim > box? > > On Fri, Jun 30, 2017 at 12:53 PM, Shannon Hicks > wrote: > >> Needed? No. >> >> Awesome? Heck yes! >> >> I decided to install a yaw dampener, because I feared cutting my >> beautifully straight rudder to accommodate an electric trim tab. It was >> relatively inexpensive ($800) compared to the rest of the gizmos on the >> plane and has been amazing in use. >> >> Last week we encountered some really bad turbulence coming into Houston >> and the ball stayed centered no matter how much we we're getting tossed >> around. >> >> In the end, this falls into the personal preference realm. >> >> If I were to build another -10 I would do the yaw dampener hands down. >> >> Shannon >> >> On Jun 30, 2017 12:08 PM, "Bob Leffler" wrote: >> >>> Historically on the the RV-10 the consensus is that it isn't needed. >>> >>> Get Outlook for iOS >>> ------------------------------ >>> *From:* owner-rv10-list-server(at)matronics.com < >>> owner-rv10-list-server(at)matronics.com> on behalf of Linn Walters < >>> flying-nut(at)cfl.rr.com> >>> *Sent:* Friday, June 30, 2017 11:21:54 AM >>> *To:* rv10-list(at)matronics.com >>> *Subject:* RE: RV10-List: Re: Rv10 yaw damper >>> >>> Interesting discussion. Does anyone really need it? >>> I plan on using a RC servo hooked to trim hinge on rudder (because I >>> can) ..... and had not heard of yaw damper ..... >>> Linn >>> >>> Sent from Samsung tablet cruising on the Allure Of The Seas. >>> >>> >>> -------- Original message -------- >>> >From mhealydds <mhealydds(at)gmail.com> >>> Date: 06/30/2017 7:42 AM (GMT-05:00) >>> To rv10-list(at)matronics.com >>> Subject RV10-List: Re: Rv10 yaw damper >>> >>> >>> >>> I had the same initial thoughts as you but, two weekends ago I installed >>> it anyway after assurance from Vans and Rob at AFS (who has been flying >>> with ti for over a year he said) that the Vans kits would work. I am happy >>> to report everything worked out well. The bulk head for the -14 and the -10 >>> is apparently the same in that area so it fits OK. The yaw damper works >>> great, but I do have to admit it is a bit pricey after Vans kit, Dynon >>> tiller arm (150.00), and new servo. It added about four pounds to the plane >>> which was not a huge deal for me. Bottom line every thing install pretty >>> easy....the Vans bracket kit essentially bolts onto existing bell crank >>> brackets and you will have to run new ground and power to new servo but can >>> share serial and data lines with elevator servo and then you are good to go >>> and a short calibration procedure. >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=470607#470607 >>> >>> >>> >>> >>> >>> >>> ========== >>> Email Forum - >>> ========== >>> p; - MATRONICS WEB FORUMS - >>> ========== >>> p; - NEW MATRONICS LIST WIKI - >>> ========== >>> p; - List Contribution Web Site - >>> p; -Matt Dralle, List Admin. >>> ========== >>> >>> >>> >>> > > > -- > Thanks, > Kevin > ________________________________________________________________________________
Date: Jun 30, 2017
Does the AP have to be engaged? Or can it be enabled without engaging the A P? Sent from my iPhone > On Jun 30, 2017, at 1:49 PM, Shannon Hicks wrote: > > It works independently of the roll auto trim. At least I'd does on the tru trak system. > > > Shannon > >> On Fri, Jun 30, 2017 at 1:47 PM Kevin Belue wrote: >> Does the yaw damper take care of rudder trim without the automatic trim b ox? >> >>> On Fri, Jun 30, 2017 at 12:53 PM, Shannon Hicks wr ote: >>> Needed? No. >>> >>> Awesome? Heck yes! >>> >>> I decided to install a yaw dampener, because I feared cutting my beautif ully straight rudder to accommodate an electric trim tab. It was relatively i nexpensive ($800) compared to the rest of the gizmos on the plane and has be en amazing in use. >>> >>> Last week we encountered some really bad turbulence coming into Houston a nd the ball stayed centered no matter how much we we're getting tossed aroun d. >>> >>> In the end, this falls into the personal preference realm. >>> >>> If I were to build another -10 I would do the yaw dampener hands down. >>> >>> Shannon >>> >>>> On Jun 30, 2017 12:08 PM, "Bob Leffler" wrote: >>>> Historically on the the RV-10 the consensus is that it isn't needed. >>>> >>>> Get Outlook for iOS >>>> >>>> From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matr onics.com> on behalf of Linn Walters >>>> Sent: Friday, June 30, 2017 11:21:54 AM >>>> To: rv10-list(at)matronics.com >>>> Subject: RE: RV10-List: Re: Rv10 yaw damper >>>> >>>> Interesting discussion. Does anyone really need it? >>>> I plan on using a RC servo hooked to trim hinge on rudder (because I ca n) ..... and had not heard of yaw damper ..... >>>> Linn >>>> >>>> Sent from Samsung tablet cruising on the Allure Of The Seas. >>>> >>>> >>>> -------- Original message -------- >>>> >=46rom mhealydds >>>> Date: 06/30/2017 7:42 AM (GMT-05:00) >>>> To rv10-list(at)matronics.com >>>> Subject RV10-List: Re: Rv10 yaw damper >>>> >>>> >>>> >>>> I had the same initial thoughts as you but, two weekends ago I installe d it anyway after assurance from Vans and Rob at AFS (who has been flying wi th ti for over a year he said) that the Vans kits would work. I am happy to r eport everything worked out well. The bulk head for the -14 and the -10 is a pparently the same in that area so it fits OK. The yaw damper works great, b ut I do have to admit it is a bit pricey after Vans kit, Dynon tiller arm (1 50.00), and new servo. It added about four pounds to the plane which was not a huge deal for me. Bottom line every thing install pretty easy....the Vans bracket kit essentially bolts onto existing bell crank brackets and you wil l have to run new ground and power to new servo but can share serial and dat a lines with elevator servo and then you are good to go and a short calibrat ion procedure. >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=470607#470607 >>>> >>>> >>>> >>>> >>>> >>>> >>>> ========== >>>> Email Forum - >>>> ========== >>>> p; - MATRONICS WEB FORUMS - >>>> ========== >>>> p; - NEW MATRONICS LIST WIKI - >>>> ========== >>>> p; - List Contribution Web Site - >>>> p; -Matt Dralle, List Admin. >>>> ========== >>>> >>>> >>>> >> >> >> >> -- >> Thanks, >> Kevin ________________________________________________________________________________
Date: Jun 30, 2017
There is another way that's even cheaper. I didn't want to cut my rudder either so I used the stock elevator spring bias system to make a rudder spring bias system. 2 pieces of cable are attached to the rudder at the horn. One goes directly to the spring but the other goes to a pulley and then to the other spring. I mounted the pulley on a bracket bolted to the back of the battery tray/elevator bellcrank box. The stock elevator spring bias assy is not modified and bolts to the bottom skin straddling a stringer. In practice right rudder is not normally needed but long, fast descents need some left. (Another builder uses a spring bias system attached to the rudder pedals.) Albert Gardner RV-10 N991RV Yuma, AZ Shannon Hicks I decided to install a yaw dampener, because I feared cutting my beautifully straight rudder to accommodate an electric trim tab. It was relatively inexpensive ($800) compared to the rest of the gizmos on the plane and has been amazing in use. Shannon ________________________________________________________________________________
From: "RV10(at)TEXASRV10.COM" <rv10(at)texasrv10.com>
Date: Jun 30, 2017
On Garmin, there is a yaw button to engage the yaw system. The yaw system tr ims to release pressure to appropriate required hands off trim. Works fantas tic. Gaylon Koenning > On Jun 30, 2017, at 13:58, Phillip Perry wrote: > > Does the AP have to be engaged? Or can it be enabled without engaging th e AP? > > Sent from my iPhone > >> On Jun 30, 2017, at 1:49 PM, Shannon Hicks wrote: >> >> It works independently of the roll auto trim. At least I'd does on the tr utrak system. >> >> >> Shannon >> >>> On Fri, Jun 30, 2017 at 1:47 PM Kevin Belue wrote: >>> Does the yaw damper take care of rudder trim without the automatic trim b ox? >>> >>>> On Fri, Jun 30, 2017 at 12:53 PM, Shannon Hicks w rote: >>>> Needed? No. >>>> >>>> Awesome? Heck yes! >>>> >>>> I decided to install a yaw dampener, because I feared cutting my beauti fully straight rudder to accommodate an electric trim tab. It was relatively inexpensive ($800) compared to the rest of the gizmos on the plane and has b een amazing in use. >>>> >>>> Last week we encountered some really bad turbulence coming into Houston and the ball stayed centered no matter how much we we're getting tossed aro und. >>>> >>>> In the end, this falls into the personal preference realm. >>>> >>>> If I were to build another -10 I would do the yaw dampener hands down. >>>> >>>> Shannon >>>> >>>>> On Jun 30, 2017 12:08 PM, "Bob Leffler" wrote: >>>>> Historically on the the RV-10 the consensus is that it isn't needed. >>>>> >>>>> Get Outlook for iOS >>>>> >>>>> From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@mat ronics.com> on behalf of Linn Walters >>>>> Sent: Friday, June 30, 2017 11:21:54 AM >>>>> To: rv10-list(at)matronics.com >>>>> Subject: RE: RV10-List: Re: Rv10 yaw damper >>>>> >>>>> Interesting discussion. Does anyone really need it? >>>>> I plan on using a RC servo hooked to trim hinge on rudder (because I c an) ..... and had not heard of yaw damper ..... >>>>> Linn >>>>> >>>>> Sent from Samsung tablet cruising on the Allure Of The Seas. >>>>> >>>>> >>>>> -------- Original message -------- >>>>> >=46rom mhealydds >>>>> Date: 06/30/2017 7:42 AM (GMT-05:00) >>>>> To rv10-list(at)matronics.com >>>>> Subject RV10-List: Re: Rv10 yaw damper >>>>> >>>>> >>>>> >>>>> I had the same initial thoughts as you but, two weekends ago I install ed it anyway after assurance from Vans and Rob at AFS (who has been flying w ith ti for over a year he said) that the Vans kits would work. I am happy to report everything worked out well. The bulk head for the -14 and the -10 is apparently the same in that area so it fits OK. The yaw damper works great , but I do have to admit it is a bit pricey after Vans kit, Dynon tiller arm (150.00), and new servo. It added about four pounds to the plane which was n ot a huge deal for me. Bottom line every thing install pretty easy....the Va ns bracket kit essentially bolts onto existing bell crank brackets and you w ill have to run new ground and power to new servo but can share serial and d ata lines with elevator servo and then you are good to go and a short calibr ation procedure. >>>>> >>>>> >>>>> >>>>> >>>>> Read this topic online here: >>>>> >>>>> http://forums.matronics.com/viewtopic.php?p=470607#470607 >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> ========== >>>>> Email Forum - >>>>> ========== >>>>> p; - MATRONICS WEB FORUMS - >>>>> ========== >>>>> p; - NEW MATRONICS LIST WIKI - >>>>> ========== >>>>> p; - List Contribution Web Site - >>>>> p; -Matt Dralle, List Admin. >>>>> ========== >>>>> >>>>> >>>>> >>> >>> >>> >>> -- >>> Thanks, >>> Kevin ________________________________________________________________________________
Date: Jun 30, 2017
Phil, My set up requires the AP do be engaged for the YD to function. I believe Garmin and TruTrak have a button to engage the YD independently. IN prctice, I fly with AP on 90% of the time, so it works for me. I flew almost my entire phase 1 (40) with it disconnected and the only time, It bothered me was long straight flights where I would have the AP on anyway. OH, that reminds me, My roll servo failed leaving Sun-n-fun this year, so I had to hand fly all the way back to Houston with 45kt headwinds. THAT SUCKED!!!! On Fri, Jun 30, 2017 at 1:58 PM, Phillip Perry wrote: > Does the AP have to be engaged? Or can it be enabled without engaging > the AP? > > Sent from my iPhone > > On Jun 30, 2017, at 1:49 PM, Shannon Hicks wrote: > > It works independently of the roll auto trim. At least I'd does on the > trutrak system. > > > Shannon > > On Fri, Jun 30, 2017 at 1:47 PM Kevin Belue wrote: > >> Does the yaw damper take care of rudder trim without the automatic trim >> box? >> >> On Fri, Jun 30, 2017 at 12:53 PM, Shannon Hicks >> wrote: >> >>> Needed? No. >>> >>> Awesome? Heck yes! >>> >>> I decided to install a yaw dampener, because I feared cutting my >>> beautifully straight rudder to accommodate an electric trim tab. It was >>> relatively inexpensive ($800) compared to the rest of the gizmos on the >>> plane and has been amazing in use. >>> >>> Last week we encountered some really bad turbulence coming into Houston >>> and the ball stayed centered no matter how much we we're getting tossed >>> around. >>> >>> In the end, this falls into the personal preference realm. >>> >>> If I were to build another -10 I would do the yaw dampener hands down. >>> >>> Shannon >>> >>> On Jun 30, 2017 12:08 PM, "Bob Leffler" wrote: >>> >>>> Historically on the the RV-10 the consensus is that it isn't needed. >>>> >>>> Get Outlook for iOS >>>> ------------------------------ >>>> *From:* owner-rv10-list-server(at)matronics.com >>> matronics.com> on behalf of Linn Walters >>>> *Sent:* Friday, June 30, 2017 11:21:54 AM >>>> *To:* rv10-list(at)matronics.com >>>> *Subject:* RE: RV10-List: Re: Rv10 yaw damper >>>> >>>> Interesting discussion. Does anyone really need it? >>>> I plan on using a RC servo hooked to trim hinge on rudder (because I >>>> can) ..... and had not heard of yaw damper ..... >>>> Linn >>>> >>>> Sent from Samsung tablet cruising on the Allure Of The Seas. >>>> >>>> >>>> -------- Original message -------- >>>> >From mhealydds <mhealydds(at)gmail.com> >>>> Date: 06/30/2017 7:42 AM (GMT-05:00) >>>> To rv10-list(at)matronics.com >>>> Subject RV10-List: Re: Rv10 yaw damper >>>> >>>> >>>> >>>> I had the same initial thoughts as you but, two weekends ago I >>>> installed it anyway after assurance from Vans and Rob at AFS (who has been >>>> flying with ti for over a year he said) that the Vans kits would work. I am >>>> happy to report everything worked out well. The bulk head for the -14 and >>>> the -10 is apparently the same in that area so it fits OK. The yaw damper >>>> works great, but I do have to admit it is a bit pricey after Vans kit, >>>> Dynon tiller arm (150.00), and new servo. It added about four pounds to the >>>> plane which was not a huge deal for me. Bottom line every thing install >>>> pretty easy....the Vans bracket kit essentially bolts onto existing bell >>>> crank brackets and you will have to run new ground and power to new servo >>>> but can share serial and data lines with elevator servo and then you are >>>> good to go and a short calibration procedure. >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=470607#470607 >>>> >>>> >>>> >>>> >>>> >>>> >>>> ========== >>>> Email Forum - >>>> ========== >>>> p; - MATRONICS WEB FORUMS - >>>> ========== >>>> p; - NEW MATRONICS LIST WIKI - >>>> ========== >>>> p; - List Contribution Web Site - >>>> p; -Matt Dralle, List Admin. >>>> ========== >>>> >>>> >>>> >>>> >> >> >> -- >> Thanks, >> Kevin >> > ________________________________________________________________________________
Date: Jul 01, 2017
On dynon/AFS system AP has to be engaged for yaw damper to work...at least with the update I have on my AFS. I had a spring based system before installing yaw damper which I kept in place for when not flying with autopilot but MUCH prefer the yaw damper that I recently put it. A necessity no, a bit pricey maybe, but would not go back at this point Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470627#470627 ________________________________________________________________________________
Date: Jul 01, 2017
Any reason the YD servo couldn't use same power and ground as the elevator servo? -sent from the I-droid implanted in my forearm On Fri, Jun 30, 2017 at 4:42 AM, mhealydds wrote: > > I had the same initial thoughts as you but, two weekends ago I installed > it anyway after assurance from Vans and Rob at AFS (who has been flying > with ti for over a year he said) that the Vans kits would work. I am happy > to report everything worked out well. The bulk head for the -14 and the -10 > is apparently the same in that area so it fits OK. The yaw damper works > great, but I do have to admit it is a bit pricey after Vans kit, Dynon > tiller arm (150.00), and new servo. It added about four pounds to the plane > which was not a huge deal for me. Bottom line every thing install pretty > easy....the Vans bracket kit essentially bolts onto existing bell crank > brackets and you will have to run new ground and power to new servo but can > share serial and data lines with elevator servo and then you are good to go > and a short calibration procedure. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470607#470607 > > ________________________________________________________________________________
Date: Jul 01, 2017
No reason at all. For the Dynon servo, you would just need to run an extra w ire for the yellow, so the YD can be turned on/off separately. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Jul 1, 2017, at 9:10 AM, Kelly McMullen wrote: > > Any reason the YD servo couldn't use same power and ground as the elevator servo? > > -sent from the I-droid implanted in my forearm > >> On Fri, Jun 30, 2017 at 4:42 AM, mhealydds wrote: >> >> I had the same initial thoughts as you but, two weekends ago I installed i t anyway after assurance from Vans and Rob at AFS (who has been flying with t i for over a year he said) that the Vans kits would work. I am happy to repo rt everything worked out well. The bulk head for the -14 and the -10 is appa rently the same in that area so it fits OK. The yaw damper works great, but I do have to admit it is a bit pricey after Vans kit, Dynon tiller arm (150 .00), and new servo. It added about four pounds to the plane which was not a huge deal for me. Bottom line every thing install pretty easy....the Vans b racket kit essentially bolts onto existing bell crank brackets and you will h ave to run new ground and power to new servo but can share serial and data l ines with elevator servo and then you are good to go and a short calibration procedure. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=470607#470607 >> >> >> >> >> >> >> ========================= >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= >> >> >> > ________________________________________________________________________________
Date: Jul 03, 2017
Subject: RV-10 Quick Build Kit for sale, finish and fly in less than
a year ! Save $$$$ Hi, I have decided to sell my RV-10 project: Quick build fuselage with doors and cowling nicely mounted Dynon D-100 and D-180 EFIS and EMSrebuilt Hartzell CS PropLycoming IO-540-C 4B5 with 700 hours.=C2-=C2- 6 rebuilt cylinders 0 STOHMuch more, you ca n see it on craigslist: Allentown (Lehigh Valley) PA craigslist:=C2-=C2- general for sale, unde r the title: "Single Engine Aircraft Vans RV-10" Thanks for looking ! ________________________________________________________________________________
Date: Jul 04, 2017
Subject: F-1046 Longeron to F-1005E Gusset Holes
I lined up the F-1046L longeron with the gusset as described on page 29-9, with the longeron flush with the skin. Then, I drilled the holes. The edge distance is terrible, but I can't see what I did wrong. I've searched and found others with the same problem, but no resolutions turn up. The diagram on 29-9 sure acts like these holes will wind up in the middle of the longeron, but I don't see how. Waiting to drill the other side until I can figure out how to avoid the same problem. Looks to me like I should replace the longeron, but I don't know how to do it any differently and still have the longeron flush with the skin. https://goo.gl/photos/J8s8gheQ1GBmUUi1A https://goo.gl/photos/z11vaX6PZt3Zc1w69 Any suggestions? ________________________________________________________________________________
Date: Jul 04, 2017
Subject: Re: F-1046 Longeron to F-1005E Gusset Holes
I don't think you need to rebuild the longeron. Give Vans a call tomorrow a nd send them the photos too. I believe they have developed a repair for th is. IIRC, it involves a gusset. But give them a shout and I'm pretty su re they'll be able to take care of you. At least you noticed it now. Some folks have built on and had to correct i t later after the tail is assembled. Only to have to tear it back apart to f ix it. Sent from my iPhone > On Jul 4, 2017, at 4:16 PM, Berck E. Nash wrote: > > I lined up the F-1046L longeron with the gusset as described on page 29-9, with the longeron flush with the skin. Then, I drilled the holes. The edge d istance is terrible, but I can't see what I did wrong. I've searched and fou nd others with the same problem, but no resolutions turn up. The diagram on 2 9-9 sure acts like these holes will wind up in the middle of the longeron, b ut I don't see how. > > Waiting to drill the other side until I can figure out how to avoid the sa me problem. Looks to me like I should replace the longeron, but I don't know how to do it any differently and still have the longeron flush with the ski n. > > https://goo.gl/photos/J8s8gheQ1GBmUUi1A > https://goo.gl/photos/z11vaX6PZt3Zc1w69 > > Any suggestions? ________________________________________________________________________________
Date: Jul 05, 2017
Thanks, I've got an e-mail out to them with the photos, I'll let you know what they send back. Rebuilding the longeron isn't a big deal. Heck, I can probably bend this one in under half an hour after all the practice with the first four. The bigger deal is that after I build it, I'm not sure what to do to fix the problem. I can line the longeron up so that the holes in the gusset are in the middle, but that's going to create quite a gap to the skins. It looks like a similar situation on the other side. On Tue, Jul 4, 2017 at 8:25 PM, Phillip Perry wrote: > I don't think you need to rebuild the longeron. Give Vans a call > tomorrow and send them the photos too. I believe they have developed a > repair for this. IIRC, it involves a gusset. But give them a shout and > I'm pretty sure they'll be able to take care of you. > > At least you noticed it now. Some folks have built on and had to correct > it later after the tail is assembled. Only to have to tear it back apart > to fix it. > > > Sent from my iPhone > > On Jul 4, 2017, at 4:16 PM, Berck E. Nash wrote: > > I lined up the F-1046L longeron with the gusset as described on page 29-9, > with the longeron flush with the skin. Then, I drilled the holes. The edge > distance is terrible, but I can't see what I did wrong. I've searched and > found others with the same problem, but no resolutions turn up. The diagram > on 29-9 sure acts like these holes will wind up in the middle of the > longeron, but I don't see how. > > Waiting to drill the other side until I can figure out how to avoid the > same problem. Looks to me like I should replace the longeron, but I don't > know how to do it any differently and still have the longeron flush with > the skin. > > https://goo.gl/photos/J8s8gheQ1GBmUUi1A > https://goo.gl/photos/z11vaX6PZt3Zc1w69 > > Any suggestions? > > ________________________________________________________________________________
Date: Jul 06, 2017
Subject: Re: Fuel filter/gascolator screen advice
Many thanks Les. Warm regards Patrick > On 12 Jun 2017, at 06:34, kearney wrote: > > > Hi > > FWIW I put my fuel filters n the wing roots. I did at one point have them under the seats. Under the seats is just a little less inconvenient than the tunnel. Even though I put an access panel in the tunnel, I wanted to be able to inspect the filters quickly and easily. All I need do now is to remove the top root cover and the filters are out in a couple of minutes. > > I also wanted to minimize connections inside the cockpit and near the exhaust. > > I used Earls Performance fuel filters which have worked out quite well. The filters screens are easily removed and cleaned. > > Cheers > > Les > C-GCWZ flying > C-GROK some assembly required > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=469979#469979 > > > > > > > > > ________________________________________________________________________________
Subject: Tire / Brake Life
Date: Jul 07, 2017
Hi I was checking my tire pressure today and started thinking about when I should be replacing my tires / brake pads. Am I correct in assuming that brake pad should be replaced when they are 2/3 worn. The new RAPCO pad I purchased a while ago have a small divot on the end which I assume is a wear indicator. Is this correct? How long should tires last? Is there a good way to tell when they need replacement? Cheers Les C-GCWZ Flying C-GROK some assembly required Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470781#470781 ________________________________________________________________________________
Subject: Re: Tire / Brake Life
Date: Jul 07, 2017
2/3 wear on the pads is about right. You can go as thin as you like as long as you don't start rubbing the disk with the rivets that hold the pads. Tires are your call, as long as the cord isn't showing. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470783#470783 ________________________________________________________________________________
Subject: Elevator Trim Servo
Date: Jul 08, 2017
Doing some T&G last evening in the 10 ... with just me on board, final typically has me full nose up on the trim - even with that, I still need some back pressure ... but that's not the story. Anyway, on roll-out, I was moving the tab back to neutral and realized it was taking a LOT longer to reset than usual. Eventually I determined that it was not moving at all. The trim had stopped in the full nose up (tab down) position. Some troubleshooting after shutdown revealed the mechanism is not jammed, it still gets power - when activated, the unit does some "whirring" - but the jack screw does not move. It appears something INTERNAL to the unit has failed. In all my years flying RV's, I've never heard of a single failure in this manner. Anyone ? Really wish I had used a DB9 or some other quick connect for this ... --Ron ________________________________________________________________________________
Date: Jul 08, 2017
Subject: Re: Elevator Trim Servo
We just replaced one on a -10 on our field. Exactly the same failure after some T&G's in the evening. There was noise but no movement as a gear broke inside the unit. It was ~10 years old, FYI. I suspect this servo gets more use (and high pressures on the mechanisms) than any other servo (Aileron and rudder for those who have rudder trim). Sent from my iPhone > On Jul 8, 2017, at 7:18 AM, Ron Walker wrote: > > > Doing some T&G last evening in the 10 ... with just me on board, final typically has me full nose up on the trim - even with that, I still need some back pressure ... but that's not the story. > > Anyway, on roll-out, I was moving the tab back to neutral and realized it was taking a LOT longer to reset than usual. Eventually I determined that it was not moving at all. The trim had stopped in the full nose up (tab down) position. > > Some troubleshooting after shutdown revealed the mechanism is not jammed, it still gets power - when activated, the unit does some "whirring" - but the jack screw does not move. It appears something INTERNAL to the unit has failed. > > In all my years flying RV's, I've never heard of a single failure in this manner. Anyone ? > > Really wish I had used a DB9 or some other quick connect for this ... > > --Ron > > > ________________________________________________________________________________
Date: Jul 08, 2017
Last message send too early. So I have been disabling auto-trim on my auto pilot. Just to keep it from working up a down until I can learn more about how much input it's putting into the system. I really don't want to go on a 3 hour flight and have the auto-trim running the tab the whole time when the trim is close enough that servo is close enough to handle the loads. So I've been using auto trim to get level and then shutting it down until it's needed. I don't know if it helps much, but I'm just hoping to extend the life of the servo by running it when it really doesn't need to be running. Phil Sent from my iPhone > On Jul 8, 2017, at 7:18 AM, Ron Walker wrote: > > > Doing some T&G last evening in the 10 ... with just me on board, final typically has me full nose up on the trim - even with that, I still need some back pressure ... but that's not the story. > > Anyway, on roll-out, I was moving the tab back to neutral and realized it was taking a LOT longer to reset than usual. Eventually I determined that it was not moving at all. The trim had stopped in the full nose up (tab down) position. > > Some troubleshooting after shutdown revealed the mechanism is not jammed, it still gets power - when activated, the unit does some "whirring" - but the jack screw does not move. It appears something INTERNAL to the unit has failed. > > In all my years flying RV's, I've never heard of a single failure in this manner. Anyone ? > > Really wish I had used a DB9 or some other quick connect for this ... > > --Ron > > > ________________________________________________________________________________
Date: Jul 08, 2017
Hi I was reading this thread with some interest as I was about to do this step as well. Prior to drilling I marked where the holes would be using a sharpie through the gusset holes. The edge distance was not good for the aft most holes. The source of the problem was that the flange of the gusset was not parallel to the skin / longeron. I was think of using a shim to move the longeron inboard but then realized there was a much simpler solution. If you rotate the F-1005C you can get the gusset flange to line up parallel to the skin. This will give good edge distance. You will need to rotate the F1005 beyond where you want it a sit will spring back a little. Cheers Les C-GCWZ Flying C-GROK some assembly required Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470800#470800 ________________________________________________________________________________
Date: Jul 08, 2017
Hi Bob Thanks for the info. It will be most useful, I don't know much about tires. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470801#470801 ________________________________________________________________________________
Subject: Question for the IO-540 Engine Mavens
Date: Jul 08, 2017
Hi Today I got a line on an IO-540 AE1A5 engine that was in a helicopter. It has 500 TSNew. It has had a the helicopter equivalent of a prop strike and so needs to be inspected etc. Can anyone tell me if it possible to use this engine as a core for use in a -10. I would plan on having the engine inspected / overhauled / converted for use on my project if it makes economic sense. Inquiring minds need to know... Les C-GCWZ flying C-GROK some assembly required Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470805#470805 ________________________________________________________________________________
Date: Jul 08, 2017
Subject: Re: Question for the IO-540 Engine Mavens
Hi Les, I don't thing this engine will be a good fit unfortunately. The IO-540 TCDS describes it as follows: -AE1A5 - Similar to O-540-F1B5 with IO-540-K angle valve cylinders, pistons, piston squirts and fuel injection and induction system. It will have angle valve cylinders which are too wide for the RV-10 cowl. It also weighs 416 lbs vs. the 379lbs of the stock D4A5. I'm not sure, but it's also likely that the sump and/or case geometry may cause issues. David On Sat, Jul 8, 2017 at 8:51 PM, kearney wrote: > > Hi > > Today I got a line on an IO-540 AE1A5 engine that was in a helicopter. It > has 500 TSNew. It has had a the helicopter equivalent of a prop strike and > so needs to be inspected etc. > > Can anyone tell me if it possible to use this engine as a core for use in > a -10. I would plan on having the engine inspected / overhauled / > converted for use on my project if it makes economic sense. > > Inquiring minds need to know... > > Les > > C-GCWZ flying > C-GROK some assembly required > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470805#470805 > > ________________________________________________________________________________
Date: Jul 09, 2017
I spent the better part of an hr this morning removing the servo. I hope re-install goes as smoothly. I removed the servo cover and got a look at the innards. One of the drive gears had a few teeth missing. In this "dead spot", the shaft will not move. Culprit identified. Pricey little gizmo, too. --Ron On 07/08/2017 08:28 AM, Phillip Perry wrote: > > We just replaced one on a -10 on our field. Exactly the same failure after some T&G's in the evening. There was noise but no movement as a gear broke inside the unit. > > It was ~10 years old, FYI. > > I suspect this servo gets more use (and high pressures on the mechanisms) than any other servo (Aileron and rudder for those who have rudder trim). > > > > Sent from my iPhone > >> On Jul 8, 2017, at 7:18 AM, Ron Walker wrote: >> >> >> Doing some T&G last evening in the 10 ... with just me on board, final typically has me full nose up on the trim - even with that, I still need some back pressure ... but that's not the story. >> >> Anyway, on roll-out, I was moving the tab back to neutral and realized it was taking a LOT longer to reset than usual. Eventually I determined that it was not moving at all. The trim had stopped in the full nose up (tab down) position. >> >> Some troubleshooting after shutdown revealed the mechanism is not jammed, it still gets power - when activated, the unit does some "whirring" - but the jack screw does not move. It appears something INTERNAL to the unit has failed. >> >> In all my years flying RV's, I've never heard of a single failure in this manner. Anyone ? >> >> Really wish I had used a DB9 or some other quick connect for this ... >> >> --Ron >> ________________________________________________________________________________
Date: Jul 09, 2017
Curious how old it was? The one we replaced had the same failure at 10 years. Sent from my iPhone > On Jul 9, 2017, at 9:49 AM, Ron Walker wrote: > > > I spent the better part of an hr this morning removing the servo. I hope re-install goes as smoothly. > > I removed the servo cover and got a look at the innards. One of the drive gears had a few teeth missing. In this "dead spot", the shaft will not move. Culprit identified. > > Pricey little gizmo, too. > > --Ron > >> On 07/08/2017 08:28 AM, Phillip Perry wrote: >> We just replaced one on a -10 on our field. Exactly the same failure after some T&G's in the evening. There was noise but no movement as a gear broke inside the unit. >> It was ~10 years old, FYI. >> I suspect this servo gets more use (and high pressures on the mechanisms) than any other servo (Aileron and rudder for those who have rudder trim). >> Sent from my iPhone >>> On Jul 8, 2017, at 7:18 AM, Ron Walker wrote: >>> >>> >>> Doing some T&G last evening in the 10 ... with just me on board, final typically has me full nose up on the trim - even with that, I still need some back pressure ... but that's not the story. >>> >>> Anyway, on roll-out, I was moving the tab back to neutral and realized it was taking a LOT longer to reset than usual. Eventually I determined that it was not moving at all. The trim had stopped in the full nose up (tab down) position. >>> >>> Some troubleshooting after shutdown revealed the mechanism is not jammed, it still gets power - when activated, the unit does some "whirring" - but the jack screw does not move. It appears something INTERNAL to the unit has failed. >>> >>> In all my years flying RV's, I've never heard of a single failure in this manner. Anyone ? >>> >>> Really wish I had used a DB9 or some other quick connect for this ... >>> >>> --Ron >>> > > > ________________________________________________________________________________
Date: Jul 09, 2017
I bought the emp kit in 2005, so I would guess at least 12 yrs old. However, it's only been flying since Oct 2016 (9 mths). Perhaps it just went brittle while sitting idle all those years. --Ron On 07/09/2017 11:28 AM, Phillip Perry wrote: > > Curious how old it was? The one we replaced had the same failure at 10 years. > > Sent from my iPhone > >> On Jul 9, 2017, at 9:49 AM, Ron Walker wrote: >> >> >> I spent the better part of an hr this morning removing the servo. I hope re-install goes as smoothly. >> >> I removed the servo cover and got a look at the innards. One of the drive gears had a few teeth missing. In this "dead spot", the shaft will not move. Culprit identified. >> >> Pricey little gizmo, too. >> >> --Ron ________________________________________________________________________________
Date: Jul 09, 2017
Thanks, I eventually came to the same conclusion. Vans wrote back and said they didn't know what caused the problem, but that I could just add a doubler. That didn't seem like a reasonable solution to me. Sure, I could add a doubler and put new holes in the longeron, but the new holes through the doubler would have bad edge distance in the gusset. I could add more holes way out in the gusset, but this wasn't satisfying to me, either. After spending a lot of time playing with the parts and a sharpie, I realized what you did, that I could pivot the gusset outboard and fix the edge distance. For the right side (which I hadn't drilled yet), I went ahead and drilled through the side skin in the forward-most hole into the longeron so I could cleco to the skin and be sure that alignment was correct. Then, I simply squeezed the gusset inboard with my hands and drilled the aft-most hole first. Put a cleco in it, and drilled the rest. I think they came out just fine. So, I rebuilt the left longeron with the bad holes (probably took me about the same amount of time as making a doubler from scratch, figuring out rivet lengths, etc, would have taken). Drilled the new longeron with my new technique and I think it too is now fine. https://goo.gl/photos/t63mDsvT4a5nmDFu5 https://goo.gl/photos/bgZw1QuKYaSiWZLS8 So, a note to anyone else who hasn't yet done this: check your edge distance before drilling these holes (particularly on the aft-most hole), and note that you can pull the gusset outboard as necessary to get the right edge distance. On Sat, Jul 8, 2017 at 5:35 PM, kearney wrote: > > Hi > > I was reading this thread with some interest as I was about to do this > step as well. > > Prior to drilling I marked where the holes would be using a sharpie > through the gusset holes. The edge distance was not good for the aft most > holes. > The source of the problem was that the flange of the gusset was not > parallel to the skin / longeron. > > I was think of using a shim to move the longeron inboard but then realized > there was a much simpler solution. > > If you rotate the F-1005C you can get the gusset flange to line up > parallel to the skin. This will give good edge distance. You will need to > rotate the F1005 beyond where you want it a sit will spring back a little. > > Cheers > > Les > > C-GCWZ Flying > C-GROK some assembly required > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=470800#470800 > > ________________________________________________________________________________
Subject: Van's FWF kit
Date: Jul 12, 2017
I've read numerous posts regarding different options when installing the engine. Does anyone know of a list of recommendations for items to delete from the Van's FWF kit. I'm installing the IO-540 from Lycoming with 1 slick and 1 pmag. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470938#470938 ________________________________________________________________________________
Date: Jul 12, 2017
I've read numerous posts regarding different options when installing the engine. Does anyone know of a list of recommendations for items to delete from the Van's FWF kit. I'm installing the IO-540 from Lycoming with 1 slick and 1 pmag. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470939#470939 ________________________________________________________________________________
Subject: Re: Van's FWF kit
Date: Jul 12, 2017
Its been awhile but IIRC I deleted most of the hoses (which I replaced with ones from Tom at TS Flightlnes), the alternator, and the oil cooler mount/bracket (which I had bought earlier so I could install it during firewall construction). -------- Todd Stovall aka Auburntsts on EAA, AOPA, and VAF RV-10 N728TT -- Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470957#470957 ________________________________________________________________________________
Date: Jul 12, 2017
https://photos.app.goo.gl/XGkzgT9ONmZDAFB33 Unless I just have an anomaly, I may have discovered the mysterious reason that "slight modification" must be done to use the 14 designated Y/D bracket kit on a -10. The Y/D bracket is supposed to sandwich in-between the pitch servo bracket and the flange of the bulkhead which are already mated up. The two aft holes, however, are about 1/16 of an inch wider on the Y/D bracket forcing you to elongate the hole inward to match up. Considering the absolute deadnuts accuracy there has been in everything else, I have to imagine that they know this. It is too far off to fit but close enough for the screw to barely catch a thread or two. A simple note in the instructions could save some tailcone imbedded frustration and perhaps, a stripped nutplate that would be a bugger to replace. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470959#470959 ________________________________________________________________________________
Date: Jul 12, 2017
I'd delete the Pmag and move on to something that's actually available. :) It was ready to ship within the next two weeks at least 7 years ago. If you are going with the stock Lycoming, Van's cowling, Hartzell prop then the fwf kit is adequate. I upgraded all the hoses to integral firesleeve from Stratoflex. If I were to do it again I'd get the fuel hoses with the red external firesleeve on it. It may keep the fuel inside the hose a bit cooler. Also, delete the hose that's connecting the fuel injection servo and the spider and get two shorter ones to connect the fuel flow sender in between there. Lenny whodja wrote: > I've read numerous posts regarding different options when installing the engine. Does anyone know of a list of recommendations for items to delete from the Van's FWF kit. I'm installing the IO-540 from Lycoming with 1 slick and 1 pmag. -------- Lenny Iszak Palm City, FL 2014 RV-10, N311LZ - 300 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=470964#470964 ________________________________________________________________________________
Date: Jul 14, 2017
It's been awhile but assuming that the kit includes the black baffle material, I'd delete and replace with a sheet of silicon material. Easy to work with, virtually like new after 900 hours, the orange/red looks good too. On 7/12/2017 11:20 AM, whodja wrote: > > I've read numerous posts regarding different options when installing the engine. Does anyone know of a list of recommendations for items to delete from the Van's FWF kit. I'm installing the IO-540 from Lycoming with 1 slick and 1 pmag. > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 14, 2017
Subject: Dynon D100 EFIS and D120 EMS for sale
Hi, I posted my RV-10 project and sold it in a week.=C2-=C2- Thanks Matroni cs and RV-10 builders. The buyer wanted to put his own panel in and did not need the Dynon D-100 a nd D-120 EFIS and EMS. Since I am not building the RV-10 I am selling them with some other items. They are in Excellent condition.=C2- I just powered them up for the first time today so you could see them. =C2-you can see it on craigslist: Allentown (Lehigh Valley) PA craigslist:=C2-=C2- general for sale, unde r the title: " Dynon D100 EFIS and D120 EMS - $4000 " Thanks for looking ! ________________________________________________________________________________
Date: Jul 16, 2017
Subject: Oshkosh Dinner?
Is there going to be a dinner on Sunday night again this year? Where do we sign up? Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad ________________________________________________________________________________
Date: Jul 16, 2017
Subject: Re: Oshkosh Dinner?
Jesse, Dinner is the Sunday before show start at 5:30. Pretty sure you already confirmed attendance for 5... we're between 51st & 52nd, just south of Lindbergh. Bob On Sun, Jul 16, 2017 at 8:00 AM Jesse Saint wrote: > > Is there going to be a dinner on Sunday night again this year? Where do we > sign up? > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > ________________________________________________________________________________
Date: Jul 16, 2017
Bob, I'm glad this came up. We suddenly have a rare chance to get to attend Os hkosh this year, first time for our RV-10 in 11 years. Is it too late to sig n up for the dinner? We plan to arrive Sunday afternoon. Thanks, Marcus > On Jul 16, 2017, at 9:49 AM, Bob Condrey wrote: > > Jesse, > > Dinner is the Sunday before show start at 5:30. Pretty sure you already c onfirmed attendance for 5... we're between 51st & 52nd, just south of Lindb ergh. > > Bob > >> On Sun, Jul 16, 2017 at 8:00 AM Jesse Saint wro te: >> >> Is there going to be a dinner on Sunday night again this year? Where do w e sign up? >> >> Jesse Saint >> Saint Aviation, Inc. >> 352-427-0285 >> jesse(at)saintaviation.com >> >> Sent from my iPad >> >> ========== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========== >> >> >> ========================== ========================== ========================== ========================== ========================== ========================== ========================== ============= ________________________________________________________________________________
From: "Kenneth Langley" <klangley1(at)mygrande.net>
Date: Jul 16, 2017
Bob, I also plan to attend. I came along with Phil Perry last year shortly after purchasing my RV 10. No, I wasn=99t the builder, but the info you guys provide here has been extremely helpful in greatly improving the condition and reliability of my RV 10. Anyway, Phil and I plan to attend again this year, and will be arriving (from Texas) as early as possible on Sunday afternoon. Kenneth Langley From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Subject: Re: RV10-List: Oshkosh Dinner? Jesse, Dinner is the Sunday before show start at 5:30. Pretty sure you already confirmed attendance for 5... we're between 51st & 52nd, just south of Lindbergh. Bob On Sun, Jul 16, 2017 at 8:00 AM Jesse Saint wrote: Is there going to be a dinner on Sunday night again this year? Where do we sign up? Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: RPM Issue
Date: Jul 16, 2017
Newish RV-10 (70 hours). So far I have had no problems since ending build with flight but during run up on today's flight rpm was normal at idle but with power quickly shot up to over 2000 (at lower than normal throttle setting) and rapidly dropped off during single mag use. Prop cycle gave no real change in pitch (no audible change). Tried high speed down taxiway and rpm went into red again. Took off cowl and linkage to govenor was fine and no other obvious problems other than engine maybe hot (or it just seemed that way as 95 outside). I have hartzell govenor from vans. Does that mean bad governor you think? Thanks Matt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471079#471079 ________________________________________________________________________________
Subject: Re: RPM Issue
Date: Jul 16, 2017
Right now all you said is that the RPM went up to 2000. Without having actual RPM numbers, I'm not sure what to say. You said the RPM went into the red, but are you saying that there is a red on the low-end or the high-end? It's not clear if you mean that it actually went over 2700 RPM. Tim > On Jul 16, 2017, at 6:43 PM, mhealydds wrote: > > > Newish RV-10 (70 hours). So far I have had no problems since ending build with flight but during run up on today's flight rpm was normal at idle but with power quickly shot up to over 2000 (at lower than normal throttle setting) and rapidly dropped off during single mag use. Prop cycle gave no real change in pitch (no audible change). Tried high speed down taxiway and rpm went into red again. Took off cowl and linkage to govenor was fine and no other obvious problems other than engine maybe hot (or it just seemed that way as 95 outside). I have hartzell govenor from vans. Does that mean bad governor you think? > > Thanks > Matt > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471079#471079 > > > > > > > > > ________________________________________________________________________________
Date: Jul 16, 2017
Sorry typing in heat and sun. Yes redline over 2700 skips from 1100 to over 2700 (maxed 2850 before reduce throttle)with increase in throttle. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471083#471083 ________________________________________________________________________________
Date: Jul 16, 2017
Make sure it's not just a displayed rpm problem. How are you getting the RPM signal? Did your brakes start dragging? It's not easy to hold the plane in place at 2700rpm. Below around 1400rpm the Hartzell governor will not change pitch. If it's real RPMs, I'd call Hartzell, their tech support is awesome. -------- Lenny Iszak Palm City, FL 2014 RV-10, N311LZ - 300 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471085#471085 ________________________________________________________________________________
Date: Jul 16, 2017
Add the resistor & you'll be good to go. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 Sent from my iPhone > On Jul 16, 2017, at 8:36 PM, Lenny Iszak wrote: > > > Make sure it's not just a displayed rpm problem. How are you getting the RPM signal? > Did your brakes start dragging? It's not easy to hold the plane in place at 2700rpm. > > Below around 1400rpm the Hartzell governor will not change pitch. > > If it's real RPMs, I'd call Hartzell, their tech support is awesome. > > -------- > Lenny Iszak > Palm City, FL > 2014 RV-10, N311LZ - 300 hrs > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471085#471085 > > > > > > > > > ________________________________________________________________________________
Date: Jul 16, 2017
If the RPMs are real, that you really got 2850...which I kind of doubt or your high speed taxi would have been an airborne event... You need to get the Lycoming service bulletin for engine overspeeds. IIRC 5% or 2835 is the threshold for inspecting and possibly replacement of some items. -sent from the I-droid implanted in my forearm On Sun, Jul 16, 2017 at 5:36 PM, Lenny Iszak wrote: > > Make sure it's not just a displayed rpm problem. How are you getting the > RPM signal? > Did your brakes start dragging? It's not easy to hold the plane in place > at 2700rpm. > > Below around 1400rpm the Hartzell governor will not change pitch. > > If it's real RPMs, I'd call Hartzell, their tech support is awesome. > > -------- > Lenny Iszak > Palm City, FL > 2014 RV-10, N311LZ - 300 hrs > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471085#471085 > > ________________________________________________________________________________
Date: Jul 16, 2017
Subject: Shhhh
Our planes are listening, and I believe have detected some OSH anxiety. In the past week I have suffered brake failure and my autopilot roll servo sheared its shear pin. All fixable, but departure time is getting close. I would be pissed if something else fails. -sent from the I-droid implanted in my forearm ________________________________________________________________________________
Date: Jul 16, 2017
Subject: Re: Shhhh
My autopilot failed, the compass sprang a leak, and I don't get back from a family vacation until sometime Tuesday to begin repairs, play catch-up on house related chores, and begin Oshkosh preparations (including seam sealing the new tent). Got a lot of stuff to do before I depart on Saturday.... > On Jul 16, 2017, at 10:26 PM, Kelly McMullen wrote: > > Our planes are listening, and I believe have detected some OSH anxiety. In the past week I have suffered brake failure and my autopilot roll servo sheared its shear pin. > All fixable, but departure time is getting close. I would be pissed if something else fails. > > -sent from the I-droid implanted in my forearm ________________________________________________________________________________
Date: Jul 16, 2017
Agree with others - check your tach. At rest or taxi speeds the mechanical prop stop should not allow 2800 RPM. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471093#471093 ________________________________________________________________________________
Subject: Alternator
Date: Jul 17, 2017
Hi I am looking at the Van's FWF kit and am wondering about the supplied alternator. Does anyone know the make / model of the alternator. My plan is to use an alternator that is easily replaced so that a failure doesn't mean a long delay on the ground. Cheers Les C-GCWZ Flying C-GROK Some assembly required Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471103#471103 ________________________________________________________________________________
Subject: Alternator
Date: Jul 17, 2017
Use a 1 wire GM alternator About $60 at auto zone lifetime warrantee Thanks, Jim Villani Broker / Salesman Great Real Estate Jim(at)Sold702.com Mammoth Creek Excavation WeDig435.com 702 379 5524 cell -------- Original message -------- From: kearney <kearney(at)shaw.ca> Date: 07/17/2017 7:54 AM (GMT-07:00) Subject: RV10-List: Alternator Hi I am looking at the Van's FWF kit and am wondering about the supplied alter nator. Does anyone know the make / model of the alternator. My plan is to use an alternator that is easily replaced so that a failure d oesn't mean a long delay on the ground. Cheers Les C-GCWZ Flying C-GROK Some assembly required Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471103#471103 ________________________________________________________________________________
Subject: Re: Alternator
Date: Jul 17, 2017
The alternator supplied with the FWF kit in 2010 was a Plane Power 60 amp unit with an internal regulator. I don't know if that has changed or not since then. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471111#471111 ________________________________________________________________________________
Date: Jul 17, 2017
Hmm, when I ordered in early 2010 it was still shown as Nippondenso, so I deleted and bought Plane Power on my own. -sent from the I-droid implanted in my forearm On Mon, Jul 17, 2017 at 11:48 AM, Bob Turner wrote: > > The alternator supplied with the FWF kit in 2010 was a Plane Power 60 amp > unit with an internal regulator. > I don't know if that has changed or not since then. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471111#471111 > > ________________________________________________________________________________
Subject: RV10 alternator
Date: Jul 17, 2017
I'd recommend using a GM or Ford alternator. About $80 new at any auto parts store and available any where on the spurge of the moment. You will have to put on a larger alternator pulley (3 in or so) in order to not over speed the alternator (check the diameter of the car engine drive pulley, RPM at cruise-about 2000 at 70 mph, the diameter of the Lycoming V-belt pulley, etc. and match things up). Much cheaper than an aircraft alternator and more reliable. Doc 123CV #41087 ________________________________________________________________________________
Date: Jul 17, 2017
Thanks for all your help. It definitely a sensor problem after some further checking. Working on a fix. Thanks for getting my head straight. Matt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471124#471124 ________________________________________________________________________________
Date: Jul 17, 2017
There isn't a "sign up" for the dinner, we're just trying to get a head count to make sure we've got a good estimate for food. The social/dinner was initially posted a while back on VAF and here. I'll bump the original post so everybody will see it. We're already on-site and the event will be I very close to where we've been in prior years; in Camp Scholler between 51st & 52nd streets, immediately south of Lindbergh. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471125#471125 ________________________________________________________________________________
Subject: Re: 2017 AirVenture RV-10 Dinner/Social
Date: Jul 17, 2017
Bump for those that missed the original post Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471126#471126 ________________________________________________________________________________
Date: Jul 17, 2017
Just to have all info in the same thread... Location is between 51st & 52nd streets, just south of Lindbergh in Camp Scholler. Start time still 5:30. As in years past, RV-10 builders/flyers/dreamers are welcome to use the common area we've set up for socializing before during the week of the show. We're on site now and have tables and shade ready to go. A few have asked about cost - A few generous vendors contribute to help facilitate our gathering and there will be a free will donation box available. There isn't a "recommended" amount and we don't keep score, just whatever you feel like contributing. This is absolutely a zero profit venture, any funds remaining after dinner expenses are covered are rolled over into the next year as "seed funds". We started putting this together in the very early RV-10 years as a way for us early builders to meet and exchange ideas. We've kept it going because there is a constant stream of new builders that can benefit. It's also RV-10 related chatter every night, a chance to reconnect with people and a chance to meet new builders. A few have asked about cost - A few generous vendors contribute to help facilitate our gathering and there will be a free will donation box available. There isn't a "recommended" amount and we don't keep score, just whatever you feel like contributing. This is absolutely a zero profit venture, any funds remaining after expenses are covered are just rolled over into the next year. Bob (and Gary) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471127#471127 ________________________________________________________________________________
Date: Jul 18, 2017
Bob, please add three to the tally, and thanks for your annual hospitality! --Dave ________________________________________________________________________________
Date: Jul 18, 2017
I've done a lot of research on the subject. The best option I've found is the Autozone 14118 from a 1976 Chevy Luv. 60 Amp, turns the right way, and externally regulated. I'm not sure why its not more popular unless there's something I'm missing. -Josh On Mon, Jul 17, 2017 at 8:47 AM, kearney wrote: > > Hi > > I am looking at the Van's FWF kit and am wondering about the supplied > alternator. Does anyone know the make / model of the alternator. > > My plan is to use an alternator that is easily replaced so that a failure > doesn't mean a long delay on the ground. > > Cheers > > Les > > C-GCWZ Flying > C-GROK Some assembly required > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471103#471103 > > ________________________________________________________________________________
Date: Jul 18, 2017
Just want to mention this so it doesn't get overlooked in the enthusiasm of getting a more easily replaceable alternator. If you are using an automotive alternator make sure you add overvoltage protection to your charging system. B & C has a crowbar module or there's a more modern option from Perihelion Designs. If you don't have one of these and your voltage regulator fails it can kill a bunch of your expensive avionics. Couple that with a lithium battery that has OV protection built in, in an overvoltage situation it disconnects itself from the circuit, there's nothing to absorb the high voltage and then all of your avionics are done before you even think about hitting your master switch. -------- Lenny Iszak Palm City, FL 2014 RV-10, N311LZ - 300 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471135#471135 ________________________________________________________________________________
Subject: Re: Rv10 yaw damper
Date: Jul 18, 2017
DO NOT USE THE DEFAULT SETTINGS. In the absence of further guidance, I tried my Y/D out this morning with the default settings. Holy Crap I thought the tail was going to come off it was oscillating back and forth so forcefully. I was grateful for the additional disconnect switch. On the ground, I called support and left a message. In the meantime I found a thread by "GaryK" on the Dynon forum. I tried his settings and it worked great. Much different than the default settings. As an example, his AY gain is .005 and the default was 1.0! the sensitivity was also 10 compared to his 4. Below are his settings which I highly recommend as a starting point. I mentioned same to Dynon when they returned my call. Settings are: Torque. 90 Sensitivity 4 Rudder Gain .2 Rudder Rate 0.020 AY Gain 0.005 -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471140#471140 ________________________________________________________________________________
Date: Jul 18, 2017
Do you have sky view or AFS EFIS. I have AFS and default setting seem to be fine. I wondered if yours was skyview or I better check mine closer. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471147#471147 ________________________________________________________________________________
Date: Jul 18, 2017
I have SkyView. They just posted new default parameters on the Dynon forum. They said there was an update glitch causing the defaults to get askew. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471148#471148 ________________________________________________________________________________
Date: Jul 18, 2017
Update for those of you that it may apply to. Turns out with latest AFS update they added the ability to customize to separate ignition setting in the RPM control menu in those with AFS and SV-EMS. This new ignition section was set to default of two pulses per 2 revolution but for six cylinder should be three pulses. One quick change and all reads OK. One of those ah ha moments I guess Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471149#471149 ________________________________________________________________________________
Date: Jul 18, 2017
Myron has the Skyview EFIS. On 7/18/2017 7:34 PM, mhealydds wrote: > > Do you have sky view or AFS EFIS. I have AFS and default setting seem to be fine. I wondered if yours was skyview or I better check mine closer. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471147#471147 > > > > > > > > > ________________________________________________________________________________
Date: Jul 19, 2017
Amy and Barry Marz are planning to come, WX permitting. Thanks much Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471157#471157 ________________________________________________________________________________
Date: Jul 20, 2017
Subject: Leaning and Learning
I am about 19.5 hours into Phase 1 and am still learning all the little nuances of the engine. For the first few hours I kept the mixture and power pushed close to the firewall for break-in. Recently, now that the engine looks like the new has worn off, I have started to lean the engine more and more aggressively. Mine might be behaving like others, but I'd like to confirm it or talk through some possibilities. Yesterday I was at 5,500 msl (roughly 7,000 DA), activated the leaning function on my G3X, and started leaning. Power: 24 In / 2500 RPM. As I began to approach peak EGT, the engine started to cough a bit. That was in the neighborhood of 12.5 GPH. I hadn't reached peak yet, so I continued with the leaning just to see. I was able to get the first cylinder to peak at 11.9ish and once I found peak for that cylinder I richened it back up to 75=C2=BA ROP. The engine smoot hed right out and was happy. That was around 14 GPH. Is this a behavior that you see in your engine, or have I missed something along the way? - The engine is an Aersport IO-540-D4A5 and pistons are 9:1. - The Ignition is Light Speed on one side and a Slick (Impluse) on the other. The slick is timed at 20=C2=BA per Aerosport's engraving on the da ta plate. - Fuel/Induction is from Airflow Performance. I'm just curious to know if your engine exhibits the same behavior of running rough before it reaches peak. I'm not attempting to run it LOP because the injectors haven't been balanced yet, but I really don't see how it would be possible to run LOP smoothly when there's even less fuel entering the nozzle. Sometimes too much data out of the EMS leads to re-learning a lot of things. In the past, I didn't have this much EGT/FF information and would just lean until it got rough and then twist the mixture in a few times. My assumption always was that the mixture was on the LOP side when the roughness started. In this case, with all this fancy equipment, I can see the roughness starts on the ROP side. Anyway, I'm just curious if this behavior is normal and something I shouldn't worry about or if there's something really going on that I need to stop and investigate. Phil ________________________________________________________________________________
Date: Jul 20, 2017
Subject: Re: Leaning and Learning
Phil, You need to balance your injectors. You have the exact same engine as I do and it took about three iterations with Don at airflow performance to get mine dialed into where I am today. Give him a call and he will send you a lean test sheet. Send it to him and he will send you a new set of injector nozzles. Replace the existing ones with the ones he sends you, then repeat the test. After a couple of tries you will be able to fly LOP just fine. Shannon On Thu, Jul 20, 2017 at 8:19 AM Phillip Perry wrote: > I am about 19.5 hours into Phase 1 and am still learning all the little > nuances of the engine. For the first few hours I kept the mixture and > power pushed close to the firewall for break-in. Recently, now that the > engine looks like the new has worn off, I have started to lean the engine > more and more aggressively. > > Mine might be behaving like others, but I'd like to confirm it or talk > through some possibilities. > > Yesterday I was at 5,500 msl (roughly 7,000 DA), activated the leaning > function on my G3X, and started leaning. Power: 24 In / 2500 RPM. As I > began to approach peak EGT, the engine started to cough a bit. That was > in the neighborhood of 12.5 GPH. > > I hadn't reached peak yet, so I continued with the leaning just to see. > I was able to get the first cylinder to peak at 11.9ish and once I found > peak for that cylinder I richened it back up to 75=C2=BA ROP. The engin e > smoothed right out and was happy. That was around 14 GPH. > > Is this a behavior that you see in your engine, or have I missed somethin g > along the way? > > - The engine is an Aersport IO-540-D4A5 and pistons are 9:1. > - The Ignition is Light Speed on one side and a Slick (Impluse) on the > other. The slick is timed at 20=C2=BA per Aerosport's engraving on the data > plate. > - Fuel/Induction is from Airflow Performance. > > I'm just curious to know if your engine exhibits the same behavior of > running rough before it reaches peak. I'm not attempting to run it LOP > because the injectors haven't been balanced yet, but I really don't see h ow > it would be possible to run LOP smoothly when there's even less fuel > entering the nozzle. > > Sometimes too much data out of the EMS leads to re-learning a lot of > things. In the past, I didn't have this much EGT/FF information and wou ld > just lean until it got rough and then twist the mixture in a few times. > My assumption always was that the mixture was on the LOP side when the > roughness started. In this case, with all this fancy equipment, I can se e > the roughness starts on the ROP side. > > Anyway, I'm just curious if this behavior is normal and something I > shouldn't worry about or if there's something really going on that I need > to stop and investigate. > > Phil > > ________________________________________________________________________________
Date: Jul 20, 2017
Hi Phil, It probably is a factor in injector balance. I can basically lean from full rich all the way to 75 LOP or more and it doesn't stumble. So my guess is that you will find the injectors need a bit of balancing. Personally I'd wait until you get 25 hours on it before backing off on the hard running, and then get it up to 9500 msl where you are well into the range where you can't exceed any high power setting going LOP and then do a very very slow full mixture pull all the way to 50 LOP. Do this 3 or 4 times, and upload it all to Savvy or use some software to look at the peak curves. You'll see if they match up or not. And then get right to balancing the injectors. People procrastinate...I know I do, and wait far too long to balance the injectors on their engines. Why suffer rough running longer than normal? On my RV-14 I haven't yet done a balance, but, that's because after running the test early on, it was so close I wasn't sure if I could even improve it. I'm going to have to go back now and see if it's changed at all. I am happy it's pretty good right out of the box, and I've been flying it LOP a bunch. Stumbling is just something you shouldn't experience if everything is set up right on an IO engine. If I am cruising LOP and I richen it up, all I get is a little acceleration, and a little more "thump" to the power stroke as the cylinder pressures get higher. Other than that it's just smooth. You're definitely right about the "too much data". People fixate on numbers when using digital data, but in this particular case, you'll want that data. Hopefully you can capture it at 1 second resolution, and if so, you'll be able to tune it in very quickly. Oh, and when you do the LOP, one benefit of being high (not Colorado high), is that you can do it at WOT. Your doing it at 24" and 2500rpm is higher than I would do it it at. That's above 75% power I believe, no? (This is off the cuff so 'scuse me if I'm wrong on that) Anyway, do the test at an altitude where you can get 21-22" and 2360rpm and see how that goes. I really don't fly LOP under 7500msl unless I power back, and I prefer not to power back. :) Tim On 7/20/2017 8:15 AM, Phillip Perry wrote: > I am about 19.5 hours into Phase 1 and am still learning all the > little nuances of the engine. For the first few hours I kept the > mixture and power pushed close to the firewall for break-in. > Recently, now that the engine looks like the new has worn off, I have > started to lean the engine more and more aggressively. > > Mine might be behaving like others, but I'd like to confirm it or talk > through some possibilities. > > Yesterday I was at 5,500 msl (roughly 7,000 DA), activated the leaning > function on my G3X, and started leaning. Power: 24 In / 2500 RPM. > As I began to approach peak EGT, the engine started to cough a bit. > That was in the neighborhood of 12.5 GPH. > > I hadn't reached peak yet, so I continued with the leaning just to > see. I was able to get the first cylinder to peak at 11.9ish and > once I found peak for that cylinder I richened it back up to 75 ROP. > The engine smoothed right out and was happy. That was around 14 GPH. > > Is this a behavior that you see in your engine, or have I missed > something along the way? > > - The engine is an Aersport IO-540-D4A5 and pistons are 9:1. > - The Ignition is Light Speed on one side and a Slick (Impluse) on the > other. The slick is timed at 20 per Aerosport's engraving on the > data plate. > - Fuel/Induction is from Airflow Performance. > > I'm just curious to know if your engine exhibits the same behavior of > running rough before it reaches peak. I'm not attempting to run it > LOP because the injectors haven't been balanced yet, but I really > don't see how it would be possible to run LOP smoothly when there's > even less fuel entering the nozzle. > > Sometimes too much data out of the EMS leads to re-learning a lot of > things. In the past, I didn't have this much EGT/FF information and > would just lean until it got rough and then twist the mixture in a few > times. My assumption always was that the mixture was on the LOP side > when the roughness started. In this case, with all this fancy > equipment, I can see the roughness starts on the ROP side. > > Anyway, I'm just curious if this behavior is normal and something I > shouldn't worry about or if there's something really going on that I > need to stop and investigate. > > Phil > > ________________________________________________________________________________
Date: Jul 20, 2017
I don't think it is particularly normal. You should not be getting more than a hint of roughness as you approach peak. I would not do your testing at the power setting you had. Reduce to 65% power first, until you determine where the roughness is coming from. You won't hurt anything at 65%, while you can cause problems leaning slowly while at or above 75%. Also, for your power setting, 11.9 is too lean for first cyl to peak. Either you don't have FF calibrated yet, or your power is dropping significantly while you are leaning. Once you have injectors balanced and any ignition issues dealt with, you can then just lean directly to a FF value LOP and know what power you are getting and that you are at a setting that treats the engine well. I have two Bendix S-1200 mags, with stock Bendix RSA fuel injection, and stock 8.5:1 compression. While I will feel a hint of vibration as I go LOP, the engine doesn't get rough until leaner than 50 LOP. The vibration is significantly less than 1 fouled plug would cause, more a feeling than hearing anything. I have not balanced injectors yet. I use the formula of 14.9 times your fuel flow while LOP equals power. For 195 hp, (75%) that is 13.0 gph. For 70% it is 12. For 65% it is 11.3, for 60% 10.5 and so on. That is with the LOP definition of degrees lean from the LAST cyl to peak. For your higher compression you might need to bump the calculation factor to 15.0 At your starting power, you were near 75%, and I would guess your power dropped off around 10% as you approached peak on first cylinder. Have you run either GAMI test or AFP leaning test? Another measure of mixture distribution is to glance at your EGTs shortly after lift-off, full power. Ideally they all will be at or 1300 or less, preferably centered on 1250, plus or minus 50. That will have you approximately 200 ROP, where you want during full power operations. You can also check your ignition at cruise altitude by setting the mixture you want, then doing a routine mag check....with the caveat that if engine quits for any reason, you go to near lean cutoff before turning mag back on...that is to protect your mufflers, and to prevent a prop surge. On 7/20/2017 6:15 AM, Phillip Perry wrote: > I am about 19.5 hours into Phase 1 and am still learning all the little > nuances of the engine. For the first few hours I kept the mixture and > power pushed close to the firewall for break-in. Recently, now that > the engine looks like the new has worn off, I have started to lean the > engine more and more aggressively. > > Mine might be behaving like others, but I'd like to confirm it or talk > through some possibilities. > > Yesterday I was at 5,500 msl (roughly 7,000 DA), activated the leaning > function on my G3X, and started leaning. Power: 24 In / 2500 RPM. > As I began to approach peak EGT, the engine started to cough a bit. > That was in the neighborhood of 12.5 GPH. > > I hadn't reached peak yet, so I continued with the leaning just to see. > I was able to get the first cylinder to peak at 11.9ish and once I > found peak for that cylinder I richened it back up to 75 ROP. The > engine smoothed right out and was happy. That was around 14 GPH. > > Is this a behavior that you see in your engine, or have I missed > something along the way? > > - The engine is an Aersport IO-540-D4A5 and pistons are 9:1. > - The Ignition is Light Speed on one side and a Slick (Impluse) on the > other. The slick is timed at 20 per Aerosport's engraving on the data > plate. > - Fuel/Induction is from Airflow Performance. > > I'm just curious to know if your engine exhibits the same behavior of > running rough before it reaches peak. I'm not attempting to run it LOP > because the injectors haven't been balanced yet, but I really don't see > how it would be possible to run LOP smoothly when there's even less fuel > entering the nozzle. > > Sometimes too much data out of the EMS leads to re-learning a lot of > things. In the past, I didn't have this much EGT/FF information and > would just lean until it got rough and then twist the mixture in a few > times. My assumption always was that the mixture was on the LOP side > when the roughness started. In this case, with all this fancy > equipment, I can see the roughness starts on the ROP side. > > Anyway, I'm just curious if this behavior is normal and something I > shouldn't worry about or if there's something really going on that I > need to stop and investigate. > > Phil > > ________________________________________________________________________________
Date: Jul 20, 2017
A little more data... Since my engine has 9:1 pistons, Aerosport power suggested that it 285 was closer to the baseline for calculating percentage of HP. So, using that math in the G3X setup, it was about 68% of power. I can't say the FF is 100% correct yet, but it's close. I've been making a number of power changes in my flights and haven't had a chance to get a constant enough run to feel like it's calibrated. But it's always been fairly close. Good info so far.. Thanks for the continued discussion. Phil On Thu, Jul 20, 2017 at 8:52 AM, Kelly McMullen wrote : > > I don't think it is particularly normal. You should not be getting more > than a hint of roughness as you approach peak. I would not do your testi ng > at the power setting you had. Reduce to 65% power first, until you > determine where the roughness is coming from. You won't hurt anything at > 65%, while you can cause problems leaning slowly while at or above 75%. > Also, for your power setting, 11.9 is too lean for first cyl to peak. > Either you don't have FF calibrated yet, or your power is dropping > significantly while you are leaning. Once you have injectors balanced and > any ignition issues dealt with, you can then just lean directly to a FF > value LOP and know what power you are getting and that you are at a setti ng > that treats the engine well. > I have two Bendix S-1200 mags, with stock Bendix RSA fuel injection, and > stock 8.5:1 compression. While I will feel a hint of vibration as I go LO P, > the engine doesn't get rough until leaner than 50 LOP. The vibration is > significantly less than 1 fouled plug would cause, more a feeling than > hearing anything. I have not balanced injectors yet. > I use the formula of 14.9 times your fuel flow while LOP equals power. Fo r > 195 hp, (75%) that is 13.0 gph. For 70% it is 12. For 65% it is 11.3, fo r > 60% 10.5 and so on. That is with the LOP definition of degrees lean from > the LAST cyl to peak. For your higher compression you might need to bump > the calculation factor to 15.0 > At your starting power, you were near 75%, and I would guess your power > dropped off around 10% as you approached peak on first cylinder. > Have you run either GAMI test or AFP leaning test? > Another measure of mixture distribution is to glance at your EGTs shortly > after lift-off, full power. Ideally they all will be at or 1300 or less, > preferably centered on 1250, plus or minus 50. That will have you > approximately 200 ROP, where you want during full power operations. > You can also check your ignition at cruise altitude by setting the mixtur e > you want, then doing a routine mag check....with the caveat that if engin e > quits for any reason, you go to near lean cutoff before turning mag back > on...that is to protect your mufflers, and to prevent a prop surge. > > > On 7/20/2017 6:15 AM, Phillip Perry wrote: > >> I am about 19.5 hours into Phase 1 and am still learning all the little >> nuances of the engine. For the first few hours I kept the mixture and >> power pushed close to the firewall for break-in. Recently, now that th e >> engine looks like the new has worn off, I have started to lean the engin e >> more and more aggressively. >> >> Mine might be behaving like others, but I'd like to confirm it or talk >> through some possibilities. >> >> Yesterday I was at 5,500 msl (roughly 7,000 DA), activated the leaning >> function on my G3X, and started leaning. Power: 24 In / 2500 RPM. As >> I began to approach peak EGT, the engine started to cough a bit. That was >> in the neighborhood of 12.5 GPH. >> >> I hadn't reached peak yet, so I continued with the leaning just to see. >> I was able to get the first cylinder to peak at 11.9ish and once I fou nd >> peak for that cylinder I richened it back up to 75=C2=BA ROP. The engi ne >> smoothed right out and was happy. That was around 14 GPH. >> >> Is this a behavior that you see in your engine, or have I missed >> something along the way? >> >> - The engine is an Aersport IO-540-D4A5 and pistons are 9:1. >> - The Ignition is Light Speed on one side and a Slick (Impluse) on the >> other. The slick is timed at 20=C2=BA per Aerosport's engraving on the data >> plate. >> - Fuel/Induction is from Airflow Performance. >> >> I'm just curious to know if your engine exhibits the same behavior of >> running rough before it reaches peak. I'm not attempting to run it LOP >> because the injectors haven't been balanced yet, but I really don't see how >> it would be possible to run LOP smoothly when there's even less fuel >> entering the nozzle. >> >> Sometimes too much data out of the EMS leads to re-learning a lot of >> things. In the past, I didn't have this much EGT/FF information and wo uld >> just lean until it got rough and then twist the mixture in a few times. >> My assumption always was that the mixture was on the LOP side when the >> roughness started. In this case, with all this fancy equipment, I can s ee >> the roughness starts on the ROP side. >> >> Anyway, I'm just curious if this behavior is normal and something I >> shouldn't worry about or if there's something really going on that I nee d >> to stop and investigate. >> >> Phil >> >> =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jul 20, 2017
I suggest you not use whatever power the engine made on the dyno, but rather 260 hp for calculating performance. My reasoning is that you then can get consistent numbers with other users. Using the stock numbers with higher compression should get you better fuel economy. Also, higher compression pistons generate more heat, the cylinders tend to run hotter, which accelerates wear. A more extreme example...I know of an aircraft that had an STC to run 10:1 pistons in a 200 hp IO-360. It might have had a MP restriction around 28" so that the engine didn't make more power than the airframe was certified for. However the aircraft did not have a full engine monitor, only single pt EGT,CHT and oil temp. Before 1000 hours the engine had self-destructed at least one piston, on takeoff from MSN for OSH. A terrible way to not make OSH. A lot of engines that had that STC did not make more than 800 hours before needing top overhauls. It is nice to have the power when you need it, or to run say something over 170 hp to higher altitudes, but I would not make a practice of running it over 195 hp in cruise, especially rich of peak. I wouldn't climb it at over 260 hp unless you had an obstacle clearance issue. These engines have very good longevity at the 250-260 hp they were originally rated, durability at higher power is not well documented. Lycoming made significant changes to the engine to run at 300 hp, such as oil nozzles spraying on the bottom of pistons, better breathing and cooling fins, bigger heads, etc. On 7/20/2017 7:08 AM, Phillip Perry wrote: > A little more data... > > Since my engine has 9:1 pistons, Aerosport power suggested that it 285 > was closer to the baseline for calculating percentage of HP. So, using > that math in the G3X setup, it was about 68% of power. I can't say the > FF is 100% correct yet, but it's close. I've been making a number of > power changes in my flights and haven't had a chance to get a constant > enough run to feel like it's calibrated. But it's always been fairly close. > > Good info so far.. Thanks for the continued discussion. > > Phil > > > On Thu, Jul 20, 2017 at 8:52 AM, Kelly McMullen > wrote: > > > > > I don't think it is particularly normal. You should not be getting > more than a hint of roughness as you approach peak. I would not do > your testing at the power setting you had. Reduce to 65% power > first, until you determine where the roughness is coming from. You > won't hurt anything at 65%, while you can cause problems leaning > slowly while at or above 75%. Also, for your power setting, 11.9 is > too lean for first cyl to peak. Either you don't have FF calibrated > yet, or your power is dropping significantly while you are leaning. > Once you have injectors balanced and any ignition issues dealt with, > you can then just lean directly to a FF value LOP and know what > power you are getting and that you are at a setting that treats the > engine well. > I have two Bendix S-1200 mags, with stock Bendix RSA fuel injection, > and stock 8.5:1 compression. While I will feel a hint of vibration > as I go LOP, the engine doesn't get rough until leaner than 50 LOP. > The vibration is significantly less than 1 fouled plug would cause, > more a feeling than hearing anything. I have not balanced injectors yet. > I use the formula of 14.9 times your fuel flow while LOP equals > power. For 195 hp, (75%) that is 13.0 gph. For 70% it is 12. For > 65% it is 11.3, for 60% 10.5 and so on. That is with the LOP > definition of degrees lean from the LAST cyl to peak. For your > higher compression you might need to bump the calculation factor to 15.0 > At your starting power, you were near 75%, and I would guess your > power dropped off around 10% as you approached peak on first cylinder. > Have you run either GAMI test or AFP leaning test? > Another measure of mixture distribution is to glance at your EGTs > shortly after lift-off, full power. Ideally they all will be at or > 1300 or less, preferably centered on 1250, plus or minus 50. That > will have you approximately 200 ROP, where you want during full > power operations. > You can also check your ignition at cruise altitude by setting the > mixture you want, then doing a routine mag check....with the caveat > that if engine quits for any reason, you go to near lean cutoff > before turning mag back on...that is to protect your mufflers, and > to prevent a prop surge. > > > On 7/20/2017 6:15 AM, Phillip Perry wrote: > > I am about 19.5 hours into Phase 1 and am still learning all the > little nuances of the engine. For the first few hours I kept > the mixture and power pushed close to the firewall for > break-in. Recently, now that the engine looks like the new has > worn off, I have started to lean the engine more and more > aggressively. > > Mine might be behaving like others, but I'd like to confirm it > or talk through some possibilities. > > Yesterday I was at 5,500 msl (roughly 7,000 DA), activated the > leaning function on my G3X, and started leaning. Power: 24 In > / 2500 RPM. As I began to approach peak EGT, the engine > started to cough a bit. That was in the neighborhood of 12.5 GPH. > > I hadn't reached peak yet, so I continued with the leaning just > to see. I was able to get the first cylinder to peak at > 11.9ish and once I found peak for that cylinder I richened it > back up to 75 ROP. The engine smoothed right out and was > happy. That was around 14 GPH. > > Is this a behavior that you see in your engine, or have I missed > something along the way? > > - The engine is an Aersport IO-540-D4A5 and pistons are 9:1. > - The Ignition is Light Speed on one side and a Slick (Impluse) > on the other. The slick is timed at 20 per Aerosport's > engraving on the data plate. > - Fuel/Induction is from Airflow Performance. > > I'm just curious to know if your engine exhibits the same > behavior of running rough before it reaches peak. I'm not > attempting to run it LOP because the injectors haven't been > balanced yet, but I really don't see how it would be possible to > run LOP smoothly when there's even less fuel entering the nozzle. > > Sometimes too much data out of the EMS leads to re-learning a > lot of things. In the past, I didn't have this much EGT/FF > information and would just lean until it got rough and then > twist the mixture in a few times. My assumption always was > that the mixture was on the LOP side when the roughness > started. In this case, with all this fancy equipment, I can see > the roughness starts on the ROP side. > > Anyway, I'm just curious if this behavior is normal and > something I shouldn't worry about or if there's something really > going on that I need to stop and investigate. > > Phil > > > =================================== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > > > ________________________________________________________________________________
Date: Jul 20, 2017
Good points... I can adjust it down and use that as the reference... Sent from my iPhone > On Jul 20, 2017, at 9:27 AM, Kelly McMullen wrote: > > G3X ________________________________________________________________________________
Date: Jul 20, 2017
Bob, Fortunately we are leaving for OSH earlier than planned. After a long long building pause I am back at it and looking forward to seeing a lot of new faces. We are a group of 5. Larry Rosen #356 and still building Slow Slow Quickbuild -------- Larry Rosen #40356 N205EN (reserved) <http> Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471202#471202 ________________________________________________________________________________
Date: Jul 20, 2017
Do you really have a Slick mag with impulse coupling? I'm a little hazy on the details, but Lycoming stopped shipping them that way, and put in retard mags with Slick start instead. I think there's a repetitive A/D on the impulse coupling in this engine? And, as someone with a relatively new engine, I assume you've heard about the wide-reaching "mandatory SB" on the connecting rod journals? But this is all independent of balancing your injectors. It's easy and relatively inexpensive. After balancing, I can slowly back the mixture way out, and the engine continues to run smoothly - just makes less and less power as I go further and further lean of peak. Running LOP gives reasonable range with the standard 60 gallon tanks. (160 KTAS on 10 gal/hr). -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471203#471203 ________________________________________________________________________________
Date: Jul 20, 2017
Phil, I've been running LOP for 900 hours and 6 years now. Everything I'd have to offer is captured in Tim's post - every single word. After you have it all set up and get comfortable (I don't need no stinking gauges, I just move the mixture next to about there), you'll even be able to lean in the climb up to 8-11k where the '10 really becomes a sweet traveling machine. But leaning in the climb in not LOP, it's just maintaining a reasonable ROP setting. Bill "LOP is great but you have to go thru a couple of tuning cycles first" Watson --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 20, 2017
Lycoming will ship with most any Slick mag you want. The problem with impulse couplings dates back awhile..current ones I don't believe have the AD..different attach method. Some vintage Bendix also had impulse coupler problems, IIRC. None of them come with Slick Start, AFAIK. You have to add that to retard breaker mags. -sent from the I-droid implanted in my forearm On Thu, Jul 20, 2017 at 10:27 AM, Bob Turner wrote: > > Do you really have a Slick mag with impulse coupling? I'm a little hazy on the details, but Lycoming stopped shipping them that way, and put in retard mags with Slick start instead. I think there's a repetitive A/D on the impulse coupling in this engine? > And, as someone with a relatively new engine, I assume you've heard about the wide-reaching "mandatory SB" on the connecting rod journals? > But this is all independent of balancing your injectors. It's easy and relatively inexpensive. After balancing, I can slowly back the mixture way out, and the engine continues to run smoothly - just makes less and less power as I go further and further lean of peak. Running LOP gives reasonable range with the standard 60 gallon tanks. (160 KTAS on 10 gal/hr). > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471203#471203 > > ________________________________________________________________________________
Subject: Re: F-1046 Longeron to F-1005E Gusset Holes
Date: Jul 20, 2017
On 7/4/2017 6:16 PM, Berck E. Nash wrote: On related note; I would recommend that builders apply corrosion protection (primer, alodine) to the longeron, particularly where it joins to the skin. Vans is very conservative with specifying areas where they recommend priming and I don't recall if this is one of those areas. Many builders are obsessive about priming and will certainly prime/alodine it. I missed this one and had to take some action to stop some filiform corrosion developing at that joint. Bill "in no way, shape or form is trying to restart any version of the primer wars" Watson > I lined up the F-1046L longeron with the gusset as described on page > 29-9, with the longeron flush with the skin. Then, I drilled the > holes. The edge distance is terrible, but I can't see what I did > wrong. I've searched and found others with the same problem, but no > resolutions turn up. The diagram on 29-9 sure acts like these holes > will wind up in the middle of the longeron, but I don't see how. > > Waiting to drill the other side until I can figure out how to avoid > the same problem. Looks to me like I should replace the longeron, but > I don't know how to do it any differently and still have the longeron > flush with the skin. > > https://goo.gl/photos/J8s8gheQ1GBmUUi1A > https://goo.gl/photos/z11vaX6PZt3Zc1w69 > > Any suggestions? --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 20, 2017
Lenny I agree on the OV protection. If you are using a VP-X, it will kill the field in an OV situation. Cheers Les C-GCWZ Flying C-GROK Some assembly required Lenny Iszak wrote: > Just want to mention this so it doesn't get overlooked in the enthusiasm of getting a more easily replaceable alternator. > If you are using an automotive alternator make sure you add overvoltage protection to your charging system. B & C has a crowbar module or there's a more modern option from Perihelion Designs. If you don't have one of these and your voltage regulator fails it can kill a bunch of your expensive avionics. > > Couple that with a lithium battery that has OV protection built in, in an overvoltage situation it disconnects itself from the circuit, there's nothing to absorb the high voltage and then all of your avionics are done before you even think about hitting your master switch. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471210#471210 ________________________________________________________________________________
Date: Jul 20, 2017
Thanks, good call. Vans does specifically call out priming the longerons. First, in section 5, they specifically say to prime all angle, as it's not alclad. Then, in section 29, it specifically says to prime the longerons, then other parts as desired. I'm not priming anything Van's doesn't say to prime, but I did miss the aluminum angle in the tail cone, so I'm going to go back and do it. Berck (feeling like he missed out, since he started building too late to join the primer wars) On Thu, Jul 20, 2017 at 4:09 PM, Bill Watson wrote: > > On 7/4/2017 6:16 PM, Berck E. Nash wrote: > On related note; I would recommend that builders apply corrosion > protection (primer, alodine) to the longeron, particularly where it joins > to the skin. > > Vans is very conservative with specifying areas where they recommend > priming and I don't recall if this is one of those areas. Many builders > are obsessive about priming and will certainly prime/alodine it. I missed > this one and had to take some action to stop some filiform corrosion > developing at that joint. > > Bill "in no way, shape or form is trying to restart any version of the > primer wars" Watson > > I lined up the F-1046L longeron with the gusset as described on page 29-9, >> with the longeron flush with the skin. Then, I drilled the holes. The edge >> distance is terrible, but I can't see what I did wrong. I've searched and >> found others with the same problem, but no resolutions turn up. The diagram >> on 29-9 sure acts like these holes will wind up in the middle of the >> longeron, but I don't see how. >> >> Waiting to drill the other side until I can figure out how to avoid the >> same problem. Looks to me like I should replace the longeron, but I don't >> know how to do it any differently and still have the longeron flush with >> the skin. >> >> https://goo.gl/photos/J8s8gheQ1GBmUUi1A >> https://goo.gl/photos/z11vaX6PZt3Zc1w69 >> >> Any suggestions? >> > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: Jul 21, 2017
Subject: Auto Response: RV10-List Digest: 14 Msgs - 07/20/17
Thank you for your email! Unfortunately, I will checking email VERY sporadically but I will get back to you when I am able. Thanks, David ________________________________________________________________________________
Date: Jul 21, 2017
Subject: leaning
I use 2250 RPM as that is the IO540 best torque point. I also use about 22.5 MP or FT. This provides about 60% and LOP fuel flows about 9 gph and 150KTAS. I have had the aircraft to 17000 MSL over the four corners area and showing about 50%, KTAS 150 and flow of slightly under 9 gph. Try best torque RPM to achieve 150 KTAS and flows of about 9 gph. The running is smooth and saves 1-3 gph by giving up about 10 KTAS. Don't know the top speed having never been there. When I see 25 gph flow for FT takeoff; I begin to think about leaning; With two people it will climb faster than a spam can even at 55-60%. David McNeill N46007 ________________________________________________________________________________
Subject: Re: leaning
Date: Jul 21, 2017
I run about the same; 2200-2300 RPM and FT. I can get 9.2 gph and 150KTAS at 9,000 and above but I now aim for 155KTAS which takes the fuel flow to 10.0 to 10.6. Nice know that the best torque point is around 2250 because I've arrived at that figure by 'feel' (?). Generally if I have a headwind I'll run more fuel thru it to get 155 -160KTAS and if a strong tailwind I roll the fuel back to do 150-155KTAS. What I do on the climb is FT with a roll back from 2700 to 2600 once the climb is established. Then at 1500 to 2000MSL I hit the leaning function on my GRT. Once all cylinders' EGT falls to -10F I start leaning to keep it there. dAs I understand it, the thinking behind that is that the engine is setup so that full rich and FT at sea level is safe in terms of cylinder cooling and detonation. Then as you climb the engine at full rich is progressively too rich. Waiting until 2000MSL then letting the EGTs fall 10F keeps things conservatively rich (ROP) at which point I begin leaning to stay there. I get some significant fuel flow savings on the climb with flows dropping below 20gph before climbing thru 9k. On 7/21/2017 8:54 AM, dlm wrote: > I use 2250 RPM as that is the IO540 best torque point. I also use > about 22.5 MP or FT. This provides about 60% and LOP fuel flows about > 9 gph and 150KTAS. I have had the aircraft to 17000 MSL over the four > corners area and showing about 50%, KTAS 150 and flow of slightly > under 9 gph. Try best torque RPM to achieve 150 KTAS and flows of > about 9 gph. The running is smooth and saves 1-3 gph by giving up > about 10 KTAS. > > Don't know the top speed having never been there. When I see 25 gph > flow for FT takeoff; I begin to think about leaning; With two people > it will climb faster than a spam can even at 55-60%. > > David McNeill > N46007 --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jul 21, 2017
Bob and any others in the know, I have an odd question, but since we are going to be arriving Sunday afternoon and camping with our airplane in the homebuilt section and nothing is really open yet on Sunday, is there any benefit to getting show tickets for Sunday? Looks like we can just walk over to the camping area where you are setup for the dinner. I dont want to be too cheap, but dont see the need to spend $19 each just to cut through either. Thanks, Marcus On Jul 17, 2017, at 11:59 PM, bcondrey wrote: Just to have all info in the same thread... Location is between 51st & 52nd streets, just south of Lindbergh in Camp Scholler. Start time still 5:30. As in years past, RV-10 builders/flyers/dreamers are welcome to use the common area we've set up for socializing before during the week of the show. We're on site now and have tables and shade ready to go. A few have asked about cost - A few generous vendors contribute to help facilitate our gathering and there will be a free will donation box available. There isn't a "recommended" amount and we don't keep score, just whatever you feel like contributing. This is absolutely a zero profit venture, any funds remaining after dinner expenses are covered are rolled over into the next year as "seed funds". We started putting this together in the very early RV-10 years as a way for us early builders to meet and exchange ideas. We've kept it going because there is a constant stream of new builders that can benefit. It's also RV-10 related chatter every night, a chance to reconnect with people and a chance to meet new builders. A few have asked about cost - A few generous vendors contribute to help facilitate our gathering and there will be a free will donation box available. There isn't a "recommended" amount and we don't keep score, just whatever you feel like contributing. This is absolutely a zero profit venture, any funds remaining after expenses are covered are just rolled over into the next year. Bob (and Gary) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471127#471127 ________________________________________________________________________________
Date: Jul 21, 2017
There is plenty to see on Sunday. Things changed a couple years ago. Most of the food places are now open on the weekend. You use your Monday band to gain access on Sunday. Nothing to purchase for Sunday. I'll be arriving HBC Saturday morning, weather permitting. Get Outlook for iOS _____________________________ From: Marcus Cooper <cooprv7(at)yahoo.com<mailto:cooprv7(at)yahoo.com>> Sent: Friday, July 21, 2017 1:55 PM Subject: Re: RV10-List: Re: 2017 AirVenture RV-10 Dinner/Social oprv7(at)yahoo.com>> Bob and any others in the know, I have an odd question, but since we are going to be arriving Sunday aftern oon and camping with our airplane in the homebuilt section and nothing is r eally open yet on Sunday, is there any benefit to getting show tickets for Sunday? Looks like we can just walk over to the camping area where you are setup for the dinner. I don=92t want to be too cheap, but don=92t see the n eed to spend $19 each just to cut through either. Thanks, Marcus On Jul 17, 2017, at 11:59 PM, bcondrey > wrote: reyb(at)gmail.com>> Just to have all info in the same thread... Location is between 51st & 52nd streets, just south of Lindbergh in Camp Sc holler. Start time still 5:30. As in years past, RV-10 builders/flyers/drea mers are welcome to use the common area we've set up for socializing before during the week of the show. We're on site now and have tables and shade r eady to go. A few have asked about cost - A few generous vendors contribute to help fac ilitate our gathering and there will be a free will donation box available. There isn't a "recommended" amount and we don't keep score, just whatever you feel like contributing. This is absolutely a zero profit venture, any f unds remaining after dinner expenses are covered are rolled over into the n ext year as "seed funds". We started putting this together in the very early RV-10 years as a way for us early builders to meet and exchange ideas. We've kept it going because there is a constant stream of new builders that can benefit. It's also RV-1 0 related chatter every night, a chance to reconnect with people and a chan ce to meet new builders. A few have asked about cost - A few generous vendors contribute to help fac ilitate our gathering and there will be a free will donation box available. There isn't a "recommended" amount and we don't keep score, just whatever you feel like contributing. This is absolutely a zero profit venture, any f unds remaining after expenses are covered are just rolled over into the nex t year. Bob (and Gary) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471127#471127 ________________________________________________________________________________
Date: Jul 21, 2017
Thanks, I had called EAA headquarters and they said nothing about the Monday band working on Sunday. We will be there just in time for the RV-10 dinner so I doubt we will need any more food. I had the impression the only thing to see was airplanes arriving which we can do from our airplane. Thanks for the heads up about the Monday bands working. Marcus On Jul 21, 2017, at 2:10 PM, Bob Leffler wrote: There is plenty to see on Sunday. Things changed a couple years ago. Most of the food places are now open on the weekend. You use your Monday band to gain access on Sunday. Nothing to purchase for Sunday. I'll be arriving HBC Saturday morning, weather permitting. Get Outlook for iOS _____________________________ From: Marcus Cooper <cooprv7(at)yahoo.com <mailto:cooprv7(at)yahoo.com>> Sent: Friday, July 21, 2017 1:55 PM Subject: Re: RV10-List: Re: 2017 AirVenture RV-10 Dinner/Social > Bob and any others in the know, I have an odd question, but since we are going to be arriving Sunday afternoon and camping with our airplane in the homebuilt section and nothing is really open yet on Sunday, is there any benefit to getting show tickets for Sunday? Looks like we can just walk over to the camping area where you are setup for the dinner. I don=92t want to be too cheap, but don=92t see the need to spend $19 each just to cut through either. Thanks, Marcus On Jul 17, 2017, at 11:59 PM, bcondrey > wrote: > Just to have all info in the same thread... Location is between 51st & 52nd streets, just south of Lindbergh in Camp Scholler. Start time still 5:30. As in years past, RV-10 builders/flyers/dreamers are welcome to use the common area we've set up for socializing before during the week of the show. We're on site now and have tables and shade ready to go. A few have asked about cost - A few generous vendors contribute to help facilitate our gathering and there will be a free will donation box available. There isn't a "recommended" amount and we don't keep score, just whatever you feel like contributing. This is absolutely a zero profit venture, any funds remaining after dinner expenses are covered are rolled over into the next year as "seed funds". We started putting this together in the very early RV-10 years as a way for us early builders to meet and exchange ideas. We've kept it going because there is a constant stream of new builders that can benefit. It's also RV-10 related chatter every night, a chance to reconnect with people and a chance to meet new builders. A few have asked about cost - A few generous vendors contribute to help facilitate our gathering and there will be a free will donation box available. There isn't a "recommended" amount and we don't keep score, just whatever you feel like contributing. This is absolutely a zero profit venture, any funds remaining after expenses are covered are just rolled over into the next year. Bob (and Gary) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471127#471127 <http://forums.matronics.com/viewtopic.php?p=471127#471127> -List" x-apple-data-detectors="true" x-apple-data-detectors-type="link" x-apple-data-detectors-result="6"> http://www.matronics.com/Navigator?RV10-List <http://www.matronics.com/Navigator?RV10-List> ta-detectors="true" x-apple-data-detectors-type="link" x-apple-data-detectors-result="7"> http://forums.matronics.com <http://forums.matronics.com/> -detectors="true" x-apple-data-detectors-type="link" x-apple-data-detectors-result="8"> http://wiki.matronics.com <http://wiki.matronics.com/> x-apple-data-detectors="true" x-apple-data-detectors-type="link" x-apple-data-detectors-result="9"> http://www.matronics.com/contribution <http://www.matronics.com/contribution> ________________________________________________________________________________
Date: Jul 21, 2017
The bands actually say sun/mon too. See you Sunday! Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> on behalf of Marcus Cooper Sent: Friday, July 21, 2017 2:29:07 PM Subject: Re: RV10-List: Re: 2017 AirVenture RV-10 Dinner/Social Thanks, I had called EAA headquarters and they said nothing about the Monda y band working on Sunday. We will be there just in time for the RV-10 dinn er so I doubt we will need any more food. I had the impression the only th ing to see was airplanes arriving which we can do from our airplane. Thank s for the heads up about the Monday bands working. Marcus On Jul 21, 2017, at 2:10 PM, Bob Leffler > wrote: There is plenty to see on Sunday. Things changed a couple years ago. Most of the food places are now open on the weekend. You use your Monday band to gain access on Sunday. Nothing to purchase for Sunday. I'll be arriving HBC Saturday morning, weather permitting. Get Outlook for iOS _____________________________ From: Marcus Cooper <cooprv7(at)yahoo.com<mailto:cooprv7(at)yahoo.com>> Sent: Friday, July 21, 2017 1:55 PM Subject: Re: RV10-List: Re: 2017 AirVenture RV-10 Dinner/Social oprv7(at)yahoo.com>> Bob and any others in the know, I have an odd question, but since we are going to be arriving Sunday aftern oon and camping with our airplane in the homebuilt section and nothing is r eally open yet on Sunday, is there any benefit to getting show tickets for Sunday? Looks like we can just walk over to the camping area where you are setup for the dinner. I don=92t want to be too cheap, but don=92t see the n eed to spend $19 each just to cut through either. Thanks, Marcus On Jul 17, 2017, at 11:59 PM, bcondrey > wrote: reyb(at)gmail.com>> Just to have all info in the same thread... Location is between 51st & 52nd streets, just south of Lindbergh in Camp Sc holler. Start time still 5:30. As in years past, RV-10 builders/flyers/drea mers are welcome to use the common area we've set up for socializing before during the week of the show. We're on site now and have tables and shade r eady to go. A few have asked about cost - A few generous vendors contribute to help fac ilitate our gathering and there will be a free will donation box available. There isn't a "recommended" amount and we don't keep score, just whatever you feel like contributing. This is absolutely a zero profit venture, any f unds remaining after dinner expenses are covered are rolled over into the n ext year as "seed funds". We started putting this together in the very early RV-10 years as a way for us early builders to meet and exchange ideas. We've kept it going because there is a constant stream of new builders that can benefit. It's also RV-1 0 related chatter every night, a chance to reconnect with people and a chan ce to meet new builders. A few have asked about cost - A few generous vendors contribute to help fac ilitate our gathering and there will be a free will donation box available. There isn't a "recommended" amount and we don't keep score, just whatever you feel like contributing. This is absolutely a zero profit venture, any f unds remaining after expenses are covered are just rolled over into the nex t year. Bob (and Gary) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471127#471127 -List" x-apple-data-detectors="true" x-apple-data-detectors-type="link" x-apple-data-detectors-result="6"> http://www.matronics.com/Navigator?RV 10-List ta-detectors="true" x-apple-data-detectors-type="link" x-apple-data-det ectors-result="7"> http://forums.matronics.com m/> -detectors="true" x-apple-data-detectors-type="link" x-apple-data-detec tors-result="8"> http://wiki.matronics.com> x-apple-data-detectors="true" x-apple-data-detectors-type="link" x-appl e-data-detectors-result="9"> http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 22, 2017
Just confirming what others have said - beginning Sunday wristbands are required for access to the grounds. There isn't actually a Sunday wristband though, as others have said, it's really just the Monday band. The break even for the weekly wristband is 4 days I believe. Bottom line: just get your Monday wristband when you do your camping reservation and you're good to go with no extra cost. Bob On Fri, Jul 21, 2017 at 2:25 PM Bob Leffler wrote: > The bands actually say sun/mon too. See you Sunday! > > Get Outlook for iOS > ------------------------------ > *From:* owner-rv10-list-server(at)matronics.com < > owner-rv10-list-server(at)matronics.com> on behalf of Marcus Cooper < > cooprv7(at)yahoo.com> > *Sent:* Friday, July 21, 2017 2:29:07 PM > *To:* rv10-list(at)matronics.com > > *Subject:* Re: RV10-List: Re: 2017 AirVenture RV-10 Dinner/Social > > Thanks, I had called EAA headquarters and they said nothing about the > Monday band working on Sunday. We will be there just in time for the RV- 10 > dinner so I doubt we will need any more food. I had the impression the > only thing to see was airplanes arriving which we can do from our > airplane. Thanks for the heads up about the Monday bands working. > > Marcus > > > On Jul 21, 2017, at 2:10 PM, Bob Leffler wrote: > > There is plenty to see on Sunday. > > Things changed a couple years ago. Most of the food places are now open > on the weekend. > > You use your Monday band to gain access on Sunday. Nothing to purchase > for Sunday. > > I'll be arriving HBC Saturday morning, weather permitting. > > Get Outlook for iOS > _____________________________ > From: Marcus Cooper <cooprv7(at)yahoo.com> > Sent: Friday, July 21, 2017 1:55 PM > Subject: Re: RV10-List: Re: 2017 AirVenture RV-10 Dinner/Social > To: > > > Bob and any others in the know, > > I have an odd question, but since we are going to be arriving Sunday > afternoon and camping with our airplane in the homebuilt section and > nothing is really open yet on Sunday, is there any benefit to getting sho w > tickets for Sunday? Looks like we can just walk over to the camping area > where you are setup for the dinner. I don=99t want to be too cheap, but don=99t > see the need to spend $19 each just to cut through either. > > Thanks, > Marcus > > > On Jul 17, 2017, at 11:59 PM, bcondrey wrote: > > > Just to have all info in the same thread... > > Location is between 51st & 52nd streets, just south of Lindbergh in Camp > Scholler. Start time still 5:30. As in years past, RV-10 > builders/flyers/dreamers are welcome to use the common area we've set up > for socializing before during the week of the show. We're on site now and > have tables and shade ready to go. > > A few have asked about cost - A few generous vendors contribute to help > facilitate our gathering and there will be a free will donation box > available. There isn't a "recommended" amount and we don't keep score, ju st > whatever you feel like contributing. This is absolutely a zero profit > venture, any funds remaining after dinner expenses are covered are rolled > over into the next year as "seed funds". > > We started putting this together in the very early RV-10 years as a way > for us early builders to meet and exchange ideas. We've kept it going > because there is a constant stream of new builders that can benefit. It's > also RV-10 related chatter every night, a chance to reconnect with people > and a chance to meet new builders. > > A few have asked about cost - A few generous vendors contribute to help > facilitate our gathering and there will be a free will donation box > available. There isn't a "recommended" amount and we don't keep score, ju st > whatever you feel like contributing. This is absolutely a zero profit > venture, any funds remaining after expenses are covered are just rolled > over into the next year. > > > Bob (and Gary) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471127#471127 > > > ========== > -List" x-apple-data-detectors="true" x-apple-data-detectors-type="lin k" > x-apple-data-detectors-result="6"> > http://www.matronics.com/Navigator?RV10-List > ========== > ta-detectors="true" x-apple-data-detectors-type="link" > x-apple-data-detectors-result="7"> http://forums.matronics.com > ========== > -detectors="true" x-apple-data-detectors-type="link" > x-apple-data-detectors-result="8"> http://wiki.matronics.com > ========== > x-apple-data-detectors="true" x-apple-data-detectors-type="link" > x-apple-data-detectors-result="9"> http://www.matronics.com/contributio n > ========== > > ________________________________________________________________________________
Date: Jul 23, 2017
Subject: Re: Oshkosh Dinner?
Bob, I was not sure if we would make it today or not. There were 4 of us in my RV-10. Counting a friend who is driving in today, please add 6 to your headcount including 3 same kids. Bruce Hoppe N720JH Sent from my iPhone > On Jul 17, 2017, at 10:37 PM, bcondrey wrote: > > > There isn't a "sign up" for the dinner, we're just trying to get a head count to make sure we've got a good estimate for food. > > The social/dinner was initially posted a while back on VAF and here. I'll bump the original post so everybody will see it. We're already on-site and the event will be I very close to where we've been in prior years; in Camp Scholler between 51st & 52nd streets, immediately south of Lindbergh. > > Bob > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471125#471125 > > > > > > > > > ________________________________________________________________________________
Subject: Oshkosh Sunday or Monday Ride East Needed
Date: Jul 24, 2017
I made an audible, and will be flying to OSH with a friend from AZ Friday. Is anyone headed East with an open seat Sunday or Monday? I am going to NJ, but anywhere from ATL to Boston could work. Thanks Frank 908 five seven 7 one six 2 5 -------- Frank Dombroski Multiple Offender RV-8, 7A, 10 x 2 RV-10 2.0 N46VT 2015 KSMQ Somerset Airport NJ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471267#471267 ________________________________________________________________________________
Subject: Re: Alternator
Date: Jul 24, 2017
Josh, Where did you get the mounting hardware for the LUV alternator. Did the Van's BRACKET KIT FOR GENERIC NIPPON DENSO ALT work? unitink72(at)gmail.com wrote: > I've done a lot of research on the subject. The best option I've found is the Autozone 14118 from a 1976 Chevy Luv. 60 Amp, turns the right way, and externally regulated. I'm not sure why its not more popular unless there's something I'm missing. > > -Josh > > > -------- Larry Rosen #40356 N205EN (reserved) <http> Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471269#471269 ________________________________________________________________________________
Date: Jul 25, 2017
Subject: Any Minimax tug comments?
Can anyone give a pirep on Minimax's tug for the -10? (www.minimaxtug.com) Looks like a pretty good product. I'm a little concerned about how well it attaches to the nose wheel since if it came off it'd make a big mess. Any input would be much appreciated! --Dave ________________________________________________________________________________
Date: Jul 25, 2017
Subject: Re: Any Minimax tug comments?
Sorry, make that www.minimaxtugs.com On Mon, Jul 24, 2017 at 22:33 David Saylor wrote: > Can anyone give a pirep on Minimax's tug for the -10? > > (www.minimaxtug.com) > > Looks like a pretty good product. I'm a little concerned about how well it > attaches to the nose wheel since if it came off it'd make a big mess. Any > input would be much appreciated! > > --Dave > > ________________________________________________________________________________
Date: Jul 25, 2017
I had one of the drill motor versions for my 10. I reviewed it on VAF, but can't find the post. It was back in 2013. In a nutshell, it just did not have enough power and had a difficult time getting traction. It required significant down pressure on the arm to keep the wheels from spinning. I returned it.... -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471273#471273 ________________________________________________________________________________
Date: Jul 26, 2017
Thanks Bill, that's great input. Did yours have the Milwaukee motor, or the Dewalt? They have a pretty big honkin Milwaukee on it now, but some still use the smaller Dewalt. Not that it would fix the downforce issue. -Dave On Tue, Jul 25, 2017 at 9:28 AM bill.peyton wrote: > > I had one of the drill motor versions for my 10. I reviewed it on VAF, > but can't find the post. It was back in 2013. In a nutshell, it just did > not have enough power and had a difficult time getting traction. It > required significant down pressure on the arm to keep the wheels from > spinning. I returned it.... > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471273#471273 > > ________________________________________________________________________________
Subject: Aveo Conforma Zip Tips
Date: Jul 28, 2017
Hi All I am back from KOSH and am wondering if anyone has installed the Aveo Conforma Zip Tips. They look like a very cool product. For that reason I'd be interested in any comments regarding performance / install etc. Cheers Les C-GCWZ Flying C-GROK Some Assembly required Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471328#471328 ________________________________________________________________________________
Subject: Many Thanks
Date: Jul 28, 2017
Hi I'd like to give a shout out to Bob Condrey and others who organized the Sunday RV10 dinner at KOSH. As in previous years it was great to meet old friends, meet new ones and chat face to face. Cheers Les C-GCWZ Flying C-GROK Some Assembly required Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471329#471329 ________________________________________________________________________________
Date: Jul 29, 2017
Subject: Re: Aveo Conforma Zip Tips
I'd be interested to hear of your experience with them Les, they look great. Warm regards Patrick > On 28 Jul 2017, at 23:54, kearney wrote: > > > Hi All > > I am back from KOSH and am wondering if anyone has installed the Aveo Conforma Zip Tips. They look like a very cool product. For that reason I'd be interested in any comments regarding performance / install etc. > > Cheers > > Les > C-GCWZ Flying > C-GROK Some Assembly required > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471328#471328 > > > > > > > > > ________________________________________________________________________________
Date: Jul 28, 2017
I don't have them installed but I bought them after seeing them in Oshkosh. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471340#471340 ________________________________________________________________________________
Subject: OSH stats
Date: Jul 29, 2017
Getting the logbook up to date and came up with a few stats. This last OSH trip from Mesa AZ KFFZ Tallied the following. I have a Barrett IO540 with 9.1 pistons, bendix FI, and bendix 1200 mags. I have A/C which was on at least 80% of the time. I had a brief divert into DBQ when OSH dropped to IFR and I didn't have a reservation. 18.4 Hobbs 16.8 Air 183.6 gallons burned 10.92 gallons per flight hour. I always run ROP. No squawks for the trip. These are amazing machines. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471343#471343 ________________________________________________________________________________
Date: Jul 29, 2017
Subject: Re: OSH stats
Yes they are. What altitudes did you use? Is your a/c electric or engine driven? Glad you had a safe trip. Albert Gardner RV-10 N991RV Yuma, AZ ---- woxofswa wrote: > > Getting the logbook up to date and came up with a few stats. > This last OSH trip from Mesa AZ KFFZ > Tallied the following. I have a Barrett IO540 with 9.1 pistons, bendix FI, and bendix 1200 mags. I have A/C which was on at least 80% of the time. I had a brief divert into DBQ when OSH dropped to IFR and I didn't have a reservation. > > 18.4 Hobbs > > 16.8 Air > > 183.6 gallons burned > > 10.92 gallons per flight hour. I always run ROP. > > No squawks for the trip. These are amazing machines. > > -------- > Myron Nelson > Mesa, AZ > Flew May 10 2014 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471343#471343 > > > > > > > > > ________________________________________________________________________________
Date: Jul 29, 2017
Altitudes really varied do to the weather. Anywhere from 4500 over the plains to 14500 over the Rockies. Probably averaged 7-8k for the trip. A/C is Airflow Systems engine driven. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471345#471345 ________________________________________________________________________________
Subject: Re: Many Thanks
Date: Jul 29, 2017
I agree. I arrived late do to a simultaneous event, but it was great to be there and I really appreciate the amount of work it takes to put that on. Well done. Thanks. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471348#471348 ________________________________________________________________________________
Date: Jul 30, 2017
What are they worth if you don't mind me asking please? Warm regards Patrick > On 29 Jul 2017, at 15:25, jeffwhip wrote: > > > I don't have them installed but I bought them after seeing them in Oshkosh. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471340#471340 > > > > > > > > > ________________________________________________________________________________
Date: Jul 30, 2017
Can't tell you what they may or may not be worth to the individual buyer. The asking price is $2200. I didn't ask if that was one wing or both. They look great, the lights are bright...but not going to do another set of wing tips and pay for another full set of lights, whether it is $2200 or $4400. By the time you factor in labor getting the fit just right with both the wing and aileron alignment, get all the nut plates done, and in my case installing Archer antennas...it would be easier to rework the glass where the lights are installed. On 7/29/2017 9:51 PM, Patrick Pulis wrote: > > What are they worth if you don't mind me asking please? > > Warm regards > > Patrick > >> On 29 Jul 2017, at 15:25, jeffwhip wrote: >> >> >> I don't have them installed but I bought them after seeing them in Oshkosh. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=471340#471340 >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: PlanePower - won't repair their own alternators. B&C will.
Date: Jul 31, 2017
At about 800 hours tach time, 950 hrs hobbs time, my Planepower alternator dropped to 1/2 output (26-28 Amp) maximum output enroute to OSH last week. I spoke to PlanePower's reps at OSH last week (including the alternator product line lead). Here's the summary: - PlanePower suggests it's either a diode failure, or (more likely) a failure of part of the stator (due to a known issue with PlanePower alternators manufactured in the past). - PlanePower won't repair this alternator. - PlanePower won't repair the new version that they currently sell for RV's. "It's not worth our time." - PlanePower won't offer any consideration or discount for those who purchased an alternator that failed. This is consistent with other reports I've heard regarding Hartzell Engine Technology (PlanePower owner) customer service. So I spoke to B & C about their alternator. Yes, they offer repair service. Yes, they'll overhaul or IRAN their alternator. I bought a B&C alternator and external controller at OSH. I'd be better off right now if I'd just spent the extra money on a B&C in the first place. -- Tim Lewis -- HEF (Manassas, VA) A&P RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 960 hrs ________________________________________________________________________________
Subject: MT prop governor failure - results of discussion with MT rep
at OSH
Date: Jul 31, 2017
As some have noted, MT's service bulletin 31 (http://www.mt-propeller.com/pdf/sbs/sb31.pdf) says the MT governor flyweight failure problem applies to engines "modified with electronic ignitions or higher compression pistons." At least one of the RVs that had an MT governor fail had dual magnetos and stock pistons. It's been reported on VAF that this has been brought to MT's attention. MT has not changed the service bulletin in the intervening months. Based on MT's unwillingness to honestly describe the failure condition in their service bulletin, I lost confidence in MT and pulled the MT governor from my plane in January. I replaced it with a PCU 5000, which has noticeably better performance than the MT governor (the PCU doesn't have the rpm hunting that the MT had). At OSH this year, I spoke with MT about the fact that their SB is misleading, in that there have been failures in engines without either electronic ignition or high compression pistons. It was amazing to hear the blamestorming from the German-accented MT rep at OSH. "What about McCauley governor failures" "What about Whirlwind propeller failures." I pointed out that the issue at hand was MT's failure to publish an honest, complete service bulletin. The MT rep continued to attack other products, rather than address MT's Service Bulletin shortcomings. I'm glad I got rid of the MT governor on my plane several months ago. Based on the behavior of MT on this issue, I'll advise all prospective builders I meet not to use MT products. -- Tim Lewis -- HEF (Manassas, VA) A&P RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 960 hrs ________________________________________________________________________________
Date: Jul 31, 2017
Subject: Re: PlanePower - won't repair their own alternators. B&C will.
I have 1100 hours on my B&C alternators and no problem. This alternator is used by many companies flight schools. Get the Best, David Sent from my iPad > On Jul 31, 2017, at 6:15 PM, Tim Lewis wrote: > > > At about 800 hours tach time, 950 hrs hobbs time, my Planepower alternator dropped to 1/2 output (26-28 Amp) maximum output enroute to OSH last week. I spoke to PlanePower's reps at OSH last week (including the alternator product line lead). Here's the summary: > > - PlanePower suggests it's either a diode failure, or (more likely) a failure of part of the stator (due to a known issue with PlanePower alternators manufactured in the past). > - PlanePower won't repair this alternator. > - PlanePower won't repair the new version that they currently sell for RV's. "It's not worth our time." > - PlanePower won't offer any consideration or discount for those who purchased an alternator that failed. > > This is consistent with other reports I've heard regarding Hartzell Engine Technology (PlanePower owner) customer service. > > So I spoke to B & C about their alternator. Yes, they offer repair service. Yes, they'll overhaul or IRAN their alternator. > > I bought a B&C alternator and external controller at OSH. I'd be better off right now if I'd just spent the extra money on a B&C in the first place. > > -- > Tim Lewis -- HEF (Manassas, VA) > A&P > RV-6A N47TD -- 1104 hrs - sold > RV-10 N31TD -- 960 hrs > > > > ________________________________________________________________________________
Subject: Re: MT prop governor failure - results of discussion with
MT rep at OSH
Date: Jul 31, 2017
I agree that the service bulletin is misleading. However, while my engine is pure stock, with 8.5:1 pistons and Bendix S1200 mags, MT both acknowledged my MT governor was in the group subject to failure, even though it is an 860-5, not an 860-3; and they performed the service bulletin on it for me. My cost was only shipping. The revised governor does have crisper control of rpm. Note that a significant portion of both brands are manufactured at the same place, by the same company. Kelly On 7/31/2017 3:17 PM, Tim Lewis wrote: > > As some have noted, MT's service bulletin 31 > (http://www.mt-propeller.com/pdf/sbs/sb31.pdf) says the MT governor > flyweight failure problem applies to engines "modified with electronic > ignitions or higher compression pistons." At least one of the RVs that > had an MT governor fail had dual magnetos and stock pistons. It's been > reported on VAF that this has been brought to MT's attention. MT has not > changed the service bulletin in the intervening months. > > Based on MT's unwillingness to honestly describe the failure condition > in their service bulletin, I lost confidence in MT and pulled the MT > governor from my plane in January. I replaced it with a PCU 5000, which > has noticeably better performance than the MT governor (the PCU doesn't > have the rpm hunting that the MT had). ________________________________________________________________________________
Subject: Re: MT prop governor failure - results of discussion with MT
re
Date: Jul 31, 2017
Hi Kelley When this debacle started I spoke to APS and confirmed that the PCU5000x and MT governors have no parts in common. They are different designs. If I recall the conversation correctly, when MT started with their own design, they also started their own manufacturing. Cheers Les C-GCWZ Flying C-GROK Some assembly required Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471381#471381 ________________________________________________________________________________
Date: Jul 31, 2017
MT re Talk to Myron, he gained much expertise from his debacle with governor failure. MT originally did not make their own governor. My understanding is that when they started making their own, that they still purchase some of the parts from the Czech supplier that had been producing them. If you physically compare to PCU, they are extremely similar. -sent from the I-droid implanted in my forearm On Mon, Jul 31, 2017 at 6:59 PM, kearney wrote: > > Hi Kelley > > When this debacle started I spoke to APS and confirmed that the PCU5000x and MT governors have no parts in common. They are different designs. If I recall the conversation correctly, when MT started with their own design, they also started their own manufacturing. > > Cheers > > Les > > C-GCWZ Flying > C-GROK Some assembly required > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471381#471381 > > ________________________________________________________________________________
Date: Aug 01, 2017
Yes - mucho kurdos. It was a most enjoyable event with great attendance. Hope to see you all next year. Even picked up a maintenance tip! -------- See you OSH '17 Q/B - flying 7 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471396#471396 ________________________________________________________________________________
Subject: If anyone can help - Aircraft value
Date: Aug 01, 2017
I have a 8 year old RV10 (400hrs) set up for VFR with one Advanced Flight Systems early (3500) EFIS. I arrived home from OSH to find a tax bill valuing my plane at $180,000. I feel that the value is closer to $140K or $150K. Does anyone out there have info on REAL sale prices that I can present to the assessor to reflect the real value of my plane. (PS- I am insured for $150K) -------- See you OSH '17 Q/B - flying 7 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471397#471397 Attachments: http://forums.matronics.com//files/img_0148_992.jpg ________________________________________________________________________________
Date: Aug 01, 2017
Subject: Re: If anyone can help - Aircraft value
Contact me off list and I should be able to help. I will need a lot more details, of course, but I should be able to provide an appraisal. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Aug 1, 2017, at 10:53 AM, AirMike wrote: > > > I have a 8 year old RV10 (400hrs) set up for VFR with one Advanced Flight Systems early (3500) EFIS. I arrived home from OSH to find a tax bill valuing my plane at $180,000. I feel that the value is closer to $140K or $150K. Does anyone out there have info on REAL sale prices that I can present to the assessor to reflect the real value of my plane. (PS- I am insured for $150K) > > -------- > See you OSH '17 > Q/B - flying 7 yrs. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471397#471397 > > > > > Attachments: > > http://forums.matronics.com//files/img_0148_992.jpg > > > > > > ________________________________________________________________________________
Date: Aug 01, 2017
I would suggest contacting the EAA for assistance in arguments to use, such as there are no two identical homebuilt aircraft, making it impossible to have comparables. Sounds like someone took the current quick build price, added new engine price and a typical modern avionics price, plus a bunch for labor. I have an unpainted quick build, with very full complement of IFR avionics, and I don't think I have much over $150K in it. Depreciation on manufactured aircraft the first few years is very steep. Compare the price of a 2005 Cirrus with a new one, for example. On 8/1/2017 11:17 AM, Jesse Saint wrote: > > Contact me off list and I should be able to help. I will need a lot more details, of course, but I should be able to provide an appraisal. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > >> On Aug 1, 2017, at 10:53 AM, AirMike wrote: >> >> >> I have a 8 year old RV10 (400hrs) set up for VFR with one Advanced Flight Systems early (3500) EFIS. I arrived home from OSH to find a tax bill valuing my plane at $180,000. I feel that the value is closer to $140K or $150K. Does anyone out there have info on REAL sale prices that I can present to the assessor to reflect the real value of my plane. (PS- I am insured for $150K) >> >> -------- >> See you OSH '17 >> Q/B - flying 7 yrs. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=471397#471397 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/img_0148_992.jpg >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Aug 01, 2017
I have advised other builders to be proactive in filing their sales tax relating to the recent FAA registration of their 'flivver'. Not an RV-10 or Cessna 172 but 'flivver'. In FL (where I live) the FL department of revenue gets new registration information from the FAA. Then they check to see if you paid sales tax related to the airplane (which you should retain a copy of) whether it's a homebuilt or certified airplane. If they don't find payment of sales tax, they open their recent copy of Trade-a-plane and look up the model (RV-10) that is on the FAA registration and send a bill for the 'asking price' it finds .... and I bet if there are two listings, they pick the higher dollar one. They'll never find a 'flivver' in TAP. Then you get the 'nastygram' requesting your payment of tax, interest, and penalties. So, what's a person to do if you're not proactive? You can collect copies bills of sale for the kit , engine, avionics and submit some % of that total to your sales tax people with a check for your share of the tax and that will usually be the end of it. You can usually under-pay some but those guys aren't stupid and you may get a second letter because you shaved too much off. If they can't find a value for the 'flivver' you registered then you'll have a lot of leeway ..... but you might have to substantiate that value or get an appraisal from your A&P. When I register my plane (hopefully next year) it'll have a nebulous model such as 'LINN model X' or some sort, and I'll be proactive in paying some sales tax. Also, remember that Van doesn't support your bird being registered as an RV-(X) if you made some major mods. Linn On 8/1/2017 11:53 AM, AirMike wrote: > > I have a 8 year old RV10 (400hrs) set up for VFR with one Advanced Flight Systems early (3500) EFIS. I arrived home from OSH to find a tax bill valuing my plane at $180,000. I feel that the value is closer to $140K or $150K. Does anyone out there have info on REAL sale prices that I can present to the assessor to reflect the real value of my plane. (PS- I am insured for $150K) > > -------- > See you OSH '17 > Q/B - flying 7 yrs. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471397#471397 > > > Attachments: > > http://forums.matronics.com//files/img_0148_992.jpg > > ________________________________________________________________________________
Date: Aug 01, 2017
I don't know about NV, but typical property taxes are around 1%, so ask yourself how much effort and pain you want to put in for $300 a year. You don't say what or if you paid last year - you certainly don't want to open up a can of worms. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471411#471411 ________________________________________________________________________________
Subject: FS: Vertical Power VP-200 Control Unit and Switch Panel
Date: Aug 02, 2017
FEDEX lost my display unit after a repair so I'm replacing the entire VP-200 system. CU - $1035 SP - $250 shipping included to US locations. -------- Todd Stovall aka Auburntsts on EAA, AOPA, and VAF RV-10 N728TT -- Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471429#471429 ________________________________________________________________________________
re
Date: Aug 02, 2017
So if anyone is interested, I'm selling a brand new MT P860-3 prop gov for $950. It was never installed so has 0 hours and was built in 2016 so is unaffected by SB 31. -------- Todd Stovall aka Auburntsts on EAA, AOPA, and VAF RV-10 N728TT -- Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471439#471439 Attachments: http://forums.matronics.com//files/2017_01_08_090710_1928481_869.jpg ________________________________________________________________________________
Date: Aug 02, 2017
Sorry Bob, I realized I sent to you instead of Mike. I'll send to him. Sent from my iPhone > On Aug 1, 2017, at 5:57 PM, Bob Turner wrote: > > > I don't know about NV, but typical property taxes are around 1%, so ask yourself how much effort and pain you want to put in for $300 a year. You don't say what or if you paid last year - you certainly don't want to open up a can of worms. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471411#471411 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 02, 2017
That's okay. I thought you were him and sent you the reply I meant for him, if the email had been from him! -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471455#471455 ________________________________________________________________________________
Date: Aug 02, 2017
Cost is $3k for lights and tips. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471456#471456 ________________________________________________________________________________
Date: Aug 02, 2017
Is that the north of the border price? I was quoted 2200. On 8/2/2017 6:39 PM, kearney wrote: > > Cost is $3k for lights and tips. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471456#471456 > > > > > > > > > ________________________________________________________________________________
Date: Aug 02, 2017
Cost is $3k for lights and tips. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471457#471457 ________________________________________________________________________________
Date: Aug 04, 2017
Yikes, that's up there, but they do look great. Warm regards Patrick > On 3 Aug 2017, at 11:16, kearney wrote: > > > Cost is $3k for lights and tips. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471457#471457 > > > > > > > > > ________________________________________________________________________________
Subject: Paint vs Wrap
Date: Aug 04, 2017
Hi A chap on the local field is wrapping his RV with vinyl rather using paint Has anyone done this with a -10. If so was the result as expected? I'd be interested in knowing how long it took and what the cost was. I have tried contacting Aircraft Wraps in Florida but haven't been able to get them to return a call. Also, recommendations on a shop to see would be useful. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471509#471509 ________________________________________________________________________________
Date: Aug 05, 2017
Subject: Re: Paint vs Wrap
I have seen one and wasn't impressed. It looked great online and in person it was a different story. Kinda like online dating........so I've been told. :) I don't know what the weight difference between the two would be, but I saw enough of the wrapped plane to know it's not anywhere close to a good (or even bad) paint job. And I can't imagine its any lighter than paint. I suppose they'd be fine for accents and stripes, etc. But a full wrap leaves a whole lot to be desired....... unless you're just looking to attract attention online and not really let people see it in person. :) Sent from my iPhone > On Aug 5, 2017, at 1:35 AM, kearney wrote: > > > Hi > > A chap on the local field is wrapping his RV with vinyl rather using paint > > Has anyone done this with a -10. If so was the result as expected? I'd be interested in knowing how long it took and what the cost was. > > I have tried contacting Aircraft Wraps in Florida but haven't been able to get them to return a call. > > Also, recommendations on a shop to see would be useful. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471509#471509 > > > > > > > > > ________________________________________________________________________________
Date: Aug 05, 2017
I'd have to agree wholeheartedly. The ones that I've seen don't rival even a poor paint job. For accent stripes, great, but anytime you plan to wrap it around something like the Cowl inlets, it's going to look like crap. The most I would do with vinyl is paint the airplane a single solid color, and then throw on vinyl striping. For that, it could be pretty nice. Especially for the N number, if you are like a buddy of mine who would really love to change his and number. Wink wink L. Tim > On Aug 5, 2017, at 10:00 AM, Phillip Perry wrote: > > > I have seen one and wasn't impressed. It looked great online and in person it was a different story. Kinda like online dating........so I've been told. :) > > I don't know what the weight difference between the two would be, but I saw enough of the wrapped plane to know it's not anywhere close to a good (or even bad) paint job. And I can't imagine its any lighter than paint. > > I suppose they'd be fine for accents and stripes, etc. But a full wrap leaves a whole lot to be desired....... unless you're just looking to attract attention online and not really let people see it in person. :) > > > > > > Sent from my iPhone > >> On Aug 5, 2017, at 1:35 AM, kearney wrote: >> >> >> Hi >> >> A chap on the local field is wrapping his RV with vinyl rather using paint >> >> Has anyone done this with a -10. If so was the result as expected? I'd be interested in knowing how long it took and what the cost was. >> >> I have tried contacting Aircraft Wraps in Florida but haven't been able to get them to return a call. >> >> Also, recommendations on a shop to see would be useful. >> >> Cheers >> >> Les >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=471509#471509 >> >> >> >> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Aug 05, 2017
Yeah L. ;) Sent from my iPad > On Aug 5, 2017, at 12:14 PM, Tim Olson wrote: > > > I'd have to agree wholeheartedly. The ones that I've seen don't rival even a poor paint job. For accent stripes, great, but anytime you plan to wrap it around something like the Cowl inlets, it's going to look like crap. The most I would do with vinyl is paint the airplane a single solid color, and then throw on vinyl striping. For that, it could be pretty nice. Especially for the N number, if you are like a buddy of mine who would really love to change his and number. Wink wink L. > > Tim > >> On Aug 5, 2017, at 10:00 AM, Phillip Perry wrote: >> >> >> I have seen one and wasn't impressed. It looked great online and in person it was a different story. Kinda like online dating........so I've been told. :) >> >> I don't know what the weight difference between the two would be, but I saw enough of the wrapped plane to know it's not anywhere close to a good (or even bad) paint job. And I can't imagine its any lighter than paint. >> >> I suppose they'd be fine for accents and stripes, etc. But a full wrap leaves a whole lot to be desired....... unless you're just looking to attract attention online and not really let people see it in person. :) >> >> >> >> >> >> Sent from my iPhone >> >>> On Aug 5, 2017, at 1:35 AM, kearney wrote: >>> >>> >>> Hi >>> >>> A chap on the local field is wrapping his RV with vinyl rather using paint >>> >>> Has anyone done this with a -10. If so was the result as expected? I'd be interested in knowing how long it took and what the cost was. >>> >>> I have tried contacting Aircraft Wraps in Florida but haven't been able to get them to return a call. >>> >>> Also, recommendations on a shop to see would be useful. >>> >>> Cheers >>> >>> Les >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=471509#471509 >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Aug 05, 2017
I wasn't impressed by the wraps either. Looks great on pictures. Still have to paint it or at least prime it and every unevenness in that shows through the vinyl. And yeah N numbers are easier to change if they are not painted on with one color and two different shadows. But who changes N numbers anyway :) And who is this L. guy? :) tomhanaway wrote: > > Yeah L. > ;) > > > > Sent from my iPad > > > > On Aug 5, 2017, at 12:14 PM, Tim Olson wrote: > > > > > > > > I'd have to agree wholeheartedly. The ones that I've seen don't rival even a poor paint job. For accent stripes, great, but anytime you plan to wrap it around something like the Cowl inlets, it's going to look like crap. The most I would do with vinyl is paint the airplane a single solid color, and then throw on vinyl striping. For that, it could be pretty nice. Especially for the N number, if you are like a buddy of mine who would really love to change his and number. Wink wink L. > > > > Tim > > > > -------- Lenny Iszak Palm City, FL 2014 RV-10, N311LZ - 300 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471523#471523 ________________________________________________________________________________
Date: Aug 05, 2017
Hmmm, I don't know how we got to online dating from a thread on aircraft wrapping but I supposed that is a topic for another thread. I appreciate the comments. I may try to check out examples that have been done by an aircraft wrap shop. I need to find a paint alternative as there are no paint shops near where I am.. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471525#471525 ________________________________________________________________________________
Date: Aug 05, 2017
So what do you prime it with?? 8^)) Do you do a prime and base coat, or a two step epoxy primer without a base coat? Or can you just polish the bare aluminum and wrap that. Which brand and type of primer? It has to be at least 10 years since the last primer wars. ;-) -sent from the I-droid implanted in my forearm On Sat, Aug 5, 2017 at 12:32 PM, Lenny Iszak wrote: > > I wasn't impressed by the wraps either. Looks great on pictures. Still have to paint it or at least prime it and every unevenness in that shows through the vinyl. > And yeah N numbers are easier to change if they are not painted on with one color and two different shadows. But who changes N numbers anyway :) > And who is this L. guy? :) > > > tomhanaway wrote: >> >> Yeah L. >> ;) >> >> >> >> Sent from my iPad >> >> >> > On Aug 5, 2017, at 12:14 PM, Tim Olson wrote: >> > >> > >> > >> > I'd have to agree wholeheartedly. The ones that I've seen don't rival even a poor paint job. For accent stripes, great, but anytime you plan to wrap it around something like the Cowl inlets, it's going to look like crap. The most I would do with vinyl is paint the airplane a single solid color, and then throw on vinyl striping. For that, it could be pretty nice. Especially for the N number, if you are like a buddy of mine who would really love to change his and number. Wink wink L. >> > >> > Tim >> > >> >> > > > -------- > Lenny Iszak > Palm City, FL > 2014 RV-10, N311LZ - 300 hrs > > _- ________________________________________________________________________________
Date: Aug 05, 2017
I maintain a -10 that is wrapped. It is not as nice as paint, probably, although I have not seen it after being washed, which would make a difference. The compound curves would be really hard, and the one I'm talking about has a painted cowl. I think you would be happier with paint. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Aug 5, 2017, at 1:35 AM, kearney wrote: > > > Hi > > A chap on the local field is wrapping his RV with vinyl rather using paint > > Has anyone done this with a -10. If so was the result as expected? I'd be interested in knowing how long it took and what the cost was. > > I have tried contacting Aircraft Wraps in Florida but haven't been able to get them to return a call. > > Also, recommendations on a shop to see would be useful. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471509#471509 > > > > > > > > > ________________________________________________________________________________
Date: Aug 06, 2017
Subject: GPS antenna mounting
I would like to ask, of those who mounted your GPS antenna on the cabin top, are you getting the performance from it that you expected? Did you install a ground plane? Also, what screws did you use to mount it. I have been looking for some MS24693-C286 screws and am not coming up with anything. Thanks. Ed Godfrey ________________________________________________________________________________
Date: Aug 06, 2017
Subject: Re: GPS antenna mounting
I have been very happy with my performance so far. The only thing I wish I had considered was installing them under the glass cabin top and inside my overhead air console. It would have been nice to not ouch a hole in the top of the plane and also protect the antenna from the WX and UV; hopefully extending the life of the antenna and rescuing another leak point to seal up. But the top has served me well to this point. Others might be able to comment on the performance inside the overhead air (if you have it). Just something to consider. Phil Sent from my iPhone > On Aug 6, 2017, at 11:42 AM, Ed Godfrey wrote: > > > I would like to ask, of those who mounted your GPS antenna on the cabin top, are you getting the performance from it that you expected? Did you install a ground plane? Also, what screws did you use to mount it. I have been looking for some MS24693-C286 screws and am not coming up with anything. Thanks. > > Ed Godfrey > > > ________________________________________________________________________________
Date: Aug 06, 2017
I look at GPS antenna location based on the purpose and approval basis of the antenna. For my GTN650 to meet IFR performance standards, I mounted on cabin top with the recommended ground plane (partly sheet metal, partly aluminum foil) per Garmin instructions. For the GPS that drives my EFIS display, I mounted it in front of the firewall, perhaps 10", underneath the cowling. If mounting GPS antenna to drive ADS-B out, I would try to follow manufacturer's recommendations. The Garmin needs a better view of the sky and takes longer to lock on than my Dynon, but it has more required validation to perform. On 8/6/2017 9:42 AM, Ed Godfrey wrote: > > I would like to ask, of those who mounted your GPS antenna on the > cabin top, are you getting the performance from it that you expected? > Did you install a ground plane? Also, what screws did you use to mount > it. I have been looking for some MS24693-C286 screws and am not coming > up with anything. Thanks. > > Ed Godfrey > > > ________________________________________________________________________________
Date: Aug 06, 2017
I mounted mine on top of the skin, a foot behind the baggage bulkhead: 1. This area has metal skin so the ground plane is there. I did use a doubler. 2. My 420W required a certain MINIMUM coax run, so there was no "extra" coax involved in this location. 3. My guess was that there was slightly less drag in this location (top of the cabin is convex which will speed up the airflow a bit). Works fine. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471558#471558 ________________________________________________________________________________
Date: Aug 06, 2017
I did exactly the same thing Bob Turner did. Works great. David Maib > On Aug 6, 2017, at 7:43 PM, Bob Turner wrote: > > > I mounted mine on top of the skin, a foot behind the baggage bulkhead: > 1. This area has metal skin so the ground plane is there. I did use a doubler. > 2. My 420W required a certain MINIMUM coax run, so there was no "extra" coax involved in this location. > 3. My guess was that there was slightly less drag in this location (top of the cabin is convex which will speed up the airflow a bit). > > Works fine. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471558#471558 > > > > > > > > > ________________________________________________________________________________
Date: Aug 06, 2017
Bob and David, I was considering putting it back there, but I ran into issues with the separation of the GPS antenna, a comm antenna and the ELT antenna. Ed On 8/6/2017 7:09 PM, David Maib wrote: > > I did exactly the same thing Bob Turner did. Works great. > > David Maib > > >> On Aug 6, 2017, at 7:43 PM, Bob Turner wrote: >> >> >> I mounted mine on top of the skin, a foot behind the baggage bulkhead: >> 1. This area has metal skin so the ground plane is there. I did use a doubler. >> 2. My 420W required a certain MINIMUM coax run, so there was no "extra" coax involved in this location. >> 3. My guess was that there was slightly less drag in this location (top of the cabin is convex which will speed up the airflow a bit). >> >> Works fine. >> >> -------- >> Bob Turner >> RV-10 QB >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=471558#471558 >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Brake fluid seeping from master cylinders
Date: Aug 06, 2017
A few weeks ago, I discovered that I had a small brake fluid leak on the left brake of the pilot's side. It was on the upper (low pressure) port of the cylinder, and very small - probably less than a drop a day. I tightened the nut on the hose going to the elbow and that didn't seem to help, so I rotated the elbow another 360 degrees clockwise and that seemed to do the trick (though NPT threads mean I can't just tighten indiscriminately - I have to be careful not to over tighten, though it has to end up pointing upwards). In any event, I thought the problem was solved, but about a week ago I saw there was still some slight seepage. It hasn't been enough to cause a noticeable drip (at least not yet), but if I run my finger along the bottom lip of the cylinder, it comes away with a bit of brake fluid residue. And I noticed something similar on the copilot's side brakes too just recently, though they seemed dry before. Maybe the higher temperatures of summer caused a few things to resize a bit. In any case, I'm hesitant to just tighten all the fittings another 360 turn since I don't want to over tighten them and have the master cylinders crack. The seepage isn't when the brakes are used - at least, I can't detect any leaks specifically caused by putting pressure on the pedals. It's just that when the plane sits in the hangar for a few days, I can see residue building up. The current rate of seepage is so small (probably several days for one drop of brake fluid) that I don't really worry about having the reservoir run out between annuals or oil changes (I'm checking it every time I change oil and remove the top cowl and it doesn't seem to noticeably decrease). Is this something that anyone else has seen? I can live with it by just wiping down the cylinders every week or two. But in the effort to make things perfect, does anyone have any suggestions? I know Van's recommends strongly to not use Teflon tape on the fittings. I'm pretty sure I used Boelube at the time, though that was several years ago. Does its effectivity diminish over time? I can easily remove all the fittings and put more Boelube on the NPT threads if that likely help fix the problem, though the necessity of my having to re-bleed the brake lines after that disassembly gives me pause, especially since I think I used Boelube in the first place so I'm not sure it would help in the long term anyway. Everything is built exactly according to Van's plans, using the hoses, etc. they provided with the kit. I know lots of people use stainless braided hoses everywhere, but the problem seems to stem from the elbow fitting, not the hoses. Any suggestions? Thanks! Dan --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Date: Aug 06, 2017
Subject: Re: Brake fluid seeping from master cylinders
Use the liquid teflon sealants...that will do the trick. I think I use loctite 567 but the stuff you can buy at the auto parts store or farm and barn will do just fine. It's NOT the same as using teflon tape. Tim > On Aug 6, 2017, at 8:16 PM, Dan Charrois wrote: > > > A few weeks ago, I discovered that I had a small brake fluid leak on the left brake of the pilot's side. It was on the upper (low pressure) port of the cylinder, and very small - probably less than a drop a day. I tightened the nut on the hose going to the elbow and that didn't seem to help, so I rotated the elbow another 360 degrees clockwise and that seemed to do the trick (though NPT threads mean I can't just tighten indiscriminately - I have to be careful not to over tighten, though it has to end up pointing upwards). > > In any event, I thought the problem was solved, but about a week ago I saw there was still some slight seepage. It hasn't been enough to cause a noticeable drip (at least not yet), but if I run my finger along the bottom lip of the cylinder, it comes away with a bit of brake fluid residue. And I noticed something similar on the copilot's side brakes too just recently, though they seemed dry before. Maybe the higher temperatures of summer caused a few things to resize a bit. > > In any case, I'm hesitant to just tighten all the fittings another 360 turn since I don't want to over tighten them and have the master cylinders crack. The seepage isn't when the brakes are used - at least, I can't detect any leaks specifically caused by putting pressure on the pedals. It's just that when the plane sits in the hangar for a few days, I can see residue building up. The current rate of seepage is so small (probably several days for one drop of brake fluid) that I don't really worry about having the reservoir run out between annuals or oil changes (I'm checking it every time I change oil and remove the top cowl and it doesn't seem to noticeably decrease). > > Is this something that anyone else has seen? I can live with it by just wiping down the cylinders every week or two. But in the effort to make things perfect, does anyone have any suggestions? I know Van's recommends strongly to not use Teflon tape on the fittings. I'm pretty sure I used Boelube at the time, though that was several years ago. Does its effectivity diminish over time? I can easily remove all the fittings and put more Boelube on the NPT threads if that likely help fix the problem, though the necessity of my having to re-bleed the brake lines after that disassembly gives me pause, especially since I think I used Boelube in the first place so I'm not sure it would help in the long term anyway. > > Everything is built exactly according to Van's plans, using the hoses, etc. they provided with the kit. I know lots of people use stainless braided hoses everywhere, but the problem seems to stem from the elbow fitting, not the hoses. > > Any suggestions? > > Thanks! Dan > --- > Dan Charrois > President, Syzygy Research & Technology > Phone: 780-961-2213 > > > > > ________________________________________________________________________________
Date: Aug 06, 2017
Hi Dan I used this with great success. https://www.amazon.ca/Permatex-80632-Thread-Sealant-PTFE/dp/B000HBNTGY/ref=sr_1_7/136-4197055-7816439?ie=UTF8&qid=1502073596&sr=8-7&keywords=permatex+thread+sealant I had a similar issue where *apparently* I had a leak on the lower fitting of a cylinder in the starboard side. I did everything I could to fix it. As it turns out the leak was on the reservoir fitting that was spritzing small amounts of fluid onto the fitting. Talk about looking in the wrong place! Cheers Les C-GCWZ flying C-GROK some assembly required Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471574#471574 ________________________________________________________________________________
Date: Aug 06, 2017
As others said: Boelube is a lubricant. You want a pipe thread sealant. Apply sparingly, not on the first thread. You should have used a thread sealant on all your pipe threads (not teflon tape). -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471577#471577 ________________________________________________________________________________
Date: Aug 06, 2017
My ELT is 4 or 5 feet further aft, and I have no com antennas on top, so separation from com antennas may be a concern. Ed Godfrey wrote: > Bob and David, > I was considering putting it back there, but I ran into issues > with the separation of the GPS antenna, a comm antenna and the ELT antenna. > > Ed > > On 8/6/2017 7:09 PM, David Maib wrote: > > > > > > > I did exactly the same thing Bob Turner did. Works great. > > > > David Maib > > > > > > > On Aug 6, 2017, at 7:43 PM, Bob Turner wrote: > > > > > > > > > > > > I mounted mine on top of the skin, a foot behind the baggage bulkhead: > > > 1. This area has metal skin so the ground plane is there. I did use a doubler. > > > 2. My 420W required a certain MINIMUM coax run, so there was no "extra" coax involved in this location. > > > 3. My guess was that there was slightly less drag in this location (top of the cabin is convex which will speed up the airflow a bit). > > > > > > Works fine. > > > > > > -------- > > > Bob Turner > > > RV-10 QB > > > > > > > > > > > > > > > Read this topic online here: > > > > > > http://forums.matronics.com/viewtopic.php?p=471558#471558 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471578#471578 ________________________________________________________________________________
Date: Aug 06, 2017
Whoops - I misspoke. It wasn't Boelube I used on my pipe threads. I had the name on the brain because I'd recently used it to lubricate the piano hinge pins that go into the cowling. I can't recall exactly, but I think the stuff I used was EZ Turn Fuel lube (described as a lubricant/sealant).. it's in a tube and *very* gooey and sticky :-) ... not the Boelube that's blue, in a little jar, and oily. But with that said, it may not be the best product for the job. A thread sealant paste like Loctite 567 or Permatex 80632 as suggested here probably would be better suited. Just so long as it can handle brake fluid properly. Thanks, everyone! Dan > On 2017-Aug-06, at 10:10 PM, Bob Turner wrote: > > > As others said: Boelube is a lubricant. You want a pipe thread sealant. Apply sparingly, not on the first thread. You should have used a thread sealant on all your pipe threads (not teflon tape). > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471577#471577 > > > > > > > > > --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Date: Aug 07, 2017
Fuel lube is almost as bad. It's not a question of when it will leak, but more like when. It's a ticketing time bomb if you are using it as a thr ead sealant. I use a permatex thread sealant and haven't had any issues. Get Outlook for iOS _____________________________ From: Dan Charrois <dan(at)syz.com<mailto:dan(at)syz.com>> Sent: Monday, August 7, 2017 1:48 AM Subject: Re: RV10-List: Re: Brake fluid seeping from master cylinders om>> Whoops - I misspoke. It wasn't Boelube I used on my pipe threads. I had the name on the brain because I'd recently used it to lubricate the piano hing e pins that go into the cowling. I can't recall exactly, but I think the stuff I used was EZ Turn Fuel lube (described as a lubricant/sealant).. it's in a tube and *very* gooey and st icky :-) ... not the Boelube that's blue, in a little jar, and oily. But with that said, it may not be the best product for the job. A thread se alant paste like Loctite 567 or Permatex 80632 as suggested here probably w ould be better suited. Just so long as it can handle brake fluid properly. Thanks, everyone! Dan > On 2017-Aug-06, at 10:10 PM, Bob Turner > wrote: > lto:bobturner(at)alum.rpi.edu>> > > As others said: Boelube is a lubricant. You want a pipe thread sealant. A pply sparingly, not on the first thread. You should have used a thread seal ant on all your pipe threads (not teflon tape). > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471577#471577 > > --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Date: Aug 07, 2017
I started getting air in my lines that I couldn't keep out recently. I'd bleed the brakes but very soon there was some air in the lines. I removed the pilot sides master cylinders and put the copilot ones in their place. Seems to have fixed the problem. ________________________________________________________________________________
Date: Aug 07, 2017
My comm antennas are on the belly. My ELT antenna is closer to the GPS antenna than recommended. I've not had any discernible issues at all. David Maib > On Aug 7, 2017, at 12:22 AM, Bob Turner wrote: > > > My ELT is 4 or 5 feet further aft, and I have no com antennas on top, so separation from com antennas may be a concern. > > > > Ed Godfrey wrote: >> Bob and David, >> I was considering putting it back there, but I ran into issues >> with the separation of the GPS antenna, a comm antenna and the ELT antenna. >> >> Ed >> >>> On 8/6/2017 7:09 PM, David Maib wrote: >>> >>> >>> >>> I did exactly the same thing Bob Turner did. Works great. >>> >>> David Maib >>> >>> >>>> On Aug 6, 2017, at 7:43 PM, Bob Turner wrote: >>>> >>>> >>>> >>>> I mounted mine on top of the skin, a foot behind the baggage bulkhead: >>>> 1. This area has metal skin so the ground plane is there. I did use a doubler. >>>> 2. My 420W required a certain MINIMUM coax run, so there was no "extra" coax involved in this location. >>>> 3. My guess was that there was slightly less drag in this location (top of the cabin is convex which will speed up the airflow a bit). >>>> >>>> Works fine. >>>> >>>> -------- >>>> Bob Turner >>>> RV-10 QB >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=471558#471558 >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >> > > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471578#471578 > > > > > > > > > ________________________________________________________________________________
Date: Aug 07, 2017
I buried my GTN antenna in the cabin top above the access plate in the overhead console. Works flawlessly, no cutting of the outside skin necessary. Cheers, Frank -------- Frank Dombroski Multiple Offender RV-8, 7A, 10 x 2 RV-10 2.0 N46VT 2015 KSMQ Somerset Airport NJ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471587#471587 ________________________________________________________________________________
Date: Aug 07, 2017
ELT interference complaints are normally with com radios not GPS. 1st generation ELTs (designed circa 1973-75) were especially bad about being plagued by responding to strong broadcast signals, such as being near TV, radio stations, which would actually excite the oscillator in the ELT, rebroadcasting just enough signal to break squelch and interfere with reception and squelch on VHF com frequencies. My previous plane had this when all rod antennas (com, ELT and Loran) were on top of fuselage. Once Loran was eliminated and one com was moved to belly, almost all of problem went away. I do not know how much improvement has been designed into 2nd generation 121.5 or 406 ELTs. On 8/7/2017 6:31 AM, David Maib wrote: > > My comm antennas are on the belly. My ELT antenna is closer to the GPS antenna than recommended. I've not had any discernible issues at all. > > David Maib > > >> On Aug 7, 2017, at 12:22 AM, Bob Turner wrote: >> >> >> My ELT is 4 or 5 feet further aft, and I have no com antennas on top, so separation from com antennas may be a concern. ________________________________________________________________________________
Date: Aug 07, 2017
Frank It sounds a good idea but in that case the antenna cable will be hanging from the ceiling, or better said, from the access plate. Isn't that so? Carlos Enviado do meu iPhone No dia 07/08/2017, s 14:35, fdombroski escreveu: > > I buried my GTN antenna in the cabin top above the access plate in the overhead console. Works flawlessly, no cutting of the outside skin necessary. > Cheers, > Frank > > -------- > Frank Dombroski > Multiple Offender RV-8, 7A, 10 x 2 > RV-10 2.0 N46VT 2015 > KSMQ Somerset Airport NJ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471587#471587 > > > > > > > > > ________________________________________________________________________________
Subject: Re: FS: Vertical Power VP-200 Control Unit and Switch Panel
Date: Aug 07, 2017
Hi Todd I sent you a PM I'm interested Regards Mike -------- RV-10 builder (flying) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471599#471599 ________________________________________________________________________________
Date: Aug 07, 2017
Meeting with the assessor tomorrow. Can anyone tell me what their tax assessment is? ??? (assessed valuation) plus a short summary of their equipment and interior/exterior. 120K 130K 160K Any info would me helpful -------- See you OSH '17 Q/B - flying 7 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471604#471604 ________________________________________________________________________________
From: "John MacCallum" <john.maccallum(at)bigpond.com>
Date: Aug 08, 2017
I have had trouble with leaks in my Brake lines as well. The Co-Pilots Master Cylinders were leaking from the nipple joints. I followed the recommended practise of using a torque wrench set to the appropriate torque in conjunction with some Loctite thread sealant. Either I didn't put enough loctite on or the stuff that I used was old? I ended up re-installing the nipples on both sides with Permatex 56521. I might add that it also solved the fuel leak problems that I had with the Fuel pressure Sender and the fuel drain plugs in the wings. Cheers John MacCallum VH-DUU RV 10 # 41016 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ibspud(at)roadrunner.com Sent: Monday, 7 August 2017 7:58 PM Subject: Re: RV10-List: Brake fluid seeping from master cylinders I started getting air in my lines that I couldn't keep out recently. I'd bleed the brakes but very soon there was some air in the lines. I removed the pilot sides master cylinders and put the copilot ones in their place. Seems to have fixed the problem. ________________________________________________________________________________
Date: Aug 08, 2017
The antenna is flush with the inside surface, and the TNC is a 90 degree fitting. there is no clearance issue. The antenna and filler consume the void tightly, and a ground plate covers the inside skin cut out. Here is a photo prior to the ground/mount plate installation. Best, Frank -------- Frank Dombroski Multiple Offender RV-8, 7A, 10 x 2 RV-10 2.0 N46VT 2015 KSMQ Somerset Airport NJ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471613#471613 Attachments: http://forums.matronics.com//files/1461681089840_139.jpg ________________________________________________________________________________
Date: Aug 08, 2017
Frank, That's a clever use of what seems like wasted volume, but please consider that the thickness of the cabin top provides a structural function. Are you taking some measures to reinforce the compromised area, like a cover plate that acts as a doubler, or additional plies below the antenna? Of course we can do what we want, but it sure seems to me like that mod gives up some crash worthiness. --Dave On Tue, Aug 8, 2017 at 5:50 AM, fdombroski wrote: > > The antenna is flush with the inside surface, and the TNC is a 90 degree > fitting. there is no clearance issue. The antenna and filler consume the > void tightly, and a ground plate covers the inside skin cut out. > > Here is a photo prior to the ground/mount plate installation. > > Best, > Frank > > -------- > Frank Dombroski > Multiple Offender RV-8, 7A, 10 x 2 > RV-10 2.0 N46VT 2015 > KSMQ Somerset Airport NJ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471613#471613 > > > Attachments: > > http://forums.matronics.com//files/1461681089840_139.jpg > > ________________________________________________________________________________
Date: Aug 08, 2017
My -10: A/W certificate in May 2011. All new (avionics, engine) at that time. Current assessed value (CA) $155K. I think that's about right. Exterior paint: do-it-yourself, quality is poor if you get within 20 feet Interior: basic/bare, spray painted ceilings, no insulation, no window trim. (These two items tend to drive used prices) Avionics: Full IFR but last generation (e.g., GPS is 420W, not 650). GRT HX, HS; Dynon D6 backup; GArmin 420W, SL30; Trio Pro autopilot; Trig TT22 transponder; home made audio panel. Skyradar D2 for ADSB-in. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471630#471630 ________________________________________________________________________________
Date: Aug 09, 2017
Sounds about right. I had $150k on mine but should have had $180k because I greatly upgraded the radios. Insure it for what you have in it and then pray you never have to collect like I did. Sent from my iPad > On Aug 8, 2017, at 2:48 PM, Bob Turner wrote: > > > My -10: > A/W certificate in May 2011. All new (avionics, engine) at that time. > Current assessed value (CA) $155K. I think that's about right. > Exterior paint: do-it-yourself, quality is poor if you get within 20 feet > Interior: basic/bare, spray painted ceilings, no insulation, no window trim. > (These two items tend to drive used prices) > Avionics: Full IFR but last generation (e.g., GPS is 420W, not 650). GRT HX, HS; Dynon D6 backup; GArmin 420W, SL30; Trio Pro autopilot; Trig TT22 transponder; home made audio panel. Skyradar D2 for ADSB-in. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471630#471630 > > > > > > > > > ________________________________________________________________________________
Date: Aug 09, 2017
I mounted the antenna for my G430w on the top - no ground plane was specified. Works perfectly at all times. It also seals up easily with a bit of silicon sealant used as a gasket. Very unobtrusive. I chose not to try and get fancy with the WAAS antenna since it is critical to IFR operations. A talk by a local radio shop convinced me further on that point. I have a lot of extra cable for the short run but understand that the whole system is tuned and no cable should be removed. So there is a big coil of cable under my hood. On 8/6/2017 12:42 PM, Ed Godfrey wrote: > > I would like to ask, of those who mounted your GPS antenna on the > cabin top, are you getting the performance from it that you expected? > Did you install a ground plane? Also, what screws did you use to mount > it. I have been looking for some MS24693-C286 screws and am not coming > up with anything. Thanks. > > Ed Godfrey > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 09, 2017
Subject: Gust Lock Reviews
Does anyone have any feedback on the Anti-Splat gust lock for the RV-10? http://www.aircraftspruce.com/catalog/pspages/gustlocks05-12368.php?clickkey=4469 https://www.youtube.com/watch?v=s5NvoygYcc8 Most specifically, any feedback on how it works/fits with the infinity grips where the sticks had to be cut down to minimum length to fit under the panel... Thanks, Phil ________________________________________________________________________________
Subject: Re: Gust Lock Reviews
Date: Aug 09, 2017
I have it with Infinity grips and if works as advertised. I didn't make any mods to the stick or panel. -------- Todd Stovall aka Auburntsts on EAA, AOPA, and VAF RV-10 N728TT -- Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471682#471682 ________________________________________________________________________________
Date: Aug 09, 2017
Phil, Tim Olson has pretty good instructions on his web site to make your own. I mostly followed his instructions, although I had to make a few parts differently as I have Paul Grimstead's Rudder pedal system. I have AntiSplat cowl flaps, and all his products are a bit spendy for what they are. Kelly -sent from the I-droid implanted in my forearm On Wed, Aug 9, 2017 at 12:11 PM, Phillip Perry wrote: > Does anyone have any feedback on the Anti-Splat gust lock for the RV-10? > > http://www.aircraftspruce.com/catalog/pspages/gustlocks05-12368.php?clickkey=4469 > > https://www.youtube.com/watch?v=s5NvoygYcc8 > > Most specifically, any feedback on how it works/fits with the infinity grips > where the sticks had to be cut down to minimum length to fit under the > panel... > > Thanks, > Phil > > ________________________________________________________________________________
Date: Aug 09, 2017
I use the very slightly modified Bogart tow bar as a control (all 3 axes) gust lock. Works fine, no extra weight since I take the tow bar everywhere anyway. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471686#471686 ________________________________________________________________________________
Date: Aug 09, 2017
Not sure I'd use the word "tuned". The extra coax is there just for its loss, since at these frequencies no coax is perfect. Seems Garmin bought an OEM antenna and put their name on it, but the antenna has too much gain for the receiver, hence the need for some attenuation or loss in the coax. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471687#471687 ________________________________________________________________________________
Date: Aug 10, 2017
I have the Antisplat Aero gust lock. It is easy to install and works well. Connects to control stick several inches below the stick grip. A gage is i ncluded, which tells you where to mount the attachment bracket on the curved part of the stick. I do not see how it could interfere with any stick grip . Bruce Hoppe Sent from my iPad > On Aug 10, 2017, at 2:11 AM, Phillip Perry wrote: > > Does anyone have any feedback on the Anti-Splat gust lock for the RV-10? > > http://www.aircraftspruce.com/catalog/pspages/gustlocks05-12368.php?clickk ey=4469 > > https://www.youtube.com/watch?v=s5NvoygYcc8 > > Most specifically, any feedback on how it works/fits with the infinity gri ps where the sticks had to be cut down to minimum length to fit under the pa nel... > > Thanks, > Phil > > > ________________________________________________________________________________
Date: Aug 10, 2017
I made this out of PVC. 600 hours and still working well -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471699#471699 Attachments: http://forums.matronics.com//files/img_2857_740.jpg ________________________________________________________________________________
Date: Aug 10, 2017
Bill, That's very similar to what I was thinking of making. Does it hold the stick well in roll also? My cargo strap around the taillight for a rudder lock isn't very professional looking, but it works great. Thanks, Marcus > On Aug 10, 2017, at 10:05 AM, bill.peyton wrote: > > > I made this out of PVC. 600 hours and still working well > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471699#471699 > > > > > Attachments: > > http://forums.matronics.com//files/img_2857_740.jpg > > > > > > ________________________________________________________________________________
Date: Aug 10, 2017
Yes, it holds the stick and the rudder pedals. I have a #8 screw with a castellated nut that protrudes through the front web that secures the end of the gust lock from lateral movement. You can see it in the photos. Total cost under $10. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471701#471701 ________________________________________________________________________________
Date: Aug 10, 2017
Sorry no picture. I have a PVC model that is an "H". One of my first locks tied in the stick and it failed when I needed it the most and I got rudder damage. So I use the "H" pvc for the rudder and seat belt for the Stick. Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bill.peyton Sent: Thursday, August 10, 2017 7:06 AM Subject: RV10-List: Re: Gust Lock Reviews I made this out of PVC. 600 hours and still working well -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471699#471699 Attachments: http://forums.matronics.com//files/img_2857_740.jpg ________________________________________________________________________________
Date: Aug 10, 2017
I built the PVC gust lock and have been happy with the results as well. Mine looks exactly like the one above, except it doesn't lock the stick. It just goes straight back and wedges on the back wall of the foot well. I use the seat belt for the stick. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471709#471709 ________________________________________________________________________________
Date: Aug 10, 2017
I 'll second Bill's comments wrt the gust lick. Works very well Rick C-GDMH Sent from my iPad > On Aug 10, 2017, at 11:02 AM, bill.peyton wrote: > > > Yes, it holds the stick and the rudder pedals. I have a #8 screw with a castellated nut that protrudes through the front web that secures the end of the gust lock from lateral movement. You can see it in the photos. Total cost under $10. > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471701#471701 > > > > > > > > > ________________________________________________________________________________
Date: Aug 10, 2017
I'm using the Bogey Bar as well. It's a mandatory item for moving the plane around and just happens to work perfectly as a gust lock. It seems almost 'tuned' to the RV10 in the sense that it jams down in front of the seat cushion and fits into the rudder pedals without modification. I used it for a while as is, then added two welded tabs to insure that is stays jammed in the rudder pedals. Here's some more info: Bogi Tow Bar as Control Lock <http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=2223&log 0875&row=1> On 8/9/2017 8:04 PM, Bob Turner wrote: > > I use the very slightly modified Bogart tow bar as a control (all 3 axes) gust lock. Works fine, no extra weight since I take the tow bar everywhere anyway. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471686#471686 > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 10, 2017
I made my gust lock similar to all the ones shown out of PVC and an extendab le paint roller pole. The ends fit into the top of the break pedals and wor k as a parking break when installed. A small Velcro strap holds the stick t ight against the assembly. The whole thing holds the breaks, rudder, elevat or and ailerons when installed. Dave Leikam N89DA > On Aug 10, 2017, at 2:48 PM, Bill Watson wrote: > > I'm using the Bogey Bar as well. It's a mandatory item for moving the pla ne around and just happens to work perfectly as a gust lock. It seems almos t 'tuned' to the RV10 in the sense that it jams down in front of the seat cu shion and fits into the rudder pedals without modification. > > I used it for a while as is, then added two welded tabs to insure that is s tays jammed in the rudder pedals. Here's some more info: > Bogi Tow Bar as Control Lock > > >> On 8/9/2017 8:04 PM, Bob Turner wrote: >> >> I use the very slightly modified Bogart tow bar as a control (all 3 axes) gust lock. Works fine, no extra weight since I take the tow bar everywhere a nyway. >> >> -------- >> Bob Turner >> RV-10 QB >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=471686#471686 >> >> >> >> >> >> >> >> >> >> > > > Virus-free. www.avast.com ________________________________________________________________________________
Date: Aug 10, 2017
Subject: Fuel pump - replacement
I am probably going to try installing a new (engine driven) fuel pump tomorrow. Has anyone replaced theirs? What's he process like? I'm guessing I don't need to drain the oil to swap it out? How much cussing does it require? It should be a simple process, but I could see fitting it under the plunger and getting everything aligned could be a pain. Any tips would help. I'd like to not fit with it for days. Thanks, Phil Sent from my iPhone ________________________________________________________________________________
Subject: Re: Fuel pump - replacement
Date: Aug 10, 2017
Phil, My RV14 came with a pump that ended up having an SB on it so I replaced it under warranty. http://www.myrv14.com/N14YT/maintenance/20170408/index.html There are some tips there for you. It's both a real pain in the butt, and also not too bad, all at the same time. You won't need to drain the oil, but you should have a new gasket or two on hand. It does require at least 10 minutes of cussing, or it isn't a project. More than 2 hours worth gets you extra points. Check out that link. That may be all you need. The safety wire trick was invaluable. Tim On 8/10/2017 9:48 PM, Phillip Perry wrote: > > I am probably going to try installing a new (engine driven) fuel pump tomorrow. Has anyone replaced theirs? > > What's he process like? I'm guessing I don't need to drain the oil to swap it out? > > How much cussing does it require? > > It should be a simple process, but I could see fitting it under the plunger and getting everything aligned could be a pain. Any tips would help. I'd like to not fit with it for days. > > Thanks, > Phil > > ________________________________________________________________________________
Date: Aug 10, 2017
You want clear access to the area, which may mean removing scat tubing around the oil cooler and the mufflers. You will need to hold the plunger up while you insert the new pump. Then hold pump in place while getting the first allen screw in place. Oh, yeah, you also need all the fuel lines clear of the area. No, you do not need to drain oil. Degree of difficulty depends on how clear your access is. I've done the swap on back of IO-360 in a Mooney. Same pump, tighter firewall clearance. On 8/10/2017 7:48 PM, Phillip Perry wrote: > > I am probably going to try installing a new (engine driven) fuel pump tomorrow. Has anyone replaced theirs? > > What's he process like? I'm guessing I don't need to drain the oil to swap it out? > > How much cussing does it require? > > It should be a simple process, but I could see fitting it under the plunger and getting everything aligned could be a pain. Any tips would help. I'd like to not fit with it for days. > > Thanks, > Phil ________________________________________________________________________________
Date: Aug 10, 2017
The safety wire trick to put the plunger in a bind and hold it in place is the way to go. I replaced my (O-320) pump a year or two ago, and it was very easy. Probably a 30 minute job once I had all of the parts and tools on hand... -----Original Message----- From: Tim Olson Sent: Thursday, August 10, 2017 10:56 PM Subject: Re: RV10-List: Fuel pump - replacement Phil, My RV14 came with a pump that ended up having an SB on it so I replaced it under warranty. http://www.myrv14.com/N14YT/maintenance/20170408/index.html There are some tips there for you. It's both a real pain in the butt, and also not too bad, all at the same time. You won't need to drain the oil, but you should have a new gasket or two on hand. It does require at least 10 minutes of cussing, or it isn't a project. More than 2 hours worth gets you extra points. Check out that link. That may be all you need. The safety wire trick was invaluable. Tim On 8/10/2017 9:48 PM, Phillip Perry wrote: > > I am probably going to try installing a new (engine driven) fuel pump > tomorrow. Has anyone replaced theirs? > > What's he process like? I'm guessing I don't need to drain the oil to > swap it out? > > How much cussing does it require? > > It should be a simple process, but I could see fitting it under the > plunger and getting everything aligned could be a pain. Any tips would > help. I'd like to not fit with it for days. > > Thanks, > Phil > > ________________________________________________________________________________
Date: Aug 11, 2017
Hi It would be fantastic if I knew the safety wire trick. Despite that I was very, very careful being sure I had the lever under the pushrod. I had a low fuel pressure while flying to Oshkosh this year. Had to change the pump a field. The Emergency Repair Shop located at the south near the ultralite area, was invaluable helping me with tools and other amenities. Dilson Em 11/08/2017 00:35, kboatright1(at)comcast.net escreveu: > > The safety wire trick to put the plunger in a bind and hold it in > place is the way to go. I replaced my (O-320) pump a year or two ago, > and it was very easy. Probably a 30 minute job once I had all of the > parts and tools on hand... > > -----Original Message----- From: Tim Olson > Sent: Thursday, August 10, 2017 10:56 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Fuel pump - replacement > > > Phil, > > My RV14 came with a pump that ended up having an SB on it so I replaced > it under warranty. > > http://www.myrv14.com/N14YT/maintenance/20170408/index.html > > There are some tips there for you. It's both a real pain in the butt, > and also > not too bad, all at the same time. You won't need to drain the oil, but > you should have a new gasket or two on hand. It does require at least > 10 minutes of cussing, or it isn't a project. More than 2 hours worth > gets you extra points. > > Check out that link. That may be all you need. The safety wire trick was > invaluable. > Tim > > > On 8/10/2017 9:48 PM, Phillip Perry wrote: >> >> I am probably going to try installing a new (engine driven) fuel pump >> tomorrow. Has anyone replaced theirs? >> >> What's he process like? I'm guessing I don't need to drain the oil >> to swap it out? >> >> How much cussing does it require? >> >> It should be a simple process, but I could see fitting it under the >> plunger and getting everything aligned could be a pain. Any tips >> would help. I'd like to not fit with it for days. >> >> Thanks, >> Phil >> >> > > ________________________________________________________________________________
Date: Aug 11, 2017
The 2017 update to Van's chapter 5 instructions gives a good treatment of NPT fitting sealing: "Because we cannot always fully tighten tapered thread fittings, and because even after fully tightening the fitting a small spiral leak path remains along the full length of threads, a thread sealant must be used during assembly. Sealants appropriate for use on aircraft NPT fittings areTite-seal, Permatex #2 and Locktite 565. Do not use RTV, Teflon tape or Fuel Lube on NPT fittings . When installing the fitting, be sure the threads on both parts are clean and dry since most sealants will not tolerate any oil contamination. First determine the clocking position by installing it finger tight and marking the desired clocking. Remove the fitting and apply a small amount of sealant to 2 - 3 threads of the male fitting. Leave the first 2 bare to prevent contamination inside the fluid path. Remember, this is an interference fit so not much sealant is required. Thread the fitting in with your fingers until you just begin to feel resistance and then an additional 1.5 - 2 turns. This is general guidance... you must still use judgement to not over tighten and damage the threads, but a properly insalled fitting is quite tight. If the installation requires a specific clocking, when approaching the correct position you must determine whether you will be able to make another full rotation and still be within the 1.5 - 2 turns stopping range. You must avoid turning the fitting backwards in the loosening direction because it will have a high probability of leaking. If you must do this, it is best to completely remove the fitting, clean up the threads on both parts, and try again." Source: http://vansaircraft.com/pdf/revisions/RV-ALL_05.pdf -- Tim Lewis -- HEF (Manassas, VA) A&P RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 960 hrs Dan Charrois wrote on 8/7/2017 1:40 AM: > > Whoops - I misspoke. It wasn't Boelube I used on my pipe threads. I had the name on the brain because I'd recently used it to lubricate the piano hinge pins that go into the cowling. > > I can't recall exactly, but I think the stuff I used was EZ Turn Fuel lube (described as a lubricant/sealant).. it's in a tube and *very* gooey and sticky :-) ... not the Boelube that's blue, in a little jar, and oily. > > But with that said, it may not be the best product for the job. A thread sealant paste like Loctite 567 or Permatex 80632 as suggested here probably would be better suited. Just so long as it can handle brake fluid properly. > > Thanks, everyone! > > Dan > >> On 2017-Aug-06, at 10:10 PM, Bob Turner wrote: >> >> >> As others said: Boelube is a lubricant. You want a pipe thread sealant. Apply sparingly, not on the first thread. You should have used a thread sealant on all your pipe threads (not teflon tape). >> >> -------- >> Bob Turner >> RV-10 QB >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=471577#471577 >> >> >> >> >> >> >> >> >> > > > --- > Dan Charrois > President, Syzygy Research & Technology > Phone: 780-961-2213 > > ________________________________________________________________________________
Date: Aug 11, 2017
I should add that this works best if you don't use the .032 safety wire, but instead use the very fine stuff used to safety wire smaller screws and bolts. You want something very fine. I have 3 sizes of safety wire in the hangar. Just nice things to have when you do your own maintenance. You could probably easily use telephone hookup wire or even a strand out of a network cable very easily too. Tim > On Aug 11, 2017, at 7:16 AM, Dilson wrote: > > > Hi > > It would be fantastic if I knew the safety wire trick. Despite that I was very, very careful being sure I had the lever under the pushrod. > > I had a low fuel pressure while flying to Oshkosh this year. Had to change the pump a field. > > The Emergency Repair Shop located at the south near the ultralite area, was invaluable helping me with tools and other amenities. > > Dilson > > > Em 11/08/2017 00:35, kboatright1(at)comcast.net escreveu: >> >> The safety wire trick to put the plunger in a bind and hold it in place is the way to go. I replaced my (O-320) pump a year or two ago, and it was very easy. Probably a 30 minute job once I had all of the parts and tools on hand... >> >> -----Original Message----- From: Tim Olson >> Sent: Thursday, August 10, 2017 10:56 PM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Fuel pump - replacement >> >> >> Phil, >> >> My RV14 came with a pump that ended up having an SB on it so I replaced >> it under warranty. >> >> http://www.myrv14.com/N14YT/maintenance/20170408/index.html >> >> There are some tips there for you. It's both a real pain in the butt, >> and also >> not too bad, all at the same time. You won't need to drain the oil, but >> you should have a new gasket or two on hand. It does require at least >> 10 minutes of cussing, or it isn't a project. More than 2 hours worth >> gets you extra points. >> >> Check out that link. That may be all you need. The safety wire trick was >> invaluable. >> Tim >> >> >> >>> On 8/10/2017 9:48 PM, Phillip Perry wrote: >>> >>> I am probably going to try installing a new (engine driven) fuel pump tomorrow. Has anyone replaced theirs? >>> >>> What's he process like? I'm guessing I don't need to drain the oil to swap it out? >>> >>> How much cussing does it require? >>> >>> It should be a simple process, but I could see fitting it under the plunger and getting everything aligned could be a pain. Any tips would help. I'd like to not fit with it for days. >>> >>> Thanks, >>> Phil >>> >>> >> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Aug 11, 2017
Subject: Before the fuel pump exchange - one last question
UPS should be here with the new pump (going w/a Tempest brand) here in a few hours. Before I commit to putting it on the engine and buying it outright, I thought I'd run this by the gallery. Earlier I was having a stumble when leaning rich of peak. Come to find out, that was a heat related issue. Re-routing a fuel line moved the line to a cooler part of the cowling and the engine has been running like a sewing machine ever since. However, I continue to have fluctuating fuel pressures in flight. Never enough to put the PSI in the yellow, but it's certainly not consistent and (In my amateur-built opinion) it's fluctuating more than it should. 1) I don't believe I have a sensor problem. Because I can kick on my Andair pump and it stabilizes at 26.9 to 27.0 PSI and holds steady. Shut it off and the fluctuation restarts. 2) I suspected an air leak on the suction side of the pump. But I tightened every fitting from the tank to the boost pump. Then pressure tested the fuel lines forward of the boost pump. No leaks found forward of the pump and likely not any air leaks behind it after tightening. 3) I suspected heat was an issue. So I installed a blast tube on the engine driven pump. (Cooling shroud is on order - BTW: Don't order one in the summer time or the lead time is around 2 months because of demand.) It didn't make a difference. So I'm starting to run out of options aside from replacing the pump itself. Last night I was zipping along through the sky and I decided to grab my phone and shoot this video showing the pace and range of the fluctuation. https://www.youtube.com/watch?v=weSIiM96Vv4 Before I commit to replacing the pump, I wanted to see if anyone else has experienced a similar symptom. Why might it be the pump? Well the engine did sit for 4-5 years before I ever got the project to the point where I could start it. So it's possible that one of the rubber check valves dried out inside the pump allowing some fuel to leak by. Thanks, Phil ________________________________________________________________________________
Subject: Re: Before the fuel pump exchange - one last question
Date: Aug 11, 2017
Hey Phil, That's interesting you had a change with re-routing the line. I'm interested in how close it was to hot stuff. The amount of fluctuation you have is pretty high. If it doesn't end up being the pump, I'd be saying it could be the sensor. I'd think that unless there were a huge air leak you wouldn't see anything that drastic. I also bought a blast tube shroud at one point but it's still in the box, never installed it. I think the fuel pump swap would be a lot harder with adding that. I know that doesn't help, but just interested in what you find. If the pump swap doesn't do it, I'd try a new sensor. Or, stick a mechanical gauge on it I suppose. Tim On 8/11/2017 8:42 AM, Phillip Perry wrote: > UPS should be here with the new pump (going w/a Tempest brand) here in a > few hours. > > Before I commit to putting it on the engine and buying it outright, I > thought I'd run this by the gallery. > > Earlier I was having a stumble when leaning rich of peak. Come to find > out, that was a heat related issue. Re-routing a fuel line moved the > line to a cooler part of the cowling and the engine has been running > like a sewing machine ever since. > > However, I continue to have fluctuating fuel pressures in flight. Never > enough to put the PSI in the yellow, but it's certainly not consistent > and (In my amateur-built opinion) it's fluctuating more than it should. > > 1) I don't believe I have a sensor problem. Because I can kick on my > Andair pump and it stabilizes at 26.9 to 27.0 PSI and holds steady. > Shut it off and the fluctuation restarts. > > 2) I suspected an air leak on the suction side of the pump. But I > tightened every fitting from the tank to the boost pump. Then pressure > tested the fuel lines forward of the boost pump. No leaks found > forward of the pump and likely not any air leaks behind it after tightening. > > 3) I suspected heat was an issue. So I installed a blast tube on the > engine driven pump. (Cooling shroud is on order - BTW: Don't order one > in the summer time or the lead time is around 2 months because of > demand.) It didn't make a difference. > > So I'm starting to run out of options aside from replacing the pump itself. > > Last night I was zipping along through the sky and I decided to grab my > phone and shoot this video showing the pace and range of the fluctuation. > > https://www.youtube.com/watch?v=weSIiM96Vv4 > > Before I commit to replacing the pump, I wanted to see if anyone else > has experienced a similar symptom. > > Why might it be the pump? Well the engine did sit for 4-5 years before > I ever got the project to the point where I could start it. So it's > possible that one of the rubber check valves dried out inside the pump > allowing some fuel to leak by. > > Thanks, > Phil > > ________________________________________________________________________________
Date: Aug 11, 2017
Variations with flight attitude are not uncommon. Fluctuations during cruise are not normal. Hard to evaluate "in the yellow" as the actual Lycoming specified numbers(from Operating Manual) are, for IO-540-A series engines, 20 min. and 26 max. While the engine will run down to around 14 psi, I'd rather not go there. I normally see 1-2 psi increase with boost pump. On 8/11/2017 6:42 AM, Phillip Perry wrote: > UPS should be here with the new pump (going w/a Tempest brand) here in a > few hours. > > Before I commit to putting it on the engine and buying it outright, I > thought I'd run this by the gallery. > > Earlier I was having a stumble when leaning rich of peak. Come to find > out, that was a heat related issue. Re-routing a fuel line moved the > line to a cooler part of the cowling and the engine has been running > like a sewing machine ever since. > > However, I continue to have fluctuating fuel pressures in flight. Never > enough to put the PSI in the yellow, but it's certainly not consistent > and (In my amateur-built opinion) it's fluctuating more than it should. > 2) I suspected an air leak on the suction side of the pump. But I > tightened every fitting from the tank to the boost pump. Then pressure > tested the fuel lines forward of the boost pump. No leaks found > forward of the pump and likely not any air leaks behind it after tightening. > > 3) I suspected heat was an issue. So I installed a blast tube on the > engine driven pump. (Cooling shroud is on order - BTW: Don't order one > in the summer time or the lead time is around 2 months because of > demand.) It didn't make a difference. > > So I'm starting to run out of options aside from replacing the pump itself. > > Last night I was zipping along through the sky and I decided to grab my > phone and shoot this video showing the pace and range of the fluctuation. > > https://www.youtube.com/watch?v=weSIiM96Vv4 > > Before I commit to replacing the pump, I wanted to see if anyone else > has experienced a similar symptom. > > Why might it be the pump? Well the engine did sit for 4-5 years before > I ever got the project to the point where I could start it. So it's > possible that one of the rubber check valves dried out inside the pump > allowing some fuel to leak by. > > Thanks, > Phil > > ________________________________________________________________________________
Date: Aug 11, 2017
I agree with Tim. I don't think you have an air leak. I'm not convinced you don't have a sensor problem. It looks worse than it probably is because of the digital numbers at more precision than needed. You really should have it stay around 23-25. The dips below 20 absent a nose up prolonged climb are a bit of a concern. Kelly On Fri, Aug 11, 2017 at 7:30 AM, Tim Olson wrote: > > Hey Phil, > > That's interesting you had a change with re-routing the > line. I'm interested in how close it was to hot stuff. > The amount of fluctuation you have is pretty high. > If it doesn't end up being the pump, I'd be saying > it could be the sensor. I'd think that unless > there were a huge air leak you wouldn't see anything > that drastic. > > On 8/11/2017 8:42 AM, Phillip Perry wrote: >> >> UPS should be here with the new pump (going w/a Tempest brand) here in a >> few hours. >> >> Before I commit to putting it on the engine and buying it outright, I >> thought I'd run this by the gallery. >> >> Earlier I was having a stumble when leaning rich of peak. Come to find >> out, that was a heat related issue. Re-routing a fuel line moved the line >> to a cooler part of the cowling and the engine has been running like a >> sewing machine ever since. >> >> However, I continue to have fluctuating fuel pressures in flight. Never >> enough to put the PSI in the yellow, but it's certainly not consistent and >> (In my amateur-built opinion) it's fluctuating more than it should. >> >> 1) I don't believe I have a sensor problem. Because I can kick on my >> Andair pump and it stabilizes at 26.9 to 27.0 PSI and holds steady. Shut >> it off and the fluctuation restarts. >>mp? Well the engine did sit for 4-5 years before I >> ever got the project to the point where I could start it. So it's possible >> that one of the rubber check valves dried out inside the pump allowing some >> fuel to leak by. >> >> Thanks, >> Phil >> > > ________________________________________________________________________________
Date: Aug 11, 2017
Phil Before changing my fuel pump I was experiencing about the same reading you are having and the same kind of variation. After the replacement, the pressure went up to around 30 PSI. But, the fluctuating fuel pressure persist I flew more than 40 hours now without a issue. My previous fuel pump had just 200 hours on it Rds Dilson Em 11/08/2017 10:42, Phillip Perry escreveu: > UPS should be here with the new pump (going w/a Tempest brand) here in > a few hours. > > Before I commit to putting it on the engine and buying it outright, I > thought I'd run this by the gallery. > > Earlier I was having a stumble when leaning rich of peak. Come to find > out, that was a heat related issue. Re-routing a fuel line moved the > line to a cooler part of the cowling and the engine has been running > like a sewing machine ever since. > > However, I continue to have fluctuating fuel pressures in flight. > Never enough to put the PSI in the yellow, but it's certainly not > consistent and (In my amateur-built opinion) it's fluctuating more > than it should. > > 1) I don't believe I have a sensor problem. Because I can kick on my > Andair pump and it stabilizes at 26.9 to 27.0 PSI and holds steady. > Shut it off and the fluctuation restarts. > > 2) I suspected an air leak on the suction side of the pump. But I > tightened every fitting from the tank to the boost pump. Then > pressure tested the fuel lines forward of the boost pump. No leaks > found forward of the pump and likely not any air leaks behind it after > tightening. > > 3) I suspected heat was an issue. So I installed a blast tube on the > engine driven pump. (Cooling shroud is on order - BTW: Don't order > one in the summer time or the lead time is around 2 months because of > demand.) It didn't make a difference. > > So I'm starting to run out of options aside from replacing the pump > itself. > > Last night I was zipping along through the sky and I decided to grab > my phone and shoot this video showing the pace and range of the > fluctuation. > > https://www.youtube.com/watch?v=weSIiM96Vv4 > > Before I commit to replacing the pump, I wanted to see if anyone else > has experienced a similar symptom. > > Why might it be the pump? Well the engine did sit for 4-5 years > before I ever got the project to the point where I could start it. > So it's possible that one of the rubber check valves dried out inside > the pump allowing some fuel to leak by. > > Thanks, > Phil > > ________________________________________________________________________________
Date: Aug 11, 2017
Do you have a flow restrictor in your fuel pressure sensor fitting? The engine driven pump puts out "heavier" pressure pulses than that electric one. The restrictor helps dampen those. Some EFISs average out the fluctuations, some don't. -------- Lenny Iszak Palm City, FL 2014 RV-10, N311LZ - 300 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471748#471748 ________________________________________________________________________________
Date: Aug 11, 2017
Yes. Restrictor installed at the pump. Sent from my iPhone > On Aug 11, 2017, at 10:00 AM, Lenny Iszak wrote: > > > Do you have a flow restrictor in your fuel pressure sensor fitting? The engine driven pump puts out "heavier" pressure pulses than that electric one. The restrictor helps dampen those. Some EFISs average out the fluctuations, some don't. > > -------- > Lenny Iszak > Palm City, FL > 2014 RV-10, N311LZ - 300 hrs > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471748#471748 > > > > > > > > > ________________________________________________________________________________
Date: Aug 11, 2017
I'm having some fluctuations when I turn on my electric pump. In talking w ith Don Rivera, it's because the o-ring is sticking a bit, it builds up pre ssure then releases. I'm seeing a single high spike, then drops to normal almost instantaneously. It was tripping an audio alert, which became quick ly annoying. I didn't see these before I upgraded my efis using the same sensor. So the new efis is more responsive in measuring sensor output than the old one. Don recommended using a flow restrictor smaller than the one Vans provided us in the kit to dampen the spike better. I haven't found a source yet. I don't have the size handy, but could look it up if anyone is interested. I'm not implying this has anything to do with Phil's issue. I'm just addin g on to Lenny's comment about flow restrictors. Bob Get Outlook for iOS _____________________________ From: Lenny Iszak <lenard(at)rapiddecision.com<mailto:lenard(at)rapiddecision.com >> Sent: Friday, August 11, 2017 11:13 AM Subject: RV10-List: Re: Before the fuel pump exchange - one last question ilto:lenard(at)rapiddecision.com>> Do you have a flow restrictor in your fuel pressure sensor fitting? The eng ine driven pump puts out "heavier" pressure pulses than that electric one. The restrictor helps dampen those. Some EFISs average out the fluctuations, some don't. -------- Lenny Iszak Palm City, FL 2014 RV-10, N311LZ - 300 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=471748#471748 ________________________________________________________________________________
Date: Aug 11, 2017
Quick Update.... UPS dropped the pump off at 10AM. By noon I had removed the old one and put the new one on (mostly - minus safety wire and a couple of scat tubes that need to be replaced). The safety wire tip was a great one and worked like a champ. The only thing I'd add is to wait to put your fittings on the pump after the pump is in position. It just gives you a few more inches and angles to work with. I wish I had done that, but didn't. I wanted to do a ground run before I took the time to safety wire it and replace the scat tubes. Mission accomplished. The run-up initially showed lower fuel pressures, a stumbling engine, and a desire to idle at an RPM much lower than normal (~500 RPM). It would have died if I let it. I tried to purge the lines as best I could with the purge valve, but it didn't get everything apparently. After a few minutes of rough running though, the engine was ticking right along as expected. Most of that was air in the lines I suspect since I had an empty pump, and lines. As far as noticeable changes, fuel pressure has taken a 25% leap forward; increasing from 25 PSI on the old pump (at taxi) to 33 PSI on the new pump. Now that it appears to work, I'll head back up there in a few hours and put the rest of it back together and hopefully fly it this evening. Then I can report in on cruise changes. But the indicators, at this point, show a step in the right direction. I did all this with a 7 year old boy and a 5 year old little girl in the hangar. I bet I heard, "Daddy I want to buy a kitten" 150 times. In combination with, "I'm ready for our dogs to die so we can get a kitten" another 82. I'm glad she was there to bug me as it eclipsed my frustration with the pump replacement. If you're going to be replacing one of these, I'd suggest bringing a 5 year old little girl to the hangar with you. If you have one that is determined to get a kitten, then even better. Hopefully I can report some in-flight observations later tonight. Phil On Fri, Aug 11, 2017 at 10:31 AM, Bob Leffler wrote: > I'm having some fluctuations when I turn on my electric pump. In talking > with Don Rivera, it's because the o-ring is sticking a bit, it builds up > pressure then releases. I'm seeing a single high spike, then drops to > normal almost instantaneously. It was tripping an audio alert, which > became quickly annoying. > > I didn't see these before I upgraded my efis using the same sensor. So > the new efis is more responsive in measuring sensor output than the old > one. > > Don recommended using a flow restrictor smaller than the one Vans provided > us in the kit to dampen the spike better. I haven't found a source yet. > I don't have the size handy, but could look it up if anyone is interested. > > I'm not implying this has anything to do with Phil's issue. I'm just > adding on to Lenny's comment about flow restrictors. > > Bob > > Get Outlook for iOS > _____________________________ > From: Lenny Iszak <lenard(at)rapiddecision.com> > Sent: Friday, August 11, 2017 11:13 AM > Subject: RV10-List: Re: Before the fuel pump exchange - one last question > To: > > > Do you have a flow restrictor in your fuel pressure sensor fitting? The > engine driven pump puts out "heavier" pressure pulses than that electric > one. The restrictor helps dampen those. Some EFISs average out the > fluctuations, some don't. > > -------- > Lenny Iszak > Palm City, FL > 2014 RV-10, N311LZ - 300 hrs > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=471748#471748 > > > ========== > -List" x-apple-data-detectors="true" x-apple-data-detectors-type="link" > x-apple-data-detectors-result="4"> http://www.matronics.com/ > Navigator?RV10-List > ========== > ta-detectors="true" x-apple-data-detectors-type="link" > x-apple-data-detectors-result="5"> http://forums.matronics.com > ========== > -detectors="true" x-apple-data-detectors-type="link" > x-apple-data-detectors-result="6"> http://wiki.matronics.com > ========== > x-apple-data-detectors="true" x-apple-data-detectors-type="link" > x-apple-data-detectors-result="7"> http://www.matronics.com/contribution > ========== > > ________________________________________________________________________________
Date: Aug 11, 2017
Well that's positive news. Surprised it actually makes that much pressure. If they weren't so expensive I'd buy a Tempest just to have on hand. I like spare parts. :) The stuff on the kids is priceless. Hopefully you won't have to have any dead dogs to get the kitten. That said, as a former Cat owner and later Dog owner, I think she's going the wrong direction. I'm sure half the list will want to beat me for this but, Dogs rule. Try taking your cat on a flight sometime... Looking forward to "The rest of the story". (Old Paul Harvey reference). Geez, that dates me, doesn't it? Am I that old? Tim On 08/11/2017 01:19 PM, Phillip Perry wrote: > Quick Update.... > > UPS dropped the pump off at 10AM. By noon I had removed the old one > and put the new one on (mostly - minus safety wire and a couple of scat > tubes that need to be replaced). The safety wire tip was a great one > and worked like a champ. The only thing I'd add is to wait to put your > fittings on the pump after the pump is in position. It just gives you > a few more inches and angles to work with. I wish I had done that, but > didn't. > > I wanted to do a ground run before I took the time to safety wire it and > replace the scat tubes. Mission accomplished. > > The run-up initially showed lower fuel pressures, a stumbling engine, > and a desire to idle at an RPM much lower than normal (~500 RPM). It > would have died if I let it. I tried to purge the lines as best I > could with the purge valve, but it didn't get everything apparently. > After a few minutes of rough running though, the engine was ticking > right along as expected. Most of that was air in the lines I suspect > since I had an empty pump, and lines. > > As far as noticeable changes, fuel pressure has taken a 25% leap > forward; increasing from 25 PSI on the old pump (at taxi) to 33 PSI on > the new pump. > > Now that it appears to work, I'll head back up there in a few hours and > put the rest of it back together and hopefully fly it this evening. > Then I can report in on cruise changes. But the indicators, at this > point, show a step in the right direction. > > I did all this with a 7 year old boy and a 5 year old little girl in the > hangar. I bet I heard, "Daddy I want to buy a kitten" 150 times. In > combination with, "I'm ready for our dogs to die so we can get a kitten" > another 82. > > I'm glad she was there to bug me as it eclipsed my frustration with the > pump replacement. If you're going to be replacing one of these, I'd > suggest bringing a 5 year old little girl to the hangar with you. If > you have one that is determined to get a kitten, then even better. > > Hopefully I can report some in-flight observations later tonight. > > Phil > > ________________________________________________________________________________
Date: Aug 11, 2017
I didn't get a Tempest after all. I put this Tempest pump in my basket several times: Model (LW15473) https://www.aircraftspruce.com/catalog/eppages/TEMPESTfuelpumpLYC2.php?clickkey=57512 When I did it kept changing my order to this pump (LW15473) https://www.aircraftspruce.com/catalog/eppages/contlycfuelpump.php I just suspected it had something to do with ACS's ordering system. When it came in, it was in a Lycoming box.... But it's working.... (apparently) Headed back to the airport in a bit to put it together. On Fri, Aug 11, 2017 at 1:52 PM, Tim Olson wrote: > > Well that's positive news. Surprised it actually makes that much > pressure. If they weren't so expensive I'd buy a Tempest just > to have on hand. I like spare parts. :) > > The stuff on the kids is priceless. Hopefully you won't have to > have any dead dogs to get the kitten. That said, as a former > Cat owner and later Dog owner, I think she's going the wrong > direction. I'm sure half the list will want to beat me for this > but, Dogs rule. Try taking your cat on a flight sometime... > Looking forward to "The rest of the story". (Old Paul Harvey > reference). Geez, that dates me, doesn't it? Am I that old? > Tim > > > On 08/11/2017 01:19 PM, Phillip Perry wrote: > >> Quick Update.... >> >> UPS dropped the pump off at 10AM. By noon I had removed the old one and >> put the new one on (mostly - minus safety wire and a couple of scat tubes >> that need to be replaced). The safety wire tip was a great one and >> worked like a champ. The only thing I'd add is to wait to put your >> fittings on the pump after the pump is in position. It just gives you a >> few more inches and angles to work with. I wish I had done that, but >> didn't. >> >> I wanted to do a ground run before I took the time to safety wire it and >> replace the scat tubes. Mission accomplished. >> >> The run-up initially showed lower fuel pressures, a stumbling engine, and >> a desire to idle at an RPM much lower than normal (~500 RPM). It would >> have died if I let it. I tried to purge the lines as best I could with >> the purge valve, but it didn't get everything apparently. After a few >> minutes of rough running though, the engine was ticking right along as >> expected. Most of that was air in the lines I suspect since I had an empty >> pump, and lines. >> >> As far as noticeable changes, fuel pressure has taken a 25% leap forward; >> increasing from 25 PSI on the old pump (at taxi) to 33 PSI on the new pump. >> >> Now that it appears to work, I'll head back up there in a few hours and >> put the rest of it back together and hopefully fly it this evening. Then I >> can report in on cruise changes. But the indicators, at this point, show a >> step in the right direction. >> >> I did all this with a 7 year old boy and a 5 year old little girl in the >> hangar. I bet I heard, "Daddy I want to buy a kitten" 150 times. In >> combination with, "I'm ready for our dogs to die so we can get a kitten" >> another 82. >> >> I'm glad she was there to bug me as it eclipsed my frustration with the >> pump replacement. If you're going to be replacing one of these, I'd >> suggest bringing a 5 year old little girl to the hangar with you. If you >> have one that is determined to get a kitten, then even better. >> >> Hopefully I can report some in-flight observations later tonight. >> >> Phil >> >> > > ________________________________________________________________________________
Date: Aug 11, 2017
Hmm, restrictor's purpose is to prevent large flow if line fails, and fuel pressure line is usually connected to the fuel servo, on opposite side to the inlet screen. So the restrictor should be in between the fuel pressure line connection on the engine end of the line going to the fuel pressure sending unit. Is your fuel pressure line connected to a fitting on the pump? You really want to know how much pressure is internal in the fuel servo, not at the pump. On 8/11/2017 8:12 AM, Phillip Perry wrote: > > Yes. Restrictor installed at the pump. > > > > Sent from my iPhone > >> On Aug 11, 2017, at 10:00 AM, Lenny Iszak wrote: >> >> >> Do you have a flow restrictor in your fuel pressure sensor fitting? The engine driven pump puts out "heavier" pressure pulses than that electric one. The restrictor helps dampen those. Some EFISs average out the fluctuations, some don't. >> >> -------- >> Lenny Iszak >> Palm City, FL >> 2014 RV-10, N311LZ - 300 hrs >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=471748#471748 >> >> >> >> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Aug 11, 2017
You got the Lycoming OEM pump at $387. The Tempest is P/N AF15473 at $309, while Lycoming is LW15473. The page is misleading in that it shows both Lycoming and Tempest in the same table under the Tempest label. PMA parts always have a modification of the OEM part number, like Superior parts will have an S in front of the Lycoming part number. They can't sell PMA part under identical part number as OEM. On 8/11/2017 1:35 PM, Phillip Perry wrote: > I didn't get a Tempest after all. > > I put this Tempest pump in my basket several times: Model (LW15473) > https://www.aircraftspruce.com/catalog/eppages/TEMPESTfuelpumpLYC2.php?clickkey=57512 > > When I did it kept changing my order to this pump (LW15473) > https://www.aircraftspruce.com/catalog/eppages/contlycfuelpump.php > > I just suspected it had something to do with ACS's ordering system. > When it came in, it was in a Lycoming box.... > > But it's working.... (apparently) Headed back to the airport in a bit > to put it together. > > On Fri, Aug 11, 2017 at 1:52 PM, Tim Olson > wrote: > > > Well that's positive news. Surprised it actually makes that much > pressure. If they weren't so expensive I'd buy a Tempest just > to have on hand. I like spare parts. :) > > The stuff on the kids is priceless. Hopefully you won't have to > have any dead dogs to get the kitten. That said, as a former > Cat owner and later Dog owner, I think she's going the wrong > direction. I'm sure half the list will want to beat me for this > but, Dogs rule. Try taking your cat on a flight sometime... > Looking forward to "The rest of the story". (Old Paul Harvey > reference). Geez, that dates me, doesn't it? Am I that old? > Tim > > > > > On 08/11/2017 01:19 PM, Phillip Perry wrote: > > Quick Update.... > > UPS dropped the pump off at 10AM. By noon I had removed the > old one and put the new one on (mostly - minus safety wire and a > couple of scat tubes that need to be replaced). The safety > wire tip was a great one and worked like a champ. The only > thing I'd add is to wait to put your fittings on the pump after > the pump is in position. It just gives you a few more inches > and angles to work with. I wish I had done that, but didn't. > > I wanted to do a ground run before I took the time to safety > wire it and replace the scat tubes. Mission accomplished. > > The run-up initially showed lower fuel pressures, a stumbling > engine, and a desire to idle at an RPM much lower than normal > (~500 RPM). It would have died if I let it. I tried to purge > the lines as best I could with the purge valve, but it didn't > get everything apparently. After a few minutes of rough > running though, the engine was ticking right along as expected. > Most of that was air in the lines I suspect since I had an empty > pump, and lines. > > As far as noticeable changes, fuel pressure has taken a 25% leap > forward; increasing from 25 PSI on the old pump (at taxi) to 33 > PSI on the new pump. > > Now that it appears to work, I'll head back up there in a few > hours and put the rest of it back together and hopefully fly it > this evening. Then I can report in on cruise changes. But the > indicators, at this point, show a step in the right direction. > > I did all this with a 7 year old boy and a 5 year old little > girl in the hangar. I bet I heard, "Daddy I want to buy a > kitten" 150 times. In combination with, "I'm ready for our dogs > to die so we can get a kitten" another 82. > > I'm glad she was there to bug me as it eclipsed my frustration > with the pump replacement. If you're going to be replacing one > of these, I'd suggest bringing a 5 year old little girl to the > hangar with you. If you have one that is determined to get a > kitten, then even better. > > Hopefully I can report some in-flight observations later tonight. > > Phil > > > =================================== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > > > ________________________________________________________________________________
Date: Aug 11, 2017
In that case, it's probably worth checking real quick to make sure that the L ycoming pump is not covered by that service bulletin that caused me to repla ce mine. They had some non-conforming parts. Lycoming was not very aggressiv e at getting them replaced. I had to ask. I highly doubt that yours will be a ffected,but it maybe worth looking up the serial number quick. The service b ulletins old enough that I bet that aircraft Spruce would have checked them a ll already. Tim > On Aug 11, 2017, at 3:35 PM, Phillip Perry wrote: > > I didn't get a Tempest after all. > > I put this Tempest pump in my basket several times: Model (LW15473) > https://www.aircraftspruce.com/catalog/eppages/TEMPESTfuelpumpLYC2.php?cli ckkey=57512 > > When I did it kept changing my order to this pump (LW15473) > https://www.aircraftspruce.com/catalog/eppages/contlycfuelpump.php > > I just suspected it had something to do with ACS's ordering system. Whe n it came in, it was in a Lycoming box.... > > But it's working.... (apparently) Headed back to the airport in a bit to p ut it together. > >> On Fri, Aug 11, 2017 at 1:52 PM, Tim Olson wrote: >> >> Well that's positive news. Surprised it actually makes that much >> pressure. If they weren't so expensive I'd buy a Tempest just >> to have on hand. I like spare parts. :) >> >> The stuff on the kids is priceless. Hopefully you won't have to >> have any dead dogs to get the kitten. That said, as a former >> Cat owner and later Dog owner, I think she's going the wrong >> direction. I'm sure half the list will want to beat me for this >> but, Dogs rule. Try taking your cat on a flight sometime... >> Looking forward to "The rest of the story". (Old Paul Harvey >> reference). Geez, that dates me, doesn't it? Am I that old? >> Tim >> >> >> >> >>> On 08/11/2017 01:19 PM, Phillip Perry wrote: >>> Quick Update.... >>> >>> UPS dropped the pump off at 10AM. By noon I had removed the old one an d put the new one on (mostly - minus safety wire and a couple of scat tubes t hat need to be replaced). The safety wire tip was a great one and worked l ike a champ. The only thing I'd add is to wait to put your fittings on the p ump after the pump is in position. It just gives you a few more inches and angles to work with. I wish I had done that, but didn't. >>> >>> I wanted to do a ground run before I took the time to safety wire it and replace the scat tubes. Mission accomplished. >>> >>> The run-up initially showed lower fuel pressures, a stumbling engine, an d a desire to idle at an RPM much lower than normal (~500 RPM). It would ha ve died if I let it. I tried to purge the lines as best I could with the p urge valve, but it didn't get everything apparently. After a few minutes o f rough running though, the engine was ticking right along as expected. Mos t of that was air in the lines I suspect since I had an empty pump, and line s. >>> >>> As far as noticeable changes, fuel pressure has taken a 25% leap forward ; increasing from 25 PSI on the old pump (at taxi) to 33 PSI on the new pump . >>> >>> Now that it appears to work, I'll head back up there in a few hours and p ut the rest of it back together and hopefully fly it this evening. Then I c an report in on cruise changes. But the indicators, at this point, show a s tep in the right direction. >>> >>> I did all this with a 7 year old boy and a 5 year old little girl in the hangar. I bet I heard, "Daddy I want to buy a kitten" 150 times. In combi nation with, "I'm ready for our dogs to die so we can get a kitten" another 8 2. >>> >>> I'm glad she was there to bug me as it eclipsed my frustration with the p ump replacement. If you're going to be replacing one of these, I'd suggest bringing a 5 year old little girl to the hangar with you. If you have one t hat is determined to get a kitten, then even better. >>> >>> Hopefully I can report some in-flight observations later tonight. >>> >>> Phil >>> >>> >> >> ========================= >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= >> >> >> > ________________________________________________________________________________
Date: Aug 11, 2017
Mine is installed like Vans plans suggest. Photo attached. Coming out of the pump there is a T. One leg goes forward to the servo. The other leg has a restrictor fitting and the hose goes on up to the firewa ll manifold where the pressure sensor is located. Phil Sent from my iPhone > On Aug 11, 2017, at 3:42 PM, Kelly McMullen wrote: > > > Hmm, restrictor's purpose is to prevent large flow if line fails, and fuel pressure line is usually connected to the fuel servo, on opposite side to t he inlet screen. So the restrictor should be in between the fuel pressure li ne connection on the engine end of the line going to the fuel pressure sendi ng unit. Is your fuel pressure line connected to a fitting on the pump? You r eally want to know how much pressure is internal in the fuel servo, not at t he pump. > >> On 8/11/2017 8:12 AM, Phillip Perry wrote: >> Yes. Restrictor installed at the pump. >> Sent from my iPhone >>> On Aug 11, 2017, at 10:00 AM, Lenny Iszak wro te: >>> > >>> >>> Do you have a flow restrictor in your fuel pressure sensor fitting? The e ngine driven pump puts out "heavier" pressure pulses than that electric one. The restrictor helps dampen those. Some EFISs average out the fluctuations, some don't. >>> >>> -------- >>> Lenny Iszak >>> Palm City, FL >>> 2014 RV-10, N311LZ - 300 hrs >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=471748#471748 >>> >>> >>> >>> >>> >>> >>> >>> >>> ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Aug 11, 2017
That could account for some of the fluctuation. Production planes connect at the servo. I have to keep switching mind between factory planes I've worked on and Van's somewhat different way of doing things. -sent from the I-droid implanted in my forearm On Fri, Aug 11, 2017 at 2:21 PM, Phillip Perry wrote: > Mine is installed like Vans plans suggest. Photo attached. > > Coming out of the pump there is a T. One leg goes forward to the servo. > > The other leg has a restrictor fitting and the hose goes on up to the firewall manifold where the pressure sensor is located. > > Phil > > > Sent from my iPhone > >> On Aug 11, 2017, at 3:42 PM, Kelly McMullen wrote: >> >> >> Hmm, restrictor's purpose is to prevent large flow if line fails, and fuel pressure line is usually connected to the fuel servo, on opposite side to the inlet screen. So the restrictor should be in between the fuel pressure line connection on the engine end of the line going to the fuel pressure sending unit. Is your fuel pressure line connected to a fitting on the pump? You really want to know how much pressure is internal in the fuel servo, not at the pump. >> >>> On 8/11/2017 8:12 AM, Phillip Perry wrote: >>> Yes. Restrictor installed at the pump. >>> Sent from my iPhone >>>> On Aug 11, 2017, at 10:00 AM, Lenny Iszak wrote: >>>> >>>> >>>> Do you have a flow restrictor in your fuel pressure sensor fitting? The engine driven pump puts out "heavier" pressure pulses than that electric one. The restrictor helps dampen those. Some EFISs average out the fluctuations, some don't. >>>>
June 23, 2017 - August 11, 2017
RV10-Archive.digest.vol-mr
