RV10-Archive.digest.vol-mt
October 14, 2017 - Present
Subject: Re: Aerosport Overhead Consol
Date: Oct 14, 2017
Hi Dave I'd be interested in pix. I am not sure I can put a WAAS antenna in the console due to depth issues. It may be tight mounting with a 90 degree BNC connector. Cheers Les C-GCWZ Flying C-GROK Some assembly required Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473558#473558 ________________________________________________________________________________
Date: Oct 14, 2017
Les, My concern is that the overhead is carbon fiber, which is not transparent to GPS, and the WAAS certified antennas are supposed to see some single digit angle to the horizon, and the fact that Cirrus, Cessna/Columbia and such aircraft put the antennas outside. Also, the depth of the overhead is such that you will likely need right angle TNC connectors. Check pricing on them. What you definitely do NOT want to do is hog out some of the foam core of the canopy. The canopy is structural and you and I don't know the design parameters of that structure. I don't know details, but I do know that one of the -10 fatalities was due to a collapsed canopy. I felt more comfortable about just making the hole for coax and attachment screws than something big enough to contain the antenna. Sealing the antenna to the canopy top is rather simple with aircraft RTV. -sent from the I-droid implanted in my forearm On Sat, Oct 14, 2017 at 5:39 PM, kearney wrote: > > Hi Kelly > > If the fiberglass and non-metallic paint don't interfere with the GPS > signal, why not keep them safe and dry in the interior - and get a .00005kt > speed boost at no extra cost! > > Cheers > > Les > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473557#473557 > > ________________________________________________________________________________
Date: Oct 15, 2017
kearney wrote: > Hi Dave > > I'd be interested in pix. I am not sure I can put a WAAS antenna in the console due to depth issues. It may be tight mounting with a 90 degree BNC connector. > Here are some photos I have, hope they help. -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473573#473573 ________________________________________________________________________________
Date: Oct 15, 2017
I installed my 420W antenna externally, because of a (irrational?) fear that some over-zealous faa inspector (either initial a/w, or a ramp check) might complain that I had not followed the installation instructions, which are part of the TSO. I did put it back on the tailcone because Vans seemed so opposed to any holes in the cabin top. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473591#473591 ________________________________________________________________________________
Date: Oct 16, 2017
I also put the GPS antennas on the tailcone directly aft of the fiberglass cabin top for two reasons. First reason was that I wanted to make sure I had a good ground plane, and I didn't want to mess with fabbing something up to fit in the overhead. Second, in IFR flight, I want EVERY possible advantage towards not having equipment failures or signal degradation. As unlikely as it may be, sticking the GPS antenna on the top was one less variable towards that goal. GPS pucks for non-ifr? I'd put those anywhere they get signal! On Sun, Oct 15, 2017 at 5:07 PM, Bob Turner wrote: > > I installed my 420W antenna externally, because of a (irrational?) fear > that some over-zealous faa inspector (either initial a/w, or a ramp check) > might complain that I had not followed the installation instructions, which > are part of the TSO. I did put it back on the tailcone because Vans seemed > so opposed to any holes in the cabin top. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473591#473591 > > ________________________________________________________________________________
Date: Oct 17, 2017
kearney wrote: > Hi Dave > > I'd be interested in pix. I am not sure I can put a WAAS antenna in the console due to depth issues. It may be tight mounting with a 90 degree BNC connector. > Les, The antenna ends up nearly touching the underside of the cabin top and is essentially as high as you can get without being outside of the aircraft but did require the 90 deg fitting. -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473639#473639 ________________________________________________________________________________
Date: Oct 17, 2017
Subject: Pitot mast tie down clearance
Hi guys, Has anyone had tie down rope clearance issues when mounting the pitot mast on the inboard side of the rib just outboard of the aileron bellcrank? That's a bit of a tongue twister, so here's a picture that shows what I'm talking about (pitot is outboard side of bellcrank): https://tinyurl.com/y76l4cq3 Thanks, David ________________________________________________________________________________
Date: Oct 17, 2017
Subject: Re: Pitot mast tie down clearance
I=99ve only got a few hours on mine and noticed it in a recent trip. I t really depends on the width of the tie down points. If they=99re n arrow, then yeah. If they=99re wide, then no. But if I moved the mast outboard I=99d still have problems at those pl aces too. So it=99s as broad as it is long. I don=99t think it=99s worth the trouble to reinvent a location a nd move it from the standard location. Sent from my iPhone > On Oct 17, 2017, at 5:25 PM, David Carr wrote: > > Hi guys, > > Has anyone had tie down rope clearance issues when mounting the pitot mast on the inboard side of the rib just outboard of the aileron bellcrank? > > That's a bit of a tongue twister, so here's a picture that shows what I'm t alking about (pitot is outboard side of bellcrank): > https://tinyurl.com/y76l4cq3 > > Thanks, > David ________________________________________________________________________________
Date: Oct 17, 2017
I did the same....pitot is one bay further out. Tim > On Oct 17, 2017, at 5:57 PM, Phillip Perry wrote: > > I=99ve only got a few hours on mine and noticed it in a recent trip. It really depends on the width of the tie down points. If they=99 re narrow, then yeah. If they=99re wide, then no. > > But if I moved the mast outboard I=99d still have problems at those p laces too. So it=99s as broad as it is long. > > I don=99t think it=99s worth the trouble to reinvent a locatio n and move it from the standard location. > > > > Sent from my iPhone > >> On Oct 17, 2017, at 5:25 PM, David Carr wrote: >> >> Hi guys, >> >> Has anyone had tie down rope clearance issues when mounting the pitot mas t on the inboard side of the rib just outboard of the aileron bellcrank? >> >> That's a bit of a tongue twister, so here's a picture that shows what I'm talking about (pitot is outboard side of bellcrank): >> https://tinyurl.com/y76l4cq3 >> >> Thanks, >> David ________________________________________________________________________________
Date: Oct 17, 2017
Mine are in the standard location and I=99ve never had any tie down clearance issues in 9 years and nearly 1000 hours. Narrow or wide doesn=99t seem to make a difference. I figured Van=99s had flight tested the prototype with the pitot in that location, so the odds of having pitot/static accuracy issues would be minimized if I followed the plans on that particular issue. David Maib 40559 985 hours On Oct 17, 2017, at 6:57 PM, Phillip Perry wrote: I=99ve only got a few hours on mine and noticed it in a recent trip. It really depends on the width of the tie down points. If they=99re narrow, then yeah. If they=99re wide, then no. But if I moved the mast outboard I=99d still have problems at those places too. So it=99s as broad as it is long. I don=99t think it=99s worth the trouble to reinvent a location and move it from the standard location. Sent from my iPhone On Oct 17, 2017, at 5:25 PM, David Carr > wrote: > Hi guys, > > Has anyone had tie down rope clearance issues when mounting the pitot mast on the inboard side of the rib just outboard of the aileron bellcrank? > > That's a bit of a tongue twister, so here's a picture that shows what I'm talking about (pitot is outboard side of bellcrank): > https://tinyurl.com/y76l4cq3 > > Thanks, > David ________________________________________________________________________________
Date: Oct 17, 2017
It=99s not an accuracy issue. It=99s the rope running into the p itot tube of the tie down points on the ground are narrow.... Sent from my iPhone > On Oct 17, 2017, at 8:00 PM, David Maib wrote: > > Mine are in the standard location and I=99ve never had any tie down c learance issues in 9 years and nearly 1000 hours. Narrow or wide doesn =99t seem to make a difference. I figured Van=99s had flight tested th e prototype with the pitot in that location, so the odds of having pitot/sta tic accuracy issues would be minimized if I followed the plans on that parti cular issue. > > David Maib > 40559 > 985 hours > > On Oct 17, 2017, at 6:57 PM, Phillip Perry wrote: > > I=99ve only got a few hours on mine and noticed it in a recent trip. It really depends on the width of the tie down points. If they=99 re narrow, then yeah. If they=99re wide, then no. > > But if I moved the mast outboard I=99d still have problems at those p laces too. So it=99s as broad as it is long. > > I don=99t think it=99s worth the trouble to reinvent a locatio n and move it from the standard location. > > > > Sent from my iPhone > >> On Oct 17, 2017, at 5:25 PM, David Carr wrote: >> >> Hi guys, >> >> Has anyone had tie down rope clearance issues when mounting the pitot mas t on the inboard side of the rib just outboard of the aileron bellcrank? >> >> That's a bit of a tongue twister, so here's a picture that shows what I'm talking about (pitot is outboard side of bellcrank): >> https://tinyurl.com/y76l4cq3 >> >> Thanks, >> David > ________________________________________________________________________________
Date: Oct 17, 2017
I understand the issue. Just putting in my $.02 worth and stating why I made the decision at the time. David Maib On Oct 17, 2017, at 9:08 PM, Phillip Perry wrote: It=99s not an accuracy issue. It=99s the rope running into the pitot tube of the tie down points on the ground are narrow.... Sent from my iPhone On Oct 17, 2017, at 8:00 PM, David Maib > wrote: > Mine are in the standard location and I=99ve never had any tie down clearance issues in 9 years and nearly 1000 hours. Narrow or wide doesn=99t seem to make a difference. I figured Van=99s had flight tested the prototype with the pitot in that location, so the odds of having pitot/static accuracy issues would be minimized if I followed the plans on that particular issue. > > David Maib > 40559 > 985 hours > > On Oct 17, 2017, at 6:57 PM, Phillip Perry > wrote: > > I=99ve only got a few hours on mine and noticed it in a recent trip. It really depends on the width of the tie down points. If they=99re narrow, then yeah. If they=99re wide, then no. > > But if I moved the mast outboard I=99d still have problems at those places too. So it=99s as broad as it is long. > > I don=99t think it=99s worth the trouble to reinvent a location and move it from the standard location. > > > > Sent from my iPhone > > On Oct 17, 2017, at 5:25 PM, David Carr > wrote: > >> Hi guys, >> >> Has anyone had tie down rope clearance issues when mounting the pitot mast on the inboard side of the rib just outboard of the aileron bellcrank? >> >> That's a bit of a tongue twister, so here's a picture that shows what I'm talking about (pitot is outboard side of bellcrank): >> https://tinyurl.com/y76l4cq3 >> >> Thanks, >> David > ________________________________________________________________________________
Date: Oct 19, 2017
Subject: Grounding question
All, I have a question/concern regarding a ground return to the battery. I have primed all my parts and skins with the Akzo Nobel 2 part primer, which is awesome stuff though it's a smelly pain to work with. All skin overlaps have been primed on both sides of the overlap, and this stuff is not conductive at all so the only electrical path is through the rivets and the small area of the rivet hole that doesn't always have primer covering it. On the outside of the plane the rivet heads have contact directly with the unprimed skin so it's really the inside skin where there is minimal area in electrical contact. I am concerned that using the skin as a ground return to the battery may not provide an excellent ground path, especially for the large currents needed for engine cranking. I would really rather not have to run another heavy wire to the front of the airplane for ground, but I will if necessary. Has anyone else faced this issue and had a problem (or no problem) using the skin as a ground return? Also, where/how have people connected the battery ground to the tailcone skin, do you use a piece of brass or copper buss bar riveted to the bottom skin or something like that? Thanks for any suggestions! Kent Ogden #40710 ultra slow-build :) ________________________________________________________________________________
Date: Oct 19, 2017
Subject: Bose Headsets Available
If anyone's interested in a couple Bose headsets (for the backseaters maybe?) I have an ad on Barnstormers. --Dave ________________________________________________________________________________
Date: Oct 19, 2017
Subject: Re: Grounding question
I used a forest of tabs mounted to my firewall with a #2 (I think) cable run from there all the way back to the battery ground in the tailcone. I'm not sure if it was overkill, but I have had zero issues so far. I think the plans ground path is through the skin to the battery tray where you ground the battery. http://www.bandc.aero/grounding-supplies-battery-cables.aspx Shannon On Thu, Oct 19, 2017 at 10:27 AM, Kent Ogden wrote: > All, > > I have a question/concern regarding a ground return to the battery. I > have primed all my parts and skins with the Akzo Nobel 2 part primer, which > is awesome stuff though it's a smelly pain to work with. All skin overlaps > have been primed on both sides of the overlap, and this stuff is not > conductive at all so the only electrical path is through the rivets and the > small area of the rivet hole that doesn't always have primer covering it. > On the outside of the plane the rivet heads have contact directly with the > unprimed skin so it's really the inside skin where there is minimal area in > electrical contact. > > I am concerned that using the skin as a ground return to the battery may > not provide an excellent ground path, especially for the large currents > needed for engine cranking. I would really rather not have to run another > heavy wire to the front of the airplane for ground, but I will if necessary. > > Has anyone else faced this issue and had a problem (or no problem) using > the skin as a ground return? Also, where/how have people connected the > battery ground to the tailcone skin, do you use a piece of brass or copper > buss bar riveted to the bottom skin or something like that? > > Thanks for any suggestions! > > Kent Ogden > #40710 ultra slow-build :) > > ________________________________________________________________________________
Date: Oct 19, 2017
Ditto Sent from my iPhone > On Oct 19, 2017, at 10:35 AM, Shannon Hicks wrote: > > I used a forest of tabs mounted to my firewall with a #2 (I think) cable r un from there all the way back to the battery ground in the tailcone. I'm n ot sure if it was overkill, but I have had zero issues so far. > > I think the plans ground path is through the skin to the battery tray wher e you ground the battery. > > http://www.bandc.aero/grounding-supplies-battery-cables.aspx > > Shannon > >> On Thu, Oct 19, 2017 at 10:27 AM, Kent Ogden wrote: >> All, >> >> I have a question/concern regarding a ground return to the battery. I ha ve primed all my parts and skins with the Akzo Nobel 2 part primer, which is awesome stuff though it's a smelly pain to work with. All skin overlaps ha ve been primed on both sides of the overlap, and this stuff is not conductiv e at all so the only electrical path is through the rivets and the small are a of the rivet hole that doesn't always have primer covering it. On the out side of the plane the rivet heads have contact directly with the unprimed sk in so it's really the inside skin where there is minimal area in electrical c ontact. >> >> I am concerned that using the skin as a ground return to the battery may n ot provide an excellent ground path, especially for the large currents neede d for engine cranking. I would really rather not have to run another heavy w ire to the front of the airplane for ground, but I will if necessary. >> >> Has anyone else faced this issue and had a problem (or no problem) using t he skin as a ground return? Also, where/how have people connected the batte ry ground to the tailcone skin, do you use a piece of brass or copper buss b ar riveted to the bottom skin or something like that? >> >> Thanks for any suggestions! >> >> Kent Ogden >> #40710 ultra slow-build :) >> >> > ________________________________________________________________________________
Date: Oct 19, 2017
Kent, There are so many rivets making metal-on-metal contact that I can't imagine there'd be any problem, even with primed skins. If you want a more of a one-piece conductor, you could use one of the long stringers as a return with a flexible conductor on each end. I like braided ground straps <http://smile.amazon.com/ACDelco-EGS8-Professional-Engine-Ground/dp/B0016HPX4O/ref=sr_1_1?srs=16926415011&ie=UTF8&qid=1508427886&sr=8-1&keywords=ground+strap#Ask>. Mine is bolted to a vertical member of the baggage floor just forward of the battery. --Dave On Thu, Oct 19, 2017 at 8:27 AM, Kent Ogden wrote: > All, > > I have a question/concern regarding a ground return to the battery. I > have primed all my parts and skins with the Akzo Nobel 2 part primer, which > is awesome stuff though it's a smelly pain to work with. All skin overlaps > have been primed on both sides of the overlap, and this stuff is not > conductive at all so the only electrical path is through the rivets and the > small area of the rivet hole that doesn't always have primer covering it. > On the outside of the plane the rivet heads have contact directly with the > unprimed skin so it's really the inside skin where there is minimal area in > electrical contact. > > I am concerned that using the skin as a ground return to the battery may > not provide an excellent ground path, especially for the large currents > needed for engine cranking. I would really rather not have to run another > heavy wire to the front of the airplane for ground, but I will if necessary. > > Has anyone else faced this issue and had a problem (or no problem) using > the skin as a ground return? Also, where/how have people connected the > battery ground to the tailcone skin, do you use a piece of brass or copper > buss bar riveted to the bottom skin or something like that? > > Thanks for any suggestions! > > Kent Ogden > #40710 ultra slow-build :) > > ________________________________________________________________________________
Date: Oct 19, 2017
+1. I ran an independent #2 ground. That said, with the number of rivets in the airframe I'm sure you'll be fine as long as you ground to something with a lot of rivets in it. I just wanted as low a resistance path to my forest of tabs as possible. Tim On 10/19/2017 10:42 AM, Phillip Perry wrote: > Ditto > > Sent from my iPhone > > On Oct 19, 2017, at 10:35 AM, Shannon Hicks > wrote: > >> I used a forest of tabs mounted to my firewall with a #2 (I think) >> cable run from there all the way back to the battery ground in the >> tailcone. I'm not sure if it was overkill, but I have had zero issues >> so far. >> >> I think the plans ground path is through the skin to the battery tray >> where you ground the battery. >> >> http://www.bandc.aero/grounding-supplies-battery-cables.aspx >> >> Shannon >> >> On Thu, Oct 19, 2017 at 10:27 AM, Kent Ogden > > wrote: >> >> All, >> >> I have a question/concern regarding a ground return to the >> battery. I have primed all my parts and skins with the Akzo Nobel >> 2 part primer, which is awesome stuff though it's a smellypain to >> work with. All skin overlaps have been primed on both sides of >> the overlap, and this stuff is not conductive at all so the only >> electrical path is through the rivets and the small area of the >> rivet hole that doesn't always have primer covering it. On the >> outside of the planethe rivet heads have contact directly with >> the unprimed skin so it's really the inside skin where there is >> minimal area in electrical contact. >> >> I am concerned that using the skin as a ground return to the >> battery may not provide an excellent ground path, especially for >> the large currents needed for engine cranking. I would really >> rather not have to run another heavy wire to the front of the >> airplane for ground, but I will if necessary. >> >> Has anyone else faced this issue and had a problem (or no problem) >> using the skin as a ground return? Also, where/how have people >> connected the battery ground to the tailcone skin, do you use a >> piece of brass or copper buss bar riveted to the bottom skin or >> something like that? >> >> Thanks for any suggestions! >> >> Kent Ogden >> #40710 ultra slow-build :) >> >> >> ________________________________________________________________________________
Date: Oct 19, 2017
I originally ran a #2 wire to the firewall forest of tabs, then realized how much it weighs, promptly ripped it all out and grounded the battery to the battery tray/bellcrank mount (F-1035). It worked out great. I think its more important that you ground everything else to a single point like the forest of tabs on the firewall. I have my tail strobe locally grounded at the end of the tail and it's making a slight audible noise. Everything else is quiet. Lenny > On Oct 19, 2017, at 11:58 AM, Tim Olson wrote: > > > +1. I ran an independent #2 ground. > > That said, with the number of rivets in the airframe I'm sure you'll be fine as long as you ground to something with a lot of rivets in it. > I just wanted as low a resistance path to my forest of tabs as > possible. > > Tim > > > On 10/19/2017 10:42 AM, Phillip Perry wrote: >> Ditto >> Sent from my iPhone >> On Oct 19, 2017, at 10:35 AM, Shannon Hicks > wrote: >>> I used a forest of tabs mounted to my firewall with a #2 (I think) cable run from there all the way back to the battery ground in the tailcone. I'm not sure if it was overkill, but I have had zero issues so far. >>> >>> I think the plans ground path is through the skin to the battery tray where you ground the battery. >>> >>> http://www.bandc.aero/grounding-supplies-battery-cables.aspx >>> >>> Shannon >>> >>> On Thu, Oct 19, 2017 at 10:27 AM, Kent Ogden > wrote: >>> >>> All, >>> >>> I have a question/concern regarding a ground return to the >>> battery. I have primed all my parts and skins with the Akzo Nobel >>> 2 part primer, which is awesome stuff though it's a smelly pain to >>> work with. All skin overlaps have been primed on both sides of >>> the overlap, and this stuff is not conductive at all so the only >>> electrical path is through the rivets and the small area of the >>> rivet hole that doesn't always have primer covering it. On the >>> outside of the plane the rivet heads have contact directly with >>> the unprimed skin so it's really the inside skin where there is >>> minimal area in electrical contact. >>> >>> I am concerned that using the skin as a ground return to the >>> battery may not provide an excellent ground path, especially for >>> the large currents needed for engine cranking. I would really >>> rather not have to run another heavy wire to the front of the >>> airplane for ground, but I will if necessary. >>> >>> Has anyone else faced this issue and had a problem (or no problem) >>> using the skin as a ground return? Also, where/how have people >>> connected the battery ground to the tailcone skin, do you use a >>> piece of brass or copper buss bar riveted to the bottom skin or >>> something like that? >>> >>> Thanks for any suggestions! >>> >>> Kent Ogden >>> #40710 ultra slow-build :) >>> >>> >>> > > > > ________________________________________________________________________________
Date: Oct 19, 2017
I used the same Akzo Noble primer on my RV-10, all skins are primed including both sides of all lap joints. ( This primer is amazing stuff, does stink like all heck, but really tough and protective. Weve used this on the eight airplanes we have built now over more than 20 years now, and can say it has held up extremely well.) I did not run a separate #2 wire up to the front. All ground current for the starter, alternator and engine sensors flows back through the airframe. I do have a #8 ground wire running from the battery to a ground bus up under the instrument panel solely for the avionics. I have absolutely no electrical issues or noise problems in this airplane. Bob Newman TCW Technologies, LLC 610-928-3420 > On Oct 19, 2017, at 11:58 AM, Tim Olson wrote: > > > +1. I ran an independent #2 ground. > > That said, with the number of rivets in the airframe I'm sure you'll be fine as long as you ground to something with a lot of rivets in it. > I just wanted as low a resistance path to my forest of tabs as > possible. > > Tim > > >> On 10/19/2017 10:42 AM, Phillip Perry wrote: >> Ditto >> Sent from my iPhone >>> On Oct 19, 2017, at 10:35 AM, Shannon Hicks > wrote: >>> I used a forest of tabs mounted to my firewall with a #2 (I think) cable run from there all the way back to the battery ground in the tailcone. I'm not sure if it was overkill, but I have had zero issues so far. >>> >>> I think the plans ground path is through the skin to the battery tray where you ground the battery. >>> >>> http://www.bandc.aero/grounding-supplies-battery-cables.aspx >>> >>> Shannon >>> >>> On Thu, Oct 19, 2017 at 10:27 AM, Kent Ogden > wrote: >>> >>> All, >>> >>> I have a question/concern regarding a ground return to the >>> battery. I have primed all my parts and skins with the Akzo Nobel >>> 2 part primer, which is awesome stuff though it's a smelly pain to >>> work with. All skin overlaps have been primed on both sides of >>> the overlap, and this stuff is not conductive at all so the only >>> electrical path is through the rivets and the small area of the >>> rivet hole that doesn't always have primer covering it. On the >>> outside of the plane the rivet heads have contact directly with >>> the unprimed skin so it's really the inside skin where there is >>> minimal area in electrical contact. >>> >>> I am concerned that using the skin as a ground return to the >>> battery may not provide an excellent ground path, especially for >>> the large currents needed for engine cranking. I would really >>> rather not have to run another heavy wire to the front of the >>> airplane for ground, but I will if necessary. >>> >>> Has anyone else faced this issue and had a problem (or no problem) >>> using the skin as a ground return? Also, where/how have people >>> connected the battery ground to the tailcone skin, do you use a >>> piece of brass or copper buss bar riveted to the bottom skin or >>> something like that? >>> >>> Thanks for any suggestions! >>> >>> Kent Ogden >>> #40710 ultra slow-build :) >>> >>> >>> > > > > ________________________________________________________________________________
Date: Oct 19, 2017
Subject: Navworx
I checked the Navworx website this morning and they have posted a notice that they have ceased operations. I have a GNS 480 that I was planning to use for a position source and was waiting for the 5.0 software to update the the 600B and make it usable again. Does anyone have the required software? Sheldon Olesen N475PV 888hrs Sent from my iPad ________________________________________________________________________________
Date: Oct 19, 2017
Subject: Navworx
Date: Oct 19, 2017
Subject: Navworx
Date: Oct 19, 2017
Subject: Re: Navworx
You don=99t have to have 5.0 software. You can use my AMOC to be tot ally legal. Phil On Thu, Oct 19, 2017 at 1:15 PM Sheldon Olesen wrote: > > I checked the Navworx website this morning and they have posted a notice > that they have ceased operations. > > I have a GNS 480 that I was planning to use for a position source and was > waiting for the 5.0 software to update the the 600B and make it usable > again. Does anyone have the required software? > > Sheldon Olesen > N475PV 888hrs > > Sent from my iPad > > =========== =========== =========== =========== =========== > > > -- Phil Yoder phil(at)philyoder.com \__________o-( )-o__________/ www.itsnotthatcomplex.com ________________________________________________________________________________
Date: Oct 19, 2017
You can use the 480 AMOC that I worked on with Phil Yoder. That will make you legal using the current software release with the 480. The three AMOCs that we created cover the entire certified Garmin GPS famil y. The AMOCS can downloaded from AOPA. The gotcha are bugs, like not being able to send traffic on both display po rts. That was supposed to be fixed in 5.0. I've the AMOCs as a stop gap to buy some time and to afford the replacement solution. Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> on behalf of Sheldon Olesen Sent: Thursday, October 19, 2017 1:08:26 PM Subject: RV10-List: Navworx I checked the Navworx website this morning and they have posted a notice th at they have ceased operations. I have a GNS 480 that I was planning to use for a position source and was w aiting for the 5.0 software to update the the 600B and make it usable again . Does anyone have the required software? Sheldon Olesen N475PV 888hrs Sent from my iPad ________________________________________________________________________________
Date: Oct 19, 2017
Subject: Navworx
Date: Oct 19, 2017
Subject: Navworx
Date: Oct 19, 2017
Subject: Navworx
Date: Oct 19, 2017
Subject: Navworx
Date: Oct 19, 2017
The airframe has plenty of surface area to carry any amount of current you will use. Running a separate cable from the battery to firewall central grounding point is a totally wasted effort. Strobes are a bit different animal if you are talking the old capacitive discharge into a flash tube variety. They do generate noise that is hard to totally suppress. LED strobes don't seem to do that. I have electrical system from battery to VPX system built to plans, with grounding cable to frame , in front of battery box. I have LED nav lights and strobes, all grounded locally, along with Vans landing lights grounded locally. The central grounding is essential for electronics that amplify noises such as intercoms, nav coms etc. It is unnecessary for resistive electrical loads, as they don't generate RF noise. My previous aircraft was a Mooney that was built with full zinc chromate primer, mostly non-structural skin, and chrome-moly tube frame, with battery behind baggage compartment. It was just fine with ground wire to airframe at battery. Cessna does the same. On 10/19/2017 9:35 AM, Lenny Iszak wrote: > > I originally ran a #2 wire to the firewall forest of tabs, then realized how much it weighs, promptly ripped it all out and grounded the battery to the battery tray/bellcrank mount (F-1035). It worked out great. > R > I think its more important that you ground everything else to a single point like the forest of tabs on the firewall. I have my tail strobe locally grounded at the end of the tail and it's making a slight audible noise. Everything else is quiet. > > Lenny > >> On Oct 19, 2017, at 11:58 AM, Tim Olson wrote: >> >> >> +1. I ran an independent #2 ground. >> >> That said, with the number of rivets in the airframe I'm sure you'll be fine as long as you ground to something with a lot of rivets in it. >> I just wanted as low a resistance path to my forest of tabs as >> possible. >> >> Tim >> >> >> On 10/19/2017 10:42 AM, Phillip Perry wrote: >>> Ditto >>> Sent from my iPhone >>> On Oct 19, 2017, at 10:35 AM, Shannon Hicks > wrote: >>>> I used a forest of tabs mounted to my firewall with a #2 (I think) cable run from there all the way back to the battery ground in the tailcone. I'm not sure if it was overkill, but I have had zero issues so far. >>>> >>>> I think the plans ground path is through the skin to the battery tray where you ground the battery. >>>> >>>> http://www.bandc.aero/grounding-supplies-battery-cables.aspx >>>> >>>> Shannon >>>> >>>> On Thu, Oct 19, 2017 at 10:27 AM, Kent Ogden > wrote: >>>> >>>> All, >>>> >>>> I have a question/concern regarding a ground return to the >>>> battery. I have primed all my parts and skins with the Akzo Nobel >>>> 2 part primer, which is awesome stuff though it's a smelly pain to >>>> work with. All skin overlaps have been primed on both sides of >>>> the overlap, and this stuff is not conductive at all so the only >>>> electrical path is through the rivets and the small area of the >>>> rivet hole that doesn't always have primer covering it. On the >>>> outside of the plane the rivet heads have contact directly with >>>> the unprimed skin so it's really the inside skin where there is >>>> minimal area in electrical contact. >>>> >>>> I am concerned that using the skin as a ground return to the >>>> battery may not provide an excellent ground path, especially for >>>> the large currents needed for engine cranking. I would really >>>> rather not have to run another heavy wire to the front of the >>>> airplane for ground, but I will if necessary. >>>> >>>> Has anyone else faced this issue and had a problem (or no problem) >>>> using the skin as a ground return? Also, where/how have people >>>> connected the battery ground to the tailcone skin, do you use a >>>> piece of brass or copper buss bar riveted to the bottom skin or >>>> something like that? >>>> >>>> Thanks for any suggestions! >>>> >>>> Kent Ogden >>>> #40710 ultra slow-build :) >>>> >>>> >>>> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Oct 19, 2017
Subject: Navworx
Date: Oct 19, 2017
As others have said, there should be lots of good metal to metal contact with the rivets - when driven properly, they expand radially against the sides of the holes. But if it worries you, its easy to measure. Ground the starter locally, and the same with the negative battery terminal. Run a pair of temporary wires from these locations to a good milli-volt voltmeter in the cockpit. Clear the prop area, and engage the starter. What does the voltmeter read? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473693#473693 ________________________________________________________________________________
Date: Oct 19, 2017
Along that line, its important to remember that the conductivity you get today may not be e conductivity you see 3, 5, or 10 years down the road. As corrosion sets in over time, resistance will increase and circuit performance is degrade. If youre in a highly corrosive environment like those of us along the gulf coast, its probably a wise investment to run a dedicated grounding wire. We spend way too much time in this area chasing down grounding problems that are frequently caused by corrosion. Often times, they get fixed by running a dedicated ground to whatever device is having problems. Phil Sent from my iPhone > On Oct 19, 2017, at 4:39 PM, Bob Turner wrote: > > > As others have said, there should be lots of good metal to metal contact with the rivets - when driven properly, they expand radially against the sides of the holes. But if it worries you, its easy to measure. Ground the starter locally, and the same with the negative battery terminal. Run a pair of temporary wires from these locations to a good milli-volt voltmeter in the cockpit. Clear the prop area, and engage the starter. What does the voltmeter read? > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473693#473693 > > > > > > > > > ________________________________________________________________________________
Date: Oct 19, 2017
Same boat here. No run from forest on firewall back to batt. LED nav and strobe lights locally grounded. No issues with those. But... I do have crazy noise when my locally grounded HID landing light ballasts heat up at first. It subsides once the draw rush is over. Thinking of swapping out for LED landing lights anyways, but have been unable to make them quiet. -Sean #40303 > Kelly McMullen > October 19, 2017 at 4:08 PM > > The airframe has plenty of surface area to carry any amount of current > you will use. > Running a separate cable from the battery to firewall central > grounding point is a totally wasted effort. > Strobes are a bit different animal if you are talking the old > capacitive discharge into a flash tube variety. They do generate noise > that is hard to totally suppress. > LED strobes don't seem to do that. > I have electrical system from battery to VPX system built to plans, > with grounding cable to frame , in front of battery box. > I have LED nav lights and strobes, all grounded locally, along with > Vans landing lights grounded locally. > The central grounding is essential for electronics that amplify noises > such as intercoms, nav coms etc. It is unnecessary for resistive > electrical loads, as they don't generate RF noise. > My previous aircraft was a Mooney that was built with full zinc > chromate primer, mostly non-structural skin, and chrome-moly tube > frame, with battery behind baggage compartment. It was just fine with > ground wire to airframe at battery. Cessna does the same. > > ________________________________________________________________________________
Date: Oct 19, 2017
Just a data point, even with a dedicated ground, my LED nav/strobes did have considerable noise. So much that it required a wholesale replacement of the lights. I didnt discover it until taxiing our for flight #1, so it became the first item I discovered before I ever left the ground. Come to find out, it wasnt a grounding or wiring problem, it was a design problem within the LED. The LEDs I had more pulled current when they were on and less when they were off. This created a surge that also broke the auto-squelch on my GTN750. So every time they fired, the squelch in my headset broke too. This required a new LED design that had a more linear current flow. So the current would remain constant even in the off cycles. This addressed the auto-squelch on the GTN. The newer Garmin Nav/Coms dont have a squelch knob. They sense the noise floor and then automatically adjust the squelch to match the floor. With a constant current draw the floor became constant again and the squelch became functional again. Just a word of caution as you go shop LEDs that flash. My were from a very reputable Certified and Experimental lighting provider and not cheapos from Napa. Its good to ask questions about the current flow patterns and not just be current flow; especially if your using newer radios with auto squelch. Fortunately the provider I used worked with me to make a swap to a newer LED version relatively painless and simple. Sent from my iPhone > On Oct 19, 2017, at 6:23 PM, Sean Stephens wrote: > > > Same boat here. No run from forest on firewall back to batt. LED nav and strobe lights locally grounded. No issues with those. But... I do have crazy noise when my locally grounded HID landing light ballasts heat up at first. It subsides once the draw rush is over. Thinking of swapping out for LED landing lights anyways, but have been unable to make them quiet. > > -Sean #40303 > >> Kelly McMullen >> October 19, 2017 at 4:08 PM >> >> The airframe has plenty of surface area to carry any amount of current you will use. >> Running a separate cable from the battery to firewall central grounding point is a totally wasted effort. >> Strobes are a bit different animal if you are talking the old capacitive discharge into a flash tube variety. They do generate noise that is hard to totally suppress. >> LED strobes don't seem to do that. >> I have electrical system from battery to VPX system built to plans, with grounding cable to frame , in front of battery box. >> I have LED nav lights and strobes, all grounded locally, along with Vans landing lights grounded locally. >> The central grounding is essential for electronics that amplify noises such as intercoms, nav coms etc. It is unnecessary for resistive electrical loads, as they don't generate RF noise. >> My previous aircraft was a Mooney that was built with full zinc chromate primer, mostly non-structural skin, and chrome-moly tube frame, with battery behind baggage compartment. It was just fine with ground wire to airframe at battery. Cessna does the same. >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Oct 19, 2017
If the conductivity of the airframe deteriorates, it means that a *lot* of rivets were not driven properly and are going to start smoking soon, if they aren't already. I grant you corrosive environments are difficult. I sure would want to have a hangar in those locations. On 10/19/2017 3:08 PM, Phillip Perry wrote: > > Along that line, its important to remember that the conductivity you get today may not be e conductivity you see 3, 5, or 10 years down the road. As corrosion sets in over time, resistance will increase and circuit performance is degrade. > > If youre in a highly corrosive environment like those of us along the gulf coast, its probably a wise investment to run a dedicated grounding wire. > > We spend way too much time in this area chasing down grounding problems that are frequently caused by corrosion. Often times, they get fixed by running a dedicated ground to whatever device is having problems. > > Phil ________________________________________________________________________________
Date: Oct 19, 2017
Thats why our gulf coast planes tend to be heavier. We soak them in primer! :) Its better here in Waco than when I was in Houston. I dont miss the rust and corrosion on everything. My hand tools look like trash after years of working down there. You could use a new tool in the morning and by the next morning it would have rust forming on it. When we move to Waco, being able to keep bread on the counter more than 4 Days was awesome! :) Sent from my iPhone > On Oct 19, 2017, at 6:52 PM, Kelly McMullen wrote: > > > If the conductivity of the airframe deteriorates, it means that a *lot* of rivets were not driven properly and are going to start smoking soon, if they aren't already. I grant you corrosive environments are difficult. I sure would want to have a hangar in those locations. > >> On 10/19/2017 3:08 PM, Phillip Perry wrote: >> Along that line, its important to remember that the conductivity you get today may not be e conductivity you see 3, 5, or 10 years down the road. As corrosion sets in over time, resistance will increase and circuit performance is degrade. >> If youre in a highly corrosive environment like those of us along the gulf coast, its probably a wise investment to run a dedicated grounding wire. >> We spend way too much time in this area chasing down grounding problems that are frequently caused by corrosion. Often times, they get fixed by running a dedicated ground to whatever device is having problems. >> Phil > > > ________________________________________________________________________________
Date: Oct 20, 2017
Philip Can you share the brand and supplier of your new LED lights? Thanks Carlos Enviado do meu iPhone No dia 20/10/2017, s 00:52, Phillip Perry escreveu: > > Just a data point, even with a dedicated ground, my LED nav/strobes did have considerable noise. So much that it required a wholesale replacement of the lights. I didnt discover it until taxiing our for flight #1, so it became the first item I discovered before I ever left the ground. > > Come to find out, it wasnt a grounding or wiring problem, it was a design problem within the LED. The LEDs I had more pulled current when they were on and less when they were off. This created a surge that also broke the auto-squelch on my GTN750. So every time they fired, the squelch in my headset broke too. > > This required a new LED design that had a more linear current flow. So the current would remain constant even in the off cycles. This addressed the auto-squelch on the GTN. > > The newer Garmin Nav/Coms dont have a squelch knob. They sense the noise floor and then automatically adjust the squelch to match the floor. With a constant current draw the floor became constant again and the squelch became functional again. > > Just a word of caution as you go shop LEDs that flash. My were from a very reputable Certified and Experimental lighting provider and not cheapos from Napa. Its good to ask questions about the current flow patterns and not just be current flow; especially if your using newer radios with auto squelch. > > Fortunately the provider I used worked with me to make a swap to a newer LED version relatively painless and simple. > > > > Sent from my iPhone > >> On Oct 19, 2017, at 6:23 PM, Sean Stephens wrote: >> >> >> Same boat here. No run from forest on firewall back to batt. LED nav and strobe lights locally grounded. No issues with those. But... I do have crazy noise when my locally grounded HID landing light ballasts heat up at first. It subsides once the draw rush is over. Thinking of swapping out for LED landing lights anyways, but have been unable to make them quiet. >> >> -Sean #40303 >> >>> Kelly McMullen >>> October 19, 2017 at 4:08 PM >>> >>> The airframe has plenty of surface area to carry any amount of current you will use. >>> Running a separate cable from the battery to firewall central grounding point is a totally wasted effort. >>> Strobes are a bit different animal if you are talking the old capacitive discharge into a flash tube variety. They do generate noise that is hard to totally suppress. >>> LED strobes don't seem to do that. >>> I have electrical system from battery to VPX system built to plans, with grounding cable to frame , in front of battery box. >>> I have LED nav lights and strobes, all grounded locally, along with Vans landing lights grounded locally. >>> The central grounding is essential for electronics that amplify noises such as intercoms, nav coms etc. It is unnecessary for resistive electrical loads, as they don't generate RF noise. >>> My previous aircraft was a Mooney that was built with full zinc chromate primer, mostly non-structural skin, and chrome-moly tube frame, with battery behind baggage compartment. It was just fine with ground wire to airframe at battery. Cessna does the same. >>> >>> >>> >>> >>> >> >> >> >> > > > > ________________________________________________________________________________
Date: Oct 20, 2017
Learn something every day - what kind of LED lighting device pulls the same current when off as it does when on, and why would we want it to do so? Please explain. On Fri, Oct 20, 2017 at 3:59 AM, Carlos Trigo wrote : > > Philip > > Can you share the brand and supplier of your new LED lights? > > Thanks > Carlos > > Enviado do meu iPhone > > No dia 20/10/2017, =C3-s 00:52, Phillip Perry > escreveu: > > > > > Just a data point, even with a dedicated ground, my LED nav/strobes did > have considerable noise. So much that it required a wholesale replacemen t > of the lights. I didn=99t discover it until taxiing our for flight #1, so it > became the first item I discovered before I ever left the ground. > > > > Come to find out, it wasn=99t a grounding or wiring problem, it w as a > design problem within the LED. The LED=99s I had more pulled curr ent when > they were on and less when they were off. This created a surge that also > broke the auto-squelch on my GTN750. So every time they fired, the > squelch in my headset broke too. > > > > This required a new LED design that had a more linear current flow. S o > the current would remain constant even in the off cycles. This address ed > the auto-squelch on the GTN. > > > > The newer Garmin Nav/Com=99s don=99t have a squelch knob. They sense the > noise floor and then automatically adjust the squelch to match the floor. > With a constant current draw the floor became constant again and the > squelch became functional again. > > > > Just a word of caution as you go shop LED=99s that flash. My we re from a > very reputable Certified and Experimental lighting provider and not > cheapo=99s from Napa. It=99s good to ask questions about the current flow > patterns and not just be current flow; especially if your using newer > radios with auto squelch. > > > > Fortunately the provider I used worked with me to make a swap to a newe r > LED version relatively painless and simple. > > > > > > > > Sent from my iPhone > > > >> On Oct 19, 2017, at 6:23 PM, Sean Stephens > wrote: > >> > > >> > >> Same boat here. No run from forest on firewall back to batt. LED nav > and strobe lights locally grounded. No issues with those. But... I do > have crazy noise when my locally grounded HID landing light ballasts heat > up at first. It subsides once the draw rush is over. Thinking of swappi ng > out for LED landing lights anyways, but have been unable to make them qui et. > >> > >> -Sean #40303 > >> > >>> Kelly McMullen > >>> October 19, 2017 at 4:08 PM > >>> > >>> The airframe has plenty of surface area to carry any amount of curren t > you will use. > >>> Running a separate cable from the battery to firewall central > grounding point is a totally wasted effort. > >>> Strobes are a bit different animal if you are talking the old > capacitive discharge into a flash tube variety. They do generate noise th at > is hard to totally suppress. > >>> LED strobes don't seem to do that. > >>> I have electrical system from battery to VPX system built to plans, > with grounding cable to frame , in front of battery box. > >>> I have LED nav lights and strobes, all grounded locally, along with > Vans landing lights grounded locally. > >>> The central grounding is essential for electronics that amplify noise s > such as intercoms, nav coms etc. It is unnecessary for resistive electric al > loads, as they don't generate RF noise. > >>> My previous aircraft was a Mooney that was built with full zinc > chromate primer, mostly non-structural skin, and chrome-moly tube frame, > with battery behind baggage compartment. It was just fine with ground wir e > to airframe at battery. Cessna does the same. > >>> > >>> > >>> > >>> > >>> > >> > >> > >> > >> > > > > > > > > > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Oct 20, 2017
When I went through it, it they referred to it is a linear current flow. Sent from my iPhone > On Oct 20, 2017, at 10:54 AM, Bill Boyd wrote: > > Learn something every day - what kind of LED lighting device pulls the sam e current when off as it does when on, and why would we want it to do so? P lease explain. > >> On Fri, Oct 20, 2017 at 3:59 AM, Carlos Trigo wro te: >> >> Philip >> >> Can you share the brand and supplier of your new LED lights? >> >> Thanks >> Carlos >> >> Enviado do meu iPhone >> >> No dia 20/10/2017, =C3-s 00:52, Phillip Perry es creveu: >> >> > >> > Just a data point, even with a dedicated ground, my LED nav/strobes did have considerable noise. So much that it required a wholesale replacement o f the lights. I didn=99t discover it until taxiing our for flight #1, so it became the first item I discovered before I ever left the ground. >> > >> > Come to find out, it wasn=99t a grounding or wiring problem, it w as a design problem within the LED. The LED=99s I had more pulled cu rrent when they were on and less when they were off. This created a surge t hat also broke the auto-squelch on my GTN750. So every time they fired, th e squelch in my headset broke too. >> > >> > This required a new LED design that had a more linear current flow. S o the current would remain constant even in the off cycles. This addresse d the auto-squelch on the GTN. >> > >> > The newer Garmin Nav/Com=99s don=99t have a squelch knob. They sense the noise floor and then automatically adjust the squelch to mat ch the floor. With a constant current draw the floor became constant agai n and the squelch became functional again. >> > >> > Just a word of caution as you go shop LED=99s that flash. My we re from a very reputable Certified and Experimental lighting provider and no t cheapo=99s from Napa. It=99s good to ask questions about the c urrent flow patterns and not just be current flow; especially if your using n ewer radios with auto squelch. >> > >> > Fortunately the provider I used worked with me to make a swap to a newe r LED version relatively painless and simple. >> > >> > >> > >> > Sent from my iPhone >> > >> >> On Oct 19, 2017, at 6:23 PM, Sean Stephens wr ote: >> >> > >> >> >> >> Same boat here. No run from forest on firewall back to batt. LED nav and strobe lights locally grounded. No issues with those. But... I do hav e crazy noise when my locally grounded HID landing light ballasts heat up at first. It subsides once the draw rush is over. Thinking of swapping out f or LED landing lights anyways, but have been unable to make them quiet. >> >> >> >> -Sean #40303 >> >> >> >>> Kelly McMullen >> >>> October 19, 2017 at 4:08 PM >> >>> >> >>> The airframe has plenty of surface area to carry any amount of curren t you will use. >> >>> Running a separate cable from the battery to firewall central groundi ng point is a totally wasted effort. >> >>> Strobes are a bit different animal if you are talking the old capacit ive discharge into a flash tube variety. They do generate noise that is hard to totally suppress. >> >>> LED strobes don't seem to do that. >> >>> I have electrical system from battery to VPX system built to plans, w ith grounding cable to frame , in front of battery box. >> >>> I have LED nav lights and strobes, all grounded locally, along with V ans landing lights grounded locally. >> >>> The central grounding is essential for electronics that amplify noise s such as intercoms, nav coms etc. It is unnecessary for resistive electrica l loads, as they don't generate RF noise. >> >>> My previous aircraft was a Mooney that was built with full zinc chrom ate primer, mostly non-structural skin, and chrome-moly tube frame, with bat tery behind baggage compartment. It was just fine with ground wire to airfra me at battery. Cessna does the same. >> >>> >> >>> >> >>> >> >>> >> >>> >> >> >> >> >> >> >> >> >> > >> > >> > >> > >> >> >> ========================= >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= >> >> >> > ________________________________________________________________________________
Date: Oct 20, 2017
Hi Kent and everyone. In my opinion you don't need to rum a ground cable to your battery, I read very good advices regarding that to your answer. If you allow me; OUT of your question but INSIDE the ground subject For your instruments and every other equipment that needs power. Run three ground wires (all of them direct from battery) not from the point you grounded your battery. MASTER GROUND - This ground should be used to every electrically "dirt" instruments or lights - IF you have real noisy and pulsing strobos I'd consider to have an extra "REALY DIRT MASTER GROUND" also tied directly to battery. AUDIO INSTRUMENT GROUND - It's only for those instruments related to audio signals (a transponder should not be tied here, the same for the glasses instruments - such as PFDs, MFDs and Skyview screens) AUDIO GROUND - Used only and only, to ground audio signals and its shields. When running ground connections it's highly recommended to run these connections instrument to instrument. I mean, run a wire from the radio ground up to the audio panel, the same for every other ground signal. if he audio panel connector doesn't have have enough pins tie all those grounds to a common wire and that wire to the audio unit. Also insulate from the air frame the ground of the headsets connector. The general idea is always lay down your wiring as a star. Regarding to ground your battery is the center of you galaxy :-) I'm ware that seems to be to much, but it isn't, doing that you will listen only the sounds that mater. Best Regards Dilson Em 19/10/2017 19:08, Kelly McMullen escreveu: > > The airframe has plenty of surface area to carry any amount of current > you will use. > Running a separate cable from the battery to firewall central > grounding point is a totally wasted effort. > Strobes are a bit different animal if you are talking the old > capacitive discharge into a flash tube variety. They do generate noise > that is hard to totally suppress. > LED strobes don't seem to do that. > I have electrical system from battery to VPX system built to plans, > with grounding cable to frame , in front of battery box. > I have LED nav lights and strobes, all grounded locally, along with > Vans landing lights grounded locally. > The central grounding is essential for electronics that amplify noises > such as intercoms, nav coms etc. It is unnecessary for resistive > electrical loads, as they don't generate RF noise. > My previous aircraft was a Mooney that was built with full zinc > chromate primer, mostly non-structural skin, and chrome-moly tube > frame, with battery behind baggage compartment. It was just fine with > ground wire to airframe at battery. Cessna does the same. > > On 10/19/2017 9:35 AM, Lenny Iszak wrote: >> >> I originally ran a #2 wire to the firewall forest of tabs, then >> realized how much it weighs, promptly ripped it all out and grounded >> the battery to the battery tray/bellcrank mount (F-1035). It worked >> out great. >> R >> I think its more important that you ground everything else to a >> single point like the forest of tabs on the firewall. I have my tail >> strobe locally grounded at the end of the tail and it's making a >> slight audible noise. Everything else is quiet. >> >> Lenny >> >>> On Oct 19, 2017, at 11:58 AM, Tim Olson wrote: >>> >>> >>> +1. I ran an independent #2 ground. >>> >>> That said, with the number of rivets in the airframe I'm sure you'll >>> be fine as long as you ground to something with a lot of rivets in it. >>> I just wanted as low a resistance path to my forest of tabs as >>> possible. >>> >>> Tim >>> >>> >>> On 10/19/2017 10:42 AM, Phillip Perry wrote: >>>> Ditto >>>> Sent from my iPhone >>>> On Oct 19, 2017, at 10:35 AM, Shannon Hicks >>> > wrote: >>>>> I used a forest of tabs mounted to my firewall with a #2 (I think) >>>>> cable run from there all the way back to the battery ground in the >>>>> tailcone. I'm not sure if it was overkill, but I have had zero >>>>> issues so far. >>>>> >>>>> I think the plans ground path is through the skin to the battery >>>>> tray where you ground the battery. >>>>> >>>>> http://www.bandc.aero/grounding-supplies-battery-cables.aspx >>>>> >>>>> Shannon >>>>> >>>>> On Thu, Oct 19, 2017 at 10:27 AM, Kent Ogden >>>> > wrote: >>>>> >>>>> All, >>>>> >>>>> I have a question/concern regarding a ground return to the >>>>> battery. I have primed all my parts and skins with the Akzo >>>>> Nobel >>>>> 2 part primer, which is awesome stuff though it's a smelly >>>>> pain to >>>>> work with. All skin overlaps have been primed on both sides of >>>>> the overlap, and this stuff is not conductive at all so the only >>>>> electrical path is through the rivets and the small area of the >>>>> rivet hole that doesn't always have primer covering it. On the >>>>> outside of the plane the rivet heads have contact directly with >>>>> the unprimed skin so it's really the inside skin where there is >>>>> minimal area in electrical contact. >>>>> >>>>> I am concerned that using the skin as a ground return to the >>>>> battery may not provide an excellent ground path, especially for >>>>> the large currents needed for engine cranking. I would really >>>>> rather not have to run another heavy wire to the front of the >>>>> airplane for ground, but I will if necessary. >>>>> >>>>> Has anyone else faced this issue and had a problem (or no >>>>> problem) >>>>> using the skin as a ground return? Also, where/how have people >>>>> connected the battery ground to the tailcone skin, do you use a >>>>> piece of brass or copper buss bar riveted to the bottom skin or >>>>> something like that? >>>>> >>>>> Thanks for any suggestions! >>>>> >>>>> Kent Ogden >>>>> #40710 ultra slow-build :) >>>>> >>>>> >>>>> >>> >>> >>> >>> >> >> >> >> >> > > ________________________________________________________________________________
Date: Oct 20, 2017
sportav8r(at)gmail.com wrote: > Learn something every day - what kind of LED lighting device pulls the same current when off as it does when on, and why would we want it to do so? Please explain. > > [/quote] You cannot just hook an LED up to 12 volts; it will pull a huge current and quickly overheat and fail. For low power lights (like panel) a dropping resistor is used. Very simple and easy, but 90% of the energy ends up in the resistor. Okay for low power lights, but not for position or landing lights. There, something more sophisticated is needed. The usual solution is to pulse the lights on/off, faster than your eye can see, to limit the power and heat build up. Those pulses can radiate RF and cause interference to other electronics. Some circuits add "smoothing" downstream to limit the RF, and provide a lower average current to the LED. So the LED has some average current thru it, while the power supply is pulsed. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473714#473714 ________________________________________________________________________________
Subject: Starter upgrade
Date: Oct 22, 2017
I've got the old LS starter that used to ship way back when with the IO540, and am planning to upgrade during the panel upgrade this winter. Anyone have feedback on the B&C lightweight starter vs the Skytec -NL model? Performance, weight, fit issues, etc? Thanks in advance. Thomas Short Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473750#473750 ________________________________________________________________________________
Subject: Re: Starter upgrade
Date: Oct 22, 2017
I have the NL on my RV-6 and have been very pleased. Most people who use the NL seem to have been satisfied. On the -10, I'm going with the B&C, just because I got a good deal on it. I don't think you'll go wrong with either one. KB -----Original Message----- From: tshort Sent: Sunday, October 22, 2017 3:53 AM Subject: RV10-List: Starter upgrade I've got the old LS starter that used to ship way back when with the IO540, and am planning to upgrade during the panel upgrade this winter. Anyone have feedback on the B&C lightweight starter vs the Skytec -NL model? Performance, weight, fit issues, etc? Thanks in advance. Thomas Short Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473750#473750 ________________________________________________________________________________
Date: Oct 22, 2017
I'd agree...between the two you will be happy either way. I just got 2 of the NL's last year. They both work better than the LS and PM. Tim > On Oct 22, 2017, at 9:17 AM, wrote: > > > I have the NL on my RV-6 and have been very pleased. Most people who use the NL seem to have been satisfied. > > On the -10, I'm going with the B&C, just because I got a good deal on it. > > I don't think you'll go wrong with either one. > > KB > > -----Original Message----- From: tshort > Sent: Sunday, October 22, 2017 3:53 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Starter upgrade > > > I've got the old LS starter that used to ship way back when with the IO540, and am planning to upgrade during the panel upgrade this winter. > > Anyone have feedback on the B&C lightweight starter vs the Skytec -NL model? > > Performance, weight, fit issues, etc? > > Thanks in advance. > > Thomas Short > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473750#473750 > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 22, 2017
IF you go with the NL, be sure to get the latest version that has improved kickback protection. The original used a shear pin, which could not be replaced without removal of the starter. On 10/22/2017 7:17 AM, kboatright1(at)comcast.net wrote: > > I have the NL on my RV-6 and have been very pleased. Most people who use > the NL seem to have been satisfied. > > On the -10, I'm going with the B&C, just because I got a good deal on it. > > I don't think you'll go wrong with either one. > > KB > > -----Original Message----- From: tshort > Sent: Sunday, October 22, 2017 3:53 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Starter upgrade > > > I've got the old LS starter that used to ship way back when with the > IO540, and am planning to upgrade during the panel upgrade this winter. > > Anyone have feedback on the B&C lightweight starter vs the Skytec -NL > model? > > Performance, weight, fit issues, etc? > > Thanks in advance. > > Thomas Short > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473750#473750 > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 22, 2017
How new are you talking, by "latest"? Mine were from 2017, and I've unboxed 3 of them this year, and every one of them came with a shear pin glued to the top under the boss mount. I do know that they advertise a new Kickback Protection System, but I do believe it's still a shear pin and since it's glued to the boss mount, I can't see it being replaced without removal of the starter. It does say: "Kickback Protection System (KPS) with field-replaceable shear pin" ... on their website. Perhaps we are supposed to cut out the pin and keep it in the plane? If that were the case though, why would they just not attach it to the starter in a ziploc bag like they do the star washers? So, I think even the current one requires a shear pin. That said, I've never had a kickback issue with any of the starters over all of these years, so I'm not sure I'd worry too much about it, if you have a well configured ignition system. Tim On 10/22/2017 5:50 PM, Kelly McMullen wrote: > > IF you go with the NL, be sure to get the latest version that has > improved kickback protection. The original used a shear pin, which > could not be replaced without removal of the starter. > > ________________________________________________________________________________
Date: Oct 23, 2017
Just an FYI.=C2- The starters and alternators are no longer being provide d and serviced by the same group as before.=C2- It's now Hartzell.=C2- Big company, big company service, NOT.Don McDonald From: Tim Olson <Tim(at)MyRV10.com> To: rv10-list(at)matronics.com Sent: Sunday, October 22, 2017 6:20 PM Subject: Re: RV10-List: Starter upgrade How new are you talking, by "latest"? Mine were from 2017, and I've unboxed 3 of them this year, and every one o f them came with a shear pin glued to the top under the boss mount. I do know that they advertise a new Kickback Protection System, but I do believe it's still a shear pin and since it's glued to the boss m ount, I can't see it being replaced without removal of the starter.=C2- It does say: "Kickback Protection System (KPS) with field-replaceable shear pin" ... on their website.=C2- Perhaps we are supposed to cut out the pin and keep it in the plane?=C2- If that were the case though, why would they j ust not attach it to the starter in a ziploc bag like they do the star washers ? So, I think even the current one requires a shear pin. That said, I've never had a kickback issue with any of the starters over all of these years, so I'm not sure I'd worry too much about it, if you have a well configured ignition system. Tim On 10/22/2017 5:50 PM, Kelly McMullen wrote: IF you go with the NL, be sure to get the latest version that has improved kickback protection. The original used a shear pin, which could not be rep laced without removal of the starter. ________________________________________________________________________________
Date: Oct 22, 2017
Subject: Breakable ties
Guys, I bought a 500-yr supply of these little breakable ties for $5. [image: Inline image 4][image: Inline image 5] I use them on my alternate air knob, and I pull it once a year to make sure it works. If anybody wants some, just send me a PM with an address and I'll send you an envelope full. The McMaster no. is 7189K31 if you want to look up all the gory details. --Dave ________________________________________________________________________________
Date: Oct 22, 2017
I have had good service from them, myself. I almost didn=99t once, bu t it ended up being done right. So I=99m not of the opinion that from a service/support perspective they are bad. Maybe some people have other e xperiences. My worst experience was that if you simply call and hope someon e will answer, chances are they won=99t....but if you leave a voice me ssage, you get a prompt response. I don=99t usually leave VM=99 s so it took me a few calls to actually get connected once Tim > On Oct 22, 2017, at 8:25 PM, Don McDonald wrot e: > > Just an FYI. The starters and alternators are no longer being provided an d serviced by the same group as before. It's now Hartzell. Big company, bi g company service, NOT. > Don McDonald > > From: Tim Olson <Tim(at)MyRV10.com> > To: rv10-list(at)matronics.com > Sent: Sunday, October 22, 2017 6:20 PM > Subject: Re: RV10-List: Starter upgrade > > How new are you talking, by "latest"? > > Mine were from 2017, and I've unboxed 3 of them this year, and every one o f them came > with a shear pin glued to the top under the boss mount. > I do know that they advertise a new Kickback Protection System, > but I do believe it's still a shear pin and since it's glued to the boss m ount, I can't see it being > replaced without removal of the starter. It does say: > > "Kickback Protection System (KPS) with field-replaceable shear pin" > ... on their website. Perhaps we are supposed to cut out the pin and > keep it in the plane? If that were the case though, why would they just > not attach it to the starter in a ziploc bag like they do the star washers ? > > So, I think even the current one requires a shear pin. > That said, I've never had a kickback issue with any of the starters > over all of these years, so I'm not sure I'd worry too much about it, > if you have a well configured ignition system. > > Tim > >> On 10/22/2017 5:50 PM, Kelly McMullen wrote: >> >> IF you go with the NL, be sure to get the latest version that has improve d kickback protection. The original used a shear pin, which could not be rep laced without removal of the starter. >> >> >> >> > > > ________________________________________________________________________________
From: John MacCallum <john.maccallum(at)bigpond.com>
Date: Oct 23, 2017
Your not wrong about no service Don. The Field wire broke off on my Plane Po wer 60Amp in my RV10. The Alternator was brand new and had about 10 hours on it. They were not interested and wouldn't even tell me what type of plug is used so that I could buy another and fix it myself. Which is of course what I ended up doing. Cheers John MacCallum VH-DUU #41016 > On 23 Oct 2017, at 12:25, Don McDonald wrote: > > Just an FYI. The starters and alternators are no longer being provided an d serviced by the same group as before. It's now Hartzell. Big company, bi g company service, NOT. > Don McDonald > > From: Tim Olson <Tim(at)MyRV10.com> > To: rv10-list(at)matronics.com > Sent: Sunday, October 22, 2017 6:20 PM > Subject: Re: RV10-List: Starter upgrade > > How new are you talking, by "latest"? > > Mine were from 2017, and I've unboxed 3 of them this year, and every one o f them came > with a shear pin glued to the top under the boss mount. > I do know that they advertise a new Kickback Protection System, > but I do believe it's still a shear pin and since it's glued to the boss m ount, I can't see it being > replaced without removal of the starter. It does say: > > "Kickback Protection System (KPS) with field-replaceable shear pin" > ... on their website. Perhaps we are supposed to cut out the pin and > keep it in the plane? If that were the case though, why would they just > not attach it to the starter in a ziploc bag like they do the star washers ? > > So, I think even the current one requires a shear pin. > That said, I've never had a kickback issue with any of the starters > over all of these years, so I'm not sure I'd worry too much about it, > if you have a well configured ignition system. > > Tim > >> On 10/22/2017 5:50 PM, Kelly McMullen wrote: >> >> IF you go with the NL, be sure to get the latest version that has improve d kickback protection. The original used a shear pin, which could not be rep laced without removal of the starter. >> >> >> >> > > > ________________________________________________________________________________
Subject: Alternator Issue
Date: Oct 23, 2017
Trouble shooting question for you all...I am having some alternator issues. I have the 60 amp PP alternator that comes with FF kit form Vans. I have about 75 hours on plane. My alternator works fine on ground and charges in 13.4 to 13.6 range, but when I am in the air in stays around 12.5 charge rate. It has has been doing that for about last 20 hours. It had a whine with RPM increase. I did some looking with multi meter and reading seemed to consistent throughout system and on both EFIS screen (AF-5000). Out of pure laziness more than anything I swapped for a brand new alternator - same result. Works fine on ground but low charge rate in flight and sometimes with go down to 12.0 volts. I recycle field switch and will sometimes get back up into 13s but doesn't stay. On side note I have a back-up PP 30 amp alternator on vacuum pad that works as it should. Any thoughts? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473795#473795 ________________________________________________________________________________
Subject: Re: Alternator Issue
Date: Oct 23, 2017
Send your question to the aeroelectric-list. Many experts there. aeroelectric-list(at)matronics.com I have same alternator, and I normally get 14.3-14.4 in flight once the battery has recovered from starter current draw. On 10/23/2017 6:25 AM, mhealydds wrote: > > Trouble shooting question for you all...I am having some alternator issues. I have the 60 amp PP alternator that comes with FF kit form Vans. I have about 75 hours on plane. My alternator works fine on ground and charges in 13.4 to 13.6 range, but when I am in the air in stays around 12.5 charge rate. It has has been doing that for about last 20 hours. It had a whine with RPM increase. I did some looking with multi meter and reading seemed to consistent throughout system and on both EFIS screen (AF-5000). Out of pure laziness more than anything I swapped for a brand new alternator - same result. Works fine on ground but low charge rate in flight and sometimes with go down to 12.0 volts. I recycle field switch and will sometimes get back up into 13s but doesn't stay. On side note I have a back-up PP 30 amp alternator on vacuum pad that works as it should. Any thoughts? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473795#473795 > > > > > > > > > ________________________________________________________________________________
Date: Oct 23, 2017
Be sure the belt is tight > On Oct 23, 2017, at 6:25 AM, mhealydds wrote: > > > Trouble shooting question for you all...I am having some alternator issues. I have the 60 amp PP alternator that comes with FF kit form Vans. I have about 75 hours on plane. My alternator works fine on ground and charges in 13.4 to 13.6 range, but when I am in the air in stays around 12.5 charge rate. It has has been doing that for about last 20 hours. It had a whine with RPM increase. I did some looking with multi meter and reading seemed to consistent throughout system and on both EFIS screen (AF-5000). Out of pure laziness more than anything I swapped for a brand new alternator - same result. Works fine on ground but low charge rate in flight and sometimes with go down to 12.0 volts. I recycle field switch and will sometimes get back up into 13s but doesn't stay. On side note I have a back-up PP 30 amp alternator on vacuum pad that works as it should. Any thoughts? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473795#473795 > > > > > > > > > ________________________________________________________________________________
Date: Oct 23, 2017
On the topic of belt slipping, here's the spec and procedure to test. Mine loosened greatly after the first 8-10 hours and required some attention. https://www.lycoming.com/sites/default/files/SI1129D%20Alternator%20Belt%20Tension%2C%20Methods%20of%20Checking.pdf Phil On Mon, Oct 23, 2017 at 9:48 AM, Larry Schneider wrote: > > Be sure the belt is tight > > > On Oct 23, 2017, at 6:25 AM, mhealydds wrote: > > > > > > Trouble shooting question for you all...I am having some alternator > issues. I have the 60 amp PP alternator that comes with FF kit form Vans. I > have about 75 hours on plane. My alternator works fine on ground and > charges in 13.4 to 13.6 range, but when I am in the air in stays around > 12.5 charge rate. It has has been doing that for about last 20 hours. It > had a whine with RPM increase. I did some looking with multi meter and > reading seemed to consistent throughout system and on both EFIS screen > (AF-5000). Out of pure laziness more than anything I swapped for a brand > new alternator - same result. Works fine on ground but low charge rate in > flight and sometimes with go down to 12.0 volts. I recycle field switch and > will sometimes get back up into 13s but doesn't stay. On side note I have a > back-up PP 30 amp alternator on vacuum pad that works as it should. Any > thoughts? > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=473795#473795 > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 23, 2017
It might be an AFS issue. I have two 5800s and one of them was giving me low voltage alarms, getting down to 11.5 or so, the other stayed rock solid displaying 14.1. It only did it once on a longer flight, and it didnt happen again. So, it may not be alternator related. Check the logs on both Efis screens. PP alternators have a whine especially at a higher load, because they have switching regulators. If I knew that before I would have installed a B&C which has an external linear voltage regulator, producing much less noise. Interestingly I dont hear the noise with the Halo headset, but I do with the Bose A20. Lenny > On Oct 23, 2017, at 9:25 AM, mhealydds wrote: > > > Trouble shooting question for you all...I am having some alternator issues. I have the 60 amp PP alternator that comes with FF kit form Vans. I have about 75 hours on plane. My alternator works fine on ground and charges in 13.4 to 13.6 range, but when I am in the air in stays around 12.5 charge rate. It has has been doing that for about last 20 hours. It had a whine with RPM increase. I did some looking with multi meter and reading seemed to consistent throughout system and on both EFIS screen (AF-5000). Out of pure laziness more than anything I swapped for a brand new alternator - same result. Works fine on ground but low charge rate in flight and sometimes with go down to 12.0 volts. I recycle field switch and will sometimes get back up into 13s but doesn't stay. On side note I have a back-up PP 30 amp alternator on vacuum pad that works as it should. Any thoughts? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473795#473795 > > > > > > > > > ________________________________________________________________________________
Date: Oct 23, 2017
Subject: Engine timing
Does anyone know of a website or YouTube video that discusses the effects of engine timing with piston changes. IE: My lycoming (aerosport really) has 9:1 pistons and the data plate still shows stock 20 timing. I have one LSE and one mag. Im considering tweaking my mag timing for the 9:1 pistons and see if I can smooth out the engine a bit more. But before I do, Id like to educate myself with reputable information. Thanks, Phil ________________________________________________________________________________
Date: Oct 23, 2017
Id start by looking at the field circuit. Any chance that switch is failing in flight? Or another connection? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473820#473820 ________________________________________________________________________________
From: "John MacCallum" <john.maccallum(at)bigpond.com>
Date: Oct 24, 2017
Hi everyone, If the Bus Voltage is falling to 12.5 Volts in Flight then the Battery is not being charged at all! These Batteries require more than 13.2 Volts to reach a full charge. The usual output voltage is 14.1 to 14.2 volts so as to overcome the internal resistance of the battery and to push some current through the battery to allow charging to take place. Yes check the belt tension as has been suggested. Check the Field connection and the connections on the output side. As for the Voltage regulator the voltage regulator is a linear regulator that is integral to the Brush Assembly. If there is noticeable whine it could be being caused by blown diodes in the rectifier pack. That will also affect the output voltage. You mention you have the PP 30 back up. If you normally leave the field breaker/switch on that Alternator will provide output when the bus voltage falls below 13 volts. So you might only be looking at what is being supplied by the PP30. I have the same setup on my RV10 and when I first start up, I don't turn Alt 1 on until I have checked that Alt 2 (PP30) is supplying current on the Alternator 2 input on my AFS4500 MFD. It will usually show around 6 to 8 amps of Charging current right after starting. Once that is checked, I turn Alt 1 on and the charging rate will then jump up To around 20 amps on the Alt 1 sensor and Alt 2 will show zero. Cheers John MacCallum VH-DUU RV 10 # 41016 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of mhealydds Sent: Tuesday, 24 October 2017 12:26 AM Subject: RV10-List: Alternator Issue Trouble shooting question for you all...I am having some alternator issues. I have the 60 amp PP alternator that comes with FF kit form Vans. I have about 75 hours on plane. My alternator works fine on ground and charges in 13.4 to 13.6 range, but when I am in the air in stays around 12.5 charge rate. It has has been doing that for about last 20 hours. It had a whine with RPM increase. I did some looking with multi meter and reading seemed to consistent throughout system and on both EFIS screen (AF-5000). Out of pure laziness more than anything I swapped for a brand new alternator - same result. Works fine on ground but low charge rate in flight and sometimes with go down to 12.0 volts. I recycle field switch and will sometimes get back up into 13s but doesn't stay. On side note I have a back-up PP 30 amp alternator on vacuum pad that works as it should. Any thoughts? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473795#473795 ________________________________________________________________________________
Subject: Re: Engine timing
Date: Oct 23, 2017
Phil, higher compression generally means faster burning of the fuel. Thus later timing and higher octane. I have stock 8.5:1 pistons and 25 degree timing. The highest compression Lycoming used for non-helicopter applications was 8.7:1 and they had 20 degree timing, which is why I suspect Aerosport recommended that value. A phone call to Aerosport should verify. Once you are above a certain rpm the LSE will begin advancing timing, depending on manifold pressure, rpm and CHT. I would suspect either plugs or fuel injectors if engine isn't as smooth as you think it should be. You should be able to verify by doing in flight mag check to see if EGT rise on single mag is greater on any one cylinder. On 10/23/2017 12:50 PM, Phillip Perry wrote: > > Does anyone know of a website or YouTube video that discusses the effects of engine timing with piston changes. > > IE: My lycoming (aerosport really) has 9:1 pistons and the data plate still shows stock 20 timing. I have one LSE and one mag. Im considering tweaking my mag timing for the 9:1 pistons and see if I can smooth out the engine a bit more. > > But before I do, Id like to educate myself with reputable information. > > Thanks, > Phil > > > > > > ________________________________________________________________________________
Date: Oct 23, 2017
Although 9:1 isn't really that much higher compression, what I can tell you is that with an increase in timing, 25 degrees, you will have higher cht's .Don McDonald From: Phillip Perry <philperry9(at)gmail.com> To: rv10-list(at)matronics.com Sent: Monday, October 23, 2017 3:02 PM Subject: RV10-List: Engine timing Does anyone know of a website or YouTube video that discusses the effects o f engine timing with piston changes.=C2- IE: My lycoming (aerosport really) has 9:1 pistons and the data plate still shows stock 20=C2=B0 timing.=C2- I have one LSE and one mag.=C2- I =99m considering tweaking my mag timing for the 9:1 pistons and see if I can smooth out the engine a bit more. But before I do, I=99d like to educate myself with reputable informat ion. Thanks, Phil S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Oct 23, 2017
Yes, advancing timing would be the wrong way to go. Would run hotter and have less detonation margin. If anything, it might take backing off to perhaps 18 degrees. On 10/23/2017 2:20 PM, Don McDonald wrote: > Although 9:1 isn't really that much higher compression, what I can tell > you is that with an increase in timing, 25 degrees, you will have higher > cht's. > Don McDonald > > ------------------------------------------------------------------------ > *From:* Phillip Perry > *To:* rv10-list(at)matronics.com > *Sent:* Monday, October 23, 2017 3:02 PM > *Subject:* RV10-List: Engine timing > > > > > Does anyone know of a website or YouTube video that discusses the > effects of engine timing with piston changes. > > IE: My lycoming (aerosport really) has 9:1 pistons and the data plate > still shows stock 20 timing. I have one LSE and one mag. Im > considering tweaking my mag timing for the 9:1 pistons and see if I can > smooth out the engine a bit more. > > But before I do, Id like to educate myself with reputable information. > > Thanks, > Phil > > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://wiki.matronics.com > http://www.matron== > > > > > ________________________________________________________________________________
Date: Oct 23, 2017
If you want to learn about how to properly run your engine (ROP, LOP, TIming, the Red Box, etc) check out the people at GAMI and their Advanced Pilot seminars. They have a weekend class that is amazing but most of the information is covered in their on-line seminar. AdvancedPilot.com It's well worth the price of admission if you truly want to know the facts (and fallacies) about managing EGT, CHT, timing, and electronic ignitions. Highly recommended. Nick -------- Nick Leonard RV-10 (40015) Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473830#473830 ________________________________________________________________________________
Date: Oct 23, 2017
I am no expert on this issue, but the people that built my engine are and have been producing reliable high performance engines for years. Barrett Precision Engines built my engine with their own cold air induction system, 9-1 pistons, Airflow Performance FM300 throttle body, Superior bearings and cylinders. and Bendix mags. They dataplate they put on it specifies timing at 25 degrees before top dead center. It came in at 288hp on the dyno. I have no idea what the Lycoming Manual says about this, but then it is no longer a stock Lycoming Robert Jones > On Oct 23, 2017, at 17:06, Kelly McMullen wrote: > > > Yes, advancing timing would be the wrong way to go. Would run hotter and have less detonation margin. If anything, it might take backing off to perhaps 18 degrees. > >> On 10/23/2017 2:20 PM, Don McDonald wrote: >> Although 9:1 isn't really that much higher compression, what I can tell you is that with an increase in timing, 25 degrees, you will have higher cht's. >> Don McDonald >> ------------------------------------------------------------------------ >> *From:* Phillip Perry >> *To:* rv10-list(at)matronics.com >> *Sent:* Monday, October 23, 2017 3:02 PM >> *Subject:* RV10-List: Engine timing >> Does anyone know of a website or YouTube video that discusses the effects of engine timing with piston changes. >> IE: My lycoming (aerosport really) has 9:1 pistons and the data plate still shows stock 20 timing. I have one LSE and one mag. Im considering tweaking my mag timing for the 9:1 pistons and see if I can smooth out the engine a bit more. >> But before I do, Id like to educate myself with reputable information. >> Thanks, >> Phil >> http://www.matronics.com/Navigator?RV10-List >> http://forums.matronics.com >> http://wiki.matronics.com >> http://www.matron== > > > ________________________________________________________________________________
Date: Oct 25, 2017
I removed the Skytec PM which didnt have enough power to turn over my IO540 with high compression pistons. I replaced it with the BandC starter, which works fine. Im mainly posting because the link between the starter and Plane Power alternator did not fit the BandC. Neither did either of the links BandC provided. I was able to drill a new 5/16 hole in the old link after bending it slightly; worked fine. I had called Plane Power and they strongly advised against leaving the link off. I believe the P/N for the link is 1002. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473870#473870 ________________________________________________________________________________
Date: Nov 01, 2017
Subject: PLEASE READ - Matronics Email List 2017 Fund Raiser During
November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are 9 great gifts to choose from! There's something for everyone, to be sure. Please make your List Contribution using any one of three secure methods including using a Credit Card, PayPal, or by Personal Check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Subject: ipad gps
Date: Nov 01, 2017
I installed a Garmin 496 and a AirGizmo mount in my panel to provide a GPS signal to my TruTrak autopilot and it worked very well until recently when it seems to have failed. New battery didn't help. Since I had recently started using an ipad on a RAM mount I'm think I would not replace the Garmin but use the ipad instead. Question is though-how do I get a GPS steering signal out of the ipad to the TruTrak? Albert Gardner RV-10 N991RV Yuma, Arizona ________________________________________________________________________________
Subject: ipad gps
Date: Nov 01, 2017
Looking on ebay for info about the price of Garmin gps units I ran across a listing for a repair service (out of Russia of all places). https://www.ebay.com/itm/Repair-Service-for-Garmin-GPSmap-296-396-496-495-Co lor-Chartplotter-GPS-Fix/263072741620?hash=item3d405b78f4:g:mrUAAOSwgv5ZXJgb Anybody ever had one repaired or used a Russian repair service before? Albert? --> I installed a Garmin 496 and a AirGizmo mount in my panel to provide a GPS signal --> to my TruTrak autopilot and it worked very well until recently when it seems to --> have failed. New battery didn't help. Since I had recently started using an ipad --> on a RAM mount I'm think I would not replace the Garmin but use the ipad instead. --> Question is though-how do I get a GPS steering signal out of the ipad to the --> TruTrak? --> Albert Gardner --> RV-10 N991RV --> Yuma, Arizona ________________________________________________________________________________
Date: Nov 01, 2017
Subject: Re: ipad gps
If you are just looking to get GPS to your TruTrak, I would look at just a simple GPS puck If you dont have another suitable GPS in the plane already.. You can buy something like the Garman GPS 18 for very cheap. The TruTrak is pretty easy to integrate with a GPS, even a simple sirf GPS. Tim > On Nov 1, 2017, at 11:58 AM, Albert wrote: > > > Looking on ebay for info about the price of Garmin gps units I ran across a > listing for a repair service (out of Russia of all places). > > https://www.ebay.com/itm/Repair-Service-for-Garmin-GPSmap-296-396-496-495-Co > lor-Chartplotter-GPS-Fix/263072741620?hash=item3d405b78f4:g:mrUAAOSwgv5ZXJgb > > Anybody ever had one repaired or used a Russian repair service before? > Albert? > > > > --> I installed a Garmin 496 and a AirGizmo mount in my panel to provide a > GPS signal --> to my TruTrak autopilot and it worked very well until > recently when it seems to --> have failed. New battery didn't help. Since I > had recently started using an ipad --> on a RAM mount I'm think I would not > replace the Garmin but use the ipad instead. --> Question is though-how do I > get a GPS steering signal out of the ipad to the --> TruTrak? > --> Albert Gardner > --> RV-10 N991RV > --> Yuma, Arizona > > > > > > > ________________________________________________________________________________
Date: Nov 01, 2017
I have been using one of these with no issues: GlobalSat BR-355 Serial GPS Receiver On Wed, Nov 1, 2017 at 1:34 PM, Tim Olson wrote: > > If you are just looking to get GPS to your TruTrak, I would look at just a > simple GPS puck If you don=99t have another suitable GPS in the pla ne > already.. You can buy something like the Garman GPS 18 for very cheap. T he > TruTrak is pretty easy to integrate with a GPS, even a simple sirf GPS. > Tim > > > On Nov 1, 2017, at 11:58 AM, Albert wrote: > > > > > > Looking on ebay for info about the price of Garmin gps units I ran > across a > > listing for a repair service (out of Russia of all places). > > > > https://www.ebay.com/itm/Repair-Service-for-Garmin- > GPSmap-296-396-496-495-Co > > lor-Chartplotter-GPS-Fix/263072741620?hash=item3d405b78f4:g: > mrUAAOSwgv5ZXJgb > > > > Anybody ever had one repaired or used a Russian repair service before? > > Albert? > > > > > > > > --> I installed a Garmin 496 and a AirGizmo mount in my panel to provid e > a > > GPS signal --> to my TruTrak autopilot and it worked very well until > > recently when it seems to --> have failed. New battery didn't help. > Since I > > had recently started using an ipad --> on a RAM mount I'm think I would > not > > replace the Garmin but use the ipad instead. --> Question is though-how > do I > > get a GPS steering signal out of the ipad to the --> TruTrak? > > --> Albert Gardner > > --> RV-10 N991RV > > --> Yuma, Arizona > > > > > > > > > > > > > > > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Nov 01, 2017
I have 2 of the BR-355's as well. I only mentioned the GPS18 because it's one that may be more familiar to some people, and can do 9600 baud. That said, my advice for you is this if you go the BR-355 route: Contact GlobalSat...they will sell you a 9600 baud version of the BR-355. I bought 2 of them from them last year. I have one of them in my RV-14, in fact, set up with a switch to be the backup GPS for my TruTrak. They're a good little GPS that you can buy for under $50. I don't think you NEED 9600 baud for the TruTrak, but I'd go that route if at all possible. Tim On 11/1/2017 2:12 PM, Jim Combs wrote: > I have been using one of these with no issues: > > > GlobalSat BR-355 Serial GPS Receiver > > ________________________________________________________________________________
Date: Nov 01, 2017
I may be dense - but what does tru-track do with a raw GPS signal? I can see a 496 putting out desired track, waypoint and course info - but ??? Phil On Wed, Nov 1, 2017 at 3:51 PM Tim Olson wrote: > > I have 2 of the BR-355's as well. > I only mentioned the GPS18 because it's one that may be > more familiar to some people, and can do 9600 baud. > > That said, my advice for you is this if you go the BR-355 route: > > Contact GlobalSat...they will sell you a 9600 baud version of > the BR-355. I bought 2 of them from them last year. I have one > of them in my RV-14, in fact, set up with a switch to be the backup > GPS for my TruTrak. They're a good little GPS that you can > buy for under $50. I don't think you NEED 9600 baud for the > TruTrak, but I'd go that route if at all possible. > > Tim > > On 11/1/2017 2:12 PM, Jim Combs wrote: > > I have been using one of these with no issues: > > > > > > GlobalSat BR-355 Serial GPS Receiver > > > > > > > -- Phil Yoder phil(at)philyoder.com \__________o-( )-o__________/ www.itsnotthatcomplex.com ________________________________________________________________________________
Subject: ipad gps
Date: Nov 01, 2017
SnVzdCBhIHNpbXBsZSBwb3NpdGlvbiBpbmRpY2F0b3Igd2hlbiB5b3UgYXJlIGluIG1hbnVhbCB0 cmFjayBtb2RlLg0KDQpGcm9tOiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20g W21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBP ZiBQaGlsIFlvZGVyDQpTZW50OiBXZWRuZXNkYXksIE5vdmVtYmVyIDEsIDIwMTcgNDozMSBQTQ0K VG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSZTogUlYxMC1MaXN0OiBpcGFk IGdwcw0KDQpJIG1heSBiZSBkZW5zZSAtIGJ1dCB3aGF0IGRvZXMgdHJ1LXRyYWNrIGRvIHdpdGgg YSByYXcgR1BTIHNpZ25hbD8gIEkgY2FuIHNlZSBhIDQ5NiBwdXR0aW5nIG91dCBkZXNpcmVkIHRy YWNrLCB3YXlwb2ludCBhbmQgY291cnNlIGluZm8gLSBidXQgPz8/DQpQaGlsDQoNCg0KT24gV2Vk LCBOb3YgMSwgMjAxNyBhdCAzOjUxIFBNIFRpbSBPbHNvbiA8VGltQG15cnYxMC5jb208bWFpbHRv OlRpbUBteXJ2MTAuY29tPj4gd3JvdGU6DQotLT4gUlYxMC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5 OiBUaW0gT2xzb24gPFRpbUBNeVJWMTAuY29tPG1haWx0bzpUaW1ATXlSVjEwLmNvbT4+DQoNCkkg aGF2ZSAyIG9mIHRoZSBCUi0zNTUncyBhcyB3ZWxsLg0KSSBvbmx5IG1lbnRpb25lZCB0aGUgR1BT MTggYmVjYXVzZSBpdCdzIG9uZSB0aGF0IG1heSBiZQ0KbW9yZSBmYW1pbGlhciB0byBzb21lIHBl b3BsZSwgYW5kIGNhbiBkbyA5NjAwIGJhdWQuDQoNClRoYXQgc2FpZCwgbXkgYWR2aWNlIGZvciB5 b3UgaXMgdGhpcyBpZiB5b3UgZ28gdGhlIEJSLTM1NSByb3V0ZToNCg0KQ29udGFjdCBHbG9iYWxT YXQuLi50aGV5IHdpbGwgc2VsbCB5b3UgYSA5NjAwIGJhdWQgdmVyc2lvbiBvZg0KdGhlIEJSLTM1 NS4gIEkgYm91Z2h0IDIgb2YgdGhlbSBmcm9tIHRoZW0gbGFzdCB5ZWFyLiAgSSBoYXZlIG9uZQ0K b2YgdGhlbSBpbiBteSBSVi0xNCwgaW4gZmFjdCwgc2V0IHVwIHdpdGggYSBzd2l0Y2ggdG8gYmUg dGhlIGJhY2t1cA0KR1BTIGZvciBteSBUcnVUcmFrLiAgVGhleSdyZSBhIGdvb2QgbGl0dGxlIEdQ UyB0aGF0IHlvdSBjYW4NCmJ1eSBmb3IgdW5kZXIgJDUwLiAgSSBkb24ndCB0aGluayB5b3UgTkVF RCA5NjAwIGJhdWQgZm9yIHRoZQ0KVHJ1VHJhaywgYnV0IEknZCBnbyB0aGF0IHJvdXRlIGlmIGF0 IGFsbCBwb3NzaWJsZS4NCg0KVGltDQoNCk9uIDExLzEvMjAxNyAyOjEyIFBNLCBKaW0gQ29tYnMg d3JvdGU6DQo+IEkgaGF2ZSBiZWVuIHVzaW5nIG9uZSBvZiB0aGVzZSB3aXRoIG5vIGlzc3VlczoN Cj4NCj4NCj4gICBHbG9iYWxTYXQgQlItMzU1IFNlcmlhbCBHUFMgUmVjZWl2ZXINCj4NCj4NCj09 PT09PT09PT09DQotTGlzdCIgcmVsPSJub3JlZmVycmVyIiB0YXJnZXQ9Il9ibGFuayI+aHR0cDov L3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCj09PT09PT09PT09DQpGT1JV TVMgLQ0KZWZlcnJlciIgdGFyZ2V0PSJfYmxhbmsiPmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNv bQ0KPT09PT09PT09PT0NCldJS0kgLQ0KZXJyZXIiIHRhcmdldD0iX2JsYW5rIj5odHRwOi8vd2lr aS5tYXRyb25pY3MuY29tDQo9PT09PT09PT09PQ0KYiBTaXRlIC0NCiAgICAgICAgICAtTWF0dCBE cmFsbGUsIExpc3QgQWRtaW4uDQpyZWw9Im5vcmVmZXJyZXIiIHRhcmdldD0iX2JsYW5rIj5odHRw Oi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQo9PT09PT09PT09PQ0KDQoNCi0tDQpQ aGlsIFlvZGVyIHBoaWxAcGhpbHlvZGVyLmNvbTxtYWlsdG86cGhpbEBwaGlseW9kZXIuY29tPiBc X19fX19fX19fX28tKCApLW9fX19fX19fX19fLyB3d3cuaXRzbm90dGhhdGNvbXBsZXguY29tPGh0 dHA6Ly93d3cuaXRzbm90dGhhdGNvbXBsZXguY29tPg0K ________________________________________________________________________________
Date: Nov 01, 2017
It keeps track of ground track and position. The ARINC lines do the steering. Tim > On Nov 1, 2017, at 3:30 PM, Phil Yoder wrote: > > I may be dense - but what does tru-track do with a raw GPS signal? I can s ee a 496 putting out desired track, waypoint and course info - but ??? > Phil > > >> On Wed, Nov 1, 2017 at 3:51 PM Tim Olson wrote: >> >> I have 2 of the BR-355's as well. >> I only mentioned the GPS18 because it's one that may be >> more familiar to some people, and can do 9600 baud. >> >> That said, my advice for you is this if you go the BR-355 route: >> >> Contact GlobalSat...they will sell you a 9600 baud version of >> the BR-355. I bought 2 of them from them last year. I have one >> of them in my RV-14, in fact, set up with a switch to be the backup >> GPS for my TruTrak. They're a good little GPS that you can >> buy for under $50. I don't think you NEED 9600 baud for the >> TruTrak, but I'd go that route if at all possible. >> >> Tim >> >> On 11/1/2017 2:12 PM, Jim Combs wrote: >> > I have been using one of these with no issues: >> > >> > >> > GlobalSat BR-355 Serial GPS Receiver >> > >> > >> ========== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========== >> >> >> > > -- > Phil Yoder phil(at)philyoder.com \__________o-( )-o__________/ www.itsnotthat complex.com ________________________________________________________________________________
Date: Nov 01, 2017
When in stand alone mode, it provides the GPS Ground track for the heading information, plus it provides altitude information for standalone altitude hold. On Wed, Nov 1, 2017 at 4:50 PM, Tim Olson wrote: > It keeps track of ground track and position. > The ARINC lines do the steering. > Tim > > On Nov 1, 2017, at 3:30 PM, Phil Yoder wrote: > > I may be dense - but what does tru-track do with a raw GPS signal? I can > see a 496 putting out desired track, waypoint and course info - but ??? > Phil > > > On Wed, Nov 1, 2017 at 3:51 PM Tim Olson wrote: > >> >> I have 2 of the BR-355's as well. >> I only mentioned the GPS18 because it's one that may be >> more familiar to some people, and can do 9600 baud. >> >> That said, my advice for you is this if you go the BR-355 route: >> >> Contact GlobalSat...they will sell you a 9600 baud version of >> the BR-355. I bought 2 of them from them last year. I have one >> of them in my RV-14, in fact, set up with a switch to be the backup >> GPS for my TruTrak. They're a good little GPS that you can >> buy for under $50. I don't think you NEED 9600 baud for the >> TruTrak, but I'd go that route if at all possible. >> >> Tim >> >> On 11/1/2017 2:12 PM, Jim Combs wrote: >> > I have been using one of these with no issues: >> > >> > >> > GlobalSat BR-355 Serial GPS Receiver >> > >> > >> ========== >> -List" rel="noreferrer" target="_blank">http://www. >> matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> -- > Phil Yoder phil(at)philyoder.com \__________o-( )-o__________/ > www.itsnotthatcomplex.com > > ________________________________________________________________________________
Subject: ipad gps
Date: Nov 01, 2017
This from TruTraks Installation Information: The Garmin 496 was wired to Pin 7. Pin 7 is Primary Serial Input. Baud rate selectable 1200, 2400, 4800 or 9600 baud. Automatically decodes NMEA-0183, Garmin Aviation Format, or Apollo/UPSAT MovingMap or GPSS format. Provides directional reference to the autopilot. How does the Global Sat BR-355 get power and how does the GPS signal come out of it? The picture looks like it has a USB connector. Does it have a serial connector also? I'm very interested because it looks like that might be all that I need. Albert Gardner From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Wednesday, November 01, 2017 1:50 PM Subject: Re: RV10-List: ipad gps It keeps track of ground track and position. The ARINC lines do the steering. Tim On Nov 1, 2017, at 3:30 PM, Phil Yoder wrote: I may be dense - but what does tru-track do with a raw GPS signal? I can see a 496 putting out desired track, waypoint and course info - but ??? Phil On Wed, Nov 1, 2017 at 3:51 PM Tim Olson wrote: I have 2 of the BR-355's as well. I only mentioned the GPS18 because it's one that may be more familiar to some people, and can do 9600 baud. That said, my advice for you is this if you go the BR-355 route: Contact GlobalSat...they will sell you a 9600 baud version of the BR-355. I bought 2 of them from them last year. I have one of them in my RV-14, in fact, set up with a switch to be the backup GPS for my TruTrak. They're a good little GPS that you can buy for under $50. I don't think you NEED 9600 baud for the TruTrak, but I'd go that route if at all possible. Tim On 11/1/2017 2:12 PM, Jim Combs wrote: > I have been using one of these with no issues: > > > GlobalSat BR-355 Serial GPS Receiver > > -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution -- Phil Yoder phil(at)philyoder.com \__________o-( )-o__________/ www.itsnotthatcomplex.com ________________________________________________________________________________
Date: Nov 01, 2017
I found this on the internet doing a search for BR-355 pin-out. You can get the connector at digikey or mouser electronics. This DIN connector is the same as that used on the OLD PS-2 Mouse / Keyboard (Pre - USB) Jim C On Wed, Nov 1, 2017 at 6:44 PM, Albert wrote: > This from TruTraks Installation Information: The Garmin 496 was wired to > Pin 7. > > > Pin 7 is Primary Serial Input. Baud rate selectable 1200, 2400, 4800 or > 9600 baud. Automatically decodes NMEA-0183, Garmin Aviation Format, or > Apollo/UPSAT MovingMap or GPSS format. Provides directional reference to > the autopilot. > > > How does the Global Sat BR-355 get power and how does the GPS signal come > out of it? The picture looks like it has a USB connector. Does it have a > serial connector also? I'm very interested because it looks like that might > be all that I need. > > Albert Gardner > > > *From:* owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list- > server(at)matronics.com] *On Behalf Of *Tim Olson > *Sent:* Wednesday, November 01, 2017 1:50 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: ipad gps > > > It keeps track of ground track and position. > > The ARINC lines do the steering. > > Tim > > > On Nov 1, 2017, at 3:30 PM, Phil Yoder wrote: > > I may be dense - but what does tru-track do with a raw GPS signal? I can > see a 496 putting out desired track, waypoint and course info - but ??? > > Phil > > > On Wed, Nov 1, 2017 at 3:51 PM Tim Olson wrote: > > > I have 2 of the BR-355's as well. > I only mentioned the GPS18 because it's one that may be > more familiar to some people, and can do 9600 baud. > > That said, my advice for you is this if you go the BR-355 route: > > Contact GlobalSat...they will sell you a 9600 baud version of > the BR-355. I bought 2 of them from them last year. I have one > of them in my RV-14, in fact, set up with a switch to be the backup > GPS for my TruTrak. They're a good little GPS that you can > buy for under $50. I don't think you NEED 9600 baud for the > TruTrak, but I'd go that route if at all possible. > > Tim > > On 11/1/2017 2:12 PM, Jim Combs wrote: > > I have been using one of these with no issues: > > > > > > GlobalSat BR-355 Serial GPS Receiver > > > > > ========== > -List" rel="noreferrer" target="_blank">http://www. > matronics.com/Navigator?RV10-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > > -- > > Phil Yoder phil(at)philyoder.com \__________o-( )-o__________/ > www.itsnotthatcomplex.com > > ________________________________________________________________________________
Date: Nov 01, 2017
The baud rate is just setting the transfer rate from the GPS to the Truetrac. Regardless of the baud rate used, you will still only get GPS updates once per second. The sentence is short so no reason to get crazy with high baud rates. Jim C On Wed, Nov 1, 2017 at 6:44 PM, Albert wrote: > This from TruTraks Installation Information: The Garmin 496 was wired to > Pin 7. > > > Pin 7 is Primary Serial Input. Baud rate selectable 1200, 2400, 4800 or > 9600 baud. Automatically decodes NMEA-0183, Garmin Aviation Format, or > Apollo/UPSAT MovingMap or GPSS format. Provides directional reference to > the autopilot. > > > How does the Global Sat BR-355 get power and how does the GPS signal come > out of it? The picture looks like it has a USB connector. Does it have a > serial connector also? I'm very interested because it looks like that might > be all that I need. > > Albert Gardner > > > *From:* owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list- > server(at)matronics.com] *On Behalf Of *Tim Olson > *Sent:* Wednesday, November 01, 2017 1:50 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: ipad gps > > > It keeps track of ground track and position. > > The ARINC lines do the steering. > > Tim > > > On Nov 1, 2017, at 3:30 PM, Phil Yoder wrote: > > I may be dense - but what does tru-track do with a raw GPS signal? I can > see a 496 putting out desired track, waypoint and course info - but ??? > > Phil > > > On Wed, Nov 1, 2017 at 3:51 PM Tim Olson wrote: > > > I have 2 of the BR-355's as well. > I only mentioned the GPS18 because it's one that may be > more familiar to some people, and can do 9600 baud. > > That said, my advice for you is this if you go the BR-355 route: > > Contact GlobalSat...they will sell you a 9600 baud version of > the BR-355. I bought 2 of them from them last year. I have one > of them in my RV-14, in fact, set up with a switch to be the backup > GPS for my TruTrak. They're a good little GPS that you can > buy for under $50. I don't think you NEED 9600 baud for the > TruTrak, but I'd go that route if at all possible. > > Tim > > On 11/1/2017 2:12 PM, Jim Combs wrote: > > I have been using one of these with no issues: > > > > > > GlobalSat BR-355 Serial GPS Receiver > > > > > ========== > -List" rel="noreferrer" target="_blank">http://www. > matronics.com/Navigator?RV10-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > > -- > > Phil Yoder phil(at)philyoder.com \__________o-( )-o__________/ > www.itsnotthatcomplex.com > > ________________________________________________________________________________
Subject: Need latest Navworx UAT Console
Date: Nov 02, 2017
I have the Navworx unit that will work with the AMOC given a certified GPS source. But I don't have a copy of the UAT console that will run, looking for help. I tried running the UAT console software I obtained back in 2012 but get an error on loading, "Nonshared DATA segment required", then if fails to open. Anyone have experience with this? A secondary concern I have is that I recall the UAT console loads a version of the Navworx software. If so, this is backlevel for my box (my box had been sent in since then for a maintenance upgrade). Does anyone have a copy of the UAT console that they can share or otherwise advise? Thanks. (I'll be posting on the VAF board as well) Bill "wired up G430w to the deadend box with all appendages crossed" Watson --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Nov 02, 2017
Power may be the hardest part about the BR-355. I can't remember for sure but I think it runs on 5V. So I had to throw together a simple 5V regulator that I mounted nearby and ran 12V into that. That's one thing about the Garmin GPS 18...I'm not sure if it reduces the 12V in the lighter plug, or if it's 12V all the way to the puck, but it may eliminate one step of getting something that works. https://buy.garmin.com/en-US/US/p/27594 For the BR-355, I cut the connector right off, wired it to a DB9, and hooked up my own power module to power it. Tim On 11/01/2017 05:44 PM, Albert wrote: > This from TruTraks Installation Information: The Garmin 496 was wired to > Pin 7. > > Pin 7 is Primary Serial Input. Baud rate selectable 1200, 2400, 4800 or > 9600 baud. Automatically decodes NMEA-0183, Garmin Aviation Format, or > Apollo/UPSAT MovingMap or GPSS format. Provides directional reference to > the autopilot. > > How does the Global Sat BR-355 get power and how does the GPS signal > come out of it? The picture looks like it has a USB connector. Does it > have a serial connector also? I'm very interested because it looks like > that might be all that I need. > > Albert Gardner ________________________________________________________________________________
Subject: Re: Need latest Navworx UAT Console
Date: Nov 02, 2017
I have version 4.1.0 if you need. You're right that if you run the app, it will upgrade your firmware. Mine is far newer than 2012, but not the 5.0 that Bob talks about. I have seen one person who couldn't get it to load on their system, due to an issue with the system, but I was able to load it on 3 of them. Tim On 11/02/2017 10:01 AM, Bill Watson wrote: > > I have the Navworx unit that will work with the AMOC given a certified > GPS source. But I don't have a copy of the UAT console that will run, > looking for help. > > I tried running the UAT console software I obtained back in 2012 but get > an error on loading, "Nonshared DATA segment required", then if fails to > open. Anyone have experience with this? > > A secondary concern I have is that I recall the UAT console loads a > version of the Navworx software. If so, this is backlevel for my box > (my box had been sent in since then for a maintenance upgrade). > > Does anyone have a copy of the UAT console that they can share or > otherwise advise? Thanks. > > (I'll be posting on the VAF board as well) > > Bill "wired up G430w to the deadend box with all appendages crossed" Watson > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus ________________________________________________________________________________
Date: Nov 02, 2017
I have a Garmin puck feeding my ELT running off of a 5V DC-DC converter: Recom Power R-78W5.0-0.5 Mouser has it for under $8.40. The puck comes with a cigarette lighter adapter, but the 5V converter is much smaller. Lenny > On Nov 2, 2017, at 11:09 AM, Tim Olson wrote: > > > Power may be the hardest part about the BR-355. I can't remember for > sure but I think it runs on 5V. So I had to throw together a simple > 5V regulator that I mounted nearby and ran 12V into that. > > That's one thing about the Garmin GPS 18...I'm not sure if it reduces > the 12V in the lighter plug, or if it's 12V all the way to the puck, > but it may eliminate one step of getting something that works. > > https://buy.garmin.com/en-US/US/p/27594 > > For the BR-355, I cut the connector right off, wired it to a DB9, > and hooked up my own power module to power it. > Tim > > > > > > On 11/01/2017 05:44 PM, Albert wrote: >> This from TruTraks Installation Information: The Garmin 496 was wired to Pin 7. >> Pin 7 is Primary Serial Input. Baud rate selectable 1200, 2400, 4800 or 9600 baud. Automatically decodes NMEA-0183, Garmin Aviation Format, or Apollo/UPSAT MovingMap or GPSS format. Provides directional reference to the autopilot. >> How does the Global Sat BR-355 get power and how does the GPS signal come out of it? The picture looks like it has a USB connector. Does it have a serial connector also? I'm very interested because it looks like that might be all that I need. >> Albert Gardner > > > ________________________________________________________________________________
Date: Nov 02, 2017
If you need 4.1.0 and the manual, let me know. I haven't been able to locate anyone that has 5.0 yet. Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> on behalf of Bill Watson Sent: Thursday, November 2, 2017 11:01:53 AM Subject: RV10-List: Need latest Navworx UAT Console I have the Navworx unit that will work with the AMOC given a certified GPS source. But I don't have a copy of the UAT console that will run, looking for help. I tried running the UAT console software I obtained back in 2012 but get an error on loading, "Nonshared DATA segment required", then if fails to open. Anyone have experience with this? A secondary concern I have is that I recall the UAT console loads a version of the Navworx software. If so, this is backlevel for my box (my box had been sent in since then for a maintenance upgrade). Does anyone have a copy of the UAT console that they can share or otherwise advise? Thanks. (I'll be posting on the VAF board as well) Bill "wired up G430w to the deadend box with all appendages crossed" Watson --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Nov 02, 2017
Exactly. If you get a puck, plan to just chop the cable up anyway. In the end you can make it smaller and lighter and not have to deal with anyones special plug. Tim > On Nov 2, 2017, at 10:28 AM, Lenny Iszak wrote: > > > I have a Garmin puck feeding my ELT running off of a 5V DC-DC converter: Recom Power R-78W5.0-0.5 > Mouser has it for under $8.40. > The puck comes with a cigarette lighter adapter, but the 5V converter is much smaller. > > Lenny > > >> On Nov 2, 2017, at 11:09 AM, Tim Olson wrote: >> >> >> Power may be the hardest part about the BR-355. I can't remember for >> sure but I think it runs on 5V. So I had to throw together a simple >> 5V regulator that I mounted nearby and ran 12V into that. >> >> That's one thing about the Garmin GPS 18...I'm not sure if it reduces >> the 12V in the lighter plug, or if it's 12V all the way to the puck, >> but it may eliminate one step of getting something that works. >> >> https://buy.garmin.com/en-US/US/p/27594 >> >> For the BR-355, I cut the connector right off, wired it to a DB9, >> and hooked up my own power module to power it. >> Tim >> >> >> >> >> >>> On 11/01/2017 05:44 PM, Albert wrote: >>> This from TruTraks Installation Information: The Garmin 496 was wired to Pin 7. >>> Pin 7 is Primary Serial Input. Baud rate selectable 1200, 2400, 4800 or 9600 baud. Automatically decodes NMEA-0183, Garmin Aviation Format, or Apollo/UPSAT MovingMap or GPSS format. Provides directional reference to the autopilot. >>> How does the Global Sat BR-355 get power and how does the GPS signal come out of it? The picture looks like it has a USB connector. Does it have a serial connector also? I'm very interested because it looks like that might be all that I need. >>> Albert Gardner >> >> >> > > > > > ________________________________________________________________________________
Date: Nov 02, 2017
The Mauledriver email is just for posting. My email is BillisinDurham - gmail (without the 'is'). I have the current manual from the Dallas folks. Thanks all! On 11/2/2017 11:01 AM, Bill Watson wrote: > > I have the Navworx unit that will work with the AMOC given a certified > GPS source. But I don't have a copy of the UAT console that will run, > looking for help. > > I tried running the UAT console software I obtained back in 2012 but > get an error on loading, "Nonshared DATA segment required", then if > fails to open. Anyone have experience with this? > > A secondary concern I have is that I recall the UAT console loads a > version of the Navworx software. If so, this is backlevel for my box > (my box had been sent in since then for a maintenance upgrade). > > Does anyone have a copy of the UAT console that they can share or > otherwise advise? Thanks. > > (I'll be posting on the VAF board as well) > > Bill "wired up G430w to the deadend box with all appendages crossed" > Watson > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Subject: ipad gps
Date: Nov 02, 2017
OK, I found a 5V power supply on ebay for $8+ but looking at the listings for the BR-355 shows also a BR-355S4 which is much cheaper. What is the difference between the units? Listing for the BR-355 are over $200. (I did find a listing for a BR-355 from China for $15 + $13 shipping!!!). Albert Gardner RV-10 N991RV Yuma, Arizona ________________________________________________________________________________
Date: Nov 02, 2017
I don't know with 100% certainty but I think the biggest difference is likely that the S4 model uses the SiRF IV chipset whereas the regular BR355 may use an older or different chipset. They are both cheap: BR-355-S4 for $27.00 https://www.amazon.com/GlobalSat-BR-355S4-GPS-Receiver-Black/dp/B00AMAJFUO BR-355 for $33.95 https://www.amazon.com/GlobalSat-BR-355-Serial-GPS-Receiver/dp/B000VUFGF8 I don't see the ability on their website to directly compare the BR-355 with no suffix, but when I compare the -W with the -S4, the difference is SiRF III vs SiRF IV, and SiRF III does 20 channels wheras the SiRF IV does 48, and boots up a little quicker. I can tell you that when I had them sell me the ones that defaulted to 9600 baud, I got the BR-355-S4 version. I paid around $50 for that. If I didn't have the baud rate fixed, it would lose it's baud setting on power-off. I bought mine for APRS tracking and wanted to be able to use 9600 baud for that. I also feed my TruTrak as a secondary GPS. Hot tip: There's a magnet in the case that you can pull the sticker off and then use a screwdriver to pry the magnet out of it. I didn't want a magnet anywhere near my plane. Once the magnet is out, the puck weighs almost nothing and you can secure it with velcro somewhere. I have one in a wingtip and one under the VS fairing and both work perfectly. Something like that DC-DC converter you found will work well. I think I have that on one of them, and on the other I used an LM7805 5V regulator similar to this, along with a couple other components: https://www.sparkfun.com/products/107 cheap to do either way. Lenny's DC-DC converter I think is this one: https://www.mouser.com/ProductDetail/RECOM/R-78W50-05/?qs=T0XSgvH75d6ym%2FmhBy%252boCA%3D%3D&gclid=CjwKCAjwhOvPBRBxEiwAx2nhLm6kZTNFsk-7LUrrI2uK_jNuTKkH5mIPGaB6Xfr_sIi4wxc-4RUORRoClb4QAvD_BwE It's also cheap and simple. You don't need a lot of wattage to drive this GPS. His can use source voltages of 6.5 to 32V, so may be a real nice option. Your GPS would be one of the last things in the panel to die if you lose power, and would be one of the better power-spike survivors at 32V. Tim On 11/2/2017 11:46 AM, Albert wrote: > > OK, I found a 5V power supply on ebay for $8+ but looking at the listings for the BR-355 shows also a BR-355S4 which is much cheaper. What is the difference between the units? Listing for the BR-355 are over $200. (I did find a listing for a BR-355 from China for $15 + $13 shipping!!!). > Albert Gardner > RV-10 N991RV > Yuma, Arizona > > ________________________________________________________________________________
Date: Nov 02, 2017
Yes the BR-355 5 V. On the Advanced Flight system, I used the sensor +5 output to drive the BR-355. There are also three terminal TO-220 case regulators that are ideal for powering this. They will take up to 35V input and are current and temperature regulated. Jim C On Thu, Nov 2, 2017 at 11:09 AM, Tim Olson wrote: > > Power may be the hardest part about the BR-355. I can't remember for > sure but I think it runs on 5V. So I had to throw together a simple > 5V regulator that I mounted nearby and ran 12V into that. > > That's one thing about the Garmin GPS 18...I'm not sure if it reduces > the 12V in the lighter plug, or if it's 12V all the way to the puck, > but it may eliminate one step of getting something that works. > > https://buy.garmin.com/en-US/US/p/27594 > > For the BR-355, I cut the connector right off, wired it to a DB9, > and hooked up my own power module to power it. > Tim > > > On 11/01/2017 05:44 PM, Albert wrote: > >> This from TruTraks Installation Information: The Garmin 496 was wired to >> Pin 7. >> >> Pin 7 is Primary Serial Input. Baud rate selectable 1200, 2400, 4800 or >> 9600 baud. Automatically decodes NMEA-0183, Garmin Aviation Format, or >> Apollo/UPSAT MovingMap or GPSS format. Provides directional reference to >> the autopilot. >> >> How does the Global Sat BR-355 get power and how does the GPS signal come >> out of it? The picture looks like it has a USB connector. Does it have a >> serial connector also? I'm very interested because it looks like that might >> be all that I need. >> >> Albert Gardner >> > > ________________________________________________________________________________
Date: Nov 03, 2017
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Help Keep Airport Courtesy Cars Running
Date: Nov 04, 2017
Last November, a few people (out of thousands) complained to me that my fundraising efforts for the Airport Courtesy Cars site were too often. In response, I will only ask for donations once a year, in November. In the past few months I have transferred all the data to a web based platform. As a result, the site will work on ANY device with no bugs, crashes, or Android and Apple permissions required. Please refer to website for more details. The site now lists over 1,830 courtesy cars across the U.S. I receive a very small percent of my operating costs from advertisers. Most of my expenses are covered from small donations from pilots like you. I take no salary. Please consider any donation to keep the site up and running in the coming year. Donations can be made via the secure PayPal tab on the site (you don not need a PayPal account), or by mailing your donation to: Airport Courtesy Cars. P.O. Box 85762, Tucson, Arizona 85754. All donors will be listed on the donor page (unless you request not to be). Any donation is greatly appreciated. Please share this post with a fellow pilot who might benefit from A.C.C.s You can continue to email me your updates and suggestions to: airportcars101(at)gmail.com Thank you, Glenn www.airportcourtesycars.com -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474311#474311 ________________________________________________________________________________
Date: Nov 05, 2017
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Tunnel Leak
Date: Nov 05, 2017
Doing my first condition inspection and everything going great until removed tunnel cover and saw some blue staining on floor and all over boost pump.....obviously a leak so I began trouble shooting. After pressurization I noticed pool of fuel coming from under pump near front and felt fuel there. I had no leak during phase one I know because I flew with cover off. Initial thought was poor connection between pump and firewall (my FF senor is not in tunnel). I re-torqued line and still leak. I removed and inspected line - looked good so cleaned and replaced and still leak. Then I remade entire line replaced and still leak. My suspicion now is that pump itself is leaking because the stain is mostly on pump and floor but pump is raised off floor (so couldn't get stain form other part of system not directly connected to pump) and none of those other fixes worked. Have any of you seen this before and if so how would you test to see if pump is bad? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474431#474431 ________________________________________________________________________________
Subject: Re: Tunnel Leak
Date: Nov 05, 2017
Assuming you have an afp pump, give don Rivera a call on Monday. Either d on or Kyle can answer your questions. They=92re pretty good folks to work with. Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> on behalf of mhealydds Sent: Sunday, November 5, 2017 10:57:45 AM Subject: RV10-List: Tunnel Leak Doing my first condition inspection and everything going great until remove d tunnel cover and saw some blue staining on floor and all over boost pump. ....obviously a leak so I began trouble shooting. After pressurization I no ticed pool of fuel coming from under pump near front and felt fuel there. I had no leak during phase one I know because I flew with cover off. Initial thought was poor connection between pump and firewall (my FF senor is not in tunnel). I re-torqued line and still leak. I removed and inspected line - looked good so cleaned and replaced and still leak. Then I remade entire line replaced and still leak. My suspicion now is that pump itself is leaki ng because the stain is mostly on pump and floor but pump is raised off flo or (so couldn't get stain form other part of system not directly connected to pump) and none of those other fixes worked. Have any of you seen this be fore and if so how would you test to see if pump is bad? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474431#474431 ________________________________________________________________________________
Subject: Prop / Throttle / Mixture Quadrant
Date: Nov 05, 2017
Hi I am close to making a decision on whether or not to use vernier control knobs or quadrant controls for Prop / Throttle / Mixture. With the Aerosport interior, I can put the quadrant on the panel or on the center console. For those who have already made this decision, I'd be interested in opinions etc. Cheers Les C-GROK (some assembly required) C-GCWZ (Flying) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474445#474445 ________________________________________________________________________________
Date: Nov 05, 2017
Subject: Re: Prop / Throttle / Mixture Quadrant
Les, I have the throttle quadrant and would not do it again. I love the look of it, but I really miss out on being able to fine adjust my mixture. Shannon On Sun, Nov 5, 2017 at 4:25 PM kearney wrote: > > Hi > > I am close to making a decision on whether or not to use vernier control > knobs or quadrant controls for Prop / Throttle / Mixture. With the > Aerosport interior, I can put the quadrant on the panel or on the center > console. > > For those who have already made this decision, I'd be interested in > opinions etc. > > Cheers > > Les > > C-GROK (some assembly required) > C-GCWZ (Flying) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=474445#474445 > > ________________________________________________________________________________
Date: Nov 05, 2017
Hi Les, If you can get a chance to fly an airplane with the quadrant, it would really help you. This is one of those things that is strictly personal preference. Ive flown both and found I prefer the stock controls. Back when I bought mine, stock from Vans was a straight push-pull throttle and vernier prop and mixture. I had owned a Bonanza prior to the -10 and it had vernier on all three. I definitely prefer no vernier on the throttle, but love it on prop and mixture for fine tuning. I know youll hear from others that love their quadrants. For what its worth, I rarely fly formation these days but I am pretty sure most serious formation organizations dont allow, or really frown on, vernier throttles. David Maib > On Nov 5, 2017, at 5:21 PM, kearney wrote: > > > Hi > > I am close to making a decision on whether or not to use vernier control knobs or quadrant controls for Prop / Throttle / Mixture. With the Aerosport interior, I can put the quadrant on the panel or on the center console. > > For those who have already made this decision, I'd be interested in opinions etc. > > Cheers > > Les > > C-GROK (some assembly required) > C-GCWZ (Flying) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=474445#474445 > > > > > > > > > ________________________________________________________________________________
Date: Nov 05, 2017
I have the traditional push/pulls and really like them. All of my cables come from McFarlane and they sell a non-locking Vernier throttle. (IE: A normal-looking throttle cable that you can push/pull like a normal throttle cable without having to push down a lock, but that you can fine tune by twisting too.) I dont regret the non-locking vernier at all, but Im not really sure how much extra functionality it brings (and I dont remember the cost difference to add that functionality either). But most of the time, it takes quite a few twists to change .1 of MP. Its really just as easy, and probably faster, to push the knob in and hunt for the right spot. For the RV-10, it really likes to perform up high and that means the black knob is pushed forward all the way anyway..... so there isnt much fine tuning in a typical cruise. Like I said, I dont regret the non-locking vernier throttle, but I am not sure if its really worth the money. If we are talking under $100 then, yeah maybe its worth it. But beyond that Id question if Id really need it again. Phil Sent from my iPhone > On Nov 5, 2017, at 5:16 PM, David Maib wrote: > > > Hi Les, > If you can get a chance to fly an airplane with the quadrant, it would really help you. This is one of those things that is strictly personal preference. Ive flown both and found I prefer the stock controls. Back when I bought mine, stock from Vans was a straight push-pull throttle and vernier prop and mixture. I had owned a Bonanza prior to the -10 and it had vernier on all three. I definitely prefer no vernier on the throttle, but love it on prop and mixture for fine tuning. I know youll hear from others that love their quadrants. For what its worth, I rarely fly formation these days but I am pretty sure most serious formation organizations dont allow, or really frown on, vernier throttles. > > David Maib > > >> On Nov 5, 2017, at 5:21 PM, kearney wrote: >> >> >> Hi >> >> I am close to making a decision on whether or not to use vernier control knobs or quadrant controls for Prop / Throttle / Mixture. With the Aerosport interior, I can put the quadrant on the panel or on the center console. >> >> For those who have already made this decision, I'd be interested in opinions etc. >> >> Cheers >> >> Les >> >> C-GROK (some assembly required) >> C-GCWZ (Flying) >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=474445#474445 >> >> >> >> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Nov 06, 2017
I had a Diamond Katana with center console mounted controls and wanted my -10 to have the throttle quadrant in the same place. Had to make a custom center console to do that. It worked out well. Glad to see that Geoff now offers that configuration. With the throttle quadrant in the center console you can just slide your arm forward on the armrest and you are on the controls. Pretty convenient. For fine control you can anchor your fingers on the right side of the console and move the knobs with your thumb. The lining in the original (green) cables melts after a while and it becomes hard to fine tune the mixture and even the prop. Ever since I switched to the black cables from Push-pull.com all the controls have been smooth and adjusting the mixture accurately is never an issue. Here=99s a picture of an early 3D rendering of my panel/console. Lenny > On Nov 5, 2017, at 5:21 PM, kearney wrote: > > > Hi > > I am close to making a decision on whether or not to use vernier control knobs or quadrant controls for Prop / Throttle / Mixture. With the Aerosport interior, I can put the quadrant on the panel or on the center console. > > For those who have already made this decision, I'd be interested in opinions etc. > > Cheers > > Les > > C-GROK (some assembly required) > C-GCWZ (Flying) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=474445#474445 > > > > > > > > > ________________________________________________________________________________
Date: Nov 05, 2017
I have the same McFarlane vernier push pull. IIRC the ratio on the throttle varies with how snug the friction lock is set. It is useful when seeking precise power settings to gather data, whether it is speeds, mixture, temps, etc. I'm happy with a quadrant in a multi-engine aircraft. but prefer push pull for single engine. On 11/5/2017 4:50 PM, Phillip Perry wrote: > > I have the traditional push/pulls and really like them. All of my cables come from McFarlane and they sell a non-locking Vernier throttle. 'm h (IE: A normal-looking throttle cable that you can push/pull like a normal throttle cable without having to push down a lock, but that you can fine tune by twisting too.) > > I dont regret the non-locking vernier at all, but Im not really sure how much extra functionality it brings (and I dont remember the cost difference to add that functionality either). > ________________________________________________________________________________
Date: Nov 05, 2017
Hey Les. My config is the quadrant under the panel on the Aerosport centre console. It's pretty much in the same position as http://www.aerosportproducts.com/rv10quadrant.htm though it looks a bit different (they've probably changed the design a couple of times since I bought it). I do like it there - really comfortable to have my hand on the controls while resting my arm on the armrest. I suppose a person would get used to whatever they have, but I can't imagine mine being somewhere different :-) Dan > On 2017-Nov-05, at 3:21 PM, kearney wrote: > > > Hi > > I am close to making a decision on whether or not to use vernier control knobs or quadrant controls for Prop / Throttle / Mixture. With the Aerosport interior, I can put the quadrant on the panel or on the center console. > > For those who have already made this decision, I'd be interested in opinions etc. > > Cheers > > Les > > C-GROK (some assembly required) > C-GCWZ (Flying) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=474445#474445 > > > > > > > > > --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Date: Nov 05, 2017
Kellym wrote: > > I'm happy with a quadrant in a multi-engine aircraft. but prefer push > pull for single engine. > > [/quote] Definitely agree. Quadrant with a multi-engine airplane works best. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474460#474460 ________________________________________________________________________________
Subject: engine controls on RV10
Date: Nov 06, 2017
Les: Another advantage to putting your engine controls on the panel (vernier controls vs quadrant controls) is the convenient space above the center channel to mount a map box for POH, check list, glasses, etc. Doc 123CV #41087 ________________________________________________________________________________
Date: Nov 06, 2017
Happy with a quadrant except when I'm upside down with my head under the panel! Albert Gardner RV-10 N991RV Yuma, AZ ________________________________________________________________________________
Subject: Flap motor safety wire hole
Date: Nov 06, 2017
Does anyone have a good tip for drilling the safety wire hole in the barrel of the flap motor. The instructions say do not remove the end as it is factory set. However I would think keeping track of the number of turns it is unscrewed should be easy to do. Drilling with a 1/16" drill into steel seems like a good way to buy drill bits. Am I stressing over a mole hill? David ________________________________________________________________________________
Date: Nov 06, 2017
RGF2aWQganVzdCBnbyBuaWNlICBhbmQgc3RlYWR5LCBzbG93IGV0YyB3aXRoIGEgbmV3IGJpdC4g IFNob3VsZG7igJl0IGJlIGEgcHJvYmxlbSBhdCBhbGwuDQpSaWNrDQojNDA5NTYNCkMtR0RNSA0K DQpTZW50IGZyb20gTWFpbCBmb3IgV2luZG93cyAxMA0KDQpGcm9tOiBEYXZpZCBKLiBGcml0enNj aGUNClNlbnQ6IE5vdmVtYmVyIDYsIDIwMTcgNzozMiBQTQ0KVG86IFJWLTEwIE1hdHJvbmljcw0K U3ViamVjdDogUlYxMC1MaXN0OiBGbGFwIG1vdG9yIHNhZmV0eSB3aXJlIGhvbGUNCg0KLS0+IFJW MTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIkRhdmlkIEouIEZyaXR6c2NoZSIgPGRmcml0ekBi cGdzaW0uY29tPg0KDQoNCkRvZXMgYW55b25lIGhhdmUgYSBnb29kIHRpcCBmb3IgZHJpbGxpbmcg dGhlIHNhZmV0eSB3aXJlIGhvbGUgaW4gdGhlIA0KYmFycmVsIG9mIHRoZSBmbGFwIG1vdG9yLsKg IFRoZSBpbnN0cnVjdGlvbnMgc2F5IGRvIG5vdCByZW1vdmUgdGhlIGVuZCBhcyANCml0IGlzIGZh Y3Rvcnkgc2V0LsKgIEhvd2V2ZXIgSSB3b3VsZCB0aGluayBrZWVwaW5nIHRyYWNrIG9mIHRoZSBu dW1iZXIgb2YgDQp0dXJucyBpdCBpcyB1bnNjcmV3ZWQgc2hvdWxkIGJlIGVhc3kgdG8gZG8uIERy aWxsaW5nIHdpdGggYSAxLzE2IiBkcmlsbCANCmludG8gc3RlZWwgc2VlbXMgbGlrZSBhIGdvb2Qg d2F5IHRvIGJ1eSBkcmlsbCBiaXRzLsKgIEFtIEkgc3RyZXNzaW5nIG92ZXIgDQphIG1vbGUgaGls bD8NCg0KRGF2aWQNCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAtIFRoZSBSVjEwLUxpc3QgRW1haWwg Rm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRv IGJyb3dzZQ0KXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJz Y3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBD aGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0g ICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCl8tPQ0K Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0NCl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNh bWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0N Cl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAg ICAgICAgICAgICAgLSBORVcgTUFUUk9OSUNTIExJU1QgV0lLSSAtDQpfLT0gQWRkIHNvbWUgaW5m byB0byB0aGUgTWF0cm9uaWNzIEVtYWlsIExpc3QgV2lraSENCl8tPSAgIC0tPiBodHRwOi8vd2lr aS5tYXRyb25pY3MuY29tDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRp b24gV2ViIFNpdGUgLQ0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEN Cl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1p bi4NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQ0KDQoNCg0KDQo ________________________________________________________________________________
Subject: Re: Flap motor safety wire hole
From: "Greg McFarlane" <grbcmcfarlane(at)gmail.com>
Date: Nov 07, 2017
To Comply with SB 07-4-12 ....... I drilled straight in (parallel to jackscrew) just to clear the rod end safety jam nut about 5/16 then vertically down to capture the previous hole. That minimised the chance of bursting out trying to drill an angled hole. As well as the safety wire, most over here are also making a small ally fitting of appropriate gauge to lay alongside the jackscrew and the rod end, with a hole large enough to allow the normal tightening of flap bolt on the rod end ball, then at the jackscrew end, bent to go around the jackscrew and secured with a clamp. Might be overkill but thats what is being done. Cheers from Western Australia Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474492#474492 ________________________________________________________________________________
Date: Nov 07, 2017
Greg, any picture :) On 07.11.2017 11:33, Greg McFarlane wrote: > > To Comply with SB 07-4-12 ....... I drilled straight in (parallel to jackscrew) just to clear the rod end safety jam nut about 5/16 then vertically down to capture the previous hole. That minimised the chance of bursting out trying to drill an angled hole. As well as the safety wire, most over here are also making a small ally fitting of appropriate gauge to lay alongside the jackscrew and the rod end, with a hole large enough to allow the normal tightening of flap bolt on the rod end ball, then at the jackscrew end, bent to go around the jackscrew and secured with a clamp. Might be overkill but thats what is being done. Cheers from Western Australia > ________________________________________________________________________________
Date: Nov 07, 2017
Date: Nov 07, 2017
Subject: Cleveland Wheel Bearings
Does anyone have a good source for wheel bearings? I found Timken nose bearings for about $40 but the my shopping cart at Vans is running about $650 for all 8 pcs for the mains. I'm pretty sure it doesn't have to be this way. But my search for LM274949-2-629 is coming up short. Has someone had success with an alternate number? Besides the Cleveland number? Thanks, --Dave ________________________________________________________________________________
Date: Nov 07, 2017
Subject: Re: Cleveland Wheel Bearings
Local auto parts store can order them or a local bearing supply co can get them Sent from my iPhone > On Nov 7, 2017, at 6:26 PM, David Saylor wrote: > > Does anyone have a good source for wheel bearings? I found Timken nose bearings for about $40 but the my shopping cart at Vans is running about $650 for all 8 pcs for the mains. I'm pretty sure it doesn't have to be this way. But my search for LM274949-2-629 is coming up short. > > Has someone had success with an alternate number? Besides the Cleveland number? > > Thanks, > > --Dave > > ________________________________________________________________________________
Date: Nov 07, 2017
I'll second the possible auto parts angle the following is my order from a few years ago after hurricane high water got on my wheels and I couldn't get them apart in time to prevent corrosion. These aren't the FAA/PMA flavor but they have been running fine for 300 hours and 4 conditional inspections. Double check the numbers and my research. -Chris N919AR > Motion Industries > Release No: Date: 10/13/2011 > F.O.B: FOB ORG,FRT PP&ADD > Terms: . CASH > Delivery: STOCK UNLESS NOTED > Qty Description Requested Date > > 4.0 TIMKEN LM29749 CONE 10/19/2011 > Item No..........: 00658750 > Cust Stk No .....: > Price............: 15.120 60.48 > > > > 4.0 TIMKEN LM29710 CUP 10/19/2011 > Item No..........: 00658736 > Cust Stk No .....: > Price............: 9.360 37.44 > > > > > SUBTOTAL 97.92 > FREIGHT* 9.89 > TAX 7.28 > TOTAL** 115.09 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Saylor Sent: Tuesday, November 07, 2017 7:27 PM Subject: RV10-List: Cleveland Wheel Bearings Does anyone have a good source for wheel bearings? I found Timken nose bearings for about $40 but the my shopping cart at Vans is running about $650 for all 8 pcs for the mains. I'm pretty sure it doesn't have to be this way. But my search for LM274949-2-629 is coming up short. Has someone had success with an alternate number? Besides the Cleveland number? Thanks, --Dave ________________________________________________________________________________
Date: Nov 07, 2017
Yeah I've taken them in to a local place in town before called "Bearing Headquarters" and they can get just about anything. Tim On 11/7/2017 7:17 PM, Don Orrick wrote: > > Local auto parts store can order them or a local bearing supply co can get them > > Sent from my iPhone > >> On Nov 7, 2017, at 6:26 PM, David Saylor wrote: >> >> Does anyone have a good source for wheel bearings? I found Timken nose bearings for about $40 but the my shopping cart at Vans is running about $650 for all 8 pcs for the mains. I'm pretty sure it doesn't have to be this way. But my search for LM274949-2-629 is coming up short. >> >> Has someone had success with an alternate number? Besides the Cleveland number? >> >> Thanks, >> >> --Dave >> >> ________________________________________________________________________________
Date: Nov 07, 2017
Once you get replacements, be aware that Cleveland has changed their grease recommendations. Aeroshell #5 is no longer 1st choice. First choice is Mobil SHC 100, which is a red synthetic grease. Skygeek carries an appropriate sized tube. The rest of suppliers, last I looked only carry 5 lbs and up. I do not know reason Cleveland changed their recommendation. Kelly On 11/7/2017 7:07 PM, Tim Olson wrote: > > Yeah I've taken them in to a local place in town before > called "Bearing Headquarters" and they can get just > about anything. > Tim > > On 11/7/2017 7:17 PM, Don Orrick wrote: >> >> Local auto parts store can order them or a local bearing supply co can >> get them >> >> Sent from my iPhone >> >>> On Nov 7, 2017, at 6:26 PM, David Saylor wrote: >>> >>> Does anyone have a good source for wheel bearings? I found Timken >>> nose bearings for about $40 but the my shopping cart at Vans is >>> running about $650 for all 8 pcs for the mains. I'm pretty sure it >>> doesn't have to be this way. But my search for LM274949-2-629 is >>> coming up short. >>> >>> Has someone had success with an alternate number? Besides the >>> Cleveland number? >>> >>> Thanks, >>> >>> --Dave >>> >>> > > > ________________________________________________________________________________
Date: Nov 07, 2017
Thank you Chris, that's just what I needed. --Dave On Tue, Nov 7, 2017 at 6:00 PM, Chris wrote: > I'll second the possible auto parts angle the following is my order from a > few years ago after hurricane high water got on my wheels and I couldn't > get them apart in time to prevent corrosion. > > These aren't the FAA/PMA flavor but they have been running fine for 300 > hours and 4 conditional inspections. Double check the numbers and my > research. > > -Chris > > N919AR > > > > Motion Industries > > > Release No: Date: 10/13/2011 > > > F.O.B: FOB ORG,FRT PP&ADD > > > Terms: . CASH > > > Delivery: STOCK UNLESS NOTED > > > Qty Description Requested > Date > > > > > > 4.0 TIMKEN LM29749 CONE > 10/19/2011 > > > Item No..........: 00658750 > > > Cust Stk No .....: > > > Price............: 15.120 60.48 > > > > > > > > > > > > 4.0 TIMKEN LM29710 CUP > 10/19/2011 > > > Item No..........: 00658736 > > > Cust Stk No .....: > > > Price............: 9.360 37.44 > > > > > > > > > > > > > > > SUBTOTAL 97.92 > > > FREIGHT* 9.89 > > > TAX 7.28 > > > TOTAL** 115.09 > > > *From:* owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list- > server(at)matronics.com] *On Behalf Of *David Saylor > *Sent:* Tuesday, November 07, 2017 7:27 PM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Cleveland Wheel Bearings > > > Does anyone have a good source for wheel bearings? I found Timken nose > bearings for about $40 but the my shopping cart at Vans is running about > $650 for all 8 pcs for the mains. I'm pretty sure it doesn't have to be > this way. But my search for LM274949-2-629 is coming up short. > > > Has someone had success with an alternate number? Besides the Cleveland > number? > > > Thanks, > > > --Dave > > ________________________________________________________________________________
Date: Nov 07, 2017
Unfortunately no picture, and a bit hard to get into the tunnel area to get one quickly [Rolling Eyes] However Ally fitting in length is about inch and half along jackscrew and long enough to allow a approx3/8 hole (hole, large enough fit over the spacer) in rod end-end.............Width, wide enough to allow for the 3/8 hole at one end, and cut wider back at the jackscrew end to allow tabs to be bent/wrapped around the shaft for extra grip, then secured with a clamp, adele or hose. Same effect as safety wire in that if the rod end jam nut was to come loose then the jackscrew would be restrained from turning because the fitting is secured by the standard mounting bolt. Just needs to fit snug along rod end and jackscrew and not interfere with the normal flap operation, especially the normal tightening of the rod end bolt. Greg Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474610#474610 ________________________________________________________________________________
Date: Nov 08, 2017
Does anyone know if AMCO applies to Avidyne ID-540? Thanks. > On Nov 2, 2017, at 9:38 AM, Bob Leffler wrote: > > If you need 4.1.0 and the manual, let me know. > > I haven=99t been able to locate anyone that has 5.0 yet. > > Get Outlook for iOS > From: owner-rv10-list-server(at)matronics.com > on behalf of Bill Watson > > Sent: Thursday, November 2, 2017 11:01:53 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Need latest Navworx UAT Console > > > > I have the Navworx unit that will work with the AMOC given a certified > GPS source. But I don't have a copy of the UAT console that will run, > looking for help. > > I tried running the UAT console software I obtained back in 2012 but get > an error on loading, "Nonshared DATA segment required", then if fails to > open. Anyone have experience with this? > > A secondary concern I have is that I recall the UAT console loads a > version of the Navworx software. If so, this is backlevel for my box > (my box had been sent in since then for a maintenance upgrade). > > Does anyone have a copy of the UAT console that they can share or > otherwise advise? Thanks. > > (I'll be posting on the VAF board as well) > > Bill "wired up G430w to the deadend box with all appendages crossed" Watson > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ========== > Email Forum - > -List">http://www.matronics.com/Navigator?RV10-List <http://www.matronics.com/Navigator?RV10-List> > ========== > p; - MATRONICS WEB FORUMS - > ums.matronics.com <http://ums.matronics.com/> > ========== > p; - NEW MATRONICS LIST WIKI - > matronics.com <http://matronics.com/> > ========== > p; - List Contribution Web Site - > p; -Matt Dralle, List Admin. > http://www.matronics.com/contribution <http://www.matronics.com/contribution> > ========== ________________________________________________________________________________
Date: Nov 08, 2017
Rob, The three AMOCS that have been approved are all for Garmin products. That having been said, the most recent responses from the FAA indicate that they may be open to approving other data sources that output the "ADS-B OUT+" protocol as it contains the necessary data elements required for position reporting. In my updated AMOC, they specifically reference the ADS-B OUT+ protocol. If the Avidyne outputs it, you should be able to get approval... I would suggest putting the AMOC together like we did - we can provide you with what we submitted as a sample if you want... Ralph -----Original Message----- From: Rob Kermanj Sent: Nov 8, 2017 8:52 AM Subject: Re: RV10-List: Need latest Navworx UAT Console Does anyone know if AMCO applies to Avidyne ID-540? Thanks. On Nov 2, 2017, at 9:38 AM, Bob Leffler wrote: If you need 4.1.0 and the manual, let me know. I havent been able to locate anyone that has 5.0 yet. Get Outlook for iOSFrom: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of Bill Watson Sent: Thursday, November 2, 2017 11:01:53 AM I have the Navworx unit that will work with the AMOC given a certified GPS source. But I don't have a copy of the UAT console that will run, looking for help. I tried running the UAT console software I obtained back in 2012 but get an error on loading, "Nonshared DATA segment required", then if fails to open. Anyone have experience with this? A secondary concern I have is that I recall the UAT console loads a version of the Navworx software. If so, this is backlevel for my box (my box had been sent in since then for a maintenance upgrade). Does anyone have a copy of the UAT console that they can share or otherwise advise? Thanks. (I'll be posting on the VAF board as well) Bill "wired up G430w to the deadend box with all appendages crossed" Watson --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ========== Email Forum - -List">http://www.matronics.com/Navigator?RV10-List ========== p; - MATRONICS WEB FORUMS - ums.matronics.com ========== p; - NEW MATRONICS LIST WIKI - matronics.com ========== p; - List Contribution Web Site - p; -Matt Dralle, List Admin. http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Nov 08, 2017
Ralph, thanks for the quick reply. Please send me the package you provided to the FAA. I spoke to Avidyne and they researching it on their end. I will forward your email (if OK with you) to Avidyne and a copy of my proposal to FAA so they also remain in the loop. Thanks again Rob. Sent from my iPhone > On Nov 8, 2017, at 7:31 AM, Ralph E. Capen wrote: > > > Rob, > > The three AMOCS that have been approved are all for Garmin products. > That having been said, the most recent responses from the FAA indicate that they may be open to approving other data sources that output the "ADS-B OUT+" protocol as it contains the necessary data elements required for position reporting. In my updated AMOC, they specifically reference the ADS-B OUT+ protocol. If the Avidyne outputs it, you should be able to get approval... > > I would suggest putting the AMOC together like we did - we can provide you with what we submitted as a sample if you want... > > Ralph > -----Original Message----- > > From: Rob Kermanj > > Sent: Nov 8, 2017 8:52 AM > > To: rv10-list(at)matronics.com > > Subject: Re: RV10-List: Need latest Navworx UAT Console > > > > Does anyone know if AMCO applies to Avidyne ID-540? > Thanks. > On Nov 2, 2017, at 9:38 AM, Bob Leffler wrote: > If you need 4.1.0 and the manual, let me know. > I havent been able to locate anyone that has 5.0 yet. > Get Outlook for iOSFrom: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of Bill Watson > Sent: Thursday, November 2, 2017 11:01:53 AM > To: rv10-list(at)matronics.com > > I have the Navworx unit that will work with the AMOC given a certified > GPS source. But I don't have a copy of the UAT console that will run, > looking for help. > > I tried running the UAT console software I obtained back in 2012 but get > an error on loading, "Nonshared DATA segment required", then if fails to > open. Anyone have experience with this? > > A secondary concern I have is that I recall the UAT console loads a > version of the Navworx software. If so, this is backlevel for my box > (my box had been sent in since then for a maintenance upgrade). > > Does anyone have a copy of the UAT console that they can share or > otherwise advise? Thanks. > > (I'll be posting on the VAF board as well) > > Bill "wired up G430w to the deadend box with all appendages crossed" Watson > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ========== > Email Forum - > -List">http://www.matronics.com/Navigator?RV10-List > ========== > p; - MATRONICS WEB FORUMS - > ums.matronics.com > ========== > p; - NEW MATRONICS LIST WIKI - > matronics.com > ========== > p; - List Contribution Web Site - > p; -Matt Dralle, List Admin. > http://www.matronics.com/contribution > ========== > > > > > > ________________________________________________________________________________
Date: Nov 08, 2017
Request for background: What kind off experience have people had with failing/damaged/rusting wheel bearings vis-a-vis maintenance of wheel bearing? I operate off a sometimes wet and mushy field where my wheels get quite a dousing. Each condition inspection, I've been repacking the bearings. So far I have seen any signs of rusting - is there something else I should be looking for? Bill "6 years and 900+ hours on same bearings, color me curious" Watson On 11/7/2017 7:26 PM, David Saylor wrote: > Does anyone have a good source for wheel bearings? I found Timken nose > bearings for about $40 but the my shopping cart at Vans is running > about $650 for all 8 pcs for the mains. I'm pretty sure it doesn't > have to be this way. But my search for LM274949-2-629 is coming up > short. > > Has someone had success with an alternate number? Besides the > Cleveland number? > > Thanks, > > --Dave > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Nov 08, 2017
The avidyne does indeed support adsb+ I can assist with writing the AMOC. It will literally take 5-10 minutes to create the doc to send to the FAA Email me if you want to go down that path. Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> on behalf of Ralph E. Capen Sent: Wednesday, November 8, 2017 9:31:07 AM Subject: Re: RV10-List: Need latest Navworx UAT Console Rob, The three AMOCS that have been approved are all for Garmin products. That having been said, the most recent responses from the FAA indicate that they may be open to approving other data sources that output the "ADS-B OU T+" protocol as it contains the necessary data elements required for positi on reporting. In my updated AMOC, they specifically reference the ADS-B OU T+ protocol. If the Avidyne outputs it, you should be able to get approval ... I would suggest putting the AMOC together like we did - we can provide you with what we submitted as a sample if you want... Ralph -----Original Message----- From: Rob Kermanj Sent: Nov 8, 2017 8:52 AM Subject: Re: RV10-List: Need latest Navworx UAT Console Does anyone know if AMCO applies to Avidyne ID-540? Thanks. On Nov 2, 2017, at 9:38 AM, Bob Leffler wrote: If you need 4.1.0 and the manual, let me know. I haven=92t been able to locate anyone that has 5.0 yet. Get Outlook for iOSFrom: owner-rv10-list-server(at)matronics.com <owner-rv10-l ist-server(at)matronics.com> on behalf of Bill Watson Sent: Thursday, November 2, 2017 11:01:53 AM Subject: RV10-List: Need latest Navworx UAT Console --> RV10-List message p osted by: Bill Watson I have the Navworx unit that will work with the AMOC given a certified GPS source. But I don't have a copy of the UAT console that will run, looking for help. I tried running the UAT console software I obtained back in 2012 but get an error on loading, "Nonshared DATA segment required", then if fails to open. Anyone have experience with this? A secondary concern I have is that I recall the UAT console loads a version of the Navworx software. If so, this is backlevel for my box (my box had been sent in since then for a maintenance upgrade). Does anyone have a copy of the UAT console that they can share or otherwise advise? Thanks. (I'll be posting on the VAF board as well) Bill "wired up G430w to the deadend box with all appendages crossed" Watson --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus Email Forum - -List">http://www.matronics.com/Navigator?RV10-List p; - MATRONICS WEB FORUMS - ums.matronics.com p; - NEW MATRONICS LIST WIKI - matronics.com p; - List Contribution Web Site - p; -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Date: Nov 08, 2017
Right, SHC 100 looks a lot like Mobil 28 but it's lighter red IIRC. I used it last year. --Dave On Tue, Nov 7, 2017 at 7:09 PM, Kelly McMullen wrote: > > Once you get replacements, be aware that Cleveland has changed their > grease recommendations. Aeroshell #5 is no longer 1st choice. > First choice is Mobil SHC 100, which is a red synthetic grease. > Skygeek carries an appropriate sized tube. The rest of suppliers, last I > looked only carry 5 lbs and up. > I do not know reason Cleveland changed their recommendation. > Kelly > > On 11/7/2017 7:07 PM, Tim Olson wrote: > >> >> Yeah I've taken them in to a local place in town before >> called "Bearing Headquarters" and they can get just >> about anything. >> Tim >> >> On 11/7/2017 7:17 PM, Don Orrick wrote: >> >>> >>> Local auto parts store can order them or a local bearing supply co can >>> get them >>> >>> Sent from my iPhone >>> >>> On Nov 7, 2017, at 6:26 PM, David Saylor wrote: >>>> >>>> Does anyone have a good source for wheel bearings? I found Timken nose >>>> bearings for about $40 but the my shopping cart at Vans is running about >>>> $650 for all 8 pcs for the mains. I'm pretty sure it doesn't have to be >>>> this way. But my search for LM274949-2-629 is coming up short. >>>> >>>> Has someone had success with an alternate number? Besides the >>>> Cleveland number? >>>> >>>> Thanks, >>>> >>>> --Dave >>>> >>>> >>>> >> >> > > ________________________________________________________________________________
Date: Nov 08, 2017
Thanks Bob. Yes ...please, please. What do you need from me? Sent from my iPhone > On Nov 8, 2017, at 8:05 AM, Bob Leffler wrote: > > The avidyne does indeed support adsb+ > > I can assist with writing the AMOC. It will literally take 5-10 minutes t o create the doc to send to the FAA > > Email me if you want to go down that path. > > Get Outlook for iOS > From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matroni cs.com> on behalf of Ralph E. Capen > Sent: Wednesday, November 8, 2017 9:31:07 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Need latest Navworx UAT Console > > > Rob, > > The three AMOCS that have been approved are all for Garmin products. > That having been said, the most recent responses from the FAA indicate tha t they may be open to approving other data sources that output the "ADS-B OU T+" protocol as it contains the necessary data elements required for positio n reporting. In my updated AMOC, they specifically reference the ADS-B OUT+ protocol. If the Avidyne outputs it, you should be able to get approval... > > I would suggest putting the AMOC together like we did - we can provide you with what we submitted as a sample if you want... > > Ralph > -----Original Message----- > > From: Rob Kermanj > > Sent: Nov 8, 2017 8:52 AM > > To: rv10-list(at)matronics.com > > Subject: Re: RV10-List: Need latest Navworx UAT Console > > > > Does anyone know if AMCO applies to Avidyne ID-540? > Thanks. > On Nov 2, 2017, at 9:38 AM, Bob Leffler wrote: > If you need 4.1.0 and the manual, let me know. > I haven=99t been able to locate anyone that has 5.0 yet. > Get Outlook for iOSFrom: owner-rv10-list-server(at)matronics.com <owner-rv10- list-server(at)matronics.com> on behalf of Bill Watson > Sent: Thursday, November 2, 2017 11:01:53 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Need latest Navworx UAT Console --> RV10-List message p osted by: Bill Watson > > I have the Navworx unit that will work with the AMOC given a certified > GPS source. But I don't have a copy of the UAT console that will run, > looking for help. > > I tried running the UAT console software I obtained back in 2012 but get > an error on loading, "Nonshared DATA segment required", then if fails to > open. Anyone have experience with this? > > A secondary concern I have is that I recall the UAT console loads a > version of the Navworx software. If so, this is backlevel for my box > (my box had been sent in since then for a maintenance upgrade). > > Does anyone have a copy of the UAT console that they can share or > otherwise advise? Thanks. > > (I'll be posting on the VAF board as well) > > Bill "wired up G430w to the deadend box with all appendages crossed" Watso n > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ========== > Email Forum - > -List">http://www.matronics.com/Navigator?RV10-List > ========== > p; - MATRONICS WEB FORUMS - > ums.matronics.com > ========== > p; - NEW MATRONICS LIST WIKI - > matronics.com > ========== > p; - List Contribution Web Site - > p; -Matt Dralle, List Admin. > http://www.matronics.com/contribution > ========== > > > > ========== > Email Forum - > -List">http://www.matronics.com/Navigator?RV10-List > ========== > p; - MATRONICS WEB FORUMS - > ums.matronics.com > ========== > p; - NEW MATRONICS LIST WIKI - > matronics.com > ========== > p; - List Contribution Web Site - > p; -Matt Dralle, List Admin. > http://www.matronics.com/contribution > ========== > > > ________________________________________________________________________________
Date: Nov 08, 2017
Wire the Avidyne to the ads600-b using the adsb+ protocol. I don=92t recall if there is an Avidyne example in the Navworx manual. Use the gtn650/gns430w as an example. The gps pins will be different, but the NavWorxs side will be the same. Disconnect the internal gps antenna Change the Navworx configuration to use the external gps Validate that you have three green status indicators Fly and get a copy of the public performance report from the FAA. If there is an Avidyne schematic in the Navworx manual, we can cut and past e that, if not you=92ll have to create an installation schematic. Again, use the Garmin schematics as an example. Then let me know. It=92s a simple cut and paste job using my application as a template. Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> on behalf of Rob Kermanj Sent: Wednesday, November 8, 2017 11:02:27 AM Subject: Re: RV10-List: Need latest Navworx UAT Console Thanks Bob. Yes ...please, please. What do you need from me? Sent from my iPhone On Nov 8, 2017, at 8:05 AM, Bob Leffler > wrote: The avidyne does indeed support adsb+ I can assist with writing the AMOC. It will literally take 5-10 minutes to create the doc to send to the FAA Email me if you want to go down that path. Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com<mailto:owner-rv10-list-server@ma tronics.com> > on behalf of Ralph E. Capen > Sent: Wednesday, November 8, 2017 9:31:07 AM Subject: Re: RV10-List: Need latest Navworx UAT Console ilto:recapen(at)earthlink.net>> Rob, The three AMOCS that have been approved are all for Garmin products. That having been said, the most recent responses from the FAA indicate that they may be open to approving other data sources that output the "ADS-B OU T+" protocol as it contains the necessary data elements required for positi on reporting. In my updated AMOC, they specifically reference the ADS-B OU T+ protocol. If the Avidyne outputs it, you should be able to get approval ... I would suggest putting the AMOC together like we did - we can provide you with what we submitted as a sample if you want... Ralph -----Original Message----- From: Rob Kermanj Sent: Nov 8, 2017 8:52 AM Subject: Re: RV10-List: Need latest Navworx UAT Console Does anyone know if AMCO applies to Avidyne ID-540? Thanks. On Nov 2, 2017, at 9:38 AM, Bob Leffler > wrote: If you need 4.1.0 and the manual, let me know. I haven=92t been able to locate anyone that has 5.0 yet. Get Outlook for iOSFrom: owner-rv10-list-server(at)matronics.com<mailto:owner- rv10-list-server(at)matronics.com> > on behalf of Bill Watson > Sent: Thursday, November 2, 2017 11:01:53 AM Subject: RV10-List: Need latest Navworx UAT Console --> RV10-List message p osted by: Bill Watson > I have the Navworx unit that will work with the AMOC given a certified GPS source. But I don't have a copy of the UAT console that will run, looking for help. I tried running the UAT console software I obtained back in 2012 but get an error on loading, "Nonshared DATA segment required", then if fails to open. Anyone have experience with this? A secondary concern I have is that I recall the UAT console loads a version of the Navworx software. If so, this is backlevel for my box (my box had been sent in since then for a maintenance upgrade). Does anyone have a copy of the UAT console that they can share or otherwise advise? Thanks. (I'll be posting on the VAF board as well) Bill "wired up G430w to the deadend box with all appendages crossed" Watson --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus Email Forum - -List">http://www.matronics.com/Navigator?RV10-List p; - MATRONICS WEB FORUMS - ums.matronics.com<http://ums.matronics.com> p; - NEW MATRONICS LIST WIKI - matronics.com<http://matronics.com> p; - List Contribution Web Site - p; -Matt Dralle, List Admin. http://www.matronics.com/contribution Email Forum - -List">http://www.matronics.com/Navigator?RV10-List p; - MATRONICS WEB FORUMS - ums.matronics.com<http://ums.matronics.com> p; - NEW MATRONICS LIST WIKI - matronics.com<http://matronics.com> p; - List Contribution Web Site - p; -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Date: Nov 08, 2017
Subject: Re: Need latest Navworx UAT Console
Thanks Bob. Will do. Will let you how it turns out. Sent from my iPhone > On Nov 8, 2017, at 2:52 PM, Bob Leffler wrote: > > Wire the Avidyne to the ads600-b using the adsb+ protocol. > > I don=99t recall if there is an Avidyne example in the Navworx manua l. > > Use the gtn650/gns430w as an example. The gps pins will be different, bu t the NavWorxs side will be the same. > > Disconnect the internal gps antenna > > Change the Navworx configuration to use the external gps > > Validate that you have three green status indicators > > Fly and get a copy of the public performance report from the FAA. > > If there is an Avidyne schematic in the Navworx manual, we can cut and pas te that, if not you=99ll have to create an installation schematic. A gain, use the Garmin schematics as an example. > > Then let me know. It=99s a simple cut and paste job using my appli cation as a template. > > Get Outlook for iOS > From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matroni cs.com> on behalf of Rob Kermanj > Sent: Wednesday, November 8, 2017 11:02:27 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Need latest Navworx UAT Console > > Thanks Bob. Yes ...please, please. What do you need from me? > > Sent from my iPhone > > On Nov 8, 2017, at 8:05 AM, Bob Leffler wrote: > >> The avidyne does indeed support adsb+ >> >> I can assist with writing the AMOC. It will literally take 5-10 minutes t o create the doc to send to the FAA >> >> Email me if you want to go down that path. >> >> Get Outlook for iOS >> From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matron ics.com> on behalf of Ralph E. Capen >> Sent: Wednesday, November 8, 2017 9:31:07 AM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Need latest Navworx UAT Console >> >> >> Rob, >> >> The three AMOCS that have been approved are all for Garmin products. >> That having been said, the most recent responses from the FAA indicate th at they may be open to approving other data sources that output the "ADS-B O UT+" protocol as it contains the necessary data elements required for positi on reporting. In my updated AMOC, they specifically reference the ADS-B OUT + protocol. If the Avidyne outputs it, you should be able to get approval.. . >> >> I would suggest putting the AMOC together like we did - we can provide yo u with what we submitted as a sample if you want... >> >> Ralph >> -----Original Message----- >> >> From: Rob Kermanj >> >> Sent: Nov 8, 2017 8:52 AM >> >> To: rv10-list(at)matronics.com >> >> Subject: Re: RV10-List: Need latest Navworx UAT Console >> >> >> >> Does anyone know if AMCO applies to Avidyne ID-540? >> Thanks. >> On Nov 2, 2017, at 9:38 AM, Bob Leffler wrote: >> If you need 4.1.0 and the manual, let me know. >> I haven=99t been able to locate anyone that has 5.0 yet. >> Get Outlook for iOSFrom: owner-rv10-list-server(at)matronics.com <owner-rv10 -list-server(at)matronics.com> on behalf of Bill Watson >> Sent: Thursday, November 2, 2017 11:01:53 AM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Need latest Navworx UAT Console --> RV10-List message posted by: Bill Watson >> >> I have the Navworx unit that will work with the AMOC given a certified >> GPS source. But I don't have a copy of the UAT console that will run, >> looking for help. >> >> I tried running the UAT console software I obtained back in 2012 but get >> an error on loading, "Nonshared DATA segment required", then if fails to >> open. Anyone have experience with this? >> >> A secondary concern I have is that I recall the UAT console loads a >> version of the Navworx software. If so, this is backlevel for my box >> (my box had been sent in since then for a maintenance upgrade). >> >> Does anyone have a copy of the UAT console that they can share or >> otherwise advise? Thanks. >> >> (I'll be posting on the VAF board as well) >> >> Bill "wired up G430w to the deadend box with all appendages crossed" Wats on >> >> >> --- >> This email has been checked for viruses by Avast antivirus software. >> https://www.avast.com/antivirus >> >> ========== >> Email Forum - >> -List">http://www.matronics.com/Navigator?RV10-List >> ========== >> p; - MATRONICS WEB FORUMS - >> ums.matronics.com >> ========== >> p; - NEW MATRONICS LIST WIKI - >> matronics.com >> ========== >> p; - List Contribution Web Site - >> p; -Matt Dralle, List Admin. >> http://www.matronics.com/contribution >> ========== >> >> >> >> ========== >> Email Forum - >> -List">http://www.matronics.com/Navigator?RV10-List >> ========== >> p; - MATRONICS WEB FORUMS - >> ums.matronics.com >> ========== >> p; - NEW MATRONICS LIST WIKI - >> matronics.com >> ========== >> p; - List Contribution Web Site - >> p; -Matt Dralle, List Admin. >> http://www.matronics.com/contribution >> ========== >> >> >> ________________________________________________________________________________
Date: Nov 09, 2017
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 09, 2017
Bill, I'll send some pictures of the bearings I'm replacing. The rollers and cones are pitted. If what you're doing is keeping the bearings in good shape, just keep doing it. It's pretty obvious when they fail. In my experience, once the cup or a roller shows even the tiniest pit/mark/dent/chip, it only takes a few hours of operation to go from "I could probably live with that" to "get that thing off my plane". --Dave On Wed, Nov 8, 2017 at 6:59 AM, Bill Watson wrote: > > Request for background: What kind off experience have people had with > failing/damaged/rusting wheel bearings vis-a-vis maintenance of wheel > bearing? > > I operate off a sometimes wet and mushy field where my wheels get quite a > dousing. Each condition inspection, I've been repacking the bearings. So > far I have seen any signs of rusting - is there something else I should be > looking for? > > Bill "6 years and 900+ hours on same bearings, color me curious" Watson > > On 11/7/2017 7:26 PM, David Saylor wrote: > >> Does anyone have a good source for wheel bearings? I found Timken nose >> bearings for about $40 but the my shopping cart at Vans is running about >> $650 for all 8 pcs for the mains. I'm pretty sure it doesn't have to be >> this way. But my search for LM274949-2-629 is coming up short. >> >> Has someone had success with an alternate number? Besides the Cleveland >> number? >> >> Thanks, >> >> --Dave >> >> >> > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Subject: Wanted: Garmin 496
Date: Nov 10, 2017
My Garmin 496 has died. The simplest solution is for me to simply replace it and avoid having to make other changes to incorporate a different source for GPS data. If anyone has a used unit (in good working order) I'm in the market for it. Don't need any accessories just a 496 with a battery. Albert Gardner RV-10 N991RV Yuma, AZ ________________________________________________________________________________
Date: Nov 10, 2017
Subject: Re: Wanted: Garmin 496
SGkgQWxiZXJ0LEkgaGF2ZSAyIDQ5NidzLiBJIG93bmVkIG9uZSB3aGVuIEkgZGVjaWRlZCB0byBi dWlsZCBhbiBSVjEyIHdoaWNoIGF0IHRoYXQgdGltZSBjYW1lIHdpdGggb25lIGFzIHN0YW5kYXJk IGVxdWlwbWVudC4gSSB3aWxsIGRpZyBhcm91bmQgYW5kIGZpbmQgaXQgYnV0IGdsYWQgdG8gc2Vs bCBpdCBpZiB5b3UgY2FuIHB1dCBpdCB0byBnb29kIHVzZS5QYXVsIEdyaW1zdGFkLMKgY29udHJv bGFwcHJvYWNowqBTZW5kIGEgcGVyc29uYWwgZW1haWwgdG8gcGF1bEBjb250cm9sYXBwcm9hY2gu Y29tCgo8IS0tCi8qIEZvbnQgRGVmaW5pdGlvbnMgKi8KQGZvbnQtZmFjZQoJe2ZvbnQtZmFtaWx5 OiJDYW1icmlhIE1hdGgiOwoJcGFub3NlLTE6MiA0IDUgMyA1IDQgNiAzIDIgNDt9CkBmb250LWZh Y2UKCXtmb250LWZhbWlseTpDYWxpYnJpOwoJcGFub3NlLTE6MiAxNSA1IDIgMiAyIDQgMyAyIDQ7 fQovKiBTdHlsZSBEZWZpbml0aW9ucyAqLwpwLk1zb05vcm1hbCwgbGkuTXNvTm9ybWFsLCBkaXYu TXNvTm9ybWFsCgl7bWFyZ2luOjBpbjsKCW1hcmdpbi1ib3R0b206LjAwMDFwdDsKCWZvbnQtc2l6 ZToxMi4wcHQ7Cglmb250LWZhbWlseToiVGltZXMgTmV3IFJvbWFuIiwic2VyaWYiO30KYTpsaW5r LCBzcGFuLk1zb0h5cGVybGluawoJe21zby1zdHlsZS1wcmlvcml0eTo5OTsKCWNvbG9yOmJsdWU7 Cgl0ZXh0LWRlY29yYXRpb246dW5kZXJsaW5lO30KYTp2aXNpdGVkLCBzcGFuLk1zb0h5cGVybGlu a0ZvbGxvd2VkCgl7bXNvLXN0eWxlLXByaW9yaXR5Ojk5OwoJY29sb3I6cHVycGxlOwoJdGV4dC1k ZWNvcmF0aW9uOnVuZGVybGluZTt9CnNwYW4uRW1haWxTdHlsZTE3Cgl7bXNvLXN0eWxlLXR5cGU6 cGVyc29uYWwtcmVwbHk7Cglmb250LWZhbWlseToiQ2FsaWJyaSIsInNhbnMtc2VyaWYiOwoJY29s b3I6IzFGNDk3RDt9Ci5Nc29DaHBEZWZhdWx0Cgl7bXNvLXN0eWxlLXR5cGU6ZXhwb3J0LW9ubHk7 fQpAcGFnZSBXb3JkU2VjdGlvbjEKCXtzaXplOjguNWluIDExLjBpbjsKCW1hcmdpbjoxLjBpbiAx LjBpbiAxLjBpbiAxLjBpbjt9CmRpdi5Xb3JkU2VjdGlvbjEKCXtwYWdlOldvcmRTZWN0aW9uMTt9 Ci0tPi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS1Gcm9tOiBBbGJlcnQgPGlic3B1 ZEByb2FkcnVubmVyLmNvbT4gRGF0ZTogMTEvOS8xNyAgMTE6NDAgUE0gIChHTVQtMDg6MDApIFRv OiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbSBTdWJqZWN0OiBSVjEwLUxpc3Q6IFdhbnRlZDogR2Fy bWluIDQ5NiAKTXkgR2FybWluIDQ5NiBoYXMgZGllZC4gVGhlIHNpbXBsZXN0IHNvbHV0aW9uIGlz IGZvciBtZSB0byBzaW1wbHkgcmVwbGFjZSBpdCBhbmQgYXZvaWQgaGF2aW5nIHRvIG1ha2Ugb3Ro ZXIgY2hhbmdlcyB0byBpbmNvcnBvcmF0ZSBhIGRpZmZlcmVudCBzb3VyY2UgZm9yIEdQUyBkYXRh LiBJZiBhbnlvbmUgaGFzIGEgdXNlZCB1bml0IChpbiBnb29kIHdvcmtpbmcgb3JkZXIpIEknbSBp biB0aGUgbWFya2V0IGZvciBpdC4gRG9uJ3QgbmVlZCBhbnkgYWNjZXNzb3JpZXMganVzdCBhIDQ5 NiB3aXRoIGEgYmF0dGVyeS5BbGJlcnQgR2FyZG5lclJWLTEwIE45OTFSVll1bWEsIEFawqA ________________________________________________________________________________
Date: Nov 11, 2017
Subject: Make Sure You're Listed! List of Contributors Published in
December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 11, 2017
Subject: Unservicable bearing cups
Here's a picture of some of the cups I just changed. I change them when they have even just one of the marks on the inner surface. So obviously these are toast. My plane sat in 2016 from April to October. I suspect that may have something to do with these marks. I'll be paying closer attention next year. All the bearings in both MLGs and one side of NLG were replaced. The rollers had corresponding marks. PNs for future reference: MLG Timken LM29749 Cone (the part with the rollers) Timken LM29710 Cup (the part pressed into the wheel) Add "20629" or "2-629" the end of the PN for FAA approved parts NLG Timken LM67000LA Cone Timken LM67010 Cup (as listed on the MATCO drawing) --Dave ________________________________________________________________________________
Subject: Re: Unservicable bearing cups
Date: Nov 11, 2017
Thanks for posting the pics and part number recap for the people who want to save this for future reference! Those marks almost have to not be from USAGE wear, but from sitting wear. Notice how they are only on 1/2 of the race...that seems to indicate, in my non-expert opinion, that either that is the side that all the weight was on, or that was the side that had not much weight and therefore had enough of a gap that moisture got in. I would think that these went bad strictly from sitting too long with moisture around. Was this still somewhat near the ocean? I bet if you had flown regularly you wouldn't have seen this. The unevenness of the marks also make me wonder if maybe the bearings were just slightly loose. That's just thinking out loud...not that I'd advise you to do anything different. Anyway, very interesting. If you scotchbrite those marks, do they polish off? I wonder how deep they go. Tim On 11/11/2017 12:21 PM, David Saylor wrote: > Here's a picture of some of the cups I just changed. I change them > when they have even just one of the marks on the inner surface. So > obviously these are toast. > > My plane sat in 2016 from April to October. I suspect that may have > something to do with these marks. I'll be paying closer attention > next year. All the bearings in both MLGs and one side of NLG were > replaced. > > The rollers had corresponding marks. > > PNs for future reference: > > MLG > Timken LM29749 Cone (the part with the rollers) > Timken LM29710 Cup (the part pressed into the wheel) > Add "20629" or "2-629" the end of the PN for FAA approved parts > > NLG > Timken LM67000LA Cone > Timken LM67010 Cup > (as listed on the MATCO drawing) > > > --Dave ________________________________________________________________________________
Date: Nov 12, 2017
Ya l think ya got it narrowed down there ;-). It was parked for engine work for spring/summer 2016. It sat in a hangar in San Jose, so probably less salt air than Watsonville but still maybe some. I=99ve heard the rule of thumb is within 30 miles of salt water. But then it=99s lived at WVI since 2007 without any real corrosion anywhere to speak of. The marks aren=99t gonna polish out. They=99re significant. =94Dave On Sat, Nov 11, 2017 at 3:21 PM Tim Olson wrote: > > Thanks for posting the pics and part number recap for the people who want > to > save this for future reference! > > Those marks almost have to not be from USAGE wear, but from sitting wear. > Notice how they are only on 1/2 of the race...that seems to indicate, > in my non-expert opinion, that either that is the side that all the weigh t > was on, or that was the side that had not much weight and therefore > had enough of a gap that moisture got in. > > I would think that these went bad strictly from sitting too long with > moisture around. Was this still somewhat near the ocean? > I bet if you had flown regularly you wouldn't have seen this. > > The unevenness of the marks also make me wonder if maybe the > bearings were just slightly loose. That's just thinking out loud...not > that I'd advise you to do anything different. > > Anyway, very interesting. If you scotchbrite those marks, do they polish > off? I wonder how deep they go. > Tim > > On 11/11/2017 12:21 PM, David Saylor wrote: > > Here's a picture of some of the cups I just changed. I change them > > when they have even just one of the marks on the inner surface. So > > obviously these are toast. > > > > My plane sat in 2016 from April to October. I suspect that may have > > something to do with these marks. I'll be paying closer attention > > next year. All the bearings in both MLGs and one side of NLG were > > replaced. > > > > The rollers had corresponding marks. > > > > PNs for future reference: > > > > MLG > > Timken LM29749 Cone (the part with the rollers) > > Timken LM29710 Cup (the part pressed into the wheel) > > Add "20629" or "2-629" the end of the PN for FAA approved parts > > > > NLG > > Timken LM67000LA Cone > > Timken LM67010 Cup > > (as listed on the MATCO drawing) > > > > > > --Dave > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Subject: CofG Question (Sort of)
Date: Nov 12, 2017
Hi I have my -10 project on a dolly and am planning to get it up on its wheels in the next couple of weeks. I have the tail cone (but not the feathers) attached and am wondering how tippy it will be if there is no engine attached. Any comments? If I need to add ballast to the nose till I get an engine, is there any preferred way to do this? Cheers Les C-GROK (now officially in fiberglass hell) C-GCWZ flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474863#474863 ________________________________________________________________________________
Date: Nov 12, 2017
Subject: Re: CofG Question (Sort of)
It=99s not tippy side to side at all. You need to prop the tail up unt il you get the engine on. You would need several hundred pounds on the nose t o hold the tail up in a stable way. I would just put a stand on the tail lik e in he attached picture. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Nov 12, 2017, at 7:27 PM, kearney wrote: > > > Hi > > I have my -10 project on a dolly and am planning to get it up on its wheel s in the next couple of weeks. > > I have the tail cone (but not the feathers) attached and am wondering how t ippy it will be if there is no engine attached. > > Any comments? If I need to add ballast to the nose till I get an engine, i s there any preferred way to do this? > > Cheers > > Les > > C-GROK (now officially in fiberglass hell) > C-GCWZ flying > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=474863#474863 > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Nov 12, 2017
Hey Les, I needed to maneuver the plane w/out wings or tail feathers in and out of the shop during painting and w/out the engine. So I lashed two 5 gal. jugs of water onto the engine mount to counter the tail. It was just enough so that I could push down on the tail to raise the front wheel ... easily steered it from the tail. Used a small prop under the tail tie down so that I could temporarily install the vert and rudder to tape off stripes matching the fuse. Later, - Lew -----Original Message----- From: kearney Sent: Sunday, November 12, 2017 7:27 PM Subject: RV10-List: CofG Question (Sort of) Hi I have my -10 project on a dolly and am planning to get it up on its wheels in the next couple of weeks. I have the tail cone (but not the feathers) attached and am wondering how tippy it will be if there is no engine attached. Any comments? If I need to add ballast to the nose till I get an engine, is there any preferred way to do this? Cheers Les ________________________________________________________________________________
Date: Nov 13, 2017
It is tail heavy about 15 lbs GARY Specketer > On Nov 12, 2017, at 7:27 PM, kearney wrote: > > > Hi > > I have my -10 project on a dolly and am planning to get it up on its wheels in the next couple of weeks. > > I have the tail cone (but not the feathers) attached and am wondering how tippy it will be if there is no engine attached. > > Any comments? If I need to add ballast to the nose till I get an engine, is there any preferred way to do this? > > Cheers > > Les > > C-GROK (now officially in fiberglass hell) > C-GCWZ flying > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=474863#474863 > > > > > > > > > ________________________________________________________________________________
Date: Nov 13, 2017
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that ilk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 13, 2017
Guys Thanks for the info. I'll likely install bump bar in tail but use the water in pail trick as well. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474945#474945 ________________________________________________________________________________
Date: Nov 13, 2017
Well, if it isn't one thing it's another. Last week my Garmin 496 GPS died, this week it's my HID landing lights. So I'm going to replace them with LEDs. Vans sells a Sunspot LED wing tip kit for the RV10/14 kits. From the picture I can't tell if they are a exact replacement for the original RV-10 wing tip landing light or not. Vans picture doesn't show the position lights that the original installation has in the wing tip. Maybe there is a better LED light available. Wouldn't mind installing them inboard from the tips for better center line coverage. I've considered an additional light under the prop for center line coverage. Tried mounting one on the front wheel pant but too much vibration for a filament type lamp. LED should be ok with vibration though. Any landing light suggestions? Albert Gardner RV-10 N991RV Yuma, AZ ________________________________________________________________________________
Date: Nov 13, 2017
I can't comment on most of the things in the email, but I can tell you that a bit over a year ago I bought a set of HID's on ebay, brand new, and the pair of them with ballasts was about $110. So, if you do end up wanting to replace your HID with another HID, the cost is probably much less than your original purchase. I think I paid $400 each back in 2005, and now they're more like $110/pr if you find them right. I'm assuming your HID is mounted in a wing cutout. You should be able to find an LED that will fit into that spot too, but you'll spend a bunch more...but you can get a real good light too. Tim On 11/13/2017 12:45 PM, Albert wrote: > > Well, if it isn't one thing it's another. Last week my Garmin 496 GPS died, > this week it's my HID landing lights. So I'm going to replace them with > LEDs. Vans sells a Sunspot LED wing tip kit for the RV10/14 kits. From the > picture I can't tell if they are a exact replacement for the original RV-10 > wing tip landing light or not. Vans picture doesn't show the position lights > that the original installation has in the wing tip. Maybe there is a better > LED light available. Wouldn't mind installing them inboard from the tips for > better center line coverage. I've considered an additional light under the > prop for center line coverage. Tried mounting one on the front wheel pant > but too much vibration for a filament type lamp. LED should be ok with > vibration though. Any landing light suggestions? > Albert Gardner > RV-10 N991RV > Yuma, AZ > ________________________________________________________________________________
Date: Nov 13, 2017
Just leave the pail of water outside overnight and you will have a solid weight. ;-( -sent from the I-droid implanted in my forearm On Mon, Nov 13, 2017 at 9:28 AM, kearney wrote: > > Guys > > Thanks for the info. I'll likely install bump bar in tail but use the > water in pail trick as well. > > Cheers > > Les > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=474945#474945 > > ________________________________________________________________________________
Date: Nov 14, 2017
Subject: Re: RV10-List Digest: 6 Msgs - 11/13/17
Try Grainger if the HID situation involves a bulb only. I had a bulb go bad but ballast worked fine; a GE HID bulb with the old ballast works with the old holder. The LED stuff I found required a complete rework of the LL fixture and tip area. N46007 On Tue, Nov 14, 2017 at 1:05 AM, RV10-List Digest Server < rv10-list(at)matronics.com> wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV10-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV10-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style > 82701&View=html&Chapter 17-11-13&Archive=RV10 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style > 82701&View=txt&Chapter 17-11-13&Archive=RV10 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV10-List Digest Archive > --- > Total Messages Posted Mon 11/13/17: 6 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 0. 08:17 AM - [PLEASE READ] Why I Have A Fund Raiser... (Matt > Dralle) > 1. 06:27 AM - Re: CofG Question (Sort of) (Gary Specketer) > 2. 08:29 AM - Re: CofG Question (Sort of) (kearney) > 3. 10:47 AM - Re: Re: CofG Question (Sort of) (Albert) > 4. 11:07 AM - Re: Re: CofG Question (Sort of) (Tim Olson) > 5. 12:26 PM - Re: Re: CofG Question (Sort of) (Kelly McMullen) > > > ________________________________ Message 0 > _____________________________________ > > > From: Matt Dralle <dralle(at)matronics.com> > Subject: RV10-List: [PLEASE READ] Why I Have A Fund Raiser... > > > Since the beginning, the Matronics List and Forum experience has been free > from > advertising. I have been approached by fair number of vendors wanting to > tap > into the large volume of activity across the various lists hosted here, > but have > always flatly refused. Everywhere you go on the Internet these days, a > user > is pummeled with flashing banners and videos and ads for crap that they > don't > want. Yahoo, Google and that ilk are not "free". The user must constantly > endure their barrage of commercialism thrust into their face at an ever > increasing > rate. Enough is enough, and the Lists at Matronics choose not to succumb > to that. > > That being said, running a service of this size is not "free". It costs a > lot > of money to maintain the hardware, pay for the electricity, air > conditioning, > maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund > raiser > each year during the month of November where I simply send out a short > email > every other day asking the members to make a small contribution to support > the > operation. That being said, that contribution is completely voluntary and > non-compulsory. > Many members choose not to contribute and that's fine. > > However, a very modest percentage of the members do choose to make a > contribution > and it is that financial support that keeps the Lists running. And that's > it. To my way of thinking, it is a much more pleasant way of maintaining > the > Lists and Forums. The other 11 months of the year, you don't see a single > advertisement > or request for support. That's refreshing and that is a List and Forum > that I want to belong to. I think other people feel the same way. > > Won't you please take a minute to make your Contribution today and support > these > Lists? > > http://www.matronics.com/contribution > > Or, drop a personal check in the mail to: > > Matt Dralle / Matronics > 581 Jeannie Way > Livermore CA 94550 > USA > > Thank you for your support! > > Matt Dralle > Email List Admin. > > > ________________________________ Message 1 > _____________________________________ > > > Subject: Re: RV10-List: CofG Question (Sort of) > From: Gary Specketer <gspecketer(at)gmail.com> > > > It is tail heavy about 15 lbs > > GARY Specketer > > > On Nov 12, 2017, at 7:27 PM, kearney wrote: > > > > > > Hi > > > > I have my -10 project on a dolly and am planning to get it up on its > wheels in > the next couple of weeks. > > > > I have the tail cone (but not the feathers) attached and am wondering > how tippy > it will be if there is no engine attached. > > > > Any comments? If I need to add ballast to the nose till I get an engine, > is there > any preferred way to do this? > > > > Cheers > > > > Les > > > > C-GROK (now officially in fiberglass hell) > > C-GCWZ flying > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=474863#474863 > > > > > > > > > > > > > > > > > > > > > ________________________________ Message 2 > _____________________________________ > > > Subject: RV10-List: Re: CofG Question (Sort of) > From: "kearney" <kearney(at)shaw.ca> > > > Guys > > Thanks for the info. I'll likely install bump bar in tail but use the > water in > pail trick as well. > > Cheers > > Les > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=474945#474945 > > > ________________________________ Message 3 > _____________________________________ > > > From: "Albert" <ibspud(at)roadrunner.com> > Subject: RE: RV10-List: Re: CofG Question (Sort of) > > > Well, if it isn't one thing it's another. Last week my Garmin 496 GPS died, > this week it's my HID landing lights. So I'm going to replace them with > LEDs. Vans sells a Sunspot LED wing tip kit for the RV10/14 kits. From the > picture I can't tell if they are a exact replacement for the original RV-10 > wing tip landing light or not. Vans picture doesn't show the position > lights > that the original installation has in the wing tip. Maybe there is a better > LED light available. Wouldn't mind installing them inboard from the tips > for > better center line coverage. I've considered an additional light under the > prop for center line coverage. Tried mounting one on the front wheel pant > but too much vibration for a filament type lamp. LED should be ok with > vibration though. Any landing light suggestions? > Albert Gardner > RV-10 N991RV > Yuma, AZ > > > ________________________________ Message 4 > _____________________________________ > > > Subject: Re: RV10-List: Re: CofG Question (Sort of) > From: Tim Olson <Tim(at)MyRV10.com> > > > I can't comment on most of the things in the email, but > I can tell you that a bit over a year ago I bought a set > of HID's on ebay, brand new, and the pair of them with > ballasts was about $110. So, if you do end up wanting > to replace your HID with another HID, the cost is > probably much less than your original purchase. I think > I paid $400 each back in 2005, and now they're more like > $110/pr if you find them right. > I'm assuming your HID is mounted in a wing cutout. > > You should be able to find an LED that will fit into > that spot too, but you'll spend a bunch more...but you > can get a real good light too. > > Tim > > > On 11/13/2017 12:45 PM, Albert wrote: > > > > Well, if it isn't one thing it's another. Last week my Garmin 496 GPS > died, > > this week it's my HID landing lights. So I'm going to replace them with > > LEDs. Vans sells a Sunspot LED wing tip kit for the RV10/14 kits. From > the > > picture I can't tell if they are a exact replacement for the original > RV-10 > > wing tip landing light or not. Vans picture doesn't show the position > lights > > that the original installation has in the wing tip. Maybe there is a > better > > LED light available. Wouldn't mind installing them inboard from the tips > for > > better center line coverage. I've considered an additional light under > the > > prop for center line coverage. Tried mounting one on the front wheel pant > > but too much vibration for a filament type lamp. LED should be ok with > > vibration though. Any landing light suggestions? > > Albert Gardner > > RV-10 N991RV > > Yuma, AZ > > > > > ________________________________ Message 5 > _____________________________________ > > > From: Kelly McMullen <apilot2(at)gmail.com> > Subject: Re: RV10-List: Re: CofG Question (Sort of) > > Just leave the pail of water outside overnight and you will have a solid > weight. ;-( > > -sent from the I-droid implanted in my forearm > > On Mon, Nov 13, 2017 at 9:28 AM, kearney wrote: > > > > > Guys > > > > Thanks for the info. I'll likely install bump bar in tail but use the > > water in pail trick as well. > > > > Cheers > > > > Les > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=474945#474945 > > > > > > ________________________________________________________________________________
Subject: B&C Starter with Plane Power alternator - need bracket
Date: Nov 14, 2017
Anyone know if there is an off the shelf bracket that fits between the B&C lightweight starter and the 60A PP alternator? I'm installing the B&C starter during the upgrade to the panel, and the original steel bracket is nowhere close to fitting. Thanks in advance Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474969#474969 ________________________________________________________________________________
Date: Nov 15, 2017
Subject: Re: Prop / Throttle / Mixture Quadrant
Hi Les I prefer a quadrant as you can have simultaneous access to all the controls easier without having to take your hand off one control to the next as in a vernier setup. I have my quadrant on the panel with the Aerosport interior as that was the only option at the time. I would prefer the controls to be on the tunnel in the center console just like in the Cirrus, as that is a more natural position for your hand and also gives you more real estate on the panel for other purposes. Warm regards Patrick > On 6 Nov 2017, at 08:51, kearney wrote: > > > Hi > > I am close to making a decision on whether or not to use vernier control knobs or quadrant controls for Prop / Throttle / Mixture. With the Aerosport interior, I can put the quadrant on the panel or on the center console. > > For those who have already made this decision, I'd be interested in opinions etc. > > Cheers > > Les > > C-GROK (some assembly required) > C-GCWZ (Flying) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=474445#474445 > > > > > > > > > ________________________________________________________________________________
Subject: Re: B&C Starter with Plane Power alternator - need bracket
Date: Nov 14, 2017
I had the same problem. Neither of the links B&C provides will work. I ended up bending the Plane Power link (only slightly) and drilling a new 5/16 hole effectively shortening the link. I inserted the long bolt from behind with some wet torque seal on the end to mark the place to drill the new hole. Hope this helps. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474971#474971 ________________________________________________________________________________
Date: Nov 14, 2017
I had to fabricate a new bracket from 4130 to fit my B&C/ Plane Power alternator. Very simple wrt my installation. Rick #40956 C-GDMH Sent from my iPad > On Nov 14, 2017, at 2:02 PM, tshort wrote: > > > Anyone know if there is an off the shelf bracket that fits between the B&C lightweight starter and the 60A PP alternator? > > I'm installing the B&C starter during the upgrade to the panel, and the original steel bracket is nowhere close to fitting. > > Thanks in advance > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=474969#474969 > > > > > > > > > ________________________________________________________________________________
Date: Nov 15, 2017
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 16, 2017
Dave, Do you recall which grease you were using while the airplane set? Just curi ous as I=99m getting ready to repack (hopefully not replace!) my beari ngs. I=99ve got Aeroshell 5 in them now. The supplied wheels and bearings f rom Cleveland had Mobil SHC 100 installed in them from the factory. I=99m wanting to look at the corrosion inhibitors in each available gr ease going forward. Thanks, Phil Sent from my iPhone > On Nov 11, 2017, at 6:40 PM, David Saylor wrote: > > Ya l think ya got it narrowed down there ;-). > > It was parked for engine work for spring/summer 2016. It sat in a hangar i n San Jose, so probably less salt air than Watsonville but still maybe some. I=99ve heard the rule of thumb is within 30 miles of salt water. But then it=99s lived at WVI since 2007 without any real corrosion anywhe re to speak of. > > The marks aren=99t gonna polish out. They=99re significant. > > =94Dave > >> On Sat, Nov 11, 2017 at 3:21 PM Tim Olson wrote: >> >> Thanks for posting the pics and part number recap for the people who want to >> save this for future reference! >> >> Those marks almost have to not be from USAGE wear, but from sitting wear. >> Notice how they are only on 1/2 of the race...that seems to indicate, >> in my non-expert opinion, that either that is the side that all the weigh t >> was on, or that was the side that had not much weight and therefore >> had enough of a gap that moisture got in. >> >> I would think that these went bad strictly from sitting too long with >> moisture around. Was this still somewhat near the ocean? >> I bet if you had flown regularly you wouldn't have seen this. >> >> The unevenness of the marks also make me wonder if maybe the >> bearings were just slightly loose. That's just thinking out loud...not >> that I'd advise you to do anything different. >> >> Anyway, very interesting. If you scotchbrite those marks, do they polish >> off? I wonder how deep they go. >> Tim >> >> On 11/11/2017 12:21 PM, David Saylor wrote: >> > Here's a picture of some of the cups I just changed. I change them >> > when they have even just one of the marks on the inner surface. So >> > obviously these are toast. >> > >> > My plane sat in 2016 from April to October. I suspect that may have >> > something to do with these marks. I'll be paying closer attention >> > next year. All the bearings in both MLGs and one side of NLG were >> > replaced. >> > >> > The rollers had corresponding marks. >> > >> > PNs for future reference: >> > >> > MLG >> > Timken LM29749 Cone (the part with the rollers) >> > Timken LM29710 Cup (the part pressed into the wheel) >> > Add "20629" or "2-629" the end of the PN for FAA approved parts >> > >> > NLG >> > Timken LM67000LA Cone >> > Timken LM67010 Cup >> > (as listed on the MATCO drawing) >> > >> > >> > --Dave >> >> >> ========== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========== >> >> >> ________________________________________________________________________________
Date: Nov 16, 2017
I had Shell 5 in the mains and SHC100 in the nose. The nose failed one of the two. All the mains failed. --Dave On Thu, Nov 16, 2017 at 10:38 AM, Phillip Perry wrote: > Dave, > > Do you recall which grease you were using while the airplane set? Just > curious as I=99m getting ready to repack (hopefully not replace!) m y bearings. > > I=99ve got Aeroshell 5 in them now. The supplied wheels and bearin gs from > Cleveland had Mobil SHC 100 installed in them from the factory. > > I=99m wanting to look at the corrosion inhibitors in each available grease > going forward. > > Thanks, > Phil > > > Sent from my iPhone > > On Nov 11, 2017, at 6:40 PM, David Saylor wrote: > > Ya l think ya got it narrowed down there ;-). > > It was parked for engine work for spring/summer 2016. It sat in a hangar > in San Jose, so probably less salt air than Watsonville but still maybe > some. I=99ve heard the rule of thumb is within 30 miles of salt wa ter. But > then it=99s lived at WVI since 2007 without any real corrosion anyw here to > speak of. > > The marks aren=99t gonna polish out. They=99re significant. > > =94Dave > > On Sat, Nov 11, 2017 at 3:21 PM Tim Olson wrote: > >> >> Thanks for posting the pics and part number recap for the people who wan t >> to >> save this for future reference! >> >> Those marks almost have to not be from USAGE wear, but from sitting wear . >> Notice how they are only on 1/2 of the race...that seems to indicate, >> in my non-expert opinion, that either that is the side that all the weig ht >> was on, or that was the side that had not much weight and therefore >> had enough of a gap that moisture got in. >> >> I would think that these went bad strictly from sitting too long with >> moisture around. Was this still somewhat near the ocean? >> I bet if you had flown regularly you wouldn't have seen this. >> >> The unevenness of the marks also make me wonder if maybe the >> bearings were just slightly loose. That's just thinking out loud...not >> that I'd advise you to do anything different. >> >> Anyway, very interesting. If you scotchbrite those marks, do they polis h >> off? I wonder how deep they go. >> Tim >> >> On 11/11/2017 12:21 PM, David Saylor wrote: >> > Here's a picture of some of the cups I just changed. I change them >> > when they have even just one of the marks on the inner surface. So >> > obviously these are toast. >> > >> > My plane sat in 2016 from April to October. I suspect that may have >> > something to do with these marks. I'll be paying closer attention >> > next year. All the bearings in both MLGs and one side of NLG were >> > replaced. >> > >> > The rollers had corresponding marks. >> > >> > PNs for future reference: >> > >> > MLG >> > Timken LM29749 Cone (the part with the rollers) >> > Timken LM29710 Cup (the part pressed into the wheel) >> > Add "20629" or "2-629" the end of the PN for FAA approved parts >> > >> > NLG >> > Timken LM67000LA Cone >> > Timken LM67010 Cup >> > (as listed on the MATCO drawing) >> > >> > >> > --Dave >> >> >> ========== >> -List" rel="noreferrer" target="_blank">http://www. >> matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributi on >> ========== >> >> >> >> ________________________________________________________________________________
Date: Nov 17, 2017
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some point, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 23 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 17, 2017
Subject: Re: Grounding question
I just wanted to get back to say thanks to all for their input on this issue. I've pondered this a bit and I'm going to do what Bob did and run a #8 wire for the ground to the panel, and let the airframe be the starter return path. This seems like a nice compromise between saving a little weight and having a good reliable ground for the avionics. Kent >>> Tcwtech 10/19/2017 12:46 PM >>> I used the same Akzo Noble primer on my RV-10, all skins are primed including both sides of all lap joints. ( This primer is amazing stuff, does stink like all heck, but really tough and protective. Weve used this on the eight airplanes we have built now over more than 20 years now, and can say it has held up extremely well.) I did not run a separate #2 wire up to the front. All ground current for the starter, alternator and engine sensors flows back through the airframe. I do have a #8 ground wire running from the battery to a ground bus up under the instrument panel solely for the avionics. I have absolutely no electrical issues or noise problems in this airplane. Bob Newman TCW Technologies, LLC 610-928-3420 > On Oct 19, 2017, at 11:58 AM, Tim Olson wrote: > > > +1. I ran an independent #2 ground. > > That said, with the number of rivets in the airframe I'm sure you'll be fine as long as you ground to something with a lot of rivets in it. > I just wanted as low a resistance path to my forest of tabs as > possible. > > Tim > > >> On 10/19/2017 10:42 AM, Phillip Perry wrote: >> Ditto >> Sent from my iPhone >>> On Oct 19, 2017, at 10:35 AM, Shannon Hicks > wrote: >>> I used a forest of tabs mounted to my firewall with a #2 (I think) cable run from there all the way back to the battery ground in the tailcone. I'm not sure if it was overkill, but I have had zero issues so far. >>> >>> I think the plans ground path is through the skin to the battery tray where you ground the battery. >>> >>> http://www.bandc.aero/grounding-supplies-battery-cables.aspx >>> >>> Shannon >>> >>> On Thu, Oct 19, 2017 at 10:27 AM, Kent Ogden > wrote: >>> >>> All, >>> >>> I have a question/concern regarding a ground return to the >>> battery. I have primed all my parts and skins with the Akzo Nobel >>> 2 part primer, which is awesome stuff though it's a smelly pain to >>> work with. All skin overlaps have been primed on both sides of >>> the overlap, and this stuff is not conductive at all so the only >>> electrical path is through the rivets and the small area of the >>> rivet hole that doesn't always have primer covering it. On the >>> outside of the plane the rivet heads have contact directly with >>> the unprimed skin so it's really the inside skin where there is >>> minimal area in electrical contact. >>> >>> I am concerned that using the skin as a ground return to the >>> battery may not provide an excellent ground path, especially for >>> the large currents needed for engine cranking. I would really >>> rather not have to run another heavy wire to the front of the >>> airplane for ground, but I will if necessary. >>> >>> Has anyone else faced this issue and had a problem (or no problem) >>> using the skin as a ground return? Also, where/how have people >>> connected the battery ground to the tailcone skin, do you use a >>> piece of brass or copper buss bar riveted to the bottom skin or >>> something like that? >>> >>> Thanks for any suggestions! >>> >>> Kent Ogden >>> #40710 ultra slow-build :) >>> >>> >>> > > List Admin. ________________________________________________________________________________
Subject: Intersection Fairings and Oil Cooler Valve
Date: Nov 17, 2017
Just finished my first condition inspection and want to do finish some items while plane open and though I might get some input.... 1. I still have yet to install upper main leg intersection fairings - for attachment to fuse bottom do you all you use the self tapping screws as in plans, rivnuts, or another clever solution? 2. I am installing an oil cooler valve - how did you all attached to oil mount? (clamps, screws, etc?) Thanks Matt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=475187#475187 ________________________________________________________________________________
Date: Nov 17, 2017
Subject: Re: Intersection Fairings and Oil Cooler Valve
1) Self tapping screws. Will probably change to nut plates at some point if they strip out or begin working out with vibration. 2) Mine is mounted on top of the oil cooler plenum. Then the scat tube attached to it. The butterfly valve is secured with LP4-3s. It does need to be secured otherwise the push cable rotates the valve around instead of operating the valve. Sent from my iPhone > On Nov 17, 2017, at 7:36 PM, mhealydds wrote: > > > Just finished my first condition inspection and want to do finish some items while plane open and though I might get some input.... > > 1. I still have yet to install upper main leg intersection fairings - for attachment to fuse bottom do you all you use the self tapping screws as in plans, rivnuts, or another clever solution? > > 2. I am installing an oil cooler valve - how did you all attached to oil mount? (clamps, screws, etc?) > > Thanks > Matt > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=475187#475187 > > > > > > > > > ________________________________________________________________________________
Subject: Landing Lights
Date: Nov 18, 2017
What is the choice for landing/taxi lights in 10's these days? Has anyone installed Van's or others LED lamps? I had some HID lights but they were running hot and have failed so I need to try something else. The HID's I had in there were the MR16 configuration since they would fit in place of Van's original wingtip lights. I replaced Van's lights with the HID and they were really bright I think just too hot for long life. Also having trouble finding the lamp I need. There is an RV-12 here that has the LED cluster in the wing that seems OK. But I'm reluctant to cut open the wing.... I found some LED lights down at Lowes in the MR16 package and they will fit right in but they are not very bright. 50W and 700 Lumens is the brightest I could find. Looking for more light. Albert Gardner RV-10 N9914RV Yuma, AZ ________________________________________________________________________________
From: Bruce Breckenridge <bbreckenridge(at)gmail.com>
Date: Nov 19, 2017
Subject: Re: Landing Lights
I pulled out all the HID brackets and put in a new homemade bracket for the Baja Designs Squadron PRO LED fixture. It used the same mounting holes as the previous bracket. VERY bright. Over 4000 lumens. Of course, I'm still in construction mode, so all I know is that it really lit up the hangar! A bit less weight as well. Bruce Breckenridge Wings... On Sat, Nov 18, 2017 at 8:24 PM, Albert wrote: > > What is the choice for landing/taxi lights in 10's these days? Has anyone > installed Van's or others LED lamps? I had some HID lights but they were > running hot and have failed so I need to try something else. The HID's I > had in there were the MR16 configuration since they would fit in place of > Van's original wingtip lights. I replaced Van's lights with the HID and > they were really bright I think just too hot for long life. Also having > trouble finding the lamp I need. There is an RV-12 here that has the LED > cluster in the wing that seems OK. But I'm reluctant to cut open the > wing.... > > I found some LED lights down at Lowes in the MR16 package and they will > fit right in but they are not very bright. 50W and 700 Lumens is the > brightest I could find. Looking for more light. > > Albert Gardner > RV-10 N9914RV > Yuma, AZ > > ________________________________________________________________________________
Date: Nov 19, 2017
If you want insanely bright lights you can get a Duckworks kit and the Baja XL80 light. 9,500 lumens each. Its more expensive, slightly heavier than an HID setup, draws almost 6 amps, but its so awesome! The HID looks like a candle next to it. :) Lenny > On Sat, Nov 18, 2017 at 8:24 PM, Albert wrote: > > What is the choice for landing/taxi lights in 10's these days? Has anyone installed Van's or others LED lamps? I had some HID lights but they were running hot and have failed so I need to try something else. The HID's I had in there were the MR16 configuration since they would fit in place of Van's original wingtip lights. I replaced Van's lights with the HID and they were really bright I think just too hot for long life. Also having trouble finding the lamp I need. There is an RV-12 here that has the LED cluster in the wing that seems OK. But I'm reluctant to cut open the wing.... > > I found some LED lights down at Lowes in the MR16 package and they will fit right in but they are not very bright. 50W and 700 Lumens is the brightest I could find. Looking for more light. > > Albert Gardner > RV-10 N9914RV > Yuma, AZ > > > > > =================================== > -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > > > ________________________________________________________________________________
Date: Nov 19, 2017
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 19, 2017
See below. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Nov 17, 2017, at 8:36 PM, mhealydds wrote: > > > Just finished my first condition inspection and want to do finish some items while plane open and though I might get some input.... > > 1. I still have yet to install upper main leg intersection fairings - for attachment to fuse bottom do you all you use the self tapping screws as in plans, rivnuts, or another clever solution? It varies. Pointy screws work fine. > > 2. I am installing an oil cooler valve - how did you all attached to oil mount? (clamps, screws, etc?)Pop rivets. > > Thanks > Matt > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=475187#475187 > > > > > > > > > ________________________________________________________________________________
Subject: Elevator Pushrod Priming?
Date: Nov 19, 2017
Has anyone primed the inside of their elevator pushrod per Van's recommendation? If so, any quick and easy methods anyone's discovered? I actually can't imagine why this is a recommendation unless you live in a salt water climate. Thanks in advance.. Bob O. ________________________________________________________________________________
Date: Nov 19, 2017
Subject: Re: Elevator Pushrod Priming?
I did. Using a string I pulled some pads back and forth through to scuff, did the same with some rags to clean, then soaked a rag with primer and pulled it through a couple of times. On Sun, Nov 19, 2017 at 8:49 PM, Bob Orre wrote: > Has anyone primed the inside of their elevator pushrod per Van=99s > recommendation? If so, any quick and easy methods anyone=99s disco vered? I > actually can=99t imagine why this is a recommendation unless you li ve in a > salt water climate. > > > Thanks in advance.. > > > Bob O. > ________________________________________________________________________________
Date: Nov 19, 2017
I primed mine per the instructions. I don't think it's so much "salt water climate" as much as that no one is ever gonna look in there ever again. And if it somehow did fail, it would be really bad. So it should be as reliable as possible. --Dave On Sun, Nov 19, 2017 at 5:49 PM, Bob Orre wrote: > Has anyone primed the inside of their elevator pushrod per Van=99s > recommendation? If so, any quick and easy methods anyone=99s disco vered? I > actually can=99t imagine why this is a recommendation unless you li ve in a > salt water climate. > > > Thanks in advance.. > > > Bob O. > ________________________________________________________________________________
Date: Nov 19, 2017
Keep in mind that the parts for the pushrod are not Alclad, and thus do not have the corrosion resistance of the exterior skins. I wouldn't be surprised if the tube and end caps are different Al alloys. Van's limits primer recommendations to a very small portion of the kit, to just those parts that have some risk of corrosion in damp air. On 11/19/2017 9:16 PM, David Saylor wrote: > I primed mine per the instructions. I don't think it's so much "salt > water climate" as much as that no one is ever gonna look in there ever > again. And if it somehow did fail, it would be really bad. So it > should be as reliable as possible. > > --Dave > > On Sun, Nov 19, 2017 at 5:49 PM, Bob Orre > wrote: > > Has anyone primed the inside of their elevator pushrod per Vans > recommendation? If so, any quick and easy methods anyones > discovered? I actually cant imagine why this is a recommendation > unless you live in a salt water climate.____ > > __ __ > > Thanks in advance..____ > > __ __ > > Bob O.____ > > ________________________________________________________________________________
Date: Nov 19, 2017
Dave Saylor wrote: > I primed mine per the instructions. I don't think it's so much "salt water climate" as much as that no one is ever gonna look in there ever again. And if it somehow did fail, it would be really bad. So it should be as reliable as possible. > > --Dave > u] +1 Same here. After primer had cured, just before inserting rod ends, I also sprayed LPS-2 in there, just for added measure. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=475300#475300 ________________________________________________________________________________
Date: Nov 20, 2017
Yep. Capped off one end and filled the tube with acid etch. Dumped it. R insed it. Allowed to dry. Then recalled it. mixed about a cup of primer, poured it in, and rolled the t ube around. Looking inside with a flashlight, you can see where primer is and isn=99 t. Kept moving it around until it was all coated. Pretty easy and nothing to fret. Phil Sent from my iPhone > On Nov 19, 2017, at 7:49 PM, Bob Orre wrote: > > Has anyone primed the inside of their elevator pushrod per Van=99s r ecommendation? If so, any quick and easy methods anyone=99s discovere d? I actually can=99t imagine why this is a recommendation unless you live in a salt water climate. > > Thanks in advance.. > > Bob O. ________________________________________________________________________________
Date: Nov 20, 2017
I would argue against using acid etch/alodine in any area that you can't access afterwards. I think the risk of not fully removing the acid exceeds any risk of poor bonding of the paint. The area will never be subject to any abrasion or scratching that tests paint adhesion. The primer itself contains sacrificial material to react with any oxidizing moisture. Of course I don't base in a corrosive atmosphere of coastal areas, so I'm certainly biased. If we aren't careful, we could re-ignite primer wars. ;-)) On 11/20/2017 5:33 AM, Phillip Perry wrote: > Yep. Capped off one end and filled the tube with acid etch. Dumped > it. Rinsed it. Allowed to dry. > > Then recalled it. mixed about a cup of primer, poured it in, and rolled > the tube around. > > Looking inside with a flashlight, you can see where primer is and isnt. > Kept moving it around until it was all coated. > > Pretty easy and nothing to fret. > > Phil ________________________________________________________________________________
Subject: Door lock for cabin doors
Date: Nov 20, 2017
Any suggestions for doors with Sid handle. Id like to install locks on both doors. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=475304#475304 ________________________________________________________________________________
Date: Nov 20, 2017
Fair enough. I just flushed it and flushed it and flushed it. Thinking about it more, I even alodined the thing too. I had a couple of 6-8 ft sections of PVC pipe. One end was opened up, the other had a fitting where I mounted a hose bibb. I could fill one pvc tube with acid etch. The other with alodine. Then I'd drop the long pieces inside the pvc tube. When done, I'd open the hose bibb and recapture each solution back in it's original container. Worked pretty well and I think they're still out in my garage. On Mon, Nov 20, 2017 at 7:33 AM, Kelly McMullen wrote : > > I would argue against using acid etch/alodine in any area that you can't > access afterwards. I think the risk of not fully removing the acid exceed s > any risk of poor bonding of the paint. The area will never be subject to > any abrasion or scratching that tests paint adhesion. > The primer itself contains sacrificial material to react with any > oxidizing moisture. Of course I don't base in a corrosive atmosphere of > coastal areas, so I'm certainly biased. If we aren't careful, we could > re-ignite primer wars. ;-)) > > On 11/20/2017 5:33 AM, Phillip Perry wrote: > >> Yep. Capped off one end and filled the tube with acid etch. Dumped >> it. Rinsed it. Allowed to dry. >> >> Then recalled it. mixed about a cup of primer, poured it in, and rolled >> the tube around. >> >> Looking inside with a flashlight, you can see where primer is and isn =99t. >> Kept moving it around until it was all coated. >> >> Pretty easy and nothing to fret. >> >> Phil >> > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Nov 20, 2017
Subject: Re: Door lock for cabin doors
It's messages like this that make me remember-that-I-forgot... to install any type of locking mechanism when assembling the doors. Standard factory latch and handles with the Plane-Around aftermarket safety latch kit. I don't think I want to run a bike cable lock under the belly around both handles. Wondering: do I even care about locking the plane (easy enough to break into even if locked, and they'd damage less if the doors simply opened...), and if I do care, are there options installable from the outside - which it the only side not yet finished and painted. On Mon, Nov 20, 2017 at 8:42 AM, whodja wrote: > > Any suggestions for doors with Sid handle. I=99d like to install lo cks on > both doors. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=475304#475304 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Nov 20, 2017
Bill, your point about damage is what I thought too. The stuff inside is ex pensive but insured. Damage to the plane could ground me for a long time and I=99m not in the mood to rebuild doors and windows. To me, locks wil l only serve to cause more damage if someone really wants your avionics, and only will stop the casual small time thief. I installed a car alarm in the door pin circuit. My doors are never locked b ut if I arm the alarm with the key fob I get the =9Cchirp chirp=9D and if someone opens the doors they get a loud wailing horn. That should b e plenty to drive away the casual thief, and maybe even the guy who really w ants my avionics. In fact, if someone can break into your locked or unlocke d plane in silence, I think you=99re more at risk than any other situa tion. But at least I don=99t HAVE to have damage done to the plane just beca use someone attempted the theft. Easy and cheap, too. Tim > On Nov 20, 2017, at 10:21 AM, Bill Boyd wrote: > > It's messages like this that make me remember-that-I-forgot... to install a ny type of locking mechanism when assembling the doors. Standard factory la tch and handles with the Plane-Around aftermarket safety latch kit. > > I don't think I want to run a bike cable lock under the belly around both h andles. Wondering: do I even care about locking the plane (easy enough to b reak into even if locked, and they'd damage less if the doors simply opened. ..), and if I do care, are there options installable from the outside - whic h it the only side not yet finished and painted. > >> On Mon, Nov 20, 2017 at 8:42 AM, whodja wrote: >> >> Any suggestions for doors with Sid handle. I=99d like to install lo cks on both doors. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=475304#475304 >> >> >> >> >> >> >> ========================= >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= >> >> >> > ________________________________________________________________________________
Date: Nov 20, 2017
Very simple solution for at least one of the doors.... both, if in a pinch and you want to crawl thru the baggage door.=C2- I made the part out a te flon type material, but could be made out of anything.=C2- You just inser t the small end into the slot on the inside of the handle, and then slide i t so that it keeps the door release from moving.=C2- See pics. Don McDonald1,000 hours and still strong as ever! From: whodja <whodja @gmail.com> To: rv10-list(at)matronics.com Sent: Monday, November 20, 2017 8:15 AM Subject: RV10-List: Door lock for cabin doors Any suggestions for doors with Sid handle. I=C3=A2=82=AC=84=A2d like to install locks on both doors. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=475304#475304 S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. /9j/4TgmRXhpZgAASUkqAAgAAAAMAAABBAABAAAAkA8AAAEBBAABAAAArAsAAA8BAgAIAAAAngAA ABABAgARAAAApgAAABIBAwABAAAAAwAAABoBBQABAAAA2gAAABsBBQABAAAA4gAAACgBAwABAAAA AgAAADEBAgAOAAAAuAAAADIBAgAUAAAAxgAAABMCAwABAAAAAQAAAGmHBAABAAAA6gAAACYDAABz YW1zdW5nAFNBTVNVTkctU00tRzkyMEEAAEc5MjBBVUNTNkVRSjEAMjAxNzoxMToyMCAxMToxNzoz MgBIAAAAAQAAAEgAAAABAAAAGgCaggUAAQAAACgCAACdggUAAQAAADACAAAiiAMAAQAAAAIAAAAn iAMAAQAAAMgAAAAAkAcABAAAADAyMjADkAIAFAAAADgCAAAEkAIAFAAAAEwCAAABkgoAAQAAAGAC AAACkgUAAQAAAGgCAAADkgoAAQAAAHACAAAEkgoAAQAAAHgCAAAFkgUAAQAAAIACAAAHkgMAAQAA AAIAAAAJkgMAAQAAAAAAAAAKkgUAAQAAAIgCAAB8kgcAYgAAAMQCAACGkgcAFQAAAJACAAAAoAcA BAAAADAxMDABoAMAAQAAAAEAAAACoAQAAQAAAJAPAAADoAQAAQAAAKwLAAACpAMAAQAAAAAAAAAD pAMAAQAAAAAAAAAFpAQAAQAAABwAAAAGpAMAAQAAAAAAAAAgpAIAHgAAAKYCAAAAAAAAAQAAABEA AAATAAAACgAAADIwMTc6MTE6MjAgMTE6MTc6MzIAMjAxNzoxMToyMCAxMToxNzozMgCaAQAAZAAA ALkAAABkAAAA8P///2QAAAAAAAAACgAAALkAAABkAAAArgEAAGQAAABBU0NJSQAAAAAAAElJQ1NB AAAASUkAQTE2TExJQzA4U00gQTE2TExKTDAyR00KAAAAAAAABwABAAcABAAAADAxMDACAAQAAQAA AAAgAQAMAAQAAQAAAAAAAAAQAAUAAQAAAFoAAABAAAQAAQAAAAAAAABQAAQAAQAAAAEAAAAAAQMA AQAAAAAAAAAAAAAAAAAAAAAAAAAJAAABBAABAAAA8AEAAAEBBAABAAAAdgEAAAMBAwABAAAABgAA ABIBAwABAAAAAwAAABoBBQABAAAAmAMAABsBBQABAAAAoAMAACgBAwABAAAAAgAAAAECBAABAAAA qAMAAAICBAABAAAAdjQAAAAAAABIAAAAAQAAAEgAAAABAAAA/9j/xAGiAAABBQEBAQEBAQAAAAAA AAAAAQIDBAUGBwgJCgsBAAMBAQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKCxAAAgEDAwIEAwUFBAQA AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWm p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6EQACAQIE BAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZ GiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SV lpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4 +fr/2wCEABUOEBIQDRUSERIYFhUZHzQiHx0dH0AuMCY0TENQT0tDSUhUXnlmVFlyWkhJaY9qcnyA h4iHUWWUn5ODnXmEh4IBFhgYHxwfPiIiPoJWSVaCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKC goKCgoKCgoKCgoKCgoKCgoKCgoKCgv/AABEIAXYB8AMBIQACEQEDEQH/2gAMAwEAAhEDEQA/AKEV ypODkDtVjjAOePeoGRyTRp1Iz9aIpfN5A+XsfWgZJQKACloAKD0zQAAgjIpaAEo+lAC9aQUALRQA g6UooASigAooGFFABRQACl7UAFOFABS0xC0vagBRxS0ALmlpiAU4UAAPNOBoAUNinB6AHbqXdQAu RS5oAAwpQc0ALSigBaBQAtLmgQtFAC0UAeeJK69GqRrycjHmU7AIsxwA3r1q9BqG8Kjcdsik0M0A TjKnd+NJNOsEReQH6VIx6NvjDgEAjPNLQAvWkPTFACjhcUUALSfSgApaACigApKAFpKBhRQAUUAF FABS0AHFKKADNLmmIdS0AFAoAUGloAdil5FMQUtABSigBaUGgBQ1O3UAAanBqAHBhTgwoAXINLxQ AUooELmlzQAUooA84opgFLz2NAE0VzNEQVcgirQ1N2wJUVhSsO5LFqiDhhxUg1GJiOtKwXLUUySf dNSZ5xSGKeKPegAooAKM0AFGKAAUooASlFAwFGKADFJQAUUAFLQAUA0AB5pR0piFFKKAFpRQAoNL mgAzSg0CFzSgmmAUuaAFBooAUUtABS5oAXNLmgQoOKcGoAXfTg9AChhinA0ALmlBoA85opgLRQAU UAJS0AOSR1PDH86tQ3zpyzMaQFkal03HPqMYq1FeQybVVufelYosZB70vvSAKKAAUUAFFABSUDFB oFAC0lABR2oAKWgAooEFLTAKdmgApaAFoFACiloAWgUALmimIUGloAUUUALmlFABmlzQIXNHWgBf rRQA4GlDUwFDU4PQB5+GAXGOfWkBoAM0Z96ACigAooAWjNABShiOhoAngvJos4Y1ZTVJB94bqVhl hNUiYfMMVJ9viIyuT9KVh3LKElck9admkMKKACigAoHpQAUtACUe1ABRQAtFMQUuKAFoFAC96M0A LQKAFB5p1ABmigBaWmITFOFAC0ooAKWgBaWgABpaAAUtABSimAClzQI5Q26d0H5VGbVP7o/Wlcdh Psqf3ePY002i9gR+NADWtPRjTTakfxfpTEIbZ+x/SmmBx6fnQAeRLjO3P0NNMUg/gNACFXHVSPwp OfSgAz7UbqADINKMDocUATLdTL/y0OKsQ6g6sA3NJody5FfxN1bH1qylxG2MOD9DSGPV1J604c8g 0hgR60YoAQlhSjnrQAtJQAUUALQKAClpiCloAPrS0ALRQAopc0AFKKAFoFMQtLQAUuaAEzTgaAFo oAUUtABS0CFooAKX8aYHMi4XGCDSiVKkoXfGerU792ejAfWgBNsf94UKgPRhQAeVxwR+dIUPfNAh pTtgflSGL2/SmAnlegpPKoAaYR3A/KkaFOu0flRcBpt4z/CKb9mQ9F/Wi4DTar2zTfsvuaLgJ9mb 1xQIJF5D4oAkVpx0b9alhu7mPPOR9aQFmPUmHEsRPuKe2oISAgYeuR0osO5bjkV03bh+Bp2QehpA DbgPlAJpw5HNAxMZowaACk5oELS0AApaYBS0AFLQAtAoAKUUAOwaOP7woAUYPejvTELS4oAQ0c9q AHCloAWloABS0CCigBaKAObOMdBSEAjBA/KkMURr3UU1oo8dKAEMSHgA0eSMfeNAw8pu0hpSkuPv gEUCDbKOd4ak3TDIwpoAPNmBwI8/SjzXz/qjmgAM/wDeQj8KBcJxkUAO82Kl3RH+KgYuIieGpNqd iKAE2DPFGznGaBCeXx/9akMXtQAgTPak2D0P4UAJsIGBkD604GQDiRqAHrcXK9JD+VOF7cAfeX/v mgB63846qh/Onf2g/eIfgaB3FXUR/FCR9DThqEX8SOPwoC48X1uepYf8BNOF3bn/AJafpQA4Twnp Iv508SRnpIp/GgBwwehFO2n0oAMUEUALRQACkkkWJC7dqAKRDXTfvJdoPRQcCqk9t5ZOTnFMRVIc A7Wx+NAuLhDgSuP+BUxEi392vSZvx5qRdWvF6uD/AMBFICVNbuB96ND+lSrrv963H4NQBKmuQH78 bD6VMurWbdWZfqKBk8d7av0nT8eKnV435SRD9DQA7BooELRQAUtMDnuO4ox6j9KkoBtzSEA96AE2 cfepcUAIFOeOTQcmgBOeho5oAUGgsfWgBCcjH9aTAxjFAhNqYwQKPLTuoxQA0xpnIFIY16jNABsP ZjSFGx940AKBJ13UuZOoINACbpPWl3uO2aBjfMY9VxS+aB1U0CASg9jRvUdaAAMpHymjIzjNACgL 60FR7UAGz2pNo9KYCFR6Um0d6AAEfwtj6U5Wl/hkcY/2jQA4XNwpwJmP1Oact9dL/GD9RQA7+0bk c4Q/8Bp66rMBhoUP44oAUawcfNb/AJNSz3PnxggFcjoaQCx2f2o7Q5yB2rQg0NzGQ8jcjj2pgZF9 pt3bOQYmZc8Mozmqe2VR8yN+IoAbknquKbkZwc0xDscdqTAHegBStNwPSgA20oJHKkg/WgCeDULu AjbKxHoTkVuadqsV5+7cBJvT1oAvkYpKAFooA5rbJjqKQmUcDBqShd0npR5rj+DIoABLzyuKPNGe VNAAJVPYilEiE9aAF3J03UFgf4hQAduopcZB5H50AJtbHFG046CgQmOOKTr60AHPpRmgBOvrRQAu fek6cUAFJQMXNJmgQhA60uB6A0DEKr2AppUUCDYMdx+NAT/aNABtYEfNRhuzUAJmT1Bpd0gHIBFM A3tjlaWOUofu5oAdI4kOQuDTKAEpDQAAZYZ6VYX53CgUAbNmnkKNvXvWtbgujO0hQAduaQya3jEw YSzHb2xwaDpMDglZmx7800IjfQY3584H6oDUEvhuNxwYz7lcUxXKz+EweQyZ/wB4/wCFQP4SmP3W QfjQBWfwrfL93afxqvJ4c1JCf3Bb/dOaAK0mkX8f3raQfhUBtLgdYnH4UANa3lUZKED6VEVdDvQE MOhoA6fSrpru03SDDqcGrVABS0AYO00hQ1JQbaCKAG7f0o2jOaAAqD2pDGp6DmgBvlD0pPKHYUAH lLnJJppjOeGNAChH/vGk2v2bmgQu2QDsaTLj60AG9/QUokI/hzmgYebxytBkUj7pzQABlPrRujoA Mr2NKFU5+bFAAVHZhSbPcUCDa3pSbW7CgBMMCMrQeD0oAM+lJkd+tACZGTzTs570AJQDTAOc9KOP cUAHbrSUAJ2pDwMnpQAQtvyQOPWtCwjBcse1JgjUjB3AVoSvtiSJRyeTQNl23jwiqF+bGTVoRoFw RVEjQi5JU5pdre/50CBvMHO44pDJIO4/KgBRM39zJpTOR/DQMUTjuP1pVZHONoz9KAHNFGww0ake 4qnc6VYyxndboPcDFAGDBDHAZFjQIu48CphQMKKBGEJEHG7FBbPRxUFBhucMppdpxyR+dABggEY/ HNNxTADn0IpOtABQDzQAcYzSZBoANoxScUALxng03AoAMAngUbRmgBCtJtFACbaNooAQoDSbBQAb aNuBwTQITa4HDGlG/wDvUxiEuDwRRuf60AKHfpijf6rmgQbxz8g/Kmlh6YoAUslJlCT834UABx0z QuAeTQBYEKuhIcAjoPWoMEE5P4UAB5GKinXMZAoAZBL5UfStazJKAoQd3pSY0bOmKC+5zwKvQIJr h5OwPFCBmnEuOR1xUoyTyKokTIHAFBZR14oEDFSMZpAEJzkGgBQq54pSq+lACbF/uigKAcgYoAdU F3KI4z6mgZz/ADuJ9TS0DCikBgeQh/h5pTbKR0pDG/ZxzgkUeQ394/nQAnkuD98/jRsl/vUABEwH UY+lJibrgGgA3SjrGDR5j4+5g0ABmP8AFGaTzU7qRQAeanpxQHhPViKAF/dZ4alwh/jxQAgUdpBm l2n+8v50ABVx6Um1wMmgBCj9hSYfPK80CF+bH3TTd3tQMCwpNy460AG5fWlyPWgA4I5NAx0DCgBc D1o20AJtpCKAE2+opNv4UxC7R6U3YB2oAAuOhP50tABQqFsjHFAEEqAZA/Kktrh4HG08Z5FAHXab Ml1B+5HTjpzmr/2gxwMsMZBHygsOtCBkwurgr5cSncoHzHoT3qeSa5RGwqvxxjg0xEqSNgZHOPrT nbI5HSgBA4I4ANP29gtADSpGMDpSlqAFDn0p4OfagArK1WUhyvYCgDPQZFMmmhhYK7gMTjFIZKVp AKBGU0DZ4/nSeVIO361JQ0o4PKmj5h/B+lAxMMf4T+VBDf3TQIbyO1LlfSgBAw70HZ1oAMKfSkKp mgBPLU9MUGEH0NMCM26nPy0fZkx0oAabZO2aT7P7mgBDA2cBjR5Tjo5oANsv97NJiYZ5GKAD971x QWkx90UAAkYcbKTzB/FH+lACeYp4KHH0o3wnqCKAAiE+v40bYv7xFACCNAQRLS7D1WSgQmx/74Jp dsnf9KAE+cdqQu3pTATeRyVOKUPz04oAQMCKXIoAODUig4zg4NACiENzTWsGIJXFAy7Y2d3bruQq QexOK0xf30UfNvGQBj71AiBL+5yW+zvk9w4qVdRcHLW82fYg/wBaAJ11YgDMU6/VM/yp/wDbMLAq /mLnuUIoAli1mzRNisAvvkVMmsWx4WVf++qBEg1WLH3gf+BCl/tOPGduT9aYCjVBx+7P50v9pR7+ h980APi1OGR9pBBJx9Kxdcv4i8jITgcbh3oAq6ZfpcQHedrr1zWDfzeZeSMG3Dd1oGdFpFz9oslz 95ODVvvSETNZqfSmfYFpFDWsAFJHX2pv2A7AecnrQAz7HJ6kfhQbRwOD+YoGMNq/fH5Uw2x/uj8q AEFpkf6taiNmvQqfzoENNmCOVIppsh1y1AEbWjdunrij7I/UP+QoAY1tJjrQYJgM5oAYI5Sfu04p KO1ADdso6rQVk7qaAEw2OFppYgYZSKAGiQetLuUHk0AG+P1o+QjFACYj7UmxfQGgBCq0nkqeSKBC GBSegpPIHY0AJ5XuR+NJ5Z7SEUwAK/8Aeo2SD+LNACHzfb8qPn/uigBpDY5Sg9eVoAAefumrEc6q oDqce4oAtWwEoyFwO3FWvL2ipKNCKDNsrMPepfsMvlgnknnFMQ/7MwiyYhx1pYrTPOwA0CJfsyj7 wwaQWxaUEqNoHSgCY2cTDmFfypr6TbN1hXn2pgRP4fs35EYH4VXk8OQBSY8qfbIoC5VbQpIxkSPz 6OahfSLuMArNNyeOaQDG0/UVjZzcsAvqOtYl680h2STbh6AYpgRwymNsjt1+lRTrsfcDlH6GmI1N CvUhzAw5Y9c1uC4iJwZFz9aQGxthPIkYe2KcIoz0m/Siw7gbbv5y4+lL9lbs60WC4n2aUd1P40n2 abso/OiwXE8iXP8Aq/5UnlPz+7P5UrDuNWBsfNHz9Ka0S94/0oAb5Kd1xSNbxnpx+NACfZ02kc4P fFJ9kUdDx9KAGPZqe4/Km/YlPpQA02Iz0BpDYei0AMNi2eUNMexY/wAJoEMNljuT9RUb2ikYIH40 xkZ0xCM8fhUR0oHp/OgCNdLcnC84pf7Mk9DQA19NcYwDxTPskoUgKxNICJ4JVUgxMT61XaOY/wAL UwEKyAY2uPekBccH+dAhVzj1pc0AJuPvSEt1BxQAhkcDrSLI/fFABvf6mly3cUwAsxHAp6Ssjgsm QKQGjDqMAwDGwP0qZb23dx85x9KVh3NGLUrYlQzjavY8VZGpW/8Az1X86dhDxfwtwJV/Oni8gx/r RmgQpu0zkAkDvik/tGBQAWC/WgZINStyeZFH1qT+0YMY8xfzoEPF9F0DA0v22P1H50ANku4sA5Bq tLqMaIemBQBg6lqkkuQG46ACsORSW3HnNAyBl2tilUjBRx8jfpTERsBFJgNnHQ0qyP8A3jQB6EEY 9KaUYnmmIUgjjJ/OgIcnaT+NAAC8bckkHqKR2cEbXbaenNACrLJ0MjY+tSpLIfuufzpAL9omDYLY /Cg3UwOOPyoGL9qkABZFPvilFzn70SUAKZ42OZIt2Og7UokhKlvJIGccUWAQvb9CjD6Gj/Rj3cUW C4AW/wDfb8qXZCRxN+YosFxBCh6Tqfwpfsx7SJSsO4G2k/vKfxphtpR0VT+IosFxPs0neMZ/CmG2 fvF+lAXG/ZjnmE/kab5AweCPzpARi3jyQGPHXmnCAqcoxHvQMcYi3Pp3x1qNoQSTsTp6UACQwhRv tY2I98Z/Sh7azI/48/yYUAV57Czd4xHblR/Gc0x9MspHwokRc4+7k0ARzaTZhgsbOcnHK4x71DPp ECNtE4YD2xTArNpcZOPOA/GmNo/dZUNAhBpNzk7Np+lR/wBn3O7Crk+1FwGPY3QzlOnvTZLG5QAt CxyO3NMBn2Wcf8sWo8mZG5iagBzFlPIIz7UoBJGB+lMQ45U8j8aNxHOTQBbh1K4jj2bg6+jDNKdT mztOwf8AAaVgHjVJApDRQvn1FRC/XvbxH8KLAOF7F0Nsv4NSG7hLf6pgPQOaVguPF5b/AMQlA9N5 qve3Fu6ZgZ8ntuJ/nRYDOLuRksTTSzd8imBG3XpSEetAA43oFJ5HQ1DyDg0AehF5/vBulIJ5lGDg n3oEKZJjyQuAPSkW6fvGPwoAd9r/AL0XH1o+1R5wYzj0BoAX7XB3RgfpR58GQfmAPtQBIt1bspWQ nGeCR0pxkt/4Zcg+tACF48bfNG3tSgJjG9fzpgG0Y6jH1oCE9D+tACFTn/69Lt7EYNACbecUbT2F ACEdiKNvtQAvJ65o+YcA0AG+ZDkMaka5kZcpkHv6UAKtzJjk/p0o+0yDjcG9wKQCiduyJz1460NO 2MmONvbFAxq3CYOYFFKssPQwgD2osFxS0BP+rb8DSZtuh3rRYLhstz/G34gUeTBjiX9KLBcQ20Rb ImXPuKDYh+d6n8aVh3EOnA9x+dNfTmxgYP5UWC5DJpkh+6MfTFL/AGfLuyF2kDgg0WC5E9hLz8rZ 9s1G1jc7fmJz70AQta3K8bAQPSl8mbAwgP1FADVV0OXgDexHFIAv8UIzTEKYYiOUFM+zoVAK8dqA EW1iB9DTZ9PhlYEscjvigCFtJUEYkIz60xtIZuVkH1NADG0t1485PpTP7KnPR1NADTpVwO4NNbTb lR8qimA3+zbkjJQCo/sM+0nZxQA0WcwXLRsfwqNreXkGIj6ilcCJoWDYII/CoJomUknOaBHpBjKY O3OfakKF+SnP0oAa8ZbAGaRrVs4B5oAieBc4JFKkAVmLJvAHBB4FAxhtyDgjmhrV8A4wD60AJ9nA HNH2XJ49KAGtansB+dJ9mbJAHH1oADAw9cdKURyKfvt+dACFZlGdxJozN13GmIdvnxnzOfel8+4H 8QNACiebuATS/apR1RaAAXjd4xSm8U/8szn2NACi9j6MhxS/a4BwAwoAU3Vv0yRThcW39/H4UAL5 0HaRfzoLRHlZF/OgBRs7up/GlKRn7rg/jQAFOOtCq2CAoIoAQgg45oG5aAFK55xSBdrcLn60AOC8 9P1pTnH3m/OgByu+3Bds/WnB5cZV8+xpAAkk7SDNJ9plHHyn8KBii7bugP0pRdITzHQAvnwZ5T9K XdbH+Ec+1ACGK0b+FKT7Jak9R+dADTp0B5GajbTAekzigCM6OOolJPuaZ/ZDkcvg/WgBv9jyDkOK RtMuP4Sp/GgBh0+8z0B/GmPZX3aP9aAIfsV8o4hP50ht7wIf3JPqM0ADw3Ix+5bH0pjfaFTJiGP7 pHNAytIrv963/Sql1Yl4i4Tbj1oEdqbyPPzA/lSfaoj0JB+lADhNB/eH1xSiaAknzFz70AIoi2EB kOetLsQqThc47GgBEjRYmO3nGKRolAHDHAoAesKbfukZoeEDBTIPSgAWDj5jTfIIcdCKAB4AMcDG RSNbjnK5B9KAEFv0JTIA6Zpvl8DMbAdetADTb8Kyg4759KHgUnIU4HqKBDTajqCPypv2Y8cDGKBh 9nXqWXHvUf2cFmyAAPQ9aBCG1BUcHnpmkezIXhTTGR/ZG37ChB9TS/Yz6Z/CgBrWbdlNBs+OlAhn 2Rj25o+zP0BIxQMTyJccOfzpAs46O350CFP2j++TQst0o4c8UDHCe5/v/pSi6ucdjQIUXk46qppR fOOsQoAcL8g8wgj608agg/5Yt+dAC/boCcmNwaX7bbnqrflQAfaLY9GYfWhbi37vQA8T2x5zSGWD PyvigBPNQfxA/SlEin+IUAO35HDigOw6N+RoAd5jjne350edN2fIoAetxLjnB/Cj7W46qKQDhdnH KfrTlu1I5Ug0DHrcRnuR9RThLGf4hQA75T6Ggop6qPyoAaYYiclF/Kud8X3UdrY+REAHk9OtAGgQ BxSYH40AJx3pCo6jBoAaVAOcU7b6E0AB3dASBQWcdHOKAHB5e8jY+tOEs2ciRqAHC4m/vmnfaZ1P UH8KABrubjIX8qX7dL/cWgBftzg8xg/Q077dx80X60AL9tXGPLOPrSi+iIwVagBRdw8nkfhTluoD wGx+FADZJLd2GXHBz0p4ltyMBkoAUpCQD8vbnNIsUIIAYE5z96gAMSjcynk8Dmk8kiRSCxHfmgB7 xsTlZCBTTG642nOfUUAI0JJGMc9eKRYA0fKrn1AoATySoyAPTBpGhKj7mfdaBCG34+VCM+9NEBVC TGaAHJbZByuPqKabJcEkDI9BQBH9nVjtxyO5FBsxuwxpgIbLHUDHrSGy/wBg/nQA37CM96PsGOoN ADTZD0xTTYN2YGgBhsX7AGmm1fdQAfZX7037O3ocUABidcctRtlX+JvxoAD53ZjRunHegBfOuOma UTzdCBQAfaHB+7TvtT/3KAHfavVCKX7UuPuGgCWKYPyKlWVv4SRSAfHcMc7zjFcH4gvje6hJjlUO BTGjrRcJtwQc0puI89D+FIA86Lqd2PpQZos8NQA5ZIGHLgH60K8Y/wCWi/nQA4eW3/LRfzpdq9N4 oANnqRik2DqvUUABBNKAQOtMQDPpTcEnjigBdvGaXGaAFxik78igBRg9vwNIUGcgc0AP2jHvTCoF ADTgdeKFQZyenqOlAE/2dQm4P/hUKl1Pyuw/GgBfOmB/1hNSC4m/56GgBftMw6kH8KPtUwGAR+Ip AAup+4X8qd9sk9EoGKL5wcMi/gad9tPaLP40AKL0Zw0bA04XkZ6q4+ooAPtkOcHcPqKeLmI/xfpQ AvnxH+MfjSiWM9HX86ADEf8As0uEPoaADy0/u0eWucgfrQAoUCgoD1FADPJTOcUggXvzQAGBDTTa p60AIbVe3Ska0BHHWgBptPYUn2P2FAg+xAjkAU02Q9KAENhnvUF1biP5RQAy0XGcjirGBnimBna7 e/YrByDh3GFrhSS2Sx5NJjR6G0KEgKGz9KTyB3BzQAv2bjPOKQQDqf5UAMa2GRgZz0o8gDkigAMA PPrTTAelAB5LjIyaXypFGQ5H40AASTuzfhQfMAzk0AKxnBA3Gm+ZNyN36UCHGaYAcij7RKP4aYAL mTugP6Uv2pu6frQAC79UNOF4ucmMkUAKbtN33TT/ALZAy7WU/WgBFurccMCR7ilaW1IykmPagBPN iPHmDHvSkxhc71I9jQAZU/xD86MY/iH50ALg0vQc0APCsBlSD6g0zYeTtwaAAoxORj8qAD3GKAH8 kYHX6UgOQeBQA1gD1pQMY9KAEOD1puBn2oAftPpxQoUkjHNACYPYkfjTt8n/AD0b/vqgAEkoP32P 407zphj5j+NIBftMueT+lKbmUfxAj3FAALyQHkKR9Kf9sb+4D+NAxRejHKc+maX7an900AKLtf7j Uou4j1yPwoAf9oixneKBPEf4hQA4SIejj86rXIhkfO4EjtmgCJSFHQYpAec5piOM8T3n2m98pT8s f86yAD0FIZ6gj2u4NvGfcUpNvuPzrzQA5hEzH51AI7GkESg5VgQTzzQBJ5Sbs8ZxxzUawEKc8k5P 40ANe3Yyg44A60/yDtPAyaAI0tyNwI57UG3OdoUHHegBy2o4yOaY0GAcRknpnPSgBGiUNgqc9BTG tjvAwfy6UAJ9mUZ5LY7EU3ysfeBx2GOtAh0lschlxtI5z1FNa3wcED6igBghU+gFKtuD93BpgRvB g42mk8j86BjWtyCVKnI60G1XGQ2KBCfZQeM5oFoBzjFAAbPnvQ1qcfKSKAGfZ5Aepo8mbP3mFAxd k46SMPxoxcr0dqBBuuh0Zvxpwnux1Kke4oAQ3NyOy/lR9rnA5jWgAF7IOsYpRfesX60DF+2j/nl+ tO+3RkcxsKAF+3JnO04qT7XbkYD4+ooEJ9qtzwXx+Bo86EnIcY9+KAHLNCG3bqeTGw3Bx+dADSyk cHNJvHQUAIT68Um4djQA4MCcDGaO9AASSOKBxQAuB6UoAx0oATGKPlHY5oAPpnFRajcLa2bMQAcZ oA4eT95Kznkk5phQZ5pAd32weaTjtQMBwc0p/L6UANJIPDGlDt/fb86AHCaUfxE/jSrPPnPmH86A Hiebr5hoFzMDw5/EUCHC8mz1z+FO+2SjPCmgBftsnXYpNL9vbvGPzoGAvh/zyH5077cuMmM/nQAo v4+6MKPtcBJJVufagBwubbAA/wDQaPOtSRyPyoAV2tX5LLTdlrnO8f8AfVADjFCwwHGfXNJ5K5H7 wEDtmgBxgBKkOcgYFBgbbjfnjHIoAR7divysAT1yKUQYU8KWPtQAw2zEKCF96VYMhgyAYPHPWgQ0 27AYCg59+lPFvhehz9aAGm39j+dKbUN6igBpswPf6Ck+yAnkfpQAjWY7BfyqM2KY+YDn60DG/YRj IIpq2W4kAD86YhPsI9P1pv2DpwfwoADYZ7MPwppsXP8A+qgBjWRU4PX6Un2M9xQAC2k/hYj8aDBK P4moATyZugJOfehoZgcEmgBAkwHGTQfOHagBfMmHbj6Uec/daAF+0S+lH2h/SgB8dwzHB4qdTk8n 86AHADOM8VzviO5LyCFTx3oAxduKQikM7QSJ60oeMnrxQAhYDocilBB6HFACE+/NC++OaAHGjFAC Ed6dg44OT6UwE5FKM0CE707GRkUAIQKSgBeKVcUAJjHSgmgAGCOuKVcKeRke9AAyqRkflSBB1FAC 7O+45oO/s7fnQAeY/aRwf940oeYDImb86AHCaf8A56mni4nP8f6UAL9puAfvKfwpReTAcqpoGL9u f+4KUXzY5jB/GkAov/WI/nS/bhjPlNQA4X0R42vn6Uv2yLODuH4UAL9rg7t+YpwuYT0cUAL5kOfv pSh4s8Mn5igA/d9cj86UKhPB/WgBSoYYIzSCNR2oAPLXJ4HNIY1xxQAnkJ6DP0pPs6ZoAT7MnpSf Zl9sfWgBDaJ2zQ1oh6HmgQhskI6/pUUtqkcZOAaAKUMJab09KsvHg/dGfrTAjuXEEBbueK5a5jkl neRu59aTBEJgb0NMMZHUYpDOsNswwcYB6GmtAKYB5AoMPOKAEERHXNHlNnvQAGOTHBNBWVe5oAUp IADuyKQeaOmfyoAMyjrSebID0oAUSvnpSieQds0wDz2PVaTzj/doAXz/AFWk88ehoEOS4Xd8ymnG dAemT7UANE0ec4INL5q+tAAJRnrS+YvZsUAG8dmH50okB6mgB++M9evqKMZOQaAAZJpefWgAG4Uv I5oATvyKGHPANAASaOtADce1HI+lAC5z2pM0ALxg9aUbCOQTQAHYeg49zQNueFFAC7iDwcfSlEj/ APPQ/nQA4SP13n86GnmHRyaQCC5n/vGnC6nHUj8qYDvtkvoPypy3jj7yg/SkApvT/c/WlF7/ANM/ 1oGKL1e6mke7VxtCHn1oEQOGOBkAe1IFAPJHNMClfSeZIIwAFX+dVii+lJgIYl6gVG1ujdVoGby3 UAXawbH54pvmWjAZdhj9aBCg2nB81uO3NO32mPv8n2oAdm2bpMtDRRHG2VQfrQAnkDBxIn50C2BG CyHHvTAQWp3cuoUj1pVtGyTvHHTFACtAzEYUcdRmmLayZ5A4PrQANaszY280wWr4+4c0AIbR+6cU psm252jNADfshyBt60G0YZyvFADWtSOduBTPs/QAf/XoAQ25HVDQttkdOaAD7P7U022ev8qAD7Ke 1Na2IOS1Axv2cnkZxSi2f1/WgA8hxwOtJ5MvTJ/OgBfLmHIZqTE/d2zSAP8ASB/F+dAluR/F+lAA Z7gDoD+FIbiXHKDP0oAUXU3/ADzFH2mUHmJfzpgKbkk8RY/GgXWByhNAC/a1/wCebUfa1H8LCgBf tUeeh/KlF1FjuKQCi4iPc0vnRZ4emIBKn94U/wAwetABvHrR5g9aAAOvrTgyn+IUABI9c0uDQAce xpV2ke9AASR0I+lLIWihaRxkYoAyxk5J6mlpAFFAEvmKfpQHUnpigYuQeKcNvU44oADj1oBWgBwI PegbR3/WmAd+GOPrQGIOQxBoEKHYEkOQT3zS75OvmN+dACiWdTlZWx9aUXM46SGgAN1cY+/TheXA H38n3FAAt7P3YflSi/n/ANk/hQA4ahIeCiml/tBs8xLQAv8AaHGDED+NAv1/54D86AHfbYhyYfrg 0gu7ZjkxvmgB4urU/wALD8KUXFpt+8R+FACie0YY3jHvSq9oDxItADv9GJyHX86NlueQy/nSAPIj bowo+ypnIIoAT7Gp6mkFovRhkeuaAEay54ORSCz9RmgBrWOOnSmNYnsPzFACCyPcfpQ1if7oNMBp siOCgP0ppsc/w4NIY06fTTYkdqAAWXtTWsj2U/lTAT7E2cZpPsT9gfyoEJ9lfvn8zSm1de5oAT7O /vSGGRaADy5BnrRiUetACFpUwSePerKZZOaAHgDNVr5jkRgnA5IoArjpS0gCgUAZwu29KUXbYyaQ xVvT6flS/bPY/nQAC946GnC87HNAC/bVHrThejHemAovl9xTheJ/e5oAd9rTON4zTvtQIxuGKLjF E/vS+caLgBnYdqXzs9RQIBOAehNOE4B6GgANwnoaTz19aAFE69DR5y0AJ5w9eKPNFADhMPWjzVoA PMU96XchHBB9qADK560vy9jQAvGfvUvH96gB657SMP8AgVKJJBx5rfnTEOWecDiVqUXE/wDz1NIA a7n/AOen4Yo+23H98flQADULgHkp+VOGpTA8ohFAx41M94h+Bp41Je8TD6UASLqELdmH4U77ZBnB Yg+4oAcLi3b+NfxFKJoD0dPzoAXdCTncmfrS/uz3X86AArH7fnR5cbdh+BoADEh7U3yE9KAA26EY pptUOKAKd3CWkwRtUdPekVcLhRmmIX7q7iMYrMdvMkLepoAKKQC0UAYmQPegnNIoKOKAD+VG45oA M0ZoAXI9aMD1oAFXDZyeamQd6QE6CpgdozyaBjoiTGXI3NjpnvUsXQbuvemIlKr/AHRTHjBwc4A6 0xDo1Tuop/lpj7ooAhkiPBTHHY0oRT95MGgB/wBni9KT7NF2oAabdc4BOKcLRP75/CgANqo/jaoH jAkK78duaQDLpHtkDMQ2emKri5yOUFAD/tIxjbj8aUXS55FAB9pAPGRmlFyB3amAfamA4Jx9acLs /wB40AL9r96X7UR3oAPtO7uPyp32g+x+tADluE/iBqTeG5VgfxoAerLjkYPtSg+ooAeGAHX8KcEB 6fzoABH83U07kUAKwB6ZxSYHY0xCjePus2PXNLvkz/rG/OgBRNKOkjH8aPPmx99s/WgBoZi2W79z Tt3oKAILt9seM8ntVJeKQDqKACloAws0ZpFBmjPrQAZpaAEJooAM0ZycUgJkFTIKQyZKVpiqnYPm zgUASqu1gc9asIo9aoQ+mO8WQkjct0FMQ4AAcDinA8UALmkPJ6UAKDjrShgwyCKAFFKKAEJ9aqRI fMLPyQ3GaQFTU5N9wB/dHNVRQMM0oIoAKWgBaAaAAUtAC9DTlY560AQvc+VJskBHv2qzHIDypyKA LSOSOalDZoEPGMcnmlGQaYD/ADDjnmpRIHH8K0CFAcdcMKG47YNMBuTnFN7mgAyR0qUOjjDDaQOo oAYWweuaVenJzQBRunLznngcCo+1IBeccUtABRQBgnrmgetIoM0DHpQIKXNACds0ZoAM1LGo70mM kQDNTKKkZKvAyaSI+awxjHWgC2SO9SDpViHCkeNHILLyOhoEIiFT94ke9S55oAKM0wI/MRmK5HvT 4wAMCkA/NFMBj8DNQo4ZiSMbR6UgMm4ffMze9R5oGLnjrSgmgBQaM0AO7UA0AFLmgBaMkUAMuIhN HkD5hUdkX5H8IpAaMRqwKaBkgpfcGmINx60pb0FACiRh0NSCUkc9aYhRKvQiguGA9qADtnNBwKAA MKbK2xCaAKPUk0opALQKAFooAwKXoeKRQZyaM0CDPWkzQMXNIelAgA5wanjFJjRKv1qVKkolP3ea iSJo5/NBwpXGKBFqEM0m9s4x0qyKoQuaKYhQRS0AGRRQA0ou7djB9acOlAC0hJoAa7E1BcOI4GPQ +1AzFznmloAM0ufWgBQaUHmgBc+ppc0ALmgGgBQaM5pAOU4NOQKpLdMn1oAmQ4NWFbI4pgKG96Xd 70xChqcGxzmgBwIPNLTEKBQF98fWgBeR1pQaABagupNxCjpQBCBS/SkAvWigYvSigRg/jR7CkUJR 260AFJSAXOKQ+tAD4xzU6jFJjRIuc+1SqMUhkjDIAqbZjGaBD1qQCqELRQAo4pMUALRmmAZJ75pe 1AAGFGfWgCuXZ3dcbQOh9arajJ+5CZpAZmKOtMB2cUufxoABSg0ALk0ZoAXNLQA4fWjPNIBc09CP u0ASZoH1oAXnqKduPrTELuPril3N3JoAUOw6McfWlEjZzuNMBRJJ607znPU0AHnOe+aXzX9RQIPN kz2ppOTk0DCl6UAApfwoAPeloEYP8qSkUHQe1IPvYpAFGKAEOBR9KAJkqVRUsZKg5qdaQx38QqVS ScEYqkIeKetMQ7PNFAC0UAFFACCloASkJoAiPWs3UHzLt9KBlQUtMQUA/hQA4GgcUAKM59qcOtAB mnUAAPalxQAtH60ASI2RTwaAHA0poEFKKAFFLQAo9qKYC0tABSigApaADoaPpQA4UlAjCGaMVJQY 4zikNAAelIaAENKvWgCZOlSrUsZKtTLQA/G404A9qAJBmn8YqhCijNAC5ooATNBNAC59qM0AIW5p rNmgCMtgE+lY07b5mY0AN/lS0wCkzzQAuactABml6UALQDQAop2aAFBooAch5qUGgBc4pwPtQIUU UAOooAXpS0wClHSgBePUZooAXtRQAtAoAWgfSgDEwPSkIqRic0mKACkoAQ0L1oAnSplqSiZalFAD kqQCgQ8dKWmAoooAWkzQAZ70UAGaM0ANamMaAILh9sTVlnk0IBR65pKoQZ9qXHFACClpAKKXIpgL nNL2pAAzmlB96AF69KdmgAFSKaYEgJHQ0Zz1oEOFLQAtLQAozml70wAUooAX8KKAFooAOaWgBR1x R7UAY200YqShpFJgeuKAExRigRFK2wZohO4ZoAtJUyipKJUqUUASKKeKBDhQKYC0UALmigAzSZoA KQmgBrGoyc0gKl63Rc8VTwB0poBBS9qYgpKYBS0gFGKWgBRRzn2oAXdQMZxQAvHrSigBe1ODY4oA lU8daXNMQ4GlzQAoNKDQA6igBRS0wFoA7/yoAWgUAFLSAWk4oAyv88UhH1qSgIpCOeeaAExSEUAM ZAQQRkGmxgA8CgCwoqZKQyZacpBPHagCYU4UCFpaYC0UAFISOlABRQAhpKQDSaiJoGUblsyfSosV SExKMUCCg0AFFAAPpThQACjtz1oAOlKD7UALmlz6UAKKX8aAHocCpFwKYDutLQAo6Uo9qBC078aA AUv40AKKXoKAFFFABS0AFKOnNAGWaMepqSgIpMUAJtpMUABHaoWBV+vWgCZOlTRikMmHFKud2aQE ymnA0xC5pQaYC0UAFJ3zSAM+9GaAA00mgBjHioXbCE0DKLkliaTtVIQuKafSgQAflS4oATFBFABS 0AGTRQADr1pR1oGL0oFADqXigQo96lXHGaYDqcKADmnDrQAvNL1oAWlFAhe/XiigBRS0AFLQAUUA Z2KMe9SUGKXFACY4pCtACFaYyg9aQwTr9KnQ80AS5wKr2jMbhw5J/DjFIC8KeKYC0UAGaKACkoEG aM0DEPSmEnNAELLgk7jUcvAx60gIMc0mKsQuOKSgAAoIoASkwSaADFKAMUCAijFABilHFABnmloG LSigQtPSgCSgEHvTAdSigBacKAFFHTmgQo6UooAUUvegABz160tABS0AZ9BHtUlBiigAwaKAAj2p pFICMrhs1MmOKBkmOKeg4oAkFOBoAXNGaACloATPakzQAUhNACE01jQBGagkOW9qEA3FJTEGKQ57 UwAA4owaAExRigQmKMUAFHNAB+FGOtAARS0AL3pfegBQM05eKAJV6Uv4UAKPalFMBR1pe9ACiloE KKXvQAuaM96AFzSigAFFMCljjPWlwKgoKBQAAY60YoAMcdOaQrQAwrSp16UhkgPFPU8UAOBpQaAF zSg0gFozTAQ0E0AJmigBCaYxpAQu/ao+5poAxQBTEBH+TSYoATFKKAEIoxTAMZpNtAgxR7UAG2jF ABijHrQMMc0o+tAhe54pQfSgCVTTsfhQAopRTAWloAWlFAg7ZpR6mgB1FACmlpgFFAFUCkAqChfx pMDtQAtGKAA8UuKQCbaaU54oGN3YODUisD3pAODD1pdwz70AKCKXIoAAaXNAAOaQmgApMigBrEdj UTNTAYeTSgdOKAEI5pcY9aYhCox60bcUAIR7UAUAGOaCtMBCD2oOe9ABijtwKBAVFG3B4oAMUYoA TFAXJoGO24pwXNAhwGKeDQAtApgLSkUAL7UtAhfwpRQAZpaAFopgL3oH6UAVgKWoKDilwPSgAx7U YoACOKAKACgDmkAFFb7wpyogHCjNAxQoHajaPSgBdq9xSbBjpQABBj0o2ikAYFJtoANgprRj1NMC GZHUZAJqofP3/dYUAWo0OAW61JigAxTcUxC4pCKADbTSPyoANtG3FABikxTAMUAUAJijFAB9KBig BO9OAoAKcKAFFOFAhaPpTAUUuMnPagB2PSj+VAhaWgApaAFFKPpTAKKAIGGKKgoMc0ooEBoA4oGF GKADvS4oAUUd8UgHDkUUAHSjtQAUEc0ALjFJ1oATviigBM008UwGkUlAB3pTQA0jjNHvQAGkoAKO woATHNGOaADGaTbTACozSYoAMYNBFACYpwHGaADGaXpQAtKKBC0Dk0wHdaO1ADuelBGBQIWloAPe lFAC0UALSgd6YH//2QD/5DNYAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJpYdLx5/D88hHDRu4gBAAAKAAAA AAAAAAcAAAD/////AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAABioTT210gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkAEAAK6urq7aAQAAlgQAAA0H AADYBAAA2P///wEAAAAJEq0xAwAAAP0JAABWCQAAaAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAAAAAAAAAACkAAAApAAAAAAAA AAAAAAAAAAAAAAAAWAAAANgEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAlAAAAAgAAAFIAAAAICgAACQAAAP0JAAB2AQAAAAAAAAAA AAAAAAAAIAAAAMgAAAARAAAAAAAAAAAAAAAAAAAA2P///xoEAAACAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAC4AAAApqIAAEkIAAAAAQAApqIAAAABAAD5////PAtKCTwLAAAn APv/ggDbAF0AtQedB4AHgAdfCQEJigg4CMUHiAcECTwKrAqeCo0KgQp5CnEKZApeCmYKgAqjCq0K tArVCu0K9ArqCvQKaAqCCpUKlAqtCtIKzQrbCtoK4AoSCi4KQwpMClYKXQqjCsIKfQnaCewJ3gib CL0IdQnoCYAJsgmbCVIIVgiKCOcIKQkzCVoIVQhnCL0IqQgTAAIAAgAAL5n/lgn9CQAADwAZAAAA AAAAAEIKJAu+BwAA3P9eCwABAAEADwAmACn//4T+R/8AAAAAAAAAAAAAAAAAAAAAAAAAAAAA2ATY BAAAAAACAJoFfgAdADMA0v///wAAAAAAAAAAAACMCJcKAAAANisANwANAAMANwArAPT/EgDQ/xoA AAAAAAAAAAAUAAABEAAnAMIKEQAAAI4JLgBdAGUBAAAAAAAAAAAAAAAAAAABAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAPQKAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAPZhAAAdAgAA9mEAAB0CAAClAQAAAAAAAAAAAAABAAAAAAAAAODEAABABgAASktKSxcR C2opAwEA0RABAC6PAABVhgAA94MBAIWDAQABAAAAAAAAAADY//8A2P//AAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAIAAAADdAAAAkhQAAAKzAQAAAAEAXM8BAMqSAQAJcv//Lfv//wrM//9GLwEA sAQAAAUMAAC7XP//QJcBAJERAQBBIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAx IgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAkREBAJERAQBBIgIAMSICADEiAgAxIgIAMSICADEi AgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSIC AEEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIA MSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICACEiAgAhIgIAISICADEiAgAxIgIAMSICADEiAgAx IgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEi AgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAISIC ACEiAgAxIgIAMSICACEiAgAhIgIAISICACEiAgAhIgIAISICACEiAgAhIgIAISICACEiAgAhIgIA ISICACEiAgAhIgIAISICACEiAgAxIgIAMSICADEiAgAhIgIAISICACEiAgAhIgIAISICACEiAgAh IgIAISICACEiAgAhIgIAMSICACEiAgAhIgIAISICACEiAgAhIgIAISICACEiAgAhIgIAISICACEi AgAhIgIAISICACEiAgAhIgIAISICACEiAgAhIgIAISICACEiAgAhIgIAISICACEiAgAhIgIAISIC ACEiAgAhIgIAMSICADEiAgAxIgIAISICACEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIA MSICADEiAgAxIgIAISICACEiAgAhIgIAISICACEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAx IgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICACEiAgAhIgIAISICADEiAgAxIgIAMSICADEi AgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSIC ADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIA MSICADEiAgBBIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAx IgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEiAgAxIgIAMSICADEi AgAxIgIAMSICADEiAgAAGwAQjB46G/8PAx0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAABBGwMQDh1BGwMQDh1BGwMQDh0AAAAAAABGGwMQFB1GGwMQFB1GGwMQ FB0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADgAAAAPgAaAvYC3g4AEAAAwEkAAADY//9t 9P//AgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEAG AACvr6+vAwBEAQoDKggDAIgBvgNTAHN3MwHY////r6+vrxgAzQDvpEoGEpTJAAgAAAA7AAAA2P// /7AAXVGOBB6UtQALAAAABgAAAMX///+6ACXmCgUwlJ0AAgAAAAMAAADJ////xABV9vsFJJTBAAQA AAALAAAAx////84AgRXrBTyUzAADAAAAAwAAAMn////YADGWgwVDlNgABQAAABcAAADG////CwDH 0O8FCwDZABQAAAAGAAAAyf///8QA0v///2cgDyciAAAACAAAANL////EANb///89NA8nDQAAAA0A AADW////xADU////MDQPJxIAAAAOAAAA1P///8QA1v///0k0DycMAAAACAAAANb////EANT///+R IA8nAAAAAB8AAADU////xADW////aCAPJxYAAAAoAAAA1v///8QA1P///yA0DycHAAAACQAAANT/ ///EANX///8xNA8nAAAAABwAAADV////xADE////ODQPJwQAAAAZAAAAxP///8QAyP///zE0DycM AAAAAwAAAMj////EAMb///8rNA8nBwAAABIAAADG////xADJ////ZyAPJw8AAABCAAAAyf///8QA xv///2wgDycGAAAAGwAAAMb////EANv///9INA8nCwAAAAEAAADb////xADZ////RzQPJxsAAAAE AAAA2f///8QA3P///yU0DycrAAAAAAAAANz////EANX///97IA8nEQAAABMAAADV////AAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACvr6+v AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAARAEAAAoDAACIAQAAAAAAAIcAAACOAAAAjgAAAJAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABABgAA/Pz8/BYGFSDVVQAAj96cugAAAADY////AQAA AA0AAAAAAAAAAAAAAFoAAADhAAAAYgIAAEsEAABUBgAASAgAAB4KAAD0CwAAmA0AAJoQAADUEwAA 1xYAAJoZAAAcHAAAnx4AAOEgAADjIgAAZiYAAEkpAADMKwAA7i0AAHExAAA0NAAAkjYAAEA4AACe OQAAyjoAAM87AADrPAAA/j0AAABAAAAAAAAAWgAAAOEAAABiAgAASwQAAFQGAABICAAAHgoAAPQL AACYDQAAmhAAANQTAADXFgAAmhkAABwcAACfHgAA4SAAAOMiAABmJgAASSkAAMwrAADuLQAAcTEA ADQ0AACSNgAAQDgAAJ45AADKOgAAzzsAAOs8AAD+PQAAAEAAAAAAAABaAAAA4QAAAGICAABLBAAA VAYAAEgIAAAeCgAA9AsAAJgNAACaEAAA1BMAANcWAACaGQAAHBwAAJ8eAADhIAAA4yIAAGYmAABJ KQAAzCsAAO4tAABxMQAANDQAAJI2AABAOAAAnjkAAMo6AADPOwAA6zwAAP49AAAAQAAAAAAAAEAA AACAAAAAAAEAAIABAAAAAgAAgAIAAAADAACAAwAAAAQAAAAFAAAABgAAAAcAAAAIAAAACQAAAAoA AAALAAAADAAAAA4AAAAQAAAAEgAAABQAAAAYAAAAHAAAACAAAAAkAAAAKAAAACwAAAAwAAAANAAA ADgAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAAAAAgAAAAIAAACc AQAA2f////T///9z////HgEAAG7///+FAQAA8v////L///+a////8wAAAHH////LAQAAnP///wIA AABX////RwEAAGL///+TAQAAy////wwAAABz////MAEAAF3///+TAQAAy////wwAAABz////MAEA AF3///+TAQAAy////wwAAABz////MAEAAF3///+TAQAAy////wwAAABz////MAEAAF3///+TAQAA y////wwAAABz////MAEAAF3///+cAQAA1/////b///9z////MAEAAFv///8AAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMwG AAAABAAAPQcAAOwFAAAAAQAAi+MAAOwFAAAAAQAAi+MAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAPMAAADlAAAA4wAAAOEAAAD0BwAAUAYAAACSAAAAQAAABQAAAAAAAABxAAAA4wAAAFUBAADG AQAAOAIAAKoCAAAbAwAAjQMAAP8DAACAAAAAfAAAAHgAAAB0AAAAcAAAAGwAAABoAAAAZAAAAGAA AABcAAAAOgAAAFAAAACKAAAA5gAAABgBAACaAQAADQIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEOssQwABAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAwAwAAYgIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADADAABiAgAAAAAAAAAAAABz AFIApwEAAAAAAADvP+8/sgEAAISoYwGEqGMBSAgAAQABSAgAAQABtwYABMoGAgGlARkAgAAAAIcA jgCOAJAADAReAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAF4AgIAABoyQA APQAuABHAAwEYwTYDwAAAAAAAAAApQEAAAAAAAAAAAAAAAAAAAAAAAAAAAAA7AUAAAABAACL4wAA 7AUAAAABAACL4wAASQgAAAABAACmogAASQgAAAABAACmogAAAAAAAAEAAAD/PwAAAAAAAAAAAAAA AAAAAAAAAAAAAACsAQAArAEAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMjE5NzMg MjAxNi8xMi8xMyAxNDoyNDo1MAAAAAAAAAAAAAAAAAAAAAAAAAACAAAAAAwLAAAAACAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAILNnAAAAAAABAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABEAAADIAAAA2P///5YE AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADAAAAAgAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAACAL4BfACIAf8DAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD/////AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA/////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAASg5xAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAHNzb2lzNjNGTTAyIDYzRk0wMiA2M0ZNMDIgMCAxIDEwMQoAAAAA AAAAAAAAAAAAAAAAc3NiZAAQoAUAADgEAAACCAAAsqEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD/5QAaEAEA FjIwMTc6MTE6MjAgMTc6MTc6MzIA/8QBogAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoLAQAD AQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNR YQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldY WVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TF xsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+hEAAgECBAQDBAcFBAQAAQJ3AAECAxEE BSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZH SElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0 tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9sAhAADBAQEBAMDAwME BAMDAwMDAwMDAwMDAwMDAwMDBAMDAwMDAwQEBAQFBAQEBQUGBgUFBgcIBwYICQkIDAwMDw8VAQMD AwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMEAwMDAwMDBAQEBAUEBAQFBQYGBQUGBwgHBggJCQgM DAwPDxX/wAARCAusD5ADASEAAhEBAxEB/9oADAMBAAIRAxEAPwDzaRqgzwfpXmG6C2b/AEhc9Nw/ nXercBLfAPb1qRmI7CSQk+tSBADmga3IZRkjFWYsKvNSy0inO2Dkc02Bt5w3rRcRcbCfd5NWkl/d nPHFIDAuWLO2PU1VhU+Zz61SZR0ZjBhJ74/pXJy5E+B6/wBaYHUWkmyH3xT/ADdzEdql7gV5UyMi sh1PIxVCZGkXOTWsihRxSewkTCQ9O1OKqRnPNRYewxPkbIq2WLDBpjTuNKgDIPNUXkYHFAmWIjkZ PWo3YhsdqBJ2IfLDHd3qyshTAHSqBsmkk3Re+OlZUed/PrQVE2V4Q/SqJXMoPbP9akbRqhgseAc8 VmyDc2TTW4hwQbc1T25c+xqikWxkqVrDu4yMkcnFAMyIgWlAYYGa72zCrEoz2oJNI42H6VzM5/en HrUsC3AfWny4NIsrqNvIpzPu4oARVB5qs7bSaAIA+5wK2EOEFAluyJzkZqoAM8UDL8bEcVOE3NuN SwI5uMCoz9zB9Ka2AoA4f2zV08gVSAQj5cUwdDRcCMcP+NbKt+7/AApoDKkYluKhLFRwOlMbRbgu CflPHappU/iFFxFbJFR+Yd2D0qXuBpIcAEVYcjy898UgM5U3tn3qwUGPpVAU3bHyiljTuaYDzHzx UoBAxQNonXocVnTRndkUCHxR5609/lPFAEi8rmj1psaE3FTUmN65rMbIfKw2TT3OFx6UCvYz0fM2 D611cKKYhz2qt0JlG4iHJrLCYPFNIkcwOKhXINUCdi4DuFRkc4plFtMBcZrNlXLfjTQFlIxtpcYN DYDGqIpkVLKQAbVNQoMvUiZceMbMjriq0YO/8almZsIi7eajkhBBxSGtzNxsbAq7GeAe9NFExlNK vz9aoB7IEGag8zrQBTkcucClii7mgadid/lHFQodxwaaQhSoU5pWO4cUxMRWx8tQSNzigkcijGTT WODgetD2Gty5EuVzT2yDUWKGs3yc1n+Z8xFNAWUUvVgQ4qgJxxQzZGKBMrMoqHJU8dKBi+9RFjnF ADGXHNXofu80AylcYzxTYcnFSStzSKfJn2qh/Gc8UFEjYIqELVDQ0D5uavDGzGaBk8PytxV13JXA 5pNElRYgxy3FJPGAhx6VIHPKh878a1NuAKkDPkJ3dK1rIA4z1pody9c/KtYwb5jWiBasRmOeKmXO 00AyHaS/NOePAzQIgR8NirUg3pxzQNblARsrdK1YV6E0FFp2AXA9KymGWoFYf0HFKrGk0Nbjiead u4pFEZUGpEGBQA043ZpN5zxTRLHFdw5qAjtTATYKU/KOKTGmN681Mo3daEhin5TxQrfNUtiZZZ+K aHoEkQvL6Uivkc0nuVZCZ+amOTQgTuKmTUjfKMmrSE2VC+WwKmyQtMaGg5PNPIAoAUHFPHzdaAFY AdKUdKADqeak2g1ImhCoxgU5flzUsEV5BuqljBxTihlpF45p/erAXbQDjihoCFhk5qVDgUrANY5N AOKRSYhOaQACgY9sbKyj9+kyVuXw+ExTFkyaixRODzmpxISNp6UzNjTFn5qgbI4FA0QY5zT8k8Vo gJRGCOarsoDZFWxMsKc4FaK/KnHpWYluZczEniqqsS2Pegu5sRr8oPtUwbtUsT1IZfWrMLfu+fSn H9QAH5qSU/LxWqEzKZyDinxnvVWEnYccluKnXIHNJ6ASK/OKSRvSshoZGxz+NWmAI5oGNVcDinYz QBUZPm/GrKjC4HpTitSStg+YM+tb0aDys+1aAUXPzEUi5qbgSDrUUq5HFSwIEJHFW85WkBGo5qbd 2q0riGgZNSGMbapaEkAbaamyHFAConNOkXA4poCBenNQnO72pvYBrEninIuDmpAudqAO9BSdycSH GKaRk5oGJnaOKj8wk4NAE275cVEg5prclkpiB5qMx4yaogi25NWs7UxQIWM4yalEpBxQBZ++KcF2 9KAHcjmmMwPWmgMufk8VGmcUmwLanApfOINNASK5PNP3EkZpMAkxjipYRlaCXuWxGOSartwcDmqt YTdh6pu5NSFdpGKpIZN/BzxxWU6jf+NMCQHaOKerEnmggt7c0xhQBIgBGDUu3bmgBFOGyKkeQ45p NgVi9Oiky4HvTE2arY8rnuKzEQebkc8/1oBI0JG2xY9v6Vmx8sT70C2J5AMVXXg8UBcjkJzU6/cp oQnlhuajZMHjnFNgXoX2jBqrPJ83FK4WBHJWm7vmx70ikWwuQKUxADcKAbDbxVNuvFAyRBkjNbMK jbTQDJgBk1kNJ82BSZLLUJI5rR8wlSD0waBGLcLhtw61NAxcbTTQmicpsORRt3cmh7iW5VkYqcDm tK3Py5NIouHpmqjHnFAFhcbcGqrjDcc81SEycD5M96ag+fJpiLjsu0DNJG5XpzT8gGyyMxwRUsSD GTxSYEErbWwOmacnzDmgBxAoHB9qCi2jHoKdJ8y0AQIvPNWemNvNBJbX7ue+Kpy5Y4qXuNM0bNdh BPrW0x3jB6UhmXIoUnFMB20AWPvLmmqBzQBC64ORUqZxk8UDTsV5fmNSxgAUFD2qPdVIgiMnNWEf ildgDEseeKYQAOKllliM/KR7VEvEpJ9akC1I4ZQKprwc1aE9ibfRtDc0CAp2FJ5eOaAaJVYj8Kdu 3cGgQ8gBce1VM4PFADznGaRTk80FJ3Hn25o28Z70DEX72TV7grigBgQA5qTdxtpJiZC8YPzVEqYa mSXSflqqM7qBp2IZUzVZAVagovAZGal7VL3AdGecUyZe4pASQE7Tmkz89BJKX420qfLzQIjllJBA qkq5bJ4pIDXQYX8KqSMQ1VcY9TleaULzmkOwhzux2qUIODQFhkw+WoIm7UDBxg5FXIWO2mibkUyh hk1SQbSQKQiQnnNSqu4ZNAEi5DYq04ylAFAfKTT15bJprcDQA+XIqvnnFUMsJTWJzQUN25HNO2Ac jrQBVdiDzUkcm/g0EEzkAYHOabHgHmgC8FVsU50AQ0AYEgxIcetW0Y7APagCZM96kK560ATA4TFV T97NAEyk4ximnJagB3AxUytgVLAYx3c1GoyfpTQF3ftTAqxDKcc1oSSsQ2aqDO/HagC6wAj+orDk XDkigB0fXJq2T0oAsDDLg+lR7AG4pATso21SeMfepMBik/lUgfmhbgSb6gdiRVAVEGXrSAwBmgAx kYFQbDuqlsBNs9aaVAPFAEu35c96iUHdzSYFpsYxQqDbmpAhLbTgU8c8mlYE7EmMc1UYb257Uins aUXyJgVG0hLbe1BIuABn1qlIm45qwJ4IMkE1bliG3FABGoRarvJ81AFhGyKZNHuQ0AUoU2uav5Pa gD4LmhJGazgNuQa4TRbDEbbKD71uh2ZBg9qVikVTLtfHfNbcMZkjDD0zUsok8vqDVCY7TgVIEA+c VLGMZxQBGCfN55FOlk5AXiqATblcmmJgP+NMo2hzGR7GseS3+ct+NAEAYq4QVrxxkgNQBbK4Xnms uQruIxSTuSNCZGRxTRw2Pek30Auhfkz7VRO4P14zSAtxHcQO9W3XatOw0VFzkkniq08i5xSBkMcu Kmd9w4607CSuPjQ9ascdKY7ERjI57U9QO1DYJBJJtGKi8wFT61JdhiSHdz0qy7jbTW4WGq2UxUA4 fn1qhbGki8bqhkh8w0D3MqW12cjjHtSQylDtzQI2fOzFj2rFY/vST61LGjUQ/LkUhBbn0pDE/wBm oHGDQBLEKjmjOM0AUVjOc1fRs4X8KALjRHZ+FUFQiTB9aANIgKmaYLgAEUAQmUOajfpxQAxV4LU9 eTigCRlIqLqcCm2BOI+M1G8mPkH0pDW4+Ne5oYAnFUncGNWE7tw9av7gqYPPFMVrlFmBNQn1pMot QnPFSyg4qSRIzgGggsTiqTAi2/NzT2O0UwHRuOpqd2BGRQBEj4PNS71JwRQA0kA8VFIMjNAESntV jcF60DTsMZg/SrMTBRg1BQ9hv5Ws6XgEU0SzMVT5vHrXSRS+Ugz6CmkIHuBJwKgCc7jTE0PJGMVC Uz0qm7CSuIGEfymoGOTkdKChy5xuzxTDIM/SqQMlEoxim7smncBeh5qzgFM1DAgMZIOKrbfLPNRc CbdkUbwvamA9JdxwKnaYKuDzU2Azy4ZquRxk8iqAldNoohbnFAD5gcZrMOc0AWYRzzVt5FUYFAFZ fnNDLjpVdAKj5NJGSvB5oTuJaDif4qhJ3HNAx+/AxURmGcd6HsBs2pyv+fSrD45qQM+WItnB4qgI GD5PrQBvwgKgz6U93GKEBSDZNOxVE2K7feqfA20FDCvFRheaAHumQKYDtUigTKxQu2auRJtxmpBI 0cArWXcJjJFAzPVjnFXkGaoorz/LyKjiYkUDLiPg1oLKAOeaCWyQHccrxUU3C81IjKyA1WAu7ntU tgRSKMGktX2yge9NIaZpXJ3LxWaq4qkgsTBOc1ISOlFxEigEZqOYgIR7UwMYRs75HFbUMeAN3PFA Fpo125qoG5IFAIiOS+KRhQ0WR4qPeFNK/QBw+Y5qVuBikUiNfWrIPGKAZAyktkVMqcZNNOxIvtVZ zg5pp3ARfm5pWPagocPu0qjmk2BJszULfJSEmRZLVMOmKBjPLOcmkZtoxUsTFjUk7qnKZpCJQBGu TWfNJvO0VaAbHGV+Zqslx0qh3G7eMiou9A0icH5cU7O0YoAbyTmpwR0oAjY4Oab5meBUgKoJNWNu AKTYLQgfpVYH5vxpICzjI4qHdtODWiAf5gpA26hsBCKUKakA2EHJqNutACdBUZyTxTkUmSchMGqW w7s1mMslCVpEjI60AWFU5qfbjmghq48SAcGlODQJKxHs71RklCMBWkdRk4kzHn2qozZzVsGPizur QzgYrOwkhmNwNQbNrZoGXg42YFNRxnmpsAOc89qep+XFNaARb9rVOqF+a1RLZTmiIbNNReMUwLka 4PNWZFG3igDN2kMaRgSaybsUWI+Kc5z0pFkiHA5oLYNMga3TNEbc4NUSSuBwRVyN/kxVLYCuxw1T rgrQ0K5GeGqbI281IysQM0HpUsBiqadg5rRCaHZ207zMjFMVhjJuGRUKt5bc0WEa0RDrxxSSIRye lAGezc4FS9V96AIu+KmWI9aAJgcHBprdaTdhof2FSBcrTKGbOtRiPLUAOb5eKVWCjmmtyWhPOGaf 5gIqiBgcCgHe2BQIm+4MGoM/NmgDVib5RVheaAGMwGQazJSS3HTNBSIOvWnCgLCMecU9Yy3NNC6l lPl4NSnkcUhvYh2Enmr0R28UGb3J3bjA4zUIGPmPNNEslzkZFN3g/hVLcoYX3fKKrFCGyfWqAsKm RUhwlNOxBKkgxzSFgSaGgIlz5g9M1dkOEH0pAJCNxqScADFAGd60QofNz70E9TSmz5fHpVe3+8c8 0rlElxk8DpTIht600wGy89KkjGFyaBNDCu5qkPTaKdySPOwYNOVhnmhsCOT/AGeKrBCWyTmiwXLg +VcULHlt1IaZZ3bcClMo20AtWQeZuOBU3l9DQUOK4GanhfaOaFoA2U+aCF4rJ2lJDu5ptibNGP5s EVaY5XA60iTPkQnrVm2jxVITRalxVMuAMVPURCq7myauhdo4osO5YU/LUfUnFAWGEkHbTx781SEP 3bRk1EZQeBTBK4xVZjnNaEXyfe5p9AJHwxyKACRxxSAhkX160ielAAVIOc1ZHK4oK6FqJcAk0/cN 2KCWyOVPl3DimQtzg0AXg4ztoYgHpUvcpbFlD0xU7T7UwetIDM87fJ+NXH+4DQBEsvG2nh+aALO4 YBPNSghl4osBVZcZqEZzxQBNnA5qjI+KaAhXJOa0ojjGaGOxOxDDA4qHB6VL2KQqnZ1pHfIyOKkC JSScU8gimtxPYlCEjNPUHpVEkwO3rzUm4EUAHBFMC4OaAI3Jp8SbuTQNCzEIuKqR5duKBs0eEHzc 1EZAeBQCG4z04p6q3rSbGPzg1GW5zSW4mSh9w21MFwKokbSbwOMc0APGCKgKDNBYvakU9jQBMOOa ZncakCQkKMVWzg7qQrCqdxzVguMYFAhyx5G400p83FAi0vTFRSCga3IlbBxVg8jigoTIC5PNIrZN MBsnSqyjnNADnbmrcR+XNITIpQWPFVwuOtMkkxVpBxmncA3DNBkB+WpApuMNn1qVRkDFWgNNB+75 9Kqjh/xoGXwuRmomwvWgd0MB3cCpwmOtAmZ9x7VBGpoETYOeaYxIIAoAuRMVXJqVpN4xQBTaIk5p UGDzQBZBGaVzgUAEY3VY8vvQA8YHFIwGM0mwKDZLYFShDimA/G1TmoU5Y0C3HPkHPap45OMd6sRM rENk9DV4YIz3oAruTmqxx3oAZkdqUHNAEucU7zMcmkAxps8CpAdy4qQG8IDmoN25uOKa3AtBPlzS cbSKoCui/PVlx6U0ARHnB5q/sBGaYEbrhTWeqkufrQBcxtHNRFxnApMBCh+9niniTC4pAV92Xq7w FzSaAj8wEbajVec1IFhetNc4NUgE3ZFWYxkc0wJi4jqB5t3SgCPd8uKrFqAGiTa2a045Ay0ARvgH IoEoxzQB8DNcZGM81izvIh3HpXEi9R1tPGzAORnPrXTJgqNnQ+lNotEMseDu78V0On52AN93FYvc vSxNcsoHyfernJEmc5AJGfSkItwrhdrfeqUxlee1AIBGDzTjCMZxVaFGbKxQ46CnwYJyaYG0GUIf pWTI7FyB0oAiWMlgcc5rUjJUc0AWAd3HWoXhHWpa7ElZ1YD5aqDO75vWkBoBvlxVcr82TQVoPX5T kU2WckYzQAyNjzu6VkXcgDZB9aAKcU2XC+9dCE/dBhT18wJoScYNOYNnIqhO4mWxhqcPunFS9xrQ q4LMQacFw2DSLLOxBg02TG3imgII/vYPSppABgiqAfG5xjtV9GXHPWgkgl2kHNYjJ+8yPWgDRjXK fhVdlUNz60rDROOny0358HFSMgBYNzSlssM0CVy6mMCrDBWTA60DKBQjOKlijwcmgV9S08igbQag GM5oGNck8DpURT5MnrQBFGOTTjndz0oQEwIAxUqpkZWmwRC+4N83SrMYQgetIqxK3A4qr5YLZaqs BI7Kq4XrVVAzN7ZoA0sYX8KrE5PNMSIGX0oCHvSYywgCmpmZcc1JJArLnAq3gAZoQFY9ciqU+7tV gVoy+7Fae75cHrQBAN272qbBxkUASJzy1SkrjFBVkVR9/wBs06QE420EkYBUc08NUgXI5F6E0yVQ 3I700BWWLnIpXD4x2oYDF4+tTlztoX6gV0k+b5qtbx0WrF6FaQEnJpo6YoKRJzjFR7QDzVIY4qMf LQg55oYnYkbB6UzLgY7VL2ETx7jRImR71m9wIFRs+1SsqgfN1pAVwADlahkyTVIWzGKCCK2Imwo+ lMZMWDDmqzfKcrQBJksvNVyo5oAZyPu1DlmbBoAn2uo+UUmW70LUCZdhHzdak8petUBCyg/KKQRA daAHmJMVnvDzlRRoBPH5iDA/rUheTPNSwJvnK5qNT83zdaEBbBJHHSmOcL70AUVchjT2duo6VQCK 4PLVKX7LQA0M2eelTgrQAMcj5aYBxg1OomROGUfLTYnYvzQCNIyBU96ynkLMQelAyHAHNWUYY47V Q0VZm3HFLHwKCi6kZbkU9gQOaCWNWRl+lPaTcKkRRbk8dafGzBgD0pWAuMFKe+KzRlJM9s0wLu8u ABzTDkdad0V6Ey5Iz2pjEA+9PQkVWbHHSoGbc2DQBZRAozSF2zhaAH+Y23aap/MGyelAE2RjPelH Kk0FlRmIOKYVJ5pNAixGCBQT83zdKRQv+7VmMD+KkS2EuOdlVRIw4NMCVCCcmlcLimhqxAvHSkIz TGCnBwanPHK1L3AcHwOab8rHnmheZI7YBUqqOp6Un5APcDblfSqKJvfmpK3RZcbBxTFccmmiSpLM ckdqjjXc2TVAiy/AwKjVSTk1RWhYbATHfFUwfmNAkyYA5px60DJRjFMGd3tSYDzjpTCoxlaQCg4G T1pN7GlYBjHPBoAGPeiwD1yOvSmEAtVrYGNIFPUUnYcfMQnnmn7hSGxzONtVs5NCJF2k09F55pyA c459qh+XtWZY/cNvHWnJ0OaAI9xDcdKthsrzQQRgruq1gbc0Ays0oxtHWqLW7yNvwSM1tHYSY8rs TaajVc02MtRrg1PwTis7gOPA4qMKXPrQA912L6VAn3qTGTODt4qKNucGhA0WGC8Grkf3cCtCBzpl CT6GsxSFciqAkyd2R0pzOelAER6ZNMU5asmhovbRjioT7VKuVdiqG69qRyMjFUInAGzn0qEDBOKo kXJJqymRVIBXx1PWow5BwOlDESjk5NPb2qRjlA79alKrjipYFQ5B4pvOa0QE/G35utQDG6mS7ljP 5VSmUnlad9BEcMrI2DxWl5pcc0IBgQZz705lOOKHYAjUZ+brVljtGB0pAC7SNx6007c0D1GHpT45 OxoKHu4A+Wo0bnJoAkbaeaqMCTx0prclscU+XI60iD+9VCLaopHNRMhU5SgllhRuX5+tQ7fm56UC Jg4BwKn80BetAEO4sc9qaymhDRBtanqp709GUDL6daVBID7UyWXMDblutQ7ucCpC5Yj96n4DZoJa HNgjjrVcMc7T0poRaGNuKgIxk1S3Aag+bNSSAkjFUA5SQKhc5PNBBH83RasKD1NAFtEJORU7LkYN AEahlJx0ofc3XpQBUb2qaHggtxSYFyR0K4zzio4ANxpICd15z2qq4P8ADVAQfNnmpudvtQAwHGcV GGO+qsiBzcmpQvGRSaAQqTUeCGxSAsHG0E1In3cCgBrD+9UB54WgpEqpgZ71IC+fagZNns1O+UDi gTIt4Bp2wSc9aA+4XbsGKcp6k0Bp5ETsN2KsRuAQDVKxLLUuDHu9qyDyTipFYEyp5q/k7eKB6eRT 3vvx2zWijLt560CVxrLn5hT0GV5qkDIW+8QelTqiH60wRaCYHFV8nfg9KBPcczY4pUkweaALR2su aosSDhaBoNzfx1NGcn2oGWGcgYWli3Fsv0oCyL7YK47VV27T8vegktJtHLdamYKwyOaTRSK4kAOP Sh5EK4zz9akCmMA5WryOWGG6VVkBIdg5qFnH8NSBGZT0pyzsO9AE6y7hzShhu4oAe2cZqLAP3utU ikG3B46VaUgHBpMTuStgDK0q4xlutIogcgnApwXjnpSsgF2qBkUqjc3sKdiXcvLsAwagbG7igQpG RSrjGO9AEm1uuOKUEdO9ADXXjNMSQLkd6BojcFzz0pVXYMrQUBfPBoAFADx94ema0Pl2+9FgK5wT RtGMd6LCY1E2tk9Kkdjj5elBJAGJyKjPXmgpChz0FOO89KBgSQvNNXJoAdls4qwo4zQAowThqkkR dvFZ63ArAYBxTFYBvnpks0vMXZhPSoQ3PNAhxbHSlDA/eoAYwGcik3cYFBSEzng1OgxzTGRuRUI9 qAEwDUiZzgdKRIEkPg9KlbbtGOtMQ1SDTvmBwOlOyAZJwuR1qkpbd75qQLe1mGTViLGcGrA1vl2c elZbnDUFKxKjP26U9uRzQJ2Gpwas78daBFGQhmpOAOKAFHNWAqYy9ACFl+6KUAdaAEY9qjI4zQAR gmrBxj5qAIg2Dhash220AQbzuqUvlcd6TAZGvzEvV3K9qEBWfrjtT0CDGaYnoSShdmR6VQjI3GrE XsZGRQJcfLQAjbm5HSk68d6AHBRjBqM8HigBCeM1ImGXnrQAqINxzUuMHipYEbgnk9KgA5+XrQtw L0Z7NTnHpVAM24Ge9QMW/CmgHxkd6t+Ye1DYEZfJ56UcdU60JgOGf4qTYpORQwGOTjAqNVJ60gH7 QOlOG48HpSdwISMPUjNgDFFgBWI5NOPzc0ASRgD7/FWkB3fL92mAk23HvUMaZOT0oAsMq4qmVBoA iEZLdOKs7dg+WgBvzH73SmnaDigD4TFtF5gy4/76FU9UijS2JRgxwehHpXCtTU80S6eO5xzjcPX1 r1HTJRJCGY849faqew0rmhIwZtvYGtGCby12+1YvcoccO27OfxqQvtXGKQESAM+/3q8wDgCn5DQq RAd6im+QECiwzm59zN07+lTwoQM96oDRRdw+Y4qBlCtwc0ACvzU5fK0AJDIQ+D0rSJDAc0CbKkhV Rwc/jWfwzZzUtCJOB3/WoZJgB2pAnYp/ac/KKryTBfmJx9TQUUzqS/dyPTrVR5RKevX0NAFi3h+d SOeRXYAbYMe1O4N2KiNhqteYcdKoE7kakucHipmXaMDvSsBVb5DmnD5huoauBAzndjHFTgZXmgtE yRDrmoZuOPSmJkCOasCQigSVyb74qEx/NQGxOvAxULR7jmgolVdop+eDUtAU25aneUPvZpAKPSpQ cUAOJzTd5UYoJIMbjuqyq5XPpQNbEYPzYpXPagY+NB1pso2jIoAoFj1rQtZOcN60bgXJVVqqAbOn NUlYdxpmPSoWlPYUwW5GuZG5rTwIkz7UDauQGfPApByM0AlYaD82KuHG3NJgUy+DxUZLNxg0krkk scfIY8VZkbAwOaQEIPHvTSMg5qkBWXAc/WpSQXFMbRZIGARUq8rjvQIjbj2qILk0DTHFcU5W5oET Mm4VF5Q9aAE8rHINJu520AO3lO1SrJvBBoAplfnqbGRigCBou/SnKu0ZqiVoP3bhimIvzUFEjcHF QtzTSuO49TximmqEOSpC3O2of6gaMS/Jn2qI8sQaze4EmFArIuDk8UgI4SSMGmu2JAvvVE9S2I8g GrIA24z+tMoiPynjmmE560AWUxt5NRyD05oAiXOcEVZWIZzQA922jA5qAANk1QFN8q/FSic4AoEx 2f4qeHyeaATuK7ccUzIAzUjRKjZGaTILYoG0aQRRHn2rJdf3nHrQIuKdqfhVdvnPNCAb5I65pki4 XFUBAke6pdm0+tAEvVaYBwTQAwSYbFS7uc0t2A1pCRjFQK2GzT2JW5OfnGaov8pqSiIsWGKmjz0p 7FJWJPJycmrCxDHWmhmjF8i+vFRSMGJoJbuZzk5wKQcDnvSYhBw2etWkTzCCeKQFlosLxVJkB9qA FXCVLjzDQVtqSH5FxVYpu+amhN3FVv4Khbhs0xosK25cUzkHNAnuN3ZarDAFPwoEUed2Kvony0FJ WKUy4apo1ylAx44zULrnmpeo0RBtpxVsHIpWEIRiq7DJqkAoG0cc0nU88UNjSHZxwKfjAzQmMjI5 3U/dxQ9wsRA7jinY2tmklcVh7OeKtIdy4NJiGs235fWhSq/NkVI0yOV9y8VSUnkU0FiNkJOasxrt qg2ZI5zSRtzimhsJPQUxI+5piQ/ODingZOaBg3pQDxQ1cBMZpM7akBv3qPu0AJjPNKByKAJGPGKb t4zVLYXUiJ9KQMaVhjGanoNwpNDSuO25OKAuDQnYGWM4WoN3ND1BIcxyKiC81BQ8R81NjHFAmxmw E5p+3jAoJK+3BzTzKdu2nHcGVVXMoPvW55gSLHGcVrckw5pCznA71ahXI5ouUlYnI20gHepaAaXz xVmP5eaQmRSyFjjFVxwaTVyolvO5MVSZSp3CmtBtkZmOQDWzbEEDPtVp2MzQlx5Zx6GudcfOSPWq AXzCBjFOVix5oAtFAV/CqwXDYrNlF/HyZqnu+bFICwG4xSGMfeoSARWydnb1qx5ePxq1oSKEHWnD riqFfWwrpkZFVMc4NJoZNnaOKTzD6VIhVY5q2DxUvcExuKh/iqkxMY5NIB3qxlgL8tRFsfL1ppXJ IWiyd1WYlwOf1oaAc7benNIsueKQEwHOac/IFAEfRag3HdQUncs5ytVh9+gZZKcA0w5HFADlHGaT dzTW5DJlO7g0xhh8CqJuWcbVBFKGyOlAhu7nFIx4oAYqbjmleP0oAVWKipPMzQAm/mpOozQWMA+Y fWrvATPtTuS0US+47e3rSbcEEd6QizkqoNG/IoAep4NRZ+ensJltegNMc54piEB2irSfMMmqWoDS OcClaHK5pktj4ox3/Wh8A4Bp3EWYXxxUzEdc1NwGZ4qsX520NBawmzPJpCMCjoBABk9f1q2ny4xS TsBO0ny5qNH3ZqkBXlfB4pVYlDmqewEQPzYqbaAN1SSkNx3p6SZ49KdwJN+DSkA80hDDzxTRJsOK AHvJvFMiHzUFltjilRqAI3PP40oHHWgCIplq0UXYoPXigl7kLOWOCKjY7RVbiIdmfn9OaYpLOB6G pA1yMxY9qz14kxQBdaIFQRUZ+VcUCsNRN5yac42kYoGXI8GPnjioi+w4HIqkJkTfNz3qSI4pgjRD ZGKquNuTQOxSL5bFTYziglouJ93FV2O1uOaCkrCMdwA6Vdgj4oAewAPWpgyhRyKAJFYHvVeSTaeO aTZO4nmZXinLOQNppXKK5PzZ9aeFzzRcAHBqwGIouBKfmXJqIDrQgE281KIgRmhgM27TirSJ3oQE pf8AhFJt71Qxx4GarhiTUsol3mpA2VxSAQDnJp5kONoFACrVkYWkmJ7CcHnNMJxzTEKJiflqZOua B2LpfCYFUk5fPvQSTu3G2qewbs570FJF4KNn4VC7BVIoGZm/5jjmp1bPFAFxRgU/r1oAZnBp4bkU ATSN8nFVw2VwaBWHxr1NIyc0CSItvzVaHAoKGOARmoVYA4oAmxnkVJnC4NADUAJznvUkh2rgVAFM PWfM534HrTsSy9GxWIH2pY3Lvg8UhGk64UYqILkZoKsTKmRimmMA5zQMZtGc07djigCFvmpMYGKd wHIvU08tsNIloUYfk8U1l4wKBDUXBq7nincCFuRVYKA9IDQyNmPaq6r8+ferAvbvlxUG3c1Ay2AF Wqxck47UDsSDipSu5c1LYWKojBbGalaLC5pokagqtPJt4FMCqrt1rRjckYoAVwetVzIfu4oA0oBu HNLKnNAEIjGM0u7Hy0AMPXNOA70ADOegp6H1oACfmxVgRZAOapCY5lG0qTVEoFORTETJL2qB87si gC0kvy4IqROWzQA9+uRUe3cMntQBEOW2U/7hwORQApfAyKVHJNAF7G5KpBNrk0APz83FPZsAUANM npVhEDrk+lNAQtGFPWpY13HFFgHyQgDiq6jafWkA8uScdKC23pQADnmpM0ARMaejZ4oAcygnrTSg oAQjAxTkoAewB56Uon2DaOaAImbzPmNTxH+H0oAWQ44qruOaANCMDGTSPjqOaAKhkPTFVmBJzQB+ aj6uyHO81XfXVZdkr7s8YNcvIa3M7zo5HEq9M5rprLUQgCA4/wD1U2tBI3lvQSGz1rUSfcuQe1YS NF0LUNx8+Ca1pDmMGpsyhkKs3INaCZHB60iVoyYBg27tUxTzRxzVIoqvagZyKqCPD4HSmBDPleF4 zVMK/U80ASgcU4KxPtQBL0HHWo3ZlQnNNk2Mj7QSxBPSqJvNsmCe9RZgK95kZB4qi93u+UHmjbcA jc/eJrLv522nYcUhpnFPdyCTG49a6axkdwpJz0p9BnoenAHG71FdO6jZx0xSEzHaM79w6ZrRj2su 3HNUCFKBDnpUgZSOaYzMnO44FLGPlxSuBLtHORzUW05yOlBSE8whtoNNkB4PrTGSoBszUDnrigAj l2nmrYlVjxQDH55p5I20CRWEnNOdxjipbHa5VGWPFSbivDVNwF8wdqcFZjkUx2LIG0fNTCNx4oER FCOKmUHbigCH7r5PrUhkUj3oARQxOR0qdmXbg9aAM7K7tvrVgIQMrxVaASfPt5NIp/vUwGMAelKE HegCwoC02XLjC0DTKqIQcH1qyRtWgop5w+ferO/5ce1QxFdeX59a2okXbkirJIJWXO1eKh2EjJqb MBgU7vaiX5U9KaGmjHEn7w896sfNkEUxF1G+XBp0T/vQD0zQBpyJuTcvpVJVOSKoENeNgc9qb0+t GiHYmRvWo3fDYFSImU5T8KrKR5vPrUtAXXUMvHWqO0o3tTAlBB+tL5gVgDTAZM2RxUC5K1QDOVbn pWhGyleOuKAImHz05sYqkBGKGXI4pgNQEHmpQMNk9KhgXBOqriq7PuPy1m9x2GMWxjNUGVi3PShC ZbUBV98VTPMmfeqJW5qL/q+PSqB3+ZgE0FFpUb+KnvgCgDPMjZ4NXoHzjdzR0Av7BjIFVC+G20IC UjK5qhuKtz0zVASYDDNQHGfpQJj9wximgE9KAQ/nvTvLZulKwxf9WpDVXUlnyvrSswNLcwj5Paqn mjdzQBY8wEVFuycCmgJxleTTHww4qiWxqRnPFSMhHWkCYnGKiKk9KdiiMwt1o2kcGpa7ASAADmm+ VubIpWJ3ZYWMjrVSeOgpEEcWOTVwbQM1RY3O7habyp5oE2WVlGNveoWznPrQSIFGdxqKTn7tJgIp HQ9avxuvQdaQE5cBfmrNb5nJXpTSHYjZWzVqJCBmhgiWRhjmoEYYIoQNDsc5qrJGzHIpiLEEZ71a kCqvNKzAyy3PFSAkimA9QAcmrwdduKmzLKEnzNViJeKdgEcgcVWPzdKTATZx70oO080AOLjGarHL N8tNAX48bfm9KgkHOVoaAci+tNkbHFNFXRGvzcCptuBg1L3C4wJg7u1KWBOKE7AxSO9PVxjA60El aVqp7nJ68ZqB2LqHK4PWnBcGqGyxsyMiq7DbmmSQbuamXgZqhpkgYE80SMFHFAJ6kKsCeasZGOKB 3IMnP+fWpv4aLgMU81I+MVIEKjOcUhU9TQAmewpBkNzQBaGCKgc9hQgET0NSYA5qgK7DJ4qeMVIE rcCo8fLmga3I1yTil+6eaBsQkHpSjjrUDF8wA1Lu3DNBLIMknApwbafmoET8MMj0qrIOw61UdxPs MQY6047j34qxpWJEQdSKd91+OlJgWXG5OOtVVO04alZgKwycirScjFACumBzWa2d/wCNA0y+B8gx UibSMN1oB/oUp4cHIqW3J4Aq0QaTMdmD3FZp+8SeaoBpUfe7U7cvagBdxPApyfe5rNlFl1OOOlVf unmkAvfcKQyZ4FNMCWIYO41bOW5HQUxMaWwMVDv71S2BIsxzKRtPWldM/MtMVhET1odB2qAGgcU/ eBxUvcVtQU5PtUhXHNNAV2YY5psYJb2rQW5akkVFx3xWemZH49aBGpt2p83pVVsn7vSgCPBPWpkj Oc0ASsCpz2pC+RgUAMJwOag3jPvQWSLn8KmVDu3GgVy32qFmXp3oGQ55wKsYGM0EMav3sCnlTnNU SSg8AGp1A60wsRPjPFRE8YoEPjHpVrbxzRYCBwBzUQ5HFBSK7A7qshsLjvQMcjDPNSuS4wtBJGIz 171MqY5NAixwRiqLHBxQBKp/WkkQ43CgkSKXHDVbxv5WrX6AOIwMHrTA22qAmWRRyal81fwoJZDJ MAp28VmCUl+vegRoq/yg0b2J68UDsSecFGGqPdubcOlK4ixneMLUEmVBB60NgUgWzV2In+KhAWGb PAoX5fxpgIYyTuPSpQuFp30AgI+bIp+CVwKEJaCbTjBqPGw5PegTRYyGHHWk8tz06UhCH5PvVV+8 2R0oAm6YqwjqB70FjC25sCrH3BzQA0/Nz2quWwcUASr2NaSMNuDTsS9xGx2qmyljxRvsIeEIXBqN SFbnrmnYDR6pkelZrKVfd71NgLyTLtAPYUjup4oAEbFMeQd6ADedvFOVhj5uTVITQqg7iT0qbbhs jpTBEhlAFM8wONooGVjGd2e1XE+7zQAwt82BUgXJyeaAHunTbU6cLjvQBnTswbrUIZyOpoAesrA4 Jq5ywz1qAJF44NBGT8tOzATYVIzVjOEpAEZBP41dIAFAFZ5ABgU2M5NAFg0BqAI3YA1Oj5UAU1cC wOBk9ai35bAqhit6npUXmKOD1qWUG8VIvJz2pAK74xip4yGHvigBNwD4pJZMAYpXQrMYjkjNIzGm CRLGw/GpgTnigbLy/d5qHcFbNBBG8yngUxSdwNA0Xmb93x6ViTyEZFBRVhJLc1ronegC4vGM09mG OKAIevNTAjFACdTz0qBgQ2e1ADvNHan+aMUAODrtJqLzBk0AQvJ6VTJYnINAGlbP2bmrsvK/LQBn pvVsk8VcZgy470mBVxioCm45qSWTgjbs/CmKNr5p2GjU3ZUZpQwxihBfUtqRt461nykhj6VQPXYY mScnpU7EUmFn3GZGKj2lm46VIyx90c1E7gjHegTIhnGR0oD84NBJbjGTUzkAgUARtwufWqu0t8y0 wHjdjBqZAc1QEzthcUsHJNBSZYlUryelVQyn60CuJglh6ZrSx+598VLQGUA3mH0zWgWGzBpoRV5O cVUaMlstzTAm2jZgCnxkKcGgC6SpFRlVI4HNAE8alaH+bpQBW5U5PSlLAjjrQBGEZjgVP5bDik0A hwvWmM47U0A5DkZqZZMcGquJjXYt92q2SOtMQBhmp0Kk80ATlP7tSjAHvQA3zB0NLvUCgLXKxOG3 VZV1dfU0AQlCT7VIBigC7E4AwajlxyRQBXRSTntUzrkcUDsVsbfvVcR+MChaCInbmpUkCj3p3AkM m4VADg80XQEhww+XrVUqwPNJgSKwUc0DLNkdKAJHI6Uu07cigBoVuuaUk0ASZG3mnryOKAIHzmkE ZbmgBx+X5TTlBHzdqAJvvUhUDmgBm/stAVup6U7oBNy5xVlQpHSkB+P26eboCapywXIO4qQKxNN9 zSs5WGEl4FbocIQUNJ7AjRF2doAPNbtrdvsGT2rCSNF0NKK5O/Oa6SO6LIFY1DuUbMEqheDVkzKD ljipRIpuMj5TkVbgl461YXCWZugqJOfmNBSdytM8e8BjzmrSJEU6igBrRJtJTk1S2uM4FAFNmYNz VWeR9h9Ka1BnNNcKpbJwayJZ1L5B5osZtkLXOOCeKi89RyDzU2uNDG1DaMbqzZL1ZMgt1o5RmW6K zbh3NdLpgbco7cUW6FHo9swTbjrkV1KOrRZY9qLWEzNlY5Ozp7VJbk9T1pgiWaTnFRLnFAxQqk5b rUm0Z+XpUsCTaO9IwGPl601sNGeY23bsVFI54HpTKJATs4qMKx+9QJjxED0609YyrcjAoFcvfLio yVIxQNFTaS3HSp/LJwMVDSGOaPYuR1qr94/NSsA0rjpViJmFMadiy/K+9VkJVvm6UDaLBZTzmqkk pDYXpQSTDayZbrVfA3YFAF9MBaiIy3NAERj+bcKsg8YqgHD0NRtjNMbQ/b8uV61XywbmgRNyRT1o GkBxnI61E5Y8DpQNkRUY/wBqm9B83AqWG4xWXf171sI/ycelNEjAm5s9akbhcDrTAqru389KjuMF OOtIDn1/1v4/1rTONme+KSY0Y0175RILYqSzuHllBHK5q0gZ2Kv8gB9KqSNsOVobETK4dOeuKQID nNLfcp7Btx0qu6jrQSIGwMCq7bg2RQBejcleetPA3HnpQBIY1AyOtUmAzk9aAIzzxUiKfTiqEriu ox71HHkHjpQMsnpzVRmOeKpASpk9ac24cChgRjf1oJYdahgVyWLcdKsglR71Nh3IzIT9alVcjJot YQznOD0p4jBwR1pgWUB6Hp0qbyR97FAFRpNrY7UrFWX3oAqhFLVaAVaaQFxXGMVAyc7qLAIXwMVX wrHn1pgKcjhelR7e5oDRiFQBU8XNACSAg1Ij4WgCs7b2wamVAoBWgC2CpTDdcVQZBvz71IFpEGOf SoiAH49apATSE7RUSkd6ZJJ5m1sDpU5ZSvJpAQDBNPYY5FO7GhFfPBpcKW5qWxkcox92mIzClqyV uW93y5qo5BPNT1KGE8YFRfNnB6VoWPHynipvvDmgl7lfGH4q5jKDucUCK2cHB4qTau3PekwKWDv9 q0YlHBpANn9BUC8LnvTQ07Cj5jVtCcYpj8yvICTxUscYxlqBXFbGcComOBQIEcjOKjaQscN0oAgK /MMdKuAKF564oAr5JfA6Zq9tG3n0oLKT8HinrIQMUAQuSxqQcCkwG7uaaeSMUhpFhYwV561Fsw3H SmhMs4AWqjHmmAofAqI/MeaAHqCpyOlWScj3osBWZj0/CnImTmlYLiuccUKFxmkNETruNNEeKVhk 6LzzU5UdRSQmKr9qikIx71QjNOd3HSranjBpoLMlVe9OKhhzTAp4w+B0q3xjmgEQnr8tSj7vNJlC gdxUTHnBpAPT26UkhPagBqL3NTFR3oAXgVC+MZFPoBVBbd7VOW4x3pXYAo4yaXfg4FN2AnHzDmmt wMCkNblcZzxU2M/eoKAqAOKhB5wagB5QEcU1cg7fegTLewAbu9RMueaqxJEHZeKac9TTATOTTqpA WE6c0/AzU3YEy9PaoyFzzTTFcgfj7vSmB2Xp1okNeZKZGZeetQDrlqhMp2LaN27VMMA5qiHcZId4 wKfDHg5NaIQ6ZsdKpZJpgOAY/LU4h9RUtgIybeRSLxyetKxRJ5h6VG2D1qQJFCkYqMxYbIFAIl/h 96crkDBqgY3O4+tSbMiqWxNyi4dHyo44rQil+UBzzTDVkpkA6Gmh89TUAPX/ABqu4+fjpRYCyowB jrUv8PPpRYTKzqMEiqquVYirEiCRyzY7VqWqKBk9aAZbl6YHSs9m2ggdaBDocsea0eF60ARSYI4q qikk0ASlOeelIYV6igpMZ04FO8zAoCw9HJFREfN+NVZDFwc5pxc9DSaE0WVA25HWpV54NNGb3HFQ OaaGPTtTK3GnrTyF2+9BJECQeKs+Z60XYiOQ5XjmqSsQ2KBolPTNKvNBQ7aQfarCEAe9CEyFpWDY HStCI7k+briqtYkryEqTiqBYls+9T1A04VBxu61ckUbMdsU7IkzRGN+e1WN4QACqQD85Gai61QCK CTipXUqMigTKu1nB71Ekfz4PrQCRpbQEqruIzipbGVySzVdjB6HpSILQOz7tQyZYZPWgaKgB3cVf RSBzTQNdgPB4p4J71Q7ImLnbgUm75eetBJEpy1SMdvSgTYqZb5jTZOeKBXEUMBwKsKzd6BpDJcH6 05Iht3UEjCuTgdKlCKBz1oLFWMbs1JKARgUAQDIGKgK5bNAFlRkAVZHyjnigTREz56U1W5oJLisp 4JpjxA/MvNNMB8ZP3T05qhcswbA6U3sA6AAjJ60yUOp+XpUgSwHPD1ZliyMpzQBDGjZww4qZkwfl qkwDJAo8w45pgICG61IFVeR1oAfuJ+lSBlx70ANwM5p2/BAWgCyCMfNUTPjJHSgNblM/vH9assgW PjripbApJzJ81bGAqAr6CkBmyO+TimpMwPzcVSGaAkVhyeacpydvakwFf5OUp8bsw+akIhcjdinq cfd60AXk5+90qV1UL8vWgDPKktz0qzGVU81SAsF1IwDUJGDkUAPLfLzVXClqCkybaMcU9CRxUjEc E81LD6UAOkHOe9QncfvUrAAyOO1SYyOaYEXKnirEbNuyelAF1pcLhTVMyE9aCWIqkuPTNX9u1c0M QxXzwarTIrUFK42CLBzV9jtHFAwVietDNQAgLY4pwbHWgB6sc1M2NvNAGc3XiomLUAMLvtOKiR2L fNQBM5OOKZGecNQBf4QblqdJgeGNAEhwfu81A77Rx1puzQFHziTirCvxzUbBoTLtzk1cVFIyKAJR jGKjXl8dqEJlo/LioXG4etUJMYAVFMJ54qfUoXj8alUgDjrQBEWYnHajaMZNCsJke4dBScZz3pEm jCOMiiRTnPpQBVZi3y+lPTIGKrQC2iA9amZVA+XrTAqspIqS3yrc0FKxPcMSvHpWahAzu4NBJKj/ ADj0zWpvHlY9qAM3J3EilJJ4oAmQcZNSFQRmgCr/ABYpMHOaALS8iomfacCgCRZT3pxf0oArlyxw elSAYHFAEyHac0ryelAEG4sfmprgY+WgBkZYNg9M1eKDGadr7iYADGO9JsB5NUIgKAdKeoxzQBNu agNnrQAYGc0hAOKAQ5k+TikjUgUATfNmloAeBjk012B4zQBLHjFOY46UDuQYLdacowaBCOKAuRQB Iq460/apoYC4x0pjc0ANCA9akChTQBFJ1yKkV/lxQA4NzjtTnwMGgBpwV+Xk0+PIHzcUANJXJzUf mYOB0oAlxuwaa2cYFACgsBTtxPDUAPSPLZqR+Plp2QEPljqamBAGKQH5H2kyRsAQD09K6F2jmjwA vT0FZGpz8tvtYsvHfihAdpBqG7jSuKrkSCt+Kf5QB+lS0UtDVgc53GtmOfkDNZtDudFbSZI571uC 1a4xg4qRGgLAxx8nPFSwwY79KaAbKu38KypbzywQKbQ0YLStNIGGRzWvHLiMKT0oSGS/bREOTn8a pyasgBH+FHKJmUdTR2Pb8qoXuqIkJ5559KpRJueevqPmytgkcmoDckNnJP407aEjXudwPOKom725 +b9amw0zlNQ1hoiQuTzjirGkzTahKBhufXNPYdz1GPSXESsw7D1rorG0KY49O1Zvcq50iREYPpWq hJXbQJu47O3g1YTAGfWga3ITkvn3q8i5GKC7ETxEHIpu/aOaTRIofdxS52nNNLQaLG4MmKy5I/mJ 9zQUNV9vympjJ8vA/Sk3YBsTYJJpJLjnAH5UrklUzEnHPNTjOAaY0XEbA5p/nDIGKkZKSHWqO3D0 APfoKkTGKAJeBVORs8Cgp7ECgk4qXyz9aCQ2mnFNo3UACSZOPSpTIOlAD1cHj1prHac+tUtAJV5X dVVjlqZZcRgF554pjHPSgl7ig4FVjJhqATANuOanLhVwaAbKYf580kr5X0oC5mgnfn3rpLfLoBQI vH92p9apK+56TAskA8Cs+ePap71IGMI/3hPvVmTKxk+1VHcpKx57fs0k2ASOf610mlN5aLnmtLAd ip3gGkkHHrUPckjiHNW2bGKAE354pCmRQBCE5qfaCMUAN8vaN1KkmTigCQmqEhoAYhya0lYAYqm7 AU5TzSIaSYCk5OKYRiqTsUPRsc1dBBXJobuSRBxnGKa43DipaAr42deaenz57UgG+Xh6tZ2rQBWJ 3NVuPgc0ADSgMKtb8x/hQ3cDDl+/TlUketC3ABlWqxgsM1QCj5TVgSZ+WgBrRcbqo/dbHvQK/Qtj 7uabjPtQFhjDPFKnymgZaZdwqHZxigCIxYOalU8YoAjYkHPaoi+WFSBdHCfhVbd8341QFz7yfhWe 2Vb8aAJVXdg06QFRTAjjY5q0ZOMUAMx3pg+9nNS0DLHUUYwM0yVuRs+Plqs2etJooF61IzgCmVuV t/NXY+RmgkrSNhqtRyfKAfSgCNxn5hUI5OKTHYkPShX20IRG82Tinhdy5pgSR8HFTsQozQBCJcmp 9/GKAGBed1Ndc80AQA4OKUpxmgCDdg4609mJFBVh0XXn1q4w+WgZSPWk70APxQV4pNAR7aX7vvSH cnRs05jQnYRCXOKhHzHFUncadibyu9N27aAbLGBszVbfjNAhg+ZqvDCrQBRkO41IicVJRYCYGTVV 5NpxSbAj83irEbbhzTWomhQvJNQyLzR1EtyREyKGixVFEgOBimbuaCSI9c08fMKBpjQMHmpCeKTG OQ0Mm45pAPC7RULNigBivzTnfvQBFu38U7YcUAAXFJs5zQA/P8NN8v8AiosAobtS+1BSRIoFNY4o BiA5qJhzxUDJ14Xmoyfmpp2FclL8AU/+DdVEMpZy341MeVxTSBMrDhse9TZobGSr0p3ekDLO4bce 1U3BLZFNIXUeB8vNMA+alL9Bj8fNimOvpUrcCRE4p5ParsJsevHJ5qfzMCrQiFjv5pETmmBMcJzR 54bgVL3AUtkVWPXik3YolC5qN48c1IESna2a0UcMuDQBH/FioZBjpVAOjqwGw1UtiXuSsAw6VTMJ znOKY0yMqRx1qRVPWoBsn3Y4p2e9AiVDk06R+MCglsp7qbszzVgiMpg561Oj4IAoBmj1TPtWY6Zk pp2EX0Hlpn2qs8pJx70hpXJkGRzUqkKaAaJWYY4pgOQaTdhFcrkmqzKd2KafUonQYqU8c0DEWQE4 pXXPNVsJ7DVbbxVlW5zSuRYnZ8jFRb8CqGhy/MKXZzQS9yTHaqzqQcigQ6P5uDTXXa1A0ri43Yqb ZtXNVsihQcjFRFeetSFwKd6tRNjimmJoZMahROM03sSTK+1qsST/ACY9qlOwrFHzeD61EGLtVILF 8cL+FMB5qxMtKdvNSFw4xSbAlXCg9Oah2jduouAjNn5arOmBmkBWXhs1cL4HFITBJN1Iz84oFYnQ DrU7MMYoHsQq2TipG+UZqkwI1bnmhzmqsSMV9lSl99ITVyyj4Xaahb5W3dc0BYmEw29Kj86gYz7z Zq8rfLsptWIJFXAJqt95/bNIssk7Uqnv5oAVpPalU7hmgCaM80krE8CgCkGIOPWrqRk8+tBBIUI5 qwknykGmtwBPmc4qndcHFN7BbUZD8vNTPMDxipAp+ZhuPXtWrDNx81AEzyLjIxVYSZNAxHcUzGVz VJ3HYiTg1YznihisWV+7UBB3ZpIQ8Pn5e9IBhgaoC03KjBqqx420gJIV28mkllxxUsCKNdzbunNX Wk2rigCrvyelBi3fN0qlsUn0I8FTirSttXNDYNCrJvbB/Wr2dq8VIrFFvmbPvVqNO57UCLe8Y2il DfjQA8kbTWUzEyED1oAsLkEGrucinuAwtxtqLbjmnsUlYeG7VYGAM1IyZSGGKb9w5oAY03NHmZHS gA3g8U7pQBEz09ZOMUAWFGRmoivzY96aQnsXlwibvSq7XIJ2/hQ9wSHIuTn1qWRMLmkMrxy/Nt9K tNyM0AOQZGKHXbzQAqPnikcc8UAKvyigtu70AR4xzUZ+bjpQK4uBjFQFNpzTsFyTjbUQX5s0WGWc /Lj0qkcl8A96QGknyLzzUDndmm0JsoEEP+NaKRFlBpAkKYyDV2N9q7TSY73Gs5BzQkuDuqSXuXd/ mD0qROvNUhDZG9KrDmhosd5dNPympAXfUe7dxQJkew7qs+VkA0El6N9gwaezhxgUAVAuGz1q4qgj PSmBJjAqLdzVAP3jpQxA5FA7EfmbuDVOVO4oEMiGSB71qhPlxmgCu3yZ70I2TQBOW7ClBwMetS0B Gy87qf8AwUAVw+0moHbnNUBNGd3FT7MDNAEIHzVcC8ZoAbjJx0qXycDNAEBXJwKcV2rTW4XIA3NX UbIxVEsYw2nd+lPD5WgCIHLYqz5XGaAGe1IU75oAb0pucGgaLYYbfwpQ+O1AMaZBSB8UCEZsioQC xoAtL8vFBbn1oAlB4qFmwaAJVO5aapw/tQA5254phJ4oAnDfLmmbs0AIGwaaz5OKAJFTcKDHtOaA I92DUnMgoAcg2Ng81ableOKAM11OakWI4BoAsJxxT+hyaAG7wTikfqKALEb7VpH+Yb6LgQh85X0q BjhsUAfjVFdkHk8/WtiPVBHgOxx9ajl8jU3Ib2K4XC8k8dqdIQp9vas2hoYZEC5q1b3UWQDSsD3O ijlVgNlXFk2HLVLQzasrjdMuDxuFepWk8SQgt1x7Vi9xjLm+jwQprIF2ckqePrWkUSxTc7gQTz9a x5yC3PSnYpNFQ3MES88H8KyptUjXO04oSKujnrjWFyfmP5//AF6wptXB4DH860USG7lE6kVBO4/n WPLdzzv8rErnpk0+XyJugyVx6mroP7vcfSkxdTJnugoYA9qyVleR8Ank1NkM0ItIa7dSyhgT3Gf6 V7b4a8OwxKrtEoO0fwj29qzbA9FnsYwoVVHA9BVBIUiPzAVBRYLREYA5/CpY179qBpXKF0205FMg lLYGaCjaRRjJ9KhkYq2F4oGWo3GP3nNNk2sDsFAiqqFTk1MSMe9Go0Qnd26UnJB9aCiiFPmfjW5F EpAyM/hUskguItv3OKqrECMsOaFYLDvs/fFN2449KGxoCcCkQg0hkhV+o6VXbd+NAD0DEfNzTMsH wOlAE3zHHvVlY+MtQA0lFapwVYcUAQEqDQfmXAoAq7CDxTCDTSAjBbdgVcCsRluaoBVJB29qmMZY ZWlcoh2sOtOQ/NzQF0WWK7ePSs8oWbI6UK4t9iRcIfmqGVt/CUxBGhA+ao5SOgoHpYbDH82W6V1V v5e3AHP4UCILj72O1VztRd3Q1Nn1AiWYZpZZVK80NAZgkTf+NTTMjQnHpTSY0zgp4C1xkev9a6S0 h2xjjmrC+ptxtt4q8PmHNJgyA8NgUrAkUgQRcH5qlfJPy9KA0uR4alBI60AycHcKQJzkUCF3L0NV 5NuPegCJF5z2p7ZzxVAQHrzUvVRt60DQqDH3qc43dKasO6I0Q5watHhcChklcdaUZz7UnsPSwMO5 6UZBGE4NSITkfeqTdnrQBGSvbrUoDEZHSgCLaS1Xx/q9o64oAyZY2DZPSp4nTG09aALmxTyBSnAU gcGgDPKsHyelW48Y96AJWJA56Vnv8xytUT1JY3Cja9Odh/DxQURD1NT9s0lcCRHHINBODntTBib1 JxUh2gZoEhnysKg2DNSMeQ2MCoQh38+tUtgNEY28elVXUZyaABOvHSrDAMKAKnyqaYxyc9qB2Hbs rgdah5VsmgRdQ5FLvGcUtQG45zSNtxTApng8U7tzQNEDrk8VOpKpQN2G7SxyafgjgUCQ/nHNM3AU mUM3ZNOyOnehCdhRHnmpgQPlpkkwKge9UpdzH5elACRqQeavblAwetA1axFuOc9qUtngUCISpzTX JVeelAEafMc1YIGMUFIg5U1ZVtwxQMbtwSTUOfn/ABoAuADAzTXxjik7gQBgAc00fMaQ7EwXHSnD r81NCHOFA4qKNfmzTAmc9AKjxxlulAFdnJ4WmhCeTQA8Lg8UpLZx2oAUAZq4q/LmpHqiFyQCBVDa SSWpDRF0fnpVodttMllgMAOfSm/eOaasNIkztHFMJ9aYyMmheaCSJ+TgU9PlHNBSHYJORTzwMHrS YDF4pxJFIB+75arEEk0AMHBqRhlaAGxjnmpQfmx2p20Ac5AHFRLkmlZgOxjk0mc9KaXcB4A/GkYj FJ6DTGKTzTe+DSKLHG2mKOTnpQ0A8kdBVZlI5pWYmRgknFXQwC4b0qiSLALZWpSvy0J2DQiEZPNP wBwarcBcZ6UvQVIEJYg89KUODVLYXUl3elMLenWpeoxnJ5o+bvUpAW4ge/SpHABzWi2BjM56Uh5G O9UibEQyOtPDEUwKzux7/rTo3AOGqXuNItluMioQecnpSY7olMg420F/l5qQuV+9TBsDigBQxzUv VcmqAjVsGpM5bimrgzQjU45odD2qiSBQN2Gq8AgHSs2BWcDqKjxxntTQDRnOBSEMDlulMli5XFQ7 vmwKoRZx8uTUC48z8aB2ZqlgIvwrPHzPx60CL+MJz6VQwN/40FXRc25X5fSqjblPNBIquc89Ksbx 2oGgyKay5GaChqDnmrDlduKAKWDu4q0qtj5qq9xPYibGcUoODRYm5fTDComQlvxpibH7GA4pVzzm gkYWw2ak8xSBmgBQVP3ODTmxsy3XFPQeqKyHJOKdli+D0pvYLkxwBUPLHipC1yX7q/NTVPPFO6AR 6FOBQ2INwBqXG5T9KQFBlIk9q041XaOOfWmrgS4pm3BzVE9dRXlRVx3qFWzytDG0NaRgQM1ZDHbk 1NxBn+Kmn5qYDSOw600ehpMBRwfrT9u7kUkBOvyrg1FzuPpVgSqQGyaSVs4xQgI88e9MycZqgGbu eatRuoODSuBOxyMrVfa5PNMgl6Lioxx1oAXd6U5XKnLdKCC8twhGKaZUP3etBYwliOaiVGJpXHYn wo+9TQwzx0ouIvRlT061ZaNSM4pgUTDl+PWtRY9qUEFWQ1ROc/LVbAXIODk+9VbsEtkUmwKqBulK 6sBk0ikJGM8n9as7scLSuDIstu5PFXlxt96YIqMG3Z7Zq2jDbg0DGleeKlRD1NBLHM2DtFSjG3Jq kIhx82R0qzldvvQBVO7PtRuAPzVIEobP3ajYD+KgCRSNuF61Ad27npQBYRRjJpTIFNBSAYk5WrIC hcN1oGVSuGytTeZ8uGoAFYM2BVzBVOPSgl7lMMwfJ6VZEyg80BYe8oYfLUClQ2WoEaCshGRUbyAc CgBinIzTWftQUhAD1FKzkDFAx0ch5p5Y5yelAERYE1aXGKa3AibIPFKJOMGm7BcMFjkVIq461IF0 H5OPSs4sxfg96oTZdJbyiPaqKA7sn1oFc1EccAVZZvkwfSpGjKwQ+R61eU5AHegZaUYGaQnJ5oAY cdF4NPUHq1ACOwxgVTDHdigllg9Oaa2Nvy9aBFMlgeTxTHkPSmhoA5IqVWxwaGUTbh+dCrlsimgL gGRijyickUmJlXaFkG71rYTaY/l64pCKmPnOelKR8wxSY0icoNmTVQD5se9SMvLwKfux0qkBCzZ6 1MhXFMBjOAcVG3IyKkXUSPHOaf8ALvpAyVgMZFORucGgkdKDtytQxPzhutAF1UJOe1DEqcDpQAu7 I4poU5qwGOrZ4qLLA4bpQMnxlcr1qMj5SGoERwjDkmrpY546UAI2COapFtp44oAmR8nmrJYUAPHz Din9FxU2AplDnNBAxzVAIo5yKuBgRg0ARshzuHSpYzxg0ANY4ORUqOWG2gB5AXlqr7tx9qBdRhAz U8bKo5ouDEYFjkdKQ/LxVXER98iryv8ALzTArPIAcDrUWWPPagLEnOKr4YmgC1GG71c25X3oArNG 2c9qnVeOaB2JDtAx3pirg57UCGOCfu1EAQfmoAsZwM9qVcP70AKwK9KcAMbjQAnBNWdgK+9AFFsh sds0pBxxQAsY5+b9aeQN3FAFgHC8UwZLc80ASFV6Uu3A4oAApzk0jNjigCMY6mpPMQDbQAzeM8U1 ySPloAEQ4yaXBJoAlAPSpc4XaaHYCqRg5Hem7CeaAPw6W65zn9aWWfcvB5+tBskMtNUlgmC9tw5z XapqRmVc/wA6loNjSWYMmGNVJJShzHzzU2E2a9jqD5Abj8a6oXIcDJ/Wk0Tc6CwlRSGz3z1ruIb2 Ix4dgOPWueSdy0zIvdQhUnY4P4is1NUGD8361cE7A2iP+1cMeePrVWfV+PlOT9auxFzBkvzIDuPr 3rlb29kXO3PQ96uMR8zOQmvpyTwcVDFdOzDdn8605RXOiixKoBPOKtY8kZqWrCGCdGPJHHvVa4vd qlFOePWpauMxQxlf5uhNdTY2aMyH19qzeg1qet6VYxhEJ649PevSrNhCoC+lYsZclmzz3rEmZjn0 qS0UN+DkVKt5t4PFBQkkySLyarxuqvwf1oA2RcHZx6VSe4OcmmkA6O4LHH9a0VkxSaAl3560pxjN FykRbz0FGSPxoGDLj56uwyDb7j3pWIKssxLYPSnK428df/r0rFJl2PLIT7VkyF/NIA4zQ0MtCMMv zdacsKqaQ0SOQq8elZLOS/FO4MtITipAq5yetIQHg8dKmDjGDVIClKPSnREgYNJgK4Gc0oIA4oQE Bc5qyqhl5qgGGNQ2RTjJ0UUgHEfLu70+OXjFJFbjXYk8U1R3NUFkPNNyR0oAY43KSeuKqJgNzQJk sj8fLzSRR7zl+KQJFohEwAa07bGM0JgyeQK3OelUZVyuBzTEUPL21GyEjmgCi8ZByPWnnPlnPpTQ 0YgGZfxrfh4UfrTEXFGTVvBC8UAVsHdn3qxzt5qWgEXk+1SEqKCrEDue1NzkUmwsgRzv21fOQox3 oE0V9v8AEetQsAaYhoOKUmqAeFDLnvTFyGI7UAO4LYqcjAG3mgCMkjnvTlO771MCOTAPFPA+TcOt Q2VYh5IINRplScUBZDmJLc1MqcUXJDyxurSiRduKAGuqJnBqi74+7zTsBDv38NxULKFIIpAaETZX FK2M807aAB2leTVHzCr4XpmkBdB3r81Q7cHiqAhKZbNWVQY5oAV0wOKavTBoAjYYPFP5IoARU796 Y7NnHagCaMcc1Jx2qUAwMc4qQ4xnvVAV/MYGlzu4NNK4EqqFFISc8UgFEYYZPBpjKAMUDuVkGGqR +aBDo8gc01iAc55pXAA+elPUZPNNATmMYyOtMCcc0ANEYzzTJAOgoAanAphOGoGnYkzkVXYc1Ias cq5p5THNAh4cjilAGdxqgHdTinFcCgCVFGOagdfm4oAsRoGXFMePZyKAGr83WoLgfLgUAQQA9KvM oAzQWU2pUyDQBYPK81Vxg5FAFlTkc1GeeKAsV3GKdEcVJROWI6VEHO7mqEywzDaPWmRtz7UCJW5w aM5XBoGiiww/HrVtDwAaBj2GORVVi3aglOw9ffrQZ2B2jpUjvcbuLc0nPegNg2DvUgCjoaAWo3G4 0o+U4oGPPNBHy8VQDAuaYcrQSSIoPJ60OPSgaYikjrTvvNQMm2DHPFVHbBwKkBw+7UeTzQBGMlqt fw0ANX3pwHzZoTARwM1IoAFUBWkJzgUsfTmgB3f2pSBj3qXqAiimfxc0rWGib6U/AxTKKpOHprSE /LQSPRcc1OVGM0CGL1qUmgLCgntSMoPJp7bARqSGx2qcgYzSSuDKbgdBUWMUPsJFuNcihkANAxvb im5OaAL0JyeafMBjiqWwmVo80rfKc0xJ2IS+acMEc1QEL8HimquTk1L3KRZboBQoyOalhZChOak2 jvSEtxpVQOKj700MlUZNSMcDApgMAHU8UZw3HNNMDRST5eaeJM8HpVEkJHzZFTZJHNRYCvI+Biok kJO09M0Ilsmb5RleT1qLezdaq1hD9g2k1VAw/FMDQXJXFRFMNmgpFpfmXFNK7DkUCaJQxYYNRBAW oEWCdi8VTY7utAEB9qUZoGicdqsrjGDQUOKgdKZjJ5oAMAHIqXJ24prcT2KhX5smjAJqiLEwbZjF W1bIz3oJJt3ynNVVOWxQA50qApxQUiJWKtxUxctw3FNDHrgDIpQMtmhkiyHtRE3PNIaJZPmpUAC5 70AyLqxB6UjkKOKCSFRuOTV9No4oQCsqdc01fQVQDyxUZqu0pwaAsVgPMPNWgNnFADtoY5p5xjFS Jke/HyjpVmIfrTQiZkxzUO0E80MBGUdqkjpAPfrxQAMc1dwIyBnilwMc0gIxtzjNWNqletMCv5a5 qVIVZuKEgLTR7F4qJDyQaaZD0HFSTUbqBTAREU1DKDnA6UmxWI1Ug4FXViwNxpXYxrSEcVNE5NId yzIny5qsg5waaEXlXbyKnEhPBqgEL4bipWlOymiDOZyTUG4g0MC35mFBHWmEl1JpDKqswbBHFaAG 9eaCiEpt4Xmo8Y5NS0Ai8tjtWiFULnvQBVPLY7VOqgc00wGF8HFTbyFphYauGO49aGY5AHSmiWOP CZ74pIiG+9xQxE7cdKpsM0gJocAc058GgCIcdKsoM8txQBG5xwtVOWbmgpIvx4QcU13JORQMnjww +fiopRz8vNAEsKY+Y1cZuMUEsrAAk5qCRAG4oHuR5wOKgaU0A0TLOwXimCR2fkcZoJNiI5XBpxRe tA72AN27VA/WgaZIoGM1GzMTtHSgYoUDrVtSMU1uS2MY80xQC3NMC50HFNDEnBotYLkhOBioNuDu piLYYFPfFVuATQBJF9/NW3YY5qCkUWY5+XmrEBJPzcUDLrvgYWoVYk80ASEgcjrTTISKAKwYlvm6 U4kA5HWgl7kqsGGDTwOeKBCMnFQeUp601uNAIsHimmM7qZRa2LtGaXhRxS2Acj1aWXtSAqycvmpV cquBQ9CUOXJbJqfjNTuUTnlcVSIwcinYGWFyVyaj/iwKRKdgINOXpVFBt3Hmmudo2ipF1HR+ppf4 6Qy8FGz8KrcBuKCCwp3DB6UzygHBoAvZwmFquwJ5NNASxAE/NxVwqAMiqArEHdTWjB60ANxgYFLt yOaAICMHiplHGTQVYeQNprGmJD+2am7EyaPlc96tKCetUIuR8HHanv6igCvk9MVFLwKAI4ySDTGY qcigC7BLvwr8VckQKMrzQBS6tg1aVNo3CgAJ3gg9qqdGwPWgTHnJIzTivAxQINxUVWaQk80ASKc1 ITgVQDdmfmPWnIedp6UwTsPbIOB0q7CisPm60DWpKUAPHSot2GwKBPQlYjApOAuRQO5Wzlsmpd3G BQIh3sG6VNjdyaAHYB+U07AQZFAEW4seaVmOMCnbQCaJcjJqcuF4FICuw3cikAOOaAFUEnmnY+bm gCU7eBmlxgbhQBHk4zTBIc4oAeZCBVQsWagC2uStQiMl+fWgCR02jinQ8n5qAJHfado6U3dgZoAa JDu4oLHdzQBJ1FNyw4FAH4JjcgwTUyEqeTnNOxpcueT5g3rVyCYwMFbmk1YLm19qyoIOPxqVL5Qu G5/GiwXLsF4u7jAz710Anwu/dnv1qWrkiJrYifafX1rW/tgyx/K+Mj+9UuIbGBPqjoxLOSM+tVV1 znr+tNIlu5b/ALY3rgHH41VOpbTuZv1qmhpiHV1PQ/qKgl1KNl5wePUU4oLmNLqMeCu0ZPvVNbkH JHFahc3tNud0wH9a6q4QyxhV4JHb6VmwucxNBJb5Yk8/WsMSM0vOcZqLBc1FmClRXZaZcKCpJH4m olEa1PVLC8UqmCOnqK7W3nBA+YdPWuaSNEWHnA75/GmGZWjI4zj1pJFGM7YJPWs1y0jYXIqrDTIG V06k/rTVmKsMmiw7m5Bc7ht9qZO5B470gJbbPWr3mYcD6U7AW/MzirO75KTRWw+IbjU7L0qRjpF/ d/hWchKsRQKxOw3rkVUQkSbfegWx0sJ/dgY7UxkGSxFBRVP3s9qbJJ0qAIHO5KijTuapbAXlXioG UlsA1IEmNq4PNVCDnNUAK2WwanZcYxQAGPcvFVMFWwalaDSuSHnFSbSBmquIYTnikUYOTTAlZ8jF Iimk3YaVy0ExyaY3XigdiPfg4qTqM00rhcQjKmsmUFW4psNyzbxFsE1flHlpkUgMFpS0mOeD/Wti GUhNvfFAmWgx9alTjk80CInYbqfwwwBT3ArtHjk1mXDDaQKYGTEMyfjW8BtQGgCSE5bNapcbcYoT uAxcZzVeaUKcYpMBiSjB+lVXJZ+DSKJl4HPNPBqWMQL8+6r3mgKFI7UJEtkDtkcVAEJ5q0xDvams vGaYkrDoz2p0jYGaCrECfO2elaA+UYPNAiM/Mc1EeDigBpTPOasKPlxU9SkyIsBxSrgc1WwXIi43 VOrZFSSQyybOajW9AT8KB30IRcGViBVnG0ZPNDdwSuU2bc+BxUuw4yaBFiJsU6T5uRxTWwFchsda jQfPg0XGlc0OmKsDBX3xTEREjpTR60ATBs8VWl+U5FAESyA8VeQAigBj/KahLg9qAHj7vFQ7tpxS uBIhyaH60wFUZBqLGGpp2AkLdBUgYAZNDYDPM3NgcUpXjNIBgGDSk4pJAOz8uKzJlO4nNICSE+tW y1NAWo+mTSswzjpTHYhkfA4qmp3Nk0D6FgnAxTNu4UEjNhXmnjmkyk7jwQtDNkZ9qQyuOtPY4FUS 1YdEe9Wd2eKYhfpUbHHWk9AJIH5zSzSZbFSAL0qBk3GqQBt2DNQl92QKClsMA5qYcUJ3GSEZFQH5 eanqC3Hq24ccUAYNFihWj3c+1V9mGoC5Zx8uT6VTZsEmmmSyHcWNWVbHHemBaXpmk2kmgFoRFcNz SkZGRQUG7+E08EdKCSGQY5qEjjNSA+M4PNWywx0oAgKk8iq2CG5oGi6jALzRjecigbApTs7RzzVJ 3JSuODDGaiZw3yigdgWI5zmpOhweaBLcjk6cURHHWgoWVsjAqmEOcmpAupHT3AUUAVR97NPxk5oA HOBxTQ+BTSAT7xqQ8CmBF1pMc0rAP3YFIuWNICdjtFVG55FBSHq+0YNLvzQD2ImqMdaCS2vIprnA xQDIFb5quYyM0CW5KvA5pjHJ4oGIKG6ULQCp0PNLuzTewXL8PSh0zSAiHy9akI3DigBiHa1SPzVA OjIBqSYZQ49KadiTDOQxqYPxTuNEq/NUjfJSuMQHdU/QVLQmx69cUrr8pPtSGUd/zYqbtmmgbJkX vTm4piRCTngVInHWnYY8vyBVhRkZoegNE4IHXmpeCp+lTcky25kxUpXAzVEvcYGycGpsgCqEPHzA 1GF+agC4pxxUcjUANU45p4fc2MUAWMYXPtVBn2t+NA1uS+dlapmTLYoG0W0HGatCPK5oEnYjCYY0 zB34oKJWU4zTN3agCMnByasxuG4oJbFlxjAqBEPWq2EPIp6vjihO5LVi0BuFQkbDmmIk35XNM3ZB FA7ECL+859asyJkZH6U0CVyoAQas7wooYbMPvjNMC80iiz0HPNVmlw2OlBI5mwuap7txoEWgwxio mYrzTsA3cWGc1PFJzg0JlWLUjZWqwHBobGJGcPVlxldwpEthEM8UrRkHOaCWhu3vVuJqdxFhnDDF V9nemncAVCTUpG0VPX5gKORVZ2w2KoAHIzUTE9KAKbBgc81KshAoAlDl+BxVyI+WdzGmnYGrF9pA 6cVUQfPx607iexqhPkzWTcNtyfai5JShk3vitNuF554pN3ArKRnPpVrzgRtFIFqUZOTViA7CM+tA 2rGqSGXPtVXHz/jTEWDIFGP60Kd3IqgHEd+tNY7hgU0yWrESjHBpxj3DimIZ5BU7iePSpkcZ21IE 7QgjcKQDHFBSF2881DMnHFJjIE9O9TnIGc1IEXmc4qYGrAayZOalPCY9qAI1B5qQOF681SE0OLbh ioghByKG7Ek4PHNJkE4qQInBBGKcQdmaAI0faeeau7tw44oAgLbTzzThhuRxQUthp64qyq4XJoGU 3k+bAq3EcgZoAtZ4wKbuoArGXDUp+cZoFYh6ZBqLbvagRKIiGAq7sCqD3xQIEbBzTnkyeOKCkIJO MUvWgYuPepVYA80AMc5PFN5XFAnsTFsp+FVlb58VSJNDftUZ5pN4xupgQm45qbzRIuB1oAhBIfFT sM4xQBPHwKjkYnpUsadgjXnmr23A4pFDd2OvNODBuBxQFxCMHPWmmQCglsYTv6cVXwd2Ka7CHHKc 1aSXgZosBP5oIIqIA5zTTAk8wLwRTt4IplJkX3jxSMOKBkSHB21MQV+aoAlU7hVtFzQBISBxTAMn NBJZzhcVD3zQUPMoxtAxTUXB3HoaViCww3DjiogmM0wIw/OKY6EndSexSZKhz8tT7Mc1IMcTxioQ uTQSWV4qbNADlbB55qUyAjGKaArnO7I4q8HwnPpTYEJkGelMPznihKwEu3avPNQ7+1MBpOOTQPm4 HFBfQdsINRzQ5GRSSsS1YZFHsBJpzSgHApiLMZ34xxV0JgZPNAEZWqUy8UANiTtVg227mgVysYjG 2RVpZMrg0DI8bn4q8OE2mgCsflz71W6Nk0A9i0BuGRT1FOxJE/FVCuTRYCdEIoPWmBMOlGzuKYDu AMGpEBJyDik0BK7YXFVxyCfxoWgLcQEscVPjjFMpkZjNPReeaCSQrk1NgIvNAFEvl+KsdVx7UAKi 4BNMAzJigC7jC1QcEsTmgCSJ8HBqyzDigCRcYzUMh4oArIGZq0SvyfhQBBuwCKhB5oAlYfLmqwTJ zQBbSQKMGl89SeBQA1mzTBx0oAZjc1WPJOOtADRHtPNDdaAHKcVNkU0wPwOkcZyKptKcjHaqsyro 17aUhMseKe7qz7l7UmgJzLmPah5qFJCGw9ArkrTspBQ1rQaj8m2Ru3rSaHco3N4hbKHn602G/kU8 t8v17UrEtl6S8jlTGQWPvVNJEB+amkK5Y+0IoJz+tYl1cykkxn5eadkCKCXE3PNOW4m3fMeKaQx5 l3H3q2jYxVAdVpnEiselekQlCqlvQVDQ3YydTkh24BHfuK5QeR2xu+oosidbiMnBYdulVFvZIXwD gCpaLR1Wna4yuod8D64716Vb60XRfLfPA6H2+tYygO5uxanuUb25x61J9uYuAh4qOUd2aKXC4/eG rKzQdcj8xRZFpjZpYmQ7SCaxQC0mB0zSaGbttC3GB2rfW3Vl+cc0miiRIQh9qpzrzlanUYkIY9as MzfdFIoEmKdTitSKYMMsaGL0JfOQnbmq7qN3HepGPwQtJGELjPXNAHRwKuBmnzqNvy0gMnYeSaru B+NJICi27PHSnxhyeOlUBeIZV5qr827I9aQE21yMnpUTccUwIANp3dqfvLEBaALsZ45qGVQenWlZ ARxjB+eppTlcJRYCNAADu60mMk46UwG5UHmrAIx8tIsjaQg1IpB5NMBjAE8VZAAXmgCEsM4FQmLc csKBF1FCLxVWXJyD0oGZu1A2e9acIXHNAk+45j8wx0q0HXZz1oJZTOWbjpVtMAfNQA15E6ViXQyC Vpq47MwkLiX8a6NMtGM+lDHYnh4bHvWg+AuaEJobGc1UuOtMRCOFqA53cVI12L8XI+brTiMH2pDY 4c1IRxTJKZ3Zx2q0nCH1pqwFf5txIqUHs1MCcbAM96hYqc5oGmQqDv8Al6VeLDADdaAZGXUDNQFw elAhmXz7Vb8wBMHrigCkWy/41Mwbb8tF0BXVHJ5qxgrUjsyGRGceoqj5R3YIoF6l6KEKM4qVs9+l BY+OJSd1SybQMe1CIK0ZG7Bp8mf4elNgNVlxhutG3ncKQExyV461CrsrfN0poB28FhipieBimBKC AM1ExDcUmBCIjnOKsjKimgEb5h61S7/jQBMrdqGjJ5FGiAljQjrSSg9qLodgiPY1HJndlaYiWMAj LdaXKk4pABTuKgZyDigaRIORmk780Ax5K44qi4LHApMRPEoX73BpZB3FCAkjJxVedyp4pliRkvgG rRQKuR1oJYxRk81YAx9KARGSCcU7y+MipGQlTmkPHFAxuO9MJ9aaExA3pUgb0p3DQlV8H5qV2U9K AsPTp8tIyHOaLIkAG/Cmknt1oAgYvnBp6JQUthSMHNSDBXNShkAc7sdqc3NUBF901Y7ZpMeo7fxi qxJ3c0tASHMTt4qNF3fepoGiQxgfdpAmDk0xFpSKeWUUARMyke9RqR36UD1A7c0DGaBEjplaoHOc VIInReMmpcZ6UFDAcHFMdecigB2Pl4pASOO9AMlBIHzVCW3HimhIQnAxUYB3Z7Uxsu+YAuO9QZJO aBL8RrEnipo1wMmk2MSQjOBTFB60gJMkGlY5HNAEIxmpD0+WgaIgDn5qmKgjjrQgZX5U0pz3qhAF PUUpzmk2AEVZiKAc9aQ0Ml9ulQgZGB1oKICpzTwMDmkJgCCaedoFAJaCoeeKc4zTJGhVHJoyScLR pYXUduI4NKDk0DLSgY5pjgdqBMrbajK4NPoJFpGwKcXyaRQuRjmo946CmgGZwcmp8grxTAaud1WG Py49qCTIlHPHWiNf71VZDRfCgDIqPBdsdaTB3Lwh2qCRUZHpSBCKMGpZGGzA9KmwzJAPmfjWuqrs GetGwmM+6faoJG54qgRAW9OtSKTVJjFIJPFW0yBzSYDw3zYNWN2BxSsSyJto+bvTN4IwaZPUgYc5 WpEPZqd0Mn+nSnAc0tSScYHJqnI2WG2mgLKMm3DdaMLncKYFpCGGKhkRc0DRCYuOBxVNoyG4oGy/ AhwN3Sr24LxQSLlMZqvwXzQUWGxtrNk4PFAyPBIyasxYH1oRAPndz0qUfd4qgBBknNDL83FJCZZR tow1Bw1USRHHQUDAFA7kJBzkVaXJXn0poCsVO6lKkj3pD3BNw4oO4HNAywhBGD1qpKBnIqSBUGRg 9MUeUc8dKYDihAzVaTkY709QHwxtjnpUjIVPy9apIssBWK80FcKRUsCOFcvz61pSIdnHpQSymh2n mpWfNAiINV6IDHviglkUmVORSLJzzTQFjcMfLVZmYnFMCZDgYNRMMnNAEmMClVN1ADvIyeRSeQM4 xQBZFuETdjtXPXcjqxCetUkA2CaXb81aEMp3/NUgbXnDb7YrOl/eE45oJaHwQYbIFaEqgJ83pVWQ jJ3DnbUYJ3VIEhBPNWIyvfrQV6k3mHOB0oJJGVoJKrF881MHZVzVlaFmKTcDnmpe9BNhNwzVyMrj 3oJsRPuJOOlUcMHz2oEaKyfJg+lVy53UFIfuOM1GCzZBqRkW1g/FSOSBg00ARpk5NTtgcDrTAh+f qelTqc8GgBzDaOKjXDHmgCyVAHHWhenNBA3K5INQtnOVoAnTH/LSnOV6DpQMgKrtz3qNSc8UDSJd hapD8i46UDGIwLZapmfsOlAFQ7T9akQkH2oA0QcpmqbE59qAIWI/GrMCsSM9M0E6luSIdhQqKoye tTcRGxA5FVTITx2popEitTGODxTGPXkVJhu1ACZYfepd2elADhnOTTzz0oAdkAYNRgZbIqiWWGzt 5qDLYx2piF2fKT3psWQxzQBYP3gRVlWAHzUASeYvY0hZWHHWpYFYl0PoKsxyMevSkUmSt1FKflHH WgTJUO4c1HIvpT0KsQLlTzxUuNxyKESx/H8dBAx8tUIco+XJqRHGcGlYBspXtUcbA0xkmeeKXDEU FAq4bmp3+7ioF6EcYI+lWTJtp6C1F81COTSeaO1IQu4mnqeeaB3FbGciplPHNAhxcAVEZcjFAFUA 789s1pAqVwetJgOUAc1G7ntUlJ9yPdxjvSxsQ3zdKCS+cEZWoxnkUAOAbNWFjOcnpTQExUY96iYH 8KoBNvFNUHdxQBeAyOaiKKDQBBIPSlQfLkdaCxc4+9TS+eO1BLGHO3C1VKnPzUCJ49wI21ph/lwe uKABc8k9KgfGaAKhJVhjpVzzvlxnmgTFDq4waruMHC96BrYmQbRuNI8mehoAYu5utDDtQBKjBRhq kLqfuUCe5VLZODU6gdTRr5g7FoFKY2zqKaEVC/zYFS/PtyPSqAgyc4PWrCMR1oAeTuOKtKo24NAD NmMmog3z4oC7LRK4qHcP4aAHZI5NQlmY4HSgA8s4z3pUDZ56UAWy6hcd8VXUEvuHSgCyxO2qJzk5 oAlTHWntlj8tAFuIHGDTXHPPSgBVKKOOtQGXkjtQBEXBOKXgYoAs9U9sVEASfloAGXA5qsqtvz2o A0SBs96qbX3cdKAJcbeT1qZZOKAG7stip9oxmgByqtQtwcCgD8A3PzYFJ5fGa1FY0Y8eXtJxSgYz jmgY1GKvntVpgG+fPNSBGGz8pqQQhuhpAZk0TK+Rk1ZjUsuDxQS0WUg2tnNOdeQaBDHUlRVF22rt ppXGnYpq+3NSqS7dKoaY8oVbJ4rRh2tjccYoGbEV2ISApHFbo1hkh4549/SgDnJdVeZ2De/rVaK5 YygdiR/OpsB3VtH5sIz3H9Kp3GnDJJ4pDuYskIhb5G5B9a6HTrxkABPbvmpaEdbBeszD0rqoJl2h i3NZtDTLTXO7hTnHpmkWd847fjScTRamgjsRgZNbVpHlgW4+tS1YtaHVRAKBjmrwf0qGyiVj8uTx VBhk0ikCkJxTJSFUvSsMxWudzYz3q7FPgYBqXoBdBI+cVeik3kZ7GpAtylgnyjNUoAxlGRjmkwOm UlVU+1NkuAE5PShO4HOXGohCVyKpLqEbNywFNK4F0To4G1gfpWhC2ADQBcJVxVB8qflGaAJFlJGC KjdcnNACMoKYHpVRcoelIC9GScZqy0Y27u9CYGaSS+3HeryRrt5POKYFKU7WwKEbjigaQx0JOaeu QKChjZJqwB8mTQBEGIbjmpy7Y6U9wEjXJyeKsSHaOO1IncrCYk4PApxII+tA9ik0fORViLPQ8UEi ucGm5yOKb2AmViBmoHnfoBSGkMQFjluKjnGF45pplGWiZk59a3kXCUMCRF+bNTyn5QKEJsZHxUcw zzTbEnYp5bpimZIYcVI/M0YucVpGJSmTQJshWNQeDUcp2igRUznmm7jnFAFgdM1EBmT8apKwDpOC BSMo2A96AI0kxxUhO6mkA3aSMVKsOKGgJimBVR0xzSewDo4g3JPNXVXtUgMc7DxUOd3NA7kZkwdp pcA/NQIkDDpULkk0FItRttSq5JZjnpQSRldpyOaeHyMGgBmzJzUyn+GhAT42j61XkANUA2OPvU7D HTmgBmT0pwAzzQBOWwOOai354PFADh0IFRFOcmgBVUZzmruRt4pMCBnIPFJnK80h3IlHJpHJq7iI d56YqVFyctxSAld9q8dKrKPMOTQUtiwvHFMfpxzQJsgUEnnipduzmgQo+Y5ofsKErAWIlG3NVJ0B NBZBGdp45rRzuXnigl7gqjkikZs8UDRGF5zVkyYXFJoGVlbLc9KjlOORSEmQq7HjFKwzTRQ0KcVK ic80WF5k5jB5zVdkw2KYF6NdoBqZmG3NBJXWTJIo+XOc0FWKrt83FTA/LxSbAjfPpTkPy4pJXGQM MNmpF55NUV0BgM8VMmCMGkwInXB4qJqQD+q4p6jFVsAMxzUjfcz3pJiZTVyCRTup54pgh4QetNb5 elAxnJqRPvUEl7cNtZ5HzZHrSaAfuOcVOB39aRSEKfxU3qKAIwSDg9Kj3fP+NAEjfMox6VGoweaB IUjnipR0xVDICvOamAGKBdRhxmn78CpGQ/ebNWhwMUAJTT7UAR45p2cdOaAI95zVhTxmhANIBOTx ULsAMDmqAWN+xqZxnkVLAYfu0wDHNFwHZzwaB8vNA07BnJpsh4wKTHuQAcZpjEmjYew6JiGxV/qM 0yCP2PFPRQORQLqV5jzUcbHNAy9uJFMLY4oEyPcad1FAhyr61IVAGQaBpFUnnFJ0PFNDJPvCkBK8 UwHhyDU+cjNBJTYbmqXbgCq6FFtVylCrtbNICw8vyhah4xmkTsNHOfaoHbkgUDuRoMuDWqF+UfSp HYgcelVduTg00wtYPJAGaj5BwOaYrkgY1YDHHSgLgoy2au4+WgRSc84pVUYp3Je5Iq1E3DUhrUlD YWiOTL4NWJ7l1xleKz8EHH86AsS+XxmkL7RgUCI0nKHirm8t81A0KZSBUIcMeaAZeR1AxmmuR1Bo EVt5J21eRPlzQUHfFRPFxuoGNVeMGm/cPFBA0kmno5zt7VSAnJ2DI71AJctmmDJj8xpzfKtTclK5 EpyeaceoxTQ7FhQCvPFTLgcVSYWIJDjkc1CHNILWLCgHk1HI3agTdyNfWlIDHmk1cErjiNi5FPR+ KV7BbUY8naq4UE5NWgaLG/YMCnI2888UxpEzPtGBWe8x3YoYy1E38VXml+THtU3sFiqPmOTxTti5 6033IHBF9akB2niouSyVxuTPfFZ2MGrQFhcipuO9MAABpOlAD85GKerBOlAEwkPpUoPOTQOxK8mV 2/hVIWKzNub+lUncRHLZCIfLzWb5bBunek0BfUHbg1HyrYHc0AbEGAMmpp0DxnHpTZBzRBWQj3q4 qZXPfFSNEmw4xioNpBoBjweean3YHHNAiRV39aSRABinca3Hwoo70TMUHFNDZn+cSatpMaZm2XPN 4pQwb73FAAcD7pzTD0z3qWURB+dtWgNo3UgHA5OahkGTxVIB6thcUvXmkwH7h0ppO3kU1sBE0rEY xxSI+OaYDzMScCrIY7M+1ArFUEljmn7sNigRMTmoWJFA0OQ7uDUu3HNAyVHxVWeQk4FAEChuOKt7 fkz3oAgVSW59at44FAE6n5cU3AOaAIjF3qaKTawX3oJbLckmFzVPzSeKVgG9eKTywOc0yiPoeKlA 3daAJdu3pUqNnigCOXOaETjNADyTjFND7aABuRmnxGqJJyQ3B4oZQqZFO9hFdJedpqVsD5hzQA3d xmowxY4pASUqNtbmpuNK5cYhwKZ9wZoHYcsu41a6jmgTG7tvSkMpNBRCWLHFSq5Qcc00yXuLu8w8 8U5zsXjmqEQ+cSpFLG2TzQBORu60gQA8UAWMDFL5gWk2BH5hJ4qQycYNLcpIcHwuahLb6LA0RBTn HbNTYx0oasSTBjUoPPNICel3ccVQETZojTPJpNATEY4FOGOpOKQCNIeg5pM/Lk1LAVBuOTUxUcUg LiY2YoHXmgCTeB0qTz8LgU0BB5p3VbVsjmqAYW5x2qYYAzQAnm4OBTd2Tk0DaFIBFR7towKAuZct wQ+33q5DhlDHvQIs9/akZNxFAEgTavFR5O6gCyCcYpvlZ5pJWAY0QqERA5pg9hFXa/tmrZQHBzT2 0BbDXxt2ioQnGaQCq+Mg0A5agCrM537R0oBKrkc5p2JJV55PWps9qLgGD1HNN3NuwRgUJAMZcEEV oRNlMGqAryIA2acOVoAE4aru4cUARvJwaqqcvz60AW2AI61FgLyDmgCMyk8VNGeeaAL+BtzUJ68U AQSJ3pqSbeDQBfXDDrUMkdAEIA6U/OygCVZSOgp7tlcnrigDM8w7tvvUu3IzQAoj71IFz+FAFjPy 7aYG2txzzQBI53LzVYMRwBxQBYBz1p5baPl5oAZ9/rxRsxQAmNpzUu8baAHRtzzUpAJzQB+AIXua sKN3ArUSGsjKakRuxoEx0g4yKiBJXrQIYM5q/DkHJ6UAWXZCORzVTeoOBxUAX0IxuqNuWwKaQA5C pzWVIhfJHSqApCMltvvitSOMQrvf61SQEE0ivnb2qhuYdCRSYE0W934JNa5YpHtb0pFIyz9/jvWt bx4IkP1oGd3p10gAU+1Xr+5TyjtwCR2pJWA48K0khcnK5qx5ojYAcYpSGjZj1BI0BJ5wKuLrAI2q 1Z2GbVnqS7hvOcnvXVC8iKBhilZlI1bO7jYgHBrroCHx5fH0rOSLTudHBGxUZ64rSEJUZNQxopy5 6Cq4z3qS0yFg27ioLkMYSB1xQWjnBE+4nnrV2MMGGamWpR0cbgx4PpTVbbIMdM1BB0MU8fl4fnjv TA6eZuXAGaLAannJ5eO+K5e9mK7iGwMmhILnmupah5e75vWuM/thjJxJjBrRRG3oddper7mRWfOS BXqMFwJIht6kUmhEqyEP14zWkMFdx54qWgIT1yOKRjkYFIBicN83SnsVJGBQBMMBQRxUu/8Ad81L QFRcEmj5txweKYFKfOc1Jb89aZS2LrY6VHjFK4yIstGcjimBKi+tWcr0xTQEfRuKRlJpSQFdxheO tMRSeTUp2E0Wlx3oLqvGKdwWhVcFzxViOIgZarWwrCMRuwKk2DG4ik0MiJH3V4NV3jJ4NJDIRCVO avA/Lj2qgHK4Bpz8igljoUJNWZI9oyakEUmK+lQHH40FEsWQc1e83I2imwI1zv8A8+tPnHy1NyWi mnHJ6U/cpPFNaiJR0pPunNUA1iG6UzaW4FAC+SQM05F9aL2An4FPBHWquBJuGKpSMM4qQIPM2n2q 9FIGFACumeaixgYpMCrIhY/LQAVjwfSpGkVlLb/bNaAGVqSiLdhsVKWAGaoBm4YyagJ3NlelMl7k 4PGKkTG6haBYsyLlcis9s5xVCLMYyuO9Sfd+9zQBAxHUcVFks3FFwLOdo+bmo8buV4oAnQY60Owx gUAVsHtT1Yjg0Mp7EnuagJy+B0pWJLGQoFOxuGaYEJKoeRTDIGOF4oAc33OaZEcHFBS2JZFPUVJG OPm5oJB8Z44qrI3y4oAfAw706QjtQA6Ju1QTg9qAGwp/eqw7dhQA5M45oyM0XKG7xnFROCeRQ9Qe wqjjHemspHJ5FKwluTRbTxjmiROc0yhUA70Px0oARTUZPNArllX+XFQtk8CgkZsK81AxbPWgskVS wzQp2tg1IF04KZHpVZVO7I6VQWuPde1KFwlBRU5yc0B+eKTAn3jHNV25PFICZIzipT8o5osFxm4V Hn5sdqaRI/aOtMb2obuUKgOKDyaaE0PGAKTHcUCGMT0p6L3NJspEpAzTwRwKQEj/AOr4qkh+Y0AS SDjiqPltnPvQBaQYHzUjsOg60IAXgZNBOeBVAMxTSDQK2oza2c1KOmKkZIgqagCMg1HuxwaAGk9x Td3HNADVcE4qz2qkgIWzjiqhyDzSaKWxZQelXlHHNIRExAPNQlgelNMQylB7UmA8nApi/MaVyyRk 44qDGODTFcesfO6nb8HFBIxjnpViLOOaAI5BlqFT0oYFleBzUD8nihAxwXA5oBG6gkH6jFMJIHNB SI+ozTQfmwaaAugfLn2pmOaYmBxSHOKBJXGipVG44FV0KNEJhKZ2NILlEg7/AGqxsO2kJsRBwars MNk9KAW44EZ4q8kg20rDKzSDd+NJvBIpgSvyvFNSPAyaCXuO2gninkACgBiglqtnhcGgCgyFmyKR cq4U0EtGqF+TNZsvU00Iq7jnFTAEYNUWaSP8nPpUZZSc0CsMLjpUfWgZAU+bNX0+6PpQS9xWGRVJ lZaAtcYC2etW0DHqabYi3twKsq4C4pFDPMGafvBoGJ9KrtQS0RbgOtTo6k8daaYiVxxVTYQd3aqA uIwxQWDZFTYV0VyCre1Shx3poY/OR8tR7iDimDJs8ZPNQjBbigktbDjioHHNAh6j5arsTv8AxoAk c/KKanSo6jW41kPWmgHoK0TG1ccI2J56Vb2bVyOKYyEZLYNRyxcg0CuiWNDjFWtuBzUjIH46cVCH I70iWgLnOc1Mso70bisWFlz9KiZhvAFMHsWRgJn2qqcs2BVLYknUEdaGyaAHZwuO9QjJbrQBqpgL zUbSDPFA7gCWOR0q2tysY296sQeaJPel8peuBUitqMZMCqu0FqALHIAxVqN8jaabQkVpbfJyBRHC R16VIPctfL0xVeSHdytAiqYW7UqxMDzQNsvKuBVGY84oEQIzBuvFXmIdMUwKy25Y8etTm3Ma5NUB WV/n2mpHz1WgVtSaEMetK+c4qWMhC4YGrRO4ACkVdEyjC470uMcmgLogZweBTw/G3vQJsaUYc03B poRIAMY71GYj1HSqAfHEd2TzVwkAbaBMgKd/WnCInmgkd5ZoJGNvepZSBFycjpT5flFC3GUvM7Cr CJn5jzVAXF2kEYppHzY7UrgTbQFzVUjJwKYDxx8tKFIOaALGRt59KqEfNkUCYjkkU1D2NAiyBTXQ npQUOSI96VsKcUmBKF3DNOX5TzS1QDzhqYzhRiqAarBqayd6a3Arse1WI/uE1RLI+S/HrUzPhNp6 0CKexs7hxVhDzhuaQ0WWHy8VWQ4OKkosBSTmo3jPUUALGxBweasN8w4oJuRIfLb5vWtDO4ZFAiJu OtCkUDJBjOajLjOKpIQvTpTXyRTARBxipMbTmgCQSAjaOtSD1NAC5J4FVWyGxQBejxjnrSSIeo6U hpkecDFMBw3NJoGy6GUjIo3CkIRWFSDk8UAWgp201Pvc1ZI/+KnMwWgaY3zARVZmOeKmwyWM5PNW 2XK8VDAVOBjvTHU5znikBOhwMmoXlycLTsBHvIHWp48tTSAmPy04S8cUwuhwbdSsxHegBok9aN/e gCRXzxmomJzQBReMs2auxgqoFAFpW7HrVheBk0APDAnFQtgNmgCYOMVbQgjHtQBBL1xVfG3k01uT uxGIK5HWmISc802UN53c1NnjFSBUYEtxxUoUquTQD2KzruOaniHZuaoklKfNkcCpQMCpAlixk5pZ dvYc0AQDGDmmI2XwKAJ3U4qFTt61YEmQx4p+1vWgCFjjrzUiUAIxJ4Bpu1h15oAeE/ippbDAD1oA 0lbKDFNAxyaAGNKuMVnyZzkUAWbckEEnirc0oK4HWgCjG/zc1cZCwBFAD1wowageUE7RQBCU53fj VlWGNvehgKTgUsYyaAJWjNATHJoAhkPYUDATJoAYGycCph8vLc0APzk5XgUpcCgBrMGXA61AqNnJ 6UATZ2ilElAH4Dh26Gr0QYfNWyRFxGYlsVKAo5brSHcVgSP9nFUw2H2npQItmMkBk59atoMLg9aA Gtx16U0KjdOtKyAazMvA6UqP3NMCUsr8GpQIwuPagDMl2o2V9arPOzLt7VVwIlBKnFNCncAemeaW 4G1AsQXI+9imzHnnpTsgK48vvVkyNtwnSiyHdl23mkQZ7iia8kdtrHipC7HfagkPB5xWGbqVpDg9 +KBpl0SSlRnpUkUrbsd81DRVzo7afZgucc1qNqmwAbuPwpNFo6zSL4SsuGyc17NpjLsUt6f1rKSL 22Ott5k8wKDXQMV2j3rNocdSBooyM96oPEOdlQWrFXyHz04oeAlcEUForfZVGSRURijBqZfoUP24 Hy1KkLsc4qES0MlWZB8tV0lmB561WgjUjmYjaetcP4k1BrK3aRztGT/I1cYk+p863evtcTMA+QSf T1rKk1EIMhufwrVRDmOu8P35muIxuzlx/OvpnTlzbIe+2s5LWxS1LEm5JOema2oTvjAHPFQwLIQA HdUOFzWbuBG4AGRUS4PJ7UIatYUyYO2ph8y8elMRUO5WNW4sH71AIWaNSuR6VXgXDc+tBRblwBxV Tdwc0rDIQMtzTzx0pgSIx71MemVqtgIQW3c+tXedufapuJlT7zkGlb5SAKTQri84ytN25HPWkih6 4UfNUTSNnC9K0QtbiR5ZsmrEhIAAoGViCBuHWmK+TzUgSkE9KUKcVS2EIBhuae+cDbQSWIcgZ74q KeZs4PSpGhi7SOetNZD1WgomjHGDUgABzTYncl3xg5NQTSq3CHNTZDKpbC4NPjGQSKa8iGSfMD7U NnHNUBAu7PFW1BHJoAcXzwKhywNFgLq4K5aoiOfl6UDdh2044pmwc7utAjMn4Py0yKRgaANHzWIp oLE0DsyVlIGRUefl+apBMYqqTVg/KOKVkMqlcnNMbJwBTFck/g296aox1oDqPHrSAkNmhAzSRty8 1WdVzVCHpxUxAYUmBRl6EL1qqhYHmhAWDk9asx46GmA9zgVWXLGgAzhsHpU/ycetBSv1Bh8vFVcH ORSuwdgJORmrisNmB1pklWQE8mokAzQBawSMUBVHPegpbCkseO1SLwMUEkUme1Z0hNA0Oib1rSVN 49aAYu3YajfnrQIr7j0SpEGT89AFs7VXA61TGdxJ6UWKRGwO7IqYHjmhg9hAcGh2BFTdkjocUshb PtTRSHJ0zSMc8UxjFYZwaRsbhQKw88LkUIw79aCRWbNNAX+KgsU8cJTNmTk0tAJCcDFTR4xQrjRG /WowSTjtTGTbF6mo/LT+HrSYCbVHXrVZuDxSAtRk7fwqNslsCmgsO2YGTUOV/GmSPDUHHek12KuP BG3io8MT7U0Tdj2GB70Kfl96ARAc5zUyN2NJooRmOeKcN3WkSS7/AJcNUH8WRQUTZBHNRDrz0oAV 2UDC9apgMWzVWQFxemG600gDpQJbsjLUCgYZ5wasAKVyOtSA0DB5oZsdKBX1JE+ZaiZOeaNBi7Rj 8KovndgdKNgBRjnvVrnbTuwFUcc0woCaZSHBcdKtKeMUCBlXGTWY/DcdKkQ5ecCrQVQMmgBhwRxT U68UrFkjNUJ5OaZLHgkDBqPgtQIft4qVCBwaAHMAeRTQaasAhbmpBgrnvTsgYg5ODTCMNRZErclx xmoSM8VLKGYwcUhXHNAEyMelTY9apCe4wgVET2FAwXrg1pRqAM07sGSGT+GoGcUiSNeuTVjcCMCg CqSQeOlMY5HvQC3GDGD60zcQeelBQfe5FPUY5NJXAuKw7013wMA0yXuMRzmrGQaAGElelJvJ+9QA 9XXNRMV3g0Eu5Z807MLWbKWyapCIkDE5q7zgCmWTr93FQPuWgCJTk81YJwvHWgm7GIcn5qnDYOBQ ICxzT2+7k0DVyooJfj1rWjTpmhCJJOBxUSEHrVWQ7sm2g9KGCqMmpYXINxJ+WnFSRQN7FSRWxxSw nB+agSsXmbNNzlcVZLHKMA0wAhsikySY4I561Dt54pIpbEgBFHHU9ata7jEz2FCjBzSJZZMgAx3q sSSc0gRMDhaqcl+OlMehb2jYM9aiHBqevzF6FsKCKhIVTVBdhuHbrTt/rTTKY+MAtkUk+QOKZPUz kkcNitTdlMnrikyik7Enioh15qNwZZKDZmqWcNj3pkGhGMjjrTzHg5NMTLCDIwak2KDmmhDT7U9V zTASVQFzWfGxMmB60DRrscR++KpryefWmNo1EVdlZ8g+c03ckVdwPy1MZZBipAmEoK4PWou+RQIC x6VNFnNU2BcJPSpBnGTUiZVdvTrU0WSPmoEB4bnpTvlxmgCBn7JVB+evWqVgEVO5qVQc4pgT7inI pTKZBtNAEHlAEsaTI3Y7UroC3uRV+XrVZiTzSYEe8Y5qzDzzSHoSM+GwKY0n5UCBdhGe9IMb6ALZ IKgVGBVLYCInDVbDqVpgN3YPFVJHbdQJkquSOe1SJOA20nigktGRccU35DyetJlIiLFT8tNLFuGp DHeQMZFTJwMGne6Ad0yRUYb5vmpJAJJIeidKbGx79aobtYfzvyelTM44AoEKx+Tiqm49KAJ1GRlq TC7uKCdmO3YbA6VYzwMUrlIXfheOtRfeyW60JgVzMynC9KmSXd97rQwHM+0cVQeUk0IC1EcJn2FH mkkgVasAqDc3z1LIduAvSmSyaPbjPeoXB3Z7UCJAyhcd8VGn3s9qQ0iwXHQ9KaVHVKLIojDODzUp kyvPWkyWQofm/Gr4+7kUh2RWYZOaeHYcCgkfkn71PHtT22ARyVHFVV3lsmhMCRpMECrKuCvNUCHD 1FHJBzQAxR89XGYBcUAVQ5De2asDDc0ARO5Q/LSrKzcUASEN1qud2eaALatheacOaTAl4A96UE9q SAd5rAgGlaTAyOtUJkfmnGakRy/3qBDs84FSbaAuxVBXkVJ5uPvdKhoLscJk6g80ebnrSsguyEyk 8LSr1y1MLsnOGHFOUlKAAyZ4NHOOKARZTgZNDOCcGgodgFfl61XJIyDQA1XIatFMMMtQBIVTtSEq BQCIN4zx1o3vnHagCymcZFObpz1oAjTOeelT+YV+7QBIH3cvTHdTxQBACD8opjbl+7TuwGjf1NWR 9zJ60gGryealJBG2mgZERT1wKokiZzuwtTKTjmpYDdzKaeHDH5qQA4J+70oRcc96pASEnPPSg7SP emBBhgcr0pfMbpQBKi7/AL1WWQKvHpQBSJOasoVbg0APc4Hy1UAycnrQAhkdTgdK0Ym3rzzxQBFI o3cVGyfLQBLEBtx3pSvJ3dKAINnzZWrilttAFck7uaNo6jrQBKFJU5qEA7yKAJG6jPSrKFQOOtAE Mk2Dwacjs4oAawPU1Fu5welACjAOV/GpmbKgUASJwKYwyaAJUUD73Sp8A/doAZ5eaeI170AfgG64 erobCYA7VuQVy2Dmoy5Y59KAJROduzFVDkvn3qQNiF9kfPpUHnZk9qAEmm7D0psLYOaALLHdVZjt OKAWpGZNnPWmidie9ACP+8p6WwbvTsBcSLZ8vao5IwOlMCJQU+anEmTrxTArNHg5BqzE2BzQBeEg C+lZcsvzHFS0BVLsfWmqcMDSA245NyAY7VGCVkz70FLQ11bcg5xWbOzE7VyfpmlYtHR6LdvbyJnP X3r2qz1orGg56Af55qXEq511jqRZlck84PWuwGpZQHPQVHIVFix6lvbZzWtDMGI98VlONjRam2oU r2qtIq9qxuaR/QqSR/ISKwyjFzwcZqWUacMOcA10EVuFTPFSJlKdV5GBWQ8IGW4p2JM1Jf8AS1Tt nH61518TFxo26M8n0OP4W9K3pq5Ez5CjZg+cnoe5pWaSQ4564710WSRz8zbsereELRvtELN/fB5z 6ivrrS4/3MY/2a5Z7s6oao1bi034IHpVqCHyoxn0qLl2FY7s4qi52moFYaWymKjTigGhjLls1bj+ UUAkMlPpRB8xx0oEaTRjbjPaq+0Jk0AVHbLYqMjjigsavBzT85ODQBME70/dt460ANzk5qyG+XHt QJ7Ffbht1D9M0EjEk7UuTuoKRXkb5hUyrlcmmkFwzsOak3eZz6UxkTtgbapKf3n40mNo2BjYKOAM 01sSRbdxzU+wY5oJAHacCqM4y1SOwiqQM1YV+MEUFAX5p27IpNgZswOTg9/Wo0yOvNCYiU81Yibb VrYllzeDTWIIpNgKgA5oL54pgRjrmputADu2KkU4HNNagJ5u2oi27JpAZ0oy1M24GRzSsNMmGQKt xnPJpjLnDDFQvCMEg1JJEkWDU7r8tAFQnAIpqdTmiwC4+fNDDJoAUjAFM56YpoC2gwtV3JDZouBM jZWpFPY0hWInXnPWqpPNNKwyRW7VZVe9DARxuqMHZQgJdnmc0wptptXG2NLcYpA1C0EJjJqwq4Gc 0AV3kydv4UqJ/FQwLJOFzVIvkmhFLYsxndwasbMHNBL0In9KpyR5GaAKoG2ti2kwMH0oAmk5ORWd K2OKAI4/XrU4PzUAOYHrTM8YFA0yZQMc00r6VLY3sRsvFVyvHWgkfGcGpXk7UJ2GnYfGciopBgk9 aoop7jmraLvINAFlxhMe1VgnU5oIJAMUmN1BYuNvvSh80rANIyalU44pgSlcjJqLbg0DTGSHPSo0 JHWgbY4nLU8x5wakB6rgYpSAOaAInk4wKq7M81QmSiOmPxxQIfGKn3baAIt26lxigErjTQFpNlMk K45p6t2pCSI5EzyKgHHFAw5zml68UAJ5fNSgbRVARFuad94UCW7ISMHFTr0oGM25arIG0ZqWBGXq EnJosFi1H8o/ClZs0AQM/GKh96e4DlGTTydvFLqAwSZOKmHrTbAfnikFMAduMVTxmlYBR8pzRJIS MCkwGRnPBqb7vPrQWKfmGagBw2KCWWSPlzUIBzmgRYByMGmsuOaABW7U7pQAbc81IvTFO4CH5eaY WpXE0G/tTC2OaAQ0HJ3U4tnigb0JY1qxtzxVC3GONozVHf8ANQMuKmeelWN20YoE2Vix3VExOQaB FhTlQOlJ92gBC9Rjk0AOK96aRuoKFHy+9TqNw9KBMUpio9uaBC/d4FAPNAFpRuGarycHAobsBHsI G6m7c80LUCRW28U2Q5GRVJWJaHwnjmrWAaZRHna1NkbIpXAroPmz71a27sUyWiQRYqNl280mJAvP NOY549KE7lAnymrfnbRTBkJmL8UKecVS2JLmduKZK25algES4Umn+Zg4xQO40sGqAJ82elNIRbIA Wol5aqCxIxwQKl/hzUtk9RmM80o9aaKDfk7TxTTTAb06c1Ju4oE9iLGTmn+1S9wQ8j5cUxflPrTT Cw9nqNfmNT1EW92xapsxY1Y0CZ3CpnHAoW4yaLiknfjFUKxUiTe2avOm1ce1JjKgXOacseWqbAJN J5a4HNUI8yOc0yWbMQ8vnrxSyy80EsdE2akdz0ppCGrVxB3NMBsw3LgVlquxs0DRog7lwagb5DxQ MsxS8Ypr/e3VSdyRiyfNjFW2GVzUgVlQ7s9qs4wKBNDRycVcVdozQCViu8u1uPWr8cgkTB64oBkD R4bNWBwvFBJXZtxx0qTy8r1oAr7dpOahKbnzQBcCfLUDfKapO4C/eXnilii+bOaGBZdQRgVmupUm pAjCkmnk4FNqw0iALub0rRVfLWkOxE4/ipoUuKAsAUqcVMOtNK5JLigtxRewEJUkZpi5zii4EwJz in7c9aaYAFA71XeL+IUySSLJ4qVgRSbGv1I956EVOvzEGk2U0W9+FxVdn5zSESI+etJt3NiqTuA8 xbVyeaqg7W4pgWyQU9DUCrzQBcxxiofK+bdSSsArPgYFRgZ5oYrFlY8jNP2+/SpGV2bBxUv8JpgZ r53HvQmdwNULqWpOVrPwd340DLucJj2qFOGzTW4krFzd6Cnct1qhMMlalMm5aBFA53d8VbU/LQVu QsSWq1G20c0mxrQGfJxTMcZqbhYYpO6r6tkYoDoB4pqtzQQSFs//AKqcpwKAGM244qwoG3FNICu0 GTnNKsfaqEyUnyxiq4my2KATLajPzUhXcaBjWXApEfHFAE2A45pyIEOc0ASNNjpSA+Z7UAIVpQ23 igBxPemedjigCVfnOTxSyLgfSgkqbyOKmWQj8aALKNzmnvPigCIXWaYXMhx60mgJ0iI5JqUjtUgK Bt561MPnoATOw+tBlzxVJWE3Yh3fNV9W+X8KBpkDXG3iovNJNKw7mjE3FNmPOaLDTuNjG7rTnl2f KKLARCc55p5kP50mrCTJY0z8xqVm7UDLMb8c0rPzQK5MoytREYagadyJ2xwKVF3DNAmiRUw/41bY DAoENIAHFMxkVSZS0IhxxTSCvzUMl7jQ+5sVYYYX8KVwKyn5qlaTb0o3Abv3Co+nIpDvoWopc/Ka ssMDcKsREG3cU4R980APJwMVTHL/AI0AaQG1cioHl4xQBEBuBpVXBoAVm7U0eooAD83Bq2nyLxQA mdxJPak3ZOz8KAJAu0g06Q5GKAGjAWnq3BoAqu3zGhG+bB6UAX9wAwO9JtA+agBjruWokU80AV5U y1XbcbRzQBK5quyfLuoAZGuc04rg+1AEucLkVX835sUAWw24cVajGFyaAGmXBwKcPm5oA/A115zU kbL0PNdBBHNtxkVBHjvQArMmcAVYQIVzikwIWPOF4FJ5TEZFSBGY2A+anR8HBoFctd89qikYEcda At2KmwscdqveWFj6c00Mz2yCcVZh3568VQF8yhRz1qPdv6UABKjg0vykfL1oGik3yn5uRU0ZDdKB BICBx6VU4z83NAD1UM3HSrJiGOlJoaJ4oW/CrToFGT1pWHdEClicLwKuQBd+JBn60WC5uRRr5ilA B06V18B2ovPQUWHfzN+11BYyFJ6Y7100epBgFB/WoaKib1tNyDnrjvXWW5bAk3cDnrWE+puixJqq odm7np1qzBeCTBJzn3rBo0OiiZJExjtUwtUALED8qhlJlTZiT5eBmtENgYNSJmVdHuKz5MmE49Kp COTdXScyZ6HNcF4vLX1kYMliOx57EVtT0E1c+fYfD9x5rEg7c8cds111p4dLYygJ/wB33q5SsJQX ZHpuiaQbaSP5cYYdvpXu+nJtRPQVjLUo6kvGE5AziseZ8khOBmoHqQBto+brUe3ecjpSYhr4UbT1 pq4qGmA1hzQAcZoswF69eaegw2RxVLzASWYp1NUjdhuM/rQA7d8u6pYzuGT0oLJC6DjvVcuM8UAW 4+RRsYt+NAEhGBjvVfcQfagT2LKuCBmpsbl4oJIRHg5oLL070FLQqumTupQ3G0VS2F1EIJFTRDHW p6lBJiqYT5siqAssTgCgk7KAGxE5q5yRxSZNr7EanDYaoZeWBFTcosJjbg1ZEQZflFMRXaIr1qAq e1IEVXB6mnR4albUYHAbFSduKtMljkyajckNihiEBbI54q1kbfehDsA56VOFIGTTCxGZADg0Ek8j pQFhnmL0NG8HpQIhdCRkVJBHz8/I96m4F1kXsKi2HHy8fSm2NMgIdDkmp1cnrUlEm8Y4pgJJ56UX uAxsZxUbcDjimAo5FHSgljl689KlBX0osIU+3SoZSNuO9ABD71NIpxlaAKwznDc07Zk5FUA112gU 5GwvNSAmSx4oZGAyaE7APifnFWW6ZNUBXLLQpBNT1AkcDHy1Dhsdaoditsbdk1oxrlcUCIZQRwaq gc80DT0LikAcVMZBt96BFcNzk80pdW4FAFc4BxUynbyKALayDHNVZip6UDsQxDnmrO3Dbu1AiU4Z eOtV1XDfN0pMrYdJn+HipIR/e5+tICSQrjFZUgJPy0CYqKR1pSjE5poROowKD70ykReXk8VaRdoo GNJ3cCoCSpxQQShS3IqQDb1oKTIi2TilK8ZFAyLdg4NPDjPNFykWd2V4qmWO4896BW1JQw781LgY zQMZtycipAcdakkdkNwvWoZEbGaaGmZ+SpO6nLKN2KYM0QQV4qqwy2KGIkXjinMRg5pIdiun3qsM pPIoY0rDMc1PxtpCZDyTQeBQCGgknmlOM0DJflx0qIkCgBykEZqEn5sU7gBFOWmLqD4qrk54oGOD YqUPkYoAkDDBz1qH+L2pNgWQDjinbCRSAqng80zqcCmgLAQ4yKhKNnmmBDtO78a0UQ4BoAccAY71 B3oAdjAy1Q4+bI6UmwJCARURXtSAjClTmpNwPFJlIY5wOKbFycmhA0XOvAoGBwaZI1iOoqBiTwKA BFPU1bHNADSp7UAFeWoQEElwn3e9SxjcuabAjYfNgVIyfKDSExAAFpUAzzTQWZL0NToc0x7DZVLd Kr7NvXrQLVgG54qQ5xmmtwY0Y6d6ftpuwiXAA4pnGOakCIkZpOO1AEgI6HrSbe9A0xvHepV9RQDJ CwppYY4pqwrEQ55pSM8CgLFyLgYNSsgPNIV0V8j7tRMMDimkFykQ2anVCRzVEkbN5ftVf7Qc9f1o LLSyblz3xTBkn2oAsjGKtRkd6BMslhiqxG84FJ7Ejtm0VGFOakpMNuDntT9y4xVXGRqy5qwBzkVa 2JsKxz0qHk0mKxdRsLg0hZcGkBVGd/tVnHy5FO+g1uQbz0pAcHNCY2T/AHiDU5YAYoujPqSqQUpi nnBpjswkHG4VEPu80xXHxjLc0+TAoHchQ5NXNuFzUsSZQZjuwKuxJ8uWpDuhkmCcCkQY607C3EkB PShQAOaoa0DcueKCC3SmtxiLkVE+S3NDAtx4UZoeQHgUgIADmpyCFyOtAFMxtIeeRUyRbOaAJN2T gUMhxk0EEtv159avuBjNUtiSFBluPWrrIQoxxQAgGFy1VCoZuKATRYK4TjriqJRt2TQNjwwAwOtL u7npTTsIQYLcVd5KikBKgHTvUxAA5oAr7fmyKexIX8KAK33gTUKSFZMZ4oA0S+VzUsT54NBL3Gyo R8wqFJ9rbW9aAsWpMOoK1EjKv3qBFgOpHFQMRzmgCmxO7C8c1YUMq5oHYdGxL4NTS7cdOaYiouM1 KdvpTY0yvlQ3FXPvLUlERwflqRMJwaBXEbH3qnRQy5FUiSUJwc1CAC+PejQCxtHQU1osciluAgUY 5qGTpxVAZm5t3XvWgpyuDzQJIeuBUm5e9SxilARwKQKVNIBG5HFVgDnFMCxsIGaWN8PzVAX3YFOP SqAHzEmgaGHJOF4FSj5Rz1oBkyNzzQ59KCWRYyamBAGKARPnCcelUg53ke9QMk75qMtg4oAlUKRk inFR2qlsBAVJPtSeXimA/ZlaYiEHmmtxXNBFU9RUxVR0qhMqSMo4qJfXtQIk+UjpzTApByelBYuV LYqYjC1L3AgQZf2qRwQw9KETqSDbt6c00I2cjpQ0GpJsY0nTrSETB1Ix3p2aAGsvcVBlgetNATiY DrUgmXtVANkcOpA64rMwVfJ6ZpBdGvG25ABUwIUZagX5EDPvOBTNuDzTGNZiOlIGY9/1oAmH+1zT vMA4FABuJ5pd3egBwO7ilxzg0CZZUY6VMRxzQIhEXOasqi46UAJgdBVKSJmbigBVi2Y3Vfj2DBxQ BI5zwvFVWyOaTQEgfK4qWNtvB71IBIw6npSKQy8dasCuVbdntVlXwuD1oApscv8AjVhWAHPWgC0j Y+btTmcNQA3ftBqoGLSZPIoAtmIkArTgwXCt1pAXA3yfLxxUC5Lc0mBczgU1cs3FIDTHyJz6VntJ lyBQBE33hWgn3Qaa3Aczgcd6bv8AlJp6AVhL8+D0qyp3EYoVhtljb0NPfaU2jrimIzfuHJpGcvwt IBwQqNxp4XcM0mBHtOcCmjg4NIB+07gVq7v+TB9Kq9wBVzyKRiVpgNVueaGZc8UAW42yOarSkFsC gBE4qfeAOaAK5Bdsr0q0qbV+agCo7DdxUqH16UAWCQR8tVx8rZNTZgS7s9KlX5hjvVARMjbvarAH y0ARbeeaRgMfL1oArDeG5PFXlfjBoAk3DbQhHNAERX58npmpSwUYFAEXmA9aiZi3A6UAKiMDntUz sNuO9ADo+Riq0kRDZoAsxOAMHrSyS44FACRAscnmtADjigD8DpOc4qnhhziuggbuY8HpThgCk2BJ HGrnJqc4Q7e1SJsXCYznmq/mMDx0oBAXz1pw2/jQD7j+Tx2qURr3ppAiNtq/c61C8vy4pjKiksas glaYB9880rNs4SgCRQWG5qYz7ThaAIjufrV2JAo96AIJ5PmwOlQkArkdaAGIWDVfDHvQNFlZto5p xmVuCeKAYoZAPlNVpJtpyOtAi1BfsB7j3rRTVZdwU9PrSY0b0N1vUPnnAPWrkeoSIwA/DmoZaZam 169hQNGDx7miLxpqAQxnPp941jJa6myZdtvEU88wM5xk9zXrmkX5mWPBzn3rNxLUmehw3JQA+1ai 35YY/rWElqWiykilsk81pAoR15qbDuU5ovM+7zWfJGVUqRTQjGlgyCSK46/sFlJAGTn0rROwmzJT RjgkJx9KmW0MJ6Y/Ck2CdzctMBlJ7EV28U6xxAg9BU6jMm41KTzNicjOOtbVkXlQM46jNDQ7l6RB SRcVAgkj3HNU2DL9KAFX5vvUx328CgBUI6mpAwBOKAMq7Ynp71jru3j60AbcfKYPWpgSgwOlBYij JyalCrmgCx937tLvPbrQAoyeW4pxVTQS2NKYGRT0cjigQ9m4qixOc0Fkyt8hBqMD5jVLYnqNckHi o97ipe5RIWyPelU00wJ1+brQ+AMUxMYmKtKalgiMj5s1G5HbrSsMahOfataJugpksWQiq7gbCV60 AjHkY5IPrUsOMcUFDWHz5NTYGKaFZDl4NOZeN1MTRW69KlQHOG6UWGmXEAHSkkYgYFAzPbJOe9Sh sLg0CZUbJJIp0RO/BoJNcqBHn2rM88q+B61IGijFhk1aTGeaAEmAZTjk1ngYOKkoXGKeM9qewyMn nmhuRTAswqDwabMm08dKdtCWUmfA96FYnmldiLqtlearkZbmmrATD5elDSE8Ck9wFVR1ap8qOhoA hf5qqHjigCzEBkfWrjLleaaQFcKinI607cp4NMCrKFxxVRWYHjpUjW5YDkkZq2T8mR1xVIop7+cG tG3NAmguBxmskMcmgSXceWPao95oBoXLY6cUgJBz3oENLEtVpTkCgaRYAAHNQNy3HTNA2TYwAR1q ZPmGGoJEPynApGPGaAGE/LnvVcSsGx2qSidmBXPeqpNAmSRnceamY46U0CRBv5xUnWmyidV705vQ VN2JsYq96qy/eqiR0TnpV0gFc96CkjObhqeHOMUDISCTmozmiw0WIye/ApWx1oC+pGM7hirZJ2gU mxksfTmmuOaRLAfKMjrVgHcvzU0gMyVMk4rN2kPxTC5rRZxg1YKgAnvQBTYndkU8fMOaV+xQhGDx UysehpgS4GM1H3xSaJe4jcDNInzHBpFIeUx0phFADB6VWcNuwOlAdSQZVeKFUlsmgCZh6U3GOlUF iFz2pq470AKyjtUQBzQK7uTgetOIwMipGORj0qyGIHNAFaTHJqJBls00BodqgfpTAjQZOTVsNgYF JspJDGA6moRjNK7JJmGV49KqfMOKAJF96eME0AV5TzgVGq9zSLHld3FPSMqeKBNlrGBmqrfepklh UyvNVyvNAEw6YoHFDE2TKQTzVK/dlgYxctjjFNDOKt3upLrEikLuPJz613sY2Qj1wP5U3sBWzl6v HleKkndkB6e9RpndzQUWXHy5pqGqCxPuNNxnrQSnYpt8r8VbXBTmqSKexAeDxTS7dqT3JG+aaA5J walsBW4pQaaHYTPepVbIxQIQ4zShiKAEPrRnjFAXJUFTBcc0BckX71WXdQnXtQS0Yxf5+PWro5Xn rTuIrOpzxU65CfhTTAypySxFRLHnk0a3LLqqAtR7iDgUxa9ifPGamRuM0ALvpyyYakyS+rBh81QS Nj7tJICEPkEGonzninYpggOcmr6njFX0Fcgk3DpUSuc80rLuK5bDAinYpASqBTmIC4FAFdVy2TUh UZoBsX7q8VntK+72p2XclFuORsCr6AEZNMojZiTtHSpAvy80xNABt6VA7FjzQSSxBQRVqQkLxUsp IqogJyamZ9i4WkJIphmLZNKWbNO7KsSgk9aD0poCDBp6vg4pgSluM1H97nvRcBwJ6dqZ/FQJkufS p1+bg9KBkmMdKYcnrQSwRRnNErcYFAhsJIOTV8kEVS2FYRcKc1oI6sME0Eu5XuHAXC9Ky0lwTQFi 0JSetPyDQMpS8NxVmJdy8+lMB7Jt5FRiUjikAgmYNmrwk3LzQAbjmnMQV96AKW4gkUm3nd3oAdub GB0p0bsrUCLEkzFcVDGhb5j1oBlxCfu9qe6rigkq5IPy1N25ppACquc1OSNuBSHcSFfnyamuAMZo EZynJ4pHOKrQLBGu5hmrcnyLx6VJZQWT5smrGdxFBLRa4KgUqNtOB0qkxCSzFRxVATPu3UmwNGOX I3NU3m7iFHNAFkL8uW9KpyMnIzVAZ7gdVpELfrQBoKMrzUJ4NSwHByOBSGQ5pDaLcWGHNEiBTkUx DQ/BDVVx+8yKoC5/DxVZmINAEsZUnmnSf7PIoAVSAOetL1PtQJk6qu33qq5w1AIkV8rj2qvg7s1A yyOnNM2gtQBZ24Ap5X5MiqQutinuIYg05mOOKYxgZsUoc55oE0Wo3FNkkOcLVIkqS5Iz3pIyehpj J8EHipSfl5pNlDQoA3DrSht3DVIEqAA0r+1AtxyJkZppYhttO4mx+8jrQcEZpCK2cNxTyxoAkEjd G6VYABGaEBXdFqGMfNg9KoTLTLtGRVQ5Y0aCJkJXgU93Y8GgaY+Md6ufLjmmMqyAfw1EnXmk2BO5 +XNRJgnntQgEd8HAoVs9aYFjcF6VIrjqaAZLv7io2mPQdaCSQSsFpFn65oAFm+bk1O0o6g0AVzPu OKVpSq8daAEWVyM1Irsxw1AE44PtUncYpWAc4ytLGMUwJCR3qE47UARDG7mnPt4xQBKr/Lio93zc UATHkCp41TGT1oAsBwOB0qvIMnIoAsw9MNUjYU8UmAhJI4oRypyetSBb87cMHpVaTCjcvWgBiEty e1TCVgdo6U1uBYGD97inN0wtMCFY8nLVKTt+7RYBPOfp2p4l9aYETsGoQDqKALW7PymrChQMetSw K7jacjvQqhuTSAeQBwKrMTnnpVWsBKsuBxVhcP1pgBQA8U0qvegBN2BxVXJL5oAlYkLkVXVy7YPT NAGmg2rx1pdzEHPSgCmQN3NWQOOKAIiWB4ppfPBpAToV2+9So2GpgXOCM1TeQg4WgBcnGTQvNADt uSM09k+X5etADVzghuKM4+7QBFuct0qb/eoAAinpRswc0ASlwFwOtUPmLknpmgC0jbatZVxg0gIm QKMr1qEKD97rTAnHy/dp3mNQB+CHmYb1qczBlxiuggg3Z4xURWpaAkRvL5qUnfz0ovoBXIOetSF8 LjFICI8gnpUKkhqAL4mGAKsDlCapbAUl++QaR4snNDVwGr8hx1qRzxmmAiDcPSn7MMCeaALbyARY HpWWvzSc+tAGptATIqDcc4oAgePd81RocHHWgCff83ShnyQBQBYaAtHuB7VlEFTg5/Wk0A5XZfXF NZyxqQBThh9avM/AxVJ3A0YLoxpk88Vdj1DMg46GlL9C49DovtKTw7eOlYEi7ZTjpWTRadiIylJF I4xivStF177KkYODj1qJrQtSPSYvEyyqBlRwO+P61dTxAiH7ynPv7/WufkK5jpbTVRNhtw7d/wD6 9dHHeg4+YY+tS42KUjch1CJF+d0/FhWfc6jEzHYyn6EH+tTyhe5D5yvESSBx61y89wsc/Zvm+vf2 qwOqs2SaDO0Dj0rEvYBuJAx1pMaMMDYever6vuTbu9utCKLMFoGkDlu/qK7K3dYkCjHAApMCViHO aeqgVNgJsDGajZAyn1xSAzvLwxqq6fP7UAPKfLnNVGcjigBh5Xmoo1GaAJS+w0vnbuKCywi55p5X BzVCuSLJ2qQf3qBj2fjAqJM7ueKTZBdJwtU9/wA340hpE+3IzVZhg4oKHKhYU8JtOapbE7MRjnim 4GKl7jKjDa2ferKfMKLjLCio5EOMin0AroSGxVwtwKQEx/1efas/bliaAJlPapwdvNAmyMyFjU6t 8uKCTMmBLcetLFlOtK5ZcZMruqEcUxNiFuasZ3Jj2qhNkKrtOakLDpQCJFNTH5hQUQKnNRSpzQBH 91fWo4/mk9KBGyy/use39K5x1Ky596kk14m/d/hSeb82KALC9NxOahJzJx60rDuOkOAKYJMCmNak ZXec9KkA7UDHq201M0mUqt0SzEc5kx71pxp8gNSIlCcGotvzYp2DYRxxTEGOT+tIq5IXz8vSosHd 1oElcuquFzVVuT6UA0C/Kwq08nyfhTuCVzOBLNilcFcHNIGhR8wqUABKaQiuG+ap9/FMaZTLZfHv WpGdqZqRp3I5Jt3y1R70DF6DNQM/OcfpQS2Wops/KRT2TJzVbCWonl/L70qcGhO5RJIcDimRv601 qDLG6gPzSJFY5GaqmTnbUvcCyi5FK8ORmi5ZTUHdtqcpQIesfemyfKDVJ3EmZ4JZ89s1pKPlH0oK LAOBimBsNQSyyeEzWY3ztQIkUbRUgPelcoqPy2RTu1MY8Gmkc5oAk6jApmygFuSouBmoy2WxSZRK G5xUhXjOaS3B7CAU0nnAqiR+z5cmqWB5n40NjSLRwBkVFnfxUtiI+h21MBgfWmhpkfQ5p2cjNMYo ftTAfmoewuor0JxUjLW7iot3OKdwDbjmlXBNIBzACk4xTQkyIjrTB3pjuVyDupdvegBQ3arAxipA AmTSyDaPWgTY1P71PJ3UDWxWccYpqNt4qgLAkwKgaTJoAcH7VYX1oADzTQnNAmiwOBVdnGcVI0Ql sdKevrQBG3LUE4AoAerADJqYTAnFAExPy5qljL5oAvfw1TZ+aAFU55qbG6mhMb5ZHNBXjnn60xpW GqseeFA/CpmGRgUPYCpt2mriNxUk7Fdz81SgdKCk7iv92qobBqlsJ9i7HzU5FAWM+Tg0itxincQ7 bmrCx/LzSArNDhs0eXjmgojY9qaF5zQTckYcVGh5xQUSd80bqBMkB4pBy340CLfQZo37uKAH4wM1 CwLcZoJbK6x7WyeauhON1AhpcZx6VIGyMU07AZ8yc5pqrmncpKxMV4xUG3BzSuMZv5xUobik3YBw amg/NQtRNGhGpfFPddg5qloSVAMtmpGNDdhpXFD47VIr96Yh5lB+WoSv8XrQAIuT1q0zbRQBGJM0 ueaALIPFKBuNNK4mI64qHyc80hIcF20ebt+WgolHA31Okm402Jkr9Kq4zzQmSQjKuD71qKd6YND3 GkVW4bHvTGXI3UlqUCHJ209xigBqP2p3VqaAs7RtqoY8nIqhWGlTjFTRJ60DLPlA9KgaHHNCdiCH bz9KtqeMUFXHe9JuzxQSOVO+aRk5zQA32FTKpxmmmJsRhiow5BpiJGyy81TWMlqVwL3lfLSquBTA hPLVbjfaMUARvNziocbuaBoULnirKpt70AyTdgGoN3zUCHkbiKmMeEzSbAaGAGMVGMbqSdgLqxgj NKSE4FUJjC/GcVDvLHFArF1I8Lk1CeWxTTsIYRinoO5NDdxpXJxLs4qpLNu4pBswhXnJqZos80FD ozsOKml5TPtQBjMhLcVbi+Uc0CbLI5qMvtbFBJFJ82KVFyMUDW5OUIQgU+2jIfc3T3oG2XbmcKm0 fT9KxQCxLZqk7kjx1waspjIpgXQRjFVJTt561LYESvkUnU1Nyi4h2DNMafccUySJ+mRRHycVSdwL uMCqr/McCmNaDQhHNXY+VwaAZTmBDZHSpo2+TmgVxFk+bHvVh03LmgCsvymrAYVLBajgNxpCu0jv SAthsqKUHHFMVtblGX72RTlGVAqhkqpUUiUCewwIetSDg+tUiRzfMKRRimUiUttFQk76gY7oMdaQ LzQBP90VJnK5oIER8EikP3s01uAjc9KiwRQwFC4O6ptu7n0pAI3TaKcnC1SATbnNMHBoaEh5fPy0 BdvNKw3sKDlqlZe9NaErcVT2pHXvmmUV9+OOtAbJ6VAE23K00LgGqQFNgQ5NSq2cCmBZ2nFR4Oaa YmupcUfJVQHbJzTBK5eLZTj0qnsLn0oEPMJHSpPKJQ89qkCNIirc1Z8rvQBLwq0IdxPagB5fnbVh flGTzQAeYM1E1xt4FAFcyFzkVKrcYoAY7+lSxRl+TxQA5vlO2lAwM0AAb5sVZ2nbnNAD1HvSGTae apKxLJkbPPSpG570mNO5JHJgYNQyNluKiww3bQKmUeYOaoCTIQYpUYdcj86TARpPm4qRZsdaFqBJ 5wbilx3pgRs2KqtIc8UATRqX68VY/wBX75oAmjXd8/6U5iQ1Jq4FjIdQPaot235aVhXK7Phs9qk3 CRPTiqDcqH5W21fhHANAXLXSqjnLYFAx2zjrRgAZoAhZ+MUkK/NmgDSx3p24AYoApOuTkVKhwMVL Am7VUeLndSAainNXCOM1S0FYh80jigZJyaYyz94Yp6x7eaAHlhTkkGcGgCOaTsKrRk5oAtqQDzTX +bpQBGoKHPWrBfK4oAqbTvz2qycBeOtAEPJ4xUeSpqWgLanjNSeXu5FNO4EoAHBoK5pgfgKR83NX go2ZHpXQQV1ID4PrTpuxWoAjXBHNMyd2Fp6WAnCngnpU48vGD1pAUn+9helO2jbnvQBFtOcjpVxX wu01WwFVjhtwq3vBj98UAVFByS1MbJbAo1uBcjRttG185pgSZBG09agICnI4NAFuFxj5+lKWj3UA QSsCMJVVEYHJ6UAWWAI+XrVYRvuz2oA1I3+XafSgxKTuIoAVoUZTtHOKyHiZWI7UhO5EQRT0OWAP SktxmzGqlQPamMgU5WmUtiZJ2TAzWisism9uuKhopMoswkkwvNacbeUoLcVEkMmfUWVCYmxj0NQ2 +sSmT94/APc+9ZWZSZ6HYa8qhVDgHjvXdQa+nlcuN2OPmqbDbZzWoa/d78W8nHsT6/WtDSdWuHZW uXyPcn+tUokXZ2EutKEEcbjcfQ+1SWfmXMgkb5lPNJxLUj0m1ZIYQvQ49axtQuEUEkjvWLRpFnCy X6eYRkfnTP7QwRhv1pqLNDTg1TGPm/WumtdQ8wgbgePWk0S2axnYYbPFW0vQRjPP1pcrBMeLwFtu asefyOeKhpjuhZJkCZHWqfmqwz3pDEEnr0phCk5oAQ7QOarAjdx60WAe+0r71BEuXx71SLOgjt22 5A7VUm+Q4ap6iK6uCeKs544qhNkij+9Qevy1IiTPy4NMwPxoGrki5HXpQQM5NBRMuNvFRc7uapbC Guvy5FUstk+lSMYxB4qaMHt0pqwE5bkAVZXGz5qWoBtQ9OtAXnmgBH6YFUScGkIkTk1OenNAOxCM E8VcTHQ0yRzIp5qDYAaRQ9vu4FVlU55pjHOnGRVYMQcGqJZcHK5qtzuoGiTmpQxAoGOQ/NT5BkZo EyqoycNVhVXPy9aBakxJxg9Kpsq5yaliJQPkOOmKy5CQ3FBRPG7nArTjiJ+Y1LuLqPkUEYqrt7U0 UNwR0pVDVWgDBnfg1acfJgelMllAR4fLVdGcYWpEPUNmpHAVcnrTX4AVw6nrUTuv8NJlIjJ4yOtE eS3NAeho54ANQSD5cin0ApISW56Zq9wRikMRUCnJpkg3dKBMbGh70PnOO1UtiRuB+NKRleKLjRVE Z3Zq0SQuKkoRV/ibpTigPSgBrbcYNOWNGGKol2K0kJQ5XgUqPxhqTuCAvzgU48AGhFAWBXBqNVPU dKYmS7ucVYjIJwetVbQkstGdvFVVi+YlqhhYlHDgDpU0mSo20iysqFTuNKzfpQA5JAeBUUnJ56U0 QIoQDjrUy8nimWDg9qjUNuy1BLLZdduDUG5M0CI5GHbpUbP8nHWgorLknmpunWgZIuKlOMUFaCJ1 qUqScjpQJbkm35feqQXD81LGWcDGRUR3ULcHsJzT1IzlqokmJ3jCVRZSjZNSAm8twKtxRnGaAH7B uodcCmgK20nil2EcGmND8AdaYRg5pNjHDDD3pygA89KQEhIPApAAOTQBFIeOOlIhxQJ3HnLdKTaw FNCHBTjmnBQOtMaGlQelU5OBQF9SquS2auCk0MdhhzUykNw3NITGkYOB0pp4FNWBFZs05Rxz1pjF PpTSoxmgByLnpUhyKLgAPFJuNADWc9BUOGPNSA5Bz81TE8fLQAikdD1pxiJ5HSgCs6MAQKroGV/m oKVjR3fKKmTbjJ60EvyFLDGBVUrk0AWUAHBqUjHI6VV0J6jQ46HrSMR0FA1fqVGyDkVKj8c9aTuB XkbnikQselIlkxBHLdamQigAkBI4qhtbdVLYpF1QwFTqxzzQDv0IZeTSKBQJLuWAyjrUocY4oEyE nJp+OKAIyq4OetUMnfgdM0ASEGozx060DTHIGJyelWcKOtAMMDtUgXAzQIOopq8NQBZzkVBnDfjT QmW9oZQR1qMttUg0ElJT8+ferLMAue9PQCpu3mpOg4pWLICzdBSYbBzRp8yW9SvtYNk9Kth1xg0h tkq47Ujbe3WmiS/bnA/ClmOaoChyKsrgjmgB3y9KZ0NADG6ipWPyYoAijD7uOlXWQlc0AUWO3jvU 0TDI3daAL56DHSpRgLx1oExyjcpJqAZDc9KBIceTVVx8w+tBRaAzHj2pgUqciqEyffxzUBbnigLD 1xkFqth1xhaTBFfOWpzZHHakMblRyOtGdw5oE2QFgM4p0ZJbJ6VSFqTSORwKI3/vUyi0duMnpVdp P7tADo5CTinSOQKCCuuS1Wtpxx1oK0LCDjDUjJ6UCZFhx9Kfk7eaEIEILc1eUCq0E0V5VOeKWNB/ FSYiUhelRfKDSdgHM2RxSoeCGpoCu/3uPWpVHy5NMCm6EvkdKvRr8uO+KLlERRg3FTgNjmgTFJAH NVcEv8tSIvqAo+f9af5inigCnIwB4qiztuGKaA04WcoKshT1emAuU6UgVd2aBNlot8mB6Vn5O+gk sdRTCGB46UFEnG3nrVYp82e1Ax2egXrUm4quWoEMEinnvUm7dx2oGRYw2T0qbcuMDrQIiZiORVbJ Y5oFZlhRxzUisAcCgReTBPPSpJWVF+Xg0AYruXbmrUWAOaAGyDnK0+M9j1pgSnd1HSmH5hg0gsV8 bWxVnacAipW5Y7OB81V+C2VqhMsgjHzU5cfw1SJFYsBzUcfJ5pgWZFO3iqiMytg+tAEzkYy1US/O B0oAtRkEZ71KHO7B6UAPbHamEHjFSwLABC+9KDz81NoB7NgcUxCS3PShICV1yPeqgDBvamBfTp+F V5cnpQTcRW+XHepABjJpoCNnUZFNRst7VQ7omfBxikCYGRS0GQk4b5qlB3fdqQJGBVctVXzCWwvS gC+i8AmnuPl+XrQSUMsGw1W1GRmgRJkfd70m4KMUAMXliT0pxPzYHSqWwDJG24xUqgFc96YEew7s 9qmIyuBQD2IgpU5NWs/LQSRKQSQOtMffux2qWUrigL/F1qUKvWkA1j2WkVWNUgIpF9aI9v40wLWQ OtRN6igAQk/SnOB+NUSSpyuKkVcHNAEhkUdaZ5i9qkBv0qZTj73SgCN8s3y9KdkIvvQBDnndVkSA jAoArkndUwUMOetAEqx8GodrB+elCAsLHuIJqaSRY1wODQwMzzNzZq4gZselVYAf5cVKJR5dGiAa k3JzTmIY0mxEoyFyKg3SF+OlLUSLTEiP3qONuctQMu8N0qYHYtAylI5Y/LVItIDgUAWk37ctUgDN 92gCVA2cGtAH5ce1AEbe9MQpu+agCRmGR5dP5K5agBquVbHarZIKZ70AUQ77iFp437vmoETPgDmq 4kxQBKpDNk1c3AD5aA0IWlJGB1pgfH3utAXQbnJ46VJuOMGgBwAxz1qRCqtz0oGXt6kcVQlfnAoA aCcZNWVdcZqAJo3UnmllxjAoAijXuakJ4xVAVQvz5bpV9QpGFpgSFdvNNY/IaAMxpcEipImLHigC wwyeasIgC5NAGfLJ82F9akjLEZNAFneo+9TQwJ46UAK5wOKbG/zfN0oAv4QjIqu6A9KQDACvXpV1 WwuaSApSS/NhT3p6ycc1QH4Ouik5p642kD0roIKEgIfdS7t4xUAAGKfsH3qALEZ3DBpGQA8UAQNG eoFJg9DxiqsJMevXnpQyjPFFhkbrkUkSnOD0oAnkG0gDvTTGAu8detMCRZMIR3pokbkHpQA0feya c65GRQBGmc4p+z5uaAG4G8VeKjy8+1AGduIfHargJIFAA2ByOtQec/THFADftDL9ahaZm5NJsBo+ frSlQvIpLcBROy9KtpMXBz1pjuKAzPyOM1cYhYyvtUjTuZYldJMryM1tLJ50YDdSKiX6jJPJTYQT WS8BUll96kpEUNw8cnJI5rqYb2RsYJNDigvckuLxkXJPSpLTWWUhS2BSA6BNRDsH3/rXZWXiPyFV Q44AHapkxo6dPFUZX55gD9aoXGvw3Hy+cDn39aixcdCpG0Eh3bwc+9WHWMLkN+tBdzBuL3yc7G6U +w8QGOdRI+1c45+tFhHsNhqVveQriUMcDofWrsjLHyhzUivYoLckPuJxzWqt1uAJPSk1cXN/VxTd KRtLVUN2FbAbipcSlJiPfYHytUsN7u6mjlHzD5LrnGaRbhepNPlQ+Ycbpe7cVdt5oyQQwzUuNtjT m0OptrlSNpPGMVWvUDAsvPeot3EYCBg2Md60QcDmmBZUgrSA4OKTAmONuR1qsCd1IpbFnJ281UaQ 5welArl2FgR1qdxxkVXQFuVi3GDVNiBn3pWKIFUs+e1aigBaEA3aCc1M2NuBSbAiU4p4egBuctim tGtLcREfl6UMxKfhQSVEkIJq4khzTAleXHShHZutA0OLY4NM3elA2LuzwahZB1qkrEj427U9h3FB ZECe9BagB4OOafvLcUANwRzSgnORQyXuWAc9aayr3qRCdBgdKqPGCcnrTaHcdGNpFa6P8mPakIgd wM4qgZDk4oKQwykdalSXIoBguTJntVsnoKpEjGxgGpox8uR1pMC2qjaWbjFc7d3RDbB06UdAI4G3 9fWrpi4zSKWxFjtU6DbzQBZyDUuFZcUB1IPLVaQcHNAyJnO7HapB7ULUCQtgcVVZs1RL3HKMjmmZ IbA6UmCdhGcioS7EijoUWA/yYpFc8ikBE+c5qWNtvPeqILO7zFINVPK+Y4oATZh6fLjZx1pNlGYj Evg9M1q5wlMGVRjdmp0OGBp3JNDzTgCmF/WkUhnU5FTA8c1IyHzMnaajkX5TjuKAKqHaaZK7Z4po RNAN33qv429KTYyTqM0mKBWIGAqlIdvK09tiSNCXOG6VbaMBeKaLIEBzUrLxQAJ1xUzDigErlcNh qsLNzigdtSdpMVGSCM96ljG5I+lOHNAPYcRxTNuetUnckevyGnsFk60WAplAjDFXVfC8UrARGRgc inq+/hqYEoVRyKaetAETLUbfdxUjTGLkCpBkmgZIq80PQBHjI5pVUZxQBNwmMU1n+XNCVySFZCTi p+vWqAXHpVWSMntQBGqYp+MGgLiF+MU2M/NUlFgnvTWwaAIfalwBTQDDQg3HaaYMnwE6U0880WBO 48KNvvUe0UAHljrTiOOKkCPbUWeSDQBExw2RWjDKCuCaAGOfm4puwNyaABlwOO1VfMYNjtQBdTDD k9qRvl6UAxobvT/NyCDTSEmVc/Pn3pS1MY8HcMGgqBQ9gImGaSNipqRMsk7hQgIp2EPdsCmrzyet MB5JoQ880DuOfFNFAyFs54pwJxQFkOyc1JuOKBNEW4nimBecmgQMecCjAxk0AAYjgdKf1GaAGqTn FWsnpQBGTg4qYAEZ70AAznFDL3qrEtkqMcYqvIcmkIqE4IqyRuiz3xSAgRcZzSsxziqvoO4xQSam IqQ3Kzk4pipnmgGidcggdqu+UCoYcmgRYjUhc1Gx5wadwKrZJwORTkyKoCQgjkVHuNAEqDd1qbZ2 oAljXDYqzKQq8elAGWV3HNCp8wNAF/ICinKQeKBMfv28ComcUCSHA8ZqIjJoKJgcLikDEnB6U7sC VkAGRTFUZyaLsCRlGOKqjIOKRLHqTuzWhtDrk0FFJ1wcD1o5C8UEvciVct83HNXQgVeOeKsaKzAl qdtxigZNyUx7VGsZOeKBNkqIFOakkQFc+1BIkSgZzTy4DYoKsWFxjdUZk5xQSPLcVEfunPpQlcCC M4Y59atiXmncTZY3ZXNRq+TgUmIjkYjpUAbJ+agCyuKfimgGsM8ilBGMGmA7gcCp045PFFhoryyh TwalRt65pNjKzH58HpUybV5pBZEE0pPA/SkiyeTRckdIPSq6rkjNNAaSsEXrSecWO0dKYD9v8Xen FsCgTRH5hNPjG5uaaRJYb5RkVEJM8GkNEnBqvI/8IoKIFJByaUuzcdqBWHKg/GrqIMZoGipK+GwK jU96CrIlPPBpQPSghuxPtOOKhQfP83HNBJYaXaQFNNLbh83egCJY8tkVKQVxigBe1Q5IORQBaSQk YagkA0FIixubNWhkAUtEMhm+7TIk4zTAU9cCnR5DVSJaNMxqyZPpVPARqYgM3O0dKQLk5NAErIpX HtVBosUAW4EXHPWlKYfPagBx2gdaFPNSBNu7Ckx3NUBA5I+lTREUAWs00jNADd2OKdxjnvQSisww crTg5xg0A9yjJnPFWIOvNWOyLpAyKHfavFSwsUWbd1qxb8EfWkMvTgFPwqika/e70El5G7VDI5B4 oEVuXOcVeTgYNNgSBQTkdarTKc+1C1AF+7gdaeAQcmmArKGoXIOKYFntUO4g8UCbEZyRVfzG+7QJ E0fBye9XsAjNKxRUcDPFNV+xNJoCTAq1GRjBpXAJEU81WVF3VYCS4AGKYCCnXmgCNZCpxTyc00xN EgJAyKtxtlTupiKrDLEVGQVPFSBdhGRk05zzgUASJ05qCQZPy80AIUOymRghuaALhVMZzTQ6jgGg CdZKZJIOxoAesmEz7VQdjI2DQAoQLVuNyBgU0wJdpk+9TDGM7aYDDFgbhRGctg1LA0TgJ+FRJjk9 6LksazEtg9KftGMigaQ5GIp5k3HaaBkqouOtOWJWbmgCaQIqbVPOKigPODQBddQo3CqnmEmgBSxN AUdTQBIB3HNWV5GDQA0quaeSoGM0AQghTkVbTDHNAEU49KqbRjJ60EtCBmHC8inh26HvQIsqo+8a Y4z0oKSHx56VZZQBnvQBGOaYck4oGXEGF/ComUE5NACEcYHNVSWB24qWBYiyOauk8ZpAJuO3imIS WOapAPYHOMcVKpCDNMCQS7+CajlOF46GgCkkPmNk1b2CLp1oAdkkZNHmn7tAEQi3NuNPchBheuKQ EC5kPzdKtqgU4oTAZJ14pyKMZPFMCwCBwDSb8EUAWPkZck81CTwVXmkwKBUhsnirSpkUJgfg6TxS x5zXRcgJMH5e9RKmwEmhIBg+Z8VI/AxSe4Do2xT/ALzUgJvMVODzVeSVTyBiqFYhMwxgdaamWOaW 7GSFgvBp0cq5xjHvVAOl67qRZMjZ+FAC+WR8/brimmZfu4/SgBQN/Sgts+U0AKpA+amPKO1K4CKp b5+wqysm79336UwIXiKndVuIbxgelADZISpyTxUW5QMY5+lAFB+Wqby9y8daTVwBYSDk02RTQlYB ipnjvVyGEg80AbOxQme+Kx5m+YgVI0xi4xz1q7Dwc9qloomZiXAB4qclQoB5NTYaZlzQZ+deKtWk ojIVueaLCLF2pmT5OK510eI9SKV+gbmpatIU+8e9XE87eQHP51LRS0IpY7tnASVgPrWvZ2F4xDNK 3Y9RRoWtDpfNls1G9yce9aMOp+bHt3c81L2LM2bdK5+bqfWs2fT5nUNE+09cgipA6PRLufTztnlL YI6nPSvQj4kj2YLZ/wA/SmtzOTKEniOMcg/pVm28RI427sdqpxM72ZPJqwzuD9aj/tUMPvZPrU29 DRMel9u5LVYXUQjfeosDZcGoB+c0yTUMcbqfKSpakRviy8NVu1vyjAFu9DiaKdzsLe+yAQ2OK211 BCuxjk1lKJakSCaMc5HNRltxyDxUNNFcyLMZ7ZqcjvUMokU9jVpY880gB8AYrOlYEYHWgBkLFTz6 1pq+RVLYpIzJpNrmq+/eQBSsM1ETCA+1R5OaGBYB4o2mlYCNuKi3Y4oFcnXnmpCCalITZEVoxkFa oRXMeD9anSM43U9gInUlvxq7FgDHfH9KGxohmQnkVBH1waRRZZdozTMbhVEsZtKnNTId3FT1GK4w OKqbTnNXYZJ1G2rMaY5NIGicruHFRbgnBoIE3g9KifPUVL3AkSQY2Hr0prRnOe1NgKqZqfO1cUgK jA9c1EOtBSHNCW6VX2mM80AaURBFPkQnkU0xMqnPSrMUmzAakxFtm3IQvpXL3ELbyx9afQVtRIDt cD3Fb2QUFItbECj5s08nPAoGO2EDNR79hyTQA1p9x4qRWyMUAOKZGafGMDBpoBrDk1WI+bFMl7k2 NozUe8ZxSaENIyaaSFpFigbue1GNpzTTAkBDDFRFTuxTJsTr8tWBgDNAWImO48VEULDFAyt5e05q wF3jAobsDIGjKc0R/M2B60EmqE2rk81WYFm4oKQoOzg809nBXipsMzN5En41dD5XBoAjK85pCuRV EsnhT8KstxUjuND4pwlHSgTZE43ciqxiOMmgQxRg1aDbhimkUmN4U04sMUxjVHOac4zQCdiApQqE HNBVwfJOKeikcmk0BY4IxVqKKkD2JHixk9qzy2HxQSNlf5eKijc1TYErKX5FIoI4oAtBMioGGOnF AhFJzzVneMUmMTrUeOaQ0xTgCiPGaBk5YCmHmgkhxTehzQNMa7bsU4DcMUJ2Bj1XB5qx24qhEe7a eal3KVoArqRupHXPSgCPyTio1TDVI7kjAmo8EdaB3Ijwc04DNC3AdinKwBrRbEvckI38ij7o5pMC Hnd7U41NyhAaeGycUgHMQoqkRk5FAETDjFNjDA56UAW881IoyRigC4RhearNGGGQKAuVsFD7VITk UAAHFRd8U0TsP8snmomGOKY7j0GDUjjjND2C41OcinGLuKlK4hANp5q2MFfwqgSuVCcuRTgdpoAl 3jFN3elAAAWqUIRTKTuR4+apSBjigCMMAcU4sDwKRLQ3p1ppPpQAzGTmkbilZgAYYpc0wDoan3Db QBH1qRDg80ASlxmozJiqSIJUfdVeRtrc0wISc4q3GuVxSuBN5fGarmPJqQJ1j2jmqznnFA0yJl+X NRIecUFFrHerkXOAaCXuag2hPwrEnPzcUCHx4281NjPIpoCIuBwag3AtiqAnxjmpBIBxTTsBOrAm lcFql6gQYxUikYosBXZjnijdgUxNXGibJxUuwsc9qB7F1RhcGgdaBXENR5waBlkHcMVGykdKAGh+ MGlGCaBMmKfLkVLEccGgLjJBg7jTFYE0CGycEYqVZMLzVjRKuG+amvz07UDIPNC/KfpVuORSPrQA kg7ioA/8NBBIQQOKrNnOaCrlgPiOoVbLGgLXJ/NCnBp33+R0oJImXFKikmgC1yBtzQqlDuPegkkY gjNUyMnjigBVJXrU/mg/LQBIvHXmmMOcihK4JXBT83NXj8yYXg4qtgMWWNg3XvWpbfc5qShkqbmO 3ilELbetAEXl4PPNSrwaCSUrupojwM0AVGUlsA1chjxjPNNAXivFUXPJFMRGDjrVqJgDQJK5ZkYF ePSs4H5qAsSEkCmKCzZoCxK0fHFOVRjHegaE2EHPanmUKMd6BlbYZDmlKFaAHHkcU6Pjg0CauXww A5qhM2MlaAIolLHcatuMjA7UBsCOF4PWruQy0CbKpXmnYAFALcrl8HAp3ls4zmgocnyMAastMoAp WYrjD865FCMFG2mFxduPmP1pwcZxVITZaD/LVCTJPFMQ0KRyanWQdKkB+T17U5sFfwqguVkJV/ar +4FPfFAGQ5Pme2atKflBqXuBaXpk0jN3ppgVy2/gUqgqetMC6ORT80EtlU53/jVryywGKBod5e0f
October 14, 2017 - Present
RV10-Archive.digest.vol-mt
