RV10-Archive.digest.vol-nb
December 24, 2017 - April 09, 2018
      >>>                            RV10-List Digest Archive
      >>>                      Total Messages Posted Sat 12/23/17: 2
      >>> Today's Message Index:
      >>>      1. 07:54 PM - Alternator will not put out current  (John Miller)
      >>>      2. 09:11 PM - Re: Alternator will not put out current  (Bob Turner)
      >>> ________________________________  Message 1  ___________________________
      __________
      >>> From: John Miller <gengrumpy(at)aol.com>
      >>> Subject: RV10-List: Alternator will not put out current
      >>> Fellow RV10 guys.
      >>> I am ready to fly the RV8 I have been building for the past 5 years, but
      >>> I have an alternator issue maybe one of you can help with.
      >>> The alternator I have installed is an Ultima (with internal voltage
      >>> regulator) from O=99Reilly=99s auto parts store.  My next
      >>> door hangar mate has an RV7 with the same alternator setup.
      >>> When I did my first ground engine run on Thursday, all worked fine
      >>> except the alternator would not put out voltage.
      >>> I double checked my connector plug wiring against my hangar mate's, and
      >>> and made my connector wiring exactly the same as his is.  Then I
      >>> confirmed that I had 12v (with alt field switch on) to each of the 2
      >>> connectors in the plug, plugged it into the alternator, and ran engine
      >>> again but no voltage increase with the alt field switch on.
      >>> With the alt field switch, there is no voltage to the connector, but
      >>> there is batt voltage showing at the alternator output wire with the
      >>> batt switch on.
      >>> Friday, I pulled the alternator off and took it back to O=99Reilly
      >>> =99s.  It bench checked ok on their alternator tester.  I also
      >>> confirmed on their tester that the 2 connectors had 12v to them - it
      >>> did.  Then I had them order a new alternator anyway and it bench checked
      >>> ok before I left the store..
      >>> Put the new alternator on this am.  Ops checked it this afternoon with
      >>> an engine run and also ran a temp lead from the alternator output
      >>> connector to a voltmeter.  The alternator output never went above the
      >>> battery voltage of 12.7v with the alt field switch on.
      >>> Thinking it might be the connector plug that plugs into the back of the
      >>> alternator, I changed out that plug for an older one I had with the
      >>> original Denso alternator I had on my RV10.  I confirmed that I had 12v
      >>> to the 2 connectors with alt field switch on and ran the engine again -
      >>> no voltage increase again!
      >>> I am at wits end trying to get the alternator to put out voltage when
      >>> the engine is runningany of you have suggestions?
      >>> Thanks - Grumpy
      >>> N184JM
      >>> ________________________________  Message 2  ___________________________
      __________
      >>> Subject: RV10-List: Re: Alternator will not put out current
      >>> From: "Bob Turner" <bobturner(at)alum.rpi.edu>
      >>> My first suggestion is to get a real schematic for this alternator, not j
      ust try
      >>> to copy your neighbors plug.
      >>> There are many different Ultima models.
      >>> Do you have a good ground connection?
      >>> Bob Turner
      >>> RV-10 QB
      >>> Read this topic online here:
      >>> http://forums.matronics.com/viewtopic.php?p=476728#476728
      >>> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Nav
      igator?RV10-List
      >>> FORUMS -
      >>> eferrer" target="_blank">http://forums.matronics.com
      >>> WIKI -
      >>> errer" target="_blank">http://wiki.matronics.com
      >>> b Site -
      >>>           -Matt Dralle, List Admin.
      >>> rel="noreferrer" target="_blank">http://www.matronics.com/contributi
      on
Subject: Alternator will not put out current
Date: Dec 24, 2017
I had an alternator put out too much volts last year. Fried the LED trim indicators and cost $500 each to repair the 2 Dynon screens. Autopilot never worked quite right afterward and finally had to send it in for a fix. There are 2 external ways to prevent overvoltage. One is a crowbar device across the field circuit breaker to short it and make it pop on overvoltage. The other is a circuit that looks at voltage and opens a contactor in the alternator output on overvoltage. I put in both. Albert (belt and suspenders) Gardner RV-10 N991RV Yuma, AZ ________________________________________________________________________________
From: "John MacCallum" <john.maccallum(at)bigpond.com>
Date: Dec 27, 2017
I am not familiar with that Alternator. You say you have two wires running to the connector both with 12 volts? Can you upload a photo of the wiring diagram for the Alternator? Also you will always have Battery Volts on the B + terminal whenever the Master is on unless you have a big Diode in line with the Battery. Cheers John MacCallum VH-DUU RV 10 # 41016 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Miller Sent: Sunday, 24 December 2017 2:53 PM Subject: RV10-List: Alternator will not put out current Fellow RV10 guys. I am ready to fly the RV8 I have been building for the past 5 years, but I have an alternator issue maybe one of you can help with. The alternator I have installed is an Ultima (with internal voltage regulator) from O=99Reilly=99s auto parts store. My next door hangar mate has an RV7 with the same alternator setup. When I did my first ground engine run on Thursday, all worked fine except the alternator would not put out voltage. I double checked my connector plug wiring against my hangar mate's, and and made my connector wiring exactly the same as his is. Then I confirmed that I had 12v (with alt field switch on) to each of the 2 connectors in the plug, plugged it into the alternator, and ran engine again but no voltage increase with the alt field switch on. With the alt field switch, there is no voltage to the connector, but there is batt voltage showing at the alternator output wire with the batt switch on. Friday, I pulled the alternator off and took it back to O=99Reilly=99s. It bench checked ok on their alternator tester. I also confirmed on their tester that the 2 connectors had 12v to them - it did. Then I had them order a new alternator anyway and it bench checked ok before I left the store.. Put the new alternator on this am. Ops checked it this afternoon with an engine run and also ran a temp lead from the alternator output connector to a voltmeter. The alternator output never went above the battery voltage of 12.7v with the alt field switch on. Thinking it might be the connector plug that plugs into the back of the alternator, I changed out that plug for an older one I had with the original Denso alternator I had on my RV10. I confirmed that I had 12v to the 2 connectors with alt field switch on and ran the engine again - no voltage increase again! I am at wits end trying to get the alternator to put out voltage when the engine is runningany of you have suggestions? Thanks - Grumpy N184JM ________________________________________________________________________________
Subject: Re: Alternator will not put out current
Date: Dec 27, 2017
Fellow RV10ers - thanks all for the tips. Found the issue and will post for all to see. On suggestion from one of the avionics dealers at Osh, they convinced my partner last summer that we needed to have over-voltage protection on the alternator to protect avionics. So we bought one of the small crow-bar types from PlanePower and installed per their instructions between the circuit breaker and the alt field switch. I chased ghosts for several days. Could always get 12v on the field wire to the rear of the alternator.but that was not telling the whole story. I needed to see if it was supplying enough amps to excite the alt field. With the help of a local A&P, we jumped the alt field wire to the connector prong on the rear of the alternator, then measured volts at the alternator.should have been 12v..less than 1v! That led me back to something in the wiring must be allowing 12v voltage to pass, but no amps to flow. Then I remembered the over-voltage protection module I installed, and removed it from the wiring. Bingo! Got a good 12v at the alternator connection followed by a good engine run with alternator putting out 14.5v into the system! I then checked with Christer at SteinAir (who built an RV8 a couple of years back). He told me this: 1. He does not have such a device on his main alternator 2. He does have one on his little backup alternator mounted on the vacuum pad 3. All the Garmin products are rated for up to 30v, so he doesn=99t see a need for one if you are using Garmin stuff (did not discuss Dynon stuff) 4. Set the voltage warning to 15v to warn you if the alternator starts to run away (I also set my amp warning flags as well) So, now all is ready for first flight - hopefully tomorrow when the cold and winds let up some here in TN. grumpy N184JM > On Dec 27, 2017, at 2:54 AM, John MacCallum wrote: > > I am not familiar with that Alternator. You say you have two wires running to the connector both with 12 volts? Can you upload a photo of the wiring diagram for the Alternator? > Also you will always have Battery Volts on the B + terminal whenever the Master is on unless you have a big Diode in line with the Battery. > > > Cheers > > John MacCallum > VH-DUU > RV 10 # 41016 > > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com ] On Behalf Of John Miller > Sent: Sunday, 24 December 2017 2:53 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Alternator will not put out current > > Fellow RV10 guys. > > I am ready to fly the RV8 I have been building for the past 5 years, but I have an alternator issue maybe one of you can help with. > > The alternator I have installed is an Ultima (with internal voltage regulator) from O=99Reilly=99s auto parts store. My next door hangar mate has an RV7 with the same alternator setup. > > When I did my first ground engine run on Thursday, all worked fine except the alternator would not put out voltage. > > I double checked my connector plug wiring against my hangar mate's, and and made my connector wiring exactly the same as his is. Then I confirmed that I had 12v (with alt field switch on) to each of the 2 connectors in the plug, plugged it into the alternator, and ran engine again but no voltage increase with the alt field switch on. > > With the alt field switch, there is no voltage to the connector, but there is batt voltage showing at the alternator output wire with the batt switch on. > > Friday, I pulled the alternator off and took it back to O=99Reilly=99s. It bench checked ok on their alternator tester. I also confirmed on their tester that the 2 connectors had 12v to them - it did. Then I had them order a new alternator anyway and it bench checked ok before I left the store.. > > Put the new alternator on this am. Ops checked it this afternoon with an engine run and also ran a temp lead from the alternator output connector to a voltmeter. The alternator output never went above the battery voltage of 12.7v with the alt field switch on. > > Thinking it might be the connector plug that plugs into the back of the alternator, I changed out that plug for an older one I had with the original Denso alternator I had on my RV10. I confirmed that I had 12v to the 2 connectors with alt field switch on and ran the engine again - no voltage increase again! > > I am at wits end trying to get the alternator to put out voltage when the engine is runningany of you have suggestions? > > Thanks - Grumpy > N184JM ________________________________________________________________________________
Subject: Re: Overhead Console
From: "Greg McFarlane" <grbcmcfarlane(at)gmail.com>
Date: Dec 27, 2017
Why not build your own ? 023 Ally is good to go with. Just make up side template out of cardboard/mdf ply etc for full length, windscreen to baggage, then make the whole thing from three pieces, sides and vent/lights etc surface. Small lugs bent and pop rivets will hold it altogether and attach, then a sealing/strengthening glass tape can be used on the joins. Your choice of headlining makes it your own. Happy to give more info if needed. grbcmcfarlane(at)gmail.com Cheers from Western Australia Read this topic online here: http://forums.matronics.com/viewtopic.php?p=476825#476825 ________________________________________________________________________________
Date: Dec 28, 2017
Subject: Re: The old nose wheel shimmy issue
Follow-up I am making sloooow progress on the nose gear shimmy issue. I tightened the belleville nut to around 28 lbs, drilled new cotter pin hole, added washer to the donut stack, went out and tried again. Performed test, and got results so many reported....much better, but shimmy still there at 12-16 kts. Borrowed a wheel balancer (Desser used to sell, stand with axle, cones,external bearings) and sure enough, nose wheel required the same 1.5 oz of wt. Some report lead wts hard to find. I used steel wts, but likely will replace with lead later to better concentrate the wt. Available lead weights: http://www.matcomfg.com/WEIGHTLEADBALANCE-idv-3682-44.html I note that with research, nose wheel shimmy is common, which may trigger main gear shimmy. Many nose wheels require balancing, and almost all need 1.5 oz directly opposite the valve stem. When I am satisfied that I have the balance as good as can get, will test again. After reading reports that go back at least 8 years, the problem and solutions are pretty uniform...belleville nut force, donut compression and balancing of the wheel, with almost identical weight needed in same place. I do have the correct Matco wheel and axle, and a Desser recap nose tire with the tube that Tim recommends. I will balance the mains after I rotate the tires for outside wear. Kelly P.S. From frigid Aridzona with 36 right now, going to 71 this afternoon. No, I don't miss the -20 in MN and WI, nor the -50 from Fairbanks. 8^) -sent from the I-droid implanted in my forearm On Mon, Dec 18, 2017 at 8:04 AM, Kelly McMullen wrote: > Thanks Tim. Yes, I had 3 friends observe my taxi in from last flight and > comment on how much the nose wheel was shimmying. > Yes, I have had main gear shimmy in the past. Nose is at lower speed and > higher frequency shimmy. > I'll check with the fish scale, get somewhere around 25-30 lb pull and > then drill new hole. > > -sent from the I-droid implanted in my forearm > > On Mon, Dec 18, 2017 at 7:54 AM, Tim Olson wrote: > >> >> I have 2 holes in my gear leg to provide for a little more >> adjustment precision. No big deal on that. >> >> Are you 100% sure that the shimmy is nosewheel? I really doubt >> it is. Almost everyone who has a shimmy, has it in the >> mains, although it FEELS like a nosewheel shimmy. I really >> don't find much for issue with the nosewheel at all, other >> than making sure you have a good breakout force on the >> rotation. And, of course, there is that need to take out the >> play of the donuts occasionally. I can't remember how many >> I have in there, but at least 2. >> Tim >> >> >> >> >> On 12/18/2017 08:40 AM, Kelly McMullen wrote: >> >>> Well, mine has gotten noticeable enough to do something about. Of course >>> I reviewed my archives and Tim's website as refresher. >>> Taking the cowling off and checking things I found that I could not >>> tighten the big nut to the next flat, so the amount of pull is irrelevant >>> at the moment. >>> Has anyone tried new Belleville washers? >>> Secondly, I noticed about a 1/4" of up/down play on the nose gear leg, >>> which I assume is compression of the donuts. (I am at about 130 hours). >>> Will check today to see if another washer is needed. Yes, I have done >>> the service bulletin upgrade, and there was no play at the time. >>> I guess the next step will be to get a wheel balancer and balance the >>> nose wheel. Then do the mains at annual condition inspection. >>> Has anyone drilled the bottom of the gear leg to get an intermediate >>> cotter pin position for the pivot nut? >>> -sent from the I-droid implanted in my forearm >>> >> >> >> >> >> > ________________________________________________________________________________
Date: Dec 28, 2017
Sounds good on the progress Kelly. Wish I was in your frigid location...our high yesterday was -1F, and today it's a bit warmer but it comes with crappy weather. We won't be seeing 20F for any time in the 7 day forecast. Regarding the recap tires, I've used recaps from Desser for the mains, and also started using the 5" recaps for the RV-14 mains as well, but I've never used them for the nosewheel yet. I've always used the standard Van's Aero Classic on the nose. I've only had to replace one, just one time, in 11 years on the RV-10, and I did that when I swapped wheels to the proper wheel, so I still have my original wheel and tire in the hangar as a spare for either plane. I do like the recaps on the mains. Saves money and seem to last longer with the extra thickness. I think I used Monster 5" on the RV-14 mains...did require opening up the fairings a bit for their size. On the -10 I've used the 15-6.00 "High Performance Retread" that they sell, not the monster. Tim On 12/28/2017 7:37 AM, Kelly McMullen wrote: > Follow-up I am making sloooow progress on the nose gear shimmy issue. I > tightened the belleville nut to around 28 lbs, drilled new cotter pin > hole, added washer to the donut stack, went out and tried again. > Performed test, and got results so many reported....much better, but > shimmy still there at 12-16 kts. Borrowed a wheel balancer (Desser used > to sell, stand with axle, cones,external bearings) and sure enough, nose > wheel required the same 1.5 oz of wt. Some report lead wts hard to > find. I used steel wts, but likely will replace with lead later to > better concentrate the wt. Available lead weights: > http://www.matcomfg.com/WEIGHTLEADBALANCE-idv-3682-44.html > I note that with research, nose wheel shimmy is common, which may > trigger main gear shimmy. Many nose wheels require balancing, and almost > all need 1.5 oz directly opposite the valve stem. > When I am satisfied that I have the balance as good as can get, will > test again. After reading reports that go back at least 8 years, the > problem and solutions are pretty uniform...belleville nut force, donut > compression and balancing of the wheel, with almost identical weight > needed in same place. I do have the correct Matco wheel and axle, and a > Desser recap nose tire with the tube that Tim recommends. > I will balance the mains after I rotate the tires for outside wear. > Kelly > > P.S. From frigid Aridzona with 36 right now, going to 71 this afternoon. > No, I don't miss the -20 in MN and WI, nor the -50 from Fairbanks. 8^) > > > -sent from the I-droid implanted in my forearm > > On Mon, Dec 18, 2017 at 8:04 AM, Kelly McMullen > wrote: > > Thanks Tim. Yes, I had 3 friends observe my taxi in from last flight > and comment on how much the nose wheel was shimmying. > Yes, I have had main gear shimmy in the past. Nose is at lower speed > and higher frequency shimmy. > I'll check with the fish scale, get somewhere around 25-30 lb pull > and then drill new hole. > > -sent from the I-droid implanted in my forearm > > On Mon, Dec 18, 2017 at 7:54 AM, Tim Olson > wrote: > > > I have 2 holes in my gear leg to provide for a little more > adjustment precision. No big deal on that. > > Are you 100% sure that the shimmy is nosewheel? I really doubt > it is. Almost everyone who has a shimmy, has it in the > mains, although it FEELS like a nosewheel shimmy. I really > don't find much for issue with the nosewheel at all, other > than making sure you have a good breakout force on the > rotation. And, of course, there is that need to take out the > play of the donuts occasionally. I can't remember how many > I have in there, but at least 2. > Tim > > > > > On 12/18/2017 08:40 AM, Kelly McMullen wrote: > > Well, mine has gotten noticeable enough to do something > about. Of course I reviewed my archives and Tim's website as > refresher. > Taking the cowling off and checking things I found that I > could not tighten the big nut to the next flat, so the > amount of pull is irrelevant at the moment. > Has anyone tried new Belleville washers? > Secondly, I noticed about a 1/4" of up/down play on the nose > gear leg, which I assume is compression of the donuts. (I am > at about 130 hours). > Will check today to see if another washer is needed. Yes, I > have done the service bulletin upgrade, and there was no > play at the time. > I guess the next step will be to get a wheel balancer and > balance the nose wheel. Then do the mains at annual > condition inspection. > Has anyone drilled the bottom of the gear leg to get an > intermediate cotter pin position for the pivot nut? > -sent from the I-droid implanted in my forearm > > > =================================== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" > target="_blank">http://www.matronics.com/contribution > =================================== > > > > > ________________________________________________________________________________
Date: Dec 28, 2017
I thought I wrote Minus 20. I remember walking to grade school in EauClaire uphill both ways through 3' of snow at -30f. (wink, wink) Kelly You could be in AZ in 8 hours with that magic 10 or 14. On 12/28/2017 7:22 AM, Tim Olson wrote: > > Sounds good on the progress Kelly. Wish I was in your > frigid location...our high yesterday was -1F, and today it's > a bit warmer but it comes with crappy weather. We won't be seeing > 20F for any time in the 7 day forecast. > ________________________________________________________________________________
Date: Dec 28, 2017
Yeah, it isn't so bad right now. It's when it's lower than -20 that it gets more painful. I'm thinking of going for a swim in the Chippewa today. :) That really is the beauty of the RV-10, folks. I tell people all the time that from where I live, I can be anywhere in the lower 48 in 12 hours or less. There's no excuse not to travel by RV with the capabilities these planes have. (although today I'd need known icing to get out of here I think) Tim On 12/28/2017 8:28 AM, Kelly McMullen wrote: > > I thought I wrote Minus 20. > I remember walking to grade school in EauClaire uphill both ways through > 3' of snow at -30f. (wink, wink) > Kelly > You could be in AZ in 8 hours with that magic 10 or 14. > > On 12/28/2017 7:22 AM, Tim Olson wrote: >> >> Sounds good on the progress Kelly. Wish I was in your >> frigid location...our high yesterday was -1F, and today it's >> a bit warmer but it comes with crappy weather. We won't be seeing >> 20F for any time in the 7 day forecast. >> > ________________________________________________________________________________
Date: Dec 28, 2017
Yeah, at about -20 the Chippewa starts emitting fog. Talk of small world, the A&P I borrowed the wheel balancer from grew up less than 3 blocks from the house I grew up in, in EauClaire, went to same grade school, about 4 yrs behind me, now works as mechanic at Chandler Airport. On 12/28/2017 7:38 AM, Tim Olson wrote: > > Yeah, it isn't so bad right now. It's when it's lower than -20 > that it gets more painful. I'm thinking of going for a swim > in the Chippewa today. :) > > That really is the beauty of the RV-10, folks. I tell people > all the time that from where I live, I can be anywhere in the > lower 48 in 12 hours or less. There's no excuse not to travel > by RV with the capabilities these planes have. > (although today I'd need known icing to get out of here I think) > > Tim > > > On 12/28/2017 8:28 AM, Kelly McMullen wrote: >> >> I thought I wrote Minus 20. >> I remember walking to grade school in EauClaire uphill both ways >> through 3' of snow at -30f. (wink, wink) >> Kelly >> You could be in AZ in 8 hours with that magic 10 or 14. >> >> On 12/28/2017 7:22 AM, Tim Olson wrote: >>> >>> Sounds good on the progress Kelly. Wish I was in your >>> frigid location...our high yesterday was -1F, and today it's >>> a bit warmer but it comes with crappy weather. We won't be seeing >>> 20F for any time in the 7 day forecast. >>> >> > > > > > ________________________________________________________________________________
Subject: Re: EFIS Configuration
Date: Jan 02, 2018
This can be tricky and is dependent on a lot of other things, like autopilot, comms, GPS, ADS-B, and sensors, just to name a few. It is also dependent on your wiring, since there is some flexibility in where things attach. Contact me offline at flymoore(at)charter.net -------- Dave Moore RV-6 built and sold RV-10 built and flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477028#477028 ________________________________________________________________________________
Date: Jan 02, 2018
Not to mention that figuring out how to configure the EFIS is one of the major ways to become familiar with the system, so that by first flight the EFIS isn't one of the new items you are testing. -sent from the I-droid implanted in my forearm On Tue, Jan 2, 2018 at 5:38 PM, nukeflyboy wrote: > > This can be tricky and is dependent on a lot of other things, like > autopilot, comms, GPS, ADS-B, and sensors, just to name a few. It is also > dependent on your wiring, since there is some flexibility in where things > attach. > > Contact me offline at flymoore(at)charter.net > > -------- > Dave Moore > RV-6 built and sold > RV-10 built and flying > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477028#477028 > > ________________________________________________________________________________
Date: Jan 03, 2018
Kelly I know that, and I already have done several steps of the configuration, but my idea is to compare data and check if I=99ve done something wrong ( for example I=99m not getting the Nav/Comm radio to comunica-te with t he GDU) or if I should configurate things differently (better). Thanks Carlos Enviado do meu iPhone No dia 03/01/2018, =C3-s 01:57, Kelly McMullen escreve u: > Not to mention that figuring out how to configure the EFIS is one of the m ajor ways to become familiar with the system, > so that by first flight the EFIS isn't one of the new items you are testin g. > > -sent from the I-droid implanted in my forearm > >> On Tue, Jan 2, 2018 at 5:38 PM, nukeflyboy wrote: >> >> This can be tricky and is dependent on a lot of other things, like autopi lot, comms, GPS, ADS-B, and sensors, just to name a few. It is also depende nt on your wiring, since there is some flexibility in where things attach. >> >> Contact me offline at flymoore(at)charter.net >> >> -------- >> Dave Moore >> RV-6 built and sold >> RV-10 built and flying >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=477028#477028 >> >> >> >> >> >> >> ========================= >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= >> >> >> > ________________________________________________________________________________
Subject: Canopy Trimming
Date: Jan 03, 2018
What tool are people using to cut the window openings? The curves are too tight for a cutoff wheel and an oscillating tool works great for straight cuts but does not want to cut the curves either. David Fritzsche ________________________________________________________________________________
Date: Jan 03, 2018
I used a combination of the cutoff wheel and small (1") sanding drum on my high speed drill. For smaller holes I used the same types of tools with my Dremel. Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David J. Fritzsche Sent: Wednesday, January 03, 2018 3:53 PM Subject: RV10-List: Canopy Trimming --> What tool are people using to cut the window openings? The curves are too tight for a cutoff wheel and an oscillating tool works great for straight cuts but does not want to cut the curves either. David Fritzsche ________________________________________________________________________________
Subject: Re: Canopy Trimming
Date: Jan 03, 2018
Yes, you can get 1 or 2" cut off wheels for the Dremel. The sanding drums are good for the final 1/8-1/16" you need to smooth out. On 1/3/2018 4:09 PM, Rene wrote: > > I used a combination of the cutoff wheel and small (1") sanding drum on my high speed drill. For smaller holes I used the same types of tools with my Dremel. > > Rene' > 801-721-6080 ________________________________________________________________________________
Date: Jan 03, 2018
The best thing I found was the cutoff wheel, then substituting a jigsaw with a fiberglass cutting blade for the curves. -----Original Message----- From: David J. Fritzsche Sent: Wednesday, January 03, 2018 5:52 PM Subject: RV10-List: Canopy Trimming What tool are people using to cut the window openings? The curves are too tight for a cutoff wheel and an oscillating tool works great for straight cuts but does not want to cut the curves either. David Fritzsche ________________________________________________________________________________
From: John MacCallum <john.maccallum(at)bigpond.com>
Date: Jan 04, 2018
I used the half moon vibrating cutter to do most of the cuts. Just the corner of it like a blade. Then I used a power file in the tight radius bends. Cheers John MacCallum RV10 VH DUU > On 4 Jan 2018, at 10:09, Rene wrote: > > > I used a combination of the cutoff wheel and small (1") sanding drum on my high speed drill. For smaller holes I used the same types of tools with my Dremel. > > Rene' > 801-721-6080 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David J. Fritzsche > Sent: Wednesday, January 03, 2018 3:53 PM > To: RV-10 Matronics > Subject: RV10-List: Canopy Trimming > > --> > > What tool are people using to cut the window openings? The curves are too tight for a cutoff wheel and an oscillating tool works great for straight cuts but does not want to cut the curves either. > > David Fritzsche > > > > > > > > ________________________________________________________________________________
Date: Jan 12, 2018
I used a PermaGrit jigsaw blade. Cuts through the fiberglass like butter and has none of the dust of a cutoff wheel. All of the PermaGrit tools are highly recommended...they make working on the fiberglass MUCH easier... https://www.fibreglast.com/product/Perma-Grit_Jig_Saw_Blades/Supplies_Tools_Laminate_Cutting Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477241#477241 ________________________________________________________________________________
Subject: Step modification
Date: Jan 16, 2018
Previously I read posts about an aluminum insert to reinforce the step. Any know where I find that modification? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477345#477345 ________________________________________________________________________________
Date: Jan 16, 2018
Subject: Re: Step modification
http://www.tcwtech.com/rv-10_construction_project.html On Tue, Jan 16, 2018 at 10:04 AM whodja wrote: > > Previously I read posts about an aluminum insert to reinforce the step. > Any know where I find that modification? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477345#477345 > > ________________________________________________________________________________
Date: Jan 16, 2018
We sell the insert on our web site. Www.tcwtech.com. Rv-10 step bushings. Bob Newman TCW Technologies, LLC 610-928-3420 > On Jan 16, 2018, at 10:58 AM, whodja wrote: > > > Previously I read posts about an aluminum insert to reinforce the step. Any know where I find that modification? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477345#477345 > > > > > > > > > ________________________________________________________________________________
Date: Jan 16, 2018
I got mine from Bob Newman. Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> on behalf of Bob Condrey Sent: Tuesday, January 16, 2018 11:08:52 AM Subject: Re: RV10-List: Step modification http://www.tcwtech.com/rv-10_construction_project.html On Tue, Jan 16, 2018 at 10:04 AM whodja > wrote: mail.com>> Previously I read posts about an aluminum insert to reinforce the step. Any know where I find that modification? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477345#477345 -List" rel="noreferrer" target="_blank">http://www.matronics.com/Naviga tor?RV10-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 16, 2018
I made mine from a short length of steel pipe radiused on the ends and epoxied in place with JB -Weld. Use a notched stick with a strap around the end to slide it into place inside the step tube. On Tue, Jan 16, 2018 at 11:39 AM, Bob Leffler wrote: > I got mine from Bob Newman. > > Get Outlook for iOS > ------------------------------ > *From:* owner-rv10-list-server(at)matronics.com matronics.com> on behalf of Bob Condrey > *Sent:* Tuesday, January 16, 2018 11:08:52 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Step modification > > http://www.tcwtech.com/rv-10_construction_project.html > > On Tue, Jan 16, 2018 at 10:04 AM whodja wrote: > >> >> Previously I read posts about an aluminum insert to reinforce the step. >> Any know where I find that modification? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=477345#477345 >> >> >> >> >> >> >> ========== >> -List" rel="noreferrer" target="_blank">http://www. >> matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> ________________________________________________________________________________
Date: Jan 17, 2018
As well as the various inserts, going up a size from the -3 bolt is a good idea considering the loads that can be imposed on the step. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477363#477363 ________________________________________________________________________________
Date: Jan 17, 2018
Subject: VOR/GS/LOC Antenna and Static Wicks
Just received my -10 empennage kit and got started building the VS. I am wondering what is the best cat whisker antenna/model number to mount in the top of the tail that others have had success with and also wondering if static wicks are necessary or overkill? ________________________________________________________________________________
Subject: Re: VOR/GS/LOC Antenna and Static Wicks
Date: Jan 17, 2018
None. Put an Archer antenna in a wingtip. Almost as good as a cat whisker, gain 1/4 knot speed, wont poke your eye out. Most builders seem to go without static wicks. I havent heard of any static problems, but, never say never. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477393#477393 ________________________________________________________________________________
Date: Jan 17, 2018
I have a standard "V" antenna on top of the vertical stabilizer, and a Bob Archer antenna in a wingtip (two NAV radios and I didn't want to reduce signal with a splitter). They both work well, though the traditional antenna on the tail does pick up stations further away. I don't have static wicks on my aircraft - at least so far, I haven't experienced any problems that might be attributable to static buildup. Dan > On 2018-Jan-17, at 8:11 PM, Tim Jennings wrote: > > Just received my -10 empennage kit and got started building the VS. I am wondering what is the best cat whisker antenna/model number to mount in the top of the tail that others have had success with and also wondering if static wicks are necessary or overkill? --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Date: Jan 18, 2018
I went with 2 Archer antennas, one in each wingtip so I wouldn't need a splitter. There was a time when having 120 nm range at 10,000 ft was important for victor airways in the west, but in today's GPS environment more than 50 nm range is unlikely to be used. Both antennas work equally well for ILS, but put centerline about 15 ft one side or the other. ;>) Static wicks might make sense if you plan on doing a lot of flying inside snow or very dry clouds. With the 10's capabilities, I want to either be on top of clouds or well underneath. Slogging along for long periods below 10K in clouds and precip is to be avoided to my way of thinking. Sure, there can be times that other factors might give that result, but the -10 climbs so well that you should be able to get on top unless there is significant vertical activity, and I want to stay away from those convective conditions. Even pilots flying actively for business are unlikely to spend much more than 10% of flight time in actual IMC. Static wicks are magnets for damage and maintenance expense. And you have to adjust the balance of control surfaces to account for their weight. JMHO On 1/17/2018 11:06 PM, Dan Charrois wrote: > > I have a standard "V" antenna on top of the vertical stabilizer, and a Bob Archer antenna in a wingtip (two NAV radios and I didn't want to reduce signal with a splitter). They both work well, though the traditional antenna on the tail does pick up stations further away. > > I don't have static wicks on my aircraft - at least so far, I haven't experienced any problems that might be attributable to static buildup. > > Dan > >> On 2018-Jan-17, at 8:11 PM, Tim Jennings wrote: >> >> Just received my -10 empennage kit and got started building the VS. I am wondering what is the best cat whisker antenna/model number to mount in the top of the tail that others have had success with and also wondering if static wicks are necessary or overkill? > > --- > Dan Charrois > President, Syzygy Research & Technology > Phone: 780-961-2213 > > > > > ________________________________________________________________________________
Date: Jan 18, 2018
You'll want to first decide how much IFR flying you really plan to do with the plane. If you aren't going to be flying IFR, I'd just throw an Archer antenna in. If you're going to be real interested in doing IFR flying, I'd really consider the whiskers. I mounted one of these CI-157P antennas (I think that's the one I used but it's been a while) underneath the tail. http://www.aircraftspruce.com/catalog/avpages/comant157p.php It gives me at minimum 25% better range of reception with no less worry about being shaded by the airframe depending on where the station is. The archer has the disadvantage of only truly having the best positioning for reception when the station is on the same side of the airplane as the antenna. Position the station on the opposite side and reception will get much worse. I've compared mine in flight many times over the years and it's definite that the range will be better with whiskers. If you're going to mount them on the bottom, you won't need to worry about removable elements. If you want it on the top, you may want to consider the CI-158C or CI-158C-2 or similar, where you can remove the elements. http://www.aircraftspruce.com/catalog/avpages/comant158c.php http://www.aircraftspruce.com/catalog/avpages/comantci158c.php I know people who have cut the holes in the top of the VS to mount the antenna. The slots if you use slots would go through the upper rib though, which could weaken it, so I'd get one with removable elements so you can just put holes in for the elements to attach through. Regarding static wicks, I've always wanted to have them on my plane but haven't installed any yet. I've paid the price a few times, having p-static build up while in the clouds and ended up with radios that got fuzzed up or snap and pop and odd things like that. But it's only happened a few times that I've been sure that's what was happening. So while think it's a good idea, I'm not ready to call it a "must do". If you do it, there is a document out there that someone worked out that shows a possible placement on the RV-10. I don't know anyone yet who's installed them all like that though. Hope that helps, Tim On 01/17/2018 09:11 PM, Tim Jennings wrote: > Just received my -10 empennage kit and got started building the VS. I > am wondering what is the best cat whisker antenna/model number to mount > in the top of the tail that others have had success with and also > wondering if static wicks are necessary or overkill? ________________________________________________________________________________
Date: Jan 18, 2018
I used to have Archer antennas in each wing tip, one for each radio. After loosing the glide slope signal several times during the turn to final, I decided to add a cat wisker antenna on the belly, which cured the issue. The Archer antenna is directional, and while it performed just fine for VOR reception, it was not as solid as I would like it for the ILS approaches. IRT static wicks. I installed mine from day 1 and I have never had any P-static issues. I have heard now of three instances of airframe static on the RV-10, which was cured with the installation of static wicks. If you do a search on VAF you should be able to find the posts. You won't find a production certified IFR aircraft without them, and if you are serious about flying IMC, then IMHO they should be installed. Dayton-Grainger has a drawing with recommended locations for the RV-10, posted below. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477404#477404 Attachments: http://forums.matronics.com//files/dayton_granger_rv10_146.jpg ________________________________________________________________________________
Date: Jan 18, 2018
Tim, I'm curious as to what benefits you see from additional range on your VOR. If flying an airway, I just select that on my GTN 650 and fly it. I guess if using a GNS430/530 I would just plug in the fixes that defined the entry and exit of the airway. While I monitor the VOR with my SL30, can't say that I have noticed a situation where I was out of range with either VOR, but I only use the VOR as primary nav when flying a VOR approach these days. Can't say that I have seen airframe blocking either, but haven't really looked for it. Gone are the days when I flew IFR with 1 nav/comm and 1 ADF as my total nav capability. On 1/18/2018 7:44 AM, Tim Olson wrote: > > You'll want to first decide how much IFR flying you really plan to do > with the plane. If you aren't going to be flying IFR, I'd just throw > an Archer antenna in. If you're going to be real interested in doing > IFR flying, I'd really consider the whiskers. ________________________________________________________________________________
Subject: Re: Static Wicks
Date: Jan 18, 2018
Not true re production built, type certified aircraft. I flew a 1965 Mooney M20E, for 18 years, which uses the same speeds except about 10 kts slower in cruise, IFR whenever needed. It was factory IFR approved. I know there are plenty of others. In the time few the Mooney I might have experience a little static once. I see the need when cruise starts approaching 200 kts, but otherwise consider it a nice to have that I would put near the bottom of my wish list. On 1/18/2018 7:56 AM, bill.peyton wrote: > You won't find a production certified IFR aircraft without them, and if you are serious about flying IMC, then IMHO they should be installed. Dayton-Grainger has a drawing with recommended locations for the RV-10, posted below. > > -------- > Bill > WA0SYV > Aviation Partners, LLC ________________________________________________________________________________
Date: Jan 18, 2018
Kelly, In my case it was a matter of losing the GS signal during approach that caused me to re-think the Archer antenna solution. The Archer antennas are somewhat directional, and apparently at a specific bank and turn angle were causing lose of signal for me. As for VOR reception it worked great. Bill -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477407#477407 ________________________________________________________________________________
Date: Jan 18, 2018
I guess, just haven't seen it with my radios, so far. I can't imagine making enough bank while on approach that would blank line of sight to either wing tip. As I said, I have nav antenna in each wing tip, each connected to a single nav-com with ILS. But I pretty much have to leave AZ to fly IFR for real..... Kelly On 1/18/2018 8:11 AM, bill.peyton wrote: > > Kelly, > In my case it was a matter of losing the GS signal during approach that caused me to re-think the Archer antenna solution. The Archer antennas are somewhat directional, and apparently at a specific bank and turn angle were causing lose of signal for me. As for VOR reception it worked great. > Bill > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477407#477407 > > > > > > > > > ________________________________________________________________________________
Date: Jan 18, 2018
For me it all comes down to one thing, basically that echos what Bill Peyton brought up right after your reply. IFR is serious business. Sure, we're allowed, as experimental builders, to do some things with our equipment that is not up to part 23 standards, but we do ourselves no favors by doing anything that hurts performance. For me, it makes me cringe when I hear about someone being so concerned about aesthetics that they would rather hide every antenna than have the best performance available. They'll hide a GPS antenna under the engine cowl, for their WASS Beta 3 capable LPV Approach GPS, rather than mount it as level as possible with a full view of the sky, on the highest point of the aircraft. I personally feel that when people do such things, with their higher end IFR equipment, that they are being irresponsible. On the same note, I view comments by people who are so 100% trusting of their GPS, that they would say things like "Why even bother installing a NAV radio", and just as short sighted and uninformed. The fact is, once you are up inside a cloud with your airplane, the lives of you and your passengers while flying IFR are largely in control of the quality of the technology you installed, and the methods you installed it with, with a huge additional factor of your own personal skill and experience. In todays world, if GPS is not functioning, such as the very recent GPS jamming that was going to happen in the South East Coast area, the impact on your ability to continue safely and successfully a flight is hindered. You need to be fully willing, if you fly in IMC, to be ready to use whatever alternate nav means necessary to provide a safe ending to your flight. If that means tuning in a VOR (or two, when off airway, to triangulate your position and find where you are) and then flying an ILS to minimums, so be it. So short and simple, I think it's taking short cuts and being a little irresponsible and goes against a philosophy of safety to make performance compromises on your navigational equipment, if that equipment could be used for instrument approaches. 95% of the time, it won't matter if you have an archer or whiskers antennas, but philosophically I can't see cutting corners on a 4-seat RV-10. I did make that compromise on my RV-14, but the number of lives in those seats is smaller, and to be honest, I still feel uneasy with the compromise. And for me, if it's an IFR day, I'd be taking the RV-10 in most cases anyway. With the Feds cutting the number of VOR stations over time, the impact will be absolutely unmanageable in the event of a widespread GPS issue. Every airliner and airplane in the sky will be looking for the the handful of fallback airports, and the controllers would likely not be able to handle the quantities of traffic to those airports. So I'm not much of a fan of getting rid of all of the VORs either. Anyway, with GPS available, it's awesome to use, but if someone is serious about flying IFR, take it seriously and build your aircraft to FAR 23 specs or better, and install for best performance, not best cosmetics. Tim On 01/18/2018 08:55 AM, Kelly McMullen wrote: > > Tim, > I'm curious as to what benefits you see from additional range on your > VOR. If flying an airway, I just select that on my GTN 650 and fly it. I > guess if using a GNS430/530 I would just plug in the fixes that defined > the entry and exit of the airway. While I monitor the VOR with my SL30, > can't say that I have noticed a situation where I was out of range with > either VOR, but I only use the VOR as primary nav when flying a VOR > approach these days. Can't say that I have seen airframe blocking > either, but haven't really looked for it. > Gone are the days when I flew IFR with 1 nav/comm and 1 ADF as my total > nav capability. > ________________________________________________________________________________
Date: Jan 18, 2018
Just my 2 centsstatic discharge is more art than science. I considered it because of static problems I had in our club=99s 182=99s which had static wicks. After looking at what needed to be done, static wicks and bonding straps, and the long term maintenance requirements I choose not to do it. I have had limited IFR time in my airplane, but have not experienced any problems. Flying since 2008. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Jennings Sent: Wednesday, January 17, 2018 8:12 PM Subject: RV10-List: VOR/GS/LOC Antenna and Static Wicks Just received my -10 empennage kit and got started building the VS. I am wondering what is the best cat whisker antenna/model number to mount in the top of the tail that others have had success with and also wondering if static wicks are necessary or overkill? ________________________________________________________________________________
Date: Jan 18, 2018
Well stated Tim. My sentiments exactly! -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477412#477412 ________________________________________________________________________________
Date: Jan 18, 2018
And one more variable... the Archer Nav antenna is very finicky about how it=99s installed. I=99ve seen a LOT that weren=99t done very well and had resulting degraded performance. Most issues I=99ve seen were routing of wiring (not along the antenna leading edge) and the antenna not as far forward as possible. For those with heat shielding for halogen wingtip landing lights, the antenna should be as close as possible to the shielding material without actually touching (that info direct from Bob Archer himself several years ago). Finally, I=99ve seen creative installs w here the strip along the wing edge wasn=99t fully electrically connected to th e wing (either under the nutplates or direct to the outboard rib). Bob On Thu, Jan 18, 2018 at 9:38 AM bill.peyton wrote: > > Well stated Tim. My sentiments exactly! > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477412#477412 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
From: "Parish Moffitt" <parish(at)parishmoffitt.com>
Date: Jan 18, 2018
To echo Tim, and add on a little here. I think one must realistically look at their abilities and their mission profile for the airplane. Not only is there a difference between VFR and IFR but there is a difference between IFR and IFR to 200 and a half on both ends where the total time for the flight is the amount you put in your logbook as actual IFR. I tell people all the time I am building my airplane to practically CAT II standards as I shoot approaches to 600ft RVR on a regular basis and feel comfortable doing so. Someone who flies through a 2000 ft overcast layer a few times a year might not have the same comfort level. I think you also need to look at where you live as well. Do you live in AZ, then a less capable IFR setup is not that big of a deal. Do you live in Seattle? Can we install auto land in this thing, LOL? I live in the Carolinas and know we can get socked in from time to time for 2 or 3 days straight. To add one more point for the original poster and this goes to the VOR antennae discussion. Where do you plan to fly your airplane? If you plan to do any flying outside the USA and in particular to some of the remote Caribbean locations, having a good VOR antennae is paramount as that may be your only means of listening to flight service. Also some airports here in the states still use VORs to transmit the ATIS, Scranton PA for instance. I used to love it when I was flying at the regional airline and watching my FO try to figure out how to get the com radio to go to 108 or 110 point something. My airplane will have a whisker up top. I placed a doubler plate on the top rib and installed nut plates for the RAMI ant. http://www.aircraftspruce.com/catalog/avpages/ramiav525.php?recfer=11262 I have also installed the static wicks per Mouser/ Dayton Grangers instructions. I have chosen to reduce my cost a little and gone with non-cert wicks at 26$ each rather than 47$. Just don't forget the bonding straps between the control surfaces and the fixed surfaces. http://www.aircraftspruce.com/catalog/elpages/esd3staticwick.php?clickkey=6974 http://mouser.org/projects/rv-10/staticwicks.html -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Thursday, January 18, 2018 10:24 AM Subject: Re: RV10-List: VOR/GS/LOC Antenna and Static Wicks For me it all comes down to one thing, basically that echos what Bill Peyton brought up right after your reply. IFR is serious business. Sure, we're allowed, as experimental builders, to do some things with our equipment that is not up to part 23 standards, but we do ourselves no favors by doing anything that hurts performance. For me, it makes me cringe when I hear about someone being so concerned about aesthetics that they would rather hide every antenna than have the best performance available. They'll hide a GPS antenna under the engine cowl, for their WASS Beta 3 capable LPV Approach GPS, rather than mount it as level as possible with a full view of the sky, on the highest point of the aircraft. I personally feel that when people do such things, with their higher end IFR equipment, that they are being irresponsible. On the same note, I view comments by people who are so 100% trusting of their GPS, that they would say things like "Why even bother installing a NAV radio", and just as short sighted and uninformed. The fact is, once you are up inside a cloud with your airplane, the lives of you and your passengers while flying IFR are largely in control of the quality of the technology you installed, and the methods you installed it with, with a huge additional factor of your own personal skill and experience. In todays world, if GPS is not functioning, such as the very recent GPS jamming that was going to happen in the South East Coast area, the impact on your ability to continue safely and successfully a flight is hindered. You need to be fully willing, if you fly in IMC, to be ready to use whatever alternate nav means necessary to provide a safe ending to your flight. If that means tuning in a VOR (or two, when off airway, to triangulate your position and find where you are) and then flying an ILS to minimums, so be it. So short and simple, I think it's taking short cuts and being a little irresponsible and goes against a philosophy of safety to make performance compromises on your navigational equipment, if that equipment could be used for instrument approaches. 95% of the time, it won't matter if you have an archer or whiskers antennas, but philosophically I can't see cutting corners on a 4-seat RV-10. I did make that compromise on my RV-14, but the number of lives in those seats is smaller, and to be honest, I still feel uneasy with the compromise. And for me, if it's an IFR day, I'd be taking the RV-10 in most cases anyway. With the Feds cutting the number of VOR stations over time, the impact will be absolutely unmanageable in the event of a widespread GPS issue. Every airliner and airplane in the sky will be looking for the the handful of fallback airports, and the controllers would likely not be able to handle the quantities of traffic to those airports. So I'm not much of a fan of getting rid of all of the VORs either. Anyway, with GPS available, it's awesome to use, but if someone is serious about flying IFR, take it seriously and build your aircraft to FAR 23 specs or better, and install for best performance, not best cosmetics. Tim On 01/18/2018 08:55 AM, Kelly McMullen wrote: > > Tim, > I'm curious as to what benefits you see from additional range on your > VOR. If flying an airway, I just select that on my GTN 650 and fly it. > I guess if using a GNS430/530 I would just plug in the fixes that > defined the entry and exit of the airway. While I monitor the VOR with > my SL30, can't say that I have noticed a situation where I was out of > range with either VOR, but I only use the VOR as primary nav when > flying a VOR approach these days. Can't say that I have seen airframe > blocking either, but haven't really looked for it. > Gone are the days when I flew IFR with 1 nav/comm and 1 ADF as my > total nav capability. > ________________________________________________________________________________
Date: Jan 18, 2018
bcondrey wrote: > And one more variable... the Archer Nav antenna is very finicky about how its installed. Ive seen a LOT that werent done very well and had resulting degraded performance. Most issues Ive seen were routing of wiring (not along the antenna leading edge) and the antenna not as far forward as possible. For those with heat shielding for halogen wingtip landing lights, the antenna should be as close as possible to the shielding material without actually touching (that info direct from Bob Archer himself several years ago). Finally, Ive seen creative installs where the strip along the wing edge wasnt fully electrically connected to the wing (either under the nutplates or direct to the outboard rib). > > > Bob > > > > --> > > > > > I agree 100% with Bobs post, above. I have personally seen installations where the ground leg was 8 away from the rib, and connected to it by a piece of wire. Ive also seen one that was backwards, with the ground leg out in the wing tip, and the radiating leg attached to the rib! Little wonder some report poor performance. Ideally these need to be installed with proper test equipment; lacking that, at least a working knowledge of what is important and what is not. As an aside, I have my backup com on an Archer. Due to the difficulty getting vertical polarization out in the wing tip, it is not as good as my external whip. However, it is nowhere near as bad as many others report. I believe this is 100% installation related. Tim: I agree with much of what you wrote. IFR is serious business. I would never install my primary nav antenna (gps) contrary to the manufacturers instructions, even if it wasnt technically illegal to do so. I would not accept my Archer nav antenna if my GS dropped out on a turn to final (it doesnt). I wouldnt accept it if I couldnt pick up a VOR 50 nm away (I can). But I am willing to accept that 50 nm range is about the limit in the 3 oclock direction (antenna is in the left wingtip). At the same time, there are some downsides to cats whiskers. They need matching networks, which seem to attract moisture over time. A walk around my home field will probably turn up one with a missing element. Theyre ice magnets. And people washing airplanes really do poke themselves on them! As the saying goes, engineering is the art of compromise. Everyone flying in IMC needs to carefully consider the consequences of their choices. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477425#477425 ________________________________________________________________________________
Date: Jan 18, 2018
Bob T I agree that many amongst us dont install the Archer antennae right, but that is also due to the poor instructions which come with them... That is why I looked thoroughly for pictures of well installed Archer antennae. Once again: one picture worths more than a thousand words Cheers Carlos Enviado do meu iPhone No dia 18/01/2018, s 20:34, Bob Turner escreveu: > > > bcondrey wrote: >> And one more variable... the Archer Nav antenna is very finicky about how its installed. Ive seen a LOT that werent done very well and had resulting degraded performance. Most issues Ive seen were routing of wiring (not along the antenna leading edge) and the antenna not as far forward as possible. For those with heat shielding for halogen wingtip landing lights, the antenna should be as close as possible to the shielding material without actually touching (that info direct from Bob Archer himself several years ago). Finally, Ive seen creative installs where the strip along the wing edge wasnt fully electrically connected to the wing (either under the nutplates or direct to the outboard rib). >> >> >> Bob >> >> >>> --> >>> >>> >> > > > I agree 100% with Bobs post, above. I have personally seen installations where the ground leg was 8 away from the rib, and connected to it by a piece of wire. Ive also seen one that was backwards, with the ground leg out in the wing tip, and the radiating leg attached to the rib! Little wonder some report poor performance. Ideally these need to be installed with proper test equipment; lacking that, at least a working knowledge of what is important and what is not. As an aside, I have my backup com on an Archer. Due to the difficulty getting vertical polarization out in the wing tip, it is not as good as my external whip. However, it is nowhere near as bad as many others report. I believe this is 100% installation related. > Tim: I agree with much of what you wrote. IFR is serious business. I would never install my primary nav antenna (gps) contrary to the manufacturers instructions, even if it wasnt technically illegal to do so. I would not accept my Archer nav antenna if my GS dropped out on a turn to final (it doesnt). I wouldnt accept it if I couldnt pick up a VOR 50 nm away (I can). But I am willing to accept that 50 nm range is about the limit in the 3 oclock direction (antenna is in the left wingtip). At the same time, there are some downsides to cats whiskers. They need matching networks, which seem to attract moisture over time. A walk around my home field will probably turn up one with a missing element. Theyre ice magnets. And people washing airplanes really do poke themselves on them! As the saying goes, engineering is the art of compromise. Everyone flying in IMC needs to carefully consider the consequences of their choices. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477425#477425 > > > > > > > > > ________________________________________________________________________________
Date: Jan 18, 2018
Bob I agree a lot with what you said. I contacted Bob Archer when I wasn't clear on the instructions and wanted to know what was critical. My point was as you say, 50 nm range is generally acceptable for VOR in the lower 48. (I routinely flew IFR a non-radar route in Alaska that had the midpoint cross-over 110 nm from each VOR and cat whiskers were needed and GPS didn't exist). I have seen the Archer antenna performance degrade more than 50% when the wing tip was painted with metallic paint. I see no drop out of ILS, even where my localizer intercept is about 12 nm out and GS intercept around 8 nm out. To some degree this is also the same argument of whether to use RG58 for VHF radios or RG-400. (totally different requirements than transponder and GPS that operate at and above 978 Mhz.) Sure, I'd like to have radar altimeter and Cat III approved autopilot...but I don't need either one, and have no problem planning legs that have forecast above Cat I minimums and alternates that at least meet alternate requirements or better. Yes, my IFR GPS antenna install is strictly in accordance with TSO/manufacturer's requirements, on top of the canopy, not under anything. Kelly Sent from my IBM-360 main frame On Thu, Jan 18, 2018 at 1:34 PM, Bob Turner wrote: > > > bcondrey wrote: > > And one more variable... the Archer Nav antenna is very finicky about > how it=99s installed. I=99ve seen a LOT that weren=99t done very well and had > resulting degraded performance. Most issues I=99ve seen were routi ng of > wiring (not along the antenna leading edge) and the antenna not as far > forward as possible. For those with heat shielding for halogen wingtip > landing lights, the antenna should be as close as possible to the shieldi ng > material without actually touching (that info direct from Bob Archer > himself several years ago). Finally, I=99ve seen creative installs where the > strip along the wing edge wasn=99t fully electrically connected to the wing > (either under the nutplates or direct to the outboard rib). > > > > > > Bob > > > > > > > --> > > > > > > > > > > > I agree 100% with Bob=99s post, above. I have personally seen insta llations > where the ground leg was 8=9D away from the rib, and connected to i t by a > piece of wire. I=99ve also seen one that was backwards, with the gr ound leg > out in the wing tip, and the radiating leg attached to the rib! Little > wonder some report poor performance. Ideally these need to be installed > with proper test equipment; lacking that, at least a working knowledge of > what is important and what is not. As an aside, I have my backup com on a n > Archer. Due to the difficulty getting vertical polarization out in the wi ng > tip, it is not as good as my external whip. However, it is nowhere near a s > bad as many others report. I believe this is 100% installation related. > Tim: I agree with much of what you wrote. IFR is serious business. I woul d > never install my primary nav antenna (gps) contrary to the manufacturer =99s > instructions, even if it wasn=99t technically illegal to do so. I w ould not > accept my Archer nav antenna if my GS dropped out on a turn to final (it > doesn=99t). I wouldn=99t accept it if I couldn=99t pick up a VOR 50 nm away (I > can). But I am willing to accept that 50 nm range is about the limit in t he > 3 o=99clock direction (antenna is in the left wingtip). At the same time, > there are some downsides to cat=99s whiskers. They need matching ne tworks, > which seem to attract moisture over time. A walk around my home field wil l > probably turn up one with a missing element. They=99re ice magnets. And > people washing airplanes really do poke themselves on them! As the saying > goes, engineering is the art of compromise. Everyone flying in IMC needs to > carefully consider the consequences of their choices. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477425#477425 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jan 20, 2018
Subject: EarthX Mounting
I just ordered an EarthX battery and was wondering if anyone had photos of how they mounted it in the standard battery box? Thanks, Shannon ________________________________________________________________________________
Date: Jan 22, 2018
Okay, this is a very valuable thread that is helping me figure out a few things that I should have figured out sometime ago. I'll share my experiences in the hope it helps others and I'll ask some questions looking for more insight. First, my GPS setup is 100% by the book and works flawlessly. I originally installed 2 Archers - a Nav and a Comm. The Archer Nav is my sole Nav antenna but I had a whip or whisker for my other Comm. I long ago got rid of the Archer Comm but I'll come back to that. I've made a good number of ILS approaches to various airports in IMC. I fly into a good number of larger airports and the ILS is assigned by default. Generally no problem but I've consistently had problems with the KAGC's ILS for 28. I've been flying into KAGC a lot over the last few years and I often get vectors for the ILS to 28. I noticed that my AP generally missed the left turn for the intercept and the GS was jumpy. I would just have to disconnect it to hand fly it. I gave up on the AP and still found it difficult to get the intercept precisely so I just got in the habit of requesting the RNAV and have no problems. Recently I decided to try a few in VMC and found that the needles were simply unuseable**. I did a few more tests at other airports and had no problems with needles - steady as a rock. But not at KAGC 28. I've wanted to blame the ILS but based on this thread, I'm convinced it's the Archer (my Archer is split to feed two NAVs). At this point after 6 years, I'm planning to put some whiskers on. It's not that I fly a lot of IMC or a lot of hard and low IMC, it's just that I file every flight, I work to stay current, most of it is east of the Mississippi and sometimes, not always predictably, I do an approach to minimums. It all has to work. I don't really understand exactly what static wicks do, when they are most needed and why I might consider them. Based on this thread, I think I encountered a single situation where I needed them. I'd appreciate your comments and any pointers to more information. What happened was this: About 5 years ago I flew from NC to Phoenix. Coming into Phoenix from Santa Fe I was up over 10K and was slam dunked into Phoenix's airspace. As I started a high speed descent I ran through some snow virga (!!) and simultaneously lost the Nav radio I was using. I swear there was lightening in my peripheral vision. I slowed down, changed radios, declared 'unable', got some vectors, and finally put it down in sunny Scottsdale. The radio had been using a whisker antenna but was now dead. Got some help from someone here on the list (it's been awhile but thanks again) to try and trouble shoot it since I didn't want to fly across the country with a single Comm. It stayed dead but during the course of flying around Phoenix I discovered that the Archer Comm antenna just wasn't performing well enough to be my sole antenna for such a cross country trip. So I spent some time swapping antenna's on my working radio to get home. Was this possibly caused by some kind of static discharge? Is that what might have killed my radio? Is that what static wicks are designed to prevent? Anyway, I continued to fly with the Archer Comm and actually used it as my 'primary' radio. It worked fine most of the time. But occasionally I'd have a comm problem and would have to switch to get maximum range. Conversely my belly mounted whisker would have problems when on the ground and I'd use the Archer. Finally I removed the Archer and mounted a 2nd belly whisker. Now when I have problems on the ground (KCLT ground at Wilson Air for example) I switch to the other radio on the other whisker and I'm able to communicate. It's clear to me now that the whiskers far outperform the Archer Comm, but that's pretty well understood by Archer users. It's a sleek backup solution on the Comm side. At this point I'm starting to shop for some Nav whiskers and the easiest way to add them to my 7 yo plane. I'm thinking that I will not be installing static wicks but think I need to recognize that as a limitation though I'm not sure how to mitigate the risks in that area. I need to learn more there. Bill "haven't scared myself in the '10 yet and would like to keep it that way" Watson ** so how can a successful ILS be completed in the soup with unuseable needles? Jumpy needles overlaying a synthethic vision display with a flight path marker can let you convince yourself that you just did an outstanding job handflying thru some nasty turbulence, as long as you turn off the flight director.... is that too much technology? --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jan 22, 2018
IIRC Bill, I think it was your plane that I assisted with some crimpers and/or connectors for your RG400 modifications. I think if you replaced that Archer com antenna with a second nav antenna so that each of your nav units had an antenna without a splitter, your problem on the ILS would go away. My previous plane had two navs, one with remote GS and the other with built-in GS, all running off one cat whisker antenna, with two splitters to get signal to all units. On some approaches one of the ILSs would be weak and flakey (technical term). I have to Archer Nav antennas, one each to individual nav coms with GS. So far I haven't seen any problems. Kelly Sent from my IBM-360 main frame On Mon, Jan 22, 2018 at 8:06 PM, Bill Watson wrote: > > Okay, this is a very valuable thread that is helping me figure out a few > things that I should have figured out sometime ago. I'll share my > experiences in the hope it helps others and I'll ask some questions looking > for more insight. > > First, my GPS setup is 100% by the book and works flawlessly. > > I originally installed 2 Archers - a Nav and a Comm. The Archer Nav is my > sole Nav antenna but I had a whip or whisker for my other Comm. I long ago > got rid of the Archer Comm but I'll come back to that. I've made a good > number of ILS approaches to various airports in IMC. I fly into a good > number of larger airports and the ILS is assigned by default. Generally no > problem but I've consistently had problems with the KAGC's ILS for 28. > > I've been flying into KAGC a lot over the last few years and I often get > vectors for the ILS to 28. I noticed that my AP generally missed the left > turn for the intercept and the GS was jumpy. I would just have to > disconnect it to hand fly it. I gave up on the AP and still found it > difficult to get the intercept precisely so I just got in the habit of > requesting the RNAV and have no problems. Recently I decided to try a few > in VMC and found that the needles were simply unuseable**. I did a few > more tests at other airports and had no problems with needles - steady as a > rock. But not at KAGC 28. I've wanted to blame the ILS but based on this > thread, I'm convinced it's the Archer (my Archer is split to feed two > NAVs). At this point after 6 years, I'm planning to put some whiskers on. > It's not that I fly a lot of IMC or a lot of hard and low IMC, it's just > that I file every flight, I work to stay current, most of it is east of the > Mississippi and sometimes, not always predictably, I do an approach to > minimums. It all has to work. > > I don't really understand exactly what static wicks do, when they are most > needed and why I might consider them. Based on this thread, I think I > encountered a single situation where I needed them. I'd appreciate your > comments and any pointers to more information. What happened was this: > About 5 years ago I flew from NC to Phoenix. Coming into Phoenix from > Santa Fe I was up over 10K and was slam dunked into Phoenix's airspace. As > I started a high speed descent I ran through some snow virga (!!) and > simultaneously lost the Nav radio I was using. I swear there was > lightening in my peripheral vision. I slowed down, changed radios, > declared 'unable', got some vectors, and finally put it down in sunny > Scottsdale. > > The radio had been using a whisker antenna but was now dead. Got some > help from someone here on the list (it's been awhile but thanks again) to > try and trouble shoot it since I didn't want to fly across the country with > a single Comm. It stayed dead but during the course of flying around > Phoenix I discovered that the Archer Comm antenna just wasn't performing > well enough to be my sole antenna for such a cross country trip. So I > spent some time swapping antenna's on my working radio to get home. > > Was this possibly caused by some kind of static discharge? Is that what > might have killed my radio? Is that what static wicks are designed to > prevent? > > Anyway, I continued to fly with the Archer Comm and actually used it as my > 'primary' radio. It worked fine most of the time. But occasionally I'd > have a comm problem and would have to switch to get maximum range. > Conversely my belly mounted whisker would have problems when on the ground > and I'd use the Archer. Finally I removed the Archer and mounted a 2nd > belly whisker. Now when I have problems on the ground (KCLT ground at > Wilson Air for example) I switch to the other radio on the other whisker > and I'm able to communicate. It's clear to me now that the whiskers far > outperform the Archer Comm, but that's pretty well understood by Archer > users. It's a sleek backup solution on the Comm side. > > At this point I'm starting to shop for some Nav whiskers and the easiest > way to add them to my 7 yo plane. I'm thinking that I will not be > installing static wicks but think I need to recognize that as a limitation > though I'm not sure how to mitigate the risks in that area. I need to > learn more there. > > Bill "haven't scared myself in the '10 yet and would like to keep it that > way" Watson > > ** so how can a successful ILS be completed in the soup with unuseable > needles? Jumpy needles overlaying a synthethic vision display with a > flight path marker can let you convince yourself that you just did an > outstanding job handflying thru some nasty turbulence, as long as you turn > off the flight director.... is that too much technology? > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: Jan 23, 2018
Bill, Your GS issue is the same issue I had with the archer antennas. So I replaced them with a tail mounted dipole (cat whisker). Problem solved! The archer antennas worked great for VOR and LOC reception, just not the GS, which is not surprising since the GS frequency is in an entirely different band (330mhz) for which the antenna is not matched. Resulting signal strength is low and coupled with the directivity caused by the airframe and antenna mounting location, does not make it an ideal candidate for a GS antenna. The issue you had with P-static I also experienced, but not on the -10, on a slow 130kt Piper Archer. Total comm failure in IMC. I installed wicks on the archer and never had the issue again. It's interesting to note that the Piper had a storm scope installed and that prior to installing the static wicks I would see numerous false targets. After the wicks the false targets disappeared. It was fortuitous that Piper actually had an option for the wicks, so it was easy to add them on. As far as the -10 is concerned, I built it knowing I would install wicks. I fly in IMC quite often and have never had static issues. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477509#477509 ________________________________________________________________________________
Date: Jan 23, 2018
Kelly, I thought I remembered it was you but wasn't sure. Thanks again! You know if you ever get out east you have a friend at 8NC8 - anything. And I'm always looking to play it forward. I was hoping someone would suggest a 2nd Archer because that would be the simplest thing for me to do at this point. The funny thing is that everyone mentions the GS being the problem but I clearly have a LOC problem at KAGC 28, in addition to the GS. Otherwise my GS works fine. I really haven't done much testing with my second NAV - only practice approaches and it seems to work fine. Having each NAV hooked up to it's own antenna would not only boost signal strength but would be a better backup configuration. Hmmm. On 1/22/2018 10:27 PM, Kelly McMullen wrote: > IIRC Bill, I think it was your plane that I assisted with some > crimpers and/or connectors for your RG400 modifications. > I think if you replaced that Archer com antenna with a second nav > antenna so that each of your nav units had an antenna without a > splitter, your problem on the ILS would go away. > My previous plane had two navs, one with remote GS and the other with > built-in GS, all running off one cat whisker antenna, with two > splitters to get signal to all units. > On some approaches one of the ILSs would be weak and flakey (technical > term). I have to Archer Nav antennas, one each to individual nav coms > with GS. So far I haven't seen any problems. > Kelly > > > Sent from my IBM-360 main frame > > On Mon, Jan 22, 2018 at 8:06 PM, Bill Watson > wrote: > > > > > Okay, this is a very valuable thread that is helping me figure out > a few things that I should have figured out sometime ago. I'll > share my experiences in the hope it helps others and I'll ask some > questions looking for more insight. > > First, my GPS setup is 100% by the book and works flawlessly. > > I originally installed 2 Archers - a Nav and a Comm. The Archer > Nav is my sole Nav antenna but I had a whip or whisker for my > other Comm. I long ago got rid of the Archer Comm but I'll come > back to that. I've made a good number of ILS approaches to > various airports in IMC. I fly into a good number of larger > airports and the ILS is assigned by default. Generally no problem > but I've consistently had problems with the KAGC's ILS for 28. > > I've been flying into KAGC a lot over the last few years and I > often get vectors for the ILS to 28. I noticed that my AP > generally missed the left turn for the intercept and the GS was > jumpy. I would just have to disconnect it to hand fly it. I > gave up on the AP and still found it difficult to get the > intercept precisely so I just got in the habit of requesting the > RNAV and have no problems. Recently I decided to try a few in > VMC and found that the needles were simply unuseable**. I did a > few more tests at other airports and had no problems with needles > - steady as a rock. But not at KAGC 28. I've wanted to blame the > ILS but based on this thread, I'm convinced it's the Archer (my > Archer is split to feed two NAVs). At this point after 6 years, > I'm planning to put some whiskers on. It's not that I fly a lot > of IMC or a lot of hard and low IMC, it's just that I file every > flight, I work to stay current, most of it is east of the > Mississippi and sometimes, not always predictably, I do an > approach to minimums. It all has to work. > > I don't really understand exactly what static wicks do, when they > are most needed and why I might consider them. Based on this > thread, I think I encountered a single situation where I needed > them. I'd appreciate your comments and any pointers to more > information. What happened was this: About 5 years ago I flew > from NC to Phoenix. Coming into Phoenix from Santa Fe I was up > over 10K and was slam dunked into Phoenix's airspace. As I > started a high speed descent I ran through some snow virga (!!) > and simultaneously lost the Nav radio I was using. I swear there > was lightening in my peripheral vision. I slowed down, changed > radios, declared 'unable', got some vectors, and finally put it > down in sunny Scottsdale. > > The radio had been using a whisker antenna but was now dead. Got > some help from someone here on the list (it's been awhile but > thanks again) to try and trouble shoot it since I didn't want to > fly across the country with a single Comm. It stayed dead but > during the course of flying around Phoenix I discovered that the > Archer Comm antenna just wasn't performing well enough to be my > sole antenna for such a cross country trip. So I spent some time > swapping antenna's on my working radio to get home. > > Was this possibly caused by some kind of static discharge? Is that > what might have killed my radio? Is that what static wicks are > designed to prevent? > > Anyway, I continued to fly with the Archer Comm and actually used > it as my 'primary' radio. It worked fine most of the time. But > occasionally I'd have a comm problem and would have to switch to > get maximum range. Conversely my belly mounted whisker would have > problems when on the ground and I'd use the Archer. Finally I > removed the Archer and mounted a 2nd belly whisker. Now when I > have problems on the ground (KCLT ground at Wilson Air for > example) I switch to the other radio on the other whisker and I'm > able to communicate. It's clear to me now that the whiskers far > outperform the Archer Comm, but that's pretty well understood by > Archer users. It's a sleek backup solution on the Comm side. > > At this point I'm starting to shop for some Nav whiskers and the > easiest way to add them to my 7 yo plane. I'm thinking that I > will not be installing static wicks but think I need to recognize > that as a limitation though I'm not sure how to mitigate the risks > in that area. I need to learn more there. > > Bill "haven't scared myself in the '10 yet and would like to keep > it that way" Watson > > ** so how can a successful ILS be completed in the soup with > unuseable needles? Jumpy needles overlaying a synthethic vision > display with a flight path marker can let you convince yourself > that you just did an outstanding job handflying thru some nasty > turbulence, as long as you turn off the flight director.... is > that too much technology? > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > > =================================== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > ________________________________________________________________________________
Date: Jan 23, 2018
Yes. I am puzzled by the suggestion that the Archer might not be tuned for GS. Cat Whiskers and towel bar and blade antennas are all tuned for 108 to 117 Mhz. GS is roughly a 3 times multiple of that, and you should not be using a GS beyond about 10 nm for approaches, where most intercepts are between 7 and 4 nm. Signal strength should only be an issue if using one or more splitters. I figure that having antenna on each wing tip if there is any airframe blanking that you can just swap to your other nav for that approach. Kelly On 1/23/2018 11:15 AM, Bill Watson wrote: > Kelly, I thought I remembered it was you but wasn't sure. Thanks > again! You know if you ever get out east you have a friend at 8NC8 - > anything. And I'm always looking to play it forward. > > I was hoping someone would suggest a 2nd Archer because that would be > the simplest thing for me to do at this point. The funny thing is that > everyone mentions the GS being the problem but I clearly have a LOC > problem at KAGC 28, in addition to the GS. Otherwise my GS works > fine. I really haven't done much testing with my second NAV - only > practice approaches and it seems to work fine. Having each NAV hooked up > to it's own antenna would not only boost signal strength but would be a > better backup configuration. Hmmm. > > On 1/22/2018 10:27 PM, Kelly McMullen wrote: >> IIRC Bill, I think it was your plane that I assisted with some >> crimpers and/or connectors for your RG400 modifications. >> I think if you replaced that Archer com antenna with a second nav >> antenna so that each of your nav units had an antenna without a >> splitter, your problem on the ILS would go away. >> My previous plane had two navs, one with remote GS and the other with >> built-in GS, all running off one cat whisker antenna, with two >> splitters to get signal to all units. >> On some approaches one of the ILSs would be weak and flakey (technical >> term). I have to Archer Nav antennas, one each to individual nav coms >> with GS. So far I haven't seen any problems. >> Kelly >> >> >> Sent from my IBM-360 main frame >> >> On Mon, Jan 22, 2018 at 8:06 PM, Bill Watson > > wrote: >> >> > >> >> Okay, this is a very valuable thread that is helping me figure out >> a few things that I should have figured out sometime ago. I'll >> share my experiences in the hope it helps others and I'll ask some >> questions looking for more insight. >> >> First, my GPS setup is 100% by the book and works flawlessly. >> >> I originally installed 2 Archers - a Nav and a Comm. The Archer >> Nav is my sole Nav antenna but I had a whip or whisker for my >> other Comm. I long ago got rid of the Archer Comm but I'll come >> back to that. I've made a good number of ILS approaches to >> various airports in IMC. I fly into a good number of larger >> airports and the ILS is assigned by default. Generally no problem >> but I've consistently had problems with the KAGC's ILS for 28. >> >> I've been flying into KAGC a lot over the last few years and I >> often get vectors for the ILS to 28. I noticed that my AP >> generally missed the left turn for the intercept and the GS was >> jumpy. I would just have to disconnect it to hand fly it. I >> gave up on the AP and still found it difficult to get the >> intercept precisely so I just got in the habit of requesting the >> RNAV and have no problems. Recently I decided to try a few in >> VMC and found that the needles were simply unuseable**. I did a >> few more tests at other airports and had no problems with needles >> - steady as a rock. But not at KAGC 28. I've wanted to blame the >> ILS but based on this thread, I'm convinced it's the Archer (my >> Archer is split to feed two NAVs). At this point after 6 years, >> I'm planning to put some whiskers on. It's not that I fly a lot >> of IMC or a lot of hard and low IMC, it's just that I file every >> flight, I work to stay current, most of it is east of the >> Mississippi and sometimes, not always predictably, I do an >> approach to minimums. It all has to work. >> >> I don't really understand exactly what static wicks do, when they >> are most needed and why I might consider them. Based on this >> thread, I think I encountered a single situation where I needed >> them. I'd appreciate your comments and any pointers to more >> information. What happened was this: About 5 years ago I flew >> from NC to Phoenix. Coming into Phoenix from Santa Fe I was up >> over 10K and was slam dunked into Phoenix's airspace. As I >> started a high speed descent I ran through some snow virga (!!) >> and simultaneously lost the Nav radio I was using. I swear there >> was lightening in my peripheral vision. I slowed down, changed >> radios, declared 'unable', got some vectors, and finally put it >> down in sunny Scottsdale. >> >> The radio had been using a whisker antenna but was now dead. Got >> some help from someone here on the list (it's been awhile but >> thanks again) to try and trouble shoot it since I didn't want to >> fly across the country with a single Comm. It stayed dead but >> during the course of flying around Phoenix I discovered that the >> Archer Comm antenna just wasn't performing well enough to be my >> sole antenna for such a cross country trip. So I spent some time >> swapping antenna's on my working radio to get home. >> >> Was this possibly caused by some kind of static discharge? Is that >> what might have killed my radio? Is that what static wicks are >> designed to prevent? >> >> Anyway, I continued to fly with the Archer Comm and actually used >> it as my 'primary' radio. It worked fine most of the time. But >> occasionally I'd have a comm problem and would have to switch to >> get maximum range. Conversely my belly mounted whisker would have >> problems when on the ground and I'd use the Archer. Finally I >> removed the Archer and mounted a 2nd belly whisker. Now when I >> have problems on the ground (KCLT ground at Wilson Air for >> example) I switch to the other radio on the other whisker and I'm >> able to communicate. It's clear to me now that the whiskers far >> outperform the Archer Comm, but that's pretty well understood by >> Archer users. It's a sleek backup solution on the Comm side. >> >> At this point I'm starting to shop for some Nav whiskers and the >> easiest way to add them to my 7 yo plane. I'm thinking that I >> will not be installing static wicks but think I need to recognize >> that as a limitation though I'm not sure how to mitigate the risks >> in that area. I need to learn more there. >> >> Bill "haven't scared myself in the '10 yet and would like to keep >> it that way" Watson >> >> ** so how can a successful ILS be completed in the soup with >> unuseable needles? Jumpy needles overlaying a synthethic vision >> display with a flight path marker can let you convince yourself >> that you just did an outstanding job handflying thru some nasty >> turbulence, as long as you turn off the flight director.... is >> that too much technology? >> >> >> >> --- >> This email has been checked for viruses by Avast antivirus software. >> https://www.avast.com/antivirus >> >> >> =================================== >> -List" rel="noreferrer" >> target="_blank">http://www.matronics.com/Navigator?RV10-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> > > > > Virus-free. www.avast.com > > > > <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Subject: Re: VOR/GS/LOC Antenna and Static Wicks
Date: Jan 23, 2018
Second thought. IF GS were the problem, there are GS antennas that are typically mounted near the top of the windshield that would also be easier than installing the cat whisker. And are tuned for GS freqs only, so rather short. On 1/23/2018 11:15 AM, Bill Watson wrote: > Kelly, I thought I remembered it was you but wasn't sure. Thanks > again! You know if you ever get out east you have a friend at 8NC8 - > anything. And I'm always looking to play it forward. > > I was hoping someone would suggest a 2nd Archer because that would be > the simplest thing for me to do at this point. The funny thing is that > everyone mentions the GS being the problem but I clearly have a LOC > problem at KAGC 28, in addition to the GS. Otherwise my GS works > fine. I really haven't done much testing with my second NAV - only > practice approaches and it seems to work fine. Having each NAV hooked up > to it's own antenna would not only boost signal strength but would be a > better backup configuration. Hmmm. > > On 1/22/2018 10:27 PM, Kelly McMullen wrote: >> IIRC Bill, I think it was your plane that I assisted with some >> crimpers and/or connectors for your RG400 modifications. >> I think if you replaced that Archer com antenna with a second nav >> antenna so that each of your nav units had an antenna without a >> splitter, your problem on the ILS would go away. >> My previous plane had two navs, one with remote GS and the other with >> built-in GS, all running off one cat whisker antenna, with two >> splitters to get signal to all units. >> On some approaches one of the ILSs would be weak and flakey (technical >> term). I have to Archer Nav antennas, one each to individual nav coms >> with GS. So far I haven't seen any problems. >> Kelly >> >> >> Sent from my IBM-360 main frame >> >> On Mon, Jan 22, 2018 at 8:06 PM, Bill Watson > > wrote: >> >> > >> >> Okay, this is a very valuable thread that is helping me figure out >> a few things that I should have figured out sometime ago. I'll >> share my experiences in the hope it helps others and I'll ask some >> questions looking for more insight. >> >> First, my GPS setup is 100% by the book and works flawlessly. >> >> I originally installed 2 Archers - a Nav and a Comm. The Archer >> Nav is my sole Nav antenna but I had a whip or whisker for my >> other Comm. I long ago got rid of the Archer Comm but I'll come >> back to that. I've made a good number of ILS approaches to >> various airports in IMC. I fly into a good number of larger >> airports and the ILS is assigned by default. Generally no problem >> but I've consistently had problems with the KAGC's ILS for 28. >> >> I've been flying into KAGC a lot over the last few years and I >> often get vectors for the ILS to 28. I noticed that my AP >> generally missed the left turn for the intercept and the GS was >> jumpy. I would just have to disconnect it to hand fly it. I >> gave up on the AP and still found it difficult to get the >> intercept precisely so I just got in the habit of requesting the >> RNAV and have no problems. Recently I decided to try a few in >> VMC and found that the needles were simply unuseable**. I did a >> few more tests at other airports and had no problems with needles >> - steady as a rock. But not at KAGC 28. I've wanted to blame the >> ILS but based on this thread, I'm convinced it's the Archer (my >> Archer is split to feed two NAVs). At this point after 6 years, >> I'm planning to put some whiskers on. It's not that I fly a lot >> of IMC or a lot of hard and low IMC, it's just that I file every >> flight, I work to stay current, most of it is east of the >> Mississippi and sometimes, not always predictably, I do an >> approach to minimums. It all has to work. >> >> I don't really understand exactly what static wicks do, when they >> are most needed and why I might consider them. Based on this >> thread, I think I encountered a single situation where I needed >> them. I'd appreciate your comments and any pointers to more >> information. What happened was this: About 5 years ago I flew >> from NC to Phoenix. Coming into Phoenix from Santa Fe I was up >> over 10K and was slam dunked into Phoenix's airspace. As I >> started a high speed descent I ran through some snow virga (!!) >> and simultaneously lost the Nav radio I was using. I swear there >> was lightening in my peripheral vision. I slowed down, changed >> radios, declared 'unable', got some vectors, and finally put it >> down in sunny Scottsdale. >> >> The radio had been using a whisker antenna but was now dead. Got >> some help from someone here on the list (it's been awhile but >> thanks again) to try and trouble shoot it since I didn't want to >> fly across the country with a single Comm. It stayed dead but >> during the course of flying around Phoenix I discovered that the >> Archer Comm antenna just wasn't performing well enough to be my >> sole antenna for such a cross country trip. So I spent some time >> swapping antenna's on my working radio to get home. >> >> Was this possibly caused by some kind of static discharge? Is that >> what might have killed my radio? Is that what static wicks are >> designed to prevent? >> >> Anyway, I continued to fly with the Archer Comm and actually used >> it as my 'primary' radio. It worked fine most of the time. But >> occasionally I'd have a comm problem and would have to switch to >> get maximum range. Conversely my belly mounted whisker would have >> problems when on the ground and I'd use the Archer. Finally I >> removed the Archer and mounted a 2nd belly whisker. Now when I >> have problems on the ground (KCLT ground at Wilson Air for >> example) I switch to the other radio on the other whisker and I'm >> able to communicate. It's clear to me now that the whiskers far >> outperform the Archer Comm, but that's pretty well understood by >> Archer users. It's a sleek backup solution on the Comm side. >> >> At this point I'm starting to shop for some Nav whiskers and the >> easiest way to add them to my 7 yo plane. I'm thinking that I >> will not be installing static wicks but think I need to recognize >> that as a limitation though I'm not sure how to mitigate the risks >> in that area. I need to learn more there. >> >> Bill "haven't scared myself in the '10 yet and would like to keep >> it that way" Watson >> >> ** so how can a successful ILS be completed in the soup with >> unuseable needles? Jumpy needles overlaying a synthethic vision >> display with a flight path marker can let you convince yourself >> that you just did an outstanding job handflying thru some nasty >> turbulence, as long as you turn off the flight director.... is >> that too much technology? >> >> >> >> --- >> This email has been checked for viruses by Avast antivirus software. >> https://www.avast.com/antivirus >> >> >> =================================== >> -List" rel="noreferrer" >> target="_blank">http://www.matronics.com/Navigator?RV10-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> > > > > Virus-free. www.avast.com > > > > <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> ________________________________________________________________________________
Date: Jan 23, 2018
The antenna itself should be resonant at GS frequencies; just that you have a 3/2 wavelength standing wave instead of a 1/2. The issue is with the gamma match feed point. Its designed so the ratio of voltage to current at that point is 50 ohms, to provide a good match to the coax. But when you have 3/2 wavelengths (remember the voltage and current standing waves are 90 deg out of phase) that same feed point will not be 50 ohms. So there will be some mismatch at the GS frequency, leading to some signal loss. One thing I notice in this discussion is that most posters dont mention what nav receiver theyre using. The key parameter is the noise generated in the receivers front end (first stage). If that noise was zero a coat hangar would work for an antenna. I wonder if varying reports are partially due to different receivers, some with less noise than others? Another common thing: people seem to have interpreted the instructions to read, you must run the nav light wires along the leading edge. I believe the interpretation should be, If you must run wires across the antenna, do it like this. Both Carl F over on vaf and myself simply moved the antenna back a bit, and ran the nav/strobe wires straight across, well in front of the antenna. Were both happy with the performance. If you decide to go with a simple GS dipole on the windscreen (common on 1976 Cessnas) remember that the GS will likely drop out anytime youre on a vector 90 degrees off final - if thats a concern. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477518#477518 ________________________________________________________________________________
Subject: ADS-B - is the time now
Date: Jan 23, 2018
I see that Garmin is shipping the all new GDL-82 ADS-B out solution. At $1795 this seems like an excellent and cost effective solution to meet the ADS-B mandate. It also works with my old panel mounted Garmin transponder. Since I already have a scout and and a panel mounted full sized I-Pad, this seem to fit the bill in a cost effective way. While I understand that Garmin is back ordered on the item, I am considering getting in the que. Has anyone pulled cord and installed this item? Inquiring minds want to know the community's collective opinion. -------- See you OSH '18 Q/B - flying 8 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477524#477524 ________________________________________________________________________________
Subject: Re: ADS-B - is the time now
Date: Jan 23, 2018
There are now lots of options. The uAvionics Echo plus their gps or the grt gps is a few hundred dollars less, and includes ADSB-in. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477526#477526 ________________________________________________________________________________
Subject: WI Help Wanted
Date: Jan 24, 2018
Hey all, been a while. As seems to happen to many of us, I am way overdue on my -10 completion due to life, kids, career, etc and I'm looking to see if I can get some experienced help from another builder or former builder in the Appleton/Green Bay area. Specifically with the firewall forward aspects while I work on wrapping up the rest of the aircraft. I already have the engine hung, a lot of the plumbing and wiring completed, along with the baffles started. So it's basically tying up loose ends, cowling, prop, etc. Thanks, Michael Sausen -10 #352 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477541#477541 ________________________________________________________________________________
Subject: Re: WI Help Wanted
Date: Jan 24, 2018
Did you move back up north? Or just never moved the project? Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> on behalf of msausen Sent: Wednesday, January 24, 2018 2:33:18 PM Subject: RV10-List: WI Help Wanted Hey all, been a while. As seems to happen to many of us, I am way overdue on my -10 completion due to life, kids, career, etc and I'm looking to see if I can get some experienced help from another builder or former builder i n the Appleton/Green Bay area. Specifically with the firewall forward aspe cts while I work on wrapping up the rest of the aircraft. I already have t he engine hung, a lot of the plumbing and wiring completed, along with the baffles started. So it's basically tying up loose ends, cowling, prop, etc . Thanks, Michael Sausen -10 #352 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477541#477541 ________________________________________________________________________________
Date: Jan 24, 2018
Yep, moved back about a year ago again. rleffler wrote: > Did you move back up north? Or just never moved the project? > > Get Outlook for iOS > ________________________________ > From: owner-rv10-list-server(at)matronics.com on behalf of msausen > Sent: Wednesday, January 24, 2018 2:33:18 PM > To: rv10-list(at)matronics.com > Subject: WI Help Wanted > > > > Hey all, been a while. As seems to happen to many of us, I am way overdue on my -10 completion due to life, kids, career, etc and I'm looking to see if I can get some experienced help from another builder or former builder in the Appleton/Green Bay area. Specifically with the firewall forward aspects while I work on wrapping up the rest of the aircraft. I already have the engine hung, a lot of the plumbing and wiring completed, along with the baffles started. So it's basically tying up loose ends, cowling, prop, etc Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477545#477545 ________________________________________________________________________________
Date: Jan 24, 2018
Good to see you back, Michael. Keep plugging. We welcomed 2 kids, moved 3 times, and I spent 1.5 years driving one way to work on it back at the old location. Id go for 4 days straight and leftism and the kids behind. I finally got it flying over the summer. Most every project has a story to tell. Just keep on plugging and Im glad youre getting back in the fold. See you at OSH! Sent from my iPhone > On Jan 24, 2018, at 2:10 PM, msausen wrote: > > > Yep, moved back about a year ago again. > > > rleffler wrote: >> Did you move back up north? Or just never moved the project? >> >> Get Outlook for iOS >> ________________________________ >> From: owner-rv10-list-server(at)matronics.com on behalf of msausen >> Sent: Wednesday, January 24, 2018 2:33:18 PM >> To: rv10-list(at)matronics.com >> Subject: WI Help Wanted >> >> >> >> Hey all, been a while. As seems to happen to many of us, I am way overdue on my -10 completion due to life, kids, career, etc and I'm looking to see if I can get some experienced help from another builder or former builder in the Appleton/Green Bay area. Specifically with the firewall forward aspects while I work on wrapping up the rest of the aircraft. I already have the engine hung, a lot of the plumbing and wiring completed, along with the baffles started. So it's basically tying up loose ends, cowling, prop, etc > > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477545#477545 > > > > > > > > > ________________________________________________________________________________
Date: Jan 24, 2018
Welcome back. To echo Phil, I wish I were closer so I could help. I took 8 years to get mine done (well flying, not necessarily done) and it is worth all the effort. Kelly Sent from my IBM-360 main frame On Wed, Jan 24, 2018 at 2:04 PM, Phillip Perry wrote : > > Good to see you back, Michael. Keep plugging. > > We welcomed 2 kids, moved 3 times, and I spent 1.5 years driving one way > to work on it back at the old location. I=99d go for 4 days straigh t and > leftism and the kids behind. I finally got it flying over the summer. > > Most every project has a story to tell. Just keep on plugging and I =99m glad > you=99re getting back in the fold. See you at OSH! > > Sent from my iPhone > > > On Jan 24, 2018, at 2:10 PM, msausen wrote: > > > > > > Yep, moved back about a year ago again. > > > > > > rleffler wrote: > >> Did you move back up north? Or just never moved the project? > >> > >> Get Outlook for iOS > >> ________________________________ > >> From: owner-rv10-list-server(at)matronics.com on behalf of msausen > >> Sent: Wednesday, January 24, 2018 2:33:18 PM > >> To: rv10-list(at)matronics.com > >> Subject: WI Help Wanted > >> > >> > >> > >> Hey all, been a while. As seems to happen to many of us, I am way > overdue on my -10 completion due to life, kids, career, etc and I'm looki ng > to see if I can get some experienced help from another builder or former > builder in the Appleton/Green Bay area. Specifically with the firewall > forward aspects while I work on wrapping up the rest of the aircraft. I > already have the engine hung, a lot of the plumbing and wiring completed, > along with the baffles started. So it's basically tying up loose ends, > cowling, prop, etc > > > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=477545#477545 > > > > > > > > > > > > > > > > > > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jan 25, 2018
Thanks Kelly. I know that this can take time but I'm approaching 15 years since i started so it's time to be done. At least that's what my wife keeps saying. :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477574#477574 ________________________________________________________________________________
Date: Jan 25, 2018
That puts you very near the original announcement and shipping of the early kits. I know how hard it is to do, but it may help to try putting the work on your daily schedule for set time periods. I know when I work at the airport, it is very easy to kill a lot of time socializing with friends, etc. On 1/25/2018 11:18 AM, msausen wrote: > > Thanks Kelly. I know that this can take time but I'm approaching 15 years since i started so it's time to be done. At least that's what my wife keeps saying. :D > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477574#477574 > > > > > > > > > ________________________________________________________________________________
Date: Jan 25, 2018
That got me thinking so I looked up when I ordered the tail kit. Looks lik e it was end of Jan 2005. 13 years really fly=92s by. Funny how I was abl e to get more done on it in the first two years than in the last 11. From: Kelly McMullen<mailto:kellym(at)aviating.com> Sent: Thursday, January 25, 2018 2:31 PM Subject: Re: RV10-List: Re: WI Help Wanted That puts you very near the original announcement and shipping of the early kits. I know how hard it is to do, but it may help to try putting the work on your daily schedule for set time periods. I know when I work at the airport, it is very easy to kill a lot of time socializing with friends, etc. On 1/25/2018 11:18 AM, msausen wrote: > > Thanks Kelly. I know that this can take time but I'm approaching 15 year s since i started so it's time to be done. At least that's what my wife ke eps saying. :D > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477574#477574 > > ________________________________________________________________________________
Date: Jan 25, 2018
If I remember correctly you have an all AFS panel. There have been three generations of newer adahrs technology since this original crossbow magneto meters. I got tired of the bells and whistles I wanted were being addd dai ly on the 5000 series, but not on the 4500s. I finally upgraded to 5500s just before OSH last year. If you have room in the budget you may want to take a look at the current g eneral gear. Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> on behalf of Michael Sausen Sent: Thursday, January 25, 2018 4:41:47 PM Subject: RE: RV10-List: Re: WI Help Wanted That got me thinking so I looked up when I ordered the tail kit. Looks lik e it was end of Jan 2005. 13 years really fly=92s by. Funny how I was abl e to get more done on it in the first two years than in the last 11. From: Kelly McMullen<mailto:kellym(at)aviating.com> Sent: Thursday, January 25, 2018 2:31 PM Subject: Re: RV10-List: Re: WI Help Wanted That puts you very near the original announcement and shipping of the early kits. I know how hard it is to do, but it may help to try putting the work on your daily schedule for set time periods. I know when I work at the airport, it is very easy to kill a lot of time socializing with friends, etc. On 1/25/2018 11:18 AM, msausen wrote: > > Thanks Kelly. I know that this can take time but I'm approaching 15 year s since i started so it's time to be done. At least that's what my wife ke eps saying. :D > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477574#477574 > > Email Forum - -List">http://www.matronics.com/Navigator?RV10-List p; - MATRONICS WEB FORUMS - ums.matronics.com p; - NEW MATRONICS LIST WIKI - matronics.com p; - List Contribution Web Site - p; -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 25, 2018
I am kit #356, only 4 kits after yours and we both seem to be on the same s chedule. This summer I got the plane on gear and mounted the engin. Now wo rking on fwf. Life has a way of changing priorities. Nice to see you are back building. Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> on behalf of Michael Sausen Sent: Thursday, January 25, 2018 4:41:47 PM Subject: RE: RV10-List: Re: WI Help Wanted That got me thinking so I looked up when I ordered the tail kit. Looks lik e it was end of Jan 2005. 13 years really fly=92s by. Funny how I was abl e to get more done on it in the first two years than in the last 11. From: Kelly McMullen<mailto:kellym(at)aviating.com> Sent: Thursday, January 25, 2018 2:31 PM Subject: Re: RV10-List: Re: WI Help Wanted That puts you very near the original announcement and shipping of the early kits. I know how hard it is to do, but it may help to try putting the work on your daily schedule for set time periods. I know when I work at the airport, it is very easy to kill a lot of time socializing with friends, etc. On 1/25/2018 11:18 AM, msausen wrote: > > Thanks Kelly. I know that this can take time but I'm approaching 15 year s since i started so it's time to be done. At least that's what my wife ke eps saying. :D > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477574#477574 > > Email Forum - -List">http://www.matronics.com/Navigator?RV10-List p; - MATRONICS WEB FORUMS - ums.matronics.com p; - NEW MATRONICS LIST WIKI - matronics.com p; - List Contribution Web Site - p; -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 25, 2018
Oh boy, oh no ..., builder's numbers. I wonder how many of the first 20 or so are still under construction. Bruce Breckenridge 40018 Fuselage gets picked up Monday! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477584#477584 ________________________________________________________________________________
Date: Jan 25, 2018
I think weve just found a winner! Keep grinding.... Sent from my iPhone > On Jan 25, 2018, at 8:24 PM, BrBreck wrote: > > > Oh boy, oh no ..., builder's numbers. I wonder how many of the first 20 or so are still under construction. > > Bruce Breckenridge > 40018 > Fuselage gets picked up Monday! > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477584#477584 > > > > > > > > > ________________________________________________________________________________
Date: Jan 26, 2018
Ha! From: Phillip Perry<mailto:philperry9(at)gmail.com> Sent: Thursday, January 25, 2018 9:19 PM Subject: Re: RV10-List: Re: WI Help Wanted I think we=92ve just found a winner! Keep grinding.... Sent from my iPhone > On Jan 25, 2018, at 8:24 PM, BrBreck wrote: > > > Oh boy, oh no ..., builder's numbers. I wonder how many of the first 20 or so are still under construction. > > Bruce Breckenridge > 40018 > Fuselage gets picked up Monday! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477584#477584 > > ________________________________________________________________________________
Date: Jan 26, 2018
VGhhbmtzIGZvciByZW1pbmRpbmcgbWUuICDwn5iDICBNeSBiaWdnZXIgY29uY2VybiBpcyB0aGUg VlAyMDAgd2l0aCBhIGRvZGd5IHJvdGFyeSBrbm9iLiAgQXQgbGVhc3QgdGhlIEFGUyBzdHVmZiBp cyBhbGwgc3RpbGwgYmV0dGVyIHRoYW4gYW55dGhpbmcgeW91IHdpbGwgZmluZCBpbiB0aGUgcmVu dGFsIG1hcmtldCB0b2RheSBzbyBJIHRoaW5rIEkgY2FuIGxpdmUgd2l0aCBpdCBmb3IgYSB3aGls ZSB5ZXQuDQoNCkZyb206IEJvYiBMZWZmbGVyPG1haWx0bzpib2JAdGhlbGVmZmxlcnMuY29tPg0K U2VudDogVGh1cnNkYXksIEphbnVhcnkgMjUsIDIwMTggNDoxOSBQTQ0KVG86IHJ2MTAtbGlzdEBt YXRyb25pY3MuY29tPG1haWx0bzpydjEwLWxpc3RAbWF0cm9uaWNzLmNvbT47IHJ2MTAtbGlzdEBt YXRyb25pY3MuY29tPG1haWx0bzpydjEwLWxpc3RAbWF0cm9uaWNzLmNvbT4NClN1YmplY3Q6IFJl OiBSVjEwLUxpc3Q6IFJlOiBXSSBIZWxwIFdhbnRlZA0KDQpJZiBJIHJlbWVtYmVyIGNvcnJlY3Rs eSB5b3UgaGF2ZSBhbiBhbGwgQUZTIHBhbmVsLiAgIFRoZXJlIGhhdmUgYmVlbiB0aHJlZSBnZW5l cmF0aW9ucyBvZiBuZXdlciBhZGFocnMgdGVjaG5vbG9neSBzaW5jZSB0aGlzIG9yaWdpbmFsIGNy b3NzYm93IG1hZ25ldG9tZXRlcnMuICBJIGdvdCB0aXJlZCBvZiB0aGUgYmVsbHMgYW5kIHdoaXN0 bGVzIEkgd2FudGVkIHdlcmUgYmVpbmcgYWRkZCBkYWlseSBvbiB0aGUgNTAwMCBzZXJpZXMsIGJ1 dCBub3Qgb24gdGhlIDQ1MDBzLiAgIEkgZmluYWxseSB1cGdyYWRlZCB0byA1NTAwcyBqdXN0IGJl Zm9yZSBPU0ggbGFzdCB5ZWFyLg0KDQpJZiB5b3UgaGF2ZSByb29tIGluIHRoZSBidWRnZXQgeW91 IG1heSB3YW50IHRvIHRha2UgYSBsb29rIGF0IHRoZSBjdXJyZW50IGdlbmVyYWwgZ2Vhci4NCg0K R2V0IE91dGxvb2sgZm9yIGlPUzxodHRwczovL2FrYS5tcy9vMHVrZWY+DQoNCkZyb206IG93bmVy LXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSA8b3duZXItcnYxMC1saXN0LXNlcnZlckBt YXRyb25pY3MuY29tPiBvbiBiZWhhbGYgb2YgTWljaGFlbCBTYXVzZW4gPG1pY2hhZWxAc2F1c2Vu Lm5ldD4NClNlbnQ6IFRodXJzZGF5LCBKYW51YXJ5IDI1LCAyMDE4IDQ6NDE6NDcgUE0NClRvOiBy djEwLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogUkU6IFJWMTAtTGlzdDogUmU6IFdJIEhl bHAgV2FudGVkDQoNClRoYXQgZ290IG1lIHRoaW5raW5nIHNvIEkgbG9va2VkIHVwIHdoZW4gSSBv cmRlcmVkIHRoZSB0YWlsIGtpdC4gIExvb2tzIGxpa2UgaXQgd2FzIGVuZCBvZiBKYW4gMjAwNS4g IDEzIHllYXJzIHJlYWxseSBmbHnigJlzIGJ5LiAgRnVubnkgaG93IEkgd2FzIGFibGUgdG8gZ2V0 IG1vcmUgZG9uZSBvbiBpdCBpbiB0aGUgZmlyc3QgdHdvIHllYXJzIHRoYW4gaW4gdGhlIGxhc3Qg MTEuDQoNCkZyb206IEtlbGx5IE1jTXVsbGVuPG1haWx0bzprZWxseW1AYXZpYXRpbmcuY29tPg0K U2VudDogVGh1cnNkYXksIEphbnVhcnkgMjUsIDIwMTggMjozMSBQTQ0KVG86IHJ2MTAtbGlzdEBt YXRyb25pY3MuY29tPG1haWx0bzpydjEwLWxpc3RAbWF0cm9uaWNzLmNvbT4NClN1YmplY3Q6IFJl OiBSVjEwLUxpc3Q6IFJlOiBXSSBIZWxwIFdhbnRlZA0KDQotLT4gUlYxMC1MaXN0IG1lc3NhZ2Ug cG9zdGVkIGJ5OiBLZWxseSBNY011bGxlbiA8a2VsbHltQGF2aWF0aW5nLmNvbT4NCg0KVGhhdCBw dXRzIHlvdSB2ZXJ5IG5lYXIgdGhlIG9yaWdpbmFsIGFubm91bmNlbWVudCBhbmQgc2hpcHBpbmcg b2YgdGhlDQplYXJseSBraXRzLiBJIGtub3cgaG93IGhhcmQgaXQgaXMgdG8gZG8sIGJ1dCBpdCBt YXkgaGVscCB0byB0cnkgcHV0dGluZw0KdGhlIHdvcmsgb24geW91ciBkYWlseSBzY2hlZHVsZSBm b3Igc2V0IHRpbWUgcGVyaW9kcy4gSSBrbm93IHdoZW4gSSB3b3JrDQphdCB0aGUgYWlycG9ydCwg aXQgaXMgdmVyeSBlYXN5IHRvIGtpbGwgYSBsb3Qgb2YgdGltZSBzb2NpYWxpemluZyB3aXRoDQpm cmllbmRzLCBldGMuDQoNCk9uIDEvMjUvMjAxOCAxMToxOCBBTSwgbXNhdXNlbiB3cm90ZToNCj4g LS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIm1zYXVzZW4iIDxtaWNoYWVsQHNhdXNl bi5uZXQ+DQo+DQo+IFRoYW5rcyBLZWxseS4gIEkga25vdyB0aGF0IHRoaXMgY2FuIHRha2UgdGlt ZSBidXQgSSdtIGFwcHJvYWNoaW5nIDE1IHllYXJzIHNpbmNlIGkgc3RhcnRlZCBzbyBpdCdzIHRp bWUgdG8gYmUgZG9uZS4gIEF0IGxlYXN0IHRoYXQncyB3aGF0IG15IHdpZmUga2VlcHMgc2F5aW5n LiAgOkQNCj4NCj4NCj4NCj4NCj4gUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOg0KPg0KPiBo dHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTQ3NzU3NCM0Nzc1NzQN Cj4NCj4NCj4NCj4NCj4NCj4NCj4NCj4NCj4NCj09PT09PT09PT09DQpFbWFpbCBGb3J1bSAtDQot TGlzdCI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCj09PT09 PT09PT09DQpwOyAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KdW1zLm1hdHJvbmljcy5jb20N Cj09PT09PT09PT09DQpwOyAgLSBORVcgTUFUUk9OSUNTIExJU1QgV0lLSSAtDQptYXRyb25pY3Mu Y29tDQo9PT09PT09PT09PQ0KcDsgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQpwOyAg ICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCmh0dHA6Ly93d3cubWF0 cm9uaWNzLmNvbS9jb250cmlidXRpb24NCj09PT09PT09PT09DQoNCg0KDQo ________________________________________________________________________________
Date: Jan 26, 2018
Thanks Larry, glad to see a lot of the old group still around! Brings back memories of the early days of the list and the stand against the =93other =94 forum when the Yahoo list was abruptly closed down. :D From: Larry Rosen<mailto:n205en(at)gmail.com> Sent: Thursday, January 25, 2018 4:29 PM Subject: Re: RV10-List: Re: WI Help Wanted I am kit #356, only 4 kits after yours and we both seem to be on the same s chedule. This summer I got the plane on gear and mounted the engin. Now wo rking on fwf. Life has a way of changing priorities. Nice to see you are back building. Get Outlook for iOS From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> on behalf of Michael Sausen Sent: Thursday, January 25, 2018 4:41:47 PM Subject: RE: RV10-List: Re: WI Help Wanted That got me thinking so I looked up when I ordered the tail kit. Looks lik e it was end of Jan 2005. 13 years really fly=92s by. Funny how I was abl e to get more done on it in the first two years than in the last 11. From: Kelly McMullen<mailto:kellym(at)aviating.com> Sent: Thursday, January 25, 2018 2:31 PM Subject: Re: RV10-List: Re: WI Help Wanted That puts you very near the original announcement and shipping of the early kits. I know how hard it is to do, but it may help to try putting the work on your daily schedule for set time periods. I know when I work at the airport, it is very easy to kill a lot of time socializing with friends, etc. On 1/25/2018 11:18 AM, msausen wrote: > > Thanks Kelly. I know that this can take time but I'm approaching 15 year s since i started so it's time to be done. At least that's what my wife ke eps saying. :D > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477574#477574 > > Email Forum - -List">http://www.matronics.com/Navigator?RV10-List p; - MATRONICS WEB FORUMS - ums.matronics.com p; - NEW MATRONICS LIST WIKI - matronics.com p; - List Contribution Web Site - p; -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 26, 2018
SSB3b3VsZCB0YWtlIGEgbG9vayBhdCBBRlMgbmV3IGFjdCBib3guICAgUm9iIHNob3VsZCBoYXZl IHRoZSBzb2xpZCBzdGF0ZSB2ZXJzaW9uIG91dCB0aGlzIHN1bW1lci4NCg0KR2V0IE91dGxvb2sg Zm9yIGlPUzxodHRwczovL2FrYS5tcy9vMHVrZWY+DQpfX19fX19fX19fX19fX19fX19fX19fX19f X19fX19fXw0KRnJvbTogb3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIDxvd25l ci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20+IG9uIGJlaGFsZiBvZiBNaWNoYWVsIFNh dXNlbiA8bWljaGFlbEBzYXVzZW4ubmV0Pg0KU2VudDogRnJpZGF5LCBKYW51YXJ5IDI2LCAyMDE4 IDg6MjU6NDAgQU0NClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogUkU6IFJW MTAtTGlzdDogUmU6IFdJIEhlbHAgV2FudGVkDQoNClRoYW5rcyBmb3IgcmVtaW5kaW5nIG1lLiAg 8J+YgyAgTXkgYmlnZ2VyIGNvbmNlcm4gaXMgdGhlIFZQMjAwIHdpdGggYSBkb2RneSByb3Rhcnkg a25vYi4gIEF0IGxlYXN0IHRoZSBBRlMgc3R1ZmYgaXMgYWxsIHN0aWxsIGJldHRlciB0aGFuIGFu eXRoaW5nIHlvdSB3aWxsIGZpbmQgaW4gdGhlIHJlbnRhbCBtYXJrZXQgdG9kYXkgc28gSSB0aGlu ayBJIGNhbiBsaXZlIHdpdGggaXQgZm9yIGEgd2hpbGUgeWV0Lg0KDQpGcm9tOiBCb2IgTGVmZmxl cjxtYWlsdG86Ym9iQHRoZWxlZmZsZXJzLmNvbT4NClNlbnQ6IFRodXJzZGF5LCBKYW51YXJ5IDI1 LCAyMDE4IDQ6MTkgUE0NClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbTxtYWlsdG86cnYxMC1s aXN0QG1hdHJvbmljcy5jb20+OyBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbTxtYWlsdG86cnYxMC1s aXN0QG1hdHJvbmljcy5jb20+DQpTdWJqZWN0OiBSZTogUlYxMC1MaXN0OiBSZTogV0kgSGVscCBX YW50ZWQNCg0KSWYgSSByZW1lbWJlciBjb3JyZWN0bHkgeW91IGhhdmUgYW4gYWxsIEFGUyBwYW5l bC4gICBUaGVyZSBoYXZlIGJlZW4gdGhyZWUgZ2VuZXJhdGlvbnMgb2YgbmV3ZXIgYWRhaHJzIHRl Y2hub2xvZ3kgc2luY2UgdGhpcyBvcmlnaW5hbCBjcm9zc2JvdyBtYWduZXRvbWV0ZXJzLiAgSSBn b3QgdGlyZWQgb2YgdGhlIGJlbGxzIGFuZCB3aGlzdGxlcyBJIHdhbnRlZCB3ZXJlIGJlaW5nIGFk ZGQgZGFpbHkgb24gdGhlIDUwMDAgc2VyaWVzLCBidXQgbm90IG9uIHRoZSA0NTAwcy4gICBJIGZp bmFsbHkgdXBncmFkZWQgdG8gNTUwMHMganVzdCBiZWZvcmUgT1NIIGxhc3QgeWVhci4NCg0KSWYg eW91IGhhdmUgcm9vbSBpbiB0aGUgYnVkZ2V0IHlvdSBtYXkgd2FudCB0byB0YWtlIGEgbG9vayBh dCB0aGUgY3VycmVudCBnZW5lcmFsIGdlYXIuDQoNCkdldCBPdXRsb29rIGZvciBpT1M8aHR0cHM6 Ly9ha2EubXMvbzB1a2VmPg0KDQpGcm9tOiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmlj cy5jb20gPG93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbT4gb24gYmVoYWxmIG9m IE1pY2hhZWwgU2F1c2VuIDxtaWNoYWVsQHNhdXNlbi5uZXQ+DQpTZW50OiBUaHVyc2RheSwgSmFu dWFyeSAyNSwgMjAxOCA0OjQxOjQ3IFBNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20NClN1 YmplY3Q6IFJFOiBSVjEwLUxpc3Q6IFJlOiBXSSBIZWxwIFdhbnRlZA0KDQpUaGF0IGdvdCBtZSB0 aGlua2luZyBzbyBJIGxvb2tlZCB1cCB3aGVuIEkgb3JkZXJlZCB0aGUgdGFpbCBraXQuICBMb29r cyBsaWtlIGl0IHdhcyBlbmQgb2YgSmFuIDIwMDUuICAxMyB5ZWFycyByZWFsbHkgZmx54oCZcyBi eS4gIEZ1bm55IGhvdyBJIHdhcyBhYmxlIHRvIGdldCBtb3JlIGRvbmUgb24gaXQgaW4gdGhlIGZp cnN0IHR3byB5ZWFycyB0aGFuIGluIHRoZSBsYXN0IDExLg0KDQpGcm9tOiBLZWxseSBNY011bGxl bjxtYWlsdG86a2VsbHltQGF2aWF0aW5nLmNvbT4NClNlbnQ6IFRodXJzZGF5LCBKYW51YXJ5IDI1 LCAyMDE4IDI6MzEgUE0NClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbTxtYWlsdG86cnYxMC1s aXN0QG1hdHJvbmljcy5jb20+DQpTdWJqZWN0OiBSZTogUlYxMC1MaXN0OiBSZTogV0kgSGVscCBX YW50ZWQNCg0KLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogS2VsbHkgTWNNdWxsZW4g PGtlbGx5bUBhdmlhdGluZy5jb20+DQoNClRoYXQgcHV0cyB5b3UgdmVyeSBuZWFyIHRoZSBvcmln aW5hbCBhbm5vdW5jZW1lbnQgYW5kIHNoaXBwaW5nIG9mIHRoZQ0KZWFybHkga2l0cy4gSSBrbm93 IGhvdyBoYXJkIGl0IGlzIHRvIGRvLCBidXQgaXQgbWF5IGhlbHAgdG8gdHJ5IHB1dHRpbmcNCnRo ZSB3b3JrIG9uIHlvdXIgZGFpbHkgc2NoZWR1bGUgZm9yIHNldCB0aW1lIHBlcmlvZHMuIEkga25v dyB3aGVuIEkgd29yaw0KYXQgdGhlIGFpcnBvcnQsIGl0IGlzIHZlcnkgZWFzeSB0byBraWxsIGEg bG90IG9mIHRpbWUgc29jaWFsaXppbmcgd2l0aA0KZnJpZW5kcywgZXRjLg0KDQpPbiAxLzI1LzIw MTggMTE6MTggQU0sIG1zYXVzZW4gd3JvdGU6DQo+IC0tPiBSVjEwLUxpc3QgbWVzc2FnZSBwb3N0 ZWQgYnk6ICJtc2F1c2VuIiA8bWljaGFlbEBzYXVzZW4ubmV0Pg0KPg0KPiBUaGFua3MgS2VsbHku ICBJIGtub3cgdGhhdCB0aGlzIGNhbiB0YWtlIHRpbWUgYnV0IEknbSBhcHByb2FjaGluZyAxNSB5 ZWFycyBzaW5jZSBpIHN0YXJ0ZWQgc28gaXQncyB0aW1lIHRvIGJlIGRvbmUuICBBdCBsZWFzdCB0 aGF0J3Mgd2hhdCBteSB3aWZlIGtlZXBzIHNheWluZy4gIDpEDQo+DQo+DQo+DQo+DQo+IFJlYWQg dGhpcyB0b3BpYyBvbmxpbmUgaGVyZToNCj4NCj4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29t L3ZpZXd0b3BpYy5waHA/cD00Nzc1NzQjNDc3NTc0DQo+DQo+DQo+DQo+DQo+DQo+DQo+DQo+DQo+ DQo9PT09PT09PT09PQ0KRW1haWwgRm9ydW0gLQ0KLUxpc3QiPmh0dHA6Ly93d3cubWF0cm9uaWNz LmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQo9PT09PT09PT09PQ0KcDsgICAtIE1BVFJPTklDUyBX RUIgRk9SVU1TIC0NCnVtcy5tYXRyb25pY3MuY29tDQo9PT09PT09PT09PQ0KcDsgIC0gTkVXIE1B VFJPTklDUyBMSVNUIFdJS0kgLQ0KbWF0cm9uaWNzLmNvbQ0KPT09PT09PT09PT0NCnA7IC0gTGlz dCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KcDsgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFs bGUsIExpc3QgQWRtaW4uDQpodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQo9 PT09PT09PT09PQ0KDQoNCg0K ________________________________________________________________________________
Date: Jan 26, 2018
Hey Michael, Still have the shaping lumber you gave to me for building my fuselage. Any time you would like to stop by CLI, your than welcome in my hanger to have a look at the 10 if it might help. It=99s been awhile since the build b ut if I can help let me know. Tom Ganster Sent from my iPad > On Jan 26, 2018, at 8:00 AM, Bob Leffler wrote: > > I would take a look at AFS new act box. Rob should have the solid state v ersion out this summer. > > Get Outlook for iOS > From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matroni cs.com> on behalf of Michael Sausen > Sent: Friday, January 26, 2018 8:25:40 AM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: WI Help Wanted > > Thanks for reminding me. =F0=9F=98=83 My bigger concern is the VP200 wit h a dodgy rotary knob. At least the AFS stuff is all still better than anyt hing you will find in the rental market today so I think I can live with it f or a while yet. > > From: Bob Leffler > Sent: Thursday, January 25, 2018 4:19 PM > To: rv10-list(at)matronics.com; rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: WI Help Wanted > > If I remember correctly you have an all AFS panel. There have been three generations of newer adahrs technology since this original crossbow magneto meters. I got tired of the bells and whistles I wanted were being addd dail y on the 5000 series, but not on the 4500s. I finally upgraded to 5500s ju st before OSH last year. > > If you have room in the budget you may want to take a look at the current g eneral gear. > > Get Outlook for iOS > > From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matroni cs.com> on behalf of Michael Sausen > Sent: Thursday, January 25, 2018 4:41:47 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: WI Help Wanted > > That got me thinking so I looked up when I ordered the tail kit. Looks li ke it was end of Jan 2005. 13 years really fly=99s by. Funny how I w as able to get more done on it in the first two years than in the last 11. > > From: Kelly McMullen > Sent: Thursday, January 25, 2018 2:31 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: WI Help Wanted > > > That puts you very near the original announcement and shipping of the > early kits. I know how hard it is to do, but it may help to try putting > the work on your daily schedule for set time periods. I know when I work > at the airport, it is very easy to kill a lot of time socializing with > friends, etc. > > On 1/25/2018 11:18 AM, msausen wrote: > > > > Thanks Kelly. I know that this can take time but I'm approaching 15 yea rs since i started so it's time to be done. At least that's what my wife ke eps saying. :D > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=477574#477574 > > > > > > > > > > > > > > > > > > > ========== > Email Forum - > -List">http://www.matronics.com/Navigator?RV10-List > ========== > p; - MATRONICS WEB FORUMS - > ums.matronics.com > ========== > p; - NEW MATRONICS LIST WIKI - > matronics.com > ========== > p; - List Contribution Web Site - > p; -Matt Dralle, List Admin. > http://www.matronics.com/contribution > ========== > > > ________________________________________________________________________________
Date: Jan 27, 2018
Subject: Re: SureFly Electronic Ignition
Has anyone installed the SureFly electronic ignition system on their RV-10? Warm regards Patrick > On 13 Dec 2017, at 23:43, SureFly wrote: > > > We have 6 Cylinder Ignition units available. Give your 10 something nice for Christmas. :D 817-373-5161 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=476379#476379 > > > > > > > > > ________________________________________________________________________________
Date: Jan 27, 2018
Yes, good results and superior support. -------- Nick Leonard RV-10 (40015) Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477626#477626 ________________________________________________________________________________
Date: Jan 28, 2018
Second that. Have about 100 hrs. on the Surefly replacing the right mag. I removed the jumper on ignition switch that grounds the right mag at startup, so both the left mag with SlickStart and the right Surefly unit are firing at TDC during cranking. Totally solved my decade-long hot start problem on the IO-540. CHTs have been normal in all phases of flight, and the bird is about 2 kts faster in cruise. Effect most noticeable when running above 9K density altitude with MP settings below 22". Good stuff. -Dan Masys N104LD 1100 hrs. > Subject: RV10-List: Re: SureFly Electronic Ignition > From: "Nick Leonard" <nick(at)nleonard.com> > > > Yes, good results and superior support. > > -------- > Nick Leonard > RV-10 (40015) Flying > ________________________________________________________________________________
Date: Jan 29, 2018
Subject: Cancellation
Would you take my email off from the list. I no longer wish to receive emails. Also include my alternate email dspender(at)charter.net For cancellation. Sent from my iPhone ________________________________________________________________________________
Subject: Re: Cancellation
Date: Jan 29, 2018
This is a self help email forum. Take yourself off the list at: http://www.matronics.com/subscription/ On 1/29/2018 7:06 AM, DennisSpender wrote: > > Would you take my email off from the list. I no longer wish to receive emails. Also include my alternate email > dspender(at)charter.net > For cancellation. > > Sent from my iPhone > > > > ________________________________________________________________________________
Subject: IO-540 alternator-starter bracket
Date: Jan 30, 2018
Does anyone know who sells the bracket for a boss mount from alternator to starter bracket? I have a B and C alternator and OEM Lycoming/Skytec starter. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477689#477689 ________________________________________________________________________________
Subject: Re: IO-540 alternator-starter bracket
Date: Jan 30, 2018
Did you try B&C? Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> on behalf of whodja Sent: Tuesday, January 30, 2018 7:13:19 AM Subject: RV10-List: IO-540 alternator-starter bracket Does anyone know who sells the bracket for a boss mount from alternator to starter bracket? I have a B and C alternator and OEM Lycoming/Skytec sta rter. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477689#477689 ________________________________________________________________________________
Date: Jan 30, 2018
Nobody out there is posting - I would appreciate hearing from you. -------- See you OSH '18 Q/B - flying 8 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477714#477714 ________________________________________________________________________________
Date: Jan 30, 2018
I think only you can really answer that for yourself. I think most of us who have ADS-B are happy we did it. There are plenty who got hurt through the NavWorx situation, and that could happen to other companies, but it is less likely as time passes. Personally, the benefits of ADS-B out are great. I have an ES transponder, so every time my plane is in the air I can track it, or if I am flying, my family or the people I am going to meet can track me, even when I am VFR. I live in Florida, in a very heavy traffic area, and I see all of the traffic because I am broadcasting and waking up the ground stations to send traffic information. I am installing ADS-B out in probably an average of 2+ planes per week in my shop. It is expensive, but I dont know a single customer who wishes they hadnt installed, except possibly those who installed NavWorx, but those customers are all planning to replace it soon, and some already have, because they see the benefits of it. There may be cheaper solutions that come out in the next 2 years, but the demand is increasing as the deadline approaches, and I think that makes it less likely that prices will be going down significantly. There are enough solutions available that anybody doing serious undercutting on price could easily increase their price and still sell equipment. I hope this helps. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Jan 30, 2018, at 10:52 PM, AirMike wrote: > > > Nobody out there is posting - I would appreciate hearing from you. > > -------- > See you OSH '18 > Q/B - flying 8 yrs. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477714#477714 > > > > > > > > > ________________________________________________________________________________
Date: Jan 31, 2018
So far as I know no one makes one. I have a plane power 60A alternator and a B&C starter. The install instructions for the starter state that no bracket is needed if a B&C alternator (or any alternator that is perfectly balanced) is installed. [My summary, I don't have the instructions in front of me] I'm still in the process of installing things, but am seriously considering not installing a bracket. I called B&C, and was told that the bracket would provide extra support / vibration dampening and might extend the life of the PP alternator. Seeing as how it's not installed with the B&C alt/starter combo, I may just go without... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477716#477716 ________________________________________________________________________________
Date: Jan 31, 2018
My comments mirror those of Jesse. I put in the NavWorx box early on and found the traffic display and alerts to be outstanding. Mine was not connected to a certified GPS, so I had to find a replacement.and installed the Uavionix Echo with the Fly GPS. It is now working with a small issue with baro altitude that they are working to resolve. The traffic display and alerts are as good as the NavWorx unit was, and I do not want to be without it anymore. The weather display is good, but you have to understand what radar picture is output over the ADS-B link. I also have a Garmin 396 with subscription XM weather on it which works on the ground when you cannot see any ADS-B towers. The combination of the 2 wx inputs gives me a really good weather picture. If anyone wants the NavWorx box, Ill be happy to make you a great deal on it. All it needs is a certified GPS input to be legal. grumpy N184JM - flying since 2006 N82WW (RV8) - flying since Dec 29, 2016 > On Jan 30, 2018, at 9:52 PM, AirMike wrote: > > > Nobody out there is posting - I would appreciate hearing from you. > > -------- > See you OSH '18 > Q/B - flying 8 yrs. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477714#477714 > > > > > > > > > ________________________________________________________________________________
Date: Jan 31, 2018
Have you talked to Plane Power? This is what is normally in their experimental kit: http://planepower.aero/images/AL12-EI60-B.jpg They offer both case mount and boss mount kits with all brackets. Is the bracket you need of differing dimensions than a stock alternator and starter combo? I used the stock PP kit with a Kelly (now Hartzell) EZ Drive starter with no problem. Sent from my IBM-360 main frame On Tue, Jan 30, 2018 at 5:13 AM, whodja wrote: > > Does anyone know who sells the bracket for a boss mount from alternator > to starter bracket? I have a B and C alternator and OEM Lycoming/Skytec > starter. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477689#477689 > > ________________________________________________________________________________
Date: Jan 31, 2018
I agree with Jesse, the time isn't now, the time was a while ago. I've been flying with ADS-B since 2009, and wouldn't be without it now. There are so many options to choose from, but only you can determine what's right for you, based on price point, and work involved. The cheapest method likely isn't the best method, but only you can determine what you're looking for out of it. If all you want is compliance, then it's one thing, but if you want all the benefits that go with it, you'll likely want more than the simplest of solutions. And some of it is driven by what's in your panel. If you just want to no think too hard about what you're going to do, then get the Garmin 345 or Stratus ESG, and once you're installed you'll have most of the options you could be looking for. Tim On 01/30/2018 09:52 PM, AirMike wrote: > > Nobody out there is posting - I would appreciate hearing from you. > > -------- > See you OSH '18 > Q/B - flying 8 yrs. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=477714#477714 > > ________________________________________________________________________________
Date: Jan 31, 2018
I agree, the decision is driven by wallet, receive capability and what you already have. The UAT option unfortunately comes saddled with unnecessary complexity..you have to keep, maintain, and certify a Mode C transponder/encoder on top of the UAT add-on. The 1090ES option costs more initially, but is only one unit to maintain and certify every 2 years, and lets you go anywhere outside US borders. It also lets you go into the flight levels if that gets you over some weather. Then you have to consider whether you are going to take advantage of the ability to receive traffic and weather, and if you want that on your PFD/MFD or something portable, or both. Those of us that have the traffic and weather on our panel mount displays probably would only use the portable as a backup..but that is decided as much by budget and how/where we fly more than anything. When you add cost of iPad and software for that, plus a means to get the data to the iPad, whether portable receiver or something built-in, those numbers are significant, though perhaps less than getting it into our panel displays. However, having an independent, battery powered display has a lot of merit. On 1/31/2018 7:33 AM, Tim Olson wrote: > > I agree with Jesse, the time isn't now, the time was a while ago. > I've been flying with ADS-B since 2009, and wouldn't be without > it now. There are so many options to choose from, but only > you can determine what's right for you, based on price point, > and work involved. The cheapest method likely isn't the best > method, but only you can determine what you're looking for > out of it. If all you want is compliance, then it's one thing, > but if you want all the benefits that go with it, you'll likely > want more than the simplest of solutions. And some of it is > driven by what's in your panel. > > If you just want to no think too hard about what you're > going to do, then get the Garmin 345 or Stratus ESG, and > once you're installed you'll have most of the options you > could be looking for. > > Tim > > > On 01/30/2018 09:52 PM, AirMike wrote: >> >> Nobody out there is posting - I would appreciate hearing from you. >> >> -------- >> See you OSH '18 >> Q/B - flying 8 yrs. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=477714#477714 >> >> > > > ________________________________________________________________________________
Date: Jan 31, 2018
For OUT I went with the ES upgrade last year on my 330 transponder. It was just a convenient option for me. Note that it also required a software upgrade for the 430W GPS and another wire between the two. For IN I built myself a Stratux (http://stratux.me) and currently get traffic/weather from that in ForeFlight on the iPad. The Stratux can now do serial out so I could send it to my AFS 4500s if/when I get the desire to do that. I also still have my Sirrux XM subscription, but that will most likely be turned off as the Stratux IN box has proven itself. Many options indeed and it all just depends. -Sean #40303 > Kelly McMullen > January 31, 2018 at 8:51 AM > > I agree, the decision is driven by wallet, receive capability and what > you already have. The UAT option unfortunately comes saddled with > unnecessary complexity..you have to keep, maintain, and certify a Mode > C transponder/encoder on top of the UAT add-on. The 1090ES option > costs more initially, but is only one unit to maintain and certify > every 2 years, and lets you go anywhere outside US borders. It also > lets you go into the flight levels if that gets you over some weather. > Then you have to consider whether you are going to take advantage of > the ability to receive traffic and weather, and if you want that on > your PFD/MFD or something portable, or both. Those of us that have the > traffic and weather on our panel mount displays probably would only > use the portable as a backup..but that is decided as much by budget > and how/where we fly more than anything. When you add cost of iPad and > software for that, plus a means to get the data to the iPad, whether > portable receiver or something built-in, those numbers are > significant, though perhaps less than getting it into our panel > displays. However, having an independent, battery powered display has > a lot of merit. > > ________________________________________________________________________________
Date: Jan 31, 2018
Sean, I'd like to learn something on this. The ES upgrade, I've heard that when you get the transponder back, it's physically longer. Is that true? If not, it's more attractive. Tim On 01/31/2018 09:13 AM, Sean Stephens wrote: > > For OUT I went with the ES upgrade last year on my 330 transponder. It > was just a convenient option for me. Note that it also required a > software upgrade for the 430W GPS and another wire between the two. > > For IN I built myself a Stratux (http://stratux.me) and currently get > traffic/weather from that in ForeFlight on the iPad. The Stratux can > now do serial out so I could send it to my AFS 4500s if/when I get the > desire to do that. > > I also still have my Sirrux XM subscription, but that will most likely > be turned off as the Stratux IN box has proven itself. > > Many options indeed and it all just depends. > > -Sean #40303 > >> Kelly McMullen >> January 31, 2018 at 8:51 AM >> >> I agree, the decision is driven by wallet, receive capability and what >> you already have. The UAT option unfortunately comes saddled with >> unnecessary complexity..you have to keep, maintain, and certify a Mode >> C transponder/encoder on top of the UAT add-on. The 1090ES option >> costs more initially, but is only one unit to maintain and certify >> every 2 years, and lets you go anywhere outside US borders. It also >> lets you go into the flight levels if that gets you over some weather. >> Then you have to consider whether you are going to take advantage of >> the ability to receive traffic and weather, and if you want that on >> your PFD/MFD or something portable, or both. Those of us that have the >> traffic and weather on our panel mount displays probably would only >> use the portable as a backup..but that is decided as much by budget >> and how/where we fly more than anything. When you add cost of iPad and >> software for that, plus a means to get the data to the iPad, whether >> portable receiver or something built-in, those numbers are >> significant, though perhaps less than getting it into our panel >> displays. However, having an independent, battery powered display has >> a lot of merit. >> >> >> >> ________________________________________________________________________________
Date: Jan 31, 2018
On 01/31/2018 09:33 AM, Tim Olson wrote: > I agree with Jesse, the time isn't now, the time was a while ago. > I've been flying with ADS-B since 2009, and wouldn't be without > it now. Ditto. I installed full ADS-B In/Out about 3 years ago, and would not want to be without it. You don't realize how valuable a tool it really is until you fly with it, so if you know someone with an installed system, ask them to take you up and demo it. -Dj ________________________________________________________________________________
Date: Jan 31, 2018
The 330ES is physically identical to the 330. There is updated software and hardware inside, but its the same tray and connector. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 > On Jan 31, 2018, at 10:47 AM, Tim Olson wrote: > > > Sean, > > I'd like to learn something on this. The ES upgrade, I've heard that > when you get the transponder back, it's physically longer. Is that true? > If not, it's more attractive. > Tim > > > On 01/31/2018 09:13 AM, Sean Stephens wrote: >> For OUT I went with the ES upgrade last year on my 330 transponder. It was just a convenient option for me. Note that it also required a software upgrade for the 430W GPS and another wire between the two. >> For IN I built myself a Stratux (http://stratux.me) and currently get traffic/weather from that in ForeFlight on the iPad. The Stratux can now do serial out so I could send it to my AFS 4500s if/when I get the desire to do that. >> I also still have my Sirrux XM subscription, but that will most likely be turned off as the Stratux IN box has proven itself. >> Many options indeed and it all just depends. >> -Sean #40303 >>> Kelly McMullen >>> January 31, 2018 at 8:51 AM >>> >>> I agree, the decision is driven by wallet, receive capability and what you already have. The UAT option unfortunately comes saddled with unnecessary complexity..you have to keep, maintain, and certify a Mode C transponder/encoder on top of the UAT add-on. The 1090ES option costs more initially, but is only one unit to maintain and certify every 2 years, and lets you go anywhere outside US borders. It also lets you go into the flight levels if that gets you over some weather. >>> Then you have to consider whether you are going to take advantage of the ability to receive traffic and weather, and if you want that on your PFD/MFD or something portable, or both. Those of us that have the traffic and weather on our panel mount displays probably would only use the portable as a backup..but that is decided as much by budget and how/where we fly more than anything. When you add cost of iPad and software for that, plus a means to get the data to the iPad, whether portable receiver or something built-in, those numbers are significant, though perhaps less than getting it into our panel displays. However, having an independent, battery powered display has a lot of merit. >>> >>> >>> >>> > > > ________________________________________________________________________________
Date: Jan 31, 2018
The 330ES upgrade does not physically change the dimensions of the transponder at all. Remove the transponder unit only from the panel, get it upgraded, the re-install (into the same tray you had before). Cheers, Stein -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Wednesday, January 31, 2018 9:47 AM Subject: Re: RV10-List: Re: ADS-B - is the time now Sean, I'd like to learn something on this. The ES upgrade, I've heard that when you get the transponder back, it's physically longer. Is that true? If not, it's more attractive. Tim On 01/31/2018 09:13 AM, Sean Stephens wrote: > --> > > For OUT I went with the ES upgrade last year on my 330 transponder. > It was just a convenient option for me. Note that it also required a > software upgrade for the 430W GPS and another wire between the two. > > For IN I built myself a Stratux (http://stratux.me) and currently get > traffic/weather from that in ForeFlight on the iPad. The Stratux can > now do serial out so I could send it to my AFS 4500s if/when I get the > desire to do that. > > I also still have my Sirrux XM subscription, but that will most likely > be turned off as the Stratux IN box has proven itself. > > Many options indeed and it all just depends. > > -Sean #40303 > >> Kelly McMullen January 31, 2018 at 8:51 >> AM >> >> I agree, the decision is driven by wallet, receive capability and >> what you already have. The UAT option unfortunately comes saddled >> with unnecessary complexity..you have to keep, maintain, and certify >> a Mode C transponder/encoder on top of the UAT add-on. The 1090ES >> option costs more initially, but is only one unit to maintain and >> certify every 2 years, and lets you go anywhere outside US borders. >> It also lets you go into the flight levels if that gets you over some weather. >> Then you have to consider whether you are going to take advantage of >> the ability to receive traffic and weather, and if you want that on >> your PFD/MFD or something portable, or both. Those of us that have >> the traffic and weather on our panel mount displays probably would >> only use the portable as a backup..but that is decided as much by >> budget and how/where we fly more than anything. When you add cost of >> iPad and software for that, plus a means to get the data to the iPad, >> whether portable receiver or something built-in, those numbers are >> significant, though perhaps less than getting it into our panel >> displays. However, having an independent, battery powered display has >> a lot of merit. >> >> >> >> ________________________________________________________________________________
Date: Jan 31, 2018
Yep. Just plop it back in the tray when you get it back. Well, and add the extra wire for the GPS position source. Stein handled my upgrade. Smooth process going through them as they handle the Garmin details. -Sean #40303 > Stein Bruch > January 31, 2018 at 10:07 AM > > The 330ES upgrade does not physically change the dimensions of the > transponder at all. Remove the transponder unit only from the panel, > get it upgraded, the re-install (into the same tray you had before). > > Cheers, > Stein > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Wednesday, January 31, 2018 9:47 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: ADS-B - is the time now > > > Sean, > > I'd like to learn something on this. The ES upgrade, I've heard that > when you get the transponder back, it's physically longer. Is that true? > If not, it's more attractive. > Tim > > ________________________________________________________________________________
Date: Jan 31, 2018
Sounds great. Glad it's that easy. Thanks guys, Tim On 01/31/2018 10:30 AM, Sean Stephens wrote: > > Yep. Just plop it back in the tray when you get it back. Well, and add > the extra wire for the GPS position source. > > Stein handled my upgrade. Smooth process going through them as they > handle the Garmin details. > > -Sean #40303 > >> Stein Bruch >> January 31, 2018 at 10:07 AM >> >> The 330ES upgrade does not physically change the dimensions of the >> transponder at all. Remove the transponder unit only from the panel, >> get it upgraded, the re-install (into the same tray you had before). >> >> Cheers, >> Stein >> >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson >> Sent: Wednesday, January 31, 2018 9:47 AM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Re: ADS-B - is the time now >> >> >> Sean, >> >> I'd like to learn something on this. The ES upgrade, I've heard that >> when you get the transponder back, it's physically longer. Is that true? >> If not, it's more attractive. >> Tim >> ________________________________________________________________________________
Subject: Re: Looking for =?ISO-8859-1?Q?2=9D?= alum butterfly valve
Date: Jan 31, 2018
You may want to try AVIACOMP International. http://www.aviacompinternational.com/connectors.html. Looks like they are the manufacture of the valve you are looking for. They may be able to help you out. Larry -------- Larry Rosen #40356 N205EN (reserved) <http> Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477732#477732 ________________________________________________________________________________
From: "Gautier, Thomas N (3262)" <thomas.n.gautier(at)jpl.nasa.gov>
Subject: N363TG first flight
Date: Feb 01, 2018
QWxsLA0KDQpOMzYzVEcgbWFkZSBpdHMgZmlyc3QgZmxpZ2h0IGxhc3QgVHVlc2RheSwgdHdvIGRh eXMgYWdvLiBJIHNwZW50IGEgbG90IG9mIHRpbWUgbHVya2luZyBhbmQgbm90IG11Y2ggdGltZSB0 YWxraW5nIHRvIHRoZSBsaXN0IGJ1dCBhbGwgeW91IHBlb3BsZSB3ZXJlIGEgZ3JlYXQgaGVscC4g VGhhbmtzLg0KDQpNeSBzZXJpYWwgbnVtYmVyIGlzIDQwMzYzIHNvLCBhcyB5b3UgY2FuIHRlbGws IHRoZSBhaXJwbGFuZSB3YXMgMTIuNyB5ZWFycyBpbiB0aGUgY29taW5nLiBTbywgaGFuZyBpbiB0 aGVyZSBhbGwgeW91IGxvdyBTTiBndXlzIHdobyBoYXZlbuKAmXQgZmxvd24geWV0LiBJdCBjYW4g YmUgZG9uZS4NCg0KUmVnYXJkcywNCg0KTmljayBHYXV0aWVyDQoNCkRvIG5vdCBhcmNoaXZlDQo ________________________________________________________________________________
Date: Feb 03, 2018
Subject: FS (Free) RV-10 Empennage Kit (SF Bay Area)
Hi Folks - Started building my RV-10 empennage kit in early 2008, got through the VS and rudder and then had a second child. The kit has been hibernating since and I don't think I'll pick it up again anytime soon. I need it to disappear from my garage, so I'm offering it to anyone who is willing to come pick it up. Unfortunately I was keeping the build log in a database that I appear to have lost. So I have some photographs, but no other details to go along with the VS an rudder. If you're interested, shoot me an email: dennis(at)bullamanka.com Dennis Keller RV-10 40825 ________________________________________________________________________________
Subject: Re: FS (Free) RV-10 Empennage Kit (SF Bay Area)
Date: Feb 04, 2018
Not that I=99m in the market, but where are you located, Dennis? From: Dennis Keller Sent: Saturday, February 03, 2018 9:09 PM Subject: RV10-List: FS (Free) RV-10 Empennage Kit (SF Bay Area) Hi Folks - Started building my RV-10 empennage kit in early 2008, got through the VS and rudder and then had a second child. The kit has been hibernating since and I don't think I'll pick it up again anytime soon. I need it to disappear from my garage, so I'm offering it to anyone who is willing to come pick it up. Unfortunately I was keeping the build log in a database that I appear to have lost. So I have some photographs, but no other details to go along with the VS an rudder. If you're interested, shoot me an email: dennis(at)bullamanka.com Dennis Keller RV-10 40825 ________________________________________________________________________________
Date: Feb 04, 2018
Quick update to close this out. As of 11AMPT, the kit should be on its way to a builder who will be able to complete it. Safe flying -- Dennis On Sat, Feb 3, 2018 at 6:09 PM, Dennis Keller wrote: > Hi Folks - > > Started building my RV-10 empennage kit in early 2008, got through the VS > and rudder and then had a second child. The kit has been hibernating since > and I don't think I'll pick it up again anytime soon. I need it to > disappear from my garage, so I'm offering it to anyone who is willing to > come pick it up. > > Unfortunately I was keeping the build log in a database that I appear to > have lost. So I have some photographs, but no other details to go along > with the VS an rudder. > > If you're interested, shoot me an email: dennis(at)bullamanka.com > > Dennis Keller > RV-10 40825 > ________________________________________________________________________________
Subject: Re: N363TG first flight
Date: Feb 06, 2018
Yippeeeeee. Safe flying, Give us some meat to chew on and inspire the others out there. Pics., stories, equipment..............Nice accomplishment -------- See you OSH '18 Q/B - flying 8 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477870#477870 ________________________________________________________________________________
Subject: Re: ADS-B compliance question
Date: Feb 13, 2018
> On 2018-Feb-08, at 5:23 PM, Bob Leffler wrote: > > > A couple questions........ > > What EFIS do you have? Is it a Skyview or AFS? Your EFIS should be providing the 261 pressure altitude. GPS altitude is only used as a backup. I believe that both are transmitted as part of the ADSB out. It's an AFS system I have. > > I can't tell you how to debug the Skyview, but on the AFS there is the ability to dump data from the serial ports to an ascii file. It may be tedious, but you can look through this output and see if there is any issues with the EFIS transmitting pressure altitude to the 261. I'm sure that you can do something similar on the Skyview. Unfortunately I don't have that experience. I'll try to do a serial port dump the next time I go flying to see if there are any inconsistencies. Thanks for the suggestion! > > How close was the nearest ADSB tower? Sometimes there are errors during initial climb out and on descent. Especially if the ADSB tower is nearby or on the field. I know that some folks were advised for the ADSB rebates to leave everything turned off until they hit 3K agl to minimize these errors. I'm not sure - and likely throughout the flight hopped between several towers. The report didn't give me much info other than just saying that there were some errors with Geo Alt. For all I know, it might have just been on the ground when the GPS was still getting a lock on the satellites and didn't know altitude yet. But in any case, I can't figure out why a total outage of 21 seconds worth of data came to a reported 3.7% fail rate, when in reality the failure rate should have been 15 times less by my calculations. > > Have you had the 261 certified yet? They should be able to see if there are any issues with the transponder and its data feeds. Although many shops have older test rigs. The "traditional Mode C" side of the transponder was certified a bit less than a year ago. Though the equipment used didn't have the ability to dig deep into the ADS-B data other than to just see that it was generally sending valid packets. > > If these weren't failed as red, I wouldn't lose any sleep over it. Generate another PAPR the next time you're In the US. The Geo Alt. section (under missing elements) was flagged as red. But none of the "exceptions" section (NIC, NACp, NACv, SIL, SDA) or anything else. Just the Geo Alt. Others have suggested potentially inputting an altitude offset to ensure barometric altitude matches closely with GPS altitude (unless the reference is to adjust the GPS altitude, though I've already set my antenna height above the wheel base accurately). But I thought the "Missing Elements" Geo Alt failures were "standalone" where the GPS didn't provide altitude data. I didn't think it was flagging that it didn't compare favourably against barometric altitude. My Baro Alt, Baro Alt Delta, Geo Alt, and Geo Alt Delta under the Kinematics section all read 0 errors and 0% failure rate. In any case, how could they actually compare the two, since baro alt for the transponder is standardized at 29.92 and geo alt isn't affected by the local air pressure. Plus, even if they recorded nearest station altimeter readings to make the appropriate corrections, even then comparing the two assumes an ISA atmosphere, which is rarely the case. From my understanding, that's why, for example, even if altimeters are set perfectly, if the weather is cold, cold temperature corrections are necessary to find true height above sea level otherwise you're flying lower than you think. The GPS altitude wouldn't reflect any of this. I'll double check the firmware for the transponder and GTN as well, to make sure they're all up to date. Regardless, I'll try doing a serial dump the next time I fly, though since I don't fly in the US that often, it might be some time before I can compare it against another PAPR. Thanks again for the suggestion! Dan --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Subject: Advice for gascolator quick drains
Date: Feb 13, 2018
Hi everyone. I have gascolators located in the wing roots of my RV-10 (here in Canada, we require them, whether they make logical sense or not). They're at the lowest point in the fuel system I can get them (also required), though the true lowest point in the fuel system is the drains in the bottom of the tanks, since fuel has to flow uphill to get into the gascolator (from either direction). So I don't expect there to be much water ever get trapped in the gascolator. And in reality, though I had a bit of water I drained once from the bottom of the tanks (the result of a not-perfectly-sealed fuel cap when the plane was left outside in the rain once), I've never seen any in the gascolators. Nonetheless, I should have a quick drain, if for no other reason than to be able to check them periodically - though water won't naturally flow into them when the plane is at rest, when the fuel is flowing, I imagine small droplets in suspension with the fuel may get trapped in the bowl and slowly build up. The trouble is that these gascolators aren't under positive pressure as gascolators would normally be - they'd be under a slight negative pressure as fuel is sucked from the tanks. I worry that if I used just a standard quick drain there might be the possibility of air leaking into the fuel line (I've seen those quick drains leak fuel on more than one occasion when the seal starts to degrade a bit - they seem to be notorious for that - so I'm reasonably certain they'd just as happily leak air in as well if they're under suction as they are). And I'm not too sure that having air bubbles in the fuel is altogether preferable to water droplets. Does anyone have any good suggestions on how to handle this? I definitely don't expect to have to check for water after every flight as most would be drained from the tank drains anyway. Screwing in just a simple plug works reliably enough to keep the air out, but is a bit problematic to periodically check and drain (fuel tends to get everywhere when you try to thread the plug back into place). Is there a quick-drain suited for this sort of specific purpose? I'm thinking of maybe something that screws in to have a positive seal to prevent leakage, but unscrews slightly to let a bit of fuel drain out? Something better than just a spring pushing against an O-ring, or having a plug that has to be completely removed, in any event. Thanks for any help or advice you might have! Dan --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Subject: Advice for gascolator quick drains (extra info)
Date: Feb 13, 2018
I just realized a better way of describing the type of fuel drain that I imagine might work perfectly for the gascolators under slight suction as I mentioned. I'm thinking of something along a similar design to how the bleeder valves for the brake lines work. The valve is held closed by screwing the mechanism shut, but when the mechanism is unscrewed, fluid can flow through and out the centre of the valve. Really, not all that dissimilar to how a regular tap works either. Does such a thing exist with a relatively low profile and 1/4" NPT threads that wouldn't protrude too far into the gascolator? Or does someone see a problem with this type of approach? But of course I'm open to any and all suggestions too! Thanks! Dan --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Date: Feb 13, 2018
Subject: Getting wing lined up and pinned
Hi list, How difficult is it to get the wing lined up and pinned to the fuselage? I had this idea that two people could lift the root while a third slips the first pin in. Then we could lift the tip/pivot the wing around the pin until the upper holes line up. Or is this more complex than I'm thinking? Thanks for the help, David ________________________________________________________________________________
Subject: Re: Advice for gascolator quick drains
Date: Feb 14, 2018
Dan I would use solid bungs with thread sealant. When I had gascolators located in the wing roots I was very concerned about getting air into the fuel system. I would not use quick drains. Cheers Les PS: MDRA no longer "requires" gascolators provided functionality is met. Perhaps you could remove yours arguing that they are no longer required. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478014#478014 ________________________________________________________________________________
Subject: Re: Getting wing lined up and pinned
Date: Feb 14, 2018
David I have had to do his twice. Each time it was remarkably easy. First off, I put my bolts into dry ice overnight to shrink them slightly. Then I used two of these lifts (https://www.princessauto.com/en/detail/300-lb-dirt-bike-motorcycle-lift/A-p8667792e) that a friend had on hand. One at the wing tip and one at the root so I could tweak the wing angle. As you suggest, I got one bolt in and the rest soon followed. I think it will be awkward to do it manually as it may be tricky to keep things steady. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478016#478016 ________________________________________________________________________________
Date: Feb 14, 2018
Ideally, if you can round up three others to help, I'd put one each at the leading and trailing edge of the root, one at the tip, and one to slip in the bolts. They won't need a lot of force. Using a round-nosed "bullet" helps line things up. As Les said, the first one is trickiest, then they get easier. --Dave On Tue, Feb 13, 2018 at 9:46 AM, David Carr wrote: > Hi list, > > How difficult is it to get the wing lined up and pinned to the fuselage? > > I had this idea that two people could lift the root while a third slips > the first pin in. Then we could lift the tip/pivot the wing around the pin > until the upper holes line up. > > Or is this more complex than I'm thinking? > > Thanks for the help, > David > ________________________________________________________________________________
Date: Feb 14, 2018
Its easiest with 4 people, it you could do it with 3. Have one at the wingtip and two at the wing root, one in front and one behind the wing. The one at the back will need a screwdriver or something to spread the rear spar carry-through so the rear space can fit into the slot. While holding the front of the wing, the person in front or behind can sight through a bolt hole to verify alignment, then the other person can put the bolt in place and tap it in. The person at the wingtip will adjust his position to help alignment. Once one bolt is in place on top, then the person at the wingtip will move up or down as necessary to get a hole at the bottom to line up, then tap another bolt in place. Make sure to grease the bolt before inserting. It will help them go in and come back out when necessary. You can clean any grease from the threads for final installation. Once 2 bolts are in place the rest will be much easier. I like to use a 2x2 long enough to hit with a mallet in front of the front tank baffle so I dont risk hitting the wing or the fuselage. Make sure any fittings in the tank area dont get in the way of the bolts. It can happen easily. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Feb 13, 2018, at 12:46 PM, David Carr wrote: > > Hi list, > > How difficult is it to get the wing lined up and pinned to the fuselage? > > I had this idea that two people could lift the root while a third slips the first pin in. Then we could lift the tip/pivot the wing around the pin until the upper holes line up. > > Or is this more complex than I'm thinking? > > Thanks for the help, > David ________________________________________________________________________________
Date: Feb 13, 2018
Subject: Test
Someone told me they couldnt post to the list so Im testing it. Tim ________________________________________________________________________________
Date: Feb 14, 2018
Subject: Re: Test
Must have been something going on...that took over 24 hours to show up. Tim > On Feb 13, 2018, at 9:17 PM, Tim Olson wrote: > > > Someone told me they couldnt post to the list so Im testing it. > Tim > > > > ________________________________________________________________________________
Subject: Test
Date: Feb 15, 2018
I think the 24 hour delay occurs because of the international date line. If somebody east of the line posts something on say Tuesday, it would show up on Monday west of the line making people wonder about time travel and such. The 24 hour delay removes the problem. People are comfortable with hours and days of delay but don't want messages from the future in their inbox. AG -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Wednesday, February 14, 2018 10:24 PM Subject: Re: RV10-List: Test Must have been something going on...that took over 24 hours to show up. Tim > On Feb 13, 2018, at 9:17 PM, Tim Olson wrote: > > > Someone told me they couldnt post to the list so Im testing it. > Tim > > > > ________________________________________________________________________________
Date: Feb 15, 2018
I used my rivet gun to tap them in. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: Wednesday, February 14, 2018 9:31 PM Subject: Re: RV10-List: Getting wing lined up and pinned Its easiest with 4 people, it you could do it with 3. Have one at the wingtip and two at the wing root, one in front and one behind the wing. The one at the back will need a screwdriver or something to spread the rear spar carry-through so the rear space can fit into the slot. While holding the front of the wing, the person in front or behind can sight through a bolt hole to verify alignment, then the other person can put the bolt in place and tap it in. The person at the wingtip will adjust his position to help alignment. Once one bolt is in place on top, then the person at the wingtip will move up or down as necessary to get a hole at the bottom to line up, then tap another bolt in place. Make sure to grease the bolt before inserting. It will help them go in and come back out when necessary. You can clean any grease from the threads for final installation. Once 2 bolts are in place the rest will be much easier. I like to use a 2x2 long enough to hit with a mallet in fr! ont of the front tank baffle so I dont risk hitting the wing or the fuselage. Make sure any fittings in the tank area dont get in the way of the bolts. It can happen easily. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Feb 13, 2018, at 12:46 PM, David Carr wrote: > > Hi list, > > How difficult is it to get the wing lined up and pinned to the fuselage? > > I had this idea that two people could lift the root while a third slips the first pin in. Then we could lift the tip/pivot the wing around the pin until the upper holes line up. > > Or is this more complex than I'm thinking? > > Thanks for the help, > David ________________________________________________________________________________
Date: Feb 15, 2018
I found with pilot bolts that my spar web holes did not line up on left wing with the holes in the square spar caps. (IOW the bolts wouldn't go through wing spar by itself without the carry through. Vans advised me to carefully use Dremel on back side of the web to enlarge web holes only to match, and even though I had the right size reamer to NOT use the reamer from the front side as it might remove material from the spar caps. Used dry ice, LPS1 and drift pins with dead blow rubber mallet to get mine in. Sent from my IBM-360 main frame On Thu, Feb 15, 2018 at 8:57 AM, Rene Felker wrote: > > I used my rivet gun to tap them in. > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list- > server(at)matronics.com] On Behalf Of Jesse Saint > Sent: Wednesday, February 14, 2018 9:31 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Getting wing lined up and pinned > > > It=99s easiest with 4 people, it you could do it with 3. Have one at the > wingtip and two at the wing root, one in front and one behind the wing. T he > one at the back will need a screwdriver or something to spread the rear > spar carry-through so the rear space can fit into the slot. While holding > the front of the wing, the person in front or behind can sight through a > bolt hole to verify alignment, then the other person can put the bolt in > place and tap it in. The person at the wingtip will adjust his position t o > help alignment. Once one bolt is in place on top, then the person at the > wingtip will move up or down as necessary to get a hole at the bottom to > line up, then tap another bolt in place. Make sure to grease the bolt > before inserting. It will help them go in and come back out when necessar y. > You can clean any grease from the threads for final installation. Once 2 > bolts are in place the rest will be much easier. I like to use a 2x2 long > enough to hit with a mallet in fr! > ont of the front tank baffle so I don=99t risk hitting the wing or the > fuselage. Make sure any fittings in the tank area don=99t get in th e way of > the bolts. It can happen easily. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > > On Feb 13, 2018, at 12:46 PM, David Carr wrote: > > > > Hi list, > > > > How difficult is it to get the wing lined up and pinned to the fuselage ? > > > > I had this idea that two people could lift the root while a third slips > the first pin in. Then we could lift the tip/pivot the wing around the p in > until the upper holes line up. > > > > Or is this more complex than I'm thinking? > > > > Thanks for the help, > > David > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Subject: RV10 Value
Date: Feb 18, 2018
Hi As I move forward with my -10 project, I am starting to give thought to selling my flying -10 in the late summer. I am interested in opinions as to what a -10 would sell for. My -10 has: 350 hrs, NDH BPE engine dyno'd at 287 HP (9:1 compression / Cold Air Induction) Showplanes cowl MT 3 bladed prop Dual AFS 4500's, GNS 430WAAS / SL30 / GTX325 TruTrak A/P with pitch trim Built in O2 Leather interior OH console Center console Nice paint Cheers Les C-GCWZ flying C-GROK Some assembly required Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478090#478090 ________________________________________________________________________________
Date: Feb 18, 2018
Subject: Re: RV10 Value
Can you predict what the Looney will be worth then? Sent from my IBM-360 main frame On Sun, Feb 18, 2018 at 1:36 PM, kearney wrote: > > Hi > > As I move forward with my -10 project, I am starting to give thought to > selling my flying -10 in the late summer. > > I am interested in opinions as to what a -10 would sell for. My -10 has: > > 350 hrs, NDH > BPE engine dyno'd at 287 HP (9:1 compression / Cold Air Induction) > Showplanes cowl > MT 3 bladed prop > Dual AFS 4500's, GNS 430WAAS / SL30 / GTX325 > TruTrak A/P with pitch trim > Built in O2 > Leather interior > OH console > Center console > Nice paint > > Cheers > > Les > > C-GCWZ flying > C-GROK Some assembly required > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478090#478090 > > ________________________________________________________________________________
Date: Feb 18, 2018
What=99s the Looney? Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 Sent from my iPhone > On Feb 18, 2018, at 9:38 PM, Kelly McMullen wrote: > > Can you predict what the Looney will be worth then? > > Sent from my IBM-360 main frame > >> On Sun, Feb 18, 2018 at 1:36 PM, kearney wrote: >> >> Hi >> >> As I move forward with my -10 project, I am starting to give thought to s elling my flying -10 in the late summer. >> >> I am interested in opinions as to what a -10 would sell for. My -10 has: >> >> 350 hrs, NDH >> BPE engine dyno'd at 287 HP (9:1 compression / Cold Air Induction) >> Showplanes cowl >> MT 3 bladed prop >> Dual AFS 4500's, GNS 430WAAS / SL30 / GTX325 >> TruTrak A/P with pitch trim >> Built in O2 >> Leather interior >> OH console >> Center console >> Nice paint >> >> Cheers >> >> Les >> >> C-GCWZ flying >> C-GROK Some assembly required >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=478090#478090 >> >> >> >> >> >> >> ========================= >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= >> >> >> > ________________________________________________________________________________
Date: Feb 18, 2018
I mispelled...Loonie, https://en.wikipedia.org/wiki/Loonie On 2/18/2018 8:03 PM, Jesse Saint wrote: > Whats the Looney? > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > Sent from my iPhone > > On Feb 18, 2018, at 9:38 PM, Kelly McMullen > wrote: > >> Can you predict what the Looney will be worth then? >> >> Sent from my IBM-360 main frame >> >> On Sun, Feb 18, 2018 at 1:36 PM, kearney > > wrote: >> >> > >> >> Hi >> >> As I move forward with my -10 project, I am starting to give >> thought to selling my flying -10 in the late summer. >> >> I am interested in opinions as to what a -10 would sell for. My >> -10 has: >> >> 350 hrs, NDH >> BPE engine dyno'd at 287 HP (9:1 compression / Cold Air Induction) >> Showplanes cowl >> MT 3 bladed prop >> Dual AFS 4500's, GNS 430WAAS / SL30 / GTX325 >> TruTrak A/P with pitch trim >> Built in O2 >> Leather interior >> OH console >> Center console >> Nice paint >> >> Cheers >> >> Les >> >> C-GCWZ flying >> C-GROK Some assembly required >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=478090#478090 >> <http://forums.matronics.com/viewtopic.php?p=478090#478090> >> >> >> >> >> >> >> =================================== >> -List" rel="noreferrer" >> target="_blank">http://www.matronics.com/Navigator?RV10-List >> =================================== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> =================================== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> ________________________________________________________________________________
Date: Feb 18, 2018
Price it was n USD. No Exchange issue then. Sent from my iPhone > On Feb 18, 2018, at 7:38 PM, Kelly McMullen wrote: > > Can you predict what the Looney will be worth then? > > Sent from my IBM-360 main frame > >> On Sun, Feb 18, 2018 at 1:36 PM, kearney wrote: >> >> Hi >> >> As I move forward with my -10 project, I am starting to give thought to s elling my flying -10 in the late summer. >> >> I am interested in opinions as to what a -10 would sell for. My -10 has: >> >> 350 hrs, NDH >> BPE engine dyno'd at 287 HP (9:1 compression / Cold Air Induction) >> Showplanes cowl >> MT 3 bladed prop >> Dual AFS 4500's, GNS 430WAAS / SL30 / GTX325 >> TruTrak A/P with pitch trim >> Built in O2 >> Leather interior >> OH console >> Center console >> Nice paint >> >> Cheers >> >> Les >> >> C-GCWZ flying >> C-GROK Some assembly required >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=478090#478090 >> >> >> >> >> >> >> ========================= >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========================= >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========================= >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========================= >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========================= >> >> >> > ________________________________________________________________________________
Date: Feb 18, 2018
It is a $1.00 Canadian that haze a Loon on the one side. Hence the name =9CLoonie=9D. We obviously call the $2.00 coin a Toonie. Speaking of which the US would do well to get rid of $1.00 bills as we did. Cheers Les Sent from my iPhone > On Feb 18, 2018, at 8:03 PM, Jesse Saint wrote: > > What=99s the Looney? > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > Sent from my iPhone > >> On Feb 18, 2018, at 9:38 PM, Kelly McMullen wrote: >> >> Can you predict what the Looney will be worth then? >> >> Sent from my IBM-360 main frame >> >>> On Sun, Feb 18, 2018 at 1:36 PM, kearney wrote: >>> >>> Hi >>> >>> As I move forward with my -10 project, I am starting to give thought to s elling my flying -10 in the late summer. >>> >>> I am interested in opinions as to what a -10 would sell for. My -10 has: >>> >>> 350 hrs, NDH >>> BPE engine dyno'd at 287 HP (9:1 compression / Cold Air Induction) >>> Showplanes cowl >>> MT 3 bladed prop >>> Dual AFS 4500's, GNS 430WAAS / SL30 / GTX325 >>> TruTrak A/P with pitch trim >>> Built in O2 >>> Leather interior >>> OH console >>> Center console >>> Nice paint >>> >>> Cheers >>> >>> Les >>> >>> C-GCWZ flying >>> C-GROK Some assembly required >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=478090#478090 >>> >>> >>> >>> >>> >>> >>> ======================== =========== >>> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Nav igator?RV10-List >>> ======================== =========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ======================== =========== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> ======================== =========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contributi on >>> ======================== =========== >>> >>> >>> >> ________________________________________________________________________________
Date: Feb 19, 2018
I can=99t speak to the value in the Canadian market, and I don=99 t know the exchange rate right now anyway. As for the $1 bill, you=99l l have to talk to the Federal Reserve about that. They still mint pennies, s o I doubt the $1 bill is going anywhere any time soon. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 Sent from my iPhone > On Feb 18, 2018, at 11:06 PM, Kearney wrote: > > It is a $1.00 Canadian that haze a Loon on the one side. Hence the name =9CLoonie=9D. We obviously call the $2.00 coin a Toonie. > > Speaking of which the US would do well to get rid of $1.00 bills as we did . > > Cheers > > Les > > Sent from my iPhone > >> On Feb 18, 2018, at 8:03 PM, Jesse Saint wrote: >> >> What=99s the Looney? >> >> Jesse Saint >> Saint Aviation, Inc. >> jesse(at)saintaviation.com >> C: 352-427-0285 >> F: 815-377-3694 >> >> Sent from my iPhone >> >>> On Feb 18, 2018, at 9:38 PM, Kelly McMullen wrote: >>> >>> Can you predict what the Looney will be worth then? >>> >>> Sent from my IBM-360 main frame >>> >>>> On Sun, Feb 18, 2018 at 1:36 PM, kearney wrote: >>>> >>>> Hi >>>> >>>> As I move forward with my -10 project, I am starting to give thought to selling my flying -10 in the late summer. >>>> >>>> I am interested in opinions as to what a -10 would sell for. My -10 has : >>>> >>>> 350 hrs, NDH >>>> BPE engine dyno'd at 287 HP (9:1 compression / Cold Air Induction) >>>> Showplanes cowl >>>> MT 3 bladed prop >>>> Dual AFS 4500's, GNS 430WAAS / SL30 / GTX325 >>>> TruTrak A/P with pitch trim >>>> Built in O2 >>>> Leather interior >>>> OH console >>>> Center console >>>> Nice paint >>>> >>>> Cheers >>>> >>>> Les >>>> >>>> C-GCWZ flying >>>> C-GROK Some assembly required >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=478090#478090 >>>> >>>> >>>> >>>> >>>> >>>> >>>> ======================== =========== >>>> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Na vigator?RV10-List >>>> ======================== =========== >>>> FORUMS - >>>> eferrer" target="_blank">http://forums.matronics.com >>>> ======================== =========== >>>> WIKI - >>>> errer" target="_blank">http://wiki.matronics.com >>>> ======================== =========== >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribut ion >>>> ======================== =========== >>>> >>>> >>>> >>> ________________________________________________________________________________
Date: Feb 19, 2018
I have over 180 hours on the SureFly electronic ignitions and they have performed well. So well, I installed 2. (I have 2 independent electrical systems with 2 alternators and 2 batteries.) -------- Dave Moore RV-6 built and sold RV-10 built and flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478109#478109 ________________________________________________________________________________
Date: Feb 19, 2018
Subject: help
Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477970#477970 -- ------------------------------ The information contained in this email and all attachments are the property of LeaseNet Services, LLC. If you have received this email in error, please delete it from all devices. ________________________________________________________________________________
Date: Feb 20, 2018
Any pictures of the ignition system installations please Dave? Warm regards Patrick > On 20 Feb 2018, at 01:30, nukeflyboy wrote: > > > I have over 180 hours on the SureFly electronic ignitions and they have performed well. So well, I installed 2. (I have 2 independent electrical systems with 2 alternators and 2 batteries.) > > -------- > Dave Moore > RV-6 built and sold > RV-10 built and flying > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478109#478109 > > > > > > > > > ________________________________________________________________________________
Date: Feb 21, 2018
Sorry, no photos. The installation is easy. Swap your mag for the unit and add a power source. Used same harness as the mag. Can use fine wire Tempest plugs or keep the heavy ones. -------- Dave Moore RV-6 built and sold RV-10 built and flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478171#478171 ________________________________________________________________________________
Date: Feb 21, 2018
Im not in the market so I dont have a finger on its pulse, but just from casual observation, I would say (hope) that a solidly built, decently equipped, RV10 should command north of 200k USD. It competes (well) against a lot more mission types and certified offerings and therefore enjoys a broader market than the average home built sportplane IMO. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478177#478177 ________________________________________________________________________________
Subject: Re: Kitlog Data Base
Date: Feb 24, 2018
A computer crash doesn't necessarily corrupt your backup files. Even if the hard drive failed, the data should still be there...at least most of it. Have you tried reinstalling kit log and then trying the backup? I'm not sure if you can get the data from the website... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478228#478228 ________________________________________________________________________________
Date: Feb 24, 2018
Been there, done that. I was able to recover my database file, but could not get the new computer to recognize and use it. I asked if the online web data could be downloaded and was told no. In the end, i used the web version and the most recent report I had done to rebuild my log. It took a few hours, but wasn't hard with two screens hooked up to my computer. It also seems to work best sending emails to get support. Matt has answered most questions multiple times and can quickly send you instructions. -------- Leok "Make no small plans, for small plans have no magic to inspire the minds of men" Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478233#478233 ________________________________________________________________________________
Subject: Standby Alternator
Date: Feb 24, 2018
Hi I am planning to use a B&C alternator as a backup mounted on the vacuum pad of my engine. Has anyone used a B&C BC462-3H alternator. I am interested in confirming that it will fit on the back of the engine. As I will be using a 90 degree oil filter adapter I will also be using the required spacer. Cheers Les C-GCWZ Flying C-GROK Somewhat less assembly required Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478239#478239 ________________________________________________________________________________
Date: Feb 25, 2018
Subject: Re: Standby Alternator
Les, Call them or email B&C direct to check. Using their Oil Filter Adapter (needs a spacer to clear the engine mount) with either their old SD-20 or their current BC410H there was a requirement for a spacer on the alternator also. Bob On Sat, Feb 24, 2018 at 9:16 PM kearney wrote: > > Hi > > I am planning to use a B&C alternator as a backup mounted on the vacuum > pad of my engine. > > Has anyone used a B&C BC462-3H alternator. I am interested in confirming > that it will fit on the back of the engine. As I will be using a 90 degree > oil filter adapter I will also be using the required spacer. > > Cheers > > Les > > C-GCWZ Flying > C-GROK Somewhat less assembly required > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478239#478239 > > ________________________________________________________________________________
Date: Feb 25, 2018
Hi Bob I did speak to TJ at B&C yesterday. He was most helpful in deciding which alternator would be best for my application. He also spoke about the spacers. I just wanted to see if anyone else has done this and find out what, if any, issues they ran into. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478242#478242 ________________________________________________________________________________
Date: Feb 25, 2018
Are you using the Lycoming horizontal adapter? If so that alternator wont fit. However it will work with the B&C 90 degree adapter. Just check there sight or call them. They are very knowledgeable and helpful. I have the BC-410H on my 540 and it fits fine with the B&C 90 degree oil filter adapter. Robert Jones > On Feb 24, 2018, at 20:12, kearney wrote: > > > Hi > > I am planning to use a B&C alternator as a backup mounted on the vacuum pad of my engine. > > Has anyone used a B&C BC462-3H alternator. I am interested in confirming that it will fit on the back of the engine. As I will be using a 90 degree oil filter adapter I will also be using the required spacer. > > Cheers > > Les > > C-GCWZ Flying > C-GROK Somewhat less assembly required > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478239#478239 > > > > > > > > > ________________________________________________________________________________
Date: Feb 27, 2018
I had a 2.5 inch spacer for my oil filter adapter thinking that would clear space for the alternator but after getting the alternator spacing kit found out I neeeded to shorten the oil adaptor by half so had a machinist cut it down to fit. -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478303#478303 ________________________________________________________________________________
Date: Feb 27, 2018
Hi I spoke to B &C again after conforming which oil filter adapter my engine builder would be using - it is from B&C . Here is what I received from B&C via email: If memory serves, your IO-540 will be going in an RV-10; and with that in mind, here is what would be needed: BC700-H Oil Filter Adapter FK502-1.4 OFA Spacer Kit (1.4) BC462-3H Alternator FK710-1.25 Alternator Drive Extension/Spacer Kit (1.25) Regarding your questions: yes, there are indeed two spacers involved a 1.4 spacer for the BC700-H Oil Filter Adapter, so that it clears the RV-10 engine mount, and a 1.25 drive extension/spacer for the BC462-3H Alternator, so that it clears the Oil Filter Adapter. As I might have mentioned on the phone, the above makes for a tight installation but it should space everything out so that the interferences are negotiated. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478304#478304 ________________________________________________________________________________
Date: Feb 27, 2018
Sounds like youre getting exactly what you need. -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478305#478305 ________________________________________________________________________________
Date: Feb 27, 2018
Back in 2008, when I was trying to figure out how to fit the SD-20 alternator and the oil filter, I tried every combination I could find and could not make it work. I had more than one conversation with B&C. They were very helpful and even suggested I look at competitors oil filter spacers when we could not get the B&C to fit. I suspect that the alternator drive extension was not available back in those days. I ended up putting my oil filter on the firewall with the Airwolf system and have always been grateful that things worked out as they did. Oil changes are a breeze with the Airwolf remote oil filter. David Maib 40559 On Feb 27, 2018, at 9:23 PM, kearney wrote: Hi I spoke to B &C again after conforming which oil filter adapter my engine builder would be using - it is from B&C . Here is what I received from B&C via email: If memory serves, your IO-540 will be going in an RV-10; and with that in mind, here is what would be needed: BC700-H Oil Filter Adapter FK502-1.4 OFA Spacer Kit (1.4) BC462-3H Alternator FK710-1.25 Alternator Drive Extension/Spacer Kit (1.25) Regarding your questions: yes, there are indeed two spacers involved a 1.4 spacer for the BC700-H Oil Filter Adapter, so that it clears the RV-10 engine mount, and a 1.25 drive extension/spacer for the BC462-3H Alternator, so that it clears the Oil Filter Adapter. As I might have mentioned on the phone, the above makes for a tight installation but it should space everything out so that the interferences are negotiated. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478304#478304 ________________________________________________________________________________
Date: Mar 04, 2018
Subject: iPad mini
Just curious for those flying with an iPad Mini Where do you mount it and what mount do you use? Regards, Alan N668G Sent from my iPhone ________________________________________________________________________________
Subject: iPad mini
Date: Mar 04, 2018
Mine sits on the back seat most of the time. For a little while I mounted in on a the cabin cover support bar above the glareshield. It was on a short adapter that positioned it just above the intercom. In my case, it's a third backup for maps and charts. As such, I almost never use it in the air. bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> On Behalf Of Alan Mekler MD Sent: Sunday, March 4, 2018 3:48 PM Subject: RV10-List: iPad mini Just curious for those flying with an iPad Mini Where do you mount it and what mount do you use? Regards, Alan N668G Sent from my iPhone ________________________________________________________________________________
Date: Mar 04, 2018
Subject: Re: iPad mini
Im using it with the Avidyne ifd100 app with my Avidyne 440 Alan Sent from my iPhone > On Mar 4, 2018, at 4:05 PM, Bob Leffler wrote: > > > Mine sits on the back seat most of the time. > > For a little while I mounted in on a the cabin cover support bar above the glareshield. It was on a short adapter that positioned it just above the intercom. > > In my case, it's a third backup for maps and charts. As such, I almost never use it in the air. > > bob > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> On Behalf Of Alan Mekler MD > Sent: Sunday, March 4, 2018 3:48 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: iPad mini > > > Just curious for those flying with an iPad Mini Where do you mount it and what mount do you use? > Regards, > Alan > N668G > > Sent from my iPhone > > > > > > > ________________________________________________________________________________
Date: Mar 05, 2018
This is an old picture; th e 696 in the center was replaced by a mini some time ago. When the 696 was there, I used the mount you see on the left side wall for the mini. That ball is still there and I could just as easily use it but I never do. It=99s much handier in the center, especially when I fly w ith someone else who wants to use it. The center mount is a combo of a 6=9D arm and a 2=9D arm. It ha s a knuckle between them called a ball adapter. The iPad mounts in an X-Naut tray that has cooling fans, which is a necessity. =94Dave [image: JPEG image] Glass Panel.jpg On Sun, Mar 4, 2018 at 13:53 Alan Mekler MD wrote: > > Just curious for those flying with an iPad Mini > Where do you mount it > and what mount do you use? > Regards, > Alan > N668G > > Sent from my iPhone =========== =========== =========== =========== =========== > > ________________________________________________________________________________
From: Robert Brunkenhoefer <robertbrunk(at)mac.com>
Date: Mar 04, 2018
Done =9C=85 Sent from my iPhone > On Mar 4, 2018, at 7:54 PM, David Saylor wrote: > > This is an old picture; th e 696 in the center was replaced by a mini som e time ago. > > When the 696 was there, I used the mount you see on the left side wall for the mini. That ball is still there and I could just as easily use it but I never do. It=99s much handier in the center, especially when I fly w ith someone else who wants to use it. > > The center mount is a combo of a 6=9D arm and a 2=9D arm. It h as a knuckle between them called a ball adapter. The iPad mounts in an X-Nau t tray that has cooling fans, which is a necessity. > > =94Dave > Glass Panel.jpg > >> On Sun, Mar 4, 2018 at 13:53 Alan Mekler MD wrote : >> >> Just curious for those flying with an iPad Mini >> Where do you mount it >> and what mount do you use? >> Regards, >> Alan >> N668G >> >> Sent from my iPhone >> ========== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========== >> >> >> ________________________________________________________________________________
Date: Mar 05, 2018
I've got a kneeboard holder for my iPad mini, and can't imagine it anywhere else. Especially since I sometimes use it to jot down notes within Foreflight, or even as a hard back for writing notes on paper if I have to. And even with 3 EFIS screens in the cockpit, I've come to rely on it being there. Dan > On 2018-Mar-04, at 1:48 PM, Alan Mekler MD wrote: > > > Just curious for those flying with an iPad Mini > Where do you mount it > and what mount do you use? > Regards, > Alan > N668G > > Sent from my iPhone > > > --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Date: Mar 05, 2018
dan, thats what i do now just don=99t like all the head down movement to see it while imc. alan > On Mar 4, 2018, at 9:08 PM, Robert Brunkenhoefer wrote: > > Done =9C=85 > > Sent from my iPhone > > On Mar 4, 2018, at 7:54 PM, David Saylor > wrote: > >> This is an old picture; th e 696 in the center was replaced by a mini some time ago. >> >> When the 696 was there, I used the mount you see on the left side wall for the mini. That ball is still there and I could just as easily use it but I never do. It=99s much handier in the center, especially when I fly with someone else who wants to use it. >> >> The center mount is a combo of a 6=9D arm and a 2=9D arm. It has a knuckle between them called a ball adapter. The iPad mounts in an X-Naut tray that has cooling fans, which is a necessity. >> >> =94Dave >> Glass Panel.jpg >> >> >> On Sun, Mar 4, 2018 at 13:53 Alan Mekler MD > wrote: > >> >> Just curious for those flying with an iPad Mini >> Where do you mount it >> and what mount do you use? >> Regards, >> Alan >> N668G >> >> Sent from my iPhone >> ========== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List <http://www.matronics.com/Navigator?RV10-List> >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com <http://forums.matronics.com/> >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com <http://wiki.matronics.com/> >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution <http://www.matronics.com/contribution> >> ========== >> >> >> ________________________________________________________________________________
Date: Mar 05, 2018
Before the panel upgrade I mounted mine to the lower left of the windshield using a suction mount and the mygoflight suction mount: http://mgfproducts.com/sport-mount-flex-suction/ The flex arm is very well made, locks in position with a single twist lock. Super solid for 100hr or so of flying. After the upgrade (3 screen G3X) I'm not sure I'll mount it or use it, I suspect it will be relegated to the back seat / flight bag as a backup. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478390#478390 ________________________________________________________________________________
Date: Mar 05, 2018
Thanks Will take a look Being right handed it is Inconvenient to have it on the left side Alan Sent from my iPhone > On Mar 5, 2018, at 6:57 AM, tshort wrote: > > > Before the panel upgrade I mounted mine to the lower left of the windshield using a suction mount and the mygoflight suction mount: > > http://mgfproducts.com/sport-mount-flex-suction/ > > The flex arm is very well made, locks in position with a single twist lock. Super solid for 100hr or so of flying. > > After the upgrade (3 screen G3X) I'm not sure I'll mount it or use it, I suspect it will be relegated to the back seat / flight bag as a backup. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478390#478390 > > > > > > > > > ________________________________________________________________________________
Date: Mar 05, 2018
My reason for using a mini instead of a full size is that I can just lay it on my lap. When I want to look at it, I pick it up and hold it close to my line of sight to the EFIS. When vfr I usually just lay it on the center tunnel. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478406#478406 ________________________________________________________________________________
Subject: Aftermarket Rudder Pedals
Date: Mar 06, 2018
Hi Everyone knows that VANS makes a great kit. That being said, some of the kit components do seem like that they are ex the iron works of Mordor. IMHO, the rudder pedals and brake lines supplied as part of the VANS kit really don't do the -10 justice. In my flying -10, I installed Paul Grimstad's after market pedals.. I have been very happy with them. They really look like they "belong'". For my current project I went back to Paul and got his current pedal iteration. It is lighter and equally appropriate in a -10 fuse. For those interested, here is a link to his website: http://controlapproach.com/products/experimental-aircraft-products/rv10-rudder-pedal-system Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478432#478432 Attachments: http://forums.matronics.com//files/img_0144_108.jpg ________________________________________________________________________________
Date: Mar 06, 2018
Subject: Re: Aftermarket Rudder Pedals
I am most happy with my Control Approach pedals. Sure grip for feet. Sent from my IBM-360 main frame On Tue, Mar 6, 2018 at 7:28 PM, kearney wrote: > > Hi > > Everyone knows that VANS makes a great kit. That being said, some of the > kit components do seem like that they are ex the iron works of Mordor. > > IMHO, the rudder pedals and brake lines supplied as part of the VANS kit > really don't do the -10 justice. In my flying -10, I installed Paul > Grimstad's after market pedals.. I have been very happy with them. They > really look like they "belong'". > > For my current project I went back to Paul and got his current pedal > iteration. It is lighter and equally appropriate in a -10 fuse. > > For those interested, here is a link to his website: > http://controlapproach.com/products/experimental- > aircraft-products/rv10-rudder-pedal-system > > Cheers > > Les > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478432#478432 > > > Attachments: > > http://forums.matronics.com//files/img_0144_108.jpg > > ________________________________________________________________________________
Date: Mar 07, 2018
I'd agree. I've never found them aesthetically unpleasing and they work just fine. In my case I don't even have the extension and don't have a problem keeping off the brakes. Plus they do make those aftermarket rubber pedals with upper and lower push areas, if someone really has to have that. There are plenty of ways to spend extra thousands of dollars...but having just signed on to SiriusXM today, I'd rather spend it on 4 years of satellite wx. To each his own I guess. To those who ask why XM when ADS-B is free....ADS-B coverage sucks at low altitudes and you don't have it when you need it most. Tim On 3/7/2018 8:39 AM, Carl Froehlich wrote: > I find the stock rudder pedal setup works just fine - after I added a simple > extension to keep my toes off the brakes. I buddy of mine made these on his > milling machine. He still has the pattern if anyone is interested. > > $2000 will buy a lot of avgas. > > Carl ________________________________________________________________________________
Date: Mar 07, 2018
Re ADSB coverage: Tim, is that primarily a 'midwest' issue in your experience? I was previously a XM subscriber and definitely preferred their wx products but I'm getting ADSB coverage everywhere I'm looking for it on the east coast and the price remains right. Just wondering.... I painted my Vans pedals (the pads with the holes) in silver and they really look spiffy - like stainless. Didn't see that coming. Those aftermarkets look pretty spiffy as well. Bill "wondering if 1,000 hours marks the beginning of some kind of a 'things fail and wear-out' mode" Watson On 3/7/2018 10:00 AM, Tim Olson wrote: > > I'd agree. I've never found them aesthetically unpleasing and they work > just fine. In my case I don't even have the extension and don't have > a problem > keeping off the brakes. Plus they do make those aftermarket rubber > pedals > with upper and lower push areas, if someone really has to have that. > There are plenty of ways to spend extra thousands of dollars...but > having just > signed on to SiriusXM today, I'd rather spend it on 4 years of > satellite wx. > To each his own I guess. > > To those who ask why XM when ADS-B is free....ADS-B coverage sucks > at low altitudes and you don't have it when you need it most. > > Tim > > > On 3/7/2018 8:39 AM, Carl Froehlich wrote: >> I find the stock rudder pedal setup works just fine - after I added a >> simple >> extension to keep my toes off the brakes. I buddy of mine made these >> on his >> milling machine. He still has the pattern if anyone is interested. >> >> $2000 will buy a lot of avgas. >> >> Carl > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Mar 07, 2018
I have these pedals (photo attached). They work great, but still don =99t fix the sticking master cylinder issue. Just recently had some badly warped rotors because of dragging brakes. Saw someone put plastic Heyco bushings in the lightning holes of their stock pedals. It make it look really cool, and probably saves the powdercoating from wearing off. Lenny > On Mar 7, 2018, at 10:00 AM, Tim Olson wrote: > > > I'd agree. I've never found them aesthetically unpleasing and they work > just fine. In my case I don't even have the extension and don't have a problem > keeping off the brakes. Plus they do make those aftermarket rubber pedals > with upper and lower push areas, if someone really has to have that. > There are plenty of ways to spend extra thousands of dollars...but having just > signed on to SiriusXM today, I'd rather spend it on 4 years of satellite wx. > To each his own I guess. > > To those who ask why XM when ADS-B is free....ADS-B coverage sucks > at low altitudes and you don't have it when you need it most. > > Tim > > > On 3/7/2018 8:39 AM, Carl Froehlich wrote: >> I find the stock rudder pedal setup works just fine - after I added a simple >> extension to keep my toes off the brakes. I buddy of mine made these on his >> milling machine. He still has the pattern if anyone is interested. >> >> $2000 will buy a lot of avgas. >> >> Carl > > > > ________________________________________________________________________________
Date: Mar 07, 2018
I would say if you live on the East coast, you'll probably have it better than most people in the country. Certainly the coverage is better and the terrain is flatter. Where it really falls apart is in the center of the country and heading west, and in the mountains in areas too. It depends on what you're flight altitude is, and the season, especially. Like for instance, one spring trip around here, we had cold temps with icing conditions all over, but VFR underneath. The ceilings being 1200' or so. Well, that's fine if you have good viz underneath...no reason to cancel a trip to the tropics, or to not be able to get home. But, you will find that under 3000-3500' of altitude the coverage is horrible in much of the country. Maybe it's summertime and there are thunderstorms and clouds...I never want to fly instruments when there are lots of thunderstorms all in my path, so I'll duck under where I can stay VFR and make decisions on the conditions and do lots of deviations. That doesn't play well always either with the altitude restrictions of ADS-B. Even by my own airport and flying to the local town that is 80,000+ people and one of the only bigger cities in our part of the state, we have to be at 3,000-3500' before we get any weather info. In the rainy periods of the year, this makes it again impossible to have the data you need to avoid storm cells and make decisions that may give you a good route to your destination. When I took the plane to idaho with ADS-B only, we had <2000' ceilings just east of the rockies in Wyoming....with great clear skies under the overcast. No weather info to be had, which means no current wind info for your possible fuel stops. So what I find is, if you are flying something heavier that you are always going to fly high, and cruise at maybe 8,000-16,000', sure, FIS-B will probably work for you if you don't care about the weather picture when you're on the ground. But for any serious x/c travel, if you are NOT interested in getting into icing, and NOT interested in flying inside clouds with embeded thunderstorms anywhere nearby, or you need to fly at 1,000-3,000' for avoiding turbulence or weather, you will be lacking all of the data you need to do it safely. I distinctly remember a flight home from OSH in the Sundowner years ago, started at 7,000 IFR, but with big black clouds to the North, ended cancelling and going lower to get home VFR. I had no weather data, and no fuel totalizer, and had an extended taxi at OSH. I felt completely at a loss for information and had to divert and stop and sit on the ground until I could get good weather data. As it turned out, if I'd have had a fuel totalizer, and any kind of in-cockpit weather, I would have known my fuel situation was "plenty" and a 10 minute diversion could have put me on the back side in completely clear skies, where I'd have been able to get home. In fact, by phone, people at home told me there wasn't a cloud in the sky...I just needed to take the right route. FIS-B is a big letdown of coverage. If the feds DOUBLED the number of uplinks, I'd say it may finally just be good enough. The way it is now, I think they should have skipped FIS-B altogether and just given a free base package of satellite weather to every pilot, with Nexrad, metars, and TAF's and TFR's. Then let them buy additional. At least in my past 1500 hours in the RV's now, I can say that satellite wx was one of the biggest things that enabled successful trips, and is probably the last piece of technology I'd want to remove from the plane, even as far as the EFIS goes. I'll fly a six-pack if I have to, but you have to pry the weather data from my hands. Tim On 3/7/2018 10:02 AM, Bill Watson wrote: > > Re ADSB coverage: Tim, is that primarily a 'midwest' issue in your > experience? I was previously a XM subscriber and definitely > preferred their wx products but I'm getting ADSB coverage everywhere > I'm looking for it on the east coast and the price remains right. > Just wondering.... > > I painted my Vans pedals (the pads with the holes) in silver and they > really look spiffy - like stainless. Didn't see that coming. Those > aftermarkets look pretty spiffy as well. > > Bill "wondering if 1,000 hours marks the beginning of some kind of > a 'things fail and wear-out' mode" Watson ________________________________________________________________________________
Date: Mar 07, 2018
I'm curious, how are those pedals balanced as far as a tendency to tip forward or aft? Not being critical at all, just wondering. I know that when I added the pedal blocks to mine for the girls, I set them up and they actually are weighted so that they would help to retract the pedal. I also remember people in the past adding return springs to the master cylinder. (is that what I see by the hose on the picture?) Is it possible that the weighting of the pedal maybe assisted in adding to the brake drag? Just thinking out loud. If that were true, maybe a slight change in the position of the lower pad could make a difference. I've not run into problems with the stock setup, but I know people who have, and I've always been curious as to what would be so different. I know that a few people have gone to a singe long hinge bolt, and I know that over tightening the bolts can really be a big problem. But other that that I can't find any serious flaws in the stock system. Van's did improve the pedal itself in the RV-14 kit, so for new builders, you may want to swap parts for the actual metal pedal itself. from the -14. Everything else is the same. Tim On 3/7/2018 10:10 AM, Lenny Iszak wrote: > I have these pedals (photo attached). They work great, but still dont > fix the sticking master cylinder issue. Just recently had some badly > warped rotors because of dragging brakes. > > Saw someone put plastic Heyco bushings in the lightning holes of their > stock pedals. It make it look really cool, and probably saves the > powdercoating from wearing off. > > Lenny > > ________________________________________________________________________________
Date: Mar 07, 2018
The pedal geometry is exactly the same as stock. I havent checked their balance but thats a good point. I did add return springs and they seem to be helping, but Im going to switch them out to clock springs, cause according to Matco the current ones are eventually going to wear out the master cylinder shaft. Lenny > On Mar 7, 2018, at 11:34 AM, Tim Olson wrote: > > I'm curious, how are those pedals balanced as far as a tendency to tip forward or aft? > Not being critical at all, just wondering. I know that when I added the pedal blocks > to mine for the girls, I set them up and they actually are weighted so that they would > help to retract the pedal. I also remember people in the past adding return springs > to the master cylinder. (is that what I see by the hose on the picture?) > Is it possible that the weighting of the pedal maybe assisted in adding to the > brake drag? Just thinking out loud. If that were true, maybe a slight change in the > position of the lower pad could make a difference. > > I've not run into problems with the stock setup, but I know people who have, > and I've always been curious as to what would be so different. I know that > a few people have gone to a singe long hinge bolt, and I know that over tightening > the bolts can really be a big problem. But other that that I can't find any > serious flaws in the stock system. Van's did improve the pedal itself in the > RV-14 kit, so for new builders, you may want to swap parts for the > actual metal pedal itself. from the -14. Everything else is the same. > Tim > > > > > On 3/7/2018 10:10 AM, Lenny Iszak wrote: >> I have these pedals (photo attached). They work great, but still dont fix the sticking master cylinder issue. Just recently had some badly warped rotors because of dragging brakes. >> >> Saw someone put plastic Heyco bushings in the lightning holes of their stock pedals. It make it look really cool, and probably saves the powdercoating from wearing off. >> >> Lenny >> >> >> > ________________________________________________________________________________
Date: Mar 07, 2018
I wholeheartedly agree with Tims assessment. XM WX on my 396 is a permanent fixture in my 10 with the ADS-B WX the backup! grumpy > On Mar 7, 2018, at 10:26 AM, Tim Olson wrote: > > > I would say if you live on the East coast, you'll probably have it better than most people in the country. > Certainly the coverage is better and the terrain is flatter. Where it really falls apart is > in the center of the country and heading west, and in the mountains in areas too. > It depends on what you're flight altitude is, and the season, especially. > Like for instance, one spring trip around here, we had cold temps with icing conditions > all over, but VFR underneath. The ceilings being 1200' or so. Well, that's fine if > you have good viz underneath...no reason to cancel a trip to the tropics, or to not > be able to get home. But, you will find that under 3000-3500' of altitude the > coverage is horrible in much of the country. Maybe it's summertime and there > are thunderstorms and clouds...I never want to fly instruments when there are > lots of thunderstorms all in my path, so I'll duck under where I can stay VFR and > make decisions on the conditions and do lots of deviations. That doesn't play > well always either with the altitude restrictions of ADS-B. Even by my own airport > and flying to the local town that is 80,000+ people and one of the only bigger > cities in our part of the state, we have to be at 3,000-3500' before we get any > weather info. In the rainy periods of the year, this makes it again impossible to > have the data you need to avoid storm cells and make decisions that may give > you a good route to your destination. When I took the plane to idaho with ADS-B > only, we had <2000' ceilings just east of the rockies in Wyoming....with great > clear skies under the overcast. No weather info to be had, which means no > current wind info for your possible fuel stops. > > So what I find is, if you are flying something heavier that you are always going to > fly high, and cruise at maybe 8,000-16,000', sure, FIS-B will probably work for you > if you don't care about the weather picture when you're on the ground. > But for any serious x/c travel, if you are NOT interested in getting into icing, > and NOT interested in flying inside clouds with embeded thunderstorms > anywhere nearby, or you need to fly at 1,000-3,000' for avoiding turbulence > or weather, you will be lacking all of the data you need to do it safely. > > I distinctly remember a flight home from OSH in the Sundowner years ago, > started at 7,000 IFR, but with big black clouds to the North, ended cancelling > and going lower to get home VFR. I had no weather data, and no fuel totalizer, > and had an extended taxi at OSH. I felt completely at a loss for information and > had to divert and stop and sit on the ground until I could get good weather > data. As it turned out, if I'd have had a fuel totalizer, and any kind of in-cockpit > weather, I would have known my fuel situation was "plenty" and a 10 minute > diversion could have put me on the back side in completely clear skies, where > I'd have been able to get home. In fact, by phone, people at home told me > there wasn't a cloud in the sky...I just needed to take the right route. > > FIS-B is a big letdown of coverage. If the feds DOUBLED the number of > uplinks, I'd say it may finally just be good enough. The way it is now, > I think they should have skipped FIS-B altogether and just given a free > base package of satellite weather to every pilot, with Nexrad, metars, > and TAF's and TFR's. Then let them buy additional. > > At least in my past 1500 hours in the RV's now, I can say that satellite wx > was one of the biggest things that enabled successful trips, and is probably the > last piece of technology I'd want to remove from the plane, even as > far as the EFIS goes. I'll fly a six-pack if I have to, but you have to pry > the weather data from my hands. > > Tim > > > On 3/7/2018 10:02 AM, Bill Watson wrote: >> >> Re ADSB coverage: Tim, is that primarily a 'midwest' issue in your experience? I was previously a XM subscriber and definitely preferred their wx products but I'm getting ADSB coverage everywhere I'm looking for it on the east coast and the price remains right. Just wondering.... >> >> I painted my Vans pedals (the pads with the holes) in silver and they really look spiffy - like stainless. Didn't see that coming. Those aftermarkets look pretty spiffy as well. >> >> Bill "wondering if 1,000 hours marks the beginning of some kind of a 'things fail and wear-out' mode" Watson > > > > ________________________________________________________________________________
Date: Mar 07, 2018
Yes, that sounds different that what I normally encounter in the east and southeast. I can get ADSB weather practically down to the ground, or at least as close to the ground as I normally find myself looking for wx info. A couple of years ago I had an odd situation where I could take off from my home field (8NC8) and fly to KTTA, passing by KRDU, and would not get any ADSB data until very short final at KTTA. However, taking off from KTTA and flying home, I would have ADSB data all the way back. Sometimes rec'ng ADSB data on the ground at 8NC8. Power down and then back up - no ADSB. Navworx worked with me (!!!) to try and fix it. We concluded it was an ADSB 'network' problem and sure enough, full service appeared magically a few months later. (Yes, I'm still runnning Navworx with the AMOC successfully) Otherwise, flying underneath a low ceiling to avoid ice is not common solution in the SE, at least for me. But I do plenty of flying under the icy overcast out of KAGC (Pittsburgh) and I consistently get ADSB at 1500' AGL when needed. Same with T-storms. Normally flying above cloud base, which often between 4 and 6k, is enough to allow convective storm avoidance via the requested deviation. Only rarely do I run into situations where getting underneath is preferable. Surface 'bumpiness', i.e. hills and antenna make me think twice about it anyway. As a wise and experienced aviator said recently, "At least in my past 1500 hours in the RV's now, I can say that satellite wx was one of the biggest things that enabled successful trips, and is probably the last piece of technology I'd want to remove from the plane, even as far as the EFIS goes. I'll fly a six-pack if I have to, but you have to pry the weather data from my hands." Indeed. It has been that way for me since I first laid eyes on Nexrad imagery in the cockpit using CheapBastard software on the communicating Palm Pilot (anyone else here ever use it?). Then the 396 came out with XM and my little Maule with its 6-pack felt like a EA6 Prowler bristling with antennas. In fact for that first year or so with the 396 it was great fun to mix it up with jet traffic that would be holding outside say KJAX because of a line of thunder-bumpers while I snaked my way in behind it. They had radar, but I could see around corners. Five minutes later it seemed like everyone had a 396 in the bag - radar capable or not. On 3/7/2018 11:26 AM, Tim Olson wrote: > > I would say if you live on the East coast, you'll probably have it > better than most people in the country. > Certainly the coverage is better and the terrain is flatter. Where it > really falls apart is > in the center of the country and heading west, and in the mountains in > areas too. > It depends on what you're flight altitude is, and the season, especially. > Like for instance, one spring trip around here, we had cold temps with > icing conditions > all over, but VFR underneath. The ceilings being 1200' or so. Well, > that's fine if > you have good viz underneath...no reason to cancel a trip to the > tropics, or to not > be able to get home. But, you will find that under 3000-3500' of > altitude the > coverage is horrible in much of the country. Maybe it's summertime > and there > are thunderstorms and clouds...I never want to fly instruments when > there are > lots of thunderstorms all in my path, so I'll duck under where I can > stay VFR and > make decisions on the conditions and do lots of deviations. That > doesn't play > well always either with the altitude restrictions of ADS-B. Even by > my own airport > and flying to the local town that is 80,000+ people and one of the > only bigger > cities in our part of the state, we have to be at 3,000-3500' before > we get any > weather info. In the rainy periods of the year, this makes it again > impossible to > have the data you need to avoid storm cells and make decisions that > may give > you a good route to your destination. When I took the plane to idaho > with ADS-B > only, we had <2000' ceilings just east of the rockies in > Wyoming....with great > clear skies under the overcast. No weather info to be had, which > means no > current wind info for your possible fuel stops. > > So what I find is, if you are flying something heavier that you are > always going to > fly high, and cruise at maybe 8,000-16,000', sure, FIS-B will probably > work for you > if you don't care about the weather picture when you're on the ground. > But for any serious x/c travel, if you are NOT interested in getting > into icing, > and NOT interested in flying inside clouds with embeded thunderstorms > anywhere nearby, or you need to fly at 1,000-3,000' for avoiding > turbulence > or weather, you will be lacking all of the data you need to do it safely. > > I distinctly remember a flight home from OSH in the Sundowner years ago, > started at 7,000 IFR, but with big black clouds to the North, ended > cancelling > and going lower to get home VFR. I had no weather data, and no fuel > totalizer, > and had an extended taxi at OSH. I felt completely at a loss for > information and > had to divert and stop and sit on the ground until I could get good > weather > data. As it turned out, if I'd have had a fuel totalizer, and any > kind of in-cockpit > weather, I would have known my fuel situation was "plenty" and a 10 > minute > diversion could have put me on the back side in completely clear > skies, where > I'd have been able to get home. In fact, by phone, people at home > told me > there wasn't a cloud in the sky...I just needed to take the right route. > > FIS-B is a big letdown of coverage. If the feds DOUBLED the number of > uplinks, I'd say it may finally just be good enough. The way it is now, > I think they should have skipped FIS-B altogether and just given a free > base package of satellite weather to every pilot, with Nexrad, metars, > and TAF's and TFR's. Then let them buy additional. > > At least in my past 1500 hours in the RV's now, I can say that > satellite wx > was one of the biggest things that enabled successful trips, and is > probably the > last piece of technology I'd want to remove from the plane, even as > far as the EFIS goes. I'll fly a six-pack if I have to, but you have > to pry > the weather data from my hands. > > Tim > > > On 3/7/2018 10:02 AM, Bill Watson wrote: >> >> Re ADSB coverage: Tim, is that primarily a 'midwest' issue in your >> experience? I was previously a XM subscriber and definitely >> preferred their wx products but I'm getting ADSB coverage everywhere >> I'm looking for it on the east coast and the price remains right. >> Just wondering.... >> >> I painted my Vans pedals (the pads with the holes) in silver and >> they really look spiffy - like stainless. Didn't see that coming. >> Those aftermarkets look pretty spiffy as well. >> >> Bill "wondering if 1,000 hours marks the beginning of some kind of >> a 'things fail and wear-out' mode" Watson > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Mar 07, 2018
...and if you are low enough 4G LTE works too. -Chris N919AR -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson Sent: Wednesday, March 07, 2018 3:55 PM Subject: Re: RV10-List: Aftermarket Rudder Pedals Yes, that sounds different that what I normally encounter in the east and southeast. I can get ADSB weather practically down to the ground, or at least as close to the ground as I normally find myself looking for wx info. A couple of years ago I had an odd situation where I could take off from my home field (8NC8) and fly to KTTA, passing by KRDU, and would not get any ADSB data until very short final at KTTA. However, taking off from KTTA and flying home, I would have ADSB data all the way back. Sometimes rec'ng ADSB data on the ground at 8NC8. Power down and then back up - no ADSB. Navworx worked with me (!!!) to try and fix it. We concluded it was an ADSB 'network' problem and sure enough, full service appeared magically a few months later. (Yes, I'm still runnning Navworx with the AMOC successfully) Otherwise, flying underneath a low ceiling to avoid ice is not common solution in the SE, at least for me. But I do plenty of flying under the icy overcast out of KAGC (Pittsburgh) and I consistently get ADSB at 1500' AGL when needed. Same with T-storms. Normally flying above cloud base, which often between 4 and 6k, is enough to allow convective storm avoidance via the requested deviation. Only rarely do I run into situations where getting underneath is preferable. Surface 'bumpiness', i.e. hills and antenna make me think twice about it anyway. As a wise and experienced aviator said recently, "At least in my past 1500 hours in the RV's now, I can say that satellite wx was one of the biggest things that enabled successful trips, and is probably the last piece of technology I'd want to remove from the plane, even as far as the EFIS goes. I'll fly a six-pack if I have to, but you have to pry the weather data from my hands." Indeed. It has been that way for me since I first laid eyes on Nexrad imagery in the cockpit using CheapBastard software on the communicating Palm Pilot (anyone else here ever use it?). Then the 396 came out with XM and my little Maule with its 6-pack felt like a EA6 Prowler bristling with antennas. In fact for that first year or so with the 396 it was great fun to mix it up with jet traffic that would be holding outside say KJAX because of a line of thunder-bumpers while I snaked my way in behind it. They had radar, but I could see around corners. Five minutes later it seemed like everyone had a 396 in the bag - radar capable or not. On 3/7/2018 11:26 AM, Tim Olson wrote: > > I would say if you live on the East coast, you'll probably have it > better than most people in the country. > Certainly the coverage is better and the terrain is flatter. Where it > really falls apart is in the center of the country and heading west, > and in the mountains in areas too. > It depends on what you're flight altitude is, and the season, especially. > Like for instance, one spring trip around here, we had cold temps with > icing conditions all over, but VFR underneath. The ceilings being > 1200' or so. Well, that's fine if you have good viz underneath...no > reason to cancel a trip to the tropics, or to not be able to get home. > But, you will find that under 3000-3500' of altitude the coverage is > horrible in much of the country. Maybe it's summertime and there are > thunderstorms and clouds...I never want to fly instruments when there > are lots of thunderstorms all in my path, so I'll duck under where I > can stay VFR and make decisions on the conditions and do lots of > deviations. That doesn't play well always either with the altitude > restrictions of ADS-B. Even by my own airport and flying to the local > town that is 80,000+ people and one of the only bigger cities in our > part of the state, we have to be at 3,000-3500' before we get any > weather info. In the rainy periods of the year, this makes it again > impossible to have the data you need to avoid storm cells and make > decisions that may give you a good route to your destination. When I > took the plane to idaho with ADS-B only, we had <2000' ceilings just > east of the rockies in Wyoming....with great clear skies under the > overcast. No weather info to be had, which means no current wind info > for your possible fuel stops. > > So what I find is, if you are flying something heavier that you are > always going to fly high, and cruise at maybe 8,000-16,000', sure, > FIS-B will probably work for you if you don't care about the weather > picture when you're on the ground. > But for any serious x/c travel, if you are NOT interested in getting > into icing, and NOT interested in flying inside clouds with embeded > thunderstorms anywhere nearby, or you need to fly at 1,000-3,000' for > avoiding turbulence or weather, you will be lacking all of the data > you need to do it safely. > > I distinctly remember a flight home from OSH in the Sundowner years > ago, started at 7,000 IFR, but with big black clouds to the North, > ended cancelling and going lower to get home VFR. I had no weather > data, and no fuel totalizer, and had an extended taxi at OSH. I felt > completely at a loss for information and had to divert and stop and > sit on the ground until I could get good weather data. As it turned > out, if I'd have had a fuel totalizer, and any kind of in-cockpit > weather, I would have known my fuel situation was "plenty" and a 10 > minute diversion could have put me on the back side in completely > clear skies, where I'd have been able to get home. In fact, by phone, > people at home told me there wasn't a cloud in the sky...I just needed > to take the right route. > > FIS-B is a big letdown of coverage. If the feds DOUBLED the number of > uplinks, I'd say it may finally just be good enough. The way it is > now, I think they should have skipped FIS-B altogether and just given > a free base package of satellite weather to every pilot, with Nexrad, > metars, and TAF's and TFR's. Then let them buy additional. > > At least in my past 1500 hours in the RV's now, I can say that > satellite wx was one of the biggest things that enabled successful > trips, and is probably the last piece of technology I'd want to remove > from the plane, even as far as the EFIS goes. I'll fly a six-pack if > I have to, but you have to pry the weather data from my hands. > > Tim > > > On 3/7/2018 10:02 AM, Bill Watson wrote: >> >> Re ADSB coverage: Tim, is that primarily a 'midwest' issue in your >> experience? I was previously a XM subscriber and definitely >> preferred their wx products but I'm getting ADSB coverage everywhere >> I'm looking for it on the east coast and the price remains right. >> Just wondering.... >> >> I painted my Vans pedals (the pads with the holes) in silver and >> they really look spiffy - like stainless. Didn't see that coming. >> Those aftermarkets look pretty spiffy as well. >> >> Bill "wondering if 1,000 hours marks the beginning of some kind of >> a 'things fail and wear-out' mode" Watson > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Mar 07, 2018
Very true. I find to be reliable in my area thats 1000-1500 max, but I think when the day come that we can all get in cockpit internet access cheaply, that will finally negate the need for all of this other satellite and FIS-B stuff. It cant come soon enough. Tim > On Mar 7, 2018, at 3:45 PM, Chris wrote: > > > ...and if you are low enough 4G LTE works too. > -Chris > N919AR > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson > Sent: Wednesday, March 07, 2018 3:55 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Aftermarket Rudder Pedals > > > Yes, that sounds different that what I normally encounter in the east and > southeast. > > I can get ADSB weather practically down to the ground, or at least as close > to the ground as I normally find myself looking for wx info. A couple of > years ago I had an odd situation where I could take off from my home field > (8NC8) and fly to KTTA, passing by KRDU, and would not get any ADSB data > until very short final at KTTA. However, taking off from KTTA and flying > home, I would have ADSB data all the way back. Sometimes rec'ng ADSB data on > the ground at 8NC8. Power down and then back up - no ADSB. Navworx worked > with me (!!!) to try and fix it. We concluded it was an ADSB 'network' > problem and sure enough, full service appeared magically a few months > later. (Yes, I'm still runnning Navworx with the AMOC successfully) > > Otherwise, flying underneath a low ceiling to avoid ice is not common > solution in the SE, at least for me. But I do plenty of flying under the > icy overcast out of KAGC (Pittsburgh) and I consistently get ADSB at 1500' > AGL when needed. Same with T-storms. Normally flying above cloud base, > which often between 4 and 6k, is enough to allow convective storm avoidance > via the requested deviation. Only rarely do I run into situations where > getting underneath is preferable. Surface 'bumpiness', i.e. hills and > antenna make me think twice about it anyway. > > As a wise and experienced aviator said recently, "At least in my past > 1500 hours in the RV's now, I can say that satellite wx was one of the > biggest things that enabled successful trips, and is probably the last piece > of technology I'd want to remove from the plane, even as far as the EFIS > goes. I'll fly a six-pack if I have to, but you have to pry the weather > data from my hands." Indeed. > > It has been that way for me since I first laid eyes on Nexrad imagery in the > cockpit using CheapBastard software on the communicating Palm Pilot (anyone > else here ever use it?). Then the 396 came out with XM and my little Maule > with its 6-pack felt like a EA6 Prowler bristling with antennas. In fact > for that first year or so with the 396 it was great fun to mix it up with > jet traffic that would be holding outside say KJAX because of a line of > thunder-bumpers while I snaked my way in behind it. They had radar, but I > could see around corners. > > Five minutes later it seemed like everyone had a 396 in the bag - radar > capable or not. > >> On 3/7/2018 11:26 AM, Tim Olson wrote: >> >> I would say if you live on the East coast, you'll probably have it >> better than most people in the country. >> Certainly the coverage is better and the terrain is flatter. Where it >> really falls apart is in the center of the country and heading west, >> and in the mountains in areas too. >> It depends on what you're flight altitude is, and the season, especially. >> Like for instance, one spring trip around here, we had cold temps with >> icing conditions all over, but VFR underneath. The ceilings being >> 1200' or so. Well, that's fine if you have good viz underneath...no >> reason to cancel a trip to the tropics, or to not be able to get home. >> But, you will find that under 3000-3500' of altitude the coverage is >> horrible in much of the country. Maybe it's summertime and there are >> thunderstorms and clouds...I never want to fly instruments when there >> are lots of thunderstorms all in my path, so I'll duck under where I >> can stay VFR and make decisions on the conditions and do lots of >> deviations. That doesn't play well always either with the altitude >> restrictions of ADS-B. Even by my own airport and flying to the local >> town that is 80,000+ people and one of the only bigger cities in our >> part of the state, we have to be at 3,000-3500' before we get any >> weather info. In the rainy periods of the year, this makes it again >> impossible to have the data you need to avoid storm cells and make >> decisions that may give you a good route to your destination. When I >> took the plane to idaho with ADS-B only, we had <2000' ceilings just >> east of the rockies in Wyoming....with great clear skies under the >> overcast. No weather info to be had, which means no current wind info >> for your possible fuel stops. >> >> So what I find is, if you are flying something heavier that you are >> always going to fly high, and cruise at maybe 8,000-16,000', sure, >> FIS-B will probably work for you if you don't care about the weather >> picture when you're on the ground. >> But for any serious x/c travel, if you are NOT interested in getting >> into icing, and NOT interested in flying inside clouds with embeded >> thunderstorms anywhere nearby, or you need to fly at 1,000-3,000' for >> avoiding turbulence or weather, you will be lacking all of the data >> you need to do it safely. >> >> I distinctly remember a flight home from OSH in the Sundowner years >> ago, started at 7,000 IFR, but with big black clouds to the North, >> ended cancelling and going lower to get home VFR. I had no weather >> data, and no fuel totalizer, and had an extended taxi at OSH. I felt >> completely at a loss for information and had to divert and stop and >> sit on the ground until I could get good weather data. As it turned >> out, if I'd have had a fuel totalizer, and any kind of in-cockpit >> weather, I would have known my fuel situation was "plenty" and a 10 >> minute diversion could have put me on the back side in completely >> clear skies, where I'd have been able to get home. In fact, by phone, >> people at home told me there wasn't a cloud in the sky...I just needed >> to take the right route. >> >> FIS-B is a big letdown of coverage. If the feds DOUBLED the number of >> uplinks, I'd say it may finally just be good enough. The way it is >> now, I think they should have skipped FIS-B altogether and just given >> a free base package of satellite weather to every pilot, with Nexrad, >> metars, and TAF's and TFR's. Then let them buy additional. >> >> At least in my past 1500 hours in the RV's now, I can say that >> satellite wx was one of the biggest things that enabled successful >> trips, and is probably the last piece of technology I'd want to remove >> from the plane, even as far as the EFIS goes. I'll fly a six-pack if >> I have to, but you have to pry the weather data from my hands. >> >> Tim >> >> >>> On 3/7/2018 10:02 AM, Bill Watson wrote: >>> >>> Re ADSB coverage: Tim, is that primarily a 'midwest' issue in your >>> experience? I was previously a XM subscriber and definitely >>> preferred their wx products but I'm getting ADSB coverage everywhere >>> I'm looking for it on the east coast and the price remains right. >>> Just wondering.... >>> >>> I painted my Vans pedals (the pads with the holes) in silver and >>> they really look spiffy - like stainless. Didn't see that coming. >>> Those aftermarkets look pretty spiffy as well. >>> >>> Bill "wondering if 1,000 hours marks the beginning of some kind of >>> a 'things fail and wear-out' mode" Watson >> >> >> >> >> > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > > > > > > > ________________________________________________________________________________
Date: Mar 08, 2018
Sorry for the thread drift... Am I the only one who has gotten the dreaded Refresh signal needed from XM? The radio boots up on channel 1 with the message, and is otherwise useless until you get XM to send the signal. We have XM in the airplane, cars, home. Different model receivers. It has happened to all of them at one time or another. Happened so often that I have the specific XM web site page bookmarked in the iPad. And then, it happened to the XM wx receiver when I really wanted it - crossing AZ VFR but with scattered lines of thunderstorms. I probably over reacted, but I was so angry that when I got home I bought an ADSB-in box and cancelled XM wx. So far, Im happy. Locally I seldom fly any distance under 3,000 (the terain doesnt allow it) and ADSB-in coverage seems good. If I frequently flew in the flatlands I might have a different opinion. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478510#478510 ________________________________________________________________________________
Date: Mar 10, 2018
I originally wanted Paul's setup; it looks really nice. Problem was, he stopped making them. I kept in touch for as long a I could wait but finally ended up with the stock system...not flying yet but they should work fine... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478554#478554 ________________________________________________________________________________
Date: Mar 19, 2018
Subject: Cowl heat protection
Hi list, What are you doing to protect the cowling from the exhaust heat? Is it working well? Pictures would be very welcome. Thanks, David ________________________________________________________________________________
Subject: Re: Cowl heat protection
Date: Mar 19, 2018
I just bought the sheets of aluminum foil self stick from Van's and covered the bottom inside of the cowl with it. It works well. I ended up with a cracked exhaust last week and it protected the cowl even from that to some degree and I have no damage. I know I have pictures on my RV10 page of when I did that plane, but it's really nothing much. Just paint a layer of resin on the inside of the cowl bottom to seal it, then peel the backing off the aluminum foil and stick it on. Van's will have you put some on where the exhaust is close, but it's best to just cover the entire cowl bottom to within a couple inches of each edge. Tim On 03/19/2018 02:02 PM, David Carr wrote: > Hi list, > > What are you doing to protect the cowling from the exhaust heat? Is it > working well? Pictures would be very welcome. > > Thanks, > David ________________________________________________________________________________
Date: Mar 19, 2018
I glued this to most of the bottom cowling with RTV: THERMO-TEC ALUMINIZED HEAT BARRIER 18"X20" http://www.aircraftspruce.com/catalog/eppages/alumheatbarrierstops.php?clickkey=75929 Also used these clamp-on exhaust shields in a couple of places where the exhaust pipes get closer to the cowling: DOUBLE EXHAUST HEAT SHIELD http://www.aircraftspruce.com/catalog/eppages/exaustheatedshield.php?clickkey=7730 Lenny > On Mar 19, 2018, at 3:02 PM, David Carr wrote: > > Hi list, > > What are you doing to protect the cowling from the exhaust heat? Is it working well? Pictures would be very welcome. > > Thanks, > David ________________________________________________________________________________
Date: Mar 19, 2018
Subject: Double Emails?
Anyone else getting double emails from all the matronics lists or is it just me? -Sean #40303 NO NOT ARCHIVE ________________________________________________________________________________
Date: Mar 19, 2018
Not me....... Rene' -----Original Message----- From: owner-rv10-list-server(at)matronics.com On Behalf Of Sean Stephens Sent: Monday, March 19, 2018 7:53 PM Subject: RV10-List: Double Emails? Anyone else getting double emails from all the matronics lists or is it just me? -Sean #40303 NO NOT ARCHIVE ________________________________________________________________________________
Date: Mar 19, 2018
Subject: Re: Double Emails?
Not me. Not me. (Sorry, couldn't resist.) Tim > On Mar 19, 2018, at 8:53 PM, Sean Stephens wrote: > > > Anyone else getting double emails from all the matronics lists or is it just me? > > -Sean #40303 > > NO NOT ARCHIVE > > > ________________________________________________________________________________
Date: Mar 20, 2018
LOL. Got that 8 times. :) > Tim Olson > Monday, March 19, 2018 9:11 PM > > Not me. > Not me. > (Sorry, couldn't resist.) > > Tim > > ________________________________________________________________________________
Date: Mar 20, 2018
Here's what I did after allowing heat to damage my cowling. The bad news is that I had to repair the cowling's inside surface and structure (scarfing, cloth, honeycomb). The good news is that I had a real good indication of where the heat problem was. I have flown 2 years since then with no additional damage or concern. I used red RTV to adhere the pieces of foil faced insulation - probably the same stuff Tim used but not sure. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Mar 21, 2018
Subject: Re: RV10-List Digest: 1 Msgs - 03/20/18
Use red RTV on the edges of the aluminum foil; I had to grind /sand out all of the RTV on the original heat protection from 10 years ago. Put the sticky back aluminum in place and use 3M blue tape to create a seam of RTV along its edges. Then pull the tape and find a nice bead of RTV holding your heat protection in place. I will be removing the cowl of the aircraft Friday so may be able to get a picture. If so , I will send Virus-free. www.avast.com <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> On Tue, Mar 20, 2018 at 11:42 PM, RV10-List Digest Server < rv10-list(at)matronics.com> wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV10-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV10-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style > 82701&View=html&Chapter 18-03-20&Archive=RV10 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style > 82701&View=txt&Chapter 18-03-20&Archive=RV10 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV10-List Digest Archive > --- > Total Messages Posted Tue 03/20/18: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 03:30 PM - Re: Cowl heat protection (Bill Watson) > > > ________________________________ Message 1 > _____________________________________ > > > Subject: Re: RV10-List: Cowl heat protection > From: Bill Watson <Mauledriver(at)nc.rr.com> > > Here's what I did after allowing heat to damage my cowling. The bad > news is that I had to repair the cowling's inside surface and structure > (scarfing, cloth, honeycomb). The good news is that I had a real good > indication of where the heat problem was. I have flown 2 years since > then with no additional damage or concern. I used red RTV to adhere > the pieces of foil faced insulation - probably the same stuff Tim used > but not sure. > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > ________________________________________________________________________________
Date: Mar 21, 2018
Stick on reflective heat shield from acs -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478769#478769 Attachments: http://forums.matronics.com//files/img_2646_182.jpg ________________________________________________________________________________
Date: Mar 23, 2018
Not surprised. I used visible heat damage (from structural composite damage to singed paint) to guide my coverage. There may be more going on than simply proximity of exhaust system parts to cowling. I guess the 'safer' but slightly heavier approach would be to cover it all as Tim suggested. On 3/20/2018 9:49 PM, Don McDonald wrote: > I took a pencil and marked the areas that were fairly close to any > exhaust pipe (with the bottom cowl on). It looks like your area > covered is smaller than mine.... just sayin'. > > wrote: > > > Here's what I did after allowing heat to damage my cowling. The bad > news is that I had to repair the cowling's inside surface and structure > (scarfing, cloth, honeycomb). The good news is that I had a real good > indication of where the heat problem was. I have flown 2 years since > then with no additional damage or concern. I used red RTV to adhere > the pieces of foil faced insulation - probably the same stuff Tim used > but not sure. > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus ________________________________________________________________________________
Date: Mar 24, 2018
I want to say thanks for all of the heat protection advice. This is a great group we have here. David On Fri, Mar 23, 2018 at 5:47 AM, Bill Watson wrote: > > Not surprised. I used visible heat damage (from structural composite > damage to singed paint) to guide my coverage. There may be more going on > than simply proximity of exhaust system parts to cowling. > > I guess the 'safer' but slightly heavier approach would be to cover it > all as Tim suggested. > > On 3/20/2018 9:49 PM, Don McDonald wrote: > > I took a pencil and marked the areas that were fairly close to any exhaust > pipe (with the bottom cowl on). It looks like your area covered is smaller > than mine.... just sayin'. > > wrote: > > > Here's what I did after allowing heat to damage my cowling. The bad > news is that I had to repair the cowling's inside surface and structure > (scarfing, cloth, honeycomb). The good news is that I had a real good > indication of where the heat problem was. I have flown 2 years since > then with no additional damage or concern. I used red RTV to adhere > the pieces of foil faced insulation - probably the same stuff Tim used > but not sure. > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > > ------------------------------ > [image: Avast logo] > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > <#m_1620520410082091488_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > ________________________________________________________________________________
Date: Mar 24, 2018
Has any used or considered using an exhaust wrap such as this for additional heat protection; https://www.heatshieldproducts.com/lava-exhaust-wrap Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478839#478839 ________________________________________________________________________________
Date: Mar 24, 2018
I've thought about it, but so far I've only used it on my car. Works great at keeping the heat in the pipe and out of the engine compartment. In my car, it smelled bad for a couple of months but later it had no smell - I don't know if you would smell it in an airplane. I've heard it makes an airplane exhaust deteriorate due to the higher heat because it is kept in the pipe. Also, may be danger of fire if oil leak is absorbed by wrap. Kevin Belue RV-6A RV-10 On Sat, Mar 24, 2018 at 5:52 AM, whodja wrote: > > Has any used or considered using an exhaust wrap such as this for > additional heat protection; https://www.heatshieldproducts.com/lava- > exhaust-wrap > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478839#478839 > > ________________________________________________________________________________
Date: Mar 24, 2018
Also with those on you cant inspect the exhaust pipes for cracks Lenny > On Mar 24, 2018, at 1:17 PM, Kevin Belue wrote: > > I've thought about it, but so far I've only used it on my car. Works great at keeping the heat in the pipe and out of the engine compartment. In my car, it smelled bad for a couple of months but later it had no smell - I don't know if you would smell it in an airplane. I've heard it makes an airplane exhaust deteriorate due to the higher heat because it is kept in the pipe. Also, may be danger of fire if oil leak is absorbed by wrap. > > Kevin Belue > RV-6A > RV-10 > > On Sat, Mar 24, 2018 at 5:52 AM, whodja wrote: > > Has any used or considered using an exhaust wrap such as this for additional heat protection; https://www.heatshieldproducts.com/lava-exhaust-wrap > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478839#478839 > > > > > > > =================================== > -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > > > ________________________________________________________________________________
Date: Mar 24, 2018
None of the exhaust manufacturers for Aircraft recommend wrapping the exhaust. Vettermans Warned me even about having areas with a tight heat shield around them. You want air to the outside of the pipe. What you will end up with is an exhaust system that does not last as long or fails. The only thing that I have heard that is sometimes done on aircraft exhaust is to ceramic coat them internally. Tim > On Mar 24, 2018, at 5:52 AM, whodja wrote: > > > Has any used or considered using an exhaust wrap such as this for additional heat protection; https://www.heatshieldproducts.com/lava-exhaust-wrap > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478839#478839 > > > > > > > > > ________________________________________________________________________________
Date: Mar 26, 2018
Subject: Auto Response: RV10-List Digest: 0 Msgs - 03/25/18
Thank you for your email! Unfortunately, I will checking email VERY sporadically but I will get back to you when I am able. Thanks, David ________________________________________________________________________________
Subject: Fly in golfing
Date: Mar 31, 2018
Will be leaving early for sun n fun wondering about finding an airport near and within walking distance of a golf course on my way down. Route will be say Indianapolis to Atlanta to Lakeland. Any experiences out there? -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478947#478947 ________________________________________________________________________________
Subject: Man, I love my airplane!
Date: Mar 31, 2018
9 years 8 months and 23 days to the time I received my certificate. About another month after that before I flew it. For those of you still building and struggling to find time or to balance schedules, hang in there. THESE ARE AWESOME AIRPLANES... In the last 3 weeks Ive flown mine from home (in Waco, Tx) to Cape Girardeau, Mo and back. To Big Bend near the Mexico border in far west Texas and back. To Billings, MT and back. To Norman, OK and back. And every time I settle into a cruise phase of the flight, Im just amazed at how awesome the RV-10 is. Tons of room to spread out. Amazing useful loads. Predicable performance. Extremely wide operating envelope. Couple all that with amazing avionics and its easy to find yourself falling in love with the airplane flight after flight after flight. These are amazing airplanes. Mine is ugly as sin and Ive even been considering a fake wood panel for OSH in an attempt to create the airborne version of the Griswolds station wagon while Im unpainted. But the airplane is amazing... If youre still building and youre struggling to find time or make progress, dont stop. Once you get the bugs worked out and start using your plane, youre going to fall in love with it flight after flight. The reward is so satisfying that any words I write cant do it justice. Just get it done and get ready to fall in love with an amazing machine. Phil Sent from my iPhone ________________________________________________________________________________
Date: Apr 01, 2018
We were flying some YE yesterday. One comment I get more than any other from those who fly in an RV for the first time-"You can see everything from this airplane." Albert Gardner RV-10 N991RV Yuma, AZ 95 yesterday, summer must be here. ________________________________________________________________________________
Date: Apr 01, 2018
Hi Dave, The only airport that I know of, in Indiana, with a golf course right next to it is Plymouth, Indiana C65. It is about 100 miles north of Indy, just south of SBN. Gas is fairly cheap and several restaurants are a short walk from the airport. Regards, Ron -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rvdave Sent: Saturday, March 31, 2018 3:37 PM Subject: RV10-List: Fly in golfing Will be leaving early for sun n fun wondering about finding an airport near and within walking distance of a golf course on my way down. Route will be say Indianapolis to Atlanta to Lakeland. Any experiences out there? -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478947#478947 ________________________________________________________________________________
Subject: Re: Man, I love my airplane!
Date: Apr 03, 2018
Coming up on four years and 440 hours. Other than the prop governor fiasco which wasnt the airplanes fault, it has been a remarkably reliable workhorse and the best overall GA aircraft I have ever flown. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479014#479014 ________________________________________________________________________________
Subject: Thought I would share my Panel Upgrade experience
From: "aerosport1" <g.combs(at)aerosportmodeling.com>
Date: Apr 03, 2018
So after flying my RV-10 N829GW for 8 years 2 months, and 1 minor panel upgrade I decided to do a major Panel update. I removed the very first Aerosport RV-10 Standard panel and installed one of our new RV310 panels with the new quad Center Console. I went from two 8.5" AFS touch screens, to two 10" touch and one 12" touch AFS screens. I also changed over to the ADVANCED QUICK PANEL system. The new Panel has a Remote Transponder, audio panel and WXworx XM receiver. The glove box is a new product from Aerosport for the RV310. Theses are Nylon PA12 and 3D printed. When I decided to do the retrofit I knew it was going to be a huge task to remove some systems in the airplane and dissect all the different wiring bundles. This was needed so I could determine which wires and items to keep and which to remove. Once I started disassembling, I thought, what have I done. My prior panel was working perfect and very efficient. Another factor that pushed me to do this upgrade was that I got caught up in the Navworx mess and had to replace the ADSB unit with a new legal system. I had many options but felt this was the best route to take. After I started dissecting, I was amazed at how many wires and systems items I was able to remove because the Advanced ACM quick panel has it all incorporated. One other thing that made life easier was during my original build I had marked all wires very good and I had a good schematic to follow. Just a suggestion for all you current builders. As I started putting the new electrical system in I became more amazed at how this simplifies everything. This system is an awesome PLUG AND PLAY. During this upgrade I decided to remove my push/pull heater cables and the Oil cooler valve and install TCW TECH linear servo kits. I also upgraded all my interior cockpit brake lines from the stock plastic ones which were getting a little brittle but still working. With this upgrade I had to replace my Magnetometer and ADAHRS with DYNON units and 2 new 2 wire OAT sensors. All these items required new wire bundles run from panel back behind the baggage area bulkhead. I also removed my 3 original 2.25 backups and installed a Garmin G5 with battery backup and Receiving data from the GTN650. Another item removed was a Garmin 696. This was a great backup GPS unit that also handled my XM weather and music. I will miss this one. Maybe I will put it in my J3 Cub. I started this project on 12-28-17 and finally finished 3-30-18. It was fun but a lot more work then I imagined. I had around 150HRS in this upgrade but it was well worth the effort. Thanks to Rob Hickman, Jeffrey Hickman and everyone at AFS for putting up with all my questions. Great customer service. I would highly recommend the Advanced Quick panel systems. Also Bob Newman from TCW TECH. The documentation was all very good and very easy to understand. One great thing is everything worked great once I got all systems settings correct. The only issue I had was to swap the white signal wire on the elevator and rudder trim. That was it. I have about 4hrs now flying behind this panel and I got to say its Awesome. I am still getting use to some items but feeling very comfortable so far. These planes are great -------- Geoff Combs RV-10 QB N829GW Flying 500 hrs 40033 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479016#479016 Attachments: http://forums.matronics.com//files/img_6718_a_1_183.jpg http://forums.matronics.com//files/img_4306_aa_101.jpg http://forums.matronics.com//files/img_4462_164.jpg http://forums.matronics.com//files/img_6708_a_679.jpg http://forums.matronics.com//files/img_6709_496.jpg http://forums.matronics.com//files/img_6710_184.jpg http://forums.matronics.com//files/img_6711_172.jpg ________________________________________________________________________________
Subject: AirNav.com Now Linked to Airport Courtesy Cars
Date: Apr 04, 2018
Airport Courtesy Cars website has been updated to link to AirNav.com. Click on any of the over 1,850 airport IDs within the site and you will be taken to the AirNav.com page for that airport. Please note Airport Courtesy Cars is now fully web based and works on any device. We have also added many locations with MOGAS. Have a great flying season and please consider a small donation to keep this site running and get your name added to the donor page. Thanks, Glenn -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479077#479077 ________________________________________________________________________________
Subject: RG-400 Coax
Date: Apr 07, 2018
Hi I am about to but 100' of RG-400 and see that I can but it from AMAZON for about 2/3 of what the Spruce cost would be. My question is if all RG-400 is created equal of if I run a quality risk buying from AMAZON versus ACS. RG-400 is even cheaper on EBAY (from China). Inquiring minds need to know..... Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479149#479149 ________________________________________________________________________________
Date: Apr 07, 2018
Subject: Re: RG-400 Coax
I=99ve purchased RG-400 on eBay a number of times - but always from d omestic vendors. Never had a problem or could I tell a difference from what B&C sells. Phil On Sat, Apr 7, 2018 at 5:54 PM kearney wrote: > > Hi > > I am about to but 100' of RG-400 and see that I can but it from AMAZON fo r > about 2/3 of what the Spruce cost would be. > > My question is if all RG-400 is created equal of if I run a quality risk > buying from AMAZON versus ACS. RG-400 is even cheaper on EBAY (from China ). > > Inquiring minds need to know..... > > Cheers > > Les > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479149#479149 > > =========== =========== =========== =========== =========== > > > -- Phil Yoder phil(at)philyoder.com \__________o-( )-o__________/ www.itsnotthatcomplex.com ________________________________________________________________________________
From: John MacCallum <john.maccallum(at)bigpond.com>
Date: Apr 08, 2018
Over the length of the cable runs likely on our Aircraft it will make no no ticeable difference between RG400 or even RG58. The only benefit really will be the Teflon Jacket and the double shield on RG400. If I was buying a reel of cable I would buy a reputable brand like Belden or Times Microwave. Cheers John Mac > On 8 Apr 2018, at 09:16, Phil Yoder wrote: > > I=99ve purchased RG-400 on eBay a number of times - but always from d omestic vendors. Never had a problem or could I tell a difference from what B &C sells. > Phil > > > >> On Sat, Apr 7, 2018 at 5:54 PM kearney wrote: >> >> Hi >> >> I am about to but 100' of RG-400 and see that I can but it from AMAZON fo r about 2/3 of what the Spruce cost would be. >> >> My question is if all RG-400 is created equal of if I run a quality risk b uying from AMAZON versus ACS. RG-400 is even cheaper on EBAY (from China). >> >> Inquiring minds need to know..... >> >> Cheers >> >> Les >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=479149#479149 >> >> >> >> >> >> >> ========== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========== >> >> >> > -- > Phil Yoder phil(at)philyoder.com \__________o-( )-o__________/ www.itsnotthat complex.com ________________________________________________________________________________
From: Bedford Landings <jack(at)bedfordlandings.com>
Date: Apr 07, 2018
I've bought a bunch of RG-400' on Amazon. As far as I can tell its identical to that from As&S Sent from Jack's iPad > On Apr 7, 2018, at 6:48 PM, kearney wrote: > > > Hi > > I am about to but 100' of RG-400 and see that I can but it from AMAZON for about 2/3 of what the Spruce cost would be. > > My question is if all RG-400 is created equal of if I run a quality risk buying from AMAZON versus ACS. RG-400 is even cheaper on EBAY (from China). > > Inquiring minds need to know..... > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479149#479149 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 07, 2018
Inquiring minds would want to know why you need that much RG-400. Only you GPS antenna and your transponder and ADS-B out if you need to do that in Canada, would need it. No com or nav unit operates on a high enough frequency for it to be of significant benefit. Yes, the double shielding is nice, theoretically, but planes operated for over 50 years on RG-58 with more than adequate performance for VHF. RG-58 is about 1/6th the price of RG-400. On 4/7/2018 6:18 PM, John MacCallum wrote: > Over the length of the cable runs likely on our Aircraft it will make > no noticeable difference between RG400 or even RG58. The only benefit > really will be the Teflon Jacket and the double shield on RG400. If I > was buying a reel of cable I would buy a reputable brand like Belden or > Times Microwave. > > Cheers John Mac > > On 8 Apr 2018, at 09:16, Phil Yoder > wrote: > >> Ive purchased RG-400 on eBay a number of times - but always from >> domestic vendors. Never had a problem or could I tell a difference >> from what B&C sells. >> Phil >> >> >> >> On Sat, Apr 7, 2018 at 5:54 PM kearney > > wrote: >> >> > >> >> Hi >> >> I am about to but 100' of RG-400 and see that I can but it from >> AMAZON for about 2/3 of what the Spruce cost would be. >> >> My question is if all RG-400 is created equal of if I run a >> quality risk buying from AMAZON versus ACS. RG-400 is even cheaper >> on EBAY (from China). >> >> Inquiring minds need to know..... >> >> Cheers >> >> Les >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=479149#479149 >> >> >> >> >> >> >> ========== >> -List" rel="noreferrer" >> target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> -- >> Phil Yoder phil(at)philyoder.com >> \__________o-( )-o__________/ www.itsnotthatcomplex.com >> <http://www.itsnotthatcomplex.com> ________________________________________________________________________________
Date: Apr 07, 2018
I use RG400 for any new coax runs in any airplane I work on, and I know many others do too. Its much easier to get a good crimp and good solid connectors on RG400 than RG58. I buy RG400 1000 at a time. It is substantially cheaper in those quantities. I always buy from Wiremaster. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Apr 7, 2018, at 9:46 PM, Kelly McMullen wrote: > > > Inquiring minds would want to know why you need that much RG-400. > Only you GPS antenna and your transponder and ADS-B out if you need to do that in Canada, would need it. > No com or nav unit operates on a high enough frequency for it to be of significant benefit. Yes, the double shielding is nice, theoretically, but planes operated for over 50 years on RG-58 with more than adequate performance for VHF. RG-58 is about 1/6th the price of RG-400. > >> On 4/7/2018 6:18 PM, John MacCallum wrote: >> Over the length of the cable runs likely on our Aircraft it will make no noticeable difference between RG400 or even RG58. The only benefit really will be the Teflon Jacket and the double shield on RG400. If I was buying a reel of cable I would buy a reputable brand like Belden or Times Microwave. >> Cheers John Mac >>> On 8 Apr 2018, at 09:16, Phil Yoder > wrote: >>> Ive purchased RG-400 on eBay a number of times - but always from domestic vendors. Never had a problem or could I tell a difference from what B&C sells. >>> Phil >>> >>> >>> >>> On Sat, Apr 7, 2018 at 5:54 PM kearney > wrote: >>> >>> > >>> >>> Hi >>> >>> I am about to but 100' of RG-400 and see that I can but it from >>> AMAZON for about 2/3 of what the Spruce cost would be. >>> >>> My question is if all RG-400 is created equal of if I run a >>> quality risk buying from AMAZON versus ACS. RG-400 is even cheaper >>> on EBAY (from China). >>> >>> Inquiring minds need to know..... >>> >>> Cheers >>> >>> Les >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=479149#479149 >>> >>> >>> >>> >>> >>> >>> ========== >>> -List" rel="noreferrer" >>> target="_blank">http://www.matronics.com/Navigator?RV10-List >>> ========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ========== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> -- >>> Phil Yoder phil@philyoder.com \__________o-( )-o__________/ www.itsnotthatcomplex.com <http://www.itsnotthatcomplex.com> > > > ________________________________________________________________________________
Date: Apr 07, 2018
Kelley It was my understanding that RG400 was preferred for a/c. Based on your comment I will check into this with Stein before I order anything. I have two comm runs to the tail along with a VOR/ILS antenna. That with the 2 GPS antennas and XM weather and it adds up quickly. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479159#479159 ________________________________________________________________________________
Date: Apr 08, 2018
I'm installing a Garmin GDL82 into a Cessna 150M. Tied in with the existing transponder will give it a relative cheap way to obtain ADS-B 2020 out. The install directions call for the use of RG400 because of the extra shielding affect. Most electronic installs call for RG400 these days. I buy most all my coax from Spruce as the cable pretty much comes from the same places no matter where you buy lt. Sent from my iPad > On Apr 7, 2018, at 9:14 PM, Jesse Saint wrote: > > > I use RG400 for any new coax runs in any airplane I work on, and I know many others do too. Its much easier to get a good crimp and good solid connectors on RG400 than RG58. I buy RG400 1000 at a time. It is substantially cheaper in those quantities. I always buy from Wiremaster. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > >> On Apr 7, 2018, at 9:46 PM, Kelly McMullen wrote: >> >> >> Inquiring minds would want to know why you need that much RG-400. >> Only you GPS antenna and your transponder and ADS-B out if you need to do that in Canada, would need it. >> No com or nav unit operates on a high enough frequency for it to be of significant benefit. Yes, the double shielding is nice, theoretically, but planes operated for over 50 years on RG-58 with more than adequate performance for VHF. RG-58 is about 1/6th the price of RG-400. >> >>> On 4/7/2018 6:18 PM, John MacCallum wrote: >>> Over the length of the cable runs likely on our Aircraft it will make no noticeable difference between RG400 or even RG58. The only benefit really will be the Teflon Jacket and the double shield on RG400. If I was buying a reel of cable I would buy a reputable brand like Belden or Times Microwave. >>> Cheers John Mac >>>> On 8 Apr 2018, at 09:16, Phil Yoder > wrote: >>>> Ive purchased RG-400 on eBay a number of times - but always from domestic vendors. Never had a problem or could I tell a difference from what B&C sells. >>>> Phil >>>> >>>> >>>> >>>> On Sat, Apr 7, 2018 at 5:54 PM kearney > wrote: >>>> >>>> > >>>> >>>> Hi >>>> >>>> I am about to but 100' of RG-400 and see that I can but it from >>>> AMAZON for about 2/3 of what the Spruce cost would be. >>>> >>>> My question is if all RG-400 is created equal of if I run a >>>> quality risk buying from AMAZON versus ACS. RG-400 is even cheaper >>>> on EBAY (from China). >>>> >>>> Inquiring minds need to know..... >>>> >>>> Cheers >>>> >>>> Les >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=479149#479149 >>>> >>>> >>>> >>>> >>>> >>>> >>>> ========== >>>> -List" rel="noreferrer" >>>> target="_blank">http://www.matronics.com/Navigator?RV10-List >>>> ========== >>>> FORUMS - >>>> eferrer" target="_blank">http://forums.matronics.com >>>> ========== >>>> WIKI - >>>> errer" target="_blank">http://wiki.matronics.com >>>> ========== >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>>> ========== >>>> >>>> >>>> >>>> -- >>>> Phil Yoder phil@philyoder.com \__________o-( )-o__________/ www.itsnotthatcomplex.com <http://www.itsnotthatcomplex.com> >> >> >> > > > > > ________________________________________________________________________________
Date: Apr 07, 2018
Of course the folks that sell the cable will recommend RG-400. It is the default, whether needed or not. Kind of like whether you choose Goodyear Flight Custom III tires or something at 1/2 the cost. Just like Lycoming will tell you that you can cruise your engine at 425 degrees all day long. All transponders, and ADS-B and GPS operate at or above 1000 Mhz, which requires better cabling and lower loss. All com and VHF nav operate at 1/10th those frequencies. Yes, RG-400 may theoretically last longer, but it is rare to see problems with RG-58 for VHF at 50 years or more, unless the plane lives outside in a hot climate its whole life. Just my experience with more than one aircraft I have owned that was manufactured and avionics installed more than 50 years ago. Even transponders installed in the 70s used RG-58, though they learned later it was sub-optimal..my last aircraft before the RV was 53 years old and got a transponder in the early 70's, it still had the same RG-58 transponder antenna cable when I sold it, and had no ATC issues, nor passing 2 year checks. I have RG-58 for my VHF use in my RV-10, and have no trouble talking to anyone at any altitude that you would expect to have line of sight. You can spend over $300 for cable if you want, or you can spend under $100 and get 98% of the performance of the expensive stuff. It is experimental and your choice, and nobody has to justify to anyone else...you just want it. Just like you can install a Garmin 500 or 600 panel if that is what you want, or you can do a G3X, or Dynon, AFS, Grand Rapids or MGL...you get to pick. 4/7/2018 7:24 PM, Danny Riggs wrote: > > I'm installing a Garmin GDL82 into a Cessna 150M. Tied in with the existing transponder will give it a relative cheap way to obtain ADS-B 2020 out. The install directions call for the use of RG400 because of the extra shielding affect. Most electronic installs call for RG400 these days. I buy most all my coax from Spruce as the cable pretty much comes from the same places no matter where you buy lt. > > Sent from my iPad > >> On Apr 7, 2018, at 9:14 PM, Jesse Saint wrote: >> >> >> I use RG400 for any new coax runs in any airplane I work on, and I know many others do too. Its much easier to get a good crimp and good solid connectors on RG400 than RG58. I buy RG400 1000 at a time. It is substantially cheaper in those quantities. I always buy from Wiremaster. >> >> Jesse Saint >> Saint Aviation, Inc. >> 352-427-0285 >> jesse(at)saintaviation.com >> >> Sent from my iPad >> >>> On Apr 7, 2018, at 9:46 PM, Kelly McMullen wrote: >>> >>> >>> Inquiring minds would want to know why you need that much RG-400. >>> Only you GPS antenna and your transponder and ADS-B out if you need to do that in Canada, would need it. >>> No com or nav unit operates on a high enough frequency for it to be of significant benefit. Yes, the double shielding is nice, theoretically, but planes operated for over 50 years on RG-58 with more than adequate performance for VHF. RG-58 is about 1/6th the price of RG-400. >>> >>>> On 4/7/2018 6:18 PM, John MacCallum wrote: >>>> Over the length of the cable runs likely on our Aircraft it will make no noticeable difference between RG400 or even RG58. The only benefit really will be the Teflon Jacket and the double shield on RG400. If I was buying a reel of cable I would buy a reputable brand like Belden or Times Microwave. >>>> Cheers John Mac >>>>> On 8 Apr 2018, at 09:16, Phil Yoder > wrote: >>>>> Ive purchased RG-400 on eBay a number of times - but always from domestic vendors. Never had a problem or could I tell a difference from what B&C sells. >>>>> Phil >>>>> >>>>> >>>>> >>>>> On Sat, Apr 7, 2018 at 5:54 PM kearney > wrote: >>>>> >>>>> > >>>>> >>>>> Hi >>>>> >>>>> I am about to but 100' of RG-400 and see that I can but it from >>>>> AMAZON for about 2/3 of what the Spruce cost would be. >>>>> >>>>> My question is if all RG-400 is created equal of if I run a >>>>> quality risk buying from AMAZON versus ACS. RG-400 is even cheaper >>>>> on EBAY (from China). >>>>> >>>>> Inquiring minds need to know..... >>>>> >>>>> Cheers >>>>> >>>>> Les >>>>> >>>>> >>>>> >>>>> >>>>> Read this topic online here: >>>>> >>>>> http://forums.matronics.com/viewtopic.php?p=479149#479149 >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> ========== >>>>> -List" rel="noreferrer" >>>>> target="_blank">http://www.matronics.com/Navigator?RV10-List >>>>> ========== >>>>> FORUMS - >>>>> eferrer" target="_blank">http://forums.matronics.com >>>>> ========== >>>>> WIKI - >>>>> errer" target="_blank">http://wiki.matronics.com >>>>> ========== >>>>> b Site - >>>>> -Matt Dralle, List Admin. >>>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>>>> ========== >>>>> >>>>> >>>>> >>>>> -- >>>>> Phil Yoder phil@philyoder.com \__________o-( )-o__________/ www.itsnotthatcomplex.com <http://www.itsnotthatcomplex.com> >>> >>> >>> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Apr 07, 2018
Interesting. Never had an issue installing crimp BNC on RG-58, nor did I find crimps on RG-400 any easier, and the RG-58 is easier to trim the insulation for the crimp. More like do you need iPhone 6,7 or X? On 4/7/2018 6:59 PM, Jesse Saint wrote: > > I use RG400 for any new coax runs in any airplane I work on, and I know many others do too. Its much easier to get a good crimp and good solid connectors on RG400 than RG58. I buy RG400 1000 at a time. It is substantially cheaper in those quantities. I always buy from Wiremaster. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > ________________________________________________________________________________
From: Roxanne and Mike Lefever <roxianmike(at)MSN.COM>
Date: Apr 08, 2018
Hi Kelly=85=85=85=85=85..a turn if life events has changed my direction on completing my RV10 project. The first thing that comes to focus is my new IO540. I have a new (out of the box parts new) IO 540 Thunderbolt Lycoming engine assembled by Aircraft Engine Specialists in Chandler, Arizona with appropriate design to be a D4A5 for a RV10. Also included an upgraded elec tronic mag on one side that will increase HP and we can provide that detail . Please spread the word, I will be listing soon on Barnstormers and Vans Air Force. Sent from Mail for Window s 10 ________________________________ From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> on behalf of Kelly McMullen Sent: Saturday, April 7, 2018 7:49:38 PM Subject: Re: RV10-List: RG-400 Coax Of course the folks that sell the cable will recommend RG-400. It is the default, whether needed or not. Kind of like whether you choose Goodyear Flight Custom III tires or something at 1/2 the cost. Just like Lycoming will tell you that you can cruise your engine at 425 degrees all day long. All transponders, and ADS-B and GPS operate at or above 1000 Mhz, which requires better cabling and lower loss. All com and VHF nav operate at 1/10th those frequencies. Yes, RG-400 may theoretically last longer, but it is rare to see problems with RG-58 for VHF at 50 years or more, unless the plane lives outside in a hot climate its whole life. Just my experience with more than one aircraft I have owned that was manufactured and avionics installed more than 50 years ago. Even transponders installed in the 70s used RG-58, though they learned later it was sub-optimal..my last aircraft before the RV was 53 years old and got a transponder in the early 70's, it still had the same RG-58 transponder antenna cable when I sold it, and had no ATC issues, nor passing 2 year checks. I have RG-58 for my VHF use in my RV-10, and have no trouble talking to anyone at any altitude that you would expect to have line of sight. You can spend over $300 for cable if you want, or you can spend under $100 and get 98% of the performance of the expensive stuff. It is experimental and your choice, and nobody has to justify to anyone else...you just want it. Just like you can install a Garmin 500 or 600 panel if that is what you want, or you can do a G3X, or Dynon, AFS, Grand Rapids or MGL...you get to pick. 4/7/2018 7:24 PM, Danny Riggs wrote: > > I'm installing a Garmin GDL82 into a Cessna 150M. Tied in with the existi ng transponder will give it a relative cheap way to obtain ADS-B 2020 out. The install directions call for the use of RG400 because of the extra shiel ding affect. Most electronic installs call for RG400 these days. I buy most all my coax from Spruce as the cable pretty much comes from the same place s no matter where you buy lt. > > Sent from my iPad > >> On Apr 7, 2018, at 9:14 PM, Jesse Saint wrote: >> >> >> I use RG400 for any new coax runs in any airplane I work on, and I know many others do too. It=92s much easier to get a good crimp and good solid c onnectors on RG400 than RG58. I buy RG400 1000=92 at a time. It is substant ially cheaper in those quantities. I always buy from Wiremaster. >> >> Jesse Saint >> Saint Aviation, Inc. >> 352-427-0285 >> jesse(at)saintaviation.com >> >> Sent from my iPad >> >>> On Apr 7, 2018, at 9:46 PM, Kelly McMullen wrote: >>> >>> >>> Inquiring minds would want to know why you need that much RG-400. >>> Only you GPS antenna and your transponder and ADS-B out if you need to do that in Canada, would need it. >>> No com or nav unit operates on a high enough frequency for it to be of significant benefit. Yes, the double shielding is nice, theoretically, but planes operated for over 50 years on RG-58 with more than adequate performa nce for VHF. RG-58 is about 1/6th the price of RG-400. >>> >>>> On 4/7/2018 6:18 PM, John MacCallum wrote: >>>> Over the length of the cable runs likely on our Aircraft it will make no noticeable difference between RG400 or even RG58. The only benefit real ly will be the Teflon Jacket and the double shield on RG400. If I was buyin g a reel of cable I would buy a reputable brand like Belden or Times Microw ave. >>>> Cheers John Mac >>>>> On 8 Apr 2018, at 09:16, Phil Yoder > wrote: >>>>> I=92ve purchased RG-400 on eBay a number of times - but always from d omestic vendors. Never had a problem or could I tell a difference from what B&C sells. >>>>> Phil >>>>> >>>>> >>>>> >>>>> On Sat, Apr 7, 2018 at 5:54 PM kearney > wrote: >>>>> >>>>> > >>>>> >>>>> Hi >>>>> >>>>> I am about to but 100' of RG-400 and see that I can but it from >>>>> AMAZON for about 2/3 of what the Spruce cost would be. >>>>> >>>>> My question is if all RG-400 is created equal of if I run a >>>>> quality risk buying from AMAZON versus ACS. RG-400 is even cheaper >>>>> on EBAY (from China). >>>>> >>>>> Inquiring minds need to know..... >>>>> >>>>> Cheers >>>>> >>>>> Les >>>>> >>>>> >>>>> >>>>> >>>>> Read this topic online here: >>>>> >>>>> http://forums.matronics.com/viewtopic.php?p=479149#479149 >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> ========== >>>>> -List" rel="noreferrer" >>>>> target="_blank">http://www.matronics.com/Navigator?RV10-List >>>>> ========== >>>>> FORUMS - >>>>> eferrer" target="_blank">http://forums.matronics.com >>>>> ========== >>>>> WIKI - >>>>> errer" target="_blank">http://wiki.matronics.com >>>>> ========== >>>>> b Site - >>>>> -Matt Dralle, List Admin. >>>>> rel="noreferrer" target="_blank">http://www.matronics.com/cont ribution >>>>> ========== >>>>> >>>>> >>>>> >>>>> -- >>>>> Phil Yoder phil(at)philyoder.com \__________ o-( )-o__________/ www.itsnotthatcomplex.com<http://www.itsnotthatcomplex.c om> <http://www.itsnotthatcomplex.com> >>> >>> >>> >> >> >> >> >> > > ________________________________________________________________________________
Date: Apr 08, 2018
Your install manuals will specify the manufacturer=92s requirements for typ e and length of cable. Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> on behalf of kearney Sent: Saturday, April 7, 2018 10:06:20 PM Subject: RV10-List: Re: RG-400 Coax Kelley It was my understanding that RG400 was preferred for a/c. Based on your com ment I will check into this with Stein before I order anything. I have two comm runs to the tail along with a VOR/ILS antenna. That with th e 2 GPS antennas and XM weather and it adds up quickly. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479159#479159 ________________________________________________________________________________
Date: Apr 08, 2018
On 4/8/2018 1:24 AM, Bob Leffler wrote: > Your install manuals will specify the manufacturers requirements for > type and length of cable. > > Get Outlook for iOS > ------------------------------------------------------------------------ I looked through the manuals I have on hand. The KX-155/165 manual only mentions RG-58. That includes its discussion of what is approved for full TSO approval. The GNS-400 series mentions 50 ohm shielded cable. I didn't find mention of RG-400 (alternate RG-142) until I got to the GTN-600 series install manual. In other words, even Garmin didn't start recommending RG-400 until about 10 years ago. The Dynon Skyview manual asserts that double shielded cable will deliver "more" transmit power and receive signal than single shielded, with no definition or quantification of how much more. It is funny that the SL-30 manual calls for RG-142, and Garmin shows it as acceptable alternate. RG-142 has a solid core connector, not stranded. It is double shielded like RG-400. There was a discussion on VAF about the differences, and pointing out that it has only been sometime after the turn of the century that RG-400 started being recommended. IF you anticipate a "noisy" RF environment in your cockpit, go for the best cable you can get. If your aircraft will have typical noise (very little) you can choose whether you want to save a couple hundred bucks or not. Note that nothing has changed in VHF electronic signal transmission since the days of the coffee grinder and crystal controlled transmitters. The internal electronics have been better shielded to avoid transmission of the RF generated during amplification of signals, etc. so that we get better quality audio. Apollo introduced digital signal processing..maybe that influences the call for better shielding..who knows. It is pretty much the same difference as whether you choose to operate at 75% power for all cruise, or if you choose to go high enough to operate at 60-65% power and save a lot of fuel while sacrificing about 5-8% speed. Your airplane and money, your choice. I haven't seen any install manual yet that says RG-400 is mandatory for com or VHF nav...only for GPS. ________________________________________________________________________________
Date: Apr 08, 2018
I forgot to mention that we should discuss whether Les should prime his antenna cables and with which type of primer. ;-) On 4/8/2018 7:57 AM, Kelly McMullen wrote: > > On 4/8/2018 1:24 AM, Bob Leffler wrote: > > Your install manuals will specify the manufacturers requirements for > > type and length of cable. > > > > Get Outlook for iOS > > ------------------------------------------------------------------------ > > I looked through the manuals I have on hand. The KX-155/165 manual only > mentions RG-58. That includes its discussion of what is approved for > full TSO approval. ________________________________________________________________________________
Date: Apr 08, 2018
Kellym wrote: > I forgot to mention that we should discuss whether Les should prime his > antenna cables and with which type of primer. ;-) > > Thats actually a good analogy. Nearly any primer will look good tomorrow. How will it perform in 10 years? Same question about less expensive/more expensive coax on VHF radios. Only the builder can decide if the cost difference is worth the risk/benefit. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479180#479180 ________________________________________________________________________________
Date: Apr 09, 2018
RG58 will work because the cable run is only short. The losses for a few metres of Coax are not noticeable to us as users. There is an advantage though with the double shielding and the Teflon outer Jacket of RG400. Less induced noise and better abrasion resistance. Also it is better to use Multi Stand rather than solid core cables because of vibration. For the money it costs to use RG400 compared to the over all costs involved with the building process, in my opinion, RG400 is the way to go! Cheers John MacCallum RV10 VH-DUU Flying > On 9 Apr 2018, at 00:57, Kelly McMullen wrote: > > > On 4/8/2018 1:24 AM, Bob Leffler wrote: > > Your install manuals will specify the manufacturers requirements for > > type and length of cable. > > > > Get Outlook for iOS > > ------------------------------------------------------------------------ > > I looked through the manuals I have on hand. The KX-155/165 manual only mentions RG-58. That includes its discussion of what is approved for full TSO approval. > The GNS-400 series mentions 50 ohm shielded cable. I didn't find mention of RG-400 (alternate RG-142) until I got to the GTN-600 series install manual. In other words, even Garmin didn't start recommending RG-400 until about 10 years ago. > The Dynon Skyview manual asserts that double shielded cable will deliver "more" transmit power and receive signal than single shielded, with no definition or quantification of how much more. > It is funny that the SL-30 manual calls for RG-142, and Garmin shows it as acceptable alternate. RG-142 has a solid core connector, not stranded. It is double shielded like RG-400. There was a discussion on VAF about the differences, and pointing out that it has only been sometime after the turn of the century that RG-400 started being recommended. > IF you anticipate a "noisy" RF environment in your cockpit, go for the best cable you can get. If your aircraft will have typical noise (very little) you can choose whether you want to save a couple hundred bucks or not. > Note that nothing has changed in VHF electronic signal transmission since the days of the coffee grinder and crystal controlled transmitters. > The internal electronics have been better shielded to avoid transmission of the RF generated during amplification of signals, etc. so that we get better quality audio. Apollo introduced digital signal processing..maybe that influences the call for better shielding..who knows. > It is pretty much the same difference as whether you choose to operate at 75% power for all cruise, or if you choose to go high enough to operate at 60-65% power and save a lot of fuel while sacrificing about 5-8% speed. Your airplane and money, your choice. > I haven't seen any install manual yet that says RG-400 is mandatory for com or VHF nav...only for GPS. > > > > > ________________________________________________________________________________
Date: Apr 09, 2018
Hi Kelley If I use a silicone based primer on my COAX cable will the electrons flow faster? Inquiring minds really, really need to know. Les [Idea] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479194#479194 ________________________________________________________________________________
Date: Apr 09, 2018
I primed the inside of my coax. No problems noted. Fairly tedious task but worth the effort. Sent from my iPhone > On Apr 9, 2018, at 9:43 AM, kearney wrote: > > > Hi Kelley > > If I use a silicone based primer on my COAX cable will the electrons flow faster? > > Inquiring minds really, really need to know. > > Les [Idea] > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479194#479194 > > > > > > > > > ________________________________________________________________________________
Date: Apr 09, 2018
Without getting into the argument on technicalities or superiorities of one over the other, I'll just provide my 2 cents on the import vs domestic. I've seen quite a bit of domestic as well as import wire, and like many things that get imported what you see (or is advertised) is not always what you get. We've seen some copycat "RG" (various spec's and types) that is a pretty good knockoff, until you realize the plating on the wire strands is tin (or even less) vs. true silver plated copper for domestically produced mil spec. Speaking of copper, some of the conductors I've seen are just some version of aluminum or pot metal, cleverly disguised. I've seen some that corrodes badly/quickly, some that was laughable and some that was passable. I'm always amazed at how much work some of the import companies will go through to copy something so closely, only to produce garbage (that looks good). Now I'm certainly not saying all import or surplus wire is that way - I've seen some that is pretty good....but when you see it for ridiculously low prices (below what someone could manufacture it for using the raw materials that it's made out of) it's often true of the old mantra "if it sounds like a duck and looks like a duck"...and speaking of surplus, I have seen quite a bit of water/hurricane damaged wire with internal corrosion. Looks good on the outside, not so much on the inside where the water has wicked up into the wire. Again, not all surplus is a bad thing. Some is simply surplus...but a good deal of it is someone passing of junk - literally. This is true whether it be 400, 58, tefzel wire, and a lot of other things (as we all know from experience). In some (not all) cases, you may have just stepped over a dollar to pick up a dime. Just my 2 cents as usual! Cheers, Stein -----Original Message----- From: owner-rv10-list-server(at)matronics.com On Behalf Of kearney Sent: Saturday, April 07, 2018 5:48 PM Subject: RV10-List: RG-400 Coax Hi I am about to but 100' of RG-400 and see that I can but it from AMAZON for about 2/3 of what the Spruce cost would be. My question is if all RG-400 is created equal of if I run a quality risk buying from AMAZON versus ACS. RG-400 is even cheaper on EBAY (from China). Inquiring minds need to know..... Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479149#479149 ________________________________________________________________________________
Subject: Mouttain High )2 System Distribution Head Location
Date: Apr 09, 2018
Hi I need to find reasonable locations for the distribution heads for my Mountain High O2 system. I am thinking of installing them in my Aerosport overhead console. For the front seat positions, the best location seems to be the large access panel - this is easy. The rear positions also can fit in the overhead console but the best spot is behind the rear access panel. In this location I can't figure out how to do the install. I am also using an Aerosport center console and have thought about putting the controllers on the front and back. These locations would work except I plan to put the headphone jacks etc in these locations. Given all that I have two questions. 1. For those who have installed in the overhead console, are you happy with this location and if not why not. Pix of how the install worked would be great. 2. For those who installed elsewhere, I'd be interested in seeing pix of the location and comments on the location. Cheers Les C-GCWZ - Flying C-GROK - Some assembly required Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479197#479197 ________________________________________________________________________________
Date: Apr 09, 2018
Subject: Re: Mouttain High )2 System Distribution Head Location
I put mine in the center console and I regret it every time I fly.... Finding another location is something I'd like to do at some point in the future. My thought process was to put the headsets, oxygen outlets, and misc cables (USB, Cigarette lighter, etc) near the center point of the cabin. It would serve as the distribution point to all 4 seats and the cables/hoses would not be a factor when exiting the airplane. What I can tell you is that it's a nightmare to pull the console to inspect/service the tunnel. It's a nightmare to get the cables/hoses re-installed in a consistent enough fashion where the interior bin will sit down flush and where the rudder cables won't rub against them. I really regret putting anything in my center console. I should have left it naked and when on finding a different spot. I constantly have mess of cables/hoses to fight through. I've also found that with that many wires/hoses in the box, things (wires and hoses) get pressed into position and it binds them. I currently have an electrical gremlin in my pilot outlet that I need to trace. I am 100% sure it's a connector issue but when you can't permanently mount the wires and forget about them, things like connector problems happen. That area is just too dynamic from maintenance period to maintenance period to expect everything to be rock-solid all the time. If you do decide to install in the center console, I've attached some pictures. The factory backing plates on the outlets were too wide to allow side-by-side installation of the outlets in the width of the console. So I had to remove them and build a single backing plate that allowed me to squeeze the two outlets closer together. Worked well. The overhead air console is probably a good choice, but I know MH wants you to mount them in a place that has static cabin pressure. I know the sensor is on the face of the outlet, but I still think it would be a good idea to build a receptacle box in the overhead to hold them, then seal that box with proseal so it won't be subject to the positive pressures inside the overhead console. That's something I'm still considering as I'm not real happy with my center console setup. I just have too many wires and not enough space. Good luck! Phil On Mon, Apr 9, 2018 at 10:03 AM, kearney wrote: > > Hi > > I need to find reasonable locations for the distribution heads for my > Mountain High O2 system. > > I am thinking of installing them in my Aerosport overhead console. For the > front seat positions, the best location seems to be the large access panel > - this is easy. The rear positions also can fit in the overhead console > but the best spot is behind the rear access panel. In this location I can't > figure out how to do the install. > > I am also using an Aerosport center console and have thought about putting > the controllers on the front and back. These locations would work except I > plan to put the headphone jacks etc in these locations. > > Given all that I have two questions. > > 1. For those who have installed in the overhead console, are you happy > with this location and if not why not. Pix of how the install worked would > be great. > > 2. For those who installed elsewhere, I'd be interested in seeing pix of > the location and comments on the location. > > Cheers > > Les > > C-GCWZ - Flying > C-GROK - Some assembly required > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479197#479197 > > ________________________________________________________________________________
Date: Apr 09, 2018
Hi Phil Thanks for the pix and insights. In my flying -10, I did much the same thing except I have a flange mounted CPC on the tunnel cover under the consol. To remove the consol, I simply unscrew the CPC and the whole thing comes off as a unit. I do have O2 ports on the front of consol as well except these are strictly outlets (no electronic heads) as they predate the new MHS system. I only have a single quick disconnect on a supply line to break. I plan to do the same thing again on the center consol using a single CPC. I don't want to put O2 on the console this time due to the additional wiring and connections associated with the distribution head. Also, I like the real estate for jacks etc. Based on you comments I'll find a different home for the O2 distribution heads. Lastly, my airplane builder fluid looks equally dark but generally says Guinness and comes in a can. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479202#479202 ________________________________________________________________________________
Date: Apr 09, 2018
If you look closely, I used a CPC too. No way Id try it without the CPC. Just too many wires to my use one. Phil Sent from my iPhone > On Apr 9, 2018, at 11:13 AM, kearney wrote: > > > Hi Phil > > Thanks for the pix and insights. In my flying -10, I did much the same thing except I have a flange mounted CPC on the tunnel cover under the consol. To remove the consol, I simply unscrew the CPC and the whole thing comes off as a unit. > > I do have O2 ports on the front of consol as well except these are strictly outlets (no electronic heads) as they predate the new MHS system. I only have a single quick disconnect on a supply line to break. > > I plan to do the same thing again on the center consol using a single CPC. I don't want to put O2 on the console this time due to the additional wiring and connections associated with the distribution head. Also, I like the real estate for jacks etc. > > Based on you comments I'll find a different home for the O2 distribution heads. > > Lastly, my airplane builder fluid looks equally dark but generally says Guinness and comes in a can. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479202#479202 > > > > > > > > >
December 24, 2017 - April 09, 2018
RV10-Archive.digest.vol-nb
