RV10-Archive.digest.vol-ne
August 20, 2018 - March 04, 2019
      altitude run up through NJ in order to clear all the airline traffic
      into Newark, LaGuardia and GA into Teterboro. And while it is busy
      overhead it can even be busier down below with all the airports along
      that NJ corridor. It can be a very uncomfortable flight VFR or IFR with
      rising terrain and low under the Class B shelf traffic. Turned out KFRG
      was the right choice and managed to get a perfect little RNAV 01 'T'
      approach in actual logged.
      Leaving KFRG (or KHPN) back to the south can be a breeze as well with
      routing directly over KJFK. Flying that route VFR is always fun with
      great views of the City and big heavy overseas flights getting a turn
      towards Europe right after they spot the "RV at 6,000". It's just cool!
      However, the next leg ended up being NYC to Pittsburgh and that
      generally requires a northeast turn to Bridgeport before a wide
      circumvention of NYC as you turn west. I got the clearance from the
      tower and spent almost 15 minutes getting it all into FF so it could
      decipher the Victor airways and then into the G430. Though previous
      experience suggested I wouldn't hit many of the waypoints, traffic and
      weather were such that I didn't want to add any in the air workload.  I
      just added the new Sentry product to the cockpit so I now had Nexrad
      displayed on my panel GRTs and the FF iPad. Seems redundant but I
      really like having both now. Anyway there was a broken line of rainy
      build-ups but my cleared route was very doable.... then it suddenly wasn't.
      I was cleared to taxi to the 01 but to hold for release from NY ATC.
      Overhead a storm appeared in what was clear blue air 15 minutes ago. It
      started to rain and the tower said it might be awhile, "there just isn't
      anywhere to squeeze you in according to NY". I wasn't going to launch
      into what quickly turned into a gusty driving rain. My wife had
      fortunately lingered after dropping me off and I joined her in the car
      after shutting down. I still didn't believe that the storm appeared out
      of no where but playing it back on the iPad showed that it was exactly
      what happened, and it happened in 4 to 6 minutes. Just amazing.
      After 30 minutes or so the storm moved on a bit and I restarted and
      taxied out to the opposite runway only to hold for release once again.
      I could easily see that all NYC traffic was now being funneled through
      just a few gaps in the storm line and they did not want to add me to the
      mix.
      With darkness approaching and the chance that my departure be weather
      blocked again, I told the tower I was considering departing VFR and
      picking up my IFR in the air over Carmel. They advised against it and
      warned me that they may not give it to me. I studied the weather and a
      VFR plan B and considered it doable. So I asked for a VFR departure and
      was cleared for takeoff squawking 1200.
      "Well, NY Approach for some reason just released you, do you still have
      the original clearance?" Oh yeah, I was 300' in the air still over the
      runway but with a wink and a nod the tower let me know that my decision
      to depart motivated NY approach to let me in despite the jam.
      I love NY ATC! They are fast talking and attitude rich but I lived
      there for a dozen years and know that they will respond to a nudge or a
      beep of the horn better than a "please, no, after you". Thanks for
      letting me win one!
      (And if you want to hear NYC Approach doing it's thing so to speak,
      check this gem out from July Not angry NY ATC works Aer Lingus Flight
      Bill "back home with 2 more approaches in actual and a scud run to
      homeplate" Watson
      N215TG
      On 8/10/2018 6:58 PM, Bill Watson wrote:
      > Just one of those days when nothing lined up properly!
      > No need to overreact though. I know I will continue to pickup
      > clearances in the air in my uncongested piece of the country but I
      > won't hesitate to do it elsewhere when needed. Experience has
      > suggested that it's not the best strategy say in the NYC area where
      > you might get (quickly) scolded before (quickly) getting the
      > clearance. And it can be a handful around Miami where there's bound
      > to be a dozen VFR targets orbiting your climb corridor while ATC tries
      > to locate your plane and your plan.
      > I would suggest that if you include "IFR" somewhere in your initial
      > call-up, you won't be ignored, even in the busiest airspace. And if
      > you eliminate any mention of a opening an IFR flight plan you'll avoid
      > much of what happened on that not so fateful day.
      > Thanks for sharing the experience, I definitely learned some stuff.
      > On 8/9/2018 5:33 PM, Dan Masys wrote:
      >> Thanks all for the educational input. I definitely have an IFR
      >> departure
      >> strategy now for this (and any) uncontrolled airport, particularly in
      >> NorCal's jurisdiction: get a clearance plus void time release via phone
      >> while on the ground, even if it is blue skies everywhere. It
      >> eliminates the
      >> issue of getting ignored during initial call-up, and saves any
      >> misunderstanding caused by nonstandard radio phraseology.
      >> A few additional details on my long story:
      >> 1. When the female controller issued my clearance and I read it back
      >> correctly, the last thing she said was 'Maintain VFR.', which led me to
      >> believe the IFR clearance was not yet active.
      >> 2. This was further reinforced when approximately ten minutes later I
      >> called
      >> Oakland Center and their initial response was 'We don't have anything
      >> in the
      >> system for you.' After a pause the Center controller remarked, "Oh,
      >> here it
      >> is", followed by "cleared direct TTE."
      >> 3. I also was concerned that initially I had been given a VFR squawk,
      >> and
      >> asked the Center controller about it. He confirmed that the initial
      >> code
      >> given was an IFR code, which made the "maintain VFR" remark of the
      >> previous
      >> controller even more curious.
      >> But all of that notwithstanding, I know forevermore not to attempt to
      >> 'open
      >> an IFR flight plan' even though that phraseology had worked without
      >> incident
      >> literally for decades.
      >> Tailwinds to all,
      >> -Dan Masys
      > This email has been checked for viruses by Avast antivirus software.
      > https://www.avast.com/antivirus
From: "Parish Moffitt" <parish(at)parishmoffitt.com>
Subject: RE: Getting beat up by NorCal ATC
Date: Aug 20, 2018
Great story Bill. I have heard some of the funniest things from NY controllers and I call two of them friends! I fly into LGA and JFK for work rather than fun at least once a month and I did it multiple times per day for a about a year at one point. I have heard this gentle nudging that you refer to on the ground frequency at LGA more than once! Parish =9Cglad to not be based in the North East anymore=9D From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson Sent: Monday, August 20, 2018 4:32 PM Subject: Re: RV10-List: RE: Getting beat up by NorCal ATC Funny that I mentioned clearance strategies in the NYC area. I just returned from a trip that included flying in and out of KFRG Republic Farmingdale LI. My experience doesn't add anything to this discussion (Robert Jones laid out the best approach), but I'll share it as a slightly off-topic point of interest. I suddenly had to fly into NYC on short notice. Though my destination was in the Bronx making KHPN Westchester Co the closest satellite AP, I chose to fly into KFRG because of IFR conditions. I know from experience that coming from the south to KHPN will result in a minimum altitude run up through NJ in order to clear all the airline traffic into Newark, LaGuardia and GA into Teterboro. And while it is busy overhead it can even be busier down below with all the airports along that NJ corridor. It can be a very uncomfortable flight VFR or IFR with rising terrain and low under the Class B shelf traffic. Turned out KFRG was the right choice and managed to get a perfect little RNAV 01 'T' approach in actual logged. Leaving KFRG (or KHPN) back to the south can be a breeze as well with routing directly over KJFK. Flying that route VFR is always fun with great views of the City and big heavy overseas flights getting a turn towards Europe right after they spot the "RV at 6,000". It's just cool! However, the next leg ended up being NYC to Pittsburgh and that generally requires a northeast turn to Bridgeport before a wide circumvention of NYC as you turn west. I got the clearance from the tower and spent almost 15 minutes getting it all into FF so it could decipher the Victor airways and then into the G430. Though previous experience suggested I wouldn't hit many of the waypoints, traffic and weather were such that I didn't want to add any in the air workload. I just added the new Sentry product to the cockpit so I now had Nexrad displayed on my panel GRTs and the FF iPad. Seems redundant but I really like having both now. Anyway there was a broken line of rainy build-ups but my cleared route was very doable.... then it suddenly wasn't. I was cleared to taxi to the 01 but to hold for release from NY ATC. Overhead a storm appeared in what was clear blue air 15 minutes ago. It started to rain and the tower said it might be awhile, "there just isn't anywhere to squeeze you in according to NY". I wasn't going to launch into what quickly turned into a gusty driving rain. My wife had fortunately lingered after dropping me off and I joined her in the car after shutting down. I still didn't believe that the storm appeared out of no where but playing it back on the iPad showed that it was exactly what happened, and it happened in 4 to 6 minutes. Just amazing. After 30 minutes or so the storm moved on a bit and I restarted and taxied out to the opposite runway only to hold for release once again. I could easily see that all NYC traffic was now being funneled through just a few gaps in the storm line and they did not want to add me to the mix. With darkness approaching and the chance that my departure be weather blocked again, I told the tower I was considering departing VFR and picking up my IFR in the air over Carmel. They advised against it and warned me that they may not give it to me. I studied the weather and a VFR plan B and considered it doable. So I asked for a VFR departure and was cleared for takeoff squawking 1200. "Well, NY Approach for some reason just released you, do you still have the original clearance?" Oh yeah, I was 300' in the air still over the runway but with a wink and a nod the tower let me know that my decision to depart motivated NY approach to let me in despite the jam. I love NY ATC! They are fast talking and attitude rich but I lived there for a dozen years and know that they will respond to a nudge or a beep of the horn better than a "please, no, after you". Thanks for letting me win one! (And if you want to hear NYC Approach doing it's thing so to speak, check this gem out from July Not angry NY ATC works Aer Lingus Flight ) Bill "back home with 2 more approaches in actual and a scud run to homeplate" Watson N215TG On 8/10/2018 6:58 PM, Bill Watson wrote: Just one of those days when nothing lined up properly! No need to overreact though. I know I will continue to pickup clearances in the air in my uncongested piece of the country but I won't hesitate to do it elsewhere when needed. Experience has suggested that it's not the best strategy say in the NYC area where you might get (quickly) scolded before (quickly) getting the clearance. And it can be a handful around Miami where there's bound to be a dozen VFR targets orbiting your climb corridor while ATC tries to locate your plane and your plan. I would suggest that if you include "IFR" somewhere in your initial call-up, you won't be ignored, even in the busiest airspace. And if you eliminate any mention of a opening an IFR flight plan you'll avoid much of what happened on that not so fateful day. Thanks for sharing the experience, I definitely learned some stuff. On 8/9/2018 5:33 PM, Dan Masys wrote: Thanks all for the educational input. I definitely have an IFR departure strategy now for this (and any) uncontrolled airport, particularly in NorCal's jurisdiction: get a clearance plus void time release via phone while on the ground, even if it is blue skies everywhere. It eliminates the issue of getting ignored during initial call-up, and saves any misunderstanding caused by nonstandard radio phraseology. A few additional details on my long story: 1. When the female controller issued my clearance and I read it back correctly, the last thing she said was 'Maintain VFR.', which led me to believe the IFR clearance was not yet active. 2. This was further reinforced when approximately ten minutes later I called Oakland Center and their initial response was 'We don't have anything in the system for you.' After a pause the Center controller remarked, "Oh, here it is", followed by "cleared direct TTE." 3. I also was concerned that initially I had been given a VFR squawk, and asked the Center controller about it. He confirmed that the initial code given was an IFR code, which made the "maintain VFR" remark of the previous controller even more curious. But all of that notwithstanding, I know forevermore not to attempt to 'open an IFR flight plan' even though that phraseology had worked without incident literally for decades. Tailwinds to all, -Dan Masys --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus _____ This email has been checked for viruses by Avast antivirus software. www.avast.com ________________________________________________________________________________
Date: Aug 20, 2018
Subject: Re: RE: Getting beat up by NorCal ATC
I=99ve had similar experiences when flying around busy airspace. They o ften want to dive you to a low altitude for arrivals, but I hate dropping 5 000 feet in cruise. If the weather allows, I say I=99ll just go VFR an d climb 500=99. Usually they either say that=99s fine but keep y our current squawk. Often enough they say they can keep me at my current alt itude or give me a slight deviation and keep me high. They would much rather have you in the system and know who and where you are than have you squawki ng 1200 and doing whatever you feel like. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Aug 20, 2018, at 4:31 PM, Bill Watson wrote: > > Funny that I mentioned clearance strategies in the NYC area. I just retur ned from a trip that included flying in and out of KFRG Republic Farmingdale LI. My experience doesn't add anything to this discussion (Robert Jones la id out the best approach), but I'll share it as a slightly off-topic point o f interest. > > I suddenly had to fly into NYC on short notice. Though my destination was in the Bronx making KHPN Westchester Co the closest satellite AP, I chose t o fly into KFRG because of IFR conditions. I know from experience that comi ng from the south to KHPN will result in a minimum altitude run up through N J in order to clear all the airline traffic into Newark, LaGuardia and GA i nto Teterboro. And while it is busy overhead it can even be busier down bel ow with all the airports along that NJ corridor. It can be a very uncomfort able flight VFR or IFR with rising terrain and low under the Class B shelf t raffic. Turned out KFRG was the right choice and managed to get a perfect l ittle RNAV 01 'T' approach in actual logged. > > Leaving KFRG (or KHPN) back to the south can be a breeze as well with rout ing directly over KJFK. Flying that route VFR is always fun with great view s of the City and big heavy overseas flights getting a turn towards Europe r ight after they spot the "RV at 6,000". It's just cool! > > However, the next leg ended up being NYC to Pittsburgh and that generally r equires a northeast turn to Bridgeport before a wide circumvention of NYC a s you turn west. I got the clearance from the tower and spent almost 15 min utes getting it all into FF so it could decipher the Victor airways and then into the G430. Though previous experience suggested I wouldn't hit many of t he waypoints, traffic and weather were such that I didn't want to add any in the air workload. I just added the new Sentry product to the cockpit so I now had Nexrad displayed on my panel GRTs and the FF iPad. Seems redundant but I really like having both now. Anyway there was a broken line of rainy build-ups but my cleared route was very doable.... then it suddenly wasn't. > > I was cleared to taxi to the 01 but to hold for release from NY ATC. Over head a storm appeared in what was clear blue air 15 minutes ago. It started to rain and the tower said it might be awhile, "there just isn't anywhere t o squeeze you in according to NY". I wasn't going to launch into what quick ly turned into a gusty driving rain. My wife had fortunately lingered after dropping me off and I joined her in the car after shutting down. I still d idn't believe that the storm appeared out of no where but playing it back on the iPad showed that it was exactly what happened, and it happened in 4 to 6 minutes. Just amazing. > > After 30 minutes or so the storm moved on a bit and I restarted and taxied out to the opposite runway only to hold for release once again. I could ea sily see that all NYC traffic was now being funneled through just a few gaps in the storm line and they did not want to add me to the mix. > > With darkness approaching and the chance that my departure be weather bloc ked again, I told the tower I was considering departing VFR and picking up m y IFR in the air over Carmel. They advised against it and warned me that th ey may not give it to me. I studied the weather and a VFR plan B and consid ered it doable. So I asked for a VFR departure and was cleared for takeoff s quawking 1200. > > "Well, NY Approach for some reason just released you, do you still have th e original clearance?" Oh yeah, I was 300' in the air still over the runway but with a wink and a nod the tower let me know that my decision to depart motivated NY approach to let me in despite the jam. > > I love NY ATC! They are fast talking and attitude rich but I lived there f or a dozen years and know that they will respond to a nudge or a beep of the horn better than a "please, no, after you". Thanks for letting me win one! > > (And if you want to hear NYC Approach doing it's thing so to speak, check t his gem out from July Not angry NY ATC works Aer Lingus Flight ) > > Bill "back home with 2 more approaches in actual and a scud run to homepla te" Watson > N215TG > >> On 8/10/2018 6:58 PM, Bill Watson wrote: >> >> Just one of those days when nothing lined up properly! >> >> No need to overreact though. I know I will continue to pickup clearances in the air in my uncongested piece of the country but I won't hesitate to d o it elsewhere when needed. Experience has suggested that it's not the best strategy say in the NYC area where you might get (quickly) scolded before ( quickly) getting the clearance. And it can be a handful around Miami where t here's bound to be a dozen VFR targets orbiting your climb corridor while AT C tries to locate your plane and your plan. >> >> I would suggest that if you include "IFR" somewhere in your initial call -up, you won't be ignored, even in the busiest airspace. And if you elimina te any mention of a opening an IFR flight plan you'll avoid much of what hap pened on that not so fateful day. >> >> Thanks for sharing the experience, I definitely learned some stuff. >> >>> On 8/9/2018 5:33 PM, Dan Masys wrote: >>> >>> Thanks all for the educational input. I definitely have an IFR departur e >>> strategy now for this (and any) uncontrolled airport, particularly in >>> NorCal's jurisdiction: get a clearance plus void time release via phone >>> while on the ground, even if it is blue skies everywhere. It eliminates the >>> issue of getting ignored during initial call-up, and saves any >>> misunderstanding caused by nonstandard radio phraseology. >>> >>> A few additional details on my long story: >>> >>> 1. When the female controller issued my clearance and I read it back >>> correctly, the last thing she said was 'Maintain VFR.', which led me to >>> believe the IFR clearance was not yet active. >>> >>> 2. This was further reinforced when approximately ten minutes later I ca lled >>> Oakland Center and their initial response was 'We don't have anything in the >>> system for you.' After a pause the Center controller remarked, "Oh, her e it >>> is", followed by "cleared direct TTE." >>> >>> 3. I also was concerned that initially I had been given a VFR squawk, an d >>> asked the Center controller about it. He confirmed that the initial cod e >>> given was an IFR code, which made the "maintain VFR" remark of the previ ous >>> controller even more curious. >>> >>> But all of that notwithstanding, I know forevermore not to attempt to 'o pen >>> an IFR flight plan' even though that phraseology had worked without inci dent >>> literally for decades. >>> >>> Tailwinds to all, >>> -Dan Masys >> >> >> --- >> This email has been checked for viruses by Avast antivirus software. >> https://www.avast.com/antivirus >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > ________________________________________________________________________________
Subject: Re: Sun Visor user reports and comparison
Date: Aug 23, 2018
I installed the Rosen 310 sunvisor. It has the outside corner beveled to allow the sunvisor to go up to the windshield. They also slide and can be positioned anyway you like. I attached mine to the upper corner of the door frame. If you have an overhead console, they should clear. Greg... -------- Greg Hale rv10 -- N210KH www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=482659#482659 Attachments: http://forums.matronics.com//files/sun_visor_126.jpg ________________________________________________________________________________
Subject: 2.25" Backup Instruments
Date: Aug 31, 2018
I just realized that while I did a write-up on this, and a youtube video, I haven't actually told anyone on the lists about it yet. The write-up here, has all the history behind this, but the short story is this: I've always wanted a better backup instrument, but the panel space and the fact that I had cut 2.25" holes and didn't have room for square instruments was limiting. I was finally going to just give up and by 2 of the RC Allen 2600-2 instruments this year, but *really* was not feeling good about that decision. But a little google searching led me to a perfect option that I hadn't found before. And, although it wasn't being sold in the U.S., I decided to take the risk and try it and bought 2 for both my RV10 and RV14. Here's the write-up link: https://www.myrv10.com/N104CD/upgrades/20180815/index.html And a quick photo: https://www.myrv10.com/N104CD/upgrades/20180815/RV20180718-200605-1668.jpg I'm not affiliate with them in any way, and have received nothing from them for showing them off, but needless to say, at the price point (under $1000), I've become a fan of theirs and want to share the info about it. Hopefully they'll be distributed in the U.S. soon enough, and it'll be an easier (although it was truly easy already) purchase for us U.S. Builders. Anyway, the video gives some info, as does the write-up, so I won't bore you here, but, after testing this in both planes and while doing aerobatics, I can say that if you're looking for something better to fill a 2.25" hole with, this would make an awesome retrofit. Hopefully it helps some of you who are currently dealing with poor backups. Tim ________________________________________________________________________________
Subject: Re: 2.25" Backup Instruments
Date: Aug 31, 2018
Thanks Tim! This may be a home run for me. I've been looking to upgrade my '3 pack' backup panel with a 1 hole attitude indicator/do all and this looks like the ticket at a good price point. I would desparately like to reconfigure my pilot panel with a larger GRT unit and a single backup unit. I'm not totally comfortable with a solution that requires electrons to work. There are some very fine instruments available in Europe that are often aimed at the glider/powered glider/LSA type market. That's been the case for many years. Only a few get US distribution and some never do. Bill On 8/31/2018 12:08 PM, Tim Olson wrote: > > I just realized that while I did a write-up on this, and a youtube > video, I haven't actually told anyone on the lists about it yet. > > The write-up here, has all the history behind this, but the short > story is this: I've always wanted a better backup instrument, but > the panel space and the fact that I had cut 2.25" holes and didn't > have room for square instruments was limiting. I was finally going > to just give up and by 2 of the RC Allen 2600-2 instruments this > year, but *really* was not feeling good about that decision. > But a little google searching led me to a perfect option that > I hadn't found before. And, although it wasn't being sold in the > U.S., I decided to take the risk and try it and bought 2 for both > my RV10 and RV14. > > Here's the write-up link: > https://www.myrv10.com/N104CD/upgrades/20180815/index.html > > And a quick photo: > https://www.myrv10.com/N104CD/upgrades/20180815/RV20180718-200605-1668.jpg > > > I'm not affiliate with them in any way, and have received nothing > from them for showing them off, but needless to say, at the > price point (under $1000), I've become a fan of theirs and want > to share the info about it. Hopefully they'll be distributed in > the U.S. soon enough, and it'll be an easier (although it was > truly easy already) purchase for us U.S. Builders. > > Anyway, the video gives some info, as does the write-up, so I won't > bore you here, but, after testing this in both planes and while > doing aerobatics, I can say that if you're looking for something > better to fill a 2.25" hole with, this would make an awesome > retrofit. > > Hopefully it helps some of you who are currently dealing with > poor backups. > > Tim > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 31, 2018
Bill, That's exactly where this came from...it was by a company that was really into the glider market in Europe. I was talking to them though and they really would love to be in the experimental market here too. I'm hoping maybe Stein picks up their 2.25" unit at least, so that it's something that everyone can easily get who has old gauges to upgrade. It's kind of a special niche market in that regards, as most U.S. people wouldn't probably want their other EFIS products, and many who would get 3.5" gauges would go with a garmin G5 or something. But, I am betting there are just tons of people out there with 2.25" holes to fill. Regarding the electrons: I forgot to mention that really the only downsides to this gauge that I've found are that: A) it's not as bright if you view it at way far off angles. 45 degrees is good, but if it's way on the other side of your panel, in certain conditions it may be tough. It's useable that way for me on mine though. And B) it doesn't have a built-in battery backup system. But, for that I think it would be real easy to either add your own (especially something like a small IBBS (maybe a mini version)) or, maybe not even worry about it. You described your 2 battery system in a different email...once you get so much redundancy, I'm not sure it's valid to worry about so many simultaneous things going wrong. Is your alternator going to do? Well, you've got 2 batteries, which equals quite a bit of time to get on the ground somewhere. Is your battery dead? Well, you've got an alternator and another battery. I mean, in my plane, I have 2 batteries but one alternator. If that alternator dies, I'm STILL going to be on the ground within an hour, no matter what, and hey, if I had a standby alternator, I would still do the same. You'd be crazy to continue while IFR on a standby alt, if there are good airports below. And, at 160kts or more, you are never more than 30 minutes from an airport in most areas of the U.S....especially the ones with the worst weather. I'm still at least considering doing a D-I-Y independent power source, but, it may be as simple as a small lithium battery pack that I keep charged up, and if my primary systems die, I flip a switch and start drawing power for this gauge from that. Would be pretty simple to do. If you check out the specs on the unit, they say the draw is <2W at 12V. It doesn't take much power to keep this thing running. https://www.kanardia.eu/product/horis/ Tim On 8/31/2018 11:48 AM, Bill Watson wrote: > > Thanks Tim! This may be a home run for me. I've been looking to > upgrade my '3 pack' backup panel with a 1 hole attitude indicator/do > all and this looks like the ticket at a good price point. I would > desparately like to reconfigure my pilot panel with a larger GRT unit > and a single backup unit. I'm not totally comfortable with a solution > that requires electrons to work. > > There are some very fine instruments available in Europe that are > often aimed at the glider/powered glider/LSA type market. That's been > the case for many years. Only a few get US distribution and some > never do. > > Bill ________________________________________________________________________________
Date: Aug 31, 2018
Regarding power backup; with 2 alternators and 2 batteries I now consider any additional backup batteries as an extra maintenance burden with no foreseeable payoff. Batteries rarely fail(internal short), they just slowly go bad. A simple maintenance check of the no-load voltage on the Odyssey's can see that point coming on from quite a distance. If I lose an alternator, I'm fine in VMC and will land immediately under IMC conditions but with no unnecessary urgency. On a trip, a remote failure of an alternator means that I just need a VFR day to take it home and DIY the replacement. Very cost effective options if needed. Having flown with the old vacuum pump setup, not being subject to a slowly failing gyro instrument really keeps you ahead of things if there is a failure. And a dual bus/batt/alt takes care of major electrical component failures. 3 identical EFIS units provides triple redundancy in the air and a welcome ability to send a unit back to the manufacturer while swapping units around so I still have 2 units in front of the pilot. Bill "wants to swap out the backup ADI, ASI, and ALT as well" Watson *Going down to the hangar to see what an updated half a panel might look like* On 8/31/2018 1:23 PM, Tim Olson wrote: > > Bill, > > That's exactly where this came from...it was by a company that was > really into the > glider market in Europe. I was talking to them though and they really > would > love to be in the experimental market here too. I'm hoping maybe Stein > picks up their 2.25" unit at least, so that it's something that > everyone can > easily get who has old gauges to upgrade. It's kind of a special > niche market > in that regards, as most U.S. people wouldn't probably want their > other EFIS > products, and many who would get 3.5" gauges would go with a garmin G5 or > something. But, I am betting there are just tons of people out there > with 2.25" > holes to fill. > > Regarding the electrons: I forgot to mention that really the only > downsides > to this gauge that I've found are that: A) it's not as bright if you > view it > at way far off angles. 45 degrees is good, but if it's way on the > other side > of your panel, in certain conditions it may be tough. It's useable > that way > for me on mine though. And B) it doesn't have a built-in battery backup > system. But, for that I think it would be real easy to either add > your own > (especially something like a small IBBS (maybe a mini version)) or, maybe > not even worry about it. > > You described your 2 battery system in a different email...once you > get so > much redundancy, I'm not sure it's valid to worry about so many > simultaneous things going wrong. Is your alternator going to do? > Well, you've > got 2 batteries, which equals quite a bit of time to get on the ground > somewhere. > Is your battery dead? Well, you've got an alternator and another > battery. > I mean, in my plane, I have 2 batteries but one alternator. If that > alternator > dies, I'm STILL going to be on the ground within an hour, no matter > what, and > hey, if I had a standby alternator, I would still do the same. You'd > be crazy to > continue while IFR on a standby alt, if there are good airports > below. And, at > 160kts or more, you are never more than 30 minutes from an airport in > most areas of the U.S....especially the ones with the worst weather. > I'm still at least considering doing a D-I-Y independent power source, > but, > it may be as simple as a small lithium battery pack that I keep > charged up, > and if my primary systems die, I flip a switch and start drawing power > for this gauge from that. Would be pretty simple to do. > > If you check out the specs on the unit, they say the draw is <2W at 12V. > It doesn't take much power to keep this thing running. > https://www.kanardia.eu/product/horis/ > > Tim > > > On 8/31/2018 11:48 AM, Bill Watson wrote: >> >> Thanks Tim! This may be a home run for me. I've been looking to >> upgrade my '3 pack' backup panel with a 1 hole attitude indicator/do >> all and this looks like the ticket at a good price point. I would >> desparately like to reconfigure my pilot panel with a larger GRT unit >> and a single backup unit. I'm not totally comfortable with a >> solution that requires electrons to work. >> >> There are some very fine instruments available in Europe that are >> often aimed at the glider/powered glider/LSA type market. That's been >> the case for many years. Only a few get US distribution and some >> never do. >> >> Bill > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 31, 2018
Tim, New to the matronics RV10 List and appreciate the write up and video you di d. I just started my RV10 build and need great planning ideas like this whe n I get to the panel. Best, Michael Smith https://rv10airplaneadventures.com/ Sent from my iPhone > On Aug 31, 2018, at 11:08 AM, Tim Olson wrote: > > > I just realized that while I did a write-up on this, and a youtube > video, I haven't actually told anyone on the lists about it yet. > > The write-up here, has all the history behind this, but the short > story is this: I've always wanted a better backup instrument, but > the panel space and the fact that I had cut 2.25" holes and didn't > have room for square instruments was limiting. I was finally going > to just give up and by 2 of the RC Allen 2600-2 instruments this > year, but *really* was not feeling good about that decision. > But a little google searching led me to a perfect option that > I hadn't found before. And, although it wasn't being sold in the > U.S., I decided to take the risk and try it and bought 2 for both > my RV10 and RV14. > > Here's the write-up link: > https://www.myrv10.com/N104CD/upgrades/20180815/index.html > > And a quick photo: > https://www.myrv10.com/N104CD/upgrades/20180815/RV20180718-200605-1668.jpg > > I'm not affiliate with them in any way, and have received nothing > from them for showing them off, but needless to say, at the > price point (under $1000), I've become a fan of theirs and want > to share the info about it. Hopefully they'll be distributed in > the U.S. soon enough, and it'll be an easier (although it was > truly easy already) purchase for us U.S. Builders. > > Anyway, the video gives some info, as does the write-up, so I won't > bore you here, but, after testing this in both planes and while > doing aerobatics, I can say that if you're looking for something > better to fill a 2.25" hole with, this would make an awesome > retrofit. > > Hopefully it helps some of you who are currently dealing with > poor backups. > > Tim > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Sep 01, 2018
Thanks for this info. I too am in the same boat and walked by the rc allen unit for many years, but not able to justify the price. In your research did you consider the MGL Vega color series. They said at Oshkosh they would have an all in one available in several months. http://www.mglavionics.com/html/vega_color_singles.html -Chris N919AR ----- Original Message ----- From: Tim Olson <Tim(at)MyRV10.com> Subject: Re: RV10-List: 2.25" Backup Instruments Bill, That's exactly where this came from...it was by a company that was really into the glider market in Europe. I was talking to them though and they really would love to be in the experimental market here too. I'm hoping maybe Stein picks up their 2.25" unit at least, so that it's something that everyone can easily get who has old gauges to upgrade. It's kind of a special niche market in that regards, as most U.S. people wouldn't probably want their other EFIS products, and many who would get 3.5" gauges would go with a garmin G5 or something. But, I am betting there are just tons of people out there with 2.25" holes to fill. Regarding the electrons: I forgot to mention that really the only downsides to this gauge that I've found are that: A) it's not as bright if you view it at way far off angles. 45 degrees is good, but if it's way on the other side of your panel, in certain conditions it may be tough. It's useable that way for me on mine though. And B) it doesn't have a built-in battery backup system. But, for that I think it would be real easy to either add your own (especially something like a small IBBS (maybe a mini version)) or, maybe not even worry about it. You described your 2 battery system in a different email...once you get so much redundancy, I'm not sure it's valid to worry about so many simultaneous things going wrong. Is your alternator going to do? Well, you've got 2 batteries, which equals quite a bit of time to get on the ground somewhere. Is your battery dead? Well, you've got an alternator and another battery. I mean, in my plane, I have 2 batteries but one alternator. If that alternator dies, I'm STILL going to be on the ground within an hour, no matter what, and hey, if I had a standby alternator, I would still do the same. You'd be crazy to continue while IFR on a standby alt, if there are good airports below. And, at 160kts or more, you are never more than 30 minutes from an airport in most areas of the U.S....especially the ones with the worst weather. I'm still at least considering doing a D-I-Y independent power source, but, it may be as simple as a small lithium battery pack that I keep charged up, and if my primary systems die, I flip a switch and start drawing power for this gauge from that. Would be pretty simple to do. If you check out the specs on the unit, they say the draw is <2W at 12V. It doesn't take much power to keep this thing running. https://www.kanardia.eu/product/horis/ Tim On 8/31/2018 11:48 AM, Bill Watson wrote: > > Thanks Tim! This may be a home run for me. I've been looking to > upgrade my '3 pack' backup panel with a 1 hole attitude indicator/do > all and this looks like the ticket at a good price point. I would > desparately like to reconfigure my pilot panel with a larger GRT unit > and a single backup unit. I'm not totally comfortable with a solution > that requires electrons to work. > > There are some very fine instruments available in Europe that are > often aimed at the glider/powered glider/LSA type market. That's been > the case for many years. Only a few get US distribution and some > never do. > > Bill ________________________________________________________________________________
Date: Sep 01, 2018
Hi Chris, No, I hadn't found that one before, actually. I saw it for the first time maybe a couple weeks ago. I haven't really been a fan of most of the MGL stuff in the past, (years ago, that is) so I didn't really look too hard at them when searching. It does look like a decent gauge, and looks like they've come a ways with it. The actual display looks to be a little smaller, and it would be nice if they put a better photo on the page. Notice how the Kanardia fills most of the circle except for top and bottom, whereas the MGL is smaller and does not use the sides of the circle either. That knob placement in the middle probably gives up some screen real estate I suppose. Anyway, it does look nice. BTW: For people looking for a more analog look for round gauges, Kanardia does have the Indu series: https://www.kanardia.eu/product/indu-round-indicators/ When I was trying to find the EFIS, I talked to the US distributor for the Indu, and he says they are sold thru Aircraft Spruce. I'd consider replacing my 2.25" 0 to 20,000' altimeter to get something more accurate, but with the EFIS already displaying altitude, it would be a waste and just for looks. I just wish all this stuff we have today would have been available back in 2005 when I was buying items for my panel. Especially at the prices they are today. Tim On 9/1/2018 12:03 AM, Chris wrote: > > Thanks for this info. I too am in the same boat and walked by the rc allen unit for many years, but not able to justify the price. In your research did you consider the MGL Vega color series. They said at Oshkosh they would have an all in one available in several months. > > http://www.mglavionics.com/html/vega_color_singles.html > > -Chris > > N919AR ________________________________________________________________________________
Date: Sep 01, 2018
Subject: Seat slide adjustment
My RV-10 is pushing 12 years old and the right seat has always been difficult to slide but not an issue until my wife had wanted to learn to fly. Ive tried various lubricants but sense the real issue is a slight misalignment of the seat rails. Has anyone found a way to tweak these or any other solutions? Thanks, Marcus 40286 ________________________________________________________________________________
Subject: Re: Seat slide adjustment
Date: Sep 01, 2018
I seem to recall the same issue - right seat hard to move, especially when fully aft. I loosened the rail fasteners in the aft end, and the seat motion was much better. I shimmed as needed, re-tightened the bolts. I cannot recall exactly where I put the shims, but it may have been the supporting structure that extends aft and looks like an inverted L. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=482846#482846 ________________________________________________________________________________
Date: Sep 02, 2018
Subject: Matco brakes
For anyone using the Matco dual (four pads per wheel) pad internal rotor brakes, anyone have some experience with these brakes. ________________________________________________________________________________
Subject: Re: Matco brakes
Date: Sep 03, 2018
Yes, I have them installed. Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> on behalf of dlm Sent: Sunday, September 2, 2018 8:41:52 PM Subject: RV10-List: Matco brakes For anyone using the Matco dual (four pads per wheel) pad internal rotor b rakes, anyone have some experience with these brakes. ________________________________________________________________________________
Date: Sep 04, 2018
I had Rosens in my RV10 and they were great. One sore point though is that they scratched the windscreen when one of my bozo buddys slapped them around roughly. To preclude that happening again, I put a dab of pro-seal along the edge that could hit the window - no more problem. Highly recommend the Rosens, but hit them with the dab of pro-seal when you install them. It looks ugly on the new units, but it works. -------- See you OSH '18 Q/B - sold. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=482919#482919 ________________________________________________________________________________
Date: Sep 09, 2018
Subject: Auto Response: RV10-List Digest: 0 Msgs - 09/08/18
Thank you for the email. Please know that Howard has passed away. If you are NOT a solicitor, please contact his wife Judy at tudulu2(at)aol.com ________________________________________________________________________________
Subject: Re: Pop Rivet Dimple Die Question
Date: Sep 11, 2018
I dont remember ever pulling out that die for the 10. -------- Dave Moore RV-6 built and sold RV-10 built and flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483099#483099 ________________________________________________________________________________
Date: Sep 11, 2018
I've used it a lot. Great for when you forgot to dimple something before assembly, or you make a change to the design. I used it when installing the Van's kit for the landing lights because I didn't have a deep enough yoke for a squeezer to reach. Jack Phillips Finishing Kit (Fiberglass Hell) #40610 Smith Mountain Lake, Virginia, where we are quietly awaiting the arrival of Florence -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of nukeflyboy Sent: Tuesday, September 11, 2018 10:02 AM Subject: RV10-List: Re: Pop Rivet Dimple Die Question I dont remember ever pulling out that die for the 10. -------- Dave Moore RV-6 built and sold RV-10 built and flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483099#483099 ________________________________________________________________________________
Date: Sep 11, 2018
Yea, not required but can be useful in a few cases. On Tue, Sep 11, 2018 at 10:51 AM Jack Philips wrote: > > > I've used it a lot. Great for when you forgot to dimple something before > assembly, or you make a change to the design. I used it when installing > the Van's kit for the landing lights because I didn't have a deep enough > yoke for a squeezer to reach. > > Jack Phillips > Finishing Kit (Fiberglass Hell) > #40610 > Smith Mountain Lake, Virginia, where we are quietly awaiting the arrival > of Florence > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] On Behalf Of nukeflyboy > Sent: Tuesday, September 11, 2018 10:02 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Pop Rivet Dimple Die Question > > > I don=C3=A2=82=AC=84=A2t remember ever pulling out that die for the 10. > > -------- > Dave Moore > RV-6 built and sold > RV-10 built and flying > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483099#483099 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Sep 11, 2018
Specifically the 1/8 version? I already bought a replacement 3/32 one that I know I will need. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483115#483115 ________________________________________________________________________________
Subject: GDL 82 Installation
Date: Sep 15, 2018
Has anyone installed the GDL 82 in their RV10? If so, where did you mount t he unit? I'm trying to determine the best place. Thanks in advance, Vicki ________________________________________________________________________________
Subject: Re: GDL 82 Installation
Date: Sep 15, 2018
Logical place is behind the wall in the baggage compartment. Maybe get a kit from Vans like you use for mounting the AHARS or strobes back there. > On Sep 15, 2018, at 8:35 AM, Vicki Jones wrote: > > Has anyone installed the GDL 82 in their RV10? If so, where did you mount the unit? I'm trying to determine the best place. > > Thanks in advance, > Vicki ________________________________________________________________________________
Subject: Conforma Wing Tips
Date: Sep 16, 2018
Hi Is anyone out there using the Aveo Conforma Wing Tips. I have a pair and have an install question. The W-1016 wing tip rib has a bit of a bend on the top side that follows the bend in the standard wing tips. The Conforma tips do not have this bend. I am wondering if other builders forced this bend into the tip or modified the W-1016 rib. Inquiring minds need to know. Cheers Les C-GCWZ - Sold C-GROK - Some assembly required Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483224#483224 ________________________________________________________________________________
Subject: Tooling up
Date: Sep 26, 2018
Have made the decision to build an RV-10 starting late fall or winter. Looking for some guidance on getting tooled up to begin. Laundry list of tools needed, suppliers, and particularly the best quality pneumatic tools that most are using. Rivet gun, drill, squeezer, dimpler, hoses, swivels, etc. Thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483374#483374 ________________________________________________________________________________
Date: Sep 26, 2018
Subject: Re: Tooling up
Look at planetools.com or cleavelandtool. They both have good kits that cover most of what you need. Do a few searches regarding the drdt-2 to see if you want that or the standard c-frame. Highly recommend a pneumatic squeezer but you can get through without it. Welcome to the club and good luck on the project! On Wed, Sep 26, 2018 at 12:36 PM Blizzard wrote: > > Have made the decision to build an RV-10 starting late fall or winter. > Looking for some guidance on getting tooled up to begin. Laundry list of > tools needed, suppliers, and particularly the best quality pneumatic tools > that most are using. Rivet gun, drill, squeezer, dimpler, hoses, swivels, > etc. Thanks. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483374#483374 > > ________________________________________________________________________________
Date: Sep 26, 2018
You'll get some good advice here. Two general things I'd say: 1. I bought one of the 'kits' offered by several vendors. I found it to be a real good starting point, especially for the many small bits of hardware required. Saves a lot of time and they sent generally good stuff. (I'd be specific but I forgot who and don't know if they are still around) 2. I wrote this on another blog and think its a great thing if able to do: "Generally speaking, one of the most informative events during my build was attending a builder class where they had 3 or 4 different brands or styles of each tool, including squeezers, guns, countersinks, cleco pliers, etc. we were encouraged to try each of them. It was a real eye opener in the sense that each student had strong preferences for one flavor or a another and those preferences were all over the map. Some of us even decided that certain tools werent needed at all. Difficult to replicate but something tothinkabout." In other words, there are few 'best tools', but a lot of good ones. Personal preference is a big deal in some categories like hand squeezers, pnuematic tools in general, and some optional tools like pneumatic cleco guns. Enjoy the build! On 9/26/2018 12:29 PM, Blizzard wrote: > > Have made the decision to build an RV-10 starting late fall or winter. Looking for some guidance on getting tooled up to begin. Laundry list of tools needed, suppliers, and particularly the best quality pneumatic tools that most are using. Rivet gun, drill, squeezer, dimpler, hoses, swivels, etc. Thanks. > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Tooling up
Date: Sep 26, 2018
In retrospect, I think the decision on C-frame vs DRDT2 comes down to help. If you plan to be solo most of the time, the DRDT is the way to go. If you have a helper you can save yourself a few hundred dollars and go with the C-Frame.and save the gym membership fee too. I use ATS- Aircraft tool and supply for many of my tools as well as cleaveland and brown for some. Get the plans on the flash drive from Van=99s read what tools you will need and start making a list. Then you can compare the various tool dealers and keep the info in a spreadsheet. The kits are great; I just think they have tools that you may not need for 2 years or more in them. We all know you will need the basic stuff, airtank, lines, connections, drill, squeezer of some kind. Airtank----spend a few dollars here. I am getting ready to upgrade yet once again and could have saved myself the time and money had I done it right the first time. Get a 2 stage, 25 or more gallon, oiled air pump and tankeither that or build a building way away from your workspace for the cheepo tank we can get at Harbor Freight. Airlines and fittings---I got these on Amazon. https://www.amazon.com/gp/product/B000Q759T4/ref=oh_aui_detailpage_o04_ s02?ie=UTF8 &psc=1 I love this hose! Get plenty of the #40, #30 drill bits. From: owner-rv10-list-server(at)matronics.com On Behalf Of Brian Lester Sent: Wednesday, September 26, 2018 12:49 PM Subject: Re: RV10-List: Tooling up Look at planetools.com <http://planetools.com> or cleavelandtool. They both have good kits that cover most of what you need. Do a few searches regarding the drdt-2 to see if you want that or the standard c-frame. Highly recommend a pneumatic squeezer but you can get through without it. Welcome to the club and good luck on the project! On Wed, Sep 26, 2018 at 12:36 PM Blizzard > wrote: > Have made the decision to build an RV-10 starting late fall or winter. Looking for some guidance on getting tooled up to begin. Laundry list of tools needed, suppliers, and particularly the best quality pneumatic tools that most are using. Rivet gun, drill, squeezer, dimpler, hoses, swivels, etc. Thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483374#483374 -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Sep 26, 2018
John Jessen bought a DRDT-2 when it first came out and I promptly put it in my hangar. Best move I ever made. Soon, I'm sure he'll want it back. It's a fantastic tool. Build a carpet covered table around it and you won't regret it. No banging noises and you can do it without an assistant. Pneumatic squeezer with multiple "heads". I miss AVERY tools, but, I'm sure someone has stepped up with an RV builder's kits that's more than adequate. RV-10 Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483378#483378 ________________________________________________________________________________
Subject: Tooling up
Date: Sep 26, 2018
I agree with everything that has been said here, and will add just a bit. It is really helpful to have a good woodcutting bandsaw with the finest toothed metal cutting blade you can get. There are a lot of cuts in aluminum to be made and this will help immensely. Also, although pricey, I found the tungsten bucking bars (I have two) to be literally worth their weight in gold. They are small and able to fit places where steel bars simply can=99t work. I would not consider building an RV without them. Jack Phillips Smith Mountain Lake, Virginia #40610 - Finishing Having escaped Fiberglass Hell, I now find myself in Plexiglas Hell =93 trimming windows and windshield From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of parish(at)parishmoffitt.com Sent: Wednesday, September 26, 2018 1:12 PM Subject: RE: RV10-List: Tooling up In retrospect, I think the decision on C-frame vs DRDT2 comes down to help. If you plan to be solo most of the time, the DRDT is the way to go. If you have a helper you can save yourself a few hundred dollars and go with the C-Frame.and save the gym membership fee too. I use ATS- Aircraft tool and supply for many of my tools as well as cleaveland and brown for some. Get the plans on the flash drive from Van=99s read what tools you will need and start making a list. Then you can compare the various tool dealers and keep the info in a spreadsheet. The kits are great; I just think they have tools that you may not need for 2 years or more in them. We all know you will need the basic stuff, airtank, lines, connections, drill, squeezer of some kind. Airtank----spend a few dollars here. I am getting ready to upgrade yet once again and could have saved myself the time and money had I done it right the first time. Get a 2 stage, 25 or more gallon, oiled air pump and tankeither that or build a building way away from your workspace for the cheepo tank we can get at Harbor Freight. Airlines and fittings---I got these on Amazon. https://www.amazon.com/gp/product/B000Q759T4/ref=oh_aui_detailpage_o04_ s02?ie=UTF8 &psc=1 I love this hose! Get plenty of the #40, #30 drill bits. From: owner-rv10-list-server(at)matronics.com > On Behalf Of Brian Lester Sent: Wednesday, September 26, 2018 12:49 PM Subject: Re: RV10-List: Tooling up Look at planetools.com <http://planetools.com> or cleavelandtool. They both have good kits that cover most of what you need. Do a few searches regarding the drdt-2 to see if you want that or the standard c-frame. Highly recommend a pneumatic squeezer but you can get through without it. Welcome to the club and good luck on the project! On Wed, Sep 26, 2018 at 12:36 PM Blizzard > wrote: > Have made the decision to build an RV-10 starting late fall or winter. Looking for some guidance on getting tooled up to begin. Laundry list of tools needed, suppliers, and particularly the best quality pneumatic tools that most are using. Rivet gun, drill, squeezer, dimpler, hoses, swivels, etc. Thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483374#483374 -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: RV10 building tools
Date: Sep 26, 2018
I am building my second RV10 ii 8 years. First one took 18mo. Second one about done in 9mo. Good places to get tools is Cleveland, Avery Tools and the Yard Store in Wichita. I invested about $5,000 in tools. One thing for sure is that Vans list is very, very deficient. You will be ordering hard ware a lot as you go along also. You can google supply stores for hard ware and non aircraft parts. Harbor Freight has compressors, pop riveters, 2-foot hydraulic jacks, air hoses, right angle grinders, wrench sets, sockets, etc., etc. I composed a list of everything I could think of and then added more to the list as I talked to builders and found out what I needed while building. You can't imagine some of the tools you will need until you get going. Good luck. ________________________________________________________________________________
Date: Sep 26, 2018
SGkgZ3V5cywNCg0KSSBkaWQgYSBmcmFtZSBteXNlbGYgd2VsZGluZyB0aGUgcXVhcnRlciBwaXBl cyBhbmQgbWFkZSBhIGJyYWNrZXQgd2hpY2ggaGFzIHRoZSBzYW1lIHR3byBob2xlcywgdGhhdCBh cmUgaW4gdGhlIGpva2VzIGZvciB0aGUgbWFudWFsIGFuZCBwbmV1bWF0aWMgc3F1ZWV6ZXIuDQpE aWQgY29zdCA5MOKCrCBzdGVlbCBwaXBlLCBzb21lIHdvcmsgb24gdGhlIGxhdGhlIGFuZCB0aGUg bWlsbGluZyBtYXNoaW5lIDpvKQ0KDQpNYWRlIHRoZSBhcm1zIGEgbGl0dGxlIGxvbmdlciB0byBy ZWFjaCBhbGwgZG93biB0byB0aGUgc3RhYmlsaXplciBsZWFkaW5nIGVkZ2UuLi4uDQoNCltjaWQ6 OTRCOTg2NzItQjQ0QS00MjczLUE3NDMtNjMyQTIxRjk0N0IyXQ0KW2NpZDpDN0MzMzY2Ni0zMjc3 LTQ3NTYtQjhGQy1FQTE3REVFRjNBRkRdDQoNCltjaWQ6MjgwRjNFREMtQzY0RC00NTBELUI4NDYt MzUyMUFDMDlBN0FBXQ0KDQpUaGUgYm90dG9tIHBsYXRlIGlzIG5vcm1hbCBzdGVlbCwgc2FuZGVk IGFuZCBwb2xpc2hlZCBzaGlueSwgdGhlbiBwdXQgc29tZSBjYXIgd2F4IGZvciBwcm90ZWN0aW9u Lg0KDQpyZWdhcmRzDQpQZXRlciBBcmluZ2VyIFN0YXJ0ZWQgRGVjIDIwMTUgbm8uNDE3NjENCg0K QW0gMjYuMDkuMjAxOCB1bSAxOTowMiBzY2hyaWViIEJyaWFuIExlc3RlciA8YnJpYW4ubGVzdGVy QGdtYWlsLmNvbTxtYWlsdG86YnJpYW4ubGVzdGVyQGdtYWlsLmNvbT4+Og0KDQpMb29rIGF0IHBs YW5ldG9vbHMuY29tPGh0dHA6Ly9wbGFuZXRvb2xzLmNvbT4gb3IgY2xlYXZlbGFuZHRvb2wuIFRo ZXkgYm90aCBoYXZlIGdvb2Qga2l0cyB0aGF0IGNvdmVyIG1vc3Qgb2Ygd2hhdCB5b3UgbmVlZC4N CkRvIGEgZmV3IHNlYXJjaGVzIHJlZ2FyZGluZyB0aGUgZHJkdC0yIHRvIHNlZSBpZiB5b3Ugd2Fu dCB0aGF0IG9yIHRoZSBzdGFuZGFyZCBjLWZyYW1lLg0KDQpIaWdobHkgcmVjb21tZW5kIGEgcG5l dW1hdGljIHNxdWVlemVyIGJ1dCB5b3UgY2FuIGdldCB0aHJvdWdoIHdpdGhvdXQgaXQuDQoNCldl bGNvbWUgdG8gdGhlIGNsdWIgYW5kIGdvb2QgbHVjayBvbiB0aGUgcHJvamVjdCENCk9uIFdlZCwg U2VwIDI2LCAyMDE4IGF0IDEyOjM2IFBNIEJsaXp6YXJkIDxjZC5zdG9uZUBzYmNnbG9iYWwubmV0 PG1haWx0bzpjZC5zdG9uZUBzYmNnbG9iYWwubmV0Pj4gd3JvdGU6DQotLT4gUlYxMC1MaXN0IG1l c3NhZ2UgcG9zdGVkIGJ5OiAiQmxpenphcmQiIDxjZC5zdG9uZUBzYmNnbG9iYWwubmV0PG1haWx0 bzpjZC5zdG9uZUBzYmNnbG9iYWwubmV0Pj4NCg0KSGF2ZSBtYWRlIHRoZSBkZWNpc2lvbiB0byBi dWlsZCBhbiBSVi0xMCBzdGFydGluZyBsYXRlIGZhbGwgb3Igd2ludGVyLiAgTG9va2luZyBmb3Ig c29tZSBndWlkYW5jZSBvbiBnZXR0aW5nIHRvb2xlZCB1cCB0byBiZWdpbi4gIExhdW5kcnkgbGlz dCBvZiB0b29scyBuZWVkZWQsIHN1cHBsaWVycywgYW5kIHBhcnRpY3VsYXJseSB0aGUgYmVzdCBx dWFsaXR5IHBuZXVtYXRpYyB0b29scyB0aGF0IG1vc3QgYXJlIHVzaW5nLiBSaXZldCBndW4sIGRy aWxsLCBzcXVlZXplciwgZGltcGxlciwgIGhvc2VzLCBzd2l2ZWxzLCBldGMuICBUaGFua3MuDQoN Cg0KDQoNClJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZToNCg0KaHR0cDovL2ZvcnVtcy5tYXRy b25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD00ODMzNzQjNDgzMzc0DQoNCg0KDQoNCg0KDQo9PT09 PT09PT09PQ0KLUxpc3QiIHJlbD0ibm9yZWZlcnJlciIgdGFyZ2V0PSJfYmxhbmsiPmh0dHA6Ly93 d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQo9PT09PT09PT09PQ0KRk9SVU1T IC0NCmVmZXJyZXIiIHRhcmdldD0iX2JsYW5rIj5odHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20N Cj09PT09PT09PT09DQpXSUtJIC0NCmVycmVyIiB0YXJnZXQ9Il9ibGFuayI+aHR0cDovL3dpa2ku bWF0cm9uaWNzLmNvbQ0KPT09PT09PT09PT0NCmIgU2l0ZSAtDQogICAgICAgICAgLU1hdHQgRHJh bGxlLCBMaXN0IEFkbWluLg0KcmVsPSJub3JlZmVycmVyIiB0YXJnZXQ9Il9ibGFuayI+aHR0cDov L3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KPT09PT09PT09PT0NCg0KDQoNCg= ________________________________________________________________________________
Date: Sep 26, 2018
I did my entire build with a pneumatic squeezer and occasionally borrowed a hand squeezer. In retrospect, I would spend less on the pneumatic by getting a used or rebuilt one from Brown or others, and get a good hand squeezer that uses the same yokes. A hand squeezer has much better control and finesse, while the pneumatic is better for multiple rivets. The DRDT-2 is a fantastic tool, especially if building at home and not wanting the noise of hammering on a C-frame. On 9/26/2018 10:57 AM, BrBreck wrote: > > John Jessen bought a DRDT-2 when it first came out and I promptly put it in my hangar. Best move I ever made. Soon, I'm sure he'll want it back. It's a fantastic tool. Build a carpet covered table around it and you won't regret it. No banging noises and you can do it without an assistant. > > Pneumatic squeezer with multiple "heads". I miss AVERY tools, but, I'm sure someone has stepped up with an RV builder's kits that's more than adequate. > > RV-10 Fuselage > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483378#483378 > > > > > > > > > ________________________________________________________________________________
Date: Sep 26, 2018
I should second the recommendation of a tungsten bucking bar. Very rarely used any other bucking bar. Some form of metal cutting bandsaw is very helpful, as is the combination belt/circular sander Harbor Freight offers. Sent from my IBM-360 main frame On Wed, Sep 26, 2018 at 6:43 PM Kelly McMullen wrote: > > I did my entire build with a pneumatic squeezer and occasionally > borrowed a hand squeezer. In retrospect, I would spend less on the > pneumatic by getting a used or rebuilt one from Brown or others, and get > a good hand squeezer that uses the same yokes. A hand squeezer has much > better control and finesse, while the pneumatic is better for multiple > rivets. The DRDT-2 is a fantastic tool, especially if building at home > and not wanting the noise of hammering on a C-frame. > > On 9/26/2018 10:57 AM, BrBreck wrote: > > > > John Jessen bought a DRDT-2 when it first came out and I promptly put it > in my hangar. Best move I ever made. Soon, I'm sure he'll want it back. > It's a fantastic tool. Build a carpet covered table around it and you > won't regret it. No banging noises and you can do it without an assistant. > > > > Pneumatic squeezer with multiple "heads". I miss AVERY tools, but, I'm > sure someone has stepped up with an RV builder's kits that's more than > adequate. > > > > RV-10 Fuselage > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=483378#483378 > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 26, 2018
I purchased all my tools from Cleaveland Tools and harbor freight. The tungs ten bucking bar is worth the price. The fabrication of spar caps and others a re easily accomplished with a band saw, belt and rotary sander, scotchbrite w heel, and drill press. You can see the tools I use at Https:/www.rv10airplaneadventures.com Finishing the rudder tomorrow. Good luck with your build! Michael Smith Sent from my iPhone > On Sep 26, 2018, at 9:09 PM, Kelly McMullen wrote: > > I should second the recommendation of a tungsten bucking bar. Very rarely u sed any other bucking bar. Some form of metal cutting bandsaw is very helpfu l, as is the combination belt/circular sander Harbor Freight offers. > Sent from my IBM-360 main frame > > >> On Wed, Sep 26, 2018 at 6:43 PM Kelly McMullen wrot e: >> >> I did my entire build with a pneumatic squeezer and occasionally >> borrowed a hand squeezer. In retrospect, I would spend less on the >> pneumatic by getting a used or rebuilt one from Brown or others, and get >> a good hand squeezer that uses the same yokes. A hand squeezer has much >> better control and finesse, while the pneumatic is better for multiple >> rivets. The DRDT-2 is a fantastic tool, especially if building at home >> and not wanting the noise of hammering on a C-frame. >> >> On 9/26/2018 10:57 AM, BrBreck wrote: >> > >> > John Jessen bought a DRDT-2 when it first came out and I promptly put i t in my hangar. Best move I ever made. Soon, I'm sure he'll want it back. It's a fantastic tool. Build a carpet covered table around it and you won' t regret it. No banging noises and you can do it without an assistant. >> > >> > Pneumatic squeezer with multiple "heads". I miss AVERY tools, but, I'm sure someone has stepped up with an RV builder's kits that's more than adeq uate. >> > >> > RV-10 Fuselage >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=483378#483378 >> > >> > >> > >> > >> > >> > >> > >> > >> > >> ========== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========== >> >> >> ________________________________________________________________________________
Date: Sep 26, 2018
Hi I suggest a belt sander be added to the tool mix. It is very handy when cleaning up straight cuts on parts. Cheers Les C-GCWZ - Sold C-GROK - Some assembly required Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483395#483395 ________________________________________________________________________________
Subject: Ceramic coating of exhaust
Date: Sep 26, 2018
Hi I was chatting with my painter today and he suggested I look at getting my exhaust tubes ceramic coated. Has anyone tried this on an IO-540 and if so what was the result. Comments / opinions appreciated. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483396#483396 ________________________________________________________________________________
Subject: Re: Ceramic coating of exhaust
Date: Sep 26, 2018
I would check with Vetterman. IIRC he is opposed to a coating, with it retaining more heat in the pipes. On 9/26/2018 8:17 PM, kearney wrote: > > Hi > > I was chatting with my painter today and he suggested I look at getting my exhaust tubes ceramic coated. > > Has anyone tried this on an IO-540 and if so what was the result. > > Comments / opinions appreciated. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483396#483396 > > > > > > > > > ________________________________________________________________________________
Date: Sep 26, 2018
Ceramic coating is too often improperly applied externally and the result is premature exhaust tube failure. Heat transfer is a normal process of combustion. Tread cautiously. John Cox On Wed, Sep 26, 2018, 20:27 Kelly McMullen wrote: > > I would check with Vetterman. IIRC he is opposed to a coating, with it > retaining more heat in the pipes. > > On 9/26/2018 8:17 PM, kearney wrote: > > > > Hi > > > > I was chatting with my painter today and he suggested I look at getting > my exhaust tubes ceramic coated. > > > > Has anyone tried this on an IO-540 and if so what was the result. > > > > Comments / opinions appreciated. > > > > Cheers > > > > Les > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=483396#483396 > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 27, 2018
I'd recommend the cleveland kit as a good starting point. Mine came with a #10 countersink bit which isn't needed, but you will need a #12, which isn't included. I've used the avery squeezer and the cleveland main squeeze--I think the cleveland main squeeze is worth the extra money. I would not recommend the sioux rivet gun. I bought the 3x and while it hasn't stopped working, it leaks and is very inconsistent. I also have an ingersoll-rand AVC 12 (roughly a 2x gun), and I love it. The 1/4" sioux air drill, on the other hand, is fantastic. I know some people just use a cordless, but I think my arm would have fallen off by now. Get a real angle drill, I don't know how people were able to do the build with one of the adapters. In addition to the kit: Get a giant box of the maroon scotch brite. I also got an entire set of numbered drill bits because every now and again the plans call for a random size that's not in the RV kits. Two microstop countersink cages are better than one because you're always switching between #30 and #40. I've also wound up with a large selection of rivet sets because I found that the kit supplied ones only work for 98% of the rivets. ________________________________________________________________________________
Date: Sep 27, 2018
Lot of good information. Thanks to everyone who took the time to post. The more info the better. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483413#483413 ________________________________________________________________________________
Date: Sep 28, 2018
Subject: Battery cable
I'm curious where people run their main cable from the battery to the front of the plane. Through the tunnel? That seems like a pain and I would have to drill some holes in the spar carrythrough or risk interferen ce with the pitch push tube, plus route around the other things in there like fuel and brake lines etc. I have some conduits run from the back up the sides of the fuselage but I have a lot of stuff to run through them and that is a fat cable coming from the battery. Kent #40710 ultra-slow build ________________________________________________________________________________
From: Byron Gillespie <bdgillespie215(at)gmail.com>
Subject: Re: Battery cable
Date: Sep 28, 2018
I ran mine up the left sidewall where it would penetrate the firewall near the relay. Most of the =9Csensitive=9D wires are on the right side wall. Byron > On Sep 28, 2018, at 10:53 AM, Kent Ogden wrote: > > I'm curious where people run their main cable from the battery to the front of the plane. Through the tunnel? That seems like a pain and I would have to drill some holes in the spar carrythrough or risk interference with the pitch push tube, plus route around the other things in there like fuel and brake lines etc. I have some conduits run from the back up the sides of the fuselage but I have a lot of stuff to run through them and that is a fat cable coming from the battery. > > Kent > #40710 ultra-slow build ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Sep 28, 2018
As you point out, the tunnel gets busy. The wires I have in the tunnel are limited to the few things that make such runs convenient: - Three antennas (comm #1 & #2 and transponder). The comm antennas are mounted on the bottom of the tunnel, one on each side. This provides plenty of clearance to the push tube and allows easy access. Transponder is under the passenger seat. (Side note: ADS-B antenna is mounted aft of the baggage compartment along with the ADS-B receiver, connecting wire is in a side conduit. VOR/ILS antenna is in the right wingtip). - Fuel pump. - Audio lines to all four headsets. - Flap wires. - Both stick grip wires. - Red cube wires. Everything else is in conduit, three on each side of the plane. I ended up filling up five of the six conduit runs. If memory serves the #2 welding cable going from the two Master Solenoids mounded at the batteries go up to the starter solenoid on the left side. Both battery ground wires go up the right side. As most of us end up with a lot of stuff aft, more conduit is better than not enough. Carl > On Sep 28, 2018, at 10:53 AM, Kent Ogden wrote: > > I'm curious where people run their main cable from the battery to the front of the plane. Through the tunnel? That seems like a pain and I would have to drill some holes in the spar carrythrough or risk interference with the pitch push tube, plus route around the other things in there like fuel and brake lines etc. I have some conduits run from the back up the sides of the fuselage but I have a lot of stuff to run through them and that is a fat cable coming from the battery. > > Kent > #40710 ultra-slow build ________________________________________________________________________________
Date: Sep 28, 2018
I would keep wires not called for by the plans out of the tunnel as much as possible. I only have transponder (near front of tunnel), fuel pump wires in the tunnel. This is a metal airframe. Absolutely zero need for a ground wire from batteries to panel. The only ground wires needed for noise reduction are those between panel mount items, audio panel and central grounding tabs on firewall. Any item that draws more than a couple amps is better grounded through the airframe. You don't have to believe me, that is summary of discussions on the Aero-Electric forum. You have enough wires fore and aft for positive power, com antennas, ADS-B, autopilot servo(s), nav lights, strobes, etc. Sent from my IBM-360 main frame On Fri, Sep 28, 2018 at 8:31 AM Carl Froehlich wrote: > carl.froehlich(at)verizon.net> > > As you point out, the tunnel gets busy. The wires I have in the tunnel > are limited to the few things that make such runs convenient: > - Three antennas (comm #1 & #2 and transponder). The comm antennas are > mounted on the bottom of the tunnel, one on each side. This provides > plenty of clearance to the push tube and allows easy access. Transponder > is under the passenger seat. (Side note: ADS-B antenna is mounted aft of > the baggage compartment along with the ADS-B receiver, connecting wire is > in a side conduit. VOR/ILS antenna is in the right wingtip). > - Fuel pump. > - Audio lines to all four headsets. > - Flap wires. > - Both stick grip wires. > - Red cube wires. > > Everything else is in conduit, three on each side of the plane. I ended > up filling up five of the six conduit runs. If memory serves the #2 > welding cable going from the two Master Solenoids mounded at the batteries > go up to the starter solenoid on the left side. Both battery ground wires > go up the right side. As most of us end up with a lot of stuff aft, more > conduit is better than not enough. > > Carl > > > On Sep 28, 2018, at 10:53 AM, Kent Ogden wrote: > > > > I'm curious where people run their main cable from the battery to the > front of the plane. Through the tunnel? That seems like a pain and I > would have to drill some holes in the spar carrythrough or risk > interference with the pitch push tube, plus route around the other things > in there like fuel and brake lines etc. I have some conduits run from the > back up the sides of the fuselage but I have a lot of stuff to run through > them and that is a fat cable coming from the battery. > > > > Kent > > #40710 ultra-slow build > > ________________________________________________________________________________
Date: Sep 28, 2018
On 9/28/2018 10:53 AM, Kent Ogden wrote: > I'm curious where people run their main cable from the battery to the > front of the plane. Through the tunnel? That seems like a pain and I > would have to drill some holes in thespar carrythrough or risk > interference with thepitchpush tube, plus route around the other > things in there like fuel and brake lines etc. I have some conduits > run from the back up the sides of the fuselage but I have a lot of > stuff to run through them and that is a fat cablecoming from the battery. > > Kent > #40710 ultra-slow build Up the left side per the Electrical Kit plans. I didn't buy the Electrical kit (most don't) but the plans for it are very useful in terms of wire routing and discovering some parts (custom cable supports and such) that are available from Vans. My electrical system looks nothing like that supported by the kit but some of the parts and particularly the fat cable route to the firewall are very useful in many designs. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Oil in air filter box
Date: Sep 28, 2018
Hi all, I am just in the last stages of ground testing before first flight. I have a new IO-540 from Vans and have run it somewhere between 1 and 2 hours for run-ups and taxi tests. After each engine run I have found a little oil inside the throttle body, some on the alternate air door, and some which appears to have been blown out the gap between the filter box and its support plate. That implies the oil finds its way into the filter box during running or priming. Has anyone else seen this and know if it is normal during the first hours of break-in? I have called Lycoming and they dont have a magic explanation, other than preservation oil still making its way out of the engine. That seems unlikely to me, so Im looking for altrenative explanations. Cheers Gordon Anderson Switzreland 41015 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483422#483422 ________________________________________________________________________________
Subject: Re: Oil in air filter box
Date: Sep 28, 2018
I am guessing they're right on with it just being preservative oil. I'd think it should end after a couple flights. Tim On 9/28/2018 11:16 AM, Gordon Anderson wrote: > > Hi all, I am just in the last stages of ground testing before first flight. I have a new IO-540 from Vans and have run it somewhere between 1 and 2 hours for run-ups and taxi tests. > After each engine run I have found a little oil inside the throttle body, some on the alternate air door, and some which appears to have been blown out the gap between the filter box and its support plate. That implies the oil finds its way into the filter box during running or priming. > Has anyone else seen this and know if it is normal during the first hours of break-in? I have called Lycoming and they dont have a magic explanation, other than preservation oil still making its way out of the engine. That seems unlikely to me, so Im looking for altrenative explanations. > > Cheers > > Gordon Anderson > Switzreland 41015 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483422#483422 > > > > > > > > > ________________________________________________________________________________
Date: Sep 28, 2018
I put my EarthX ETX 900 on the engine side of the firewall. I have a 43 poun d prop with spinner so weight and balance will likely work out fine. I did t he computations using Vans factory aircraft as a starting point and it was c lose to a wash. I ran my starter cable back down the left side of the BPE oi l pan and up and over the engine mount using adel clamps on the engine mount . The battery weighs about 5 pounds and the battery cable will be about 18 =9D long. The starter cable is the longest. The Battery is on the lower r ight side of the firewall. Yes it is more expensive, but it is a lot lighter and I saved several pounds of #2 cable. They also last much longer and the d ischarge rate while parked is close to insignificant. Robert Jones > On Sep 28, 2018, at 09:16, Bill Watson wrote: > >> On 9/28/2018 10:53 AM, Kent Ogden wrote: >> I'm curious where people run their main cable from the battery to the fro nt of the plane. Through the tunnel? That seems like a pain and I would ha ve to drill some holes in the spar carrythrough or risk interference with t he pitch push tube, plus route around the other things in there like fuel an d brake lines etc. I have some conduits run from the back up the s ides of the fuselage but I have a lot of stuff to run through them and that i s a fat cable coming from the battery. >> >> Kent >> #40710 ultra-slow build > Up the left side per the Electrical Kit plans. > > I didn't buy the Electrical kit (most don't) but the plans for it are very useful in terms of wire routing and discovering some parts (custom cable su pports and such) that are available from Vans. My electrical system looks n othing like that supported by the kit but some of the parts and particularly the fat cable route to the firewall are very useful in many designs. > > > > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > ________________________________________________________________________________
Subject: Brake Issue
Date: Sep 30, 2018
On my second condition inspection and came up with brake issue I thought I would throw out to experts before I call Grove tomorrow. I was inspecting my right brake and noticed excessive wear on the break pad on inboard/piston side...much more than opposite pad or pads on left brakes. I then noticed that the piston on the brake is in a extended position which accounts for uneven wear. Replacing pads no big deal, but I need to figure out why piston stays out (it won't push back in). I have pulled brake pedals all the way aft and doesn't seem to help. This does not happen on left brake (piston and wear are normal). Don't see any leaks. It was braking fine on all flights since last condition inspection and I didn't notice this at last condition inspection. I was hoping for suggestions or thoughts on the issue...hoping to not have to drain fluid. I have attached photo. Thanks. Matt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483474#483474 Attachments: http://forums.matronics.com//files/hs97czxpqw2zzxzrvvpfg_126.jpg ________________________________________________________________________________
Subject: Re: Brake Issue
Date: Sep 30, 2018
Try pulling the piston out and use a little scotch brite on the piston and the cylinder. Sounds like a bit of grit is keeping it from moving freely. grumpy N184JM > On Sep 30, 2018, at 11:50 AM, mhealydds wrote: > > > On my second condition inspection and came up with brake issue I thought I would throw out to experts before I call Grove tomorrow. I was inspecting my right brake and noticed excessive wear on the break pad on inboard/piston side...much more than opposite pad or pads on left brakes. I then noticed that the piston on the brake is in a extended position which accounts for uneven wear. Replacing pads no big deal, but I need to figure out why piston stays out (it won't push back in). I have pulled brake pedals all the way aft and doesn't seem to help. This does not happen on left brake (piston and wear are normal). Don't see any leaks. It was braking fine on all flights since last condition inspection and I didn't notice this at last condition inspection. I was hoping for suggestions or thoughts on the issue...hoping to not have to drain fluid. I have attached photo. Thanks. Matt > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483474#483474 > > > > > Attachments: > > http://forums.matronics.com//files/hs97czxpqw2zzxzrvvpfg_126.jpg > > > > > > ________________________________________________________________________________
Date: Sep 30, 2018
Its common to have to disassemble the caliper and replace the oring on the piston when the brake linings get low. I would pull it off and replace the oring and look for any problems in working the piston in the caliper. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Sep 30, 2018, at 12:50 PM, mhealydds wrote: > > > On my second condition inspection and came up with brake issue I thought I would throw out to experts before I call Grove tomorrow. I was inspecting my right brake and noticed excessive wear on the break pad on inboard/piston side...much more than opposite pad or pads on left brakes. I then noticed that the piston on the brake is in a extended position which accounts for uneven wear. Replacing pads no big deal, but I need to figure out why piston stays out (it won't push back in). I have pulled brake pedals all the way aft and doesn't seem to help. This does not happen on left brake (piston and wear are normal). Don't see any leaks. It was braking fine on all flights since last condition inspection and I didn't notice this at last condition inspection. I was hoping for suggestions or thoughts on the issue...hoping to not have to drain fluid. I have attached photo. Thanks. Matt > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483474#483474 > > > > > Attachments: > > http://forums.matronics.com//files/hs97czxpqw2zzxzrvvpfg_126.jpg > > > > > > ________________________________________________________________________________
Date: Sep 30, 2018
Odds are you rolled the O ring on the puck - so the puck no longer moves freely. Replace it, fill and bleed. I had this happen on one side at about the 100 hour point. First indication was a very worn tire after I noticed one brake dragging. These puck O rings are good to have in your airplane stuff I carry with me box, along with a set of brake pads. Carl > On Sep 30, 2018, at 12:50 PM, mhealydds wrote: > > > On my second condition inspection and came up with brake issue I thought I would throw out to experts before I call Grove tomorrow. I was inspecting my right brake and noticed excessive wear on the break pad on inboard/piston side...much more than opposite pad or pads on left brakes. I then noticed that the piston on the brake is in a extended position which accounts for uneven wear. Replacing pads no big deal, but I need to figure out why piston stays out (it won't push back in). I have pulled brake pedals all the way aft and doesn't seem to help. This does not happen on left brake (piston and wear are normal). Don't see any leaks. It was braking fine on all flights since last condition inspection and I didn't notice this at last condition inspection. I was hoping for suggestions or thoughts on the issue...hoping to not have to drain fluid. I have attached photo. Thanks. Matt > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483474#483474 > > > > > Attachments: > > http://forums.matronics.com//files/hs97czxpqw2zzxzrvvpfg_126.jpg > > > > > > ________________________________________________________________________________
Date: Sep 30, 2018
What others have said. I don't know with the Grove calipers, but the Cleveland calipers used on the RV-10 are somewhat prone to having the piston cock a little to one side, and you can see it on wear. It also results in brake fluid leaking well before the pad is worn out. I've not had that problem with Clevelands on other aircraft, but this particular caliper seems a little deficient in that regard. New O-ring, new brake pad, and a good dry lube (silicone or similar) on the pins the caliper floats on. If it isn't floating freely that will cause wear on one pad. On 9/30/2018 10:14 AM, Carl Froehlich wrote: > > Odds are you rolled the O ring on the puck - so the puck no longer moves freely. Replace it, fill and bleed. I had this happen on one side at about the 100 hour point. First indication was a very worn tire after I noticed one brake dragging. > > These puck O rings are good to have in your airplane stuff I carry with me box, along with a set of brake pads. > > Carl > >> On Sep 30, 2018, at 12:50 PM, mhealydds wrote: >> >> >> On my second condition inspection and came up with brake issue I thought I would throw out to experts before I call Grove tomorrow. I was inspecting my right brake and noticed excessive wear on the break pad on inboard/piston side...much more than opposite pad or pads on left brakes. I then noticed that the piston on the brake is in a extended position which accounts for uneven wear. Replacing pads no big deal, but I need to figure out why piston stays out (it won't push back in). I have pulled brake pedals all the way aft and doesn't seem to help. This does not happen on left brake (piston and wear are normal). Don't see any leaks. It was braking fine on all flights since last condition inspection and I didn't notice this at last condition inspection. I was hoping for suggestions or thoughts on the issue...hoping to not have to drain fluid. I have attached photo. Thanks. Matt >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=483474#483474 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/hs97czxpqw2zzxzrvvpfg_126.jpg >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Oct 01, 2018
-----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Miller Sent: Sunday, September 30, 2018 12:00 PM Subject: Re: RV10-List: Brake Issue Try pulling the piston out and use a little scotch brite on the piston and the cylinder. Sounds like a bit of grit is keeping it from moving freely. grumpy N184JM > On Sep 30, 2018, at 11:50 AM, mhealydds wrote: > > > On my second condition inspection and came up with brake issue I thought I would throw out to experts before I call Grove tomorrow. I was inspecting my right brake and noticed excessive wear on the break pad on inboard/piston side...much more than opposite pad or pads on left brakes. I then noticed that the piston on the brake is in a extended position which accounts for uneven wear. Replacing pads no big deal, but I need to figure out why piston stays out (it won't push back in). I have pulled brake pedals all the way aft and doesn't seem to help. This does not happen on left brake (piston and wear are normal). Don't see any leaks. It was braking fine on all flights since last condition inspection and I didn't notice this at last condition inspection. I was hoping for suggestions or thoughts on the issue...hoping to not have to drain fluid. I have attached photo. Thanks. Matt > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483474#483474 > > > > > Attachments: > > http://forums.matronics.com//files/hs97czxpqw2zzxzrvvpfg_126.jpg > > > John, You should check to see if your piston is reversed. It's not that difficult to bleed the brakes. Joe> > > ________________________________________________________________________________
Date: Oct 01, 2018
Thanks all I will work on that today. Luckily local shop had those o-rings in stock. Thanks again. Matt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483502#483502 ________________________________________________________________________________
Date: Oct 04, 2018
Subject: RV10 Matco brakes
I have the following spare parts available for the Matco heavy duty brakes for the RV10' 2 wheels including bearings, spacers and washers $75 each 2 sets of two brake shoes with new pads $75 each 1 bag misc. shoe spacers and bolts $50 I was an original prototype user of these brakes; since I fly from paved, lengthy strips I find I do not need the extra stopping power. Anyone using the Matco brakes may call concerning these serviceable parts. 480-626-4048 ________________________________________________________________________________
Date: Oct 05, 2018
Subject: seat belts
A long time ago (2006) in a land far way, my buddy and I developed a procedure to anchor inertial seat belts in the RV10 "lid". One of the users of that procedure kept a copy of that website; I believe his location was in UT or possibly Canada. Please contact me if you a copy of same as another new builder is considering it. Thanks. 480-626-4048 ________________________________________________________________________________
Subject: Magneto gasket
Date: Oct 06, 2018
After adjusting timing (off 3 degrees) and doing a leak check after second annual condition inspection I have an oil leak under right mag on stock IO-540 engine. I assume that means I need new gasket. I see two part numbers. Which gasket do I need? Matt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483645#483645 ________________________________________________________________________________
Date: Oct 06, 2018
Subject: Re: Magneto gasket
For the C4B5 and D4A5 I only see one gasket for the mag and adapter: 62224. What other part number do you see? Do you have an engine other than the most common 250/260hp IO-540? Sent from my IBM-360 main frame On Sat, Oct 6, 2018 at 10:33 AM mhealydds wrote: > > After adjusting timing (off 3 degrees) and doing a leak check after second > annual condition inspection I have an oil leak under right mag on stock > IO-540 engine. I assume that means I need new gasket. I see two part > numbers. Which gasket do I need? > > Matt > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483645#483645 > > ________________________________________________________________________________
Subject: Flap Actuator Motor
Date: Oct 18, 2018
Had an issue with my flaps not moving on occasion. Was going to replace the unit (approx $450) but found a paper on Vans site (Support|Contstruction FAQ|Flap Motor Maintenance) called Flaky Flap Motors. It said that in 2002 they switched suppliers and the new units used a motor made by Pittman. It said the problem appeared to be in the previous units using a Motion Systems motor. Mine was the newer unit (Pittman) but the reported problem apparently was caused by grease from the gearbox getting into the motor causing failure. Even though mine was the newer motor I followed the procedure and it seems to have solved the problem. Since this was a little hard to find I'll copy the procedure below. The original has several highly useful pictures. Note: there some washers on the end shaft. Keep track of the order in which they were installed. also a couple of small o rings. Albert Gardner RV-10 N991RV Yuma, AZ (Home of the Arizona Territorial Prison) (Not a current or former inmate) FLAKY FLAP MOTORS Over the years, we=99ve received the occasional report of intermittent flap motor operation. We never found a consistent problem. Sometimes it was poor wiring or a bad ground, a couple times it was a switch giving up, occasionally the problem would be with the motor itself. But problems were rare, and the flap motors in our demonstrator airplanes worked day in, day out, for years. In 2002, we switched suppliers, replacing the units we=99d received from Motion Systems with a custom made unit powered by a Pittman brand motor. The new units can identified by the Van=99s logo incised on the aluminum gear box housing. Not long after the change was made we got a significant number of complaints about motors failing after just a few hours. Naturally, we suspected the new motorsbut as it turns out, the newer =9CVan=99s=9D units were not the culprit. Instead, the problem seems to appear in one of the last batches of Motion Systems units. These we received about three years ago and they are now starting to appear in finished airplanes. The problem is usually caused by an excess of grease in the gearbox (that=99s the almost cubical casting where the flap actuator tube and the motor meet at right angles). As the unit spins, hydraulic pressure pushes grease back into the motor unit and coats the windings, commutator and brushes. Grease is an insulator, and when the brushes are insulated from the commutator, yo=99 motor don=99 motate no mo=99. Cleanliness is next towell, it makes your flap motor work better too. You can remove the cap on the end of the motor and wipe the commutator shaft clean and your motor will work for a while. But to really solve the problem, all the grease must be removed from the flap motor or the whole cycle will just repeat. Remove the actuator unit from the aircraft and take it a clean, well-lighted bench. Assemble a small jar of clean lacquer thinner, some cotton swabs, a Phillips screwdriver, an allen key set, tweezers and some of those very thin wire ties that come on loaves of bread. If you=99re of an age and have a magnifying visor, bring it. Remove the Phillips screws from the motor assembly and gently, carefully, remove the steel cap from the end of the motor. Inside is a black plastic horseshoe wrapped around a shaft. Notice the three small holes in the heel of the horseshoe. Turn over the cap and look inside =93 see the little index pin? See where it goes =93 that hole in the horseshoe? Remember that. There are several washers on the shaft. These must be reinstalled in the order they came out, so carefully note and preserve their orientation as you remove them. Slide the horseshoe gently off the motor shaft. A couple of little copper colored things are going to jump out (those are the brushes). They are retained by very thin wire springs. Now use the allen key to remove the bolts holding the motor to the gear box. Pull the motor winding/shaft assembly out of the cylindrical housing (the magnets will resist, but it will come out) and inspect it for grease and corruption. Clean the motor and brush assembly with lacquer thinner or some other clean solvent. Scoop any excess grease out of the gearbox. There should be enough to lubricate the gears, but the whole cavity does not need to be full of grease. Be careful not to disturb the tiny o-ring in the recess of the gearbox. Clean the commutator (the shiny part of the shaft that the brushes ride on) with the cotton swabs or even a bit of scotchbrite. Reassembling the motor can be more difficult than getting it apart. Begin by teasing the little springs that go behind the brushes back into their recess and tie them back with the wire ties. This may take some patience When the springs are held back, use the tweezers to re-insert the brushes, taking care that curve worn on their contact surface matches the curve of the motor shaft. Tie the brushes back. Insert the gear end of the motor shaft back into the gearbox and check to see the baseplate is down tight. Put the cylinder/magnet back around the motor =93 the little notch in the rim should be on end away from the gearbox. Gently, carefully put the horseshoe back around the shaft and slide the wire ties out. The springs should force the brushes up against the commutator. Reinstall the washers. Reinstall the cap with the long Phillips screws. Find a 12-v battery and test the motor by holding the wires against the posts. Reversing the wires should make the motor run the other direction. The motor unit and screws securing the housing to the gearbox. The long phillips-head and short allen-head screws have been removed or backed off and the motor separated from the gear box. The motor cap and the horseshoe shaped brush housing have been removed. The brushes have popped out of the housing, and if you look closely, you can see the tiny spring that must be behind the brush when it is re-inserted. The springs keep the brushes up against the motor armature. The motor armature has been removed from within the motor housing and the washers removed from the motor shaft. Tucking the springs and brushes back into their cubbyholes is the toughest part of the exercise. Be careful not to bend the springs. A small spacer made of any non-magnetic scrap, that keeps the brushes pushed back will help get the =9Chorseshoe=9D back on the shaft. ________________________________________________________________________________
Subject: emagair P200
Date: Oct 27, 2018
I just wonder, if anyone has the 6 cyl P200 emagair ignition in use and what the experience is so far. Cheers Werner ________________________________________________________________________________
Date: Oct 29, 2018
Subject: Re: emagair P200
SGkgV2VybmVyLA0KSSBjb250YWN0ZWQgQnJhZCBhdCBFTWFnIHRvZGF5IGFuZCBpZiBJIHVuZGVy c3Rvb2QgaGlzIHJlcGx5IGNvcnJlY3RseSwgdGhlDQpQMjAwIGlzbuKAmXQgYXZhaWxhYmxlIHll dC4NCg0K4oCcU2FmVCBzd2l0Y2ggaXMgYSBmZWF0dXJlIG9mIG91ciBuZXcgU2VyaWVzIDIwMFQg KHNvb24gdG8gcmVsZWFzZSBhcyBhIHNpeA0KY3lsaW5kZXIgbW9kZWwpLuKAnA0KDQpGV0lXLA0K THluDQoNCk9uIFNhdCwgT2N0IDI3LCAyMDE4IGF0IDE0OjAzIFdlcm5lciBTY2huZWlkZXIgPGds YXN0YXJAZ214Lm5ldD4gd3JvdGU6DQoNCj4gLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBi eTogV2VybmVyIFNjaG5laWRlciA8Z2xhc3RhckBnbXgubmV0Pg0KPg0KPg0KPiBJIGp1c3Qgd29u ZGVyLCBpZiBhbnlvbmUgaGFzIHRoZSA2IGN5bCBQMjAwIGVtYWdhaXIgaWduaXRpb24gaW4gdXNl IGFuZA0KPiB3aGF0IHRoZSBleHBlcmllbmNlIGlzIHNvIGZhci4NCj4NCj4gQ2hlZXJzIFdlcm5l cg0KPiBfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PQ0KPiBfLT0gICAgICAgICAgLSBUaGUgUlYxMC1MaXN0IEVtYWlsIEZvcnVtIC0N Cj4gXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dz ZQ0KPiBfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlw dGlvbiwNCj4gXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hh dCwgRkFRLA0KPiBfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KPiBfLT0NCj4g Xy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQo+ IF8tPQ0KPiBfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PQ0KPiBfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1T IC0NCj4gXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBG b3J1bXMhDQo+IF8tPQ0KPiBfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQo+ IF8tPQ0KPiBfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PQ0KPiBfLT0gICAgICAgICAgICAgIC0gTkVXIE1BVFJPTklDUyBMSVNUIFdJ S0kgLQ0KPiBfLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9uaWNzIEVtYWlsIExpc3QgV2lr aSENCj4gXy09ICAgLS0+IGh0dHA6Ly93aWtpLm1hdHJvbmljcy5jb20NCj4gXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj4gXy09 ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KPiBfLT0gIFRoYW5r IHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KPiBfLT0gICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQo+IF8tPSAgIC0tPiBodHRwOi8v d3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQo+IF8tPT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQo+DQo+DQo+DQo+DQo ________________________________________________________________________________
Date: Oct 30, 2018
Hi Lyn, you could be registered on a preseries with a depot and got a better price and this once are delivered as far as I heard since summer so I thought I ask if someone is already using one :) Did you ask for pricing as well? Thanks anyway Cheers Werner On 30.10.2018 07:26, Lyn Robertson wrote: > Hi Werner, > I contacted Brad at EMag today and if I understood his reply correctly, > the P200 isnt available yet. > > SafT switch is a feature of our new Series 200T (soon to release as a > six cylinder model). > > FWIW, > Lyn > ________________________________________________________________________________
Date: Oct 30, 2018
Here are some websites to check out.=C2- These units have been installed on quite a few planes for quite a while now.=C2- They are almost complet e with FAA testing (which has been a total pain in the ass) to be instlled as a direct mag replacement on various certified planes.=C2- Same group t hat started Skytec starters and Plane Power alternators.=C2- Matronics Email Lists :: View topic - SureFly Electronic Ignition | | | | Matronics Email Lists :: View topic - SureFly Electronic Ignition | | | https://backcountrypilot.org/forum/new-electronic-ignition-system-coming-19 698 http://www.aero-news.net/index.cfm?do=main.ajTextPost&id=442b456a-4f61- 4c62-b0fa-c7e31435fb30 son(at)gmail.com> wrote: Hi Werner,I contacted Brad at EMag today and if I understood his reply cor rectly, the P200 isn=99t available yet.=C2- =9CSafT switch is a feature of our new Series 200T (soon to release a s a six cylinder model).=9C FWIW,Lyn On Sat, Oct 27, 2018 at 14:03 Werner Schneider wrote: I just wonder, if anyone has the 6 cyl P200 emagair ignition in use and what the experience is so far. Cheers Werner -List" rel="noreferrer" target="_blank">http://www.matronics.com/Naviga tor?RV10-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Oct 30, 2018
Hi Werner, I am just doing preliminary investigations into which electronic ignition to use so I haven't asked for pricing yet. I am building an RV-14A and so far have only the empennage and wings completed so I have some time before making a decision about my ignition system. I will be interested to see if anyone replies to your original post. The P200T seems like a big improvement over previous models. While I really like the PMag conceptually, there are several reports out there of "loss of timing" which concern me. People have said that the loss of timing can occur in such a way as to prevent the engine from running even if there is still a function mag available. E-Mag's solution (for models prior to P200T) is to simply "turn off" the offending mag but it takes time to determine which one has failed and the failure might occur during a phase of flight when extra time just isn't available. If I understand the intent, the "tandem" approach in the model P200T means that, in the event of a loss of timing, one could simply switch both mags to "fixed" (without knowing specifically which one failed) and have the equivalent of traditional mags. Switching the mags is more or less instantaneous so no time is lost troubleshooting. Anyway, this new model seems to address the only real concern I had about using PMags. I have heard really great things about them, otherwise. Best regards, Lyn On Tue, Oct 30, 2018 at 2:07 AM Werner Schneider wrote: > > Hi Lyn, > > you could be registered on a preseries with a depot and got a better > price and this once are delivered as far as I heard since summer so I > thought I ask if someone is already using one :) > > Did you ask for pricing as well? > > Thanks anyway > > Cheers > > Werner > > On 30.10.2018 07:26, Lyn Robertson wrote: > > Hi Werner, > > I contacted Brad at EMag today and if I understood his reply correctly, > > the P200 isn=99t available yet. > > > > =9CSafT switch is a feature of our new Series 200T (soon to relea se as a > > six cylinder model).=9C > > > > FWIW, > > Lyn > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Nov 01, 2018
Subject: PLEASE READ - Matronics Email List 2018 Fund Raiser During
November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are 9 great gifts to choose from! There's something for everyone, to be sure. Please make your List Contribution using any one of three secure methods including using a Credit Card, PayPal, or by Personal Check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 02, 2018
Subject: Cleveland Brake Caliper Model Number
Does anyone have the Cleveland brake caliper model number used on the -10. Vans delivered this a wheel set and does not have the brake caliper model number. I need a rebuild kit and cannot read the label on the caliper. I did not take a picture of it at install. I believe it is a 30-59 but not sure. Thanks, Jim C 40192 - N312F ________________________________________________________________________________
Subject: Re: Cleveland Brake Caliper Model Number
Date: Nov 02, 2018
Hi Jim, I think it's a 30-59E. At least that's what my maintenance notes say: https://www.skygeek.com/cleveland-30-59e-brake-assembly.html Here's a whole Cleveland pdf on it: https://www.parker.com/literature/WBtech.PDF And a page I saved once for myself: https://www.myrv10.com/tips/maintenance/Cleveland_Wheels_and_Brakes/Cleveland_RV10_Brakes.pdf Tim PS: You're reminding me why I sent in my 2018 Donation to Matronics yesterday. Because: A) I like you guys, and B) This is the fastest method to get this kind of information. On 11/2/18 1:26 PM, Jim Combs wrote: > Does anyone have the Cleveland brake caliper model number used on the > -10. Vans delivered this a wheel set and does not have the brake > caliper model number. I need a rebuild kit and cannot read the label on > the caliper. I did not take a picture of it at install. > > I believe it is a 30-59 but not sure. > > Thanks, Jim C > > 40192 - N312F > > ________________________________________________________________________________
Date: Nov 02, 2018
Great! - Thanks On Fri, Nov 2, 2018 at 2:46 PM Tim Olson wrote: > > Hi Jim, > > I think it's a 30-59E. At least that's what my maintenance notes say: > > https://www.skygeek.com/cleveland-30-59e-brake-assembly.html > > Here's a whole Cleveland pdf on it: > https://www.parker.com/literature/WBtech.PDF > > And a page I saved once for myself: > > > https://www.myrv10.com/tips/maintenance/Cleveland_Wheels_and_Brakes/Cleveland_RV10_Brakes.pdf > > Tim > > > PS: You're reminding me why I sent in my 2018 Donation to Matronics > yesterday. > > Because: > A) I like you guys, and > > B) This is the fastest method to get this kind of information. > > > On 11/2/18 1:26 PM, Jim Combs wrote: > > Does anyone have the Cleveland brake caliper model number used on the > > -10. Vans delivered this a wheel set and does not have the brake > > caliper model number. I need a rebuild kit and cannot read the label on > > the caliper. I did not take a picture of it at install. > > > > I believe it is a 30-59 but not sure. > > > > Thanks, Jim C > > > > 40192 - N312F > > > > > > ________________________________________________________________________________
Date: Nov 02, 2018
All you need to "overhaul" caliper is the correct O-ring, unless there are damaged parts. I suppose brake pads as well. Sent from my IBM-360 main frame On Fri, Nov 2, 2018 at 12:32 PM Jim Combs wrote: > Great! - Thanks > > On Fri, Nov 2, 2018 at 2:46 PM Tim Olson wrote: > >> >> Hi Jim, >> >> I think it's a 30-59E. At least that's what my maintenance notes say: >> >> https://www.skygeek.com/cleveland-30-59e-brake-assembly.html >> >> Here's a whole Cleveland pdf on it: >> https://www.parker.com/literature/WBtech.PDF >> >> And a page I saved once for myself: >> >> >> https://www.myrv10.com/tips/maintenance/Cleveland_Wheels_and_Brakes/Cleveland_RV10_Brakes.pdf >> >> Tim >> >> >> PS: You're reminding me why I sent in my 2018 Donation to Matronics >> yesterday. >> >> Because: >> A) I like you guys, and >> >> B) This is the fastest method to get this kind of information. >> >> >> >> >> >> >> >> On 11/2/18 1:26 PM, Jim Combs wrote: >> > Does anyone have the Cleveland brake caliper model number used on the >> > -10. Vans delivered this a wheel set and does not have the brake >> > caliper model number. I need a rebuild kit and cannot read the label >> on >> > the caliper. I did not take a picture of it at install. >> > >> > I believe it is a 30-59 but not sure. >> > >> > Thanks, Jim C >> > >> > 40192 - N312F >> > >> > >> >> ========== >> br> fts!) >> r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> -Matt Dralle, List Admin. >> ========== >> -List" rel="noreferrer" target="_blank"> >> http://www.matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> ________________________________________________________________________________
Date: Nov 02, 2018
Where can I get a correct o-ring made from a material that is compatible with the fluid and will work at the brake temperatures? Jim C On Fri, Nov 2, 2018 at 6:02 PM Kelly McMullen wrote: > All you need to "overhaul" caliper is the correct O-ring, unless there are > damaged parts. I suppose brake pads as well. > > Sent from my IBM-360 main frame > > > On Fri, Nov 2, 2018 at 12:32 PM Jim Combs wrote: > >> Great! - Thanks >> >> On Fri, Nov 2, 2018 at 2:46 PM Tim Olson wrote: >> >>> >>> Hi Jim, >>> >>> I think it's a 30-59E. At least that's what my maintenance notes say: >>> >>> https://www.skygeek.com/cleveland-30-59e-brake-assembly.html >>> >>> Here's a whole Cleveland pdf on it: >>> https://www.parker.com/literature/WBtech.PDF >>> >>> And a page I saved once for myself: >>> >>> >>> https://www.myrv10.com/tips/maintenance/Cleveland_Wheels_and_Brakes/Cleveland_RV10_Brakes.pdf >>> >>> Tim >>> >>> >>> PS: You're reminding me why I sent in my 2018 Donation to Matronics >>> yesterday. >>> >>> Because: >>> A) I like you guys, and >>> >>> B) This is the fastest method to get this kind of information. >>> >>> >>> >>> >>> >>> >>> >>> On 11/2/18 1:26 PM, Jim Combs wrote: >>> > Does anyone have the Cleveland brake caliper model number used on the >>> > -10. Vans delivered this a wheel set and does not have the brake >>> > caliper model number. I need a rebuild kit and cannot read the label >>> on >>> > the caliper. I did not take a picture of it at install. >>> > >>> > I believe it is a 30-59 but not sure. >>> > >>> > Thanks, Jim C >>> > >>> > 40192 - N312F >>> > >>> > >>> >>> ========== >>> br> fts!) >>> r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com >>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>> -Matt Dralle, List Admin. >>> ========== >>> -List" rel="noreferrer" target="_blank"> >>> http://www.matronics.com/Navigator?RV10-List >>> ========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ========== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> ________________________________________________________________________________
Date: Nov 02, 2018
So I did find on Aircraft Spruce web page a Cleveland Brake Applications PDF that listed Vans RV series aircraft including the -10. It has a part breakdown of the 30-59E and listed the correct O-Ring. The cleveland part is 101-05200 also known as a MS28775-224 military spec part. Got them ordered. Great list and support from fellow RV-10 people. Thanks, Jim Combs N312F On Fri, Nov 2, 2018 at 6:02 PM Kelly McMullen wrote: > All you need to "overhaul" caliper is the correct O-ring, unless there are > damaged parts. I suppose brake pads as well. > > Sent from my IBM-360 main frame > > > On Fri, Nov 2, 2018 at 12:32 PM Jim Combs wrote: > >> Great! - Thanks >> >> On Fri, Nov 2, 2018 at 2:46 PM Tim Olson wrote: >> >>> >>> Hi Jim, >>> >>> I think it's a 30-59E. At least that's what my maintenance notes say: >>> >>> https://www.skygeek.com/cleveland-30-59e-brake-assembly.html >>> >>> Here's a whole Cleveland pdf on it: >>> https://www.parker.com/literature/WBtech.PDF >>> >>> And a page I saved once for myself: >>> >>> >>> https://www.myrv10.com/tips/maintenance/Cleveland_Wheels_and_Brakes/Cleveland_RV10_Brakes.pdf >>> >>> Tim >>> >>> >>> PS: You're reminding me why I sent in my 2018 Donation to Matronics >>> yesterday. >>> >>> Because: >>> A) I like you guys, and >>> >>> B) This is the fastest method to get this kind of information. >>> >>> >>> >>> >>> >>> >>> >>> On 11/2/18 1:26 PM, Jim Combs wrote: >>> > Does anyone have the Cleveland brake caliper model number used on the >>> > -10. Vans delivered this a wheel set and does not have the brake >>> > caliper model number. I need a rebuild kit and cannot read the label >>> on >>> > the caliper. I did not take a picture of it at install. >>> > >>> > I believe it is a 30-59 but not sure. >>> > >>> > Thanks, Jim C >>> > >>> > 40192 - N312F >>> > >>> > >>> >>> ========== >>> br> fts!) >>> r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com >>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>> -Matt Dralle, List Admin. >>> ========== >>> -List" rel="noreferrer" target="_blank"> >>> http://www.matronics.com/Navigator?RV10-List >>> ========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ========== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> ________________________________________________________________________________
Date: Nov 02, 2018
I think I got some from a friend in a split order from McMaster Carr. We sw itched to Viton for I think higher temp resistance. It=99s been a loo ooong time now. I use the synthetic version of aviation brake fluid. Tim > On Nov 2, 2018, at 5:41 PM, Jim Combs wrote: > > Where can I get a correct o-ring made from a material that is compatible w ith the fluid and will work at the brake temperatures? > > Jim C > >> On Fri, Nov 2, 2018 at 6:02 PM Kelly McMullen wrote: >> All you need to "overhaul" caliper is the correct O-ring, unless there ar e damaged parts. I suppose brake pads as well. >> Sent from my IBM-360 main frame >> >> >>> On Fri, Nov 2, 2018 at 12:32 PM Jim Combs wrote: >>> Great! - Thanks >>> >>>> On Fri, Nov 2, 2018 at 2:46 PM Tim Olson wrote: >>>> >>>> Hi Jim, >>>> >>>> I think it's a 30-59E. At least that's what my maintenance notes say: >>>> >>>> https://www.skygeek.com/cleveland-30-59e-brake-assembly.html >>>> >>>> Here's a whole Cleveland pdf on it: >>>> https://www.parker.com/literature/WBtech.PDF >>>> >>>> And a page I saved once for myself: >>>> >>>> https://www.myrv10.com/tips/maintenance/Cleveland_Wheels_and_Brakes/Cle veland_RV10_Brakes.pdf >>>> >>>> Tim >>>> >>>> >>>> PS: You're reminding me why I sent in my 2018 Donation to Matronics >>>> yesterday. >>>> >>>> Because: >>>> A) I like you guys, and >>>> >>>> B) This is the fastest method to get this kind of information. >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> On 11/2/18 1:26 PM, Jim Combs wrote: >>>> > Does anyone have the Cleveland brake caliper model number used on the >>>> > -10. Vans delivered this a wheel set and does not have the brake >>>> > caliper model number. I need a rebuild kit and cannot read the label on >>>> > the caliper. I did not take a picture of it at install. >>>> > >>>> > I believe it is a 30-59 but not sure. >>>> > >>>> > Thanks, Jim C >>>> > >>>> > 40192 - N312F >>>> > >>>> > >>>> >>>> ========== >>>> br> fts!) >>>> r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com >>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribut ion >>>> -Matt Dralle, List Admin. >>>> ========== >>>> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Na vigator?RV10-List >>>> ========== >>>> FORUMS - >>>> eferrer" target="_blank">http://forums.matronics.com >>>> ========== >>>> WIKI - >>>> errer" target="_blank">http://wiki.matronics.com >>>> ========== >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribut ion >>>> ========== >>>> >>>> >>>> ________________________________________________________________________________
Date: Nov 02, 2018
Jim I think I have some that you could have. I can check tomorrow. These are the Viton that Tim is talking about. Also I used the Royco 756, Higher flash po int. I did get them at McMaster Geoff Sent from my iPhone Geoff Combs Aerosport Modeling & Design > On Nov 2, 2018, at 9:28 PM, Tim Olson wrote: > > I think I got some from a friend in a split order from McMaster Carr. We s witched to Viton for I think higher temp resistance. It=99s been a lo oooong time now. I use the synthetic version of aviation brake fluid. > Tim > >> On Nov 2, 2018, at 5:41 PM, Jim Combs wrote: >> >> Where can I get a correct o-ring made from a material that is compatible w ith the fluid and will work at the brake temperatures? >> >> Jim C >> >>> On Fri, Nov 2, 2018 at 6:02 PM Kelly McMullen wrote: >>> All you need to "overhaul" caliper is the correct O-ring, unless there a re damaged parts. I suppose brake pads as well. >>> Sent from my IBM-360 main frame >>> >>> >>>> On Fri, Nov 2, 2018 at 12:32 PM Jim Combs wrote: >>>> Great! - Thanks >>>> >>>>> On Fri, Nov 2, 2018 at 2:46 PM Tim Olson wrote: >>>>> >>>>> Hi Jim, >>>>> >>>>> I think it's a 30-59E. At least that's what my maintenance notes say: >>>>> >>>>> https://www.skygeek.com/cleveland-30-59e-brake-assembly.html >>>>> >>>>> Here's a whole Cleveland pdf on it: >>>>> https://www.parker.com/literature/WBtech.PDF >>>>> >>>>> And a page I saved once for myself: >>>>> >>>>> https://www.myrv10.com/tips/maintenance/Cleveland_Wheels_and_Brakes/Cl eveland_RV10_Brakes.pdf >>>>> >>>>> Tim >>>>> >>>>> >>>>> PS: You're reminding me why I sent in my 2018 Donation to Matronics >>>>> yesterday. >>>>> >>>>> Because: >>>>> A) I like you guys, and >>>>> >>>>> B) This is the fastest method to get this kind of information. >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> On 11/2/18 1:26 PM, Jim Combs wrote: >>>>> > Does anyone have the Cleveland brake caliper model number used on th e >>>>> > -10. Vans delivered this a wheel set and does not have the brake >>>>> > caliper model number. I need a rebuild kit and cannot read the labe l on >>>>> > the caliper. I did not take a picture of it at install. >>>>> > >>>>> > I believe it is a 30-59 but not sure. >>>>> > >>>>> > Thanks, Jim C >>>>> > >>>>> > 40192 - N312F >>>>> > >>>>> > >>>>> >>>>> ========== >>>>> br> fts!) >>>>> r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com >>>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribu tion >>>>> -Matt Dralle, List Admin. >>>>> ========== >>>>> -List" rel="noreferrer" target="_blank">http://www.matronics.com/N avigator?RV10-List >>>>> ========== >>>>> FORUMS - >>>>> eferrer" target="_blank">http://forums.matronics.com >>>>> ========== >>>>> WIKI - >>>>> errer" target="_blank">http://wiki.matronics.com >>>>> ========== >>>>> b Site - >>>>> -Matt Dralle, List Admin. >>>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribu tion >>>>> ========== >>>>> >>>>> >>>>> ________________________________________________________________________________
Date: Nov 02, 2018
I have several people that I know with -10s and i ordered extras as well. I have spares now too. Thanks, Jim C On Fri, Nov 2, 2018 at 9:33 PM Tim Olson wrote: > I think I got some from a friend in a split order from McMaster Carr. We > switched to Viton for I think higher temp resistance. It=99s been a looooong > time now. I use the synthetic version of aviation brake fluid. > Tim > > On Nov 2, 2018, at 5:41 PM, Jim Combs wrote: > > Where can I get a correct o-ring made from a material that is compatible > with the fluid and will work at the brake temperatures? > > Jim C > > On Fri, Nov 2, 2018 at 6:02 PM Kelly McMullen wrote: > >> All you need to "overhaul" caliper is the correct O-ring, unless there >> are damaged parts. I suppose brake pads as well. >> >> Sent from my IBM-360 main frame >> >> >> >> On Fri, Nov 2, 2018 at 12:32 PM Jim Combs wrote: >> >>> Great! - Thanks >>> >>> On Fri, Nov 2, 2018 at 2:46 PM Tim Olson wrote: >>> >>>> >>>> Hi Jim, >>>> >>>> I think it's a 30-59E. At least that's what my maintenance notes say: >>>> >>>> https://www.skygeek.com/cleveland-30-59e-brake-assembly.html >>>> >>>> Here's a whole Cleveland pdf on it: >>>> https://www.parker.com/literature/WBtech.PDF >>>> >>>> And a page I saved once for myself: >>>> >>>> >>>> https://www.myrv10.com/tips/maintenance/Cleveland_Wheels_and_Brakes/Cl eveland_RV10_Brakes.pdf >>>> >>>> Tim >>>> >>>> >>>> PS: You're reminding me why I sent in my 2018 Donation to Matronics >>>> yesterday. >>>> >>>> Because: >>>> A) I like you guys, and >>>> >>>> B) This is the fastest method to get this kind of information. >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> On 11/2/18 1:26 PM, Jim Combs wrote: >>>> > Does anyone have the Cleveland brake caliper model number used on th e >>>> > -10. Vans delivered this a wheel set and does not have the brake >>>> > caliper model number. I need a rebuild kit and cannot read the labe l >>>> on >>>> > the caliper. I did not take a picture of it at install. >>>> > >>>> > I believe it is a 30-59 but not sure. >>>> > >>>> > Thanks, Jim C >>>> > >>>> > 40192 - N312F >>>> > >>>> > >>>> >>>> ========== >>>> br> fts!) >>>> r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com >>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribu tion >>>> -Matt Dralle, List Admin. >>>> ========== >>>> -List" rel="noreferrer" target="_blank"> >>>> http://www.matronics.com/Navigator?RV10-List >>>> ========== >>>> FORUMS - >>>> eferrer" target="_blank">http://forums.matronics.com >>>> ========== >>>> WIKI - >>>> errer" target="_blank">http://wiki.matronics.com >>>> ========== >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribu tion >>>> ========== >>>> >>>> >>>> >>>> ________________________________________________________________________________
Date: Nov 03, 2018
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 03, 2018
Thanks, I have already ordered the parts. I did have to buy 25 (Min Qnty) but I want spares and I have two other -10 owners that asked me to order some for them too. So we will share as well. Thanks, Jim C On Fri, Nov 2, 2018 at 9:47 PM g.combs wrote: > Jim > I think I have some that you could have. I can check tomorrow. These are > the Viton that Tim is talking about. Also I used the Royco 756, Higher > flash point. > I did get them at McMaster > > Geoff > > Sent from my iPhone > Geoff Combs > Aerosport Modeling & Design > > > On Nov 2, 2018, at 9:28 PM, Tim Olson wrote: > > I think I got some from a friend in a split order from McMaster Carr. We > switched to Viton for I think higher temp resistance. It=99s been a looooong > time now. I use the synthetic version of aviation brake fluid. > Tim > > On Nov 2, 2018, at 5:41 PM, Jim Combs wrote: > > Where can I get a correct o-ring made from a material that is compatible > with the fluid and will work at the brake temperatures? > > Jim C > > On Fri, Nov 2, 2018 at 6:02 PM Kelly McMullen wrote: > >> All you need to "overhaul" caliper is the correct O-ring, unless there >> are damaged parts. I suppose brake pads as well. >> >> Sent from my IBM-360 main frame >> >> >> >> On Fri, Nov 2, 2018 at 12:32 PM Jim Combs wrote: >> >>> Great! - Thanks >>> >>> On Fri, Nov 2, 2018 at 2:46 PM Tim Olson wrote: >>> >>>> >>>> Hi Jim, >>>> >>>> I think it's a 30-59E. At least that's what my maintenance notes say: >>>> >>>> https://www.skygeek.com/cleveland-30-59e-brake-assembly.html >>>> >>>> Here's a whole Cleveland pdf on it: >>>> https://www.parker.com/literature/WBtech.PDF >>>> >>>> And a page I saved once for myself: >>>> >>>> >>>> https://www.myrv10.com/tips/maintenance/Cleveland_Wheels_and_Brakes/Cl eveland_RV10_Brakes.pdf >>>> >>>> Tim >>>> >>>> >>>> PS: You're reminding me why I sent in my 2018 Donation to Matronics >>>> yesterday. >>>> >>>> Because: >>>> A) I like you guys, and >>>> >>>> B) This is the fastest method to get this kind of information. >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> On 11/2/18 1:26 PM, Jim Combs wrote: >>>> > Does anyone have the Cleveland brake caliper model number used on th e >>>> > -10. Vans delivered this a wheel set and does not have the brake >>>> > caliper model number. I need a rebuild kit and cannot read the labe l >>>> on >>>> > the caliper. I did not take a picture of it at install. >>>> > >>>> > I believe it is a 30-59 but not sure. >>>> > >>>> > Thanks, Jim C >>>> > >>>> > 40192 - N312F >>>> > >>>> > >>>> >>>> ========== >>>> br> fts!) >>>> r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com >>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribu tion >>>> -Matt Dralle, List Admin. >>>> ========== >>>> -List" rel="noreferrer" target="_blank"> >>>> http://www.matronics.com/Navigator?RV10-List >>>> ========== >>>> FORUMS - >>>> eferrer" target="_blank">http://forums.matronics.com >>>> ========== >>>> WIKI - >>>> errer" target="_blank">http://wiki.matronics.com >>>> ========== >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> rel="noreferrer" target="_blank">http://www.matronics.com/contribu tion >>>> ========== >>>> >>>> >>>> >>>> ________________________________________________________________________________
Date: Nov 05, 2018
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2018
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that ilk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, Commercial-greade Internet Connection, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 07, 2018
Subject: FS: Aerosport landing light kit
Hi list, I have an unused Aerosport cowl landing light kit for the RV-10: https://www.aerosportproducts.com/landinglight.htm This is the universal version where you supply your own light. Aerosport can provide mounting plates for MR-16, Kuntzelman, and Baja Designs LED lights or a precut blank for a "custom" installation. $170 shipped in the US. David ________________________________________________________________________________
Date: Nov 07, 2018
David, I'm like this if it is still available. Albert Gardner N991RV Yuma, AZ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Carr Sent: Wednesday, November 07, 2018 5:11 PM Subject: RV10-List: FS: Aerosport landing light kit Hi list, I have an unused Aerosport cowl landing light kit for the RV-10: https://www.aerosportproducts.com/landinglight.htm This is the universal version where you supply your own light. Aerosport can provide mounting plates for MR-16, Kuntzelman, and Baja Designs LED lights or a precut blank for a "custom" installation. $170 shipped in the US. David ________________________________________________________________________________
Date: Nov 08, 2018
Subject: Re: FS: Aerosport landing light kit
Hi Albert, I sent you a direct email reply---just wanted to make sure it went through. David On Wed, Nov 7, 2018 at 10:29 PM, Albert wrote: > David, I'm like this if it is still available. > > Albert Gardner > > N991RV > > Yuma, AZ > > > *From:* owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list- > server(at)matronics.com] *On Behalf Of *David Carr > *Sent:* Wednesday, November 07, 2018 5:11 PM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: FS: Aerosport landing light kit > > > Hi list, > > > I have an unused Aerosport cowl landing light kit for the RV-10: > > https://www.aerosportproducts.com/landinglight.htm > > > This is the universal version where you supply your own light. Aerosport > can provide mounting plates for MR-16, Kuntzelman, and Baja Designs LED > lights or a precut blank for a "custom" installation. > > > $170 shipped in the US. > > > David > ________________________________________________________________________________
Date: Nov 09, 2018
Subject: List Contribution - Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Subject: RV-10 VS Osprey
Date: Nov 10, 2018
Went out flying this morning and when I got back it looks like someone is parked in my spot! ________________________________________________________________________________
Date: Nov 10, 2018
Subject: Re: RV-10 VS Osprey
I bet the Osprey has a shorter takeoff roll Sent from my iPhone > On Nov 10, 2018, at 4:19 PM, Albert wrote: > > Went out flying this morning and when I got back it looks like someone is parked in my spot! > > <20181110_092911 (6) (Small).jpg> ________________________________________________________________________________
From: Robert Brunkenhoefer <robertbrunk(at)mac.com>
Date: Nov 10, 2018
The damn nerve of some people !!! Robert E Brunkenhoefer > On Nov 10, 2018, at 3:27 PM, Dick Gurley wrote: > > I bet the Osprey has a shorter takeoff roll > > Sent from my iPhone > >> On Nov 10, 2018, at 4:19 PM, Albert wrote: >> >> Went out flying this morning and when I got back it looks like someone i s parked in my spot! >> >> <20181110_092911 (6) (Small).jpg> ________________________________________________________________________________
Date: Nov 10, 2018
Maybe your plane.... you think an Osprey can get off the ground in under 3 00'? tt.net> wrote: I bet the Osprey has a shorter takeoff roll Sent from my iPhone On Nov 10, 2018, at 4:19 PM, Albert wrote: Went out flying this morning and when I=C2- got back it looks like someon e is parked in my spot! =C2- <20181110_092911 (6) (Small).jpg> ________________________________________________________________________________
Date: Nov 10, 2018
The Osprey can do a vertical takeoff, but they seldom do. We had one come vi sit us. They planned a training mission to come see and test fly an RV-10 at KGNV. Pretty cool machine. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Nov 10, 2018, at 6:41 PM, Don McDonald wro te: > > Maybe your plane.... you think an Osprey can get off the ground in under 3 00'? > net> wrote: > > > I bet the Osprey has a shorter takeoff roll > > Sent from my iPhone > >> On Nov 10, 2018, at 4:19 PM, Albert wrote: >> > > Went out flying this morning and when I got back it looks like someone is parked in my spot! > > > >> <20181110_092911 (6) (Small).jpg> ________________________________________________________________________________
Date: Nov 11, 2018
Subject: WX-500
Hi, I'm wondering if anyone has installed a WX-500 in their RV-10 and if so if they know where the preferred mounting location is for the antenna?=C2- T he obvious place to put it is under the tailcone near the leading edge of t he tailplane but that might not be the quietest.=C2- The L3 installation manual says the plane should be surveyed to find the best location but I wo nder if there might be a generic position that others have found? Many thanks in anticipation Rodger (40437)It's 43C today and just warming up! ________________________________________________________________________________
Date: Nov 11, 2018
I hope that you left them a Birthday card! Happy Birthday 243! Semper Fi Read this topic online here: http://forums.matronics.com/viewtopic.php?p=484775#484775 ________________________________________________________________________________
Date: Nov 11, 2018
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 13, 2018
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 15, 2018
Subject: Make Sure You're Listed! List of Contributors Coming Soon!
Dear Listers, There's just two more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 17, 2018
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 19, 2018
Subject: LOC
Dear Listers, Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by popping a personal check in the mail to: Matronics Email Lists c/o Matt Dralle 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Email List Administrator ________________________________________________________________________________
Subject: Door interior
Date: Nov 19, 2018
Ive seen a few photos of doors with a fabric interior lining. Can anyone provide a source to have them made or anyone have any patterns. Abby at Flightline no longer makes them. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485330#485330 ________________________________________________________________________________
Subject: Re: Door interior
Date: Nov 19, 2018
Mine are fabric covered, but it isn't anything that is special. Abby did sell me the fabric, but all I did was glue it on and trim it. You could buy suitable fabric anywhere and just glue and stretch it in place and do what I did. Tim On 11/19/2018 8:29 PM, whodja wrote: > > Ive seen a few photos of doors with a fabric interior lining. Can anyone provide a source to have them made or anyone have any patterns. Abby at Flightline no longer makes them. > > Thanks > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=485330#485330 > > > > > > > > > ________________________________________________________________________________
From: John MacCallum <john.maccallum(at)bigpond.com>
Date: Nov 20, 2018
Did you just use spray on contact like 3M? Cheers John MacCallum VHDUU Sent from my iPhone > On 20 Nov 2018, at 1:45 pm, Tim Olson wrote: > > > Mine are fabric covered, but it isn't anything that is special. Abby > did sell me the fabric, but all I did was glue it on and trim it. > You could buy suitable fabric anywhere and just glue and stretch it in > place and do what I did. > Tim > > >> On 11/19/2018 8:29 PM, whodja wrote: >> Ive seen a few photos of doors with a fabric interior lining. Can anyone provide a source to have them made or anyone have any patterns. Abby at Flightline no longer makes them. >> Thanks >> Read this topic online here: >> http://forums.matronics.com/viewtopic.php?p=485330#485330 > > > > > ________________________________________________________________________________
Date: Nov 20, 2018
I may have it on my website, I'm not sure. It's been 12 years now. ;) But, I think it was this stuff: 3M Super 77 Spray Adhesive. https://www.uline.com/Product/Detail/S-18767/Aerosols/3M-Super-77-Spray-Adhesive-Low-VOC?pricode=WB1191&gadtype=pla&id=S-18767&gclid=Cj0KCQiA_s7fBRDrARIsAGEvF8TA3pVgSr2ak_N8E0-rq0Anfi_eQPeywRLPkYodmdy17YR79MXFy6AaAnLTEALw_wcB&gclsrc=aw.ds Tim On 11/20/18 12:11 AM, John MacCallum wrote: > > Did you just use spray on contact like 3M? > > Cheers > John MacCallum > VHDUU > ________________________________________________________________________________
Date: Nov 20, 2018
FWIW, I installed Abbey's interior and have been pretty happy with it. However, after having covered the doors and flown it for a few years, I decided to remove the fabric and just paint the doors in conjunction with a door latch upgrade. I prefer the doors painted. I have the fabric headliner in. The thing I never could get to work well is the window trim. A more careful and patient person could do a better job I'm sure. But the fabric covered rubber round (or double round) they supplied is subject to heat expansion and contraction which I found makes it impossible to glue and have it stay in place while sitting on the ramp in say, Phoenix. Just FYI. Bill "finishing up a panel upgrade where the new large screen EFIS isn't working and won't be in time for the trip to Mom and TG day GD!" Watson ....time to punt. On 11/19/2018 9:29 PM, whodja wrote: > > Ive seen a few photos of doors with a fabric interior lining. Can anyone provide a source to have them made or anyone have any patterns. Abby at Flightline no longer makes them. > > Thanks > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=485330#485330 --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Nov 20, 2018
I used 3m Super 77 on some of the stuff. But there is also a purpose-made spray on glue for headliners available at auto supply places. Works perfectly for headliners and doors - a bit easier to work with than Super 77. On 11/20/2018 9:29 AM, Tim Olson wrote: > > I may have it on my website, I'm not sure. It's been 12 years now. ;) > But, I think it was this stuff: 3M Super 77 Spray Adhesive. > > https://www.uline.com/Product/Detail/S-18767/Aerosols/3M-Super-77-Spray-Adhesive-Low-VOC?pricode=WB1191&gadtype=pla&id=S-18767&gclid=Cj0KCQiA_s7fBRDrARIsAGEvF8TA3pVgSr2ak_N8E0-rq0Anfi_eQPeywRLPkYodmdy17YR79MXFy6AaAnLTEALw_wcB&gclsrc=aw.ds > > > Tim > > On 11/20/18 12:11 AM, John MacCallum wrote: >> >> >> Did you just use spray on contact like 3M? >> >> Cheers >> John MacCallum >> VHDUU >> --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Nov 21, 2018
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 21, 2018
I painted the interior of my doors. I used an epoxy based single stage paint with a flattening agent. To add texture to the surface I came back and spayed with a 1-3psi setting on the paint gun. This "spattered" liquid paint on to the surface. When it dries it looks slightly textured. I did this for all the interior surfaces that show. I also have the Aerosport headliner and interior panels. I matched the paint to the kydex interior panels. It is very difficult to put the material on the door surface and get a nice looking finish around the edges and windows. In addition, it adds weight to the door, which will cause you to use the higher pressure gas struts. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485473#485473 ________________________________________________________________________________
Date: Nov 21, 2018
Ditto on the weight and higher pressure gas cylinder. On 11/21/2018 9:27 AM, bill.peyton wrote: > > I painted the interior of my doors. I used an epoxy based single stage paint with a flattening agent. To add texture to the surface I came back and spayed with a 1-3psi setting on the paint gun. This "spattered" liquid paint on to the surface. When it dries it looks slightly textured. I did this for all the interior surfaces that show. I also have the Aerosport headliner and interior panels. I matched the paint to the kydex interior panels. It is very difficult to put the material on the door surface and get a nice looking finish around the edges and windows. In addition, it adds weight to the door, which will cause you to use the higher pressure gas struts. > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=485473#485473 > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Nov 21, 2018
I wouldn't say it's a guaranteed problem. I'm still running my original 2005 gas cylinders, with fabric covered doors, and it hasn't been a problem yet. The doors are fully resting open right now, in fact. I also think that having at least some sort of covering will help a little to deaden sound. That said, a painted door will look just fine too. I wouldn't hesitate to put light fabric on again, myself. Tim On 11/21/2018 12:21 PM, Bill Watson wrote: > > Ditto on the weight and higher pressure gas cylinder. > > On 11/21/2018 9:27 AM, bill.peyton wrote: >> >> I painted the interior of my doors. I used an epoxy based single >> stage paint with a flattening agent. To add texture to the surface I >> came back and spayed with a 1-3psi setting on the paint gun. This >> "spattered" liquid paint on to the surface. When it dries it looks >> slightly textured. I did this for all the interior surfaces that >> show. I also have the Aerosport headliner and interior panels. I >> matched the paint to the kydex interior panels. It is very difficult >> to put the material on the door surface and get a nice looking finish >> around the edges and windows. In addition, it adds weight to the >> door, which will cause you to use the higher pressure gas struts. >> >> -------- >> Bill >> WA0SYV >> Aviation Partners, LLC >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=485473#485473 >> >> >> >> >> >> >> >> >> >> > > > --- > This email has been checked for viruses by Avast antivirus software. > https://www.avast.com/antivirus > > > > ________________________________________________________________________________
Date: Nov 21, 2018
Im still on regular cylinders with the same light fabric from Abby that Tim describes. I also have the flush door handles. No problems. David Maib > On Nov 21, 2018, at 2:07 PM, Tim Olson wrote: > > > I wouldn't say it's a guaranteed problem. I'm still > running my original 2005 gas cylinders, with fabric covered > doors, and it hasn't been a problem yet. The doors are > fully resting open right now, in fact. > > I also think that having at least some sort of covering > will help a little to deaden sound. That said, a painted > door will look just fine too. I wouldn't hesitate to put > light fabric on again, myself. > Tim > >> On 11/21/2018 12:21 PM, Bill Watson wrote: >> Ditto on the weight and higher pressure gas cylinder. >>> On 11/21/2018 9:27 AM, bill.peyton wrote: >>> >>> I painted the interior of my doors. I used an epoxy based single stage paint with a flattening agent. To add texture to the surface I came back and spayed with a 1-3psi setting on the paint gun. This "spattered" liquid paint on to the surface. When it dries it looks slightly textured. I did this for all the interior surfaces that show. I also have the Aerosport headliner and interior panels. I matched the paint to the kydex interior panels. It is very difficult to put the material on the door surface and get a nice looking finish around the edges and windows. In addition, it adds weight to the door, which will cause you to use the higher pressure gas struts. >>> >>> -------- >>> Bill >>> WA0SYV >>> Aviation Partners, LLC >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=485473#485473 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> --- >> This email has been checked for viruses by Avast antivirus software. >> https://www.avast.com/antivirus > > > > > ________________________________________________________________________________
Date: Nov 21, 2018
This discussion is very interesting. I have been kicking around what to do with my interior, doors, inside, maybe overhead console, maybe not, headliner, etc. It is about decision time if I am ever going to finish the plane. I need to change some personal priorities. I appreciate the help some of you have provided when I had specific questions I directed at a few members. Always enjoy advice from those who have gone before. David On 11/21/2018 11:41 AM, David Maib wrote: > > Im still on regular cylinders with the same light fabric from Abby that Tim describes. I also have the flush door handles. No problems. > > David Maib > > >> On Nov 21, 2018, at 2:07 PM, Tim Olson wrote: >> >> >> I wouldn't say it's a guaranteed problem. I'm still >> running my original 2005 gas cylinders, with fabric covered >> doors, and it hasn't been a problem yet. The doors are >> fully resting open right now, in fact. >> >> I also think that having at least some sort of covering >> will help a little to deaden sound. That said, a painted >> door will look just fine too. I wouldn't hesitate to put >> light fabric on again, myself. >> Tim >> >>> On 11/21/2018 12:21 PM, Bill Watson wrote: >>> Ditto on the weight and higher pressure gas cylinder. >>>> On 11/21/2018 9:27 AM, bill.peyton wrote: >>>> >>>> I painted the interior of my doors. I used an epoxy based single stage paint with a flattening agent. To add texture to the surface I came back and spayed with a 1-3psi setting on the paint gun. This "spattered" liquid paint on to the surface. When it dries it looks slightly textured. I did this for all the interior surfaces that show. I also have the Aerosport headliner and interior panels. I matched the paint to the kydex interior panels. It is very difficult to put the material on the door surface and get a nice looking finish around the edges and windows. In addition, it adds weight to the door, which will cause you to use the higher pressure gas struts. >>>> >>>> -------- >>>> Bill >>>> WA0SYV >>>> Aviation Partners, LLC >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=485473#485473 >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> --- >>> This email has been checked for viruses by Avast antivirus software. >>> https://www.avast.com/antivirus >> >> >> >> > > ________________________________________________________________________________
Date: Nov 22, 2018
I appreciate all the ideas. Ill paint the interior as planned and continue to look for a source to cover the inside. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485501#485501 ________________________________________________________________________________
Date: Nov 23, 2018
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 24, 2018
Hi David, I installed a Overhead Console in my 10. I did so because I thought if I ever wanted to put Air Conditioning in it would be handy to have it there already. I havent done so as yet but I did put Map Lights where the Vents would go if I had have. In hind sight the Overhead console looks good and it does give you somewhere for your Head Sets to hang off and also have the Cabin Lights installed there on. It really wasnt hard to install and maybe took me about 8 or 10 hours including putting the lights in. Its your plane in the final analysis so you do what you would like. Cheers John MacCallum VH-DUU > On 22 Nov 2018, at 4:07 pm, David J. Fritzsche wrote: > > > This discussion is very interesting. I have been kicking around what to do with my interior, doors, inside, maybe overhead console, maybe not, headliner, etc. It is about decision time if I am ever going to finish the plane. I need to change some personal priorities. I appreciate the help some of you have provided when I had specific questions I directed at a few members. Always enjoy advice from those who have gone before. > > David > >> On 11/21/2018 11:41 AM, David Maib wrote: >> >> Im still on regular cylinders with the same light fabric from Abby that Tim describes. I also have the flush door handles. No problems. >> >> David Maib >> >> >>> On Nov 21, 2018, at 2:07 PM, Tim Olson wrote: >>> >>> >>> I wouldn't say it's a guaranteed problem. I'm still >>> running my original 2005 gas cylinders, with fabric covered >>> doors, and it hasn't been a problem yet. The doors are >>> fully resting open right now, in fact. >>> >>> I also think that having at least some sort of covering >>> will help a little to deaden sound. That said, a painted >>> door will look just fine too. I wouldn't hesitate to put >>> light fabric on again, myself. >>> Tim >>> >>>> On 11/21/2018 12:21 PM, Bill Watson wrote: >>>> Ditto on the weight and higher pressure gas cylinder. >>>>> On 11/21/2018 9:27 AM, bill.peyton wrote: >>>>> >>>>> I painted the interior of my doors. I used an epoxy based single stage paint with a flattening agent. To add texture to the surface I came back and spayed with a 1-3psi setting on the paint gun. This "spattered" liquid paint on to the surface. When it dries it looks slightly textured. I did this for all the interior surfaces that show. I also have the Aerosport headliner and interior panels. I matched the paint to the kydex interior panels. It is very difficult to put the material on the door surface and get a nice looking finish around the edges and windows. In addition, it adds weight to the door, which will cause you to use the higher pressure gas struts. >>>>> >>>>> -------- >>>>> Bill >>>>> WA0SYV >>>>> Aviation Partners, LLC >>>>> >>>>> >>>>> >>>>> >>>>> Read this topic online here: >>>>> >>>>> http://forums.matronics.com/viewtopic.php?p=485473#485473 >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>> --- >>>> This email has been checked for viruses by Avast antivirus software. >>>> https://www.avast.com/antivirus >>> >>> >>> >>> >> >> >> >> > > > ________________________________________________________________________________
Date: Nov 24, 2018
I think you will find a fair number of -10 builders combined the overhead console with two NACA scoops behind the baggage compartment to feed air vents overhead. It makes a big difference for me in Aridzona. I also installed map lights next to the vents. Sent from my IBM-360 main frame On Sat, Nov 24, 2018 at 3:25 AM John MacCallum wrote: > john.maccallum(at)bigpond.com> > > Hi David, > I installed a Overhead Console in my 10. I did so because I thought if I > ever wanted to put Air Conditioning in it would be handy to have it there > already. I haven=99t done so as yet but I did put Map Lights where the Vents > would go if I had have. In hind sight the Overhead console looks good and > it does give you somewhere for your Head Sets to hang off and also have t he > Cabin Lights installed there on. It really wasn=99t hard to instal l and > maybe took me about 8 or 10 hours including putting the lights in. > It=99s your plane in the final analysis so you do what you would li ke. > > Cheers > John MacCallum > VH-DUU > > > On 22 Nov 2018, at 4:07 pm, David J. Fritzsche > wrote: > > m > > > > > > This discussion is very interesting. I have been kicking around what t o > do with my interior, doors, inside, maybe overhead console, maybe not, > headliner, etc. It is about decision time if I am ever going to finish t he > plane. I need to change some personal priorities. I appreciate the help > some of you have provided when I had specific questions I directed at a f ew > members. Always enjoy advice from those who have gone before. > > > > David > > > >> On 11/21/2018 11:41 AM, David Maib wrote: > >> > >> I=99m still on regular cylinders with the same light fabric from Abby > that Tim describes. I also have the flush door handles. No problems. > >> > >> David Maib > >> > >> > >>> On Nov 21, 2018, at 2:07 PM, Tim Olson wrote: > >>> > >>> > >>> I wouldn't say it's a guaranteed problem. I'm still > >>> running my original 2005 gas cylinders, with fabric covered > >>> doors, and it hasn't been a problem yet. The doors are > >>> fully resting open right now, in fact. > >>> > >>> I also think that having at least some sort of covering > >>> will help a little to deaden sound. That said, a painted > >>> door will look just fine too. I wouldn't hesitate to put > >>> light fabric on again, myself. > >>> Tim > >>> > >>>> On 11/21/2018 12:21 PM, Bill Watson wrote: > >>>> Ditto on the weight and higher pressure gas cylinder. > >>>>> On 11/21/2018 9:27 AM, bill.peyton wrote: > billpeyton9(at)gmail.com> > >>>>> > >>>>> I painted the interior of my doors. I used an epoxy based single > stage paint with a flattening agent. To add texture to the surface I cam e > back and spayed with a 1-3psi setting on the paint gun. This "spattere d" > liquid paint on to the surface. When it dries it looks slightly textured . > I did this for all the interior surfaces that show. I also have the > Aerosport headliner and interior panels. I matched the paint to the kyde x > interior panels. It is very difficult to put the material on the door > surface and get a nice looking finish around the edges and windows. In > addition, it adds weight to the door, which will cause you to use the > higher pressure gas struts. > >>>>> > >>>>> -------- > >>>>> Bill > >>>>> WA0SYV > >>>>> Aviation Partners, LLC > >>>>> > >>>>> > >>>>> > >>>>> > >>>>> Read this topic online here: > >>>>> > >>>>> http://forums.matronics.com/viewtopic.php?p=485473#485473 > >>>>> > >>>>> > >>>>> > >>>>> > >>>>> > >>>>> > >>>>> > >>>>> > >>>>> > >>>>> > >>>> --- > >>>> This email has been checked for viruses by Avast antivirus software. > >>>> https://www.avast.com/antivirus > >>> > >>> > >>> > >>> > >> > >> > >> > >> > > > > > > > > =========== =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Nov 25, 2018
Yes I have seen that done a few times. It gets well over 40 deg C here in Na rromine, NSW in Summer so it would be a good feature! It=99s always a race always to get to 7 or 8 thousand feet to cool off ! Cheers John MacCallum VH-DUU RV10 41016 > On 25 Nov 2018, at 12:54 am, Kelly McMullen wrote: > > I think you will find a fair number of -10 builders combined the overhead c onsole with two NACA scoops behind the baggage compartment to feed air vents overhead. It makes a big difference for me in Aridzona. I also installed ma p lights next to the vents. > Sent from my IBM-360 main frame > > >> On Sat, Nov 24, 2018 at 3:25 AM John MacCallum wrote: om> >> >> Hi David, >> I installed a Overhead Console in my 10. I did so because I thought if I ever wanted to put Air Conditioning in it would be handy to have it there a lready. I haven=99t done so as yet but I did put Map Lights where the V ents would go if I had have. In hind sight the Overhead console looks good a nd it does give you somewhere for your Head Sets to hang off and also have t he Cabin Lights installed there on. It really wasn=99t hard to instal l and maybe took me about 8 or 10 hours including putting the lights in. >> It=99s your plane in the final analysis so you do what you would li ke. >> >> Cheers >> John MacCallum >> VH-DUU >> >> > On 22 Nov 2018, at 4:07 pm, David J. Fritzsche wrot e: >> > m> >> > >> > This discussion is very interesting. I have been kicking around what t o do with my interior, doors, inside, maybe overhead console, maybe not, hea dliner, etc. It is about decision time if I am ever going to finish the pla ne. I need to change some personal priorities. I appreciate the help some o f you have provided when I had specific questions I directed at a few member s. Always enjoy advice from those who have gone before. >> > >> > David >> > >> >> On 11/21/2018 11:41 AM, David Maib wrote: >> >> >> >> I=99m still on regular cylinders with the same light fabric from Abby that Tim describes. I also have the flush door handles. No problems. >> >> >> >> David Maib >> >> >> >> >> >>> On Nov 21, 2018, at 2:07 PM, Tim Olson wrote: >> >>> >> >>> >> >>> I wouldn't say it's a guaranteed problem. I'm still >> >>> running my original 2005 gas cylinders, with fabric covered >> >>> doors, and it hasn't been a problem yet. The doors are >> >>> fully resting open right now, in fact. >> >>> >> >>> I also think that having at least some sort of covering >> >>> will help a little to deaden sound. That said, a painted >> >>> door will look just fine too. I wouldn't hesitate to put >> >>> light fabric on again, myself. >> >>> Tim >> >>> >> >>>> On 11/21/2018 12:21 PM, Bill Watson wrote: >> >>>> Ditto on the weight and higher pressure gas cylinder. >> >>>>> On 11/21/2018 9:27 AM, bill.peyton wrote: om> >> >>>>> >> >>>>> I painted the interior of my doors. I used an epoxy based single s tage paint with a flattening agent. To add texture to the surface I came ba ck and spayed with a 1-3psi setting on the paint gun. This "spattered" li quid paint on to the surface. When it dries it looks slightly textured. I d id this for all the interior surfaces that show. I also have the Aerosport h eadliner and interior panels. I matched the paint to the kydex interior pan els. It is very difficult to put the material on the door surface and get a nice looking finish around the edges and windows. In addition, it adds wei ght to the door, which will cause you to use the higher pressure gas struts. >> >>>>> >> >>>>> -------- >> >>>>> Bill >> >>>>> WA0SYV >> >>>>> Aviation Partners, LLC >> >>>>> >> >>>>> >> >>>>> >> >>>>> >> >>>>> Read this topic online here: >> >>>>> >> >>>>> http://forums.matronics.com/viewtopic.php?p=485473#485473 >> >>>>> >> >>>>> >> >>>>> >> >>>>> >> >>>>> >> >>>>> >> >>>>> >> >>>>> >> >>>>> >> >>>>> >> >>>> --- >> >>>> This email has been checked for viruses by Avast antivirus software. >> >>>> https://www.avast.com/antivirus >> >>> >> >>> >> >>> >> >>> >> >> >> >> >> >> >> >> >> > >> > >> > >> >> >> ========== >> br> fts!) >> r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> -Matt Dralle, List Admin. >> ========== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navi gator?RV10-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========== >> >> >> ________________________________________________________________________________
Subject: Seat Tee Handle Location
Date: Nov 25, 2018
Every RV-10 that I have seen has the front seat tee handle next to the door. It seams that it would be much easier to access and operate if it was inboard near the tunnel. What am I missing? Larry Rosen N205EN Just installed the seats ________________________________________________________________________________
Date: Nov 25, 2018
Abby will still make RV-10 seat covers and carpet sets. The door and headliner is just fabric, that Abby can supply, that you cut to fit and use spray adhesive (like others have said) to put it on. She no longer makes the upper interior panels. Fabric covered doors with McMaster door seals is not quite as easy as the Vans seals. You would need to hold the fabric off the perimeter edge so seals to the painted fiberglass. Then you have to provide some sort of finished edge on the fabric. On 11/19/2018 9:29 PM, whodja wrote: > > Ive seen a few photos of doors with a fabric interior lining. Can anyone provide a source to have them made or anyone have any patterns. Abby at Flightline no longer makes them. > > Thanks > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=485330#485330 > > ________________________________________________________________________________
Date: Nov 25, 2018
Subject: Re: Seat Tee Handle Location
Aero sport make a extension that places the seat lever handle in the front. Makes it easy to get to. I have one in my 10. There is another company that makes one very similar cant think of their name. Thanks Neil Sent from my iPhone > On Nov 25, 2018, at 12:08 PM, Larry Rosen wrote: > > > Every RV-10 that I have seen has the front seat tee handle next to the door. It seams that it would be much easier to access and operate if it was inboard near the tunnel. What am I missing? > > Larry Rosen > N205EN > Just installed the seats > > > > > ________________________________________________________________________________
Date: Nov 25, 2018
Larry, I feel the same way and haven't seen any issues with -10s set up like that. David On Sun, Nov 25, 2018 at 11:14 AM Larry Rosen wrote: > > Every RV-10 that I have seen has the front seat tee handle next to the > door. It seams that it would be much easier to access and operate if it > was inboard near the tunnel. What am I missing? > > Larry Rosen > N205EN > Just installed the seats > > ________________________________________________________________________________
Date: Nov 25, 2018
Date: Nov 25, 2018
The Aerosport handles work well. Easy to reach in front of the seat. You will have difficulty if you reverse the seats to put the handle next to the tunnel, because the lever to tilt the seat back is also on the outside and nearly impossible to get to if it were next to the tunnel. On 11/25/2018 10:19 AM, Neil Corella wrote: > > Aero sport make a extension that places the seat lever handle in the front. Makes it easy to get to. I have one in my 10. There is another company that makes one very similar cant think of their name. Thanks Neil > > Sent from my iPhone > >> On Nov 25, 2018, at 12:08 PM, Larry Rosen wrote: >> >> >> Every RV-10 that I have seen has the front seat tee handle next to the door. It seams that it would be much easier to access and operate if it was inboard near the tunnel. What am I missing? >> >> Larry Rosen >> N205EN >> Just installed the seats >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Nov 25, 2018
I know a guy that has built several -10's and he always swaps the seats and puts the T handles next to the tunnel. If you do not have a center console, it works just fine and they're easier to get to. I started out (2007) with the very early levers similar to the Aerosport levers. They worked great, but were made out of lighter metal than needed and eventually broke. I was going to replace them with similar ones from IflyRV10.com, but the mounting holes were in a different location and I did not want to drill more holes in the seat. They also offered a T-Handle extension that simply raises the T-Handle about 2 or 3 inches higher, so I opted for that. Works great. If I was building today, I'd definitely install the Aerosport levers. Bottom line, no problems and easier access with the T-Handle next to the tunnel, as long as you don't have a center console mounted on the tunnel. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485717#485717 ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Nov 25, 2018
I would recommend just finishing/paint the doors. Dont use a flat paint for this. Flat paint will hold the dirt and stain more then a semi-gloss. Use a nice 2 part paint if possible. Let the finish coat dry about 90% and then if using a spray gun and air compressor turn the air way down 2-5lbs and put a nice spatter/speckle finish coat on. This makes a real nice, very light texture finish and will also clean up very easy. I have had many people ask what I put on my doors, thinking it was fabric, plastic or a vinyl/leather. FWIW -----Original Message----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> On Behalf Of Larry Rosen Sent: November 25, 2018 12:16 PM Subject: Re: RV10-List: Door interior Abby will still make RV-10 seat covers and carpet sets. The door and headliner is just fabric, that Abby can supply, that you cut to fit and use spray adhesive (like others have said) to put it on. She no longer makes the upper interior panels. Fabric covered doors with McMaster door seals is not quite as easy as the Vans seals. You would need to hold the fabric off the perimeter edge so seals to the painted fiberglass. Then you have to provide some sort of finished edge on the fabric. On 11/19/2018 9:29 PM, whodja wrote: > > Ive seen a few photos of doors with a fabric interior lining. Can anyone provide a source to have them made or anyone have any patterns. Abby at Flightline no longer makes them. > > Thanks > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=485330#485330 > > ________________________________________________________________________________
Date: Nov 26, 2018
I grab the center metal support with my inboard hand and work the t-handle with the outboard hand. Moving the T-Handle to the inside does not allow the use of the support to pull forward. Jim C On Sun, Nov 25, 2018 at 2:26 PM David Carr wrote: > Larry, > > I feel the same way and haven't seen any issues with -10s set up like that. > > David > > On Sun, Nov 25, 2018 at 11:14 AM Larry Rosen wrote: > >> >> Every RV-10 that I have seen has the front seat tee handle next to the >> door. It seams that it would be much easier to access and operate if it >> was inboard near the tunnel. What am I missing? >> >> Larry Rosen >> N205EN >> Just installed the seats >> >> >> ========== >> br> fts!) >> r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> -Matt Dralle, List Admin. >> ========== >> -List" rel="noreferrer" target="_blank"> >> http://www.matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> ________________________________________________________________________________
Date: Nov 26, 2018
That=99s how I do it too, Jim. The hand =9Cgrab=9D opening on each side of the glare shield worked fine on the airplanes I flew with t he T-handles moved inboard. David Maib > On Nov 26, 2018, at 9:34 AM, Jim Combs wrote: > > I grab the center metal support with my inboard hand and work the t-handle with the outboard hand. Moving the T-Handle to the inside does not allow t he use of the support to pull forward. > > Jim C > > >> On Sun, Nov 25, 2018 at 2:26 PM David Carr wrote: >> Larry, >> >> I feel the same way and haven't seen any issues with -10s set up like tha t. >> >> David >> >>> On Sun, Nov 25, 2018 at 11:14 AM Larry Rosen wrote: >>> >>> Every RV-10 that I have seen has the front seat tee handle next to the >>> door. It seams that it would be much easier to access and operate if it >>> was inboard near the tunnel. What am I missing? >>> >>> Larry Rosen >>> N205EN >>> Just installed the seats >>> >>> >>> ========== >>> br> fts!) >>> r> > e.com" rel="noreferrer" target="_blank">www.mypilotstore.com >>> rel="noreferrer" target="_blank">http://www.matronics.com/contributi on >>> -Matt Dralle, List Admin. >>> ========== >>> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Nav igator?RV10-List >>> ========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ========== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contributi on >>> ========== >>> >>> >>> ________________________________________________________________________________
Date: Nov 27, 2018
Subject: What's My Contribution Used For?
Dear Listers, Some have asked, "What's my Contribution used for?" and that's a good question. Here are just a few examples of what your direct List support enables. It provides for the very expensive, commercial-grade Internet connection used on the List insuring maximum performance and minimal contention when accessing List services. It pays for the regular system hardware and software upgrades enabling the highest performance possible for services such as the Archive Search Engine, List Browser, and Forums. It pays for narly 30 years (yeah, I really said *30* years) worth of online archive data available for instant random search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power this List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. How many places on the Internet can you make all those statements these days? It is YOUR CONTRIBUTION that directly enables these many aspects of these valuable List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport... List Contribution Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2018
Dear Listers, There are just a Two days left for this year's List Fund Raiser! If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2018
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 55! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Cabin heat valve
Date: Dec 07, 2018
Some time back in a discussion of heat in the tunnel, I think there was some discussion of an alternate valve on the firewall that diverted hot air from the muffs into the cowl rather than blocking it. Supposedly wade the heat problem less. Anyone remember the unit? Albert Gardner RV-10 N991RV Yuma, AZ ________________________________________________________________________________
Subject: Re: Cabin heat valve
Date: Dec 08, 2018
I this what you are talking about? This is a quality valve but will not change anything in the amount of heat directed at the firewall. > On Dec 8, 2018, at 12:16 AM, Albert wrote: > > > Some time back in a discussion of heat in the tunnel, I think there was some discussion of an alternate valve on the firewall that diverted hot air from the muffs into the cowl rather than blocking it. Supposedly wade the heat problem less. Anyone remember the unit? > Albert Gardner > RV-10 N991RV > Yuma, AZ > > > > > > > ________________________________________________________________________________
Subject: Wheel fairing build up
Date: Dec 08, 2018
The fairings from S Africa are exceptional! Perfect fit! Did you add the additional 2 layers as called for in the plans for the Vans fairing? The quality appears to be good enough but any feedback is appreciated. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486166#486166 ________________________________________________________________________________
Date: Dec 08, 2018
Plane Innovations has the stainless doors. Neither the aluminum or stainles s doors actually block the airflow. In both doors the airflow is allowed t o flow through the muffs, to the doors, and if the doors are closed at the f irewall, the air flows out the bottom of the cowling. What do the stainless doors do? 1) They=99re stainless so their melting point is higher than aluminum. So and engine fire isn=99t going to burn them off as quickly. 2) They have a small lip (approximately 1/8=9D) that acts like a baffl e to prevent leakage under the door. This is where the heat savings comes i n. Rather than letting the air leak under a closed door, it=99s redir ected away from the cracked opening and most of it goes out the bottom of th e tunnel. Do they work for heat related issues? Absolutely. I have knowledge of two 10=99s within 8 miles of my house that have ex perienced fuel related heat issues in the Texas summer. One could have turn ed out very badly but fortunately didn=99t. Installing the doors made a dramatic difference on both of those airplanes. It=99s still a good idea to put a radiant barrier on the front of the f irewall (that really helped me cool my feet off on long summer taxi=99 s) but the doors played a significant role in resolving the heat problems in side the tunnel. When installing them, it=99s a good idea to lay down a thick bead of f irewall sealant under the doors and then screw the doors down about 3/4 of t he way so they=99re not tight against the firewall. Then wait for th e sealant to cure fully before tightening the doors down the rest of the wa y. This keeps the cured sealant between the hot doors and the firewall and b reaks up the thermal bridge between the doors and firewall. Thus your fire wall doesn=99t act like a heatsink for your hot doors. Other note for the archives: I chose to use the Cool It mat from ThermoTec o n the (bottom 1/3) front side of the firewall. Adhesive backed, easy to cut to shape, and sticks well assuming you get the surface clean. I used it to line my lower cowling too. I=99m sure there are other good products o ut there, but it=99s just what I used because the local Auto Zones car ried it. Phil Sent from my iPhone > On Dec 8, 2018, at 5:51 AM, Rob Kermanj wrote: > > > I this what you are talking about? This is a quality valve but will not c hange anything in the amount of heat directed at the firewall. > > > >> On Dec 8, 2018, at 12:16 AM, Albert wrote: >> >> >> Some time back in a discussion of heat in the tunnel, I think there was s ome discussion of an alternate valve on the firewall that diverted hot air f rom the muffs into the cowl rather than blocking it. Supposedly wade the hea t problem less. Anyone remember the unit? >> Albert Gardner >> RV-10 N991RV >> Yuma, AZ >> >> >> >> >> http://www.matronics.com/Navigator?RV10-List >> http://wiki.matronics.com >> http://www.matronics.com/contribution >> >> >> > ________________________________________________________________________________
Date: Dec 08, 2018
Phil, Can you give a link to =9CSS doors=9D? Plane Innovation website shows a tribox similar to Van=99s Thanks. Rob > On Dec 8, 2018, at 8:38 AM, Phillip Perry wrote: > > Plane Innovations has the stainless doors. Neither the aluminum or stainless doors actually block the airflow. In both doors the airflow is allowed to flow through the muffs, to the doors, and if the doors are closed at the firewall, the air flows out the bottom of the cowling. > > What do the stainless doors do? > 1) They=99re stainless so their melting point is higher than aluminum. So and engine fire isn=99t going to burn them off as quickly. > > 2) They have a small lip (approximately 1/8=9D) that acts like a baffle to prevent leakage under the door. This is where the heat savings comes in. Rather than letting the air leak under a closed door, it=99s redirected away from the cracked opening and most of it goes out the bottom of the tunnel. > > Do they work for heat related issues? Absolutely. > > I have knowledge of two 10=99s within 8 miles of my house that have experienced fuel related heat issues in the Texas summer. One could have turned out very badly but fortunately didn=99t. Installing the doors made a dramatic difference on both of those airplanes. > > It=99s still a good idea to put a radiant barrier on the front of the firewall (that really helped me cool my feet off on long summer taxi=99s) but the doors played a significant role in resolving the heat problems inside the tunnel. > > When installing them, it=99s a good idea to lay down a thick bead of firewall sealant under the doors and then screw the doors down about 3/4 of the way so they=99re not tight against the firewall. Then wait for the sealant to cure fully before tightening the doors down the rest of the way. This keeps the cured sealant between the hot doors and the firewall and breaks up the thermal bridge between the doors and firewall. Thus your firewall doesn=99t act like a heatsink for your hot doors. > > Other note for the archives: I chose to use the Cool It mat from ThermoTec on the (bottom 1/3) front side of the firewall. Adhesive backed, easy to cut to shape, and sticks well assuming you get the surface clean. I used it to line my lower cowling too. I=99m sure there are other good products out there, but it=99s just what I used because the local Auto Zones carried it. > > Phil > > > > Sent from my iPhone > > On Dec 8, 2018, at 5:51 AM, Rob Kermanj > wrote: > >> >> I this what you are talking about? This is a quality valve but will not change anything in the amount of heat directed at the firewall. >> >> >> >>> On Dec 8, 2018, at 12:16 AM, Albert > wrote: >>> > >>> >>> Some time back in a discussion of heat in the tunnel, I think there was some discussion of an alternate valve on the firewall that diverted hot air from the muffs into the cowl rather than blocking it. Supposedly wade the heat problem less. Anyone remember the unit? >>> Albert Gardner >>> RV-10 N991RV >>> Yuma, AZ >>> >>> >>> >>> >>> http://www.matronics.com/Navigator?RV10-List <http://www.matronics.com/Navigator?RV10-List> >>> http://wiki.matronics.com >>> http://www.matronics.com/contribution <http://www.matronics.com/contribution> >>> >>> >>> >> ________________________________________________________________________________
Date: Dec 08, 2018
That=99s it. It looks similar but is made of stainless. http://www.planeinnovations.com/store/p1/Heater_Bypass_Valve.html Sent from my iPhone > On Dec 8, 2018, at 7:51 AM, Rob Kermanj wrote: > > Phil, > > Can you give a link to =9CSS doors=9D? Plane Innovation websi te shows a tribox similar to Van=99s > > Thanks. > > Rob > > > >> On Dec 8, 2018, at 8:38 AM, Phillip Perry wrote: >> >> Plane Innovations has the stainless doors. Neither the aluminum or stain less doors actually block the airflow. In both doors the airflow is allowe d to flow through the muffs, to the doors, and if the doors are closed at th e firewall, the air flows out the bottom of the cowling. >> >> What do the stainless doors do? >> 1) They=99re stainless so their melting point is higher than alumin um. So and engine fire isn=99t going to burn them off as quickly. >> >> 2) They have a small lip (approximately 1/8=9D) that acts like a ba ffle to prevent leakage under the door. This is where the heat savings come s in. Rather than letting the air leak under a closed door, it=99s re directed away from the cracked opening and most of it goes out the bottom of the tunnel. >> >> Do they work for heat related issues? Absolutely. >> >> I have knowledge of two 10=99s within 8 miles of my house that have experienced fuel related heat issues in the Texas summer. One could have t urned out very badly but fortunately didn=99t. Installing the doors m ade a dramatic difference on both of those airplanes. >> >> It=99s still a good idea to put a radiant barrier on the front of t he firewall (that really helped me cool my feet off on long summer taxi =99s) but the doors played a significant role in resolving the heat problems inside the tunnel. >> >> When installing them, it=99s a good idea to lay down a thick bead o f firewall sealant under the doors and then screw the doors down about 3/4 o f the way so they=99re not tight against the firewall. Then wait for the sealant to cure fully before tightening the doors down the rest of the way. This keeps the cured sealant between the hot doors and the firewall a nd breaks up the thermal bridge between the doors and firewall. Thus your f irewall doesn=99t act like a heatsink for your hot doors. >> >> Other note for the archives: I chose to use the Cool It mat from ThermoTe c on the (bottom 1/3) front side of the firewall. Adhesive backed, easy to c ut to shape, and sticks well assuming you get the surface clean. I used it t o line my lower cowling too. I=99m sure there are other good products out there, but it=99s just what I used because the local Auto Zones c arried it. >> >> Phil >> >> >> >> Sent from my iPhone >> >>> On Dec 8, 2018, at 5:51 AM, Rob Kermanj wrote: >>> >>> >>> I this what you are talking about? This is a quality valve but will not change anything in the amount of heat directed at the firewall. >>> >>> >>> >>>> On Dec 8, 2018, at 12:16 AM, Albert wrote: >>>> >>>> >>>> Some time back in a discussion of heat in the tunnel, I think there was some discussion of an alternate valve on the firewall that diverted hot air from the muffs into the cowl rather than blocking it. Supposedly wade the h eat problem less. Anyone remember the unit? >>>> Albert Gardner >>>> RV-10 N991RV >>>> Yuma, AZ >>>> >>>> >>>> >>>> >>>> http://www.matronics.com/Navigator?RV10-List >>>> http://wiki.matronics.com >>>> http://www.matronics.com/contribution >>>> >>>> >>>> >>> > ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Dec 08, 2018
What I did. I installed a piece Koolmat between the cabin heat boxes and the firewall (h oles cut out for the boxes): https://www.aircraftspruce.com/catalog/appag es/koolmat.php. I extended the mat over the top of the boxes, then down and o ver the front of the boxes. My thinking: - No matter what box you use, if you hard mount it to the firewall you will p rovide a very good heat transfer path to the tunnel (flapper open or shut). The mat between the box and the firewall mitigates this problem. - During the summer you are still pumping huge amounts of heated air toward t he cabin boxes. The hot air bounces off the closed flapper and right back a t the engine (in the area of the mechanical fuel pump). The Koolmat draped o ver the front of the boxes redirects this heated air down to the cowl exit. One other mod was to put a 3/4=9D orifice in each heat muff SCAT hose b affle flange. On the coldest day I was only using a fraction of the heat th at the system provides, so why have all that air taken away from engine cool ing if not needed? I still only crack open the aft heat on cold days. Never had a tunnel heat problem. Carl > On Dec 8, 2018, at 8:51 AM, Rob Kermanj wrote: > > Phil, > > Can you give a link to =9CSS doors=9D? Plane Innovation websi te shows a tribox similar to Van=99s > > Thanks. > > Rob > > > >> On Dec 8, 2018, at 8:38 AM, Phillip Perry wrote: >> >> Plane Innovations has the stainless doors. Neither the aluminum or stain less doors actually block the airflow. In both doors the airflow is allowe d to flow through the muffs, to the doors, and if the doors are closed at th e firewall, the air flows out the bottom of the cowling. >> >> What do the stainless doors do? >> 1) They=99re stainless so their melting point is higher than alumin um. So and engine fire isn=99t going to burn them off as quickly. >> >> 2) They have a small lip (approximately 1/8=9D) that acts like a ba ffle to prevent leakage under the door. This is where the heat savings come s in. Rather than letting the air leak under a closed door, it=99s re directed away from the cracked opening and most of it goes out the bottom of the tunnel. >> >> Do they work for heat related issues? Absolutely. >> >> I have knowledge of two 10=99s within 8 miles of my house that have experienced fuel related heat issues in the Texas summer. One could have t urned out very badly but fortunately didn=99t. Installing the doors m ade a dramatic difference on both of those airplanes. >> >> It=99s still a good idea to put a radiant barrier on the front of t he firewall (that really helped me cool my feet off on long summer taxi =99s) but the doors played a significant role in resolving the heat problems inside the tunnel. >> >> When installing them, it=99s a good idea to lay down a thick bead o f firewall sealant under the doors and then screw the doors down about 3/4 o f the way so they=99re not tight against the firewall. Then wait for the sealant to cure fully before tightening the doors down the rest of the way. This keeps the cured sealant between the hot doors and the firewall a nd breaks up the thermal bridge between the doors and firewall. Thus your f irewall doesn=99t act like a heatsink for your hot doors. >> >> Other note for the archives: I chose to use the Cool It mat from ThermoTe c on the (bottom 1/3) front side of the firewall. Adhesive backed, easy to c ut to shape, and sticks well assuming you get the surface clean. I used it t o line my lower cowling too. I=99m sure there are other good products out there, but it=99s just what I used because the local Auto Zones c arried it. >> >> Phil >> >> >> >> Sent from my iPhone >> >>> On Dec 8, 2018, at 5:51 AM, Rob Kermanj wrote: >>> >>> >>> I this what you are talking about? This is a quality valve but will not change anything in the amount of heat directed at the firewall. >>> >>> >>> >>>> On Dec 8, 2018, at 12:16 AM, Albert wrote: >>>> >>>> >>>> Some time back in a discussion of heat in the tunnel, I think there was some discussion of an alternate valve on the firewall that diverted hot air from the muffs into the cowl rather than blocking it. Supposedly wade the h eat problem less. Anyone remember the unit? >>>> Albert Gardner >>>> RV-10 N991RV >>>> Yuma, AZ >>>> >>>> >>>> >>>> >>>> http://www.matronics.com/Navigator?RV10-List >>>> http://wiki.matronics.com >>>> http://www.matronics.com/contribution >>>> >>>> >>>> >>> > ________________________________________________________________________________
Subject: Hot center channel
Date: Dec 08, 2018
Our center channel would get so hot you didn't want to leave your hand on it. I read a report of vapor locking in the fuel lines in the center channel when we were building so, we put a piece of fire wall insulation over the fuel lines and sealed the heat boxes with RTV silicone also to try to keep any air flow out. Center channel was still "hot". Put fire wall insulation from Wicks on fire wall. Center channel is only "warm" now even in 90 plus degree weather. I am convinced the fire wall insulation is the major thing to do to keep the center channel cool. However, I would also recommend insulating the center channel, etc. You also have to put insulation "mats" on each side of the engine cowling or the eghaust heat will warp the cowling. ________________________________________________________________________________
Date: Dec 08, 2018
After reading the comments I'm wondering about making a removable restrictor/air dam in front on the scat tube. Normally need very little heat in Arizona although last winter in Missouri max heat was needed on very cold days. I guess one could make a shutter like dam that could be operated from the cockpit as opposed to having to remove the top cowl. I installed a sliding restrictor to block heat on my side in the cabin since my wife usually wants a lot more heat than I do. Albert Gardner RV-10 N991RV Yuma, AZ ________________________________________________________________________________
Subject: Re: Hot center channel
From: "Greg McFarlane" <grbcmcfarlane(at)gmail.com>
Date: Dec 09, 2018
In mild climates really only heat is required to the front and not at all to the rear. One heat muff to supply the front only cuts the heat to the firewall and so the tunnel by half. (the firewall vent for the rear can be permanently sealed off and the air out of the unused heat muff can be dumped down, or that heat muff can be removed) For the front Using a T fitting incorporating a butterfly valve (available from Spruce) the heater air from the heat muff can be diverted via a scat down toward the bottom cowl instead of blasting away at the firewall all the time the heater is not required. (which of course includes Summer) Only two push pull controls are still required, one to control the T fitting and one at the firewall valve. Using this solution the firewall valve really only needs to be full open, heater on, or fully closed heater off, this reduces the likely introduction of unwanted fumes entering the cabin with a partly opened firewall valve, heat is regulated via the T fitting out of the heat muff, the heated air is still full flowing through the heat muff so no abnormal build up of heat by restriction. Just my solution which has kept the tunnel cool. Cheeers from Western Australia Read this topic online here: http://forums.matronics.com/viewtopic.php?p=486190#486190 ________________________________________________________________________________
Date: Dec 09, 2018
Here is a possibility. > On Dec 9, 2018, at 12:53 AM, Albert wrote: > > > After reading the comments I'm wondering about making a removable > restrictor/air dam in front on the scat tube. Normally need very little heat > in Arizona although last winter in Missouri max heat was needed on very cold > days. I guess one could make a shutter like dam that could be operated from > the cockpit as opposed to having to remove the top cowl. I installed a > sliding restrictor to block heat on my side in the cabin since my wife > usually wants a lot more heat than I do. > Albert Gardner > RV-10 N991RV > Yuma, AZ > > > > > ________________________________________________________________________________
Date: Dec 09, 2018
I just use aluminum tape and cover about 1/3 of the inlet in the baffle. Its easy to remove when you want full flow. Tim > On Dec 8, 2018, at 11:53 PM, Albert wrote: > > > After reading the comments I'm wondering about making a removable > restrictor/air dam in front on the scat tube. Normally need very little heat > in Arizona although last winter in Missouri max heat was needed on very cold > days. I guess one could make a shutter like dam that could be operated from > the cockpit as opposed to having to remove the top cowl. I installed a > sliding restrictor to block heat on my side in the cabin since my wife > usually wants a lot more heat than I do. > Albert Gardner > RV-10 N991RV > Yuma, AZ > > > > > ________________________________________________________________________________
Subject: Paint Scheme
Date: Dec 17, 2018
After 12 years of off-and-on work on my RV-10 project, I've reached the point where it is time to think about a paint scheme. It seems I recall that there are some software packages around that will let you experiment with various paint schemes on an RV-10 3-view. Can anyone recommend such a program? Jack Phillips Smith Mountain Lake, Virginia Fuselage Done, Wings Done, Engine Installed, finishing up the cowling ________________________________________________________________________________
Date: Dec 19, 2018
Subject: 2018 List of Contributors
Dear Listers, The 2018 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 And finally, I'm proud to present The 2018 Fund Raiser List of Contributors: http://www.matronics.com/loc Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Date: Jan 15, 2019
Subject: Salt Lake City airports
This next month Ill be flying into Salt Lake City, arriving from and departing to the east. Purpose is to eat at In-N-Out as well as go downtown. Any suggestions on an airport to use? ________________________________________________________________________________
Subject: Re: Salt Lake City airports
Date: Jan 15, 2019
I don't recall the locations of the IN and Out burger shops. While SLC is closest to downtown, Bountiful (BTF) is much more GA friendly, has both self serve 100LL and 91 octane Mogas, as well as they can get Hertz car for you on field. U42 is a distance from downtown. For either SLC or BTF you will need Class B clearance. They are pretty good about working you in. Rwy 17/35 is normal GA at SLC. I believe there are still a couple RV-10s based at BTF. On 1/15/2019 8:56 AM, Curtis Groote wrote: > > This next month Ill be flying into Salt Lake City, arriving from and departing to the east. Purpose is to eat at In-N-Out as well as go downtown. Any suggestions on an airport to use? > > > > > ________________________________________________________________________________
Date: Jan 15, 2019
Sean Strasburg and Scott Schmidt should be able to help with all the local knowledge you could ask for. Theyre both local and flying in and out of there regularly. Sent from my iPhone > On Jan 15, 2019, at 2:12 PM, Kelly McMullen wrote: > > > I don't recall the locations of the IN and Out burger shops. While SLC is closest to downtown, Bountiful (BTF) is much more GA friendly, has both self serve 100LL and 91 octane Mogas, as well as they can get Hertz car for you on field. U42 is a distance from downtown. > For either SLC or BTF you will need Class B clearance. They are pretty good about working you in. Rwy 17/35 is normal GA at SLC. I believe there are still a couple RV-10s based at BTF. > >> On 1/15/2019 8:56 AM, Curtis Groote wrote: >> This next month Ill be flying into Salt Lake City, arriving from and departing to the east. Purpose is to eat at In-N-Out as well as go downtown. Any suggestions on an airport to use? > > > ________________________________________________________________________________
Date: Jan 15, 2019
I've used South Valley Regional; U42; in the past. Nothing but good words about them. There's an In-n-Out right at the south end of the field. Rental and crew cars were readily available. About 13ish mile drive to downtown SLC. Make SURE you hit R&R BBQ in downtown SLC ... best BBQ west of Texas. --Ron On 1/15/19 2:12 PM, Kelly McMullen wrote: > > I don't recall the locations of the IN and Out burger shops. While SLC > is closest to downtown, Bountiful (BTF) is much more GA friendly, has > both self serve 100LL and 91 octane Mogas, as well as they can get Hertz > car for you on field. U42 is a distance from downtown. > For either SLC or BTF you will need Class B clearance. They are pretty > good about working you in. Rwy 17/35 is normal GA at SLC. I believe > there are still a couple RV-10s based at BTF. > > On 1/15/2019 8:56 AM, Curtis Groote wrote: >> >> This next month Ill be flying into Salt Lake City, arriving from and >> departing to the east. Purpose is to eat at In-N-Out as well as go >> downtown. Any suggestions on an airport to use? >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Jan 15, 2019
I've flown directly into SLC a couple of times, and found them perfectly accommodating for GA. Never been refused entry into Class B, but I always do those flights with a VFR flight plan specifying a destination airport in the class B so maybe that helps since they're ready and expecting you... > On 2019-Jan-15, at 8:56 AM, Curtis Groote wrote: > > > This next month Ill be flying into Salt Lake City, arriving from and departing to the east. Purpose is to eat at In-N-Out as well as go downtown. Any suggestions on an airport to use? > --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Date: Jan 15, 2019
I'm 10 minutes from South Valley Regioinal (U42) and have been flying out of there as a student pilot for 1 1/2 years and I echo Ron Walker's comments. If you have an RV-10, would love to see it. Isaac Schantz RV-10 Builder 41847 60% complete (building for just less than 1 year) On Tue, Jan 15, 2019 at 2:36 PM Dan Charrois wrote: > > I've flown directly into SLC a couple of times, and found them perfectly > accommodating for GA. Never been refused entry into Class B, but I alway s > do those flights with a VFR flight plan specifying a destination airport in > the class B so maybe that helps since they're ready and expecting you... > > > > On 2019-Jan-15, at 8:56 AM, Curtis Groote wrote: > > > > > > This next month I=99ll be flying into Salt Lake City, arriving fr om and > departing to the east. Purpose is to eat at In-N-Out as well as go > downtown. Any suggestions on an airport to use? > > > > --- > Dan Charrois > President, Syzygy Research & Technology > Phone: 780-961-2213 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jan 15, 2019
Subject: Anybody use stock fuel valve?
Hi all, Has anyone on this list fitted the stock fuel valve? Any tips for making the installation look more polished or operate as well as possible? I can find very little online about it. FYI---not really interested in going the Andair valve option. Thanks! ________________________________________________________________________________
Subject: Re: Anybody use stock fuel valve?
Date: Jan 15, 2019
I installed the stock valve as per the plans - not a single change. It does the job, never saw a need to modify it. It's a bit of a nuisance to have to remove the handle every time you want the tunnel cover removed, but what can ya do, it's only once a year. --Ron On 1/15/19 7:13 PM, David Carr wrote: > Hi all, > > Has anyone on this list fitted the stock fuel valve? Any tips for > making the installation look more polished or operate as well as > possible? I can find very little online about it. > > FYI---not really interested in going the Andair valve option. > > Thanks! ________________________________________________________________________________
From: Bruce Breckenridge <bbreckenridge(at)gmail.com>
Date: Jan 15, 2019
Great question. I installed the Andair Valve in another plane, and, it works sweetly. I was hoping to go "stock" on the -10 project. Hoping more than just Mr. Walker speaketh up. Bruce 40018 On Tue, Jan 15, 2019 at 5:30 PM David Carr wrote: > Hi all, > > Has anyone on this list fitted the stock fuel valve? Any tips for making > the installation look more polished or operate as well as possible? I can > find very little online about it. > > FYI---not really interested in going the Andair valve option. > > Thanks! > ________________________________________________________________________________
Date: Jan 16, 2019
Just about every RV-10 that I=92m aware of, including mine has gone with an Andair valve. Mine has been flying for over six years, so I haven=92t re ally bothered to keep up with all the factory parts quality control issues. Hopefully, that vendor has fixed their issues over the years. I don=92 t have any data, pro or con. Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of Bruce Breckenridge Sent: Tuesday, January 15, 2019 11:06 PM Subject: Re: RV10-List: Anybody use stock fuel valve? Great question. I installed the Andair Valve in another plane, and, it wor ks sweetly. I was hoping to go "stock" on the -10 project. Hoping more th an just Mr. Walker speaketh up. Bruce 40018 On Tue, Jan 15, 2019 at 5:30 PM David Carr > wrote: Hi all, Has anyone on this list fitted the stock fuel valve? Any tips for making t he installation look more polished or operate as well as possible? I can f ind very little online about it. FYI---not really interested in going the Andair valve option. Thanks! ________________________________________________________________________________
Date: Jan 16, 2019
I have the stock valve in my RV-6, and it is doing fine after 18 maintenance free years. I installed the stock valve in the RV-10 I'm finishing and have no qualms about it. The installation is very simple - just follow the plans. Kyle Boatright -----Original Message----- From: Ron Walker Sent: Tuesday, January 15, 2019 8:39 PM Subject: Re: RV10-List: Anybody use stock fuel valve? I installed the stock valve as per the plans - not a single change. It does the job, never saw a need to modify it. It's a bit of a nuisance to have to remove the handle every time you want the tunnel cover removed, but what can ya do, it's only once a year. --Ron On 1/15/19 7:13 PM, David Carr wrote: > Hi all, > > Has anyone on this list fitted the stock fuel valve? Any tips for making > the installation look more polished or operate as well as possible? I can > find very little online about it. > > FYI---not really interested in going the Andair valve option. > > Thanks! ________________________________________________________________________________
Date: Jan 15, 2019
Stock valve in mine. Kit purchase circa 2008, just in time to get the slightly modified valve with the new handle (aluminum pointer, lift-to-turn). The older brass handle was just plain ugly IMHO. No problems to date. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487010#487010 ________________________________________________________________________________
Date: Jan 15, 2019
If you try a Big H burger from Hires up on 7th east in SLC, youll throw rocks at In and put. Been into all three airports in the SLC valley with my RV and theyre all nicely accommodating. BOuntiful definitely has the cheapest gas. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487011#487011 ________________________________________________________________________________
Date: Jan 15, 2019
If you try a Big H burger from Hires up on 7th east in SLC, youll throw rocks at In and put. Been into all three airports in the SLC valley with my RV and theyre all nicely accommodating. BOuntiful definitely has the cheapest gas. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487012#487012 ________________________________________________________________________________
Date: Jan 16, 2019
I installed the stock valve 11 years ago and have had no problems. If you push down on the valve during loading it can make it move hard. Just pull up on the handle and release and your good to go. Get Outlook for iOS ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of David Carr <junk@dc arr.org> Sent: Tuesday, January 15, 2019 8:31 PM Subject: RV10-List: Anybody use stock fuel valve? Hi all, Has anyone on this list fitted the stock fuel valve? Any tips for making t he installation look more polished or operate as well as possible? I can f ind very little online about it. FYI---not really interested in going the Andair valve option. Thanks! ________________________________________________________________________________
Date: Jan 16, 2019
I use the stock valve in my RV-10. 2.5 yrs and no issues. Joe On Tue, Jan 15, 2019 at 8:31 PM David Carr wrote: > Hi all, > > Has anyone on this list fitted the stock fuel valve? Any tips for making > the installation look more polished or operate as well as possible? I can > find very little online about it. > > FYI---not really interested in going the Andair valve option. > > Thanks! > ________________________________________________________________________________
Date: Jan 16, 2019
No issues in 10 years. Anh > On Jan 16, 2019, at 10:27 AM, Joe arvai wrote: > > I use the stock valve in my RV-10. 2.5 yrs and no issues. > > Joe > >> On Tue, Jan 15, 2019 at 8:31 PM David Carr wrote: >> Hi all, >> >> Has anyone on this list fitted the stock fuel valve? Any tips for making the installation look more polished or operate as well as possible? I can f ind very little online about it. >> >> FYI---not really interested in going the Andair valve option. >> >> Thanks! ________________________________________________________________________________
Date: Jan 16, 2019
8 years, 1150 hrs, no issues. Stock valve, unpainted, per plans. I lightly coat the nylon w/ fuel lube every few years if it gets hard to turn. Same experience with my RV-6A for 1100 hrs. Sent from my iPhone > On Jan 16, 2019, at 4:31 PM, DejaVu wrote: > > No issues in 10 years. > Anh > > > >> On Jan 16, 2019, at 10:27 AM, Joe arvai wrote: >> >> I use the stock valve in my RV-10. 2.5 yrs and no issues. >> >> Joe >> >>> On Tue, Jan 15, 2019 at 8:31 PM David Carr wrote: >>> Hi all, >>> >>> Has anyone on this list fitted the stock fuel valve? Any tips for makin g the installation look more polished or operate as well as possible? I can find very little online about it. >>> >>> FYI---not really interested in going the Andair valve option. >>> >>> Thanks! ________________________________________________________________________________
Date: Jan 16, 2019
I used the stock fuel selector valve. First flight in 2010, 1000+ hours no issues. Jim C (N312F) On Tue, Jan 15, 2019 at 11:52 PM Bob Leffler wrote: > Just about every RV-10 that I=99m aware of, including mine has gone with an > Andair valve. Mine has been flying for over six years, so I haven =99t > really bothered to keep up with all the factory parts quality control > issues. Hopefully, that vendor has fixed their issues over the years. I > don=99t have any data, pro or con. > > Get Outlook for iOS > > ------------------------------ > *From:* owner-rv10-list-server(at)matronics.com on behalf of Bruce > Breckenridge > *Sent:* Tuesday, January 15, 2019 11:06 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Anybody use stock fuel valve? > > Great question. I installed the Andair Valve in another plane, and, it > works sweetly. I was hoping to go "stock" on the -10 project. Hoping mo re > than just Mr. Walker speaketh up. > > Bruce > 40018 > > On Tue, Jan 15, 2019 at 5:30 PM David Carr wrote: > >> Hi all, >> >> Has anyone on this list fitted the stock fuel valve? Any tips for makin g >> the installation look more polished or operate as well as possible? I c an >> find very little online about it. >> >> FYI---not really interested in going the Andair valve option. >> >> Thanks! >> > ________________________________________________________________________________
Date: Jan 17, 2019
My kit came with the Andair. Much nicer than the stock valve in my 6A. I have a stock -10 valve for sale :-) On Wed, Jan 16, 2019 at 6:52 PM Jim Combs wrote: > I used the stock fuel selector valve. First flight in 2010, 1000+ hours > no issues. > > Jim C (N312F) > > On Tue, Jan 15, 2019 at 11:52 PM Bob Leffler wrote: > >> Just about every RV-10 that I=99m aware of, including mine has gon e with an >> Andair valve. Mine has been flying for over six years, so I haven =99t >> really bothered to keep up with all the factory parts quality control >> issues. Hopefully, that vendor has fixed their issues over the years. I >> don=99t have any data, pro or con. >> >> Get Outlook for iOS >> >> ------------------------------ >> *From:* owner-rv10-list-server(at)matronics.com on behalf of Bruce >> Breckenridge >> *Sent:* Tuesday, January 15, 2019 11:06 PM >> *To:* rv10-list(at)matronics.com >> *Subject:* Re: RV10-List: Anybody use stock fuel valve? >> >> Great question. I installed the Andair Valve in another plane, and, it >> works sweetly. I was hoping to go "stock" on the -10 project. Hoping m ore >> than just Mr. Walker speaketh up. >> >> Bruce >> 40018 >> >> On Tue, Jan 15, 2019 at 5:30 PM David Carr wrote: >> >>> Hi all, >>> >>> Has anyone on this list fitted the stock fuel valve? Any tips for >>> making the installation look more polished or operate as well as possib le? >>> I can find very little online about it. >>> >>> FYI---not really interested in going the Andair valve option. >>> >>> Thanks! >>> >> ________________________________________________________________________________
Subject: Relocating red cube
Date: Jan 20, 2019
Hi everyone. I've had ongoing fuel pressure fluctuation issues from time to time and am trying to improve every piece of the puzzle to see if I can make them go away. One of the things I'm doing is relocating my red cube fuel flow transducer from the tunnel (as per plans) to the positive pressure side of the fuel pump (which a lot of people do). According to the FT-60 red cube documentation which I recently stumbled across (https://buy-ei.com/wp-content/uploads/2018/03/FT-60-Info-Rev-F.pdf) they come right out and say "If the aircraft has a fuel pump(s), the flow transducer MUST be installed downstream of the last fuel pump. Installing the transducer upstream of the fuel pump(s) can cause vapor lock and jumpy/inaccurate readings." That sentence definitely conflicts with the plans for putting it in the tunnel, and makes me hopeful that this will make a difference in taming my pressure fluctuations (not to mention should also help the erroneous readings it gives when the electric boost pump is on). But I'm struggling a bit with where exactly to put it. The two options for the positive pressure side of the fuel pump mean either between the engine pump and servo, or between the servo and spider. Most people I've heard who have moved it have placed it between the servo and spider. However, in the installation instructions for Electronics International's FP-5 (https://buy-ei.com/wp-content/uploads/FP-5L-II.pdf) which uses the red cube, they suggest mounting locations. Applicable to my fuel injected engine without a fuel return line from the servo, they say to refer to the drawings on page 17 or 18, both of which place the red cube between the fuel pump and servo. Their drawings placing the cube between the servo and spider are marked as being only applicable on aircraft with a fuel return line from the fuel servo. Has this been noticed before and I'm just late to the party? Or do most people who have been relocating the cube also have a fuel return line, which is why it's been common to mount between the servo and spider? Does anyone know what the reason might be to not install the red cube between the servo and spider on an installation without a fuel return line from the servo? Thanks! Dan --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Subject: Re: Relocating red cube
Date: Jan 20, 2019
Dan, I used the location between the mechanical pump and the servo on a Mooney I had before the RV, because that was where the STC instructions said to put it. On my RV-10, I put it between the servo and the spider, near the right front corner of the oil sump, before the line goes up to the spider. Both locations delivered stable readings. I'd say convenience to get relatively straight hose runs in and out of the cube is the main point. Kelly On 1/20/2019 2:54 AM, Dan Charrois wrote: > > Hi everyone. > > I've had ongoing fuel pressure fluctuation issues from time to time and am trying to improve every piece of the puzzle to see if I can make them go away. > > One of the things I'm doing is relocating my red cube fuel flow transducer from the tunnel (as per plans) to the positive pressure side of the fuel pump (which a lot of people do). According to the FT-60 red cube documentation which I recently stumbled across (https://buy-ei.com/wp-content/uploads/2018/03/FT-60-Info-Rev-F.pdf) they come right out and say "If the aircraft has a fuel pump(s), the flow transducer MUST be installed downstream of the last fuel pump. Installing the transducer upstream of the fuel pump(s) can cause vapor lock and jumpy/inaccurate readings." That sentence definitely conflicts with the plans for putting it in the tunnel, and makes me hopeful that this will make a difference in taming my pressure fluctuations (not to mention should also help the erroneous readings it gives when the electric boost pump is on). > > But I'm struggling a bit with where exactly to put it. The two options for the positive pressure side of the fuel pump mean either between the engine pump and servo, or between the servo and spider. Most people I've heard who have moved it have placed it between the servo and spider. > > However, in the installation instructions for Electronics International's FP-5 (https://buy-ei.com/wp-content/uploads/FP-5L-II.pdf) which uses the red cube, they suggest mounting locations. Applicable to my fuel injected engine without a fuel return line from the servo, they say to refer to the drawings on page 17 or 18, both of which place the red cube between the fuel pump and servo. Their drawings placing the cube between the servo and spider are marked as being only applicable on aircraft with a fuel return line from the fuel servo. > > Has this been noticed before and I'm just late to the party? Or do most people who have been relocating the cube also have a fuel return line, which is why it's been common to mount between the servo and spider? Does anyone know what the reason might be to not install the red cube between the servo and spider on an installation without a fuel return line from the servo? > > Thanks! > > Dan > --- > Dan Charrois > President, Syzygy Research & Technology > Phone: 780-961-2213 > > > > > ________________________________________________________________________________
Date: Jan 20, 2019
I have an Airflow Performance FM300 on the front of a Barrett Cold Air Induc tion manifold. Putting the Red Cube after the fuel Servo was a non starter f or me because there was not enough room after the Servo to mount it without t ight turns before and after the Red Cube. I finally mounted it the left side on the fuel line run from the engine driven fuel pump to the Servo. This ga ve me a fairly straight run before and after. I used Axel clamps to support t he fuel lines at the front and back of the oil pan. The fuel lines were fire sleeved of course and a got about 12 inches of fire sleeve to go over the R ed Cube. I punched a hole in the sleeve for the wires and used hose clamps t o secure the ends after everything was tightened down. You can see that I ha d to fold it up to secure it. I can=99t say how well this works because I am still working on wiring avionics. Robert Jones > On Jan 20, 2019, at 01:54, Dan Charrois wrote: > > > Hi everyone. > > I've had ongoing fuel pressure fluctuation issues from time to time and am trying to improve every piece of the puzzle to see if I can make them go aw ay. > > One of the things I'm doing is relocating my red cube fuel flow transducer from the tunnel (as per plans) to the positive pressure side of the fuel pu mp (which a lot of people do). According to the FT-60 red cube documentatio n which I recently stumbled across (https://buy-ei.com/wp-content/uploads/20 18/03/FT-60-Info-Rev-F.pdf) they come right out and say "If the aircraft has a fuel pump(s), the flow transducer MUST be installed downstream of the las t fuel pump. Installing the transducer upstream of the fuel pump(s) can cau se vapor lock and jumpy/inaccurate readings." That sentence definitely conf licts with the plans for putting it in the tunnel, and makes me hopeful that this will make a difference in taming my pressure fluctuations (not to ment ion should also help the erroneous readings it gives when the electric boost pump is on). > > But I'm struggling a bit with where exactly to put it. The two options fo r the positive pressure side of the fuel pump mean either between the engine pump and servo, or between the servo and spider. Most people I've heard wh o have moved it have placed it between the servo and spider. > > However, in the installation instructions for Electronics International's FP-5 (https://buy-ei.com/wp-content/uploads/FP-5L-II.pdf) which uses the red cube, they suggest mounting locations. Applicable to my fuel injected engi ne without a fuel return line from the servo, they say to refer to the drawi ngs on page 17 or 18, both of which place the red cube between the fuel pump and servo. Their drawings placing the cube between the servo and spider ar e marked as being only applicable on aircraft with a fuel return line from t he fuel servo. > > Has this been noticed before and I'm just late to the party? Or do most p eople who have been relocating the cube also have a fuel return line, which i s why it's been common to mount between the servo and spider? Does anyone k now what the reason might be to not install the red cube between the servo a nd spider on an installation without a fuel return line from the servo? > > Thanks! > > Dan > --- > Dan Charrois > President, Syzygy Research & Technology > Phone: 780-961-2213 > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Jan 20, 2019
I suspended my FP-5 in the line between the fuel servo and flow divider IAW the drawing on page 20 of the FT-5 manual. I wrapped the transducer with fire sleeve per the instructions. It has worked well in this location for 4 years and over four hundred hours. Several other RV's have done the same thing. I believe Airflow Performance recommended this location to me. This location eliminated the surging fuel flow readings I used to see. My setup: RV-10, IO-540 C4B5, standard installation with stock Van's fuel selector, stock RV-10 airflow performance boost pump in the tunnel, mechanical fuel pump on the engine. Bendix fuel injection system. No fuel return line. -- Tim Lewis -- HEF (Manassas, VA) CFI, A&P RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 1000 hrs Dan Charrois wrote on 1/20/2019 4:54 AM: > > Hi everyone. > > I've had ongoing fuel pressure fluctuation issues from time to time and am trying to improve every piece of the puzzle to see if I can make them go away. > > One of the things I'm doing is relocating my red cube fuel flow transducer from the tunnel (as per plans) to the positive pressure side of the fuel pump (which a lot of people do). According to the FT-60 red cube documentation which I recently stumbled across (https://buy-ei.com/wp-content/uploads/2018/03/FT-60-Info-Rev-F.pdf) they come right out and say "If the aircraft has a fuel pump(s), the flow transducer MUST be installed downstream of the last fuel pump. Installing the transducer upstream of the fuel pump(s) can cause vapor lock and jumpy/inaccurate readings." That sentence definitely conflicts with the plans for putting it in the tunnel, and makes me hopeful that this will make a difference in taming my pressure fluctuations (not to mention should also help the erroneous readings it gives when the electric boost pump is on). > > But I'm struggling a bit with where exactly to put it. The two options for the positive pressure side of the fuel pump mean either between the engine pump and servo, or between the servo and spider. Most people I've heard who have moved it have placed it between the servo and spider. > > However, in the installation instructions for Electronics International's FP-5 (https://buy-ei.com/wp-content/uploads/FP-5L-II.pdf) which uses the red cube, they suggest mounting locations. Applicable to my fuel injected engine without a fuel return line from the servo, they say to refer to the drawings on page 17 or 18, both of which place the red cube between the fuel pump and servo. Their drawings placing the cube between the servo and spider are marked as being only applicable on aircraft with a fuel return line from the fuel servo. > > Has this been noticed before and I'm just late to the party? Or do most people who have been relocating the cube also have a fuel return line, which is why it's been common to mount between the servo and spider? Does anyone know what the reason might be to not install the red cube between the servo and spider on an installation without a fuel return line from the servo? > > Thanks! > > Dan > --- > Dan Charrois > President, Syzygy Research & Technology > Phone: 780-961-2213 > > ________________________________________________________________________________
Date: Jan 20, 2019
Whatever you do, use flexible fire sleeve hose after transducer. DO NOT use ridged aluminum fuel line after the transducer or before the spider like under the fuel selector. Suspend the transducer with minimal support for maximum flexibility At least one -10 had engine failure due to cracked fuel line because of this. It ended ok with emergency landing at an airport out of IFR. Lots of vibration down there. Dave Leikam N89DA > On Jan 20, 2019, at 7:53 PM, Tim Lewis wrote: > > > I suspended my FP-5 in the line between the fuel servo and flow divider IAW the drawing on page 20 of the FT-5 manual. I wrapped the transducer with fire sleeve per the instructions. It has worked well in this location for 4 years and over four hundred hours. Several other RV's have done the same thing. I believe Airflow Performance recommended this location to me. > > This location eliminated the surging fuel flow readings I used to see. > > My setup: RV-10, IO-540 C4B5, standard installation with stock Van's fuel selector, stock RV-10 airflow performance boost pump in the tunnel, mechanical fuel pump on the engine. Bendix fuel injection system. No fuel return line. > > -- > Tim Lewis -- HEF (Manassas, VA) > CFI, A&P > RV-6A N47TD -- 1104 hrs - sold > RV-10 N31TD -- 1000 hrs > > Dan Charrois wrote on 1/20/2019 4:54 AM: >> >> Hi everyone. >> >> I've had ongoing fuel pressure fluctuation issues from time to time and am trying to improve every piece of the puzzle to see if I can make them go away. >> >> One of the things I'm doing is relocating my red cube fuel flow transducer from the tunnel (as per plans) to the positive pressure side of the fuel pump (which a lot of people do). According to the FT-60 red cube documentation which I recently stumbled across (https://buy-ei.com/wp-content/uploads/2018/03/FT-60-Info-Rev-F.pdf) they come right out and say "If the aircraft has a fuel pump(s), the flow transducer MUST be installed downstream of the last fuel pump. Installing the transducer upstream of the fuel pump(s) can cause vapor lock and jumpy/inaccurate readings." That sentence definitely conflicts with the plans for putting it in the tunnel, and makes me hopeful that this will make a difference in taming my pressure fluctuations (not to mention should also help the erroneous readings it gives when the electric boost pump is on). >> >> But I'm struggling a bit with where exactly to put it. The two options for the positive pressure side of the fuel pump mean either between the engine pump and servo, or between the servo and spider. Most people I've heard who have moved it have placed it between the servo and spider. >> >> However, in the installation instructions for Electronics International's FP-5 (https://buy-ei.com/wp-content/uploads/FP-5L-II.pdf) which uses the red cube, they suggest mounting locations. Applicable to my fuel injected engine without a fuel return line from the servo, they say to refer to the drawings on page 17 or 18, both of which place the red cube between the fuel pump and servo. Their drawings placing the cube between the servo and spider are marked as being only applicable on aircraft with a fuel return line from the fuel servo. >> >> Has this been noticed before and I'm just late to the party? Or do most people who have been relocating the cube also have a fuel return line, which is why it's been common to mount between the servo and spider? Does anyone know what the reason might be to not install the red cube between the servo and spider on an installation without a fuel return line from the servo? >> >> Thanks! >> >> Dan >> --- >> Dan Charrois >> President, Syzygy Research & Technology >> Phone: 780-961-2213 >> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Jan 21, 2019
What you say is correct, but should be clarified. If the line is on or connects to the engine it must be hose due to the vibration. If in the tunnel, rigid line is okay. There are two types of hose that can be used. Standard fuel line with external fire sleeve is okay. When I got my kit, Vans supplied standard hose without fire sleeve. It needed to have fire sleeve added. Integral fire sleeve hose with teflon core is nicer and longer lasting. It is more flexible, smaller external diameter and does not deteriorate from heat or age. Fuel lines are best fabricated by professional hose shops. It may cost you 50 or 100 more, but will eliminate one source of substantial hazard. While as an A&P I have experience fabricating hoses, given the time it takes, the need for tooling and proper pressure testing, I buy my fuel lines from professional aviation hose shop. Just one more choice to make for each builder. Kelly On 1/20/2019 9:03 PM, Dave Leikam wrote: > > Whatever you do, use flexible fire sleeve hose after transducer. DO NOT use ridged aluminum fuel line after the transducer or before the spider like under the fuel selector. > Suspend the transducer with minimal support for maximum flexibility > At least one -10 had engine failure due to cracked fuel line because of this. It ended ok with emergency landing at an airport out of IFR. Lots of vibration down there. > > Dave Leikam > N89DA ________________________________________________________________________________
Date: Jan 21, 2019
arplnplt(at)gmail.com wrote: > Whatever you do, use flexible fire sleeve hose after transducer. DO NOT use ridged aluminum fuel line after the transducer or before the spider like under the fuel selector. > Suspend the transducer with minimal support for maximum flexibility > At least one -10 had engine failure due to cracked fuel line because of this. It ended ok with emergency landing at an airport out of IFR. Lots of vibration down there. > > Dave Leikam > N89DA Keeping in mind comments of those with greater experience (Hi Kelley), I would disagree with with Dave's minimal support comment. I would think that vibration is only a problem if the transducer does not move in sync with the engine. If the transducer is securely mounted to the engine, then it will move with the engine and so there would be no vibration issue. There are soft aluminium tubes used on the engine and these are not a problem as they are attached to the engine at both ends. It is when things vibrate differently from what it is attached to that things get sporty! I didn't find it hard to make my own braided steel fuel hoses using hose ends and hose tubing from a lo cal speed shop. I used Aeroquip hoses / ends as I wanted to know the provenance of the parts. Use of a Koul Tool (also available at a speed shop) made making up the hoses fast and simple. Cheers Les RV10: C-GCWZ Sold RV10: C-GROK Nearing completion Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487123#487123 ________________________________________________________________________________
Date: Jan 21, 2019
Les, I haven't found it a problem to mount the cube to the engine, but EI recommends against doing that. As for making hoses, true, not difficult, but there are easy ways to screw it up and not know that it isn't right if you don't have the experience to inspect the finished hose. Most shops don't charge that much to do it for you, and properly pressure test the hose. On 1/21/2019 7:11 AM, kearney wrote: > > > arplnplt(at)gmail.com wrote: >> Whatever you do, use flexible fire sleeve hose after transducer. DO NOT use ridged aluminum fuel line after the transducer or before the spider like under the fuel selector. >> Suspend the transducer with minimal support for maximum flexibility >> At least one -10 had engine failure due to cracked fuel line because of this. It ended ok with emergency landing at an airport out of IFR. Lots of vibration down there. >> >> Dave Leikam >> N89DA > > > Keeping in mind comments of those with greater experience (Hi Kelley), I would disagree with with Dave's minimal support comment. I would think that vibration is only a problem if the transducer does not move in sync with the engine. If the transducer is securely mounted to the engine, then it will move with the engine and so there would be no vibration issue. There are soft aluminium tubes used on the engine and these are not a problem as they are attached to the engine at both ends. > > It is when things vibrate differently from what it is attached to that things get sporty! > > I didn't find it hard to make my own braided steel fuel hoses using hose ends and hose tubing from a lo cal speed shop. I used Aeroquip hoses / ends as I wanted to know the provenance of the parts. > > Use of a Koul Tool (also available at a speed shop) made making up the hoses fast and simple. > > Cheers > > Les > > RV10: C-GCWZ Sold > RV10: C-GROK Nearing completion > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487123#487123 > > > > > > > > > ________________________________________________________________________________
Date: Jan 21, 2019
I have 600+ hours on my -10. My transducer is mounted just in front of the servo with flex hose in and out. I made a tab from aluminum stock connected to the air cleaner below and clamped to the hose above that allows the whole thing to move slightly forward and aft. 600 hours, no cracks no problem. I do not have Red Cube. I have the one that comes with Garmin 900x from 2010. Cant remember the manufacturer. Talked directly to them and was told absolutely do not mount directly to the engine for a number of reasons. Also instructed to place after the servo before the spider. My fuel totals are and have always been within .1 gal of of actual burn. Extremely accurate. My 2 cents. Dave Leikam N89DA > On Jan 21, 2019, at 8:19 AM, Kelly McMullen wrote: > > > Les, > I haven't found it a problem to mount the cube to the engine, but EI recommends against doing that. As for making hoses, true, not difficult, but there are easy ways to screw it up and not know that it isn't right if you don't have the experience to inspect the finished hose. Most shops don't charge that much to do it for you, and properly pressure test the hose. > >> On 1/21/2019 7:11 AM, kearney wrote: >> arplnplt(at)gmail.com wrote: >>> Whatever you do, use flexible fire sleeve hose after transducer. DO NOT use ridged aluminum fuel line after the transducer or before the spider like under the fuel selector. >>> Suspend the transducer with minimal support for maximum flexibility >>> At least one -10 had engine failure due to cracked fuel line because of this. It ended ok with emergency landing at an airport out of IFR. Lots of vibration down there. >>> >>> Dave Leikam >>> N89DA >> Keeping in mind comments of those with greater experience (Hi Kelley), I would disagree with with Dave's minimal support comment. I would think that vibration is only a problem if the transducer does not move in sync with the engine. If the transducer is securely mounted to the engine, then it will move with the engine and so there would be no vibration issue. There are soft aluminium tubes used on the engine and these are not a problem as they are attached to the engine at both ends. >> It is when things vibrate differently from what it is attached to that things get sporty! >> I didn't find it hard to make my own braided steel fuel hoses using hose ends and hose tubing from a lo cal speed shop. I used Aeroquip hoses / ends as I wanted to know the provenance of the parts. >> Use of a Koul Tool (also available at a speed shop) made making up the hoses fast and simple. >> Cheers >> Les >> RV10: C-GCWZ Sold >> RV10: C-GROK Nearing completion >> Read this topic online here: >> http://forums.matronics.com/viewtopic.php?p=487123#487123 > > > ________________________________________________________________________________
Date: Jan 21, 2019
Kelly is correct. Any rigid lines in the engine compartment are going to crack. Flexible lines are a must. I used the braided line with Teflon core and fire sleeve for everything. I am fortunate that I have a hose shop (All Hose) close by. They have also been very helpful with any standard or unusual fitting that I needed. I used stainless steel fittings for all the fuel system, firewall forward. I did not bother with Stainless Steel for the oil lines. After all my oil cooler is aluminum and will melt with a fuel fire anyway. The main thing is to make sure that never happens. Robert Jones > On Jan 21, 2019, at 04:48, Kelly McMullen wrote: > > > What you say is correct, but should be clarified. If the line is on or connects to the engine it must be hose due to the vibration. If in the tunnel, rigid line is okay. > There are two types of hose that can be used. Standard fuel line with external fire sleeve is okay. When I got my kit, Vans supplied standard hose without fire sleeve. It needed to have fire sleeve added. Integral fire sleeve hose with teflon core is nicer and longer lasting. It is more flexible, smaller external diameter and does not deteriorate from heat or age. Fuel lines are best fabricated by professional hose shops. It may cost you 50 or 100 more, but will eliminate one source of substantial hazard. While as an A&P I have experience fabricating hoses, given the time it takes, the need for tooling and proper pressure testing, I buy my fuel lines from professional aviation hose shop. Just one more choice to make for each builder. > Kelly > >> On 1/20/2019 9:03 PM, Dave Leikam wrote: >> Whatever you do, use flexible fire sleeve hose after transducer. DO NOT use ridged aluminum fuel line after the transducer or before the spider like under the fuel selector. >> Suspend the transducer with minimal support for maximum flexibility >> At least one -10 had engine failure due to cracked fuel line because of this. It ended ok with emergency landing at an airport out of IFR. Lots of vibration down there. >> Dave Leikam >> N89DA > > > > ________________________________________________________________________________
Date: Jan 21, 2019
SGksDQoNCnJlZ2FyZGluZyB0aGUgdmFwb3IgbG9jayBwcm9ibGVtOg0KV2hhdCBhYm91dCBhIHJl dHVybiBsaW5lIGludG8gb25lIHdpbmcgd2l0aCBhIHZhbHZlIHlvdSBjYW4gb3BlbiBhbmQgY2xv c2UgaW4gZmxpZ2h0Pz8NCkJlZm9yZSBob3Qgc3RhcnRzIHlvdSBjb3VsZCBvcGVuIHRoZSB2YWx2 ZSBhbmQgcmVtb3ZlIHRoZSBhaXIgaW4gdGhlIGZ1ZWwgbGluZXMgd2l0aCB0aGUgZWxlY3RyaWMg ZnVlbCBwdW1wIGZsdXNoaW5nIHdpdGggY29sZCBmdWVsIGZyb20gdGhlIHdpbmcgdGFuay4gQWZ0 ZXIgdGFrZW9mZiB5b3UgY2xvc2UgdGhlIHZhbHZlIHRvIGhhdmUgY29ycmVjdCBmdWVsIGZsb3cg cmVhZGluZ3MuLi4NCg0KR3JlZXRpbmdzIGZyb20gR2VybWFueQ0KDQoNClBldGVyIEFyaW5nZXIN Cg0KQW0gMjEuMDEuMjAxOSB1bSAxNDowMyBzY2hyaWViIEtlbGx5IE1jTXVsbGVuIDxrZWxseW1A YXZpYXRpbmcuY29tPG1haWx0bzprZWxseW1AYXZpYXRpbmcuY29tPj46DQoNCi0tPiBSVjEwLUxp c3QgbWVzc2FnZSBwb3N0ZWQgYnk6IEtlbGx5IE1jTXVsbGVuIDxrZWxseW1AYXZpYXRpbmcuY29t PG1haWx0bzprZWxseW1AYXZpYXRpbmcuY29tPj4NCg0KV2hhdCB5b3Ugc2F5IGlzIGNvcnJlY3Qs IGJ1dCBzaG91bGQgYmUgY2xhcmlmaWVkLiAgSWYgdGhlIGxpbmUgaXMgb24gb3INCmNvbm5lY3Rz IHRvIHRoZSBlbmdpbmUgaXQgbXVzdCBiZSBob3NlIGR1ZSB0byB0aGUgdmlicmF0aW9uLiBJZiBp biB0aGUNCnR1bm5lbCwgcmlnaWQgbGluZSBpcyBva2F5Lg0KVGhlcmUgYXJlIHR3byB0eXBlcyBv ZiBob3NlIHRoYXQgY2FuIGJlIHVzZWQuIFN0YW5kYXJkIGZ1ZWwgbGluZSB3aXRoDQpleHRlcm5h bCBmaXJlIHNsZWV2ZSBpcyBva2F5LiBXaGVuIEkgZ290IG15IGtpdCwgVmFucyBzdXBwbGllZCBz dGFuZGFyZA0KaG9zZSB3aXRob3V0IGZpcmUgc2xlZXZlLiBJdCBuZWVkZWQgdG8gaGF2ZSBmaXJl IHNsZWV2ZSBhZGRlZC4gSW50ZWdyYWwNCmZpcmUgc2xlZXZlIGhvc2Ugd2l0aCB0ZWZsb24gY29y ZSBpcyBuaWNlciBhbmQgbG9uZ2VyIGxhc3RpbmcuIEl0IGlzDQptb3JlIGZsZXhpYmxlLCBzbWFs bGVyIGV4dGVybmFsIGRpYW1ldGVyIGFuZCBkb2VzIG5vdCBkZXRlcmlvcmF0ZSBmcm9tDQpoZWF0 IG9yIGFnZS4gRnVlbCBsaW5lcyBhcmUgYmVzdCBmYWJyaWNhdGVkIGJ5IHByb2Zlc3Npb25hbCBo b3NlIHNob3BzLg0KSXQgbWF5IGNvc3QgeW91IDUwIG9yIDEwMCBtb3JlLCBidXQgd2lsbCBlbGlt aW5hdGUgb25lIHNvdXJjZSBvZg0Kc3Vic3RhbnRpYWwgaGF6YXJkLiBXaGlsZSBhcyBhbiBBJlAg SSBoYXZlIGV4cGVyaWVuY2UgZmFicmljYXRpbmcgaG9zZXMsDQpnaXZlbiB0aGUgdGltZSBpdCB0 YWtlcywgdGhlIG5lZWQgZm9yICB0b29saW5nIGFuZCBwcm9wZXIgcHJlc3N1cmUNCnRlc3Rpbmcs IEkgYnV5IG15IGZ1ZWwgbGluZXMgZnJvbSBwcm9mZXNzaW9uYWwgYXZpYXRpb24gaG9zZSBzaG9w LiBKdXN0DQpvbmUgbW9yZSBjaG9pY2UgdG8gbWFrZSBmb3IgZWFjaCBidWlsZGVyLg0KS2VsbHkN Cg0KT24gMS8yMC8yMDE5IDk6MDMgUE0sIERhdmUgTGVpa2FtIHdyb3RlOg0KLS0+IFJWMTAtTGlz dCBtZXNzYWdlIHBvc3RlZCBieTogRGF2ZSBMZWlrYW0gPGFycGxucGx0QGdtYWlsLmNvbTxtYWls dG86YXJwbG5wbHRAZ21haWwuY29tPj4NCg0KV2hhdGV2ZXIgeW91IGRvLCB1c2UgZmxleGlibGUg ZmlyZSAgc2xlZXZlIGhvc2UgYWZ0ZXIgdHJhbnNkdWNlci4gIERPIE5PVCB1c2UgcmlkZ2VkIGFs dW1pbnVtIGZ1ZWwgbGluZSBhZnRlciB0aGUgdHJhbnNkdWNlciBvciBiZWZvcmUgdGhlIHNwaWRl ciBsaWtlIHVuZGVyIHRoZSBmdWVsIHNlbGVjdG9yLg0KU3VzcGVuZCB0aGUgdHJhbnNkdWNlciB3 aXRoIG1pbmltYWwgc3VwcG9ydCBmb3IgbWF4aW11bSBmbGV4aWJpbGl0eQ0KQXQgbGVhc3Qgb25l IC0xMCBoYWQgZW5naW5lIGZhaWx1cmUgZHVlIHRvIGNyYWNrZWQgZnVlbCBsaW5lIGJlY2F1c2Ug b2YgdGhpcy4gIEl0IGVuZGVkIG9rIHdpdGggZW1lcmdlbmN5IGxhbmRpbmcgYXQgYW4gYWlycG9y dCBvdXQgb2YgSUZSLiAgTG90cyBvZiB2aWJyYXRpb24gZG93biB0aGVyZS4NCg0KRGF2ZSBMZWlr YW0NCk44OURBDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgLSBUaGUgUlYxMC1MaXN0IEVtYWlsIEZv cnVtIC0NCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBi cm93c2UNCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2Ny aXB0aW9uLA0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hh dCwgRkFRLA0KXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCl8tPQ0KXy09ICAg LS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQpfLT0NCl8t PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09DQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCl8tPSBTYW1l IGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KXy09DQpf LT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQpfLT0NCl8tPT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAg ICAgICAgICAgIC0gTkVXIE1BVFJPTklDUyBMSVNUIFdJS0kgLQ0KXy09IEFkZCBzb21lIGluZm8g dG8gdGhlIE1hdHJvbmljcyBFbWFpbCBMaXN0IFdpa2khDQpfLT0gICAtLT4gaHR0cDovL3dpa2ku bWF0cm9uaWNzLmNvbQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9u IFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQpf LT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4u DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cg0KDQoNCg0KDQo ________________________________________________________________________________
Date: Jan 21, 2019
Airflow Performance makes a bypass valve and fittings to mount just before t he fuel distributor. It can=99t be used in flight because all fuel is b ypassed back to a Wing tank. Fuel vapors forming after the engine driven fue l pump are very unlikely because of the higher pressure. Vapors forming befo re the electric fuel pump are the most likely because the pump is sucking in stead of pushing, lowering the pressure. I find it hard to believe that pilo ts are experiencing vapors forming after the engine driven fuel pump. If the re are vapors forward they were formed earlier, or after shutdown because of residual heat. The Airflow Performance calve solves the last problem by pur ging hot fuel and vapors back to a fuel tank before start. Robert Jones > On Jan 21, 2019, at 07:45, Peter wrote: > > Hi, > > regarding the vapor lock problem: > What about a return line into one wing with a valve you can open and close in flight?? > Before hot starts you could open the valve and remove the air in the fuel l ines with the electric fuel pump flushing with cold fuel from the wing tank. After takeoff you close the valve to have correct fuel flow readings... > > Greetings from Germany > > > Peter Aringer > >> Am 21.01.2019 um 14:03 schrieb Kelly McMullen : >> >> >> What you say is correct, but should be clarified. If the line is on or >> connects to the engine it must be hose due to the vibration. If in the >> tunnel, rigid line is okay. >> There are two types of hose that can be used. Standard fuel line with >> external fire sleeve is okay. When I got my kit, Vans supplied standard >> hose without fire sleeve. It needed to have fire sleeve added. Integral >> fire sleeve hose with teflon core is nicer and longer lasting. It is >> more flexible, smaller external diameter and does not deteriorate from >> heat or age. Fuel lines are best fabricated by professional hose shops. >> It may cost you 50 or 100 more, but will eliminate one source of >> substantial hazard. While as an A&P I have experience fabricating hoses, >> given the time it takes, the need for tooling and proper pressure >> testing, I buy my fuel lines from professional aviation hose shop. Just >> one more choice to make for each builder. >> Kelly >> >>> On 1/20/2019 9:03 PM, Dave Leikam wrote: >>> >>> Whatever you do, use flexible fire sleeve hose after transducer. DO NO T use ridged aluminum fuel line after the transducer or before the spider li ke under the fuel selector. >>> Suspend the transducer with minimal support for maximum flexibility >>> At least one -10 had engine failure due to cracked fuel line because of t his. It ended ok with emergency landing at an airport out of IFR. Lots of v ibration down there. >>> >>> Dave Leikam >>> N89DA >> ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= >> >> >> >> >> ________________________________________________________________________________
Date: Jan 21, 2019
Hi again everyone. To add some more info to the discussion, I just heard back from a tech at Electronics International (the makers of the red cube) to get their take on placement. Obviously, they disagree with the placement in the tunnel between the electric and mechanical pump. In addition to the "water hammer" effect of placing it in that location that causes erratically high readings, they said their transducers were designed for fuel to be pushed through, not sucked through. As far as the discussion of where specifically to locate it past both pumps (between pump to servo or servo to spider), they suggested that in a case without a return line from the servo they suggest their diagram on page 18 (between the pump and servo). They said their rationale for not placing it between servo to spider in that situation is based on maintaining the calibrated pressure on the outlet from the servo (based on the number of orifices/volume it's serving). Apparently, the cube in that position has the potential of changing this pressure provided by the servo slightly, and as such their STC for installation without a return line disallows that. With that said, they know that many homebuilt owners have installed it between the servo and divider, without return lines, and obviously it's working for them. Dan --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Date: Jan 21, 2019
There is not a vapor lock problem. Some engines will run a bit rough at taxi power after a hot start, but that is uneven fuel delivery, and maybe some vapor, but it isn't a lock. Hot starting is the challenge of getting the right mixture during cranking, not vapor lock. I have been flying with a Bendix RSA-5 system for 20 years now. On the 200 hp 4 cyl Lycoming in the Mooney preceding my RV-10, it was easy to flood the engine when hot. With the 6 cyl 540 engine, it isn't as prone to flooding, it is just getting the right mixture. The mechanical pump doesn't necessarily generate enough pressure at cranking speeds. I get better hot start reliability with the boost pump on, and then bring in the mixture slowly. When right, the engine fires and keeps running. Without the boost pump it often fires and then quits. W'ith the RSA system it is just a matter of finding what procedure is most reliable. If the approach from the mixture cutoff isn't working, and adding throttle doesn't help, you can perhaps go to full rich and flood engine, then lean out until it fires. Sent from my TRS-80 Model 100 On Mon, Jan 21, 2019 at 8:54 AM Peter wrote: > Hi, > > regarding the vapor lock problem: > What about a return line into one wing with a valve you can open and close > in flight?? > Before hot starts you could open the valve and remove the air in the fuel > lines with the electric fuel pump flushing with cold fuel from the wing > tank. After takeoff you close the valve to have correct fuel flow > readings... > > Greetings from Germany > > > Peter Aringer > > Am 21.01.2019 um 14:03 schrieb Kelly McMullen : > > > What you say is correct, but should be clarified. If the line is on or > connects to the engine it must be hose due to the vibration. If in the > tunnel, rigid line is okay. > There are two types of hose that can be used. Standard fuel line with > external fire sleeve is okay. When I got my kit, Vans supplied standard > hose without fire sleeve. It needed to have fire sleeve added. Integral > fire sleeve hose with teflon core is nicer and longer lasting. It is > more flexible, smaller external diameter and does not deteriorate from > heat or age. Fuel lines are best fabricated by professional hose shops. > It may cost you 50 or 100 more, but will eliminate one source of > substantial hazard. While as an A&P I have experience fabricating hoses, > given the time it takes, the need for tooling and proper pressure > testing, I buy my fuel lines from professional aviation hose shop. Just > one more choice to make for each builder. > Kelly > > On 1/20/2019 9:03 PM, Dave Leikam wrote: > > > Whatever you do, use flexible fire sleeve hose after transducer. DO NOT > use ridged aluminum fuel line after the transducer or before the spider > like under the fuel selector. > > Suspend the transducer with minimal support for maximum flexibility > > At least one -10 had engine failure due to cracked fuel line because of > this. It ended ok with emergency landing at an airport out of IFR. Lots > of vibration down there. > > > Dave Leikam > > N89DA > > ________________________________________________________________________________
Date: Jan 22, 2019
Data point My -10 started flying in May2016. Since then, I have acquired 370 hours and an instrument rating in it. I have G3x touch and review my data after each flight (retired). I copied another builders red cube location and my pressure and flow has been rock solid. My YIO-540-D4A5 had two threaded holes in the sump where I installed a piece of angle. I installed the cube there using black baffle material to isolate it from vibration. Tom Swarengen (TS FlightLine) made all my fire sleeved lines. No issues to date. ________________________________________________________________________________
Date: Jan 23, 2019
Ive used the stock valve in my 6, it got stiff on me once but disassembled and lubed, no problem since. Using the stock valve on my 10 and no problems, using the red pointer knob. -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487204#487204 ________________________________________________________________________________
Date: Jan 23, 2019
Ive used the stock valve in my 6, it got stiff on me once but disassembled and lubed, no problem since. Using the stock valve on my 10 and no problems, using the red pointer knob. -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487207#487207 ________________________________________________________________________________
Subject: Door seal
Date: Feb 01, 2019
After 12 years, I need to replace one of my Vans supplied door seals. Has anyone found a better door seal than what you can get from Vans? Thanks, grumpy N184JM ________________________________________________________________________________
Subject: Section 38 Page 38-8
Date: Feb 14, 2019
With regard to Step 4, and Figure 1. It appears that the cable exiting the left side of the fuselage is supposed to cross over the cable exiting the right side of the fuselage. It seems to me that this could use more clarity. It also seems like it would have been prudent to have a guide to prevent the cables from ever rubbing in that area. I suspect there are some flying examples that have this wrong. I welcome your comments. Kelly 80466, flying for almost 3 years ________________________________________________________________________________
Subject: Re: Section 38 Page 38-8
Date: Feb 14, 2019
Though the diagram appears to have the cables rubbing against each other, in 3 dimensions they don't come close enough to one another to worry about them chafing. It's one of those situations where the "real world" example makes more sense than the diagram. There wouldn't be flying examples of anyone getting this wrong, since if you didn't have the crossover of cables, the rudder would operate backwards. Dan > On 2019-Feb-14, at 8:12 PM, Kelly McMullen wrote: > > > With regard to Step 4, and Figure 1. > It appears that the cable exiting the left side of the fuselage is supposed to cross over the cable exiting the right side of the fuselage. > It seems to me that this could use more clarity. It also seems like it would have been prudent to have a guide to prevent the cables from ever rubbing in that area. I suspect there are some flying examples that have this wrong. I welcome your comments. > Kelly > 80466, flying for almost 3 years > > > --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Date: Feb 14, 2019
Well, they may have been "flown" examples for one flight. After that they would probably be salvage examples. ;) I agree. If someone follows the plans, they seem to be just fine. I'd worry more about wearing through the snap bushings, especially in places where the cable is always rubbing in the same spot. That's something to check ever condition inspection. Tim On 2/14/2019 9:47 PM, Dan Charrois wrote: > > There wouldn't be flying examples of anyone getting this wrong, since if you didn't have the crossover of cables, the rudder would operate backwards. > > Dan > ________________________________________________________________________________
Date: Feb 14, 2019
I have seen an example of where the cable cross-over existed, but was "wrong" as the wrong cable on top, so that the cables in fact did rub. I wasn't suggesting one might not crossover the cables, that is clearly shown on the plans. What is not so clear is which one needs to be on top. Until tension is applies it is not so obvious. Kelly On 2/14/2019 8:47 PM, Dan Charrois wrote: > > Though the diagram appears to have the cables rubbing against each other, in 3 dimensions they don't come close enough to one another to worry about them chafing. It's one of those situations where the "real world" example makes more sense than the diagram. > > There wouldn't be flying examples of anyone getting this wrong, since if you didn't have the crossover of cables, the rudder would operate backwards. > > Dan > >> On 2019-Feb-14, at 8:12 PM, Kelly McMullen wrote: >> >> >> With regard to Step 4, and Figure 1. >> It appears that the cable exiting the left side of the fuselage is supposed to cross over the cable exiting the right side of the fuselage. >> It seems to me that this could use more clarity. It also seems like it would have been prudent to have a guide to prevent the cables from ever rubbing in that area. I suspect there are some flying examples that have this wrong. I welcome your comments. >> Kelly >> 80466, flying for almost 3 years >> >> >> > > > > --- > Dan Charrois > President, Syzygy Research & Technology > Phone: 780-961-2213 > > > > > ________________________________________________________________________________
Subject: Build Time
From: "Greg McFarlane" <grbcmcfarlane(at)gmail.com>
Date: Feb 15, 2019
Can anyone give me an idea of build times in hours that have been put in to build the Elevators and also the wings (not QB) ? Know I could probably trawl through some of the excellent build logs that are around to get an idea, but hopefully this will be an easier way to get the info [Rolling Eyes] [Rolling Eyes] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487609#487609 ________________________________________________________________________________
Date: Feb 15, 2019
Subject: Re: Build Time
SSBzcGVudCA3MS41IGhvdXJzIG9uIG15IGVsZXZhdG9ycy4gVGhhdCBpbmNsdWRlcyBvcHRpb25h bC8gZGlzY3JldGlvbmFyeSB0aW1lIGZvciBwcmltaW5nLMKgIHByb3NlYWwgZm9yIHRoZSB0cmFp bGluZyBlZGdlLCBhbmQgbWFraW5nIG1vZGlmaWNhdGlvbiBmb3Igc3RhdGljIHdpY2tzLsKgQXMg Zm9yIHRoZSB3aW5nLCBJIGFtIDIyNCBob3VycyBpbnRvIGl0IHNvIGZhci4gTWFpbiB3aW5nIGJv ZHkgaXMgY29tcGxldGUgdGhyb3VnaCB0aGUgdG9wIHNraW4gYXR0YWNoZWQgYW5kIGdhcCBmYWly aW5ncyBhdHRhY2hlZC4gRmxhcHMgYXJlIGNvbXBsZXRlIGFuZCB3b3JraW5nIG9uIHRoZSBmdWVs IHRhbmtzLCBwcm9iYWJseSBhYm91dCA2MCUgY29tcGxldGUgYnV0IEkgaGF2ZW4ndCBsZWFrIHRl c3RpbmcgYW55dGhpbmcgeWV0LCBMT0whwqBIb3BlIHRoaXMgaGVscHMuU2VudCBmcm9tIG15IFQt TW9iaWxlIDRHIExURSBEZXZpY2UKLS0tLS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLUZy b206IEdyZWcgTWNGYXJsYW5lIDxncmJjbWNmYXJsYW5lQGdtYWlsLmNvbT4gRGF0ZTogMi8xNS8x OSAgMDQ6MjUgIChHTVQtMDU6MDApIFRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbSBTdWJqZWN0 OiBSVjEwLUxpc3Q6IEJ1aWxkIFRpbWUgLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTog IkdyZWcgTWNGYXJsYW5lIiA8Z3JiY21jZmFybGFuZUBnbWFpbC5jb20+Q2FuIGFueW9uZSBnaXZl IG1lIGFuIGlkZWEgb2YgYnVpbGQgdGltZXMgaW4gaG91cnMgdGhhdCBoYXZlIGJlZW4gcHV0IGlu IHRvIGJ1aWxkIHRoZSBFbGV2YXRvcnMgYW5kIGFsc28gdGhlIHdpbmdzIChub3QgUUIpID/CoMKg IEtub3cgSSBjb3VsZCBwcm9iYWJseSB0cmF3bCB0aHJvdWdoIHNvbWUgb2YgdGhlIGV4Y2VsbGVu dCBidWlsZCBsb2dzIHRoYXQgYXJlIGFyb3VuZCB0byBnZXQgYW4gaWRlYSwgYnV0IGhvcGVmdWxs eSB0aGlzIHdpbGwgYmUgYW4gZWFzaWVyIHdheSB0byBnZXQgdGhlIGluZm/CoMKgIFtSb2xsaW5n IEV5ZXNdwqAgW1JvbGxpbmcgRXllc11SZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6aHR0cDov L2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD00ODc2MDkjNDg3NjA5Xy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT1f LT3CoMKgwqDCoMKgwqDCoMKgwqAgLSBUaGUgUlYxMC1MaXN0IEVtYWlsIEZvcnVtIC1fLT0gVXNl IHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlXy09IHRoZSBt YW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sXy09IEFyY2hp dmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLF8tPSBQaG90b3No YXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Xy09Xy09wqDCoCAtLT4gaHR0cDovL3d3dy5tYXRyb25p Y3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3RfLT1fLT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PV8tPcKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtXy09IFNhbWUgZ3JlYXQgY29udGVudCBh bHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhXy09Xy09wqDCoCAtLT4gaHR0cDovL2Zv cnVtcy5tYXRyb25pY3MuY29tXy09Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT1fLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAt IE5FVyBNQVRST05JQ1MgTElTVCBXSUtJIC1fLT0gQWRkIHNvbWUgaW5mbyB0byB0aGUgTWF0cm9u aWNzIEVtYWlsIExpc3QgV2lraSFfLT3CoMKgIC0tPiBodHRwOi8vd2lraS5tYXRyb25pY3MuY29t Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT1fLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIg U2l0ZSAtXy09wqAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhXy09wqDCoMKg wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtTWF0 dCBEcmFsbGUsIExpc3QgQWRtaW4uXy09wqDCoCAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29t L2NvbnRyaWJ1dGlvbl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09 ________________________________________________________________________________
Date: Feb 15, 2019
I spent 547.5 on both wings (non-QB), not priming except where Van's required, this included pressure testing on the wing tanks. Used the Aveo Engineering ZipTips as opposed to Vans wing tips and lights. Also included the Dynon autopilot servo for the ailerons and Dynon heated pitot with mast. Don't get bogged down in the tank build. Just slog through it until done. It's not as bad as everyone out there says it is. Although more expensive, found the pro-seal in the tubes worked really well. I was really liberal with it and ended up using 18 tubes on both tanks. Leak test only showed one rivet with a leak. Easily fixed. Frustration with leaking tanks was kept to a minimum. As they say, build on!! On Fri, Feb 15, 2019 at 4:38 AM parish wrote: > I spent 71.5 hours on my elevators. That includes optional/ discretionary > time for priming, proseal for the trailing edge, and making modification > for static wicks. > > As for the wing, I am 224 hours into it so far. Main wing body is complete > through the top skin attached and gap fairings attached. Flaps are complete > and working on the fuel tanks, probably about 60% complete but I haven't > leak testing anything yet, LOL! > > Hope this helps. > > > Sent from my T-Mobile 4G LTE Device > > -------- Original message -------- > From: Greg McFarlane <grbcmcfarlane(at)gmail.com> > Date: 2/15/19 04:25 (GMT-05:00) > To: rv10-list(at)matronics.com > Subject: RV10-List: Build Time > > > > > Can anyone give me an idea of build times in hours that have been put in > to build the Elevators and also the wings (not QB) ? Know I could > probably trawl through some of the excellent build logs that are around to > get an idea, but hopefully this will be an easier way to get the info > [Rolling Eyes] [Rolling Eyes] > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487609#487609 > > ________________________________________________________________________________
Date: Feb 16, 2019
Subject: MAC 3 LED Trim Indicator...
Hello, A fellow homebuilder friend of mine has a old-style three-LED (Red|Green|Red) MAC Trim Position Indicator. The Green LED was burned out, and the wires were cut off too short. I told him I would try to replace the LED and lead wires. I got it apart without completely destroying it. But the internal wiring and polarity of the LEDs isn't that clear to me, nor is the actuation of it through a servo electronically. I'm not sure how to activate three LEDs with only three wires? (Or did there used to be four wires?) Does anyone have a PDF schematic of the 3-LED MAC Trim Indicator that you could email to me? Or better yet, does anyone have a spare or unused one of these they would like to sell me? Thank you, Matt Dralle Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Feb 16, 2019
Date: Feb 16, 2019
Subject: Re: MAC 3 LED Trim Indicator...
Hi Matt, The obvious (but probably incorrect) answer is that the chassis is the 4th wire. Is the housing metal? J John Baer Lititz Precision Products LLC Lititz PA USA www.LititzPP.com Cell (EST USA) (717) 413-7931 Skype: John.Baer7712 From: <owner-rv10-list-server(at)matronics.com> on behalf of Matt Dralle <dralle(at)matronics.com> Date: Saturday, February 16, 2019 at 7:32 PM Subject: RV10-List: MAC 3 LED Trim Indicator... Hello, A fellow homebuilder friend of mine has a old-style three-LED (Red|Green|Red) MAC Trim Position Indicator. The Green LED was burned out, and the wires were cut off too short. I told him I would try to replace the LED and lead wires. I got it apart without completely destroying it. But the internal wiring and polarity of the LEDs isn't that clear to me, nor is the actuation of it through a servo electronically. I'm not sure how to activate three LEDs with only three wires? (Or did there used to be four wires?) Does anyone have a PDF schematic of the 3-LED MAC Trim Indicator that you could email to me? Or better yet, does anyone have a spare or unused one of these they would like to sell me? Thank you, Matt Dralle Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Wing walk
Date: Feb 18, 2019
Any recommendations for wing walk material? I have searched the archives and a few recommended the clear from ACS. Hows the durability of the clear? Any other recommendations? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487669#487669 ________________________________________________________________________________
Subject: Re: Wing walk
Date: Feb 18, 2019
I think they're all durable, but I've had people buy the clear who've not been completely happy in the long run, mainly because it can yellow and it gets dirty and looks bad then. So it's more common to go black. But, if someone else has a different reply, please add it. Mine is not first hand but second hand. Tim On 2/18/19 8:22 AM, whodja wrote: > > Any recommendations for wing walk material? I have searched the archives and a few recommended the clear from ACS. Hows the durability of the > clear? Any other recommendations? > > ________________________________________________________________________________
Date: Feb 18, 2019
I like the black because in addition to not yellowing it gives people a clear image of where it is okay to step. Marcus > On Feb 18, 2019, at 9:41 AM, Tim Olson wrote: > > > I think they're all durable, but I've had people buy the clear who've > not been completely happy in the long run, mainly because it can > yellow and it gets dirty and looks bad then. So it's more common to > go black. > But, if someone else has a different reply, please add it. Mine is > not first hand but second hand. > > Tim > > >> On 2/18/19 8:22 AM, whodja wrote: >> Any recommendations for wing walk material? I have searched the archives and a few recommended the clear from ACS. Hows the durability of the >> clear? Any other recommendations? > > > ________________________________________________________________________________
Date: Feb 18, 2019
I have the vans black wing walk installed. Its been 6 years and still looks new. It comes with the cutouts for the screws -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487680#487680 ________________________________________________________________________________
Date: Feb 18, 2019
I totally agree with Tim and Marcus. FWIW Sent from my iPhone Geoff Combs Aerosport Modeling & Design > On Feb 18, 2019, at 10:18 AM, Marcus Cooper wrote: > > > I like the black because in addition to not yellowing it gives people a clear image of where it is okay to step. > > Marcus > > >> On Feb 18, 2019, at 9:41 AM, Tim Olson wrote: >> >> >> I think they're all durable, but I've had people buy the clear who've >> not been completely happy in the long run, mainly because it can >> yellow and it gets dirty and looks bad then. So it's more common to >> go black. >> But, if someone else has a different reply, please add it. Mine is >> not first hand but second hand. >> >> Tim >> >> >>> On 2/18/19 8:22 AM, whodja wrote: >>> Any recommendations for wing walk material? I have searched the archives and a few recommended the clear from ACS. Hows the durability of the >>> clear? Any other recommendations? >> >> >> > > > > > > ________________________________________________________________________________
Date: Feb 19, 2019
Thanks guys! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487687#487687 ________________________________________________________________________________
Date: Feb 19, 2019
I did the test - black on one side, clear on the other! They both work, have been durable, but, as Tim said, the clear is near impossible to clean. Id suggest the black. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487691#487691 ________________________________________________________________________________
Date: Feb 19, 2019
This is relevant to me as I need to replace the wing walk during the inspection this year. Mine is peeling off (maybe because my airplane is so fast?!? ha) Any experience with the paint on kind? What is the best solvent to remove the old wing walk / adhesive without paint damage? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487706#487706 ________________________________________________________________________________
Date: Feb 20, 2019
I removed some in the fall and just used a heat gun to heat it gently, and then it peeled up without any paint issues. But it would be easily possible to pull paint off rivet heads if they're covered. That said, as long as you're reapplying, you can always paint the rivet heads and they should stay buried. Peel towards the center from all edges first, and that should help ensure no paint issues. Tim On 2/20/2019 1:59 AM, tshort wrote: > > This is relevant to me as I need to replace the wing walk during the inspection this year. Mine is peeling off (maybe because my airplane is so fast?!? ha) > > Any experience with the paint on kind? > > What is the best solvent to remove the old wing walk / adhesive without paint damage? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487706#487706 > > ________________________________________________________________________________
Date: Feb 20, 2019
If it is the self-adhesive variety, I would recommend gentle use of a heat gun....as I see Tim just suggested. I would recommend against the brushed-on variety. I've never seen any hand-applied wing walk that looked right. I'm not sure how paint shops put it on, but they generally do a good job. Sent from my TRS-80 Model 100 On Wed, Feb 20, 2019 at 1:05 AM tshort wrote: > > This is relevant to me as I need to replace the wing walk during the > inspection this year. Mine is peeling off (maybe because my airplane is so > fast?!? ha) > > Any experience with the paint on kind? > > What is the best solvent to remove the old wing walk / adhesive without > paint damage? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487706#487706 > > ________________________________________________________________________________
Subject: unsuscribe
Date: Feb 23, 2019
Germn Walas www.globalworld.com.ar >From USA (+01) 786-207-4816 Desde Arg. (+54) 11 5-984-1301 Skype: gwalas www.linkedin.com/in/germanwalas/ -----Original Message----- From: owner-rv10-list-server(at)matronics.com On Behalf Of RV10-List Digest Server Sent: Saturday, February 23, 2019 2:44 AM Subject: RV10-List Digest: 0 Msgs - 02/22/19 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV10-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV10-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-02-22&Archive=RV10 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2019-02-22&Archive=RV10 =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV10-List Digest Archive --- Total Messages Posted Fri 02/22/19: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________________
Subject: Paint stencils
Date: Feb 27, 2019
Does anyone have a recommendation for paint stencils? My designer was not Scheme Designers but it should have been. I have a great painter and stencils would be a big help. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487841#487841 ________________________________________________________________________________
Date: Feb 27, 2019
Subject: Re: Paint stencils
I used these guys, they were awesome and delivered good quality work: http://moodyaero.com/ Lenny > On Feb 27, 2019, at 5:55 PM, whodja wrote: > > > Does anyone have a recommendation for paint stencils? My designer was > not Scheme Designers but it should have been. > > I have a great painter and stencils would be a big help. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487841#487841 > > > > > > > > > ________________________________________________________________________________
Date: Feb 28, 2019
Thanks Lenny Did they do your 10? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487848#487848 ________________________________________________________________________________
Date: Feb 28, 2019
I used Denny Demeter at AvGrafix. http://www.avgrafix.com/ .They did all the graphics in vinyl for my Pietenpol Air Camper that I built 15 years ago (you can see a picture of it on their web page at the top right corner of their photo gallery). The graphics were done in vinyl, but the 30" numbers on the wings were a vinyl stencil and the numbers were painted on using their stencils. All has lasted well for 15 years of flying all over the country, even in rain (not something you want to do in an open cockpit airplane). They are very good people to work with. Jack Phillips Pietenpol Air Camper NX899JP, "Icarus Plummet" RV-10 # 40610, N142KW, almost (finishing wheel fairings before bolting the wings on) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of whodja Sent: Wednesday, February 27, 2019 8:56 PM Subject: RV10-List: Paint stencils Does anyone have a recommendation for paint stencils? My designer was not Scheme Designers but it should have been. I have a great painter and stencils would be a big help. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487841#487841 ________________________________________________________________________________
Date: Feb 28, 2019
Yes, it was for the -10. Lenny > On Feb 28, 2019, at 3:48 AM, whodja wrote: > > > Thanks Lenny > > Did they do your 10? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487848#487848 > > > > > > > > > ________________________________________________________________________________
Subject: Kitlog seems to be down - is it still supposed to be operational?
Date: Feb 28, 2019
Was recently checking my build pages and it seems the site has been down for at least a few days. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: Kitlog seems to be down - is it still supposed to be operational?
Date: Mar 01, 2019
Nevermind - it's up an running again. On 2/28/2019 4:47 PM, Bill Watson wrote: > > Was recently checking my build pages and it seems the site has been > down for at least a few days. > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Loose Control Stick
Date: Mar 03, 2019
Hi I have noticed that there is more forward/backward movement in the control stick than I would like. It appears is the due to the control stick OD being somewhat smaller than the WD-1011 ID. Has anyone else encountered this and if so what was the solution. Cheers Les RV10 - C-GCWZ sold RV10 - C-GROK almost complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487899#487899 ________________________________________________________________________________
Date: Mar 03, 2019
Subject: Re: Loose Control Stick
I saw something similar, many of us have. It was the brass bushing further down on the assembly. (sorry, dont have the part numbers now) I turned down a new bushing to a custom fit out of delrin, and its got zero slop now. Phil > On Mar 3, 2019, at 7:16 PM, kearney wrote: > > > Hi > > I have noticed that there is more forward/backward movement in the control stick than I would like. It appears is the due to the control stick OD being somewhat smaller than the WD-1011 ID. Has anyone else encountered this and if so what was the solution. > > Cheers > > Les > > RV10 - C-GCWZ sold > RV10 - C-GROK almost complete > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487899#487899 > > > > > > > > > ________________________________________________________________________________
Date: Mar 04, 2019
Les Mine are an interference fit on both sticks. Something has changed. Warm regards PATRICK =9CSafety Never Sleeps=9D > On 4 Mar 2019, at 11:46, kearney wrote: > > > Hi > > I have noticed that there is more forward/backward movement in the control stick than I would like. It appears is the due to the control stick OD bein g somewhat smaller than the WD-1011 ID. Has anyone else encountered this and if so what was the solution. > > Cheers > > Les > > RV10 - C-GCWZ sold > RV10 - C-GROK almost complete > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487899#487899 > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Mar 03, 2019
Hi Patrick I don't recall this being a problem on my first -10. In any event,the sticks are *not* an interference fit now. I think I'll call Vans in the am. Thanks Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487902#487902 ________________________________________________________________________________
Date: Mar 03, 2019
Very common. Some are worse than others Sent from my iPad > On Mar 3, 2019, at 8:57 PM, kearney wrote: > > > Hi Patrick > > I don't recall this being a problem on my first -10. In any event,the sticks are *not* an interference fit now. I think I'll call Vans in the am. > > Thanks > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487902#487902 > > > > > > > > > ________________________________________________________________________________
Date: Mar 03, 2019
David That is not a comforting thought! Controls are not something that should be "sloppy". I'll post whatever info I get from Vans. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487905#487905 ________________________________________________________________________________
Date: Mar 04, 2019
Ever flown a Cessna? ;) -----Original Message----- David That is not a comforting thought! Controls are not something that should be "sloppy". I'll post whatever info I get from Vans. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=487905#487905 ________________________________________________________________________________
Date: Mar 04, 2019
Ben Yes I have. The rehab was extensive. Cheers Les Sent from my iPhone > On Mar 4, 2019, at 8:50 AM, Ben Westfall wrote: > > > Ever flown a Cessna? ;) > > -----Original Message----- > > David > > That is not a comforting thought! Controls are not something that should be > "sloppy". I'll post whatever info I get from Vans. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=487905#487905 > > > > > > > > > > > > ________________________________________________________________________________
Date: Mar 04, 2019
Subject: Plumbing in some extra fuel capacity
All, I would like to build in some fuel plumbing to allow for optional extra capacity, perhaps using tanks like these: https://www.turtlepac.com/products/collapsible-aircraft-ferry-tanks/ A 25 or 33 gallon tank would add significant range for the occasional long distance flight or allow for improved range at high speed cruise. I am trying to not design in a weak point in my fuel system though, as it is so critical and there have been some accidents related to fuel system issues. One idea is to add a 'T' AN fitting to the fuel line under the copilot seat, that would then have an aluminum line run along the right side of the cockpit to the right rear seat, and would normally hide under the side cover next to that seat. I would put a shutoff valve there that would normally be closed, and on the other side of the valve put an appropriate fitting that could attach to the ferry tank that could be strapped to the seat. To use, take the side cover off, connect the ferry tank, bleed the air out of the system, then during flight fuel could be pumped into the right tank while running the engine on the left tank (or maybe the right tank, might not matter). When the ferry tank is nearly empty, shut off the pump and close the valve. One concern is that the extension plumbing would have air in it until it is used, and air bubbles could conceivably find their way into the main line. The extension line could be filled with fuel too, but that would sit there stagnant for possibly long periods of time (is that an issue?). I had also considered adding a check valve to prevent fuel from flowing from the main tank side back into the extension plumbing (in case of a leak in the extension), but that would be generally uphill so gravity would be on your side there. Another possibility is to plumb directly to the tank, but the tank is finished and I'm not sure I'd like to poke any more holes in it, which would probably leave some aluminum bits inside to boot. I can't just plumb into the vent line since there is no way to let the displaced air out of the tank when pumping in fuel through that line. I don't want to start a debate about the RV-10 range etc, just want to hear thoughts on what's likely to work without adding too much extra complexity and risk. Thanks for your thoughts! Kent Ogden #40710 ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Mar 04, 2019
Subject: Re: Plumbing in some extra fuel capacity
Interesting timing, I just discussed this with another RV-10 builder earlier today. Some thoughts: - There are commercial wingtip tanks that add 15 gallons or so of fuel, but I ruled this option out as it added a lot of complexity, weight and has a hug e price tag. Add to that the obvious =9CVan=99s did not conside r this in the wing design=9D aspect. - My neighbor at Dogwood is the guy that flew his specialty build Lancair IV over both the North and South Poles. He had a total of seven fuel tanks ad ded to the plane (380 or so gallons). Five of the tanks he custom made usin g carbon fiber board to fit all the contours of the plane, the aft large one strong enough to support the one large and one small badder tanks like that you reference. He had a very straightforward approach to fuel plumbing to m itigate risk of something going wrong - yielding a forced landing in the Arc tic or Antarctic. He had a single, simple 90 degree isolation valve for eac h tank going to a Facet pump. The transferred fuel only goes to the 10 gall on header tank that has a clear sight glass for fuel level. He transferred f uel every hour or so like Limburg did in the Sprit of St. Louis. Stealing from the above and ruling out the header tank or extra wing tanks l eads to a 20+ gallon ferry tank that gets mounted in place of one or both re ar seats. The ferry tank being one of many composite racing tank options (I would not consider the badder tank for this application). I have this set u p for my new RV-8 project, the tank being fed into a T on the right tank fue l line before it goes to the fuel valve. The T will be normally capped when not being used for this connection. Ferry tank vent will go to the wing ro ot area or aft to exit the bottom of the fuselage. Operation will be to bur n 20 or so gallons out of the right tank, fly on the left tank, open the fer ry tank isolation valve and turn on the Facet pump (with check valve) to tra nsfer fuel to the right tank. My Lancair buddy tells me the change in noise from the Facet pump when the ferry tank is dry is obvious - but you will al so get the right tank fuel sender increasing as a positive indication. My thinking is that 99+% of the time having more than the five hours of gas w ill not be needed, so the ferry tank will spend most of it=99s life on the shelf in the hangar. Make it easy to get in and out of the plane. If you want to get fancy you can build a couple of tanks out of carbon that e xactly fits the rear seat floor area, moving the ferry tank weigh a little m ore forward toward the center of gravity. No other changes to the standard fuel system other than this T is done. Whi le I did build the right tank with an extra fuel fitting for this purpose I d ecided a T on the inside of the fuselage line was more practical. For the RV-10 you lose one or both back seats depending on ferry tank size, b ut the added weight of the fuel translates to not carrying four people. Carl > On Mar 4, 2019, at 4:03 PM, Kent Ogden wrote: > > All, > > I would like to build in some fuel plumbing to allow for optional extra ca pacity, perhaps using tanks like these: > > https://www.turtlepac.com/products/collapsible-aircraft-ferry-tanks/ > > A 25 or 33 gallon tank would add significant range for the occasional long distance flight or allow for improved range at high speed cruise. > > I am trying to not design in a weak point in my fuel system though, as it i s so critical and there have been some accidents related to fuel system issu es. > > One idea is to add a 'T' AN fitting to the fuel line under the copilot sea t, that would then have an aluminum line run along the right side of the coc kpit to the right rear seat, and would normally hide under the side cover ne xt to that seat. I would put a shutoff valve there that would normally be c losed, and on the other side of the valve put an appropriate fitting that co uld attach to the ferry tank that could be strapped to the seat. To use, ta ke the side cover off, connect the ferry tank, bleed the air out of the syst em, then during flight fuel could be pumped into the right tank while runnin g the engine on the left tank (or maybe the right tank, might not matter). W hen the ferry tank is nearly empty, shut off the pump and close the valve. > > One concern is that the extension plumbing would have air in it until it i s used, and air bubbles could conceivably find their way into the main line. The extension line could be filled with fuel too, but that would sit there stagnant for possibly long periods of time (is that an issue?). I had also considered adding a check valve to prevent fuel from flowing from the main t ank side back into the extension plumbing (in case of a leak in the extensio n), but that would be generally uphill so gravity would be on your side ther e. > > Another possibility is to plumb directly to the tank, but the tank is fini shed and I'm not sure I'd like to poke any more holes in it, which would pro bably leave some aluminum bits inside to boot. I can't just plumb into the v ent line since there is no way to let the displaced air out of the tank when pumping in fuel through that line. > > I don't want to start a debate about the RV-10 range etc, just want to hea r thoughts on what's likely to work without adding too much extra complexity and risk. > > Thanks for your thoughts! > > Kent Ogden > #40710 > ________________________________________________________________________________
Date: Mar 04, 2019
August 20, 2018 - March 04, 2019
RV10-Archive.digest.vol-ne
