RV7-Archive.digest.vol-ab
January 05, 2002 - August 26, 2002
> I'm getting close to finishing my empennage and wanted the general opinion of
> you folks further into the project than myself. Is is a good idea to leave
> the blue covering on the skins until painting several years from now or is it
> better to remove it when the part is completed?
> Thank you.
> Russ Clifford
> Lake Forest, CA
> getting ready to start rudder
Subject: | Re: Blue cellophane covering |
Ellis H Mcgaughy writes :
> I took mine off. I'm not polishing my airplane (I will paint) and I didn't
> care to take the risk of corrosion between the plastic and the aluminum
> .... or taking the risk of having great difficulty in removing it (I'm a
> slow builder). I don't know if it is true, but I have read of cases
> (allogations) of corrosion between the plastic and the aluminum.
I'm pulling mine off, for what it's worth. I intend to store the
finished parts by hanging them from the (10 foot tall) ceiling of
the garage, so I hope that'll reduce the chance of "hangar rash".
I have also heard that after time (and I, too, am a slow builder)
the plastic becomes more difficult to take off. The info about
the possibility of corosion is new to me, but I can see how that
sort of problem might occur too. Like Ellis, I am going to paint so
keeping the skins perfectly un-scuffed isn't an issue. Just another
datapoint for your consideration.
-- Dwight
From: | "Steven DiNieri" <capsteve(at)adelphia.net> |
Subject: | Blue cellophane covering |
When I built my 6a I cut the plastic with a flat soldering gun
tip. Just stripe where the rivet lines are. Remember to remove the
plastic before dimpling or you'll end up having to pick a bunch of tiny
smashed plastic circles out of the dimples..
After a two year building process I removed the plastic, (which
was clear and seemed to have a more aggressive adhesive than the blue on
my 7 emp) with little effort. Just take it slow and wipe down with
lantern fluid to remove any adhesive residue after.
The big thing is after working for two years in a heated garage
in New York, I've found mild surface oxidation to the areas that were
exposed to the atmosphere. It was really noticeable when I pulled off
the remaining plastic and was able to make a direct comparison. Needless
to say it cleaned up with scotch bright pads and painted well.
FWIW
Steven DiNieri
Rv6a N221RV
Rv7a ??????
The warning about not dimpling with the plastic in place may not be
necessary, as it's very difficult to de-burr the holes without removing
the plastic from them. Since the flow is drill -> deburr -> dimple,
you'll have to get the plastic out of the way anyway before dimpling...
Of course, that's assuming you were deburring all your holes, right? 8-)
-RB4
Subject: | [ Alex Peterson ] : New Email List Photo Share Available! |
From: | Email List Photo Shares <pictures(at)matronics.com> |
A new Email List Photo Share is available:
Poster: Alex Peterson
Subject: VM11120A Vacuum switch
http://www.matronics.com/photoshare/alexpeterson@usjet.net.01.06.2002/index.html
o EMAIL LIST PHOTO SHARE
Share your files and photos with other List members simply by
emailing the files to:
Please view the typical Share above and include the Description Text
Fields as shown along with your submission of files and photos.
o Main Photo Share Index:
From: | "Wayne Pedersen" <wayne(at)pedersentransport.com> |
Starting that daunting task of looking for a engine for the RV 7. Have a
local guy here who is building 2 planes with corvair engines. He is
offering one to me and with high compression pistons and fuel injections.
The price is right and he claims about 180-hp when the mods are completed.
Any thoughts or experience on these in RV's ??? Searched the archives and
didn't come up with anything
Wayne in Southern Alberta
RV7 empennage
Subject: | Re: corvair engines |
Wayne,
Go to http://home.HiWAAY.net/~langford/ and follow Mark Langford's links
about his Corvair conversion. There has been a wealth of work done on the
Corvair and most is reachable from Mark's site.
Bottom line, if you are looking for 100 - 130 hp. then the Corvair can be
a reliable solution. More than that and you are looking at longevity
issues.
Steve Eberhart
RV-7A - empannage complete (except for one elevator),
reconfiguring jig for wing, N14SE reserved
One test is worth a thousand expert opinions but a thousand opinions are
easier to get. --plagiarized from an unknown author
Subject: | RE: RV7-List Digest: 2 Msgs - 01/07/02 |
Wayne;
You've got to get into the great controversy of the 21st century: The
Eggenfellner Subaru Aircraft Engine. My son & I are convinced that this
is the engine for us (RV-7a & RV-8). Obviously you're open to auto
conversions, so at least take a peek: www.subaruaircraft.com.
-----Original Message-----
[mailto:rv7-list-digest(at)matronics.com]
Subject: RV7-List Digest: 2 Msgs - 01/07/02
________
From: "Wayne Pedersen" <wayne(at)pedersentransport.com>
Subject: RV7-List: corvair engines
a
injections.
completed.
and
RV7 empennage
Subject: | RE:auto conversions |
Ross
This is a very interesting subject / controversy. I have been looking at
the subaru engines as well and like the simplicity of operating and of
course the economics. Concerns are that there are not that many installed
and flying yet as far as I can see and waiting to see how they fair in
the -7. I am interested in your pro and cons that led you to this decision
and of course anybody else's opinions as well.
Wayne in s.alberta
rv-7 rudder
Subject: RV7-List: RE: RV7-List Digest: 2 Msgs - 01/07/02
Wayne;
________
a
injections.
completed.
and
RV7 empennage
Subject: | RE: Auto Conversions |
My Questions / concerns about Auto conversions:
1 What output power are they designed to operate at? probably about
30%
2 At 4000 RPM how long will they last and what will the power to the
prop be?
Its my feeling that most auto engines don't operate at 75% power
continuously very long and if you do operate the this way how can they
be kept cool enough. My experience with auto engines in planes is only
as an observer,I have not owned one myself.
Ray Krone
N210RM soon to be RV 8 Builder
Subject: | Re: RE: Auto Conversions |
> 30%
> prop be?
> Ray Krone
1. Auto engines are designed to operate at anything from idle to full power.
Their design duty cycle i.e. the average percentage of power output they
operate at over their life is probably around 30%. However-- Most engines
are durability tested at full throttle for a minimum of 1000 hours. A typical
Detroit durability test would be full throttle, rpm cycling between peak
torque rpm and peak horsepower rpm (typically 4500 rpm to 6500 rpm) for 1000
hours stopping only for oil changes and any required maintenance. A Japanese
test would likely be even more severe.
2. At 4000 rpm most well designed auto engines would easily go 1500-2500
hours. To know how much power would be available at the prop you need to see
a torque/horsepower graph for the the engine and then multiply that by the
efficiency of your reduction drive. For a rough calculation divide 4000 by
the redline rpm of the engine in question and then use that factor multiplied
by published horsepower to give an approximation of the engine's output
power.
3. Monitor the coolant and oil temps and make sure they aren't excessive.
Shoot for 195 degree coolant and 215 oil maximum temps. Sometimes the water
pump RPM has to be slowed down a little (use a bigger pulley) and don't skimp
on heat exchanger (radiator) size.
Hope this helps.
Scarborough, Ontario, Canada
RV-7 Emp.
Subject: | Dynacam Engine Demo at Flabob |
I bopped up to Flabob today for the Dynacam engine demo and the EAA BBQ.
Great time. Random meaningless pictures here:
http://www.rvproject.com:8000/images/flabob/
A couple RVs (one really beautiful RV-6A, other than that nosewheel), a few
other interesting planes, great folks, lots of chicken.
The Dynacam engine seems like it has possibilities. For those who aren't
familiar with it, it's a 12-cylinder engine. There are 6 pairs of
connected, outwardly opposing pistons. Basically 6 double-sided pistons.
They fire back and forth along the engine's longitudinal axis, which is
aligned with the aircraft's longitudinal axis (or vertical in a heli).
There is a large "cam wheel" centrally located on the drive shaft. This cam
"wobbles" back and forth, so to speak, pushing the piston pairs back and
forth. There are valves on each end of the engine.
Very interesting design. It's supposed to be a bit lighter than a
traditional 4-banger, and apparently it's smooth to boot. They claim 210
hp. Dammit...I left the brochure up there on the picnic table! Duh.
Well, anyway, my opinion (I know, you didn't ask) is that this engine ain't
for me. I'm not comfortable with the forces imparted on the cam wheel.
There are roller bearings all over this engine, and I don't like that. The
engine's redline is 2000 RPM, and cruise power setting is 1700 RPM. What
kind of prop can you swing at that speed? I don't know much about gear
reduction other than the fact that I don't want to mess with it. And I
don't know props well enough either. Somebody needs to tell me what would
be involved in properly thrusting an RV-7 with an engine only turning
1700-2000 RPM.
One more thing...the engine config Dynacam is using has dual carbs (not for
me), although they say there's a fuel injection system that produces
identical power. Hm.
I'd like to see how these engines perform over hundreds of thousands of
collective flight hours. They've got an Arrow flying with one of these
suckers right now. We'll see. Anyway, it was really interesting to see a
different design. Good food for thought.
Who wants to buy my Mooney? http://www.m20j.com:8000 I need to sell it so
I can buy the rest of my RV-7. Argh!
)_( Dan
dan(at)rvproject.com
Subject: | Re: RV7-List Digest: 1 Msgs - 01/13/02 |
In a message dated 1/13/02 11:54:47 PM, rv7-list-digest(at)matronics.com writes:
<< Somebody needs to tell me what would
1700-2000 RPM. >>
Lots of blade surface... Look at some of the big old radial engines, those
are the rpm's they used... Good looking Mooney, Dan. Makes me think one needs
at least two airplanes... :-)
Jerry Cochran
Wilsonville, OR
RV6a waiting for finish kit
Just want to clear up a couple of questions Dan raised below:
____
> From: "Dan Checkoway" <dan(at)rvproject.com>
> Subject: RV7-List: Dynacam Engine Demo at Flabob
> Great time.
few
cam
--Most of the info is on the website: http://www.dynacam.com
or send us your address and we'll send you another one.
--Just wanted to clarify a couple of points here:
--Just to clarify, there are no damaging forces on the cam
wheel. The cam surface where the cam-follower roller-bearings ride is a
special case hardened bearing steel that shows no wear even after 2,000
hours of running. The 2 rollers in each piston, ride on each side of the
cam, making the design a 'roller bearing engine.' All the surfaces are
sprayed with oil continually. The engine had almost zero wear on all
critical surfaces during the FAA certification tests.
The engine's redline is 2000 RPM, and cruise power setting is 1700 RPM.
What
--Turbo props can turn their props any speed they want. They choose
to run turbo props at between 1700 and 2,000 for the most part because props
can be designed to run more efficiently in those RPM ranges. Any prop
designer can design a prop to require 200 HP in order to turn the prop up to
1700 or 2,000 RPM.
--Good point. The Dyna-Cam gives you the benefit of a geared engine
without having to have gears.
for
> identical power.
--The engines that are being produced will be fuel injected like the
engine pictured on our web site. Only the first engine prototype that we
installed in the Piper Arrow that you saw in our video had dual carbs. We
later changed over with the blessing of our FAA rep.
--Thanks for the review and the opportunity to try to clear up a
couple of these points.
Pat Wilks, Dyna-Cam
Pat,
How about that issue? I'm probably visualizing this incorrectly, but it
would seem that while the top cylinder is firing from left to right, the
bottom cylinder is firing from right to left (or front/back, however you
want to put it).
The opposite motion leads me to believe that there's a 2x moment applied on
the outer edges of the cam wheel. That would impart a "twisting force" in
the main shaft. Couple that with gyroscopic precession, and the situation
gets nasty quick.
This cam wheel/shaft design seems prone to stress issues...both the surface
on the cam wheel constantly being pushed on, and the shaft and its bearings
having to resist the twist.
Any word on this? Am I smoking crack?
)_( Dan
Subject: | Re: RV7-List Digest: 3 Msgs - 01/14/02 |
____
> Subject: Re: RV7-List: Re: RV7-List Digest: 1 Msgs - 01/13/02
> Pat,
> want to put it).
on
> gets nasty quick.
surface
bearings
--There are 12 cylinders in the Dyna-Cam and each fires with every
revolution (only 3 pistons fire with each revolution of a conventional
engine). After one end fires, 30 degrees later the piston on the opposite
end and on the other side of the diameter fires. There are always 3 pistons
on the power pulse at any one time. It creates a smooth, harmonious,
continual force, much like an electric motor. After reviewing the operation
for about two hours, I had a man who spent 50 years as the cam expert for
Bullova watches make the claim to me that our piston cam operation was sheer
perfection and could not be improved.
--You can look at the animation on the website of our plastic model
at http://www.dynacam.com/Product/Design_Overview/design_overview.html - it
really illustrates the cam piston actuation.
The plastic models can be mail ordered from our office also.
Thanks again,
Pat Wilks
> What
> 1700 or 2,000 RPM.
I would think you'd need a pretty big prop to do this, and there would be
ground clearance issues in a small plane.
Some automotive air conditioning compressors are configured exactly the same
way - a central swashplate with opposed pistons pushing on it.
This engine has been around a long time. I remember Popular Science
in the 70's doing an article on it. I think there were issues about the bearings
and swashplate wear. Perhaps they've been solved by now. I think
that the side forces on the pistons as well as the "twist" on the swashplate
would be interesting engineering problems.
Another engine question: Is the 180 hp IO-360 Lycoming a slant-valve or a
parallel-valve engine? Someone told me that a 180 IO-360 is the same engine as
the
200 hp IO-360 with lower compression pistons, and I am not sure if this is correct.
Mark Olson
RV-7A, Empennage kit mostly finished - awaiting QB fuselage/wings
Mark,
Just to let you know something I found out this past week on 180hp
IO360's. You need to be careful because some of those engine's have the fuel
injection at the rear of the engine and will not work in an RV unless you buy
a new oil sump and new intake components. I was looking at one and called
van's and they said it would take some work to convert.
Subject: | Re: Dynacam (& Lycoming 360's) |
Mark,
I've been watching the dynacam development for many years, and I hope it
works out for them. One should not compare the engine with the "swashplate"
type of pump found in conditioner pumps, or 747/777 etc.. hydraulic pumps.
The dynacam does note use a flat "swashplate" type of rotor at all, in fact
it's kind of wavy. From an engineering standpoint this puts little
"twisting" force on the shaft. Also in the dynacam the pistons work on both
sides of the rotor, not one. Anyway, I don't have much of an opinion either
way, I just pay attention to facts, not rampant opinions or pure
speculation. As far as a prop, it would be very easy for a company to
optimize a wide cord constant speed prop for those things, since that's
typically the range of RPM used by Turboprops.
Regarding your (I)O-360 question, the typical 180 h.p. Lycoming is NOT the
same engine as the 200 h.p. engine. There are a very few derated 200 h.p.
engines around, but most 180 h.p. ones like My AEIO-360-B4A have parallel
valve heads, and is similar to others. The 200 h.p. IO-360 has a totally
different head on it, with Angled Valves. This engine is a couple of inches
wider, which is why it won't fit under the RV4 or RV6 cowling without
modification (but a few have shoehorned them in). The easiest way to
identify the difference between the engines by appearance is the valve
covers.
The parallel valve 180 h.p. 360's have the same large deep valve covers as
the 290's and 320's.
The agle valve 200 h.p. 360's have very shallow valve covers (space
conservation) that look similar to the IO-540's.
Hope this helps out!
Stein Bruch
RV6, Minneapolis
Finishing
bearings
as the
correct.
Mark Olson
Subject: | O-360's (was dynacam). |
Sorry, but this is just not correct at all.
To my knowledge (limited and I can be wrong) there were very few 180h.p.
IO-360's with the fuel servo mounted in the rear. There were however many
carburated O-360's with horizontal mounted carbs (cherokees) made, these are
the A1C, & A1G series of O-360's and a few others.
The are some helicopter IO-360's with the fuel servo in the back and are
probably VIO's (Helicopter) and/or some HIO's (helicopter). Lycoming has
made hundreds of variants, but for the most part the MAJORITY of Injected
360's have the fuel servo in the same lower sump spot as the 320's do.
Many of the 200 h.p. IO-360's DO have the fuel servo mounted horizontally in
some applications.
Please don't flame me on this, I just wanted people to know that the
majority of 180 h.p. IO-360's have the servo in the same location as the
carurated 180h.p. 360's. These are still being produced new and are being
installed on several new production aircraft. I know there is almost one of
every type of configuration you can think of and Lycoming made an effort to
confuse us all with the hundreds of variants.
For everyone's enjoyment, I've scanned the Lycoming engine spec sheets onto
my website and they'll be available later tonight or tomorrow for viewing
under the engine section.
FYI,I have a 180 h.p. AEIO-360-B4A and my servo is mounted in the standard
position and looks just like a regular 0-360 as do MANY of the IO-360's.
Stein Bruch, A&P
RV6, Minneapolis, Finishing.
[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Slgmjg1(at)cs.com
Subject: Re: RV7-List: Re: Dynacam
Mark,
fuel
buy
Stein, I appreciate the info you sent regarding parallel vs. slant valve engines.
Also, I'll make sure if I decide to go with the 180 HP IO360 that the fuel servo
is not at the rear of the engine...
I noticed Aerosportpower offers these engines, and for an extra $100
they can install 9.2-1 compression ratio pistons. What effect does this
have on the horsepower output, and - more importantly - what octane
fuel is now required? I would imagine that the engine will not run on
anything less than 100LL.
Thanks again!
Mark Olson
> Mark,
> fuel
> buy
Subject: | Re: RV7-List Digest: 5 Msgs - 01/15/02 |
____
> From: Mark Olson <MOLSON1(at)MN.RR.COM>
> Subject: RV7-List: Re: Dynacam
> > What
choose
props
up to
> > 1700 or 2,000 RPM.
--Because of the slow RPM additional blades can be added without
significant loss of efficiency. Also blades can be designed that have a
higher forward pitch. Most props for a 200 HP engine have a forward pitch of
about 60" - 80". The Dyna-Cam is able to bring a prop up to speed that has
a 200" forward pitch. As I understand, the forward pitch is influenced by
the twist, camber, cord and other characteristics of the blade. So a 3 - 4
bladed prop with a 68" diameter can be matched to the Dyna-Cam. We are
currently interviewing prop designers to get one built. MT Propellers in
Germany is also offering an electric pitch prop that will work with the
Dyna-Cam.
bearings
swashplate
--Those issues were solved before the engine was certified. Since
the pistons are supported on each end by the cylinder walls, the forces do
not cause any problems within the 2,000 hour TBO.
Pat Wilks
Hi
I'm working on my second fuel tank. I found a better way of fitting those Z
brackets on. The directions tell you to drill 1/8 in. hole etc. place nut
plates on. The trouble is that the spar side holes in relationship to the
tank baffle are not center of one other. I find that it is better to fit the
tank side first. (It's easier later to pop those rivets on). The way that I
did that is to place the skin on spar with baffle in place. One hole in each
z bracket. Clecoed them on to the baffle. Then I marked them on the bottom
of the z brackets (spar side) checked them. They will be off center to the
inside but you can get the nut plates on. Place back on and drill all the
holes out.
Scott Trask IMT
P.S.
If you like the idea and you use it let me know(If you can understand it).
From: | "Francis, David" <David.Francis(at)defence.gov.au> |
Russ,
Scratches are a risk to airworthiness, hence it is best to leave the plastic
on till late. My practice is to drill with both plastic on, remove inside
plastic, dimple, alodine, using a hot soldering iron, remove a 3/4 inch wide
strip along rivet lines, then rivet.
Regards, David Francis, Canberra, Australia, wings 60%
From: RJCLIFF77(at)aol.com [mailto:RJCLIFF77(at)aol.com]
Subject: RV7-List: Blue cellophane covering
it
Thank you.
Russ Clifford
Lake Forest, CA
Subject: | stiffeners adhesive |
Wayne,
On the recommendation of my local maintenance shop I use a marine product
(avaliable form yaghting shops) called Durolac. Its a yellow anti-corrosive
cream in a tube. Proseal is too hard to mix and keep the place clean, RTV
would do but is almost as gooey as proseal.
Durolac is anti-corrosive and also cushions the rivet from its hole,
reducing the tendency to produce smoking rivets in later life. I use it on
all external rivets.
Regards, David Francis, Canberra, Australia, wings 60%.
From: Wayne Pedersen [mailto:wayne(at)pedersentransport.com]
Subject: RV7-List: stiffeners adhesive
getting ready to install the stiffeners in the rudder. It has been
recommended by a few to use adhesive i.e.. proseal or RTV sealant to help
reduce loosening due to vibrations. What's the consensus - waste of time and
$$ or a must do ?
Wayne
RV7a empennage in Southern Alberta
Wayne, before you take the risk of using an automotive engine in a plane
have a look at the 6 litre 200hp engine being developed by Jabiru aircraft.
They have over 1000 of their 80 and 120hp engines flying world wide. See
www.jabiru.net.au
The weight saving and price are much better than the Lycoming alternative.
RV7 empennage
From: | "Camille Hawthorne" <camillehawthorne(at)hotmail.com> |
Subject: | Re: Tank Z brackets |
This sounds like a much better way to deal with the brackets. I wish I hadn't drilled
all the holes for both tanks at the same time! My holes were slightly off
when I had the baffle lined up, but the directions say to enlarge the hole
in the baffle if this happens. Well, after staring at the prints and directions
for quite awhile (I do that a lot!) I came to the conclusion that if the hole
in the baffle is enlarged, so must be the hole in the rib! NO BUENO! Wouldn't
that be tough to seal? Isn't the fuel supposed to stay on the inside of the
tank? I think the plans should say to enlarge the hole on the Z brackets, not
the baffle. Anyone else agree?
Camille
holes out.
From: "Francis, David" <David.Francis(at)defence.gov.au>
Subject: SEC: UNCLASSIFIED RE: RV7-List: corvair engines
Thanks David for heads up on the Jab. Looked at the site and looking
forward to RV6 testing
Wayne RV 7a in Southern Alberta
Empenage -rudder
www.jabiru.net.au
RV7 empennage
Subject: | re:proseal stiffeners |
Subject: SEC: UNCLASSIFIED RE: RV7-List: stiffeners adhesive
Wayne,
Thanks David for info. Unfortunatly I had allready purchased the proseal
and used it on the stiffners. Its been two weeks and the "table' that I
used to mix it on is still not as dry as I thought it should be. I have
been keeping the garage heated to 15 C but will give it some more time. The
Duralac product sounds like it would have worked much "cleaner"
Wayne RV 7 a in Southern ALberta
Emenage - Rudder
$$ or a must do ?
Wayne
on 1/21/02 4:32 AM, Camille Hawthorne at camillehawthorne(at)hotmail.com wrote:
> hadn't drilled all the holes for both tanks at the same time! My holes were
> slightly off when I had the baffle lined up, but the directions say to enlarge
> the hole in the baffle if this happens. Well, after staring at the prints and
> directions for quite awhile (I do that a lot!) I came to the conclusion that
> if the hole in the baffle is enlarged, so must be the hole in the rib! NO
> BUENO! Wouldn't that be tough to seal? Isn't the fuel supposed to stay on the
> inside of the tank? I think the plans should say to enlarge the hole on the Z
> brackets, not the baffle. Anyone else agree?
Camille
Hi Camille and List
The first tank I ended up making a few extra holes because of the those Z
brackets but no leaks. I did have a leak around a rivet that holds the clip
for the flange of the gas cap. The other tank I placed the clip on just on
the gas cap flange independent from the skin. The rivet head would be under
the skin.
Camille, you should be ok with that pro-seal. It works nice. In some
places I place it inside and out. If you didn't place the rivets in yet I
would push a little pro-seal in the hole in front of the rivet.
Scott Trask IMT
Subject: | Tank access plate screws |
I had an EAA Tech Counselor inspection done this weekend by Gary Sobek. One thing
he recommended was not using Van's phillips head screws in the fuel tank access
cover, but rather getting some Allen head (ie., hex key) 8-32 half inch machine
screws for that cover. Reason is that after you have mounted the wings, there
is
only about 3 inches of space to get a tool in there to remove those screws, and
ProSealed phillips head screws will likely strip out when you try to turn them
from
the side without much leverage. I swapped out the screws this evening with Allen
head screws generously dabbed with ProSeal. Looks like it will work well, as a
standard Allen wrench with a 90 degree bend will get a good bite on those screw
heads.
He also recommended not using Van's cork gasket and just Prosealing the cover on.
I
was just about to close up the right tank so I went ahead and did this, putting
a
generous coating on both cover plate and the rib surface that holds the platenuts.
(Scuff with emery cloth and MEK clean to get a good bonding with ProSeal.) Since
the left tank already had the cork gasket ProSealed in, I just changed the screws
on
that one. Now I have a comparison setup; will let the list know which one leaks
first :-(. Or maybe never :-).
Something to consider...
-Dan Masys
-7A wings
Hi
What are you guys doing for a back ground(color of paint if any) in the
wing behind the landing light? I was thinking of using chrome paint it
should brighten the light a little.
Scott Trask IMT
Subject: | Re: Landing Lights |
Scott Trask wrote:
> Hi
> Scott Trask IMT
I used Rustoleum white appliance epoxy to paint the landing light bracket and
the forward inside parts of the wing bay. Makes a great high gloss white
finish (but don't put it on over primer; it will 'pull' most primers and
wrinkle). If you compare luminence I think white beats chrome paint, unless
you can achieve a mirror finish (and then it is not clear that the mirrors
will be sending the reflected light where you want it to go).
-Dan Masys
-7A wings (done except for autopilot servo wiring and bottom skins)
I am in the middle of the tank sealing experience
I thought I would offer some items that might help
someone not there yet
as suggested in the instructions, three work sessions
I didn't have that must time for each
I have made 3 sessions thus far and have about half of
it complete
It took me about 3 hrs to install the stiffeners and
filler and drain hole
Session # 2 was the two end ribs with nose stiffeners
and corner stiffeners and inverted flop tube
Session # 3 I thought would get all the interior ribs
but I was mistaken. I got in two in about 2.5 hours.
I am thinking 5 work sessions will get it done.
Seems that about 1.5 or 2 ounces is enough proseal to
mix at one time
I had a set of digital postal scales. That works
pretty good.
I used one batch for each of the two ribs tonight.
A little MEK stirred into the putty makes it more
manageable. I used the popsickle stick and a acid
brush with the bristles cut to half of their length to
push the goo into the right places
I had countersunk the skin rather than dimple. Seems
that I couldn't get the dimples deep enough on the
vert stab which is also .032 sheet.
it is still difficult to get the depression deep
enough. I believe the proseal holds the rivs out a
little. I now think the TANK dies from the tool man
is the correct choice. TANK dies are several
thousandths deeper.
I believe the dimples would help locate the ribs to
the skin a little better when you have got every thing
buttered with goo
This may be worth what it cost you, but these are my
experiences so far.
cary rhodes, middle of wings and fuse just arrived
Just be aware that if you put the end ribs in before the inner ribs, you're
going to have an interesting time running the tank vent line. Better to
either start with the outboard end and work towards the inner rib, or just do
the inner ribs and save the most inboard and outboard ones for later, after
the tank vent is installed. Even more important if you have the capacitance
fuel senders, since you're going to have to do some wiring and screw + spacer
assembly on the 2nd rib in from both directions.
-Dan Masys
-7A wings
on 1/25/02 9:01 PM, Dan Masys at dmasys(at)home.com wrote:
> Scott Trask wrote:
>> Hi
>> Scott Trask IMT
> -Dan Masys
Hi Dan
Thanks for the responds, I would have to agree. I was thinking white but a
good young salesman sole me the chrome paint.
Scott Trask IMT
From: | John Reuterskiold <mtnflyr(at)attglobal.net> |
Since I have gotten tired of trying to figure out which bag a particular
part is in I have created a MS Access database of the bags and the parts
within them. If any of you have Access and would be interested I will
be glad to share. It will currently produce 3 reports, 1)the bag number
and Van's short description, 2)list of bags in ascending order and the
parts in them (very similar to what Van's sends except in numerical
order, 3)parts in ascending part number order and the bag it is in.
And to answer the question, yes I have excess time on my hands while on
the road (it is just to hard to take the wings with you).
John Reuterskiold
QB wings and fuselage
Subject: | Re: Bag parts list |
Yup, there is a lot of interest here in ANY kind of inventory system.
Thanks. My email address is siinc(at)gwi.net
May I suggest that you upload your Access db file to the photos/files
section (http://www.matronics.com/photoshare) so that anyone who is
interested can download the files for themselves?
Again, Thanks.
Don Stewart
> John Reuterskiold
Subject: | RV Finder (web tool) |
Ok, it was only a matter of time before I broke down and built this:
http://www.rvproject.com:8000/rvfinder.jsp
Enter your zip code, select a radius, and you can find all the registered
RVs of various types that are located nearby.
Enjoy!
)_( Dan
SoCAL-RVlist(at)yahoogroups.com
Subject: | RE: RV-List: RV Finder (web tool) |
Hi Dan,
So when's the international version coming out? Ya never know some of you yanks
might want to come done and visit some of us Aussies on day!!
Looks cool!
rv7-list(at)matronics.com; SoCAL-RVlist(at)yahoogroups.com
Subject: RV-List: RV Finder (web tool)
--> RV-List message posted by: "Dan Checkoway"
Enjoy!
)_( Dan
Subject: | Re: RV Finder (web tool) |
> what about those of us who registered our planes with a space in between
the
> V and the number... like "RV 6". Will you recognize those as well as the
> ones registered with no space or a dash?
A lot of people have been asking about different patterns of model numbers.
If there are any uber-geeks out there (I'm not pointing fingers) who might
want to help enhance this tools ability to recognize RV model number
patterns, here's the regular expression I'm using:
.*RV[-[:space:]]?[[:digit:]]+(A)?.*
It now supports missing dashes, using a space instead of a dash, etc. If
anybody has suggestions on how to improve that, just let me know.
)_( Dan
From: | "Stephen Reynolds" <stephen.j.reynolds(at)talk21.com> |
Subject: | Re: RE: RV-List: RV Finder (web tool) |
the French RV site has a map of France with all the builders located on it.
pretty useful
http://www.welcome.to/RV-6
----- Original Message -----
Subject: RV7-List: RE: RV-List: RV Finder (web tool)
> Hi Dan,
yanks might want to come done and visit some of us Aussies on day!!
> Looks cool!
> John
> From: Dan Checkoway [mailto:dan(at)rvproject.com]
> To: rv-list(at)matronics.com; RV7and7A(at)yahoogroups.com;
> Enjoy!
> )_( Dan
Subject: | More speed, more features |
Unfortunately I'm not talking about an RV...
But I am talking about the RV finder web tool. I made some major speed
enhancements and it now supports "over the border" queries. Basically
you're no longer tied to just the state you entered. It'll pull in RVs from
any state, sorted by distance.
So, for example, if you do a query for "Reno, NV", you get lots of nearby
California RVs as well.
Still not international, but one thing at a time.
)_( Dan
From: | "Doug Preston" <dprestonsr1(at)charter.net> |
Any body know of a 6, 7 or 8 with 540 engine?
Appreciate any info on such a critter.
Doug Preston
RV-6A - N1610P bought used & flying
RV-7A starting fuselage.
Subject: | Re: e: RV7-List: |
try Van's....also I heard that there is a couple in eugene, or, one is
flying..the other is building...of course there's the rocket...but it's
beefed up just to take the stress...
> Thanks,
> Doug Preston
Hi John,
I do have MS Access and would really like to see the inventory list you
put together.
Vern
Houston, TX
From: "John Reuterskiold" <mtnflyr(at)attglobal.net>
Subject: RV7-List: Bag parts list
> John Reuterskiold
rv8-list(at)matronics.com, rv7-list(at)matronics.com, rv9-list(at)matronics.com,
homebuilt-list(at)matronics.com, tailwind-list(at)matronics.com,
yak-list(at)matronics.com
Subject: | RV-4 Project For Sale... |
Listers,
I've decided I want an RV-7 and am selling my RV-4 Airframe Project. Below
are two URLs with tons of pictures of the project. Please note that *only*
the items listed specifically below are being sold. The avionics, engine,
prop, etc. shown in the pictures will be kept for my next project.
http://www.matronics.com/mattsrv4/
http://www.matronics.com/mattsrv4/MiscPictures/
I would prefer not split this stuff up and will sell it as a package deal
only. Wings and tanks are 95% done and are wired for Whelen Strobes and
position lights. Fin, Rudder, Horz Stab are complete. Elevators are 50%
complete. Fuselage is about 80% complete with canopy completely
installed. Fuselage is on the gear, but little work FWF has been
done. The cutout in the FW for the prop governor has been started.
Workmanship is good throughout the kit.
Here is a list of the items included in the sale:
Van's RV-4 Kit (Emp/Wing/Fuse/Finish)
Vetterman Exhaust (Crossover)
Engine Baffle Kit
Filtered Air Box
2 Lever Quadrants
F&R Seat Belts
Molded Stick Grips
Electric Elevator Trim Kit
Electric Aileron Trim Kit
Electric Flap Kit
Fuel Tank Flop Tubes L&R
Fuel Selector Valve
Rear Seat Rudder Pedals
Full Swivel Tailwheel Assy
Heat Selector
Bob Olds Landing Lights L&R
Tires & Tubes
Tailwheel Fairing
Fiberglass Gear Fairings
Temperfoam Front and Rear Seats w/ Upholstery
New Light Weight Prepreg Cowling for CS O360
This list of items represents an investment of over $17,000. I will sell
the whole thing for $11,000 firm. I can accept M/C or Visa for an
additional 4% of the sale amount.
I will crate the entire kit as listed above for shipment anywhere in the
continental US for an additional $600. Freight charges will be COD via the
carrier of your choice.
For further information, please contact me via email at dralle(at)matronics.com
Subject: | AKZO primer shelf life? |
I'm not asking what primer to use. 8
But I would like some advice on the shelf life of primers...specifically the
AKZO 2-part epoxy primer. Bought it in August of 2001. Used it nearly
every day until October. Then, after the emp was finished it's been sitting
on my shelf since then. About to order my wings (finally!) and I'm
wondering:
Will AKZO be usable after 4-6 months of sitting idle on a shelf? I assume
that's no problem as long as I thoroughly shake/stir (shaken, not
stirred...) up the main part before mixing?
)_( Dan
N747DC RV-7 wings soon
N201DD Mooney 201 (FINALLY SOLD!)
Subject: | Belated List of Contributors #2... |
Dear Listers,
I'd like to apologize for the delay in posting the 2001 List of
Contributors Number 2, as well as getting behind in the List Photo
Shares. Here's my sad story... Over the Christmas holidays, I was working
out in the shop on a rotating drum sander. I was sanding out the woofer
hole in a speaker enclosure and, long story short, the part got away from
me and started spinning like a Hula hoop on the drum. Rather than just
turning the machine off like I should have done, I tried to grab the part
and in the process badly broke the ring fingers on *both* my right and left
hands!! I had to go in for surgery on the left hand because of the joint
damage and was stuck in a thing called an "external fixator" for almost 4
weeks. The right hand has healed up well, but the left one is very stiff
and I'm currently only getting about 70 degrees of bend. The doctor says
that I will get 80-90% of the moment back with a great deal of therapy and
I'm going to hold them to that...
The moral of the story is that even a sander can be a dangerous tool. I
had been working with a table saw, drill press, scroll saw, and high power
routers all day long and afforded them all the respect they deserved. But
with the sander, I never even thought about how things could go bad. It
just didn't seem like a dangerous tool. Be careful out there in the
shop. In a moment you can hurt yourself; hurt yourself in such a way that
you will have to live with the damage the rest of your life. Nothing is
worth that.
I'm finally back working on the computer and getting back to email and
other stuff. Later today I will be processing the mound of Photo Shares
that have backed up while I was out. I also just finished up the 2001 List
Contributions and have included the List Number 2 below.
I want to thank everyone that has so generously contributed to the List
this past year! It is your Contributions that make these Lists possible.
I understand that the Van's Videos from the Builder's Bookstore should be
shipping very soon if not already, and the discount coupons from Brown
Tools should already have arrived. Thanks again to Andy Gold and Michael
Brown for their generous support of the Lists this year with these giveaways!
Oh, and now that my fingers are working pretty well again, I've decided to
go ahead and finish my RV-4!! I had a LOT of guilt over wanting to sell
it... :-)
Happy Building and Flying!
Email List Administrator
Alexander, Don
Alexander, George
Andrews, Jim
Anonymous
Blake, James
Bowman, John
Buryl, Hill
Butler, Sherman
Cantrell, Jimmy
DeRuiter, Marcel
Deffner, David
Graumlich, Tom
Griffin, Randy
Harbour, Keith
Hunt, Robin
Jannon, Terence
Johnson, Jackie
Kahn, Steve
Labhart, Norm
Laird, David
Larson, Joe
Licking, Larry
Maynard, Brad
Navratil, Richard
Noonan, Thomas
Petersen, Paul
Reed, Gary
Rogers, Ken
Salter, Phillip
Schmit, John
Schultz, David
Sheffield, Ray
Smith, Edmond
Staley, Dick
Utterback, Tom
Uvanni, Bruce
Williams, Henry
Wilson, Robert
Woodward, Don
Worthington, Victor
Zirges, Malcom
Subject: | [ Bob Haan ] : New Email List Photo Share Available! |
Poster: Bob Haan
Subject: New WigWag II
http://www.matronics.com/photoshare/bhaan@easystreet.com.02.17.2002/index.html
Subject: | [ John Reuterskiold ] : New Email List Photo Share Available! |
Poster: John Reuterskiold
Subject: RV7 Bag-Parts Database
http://www.matronics.com/photoshare/mtnflyr@attglobal.net.02.17.2002/index.html
Subject: | [ JT Garner ] : New Email List Photo Share Available! |
Poster: JT Garner
Subject: Landing Light Hole
http://www.matronics.com/photoshare/jtgarner@shentel.net.02.17.2002/index.html
Subject: | The engine debate |
This is for people who:
1) want to reopen the auto vs Lycoming engine debate, or
2) have a bit of a sense of humor:
This weekend on Car-Talk (you know, the National Public Radio program) The
guys take a phone call from me regarding the subaru engine in a home built
aircraft. Needless to say, they had a lot of fun with the topic, and were NO
help at all! For some reason, they seemed to be of the impression that those
who build aircraft in their garages are less than normal. Listen in. We
recorded the segment on Wednesday, and they don't guarantee it'll get on
(they "mix and match" the calls to get the best mix of humor and time limit
potential) but they are already asking me for pix to post on their web site.
Ed Winne
RV 9A
Palmyra PA
wings/QB fuse
Subject: | autoengine debate |
I'm interested in exploring the benefits and drawbacks of a Mazda RX7 engine
in an RV7a. The EAA article this month seemed to indicate that this was a
reasonable alternative. Since I am not really interested in a truly
"experimental" engine, I would be interested to know the costs and issues
involved in purchasing a firewall forward Wankel kit. What kind of prop and
speed reducer would the RV7a need? Or is one of the new diesels a better
choice?
Mike Okrent
Empennage 90%, getting ready to order the wings
Hi
I'm about done with my wings! I found an easy way to test for leaks. I
started with a low pressure gauge and placed about 1 1/2 lbs. in tank. Let
it stand for a day and check the pressure gauge and spray soap on it if you
need to locate a leak. I found that you can easily push that much pressure
in with your lungs. So, one can place two rubber or plastic hoses over the
two fittings, pinch them off after blowing in tank. Then spray down with
soap and water. I had a leak in the electrical fitting in the center. I
never would had guessed that there would be a leak there. I had accidentally
sprayed soap in it and bubbles quickly appeared. I had placed heat shrink
over the wire to the fitting. I didn't put enough pro seal up the top edge
of the heat shrink around the wire. It was easily repaired.
Also I found something that works well around the cork gasket other than pro
seal. It's called Aviation Form-A-Gasket Sealant Liquid (Item# 80019).
This is a gas resistant substance made by Permatex. I placed it on the tank
side (between the cork and the tank). I did not put any between the lid and
the cork. I didn't have any leaks in that area. Do you think I should place
it on both sides?
Scott Trask IMT
Subject: | autopilot questions |
I've got a few questions for people who have installed autopilots in their
RVs (I searched the archives and didn't quite find what I was looking for):
1) How much weight does your typical autopilot add? Assume both pitch and
roll.
2) How level does the autopilot really hold an RV...does it hunt like crazy
(too sensitive)?
3) If a builder decided to install an autopilot after the aircraft was
already complete (a complete RV...that's an oxymoron) and flying, how
trivial or impossible would that be?
You can probably see what I'm getting at... (a) I don't want to weigh my RV
down, (b) I don't want to bother unless it'll hold it rock steady, and (c)
I'd rather wait to see what my empty weight turns out to be. I'll take any
and all data points...
)_( Dan
From: "brian_meier" <brian.c.meier(at)accenture.com>
Subject: [RV7and7A] S-Tec Autopilot Roll Servo Mounting Pictures
> Group,
> I have loaded some pictures of my planned mounting for the S-Tec
> Autopilot Roll Servo in my wing. I purchased the following from A/C
> Spruce: S-Tec System 30 Autopilot for about $5500
> (1)Roll Servo 0106-9-R4
> (1)Pitch Servo 0108-10-P5
> (1)Hardware Kit about $600
> The Hardware Kit is not normally quoted, that's why the price is
> about $600 higher than what I thought. But when I finish
> installation and purchase the Turn Coordn, Programmer & Transducer
> and give S-Tec the lenght of wire runs I need, they will custom fab a
> wiring harness.
> Look at the installation pictures under the FILES...then N975BM
> Folder...then S-Tec Autopilot Installation Folder.
> Let me know what you guys think. I'm trying to mount the servo to
> the spar in the outermost bay. There are 2 lightning holes in the
> spar. The hole on the inboard side is the perfect size to fit the
> back side of the servo. Using one of the brackets supplied, I
> clamped it in position to test it out. I also used a dowel rod to
> simulate a pushrod. I need to make sure that attaching the dowel rod
> to the aileron bracket where the control push tube attaches is OK.
> So far it looks as if I can still get full deflection of the aileron
> with the dowel rod connected to the roll servo.
> Good luck and keep building.
> Brian Meier
> N975BM (reserved)
> Access Your PC from Anywhere
> It's Easy. It's Fun. - Free Download.
> http://us.click.yahoo.com/kmECdA/7XkDAA/DIxGAA/1yWplB/TM
> Van's Air Force - World Wide Wing
> www.vansaircraft.net
From: | "Konrad Werner" <Connywerner(at)wans.net> |
Subject: | RV-4 Project FOR SALE |
My fellow RVators,
RV-4 Tail & Wing Kits FOR SALE
Early 1980's Kit, Serial number is in the two digits. A VIRGIN (i.e.
nearly untouched).
Today's cost from Vans would be over $5400 for the same Kit (-with
predrilled parts).
This is a great opportunity to get started on a Van's RV-4, while at the
same time saving some serious (engine) money over buying new!
Please contact me OFF LIST if you are interested, and then make me a
reasonable offer for the two Kits!
Sincerely,
Konrad Werner
Albuquerque, NM.
I have finished my second tank and unlike the first
this one leaks
I must have been too skimpy with the black pudding
trying to make the quart of goo enough for both tanks
The 3 leaks I have are around the rivit heads in the
middle portion of the tank
ie - not on the baffle plate - the easy ones to get to
to replace
Has anyone had experience with the slosh sealer??
Does anyone have alternate repair advice
I am afraid if I pull the baffle off of the back it
will totally wreck the tank
Cary Rhodes
75% wings
Fuse in waiting
http://sports.yahoo.com/
> this one leaks
> to replace
> Cary Rhodes
> 75% wings
> Fuse in waiting
Hi Cary,
My best suggestion to you is contact Van's. They are very helpful in cases
like this. Maybe you could place pro-seal on the outside and put a shop vac
over the filling cap, creating a vacuum. Leave it on long enough and it
will suck the pro-seal or whatever you are using into the leaking area. Let
is set up.
Or drill out the leaking rivets and replace with blind rivets, adding more
of whatever you are using on the blind rivets to seal.
That's all I have to offer. Hope it works for you.
Scott Trask
IMT
From: | "Norman Younie" <rv6capt(at)pacificcoast.net> |
cut a round hole in the baffle in the section that leaks
repair the leak
make a round plate to cover the new inspection hole
seal and rivet it on
Subject: | RV7-List Digest: 4 Msgs - 03/18/02 |
Dan'
Why dont you shop around at the banks you will probably get a better deal
anyway, that is certainly the case in UK. You've got to get that kit I am
following you website, I would be lost without you mate!
Subject: | Ban for Life!!!! |
March 19, 2002
Hello:
Im building an RV-7A QB in Maine. I succeeded in getting myself ban for life from
Doug Reeves Vansaircraft.NET builders chat group for chatting too much & off
the topic postings. Whatever happened to freedom of speech? Not only am I ban
for life from posting but I cannot even read the archives as non-members are
able to do on this matronics site. Then the bulk of the members on the site voted
in a poll for a 30-60 day ban for members who needed to be disciplined and
yet I get ban for life whats up with that? I even offered to pay a fine of
$100 as a donation to the site and got rejected by the moderator. None of the
members dare speak out since they too might get ban. I disagree totally with a
life ban thats absolutely ridiculous!! I will be the first to admit that Im
far from perfect and a few 30-day bans now and then would have been most sufficient.
Anyway Im building an RV-7A QB my engine showed up today Im using an O-360 180
HP with a 200 HP forward facing sump and Lycon.com induction tubes which will
allow me to use the sleek vans cowl which does not have the lower air scoop.
My engine is also fuel injected.
The unknown at this point is how the exhaust will work out. Any comments would
be greatly appreciated. Vetterman said the heating system may be an issue. Here
in Maine I want HOT HEAT in the winter. Im working with an exhaust guy in
CA who says he sees no problems with building a 4-into-1 exhaust for my RV. I
really want the 4-into-1 since Im told it will boost the HP as much as 20 HP
does anyone know if this is true??
Ive also gone with an engine mount which is a combo 7 & 7A mount this will allow
me to put this RV on floats at a later date. Im discovering the battery box
for the RV-7A will not fit so I think I may have to use the battery box normally
used on the RV-7.
If any of you are planning to put your RV on floats, Id love to have your e-mail address and keep in touch - my e-mail is cdowjr(at)yahoo.com. As far as floats are concerned www.full-lotus.com seems to have a nice set floats run about $6,500 for the RV-7.
Well anyway I hope you all will be more patient with me than the other group. I
think there is some good in every RV owner/builder - sometimes it just takes
some time to find it and that other group just kicked out a nice guy a Maine
RV-7A QB Builder for LIFE Whats up with that!!! Control freek!! - I truly
don't get it!!
Have a great day.
Cliff Dow, Jr.
Cdowjr(at)yahoo.com
Maine RV-7A QB Builder (N-327CD)
Subject: | Carbon Monoxide Detectors |
I just got the new panel mount model 352 carbon monoxide detector from www.coguardian.com
Nice unit! Its pretty compact. Just recently available.
Cliff Dow, Jr.
Cdowjr(at)yahoo.com
Maine RV-7A QB Builder.
Subject: | Exhaust (was Ban for Life!!!!) |
Hi Cliff,
I've yet to see any simple "bolt on" item that will increase ouptup by 20
h.p. I'd be leery of somebody claiming that much. You COULD get a slight
performance increase from a 4-1 exhaust, but exhaust systems are funny, and
more of an art than a science. I would also shy away from anyone who has
not built a bunch of exhaust systems for an RV. If you check the archives
there are a multitude of stories about people "re-inventing the wheel" when
it comes to exhaust.
That being said, I've seen several exhaust systems on RV's, and can
unequivocally say the Larry Vetterman's are probably the best quality, and
fit like a glove out of the box. He has literally build hundreds of sets,
and the workmanship is outstanding.
IMHO, The best way to get increased horsepower out of these things is
definately electronic ignition, and the best way to go fast is a clean,
light airframe. That 20 extra horse will get you less speed than a nice,
clean plane!
Stein Bruch
RV6, Minneapolis
March 19, 2002
Hello:
would be greatly appreciated. Vetterman said the heating system may be an
issue. Here in Maine I want HOT HEAT in the winter. Im working with an
exhaust guy in CA who says he sees no problems with building a 4-into-1
exhaust for my RV. I really want the 4-into-1 since Im told it will boost
the HP as much as 20 HP does anyone know if this is true??
Have a great day.
Cliff Dow, Jr.
Cdowjr(at)yahoo.com
Hello Everybody;
I am a new RV-7A builder who has just started the empennage kit. I wanted
to say "Hi" to everybody out there. I hope you all don't mind if I lurk
around and try to pick up building hints or ask a question or two when I am
puzzled during construction. I figure there is a great wealth of knowledge
on this list and Im sure I could benefit from those of you who have
completed construction or are further along in the building process.
I live in Woodbridge, VA and I work for the FAA (GASP!!) as a program
manager in Airways Facilities. I currently fly a Tri-Pacer and decided to
build an RV because I wanted something that cruises faster (much) than
100mph. I also ride a Kawasaki Vulcan Classic (Harley clone), and have an
old Jaguar convertible that I am just completing a restoration on.
Anyway, a big "hello" to all of you -- now back to the shop for another
building session....
Skip Bona
vapilot1(at)hotmail.com
Send and receive Hotmail on your mobile device: http://mobile.msn.com
Subject: | Need any drill Bits??? |
Here is a site for any drill bits you might need - I just ordered some 2 1/4 &
3 1/8th for my instrument panel - carbide tip (grit style) bits - supposed to
work nice - no walking around like some regular holesaws - and they fit regular
Makita arbors.
Also, on my QB wings I needed to run holes under the skins for wires - needed a
4 foot drill bit and found the ones at the local electrical shop worked fine
- even thought they were for wood (about $35).
http://www.advantage-drillbits.com/drilltype.html
Cliff Dow, Jr.
cdowjr(at)yahoo.com
Maine RV-7A QB Builder (N327CD)
Subject: | Welcome Cliff.... if.... |
Dear Cliff...
You should realize that lots of RV builders like myself are members of more
than one list, so are fully aware of the problems that got you bounced from
Doug's list. If I remember correctly, you were only bounced after multiple
warnings, so have only yourself to blame. I think you have a lot to
contribute to this list and your enthusiasm for RV's is unquestioned. And as
long as you stay on subject, which is the furtherance of the enjoyment we all
share with our projects, I have little doubt you will be welcomed by all.
Let's avoid the subjects that offended many on Doug's list. Hope you take
this in the constructive spirit it was meant, and best to you.
Sincerely,
Jerry Cochran
Wilsonville, OR
RV6a 50% done, 90% to go....
In a message dated 3/19/02 11:54:38 PM, rv7-list-digest(at)matronics.com writes:
<< Im building an RV-7A QB in Maine. I succeeded in getting myself ban for
life from Doug Reeves Vansaircraft.NET builders chat group for chatting too
much & off the topic postings. Whatever happened to freedom of speech? Not
only am I ban for life from posting but I cannot even read the archives as
non-members are able to do on this matronics site. >>
Subject: | Re: Welcome Cliff.... if.... |
Don't get smart and bossy with me Jerry or i'll have
to slap you silly!!!!
not much when it comes to being told what do my
friend.
I'm a pround member of the Matronics list and on a
mission to harrass that list that ban me -ban me for
freaking life - what's up with that!!!!! - that little
prick son of a bitch dirt bag sum sucking jerk face
maget scum sucking ying yang!!!!!!!!! Control Freak!!!
cliff dow jr
cdowjr(at)yahoo.com
PS Oh yah did I call you a control freak!!!!!!!!! yah
doug - you!!!!!!!!!
--- Jerry2DT(at)aol.com wrote:
> Dear Cliff...
> you have a lot to
> best to you.
> Sincerely,
> Jerry Cochran
> Wilsonville, OR
> Contributions of
> any other form
> latest messages.
> other List members.
> http://www.matronics.com/subscription
> http://www.matronics.com/search
http://movies.yahoo.com/
You know Cliff, I commented to you once on an instrument issue and you
replied back with a smart-ass answer. Wise up or get banned everywhere.
Kev
Subject: Re: RV7-List: Welcome Cliff.... if....
> friend.
> cliff dow jr
> cdowjr(at)yahoo.com
> doug - you!!!!!!!!!
> > Dear Cliff...
> > you have a lot to
> > best to you.
> > Sincerely,
> > Jerry Cochran
> > Wilsonville, OR
> > Contributions of
> > any other form
> > latest messages.
> > other List members.
A message to this Cliff Dow Jr.,
I DO NOT (as probably everyone else on this list) care about your self
induced problems with Doug Reeves very fine site, nor do I want to hear
about your hatred!! Where did you come from?? Get yourself to a
psychiatrist & deal with the underlying problem!
One more thing:
DO NEVER USE YOUR FOUL LANGUAGE ON THIS LIST AGAIN, AS IT IS OFFENSIVE TO
EVERYONE !!
For your own sake, I wish you well!!
Konrad Werner
> friend.
> cliff dow jr
> cdowjr(at)yahoo.com
> doug - you!!!!!!!!!
> > Dear Cliff...
> > you have a lot to
> > best to you.
> > Sincerely,
> > Jerry Cochran
> > Wilsonville, OR
> > Contributions of
> > any other form
> > latest messages.
> > other List members.
Subject: | Welcome Cliff.TAKE IT OFFLINE. |
Good Lord Cliff,
I'm sure you have a great deal to add to a list, but stuff like the comments
below belong offline.
Please DO NOT the Matronics "RV List" as a sounding board for your personal
problems with another list or people. Simply take it offline.
I have nothing against you, and wish it to stay that way. I'm just trying
to keep you out of trouble early on.
Happy Building,
Stein Bruch
[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Clifford Dow
friend.
cliff dow jr
cdowjr(at)yahoo.com
doug - you!!!!!!!!!
> Dear Cliff...
> you have a lot to
> best to you.
> Sincerely,
> Jerry Cochran
> Wilsonville, OR
> Contributions of
> any other form
> latest messages.
> other List members.
Subject: | It wasn't me!!!!!! |
Hey fellow builders, I am NOT the one who got booted off one of the RV
Lists. I had about 6 hits on my computer condemning me for shooting my mouth
off. Wrong person though. I did see that posting from the guy who was
responsible but don't remember his name. I very quickly hit the delete key.
Russ Clifford
RV-7 waiting for wings
Anyone ever heard of putting heated seats in an RV??
my chevy suburban has nice heated seats and they are
awesome in the winter time.
cliff dow jr
cdowjr(at)yahoo.com
Maine RV-7A QB Builder (engine almost bolted on!! Yippy!!)
Subject: | Re: RV7-List Digest: 10 Msgs - 03/20/02 |
In a message dated 3/20/02 11:54:56 PM, rv7-list-digest(at)matronics.com writes:
Cliff....
I see you didn't learn anything by getting bounced on Doug's list. You should
give serious thought to giving up your project, doubtful if you can get a
pilot's license with your attitude. No instructor would put up with it for a
second.
Jerry
to slap you silly!!!! >>
Subject: | Cary's Fuel tank |
Hi Cary
What did you do with your leaking rivets? Did you contact Van's? Let use
know what you did and well it worked.
Scott Trask IMT
Subject: | Re: Cary's Fuel tank |
Thanks for asking Scott
I mixed up some proseal, cut it with MEK until it
looked like thin paint.
Dabbed it on the offending rivets and put a vacuum of
about 20 to 24 inches of water
Just sucked the sealant right into the leak
Seems to have worked well
Cary Rhodes, ailerons
--- Scott Trask wrote:
> Hi Cary
> Scott Trask IMT
> Contributions of
> any other form
> latest messages.
> other List members.
I'm sorry
had too much red win last night due to the arrival of
my engine - which I got mounted this morning - i truly
am sorry - will work on keeping myself off this
computer in the evening.
cliff jr
cdowjr(at)yahoo.com
> Cliff....
> second.
> Jerry
> From: Clifford Dow <cdowjr(at)yahoo.com>
> have
> Contributions of
> any other form
> latest messages.
> other List members.
Subject: | Re: Heated Seats?? |
I haven't heard of those in a RV but other planes I have. It would be to
less advantage to me since I live in california where the temp rarly gets
below 60. Rigth now at 7AM it is proubly 68 degree's outside. Ill be making
a trip from the LAX area to up north (Palos Romos) which shoudl be fun but
not in an RV. Thorp T-18 (Tail-draggers are the best)
Justin
Subject: RV7-List: Heated Seats??
> cliff dow jr
> cdowjr(at)yahoo.com
Check the RV-List archives. There was detailed discussion on them a year or
two ago.
Greg Young - Houston (DWH)
RV-6 N6GY ...Rebuilding!
searching for Navion to fly
> would be to
> temp rarly gets
> > cliff dow jr
Are you rebuilding the RV-6 that you lost in the "incident", or are you
starting over?
Don Parsons
Houston
[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Greg Young
Subject: RE: RV7-List: Heated Seats??
[...stuff deleted...]
Don,
Well kinda both. The only piece of metal that isn't bent is the vertical
stab. Everything else absorbed energy that I didn't have to. I picked up the
salvage on Tuesday and it's still sitting on the trailer in my hangar. If I
rebuild the airframe as a -6 then I could just continue with my test period.
If I build a -7 I think I'd need a new DAR sign-off. I have not started
disassembly and inventory but there's a lot to use on either a -6 or -7.
What I know of so far: VS (likely a wall hanging though), wing tips w/ RMD
lights, nav lights, strobes, ELT, a couple antennas, tail wheel assy, seat
belts, stick grips, AFP fuel pump, battery & box, complete panel, FWF except
prop & cowling, spinner, windshield, canopy and one wheel/tire/brake and
gear leg fairing. Amazingly, everything still lit up when the master was
thrown by the salvage guys so we had to disconnect the battery for
transport.
Whether it's technically rebuild or new, -6 or -7, I'm just calling it the
Phoenix project.
> or are you
> starting over?
> Don Parsons
> Houston
All that California has to offer is stuck up girls and good weather. I'd
rather live in Co. or something in the colder climate, just not old enough
to move out. =)
Justin
Subject: Re: RV7-List: Heated Seats??
> we hate you..fello pilots of oregon...windy, and COLD here {:~) do not
archive
gets
making
but
> > Justin
> > From: "Clifford Dow" <cdowjr(at)yahoo.com>
> > To: "RV-7 Matronics List RV-7"
> > > cliff dow jr
> > > cdowjr(at)yahoo.com
From: | "Builder's Bookstore" <winterland(at)rkymtnhi.com> |
Subject: | Free Thunderbird, Blue Angels videos |
I've got 5 copies of a Thunderbirds / Blue Angles video which we'll give
away for Free to the first 5 people who ask for it along with any other
regular order from Builder's Bookstore.
It's a 50 minute video, 1/2 on the Thunderbirds, and 1/2 on the Blue
Angels. The Thunderbird segment is excellent. The Blue Angels section
is not as good.
To get one, just write FREE THUNDERBIRDS VIDEO in the special
instructions box on the Builder's Bookstore on-line order form, or say
so if you prefer to order something by phone.
Also, in case you are caller #6 or later, note if your regular order
depends on whether there is a free video left to include in your
package.
Andy
Builder's Bookstore
http://buildersbooks.com
800 780-4115
From: | Peter W Mountain <peterm(at)kdc0.cavecreek.net> |
Hi all;
I'm looking for some advice. I am working on the empennage for my RV-7A QB
and this is all new stuff for me so please bear with me. I am wondering if
it's necessary to prime the inside of the empennage skins? I've been using
a self-etching primer (spray can) to prime the spars, ribs, etc. I do not
live in a salt air environment. Any thoughts?
Thanks for your help!
Skip
I am sure the advice is everywhere!!!!!
I have the opinion that I prime all inside skins with
epoxy primer after being etched with acid. I use a
scotchbite pad and gloves to scrub the skins with
water and alumprep. Then let air dry. When it was soo
cold this winter I voted for the self etching primer.
cary rhodes
--- lucky pilot wrote:
> Hi all;
> Skip
> Contributions of
> any other form
> latest messages.
> other List members.
Skip,
Keep in mind that the aluminum is already very well protected by it's Alclad
coating. Being concerned about weight, especially in the tail section, I'm
only going to use a self etching chromate primer on the inside surfaces like
you are just to cover any scratches that may be there. I live near the coast
in Houston but I'll bet I'll be long buried before the inside of my aircraft
shows any rust.
I think what you (we) are doing by using just the spray can self-etching
primer might be considered by some to be technically overkill, but it's a
really good thing to do because of the high degree of added protection you get
without adding hardly any extra weight.
Some builders have mentioned that they are going to spray both chromate and
then epoxy primer on the inside of their entire aircraft. I wish they would
rethink that. I was in the paint business (collision shop) for over 25 years
and I can assure you that you are talking about some SIGNIFICANT weight gain
doing that. And most of that weight gain will end up behind the CG.
Anyone who has to have the implications of that explained to them might want
to think about selling their project off altogether so that they can live out
their expected full and natural life :-)
Vern
>===== Original Message From rv7-list(at)matronics.com =====
>Hi all;
>Skip
From: | "Ellis H Mcgaughy" <Ellis.H.Mcgaughy-1(at)usa.dupont.com> |
03/28/2002 09:51:50 AM
It would be interesting for someone to weigh a piece of their empennage
(say HS) and compare to the weight of one painted with epoxy.
I painted mine and my HS weighs 18 pounds (at least by my bath scales). I
thought about running an experiment to more accurately determine the weight
gain per square inch of paint area, but have not done it yet. No doubt it
adds weight .... but in the end, I painted .... and so have many more.
It's alclad, this stuff is going to be here long after we are here. Not to
sound at all smart :-), but who in their right mind is going to buy a 40 year
old homebuilt RV-7 in 2042 whether it's primed or not. With that said, I am
using the 7220 self etching primer in a can from NAPA on any part that is
going to be attached to another, ie., I am priming the ribs so that I have a
coat of primer between the rib and unprimed skin. Gives me little warm and
fuzzy feeling, probably not much else.
Dana Overall
Richmond, KY
New totally pre punched 7 emp.
http://rvflying.tripod.com
For what it's worth (if anyone is keeping statistics), this is my plan
as well. I am using the Sherwin-Williams 988 self-etching primer
(similar, if not identical, to the NAPA stuff). In general the rule
will be to put one coat of primer between any two contacting aluminum
surfaces, and to fully coat any non-alclad surfaces. To accomplish
this, i'll be priming all the ribs, but no skins.
There's a few reasons i've chosen to go this route. One, I don't have
access to a large paint shop that's conveniently accessible. So small
parts, painted in small batches, in my (open) carport, with a rattle
can, will suffice. At least until I reach the fuselage. Two, I want to
keep the weight down, and regardless of whether people think the extra
weight of priming *everything* is negligible or not, it is weight that
(in my opinion) can be avoided. And Three, despite living in a "salty
environment" (Vancouver, BC area), i've seen oodles and oodles of
Cessna's that are 50 years old and have no corrosion on the insides,
despite living in the same region.
-RB4
RV-7 Empennage
rv7 "at" b4.ca
HEY...you NEVER know....I own an ercoupe that's over fifty years old..and it's
still going strong...gonna sell my RV8A that's almost finished, and go back to
it...of course it don't go as fast, or with the style as a Van's, but it iS
cheaper to fly!..but, like the sign says...it's experimental!...blue skys to you!
> Dana Overall
> Richmond, KY
I use varaprime from auto paint stores. You must mix and spray with a gun-go
with a small gravity fed one. I have tried nearly all types/forms. I spray
ribs, spars and interior of skins. Perhaps it's over kill, but much easier
than the etch, alodine, epoxy method and sticks better than spray can stuff.
I use spray cans of Marhide as a touch up so I don't have to mix-clean. Auto
paint guys will give you all the directions.
Bob in Arkansas
Here we go with the primer questions for this week. I recently finished my
-7 empennage and used the NAPA 7220 on the skeleton and inside of the skins.
I'm about ready to start on the wings and trying to decide which way to go.
The shaker cans are easy to use and convenient. I think I will not paint the
inside skins as they are alclad. For the inside structures I'm not sure.
One builder mentioned that the 7220 won't protect against moisture unless it
is sprayed with an epoxy primer. This builder suggested I use alodine and
then spray with a primer. What would you veteran guys suggest on priming?
Seems like the choices are many and wonder which is best. It has always been
said: Keep the aircraft light in weight.
Russ Clifford
Lake forest, CA
RV-7A waiting for wings
Check the archives-this enough reading for you to get the idea.
I etched, alodined, and epoxy primed tail. True over kill if you are not near
salt water.
I won't do again.
From: | "James & Shalise Cash" <jcash(at)granbury.com> |
Subject: | FS: 0-360 Barrett C/S prop firewall forward package! |
RV-6/7 almost firewall forward package by Barrett. All new or 0 SMOH!
Engine: Barrett Performance Aircraft Lycoming O-360-A3A
Serial# L-8845-36A
0 SMOH, 1900 TT, no prop strike
180HP with all yellow tags
(Certified Engine)
All AD's complied with
New slick mags and harnesses
Chromed Intake tubes and Valve
covers
Real Gaskets under valve covers
AC Fuel pump
Oil Filter
Adjustable oil pressure
Ellison Throttle Body Injector: EFS-4-5, New!
RV-6 Baffling: Installed and fitted
Prop: Hartzell Constant Speed Prop
HC-C2YK-1BF
Serial# CH 28403
0 SMOH
Prop Governor: Woodward B210681
Serial# 2001891
0 SMOH
Exhaust: Vetterman Crossover stainless steel
exhaust, RV-6, NEW
Airbox: Vans RV-6 airbox
Cowling: RV-6 Lightweight cowling
Installed, and fitted for engine and
prop
Set up for Dzus fasteners (not
included)
Scoop needs to be bonded to cowl
Only $26,999!!! Buyer responsible for delivery
I am upgrading my RV-6 project to an IO-360. Please, only serious
inquiries. Please email me any and all questions. I will provide my
phone number to serious inquiries. I will sell to the first offer to
take the entire package.
Located in Granbury, TX TX01
Jimmy Cash
Granbury, TX
I'm new to this list and haven't even started my project yet, but it seems
to me that one could simply weigh all the parts that go into the HS, and
see how that compares to a finished primed one. Wouldn't that give some
idea of how much weight you are adding with primer?
Bruce Swayze
RV-7A (not started yet)
I did a test and the Self etching primer does not stick as well to AL after
it has been alodined. The Sherwin Williams 988 can says that as well.
John,
RV Wings.
-----Original Message-----
Subject: Re: RV7-List: RE: priming
the
it
been
Russ Clifford
Lake forest, CA
Subject: | Aileron Push Rods |
There must be a trick to riveting the rod ends to the powder coated aileron
push rods. It calls for a 470 4-12 rivet through the rod end and they all
bend over because so much sticks out. The center of the rod end is hollow
so I'm sure the rivet squeezes up inside as well. I get big ugly rivets on
the working side and don't know how to make them squeeze properly, any one
know the trick?
RV 7 wings
Subject: | RE: Aileron Push Rods |
I saw them do this on 'From the Ground Up' the show on Discovery wings,
building an RV-8. It looked fairly straightforward. They used some sort
of pop rivet. Not sure the exact spec though. I haven't got to the wings
yet, still waiting for delivery. Are the called out rivets too long?
Any more detailed info regarding your problem might help me understand
the issue....
Sorry for the direct e-mail, I'm at work and just thought I'd write
back quickly...
Mark Taylor
CAD Technical Specialist
313 203 4702
Subject: RV7-List: Aileron Push Rods
> RV7 List message posted by: John Adams
coated aileron
push rods. It calls for a 470 4 12 rivet through the rod end and
they all
hollow
rivets on
one
know the trick?
RV 7 wings
_
_ = The RV7
List Email Forum
_ = This forum is sponsored entirely through the Contributions
of
_ = List members. You'll never see banner ads or any other
form
_ = of direct advertising on the Matronics Forums.
_
_ = !! NEW !!
_ = Browse List: Use your web browser to view the latest
messages.
_ = Photo Share: Share photos and files with other List
members.
_
_ = List Related Information
_ = Post Message: rv7 list(at)matronics.com
_ = UN/SUBSCRIBE:
_ = Photo Share:
_ = Browse List:
http://www.matronics.com/browselist/rv7 list
_ = Search Engine: http://www.matronics.com/search
_ = Archives:
_ = List Specific: http://www.matronics.com/rv7 list
_ = Other Lists:
_ = Contributions:
_ = Matronics: http://www.matronics.com/
_
Pop rivets are used on all the push rods but this one (the one going
directly to the aileron). The rivet goes all the way through the 1/2 inch
rod.
Subject: RV7-List: RE: Aileron Push Rods
the issue....
back quickly...
Mark Taylor
313 203 4702
coated aileron
they all
hollow
rivets on
one
know the trick?
RV 7 wings
_
_ = The RV7
List Email Forum
of
form
_
_ = !! NEW !!
messages.
members.
_
_ = UN/SUBSCRIBE:
_ = Photo Share:
_ = Browse List:
_ = Archives:
_ = Other Lists:
_ = Contributions:
_
I just finished my wings. Having primed the empennage and become disgusted
with the labour, mess and cost of prming, the wings are alodined only. I
save labour by not having to scuff the components and on the cleanup. Teh
results are excellent. The only drawback to alodining is that it is not as
scratch resistant as a good hard primer - so I do some touchup with primer.
An alternate suggested by a local maintainter is to wet assemble. Leave the
wing skins as untouched alclad. Where rib and skin meet, use a spray can to
spray both the rib flange and along the inside of the line of rivet holes
and cleco and rivet them together while the primer is still wet.
These are the two least labour intensive methods I know. The most labour
intensive is to scuff, alodine and them prime with the two part primer used
on agricultural aircraft! That is good enough for a plane that lives at the
beach.
David Francis, Canberra, Australia, VH-ZEE, wings finished over easter.
From: John Adams [mailto:jadams(at)scoutmedical.com]
Subject: RE: RV7-List: RE: priming
Subject: | Re: RV7-List Digest: 5 Msgs - 04/01/02 |
In a message dated 4/1/02 11:55:16 PM, rv7-list-digest(at)matronics.com writes:
<< There must be a trick to riveting the rod ends to the powder coated aileron
know the trick?
RV 7 wings >>
On my -6a plans they say to have 'em welded as an alternate. I did just that,
took them to a good welding shop and had them TIG welded. Looks great and is
MUCH stronger than rivets. Cost $20 though. My .02. BTW, you can then paint
them over with Van's touch up paint that matches the powder coat.
Jerry Cochran
Wilsonville, OR
RV6a QB F kit
> know the trick?
> John
> RV 7 wings >>
> Jerry Cochran
> Wilsonville, OR
> RV6a QB F kit
I also welded my A. rods on my TIG welder. On my other home build it has
rod like that I did the same thing. Good way to go.
Scott Trask IMT
Subject: | re: aileron push rods |
I whammed the -12 rivets with a hammer. they didn't
bend but were not quite as pretty as they should be.
gorilla rivet- strong but ugly --
I wish i had tig welded them
cary rhodes
building flaps
http://http://taxes.yahoo.com/
From: | "LarryRobertHelming" <lhelming(at)sigecom.net> |
Subject: | Tail Dragger rear fuse question |
I am stuck. the tie down bar and the tail spring mount seem to conflict
when following the builder's manual. Drawing 21 shows the tie down
mounted on the F712 bulkhead. Drawing 27, in describing the tail spring
position, omits the tie down. I can't see how they both can go on
F712.
Larry in Indiana
They don't, the tie down is for the -7a and the spring is for the -7.
in fact if you are building a -7, you should even have the extrusion to
make the tie down bracket. The drawings nor the manual really specify.
Do not know which you are building, but if you are building the -7 make
sure you get the spring weldment in before you put bottom skin on. It
is very tight.
Gary M. Coonan
-7 Fusalage, waiting on finshing
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of
LarryRobertHelming
Subject: RV7-List: Tail Dragger rear fuse question
F712.
Larry in Indiana
Hi Larry,
You don't have a tie down for a tail dragger (uses the tailwheel). The tie
down is intended for the 7A (nose dragger).
Stein Bruch
RV6, Minneapolis.
LarryRobertHelming
F712.
Larry in Indiana
Subject: | Re: Tail Dragger rear fuse question |
Thanks for your reply. I guess part of the real confusing thing is I have
the tie down bar and put it in. Of course I couldn't have done that if I
hadn't. I am building an RV7.
Subject: RE: RV7-List: Tail Dragger rear fuse question
> Hi Larry,
> Cheers,
> Stein Bruch
> RV6, Minneapolis.
> From: owner-rv7-list-server(at)matronics.com
> LarryRobertHelming
> To: rv7-list(at)matronics.com
> F712.
> Larry in Indiana
Subject: | Wing jig or religious statement?! |
I've searched the archives but couldn't find an answer to this wing jig
question:
I'd like to put the angle stock on the *outside* of the wing jig instead of
on the inside. Drawing 12A calls for approximately 114" in between vertical
posts, but the way I want to orient my jig, I've got one piece of angle
stock inside one post, and the other piece of angle stock *outside* the
other post. The distance works out just fine, but what I'm wondering is
whether that one jig post being inside the span of the wing will interfere
in any way.
I assume it won't, since I've got at least a foot between the vertical post
and where the spar will mount on the angle stock.
Just let me know if I'm getting into dangerous territory here.
The other thing...I decided not to mount my cross bar angle stock just
yet...I'm going to wait until the last minute, because from my neighbors'
perspective, it looks like I've built a giant crucifix in my garage. If I
leave it like that, they're definitely gonna think I'm some religious freak.
8
)_( Dan
Subject: | Rudder Clearance with VS at Counterweight |
Just finished the rudder alignement with the vertical stabilizer. The gap
came out to 1/8" along the top edge. I could not locate a dimension on any
of the drawings. Is this OK?
Mike Okrent
Rv7A Elevators
I mounted both cross pieces on the outside with no problems on my 7A
wings.
Brandon Dixon
7A fuse kit
Subject: RV7-List: Wing jig or religious statement?!
question:
of
vertical
interfere
in any way.
Dan. I built my jig for RV6 wings and then converted the tail to RV7. The
distance between posts was short so my two brackets were bolted to the
outside faces of the posts. The wing root end was ok because the spars
extend beyond the areas to be riveted. However at the tip end the post
prevented me from drilling, dimpling and riveting the outboard rib in the
jig. Remedies:
a. If only one end bracket has to be on the outside of a post, make sure
that end supports the wing root.
b. make the brackets so long that there is enough room for a dimpling tool
to fit between post and wing tip rib.
c. Do as I did, get one hefty son to hold the wing tip clear of the jig
whilst I did my duty.
David Francis, VH-ZEE, wings finished, Canberra, Australia.
interfere
in any way.
From: | "Wayne Pedersen" <wayne(at)pedersentransport.com> |
Subject: | Home insurance cancelled due to RV7 being built |
I received a registered letter in the mail today from ALLIANZ Insurance
Company of Canada in which they revoked my homeowners insurance policy with
no reason stipulated. Here's why:
- started building RV 7a in November 01 and contacted my broker to see if I
could up my contents insurance to cover the aircraft in the garage.
- he finally got back to me two months later and said no. Not a big deal I
just went and got builders insurance through my aviation broker.
- Last week I get a call from my home insurance broker saying that Allianz
is all freaked out about my building of an aircraft in my garage. I
explained that its just aluminum, rivets and that I wasnt even painting or
priming in this location.
-yesterday I received the registered letter revoking my homeowners
insurance. They will not talk direct to me so the broker phoned to see what
the scoop is. Yup, you guessed it...that brain dead varmints feel that my
stack aluminum is a threat and want to remove themselves from the risk
UGGGGGHHHHHHH ! I'm so frustrated I could over squeeze a -9 rivet and then
eat it.
Seems they have a clause that will allow them to cancel for any reason
sane or not ). Too bad or I would sue them for mega Canadian dollars ( = a
few U.S. $$ ) and finish my plane in style.
So fair warning to all my Canadian homebuilders and maybe they should be
looking at dumping Alianz before they get dumped.
Wayne in S.ALberta
RV 7a fuse
Subject: | Canopies to tip or slide? |
Inthe next months I will be ordering my RV7 fuselage and finish kit but I
am not sure which canopy to go for. The most important feature I require is
head protection in the event of a tip over and first impressions would
indicate that a slider would be the way to go. However if you look at the
head rail behind the humans on a tip up it appears to be very much more
substantial than that of a slider, does any one have any definitive
information?
Other considerations are weight, time and ease of construction, and drag
penalty
Any experts out there
Subject: | Re: Canopies to tip or slide? |
One of my considerations in selection of a canopy style was the accessibility
of the instrument panel. Certainly the floor of the 7 is more open than the
6. But, even with a removable panel the tipper is much easier to work behind
the panel. I have never owned an airplane that I didn't have to get behind
the panel on a regular basis.
My feelings are the slider looks better from the outside and is cooler in
taxi. The tipper looks better from the inside out. I plan on flying more
than I do taxiing so tipper it is. Plus, I know I will be putting all kinds
of new tricks in the panel even after I "finish" it.
Honestly, you can just about flip a coin you will like either selection.
Dana Overall
Richmond, KY
I think Dana is right, either would be a good choice. I decided to go with the
slider. After going to Sun-n-Fun and getting in and out of Van's 7, I noticed
I had to be careful not to hit my head on the tipper. Also, most of the RV6's
flying solved the accessibility problem by making some nice looking sub-panels.
They also said by taking out the seats and laying on a board made it easy to
get to the back side of the panel. I'm in a warm climate and sliding the canopy
while taxing made it the choice for me. There is also a guy that made a slider
that tips in the rear position to make loading the baggage compartment easier.
My 2 cents worth.
Is the rear headrail on the tipper formed alum. or is it a steel support like the
slider?
Allen Blackwell
Tylertown, MS
Your favorite stores, helpful shopping tools and great gift ideas. Experience the convenience of buying online with Shop@Netscape! http://shopnow.netscape.com/
Maybe you guys already know this but I didn't. When you use an aircraft
flare tool on AL gas line it can gall the AL and make an ugly looking flare
on the inside. AL will also build up on the tool and make it worse the next
flare you make. A shot of WD40 to the flare tool just before each use makes
perfect shinny flares on the inside of the tube without galling. Anyone
know how you make the tight bends on the side of the cockpit where the gas
line exits the body? I think I will add an elbow now that I can make good
flares.
N577RV
From: | "Francis, David" <David.Francis(at)defence.gov.au> |
John,
And for others encountering tubes for the first time.
Aircraft components have a 37.5 degree flare, not the 50 degrees common to
automotive parts. Yes oil is needed prior to every use to prevent galling.
For bends the critical thing is to prevent crimping of the line. You may
choose to bend by hand, works well for gentle bends. Bend around a small tin
can. Some reduction in cross section may easily occur, but that is usually
not a problem. Preferably use a proper tube bending tube or snake. The snake
can be hard to remove after bending. Tube benders produce wonderful bends
but can be awkward to use in situ.
See the Avery tools catalog page 54.
David Francis, VH-ZEE, Canberra, Australia, building ailerons.
Subject: RV7-List: Flare Tool
on the inside. Anyone
flares.
N577RV
Hi
Help! Is there a site where I can place an add for a fly-in to get RV's to
come? I would like to get a good group of RV's to show up at our Michigan
Upper Peninsula EAA chp439 fly-in. It will be on Sept. 21 rain day Sept. 22
at IMT. Our Pres. is a Lancair builder and he's always getting a few
lancair planes to show up.
We will be getting some war birds in, Ford tri-motor and others. Big Band
hanger dancing in the evening.
Scott Trask (RV7A builder--1/2 way there!)
IMT
"RV6"
Subject: | Re: RV6-List: Fly-in |
Be sure to list it on the vansairforce website.
Subject: RV6-List: Fly-in
> --> RV6-List message posted by: Scott Trask
> Hi
to
22
Band
> IMT
Subject: | to shave or not to shave |
That is the question...while waiting for my wing kit, I got bored, so I
started messing around with a rivet shaver. I was playing with it for the
first time, trying it out on my little SportAir project.
WOW!!!!!!!
Granted, my rivets come out much better now than they did on my first-ever
riveting job, but the shaver can have a dramatic effect. The rivets that
stood a bit high ended up completely smooth and flush to the touch. I'm
definitely impressed.
But here's the question...is it worth shaving every rivet on the plane for
consistency and a "silky smooth" finish? Or does the paint prep process
take care of this naturally? I can see a few factors...ScotchBrite and
primer may go a long way to smooth out the minor "tall" rivets, but does
that really compare? Is there any risk in rivet shaving, i.e. reducing the
"effective radius" of the rivet head (I guess this is minimized by
accurately tweaking the microstop)?
Anyway, I'm curious. I was going to create a web poll, but I figure I'd
like to hear people's opinions in more than a yes/no fashion.
)_( Dan
RV-7 N714D (wings mid-shipment, fuse & finish in June)
From: | "Paul Besing" <azpilot(at)extremezone.com> |
Subject: | Re: RV-List: to shave or not to shave |
This goes back to "getting the airplane finished" If you do a good job
dimpling/countersinking, you should be fine. It is a metal airplane, and
people expect to see rivets. It couldn't hurt to use the shaver for the few
rivets that sit slightly above the surface, but I would not do every rivet.
You are creating unnecessary work, IMHO. Also, you won't care. Once you
fly it, painted or not, you won't care. Your freaking grin will be so wide
that your eyes will be squinted and you couldn't see those darn rivets
anyway.
Paul Besing
RV-6A Sold (Waiting on the RV-10)
Kitlog Pro Builder's Log Software
http://www.kitlog.com
Subject: RV-List: to shave or not to shave
> WOW!!!!!!!
the
> )_( Dan
Subject: | Re: RV-List: to shave or not to sha |
ve
Foolks a couple of things about proud rivets:
a. I now use the slightly deeper tank dies as standard, particularly on the
thicker skins. This gives a more consistently smooth outcome.
b. sanding during the painting process can be used to smooth out the higher
rivets, with or without filler being applied.
c. Most high rivets are under driven. any particularly high rivets can be
flattened somewhat with an extra hit, particularly effective is to back
rivet selectively, ie. bucking bar on the manufactured head, if you have
access for the gun from the rear.
HAve fun, David Francis, wings finished.
From: Paul Besing [mailto:azpilot(at)extremezone.com]
Subject: RV7-List: Re: RV-List: to shave or not to shave
Paul Besing
> WOW!!!!!!!
> )_( Dan
Using the tank dies to get a smoother result is an interesting idea.
I've read the writeup that Sam Buchanan has on his web site. One thing I
have to wonder, though, is since the manufactured head of the rivet ends
up being a couple thousandths of an inch below the surface of the skin, is
it possible that rivets set in tank-dimpled holes will be a couple
thousandths loose? IOW, is it possible that the flush rivet set can't
actually contact the rivet head because the skin is in the way? Or does
the flush rivet set compress the skin enough to guarantee that the rivet
is fully set?
What do those of you who've used the tank dies think? Has anyone tried
twisting the shop head of rivets driven in such holes to see if they're
any looser than rivets set in non-tank-die-dimpled holes?
-- Lynn
RV-7A emp (still...)
Louisville, CO
From: | "Francis, CMDR David" <David.Francis(at)defence.gov.au> |
Subject: | Re: RV-List: to shave or not to s |
have
Lynn, I first had the same doubts. However consider that:
a. a cleco does not hold skin to rib rigidly, ie there is play available.
b. when you dimple two things occur, you bend the metal to form a dimple,
and the hole is slightly widened by the male die. The displaced metal goes
somewhere - it goes into the rim of the dimple ie. the dimple rises (look
along a dimpled surface against a distant light, each dimple has a visible
rise. This rise creates a small gap. That gap is flattened out by the rivet
gun hammer.
c. when you hit the assembly with a rivet gun the whole deal vibrates.
In summary there is plenty of give in dimple and rib, enough to give good
contact between hammer and bucking bar.
The way I got into the technique was the failure of the conventional dies to
dimple well on the thick inner top wing skin. The quality of the dimpling
determines the quality of the finish. The standard dies on thicker skin gave
a shallower dimple, hence my initial riveting gave slightly proud rivets. I
dont have a shaver, so I unzipped the skin, re-dimpled with the tank rivets,
and got lovely results. The TC passed the work on first inspection.
The proud rivets are lacking in strenght because the full area of the
manufactured head is not in full contact with the skin. Hence the better
finished tank die rivets must be stronger.
PS the Vans bible states the flaps are the easiest part of the wing kit to
build - wrong, beware the inner leading edge brackets, they call for black
smith skills.
Hope this helps, David Francis, VH-ZEE.
the
is fully set?
-- Lynn
Louisville, CO
From: | John Reuterskiold <mtnflyr(at)attglobal.net> |
Subject: | Tailwheel Socket Install |
Any -7 quickbuilders out there who have figured out an easy way to get
the tailwheel spring socket (WD-409) mounted square between F-711 and
F-712 bulkheads? I bet this would have been easier to align before the
F-711 was riveted in place.
John Reuterskiold
RV-7 QB wings done
Subject: | Re: Tailwheel Socket Install |
I haven't. I have it installed temporarily and after a lot of trial and
error have a snug fit at the bottom of the 409 but about 1/16" gap at the
top of the rear plate and 712. I may just shim it per Vans instructions but
I want to do a trial fit of the VS before I commit to drilling holes. I did
find it helped to straighten the plates of the 409 that had warped during
welding.
Neil McLeod
7QB Fuse
Subject: RV7-List: Tailwheel Socket Install
> Thanks
> John Reuterskiold
> RV-7 QB wings done
Subject: | Lubricating the micro-stop |
I'm machine countersinking the hundreds of holes where nutplates attach to
the wing spars. Problem is, since I'm doing zillions of holes in one
sitting, the micro-stop gets HOT. Last night I took it apart, and I cleaned
and greased the moving parts, but that didn't seem to help alleviate the
heat problem.
Is this common? I have to assume so, but since I haven't read anything
about it in the archives I'm not sure. Is it just a sign that I need to
move onto something else and let the dang thing cool off?
Stupid questions, I know, but pardon my caution...I'd rather ask a stupid
question than have to replace the tool (or worse, kit parts).
)_( Dan
http://www.rvproject.com
Dan,
I have not encountered a heat problem. But I operate a slow air drill at
reduced pressure, about 35psi to slow it down so I can control the beast and
get a smooth finish.
Regards, David Francis, VH-ZEE. Australia.
Subject: RV7-List: Lubricating the micro-stop
heat problem.
)_( Dan
Subject: | Paint gun recommendation |
I'm looking for input on the optimal paint gun for priming the internals of my
RV-7A parts. The objective is to minimize fumes because I'll spraying in my attached
garage.
My current thinking is that a HVLP gravity feed with a narrow spray pattern (at
8" from work) would be the best bet for minimizing over-spray (and thus fumes?).
Any recommendations? Am I on the right track? Is one brand easier to clean than
another?
John Burns
Albuquerque
John,
If oversparay is the problem a lateral approach is to use alodine. Not much
overspray from things sitting in a bath. Also its not temperature or
humidity sensitive like spray painting is.
Regards, David Francis, VH-ZEE, flaps & ailerons nearly finished.
Subject: RV7-List: Paint gun recommendation
my RV-7A parts. The objective is to minimize fumes because I'll spraying in
my attached garage.
John Burns
Albuquerque
Subject: | Re: Paint gun recommendation |
John, There is a ton of material in the archives, but if you want my recent
experience, here goes- I agree on your choice of the hvlp gravity gun, I use
a small Porter Cable GT0801 hvlp gravity detail gun 4.5oz. cup with very good
results. Since I live near the gulf I have chosen you do the full corrosion
treatment. 1. alum.cleaner/etch 2. Alodine 3.PPG. DP402LF catalyst / DP50LF
epoxy primer. I have been amazed at how little paint it takes to cover with a
very lite coat on the insides of the skin and frame, So far the HS has taken
4.5 oz.(mixed), VS 2.5 oz and the rudder 2oz. Over spray is at a minim. Hope
this helps. Sam Kurtz N467SK
Subject: | Alodine vs. primer |
Is alodine by itself sufficient protection? I'm just starting
construction and this is something I've been wondering about. My plane
will live in eastern Pennsylvania, but may make occasional trips to
Florida.
Jim Hasper - RV-7 builder
Not sure how other listers are going to reply to this, but I can say that we
( at Superior ) leave our engines alodined ( paint ready ) and have had no
problems. All the major components are investment cast aluminum.
Subject: RV7-List: Alodine vs. primer
Florida.
Jim,
My local aircraft maintainer indicates that alodine provides very good
protection. Alodine plus primer would be appropriate if the aircraft has a
permanent home within the salt spray zone of a beach, and in crop spraying
aircraft.
Alodine is adds no weight, has no overspray, does not requriescuffing of the
aluminium, and seems to be about the same cost as the cheaper single part
primers. The only downside I have found so far is that it is not as scratch
resistant as a two part primer. So I get to use tape and touch ip a bit
more.
Regards, David Francis, VH-ZEE wings finished.
Subject: | To flute or not to flute |
W-408-1 L & R are the most inboard leading edge ribs, just outboard of the
tanks. They didn't come pre-punched in my kit. I'm not upset about that,
but I'm kind of confused about how to go about fluting those 2 ribs to
straighten them.
On the emp, we had a fluting guide (a full-scale drawing) for all
non-pre-punched ribs, which showed the rivet pattern, and thus where to make
the flutes.
Am I missing something essential on these 2 wing leading edge ribs...like a
fluting diagram somewhere? Or is it as simple as putting it up against the
next ribs over and just matching up the hole/fluting pattern?
It's been a long, tiring week (work-wise, not building wise unfortunately)
and I apologize if this is a lame-ass question. 8
)_( Dan
RV-7 N714D (wings)
dan @ rvproject . com
Subject: | Re: To flute or not to flute |
I'd insert the ribs and make sure they are fully inserted. Put a center
line on the rib with a red or black marker. Get it centered and mark the
hole locations using the skin as a guide. Then remove the rib and flute
between the holes. I'd just be real careful and get the rib fully inserted
before hand. Lay the rib on any flat surface and flute no more than
required to get to lay flat.
Larry in Indiana, working on the fuselage brake pedals.
----- Original Message -----
Subject: RV7-List: To flute or not to flute
> straighten them.
make
> the flutes.
a
the
> )_( Dan
> RV-7 N714D (wings)
Dan,
Dont fuss too much at this stage. The heavy undrilled ribs will form a 3
layer sandwich of inner rib, a joining plate that links leading edge and the
tank, and the outer leading edge skin. When you get to cleco the whole deal
mark the rivet points, flute between them, then drill & debur. Be very
careful with the joining strip, it likes to slide around and also needs
trimming. You will see what I mean when you get to put it together. This is
one area where going slowly pays off.
By the way the precision of the fluting of your wing ribs determines the
ease of skin to fram mating at a later stage. I was given this tip by a RV6
builder (yes those dinosoars are still in production, so I went back and
re-fluted to the very best standard I could. Even so I still cold hav epaid
more attention to making sure the flanges are 90 degrees to the web.
It paid off, all my skins went on first time, no trouble. The only oops was
my first try to fit a skin went bad because the mid-span jak under the rear
spar was not adjusted enough to take the sag out. After a bit of head
scratching I just upped the jack and voila, perfect fit first time.
Also I got mediocre riveting results on the first thick skin, and also on
the curved leading edge skins, so I re-dimpled with tank dies, much better
outcome.
David Francis, VH-ZEE, wings, ailerons & flaps finished.
straighten them.
_
Subject: | SEC: UNCLASSIFIED: To flute or not to flute |
Dan,
Also I got mediocre riveting results on the first thick skin, so I
re-dimpled with tank dies, much better on the thicker skins.
straighten them.
the flutes.
)_( Dan
RV-7 N714D (wings)
I just got an RV-7 wing construction manual correction in the mail from
Van's. Cool. As I looked at the figures at the end something caught my eye
and made my heart drop...
In Fig. 7-1, the doubler plate is obviously countersunk for flush rivets.
But...on the plans, they specifically call for AN470 round-head rivets
there!
Now I'm freaking out a bit, because I don't quite know how the wing mates up
to the fuselage and whether those rivets are indeed supposed to be flush! I
obviously want to figure this out before I skin the wings.
Can somebody out there please tell me that Figure 7-1 is misleading and that
yes, we are supposed to have AN470 rivets attaching W-707D (doubler plate)
and W-707G (doubler fork) to the rear spar?!?
Patiently awaiting the doctors' diagnosis...
)_( Dan
Subject: | QB Rudder Pedal Brace Riveting Clearance |
Any QB builders with a better solution than Van's for attaching the
rudder brace to the firewall stiffner?
My question to Vans:
On an RV7 QB what is the recommended method of attaching F-6118 rudder
pedal brace to F-601N-L firewall stiffener? The QB already has the
F-601K-1 firewall recess riveted in place. There is insufficient
clearance to insert the recommended rivet AN470AD4-5 let alone trying to
get a bucking bar in between the stiffener and firewall recess.
Vans Response:
The best way to do it on the QBs is to drill through the angle, brace
and recess and rivet it all together, using a spacer(s) to fill the
remainder of the gap between the brace and recess.
I personally don't like this soltion for a couple reasons; 1) I don't
think the strength will be the same. 2) I don't want any more holes in
the firewall than are absolutely necessary. 3) Its ugly. I am thinking
of drilling out the rivets holding the recess, riveting in the brace,
and then reriveting the recess. I am open to any other suggestions or
ideas.
I used this method because I wanted the box flanges on the cockpit side of
the firewall (slow build). Others have used it because the box was already
mounted, ala QB. To your points:
1) It's plenty strong. The brace will buckle and the nylon shear before the
rivets let go. I can provide pictures.
2) You've already got a bazillion rivets in the firewall - what's 4 or 5
more?
3) There's only 4 or 5 rivets on the side of the recess. Use 1/8" round head
rivets with mfgr head on firewall side and they look fine. They are in an
area of the recess that is almost impossible to view once the engine is
installed - particularly with a governor in the recess. You'll likely do
more cosmetic damage if you try to remove and re-rivet the box.
RV-6 N6GY ...project Phoenix
Navion N5221K - just an XXL RV-6A
> F-6118 rudder
> alone trying to
> Vans Response:
> holes in
> am thinking
> suggestions or
> ideas.
> Thanks
> John
Subject: | Re: QB Rudder Pedal Brace Riveting Clearance |
I plan to use heavy duty blind rivets. I called Van's, this was their
suggestion.
Bob Trumpfheller
Subject: | TruTrak installation |
I just scanned in seven TruTrak installation diagrams:
http://www.rvproject.com/trutrak.html
I had been trying to figure out (by searching the archives) whether
autopilot installation would be difficult after the wings have been
completed. I just got the info pack from TruTrack on their RV-7
installation...and by the looks of it, the roll servo attaches using
existing bellcrank bracket bolts. Looks like a couple of servo attach
brackets just bolt on right there and no additional provisions have to be
made to the main spar.
I'm not positive about this, though. If anybody wants to confirm this,
it'll etch in stone my decision to put off buying an autopilot until much
later.
I apologize if this has already been covered in the archives, but I couldn't
find it.
)_( Dan
Subject: | [ Dale Larsen ] : New Email List Photo Share Available! |
From: | Email List Photo Shares <pictures(at)matronics.com> |
A new Email List Photo Share is available:
Poster: Dale Larsen <slickrock@been-there.com>
Subject: Flap position indicator
http://www.matronics.com/photoshare/slickrock@been-there.com.05.27.2002/index.html
o EMAIL LIST PHOTO SHARE
Share your files and photos with other List members simply by
emailing the files to:
Please view the typical Share above and include the Description Text
Fields as shown along with your submission of files and photos.
o Main Photo Share Index:
Subject: | [ Dan Checkoway ] : New Email List Photo Share Available! |
Poster: Dan Checkoway
Subject: TruTrak autopilot installation diagrams
http://www.matronics.com/photoshare/dan@rvproject.com.05.27.2002/index.html
Subject: | [ Gary Crowder ] : New Email List Photo Share Available! |
Poster: Gary Crowder
Subject: Manual trim cable mount
http://www.matronics.com/photoshare/rv9er@3rivers.net.05.28.2002/index.html
Subject: | [ Kevin ] : New Email List Photo Share Available! |
Poster: Kevin
Subject: AK aug 2001
http://www.matronics.com/photoshare/rv8r300@attbi.com.05.29.2002/index.html
Subject: | New Builder - Maybe? |
From: | "Ted Strand" <tstrand(at)strandcentral.com> |
Hello,
I am considering the purchase of an RV-7A kit in the near future. This
week I am going to Vans for a factory tour and test flight, and then
onto California for an EAA building class. Is there anything I should
"be sure to ask" about during either the tour or class? I love flying
and love to build stuff, so this seems like a good fit. My wife
convinced me to wait until the class is over; to be sure this is
something that we both want to do.
Any helpful hint, suggestions, tips, etc.., would be greatly
appreciated!!!
-Ted Strand-
Subject: | Re: New Builder - Maybe? |
on 6/1/02 11:30 PM, Ted Strand at tstrand(at)strandcentral.com wrote:
> Hello,
> appreciated!!!
> -Ted Strand-
Hi Ted & List
If you haven't already gathered your tools up yet, one tool I would look
for would be a pneumatic hammer gun that allows you to grip close to the end
with the trigger right there. It would allow you to operate it with one hand
easier. If they make such a tool, I haven't looked myself for one I'll live
with tools I have.
I have made some of my own tools fairly easy. Fluting, dimpling tools and
a attachment for the table saw for sanding.
Scott Trask Working on Fuselage Kit
I did the same thing...waited until after the SportAir workshop to see if
building was something I was up to. It was, and it will be for you, too.
You *will* end up getting hooked. May as well order the empennage now so
that once you're rip-raring to go, you have less of a wait for the kit.
In the words of Hans and Frans...hear me now and believe me later... 8
)_( Dan
RV-7 N714D (wings)
Subject: RV7-List: New Builder - Maybe?
> Hello,
> appreciated!!!
> -Ted Strand-
Subject: | Tank Z brackets question |
Ok, I'm a little confused...I'm getting started building the tanks, and I'm
about to drill the Z brackets (talking about an RV-7 here). I understand
the process Van's outlines, and I think it's pretty lame, since there's no
guarantee that once the tanks are completed that the #12 holes in the Z
brackets will align perfectly with the spar holes...and there's no guarantee
that the tank will align perfectly with the outboard skin or the holes in
the spar.
That's fine, I'm scrapping Van's instructions and I'm going with the
approach that Steve Hurlbut outlines:
http://checkoway.com/url/?s=c9bc2576
That seems to be the most logical approach for getting it perfect.
BUT...
What's the deal with the root Z bracket? There's absolutely nothing in
Van's instructions about this (at least that I could find). Apparently, it
never gets drilled. 8
) And what's the deal with nutplates for that root Z
bracket? My spar came pre-drilled for nutplates to mount on the aft side of
the spar (it seems), but again there are no instructions.
I'm happy to fill in the blanks and make some logical assumptions here, but
I wanted to check with other builders first...
I'm planning on installing nutplates on the aft side of the spar and
drilling the root Z bracket just like the others. Right?!
I must be missing something...
)_( Dan
Subject: | Re: RV7-List Digest: 4 Msgs - 06/02/02 |
In a message dated 6/2/02 11:55:45 PM, rv7-list-digest(at)matronics.com writes:
<< I am considering the purchase of an RV-7A kit in the near future. This
appreciated!!!
I have nothing but admiration and awe for folks who manage to build one of
these things in the "slo-build" mode while balancing the needs of a wife,
family, and profession. I am retired, with the kids grown up, the wife fully
on board with the process and building a "Quickbuild" 6a. I'm just closing in
on 1300 hours with it and anticipate the airframe will be done in another
2-300 hours. I've been told I will be half done at that point. Of course,
I'm counting "noodling" time, watching the video, re-reading the
plans/manual, etc. The next one :-) will be done in less than half that time,
but still quite a time and money commitment. That's the bad news. The good
news that gets me to the garage 35 hours a week is what I will be flying when
I get done, probably the sweetest flying, best looking sport plane on the
planet! So.... Rivet On!!!!
Jerry Cochran
Subject: | protective barrier skin cream? |
Can anybody out there recommend a protective barrier cream for your skin
(human skin, not RV skin)?
I've seen several products at this point and I'm swimming in confusion over
which ones actually protect you from harsh elements (i.e. ProSeal, etc.) and
which ones are just dirt & grime barriers.
Gloves in a Bottle?
West Systems 831?
Debba?
Any advice is appreciated...
)_( Dan
RV-7 N714D (tanks)
From: | Harold Roman <haroldroman00(at)yahoo.com> |
I just received the RV7 study plans last night. There were revisions included that
seem to change the rudder so that it is about 2 1/2 inches longer (wider).
I remember reading in the last RVator newsletter that Vans had some concerns about
the RV7's spin recovery. I guess it wasn't exactly a problem, but it wasn't
as good as expected. The possible fix was to make the rudder bigger.
So, does anyone out there know, is the bigger rudder the fix for the spin recovery
issue? Or is it going to become bigger yet again?
++Harold
Sign-up for Video Highlights of 2002 FIFA World Cup
Subject: | Re: bigger rudder |
Hi Harold,
Sorry, I posted this to the RV-List and should have copied the RV-7 list
too.
The short answer is yes, the larger rudder is the fix for the spin
recovery issue. For more details read on below:
--> RV-List message posted by: Rob Prior
I can confirm some of this and add a little more:
At the Langley (CYNJ) RV-Fly-In on Saturday of this weekend, we had Gus
Funnel from Vans up in the Factory RV-7. It had the stock tail on it.
Gus sat in on a seminar on RV-building, to answer questions, and at the
end asked if anyone was interested in an RV-7 Spin/Stall update. He
went into the background of the problem in a little more detail, which
i'll try to summarize.
Apparently the RV-6, when spun, will recover from a 6+ turn spin in 1.5
turns from application of recovery inputs. Apparently the Aerobatic
"requirement" is that an aircraft recover in 1.25 turns, but Van decided
that the 1.5 turns was something they could live with.
When they tested the -6 with the -7 mods, it also recovered in 1.5
turns, so they figured they were okay. Now that they're testing the
real -7, though, they found that it takes almost 2 turns to recover from
a 6+ turn spin. Van decided that that was a little higher than he was
comfortable with, and that he would prefer to see a larger rudder, with
faster recovery.
So while the only issue is with the speed of recovery from spins, Van
will still be recommending that anyone who does not install the new
rudder placard the aircraft in such a way that Aerobatics are Prohibited.
The solution is a new rudder. It will be larger, like the -9. It will
also be of the -9 design, ie. the trailing edge is double-flush riveted,
and not folded (the two skins come together and sandwich a triangular
extrusion to keep the shape). It will be the only control surface on
the aircraft built in this manner.
Gus went on to say that they would be sending new tails to all -7
builders at no cost. I'll have to check on how easy it will be for me
to bring the new parts into Canada at "no cost", but...
-Rob Prior
rv7 "at" b4.ca
RV-7 Empennage (but haven't built the rudder yet... 8-)
Dwight Frye wrote:
> --> RV-List message posted by: Dwight Frye
> On Sun Jun 9 12:23:00 2002, Steven Eberhart wrote :
>>According to the Second Issue, 2002 RVator the spin tests performed
on the
>>RV-7 demonstrator meet FAA requirements for standard category
aircraft but
>>not for aerobatic category [:-(] THe article ended saying that they were
>>going to try a larger rudder. Guess the RV-9 rudder is larger than the
>>RV-7 rudder.
>>Wonder what Van's position is going to be on replacement rudders? THe
>>aerobatic capabilities was the main reason I chose the RV-7 over the
RV-9.
> I was in the Portland area last week, and (along with other activities)
> stopped in by the factory. Since the whole RV-7 rudder thing had been
> under discussion, I asked the guy at the factory what the deal might be
> and he filled me in on that details.
> They did the spin testing with the RV-9 rudder (which is definitely a
> larger rudder), and found that the spin characteristics were more to
their
> liking. He informed me that the plan was to ship ALL builders of
RV-7s new
> rudder kits, starting with folks who had already gotten their finishing
> kits (assuming they would be in the greatest need, and closest to flying)
> and then working down the list of builders until everyone had a
replacement.
> The intent (as I understood it) was to provide the new rudders free
of charge,
> and that there was no need to get on a list because they were going
to ship
> everyone a replacement automatically.
> Mind you, this is just what I was told verbally, and details _may_ change
> by the time they get an official announcement out. However, the
details as
> they were relayed to me sounded pretty firm.
> Given that the original rudder was not a _dangerous_ design, but simply
> not quite what Van had wanted to see in terms of spin behavior, their
making
> the choice to ship us all replacements is fantastic. Also, given that the
> don't recommend spins in the -7, (nor did they in the -6 either, and
never
> intended to recommend intentional spins) it could be argued that they
didn't
> need to go the extra mile on this issue. But, it seems they have made the
> choice to go that extra mile, and I for one, appreciate their commitment
> to providing the airplane we all expect ... even if there are bumps
in the
> road to achieving that.
> -- Dwight (old rudder parts on the shelf, working on elevators,
> with wing kit inventoried and shelved too ... )
Subject: | engine questions |
I have come across an engine/prop that may work with the -7a that I'm
building. I'm not engine literate at all and need help in the questions I
should be asking and getting a feel for the fair market value. Here's the
scoop
Engine is a IO-360 A3B6D TTSN 3016 TSOH 1141.5 came out of a money that
was up grading
Prop is a McCauley c/s new still in box.
Both were being set up for a GP-4 project before the owner passed away.
Logs are available.
Wayne in Southern Alberta
RV -7a fuse
Subject: | Re: engine questions |
On the engine, Van's has a list of engines that wont work/fit. It is a
angle valve head right?
The prop, I would call the manufacture because alot of props are aircraft
specific.
>scoop
>was up grading
>Logs are available.
>RV -7a fuse
Scott Bilinski
Eng dept 8220
Phone (858) 657-2536
Pager (858) 502-5190
Just a very minor thing about that engine model...
This might not apply, but if the engine was originally an A1B6D, you should
have the logbook entry which shows it was converted to A3B6D (re-indexing
the prop flange bushings) as per service bulletin M20-206. Not sure if
you'd ever need that proof, but it couldn't hurt to have it. Again, this
only applies if the engine was originally an A1B6D.
If you want a copy of the M20-206 service bulletin, here you go:
http://www.m20j.com/pdfs/service_bulletins/sbm20-206.pdf
A former Mooney owner...
)_( Dan
RV-7 N714D (tanks)
From: "Wayne Pedersen" <wayne(at)pedersentransport.com>
Subject: RV7-List: engine questions
> scoop
> was up grading
> Logs are available.
> RV -7a fuse
If it came off a Mooney, that McCauley prop is 99.9999% sure to be certified
for either the A1B6 or A3B6 series, D (dual single-drive mag) or not. That
McCauley prop tends to be quieter than the square-tip Hartzell in my
opinion.
)_( Dan
Subject: Re: RV7-List: engine questions
> specific.
I
> >scoop
that
> >was up grading
> >Logs are available.
> >RV -7a fuse
> Scott Bilinski
> Eng dept 8220
Subject: | Need Help Checking Out An RV7 Kit In Mississippi |
Is there anyone out there in Mississippi that could check out a
kit-in-progress for me? I'm trying to pick up an RV-7 project, but
cannot get there to check it out beforehand. I'd rather not buy it
COMPLETELY sight-unseen. Having another builder look it over first
would really help out.
We're arranging delivery for the weekend of June 22, so I'd like to get
it checked, say, before the 18th or 19th. Any help would be GREATLY
appreciated.
Any other ideas would be appreciated as well. (No digital camera
available)
-Vince
Vince Orton
About to start an RV-7A ...
Subject: | Re: protective barrier skin cream? |
> Gloves in a Bottle?
> West Systems 831?
> Debba?
> )_( Dan
> RV-7 N714D (tanks)
Hi Dan
I used rubber gloves with some solvent in a can to clean the rubber gloves
off when they got full of pro-seal. What's fun is when you go to get a rivet
and about 20 rivets stick to your finger. If you get some on your hands it
will come off. Scott Trask
No need to rely on hearsay. If you haven't see the service bulletin, go here:
http://www.vansaircraft.com/public/notices.htm
Dan,
I just used cheap disposable plastic gloves. When rivetting they have a life
of about 30 minutes at which point I chuck them away. Proseal is like bad
news and taxes, it penetrates into places you cannot imagine.
Have fun, David Francis, VH-ZEE, wings finished, fuselage growing in the
bank account.
Subject: Re: RV7-List: protective barrier skin cream?
> )_( Dan
> RV-7 N714D (tanks)
Hi Dan
Subject: | [ Fabian Lefler ] : New Email List Photo Share Available! |
Poster: Fabian Lefler
Subject: Compressor-Tool Bench
http://www.matronics.com/photoshare/FLEFLER@broward.org.06.13.2002/index.html
Subject: | List Browsing Feature! |
Dear Listers,
I thought I'd post a little reminder to everyone about a very slick feature
of the email Lists here at Matronics. You can now use Netscape or Internet
Explorer to browse the current messages on your favorite List! The List
Browse Function tracks the current 7 day's worth of List messages for any
given List. Indexes are updated every 30 minutes with new messages that
have been posted. You can resort the message indexes by Thread, Subject,
Author, or Date and easily track and find current threads.
A number of List members have written to say that they love the List
Browser because they can keep tabs on the latest List messages throughout
the day without having to constantly check their email or wait for the
Digest issue to come out.
You can check out the List Browse Feature by going to the following URL and
clicking on the List of your choice:
http://www.matronics.com/listbrowse
Enjoy!
Email List Admin.
Subject: | XDP4000X-List: unhappy |
All-
I hooked up my xdp-4000x and it sounds like crap. I ordered the necessary cable
from online and tried to tune it, but it just got worse. Is there something missing
htat I need to do to get it to work. When I bypass it with rca splitters
the res of my system works like a charm. I have the 6001ES running three 10'
ES subs. Then 2 1805 ES's handling everything else. Aside from the problems with
the 4x, there is a huge disparity between cd volume and radio volume. I mean
huge!!!. I can max out radio volume and it sounds ok, then pop in a cd and
half way blows mee out of the cab. Any ideas, I anm just so dissapointed right
now....
Reply-To: xdp4000x-list(at)matronics.com
To: Email-Lists(at)matronics.com
Subject: XDP4000X-List: List Browsing Feature!
Date: Fri, 14 Jun 2002 00:52:33 -0700
-- XDP4000X-List message posted by: Matt Dralle
Dear Listers,
Enjoy!
Email List Admin.
Subject: | Re: RV7-List Digest: 10 Msgs - 06/13/02 |
I would like to invite all RV builders, flyers and Enthusiasts to our November
15-17 Fly-In!! I am hosting this event in the name of FUN!! The host airport
is Galveston, Texas at the Lonestar Flight Museum.
Come join the fun and enter the show. Local EAA chapters will be making Young
Eagle flights throughout the day. Phillips 66 fuel rebates and local fuel pricing
will be in effect for all flyers.
Saturday night we will host a banquet inside the Lonestar Flight Museum. Nothing
better than dancing the night away with history surrounding us.
For more information and a list of all the historic tour sites, please view our
website.
http://www.davidawilks.com/fly-in
Hope to see you there!!
David Wilks
832-282-4004
Subject: | Re: Need Help Checking Out An RV7 Kit In Mississippi |
I live in Pass Christian Mississippi on the Gulf
Coast. If I can help Vince Orton check on his kit
please e mail me directly.
> check out a
> RV-7 project, but
> rather not buy it
> look it over first
> so I'd like to get
> would be GREATLY
> appreciated.
> digital camera
> available)
> Thanks,
> -Vince
> Vince Orton
> Contributions of
> any other form
> latest messages.
> other List members.
> http://www.matronics.com/subscription
Henry W. Kinney
4395 Menge Ave.
Pass Christian, Mississippi
39571
Subject: | Wing skin scarf joint |
I've read the archives about how to file down the top wing skins to flatten
the overlapping scarf joint...and the only thing I came up with was either
using a bastard file or a 5" disc sander. But it doesn't say which
surface(s) to file...
Can somebody who has does this successfully give me some advice on this
process? I'm curious if I should file the underlapping skin only on the
top, and file the overlapping skin only on the bottom, etc. Kind of
curious...I'm probably over-thinking this, but I'd love some feedback.
)_( Dan
RV-7 N714D tanks
Subject: | Re: Wing skin scarf joint |
Dan
I shaved, I guess is the proper term, Both of the
skins the top of the bottom one and the bottom of the
top skin that overlaps about 2 inches wide and 5 or 6
inches down the joint.
I used a heavy rasp or file then sanded and scotch
bite to smooth it back up.
This is just to get a better airflow over the leading
edge of the beginning of the joint.
Its not very scientific as to how much.
I just cut some til it looked good.
I would stay away from the power tools.
there will still be a slight mismatch. Only way to
get by this is to use a one piece top skin.
cary rhodes
fuse
> doesn't say which
> some advice on this
> love some feedback.
> )_( Dan
> RV-7 N714D tanks
> Contributions of
> any other form
> latest messages.
> other List members.
Subject: | tank cradle orientation while riveting |
I want to get some advice on riveting the tank ribs. What's the most ideal
way of orienting the cradle while riveting?
With the leading edge (riveting from trailing to leading edge), it was
easy...I screwed it down vertically (normal) to my bench, we riveted from
the trailing edge "forward" (down), and when we got to where the curve was
too sharp for the rivet gun to have decent access (after having riveted most
of both sides), I took the ldg edge out of the cradle and laid it down flat
on the bench, riveting the rest with the ldg edge horizontal and "free".
Since the tank ribs are supposed to be riveted from the leading edge to the
trailing edge, I can't do that...gotta start with the tough access angle.
What do you guys recommend to make this easier? Use a cradle "tall" enough
so that even when screwed down you have decent access to the leading edge
rivets?
Just curious,
)_( Dan
dan at rvproject . com
Subject: | flop tube anti hang-up strips |
Today I tried to determine if the flop tube anti hang-up strips are really
necessary as Van's plans very vaguely suggests. I attached the flop tube
and rotated the tank around, trying to get the tube to get hung up. As hard
as I tried, the tube wouldn't get caught anywhere, and it definitely doesn't
go anywhere near the trap door.
I riveted a "chafe strip" over the inspection hole, but that's all I'm
planning on doing.
Pictures of my trials and tribulations:
http://www.rvproject.com/20020627.html
Can anybody corroborate this approach? Or, if you have a good reason why I
should do anything additional (like the little diagonal stiffener to 2nd rib
strip that the plans "hint" at), please let me know before I start
sealing/riveting ribs... 8
)_( Dan
RV-7 N714D (tanks)
Subject: | Autopilot for RV6A |
I am seeking opinions on two-axis autopilots (roll & pitch) for an
RV6A. I have looked at the S-Tec and TruTrak systems. Both are
costly. Are there other two-axis autopilots which are less expensive
and work well? I have also looked at the Navaid which is a single axis
(roll) unit. It is reasonably priced for single axis unit. Does anyone
have experience with the EZ-Trim pitch control unit? Perhaps it could
be used with the Navaid to give 2 axis functionality?
Roger Crandell
Subject: | Re: Autopilot for RV6A |
You could make your own using gyro's and servo's from R/c airplanes. The
airplanes known as "Scale Models" have devices that would work. I have a
freind in my EAA chapter building a sonex doing what I just told you but he
knows how to program it etc... IF you woudl liek I could have him e-mail
you.
Justin
Subject: RV7-List: Autopilot for RV6A
> Roger Crandell
Subject: | tank cradle orientation while riv |
eting
Dan,
You only need two supporting female rib shaped supports for the tank. Clamp
them to two saw horses. Put the tank in nose down and move the two saw
horses around to get access to the lines of rivets as required. Its easy.
Start from the middle rib and move outwards. Think out the access sequence
carefully becuase you still need to run the vent line before closing the end
ribs.
Think carefully about the sequence for the nose reinforcements for the two
outer ribs. Also also think the sequence for the tank filler.
Have fun with the proseal.
Regards, David Francis, Canberra Australia.
RV7and7A(at)yahoogroups.com
Subject: RV7-List: tank cradle orientation while riveting
rivets?
Just curious,
)_( Dan
Anyone ever consider putting the landing lights in the lower engine cowl
instead of the wing? I'm just thinking about it and if anyone else has done
it or tried I'd like to hear their thoughts. My Cessna has them there and
they work fine.
canopy N557RV
From: | "TruTrak Flight Systems" <info(at)trutrakflightsystems.com> |
Subject: | Re: Landing lights |
We (TruTrak flight systems) have an RV-9A, and our landing light is in the
lower left cowling. Seems to work great.
Subject: RV7-List: Landing lights
done
> they work fine.
> John
> canopy N557RV
John,
Putting lights in the engine cowl is not regarded well my maintenance folks.
Cessna and Piper do it, and are not thanked for the outcome. Consider:
a. vibration and heat of the engine bay shorten the life if the fragile
light filament.
b. every time you take the cowls off you have to make and break an
electrical connection for the power supply, and because the cowl is
fibreglass, another for the ground.
c. the light takes up space in a closely cowled engine space.
d. you will have to make up your own mounting bracket on surfaces which bend
in 3 dimensions, in contrast the Duckworks kit has already solved the
mounting problem for you.
David Francis, Canberra, Australia, VH-ZEE, with lights in the wing tips.
they work fine.
canopy N557RV
Any suggestions on how to make the F 715 rib follow the contour of the
bottom skin. Seems to want to buckle on me.
RV 7a Fuse
Mark a center line on F715. Then flute as needed and it will fit. That is
how I did it.
Larry in Indiana
Subject: RV7-List: F 715 fit
Subject: | Four New Email Lists At Matronics!! |
Dear Listers,
I've just added four new email Lists to the current lineup at
Matronics. These new lists include:
KRNet:
krnet-List(at)matronics.com The RANS KR1 and KR2 Series
Cub:
cub-List(at)matronics.com The Piper J-3 Cub
RV10:
rv10-List(at)matronics.com The New 4-place RV from Van's!
Europa:
europa(at)matronics.com The Slick European Composite
All the usual features are available with the new Lists including the
search engine, archive download, 7-day List browse, and PhotoShare!
To sign up for any or all of the new lists, please go to the List
Subscription page and put in your email address and select the Lists of
your choice. The URL for the Subscription page is:
http://www.matronics.com/subscibe
Don't forget that its your posts that generate traffic on the respective
Lists! Post an introduction and a description of your project or dreams!
Best regards,
Matronics Email List Admin.
Subject: | [With Good URL This Time!] Four New Email Lists At Matronics!! |
[Typo in the subscribe page URL last time - SORRY! -Matt]
Dear Listers,
KRNet:
Cub:
RV10:
Europa:
http://www.matronics.com/subscribe
Best regards,
From: | "Phil Birkelbach" <phil(at)petrasoft.net> |
Subject: | Floor Stiffeners |
I am about ready to install the floor stiffeners in my RV7. There is an
offset pressed into one end of the stiffeners that I received in my kit. It
seems that this end goes toward the firewall (as best as I can tell anyway).
Do I need to put this little offset in the other end of the stiffener and if
so how is the best way to go about it? If not how do I attach the
stiffeners to the F-704 bulkhead without there being a big gap between the
stiffeners and the bottom skin?
Godspeed,
Phil Birkelbach - Houston
RV-7 N727WB (Reserved)
http://www.myrv7.com
Subject: | Re: Floor Stiffeners |
I installed shims b/t all 772B and 772 skin in first hole nearest 704 blkhd
to smooth the transition. I also installed a shim b/t 601J and 772B-R/L to
make that solid. Larry in Indiana
It
anyway).
if
> Godspeed,
I have been a LURKER! I admit it. But I have now completed a milestone
and wish to come out of the hanger. My Horizontal Stabilizer is hanging
on the wall.
The VS is in the jig and I will rivit skins today. Maybe I really can
build an airplane.
Marty Kwitek
Green Bay, WI
Emp - VS
Subject: | [ Patty Gillies ] : New Email List Photo Share Available! |
Poster: Patty Gillies
Subject: Fuel Selector Plate (labeling)
http://www.matronics.com/photoshare/gillies-patty@sc.edu.07.07.2002/index.html
Subject: | DON'T DO THIS! (and a fuel drain question) |
First the fuel drain question...I installed the drain in my first fuel tank
by basically tightening the crap out of it. It still stands out more than I
would have expected:
http://www.rvproject.com/images/20020708_drain.jpg
Is this normal? I assume so, but let me know so I can sleep better. Ok,
now for the "DON'T DO THIS" column for the day.
I'm installing flop tubes in my tanks, and a few weeks ago I fabricated and
drilled the attach angle for my first tank. The plans didn't really say
much about the flop tube installation or where exactly to drill the six
rivet holes to attach the angle to the inboard rib. The plans just kind of
*suggest* where they should go. So I drilled 'em where it looked right, and
where it looked like there was good clearance and all that.
Well, today I went to actually rivet and seal the sucker on there, and check
out what I found:
http://www.rvproject.com/20020708.html
The rivets totally interfered with the flop tube fitting nut! Dang! Well,
I thought I was going to have to leave those holes and drill two new ones,
just filling the gaping holes with Proseal. That would suck. I'm sure it
would seal, but it would be ugly and lurking in the back of my mind.
But after a few minutes of cursing and brainstorming, I realized that I
could countersink those holes and use AN426AD4-7 flush head rivets in
there...and that's what I ended up doing. It all worked out, but the moral
of the story is:
TAKE CARE when drilling those rivet holes!!! Think before you drill!
Ok, enough from me...
)_( Dan
From: | "Heinrich Gerhardt" <hgerhardt(at)earthlink.net> |
For sale: Van's (Vetterman) exhaust system for RV-7/7A with IO-360 200HP.
Brand new. Bolted it up to my engine and found it hits the cowl. (I'm
building a -6 with IO-360.) Van's is backordered right now, and I'll sell
you mine for what Van's sells it for ($720), but with free shipping.
Subject: | Re: DON'T DO THIS! (and a fuel drain question) |
Hi Dan
I didn't like it on my ether. What I did I ran a pipe tap through it, cut
the threats a little deeper. Just make sure that your starting from the
right side. I almost made that mistake. Had it in the vise started to tap it
from the wrong side. But I stop before I when to deep.
Scott Trask (fuselage) IMT
Subject: | Fuse Jig for RV-8 |
I have a good fuse jig which has now built 2 fuse's. It has been cut in
half for easy moving and set up to be bolted back together. it will now
eaisly fit into the back of a pickup. I am located in San Diego, anyone
interested let me know.
Scott Bilinski
Eng dept 8220
Subject: | [ Bob Paulovich ] : New Email List Photo Share Available! |
Poster: Bob Paulovich
Subject: Fatal RV Crash
http://www.matronics.com/photoshare/Bobpaulo@aol.com.07.12.2002/index.html
Subject: | Re: Fuse Jig for RV-8 |
Scott,
How was building the fuse? Would you say the jig is necessary, just
helpful, or irrelevant? I was planning on using sawhorses since that's what
I heard works with the RV-7 fuse, but I'm curious what your thoughts are.
Did you end up settling on a powerplant? Sounds like you'll be flying soon
if you're already finishing.
)_( Dan
Subject: RV7-List: Fuse Jig for RV-8
> Scott Bilinski
> Eng dept 8220
OOOps. Posted to the 7 board should have been to the 8 board.
Other than that I like the jig because it is very solid and nothing is
going to move. On the 7 I have no idea. Should be flying the first quarter
of next year. Power plant O-360-B1B with 9:1 pistons dual electroinc
iginition and Air Flow Performance injection with Superior Air parts Sump
for better flow, and its tuned. 200 HP I hope.
>Scott,
>)_( Dan
>From: "Scott Bilinski" <bilinski(at)qcpi.com>
>To:
>> Scott Bilinski
>> Eng dept 8220
Scott Bilinski
Eng dept 8220
Somebody on a local email list was looking for a detail about a particular
model Lycoming engine. That got me thinking about this and I downloaded the
TCDS from the FAA for the most common certified engines and props for RVs.
In case you need more specs than you know what to do with, I figured I'd
forward this link to some of the "big" lists:
http://www.rvproject.com/tcds/
Enjoy...
)_( Dan
RV-7 N714D (wings)
Subject: | Matchdrill hole question |
I just finished "drilling the HS" section. I noticed one area where matchdrilling
didn't work out perfectly. Not bad, but I want to know of others experienced
the same outcome after clecoing stuff together.
Please refer to this photo: http://mywebpages.comcast.net/jgburns/emp_HS_right_drilling_complete.html
Note the cleco installed in the matchdrilled hole that goes through HS-405 and
HS-702 (rib and front spar respectively). The matchdrilled hole through the 601PP
skin ended up within a 1/2 diameter of the flange edge in HS-405 (aft) rib.
I think this was the case for the left HS assembly, definately on the right
side as you may be able to see (I didn't take this photo with that concern in
mind, but show my progress).
Anybody else out there notice that?
Hi John,
This sort of mismatch does occasionally occur. Things to look for if you
spot it - is the piece straight and well supported? Can some fluting cure
it? Are the flanges at 90 degrees to each other, a bend might fix it.
I spotted this problem trying to fit a wing skin to the wing frame. After a
lot of head scratching and threats to use a mechanical persuader I woke up
that the jack stopping the wing from sagging had backed off. Easy to fix,
felt like a dummy, but nobody was watching.
Riveting pulls things together with high pressure, you can simulate this by
using wingnut clecos. These things grip like a randy whatsit on Saturday
night. If all else fails and a normal sized drill gives an oval hole, then
start drilling oversize. A little bit oversize, use a longer rivet and
fatten it up in a squeezer to prevent bending, insert and drive it. If you
need to go bigger to get a round hole, then go up to the next size rivet.
If the problem is a hole too close to an edge, as long as surrounding rivets
are all acceptable, then accept it. If there is room you can choose to
reinforce it by installing an additional rivet either side to take the load
and reduce the propensity for the edge rivet to put a crack in the flange.
These structures are remarkably robust when riveted. Thats why we are still
using this method after 70 years of development.
Hope this helps, David Francis, VH-ZEE, wings finished, fuselage growing in
the bank account.
-----Original Message-----
Subject: RV7-List: Matchdrill hole question
matchdrilling didn't work out perfectly. Not bad, but I want to know of
others experienced the same outcome after clecoing stuff together.
Subject: | AEIO-360-A1E6 vs. IO-360-A1B6 |
Brand new 200hp AEIO-360-A1E6 from Aircraft Spruce = $28,995
Brand new 200hp IO-360-A1B6 from Van's Aircraft = $31,300
Hm...can any experts out there tell me what the major differences are?
Engine mount compatibility? Is there anything about the AEIO that's
generally a negative attribute for normal, non-aerobatic operation?
)_( Dan
RV-7 N714D (wings)
Don't know about technical differences. But do you have to pay state
taxes if you buy an engine from Van's (Oregon) as opposed to Aircraft
Spruce? I'd like to know the answer to this one myself. Anybody?
Pete Krok
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Dan Checkoway
Subject: RV7-List: AEIO-360-A1E6 vs. IO-360-A1B6
)_( Dan
RV-7 N714D (wings)
Subject: | RV-10/11 Oshkosh Update |
Was anyone at the Oshkosh forum this past Thursday and have any additional
info on the RV-10?
Bret Smith
From: | "Brooks Wolfe" <slipstream13(at)earthlink.net> |
Has anyone put together a spreadsheet of the RV-7's bag contents? I had
a
look at the 1998 version, which doesn't track with what I'm looking at now.
In the meantime, I'm getting started on the wing and any tips on sorting
out
the platenuts would be greatly appreciated.=0D
=0D
Brooks
In a message dated 7/27/02 11:56:18 PM, rv7-list-digest(at)matronics.com writes:
<< Don't know about technical differences. But do you have to pay state
Oregon doesn't have a sales tax (yet), but if you live in a state that does,
like CA or WA, you probably would be liable for taxes in that state on the
item. You would report it wouldn't you??? heheheh...
Jerry Cochran
Wilsonville, OR
RV6a finish kit
Subject: | Re: Tax on Lyc 360 |
Actually, sales tax is collected by companies doing business in a state
and selling to another address within the same state. Unless the company
is registered to do business in another state, sales tax collection (if
any) is limited to instate sales.
If a company is registered to do business in Washington AND California,
then sales tax would be collected for any sales to either a WA or CA
address.
Don
AZ
> Jerry Cochran
> Wilsonville, OR
> RV6a finish kit
From: | "LarryRobertHelming" <lhelming(at)sigecom.net> |
Subject: | Re: Bag Contents |
Try this:
RV7 Fuselage Hardware Bags Parts List January 11,2002
Bag Part
1952 an426ad3-3.5
1953 an426ad3-4
1954 an426ad3-4.5
1955 an426ad3-3.5
1956 an426ad4-5
1957 an426ad4-6
1958 an426ad4-7
1959 an470ad4-4
1960 an470ad4-5
1961 an470ad4-6
1962 an470ad4-7
1963-2 LP4-3
1963-2 MSP-42
1963-2 CS4-4
1964-1 K1000-08
1964-1 K1000-3
1964-1 K1000-4
1965 ms21051-L08
1965 ms21051-L3
1965 mk1000-428
1966 AN818-4D
1966 AN819-4D
1966 AN822-4D
1966 AN832-4D
1966 AN833-4D
1966 AN837-4D
1966 AN924-4D
1966 AN816-6D
1966 AN818-6D
1966 AN819-6D
1966 AN822-6D
1967 bushing sb437-4
1967 bushing sb500-6
1967 bushing sb625-7
1968 an507-6r6
1968 an509-10r12
1968 an515-8r8
1968 an526C832r8
1968 screw 5/16-20X1 1/2
1969 AN3-4A
1969 AN3-5
1969 AN3-5A
1969 AN3-6
1969 AN3-6A
1969 AN3-7
1969 AN3-7A
1969 AN3-10A
1969 AN3-11
1969 AN3-11A
1969 AN3-13A
1969 AN3-22A
1970 AN4-4A
1970 AN4-6A AN4H6A
1970 AN4-7A
1970 AN4-10A
1970 AN4-12A
1970 AN4-16
1970 AN4-25A
1970 AN4-27
1970 AN5-22A
1970 AN23-10
1970 AN5-10
1971 AN365-832A
1971 AN365-1032
1971 AN365-428
1971 AN365-524
1971 AN316-4R
1971 AN316-5R
1971 AN316-6R
1971 AN310-4
1971 AN363-420 NUT 1/4-20 SL
1971 MS21042-3
1971 AN310-5
1971 AN310-3
1972 MD3616M BEARING
1972 M3414 BEARING
1972 F3514M BEARING
1972 CM-4M ROD END BRNG
1972 VA-101
1972 AN490HT11P-SDM 0.634
1972 VA-146
1973 AN931-4-12
1973 AN931-6-16
1973 AN960-8
1973 AN960-10
1973 AN960-10L
1973 AN960-416
1973 AN960-516
1973 AN970-4
1973 AN960-416L
1973 WASHER 5702-95-30
1973 WASHER 5702-75-60
1974 MS21919DG4
1974 MS24665-132
1974 MS24665-208
1974 MS21919WDG6
1975 F 63-PT3-25
1975 F 69-N-04X02
1975 F 271-N-04X02
666 F-6116
666 F-680
670 VA-107
487 Fuel Valve V407P
487 f 1/4 pipe plug
665 F-6115
673 F-636
833 AN426AD3-8
QP 1948 an4-34a
807 AN426AD4-5
404 AN470AD4-4
405 AN470AD4-5
421 AN426AD3-4
422 AN426AD4-4
428 AN470AD4-7
468 AN426AD3-3.5
477 AN470AD4-6
479 AN470AD4-8
480 AN470AD4-9
683-1 AN426AD3-6
685 AN426AD4-5
687 AN426AD4-7
829 AN426AD3-4.5
830 AN426AD3-5
836 AN426AD4-6
838 AN426AD4-8
1942 K1000-08
1943 K1100-06
1943 K1000-4
1944 MS21051-L08
1945 SB625-7 BUSHING
Q 1948 AN4-13A
Q 1948 AN3-12A
Q 1948 AN4-4A
1946 AN509-8R8
1946 AN509-10R12
1946 AN515-8R8
1947 AN3-5A
1947 AN3-6A
1947 AN3-10A
1947 AN3-12A
1947 AN3-22A
1949 AN365-832A
1949 AN365-1032
1949 AN365-428
1950 AN960-8
1950 AN960-10
1950 AN960-416
1950 AN960-10L
1951 MA21919WDG6 AN742-6 REPLACES
1981 F-601C-1
1981 F-601F-1
1981 F-601G-1
1981 F-601H-1
672-PC F-634-L-PC
672-PC F-634-R-PC
1982 AB4-250X1 1/2X2 ALUM BAR
1982 AS3-063X0.625X3 ALUM SHEET
1982 AS3-125X0.75X4.25 ALUM SPACER
832 AN426AD3-7
QP 464 AN426AD4-11
QP 457 AN426AD4-14
699 AN4-6A
699 AN4-7A
699 AN960-416
699 AN365-428
1923 CM-4MS BEARING
1923 AN936A416
437 LP4-3
1980 AN526C832R8
1980 AA3-032X3/4X3/4X2 ALUM ANGLE
926-1 w/elec flap sub-kit
926-1 AN515-8R8
926-1 K1000-08
926-1 AN4-10A
926-1 AN4-21
926-1 AN3-22A
926-1 AN310-4
926-1 AN365-1032
926-1 AN365-428
926-1 AN960-416
926-1 AN960-10
926-1 MS24665-208
926-1 AT6-058X3/8X2
926-1 AA6-063X3/4X3/4X6
926-1 EF-603
926-1 EF-604
926-1 AB6-125X1X3
926-1 AA6-125X1X1X2
926-1 ES S338T
926-1 ES DVI8-188B-M
926-1 F-661EF
926-1 AN365-832A
926-1 ES 36152
422 AN426AD4-4
832 AN426AD3-7
1990 CS4-4
1990 K1000-08
1990 SB500-6 BUSHING
1990 AN509-8R8
1990 AN526C832R8
1990 AS3-063X3X3
1990 VS-411PP-PC
1991 AN3-5A
1991 AN4-10A
1991 AN365-1032
1991 AN365-428
1991 AN960-10
1991 AN960-416
496 AN960-616
496 AN6-30
496 AN310-6
496 MS24665-300
497 AN4-14A
497 AN365-428
497 AN960-416
489 VA-105C
489 VA-105B
489 VA-105A
From: "Brooks Wolfe" <slipstream13(at)earthlink.net>
Subject: RV7-List: Bag Contents
> Jerry Cochran
> Wilsonville, OR
> RV6a finish kit
> Hi
Taxes, if you live in a state that has sales tax they will get you. I
live in MI it has a sales tax. My first plane I build after I N-numbered it
I got a letter from the state wanting me to produce sales slips for the
plane. If I didn't pay sales tax in this state or any other state I had to
pay the state the tax. So be as brief as possible when giving info on what
you bought. Maybe just keep the slip from Van's to show.
Scott Trask IMT
Subject: | Re: First Milestone |
Keep going Marty
Subject: RV7-List: First Milestone
> on the wall.
> build an airplane.
> Marty Kwitek
> Green Bay, WI
> Emp - VS
Tax: It all depends on the state. In my state (Vermont), you are
technically supposed to pay sales tax on anything you buy, whether it's
from catalog or even from the Internet. (Why this last is legal I'm not
sure -- I thought Congress banned Internet sales taxes.)
I haven't investigated how this all relates to homebuilding yet, but I
can imagine a worst-case scenario of buying your parts over a period of
years, getting audited by your state when you eventually register your
new plane, and getting nailed for back-taxes for those years you
_should_ have been paying.
Luck of the draw, perhaps.
Rick
RV-7 emp.
In California we have a use tax. Bottom line you are required to send in
the sales tax on ANYTHING purchased out side of the state. Just ask your
tax guy.
With that said, they only go after high dollar items. I will send in the
sales tax for the kit and the matter will be considered closed according to
the tax board. If you dont send it in they can catch up with you later and
you have to pay on the kit engine or? PLUS penalties.
>Rick
>RV-7 emp.
Scott Bilinski
Eng dept 8220
From: | Bob Collins <bcollins747_1999(at)yahoo.com> |
Subject: | Re: RV-10/11 Oshkosh Update |
I didn't get to the forum but I went to the dinner
Saturday night where a similar - if shortened
presentation was made. The most interesting part for
me (and I'm not going to build a 10) is that you'll be
building in modular form. Take the fuselage for
instance. Instead of having some big honkin' fuselage,
you'll build pieces of it, eventually connecting it
all together. Build a piece of it, put aside, build
another piece. Very helpful.
Also the current skin stiffeners willa ctually be
joined ribs, thus eliminating the manufacturing of
these little babies.
BC
> info on the RV-10?
> Bret Smith
> Contributions of
> any other form
> latest messages.
> other List members.
> http://www.matronics.com/search
http://health.yahoo.com
Subject: | prospective builders...tool run-down |
There's been a lot of talk about tools...what's required, where to get good
deals, etc. I finally got around to putting together a pretty comprehensive
page with tons of pictures and descriptions of the tools I use regularly.
http://www.rvproject.com/tools.html
I'm not in any way trying to endorse any manufacturers or vendors or
anything like that. I'm just trying to provide data points for prospective
builders. I hope somebody out there finds this useful.
)_( Dan
RV-7 N714D (wings...still!)
Dan Checkoway did an excellent job of describing and recommending
various tools to use in the build of an RV-7. Based on his
recommendations I started looking around for a pneumatic rivet squeezer.
They are expensive, but I noted that the Avery Tool price of $610.00 for
the pneumatic squeezer with the Longeron Yoke (P/N 7555) can now be beat
by a "Summer Special" that "Rivettools.com" is having. It looks like
they are selling the same setup for $455.00. Click on the following
address for more information: http://www.rivettools.com/
I got their web address from the Van's Catalog.
Pete Krok
pkrok(at)eee.org
Redlands CA
RV-7A Emp.
rv7-list(at)matronics.com
Subject: RV7-List: prospective builders...tool run-down
good
comprehensive
regularly.
prospective
)_( Dan
You can find these regularly on EBay for $280-300. That's where I got mine. Chicago
Pneumatic, with yoke...$285.
Kevin
[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Peter Krok
Subject: RE: RV7-List: prospective builders...tool run-down
Pete Krok
pkrok(at)eee.org
Redlands CA
RV-7A Emp.
good
comprehensive
regularly.
prospective
)_( Dan
Subject: | Question on Primers |
Some of the guys building aircraft in my local area are simply using TSP
to prep the aluminum before priming. That's all they use, i.e., they
don't use Alumiprep No.33 or Alodine No. 1201 before priming with the
AKZO 2-part Epoxy primer at $93.50/gal from Aircraft Spruce.
For the priming they are using the following 2 NAPA brand products (from
the auto-paint store).
Econo-Etch Etching Primer (P/N 15210) at $47.69/gal, and
Econo-Etch Etching Primer Reducer (P/N 15213) at $24.09/gal
The primer and reducer are mixed 1:1 and the end color is the same green
primer color we are used to seeing. They say they've been getting good
results.
Question 1: Is TSP sufficient in most cases, i.e., where the aluminum
is almost factory fresh with little or no corrosion? . or is the
general recommendation to use Alumiprep No.33 and Alodine No. 1201 on
all parts before priming?
Question 2: Have any other folks out there had any experience using the
NAPA 2-part primer?
I'm just getting started. I want to do a good job, but I don't want to
do the overkill business. NAPA's just down the block, more convenient
and less expensive. I certainly don't mind going to Aircraft Spruce if
there's a significant difference in the outcome.
Thanks for your replies. Since my question is rather lengthy, please
don't forget to "SNIP-SNIP" my e-mail from any replies you are kind
enough to send.
Pete Krok
pkrok(at)eee.org
Redlands, CA
RV-7A Emp
Subject: | Re: Question on Primers |
IMHO unless you park your plane very near the ocean you will never see the
difference, my 1956 182 has next to no corrosion and no primer anywhere
except on repairs I have done. Alodine is an acid conversion treatment that
etches the surface promoting adhesion of the primer. It is redundant with an
etching primer. I'm using alodine/AKZO on the non alclad spars and
structural parts and a Sherwin-William self etching primer on the clad
stuff.
Neil McLeod
7QB fuselage installing systems
Subject: RV7-List: Question on Primers
> results.
> NAPA 2-part primer?
> enough to send.
> Pete Krok
> pkrok(at)eee.org
> Redlands, CA
> RV-7A Emp
Subject: | Edge distance fix for the HS-405 Flange |
I'm just getting around to dimpling the spars and ribs for the HS stabilizer.
Per a previous posting, I noticed that the pre-punched (skin) holes that determine
the hole location for HS-405 (flange) puts it right on the flange edge.
The joggle in flange allows HS-405 to fit in between the front spar flanges.
When Van's a/c programmed the hole location in the CNC machine this was probably
overlooked.
My fix was to make four backer plates out of 0.032 Alclad. I'll drill one hole
in each backer plate to cleco it in place. I'll drill the other hole when I'm
riveting the HS together.
See the photos for more information.
http://mywebpages.comcast.net/jgburns/Empennage_2.html
A few builders already responded. They ignored it, but I thought it would be good
experience to make a few custom pieces.
John Burns
Albuquerque, NM
Subject: | RV7 Tip Up Question |
F721B canopy deck was predrilled and positioned on F718 longeron during
longeron preparation. Now, several months later, when fitting F757T gusset
(having fabricated it with square hole cut out per plans dwg 18 and 25 for
tip up) between F721B and F718 and positioning it with hole impressions
(which seem to be for alignment and positioning purposes), I find the square
hole is partially covered by aft edge of F721B. It is possible I cut F721B
for tip up incorrectly months ago but I can't verify that due to lack of
measurement data from leading edge of F721B. As I measure F721B from top of
horizontal surface from end to end after being trimmed per instructions for
tip up, it is 28 7/8" long. I could use a verification of this from
someone.
In addition, the slot cut and extended in F721B needs extending more about
1/2 inch to get it to fit with F757T. Looks like I could shorten F721B at
aft end by the 1/2" to get this step to fit. Just wondering, if anyone
else had this problem shortly after turning the fuselage upright?
It was nice to meet several of you at the gathering under the tallest of
trees at Oshkosh. I want to second what someone else posted recently on the
nice work that Steve Eberhart has done with the RV7 (tail wheel model) R/C
plane. I hope he continues to develop this and other non-flying models of
the 7/7A. I know I'd like to have one that looks just like my real plane
when I get it done and painted.
Larry in Indiana, working on RV7 fuselage
Subject: | Scotchbrite wheels and drill motors |
Listers,
I fear I'm beating a dead horse, but saw nothing to answer this question
in the archives. My 1" Scotchbrite wheel is too wide for my grinder,
and the housing is built in such a way that there's no way to make it
work. I'd rather not buy another grinder, so I am looking for other
ways to do this.
I have a spare drill press. Is that an option? Can you find arbors big
enough?
While I'm airing my ignorance, I also see mention of using a drill
motor. What, exactly, is a drill motor? Looking at Avery and Brown,
drill motors look much like power drills to me -- well, some do, anyway.
I assume that putting the wheel into a drill motor would give me a
handheld Scotchbrite wheel. Do people find that desirable?
Thanks.
Rick McCraw
RV-7 emp (just beginning; can you tell? :-)
Subject: | Re: Great site Dan! |
> Question: what process do you follow that has worked for you to prepare
the
> Aluminum before you shoot the AKZO primer? MEK, Alodine? Do you also
shoot
> the skins since they are alclad?
I'm copying the lists just in case this is of value to anybody.
I'll answer these questions in reverse order...nope, I don't shoot the
insides of skins. You might think I'm nuts, but I believe the Alclad, if
kept unscratched (worth all the trouble with the soldering iron to
strategically leave on patches of blue plastic while working with the
skins), will last a good long time before any corrosion forms. I prime
anything which has been scratched, filed, extruded, or bent (notice how
Alclad thins in bent areas, like on rib flange corners?).
In answer to "MEK, Alodine?" I don't believe Alodine will be effective on
Alclad, even if you clean it with MEK. I'm pretty sure Alodine only works
effectively on raw aluminum. So I "etch" the parts first.
Here's what I do as the full priming process...this process is what was
recommended to me and I'm convinced it's the best way to go. I apologize if
anything in here is way too detailed (like "transfer the primer into your
gun"), but you never know. Some people like lots of detail...
1) Set up hangers for all the pieces you'll be prepping. Not necessarily
hangers where the parts will get sprayed, but where they can dry during the
prep process. I usually use a bunch of pieces of stripped strands of 12
gauge (or whatever) Romex, which holds its shape nicely when bent and fits
through #30 holes no problem:
http://www.rvproject.com/images/20020719_hanging.jpg
Sometimes I just hammer some nails into a 2x4 clamped across whatever:
http://www.rvproject.com/images/20020508_hanging2.jpg
Other times I just use nails in the edge of a bench:
http://www.rvproject.com/images/20020809_stiffeners_hanging.jpg
2) Set up the prep area...I have a drain in the driveway just outside my
garage. Don't even tell me how horrible it is to let chemicals wash into
ocean...I feel bad enough about it already...I just try to minimize the
amount of chemicals I drain. I've pretty much accepted that during the
building process I'm contributing to the demise of the environment. Ok,
guilt trip aside...anyway, I bring a hose over for rinsing. Get a little
stool or something to sit on to make your life a little easier. Get a
maroon Scotch Brite pad (7447 or whatever). Wear full cover, a respirator,
saftey goggles, and rubber gloves. I want to take no chances with Alodine,
a chromic sure to cause nasty health problems.
3) Dilute Alumiprep in a spray bottle according to the instructions. Take
each part, spray it down with the Alumiprep solution, and scrub the bejezus
out of it with the Scotch Brite pad. There's nothing like the look of RAW
aluminum. It has that dull smooth character once the Alclad has been
stripped off. Get the edges, too. Don't let the Alumiprep dry, do one side
or portion at a time if you have to. Rinse the part off thoroughly when
you're done and hang it back up.
4) Put a small bit of Alodine in a cup and get a foam brush. Somehow brush
the Alodine onto the parts. My technique varies here...I used to brush it
on while the part was hanging but that's kind of silly since the stuff runs
right down and drips off, and having to raise your arm to brush it on you're
likely to get Alodine running down the glove and on your sleeve, increasing
the chance of contacting that nasty crap. Lately I just lay the parts down
horizontally on a cardboard box or a chicken wire mesh and brush the Alodine
on there. I believe the BEST way to Alodine stuff is in a dip trough,
though (although I never do it). That ensures the best consistent coverage
and gets you that nice gold finish...but it takes FAR more Alodine to do
that. I've seen people design all sorts of recycling methods for Alodine,
and that's a good way to go if you want to put the extra effort in. I've
also seen people fill a PVC pipe with Alodine in which you can soak long,
narrow parts like stiffeners without using as much. But for larger parts
like spars and ribs, I'm not about to fill a huge bucket full of Alodine if
you know what I mean. I'm satisfied with the level of conversion that
brushing on and using very little Alodine provides. To each his own here.
Anyway, let the part sit/soak/brush for 3 minutes or whatever the
instructions say, and then thoroughly rinse the part off and hang it up to
dry FULLY. It's at this phase where nothing should touch the part,
especially not oily fingers. Use latex/rubber gloves when handling the
parts between now and spraying.
5) Once everything is dry, get it into position for priming. I don't have a
consistent way of doing this. Sometimes I lay stuff across chicken wire,
sometimes I spray it while hanging, sometimes I lay it out on a dust-free
surface. Whatever works for you.
6) Mix up the primer. My understanding (and this could be COMPLETELY wrong)
is that there's a 30-minute "induction" period for AKZO...and my
interpretation of that is that you mix one-to-one of the green stuff and the
catalyst, and then you let it sit 30 minutes while it does its chemical
thing. I mix it every 5-10 minutes or so during that process with one of
those drill-mounted stirrers. I'm guessing that the 30-minute thing is
either wrong or unnecessary, but who knows. I'm not a chemist, but it has
worked like a charm for me and I'm happy with how my primer layer comes out.
7) Get the sprayer set up. The 30-minute "induction" time is a good time to
get last-minute items ready. I take my inline oiler out of the air line and
hook up a dedicated "clean air" line for spraying. I set my regulator on
about 23 psi (the magic # for me, you'll find your own). Get some latex
gloves handy. I even put ear plugs in when priming so that chromic crap
doesn't get in my ears and have a nice straight path to my brain. Anyway,
once the primer's ready, get your safety gear on and transfer the primer to
your spray gun -- I use those cheap little disposable paper funnels from
Spruce. Have some Acetone and a rag around for cleanup.
8) Spray everything. A thin, semi-transparent layer is all that's required.
I tend to go a little heavier than that just for kicks. If I add another 2
pounds to the aircraft overall I won't be upset. I like the way the AKZO
holds up to scratches, chemicals, etc. You'll find your own happy medium
thickness-wise.
9) Let it dry at least 15-30 minutes before handling. If you can let it dry
in the sun, it will be ready for handling almost instantaneously. AKZO
dries *fast* in dry heat, especially direct sunlight.
10) I clean my spray gun with Acetone. First I fill the cup up about
halfway and then spray it on some scrap (i.e. a cardboard box, whatever)
while shaking it vigorously, cycling the "mixture", etc. Once that's all
sprayed out, I take the cup off and wipe everything down as best I can with
Acetone, paying close attention to the nozzle, etc.
Yeah, this is absolutely 100% more time-consuming than just MEK'ing the
parts down and spraying on some self-etching primer from a can. But for me,
AKZO is as durable as I want it to be. I don't dig the way the spray can
primer lays on. Much less durable in my *opinion*. Take all this with a
grain of salt.
I hope this info is helpful,
)_( Dan
Subject: | Re: Scotchbrite wheels and drill motors |
> ways to do this.
Have you tried taking the "end cap" off your bench grinder? I had to do
this since the 6" ScotchBrite wheel was too thick and sticks out the side.
My end caps were held on with 3 screws or something like that.
http://www.rvproject.com/images/tools/bench_grinder_scotch_brite_wheel.jpg
)_( Dan
We all were at the stage you are at. Welcome to the group.
A drill motor is simply an electric drill. In shop class they called
them drill motors to keep from confusing them with drill bits when
someone asked for a drill.
You will use the scotchbrite wheel enough to warrant a trip to Harbor
Freight to buy one that will fit the wheel. You can easily drill out
the center mounting hole if you need to to fit the grinder.
I have a second 2" diameter scotchbrite wheel that will mount in an air
die grinder. I find it useful in deburring the cutouts in the wing
ribs, etc.
Steve Eberhart
RV-7A - working on wings
N14SE reserved
Rick McCraw wrote:
> Listers,
> ways to do this.
> enough?
> Thanks.
> Rick McCraw
Subject: | Re: RV7-List Digest: 4 Msgs - 08/12/02 |
08/13/2002 06:09:48 AM
I used my radial arm saw for the large scotchbrite wheel, just swiveled the
head 90 degrees and removed the shielding. It will even out if the hole is
a little off center to start with. This has worked great for me. I also use
a 90 degree 1/4 inch arbor die grinder for the two inch wheel.
Just finishing first wing.
Listers,
ways to do this.
enough?
Thanks.
Rick McCraw
Thanks to all who responded about Scotchbrite wheels. Dan, the existing
bench grinder is a no-go -- there is no end cap, and the housing is
solid. Having spent plenty on tools so far (probably a fraction of what
I'll end up with), I will take Steve's suggestion and throw the wheel on
my radial arm saw. If that doesn't work for me, then Harbor Freight,
here I come.
Rick McCraw
RV-7 emp -- as of today! (first metal -- finally drilled out my first
holes. Not much, but a start.)
I'm thinking about engine options for the RV7 and while at Oshkosh I saw a
6A 350 C1R Franklin 6 cylinder engine in a home built. This engine is
220hp, certified, and costs about $15,000 new. The RV7 package with engine
mounts is about $25,000 (www.franklinengines.com). This all sounds pretty
good. What am I missing here? There must be more to the story. A 4
cylinder Lycoming 200hp costs $30,000 from Vans.
Canopy
From: | Ross Schlotthauer <rdschlotthauer(at)yahoo.com> |
Subject: | Re: Franklin Engine |
John,
You can definately get an opinion on this engine by
calling Vans. I talked to Tom Green, their GM at the
Arlington fly in about it. They had one in an 8. He
painted a pretty bleak picture, but I would expect
this to a point considering the relationship they have
with Lyc.
What does the $25,000 include?
Ross Schlotthauer
RV7
> to the story. A 4
> John
> Canopy
> Contributions of
> any other form
> latest messages.
> other List members.
HotJobs - Search Thousands of New Jobs
http://www.hotjobs.com
Check the compression of the 220HP Franklin engine, I think it is 10.3 or
10.5 to one. With the changing of AVGAS (read lower octane) in the near
future I would not even think about buying one. If the Octane is lowered to
95~96 as I have read, this engine will not be able to run on it. I have
been on the same path and ended up with a Lycoming.
If you want 200HP the best thing you could do is have someone build you a
O-360 180HP into a IO-360 200 HP and save the extra money and 30+ lbs. Aero
Sport Power is building me an engine, they supply the core. I am getting
9.2:1 pistons, Light Speed Dual Electronic ignition, Superior Air Parts
sump for better flow. Air Flow Performance fuel injection, and remote oil
filter. All this for 18.7K. This will either be a 200hp engine or 200 HP+.
On the down side the core he is rebuilding for me is a conical mount and
they are using refurb parts. With the reputation of Aero Sport Power I have
the utmost confidence in the engine. They are one of the few companies in
the experimental world that I have heard nothing bad about them to date. Oh
about the compression 9.2:1, you can run on auto gas but the safety margin
is eroded a little. If you can run 11:1 on 100 octane as some people do
then you can run 9.2:1 on 95~96 Octane. I have called engine builders and
they have reluctantly agreed with this after thinking about it.
Just my 2 cents from and RV 8 builder.
>John
>Canopy
Scott Bilinski
Eng dept 8220
"What does the $25,000 include?"
"Ross Schlotthauer
RV7"
On their web site they have a list of items for the RV8 kit. The RV7 kit
will be the same items which is pretty complete including a new mount (not
for the 7A)and accessories, no baffles however, just plans for baffles.
John Adams
Subject: | Nutplate on aileron spar |
Ok, I'll do my best to describe this...
On the inboard end of the aileron spar, there are 3 bolt holes where the
hinge bracket mounts. The instructions call for trimming a hole in the
inboard aileron rib so you can get a wrench back there on the nut.
BUT...the match-drilled aileron spars came pre-drilled with nutplate rivet
holes around the middle "recessed" bolt hole...but this isn't indicated on
the drawing. I have to assume those are nutplate rivet holes, and they're
there for a reason. It sure seems logical to me to use the nutplate blind
instead of having to cut a wrench access hole in the rib.
How are most of you handling this? Are you installing a nutplate there or
going with the traditional wrench-hole-cutting method?
Thanks in advance,
)_( Dan
RV-7 N714D (ailerons...obviously)
dan @ rvproject . com
Subject: | Dimple aileron nose skin |
Ok, you countersink the holes in the galvanized pipe...but how do you dimple
the respective holes in the aileron nose skin? Or do you bother?
The plans call for countersunk CS4-4 rivets in those holes, but I can't
figure out how to get the skin holes dimpled properly. I fear that if I use
the C-frame it will leave major smiles around the holes since the curve is
pretty sharp.
How have you dealt with this? Does pulling the rivet dimple the .020 as it
compresses? Haven't asked Van's yet...it's just after midnight, figured
somebody out there in list-land is listening.
)_( Dan
Subject: | Re: Nutplate on aileron spar |
Dan
I don't think mine had a nutplate indication at this
location
I just knawed out a mouse hole as instructed
cary
> there on the nut.
> rib.
> method?
> Thanks in advance,
> )_( Dan
> Contributions of
> any other form
> latest messages.
> other List members.
Dan,
I used the hole in the rib on both ailerons.
Ross Schlotthauer
RV7
> there on the nut.
> rib.
> method?
> Thanks in advance,
> )_( Dan
> Contributions of
> any other form
> latest messages.
> other List members.
Subject: | Re: Dimple aileron nose skin |
Dan,
I can tell you this, Countersinking the pipe and then
simply pulling the rivets doesn't work. I tried this
and the rivets popped before the skin pulled down into
the hole. Also, using the pop rivet dimple dies
doen't work because it leaves a flat spot around the
dimple on the curved surface. The best Idea I have
heard is to countersink the pipe and cleco the skin to
it, and then tap only your male dimple die aginst the
skin with the pilot going into the pipe. I will be
drilling out my rivets and doing this.
Ross
> do you bother?
> holes, but I can't
> pretty sharp.
> )_( Dan
> Contributions of
> any other form
> latest messages.
> other List members.
From: | "Gannon, Terence" <Terence.Gannon(at)trican.ca> |
My experience is that dimpling the counterweight, and not dimpling the skin
does work, but in my case, I set the aileron in some V-blocks bolted to the
bench so that I could push down with the rivet puller (hard!), while still
pulling the rivet. I figured my pushing was doing most of the dimpling of
the skin. The result was nearly a perfectly flush rivet, that I
subsequently cleaned up just a little with a jewellers file, and then buffed
out with a Scrotchbrite in a die-grinder. I think they'll look just fine,
painted. HTH.
Regards...
Terry in Calgary
RV-6 S/N 24414
"Wings"
>From: "Ross Schlotthauer" <rdschlotthauer(at)yahoo.com>
>To: "rv7-list(at)matronics.com"
>Cc:
>Bcc:
>Subject: Re: RV7-List: Dimple aileron nose skin
>Type: IPM.Note
>Date: Friday, August 16, 2002 9:12 AM
>Dan,
>Ross
>> do you bother?
>> holes, but I can't
>> pretty sharp.
>> )_( Dan
>> Contributions of
>> any other form
>> latest messages.
>> other List members.
Subject: | Rivet pattern...bottom wing skin root rib |
I'm confused...maybe somebody who has already dealt with mating their wings
to the fuselage can help.
On DWG 12, the bottom wing view shows that you put a rivet in every *other*
hole, skin to root rib. But then it says to reference DWG 38, which clearly
shows the pattern is every 3rd hole!
What gives? I can obviously leave the bottom skin unriveted at the root
rib, but I'd rather wrap this up.
)_( Dan
I've got a friend that put one of these Franklin 220hp PZL engines in his Stinson.
The first engine broke a crankshaft over South Dakota. Guess what,
PZL would not even return his phone call. If this was not a lesson enough, he put
a second one in. Now he has been down a couple of months trying to get gears
to connect his mags. I think if I'm going to put that much work in my RV, I'm
going to stick with a tried and true engine. My two cents worth.
Allen Blackwell allenbldk(at)netscape.net
Stinson N8755K and building a RV7
Dan,
Speaking from one who has just installed my wings and just finished that
EXACT step, I can tell you DON'T drill that last rib until the wings are
installed. I was told by many builders and am glad I didn't. I just put
the wings on, drilled for the fairing/skin, and this week when I took the
wings back off to paint I riveted the rib on and installed the nutplates for
the fairings. If you drill and rivet that last rib, you will have a more
difficult time drilling that skin to the rib when the wing is installed.
Best of luck,
Stein Bruch
RV6, Minneappolis--High on Acetone/MEK/DP-40...painting.
[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Dan Checkoway
Subject: RV7-List: Rivet pattern...bottom wing skin root rib
)_( Dan
Subject: | new alodine trick |
Well, I don't know if this is new...but I'll be happy to take credit for it
if it is. 8
When alodining parts, here's a way to get thorough coverage with a minimum
of alodine and essentially no runoff or waste:
Take a large Ziploc sandwich bag (I used the common 1 gallon size that we
had lying around the kitchen), and pour a bit of alodine in there...maybe a
cup or so. Place your small parts into the bag one or two (or whatever) at
a time, and seal it if you want (or not). Slosh the parts around in the
alodine for a minute or two, take 'em out and rinse. The alodine stays in
the bag and the coverage on the parts is way better than what you get when
brushing it on.
This will only work for small parts, obviously -- I just did this with
aileron ribs and reinforcement plates and Gretz pitot mounting plates, etc.
I have to say it works excellent. Wish I knew this trick a while ago.
The coolest part is that you can drink the alodine right out of the bag when
you're done. Um, not.
)_( Dan
RV-7 N714D (ailerons)
From: | "Francis, CMDR David" <David.Francis(at)defence.gov.au> |
Dan and others,
I use alodine a lot. Brushing and spraying produce poor coverage. A bath is
always the best for nice coverage. For bits I use:
a. small bits, empty 2 litre ice cream containers.
b. big awkward bits a 200 litre rectangular bin.
c. long bits, either a length of plastic pipe with end caps, or a lenght of
plastic guttering with end bulkheads glued in place, depending on length.
d. big skins are a problem, being too big/awkward for any sort of tub, so I
brush it on using a soggy chux and a very light touch (heavy touch scratches
off the new deposit till it hardens)and have not always been very
successful.
I will add the bag technique to the list. Thanks for the tip.
David Francis, VH-ZEE, fuselage growing in the bank account.
RV7and7A(at)yahoogroups.com; SoCAL-RVlist(at)yahoogroups.com
Subject: RV7-List: new alodine trick
if it is. 8
brushing it on.
)_( Dan
John,
Two comments, it is unwise to have more than 200hp in an RV7, that is the
designers intent and various flutter and strength thresholds may be exceeded
if you overpower the airframe. Suggest you talk to Vans about power limits.
This is not the only good deal around, have a look at www.jabiru.net.au and
look for the 6litre 200hp engine they have designed for the RV6/7 market.
The Australian price is A$25 300 which is about US$13k. The reason it is so
cheap is that us Aussies work for the same number of $ that US citizens do,
but market forces mean our $ is half the value of yours.
Guess what engine I am looking at very hard.
Have fun, David Francis, VH-ZEE, wings finished.
From: John Adams [mailto:jadams(at)scoutmedical.com]
Subject: RV7-List: Franklin Engine
Dave...
Thanks for pointing out the Jabiru 6000. If successful, that engine might
cause a sensation in the RV world. I notice they only rate their engines for
1000 hrs TBO, I wonder why? Of course, many Lyc/Cons don't make it to their
2000 hrs either....
Jerry Cochran
RV6a finish kit/E-Soob
Wilsonville, Oregon USA
In a message dated 8/19/02 11:58:49 PM, rv7-list-digest(at)matronics.com writes:
<< This is not the only good deal around, have a look at www.jabiru.net.au and
Subject: | Re: Jabiru 6 litre |
The dis advantage of the Jabiru is that it spins a smaller propeller to get
the higher RPM.
A sonex did about 6 high speed passes at our EAA "open house" and it
did quiet well using it's 85HP VW motor. When the RV's came out it lost by
far, a sonex can;t climb nearly as fast.
Justin
----- Original Message -----
Subject: RV7-List: Jabiru 6 litre
> Dave...
for
their
> 2000 hrs either....
> Cheers,
> Jerry Cochran
writes:
and
so
do,
My understanding of the 1000 hr tbo is as follows:
a. for the 6000 its a new product not in production till end 02, therefore
its a low initial figure till they build reliability data up.
b. on the 2200 and 3300 engines they offer in Australia a fixed price
overhaul that is so cheap doing 2 in 2000 hrs is still cheaper than doing
one Lycoming overhaul in 2000hrs.
c. Their 2200 engine is certified, but the 6000 is not going to be, to keep
the cost down, but at least as a manufacturer they know how to meet
certification quality standards.
d. the production date of the 6000 has slipped by 12 months total due to
development problems identified during flight test. This is good by me, it
means fewer bugs in the product before it gets to us.
e. For info Jabiru now own Microair, who make the tiny comm and transponder
radios.
Hope this helps folks make informed decisions, its always risky taking on a
new engine, even from a company with Jabirus generally good track record.
Although I am committed to the Jabiru 6000, I am still very cautious about
it.
Regards, David
From: Jerry2DT(at)AOL.com [mailto:Jerry2DT(at)AOL.com]
Dave...
2000 hrs either....
Jerry Cochran
on 8/20/02 11:33 AM, Jerry2DT(at)AOL.com at Jerry2DT(at)AOL.com wrote:
> Dave...
> 2000 hrs either....
> Cheers,
> Jerry Cochran
The Jabiru engine, I hope it will do well. From some of my resources the
Jabiru 80 Hp is a high maintenance engine. The valves seem poorly lubricated
and there have been some reports of burned values. Maybe they worked it out.
The 8 cylinder 200 Hp engine is very new. I would like to see them put some
hours on it and get some non-biased reports.
Scott Trask IMT
Subject: | way to avoid countersinking the flap hinges |
This is a note to builders who haven't completed their wings yet...I'm
building my flaps and hit the point in the instructions where it says you
can avoid countersinking the flap hinge by dimpling the skin and
countersinking the spar. Makes perfect sense.
The little burble I hit had to do with the fact that I already *dimpled*
both the bottom wing skin rear edge and the *flap brace* as well. The
result is that I'm going to have to machine countersink the holes on the
forward half of the flap hinge. No big deal, but I was wondering if that
would cause a structural issue...i.e. with the rivet bucktails not having as
much material to grip or whatever. As it turns out, I called Van's and they
said it was perfectly fine. But...I would rather have avoided this so I
wouldn't have to countersink the hinge.
So in case you haven't hit this point yet, you might want to consider
machine countersinking the flap brace holes instead. That will mirror the
method on the flap and you can avoid countersinking the hinge.
Just something to consider. Hope this helps...
)_( Dan
RV-7 N714D (flaps)
Subject: | Any tips on bending FL-706B? |
The flap inboard end reinforcement bracket FL-706B is supposed to be bent
6.3 degrees, according to the plans, so that it will snug into the angle
created by the inboard rib and the FL-706A angle.
Any tips on how to make that bend? A vise and brute force? Any tricks?
Thanks in advance,
)_( Dan
RV-7 N714D (flaps)
Subject: | Re: way to avoid countersinking the flap hinges |
> )_( Dan
> RV-7 N714D (flaps)
Dan
You can remove the dimples, just drive them back with your rivet gun
(hammer) and bucking bar.
Scott Trask IMT
Subject: | Re: Any tips on bending FL-706B? |
Dan,
Vise and 8 oz hammer. Move small amounts and measure
accurately.
Ross Schlotthauer
> snug into the angle
> force? Any tricks?
> Thanks in advance,
> )_( Dan
> RV-7 N714D (flaps)
> Contributions of
> any other form
> latest messages.
> other List members.
http://finance.yahoo.com
Subject: | CM-4MS flap rod end bearing |
Can somebody confirm that the CM-4MS bearings used on the flaps are supplied
in the fuselage kit hardware? I didn't seem to get any with the wing kit
hardware.
Thanks in advance,
)_( Dan
RV-7 N714D (flaps)
From: | "peter decraene" <peterdecraene(at)attbi.com> |
Subject: | Re: CM-4MS flap rod end bearing |
Bearings are with the Fuse kit.
Pete DeCraene
ordered finish kit
January 05, 2002 - August 26, 2002
RV7-Archive.digest.vol-ab
