RV7-Archive.digest.vol-ag
October 02, 2004 - December 07, 2004
      while you build & it ain't gonna be maintenance friendly, so it meets
      traditional aircraft standards. ;-)
      Email me off list if you want details.
From: "Brian Meyette" <brianpublic(at)starband.net>
Subject: Tip tanks by Jon Johanson?
Date: Oct 02, 2004
At the recent RV Forum in Fulton, NY, there were RVs there with extended range tanks. One had them in the leading edge, like Van's, one bay outboard for the stock tanks, and the other had (I believe) 12 gallons in the baggage compartment. I have pics of both, if people want to see. brian -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Charlie England Subject: Re: RV7-List: Tip tanks by Jon Johanson? Allen Fulmer wrote: > >Anyone installed the tip tanks by Jon Johanson? > >If so, comments pro and/or con? > >Expensive but a reported extra 12 gallons per side! > >Thanks, > >Allen Fulmer >RV7 Wings >N808AF reserved > I'm about midway through adding 12 gal/side to the wing leading edges on my -7 wings. It's not approved by Van's (the last time I checked they wouldn't recommend the tip tank mod either), but it's already been done by at least 2 RV-9 guys. It's a lot more work than bolting on the tip tanks, but only costs about $200-$300 total to do. It's got to be done while you build & it ain't gonna be maintenance friendly, so it meets traditional aircraft standards. ;-) Email me off list if you want details. Charlie --- --- ________________________________________________________________________________
Subject: Souther Arizona RV builders?
Date: Oct 03, 2004
Fellow Southern Arizona RV builders. I am building a RV-7A in Tucson Arizona (wings 80% complete) and I am trying to get a list of RV builders (not owners) here in Southern Arizona. Please chime in with the type and status of your project. You can contact me directly at merems(at)cox.net or post directly to the newsgroup. ________________________________________________________________________________
From: "Francis, David CMDR" <David.Francis(at)defence.gov.au>
Subject: Tip Tanks by Johanson
Date: Oct 05, 2004
Allen, I have installed two sets of Johanson tip tanks, and have also observed their construction during some maintenance training I managed to organise in Adelaide, South Australia. The fuel capacity is 12.5 USG. Each fibreglass tanks should weigh in at 11.5 lbs each. The fibreglass tanks are over-built in order to withstand hangar rash. There is around 70 or more manhours in the construction of each set of tanks, and that drives the price. They are now a very mature product. Naturally the inboard rim of each tank has to be built slightly oversize to allow for individual variation on wing tip profile and that generates a lot of trimming with a cut-off disk, and some sanding down with a coarse flap wheel. Then you get to instal a lot of nutplates. Allow 4 days work to install a pair of tanks if you have seen the process before, more if you havent. What else do you need to know? Email me direct if you would like more info, of which I have plenty. Regards, David Francis, Canberra, Australia -----Original Message----- From: Allen Fulmer [mailto:afulmer(at)charter.net] Subject: POSSIBLE SPAM-DEFGRAM178/04 [dkn01] RV7-List: Tip Tanks by Johanson Anyone installed the tip tanks by Jon Johanson? If so, comments pro and/or con? Expensive but a reported extra 12 gallons per side! Thanks, Allen Fulmer RV7 Wings N808AF reserved ________________________________________________________________________________
Subject: Builders Log
Date: Oct 08, 2004
I would like to find out how most of you are tracking your time and what you are using for a builders log. Anyone have suggestions on the best way to track time and progress. I have an Apple iMac so I can create my own database if necessary. I know there is a Kitpro Log Plus for Windows computers, but I don't think it is available for Apple. Any thoughts or suggestions greatly appreciated. Larry Bell, RV-7A Waiting for Wings and Fuselage Empennage Complete ________________________________________________________________________________
From: "David Figgins" <2004nospam(at)earthlink.net>
Date: Oct 08, 2004
Larry I am using a web site to track progress and time which seems to be what a lot of people are doing, mine is simple but some of them are excellent (www.whiskeybravo.com is good and has many links to others). Kind of fun to do and provides some feedback to other builders at similar stages in the process. Dave Figgins RV-7A empennage (wings on order) Dbfiggins.home.comcast.net -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of William Bell Subject: RV7-List: Builders Log I would like to find out how most of you are tracking your time and what you are using for a builders log. Anyone have suggestions on the best way to track time and progress. I have an Apple iMac so I can create my own database if necessary. I know there is a Kitpro Log Plus for Windows computers, but I don't think it is available for Apple. Any thoughts or suggestions greatly appreciated. Larry Bell, RV-7A Waiting for Wings and Fuselage Empennage Complete advertising on the Matronics Forums. ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: Re: Builders Log
Date: Oct 09, 2004
I am making entries in my builder's instruction (step by step) book that Vans supplied us. As I complete each step, I date and ok it as done. If there is any issue that still needs attention, I notate that for later review and completion. I also take some pictures but not that many. I am more concerned about building a quality plane rather than documenting it. Others such as Day Checkaway and Sam Buchanon and many others have great web sites that shows they devoted a larger part of their life to documenting their work. I use them when ever needed. I particularly take pictures of my project when someone that has considerable experience comes over and look at my project. That is evidence that I am not just doing this without some oversight. The construction book with my log notes along with pics and receipts of extra things needed to complete the plane are plenty of evidence of meeting the 51% rule. Indiana Larry, RV7 TipUp "SunSeeker" About 96% complete and 14% yet to go. The sincerest satisfactions in life come in doing and not dodging duty; in meeting and solving problems, in facing facts; in flying a virgin plane never flown before. - Richard L. Evans & Larry R Helming ----- Original Message ----- From: "William Bell" <wmlbell(at)comcast.net> Subject: RV7-List: Builders Log > > I would like to find out how most of you are tracking your time and > what you are using for a builders log. Anyone have suggestions on the > best way to track time and progress. I have an Apple iMac so I can > create my own database if necessary. I know there is a Kitpro Log Plus > for Windows computers, but I don't think it is available for Apple. > Any thoughts or suggestions greatly appreciated. > > Larry Bell, RV-7A > Waiting for Wings and Fuselage > Empennage Complete > > ________________________________________________________________________________
Date: Oct 09, 2004
I bought kitlog and discontinued using it. It is not user friendly. I NOW KEEP TRACK IN A WRITTEN BOOK AND TAKE DIGITAL PICS THAT I PRINT AND ADD TO THE APPROPRIATE COMMENTS. ----- Original Message ----- From: "William Bell" <wmlbell(at)comcast.net> Subject: RV7-List: Builders Log > > I would like to find out how most of you are tracking your time and > what you are using for a builders log. Anyone have suggestions on the > best way to track time and progress. I have an Apple iMac so I can > create my own database if necessary. I know there is a Kitpro Log Plus > for Windows computers, but I don't think it is available for Apple. > Any thoughts or suggestions greatly appreciated. > > Larry Bell, RV-7A > Waiting for Wings and Fuselage > Empennage Complete > > ________________________________________________________________________________
Subject: Air Compressor & Tools
Date: Oct 11, 2004
Greetings everyone, I am forgoing building a Cozy MK-IV (maybe 2% done) for an RV-7A for too many reasons to list and I have a few questions for those willing to answer. 1) Which tool kit would you recommend? (i.e. Avery, Cleveland, etc.) 2) Would a 21 Gallon air compressor be adequate for the building process? Thanks in advance for your guidance. Scott Shook RV-7A (Order Form ready to fax to Vans.) ________________________________________________________________________________
Date: Oct 11, 2004
Subject: Re: Air Compressor & Tools
Scot, With a 21 gallon air compressor you can easily accomplish any task that you will run into building an RV. I used a 1 1/2 gallon all last week end and it kept up with an airdrill and a rivet gun with hardly ever running. Where you might have some problems is with airtools that require constant running like die grinders. There is tons of info in the archives about air compressors, you could spend a day or so just reading it all. Lets start a thread about bigger vs. quieter. Avery and Cleaveland both make good tools. I have had good service from both. Mike Ice RV-9 Anchorage, Alaska ----- Original Message ----- From: "Scott R. Shook" <sshook(at)cox.net> Subject: RV7-List: Air Compressor & Tools > > Greetings everyone, > > I am forgoing building a Cozy MK-IV (maybe 2% done) for an RV-7A for too > many reasons to list and I have a few questions for those willing to answer. > > 1) Which tool kit would you recommend? (i.e. Avery, Cleveland, etc.) > > 2) Would a 21 Gallon air compressor be adequate for the building process? > > Thanks in advance for your guidance. > > Scott Shook > RV-7A (Order Form ready to fax to Vans.) > > ________________________________________________________________________________
Date: Oct 11, 2004
I am at a mid empennage stage. Bought Avery kit with 3x and pneumatic squeezer. Around $2100. Get a compressor that requires oil. Quieter and will last longer. I have a Dewalt EMGLO with a little tank. Probably would not be happy spraying or running pneumatic drills but for squeezing etc its great and does not run all the time. I am on a 7a too. Regards Tim ________________________________________________________________________________
Date: Oct 11, 2004
1. I have repeatedly found Avery's customer service and responsiveness to be VASTLY better than Cleaveland's. 2. yes, but avoid the oilless type - they are EXTREMELY noisy brian http://brian76.mystarband.net/RV-7Ahome.htm -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Scott R. Shook Subject: RV7-List: Air Compressor & Tools Greetings everyone, I am forgoing building a Cozy MK-IV (maybe 2% done) for an RV-7A for too many reasons to list and I have a few questions for those willing to answer. 1) Which tool kit would you recommend? (i.e. Avery, Cleveland, etc.) 2) Would a 21 Gallon air compressor be adequate for the building process? Thanks in advance for your guidance. Scott Shook RV-7A (Order Form ready to fax to Vans.) --- --- ________________________________________________________________________________
Date: Oct 11, 2004
Scott, I'm using 30 gal compressor. It runs often and is loud but is getting the job done. I have been using the Avery tool kit. Great tools and excellent customer service. Good luck on your 7! Bill Lull > > From: "Scott R. Shook" <sshook(at)cox.net> > Date: 2004/10/11 Mon PM 09:40:20 EDT > To: > Subject: RV7-List: Air Compressor & Tools > > > Greetings everyone, > > I am forgoing building a Cozy MK-IV (maybe 2% done) for an RV-7A for too > many reasons to list and I have a few questions for those willing to answer. > > 1) Which tool kit would you recommend? (i.e. Avery, Cleveland, etc.) > > 2) Would a 21 Gallon air compressor be adequate for the building process? > > Thanks in advance for your guidance. > > Scott Shook > RV-7A (Order Form ready to fax to Vans.) > > > > > > > ________________________________________________________________________________
Date: Oct 12, 2004
Scott I didn't have a lot of money to spend so I bought the empennage toolkit from cleveland and I like it. The only other thing you need with it is a squeezer so I bought the Main Squeeze from Cleveland and it has also performed well. I've never had any problems with their customer service. You may want to purchase more clecos than the kit has. I also bought the Avery Deburring tool. (http://www.kane-king.com/rv7aproject/20040927.htm) <- this one. I highly recommend it! I just got a cheap Sears air compressor. It works just fine. I don't have any tools that require a lot of air so it doesn't run that much. Bill King www.kane-king.com > > From: "Scott R. Shook" <sshook(at)cox.net> > Date: 2004/10/11 Mon PM 09:40:20 EDT > To: > Subject: RV7-List: Air Compressor & Tools > > > Greetings everyone, > > I am forgoing building a Cozy MK-IV (maybe 2% done) for an RV-7A for too > many reasons to list and I have a few questions for those willing to > answer. > > 1) Which tool kit would you recommend? (i.e. Avery, Cleveland, etc.) > > 2) Would a 21 Gallon air compressor be adequate for the building process? > > Thanks in advance for your guidance. > > Scott Shook > RV-7A (Order Form ready to fax to Vans.) > ________________________________________________________________________________
Date: Oct 12, 2004
A 21-gallon tank should do nicely - it's more a matter of how quickly the compressor will recharge the tank and how long you're willing to wait for that to happen. No problem for rivet guns and drills, might slow you down a bit with a die grinder or paint gun. I'd stick with your current compressor and save the money for other items (like panel goodies). However, if you ever feel like you need a bigger compressor, I bought a 60-gallon/5 HP Husky from Home Depot for about $400 and have been extremely pleased with it. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Scott R. Shook Subject: RV7-List: Air Compressor & Tools Greetings everyone, I am forgoing building a Cozy MK-IV (maybe 2% done) for an RV-7A for too many reasons to list and I have a few questions for those willing to answer. 1) Which tool kit would you recommend? (i.e. Avery, Cleveland, etc.) 2) Would a 21 Gallon air compressor be adequate for the building process? Thanks in advance for your guidance. Scott Shook RV-7A (Order Form ready to fax to Vans.) ________________________________________________________________________________
From: George Neal E Capt AU/PC <Neal.George(at)maxwell.af.mil>
Date: Oct 12, 2004
I use KitLog to manage the written record and relevant photos of my progress (and mistakes). I don't particularly like it, but I'm not smart enough to make it better. And it's paid for. For keeping track of time, I use a Hobbs meter to add a little novelty. In the months leading up to my first sub-kit order, I looked around, called tractor dealers, marine dealers, leafed through catalogues and web sites looking for an inexpensive unit. One of the boat shops that I called had a 110v unit that was intended for a generator - $10. I mounted it and a switch in a 4" galvanized electrical box. Neal George RV-7 N8ZG, wings >I would like to find out how most of you are tracking your time and >what you are using for a builders log. ________________________________________________________________________________
Date: Oct 12, 2004
My website and a few other notes are all I do for a builder's log. I track time in the workshop as time on the project. Feeling that there is no reasonable way to track it to the minute, I round to half hour increments. Now, if I could just find more time.... Kathleen Evans www.rv7.us -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of George Neal E Capt AU/PC Subject: RE: RV7-List: Builders Log I use KitLog to manage the written record and relevant photos of my progress (and mistakes). I don't particularly like it, but I'm not smart enough to make it better. And it's paid for. For keeping track of time, I use a Hobbs meter to add a little novelty. In the months leading up to my first sub-kit order, I looked around, called tractor dealers, marine dealers, leafed through catalogues and web sites looking for an inexpensive unit. One of the boat shops that I called had a 110v unit that was intended for a generator - $10. I mounted it and a switch in a 4" galvanized electrical box. Neal George RV-7 N8ZG, wings >I would like to find out how most of you are tracking your time and >what you are using for a builders log. ________________________________________________________________________________
Date: Oct 12, 2004
I also just use a web site as my log (www.openweave.org/RV7). It is a bit of homebrew code that I put together to serve it all up ... as opposed to any sort of commercial or freeware package. One of my requirements was that I put my log in a format that allowed me to easily generate a formatted and printed version, and I can do that *fairly* easily with what I have put together. I also just round .. but to the nearest 15 minutes. I agree that there is no way to track it to the minute. As to the "if I could just find more time" part of Kathleen's comments ... I couldn't agree more! -- Dwight On Tue Oct 12 13:13:32 2004, Kathleen(at)rv7.us wrote : > > >My website and a few other notes are all I do for a builder's log. I track >time in the workshop as time on the project. Feeling that there is no >reasonable way to track it to the minute, I round to half hour increments. >Now, if I could just find more time.... > >Kathleen Evans >www.rv7.us > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of George Neal E Capt >AU/PC >To: rv7-list(at)matronics.com >Subject: RE: RV7-List: Builders Log > > > >I use KitLog to manage the written record and relevant photos of my progress >(and mistakes). I don't particularly like it, but I'm not smart enough to >make it better. And it's paid for. > >For keeping track of time, I use a Hobbs meter to add a little novelty. In >the months leading up to my first sub-kit order, I looked around, called >tractor dealers, marine dealers, leafed through catalogues and web sites >looking for an inexpensive unit. One of the boat shops that I called had a >110v unit that was intended for a generator - $10. I mounted it and a >switch in a 4" galvanized electrical box. > >Neal George >RV-7 N8ZG, wings > >>I would like to find out how most of you are tracking your time and >>what you are using for a builders log. > > ________________________________________________________________________________
Subject: Left hand vs right hand
Date: Oct 12, 2004
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Hi all, I have about 450 hours TT and most of that has been done in my current zenair zodiac with a center stick. Hence it has two interconnected throttles, on the left for me and on the right for my PX. I had rather nasty incident (crash) in a C152 while trying to land from the right seat with about 70 hours of experience right after getting my ticket.....If your saying dumba*s in your head right now, believe me you wouldn't be the first. Most of the crash was caused by the fact I changed hands. So of course, the RV7a is throttle in RH and stick in left...i.e opposite to what I fly now.....hmm... The dumba*s concept is coming into view again. So I wondered what you all thought of maybe going for the throttle in the left and RH on the stick. I note that grand website master Dan Checkoway did it but the quadrant is a bit on the ugly side for me. With three levers though I'm not sure what else to do. The other issue is that I like to at least give my Wife a fighting chance to walk away from the wreckage should any of my vital bodily functions decide to fail...Apparently we only have on heart....What a crappy design that is....:) So that would mean at least a dual interconnected throttle, not easy unless you have a solid rod rather than cable throttles. Any thoughts? Frank P.s, Dan my lunchtime reading has taken a downturn so could you please update your website?....:) -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Kathleen(at)rv7.us Subject: RE: RV7-List: Builders Log My website and a few other notes are all I do for a builder's log. I track time in the workshop as time on the project. Feeling that there is no reasonable way to track it to the minute, I round to half hour increments. Now, if I could just find more time.... Kathleen Evans www.rv7.us -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of George Neal E Capt AU/PC Subject: RE: RV7-List: Builders Log I use KitLog to manage the written record and relevant photos of my progress (and mistakes). I don't particularly like it, but I'm not smart enough to make it better. And it's paid for. For keeping track of time, I use a Hobbs meter to add a little novelty. In the months leading up to my first sub-kit order, I looked around, called tractor dealers, marine dealers, leafed through catalogues and web sites looking for an inexpensive unit. One of the boat shops that I called had a 110v unit that was intended for a generator - $10. I mounted it and a switch in a 4" galvanized electrical box. Neal George RV-7 N8ZG, wings >I would like to find out how most of you are tracking your time and >what you are using for a builders log. == == == == ________________________________________________________________________________
Date: Oct 12, 2004
Subject: Re: Left hand vs right hand
frank flying with the left hoof is really not much of a transition. you'll get comfortable with it in a hurry. Personally I would go to all the complications of a dual system. Keep it simple, you'll be glad you did. cary rhodes --- "Hinde, Frank George (Corvallis)" wrote: > (Corvallis)" > > Hi all, > > I have about 450 hours TT and most of that has been > done in my current > zenair zodiac with a center stick. Hence it has two > interconnected > throttles, on the left for me and on the right for > my PX. > > I had rather nasty incident (crash) in a C152 while > trying to land from > the right seat with about 70 hours of experience > right after getting my > ticket.....If your saying dumba*s in your head right > now, believe me you > wouldn't be the first. > > Most of the crash was caused by the fact I changed > hands. > > So of course, the RV7a is throttle in RH and stick > in left...i.e > opposite to what I fly now.....hmm... The dumba*s > concept is coming into > view again. > > So I wondered what you all thought of maybe going > for the throttle in > the left and RH on the stick. I note that grand > website master Dan > Checkoway did it but the quadrant is a bit on the > ugly side for me. With > three levers though I'm not sure what else to do. > > The other issue is that I like to at least give my > Wife a fighting > chance to walk away from the wreckage should any of > my vital bodily > functions decide to fail...Apparently we only have > on heart....What a > crappy design that is....:) > > So that would mean at least a dual interconnected > throttle, not easy > unless you have a solid rod rather than cable > throttles. > > Any thoughts? > > Frank > > P.s, Dan my lunchtime reading has taken a downturn > so could you please > update your website?....:) > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com] On > Behalf Of > Kathleen(at)rv7.us > To: rv7-list(at)matronics.com > Subject: RE: RV7-List: Builders Log > > > > My website and a few other notes are all I do for a > builder's log. I > track time in the workshop as time on the project. > Feeling that there > is no reasonable way to track it to the minute, I > round to half hour > increments. Now, if I could just find more time.... > > Kathleen Evans > www.rv7.us > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com] On > Behalf Of George Neal E > Capt AU/PC > To: rv7-list(at)matronics.com > Subject: RE: RV7-List: Builders Log > > AU/PC > > > I use KitLog to manage the written record and > relevant photos of my > progress (and mistakes). I don't particularly like > it, but I'm not > smart enough to > make it better. And it's paid for. > > For keeping track of time, I use a Hobbs meter to > add a little novelty. > In the months leading up to my first sub-kit order, > I looked around, > called tractor dealers, marine dealers, leafed > through catalogues and > web sites looking for an inexpensive unit. One of > the boat shops that I > called had a 110v unit that was intended for a > generator - $10. I > mounted it and a switch in a 4" galvanized > electrical box. > > Neal George > RV-7 N8ZG, wings > > >I would like to find out how most of you are > tracking your time and > >what you are using for a builders log. > > > == > == > == > == > > > > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV7-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > _______________________________ Declare Yourself - Register online to vote today! http://vote.yahoo.com ________________________________________________________________________________
Date: Oct 12, 2004
Frank, What you may not know is that Dan is a southpaw so he is naturally handicapped and can't fly using his left hand. He sure can build airplanes and websites. Don BTW Dan if you caught my last web entry you will see that I am even more handicapped!! -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Hinde, Frank George (Corvallis) Subject: RV7-List: Left hand vs right hand Hi all, I have about 450 hours TT and most of that has been done in my current zenair zodiac with a center stick. Hence it has two interconnected throttles, on the left for me and on the right for my PX. I had rather nasty incident (crash) in a C152 while trying to land from the right seat with about 70 hours of experience right after getting my ticket.....If your saying dumba*s in your head right now, believe me you wouldn't be the first. Most of the crash was caused by the fact I changed hands. So of course, the RV7a is throttle in RH and stick in left...i.e opposite to what I fly now.....hmm... The dumba*s concept is coming into view again. So I wondered what you all thought of maybe going for the throttle in the left and RH on the stick. I note that grand website master Dan Checkoway did it but the quadrant is a bit on the ugly side for me. With three levers though I'm not sure what else to do. The other issue is that I like to at least give my Wife a fighting chance to walk away from the wreckage should any of my vital bodily functions decide to fail...Apparently we only have on heart....What a crappy design that is....:) So that would mean at least a dual interconnected throttle, not easy unless you have a solid rod rather than cable throttles. Any thoughts? Frank P.s, Dan my lunchtime reading has taken a downturn so could you please update your website?....:) -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Kathleen(at)rv7.us Subject: RE: RV7-List: Builders Log My website and a few other notes are all I do for a builder's log. I track time in the workshop as time on the project. Feeling that there is no reasonable way to track it to the minute, I round to half hour increments. Now, if I could just find more time.... Kathleen Evans www.rv7.us -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of George Neal E Capt AU/PC Subject: RE: RV7-List: Builders Log I use KitLog to manage the written record and relevant photos of my progress (and mistakes). I don't particularly like it, but I'm not smart enough to make it better. And it's paid for. For keeping track of time, I use a Hobbs meter to add a little novelty. In the months leading up to my first sub-kit order, I looked around, called tractor dealers, marine dealers, leafed through catalogues and web sites looking for an inexpensive unit. One of the boat shops that I called had a 110v unit that was intended for a generator - $10. I mounted it and a switch in a 4" galvanized electrical box. Neal George RV-7 N8ZG, wings >I would like to find out how most of you are tracking your time and >what you are using for a builders log. == == == == ________________________________________________________________________________
Date: Oct 12, 2004
Frank, I have given this a lot of thought and don't think there is a right (:-) correct) answer. I like the left-on-the-stick and right hand for throttle work and radios arrangement. My husband likes to fly from the right seat most of the time. When he flies solo, he uses the right seat except in the Mooney which has no brakes on the right. In our situation, the normal configuration works well. Mostly, I believe that whatever you do, you should allow for flight from either seat. 1) You never know what your future flight circumstance will be and, 2) You may want to sell your plane some day. I don't find any difference in flying left seat or right, but I like the left seat with left hand on a stick or yoke, so that's going to be my primary flight position. You really have to sit in an airplane and think about what works for you. It's your airplane, YOU have to be comfortable. No one can tell you which is best for you.... Kathleen Evans www.rv7.us -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Subject: RV7-List: Left hand vs right hand Hi all, I have about 450 hours TT and most of that has been done in my current zenair zodiac with a center stick. Hence it has two interconnected throttles, on the left for me and on the right for my PX. I had rather nasty incident (crash) in a C152 while trying to land from the right seat with about 70 hours of experience right after getting my ticket.....If your saying dumba*s in your head right now, believe me you wouldn't be the first. Most of the crash was caused by the fact I changed hands. So of course, the RV7a is throttle in RH and stick in left...i.e opposite to what I fly now.....hmm... The dumba*s concept is coming into view again. So I wondered what you all thought of maybe going for the throttle in the left and RH on the stick. I note that grand website master Dan Checkoway did it but the quadrant is a bit on the ugly side for me. With three levers though I'm not sure what else to do. The other issue is that I like to at least give my Wife a fighting chance to walk away from the wreckage should any of my vital bodily functions decide to fail...Apparently we only have on heart....What a crappy design that is....:) So that would mean at least a dual interconnected throttle, not easy unless you have a solid rod rather than cable throttles. Any thoughts? Frank P.s, Dan my lunchtime reading has taken a downturn so could you please update your website?....:) -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Kathleen(at)rv7.us Subject: RE: RV7-List: Builders Log My website and a few other notes are all I do for a builder's log. I track time in the workshop as time on the project. Feeling that there is no reasonable way to track it to the minute, I round to half hour increments. Now, if I could just find more time.... Kathleen Evans www.rv7.us -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of George Neal E Capt AU/PC Subject: RE: RV7-List: Builders Log I use KitLog to manage the written record and relevant photos of my progress (and mistakes). I don't particularly like it, but I'm not smart enough to make it better. And it's paid for. For keeping track of time, I use a Hobbs meter to add a little novelty. In the months leading up to my first sub-kit order, I looked around, called tractor dealers, marine dealers, leafed through catalogues and web sites looking for an inexpensive unit. One of the boat shops that I called had a 110v unit that was intended for a generator - $10. I mounted it and a switch in a 4" galvanized electrical box. Neal George RV-7 N8ZG, wings >I would like to find out how most of you are tracking your time and >what you are using for a builders log. == == == == ________________________________________________________________________________
Date: Oct 12, 2004
I've heard both sides of this discussion several times, too. I'm right handed and I prefer to fly the plane with the left hand so I can use my RIGHT hand to adjust throttle, change radio frequencies, write clearances, etc. Seems the same as a C-150 to me. When I flare in a C-150, I'm flying the plane with my left hand and have the right hand at the ready on throttle, flaps, etc. For me, flying from the right seat is awkward, NOT from the left hand vs. right hand debate, but rather from the visual appearance over the cowling. If I ever become an instructor, I'm told I will get used to it. Don -----Original Message----- From: Kathleen(at)rv7.us [mailto:Kathleen(at)rv7.us] Subject: RE: RV7-List: Left hand vs right hand Frank, I have given this a lot of thought and don't think there is a right (:-) correct) answer. I like the left-on-the-stick and right hand for throttle work and radios arrangement. My husband likes to fly from the right seat most of the time. When he flies solo, he uses the right seat except in the Mooney which has no brakes on the right. In our situation, the normal configuration works well. Mostly, I believe that whatever you do, you should allow for flight from either seat. 1) You never know what your future flight circumstance will be and, 2) You may want to sell your plane some day. I don't find any difference in flying left seat or right, but I like the left seat with left hand on a stick or yoke, so that's going to be my primary flight position. You really have to sit in an airplane and think about what works for you. It's your airplane, YOU have to be comfortable. No one can tell you which is best for you.... Kathleen Evans www.rv7.us -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Subject: RV7-List: Left hand vs right hand Hi all, I have about 450 hours TT and most of that has been done in my current zenair zodiac with a center stick. Hence it has two interconnected throttles, on the left for me and on the right for my PX. I had rather nasty incident (crash) in a C152 while trying to land from the right seat with about 70 hours of experience right after getting my ticket.....If your saying dumba*s in your head right now, believe me you wouldn't be the first. Most of the crash was caused by the fact I changed hands. So of course, the RV7a is throttle in RH and stick in left...i.e opposite to what I fly now.....hmm... The dumba*s concept is coming into view again. So I wondered what you all thought of maybe going for the throttle in the left and RH on the stick. I note that grand website master Dan Checkoway did it but the quadrant is a bit on the ugly side for me. With three levers though I'm not sure what else to do. The other issue is that I like to at least give my Wife a fighting chance to walk away from the wreckage should any of my vital bodily functions decide to fail...Apparently we only have on heart....What a crappy design that is....:) So that would mean at least a dual interconnected throttle, not easy unless you have a solid rod rather than cable throttles. Any thoughts? Frank P.s, Dan my lunchtime reading has taken a downturn so could you please update your website?....:) -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Kathleen(at)rv7.us Subject: RE: RV7-List: Builders Log My website and a few other notes are all I do for a builder's log. I track time in the workshop as time on the project. Feeling that there is no reasonable way to track it to the minute, I round to half hour increments. Now, if I could just find more time.... Kathleen Evans www.rv7.us -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of George Neal E Capt AU/PC Subject: RE: RV7-List: Builders Log I use KitLog to manage the written record and relevant photos of my progress (and mistakes). I don't particularly like it, but I'm not smart enough to make it better. And it's paid for. For keeping track of time, I use a Hobbs meter to add a little novelty. In the months leading up to my first sub-kit order, I looked around, called tractor dealers, marine dealers, leafed through catalogues and web sites looking for an inexpensive unit. One of the boat shops that I called had a 110v unit that was intended for a generator - $10. I mounted it and a switch in a 4" galvanized electrical box. Neal George RV-7 N8ZG, wings >I would like to find out how most of you are tracking your time and >what you are using for a builders log. == == == == ________________________________________________________________________________
Subject: Tire Change
Date: Oct 12, 2004
I'm doing my first tire change on an RV-6 that I bought last year. (starting -7 tail kit this winter). I have one of Vans axle jacks that you slide the tire onto to remove it. Since the aircraft has wheel pants the hub nut is solid so I had to remove that before I could install the jack. My question: Can you intall the wheel, let the jack down and still get the correct tork on the hub nut while the wheel is resting on the ground? Thanks in advance. John Brunke ________________________________________________________________________________
Subject: Re: Tire Change
Date: Oct 12, 2004
Yikes! Be careful -- wheel halves have been known to separate and kill people. Or at least take out a chunk of skull. NEVER handle a wheel with the tire inflated. Only inflate it once the wheel halves are captured with the axle nut. Now to answer your question... You're supposed to hollow out the end of the axle nut and use a little steel screw-on bracket for the wheel pant attach nutplate. Photos here: http://www.rvproject.com/20030411.html (bottom of the page) That way, the order is like this: 1) Remove the wheel pant 2) Remove the inner brake pad 3) Remove the attach bracket from the axle nut 4) Remove the cotter pin 5) Insert the jack stand 6) Jack it up 7) Deflate the tire (I completely remove the valve from the valve stem) 8) Remove the axle nut 9) Slide the wheel & nut off the axle Installation is the reverse -- don't inflate the tire until the wheel halves are captured by the axle nut!!! Be careful, )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "John Brunke" <jwbrunk(at)attglobal.net> Subject: RV7-List: Tire Change > > I'm doing my first tire change on an RV-6 that I bought last year. (starting -7 tail kit this winter). I have one of Vans axle jacks that you slide the tire onto to remove it. > > Since the aircraft has wheel pants the hub nut is solid so I had to remove that before I could install the jack. > > My question: Can you intall the wheel, let the jack down and still get the correct tork on the hub nut while the wheel is resting on the ground? Thanks in advance. > > John Brunke > > ________________________________________________________________________________
Date: Oct 12, 2004
Aerobatics -- do your maneuvers to the left. Stick in right. Formation -- throttle lever/quadrant, not friction control (DEFINITELY not vernier). Shoulder room. Who cares about the passenger? He's lucky he has a stick (when I leave it in) and some pedals, let alone brakes and a throttle. If somebody wants to land your plane, pull the throttle on 'em. If they can't land without power, they aren't landing my plane. Handicap? I flew stick-in-left at first with Alex (training), and I hated it. Fingers on a chalkboard comes to mind. After the first landing I got out and flew from the right instead. It's not like I couldn't fly that way, it's just unnatural for me. Southpaw or not, it went against a pattern that had become very comfortable. My right arm is stronger, and I much prefer to use that arm on the stick. When I do aerobatics, I'm happy that rolling to the left is a push, not a pull. Do it your way. )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Hull, Don" <Donald.C.Hull(at)nasa.gov> Subject: RE: RV7-List: Left hand vs right hand > > I've heard both sides of this discussion several times, too. I'm right > handed and I prefer to fly the plane with the left hand so I can use my > RIGHT hand to adjust throttle, change radio frequencies, write clearances, > etc. Seems the same as a C-150 to me. When I flare in a C-150, I'm flying > the plane with my left hand and have the right hand at the ready on > throttle, flaps, etc. For me, flying from the right seat is awkward, NOT > from the left hand vs. right hand debate, but rather from the visual > appearance over the cowling. If I ever become an instructor, I'm told I > will get used to it. > Don > > -----Original Message----- > From: Kathleen(at)rv7.us [mailto:Kathleen(at)rv7.us] > To: rv7-list(at)matronics.com > Subject: RE: RV7-List: Left hand vs right hand > > > Frank, > I have given this a lot of thought and don't think there is a right (:-) > correct) answer. I like the left-on-the-stick and right hand for throttle > work and radios arrangement. My husband likes to fly from the right seat > most of the time. When he flies solo, he uses the right seat except in the > Mooney which has no brakes on the right. In our situation, the normal > configuration works well. > > Mostly, I believe that whatever you do, you should allow for flight from > either seat. 1) You never know what your future flight circumstance will be > and, 2) You may want to sell your plane some day. > > I don't find any difference in flying left seat or right, but I like the > left seat with left hand on a stick or yoke, so that's going to be my > primary flight position. You really have to sit in an airplane and think > about what works for you. It's your airplane, YOU have to be comfortable. > No one can tell you which is best for you.... > > Kathleen Evans > www.rv7.us > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Hinde, Frank > George (Corvallis) > To: rv7-list(at)matronics.com > Subject: RV7-List: Left hand vs right hand > > > > Hi all, > > I have about 450 hours TT and most of that has been done in my current > zenair zodiac with a center stick. Hence it has two interconnected > throttles, on the left for me and on the right for my PX. > > I had rather nasty incident (crash) in a C152 while trying to land from the > right seat with about 70 hours of experience right after getting my > ticket.....If your saying dumba*s in your head right now, believe me you > wouldn't be the first. > > Most of the crash was caused by the fact I changed hands. > > So of course, the RV7a is throttle in RH and stick in left...i.e opposite to > what I fly now.....hmm... The dumba*s concept is coming into view again. > > So I wondered what you all thought of maybe going for the throttle in the > left and RH on the stick. I note that grand website master Dan Checkoway did > it but the quadrant is a bit on the ugly side for me. With three levers > though I'm not sure what else to do. > > The other issue is that I like to at least give my Wife a fighting chance to > walk away from the wreckage should any of my vital bodily functions decide > to fail...Apparently we only have on heart....What a crappy design that > is....:) > > So that would mean at least a dual interconnected throttle, not easy unless > you have a solid rod rather than cable throttles. > > Any thoughts? > > Frank > > P.s, Dan my lunchtime reading has taken a downturn so could you please > update your website?....:) > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Kathleen(at)rv7.us > To: rv7-list(at)matronics.com > Subject: RE: RV7-List: Builders Log > > > My website and a few other notes are all I do for a builder's log. I track > time in the workshop as time on the project. Feeling that there is no > reasonable way to track it to the minute, I round to half hour increments. > Now, if I could just find more time.... > > Kathleen Evans > www.rv7.us > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of George Neal E Capt > AU/PC > To: rv7-list(at)matronics.com > Subject: RE: RV7-List: Builders Log > > > > I use KitLog to manage the written record and relevant photos of my progress > (and mistakes). I don't particularly like it, but I'm not smart enough to > make it better. And it's paid for. > > For keeping track of time, I use a Hobbs meter to add a little novelty. In > the months leading up to my first sub-kit order, I looked around, called > tractor dealers, marine dealers, leafed through catalogues and web sites > looking for an inexpensive unit. One of the boat shops that I called had a > 110v unit that was intended for a generator - $10. I mounted it and a > switch in a 4" galvanized electrical box. > > Neal George > RV-7 N8ZG, wings > > >I would like to find out how most of you are tracking your time and > >what you are using for a builders log. > > > == > == > == > == > > ________________________________________________________________________________
From: "Chuck aka Charlie Imken" <skikrazi(at)centurytel.net>
Date: Oct 12, 2004
Scott, I gave up on a Cozy MK-IV for a 7A also. After flying RV's a few times, I now realize it was one of the best decisions I ever made. I got my tool kit from Avery. It is enough to get you started but then buying a band saw later from Harbor Freight might help make small parts faster than a hacksaw. A 21 gal air compressor is adequate. Mine is a 17 gal. It still works and my airframe is complete. When cutting the Plexiglas for the canopy, I did have to wait a few times between cuts to let the pressure rebuild....but no real problem though. Chuck Imken ----- Original Message ----- From: "Scott R. Shook" <sshook(at)cox.net> Subject: RV7-List: Air Compressor & Tools > > Greetings everyone, > > I am forgoing building a Cozy MK-IV (maybe 2% done) for an RV-7A for too > many reasons to list and I have a few questions for those willing to answer. > > 1) Which tool kit would you recommend? (i.e. Avery, Cleveland, etc.) > > 2) Would a 21 Gallon air compressor be adequate for the building process? > > Thanks in advance for your guidance. > > Scott Shook > RV-7A (Order Form ready to fax to Vans.) > > ________________________________________________________________________________
Date: Oct 13, 2004
Flying with stick in left or right hand is purely a matter of personal preference. The joy of homebuilding is that you can customise your creation. My choice is right handed sticks and two left handed throttles. Here is how it will be done: Throttle quadrant on left hand of P1. The ideal position for a hand control is 3 inches aft of the knee, at thigh height. So my quadrant will be cut into the armrest. The quadrant will be a 3 lever deal. To keep the dual throttle arrangement simple the centre throttle will be a simple push/pull deal. Both throttle cables will join at the carby, again to keep it simple and minimise friction. Have fun arguing about it, just remember that every home builder is right. David Francis, Canberra, Australia ________________________________________________________________________________
Date: Oct 12, 2004
A year or so ago a passed the email address of John Hafen (Major General) along to someone here because he installed two throttle controls. It is unnerving to be in the right seat and watch the throttle move without seeing any hand on it. Wayne -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Hull, Don Subject: RE: RV7-List: Left hand vs right hand I've heard both sides of this discussion several times, too. I'm right handed and I prefer to fly the plane with the left hand so I can use my RIGHT hand to adjust throttle, change radio frequencies, write clearances, etc. Seems the same as a C-150 to me. When I flare in a C-150, I'm flying the plane with my left hand and have the right hand at the ready on throttle, flaps, etc. For me, flying from the right seat is awkward, NOT from the left hand vs. right hand debate, but rather from the visual appearance over the cowling. If I ever become an instructor, I'm told I will get used to it. Don -----Original Message----- From: Kathleen(at)rv7.us [mailto:Kathleen(at)rv7.us] Subject: RE: RV7-List: Left hand vs right hand Frank, I have given this a lot of thought and don't think there is a right (:-) correct) answer. I like the left-on-the-stick and right hand for throttle work and radios arrangement. My husband likes to fly from the right seat most of the time. When he flies solo, he uses the right seat except in the Mooney which has no brakes on the right. In our situation, the normal configuration works well. Mostly, I believe that whatever you do, you should allow for flight from either seat. 1) You never know what your future flight circumstance will be and, 2) You may want to sell your plane some day. I don't find any difference in flying left seat or right, but I like the left seat with left hand on a stick or yoke, so that's going to be my primary flight position. You really have to sit in an airplane and think about what works for you. It's your airplane, YOU have to be comfortable. No one can tell you which is best for you.... Kathleen Evans www.rv7.us -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Subject: RV7-List: Left hand vs right hand Hi all, I have about 450 hours TT and most of that has been done in my current zenair zodiac with a center stick. Hence it has two interconnected throttles, on the left for me and on the right for my PX. I had rather nasty incident (crash) in a C152 while trying to land from the right seat with about 70 hours of experience right after getting my ticket.....If your saying dumba*s in your head right now, believe me you wouldn't be the first. Most of the crash was caused by the fact I changed hands. So of course, the RV7a is throttle in RH and stick in left...i.e opposite to what I fly now.....hmm... The dumba*s concept is coming into view again. So I wondered what you all thought of maybe going for the throttle in the left and RH on the stick. I note that grand website master Dan Checkoway did it but the quadrant is a bit on the ugly side for me. With three levers though I'm not sure what else to do. The other issue is that I like to at least give my Wife a fighting chance to walk away from the wreckage should any of my vital bodily functions decide to fail...Apparently we only have on heart....What a crappy design that is....:) So that would mean at least a dual interconnected throttle, not easy unless you have a solid rod rather than cable throttles. Any thoughts? Frank P.s, Dan my lunchtime reading has taken a downturn so could you please update your website?....:) -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Kathleen(at)rv7.us Subject: RE: RV7-List: Builders Log My website and a few other notes are all I do for a builder's log. I track time in the workshop as time on the project. Feeling that there is no reasonable way to track it to the minute, I round to half hour increments. Now, if I could just find more time.... Kathleen Evans www.rv7.us -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of George Neal E Capt AU/PC Subject: RE: RV7-List: Builders Log I use KitLog to manage the written record and relevant photos of my progress (and mistakes). I don't particularly like it, but I'm not smart enough to make it better. And it's paid for. For keeping track of time, I use a Hobbs meter to add a little novelty. In the months leading up to my first sub-kit order, I looked around, called tractor dealers, marine dealers, leafed through catalogues and web sites looking for an inexpensive unit. One of the boat shops that I called had a 110v unit that was intended for a generator - $10. I mounted it and a switch in a 4" galvanized electrical box. Neal George RV-7 N8ZG, wings >I would like to find out how most of you are tracking your time and >what you are using for a builders log. == == == == == == == == ________________________________________________________________________________
Date: Oct 13, 2004
john torque is probably not going to be an issue. The axle is drilled with the nut to accept a cotter pin. You will have to hunt the hole to line up with the matching hole in the cap nut. certified planes ususlly have multiple locations to place the cotter pin, ie castle nut or threaded ring, but the rv is custom drilled only in one position. keep the left and right nut separate so they go back on the same axle. cary rhodes --- John Brunke wrote: > > > I'm doing my first tire change on an RV-6 that I > bought last year. (starting -7 tail kit this > winter). I have one of Vans axle jacks that you > slide the tire onto to remove it. > > Since the aircraft has wheel pants the hub nut is > solid so I had to remove that before I could install > the jack. > > My question: Can you intall the wheel, let the jack > down and still get the correct tork on the hub nut > while the wheel is resting on the ground? Thanks in > advance. > > John Brunke > > > > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RV7-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ ________________________________________________________________________________
Date: Oct 13, 2004
Please remove me from the RV7 mailing list. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Kathleen(at)rv7.us Subject: RE: RV7-List: Left hand vs right hand Frank, I have given this a lot of thought and don't think there is a right (:-) correct) answer. I like the left-on-the-stick and right hand for throttle work and radios arrangement. My husband likes to fly from the right seat most of the time. When he flies solo, he uses the right seat except in the Mooney which has no brakes on the right. In our situation, the normal configuration works well. Mostly, I believe that whatever you do, you should allow for flight from either seat. 1) You never know what your future flight circumstance will be and, 2) You may want to sell your plane some day. I don't find any difference in flying left seat or right, but I like the left seat with left hand on a stick or yoke, so that's going to be my primary flight position. You really have to sit in an airplane and think about what works for you. It's your airplane, YOU have to be comfortable. No one can tell you which is best for you.... Kathleen Evans www.rv7.us -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Subject: RV7-List: Left hand vs right hand Hi all, I have about 450 hours TT and most of that has been done in my current zenair zodiac with a center stick. Hence it has two interconnected throttles, on the left for me and on the right for my PX. I had rather nasty incident (crash) in a C152 while trying to land from the right seat with about 70 hours of experience right after getting my ticket.....If your saying dumba*s in your head right now, believe me you wouldn't be the first. Most of the crash was caused by the fact I changed hands. So of course, the RV7a is throttle in RH and stick in left...i.e opposite to what I fly now.....hmm... The dumba*s concept is coming into view again. So I wondered what you all thought of maybe going for the throttle in the left and RH on the stick. I note that grand website master Dan Checkoway did it but the quadrant is a bit on the ugly side for me. With three levers though I'm not sure what else to do. The other issue is that I like to at least give my Wife a fighting chance to walk away from the wreckage should any of my vital bodily functions decide to fail...Apparently we only have on heart....What a crappy design that is....:) So that would mean at least a dual interconnected throttle, not easy unless you have a solid rod rather than cable throttles. Any thoughts? Frank P.s, Dan my lunchtime reading has taken a downturn so could you please update your website?....:) -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Kathleen(at)rv7.us Subject: RE: RV7-List: Builders Log My website and a few other notes are all I do for a builder's log. I track time in the workshop as time on the project. Feeling that there is no reasonable way to track it to the minute, I round to half hour increments. Now, if I could just find more time.... Kathleen Evans www.rv7.us -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of George Neal E Capt AU/PC Subject: RE: RV7-List: Builders Log I use KitLog to manage the written record and relevant photos of my progress (and mistakes). I don't particularly like it, but I'm not smart enough to make it better. And it's paid for. For keeping track of time, I use a Hobbs meter to add a little novelty. In the months leading up to my first sub-kit order, I looked around, called tractor dealers, marine dealers, leafed through catalogues and web sites looking for an inexpensive unit. One of the boat shops that I called had a 110v unit that was intended for a generator - $10. I mounted it and a switch in a 4" galvanized electrical box. Neal George RV-7 N8ZG, wings >I would like to find out how most of you are tracking your time and >what you are using for a builders log. == == == == == == == == ________________________________________________________________________________
Date: Oct 13, 2004
Subject: RV7 primer primer
Hello everyone, I just ordered the tail kit, all the Avery tools, air compressor, a bunch of stuff from harbour freight and signed up for the RV Assembly Sport Air workshop. I have been overseas in the Middle East for the past 12 years following this email list and watching everyones progress on the web, especially Dan Chekoway's fantastic and detailed site. I pretty much went to his tools section and oordered everything he had described there. The last decision to make before beginning is primer. At the risk of irritating eveyone with my first email, I am going to ask a primer question. Before everybody flames me, I will tell you that I have done an extensive search of the matronics list and read as much as I could find about priming all over the web. Doing that actually confused me more. What I would like is to gather is as much opinion as possible on AFS waterborne primer/sealer. There was very little information in the list and almost none on the web with the exception of the AFS website itself and Andy Karmy's RV9 website and an article he wrote for EAA. So flame me if you must but opinions would be appreciated. Andy Bell RV7 or 7A bellwa77(at)aol.com ________________________________________________________________________________
Date: Oct 13, 2004
Subject: Re: RV7 primer primer
I have used the AFS primer on my RV9A (not flying yet). It goes on quite nicely and bonds tenaciously to the aluminum. I frequently paint the parts first and then dimple - the paint takes the dimpling without a whimper. I can't vouch for its long term performance - you will have to look at their website for that information, although the parts I painted almost two years ago look just like they did when first painted. The really nice thing about it is that it is water based so the cleanup is easy and there is no bad smell or dangerous fumes. Dick Tasker Bellwa77(at)AOL.com wrote: > >Hello everyone, > >I just ordered the tail kit, all the Avery tools, air compressor, a bunch of >stuff from harbour freight and signed up for the RV Assembly Sport Air >workshop. I have been overseas in the Middle East for the past 12 years following >this email list and watching everyones progress on the web, especially Dan >Chekoway's fantastic and detailed site. I pretty much went to his tools section and >oordered everything he had described there. The last decision to make before >beginning is primer. > >At the risk of irritating eveyone with my first email, I am going to ask a >primer question. Before everybody flames me, I will tell you that I have done an >extensive search of the matronics list and read as much as I could find about >priming all over the web. Doing that actually confused me more. What I would >like is to gather is as much opinion as possible on AFS waterborne >primer/sealer. There was very little information in the list and almost none on the web >with the exception of the AFS website itself and Andy Karmy's RV9 website and >an article he wrote for EAA. So flame me if you must but opinions would be >appreciated. > >Andy Bell >RV7 or 7A >bellwa77(at)aol.com > > > > ________________________________________________________________________________
Date: Oct 13, 2004
15:05:15, Serialize by Router on slcnot1/SCT(Release 6.0.4|June 01, 2004) at 10/13/2004 15:05:17, Serialize complete at 10/13/2004 15:05:17, Itemize by SMTP Server on sctmnot9/SCT(Release 6.0.4|June 01, 2004) at 10/13/2004 17:05:17, Serialize by Router on sctmnot9/SCT(Release 6.0.4|June 01, 2004) at 10/13/2004 17:05:17, Serialize complete at 10/13/2004 17:05:17 I'm using AFS primer on my empennage kit and have been quite happy with it. I don't think it is quite as tough as 2-part epoxy, but it is wonderful to use. Water clean-up and no noxious fumes. It sprays quite well - I've been using a Harbor Freight HPLV touch-up gun, and use it straight out of the jar. No complaints. Bob Smith -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Bellwa77(at)AOL.com Subject: RV7-List: RV7 primer primer Hello everyone, I just ordered the tail kit, all the Avery tools, air compressor, a bunch of stuff from harbour freight and signed up for the RV Assembly Sport Air workshop. I have been overseas in the Middle East for the past 12 years following this email list and watching everyones progress on the web, especially Dan Chekoway's fantastic and detailed site. I pretty much went to his tools section and oordered everything he had described there. The last decision to make before beginning is primer. At the risk of irritating eveyone with my first email, I am going to ask a primer question. Before everybody flames me, I will tell you that I have done an extensive search of the matronics list and read as much as I could find about priming all over the web. Doing that actually confused me more. What I would like is to gather is as much opinion as possible on AFS waterborne primer/sealer. There was very little information in the list and almost none on the web with the exception of the AFS website itself and Andy Karmy's RV9 website and an article he wrote for EAA. So flame me if you must but opinions would be appreciated. Andy Bell RV7 or 7A bellwa77(at)aol.com ________________________________________________________________________________
Date: Oct 13, 2004
Welcome Andy My tail has an assortment of SW-988 (expensive garbage), Rustoleum (what was I thinking) and VeriPrime (good stuff, but needs a topcoat). Were I to start over, I'd use AFS to prime the contact points where dissimilar metals meet and alodine the extruded parts. Leave the rest of it as-is. The other primers are all great as an integral part of their respective finishing systems, but according to all the literature and sales reps, offer no moisture barrier - they are intended to be top-coated. Without a top-coat they are porous and would actually attract and wick moisture and the stuff dissolved in it. I used screws and nutplates to mount my fiberglass tips. I still don't like the idea of using pop rivets. After the plane is painted I will treat it with Corrosion-X. Can't do that with the tips on. Neal RV-7 N8ZG Wings - and short on clecos ________________________________________________________________________________
From: "Brian Meyette" <brianpublic(at)starband.net>
Date: Oct 13, 2004
What exactly is the AFS the last 3 messages referred to? brian -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of George Neal E Capt AU/PC Subject: RE: RV7-List: RV7 primer primer Welcome Andy My tail has an assortment of SW-988 (expensive garbage), Rustoleum (what was I thinking) and VeriPrime (good stuff, but needs a topcoat). Were I to start over, I'd use AFS to prime the contact points where dissimilar metals meet and alodine the extruded parts. Leave the rest of it as-is. The other primers are all great as an integral part of their respective finishing systems, but according to all the literature and sales reps, offer no moisture barrier - they are intended to be top-coated. Without a top-coat they are porous and would actually attract and wick moisture and the stuff dissolved in it. I used screws and nutplates to mount my fiberglass tips. I still don't like the idea of using pop rivets. After the plane is painted I will treat it with Corrosion-X. Can't do that with the tips on. Neal RV-7 N8ZG Wings - and short on clecos --- --- ________________________________________________________________________________
Date: Oct 13, 2004
Brian Meyette wrote: > > What exactly is the AFS the last 3 messages referred to? Aircraft Finishing Systems: http://www.aircraftfinishing.com They manufacture and sell water based polyurethane paints. -- Tim Coldenhoff #90338 - Finishing! http://rv9a.deru.com ________________________________________________________________________________
Date: Oct 14, 2004
From: "Richard E. Tasker" <retasker(at)optonline.net>
http://www.aircraftfinishing.com/ Dick Tasker Brian Meyette wrote: > >What exactly is the AFS the last 3 messages referred to? >brian > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of George Neal E Capt >AU/PC >To: rv7-list(at)matronics.com >Subject: RE: RV7-List: RV7 primer primer > > > >Welcome Andy > >My tail has an assortment of SW-988 (expensive garbage), Rustoleum (what was >I thinking) and VeriPrime (good stuff, but needs a topcoat). > >Were I to start over, I'd use AFS to prime the contact points where >dissimilar metals meet and alodine the extruded parts. Leave the rest of it >as-is. The other primers are all great as an integral part of their >respective finishing systems, but according to all the literature and sales >reps, offer no moisture barrier - they are intended to be top-coated. >Without a top-coat they are porous and would actually attract and wick >moisture and the stuff dissolved in it. > >I used screws and nutplates to mount my fiberglass tips. I still don't like >the idea of using pop rivets. After the plane is painted I will treat it >with Corrosion-X. Can't do that with the tips on. > >Neal >RV-7 N8ZG >Wings - and short on clecos > > >--- > >--- > > > > ________________________________________________________________________________
Date: Oct 14, 2004
Thanks, Dick! I believe you were working on an alternative electrical system for the Eggenfellner engines. How is that coming along? brian -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Richard E. Tasker Subject: Re: RV7-List: RV7 primer primer http://www.aircraftfinishing.com/ Dick Tasker Brian Meyette wrote: > >What exactly is the AFS the last 3 messages referred to? >brian > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of George Neal E Capt >AU/PC >To: rv7-list(at)matronics.com >Subject: RE: RV7-List: RV7 primer primer > > > >Welcome Andy > >My tail has an assortment of SW-988 (expensive garbage), Rustoleum (what was >I thinking) and VeriPrime (good stuff, but needs a topcoat). > >Were I to start over, I'd use AFS to prime the contact points where >dissimilar metals meet and alodine the extruded parts. Leave the rest of it >as-is. The other primers are all great as an integral part of their >respective finishing systems, but according to all the literature and sales >reps, offer no moisture barrier - they are intended to be top-coated. >Without a top-coat they are porous and would actually attract and wick >moisture and the stuff dissolved in it. > >I used screws and nutplates to mount my fiberglass tips. I still don't like >the idea of using pop rivets. After the plane is painted I will treat it >with Corrosion-X. Can't do that with the tips on. > >Neal >RV-7 N8ZG >Wings - and short on clecos > > >--- > >--- > > --- --- ________________________________________________________________________________
Date: Oct 14, 2004
Well, the one I originally designed for my plane is basically done except for final testing. However, the one I volunteered to design for the Subaru group didn't go anywhere because everyone had different opinions on what they wanted it to do - many of them conflicting. So I ended up doing nothing more on it. Dick Tasker Brian Meyette wrote: > >Thanks, Dick! I believe you were working on an alternative electrical >system for the Eggenfellner engines. How is that coming along? >brian > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Richard E. Tasker >To: rv7-list(at)matronics.com.Gecko/20040803 >Subject: Re: RV7-List: RV7 primer primer > > >http://www.aircraftfinishing.com/ > >Dick Tasker > >Brian Meyette wrote: > > > >> >>What exactly is the AFS the last 3 messages referred to? >>brian >> >>-----Original Message----- >>From: owner-rv7-list-server(at)matronics.com >>[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of George Neal E Capt >>AU/PC >>To: rv7-list(at)matronics.com >>Subject: RE: RV7-List: RV7 primer primer >> >> >> >>Welcome Andy >> >>My tail has an assortment of SW-988 (expensive garbage), Rustoleum (what >> >> >was > > >>I thinking) and VeriPrime (good stuff, but needs a topcoat). >> >>Were I to start over, I'd use AFS to prime the contact points where >>dissimilar metals meet and alodine the extruded parts. Leave the rest of >> >> >it > > >>as-is. The other primers are all great as an integral part of their >>respective finishing systems, but according to all the literature and sales >>reps, offer no moisture barrier - they are intended to be top-coated. >>Without a top-coat they are porous and would actually attract and wick >>moisture and the stuff dissolved in it. >> >>I used screws and nutplates to mount my fiberglass tips. I still don't >> >> >like > > >>the idea of using pop rivets. After the plane is painted I will treat it >>with Corrosion-X. Can't do that with the tips on. >> >>Neal >>RV-7 N8ZG >>Wings - and short on clecos >> >> >>--- >> >>--- >> >> >> >> > > >--- > >--- > > > > ________________________________________________________________________________
Date: Oct 14, 2004
Subject: Slobovia Outernational BBQ 2 day warning
We hope to see you here at Slobovia Outernational Saturday morning to eat BBQ & talk airplanes. We expect to have a good turnout of homebuilts & classics, with some alternative engines in the mix. Info on Slobovia (MS71) can be found at http://www.airnav.com/airport/MS71 or you can email me direct for driving directions. Charlie flying RV-4; RV-7 wings ________________________________________________________________________________
Date: Oct 15, 2004
Thanks for all the responses on the AFS primer and primer in general. Based on your responses and Dan's new outlook on priming, I will probably go with AFS on non Alclad parts and Alclad that has been scratched up. I am not sure about priming the Alcad parts in general because I wonder if the AFS ectching stuff destroys the Alclad protection. I have four kids and a dog running around here and just don't want to mess with that nasty stuff. I wonder if alot of us have been obsessing over priming these things anyway. This plane probably outlive me without primer. Frank, I'll give you a call if (when?) I get stuck. I am really going to put Van's claim to the test that someone with average skills can build one of these. I had trouble getting the wheels on my compressor! HA Dan, I'll be placing an order for your DVD website in the near furture. Thanks again RV7? or RV7A?, Tip Up? or Slider? ________________________________________________________________________________
Date: Oct 15, 2004
Bellwa77(at)AOL.com wrote: > >Thanks for all the responses on the AFS primer and primer in general. Based >on your responses and Dan's new outlook on priming, I will probably go with AFS >on non Alclad parts and Alclad that has been scratched up. I am not sure >about priming the Alcad parts in general because I wonder if the AFS ectching >stuff destroys the Alclad protection. > > Unless you get really violent with the abrasive pads, the etching cleaner only etches the oxide off of the surface of the alclad and roughs up the surface microscopically so if you want to prime the alclad do it without worries. On the other hand, depending where you live and will keep your plane, painting the alclad may be entirely unnecessary and a waste of time. I did prime mine with AFS since I may end up living near the coast (salt air and all) when I retire in a few years. Whether it will really make any difference my grandchildren will have to find out (and my sons are still in college). Dick Tasker ________________________________________________________________________________
Date: Oct 15, 2004
Subject: Re: Builders Log
In a message dated 10/12/04 10:41:42 AM US Eastern Standard Time, Neal.George(at)maxwell.af.mil writes: > > For keeping track of time, I use a Hobbs meter to add a little novelty. In > the months leading up to my first sub-kit order, I looked around, called > tractor dealers, marine dealers, leafed through catalogues and web sites > looking for an inexpensive unit. One of the boat shops that I called had a > 110v unit that was intended for a generator - $10. I mounted it and a > switch in a 4" galvanized electrical box. > > Neal George > RV-7 N8ZG, wings Neal, That's a great idea. I'm going to do that on my next project. As soon as I recuperate from building my first airplane. Dan Hopper RV-7A N766DH (Flying about 60 hours.) ________________________________________________________________________________
Date: Oct 16, 2004
Subject: Re: Rudder question
Dave; According to Van's you don't actually need Proseal in the rudder. Go to the FAQ page on the Van's website and download the PDF called "materials used in Van's aircraft." It's 24 pages of very useful stuff, including this: ========== Before doing the final riveting, put a dab of RTV or tank sealant at the inside of the skin where the two stiffeners overlap. This will tie the stiffeners together. A dab about the size of some chewing gum will do the job and prevent the skins from cracking at this point due to vibration. =========== So, all you need is some sort of goop in there....doesn't need to be Proseal. Andrew Douglas Bridgeport, CT RV wannabe ________________________________________________________________________________
Date: Oct 16, 2004
I was just at the AFS website looking at the page for the primer/sealer, and saw this: ===== Spraying - reduce with distilled water to 20-25 seconds Dupont M50. ===== Which I assume means to thin it to a certain point. Dupont M50 is obviously a measure of viscosity...possibly measured by pouring a liquid through a calibrated funnel and timing it??? Is anyone who's using the AFS primer doing this? Is there some sort of tool used to measure it? Andrew Douglas Bridgeport, CT RV wannabe ________________________________________________________________________________
Date: Oct 16, 2004
Subject: Re: RV7 primer primer - Dupont M50
Andrew I use AFS and found my viscocity cup (Dupont M50) at a local Auto paint store. Frank @SGU & SLC --------------------------------- vote.yahoo.com - Register online to vote today! ________________________________________________________________________________
Date: Oct 18, 2004
10:18:37, Serialize by Router on slcnot1/SCT(Release 6.0.4|June 01, 2004) at 10/18/2004 10:18:39, Serialize complete at 10/18/2004 10:18:39, Itemize by SMTP Server on sctmnot9/SCT(Release 6.0.4|June 01, 2004) at 10/18/2004 12:18:39, Serialize by Router on sctmnot9/SCT(Release 6.0.4|June 01, 2004) at 10/18/2004 12:18:41, Serialize complete at 10/18/2004 12:18:41 You can order the viscosity cup with the paint from AFS. I actually have not thinned mine at all - the primer seems about right straight out of the bottle, and sprays fine with my touch-up gun. But you can use the cup and thin if you so desire to make sure it is "perfect." Bob -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Andrew Douglas Subject: RV7-List: Re: RV7 primer primer I was just at the AFS website looking at the page for the primer/sealer, and saw this: ===== Spraying - reduce with distilled water to 20-25 seconds Dupont M50. ===== Which I assume means to thin it to a certain point. Dupont M50 is obviously a measure of viscosity...possibly measured by pouring a liquid through a calibrated funnel and timing it??? Is anyone who's using the AFS primer doing this? Is there some sort of tool used to measure it? Andrew Douglas Bridgeport, CT RV wannabe ________________________________________________________________________________
Date: Oct 18, 2004
Subject: CP 214 squeezer
Does anyone have a manual for the 214 squeezer? Thanks Dave Figgins empennage (wing kit in December) ________________________________________________________________________________
Date: Oct 23, 2004
Subject: [ Neal George ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Neal George Subject: 110v Hobbs Meter http://www.matronics.com/photoshare/Neal.George@MAXWELL.AF.MIL.10.23.2004/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject: Squeezing out bad rivets
Date: Oct 25, 2004
I'm a beginning riveter, and I've just started trying to rivet the Vertical stabilizer main spar to the doubler plate with some 470AD4-6's (RV7). I'm somewhat new to this and slightly frustrated with the results I've been getting so far. The rivets all seem to begin to 'glance' off toward the C-shape portion of the yoke and then fall to one side and look ugly or sometimes I end up shearing a portion of the shop head. I've tried different techniques including the latest: squeezing ever-so-slightly and re-aligning the squeezer to attempt to straighten it out; but having no luck most of the time. I probably have <30-40% acceptance rate, far from zero non-conformance =) I have the Tatco squeezer, and have helped a friend squeeze these rivets on her RV-9, with the same type of squeezer and sets with no problem and not nearly as much fuss. Has anyone else had issues with these damn AD4's? Here's my current troubleshooting list: 1. Correct length? As far as I can tell, yes. The print calls for -6 rivets, and in measuring the combined metal thickness of 0.161 and the 1/8" diameter x1.5 brings me to ~0.349 which is just too long for a -5.5 rivet (.3125). The -6 is .375. I also am convinced that .026 too long will not cause such a toppling over of the rivet. 2. Rivet quality/age? The bag is dated 08/27/2004 for the -6's and 4/21/04 for the -5's, don't think there should be any material composition/structure change that rapidly unless they were in a big container sitting on a shelf for a while before bagging... I have similar problems with -4 -5 -6 and -7's, both in and out of metal 3. Squeezer. Is the yoke slightly off at one end? I know these are high quality squeezers, but does anyone think that a slight misalignment might push the rivets toward the inside of the C? Kind of wishing I had someone else's squeezer to try for a while... this seems to be the most plausable reason so far. 4. Sets. Does having a slightly convexed flush set have any bearing on this problem? I put two flush sets in the squeezer for grins and brought them together to find them only touching in the center - they aren't perfectly flat. Should I try to sand one flat? I really don't think this is the problem either. What am I missing? Any thoughts would be extremely helpful! Thanks, Andy Olech Ellington, CT RV-7 Tail section on hold until my inability to set rivets disappears magically. ________________________________________________________________________________
Date: Oct 25, 2004
Subject: Re: Squeezing out bad rivets
In a message dated 10/25/04 9:15:15 PM US Eastern Standard Time, olechap(at)comcast.net writes: > 4. Sets. Does having a slightly convexed flush set have any bearing on > this > problem? I put two flush sets in the squeezer for grins and brought them > together to find them only touching in the center - they aren't perfectly > flat. Should I try to sand one flat? I really don't think this is the > problem either. > > What am I missing? Any thoughts would be extremely helpful! > > Thanks, > > Andy Olech > Ellington, CT > Andy, It is necessary to be really well centered on the rivet. Put a rivet in your squeezer (no sheet metal, just the rivet) and center it up real well. When you squeeze it, it should only get fatter, not bend over. Maybe your yoke is not strong enough for the -4 rivets. It sounds like it may be deflecting, and bending the rivets for that reason. A yoke with less reach will be stiffer, and may fix your problem. Hang in there. You'll be an expert in a few weeks. Dan Hopper RV-7A N766DH ________________________________________________________________________________
Date: Oct 25, 2004
I don't have a hand squeezer, but all squeezers work basically the same, so comments below... Andrew Olech wrote: >1. Correct length? As far as I can tell, yes. The print calls for -6 >rivets, and in measuring the combined metal thickness of 0.161 and the 1/8" >diameter x1.5 brings me to ~0.349 which is just too long for a -5.5 rivet >(.3125). The -6 is .375. I also am convinced that .026 too long will not >cause such a toppling over of the rivet. > > Unless the rivets are a lot too long, they will work. Being 0.026 too long in definitely no problem. If it was, we wouldn't be able to build the plane without cutting a lot of rivets.. By the way, -5.5 should be 0.3438, not 0.3125 (that is -5). >2. Rivet quality/age? The bag is dated 08/27/2004 for the -6's and 4/21/04 >for the -5's, don't think there should be any material composition/structure >change that rapidly unless they were in a big container sitting on a shelf >for a while before bagging... I have similar problems with -4 -5 -6 >and -7's, both in and out of metal > > Shouldn't be a problem with the rivets from Van's. In fact, the rivets used are not really susceptible to change in characteristics due to aging in any reasonable timeframe (years). >3. Squeezer. Is the yoke slightly off at one end? I know these are high >quality squeezers, but does anyone think that a slight misalignment might >push the rivets toward the inside of the C? Kind of wishing I had someone >else's squeezer to try for a while... this seems to be the most plausable >reason so far. > > I would bet on this if you have been able to squeeze rivets correctly with someone else's squeezer (that you indicated earlier in the email). Especially so if the rivet always bends in the one direction that you seem to indicate. Any way to borrow hers for a day? >4. Sets. Does having a slightly convexed flush set have any bearing on this >problem? I put two flush sets in the squeezer for grins and brought them >together to find them only touching in the center - they aren't perfectly >flat. Should I try to sand one flat? I really don't think this is the >problem either. > > This is the normal shape for the flush sets. If they were flat, they would mar the aluminum unless you kept them EXACTLY perpendicular to the rivet/aluminum being set. Dick Tasker ________________________________________________________________________________
From: "Francis, David CMDR" <David.Francis(at)defence.gov.au>
Date: Oct 26, 2004
Andrew, I am going to be adventurous and attempt coaching across 10,000 miles. My first observation is that unless you are a weight lifter or gorilla hand squeezing AD4 rivets is very difficult. I hand squeeze AD3 only, AD4 are just beyond me and I either rivet them or use a pneumatic squeezer. So my advice is avoid the problem altogether and use a different tool, preferably powered. A personal view, but I don't like the Tatco squeezers, and prefer the much more substantial Avery squeezer. I would only use a Tatco where I have a confined space that the smaller Tatco will go where the Avery wont. If you choose to stick to a hand squeezer push hard on the manufactured head while squeezing the handle, and keeping the squeezer straight. You will need heaps of strength to do this with an AD4 rivet. Email me offline if you need elaboration. Regards, David Francis, VH-ZEE, Canberra, Australia. -----Original Message----- From: Andrew Olech [mailto:olechap(at)comcast.net] Subject: RV7-List: Squeezing out bad rivets I'm a beginning riveter, and I've just started trying to rivet the Vertical stabilizer main spar to the doubler plate with some 470AD4-6's (RV7). I'm somewhat new to this and slightly frustrated with the results I've been getting so far. ________________________________________________________________________________
Date: Oct 26, 2004
I may be stating the obvious here, but be sure to hold the squeezer handle that is in line with the rivet shank stationary and move the other handle toward it- if you move both handles toward each other the shop head will almost certainly bend over. I don't own a pneumatic squeezer. The 1/8" rivets take a little oomph but are certainly do-able by hand. Good luck! Jim ________________________________________________________________________________
Date: Oct 26, 2004
Unless I am missing something in your writing you should be using a cupped set of rivet sets, I ordered 2 of them from the yardstore.com. One side of the rivet set is flat (obvious) the other for setting 470 or universal rivets is convex. The rivet when held to the set should sit inside with only a small amount of the rivet head showing. Second I put the cupped set in the top of the squeezer and the flat set in the movable or bottom of the tool. I then pull the rivet down to ensure a tight contact with the metal and squeeze. You could alternate the sets in the tool as well. When finished the domed head should look as good as a new one if you are applying pressure to hold the squeezer tight to the head of the rivet. I hope this helps. T.S. 7A finishing ________________________________________________________________________________
Subject: Pitot tubing question
Date: Oct 26, 2004
I am completing my left wing (RV-7) and getting ready to install the pitot tubing. The plans are a bit unclear in this area. I know the tubing passes through the snap bushing to the wing root, however how have most of you terminated the tubing. Did you leave a short length (at the root), flare it and bend it 90 degrees. Did you install a 90 degree bulkhead fitting in the root rib? If so what was your procedure for flaring the end? Any help would be appreciated. Paul ________________________________________________________________________________
Date: Oct 26, 2004
Paul I used nylo seal tubing and no fittings from about a foot from the pitot to the inside of the cabin. It is basically the same method that Dan C used. There are pictures on my web site. Don VS -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Merems rv7-list(at)matronics.com; RV-9A(at)yahoogroups.com; rv9-list(at)matronics.com Subject: RV7-List: Pitot tubing question I am completing my left wing (RV-7) and getting ready to install the pitot tubing. The plans are a bit unclear in this area. I know the tubing passes through the snap bushing to the wing root, however how have most of you terminated the tubing. Did you leave a short length (at the root), flare it and bend it 90 degrees. Did you install a 90 degree bulkhead fitting in the root rib? If so what was your procedure for flaring the end? Any help would be appreciated. Paul ________________________________________________________________________________
Subject: Re: Pitot tubing question
Date: Oct 26, 2004
Paul, Be sure to check the latest construction FAQ on Van's site about pitot tubing routing. If I recall they recommend that the tubing come inboard of the root rib below and aft of the largest (forward-most) lightening hole. I wish I knew this up front -- it's where I ended up routing mine in the long run. The fuselage has stuff in the way that you can't really penetrate if you try to run the pitot tubing along the spar web. You gotta go aft and low. I recommend a similar location for wiring run/conduit. I put mine up and forward and that's FAR from ideal. Hope this helps...keep it in mind when you decide how you want the tubing to exit the wing and enter the fuselage. http://www.vansaircraft.com/pdf/Wing_Wiring.pdf )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "DonVS" <dsvs(at)comcast.net> Subject: RE: RV7-List: Pitot tubing question > > Paul > I used nylo seal tubing and no fittings from about a foot from the pitot to > the inside of the cabin. It is basically the same method that Dan C used. > There are pictures on my web site. Don VS > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Merems > To: RV-8(at)yahoogroups.com; RV10 Group; RV7and7A(at)yahoogroups.com; > rv7-list(at)matronics.com; RV-9A(at)yahoogroups.com; rv9-list(at)matronics.com > Subject: RV7-List: Pitot tubing question > > > I am completing my left wing (RV-7) and getting ready to install the pitot > tubing. The plans are a bit unclear in this area. I know the tubing passes > through the snap bushing to the wing root, however how have most of you > terminated the tubing. Did you leave a short length (at the root), flare it > and bend it 90 degrees. Did you install a 90 degree bulkhead fitting in the > root rib? If so what was your procedure for flaring the end? > > Any help would be appreciated. > > Paul > > ________________________________________________________________________________
From: "Steve Sampson" <SSampson.SLN21(at)london.edu>
Date: Oct 27, 2004
Andrew - a slightly different perspective to most of the other replies. I have just squeezed the last rivet on an RV9a (though not flown it yet) and I have done it all with a Tatco squeezer and a 2X gun. I am no expert but most of my rivets are OK and I always preferred squeezing to gunning. It is tiring on the hands though and if building a second I might get a bit more oomph to save my hands. Perhaps a main squeeze. My thought is that you are probably not getting the rivets quite in the center of the dies since early on when I had them off centre I had similar problems. In view of the fact that the dies are as you say convex this appears to matter. Hope this helps, you will win! Also make sure there is no crap UNDER the die where it slots in, and check them for symetry. By the way do keep an eye on the rivet call out for accuracy. I am sure, thinking back, some of the required lengths were too long when calculated. This is true of bolts also. Good luck, Steve. --- ________________________________________________________________________________
Date: Oct 27, 2004
Subject: RV6 160 horse..
Hey guys- When filing a flight plan with an RV6 on a 160 horse, what airspeed do you file for? :) Jeff ________________________________________________________________________________
Date: Oct 27, 2004
Hey guys- When filing a flight plan with an RV6 on a 160 horse, what airspeed do you file for? :) Jeff ----------------------------------------------------- RV6-A 160 HP F/P (79") Sensenich @ 60-65% power = 145Kts and 7.95 US/GPH average burn coast to coast & return. George in Langley BC. ________________________________________________________________________________
Date: Oct 27, 2004
Subject: Re: RV6 160 horse..
Thanks.. that solves a mild argument between myself and a friend. ----- Original Message ----- From: "GMC" <gmcnutt(at)shaw.ca> Subject: RE: RV7-List: RV6 160 horse.. > > > Hey guys- > > When filing a flight plan with an RV6 on a 160 horse, what airspeed do you > file for? :) > > Jeff > > ----------------------------------------------------- > > RV6-A 160 HP F/P (79") Sensenich @ 60-65% power = 145Kts and 7.95 US/GPH > average burn coast to coast & return. > > George in Langley BC. > > ________________________________________________________________________________
Subject: RV Newbie Question
Date: Oct 27, 2004
Hi All- I just completed my RV-7 HS from an early kit that required building the jig. While I was looking over my work (and a few minor mistakes).I noticed something that has me concerned. On the top left hand skin closest to the root and furthest aft I have a very slight amount of "oil canning". The skin feels like it should be a little tighter in this area. If I press down lightly on the trailing edge of the HS it feels a bit better, but still just a little less taught than the opposite side. I was wondering if anyone had ever experienced this. And if so what they did to rectify it. I am only about 30 min from Vans and am considering picking up a new HS to complete while I await the arrival of my QB in February. The second one always comes out better right? Any help would be greatly appreciated! Thanks- Dan Dan Reed Qualcomm Wireless Business Solutions Office 800-544-4977 ext 86694 Mobile 503-260-2499 ________________________________________________________________________________
Subject: sec: unclassified - Newbie Question: OIL CANNING
Date: Oct 28, 2004
Dan, There is an unwritten convention among RV builders at fly-ins - never look too hard at, or offer criticism of, a fellow builders empenage - that is where the learning curve is. So please show me the empennage that does no have some oil canning. By all means seek advice from Vans, but I am pretty sure that the advice will be - ignore it. It is unlikely to be an airworthiness problem. If you have ever flown in an aluminium glider (L13 Blanik)in turbulence or aeros you will hear a symphony of oil can bongs boings and bangs. The only sure fire way to avoid oil canning is to get a hot air blower as used on heat shrink and warm the area you are riveting. It will cool after riveting to a lovely taught finish. Once you have built in oil canning it will be there for you to admire forever. Keep on building - you can look forward to much bigger mistakes to solve - trust me, but dont ask me how I know. Regards, VH-ZEE, Canberra, Australia ________________________________________________________________________________
Subject: lights
Date: Oct 28, 2004
Does anyone have any comments (pro or con) on the CreativAir position/landing lights? Nelson Tower RV7 wings fuse on order ________________________________________________________________________________
Subject: Re: lights
Date: Oct 28, 2004
Nelson, I ordered the two kits and they are due to show up at my door today. I will let you know how look. The owner (Bill Vondane has been busy in his other profession (Like all of us) and it took a couple emails to get it shipped, but he seems like a very nice and accommodating person. I am looking forward to receiving and installing the kits. Richard Glick ----- Original Message ----- From: <nltiiii(at)bellsouth.net> Subject: RV7-List: lights > > Does anyone have any comments (pro or con) on the CreativAir > position/landing lights? > > Nelson Tower > RV7 wings > fuse on order > > > ________________________________________________________________________________
Date: Oct 28, 2004
Hi Dan. As far as I know, the RV-7 does not require a jig (as opposed to a building platform) to build the HS, or any of the other major components. As a matter of fact, I understand that Vans discourages the use of a jig. Part of the concept of the pre-punched holes is that no jig is needed and if you force the part into a jig you might actually build it out of alignment. Your "oil-canning" problem might be a symptom of this. Mike Neff (RV-7 builder) -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Dan Reed Subject: RV7-List: RV Newbie Question Hi All- I just completed my RV-7 HS from an early kit that required building the jig. While I was looking over my work (and a few minor mistakes).I noticed something that has me concerned. On the top left hand skin closest to the root and furthest aft I have a very slight amount of "oil canning". The skin feels like it should be a little tighter in this area. If I press down lightly on the trailing edge of the HS it feels a bit better, but still just a little less taught than the opposite side. I was wondering if anyone had ever experienced this. And if so what they did to rectify it. I am only about 30 min from Vans and am considering picking up a new HS to complete while I await the arrival of my QB in February. The second one always comes out better right? Any help would be greatly appreciated! Thanks- Dan Dan Reed Qualcomm Wireless Business Solutions Office 800-544-4977 ext 86694 Mobile 503-260-2499 ________________________________________________________________________________
Date: Oct 29, 2004
Subject: Re: RV Newbie Question
Neff, Mike wrote: > As far as I know, the RV-7 does not require a jig (as opposed to a > building platform) to build the HS, or any of the other major > components. As a matter of fact, I understand that Vans discourages > the use of a jig. Part of the concept of the pre-punched holes is > that no jig is needed and if you force the part into a jig you might > actually build it out of alignment. Your "oil-canning" problem might > be a symptom of this. You must have one of the later -7 kits if that was the case. Early -7 tail kits weren't fully pre-punched, the ribs and front spar came un-punched and you have to align them with the (pre-punched) skins to mark the holes. I wouldn't want to do that without a jig. Later (and current) -7 tail kits come fully punched, so completely that you can assemble the entire HS with clecos straight out of the box. I can see where that would remove the need for a jig, but if your jig is true I doubt it would hurt. -Rob ________________________________________________________________________________
Date: Oct 29, 2004
Subject: Wiring
Gentlemen: I am building a RV-7 QB and am at the point where I am thinking about the wingtip landing lights/position lights and the general wiring of the aircraft. This is where I need help. I don't know what gauge or type of wire goes where. Should I get one of those wiring harnesses from Van's (I've heard that they are too much for what you get) or build my own wire by wire? Bob in Austin ________________________________________________________________________________
Subject: Wiring
Date: Oct 29, 2004
My Suggestions 1) Start by going to http://www.aeroelectric.com/ and ordering Bob's book 2) Try to attend one of his seminars 3) Subscribe to the AeroElectric-List to ask electrical questions http://www.matronics.com/subscription 4) Have your radios, intercom and navigational equipment pre-wired if you can 5) Wire the rest of the airplane yourself Ross Mickey N9PT -----Original Message----- Gentlemen: I am building a RV-7 QB and am at the point where I am thinking about the wingtip landing lights/position lights and the general wiring of the aircraft. This is where I need help. I don't know what gauge or type of wire goes where. Should I get one of those wiring harnesses from Van's (I've heard that they are too much for what you get) or build my own wire by wire? Bob in Austin ________________________________________________________________________________
Date: Oct 29, 2004
Subject: Re: Wiring
Bob, One place to start is to obtain Van's documentation and wiring diagrams before you decide to order the kit. If you know of anyone close to you, maybe you can look over their diagrams. The individual circuits are very simple, but there a lot of little decisions to make. The wire sizes, etc., are called out in Van's plans. Hope this helps, Dan Hopper RV-7A N766DH -- Flying since 7/7/04 -- 60+ hours In a message dated 10/29/04 11:05:52 AM US Eastern Standard Time, oai(at)direcway.com writes: > > Gentlemen: > I am building a RV-7 QB and am at the point where I am thinking about the > wingtip landing lights/position lights and the general wiring of the aircraft. > This is where I need help. > I don't know what gauge or type of wire goes where. Should I get one of > those wiring harnesses from Van's (I've heard that they are too much for what > you get) or build my own wire by wire? > Bob in Austin > > ________________________________________________________________________________
From: "Stan & Aylene Bahrns" <bahrns(at)effingham.net>
Subject: Wiring
Date: Oct 30, 2004
Bob, Attached is a jpeg of my cad drawing of what I am using to wire my RV7-A. The wire numbers are mostly the same as van's wiring diagram numbers & I also have most of the guage wire that is to be used on each wire & have also labeled each wire under clear shrink tubing as to where it goes. Hope it is of some assistance. Stan Bob, One place to start is to obtain Van's documentation and wiring diagrams before you decide to order the kit. If you know of anyone close to you, maybe you can look over their diagrams. The individual circuits are very simple, but there a lot of little decisions to make. The wire sizes, etc., are called out in Van's plans. Hope this helps, Dan Hopper RV-7A --- ________________________________________________________________________________
Subject: Pitot Tubing routing-continued
Date: Oct 30, 2004
1.27 SUBJ_HAS_UNIQ_ID Subject contains a unique ID Fellow RV builders, I am finishing my RV-7 wings and installing the standard pitot tube system. I emailed the group and received some very good information. Most builders are using nylon tubing and transitioning from the aluminum tube somewhere in the wing. However if you follow Van's instructions and use the "center" hole in the main ribs, the aluminum tubing will block access to the center fuel tank "Z" bracket bolt, not a good thing. So it appears to me that if you are going to run the tubing down the "center" hole, you better transition to nylon tubing before it blocks the bolt. This means you really need to transition to nylon tubing right behind the AN bulkhead fitting for the pitot tube. Am I off base? If I knew of this before I skinned (top skin) my wings, I might have drilled a tube routing hole further aft in the main rib to accommodate the aluminum tubing. Paul (RV-4/RV-7A) ________________________________________________________________________________
Date: Oct 30, 2004
I drilled new routing holes and ran aluminum all the way in to the wing root where I installed an AN fitting. That way there is no splice transition point in the line to cause future trouble, I could route it where it was out of the way and I don't have to worry about it in the future. It's not really any heavier and it's simple to do. Kathleen Evans www.rv7.us -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Merems RV-8(at)yahoogroups.com; rv7-list(at)matronics.com; RV7and7A(at)yahoogroups.com Subject: RV7-List: Pitot Tubing routing-continued Fellow RV builders, I am finishing my RV-7 wings and installing the standard pitot tube system. I emailed the group and received some very good information. Most builders are using nylon tubing and transitioning from the aluminum tube somewhere in the wing. However if you follow Van's instructions and use the "center" hole in the main ribs, the aluminum tubing will block access to the center fuel tank "Z" bracket bolt, not a good thing. So it appears to me that if you are going to run the tubing down the "center" hole, you better transition to nylon tubing before it blocks the bolt. This means you really need to transition to nylon tubing right behind the AN bulkhead fitting for the pitot tube. Am I off base? If I knew of this before I skinned (top skin) my wings, I might have drilled a tube routing hole further aft in the main rib to accommodate the aluminum tubing. Paul (RV-4/RV-7A) ________________________________________________________________________________
Subject: Re: lights
Date: Oct 31, 2004
So far I have installed three sets in customers RVs and they have no complaints. The light they project is better then the wing mounted from the kit manufacturer. I am about to install the LED setup next and looking forward to it. ----- Original Message ----- From: "Rick" <richardglick(at)charter.net> Subject: Re: RV7-List: lights > > Nelson, > > I ordered the two kits and they are due to show up at my door today. I > will let you know how look. The owner (Bill Vondane has been busy in his > other profession (Like all of us) and it took a couple emails to get it > shipped, but he seems like a very nice and accommodating person. I am > looking forward to receiving and installing the kits. > > Richard Glick > ----- Original Message ----- > From: <nltiiii(at)bellsouth.net> > To: > Subject: RV7-List: lights > > > > > > Does anyone have any comments (pro or con) on the CreativAir > > position/landing lights? > > > > Nelson Tower > > RV7 wings > > fuse on order > > > > > > > > ________________________________________________________________________________
From: "David Figgins" <2004nospam(at)earthlink.net>
Subject: RV7 QB tanks
Date: Oct 31, 2004
I think I may have run into a problem and need some advice, I have the wing kit on order with the QB tanks (due in December), and in reading the drawings and instruction this past couple of days I noticed a tank mod is required for inverted flight that adds a flop tube in the standard vent line area and moves the sender outboard one station. I am assuming the QB tanks are in the standard configuration. Questions therefore are 1) can the tank be modified for this mod after it is complete (i.e. can you get access and keep inside clean) and 2) is this mod for sustained inverted flight and regular rolls, loops etc are OK with the standard tanks. Thanks for any input Dave RV7A ________________________________________________________________________________
Subject: lights
Date: Oct 31, 2004
Steve, Whose Landing lights are you referring to? I need to settle on a landing / position light setup (without cutting into the wing leading edge). I'm interested in how the LED's perform. Thanks for any info. Sam (7A builder) -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Steve Newcomer Subject: Re: RV7-List: lights So far I have installed three sets in customers RVs and they have no complaints. The light they project is better then the wing mounted from the kit manufacturer. I am about to install the LED setup next and looking forward to it. ----- Original Message ----- From: "Rick" <richardglick(at)charter.net> Subject: Re: RV7-List: lights > > Nelson, > > I ordered the two kits and they are due to show up at my door today. I > will let you know how look. The owner (Bill Vondane has been busy in his > other profession (Like all of us) and it took a couple emails to get it > shipped, but he seems like a very nice and accommodating person. I am > looking forward to receiving and installing the kits. > > Richard Glick > ----- Original Message ----- > From: <nltiiii(at)bellsouth.net> > To: > Subject: RV7-List: lights > > > > > > Does anyone have any comments (pro or con) on the CreativAir > > position/landing lights? > > > > Nelson Tower > > RV7 wings > > fuse on order > > > > > > > > == == == == ________________________________________________________________________________
Subject: Re: lights
Date: Oct 31, 2004
I have been researching this for a while, the best bet is Bill Vondane (might be misspelled) at www.creativeair.com, hands down because I refuse to cut into the leading edge when it looks so good.. Danny.. ----- Original Message ----- From: "sjevans" <sjevans(at)cox.net> Subject: RE: RV7-List: lights > > Steve, > Whose Landing lights are you referring to? I need to settle on a > landing / position light setup (without cutting into the wing leading > edge). > I'm interested in how the LED's perform. > Thanks for any info. > Sam > (7A builder) > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Steve Newcomer > To: rv7-list(at)matronics.com > Subject: Re: RV7-List: lights > > > So far I have installed three sets in customers RVs and they have no > complaints. The light they project is better then the wing mounted from > the > kit manufacturer. I am about to install the LED setup next and looking > forward to it. > > > ----- Original Message ----- > From: "Rick" <richardglick(at)charter.net> > To: > Subject: Re: RV7-List: lights > > >> >> Nelson, >> >> I ordered the two kits and they are due to show up at my door today. > I >> will let you know how look. The owner (Bill Vondane has been busy in > his >> other profession (Like all of us) and it took a couple emails to get > it >> shipped, but he seems like a very nice and accommodating person. I am >> looking forward to receiving and installing the kits. >> >> Richard Glick >> ----- Original Message ----- >> From: <nltiiii(at)bellsouth.net> >> To: >> Subject: RV7-List: lights >> >> >> > >> > Does anyone have any comments (pro or con) on the CreativAir >> > position/landing lights? >> > >> > Nelson Tower >> > RV7 wings >> > fuse on order >> > >> > >> > >> >> > > > == > == > == > == > > > ________________________________________________________________________________
Subject: lights
Date: Oct 31, 2004
I believe the correct website is www.creativair.com. The positives of Bill's halogen landing lights are that they are reasonably bright and very light weight. They do draw a fair amount of amperage and make a lot of heat, but what bright lights don't? I have installed a pair of them.... Kathleen Evans www.rv7.us -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of sportpilot Subject: Re: RV7-List: lights I have been researching this for a while, the best bet is Bill Vondane (might be misspelled) at www.creativeair.com, hands down because I refuse to cut into the leading edge when it looks so good.. Danny.. ----- Original Message ----- From: "sjevans" <sjevans(at)cox.net> Subject: RE: RV7-List: lights > > Steve, > Whose Landing lights are you referring to? I need to settle on a > landing / position light setup (without cutting into the wing leading > edge). > I'm interested in how the LED's perform. > Thanks for any info. > Sam > (7A builder) > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Steve Newcomer > To: rv7-list(at)matronics.com > Subject: Re: RV7-List: lights > > > So far I have installed three sets in customers RVs and they have no > complaints. The light they project is better then the wing mounted from > the > kit manufacturer. I am about to install the LED setup next and looking > forward to it. > > > ----- Original Message ----- > From: "Rick" <richardglick(at)charter.net> > To: > Subject: Re: RV7-List: lights > > >> >> Nelson, >> >> I ordered the two kits and they are due to show up at my door today. > I >> will let you know how look. The owner (Bill Vondane has been busy in > his >> other profession (Like all of us) and it took a couple emails to get > it >> shipped, but he seems like a very nice and accommodating person. I am >> looking forward to receiving and installing the kits. >> >> Richard Glick >> ----- Original Message ----- >> From: <nltiiii(at)bellsouth.net> >> To: >> Subject: RV7-List: lights >> >> >> > >> > Does anyone have any comments (pro or con) on the CreativAir >> > position/landing lights? >> > >> > Nelson Tower >> > RV7 wings >> > fuse on order >> > >> > >> > >> >> > > > == > == > == > == > > > ________________________________________________________________________________
Date: Nov 01, 2004
I've been through this question myself 1. it can be done, but not easy - it looked to me to be a real bitch to do 2. it's mainly for sustained inverted flight and other negative G maneuvers; positive G maneuvers don't need it for details & pics from someone who did it, see here: http://www.bobbrown.com/n112b_wings_9.html brian http://brian76.mystarband.net/RV-7Ahome.htm -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of David Figgins rv7-list(at)matronics.com Subject: RV7-List: RV7 QB tanks I think I may have run into a problem and need some advice, I have the wing kit on order with the QB tanks (due in December), and in reading the drawings and instruction this past couple of days I noticed a tank mod is required for inverted flight that adds a flop tube in the standard vent line area and moves the sender outboard one station. I am assuming the QB tanks are in the standard configuration. Questions therefore are 1) can the tank be modified for this mod after it is complete (i.e. can you get access and keep inside clean) and 2) is this mod for sustained inverted flight and regular rolls, loops etc are OK with the standard tanks. Thanks for any input Dave RV7A --- --- ________________________________________________________________________________
From: "Chuck aka Charlie Imken" <skikrazi(at)centurytel.net>
Subject: Re: lights
Date: Nov 01, 2004
I can understand quickbuild folks being nervous about cutting a hole in the leading edge of a completed wing. But if you are building your wing from scratch, it costs only about 65 or 70 dollars for a new skin and ribs for the leading edge should you screw it up. Don't ask me how I know this. Don't archive. Chuck Imken ----- Original Message ----- From: <Kathleen(at)rv7.us> Subject: RE: RV7-List: lights > > I believe the correct website is www.creativair.com. > > The positives of Bill's halogen landing lights are that they are reasonably > bright and very light weight. They do draw a fair amount of amperage and > make a lot of heat, but what bright lights don't? I have installed a pair > of them.... > > Kathleen Evans > www.rv7.us > > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of sportpilot > To: rv7-list(at)matronics.com > Subject: Re: RV7-List: lights > > > I have been researching this for a while, the best bet is Bill > Vondane (might be misspelled) at www.creativeair.com, hands down because I > refuse to cut into the leading edge when it looks so good.. > > Danny.. > > > ----- Original Message ----- > From: "sjevans" <sjevans(at)cox.net> > To: > Subject: RE: RV7-List: lights > > > > > > Steve, > > Whose Landing lights are you referring to? I need to settle on a > > landing / position light setup (without cutting into the wing leading > > edge). > > I'm interested in how the LED's perform. > > Thanks for any info. > > Sam > > (7A builder) > > > > -----Original Message----- > > From: owner-rv7-list-server(at)matronics.com > > [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Steve Newcomer > > To: rv7-list(at)matronics.com > > Subject: Re: RV7-List: lights > > > > > > So far I have installed three sets in customers RVs and they have no > > complaints. The light they project is better then the wing mounted from > > the > > kit manufacturer. I am about to install the LED setup next and looking > > forward to it. > > > > > > ----- Original Message ----- > > From: "Rick" <richardglick(at)charter.net> > > To: > > Subject: Re: RV7-List: lights > > > > > >> > >> Nelson, > >> > >> I ordered the two kits and they are due to show up at my door today. > > I > >> will let you know how look. The owner (Bill Vondane has been busy in > > his > >> other profession (Like all of us) and it took a couple emails to get > > it > >> shipped, but he seems like a very nice and accommodating person. I am > >> looking forward to receiving and installing the kits. > >> > >> Richard Glick > >> ----- Original Message ----- > >> From: <nltiiii(at)bellsouth.net> > >> To: > >> Subject: RV7-List: lights > >> > >> > >> > > >> > Does anyone have any comments (pro or con) on the CreativAir > >> > position/landing lights? > >> > > >> > Nelson Tower > >> > RV7 wings > >> > fuse on order > >> > > >> > > >> > > >> > >> > > > > > > == > > == > > == > > == > > > > > > > > ________________________________________________________________________________
Subject: lights
Date: Nov 01, 2004
HID's are brighter and generate little heat. They also produce a better colour temperature light and draw less than an amp once ignited. They generate less heat because they work like a flourescent tube in that xenon gas is excited rather than heating up a filament. Advantages in an aircraft are that you should never have to change a bulb, lighter gauge wiring and no relays, and better visibilty. Downside is of course cost, but to me the advantages are worth the extra cash. Mark Taylor http://home.comcast.net/~mtaylo17/RV7/ >From: Kathleen(at)rv7.us >Reply-To: rv7-list(at)matronics.com >To: >Subject: RE: RV7-List: lights >Date: Sun, 31 Oct 2004 20:44:04 -0800 > > >I believe the correct website is www.creativair.com. > >The positives of Bill's halogen landing lights are that they are reasonably >bright and very light weight. They do draw a fair amount of amperage and >make a lot of heat, but what bright lights don't? I have installed a pair >of them.... > > Kathleen Evans >www.rv7.us > > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of sportpilot >To: rv7-list(at)matronics.com >Subject: Re: RV7-List: lights > > > I have been researching this for a while, the best bet is Bill >Vondane (might be misspelled) at www.creativeair.com, hands down because I >refuse to cut into the leading edge when it looks so good.. > >Danny.. > > >----- Original Message ----- >From: "sjevans" <sjevans(at)cox.net> >To: >Subject: RE: RV7-List: lights > > > > > > Steve, > > Whose Landing lights are you referring to? I need to settle on a > > landing / position light setup (without cutting into the wing leading > > edge). > > I'm interested in how the LED's perform. > > Thanks for any info. > > Sam > > (7A builder) > > > > -----Original Message----- > > From: owner-rv7-list-server(at)matronics.com > > [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Steve Newcomer > > To: rv7-list(at)matronics.com > > Subject: Re: RV7-List: lights > > > > > > So far I have installed three sets in customers RVs and they have no > > complaints. The light they project is better then the wing mounted from > > the > > kit manufacturer. I am about to install the LED setup next and looking > > forward to it. > > > > > > ----- Original Message ----- > > From: "Rick" <richardglick(at)charter.net> > > To: > > Subject: Re: RV7-List: lights > > > > > >> > >> Nelson, > >> > >> I ordered the two kits and they are due to show up at my door today. > > I > >> will let you know how look. The owner (Bill Vondane has been busy in > > his > >> other profession (Like all of us) and it took a couple emails to get > > it > >> shipped, but he seems like a very nice and accommodating person. I am > >> looking forward to receiving and installing the kits. > >> > >> Richard Glick > >> ----- Original Message ----- > >> From: <nltiiii(at)bellsouth.net> > >> To: > >> Subject: RV7-List: lights > >> > >> > >> > > >> > Does anyone have any comments (pro or con) on the CreativAir > >> > position/landing lights? > >> > > >> > Nelson Tower > >> > RV7 wings > >> > fuse on order > >> > > >> > > >> > > >> > >> > > > > > > == > > == > > == > > == > > > > > > > > ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: Re: lights
Date: Nov 02, 2004
I think everyone is concerned about cutting any hole in a perfectly good wing, quick build or slowwwww. For that reason, I recommend you do NOT as I did it with Duckworks. If I were doing it again, I would install all my lights in the wing tip and leave the perfectly good leading edge of my wing in perfect condition. For a very good low cost example, you could look at the pictures provided by Vince Fraizer. By the way, Vince's Rocket is now flying. ((... scroll clear to the bottom and look at the wingtip lights section. http://www.usi.edu/science/chemistry/vfrazier/Construction%20Notes%20for%20the%20tail%20and%20wings.htm you may need to paste the long link back together in your browser. If that won't work click on the URL below and then go to the Wings and Tail section. Vince Frazier 812-985-7309 home 812-464-1839 work Stinson 108, NC97535 flying F-1H Rocket, N540VF reserved http://www.usi.edu/science/chemistry/vfrazier/page1.html )) Larry > I can understand quickbuild folks being nervous about cutting a hole in the > leading edge of a completed wing. But if you are building your wing from > scratch, it costs only about 65 or 70 dollars for a new skin and ribs for > the leading edge should you screw it up. Don't ask me how I know this. > > > I believe the correct website is www.creativair.com. > > > > The positives of Bill's halogen landing lights are that they are > reasonably > > bright and very light weight. They do draw a fair amount of amperage and > > make a lot of heat, but what bright lights don't? I have installed a pair > > of them.... > > > > > > I have been researching this for a while, the best bet is Bill > > Vondane (might be misspelled) at www.creativeair.com, hands down because I > > refuse to cut into the leading edge when it looks so good.. > > > > > Whose Landing lights are you referring to? I need to settle on a > > > landing / position light setup (without cutting into the wing leading > > > edge). > > > So far I have installed three sets in customers RVs and they have no > > > complaints. The light they project is better then the wing mounted from > > > the > > > kit manufacturer. I am about to install the LED setup next and looking > > > forward to it. > > > > > >> > > >> I ordered the two kits and they are due to show up at my door today. > > > I > > >> will let you know how look. The owner (Bill Vondane has been busy in > > > his > > >> other profession (Like all of us) and it took a couple emails to get > > > it > > >> shipped, but he seems like a very nice and accommodating person. I am > > >> looking forward to receiving and installing the kits. > > >> > > >> > Does anyone have any comments (pro or con) on the CreativAir > > >> > position/landing lights? > > >> > ________________________________________________________________________________
Subject: Re: lights
Date: Nov 02, 2004
Duckworks lights are great and were a breeze to install on my slow build. I did not wait until the wings were finished to cut the holes. I did it as soon as I had each leading edge skin riveted to the ribs--very easy to cut and install at that point. Those can be focused easier and better than wing tip lights and have no heat problems. ----- Original Message ----- From: "LarryRobertHelming" <lhelming(at)sigecom.net> Subject: Re: RV7-List: lights > > I think everyone is concerned about cutting any hole in a perfectly good > wing, quick build or slowwwww. For that reason, I recommend you do NOT as I > did it with Duckworks. If I were doing it again, I would install all my > lights in the wing tip and leave the perfectly good leading edge of my wing > in perfect condition. For a very good low cost example, you could look at > the pictures provided by Vince Fraizer. By the way, Vince's Rocket is now > flying. > > ((... scroll clear to the bottom and look at the wingtip lights section. > http://www.usi.edu/science/chemistry/vfrazier/Construction%20Notes%20for%20the%20tail%20and%20wings.htm > you may need to paste the long link back > together in your browser. If that won't work click on the URL below and > then go to the Wings and Tail section. > > Vince Frazier > 812-985-7309 home > 812-464-1839 work > Stinson 108, NC97535 flying > F-1H Rocket, N540VF reserved > http://www.usi.edu/science/chemistry/vfrazier/page1.html )) > > Larry > > > I can understand quickbuild folks being nervous about cutting a hole in > the > > leading edge of a completed wing. But if you are building your wing from > > scratch, it costs only about 65 or 70 dollars for a new skin and ribs for > > the leading edge should you screw it up. Don't ask me how I know this. > > > > > I believe the correct website is www.creativair.com. > > > > > > The positives of Bill's halogen landing lights are that they are > > reasonably > > > bright and very light weight. They do draw a fair amount of amperage > and > > > make a lot of heat, but what bright lights don't? I have installed a > pair > > > of them.... > > > > > > > > > I have been researching this for a while, the best bet is Bill > > > Vondane (might be misspelled) at www.creativeair.com, hands down because > I > > > refuse to cut into the leading edge when it looks so good.. > > > > > > > Whose Landing lights are you referring to? I need to settle on a > > > > landing / position light setup (without cutting into the wing leading > > > > edge). > > > > So far I have installed three sets in customers RVs and they have no > > > > complaints. The light they project is better then the wing mounted > from > > > > the > > > > kit manufacturer. I am about to install the LED setup next and looking > > > > forward to it. > > > > > > > >> > > > >> I ordered the two kits and they are due to show up at my door today. > > > > I > > > >> will let you know how look. The owner (Bill Vondane has been busy in > > > > his > > > >> other profession (Like all of us) and it took a couple emails to get > > > > it > > > >> shipped, but he seems like a very nice and accommodating person. I > am > > > >> looking forward to receiving and installing the kits. > > > >> > > > >> > Does anyone have any comments (pro or con) on the CreativAir > > > >> > position/landing lights? > > > >> > > > ________________________________________________________________________________
Subject: RE: RV7-No jig for the tail!!!
Date: Nov 02, 2004
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Very good news from Van's. I asked them about the need for the extensive jig that builders have been using for the tail kits. Probably 15 hours saved right there! --Original Message----- From: Bruce Reynolds [mailto:brucer(at)vansaircraft.com] Subject: Re: 71965..First question, RV 7 Frank, You are the recipient of modern technology. The prepunched tail kits need no jigs. Just follow the instructions in the manual. Bruce Reynolds brucer(at)vansaircraft.com ________________________________________________________________________________
Subject: Re: RE: RV7-No jig for the tail!!!
Date: Nov 02, 2004
Frank,........more very good news. You won't need jigs for the wings or fuselage either even if you build the slow-build kits. ----- Original Message ----- From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com> Subject: RV7-List: RE: RV7-No jig for the tail!!! > > > Very good news from Van's. I asked them about the need for the extensive > jig that builders have been using for the tail kits. > > Probably 15 hours saved right there! > > > --Original Message----- > From: Bruce Reynolds [mailto:brucer(at)vansaircraft.com] > To: Hinde, Frank George (Corvallis) > Subject: Re: 71965..First question, RV 7 > > > Frank, > > You are the recipient of modern technology. The prepunched tail > kits need no jigs. Just follow the instructions in the manual. > > > Bruce Reynolds > brucer(at)vansaircraft.com > > ________________________________________________________________________________
Date: Nov 03, 2004
While a jig is not needed, it is highly recommended that the various empennage structures (HS, VS, Rudder, Elevators) be secured in some type of cradle(s) for some of the operations. I learned the hard way while drilling a hole in the Horizontal Stabilizer assembly one night. The assembly slipped and the resulting hole was oval instead of round. I promptly made two cradles of particle board in TEE configuration with some pipe insulation added for padding. The cradles also help to save worktable space. Just my opinion... Don -----Original Message----- From: Hinde, Frank George (Corvallis) [mailto:frank.hinde(at)hp.com] Subject: RV7-List: RE: RV7-No jig for the tail!!! --> Very good news from Van's. I asked them about the need for the extensive jig that builders have been using for the tail kits. Probably 15 hours saved right there! --Original Message----- From: Bruce Reynolds [mailto:brucer(at)vansaircraft.com] Subject: Re: 71965..First question, RV 7 Frank, You are the recipient of modern technology. The prepunched tail kits need no jigs. Just follow the instructions in the manual. Bruce Reynolds brucer(at)vansaircraft.com advertising on the Matronics Forums. ________________________________________________________________________________
Subject: Fuel tank leading edge skin match
Date: Nov 07, 2004
Slow build RV7 wing. Left wing aligned perfectly. However, when I set the right fuel tank on the spar (using Dan C's methodology for Z bracket drilling) after setting the leading edge, drilling the W-408-1R Leading Edge rib and W-423 Joint plate, the tank skin lacks about 1/32" meeting the top skin when I pull down as hard as I can (bottom of tank skin already clecoed to spar and lines up fine with bottom of leading edge skin). Match is perfect when tank is set not quite on the joint plate (thus Z brackets/baffle interface seems correct), but as soon as I set it on the joint plate I get the little 1/32" "lifting" of the tank. I know the Orndorf tapes show using straps to pull (force!) the tank into position for drilling. (Didn't have to do this on left tank.) It just seems the tank will always have to be "forced" into position for attachment. I have removed the joint plate and alignment is perfect so the problem seems to be the joint plate but I have studied it and cannot see what is holding the tank skin up! Am I obsessing? Should I just use straps to force it and go on? Or persevere until I find the problem and get it to sit correctly in an unforced state like the left one did? Thanks, Allen Fulmer RV7 Wings N808AF reserved ________________________________________________________________________________
Date: Nov 08, 2004
Subject: Re: Fuel tank leading edge skin match
Allan, this is not uncommon. The fix is in the nose of your tank ribs. they need to be flatten, recessed further rounded or whatever needs to happen to effectively shorten the overall length of each rib untill the tank skin fits correctly or has zero gap. There is no need for straps this will cure it. Good luck Tad Sargent Sargentclt(at)CS.com RV7A ________________________________________________________________________________
Date: Nov 08, 2004
From: "David E. Nelson" <david.nelson(at)pobox.com>
Hi Allen, Ran into a similar situation with a small gap at the LE of the tank. I also used Dan's method. I ended up using a strap and then drilled the joint plate holes to full size. Now, come final assembly, the dimpled holes _should_ help pull the tank in and line it up nicely. Test fits have shown good fit, however. Another thing to consider: When you attach the tank baffle and tank brackets, don't use too much proseal as that will cause the tank to move forward. Regards, /\/elson Austin, TX On Sun, 7 Nov 2004, Allen Fulmer wrote: > > Slow build RV7 wing. > > Left wing aligned perfectly. > > However, when I set the right fuel tank on the spar (using Dan C's > methodology for Z bracket drilling) after setting the leading edge, drilling > the W-408-1R Leading Edge rib and W-423 Joint plate, the tank skin lacks > about 1/32" meeting the top skin when I pull down as hard as I can (bottom of > tank skin already clecoed to spar and lines up fine with bottom of leading > edge skin). > > Match is perfect when tank is set not quite on the joint plate (thus Z > brackets/baffle interface seems correct), but as soon as I set it on the > joint plate I get the little 1/32" "lifting" of the tank. I know the Orndorf > tapes show using straps to pull (force!) the tank into position for drilling. > (Didn't have to do this on left tank.) It just seems the tank will always > have to be "forced" into position for attachment. > > I have removed the joint plate and alignment is perfect so the problem seems > to be the joint plate but I have studied it and cannot see what is holding > the tank skin up! > > Am I obsessing? Should I just use straps to force it and go on? Or > persevere until I find the problem and get it to sit correctly in an unforced > state like the left one did? > > Thanks, > > Allen Fulmer > RV7 Wings > N808AF reserved > > -- ~~ ** ~~ If you didn't learn anything when you broke it the 1st ~~ ** ~~ time, then break it again. ________________________________________________________________________________
Date: Nov 09, 2004
Subject: Another flying RV-7 with Dynon and Grand Rapids EFIS
Jeff Bordelon took these pics and posted them to his web site. Here is the link http://www.jeffsrv7a.com/KeithsRV7.htm As you can see I have both the Grand Rapids and Dynon EFIS systems. I really like both of them, they both have there place in the panel and they keep getting better with each software update. If you have any questions about either one let me know. Keith Uhls keithuhls(at)juno.com RV-7 N7KU now flying ________________________________________________________________________________
Subject: Fuel tank leak blues
Date: Nov 10, 2004
I finished up the right (and final) tank Sunday by prosealing the access plate and fuel tank sender directly onto the rib. Then yesterday (Tuesday), I built up enough nerve to test it out. Before I even got the manometer pumped to 2.6 psi, I could feel the breeze. Adding the soapy bubbles, I actually got the leak to blow a bubble about as big as a football. No problem finding the leak; it was along the bottom baffle-to-skin seam in the most inboard bay. Well, at least it was an area I could get to by removing the access cover. So I did. Man, proseal can really set up in two days. It was a rough trip prying that sucker off. But eventually I did and it took two hours of scraping and wiping with MEK to remove all the ProSeal from the rib and access cover. Then I filled a syringe with sealant and layed a huge glob inside along the seam and just ont he other side of the rib. Now, here's the deal. As I was taking off the access cover, I realized that this would really be a risky job if the sealant were more than 3 days old, to the point where it seemed perfectly possible to damage the rib. I thought, 'man, I'm not prosealing this directly onto the rib again. Now I know there's a zillion messages in the archive about other possibilities and I've reviewed half-a-zillion of them. I think I want to use the cork gasket when I put this back on because IF I didn't stop the leak, I really don't want to repeat theprocess of getting that access cover off again. The question is on technique. Should I pro-seal both sides of the cork gasket and then put the access cover back on? Should I just Proseal the gasket to the rib? Should I just ProSeal the gasket to the cover? I'm just trying to figure out the best way to seal this thing (there was NOOOOO way, the cover was going to leak the way I had prosealed it before; but it also seemed like there was no way that access cover was ever going to come off in the future, which kinda takes away the point of having an access cover. What say you? Bob St. Paul ________________________________________________________________________________
Subject: Re: Fuel tank leak blues
Date: Nov 10, 2004
Hi Bob, I always pro-seal both sides of the cork and install it being careful not to over tighten the screws. I have not had a leak (2 RVs of my own and several other I have helped with) yet. Remember, it may take a couple weeks for the pro-seal to cure depending on the ambient temp so don't put pressure on it too soon. Good Luck, Robbie www.attawayair.com ----- Original Message ----- From: "Bob Collins" <bcollins(at)visi.com> Subject: RV7-List: Fuel tank leak blues > > I finished up the right (and final) tank Sunday by prosealing the access > plate and fuel tank sender directly onto the rib. Then yesterday > (Tuesday), > I built up enough nerve to test it out. Before I even got the manometer > pumped to 2.6 psi, I could feel the breeze. Adding the soapy bubbles, I > actually got the leak to blow a bubble about as big as a football. No > problem finding the leak; it was along the bottom baffle-to-skin seam in > the most inboard bay. Well, at least it was an area I could get to by > removing the access cover. > > So I did. Man, proseal can really set up in two days. It was a rough trip > prying that sucker off. But eventually I did and it took two hours of > scraping and wiping with MEK to remove all the ProSeal from the rib and > access cover. > > Then I filled a syringe with sealant and layed a huge glob inside along > the > seam and just ont he other side of the rib. > > Now, here's the deal. As I was taking off the access cover, I realized > that > this would really be a risky job if the sealant were more than 3 days old, > to the point where it seemed perfectly possible to damage the rib. I > thought, 'man, I'm not prosealing this directly onto the rib again. > > Now I know there's a zillion messages in the archive about other > possibilities and I've reviewed half-a-zillion of them. I think I want to > use the cork gasket when I put this back on because IF I didn't stop the > leak, I really don't want to repeat theprocess of getting that access > cover > off again. > > The question is on technique. Should I pro-seal both sides of the cork > gasket and then put the access cover back on? Should I just Proseal the > gasket to the rib? Should I just ProSeal the gasket to the cover? I'm just > trying to figure out the best way to seal this thing (there was NOOOOO > way, > the cover was going to leak the way I had prosealed it before; but it also > seemed like there was no way that access cover was ever going to come off > in > the future, which kinda takes away the point of having an access cover. > > What say you? > > Bob > St. Paul > > > ________________________________________________________________________________
Date: Nov 10, 2004
Bob, This is a web site that has info on pro-seal. http://corporate.ppg.com/ppg/aerospace/default.htm Robbie www.attawayair.com ----- Original Message ----- From: "Bob Collins" <bcollins(at)visi.com> Subject: RV7-List: Fuel tank leak blues > > I finished up the right (and final) tank Sunday by prosealing the access > plate and fuel tank sender directly onto the rib. Then yesterday > (Tuesday), > I built up enough nerve to test it out. Before I even got the manometer > pumped to 2.6 psi, I could feel the breeze. Adding the soapy bubbles, I > actually got the leak to blow a bubble about as big as a football. No > problem finding the leak; it was along the bottom baffle-to-skin seam in > the most inboard bay. Well, at least it was an area I could get to by > removing the access cover. > > So I did. Man, proseal can really set up in two days. It was a rough trip > prying that sucker off. But eventually I did and it took two hours of > scraping and wiping with MEK to remove all the ProSeal from the rib and > access cover. > > Then I filled a syringe with sealant and layed a huge glob inside along > the > seam and just ont he other side of the rib. > > Now, here's the deal. As I was taking off the access cover, I realized > that > this would really be a risky job if the sealant were more than 3 days old, > to the point where it seemed perfectly possible to damage the rib. I > thought, 'man, I'm not prosealing this directly onto the rib again. > > Now I know there's a zillion messages in the archive about other > possibilities and I've reviewed half-a-zillion of them. I think I want to > use the cork gasket when I put this back on because IF I didn't stop the > leak, I really don't want to repeat theprocess of getting that access > cover > off again. > > The question is on technique. Should I pro-seal both sides of the cork > gasket and then put the access cover back on? Should I just Proseal the > gasket to the rib? Should I just ProSeal the gasket to the cover? I'm just > trying to figure out the best way to seal this thing (there was NOOOOO > way, > the cover was going to leak the way I had prosealed it before; but it also > seemed like there was no way that access cover was ever going to come off > in > the future, which kinda takes away the point of having an access cover. > > What say you? > > Bob > St. Paul > > > ________________________________________________________________________________
Date: Nov 10, 2004
Don't proseal the cork. You will never get it off. I have built 3 RV's now and they don't leak just using the cork. Bob Collins wrote: > >I finished up the right (and final) tank Sunday by prosealing the access >plate and fuel tank sender directly onto the rib. Then yesterday (Tuesday), >I built up enough nerve to test it out. Before I even got the manometer >pumped to 2.6 psi, I could feel the breeze. Adding the soapy bubbles, I >actually got the leak to blow a bubble about as big as a football. No >problem finding the leak; it was along the bottom baffle-to-skin seam in >the most inboard bay. Well, at least it was an area I could get to by >removing the access cover. > >So I did. Man, proseal can really set up in two days. It was a rough trip >prying that sucker off. But eventually I did and it took two hours of >scraping and wiping with MEK to remove all the ProSeal from the rib and >access cover. > >Then I filled a syringe with sealant and layed a huge glob inside along the >seam and just ont he other side of the rib. > >Now, here's the deal. As I was taking off the access cover, I realized that >this would really be a risky job if the sealant were more than 3 days old, >to the point where it seemed perfectly possible to damage the rib. I >thought, 'man, I'm not prosealing this directly onto the rib again. > >Now I know there's a zillion messages in the archive about other >possibilities and I've reviewed half-a-zillion of them. I think I want to >use the cork gasket when I put this back on because IF I didn't stop the >leak, I really don't want to repeat theprocess of getting that access cover >off again. > >The question is on technique. Should I pro-seal both sides of the cork >gasket and then put the access cover back on? Should I just Proseal the >gasket to the rib? Should I just ProSeal the gasket to the cover? I'm just >trying to figure out the best way to seal this thing (there was NOOOOO way, >the cover was going to leak the way I had prosealed it before; but it also >seemed like there was no way that access cover was ever going to come off in >the future, which kinda takes away the point of having an access cover. > >What say you? > >Bob >St. Paul > > > > ________________________________________________________________________________
Date: Nov 10, 2004
Subject: RV -7 with GRT EFIS and Dynon
Q:IIncidentallywhat do you use to drive the VOR and glideslope? A: I purchased my GRT EFIS before they where selling them off the shelf. So some things were not available at that time. For me I wanted to be able to fly GPS approaches and in order to do that I had to have an OBS. So I purchased the one from Garmin. I do not know if the one on the EFIS would be legal and did not want to go through that battle in case I lost. I do not have the interface yet but it is wired so I can drive the OBS with the EFIS. Q: Where did you get the switches for your panel? A: A good question... I had a couple of guys here in Lockhart get their switches from Gulf Coast Avionics. They paid $40 plus $10 for engraving. I have 13 of these suckers.....and that is a lot of money. I looked for Honeywell AML switches from Allied electronics and Newarkinone. I purchased them from Newarkinone because they were the cheapest. However I found out that they were low amperage (3amps). There are higher amperages available from GCA (10 amps) At least that is what I was told when I called them. One of my switches went bad and that made me research the amperage. I ended up purchasing a few from them for my high amperage items. Landing lights, strobes etc. We are putting them in this week and I will let you know how that goes. I had mine engraved by a guy in Las Vegas, Andy's Engraving and he charged me $7.00 each. He did them in a matter of days and I was really happy with them. Q:I am not trying to nitpick anything but when flying the American Flag on the tail of an aircraft the stars are into the wind. A: Thanks for letting me know, especially before I got paint on it. I will change it. Jeff Bordelon took these pics and posted them to his web site. Here is the link http://www.jeffsrv7a.com/KeithsRV7.htm As you can see I have both the Grand Rapids and Dynon EFIS systems. I really like both of them, they both have there place in the panel and they keep getting better with each software update. If you have any questions about either one let me know. Keith Uhls keithuhls(at)juno.com RV-7 N7KU now flying ________________________________________________________________________________
From: "Francis, David CMDR" <David.Francis(at)defence.gov.au>
Date: Nov 11, 2004
Bob, Just to add to the squillion tank gasket sealing options. If you do want to add sealer to the cork gasket but dont like fighting with cured proseal, look for Loctite No3, its billed as an aviation gasket sealant that does not set. It looks and smells like a variation of proseal that sets but stays tacky like fresh chewing gum. As a minimum it will be good to seal the threads of the screws on the tank access hatch, I will be able to undo the screws with out destroying the heads in the proces. Keep bubbling along, David Francis, Canberra, Australia, waiting for the engine. -----Original Message----- From: Norman Younie [mailto:rv6capt(at)pacificcoast.net] Subject: Re: RV7-List: Fuel tank leak blues Don't proseal the cork. You will never get it off. I have built 3 RV's now and they don't leak just using the cork. Bob Collins wrote: > >I finished up the right (and final) tank Sunday by prosealing the access >plate and fuel tank sender directly onto the rib. ________________________________________________________________________________
Date: Nov 10, 2004
Bob, I pro sealed everything that did not move and some things that did.....did not use cork gaskets but did use #8 Allen head screws in lieu of Phillips head screws-easier to tighten or remove. ......so far, no leaks. A friend just replaced a Phillips head screw with an Allen head screw because of a leak in his RV just over a year old (he did not Proseal the cork gaskets when tanks were built). -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Francis, David CMDR Subject: SEC: UNCLASSIFIED RV7-List: Fuel tank leak blues Bob, Just to add to the squillion tank gasket sealing options. If you do want to add sealer to the cork gasket but dont like fighting with cured proseal, look for Loctite No3, its billed as an aviation gasket sealant that does not set. It looks and smells like a variation of proseal that sets but stays tacky like fresh chewing gum. As a minimum it will be good to seal the threads of the screws on the tank access hatch, I will be able to undo the screws with out destroying the heads in the proces. Keep bubbling along, David Francis, Canberra, Australia, waiting for the engine. -----Original Message----- From: Norman Younie [mailto:rv6capt(at)pacificcoast.net] Subject: Re: RV7-List: Fuel tank leak blues Don't proseal the cork. You will never get it off. I have built 3 RV's now and they don't leak just using the cork. Bob Collins wrote: > >I finished up the right (and final) tank Sunday by prosealing the access >plate and fuel tank sender directly onto the rib. ________________________________________________________________________________
Date: Nov 11, 2004
>> I think I want to use the cork gasket when I put this back on because IF I didn't stop the leak, I really don't want to repeat the process of getting that access cover off again. << Vans put a warning and advice out in this or last year's RVator on this topic. They suggest now that the plates should not utilize the cork seals because they will eventually leak. It might take years but their experience shows they do deteriorate and leak with time. They now recommend to proseal them. I removed my perfectly good cork seals that had been pressure tested ( I waited a full 6 months before testing them however) and redid them using only proseal. I figure it is a lot less work now than later after they are mounted on the fuselage. Check with Vans on this first to make sure they have not changed their mind on this again. If you find what I am saying is not currently true, post your results for all to see. Indiana Larry, RV7 TipUp "SunSeeker" ----- Original Message ----- From: "Bob Collins" <bcollins(at)visi.com> Subject: RV7-List: Fuel tank leak blues > > I finished up the right (and final) tank Sunday by prosealing the access > plate and fuel tank sender directly onto the rib. Then yesterday (Tuesday), > I built up enough nerve to test it out. Before I even got the manometer > pumped to 2.6 psi, I could feel the breeze. Adding the soapy bubbles, I > actually got the leak to blow a bubble about as big as a football. No > problem finding the leak; it was along the bottom baffle-to-skin seam in > the most inboard bay. Well, at least it was an area I could get to by > removing the access cover. > > So I did. Man, proseal can really set up in two days. It was a rough trip > prying that sucker off. But eventually I did and it took two hours of > scraping and wiping with MEK to remove all the ProSeal from the rib and > access cover. > > Then I filled a syringe with sealant and layed a huge glob inside along the > seam and just ont he other side of the rib. > > Now, here's the deal. As I was taking off the access cover, I realized that > this would really be a risky job if the sealant were more than 3 days old, > to the point where it seemed perfectly possible to damage the rib. I > thought, 'man, I'm not prosealing this directly onto the rib again. > > Now I know there's a zillion messages in the archive about other > possibilities and I've reviewed half-a-zillion of them. I think I want to > use the cork gasket when I put this back on because IF I didn't stop the > leak, I really don't want to repeat theprocess of getting that access cover > off again. > > The question is on technique. Should I pro-seal both sides of the cork > gasket and then put the access cover back on? Should I just Proseal the > gasket to the rib? Should I just ProSeal the gasket to the cover? I'm just > trying to figure out the best way to seal this thing (there was NOOOOO way, > the cover was going to leak the way I had prosealed it before; but it also > seemed like there was no way that access cover was ever going to come off in > the future, which kinda takes away the point of having an access cover. > > What say you? > > Bob > St. Paul ________________________________________________________________________________
Date: Nov 11, 2004
Subject: Re: RV -7 with GRT EFIS and Dynon
I have been looking for nice rocker switches also..............here is what i am going with on our 7A. Haven't found much selection. http://www.aerocraftparts.com/Categories.aspx?Category=38940ec0-b260-4e9f-a23c -b80ff8e89c67 ________________________________________________________________________________
Date: Nov 11, 2004
Maybe a little off subject, but "amen" to the Allen head screws. Especially as your aircraft ages, the Phillips get to be a real pain, used to struggle with them all the time on my 40-year old Cessna. I'm using Torx fasteners on my RV wherever possible, #8 stainless are avialable from http://www.microfasteners.com/. Either Allen or Torx are a big improvement because you don't have to apply "down" force to keep the driver engaged with the fastener head. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Imken Subject: RE: UNCLASSIFIED RV7-List: Fuel tank leak blues Bob, I pro sealed everything that did not move and some things that did.....did not use cork gaskets but did use #8 Allen head screws in lieu of Phillips head screws-easier to tighten or remove. ......so far, no leaks. A friend just replaced a Phillips head screw with an Allen head screw because of a leak in his RV just over a year old (he did not Proseal the cork gaskets when tanks were built). -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Francis, David CMDR Subject: SEC: UNCLASSIFIED RV7-List: Fuel tank leak blues Bob, Just to add to the squillion tank gasket sealing options. If you do want to add sealer to the cork gasket but dont like fighting with cured proseal, look for Loctite No3, its billed as an aviation gasket sealant that does not set. It looks and smells like a variation of proseal that sets but stays tacky like fresh chewing gum. As a minimum it will be good to seal the threads of the screws on the tank access hatch, I will be able to undo the screws with out destroying the heads in the proces. Keep bubbling along, David Francis, Canberra, Australia, waiting for the engine. -----Original Message----- From: Norman Younie [mailto:rv6capt(at)pacificcoast.net] Subject: Re: RV7-List: Fuel tank leak blues Don't proseal the cork. You will never get it off. I have built 3 RV's now and they don't leak just using the cork. Bob Collins wrote: > >I finished up the right (and final) tank Sunday by prosealing the access >plate and fuel tank sender directly onto the rib. ________________________________________________________________________________
Date: Nov 11, 2004
Someone said the difference between the stainless Torx version of a #8 and the AN version is the shoulder on the AN whereas the threads go right up to the head on the stainless Torx. I have both and can see this. Does anyone know which one is actually stronger as one is stainless and the other AN spec'd steel? Or does it not really matter in the case of fuel tank and access plate attachment? Thanks, Allen Fulmer RV7 Wings -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Herron, Al Subject: RE: UNCLASSIFIED RV7-List: Fuel tank leak blues Maybe a little off subject, but "amen" to the Allen head screws. Especially as your aircraft ages, the Phillips get to be a real pain, used to struggle with them all the time on my 40-year old Cessna. I'm using Torx fasteners on my RV wherever possible, #8 stainless are avialable from http://www.microfasteners.com/. Either Allen or Torx are a big improvement because you don't have to apply "down" force to keep the driver engaged with the fastener head. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Imken Subject: RE: UNCLASSIFIED RV7-List: Fuel tank leak blues Bob, I pro sealed everything that did not move and some things that did.....did not use cork gaskets but did use #8 Allen head screws in lieu of Phillips head screws-easier to tighten or remove. ......so far, no leaks. A friend just replaced a Phillips head screw with an Allen head screw because of a leak in his RV just over a year old (he did not Proseal the cork gaskets when tanks were built). -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Francis, David CMDR Subject: SEC: UNCLASSIFIED RV7-List: Fuel tank leak blues Bob, Just to add to the squillion tank gasket sealing options. If you do want to add sealer to the cork gasket but dont like fighting with cured proseal, look for Loctite No3, its billed as an aviation gasket sealant that does not set. It looks and smells like a variation of proseal that sets but stays tacky like fresh chewing gum. As a minimum it will be good to seal the threads of the screws on the tank access hatch, I will be able to undo the screws with out destroying the heads in the proces. Keep bubbling along, David Francis, Canberra, Australia, waiting for the engine. -----Original Message----- From: Norman Younie [mailto:rv6capt(at)pacificcoast.net] Subject: Re: RV7-List: Fuel tank leak blues Don't proseal the cork. You will never get it off. I have built 3 RV's now and they don't leak just using the cork. Bob Collins wrote: > >I finished up the right (and final) tank Sunday by prosealing the access >plate and fuel tank sender directly onto the rib. ________________________________________________________________________________
Date: Nov 11, 2004
I've been told never use stainless in a structural application where the strength of the fastener has been calculated to take a load. But for most access panels, trim, etc., they should be fine, and those are the items you take apart the most. Definitely check with Van's if you are in doubt about whether the fastener is in a critical load path. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Allen Fulmer Subject: RE: UNCLASSIFIED RV7-List: Fuel tank leak blues Someone said the difference between the stainless Torx version of a #8 and the AN version is the shoulder on the AN whereas the threads go right up to the head on the stainless Torx. I have both and can see this. Does anyone know which one is actually stronger as one is stainless and the other AN spec'd steel? Or does it not really matter in the case of fuel tank and access plate attachment? Thanks, Allen Fulmer RV7 Wings -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Herron, Al Subject: RE: UNCLASSIFIED RV7-List: Fuel tank leak blues Maybe a little off subject, but "amen" to the Allen head screws. Especially as your aircraft ages, the Phillips get to be a real pain, used to struggle with them all the time on my 40-year old Cessna. I'm using Torx fasteners on my RV wherever possible, #8 stainless are avialable from http://www.microfasteners.com/. Either Allen or Torx are a big improvement because you don't have to apply "down" force to keep the driver engaged with the fastener head. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Imken Subject: RE: UNCLASSIFIED RV7-List: Fuel tank leak blues Bob, I pro sealed everything that did not move and some things that did.....did not use cork gaskets but did use #8 Allen head screws in lieu of Phillips head screws-easier to tighten or remove. ......so far, no leaks. A friend just replaced a Phillips head screw with an Allen head screw because of a leak in his RV just over a year old (he did not Proseal the cork gaskets when tanks were built). -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Francis, David CMDR Subject: SEC: UNCLASSIFIED RV7-List: Fuel tank leak blues Bob, Just to add to the squillion tank gasket sealing options. If you do want to add sealer to the cork gasket but dont like fighting with cured proseal, look for Loctite No3, its billed as an aviation gasket sealant that does not set. It looks and smells like a variation of proseal that sets but stays tacky like fresh chewing gum. As a minimum it will be good to seal the threads of the screws on the tank access hatch, I will be able to undo the screws with out destroying the heads in the proces. Keep bubbling along, David Francis, Canberra, Australia, waiting for the engine. -----Original Message----- From: Norman Younie [mailto:rv6capt(at)pacificcoast.net] Subject: Re: RV7-List: Fuel tank leak blues Don't proseal the cork. You will never get it off. I have built 3 RV's now and they don't leak just using the cork. Bob Collins wrote: > >I finished up the right (and final) tank Sunday by prosealing the access >plate and fuel tank sender directly onto the rib. ________________________________________________________________________________
Date: Nov 11, 2004
For those that have opened the sealed coveres, can you offer any tips that made the removal job easier? I've heard that heating the proseal with a heat gun softens it a bit making it easier to remove. What have others found? Bevan RV7A with corked and prosealed covers -----Original Message----- From: LarryRobertHelming [SMTP:lhelming(at)sigecom.net] Subject: Re: RV7-List: Fuel tank leak blues >> I think I want to use the cork gasket when I put this back on because IF I didn't stop the leak, I really don't want to repeat the process of getting that access cover off again. << Vans put a warning and advice out in this or last year's RVator on this topic. They suggest now that the plates should not utilize the cork seals because they will eventually leak. It might take years but their experience shows they do deteriorate and leak with time. They now recommend to proseal them. I removed my perfectly good cork seals that had been pressure tested ( I waited a full 6 months before testing them however) and redid them using only proseal. I figure it is a lot less work now than later after they are mounted on the fuselage. Check with Vans on this first to make sure they have not changed their mind on this again. If you find what I am saying is not currently true, post your results for all to see. Indiana Larry, RV7 TipUp "SunSeeker" ----- Original Message ----- From: "Bob Collins" <bcollins(at)visi.com> Subject: RV7-List: Fuel tank leak blues > > I finished up the right (and final) tank Sunday by prosealing the access > plate and fuel tank sender directly onto the rib. Then yesterday (Tuesday), > I built up enough nerve to test it out. Before I even got the manometer > pumped to 2.6 psi, I could feel the breeze. Adding the soapy bubbles, I > actually got the leak to blow a bubble about as big as a football. No > problem finding the leak; it was along the bottom baffle-to-skin seam in > the most inboard bay. Well, at least it was an area I could get to by > removing the access cover. > > So I did. Man, proseal can really set up in two days. It was a rough trip > prying that sucker off. But eventually I did and it took two hours of > scraping and wiping with MEK to remove all the ProSeal from the rib and > access cover. > > Then I filled a syringe with sealant and layed a huge glob inside along the > seam and just ont he other side of the rib. > > Now, here's the deal. As I was taking off the access cover, I realized that > this would really be a risky job if the sealant were more than 3 days old, > to the point where it seemed perfectly possible to damage the rib. I > thought, 'man, I'm not prosealing this directly onto the rib again. > > Now I know there's a zillion messages in the archive about other > possibilities and I've reviewed half-a-zillion of them. I think I want to > use the cork gasket when I put this back on because IF I didn't stop the > leak, I really don't want to repeat theprocess of getting that access cover > off again. > > The question is on technique. Should I pro-seal both sides of the cork > gasket and then put the access cover back on? Should I just Proseal the > gasket to the rib? Should I just ProSeal the gasket to the cover? I'm just > trying to figure out the best way to seal this thing (there was NOOOOO way, > the cover was going to leak the way I had prosealed it before; but it also > seemed like there was no way that access cover was ever going to come off in > the future, which kinda takes away the point of having an access cover. > > What say you? > > Bob > St. Paul ________________________________________________________________________________
Date: Nov 11, 2004
Subject: CH Products Control Stick Switches Electrical Specifications
There has been discussions about the CH Products control sticks (http://www.chproducts.com/retail/aircraft.html) on the newsgroups lately. I have two of them, but there was a question about what the switch ratings were. I contacted Kevin Williamson of CH Products and he was kind enough to supply me with a set of sample switches (from Omron) and the part numbers thereof. I downloaded the complete data sheet from the web, reviewed the specifications and then called the Omron factory representative. There are a few minor errors in the datasheet available on the web, so the rep emailed me the revised (corrected) sheets. I also discussed with him the specifications listed and got clarification, although it turned out that when I received the revised data sheets, the specification is very clear now. The bottom line is that the electrical rating for all three different switches is: 1-50mA, at 5-24V. The explanation for the ratings is: 1. The lower values (1 mA at 5V) are to make sure that the switch sees enough energy when switching to keep the contacts clean. Any lower values would not guarantee that the contacts will always make proper contact over the life of the switch. If for some reason the load being switched is too low, a resistor could be added in parallel with the load to increase the current to at least 1 mA. 2. The higher values (50 mA at 24V) are the maximum values that should be switched that will not damage the switch. Switching any higher loads will risk damaging the contacts - either welding them shut or warping them or causing excessive arc damage - and will certainly shorten the life of the switch. 3. These ratings are for a resistive load, so if they are to be used with a relay or motor the contacts MUST be protected with a diode or other type of snubber network! Of course, the manufacturer always has a margin in the design so if one chooses to switch 55mA at 14V (for instance), the switch will probably still have a reasonable life. However, pushing them to 100 mA or more will definitely shorten the life and may result in a catastrophic failure at some point. These switches are rated for a lot of actuations so their use in an airplane should be no problem. The hat switches are rated for 300,000 operations (minimum), the switches on the top face of the stick are rated for 100,000 operations (minimum) and the trigger (typically used for push-to-talk) is rated for 1,000,000 operations (minimum). To put these numbers in perspective, let's assume you make one flight every day for ten years. For each flight you could use the hat switch to trim the airplane 82 times in each direction, you could actuate the flaps (assuming that is what you use the two gray switches on the top of the stick for) 27 times each up and down and you could push-to-talk 274 times. I am satisfied that the switches used are as robust as you will find and the ratings are adequate for the task. Just don't go overboard on what you connect direct to the switches and your CH Products control stick will have a long and happy life! Dick Tasker ________________________________________________________________________________
Date: Nov 11, 2004
Subject: Orndorff videos index
Hi All, Has anyone indexed the Orndoff videos. Specifically the finish kit set? John McDonnell ________________________________________________________________________________
From: "Brian Meyette" <brianpublic(at)starband.net>
Date: Nov 12, 2004
Yeah - I have it - number refers to the minute that it starts on TAPE 1 0 = tipup 0:15 = slider 1:13 = engine mount 1:19 = nose gear mount 1:24 = wheels & tires 1:31 = main gear 1:40 = slider canopy, front fiberglass trim TAPE 2 0 = finish slider fiberglass 0:17 = brakes 0:27 = back to slider windshield fiberglass 0:28 = mount H-stab 0:35 = V-stab 0:42 = stabilizer tips fiberglass 0:43 = mount engine 1:00 = spinner & prop 1:16 = top cowl 1:29 = bottom cowl 1:40 = air scoop 1:46 = air box TAPE 3 0 = finish air box 0:4 = fiberglass scoop to cowl 0:10 = lower cowl hinges 0:15 = blend scoop to lower cowl 0:18 = nose wheel fairing 0:24 = nose gear fairing 0:30 = U620/621 cowl brackets 0:32 = fiberglass gear fairings HTH, brian http://brian76.mystarband.net/RV-7Ahome.htm -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of JTAnon(at)AOL.com Subject: RV7-List: Orndorff videos index Hi All, Has anyone indexed the Orndoff videos. Specifically the finish kit set? John McDonnell --- --- ________________________________________________________________________________
Date: Nov 12, 2004
Whoops - Ieft out part of TAPE 3. Here's the full list: TAPE 1 0 = tipup 0:15 = slider 1:13 = engine mount 1:19 = nose gear mount 1:24 = wheels & tires 1:31 = main gear 1:40 = slider canopy, front fiberglass trim TAPE 2 0 = finish slider fiberglass 0:17 = brakes 0:27 = back to slider windshield fiberglass 0:28 = mount H-stab 0:35 = V-stab 0:42 = stabilizer tips fiberglass 0:43 = mount engine 1:00 = spinner & prop 1:16 = top cowl 1:29 = bottom cowl 1:40 = air scoop 1:46 = air box TAPE 3 0 = finish air box 0:4 = fiberglass scoop to cowl 0:10 = lower cowl hinges 0:15 = blend scoop to lower cowl 0:18 = nose wheel fairing 0:24 = nose gear fairing 0:30 = U620/621 cowl brackets 0:32 = fiberglass gear fairings 0:42 = fiberglass bottom cowl/air scoop 0:47 = main wheel pants 0:56 = main gear ALUMINUM fairings 1:06 = spinner 1:13 = tail fairing -----Original Message----- From: Brian Meyette [mailto:brianpublic(at)starband.net] Subject: RE: RV7-List: Orndorff videos index Yeah - I have it - number refers to the minute that it starts on TAPE 1 0 = tipup 0:15 = slider 1:13 = engine mount 1:19 = nose gear mount 1:24 = wheels & tires 1:31 = main gear 1:40 = slider canopy, front fiberglass trim TAPE 2 0 = finish slider fiberglass 0:17 = brakes 0:27 = back to slider windshield fiberglass 0:28 = mount H-stab 0:35 = V-stab 0:42 = stabilizer tips fiberglass 0:43 = mount engine 1:00 = spinner & prop 1:16 = top cowl 1:29 = bottom cowl 1:40 = air scoop 1:46 = air box TAPE 3 0 = finish air box 0:4 = fiberglass scoop to cowl 0:10 = lower cowl hinges 0:15 = blend scoop to lower cowl 0:18 = nose wheel fairing 0:24 = nose gear fairing 0:30 = U620/621 cowl brackets 0:32 = fiberglass gear fairings HTH, brian http://brian76.mystarband.net/RV-7Ahome.htm -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of JTAnon(at)AOL.com Subject: RV7-List: Orndorff videos index Hi All, Has anyone indexed the Orndoff videos. Specifically the finish kit set? John McDonnell --- --- --- ________________________________________________________________________________
Date: Nov 12, 2004
And while we're at it, here's the list for the "Aircraft Systems" tapes: TAPE 1 0 = intro 0:5 = engine acc, cowl baffles 0:27 = instrument panel, throttle/prop cables 0:35 = fuel pump & fuel plumbing 0:38-0:43 = making hoses 0:48 = oil system 0:54 = hot air 1:02 = brake lines 1:06 = instrument panel 1:22 = soundproofing 1:26 = antennas 1:36 = wiring TAPE 2 0 = wiring 0:18 = cabin air & heat 0:21 = more wiring 0:23 = pre-oiling 0:26 = flight instruments 0:31 = showing us his house 0:35 = starting engine 0:37 = painting 0:44 = pre-flight prep & first flight 0:52 = trim & correcting heavy wing I have the Quick Build tapes, too, but they are so out of date George oughta be ashamed of himself for continuing to sell them. -----Original Message----- From: Brian Meyette [mailto:brianpublic(at)starband.net] Subject: RE: RV7-List: Orndorff videos index Whoops - Ieft out part of TAPE 3. Here's the full list: TAPE 1 0 = tipup 0:15 = slider 1:13 = engine mount 1:19 = nose gear mount 1:24 = wheels & tires 1:31 = main gear 1:40 = slider canopy, front fiberglass trim TAPE 2 0 = finish slider fiberglass 0:17 = brakes 0:27 = back to slider windshield fiberglass 0:28 = mount H-stab 0:35 = V-stab 0:42 = stabilizer tips fiberglass 0:43 = mount engine 1:00 = spinner & prop 1:16 = top cowl 1:29 = bottom cowl 1:40 = air scoop 1:46 = air box TAPE 3 0 = finish air box 0:4 = fiberglass scoop to cowl 0:10 = lower cowl hinges 0:15 = blend scoop to lower cowl 0:18 = nose wheel fairing 0:24 = nose gear fairing 0:30 = U620/621 cowl brackets 0:32 = fiberglass gear fairings 0:42 = fiberglass bottom cowl/air scoop 0:47 = main wheel pants 0:56 = main gear ALUMINUM fairings 1:06 = spinner 1:13 = tail fairing -----Original Message----- From: Brian Meyette [mailto:brianpublic(at)starband.net] Subject: RE: RV7-List: Orndorff videos index Yeah - I have it - number refers to the minute that it starts on TAPE 1 0 = tipup 0:15 = slider 1:13 = engine mount 1:19 = nose gear mount 1:24 = wheels & tires 1:31 = main gear 1:40 = slider canopy, front fiberglass trim TAPE 2 0 = finish slider fiberglass 0:17 = brakes 0:27 = back to slider windshield fiberglass 0:28 = mount H-stab 0:35 = V-stab 0:42 = stabilizer tips fiberglass 0:43 = mount engine 1:00 = spinner & prop 1:16 = top cowl 1:29 = bottom cowl 1:40 = air scoop 1:46 = air box TAPE 3 0 = finish air box 0:4 = fiberglass scoop to cowl 0:10 = lower cowl hinges 0:15 = blend scoop to lower cowl 0:18 = nose wheel fairing 0:24 = nose gear fairing 0:30 = U620/621 cowl brackets 0:32 = fiberglass gear fairings HTH, brian http://brian76.mystarband.net/RV-7Ahome.htm -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of JTAnon(at)AOL.com Subject: RV7-List: Orndorff videos index Hi All, Has anyone indexed the Orndoff videos. Specifically the finish kit set? John McDonnell --- --- --- --- ________________________________________________________________________________
Date: Nov 12, 2004
Subject: Re: Orndorff videos index
God Bless you Brian John McDonnell (dreading the canopy) ________________________________________________________________________________
Date: Nov 12, 2004
God Double Bless Brian John DNA ________________________________________________________________________________
Date: Nov 12, 2004
Hi , would anybody have a set for sale, contact me directly. Franz -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Brian Meyette Subject: RE: RV7-List: Orndorff videos index Whoops - Ieft out part of TAPE 3. Here's the full list: TAPE 1 0 = tipup 0:15 = slider 1:13 = engine mount 1:19 = nose gear mount 1:24 = wheels & tires 1:31 = main gear 1:40 = slider canopy, front fiberglass trim TAPE 2 0 = finish slider fiberglass 0:17 = brakes 0:27 = back to slider windshield fiberglass 0:28 = mount H-stab 0:35 = V-stab 0:42 = stabilizer tips fiberglass 0:43 = mount engine 1:00 = spinner & prop 1:16 = top cowl 1:29 = bottom cowl 1:40 = air scoop 1:46 = air box TAPE 3 0 = finish air box 0:4 = fiberglass scoop to cowl 0:10 = lower cowl hinges 0:15 = blend scoop to lower cowl 0:18 = nose wheel fairing 0:24 = nose gear fairing 0:30 = U620/621 cowl brackets 0:32 = fiberglass gear fairings 0:42 = fiberglass bottom cowl/air scoop 0:47 = main wheel pants 0:56 = main gear ALUMINUM fairings 1:06 = spinner 1:13 = tail fairing -----Original Message----- From: Brian Meyette [mailto:brianpublic(at)starband.net] Subject: RE: RV7-List: Orndorff videos index Yeah - I have it - number refers to the minute that it starts on TAPE 1 0 = tipup 0:15 = slider 1:13 = engine mount 1:19 = nose gear mount 1:24 = wheels & tires 1:31 = main gear 1:40 = slider canopy, front fiberglass trim TAPE 2 0 = finish slider fiberglass 0:17 = brakes 0:27 = back to slider windshield fiberglass 0:28 = mount H-stab 0:35 = V-stab 0:42 = stabilizer tips fiberglass 0:43 = mount engine 1:00 = spinner & prop 1:16 = top cowl 1:29 = bottom cowl 1:40 = air scoop 1:46 = air box TAPE 3 0 = finish air box 0:4 = fiberglass scoop to cowl 0:10 = lower cowl hinges 0:15 = blend scoop to lower cowl 0:18 = nose wheel fairing 0:24 = nose gear fairing 0:30 = U620/621 cowl brackets 0:32 = fiberglass gear fairings HTH, brian http://brian76.mystarband.net/RV-7Ahome.htm -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of JTAnon(at)AOL.com Subject: RV7-List: Orndorff videos index Hi All, Has anyone indexed the Orndoff videos. Specifically the finish kit set? John McDonnell --- --- --- --- --- ________________________________________________________________________________
Date: Nov 12, 2004
Hey John, I am finishing up the canopy fit now. It really isn't that bad; see details on my site, Dan Checkoway's, and Walter Tondu's. See my site for links. The BIG CUT, which I think everyone dreads, was rather anti-climatic. The frame takes a bunch of tinkering. At first it doesn't fit, then as you tweak here & there, it comes into place. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of JTAnon(at)AOL.com Subject: Re: RV7-List: Orndorff videos index God Bless you Brian John McDonnell (dreading the canopy) --- --- ________________________________________________________________________________
Date: Nov 14, 2004
Where can I get a set? I should be getting the wings and fuselage next month and the tapes would help. On Nov 12, 2004, at 3:04 PM, Franz Fux wrote: > > > Hi , > would anybody have a set for sale, contact me directly. > Franz > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Brian Meyette > To: rv7-list(at)matronics.com > Subject: RE: RV7-List: Orndorff videos index > > > > > Whoops - Ieft out part of TAPE 3. Here's the full list: > > TAPE 1 > 0 = tipup > 0:15 = slider > 1:13 = engine mount > 1:19 = nose gear mount > 1:24 = wheels & tires > 1:31 = main gear > 1:40 = slider canopy, front fiberglass trim > > TAPE 2 > 0 = finish slider fiberglass > 0:17 = brakes > 0:27 = back to slider windshield fiberglass > 0:28 = mount H-stab > 0:35 = V-stab > 0:42 = stabilizer tips fiberglass > 0:43 = mount engine > 1:00 = spinner & prop > 1:16 = top cowl > 1:29 = bottom cowl > 1:40 = air scoop > 1:46 = air box > > TAPE 3 > 0 = finish air box > 0:4 = fiberglass scoop to cowl > 0:10 = lower cowl hinges > 0:15 = blend scoop to lower cowl > 0:18 = nose wheel fairing > 0:24 = nose gear fairing > 0:30 = U620/621 cowl brackets > 0:32 = fiberglass gear fairings > 0:42 = fiberglass bottom cowl/air scoop > 0:47 = main wheel pants > 0:56 = main gear ALUMINUM fairings > 1:06 = spinner > 1:13 = tail fairing > > > -----Original Message----- > From: Brian Meyette [mailto:brianpublic(at)starband.net] > To: rv7-list(at)matronics.com > Subject: RE: RV7-List: Orndorff videos index > > Yeah - I have it - number refers to the minute that it starts on > > TAPE 1 > 0 = tipup > 0:15 = slider > 1:13 = engine mount > 1:19 = nose gear mount > 1:24 = wheels & tires > 1:31 = main gear > 1:40 = slider canopy, front fiberglass trim > > TAPE 2 > 0 = finish slider fiberglass > 0:17 = brakes > 0:27 = back to slider windshield fiberglass > 0:28 = mount H-stab > 0:35 = V-stab > 0:42 = stabilizer tips fiberglass > 0:43 = mount engine > 1:00 = spinner & prop > 1:16 = top cowl > 1:29 = bottom cowl > 1:40 = air scoop > 1:46 = air box > > > TAPE 3 > 0 = finish air box > 0:4 = fiberglass scoop to cowl > 0:10 = lower cowl hinges > 0:15 = blend scoop to lower cowl > 0:18 = nose wheel fairing > 0:24 = nose gear fairing > 0:30 = U620/621 cowl brackets > 0:32 = fiberglass gear fairings > > HTH, > brian > http://brian76.mystarband.net/RV-7Ahome.htm > > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of JTAnon(at)AOL.com > To: rv7-list(at)matronics.com > Subject: RV7-List: Orndorff videos index > > > Hi All, > > Has anyone indexed the Orndoff videos. Specifically the finish kit > set? > > John McDonnell > > > --- > > --- > > --- > > > --- > > --- > > > _-===================================================================== > _-> _-= -- Please Support Your Lists This Month -- > _-= (And Get Some AWESOME FREE Gifts!) > _-> _-= November is the Annual List Fund Raiser. Click on the > _-= Contribution link below to find out more about this > _-= year's Terrific Free Incentive Gifts provided by the > _-= The Builder's Bookstore www.buildersbooks.com! > _-> _-= List Contribution Web Site > _-> _-= http://www.matronics.com/contribution > _-> _-= Thank you for your generous support! > _-= -Matt Dralle, List Admin. > _-> _-===================================================================== > _-= - The RV7-List Email Forum - > _-= This forum is sponsored entirely through the Contributions > _-= of List members. You'll never see banner ads or any other > _-= form of direct advertising on the Matronics Forums. > _-===================================================================== > _-= List Related Information > _-= Post Message: rv7-list(at)matronics.com > _-= UN/SUBSCRIBE: http://www.matronics.com/subscription > _-= List FAQ: http://www.matronics.com/FAQ/RV7-List.htm > _-= Search Engine: http://www.matronics.com/search > _-= 7-Day Browse: http://www.matronics.com/browse/rv7-list > _-= Browse Digests: http://www.matronics.com/digest/rv7-list > _-= Live List Chat: http://www.matronics.com/chat > _-= Archives: http://www.matronics.com/archives > _-= Photo Share: http://www.matronics.com/photoshare > _-= List Specific: http://www.matronics.com/rv7-list > _-= Other Lists: http://www.matronics.com/emaillists > _-= Trouble Report http://www.matronics.com/trouble-report > _-= Contributions: http://www.matronics.com/contribution > _-===================================================================== > > _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The RV7-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: rv7-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/RV7-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/rv7-list _-= Browse Digests: http://www.matronics.com/digest/rv7-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/rv7-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
Subject: [ Keith T Uhls ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Keith T Uhls Lists: RV-List,RV6-List,RV7-List,RV9-List Subject: RV-7 with GRT EFIS and Dynon http://www.matronics.com/photoshare/keithuhls@juno.com.11.14.2004/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The RV7-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: rv7-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/RV7-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/rv7-list _-= Browse Digests: http://www.matronics.com/digest/rv7-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/rv7-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Subject: Proseal quantity?
Date: Nov 14, 2004
Gents, I am planning on using cartridges of Proseal to finish off my RV-7 tanks. I am purchasing my sealant from Aircraft Spruce. Does anyone know how many cartridges it will take to complete both tanks? What cartridge sizes ? Thanks, Paul _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The RV7-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: rv7-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/RV7-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/rv7-list _-= Browse Digests: http://www.matronics.com/digest/rv7-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/rv7-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 15, 2004
william, Try the Orndorff web site, www.fly-gbi.com/main.htm Mike Ice ----- Original Message ----- From: "William Bell" <wmlbell(at)comcast.net> Subject: Re: RV7-List: Orndorff videos index > > Where can I get a set? I should be getting the wings and fuselage next > month and the tapes would help. > On Nov 12, 2004, at 3:04 PM, Franz Fux wrote: > > > > > > > Hi , > > would anybody have a set for sale, contact me directly. > > Franz > > > > -----Original Message----- > > From: owner-rv7-list-server(at)matronics.com > > [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Brian Meyette > > To: rv7-list(at)matronics.com > > Subject: RE: RV7-List: Orndorff videos index > > > > > > > > > > Whoops - Ieft out part of TAPE 3. Here's the full list: > > > > TAPE 1 > > 0 = tipup > > 0:15 = slider > > 1:13 = engine mount > > 1:19 = nose gear mount > > 1:24 = wheels & tires > > 1:31 = main gear > > 1:40 = slider canopy, front fiberglass trim > > > > TAPE 2 > > 0 = finish slider fiberglass > > 0:17 = brakes > > 0:27 = back to slider windshield fiberglass > > 0:28 = mount H-stab > > 0:35 = V-stab > > 0:42 = stabilizer tips fiberglass > > 0:43 = mount engine > > 1:00 = spinner & prop > > 1:16 = top cowl > > 1:29 = bottom cowl > > 1:40 = air scoop > > 1:46 = air box > > > > TAPE 3 > > 0 = finish air box > > 0:4 = fiberglass scoop to cowl > > 0:10 = lower cowl hinges > > 0:15 = blend scoop to lower cowl > > 0:18 = nose wheel fairing > > 0:24 = nose gear fairing > > 0:30 = U620/621 cowl brackets > > 0:32 = fiberglass gear fairings > > 0:42 = fiberglass bottom cowl/air scoop > > 0:47 = main wheel pants > > 0:56 = main gear ALUMINUM fairings > > 1:06 = spinner > > 1:13 = tail fairing > > > > > > -----Original Message----- > > From: Brian Meyette [mailto:brianpublic(at)starband.net] > > To: rv7-list(at)matronics.com > > Subject: RE: RV7-List: Orndorff videos index > > > > Yeah - I have it - number refers to the minute that it starts on > > > > TAPE 1 > > 0 = tipup > > 0:15 = slider > > 1:13 = engine mount > > 1:19 = nose gear mount > > 1:24 = wheels & tires > > 1:31 = main gear > > 1:40 = slider canopy, front fiberglass trim > > > > TAPE 2 > > 0 = finish slider fiberglass > > 0:17 = brakes > > 0:27 = back to slider windshield fiberglass > > 0:28 = mount H-stab > > 0:35 = V-stab > > 0:42 = stabilizer tips fiberglass > > 0:43 = mount engine > > 1:00 = spinner & prop > > 1:16 = top cowl > > 1:29 = bottom cowl > > 1:40 = air scoop > > 1:46 = air box > > > > > > TAPE 3 > > 0 = finish air box > > 0:4 = fiberglass scoop to cowl > > 0:10 = lower cowl hinges > > 0:15 = blend scoop to lower cowl > > 0:18 = nose wheel fairing > > 0:24 = nose gear fairing > > 0:30 = U620/621 cowl brackets > > 0:32 = fiberglass gear fairings > > > > HTH, > > brian > > http://brian76.mystarband.net/RV-7Ahome.htm > > > > > > -----Original Message----- > > From: owner-rv7-list-server(at)matronics.com > > [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of JTAnon(at)AOL.com > > To: rv7-list(at)matronics.com > > Subject: RV7-List: Orndorff videos index > > > > > > Hi All, > > > > Has anyone indexed the Orndoff videos. Specifically the finish kit > > set? > > > > John McDonnell > > > > > > --- > > > > --- > > > > --- > > > > > > --- > > > > --- > > > > > > _-===================================================================== > > _-> _-= -- Please Support Your Lists This Month -- > > _-= (And Get Some AWESOME FREE Gifts!) > > _-> _-= November is the Annual List Fund Raiser. Click on the > > _-= Contribution link below to find out more about this > > _-= year's Terrific Free Incentive Gifts provided by the > > _-= The Builder's Bookstore www.buildersbooks.com! > > _-> _-= List Contribution Web Site > > _-> _-= http://www.matronics.com/contribution > > _-> _-= Thank you for your generous support! > > _-= -Matt Dralle, List Admin. > > _-> _-===================================================================== > > _-= - The RV7-List Email Forum - > > _-= This forum is sponsored entirely through the Contributions > > _-= of List members. You'll never see banner ads or any other > > _-= form of direct advertising on the Matronics Forums. > > _-===================================================================== > > _-= List Related Information > > _-= Post Message: rv7-list(at)matronics.com > > _-= UN/SUBSCRIBE: http://www.matronics.com/subscription > > _-= List FAQ: http://www.matronics.com/FAQ/RV7-List.htm > > _-= Search Engine: http://www.matronics.com/search > > _-= 7-Day Browse: http://www.matronics.com/browse/rv7-list > > _-= Browse Digests: http://www.matronics.com/digest/rv7-list > > _-= Live List Chat: http://www.matronics.com/chat > > _-= Archives: http://www.matronics.com/archives > > _-= Photo Share: http://www.matronics.com/photoshare > > _-= List Specific: http://www.matronics.com/rv7-list > > _-= Other Lists: http://www.matronics.com/emaillists > > _-= Trouble Report http://www.matronics.com/trouble-report > > _-= Contributions: http://www.matronics.com/contribution > > _-===================================================================== > > > > > > > _-===================================================================== > _-> _-= -- Please Support Your Lists This Month -- > _-= (And Get Some AWESOME FREE Gifts!) > _-> _-= November is the Annual List Fund Raiser. Click on the > _-= Contribution link below to find out more about this > _-= year's Terrific Free Incentive Gifts provided by the > _-= The Builder's Bookstore www.buildersbooks.com! > _-> _-= List Contribution Web Site > _-> _-= http://www.matronics.com/contribution > _-> _-= Thank you for your generous support! > _-= -Matt Dralle, List Admin. > _-> _-===================================================================== > _-= - The RV7-List Email Forum - > _-= This forum is sponsored entirely through the Contributions > _-= of List members. You'll never see banner ads or any other > _-= form of direct advertising on the Matronics Forums. > _-===================================================================== > _-= List Related Information > _-= Post Message: rv7-list(at)matronics.com > _-= UN/SUBSCRIBE: http://www.matronics.com/subscription > _-= List FAQ: http://www.matronics.com/FAQ/RV7-List.htm > _-= Search Engine: http://www.matronics.com/search > _-= 7-Day Browse: http://www.matronics.com/browse/rv7-list > _-= Browse Digests: http://www.matronics.com/digest/rv7-list > _-= Live List Chat: http://www.matronics.com/chat > _-= Archives: http://www.matronics.com/archives > _-= Photo Share: http://www.matronics.com/photoshare > _-= List Specific: http://www.matronics.com/rv7-list > _-= Other Lists: http://www.matronics.com/emaillists > _-= Trouble Report http://www.matronics.com/trouble-report > _-= Contributions: http://www.matronics.com/contribution > _-===================================================================== > > _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The RV7-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: rv7-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/RV7-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/rv7-list _-= Browse Digests: http://www.matronics.com/digest/rv7-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/rv7-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Subject: Re: Proseal quantity?
Date: Nov 15, 2004
I used 12 cartridges For two tanks. Be sure to use the cartridge gun it saves time and sealent. ----- Original Message ----- From: "Merems" <merems(at)cox.net> Subject: RV7-List: Proseal quantity? > > Gents, > > I am planning on using cartridges of Proseal to finish off my RV-7 tanks. I am purchasing my sealant from Aircraft Spruce. Does anyone know how many cartridges it will take to complete both tanks? What cartridge sizes ? > > Thanks, > > Paul > > ________________________________________________________________________________
Date: Nov 15, 2004
Thanks much. On Nov 15, 2004, at 9:30 AM, Michael T. Ice wrote: > > william, > > Try the Orndorff web site, > > www.fly-gbi.com/main.htm > > > Mike Ice > > ----- Original Message ----- > From: "William Bell" <wmlbell(at)comcast.net> > To: > Subject: Re: RV7-List: Orndorff videos index > > >> >> Where can I get a set? I should be getting the wings and fuselage >> next >> month and the tapes would help. >> On Nov 12, 2004, at 3:04 PM, Franz Fux wrote: >> >>> >>> >>> Hi , >>> would anybody have a set for sale, contact me directly. >>> Franz >>> >>> -----Original Message----- >>> From: owner-rv7-list-server(at)matronics.com >>> [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Brian >>> Meyette >>> To: rv7-list(at)matronics.com >>> Subject: RE: RV7-List: Orndorff videos index >>> >>> >>> >>> >>> Whoops - Ieft out part of TAPE 3. Here's the full list: >>> >>> TAPE 1 >>> 0 = tipup >>> 0:15 = slider >>> 1:13 = engine mount >>> 1:19 = nose gear mount >>> 1:24 = wheels & tires >>> 1:31 = main gear >>> 1:40 = slider canopy, front fiberglass trim >>> >>> TAPE 2 >>> 0 = finish slider fiberglass >>> 0:17 = brakes >>> 0:27 = back to slider windshield fiberglass >>> 0:28 = mount H-stab >>> 0:35 = V-stab >>> 0:42 = stabilizer tips fiberglass >>> 0:43 = mount engine >>> 1:00 = spinner & prop >>> 1:16 = top cowl >>> 1:29 = bottom cowl >>> 1:40 = air scoop >>> 1:46 = air box >>> >>> TAPE 3 >>> 0 = finish air box >>> 0:4 = fiberglass scoop to cowl >>> 0:10 = lower cowl hinges >>> 0:15 = blend scoop to lower cowl >>> 0:18 = nose wheel fairing >>> 0:24 = nose gear fairing >>> 0:30 = U620/621 cowl brackets >>> 0:32 = fiberglass gear fairings >>> 0:42 = fiberglass bottom cowl/air scoop >>> 0:47 = main wheel pants >>> 0:56 = main gear ALUMINUM fairings >>> 1:06 = spinner >>> 1:13 = tail fairing >>> >>> >>> -----Original Message----- >>> From: Brian Meyette [mailto:brianpublic(at)starband.net] >>> To: rv7-list(at)matronics.com >>> Subject: RE: RV7-List: Orndorff videos index >>> >>> Yeah - I have it - number refers to the minute that it starts on >>> >>> TAPE 1 >>> 0 = tipup >>> 0:15 = slider >>> 1:13 = engine mount >>> 1:19 = nose gear mount >>> 1:24 = wheels & tires >>> 1:31 = main gear >>> 1:40 = slider canopy, front fiberglass trim >>> >>> TAPE 2 >>> 0 = finish slider fiberglass >>> 0:17 = brakes >>> 0:27 = back to slider windshield fiberglass >>> 0:28 = mount H-stab >>> 0:35 = V-stab >>> 0:42 = stabilizer tips fiberglass >>> 0:43 = mount engine >>> 1:00 = spinner & prop >>> 1:16 = top cowl >>> 1:29 = bottom cowl >>> 1:40 = air scoop >>> 1:46 = air box >>> >>> >>> TAPE 3 >>> 0 = finish air box >>> 0:4 = fiberglass scoop to cowl >>> 0:10 = lower cowl hinges >>> 0:15 = blend scoop to lower cowl >>> 0:18 = nose wheel fairing >>> 0:24 = nose gear fairing >>> 0:30 = U620/621 cowl brackets >>> 0:32 = fiberglass gear fairings >>> >>> HTH, >>> brian >>> http://brian76.mystarband.net/RV-7Ahome.htm >>> >>> >>> -----Original Message----- >>> From: owner-rv7-list-server(at)matronics.com >>> [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of >>> JTAnon(at)AOL.com >>> To: rv7-list(at)matronics.com >>> Subject: RV7-List: Orndorff videos index >>> >>> >>> Hi All, >>> >>> Has anyone indexed the Orndoff videos. Specifically the finish kit >>> set? >>> >>> John McDonnell >>> >>> >>> --- >>> >>> --- >>> >>> --- >>> >>> >>> --- >>> >>> --- >>> >>> >>> _- >>> ===================================================================== >>> _-> >>> _- >>> ===================================================================== >>> _- >>> ===================================================================== >>> >>> >> >> >> _- >> ===================================================================== >> _-> >> _- >> ===================================================================== >> _- >> ===================================================================== >> _- >> ===================================================================== >> >> > > ________________________________________________________________________________
Date: Nov 16, 2004
Subject: Re: Lead counter weights
I used a rasp and then a fine file to get it the way I wanted. Hope that helps. Tad Sargent Sargentclt(at)CS.com RV7A ________________________________________________________________________________
Date: Nov 17, 2004
Subject: VS Rudder Faring Holes
Hello Folks, I am getting ready to rivet the rudder. Some of the skin to rib holes are left open for the farings. Does anyone know if these are suppossed to be dimpled along with all the others. Thanks Andy RV7 or 7A ________________________________________________________________________________
Date: Nov 17, 2004
Subject: Re: VS Rudder Faring Holes
Sorry, I meant the faring holes for the Vertical Stabilizer. Andy ________________________________________________________________________________
Date: Nov 17, 2004
Andy, My 2 cents is not to bother thinking about where that fairing will attach yet. It's just as easy to drill the screw hole(s) between rivets, rather than trying to locate them on a rivet hole. My point is don't sweat it now. If you do choose to co-locate screw holes on existing rivet holes, don't dimple 'em. For what it's worth, I dimpled & riveted every hole. When I mounted my fairing I just drilled new holes for the screws & nutplates. It's not a big deal. The one area where it matters much more (imho) is on F-709. I had riveted that entirely, and had to drill a couple of rivets out for the screw holes. It's less trivial to drill new holes between rivets in that spot, and much more straightforward to use existing rivet holes. You'll see what I mean. )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: <Bellwa77(at)AOL.com> Subject: Re: RV7-List: VS Rudder Faring Holes > > Sorry, I meant the faring holes for the Vertical Stabilizer. > > Andy > > ________________________________________________________________________________ DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; b=kZ7furyoIA3DDM6l74Z9Lwia31j316JMp9OYEC6q+Ux8tbykzj//WX2kadcR8DHM0ZXffEGeMCzQzVQuZhVbZYwsxcEv1bJZK/iAQmip1aFZgXRZVmYLZkJuzSjH4MiQ4HQNPWFiO8+l+z/ZzpkxWLieTXSDixduTg/6f6kP/fg;
Date: Nov 19, 2004
Subject: My rv7 Quick Build kit is for sale
I have a RV7a QB kit for sale. The empennage is complete (built under the supervision of George Orendorff), and the autopilot has been installed in the wing. The wings have all the control surfaces installed. These were also installed under the supervision of George. In addition, I have the wing light kit, and the strobe light kit (Whelen) still in the box. All purchased from Van's. I have a dimpler, an air squeezer and many special tools. Also, Dupont Vari-prime primer, and fiberglassing tools and products. Also have a nice workbench. The workmanship on this kit is excellent. Everything has been primed with vari-prime and all metal work is excellent. I haven't done any fiberglassing I'll sell it all for around $25,000. I live in Euless, Texas. Telephone 817-685-2120. Tom Hadley ===== Tom Hadley RV7a __________________________________ http://my.yahoo.com ________________________________________________________________________________
Date: Nov 19, 2004
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Damn...your a month too late for me...:( -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Thomas Hadley Subject: RV7-List: My rv7 Quick Build kit is for sale I have a RV7a QB kit for sale. The empennage is complete (built under the supervision of George Orendorff), and the autopilot has been installed in the wing. The wings have all the control surfaces installed. These were also installed under the supervision of George. In addition, I have the wing light kit, and the strobe light kit (Whelen) still in the box. All purchased from Van's. I have a dimpler, an air squeezer and many special tools. Also, Dupont Vari-prime primer, and fiberglassing tools and products. Also have a nice workbench. The workmanship on this kit is excellent. Everything has been primed with vari-prime and all metal work is excellent. I haven't done any fiberglassing I'll sell it all for around $25,000. I live in Euless, Texas. Telephone 817-685-2120. Tom Hadley ===== Tom Hadley RV7a __________________________________ http://my.yahoo.com ________________________________________________________________________________
Subject: thinking about buying
Date: Nov 21, 2004
Hello all, I am pondering the 7A or the 9A..I'm sure you guys have some opinions and why you bought the 7..If you have a minute help me out...Also, what is the distance between the landing gear, I'm trying to compare it to my 172E. and that of a Warrior.. Tks Ron ________________________________________________________________________________
From: "Francis, David CMDR" <David.Francis(at)defence.gov.au>
Date: Nov 22, 2004
Ron, They are different aircraft to meet differing needs. The RV7 is the typical RV family design - an aerobatic fun machine that has a fairly good cross country performance. To get good sportplane style performance, at the weight needed to provide a strong aerobatic airframe, largish engines are required - 160-200hp. To cater for those who do not need or desire aerobatic capability the RV9 was designed to be a cheap and very efficient non-arobatic cross country cruiser. Hence a modernised RV6 fuselage was married to a lightweight wing. Span was increased to give good high altitude cruise performance, and as a side effect good runway performance. Because it is light and non-aerobatic smaller, cheaper engines are suitable in the 125-160hp range. Take your choice, but they are very different planes for different missions at very different total cost. PS, they perform a lot better if you throw away the A. Tail draggers forever. David Francis, RV7 VH-ZEE, Canberra, Australia -----Original Message----- From: Ron Brown [mailto:brown_rj(at)bellsouth.net] Subject: RV7-List: thinking about buying Hello all, I am pondering the 7A or the 9A..I'm sure you guys have some opinions and why you bought the 7..If you have a minute help me out...Also, what is the distance between the landing gear, I'm trying to compare it to my 172E. and that of a Warrior.. Tks Ron ________________________________________________________________________________
Subject: Re: thinking about buying
Date: Nov 21, 2004
Eh...since you posted this to the rv7-list, you gotta expect some pretty biased answers. Here's mine... The cliche: If you wanted to fly a trainer, you'd keep dumping money into your 172E. If you want to fly a 200+mph aerobatic efficient little speed demon -- that is just as stable but more solid and defines "obedient" -- go with the RV-7[A]. ;-) But really, build any RV and you can't lose. If you do build a -9A, though, try to make sure you won't outgrow it -- or be prepared to build a 2nd RV if you do. Personally, I like having the versatility. You can fly an RV-7 like an RV-9, but NOT vice versa. I've never heard anybody say, "Man, I wish I had less power," or "Man, if only this plane was a few knots slower." An O-360 equipped RV-7A versus an O-320 equipped RV-9A...what's the difference in total cost to build? My guess is essentially nothing. Best of luck, )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Ron Brown" <brown_rj(at)bellsouth.net> Subject: RV7-List: thinking about buying > > Hello all, > I am pondering the 7A or the 9A..I'm sure you guys have some opinions and why you bought the 7..If you have a minute help me out...Also, what is the distance between the landing gear, I'm trying to compare it to my 172E. and that of a Warrior.. > Tks > Ron > > ________________________________________________________________________________
Date: Nov 22, 2004
Hi Ron, I detect you being a bit nervous about the flying and landing qualities of an RV. Yep, it is not like your 172, but what a challenge. When you get to that magic day, and at last fly your creation, and another member of the family, that it is feet on the rudder, one hand on the stick, and the other on the power, you are in charge, and you fly it as pilot in command. I have heaps of time in production aircraft, but I am realy looking forward to finishing my 7, and facing the challenge. However, like you it, will be with a certain amount of apprehension. Stan Jones -------Original Message------- From: rv7-list(at)matronics.com Date: Monday, November 22, 2004 15:51:47 Subject: RV7-List: thinking about buying Hello all, I am pondering the 7A or the 9A..I'm sure you guys have some opinions and why you bought the 7..If you have a minute help me out...Also, what is the distance between the landing gear, I'm trying to compare it to my 172E. and that of a Warrior.. Tks Ron ________________________________________________________________________________
Date: Nov 22, 2004
Here here David, biff the A Tail draggers are the way to go. Stan Jones. Here we go again -------Original Message------- From: rv7-list(at)matronics.com Date: Monday, November 22, 2004 14:43:47 Subject: SEC: UNCLASSIFIED RE: RV7-List: thinking about buying gov.au> Ron, They are different aircraft to meet differing needs. The RV7 is the typical RV family design - an aerobatic fun machine that has a fairly good cross country performance. To get good sportplane style performance, at the weight needed to provide a strong aerobatic airframe, largish engines are required - 160-200hp. To cater for those who do not need or desire aerobatic capability the RV9 was designed to be a cheap and very efficient non-arobatic cross country cruiser. Hence a modernised RV6 fuselage was married to a lightweight wing. Span was increased to give good high altitude cruise performance, and as a side effect good runway performance. Because it is light and non-aerobatic smaller, cheaper engines are suitable in the 125-160hp range. Take your choice, but they are very different planes for different missions at very different total cost. PS, they perform a lot better if you throw away the A. Tail draggers forever. David Francis, RV7 VH-ZEE, Canberra, Australia -----Original Message----- From: Ron Brown [mailto:brown_rj(at)bellsouth.net] Subject: RV7-List: thinking about buying Hello all, I am pondering the 7A or the 9A..I'm sure you guys have some opinions and why you bought the 7..If you have a minute help me out...Also, what is the distance between the landing gear, I'm trying to compare it to my 172E. and that of a Warrior.. Tks Ron ________________________________________________________________________________
From: "Peter DeCraene" <peterdecraene(at)comcast.net>
Date: Nov 22, 2004
Ron, I have to agree with Dan's answer. I have flown both the 9A and 7A. The biggest difference in they way that they handle in cruise is the stick force. The 9 is solid where the 7 requires light force to put in in a turn. I tested my auto pilot this weekend and it will make a long cross country easy. In the patern both airplanes handle about the same. The 9 will float a little more but nothing like the 172. I was apprehensive about doing my first flight and even considered letting someone else do the honors until I did transition training. After that I felt confident that I could handle the airplane. Go with the the 7 if you think you might want to do a roll every now and then, (once your flying it you will) and try to stay current while you build. Pete DeCraene N526PD RV-7A ----- Original Message ----- From: "Ron Brown" <brown_rj(at)bellsouth.net> Subject: RV7-List: thinking about buying > > Hello all, > I am pondering the 7A or the 9A..I'm sure you guys have some opinions and > why you bought the 7..If you have a minute help me out...Also, what is the > distance between the landing gear, I'm trying to compare it to my 172E. > and that of a Warrior.. > Tks > Ron > > > ________________________________________________________________________________
Date: Nov 22, 2004
I went with the 7A for the "Walter Mitty" factor - I just thought it would be cool to be able to do aerobatics occasionally, even though I don't really know if I'll like it. After all, one reason I sold my 172 is I was getting a little bored with straight-and-level. I also reasoned that the airplane would have a little better performance and be a little stronger structurally thant the -9. Don't let anyone talk you out of the nosewheel - it's nice to be able to land in a crosswind. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Ron Brown Subject: RV7-List: thinking about buying Hello all, I am pondering the 7A or the 9A..I'm sure you guys have some opinions and why you bought the 7..If you have a minute help me out...Also, what is the distance between the landing gear, I'm trying to compare it to my 172E. and that of a Warrior.. Tks Ron ________________________________________________________________________________
Date: Nov 22, 2004
Why can't you land in a cross wind with a tail dragger? Herron, Al wrote: > >I went with the 7A for the "Walter Mitty" factor - I just thought it would >be cool to be able to do aerobatics occasionally, even though I don't really >know if I'll like it. After all, one reason I sold my 172 is I was getting >a little bored with straight-and-level. I also reasoned that the airplane >would have a little better performance and be a little stronger structurally >thant the -9. Don't let anyone talk you out of the nosewheel - it's nice to >be able to land in a crosswind. > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Ron Brown >To: rv7-list(at)matronics.com >Subject: RV7-List: thinking about buying > > >Hello all, >I am pondering the 7A or the 9A..I'm sure you guys have some opinions and >why you bought the 7..If you have a minute help me out...Also, what is the >distance between the landing gear, I'm trying to compare it to my 172E. and >that of a Warrior.. >Tks >Ron > > > > ________________________________________________________________________________
Date: Nov 22, 2004
Because he made a joke trying to bait some of you. Its always fun to watch. Franz RV7Eh -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Norman Younie Subject: Re: RV7-List: thinking about buying Why can't you land in a cross wind with a tail dragger? Herron, Al wrote: > >I went with the 7A for the "Walter Mitty" factor - I just thought it would >be cool to be able to do aerobatics occasionally, even though I don't really >know if I'll like it. After all, one reason I sold my 172 is I was getting >a little bored with straight-and-level. I also reasoned that the airplane >would have a little better performance and be a little stronger structurally >thant the -9. Don't let anyone talk you out of the nosewheel - it's nice to >be able to land in a crosswind. > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Ron Brown >To: rv7-list(at)matronics.com >Subject: RV7-List: thinking about buying > > >Hello all, >I am pondering the 7A or the 9A..I'm sure you guys have some opinions and >why you bought the 7..If you have a minute help me out...Also, what is the >distance between the landing gear, I'm trying to compare it to my 172E. and >that of a Warrior.. >Tks >Ron > > --- --- ________________________________________________________________________________
Date: Nov 23, 2004
Of course you can land in a crosswind with a tail dragger. That's what the rudder pedals are for. -------Original Message------- From: rv7-list(at)matronics.com Date: Tuesday, November 23, 2004 07:53:14 Subject: Re: RV7-List: thinking about buying Why can't you land in a cross wind with a tail dragger? Herron, Al wrote: > >I went with the 7A for the "Walter Mitty" factor - I just thought it would >be cool to be able to do aerobatics occasionally, even though I don't really >know if I'll like it. After all, one reason I sold my 172 is I was getting >a little bored with straight-and-level. I also reasoned that the airplane >would have a little better performance and be a little stronger structurally >thant the -9. Don't let anyone talk you out of the nosewheel - it's nice to >be able to land in a crosswind. > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Ron Brown >To: rv7-list(at)matronics.com >Subject: RV7-List: thinking about buying > > >Hello all, >I am pondering the 7A or the 9A..I'm sure you guys have some opinions and >why you bought the 7..If you have a minute help me out...Also, what is the >distance between the landing gear, I'm trying to compare it to my 172E. and >that of a Warrior.. >Tks >Ron > > ________________________________________________________________________________
Date: Nov 22, 2004
Some people just don't want the "adventure" of the tailwheel. :) Something's gotta seperate the men from the boys.. LOL ----- Original Message ----- From: "Stan Jones" <stan.jones(at)xtra.co.nz> Subject: Re: RV7-List: thinking about buying > > Of course you can land in a crosswind with a tail dragger. That's what the > rudder pedals are for. > > -------Original Message------- > > From: rv7-list(at)matronics.com > Date: Tuesday, November 23, 2004 07:53:14 > To: rv7-list(at)matronics.com > Subject: Re: RV7-List: thinking about buying > > > Why can't you land in a cross wind with a tail dragger? > > Herron, Al wrote: > > > > >I went with the 7A for the "Walter Mitty" factor - I just thought it would > >be cool to be able to do aerobatics occasionally, even though I don't > really > >know if I'll like it. After all, one reason I sold my 172 is I was getting > >a little bored with straight-and-level. I also reasoned that the airplane > >would have a little better performance and be a little stronger > structurally > >thant the -9. Don't let anyone talk you out of the nosewheel - it's nice to > >be able to land in a crosswind. > > > >-----Original Message----- > >From: owner-rv7-list-server(at)matronics.com > >[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Ron Brown > >To: rv7-list(at)matronics.com > >Subject: RV7-List: thinking about buying > > > > > > > >Hello all, > >I am pondering the 7A or the 9A..I'm sure you guys have some opinions and > >why you bought the 7..If you have a minute help me out...Also, what is the > >distance between the landing gear, I'm trying to compare it to my 172E. and > >that of a Warrior.. > >Tks > >Ron > > > > > > ________________________________________________________________________________
From: "David Figgins" <2004nospam(at)earthlink.net>
Subject: elevator
Date: Nov 23, 2004
I am just finishing the left elevator and last night bent the tabs at the cutout where the trim tab fits, the bend does not look very good as I could not position the wood blocks properly due to the stiffeners, the net result is the bend is not sharp an not quite at 90 degrees to the trailing edge. Not sure what I can do apart from buying new skin and stiffeners and starting over. I thought about cutting this area out and making an end cap rib and riveting it in position. Anyone else screwed this area up and fixed it? Strikes me this would have been easier to do first before the stiffeners were installed and the sharp skin bend made but I was following the directions. Dave (irritated on last elevator waiting for wings) ________________________________________________________________________________
Date: Nov 23, 2004
> It flies like a much bigger > airplane than it is. Careful in reading into that comment. I know what Dan means and totally agree with him, but it doesn't feel like anything "big" per se. It's more responsive, and more obedient...which tends to highlight either the pilot's skill or lack thereof...which in my opinion makes the RV an *excellent* plane to fly. It makes just about any pilot better, because it doesn't obscure bad habits like other planes do. Sloppy rudder work, you (and your passengers) are gonna know about it. Over-controlling, you'll know about it. It doesn't take more than about 20 minutes in flight or a handful of takeoffs and landings to build your finesse up. It's all about a light touch, just fingertip pressure in most phases of flight. That said, the plane is not twitchy or unpredictable. It does what the pilot commands it to do. Trim it up and take your hands & feet off the controls. Very stable. In bumps it's more susceptible to larger roll excursions being induced than, say, a Mooney or a "bigger" plane. But like any other plane, it's usually best not to over-control it, just let it ride the bumps and use fingertip pressure to keep it in check (or click on the autopilot). "Bigger" planes tend to have more control force. I use the example of the Mooney again...at higher airspeeds, control force in a Mooney gets very stiff. In the RV, it does stiffens up, but proportionately less -- control break-out force is much lower than in most spam cans capable of indicating 150-160 knots in cruise. In your Cessna 172E, you probably never get fast enough to feel the same type of effect. "Bigger" planes also tend to feel heavier on approach and landing. Sometimes, even when a bigger plane is trimmed, you feel like you have to tug at the yoke -- specifically a Skylane, which produces a very heavy feel in the flare. In some planes & conditions it's not unusual to use full aileron inputs to counteract gusts, turbulence, what have you. In my RV, the only time the stick has ever hit the stop in flight has been when doing rolls or stalls (stick back). You have so much more control authority in an RV than in a bigger plane. It gets "mushy" relatively speaking, but it still takes less control movement than you might imagine if you've never flown one before. Again, "obedient" is the word I use. I tend to associate "bigger" with a heavier feel. The RV is anything but heavy in feel. Experience it firsthand. Go get a ride in an RV-7 and make sure the pilot lets you do some flying! ;-) )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Nov 23, 2004
In a message dated 11/23/04 10:53:48 AM US Eastern Standard Time, dan(at)rvproject.com writes: > > >It flies like a much bigger > >airplane than it is. > > Careful in reading into that comment. I know what Dan means and totally > agree with him, but it doesn't feel like anything "big" per se. > > You're right Dan C. Very good explanation. What I meant to say was that it doesn't fly like you might expect a plane its size to fly. That being twitchy and unstable. I have only been flying about 6 years -- about 600 hours, and found the RV7A to be very easy to learn how to fly. The 200 hp actually makes it easier to handle, in my opinion. You don't have to wonder if you'll have enough runway! If you rotate a little too early, let off the elevator a little and up she goes, anyway. Now, don't flame me for flying sloppy, I'm only speaking in relative terms here. Dan H. RV-7A ________________________________________________________________________________
Date: Nov 23, 2004
I have flown the RV-6, the 6A, the 7 and the 9A. Every one is a dream to fly after flying rented 172's, 182's, T-210's, V-tails, Bellanca's, Piper's and Mooney's for years. Tail wheel vs. nose wheel? I prefer recent technology. We've been to the moon and back since tail wheels were invented. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Dan Checkoway Subject: Re: RV7-List: thinking about buying > It flies like a much bigger > airplane than it is. Careful in reading into that comment. I know what Dan means and totally agree with him, but it doesn't feel like anything "big" per se. It's more responsive, and more obedient...which tends to highlight either the pilot's skill or lack thereof...which in my opinion makes the RV an *excellent* plane to fly. It makes just about any pilot better, because it doesn't obscure bad habits like other planes do. Sloppy rudder work, you (and your passengers) are gonna know about it. Over-controlling, you'll know about it. It doesn't take more than about 20 minutes in flight or a handful of takeoffs and landings to build your finesse up. It's all about a light touch, just fingertip pressure in most phases of flight. That said, the plane is not twitchy or unpredictable. It does what the pilot commands it to do. Trim it up and take your hands & feet off the controls. Very stable. In bumps it's more susceptible to larger roll excursions being induced than, say, a Mooney or a "bigger" plane. But like any other plane, it's usually best not to over-control it, just let it ride the bumps and use fingertip pressure to keep it in check (or click on the autopilot). "Bigger" planes tend to have more control force. I use the example of the Mooney again...at higher airspeeds, control force in a Mooney gets very stiff. In the RV, it does stiffens up, but proportionately less -- control break-out force is much lower than in most spam cans capable of indicating 150-160 knots in cruise. In your Cessna 172E, you probably never get fast enough to feel the same type of effect. "Bigger" planes also tend to feel heavier on approach and landing. Sometimes, even when a bigger plane is trimmed, you feel like you have to tug at the yoke -- specifically a Skylane, which produces a very heavy feel in the flare. In some planes & conditions it's not unusual to use full aileron inputs to counteract gusts, turbulence, what have you. In my RV, the only time the stick has ever hit the stop in flight has been when doing rolls or stalls (stick back). You have so much more control authority in an RV than in a bigger plane. It gets "mushy" relatively speaking, but it still takes less control movement than you might imagine if you've never flown one before. Again, "obedient" is the word I use. I tend to associate "bigger" with a heavier feel. The RV is anything but heavy in feel. Experience it firsthand. Go get a ride in an RV-7 and make sure the pilot lets you do some flying! ;-) )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Subject: RV7 List Thinking about Buying
Date: Nov 23, 2004
Prior to purchasing an RV I owned 4 different Cessnas including a 172, 2 - 182s, and a 170B. A few years ago I became interested in RVs and finally purchased an already built RV6 a few months ago. It is a very nice plane with a 180HP Lyc and a constant speed prop. At purchase time I had never piloted a low wing plane and had about 100 hours of Cessna 170 tail dragger time. I am having the time of my life with this new RV6. I now have about 15 or 20 hours in it (6 of which was dual time), and while I certainly respect the plane and am not overconfident in it, it is comfortable for me at this point. The RV6 is at least as easy to take-off and land as any plane I have flown....probably easier.....and frankly tail draggers are more enjoyable for me, although I fully understand that not everyone shares that enthusiasm for them. Additionally I like the agility, speed, cross country worthiness, and short field performance of the RVs. My feeling is that no matter what model of RV you decide to purchase you will enjoy it. My only counsel would be, since you will probably move up the RV learning curve pretty quickly....think ahead and honestly evaluate the type of flying you enjoy so you dont have to look back and wish you had purchased more engine and prop than you did. Mike Robertson, at Van's homecoming, kindly gave me a ride in his 9A and that is one VERY nice plane (thanks Mike!)....but as Dan Checkoway (I think) aptly stated, you can fly a 7 like a 9, but not the other way around....but then you may not need the flying characteristics of a 7...Mike's 9A was a beauty, was very agile, and flew very nicely. To summarize....its all up to you....and generally speaking, you wont go wrong with an RV. Good luck. Tony Marshall www.lambros.com P.O. Box 906 Polson, MT 59860 800-432-6828 Office 406-249-0835 Cell ________________________________________________________________________________
Date: Nov 23, 2004
We've been to the moon & back since nose wheels were invented. too. Come to think of it, we've been to the moon & back since Lycomings were invented. Which recent technology is powering your plane? ;-) Actually, a trike is likely more valuable on the market & will certainly have a larger base of potential buyers if you need to sell. Charlie (lazy prefer tailwheel to keep me honest & alert but have no problem with better pilots preferring nosewheels) Imken wrote: > >I have flown the RV-6, the 6A, the 7 and the 9A. Every one is a dream to >fly after flying rented 172's, 182's, T-210's, V-tails, Bellanca's, Piper's >and Mooney's for years. Tail wheel vs. nose wheel? I prefer recent >technology. We've been to the moon and back since tail wheels were >invented. > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Dan Checkoway >To: rv7-list(at)matronics.com >Subject: Re: RV7-List: thinking about buying > > ________________________________________________________________________________
From: "Brian J. Decker" <bdecker(at)blueroofranch.com>
Subject: elevator
Date: Nov 23, 2004
I made a similar mistake on my RV-8 a couple of years ago. I wasn't happy with the bends so I removed the "ears" and fabricated a small piece that I could pro-seal in place. I think it looked better than the folds when I was done. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of David Figgins vansairforce(at)yahoogroups.com Subject: RV7-List: elevator --> <2004nospam(at)earthlink.net> I am just finishing the left elevator and last night bent the tabs at the cutout where the trim tab fits, the bend does not look very good as I could not position the wood blocks properly due to the stiffeners, the net result is the bend is not sharp an not quite at 90 degrees to the trailing edge. Not sure what I can do apart from buying new skin and stiffeners and starting over. I thought about cutting this area out and making an end cap rib and riveting it in position. Anyone else screwed this area up and fixed it? Strikes me this would have been easier to do first before the stiffeners were installed and the sharp skin bend made but I was following the directions. Dave (irritated on last elevator waiting for wings) advertising on the Matronics Forums. ________________________________________________________________________________
Subject: RE: [VAF Mailing List] elevator
Date: Nov 24, 2004
Thanks everyone for the input (nice to know I am not alone 8>) ) I have decided to go the cap rib route for the elevator and the tab Dave _____ From: David Brand [mailto:dbrandx(at)yahoo.com] Subject: Re: [VAF Mailing List] elevator Dave, I`ve always thought a separate little rib there, as you`ve mentioned, is a good idea. I managed to finesse mine into a pretty fair rendition of "per the plans", although for me the tricky part was trimming the bent down flange so that the inner one didn`t bottom out on the skin surface. It would be nice if Van provided a max dimension here. I don`t know, maybe he does, now. Not when my plans were drawn in late `96. If you look at enough RVs at the different fly-ins, you`ll eventually come across examples of the rib method. I`ve seen a couple three over the years. In fact, I think "Franklinstein" (the RV-8 prototype) is one example. Dave Brand 80254 N254LF --- David Figgins wrote: > > I am just finishing the left elevator and last night bent the tabs at > the > cutout where the trim tab fits, the bend does not look very good as I > could > not position the wood blocks properly due to the stiffeners, the net > result > is the bend is not sharp an not quite at 90 degrees to the trailing > edge. > Not sure what I can do apart from buying new skin and stiffeners and > starting over. I thought about cutting this area out and making an end > cap > rib and riveting it in position. > Anyone else screwed this area up and fixed it? > Strikes me this would have been easier to do first before the stiffeners > were installed and the sharp skin bend made but I was following the > directions. > > Dave (irritated on last elevator waiting for wings) > > > > > [Non-text portions of this message have been removed] > > > > > __________________________________ http://my.yahoo.com Online help on this group at: http://help.yahoo.com/help/groups/ ADVERTISEMENT <http://us.ard.yahoo.com/SIG=129aalkfn/M=298184.5639630.6699735.3001176/D=gr oups/S=1705340085:HM/EXP=1101382898/A=2434970/R=0/SIG=11edksnhv/*http://www. netflix.com/Default?mqso=60185402> click here <http://us.adserver.yahoo.com/l?M=298184.5639630.6699735.3001176/D=groups/S:HM/A=2434970/rand=227950474> _____ * To visit your group on the web, go to: http://groups.yahoo.com/group/vansairforce/ * To unsubscribe from this group, send an email to: vansairforce-unsubscribe(at)yahoogroups.com <http://docs.yahoo.com/info/terms/> . ________________________________________________________________________________
Date: Nov 25, 2004
Subject: Removing protective plastic
I think I read a few weeks back that someone was having trouble removing the plastic that comes on the aluminum skins. Take your electric heatgun and heat it just a little and it ususlly comes right off. Switch to Netscape Internet Service. As low as $9.95 a month -- Sign up today at http://isp.netscape.com/register Netscape. Just the Net You Need. New! Netscape Toolbar for Internet Explorer Search from anywhere on the Web and block those annoying pop-ups. Download now at http://channels.netscape.com/ns/search/install.jsp ________________________________________________________________________________
Date: Nov 27, 2004
Subject: Lister Comments - Please Support The Lists
Dear Listers, Wow! People have been including some very nice comments along with their Contributions lately! I've included another set of below and will send another set in a couple of days. Guys, I really appreciate your kind words and support. In the last few days, the contributions have really started to come in and its looking like support this year may slightly surpass last year's. There's still a few days left in this year's Fund Raiser, so if you've been waiting until the last minute to make your Contribution, now's the time! Make Your Contribution Today: http://www.matronics.com/contribution Thank you! Matt Dralle Email List Administrator ----------------- More of What Listers Are Saying... -------------------- Every morning 5:30 am, coffee and the "List". It's how I start my day. Robert G. The list is still my favorite aviation magazine. Roger H. Great resource, without the distraction of pop ups and ads! Douglas D. I look forward to my daily list reading almost as much as my coffee! Hal K. Great service! Aaron G. I have made some great friends, because of it! Bob D. Great resource!! Richard S. I learn something of value every time I read the messages. Stan S. Great list! Thomas E. Now that I am close to completion of my [homebuilt], I look back and wonder how I could ever have made it this far without [the Lists]. Jeff O. Outstanding site and administration. Anthony S. Great forum for our projects. Darrel M. I have become a List Addict! George M. A very helpful resource for me. Dennis K. Great for staying up on the latest. Forrest L. Valuable benefit for the users. George A. Great tool for all [builders]. Tony M. Can't tell you how much I appreciate the archives. Ken B. I really enjoy the sharing of information and the "discussions" that come up. Ross S. [The List] reminds us home builders that help is just a few clicks away. Danny W. A great resource! Christopher S. Always a pleasure to support this list! Richard W. Thanks for helping all of us build better aircraft. John P. Great list(s)for data, info and making friends. John S. [The] List has helped me much with my building process. Raimo T. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Mounting the aileron
Date: Nov 27, 2004
Folks: I'm just about finished with the wings and am just tidying up before slapping on the bottom skins. This afternoon, I figured I'd grease up the bellcrank bolt and finish that whole scene. The ailerons and flaps lined up very nicely. I did have to use the Dremel tool to enlarge the hole in the rear spar (mostly topside) to keep the pushrod to the aileron from catching any of the rear spar. Now, the one thing I did notice after completing that is that at some point in the down travel (aileron down), that pushrod hits the outboard edge of that hole in the rear spar....and that hole is right up flush with the aileron bracket. I'm just wondering if that's normal and is actually beyond the down limit of the aileron (I figure there ARE aileron stops to be installed somewhere but it doesn't seem to be on the wing plans that I can see) or whether this is indicative of a problem. Regards, Bob St. Paul, Minn. ________________________________________________________________________________
Subject: Re: Mounting the aileron
Date: Nov 27, 2004
Up travel on the other aileron is gonna limit down travel on that aileron. But if, once all the controls are connected (in other words don't bother now), you still have a clearance issue, just dremel the hole out. Or dremel it out now that access is easy. My point is that until it's all rigged you may not know what you need range-wise. Or just use the specs Van's spells out in the book. If you can hit the spec before the pushrod rubs the hole, you'll most likely be fine (double check once it's all installed together). )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Bob Collins" <bcollins(at)visi.com> Subject: RV7-List: Mounting the aileron > > Folks: > I'm just about finished with the wings and am just tidying up before > slapping on the bottom skins. This afternoon, I figured I'd grease up the > bellcrank bolt and finish that whole scene. The ailerons and flaps lined up > very nicely. I did have to use the Dremel tool to enlarge the hole in the > rear spar (mostly topside) to keep the pushrod to the aileron from catching > any of the rear spar. Now, the one thing I did notice after completing that > is that at some point in the down travel (aileron down), that pushrod hits > the outboard edge of that hole in the rear spar....and that hole is right up > flush with the aileron bracket. > > I'm just wondering if that's normal and is actually beyond the down limit > of the aileron (I figure there ARE aileron stops to be installed somewhere > but it doesn't seem to be on the wing plans that I can see) or whether this > is indicative of a problem. > > Regards, > > Bob > St. Paul, Minn. > > ________________________________________________________________________________
Date: Nov 27, 2004
Subject: Edge Distance Problem
Hi folks, Working on the HS I just finished drilling the HS-405 thru theHS-702 and then 714 and 710 reiforcement bars. That came out fine. When drilling the HS-405 thru the 702 and the HS-404, one of the holes came out too close to the edge of the 404 flange. Remeber the one that had to be cut to fit between the reinforcement bars? I got about one rivet diameter from the edge, if that. What do you suggest? Should I move toward the center 3 rivet diameters from the offending hole and put in another hole. If so, should I fill the bad hole with a rivet too? Or should I order another 404. Thanks for your help. Its a real Bummer Andy Bell RV7A ________________________________________________________________________________
Subject: Re: Edge Distance Problem
Date: Nov 28, 2004
Andy Does it look like this? http://www.kane-king.com/rv7aproject/images/2F04-9-21(21-35).jpg If it does, just go ahead and put a rivet in it. There are so many rivets in this area holding the whole thing together, it's not going to matter. When I did this I agonized over it for a long time. My tech counsellor came over and looked at it and said it was fine. Bill King www.kane-king.com ----- Original Message ----- From: <Bellwa77(at)AOL.com> Subject: RV7-List: Edge Distance Problem > > Hi folks, > Working on the HS > I just finished drilling the HS-405 thru theHS-702 and then 714 and 710 > reiforcement bars. That came out fine. When drilling the HS-405 thru the > 702 and > the HS-404, one of the holes came out too close to the edge of the 404 > flange. > Remeber the one that had to be cut to fit between the reinforcement bars? > I > got about one rivet diameter from the edge, if that. What do you suggest? > Should > I move toward the center 3 rivet diameters from the offending hole and put > in > another hole. If so, should I fill the bad hole with a rivet too? Or > should I > order another 404. Thanks for your help. Its a real Bummer > > Andy Bell > RV7A > > > ________________________________________________________________________________
Date: Nov 28, 2004
In a message dated 11/27/04 11:42:15 PM US Eastern Standard Time, Bellwa77(at)AOL.com writes: > Should > I move toward the center 3 rivet diameters from the offending hole and put > in > another hole. If so, should I fill the bad hole with a rivet too? Or should > I > order another 404. Thanks for your help. Its a real Bummer > > Andy Bell > RV7A > Andy, That seems like a perfectly reasonable thing to do. Put a rivet in the bad hole too. Put the factory head in the side with the edge problem. Don't overdo it when setting that one. Quit poutin' and git back to work! Dan Hopper RV-7A (Flying since July) ________________________________________________________________________________
Date: Nov 28, 2004
Thanks folks for relieving me of that stress. Dan, I wanted to send a picture to the list but didn't know how. I don't have a website yet. But mine looks alot like Bill's. I will do as you all suggest. When your wheels first leave the ground does your mind flash back to all the little things that weren't quite right?? Thansk again Andy Bell RV7A ________________________________________________________________________________
Date: Nov 28, 2004
> When your wheels first leave > the ground does your mind flash back to all the little things that weren't quite > right?? Trust me, rivets in the HS were the LAST thing on my mind. All I cared about was that the fan kept spinning. Engine, electrical, instrumentation, and most importantly FEEL (rigging, control responsiveness, etc.) were the things I was thinking about on the first several flights. The only time I even bothered to think about rivets was when I was doing G envelope expansion. Creak...squeak...groan...just kidding. Unlike other non-RV planes I've flown, this thing doesn't make a friggin' sound when you load it. Only the pilot groans over 4G. ;-) )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Nov 28, 2004
Bob, Don't forget your ailerons may/may not require stops for aileron travel. The ailerons don't travel as much as the hinges may allow if the stops are not in place. You shouldn't have any interference problems once your travel is measured. Hope this helps, Jack Lockamy Camarillo, CA -7A FWF ________________________________________________________________________________
Subject: tinted canopy or not?
Date: Nov 28, 2004
When I opened my finish kit I realized that I had forgotten to make a decision on the tint. Van's did it for me and sent it tinted grey. I was (still am) contemplating ordeing the canopy with no tint. I fly with a friend in a Q2 with no tint in his bubble and I really like the to see all the colors in full especially the varying shades of grey in the clouds. I think the greyness of the clouds helps to judge the weather associated with them. Should I re-order or keep what I got? I'd like to hear from those who are flying with and without grey tint. Bevan RV7A fuse ________________________________________________________________________________
Date: Nov 29, 2004
Bevan, I consulted Jon Johanson on the subject of tint before placing my order, particularly because I want to fly at night. He came back very clearly in favour of the tint. Thats a lot of experience talking there. These little planes fly high and fly far. Up at 10,000 there is not much pollution to filter the sun, and if you fly out of the cloudy/smoggy areas into one of the sunnier regions you will suffer under an unfiltered sun. You get to appreciate it in sunny snowy conditions too. According to Jon, the tint is no significant impediment to night flight and helps filter the frizzling summer sun. Regards, David Francis, just beginning to frizzle under the first hot spell of the Australian summer. -----Original Message----- From: B Tomm [mailto:fvalarm(at)rapidnet.net] Subject: RV7-List: tinted canopy or not? When I opened my finish kit I realized that I had forgotten to make a decision on the tint. Van's did it for me and sent it tinted grey. I was (still am) contemplating ordeing the canopy with no tint. I fly with a friend in a Q2 with no tint in his bubble and I really like the to see all the colors in full especially the varying shades of grey in the clouds. I think the greyness of the clouds helps to judge the weather associated with them. Should I re-order or keep what I got? I'd like to hear from those who are flying with and without grey tint. Bevan RV7A fuse ________________________________________________________________________________
Subject: ProSeal curing?
Date: Nov 29, 2004
Fellow builders, I am sealing up my fuel tanks and wanted some information about curing time and temperature. When I began sealing (multiple day event) a cold front came in and the temperature dropped in the 50's during the day (shop temp around 60). Shop temp dropped during the night to low 50's I think. The next day it was a little warmer heated the shop a little (small electric heater) shop temp around 65. Nighttime temp mid 50's. Next day warmer still, nighttime temps mid 50's. Then rather cold again with nighttime temps below freezing, shop time overnight high 40's I think. During the sealing process (using cartridges) I would dispense about half the cartridge and refrigerate the remainder. About 2 to 3 hours later I would use the remainder stored in the refrigerator. As I mentioned I had several sealing sessions and am finding that the ProSeal is curing at different rates. Some are rather slow, some are faster. What have others experienced when it came to temperature and time? How long does it take to cure when experiencing the temperature swings like I have. I now am running the heater all night to keep the shop warmer. Paul ________________________________________________________________________________
Subject: Re-application of Proseal over Proseal
Date: Nov 29, 2004
Fellow builders, I am in the process of sealing my tanks and am ready to install the rear baffle. The inboard and outboard ribs when install/sealed a few days ago. After examining some of the filleting on the inside of the inboard and outboard ribs, I may want to add some additional sealant to increase the fillet in a few locations. What preparation other then cleaning with MEK/Acetone is recommended? Even though I worked in a open/ventilated shop, I inhaled way to many MEK and ProSeal fumes during the sealing process over the last week. Know wonder my Thanksgiving dinner tasted like ProSeal. Paul ________________________________________________________________________________
Date: Nov 29, 2004
Paul, I had about the same temp swings as you only mine always were in the 55 to 85 range. It took about four days for the entire batch to fully cure. I also put the cartridge in the refrigerator between uses and that allowed me to get about 2 hours use out of them. Hope this helps. Don -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Merems rv7-list(at)matronics.com; RV-9A(at)yahoogroups.com; rv9-list(at)matronics.com Subject: RV7-List: ProSeal curing? Fellow builders, I am sealing up my fuel tanks and wanted some information about curing time and temperature. When I began sealing (multiple day event) a cold front came in and the temperature dropped in the 50's during the day (shop temp around 60). Shop temp dropped during the night to low 50's I think. The next day it was a little warmer heated the shop a little (small electric heater) shop temp around 65. Nighttime temp mid 50's. Next day warmer still, nighttime temps mid 50's. Then rather cold again with nighttime temps below freezing, shop time overnight high 40's I think. During the sealing process (using cartridges) I would dispense about half the cartridge and refrigerate the remainder. About 2 to 3 hours later I would use the remainder stored in the refrigerator. As I mentioned I had several sealing sessions and am finding that the ProSeal is curing at different rates. Some are rather slow, some are faster. What have others experienced when it came to temperature and time? How long does it take to cure when experiencing the temperature swings like I have. I now am running the heater all night to keep the shop warmer. Paul ________________________________________________________________________________
Subject: Primer debate (wars)
Date: Nov 30, 2004
Yes I checked the archives and read a bunch of interesting opinions on what kind of primer to use. All of the opinions (I read) had a similar opinion though and went something like "OF course one HAS to prime the unprotected 6061T6 'cus it has no alclad on it."...Oh really? As reformed Zenair Zodiac builder (my 7 QB is on the boat) I must say I'm not so sure about the assumption that non alclad alu will dissappear before my very eyes...Reason being is that zenairs are made ENITERLY of 6061T6 with no alclad whatsover. In fact it is rare to find such an aircraft with completly primed inner surfaces because the factory recommend only zinc cromating the mating surfaces between the 6061 parts. Clearly this is because the movement between the parts might remove the protective corrosion layer. 5 years ago I finished my Zod and have not seen as much as a hint of corrosion on my annuals. The prototype has been flying snce 1974 and apparently is in similar shape. So what do you all think about that? Having said that, as EVERYONE else primes everything (except the alclad) I will do the same, besides there is not that much left on a QB so the 8 cans of NAPA 7220 SEP will hopefully be adequate. Cheers and see you all when I have the innevitable problems...:) Frank ________________________________________________________________________________ DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; b=oS3AVsMw/XWs3A4uYLJBXiGnfo+RDkA9V2nbKCUcqDxvp0nzIcFEDhbDS2xKjibhOf/+3jtx4Y/uCR+H4kasrjbOWEiBf0HIGyiuse8Qe0j1BkunnVeDySWxNRl6/8nnQ1Q5Gdture6Zxs0SCv/KkQaeqz2tT2x51pFEcQw87IE;
Date: Nov 30, 2004
Subject: Re: ProSeal curing?
I built my first tank in the dead of winter -- more or less -- in the unheated garage. I worked in temperatures of about 10 to anywhere near 30 or 40. The tank sealant was stiff right from the start. But I had no problems in curing. It cured...well... when it cured...sometimes it took 5 days. Then this summer I started building the tank in August and it was 70 and 80 degrees. I was amazed how much easier the sealant was to mix and apply. And of course it cured fast. Then I ended up finishing the 2nd tank last week...back in the 30s. All in all...no big deal. If you want it to cure faster....take a worklight, stick it in the access hole or drape it over a rib and into a bay and then put some plastic over it (I just grab some paint drop cloths from Home Depot. That'll keep the innards of the tank nice and warm without costing you and arm and a leg to heat the garage all night. I use one of the little Mr. Heaters when I'm working on the plane in the winter (like I did this morning). Hey, after a half hour, your body adjusts to the cooler temperatures although picking up a cold steel bucking bar and rivet gun in those conditions quickly teaches you to bring them inside at night. I do the bottom skins of the wing by myself (leave the wing in the jig, if you've got long arms, it's not that big of a deal. But you can't wear any jacket when doing it because you'll never get your hand inside the wing to buck. Bottom line? Don't fret about it. Bob St. Paul --- Merems wrote: > I am sealing up my fuel tanks and wanted some > information about curing time and temperature. __________________________________ http://my.yahoo.com ________________________________________________________________________________ DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; b=GwH3g8549SqASDGZTzxo2i079FTCXxEErOM+cNy1IORbkYf9UWs4CaVQUWJIl8Z7s1NYKGlQ20qMlHa8gTXf2ck7ovDHfz+AU2DZNKHWJD6QHJ0TAu1clsxtIR+anuz8G7KvpIVl6Hyy4BKM8HVG2rUD8O7dVVVLe5HvdBaEx10;
Date: Nov 30, 2004
Subject: Re: Re-application of Proseal over Proseal
--- Merems wrote: > > I am in the process of sealing my tanks and am ready > to install the rear baffle. The inboard and > outboard ribs when install/sealed a few days ago. > After examining some of the filleting on the inside > of the inboard and outboard ribs, I may want to add > some additional sealant to increase the fillet in a > few locations. What preparation other then cleaning > with MEK/Acetone is recommended? That's about all I did. BEfore putting the baffle on I checked some of the fillets for signs of any pinholes etc and just dabbed a little more ProSeal in there. No extra work was required. By the way, I know you work in a ventilated shop, but wear a respirator when you work with MEK. That stuff will destroy your neurological system. __________________________________ ________________________________________________________________________________
Date: Dec 01, 2004
Frank, Well not EVERYONE primes. Look inside my RV7 and you will see a lovely gold interior. Your RV7QB comes with a fetching silver interior. Alodine. No overspray, no cleanup, no spray gun, no weight gain, just a chemically inert conversion coating. So the primer war is like most wars, unnecessary. Glad to see you dont like nosewheels. Regards, David Francis, Canberra, Australia. -----Original Message----- From: Hinde, Frank George (Corvallis) [mailto:frank.hinde(at)hp.com] Subject: RV7-List: Primer debate (wars) Yes I checked the archives and read a bunch of interesting opinions on what kind of primer to use. All of the opinions (I read) had a similar opinion though and went something like "OF course one HAS to prime the unprotected 6061T6 'cus it has no alclad on it."...Oh really? As reformed Zenair Zodiac builder (my 7 QB is on the boat) I must say I'm not so sure about the assumption that non alclad alu will dissappear before my very eyes...Reason being is that zenairs are made ENITERLY of 6061T6 with no alclad whatsover. In fact it is rare to find such an aircraft with completly primed inner surfaces because the factory recommend only zinc cromating the mating surfaces between the 6061 parts. Clearly this is because the movement between the parts might remove the protective corrosion layer. 5 years ago I finished my Zod and have not seen as much as a hint of corrosion on my annuals. The prototype has been flying snce 1974 and apparently is in similar shape. So what do you all think about that? Having said that, as EVERYONE else primes everything (except the alclad) I will do the same, besides there is not that much left on a QB so the 8 cans of NAPA 7220 SEP will hopefully be adequate. Cheers and see you all when I have the innevitable problems...:) Frank ________________________________________________________________________________
Date: Nov 30, 2004
Subject: Re: Primer debate (wars)
Hinde, Frank George (Corvallis) wrote: > >Yes I checked the archives and read a bunch of interesting opinions on >what kind of primer to use. All of the opinions (I read) had a similar >opinion though and went something like "OF course one HAS to prime the >unprotected 6061T6 'cus it has no alclad on it."...Oh really? > >As reformed Zenair Zodiac builder (my 7 QB is on the boat) I must say >I'm not so sure about the assumption that non alclad alu will dissappear >before my very eyes...Reason being is that zenairs are made ENITERLY of >6061T6 with no alclad whatsover. In fact it is rare to find such an >aircraft with completly primed inner surfaces because the factory >recommend only zinc cromating the mating surfaces between the 6061 >parts. Clearly this is because the movement between the parts might >remove the protective corrosion layer. > >5 years ago I finished my Zod and have not seen as much as a hint of >corrosion on my annuals. The prototype has been flying snce 1974 and >apparently is in similar shape. > >So what do you all think about that? > >Having said that, as EVERYONE else primes everything (except the alclad) >I will do the same, besides there is not that much left on a QB so the 8 >cans of NAPA 7220 SEP will hopefully be adequate. > >Cheers and see you all when I have the innevitable problems...:) > >Frank > Interesting data point on the Zodiac. What do they weigh? I thought that 6061 was much weaker per pound than 2024 but not as corrosion prone (hence the alclad on 2024). It would still be more corrosion prone than the pure AL of the alclad coating on the skins, which is probably why Van's recommends priming. Charlie ________________________________________________________________________________
Date: Nov 30, 2004
Subject: removal from the list
Please remove me from the RV 7 list. Thank you ________________________________________________________________________________
Subject: steps on RV-7A
Date: Nov 30, 2004
I am to the point on my 7A fuse that I need to install my steps. The hole diameter in the fuse skin called out in the plans (I think 1 =BD inches) is perfect for the tube that goes through it. But is not big enough to clear the weld fillet at intersection of the tube and the square piece that rivets to the skin. If I make the hole large enough to clear the filament, I believe that I will end up with an exposed hole underneath the tube because the bottom of the tube is flush with the bottom of the square piece. Did anyone else have this problem? Can I sand down the weld on the bottom part of the tube? I can=92t find anyone=92s website that shows good pictures or give any explanation about how they approached this. Bryan Hooks RV-7A, slow build Knoxville, TN bryanhooks(at)comcast.net ________________________________________________________________________________
Subject: Re: steps on RV-7A
Date: Nov 30, 2004
----- Original Message ----- From: "Bryan Hooks" <bryanhooks(at)comcast.net> Subject: RV7-List: steps on RV-7A I'm at the same point on my slobuild 7-A and haven't found any plans for its installation? > > I am to the point on my 7A fuse that I need to install my steps. The > hole diameter in the fuse skin called out in the plans (I think 1 =BD > inches) is perfect for the tube that goes through it. But is not big > enough to clear the weld fillet at intersection of the tube and the > square piece that rivets to the skin. If I make the hole large enough > to clear the filament, I believe that I will end up with an exposed hole > underneath the tube because the bottom of the tube is flush with the > bottom of the square piece. Did anyone else have this problem? Can I > sand down the weld on the bottom part of the tube? > > > I can=92t find anyone=92s website that shows good pictures or give any > explanation about how they approached this. > > Bryan Hooks > RV-7A, slow build > Knoxville, TN > bryanhooks(at)comcast.net > > ________________________________________________________________________________
Date: Dec 02, 2004
The step kit includes the installation instructions. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Paul Pflimlin Subject: Re: RV7-List: steps on RV-7A ----- Original Message ----- From: "Bryan Hooks" <bryanhooks(at)comcast.net> Subject: RV7-List: steps on RV-7A I'm at the same point on my slobuild 7-A and haven't found any plans for its installation? > > I am to the point on my 7A fuse that I need to install my steps. The > hole diameter in the fuse skin called out in the plans (I think 1 =BD > inches) is perfect for the tube that goes through it. But is not big > enough to clear the weld fillet at intersection of the tube and the > square piece that rivets to the skin. If I make the hole large enough > to clear the filament, I believe that I will end up with an exposed hole > underneath the tube because the bottom of the tube is flush with the > bottom of the square piece. Did anyone else have this problem? Can I > sand down the weld on the bottom part of the tube? > > > I can=92t find anyone=92s website that shows good pictures or give any > explanation about how they approached this. > > Bryan Hooks > RV-7A, slow build > Knoxville, TN > bryanhooks(at)comcast.net > > ________________________________________________________________________________
Date: Dec 02, 2004
I had a gap beneath the tubes where they exit the fuselage. I reduced the size of the gaps from the inside with some thin scrap aluminum sheet as best I could. Then I pushed some pro seal into any remaining openings and smoothed it off with a little MEK on the tip of my chemical-glove index finger....now smooth as silk and no air holes. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Bryan Hooks Subject: RV7-List: steps on RV-7A I am to the point on my 7A fuse that I need to install my steps. The hole diameter in the fuse skin called out in the plans (I think 1 =BD inches) is perfect for the tube that goes through it. But is not big enough to clear the weld fillet at intersection of the tube and the square piece that rivets to the skin. If I make the hole large enough to clear the filament, I believe that I will end up with an exposed hole underneath the tube because the bottom of the tube is flush with the bottom of the square piece. Did anyone else have this problem? Can I sand down the weld on the bottom part of the tube? I can=92t find anyone=92s website that shows good pictures or give any explanation about how they approached this. Bryan Hooks RV-7A, slow build Knoxville, TN bryanhooks(at)comcast.net ________________________________________________________________________________
Date: Dec 02, 2004
Thanks to all. I'm going to tear into it this weekend. Sounds like just one more of those things that ya' just gotta make work. I do like the idea of putting a shim on the backside of the skin. I'll give that a shot. -bryan -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Imken Subject: RE: RV7-List: steps on RV-7A I had a gap beneath the tubes where they exit the fuselage. I reduced the size of the gaps from the inside with some thin scrap aluminum sheet as best I could. Then I pushed some pro seal into any remaining openings and smoothed it off with a little MEK on the tip of my chemical-glove index finger....now smooth as silk and no air holes. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Bryan Hooks Subject: RV7-List: steps on RV-7A I am to the point on my 7A fuse that I need to install my steps. The hole diameter in the fuse skin called out in the plans (I think 1 =BD inches) is perfect for the tube that goes through it. But is not big enough to clear the weld fillet at intersection of the tube and the square piece that rivets to the skin. If I make the hole large enough to clear the filament, I believe that I will end up with an exposed hole underneath the tube because the bottom of the tube is flush with the bottom of the square piece. Did anyone else have this problem? Can I sand down the weld on the bottom part of the tube? I can=92t find anyone=92s website that shows good pictures or give any explanation about how they approached this. Bryan Hooks RV-7A, slow build Knoxville, TN bryanhooks(at)comcast.net ________________________________________________________________________________
Subject: Riveting Question
Date: Dec 06, 2004
Ok so I have the skins, ribs, and spars of the HS dimpled, primed, etc. and I have a question. If you are using the same dimple die for dimpling the skins and spars/ribs, how does one account for the thickness of the skin? There are spots where the skins appear to have a very slight gap between the rib/spar to which they attach on spot I noticed this was on the outboard end of the rear spar to the skin. I thought about this while I was countersinking my 710/714 but really did not revisit it until now. If you are dimpling the skin to account for a flush AN426 on the skin and this same dimple die is used on your ribs/spars, would there not be a clearance issue with the ribs/spars. The rivets on the skins sit perfectly flush but I am wondering if this is normal or if I did something wrong. Thank You, Scott RV-7A Empennage ________________________________________________________________________________
Date: Dec 06, 2004
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
I just finished my VS and it came out OK...I did have the same concern but I did not notice and gaps when I rivited it all together. Frank -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Scott R. Shook Subject: RV7-List: Riveting Question Ok so I have the skins, ribs, and spars of the HS dimpled, primed, etc. and I have a question. If you are using the same dimple die for dimpling the skins and spars/ribs, how does one account for the thickness of the skin? There are spots where the skins appear to have a very slight gap between the rib/spar to which they attach on spot I noticed this was on the outboard end of the rear spar to the skin. I thought about this while I was countersinking my 710/714 but really did not revisit it until now. If you are dimpling the skin to account for a flush AN426 on the skin and this same dimple die is used on your ribs/spars, would there not be a clearance issue with the ribs/spars. The rivets on the skins sit perfectly flush but I am wondering if this is normal or if I did something wrong. Thank You, Scott RV-7A Empennage ________________________________________________________________________________
Subject: Another riveting question
Date: Dec 06, 2004
Ok so I built my VS this W/E and I have never driven a solid rivet before. They all came out OK except that the flush rivet set marks the skins when driving the 426's. Nothing a rub with a scotchbite pad won't take out so presumably no big deal? I was doing the riveting and bucking by myself which is a little trickier because the 2x gun tends to slide around but as the rivets are flush I can't see how you can aviod marking the skins? Am I doing something wrong or is this just a fact of life? Thanks Frank ________________________________________________________________________________
Subject: Re: Riveting Question
Date: Dec 06, 2004
> If you are using the same dimple die for dimpling the skins and > spars/ribs, how does one account for the thickness of the skin? Use a bigger hammer. ;-) Are you sure you're getting fully-formed dimples? In theory, the end result after dimpling should be symmetrical on the top and bottom surface of the skin. If the dies fit together, then skin dimples should fit into each other. Also, quality of dimple dies may play into the equation. I learned late in the project that not all dimple dies are created equal. Some of the best dimple dies, which form the cleanest, most properly deep dimples I've seen are the ones my hangar-mate Linas has: http://images.rvproject.com/images/2004/20041023_dimple_dies.jpg I'll be getting (or stealing) a set of these before my next project begins. Your mileage may vary -- at some rare times you may have to "touch up" dimples using a countersink tool. Try to avoid that if possible, but whatever works for you! )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Dec 06, 2004
Just put a piece of masking tape over the part of the gun that contacts the rivet and it will slide less and will mark the skin less. Other than that the marks are pretty normal and will come out during the prep for painting. Franz -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Hinde, Frank George (Corvallis) Subject: RE: RV7-List: Another riveting question Ok so I built my VS this W/E and I have never driven a solid rivet before. They all came out OK except that the flush rivet set marks the skins when driving the 426's. Nothing a rub with a scotchbite pad won't take out so presumably no big deal? I was doing the riveting and bucking by myself which is a little trickier because the 2x gun tends to slide around but as the rivets are flush I can't see how you can aviod marking the skins? Am I doing something wrong or is this just a fact of life? Thanks Frank -- Checked by AVG Anti-Virus. -- Checked by AVG Anti-Virus. ________________________________________________________________________________
From: George Neal E Capt AU/PC <Neal.George(at)maxwell.af.mil>
Date: Dec 06, 2004
Frank - You may be hitting too hard. Try turning the air pressure down. With my Taylor 2X gun I never use more than 30-psi on -3 rivets. Use a *regulator* to control the pressure. The cute little swivel-valve contraption that came with my Cleveland kit makes a fair swivel and a horrible regulator. Use the heaviest bucking bar that you can to reduce the number of hits required. Neal RV-7 N8ZG (tanks closed!) RV-8 N998GM (HS dimpled) > except that the flush rivet set marks the skins when driving the 426's. Frank < ________________________________________________________________________________
Subject: Fuselage Parts
Date: Dec 06, 2004
Listers - I'm pondering the fuselage order (RV-7 Slider), and would appreciate some guidance. I plan to delete the chains (Rocket Steering Link) and boiler valve (Andair) and add the firewall recess. What other substitutions or changes would you make if you had it to do over? Neal ________________________________________________________________________________
Date: Dec 06, 2004
Scott, Some builders use "Tank Skin Dimple Dies" from Cleaveland Tool. See www.cleavelandtool.com The item number is DIE4263T When used on the ribs/spars, they provide a slightly deeper dimple for the dimpled skin to set into. Notice they are only used on the underlying ribs or spars. A standard 3/32" dimple die is used to dimple the skin. I've been pleased with the results on my RV-7 empennage. Don Hull -----Original Message----- From: Scott R. Shook [mailto:sshook(at)cox.net] Subject: RV7-List: Riveting Question Ok so I have the skins, ribs, and spars of the HS dimpled, primed, etc. and I have a question. If you are using the same dimple die for dimpling the skins and spars/ribs, how does one account for the thickness of the skin? There are spots where the skins appear to have a very slight gap between the rib/spar to which they attach on spot I noticed this was on the outboard end of the rear spar to the skin. I thought about this while I was countersinking my 710/714 but really did not revisit it until now. If you are dimpling the skin to account for a flush AN426 on the skin and this same dimple die is used on your ribs/spars, would there not be a clearance issue with the ribs/spars. The rivets on the skins sit perfectly flush but I am wondering if this is normal or if I did something wrong. Thank You, Scott RV-7A Empennage advertising on the Matronics Forums. ________________________________________________________________________________
Date: Dec 06, 2004
You may have problems getting the rocket steering link. Repeated requests for information and how to order have not been answered. Don -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of George Neal E Capt AU/PC Subject: RV7-List: Fuselage Parts Listers - I'm pondering the fuselage order (RV-7 Slider), and would appreciate some guidance. I plan to delete the chains (Rocket Steering Link) and boiler valve (Andair) and add the firewall recess. What other substitutions or changes would you make if you had it to do over? Neal ________________________________________________________________________________
Date: Dec 06, 2004
On 12/06 11:01, Dan Checkoway wrote: > > > If you are using the same dimple die for dimpling the skins and > > spars/ribs, how does one account for the thickness of the skin? > > Use a bigger hammer. ;-) > > Are you sure you're getting fully-formed dimples? In theory, the end result > after dimpling should be symmetrical on the top and bottom surface of the > skin. If the dies fit together, then skin dimples should fit into each > other. > > Also, quality of dimple dies may play into the equation. I learned late in > the project that not all dimple dies are created equal. Some of the best > dimple dies, which form the cleanest, most properly deep dimples I've seen > are the ones my hangar-mate Linas has: > http://images.rvproject.com/images/2004/20041023_dimple_dies.jpg I'll be > getting (or stealing) a set of these before my next project begins. I concur. These dies are fantastic. Plus PART sells a great pneumatic squeezer for a very good price. And the dimple dies come with the squeezer, or at least they did when I bought them. -- Walter Tondu http://www.rv7-a.com ________________________________________________________________________________
Date: Dec 06, 2004
The marks won't hurt anything as long as they're not actual dents in the skin - you're probably going to paint your plane anyway, right? Even if you don't the surface marks will polish out. One tip: the mushroom-style sets (slightly concave surface) are a lot more forgiving of slight misalignments than the flat set with a "square shoulder". Found this out the hard way (nothing a little Bondo won't fix!) : { -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Hinde, Frank George (Corvallis) Subject: RE: RV7-List: Another riveting question Ok so I built my VS this W/E and I have never driven a solid rivet before. They all came out OK except that the flush rivet set marks the skins when driving the 426's. Nothing a rub with a scotchbite pad won't take out so presumably no big deal? I was doing the riveting and bucking by myself which is a little trickier because the 2x gun tends to slide around but as the rivets are flush I can't see how you can aviod marking the skins? Am I doing something wrong or is this just a fact of life? Thanks Frank ________________________________________________________________________________ DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; b=IyRzjyt+bVaVaV3Bf2N472rrmn5ZsejI/TfXeWoXDzANCUCVQzstRy/k6wbdrwG8tLghN4knJCPuyhKNeLYEVGcl/F3jgZIrrhSog78FBPUiu4lXTYwkSNdUGLqdyhN3gAYHfUqRKJ30VgEz9S/YTxUXAq+XcGNEOUpIrfQD5WE;
Date: Dec 06, 2004
Subject: RE: MEK
Hi to all Don't you just love the smell of MEK and Proseal in the morning. Kind of reminds of Robert Duvall in Apocalyse Now when he said, " don't you just love the smell of napalm in the morining"..... Had my baptism to the gouuuuuuuuuuuuie stuff this AM. Got all the tools, towels, Mek, Rubber gloves covered with through away surgical gloves, paint respiriator.............and went to it. Mixed a cartridge of Proseal: very thick, hard to mix, and really hard to expel from the cartridge. Used a popcicle stick to glob the stuff on the aft stiffener of the rudder. Smoothed out.....got some on the gloves...get new gloves...........the old gloves now stuck to my shoes...........new gloves now stuck to the rubber gloves ...................get new rubber gloves covered again with new surgical gloves...................paper towel moved and now the stuff is on the work table..................back to the stiffener after clean up of table. Put stiffener in the aft rudder ...tight fit..........change surgical gloves.......slowly open aft edge of rudder and push siffener in.....................cleco Aluminum angle to aft edge of rudder. Boy that baby is as straight as an arrow..........................................DONE.....Crap I still have to clean up.................again don';t you just love the smell of Proseal in the morning. Now the ?????????How long will the excess proseal keep that is in the cartridge Thanks for you listening ear and help Frank @SGU and SLC Ready to start the wing this week!!!!!!!!!!!!! --------------------------------- ________________________________________________________________________________ DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; b=s9VAwKz44e4JYjYpNFptXj4nSf2cXHqo1bdLcdxFxJuVbnWs7CH1LHUKQWO5sBGEHsxTaCbTpw1Eep1jFi+UI6M9wJ41VvvBPe8Fyb4Xtkq6ZGJX7uhrtOXaNRsNcUtexm21CR4rEx4FR4u00dvQPkUQ8hQu8NYTaWzGeSOjfkg;
Date: Dec 06, 2004
Expanding on this a bit more, I've done almost all of my riveting solo, and that includes the bottom skins on both wings without any help. I finished the right wing this weekend and I'm amazed at how nice they came out. First, on the subject of marks, don't worry about it. When you first pull off the blue plastic, it's so nice and pretty and shiney you just want it to be that way forever. Then a fingerprint here, a fingerprint there and all of a sudden they're not shiny anymore. Bummer. But unless we're talking dings, it doesn't matter. It's true you can put some masking tape on the rivet set and that helps. But you really have to monitor the condition of that tape because as it wears away (and it'll wear away relatively quickly), it's possible that as you drive a rivet and the gun slides a little bit, a little sliver of that adhesive will get under the rivet. And you'll have a crappy rivet. I use the swivel head set with the rubber guard (the one that Cleaveland use to put in their catalog with the notation, "recommended by others, but not by us." I never understood why because I think it's great. Your riveting will improve over time but there are some principles available to you know which become clear only through experience and, more important, bucking by yourself in tight spots. The most important thing is to prevent the rivet set from sliding AND to make sure the bucking bar is flat. If you make sure the gun is centered on the flush head, and the bucking bar is flat on the shop head side, you'll be less likely to skid. How can you check this? Simple. And this works great when you're bucking blind (that is, you can't see the bucking bar). Just before you shoot. Push on the bucking bar. It'll lift the rivet set off the skin. As it does, does the set, or the gun lean one way or the other? If it does, it's not centered. So move the gun up or down slightly. The other mistake that some people make is putting too much pressure on the bucking bar when shooting... as if the harder you push, the better the shop head. It won't work that way because what you end up doing is pushing back on the gun, via the rivet, which will lift the gun off the skin ever so slightly and away you go. Just place that bucking bar on the rivet and hold enough pressure there to keep it there. It'll do all the work. Also, check the psi for the gun if it's really skidding around. It might be possible to lower the setting to something less likely to make it bounce, and get better rivets in the process. Flush rivets are fun to shoot because when you first start, yeah, they're flush....but you can almost feel the depression. Eventually, you'll run your finger over the surface, and you'll have a hard time telling where the skin ends and the rivet begins. And finally, the BEST part of the technique you can learn? Don't take the bucking bar off or the gun off the material until it's stopped. This sounds like a real "duh," but I found that counting "one thousand one, one thousand two" after you let go of the trigger teaches you a technique that eventually becomes reflexive. But, especially on universal heads, you'll be amazed at how easy is to put a smiley on these things and much of it is avoidable through just two things: everything straight and perpendicular....and don't lift anything off the surface until you're sure you've stopped. Bob St. Paul --- Franz Fux wrote: > > > Just put a piece of masking tape over the part of > the gun that contacts the > rivet and it will slide less and will mark the skin > less. Other than that > the marks are pretty normal and will come out during > the prep for painting. > Franz > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com]On > Behalf Of Hinde, Frank > George (Corvallis) > To: rv7-list(at)matronics.com > Subject: RE: RV7-List: Another riveting question > > > (Corvallis)" > > > Ok so I built my VS this W/E and I have never driven > a solid rivet > before. They all came out OK except that the flush > rivet set marks the > skins when driving the 426's. Nothing a rub with a > scotchbite pad won't > take out so presumably no big deal? > > I was doing the riveting and bucking by myself which > is a little > trickier because the 2x gun tends to slide around > but as the rivets are > flush I can't see how you can aviod marking the > skins? > > Am I doing something wrong or is this just a fact of > life? > > Thanks > ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: Re: Fuselage Parts
Date: Dec 06, 2004
When I got my fuselage kit, they did not ship the fairing that fits the wing to the fuselage. I would ask that it be sent with the fuselage kit and not the finish kit. Indiana Larry, RV7 TipUp "SunSeeker" The sincerest satisfactions in life come in doing and not dodging duty; in meeting and solving problems, in facing facts; in flying a virgin plane never flown before. - Richard L. Evans & Larry R Helming ----- Original Message ----- From: "George Neal E Capt AU/PC" <Neal.George(at)maxwell.af.mil> Subject: RV7-List: Fuselage Parts > > Listers - > > I'm pondering the fuselage order (RV-7 Slider), and would appreciate some > guidance. > > I plan to delete the chains (Rocket Steering Link) and boiler valve (Andair) > and add the firewall recess. > > What other substitutions or changes would you make if you had it to do over? > > Neal > > ________________________________________________________________________________
Date: Dec 07, 2004
Subject: Re: Another riveting question
Frank, Two things. One: using Van's riveting tape will help in several ways. Use a piece of tape only about 2 inches long. Put it across the line of rivets. This will act not only to hold the rivet in the hole, which I don't even consider to be much of a benefit, but will act as a target to center up the flush rivet tool. Where the line of rivets crosses the tape is the exact position of the rivet. It also acts to protect the skin and the flush rivet tool. It does this by keeping the tool from picking up soft aluminum from the surface of the skin and galling the skin. Now, for the next rivet just use the same piece of tape moving it about 1/8 inch as you place it over the next rivet. You can do about 10 or even 20 rivets with one 2 inch length of tape! You'll save hundreds of dollars in tape alone! Whoops, I'm getting too excited! Two: if you are more interested in getting a nice job than in getting done in a hurry, try pre-squeezing the rivets up to the size that the hole is after it is dimpled. After dimpling, the holes are about .100 inch. You can set up your squeezer and do as many rivets as you'll need for a while. I would do about 50 at a time. This helps in two ways. The skin takes less beating since the rivets fatten up before the shop head starts to form anyway, and the rivets are less likely to bend over (even a little) since they are now shorter when you start driving them. The pros on the list will probably flame away at me, but when I started doing these two things my riveting improved greatly. Yeah, maybe I'm too particular, but when I'm up at 8500 feet or pulling 4 g's in a steep turn, I'm glad I took a little extra time putting it together. Dan Hopper RV-7A N766DH (Flying since July -- about 80 hours) In a message dated 12/6/04 1:51:11 PM US Eastern Standard Time, frank.hinde(at)hp.com writes: > Ok so I built my VS this W/E and I have never driven a solid rivet > before. They all came out OK except that the flush rivet set marks the > skins when driving the 426's. Nothing a rub with a scotchbite pad won't > take out so presumably no big deal? > > I was doing the riveting and bucking by myself which is a little > trickier because the 2x gun tends to slide around but as the rivets are > flush I can't see how you can aviod marking the skins? > > Am I doing something wrong or is this just a fact of life? > > Thanks > > Frank > > ________________________________________________________________________________
From: "Brian Meyette" <brianpublic(at)starband.net>
Date: Dec 07, 2004
What's the source of these PART dimple dies you guys are referring to? brian http://brian76.mystarband.net/RV-7Ahome.htm -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Walter Tondu Subject: Re: RV7-List: Riveting Question On 12/06 11:01, Dan Checkoway wrote: > > > If you are using the same dimple die for dimpling the skins and > > spars/ribs, how does one account for the thickness of the skin? > > Use a bigger hammer. ;-) > > Are you sure you're getting fully-formed dimples? In theory, the end result > after dimpling should be symmetrical on the top and bottom surface of the > skin. If the dies fit together, then skin dimples should fit into each > other. > > Also, quality of dimple dies may play into the equation. I learned late in > the project that not all dimple dies are created equal. Some of the best > dimple dies, which form the cleanest, most properly deep dimples I've seen > are the ones my hangar-mate Linas has: > http://images.rvproject.com/images/2004/20041023_dimple_dies.jpg I'll be > getting (or stealing) a set of these before my next project begins. I concur. These dies are fantastic. Plus PART sells a great pneumatic squeezer for a very good price. And the dimple dies come with the squeezer, or at least they did when I bought them. -- Walter Tondu http://www.rv7-a.com --- ---
October 02, 2004 - December 07, 2004
RV7-Archive.digest.vol-ag
