RV7-Archive.digest.vol-ah
December 07, 2004 - June 15, 2005
Subject: | Re: Riveting Question |
On 12/07 11:54, Brian Meyette wrote:
> What's the source of these PART dimple dies you guys are referring to?
> brian
http://www.rivettools.com
Walter Tondu
http://www.rv7-a.com
Subject: | Re: Riveting Question (PART website) |
Brian,
I believe they are referring to the following website
http://www.rivettools.com/
Dave
> brian
> http://brian76.mystarband.net/RV-7Ahome.htm
> brian
And I was mistaken, the rivet set was not free but was discounted
when I purchased my squeezer/rivet set combo. The discount is
still available if you purchase both at the same time.
Walter Tondu
Subject: | Re: Another riveting question |
use masking tape, 1.5 inch works here.. get the better type as it is
thicker.. they make some special tape for it but mine
came out exactly like the factory (quick build) once I used the tape, also
be sure and don't set the gun too high..
Danny..
----- Original Message -----
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Subject: RE: RV7-List: Another riveting question
> Ok so I built my VS this W/E and I have never driven a solid rivet
> before. They all came out OK except that the flush rivet set marks the
> skins when driving the 426's. Nothing a rub with a scotchbite pad won't
> take out so presumably no big deal?
> I was doing the riveting and bucking by myself which is a little
> trickier because the 2x gun tends to slide around but as the rivets are
> flush I can't see how you can aviod marking the skins?
> Am I doing something wrong or is this just a fact of life?
> Thanks
> Frank
Subject: | Another riveting question |
From: | "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com> |
Thanks to all who answered...
I'm thinking I may have had the pressure wound up a bit high...I was
running 50psi for the 426's (2X gun) and yes the idea of the rivet set
bouncing would make sense...Thats why the gun moves around...DUH!...I
guess I might have been trying too hard to push back on the rivet with
the bucking bar on my fingertips. It seemed to need quite a bit of force
to form the shop head.
From the wonderful replies I got I assume I need less pressure, both
from the gun and the fingers
Frank
-----Original Message-----
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of sportpilot
Subject: Re: RV7-List: Another riveting question
also
Danny..
> won't take out so presumably no big deal?
> are flush I can't see how you can aviod marking the skins?
> Thanks
> Frank
Subject: | Fuel tank to main skin gap? |
Fellow builders,
I just placed my finished left fuel tank (RV-7A) on my wing and noticed a gap between
the aft edge of the tank skin and the forward edge of the main skins on
my wing (top and bottom gap equal). I opted to wait to match drill and dimple
the leading edge junction until after sealing the tanks. I have measured the
edge distance of the screw holes in the tank skin and compared this to the center
distance from the nutplate holes (countersinked) to the forward edge of
the main tank skins, both are 5/16". So what this means is that there is a buildup
of tolerances or ProSeal that is pushing the tank forward slightly. I would
say that the gap is approximately 0.040. However the tank to leading edge
junction (at the nose) is pretty much of a perfect match. So the screw holes
in the tank don't line up with the nutplates perfectly. I was generous with
"buttering" the ProSeal on both the "Z" bracket and tank rib aft flanges but
not over generous. I know there is a very thin layer of ProSeal that maybe contributing
to this gap, but not that much. When I built my RV-4 (old school) you
could line everything up without any gaps because you put all the hole. With
the match punched, you can't adjust things at all.
What have other experienced after mounting the tanks.
Paul (RV-4/RV-7A)
From: | Norman Younie <rv6capt(at)pacificcoast.net> |
Subject: | Re: Fuel tank to main skin gap? |
You will have to remove the excess pro-seal. There is no room for it . I
have built six sets of tanks and have learn the hard way myself.
Merems wrote:
>Fellow builders,
between the aft edge of the tank skin and the forward edge of the main skins on
center distance from the nutplate holes (countersinked) to the forward edge of
would say that the gap is approximately 0.040. However the tank to leading edge
not over generous. I know there is a very thin laye!
>r of ProSeal that maybe contributing to this gap, but not that much. When I built
my RV-4 (old school) you could line everything up without any gaps because
you put all the hole. With the match punched, you can't adjust things at all.
>Paul (RV-4/RV-7A)
DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws;
s=s1024; d=yahoo.com;
b=ZLcCMs8dZO9AWUbLE0uKUlw+p6gS9chVgG7Lvo7QVvbdUM5LmxVGb5hH/TQcraR+vKAgA5w7dtff8QSBCd6GOHcT2a+xi4Ci/OYqJSHdSGL1jNfUX5HiAI0SHWenKFs2JE9Gh29K5jEDF1tflyjfD+9qLWAWwvDoDrb3uL+B18w;
From: | Bob Collins <bcollins747_1999(at)yahoo.com> |
It may not necessarily be a build-up of ProSeal and
I'm aware of several people who actually filed their
z-brackets to compensate.
When I was building my first tank, I had the same
problem and on the archives, I read several similar
problems. Then I did a simple thing and the problem
disappeared.
I returned the jack to the wing jig, centered it on
the spar, and gave it a couple of cranks. There was a
minor pop, and all of a sudden the tank fit perfectly.
The "clue" here is the fact the nose gap is perfect
but the gap appears to increase as you go farther aft.
Since sharing this information in the spring, I've
seen several people have the same problem, and giving
the spar a little help cured it.
I can't guarantee this is your problem, but I would at
least try it before taking any other "invasive"
action. It's worked for other people.
St. Paul
--- Norman Younie wrote:
> >Fellow builders,
> my wing and noticed a gap between the aft edge of
> on my wing (top and bottom gap equal). I opted to
> wait to match drill and dimple the leading edge
> measured the edge distance of the screw holes in the
> tank skin and compared this to the center distance
> forward edge of the main tank skins, both are 5/16".
> So what this means is that there is a buildup of
> forward slightly. I would say that the gap is
> edge junction (at the nose) is pretty much of a
> perfect match. So the screw holes in the tank don't
> generous with "buttering" the ProSeal on both the
> "Z" bracket and tank rib aft flanges but not over
> generous. I know there is a very thin lay!
> e!
> because you put all the hole. With the match
> tanks.
> >Paul (RV-4/RV-7A)
b=zIy7f62NSqE9yvVXmU7pRcLWQ13b7K3CrIcxkSykYXSKEqdX2yC9NTRO+FLhuP3gh8hXxLj2C67rWYyqC95aoMl0hAgjsWiGPDiN47cQwk1ULsAVs+SBG0RArfTGxPWknerc6O6U7vrnEC6vdea0sRz6BEazy0kroAQJYL+32TI;
I also left one thing out. In working and mounting my
second tank, I came up with a process of mounting it
that helped. Initially, I just plopped it on and
looked at all the gaps that didn't fit right etc.
Then, for the heck of it, I tried a bunch of different
combinations of things to make the mounting process
more precise.
I can't say for sure this will work for you, but I can
say for sure that I've found this procedure to result
in the best fit. It's worth trying.
1)Run a bolt in the middle of the most inboard
zbracket to line things up. The gap between the
leading edge will be wide, but don't worry! It'll work
out.
2)Install bolts in the upper holes of all zbrackets
to spar connections
3) Install bolts on the bottom side of all
connections.
4) Install the middle bolt on all zbracket to spar
connections. This will pull the tank down and I find
the gap between leading edge and tank becomes perfect
(assuming you used the Checkoway method).
5)Add the screws on the skin
Try this in addition to my previous note about adding
the support to the jig and see what happens.
BC
Subject: | Fuel injection system |
I am working on the fuselage (QB) now and noticed the location for the std fuel
pump is already done on the firewall. I am thinking about going to a IO-360 and
wonder if anyone knows the recommended high presure fuel pump location. I don't
see any info on Van's web site etc. and nothing in the drawings I have.
Larry, RV-7A working
Larry,
Would you be referring to the boost pump by chance as the fuel pump is
on the engine at the lower left corner on the accessory section. You are
welcome to visit our web site a see our engine packages. Especially the
ALL NEW Lycoming IO-390X. Our address is bpa(at)bpaengines.com. Or call us.
We would be more than happy to discuss your engine needs in detail.
Sincerely,
Allen Barrett
Barrett Performance Aircraft, Inc.
2870-B N. Sheridan Rd.
Tulsa, OK 74115
[918] 835-1089 phone
[918] 835-1754 fax
www.bpaengines.com
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of LARRY RUSH
Subject: RV7-List: Fuel injection system
std fuel pump is already done on the firewall. I am thinking about going
to a IO-360 and wonder if anyone knows the recommended high presure fuel
pump location. I don't see any info on Van's web site etc. and nothing
Subject: | Speaking of Aerosport |
Speaking of aerosport,
A couple of snippets they gave me....
1) The Superior parts built engine has a much better warranty as far as
using premium autogas.
2) They can supply the flstic FF sump for $500 less than their standard
FF cast sump.
3) They are happy to retard the Max advance on the LS ignition to give a
better detonation margin for use with 92 octane...I was going to have
them set the max to 40 as opposed to the 45 deg standard.
Can't afford my engine till about June next year (to tight to borrow
money), just hoping the price doesn't sky rocket due to the poor US
exchange rate?
Frank
Hi All,
So having built a different manufacturer's plane before one brings a few
ideas that are not part of the Van's verbage...The fact that my old
Zenair zodiac (made entirely of non alclad 6061) is ONLY primed between
the mating surfaces being one of them.
So how about this...When deburring I found that if I use a sharp drill
there is very little burr on the drilled parts. Using the deburring tool
seems to have a very small improvement according to the "finger" test.
I have been experimenting and found that I can get much better (and
faster) results by rubbing with a fine scotchbite pad (or even the very
fine scotchbrite flap wheels mounted in a drill). The rason I came up
with this is that Zenair suggested beburing by rubbing a file across the
holes....A little too scratchy for me but the scotch brite pad/wheel
gives much smoother results.
Of course it does remove a bit more of the alclad so I tend to prime a
little more with my rattle can than I otherwise would.
Any thoughts on this approach good or bad?
Frank
I've found the scotchbrite to work great for deburring, especially on the
skins. (I prime them)
Cammie
Hi All,
Frank
I also find that a drill bit seems to do a better job than the deburring
tool, especially on the smaller holes. I think Van's even recommends this
method somewhere in the build manual, if I recall correctly. Drill bits are
too long to fit in some spots - I've also used a countersink bit to reach in
tight spots (by hand).
[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Hinde, Frank
George (Corvallis)
Subject: RV7-List: Deburring
Hi All,
Frank
Hi Folks
I'm a little late to this thread but I thought I'd add my two cents. I
noticed that with the flush set that I was also getting marks on the skin. They
weren't smileys, just a scuffing sort of mark. I was thinking that maybe my flush
set has some imperfections or something. I couldn't really see anything wrong
with it. I was about to order a new flush set when I tried using that rivet
tape that came with the Avery toolkit. Now I get no marks at all. So my VS and
the left side of the HS have the marks but the right side HS looks good.
Bummer. Nothing that paint prep won't take out. Its a shame I learn all these things
about halfway thru any process. Thanks for the tape idea whoever that was.
Andy
Andy's Rule of Airplane Building::Everything takes at least three times as
long as you think it will, even if you apply this rule
In a message dated 12/11/04 3:27:09 PM US Eastern Standard Time,
Bellwa77(at)AOL.com writes:
> Andy
That's why we build another airplane!
Dan Hopper
RV-7A (Flying)
I too have some scuff marks. Mine are caused by the "galling" of the alclad on
the rivet set. I have used tape on the skins, no marks. Tape on the set , no
marks. However you will have to replace the tape on the set every dozen or so
rivets. I have also used some auto rubbing compound on the rivet set remove
the galling, it works but you have to polish the set every 20-30 rivets. The
bottom line is that when you are ready to paint, you will need to prep the skins
by scotchbrighting the rivet lines anyway.
Paul (RV-4/RV-7A)
To: rv7-list(at)matronics.com
Sent: Saturday, December 11, 2004 1:26 PM
Hi Folks
things
Andy
Dan I am building a 7A and I would very much like to see yours, you know the keep
building encouragement kind of thing
>> Andy
>Dan Hopper
>RV-7A (Flying)
When using the flush riveting head try putting masking tape on the tool face.
Larry, RV-7A working (3rd RV)
Last 7A message from
Tad Sargent
>> Andy
>Dan Hopper
>RV-7A (Flying)
Subject: | RV7a Rudder edge rivetting |
Morning all,
So I glued up my rudder trailing edge on Saturday...I actually used
Vulkem 116 building caulking as I didn't have any epoxy...Given time
this stuff sets up like the stickiest stuff on the planet so we'll see
how that goes.
So to set the rivets it says to use a dimple...eh what?...do they mean a
female dimple?
Are there any tricks you guys can pass along to get the best
results....I assume you set with a squeezer?
Frank
In a message dated 12/13/04 10:24:53 AM US Eastern Standard Time,
Sargentclt(at)cs.com writes:
> the keep building encouragement kind of thing
Come to Robison (pvt) just W of Peru, IN, and see it. Or, if you're not too
far away I'll come see you. Where are you located?
Dan
Subject: | Re: RV7a Rudder edge rivetting |
Frank,
Here are a few tips --- all my opinion, of course.
You should have countersunk the wedge extrusion that goes between the skins,
and dimpled both skins.
Alternate the direction you insert the rivets from, to avoid any tendency to
curl the TE. Keep this straight by marking every other one with a Sharpie.
I used a back rivet plate and flush set in the rivet gun. Start at the
center and work both ways, although this probably doesn't matter. Just make sure
that the shop heads are not above the surface if you are going to back rivet,
so they don't interfere with the next rivet and cause a problem.
To be honest, mine isn't perfect -- I think because I didn't use any
adhesive. The adhesive is very important to keep the edge straight.
Hope this helps,
Dan Hopper
RV-7A
N766DH (Flying since July)
In a message dated 12/13/04 2:15:27 PM US Eastern Standard Time,
frank.hinde(at)hp.com writes:
> female dimple?
> Thanks
> Frank
Hope that's not corrosive to aluminum...
)_( Dan
RV-7 N714D
http://www.rvproject.com
Me too!
I know building flashing is often made of aluminium so I would doubt
it...Hate to be building a new rudder in a few years....:)
Frank
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Dan Checkoway
Subject: Re: RV7-List: RV7a Rudder edge rivetting
)_( Dan
RV-7 N714D
As said before, the aluminum wedge should already be coutersunk and the
skins already dimpled.
Now, I don't know if I would necessarily squeeze them with a squeezer
becaues you're working on two angeled surfaces, and on top of that you're
filling one of the dimples with the shop head/bucktail of the rivet. I did
mine with no adhesive at all, just a nice big back rivet plate I made out of
some 1/4" steel about 6"x12" in size. That allowed me to gently rivet every
5th rivet partially back and forth until the whole edge was done.
The key is not to completely rivet from one end to the other, that will
invite a twist, but rather to slightly rivet the edge back and forth until
they are perfect. You don't want to set the rivets completely on the first
shot either, take two or three passes to get them completely set and you
can/will keep the whole thing straight as an arrow. My rudder ended up
nearly perfect (lined up with one of those cheapo laser level thingies) and
only took a little while to do.
Just my 2 cents as usual.
Stein Bruch
RV6's, Minneapolis (one has an RV7 tail on it so this qualifies for the
above response..I think :)
George (Corvallis)
Subject: RV7-List: RV7a Rudder edge rivetting
Morning all,
how that goes.
female dimple?
Frank
13:06:56,
Serialize by Router on slcnot1/SCT(Release 6.0.4|June 01, 2004) at 12/13/2004
13:06:57,
Serialize complete at 12/13/2004 13:06:57,
Itemize by SMTP Server on sctmnot9/SCT(Release 6.0.4HF100 | September 14,
2004) at
12/13/2004 15:06:57,
Serialize by Router on sctmnot9/SCT(Release 6.0.4HF100 | September 14,
2004) at
Serialize complete at 12/13/2004 15:06:57
I actually drilled holes (not all the way through) in my back-rivet plate so
I could cleco the rudder to the plate, and also counter-sunk the plate in a
big piece of MDF. Then I could drill more holes in the MDF so that the
rudder could be held flat against a larger area. Didn't use any adhesive
and it seemed to work great!
Frank,
sure
rivet,
Hope this helps,
Dan Hopper
RV-7A
From: | George Neal E Capt AU/PC <Neal.George(at)maxwell.af.mil> |
Frank -
I believe the instructions recommend using a cupped set for AN470 rivets to
start the shop head, then switching to a flush set to finish.
If memory serves, I shimmed the rudder LE to get the TE to lay flat on my
back-riveting plate. Then used the back-rivet set to start the rivet, flush
set to finish. I started in the center, then did the ends, then moved to
the center between two of the just-set rivets, basically splitting a
progressively smaller gap. Mine came out dead straight. I used 30-min
epoxy on the AEX wedge.
I've heard that starting at one end or the middle and working straight out
will often result in a bowed TE.
Neal
RV-7 Wings
RV-8 Emp
Exactly the same way I did it, same result. I used the tank sealant, but I
think I'd use the epoxy if I had to do it again, less messy. Main thing is
to rivet a little at a time and check the TE often to make sure it's still
straight. I worried for two weeks ahead about this step, turned out to be
no big deal.
Al Herron
RV-7A QB
[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of George Neal E
Capt AU/PC
Subject: RE: RV7-List: RV7a Rudder edge rivetting
Frank -
Neal
RV-7 Wings
RV-8 Emp
Thanks for the help on the TE rivetting.
Another one is the AN470 rivets in the spars. Having squeezed a dozen
rivets I could see this was going to be a painful experience. So on the
VS spar I drilled the back plate to accept a cupped rivet set, got the
back rivet set in the gun and started pounding away.
I noticed however that the rivets have a tendancy to bend instead of
driving straight. I'm thinking that if I support the spar better I might
have better results with the HS spar because I can have two hands on the
rivet gun to stop it wandering.
I may have had the air pressure up a bit high too.
Has anyone had good or bad results with this method?...Its certainly a
whole lot easier than using a hand squeezer that's for sure (no smileys
either) and a pnuematic looks little overkill for the QB kit.
Any thoughts?
Frank
Lazyness is the Mother of all invention....:)
Subject: | Re: And another one |
> Any thoughts?
There are two gotta-haves in my book. (and I would never ever
consider building without #2)
1) items to be rivetted should be stabilized very well, even if
it means placing in a padded vise, especially when using a cupped set.
2) pneumatic squeezer. Perfect results every time, without question.
Walter Tondu
What type of epoxy would you use? There seems to be a whole bunch of
different types out there. Forgive me if this is a stupid question but what is
RTV? Is
that an Epoxy too?
Andy
In a message dated 12/13/2004 3:36:09 PM Eastern Standard Time,
Al.Herron(at)aerojet.com writes:
no big deal.
Al Herron
RV-7A QB
Capt AU/PC
Frank -
Neal
RV-7 Wings
RV-8 Emp
The plans say to use any kind of epoxy with a 30 minute working
time....my Supermend epoxy only claimed 15 mins so I went with the
building caulking instead.
RTV is not an epoxy its gasket sealant that is silicone based...Makes a
rubbery seal. Not what your looking for to glue the tail edges together.
Frank
Bellwa77(at)AOL.com
what is RTV? Is
that an Epoxy too?
Andy
but I think I'd use the epoxy if I had to do it again, less messy. Main
thing is to rivet a little at a time and check the TE often to make sure
it's still straight. I worried for two weeks ahead about this step,
turned out to be no big deal.
Al Herron
RV-7A QB
Capt AU/PC
Frank -
to start the shop head, then switching to a flush set to finish.
my back-riveting plate. Then used the back-rivet set to start the
rivet, flush set to finish. I started in the center, then did the ends,
then moved to the center between two of the just-set rivets, basically
splitting a progressively smaller gap. Mine came out dead straight. I
used 30-min epoxy on the AEX wedge.
out will often result in a bowed TE.
Neal
RV-7 Wings
RV-8 Emp
There are no stupid questions.
I'll pass along another thing about RTV because it's a safety item. Do not
get the stuff anywhere near your fuel system. In contact with avgas it will
swell up by a factor of about 10. I had a (supposedly FAA certified) A&P use
to seal the fuel tank access panels on my 172. The panel screws pushed
little #8-size pellets of the stuff into my fuel tank, where they proceeded
to grow to the approximate size and consistency of a big garden slug. I was
lucky - another mechanic spotted the problem a couple of weeks later before
they clogged my fuel lines. I was only out $400 to get the tanks flushed
instead whatever an off-field landing might have cost me. Word to the wise.
Bellwa77(at)AOL.com
is RTV? Is
that an Epoxy too?
Andy
no big deal.
Al Herron
RV-7A QB
Capt AU/PC
Frank -
Neal
RV-7 Wings
RV-8 Emp
Subject: | HS Rear Spar Question |
Ok so everything is primed and ready to go together.Following the plans, I
am ready for the rear spar.
But there is really no indication which direction the machined heads will
face (fore or aft) for the rear spar (HS 609/603). If you read section 5 in
the manual it looks like the machined head is on the thinner piece of
material. However, I am not going off of that. Is there something I am
missing??
I checked other builders sites and from what I saw of the pictures (read:
SQUINTED) I could have swore that I found it both ways.
Any help would be appreciated.
Scott
From: | "Francis, David CMDR" <David.Francis(at)defence.gov.au> |
Scott,
There is a convention that the shop head should, for preference, be against
the thinner sheet.
However Vans, somewhere in my construction manual, address the issue and
make the observation that they have no evidence whatever that rivet
orientation makes any difference to the strength of the final product.
On my plane I put the shop head against the thinner sheet, but only where
access is convenient. If access is not excellent the chance of a smiley or
bent rivet becomes high and the damage is not worth the risk. I then orient
the rivet for best access, regardless of sheet thickness.
Stop worrying and keep pounding.
Regards, David Francis, Canberra, Australia.
Subject: RV7-List: HS Rear Spar Question
missing??
Scott
Subject: | Re: HS Rear Spar Question |
against
> the thinner sheet.
Other way around (probably what you meant)...manufactured head against the
thinner stock, shop head formed against the thicker stock.
In my opinion, this only matters when you're using .020" or thinner, because
that's when you can really start to see scalloping/buckling around the shop
heads on the thinner material. In my experience the effect is exaggerated
when you attach thin (i.e. .020") stock to thicker stock with 1/8" or larger
diameter fasteners.
Exactly. Just keep the convention in mind, because sometimes it does have a
cosmetic effect.
)_( Dan
RV-7 N714D
Dan,
You are correct, I meant the manufactured head should, by convention, be
against the thinner sheet.
Its easy to reverse things when living down under, its hell hanging onto the
earth upside down you know.
David Francis, enjoying a hot summer, Canberra, Australia.
Subject: Re: UNCLASSIFIED RE: RV7-List: HS Rear Spar Question
against
> the thinner sheet.
diameter fasteners.
cosmetic effect.
)_( Dan
RV-7 N714D
_
From: | "LarryRobertHelming" <lhelming(at)sigecom.net> |
You already have some good replies and I agree that the shop head should go
on the thicker mat'l side unless there are/is a reason to do it the other
way. One other reason is because you want the DAR and others to be able to
see your shop heads after the part is closed up. They can easily see the
quality of your finished rivet.
Indiana Larry, RV7 TipUp "SunSeeker"
The sincerest satisfactions in life come in doing and not dodging duty;
in meeting and solving problems, in facing facts;
in flying a virgin plane never flown before.
- Richard L. Evans & Larry R Helming
in
> missing??
> Scott
against
> the thinner sheet.
orient
((((((((()))))))))) I realize this reply came from down under and perhaps
its in the semantics........However, with all due respect to our friends who
mostly upside down with us when standing with feet on firm ground in
Australia..........
I believe the shop head ( our shop ) should be on the thicker, not thinner
material side. The machined head ( manufacturer ) should be on the thinner
side. Less likely to cause stress cracks that way which can weaken our
structures just a bit. See my other post on this for another reason you
might want your shop heads to be on the "seen" side.
Subject: | [ Jim Jewell ] : New Email List Photo Share Available! |
From: | Email List Photo Shares <pictures(at)matronics.com> |
A new Email List Photo Share is available:
Poster: Jim Jewell
Subject: RV6-A lower cowl engine air intake seal
http://www.matronics.com/photoshare/jjewell@telus.net.12.18.2004/index.html
o Main Photo Share Index
o Submitting a Photo Share
If you wish to submit a Photo Share of your own, please include the
following information along with your email message and files:
2) Your Full Name:
3) Your Email Address:
Email the information above and your files and photos to:
Fellow RV'ers,
Is it Ok to use DC-4 compound on the fuel cap "O" ring?
If not, what do some of you use?
Thanks in advance,
John Brunke N215KC, RV-6
RV-7 tail in the basement.
EZ-Turn (a.k.a. Fuelube)
Spruce p/n 09-00306
)_( Dan
RV-7 N714D
Subject: RV7-List: Fuel cap
> Fellow RV'ers,
> Thanks in advance,
Subject: | Radio/Intercom interference with engine issue |
rv-list(at)matronics.com, aeroelectric-list(at)matronics.com
I have an interesting issue. I am flying my friends RV-7, this is the
second flight. I had the throttle basically full (breaking in the engine) and
the
radio progressively seemed to get worse (over a 515 minute period) with
static when receiving transmissions from ATC. It got so bad, I could barely hear
him. He said he had no issues hearing me. I told him I was going to come
in for a full stop, pulled back the throttle, and could hear fine once again.
So I called the controller and told him I was going to go around again and
once I gave it over about 75% power, the radio once again had a bunch of
static (only when receiving transmissions).
The plane has a PS Engineering PM1000 intercom, Garmin 430 radio, and a
Headsets Inc ANR in a Dave Clark 13.4 headset. It also has a Lightspeed
electronic ignition on the right mag. I did a mag check in the air and it did
not
seem to make a difference.
I pulled and reseated the headset plugs and that did not fix the issue.
Does anyone have any ideas what to check? We had no issues on the first
flight. Thanks in advance!
-Mike Kraus
N223RV RV-4 Flying
N213RV RV-10 Tailcone Complete, working on wings
Having had a very similar experience in a different situation; I found it to
be a loose wire causing what sounds like static. Essentially what was
happening at certain vibrations/frequencies I would hear the same static and
sometimes there was even complete loss - it actually was a loose wire
partially disconnecting/connecting very quickly.
I would suggest tracing all the way from the headset jacks to the radio
before having someone pull the radio and look at it. I think you may find
the solution to be a simple one if it is only happening at certain engine
speeds.
Just my 2 cents...
Scott
HS Complete!!!
VS being skinned!!!
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of N223RV(at)AOL.com
rv-list(at)matronics.com; aeroelectric-list(at)matronics.com
Subject: RV7-List: Radio/Intercom interference with engine issue
and the radio progressively seemed to get worse (over a 515 minute period)
with static when receiving transmissions from ATC. It got so bad, I could
barely hear him. He said he had no issues hearing me. I told him I was
going to come in for a full stop, pulled back the throttle, and could hear
fine once again.
did not seem to make a difference.
-Mike Kraus
N223RV RV-4 Flying
advertising on the Matronics Forums.
From: | Jeff Williams <Tramsootru(at)direcway.com> |
Subject: | Re: Radio/Intercom interference with engine issue |
We have been having a very similar problem with our radios.. Sounds like
we're getting out fine, 4x5 or so, but recieving, is horrible.. Plane's been
in the shop for 2 weeks.. Going out tomorrow to fly it and see if we've
gotten anywwhere..
and the
barely hear
come
again.
and
it did not
> -Mike Kraus
> N223RV RV-4 Flying
I have been thinking of enclosing the landing lights in the wing tip as
quite a few of you have. My questions are:
1. with a 75watt halogen is the light adequate?
2. It seems that at the very best the lights will parallel the chord vs
getting the light(s) to point towards the centerline. Dose this leave a dark
spot along the center line?
Ed Clegg RV 8
Subject: | EAA Tech Counselor |
So I am done with the HS and working on the VS and wanted to know if there
are any EAA tech Counselors in the Phoenix (East Valley) area with some time
on their hands to come out and have a look at my progress?
Also, is this a good time or should I wait until the control surfaces are
done?
Thoughts?
Scott & Jenni
Subject: | Re: EAA Tech Counselor |
Assuming you're an EAA member, there's a database in
the members only section of the EAA Web site for you
to find tech counselors in your area.
http://members.eaa.org/home/lookup/
I always have the tech counselor stop by whenever I've
got a pile of work for them to look at. They'll stop
by as often as you want. I would, however, go ahead
and start on the control surface. I like to leave one
major part exposed so they can see the "innards".
Bob Collins
St. Paul
Waiting for fuselage
> progress?
> done?
> Thoughts?
> Scott & Jenni
http://info.mail.yahoo.com/mail_250
Subject: | [ Kelly Patterson ] : New Email List Photo Share Available! |
Poster: Kelly Patterson
Subject: Tailcone baggage compartment
http://www.matronics.com/photoshare/kbob@cox.net.12.31.2004/index.html
2) Your Full Name:
Subject: | Re: [ Kelly Patterson ] : New Email List Photo Share Available! |
I certainly understand why some might like to see extra room for
carrying "stuff" in our RV's, but am I the only one who has great misgivings
about making room for more baggage considerably further AFT behind the CG?
As a benchmark reference, note that Van's gives us the option to drill
out lightening holes in the vertical stab in order to not just save weight,
but more importantly, to get some weight off the tail. Those holes are only
good for a few ounces at best, and they can be important ounces, but now
there seems to be a number of people willing to put more POUNDS way behind
the CG.
I'm thinking that it's only a matter of time before we hear of the first
accident caused by too much weight aft of the CG. Sure, we're all smart
enough to carefully figure our load and it's affect on the CG for a
particular flight, but what if a load unexpectedly shifted rearward? Even a
few inches could make a big difference if it happened halfway back toward
the tail. An inflight "emergency" like that might go undetected for a while,
but could bite hard on final when the tanks have burned off lot's of weight
formerly in front of the CG and a pilot slows down for landing.
Just my .02 without trying to offend anyone.
Vern
RV7-A QB
From: "Email List Photo Shares" <pictures(at)matronics.com>
Subject: RV7-List: [ Kelly Patterson ] : New Email List Photo Share
Available!
the
> 1) Email List or Lists that they are related to:
> 2) Your Full Name:
> 4) One line Subject description:
> 5) Multi-line, multi-paragraph description of topic:
> 6) One-line Description of each photo or file:
Subject: | Love is not love Which. |
ALERT!
This e-mail, in its original form, contained one or more attached files that were infected with a virus, worm, or other type of security threat. This e-mail was sent from a Road Runner IP address. As part of our continuing initiative to stop the spread of malicious viruses, Road Runner scans all outbound e-mail attachments. If a virus, worm, or other security threat is found, Road Runner cleans or deletes the infected attachments as necessary, but continues to send the original message content to the recipient. Further information on this initiative can be found at http://help.rr.com/faqs/e_mgsp.html.
Please be advised that Road Runner does not contact the original sender of the
e-mail as part of the scanning process. Road Runner recommends that if the sender
is known to you, you contact them directly and advise them of their issue.
If you do not know the sender, we advise you to forward this message in its entirety
(including full headers) to the Road Runner Abuse Department, at abuse(at)rr.com.
Love's not Time's fool, though rosy lips and cheeks
Within his bending sickle's compass come:
Love alters not with his brief hours and weeks,
But bears it out even to the edge of doom.
If this be error and upon me proved,
I never writ, nor no man ever loved.
From: | "Clark, Thomas M UTPWR" <Tom.Clark(at)UTCFuelCells.com> |
rv8-list(at)matronics.com, rv9-list(at)matronics.com, rv-list(at)matronics.com,
Mid-AtlRVwing(at)yahoogroups.com, rv8list(at)yahoogroups.com,
BostonRVBuilders(at)yahoogroups.com
Groups,
I have had a bunch of questions about my modified RV-8 Fastback which was
completed mid. last year. I now have a web site that should answer many of
the questions about this modification. Try the link below.
Tom RV8 Fastback, N525TC, 75 hours
http://members.cox.net/rv8fastback
Tom Clark
860-727-2287 Office
860-604-5826 Cell
860-998-9811 Fax
e-mail: tom.clark(at)utcfuelcells.com
Subject: | [PLEASE READ NOW] - Addressing Upgrade At Matronics TONIGHT! |
Dear Listers,
Service Provider to upgrade to a larger IP subnet. I will be
re-addressing all of the machines on the network including the
Matronics Web Server and Matronics Email Server at that time. Name
Service will be updated at that time as well and most things should
work again pretty quick. There may be some bounced email for a few hours
or even a day or so as the new name-to-ip-address resolutions propagate
into the depths of the Internet.
If you have problems posting a message to one of the Lists or get a
bounced message back, please wait a couple of hours and try sending it
again. Generally, access to the web site should work within 1-hour of
Hopefully the transition will go smoothly and you'll hardly even
notice! :-)
Thanks for your patience!
List Administrator
Does anyone know where to get rocker switches that have engraved I.D.'s on the
switches themselves??? I have seen them but do not recall who has them....
LARRY, I JUST GOT OURS HERE.
DOUG PRESTON
RV-7A WIRING
_www.aerocraftparts.com/Categories.aspx?Category=38940ec0-b260-4e9f-a23c-b80ff
8e89c67_
(http://www.aerocraftparts.com/Categories.aspx?Category=38940ec0-b260-4e9f-a23c-b80ff8e89c67)
Subject: | E: RV7-List:Newbie advice |
I have just hung my tail kit on the fuse (less than 100 hours thanks to
pre punched empanage kits) and therefore feel I am a complete expert on
all aspects of RV building...NOT!
But, One area all the builders websites complain about is having to set
the blind rivets by hand. If you trot down to Harbor frieght you can by
a pneumatic pop riveter for like 35 bucks. I built a zenair Zodiac which
is completely assembled by blind rivets so of course I bought one.
They work very very well.
I would suggest for the few hundred you might have to set on the RV they
may well be worth the investment.
Imagine setting blind rivets with one finger....:)
Frank
Subject: | Flop tube problems |
For those interested I designed a simple anti-rotation bracket for my flop tube
installation. It is easy to make and install while constructing the tank. I
believe it can be easily retrofitted to an existing tank with minimal effort,
but you will have to remove the flop tube from the 90 bulkhead elbow.
Photos are posted on my website ExperimenalAero.com http://www.experimentalaero.com/flop_tube_anti_rotation.htm
Paul
To: RV7and7A(at)yahoogroups.com
Sent: Thursday, January 13, 2005 12:56 AM
Subject: [RV7Yahoo] Re: Flop tube problems
For those that are interested, I was told by Vans that flop tubes
should be fitted with anti-rotation brackets as well. This makes
sense to me but is not depicted on the drawings or described in the
instructions. It will be fun installing them now...
Another kind person pointed me to the Standard Aircraft Handbook,
where the torque figures are in fact listed.
Richard
--- In RV7and7A(at)yahoogroups.com, "rwtrwtau" wrote:
> Hi Everyone,
> I'm wondering if people have been having issues getting the flop
> tubes installed in their tanks? My issues seems to be stopping
the
> fitting from turning when I connect the AN-929-6D end cap.
> First I tried sealing the fitting by smearing the fitting, nut and
> hole with Proseal. I quickly discovered that that was a bad idea
as
> the Proseal turns into rubbery like stuff when it sets not
adhesive.
> I have since tried with the fittings dry and Proseal removed.
This
> has not helped either.
> Looking at the plans (16A) I have installed the T-410 plate inside
> the rib and the T-405 reinforcing angle. The T-410 plate is not
> specifically called out but I assume it should be there even in
flop
> tube installations.
> I do not see a call-out for a bulkhead washer on the plans.
Indeed
> if I install on, there will not be any thread for the nut to clamp
> down on, let alone 1 turn extra.
> I was thinking of making some anti-rotation brackets to fit in the
> tank but that will be a pain. I have also made some very thin
> washers from .016" Alclad and this seems to help.
> Does anyone know what the torque requirements for these fittings
> is? I have been working on the basis of finger tight + 1/2 turn.
> Thanks
> Richard
Van's Air Force - World Wide Wing
www.vansaircraft.net
a.. To visit your group on the web, go to:
http://groups.yahoo.com/group/RV7and7A/
b.. To unsubscribe from this group, send an email to:
RV7and7A-unsubscribe(at)yahoogroups.com
Subject: | Space in RV 7 wing roots |
Hi guys,
I'm planning on doing something a little different with the fuel system
on the 7A to improve the margin against vapour lock for use with
Autofuel, which boils a whole lot easier than 100LL does if the pump
sucks on the fuel.
The first part of the mods require installing an electric fuel pump (and
hopefully pressure regulator) in each wing root, i.e as close to the
fuel tank as possible..
Does anyone know the approximate width of the space between the tank and
the fuse side, has anyone seen a pump installed in that location?
Frank
Subject: | Re: [NorCal-rvlist] Wing root space RV7A |
Frank,
I saw your post on the rv7-list but didn't reply because I didn't have exact
dimensions handy...and in fact, it will vary from aircraft to aircraft based
on sweep.
In my particular case, the distance between the fuel tank and side skin
starts out around 4" at the leading edge and tapers down to about 3" at the
spar.
I've definitely seen people mount boost pumps in the wing root, claiming
that it's much cooler for them there (and I buy that).
Do a Matronics RV list search (http://www.matronics.com/searching/) for
"pump & wing root" and you'll get a buttload of info on the topic of fuel
pump installation. I don't recall where exactly I saw photos on the web of
wing root pump setups, but I know I've seen 'em out there before. You'll
have to work some tubing magic, but that's not a big deal.
If it's any consolation, the standard AFP high pressure pump install kit
that Van's sells worked well. My pump/filter is located right in front of
the selector valve. It doesn't get in the way of our legs and stuff, but it
does introduce a lot of fuel connections into the cabin area. FWIW, I've
had various tiny oil leaks and brake fitting leaks in the past, but the fuel
system has been dry as a bone.
In a way, I'd almost rather have the leak in the cabin than outside.
Outside I'd never know about it until I was on the ground. Inside, I assume
I'd know about it right away.
Best of luck,
)_( Dan
RV-7 N714D
Subject: [NorCal-rvlist] Wing root space RV7A
> Hi guys,...Posted this to the Mtronics RV 7 group but no reply...Can
> anyone help?
> sucks on the fuel.
> Thanks
> Frank
> [Non-text portions of this message have been removed]
> Give the gift of life to a sick child.
> Support St. Jude Children's Research Hospital's 'Thanks & Giving.'
> http://us.click.yahoo.com/5iY7fA/6WnJAA/Y3ZIAA/jrDrlB/TM
> <*> To visit your group on the web, go to:
> http://groups.yahoo.com/group/NorCal-rvlist/
> <*> To unsubscribe from this group, send an email to:
> NorCal-rvlist-unsubscribe(at)yahoogroups.com
> http://docs.yahoo.com/info/terms/
the
> spar.
And in case it sounds like I've got a "swept wing" RV-7, I don't... ;-)
It's due to the curving contour of the fuselage.
)_( Dan
Hey Frank,
The distance is about 4". Just to let you know (and I'm sure someone will have
an opinion about this but) I am running auto fuel in my 7A with the standard
boost pump from vans in the normal location (inside of firewall) and I have
60 hours on the plain now and have had no trouble with vapor lock. I run 93 octain
fuel from BP in a 0-360A1A. Not a bad idea to put it in the wing root for
if anything piece of mind. Have fun.
"Hinde, Frank George (Corvallis)" wrote:
>Hi guys,
>sucks on the fuel.
>Thanks
>Frank
Thanks Dan...Loved the video!
Frank
Subject: RV7-List: Re: [NorCal-rvlist] Wing root space RV7A
> skin starts out around 4" at the leading edge and tapers down to about
> 3" at
the
> spar.
)_( Dan
Actually that is a good point...I had a cracked fitting inside my cabin
and hardly any fuel leaked but it stunk to high heaven...:)
I was just terrified it might burst into flames before I got it down....
Frank
Frank,
exact dimensions handy...and in fact, it will vary from aircraft to
aircraft based on sweep.
the spar.
fuel pump installation. I don't recall where exactly I saw photos on
the web of wing root pump setups, but I know I've seen 'em out there
before. You'll have to work some tubing magic, but that's not a big
deal.
of the selector valve. It doesn't get in the way of our legs and stuff,
but it does introduce a lot of fuel connections into the cabin area.
FWIW, I've had various tiny oil leaks and brake fitting leaks in the
past, but the fuel system has been dry as a bone.
assume I'd know about it right away.
Best of luck,
)_( Dan
RV-7 N714D
> anyone help?
system
> sucks on the fuel.
(and
and
> Thanks
> Frank
Yes its probably OK with the 3/8ths fuel line but hydralically the best
place is "out there" and I do like my current A/C setup which does the
same thing and I switch taks by simply switching pumps...Works real good
and you can remove the engine pump which...yeah ok it does'nt require
electricity but is very prone to vapour lock too.
Besides each of the Lightspeeds need elctric too...:)
So for me if it will fit its worth forcing...:)
Frank
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Slgmjg1(at)cs.com
Subject: RE: RV7-List: Space in RV 7 wing roots
Hey Frank,
will have an opinion about this but) I am running auto fuel in my 7A
with the standard boost pump from vans in the normal location (inside of
firewall) and I have 60 hours on the plain now and have had no trouble
with vapor lock. I run 93 octain fuel from BP in a 0-360A1A. Not a bad
idea to put it in the wing root for if anything piece of mind. Have fun.
>Hi guys,
>sucks on the fuel.
>(and hopefully pressure regulator) in each wing root, i.e as close to
>the fuel tank as possible..
>and the fuse side, has anyone seen a pump installed in that location?
>Thanks
>Frank
Subject: | Seat Backs in a 7A |
Hi all,
I'm a little confused over the seat back hinge placement. The pans say
to have an overall hinge length of 15.5 inches where the seat back is 16
inches. Naturally I cut 15.5 inches and centered it on the seat back.
Didn't look quite right so I looked harder and it appears the really
there should be 16" of hinge, with the closed end on the inboard side.
The inboard edge of the seat back should be right on the edge of the
tunnel cover flange.
Does that sound right to you guys?
It would be better if Van's gave a dimension relating the seat back
positon to the airframe.
Frank
Subject: | Re: Seat Backs in a 7A |
Frank,
There is a lot of detail on DWG 30. Its all there.
Dan Hopper
Walton IN
RV-7A
N766DH (Flying since July until sometime in Dec. Wx bad here in Indiana
lately.)
In a message dated 1/19/05 11:54:07 A.M. US Eastern Standard Time,
Hi all,
Frank
Frank,
I'm working on the seat backs too.
The drawing can be a bit confusing:
On drawing 30, bottom-center, note "F-637 Seat Back Assembly". To the
left, in area A-7.5, note the side view at bottom: "F-637E Make from
AN257-P3 Hinge 16" long".
Then, note the front view in area A-6, shows a dimension of 15 1/2"
Total Hinge Length. You can see that the dimension is actually from the
end of the hinge eye on one end to the end of the hinge eye on the other
end.
Bad wording in my opinion.
Sam
Abilene, TX
7A
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Hinde, Frank
George (Corvallis)
Subject: RV7-List: Seat Backs in a 7A
Hi all,
Frank
Yes I understand it now Sam thanks...I just saw a picture from a
builders website...It is as you say...closed end flush with one end
(inside) and that closed end "overhangs" the hinge on the floor to the
inboard side.
Phew...:)
Frank
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of sjevans
Subject: RE: RV7-List: Seat Backs in a 7A
Frank,
end.
Sam
Abilene, TX
7A
George (Corvallis)
Hi all,
Frank
Subject: | Horizontal Stab Rear Spar |
Well, I just got my Empennage Kit and I'm hard at it drilling out the
Horizontal Stab's. Question, on drawing 3 at the AFT Exploded ISO View (3B)
there is a note to "Trim horz. Stab rear spar to allow for elevator control
horns to pivot...(see DWG 27A)". I looked at DWG 27A and can see the
bearing and horns but no callout for a trim dimension. Is this trimmed
during assembly for clearance?
Dan Storer
RV7A newbie
Oklahoma City
From: | "Ken & Terri Howell" <tandk_howell(at)comcast.net> |
Dan,
I'm also an RV-7 newbie, but I believe the dimension you are looking for is
on DWG 3, where it is shown as "~1" which I take to mean approximately one
inch. That's one inch off each side. It would be easiest to do before you
rivet the rear spar together, don't wait 'till afterward like I did.
Ken Howell
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Daniel Storer
Subject: RV7-List: Horizontal Stab Rear Spar
Dan Storer
RV7A newbie
Oklahoma City
From: | "Dave Figgins" <2004nospam(at)earthlink.net> |
I do not have the plans with me but if I recall if you read the elevator
section it talks about potentially cutting the rear spar flange to allow
full travel of the elevator/horns, it make the point about NOT removing any
spar material just the flange.
Dave RV-7A (just finished the empennage)
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Ken & Terri Howell
Subject: RE: RV7-List: Horizontal Stab Rear Spar
Dan,
Ken Howell
Dan Storer
RV7A newbie
Oklahoma City
Subject: | high oil and fuel pressure |
Most of you folks are good at problem solving. I think I know the answer but here's
the situation.
Flew my RV-6 with an O-320 last week. Air temperature was 6 degrees F. Oil temp
never made it above 150 degrees. As I leveled off and the
fixed pitch prop rpm came up to normal cruise, the oil pressure came up to just
below or at red line and fluctuating about 2 to 3 psi. I reduced RPM to
1700 and slowly came back in to land and the pressure stayed around 85 psi (red
line is 90). In the pattern when my airspeed was back below
100 mph the oil pressure was in its normal range around 80psi.
Ok, it was a really cold day. So I'm thinking that the oil cooler was getting
too much air flow. I was able to block 1/2 of the air flow and flew a couple
of days later when it was in the high 30's. Flight went great.
Went flying today and the air temp was 23 degrees. Even with half the airflow
to the cooler blocked the pressure fluctuation up near red line occurred again.
This aircraft has Van's engine gauges and I was also venturing that the transducer
might be bad, but during these high oil pressure indications the fuel pressure
would also rise. They would rise at the same points. I'm concerned because redline
for fuel pressure is 8 psi and the indication at one point was 12 psi.
So, has anyone run into too much cooling for oil and if so did it also affect your
fuel pressure?
Also, I am concerned about the fuel pressure excursion above red line. What specifically
do you think I should check? I took the cowl off after today's flight
and did not notice any leaks.
The engine was about 45 degrees F when I started it. It is kept in a heated hanger
so the oil was not at ambient temperature when I started it.
I would appreciate your comments.
John Brunke
St. Charles, IL
From: | "Jim Nolan" <jamespnolan(at)earthlink.net> |
Subject: | Re: high oil and fuel pressure |
First off, I doubt the vernitherm opened to let your oil cooler even be in
the circuit. Secondly, it's cold. Fuel pressure and oil pressure will be
higher with thicker substances to push.
Jim Nolan
1727 Briarwood Dr.
Warsaw, In 46580
Subject: RV7-List: high oil and fuel pressure
but here's the situation.
Oil temp never made it above 150 degrees. As I leveled off and the
just below or at red line and fluctuating about 2 to 3 psi. I reduced RPM
to
(red line is 90). In the pattern when my airspeed was back below
getting too much air flow. I was able to block 1/2 of the air flow and flew
a couple
airflow to the cooler blocked the pressure fluctuation up near red line
occurred again.
transducer might be bad, but during these high oil pressure indications the
fuel pressure
because redline for fuel pressure is 8 psi and the indication at one point
was 12 psi.
affect your fuel pressure?
What specifically do you think I should check? I took the cowl off after
today's flight
heated hanger so the oil was not at ambient temperature when I started it.
> John Brunke
> St. Charles, IL
Make sure that the grounds to the gages are good, if they are not
sometimes you can get faulty readings.
redline for fuel pressure is 8 psi and the indication at one point was 12 psi.
your fuel pressure?
>John Brunke
>St. Charles, IL
What type/weight oil?
to
a couple
occurred again.
fuel pressure
was 12 psi.
today's flight
> John Brunke
> St. Charles, IL
Not a likely culprit since your temp/pressure readings seem to be related,
but I've had a false low temp reading in the past due to a badly placed
sensor (it was in the front of the oil pan in direct air blast). Oil temp
never showed above 100 deg even though the engine was operating normally.
Don't think it's a problem in your case but just something to check.
[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of John Brunke
to
a couple
occurred again.
fuel pressure
was 12 psi.
specifically do you think I should check? I took the cowl off after today's
flight
John Brunke
St. Charles, IL
From: | "James E. Clark" <james(at)nextupventures.com> |
Comments below ....
James
{SNIP}
| the fuel pressure
| point was 12 psi.
Hmmm ....
I would check the power, ground and sense wires to the gauges. During this
time was the electrical system otherwise doing fine?
Just a thought.
James
Subject: | High oil and fuel pressures |
Tim,
I use AeroShell 15/50
> James
> {SNIP}
> | the fuel pressure
> | point was 12 psi.
> Hmmm ....
> Just a thought.
> James
James,
The electrical system was working perfectly.
Just the way the guages were moving back and forth
in relatation to each other, I'm going to take a closer look
at the grounding situation up at the manifold. Maybe the lower temperatures
are contracting something enough to lose a good ground.
John Brunke
Anyone out there experience looseing jam nuts. I have heard of some problem.
Is there any reason not to use lock nuts on these.....
Ed Clegg
John,
There was a post a few days ago about grounding the Van's gauge mounting
"manifold." It is annodized which is a very tough insulator. Take a bolt out
and use knife or file to cut through the annodized layer, then run a ground
wire to a good ground.
Dan Hopper
Walton, IN
RV-7A
N766DH (Flying since last July)
In a message dated 1/28/05 12:45:18 A.M. US Eastern Standard Time,
jwbrunk(at)attglobal.net writes:
> Hmmm ....
> Just a thought.
> James
James,
John Brunke
Thanks for all the suggestions on the high readings.
I checked the grounding of the pressure transducers and they checked out ok.
The lines to the guages are also in order.
The high oil pressure I can certainly understand due to the cold weather.
I guess the new question is why is the fuel pressure going 2 to 3 psi over
red line
as the fixed pitch prop comes up to cruise RPM?
I'll let you folks know when I get it figured out.
John Brunke
St. Charles, IL
John,
Do you have a door at the back of the oil cooler you can close, and if so,
did you have it closed? Some have such a door, some don't.
Chuck
Subject: Re: RV7-List: high oil and fuel pressure
red line
John Brunke
St. Charles, IL
Yes I do have an oil cooler door. The builder did a really nice job on it.
I have checked the operation of it and it is working properly.
Subject: RE: RV7-List: high oil and fuel pressure
> John,
> Chuck
> From: owner-rv7-list-server(at)matronics.com
> ok.
> red line
> John Brunke
> St. Charles, IL
From: | "Don Patterson" <dpatterson14(at)wi.rr.com> |
Subject: | Removing material from HS rear spar |
Dave
I am new to the RV 7a empennage also and I had the same question about the trimming
the rear spar flange for clearance of the elevator horn. I called Van's
and they confirmed that you remove only one inch from both flanges. I placed
my spar reinforcement bars in and drew a line along the bottom edge of the bars
for one inch in both left and right directions from the center and trimmed on
the line. There is no need to go into the radius of the flange.
Don
Subject: | Sam James Holy cowl, RV 7A |
Hi all, I'm planning ahead here
Anyone have any thoughts about using one of these cowls compared to the
stock Van's item?
I seen some posts that claim performance but at the cost of being harder
to fit.
Frank
Subject: | Re: Sam James Holy cowl, RV 7A |
I would consider using one next time. Thing is, you need an extended hub
propeller if I'm not mistaken. Wonder how much additional stress that puts
on the crankshaft. It wouldn't hurt CG-wise. Even if you don't use the Sam
James cowl, an extended hub prop would do wonders for allowing more
clearance for horizontal induction goodies...ram air inlet, etc. I can tell
you that making the ram air inlet work with a compact hub Hartzell was
interesting...
Back on topic...they sure look pretty with the nose extended with the James
cowl.
Have you read Randy Lervold's writeup on it? IIRC he said he might not do
it that way if he had to do it over. Apparently it added considerable time
and labor to the build process. http://www.rv-8.com/Cowl.htm
)_( Dan
RV-7 N714D
Subject: RV7-List: Sam James Holy cowl, RV 7A
> stock Van's item?
> to fit.
> Thanks
> Frank
Interesting...I saw the write up and it sounds even with the mold
corrected it is probably at least SOME more work...Hmm as you say Dan it
looks hot!
Thisnk I might check out the 4" extension and if Aerosport are happy
with this if required,,....Oh and yes, that Van's will refund the cost
of the cowl coming with my finish kit...:)
Frank
Subject: Re: RV7-List: Sam James Holy cowl, RV 7A
hub propeller if I'm not mistaken. Wonder how much additional stress
that puts on the crankshaft. It wouldn't hurt CG-wise. Even if you
don't use the Sam James cowl, an extended hub prop would do wonders for
allowing more clearance for horizontal induction goodies...ram air
inlet, etc. I can tell you that making the ram air inlet work with a
compact hub Hartzell was interesting...
James cowl.
do it that way if he had to do it over. Apparently it added
considerable time and labor to the build process.
)_( Dan
RV-7 N714D
the
> stock Van's item?
harder
> to fit.
> Thanks
> Frank
From: | "Noel & Yoshie Simmons" <noel(at)blueskyaviation.net> |
I installed one of these on an RV-6A. Lots of hard work, but the cowling
worked perfectly, I also made my own NACA duct on the side of the cowling
for the oil cooler. All temps would stay normal even in high power slow
flight. I did not use the 4" extension, still up in the air about that,
With the extension it may be a bit easier. If you would like a picture just
send me an email at NOEL(at)BLUESKYAVIATION.NET
Noel
George (Corvallis)
stock Van's item?
to fit.
Frank
Will James just told me he thinks a 4" prop extension will limit the
motor to pull about 3.5 G's...Ouch...Don't like that.
I could go with an updraft and have no extension but I'm not sure I like
that option either....hmmm
Any thoughts?
Frank
George (Corvallis)
Subject: RE: RV7-List: Sam James Holy cowl, RV 7A
looks hot!
Frank
James cowl.
)_( Dan
RV-7 N714D
the
> stock Van's item?
harder
> to fit.
> Thanks
> Frank
Will James worked with me to come up with a version of the cowl for my
**carbureted** RV6A O-360. Maybe this would help you.
This version would not require the extension and in theory should be easier
to fit. I have the cowl but won't be working on that until it warms up.
If you check his site, you will see a picture of it.
James
| From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-
| server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis)
| Sent: Tuesday, February 01, 2005 1:19 PM
| stock Van's item?
| to fit.
| Thanks
| Frank
{SNIP}
From: | Dennis Haverlah <clouduster(at)austin.rr.com> |
I just recieved the Sam James rotary versioin for my 7A. I plan on
using a Mazda RX-8 engine and Tracy Crook's PSRU. The workmanship on
the cowl is great. It has the shark air intake below the spinner. I
won't be installing it until this spring.
Dennis Haverlah
>James
>| stock Van's item?
>| to fit.
>| Thanks
>| Frank
>{SNIP}
I had Noel Simmons install one on my 6A. I would definetly recommend a prop
extension
that Sam James recommends during installation. Noel chopped off approx 3-4"
to make it
fit and in doing so had to mold blisters in front of cowl to accomodate
starter & alternator.
Added a lot more cost to installation. Anybody interested in pics e-mail me
off list I'll forward.
Mike Comeaux
mcomeaux(at)bendnet.com
> stock Van's item?
> to fit.
> Thanks
> Frank
From: | "benandginny" <benandginny(at)insightbb.com> |
"RV7-List Digest List"
Subject: | Re: RV7-List Digest: 8 Msgs - 02/01/05 |
Hey Dennis,
Does Sam (Will) James ship the cowl in a crate or how does he package it.?
The reason I ask is I'm wondering if I get one can I use his container to
return my Van's cowl.
Ben Cunningham
RV7 Finish Kit
________________________________ Message 7
_____________________________________
> From: Dennis Haverlah <clouduster(at)austin.rr.com>
> Dennis Haverlah
Subject: | Cruise performance |
I know an email about fuel economy and RV's is kind of an oxymoron and
it fact it hard to pin down data.
However part of my intended mission is long cross countries and it
appears the RV 7 could be pretty good, especially going slower but of
course I want to get there as well!
So with an IO360 with a modern EI and FI packages what do these planes
get at 200mph in the way of fuel burn?
I admit to a slightly hidden adgenda, I am pretty convinced the cooling
drag with a water cooled motor causes more drag and while there are
claims of the "same performance" to an IO360 it gets blurry to know at
what fuel burn they are making the same speed.
So what are your experiences?
Frank
Subject: | Re: Cruise performance |
At 173 KTAS (200mph true airspeed), mine burns about 8.7 gph. IO-360-A1B6
w/single Lightspeed Plasma II. I lean to about 50 ROP. With a 180hp
injected + EI you can probably beat that by a tenth of a gallon per hour or
two.
When I fly in formation with slower planes, and we do 160 to 165 KTAS or so
(kind of a lowest common denominator speed), I'm usually burning 7 to 7.5
gph. Other planes in the formation without FI or EI are burning 2+ gph more
than I am -- with smaller engines.
When I fly alone and am travelling "to get there," I fly at full throttle,
2470 RPM, leaned to 50 ROP. At 8000' DA, I usually see 9.4 to 9.6 gph and
about 175 to 180 KTAS.
I haven't even mentioned LOP operations...if you can live without the high
speed, you can get the fuel burn down dramatically.
FI + EI kicks butt for economy...and allows you to really fine tune power
output to your intention for the particular conditions.
)_( Dan
RV-7 N714D
From: | "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com> |
Damn that's good!
With my fuel system set up to run autogas this is going to be cheaper
than running my Dodge Neon...Well...Maybe not...:)
Frank
-----Original Message-----
Subject: Re: RV7-List: Cruise performance
IO-360-A1B6 w/single Lightspeed Plasma II. I lean to about 50 ROP.
With a 180hp injected + EI you can probably beat that by a tenth of a
gallon per hour or two.
so (kind of a lowest common denominator speed), I'm usually burning 7 to
7.5 gph. Other planes in the formation without FI or EI are burning 2+
gph more than I am -- with smaller engines.
throttle, 2470 RPM, leaned to 50 ROP. At 8000' DA, I usually see 9.4 to
9.6 gph and about 175 to 180 KTAS.
high speed, you can get the fuel burn down dramatically.
power output to your intention for the particular conditions.
)_( Dan
RV-7 N714D
Seems like there is nervousness around using a 4" prop extension and C/s
prop for aerobatics. Can't as yet find a definative answer.
If the 3.5G limit is true and the Hartzell weighs a hefty 53lbs, then
one answer might be a Whirlwind prop which weighs a 20lb less?...Trouble
is thst option is another 2000 bucks (performance seems about the same)
and it still might not get back to the 6G the airframe is rated for.
Hmm...the extra 5 mph is looking expensive in terms of cash and/or
aerobatic performance loss.
Any thoughts anyone?
George (Corvallis)
Any thoughts?
Frank
George (Corvallis)
looks hot!
Frank
James cowl.
)_( Dan
RV-7 N714D
----- Original Message -----
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
the
> stock Van's item?
harder
> to fit.
> Thanks
> Frank
Subject: | SEC: UNCLASSIFIED RE: PROP SELECTION |
My thoughts on prop selection.
A C/S prop is unlikely to make a plane go faster than a properly selected
coarse pitch fixed pitch prop. It does provide flexibility between climb and
cruise regimes, at a substantial cost in dollars and weight.
Generally, without a G-suit, most of us will start to grey out around 4.5G,
which is probably the practical G limit for most of us, variable with age,
fitness and recent exposure to G.
A conventional C/S prop is excellent for aerobatics. It treats the engine
very gently and provides lots of protection against overspeed.
The difference between a conventional and aerobatic C/S props is in the form
of protection against oil supply failure. A conventional prop that loses oil
pressure will fail to fine pitch, so the plane can climb and complete a
flight.
An aerobatic prop has counterweights and a reversed failure mode. The
aerobatic prop will fail to coarse pitch to prevent engine overspeed during
aeros. This means the governor acts in reverse. The counterweights are there
to provide protection from momentary failure of oil pressure during very
vigorous aeros, they keep the pitch as-is during short duration excursions
in oil pressure. Others with better knowledge may elaborate more accurately
on this point.
RVs are for recreational aeros only, not hard core vigorous stuff, so for
most of us a conventional C/S prop is really good for the engine compared to
fixed pitch. Provided you have the budget - a C/S prop will not pay for
itself in fuel savings, as fuel injection and electronic ignition will.
A final observation. Certified aerobatic aircraft have to meet a requirement
that, when going down vertically, at full power, the plane will not exceed
Vne. That is why 200hp planes like the Cap 10 are draggy and only cruise at
120kts.
An RV is experimental and does not meet that criteria, its a slippery
critter downhill. A fine pitch prop is an important brake when going
downhill.
David Francis, VH-ZEE, Canberra, Australia
From: Hinde, Frank George (Corvallis) [mailto:frank.hinde(at)hp.com]
Another update,
Spoke to Sam Tilleman at Sabre manufacturing who tells me that "sure a
4" inch extension will cause more wear if you doin hardcore aerobatics,
but will it break anything?...NO!" He says he has litterally hundreds of
the extensions out there some of them pulling some hardcore G's.He waxed
lyrical about Berkuts pulling vertical with a 540 with a 6 to 8"
extension and all that.
Really it comes down to...How much hardcore aerobatics are going to
do?...Good point!
The other interesting observation was that his current plane runs a
Hartzell C/C which is coming off at the the first sign of the next AD.
He is sure the AD's have cost him way more than the extra $2K a
Whirlwind 200 will cost. Whilrwind save quite a bit of weight too.
Of course we don't know what AD's (of course they don't really exist in
experimental land) the Whirlwind will need either or when the front
bearing will start knocking...probably not in the 2000 hour TBO.
So apart from the risk of not being able to put 200lbs of baggage behind
the seats it looks like the Holy Cowl/ Whirlwind combo might be a good
plan.
Frank
George (Corvallis)
George (Corvallis)
Any thoughts?
Frank
George (Corvallis)
looks hot!
Frank
James cowl.
)_( Dan
RV-7 N714D
the
> stock Van's item?
harder
> to fit.
> Thanks
> Frank
Subject: | Re: SEC: UNCLASSIFIED RE: PROP SELECTION |
If you get a WW RV200 prop now called Titan, you might
want to keep it in the back of your mind that the
RV-7a engine cowling will need cutting,refitting or
replacing. Either the lower half or the upper half.
I'm off 3/32" at an angle so my "fitted for a
Hartzell" lower cowling is a paper weight and a new
lower $445 cowling is being shipped.
I know another RV-7a builder who also has a lower
cowling available since buying a WWRV200 prop.
Supposedly they(the WWRV 200) bolt right on the
RV-8's.
YMMV.
Subject: | Whirl Wind prop fit |
I had fitted my 7A cowl for the Hartzell but finally bought the Whirl Wind
RV200. Before purchase WW said that the fit is the same --- NOT. The spinner
gently rubbed the cowl and there is no adjustment. I'm thinking "hours and
hours of work shot, not to mention the cost of replacing both the top and
bottom cowl halves". I decided to build up the inside of the cowl ring 5/32"
+/- with epoxy and glass and then sanded the front to fit. It's better than
the original Hartzell fit. I made the gap at the top 1/8" and the bottom 3/16"
to account for the eventual engine sag. I'm assumed 1/4" sag (pure guess
work) and ran a computer model to get that 1/16" difference.
There is a photo of the installation at:
http://users.aol.com/n67bt
Bob Trumpfheller
PS, the original was posted on the RV7 list but I thought it might be of
interest to some RV listers as well.
< If you get a WW RV200 prop now called Titan, you might
RV-8's.
YMMV. >
Hey Ben,
You're a pilot of UPS for crying out loud!!!! Go to the back and find a box.
The Sam James should work fine for the turbo charged subaru. It is about 6" longer
according to Sam. You will need roughly 4.5" additional length for everything
to fit.
Darwin N. Barrie
Chandler AZ
Good point, In my case however I'm starting from scratch so its either a
WW200RV/Howly cowl/4"extension or Hartz/vans cowl.
I need to check on the cost of the Vans cowl and spinner for return to
get the net cost delta between the two setups.
Frank
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of mark manda
Subject: Re: RV7-List: SEC: UNCLASSIFIED RE: PROP SELECTION
If you get a WW RV200 prop now called Titan, you might want to keep it
in the back of your mind that the RV-7a engine cowling will need
cutting,refitting or replacing. Either the lower half or the upper
half.
I'm off 3/32" at an angle so my "fitted for a Hartzell" lower cowling is
a paper weight and a new lower $445 cowling is being shipped.
I know another RV-7a builder who also has a lower cowling available
Supposedly they(the WWRV 200) bolt right on the RV-8's.
YMMV.
From: | "Bobby Hester" <bhester(at)hopkinsville.net> (by way of Matt Dralle <nospam(at)matronics.com>) |
Subject: | Re: [RV7Yahoo] RE: Electrical Tools |
of Matt Dralle )
> From: Frank Stringham <fstringham7a(at)yahoo.com>
> Date: Thu, 3 Feb 2005 06:35 (CDT)
> Subject: [RV7Yahoo] RE: Electrical Tools
> Hi to all
> Ready to start the electrical process and need to get tools. What have you
> folks found to be a good set / type / name brand electrical tools to buy. I
> do know my house construction electrical tools are a bit much for the
> planes delicate wires and materials.
> TIA
You can get everything you need here:
http://www.bandc.biz/parts.html
http://www.steinair.com/
You'll need:
RCT-1 - PIDG Style Crimp Tool
RCT-2 - BNC Coax Crimp Tool
RCT-3 - D-Sub Pin/Socket Crimper (maybe)
BCT-1 - B-Crimp Open Barrel Terminal Tool (maybe)
DSE-1 - Insertion/Extraction Tool - D-Sub Pin (maybe)
Surfing the web from Hopkinsville, KY
RV7A web site: http://www.geocities.com/hester-hoptown/RVSite
Some cost comparisons,
Vans will refund $800 for the cowl and all the hardware to fit it.
Holy cowl costs $950
Plenum to match $400
Hardware guess $ 50...
Prop extension $400
Total ..........1800....Less$800 refund from Vans gives a cost increase
of $1000 to use the Sam James cowl.
Ouch!...Back to hanging lead on the front of the engine mount instead I
think...:)
Frank
From: | "Greg Blakey" <gblakey(at)vic.australis.com.au> |
Frank,
Does anyone know if Vans supply a flush cowl to match the WW 200RV prop
without major modifications or are they all the one style for constant
speed?
Regards, Greg
> Prop extension $400
> think...:)
> Frank
Are you using an IO360 engine?
If you are using the O-360 carbureted engine, then no prop extension
required with the latest cowl from Will.
James
| Sent: Thursday, February 03, 2005 3:21 PM
| Prop extension $400
| increase of $1000 to use the Sam James cowl.
| I
| think...:)
| Frank
No...Injected,...:)
Frank
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of James E. Clark
James
| Prop extension $400
| I
| think...:)
| Frank
My standard Vans, RV7A, IO360, 200 HP cowl would have worked fine for the WW
RV200. Just trim a little more at the firewall.
Bob Trumpfheller
--> RV7-List message posted by: "Greg Blakey" _gblakey(at)vic.australis.com.au_
(mailto:gblakey(at)vic.australis.com.au)
< Frank,
speed?
Regards, Greg >
I concur, the stock cowl would work fine BEFORE using
Van's suggested 2.25".
> Bob Trumpfheller
> < Frank,
> style for constant
> speed?
> Regards, Greg >
> Contributions
> any other
> Forums.
> http://www.matronics.com/subscription
> http://www.matronics.com/FAQ/RV7-List.htm
http://my.yahoo.com
Subject: | Help..."Extra" holes in wing spar stub and F704 pieces? |
From: | Andrew Douglas <adouglas(at)optonline.net> |
Because of a mistake I made that's almost too dumb to talk about (I didn't
notice some holes that were to be used to match drill some parts until after
I'd drilled holes in the wrong place), we now are very gun-shy when we see a
hole that seems to be extraneous, or don't find a hole that we think should
be there.
We've found a few of the former (holes with no apparent purpose) on the main
spar and its corresponding bulkhead assembly (F704).
Can anyone tell me why there are two holes on the wing spar web, at the
inboard end, next to the nutplates that receive the two small bolts which
pass through the F704G bars? Dwg 11, sector B9...you'll clearly see the two
trios of holes for the nutplates, but there are two additional holes there.
These holes line up with the rivet holes that you drill through the 704G
bars. However, as far as we can tell they have no purpose. We're absolutely
sure that the holes in the 704Gs get rivets in them, which hold 704G to the
704B aft bulkhead and 704D vertical. The manufactured heads of the rivets
are definitely meant to set into the 704G, which means that these holes in
the spar serve no purpose and can be ignored, right?
Or do they? We're looking at each other and constantly saying "it wouldn't
be there if there weren't a reason for it."
For that matter, if the bolts that go through the 704G bars and into the
spar terminate in nutplates that are riveted to the spar, then why the heck
are there bolt holes in the FORWARD 704D too? Same deal...they have no
apparent purpose.
Please help.
Andrew Douglas
Page 8-2
Subject: | Re: Help..."Extra" holes in wing spar stub and F704 pieces? |
Look carefully on the plans there are a few holes that are for tooling
purposes and will not have a rivet installed. These were possibly there to hold
the
piece in place in a fixture or jig in order to match drill the spars
together. You are right to check 2-3-4 times and then drill.
Good luck
Tad Sargent
Sargentclt(at)CS.com
RV7A
Subject: | Planning for an engine |
I would like to build my own engine for my 7A. I'm looking at an IO-360 180
hp with a CS prop. I've been told the 200 hp weighs 30-40 lbs more and cost
significantly more for the extra 20 hp, so I can't justify it.
Has anyone found a good kit engine that they have assembled, and if so who,
how much and what was your experience?
Dan S.
RV7A
Dan,
Haven't done this, but hear good things.
Checkout Superior's XP-360 build options.
http://www.xp-360.com/
Sam
7A@ABI
Subject: RV7-List: Planning for an engine
180
cost
who,
Dan S.
RV7A
Subject: | Re: Planning for an engine |
Dan,
There was just an article in last months "Kitplanes" about Superior's
IO-360 engine. You can buy the kit or go to their factory in Dallas and
build an engine under their supervision. Hope that helps.
John Brunke,
N215KC
From: | "Brian Meyette" <brianpublic(at)starband.net> |
clamav-milter version 0.80j
on apollo
Check this out:
http://brian76.mystarband.net/SuperiorTextPics.htm
brian
[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Daniel Storer
Dan S.
RV7A
Checked by AVG Anti-Virus.
From: | "springcanyon" <springcanyon(at)mymethow.com> |
Subject: | Diesel engine for an RV-7 |
I am working on an RV-7 and am approaching the time when I need to know
which or what engine I am going to install. I love the idea of a diesel
engine. Since this is a major investment as well as one of the most
important parts of my airplane I would like some other opinions. I have
talked with Delta Hawk and their engine sounds good and looks good. The
thing that bothers me is the total lack of field experience with this
engine. Anyone have opinions about this?
Don Owens
Any ...and I mean any water cooled engine out there will produce more
cooling drag than an aircooled one will.
Note a good aircooled Lycosaurus will do around 200mph on 10 GPH.
Similar fuel burn on a very good water cooled automotive conversion will
give less than 180mph.
It will still do 200mph but the fuel burn will get significant...I think
fuel burn is proportional to speed squared (or is that cubed?) and that
part of the curve will get pretty steep.
Not saying that drag can't be reduced (P51 Mustang style scoops and
optimised radiators) but it certainly won't be a bolt on package.
I hate to say it but about the best bet is a Lycoming...And I spent a
year trying to prove otherwise...I even fly behind a little Subaru in a
Zenair Zodiac....A total engine rebuild for a couple of grand is sure
attractive but I just can't have a slow plane anymore and to burn
another 3 to 4 GPH to make the speed I want gets to be a big bill over
2000 hours as well...
My 2 cents
Frank
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of springcanyon
Subject: RV7-List: Diesel engine for an RV-7
Don Owens
Not flying yet, but I have a GM V6 truck engine in my plane along with the
firewall forward package from Belted Air Power. The air intake is the
original size and the radiator is mounted on the firewall with the original
air exit openings. My engine (modestly modified) will produce around 225 HP
and should make the plane cruise comfortably in the 200MPH range and the
fuel burn should be no more than 10 GPM. Again, this is purely speculation
on my behalf, but after talking with several others that have gone the GM V6
route with the kit from BAP, I think the assumption that a liquid cooled
engine will always create more drag is controversial at best. There is a
reason Burt Rutan absolutely required one of the engines in his "non-stop
around the world airplane" to be liquid cooled!
Gary Dwinal
RV7A
Subject: RE: RV7-List: Diesel engine for an RV-7
Note a good aircooled Lycosaurus will do around 200mph on 10 GPH. Similar
fuel burn on a very good water cooled automotive conversion will give less
than 180mph.
fuel burn is proportional to speed squared (or is that cubed?) and that part
I hate to say it but about the best bet is a Lycoming...And I spent a year
trying to prove otherwise...I even fly behind a little Subaru in a Zenair
Zodiac....A total engine rebuild for a couple of grand is sure attractive
but I just can't have a slow plane anymore and to burn another 3 to 4 GPH to
make the speed I want gets to be a big bill over 2000 hours as well...
My 2 cents
Frank
Don Owens
NOTICE: The information contained in this communication is intended solely
for use by the designated recipient(s). This communication may also contain
confidential or proprietary information and may be subject to
confidentiality protection under the law. If you are not a designated
recipient, you may not review, copy, or distribute this message. If you
receive this message in error, please notify the sender and destroy your
copy.
Thank you for your cooperation.
Fisher Engineering, a division of Douglas Dynamics, LLC
The only experience I have had with the Delta Hawk is a non flying running
demonstration at Osh Kosh and couple of years ago. The engine was extremely
noisy. It seemed to run very well and very smooth though. I do not know
what the fuel burn is for them.
Gary Dwinal
From: springcanyon [mailto:springcanyon(at)mymethow.com]
Don Owens
copy.
> with the firewall forward package from Belted Air Power. The air
> intake is the original size and the radiator is mounted on the
> firewall with the original air exit openings...I think the assumption
> that a liquid cooled engine will always create more drag is controversial
> at best.
The fact that the size of the inlet and exit openings is the same doesn't
mean much on it's own. If you just put a radiator between the inlet and
exit like on your conversion, and don't put one there on a Lycoming
installation, the drag will be higher on the engine with the radiator due
to the back pressure it generates as air slows down to flow through the
rad.
It is possible to control the air flow to and from the rad with
well-designed expansion (upstream) and compression (downstream) chambers
around the rad. I seem to recall reading that on a P-51 in the right
cruise configuration you could realize a small amount of *thrust* from this
arrangement. But that's some finicky engineering to get the cooling to
that point.
I guess what i'm saying is that if you have an airplane that's designed
from the start to use a water-cooled engine, you can design the airplane to
take advantage of the water cooling and to realize the least drag. But
when you have an airplane that's designed for an air-cooled engine, trying
to retrofit a water-cooled one later isn't likely to be as efficient.
> My engine (modestly
> modified) will produce around 225 HP and should make the plane cruise
> comfortably in the 200MPH range and the fuel burn should be no more
> than 10 GPM.
As the original poster pointed out, 200MPH can be achieved with a 200HP
Lycoming, so it sounds like you need an extra 25HP to get there with your
conversion. Not saying the fuel burn will be higher as a result, but it's
quite likely.
-Rob
(Considering the Renesis Rotary engine for my -7, so i'm really not against
auto-conversions... really!)
installation, the drag will be higher on the engine with the radiator due to
the back pressure it generates as air slows down to flow through the rad.
around the rad. I seem to recall reading that on a P-51 in the right cruise
arrangement. But that's some finicky engineering to get the cooling to that
point.
I guess what i'm saying is that if you have an airplane that's designed from
the start to use a water-cooled engine, you can design the airplane to take
advantage of the water cooling and to realize the least drag. But when you
have an airplane that's designed for an air-cooled engine, trying to
> My engine (modestly
> than 10 GPM.
quite likely.
-Rob
copy.
Lycoming, so it sounds >like you need an extra 25HP to get there with your
conversion. Not saying the fuel burn will >be higher as a result, but it's
quite likely.
>-Rob
Rob - I pretty much agree with everything you said - but,
What has not been said on this thread is the highly documented fact that
liquid cooled engines do not require nearly the same amount of fuel as air
cooled engines do per BHP. Air cooled engines require additional fuel to
help cool the engine. I do not believe my 225HP liquid cooled engine will
require 10GPH to operate at 200 MPH like the 200HP Lycoming does. I have a
brand new lycoming 0-360 in my Cherokee and it requires a lot more than 10
GPM at only 155 MPH. But then that airplane is a slug aerodynamically when
compared to the RV's. This is an argument that will go on for years and
years, but Jess Meyers has been flying his GM V6 powered RV6 for about 9
years now with only routine maintenance and I for one am very impressed with
that statistic. Plus I am old hot rod guy that has built many, many race
car and hot rod engines and I have always wanted to build my own car type
engine for an airplane!
Gary Dwinal
copy.
All I can tell you is that when I finally nailed down some builders of
the Eggenfelner Subaru FWF the numbers were as I described.
I honestly think it MAY be possible to design a cooling system (pressure
recovery ducts etc) that will produce close to the same drag as an air
cooled motor, but remember you got 2 to 3 times the flowrate of air in a
water cooled motor than an aircooled unit (in theory)...If true thats a
lot more drag.
One guy built two identical RV 7's the soob did 178mph at 10 GPH and the
Lyc did 200mph.
Once again both our perpestives are purely speculative and builders have
been known to stretch the truth...Heaven forbid!...:)
I wonder how Burt Ruan designed the cooling system for his motor..Is it
not possible it was only designed for say 75% power?...I.e full power on
take off but throttle back before it overheated? He could have
significantly have reduced the cooling drag that way too. Liquid cooled
motors are more evently cooled and can therefore be built with tighter
tolerances which makes them more efficient and reliable. My guess is
Burt was looking for really good economy cruise at reduced power with
exceptional reliabitlity.
Best of luck with your project.
Frank
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Gary Dwinal
the firewall forward package from Belted Air Power. The air intake is
the original size and the radiator is mounted on the firewall with the
original air exit openings. My engine (modestly modified) will produce
around 225 HP and should make the plane cruise comfortably in the 200MPH
range and the fuel burn should be no more than 10 GPM. Again, this is
purely speculation on my behalf, but after talking with several others
that have gone the GM V6 route with the kit from BAP, I think the
assumption that a liquid cooled engine will always create more drag is
controversial at best. There is a reason Burt Rutan absolutely required
one of the engines in his "non-stop around the world airplane" to be
liquid cooled!
Gary Dwinal
RV7A
Similar
less
than 180mph.
part
year
Zenair
attractive
GPH to
My 2 cents
Frank
Don Owens
solely
contain
copy.
From: | Steve Noujaim <nouj(at)compuserve.com> pieces? |
Subject: | Help..."Extra" holes in wing spar stub and F704 |
pieces?
Hi
They are may be either for tooling or for that extra wiring I reckon. You
may wish to check out Dan Checkoways site rvproject.com he has loads of
pictures and its full of handy hints
Subject: | Re: Diesel engine for an RV-7 |
Basic reason for the water cooled Continental on the Voyager was it was
FREE! and they threw in a prop as well.
> original
> HP
> speculation
> V6
> Gary Dwinal
> RV7A
> To: rv7-list(at)matronics.com
> than 180mph.
> part
> to
> My 2 cents
> Frank
> Thanks,
> Don Owens
> solely
> contain
> copy.
Subject: | Re: RV-List: Primer Job looks like Crap... |
I've had generally the same results with the SW primer. The thing is: I
really LIKE the primer. It's hard as nails. I've gone through 3/4 of a
gallon of the stuff and I'm still experimenting with it; and I spent a lot
of time last summer on various HVLP sites to get a good handle on how to use
these things. By the time I did the flap components last fall, they were
better. The problem seemed to be that the product wasn't atomizing enough.
So I turned down the fluid just a bit and turned up the pressure (I think
that's what I did). If you patrol the net for HVLP spray techniques, you'll
probably find a step-by-step to how to set the gun properly. Because the
instructions from Craftsman (maker of the HVLP gun) were crappy.
Also, I made the first pass a "fog coat," rather than try to, you know,
paint the piece. So a little more patience another solution (something I'm
not very good at. I should point out that I tried some of that water based
primer (the name of which I can't remember), and I didn't like the way that
went on either. So that's what sent me to "HVLP school." I figured it was
the painter, not the paint.
What I really go for with SW is a tint more than anything else.
Bob Collins
St. Paul
From: | "Helming, L R & K L" <lhelming(at)sigecom.net> |
There are lots of good primers. Find one that is compatible with the top
coat paint product you want to use. Then learn how to prep, mix and shoot
it.
One primer that works with PPG Concept is DP. DP can be thinned with their
thinner product. Sprays on and covers better using some thinner. The only
thing you might not like is it takes time to dry. But it is tough as just
about anything. Requires the metal to be properly prepared before hand.
For light colored top coats use DP48 as the number indicates the color.
DP40 is an olive drab type color. There are others. Check at your local
auto paint distributor.
Indiana Larry
Subject: RV7-List: Re: RV-List: Primer Job looks like Crap...
Subject: | Lower Rudder Tip |
I am working on the lower rudder tip and the part of the tip forward
of the control horn doesn't sit flat against the spar. There aren't
any attach points noted in the plans here and I was wondering if
anyone else had this problem and what was the remedy.
Scott
www.scottfarner.com
RV-7 Waiting for Wings
Subject: | Re: RV7-List Digest: 1 Msgs - 02/28/05 |
Joe
Sorry to hear that. Now you've got another couple of daily tasks. But I
think you will see a definite improvement in his behavior after he's had
the shots for awhile.
JimL
wrote:
> Online Versions of Today's List Digest Archive
> Today's complete RV7-List Digest can also be found in either of the
> two Web Links listed below. The .html file includes the Digest formatted
> in HTML for viewing with a web browser and features Hyperlinked Indexes
> and Message Navigation. The .txt file includes the plain ASCII version
> of the RV7-List Digest and can be viewed with a generic text editor
> such as Notepad or with a web browser.
> HTML Version:
> http://www.matronics.com/digest/rv7-list/Digest.RV7-List.2005-02-28.html
> Text Version:
> http://www.matronics.com/digest/rv7-list/Digest.RV7-List.2005-02-28.txt
> EMail Version of Today's List Digest Archive
> RV7-List Digest Archive
> Total Messages Posted Mon 02/28/05: 1
> Today's Message Index:
> 1. 08:13 PM - Lower Rudder Tip (Scott Farner)
> ________________________________ Message 1
> From: Scott Farner <sfarner(at)gmail.com>
> Subject: RV7-List: Lower Rudder Tip
> Thanks,
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
Subject: | clearance hole in firewall for nose gear leg bolt (RV-7A) |
Fellow RV-7A builders,
What is the proper size hole to cut in the firewall to gain access to the nose
gear leg bolt. There is a inconsistency in the plans. On the firewall construction
drawing it calls out 3/4" diameter hole and on the nose gear installation
drawing (where the bolt is actually called out) it calls out a 1" diameter
hole.
I don't want to put in a larger hole if it is not required.
Paul (RV-7A fuselage)
Subject: | Re: clearance hole in firewall for nose gear leg bolt (RV-7A) |
hole.
Make the hole slightly larger than the socket needed to fit the bolt
Jim Streit
rv90073
I did not put in a hole in the firewall at all. There was enough clearance.
Chuck Imken
[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Merems
Subject: RV7-List: clearance hole in firewall for nose gear leg bolt (RV-7A)
nose gear leg bolt. There is a inconsistency in the plans. On the firewall
construction drawing it calls out 3/4" diameter hole and on the nose gear
installation drawing (where the bolt is actually called out) it calls out a
1" diameter hole.
Subject: | Nav-Aid Servo Installation |
Does anyone know where I can get some info on installing a Nav-Aid servo in the
right wing.
It looks like it will be a pretty tight installation beside the bellcrank. Skins
are riveted on and yes I should have done it before I did that. Drawings or
pics please????
Larry, RV-7A
From: | "Glenn Brasch" <gbrasch(at)earthlink.net> |
Subject: | Van's Aircraft Belt Buckles For Sale |
I have high quality "Van's Aircraft - Total Performance" belt buckles
for sale. I have also recently updated my site with better pictures, and customer
comments. Please check them out at:
http://home.earthlink.net/~gbrasch/
Thank you, Glenn Brasch, Tucson RV-9A fuselage
Subject: | Paint overspray removal |
I recently spray painted part of my aircraft with an oil based paint.
After I removed the masking, I noticed that there was some paint
overspray on one of the Lexan windows.
Does anyone know how to remove an oil based paint from Lexan?
Subject: | Re: Paint overspray removal |
If your Lexan is coated (like Percy's), it is safe to use xylene, which may remove
the fresh paint. If it is not coated, the xylene may still be ok but I don't
know. You could try it on a scrap first maybe?
Red
Sent: Sunday, April 03, 2005 12:09 PM
Subject: RV7-List: Paint overspray removal
From: | "WILLIAM KELLY" <v1rotate(at)verizon.net> |
Hi,
I've been a silent reader of this site for some time. I've heard from the
Grumman-Gang list that automotive shops use some sort of a clay that when
rubbed on the overspray area will remove the overspray. You might try an
auto supply or local auto paint shop to learn more.
Bill Kelly
Someday (maybe) builder of RV-7A
Grumman AA1C 39065
Lancaster, CA
From: | "LarryRobertHelming" <lhelming(at)sigecom.net> |
Regarding the paint overspray on canopy:
I had some of this. Mine was light in my opinion. It was easily seen
through but it was there. I soaked a cloth in kerosene and laid that on the
area for a few hours and then used my finger nail and a plastic scraper and
was able to carefully and gentlely remove all of it without damage to the
canopy. I had another area on my canopy that I purposely lightly sanded and
thoroughly painted. Later I needed to remove that paint. I used the
sanding, and polishing system sold by ACS. It was a lot of work but it did
the job. I can see a bit of distortion in looking through the glass now
that it is all done.
{Friends are like angels who lift us to our feet
when our wings have trouble remembering how to fly....unknown}
Indiana Larry, RV7 Tip Up
Subject: Re: RV7-List: Paint overspray removal
> Hi,
> Bill Kelly
> Grumman AA1C 39065
> Lancaster, CA
You could try methanol. TEST FIRST. You can cloud up polycarbonite easily.
I would think Acetone would work. I use it to clean my eye glasses.
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of TimUK(at)AOL.com
easily.
I was reading recently in an aviation magazine. I can't remember which one
but I think it was Kitplanes. The three solutions they said not to use were:
Acetone, Lacquer Thinner and window cleaner (which has ammonia in it).
Bill Near
Subject: RE: RV7-List: Paint overspray removal
> easily.
Morning all,
I see there is a choice between a 72 and 74" BA Hartzell prop available
for the 180HP motor.
Anyone have any experience with the larger prop for performance/economy
on the 7?
Frank
LarryRobertHelming
the area for a few hours and then used my finger nail and a plastic
scraper and was able to carefully and gentlely remove all of it without
damage to the canopy. I had another area on my canopy that I purposely
lightly sanded and thoroughly painted. Later I needed to remove that
paint. I used the sanding, and polishing system sold by ACS. It was a
lot of work but it did the job. I can see a bit of distortion in
looking through the glass now that it is all done.
{Friends are like angels who lift us to our feet when our wings have
> Hi,
the
when
an
> Bill Kelly
> Grumman AA1C 39065
> Lancaster, CA
From: | Norman Younie <rv6capt(at)pacificcoast.net> |
The 74" is too long and you will be picking up too many stones etc.
Hinde, Frank George (Corvallis) wrote:
>Morning all,
>on the 7?
>Thanks
>Frank
>LarryRobertHelming
>From: "WILLIAM KELLY" <v1rotate(at)verizon.net>
>To:
>>Hi,
>the
>when
>an
>>Bill Kelly
>>Grumman AA1C 39065
>>Lancaster, CA
Has anyone tried putting an injected CS IO360 C1D6 or C1C in a RV7A? I
remember something about interference with the nose gear or firewall.
Subject: | [Please Read] Matronics Email Server Upgrade... |
Dear Listers,
I will be upgrading the Matronics Email Server this weekend. This includes
some hardware improvements - more memory, faster, more capable processors -
as well as a complete operating system upgrade from scratch. I hope to
have both the old system and the new system running at the same time to
minimize the actual impact of the upgrade.
Hopefully there will be little actual downtime during the transition, but a
few posts may get lost in the shuffle. If you don't see your post show up
on the List in the normal amount of time (plus a little bit), then please
just try posting it again.
Upgrading the Matronics Email Server operating system (from Redhat Linux
7.2 to Redhat Linux WS 4) is a sizeable undertaking and requires a great
deal of work to port all of the utilities, programs, and scripts over to
the new system. As I've already mentioned, both the old and new systems
will be on line at the same time, so interruption should be held to an
absolute minimal. You might see a couple of odd test messages during the
cut-over or other odd messages; please just ignore them.
I have setup a new System Status Web Page that I will use to update List
Members on the current status of the email and web systems. Please refer
to it as often as you like:
http://www.matronics.com/SystemStatus/
Thank you for your continued support of the List Services at
Matronics! Its your yearly Contributions that make these major upgrades
possible!
Best regards,
Subject: | Best location to mount strobe power supply in RV-7/9 |
Fellow RV builders,
I am trying to determine the best location to mount my strobe power supply (central
supply) in my RV-7A. Any thoughts would be helpful. Pros and Cons.
Paul
Paul,
Mine is going right behind the baggage bulkhead. Dan C put his in the same
place. As you are building an A you should have no weight and balance
issues regardless of which engine prop combo you choose. I am using a cs
Hartzell with the 200 hp lycoming.
Don
Fuse.
rv7-list(at)matronics.com; RV7and7A(at)yahoogroups.com
Subject: RV7-List: Best location to mount strobe power supply in RV-7/9
Fellow RV builders,
(central supply) in my RV-7A. Any thoughts would be helpful. Pros and
Cons.
Paul
Subject: | Dual Throttle Control in an RV-7/9 |
Fellow RV-builders,
I really want a left hand throttle control in my RV, but also recognize the advantages
of having a center throttle, mixture, prop control etc. So to solve this
conflict I am designing a dual throttle control in my RV-7A. I would like
to know if any of you fellow builders might be interested in this dual approach.
Please contact me at pmerems(at)experimentalaero.com.
Paul (RV-4/RV-7A fuse)
Subject: | [Please Read] Matronics Email Server Upgrade Complete! |
Dear Listers,
The upgrade of the Matronics Email Server can be considered complete at
this time. All known issues related to the upgrade process have been
resolved and email services are running normal. The Nightly Digest
processing has not yet been tested and will wait for tonight's update.
If you encounter any odd behavior with respect to the Matronics Email
Server over the next few days, please contact me via email at
dralle(at)matronics.com or if that fails try dralle(at)speakeasy.net.
Thanks to everyone for being patient through this arduous process of a
major system upgrade!
Email List Administrator
At 12:37 PM 4/16/2005 Saturday, Matt Dralle wrote:
>Dear Listers,
>includes some hardware improvements - more memory, faster, more capable
>processors - as well as a complete operating system upgrade from
>scratch. I hope to have both the old system and the new system running at
>the same time to minimize the actual impact of the upgrade.
>a few posts may get lost in the shuffle. If you don't see your post show
>up on the List in the normal amount of time (plus a little bit), then
>please just try posting it again.
>possible!
>Best regards,
>Matt Dralle
>Matronics Email List Administrator
Anyone out there install heated seats in there rv 8. I am looking for
supplier and recommendations.
Thanks, Ed Clegg
There was an RV8 at SnF (quite colorful and nicely done) that had heated
seats. Don't remember the N number or owner name. Someone else might
remember.
James
| server(at)matronics.com] On Behalf Of ed clegg
| Sent: Wednesday, April 20, 2005 10:34 AM
| To: RV-8(at)yahoogroups.com; rv7-list(at)matronics.com
| Subject: RV7-List: heated seats
| Thanks, Ed Clegg
Subject: | getting started` |
Hello rv7 list,
I just filled out your membership application, aka rv7 empennage order form.
My form is still enroute to Oregon with the Van's crew taking their sweet
time flying back from Sun-n-Fun. Who can blame them? The folks at Cleveland
tools were quick to ship my first batch of tools, so my shop now has some
strange new tools in it. Waiting on metal...
No questions yet. Visit me on the web if you like.
http://donka.net/gallery/view_album.php?set_albumName=rv7log
Don Hall
From: | "Cory Emberson" <bootless(at)earthlink.net> |
Subject: | Dan Checkoway's Panel in June Kitplanes Magazine |
Hello, all!
I just got my June issue of Kitplanes Magazine, and lo and behold, there is
Dan Checkoway's RV-7 panel in former RV-8'er Ken Balch's panel article!
Well done!
best, Cory
Subject: | [ Mike Holland ] : New Email List Photo Share Available! |
From: | Email List Photo Shares <pictures(at)matronics.com> |
A new Email List Photo Share is available:
Poster: Mike Holland
Lists: RV-List,RV6-List,RV7-List,RV8-List,RV9-List,RV10-List
Subject: Quickbuild Fuel Pickup Issue
http://www.matronics.com/photoshare/hollandm@pacbell.net.05.02.2005/index.html
o Main Photo Share Index
o Submitting a Photo Share
If you wish to submit a Photo Share of your own, please include the
following information along with your email message and files:
2) Your Full Name:
3) Your Email Address:
Email the information above and your files and photos to:
Subject: | Re: Trailing edge silicone |
OK I'm new to this game (the list) and here goes with my first ever post. My
name is Rick Rammos, from Miami, FL, and I'm in the process of slowly
building an RV-7A. I'm approaching completion on the tail and have made what I
think
is a minor mistake, but I'm not sure. Before closing the right elevator the
instructions say to but a dab if Permatex or similar product between the
stiffeners at the trailing edge. oops. Of course I went out and bought the stuff
but sealed up the elevator without it. I can't imagine drilling out all those
rivets for this and thought of drilling the lower rivets at the back
stiffener, injecting some silicone and then closing with a blind rivet. Is this
overkill? Should I just forget it? At this early stage I hate to start taking
short cuts but I do want to be realistic if this project is going to progress.
So
what of it guys, any comments?
Rick R
RV-7A
Miami
From: | Charlie England <ceengland(at)bellsouth.net> |
I think
So
>Rick R
>RV-7A
>Miami
I closed one of mine before remembering the sealant, too.
It's more trouble, but you can use small diameter tubing to inject the
sealant. The semi-rigid translucent stuff from the hardware store
(tygon?) comes in a size that will just slide up the trailing edge.
Force a little into the end, thread it in to the right distance & force
the sealant out slowly with low pressure air.
Subject: | F-705G - Tip up canopy only ... ? |
I know these angles are required for the tip-up canopy and I'm
fairly sure should be ommited completely for the slider canopy,
but wanted to check with others ... can anyone confirm ?
__g__
Gerry Filby gerf(at)gerf.com
Tel: 415 203 9177
Subject: | Re: F-705G - Tip up canopy only ... ? |
One of the guys at Vans told me to just leave them in since I had already installed
them. What a pain to remove them later when it became apparent that they
caused interference with the bolts for the rear canopy hold down blocks.
Bob Thaxton RV-7 N711RT
> __g__
>Van==========================================================
> Tel: 415 203 9177
-- RV7-List message posted by: Gerry Filby
__g__
Tel: 415 203 9177
Oh great. I got a quickbuild and they're still in my fuselage. I've painted
now as well.
Mark Taylor
www.4sierratango.com
>From: ramthaxton(at)comcast.net
>Reply-To: rv7-list(at)matronics.com
>Subject: Re: RV7-List: F-705G - Tip up canopy only ... ?
>Date: Fri, 13 May 2005 01:27:22 +0000
>installed them. What a pain to remove them later when it became apparent
>that they caused interference with the bolts for the rear canopy hold down
>blocks.
> > __g__
> > Tel: 415 203 9177
>blocks.
> __g__
> Tel: 415 203 9177
Hi All,
According to GAMI the IO360 can run premium autofuel and they recommend
the following.
Based presumably on the testing they have done with their new PRISM
ignition system that adjusts the spark timing and measures the crank
angle where the max cylinder pressure occurs....Apparently this point is
16 deg ATDC.
For the first time we are on the cusp of having the timing being
adjusted based on what the engine is actually doing...its a bit like a
highly advanced knoock sensor found on auto engines.
By this time you should be saying WOW!
The great thing is you can almost throw any fuel in it you want (as long
as it does not pre-ignite)...If it detontates the Prism will presumably
retard the ignition until it stops.
But I digress...They say to keep CHT's down to 375F or less. And then
run at 100F ROP or 25 to 50 LOP.
So there you have it...They believe these are conservative numbers.
Frank
I'm looking to buy either an RV-7A or a RV-9A, does anyone know of any
that are for sale or will be for sale in the next 24 months?
--> RV7-List message posted by: "Cliff Lotter"
Have you forgotten about vapour-lock?
Cliff Lotter
Subject: RE: RV7-List: Autofuel
> --> RV7-List message posted by: "Hinde, Frank George (Corvallis)"
> Hi All,
> the following.
> 16 deg ATDC.
> Frank
Nope...And I am not opening all this up again.
But with a PROPERLY designed fuel system the only place vapour will be
an issue will be in the injector lines....This should be be more in the
"annoyance" level rather than the life threatening Vapour lock that can
happen when the fuel pump is not in the correct place...Hydraulically
speaking.
Note there are many auto conversions flying around without VL
issues...But look where there fuel pumps are...Very different to the
standard Lycoming setup...I'm simply replicating this on a Lycoming.
Frank
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Cliff Lotter
Subject: Re: RV7-List: Autofuel
Cliff Lotter
> Hi All,
> recommend the following.
> is
> 16 deg ATDC.
> long as it does not pre-ignite)...If it detontates the Prism will
> presumably retard the ignition until it stops.
> Frank
From: | Bob Collins <bcollins747_1999(at)yahoo.com> |
Subject: | Corner rib center fuselage question |
--> RV7-List message posted by: Bob Collins
I 've stared at the plans and viewed the Web sites
and I'm not convinced I'm seeing things right on
trimming the corner rib (I think it's F-723) forward
part where it mates with the 705 bulkhead.
On the drawings, it appears to show that both forward
flanges are trimmed maybe 3/4 of an inch or so and
tapered aft. This would appear to include the little
joggle section of the outboard flange. However the
fact there's a joggle there tells me that it's there
for a reason and that reason is not to cut it off.
However, in fitting the rib to be flush with the
outboard edge of the bottom skin, that flange --
whether it gets tucked inside the 705L flange or put
to the outside of that 705L flange (which I assume it
doesn't because that would put a nice bump in the
skin), pushes the rib inboard from the corner edge of
the bottom skin slightly. You couldn't get it flush.
So the instruction say get it flush with the botom
skin, best done if that front of the flange of the
corner rib is gone.
However I've seen at least one Web site in which it
was the inboard side of the flange that got cut away
(and not tapered, either) while the outboard side
(with the joggle) stayed as presented. And THAT
confuses me too, because that flange doesn't appear to
be interfering with anything.
As many have noted, the plans are very vague here, and
I'm sitting here with a drill and snips ready to go.
so hurry up and put me on the right track ! (g)
Bob Collins
St. Paul, Minn
Stay in touch with email, IM, photo sharing and more. Check it out!
http://discover.yahoo.com/stayintouch.html
From: | "Bob Collins" <bcollinsrv7a(at)comcast.net> |
Subject: | Re: Corner rib center fuselage question |
--> RV7-List message posted by: "Bob Collins"
Ok, let me answer my own question here for purposes of the archives. Maybe
it'll help someone else. After looking at the plans again and after fitting
the piece (the corner rib), it is clear that what the plans are showing is
correct. BOTH the web of the corner rib (at least the front portion and I
suspect the aft portion too) and the inside flange of the corner rib have to
get cut off. This is counter to some of the stuff I read on a few builders
sites.
Here's why:
It's obvious when you fit the piece that this is done for two reasons.
First, if you don't cut the front portion of the flange off, you can't
align the edge of the corner rib to be properly flush with the edge on the
bottom center section skin. What's more, if you leave the flange on, you
cannot properly fit the F-723A piece onto the Web of the corner rib.
Now the web portion gets cut off because if you don't, it will go up and
over the flange on the bulkhead, leaving a small gap between the skin and
the bottom of the corner rib. And if you look at the other ribs next to it,
you can see how they've addressed that. Then, using the F23A allows a flush
mating with the corner rib and the bulkhead here, allowing the skin to rest
evenly across the bulkhead and the corner rib.
Many have noted -- correctly -- that the plans aren't very clear in this
regard. First, they show up and forward, but they don't show inboard and
outboard. Secondly, a top view of this piece would've eliminated any
confusion.
But maybe nobody else was confused in the first place. (g)
Ping to all active RV projects in the Atlanta area. If you're interested in
networking locally, please reply.
Don Hall
N517DG
RV7 - empennage
http://donka.net/rv7project.html
Subject: | wire gauge drill bits |
I bought a "rv empennage tool kit", which supposedly has all you *need* to
build the tail. (Like all you need to build a house is a hammer and saw.)
I was pretty disappointed with the kit when I immediately ran into
instructions calling for #12 and #19 drill bits. Not in the kit, and
apparently not at your average hardware store.
I'm curious whether anyone is knows if any brick and mortar hardware stores
sell drill bits in wire gauge sizes. I was surprised that Home Depot didn't
stock such bits. I ended up ordering online from Cummins.
I've already ordered this:
http://www.cumminstools.com/browse.cfm/4,621.html
$49.99 USD / Each
115pc High Speed Steel Titanium Coated Drill Bit Set
Power Tools / Drills / Drill Bits & Accessories
High speed titanium coated drill bits
60 pc. wire guage bits numbered 1 to 60
26 pc. lettered bits (A-Z)
29 pc. fractional bits 1/16" to 1/2" in 1/64" increments
One metal index box
Interestingly, Sears had this
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&p
id=00967115000
$219.99
Craftsman 115 pc. Drill Bit Set, High Speed Steel, Black Oxide Twist
Sears item #00967115000 Mfr. model #67115
These high speed steel bits are hardened, heat-treated and tempered for
long-lasting strength. Precision-ground process ensures accurate geometry
and hole size, and fast material removal. Learn more
Subject: | Re: wire gauge drill bits |
$22.99 from Harbor Freight:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=528
I personally don't have a full wire gauge set. I just buy individual bits
from Brown or whatever. They're relatively cheap. #40, #30, #27, #19, #12,
#11, #10, and 1/4" are just about all you're gonna need. Then your run of
the mill 1/8", and 3/32" will be useful for undersize drilling stuff.
#40 for 3/32" rivet
#30 for 1/8" rivet
#27 for 5/32" rivets or #6 screws
#19 for #8 screws
#12-10 for #10 or 3/16" fasteners (#12 for tight fit, #10 for clearance fit)
1/4" for 1/4"
You may also want to snag a chucking reamer in 1/4" for stuff like bellcrank
and control column bushings, and when you get around to working on the
baffles, 13/64" and 17/64" reamers will be helpful for slightly oversizing
the 3/16" and 1/4" holes to reduce stress (as per Van's recommendation).
)_( Dan
RV-7 N714D
http://www.rvproject.com
Subject: RV7-List: wire gauge drill bits
stores
didn't
> $49.99 USD / Each
> One metal index box
> id=00967115000
> $219.99
http://www.kbctools.com
I buy tools and perishables (drills and mills) from
them. Wholesaler that deals to the public.
> Not in the kit, and
> Cummins.
> $49.99 USD / Each
> increments
> One metal index box
> id=00967115000
> $219.99
> Black Oxide Twist
> browse
> Subscriptions page,
> FAQ,
Have fun online with music videos, cool games, IM and more. Check it out!
http://discover.yahoo.com/online.html
From: | "Jamie Painter" <jdpainter(at)jpainter.org> |
Hey Don:
Where are you located?
I live in Suwanee, fly out of LZU. I'm building a -7A and am now into the aft
fuselage. Are you invovled in an EAA chapter? I'm chairman of the Board of
Directors for 690 at LZU. We have 6 RV's in our 'Sport Aviation Complex' and
many more on the way. Let's see...I'm probably forgetting some...but we have
my -7A, a -7, two -8's and two -9's currently under construction. Our chapter
is a great way to meet RV'ers. See my .sig for my website.
Good luck on your project.
- Jamie
> Don Hall
> N517DG
> RV7 - empennage
Jamie D. Painter
RV-7A fuselage N622JP (reserved)
http://rv.jpainter.org
Find a hardware store that serves contractors (especially electrical) and
construction folks and they will have the drill bits.
stores
didn't
Morning all,
A note of caution for you all...in other words don't do what I did!
The QB kit I find lulls you into a false sense of security in that one
tends to ASSUME all the holes are in the right place...When it came to
the engine mount I found the pilot holes they conveniently drill in the
4 corners firewall are not THAT convenient.
I can feel you cringing as I write this...YUP I opened them up to size
without having the engine mount in place...Even though the instructions
tell you the reason the holes are undersized is to allow for error in
hole placement.
It turned out the top holes were perfect (thankfully) and had I just
drilled these out to size, hung the mount and drilled the 4 bottom holes
thru the engine mount life would have been good.
But no,I just blindly opened them all up to size without the mount in
place...Arrrgh!
I then had to drill out the rivets holding the bottom corner weldments
and the angle that runs vertically btween the top and bottom weldments
in order to get the bottom ones out.
As the weldments are match drilled to the airframe it looked just as
easy to stip the paint off, weld a 1/8th thick 4130 plate over the
3/8ths holes and repaint....Plus it saved the cost and waiting for the
new parts.
Which is what I did and I will rivet the weldments back in the fuse this
evening....And then drill the lower mount holes like I should have done
in the first place!
In the end about 4 hours work total that had absolutly no need to be
done if I had been more careful...The joke of it was I would NEVER have
done this on my previous airplane cus absolutly nothing was pre-drilled.
Maybe I now only saved 996 hours vs building a slow build kit...:)
Live and learn I hope!
Frank
I bought a bunch of #30 and #40bits from the one of the large internet
dealers (work out to about a buck per bit with shipping) and the Harbor
Freight 115 pc set for all the other sizes.
Incidently...Am I the only one that went thru about 4 bits to drill the
holes in the axles for the cotter pins?
Frank
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Bob Collins
Subject: RE: RV7-List: wire gauge drill bits
and construction folks and they will have the drill bits.
stores
didn't
One last point on drill sizes - the plans call-out for a .311 drill bit
to match drill the gear legs to the gear mount box on my RV7A did not
show up on any of my conversion charts and that size turned out to be a
custom Metric drill bit size 7.9MM. Cost me $8 Canadian from industrial
supply place to make those holes 1.5 thousands smaller than the optional
5/16 size.
George in Langley BC
I read with great interest this thread and felt that a reply would now
be necessary. I just don't understand the difference between a drilled
hole that is drilled with the .311 dia bit vs the hole drilled with a
.3125 (5/16) bit when the standard tolerance for a drilled hole made
using a standard twist drill bit is + or - .005. this is the tolerance
listed for drilled holes in aluminum in both the Reference Manual for
Mechanical Engineers, and the ASTM Standards Manual
Tyler Bryant N442TJ
>5/16 size.
>Cheers,
Subject: | Drills vs reamers |
That's easy...When I went to drill one of my weldments with a drill bit
it was jumping around a bit and did not exactly give the most pretty
hole I have ever seen....Kinda hard to hold everything in line with a
relatively large drill bit and the drill wants to remove too much metal
too quickly
I finished the hole off with 3120 reamer and it was a much better
finish...I would have bought a new weldment except I had a perfect hole
on one side and finally decided the not quite so good hole was not going
to be a problem operationally. Reamers remove much less metal and the
amount they remove depends on how hard you push on them....Actually I
pull mine through the gear legs as it helps keep everything lined up
I did have a fleeting thought about weling a plate over it and
re-drilling...But as I said it will be OK...just not perfect.
Bottom line, when the plans say "ream"...I borrow a reamer from work and
make life a lot less stressful..:)
Frank
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of TylerB
Subject: Re: RV7-List: wire gauge drill bits
Tyler Bryant N442TJ
Subject: | Rotary engine Seminar May 27-29 |
1.30 UNDISC_RECIPS Valid-looking To "undisclosed-recipients"
For those interested in rotary engine power for aircraft, there will be
a rotary event here at Slobovia Outernational (MS71) just north of
Jackson MS beginning Friday afternoon, May 27. If you are driving to
Jackson a brochure & map of how to get here can be found on Tracy
Crook's web site at http://www.rotaryaviation.com/new_page_3.htm.
Flying info can be found at http://www.airnav.com/airport/MS71.
'Scheduled to Appear,' either with presentations or to be available for
Q&A are several folks who are already flying or manufacture & sell
accessories for rotary conversions:
Ed Anderson
Tracy Crook
Bill Eslick
Bernie Kerr
Ed Klepeis
We've got plenty of space in the house and a couple of our neighbors
have offered hangar apartments for additional lodging. Just throw a
bedroll & towel (& tent if you if you prefer) in the car/plane & we will
find a place for you to sleep.
Spouses are welcome; it's looking like they may have more fun than us
rotorheads. Possible activities include antiquing/sightseeing in a
historic town near Slobovia.
If you are thinking about coming, drop me a line at
ceengland(at)bellsouth.net or call at 601-879-9596 so we can be sure no one
goes hungry. :-)
Tupper's having the time of her life getting the house & meals prepped,
& I've got a clean hangar for the 1st time in almost a decade. Ya'll Come!
Charlie & Tupper
Subject: | FW: flop tube quick build |
Date: Mon, 23 May 2005 23:08:52 -0600
Subject: flop tube quick build
When installing the trap door in the aft rib of the left fuel tank Does
the lightning hole in the rib also need to be plugged? It seems to me that
if you were flying on a knife edge left wing down that the trap door would
do no good if the other hole remained open. Also any recommendations on wing
tip landing light, nav and strobe configuration would be a big help?
RV-7 Quick build Massachusetts
Subject: | flop tuge Qbuild |
From: | "Frank Eldridge" <eldridge(at)legis.state.ga.us> |
Subject: | Re: Rotary engine Seminar May 27-29 1.30 |
Please remove my email address from your list. I do not care to receive
these emails.
Thank you for your assistance in this matter.
Frank Eldridge, Jr.
Subject: | Removal from RV-List |
Only you can remove yourself from the list. Please go to the Matronics
webpage linked in the signature below and unsubscribe your email address
manually.
-Rob (not a list administrator, just someone trying to help)
On 11:23:10 2005-05-25 "Frank Eldridge" wrote:
> .ga.us>
> receive these emails.
> Frank Eldridge, Jr.
on hestia
I bought one of those cheap crappy Chinese drill bit sets once. It's a big
waste of time & money. Anything under $100 is Chinese and thus crap. Many
of the larger drill bits are not even straight. The smaller ones have
varying degrees of sharpness. If you're going to get a full drill bit set,
get a US made one from MSC. You'll spend a couple hundred on a decent one,
but you'll have something that's worth your money.. If you just want a few
sizes for the plane, like 12 & 19, your best bet is get them from Avery.
They have good US-made ones. The price of the Sears one tells me it might
be US made, but be sure to check first - Sears tools are DEFINTELY not what
they once were.
brian
http://brian76.mystarband.net/RV-7Ahome.htm
[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Don Hall
$49.99 USD / Each
One metal index box
id=00967115000
$219.99
on hestia
I bought one of those, too, but then I realized it's better to drill smaller
and use a reamer for the final exact size. MSC has reamers of every
imaginable diameter, as well as super-fast delivery and excellent customer
service.
http://www1.mscdirect.com/cgi/nnsrhm
brian
[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of GMC
5/16 size.
on andromeda
Did you use Harbor Freight drill bits to do it?
[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Hinde, Frank George
(Corvallis)
Frank
stores
didn't
Titanium bits are gold colored and very pretty. They have a titanium
nitrite (nitrate? something like that) coating that has nonstick
properties. When you replace bits, don't bother buying the titanium bits
for smaller diameters. Just buy standard bits and save money. The
titanium coating reduces wear and I tend to break bits that small before
wearing them out.
Too bad we don't have Costco in the midwest, I would grab one of these
sets.
MG
Herron, Al wrote:
>I picked up a set of numbered drill bits from Costco recently (this was in
>Northern California) for about $40 US. Size ranged from very small (#60?)
>up to about 1/2-inch in single-number increments, came in a nice metal case
>with all the bits labeled both in index numbers and decimal equivalents.
>Packaging claimed to be titanium bits, I was skeptical at that price but
>they turned out to be very nice bits. The box alone was probably worth the
>price.
I seem to remember that the plans say to plug the hole BUT I also seem to
remember someone recently saying that Van's had said not to block the hole
because it will make filling the tank very slow. I don't know but if I
were to do it again, I think I would block the hole and enlarge/make a new
hole for air higher up the rib. When I did mine, I put in the flapper
valve and left the hole alone. Now that I think about it, I think I made
that decision based on discussions with someone at Vans.
I'm not planning for aerobatics and didn't put the flop tube in, just the
flappers because I like to slip on short final. Not flying yet so YMMV.
Bevan
-----Original Message-----
Subject: RV7-List: flop tuge Qbuild
wing
Subject: | Wing remove/re-attach. |
From: | "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com> |
Hi all,...I was just in an IM conversation about the above and thought I
would re-post here in case it helps someone.
I made what is (according to Van's) the classic mistake...I forgot to
trim the rear spar wing attach points before I had all my remaining
friends help me install the wings. This resulted in a 1 1/4" forward
sweep...Now personally I think the Extra 300 looks kinda cool but RV's
are not supposed to do that!
So now all my friends are at work on my day off so how do I get the
wings on and off by myself?...See what I did below...
Frank
RV-7A...It Looks like an airplane!
Actually its pretty easy after you got past the out burst of emotion
that you screwed up!
Made a sling (old climbing rope) to hold the root of the wing..suspended
from roof rafters
old office chair on casters secured to tip of wing (no tip installed)
Using a ratchet strap thru end rib holes round back of chair...Chair is
really good cus it is height adjustable to line up the dihedral!
undo bolts...pull...wing root drops into sling
sweet
Up onto sawhorses...One end at a time...:)
Reverse to re-install
easy!
Actually after I done it twice I realised it really is very safe.....as
long as the sling holds
I made mine adjustable by using a ratchet strap in the middle of the
rope...That way you can micro adjust the height for re-insertion
Subject: | F-623 Baggage Compt Corner Ribs |
Scratchin' my head once again ...
The plans seem to indicate that the edge of the F-623 baggage
corner rib abuts the edge of the lower flange of the F-705A
bulkhead channel ... then the F-623A attach strip overlaps and
connects the two. But when I lay out the parts like this the
apex of the rib's 'triangle' doesn't line up with the similar
apex along the edge of the F-976 skin and the aft end of the
rib protrudes beyond the line joining the ends of the adjascent
ribs. It just doesn't look right. Furthermore the forward end
of the rib outboard flange is factory shaped such that it might
overlap on the inside of the flange of the F-705D bulkhead
verticle channel - a single rivet passing through the skin, the
bulkhead flange and then the rib flange. (Confused yet ? I am.)
The only solution I can see is to trim away part of the forward
web and inboard flange of the rib - but I don't see any note of
this in the plans or instructions. Anyone got any insight into
this ?
__g__
Tel: 415 203 9177
Gerry:
I just did the same part the other day and that joggle confused me because
it suggests the flange fits inside the bulkhead flange. But if you do that,
you can't get the edge of the corner rib to line up flush with the bottom
skin, although I have seen some Web sites that have suggested cutting aroudn
etc.
Don't bother.
Hack it off. The two flanges, the web,etc whee it meets the flange of the
side of the bulkhead and the top. Front and back (I left the back intact
until we mated the center and aft section on Thursday and then it was much
easier to see why you have to do the same to the rear section.
It takes awhile to see this on the plans. They really needed a zoomed-in
overhead shot here.
Disclaimer: I see you posted this to both the 9 and 7 groups. I'm building a
7. I have no idea if the situation is the same with the 9.
St. Paul
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Gerry Filby
Subject: RV7-List: F-623 Baggage Compt Corner Ribs
Subject: | Re: F-623 Baggage Compt Corner Ribs |
You're right, if you keep the joggle portion of the Web, it won't sit perfectly
flush at the forward portion of the skin. But it might be close enough. However,
I suspect that the fact it won't, is the reason Van's drawings show the entire
forward part getting hacked off.
The inclusion of the joggle, however, might lead one to conclude that they want
the flange mated with the bulkhead, but the plans themselves don't show that,
which is why I just hacked it off.
I doubt there's an ounce of difference structurally and I chose to cut it off --
aside from the fact that's what the plans said -- to get a perfectly flush fit.
> Thanks Jamie ... very useful pictures.
> The think I'm concerned with is that if I don't trim away the
> forward part of the flange and web of the rib it won't sit
> flush against the bottom skin as it approaches the lower web of
> the 705 bulkhead.
> I'm probably "over engineering" this and should just go ahead
> and make a decision ...
> g
the 705 bulkhead.
g
Interesting that one list member sent me a pic offline of this
area in his quick build fuse - appears that Van's doesn't trim
the front end off and just lets the web of the rib ride up over
the flange of the bulkhead. I guess they don't worry about the
rib not being flush with the skin. When I say Van's - I mean
whoever the contractor is that builds the quickbuilds for them
g
> won't sit perfectly flush at the forward portion of the skin.
> But it might be close enough. However, I suspect that the fact
> it won't, is the reason Van's drawings show the entire forward
> conclude that they want the flange mated with the bulkhead, but
> the plans themselves don't show that, which is why I just
> hacked it off.
> > the 705 bulkhead.
> > g
> hacked it off.
> the 705 bulkhead.
> g
__g__
Tel: 415 203 9177
Subject: | ready to order wing kit |
Not done with the tail yet, but with a 12-week lead time...
So - the only choice from Van's when ordering a wing kit is the fuel sender.
I'm going with capactive.
What else should I be thinking about or buying along with the wing kit?
IOW, When should I worry about selecting lights, autopilot etc?
(It'd be great if I discover that the wing plans have giant red sticky notes
like "Whoa! go buy an auto-pilot servo right now before closing in this
part"?)
I want: strobes, ifr, autopilot, etc.
I think I might want: tip landing lights (attracted to simplicity), trutrak,
AOA indicator...
Subject: | Re: ready to order wing kit |
Well if you are a big wuss like I am, the only other option you have
to think about is getting pre-built fuel tanks. I've seen autopilot
installations in the wing, but you can also mount it in the fuselage.
Any thing like lights, strobes and such that will be mounted on the
tip can wait until later (in fact the plans mention to put off wing
tip installation). The only thing to worry about during construction
is for these items is wiring runs. I can't remember if the plans
mention it, but it is best done before the ribs are riveted. If you go
for a heated pitot, installation will be near the end of wing
construction (depending on which wing you start with) before the
bottom skins are riveted.
Scott
www.scottfarner.com
RV-7A Waiting for Fuselage
> part"?)
> AOA indicator...
I used Duckworks lights and an Aero instrument heated pitot. I also
installed the trutrack servo in the wing.I found it worthwhile to have these
tinmgs on hand before building the wing.
Don
RV7
Finish Kit
Subject: RV7-List: ready to order wing kit
part"?)
AOA indicator...
Some autopilot manufacturers, such as TruTrak, will sell or give you the
servo brackets without having to buy a system -- they figure you're gonna be
a customer if they give you the brackets. Good marketing, and good sense.
If you have a choice, install the TruTrak aileron servo bracket when you
build the wing spar. It's no big thing to install it later, but you'd save
time by doing it up front.
While you're planning, consider the THREE wiring runs which don't really go
in the normal root-to-tip conduit...
1) Autopilot servo
2) Pitot heat
3) OAT sensor
As tempting as it is to put the OAT sensor in the NACA vent like so many RVs
out there have done, don't do it if you have the choice. The reading will
not be perfectly accurate there...hot air escapes the sides of the cowling
right in front of it. An OAT sensor belongs out on the bottom of the wing.
If it's not going to be accurate, why bother?!
Anyway, for these three wiring runs, just consider installing additional
snap bushings or grommets. Everything else (antennas, strobes, position
lights, landing lights, cameras) can be wired through the conduit. Yes,
strobe wires & antenna wires can be run together.
I don't recommend running the wires now, just start thinking about where
they will run.
Hope this helps,
)_( Dan
RV-7 N714D
----- Original Message -----
sender.
notes
> part"?)
trutrak,
> AOA indicator...
>1) Autopilot servo
>2) Pitot heat
>3) OAT sensor
>they will run.
>Hope this helps,
>)_( Dan
>RV-7 N714D
>From: "Don Hall" <dhall(at)donka.net>
>To:
>sender.
>notes
>>part"?)
>trutrak,
>>AOA indicator...
I see guys mounting the autopilot servo in the wing and some mounting it
in the fuselage. What's the difference?
On the -7, the "standard" TruTrak installation is in the wing. On the -6
and -8 the standard installation is under the seat pan.
The idea is to create an isolated system, where roll inputs won't affect
pitch (i.e. "pitch bump"), and vice versa. On the -8, you can get away with
isolation with the servo in the fuselage because of the control column
design. On the-7, you can't. And on the -6, they went for the path of
least resistance.
Talk to Jim at TruTrak if you have any questions about this.
)_( Dan
RV-7 N714D
Don, with the way things are changing, I would wait for buying the AP
because there is good odds there will be something better/cheaper/improved
in the next 12 months. FWIW, I installed the tru trac AP, landing lights,
strobes, and position lights after my wings where finished. You will want
to install conduit for running wires before you close up the wing however.
I had not yet painted the wings when I put the Duckworth landing lights in.
I would rethink the landing lights and look at the wing tip type if I were
doing it again. However, Duckworth are ok and it leaves more room for the
position and strobes in the tips.
Indiana Larry, RV7 Tip Up It Flies
> sender.
Just wanted to get the brands spelled correctly for the builder who's
reading the archive...
tru trac = TruTrak http://www.trutrakflightsystems.com
Duckworth = Duckworks http://www.duckworksaviation.com
)_( Dan
RV-7 N714D
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: Re: RV7-List: ready to order wing kit
in.
> > sender.
From: | "David E. Nelson" <david.nelson(at)pobox.com> |
Subject: | Fitting/aligning the flaps/ailerons |
15, 2004) at 06/06/2005 08:06:07 AM,
Serialize by Router on MailServ58-US/AUS/H/NIC(Release 6.5.3FP1|December
15, 2004) at
06/06/2005 08:06:09 AM,
Serialize complete at 06/06/2005 08:06:09 AM
Hi All,
Got the right aileron on this weekend and scratched my head about attaching the
flap. The plans call out for 1/4" spacing between the flap/aileron and
aileron/wing-tip. So I placed the wing-tip on the wing only to discover that a
lot of sanding needs to occur on the wing-tip to achieve the 1/4" spacing. Is
there a better reference that I can measure to/from to adjust the
inboard/outboard positions of the flap/aileron?
If possible, I'd like to move the aileron inboard by one washer thickness to
avoid a slight binding between the push rod and the rear spar. I could dremel
out the hole a little bit more but I'd rather not if at all possible.
Thoughts?
And finally, I've already dimpled the bottom wing skins and the flap brace
causing my #40 holes to no longer be #40. So how do I accurately drill the
flap hinge so that the rivets will fall into place?
/\/elson
RV-7A Wings - Flaps and Ailerons
Austin, TX
Subject: | Fitting/aligning the flaps/ailerons 15, 2004) at 06/06/2005 |
08:06:07 AM, Serialize by Router on MailServ58-US/AUS/H/NIC(Release
6.5.3FP1|December 15, 2004) at 06/06/2005 08:06:09 AM, Serialize complete
Hello David...It was about 3 weeks ago that I got to this very
point...and made the very same mistake except I actually rivitted the
rear lower skin to the flap brace WITHOUT installing the flap
hinge...DOH!
The answer to the hinge dilemma is "very carefully", that is very
carefully clamp the hinge on the bottom of the wing skin with the flap
attatched to the hinge....the rear edge of the flap and the aileron need
to line up with the aileron clamped in the neutral position (piece of
angle clamped to the outboard rib and clecoe type clamp on the aileron
weldment will hold it firmly in place). Then slide the wing towards you
so that you can drill from the top side and fully rotate the flap
upwards to allow access for the drill..Spot drill with a larger than #40
drill bit in about 6 locations along the hinge.
Remove everything...drill the spots out to #40 and fit the hinge as
normal...On both of mine I found I had to shim the aileron out about one
thin washers worth under each of the weldments...alignment is now
perfect.
However I have told you all this in reverse...First you have to position
the flap aileron laterally.
First off the reference is the aileron itself...My reference was the two
washers shown on the outboard hinge...always put these in there when
trial fitting, make the spacer on the other end to suit. That sets the
lateral reference...Now your flap needs to be set 3/16ths to 1/4" from
thes edge of the aileron.
Yes there will be sanding (cutting with the flexiglass disc provided for
the canopy works well) on the tip to get the clearance...If you think
about it there has to be, no way round it.
Frank
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of David E.
Nelson
Subject: RV7-List: Fitting/aligning the flaps/ailerons 15, 2004) at
06/06/2005 08:06:07 AM, Serialize by Router on
MailServ58-US/AUS/H/NIC(Release 6.5.3FP1|December 15, 2004) at
06/06/2005 08:06:09 AM, Serialize complete at 06/06/2005 08:06:09 AM
Hi All,
attaching the flap. The plans call out for 1/4" spacing between the
flap/aileron and aileron/wing-tip. So I placed the wing-tip on the wing
only to discover that a lot of sanding needs to occur on the wing-tip to
achieve the 1/4" spacing. Is there a better reference that I can
measure to/from to adjust the inboard/outboard positions of the
flap/aileron?
thickness to avoid a slight binding between the push rod and the rear
spar. I could dremel out the hole a little bit more but I'd rather not
if at all possible.
Thoughts?
brace causing my #40 holes to no longer be #40. So how do I accurately
drill the flap hinge so that the rivets will fall into place?
Subject: | Re: Fitting/aligning the flaps/ailerons 15, 2004) at 06/06/2005 |
Center the aileron brackets as best you can. That's a good starting point.
In other words, try to get the powder coated brackets on the ailerons as
centered as possible over the aluminum bearing brackets on the wings.
Record (write down, photograph, whatever) the combination of washers you
used to achieve that centering...you will want to use that same combination
going forward.
Once the aileron is where you want it, let that be the reference for all
else.
Install the flap to achieve proper spacing from the aileron, and trim or
file the inboard edge of the flap to achieve spacing from the fuselage.
That gap can be a little tighter. Mine almost contacts (it did contact on
my early flights, filed it back a bit).
Next install the wing tip. Yes, the flange comes "oversized" and the aft
end definitely extends inboard too far. You will have to trim this. Trim
it so that when the wing tip is positioned, you have proper spacing between
it and your aileron.
Yes, you will most likely have the wing tip trailing edge extending aft past
the aileron trailing edge. This is common. And the wing tip trailing edge
might not be perfectly in trail with the aileron when the aileron is rigged
& centered (use the bellcrank rigging tool here to hold it rigid). You can
trim the wing tip trailing edge, and you can slice open its edge and then
re-epoxy it where you want it.
My advice is to RIG THE AILERONS, and then match the flap & wing tip to the
aileron, NOT vice versa!
On the flap hinge, just do your best to center everything. You were
supposed to countersink, not dimple, the flap brace. I made the same
mistake.
)_( Dan
RV-7 N714D (500+ hours)
From: "David E. Nelson" <david.nelson(at)pobox.com>
MailServ58-US/AUS/H/NIC(Release 6.5.3FP1|December 15, 2004) at 06/06/2005
> Hi All,
attaching the
that a
Is
to
dremel
> Thoughts?
the
> Thanks,
> /\/elson
> Austin, TX
08":06:07.AM(at)roxy.matronics.com,
6.5.3FP1|December 15, 2004) at 06/06/2005 08:06:09.AM(at)roxy.matronics.com,
Serialize complete
identified this incoming email as possible spam. An
analysis of the message is below.
Content analysis details: (1.6 points)
1.6 SUBJ_HAS_SPACES Subject contains lots of white space
I agree with Dan on all.
Norman
RV-6, RV-7, RV-7, F1 Rocket
>going forward.
>else.
>mistake.
>)_( Dan
>To:
>>Hi All,
>attaching the
>that a
>Is
>to
>dremel
>>Thoughts?
>the
>>Thanks,
>> /\/elson
>> Austin, TX
Incidently....I dimpled everything....skin, flap brace and hinge...All
works just fine and saves a bit of time.
With my alerons/flaps set up like in my previous message I had the flap
skin scrape the sides of the fuse...some mild trimming and its worked
out perfect...As Dan would say..."Your milage may vary".
Frank
RV-7 airframe Almost complete...:)
mistake.
)_( Dan
Subject: | glueing rudder aft edge |
I don't feel like doing pro-seal. Any other glues you'd recommend for this
job? Preferrably something at home depot or ace...
15, 2004) at 06/07/2005 07:50:04 AM,
15, 2004) at
06/07/2005 07:50:07 AM,
Serialize complete at 06/07/2005 07:50:07 AM
Dan, Norman, and Frank,
Thanks for the responses. Got the right aileron squared away yesterday evening
and started on the flap hinge using a #41 drill (as that is what seemed to fit
dimpled holes) to initially mark the holes on the hinge and then followed up
with a #40. Edge distance is Ok and I think it'll all work out just fine. If
not, I can always order some more hinge and try again. ;) A couple of lessons
have been learned from this experience and that's a good thing - I just hope
that if I do this all over again many years from now I'll remember them.
Thanks again,
/\/elson
RV-7A - Flaps and ailerons
Austin, TX
~~ ** ~~ 4 out of 3 people have problems with fractions ~~ ** ~~
Vulkem 116 sealant sold at Home Depot....It is THE duct sealant used by
all my contractors for a large wafer fab...When it sets up it sticks
like you won't believe and stays gooey.
Oh and is perfectly compatible with Aluminium.
Frank
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Don Hall
Subject: RV7-List: glueing rudder aft edge
this job? Preferrably something at home depot or ace...
Subject: | RE: glueing rudder aft edge |
From: | "Glaeser, Dennis A" <dennis.glaeser(at)eds.com> |
this job?
I plan on using JB Weld. I think any epoxy would work also. All it's
doing is holding things in place to make the riveting easier.
I helped my son do his rudder, and we didn't glue it at all. Of course
it required 2 of us to do it that way, but it came out great.
Dennis Glaeser
RV7A Empennage coming next week...
Subject: | Re: glueing rudder aft edge |
From: | "Lockamy, Jack L" <jack.lockamy(at)navy.mil> |
May not be available at Home Depot or Ace.... but I would use 3M 5200 Fast Cure
(24-HR) Adhesive/Sealant. You can purchase it online or as I did from a local
marine supply store. Boaters (and airplane builders) love this stuff. I've
yet to find a better adhesive. Comes in white or black color. One six-ounce
tube is approx. $10 but will be enough to build an entire airplane where needed.
Store the unused portion in a zip lock bag and keep it refrigerated.
Caution: Once this stuff sets up... it WON'T be coming off! I used it to glue
my NACA vents to the fuselage so as not to use any rivets. I also used it glue
the intersection fairings to my wheel pants.
NOTE: The regular 3M 5200 takes 5-7 days to set-up. Be sure to get the 5200 FAST
CURE (24-HR) unless you are not in a hurry....
Jack
N174JL RV-7A
Flying and at the paint shop
Subject: | Re: 5 point harness |
On 06/10 4:08, Cliff Lotter wrote:
> How do I fit the crotch strap for a 5 point harness to the RV7? There are pre
cut holes in the correct position but no indication of how to fit, in fact the
pre-cup holes are not even indicated in the plans.
Order Vans 5pt harness installation kit. It's a seperate order.
Comes with instructions and plans. Just be aware the vans
crotch strap thickness at the mounting point is different
from other seat belt manufacturers like team rocket. And
the bolt size is also different.
Walter Tondu
http://www.rv7-a.com
On 06/10 9:25, Dan Checkoway wrote:
> I don't have a 5-point system (I have Van's simple cheap lightweight
> 4-point). The 5-point is an uncomfortable waste of weight & cost (imho).
> Not worth it unless you have inverted OIL *and* FUEL *and* you do lots of
> sustained inverted. Otherwise why bother?
Safety. If it will hold you better in the seat inverted it's
certainly going to keep you in the seat better if you have to
land *unexpectedly*.
And the el-cheapo vans belts don't look near as cool either.
This is obviously the main factor why I didn't chose them. :)
You don't *have* to use it if it's uncomfortable.
So what if it weights a pound more. You aren't going
to notice the net speed loss, even if you could measure it.
Walter Tondu
On 06/10 10:51, Dan Checkoway wrote:
> Understood about safety.
> How quickly can you remove it? Surely you don't want it just lying there
> where it can interfere with the stick.
Shove it back into the slot in the seat cushion.
It's out of the way at that point.
Walter Tondu
So is the consensus that a side by side RV with inverted fuel and oil
really needs 5 point harnesses?
Don't think I'm going to like the answer to this.....
Frank
Both sides have +'s and -'s and now it's up to you. Make the desision and then
go for it and don't look back. I went forward with the 5 Point Hooker in my RV7A
and I certantly wont second guess what I did.
Richard Glick
RV7A, Wisconsin
> From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
> Date: 2005/06/10 Fri PM 03:02:58 EDT
> To:
> Subject: RE: RV7-List: 5 point harness
> Frank
yes
>Frank
You need to buy the supplemental parts from Van's, or get the drawings and
make the parts yourself. I have the Hooker brand and highly recommend them.
Tad Sargent
Sargentclt(at)CS.com
RV7A
Subject: | Re: RV7-List Digest: 2 Msgs - 06/08/05 |
I'm considering sending my fuel tanks out to be done. Since i'm building the
slow wings any help with speeding the process can't hurt and with all I've
read about pro-seal, well let's just say I wasn't looking forward to it. Does
anyone know where I can get this done? I read on Van's site that they do -9
wings for about $1,600./pair but did not see anything about the -7. I checked
out Evan's site and it looks promising. Are there any other options? Does
anyone have experience with Evan's. Thanks for any help.
Rick Rammos
Miami
RV-7A / wings
Subject: | Re: Builder assist with fuel tanks |
HTML_NONELEMENT_00_10(at)roxy.matronics.com, BODY:, to(at)roxy.matronics.com,
of(at)roxy.matronics.com, HTML(at)roxy.matronics.com,
elements(at)roxy.matronics.com, are(at)roxy.matronics.com,
non-standard(at)roxy.matronics.com
Rick,
Contact Doug Ripley at Sport Air, Inc. here in Atlanta. He runs a full
service Builder Assist Shop and specializes in RV's. Does very high quality
work. _doug(at)sportairinc.com_ (mailto:doug(at)sportairinc.com) 404-403-9208
_http://www.sportairinc.com/_ (http://www.sportairinc.com/)
Jon Berndsen
RV-7A
In a message dated 6/13/2005 3:01:30 A.M. Eastern Standard Time,
rv7-list-digest(at)matronics.com writes:
Subject: RV7-List: Re: RV7-List Digest: 2 Msgs - 06/08/05
the
Does
checked
Rick Rammos
Miami
RV-7A / wings
"IMB Recipient 1"
Rick,
Jon Berndsen
RV-7A
the
Does
checked
Rick Rammos
Miami
RV-7A / wings
From: | Frank Stringham <fstringham7a(at)yahoo.com> |
Rick
I felt like you ....but ....decide I would give the process a try. Much to my surprise
it wasn't as big a headache as I thought. I learned a bunch of things
and new techniques that will help me on the rest of the plane. I just wish I knew
them when I started the tanks in stead of learning through trial and error.
I wish I lived closer or had my plane done and could come and help you do your
tanks. If you decide to give the process a try e-mail me off line fstringham(at)hotmail.com
or give me a call 435-632-6895 and I would be happy to give you
the info as to what worked for me.
Frank @ sgu and slc
Rick Rammos
Miami
RV-7A / wings
Hey Rick don't let people scare you off of building them yourself, its
no big deal. I have build four sets of them now.
>Rick Rammos
>Miami
>RV-7A / wings
I had a misfire while dimpling my vertical stabilizer skin and now have an
offset, elongated and mis-formed dimple. A search of the archives shows no
previous topics - am I the first to make this mistake? Any recommendations
for a fix?
Thanks in advance,
Norm Tatz
RV-7 Empennage
Subject: | Re: Dimple Problem |
Norm,
Check out this link:
http://www.rvproject.com/20020824.html
Scott
www.scottfarner.com
Waiting for Fuse
> for a fix?
> Thanks in advance,
> Norm Tatz
> RV-7 Empennage
I haven't yet dealt with a misfire like that pictured below, but for a less
severe one, I squeezed the unsightly dimple area back to flat and redimpled.
If the resulting hole seemed slightly larger, I try using a half-size longer
rivet to allow for more expansion and still get a decent size shophead.
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Scott Farner
Subject: Re: RV7-List: Dimple Problem
Norm,
Scott
www.scottfarner.com
Waiting for Fuse
> have an offset, elongated and mis-formed dimple. A search of the
> archives shows no previous topics - am I the first to make this
> mistake? Any recommendations for a fix?
> Thanks in advance,
> Norm Tatz
> RV-7 Empennage
Wow, 1600 bucks? That's 40% of the premium for the quickbuild option on the
wings. I've already ordered the slowbuild wings. I'm glad if that's the
price. Now all temptation to avoid pro-seal is averted for me. ;>
Don
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of ENAJRICK(at)aol.com
the slow wings any help with speeding the process can't hurt and with all
I've read about pro-seal, well let's just say I wasn't looking forward to
it. Does anyone know where I can get this done? I read on Van's site that
they do -9 wings for about $1,600./pair but did not see anything about the
-7. I checked out Evan's site and it looks promising. Are there any other
options? Does anyone have experience with Evan's. Thanks for any help.
Rick Rammos
Miami
RV-7A / wings
From: | Darrell Reiley <lifeofreiley2003(at)yahoo.com> |
Van's is getting out of the tank business unless you are purchasing QB wings.
I believe they have even been removed from the latest order sheet.
Evans built Van's tanks for a long time... I would use Evans.
Darrell
BERNDSENCO(at)aol.com wrote:
Rick,
Jon Berndsen
RV-7A
the
Does
checked
Rick Rammos
Miami
RV-7A / wings
Norm, I did the same thing on my HS. I smacked the booboo flat and re-dimpled.
After everything was done, you can hardly tell.
Subject: | elevator counterbalance |
The plans call for a section of the counterbalance to be cut out. It was
fun enough just drilling holes in lead. My bandsaw wasn't enjoying the job
too much, but I suppose it'll work if I keep at it. But I wonder if there
is an easier way... Any tips on the best tools for cutting out a section of
lead and then shaping a radius into a corner?
Subject: | Re: elevator counterbalance |
You can use a chisel on lead. Sometimes even a razor blade.
)_( Dan
RV-7 N714D
Subject: RV7-List: elevator counterbalance
job
of
From: | "Wayne Glasser" <ku-tec(at)bigpond.net.au> |
Subject: | Duplicate messages |
Is anyone else getting duplicate messages from this list? I started
receiving them about a week ago.
Wayne
put a wood cutting blade on your band saw and it will cut the lead quick and
easy if you let it get hot it will be harder to work with so do a little at
the time.Same with drilling a little at the time.If it was easy it would not
be as much fun.
George
> job
> of
From: | "Don Patterson" <dpatterson14(at)wi.rr.com> |
I used a band saw but used some lube on the blade. Watch how much you
remove... I followed the print and found later that I needed to add more
lead.
Don Patterson
Subject: Re: RV7-List: elevator counterbalance
> )_( Dan
> RV-7 N714D
> To:
was
> job
there
section
> of
From: | George Neal E Capt AU/XPRR <Neal.George(at)maxwell.af.mil> |
Don -
I used a fine-tooth hack saw and lubed the blade with T-9 (Boelube in a
spray can) to rough out the lead. Then used a rat-tail rasp to rough out
the inside radius, finish with a chainsaw file. Vixen file for the flat /
outside radius areas. Also used T-9 on the files and cleaned the files
often with the file card / wire brush.
Neal
RV-7 N8ZG
Fuselage
www.appaero.com
posted by: "Don Hall"
Any tips on the best tools for cutting out a section of lead and then
Subject: | Fitting the firewall recess |
15, 2004) at 06/15/2005 08:10:25 AM,
Serialize by Router on MailServ59-US/AUS/H/NIC(Release 6.5.3FP1|December
15, 2004) at
06/15/2005 08:10:26 AM,
Serialize complete at 06/15/2005 08:10:26 AM
Hi All,
Got started on the firewall and the fit of the recess is causing me fits. All
the holes line up except the top two (#30's). I have to really bend/push/shove
the cleco to get it in which isn't right. And there's no way I'm going to be
December 07, 2004 - June 15, 2005
RV7-Archive.digest.vol-ah
