RV7-Archive.digest.vol-ai
June 15, 2005 - August 21, 2005
      able to get a rivet in there and properly seated.
      Is this normal do I possibly have a malformed/malpunched recess?
                /\/elson
                RV-7A - Fuselage
                Austin, TX
Date: Jun 15, 2005
Subject: Re: Fitting the firewall recess 15, 2004) at 06/15/2005 08:10:25
AM, Serialize by Router on MailServ59-US/AUS/H/NIC(Release 6.5.3FP1|December 15, 2004) at 06/15/2005 08:10:26 AM, Serialize complete at 06/15/2005 08:10:26 AM On 06/15 8:14, David E. Nelson wrote: > Got started on the firewall and the fit of the recess is causing me fits. All > the holes line up except the top two (#30's). I have to really bend/push/shove > the cleco to get it in which isn't right. And there's no way I'm going to be > able to get a rivet in there and properly seated. > > Is this normal do I possibly have a malformed/malpunched recess? That's a fairly normal situation. Don't sweat it. You are going to proseal that puppy in place anyhow. Just get it in as best as you can. If there are small gaps, they'll be covered with the goop. -- Walter Tondu http://www.rv7-a.com ________________________________________________________________________________
Date: Jun 15, 2005
Subject: Re: elevator counterbalance
Use a rasp file. Don Hall wrote: > > >The plans call for a section of the counterbalance to be cut out. It was >fun enough just drilling holes in lead. My bandsaw wasn't enjoying the job >too much, but I suppose it'll work if I keep at it. But I wonder if there >is an easier way... Any tips on the best tools for cutting out a section of >lead and then shaping a radius into a corner? > > > > ________________________________________________________________________________
From: "Brian Meyette" <brianpublic(at)starband.net>
Subject: Fitting the firewall recess 15, 2004) at 06/15/2005 08:10:25
Date: Jun 15, 2005
clamav-milter version 0.80j on apophis.email.starband.net Pro-seal?? Uh-oh Guess I missed that part - I just riveted mine in. Well, I guess I'll have to just apply it around the edges from the inside. brian -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Walter Tondu Subject: Re: RV7-List: Fitting the firewall recess 15, 2004) at 06/15/2005 08:10:25 AM, Serialize by Router on MailServ59-US/AUS/H/NIC(Release 6.5.3FP1|December 15, 2004) at 06/15/2005 08:10:26 AM, Serialize complete at 06/15/2005 08:10:26 AM On 06/15 8:14, David E. Nelson wrote: > Got started on the firewall and the fit of the recess is causing me fits. All > the holes line up except the top two (#30's). I have to really bend/push/shove > the cleco to get it in which isn't right. And there's no way I'm going to be > able to get a rivet in there and properly seated. > > Is this normal do I possibly have a malformed/malpunched recess? That's a fairly normal situation. Don't sweat it. You are going to proseal that puppy in place anyhow. Just get it in as best as you can. If there are small gaps, they'll be covered with the goop. -- Walter Tondu http://www.rv7-a.com -- -- ________________________________________________________________________________
Subject: Re: Dimple Problem
Date: Jun 15, 2005
While dimpling one of the skins on my QB wings, my son who has manning the hammer while I manipulated the skin hit the dimpler before I was ready and left a malpositioned dimple and hole. I did what everybody else has done, tried to flatten it as best I could and then moved on. In twenty years, I will look at that hole and praise God I was able to build an airplane with my son. Bill Near-Wiring ----- Original Message ----- From: "Doug Cook" <Dugcook(at)cox.net> Subject: Re: RV7-List: Dimple Problem > > Norm, I did the same thing on my HS. I smacked the booboo flat and > re-dimpled. After everything was done, you can hardly tell. > > > ________________________________________________________________________________
Date: Jun 15, 2005
I second that warning! I also took off what the print said and it was too light, and had to add some back. I wonder if the paint job will effect the final balance of the elevator to the point of having to remove material? Any words of wisdom from those completed RV's? I used my band saw with a wood hook blade (6 teeth per inch) and several relief cuts perpendicular to the direction of cut, and hand filed it smooth. It worked like a champ just take your time. Dan Storer 7A Oklahoma City Wings -------Original Message------- From: Don Patterson Date: 06/15/05 06:56:18 Subject: Re: RV7-List: elevator counterbalance I used a band saw but used some lube on the blade. Watch how much you remove... I followed the print and found later that I needed to add more lead. Don Patterson ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: Re: RV7-List: elevator counterbalance > > You can use a chisel on lead. Sometimes even a razor blade. > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > ----- Original Message ----- > From: "Don Hall" <dhall(at)donka.net> > To: > Subject: RV7-List: elevator counterbalance > > > > > > > > The plans call for a section of the counterbalance to be cut out. It was > > fun enough just drilling holes in lead. My bandsaw wasn't enjoying the > job > > too much, but I suppose it'll work if I keep at it. But I wonder if there > > is an easier way... Any tips on the best tools for cutting out a section > of > > lead and then shaping a radius into a corner? > > > > > > ________________________________________________________________________________
Date: Jun 16, 2005
I was also surprised at how difficult it was to cut a soft metal like lead. The problem is that the soft lead loads up the fine teeth of a blade designed for harder metals and you wind up just polishing the bottom of the cut. I solved the problem by using a cross-cut hand saw for wood, took bigger "bites" out of the lead and cleared the chips better. I just made two cuts, at 90 degrees, to near where the radius needed to be. Then I used a sharp 1/4-inch wood chisel to cut out the waste area, and a coarse round file to form the fillet. Kind of brute force but it worked. In retrospect, a coping saw with a wood-cutting blade might have been a more elegant solution. A wood-cutting blade in your band saw at slow speed might also work. ________________________________________________________________________________
Subject: elevator counterbalance
Date: Jun 16, 2005
Like Al said, I was surprised how difficult it was to cut lead, but pleasantly surprised how easy it was to countersink the lead. Actually used my Avery deburr tool and it worked quick and easy. Jim -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Herron, Al Subject: Re: RV7-List: elevator counterbalance I was also surprised at how difficult it was to cut a soft metal like lead. The problem is that the soft lead loads up the fine teeth of a blade designed for harder metals and you wind up just polishing the bottom of the cut. I solved the problem by using a cross-cut hand saw for wood, took bigger "bites" out of the lead and cleared the chips better. I just made two cuts, at 90 degrees, to near where the radius needed to be. Then I used a sharp 1/4-inch wood chisel to cut out the waste area, and a coarse round file to form the fillet. Kind of brute force but it worked. In retrospect, a coping saw with a wood-cutting blade might have been a more elegant solution. A wood-cutting blade in your band saw at slow speed might also work. ________________________________________________________________________________
Date: Jun 16, 2005
Well, thanks for all the advice everyone! It's great to not to hear my echo when I yell for help. Anyway, I actually made it to the basement tonight without discovering any more tools I needed, so I guess email fills that gap. I haven't yet added rat tails or T7's to my growing tool collection, but I did spray the heck out of my bandsaw with wd40 and what a difference. No WD40: blade goes for 2 seconds and grabs the lead. With Wd40: cuts like butter. I wouldn't call the cut pretty but it somewhat resembles the drawing. I tried to leave it a little thicker than the drawing. (The drawing does say that the cut is about what you'd expect to need after adding paint, so I won't worry that I've cut too much for another 2-3 years...) *************************** Don Hall N517DG (registered) rv7 empennage *************************** ________________________________________________________________________________
Date: Jun 16, 2005
Herron, Al wrote: > >I was also surprised at how difficult it was to cut a soft metal like >lead. The problem is that the soft lead loads up the fine teeth of a >blade designed for harder metals and you wind up just polishing the >bottom of the cut. I solved the problem by using a cross-cut hand saw >for wood, took bigger "bites" out of the lead and cleared the chips >better. I just made two cuts, at 90 degrees, to near where the radius >needed to be. Then I used a sharp 1/4-inch wood chisel to cut out the >waste area, and a coarse round file to form the fillet. Kind of brute >force but it worked. In retrospect, a coping saw with a wood-cutting >blade might have been a more elegant solution. A wood-cutting blade in >your band saw at slow speed might also work. > I'm pretty sure no one will like this, but a table saw cuts them like butter. Just secure it to a wood block big enough to keep your hands away from the blade & feed it slow. 2 cuts 90 degrees apart & you are done, with a slab left to put back after you discover you removed too much. Charlie ________________________________________________________________________________
Subject: Dan Checkoway's First Article in Kitplanes Magazine
Date: Jun 17, 2005
Hi Dan and all... Just got my new (August) copy of Kitplanes magazine, and lo and behold, there's the first in a series by Dan Checkoway ("Made in Metal" - Build Your Skills series)! Way to go, Dan! best, Cory ________________________________________________________________________________
Date: Jun 18, 2005
Subject: [ Henry Hore ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Henry Hore <elsa-henry@darlor-watch.com> Lists: RV-List,RV6-List,RV7-List,RV8-List,RV9-List Subject: Leveling RV6-A Fuselage http://www.matronics.com/photoshare/elsa-henry@darlor-watch.com.06.18.2005/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject: Oshkosh Get-together
Date: Jun 26, 2005
Wednesday July 27, 2005 Beginning at 6 p.m. Camp Scholler Back in 2003, we started the annual tradition of a get-together of RV7/7A builders at some point during Oshkosh (AirVenture). It lasted one year because the 2004 confab coincided with the Democratic National Convention in Boston and covering that sort of stuff is what I do for a living. But the get-together is back and this is your not-so-formal invitation to show up anytime between 6 p.m. and 10 p.m. When we did this a few years ago, we had about 20 people show up and it was a fabulous time even though our meek little camp barbecue grill was way too small, and a single campsite didn't allow us to spread out with the sort of luxury and elbow room RV7/7A builders deserve. This year will be different. Hope to see you there. Click the link for more particulars. http://home.comcast.net/~bcollinsrv7a/eaa/ Bob St. Paul ________________________________________________________________________________
"RV10 Group" ,
Subject: Paper or Plastic-A warning about primers
Date: Jun 26, 2005
Fellow builders, Please take the time to read this email. I spent a bit of time writing it in the hopes that it prevent another builder/builders from experiencing my blunder this morning. I will try my literary skills this morning to help entertain and educate. This may be a little long winded but I need to vent. Southern Arizona may sound like the great place to live. Warm winters, beautiful sunsets, low humidity, wide open spaces and great flying weather makes this state seem ideal. However, the summers can be another story. At 5:30 this morning the temperature is 80 degrees and rising. The morning sun is angling into the entrance of my shop (my garage door faces east). The temperature is rising and I know I only have about an hour to setup and spray my primer before Mother Nature forces me to quit for the day; I spray my primer outside like many RV builders. You might be asking yourself why not primer late in the day when the sun is going down or at least in the shade? Midday the temperature is over 100, by late afternoon (when my garage casts a shadow providing shade) the temperature is hovering around 104-106. This is way too hot to spray. At this temp and low humidity most of the primer dries before it reaches the parts. Not to mention the surface temperature of the parts is a bit too high. In addition, the afternoons are a bit breezy while the mornings are pretty calm. The mornings are the only option for me this time of year. I proceeded to setup my 4'x8' wire mesh paint platform and drop clothes (painters plastics) outside the entrance to my shop. I had decided to debur and prep many of RV-7A fuselage parts so I could spray them at the same time-more efficient I thought. I would guess that I had about 75% or more of the fuselage components (excluding the skins) ready for primer painting. That is a very large number of parts. It has taken a lot of time to clean and prep all these parts, I started weeks back. I am on my second RV. My first was an RV-4 years ago. Back then I used a wash primer but I don't remember the brand, it was gray in color, very similar to the Sherwin Williams (SW) wash primer. Unfortunately it was no longer available. I decided to use the SW wash primer on my RV-7A. I used it on the empennage and wings, but I was never happy with the results. Spitting chunks was a big problem. I never had that problem with the old gray wash primer on my RV-4. When I built my RV-4 I sprayed my primer using a Docken spray gun. This is a very simple siphon gun that is similar to the Badger hobby store paint guns. It used disposable 16 oz cups. It made cleaning up after spaying quick and easy, just through the cup away when you were done. As I mentioned, I was not happy with the results I was getting from the SW wash primer. I decided to use the AKSO epoxy primer for the rest of my RV-7A project. And since I was using a new primer, I bought a new gun (HVLP) to apply it. Now this is where the paper or plastic fits into this long winded story. Like the SW wash primer, the AKSO is a two component system. I had several 16 oz cups left over from my Docken spray gun days and I have been using them for mixing the SW wash primer prior to loading spray gun cup. These cups are wax-coated paper cups (Dixie brand) and over 20 years old. These cups did the job, but I was running out of them. They seemed to be the "perfect" size for the amount of primer I was mixing. A week ago I used the AKSO for the first time. The most significant difference between the SW wash and the AKSO is the AKSO requires a 30 minute induction time. This means you mix the two components and wait 30 minutes before spraying. This gives the two components time to react with each other. The results were great. I only had a short time to spray so I wanted to learn the behavior of the new gun and primer to help me plan my larger primer session for this weekend. Yesterday was a good day. I sprayed two groups of parts. By 7:30 in the morning the temperature was approaching 90 degrees and I couldn't see through my goggles well (yes I use a respirator). All the parts in the group were well coated and it was time to cleanup. One more early morning primer session and all the parts would be coated, then on to assembly, the fun stuff. So this morning I would finish the job. Everything was set in place; parts were on the spray platform and now it was time to mix the paint. I have been using my Black and Decker Workmate (if you never used one, they are great tool to have around the shop-one of my most used tools) as a surface to mix my paints. I laid plastic over it to protect it from any spills and it was also sitting on some plastic as well. The Workmate was in the shop so the primers weren't exposed to the heat and sunlight. I had used up all my 16 oz. cups the day before and I had shopped around weeks earlier trying to find a replacement. I only found smaller paper cups available in the local supermarkets but they had larger disposable plastic cups. So I bought the plastic due to their size. I wanted paper but I needed the larger cup size. Life was good, everything was ready to primer and I mixed two batches of primer (14 oz. each) in my new plastic cups. And off I went to work on a few other things in the shop while I waited for the induction time (30 minutes) to pass. After 15 minutes had passed, I went to stir the primer. I noticed one of the cups was "sagging" a bit. Alarm bells in my head went off immediately. I grabbed the trashcan. I knew what was going to happen. The dam was leaking and it was about to rupture. Just as I lifted up the trashcan the cup dissolved away. None of the primer made it into the trashcan. Fourteen ounces of the best primer was now on the floor and covering the base of the Workmate (the plastic covering the surface didn't extend all the way down to the base). But I knew this was just the beginning. Within seconds, the second cup dissolved before I could get the trashcan under it and more epoxy made it onto the floor. Did I mention my shop floor is coated with an epoxy (two part-water based-gray)? So now I am staring at a rather large epoxy mess that only acetone will clean up. But acetone will also dissolve my epoxy floor coating. Profanities flew and the odor of acetone filled the air. All is cleaned up now. My epoxy coated floor looks chemically abused and my Workmate base is camouflage colored and ready to report for military duty. I have wasted precious primer and delayed my progress once again. Hopefully next Friday I will have everything rapped up. The moral of the story is: When given the choice paper or plastic, choose paper. ________________________________________________________________________________
Date: Jun 26, 2005
Paul, As I was the one who recommended the AKZO, I guess I owe you an apology for not warning you about its appetite for plastic. Glad to hear that everything is well now. Don VS -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Merems opticalprod(at)worldnet.att.net Subject: RV7-List: Paper or Plastic-A warning about primers Fellow builders, Please take the time to read this email. I spent a bit of time writing it in the hopes that it prevent another builder/builders from experiencing my blunder this morning. I will try my literary skills this morning to help entertain and educate. This may be a little long winded but I need to vent. Southern Arizona may sound like the great place to live. Warm winters, beautiful sunsets, low humidity, wide open spaces and great flying weather makes this state seem ideal. However, the summers can be another story. At 5:30 this morning the temperature is 80 degrees and rising. The morning sun is angling into the entrance of my shop (my garage door faces east). The temperature is rising and I know I only have about an hour to setup and spray my primer before Mother Nature forces me to quit for the day; I spray my primer outside like many RV builders. You might be asking yourself why not primer late in the day when the sun is going down or at least in the shade? Midday the temperature is over 100, by late afternoon (when my garage casts a shadow providing shade) the temperature is hovering around 104-106. This is way too hot to spray. At this temp and low humidity most of the primer dries before it reaches the parts. Not to mention the surface temperature of the parts is a bit too high. In addition, the afternoons are a bit breezy while the mornings are pretty calm. The mornings are the only option for me this time of year. I proceeded to setup my 4'x8' wire mesh paint platform and drop clothes (painters plastics) outside the entrance to my shop. I had decided to debur and prep many of RV-7A fuselage parts so I could spray them at the same time-more efficient I thought. I would guess that I had about 75% or more of the fuselage components (excluding the skins) ready for primer painting. That is a very large number of parts. It has taken a lot of time to clean and prep all these parts, I started weeks back. I am on my second RV. My first was an RV-4 years ago. Back then I used a wash primer but I don't remember the brand, it was gray in color, very similar to the Sherwin Williams (SW) wash primer. Unfortunately it was no longer available. I decided to use the SW wash primer on my RV-7A. I used it on the empennage and wings, but I was never happy with the results. Spitting chunks was a big problem. I never had that problem with the old gray wash primer on my RV-4. When I built my RV-4 I sprayed my primer using a Docken spray gun. This is a very simple siphon gun that is similar to the Badger hobby store paint guns. It used disposable 16 oz cups. It made cleaning up after spaying quick and easy, just through the cup away when you were done. As I mentioned, I was not happy with the results I was getting from the SW wash primer. I decided to use the AKSO epoxy primer for the rest of my RV-7A project. And since I was using a new primer, I bought a new gun (HVLP) to apply it. Now this is where the paper or plastic fits into this long winded story. Like the SW wash primer, the AKSO is a two component system. I had several 16 oz cups left over from my Docken spray gun days and I have been using them for mixing the SW wash primer prior to loading spray gun cup. These cups are wax-coated paper cups (Dixie brand) and over 20 years old. These cups did the job, but I was running out of them. They seemed to be the "perfect" size for the amount of primer I was mixing. A week ago I used the AKSO for the first time. The most significant difference between the SW wash and the AKSO is the AKSO requires a 30 minute induction time. This means you mix the two components and wait 30 minutes before spraying. This gives the two components time to react with each other. The results were great. I only had a short time to spray so I wanted to learn the behavior of the new gun and primer to help me plan my larger primer session for this weekend. Yesterday was a good day. I sprayed two groups of parts. By 7:30 in the morning the temperature was approaching 90 degrees and I couldn't see through my goggles well (yes I use a respirator). All the parts in the group were well coated and it was time to cleanup. One more early morning primer session and all the parts would be coated, then on to assembly, the fun stuff. So this morning I would finish the job. Everything was set in place; parts were on the spray platform and now it was time to mix the paint. I have been using my Black and Decker Workmate (if you never used one, they are great tool to have around the shop-one of my most used tools) as a surface to mix my paints. I laid plastic over it to protect it from any spills and it was also sitting on some plastic as well. The Workmate was in the shop so the primers weren't exposed to the heat and sunlight. I had used up all my 16 oz. cups the day before and I had shopped around weeks earlier trying to find a replacement. I only found smaller paper cups available in the local supermarkets but they had larger disposable plastic cups. So I bought the plastic due to their size. I wanted paper but I needed the larger cup size. Life was good, everything was ready to primer and I mixed two batches of primer (14 oz. each) in my new plastic cups. And off I went to work on a few other things in the shop while I waited for the induction time (30 minutes) to pass. After 15 minutes had passed, I went to stir the primer. I noticed one of the cups was "sagging" a bit. Alarm bells in my head went off immediately. I grabbed the trashcan. I knew what was going to happen. The dam was leaking and it was about to rupture. Just as I lifted up the trashcan the cup dissolved away. None of the primer made it into the trashcan. Fourteen ounces of the best primer was now on the floor and covering the base of the Workmate (the plastic covering the surface didn't extend all the way down to the base). But I knew this was just the beginning. Within seconds, the second cup dissolved before I could get the trashcan under it and more epoxy made it onto the floor. Did I mention my shop floor is coated with an epoxy (two part-water based-gray)? So now I am staring at a rather large epoxy mess that only acetone will clean up. But acetone will also dissolve my epoxy floor coating. Profanities flew and the odor of acetone filled the air. All is cleaned up now. My epoxy coated floor looks chemically abused and my Workmate base is camouflage colored and ready to report for military duty. I have wasted precious primer and delayed my progress once again. Hopefully next Friday I will have everything rapped up. The moral of the story is: When given the choice paper or plastic, choose paper. ________________________________________________________________________________
Date: Jul 02, 2005
Subject: [ eanderson(at)carolina.rr.com ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: eanderson(at)carolina.rr.com Lists: RV-List,RV3-List,RV4-List,RV6-List,RV7-List,RV8-List,RV9-List,RV10-List Subject: Brake Line Failure http://www.matronics.com/photoshare/eanderson@carolina.rr.com.07.02.2005/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
From: Steve Cooper <sportflyer(at)emcity.net> (SquirrelMail authenticated
user sportflyer) by webmail.emcity.net with HTTP; Sat, 2 Jul 2005 12:39:52.-0600(at)roxy.matronics.com (MDT)
Date: Jul 02, 2005
Subject: Looking for Engine
I'm looking for a used Rotax 912/912S or new in crate. Have cash ready to purchase. sportflyer(at)emcity.net ________________________________________________________________________________
Subject: Does this deburring tool exist?
Date: Jul 03, 2005
I'll be hunting this at Osh. Ideal deburring tool: Can debur both sides of a hole simultaneously. 2nd place to a tool that deburs only the under side of the hole (for getting at the inside of a flange). A friend of mine showed me a deburring bit that has a spring-loaded blade that can do exactly that. You mount the bit into a drill, and it deburs the front\top of the hole on the way through, then the bottom\under side of the hole when you pull it out. He did not have one of those things for #40, so cannot attest to how effective it is. I also question whether that spring concept would work on a thin skin for a small #40 hole. My only deburring tool is one of those countersinks that you mount into a cordless screwdriver. It works great everywhere except those hard to reach places like inside the bend of a skin or the inside holes of a flange. For most tight spots, I remove the countersink shank from the screwdriver and spin\rotate the sink manually. That works fine, but it's a pain so I'm looking for a better tool for those spots. If I come back from Osh with one thing, it'll be a deburring tool that makes it real easy to debur inside flanges and spars. Anybody have any experience with those deburring bits? Any other favorites? *************************** Don Hall N517DG (registered) rv7 empennage http://donka.net/rv7project.html *************************** ________________________________________________________________________________
Date: Jul 03, 2005
Don, I just ordered one for 3/32" / #40 holes direct from Cogsdill tools for around $50. Works great and what a time saver! Pictures and link to Cogsdill here... http://www.rv7factory.com/log/050624.html Make sure you order it with a neutral rake blade as it is designed specifically for aluminum. I ordered a replacement blade ($8), but they don't recommend replacing the blades on the 3/32" version yourself... when I got it I can see why... it is very small. Good Luck, Brad RV-7 Livermore, CA -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Don Hall Subject: RV7-List: Does this deburring tool exist? I'll be hunting this at Osh. Ideal deburring tool: Can debur both sides of a hole simultaneously. 2nd place to a tool that deburs only the under side of the hole (for getting at the inside of a flange). A friend of mine showed me a deburring bit that has a spring-loaded blade that can do exactly that. You mount the bit into a drill, and it deburs the front\top of the hole on the way through, then the bottom\under side of the hole when you pull it out. He did not have one of those things for #40, so cannot attest to how effective it is. I also question whether that spring concept would work on a thin skin for a small #40 hole. My only deburring tool is one of those countersinks that you mount into a cordless screwdriver. It works great everywhere except those hard to reach places like inside the bend of a skin or the inside holes of a flange. For most tight spots, I remove the countersink shank from the screwdriver and spin\rotate the sink manually. That works fine, but it's a pain so I'm looking for a better tool for those spots. If I come back from Osh with one thing, it'll be a deburring tool that makes it real easy to debur inside flanges and spars. Anybody have any experience with those deburring bits? Any other favorites? *************************** Don Hall N517DG (registered) rv7 empennage http://donka.net/rv7project.html *************************** ________________________________________________________________________________
Date: Jul 03, 2005
Thanks, Very clean website of yours. I'm curious about the elaborate condensor. Did it work? Would adding an inline moisture filter not work? I live in Georgia, very humid, but interestingly my moisture filter hasn't yet trapped much. I do empty my compressor frequently and a lot of water comes out. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Brad Oliver Subject: RE: RV7-List: Does this deburring tool exist? Don, I just ordered one for 3/32" / #40 holes direct from Cogsdill tools for around $50. Works great and what a time saver! Pictures and link to Cogsdill here... http://www.rv7factory.com/log/050624.html Make sure you order it with a neutral rake blade as it is designed specifically for aluminum. I ordered a replacement blade ($8), but they don't recommend replacing the blades on the 3/32" version yourself... when I got it I can see why... it is very small. Good Luck, Brad RV-7 Livermore, CA -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Don Hall Subject: RV7-List: Does this deburring tool exist? I'll be hunting this at Osh. Ideal deburring tool: Can debur both sides of a hole simultaneously. 2nd place to a tool that deburs only the under side of the hole (for getting at the inside of a flange). A friend of mine showed me a deburring bit that has a spring-loaded blade that can do exactly that. You mount the bit into a drill, and it deburs the front\top of the hole on the way through, then the bottom\under side of the hole when you pull it out. He did not have one of those things for #40, so cannot attest to how effective it is. I also question whether that spring concept would work on a thin skin for a small #40 hole. My only deburring tool is one of those countersinks that you mount into a cordless screwdriver. It works great everywhere except those hard to reach places like inside the bend of a skin or the inside holes of a flange. For most tight spots, I remove the countersink shank from the screwdriver and spin\rotate the sink manually. That works fine, but it's a pain so I'm looking for a better tool for those spots. If I come back from Osh with one thing, it'll be a deburring tool that makes it real easy to debur inside flanges and spars. Anybody have any experience with those deburring bits? Any other favorites? *************************** Don Hall N517DG (registered) rv7 empennage http://donka.net/rv7project.html *************************** ________________________________________________________________________________
Date: Jul 03, 2005
Don, thanks for the nice comments (about the web site). The condenser does pull more moisture out of the air than just my filter alone. I built it because I was looking for a quick and easy solution to water in vapor form. The filter I currently have traps water in liquid form but the vapor passes through it unencumbered. We had a humid weekend (for us) the day I had the water problems, but it has been very dry (normal) since, so it is hard to compare. I would like to test it on another humid day to see just how well it really works. I also built the condenser because I couldn't seem to find an air dryer (dryer not filter) locally at a reasonable price. Ironically, the day after I finished the condenser I found this online ... http://www.contractorstools.com/camp_at_filters_PA2085.html I even found a few on eBay for around $75. If I had known about it prior, and wasn't so time constrained, I probably would have ordered one of them instead of building the condenser. Happy building! Brad -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Don Hall Subject: RE: RV7-List: Does this deburring tool exist? Thanks, Very clean website of yours. I'm curious about the elaborate condensor. Did it work? Would adding an inline moisture filter not work? I live in Georgia, very humid, but interestingly my moisture filter hasn't yet trapped much. I do empty my compressor frequently and a lot of water comes out. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Brad Oliver Subject: RE: RV7-List: Does this deburring tool exist? Don, I just ordered one for 3/32" / #40 holes direct from Cogsdill tools for around $50. Works great and what a time saver! Pictures and link to Cogsdill here... http://www.rv7factory.com/log/050624.html Make sure you order it with a neutral rake blade as it is designed specifically for aluminum. I ordered a replacement blade ($8), but they don't recommend replacing the blades on the 3/32" version yourself... when I got it I can see why... it is very small. Good Luck, Brad RV-7 Livermore, CA -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Don Hall Subject: RV7-List: Does this deburring tool exist? I'll be hunting this at Osh. Ideal deburring tool: Can debur both sides of a hole simultaneously. 2nd place to a tool that deburs only the under side of the hole (for getting at the inside of a flange). A friend of mine showed me a deburring bit that has a spring-loaded blade that can do exactly that. You mount the bit into a drill, and it deburs the front\top of the hole on the way through, then the bottom\under side of the hole when you pull it out. He did not have one of those things for #40, so cannot attest to how effective it is. I also question whether that spring concept would work on a thin skin for a small #40 hole. My only deburring tool is one of those countersinks that you mount into a cordless screwdriver. It works great everywhere except those hard to reach places like inside the bend of a skin or the inside holes of a flange. For most tight spots, I remove the countersink shank from the screwdriver and spin\rotate the sink manually. That works fine, but it's a pain so I'm looking for a better tool for those spots. If I come back from Osh with one thing, it'll be a deburring tool that makes it real easy to debur inside flanges and spars. Anybody have any experience with those deburring bits? Any other favorites? *************************** Don Hall N517DG (registered) rv7 empennage http://donka.net/rv7project.html *************************** ________________________________________________________________________________
Subject: Fitting the F-779 aft bottom skin?
Date: Jul 04, 2005
Fellow RV-7 builders, I need some help. I am trying to fit my F-779 bottom skin and I am having a bit of trouble. This is the 0.040 thick bottom skin that ties the last three bulkheads together. My original skin didn't fit well. I tried to bend it by hand, clamped it between wood blocks and put some muscle into it, but without much success. I thought it might have been improperly formed at the factory so I ordered an new one. Well this one is about as bad as the original. Once again I tried to bend without success. I may not be the strongest builder but maybe one of you have a great idea for me to try before I break my wrists trying to muscle this skin. Thanks in advance, Paul ________________________________________________________________________________
Date: Jul 04, 2005
Paul, See Dam C's site Sept 4 2004. If your parts are correct maybe you don't have the flanges bent to the right shape, they need to taper as the tail gets narrower. Don -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Merems Subject: RV7-List: Fitting the F-779 aft bottom skin? Fellow RV-7 builders, I need some help. I am trying to fit my F-779 bottom skin and I am having a bit of trouble. This is the 0.040 thick bottom skin that ties the last three bulkheads together. My original skin didn't fit well. I tried to bend it by hand, clamped it between wood blocks and put some muscle into it, but without much success. I thought it might have been improperly formed at the factory so I ordered an new one. Well this one is about as bad as the original. Once again I tried to bend without success. I may not be the strongest builder but maybe one of you have a great idea for me to try before I break my wrists trying to muscle this skin. Thanks in advance, Paul ________________________________________________________________________________
Subject: Re: Fitting the F-779 aft bottom skin?
Date: Jul 04, 2005
Just dealt with that bit myself just recently ... it requires quite a bit of "manipulation" according to Van's builder support line. Can you be a bit more explicit about what's not fitting against what ? Maybe some photos ? There's a handful of "tricks" for getting past this hurdle, I'm sure folks around can help ... g > > > Fellow RV-7 builders, > > I need some help. I am trying to fit my F-779 bottom skin and > I am having a bit of trouble. This is the 0.040 thick bottom > skin that ties the last three bulkheads together. My original > skin didn't fit well. I tried to bend it by hand, clamped it > between wood blocks and put some muscle into it, but without > much success. I thought it might have been improperly formed > at the factory so I ordered an new one. Well this one is about > as bad as the original. Once again I tried to bend without > success. > > I may not be the strongest builder but maybe one of you have a > great idea for me to try before I break my wrists trying to > muscle this skin. > > Thanks in advance, > > Paul > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Subject: Firwall planning
Date: Jul 05, 2005
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Morning all...I started hanging stuff on the firewall yesterday and realised I have to allow space for the inverted oil system which I don't yet have as it is coming with the engine in a few weeks. For those of you who fitted the invert, did you have to move stuff around on the firewall or did the Van's locations leave enough room for the tank ind invert valve. I have an IO360 with forward induction, Sam James cowl and Odyssey battery on the firewall. Thanks Frank....Airframe still almost finished...:) ________________________________________________________________________________
Date: Jul 05, 2005
clamav-milter version 0.80j on hathor This is really for bigger holes than rivet holes, but it works well for me: http://brian76.mystarband.net/tools.htm#debur It has easily interchangeable blades. The one shown in it will do both sides of a hole. It's from MSC. brian http://brian76.mystarband.net/RV-7Ahome.htm -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Don Hall Subject: RV7-List: Does this deburring tool exist? I'll be hunting this at Osh. Ideal deburring tool: Can debur both sides of a hole simultaneously. 2nd place to a tool that deburs only the under side of the hole (for getting at the inside of a flange). A friend of mine showed me a deburring bit that has a spring-loaded blade that can do exactly that. You mount the bit into a drill, and it deburs the front\top of the hole on the way through, then the bottom\under side of the hole when you pull it out. He did not have one of those things for #40, so cannot attest to how effective it is. I also question whether that spring concept would work on a thin skin for a small #40 hole. My only deburring tool is one of those countersinks that you mount into a cordless screwdriver. It works great everywhere except those hard to reach places like inside the bend of a skin or the inside holes of a flange. For most tight spots, I remove the countersink shank from the screwdriver and spin\rotate the sink manually. That works fine, but it's a pain so I'm looking for a better tool for those spots. If I come back from Osh with one thing, it'll be a deburring tool that makes it real easy to debur inside flanges and spars. Anybody have any experience with those deburring bits? Any other favorites? *************************** Don Hall N517DG (registered) rv7 empennage http://donka.net/rv7project.html *************************** -- -- ________________________________________________________________________________
Date: Jul 05, 2005
> I need some help. I am trying to fit my F-779 bottom skin and I am having a > bit of trouble. This is the 0.040 thick bottom skin that ties the last three > bulkheads together. My original skin didn't fit well. I tried to bend it by > hand, clamped it between wood blocks and put some muscle into it, but without > much success. I thought it might have been improperly formed at the factory > so I ordered an new one. Well this one is about as bad as the original. Once > again I tried to bend without success. Yes, this piece doesn't fit so well out of the box. My bend radius didn't seem to be quite right. Using my hand seamer I was able to increase the radius enough that it fit like a glove. You can see here for how it fit before and after I bent it a little. http://rv.jpainter.org/?view=entry&date=2005-05-14 Also, it's been mentioned earlier...but make sure that you have bent the flanges accordingly. The bulkhead webs should not be 90 degrees to the flanges. Best of luck, Jamie -- Jamie D. Painter RV-7A fuselage N622JP (reserved) http://rv.jpainter.org ________________________________________________________________________________
Subject: Brake pedals installation
Date: Jul 06, 2005
I'm mucking about assembling the brake pedals and just looking at the schematics and trial fitting things, I notice the plans call for about 4 washers between the attachment angle and the master break cylinder. Wouldn't it be better to cut a little spacer tube and stick that in that location instead. Bob St. Paul ________________________________________________________________________________
Date: Jul 06, 2005
Yes but making the spacers is a fiddly task and its just a cosmetic thing...There are plenty of things to needlessly spend your time on later on. Personally I would just slap in the washers and move on. Frank -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Bob Collins Subject: RV7-List: Brake pedals installation I'm mucking about assembling the brake pedals and just looking at the schematics and trial fitting things, I notice the plans call for about 4 washers between the attachment angle and the master break cylinder. Wouldn't it be better to cut a little spacer tube and stick that in that location instead. Bob St. Paul ________________________________________________________________________________
Subject: Re: Brake pedals installation
Date: Jul 06, 2005
also with the "tubge type" spacers, you incerase the stress points in a closer circle, where as the washers help even the load over a larger aerea.. ----- Original Message ----- From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com> Subject: RE: RV7-List: Brake pedals installation > > Yes but making the spacers is a fiddly task and its just a cosmetic > thing...There are plenty of things to needlessly spend your time on > later on. Personally I would just slap in the washers and move on. > > Frank > > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Bob Collins > To: rv7-list(at)matronics.com > Subject: RV7-List: Brake pedals installation > > > I'm mucking about assembling the brake pedals and just looking at the > schematics and trial fitting things, I notice the plans call for about 4 > washers between the attachment angle and the master break cylinder. > Wouldn't it be better to cut a little spacer tube and stick that in that > location instead. > > Bob > St. Paul > > ________________________________________________________________________________
"RV7and7A(at)yahoogroups. com" , "Eaa740(at)Thayer. Dartmouth. Edu"
Subject: FW: [BostonRVBuilders] Wiring workshop and this weekend's cookout
in Plymouth, MA
Date: Jul 11, 2005
clamav-milter version 0.80j on hathor fyi Bob Nuckolls is the expert on wiring experimental planes. It should be a most informative seminar. brian -----Original Message----- From: BostonRVBuilders(at)yahoogroups.com [mailto:BostonRVBuilders(at)yahoogroups.com]On Behalf Of John Sannizzaro Subject: [BostonRVBuilders] Wiring workshop and this weekend's cookout in Plymouth, MA Just an update, Folks! almost 1 month away and have 15 signed up. We NEED 18 in order to make it a go. Sign up here and NOW! http://www.aeroelectric.com/seminars/Plymouth_2005.html Also, if you need a room I am holding these rooms at the Comfort Inn until TOMORROW! After that date, I would have to put my own money down and I don't want to do that as I am doing this for education and entertainment... not for profit! For more details and up to date information, see my chapter's website at: www.eaaul62.com ...where we will be offering last minute information regarding the event. One more thing! We are having a cookout, this coming weekend!On Saturday, July 16th we will be cooking burgers, dogs and I plan on making my award winning chili! The food is free, all we ask for is a donation. The event on the 16th will be at Ace Helicopter on the south side of the field! By aircraft, you will taxi as though you are departing on runway 33... but take the turnoff at the only hangar there. We will have a comm radio tuned to Unicom, 123.00 if you have any questions. The grass will be mowed for parking so taxi on up and have some lunch! By car, the airport is on South Meadow in Plymouth. Enter at Gate 6 and follow the signs along the dirt road past the approach end of runway 6, to the event. We will be there from 11AM until the food is gone or the last plane leaves! Email me if you have any questions. N357JS at adelphia.net See you there! John S. _____ * Visit your group " BostonRVBuilders <http://groups.yahoo.com/group/BostonRVBuilders> " on the web. * To unsubscribe from this group, send an email to: BostonRVBuilders-unsubscribe(at)yahoogroups.com <http://docs.yahoo.com/info/terms/> . _____ -- ________________________________________________________________________________
Subject: Sam James Yahoogroup
Date: Jul 11, 2005
Hello all, I have just set up a yahoo groups for those of us installing the Sam James "Holy cowl" and plenum... James Aircraft are supporting the endeavour and will be checking messages and answering questions. Please feel free to join the groups at http://groups.yahoo.com/group/Samjames/ and post your experiences. This has just been set up in the last few hours and we will be inviting the past James aircraft customers directly. Thanks Frank ________________________________________________________________________________
Subject: tenderfoot?
Date: Jul 12, 2005
If the rank of Eagle is a flying RV, then I figure completing a tail is somewhere around Tenderfoot. Gimme the patch. In right at 2 months, I have successfully converted a box of aluminum into an empennage. I consider myself one of those people whose mechanical histories are sufficiently weak enough to suggest that I have no business building an airplane. With the empennage now done, my doubts are diminishing. At the same time, when I realize that I am maybe 10% done, it is very easy to feel overwhelmed yet again. But with all of your help and your websites so well documented, it is like having a dozen experts on hand to keep me on track. A special thank you to those who have so well documented your mistakes. You've saved me a few, and you've made me realize that my own mistakes are normal and recoverable, albeit sometimes resolved with $4 shipping and handling charges. Oshkosh is coming. I will hope to meet a few of you there. ************************************* Don Hall N517DG (registered) rv7 (waiting on slow-build wings...) http://donka.net/rv7project.html ************************************** ________________________________________________________________________________
From: "James E. Clark" <james(at)nextupventures.com>
Date: Jul 13, 2005
I *think* the group URL is: http://groups.yahoo.com/group/JamesAircraft James | -----Original Message----- | From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list- | server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) | Sent: Monday, July 11, 2005 5:14 PM | To: rv7-list(at)matronics.com | Subject: RV7-List: Sam James Yahoogroup | | | | Hello all, | | I have just set up a yahoo groups for those of us installing the Sam | James "Holy cowl" and plenum... James Aircraft are supporting the | endeavour and will be checking messages and answering questions. | | Please feel free to join the groups at | http://groups.yahoo.com/group/Samjames/ and post your experiences. | | This has just been set up in the last few hours and we will be inviting | the past James aircraft customers directly. | | Thanks | | Frank | | | | | ________________________________________________________________________________
Date: Jul 13, 2005
Ha ha ...It is Now...:)... Liz James did not like the "Sam James" reference and changed it on me...Thats what you get for for making someone a groups moderator. Thanks for the correction Frank -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of James E. Clark Subject: RE: RV7-List: Sam James Yahoogroup --> I *think* the group URL is: http://groups.yahoo.com/group/JamesAircraft James | -----Original Message----- | From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list- | server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) | Sent: Monday, July 11, 2005 5:14 PM | To: rv7-list(at)matronics.com | Subject: RV7-List: Sam James Yahoogroup | | | | Hello all, | | I have just set up a yahoo groups for those of us installing the Sam | James "Holy cowl" and plenum... James Aircraft are supporting the | endeavour and will be checking messages and answering questions. | | Please feel free to join the groups at | http://groups.yahoo.com/group/Samjames/ and post your experiences. | | This has just been set up in the last few hours and we will be | inviting the past James aircraft customers directly. | | Thanks | | Frank | | | | | ________________________________________________________________________________
Date: Jul 13, 2005
Yup. Liz is "good people". I suspect that she wanted to be able to incorporate the stuff from **Will** James (the son and her husband). Will is who does the "new cowl" I referenced. James | -----Original Message----- | From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list- | server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) | Sent: Wednesday, July 13, 2005 6:39 PM | To: rv7-list(at)matronics.com | Subject: RE: RV7-List: Sam James Yahoogroup | | | | Ha ha ...It is Now...:)... Liz James did not like the "Sam James" | reference and changed it on me...Thats what you get for for making | someone a groups moderator. | | Thanks for the correction | | Frank | | -----Original Message----- | From: owner-rv7-list-server(at)matronics.com | [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of James E. Clark | To: rv7-list(at)matronics.com | Subject: RE: RV7-List: Sam James Yahoogroup | | --> | | I *think* the group URL is: | | http://groups.yahoo.com/group/JamesAircraft | | | James | | | | -----Original Message----- | | From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list- | | server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) | | Sent: Monday, July 11, 2005 5:14 PM | | To: rv7-list(at)matronics.com | | Subject: RV7-List: Sam James Yahoogroup | | | | | | | | Hello all, | | | | I have just set up a yahoo groups for those of us installing the Sam | | | James "Holy cowl" and plenum... James Aircraft are supporting the | | endeavour and will be checking messages and answering questions. | | | | Please feel free to join the groups at | | http://groups.yahoo.com/group/Samjames/ and post your experiences. | | | | This has just been set up in the last few hours and we will be | | inviting the past James aircraft customers directly. | | | | Thanks | | | | Frank | | | | | | | | | | | | | | | ________________________________________________________________________________
Date: Jul 14, 2005
Subject: List Digest Truncation Fixed!!
Dear Listers, I finally figured out today what was causing the occasional truncation of the daily List Digest emails. Seems that every once in a while a message would contain a single "." (period) on line all by itself. The mailers would see this and assume that this was the universal emailer signal for "end of message", and consequently wouldn't process any of the rest of the Digest message. I've put in a filter today to remove any of these sequences so we should be back in business on the Digests. Best regards, Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jul 14, 2005
Ahhh, Matt, what a difference a little dot can make. Seriously, thanks for all the work you do to make these lists available. Don Hull RV-7 emp -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Matt Dralle Subject: RV7-List: List Digest Truncation Fixed!! Dear Listers, I finally figured out today what was causing the occasional truncation of the daily List Digest emails. Seems that every once in a while a message would contain a single "." (period) on line all by itself. The mailers would see this and assume that this was the universal emailer signal for "end of message", and consequently wouldn't process any of the rest of the Digest message. I've put in a filter today to remove any of these sequences so we should be back in business on the Digests. Best regards, Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle@matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jul 14, 2005
Thanks for your dedication to the group and hard work, Franz -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Hull, Don Subject: RE: RV7-List: List Digest Truncation Fixed!! Ahhh, Matt, what a difference a little dot can make. Seriously, thanks for all the work you do to make these lists available. Don Hull RV-7 emp -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Matt Dralle Subject: RV7-List: List Digest Truncation Fixed!! Dear Listers, I finally figured out today what was causing the occasional truncation of the daily List Digest emails. Seems that every once in a while a message would contain a single "." (period) on line all by itself. The mailers would see this and assume that this was the universal emailer signal for "end of message", and consequently wouldn't process any of the rest of the Digest message. I've put in a filter today to remove any of these sequences so we should be back in business on the Digests. Best regards, Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle@matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft -- -- ________________________________________________________________________________
Subject: RE: antenna mounting
Date: Jul 14, 2005
Hi everybody, for those of you with a slider canopy, where have you installed the ELT. As I would like to have the ELT near me in case I have to leave the aircraft in a hurry, I was thinking of mounting the unit itself on the tunnel cover between the two seats, with the antenna mounted stationary somewhere behind the seat. It can not be mounted on the slider and I don't want to mount it outside on the fuselage. Any ideas from the builders before me, Thanks Franz RV7A -- ________________________________________________________________________________
From: "Stan & Aylene Bahrns" <bahrns(at)effingham.net>
Date: Jul 14, 2005
I have the same problem. I think I am going to mount the ELT behind the seat & I finally found an antenna that is just a wire as allthe ones I had earlier had a spring on the end which lookes like lots of drag. I am thinking about mounting it under the aircraft a little ahead of the tail as in mosst cases the RV's end up on their top & then the antenna would be in the right position. Unlike the tip up canopy there are no place to put them inside that I can find. If you have any better ideas I would be interested to hear them. Thanks, Stan Bahrns RV7-A from IL Phone (217)342-2909 Fax (217)342-4342 Work email: stanb(at)bahrns.com Home email: bahrns(at)effingham.net Hi everybody, for those of you with a slider canopy, where have you installed the ELT. As I would like to have the ELT near me in case I have to leave the aircraft in a hurry, I was thinking of mounting the unit itself on the tunnel cover between the two seats, with the antenna mounted stationary somewhere behind the seat. It can not be mounted on the slider and I don't want to mount it outside on the fuselage. Any ideas from the builders before me, Thanks Franz RV7A -- -- -- ________________________________________________________________________________
Subject: Electrical Tools-Wiring Supplies-Harnesses and More
Date: Jul 15, 2005
Hi Everyone, With Matt Dralle's permission, I wanted to let everyone on the list know that Affordable Panels has added electrical tools, electrical supplies, wiring harnesses and more to our inventory. We have some of the lowest prices on everything from tools, terminals, connectors, wire, electroluminescent lighting, etc. Our wiring harnesses for all Trutrak Autopilots are available in "Standard" and "Wing Root Disconnect" form, and we also offer harnesses for the Dynon EFIS, Flightcom and many others at the very best prices. Our full page catalog will be out in a couple of weeks. In the mean time, anyone interested can download the electrical portion of our catalog here. http://www.affordablepanels.com/electrical.htm All electrical orders placed on-line or faxed with a total above $175.00 will ship free via UPS GROUND. Best Regards, Fabian Lefler www.affordablepanels.com ________________________________________________________________________________
Date: Jul 16, 2005
From: Garey Wittich <gareywittich2000(at)yahoo.com>
Subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL
> This Information comes from my own research which I did for > my RV-8A, which I am building. Information applies to both Aluminum and Composite aircraft. This is the 3th printing. > > --------------- ------------- ------------ > > SAVE YOURSELF hundreds of hours of research time and > building time, by using the comprehensive > > "Guide to Painting & Corrosion Control of Aluminum > and > Composite Aircraft" > > This book took over 600+ hours of research time by > me, > a fussy RV-8A Builder. Contains 69 pages of the > latest, practical information - summarized and > gathered from MIL Standards, Paint Shops, Builders > like you (what worked or didn't), Airframe Mfgs, > etc. > Covers products from PP&G, Dupont, Sherwin W'ms, > Sterling, Poly Fiber, Deft, Randolph Paints, PRC De > Soto, US Paints, Aircraft Finishing Systems, 3M, > etc. > > Some of the Topics covered in the 30 Sections are: > * Aircraft Paints vs Auto Paints and Other > Considerations > * Corrosion Control > * Spray Guns - selecting, adjusting, using > and painting problems > * Brushes / Rollers used with Primers & > Paints > * Prep Methods for Painting - Fiberglass, > Steel and Aluminum > * Epoxy Primers for Aluminum - MIL & > Commercial, Solvent & Water Reducible > * Primers for Fiberglass & Steel > * Wash Primers & Self Etching Primers > * Other Primers - Zinc Chromate,Zinc Oxide, > Enamel > * Paint Types: MIL & Non MIL Polyurethanes > Enamel Types > Acrylics - Lacquers & Enamels > * Acid Etch / Conversion Coatings (Alodine) > * Selecting a Paint Shop > * 3M Cleaning Pads, Liquid Cleaner > compatibility > * Paint Booths and their Construction > * References - MIL Standards & Tech Orders > * Directory of Aircraft Paint Mfgs, Distrib- > utors, etc. E-Mail addresses, phone > numbers, Application Notes > > YOUR AIRPLANE is judged by it's Paint Job and it is > costly too, so have the latest "Information" in > order > to make good decisions. Contains plenty of "Do's" > and > "Don'ts" that save you time, money and frustration. > > Send a check for $26 to (includes Postage within the > US) to: > Garey Wittich RV-8A Builder > 58 Village Parkway > Santa Monica, CA. 90405 > > __________________________________ http://mobile.yahoo.com/learn/mail ________________________________________________________________________________
Date: Jul 17, 2005
Subject: Change of Heart 7A to 7 ???
Big question, but first the short story. I live on a grass field in Oklahoma, and at one time we had three RV's on the field plus several factory planes. So after much research and time making promises to my wife, I decided to build an RV 7A. I've got the tail done and the wing almost there (after a three month absence working honey do list). I also have the fuselage kit on the shelf ready to start this fall. So my big question is what if I wanted to change to a "7" tail dragger... what would it take? Just looking at the two aircraft on Van's web site it looks like the change is in the fuselage kit, so I would have to send my engine mount and landing gear back and get the tail wheel, is this correct. I'm sure I'm not the first to change their mind. One might wonder what drive me to a big change in plans. Believe it or not it was safety. Grass fields and tail wheels go together, plus don't forget the sexy look of a day gone by. Can anyone tell me if they've ever done the conversion at this point of the game? Thanks, Dan S. OKC ________________________________________________________________________________
Subject: DWG 28 hole callouts in two spots
Date: Jul 17, 2005
Hi folks: Two questions based on notes on DWG 28 regarding fuselage skin holes to be drilled. 1) One is a notation on the bottom skin where the corner rib fits. It says "enlarge this hole for flap rod access" (or something like that), but does not call out a dimension. I assume it's pretty small considering how close it sits to rivets on either side, but I'm curious what size hole is called for here. 2) The other is the static port. The location is clearly shown on DWG 28, but not he size of the hole for the port. Anyone? And thank you Bob St. Paul, Minn. ________________________________________________________________________________
Date: Jul 17, 2005
Subject: Re: DWG 28 hole callouts in two spots
The hole for the flap pushrods is surprisingly large. It has to accommodate the size of the rod end bearing. I waited until I mated the wings and had the flaps on and then gradually enlarged the hole until there was no interference with the pushrod. Then I traced the hole onto a piece of paper and transferred it to the other side. I had a couple of pictures of other people's planes that I used as a starting point. The hole is kind of an inverted V on the side of the fuselage and kind of a slot on the bottom. The hole actually took out 2 rivets on the bottom. Probably the best thing to do is wait until next week and trace someone else's holes at Oshkosh and use that as a template for yours. As far as the static port hole goes, I believe this is just a #30 hole for the rivet. I'm not positive about this but if you track down the static port rivet itself you should be able to tell for sure. Dan RV-7A Just starting the canopy Bob Collins wrote: Hi folks: Two questions based on notes on DWG 28 regarding fuselage skin holes to be drilled. 1) One is a notation on the bottom skin where the corner rib fits. It says "enlarge this hole for flap rod access" (or something like that), but does not call out a dimension. I assume it's pretty small considering how close it sits to rivets on either side, but I'm curious what size hole is called for here. 2) The other is the static port. The location is clearly shown on DWG 28, but not he size of the hole for the port. Anyone? And thank you Bob St. Paul, Minn. --------------------------------- ________________________________________________________________________________
Date: Jul 17, 2005
OK, one more question. In taking off the left and right skins, I realized today that there are 4 vertical rivets -- apparently #40s -- just forward (maybe 4-5 inches) of the big center section bulkhead. They were not drilled and nothing in the process up to this point apparently called for them to be fitted to anything. But DWG 28 says these are dimpled rivets and if I'm going to dimple these four, I need to do it now. I checked the various drawings and could not find the use for these four rivets. Anyone? bob -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Dan Reeves Subject: Re: RV7-List: DWG 28 hole callouts in two spots The hole for the flap pushrods is surprisingly large. It has to accommodate the size of the rod end bearing. I waited until I mated the wings and had the flaps on and then gradually enlarged the hole until there was no interference with the pushrod. Then I traced the hole onto a piece of paper and transferred it to the other side. I had a couple of pictures of other people's planes that I used as a starting point. The hole is kind of an inverted V on the side of the fuselage and kind of a slot on the bottom. The hole actually took out 2 rivets on the bottom. ________________________________________________________________________________
Date: Jul 17, 2005
Hello Bob, I think the holes you are referring to are the holes for the air vent angle support. If so, don't dimple these yet as you will use them to match drill the vent angle. You can dimple later with a pop rivet dimpler. Have a great day, Bill -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Bob Collins Subject: RE: RV7-List: DWG 28 hole callouts in two spots OK, one more question. In taking off the left and right skins, I realized today that there are 4 vertical rivets -- apparently #40s -- just forward (maybe 4-5 inches) of the big center section bulkhead. They were not drilled and nothing in the process up to this point apparently called for them to be fitted to anything. But DWG 28 says these are dimpled rivets and if I'm going to dimple these four, I need to do it now. I checked the various drawings and could not find the use for these four rivets. Anyone? bob -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Dan Reeves Subject: Re: RV7-List: DWG 28 hole callouts in two spots The hole for the flap pushrods is surprisingly large. It has to accommodate the size of the rod end bearing. I waited until I mated the wings and had the flaps on and then gradually enlarged the hole until there was no interference with the pushrod. Then I traced the hole onto a piece of paper and transferred it to the other side. I had a couple of pictures of other people's planes that I used as a starting point. The hole is kind of an inverted V on the side of the fuselage and kind of a slot on the bottom. The hole actually took out 2 rivets on the bottom. ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Jul 17, 2005
> > Hi folks: > Two questions based on notes on DWG 28 regarding fuselage skin holes to > be drilled. > > 1) One is a notation on the bottom skin where the corner rib fits. It says > "enlarge this hole for flap rod access" (or something like that), but does > not call out a dimension. I assume it's pretty small considering how close > it sits to rivets on either side, but I'm curious what size hole is called > for here. (((((((( I left this hole for cutting out until I mounted the > flaps and could actually get to working it up and down. Better to wait > unless you want to risk making it too small or in the slightly wrong > place. The shape is irregular is the best way to say it. ))))))) > > 2) The other is the static port. The location is clearly shown on DWG 28, > but not he size of the hole for the port. Anyone?(((((((You should buy > either Vans or someone else's static air kit first. That will tell you > what size hole you need. I suggest you use Van's static air kit even > though some think it is less than robust. I have used it now with 50 > hours flying and it works!!!!!! Indiana Larry, RV7, tip up, > flying.))))))))) > ________________________________________________________________________________
"RV10 Group" ,
Subject: DRDT-2 dimpling tool at Oshkosh
Date: Jul 17, 2005
Fellow RV builders. The DRDT-2 (www.experimentalaero.com) will be on display at the EAA sheet metal workshop and or the Avery Tool booth at Oshkosh. I will be at AirVenture from Monday through Saturday. Stop by and give the DRDT-2 a test drive. For those of you who already own one, I'd enjoy meeting you so stop by and say hi. Paul Merems ExperimentalAero ________________________________________________________________________________
Date: Jul 18, 2005
Hey Dan, It is certainly doable...I have a friend building a 7a form a 7...I.e going the other way to you. Now I wonder if I could set you guys and maybe you could help each other out to swap the parts if you have all your on hand? Let me know if your interested. Frank in Oregon -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Daniel Storer Subject: RV7-List: Change of Heart 7A to 7 ??? Big question, but first the short story. I live on a grass field in Oklahoma, and at one time we had three RV's on the field plus several factory planes. So after much research and time making promises to my wife, I decided to build an RV 7A. I've got the tail done and the wing almost there (after a three month absence working honey do list). I also have the fuselage kit on the shelf ready to start this fall. So my big question is what if I wanted to change to a "7" tail dragger... what would it take? Just looking at the two aircraft on Van's web site it looks like the change is in the fuselage kit, so I would have to send my engine mount and landing gear back and get the tail wheel, is this correct. I'm sure I'm not the first to change their mind. One might wonder what drive me to a big change in plans. Believe it or not it was safety. Grass fields and tail wheels go together, plus don't forget the sexy look of a day gone by. Can anyone tell me if they've ever done the conversion at this point of the game? Thanks, Dan S. OKC ________________________________________________________________________________
Date: Jul 18, 2005
Dan, The quick answer to your question is yes, it has been done, but in reverse. The current factory model RV7/7A was originally built as a tail dragger, and then converted over to the 7A which it is today. I am sure it is just a matter of swapping some of your parts such as the engine mount and landing gear legs. The brake line bracket for the firewall is different and I am sure there are a few other parts. Gary Dwinal -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Daniel Storer Subject: RV7-List: Change of Heart 7A to 7 ??? Big question, but first the short story. I live on a grass field in Oklahoma, and at one time we had three RV's on the field plus several factory planes. So after much research and time making promises to my wife, I decided to build an RV 7A. I've got the tail done and the wing almost there (after a three month absence working honey do list). I also have the fuselage kit on the shelf ready to start this fall. So my big question is what if I wanted to change to a "7" tail dragger... what would it take? Just looking at the two aircraft on Van's web site it looks like the change is in the fuselage kit, so I would have to send my engine mount and landing gear back and get the tail wheel, is this correct. I'm sure I'm not the first to change their mind. One might wonder what drive me to a big change in plans. Believe it or not it was safety. Grass fields and tail wheels go together, plus don't forget the sexy look of a day gone by. Can anyone tell me if they've ever done the conversion at this point of the game? Thanks, Dan S. OKC NOTICE: The information contained in this communication is intended solely for use by the designated recipient(s). This communication may also contain confidential or proprietary information and may be subject to confidentiality protection under the law. If you are not a designated recipient, you may not review, copy, or distribute this message. If you receive this message in error, please notify the sender and destroy your copy. Thank you for your cooperation. Fisher Engineering, a division of Douglas Dynamics, LLC ________________________________________________________________________________
Subject: Re: Change of Heart 7A to 7 ???
Date: Jul 18, 2005
Conversion from a *completed* -7A to -7... Starting with the rear half... Remove the rudder and elevators. Probably want to get the aft elevator pushrod out to make room. Drill the tiedown bracket off the rear bulkhead, no big deal. Cut the "mouse hole" in the bottom of the tailcone skin for the tailwheel spring mount. But can you even get a tailwheel spring mount in there between F-711 and F-712 once the aft deck is installed? Will it fit into the inspection hole? And then can you phenagle it to get it oriented? Probably doable, but I'm guessing it's tough at best. Good friggin' luck getting back there to rivet that stuff in. I actually think you'd be better off drilling out the aft rivets on the side skins, or at leastt one side, and peeling that side skin back (forward) to gain access to the bay between F-711 and F-712, and a little access forward of F-711 for bucking/shooting/squeezing. I personally wouldn't want my tailwheel spring installed with pop rivets, but that's just me. Careful on the alignment when re-riveting that side skin and the tailcone together. Take care not to introduce twist. Install the tailwheel spring and tailwheel. Install chains or a rocket steering link or what have you. Rig that up. Moving forward... Remove the steps, then you gotta patch those holes. Or just keep 'em on, but you don't need 'em on the taildragger. If you do remove 'em, will you have to drill out the baggage floor skins? Don't think so, since I believe the steps just slide out and aren't fastened inboard, but I'm not positive. Double check that. Move to the front half... Rip out all the brake lines. Most likely rip out your fuel supply tubing as well (easy to redo once the weldments are gone). Pull the engine. (yes, pull the engine) Hoist the plane. Remove the nose gear. Remove the engine mount. Replace it with a taildragger engine mount...you will need to cut clearance notches into the bottom corners of the firewall flange for the new location of the mains. Remove the main gear legs. Install them in the new engine mount. Jeez, can you even do that? I understand the mains are match-drilled to the engine mount. You may need to get new gear legs that are match drilled for your new engine mount. Figure that out. Plane is now on gear again. Remove the weldments from in front of F-704. Fill all the holes with shorter bolts. Now you've got exterior holes to patch: - step holes - old main gear holes in the fuselage - lower cowl old nosegear "slot" Cut new holes in the lower cowl, aft lower corners, for the new mains. Install new brake lines through the firewall. Don't forget the reinforcement "patch" on the firewall where the fittings pass through. Possibly install new main gear leg fairings. New upper gear leg intersection fairings. Redo your weight and balance. Do the requisite flight testing. .... I personally wouldn't want to go through all of this. Just build a taildragger from the get-go if that's what you want! )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Gary Dwinal" <GDwinal(at)fisherplows.com> Subject: RE: RV7-List: Change of Heart 7A to 7 ??? > > > Dan, > The quick answer to your question is yes, it has been done, but in > reverse. The current factory model RV7/7A was originally built as a > tail dragger, and then converted over to the 7A which it is today. I am > sure it is just a matter of swapping some of your parts such as the > engine mount and landing gear legs. The brake line bracket for the > firewall is different and I am sure there are a few other parts. > > Gary Dwinal > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Daniel Storer > To: rv7-list(at)matronics.com > Subject: RV7-List: Change of Heart 7A to 7 ??? > > > Big question, but first the short story. I live on a grass field in > Oklahoma, and at one time we had three RV's on the field plus several > factory planes. So after much research and time making promises to my > wife, I decided to build an RV 7A. I've got the tail done and the wing > almost there (after a three month absence working honey do list). I > also have the fuselage kit on the shelf ready to start this fall. > > So my big question is what if I wanted to change to a "7" tail > dragger... what would it take? Just looking at the two aircraft on > Van's web site it looks like the change is in the fuselage kit, so I > would have to send my engine mount and landing gear back and get the > tail wheel, is this correct. I'm sure I'm not the first to change their > mind. One might wonder what drive me to a big change in plans. Believe > it or not it was safety. Grass fields and tail wheels go together, plus > don't forget the sexy look of a day gone by. > > Can anyone tell me if they've ever done the conversion at this point of > the game? > > Thanks, > > Dan S. > OKC > > > NOTICE: The information contained in this communication is intended solely > for use by the designated recipient(s). This communication may also > contain confidential or proprietary information and may be subject to > confidentiality protection under the law. If you are not a designated > recipient, you may not review, copy, or distribute this message. If you > receive this message in error, please notify the sender and destroy your > copy. > > Thank you for your cooperation. > > Fisher Engineering, a division of Douglas Dynamics, LLC > > > ________________________________________________________________________________
Date: Jul 18, 2005
You might find someone in the area that is going to build a -7A and is just about ready to order the fuse kit. Have them buy the -7 kit and trade parts. Otherwise I think it's basically sending back your main gear weldments, the engine mount, the rear tie down, and the nose gear stuff. Then you'll get the tailwheel weldment, the tail wheel spring, wheel, etc., the other engine mount, the little fuse gussets and probably some hardware. The only thing that I can think of that might bite you would be the holes in the VS rear spar. On the -7 your not supposed to drill them until you mount the VS to the fuse but I don't know about those "other" planes. :-) I think the NG guys have four AN3 bolts and we TD guys have three AN4 bolts. They probably don't interfere since the conversion has been done on other aircraft. If you haven't drilled the holes in the VS then it doesn't matter. Since you haven't built the fuse then this is just a parts exchange. Other than the VS attach holes there are no differences between the -7 and -7A on the tail or wings. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB - Finishing Up http://www.myrv7.com Daniel Storer wrote: > > >Big question, but first the short story. I live on a grass field in >Oklahoma, and at one time we had three RV's on the field plus several >factory planes. So after much research and time making promises to my wife, >I decided to build an RV 7A. I've got the tail done and the wing almost >there (after a three month absence working honey do list). I also have the >fuselage kit on the shelf ready to start this fall. > >So my big question is what if I wanted to change to a "7" tail dragger... >what would it take? Just looking at the two aircraft on Van's web site it >looks like the change is in the fuselage kit, so I would have to send my >engine mount and landing gear back and get the tail wheel, is this correct. >I'm sure I'm not the first to change their mind. One might wonder what >drive me to a big change in plans. Believe it or not it was safety. Grass >fields and tail wheels go together, plus don't forget the sexy look of a day >gone by. > >Can anyone tell me if they've ever done the conversion at this point of the >game? > >Thanks, > >Dan S. >OKC > > > > ________________________________________________________________________________
Date: Jul 22, 2005
Frank, There is a good chance the swap out might work. If I do this I'll be shipping parts back to Van's anyway, and I rather help out a fellow builder. I'll be in Oshkosh next week speak to as many RV'ers as I can along with pics of all the good stuff. I plan to stop by Van's booth and ask for their input. Regards -------Original Message------- From: Hinde, Frank George (Corvallis) Date: 07/18/05 10:40:18 Subject: RE: RV7-List: Change of Heart 7A to 7 ??? hinde(at)hp.com> Hey Dan, It is certainly doable...I have a friend building a 7a form a 7...I.e going the other way to you. Now I wonder if I could set you guys and maybe you could help each other out to swap the parts if you have all your on hand? Let me know if your interested. Frank in Oregon -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Daniel Storer Subject: RV7-List: Change of Heart 7A to 7 ??? Big question, but first the short story. I live on a grass field in Oklahoma, and at one time we had three RV's on the field plus several factory planes. So after much research and time making promises to my wife, I decided to build an RV 7A. I've got the tail done and the wing almost there (after a three month absence working honey do list). I also have the fuselage kit on the shelf ready to start this fall. So my big question is what if I wanted to change to a "7" tail dragger... what would it take? Just looking at the two aircraft on Van's web site it looks like the change is in the fuselage kit, so I would have to send my engine mount and landing gear back and get the tail wheel, is this correct. I'm sure I'm not the first to change their mind. One might wonder what drive me to a big change in plans. Believe it or not it was safety. Grass fields and tail wheels go together, plus don't forget the sexy look of a day gone by. Can anyone tell me if they've ever done the conversion at this point of the game? Thanks, Dan S. OKC ________________________________________________________________________________
Subject: Landing gear or not?
Date: Jul 26, 2005
Morning all, Engine should be with me in the next week or so. The airframe is ready but I was wondering whether to put the fuse on the landing gear or not? I have a tractor with a front loader so lifting the airframe plus engine(with a nylon strap under the fuse or around engine mount) up onto its gear later would be no problem. I have not installed any instruments/wiring so was thinking having to not have to climb up into the plane with it on its gear might be an ergonomic advantage. Anyone have any thoughts on this approach?? Thanks RV7a...fuse complete..almost..:) ________________________________________________________________________________
Subject: Re: Landing gear or not?
Date: Jul 26, 2005
My opinion is that you should finish as much of your wiring as humanly possible before installing the engine. I had a much easier time wiring with my engine NOT installed, and with the fuse on a short sawhorse, since I could stand right in front of the firewall and reach back in. Basically, here's my advice fwiw... Finish the fuselage interior. Paint it if you want. Install the sub-panel and associated front deck structure. Install your panel, instruments, avionics. Wire everything up. Install as many firewall doodads as you can before the engine goes on (battery box, contactors, transducer manifold, brake fluid reservoir, nutplates for this and that, bulkhead fittings for fuel & stuff, etc. Install the engine mount. Put it on gear. Hang the engine. Just my 2 cents, )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com> Subject: RV7-List: Landing gear or not? > > > Morning all, > > Engine should be with me in the next week or so. The airframe is ready > but I was wondering whether to put the fuse on the landing gear or not? > > I have a tractor with a front loader so lifting the airframe plus > engine(with a nylon strap under the fuse or around engine mount) up onto > its gear later would be no problem. > > I have not installed any instruments/wiring so was thinking having to > not have to climb up into the plane with it on its gear might be an > ergonomic advantage. > > Anyone have any thoughts on this approach?? > > Thanks > > RV7a...fuse complete..almost..:) > > > ________________________________________________________________________________
Date: Jul 26, 2005
Thanks Dan, Certainly hard to argue with your success but unfortunatly the engine is on its way and I can't quite afford the instruments yet. Van's said to do the engine first and the wiring after. Oh well..Another couple of months and I'll be ready to order instruments so it looks like I'm stuck with hanging the engine before wiring. I have the firewall just about ready but as the invert kit is coming with the engine I wanted to have everything in hand before I bolt on the battery box and contactors. Sounds like having the thing down low is an advantage though so I can easily lift it off its landing gear and set it back down on a low sawhorse with the engine in place (might have to drop off the exhaust as well I guess). Its an adventure right?...:) Frank -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Dan Checkoway Subject: Re: RV7-List: Landing gear or not? My opinion is that you should finish as much of your wiring as humanly possible before installing the engine. I had a much easier time wiring with my engine NOT installed, and with the fuse on a short sawhorse, since I could stand right in front of the firewall and reach back in. Basically, here's my advice fwiw... Finish the fuselage interior. Paint it if you want. Install the sub-panel and associated front deck structure. Install your panel, instruments, avionics. Wire everything up. Install as many firewall doodads as you can before the engine goes on (battery box, contactors, transducer manifold, brake fluid reservoir, nutplates for this and that, bulkhead fittings for fuel & stuff, etc. Install the engine mount. Put it on gear. Hang the engine. Just my 2 cents, )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com> Subject: RV7-List: Landing gear or not? > > > Morning all, > > Engine should be with me in the next week or so. The airframe is ready > but I was wondering whether to put the fuse on the landing gear or not? > > I have a tractor with a front loader so lifting the airframe plus > engine(with a nylon strap under the fuse or around engine mount) up onto > its gear later would be no problem. > > I have not installed any instruments/wiring so was thinking having to > not have to climb up into the plane with it on its gear might be an > ergonomic advantage. > > Anyone have any thoughts on this approach?? > > Thanks > > RV7a...fuse complete..almost..:) > > > ________________________________________________________________________________
Subject: Panel wiring
Date: Jul 26, 2005
Well, well. Just talked to John Stark and he will sell me the trays for all my panel toys now and build the wiring harness. He will then credit the full cost of the trays towards my avionics when I purchase them. This is very very cool because it means I can do all the wiring and completely defray the cost of the avionics. As I have to save for everything before I buy it (It's a function of being an English tightwad) this allows me to install wiring before engine as Dan suggested below. Pretty neat huh? My opinion is that you should finish as much of your wiring as humanly possible before installing the engine. I had a much easier time wiring with my engine NOT installed, and with the fuse on a short sawhorse, since I could stand right in front of the firewall and reach back in. Basically, here's my advice fwiw... Finish the fuselage interior. Paint it if you want. Install the sub-panel and associated front deck structure. Install your panel, instruments, avionics. Wire everything up. Install as many firewall doodads as you can before the engine goes on (battery box, contactors, transducer manifold, brake fluid reservoir, nutplates for this and that, bulkhead fittings for fuel & stuff, etc. Install the engine mount. Put it on gear. Hang the engine. Just my 2 cents, )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Jul 26, 2005
Yup, that's the best way, and the way I'm attacking mine. Practically all my wiring is done now bar a few odds and ends, so I put the plane up on it's gear the other week. It's funny, because when it's down on a sawhorse, it makes progress seem so slow. When it goes up on the wheels though, it's like WOW! I'm almost done! Well, seems like it anyway, but I know it's nowhere even close still! Mark www.4sierratango.com >From: "Dan Checkoway" <dan(at)rvproject.com> >Reply-To: rv7-list(at)matronics.com >To: >Subject: Re: RV7-List: Landing gear or not? >Date: Tue, 26 Jul 2005 10:06:04 -0700 > > >My opinion is that you should finish as much of your wiring as humanly >possible before installing the engine. I had a much easier time wiring >with >my engine NOT installed, and with the fuse on a short sawhorse, since I >could stand right in front of the firewall and reach back in. > >Basically, here's my advice fwiw... > >Finish the fuselage interior. Paint it if you want. Install the sub-panel >and associated front deck structure. Install your panel, instruments, >avionics. Wire everything up. Install as many firewall doodads as you can >before the engine goes on (battery box, contactors, transducer manifold, >brake fluid reservoir, nutplates for this and that, bulkhead fittings for >fuel & stuff, etc. Install the engine mount. Put it on gear. Hang the >engine. > >Just my 2 cents, >)_( Dan >RV-7 N714D >http://www.rvproject.com > >----- Original Message ----- >From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com> >To: >Subject: RV7-List: Landing gear or not? > > > > > > > > Morning all, > > > > Engine should be with me in the next week or so. The airframe is ready > > but I was wondering whether to put the fuse on the landing gear or not? > > > > I have a tractor with a front loader so lifting the airframe plus > > engine(with a nylon strap under the fuse or around engine mount) up onto > > its gear later would be no problem. > > > > I have not installed any instruments/wiring so was thinking having to > > not have to climb up into the plane with it on its gear might be an > > ergonomic advantage. > > > > Anyone have any thoughts on this approach?? > > > > Thanks > > > > RV7a...fuse complete..almost..:) > > > > > > > > ________________________________________________________________________________
Subject: Map Box
Date: Jul 28, 2005
Hi guys, The drawing for the map box shows cut out's in two different location on the instrument pnel depending on whether it is a tip-up or slider canopy. The tip up is shown lower on theinstrument panel than the slider. I have a tip up but want to pit the map box up higher like on the slider to fit the Dynon engine instrument under the map box. It will fit but only if the map box is up higher. I can't see any reason the map box can't go up high but wondered if anyone had any actual experience on this...i did phone Van's but guess where they are?..:) Thanks Frank ________________________________________________________________________________
Subject: Re: Map Box
Date: Jul 28, 2005
The tip up frame, the C channel at the front of the canopy, comes down about 2 or 3 inches from the top. That's about all I can think of at the moment... )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com> Subject: RV7-List: Map Box > > > Hi guys, > > The drawing for the map box shows cut out's in two different location on > the instrument pnel depending on whether it is a tip-up or slider > canopy. > > The tip up is shown lower on theinstrument panel than the slider. > > I have a tip up but want to pit the map box up higher like on the slider > to fit the Dynon engine instrument under the map box. It will fit but > only if the map box is up higher. > > I can't see any reason the map box can't go up high but wondered if > anyone had any actual experience on this...i did phone Van's but guess > where they are?..:) > > Thanks > > Frank > > > ________________________________________________________________________________
Date: Jul 29, 2005
Subject: Right hand seat?
Hello fellow-builders! I live i Norway and am starting on the empennage on my RV-7A QB next week. I'm considering building the cockpit so the right hand seat is the pilot-seat. That way I can have the right hand on the stick and the left on throttle and prop-control. That suits and ex-fighterpilot better! hehe! I have not decided on engine or instruments yet, but the inndodyn turbine sure is interesting! Fuelprice for 100L here in Norway now is approx 6 USD per gallon! Jet A-1 is almost 1/3 of this... Diesel is approx half... I'm planning to fly both aerobatics and x-country so the Eggenfellner engine is no option I guess??. (price for autofuel is approx the same as for diesel) Does any of you have built an RV-7 with the right hand seat as primary? Will it be any big problems doing this? For example have I ordered elec aileron and elevator trim and lighting system nr 6 from Vans. Will this be ok or do I have to modify these sets to fit the right hand seat? Can anyone give me a good reason for why the left seat is standard pilot seat?? Best regards Alf Olav Frog, a builder-to-be... :-) ________________________________________________________________________________
Date: Jul 29, 2005
I'm building mine from the left seat and am told it is easy to change hands....But I'm nervous about it. If I can't deal with it it does not look "THAT" big of a deal to install a little sub panel and mount the cables on the left...Assuming the lengths will still work. The reason the left seat is standard is because most the traffic patterns turn to the left so its easier to see where your going. Forget the Innodyn, I been following it for months...Highly unlikely its going to work out. As for the Eggenfelner, yes it is a good package but it is still debatable as to what performance loss there is running a water cooled moter (extra cooling drag) in a slippery RV...In the early versions it was reputed to be 25 mph at cruise...or cruise at the same speed but use a lot more fuel. Until there is a head to head fly off I we won't know for sure. Hae you thought about a Lycoming clone?...Word is they will run perfectly well on autofuel and that is what I am planning albeit a slightly different fuel pumping layout to be sure to avoid vapour lock, and please don't all start a war on me...yes autofuel will lean perfectly well too as long as a close eye is kept on the CHT monitor. You have a quite a ways to go before ordering the engine plenty of time to look at options. All the best Frank -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Alf Olav Frog Subject: RV7-List: Right hand seat? Hello fellow-builders! I live i Norway and am starting on the empennage on my RV-7A QB next week. I'm considering building the cockpit so the right hand seat is the pilot-seat. That way I can have the right hand on the stick and the left on throttle and prop-control. That suits and ex-fighterpilot better! hehe! I have not decided on engine or instruments yet, but the inndodyn turbine sure is interesting! Fuelprice for 100L here in Norway now is approx 6 USD per gallon! Jet A-1 is almost 1/3 of this... Diesel is approx half... I'm planning to fly both aerobatics and x-country so the Eggenfellner engine is no option I guess??. (price for autofuel is approx the same as for diesel) Does any of you have built an RV-7 with the right hand seat as primary? Will it be any big problems doing this? For example have I ordered elec aileron and elevator trim and lighting system nr 6 from Vans. Will this be ok or do I have to modify these sets to fit the right hand seat? Can anyone give me a good reason for why the left seat is standard pilot seat?? Best regards Alf Olav Frog, a builder-to-be... :-) ________________________________________________________________________________
Subject: Re: Right hand seat?
Date: Jul 29, 2005
One alternative might be to put the throttle quadrant on the left and stay in the left seat - take a look at Dan Checkoway's site for an example ... http://www.rvproject.com g > > > Hello fellow-builders! > > I live i Norway and am starting on the empennage on my RV-7A QB > next week. > > I'm considering building the cockpit so the right hand seat is > the pilot-seat. > That way I can have the right hand on the stick and the left on > throttle and prop-control. That suits and ex-fighterpilot > better! hehe! > > I have not decided on engine or instruments yet, but the > inndodyn turbine sure is interesting! > Fuelprice for 100L here in Norway now is approx 6 USD per gallon! > Jet A-1 is almost 1/3 of this... > Diesel is approx half... > I'm planning to fly both aerobatics and x-country so the > Eggenfellner engine is no option I guess??. (price for autofuel > is approx the same as for diesel) > > Does any of you have built an RV-7 with the right hand seat as primary? > Will it be any big problems doing this? > For example have I ordered elec aileron and elevator trim and > lighting system nr 6 from Vans. Will this be ok or do I have to > modify these sets to fit the right hand seat? > > Can anyone give me a good reason for why the left seat is > standard pilot seat?? > > Best regards Alf Olav Frog, a builder-to-be... :-) > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Jul 29, 2005
On 2:25:18 2005-07-29 Alf Olav Frog wrote: > Does any of you have built an RV-7 with the right hand seat as > primary? Will it be any big problems doing this? > For example have I ordered elec aileron and elevator trim and > lighting system nr 6 from Vans. Will this be ok or do I have to modify > these sets to fit the right hand seat? I'm building mine this way as well. There are no technical limitations that preclude putting the pilot's seat on the right side. Since you're building it from the start, you can put anything you need where you want it. Electric trim and lighting hardware can all be mounted for right seat pilots. Another option would be to install dual engine controls, one set in the center of the panel and one on the left side of the left seat. Many people have done this, but in my opinion the installations i've seen have all looked like afterthoughts. The ones i've tried have all felt either too loose or too tight, because of the extra hardware for the two systems. > Can anyone give me a good reason for why the left seat is standard > pilot seat?? Standard circuits are left-hand, so you are always on the side that can see the airport. Not a problem in a military (tandem seating) airplane. -Rob ________________________________________________________________________________
Date: Jul 29, 2005
I thought it was the brits that liked sitting on the wrong side. ;> -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Alf Olav Frog Subject: RV7-List: Right hand seat? Hello fellow-builders! I live i Norway and am starting on the empennage on my RV-7A QB next week. I'm considering building the cockpit so the right hand seat is the pilot-seat. That way I can have the right hand on the stick and the left on throttle and prop-control. That suits and ex-fighterpilot better! hehe! I have not decided on engine or instruments yet, but the inndodyn turbine sure is interesting! Fuelprice for 100L here in Norway now is approx 6 USD per gallon! Jet A-1 is almost 1/3 of this... Diesel is approx half... I'm planning to fly both aerobatics and x-country so the Eggenfellner engine is no option I guess??. (price for autofuel is approx the same as for diesel) Does any of you have built an RV-7 with the right hand seat as primary? Will it be any big problems doing this? For example have I ordered elec aileron and elevator trim and lighting system nr 6 from Vans. Will this be ok or do I have to modify these sets to fit the right hand seat? Can anyone give me a good reason for why the left seat is standard pilot seat?? Best regards Alf Olav Frog, a builder-to-be... :-) ________________________________________________________________________________
Date: Jul 29, 2005
In a message dated 7/29/2005 12:42:17 PM Eastern Standard Time, dhall(at)donka.net writes: I'm considering building the cockpit so the right hand seat is the pilot-seat. That way I can have the right hand on the stick and the left on throttle and prop-control. That suits and ex-fighterpilot better! hehe! I am also an ex-fighter pilot. I decided to install a second throttle on left siderail, and kept the original throttle all hooked up. Works great, can fly from either seat now, with brakes on both sides too. ________________________________________________________________________________
Date: Jul 29, 2005
Interesting, so if I understand correctly you left the mixture, prop, and throttle in the middle and just added the second throttle? How did you connect the throttles together? I would love to do this method as I fly with the stick in my right hand...no jokes please..:) Frank Cutting instrument panel, RV 7a -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of OneFighterPilot(at)aol.com Subject: Re: RV7-List: Right hand seat? In a message dated 7/29/2005 12:42:17 PM Eastern Standard Time, dhall(at)donka.net writes: I'm considering building the cockpit so the right hand seat is the pilot-seat. That way I can have the right hand on the stick and the left on throttle and prop-control. That suits and ex-fighterpilot better! hehe! I am also an ex-fighter pilot. I decided to install a second throttle on left siderail, and kept the original throttle all hooked up. Works great, can fly from either seat now, with brakes on both sides too. ________________________________________________________________________________
Date: Jul 29, 2005
In a message dated 7/29/2005 3:23:05 PM Eastern Standard Time, frank.hinde(at)hp.com writes: Interesting, so if I understand correctly you left the mixture, prop, and throttle in the middle and just added the second throttle? How did you connect the throttles together? Yes, only throttle on left. Contact FBO guy here at Spruce Creek Fly-In for pix via email, etc. Paul Brevard at _SpruceCreekAir(at)BellSouth.net_ (mailto:SpruceCreekAir(at)BellSouth.net) He installed it, and both trottles work in unison just lovely. ________________________________________________________________________________
Date: Jul 29, 2005
Hey, I spent a lot of years in the UK, and that comment did not come from me. I love the Brits for many reasons, one of which is that they are usually smarter than us here in America on a number of issues. Unfortunately, one of them is not this frigging war. ________________________________________________________________________________
Date: Jul 29, 2005
From: "William J. Applegate" <bigapple(at)gct21.net>
Hi Alf, At some very, very distant point in the future you will be transferring ownership to someone else. I would not recommend building anything that would lessen the appeal to the "new" owner. I am a retired Air Force fighter pilot and now own an aircraft with two yokes and throttle, prop and mixture controls located in the center of the panel. I had never operated a prop before and was a little daunted by the concept, but it all has been a non issue. I'm sure that flying from the left seat will not be a problem for you. I would try to get a left seat ride with an IP and check it out before I made the decision to fixate on a right seat configuration. Best regards.......Bill Applegate, Tucson, Arizona, USA Alf Olav Frog wrote: > >Hello fellow-builders! > >I live i Norway and am starting on the empennage on my RV-7A QB next week. > >I'm considering building the cockpit so the right hand seat is the pilot-seat. >That way I can have the right hand on the stick and the left on throttle and prop-control. That suits and ex-fighterpilot better! hehe! > >I have not decided on engine or instruments yet, but the inndodyn turbine sure is interesting! >Fuelprice for 100L here in Norway now is approx 6 USD per gallon! >Jet A-1 is almost 1/3 of this... >Diesel is approx half... >I'm planning to fly both aerobatics and x-country so the Eggenfellner engine is no option I guess??. (price for autofuel is approx the same as for diesel) > >Does any of you have built an RV-7 with the right hand seat as primary? >Will it be any big problems doing this? >For example have I ordered elec aileron and elevator trim and lighting system nr 6 from Vans. Will this be ok or do I have to modify these sets to fit the right hand seat? > >Can anyone give me a good reason for why the left seat is standard pilot seat?? > >Best regards Alf Olav Frog, a builder-to-be... :-) > > > > ________________________________________________________________________________
Date: Jul 29, 2005
In a message dated 7/29/2005 3:55:40 PM Eastern Standard Time, OneFighterPilot(at)aol.com writes: Interesting, so if I understand correctly you left the mixture, prop, and throttle in the middle and just added the second throttle? How did you connect the throttles together? Yes, only throttle on left. Contact FBO guy here at Spruce Creek Fly-In for pix via email, etc. Paul Brevard at _SpruceCreekAir(at)BellSouth.net_ (mailto:SpruceCreekAir(at)BellSouth.net) He installed it, and both trottles work in unison just lovely. ________________________________________________________________________________
Date: Jul 30, 2005
Subject: 2 or 3 blade prop??
> > > Hello again! > > Thanks for all the inputs regarding the right hand seat! Great that there's a forum like this for us who are living outside of the "action"! > > Since I got so good response on my first issue, here's another choice I've to make: 2 or 3 blade prop? > > Ok, I know that the engine-choice is the first and biggest, but there I'm so far looking into different options.... what IS decided however, is a CS-prop. > > When the engine-choice is made, I'll check out the producers opinon regarding this, but what do you guys out there think?? > I was thinking that since I'm building a 7A, the distance to the ground from the propellertips would be slightly greater (better) with a 3 blade since this prop has a smaller diameter?? > Is there any big advantages or disadvantages with a 3 blade vs a 2 blade? (expect for the price...) > Is a 2 blade more efficient maybe?? > > > > Best regards Alf Olav Frog > > > ________________________________________________________________________________
Date: Jul 30, 2005
3-blade is less noisy. I bet that's a more important consideration in Europe than here in the States. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Alf Olav Frog Subject: RV7-List: 2 or 3 blade prop?? > > > Hello again! > > Thanks for all the inputs regarding the right hand seat! Great that there's a forum like this for us who are living outside of the "action"! > > Since I got so good response on my first issue, here's another choice I've to make: 2 or 3 blade prop? > > Ok, I know that the engine-choice is the first and biggest, but there I'm so far looking into different options.... what IS decided however, is a CS-prop. > > When the engine-choice is made, I'll check out the producers opinon regarding this, but what do you guys out there think?? > I was thinking that since I'm building a 7A, the distance to the ground from the propellertips would be slightly greater (better) with a 3 blade since this prop has a smaller diameter?? > Is there any big advantages or disadvantages with a 3 blade vs a 2 > blade? (expect for the price...) Is a 2 blade more efficient maybe?? > > > Best regards Alf Olav Frog > > ________________________________________________________________________________
Date: Jul 30, 2005
Subject: Re: 2 or 3 blade prop??
Alf Olav Frog wrote: > > > > >>Hello again! >> >>Thanks for all the inputs regarding the right hand seat! Great that there's a forum like this for us who are living outside of the "action"! >> >>Since I got so good response on my first issue, here's another choice I've to make: 2 or 3 blade prop? >> >>Ok, I know that the engine-choice is the first and biggest, but there I'm so far looking into different options.... what IS decided however, is a CS-prop. >> >>When the engine-choice is made, I'll check out the producers opinon regarding this, but what do you guys out there think?? >>I was thinking that since I'm building a 7A, the distance to the ground from the propellertips would be slightly greater (better) with a 3 blade since this prop has a smaller diameter?? >>Is there any big advantages or disadvantages with a 3 blade vs a 2 blade? (expect for the price...) >>Is a 2 blade more efficient maybe?? >> >> >> >>Best regards Alf Olav Frog >> 2 blades are usually cheaper & usually slightly faster. Someone will now jump in with info that their particular 3 blade is faster. ;-) 3 blades are usually smaller in diameter but there should be plenty of ground clearance anyway. 3 blades are usually a bit quieter & can be a bit smoother. Offsetting the quieter feature of the smaller diameter 3 blade is the fact that at low speeds the larger the diameter the more efficient (higher thrust per hp) the prop will be. Some pay the extra money for the 'cool' factor of the 3 blades. My opinion is that new modern airfoil 2 blades & 3 blades are close enough that the decision for me would come down to money. Charlie ________________________________________________________________________________
Date: Jul 30, 2005
Subject: ACS EFIS?
Hey guys.. Does anyone know if ACS has a standalone EFIS or if they still only offer the engine management system? thanks Jeff ________________________________________________________________________________
Date: Jul 31, 2005
There is an excellent article on the benefits and tradeoffs of 2 blade versus 3 blade props in the latest issue of "Aviation Consumer" magazine. You might want to get a copy. Bill Kelly RV-7A wannabe builder >> Hello again! >> >> Thanks for all the inputs regarding the right hand seat! Great that >> there's a forum like this for us who are living outside of the "action"! >> >> Since I got so good response on my first issue, here's another choice >> I've to make: 2 or 3 blade prop? >> >> Ok, I know that the engine-choice is the first and biggest, but there I'm >> so far looking into different options.... what IS decided however, is a >> CS-prop. >> >> When the engine-choice is made, I'll check out the producers opinon >> regarding this, but what do you guys out there think?? >> I was thinking that since I'm building a 7A, the distance to the ground >> from the propellertips would be slightly greater (better) with a 3 blade >> since this prop has a smaller diameter?? >> Is there any big advantages or disadvantages with a 3 blade vs a 2 blade? >> (expect for the price...) >> Is a 2 blade more efficient maybe?? >> >> >> >> Best regards Alf Olav Frog ________________________________________________________________________________
Date: Jul 31, 2005
After flying a Diamond with a three blade MT, it was more than enough to convince me. It was so smooth and quiet. I ordered my prop at Oshkosh this past week. A three blade MT. Mark. >From: "WILLIAM KELLY" <v1rotate(at)verizon.net> >Reply-To: rv7-list(at)matronics.com >To: >Subject: Re: RV7-List: 2 or 3 blade prop?? >Date: Sun, 31 Jul 2005 00:38:53 -0700 > > >There is an excellent article on the benefits and tradeoffs of 2 blade >versus 3 blade props in the latest issue of "Aviation Consumer" magazine. >You might want to get a copy. > >Bill Kelly >RV-7A wannabe builder > > >> Hello again! > >> > >> Thanks for all the inputs regarding the right hand seat! Great that > >> there's a forum like this for us who are living outside of the >"action"! > >> > >> Since I got so good response on my first issue, here's another choice > >> I've to make: 2 or 3 blade prop? > >> > >> Ok, I know that the engine-choice is the first and biggest, but there >I'm > >> so far looking into different options.... what IS decided however, is a > >> CS-prop. > >> > >> When the engine-choice is made, I'll check out the producers opinon > >> regarding this, but what do you guys out there think?? > >> I was thinking that since I'm building a 7A, the distance to the ground > >> from the propellertips would be slightly greater (better) with a 3 >blade > >> since this prop has a smaller diameter?? > >> Is there any big advantages or disadvantages with a 3 blade vs a 2 >blade? > >> (expect for the price...) > >> Is a 2 blade more efficient maybe?? > >> > >> > >> > >> Best regards Alf Olav Frog > > ________________________________________________________________________________
Date: Jul 31, 2005
A bit controversial this one but from my desk research my conclusion was the MT 3 blade prop reduced the speed of the airplane, but run smoother. The Hartzell prop although heavy was not quite as fast as the fastest of the bunch it's a lot cheaper. For me (highly personal decision) the Hartzell was the best value for money and they seem to have resolved their repair problems they were plagued with a few years ago....At least I know of several examples oflate with high hours and no issues. Frank -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Alf Olav Frog Subject: RV7-List: 2 or 3 blade prop?? > > > Hello again! > > Thanks for all the inputs regarding the right hand seat! Great that there's a forum like this for us who are living outside of the "action"! > > Since I got so good response on my first issue, here's another choice I've to make: 2 or 3 blade prop? > > Ok, I know that the engine-choice is the first and biggest, but there I'm so far looking into different options.... what IS decided however, is a CS-prop. > > When the engine-choice is made, I'll check out the producers opinon regarding this, but what do you guys out there think?? > I was thinking that since I'm building a 7A, the distance to the ground from the propellertips would be slightly greater (better) with a 3 blade since this prop has a smaller diameter?? > Is there any big advantages or disadvantages with a 3 blade vs a 2 > blade? (expect for the price...) Is a 2 blade more efficient maybe?? > > > > Best regards Alf Olav Frog > > > ________________________________________________________________________________
Date: Jul 31, 2005
Subject: RV 7 Party
Bob, Thanks for hosting this. I had a great time. You did an awful lot of work to make this happen. Please keep my email and let me know how I can help next year. John McDonnell ________________________________________________________________________________
Subject: that blue stuff
Date: Jul 31, 2005
I want to leave the protective blue film on my finished surfaces till it's absolutely necessary to remove it. So that could be 2-3 years for the blue film on all the finished tail feathers. I understand there is a chance that the adhesive gets old, stickier, and harder to remove. Anybody experienced that? ________________________________________________________________________________
Date: Jul 31, 2005
Subject: Re: that blue stuff
Don Hall wrote: > >I want to leave the protective blue film on my finished surfaces till it's >absolutely necessary to remove it. So that could be 2-3 years for the blue >film on all the finished tail feathers. I understand there is a chance that >the adhesive gets old, stickier, and harder to remove. Anybody experienced >that? > I've been removing some that's about 2 years old over the last couple of days. Most comes off easily. The sheets that are stubborn just leave some adhesive on the metal. I've found that a heat gun used to head the metal only a little (still not too hot to touch) has made mine release easily. It even helps with the stuff that's releasing ok, making the job go faster. Some have seen corrosion problems under the plastic. I've only seen a couple of very small spots at the edge of a piece that were less of a problem than some scratches that were there when I unboxed the parts. YMMV Charlie ________________________________________________________________________________
Subject: Map Box
Date: Jul 31, 2005
I built a map box and put it between the seats on my RV-7A tip up.......something you may want to consider. With a flip over padded top, it also serves as an arm rest for both pilot and passenger. Chuck N735RV -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Dan Checkoway Subject: Re: RV7-List: Map Box The tip up frame, the C channel at the front of the canopy, comes down about 2 or 3 inches from the top. That's about all I can think of at the moment... )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com> Subject: RV7-List: Map Box > > > Hi guys, > > The drawing for the map box shows cut out's in two different location on > the instrument pnel depending on whether it is a tip-up or slider > canopy. > > The tip up is shown lower on theinstrument panel than the slider. > > I have a tip up but want to pit the map box up higher like on the slider > to fit the Dynon engine instrument under the map box. It will fit but > only if the map box is up higher. > > I can't see any reason the map box can't go up high but wondered if > anyone had any actual experience on this...i did phone Van's but guess > where they are?..:) > > Thanks > > Frank > > ________________________________________________________________________________
Date: Jul 31, 2005
Heat gun helps but did not help much on my blue vinyl left on for 3 years. I let the painter take off the sticky stuff when he painted it. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Charlie England Subject: Re: RV7-List: that blue stuff Don Hall wrote: > >I want to leave the protective blue film on my finished surfaces till it's >absolutely necessary to remove it. So that could be 2-3 years for the blue >film on all the finished tail feathers. I understand there is a chance that >the adhesive gets old, stickier, and harder to remove. Anybody experienced >that? > I've been removing some that's about 2 years old over the last couple of days. Most comes off easily. The sheets that are stubborn just leave some adhesive on the metal. I've found that a heat gun used to head the metal only a little (still not too hot to touch) has made mine release easily. It even helps with the stuff that's releasing ok, making the job go faster. Some have seen corrosion problems under the plastic. I've only seen a couple of very small spots at the edge of a piece that were less of a problem than some scratches that were there when I unboxed the parts. YMMV Charlie ________________________________________________________________________________
Subject: Map Box
Date: Aug 01, 2005
I did think of this and have seen a few designs that might be easy to retrofit. At the moment I'm dealing with the Wife who is making deamnds like...I want a headrest, little pouches for everything, comfy seats etc etc. Now all of this is reasonable if I want her to travel long distances in this airplane..Trouble is I also know how building time goes exponential for all but the simplest of deviations from the plans.. OK so has put a PX headrest in their RV7 tip up?..:) Frank Finished cutting out the instrument panel....Coool! -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Imken Subject: RE: RV7-List: Map Box I built a map box and put it between the seats on my RV-7A tip up.......something you may want to consider. With a flip over padded top, it also serves as an arm rest for both pilot and passenger. Chuck N735RV ________________________________________________________________________________
Date: Aug 01, 2005
How are you going to get into the baggage area if you put in headrests?? Hinde, Frank George (Corvallis) wrote: > >I did think of this and have seen a few designs that might be easy to >retrofit. At the moment I'm dealing with the Wife who is making deamnds >like...I want a headrest, little pouches for everything, comfy seats etc >etc. > >Now all of this is reasonable if I want her to travel long distances in >this airplane..Trouble is I also know how building time goes exponential >for all but the simplest of deviations from the plans.. > >OK so has put a PX headrest in their RV7 tip up?..:) > >Frank >Finished cutting out the instrument panel....Coool! > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Imken >To: rv7-list(at)matronics.com >Subject: RE: RV7-List: Map Box > > >I built a map box and put it between the seats on my RV-7A tip >up.......something you may want to consider. With a flip over padded >top, it also serves as an arm rest for both pilot and passenger. >Chuck >N735RV > > > > ________________________________________________________________________________
Date: Aug 01, 2005
Frank, Would you mind going into some of the things you have found out about the Innodyn engine that would not make it suitable for the RV? The simplicity of parts and power for weight seem very promising. John Brunke St. Charles, IL > >" Forget the Innodyn, I been following it for months...Highly unlikely its > going to work out." > ________________________________________________________________________________
Date: Aug 01, 2005
Subject: Re: To the fighter pilots
In a message dated 8/1/2005 11:15:00 AM Eastern Standard Time, frank.hinde(at)hp.com writes: What exactly is the appeal of an RV to an ex fighter pilot?....I mean the RV's are fabulous to us ex spam can jockeys but I'm having a hard time imagining why someone who has done aerobatics at 600mph for a living would be interested in a measly 200mph on a good day...and spend up to $100k getting there... I mean are RV's really THAT good?...:) VERY Good Point you make. I have nearly 5000 hours fighter time and hadn't flown in about 25 years. So, being the romantic, I decided to get something that looked neat, would pull Gs for gentleman's acro and get that old feeling back-----that excitment, the rush. After 50 hours in my RV-6, I found out that the RV just doesn't do it for me. It's for sale now, a beautiful bird with fewer than 160 hours on it total time. You can't go home again, so to speak, not in an RV. ________________________________________________________________________________
Date: Aug 01, 2005
There is an Innodyn "Yahoo groups" that has a number of informed opinions...and a lot of hot air like any list..:) Anyway, there are a few guys in there with actual design experience with turbines and a number of high time jet pilots and flight engineers etc. All of these folks are attracted to homebuilts with turbines because they have been flying them for so long. Anyway, the jist of the argument is there is now way a little turbine with a single rotor with (I'm guessing a little) a 4:1 pressure ratio will give anything like 7GPH for each 100HP. Either the pressure ratio is much higher (like 14:1) not possible with a single wheel or it doesn't make anywhere near the power they claim OR it guzzles fuel at an eye watering rate!...Actually all turbines guzzle fuel but they are suggesting this engine is more efficient than just about any turbine out there. Innodyn has been EXTREMLY evasive when repeatedly asked about fuel consumption. So there you have it..I know very little about turbines (except of course like any patriotic Brit, it was invented by Sir Frank Whittle, a noted Brit!) Frank -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of John Brunke Subject: Re: RV7-List: Right hand seat? Frank, Would you mind going into some of the things you have found out about the Innodyn engine that would not make it suitable for the RV? The simplicity of parts and power for weight seem very promising. John Brunke St. Charles, IL > >" Forget the Innodyn, I been following it for months...Highly unlikely >its going to work out." > ________________________________________________________________________________
Date: Aug 01, 2005
> Yes I have built a F1 Rocket and there is nothing out there like it. It > will out climb and out roll the Extra 300. Sounds fun. What's your typical true airspeed in cruise, and at what fuel burn? How about the cost of insurance? )_( Dan RV-7 N714D (578 hours) http://www.rvproject.com ________________________________________________________________________________
Date: Aug 01, 2005
Most folks that fly aerobatics in RV's prefer the Hartzell prop over the MT for the CS response time ......just a thought for the selection criteria Dan S. OKC 7A Wings/Fuse -------Original Message------- From: Hinde, Frank George (Corvallis) Date: 07/31/05 11:30:13 Subject: RE: RV7-List: 2 or 3 blade prop?? hinde(at)hp.com> A bit controversial this one but from my desk research my conclusion was the MT 3 blade prop reduced the speed of the airplane, but run smoother. The Hartzell prop although heavy was not quite as fast as the fastest of the bunch it's a lot cheaper. For me (highly personal decision) the Hartzell was the best value for money and they seem to have resolved their repair problems they were plagued with a few years ago....At least I know of several examples oflate with high hours and no issues. Frank -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Alf Olav Frog Subject: RV7-List: 2 or 3 blade prop?? > > > Hello again! > > Thanks for all the inputs regarding the right hand seat! Great that there's a forum like this for us who are living outside of the "action"! > > Since I got so good response on my first issue, here's another choice I've to make: 2 or 3 blade prop? > > Ok, I know that the engine-choice is the first and biggest, but there I'm so far looking into different options.... what IS decided however, is a CS-prop. > > When the engine-choice is made, I'll check out the producers opinon regarding this, but what do you guys out there think?? > I was thinking that since I'm building a 7A, the distance to the ground from the propellertips would be slightly greater (better) with a 3 blade since this prop has a smaller diameter?? > Is there any big advantages or disadvantages with a 3 blade vs a 2 > blade? (expect for the price...) Is a 2 blade more efficient maybe?? > > > Best regards Alf Olav Frog > > ________________________________________________________________________________
Date: Aug 01, 2005
Fuel burn 10.6 at 190kts economy cruise. Dan Checkoway wrote: > > > >>Yes I have built a F1 Rocket and there is nothing out there like it. It >>will out climb and out roll the Extra 300. >> >> > >Sounds fun. > >What's your typical true airspeed in cruise, and at what fuel burn? How >about the cost of insurance? > >)_( Dan >RV-7 N714D (578 hours) >http://www.rvproject.com > > > > ________________________________________________________________________________
Date: Aug 01, 2005
Speed is relative!! 150 MPH is damn fast at ten feet above terrain or water. Mach 1 or more, is just like floating in a balloon at Angels 30 and that's where fighter pilots do their aerobatics. 4 G's is 4 G's at Mach 1 or 150 MPH. A Piper cub or a fully loaded C-47 landing with a 25 MPH 90o x wind is real exciting. An A-6 Intruder flying nap of the earth at night is exciting. Aerobatics in an RV or Citabria are both fun and exciting. Aviation; wheather flying a TD a Helo a seaplane or night LDGs on a Carrier are full of fun and thrills. After more than 50 years of doing it you never get tired, at least I never have. ----- Original Message ----- From: <OneFighterPilot(at)aol.com> Subject: Re: RV7-List: To the fighter pilots > > > In a message dated 8/1/2005 11:15:00 AM Eastern Standard Time, > frank.hinde(at)hp.com writes: > > > What exactly is the appeal of an RV to an ex fighter pilot?....I mean > the RV's are fabulous to us ex spam can jockeys but I'm having a hard > time imagining why someone who has done aerobatics at 600mph for a > living would be interested in a measly 200mph on a good day...and spend > up to $100k getting there... > > I mean are RV's really THAT good?...:) > > > VERY Good Point you make. I have nearly 5000 hours fighter time and > hadn't > flown in about 25 years. So, being the romantic, I decided to get > something > that looked neat, would pull Gs for gentleman's acro and get that old > feeling > back-----that excitment, the rush. After 50 hours in my RV-6, I found > out > that the RV just doesn't do it for me. It's for sale now, a beautiful > bird > with fewer than 160 hours on it total time. You can't go home again, so > to > speak, not in an RV. > > > ________________________________________________________________________________
Date: Aug 01, 2005
Doesn't the hydraulic CS MT uses the same governor as the Hartzell? If so why would the speed of change differ? I know the electrically control CS MT is slower but on a Lyc it could be the governor. Am I wrong here? Bevan RV7A fuse -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Daniel Storer Subject: RE: RV7-List: 2 or 3 blade prop?? Most folks that fly aerobatics in RV's prefer the Hartzell prop over the MT for the CS response time ......just a thought for the selection criteria Dan S. OKC 7A Wings/Fuse -------Original Message------- From: Hinde, Frank George (Corvallis) Date: 07/31/05 11:30:13 Subject: RE: RV7-List: 2 or 3 blade prop?? hinde(at)hp.com> A bit controversial this one but from my desk research my conclusion was the MT 3 blade prop reduced the speed of the airplane, but run smoother. The Hartzell prop although heavy was not quite as fast as the fastest of the bunch it's a lot cheaper. For me (highly personal decision) the Hartzell was the best value for money and they seem to have resolved their repair problems they were plagued with a few years ago....At least I know of several examples oflate with high hours and no issues. Frank -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Alf Olav Frog Subject: RV7-List: 2 or 3 blade prop?? > > > Hello again! > > Thanks for all the inputs regarding the right hand seat! Great that there's a forum like this for us who are living outside of the "action"! > > Since I got so good response on my first issue, here's another choice I've to make: 2 or 3 blade prop? > > Ok, I know that the engine-choice is the first and biggest, but there I'm so far looking into different options.... what IS decided however, is a CS-prop. > > When the engine-choice is made, I'll check out the producers opinon regarding this, but what do you guys out there think?? > I was thinking that since I'm building a 7A, the distance to the ground from the propellertips would be slightly greater (better) with a 3 blade since this prop has a smaller diameter?? > Is there any big advantages or disadvantages with a 3 blade vs a 2 > blade? (expect for the price...) Is a 2 blade more efficient maybe?? > > > Best regards Alf Olav Frog > > ________________________________________________________________________________
Date: Aug 02, 2005
In a message dated 8/1/2005 9:36:58 PM Eastern Standard Time, dhall(at)donka.net writes: Also, if you like formation flying and you can afford a MiG or even a jet-trainer like the L39, you might get like 1 other person who you can go formation flying with every other month or two if you're lucky. Here at Spruce Creek Fly-In there are over 20 RVs either flying or abuilding. Every Saturday they and other aircraft have "gaggles", formation flights out to breakfast somewhere or just playing in the local area-----some of the damndest formations you have ever seen. And some can really fly. The rest are " Navy pukes"-----Navy formation is two or more acft going in about the same direction at about the same time at about the same airspeed and altitude. (That's my AF humor, sorry) Personally, I opted out of that aspect. Over 20 years of formation was enough for me. Occassionally, we see a flight for four Stearmans, Bonanzas, all manner of acft flying formation. You have to go where its "at". ________________________________________________________________________________
Date: Aug 02, 2005
I just took all mine off, after 2-3 years. The blue stuff and the clear stuff as easy as it was when new, but I had a couple of wing panels that had the white stuff, and it was a bear. It got really brittle and came off in really small pieces. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB - Finishing Up http://www.myrv7.com Don Hall wrote: > >I want to leave the protective blue film on my finished surfaces till it's >absolutely necessary to remove it. So that could be 2-3 years for the blue >film on all the finished tail feathers. I understand there is a chance that >the adhesive gets old, stickier, and harder to remove. Anybody experienced >that? > > > > ________________________________________________________________________________
Date: Aug 03, 2005
From: "Francis, David CMDR" <David.Francis(at)defence.gov.au>
The speed of pitch change tends to be dominated by the response rate of the governor. As I understand it the MT governor, which is in fact a rebadged Johstroj product (according to the data plate on mine)has the fastest response rate because it has the smallest and lightest counterweights. Regards, David A Francis VH-ZEE Canberra, Australia -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] Subject: RE: RV7-List: 2 or 3 blade prop?? Doesn't the hydraulic CS MT uses the same governor as the Hartzell? If so why would the speed of change differ? I know the electrically control CS MT is slower but on a Lyc it could be the governor. Am I wrong here? Bevan RV7A fuse -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Daniel Storer Subject: RE: RV7-List: 2 or 3 blade prop?? Most folks that fly aerobatics in RV's prefer the Hartzell prop over the MT for the CS response time ......just a thought for the selection criteria Dan S. OKC 7A Wings/Fuse -------Original Message------- From: Hinde, Frank George (Corvallis) Date: 07/31/05 11:30:13 Subject: RE: RV7-List: 2 or 3 blade prop?? hinde(at)hp.com> A bit controversial this one but from my desk research my conclusion was the MT 3 blade prop reduced the speed of the airplane, but run smoother. The Hartzell prop although heavy was not quite as fast as the fastest of the bunch it's a lot cheaper. For me (highly personal decision) the Hartzell was the best value for money and they seem to have resolved their repair problems they were plagued with a few years ago....At least I know of several examples oflate with high hours and no issues. Frank -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Alf Olav Frog Subject: RV7-List: 2 or 3 blade prop?? > > > Hello again! > > Thanks for all the inputs regarding the right hand seat! Great that there's a forum like this for us who are living outside of the "action"! > > Since I got so good response on my first issue, here's another choice I've to make: 2 or 3 blade prop? > > Ok, I know that the engine-choice is the first and biggest, but there I'm so far looking into different options.... what IS decided however, is a CS-prop. > > When the engine-choice is made, I'll check out the producers opinon regarding this, but what do you guys out there think?? > I was thinking that since I'm building a 7A, the distance to the ground from the propellertips would be slightly greater (better) with a 3 blade since this prop has a smaller diameter?? > Is there any big advantages or disadvantages with a 3 blade vs a 2 > blade? (expect for the price...) Is a 2 blade more efficient maybe?? > > > Best regards Alf Olav Frog > > ________________________________________________________________________________
Date: Aug 02, 2005
MT & Johistroj used to be the same governor. It was developed by the two companies to be sold as an MT unit, but when Johistroj started selling it under their own name behind MT's back, MT broke ties with them and continued development of the governor on their own. Now MT's governor is a little different than the Johistroj. Not sure when all this happened, but it must've been fairly recently. Reason I know this is I just ordered my prop at Oshkosh, and I spoke with the MT guy Eric about this. I asked about the governor specifically, and this was what he told me. Anyways, I ordered the whole package. Chrome spinner and all. Mark www.4sierratango.com >From: "Francis, David CMDR" <David.Francis(at)defence.gov.au> >Reply-To: rv7-list(at)matronics.com >To: >Subject: SEC: UNCLASSIFIED RE: RV7-List: 2 or 3 blade prop?? >Date: Wed, 3 Aug 2005 09:11:41 +1000 > > > >The speed of pitch change tends to be dominated by the response rate of the >governor. As I understand it the MT governor, which is in fact a rebadged >Johstroj product (according to the data plate on mine)has the fastest >response rate because it has the smallest and lightest counterweights. > >Regards, >David A Francis >VH-ZEE >Canberra, Australia > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com] >To: rv7-list(at)matronics.com >Subject: RE: RV7-List: 2 or 3 blade prop?? > > >Doesn't the hydraulic CS MT uses the same governor as the Hartzell? If so >why would the speed of change differ? I know the electrically control CS >MT >is slower but on a Lyc it could be the governor. Am I wrong here? > >Bevan >RV7A fuse > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Daniel Storer >To: rv7-list(at)matronics.com >Subject: RE: RV7-List: 2 or 3 blade prop?? > > >Most folks that fly aerobatics in RV's prefer the Hartzell prop over the MT >for the CS response time ......just a thought for the selection criteria > >Dan S. >OKC 7A Wings/Fuse > >-------Original Message------- > >From: Hinde, Frank George (Corvallis) >Date: 07/31/05 11:30:13 >To: rv7-list(at)matronics.com >Subject: RE: RV7-List: 2 or 3 blade prop?? > >hinde(at)hp.com> > >A bit controversial this one but from my desk research my conclusion was >the >MT 3 blade prop reduced the speed of the airplane, but run smoother. >The Hartzell prop although heavy was not quite as fast as the fastest of >the >bunch it's a lot cheaper. For me (highly personal decision) the Hartzell >was >the best value for money and they seem to have resolved their repair >problems they were plagued with a few years ago....At least I know of >several examples oflate with high hours and no issues. > >Frank > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Alf Olav Frog >To: rv7-list(at)matronics.com >Subject: RV7-List: 2 or 3 blade prop?? > > > > > > > > Hello again! > > > > Thanks for all the inputs regarding the right hand seat! Great that >there's a forum like this for us who are living outside of the "action"! > > > > Since I got so good response on my first issue, here's another choice >I've to make: 2 or 3 blade prop? > > > > Ok, I know that the engine-choice is the first and biggest, but there >I'm so far looking into different options.... what IS decided however, is a >CS-prop. > > > > When the engine-choice is made, I'll check out the producers opinon >regarding this, but what do you guys out there think?? > > I was thinking that since I'm building a 7A, the distance to the >ground from the propellertips would be slightly greater (better) with a >3 blade since this prop has a smaller diameter?? > > Is there any big advantages or disadvantages with a 3 blade vs a 2 > > blade? (expect for the price...) Is a 2 blade more efficient maybe?? > > > > > > Best regards Alf Olav Frog > > > > > > ________________________________________________________________________________
Date: Aug 05, 2005
Subject: constant speed prop
Has anybody out there got any experience in a RV-6 or RV-7 with a constant speed prop flying in the upper teens. Also have any of you got super or turbo chargers on you engine. I am thinking of going for a turbo-charged constant speed engine on my next plane and looking for any info I can find. Right now at 15500 wot I get 170kts with 2670rpm and would like to run the engine slower with the same speeds or better. Any help would be appriecated. Cheers Norman ________________________________________________________________________________
Date: Aug 05, 2005
Norman, Why dont you talk to Jon Johanson. He has some relevant experience. He flew his RV4 around the world on a carburetted fixed pitch prop and flew the same plane to Antarctica with a fuel injected, turbocharged constant speed deal. Try him at jonj(at)flymore.com.au He barely sips fuel at FL230. Regards, David Francis Canberra, Australia -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] Subject: RV7-List: constant speed prop Has anybody out there got any experience in a RV-6 or RV-7 with a constant speed prop flying in the upper teens. Also have any of you got super or turbo chargers on you engine. I am thinking of going for a turbo-charged constant speed engine on my next plane and looking for any info I can find. Right now at 15500 wot I get 170kts with 2670rpm and would like to run the engine slower with the same speeds or better. Any help would be appriecated. Cheers Norman ________________________________________________________________________________
From: "Brian Meyette" <brianpublic(at)starband.net>
Date: Aug 05, 2005
You might want to check out the Eggenfellner Subaru offerings. Web = http://eggenfellneraircraft.com Mail list = http://groups.yahoo.com/group/subaruaircraft/ Constant speed MT prop, 2 models of supercharged engines - sounds like you might like the single cam model brian http://brian76.mystarband.net/RV-7Ahome.htm -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Norman Younie Subject: RV7-List: constant speed prop Has anybody out there got any experience in a RV-6 or RV-7 with a constant speed prop flying in the upper teens. Also have any of you got super or turbo chargers on you engine. I am thinking of going for a turbo-charged constant speed engine on my next plane and looking for any info I can find. Right now at 15500 wot I get 170kts with 2670rpm and would like to run the engine slower with the same speeds or better. Any help would be appriecated. Cheers Norman -- -- ________________________________________________________________________________
Subject: Engine decision time ...
Date: Aug 05, 2005
0.25 HELO_DYNAMIC_DHCP Relay HELO'd using suspicious hostname (DHCP) 0.74 HELO_DYNAMIC_HCC Relay HELO'd using suspicious hostname (HCC) 1.40 HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP addr 1) Fellow builders, Its that daunting and exciting time to decide what engine to put in my RV9 (taildragger). I've decided to rule out the auto conversions and go Lycosaur (IO-320 or 360) but I could use a like a little help deciding which. The 9 fuselage is pretty much identical to the 7, so it will take a 360. I know Van's recommends the 320 as the max for the 9 presumably to limit the possibility of exceeding Vne for the airframe etc etc. I'm wondering if folks already flying their 9s are getting max performance as advertised with the 320 and thus there's no purpose to putting in the 360. My mission is fastest possible cruise for frequent trips up and down the California coast from my home base in San Francisco to destinations like LA, San Diego, Tahoe, Portland, Seattle with the occassional coast to coast jaunt. Resale value is probably less of a concern to me - I can't ever see myself selling this puppy. Any experiences, thoughts, rants, prejudices and musings will be most welcome :) __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 05, 2005
If it were me...:) I'd stuff an IO360 in there and get some close to red line cruise and run LOP all the time in cruise and get some serious economy. But then I'm bulding a 7a and could easily see me putting an IO540 in it for the same reaon if it weren't so heavy. The only other consideration is insurance cost. Frank -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Gerry Filby Subject: RV7-List: Engine decision time ... Fellow builders, Its that daunting and exciting time to decide what engine to put in my RV9 (taildragger). I've decided to rule out the auto conversions and go Lycosaur (IO-320 or 360) but I could use a like a little help deciding which. The 9 fuselage is pretty much identical to the 7, so it will take a 360. I know Van's recommends the 320 as the max for the 9 presumably to limit the possibility of exceeding Vne for the airframe etc etc. I'm wondering if folks already flying their 9s are getting max performance as advertised with the 320 and thus there's no purpose to putting in the 360. My mission is fastest possible cruise for frequent trips up and down the California coast from my home base in San Francisco to destinations like LA, San Diego, Tahoe, Portland, Seattle with the occassional coast to coast jaunt. Resale value is probably less of a concern to me - I can't ever see myself selling this puppy. Any experiences, thoughts, rants, prejudices and musings will be most welcome :) __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: Re: Engine decision time ...
Date: Aug 05, 2005
Interesting, you post a question for an RV9 on the RV7 list. ( do not archive ) Gerry, You might be more of a test pilot than me,,,,,,,,,,but,,,,,,,,,,,My suggestion: Better to send this question to Vans and challenge them as to why they do not suggest or support putting an 360 in the RV9? I have a friend that has an O-320 FP prop in an RV6. It does 185 mph very easily. I have heard other pilots say something like it doesn't matter how fast your plane, you always want to go faster at times. So, will you be happy going 185 or even 190 if someone else is going 195? I would not override the design of Vans without understanding fully what the trade offs and risks are. Also, Imagine what your insurance agent is going to say and charge when they learn you are stepping beyond the kit design limit? It's no longer a kit plane!! If you were the agent, would you insure yourself putting a bigger engine in an airframe designed for 160 hp max.? The plane is designed for certain stresses and the extra 20 hp and weight could be a problem. Think about it and your motivations for considering a 360. You are the pilot/owner however. Your life. Your insurance premiums. You got to get there fast, right?. Maybe you could just take off the ramp 5 minutes earlier with the 320 and arrive there at the same time. Could another way to look at it come down to time management? Your life. Think about it..... Indiana Larry, RV7 Tip Up It Flies ----- Original Message ----- > > > Fellow builders, > > Its that daunting and exciting time to decide what engine to > put in my RV9 (taildragger). I've decided to rule out the auto > conversions and go Lycosaur (IO-320 or 360) but I could use a > like a little help deciding which. The 9 fuselage is pretty > much identical to the 7, so it will take a 360. I know Van's > recommends the 320 as the max for the 9 presumably to limit the > possibility of exceeding Vne for the airframe etc etc. > snip ________________________________________________________________________________
Date: Aug 05, 2005
You can use the 360, derated in the 9, then at altitude you get a little more power. I think that it's derated by rpm restriction, but cant' be sure. I remember reading an artical somewhere, but I can't remember where it was. Anybody else remember that one? I got mine from Mattituck. Their TMX is great value as far as Lycosaurs go, and they can build it out of Superior parts if you should so desire. The TMX is normally ECI based. I asked for the Ryton sump on mine so I could eliminate the intake from the cowling. This basically means that Mattituck have to order a complete XP-360 to get the sump as Superior do not sell the sump separately. On the flip side, Cameron a couple of hangars down has a 320 in his 9A and is very pleased with the way it performs. Van's are pretty honest in department too, which is nice as we all get a realistic guide as to how our aircraft will perform. Check out the Firewall Forward page on my website to see more info on the engine. Mark www.4sierratango.com >From: Gerry Filby <gerf(at)gerf.com> >Reply-To: rv7-list(at)matronics.com >To: rv9-list(at)matronics.com, rv7-list(at)matronics.com >Subject: RV7-List: Engine decision time ... >Date: Fri, 05 Aug 2005 10:08:44 -0700 0.25 HELO_DYNAMIC_DHCP >Relay HELO'd using suspicious hostname (DHCP) 0.74 HELO_DYNAMIC_HCC > Relay HELO'd using suspicious hostname (HCC) 1.40 >HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP addr 1) > > >Fellow builders, > >Its that daunting and exciting time to decide what engine to >put in my RV9 (taildragger). I've decided to rule out the auto >conversions and go Lycosaur (IO-320 or 360) but I could use a >like a little help deciding which. The 9 fuselage is pretty >much identical to the 7, so it will take a 360. I know Van's >recommends the 320 as the max for the 9 presumably to limit the >possibility of exceeding Vne for the airframe etc etc. > >I'm wondering if folks already flying their 9s are getting max >performance as advertised with the 320 and thus there's no >purpose to putting in the 360. My mission is fastest possible >cruise for frequent trips up and down the California coast from >my home base in San Francisco to destinations like LA, San >Diego, Tahoe, Portland, Seattle with the occassional coast to >coast jaunt. Resale value is probably less of a concern to me >- I can't ever see myself selling this puppy. > >Any experiences, thoughts, rants, prejudices and musings will >be most welcome :) > >__g__ > >========================================================== >Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 > > ________________________________________________________________________________
Subject: which pitot tube?
Date: Aug 05, 2005
Make of Pitot Model Amps Circuit Breaker to use Wire Size ---- Aero Instruments AN5812 8A 10A 14 ga Aero Instruments AN5814 12A 20A 12 ga -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Subject: RE: RV7-List: Engine decision time ... --> If it were me...:) I'd stuff an IO360 in there and get some close to red line cruise and run LOP all the time in cruise and get some serious economy. But then I'm bulding a 7a and could easily see me putting an IO540 in it for the same reaon if it weren't so heavy. The only other consideration is insurance cost. Frank -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Gerry Filby Subject: RV7-List: Engine decision time ... Fellow builders, Its that daunting and exciting time to decide what engine to put in my RV9 (taildragger). I've decided to rule out the auto conversions and go Lycosaur (IO-320 or 360) but I could use a like a little help deciding which. The 9 fuselage is pretty much identical to the 7, so it will take a 360. I know Van's recommends the 320 as the max for the 9 presumably to limit the possibility of exceeding Vne for the airframe etc etc. I'm wondering if folks already flying their 9s are getting max performance as advertised with the 320 and thus there's no purpose to putting in the 360. My mission is fastest possible cruise for frequent trips up and down the California coast from my home base in San Francisco to destinations like LA, San Diego, Tahoe, Portland, Seattle with the occassional coast to coast jaunt. Resale value is probably less of a concern to me - I can't ever see myself selling this puppy. Any experiences, thoughts, rants, prejudices and musings will be most welcome :) __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 06, 2005
I recall a couple of messages by Mahlon Russel himself (of Mattituck) actually recommend putting the 360 in the RV9. And IIRC, the reasoning was that it wasn't any heavier than the 320, it would be derated (but just a little?), and what you got was more power for climb performance and still good fuel economy at cruise. Still, before I did use a 360 in your RV9, I would recommend calling someone personally to discuss all the issues. If you're thinking of going with a Mattituck (my choice as well), call Mahlon in person. He's been known to be very accessable and willing to spend time with potential customers with these kind of questions. Vern RV7-A ----- Original Message ----- From: "Mark Taylor" <mtaylo17(at)msn.com> Subject: RE: RV7-List: Engine decision time ... > > You can use the 360, derated in the 9, then at altitude you get a little > more power. I think that it's derated by rpm restriction, but cant' be sure. > I remember reading an artical somewhere, but I can't remember where it was. > Anybody else remember that one? > > I got mine from Mattituck. Their TMX is great value as far as Lycosaurs go, > and they can build it out of Superior parts if you should so desire. The TMX > is normally ECI based. I asked for the Ryton sump on mine so I could > eliminate the intake from the cowling. This basically means that Mattituck > have to order a complete XP-360 to get the sump as Superior do not sell the > sump separately. > > On the flip side, Cameron a couple of hangars down has a 320 in his 9A and > is very pleased with the way it performs. Van's are pretty honest in > department too, which is nice as we all get a realistic guide as to how our > aircraft will perform. > > Check out the Firewall Forward page on my website to see more info on the > engine. > > Mark > www.4sierratango.com > > > >From: Gerry Filby <gerf(at)gerf.com> > >Reply-To: rv7-list(at)matronics.com > >To: rv9-list(at)matronics.com, rv7-list(at)matronics.com > >Subject: RV7-List: Engine decision time ... > >Date: Fri, 05 Aug 2005 10:08:44 -0700 0.25 HELO_DYNAMIC_DHCP > >Relay HELO'd using suspicious hostname (DHCP) 0.74 HELO_DYNAMIC_HCC > > Relay HELO'd using suspicious hostname (HCC) 1.40 > >HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP addr 1) > > > > > > > >Fellow builders, > > > >Its that daunting and exciting time to decide what engine to > >put in my RV9 (taildragger). I've decided to rule out the auto > >conversions and go Lycosaur (IO-320 or 360) but I could use a > >like a little help deciding which. The 9 fuselage is pretty > >much identical to the 7, so it will take a 360. I know Van's > >recommends the 320 as the max for the 9 presumably to limit the > >possibility of exceeding Vne for the airframe etc etc. > > > >I'm wondering if folks already flying their 9s are getting max > >performance as advertised with the 320 and thus there's no > >purpose to putting in the 360. My mission is fastest possible > >cruise for frequent trips up and down the California coast from > >my home base in San Francisco to destinations like LA, San > >Diego, Tahoe, Portland, Seattle with the occassional coast to > >coast jaunt. Resale value is probably less of a concern to me > >- I can't ever see myself selling this puppy. > > > >Any experiences, thoughts, rants, prejudices and musings will > >be most welcome :) > > > >__g__ > > > >========================================================== > >Gerry Filby gerf(at)gerf.com > > Tel: 415 203 9177 > > > > > > ________________________________________________________________________________
Date: Aug 06, 2005
I'll second that with Mahlon Russell. He's a great person to deal with. The other cool thing about Mattituck is they don't pressure you into buying. Their way is to inform you as best they can, answer your questions and let theie engines sell themselves. It works. I know Mahlon was bombarded with questions before I placed the order! If you have your heart set on a Superior engine, that's no problem, because they can do that too since they're one of superior's builders. Mark. www.4sierratango.com >From: "Vern W" <vernw(at)pdq.net> >Reply-To: rv7-list(at)matronics.com >To: >Subject: Re: RV7-List: Engine decision time ... >Date: Sat, 6 Aug 2005 06:43:06 -0500 > > > I recall a couple of messages by Mahlon Russel himself (of Mattituck) >actually recommend putting the 360 in the RV9. And IIRC, the reasoning was >that it wasn't any heavier than the 320, it would be derated (but just a >little?), and what you got was more power for climb performance and still >good fuel economy at cruise. > Still, before I did use a 360 in your RV9, I would recommend calling >someone personally to discuss all the issues. If you're thinking of going >with a Mattituck (my choice as well), call Mahlon in person. He's been >known >to be very accessable and willing to spend time with potential customers >with these kind of questions. > >Vern >RV7-A > >----- Original Message ----- >From: "Mark Taylor" <mtaylo17(at)msn.com> >To: >Subject: RE: RV7-List: Engine decision time ... > > > > > > You can use the 360, derated in the 9, then at altitude you get a little > > more power. I think that it's derated by rpm restriction, but cant' be >sure. > > I remember reading an artical somewhere, but I can't remember where it >was. > > Anybody else remember that one? > > > > I got mine from Mattituck. Their TMX is great value as far as Lycosaurs >go, > > and they can build it out of Superior parts if you should so desire. The >TMX > > is normally ECI based. I asked for the Ryton sump on mine so I could > > eliminate the intake from the cowling. This basically means that >Mattituck > > have to order a complete XP-360 to get the sump as Superior do not sell >the > > sump separately. > > > > On the flip side, Cameron a couple of hangars down has a 320 in his 9A >and > > is very pleased with the way it performs. Van's are pretty honest in > > department too, which is nice as we all get a realistic guide as to how >our > > aircraft will perform. > > > > Check out the Firewall Forward page on my website to see more info on >the > > engine. > > > > Mark > > www.4sierratango.com > > > > > > >From: Gerry Filby <gerf(at)gerf.com> > > >Reply-To: rv7-list(at)matronics.com > > >To: rv9-list(at)matronics.com, rv7-list(at)matronics.com > > >Subject: RV7-List: Engine decision time ... > > >Date: Fri, 05 Aug 2005 10:08:44 -0700 0.25 HELO_DYNAMIC_DHCP > > >Relay HELO'd using suspicious hostname (DHCP) 0.74 >HELO_DYNAMIC_HCC > > > Relay HELO'd using suspicious hostname (HCC) 1.40 > > >HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP addr >1) > > > > > > > > > > > >Fellow builders, > > > > > >Its that daunting and exciting time to decide what engine to > > >put in my RV9 (taildragger). I've decided to rule out the auto > > >conversions and go Lycosaur (IO-320 or 360) but I could use a > > >like a little help deciding which. The 9 fuselage is pretty > > >much identical to the 7, so it will take a 360. I know Van's > > >recommends the 320 as the max for the 9 presumably to limit the > > >possibility of exceeding Vne for the airframe etc etc. > > > > > >I'm wondering if folks already flying their 9s are getting max > > >performance as advertised with the 320 and thus there's no > > >purpose to putting in the 360. My mission is fastest possible > > >cruise for frequent trips up and down the California coast from > > >my home base in San Francisco to destinations like LA, San > > >Diego, Tahoe, Portland, Seattle with the occassional coast to > > >coast jaunt. Resale value is probably less of a concern to me > > >- I can't ever see myself selling this puppy. > > > > > >Any experiences, thoughts, rants, prejudices and musings will > > >be most welcome :) > > > > > >__g__ > > > > > >========================================================== > > >Gerry Filby gerf(at)gerf.com > > > Tel: 415 203 9177 > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 06, 2005
My friend Ted put an O-360 from Aero Sport Power into his 9A-has over 100 hours on it and is very happy with it. With a half tank of gas, the 9A climbs out at 2100 fpm over 100 MPH. I have an O-360 in my 7A with 10 to 1 pistons, Light Speed ignition, ceramic-coated exhausts (in and out) and I can barely keep up the 9A. The 9A with an O-360 is awesome. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Mark Taylor Subject: Re: RV7-List: Engine decision time ... I'll second that with Mahlon Russell. He's a great person to deal with. The other cool thing about Mattituck is they don't pressure you into buying. Their way is to inform you as best they can, answer your questions and let theie engines sell themselves. It works. I know Mahlon was bombarded with questions before I placed the order! If you have your heart set on a Superior engine, that's no problem, because they can do that too since they're one of superior's builders. Mark. www.4sierratango.com >From: "Vern W" <vernw(at)pdq.net> >Reply-To: rv7-list(at)matronics.com >To: >Subject: Re: RV7-List: Engine decision time ... >Date: Sat, 6 Aug 2005 06:43:06 -0500 > > > I recall a couple of messages by Mahlon Russel himself (of Mattituck) >actually recommend putting the 360 in the RV9. And IIRC, the reasoning was >that it wasn't any heavier than the 320, it would be derated (but just a >little?), and what you got was more power for climb performance and still >good fuel economy at cruise. > Still, before I did use a 360 in your RV9, I would recommend calling >someone personally to discuss all the issues. If you're thinking of going >with a Mattituck (my choice as well), call Mahlon in person. He's been >known >to be very accessable and willing to spend time with potential customers >with these kind of questions. > >Vern >RV7-A > >----- Original Message ----- >From: "Mark Taylor" <mtaylo17(at)msn.com> >To: >Subject: RE: RV7-List: Engine decision time ... > > > > > > You can use the 360, derated in the 9, then at altitude you get a little > > more power. I think that it's derated by rpm restriction, but cant' be >sure. > > I remember reading an artical somewhere, but I can't remember where it >was. > > Anybody else remember that one? > > > > I got mine from Mattituck. Their TMX is great value as far as Lycosaurs >go, > > and they can build it out of Superior parts if you should so desire. The >TMX > > is normally ECI based. I asked for the Ryton sump on mine so I could > > eliminate the intake from the cowling. This basically means that >Mattituck > > have to order a complete XP-360 to get the sump as Superior do not sell >the > > sump separately. > > > > On the flip side, Cameron a couple of hangars down has a 320 in his 9A >and > > is very pleased with the way it performs. Van's are pretty honest in > > department too, which is nice as we all get a realistic guide as to how >our > > aircraft will perform. > > > > Check out the Firewall Forward page on my website to see more info on >the > > engine. > > > > Mark > > www.4sierratango.com > > > > > > >From: Gerry Filby <gerf(at)gerf.com> > > >Reply-To: rv7-list(at)matronics.com > > >To: rv9-list(at)matronics.com, rv7-list(at)matronics.com > > >Subject: RV7-List: Engine decision time ... > > >Date: Fri, 05 Aug 2005 10:08:44 -0700 0.25 HELO_DYNAMIC_DHCP > > >Relay HELO'd using suspicious hostname (DHCP) 0.74 >HELO_DYNAMIC_HCC > > > Relay HELO'd using suspicious hostname (HCC) 1.40 > > >HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP addr >1) > > > > > > > > > > > >Fellow builders, > > > > > >Its that daunting and exciting time to decide what engine to > > >put in my RV9 (taildragger). I've decided to rule out the auto > > >conversions and go Lycosaur (IO-320 or 360) but I could use a > > >like a little help deciding which. The 9 fuselage is pretty > > >much identical to the 7, so it will take a 360. I know Van's > > >recommends the 320 as the max for the 9 presumably to limit the > > >possibility of exceeding Vne for the airframe etc etc. > > > > > >I'm wondering if folks already flying their 9s are getting max > > >performance as advertised with the 320 and thus there's no > > >purpose to putting in the 360. My mission is fastest possible > > >cruise for frequent trips up and down the California coast from > > >my home base in San Francisco to destinations like LA, San > > >Diego, Tahoe, Portland, Seattle with the occassional coast to > > >coast jaunt. Resale value is probably less of a concern to me > > >- I can't ever see myself selling this puppy. > > > > > >Any experiences, thoughts, rants, prejudices and musings will > > >be most welcome :) > > > > > >__g__ > > > > > >========================================================== > > >Gerry Filby gerf(at)gerf.com > > > Tel: 415 203 9177 > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 06, 2005
Subject: Filing rivets
I have a few areas I want to fill countersubk rivet heads - what are people using to fill these areas. I will use PPG primer and PPG polyurethane for linished paint. Appeciate any suggestions. Mary Beth RV7A just turned fuselage canoe over. ________________________________________________________________________________
Subject: Re: Filing rivets
Date: Aug 06, 2005
SuperFil will be one product that will work with filling rivet depressions and with your paints and later on with fiber glass. It is epoxy based. Great stuff, not too expensive and easy to work with but requires 24 hours to dry and setup. Indiana Larry, RV7 Tip Up It Flies ----- Original Message ----- > > I have a few areas I want to fill countersubk rivet heads - what are > people > using to fill these areas. I will use PPG primer and PPG polyurethane for > linished paint. > Appeciate any suggestions. > > Mary Beth > RV7A just turned fuselage canoe over. ________________________________________________________________________________
Date: Aug 06, 2005
From: "Brooks Wolfe" <slipstream13(at)earthlink.net>
Subject: Interior thoughts..
I'm looking for a good interior set for my -7. Outside of Oregon Aero seats I haven't really shopped around yet for interior kits. The fuselage is about ready to close up, so it's time to make decisions on where to paint and where to upholster, etc. I don't want to weigh my plane down with a bunch of overstuffed padding, but Van's demonstrators are definitely more Spartan than what I'm imagining.. Does anyone have some good references for interior kit suppliers? Brooks ________________________________________________________________________________
Date: Aug 06, 2005
I've heard penty of good stuff about http://www.classicaerodesigns.com/default.asp and plan to use them myself. Bevan -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Brooks Wolfe Subject: RV7-List: Interior thoughts.. --> I'm looking for a good interior set for my -7. Outside of Oregon Aero seats I haven't really shopped around yet for interior kits. The fuselage is about ready to close up, so it's time to make decisions on where to paint and where to upholster, etc. I don't want to weigh my plane down with a bunch of overstuffed padding, but Van's demonstrators are definitely more Spartan than what I'm imagining.. Does anyone have some good references for interior kit suppliers? Brooks ________________________________________________________________________________
Subject: Re: Interior thoughts..
Date: Aug 06, 2005
http://www.classicaerodesigns.com Looks great, very comfortable on some very long trips, and has stood up remarkably to people getting in and out of the plane for hundreds of hours. Still looks practically new, and I've never cleaned 'em. Good stuff, highly recommended. )_( Dan RV-7 N714D (583 hours) http://www.rvproject.com ----- Original Message ----- From: "Brooks Wolfe" <slipstream13(at)earthlink.net> Subject: RV7-List: Interior thoughts.. > > > I'm looking for a good interior set for my -7. Outside of Oregon Aero > seats > I haven't really shopped around yet for interior kits. The fuselage is > about ready to close up, so it's time to make decisions on where to paint > and where to upholster, etc. I don't want to weigh my plane down with a > bunch of overstuffed padding, but Van's demonstrators are definitely more > Spartan than what I'm imagining.. Does anyone have some good references > for interior kit suppliers? > > Brooks > > > ________________________________________________________________________________
Date: Aug 07, 2005
Flightline Interiors. You can find their website with a Google search. Talk with Abby. Easy to work with and quality work and materials. Indiana Larry, RV7 Tip Up It Flies Teamwork: " A lot of people doing exactly what I say." (Marketing exec., Citrix Corp.) ----- Original Message ----- > > > I'm looking for a good interior set for my -7. Outside of Oregon Aero > seats > I haven't really shopped around yet for interior kits. The fuselage is > about ready to close up, so it's time to make decisions on where to paint > and where to upholster, etc. I don't want to weigh my plane down with a > bunch of overstuffed padding, but Van's demonstrators are definitely more > Spartan than what I'm imagining.. Does anyone have some good references > for interior kit suppliers? > > Brooks ________________________________________________________________________________
Subject: 2 or 3 blade prop??
Date: Aug 07, 2005
FWIW, Aviation Consumer has an article on 2 vs 3 in this month's issue. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Mark Taylor Subject: RE: SEC: UNCLASSIFIED RE: RV7-List: 2 or 3 blade prop?? MT & Johistroj used to be the same governor. It was developed by the two companies to be sold as an MT unit, but when Johistroj started selling it under their own name behind MT's back, MT broke ties with them and continued development of the governor on their own. Now MT's governor is a little different than the Johistroj. Not sure when all this happened, but it must've been fairly recently. Reason I know this is I just ordered my prop at Oshkosh, and I spoke with the MT guy Eric about this. I asked about the governor specifically, and this was what he told me. Anyways, I ordered the whole package. Chrome spinner and all. Mark www.4sierratango.com >From: "Francis, David CMDR" <David.Francis(at)defence.gov.au> >Reply-To: rv7-list(at)matronics.com >To: >Subject: SEC: UNCLASSIFIED RE: RV7-List: 2 or 3 blade prop?? >Date: Wed, 3 Aug 2005 09:11:41 +1000 > > > >The speed of pitch change tends to be dominated by the response rate of >the governor. As I understand it the MT governor, which is in fact a >rebadged Johstroj product (according to the data plate on mine)has the >fastest response rate because it has the smallest and lightest counterweights. > >Regards, >David A Francis >VH-ZEE >Canberra, Australia > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com] >To: rv7-list(at)matronics.com >Subject: RE: RV7-List: 2 or 3 blade prop?? > > >Doesn't the hydraulic CS MT uses the same governor as the Hartzell? If >so why would the speed of change differ? I know the electrically >control CS MT is slower but on a Lyc it could be the governor. Am I >wrong here? > >Bevan >RV7A fuse > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Daniel Storer >To: rv7-list(at)matronics.com >Subject: RE: RV7-List: 2 or 3 blade prop?? > > >Most folks that fly aerobatics in RV's prefer the Hartzell prop over >the MT for the CS response time ......just a thought for the selection >criteria > >Dan S. >OKC 7A Wings/Fuse > >-------Original Message------- > >From: Hinde, Frank George (Corvallis) >Date: 07/31/05 11:30:13 >To: rv7-list(at)matronics.com >Subject: RE: RV7-List: 2 or 3 blade prop?? > >--> hinde(at)hp.com> > >A bit controversial this one but from my desk research my conclusion >was the MT 3 blade prop reduced the speed of the airplane, but run >smoother. >The Hartzell prop although heavy was not quite as fast as the fastest >of the bunch it's a lot cheaper. For me (highly personal decision) the >Hartzell was the best value for money and they seem to have resolved >their repair problems they were plagued with a few years ago....At >least I know of several examples oflate with high hours and no issues. > >Frank > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Alf Olav Frog >To: rv7-list(at)matronics.com >Subject: RV7-List: 2 or 3 blade prop?? > > > > > > > > Hello again! > > > > Thanks for all the inputs regarding the right hand seat! Great that >there's a forum like this for us who are living outside of the "action"! > > > > Since I got so good response on my first issue, here's another > > choice >I've to make: 2 or 3 blade prop? > > > > Ok, I know that the engine-choice is the first and biggest, but > > there >I'm so far looking into different options.... what IS decided however, >is a CS-prop. > > > > When the engine-choice is made, I'll check out the producers opinon >regarding this, but what do you guys out there think?? > > I was thinking that since I'm building a 7A, the distance to the >ground from the propellertips would be slightly greater (better) with a >3 blade since this prop has a smaller diameter?? > > Is there any big advantages or disadvantages with a 3 blade vs a 2 > > blade? (expect for the price...) Is a 2 blade more efficient maybe?? > > > > > > Best regards Alf Olav Frog > > > > > > ________________________________________________________________________________
Date: Aug 07, 2005
I saw a beautiful leather interior at Oshkosh done by Becki Orndorff. http://www.fly-gbi.com/ Allen Fulmer RV7 Wings (QB Fuse on hand) N808AF reserved Alexander City, AL -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Brooks Wolfe Subject: RV7-List: Interior thoughts.. I'm looking for a good interior set for my -7. ________________________________________________________________________________
Date: Aug 08, 2005
Speaking of which, I like the idea of not painting the interior so... I was looking at the Fliteline Interiors interior kit for $600. I was having a hard time understanding what I got for the money. I mean it "looks" like a big sheet of fabric that you cut to suit....I note from GBI they offer a "big sheet of fabric" for $75. Anyone know what the extra $525 buys me?... The Side panels are awesome. The airplane on the website belongs to a friend of mine and they are sweet....But for a thousand bucks for two side panels they are too rich for my taste. Frank ________________________________________________________________________________
Subject: Fw: RV9-List: Engine decision time ...
Date: Aug 08, 2005
Thanks to all of you for your helpful posts - lots of food for thought ! g > > --> RV9-List message posted by: Gerry Filby > > > Fellow builders, > > Its that daunting and exciting time to decide what engine to > put in my RV9 (taildragger). I've decided to rule out the auto > conversions and go Lycosaur (IO-320 or 360) but I could use a > like a little help deciding which. The 9 fuselage is pretty > much identical to the 7, so it will take a 360. I know Van's > recommends the 320 as the max for the 9 presumably to limit the > possibility of exceeding Vne for the airframe etc etc. > > I'm wondering if folks already flying their 9s are getting max > performance as advertised with the 320 and thus there's no > purpose to putting in the 360. My mission is fastest possible > cruise for frequent trips up and down the California coast from > my home base in San Francisco to destinations like LA, San > Diego, Tahoe, Portland, Seattle with the occassional coast to > coast jaunt. Resale value is probably less of a concern to me > - I can't ever see myself selling this puppy. > > Any experiences, thoughts, rants, prejudices and musings will > be most welcome :) > > __g__ > > ========================================================== > Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 08, 2005
----- Original Message ----- > > > Speaking of which, I like the idea of not painting the interior so... > > I was looking at the Fliteline Interiors interior kit for $600. I was > having a hard time understanding what I got for the money. I mean it > "looks" like a big sheet of fabric that you cut to suit....I note from > GBI they offer a "big sheet of fabric" for $75. > > Anyone know what the extra $525 buys me?... ((((((((((I imagine that is cutting and sewing together the seats and the other parts included for the price. It has been a year and half since I bought mine, so I would suggest you check the website or email Abby to see what the current pricing covers. Like any business, I would be surprised if there has not been some chances during the last 18 months. My kit kit included the back and side walls and floors which were all custom cut with 99% of the fine cutouts already there. If you are handy with time and sewing and fitting, the fabric from GBI could be the way to go. Indiana Larry)))))))))))))) > > The Side panels are awesome. The airplane on the website belongs to a > friend of mine and they are sweet....But for a thousand bucks for two > side panels they are too rich for my taste. > > Frank ________________________________________________________________________________
Date: Aug 08, 2005
I have an upholstery kit from Abby. It is COMPLETE! Every part is cut to shape for every exposed part in the cockpit and baggage area. About the only area that is not covered is the firewall. All you have to do is spray with adhesive and stick them in position. It is awesome! Of course if you have much more time than money, you could probably start with a large piece of upholstery cloth and do the same. But you would also have to know how to stitch pieces together and have an industrial sewing machine to do so as well. Well worth the money in my opinion! Dick Tasker Hinde, Frank George (Corvallis) wrote: > >Speaking of which, I like the idea of not painting the interior so... > >I was looking at the Fliteline Interiors interior kit for $600. I was >having a hard time understanding what I got for the money. I mean it >"looks" like a big sheet of fabric that you cut to suit....I note from >GBI they offer a "big sheet of fabric" for $75. > >Anyone know what the extra $525 buys me?... > >The Side panels are awesome. The airplane on the website belongs to a >friend of mine and they are sweet....But for a thousand bucks for two >side panels they are too rich for my taste. > >Frank > > > > ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Date: Aug 08, 2005
Frank, it gets you 37 individually custom cut pieces that fit perfectly. It includes the carpet also cut and the floor insulation as well as a firewall blanket. It was worth it to me. I think the rear baggage wall cover and baggage area cover is included as well. Talk to Abby, you won't be sorry. Bill S 7a Ark fuse panel -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Hinde, Frank George (Corvallis) Subject: RE: RV7-List: Interior thoughts.. Speaking of which, I like the idea of not painting the interior so... I was looking at the Fliteline Interiors interior kit for $600. I was having a hard time understanding what I got for the money. I mean it "looks" like a big sheet of fabric that you cut to suit....I note from GBI they offer a "big sheet of fabric" for $75. Anyone know what the extra $525 buys me?... The Side panels are awesome. The airplane on the website belongs to a friend of mine and they are sweet....But for a thousand bucks for two side panels they are too rich for my taste. Frank ________________________________________________________________________________
Date: Aug 08, 2005
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
I just saw your pics, I must admit it looks hot! Thanks for sending them to me...I have a raised center cover with a large box into which I can throw kinck knacks (going to make a lightweight cover to add cup holders just for a joke..:)..) So my front carpet will have to be custom. But apart from that..Boy yes she does good work! Frank -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Bill Schlatterer Subject: RE: RV7-List: Interior thoughts.. --> Frank, it gets you 37 individually custom cut pieces that fit perfectly. It includes the carpet also cut and the floor insulation as well as a firewall blanket. It was worth it to me. I think the rear baggage wall cover and baggage area cover is included as well. Talk to Abby, you won't be sorry. Bill S 7a Ark fuse panel -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Hinde, Frank George (Corvallis) Subject: RE: RV7-List: Interior thoughts.. Speaking of which, I like the idea of not painting the interior so... I was looking at the Fliteline Interiors interior kit for $600. I was having a hard time understanding what I got for the money. I mean it "looks" like a big sheet of fabric that you cut to suit....I note from GBI they offer a "big sheet of fabric" for $75. Anyone know what the extra $525 buys me?... The Side panels are awesome. The airplane on the website belongs to a friend of mine and they are sweet....But for a thousand bucks for two side panels they are too rich for my taste. Frank ________________________________________________________________________________
Date: Aug 08, 2005
Hey Folks, This sounds like an interesting package to me too - somewhere along the line I missed the URL of the supplier - could you repost it ? Many thanks, g > > > > Frank, it gets you 37 individually custom cut pieces that fit > perfectly. It > includes the carpet also cut and the floor insulation as well > as a firewall > blanket. It was worth it to me. I think the rear baggage wall > cover and > baggage area cover is included as well. Talk to Abby, you > won't be sorry. > > Bill S > 7a Ark fuse panel > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Hinde, Frank > George (Corvallis) > To: rv7-list(at)matronics.com > Subject: RE: RV7-List: Interior thoughts.. > > > > > Speaking of which, I like the idea of not painting the interior so... > > I was looking at the Fliteline Interiors interior kit for $600. I was > having a hard time understanding what I got for the money. I mean it > "looks" like a big sheet of fabric that you cut to suit....I note from > GBI they offer a "big sheet of fabric" for $75. > > Anyone know what the extra $525 buys me?... > > The Side panels are awesome. The airplane on the website belongs to a > friend of mine and they are sweet....But for a thousand bucks for two > side panels they are too rich for my taste. > > Frank > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 08, 2005
What does the complete Flightline interior kit weigh, roughly? Just curious what the penalty for plushness is. )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Richard Tasker" <retasker(at)optonline.net> Subject: Re: RV7-List: Interior thoughts.. > > I have an upholstery kit from Abby. It is COMPLETE! Every part is cut > to shape for every exposed part in the cockpit and baggage area. About > the only area that is not covered is the firewall. All you have to do > is spray with adhesive and stick them in position. > > It is awesome! > > Of course if you have much more time than money, you could probably > start with a large piece of upholstery cloth and do the same. But you > would also have to know how to stitch pieces together and have an > industrial sewing machine to do so as well. > > Well worth the money in my opinion! > > Dick Tasker > > Hinde, Frank George (Corvallis) wrote: > > > > >Speaking of which, I like the idea of not painting the interior so... > > > >I was looking at the Fliteline Interiors interior kit for $600. I was > >having a hard time understanding what I got for the money. I mean it > >"looks" like a big sheet of fabric that you cut to suit....I note from > >GBI they offer a "big sheet of fabric" for $75. > > > >Anyone know what the extra $525 buys me?... > > > >The Side panels are awesome. The airplane on the website belongs to a > >friend of mine and they are sweet....But for a thousand bucks for two > >side panels they are too rich for my taste. > > > >Frank > > > > > > > > > > ________________________________________________________________________________
Date: Aug 08, 2005
From: "Richard E. Tasker" <retasker(at)optonline.net>
http://my.execpc.com/~erdmannb/index.htm Dick Tasker Gerry Filby wrote: > > >Hey Folks, > >This sounds like an interesting package to me too - somewhere >along the line I missed the URL of the supplier - could you >repost it ? > >Many thanks, > >g > ---- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. ---- ________________________________________________________________________________
Date: Aug 08, 2005
Just FYI. She did a custom rear wall cover for my golf club compartment and baggage floor doors as well and they look great. Bill S -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Hinde, Frank George (Corvallis) Subject: RE: RV7-List: Interior thoughts.. I just saw your pics, I must admit it looks hot! Thanks for sending them to me...I have a raised center cover with a large box into which I can throw kinck knacks (going to make a lightweight cover to add cup holders just for a joke..:)..) So my front carpet will have to be custom. But apart from that..Boy yes she does good work! Frank -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Bill Schlatterer Subject: RE: RV7-List: Interior thoughts.. --> Frank, it gets you 37 individually custom cut pieces that fit perfectly. It includes the carpet also cut and the floor insulation as well as a firewall blanket. It was worth it to me. I think the rear baggage wall cover and baggage area cover is included as well. Talk to Abby, you won't be sorry. Bill S 7a Ark fuse panel -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Hinde, Frank George (Corvallis) Subject: RE: RV7-List: Interior thoughts.. Speaking of which, I like the idea of not painting the interior so... I was looking at the Fliteline Interiors interior kit for $600. I was having a hard time understanding what I got for the money. I mean it "looks" like a big sheet of fabric that you cut to suit....I note from GBI they offer a "big sheet of fabric" for $75. Anyone know what the extra $525 buys me?... The Side panels are awesome. The airplane on the website belongs to a friend of mine and they are sweet....But for a thousand bucks for two side panels they are too rich for my taste. Frank ________________________________________________________________________________
Date: Aug 08, 2005
About 12 pounds including the adhesive to mount the pieces (and including a couple extra large pockets for storage on the seat backs). As mentioned, this is complete - essentially every surface covered, including the floor, in the cockpit and the baggage area and includes a tonneau cover for the baggage area to keep prying eyes out. If you are worried about the extra weight and wanted to leave some off you could - Abby is very amenable to modifications. It should be noted that the kit is not just for "plushness" although it certainly is that :-) - the upholstery and carpet act to make a much quieter plane inside the cockpit. Probably warmer too at altitude To me the extra ten pounds are worth it - but then again my wife and I are well under the 170 lbs FAA "standard person" so we have more spare pounds to play with than some :-) . To each his own... Dick Tasker P.S. Did you ever build the warning tone circuit? Dan Checkoway wrote: > >What does the complete Flightline interior kit weigh, roughly? Just curious >what the penalty for plushness is. > >)_( Dan >RV-7 N714D >http://www.rvproject.com > ---- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. ---- ________________________________________________________________________________
Date: Aug 08, 2005
Just went and picked it all up and it couldn't be more than a couple of pounds 3-4 tops. It's very light and the carpet is nothing like what I would have thought of as "carpet" for weight. On the other hand, she did a fabulous job on my Oregon Aero seats and they are really heavy,.... but nice on the tush ;-) but that's OA and not the covers. NO regrets there. Bill S 7a Ark -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Dan Checkoway Subject: Re: RV7-List: Interior thoughts.. What does the complete Flightline interior kit weigh, roughly? Just curious what the penalty for plushness is. )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "Richard Tasker" <retasker(at)optonline.net> Subject: Re: RV7-List: Interior thoughts.. > > I have an upholstery kit from Abby. It is COMPLETE! Every part is cut > to shape for every exposed part in the cockpit and baggage area. About > the only area that is not covered is the firewall. All you have to do > is spray with adhesive and stick them in position. > > It is awesome! > > Of course if you have much more time than money, you could probably > start with a large piece of upholstery cloth and do the same. But you > would also have to know how to stitch pieces together and have an > industrial sewing machine to do so as well. > > Well worth the money in my opinion! > > Dick Tasker > > Hinde, Frank George (Corvallis) wrote: > > > > >Speaking of which, I like the idea of not painting the interior so... > > > >I was looking at the Fliteline Interiors interior kit for $600. I was > >having a hard time understanding what I got for the money. I mean it > >"looks" like a big sheet of fabric that you cut to suit....I note from > >GBI they offer a "big sheet of fabric" for $75. > > > >Anyone know what the extra $525 buys me?... > > > >The Side panels are awesome. The airplane on the website belongs to a > >friend of mine and they are sweet....But for a thousand bucks for two > >side panels they are too rich for my taste. > > > >Frank > > > > > > > > > > ________________________________________________________________________________
Date: Aug 08, 2005
Golf club compartment? Do you have pictures? Can you fit 2 sets and 2 people with some baggage? Thanks Rob... thinking about building On Aug 8, 2005, at 6:02 PM, Bill Schlatterer wrote: > > > Just FYI. She did a custom rear wall cover for my golf club > compartment and > baggage floor doors as well and they look great. > > > Bill S > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Hinde, Frank > George (Corvallis) > To: rv7-list(at)matronics.com > Subject: RE: RV7-List: Interior thoughts.. > > > > > I just saw your pics, I must admit it looks hot! > > Thanks for sending them to me...I have a raised center cover with a > large box into which I can throw kinck knacks (going to make a > lightweight cover to add cup holders just for a joke..:)..) So my > front > carpet will have to be custom. > > But apart from that..Boy yes she does good work! > > Frank > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Bill > Schlatterer > To: rv7-list(at)matronics.com > Subject: RE: RV7-List: Interior thoughts.. > > --> > > Frank, it gets you 37 individually custom cut pieces that fit > perfectly. > It includes the carpet also cut and the floor insulation as well as a > firewall blanket. It was worth it to me. I think the rear baggage > wall > cover and baggage area cover is included as well. Talk to Abby, you > won't be sorry. > > Bill S > 7a Ark fuse panel > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Hinde, Frank > George (Corvallis) > To: rv7-list(at)matronics.com > Subject: RE: RV7-List: Interior thoughts.. > > > > > Speaking of which, I like the idea of not painting the interior so... > > I was looking at the Fliteline Interiors interior kit for $600. I was > having a hard time understanding what I got for the money. I mean it > "looks" like a big sheet of fabric that you cut to suit....I note from > GBI they offer a "big sheet of fabric" for $75. > > Anyone know what the extra $525 buys me?... > > The Side panels are awesome. The airplane on the website belongs to a > friend of mine and they are sweet....But for a thousand bucks for two > side panels they are too rich for my taste. > > Frank > > ________________________________________________________________________________
Date: Aug 09, 2005
Yes I have the same package with some extras added (abby is awesome to work with) and the quality / price can't be beat.. you won't be disapointed.. Danny.. ----- Original Message ----- From: Gerry Filby <gerf(at)gerf.com> Date: Monday, August 8, 2005 6:56 pm Subject: RE: RV7-List: Interior thoughts.. > > > Hey Folks, > > This sounds like an interesting package to me too - somewhere > along the line I missed the URL of the supplier - could you > repost it ? > > Many thanks, > > g > > > > > > > > > > Frank, it gets you 37 individually custom cut pieces that fit > > perfectly. It > > includes the carpet also cut and the floor insulation as well > > as a firewall > > blanket. It was worth it to me. I think the rear baggage wall > > cover and > > baggage area cover is included as well. Talk to Abby, you > > won't be sorry. > > > > Bill S > > 7a Ark fuse panel > > > > -----Original Message----- > > From: owner-rv7-list-server(at)matronics.com > > [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Hinde, > Frank> George (Corvallis) > > To: rv7-list(at)matronics.com > > Subject: RE: RV7-List: Interior thoughts.. > > > > > > > > > > Speaking of which, I like the idea of not painting the interior > so...> > > I was looking at the Fliteline Interiors interior kit for $600. > I was > > having a hard time understanding what I got for the money. I > mean it > > "looks" like a big sheet of fabric that you cut to suit....I > note from > > GBI they offer a "big sheet of fabric" for $75. > > > > Anyone know what the extra $525 buys me?... > > > > The Side panels are awesome. The airplane on the website belongs > to a > > friend of mine and they are sweet....But for a thousand bucks > for two > > side panels they are too rich for my taste. > > > > Frank > > > > > > > > > > > > > > > > -- > __g__ > > ========================================================== > Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 > > > > > > > ________________________________________________________________________________
Date: Aug 09, 2005
Well, for those of us that don't like chemicals and spray guns, Abby's interior kit looks like a great way to get out of painting almost every piece of the interior. - Jamie RV-7A Forward Fuselage http://rv.jpainter.org sportypilot(at)stx.rr.com wrote: > >Yes I have the same package with some extras added (abby is awesome to >work with) >and the quality / price can't be beat.. you won't be disapointed.. > >Danny.. > >----- Original Message ----- >From: Gerry Filby <gerf(at)gerf.com> >Date: Monday, August 8, 2005 6:56 pm >Subject: RE: RV7-List: Interior thoughts.. > > > >> >> >>Hey Folks, >> >>This sounds like an interesting package to me too - somewhere >>along the line I missed the URL of the supplier - could you >>repost it ? >> >>Many thanks, >> >>g >> >> >> >> >>> >>> >>>Frank, it gets you 37 individually custom cut pieces that fit >>>perfectly. It >>>includes the carpet also cut and the floor insulation as well >>>as a firewall >>>blanket. It was worth it to me. I think the rear baggage wall >>>cover and >>>baggage area cover is included as well. Talk to Abby, you >>>won't be sorry. >>> >>>Bill S >>>7a Ark fuse panel >>> >>>-----Original Message----- >>>From: owner-rv7-list-server(at)matronics.com >>>[mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Hinde, >>> >>> >>Frank> George (Corvallis) >> >> >>>To: rv7-list(at)matronics.com >>>Subject: RE: RV7-List: Interior thoughts.. >>> >>> >>> >>> >>>Speaking of which, I like the idea of not painting the interior >>> >>> >>so...> >> >> >>>I was looking at the Fliteline Interiors interior kit for $600. >>> >>> >>I was >> >> >>>having a hard time understanding what I got for the money. I >>> >>> >>mean it >> >> >>>"looks" like a big sheet of fabric that you cut to suit....I >>> >>> >>note from >> >> >>>GBI they offer a "big sheet of fabric" for $75. >>> >>>Anyone know what the extra $525 buys me?... >>> >>>The Side panels are awesome. The airplane on the website belongs >>> >>> >>to a >> >> >>>friend of mine and they are sweet....But for a thousand bucks >>> >>> >>for two >> >> >>>side panels they are too rich for my taste. >>> >>>Frank >>> >>> >>> >>> >>> >>> >>> >>> >>> >>-- >>__g__ >> >>========================================================== >>Gerry Filby gerf(at)gerf.com >> Tel: 415 203 9177 >> >> >> >> >> >> >> >> >> > > > > ________________________________________________________________________________
Subject: Rudder Skin Question
Date: Aug 09, 2005
We are getting to the point that we are ready to rivet on the rudder skin and there is nothing really indicating whether the R901L & R go over or under the counter-balance skin. To me logic would suggest that the counter balance skin goes on top but in the drawings it looks like the rudder skin goes on top pointing into the wind. I know it sounds like a simple question; I just want to make sure it is right. Any experienced builders care to comment? Thanks, Scott (Rudder ready to close out - wing kit still collecting dust) ________________________________________________________________________________
Date: Aug 09, 2005
Subject: Wing tip modification
Has any one modified their wing tips for light storage? I remember seeing this a few years ago at Oshkosh, and from what I remember it looked like they cut a rectangle in the top with a hinge and lock. Does any one have picture or pro's and con's stories? Looks like a good place to stow a canopy cover and stuff like that.... Thanks, Dan S. Oklahoma City ________________________________________________________________________________
Date: Aug 09, 2005
Rudder skin goes on top of the counter balance skin...Taper the edge of the rudder skin to give a smooth transition Frank RV 7a -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Scott R. Shook Subject: RV7-List: Rudder Skin Question We are getting to the point that we are ready to rivet on the rudder skin and there is nothing really indicating whether the R901L & R go over or under the counter-balance skin. To me logic would suggest that the counter balance skin goes on top but in the drawings it looks like the rudder skin goes on top pointing into the wind. I know it sounds like a simple question; I just want to make sure it is right. Any experienced builders care to comment? Thanks, Scott (Rudder ready to close out - wing kit still collecting dust) ________________________________________________________________________________
Subject: Storage mods
Date: Aug 09, 2005
And how about this idea.... Even with an IFR stack my space between the sub panel and firwall will be almost completly empty. A lot of builders have cut access holes in the top skin either side of the central stiffner. Looks to me like a lot of space where a small locker could be fabricated. In the right place from a W&B perspective too. Sounds whacky but it looks doable and when your camping you always need a little more space for hiking boots, food items, kitchen sink etc. Frank ________________________________________________________________________________
Subject: Re: Rudder Skin Question
Date: Aug 09, 2005
Definitely on top - you want overlapping edges pointing aft - unless you're planning on flying backwads ;-) g > > > We are getting to the point that we are ready to rivet on the > rudder skin > and there is nothing really indicating whether the R901L & R go over or > under the counter-balance skin. To me logic would suggest that > the counter > balance skin goes on top but in the drawings it looks like the > rudder skin > goes on top pointing into the wind. > > I know it sounds like a simple question; I just want to make sure it is > right. Any experienced builders care to comment? > > > Thanks, > > Scott > (Rudder ready to close out - wing kit still collecting dust) > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 09, 2005
Subject:
rv7-list(at)matronics.com, rv8-list(at)matronics.com, rv9-list(at)matronics.com, Listers, Gary VanRemortel just sent me an update to the RV Yeller Pages and it can be found here: http://www.matronics.com/YellerPages/ Thanks Gary!! Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Aug 09, 2005
> Definitely on top - you want overlapping edges pointing aft - > unless you're planning on flying backwads ;-) Actually, the configuration where the gap faces *forward* apparently produces less drag! That said, my gaps face aft. I do know of one RV-6 with all gaps facing forward, though. )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Aug 09, 2005
Wow, that does surprise me - can any of you aeronautical engineers enlighten on how this works ? I'm pretty sure the ailerons on the 9 have the counterbalance skins on top - at least mine do :-)) I was also thinking of bugs, liquids and the like being drawn into the interior, although it is protected somewhat by the flight surface its hinged on. g > > > > Definitely on top - you want overlapping edges pointing aft - > > unless you're planning on flying backwads ;-) > > Actually, the configuration where the gap faces *forward* apparently > produces less drag! > > That said, my gaps face aft. I do know of one RV-6 with all gaps facing > forward, though. > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 09, 2005
I asked because in drawing 7 of the rudder, the counterbalance skin is drawn with broken lines (that would put the gap facing forward and the rudder skin is overlapping the counter balance skin). From my H.S. mechanical drawing class I recall broken lines indicate that things are hidden. That's why I was confused. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Dan Checkoway Subject: Re: RV7-List: Rudder Skin Question > Definitely on top - you want overlapping edges pointing aft - > unless you're planning on flying backwads ;-) Actually, the configuration where the gap faces *forward* apparently produces less drag! That said, my gaps face aft. I do know of one RV-6 with all gaps facing forward, though. )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Aug 10, 2005
Scott, I suspect that the main reason overlaps should face aft is that the slipstream will blast rain into the overlap causing corrosion in the longer run. At our speeds I suspect the aerodynamic effects are a secondary consideration. In the case of the ailerons, I suspect the forward facing overlap is to ease construction. Note that the trailing edge finish on RV ailerons is critical to sweet handling and I suspect Van wants to avoid a riveted trailing aileron edge at all costs. Obviously the rudder trailing edge is not as critical to rudder effectiveness. Just a lateral thought, David Francis, Canberra, Australia. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] Subject: RE: RV7-List: Rudder Skin Question I asked because in drawing 7 of the rudder, the counterbalance skin is drawn with broken lines (that would put the gap facing forward and the rudder skin is overlapping the counter balance skin). From my H.S. mechanical drawing class I recall broken lines indicate that things are hidden. That's why I was confused. -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Dan Checkoway Subject: Re: RV7-List: Rudder Skin Question > Definitely on top - you want overlapping edges pointing aft - > unless you're planning on flying backwads ;-) Actually, the configuration where the gap faces *forward* apparently produces less drag! That said, my gaps face aft. I do know of one RV-6 with all gaps facing forward, though. )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Aug 09, 2005
Check your rudder drawing in section G-10. There are notes there referring to bevelling the outside of the skin to make a smooth transition for the rudder skin. I beveled the inside to hide any errant scratches. The rudder skin then goes over the counterbalance skin. Bass ackwards, but the way Van's designed it. If you peel the rudder skin back at the counterbalance, you are flying way to fast. Dave Nellis N410DN (Res.) --- Dan Checkoway wrote: > > > > Definitely on top - you want overlapping edges > pointing aft - > > unless you're planning on flying backwads ;-) > > Actually, the configuration where the gap faces > *forward* apparently > produces less drag! > > That said, my gaps face aft. I do know of one RV-6 > with all gaps facing > forward, though. > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > > > browse > Subscriptions page, > FAQ, > > > > > > ________________________________________________________________________________
Date: Aug 09, 2005
Scott, Although the plans are not clear and the instructions don't specifically say so, the counterbalance skin laps over the top of the rudder skins. There is a note on the plans to taper the aft edge of the counterbalance skin. There would be no reason to do this if this part were covered by the rudder skins. This way, the rudder skins lay flat on the spar all the way up and the counterbalance skin makes a bit of a joggle as it goes from the rib to the rudder skin. These skins are all of what, .016? so it isn't much of a jump. Call Van's if you want an official ruling. Mark Scott R. Shook wrote: > >We are getting to the point that we are ready to rivet on the rudder skin >and there is nothing really indicating whether the R901L & R go over or >under the counter-balance skin. To me logic would suggest that the counter >balance skin goes on top but in the drawings it looks like the rudder skin >goes on top pointing into the wind. > >I know it sounds like a simple question; I just want to make sure it is >right. Any experienced builders care to comment? > > >Thanks, > >Scott >(Rudder ready to close out - wing kit still collecting dust) > > ________________________________________________________________________________
Date: Aug 09, 2005
Sorry, but you've got it backwards. The rudder skin goes ON TOP (as in outside) of the counterbalance skin as per the plans. Hence the dashed line for the outline of the rudder counterbalance skin as it sits behind the rudder skin. As was stated earlier, you bevel the "outside" (quoted from the plans) edges of the counterbalance skin (per the diagram) so that the rudder skins lay flat as they transitions from the spar OVER the edge of counterbalance skin. It does seem counterintuitive at first to have the exposed edge of the rudder skins facing forward, but they fit very tight and flush. I don't know, but it may have been counterbalance skin over rudder skin in the older style rudder (bent TE), but for the newer style rudder (riveted TE) it IS rudder skin over counterbalance skin. Regards, Brad Oliver RV-7 Livermore, CA -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Mark Grieve Subject: Re: RV7-List: Rudder Skin Question Scott, Although the plans are not clear and the instructions don't specifically say so, the counterbalance skin laps over the top of the rudder skins. There is a note on the plans to taper the aft edge of the counterbalance skin. There would be no reason to do this if this part were covered by the rudder skins. This way, the rudder skins lay flat on the spar all the way up and the counterbalance skin makes a bit of a joggle as it goes from the rib to the rudder skin. These skins are all of what, .016? so it isn't much of a jump. Call Van's if you want an official ruling. Mark Scott R. Shook wrote: > >We are getting to the point that we are ready to rivet on the rudder skin >and there is nothing really indicating whether the R901L & R go over or >under the counter-balance skin. To me logic would suggest that the counter >balance skin goes on top but in the drawings it looks like the rudder skin >goes on top pointing into the wind. > >I know it sounds like a simple question; I just want to make sure it is >right. Any experienced builders care to comment? > > >Thanks, > >Scott >(Rudder ready to close out - wing kit still collecting dust) > > ________________________________________________________________________________
Subject: Van's Firewall Forward Kit ... worth the money ?
Date: Aug 10, 2005
0.25 HELO_DYNAMIC_DHCP Relay HELO'd using suspicious hostname (DHCP) 0.74 HELO_DYNAMIC_HCC Relay HELO'd using suspicious hostname (HCC) 1.40 HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP addr 1) More shopping decisions ... Van's Firewall Forward kit for the RV-9 (constant speed prop) is some $4,300. Whilst Van's kits are usually very good value for money, I was wondering what experiences people had with this kit. Were you happy with the qauality ? Were there things missing or things not needed ? Did you still have to fork out for extras ? Would you buy it again ? PS Most likely I'm going to get an IO-320 from Aerosport which might have some bearing on the cost effectiveness of the FWF kit. __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 10, 2005
Subject: Re: Van's Firewall Forward Kit ... worth the money ?
Gerry Filby wrote: > > >More shopping decisions ... > >Van's Firewall Forward kit for the RV-9 (constant speed prop) >is some $4,300. Whilst Van's kits are usually very good value >for money, I was wondering what experiences people had with >this kit. > >Were you happy with the qauality ? > > Yes >Were there things missing or things not needed ? > > The closer you are to standard (i.e. no funny fuel injection or electronic ignition) the closer the kit will be to what you want. I suspect that there would still be a few things here and there that would not quite match up to your exact needs but it'll be close. I went with one electronic ignition and an AFP fuel injection system on what would normally be a carburated engine so I had to do a lot of deleting of stuff from the kit but all in all it was pretty decent. >Did you still have to fork out for extras ? > > Of course. >Would you buy it again ? > > Absolutely! Just having the right hoses, and fittings made it worth it. There is a lot of stuff in there. Some of it you'll decide not to use and some of it will fall short but it sucks to spend $5 shipping a $6 part because it's the only little fitting that you need. >PS Most likely I'm going to get an IO-320 from Aerosport which >might have some bearing on the cost effectiveness of the FWF kit. > > Take a close look at the list of things that are in the IO-320 kit. Van's will let you delete things from the kit. I deleted about half of the O-360 kit stuff on mine and it worked out great. Call them, they will work with you. >__g__ > > > > Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB - Finishing Up http://www.myrv7.com ________________________________________________________________________________
Subject: Rudder/Counterweight Skin Over/Under Debate
Date: Aug 10, 2005
For those pondering which skin goes on top-- built my empennage at Alexander Technical Center (www.buildtofly.com), and they were adamant that, illogical as it may seem... it goes as shown on the drawing with the rudder skin on top. Both edges do get tapered down to give as smooth a joint as possible. They've built hundreds of these puppies down there. ________________________________________________________________________________
Date: Aug 10, 2005
absolutely worth the money. Everything fits as is should and you have all the pieces you need to complete the kit. Tad S. RV7A Painting ________________________________________________________________________________
Date: Aug 10, 2005
Under, If it is the same as the 7A Tad S. Painting ________________________________________________________________________________
Date: Aug 10, 2005
I did a little checking into the cost comparisons of the FWF kit & separate parts. I priced everything listed on the sample FWF kit (I think it was a 320 CS setup) and separate parts as listed in the Van's catalog & their website. I may have had to look at Spruce for some things. I could only come up with something like a $300 difference. That was enough to convince me that the FWF kit was worth it. Sam 7A @ABI emp attached to fuse -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Sargentclt(at)cs.com Subject: Re: RV7-List: Van's Firewall Forward Kit ... worth the money ? absolutely worth the money. Everything fits as is should and you have all the pieces you need to complete the kit. Tad S. RV7A Painting ________________________________________________________________________________
money ?
Date: Aug 11, 2005
Gerry, I got an injected 0360 with aerobatic sump, constant speed, from Aerosport. The engine is just superb. I had to do a lot of deleting from the Vans FWF kit to cater for my odd sump, but must say that the baffle kit, oil cooler and hoses and connections alone make life relatively easy and are very well priced. I deleted the throttle/mixture/governor cables and exhaust due to my Sky Dynamics sump, and the cost and delays in getting substitutes from Spruce is quite high. So staying with Vans standard designs saves on freight and lots of labour making up odd shaped brackets. Standardisation really has big benefits. One final comment, for fuel injection Vans plans do not include a gascolator to trap water. If you elect to fit a gascolator you will need a high pressure Andair gascolator, not a Vans low pressure one. Dont ask how I found out the difference. Regards, David A Francis, Canberra, Australia -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] Subject: RV7-List: Van's Firewall Forward Kit ... worth the money ? More shopping decisions ... Van's Firewall Forward kit for the RV-9 (constant speed prop) is some $4,300. Whilst Van's kits are usually very good value for money, I was wondering what experiences people had with this kit. Were you happy with the qauality ? Were there things missing or things not needed ? Did you still have to fork out for extras ? Would you buy it again ? PS Most likely I'm going to get an IO-320 from Aerosport which might have some bearing on the cost effectiveness of the FWF kit. __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 10, 2005
Subject: RE: RV9-List: Van's Firewall Forward Kit ... worth the money
? Definitely 80% of the wiring part of the kit was useless. Most of the wires were for other models and unless you are going to install Vans prepunched panel most of the smaller wires are useless also. I just cut them up and used them as I could. Although, what do you do when you have to crimp a 003 wire? -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Gerry Filby Subject: RV9-List: Van's Firewall Forward Kit ... worth the money ? --> RV9-List message posted by: Gerry Filby More shopping decisions ... Van's Firewall Forward kit for the RV-9 (constant speed prop) is some $4,300. Whilst Van's kits are usually very good value for money, I was wondering what experiences people had with this kit. Were you happy with the qauality ? Were there things missing or things not needed ? Did you still have to fork out for extras ? Would you buy it again ? PS Most likely I'm going to get an IO-320 from Aerosport which might have some bearing on the cost effectiveness of the FWF kit. __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 10, 2005
Bradley, I was involved in the construction of 2 RV-9 rudders and thought sure the counterbalance skin went on top. Humm, could my memory be going on me here? That was 3 years ago. I am sorry for providing bad information and trying to sound like such an authority all the while. Thank you for setting me straight. Mark Bradley Oliver wrote: > > >Sorry, but you've got it backwards. The rudder skin goes ON TOP (as in >outside) of the counterbalance skin as per the plans. Hence the dashed line >for the outline of the rudder counterbalance skin as it sits behind the >rudder skin. As was stated earlier, you bevel the "outside" (quoted from >the plans) edges of the counterbalance skin (per the diagram) so that the >rudder skins lay flat as they transitions from the spar OVER the edge of >counterbalance skin. It does seem counterintuitive at first to have the >exposed edge of the rudder skins facing forward, but they fit very tight and >flush. > >I don't know, but it may have been counterbalance skin over rudder skin in >the older style rudder (bent TE), but for the newer style rudder (riveted >TE) it IS rudder skin over counterbalance skin. > >Regards, >Brad Oliver >RV-7 Livermore, CA > > >-----Original Message----- >From: owner-rv7-list-server(at)matronics.com >[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Mark Grieve >To: rv7-list(at)matronics.com >Subject: Re: RV7-List: Rudder Skin Question > > >Scott, >Although the plans are not clear and the instructions don't specifically >say so, the counterbalance skin laps over the top of the rudder skins. >There is a note on the plans to taper the aft edge of the counterbalance >skin. There would be no reason to do this if this part were covered by >the rudder skins. This way, the rudder skins lay flat on the spar all >the way up and the counterbalance skin makes a bit of a joggle as it >goes from the rib to the rudder skin. These skins are all of what, .016? >so it isn't much of a jump. > >Call Van's if you want an official ruling. >Mark > >Scott R. Shook wrote: > > > >> >>We are getting to the point that we are ready to rivet on the rudder skin >>and there is nothing really indicating whether the R901L & R go over or >>under the counter-balance skin. To me logic would suggest that the counter >>balance skin goes on top but in the drawings it looks like the rudder skin >>goes on top pointing into the wind. >> >>I know it sounds like a simple question; I just want to make sure it is >>right. Any experienced builders care to comment? >> >> >>Thanks, >> >>Scott >>(Rudder ready to close out - wing kit still collecting dust) >> >> >> >> >> ________________________________________________________________________________
Date: Aug 11, 2005
Subject: Re: Storage mods
Frank, I like it, I'll keep this in mind when I get to that step on my fuse. It might need a skin stiffener to transfer the load at the access door, but that can be worked into the design. Still working on the wing tip storage design, fiberglass....Ugh! Thanks, Dan S. OKC -------Original Message------- From: Hinde, Frank George (Corvallis) Date: 08/09/05 18:15:35 Subject: RV7-List: Storage mods hinde(at)hp.com> And how about this idea.... Even with an IFR stack my space between the sub panel and firwall will be almost completly empty. A lot of builders have cut access holes in the top skin either side of the central stiffner. Looks to me like a lot of space where a small locker could be fabricated. In the right place from a W&B perspective too. Sounds whacky but it looks doable and when your camping you always need a little more space for hiking boots, food items, kitchen sink etc. Frank ________________________________________________________________________________
Date: Aug 12, 2005
Don't forget that the wiring for all the avionics takes up space and the plumbing for your instruments. I wouldn't recommend it, it'll make things too tight to work up under there and if you have to fix or add something in the future you'll be learning how to cuss. Cheers Norman RV-6, RV-7, RV-7, F1 Rocket, working on a RV-9A Daniel Storer wrote: > >Frank, > >I like it, I'll keep this in mind when I get to that step on my fuse. It >might need a skin stiffener to transfer the load at the access door, but >that can be worked into the design. Still working on the wing tip storage >design, fiberglass....Ugh! > >Thanks, > >Dan S. >OKC >-------Original Message------- > >From: Hinde, Frank George (Corvallis) >Date: 08/09/05 18:15:35 >To: rv7-list(at)matronics.com >Subject: RV7-List: Storage mods > >hinde(at)hp.com> > >And how about this idea.... > >Even with an IFR stack my space between the sub panel and firwall will >be almost completly empty. A lot of builders have cut access holes in >the top skin either side of the central stiffner. Looks to me like a lot >of space where a small locker could be fabricated. In the right place >from a W&B perspective too. > >Sounds whacky but it looks doable and when your camping you always need >a little more space for hiking boots, food items, kitchen sink etc. > >Frank > > > > ________________________________________________________________________________
Subject: Firewall Recess undersized
Date: Aug 12, 2005
I'm just starting to match the F-601K recess to the firewall (RV-7) and am having difficulty aligning the holes. The top sides of the recess (airframe coordinates) on the upper section, where the metal is formed using bends at two different angles, is crinkled slightly...but the bends were made such that the overall width of the recessed piece is undersized ~ 0.150. I'd expect someone else has had this problem, hopefully; I'm debating using a wood block and a hammer to try and take some of the bend out but I'm afraid of either overdoing it and not being able to bend it back (after cold working) or crinkling the sidewalls such that other holes won't line up. I suppose you can't really see it unless you're looking for it... but I can wait to see if there are any tried and true tricks to widening it. Any thoughts would be appreciated, Andy Olech, RV-7 Ellington, CT ________________________________________________________________________________
Date: Aug 13, 2005
"'rv7-list(at)matronics.com'" Subject: Date: Sat, 13 Aug 2005 14:54:36 -0500 Hey guys, > > > I am new to the RV list and recently purchased a RF7A QB from an > individual. I was trying to fit up my HS/elevator and noticed that > when clamped in place, there was almost no travel of down elevator > allowed due to the down stop (F711E). When I called Vans, they told > me that this piece had to be trimmed and almost seemed insulted by the > question since this information was in my instructions. > > > Well either I'm a complete idiot or I am missing something because I > have been completely through my instructions and drawings and I have found no reference to this nor have I found any information on elevator defection limits. I am concerned that maybe I am missing some of my instruction manual. > > > Can anyone out there tell me where this info is located? Hey guys, I am new to the RV list and recently purchased a RF7A QB from an individual. I was trying to fit up my HS/elevator and noticed that when clamped in place, there was almost no travel of down elevator allowed due to the down stop (F711E). When I called Vans, they told me that this piece had to be trimmed and almost seemed insulted by the question since this information was in my instructions. Well either I'm a complete idiot or I am missing something because I have been completely through my instructions and drawings and I have found no reference to this nor have I found any information on elevator defection limits. I am concerned that maybe I am missing some of my instruction manual. Can anyone out there tell me where this info is located? ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: Re:
Date: Aug 13, 2005
----- Original Message ----- From: <owner-rv7-list-server(at)matronics.com> > > From: "AYRES, JIMMY L" <JAYRES(at)entergy.com> > To: "'rvsoutheast-list(at)matronics.com'" , > "'rv7-list(at)matronics.com'" > Subject: > Date: Sat, 13 Aug 2005 14:54:36 -0500 > > Hey guys, > >> > >> > >> I am new to the RV list and recently purchased a RF7A QB from an > >> individual. I was trying to fit up my HS/elevator and noticed that > >> when clamped in place, there was almost no travel of down elevator > >> allowed due to the down stop (F711E). When I called Vans, they told > >> me that this piece had to be trimmed and almost seemed insulted by the > >> question since this information was in my instructions. ((((((((((I too have been convinced some needed facts were not in the builder's manual or the drawings. After several humbling enlightenments, I have learned that Vans knows their stuff and they have worked with the instructions and our questions enough that they know what they are saying. You are right to consult the RV-List to look for a quick answer or second opinion. The best, final authority is alway Vans however. )))))))))))) > >> > >> > >> Well either I'm a complete idiot or I am missing something because I > >> have been completely through my instructions and drawings and I have >> found no reference to this nor have I found any information on elevator >> defection limits. I am concerned that maybe I am missing some of my >> instruction manual. ((((((((((Vans can quote you page and paragraph where such instructions are located. Take a humble attitude with Vans and I think you will great cooperation and help. If you are missing something, they can help you but when you need it, you need it. When it is all done and you are flying as I and my wife did today to visit your son, you will nearly forget all those days when you learned something new. )))))))))))))))) > >> > >> > >> Can anyone out there tell me where this info is located? ((((((((((NO not off hand, my plans and builder's manual are at the hangar. But, I can tell you that they are there. You might look in the manual where it instructs you to mount the elevators on the horizontal stabilizer. The min and max angles are there somewhere. (I found them and used them during the building process.) Indiana Larry, RV7 Tip Up It Flies ))))))))))))))) > ________________________________________________________________________________
Subject: cabin heat for RV 7a
Date: Aug 13, 2005
I understand that some RV builders have been installing the cabin heat system that is offered from Glasair. The system has a rotary valve that can direct heat to both pilot and passenger and windshield defrost. I was wondering if any one had any knowledge of this unit and how well it works. Wisconsin gets real cold in winter. Thanks Don ________________________________________________________________________________
Date: Aug 13, 2005
Subject: Re:
Jimmy - Instructions for setting the elevator travel stops can be found on page 8-16, with the reference drawing no. 27A. Travel limits for the elevator and all the control surfaces can be found on page 15-2 Herb --- owner-rv7-list-server(at)matronics.com wrote: > > From: "AYRES, JIMMY L" <JAYRES(at)entergy.com> > To: "'rvsoutheast-list(at)matronics.com'" > , > "'rv7-list(at)matronics.com'" > > Subject: > Date: Sat, 13 Aug 2005 14:54:36 -0500 > > Hey guys, > > > > > > > > > I am new to the RV list and recently purchased a > RF7A QB from an > > > individual. I was trying to fit up my HS/elevator > and noticed that > > > when clamped in place, there was almost no travel > of down elevator > > > allowed due to the down stop (F711E). When I > called Vans, they told > > > me that this piece had to be trimmed and almost > seemed insulted by the > > > question since this information was in my > instructions. > > > > > > > > > Well either I'm a complete idiot or I am missing > something because I > > > have been completely through my instructions and > drawings and I have found no reference to this nor > have I found any information on elevator defection > limits. I am concerned that maybe I am missing some > of my instruction manual. > > > > > > > > > Can anyone out there tell me where this info is > located? > > > > > > style='font-size:10.0pt;font-family:"Courier > New"'>Hey guys, > > > style='font-size:10.0pt;font-family:"Courier New"'> > > > style='font-size:10.0pt;font-family:"Courier New"'> > > > style='font-size:10.0pt;font-family:"Courier New"'> > I am new to the RV list > and recently purchased a RF7A QB from an > > > style='font-size:10.0pt;font-family:"Courier New"'> > individual. I was > trying to fit up my HS/elevator and noticed that > > > style='font-size:10.0pt;font-family:"Courier New"'> > when clamped in place, > there was almost no travel of down elevator > > > style='font-size:10.0pt;font-family:"Courier New"'> > allowed due to the down > stop (F711E). When I called Vans, they told > > > style='font-size:10.0pt;font-family:"Courier New"'> > me that this piece had > to be trimmed and almost seemed insulted by the > > > style='font-size:10.0pt;font-family:"Courier New"'> > question since this > information was in my instructions. > > > style='font-size:10.0pt;font-family:"Courier New"'> > > > style='font-size:10.0pt;font-family:"Courier New"'> > > > style='font-size:10.0pt;font-family:"Courier New"'> > Well either I'm a > complete idiot or I am missing something because I > > > style='font-size:10.0pt;font-family:"Courier New"'> > have been completely > through my instructions and drawings and I have > found no reference to this nor > have I found any information on elevator defection > limits. I am concerned that > maybe I am missing some of my instruction manual. > > > style='font-size:10.0pt;font-family:"Courier New"'> > > > style='font-size:10.0pt;font-family:"Courier New"'> > > > style='font-size:10.0pt;font-family:"Courier New"'> > Can anyone out there > tell me where this info is located? > > > > > > > browse > Subscriptions page, > FAQ, > > > > > > ________________________________________________________________________________
Subject: Re:
Date: Aug 14, 2005
Section 15, Page 2 shows the angles for rigging control surfaces. It's not where you'd expect to look for something when your working on your empennage. Good luck! Mark. www.4sierratango.com >From: "LarryRobertHelming" <lhelming(at)sigecom.net> >Reply-To: rv7-list(at)matronics.com >To: >Subject: RV7-List: Re: Date: Sat, 13 Aug 2005 19:55:00 -0500 > > >----- Original Message ----- >From: <owner-rv7-list-server(at)matronics.com> > > > > > > From: "AYRES, JIMMY L" <JAYRES(at)entergy.com> > > To: "'rvsoutheast-list(at)matronics.com'" , > > "'rv7-list(at)matronics.com'" > > Subject: > > Date: Sat, 13 Aug 2005 14:54:36 -0500 > > > > Hey guys, > > > >> > > > >> > > > >> I am new to the RV list and recently purchased a RF7A QB from an > > > >> individual. I was trying to fit up my HS/elevator and noticed that > > > >> when clamped in place, there was almost no travel of down elevator > > > >> allowed due to the down stop (F711E). When I called Vans, they told > > > >> me that this piece had to be trimmed and almost seemed insulted by the > > > >> question since this information was in my instructions. > >((((((((((I too have been convinced some needed facts were not in the >builder's manual or the drawings. After several humbling enlightenments, I >have learned that Vans knows their stuff and they have worked with the >instructions and our questions enough that they know what they are saying. >You are right to consult the RV-List to look for a quick answer or second >opinion. The best, final authority is alway Vans however. )))))))))))) > > > >> > > > >> > > > >> Well either I'm a complete idiot or I am missing something because I > > > >> have been completely through my instructions and drawings and I have > >> found no reference to this nor have I found any information on elevator > >> defection limits. I am concerned that maybe I am missing some of my > >> instruction manual. > >((((((((((Vans can quote you page and paragraph where such instructions are >located. Take a humble attitude with Vans and I think you will great >cooperation and help. If you are missing something, they can help you but >when you need it, you need it. When it is all done and you are flying as I >and my wife did today to visit your son, you will nearly forget all those >days when you learned something new. )))))))))))))))) > > > > >> > > > >> > > > >> Can anyone out there tell me where this info is located? > >((((((((((NO not off hand, my plans and builder's manual are at the hangar. >But, I can tell you that they are there. You might look in the manual >where >it instructs you to mount the elevators on the horizontal stabilizer. The >min and max angles are there somewhere. (I found them and used them during >the building process.) > >Indiana Larry, RV7 Tip Up It Flies ))))))))))))))) > > > > ________________________________________________________________________________
Subject: RV 8 Gear Towers
Date: Aug 16, 2005
There has been some discussion relating to opening the towers for better access. What I would like is those that have and are flying to let us know how they are holding up. Also is there any engineering out there on the pros and cons. I am thinking of this but still up in the air. I have had mixed opinions from good sources. Thanks, Ed Clegg ________________________________________________________________________________
Date: Aug 16, 2005
Vans has indicated that the rivets which hold the 802C to the angles could be replaced with #8 screws. I consequently went ahead and cut 802C cross wise above the WD821 weldment and two rivet holes below the top lightening hole. I also put two stout doubler plates to effect the junction. The doubler plates are riveted into the removable part of 802C and screwed via #8s into the top and bottom part of 802C. Have not flown yet so can't report but if anyone is interested I can send pictures. Michele Delsol RV8 Fuselage > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list- > server(at)matronics.com] On Behalf Of ed clegg > Sent: Tuesday, August 16, 2005 3:39 PM > To: rv7-list(at)matronics.com; RV-8(at)yahoogroups.com > Subject: RV7-List: RV 8 Gear Towers > > > There has been some discussion relating to opening the towers for better > access. > What I would like is those that have and are flying to let us know how > they > are holding up. > Also is there any engineering out there on the pros and cons. > I am thinking of this but still up in the air. I have had mixed opinions > from good sources. > Thanks, > Ed Clegg > > > > > ________________________________________________________________________________
Subject: Roller tappets - another ~ - OUCH !!
Date: Aug 16, 2005
0.25 HELO_DYNAMIC_DHCP Relay HELO'd using suspicious hostname (DHCP) 0.74 HELO_DYNAMIC_HCC Relay HELO'd using suspicious hostname (HCC) 1.40 HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP addr 1) Folks, Looks like adding the roller tappet option to your 320 or 360 is going to add another $3-4000 to the price (that's Aerosport's current estimate). I've been hunting around and haven't found much discussion on the upgrade apart from various announcements from Delphi and Lycoming. This "new technology" solves premature wear and corrosion only ? They also enable alternate cam profiles ? (Not likely for this first timer.) Is it worth it ? If the subject's been beaten to death already I'd happily take a link to some reference ... __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 17, 2005
From: "Francis, David CMDR" <David.Francis(at)defence.gov.au>
Gerry, As I understand it galled tappets are expensive to repair, probably more than the cost of the installation of roller tappets. But the writings I have seen indicate that galled tappets is most common in aircraft that fly infrequently. If you fly a minimum of 30 minutes per week every week you will probably be safe. The 30 minute figure is driven by a separate issue. It generally takes a bit under 30 minutes of operation at normal temperatures to drive all moisture out of the lubrication oil, and that prevents internal engine corrosion. I fly a Pawnee glider tug that flies only on weekends, 1-3 hrs per week, since 1982, and its never had a galling problem. Regards, David Francis, Canberra, Australia -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] Subject: RV7-List: Roller tappets - another ~ - OUCH !! Folks, Looks like adding the roller tappet option to your 320 or 360 is going to add another $3-4000 to the price (that's Aerosport's current estimate). I've been hunting around and haven't found much discussion on the upgrade apart from various announcements from Delphi and Lycoming. This "new technology" solves premature wear and corrosion only ? They also enable alternate cam profiles ? (Not likely for this first timer.) Is it worth it ? If the subject's been beaten to death already I'd happily take a link to some reference ... __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Subject: Gusset questions
Date: Aug 17, 2005
I have a couple of questions on gussets and Van's has been relatively curt and unhelpful on one of them. The first one involves the gusset on the seatbacks to the main longeron. Here's my situation. Following Van's instructions, I have riveted onlyt he "keeper" rivets in the longeron and no others. I have fitted, modified and prepped the gusset (I think it's 656). There's that big honkin' piece of angle I prepped months ago but did not drill to the 705 bulkhead,,,these are the four prepunched holes in the bulkhead and in the gusset itself. But after fitting the three. I drilled these four holes. So the longeron rivets on the skin have not been shot. And I notice that the large piece of angle -- the 705G -- is slightly blocking the side skin to longeron holes. Being mindful of the warnings not to rivet the side skin to the longeron except for the "keeper" rivet holes provided, I am thus faced with riveting the gussets/705g and 705 bulkhead now...leaving me with a real problem when I go to shoot those side skin-to-longeron rivets are going to be blocked by the angle when I got to shoot them. So it seems that the only logical solution is to shoot those side skin-to-longeron rivets now....THEN rivet the 705G-bulkhead-and gusset together and screw the instructions about the longeron rivets. That's what I asked Van's. But they (well, Ken) sent me back this detailed e-mail, "or rivet in 705g after skins are on as suggested in note 5." Nice. Not only didn't I get an answer to the question I asked. I also got a little "shot" for no extra charge. The point was, I know all about Note 5. I read Note 5. I DID wait to rivet the 705G until the skins are already on. THE SKINS _are_ ALREADY ON!! (Sorry). That's why I wrote you, Van's. The skins are, you told me not to rivet the longerons, yo told me TO rivet the gusset. If I rivet the gusset, my path to those longeron rivets is going to be blocked by the 705G. It seemed like a simple question. Van's punted. What do you folks say? -0- On the next gusset. The 695-- that connects the longeron to the firewall, everything has fit perfectly and I've drilled it. Everything's great. But I'm concerned that the rivet holes are too close to the web of the engine mount reinforcement bracket... 7/32" as near as I can tell. Pretty tight. Wondering if anyone has had similar measurements and whether you had any problems setting those rivets? I love Van's. I love this kit. I'm having a great time. But I wouldn't mind seeing a full-time tech support guy to replace 5 guys who obviously have other stuff to do. Bob St. Paul ________________________________________________________________________________
From: "Brian Meyette" <brianpublic(at)starband.net>
Date: Aug 17, 2005
Ken isn't Van's most gushingly friendly employee - he can be rather curt & sometimes unhelpful brian -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Bob Collins Subject: RV7-List: Gusset questions I have a couple of questions on gussets and Van's has been relatively curt and unhelpful on one of them. The first one involves the gusset on the seatbacks to the main longeron. Here's my situation. Following Van's instructions, I have riveted onlyt he "keeper" rivets in the longeron and no others. I have fitted, modified and prepped the gusset (I think it's 656). There's that big honkin' piece of angle I prepped months ago but did not drill to the 705 bulkhead,,,these are the four prepunched holes in the bulkhead and in the gusset itself. But after fitting the three. I drilled these four holes. So the longeron rivets on the skin have not been shot. And I notice that the large piece of angle -- the 705G -- is slightly blocking the side skin to longeron holes. Being mindful of the warnings not to rivet the side skin to the longeron except for the "keeper" rivet holes provided, I am thus faced with riveting the gussets/705g and 705 bulkhead now...leaving me with a real problem when I go to shoot those side skin-to-longeron rivets are going to be blocked by the angle when I got to shoot them. So it seems that the only logical solution is to shoot those side skin-to-longeron rivets now....THEN rivet the 705G-bulkhead-and gusset together and screw the instructions about the longeron rivets. That's what I asked Van's. But they (well, Ken) sent me back this detailed e-mail, "or rivet in 705g after skins are on as suggested in note 5." Nice. Not only didn't I get an answer to the question I asked. I also got a little "shot" for no extra charge. The point was, I know all about Note 5. I read Note 5. I DID wait to rivet the 705G until the skins are already on. THE SKINS _are_ ALREADY ON!! (Sorry). That's why I wrote you, Van's. The skins are, you told me not to rivet the longerons, yo told me TO rivet the gusset. If I rivet the gusset, my path to those longeron rivets is going to be blocked by the 705G. It seemed like a simple question. Van's punted. What do you folks say? -0- On the next gusset. The 695-- that connects the longeron to the firewall, everything has fit perfectly and I've drilled it. Everything's great. But I'm concerned that the rivet holes are too close to the web of the engine mount reinforcement bracket... 7/32" as near as I can tell. Pretty tight. Wondering if anyone has had similar measurements and whether you had any problems setting those rivets? I love Van's. I love this kit. I'm having a great time. But I wouldn't mind seeing a full-time tech support guy to replace 5 guys who obviously have other stuff to do. Bob St. Paul -- -- ________________________________________________________________________________
Subject: Re: Gusset questions
Date: Aug 17, 2005
Bob, I am a month or so behind you and hope to learn from your posting. Paul ----- Original Message ----- From: Bob Collins To: rv7-list(at)matronics.com Sent: Wednesday, August 17, 2005 5:40 PM Subject: RV7-List: Gusset questions I have a couple of questions on gussets and Van's has been relatively curt and unhelpful on one of them. The first one involves the gusset on the seatbacks to the main longeron. Here's my situation. Following Van's instructions, I have riveted onlyt he "keeper" rivets in the longeron and no others. I have fitted, modified and prepped the gusset (I think it's 656). There's that big honkin' piece of angle I prepped months ago but did not drill to the 705 bulkhead,,,these are the four prepunched holes in the bulkhead and in the gusset itself. But after fitting the three. I drilled these four holes. So the longeron rivets on the skin have not been shot. And I notice that the large piece of angle -- the 705G -- is slightly blocking the side skin to longeron holes. Being mindful of the warnings not to rivet the side skin to the longeron except for the "keeper" rivet holes provided, I am thus faced with riveting the gussets/705g and 705 bulkhead now...leaving me with a real problem when I go to shoot those side skin-to-longeron rivets are going to be blocked by the angle when I got to shoot them. So it seems that the only logical solution is to shoot those side skin-to-longeron rivets now....THEN rivet the 705G-bulkhead-and gusset together and screw the instructions about the longeron rivets. That's what I asked Van's. But they (well, Ken) sent me back this detailed e-mail, "or rivet in 705g after skins are on as suggested in note 5." Nice. Not only didn't I get an answer to the question I asked. I also got a little "shot" for no extra charge. The point was, I know all about Note 5. I read Note 5. I DID wait to rivet the 705G until the skins are already on. THE SKINS _are_ ALREADY ON!! (Sorry). That's why I wrote you, Van's. The skins are, you told me not to rivet the longerons, yo told me TO rivet the gusset. If I rivet the gusset, my path to those longeron rivets is going to be blocked by the 705G. It seemed like a simple question. Van's punted. What do you folks say? -0- On the next gusset. The 695-- that connects the longeron to the firewall, everything has fit perfectly and I've drilled it. Everything's great. But I'm concerned that the rivet holes are too close to the web of the engine mount reinforcement bracket... 7/32" as near as I can tell. Pretty tight. Wondering if anyone has had similar measurements and whether you had any problems setting those rivets? I love Van's. I love this kit. I'm having a great time. But I wouldn't mind seeing a full-time tech support guy to replace 5 guys who obviously have other stuff to do. Bob St. Paul ________________________________________________________________________________
Date: Aug 18, 2005
Subject: Stringer
I am building and RV-7. A friend of mine has a beautiful flying RV-8 and suggested to me that I should run an additional center stringer down the center of the aft fuselage from the back of the baggage compartment to the last bulkhead to help prevent oil caning of the skins. The distance on the 7 between bulkheads is rather short and it doesn't appear that oil canning would be an issue, I think the 8 has a slightly longer fuselage. Has any one else considered doing this? Bill Cormier Sturbridge MA ________________________________________________________________________________
Date: Aug 18, 2005
Hi Paul: I suspect that -- given my tendency to poke along -- you're about two months away from being one month ahead of ME. (g) So...likewise. (g) Regards, Bob -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Merems Subject: Re: RV7-List: Gusset questions Bob, I am a month or so behind you and hope to learn from your posting. Paul ----- Original Message ----- From: Bob Collins To: rv7-list(at)matronics.com Sent: Wednesday, August 17, 2005 5:40 PM Subject: RV7-List: Gusset questions ________________________________________________________________________________
Subject: Re: Stringer
Date: Aug 18, 2005
Bill I had an obvious oil can in the bay just aft of the baggage area. I bridged the can with a piece of J stringer between the two bulkheads. I saw no need to extend the extra stringer any further aft. Dean Van Winkle RV-9A Fuselage/Finish ----- Original Message ----- From: "flutewitch" <flutewitch(at)cox.net> Subject: RV7-List: Stringer > > I am building and RV-7. A friend of mine has a beautiful flying RV-8 and > suggested to me that I should run an additional center stringer down the > center of the aft fuselage from the back of the baggage compartment to the > last bulkhead to help prevent oil caning of the skins. The distance on the > 7 > between bulkheads is rather short and it doesn't appear that oil canning > would be an issue, I think the 8 has a slightly longer fuselage. Has any > one > else considered doing this? > > Bill Cormier > Sturbridge MA > > > ________________________________________________________________________________
Date: Aug 18, 2005
Subject: Re: RV7-List Digest: 3 Msgs - 08/17/05
I enjoy reading these messages as I'm building an -6 and I'm getting close to the "gusset" area my self. A friend of mine is building a -7 so I get to see his drawings and because their much more clear than the -6 drawings it helps to move things along. My point is, unless I'm wrong, my drawings put the gussets, f-656, at the f606 an f607 bulkhead this should be f706 and f707 for the -7 ( see drawing # 26 of the -7 package ) . I hope I'm right, I'd hate to plug the extra holes in this thing. Patrick in Calgary --- RV7-List Digest Server wrote: > * > > ================================================== > Online Versions of Today's List Digest Archive > ================================================== > > Today's complete RV7-List Digest can also be found > in either of the > two Web Links listed below. The .html file includes > the Digest formatted > in HTML for viewing with a web browser and features > Hyperlinked Indexes > and Message Navigation. The .txt file includes the > plain ASCII version > of the RV7-List Digest and can be viewed with a > generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/rv7-list/Digest.RV7-List.2005-08-17.html > > Text Version: > > > http://www.matronics.com/digest/rv7-list/Digest.RV7-List.2005-08-17.txt > > > ================================================ > EMail Version of Today's List Digest Archive > ================================================ > > > > > RV7-List Digest Archive > --- > Total Messages Posted Wed > 08/17/05: 3 > > > > > Today's Message Index: > ---------------------- > > 1. 05:40 PM - Gusset questions (Bob Collins) > 2. 06:50 PM - Re: Gusset questions (Brian > Meyette) > 3. 08:54 PM - Re: Gusset questions (Merems) > > > > ________________________________ Message 1 > _____________________________________ > > > From: "Bob Collins" <bcollinsrv7a(at)comcast.net> > Subject: RV7-List: Gusset questions > > > > > I have a couple of questions on gussets and Van's > has been relatively curt > and unhelpful on one of them. > > The first one involves the gusset on the seatbacks > to the main longeron. > Here's my situation. Following Van's instructions, I > have riveted onlyt he > "keeper" rivets in the longeron and no others. I > have fitted, modified and > prepped the gusset (I think it's 656). There's that > big honkin' piece of > angle I prepped months ago but did not drill to the > 705 bulkhead,,,these are > the four prepunched holes in the bulkhead and in the > gusset itself. But > after fitting the three. I drilled these four holes. > > So the longeron rivets on the skin have not been > shot. And I notice that > the large piece of angle -- the 705G -- is slightly > blocking the side skin > to longeron holes. Being mindful of the warnings not > to rivet the side skin > to the longeron except for the "keeper" rivet holes > provided, I am thus > faced with riveting the gussets/705g and 705 > bulkhead now...leaving me with > a real problem when I go to shoot those side > skin-to-longeron rivets are > going to be blocked by the angle when I got to shoot > them. > > So it seems that the only logical solution is to > shoot those side > skin-to-longeron rivets now....THEN rivet the > 705G-bulkhead-and gusset > together and screw the instructions about the > longeron rivets. > > That's what I asked Van's. But they (well, Ken) sent > me back this detailed > e-mail, "or rivet in 705g after skins are on as > suggested in note 5." > > Nice. Not only didn't I get an answer to the > question I asked. I also got a > little "shot" for no extra charge. The point was, I > know all about Note 5. > I read Note 5. I DID wait to rivet the 705G until > the skins are already on. > THE SKINS _are_ ALREADY ON!! (Sorry). That's why I > wrote you, Van's. The > skins are, you told me not to rivet the longerons, > yo told me TO rivet the > gusset. If I rivet the gusset, my path to those > longeron rivets is going to > be blocked by the 705G. > > It seemed like a simple question. Van's punted. What > do you folks say? > > -0- > > On the next gusset. The 695-- that connects the > longeron to the firewall, > everything has fit perfectly and I've drilled it. > Everything's great. But > I'm concerned that the rivet holes are too close to > the web of the engine > mount reinforcement bracket... 7/32" as near as I > can tell. Pretty tight. > Wondering if anyone has had similar measurements and > whether you had any > problems setting those rivets? > > I love Van's. I love this kit. I'm having a great > time. But I wouldn't mind > seeing a full-time tech support guy to replace 5 > guys who obviously have > other stuff to do. > > Bob > St. Paul > > > > > > > ________________________________ Message 2 > _____________________________________ > > > From: "Brian Meyette" <brianpublic(at)starband.net> > Subject: RE: RV7-List: Gusset questions > > > > Ken isn't Van's most gushingly friendly employee - > he can be rather curt & > sometimes unhelpful > brian > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com]On > Behalf Of Bob Collins > Subject: RV7-List: Gusset questions > > > > > I have a couple of questions on gussets and Van's > has been relatively curt > and unhelpful on one of them. > > The first one involves the gusset on the seatbacks > to the main longeron. > Here's my situation. Following Van's instructions, I > have riveted onlyt he > "keeper" rivets in the longeron and no others. I > have fitted, modified and > prepped the gusset (I think it's 656). There's that > big honkin' piece of > angle I prepped months ago but did not drill to the > 705 bulkhead,,,these are > the four prepunched holes in the bulkhead and in the > gusset itself. But > after fitting the three. I drilled these four holes. > > So the longeron rivets on the skin have not been > shot. === message truncated === ________________________________________________________________________________
Date: Aug 18, 2005
Yeah, in fact something I'm going to do at my semi-annual in a month or two (mid-year inspection) is to put stiffeners on ALL tailcone skins below the stringers. Lower side panels and belly panels. They don't oil can, but they pucker a little. There's one which pushes in when I fly, and as just as I'm slowing down to land you can hear it "pong" back out. Wish I had put stiffeners back there when I built it. I'm just going to proseal some lightweight .025 angle back there, either diagonally or straight across each large quadrant of skin. )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: "flutewitch" <flutewitch(at)cox.net> Subject: RV7-List: Stringer > > I am building and RV-7. A friend of mine has a beautiful flying RV-8 and > suggested to me that I should run an additional center stringer down the > center of the aft fuselage from the back of the baggage compartment to the > last bulkhead to help prevent oil caning of the skins. The distance on the > 7 > between bulkheads is rather short and it doesn't appear that oil canning > would be an issue, I think the 8 has a slightly longer fuselage. Has any > one > else considered doing this? > > Bill Cormier > Sturbridge MA > > > ________________________________________________________________________________
Date: Aug 18, 2005
Not an issue. I think Van has this figured out. Tad S RV7A painting ________________________________________________________________________________
Subject: Re: More gusset questions
Date: Aug 18, 2005
> My 2 cents is...follow the order as laid out in the construction manual. That's my point. It's impossible to follow the order laid out in the construction manual/plans. 1. The plans say don't rivet the side skins to the longeron. 2. The plans say rivet the gusset to the 705G/705 bulkhead. 3. The 705G interferes with the side-skins-to-longeron rivets in those 2 (and possibly 3) holes. It seems to me the only way to do this would be to rivet the side skins to longerons in those locations now, THEN rivet the 705 bulkhead, 705G and gusset. Either way, I'm going to have to ignore someting in the manual/plans. What I was asking Van's was which one should it be? I ended up being Ken Scott's straight man instead. > > But I don't know about this half bucktail thing. Ah, then if you want to know how to make a half-bucktail, you've come to the master, Grasshopper. >If you centered the > skin-to-longeron holes on the longeron, I don't see the issue with bucking > the skin rivets. Are your skin-to-longeron holes up high, near the vertex > of the longeron, or something? A portion of the top of the 705G web -- I THINK -- fits inside the longeron. This is not entirely dissimillar to those brackets on the firewall where you put the blind rivet. > If you'll have an issue bucking rivets due to other rivet heads. It It' s not the rivet heads, it's the 705 G. > Maybe if you have some photos handy I can make a more educated guess as to > what advice you want to hear! I'll have to take some tonight. I must be doing SOMETHING wrong because apparently nobody else has ever run into this. My 2 cents is...follow the order as laid out in the construction manual. That's my point. It's impossible to follow the order laid out in the construction manual/plans. 1. The plans say don't rivet the side skins to the longeron. 2. The plans say rivet the gusset to the 705G/705 bulkhead. 3. The 705G interferes with the side-skins-to-longeron rivets in those 2 (and possibly 3) holes. It seems to me the only way to do this would be to rivet the side skins to longerons in those locations now, THEN rivet the 705 bulkhead, 705G and gusset. Either way, I'm going to have to ignore someting in the manual/plans. What I was asking Van's was which one should it be? I ended up being Ken Scott's straight man instead. But I don't know about this half bucktail thing. Ah, then if you want to know how to make a half-bucktail, you've come to the master, Grasshopper. If you centered the skin-to-longeron holes on the longeron, I don't see the issue with bucking the skin rivets. Are your skin-to-longeron holes up high, near the vertex of the longeron, or something? A portion of the top of the 705G web-- I THINK -- fits inside the longeron. This is not entirely dissimillar to those brackets on the firewall where you put the blind rivet. If you'll have an issue bucking rivets due to other rivet heads. It It' s not the rivet heads, it's the 705 G. Maybe if you have some photos handy I can make a more educated guess as to what advice you want to hear! I'll have to take some tonight. I must be doing SOMETHING wrong because apparently nobody else has ever run into this. ________________________________________________________________________________
Date: Aug 18, 2005
> That's my point. It's impossible to follow the order laid out in the > construction manual/plans. > > 1. The plans say don't rivet the side skins to the longeron. > 2. The plans say rivet the gusset to the 705G/705 bulkhead. > 3. The 705G interferes with the side-skins-to-longeron rivets in those 2 > (and possibly 3) holes. > > It seems to me the only way to do this would be to rivet the side skins to > longerons in those locations now, THEN rivet the 705 bulkhead, 705G and > gusset. Ah. F-705. For some reason I thought you were talking about the gussets up at the firewall. I must be confusing this thread with another thread you posted very recently. Yeah, it's almost impossible to buck those side skin rivets. Just use pop rivets on the side skin. Or wait to rivet the gussets in, but that might cause a cascade of other chicken-and-egg issues. )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Aug 18, 2005
> > Ah. F-705. For some reason I thought you were talking about the gussets up > at the firewall. I must be confusing this thread with another thread you > posted very recently. Well, actually that was the other part of the question. But I looked again last night (OK, I admit it, I often stroll out to the garage late at night just to ...you know...be with the plane) and realized those aren't going to be a big deal. Thanks for the assist. That's more than I got from Bend. Ah. F-705. For some reason I thought you were talking about the gussets up at the firewall. I must be confusing this thread with another thread you posted very recently. Well, actually that was the other part of the question. But I looked again last night (OK, I admit it, I often stroll out to the garage late at night just to ...you know...be with the plane) and realized those aren't going to be a big deal. Thanks for the assist. That's more than I got from Bend. ________________________________________________________________________________
Date: Aug 19, 2005
//I'm working on this right now and all my bucktails are easily accessible w/ a bucking bar. Something must be off. How about a picture, Bob? - Jamie, RV-7A Fuselage I think I've done everything correctly. The picture is here. The .125 of the 705G DOES interfere with getting good access at those two skin-to-longeron rivets. It would think the opportunity to slice a bucktail or beat up the angle pretty good is quite prevalent here. http://home.comcast.net/~bcollinsrv7a/eaa/rv.html ________________________________________________________________________________
Date: Aug 19, 2005
> I think I've done everything correctly. The picture is here. The .125 of > the 705G DOES interfere with getting good access at those two > skin-to-longeron rivets. It would think the opportunity to slice a > bucktail > or beat up the angle pretty good is quite prevalent here. > > http://home.comcast.net/~bcollinsrv7a/eaa/rv.html Bob, We all go through this. Two things you need to do... 1) Gouge out a big of the gusset where the rivets will go. 2) Use pop rivets (skin to longeron) in that area. The reason for gouging out the gusset is to provide enough depth for the pop rivet to insert before it gets pulled. Trust me, this is the fastest method. Pop a little filler in the pop rivet, nobody will ever be the wiser. Moving right along... )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Aug 19, 2005
I think all who have been there and done it remember now what you are talking about. You can only do the best you can do. I think I took a small piece of spring steel and ground it down on half its side and slipped it in there to do the bucking chore. It turned out about half right and I moved on. Happy to report, my plane has flown for 57 hours without that incision tearing loose. Indiana Larry, RV7 Tip Up It Flies Teamwork: " A lot of people doing exactly what I say." (Marketing exec., Citrix Corp.) ----- Original Message ----- From: "Bob Collins" <bcollinsrv7a(at)comcast.net> Subject: RV7-List: Re: More gusset questions > > //I'm working on this right now and all my bucktails are easily > accessible w/ a bucking bar. Something must be off. How about a > picture, Bob? > > - Jamie, RV-7A Fuselage > > I think I've done everything correctly. The picture is here. The .125 of > the 705G DOES interfere with getting good access at those two > skin-to-longeron rivets. It would think the opportunity to slice a > bucktail > or beat up the angle pretty good is quite prevalent here. > > http://home.comcast.net/~bcollinsrv7a/eaa/rv.html > > > ________________________________________________________________________________
Subject: Nosewheel collapse another view
Date: Aug 19, 2005
Gents, I too am building an RV-7A and have been following the discussions about the recent nosewheel collapse. I am concerned about this situation as many of you are. I have talked with Ken Krueger (Van's engineering), who I have a tremendous respect for, about some of these recent accidents. I am certain Van's Aircraft takes this situation very seriously. However if you step back and ask yourself are there a few RV'As out there that have had the highest number of landings to date, where would you find them? What kind of landing have they seen? Grass or paved runways? My best guess is these are the RV-7A and RV-9A prototypes at Van's Aircraft. Who flies these? Van's staff. Where have they landed? Grass or pavement? Both. Have they taxied on grass? Yes. Have they botched a few landing? I would think so. Now I would bet these two aircraft have 10 times or more the numbers of landing then any another RV's out there and their nose gears haven't collapsed. I am not saying there isn't a issue, I am just giving you another view to understand possibly why Van's Aircraft appears to have "no comment" when it comes to this issue. In all the postings about this issue, no one has mentioned the possibility of improper heat treating of the gear leg. If I recall this was an issue sometime ago with some main gear legs on RV's. This might be the root cause. This can be easily determined by sending the nose gear leg off to any qualified machine shop who can perform a hardness test on the leg. This will help determine if the gear was heat treated properly. Food for thought. Paul ________________________________________________________________________________
Date: Aug 19, 2005
I've wondered whether powder coating affects the heat treating since it involves considerable heat. Anyone KNOW the answer. Bevan -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Merems Subject: RV7-List: Nosewheel collapse another view Gents, I too am building an RV-7A and have been following the discussions about the recent nosewheel collapse. I am concerned about this situation as many of you are. I have talked with Ken Krueger (Van's engineering), who I have a tremendous respect for, about some of these recent accidents. I am certain Van's Aircraft takes this situation very seriously. However if you step back and ask yourself are there a few RV'As out there that have had the highest number of landings to date, where would you find them? What kind of landing have they seen? Grass or paved runways? My best guess is these are the RV-7A and RV-9A prototypes at Van's Aircraft. Who flies these? Van's staff. Where have they landed? Grass or pavement? Both. Have they taxied on grass? Yes. Have they botched a few landing? I would think so. Now I would bet these two aircraft have 10 times or more the numbers of landing then any another RV's out there and their nose gears haven't collapsed. I am not saying there isn't a issue, I am just giving you another view to understand possibly why Van's Aircraft appears to have "no comment" when it comes to this issue. In all the postings about this issue, no one has mentioned the possibility of improper heat treating of the gear leg. If I recall this was an issue sometime ago with some main gear legs on RV's. This might be the root cause. This can be easily determined by sending the nose gear leg off to any qualified machine shop who can perform a hardness test on the leg. This will help determine if the gear was heat treated properly. Food for thought. Paul ________________________________________________________________________________
Date: Aug 19, 2005
Maybe I've been asleep, but I haven't seen a discussion of nosewheel collapses on either the RV or the RV-7 lists. Can someone please point me at this discussion? Rick RV-7(A?) -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of B Tomm Subject: RE: RV7-List: Nosewheel collapse another view I've wondered whether powder coating affects the heat treating since it involves considerable heat. Anyone KNOW the answer. Bevan -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Merems Subject: RV7-List: Nosewheel collapse another view Gents, I too am building an RV-7A and have been following the discussions about the recent nosewheel collapse. I am concerned about this situation as many of you are. I have talked with Ken Krueger (Van's engineering), who I have a tremendous respect for, about some of these recent accidents. I am certain Van's Aircraft takes this situation very seriously. However if you step back and ask yourself are there a few RV'As out there that have had the highest number of landings to date, where would you find them? What kind of landing have they seen? Grass or paved runways? My best guess is these are the RV-7A and RV-9A prototypes at Van's Aircraft. Who flies these? Van's staff. Where have they landed? Grass or pavement? Both. Have they taxied on grass? Yes. Have they botched a few landing? I would think so. Now I would bet these two aircraft have 10 times or more the numbers of landing then any another RV's out there and their nose gears haven't collapsed. I am not saying there isn't a issue, I am just giving you another view to understand possibly why Van's Aircraft appears to have "no comment" when it comes to this issue. In all the postings about this issue, no one has mentioned the possibility of improper heat treating of the gear leg. If I recall this was an issue sometime ago with some main gear legs on RV's. This might be the root cause. This can be easily determined by sending the nose gear leg off to any qualified machine shop who can perform a hardness test on the leg. This will help determine if the gear was heat treated properly. Food for thought. Paul ________________________________________________________________________________
Date: Aug 20, 2005
From: Darrell Reiley <lifeofreiley2003(at)yahoo.com>
First quarter of 2005 on the RV7 yahoo group, just before the bulletin was issued... Maybe I've been asleep, but I haven't seen a discussion of nosewheel collapses on either the RV or the RV-7 lists. Can someone please point me at this discussion? Rick RV-7(A?) -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of B Tomm Subject: RE: RV7-List: Nosewheel collapse another view I've wondered whether powder coating affects the heat treating since it involves considerable heat. Anyone KNOW the answer. Bevan -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Merems Subject: RV7-List: Nosewheel collapse another view Gents, I too am building an RV-7A and have been following the discussions about the recent nosewheel collapse. I am concerned about this situation as many of you are. I have talked with Ken Krueger (Van's engineering), who I have a tremendous respect for, about some of these recent accidents. I am certain Van's Aircraft takes this situation very seriously. However if you step back and ask yourself are there a few RV'As out there that have had the highest number of landings to date, where would you find them? What kind of landing have they seen? Grass or paved runways? My best guess is these are the RV-7A and RV-9A prototypes at Van's Aircraft. Who flies these? Van's staff. Where have they landed? Grass or pavement? Both. Have they taxied on grass? Yes. Have they botched a few landing? I would think so. Now I would bet these two aircraft have 10 times or more the numbers of landing then any another RV's out there and their nose gears haven't collapsed. I am not saying there isn't a issue, I am just giving you another view to understand possibly why Van's Aircraft appears to have "no comment" when it comes to this issue. In all the postings about this issue, no one has mentioned the possibility of improper heat treating of the gear leg. If I recall this was an issue sometime ago with some main gear legs on RV's. This might be the root cause. This can be easily determined by sending the nose gear leg off to any qualified machine shop who can perform a hardness test on the leg. This will help determine if the gear was heat treated properly. Food for thought. Paul Darrell Reiley Round Rock, Texas RV 7A "Reiley Rocket" N622DR (reserved) --------------------------------- ________________________________________________________________________________
Subject: Re: Nosewheel collapse another view
Date: May 20, 2005
www.vansairforce.net http://www.vansairforce.com/community/showthread.php?t=2846&highlight=nosewheel ----- Original Message ----- From: "Darrell Reiley" <lifeofreiley2003(at)yahoo.com> Subject: RE: RV7-List: Nosewheel collapse another view > > > First quarter of 2005 on the RV7 yahoo group, just before the bulletin was > issued... > > "Richard McCraw" > > Maybe I've been asleep, but I haven't seen a discussion of nosewheel > collapses on either the RV or the RV-7 lists. Can someone please point me > at this discussion? > > Rick > RV-7(A?) > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of B Tomm > To: rv7-list(at)matronics.com > Subject: RE: RV7-List: Nosewheel collapse another view > > > I've wondered whether powder coating affects the heat treating since it > involves considerable heat. Anyone KNOW the answer. > > Bevan > > -----Original Message----- > From: owner-rv7-list-server(at)matronics.com > [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Merems > To: RV7and7A(at)yahoogroups.com; rv9-list(at)matronics.com > Subject: RV7-List: Nosewheel collapse another view > > > Gents, > > I too am building an RV-7A and have been following the discussions about > the > recent nosewheel collapse. I am concerned about this situation as many of > you are. > > I have talked with Ken Krueger (Van's engineering), who I have a > tremendous > respect for, about some of these recent accidents. I am certain Van's > Aircraft takes this situation very seriously. However if you step back and > ask yourself are there a few RV'As out there that have had the highest > number of landings to date, where would you find them? What kind of > landing > have they seen? Grass or paved runways? My best guess is these are the > RV-7A and RV-9A prototypes at Van's Aircraft. Who flies these? Van's > staff. Where have they landed? Grass or pavement? Both. Have they taxied > on grass? Yes. Have they botched a few landing? I would think so. Now I > would bet these two aircraft have 10 times or more the numbers of landing > then any another RV's out there and their nose gears haven't collapsed. > > I am not saying there isn't a issue, I am just giving you another view to > understand possibly why Van's Aircraft appears to have "no comment" when > it > comes to this issue. > > In all the postings about this issue, no one has mentioned the possibility > of improper heat treating of the gear leg. If I recall this was an issue > sometime ago with some main gear legs on RV's. This might be the root > cause. This can be easily determined by sending the nose gear leg off to > any qualified machine shop who can perform a hardness test on the leg. > This > will help determine if the gear was heat treated properly. > > Food for thought. > > Paul > > > Darrell Reiley > Round Rock, Texas > > RV 7A "Reiley Rocket" > N622DR (reserved) > > --------------------------------- > > > ________________________________________________________________________________
Date: Aug 20, 2005
Subject: More data - Nosewheel collapse another view
Ok folks, more time to spare - too hot to work in the hangar. Besides, I have just finished working off the FAA squawks on my -9A, made the cowl much easier to remove and install, and will call the FAA Monday to hopefully get an airworthiness certificate. What we have been missing in this discussion is the exposure to accidents, that is, how may RV taildraggers are there, how many A models, how long has each model been in service? For example, IF most of the 7s and 9s are A models, then anything that ends up inverted is going to be an A model. Here are the numbers I found. The data below with "Airplanes" in service, and those "inverted", flipped, or nosed over. I took out the fatal because you can crash inverted, which is not the issue here. For -6, 672 airplanes and 34 inverted, flipped, or nosed over -6A, 642 airplanes and 33 inverted About even for both For -7, 57 airplanes and 0 inverted -7A, 98 airplanes and 3 inverted not a significant difference, one or two either way can even it up For -8, 298 airplanes and 7 inverted -8A, 84 airplanes and 5 inverted may show some significance, not much though, again, one or two out of the -8A and numbers would even up For -9, 15 airplanes and 0 inverted -9A, 107 airplanes and 3 inverted the first -9 that goes inverted, and we can wait for 7 more -9As to even the score, just kidding. Also, the 6 and 6A have been around much longer so with 33 hits each, on average 3 "inverted" a year (for 10 years, just a WAG by me, suggest a better number of years if you will). To me, it does not seem that 7, 8 and 9As are on pace to match the 6As. Too bad we can't get the number of hours flown, or number of flights, etc. Also, I have no idea if the 6A gear is significantly different that the 7, 8 or 9A. Right now, I don't see a significant difference between the models. Of course, the situation may become much clearer as the number of RVs come into service and the years add up. Clearly, ditches and soft ground are a menace to the A models,as they are for many of the certified airplanes. Also, engine problems, fuel starvation, fuel exhaustion, etc are a significant factor that can be better controlled. This was a very quick look, so there may be some glaring mistakes. Also, there are some double counts in some cases where, for example, "flip" and "inverted" both are in a file. Let me know if there are other ways to parse out the numbers. Also, I would encourage you to go to the NTSB web site and use the query system, read some of the reports (www.ntsb.gov, select AVIATION at the top, select ACCIDENT DATA BASE at the top, select QUERY at the top) . The FAA data base has the registration data, that is, the number of RVs registered. With that said, practice the slow flight, spot landings, stick all the way back, at least for the A models. I should have stayed at the hangar and finished my flight test cards. Regards, John. ________________________________________________________________________________
Subject: Re: More data - Nosewheel collapse another view
Date: Aug 20, 2005
On Aug 20, 2005, at 6:47 PM, JohnCClarkVA(at)cs.com wrote: > Clearly, ditches and soft ground are a menace to the A models,as they > are for > many of the certified airplanes. Also, engine problems, fuel > starvation, > fuel exhaustion, etc are a significant factor that can be better > controlled. How true this is. MANY certified nosedraggers have gone over during off-field landings...it's one of the caveats of the design. The FBO that I currently rent from had a 150 go over a few years back when the woman flying it got lost and decided to put it down on a grass field to ask for directions (I kid you not). The nosewheel sank in the ground and up and over it went. That being said. the flip-overs on paved surfaces do require further examination and I believe it has been pretty well established that pilot error is the biggest cause. These airplanes are not trainers. They should not be landed on the nose gear. It's been demonstrated that these nose-draggers can land on almost any decent field, so that indicates to me that there's no fundamental problem in the design. There just isn't much room for inattention or carelessness in the design. All the best, Jamie D. Painter N622JP (reserved) Fuselage ________________________________________________________________________________
Date: Aug 21, 2005
//the woman flying it got lost and decided to put it down on a grass field to ask for directions (I kid you not). I often wonder why more people don't just drop down and look at the water towers when they get lost. ________________________________________________________________________________
Date: Aug 21, 2005
clamav-milter version 0.80j on hathor So what did he have to say about it? brian -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Merems Subject: RV7-List: Nosewheel collapse another view I have talked with Ken Krueger (Van's engineering), who I have a tremendous respect for, about some of these recent accidents. I am certain Van's Aircraft takes this situation very seriously Paul -- ________________________________________________________________________________
Date: Aug 21, 2005
I spoke with Ken Krueger a while back when there were discussions on the newsgroups about the new nosegear yoke. I was concerned about the latest RV-7A nose over after seeing some photos of the accident. He believed that the new fork design was not a significant change that have effected the outcome of the landing. The change was due to other reasons (I believe manufacturing issues). He had personal experienced bad landing in the RV-7/9A and had taxied many times on grass without incident. I was up at Oshkosh this year. There were hundreds of RV's, many of them A's. They were parked all over and many had to taxi their aircraft in the grass great distances. The grass was cut and smooth, but wasn't exactly flat. I understand that many had to fast taxi due to the large numbers of aircraft landing and parking. I personally saw production aircraft fast taxi on the grass and start to "porpoise", not a good sight. I talked with on of the RV-10 owners there (aircraft was painted light tan) who fast taxied and the rudder bottom hit the ground (must have been fully loaded). The rudder bottom was cracked and rear position/strobe was broken. The rudder wasn't bent. I didn't see or hear of any A's having any issue with there gear collapsing. Paul ----- Original Message ----- From: Brian Meyette To: rv7-list(at)matronics.com Sent: Sunday, August 21, 2005 6:02 AM Subject: RE: RV7-List: Nosewheel collapse another view So what did he have to say about it? brian -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com]On Behalf Of Merems To: RV7and7A(at)yahoogroups.com; rv9-list(at)matronics.com Subject: RV7-List: Nosewheel collapse another view I have talked with Ken Krueger (Van's engineering), who I have a tremendous respect for, about some of these recent accidents. I am certain Van's Aircraft takes this situation very seriously Paul -- ________________________________________________________________________________
Subject: Shimming required?
Date: Aug 21, 2005
Gents, Have any other builders needed to shim about 0.063" (1/16") between the F-724 (Aft Fuselage Bulkhead) bottom flange and the F-623 (Corner Rib). To refresh some of your memory this is the F-623 is bottom corner rib that extends to the side of the baggage bay to the side skins. This is the rib that get notched for the flap pushrod and also get trimmed for the step tube to clear. The F-724 is the vertical bulkhead in the baggage bay. It appears that without shimming the side skins will not line up properly with the bottom skin and corner rib flange. Attached is a image from the plan set. Any thoughts? Paul ________________________________________________________________________________
Date: Aug 21, 2005
Yea, BUT John & Jamie: Thanks for the data, but I think statistics and getting into a tail dragger vs. nosedragger comparison debate is not really useful at this point. I DON'T want to turn this into a defense mode of tail draggers Vs. tri-gear, which always turns into a heated debate. Lets just focus on the Tri-gear and the physics of what happens to the nose gear. I think the pros-cons of TRI vs TD has been beat to death. By saying SEE TAILDRAGGERS FLIP TO, does nothing to explain or explore possible improvements to the RV-A design. The fact that gears his gears have folded, by justifying it gets into a non-value added event at a certain point. Clearly pilot skill and poor tire clearance has been factors, but Why/How do taildraggers flip? No doubt it for totally different reasons than a nose dragger. In fact the Tri-gear should be more stable in some ways. To tie with taildragger accidents should not be a plus for the Tri-gear configuration or justification of its service history. If the nose gear was stiffer would the flip rate go to zero? Fact a RV-7A folded a nose gear during taxi. Fact, another folded the gear during take-off roll. In either of these two cases, they flip not flip, but they are not in your STATS. Regardless, flip or not, gears of any kind that bend during seemingly normal operations is not super acceptable. In the takeoff case, tire interference was thought to cause a jam or drag. That is a reasonable explanation and the solution is tire clearance and proper tire pressure. In many others is thought to be pilot error, which is also likely are reasonable. The 4kt taxi case? Did a combo of grass jamming, bump, soft ground and aircraft weight conspire to cause this folded gear? Is that acceptable. ( Sorry for the comparison but I feel confident in saying a tail dragger would not have been damaged gear (or nosed over) in the same 4kt taxi condition.) Of your data/stats, how many taildragger's flipped over during taxi or initial takeoff? When it comes to statistics, figures lie. I mean it is useful info and interesting but conclusions can not be made without detailed understanding and failure analysis of every case, beyond the plane ended up on its back. Loss of control during landing resulting in a ground loop can flip any plane, especially a TD. If this is the reason, it is pilot error. Bottom line it should be in pilot control and the structure should be robust enough to take abuse or extreme conditions. A Mooney is NOT a soft field plane. Taxi on dirt with a Mooney is asking for a bent prop. IN a RV billed as total performance we expect soft field capability. There does seem to be a correlation to soft surface and nose gear problems. Why do A-models flip and why do taildragger flip? I know the data you are using, and it is hard to compare apples and apples with the broad brush information available, with out detail analysis of each case, which is just not available unless you investigated and interviewed every case. However what you did is great, but what does it matter if you bend your plane. The idea is not become a statistic. I would like to see that A-model flip rate go to zero, not tie with a taildragger. I like tail draggers but the A-model should have better stats than the TD for landing (taxi) accidents. That is the whole idea of this easier more stable (directionally) configuration in theory. Historically when Cessna or Piper went from TD to Tri ground handling improved and landing accidents improved. You would expect the same from the RV-A model. Statistics is a great place to start but I think we are past that now. Lets get the Tri gear down to Zero gear issues or flips. Cheers George PS Van's Aircraft did check heat treat on some of the nose gear struts and they where good. RV7-List Digest Server wrote: 4. 03:48 PM - More data - Nosewheel collapse another view (JohnCClarkVA(at)cs.com) 5. 08:25 PM - Re: More data - Nosewheel collapse another view (Jamie Painter) ________________________________ Message 4 From: JohnCClarkVA(at)cs.com Subject: RV7-List: More data - Nosewheel collapse another view Ok folks, more time to spare - too hot to work in the hangar. Besides, I have just finished working off the FAA squawks on my -9A, made the cowl much easier to remove and install, and will call the FAA Monday to hopefully get an airworthiness certificate. What we have been missing in this discussion is the exposure to accidents, that is, how may RV taildraggers are there, how many A models, how long has each model been in service? For example, IF most of the 7s and 9s are A models, then anything that ends up inverted is going to be an A model. Here are the numbers I found. The data below with "Airplanes" in service, and those "inverted", flipped, or nosed over. I took out the fatal because you can crash inverted, which is not the issue here. For -6, 672 airplanes and 34 inverted, flipped, or nosed over -6A, 642 airplanes and 33 inverted About even for both For -7, 57 airplanes and 0 inverted -7A, 98 airplanes and 3 inverted not a significant difference, one or two either way can even it up For -8, 298 airplanes and 7 inverted -8A, 84 airplanes and 5 inverted may show some significance, not much though, again, one or two out of the -8A and numbers would even up For -9, 15 airplanes and 0 inverted -9A, 107 airplanes and 3 inverted the first -9 that goes inverted, and we can wait for 7 more -9As to even the score, just kidding. Also, the 6 and 6A have been around much longer so with 33 hits each, on average 3 "inverted" a year (for 10 years, just a WAG by me, suggest a better number of years if you will). To me, it does not seem that 7, 8 and 9As are on pace to match the 6As. Too bad we can't get the number of hours flown, or number of flights, etc. Also, I have no idea if the 6A gear is significantly different that the 7, 8 or 9A. Right now, I don't see a significant difference between the models. Of course, the situation may become much clearer as the number of RVs come into service and the years add up. Clearly, ditches and soft ground are a menace to the A models,as they are for many of the certified airplanes. Also, engine problems, fuel starvation, fuel exhaustion, etc are a significant factor that can be better controlled. This was a very quick look, so there may be some glaring mistakes. Also, there are some double counts in some cases where, for example, "flip" and "inverted" both are in a file. Let me know if there are other ways to parse out the numbers. Also, I would encourage you to go to the NTSB web site and use the query system, read some of the reports (www.ntsb.gov, select AVIATION at the top, select ACCIDENT DATA BASE at the top, select QUERY at the top) . The FAA data base has the registration data, that is, the number of RVs registered. With that said, practice the slow flight, spot landings, stick all the way back, at least for the A models. I should have stayed at the hangar and finished my flight test cards. Regards, John. ________________________________ Message 5 From: Jamie Painter Subject: Re: RV7-List: More data - Nosewheel collapse another view On Aug 20, 2005, at 6:47 PM, JohnCClarkVA(at)cs.com wrote: > Clearly, ditches and soft ground are a menace to the A models,as they > are for > many of the certified airplanes. Also, engine problems, fuel > starvation, > fuel exhaustion, etc are a significant factor that can be better > controlled. How true this is. MANY certified nosedraggers have gone over during off-field landings...it's one of the caveats of the design. The FBO that I currently rent from had a 150 go over a few years back when the woman flying it got lost and decided to put it down on a grass field to ask for directions (I kid you not). The nosewheel sank in the ground and up and over it went. That being said. the flip-overs on paved surfaces do require further examination and I believe it has been pretty well established that pilot error is the biggest cause. These airplanes are not trainers. They should not be landed on the nose gear. It's been demonstrated that these nose-draggers can land on almost any decent field, so that indicates to me that there's no fundamental problem in the design. There just isn't much room for inattention or carelessness in the design. All the best, Jamie D. Painter N622JP (reserved) Fuselage --------------------------------- ________________________________________________________________________________
Date: Aug 21, 2005
Just for the heck of it I converted John Clark's statistics to percentages, as follows:
June 15, 2005 - August 21, 2005
RV7-Archive.digest.vol-ai
