RV7-Archive.digest.vol-ap
August 08, 2007 - April 02, 2008
> Regards,
> Rafael
> From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-
> server(at)matronics.com] On Behalf Of J. Brunke
> Sent: Friday, August 03, 2007 11:04 PM
> To: rv7-list(at)matronics.com
> Subject: Re: RV7-List: Elevator trim rigging
> Dear Rafael,
> I had the same problem, till a more experienced builder told me to
> put a bend in the threaded rod.
> It will lift it just slightly and should give you a little more
> breathing room.
> Hope that works for you. Sorry I don't have a photo close by to
> send.
> John Brunke
> RV7 in progress
> ----- Original Message -----
> From: Rafael
> Sent: Friday, August 03, 2007 6:22 PM
> Subject: RV7-List: Elevator trim rigging
> Hi folks!
> I would appreciate some help. I=92m trying to rig up the electric
> trim and find that I need to trim away quite a bit of metal to
> eliminate interference for the full down trim.
> I followed Van=92s instructions regarding the positioning of the trim
> motor mount. As you can see from the pictures, though still within
> the opening footprint,
> the actuating rod turned out pretty close to the inboard edge. (I
> thought about centering the mounts at the time, but decided to
> trust the plans.)
> After installing the trim system, there is a slight miss-alignment,
> but nothing that would cause stress in the system. I made some
> marks on the max, min, and half-way travel of the actuating rod. I
> then adjusted the length for no trim at the half-way point.
> What worries me most is the amount of metal I have to file out to
> prevent the actuating rod from contacting the elevator under max
> down trim. As you can see, I=92ve already removed quite a bit of
> Aluminum. I hesitate to trim further without some reassurance.
> Van=92s builder=92s assistance is closed for the weekend, so I thought
> I would seek y=92alls=92 help (I recently moved to Aiken, SC, and I=92m
> learning the local grammar ;))
> Thanks and best regards,
> Rafael
> href="http://www.matronics.com/Navigator?RV7-List">http://
> href="http://forums.matronics.com">http://forums.matronics.com
From: | "Michael Crawford" <g4mech(at)sbcglobal.net> |
Subject: | Elevator trim rigging |
Yep, my RV-7 needs VERY little trim changes through the full speed range.
RV-7
250 Hours
_____
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Dave Cudney
Sent: Wednesday, August 08, 2007 10:49 PM
Rafael:
I just got back from a trip and saw your question about the trim travel. I
measured mine today and it is very close to your measurement. I have 20.3
up trim (down movement of the trim tab) and 24.8 down trim (up movement of
the trim tab) for a total of 45.3. As I recall from the last RV that I
flew you use very little of the trim tab to adjust for approach speed and
curse. I see no method of getting more travel without changing the trim
servo. Maybe someone else has a method to get more travel from the servo.
good luck
dave
RV 7A
Starting on the cowling
On Aug 4, 2007, at 7:54 AM, Rafael wrote:
Thanks again, John for your suggestion.
I bent the rod a few degrees and that worked very well. It not only gave me
good clearance, but I was also to correct for the slight miss-alignment.
I now have another question: I measure a trim control of 20.6 degrees up
trim max. and 23.2 degrees down trim max. Van's figures, on section 15:
Flight Controls, call for Maximum up/down of 25-35 degrees. That implies to
me that a minimum travel of 50 degrees is necessary. I'm getting 43.8
degrees, so there's no way to meet these numbers. It's all that the motor
actuator will give.
Any comments as to what's going on?
Thanks and regards,
Rafael
_____
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Rafael
Sent: Friday, August 03, 2007 10:58 PM
Subject: RE: RV7-List: Elevator trim rigging
Thanks!
That makes a lot of sense. It's definitely less traumatic than removing al
that aluminum.
I'll try it.
Rafael
_____
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of J. Brunke
Dear Rafael,
I had the same problem, till a more experienced builder told me to put a
It will lift it just slightly and should give you a little more breathing
room.
Hope that works for you. Sorry I don't have a photo close by to send.
John Brunke
RV7 in progress
Hi folks!
I would appreciate some help. I'm trying to rig up the electric trim and
find that I need to trim away quite a bit of metal to eliminate interference
I followed Van's instructions regarding the positioning of the trim motor
mount. As you can see from the pictures, though still within the opening
footprint,
the actuating rod turned out pretty close to the inboard edge. (I thought
about centering the mounts at the time, but decided to trust the plans.)
After installing the trim system, there is a slight miss-alignment, but
nothing that would cause stress in the system. I made some marks on the
max, min, and half-way travel of the actuating rod. I then adjusted the
What worries me most is the amount of metal I have to file out to prevent
the actuating rod from contacting the elevator under max down trim. As you
can see, I've already removed quite a bit of Aluminum. I hesitate to trim
Van's builder's assistance is closed for the weekend, so I thought I would
seek y'alls' help (I recently moved to Aiken, SC, and I'm learning the local
grammar ;))
Rafael
href="http://www.matronics.com/Navigator?RV7-List">http://www.matronics.com/
Navigator?RV7-List
- The RV7-List Email Forum - class="Apple-converted-space"> -->
<http://www.matronics.com/Navigator?RV7-List>
http://www.matronics.com/Navigator?RV7-List - NEW MATRONICS WEB
FORUMS - class="Apple-converted-space"> -->
<http://forums.matronics.com> http://forums.matronics.com
Thanks!
That's what it is and it looks like it will do fine.
Rafael
RV7A Just finishing the empennage.
_____
Sent: Thursday, August 09, 2007 1:49 AM
Rafael:
good luck
dave
RV 7A
actuator will give.
Thanks and regards,
Rafael
_____
Thanks!
that aluminum.
I'll try it.
Rafael
_____
Dear Rafael,
room.
John Brunke
RV7 in progress
Hi folks!
footprint,
grammar ;))
Rafael
Navigator?RV7-List
- NEW MATRONICS WEB FORUMS - class="Apple-converted-space">
--> <http://forums.matronics.com> http://forums.matronics.com
From: | "Paul Walter" <pdwalter(at)bigpond.net.au> |
I am considering a 180hp titan engine for my 7A. Can anyone on the list
expand on these thoughts or provide me with positive/negative input on
this range of engines.
Thank you
Paul Walter
I have a TMX IOF-360 from Mattituck with Titan cylinders. The rest of my en
gine is Superior Air Parts. I'm up to 115 hours now, and they've been fine.
My TBO is 2400hrs!
Mark.
From: pdwalter(at)bigpond.net.auTo: rv7-list(at)matronics.comSubject: RV7-List: T
itanDate: Fri, 10 Aug 2007 10:03:16 +1000
I am considering a 180hp titan engine for my 7A. Can anyone on the list exp
and on these thoughts or provide me with positive/negative input on this ra
nge of engines.
Thank you
Paul Walter
The guy to talk to is Robbie Attaway at www.attawayair.com. He's an RV6
builder and also a Titan engine builder. ou can see more on his site.
He's built several engines for people such as Mark Chamberlain and
Darwin Barrie (Phoenix area). I spoke with him a few months back after
his EAA presentation about the engines. I was on the fence until I spoke
with him about it. Now I'm just waiting (actually still building and
saving) for ECi to come out with a stroked IO-360! Yeah baby!
Carlos in AZ
RV-7A
N174PP reserved
> list expand on these thoughts or provide me with positive/negative
> input on this range of engines.
> Thank you
> Paul Walter
From: | "Tad Sargent" <tadsargent(at)bellsouth.net> |
Paul, I fly the ECI Titan component engine, assembled by Penn Yann Aero. In
a word, Flawless.
Tad Sargent 302 hours 7A 18 months
FFI Wingman
_____
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Paul Walter
Sent: Thursday, August 09, 2007 8:03 PM
Subject: RV7-List: Titan
expand on these thoughts or provide me with positive/negative input on this
range of engines.
Thank you
Paul Walter
Subject: | ECI Titan engines |
Hello Mark,
I purchased the ECI Titan kit (188 HP at 2700 RPMs)...basic O-360-B1A
(hollow crank). The short of it... I have not started the engine as of yet
but am happy with the build. I asked John Sjaardema (Excel Air in
Rensselaer, IN at the airport), www.excelairservices.com) my builder to take
on the engine build...customer assisted (a plug for John). I basically
built the engine myself with help from John and his certified A&Ps (work
space, knowledge, parts, tools, etc.). Spent about 2 weeks part time
building the engine and everything looked good...the entire kit was within
specs (a few exceptions), and John is very particular about clearances and
so forth. I probably spent 2 days with the micrometers.
Exceptions: there were 3 tapped holes in the case that were not all of the
way thru and would not accept a full-length bolt; but we modified the bolts
and were acceptable to John. Also, 3 exhaust valve rocker arms were not
within the dry-tappet specs in the Lycoming manuals (John's specs...minimum
0.030 clearance) but ECI made the fixes at their facility--ECI sent them
back, I installed them and were perfect (0.035). John and I were happy with
the build. John also painted the engine. I also replaced the cork gaskets
with a better quality gasket for the valve covers--the cork material tends
to leak. I also replaced the adjustable oil pressure part with a manual one
(adjustable with washers)...the adjustable part tends to leak also.
My engine situation: Precision Fuel Injection (reman Bendix-style servo--no
fuel tank return requirements), vertical induction (I like the snorkel
look...more distinctive and more effective air flow), fixed pitch prop from
Sensenich and of course the Titan cylinders. The case is mfg by ECI and
most of the parts but the crankshaft and camshaft are Lycoming products...I
believe (experimental); not sure on that. I also purchased a new SkyTech
starter for the engine and the FWF kit from Van's which is mostly done. I
purchased the kit, Slick mags (dual coupling) and a few other parts (fuel
pump) from A.E.R.O., Inc. Their pricing was very competitive and they sold
the new mags basically at their cost (www.aeroinstock.com, Grant City, IL)
who is also a builder. POC is Jesse Robinson. Sorry for the plugs.
Hope to fireup the engine next month.
Ron Fearnow
-7A, wrapping up the slider canopy....hopefully this week
From: "RV7-List Digest Server" <rv7-list(at)matronics.com>
Sent: Friday, 10 August, 2007 2:57 AM
Subject: RV7-List Digest: 4 Msgs - 08/09/07
> Online Versions of Today's List Digest Archive
> Today's complete RV7-List Digest can also be found in either of the
> two Web Links listed below. The .html file includes the Digest formatted
> in HTML for viewing with a web browser and features Hyperlinked Indexes
> and Message Navigation. The .txt file includes the plain ASCII version
> of the RV7-List Digest and can be viewed with a generic text editor
> such as Notepad or with a web browser.
> HTML Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-08-09&Archive=RV7
> Text Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-08-09&Archive=RV7
> EMail Version of Today's List Digest Archive
> RV7-List Digest Archive
> Total Messages Posted Thu 08/09/07: 4
> Today's Message Index:
> 1. 04:26 AM - Re: Elevator trim rigging (Rafael)
> 2. 05:04 PM - Titan (Paul Walter)
> 3. 05:20 PM - Re: Titan (Mark Taylor)
> 4. 08:41 PM - Re: Titan (Carlos A Hernandez)
> ________________________________ Message 1
> From: "Rafael" <rafael(at)gforcecable.com>
> Thanks!
> Cheers,
> Rafael
> _____
> Rafael:
> I
> good luck
> dave
> RV 7A
> me
> to
> actuator will give.
> Thanks and regards,
> Rafael
> _____
> Thanks!
> al
> that aluminum.
> I'll try it.
> Regards,
> Rafael
> _____
> Dear Rafael,
> room.
> John Brunke
> RV7 in progress
> From: <mailto:rafael(at)gforcecable.com> Rafael
> Hi folks!
> interference
> footprint,
> you
> local
> grammar ;))
> Rafael
> Navigator?RV7-List
> ________________________________ Message 2
> From: "Paul Walter" <pdwalter(at)bigpond.net.au>
> Thank you
> Paul Walter
> ________________________________ Message 3
> From: Mark Taylor <mtaylo17(at)msn.com>
> Subject: RE: RV7-List: Titan
> en
> fine.
> My TBO is 2400hrs!
> Mark.
> T
> exp
> ra
> nge of engines.
> Thank you
> Paul Walter
> ________________________________ Message 4
> From: Carlos A Hernandez <carlosh@sec-engr.com>
> Subject: Re: RV7-List: Titan
> Carlos in AZ
> RV-7A
> N174PP reserved
>> Thank you
>> Paul Walter
Subject: | Fw: ECI Titan engines |
Mark, forgot the photo...
Ron F.
Cc:
Sent: Sunday, 12 August, 2007 8:53 AM
Subject: ECI Titan engines
> Hello Mark,
> yet but am happy with the build. I asked John Sjaardema (Excel Air in
> take on the engine build...customer assisted (a plug for John). I
> basically built the engine myself with help from John and his certified
> A&Ps (work space, knowledge, parts, tools, etc.). Spent about 2 weeks
> part time building the engine and everything looked good...the entire kit
> was within specs (a few exceptions), and John is very particular about
> clearances and so forth. I probably spent 2 days with the micrometers.
> the way thru and would not accept a full-length bolt; but we modified the
> bolts and were acceptable to John. Also, 3 exhaust valve rocker arms were
> not within the dry-tappet specs in the Lycoming manuals (John's
> specs...minimum 0.030 clearance) but ECI made the fixes at their
> facility--ECI sent them back, I installed them and were perfect (0.035).
> John and I were happy with the build. John also painted the engine. I
> also replaced the cork gaskets with a better quality gasket for the valve
> covers--the cork material tends to leak. I also replaced the adjustable
> oil pressure part with a manual one (adjustable with washers)...the
> servo--no fuel tank return requirements), vertical induction (I like the
> snorkel look...more distinctive and more effective air flow), fixed pitch
> prop from Sensenich and of course the Titan cylinders. The case is mfg by
> ECI and most of the parts but the crankshaft and camshaft are Lycoming
> products...I believe (experimental); not sure on that. I also purchased
> a new SkyTech starter for the engine and the FWF kit from Van's which is
> mostly done. I purchased the kit, Slick mags (dual coupling) and a few
> other parts (fuel pump) from A.E.R.O., Inc. Their pricing was very
> competitive and they sold the new mags basically at their cost
> (www.aeroinstock.com, Grant City, IL) who is also a builder. POC is
> Ron Fearnow
> To: "RV7-List Digest List"
>> HTML Version:
>> Text Version:
>> Thanks!
>> Cheers,
>> Rafael
>> _____
>> Rafael:
>> I
>> 20.3
>> of
>> good luck
>> dave
>> RV 7A
>> me
>> to
>> motor
>> actuator will give.
>> Thanks and regards,
>> Rafael
>> _____
>> Thanks!
>> al
>> that aluminum.
>> I'll try it.
>> Regards,
>> Rafael
>> _____
>> Dear Rafael,
>> room.
>> John Brunke
>> RV7 in progress
>> Hi folks!
>> interference
>> footprint,
>> thought
>> you
>> trim
>> would
>> local
>> grammar ;))
>> Rafael
>> Navigator?RV7-List
>> Thank you
>> Paul Walter
>> en
>> fine.
>> My TBO is 2400hrs!
>> Mark.
>> T
>> exp
>> ra
>> nge of engines.
>> Thank you
>> Paul Walter
>> Carlos in AZ
>> RV-7A
>> N174PP reserved
>>> Thank you
>>> Paul Walter
Subject: | Elec trim with manual trimhorn |
> Hi all.
> Regarding the interference beetween the elec trimrod and elevator: I used the
manual trimhorn instead of the electric one.
> The manual trimhorn is slightly bigger (comes with the emp kit I think) beacuse
it''s a combined manual/elec trimhorn.
> By using the manual holes, the trimrod moves further away from the elevator skin.
> Also, the manual trimhorn used with elec trim will make the elec trim slightly
less sensitive, which according to some other Norwegain RVators is a good thing.
> I don't know that, but I have not trimmed away the elec "eye" on the horn yet,
because I'm planning to fly with both horns and trim away one of them after
testflying.
> Just my 2-cents from Norway.
> regards Alf Olav Frog
