RV7-Archive.digest.vol-as
June 30, 2010 - August 01, 2010
by the Grove gear, I've got nearly all the wear on the outside 50% of the
tread. I could probably rotate them 180 degrees and get another 70 hours of
flight time, which wouldn't be bad for 22-year old stock kit tires from Van's
(remember, I swiped them from the RV-4 project after the brake incident). But,
I probably should have rotated them a bit sooner. While there's not cord showing,
the tread is gone. Live and learn; I'll be rotating these GYCFIII's in
a more timely manner. If I can double my wear life by rotating because of the
camber, I might get 1000 hours out of these babies! ;-)
RV-8 #82880 N998RV
Status: Enjoying The Fruits of 2500 Hours of Labor!
Subject: | Lubing The Tail Wheel Fork Bearing... |
How the heck do you lube the bronze bearing on the tailwheel fork short of taking
the giant nut off. I lubed it up good during initial assembly, then at about
40 hours, it started to kind of stick, so I dissembled and lubed it again.
Now at 70 its doing it again. I foolishly put a Zerk fitting in the body of
the thing, thinking that next time I could just shoot some lube in there. Great
idea except that it doesn't work for such a tight fit.
Is there some "super lube" you can get that will last forever? I've used both
graphite wheel bearing grease and Aeroshell #6 grease.
Thanks!
RV-8 #82880 N998RV
Matt,
I use aircraft wing jacks and lift the plane at the tie downs. No problems
so far. BTW this is a 7 but I know others with 8's that also use ac wing
jacks
-----Original Message-----
[mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Matt Dralle
Sent: Wednesday, June 30, 2010 8:00 PM
Subject: RV7-List: Jacking Point
Okay, so I'm sure this has been asked a few times already, and I should
search the archive, but what the heck, let's start a new thread.
I got my new tires today (Goodyear Custom Flight III, btw. Super sweet.)
and started looking for ways to get them on. I can really only see two ways
to jack the plane up easily with a normal jack.
1) I could put a short saw horse under the wing tie down and then put a
hydraulic jack on it and lift the side of the airplane up by this point. If
I just gently lift the plane by hand at this point, it seems like that's an
awful lot of weight to be lifting that far out on the wing. Can the spars
really handle this?
2) I could put a saw horse under the lower engine mount bolt to the firewall
and use a hydraulic jack to lift the plane up. This seems less scary, but I
question the shear strength of the bolt lifting all of the weight by this
single point.
What's the convential wisdom on jacking a tail dragger RV-8 to change the
tires? There has to be a way with out building some elaborate dolphin
contraption.
BTW, with regards to my tire wear, since there's a fair amount of camber(?)
afforded by the Grove gear, I've got nearly all the wear on the outside 50%
of the tread. I could probably rotate them 180 degrees and get another 70
hours of flight time, which wouldn't be bad for 22-year old stock kit tires
from Van's (remember, I swiped them from the RV-4 project after the brake
incident). But, I probably should have rotated them a bit sooner. While
there's not cord showing, the tread is gone. Live and learn; I'll be
rotating these GYCFIII's in a more timely manner. If I can double my wear
life by rotating because of the camber, I might get 1000 hours out of these
babies! ;-)
RV-8 #82880 N998RV
Subject: | Re: Highest Quality...? |
Well, if I'd of been paying attention, I could have rotated them and easily gotten
another 70 from them probably. But, I just got the new Goodyear Flight Custom
III's installed last night and then went out and shot some landings. WHAT
A DIFFERENCE! The GY's are 10 times the quality of the stock one's. The sidewalls
are definately far more rigid and the tread is thicker. The rubber seems
a lot "harder" too.
I noticed that the old ones had a "flat spot" when I was removing them. I just
thought "rough" was the way the RV's were suppose to ride. Now the plane really
rolls smoothly. It also seems to track down the runway much better. Wheel
landings are a thing of beauty, and I've almost got that three-point licked.
I was happy to note that my brakes barely look used! Since the brake incident
and subsequent replacement of the wheels and brakes, I have been ever vigilant
about staying off the brakes. I try to taxi like I don't have brakes. Guess
its paying off!
Yeah, I've been flying a LOT! I just can't seem to not head out to the hanger
after work and fly around. My Chevron av-gas bill was $2700 last month! I just
can't believe how nice the RV-8 is to fly. What a joy.
For those that are still slaving away, *keep at it*! It is worth all of the time
you invest in it...
Best,
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: Enjoying The Fruits of 2500 Hours of Labor...
At 02:42 PM 6/28/2010 Monday, you wrote:
>Matt,
>The Van's tires are worn out after only 70 hours? And how in the world did you
put 70 hours on it already? You have been doing some serious flying! I've
got 84 on my originals and I've still got another 20-30 hours left in them. But,
they are not high quality tires.
>I'm ready to order new tires and tubes so I've talked to a number of other RV
owners asking their advice. I've always liked Michelin, but the RV guys near
me all recommend using the Goodyear Flight Custom III. They tell me the sidewalls
are much stiffer and thread is deeper and overall the tire is longer lasting.
Also, many local guys recommended the Michelin Airstop tubes. They tell
me they have no air leaks with the Airstop tubes. With my original tubes, I
have to air up the tires every 6 weeks. The Goodyears have kevlar in the sidewalls
which apparently stiffens the sidewall.
>So, I'm ordering a set of GY tires and Michelin tubes.
>FYI.
>Stan Sutterfield
><http://www.rv-8a.net>www.rv-8a.net
>Its almost time for a new set of tires on the 'ol RV-8. What are the very best
>tires for the RV wheels? I'd like something that will last a little longer than
>70 hours.
Subject: | Re: Update On RV-8 Princeton Fuel Probe Installation... |
At 05:40 PM 6/28/2010 Monday, you wrote:
>--> RV-List message posted by: "j. davis"
>On 06/21/2010 12:00 AM, Matt Dralle wrote:
>>All that
>>matters at this point is that they are both working and are exceptionally accurate
in
>>the 15-0 gallon range which is where it counts.
>...and you just *might* owe Princeton an apology for what I *seem* to remember
as some pretty heavy bad-mouthing in your last few posts. But w/o actually going
back into the archives, I may be wrong...
>Regards, J.
>Sonex #325 C-FJNJ, Jabiru 3300a, Prince P-Tip, Aerocarb
>restoring the Johnston Special
>http://cleco.ca
I might have been a little rough on Princeton initially, but considering how annoyed
I was at that prospect of having to replace them, I think I held back pretty
well: :-)
Reference:
http://forums.matronics.com/viewtopic.php?t=69954 and
http://forums.matronics.com/viewtopic.php?t=69999 and
http://forums.matronics.com/viewtopic.php?t=71281
Just having to remove them to adjust the probe tip so that it wasn't touching the
bottom of the tank was a major ordeal. Since in a QB you can see into the
tank when installing them, they should be pre-bent to make sure they don't touch
or have an insulative piece of plastic on the tip.
And why the first three calibrations didn't take is completely baffling. I almost
didn't try to calibrate again for the forth time, but I was just so demoralized
at having to remove them and try to fit floats in, that I just gave the
calibration one more try. Whew, glad I did.
Anyway, I wanted to clear the air and that's why I posted my extended pirep on
the successful calibration finally. I sent the same report to Princeton, GRT,
and the GRT-EFIS forum as well.
I've got about 20 hours on them now since the successful calibration. They remain
about as accurate as I reported. They still give kind of wonky readings when
the tanks are full sometimes. The lower the fuel level, the more accurate
they seem to be. That being said, based on comparisons with the FuelChec DX
flow meter, I wouldn't trust the level probes more than about +- 1.5 gallons or
so (within 3 gallons of actual). But, that's good enough I suppose. I still
rely on the flow meter's fuel "remanding" mostly as it has proved to be reliable
to within .5 gallons or better.
BTW, the FuelChec DX has a really cool feature called the "Switch Tanks" warning.
You set it to the amount of fuel burn you want to keep your tank levels balanced.
For example, I have mine sent to 3 gallons. Every three gallons of fuel
burn, the FuelChec flashes a warning indicating its time to switch tanks.
I've found this really keeps the fuel balanced across the tanks. Its also an
excellent reminder every 20 minutes or so to check the fuel levels.
RV-8 #82880 N998RV
Subject: | Wheelpants Part Duex - Air Access Door & Misc... |
I'm happy to report that my second wheel pant installation on the RV-8 is coming
out very nice. With the Grove gear (I guess), I'm finding that I have to add
a large cutout to clear the rear brake caliper. I didn't do this on the first
set and found that it put undue stress on the whole pant assembly. Now I just
have to figure out how to make a "blister" to cover it. Anyone know of a
premade fiberglass blister about 2.25" wide that I could just epoxy to the pant?
Anyway, here's my real question. Has anyone used these little doors on the sides
of their RV wheelpants to access the valve stem for checking the pressure?
Drilling a 1" hole sounds like just the right amount of work to me at this point...
http://www.aircraftspruce.com/catalog/hapages/accessdoors.php
RV-8 #82880 N998RV
From: | Charlie England <ceengland(at)bellsouth.net> |
Subject: | Re: For Sale: Hartzell extended hub prop, Precision fuel injection, |
front induction sump
On 7/4/2010 11:15 PM, Charlie England wrote:
> I have for sale a nearly new Hartzell HC-M2YR-1BF extended hub prop.
> Also available, a used governor & high pressure line for this prop.
> This is the prop that fit's James' 'long' cowl without the need for an
> extension. The prop was installed new on a Mustang II, and removed
> when the builder retired the airframe with around 100 hrs on the prop
> (he didn't want to worry about liability when he quit flying the plane).
> I also have available a sump & intake tubes for a parallel valve O-360
> that is set up for a forward facing servo. It's a sump from an A-1x
> series engine that originally had a rear induction, modified by a
> certified engine shop for a forward facing injector. The sump & intake
> tubes will fit an unmodified Rv-x motor mount (unlike the 'C' series
> sumps). The servo mount position appears to be within fractions of an
> inch of the OEM Lyc forward facing servo, based on comparing pics of
> the OEM part to this one.
> Additionally, I have a Precision EX5VA1 fuel injection system,
> complete from the firewall to the heads, including the flex lines with
> firesleeve, high pressure pump, servo, distribution block, injector
> lines, and injectors. This system came off an RV-7 with less than 10
> hours (wrecked). This system is 'as new', if it was still in the
> packing, you couldn't tell it had ever been installed.
> If you're interested in any of these items, email me or give me a call
> at 601-879-9596 & we can discuss price (prices will be very reasonable).
> Thanks,
> Charlie
Correction: the prop's model number is HC-M2YR-1BF.
Subject: | For Sale: RV7 Emp, QB Wings, QB Fuse - North Carolina |
See my listing on VAF:
http://www.vansairforce.com/community/showthread.php?t=60219
RV-7 with a tip-up canopy, qb wings and qb fuse. Kit is located in
Denver, N.C. More photos can be found on my website www.therv7.com.
Asking $23,000. Thanks for looking.
Subject: | For Sale: RV7 Emp w/QB Wings + QB Fuse - North Carolina |
I'm sending this again. I don't think the first time worked (I never got
the email).
Listing on VAF:
Asking $23,000. May be willing to sell the tail seperate from the
wing/fuse if needed. Thanks for looking.
From: | "Richard E. Tasker" <retasker(at)optonline.net> |
Subject: | How to get to several rivets? |
I have just (almost) completed riveting the forward top skin on my RV9A
Slider. However, I am at a loss as to how to rivet these three
locations on each side. The back side of the rivets are buried under
the railing and none of the bucking bars I have will reach any of them.
What has everyone done to set these rivets?
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
Subject: | Re: RV9-List: How to get to several rivets? |
At 08:04 PM 7/18/2010 Sunday, Richard E. Tasker wrote:
>I have just (almost) completed riveting the forward top skin on my RV9A Slider.
However, I am at a loss as to how to rivet these three locations on each side.
The back side of the rivets are buried under the railing and none of the
bucking bars I have will reach any of them. What has everyone done to set these
rivets?
Hi Richard,
Use some CherryMax CR3214! Done.
Here's a write up I did on using these on my RV-8 Project:
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8%26project=638%26category=2973%26log=94469%26row=192
and
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8%26&project=638%26category=2973%26log=94470%26row=191
RV-8 #82880 N998RV
Status: Redoing Wheelpants & Oil Door...
Subject: | Re: How to get to several rivets? (w/ Links That Work!) |
--> RV9-List message posted by: Matt Dralle
rivets?
Hi Richard,
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2973&log=94469&row=192
and
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category=2973&log=94470&row=191
RV-8 #82880 N998RV
Subject: | Re: RV9-List: Re: How to get to several rivets? (w/ Links That |
Work!)
Thanks, Matt. I knew there was probably some sort of pulled solution
but didn't know what.
I will order some tonight and then the forward top skin will be done!
Dick Tasker
side. The back side of the rivets are buried under the railing and none of the
rivets?
> Hi Richard,
> and
> Matt Dralle
> RV-8 #82880 N998RV
> http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel
> Status: Redoing Wheelpants& Oil Door...
Please Note:
Subject: | Re: Instrument Panel Labels |
>Hi Matt,
>I live in Livermore and I'm building an RV10. I contacted Chris at Everon Graphics
in Livermore about a silkscreen for my instrument panel. He said that he
worked on some labels for you and thought that I might like to follow the same
approach. But I didn't really understand how it worked.
>I have heard of an approach in which text is printed on a large sheet of plastic
that is cut to match the outline and cut-outs of the panel. The entire sheet
is adhesively applied to the entire panel. The plastic is available in a choice
of colors; the panel does not get painted.
>Alternatively, some builders will have text printed on a sheet of plastic, cut
the sheet into little pieces that are adhesively applied to the panel, and possibly
spray a clear coat. The plastic might have a color, or might be clear.
>Can you tell me which approach you used? Are you happy with the results? Any
problems working with Chris (he seems a bit slow to return my phone calls)?
>Dave Head
Hi Dave!
Here's my recommendation. Have your completed instrument panel power coated medium-gloss
black. This will give the labels a really good surface to bond too.
I power coated my panel a textured black, and the labels don't like to stick
to that texture nearly as well as a gloss.
Use a good CAD program to layout your instrument panel in 100% exact scale. Be
exact on the placement of instruments and holes. I had my panel CNC cut, so
I already had a CAD diagram to start with that had a very accurate instruemnt
and hole layout.
Take the CAD layout of the instruments and holes, and over lay on a separate layer
all of the silkscreening you want. Use a nice BOLD found. Make sure that
all of your various lettering is all laid out straight using guides in the CAD
program.
Now, print out the whole panel with the labels. If you don't have a wide format
plotter, you can tile the prints and then ScotchTape them together. If you
want, you can email the file and I can plot it out for you and then meet you out
at my hanger sometime.
Using the printout, cut it out, and then tape it to your real panel and sit in
the plane in the normal position. Make sure that you can read all of the labeling
and that it really says what you want it to say. Remember, when you're labeling,
LESS-IS-MORE, so don't get too wordy, but be specific. Also remember
that some instruments may stick out from the panel and might obscure the view
of the label from the normal seating postion.
If you have a stick grip with buttons, you can also add a caricature of the stick
grip with button labels and put this on the panel too. See attached.
Once you're happy with your layout, - and don't be afraid to do a number of iterations
of CAD-Plot-Cut-Fit - output your CAD drawing in a high-resolution PDF.
Use perhaps 2000 dpi or more. You can email this file Chris at Everon Graphics
and he will create the mat-finish label from it directly. Creating the label
is a four layer process and there will be white layer, a black layer, textured
top layer, and a sticky back layer. If you give your power coated panel
to Chris, he will apply the label and cut out all the holes for you. That will
cost extra, however. Chris did a very nice job on my panel and I would recommend
it.
You can also create CAD drawings for all the other little labels around the plane.
I made labels for the cabin lights, alt air, cabin heat, etc. Chris has
a nice die cut machine for cutting out these rectangular sized labels.
Chris can also do full-color labels as well. These cost quite a bit more, but
would be really cool. I just didn't have anything that really screamed out color,
so I went with the black-n-white, in keeping with the rest of my interior.
RV-8 #82880 N998RV
Status: New Wheelpants & Oil Door...
SECTION
HEADER
9
$ACADVER
AC1006
9
$EXTMIN
10
0.179760
20
0.180720
9
$EXTMAX
10
3.815280
20
5.816400
9
$LTSCALE
40
0.024000
9
$PDMODE
70
35
9
$PDSIZE
40
0.019200
ENDSEC
SECTION
TABLES
TABLE
LTYPE
70
9
LTYPE
CONTINUOUS
70
64
Solid line
72
65
73
0.000000
LTYPE
DASHED
70
64
__ __ __ __ __ __ __ __ __ __ __ __ __ __ __
72
65
73
0.000180
49
0.000120
49
-0.000060
LTYPE
HIDDEN
70
64
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
72
65
73
0.000090
49
0.000060
49
-0.000030
LTYPE
CENTER
70
64
____ _ ____ _ ____ _ ____ _ ____ _ ____ _ ____
72
65
73
0.000480
49
0.000300
49
-0.000060
49
0.000060
49
-0.000060
LTYPE
PHANTOM
70
64
_____ _ _ _____ _ _ _____ _ _ _____ _ _ ____
72
65
73
6
40
0.000600
49
0.000300
49
-0.000060
49
0.000060
49
-0.000060
49
0.000060
49
-0.000060
LTYPE
DOT
70
64
65
73
0.000060
49
0.000000
49
-0.000060
LTYPE
DASHDOT
70
64
__ . __ . __ . __ . __ . __ . __ . __ . __ . __
72
65
73
0.000240
49
0.000120
49
-0.000060
49
0.000000
49
-0.000060
LTYPE
BORDER
70
64
__ __ . __ __ . __ __ . __ __ . __ __ . __ __
72
65
73
6
40
0.000420
49
0.000120
49
-0.000060
49
0.000120
49
-0.000060
49
0.000000
49
-0.000060
LTYPE
DIVIDE
70
64
__ . . __ . . __ . . __ . . __ . . __ . . __
72
65
73
6
40
0.000300
49
0.000120
49
-0.000060
49
0.000000
49
-0.000060
49
0.000000
49
-0.000060
LTYPE
DOTDOT
70
64
65
73
5
40
0.000132
49
-0.000060
49
0.000000
49
-0.000060
49
0.000000
49
-0.000060
ENDTAB
TABLE
STYLE
70
8
STYLE
70
SN0
40
0.000000
41
0.000240
50
0.000000
71
0.000000
ITALICC
STYLE
70
68
SV0
40
0.000000
41
0.000240
50
0.000000
71
0.000000
ITALICC
STYLE
70
SN1
40
0.000000
41
0.000240
50
0.000000
71
0.000000
CYRILLIC
STYLE
70
68
SV1
40
0.000000
41
0.000240
50
0.000000
71
0.000000
CYRILLIC
STYLE
70
SN2
40
0.000000
41
0.000240
50
0.000000
71
0.000000
ROMAND
STYLE
70
68
SV2
40
0.000000
41
0.000240
50
0.000000
71
0.000000
ROMAND
STYLE
70
SN3
40
0.000000
41
0.000240
50
0.000000
71
0.000000
ROMAND
STYLE
70
68
SV3
40
0.000000
41
0.000240
50
0.000000
71
0.000000
ROMAND
ENDTAB
TABLE
LAYER
70
LAYER
FOREGROUND
70
64
62
7
6
CONTINUOUS
LAYER
BACKGROUND
70
65
62
-7
6
CONTINUOUS
LAYER
64
62
7
6
CONTINUOUS
ENDTAB
ENDSEC
SECTION
ENTITIES
POLYLINE
8
FOREGROUND
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
FOREGROUND
6
CONTINUOUS
10
0.000000
20
5.997120
VERTEX
8
FOREGROUND
6
CONTINUOUS
10
4.000080
20
5.997120
VERTEX
8
FOREGROUND
6
CONTINUOUS
10
4.000080
20
-0.002880
VERTEX
8
FOREGROUND
6
CONTINUOUS
10
0.000000
20
-0.002880
VERTEX
8
FOREGROUND
6
CONTINUOUS
10
0.000000
20
5.997120
SEQEND
8
SOLID
8
0.743280
20
5.101200
11
3.355440
21
5.101200
12
0.743280
22
1.976160
13
3.355440
23
1.976160
POLYLINE
8
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
CONTINUOUS
10
0.743280
20
5.101200
VERTEX
8
CONTINUOUS
10
3.355440
20
5.101200
VERTEX
8
CONTINUOUS
10
3.355440
20
1.976160
VERTEX
8
CONTINUOUS
10
0.743280
20
1.976160
VERTEX
8
CONTINUOUS
10
0.743280
20
5.101200
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.758240
20
3.640320
VERTEX
8
7
6
CONTINUOUS
10
1.777440
20
3.654960
VERTEX
8
7
6
CONTINUOUS
10
1.800000
20
3.670800
VERTEX
8
7
6
CONTINUOUS
10
1.805040
20
3.680160
VERTEX
8
7
6
CONTINUOUS
10
1.806240
20
3.691920
VERTEX
8
7
6
CONTINUOUS
10
1.805280
20
3.717360
VERTEX
8
7
6
CONTINUOUS
10
1.803120
20
3.733680
VERTEX
8
7
6
CONTINUOUS
10
1.801920
20
3.739920
VERTEX
8
7
6
CONTINUOUS
10
1.795920
20
3.755520
VERTEX
8
7
6
CONTINUOUS
10
1.787040
20
3.770160
VERTEX
8
7
6
CONTINUOUS
10
1.776960
20
3.780960
VERTEX
8
7
6
CONTINUOUS
10
1.779120
20
3.773040
VERTEX
8
7
6
CONTINUOUS
10
1.780080
20
3.768720
VERTEX
8
7
6
CONTINUOUS
10
1.781040
20
3.763920
VERTEX
8
7
6
CONTINUOUS
10
1.782000
20
3.758160
VERTEX
8
7
6
CONTINUOUS
10
1.782720
20
3.751920
VERTEX
8
7
6
CONTINUOUS
10
1.783200
20
3.745200
VERTEX
8
7
6
CONTINUOUS
10
1.783440
20
3.738000
VERTEX
8
7
6
CONTINUOUS
10
1.783440
20
3.723120
VERTEX
8
7
6
CONTINUOUS
10
1.782960
20
3.716160
VERTEX
8
7
6
CONTINUOUS
10
1.782720
20
3.710400
VERTEX
8
7
6
CONTINUOUS
10
1.782240
20
3.705600
VERTEX
8
7
6
CONTINUOUS
10
1.781520
20
3.701760
VERTEX
8
7
6
CONTINUOUS
10
1.779840
20
3.695280
VERTEX
8
7
6
CONTINUOUS
10
1.777200
20
3.688320
VERTEX
8
7
6
CONTINUOUS
10
1.773360
20
3.681360
VERTEX
8
7
6
CONTINUOUS
10
1.771200
20
3.678000
VERTEX
8
7
6
CONTINUOUS
10
1.766400
20
3.671760
VERTEX
8
7
6
CONTINUOUS
10
1.764480
20
3.668880
VERTEX
8
7
6
CONTINUOUS
10
1.762800
20
3.666000
VERTEX
8
7
6
CONTINUOUS
10
1.761360
20
3.663360
VERTEX
8
7
6
CONTINUOUS
10
1.759440
20
3.657840
VERTEX
8
7
6
CONTINUOUS
10
1.758720
20
3.652320
VERTEX
8
7
6
CONTINUOUS
10
1.758240
20
3.647280
VERTEX
8
7
6
CONTINUOUS
10
1.758240
20
3.640320
SEQEND
8
SOLID
8
15
10
1.740720
20
3.018720
11
1.743600
21
3.050640
12
1.681440
22
3.025680
13
1.680720
23
3.073920
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.740720
20
3.018720
VERTEX
8
7
6
CONTINUOUS
10
1.743600
20
3.050640
VERTEX
8
7
6
CONTINUOUS
10
1.680720
20
3.073920
VERTEX
8
7
6
CONTINUOUS
10
1.681440
20
3.025680
VERTEX
8
7
6
CONTINUOUS
10
1.740720
20
3.018720
SEQEND
8
SOLID
8
15
10
1.680720
20
3.073920
11
1.699920
21
3.074640
12
1.743600
22
3.050640
13
1.744080
23
3.055680
POLYLINE
8
15
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
15
6
CONTINUOUS
10
1.680720
20
3.073920
VERTEX
8
15
6
CONTINUOUS
10
1.699920
20
3.074640
VERTEX
8
15
6
CONTINUOUS
10
1.744080
20
3.055680
VERTEX
8
15
6
CONTINUOUS
10
1.743600
20
3.050640
VERTEX
8
15
6
CONTINUOUS
10
1.680720
20
3.073920
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.680720
20
3.073920
VERTEX
8
7
6
CONTINUOUS
10
1.699920
20
3.074640
VERTEX
8
7
6
CONTINUOUS
10
1.744080
20
3.055680
VERTEX
8
7
6
CONTINUOUS
10
1.743600
20
3.050640
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
2.134320
20
4.146000
VERTEX
8
7
6
CONTINUOUS
10
2.145120
20
4.141920
VERTEX
8
7
6
CONTINUOUS
10
2.155200
20
4.137360
VERTEX
8
7
6
CONTINUOUS
10
2.160000
20
4.134720
VERTEX
8
7
6
CONTINUOUS
10
2.164560
20
4.132080
VERTEX
8
7
6
CONTINUOUS
10
2.168880
20
4.129680
VERTEX
8
7
6
CONTINUOUS
10
2.172480
20
4.127280
VERTEX
8
7
6
CONTINUOUS
10
2.175600
20
4.125120
VERTEX
8
7
6
CONTINUOUS
10
2.178480
20
4.123200
VERTEX
8
7
6
CONTINUOUS
10
2.183760
20
4.119600
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
2.241840
20
4.060560
VERTEX
8
7
6
CONTINUOUS
10
2.251440
20
4.036560
VERTEX
8
7
6
CONTINUOUS
10
2.253360
20
4.027440
VERTEX
8
7
6
CONTINUOUS
10
2.252880
20
4.019520
VERTEX
8
7
6
CONTINUOUS
10
2.250960
20
4.011120
VERTEX
8
7
6
CONTINUOUS
10
2.246160
20
4.001040
VERTEX
8
7
6
CONTINUOUS
10
2.231040
20
3.981120
VERTEX
8
7
6
CONTINUOUS
10
2.194320
20
3.940800
VERTEX
8
7
6
CONTINUOUS
10
2.173920
20
3.919920
VERTEX
8
7
6
CONTINUOUS
10
2.166000
20
3.909120
VERTEX
8
7
6
CONTINUOUS
10
2.159760
20
3.896640
VERTEX
8
7
6
CONTINUOUS
10
2.156160
20
3.882240
VERTEX
8
7
6
CONTINUOUS
10
2.154480
20
3.866160
VERTEX
8
7
6
CONTINUOUS
10
2.154720
20
3.847680
VERTEX
8
7
6
CONTINUOUS
10
2.158560
20
3.822240
VERTEX
8
7
6
CONTINUOUS
10
2.167440
20
3.786480
VERTEX
8
7
6
CONTINUOUS
10
2.183520
20
3.734640
VERTEX
8
7
6
CONTINUOUS
10
2.206800
20
3.663840
VERTEX
8
7
6
CONTINUOUS
10
2.223840
20
3.601440
VERTEX
8
7
6
CONTINUOUS
10
2.244000
20
3.511920
VERTEX
8
7
6
CONTINUOUS
10
2.256720
20
3.442080
VERTEX
8
7
6
CONTINUOUS
10
2.267280
20
3.370080
VERTEX
8
7
6
CONTINUOUS
10
2.276640
20
3.289920
VERTEX
8
7
6
CONTINUOUS
10
2.282880
20
3.223440
VERTEX
8
7
6
CONTINUOUS
10
2.289360
20
3.128160
VERTEX
8
7
6
CONTINUOUS
10
2.296080
20
2.989920
VERTEX
8
7
6
CONTINUOUS
10
2.296080
20
2.982240
VERTEX
8
7
6
CONTINUOUS
10
2.297520
20
2.980320
VERTEX
8
7
6
CONTINUOUS
10
2.318160
20
2.977920
VERTEX
8
7
6
CONTINUOUS
10
2.356560
20
2.974080
VERTEX
8
7
6
CONTINUOUS
10
2.393760
20
2.968320
VERTEX
8
7
6
CONTINUOUS
10
2.416080
20
2.963520
VERTEX
8
7
6
CONTINUOUS
10
2.435520
20
2.957520
VERTEX
8
7
6
CONTINUOUS
10
2.450400
20
2.950800
VERTEX
8
7
6
CONTINUOUS
10
2.460240
20
2.943840
VERTEX
8
7
6
CONTINUOUS
10
2.465760
20
2.936640
VERTEX
8
7
6
CONTINUOUS
10
2.468880
20
2.929200
VERTEX
8
7
6
CONTINUOUS
10
2.469600
20
2.918880
VERTEX
8
7
6
CONTINUOUS
10
2.468160
20
2.912640
VERTEX
8
7
6
CONTINUOUS
10
2.464320
20
2.906160
VERTEX
8
7
6
CONTINUOUS
10
2.456640
20
2.899680
VERTEX
8
7
6
CONTINUOUS
10
2.442720
20
2.892960
VERTEX
8
7
6
CONTINUOUS
10
2.422800
20
2.886720
VERTEX
8
7
6
CONTINUOUS
10
2.386320
20
2.878560
VERTEX
8
7
6
CONTINUOUS
10
2.341920
20
2.871840
VERTEX
8
7
6
CONTINUOUS
10
2.323440
20
2.869920
VERTEX
8
7
6
CONTINUOUS
10
2.320800
20
2.868240
VERTEX
8
7
6
CONTINUOUS
10
2.319120
20
2.860800
VERTEX
8
7
6
CONTINUOUS
10
2.318640
20
2.829120
VERTEX
8
7
6
CONTINUOUS
10
2.318640
20
2.786400
VERTEX
8
7
6
CONTINUOUS
10
2.316000
20
2.781840
VERTEX
8
7
6
CONTINUOUS
10
2.310000
20
2.777280
VERTEX
8
7
6
CONTINUOUS
10
2.291760
20
2.768640
VERTEX
8
7
6
CONTINUOUS
10
2.262960
20
2.759280
VERTEX
8
7
6
CONTINUOUS
10
2.236800
20
2.753520
VERTEX
8
7
6
CONTINUOUS
10
2.207520
20
2.749680
VERTEX
8
7
6
CONTINUOUS
10
2.173680
20
2.747040
VERTEX
8
7
6
CONTINUOUS
10
2.122320
20
2.745600
VERTEX
8
7
6
CONTINUOUS
10
2.039520
20
2.746320
VERTEX
8
7
6
CONTINUOUS
10
1.969200
20
2.749680
VERTEX
8
7
6
CONTINUOUS
10
1.929600
20
2.753760
VERTEX
8
7
6
CONTINUOUS
10
1.902720
20
2.758080
VERTEX
8
7
6
CONTINUOUS
10
1.878960
20
2.763840
VERTEX
8
7
6
CONTINUOUS
10
1.856400
20
2.771520
VERTEX
8
7
6
CONTINUOUS
10
1.844400
20
2.777760
VERTEX
8
7
6
CONTINUOUS
10
1.839840
20
2.782560
VERTEX
8
7
6
CONTINUOUS
10
1.838640
20
2.798640
VERTEX
8
7
6
CONTINUOUS
10
1.836960
20
2.898240
VERTEX
8
7
6
CONTINUOUS
10
1.835760
20
2.905200
VERTEX
8
7
6
CONTINUOUS
10
1.831200
20
2.912400
VERTEX
8
7
6
CONTINUOUS
10
1.821600
20
2.919840
VERTEX
8
7
6
CONTINUOUS
10
1.790160
20
2.936160
VERTEX
8
7
6
CONTINUOUS
10
1.782720
20
2.940720
VERTEX
8
7
6
CONTINUOUS
10
1.769760
20
2.951760
VERTEX
8
7
6
CONTINUOUS
10
1.758960
20
2.964480
VERTEX
8
7
6
CONTINUOUS
10
1.750800
20
2.976720
VERTEX
8
7
6
CONTINUOUS
10
1.743360
20
2.993280
VERTEX
8
7
6
CONTINUOUS
10
1.741440
20
3.005280
VERTEX
8
7
6
CONTINUOUS
10
1.741440
20
3.023520
VERTEX
8
7
6
CONTINUOUS
10
1.743360
20
3.052080
VERTEX
8
7
6
CONTINUOUS
10
1.745760
20
3.065760
VERTEX
8
7
6
CONTINUOUS
10
1.750080
20
3.078720
VERTEX
8
7
6
CONTINUOUS
10
1.756800
20
3.090240
VERTEX
8
7
6
CONTINUOUS
10
1.765680
20
3.102000
VERTEX
8
7
6
CONTINUOUS
10
1.776000
20
3.112560
VERTEX
8
7
6
CONTINUOUS
10
1.793760
20
3.125520
VERTEX
8
7
6
CONTINUOUS
10
1.814640
20
3.135600
VERTEX
8
7
6
CONTINUOUS
10
1.850880
20
3.148800
VERTEX
8
7
6
CONTINUOUS
10
1.855440
20
3.152400
VERTEX
8
7
6
CONTINUOUS
10
1.857360
20
3.159120
VERTEX
8
7
6
CONTINUOUS
10
1.857360
20
3.202320
VERTEX
8
7
6
CONTINUOUS
10
1.853040
20
3.365520
VERTEX
8
7
6
CONTINUOUS
10
1.851840
20
3.373200
VERTEX
8
7
6
CONTINUOUS
10
1.844160
20
3.383040
VERTEX
8
7
6
CONTINUOUS
10
1.790880
20
3.443280
VERTEX
8
7
6
CONTINUOUS
10
1.763280
20
3.477120
VERTEX
8
7
6
CONTINUOUS
10
1.755360
20
3.489600
VERTEX
8
7
6
CONTINUOUS
10
1.751280
20
3.503280
VERTEX
8
7
6
CONTINUOUS
10
1.749840
20
3.517200
VERTEX
8
7
6
CONTINUOUS
10
1.749840
20
3.524160
VERTEX
8
7
6
CONTINUOUS
10
1.752720
20
3.535200
VERTEX
8
7
6
CONTINUOUS
10
1.757760
20
3.544800
VERTEX
8
7
6
CONTINUOUS
10
1.767600
20
3.557520
VERTEX
8
7
6
CONTINUOUS
10
1.768560
20
3.561120
VERTEX
8
7
6
CONTINUOUS
10
1.767360
20
3.564000
VERTEX
8
7
6
CONTINUOUS
10
1.738320
20
3.600720
VERTEX
8
7
6
CONTINUOUS
10
1.734480
20
3.606960
VERTEX
8
7
6
CONTINUOUS
10
1.733520
20
3.611760
VERTEX
8
7
6
CONTINUOUS
10
1.734480
20
3.616080
VERTEX
8
7
6
CONTINUOUS
10
1.746240
20
3.629520
VERTEX
8
7
6
CONTINUOUS
10
1.766880
20
3.647760
VERTEX
8
7
6
CONTINUOUS
10
1.797360
20
3.669120
VERTEX
8
7
6
CONTINUOUS
10
1.803120
20
3.676800
VERTEX
8
7
6
CONTINUOUS
10
1.804800
20
3.685440
VERTEX
8
7
6
CONTINUOUS
10
1.805520
20
3.699600
VERTEX
8
7
6
CONTINUOUS
10
1.804800
20
3.717600
VERTEX
8
7
6
CONTINUOUS
10
1.802640
20
3.733680
VERTEX
8
7
6
CONTINUOUS
10
1.799520
20
3.745920
VERTEX
8
7
6
CONTINUOUS
10
1.791360
20
3.762480
VERTEX
8
7
6
CONTINUOUS
10
1.782960
20
3.774240
VERTEX
8
7
6
CONTINUOUS
10
1.758240
20
3.798480
VERTEX
8
7
6
CONTINUOUS
10
1.700640
20
3.848400
VERTEX
8
7
6
CONTINUOUS
10
1.686000
20
3.864240
VERTEX
8
7
6
CONTINUOUS
10
1.675440
20
3.879120
VERTEX
8
7
6
CONTINUOUS
10
1.668240
20
3.892560
VERTEX
8
7
6
CONTINUOUS
10
1.663920
20
3.906000
VERTEX
8
7
6
CONTINUOUS
10
1.662000
20
3.922800
VERTEX
8
7
6
CONTINUOUS
10
1.662000
20
3.943200
VERTEX
8
7
6
CONTINUOUS
10
1.663920
20
3.965040
VERTEX
8
7
6
CONTINUOUS
10
1.669440
20
3.999120
VERTEX
8
7
6
CONTINUOUS
10
1.678560
20
4.035120
VERTEX
8
7
6
CONTINUOUS
10
1.682160
20
4.046160
VERTEX
8
7
6
CONTINUOUS
10
1.690800
20
4.064640
VERTEX
8
7
6
CONTINUOUS
10
1.699440
20
4.077360
VERTEX
8
7
6
CONTINUOUS
10
1.711680
20
4.090320
VERTEX
8
7
6
CONTINUOUS
10
1.721520
20
4.099200
VERTEX
8
7
6
CONTINUOUS
10
1.733040
20
4.108080
VERTEX
8
7
6
CONTINUOUS
10
1.745760
20
4.116480
VERTEX
8
7
6
CONTINUOUS
10
1.759680
20
4.124400
VERTEX
8
7
6
CONTINUOUS
10
1.789680
20
4.138560
VERTEX
8
7
6
CONTINUOUS
10
1.821120
20
4.150800
VERTEX
8
7
6
CONTINUOUS
10
1.850640
20
4.160880
VERTEX
8
7
6
CONTINUOUS
10
1.875120
20
4.167600
VERTEX
8
7
6
CONTINUOUS
10
1.901040
20
4.172160
VERTEX
8
7
6
CONTINUOUS
10
1.923840
20
4.174320
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.794960
20
4.105440
VERTEX
8
7
6
CONTINUOUS
10
1.781280
20
4.103520
VERTEX
8
7
6
CONTINUOUS
10
1.773840
20
4.101120
VERTEX
8
7
6
CONTINUOUS
10
1.766640
20
4.097760
VERTEX
8
7
6
CONTINUOUS
10
1.757520
20
4.090560
VERTEX
8
7
6
CONTINUOUS
10
1.753200
20
4.084800
VERTEX
8
7
6
CONTINUOUS
10
1.749840
20
4.074480
VERTEX
8
7
6
CONTINUOUS
10
1.749120
20
4.066080
VERTEX
8
7
6
CONTINUOUS
10
1.750560
20
4.057200
VERTEX
8
7
6
CONTINUOUS
10
1.754160
20
4.048560
VERTEX
8
7
6
CONTINUOUS
10
1.762800
20
4.038480
VERTEX
8
7
6
CONTINUOUS
10
1.773600
20
4.031280
VERTEX
8
7
6
CONTINUOUS
10
1.787280
20
4.025280
VERTEX
8
7
6
CONTINUOUS
10
1.798800
20
4.022880
VERTEX
8
7
6
CONTINUOUS
10
1.811280
20
4.021920
VERTEX
8
7
6
CONTINUOUS
10
1.828800
20
4.022400
VERTEX
8
7
6
CONTINUOUS
10
1.842240
20
4.025040
VERTEX
8
7
6
CONTINUOUS
10
1.846080
20
4.026480
VERTEX
8
7
6
CONTINUOUS
10
1.857600
20
4.034640
VERTEX
8
7
6
CONTINUOUS
10
1.863360
20
4.042800
VERTEX
8
7
6
CONTINUOUS
10
1.865760
20
4.049040
VERTEX
8
7
6
CONTINUOUS
10
1.867440
20
4.059840
VERTEX
8
7
6
CONTINUOUS
10
1.867200
20
4.067040
VERTEX
8
7
6
CONTINUOUS
10
1.866240
20
4.073040
VERTEX
8
7
6
CONTINUOUS
10
1.861920
20
4.082880
VERTEX
8
7
6
CONTINUOUS
10
1.855680
20
4.090800
VERTEX
8
7
6
CONTINUOUS
10
1.848000
20
4.096560
VERTEX
8
7
6
CONTINUOUS
10
1.840080
20
4.099920
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.750320
20
3.525840
VERTEX
8
7
6
CONTINUOUS
10
1.752720
20
3.516240
VERTEX
8
7
6
CONTINUOUS
10
1.757280
20
3.507600
VERTEX
8
7
6
CONTINUOUS
10
1.763520
20
3.502320
VERTEX
8
7
6
CONTINUOUS
10
1.772400
20
3.499440
VERTEX
8
7
6
CONTINUOUS
10
1.779600
20
3.498960
VERTEX
8
7
6
CONTINUOUS
10
1.792320
20
3.500880
VERTEX
8
7
6
CONTINUOUS
10
1.812000
20
3.508560
VERTEX
8
7
6
CONTINUOUS
10
1.835520
20
3.521280
VERTEX
8
7
6
CONTINUOUS
10
1.864080
20
3.542160
VERTEX
8
7
6
CONTINUOUS
10
1.907280
20
3.579120
VERTEX
8
7
6
CONTINUOUS
10
1.986720
20
3.651840
VERTEX
8
7
6
CONTINUOUS
10
2.012640
20
3.677760
VERTEX
8
7
6
CONTINUOUS
10
2.015760
20
3.682560
VERTEX
8
7
6
CONTINUOUS
10
2.017680
20
3.690720
VERTEX
8
7
6
CONTINUOUS
10
2.016720
20
3.695760
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.766880
20
3.555600
VERTEX
8
7
6
CONTINUOUS
10
1.856640
20
3.636000
VERTEX
8
7
6
CONTINUOUS
10
1.904160
20
3.675120
VERTEX
8
7
6
CONTINUOUS
10
1.945440
20
3.704400
VERTEX
8
7
6
CONTINUOUS
10
1.965600
20
3.716160
VERTEX
8
7
6
CONTINUOUS
10
1.976160
20
3.719760
VERTEX
8
7
6
CONTINUOUS
10
1.984560
20
3.720240
VERTEX
8
7
6
CONTINUOUS
10
1.992000
20
3.718800
VERTEX
8
7
6
CONTINUOUS
10
2.000880
20
3.714000
VERTEX
8
7
6
CONTINUOUS
10
2.013360
20
3.701040
VERTEX
8
7
6
CONTINUOUS
10
2.017680
20
3.693120
VERTEX
8
7
6
CONTINUOUS
10
2.019600
20
3.681360
VERTEX
8
7
6
CONTINUOUS
10
2.020080
20
3.644160
VERTEX
8
7
6
CONTINUOUS
10
2.019600
20
3.406320
VERTEX
8
7
6
CONTINUOUS
10
2.020080
20
3.355200
VERTEX
8
7
6
CONTINUOUS
10
2.019600
20
3.345120
VERTEX
8
7
6
CONTINUOUS
10
2.018400
20
3.336480
VERTEX
8
7
6
CONTINUOUS
10
2.014560
20
3.324480
VERTEX
8
7
6
CONTINUOUS
10
2.007120
20
3.312240
VERTEX
8
7
6
CONTINUOUS
10
1.987920
20
3.290880
VERTEX
8
7
6
CONTINUOUS
10
1.974240
20
3.278640
VERTEX
8
7
6
CONTINUOUS
10
1.969200
20
3.276480
VERTEX
8
7
6
CONTINUOUS
10
1.966320
20
3.276720
VERTEX
8
7
6
CONTINUOUS
10
1.956240
20
3.282720
VERTEX
8
7
6
CONTINUOUS
10
1.892160
20
3.338400
VERTEX
8
7
6
CONTINUOUS
10
1.850400
20
3.376080
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
2.296080
20
2.982000
VERTEX
8
7
6
CONTINUOUS
10
2.296800
20
2.973360
VERTEX
8
7
6
CONTINUOUS
10
2.298240
20
2.968080
VERTEX
8
7
6
CONTINUOUS
10
2.300880
20
2.962800
VERTEX
8
7
6
CONTINUOUS
10
2.305440
20
2.958240
VERTEX
8
7
6
CONTINUOUS
10
2.312880
20
2.955360
VERTEX
8
7
6
CONTINUOUS
10
2.323920
20
2.954160
VERTEX
8
7
6
CONTINUOUS
10
2.358480
20
2.953920
VERTEX
8
7
6
CONTINUOUS
10
2.389680
20
2.952480
VERTEX
8
7
6
CONTINUOUS
10
2.422800
20
2.948400
VERTEX
8
7
6
CONTINUOUS
10
2.437680
20
2.945280
VERTEX
8
7
6
CONTINUOUS
10
2.450880
20
2.941200
VERTEX
8
7
6
CONTINUOUS
10
2.458320
20
2.937120
VERTEX
8
7
6
CONTINUOUS
10
2.463840
20
2.932320
VERTEX
8
7
6
CONTINUOUS
10
2.466720
20
2.927040
VERTEX
8
7
6
CONTINUOUS
10
2.467200
20
2.921520
VERTEX
8
7
6
CONTINUOUS
10
2.465760
20
2.915760
VERTEX
8
7
6
CONTINUOUS
10
2.462160
20
2.910000
VERTEX
8
7
6
CONTINUOUS
10
2.455680
20
2.904720
VERTEX
8
7
6
CONTINUOUS
10
2.445120
20
2.899680
VERTEX
8
7
6
CONTINUOUS
10
2.429760
20
2.895360
VERTEX
8
7
6
CONTINUOUS
10
2.398080
20
2.889840
VERTEX
8
7
6
CONTINUOUS
10
2.349360
20
2.884320
VERTEX
8
7
6
CONTINUOUS
10
2.317920
20
2.881680
VERTEX
8
7
6
CONTINUOUS
10
2.309280
20
2.880240
VERTEX
8
7
6
CONTINUOUS
10
2.301600
20
2.878080
VERTEX
8
7
6
CONTINUOUS
10
2.289120
20
2.871120
VERTEX
8
7
6
CONTINUOUS
10
2.284080
20
2.866080
VERTEX
8
7
6
CONTINUOUS
10
2.275920
20
2.852880
VERTEX
8
7
6
CONTINUOUS
10
2.270160
20
2.838000
VERTEX
8
7
6
CONTINUOUS
10
2.265600
20
2.816880
VERTEX
8
7
6
CONTINUOUS
10
2.263440
20
2.810160
VERTEX
8
7
6
CONTINUOUS
10
2.256000
20
2.796480
VERTEX
8
7
6
CONTINUOUS
10
2.244960
20
2.783760
VERTEX
8
7
6
CONTINUOUS
10
2.232000
20
2.772720
VERTEX
8
7
6
CONTINUOUS
10
2.215920
20
2.763600
VERTEX
8
7
6
CONTINUOUS
10
2.196960
20
2.755920
VERTEX
8
7
6
CONTINUOUS
10
2.186640
20
2.752800
VERTEX
8
7
6
CONTINUOUS
10
2.164320
20
2.748480
VERTEX
8
7
6
CONTINUOUS
10
2.133120
20
2.745840
VERTEX
8
7
6
CONTINUOUS
10
2.123760
20
2.745600
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
2.020080
20
3.355920
VERTEX
8
7
6
CONTINUOUS
10
2.018400
20
3.205920
VERTEX
8
7
6
CONTINUOUS
10
2.016960
20
3.157920
VERTEX
8
7
6
CONTINUOUS
10
2.014560
20
3.129360
VERTEX
8
7
6
CONTINUOUS
10
2.012400
20
3.117360
VERTEX
8
7
6
CONTINUOUS
10
2.009040
20
3.110640
VERTEX
8
7
6
CONTINUOUS
10
2.001120
20
3.105600
VERTEX
8
7
6
CONTINUOUS
10
1.967760
20
3.094560
VERTEX
8
7
6
CONTINUOUS
10
1.941840
20
3.083280
VERTEX
8
7
6
CONTINUOUS
10
1.923840
20
3.072720
VERTEX
8
7
6
CONTINUOUS
10
1.912320
20
3.062640
VERTEX
8
7
6
CONTINUOUS
10
1.903680
20
3.051120
VERTEX
8
7
6
CONTINUOUS
10
1.895760
20
3.034320
VERTEX
8
7
6
CONTINUOUS
10
1.891200
20
3.016800
VERTEX
8
7
6
CONTINUOUS
10
1.890000
20
2.998800
VERTEX
8
7
6
CONTINUOUS
10
1.890480
20
2.989920
VERTEX
8
7
6
CONTINUOUS
10
1.893840
20
2.972880
VERTEX
8
7
6
CONTINUOUS
10
1.899120
20
2.959440
VERTEX
8
7
6
CONTINUOUS
10
1.906080
20
2.949600
VERTEX
8
7
6
CONTINUOUS
10
1.919280
20
2.938080
VERTEX
8
7
6
CONTINUOUS
10
1.935360
20
2.928240
VERTEX
8
7
6
CONTINUOUS
10
1.954320
20
2.919840
VERTEX
8
7
6
CONTINUOUS
10
1.987920
20
2.905920
VERTEX
8
7
6
CONTINUOUS
10
1.997520
20
2.899680
VERTEX
8
7
6
CONTINUOUS
10
1.998720
20
2.897760
VERTEX
8
7
6
CONTINUOUS
10
1.998000
20
2.896320
VERTEX
8
7
6
CONTINUOUS
10
1.993200
20
2.895360
VERTEX
8
7
6
CONTINUOUS
10
1.979760
20
2.896080
VERTEX
8
7
6
CONTINUOUS
10
1.960560
20
2.899200
VERTEX
8
7
6
CONTINUOUS
10
1.900560
20
2.914800
VERTEX
8
7
6
CONTINUOUS
10
1.880640
20
2.917680
VERTEX
8
7
6
CONTINUOUS
10
1.870560
20
2.918160
VERTEX
8
7
6
CONTINUOUS
10
1.860720
20
2.917680
VERTEX
8
7
6
CONTINUOUS
10
1.830960
20
2.912400
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.994880
20
2.901840
VERTEX
8
7
6
CONTINUOUS
10
2.010000
20
2.890560
VERTEX
8
7
6
CONTINUOUS
10
2.018160
20
2.881920
VERTEX
8
7
6
CONTINUOUS
10
2.023920
20
2.871840
VERTEX
8
7
6
CONTINUOUS
10
2.026800
20
2.860320
VERTEX
8
7
6
CONTINUOUS
10
2.027520
20
2.854080
VERTEX
8
7
6
CONTINUOUS
10
2.026320
20
2.841120
VERTEX
8
7
6
CONTINUOUS
10
2.022480
20
2.826960
VERTEX
8
7
6
CONTINUOUS
10
2.010960
20
2.802240
VERTEX
8
7
6
CONTINUOUS
10
1.996080
20
2.776800
VERTEX
8
7
6
CONTINUOUS
10
1.988160
20
2.766480
VERTEX
8
7
6
CONTINUOUS
10
1.981200
20
2.760720
VERTEX
8
7
6
CONTINUOUS
10
1.974240
20
2.757120
VERTEX
8
7
6
CONTINUOUS
10
1.961760
20
2.754480
VERTEX
8
7
6
CONTINUOUS
10
1.947360
20
2.753520
VERTEX
8
7
6
CONTINUOUS
10
1.930800
20
2.753520
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.857120
20
3.156720
VERTEX
8
7
6
CONTINUOUS
10
1.856880
20
3.151200
VERTEX
8
7
6
CONTINUOUS
10
1.857120
20
3.148320
VERTEX
8
7
6
CONTINUOUS
10
1.857840
20
3.145200
VERTEX
8
7
6
CONTINUOUS
10
1.859280
20
3.142080
VERTEX
8
7
6
CONTINUOUS
10
1.860960
20
3.138960
VERTEX
8
7
6
CONTINUOUS
10
1.863360
20
3.136080
VERTEX
8
7
6
CONTINUOUS
10
1.866000
20
3.133440
VERTEX
8
7
6
CONTINUOUS
10
1.869120
20
3.131040
VERTEX
8
7
6
CONTINUOUS
10
1.872960
20
3.129120
VERTEX
8
7
6
CONTINUOUS
10
1.877520
20
3.127200
VERTEX
8
7
6
CONTINUOUS
10
1.883040
20
3.125520
VERTEX
8
7
6
CONTINUOUS
10
1.889760
20
3.123840
VERTEX
8
7
6
CONTINUOUS
10
1.897440
20
3.122400
VERTEX
8
7
6
CONTINUOUS
10
1.913760
20
3.120000
VERTEX
8
7
6
CONTINUOUS
10
1.929840
20
3.118560
VERTEX
8
7
6
CONTINUOUS
10
1.937760
20
3.118320
VERTEX
8
7
6
CONTINUOUS
10
1.946400
20
3.118080
VERTEX
8
7
6
CONTINUOUS
10
1.964640
20
3.118080
VERTEX
8
7
6
CONTINUOUS
10
1.973520
20
3.118560
VERTEX
8
7
6
CONTINUOUS
10
1.981920
20
3.119040
VERTEX
8
7
6
CONTINUOUS
10
1.989600
20
3.119760
VERTEX
8
7
6
CONTINUOUS
10
1.996080
20
3.120720
VERTEX
8
7
6
CONTINUOUS
10
2.001600
20
3.122160
VERTEX
8
7
6
CONTINUOUS
10
2.005920
20
3.124080
VERTEX
8
7
6
CONTINUOUS
10
2.009040
20
3.126480
VERTEX
8
7
6
CONTINUOUS
10
2.011440
20
3.129360
VERTEX
8
7
6
CONTINUOUS
10
2.013120
20
3.132240
VERTEX
8
7
6
CONTINUOUS
10
2.014080
20
3.135120
VERTEX
8
7
6
CONTINUOUS
10
2.015520
20
3.139440
VERTEX
8
7
6
CONTINUOUS
10
2.016240
20
3.143280
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.748160
20
4.117680
VERTEX
8
7
6
CONTINUOUS
10
1.729200
20
4.100400
VERTEX
8
7
6
CONTINUOUS
10
1.719600
20
4.088400
VERTEX
8
7
6
CONTINUOUS
10
1.714080
20
4.075680
VERTEX
8
7
6
CONTINUOUS
10
1.712640
20
4.068960
VERTEX
8
7
6
CONTINUOUS
10
1.712160
20
4.061760
VERTEX
8
7
6
CONTINUOUS
10
1.712640
20
4.054320
VERTEX
8
7
6
CONTINUOUS
10
1.716240
20
4.040400
VERTEX
8
7
6
CONTINUOUS
10
1.722720
20
4.028400
VERTEX
8
7
6
CONTINUOUS
10
1.731360
20
4.018800
VERTEX
8
7
6
CONTINUOUS
10
1.742160
20
4.010640
VERTEX
8
7
6
CONTINUOUS
10
1.755840
20
4.003920
VERTEX
8
7
6
CONTINUOUS
10
1.764480
20
4.001040
VERTEX
8
7
6
CONTINUOUS
10
1.785120
20
3.997200
VERTEX
8
7
6
CONTINUOUS
10
1.809840
20
3.995520
VERTEX
8
7
6
CONTINUOUS
10
1.837920
20
3.996720
VERTEX
8
7
6
CONTINUOUS
10
1.852560
20
3.998640
VERTEX
8
7
6
CONTINUOUS
10
1.881600
20
4.005600
VERTEX
8
7
6
CONTINUOUS
10
1.907040
20
4.014960
VERTEX
8
7
6
CONTINUOUS
10
1.927200
20
4.025280
VERTEX
8
7
6
CONTINUOUS
10
1.943280
20
4.036080
VERTEX
8
7
6
CONTINUOUS
10
1.971600
20
4.058160
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.702560
20
4.080720
VERTEX
8
7
6
CONTINUOUS
10
1.695600
20
4.066560
VERTEX
8
7
6
CONTINUOUS
10
1.690560
20
4.050960
VERTEX
8
7
6
CONTINUOUS
10
1.688880
20
4.033200
VERTEX
8
7
6
CONTINUOUS
10
1.689360
20
4.024560
VERTEX
8
7
6
CONTINUOUS
10
1.690800
20
4.016160
VERTEX
8
7
6
CONTINUOUS
10
1.693200
20
4.008480
VERTEX
8
7
6
CONTINUOUS
10
1.696320
20
4.001760
VERTEX
8
7
6
CONTINUOUS
10
1.704240
20
3.990960
VERTEX
8
7
6
CONTINUOUS
10
1.713840
20
3.983040
VERTEX
8
7
6
CONTINUOUS
10
1.726800
20
3.976800
VERTEX
8
7
6
CONTINUOUS
10
1.803600
20
3.953520
VERTEX
8
7
6
CONTINUOUS
10
1.839120
20
3.940800
VERTEX
8
7
6
CONTINUOUS
10
1.864080
20
3.929760
VERTEX
8
7
6
CONTINUOUS
10
1.896960
20
3.911760
VERTEX
8
7
6
CONTINUOUS
10
1.912080
20
3.900960
VERTEX
8
7
6
CONTINUOUS
10
1.934160
20
3.880080
VERTEX
8
7
6
CONTINUOUS
10
1.955280
20
3.856800
VERTEX
8
7
6
CONTINUOUS
10
1.964880
20
3.844080
VERTEX
8
7
6
CONTINUOUS
10
1.974480
20
3.826800
VERTEX
8
7
6
CONTINUOUS
10
1.995120
20
3.776880
VERTEX
8
7
6
CONTINUOUS
10
2.007600
20
3.740400
VERTEX
8
7
6
CONTINUOUS
10
2.014560
20
3.712800
VERTEX
8
7
6
CONTINUOUS
10
2.018400
20
3.689760
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
2.037360
20
4.014000
VERTEX
8
7
6
CONTINUOUS
10
2.033520
20
3.978480
VERTEX
8
7
6
CONTINUOUS
10
2.032800
20
3.949680
VERTEX
8
7
6
CONTINUOUS
10
2.034720
20
3.928560
VERTEX
8
7
6
CONTINUOUS
10
2.039040
20
3.906240
VERTEX
8
7
6
CONTINUOUS
10
2.046960
20
3.884640
VERTEX
8
7
6
CONTINUOUS
10
2.071680
20
3.834480
VERTEX
8
7
6
CONTINUOUS
10
2.085120
20
3.801120
VERTEX
8
7
6
CONTINUOUS
10
2.090880
20
3.783360
VERTEX
8
7
6
CONTINUOUS
10
2.100000
20
3.745440
VERTEX
8
7
6
CONTINUOUS
10
2.106480
20
3.701760
VERTEX
8
7
6
CONTINUOUS
10
2.115120
20
3.621120
VERTEX
8
7
6
CONTINUOUS
10
2.122320
20
3.536880
VERTEX
8
7
6
CONTINUOUS
10
2.128080
20
3.453360
VERTEX
8
7
6
CONTINUOUS
10
2.135040
20
3.309360
VERTEX
8
7
6
CONTINUOUS
10
2.137680
20
3.214800
VERTEX
8
7
6
CONTINUOUS
10
2.137200
20
3.168240
VERTEX
8
7
6
CONTINUOUS
10
2.134800
20
3.141360
VERTEX
8
7
6
CONTINUOUS
10
2.130480
20
3.118080
VERTEX
8
7
6
CONTINUOUS
10
2.127360
20
3.107280
VERTEX
8
7
6
CONTINUOUS
10
2.123520
20
3.097200
VERTEX
8
7
6
CONTINUOUS
10
2.113920
20
3.078960
VERTEX
8
7
6
CONTINUOUS
10
2.101920
20
3.063360
VERTEX
8
7
6
CONTINUOUS
10
2.088000
20
3.050160
VERTEX
8
7
6
CONTINUOUS
10
2.072880
20
3.039360
VERTEX
8
7
6
CONTINUOUS
10
2.056560
20
3.030720
VERTEX
8
7
6
CONTINUOUS
10
2.039760
20
3.024000
VERTEX
8
7
6
CONTINUOUS
10
2.013840
20
3.017040
VERTEX
8
7
6
CONTINUOUS
10
1.980000
20
3.011040
VERTEX
8
7
6
CONTINUOUS
10
1.920000
20
3.006240
VERTEX
8
7
6
CONTINUOUS
10
1.894800
20
3.004320
VERTEX
8
7
6
CONTINUOUS
10
1.904160
20
3.002640
VERTEX
8
7
6
CONTINUOUS
10
1.980000
20
2.995440
VERTEX
8
7
6
CONTINUOUS
10
2.040000
20
2.987760
VERTEX
8
7
6
CONTINUOUS
10
2.065920
20
2.982720
VERTEX
8
7
6
CONTINUOUS
10
2.088240
20
2.975760
VERTEX
8
7
6
CONTINUOUS
10
2.098320
20
2.971200
VERTEX
8
7
6
CONTINUOUS
10
2.107440
20
2.965920
VERTEX
8
7
6
CONTINUOUS
10
2.115840
20
2.959920
VERTEX
8
7
6
CONTINUOUS
10
2.123520
20
2.952960
VERTEX
8
7
6
CONTINUOUS
10
2.130240
20
2.945040
VERTEX
8
7
6
CONTINUOUS
10
2.141520
20
2.927280
VERTEX
8
7
6
CONTINUOUS
10
2.149920
20
2.907840
VERTEX
8
7
6
CONTINUOUS
10
2.155920
20
2.887440
VERTEX
8
7
6
CONTINUOUS
10
2.159760
20
2.867280
VERTEX
8
7
6
CONTINUOUS
10
2.162640
20
2.838480
VERTEX
8
7
6
CONTINUOUS
10
2.165280
20
2.797680
VERTEX
8
7
6
CONTINUOUS
10
2.168880
20
2.774640
VERTEX
8
7
6
CONTINUOUS
10
2.171520
20
2.766720
VERTEX
8
7
6
CONTINUOUS
10
2.176560
20
2.759760
VERTEX
8
7
6
CONTINUOUS
10
2.182320
20
2.756880
VERTEX
8
7
6
CONTINUOUS
10
2.193360
20
2.756160
VERTEX
8
7
6
CONTINUOUS
10
2.199840
20
2.756880
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.786560
20
3.769680
VERTEX
8
7
6
CONTINUOUS
10
1.794000
20
3.773520
VERTEX
8
7
6
CONTINUOUS
10
1.801440
20
3.777840
VERTEX
8
7
6
CONTINUOUS
10
1.808880
20
3.783120
VERTEX
8
7
6
CONTINUOUS
10
1.812480
20
3.786240
VERTEX
8
7
6
CONTINUOUS
10
1.816320
20
3.789840
VERTEX
8
7
6
CONTINUOUS
10
1.820160
20
3.793680
VERTEX
8
7
6
CONTINUOUS
10
1.824000
20
3.798000
VERTEX
8
7
6
CONTINUOUS
10
1.831920
20
3.807360
VERTEX
8
7
6
CONTINUOUS
10
1.839360
20
3.816720
VERTEX
8
7
6
CONTINUOUS
10
1.846800
20
3.825600
VERTEX
8
7
6
CONTINUOUS
10
1.853760
20
3.833280
VERTEX
8
7
6
CONTINUOUS
10
1.860720
20
3.839760
VERTEX
8
7
6
CONTINUOUS
10
1.867200
20
3.845280
VERTEX
8
7
6
CONTINUOUS
10
1.873440
20
3.850320
VERTEX
8
7
6
CONTINUOUS
10
1.879680
20
3.854640
VERTEX
8
7
6
CONTINUOUS
10
1.885680
20
3.858480
VERTEX
8
7
6
CONTINUOUS
10
1.891680
20
3.862080
VERTEX
8
7
6
CONTINUOUS
10
1.897680
20
3.865440
VERTEX
8
7
6
CONTINUOUS
10
1.903680
20
3.868320
VERTEX
8
7
6
CONTINUOUS
10
1.909440
20
3.870720
VERTEX
8
7
6
CONTINUOUS
10
1.914960
20
3.872880
VERTEX
8
7
6
CONTINUOUS
10
1.920000
20
3.874320
VERTEX
8
7
6
CONTINUOUS
10
1.924560
20
3.875040
VERTEX
8
7
6
CONTINUOUS
10
1.928400
20
3.875520
VERTEX
8
7
6
CONTINUOUS
10
1.931760
20
3.875280
VERTEX
8
7
6
CONTINUOUS
10
1.934880
20
3.874800
VERTEX
8
7
6
CONTINUOUS
10
1.937520
20
3.873840
VERTEX
8
7
6
CONTINUOUS
10
1.940160
20
3.872400
VERTEX
8
7
6
CONTINUOUS
10
1.944960
20
3.869040
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.794720
20
4.065120
VERTEX
8
7
6
CONTINUOUS
10
1.786800
20
4.064880
VERTEX
8
7
6
CONTINUOUS
10
1.778640
20
4.062480
VERTEX
8
7
6
CONTINUOUS
10
1.771680
20
4.056960
VERTEX
8
7
6
CONTINUOUS
10
1.769760
20
4.053600
VERTEX
8
7
6
CONTINUOUS
10
1.769040
20
4.046160
VERTEX
8
7
6
CONTINUOUS
10
1.771200
20
4.039440
VERTEX
8
7
6
CONTINUOUS
10
1.778880
20
4.031760
VERTEX
8
7
6
CONTINUOUS
10
1.785120
20
4.028400
VERTEX
8
7
6
CONTINUOUS
10
1.800960
20
4.024560
VERTEX
8
7
6
CONTINUOUS
10
1.813920
20
4.023600
VERTEX
8
7
6
CONTINUOUS
10
1.829760
20
4.025040
VERTEX
8
7
6
CONTINUOUS
10
1.838400
20
4.027680
VERTEX
8
7
6
CONTINUOUS
10
1.841520
20
4.029600
VERTEX
8
7
6
CONTINUOUS
10
1.844880
20
4.034640
VERTEX
8
7
6
CONTINUOUS
10
1.845840
20
4.040880
VERTEX
8
7
6
CONTINUOUS
10
1.844640
20
4.046880
VERTEX
8
7
6
CONTINUOUS
10
1.839360
20
4.054080
VERTEX
8
7
6
CONTINUOUS
10
1.834080
20
4.058160
VERTEX
8
7
6
CONTINUOUS
10
1.829040
20
4.060560
VERTEX
8
7
6
CONTINUOUS
10
1.823520
20
4.062000
SEQEND
8
SOLID
8
15
10
1.794720
20
4.127760
11
1.844880
21
4.125600
12
1.794720
22
4.112400
13
1.844880
23
4.110240
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.794720
20
4.127760
VERTEX
8
7
6
CONTINUOUS
10
1.844880
20
4.125600
VERTEX
8
7
6
CONTINUOUS
10
1.844880
20
4.110240
VERTEX
8
7
6
CONTINUOUS
10
1.794720
20
4.112400
VERTEX
8
7
6
CONTINUOUS
10
1.794720
20
4.127760
SEQEND
8
SOLID
8
15
10
1.794720
20
4.042560
11
1.794720
21
4.112400
12
1.815600
22
4.041360
13
1.844880
23
4.110240
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.794720
20
4.042560
VERTEX
8
7
6
CONTINUOUS
10
1.794720
20
4.112400
VERTEX
8
7
6
CONTINUOUS
10
1.844880
20
4.110240
VERTEX
8
7
6
CONTINUOUS
10
1.815600
20
4.041360
VERTEX
8
7
6
CONTINUOUS
10
1.794720
20
4.042560
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
2.189520
20
4.124640
VERTEX
8
7
6
CONTINUOUS
10
2.150880
20
4.091760
VERTEX
8
7
6
CONTINUOUS
10
2.151840
20
4.079040
VERTEX
8
7
6
CONTINUOUS
10
2.155680
20
4.070880
VERTEX
8
7
6
CONTINUOUS
10
2.160000
20
4.062960
VERTEX
8
7
6
CONTINUOUS
10
2.165520
20
4.055760
VERTEX
8
7
6
CONTINUOUS
10
2.168400
20
4.052640
VERTEX
8
7
6
CONTINUOUS
10
2.171280
20
4.050000
VERTEX
8
7
6
CONTINUOUS
10
2.173920
20
4.047600
VERTEX
8
7
6
CONTINUOUS
10
2.176320
20
4.045440
VERTEX
8
7
6
CONTINUOUS
10
2.181120
20
4.041840
VERTEX
8
7
6
CONTINUOUS
10
2.186880
20
4.038240
VERTEX
8
7
6
CONTINUOUS
10
2.193120
20
4.034640
VERTEX
8
7
6
CONTINUOUS
10
2.196480
20
4.032960
VERTEX
8
7
6
CONTINUOUS
10
2.200320
20
4.032240
VERTEX
8
7
6
CONTINUOUS
10
2.202480
20
4.032480
VERTEX
8
7
6
CONTINUOUS
10
2.204880
20
4.032960
VERTEX
8
7
6
CONTINUOUS
10
2.207760
20
4.033920
VERTEX
8
7
6
CONTINUOUS
10
2.210880
20
4.035600
VERTEX
8
7
6
CONTINUOUS
10
2.214480
20
4.037760
VERTEX
8
7
6
CONTINUOUS
10
2.218320
20
4.040640
VERTEX
8
7
6
CONTINUOUS
10
2.222400
20
4.043760
VERTEX
8
7
6
CONTINUOUS
10
2.226960
20
4.047360
VERTEX
8
7
6
CONTINUOUS
10
2.236320
20
4.055760
VERTEX
8
7
6
CONTINUOUS
10
2.246160
20
4.064400
VERTEX
8
7
6
CONTINUOUS
10
2.189520
20
4.124640
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
1.926240
20
4.182720
VERTEX
8
7
6
CONTINUOUS
10
1.938000
20
4.201440
VERTEX
8
7
6
CONTINUOUS
10
1.943760
20
4.207440
VERTEX
8
7
6
CONTINUOUS
10
1.958160
20
4.218240
VERTEX
8
7
6
CONTINUOUS
10
1.964880
20
4.221600
VERTEX
8
7
6
CONTINUOUS
10
1.979040
20
4.225440
VERTEX
8
7
6
CONTINUOUS
10
1.994640
20
4.226640
VERTEX
8
7
6
CONTINUOUS
10
2.001360
20
4.226880
VERTEX
8
7
6
CONTINUOUS
10
2.026800
20
4.224960
VERTEX
8
7
6
CONTINUOUS
10
2.050320
20
4.219200
VERTEX
8
7
6
CONTINUOUS
10
2.063040
20
4.213920
VERTEX
8
7
6
CONTINUOUS
10
2.079360
20
4.204320
VERTEX
8
7
6
CONTINUOUS
10
2.102400
20
4.186560
VERTEX
8
7
6
CONTINUOUS
10
2.125920
20
4.159680
VERTEX
8
7
6
CONTINUOUS
10
2.138880
20
4.137360
VERTEX
8
7
6
CONTINUOUS
10
2.149440
20
4.114800
VERTEX
8
7
6
CONTINUOUS
10
2.151840
20
4.104240
VERTEX
8
7
6
CONTINUOUS
10
2.153040
20
4.090800
VERTEX
8
7
6
CONTINUOUS
10
2.152560
20
4.073760
VERTEX
8
7
6
CONTINUOUS
10
2.150880
20
4.062240
VERTEX
8
7
6
CONTINUOUS
10
2.145600
20
4.047840
VERTEX
8
7
6
CONTINUOUS
10
2.135520
20
4.034160
VERTEX
8
7
6
CONTINUOUS
10
2.123520
20
4.021680
VERTEX
8
7
6
CONTINUOUS
10
2.115360
20
4.015680
VERTEX
8
7
6
CONTINUOUS
10
2.105760
20
4.011360
VERTEX
8
7
6
CONTINUOUS
10
2.094000
20
4.009440
VERTEX
8
7
6
CONTINUOUS
10
2.078880
20
4.008720
VERTEX
8
7
6
CONTINUOUS
10
2.061360
20
4.009920
VERTEX
8
7
6
CONTINUOUS
10
2.044080
20
4.012560
VERTEX
8
7
6
CONTINUOUS
10
2.027520
20
4.017360
VERTEX
8
7
6
CONTINUOUS
10
2.010960
20
4.026000
VERTEX
8
7
6
CONTINUOUS
10
1.994400
20
4.037760
VERTEX
8
7
6
CONTINUOUS
10
1.972560
20
4.056480
VERTEX
8
7
6
CONTINUOUS
10
1.955760
20
4.075200
VERTEX
8
7
6
CONTINUOUS
10
1.946880
20
4.087680
VERTEX
8
7
6
CONTINUOUS
10
1.936080
20
4.106880
VERTEX
8
7
6
CONTINUOUS
10
1.928400
20
4.126080
VERTEX
8
7
6
CONTINUOUS
10
1.923840
20
4.144080
VERTEX
8
7
6
CONTINUOUS
10
1.922160
20
4.160400
VERTEX
8
7
6
CONTINUOUS
10
1.923120
20
4.170000
VERTEX
8
7
6
CONTINUOUS
10
1.926240
20
4.182720
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
2.081280
20
4.176240
VERTEX
8
7
6
CONTINUOUS
10
2.072160
20
4.171440
VERTEX
8
7
6
CONTINUOUS
10
2.067360
20
4.169520
VERTEX
8
7
6
CONTINUOUS
10
2.062080
20
4.167600
VERTEX
8
7
6
CONTINUOUS
10
2.056560
20
4.165920
VERTEX
8
7
6
CONTINUOUS
10
2.050320
20
4.164720
VERTEX
8
7
6
CONTINUOUS
10
2.043840
20
4.164000
VERTEX
8
7
6
CONTINUOUS
10
2.036880
20
4.163520
VERTEX
8
7
6
CONTINUOUS
10
2.029440
20
4.163040
VERTEX
8
7
6
CONTINUOUS
10
2.012640
20
4.163040
VERTEX
8
7
6
CONTINUOUS
10
2.003280
20
4.163280
VERTEX
8
7
6
CONTINUOUS
10
1.993200
20
4.163520
VERTEX
8
7
6
CONTINUOUS
10
1.982640
20
4.164000
VERTEX
8
7
6
CONTINUOUS
10
1.961040
20
4.165680
VERTEX
8
7
6
CONTINUOUS
10
1.950960
20
4.166640
VERTEX
8
7
6
CONTINUOUS
10
1.941360
20
4.167840
VERTEX
8
7
6
CONTINUOUS
10
1.923120
20
4.170720
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
2.092800
20
4.164960
VERTEX
8
7
6
CONTINUOUS
10
2.089680
20
4.149360
VERTEX
8
7
6
CONTINUOUS
10
2.088960
20
4.141200
VERTEX
8
7
6
CONTINUOUS
10
2.088720
20
4.136880
VERTEX
8
7
6
CONTINUOUS
10
2.088720
20
4.131840
VERTEX
8
7
6
CONTINUOUS
10
2.088960
20
4.126320
VERTEX
8
7
6
CONTINUOUS
10
2.089680
20
4.120320
VERTEX
8
7
6
CONTINUOUS
10
2.090640
20
4.113840
VERTEX
8
7
6
CONTINUOUS
10
2.092080
20
4.106640
VERTEX
8
7
6
CONTINUOUS
10
2.093760
20
4.098960
VERTEX
8
7
6
CONTINUOUS
10
2.095920
20
4.090800
VERTEX
8
7
6
CONTINUOUS
10
2.100720
20
4.074480
VERTEX
8
7
6
CONTINUOUS
10
2.103360
20
4.066800
VERTEX
8
7
6
CONTINUOUS
10
2.106240
20
4.059360
VERTEX
8
7
6
CONTINUOUS
10
2.109120
20
4.052400
VERTEX
8
7
6
CONTINUOUS
10
2.112240
20
4.046160
VERTEX
8
7
6
CONTINUOUS
10
2.115600
20
4.040400
VERTEX
8
7
6
CONTINUOUS
10
2.119440
20
4.035120
VERTEX
8
7
6
CONTINUOUS
10
2.123280
20
4.030080
VERTEX
8
7
6
CONTINUOUS
10
2.127120
20
4.025280
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
2.085600
20
4.170000
VERTEX
8
7
6
CONTINUOUS
10
2.079120
20
4.163040
VERTEX
8
7
6
CONTINUOUS
10
2.072160
20
4.156080
VERTEX
8
7
6
CONTINUOUS
10
2.064960
20
4.149360
VERTEX
8
7
6
CONTINUOUS
10
2.060640
20
4.146240
VERTEX
8
7
6
CONTINUOUS
10
2.055840
20
4.142880
VERTEX
8
7
6
CONTINUOUS
10
2.050320
20
4.139520
VERTEX
8
7
6
CONTINUOUS
10
2.044080
20
4.136160
VERTEX
8
7
6
CONTINUOUS
10
2.036880
20
4.132800
VERTEX
8
7
6
CONTINUOUS
10
2.028720
20
4.129440
VERTEX
8
7
6
CONTINUOUS
10
2.019840
20
4.126080
VERTEX
8
7
6
CONTINUOUS
10
2.010240
20
4.122960
VERTEX
8
7
6
CONTINUOUS
10
2.000400
20
4.120080
VERTEX
8
7
6
CONTINUOUS
10
1.990560
20
4.117440
VERTEX
8
7
6
CONTINUOUS
10
1.980960
20
4.115280
VERTEX
8
7
6
CONTINUOUS
10
1.972080
20
4.113360
VERTEX
8
7
6
CONTINUOUS
10
1.963920
20
4.111920
VERTEX
8
7
6
CONTINUOUS
10
1.956480
20
4.110960
VERTEX
8
7
6
CONTINUOUS
10
1.950240
20
4.110240
VERTEX
8
7
6
CONTINUOUS
10
1.944720
20
4.109520
VERTEX
8
7
6
CONTINUOUS
10
1.935120
20
4.108800
SEQEND
8
POLYLINE
8
7
6
CONTINUOUS
66
0.000000
41
0.000000
VERTEX
8
7
6
CONTINUOUS
10
2.089680
20
4.166640
VERTEX
8
7
6
CONTINUOUS
10
2.082480
20
4.155120
VERTEX
8
7
6
CONTINUOUS
10
2.076000
20
4.143120
VERTEX
8
7
6
CONTINUOUS
10
2.070240
20
4.130400
VERTEX
8
7
6
CONTINUOUS
10
2.065200
20
4.117920
VERTEX
8
7
6
CONTINUOUS
10
2.062800
20
4.111680
VERTEX
8
7
6
CONTINUOUS
10
2.060640
20
