RV8-Archive.digest.vol-ab
December 25, 2000 - January 21, 2002
      > If so, what is the best way to hold the bellcrank in the neutral position?
      > The plans call a 2 1/2 in.
      > dimension from the spar web to the center of the rod end bearing
      > bolt hole.
      > I've got my wing upside down in a holder like you use for the fuel tanks.
      > As an alternate to the airfoil template, wouldn't tapeing some 1 by 2's to
      > the wing that extends over the trailing edge so as to conform to the shape
      > of the wing, work as well or better for fairing the aileron as the airfoil
      > template?
      > The AN3 bolts that fit the various powder coated brackets is a very tight
      > fit, if they fit at all. Can I   ream the brackets with a 3/16 reamer?
      > The brass bushing for the aileron bellcrank is to small for the AN4 bolt,
      > is reaming  with a 1/4 in. reamer using a drill press the best option?
      > Thanks
      > Dean
      >  RV-8A QB Wings
From: "Larry Dysinger" <larrykdysinger(at)hotmail.com>
Subject: Re: Aileron fitting RV8 QB
Date: Dec 25, 2000
Dean, Yes, you will need to ream these parts to allow the bolts to go thru the bellcrank holes and the brass bushing. I have temporarily mounted the aileron to my left wing and then went to mount the flap, only to find that the flap was about .25 inches shorter than the aileron. Called up Van's and they are sending me a wider piano hinge. Interestingly enough, everything is the size identified in the drawings, and still it is off. The use of the 1x2's could certainly work. Larry RV8-QB 81251 Left Wing From: Dean <dweb5(at)adams.net> Subject: RV8-List: Aileron fitting RV8 QB Date: Mon, 25 Dec 2000 01:46:03 -0600 I'm working on the wing of an RV-8A -QB, getting ready to fit the aileron and the flap. The aileron spar is already predrilled #30 holes for the attach brackets. The brackets are predrilled. The hinges are predrilled to the spar. So the fitting of the aileron to the wing in the case of the QB kit is just trying to trail the aileron to the wing using the adjustment on the push rod with the bellcrank in the neutral position. Then you fit the flap to the aileron. Is this correct? If so, what is the best way to hold the bellcrank in the neutral position? The plans call a 2 1/2 in. dimension from the spar web to the center of the rod end bearing bolt hole. I've got my wing upside down in a holder like you use for the fuel tanks. As an alternate to the airfoil template, wouldn't tapeing some 1 by 2's to the wing that extends over the trailing edge so as to conform to the shape of the wing, work as well or better for fairing the aileron as the airfoil template? The AN3 bolts that fit the various powder coated brackets is a very tight fit, if they fit at all. Can I ream the brackets with a 3/16 reamer? The brass bushing for the aileron bellcrank is to small for the AN4 bolt, is reaming with a 1/4 in. reamer using a drill press the best option? Thanks Dean RV-8A QB Wings Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Dec 25, 2000
Larry, Same here about the flap hinge. Everything measured great, and the flap was short. I ordered a wider hinge and added the wide half to the hinge already attached to the flap. Worked out perfect. I have heard this from almost everyone...maybe Van's needs to add the wider hinge...wouldn't hurt. Good luck Dan > >Dean, > >Yes, you will need to ream these parts to allow the bolts to go thru the >bellcrank holes and the brass bushing. > >I have temporarily mounted the aileron to my left wing and then went to >mount the flap, only to find that the flap was about .25 inches shorter than >the aileron. > >Called up Van's and they are sending me a wider piano hinge. > >Interestingly enough, everything is the size identified in the drawings, and >still it is off. > >The use of the 1x2's could certainly work. > >Larry >RV8-QB 81251 Left Wing > > >From: Dean <dweb5(at)adams.net> >To: rv8-list(at)matronics.com >Subject: RV8-List: Aileron fitting RV8 QB >Date: Mon, 25 Dec 2000 01:46:03 -0600 > > >I'm working on the wing of an RV-8A -QB, getting ready to fit the aileron >and the flap. >The aileron spar is already predrilled #30 holes for the attach brackets. >The brackets are predrilled. >The hinges are predrilled to the spar. So the fitting of the aileron to >the wing in the case of the QB kit >is just trying to trail the aileron to the wing using the adjustment on >the push rod with the bellcrank in the neutral position. Then you fit the >flap to the aileron. Is this correct? > >If so, what is the best way to hold the bellcrank in the neutral position? >The plans call a 2 1/2 in. >dimension from the spar web to the center of the rod end bearing bolt hole. > >I've got my wing upside down in a holder like you use for the fuel tanks. >As an alternate to the airfoil template, wouldn't tapeing some 1 by 2's to >the wing that extends over the trailing edge so as to conform to the shape >of the wing, work as well or better for fairing the aileron as the airfoil >template? > > >The AN3 bolts that fit the various powder coated brackets is a very tight >fit, if they fit at all. Can I ream the brackets with a 3/16 reamer? >The brass bushing for the aileron bellcrank is to small for the AN4 bolt, >is reaming with a 1/4 in. reamer using a drill press the best option? > > >Thanks >Dean > RV-8A QB Wings > > >Get your FREE download of MSN Explorer at http://explorer.msn.com > > ________________________________________________________________________________
Date: Dec 25, 2000
Dan, I agree, but I did not get that impressoin from my convresation with them. Larry RV-8QB 81251 From: TwoAviators <TwoAviators(at)lexcominc.net> Subject: Re: RV8-List: Aileron fitting RV8 QB Date: Mon, 25 Dec 2000 11:40:13 -0500 Larry, Same here about the flap hinge. Everything measured great, and the flap was short. I ordered a wider hinge and added the wide half to the hinge already attached to the flap. Worked out perfect. I have heard this from almost everyone...maybe Van's needs to add the wider hinge...wouldn't hurt. Good luck Dan > >Dean, > >Yes, you will need to ream these parts to allow the bolts to go thru the >bellcrank holes and the brass bushing. > >I have temporarily mounted the aileron to my left wing and then went to >mount the flap, only to find that the flap was about .25 inches shorter than >the aileron. > >Called up Van's and they are sending me a wider piano hinge. > >Interestingly enough, everything is the size identified in the drawings, and >still it is off. > >The use of the 1x2's could certainly work. > >Larry >RV8-QB 81251 Left Wing > > >From: Dean <dweb5(at)adams.net> >To: rv8-list(at)matronics.com >Subject: RV8-List: Aileron fitting RV8 QB >Date: Mon, 25 Dec 2000 01:46:03 -0600 > > >I'm working on the wing of an RV-8A -QB, getting ready to fit the aileron >and the flap. >The aileron spar is already predrilled #30 holes for the attach brackets. >The brackets are predrilled. >The hinges are predrilled to the spar. So the fitting of the aileron to >the wing in the case of the QB kit >is just trying to trail the aileron to the wing using the adjustment on >the push rod with the bellcrank in the neutral position. Then you fit the >flap to the aileron. Is this correct? > >If so, what is the best way to hold the bellcrank in the neutral position? >The plans call a 2 1/2 in. >dimension from the spar web to the center of the rod end bearing bolt hole. > >I've got my wing upside down in a holder like you use for the fuel tanks. >As an alternate to the airfoil template, wouldn't tapeing some 1 by 2's to >the wing that extends over the trailing edge so as to conform to the shape >of the wing, work as well or better for fairing the aileron as the airfoil >template? > > >The AN3 bolts that fit the various powder coated brackets is a very tight >fit, if they fit at all. Can I ream the brackets with a 3/16 reamer? >The brass bushing for the aileron bellcrank is to small for the AN4 bolt, >is reaming with a 1/4 in. reamer using a drill press the best option? > > >Thanks >Dean > RV-8A QB Wings > > >Get your FREE download of MSN Explorer at http://explorer.msn.com > > Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Dec 25, 2000
Dean, Yes, I found the pre-drilled holes were dead on in my SB-8. So just use them and done bother with anything else. The best way to have the bellcrank in the right position is to make up a temporary L bracket with a hole in it 2.5 inches from the corner. Just cleco that to the main spar (little hole wont hurt) and the bellcrank bolt goes into the hole you made. It holds the pushrod in place. The brackets are powder coated, so you have to ream (or drill) the hole out again to fit the bolt. And yes, the bushing does need to be reamed or drilled 1/4 inch. Remeber that the bold does not rotate in the brass bushing. Instead the brass bushing is captured firmly by the "ears" and the bolt being torqued up, and rotates in the weldment. Gordon Robertson SB-8, second wing. Dean wrote: > > I'm working on the wing of an RV-8A -QB, getting ready to fit the aileron > and the flap. > The aileron spar is already predrilled #30 holes for the attach brackets. > The brackets are predrilled. > The hinges are predrilled to the spar. So the fitting of the aileron to > the wing in the case of the QB kit > is just trying to trail the aileron to the wing using the adjustment on > the push rod with the bellcrank in the neutral position. Then you fit the > flap to the aileron. Is this correct? > > If so, what is the best way to hold the bellcrank in the neutral position? > The plans call a 2 1/2 in. > dimension from the spar web to the center of the rod end bearing bolt hole. > > I've got my wing upside down in a holder like you use for the fuel tanks. > As an alternate to the airfoil template, wouldn't tapeing some 1 by 2's to > the wing that extends over the trailing edge so as to conform to the shape > of the wing, work as well or better for fairing the aileron as the airfoil > template? > > The AN3 bolts that fit the various powder coated brackets is a very tight > fit, if they fit at all. Can I ream the brackets with a 3/16 reamer? > The brass bushing for the aileron bellcrank is to small for the AN4 bolt, > is reaming with a 1/4 in. reamer using a drill press the best option? > > Thanks > Dean > RV-8A QB Wings > ________________________________________________________________________________
Subject: Aileron fitting RV8 QB
Date: Dec 25, 2000
Do you lubricate this in any way? I also noticed that theere will be bare steel where the brass bushing is rotating. What will prevent this from rusting? I bought a 1/4" reamer and had no problems fitting the bushing and bolt. Not sure if I need any lubricants/primer in any of these areas though. Are RV-8 Wings The brackets are powder coated, so you have to ream (or drill) the hole out again to fit the bolt. And yes, the bushing does need to be reamed or drilled 1/4 inch. Remeber that the bold does not rotate in the brass bushing. Instead the brass bushing is captured firmly by the "ears" and the bolt being torqued up, and rotates in the weldment. Gordon Robertson SB-8, second wing. ________________________________________________________________________________
Date: Dec 25, 2000
> > Do you lubricate this in any way? I also noticed that theere will be bare > steel where the brass bushing is rotating. What will prevent this from > rusting? I coated the inside of it with grease. That should reduce the friction and the rust, but I also wondered about it. Terry RV-8A fuselage ________________________________________________________________________________
Date: Dec 25, 2000
> I'm working on the wing of an RV-8A -QB, getting ready to fit the aileron > and the flap. > The aileron spar is already predrilled #30 holes for the attach brackets. > The brackets are predrilled. > The hinges are predrilled to the spar. So the fitting of the aileron to > the wing in the case of the QB kit > is just trying to trail the aileron to the wing using the adjustment on > the push rod with the bellcrank in the neutral position. Then you fit the > flap to the aileron. Is this correct? > > If so, what is the best way to hold the bellcrank in the neutral position? > The plans call a 2 1/2 in. > dimension from the spar web to the center of the rod end bearing bolt hole. > > I've got my wing upside down in a holder like you use for the fuel tanks. > As an alternate to the airfoil template, wouldn't tapeing some 1 by 2's to > the wing that extends over the trailing edge so as to conform to the shape > of the wing, work as well or better for fairing the aileron as the airfoil > template? > > > The AN3 bolts that fit the various powder coated brackets is a very tight > fit, if they fit at all. Can I ream the brackets with a 3/16 reamer? > The brass bushing for the aileron bellcrank is to small for the AN4 bolt, > is reaming with a 1/4 in. reamer using a drill press the best option? Dean, Yes, use the aileron for the reference, but the method I prefer, and that I think is more accurate, is using the tooling holes in the end wing rib to line up with the tooling holes in the end aileron rib. Tom Green gave me this tip and says it's the most accurate method. I posted a Builder's Tip on my web site about this as follows... "When you are mounting your wings you will need to align four things on each wing: the aileron, the wing tip, the flap, and the flap fairing. You will immediately wonder what to use as a reference, and it doesn't tell you in the manual. Here's the trick: align the aileron with the outboard wing ribs by centering the tooling holes in both wing ribs and the aileron rib. You will need a 5' straightedge to do this. Then duct tape the aileron in place and line up the flap to match. Working your way inboard you can then install the flap fairing correctly so the flap fits into it perfectly when fully retracted. Keeping the aileron in place with the duct tape then fit the trailing edge of the wing tip, which has quite a bit of adjustment possible with it, to the trailing edge of the aileron. Voila, you now have the entire trailing edge aligned exactly where it's supposed to be." Worked for me, Randy Lervold RV-8, #80500, painting the fuselage tomorrow. www.rv-8.com ________________________________________________________________________________
Date: Dec 26, 2000
Are I just used a spot of grease. Regular auto grease, although I suppose that some purists may say that Lithium grease or some such is best. But it will not rust with the constant movement, and brass is self lubricating to an extent, so don't prime. An Oilite bushing, instead of brass, would have been better in my opinion, since it is impregnated with oil. But brass is fine. Not much load there. Are Barstad wrote: > > Do you lubricate this in any way? I also noticed that theere will be bare > steel where the brass bushing is rotating. What will prevent this from > rusting? > > I bought a 1/4" reamer and had no problems fitting the bushing and bolt. Not > sure if I need any lubricants/primer in any of these areas though. > > Are > RV-8 Wings > > > The brackets are powder coated, so you have to ream (or drill) the hole out > again to fit the bolt. And yes, the bushing does need to be reamed or > drilled > 1/4 inch. Remeber that the bold does not rotate in the brass bushing. > Instead > the brass bushing is captured firmly by the "ears" and the bolt being > torqued > up, and rotates in the weldment. > > Gordon Robertson > SB-8, second wing. > ________________________________________________________________________________
Date: Dec 27, 2000
Subject: Flap Brace ,Bottom Skins and Lap joints
More questions Where the bottom skins over lap to make the Lap Joint and the flap brace attaches to those skins. Do I need to make a butt joint at the point where the skins overlap and the flap brace joins them, like the joint made in the top skins? Also does everyone pre-bend the skin edges on lap and butt joints to prevent skin curling while riveting. Does it make a difference. Seems to me it might look worse if the pre-bend was bent to much. Thanks Dean ________________________________________________________________________________
Date: Dec 28, 2000
Subject: Re: Flap Brace ,Bottom Skins and Lap joints
Dean, No, the top is critical because of the flap skin which touches the flap itself, so must be smooth. But the bottom has no such restriction. My principle is KISS (Keep it simple, stupid!) I did pre-bend the skins before riveting. It does stop curling, but I have no experience with the curled variety so I dont know if it helps. There is a slight line left where the roller type bender creased the skin, but the riveting pulls it down flush and paint will cover it. TIP: Bend the skin before dimpling the holes! Gordon Dean wrote: > > More questions > > Where the bottom skins over lap to make the Lap Joint and the flap brace > attaches to those skins. > Do I need to make a butt joint at the point where the skins overlap and the > flap brace joins them, like the joint made in the top skins? Also does > everyone pre-bend the skin edges on lap and butt joints to prevent skin > curling while riveting. Does it make a difference. Seems to me it might > look worse if the pre-bend was bent to much. > > Thanks > Dean > ________________________________________________________________________________
Subject: Re: RV8-List Digest: 1 Msgs - 12/28/00
Date: Dec 29, 2000
Is there any RV8's in the Los Angeles area. I have watched two so far one 6 and another 6A. Would love to see an 8. ________________________________________________________________________________
From: "Sally and George" <aeronut58(at)hotmail.com>
Subject: Sigma Tek Attitude Indicator Connections
Date: Dec 29, 2000
I've got a Sigma Tek Model 5000B attitude indicator in my panel. There are 1/4" NPT connections for vacuuma and for filtered air and a 1/8" NPT connection for the vacuum gage. There's also another 1/4" NPT connection that is unidentified. Anybody have an idea what that could be for? George Kilishek N888GK (reserved) Endless firewall forward Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Dec 31, 2000
Subject: flap motor interfers?
All, 1. Flap motor interfers with F-876ppL side panel about a half inch. Any one had this problem? Thoughts? 2. Ground adjustable rudder peddles, what keeps them from just falling backwards when not in use? 3. Anyone have any general routing thoughts for the manual elevator trim cable? Thanks to all, and Happy New Year!!! Dan -8 Fuselage TwoAviators(at)lexcominc.net ________________________________________________________________________________
Subject: Re: flap motor interfers?
Date: Dec 31, 2000
> 1. Flap motor interfers with F-876ppL side panel about a half inch. Any one > had this problem? Thoughts? You need to make the hole larger. Watch the shaft through it's travel and make the sure the hole accomodates it. > 2. Ground adjustable rudder peddles, what keeps them from just falling > backwards when not in use? The master cylinders. > 3. Anyone have any general routing thoughts for the manual elevator trim > cable? The plans call for it to behind the throttle quadrant. Mine wouldn't fit so I altered the path to go below the throttle quadrant and then arc up under the canopy rail. Randy Lervold RV-8, #80500, painting www.rv-8.com Home Wing VAF ________________________________________________________________________________
Date: Dec 31, 2000
Dan, 1. If you are talking about the horizontal side panel then I had the same problem and elongated the hole to make it fit. Or if you haven't installed the upper mount yet for the actuator then you could slide that up or down as necessary to make it clear. The actuator has plenty of travel so some moving around is ok. 2. The rudder cables, or if you mean back towards the pilot then it is the pilot's feet. 3. Can't help you as I have electronic trim tabs Mike Robertson RV-8A N809RS >From: TwoAviators <TwoAviators(at)lexcominc.net> >Reply-To: rv8-list(at)matronics.com >To: rv8-list(at)matronics.com >Subject: RV8-List: flap motor interfers? >Date: Sun, 31 Dec 2000 16:33:30 -0500 > > >All, > >1. Flap motor interfers with F-876ppL side panel about a half inch. Any one >had this problem? Thoughts? > >2. Ground adjustable rudder peddles, what keeps them from just falling >backwards when not in use? > >3. Anyone have any general routing thoughts for the manual elevator trim >cable? > >Thanks to all, and Happy New Year!!! > >Dan >-8 Fuselage >TwoAviators(at)lexcominc.net > > Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Jan 01, 2001
Dan: 1. Flap motor interfers with F-876ppL side panel about a half inch. Any one had this problem? Thoughts? ====Don't see how it can, if installed per drawing. Suggest rechecking bearing locations and orientation of motor per drawings. 2. Ground adjustable rudder peddles, what keeps them from just falling backwards when not in use? ====Rudder cables in one direction and brake cylinders in the other direction. 3. Anyone have any general routing thoughts for the manual elevator trim cable? ==== I used the holes shown on the drawings (don't have drawings inside with me now, but it's the sheet that shows full size drawings of each bulkhead). Trim cable locations are called out and they work well. One caution: if you're planning to put in a rear seat throttle quadrant, that location is very close to the specified trim cable location...be accurate. George Kilishek N888GK (reserved) Firewall forward ________________________________________________________________________________
Subject: Web site update
Date: Jan 01, 2001
For those interested, I have posted several updates to my web site... www.rv-8.com. Updates include... -A trick solution for your emergency com antenna on the 'Products & ideas' page http://www.rv-8.com/pgIdeasProducts.htm -Pics of my compliance with the fuel tank pickup service notice. http://www.rv-8.com/pgWings.htm -My cowling is now 99% done. http://www.rv-8.com/pgPlenumCowl.htm -An update on the painting, see the 'Painting page http://www.rv-8.com/pgPainting.htm Happy New Year! Randy Lervold RV-8, #80500, painting www.rv-8.com Home Wing VAF ________________________________________________________________________________
Subject: Wing jigging and outboard rib
Date: Jan 07, 2001
I'm about to jig my wings. In the manual it says to rivet all ribs except 2 outboard root ribs. This is fine since it will be the only way to get at rivets. But... The outboard rib that fastens to the jig. I riveted it to the rear spar only since the drawings tells me that the same rivets are used for the main rib as the leading edge rib. Hence, I understand that you can only cleco on the forward flange of the outboard main rib and then attach it to the jig. Is this right? Even the Orndorf videos doesn't say to omit these rivets until you rivet on the leading edge. Thanks, Are RV-8 Wings ________________________________________________________________________________
Subject: Re: Wing jigging and outboard rib
Date: Jan 07, 2001
Are, I clecoed the forward edge flange of the outboard rib to the main spar and mounted the skeleton in the jig. It remained this way until it was time to rivet the leading edge on. Works fine, no problem. Vince Welch RV-8A Fuselage Roaming Shores, Ohio ----- Original Message ----- From: "Are Barstad" <abarstad(at)bconnex.net> Sent: Sunday, January 07, 2001 12:20 PM Subject: RV8-List: Wing jigging and outboard rib > > I'm about to jig my wings. In the manual it says to rivet all ribs except 2 > outboard root ribs. This is fine since it will be the only way to get at > rivets. > > But... The outboard rib that fastens to the jig. I riveted it to the rear > spar only since the drawings tells me that the same rivets are used for the > main rib as the leading edge rib. Hence, I understand that you can only > cleco on the forward flange of the outboard main rib and then attach it to > the jig. > > Is this right? Even the Orndorf videos doesn't say to omit these rivets > until you rivet on the leading edge. > > Thanks, > Are > RV-8 Wings > > ________________________________________________________________________________
Subject: Re: RV8-List Digest: 0 Msgs - 01/06/01
Date: Jan 07, 2001
Ed: You wrote: >>I have planned our RV-8 panel for the Garmin 430 GPS with Glide >slope,Garmin327 TRXPDNR, and the Garmin 340 AUDIO PNL. > Question... Can I install this equipment myself or is it best to have >an >avionics shop do it? I have no experience with avionics and am a first >time >builder. You can install these radios yourself, but it is no small job, and the price of a mistake can be high. Vans will sell you radios which they pre-wire and test in their lab for about the same price (maybe a little less) than uninstalled prices from radio shops. Your installation then consists of mechanical mounting and connecting ground, +12V, encoder cable connection and antennas. I know that Vans does this for King radios...don't know if they offer Garmin or not. If you decide to have an avionics shop do it, I'd suggest having it done before rivetting the forward turtle deck and windscreen in place. Also, whether your or somebody else installs the radios, cut a LARGE hole (all the way across) in the baggage compartment bulkhead to provide access to radios and instruments. You can close the hole with a removeable panel. George Kilishek N888GK (reserved) Firewall forward Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Jan 07, 2001
Subject: Fuel vent tube
Date: Jan 15, 2001
Listers, I'm trying to finish up my fuel vent system and now have it plumbed to where it goes through the gear tower floor in my RV-8. I can't find anything in the plans or manual regarding what sort of length or shape extends below the gear access cover. I'm assuming that you fab an aluminum tube and penetrate the gear access cover with a rubber grommet. Do you bend it forward or leave it straight with a slash cut? How far should it protrude? Is this specified somewhere in the manual or plans and I'm blind? Thanks, Randy Lervold RV-8, #80500, N558RL, final plumbing & wiring www.rv-8.com Home Wing VAF ________________________________________________________________________________
Subject: Re: Fuel vent tube
Date: Jan 15, 2001
Randy: I used an AN fitting in the floor of the gear towers. Don't have the drawings handy, but I think it was an AN815 union. You have to search hard for it, but it is shown on one of the drawings of the gear box...can't remember which one. Keep plugging...you're getting to the fun part now. George Kilishek N888GK (reserved) Firewall forward forever ----- Original Message ----- From: Randy Lervold Sent: Monday, January 15, 2001 6:18 PM Subject: RV8-List: Fuel vent tube Listers, I'm trying to finish up my fuel vent system and now have it plumbed to where it goes through the gear tower floor in my RV-8. I can't find anything in the plans or manual regarding what sort of length or shape extends below the gear access cover. I'm assuming that you fab an aluminum tube and penetrate the gear access cover with a rubber grommet. Do you bend it forward or leave it straight with a slash cut? How far should it protrude? Is this specified somewhere in the manual or plans and I'm blind? Thanks, Randy Lervold RV-8, #80500, N558RL, final plumbing & wiring www.rv-8.com Home Wing VAF = = = = Get your FREE download of MSN Explorer at http://explorer.msn.com ________________________________________________________________________________
Date: Jan 21, 2001
Subject: Matronics Web Server Upgrade...
B Dear Listers, I will be upgrading the Matronics Web Server this afternoon (1/21/01) and will be taking it offline for a number of hours. I hope to have it back online by this evening sometime, depending on how well the upgrade goes. Best regards, Matt Dralle Email List Admin. -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email
http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft Great minds discuss ideas, Average minds discuss events, Small minds discuss people... ________________________________________________________________________________
Date: Jan 28, 2001
Subject: Re: RV8-List Digest: 0 Msgs - 01/27/01
Hi, new to the thread. Becoming more and more interested in the RV8 or RV8A. Any advice or suggestions out there from anyone who is building or has built one? Especially why you chose the RV over others such as the Lancair etc. Thanks, Tim near Las Vegas ________________________________________________________________________________
Date: Jan 28, 2001
Hi, thanks for the note. Everyone writing seems to be wildly enthusiastic about the Vans product. Are you really in Aurora? Isn't that where the kits are built? Was going up to tour the factory this weekend but they're not open on weekends so I'll probably go up late next week. Best of luck on your project! Tim ________________________________________________________________________________
Date: Jan 28, 2001
Thanks, I'll call first. Interested only in the RV8 or RV8A. Since you seem to be right in the thick of things so to speak any thoughts on the RV8 Vs RV8A. Also I have seen RV's for sale that aren't even completed...."pick your paint and radios"....what's with that. Is it legal to build and sell one without ever flying it or intending to fly it? Thanks, Tim ________________________________________________________________________________
Date: Jan 29, 2001
I just visited the factory last week, and I was very impressed. I'm also interested in the RV-8A, and took a demo flight. They're not kidding when they talk about that RV grin. I actually visited the old place a couple of years ago, but wasn't quite ready to start building yet. I was lucky I never did a demo flight back then, or I'd would have tried to start before I was ready.. Their manufacturing is even more advanced now with the pre-drilled holes. Even some of the spar components are pre-drilled, not just the skins. I'm getting ready to place an order for the tail kit. By the way, it's my understanding that you can build one and sell it, as long as you're not doing it as a business. In other words, the purpose still has to be for the recreation of building. ----- Original Message ----- From: <Nvatp(at)cs.com> Sent: Sunday, January 28, 2001 11:23 PM Subject: Re: RV8-List: Re: RV8-List Digest: 0 Msgs - 01/27/01 Thanks, I'll call first. Interested only in the RV8 or RV8A. Since you seem to be right in the thick of things so to speak any thoughts on the RV8 Vs RV8A. Also I have seen RV's for sale that aren't even completed...."pick your paint and radios"....what's with that. Is it legal to build and sell one without ever flying it or intending to fly it? Thanks, Tim ________________________________________________________________________________
Date: Jan 29, 2001
rv8-list(at)matronics.com wrote: > > > I just visited the factory last week, and I was very impressed. I'm also > interested in the RV-8A, and took a demo flight. They're not kidding when > they talk about that RV grin. I actually visited the old place a couple of > years ago, but wasn't quite ready to start building yet. I was lucky I > never did a demo flight back then, or I'd would have tried to start before I > was ready.. Their manufacturing is even more advanced now with the > pre-drilled holes. Even some of the spar components are pre-drilled, not > just the skins. I'm getting ready to place an order for the tail kit. > > By the way, it's my understanding that you can build one and sell it, as > long as you're not doing it as a business. In other words, the purpose > still has to be for the recreation of building. > > ----- Original Message ----- > From: <Nvatp(at)cs.com> > To: > Sent: Sunday, January 28, 2001 11:23 PM > Subject: Re: RV8-List: Re: RV8-List Digest: 0 Msgs - 01/27/01 > > > > Thanks, I'll call first. Interested only in the RV8 or RV8A. Since you seem > to be right in the thick of things so to speak any thoughts on the RV8 Vs > RV8A. Also I have seen RV's for sale that aren't even completed...."pick > your > paint and radios"....what's with that. Is it legal to build and sell one > without ever flying it or intending to fly it? Thanks, Tim > > > Great, good luck with the project. Where are you? Thanks for the info on the already built airplanes. Thanks, Tim > > > > ________________________________________________________________________________
Date: Feb 08, 2001
Subject: Toe in anyone?
Dear -8 builders, after careful alignment of the main gear legs, and lots of work later, I have measured the axles and find them toe in by 2.1 degrees each. This is gut wrenching. Rechecking the gear legs, the leading edges are dead nuts aligned and equal distant from a hole in the bottom of the tail cone. I guess there must be some twist there somewhere. So, I screwed up and didn't check the axles, just the gear alignment. Now I have to fix it. My questions are these: 1. Has anyone finished one and flown it, with toe in? I know this is not a car, but cars have toe in for stability, does this apply to us taildraggers? If so, how much is the right amount? 2. Can this much be corrected with 1 degree shims like on my Cessna? Is 2 degrees too much? Will it bend axle bolts? thanks to all, Dan ________________________________________________________________________________
Date: Feb 08, 2001
Subject: Phone number??
It is time to start looking for engines. I have read a lot about Bart Lalonde at Aerosport Power in Canada.=A0 Does anyone have his phone number?=20 Does he sell engines outright or do you have to have a core to trade in? What kind of price ranges are we talking about? I am looking at the IO-360 A1B6 200 HP. Is there any problems with taxes or tarrifs when ordering from Canada? Howard Cochran Mooresville, NC 1/2 of 80188 Painting interior on Friday Feb. 9th. Canopy next. ________________________________________________________________________________
Subject: Re: Toe in anyone?
Date: Feb 09, 2001
Dan: I think that toe-in is a bad thing for a tail dragger. Makes it easier to turn. After carefully aligning my gear legs prior to drilling, I found almost 3% discrepancy when checking the axle alignment. I corrected with Van's shims. Haven't taxied the plane yet, so can't report on results, but I think I'm going to be all right. George Kilishek. Engine installation almost finished. >From: TwoAviators <TwoAviators(at)lexcominc.net> >Reply-To: rv8-list(at)matronics.com >To: rv8-list(at)matronics.com >Subject: RV8-List: Toe in anyone? >Date: Thu, 08 Feb 2001 20:04:12 -0500 > > >Dear -8 builders, after careful alignment of the main gear legs, and lots >of work later, I have measured the axles and find them toe in by 2.1 >degrees each. This is gut wrenching. Rechecking the gear legs, the leading >edges are dead nuts aligned and equal distant from a hole in the bottom of >the tail cone. I guess there must be some twist there somewhere. > >So, I screwed up and didn't check the axles, just the gear alignment. Now I >have to fix it. My questions are these: > >1. Has anyone finished one and flown it, with toe in? I know this is not a >car, but cars have toe in for stability, does this apply to us >taildraggers? If so, how much is the right amount? > >2. Can this much be corrected with 1 degree shims like on my Cessna? Is 2 >degrees too much? Will it bend axle bolts? > >thanks to all, > >Dan > > ________________________________________________________________________________
Date: Feb 11, 2001
Subject: Flight Test Links - new URL
My Flight Test Links were part of my RV Links page, but the page was getting too unwieldy. So, today I split the flight test info off on its own page: http://www.cyberus.ca/~khorton/ftlinks.html My RV Links page is still at: http://www.cyberus.ca/~khorton/rvlinks.html Take care, -- Kevin Horton RV-8 (canopy skirt) Ottawa, Canada http://eccentrix.com/misc/rv8/rv8.html ________________________________________________________________________________
Date: Feb 11, 2001
From: Elbie(at)aol.com (by way of Matt Dralle 925-606-1001 <dralle(at)matronics.com>)
Subject: Announcement
2/9/2001 Fellow Pilots and Builders: EM aviation is pleased to announce that the RiteAngle III Angle of Attack system is in production. I know this has been a long, long wait for some of you, however I will not sell a system that is not up to my standards. The long delay was partially caused by the total new design required after the RiteAngle 2000 system was terminated. The remainder of the delay was insuring the system met all our requirements such as both hot and cold environment testing. The first production group of systems off the line are being again extensively tested for approximately 2 weeks before we deliver any systems to insure there are no "bugs" appearing. When all production testing is accomplished I will ship according to who has sent in the order form via fax or US mail. (Again, DO NOT send your credit card number via e-mail! I DO NOT have a secure e-mail line.) If you want a spot in line for early delivery you can request this via e-mail, and mail your check or CC number. At present time I estimate 4- 10 weeks before your delivery, depending on when I receive your payment. To those of you who have been in correspondence with me for the last year, thanks for your belief in EM aviation's product, and soon you will have a product in your hands. I honor my correspondence of the quoted price. Current price $295 + mount & options see web site for information. www.riteangle.com Elbie Mendenhall President EM Aviation, LLC P NE Prairie Rd Brush Prairie WA 98606 360-260-0772 www.riteangle.com ________________________________________________________________________________
Date: Feb 12, 2001
Subject: RV-8 Fuselage Jig
From: Robert Northrup Free to a good home, one each RV-8 fuselage jig in Rochester, New York. Please repond to my e-mail, robert.northrup(at)kodak.com Bob 80578 ________________________________________________________________________________
Date: Feb 12, 2001
Subject: RV8 Fuselage Jig
From: Robert Northrup My fuselage jig has been spoken for. Only 47 minutes on the site! That's quite a response time. ________________________________________________________________________________
Date: Feb 12, 2001
Subject: Unfinished RV-8 for sale
I have a partially completed RV-8 for sale. Wings are completed (includes the strobes) Empennage is completed Fuselage - drilled, primed and ready to be riveted I have not ordered the finish kit. For sale for $9,950 firm. After having attempted to get my tail dragger sign off, I have realized that I am a much better nose dragger pilot and I do not want to tempt fate. I can be contacted at gary.rush(at)west.sun.com. I am located in Carlsbad, CA. Thanks, Gary ________________________________________________________________________________
Subject: RV8A Divorce Sale
Date: Feb 23, 2001
RV8A Divorce Sale RV Fans my pending divorce is forcing the sale of my RV8A project. I am losing both my home and workshop and will very soon lack the resources to work on my project. Enough praise of my wife's skills. What I have is an RV8A tail, wing and fuselage kits for sale. Tail complete except for fiberglass. Wing kit nearly complete ready for bottom skin riveting. Fuselage kit firewall, bulkheads and floor assembly done ready for installation into jig. It has electric trim elevator and aileron, adjustable rudder peddles and rear peddles (both at wife's insistence) and Duckworth landing lights from Van's in both wings. Don't want to start the primer wars but... I am of the alodine and epoxy primer camp; all parts have been treated that way. I am an A&P and aviation professional and the project has been built in a correct and airworthy manor. Checked Van's wed site today and have found the price for the basic kits is $12007 looking for a "fair, honest, and reasonable offer" to jump start someone into an 8A. Please contact me off list at (rv8aforsale(at)hotmail.com) My tools are not for sale, as I WILL start again once I am reestablished. Shafted in Ohio ________________________________________________________________________________
Date: Mar 02, 2001
Subject: RV-8A Quick Build Wings and Fuselage for Sale
For Sale RV8A Quick Build Wings and Fuselage for sale. All parts in new condition. Purchased in April of 2000. Fuselage has never been out of the shipping crate. All parts have been inventoried. The only work that has been done is on the left wing. The bottom skin has been drilled on and dimpled but not riveted. The wings are back in the shipping crate. So pick up will be very easy for someone in the Midwest. The kit was received from Vans in May of 2000. An unexpected job change and move forces sale. Since August, I have had little time to work on the airplane. A new kit from Vans is $17,425.00 plus shipping. It would cost a thousand dollars to have it shipped from Vans to the Midwest. Please e-mail me a reasonable offer at dweb5(at)adams.net . Located in Illinois. ________________________________________________________________________________
Subject: Jet fuel
Date: Mar 02, 2001
Maybe this is why I build so slow. I always wanted there to be a wiff of kerosene around my little fighter. From this morning's AOPA newsletter, for those that missed it: FRENCH COMPANY TO PRODUCE DIESEL ENGINE A French company has received Design Organization Approval in Europe for its SR 305 230-horsepower diesel engine that offers improved performance, longer TBO, and the ability to run on jet fuel. SMA, Societe de Motorisation Aeronautiques, created four years ago by Aerospatiale and Renault for the development and sales of a range of piston aircraft engines, plans to go into production soon. All of the testing has been completed. Following an administrative process, the company expects to have certification under the Joint Aviation Authorities (JAA) by the end of the month, said a company official. Through a reciprocal agreement, SMA also plans to receive FAA certification in the United States later this year. A price has not been announced. For more, see the Web site ( http://www.smaengines.com/ ). They talk about 200 to 300 hp models. No word yet on weight, price, or availability. Terry RV-8A #80729 about ready to rivet fuselage skins ________________________________________________________________________________
Date: Mar 02, 2001
Subject: Re: RV8-List Digest: 1 Msgs - 02/23/01
Here=E2=80=99s a win-win offer! I am about to embark on a first-time Rocket kit build and this may be my only one. I would like to save $ by acquiring used tools from a Van=E2=80=99s or derivative builder who is finished or about to complete, and also may not be planning another. Please do not reply through the list, but directly to me: DvdBock(at)AOL.com ________________________________________________________________________________
Subject: Re: Wing Assembly
Date: Mar 05, 2001
> For my RV8 wing, I have thought about just clecoing the main ribs to the > front and rear spars, then placing it in the jig to drill the skins. Then > disassemble and prime the ribs. Anybody else try this route? > Thanks in advance, > Jack Textor > RV8 > DSM Jack, You could do that but it would result in a lot more work on your part. Jigging your wings can be fairly time consuming to get everything exactly plumb. The time you would save in priming everything as a batch would be less than the time spent re-jigging. Bottom line: I wouldn't do it. Randy Lervold RV-8, #80500, finishing details, fly in May(?) www.rv-8.com Home Wing VAF ________________________________________________________________________________
Date: Mar 06, 2001
Subject: Old o-320 flange bushings?
Help, I have an OLD 0-320-nothing, with 3/8 bushings on the prop flange. Van's catalog says they need to be replaced with 7/16. Where in the heck can I get them, or do I need to drill and tap them out? Thanks all, Dan Ward 81243 finishing kit (about half way) TwoAviators(at)lexcominc.net ________________________________________________________________________________
Date: Mar 07, 2001
Subject: Re: blind rivets
Cherry Max rivet removal is a breeze after the lock ring is removed. The trick is the lock ring. Easiest way is to use a carbide tip, round burr to grind off the stem & lock ring. After ring is removed, knock out center with a punch, than drill off the rivet head. Protect the skin by placing furance tape around the rivet before you start this process. Tim (buildin' an RV8 in Indiana) ________________________________________________________________________________
Date: Mar 07, 2001
Subject: RV-8 LG Box heads up
I picked the brains of several RV-8 builders prior to building the LG boxes for my RV-8. They gave me lots of good advice, which I put on the web at: http://eccentrix.com/misc/rv8/fuselage/f06.html I started to permanently install my LG legs this weekend, and discovered a glitch. I had gotten advice from earlier builders to swap a rivet location for an AN509 screw location. I did that to sort out an apparent interference problem, but it has created a bit of a domino effect. I now discover that the reason Van put that rivet where he did is that it is next to the nut on the NAS bolts that attach the U-803s. Now I have an AN509 screw at that location, and the nut gets in the way. I see four options: 1. insert the NAS bolts the other way, with the nuts on the bottom. The cover will have to be shortened, as the bolt ends will protrude, but that area gets covered with a fairing anyway. I'll need to remove several AN509 screws to get the bolts in, but I can put them all back afterwards. 2. Put an AN426 5-X rivet in place of the AN509 screw. You lose a tiny bit of strength, but there are a lot of fasteners in that area, so I suspect the loss of strength is in the noise. 3. Put a CherryMax rivet in place of the AN509 screw. This has more strength than option 2, but I'm not sure how big the pulled head is on the rivet. It might be long enough to still get in the way. 4. Remove the AN509 screws, and replace them after the NAS bolts are torqued. I'm not yet sure if I could get all the AN509 screws back in, and they would have to come out every time you retorqued those bolts. Not fun. I'm leaning towards option 1. Options 2 or 3 should probably be run by Van's first. I updated my Landing Gear Box notes to reflect this latest info. Lesson of the day - don't assume you are smarter than Van ;-) Kevin Horton RV-8 (installing landing gear) Ottawa, Canada http://eccentrix.com/misc/rv8/rv8.html ________________________________________________________________________________
Subject: Re: RV-8 LG Box heads up
Date: Mar 07, 2001
Kevin: Can you replace the offending screw with an AN426-5X riven AND drill out the rivet you had swapped for it and replace it with and AN509 screw? That should leave you a little stronger than Van intended. For sure don't do option 4. Once you have the tank vent tubes, wiring and avionics coax cable running through those LG boxes and have the windshield and forward fuselage riveted in place you'll not want to do any repetitive maintenance jobs in that area. I'd also recommend you talk to Vans: preferably Ken Krueger, whom I've found to have a solid engineering knowledge of the plane as well as a very pragmatic approach to problem solving. There's no problem on this airplane that can't be fixed. George Kilishek N888GK (reserved)- endless firewall forward almost ended. >From: Kevin Horton <khorton(at)cyberus.ca> >Reply-To: rv8-list(at)matronics.com >To: rv8-list(at)matronics.com, rv8list(at)egroups.com >Subject: RV8-List: RV-8 LG Box heads up >Date: Wed, 7 Mar 2001 21:48:31 -0500 > > >I picked the brains of several RV-8 builders prior to building the LG >boxes for my RV-8. They gave me lots of good advice, which I put on >the web at: > >http://eccentrix.com/misc/rv8/fuselage/f06.html > >I started to permanently install my LG legs this weekend, and >discovered a glitch. I had gotten advice from earlier builders to >swap a rivet location for an AN509 screw location. I did that to >sort out an apparent interference problem, but it has created a bit >of a domino effect. I now discover that the reason Van put that >rivet where he did is that it is next to the nut on the NAS bolts >that attach the U-803s. Now I have an AN509 screw at that location, >and the nut gets in the way. I see four options: > >1. insert the NAS bolts the other way, with the nuts on the bottom. >The cover will have to be shortened, as the bolt ends will protrude, >but that area gets covered with a fairing anyway. I'll need to >remove several AN509 screws to get the bolts in, but I can put them >all back afterwards. > >2. Put an AN426 5-X rivet in place of the AN509 screw. You lose a >tiny bit of strength, but there are a lot of fasteners in that area, >so I suspect the loss of strength is in the noise. > >3. Put a CherryMax rivet in place of the AN509 screw. This has more >strength than option 2, but I'm not sure how big the pulled head is >on the rivet. It might be long enough to still get in the way. > >4. Remove the AN509 screws, and replace them after the NAS bolts are >torqued. I'm not yet sure if I could get all the AN509 screws back >in, and they would have to come out every time you retorqued those >bolts. Not fun. > >I'm leaning towards option 1. Options 2 or 3 should probably be run >by Van's first. > >I updated my Landing Gear Box notes to reflect this latest info. > >Lesson of the day - don't assume you are smarter than Van ;-) > >Kevin Horton RV-8 (installing landing gear) >Ottawa, Canada >http://eccentrix.com/misc/rv8/rv8.html > > ________________________________________________________________________________
Date: Mar 07, 2001
Subject: Re: Old o-320 flange bushings?
I had that on a 0290...I pressed them out, then went to western propeller in troughtdale ore, and he gave (read sold) me new bushings I needed...I am told the old 0320's are the same...good luck RV8A fininshing...I think do not aechive TwoAviators wrote: > > Help, I have an OLD 0-320-nothing, with 3/8 bushings on the prop flange. > Van's catalog says they need to be replaced with 7/16. Where in the heck > can I get them, or do I need to drill and tap them out? > > Thanks all, > > Dan Ward > 81243 > finishing kit (about half way) > > TwoAviators(at)lexcominc.net > ________________________________________________________________________________
Date: Mar 08, 2001
----- Original Message ----- From: "TwoAviators" <TwoAviators(at)lexcominc.net> Sent: Tuesday, March 06, 2001 6:39 PM Subject: RV8-List: Old o-320 flange bushings? > > Help, I have an OLD 0-320-nothing, with 3/8 bushings on the prop flange. > Van's catalog says they need to be replaced with 7/16. Where in the heck > can I get them, or do I need to drill and tap them out? > You only need the 7/16 bushings if you are going to a CS. If that is what you are doing, then you will need 3 different bushings. You can get the #s out of the LYC. parts book. They are not cheap! NO DRILLING OF OLD BUSHINGS! the original threads are rolled.Terry B. ________________________________________________________________________________
Date: Mar 08, 2001
Terry B I am using a Dermuth wood prop, and they can make my hole pattern anything I need. Tell me how it will not effect the crush plate and the 2 1/2inch prop extention. I need to let the prop people know. It would be great if I didn't have to change it. Thanks, Dan W > > >----- Original Message ----- >From: "TwoAviators" <TwoAviators(at)lexcominc.net> >To: >Sent: Tuesday, March 06, 2001 6:39 PM >Subject: RV8-List: Old o-320 flange bushings? > > >> >> Help, I have an OLD 0-320-nothing, with 3/8 bushings on the prop flange. >> Van's catalog says they need to be replaced with 7/16. Where in the heck >> can I get them, or do I need to drill and tap them out? >> >You only need the 7/16 bushings if you are going to a CS. If that is what >you are >doing, then you will need 3 different bushings. You can get the #s out of >the LYC. >parts book. They are not cheap! NO DRILLING OF OLD BUSHINGS! >the original threads are rolled.Terry B. > > ________________________________________________________________________________
Subject: cratex part number1357-f
Date: Mar 12, 2001
all, if you are deburring punched lightening holes try this rubberized abrasive. it has a 1/4" 20 insert and you mount it on a mandrel for a 1/4" die grinder. the abrasive is 7/8" diameter x 1.25" long and is rated to 20,000rpm. first true the things up on a ruff something (i use a peice of concrete slab in my garage footing). i just did a bunch of wing ribs and spars in about an hour -- faster than i did just four ribs using sandpaper and scotch bright. definitely worth the money. check out www.cratex.com. try part number 1367-f (f stand for fine - i find this works best for me). they are $5.00 per package of 25. i also use the same compond in my dremel tool for doing smaller cutouts like where the rib flanges meet. these products have saved me a lot of time and do a much better job than any other method i have seen. when using these smaller bullet style, reshape and balance them on the same ruff something you used in the above paragraph. you can order these from mcmaster carr. i do not work for cratex nor do i hold any stock in this company, i just hate deburring and these make it go faster. i just wish i had found this product sooner for myself. have fun, todd rudberg n232tb rv-8 wings ________________________________________________________________________________
Date: Mar 12, 2001
Subject: Lycomming cyl base nut?
Anyone, I need a (thats right, just one) cylinder base nut for my 0-320. Specifically, I need the 3/8, Lyc p/n 71134. Minimum order, plus shipping and handling and all that makes it VERY expensive. Anyone have one I can buy, a good used one would be fine. Also, I have some specific questions about my engine, any engine people out there? Thanks, Dan 81243 Finishing kit ________________________________________________________________________________
Subject: Re: Lycomming cyl base nut?
Date: Mar 12, 2001
Call John Hendrickson at Superior Air Parts in Dallas. 800 487-4884. I'll bet he can fix you up. John is a good guy. The nut shouldn't cost but a couple of buck, I would guess. Tom Waiting for my QB RV-8 ----- Original From: "TwoAviators" <TwoAviators(at)lexcominc.net> Sent: Monday, March 12, 2001 8:20 PM Subject: RV8-List: Lycomming cyl base nut? > > Anyone, > > I need a (thats right, just one) cylinder base nut for my 0-320. > Specifically, I need the 3/8, Lyc p/n 71134. Minimum order, plus shipping > and handling and all that makes it VERY expensive. Anyone have one I can > buy, a good used one would be fine. > > Also, I have some specific questions about my engine, any engine people out > there? > > Thanks, > > Dan 81243 > Finishing kit > > ________________________________________________________________________________
Subject: Wing bolt torque?
Date: Mar 13, 2001
Listers, Just wanted to confirm the torque settings I am about to use in finally tightening my wing bolts. The smaller bolts are AN-4s and the table in AC 43.13 shows 50-75 in/lbs. The larger bolts are AN7 in size but are special high-strength bolts. Do I use the standard torque setting for an AN7 fine thread of 450-500 in/lbs? Thanks, Randy Lervold RV-8, #80500, sure isn't as warm in the hangar as it was in the garage! www.rv-8.com Home Wing VAF ________________________________________________________________________________
Date: Mar 13, 2001
I Just completed the overhaul on my 0-320. I have some used nuts from my engine. I had some chewed nuts so I decided to replace all of them. Next time I will ask the price first. It cost over $100. 00. I am also an A&P so I be able to answer your questions. You can call me at 303-797-1373 or we can use E mail. Mark Delano EAA Tech counselor 6A finish kit TwoAviators wrote: > > Anyone, > > I need a (thats right, just one) cylinder base nut for my 0-320. > Specifically, I need the 3/8, Lyc p/n 71134. Minimum order, plus shipping > and handling and all that makes it VERY expensive. Anyone have one I can > buy, a good used one would be fine. > > Also, I have some specific questions about my engine, any engine people out > there? > > Thanks, > > Dan 81243 > Finishing kit > ________________________________________________________________________________
Date: Mar 13, 2001
Mark, Thanks for the response. AS you well know nothing that has Lycomming on it is cheap. I have a guy that offered to send me one. IF that doesn't materialize I'd be happy to buy a good used one from you. I have a 0-320, and when I was last over hauled it has high compression pistons put in it. I believe that makes it a 160hp version of the 150hp engine. I have heard that lycomming doesn't like that, but heard others say it has worked fine for years. I have about 100 smoh and really don't want to take it apart. The engine has a very early Marvel carb on it, and my slightly high EGT confirms the talk I hear from others that the early carbs ran lean. I tried rejetting it, with no change. What version carb would you suggest? I'd much rather run rich than lean. Thank you for your assistance. Dan > >I Just completed the overhaul on my 0-320. I have some used nuts from my >engine. >I had some chewed nuts so I decided to replace all of them. Next time I will >ask the price first. It cost over $100. 00. I am also an A&P so I be able to >answer your questions. You can call me at 303-797-1373 or we can use E mail. > >Mark Delano >EAA Tech counselor >6A finish kit > >TwoAviators wrote: > >> >> Anyone, >> >> I need a (thats right, just one) cylinder base nut for my 0-320. >> Specifically, I need the 3/8, Lyc p/n 71134. Minimum order, plus shipping >> and handling and all that makes it VERY expensive. Anyone have one I can >> buy, a good used one would be fine. >> >> Also, I have some specific questions about my engine, any engine people out >> there? >> >> Thanks, >> >> Dan 81243 >> Finishing kit >> > > ________________________________________________________________________________
Date: Mar 14, 2001
I plan to use a MA4SPA Marvel carb on my enj. I agree that it is better to run rich. What do you mean by 'slightly high EGT'. If your carb is rebuilt to Marvel specifications and properly adjusted it should be OK. I would also check the calibration of your EGT sys. I had a hangar mate who installed a Westac EGT, had high temp indications. After several conversations with the manufacturer he discovered they had supplied the wrong thermocouple, that is his gage was calibrated with a type K thermocouple and they sent him type J. Both will produce an indication an the gage but the wrong type will give erroneous readings. I would also expect the 160 HP to have higher EGT than the lower compression engine as is producing more power. I would not be in to big a hurry to take your eng. apart. there are many things to look at before you disassemble it Enough of my rambling good luck Mark TwoAviators wrote: > > Mark, > > Thanks for the response. AS you well know nothing that has Lycomming on it > is cheap. I have a guy that offered to send me one. IF that doesn't > materialize I'd be happy to buy a good used one from you. > > I have a 0-320, and when I was last over hauled it has high compression > pistons put in it. I believe that makes it a 160hp version of the 150hp > engine. I have heard that lycomming doesn't like that, but heard others say > it has worked fine for years. I have about 100 smoh and really don't want > to take it apart. > > The engine has a very early Marvel carb on it, and my slightly high EGT > confirms the talk I hear from others that the early carbs ran lean. I tried > rejetting it, with no change. What version carb would you suggest? I'd much > rather run rich than lean. > > Thank you for your assistance. > > Dan > > > > >I Just completed the overhaul on my 0-320. I have some used nuts from my > >engine. > >I had some chewed nuts so I decided to replace all of them. Next time I will > >ask the price first. It cost over $100. 00. I am also an A&P so I be able to > >answer your questions. You can call me at 303-797-1373 or we can use E mail. > > > >Mark Delano > >EAA Tech counselor > >6A finish kit > > > >TwoAviators wrote: > > > >> > >> Anyone, > >> > >> I need a (thats right, just one) cylinder base nut for my 0-320. > >> Specifically, I need the 3/8, Lyc p/n 71134. Minimum order, plus shipping > >> and handling and all that makes it VERY expensive. Anyone have one I can > >> buy, a good used one would be fine. > >> > >> Also, I have some specific questions about my engine, any engine people out > >> there? > >> > >> Thanks, > >> > >> Dan 81243 > >> Finishing kit > >> > > > > > ________________________________________________________________________________
Date: Mar 15, 2001
Subject: Carb wanted
All, After some great advise, I am looking for a carb to replace the one I have. I have a Marvel 10-3678-12, and am looking for a 10-3678-32, 10-5135, or 10-5217. I will trade my carb + cash if anyone is interested, or buy outright. Thanks to Bart for his knowledge and insight. Dan TwoAviators(at)lexcominc.net ________________________________________________________________________________
Date: Mar 16, 2001
Subject: Re: Carb/fuel pump for sale
Going with fuel injecation, have boxed carb and low pressure plump new from Lycoming. Carb 10-4164-1, pump ? standard on 0-360. $700 On vacataion Sun. til Apr. 1. Dennis Off list or 541-687-2360 ________________________________________________________________________________
Subject: Aluminum Gear Legs -- Grove Aircraft
Date: Mar 24, 2001
All, If you like the idea of Aluminum Gear Legs for your RV-8 check out Grove Aircraft's design. I have talked with Robbie Grove and was impressed with his knowledge. If my recommendation does not impress you (which it shouldn't), relize that he builds gear legs for Zilco aircraft as well as others so he knows what he is doing. I really like the fared gear legs he made for John Huft http://skywagon.homestead.com/rv8.html. I have placed my name on a list of individuals who would like to get these. They are $1500, but Van's gives you almost $700 for your gear legs, so you are out $800, but no need for gear leg fairings and brake lines. Last I heard Robbie needs to get commitment from eight others in order to make more. His number: (619) 562-1268. Also, I just recieved my Hot Tips from Massey Aircraft. They are cool. See click on link below: http://www.masseyaircraftservice.com/performance.htm On all the above, do your own research and call Van's for their opinion on these changes. Humbly submited by, Todd W. Rudberg RV-8 Wings N232TB ________________________________________________________________________________
Date: Mar 25, 2001
Naive thoughts regarding the AL gear legs: I REALLY like the sound of already-faired and internal brake lines. But I wonder about the wear of the AL against the steel attachment hardware, as seen in this picture: http://skywagon.homestead.com/files/belly_leg.jpg Isn't the AL going to loose that battle? Larry Bowen RV-8 fuse Email: Larry(at)BowenAero.com Web: http://BowenAero.com > -----Original Message----- > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Todd Rudberg > Sent: Saturday, March 24, 2001 9:47 PM > To: 'rv8-list(at)matronics.com' > Subject: RV8-List: Aluminum Gear Legs -- Grove Aircraft > > > All, > If you like the idea of Aluminum Gear Legs for your RV-8 check out Grove > Aircraft's design. I have talked with Robbie Grove and was impressed with > his knowledge. If my recommendation does not impress you (which it > shouldn't), relize that he builds gear legs for Zilco aircraft as well as > others so he knows what he is doing. I really like the fared gear legs he > made for John Huft http://skywagon.homestead.com/rv8.html. I > have placed my > name on a list of individuals who would like to get these. They > are $1500, > but Van's gives you almost $700 for your gear legs, so you are > out $800, but > no need for gear leg fairings and brake lines. Last I heard > Robbie needs to > get commitment from eight others in order to make more. His number: (619) > 562-1268. [snip] ________________________________________________________________________________
Date: Mar 30, 2001
Subject: man'l trim control
has anyone pix (e-mail) of man'l trim installation on a RV8a...need some ideas on the placement. of the contorl cable....thanks in advance.. RV8a, finishing..I think...maybe...possibly...well..... ________________________________________________________________________________
Date: Mar 30, 2001
Subject: dimple dies
does any one in the greater portland-salem aerea have the large dimple dies that fit the large inspection plates in the wings of the RV8's that I could rent, beg, or borrow?I assume one uses the ones that use the pop-rivet tool...thanks...503-678-3343 ________________________________________________________________________________
Subject: RV8 Fuselage F815 to F804 Attach
Date: Mar 31, 2001
Hello, STAGE: Fuselage measuring the F804 to rear spar distance to insure wings will fit prior to 'tacking down' the F815 floor rib. PROBLEM: Though everything lines up, the F815 floor rib flange does not tuck under the F804 main carry through spar flange enough to rivet through it and still maintain rivet hole to edge(end) clearance. I have emailed Van's but would like to get working this weekend. QUESTION: Anyone else been in the same boat, or more accurately the same inverted canoe? Your solution? Thanks and Regards, Vince Himsl RV8 Fuselage Moscow, ID USA ________________________________________________________________________________
Date: Apr 12, 2001
Subject: RV-8 for sale
I just got a call from Sen. Jim Inhofe (R-OK), informing me that he's looking to sell his RV-8. He is expecting his new -8 to be done soon and doesn't want two RV-8s. Can't imagine why. He had it at Oshkosh last year, so those of you who perused the RV corral may have noticed it. He has a website with pics and contact info at: http://www.padre.homestead.com/ I told him I'd pass this info on to the RV-8 list community. --Don McNamara N8RV ________________________________________________________________________________
Subject: AN3 Bolt edge dist
Date: Apr 21, 2001
Builder's What is the min edge distance for an AN3 bolt through .125 alum material, is it the same as rivets, 2x Chris RV8 Mounting horiz an vert stab. ________________________________________________________________________________
Date: Apr 25, 2001
From: Doug and Kelly Snead <kellyndoug(at)yahoo.com>
Subject: tools for sale
rv9-list(at)matronics.com To any new RV builder, > I have some basic tools for sale that I bought > from Avery and from the Yard. If you would like more > information please write or call at: > > kellyndoug(at)yahoo.com > 580-233-8997 > > > Doug > Enid, OK Yahoo! Auctions - buy the things you want at great prices http://auctions.yahoo.com/ ________________________________________________________________________________
Date: Apr 25, 2001
Subject: dumb question # 44499776
has anyone decided to replace the van's supplied cowl with a different cowl?...I sure would like to change mine, but havn't heard of anyone around the portland-salem washington aerea doing it...any comments?...thanks...jolly ________________________________________________________________________________
Date: Apr 26, 2001
Subject: Re: dumb question # 44499776
sir, I think Rocket Engineering has a cowling, though I wonder why you don't use Vans. I am finishing my -8, and will use Vans cowling with some modification. Good Luck. dan 81243 finishing N417SN reserved > >has anyone decided to replace the van's supplied cowl with a different >cowl?...I sure would like to change mine, but havn't heard of anyone >around the portland-salem washington aerea doing it...any >comments?...thanks...jolly > > ________________________________________________________________________________
Date: Apr 26, 2001
Try Sam James, he provides a nice alternative. Jim Stone SDF ----- Original Message ----- From: old ogre <jollyd(at)teleport.com> Sent: Wednesday, April 25, 2001 9:57 PM Subject: RV8-List: dumb question # 44499776 > > has anyone decided to replace the van's supplied cowl with a different > cowl?...I sure would like to change mine, but havn't heard of anyone > around the portland-salem washington aerea doing it...any > comments?...thanks...jolly > > > > > > ________________________________________________________________________________
Date: May 02, 2001
Gentlemen, and ladies, I looking for 3/8 prop bolts. I think I need AN6 -82. Suggestions? Using Aymar Demuth prop and Van's 2 1/4 extension and crush plate. Thanks, Dan 81243 Finishing kit N417SN reserved. ________________________________________________________________________________
Subject: NACA vent????
Date: May 09, 2001
Hello listers, Close to closing my right wing (rv8). The manual says to install the vent with proseal and pop rivets. Would it be better to countersink the skin (.032) and use flush rivets? Also, should I install a screen of some type, just below the skin or the inlet or outlet of the hose? Size of screen? and last but not least, it sounds like the RV series is hot, should I plan a vent in the left wing also for extra air? Thanks! Jack DSM RV8, wings ________________________________________________________________________________
From: "Larry Dysinger" <larrykdysinger(at)hotmail.com>
Subject: Re: NACA vent????
Date: May 09, 2001
Jack, I dimpled the skin and used flush pop rivets. Also used Blue RTV. I will insert a screen to keep the nasty bugs out. Larry RV-8QB 81251 From: "Jack Textor" <pincjt(at)ix.netcom.com> Subject: RV8-List: NACA vent???? Date: Wed, 9 May 2001 13:49:01 -0500 Hello listers, Close to closing my right wing (rv8). The manual says to install the vent with proseal and pop rivets. Would it be better to countersink the skin (.032) and use flush rivets? Also, should I install a screen of some type, just below the skin or the inlet or outlet of the hose? Size of screen? and last but not least, it sounds like the RV series is hot, should I plan a vent in the left wing also for extra air? Thanks! Jack DSM RV8, wings ________________________________________________________________________________
Date: May 09, 2001
Mine is on with proseal only. Other have assured me it's never coming off. I'll put a screen over the round end when I install the hose. Larry Bowen RV-8 fuse Email: Larry(at)BowenAero.com Web: http://BowenAero.com > -----Original Message----- > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Jack Textor > Sent: Wednesday, May 09, 2001 2:49 PM > To: RV-8-List (E-mail) > Subject: RV8-List: NACA vent???? > > > Hello listers, > Close to closing my right wing (rv8). The manual says to install the vent > with proseal and pop rivets. Would it be better to countersink the skin > (.032) and use flush rivets? Also, should I install a screen of > some type, > just below the skin or the inlet or outlet of the hose? Size of > screen? and > last but not least, it sounds like the RV series is hot, should I plan a > vent in the left wing also for extra air? Thanks! > Jack > DSM > RV8, wings > > ________________________________________________________________________________
Date: May 10, 2001
Subject: Re: RV8-List Digest: 3 Msgs - 05/09/01
'RV8-List Digest Server' wrote:=0A=0A- * - RV8-List Digest Archive - --- - Total Messages Posted Wed 05/09/01: 3 - - - _______ - From: "Jack Textor" <pincjt(at)ix.netcom.com ...'=0A=0A=0A> Take a look to the attachment. =0A=0A=0A ________________________________________________________________________________
Date: May 10, 2001
Jack: The reason for using pop rivets is the very difficult access to this point. If you can get to it to buck it, there's no reason not to use flush rivets (but you won't gain much other than a certain smugness). I don't think that you need a screen (Just my opinion). I also don't think a second vent would help much, and will give you major space and layout problems in the rear cockpit. George N888GK Finishing cooling baffles >From: "Jack Textor" <pincjt(at)ix.netcom.com> >Reply-To: rv8-list(at)matronics.com >To: "RV-8-List (E-mail)" >Subject: RV8-List: NACA vent???? >Date: Wed, 9 May 2001 13:49:01 -0500 > > >Hello listers, >Close to closing my right wing (rv8). The manual says to install the vent >with proseal and pop rivets. Would it be better to countersink the skin >(.032) and use flush rivets? Also, should I install a screen of some type, >just below the skin or the inlet or outlet of the hose? Size of screen? >and >last but not least, it sounds like the RV series is hot, should I plan a >vent in the left wing also for extra air? Thanks! >Jack >DSM >RV8, wings > > ________________________________________________________________________________
Date: May 19, 2001
Subject: insurance
I have been told there is construction insurance available...can anyone please tell me which one is the best to get...if there is one...thanks j. dawson RV8A finishing? ________________________________________________________________________________
Subject: insurance
Date: May 19, 2001
The Van's-sponsered insurance, VanGuard, offers project coverage. I have my renters ins through them too. So far, so good. There is more info on Van's website. Larry Bowen RV-8 fuse Email: Larry(at)BowenAero.com Web: http://BowenAero.com > -----Original Message----- > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of old ogre > Sent: Saturday, May 19, 2001 9:21 AM > To: RV-8-List (E-mail) > Subject: RV8-List: insurance > > > I have been told there is construction insurance available...can anyone > please tell me which one is the best to get...if there is one...thanks > j. dawson > RV8A finishing? > > ________________________________________________________________________________
Date: May 19, 2001
Subject: 8A spar center section rivets
I'm currently installing the floors and control tube in my -8A, and am wondering when I rivet the two halves of the wing center section (F-804A and F-804B) together. I'm referring to the row of 12, 1/8" rivets that attach the upper forward flanges together. The bottom side was riveted together when I put the skins on, but I can't seem to find a reference to this top row of rivets in the manual. Hopefully I didn't overlook it. I ask because I'm about to drill the bolt holes for the rear stick support. Since the front stick support attaches to the front of the center section, I was wondering if the rivets I'm asking about should already be in. Matthew -8A fuse ________________________________________________________________________________
Subject: RV-8 Vx & Vy?
Date: May 19, 2001
Flying RV-8ers, What are you using for Vx and Vy? Also, what have you determined as "best glide" speed? Thanks, Randy Lervold www.rv-8.com ________________________________________________________________________________
Subject: Re: insurance
Date: May 19, 2001
Go to van's web page and click on the web link for NationAir. Good builder's insurance rates. From: old ogre <jollyd(at)teleport.com> Subject: RV8-List: insurance Date: Sat, 19 May 2001 06:20:48 -0700 I have been told there is construction insurance available...can anyone please tell me which one is the best to get...if there is one...thanks j. dawson RV8A finishing? ________________________________________________________________________________
Subject: insurance
Date: May 19, 2001
Whoops. Spoke to soon. I just received a cancellation notice from GreatAmerican, the underwriter for my renters insurance from NationAir/VanGuard. "Because we have discontinued writing your class and type of risk." In my book, insurance rates right up there with taxes and root canals!! Larry Bowen RV-8 fuse Email: Larry(at)BowenAero.com Web: http://BowenAero.com > -----Original Message----- > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Larry Bowen > Sent: Saturday, May 19, 2001 11:26 AM > To: rv8-list(at)matronics.com > Subject: RE: RV8-List: insurance > > > The Van's-sponsered insurance, VanGuard, offers project coverage. > I have my > renters ins through them too. So far, so good. There is more > info on Van's > website. > > Larry Bowen > RV-8 fuse > Email: Larry(at)BowenAero.com > Web: http://BowenAero.com ________________________________________________________________________________
Subject: Re: 8A spar center section rivets
Date: May 21, 2001
Matthew, I'm in about the same area you are and have been wondering the same thing. I have read through the entire instruction set for the fuselage and can't find it either. I have come close to going ahead and doing it, but remembered how many rivets I have drilled out and passed. Maybe it is in the finish kit??? Bill C., RV8A fuselage, Phoenix ----- Original Message ----- From: Matthew Gelber <mgelber(at)pacbell.net> Sent: Saturday, May 19, 2001 9:12 AM Subject: RV8-List: 8A spar center section rivets > > I'm currently installing the floors and control tube in my -8A, and am > wondering when I rivet the two halves of the wing center section (F-804A and > F-804B) together. I'm referring to the row of 12, 1/8" rivets that attach > the upper forward flanges together. The bottom side was riveted together > when I put the skins on, but I can't seem to find a reference to this top > row of rivets in the manual. Hopefully I didn't overlook it. > > I ask because I'm about to drill the bolt holes for the rear stick support. > Since the front stick support attaches to the front of the center section, I > was wondering if the rivets I'm asking about should already be in. > > Matthew > -8A fuse > > ________________________________________________________________________________
Date: May 20, 2001
Larry-- Hey, watch that ROOT CANAL comment, bub ... I take serious exception to being lumped together with tax collectors and other sinners! --Don McNamara Ver-r-r-y slow RV-8 builder and dentist (who just happens to enjoy doing exceptionally painless root canals!) Larry Bowen wrote: In my book, insurance rates right up there with taxes and root canals!! > > Larry Bowen > RV-8 fuse > ________________________________________________________________________________
From: "Sally and George" <aeronut58(at)hotmail.com>
Subject: Carburetor Fitting
Date: May 23, 2001
I need a new fitting for connecting fuel supply to my Marvel carburetor on an O-360A4M. Anybody know a source for these? Do they have the same thread as the fuel pump fittings which are available from Van's? If not, does anyone know what the thread is? Thanks for any help. George Kilishek 99% done. A lot left to do. ________________________________________________________________________________
Date: May 24, 2001
Subject: Prop bolts, help!
I have a 0-320 with 3/8 prop bolts. After being discouraged from changing to 7/16, I now have not been able to find AN6-73's 0r An6W73 bolts. They are 3/8 bolts 7 1/2 " long. I have my prop, and spacer and hate to change now. Aircraft Spruce has 8" bolts for a measly $40 each (Geeeezzzzzzzzz) I have called bolt suppliers and they don't want to talk if its for an airplane. Please anyone have any ideas??? Thanks Dan Ward 81432 N417SN(reserved) Finishing Kit, (about half finished with peoject) ________________________________________________________________________________
Subject: Re: Prop bolts, help!
Date: May 24, 2001
I was able to buy a new set of prop bolts (7/16x7-1/2") from Sensenich. Denise was very helpful, and even gave me an OEM discount (15%)without my asking. Price was $225 for the set (not cheap, even discounted). Their phone # is 717-569-0435. Good luck. George N888GK (reserved). 99% finished. End still not in sight. >From: TwoAviators <TwoAviators(at)lexcominc.net> >Reply-To: rv8-list(at)matronics.com >To: rv8-list(at)matronics.com >Subject: RV8-List: Prop bolts, help! >Date: Thu, 24 May 2001 17:32:04 -0400 > > >I have a 0-320 with 3/8 prop bolts. After being discouraged from changing >to 7/16, I now have not been able to find AN6-73's 0r An6W73 bolts. They >are 3/8 bolts 7 1/2 " long. I have my prop, and spacer and hate to change >now. Aircraft Spruce has 8" bolts for a measly $40 each (Geeeezzzzzzzzz) I >have called bolt suppliers and they don't want to talk if its for an >airplane. > >Please anyone have any ideas??? > >Thanks > >Dan Ward >81432 >N417SN(reserved) >Finishing Kit, (about half finished with peoject) > > ________________________________________________________________________________
Subject: RE: Prop bolts, help!
Date: May 24, 2001
> Dan Ward > 81432 > N417SN(reserved) > Finishing Kit, (about half finished with peoject) What does that mean, you have another year to go?! I don't think so! Larry Bowen Email: Larry(at)BowenAero.com Web: http://BowenAero.com ________________________________________________________________________________
Date: May 25, 2001
Subject: Re: RV8-List Digest: 3 Msgs - 05/24/01
Re the prop bolts.... Find out what material they're made from (must be gold :-)) and any machine shop can machine the threads for you. Heck, it can't be THAT exotic, can it? Jerry Cochran RV6a wings ________________________________________________________________________________
Date: May 25, 2001
you got to be kidding, have a machine shop make the prop bolts! My life is worth more than a set of bolts.... Tom Schad A&P IA ----- Original Message ----- From: <Jerry2DT(at)aol.com> Sent: Friday, May 25, 2001 3:33 PM Subject: RV8-List: Re: RV8-List Digest: 3 Msgs - 05/24/01 > > Re the prop bolts.... > > Find out what material they're made from (must be gold :-)) and any machine > shop can machine the threads for you. Heck, it can't be THAT exotic, can it? > > Jerry Cochran > RV6a wings > > ________________________________________________________________________________
Date: May 26, 2001
Subject: Re: RV8-List Digest: 2 Msgs - 05/25/01
In a message dated 5/25/01 10:54:05 PM, rv8-list-digest(at)matronics.com writes: << you got to be kidding, have a machine shop make the prop bolts! My life is worth more than a set of bolts.... Tom Schad A&P IA >> With all due respect.... ANY material such as stainless or nitrided steel or whatever can be EXACTLY duplicated. This is not rocket science, although with the prices folks like Cessna charge, you'd think it was. I totally respect your point of using only the "expensive brand" prop bolts, and when it comes time for mine, I'll probably do the same thing, but just because of the convenience, nothing else. But no doubt in my mind someone with the expertise and inclination could easily duplicate those. Any materials engineers or machinists out there want to weigh in on this one? Jerry Cochran Wilsonville, OR (that's right, 10 min. from Van's, lucky me.) RV6a wings ________________________________________________________________________________
Date: May 26, 2001
I'm using Vx=75 and Vy=95 knots. Best glide is about Vy too. Here are some other numbers collected: 7000 ft, 78% power, 2780 RPM, full throttle, GPS speed check: 163, 175, 177, 191average high cruise ground speed of 176 knots = 202.4 mph 45% power to maintain 65KI at full flaps 25% power to maintain 65KI at flaps 21% power to maintain 65KI at 0 flaps Stall, 6500 ft, no flaps, GPS speed check: 50KI, 51 knots into wind; 51KI, 71 knots downwindcall it 50 KI and 60 knots ground speed (= 70 mph) Stall, 6500 ft, full flaps, GPS speed check: 40KI, 42 knots into wind; 40KI, 56 knots downwindcall it 40 KI and 49 knots groundspeed (= 56 mph) Level 100 KI at 5000 ft took 23% power Using Technology Kitchen Engine Power Monitor Greg Miller RV8 N89GM, 55 hrs TT -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Randy Lervold Sent: Saturday, May 19, 2001 11:19 AM Subject: RV8-List: RV-8 Vx & Vy? Flying RV-8ers, What are you using for Vx and Vy? Also, what have you determined as "best glide" speed? Thanks, Randy Lervold www.rv-8.com ________________________________________________________________________________
Subject: insurance
Date: May 26, 2001
I have insurance through AIG: $60K hull and $1M liability for $1300/yr. Had to fly the first 25 hr without insurance though, since that was their minimum. Greg Miller RV8 N89GM, 55 hr -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Larry Bowen Sent: Saturday, May 19, 2001 9:35 PM Subject: RE: RV8-List: insurance Whoops. Spoke to soon. I just received a cancellation notice from GreatAmerican, the underwriter for my renters insurance from NationAir/VanGuard. "Because we have discontinued writing your class and type of risk." In my book, insurance rates right up there with taxes and root canals!! Larry Bowen RV-8 fuse Email: Larry(at)BowenAero.com Web: http://BowenAero.com > -----Original Message----- > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Larry Bowen > Sent: Saturday, May 19, 2001 11:26 AM > To: rv8-list(at)matronics.com > Subject: RE: RV8-List: insurance > > > The Van's-sponsered insurance, VanGuard, offers project coverage. > I have my > renters ins through them too. So far, so good. There is more > info on Van's > website. > > Larry Bowen > RV-8 fuse > Email: Larry(at)BowenAero.com > Web: http://BowenAero.com ________________________________________________________________________________
Date: May 26, 2001
Jerry: Yes, I think they can be that exotic. These bolts operate in an extremely difficult environment: shock, vibration, oscillating loads and more. They must be free of all residual stress, have no crystalline faults in the material and be corrosion proof, among other things. Your average machine shop can't come close. The suppliers of these things are probably making more than a good buck on them, but after paying for the product liability insurance they may not be doing as well as we think. Just my opinion. George Kilishek N888GK (reserved) 99% done. Probably never be finished. >From: Jerry2DT(at)aol.com >Reply-To: rv8-list(at)matronics.com >To: rv8-list(at)matronics.com >Subject: RV8-List: Re: RV8-List Digest: 3 Msgs - 05/24/01 >Date: Fri, 25 May 2001 16:33:54 EDT > > >Re the prop bolts.... > >Find out what material they're made from (must be gold :-)) and any machine >shop can machine the threads for you. Heck, it can't be THAT exotic, can >it? > >Jerry Cochran >RV6a wings > > ________________________________________________________________________________
Date: May 28, 2001
Matt: Did you ever get a definitive answer on this? My bird is about ready to fly and I haven't put those rivets in yet. George N888GK (reserved) >From: Matthew Gelber <mgelber(at)pacbell.net> >Reply-To: rv8-list(at)matronics.com >To: rv8-list(at)matronics.com >Subject: RV8-List: 8A spar center section rivets >Date: Sat, 19 May 2001 09:12:26 -0700 > > >I'm currently installing the floors and control tube in my -8A, and am >wondering when I rivet the two halves of the wing center section (F-804A >and >F-804B) together. I'm referring to the row of 12, 1/8" rivets that attach >the upper forward flanges together. The bottom side was riveted together >when I put the skins on, but I can't seem to find a reference to this top >row of rivets in the manual. Hopefully I didn't overlook it. > >I ask because I'm about to drill the bolt holes for the rear stick support. >Since the front stick support attaches to the front of the center section, >I >was wondering if the rivets I'm asking about should already be in. > >Matthew >-8A fuse > > ________________________________________________________________________________
Date: May 29, 2001
Subject: another dumb question
I have a RV8A...the fuse is almost finished, with the engine hung, wired, plumbed, ect...the wings are still off...is it safe to run the engine with the wings off, or will sturcture damage result?....thanks.. ________________________________________________________________________________
Subject: Re: another dumb question
Date: May 29, 2001
Don't think you'll do any structural damage. Why not wait till the wings are hung, though. Then you won't have to rig a fuel tank and feed. How you gonna tie it down? George N888GK >From: old ogre <jollyd(at)teleport.com> >Reply-To: rv8-list(at)matronics.com >To: "RV-8-List (E-mail)" >Subject: RV8-List: another dumb question >Date: Tue, 29 May 2001 18:43:51 -0700 > > >I have a RV8A...the fuse is almost finished, with the engine hung, >wired, plumbed, ect...the wings are still off...is it safe to run the >engine with the wings off, or will sturcture damage result?....thanks.. > > ________________________________________________________________________________
Subject: RV-8 ingress/egress
Date: May 31, 2001
Guys, Let me offer to start a very serious and controversial thread here, one that is surely to be looked up frequently in the archives... "What is the best way for passengers to get in and out of the back seat of an RV-8?" There, I asked, I admit it, I can't figure it out. I can build the friggin plane, but I can't for the life of me figure out an elegant way for passengers to get in and get out *without* stepping on my nice new DJ Lauritsen upholstery. So please offer up the results of your extensive ergonomic testing in this area for the benefit of all, and especially me! Of course demonstration pictures would always be appreciated, in fact I volunteer to post the winning technique on my site. Randy Lervold RV-8, N558RL, 33.1 hrs. www.rv-8.com ________________________________________________________________________________
Date: Jun 01, 2001
Subject: Re: RV-8 ingress/egress
Randy I have always accepted the fact that in this type of airplane YOU WILL step on the back seat. I am planning to have a small mat made up to place on both seats to step on until you get in. Will keep the dirt and stuff off of the seat and in turn off of your tail feathers. Nearly every airplane of this type that I have flown (Two holer, fore and aft) requires that you step on the seat. T-34's, Stearmans, T-6, Pitts, etc. I don't know of anyone who has the proper number of degrees of freedom at the base of the spine and leg intersection that will permit having one leg on the wing walk and the other on the floor of the airplane. I just finished a back operation and I can tell you for a fact that I sure as hell am not going to try to through my afterburner out of joint trying to reach the floor in one shot. Make a nice little pad to put on the seat, grab the roll bar, put your right foot on the seat and then raise the left foot and put it down in the cockpit. Depending on size you may want to continue to hold the roll bar and/or place one or both hands on the cockpit rails and lower yourself into the pit. Of course you have to get that right foot out of the way and you might want to let your seat pack slide down the seat back to keep from crashing onto the seat. By the way I looked at Jeff's RV-8 when it was here at 14A and he had three cushions made up for the back seat so that you could adjust the height for different passengers. Neat idea and I am going to copy it. I once crawled into a Mooney Mite and could not get out. You sit on the floor with a very thin seat cushion and there is no place to hook your heel to get any leverage to push yourself out. The cockpit rails, at the time, placed my arms at a point where I could not get any leverage to push myself up and out. Finally I had to summon my buddy and ask him to haul my fanny up far enough so I could get out of the damned thing. It was the first and last time for me in an M-18. Got a lot of laughs out of that over the years. Now lets see what some others have to say in this airmans ballet. Howard Cochran Mooresville, NC ________________________________________________________________________________
rv8list(at)yahoogroups.com, rv-list(at)matronics.com
Date: Jun 01, 2001
Ahhh, I can finally speak with experience, WITHOUT having my own flying RV-8! :) I'm 5'11", around 180lb and have by now had a few back seat rides in 2 different 8's. I have always been able to enter without stepping on the seat. Here's what I do: Before you start the routine, you must of course place the harness in a way so you won't sit on it. Also make sure the foot wells are clear. I find that sometimes maps etc. might slide down in them. 1) Step on the wing-walk with both feet, torso facing the cockpit. 2) Grab left side of roll bar with left hand and right side of turtle deck with right hand. 3) Put right foot ON THE FLOOR just forward of the seat and aft of the right rudder pedal. 4) Put left foot on the floor just forward of the seat and aft of the left rudder pedal. 5) Move hands to grab sides (on the rails I think) one at the time - left first. 6) Slide in, get comfy, make sure you don't obstruct the stick and enjoy the fantastic view. I get out by reversing the technique: Pull feet towards yourself and stand up by hanging on to the rails first then change grip to roll-bar/turtle deck and left foot out first (this is a wee bit tough - I have to stretch. Then right foot out. If your voice sounds like Michael Jackson's when you say "thanks for a terrific ride", you should get medical attention first, then read my instructions again... The other option is something I think Terry Jantzi did: Cut a Styrofoam piece into the shape of a size 12 foot (pucker factor). The passenger can then drop the 'foot' in the seat, stand on it and slide in. You should probably remove the 'foot' before sitting down to avoid discomfort... :) NOTE: I noticed that one builder installed the fire extinguisher on the left wall just under the rail. This seem to conflict with the knees of passengers that are taller than 6'2". It was also in the way when exiting the seat since the left foot had to be lifted higher at an earlier stage. Another installation I saw was behind the pilots seat-back; up fairly high. This was nice and does not interfere with the passenger. I'm not sure how easy the pilot can reach it though. I will try it sometime before installing mine. I will be able to take pictures of this tomorrow if anyone is interested. Are RV-8 Wings -----Original Message----- From: Randy Lervold [mailto:randy@rv-8.com] Sent: June 1, 2001 12:49 AM rv-list(at)matronics.com Subject: RV8-List: RV-8 ingress/egress Guys, Let me offer to start a very serious and controversial thread here, one that is surely to be looked up frequently in the archives... "What is the best way for passengers to get in and out of the back seat of an RV-8?" There, I asked, I admit it, I can't figure it out. I can build the friggin plane, but I can't for the life of me figure out an elegant way for passengers to get in and get out *without* stepping on my nice new DJ Lauritsen upholstery. So please offer up the results of your extensive ergonomic testing in this area for the benefit of all, and especially me! Of course demonstration pictures would always be appreciated, in fact I volunteer to post the winning technique on my site. Randy Lervold RV-8, N558RL, 33.1 hrs. www.rv-8.com ________________________________________________________________________________
Date: Jun 03, 2001
Subject:
unsubscribe dweb5(at)adams.net ________________________________________________________________________________
Date: Jun 04, 2001
Subject: Re: RV8-List Digest: 1 Msgs - 06/03/01
Please unsubscribe bbsumrell@cs/.com Thank you ,BBS ________________________________________________________________________________
Date: Jun 09, 2001
Subject: Re: RV8-List Digest: 0 Msgs - 06/07/01
Still need some basic tools like 3x Rivet Gun, Microstop countersinks, C bench dimpler, Deburring Set, etc. I am about to embark on a first-time F1 Rocket kit build and I would like to save $ by acquiring used tools from a prior builder. Please do not reply through the list, but directly to me: DvdBock(at)AOL.com ________________________________________________________________________________
Date: Jun 09, 2001
Subject: RV8 Empennage for sale
Well, it's taken me a year to finish the empennage , and I've come to the conclusion that it's going to take me a long time to get this project done, so I'm going to sell it and look for another avenue to get into the air. So.... FOR SALE: finished RV8 empennage, with serial number, plans, builders manual. Internal services primed, excellent workmanship (checked by A&P early on). Asking $2200. Also, will negotiate on selling some tools ( 3X rivet gun, Tatco squeezer, C-tool, rivet sets, dies, etc.). Have digitized photos of project that I can send you if interested. Steve Prull Bend, OR 541-383-8277 sprull(at)bendcable.com ________________________________________________________________________________
Date: Jun 11, 2001
Subject: Update:RV8 Empennage for sale
The RV8 empennage is still for sale - but I'm open on the price. I placed $2200 in the previous ad, not having any idea of what such things go for, and hoping to get something for my labor. On the other hand, perhaps I'm dreaming :-) , so I'll just say "Best Offer" Steve Prull Bend, OR 541-383-8277 sprull(at)bendcable.com ________________________________________________________________________________
Date: Jun 12, 2001
Subject: Oshkosh RV-8/A meetings
Oshkosh is sneaking up again this year, especially so for those of you who are scrambling to finish in time to make the event in your new RVs! Each of the last few years, an informal gathering of RV-8 and -8A builders has been organized during Oshkosh so that faces can be put with names, and old acquaintences be renewed. Since so many of you have been so helpful to me while I continue to stumble along, I've really enjoyed finally meeting and thanking you for all your help. I think it's been a good time for all who've dropped by. This year, Oshkosh ("AirVulture" or "AirVenture", whichever you prefer) starts on Tuesday, July 24 and runs through Monday, July 30. Traditionally, we've held the meetings under an open tree in the Theater in the Woods area, twice during the convention, for any who can show up. Thursday, July 26 at 9:00am and Sunday, July 29 at 10:00 should allow time for most who'd like to gather to do so. If there are major conflicts with seminars or something, we can always change the schedule. So, for you control freaks, check your calendars and seminar schedules and let me know if these times are bad. Otherwise, they'll be chiseled in stone. I'll be posting this note to the RV-Lists again in July, as Oshkosh looms closer. As always, these gatherings are NOT exclusive--anyone may attend. It's just a time to meet other RV-8 builders and swap lies. Oh, and bring your own coffee and doughnuts. I don't think Bob Dimeo can carry enough for all of us! --Don McNamara N8RV ________________________________________________________________________________
Subject: Re: [rv8list] Oshkosh RV-8/A meetings
Date: Jun 12, 2001
Fellow -8ers, Look forward to meeting again. Thursday at 9 am sounds good. See you there Larry RV-8QB 81251 From: N8RV(at)gte.net Subject: [rv8list] Oshkosh RV-8/A meetings Date: Tue, 12 Jun 2001 10:34:43 -0500 Oshkosh is sneaking up again this year, especially so for those of you who are scrambling to finish in time to make the event in your new RVs! Each of the last few years, an informal gathering of RV-8 and -8A builders has been organized during Oshkosh so that faces can be put with names, and old acquaintences be renewed. Since so many of you have been so helpful to me while I continue to stumble along, I've really enjoyed finally meeting and thanking you for all your help. I think it's been a good time for all who've dropped by. This year, Oshkosh ("AirVulture" or "AirVenture", whichever you prefer) starts on Tuesday, July 24 and runs through Monday, July 30. Traditionally, we've held the meetings under an open tree in the Theater in the Woods area, twice during the convention, for any who can show up. Thursday, July 26 at 9:00am and Sunday, July 29 at 10:00 should allow time for most who'd like to gather to do so. If there are major conflicts with seminars or something, we can always change the schedule. So, for you control freaks, check your calendars and seminar schedules and let me know if these times are bad. Otherwise, they'll be chiseled in stone. I'll be posting this note to the RV-Lists again in July, as Oshkosh looms closer. As always, these gatherings are NOT exclusive--anyone may attend. It's just a time to meet other RV-8 builders and swap lies. Oh, and bring your own coffee and doughnuts. I don't think Bob Dimeo can carry enough for all of us! --Don McNamara N8RV ________________________________________________________________________________
Subject: Re: Oshkosh RV-8/A meetings
Date: Jun 12, 2001
My wife (Tina) I will definitely make one of those meetings, even if we do have to bring our own munchies! I am about to order the finish kit. Do Not Archive Bill & Tina Christie, RV8A, finishing up fuselage ----- Original Message ----- From: <n8rv(at)gte.net> Sent: Tuesday, June 12, 2001 8:34 AM Subject: RV8-List: Oshkosh RV-8/A meetings > > Oshkosh is sneaking up again this year, especially so for those of you > who are scrambling to finish in time to make the event in your new RVs! > > Each of the last few years, an informal gathering of RV-8 and -8A > builders has been organized during Oshkosh so that faces can be put with > names, and old acquaintences be renewed. > > Since so many of you have been so helpful to me while I continue to > stumble along, I've really enjoyed finally meeting and thanking you for > all your help. I think it's been a good time for all who've dropped by. > > This year, Oshkosh ("AirVulture" or "AirVenture", whichever you prefer) > starts on Tuesday, July 24 and runs through Monday, July 30. > Traditionally, we've held the meetings under an open tree in the Theater > in the Woods area, twice during the convention, for any who can show up. > > Thursday, July 26 at 9:00am and Sunday, July 29 at 10:00 should allow > time for most who'd like to gather to do so. > > If there are major conflicts with seminars or something, we can always > change the schedule. So, for you control freaks, check your calendars > and seminar schedules and let me know if these times are bad. > Otherwise, they'll be chiseled in stone. > > I'll be posting this note to the RV-Lists again in July, as Oshkosh > looms closer. As always, these gatherings are NOT exclusive--anyone may > attend. It's just a time to meet other RV-8 builders and swap lies. > > Oh, and bring your own coffee and doughnuts. I don't think Bob Dimeo > can carry enough for all of us! > > --Don McNamara > N8RV > > ________________________________________________________________________________
Date: Jun 12, 2001
Thursday, July 26th at 9:00am sounds great. I look forward to meeting all you fellow RV-8 builders. --Glenn Vokac RV-8 #81376 ----- Original Message ----- From: <n8rv(at)gte.net> Sent: Tuesday, June 12, 2001 10:34 AM Subject: RV8-List: Oshkosh RV-8/A meetings > > ________________________________________________________________________________
Subject: rv-8 for sale
Date: Jun 12, 2001
Post message RV-8 for sale. Marriage forces sale She wants a RV-7 Wings and fuel cells assembled.. awaiting rigging and top sheet of skin on wings. Landing lights installed... tail beautifuly done as well. Extra RV-8 tail partially assembled for extra or seperate. All except finishing kit included in kit. Please email brianpwallis(at)hotmail.com or brianpwallis(at)aol.com 315-775-7913home 315-486-3117cell Will consider all offers. Thank you. Brian Wallis ________________________________________________________________________________
Date: Jun 13, 2001
Subject: tow bar?
has anyone "invented" a tow bar for the nose gear of a RV8A?...it sure would come RV8A finishing, finishing, finis.....h.....i..... ________________________________________________________________________________
Subject: RV-8 project for sale
Date: Jun 17, 2001
Listers: Four or five days ago I posted about a RV-8 project for sale due to the builder passing away. Yesterday, I borrowed a digital camera, visited his widow's house and took my first digital pictures of his project. This morning my 16 year old son created a Web site on Tripod where he placed the pictures for all interested to view. I included the description of what is included in the project, and what work remains to be done. Look at: http://rv-8project.tripod.com/index.html The asking price is $40,000. I can be reached at this e-mail address or 512/261-4122 (home) or 512/626-7886 (cell). I will be out of town from Wednesday until the following Monday. Mark Frederick of Team Rocket also is familiar with the project and can be reached at 512/365-8131(Work). I believe he also will be out of town the later part of the week. You could be flying in a very few months of work. Mark Goldberg ________________________________________________________________________________
Subject: Re: RV-8 project for sale
Date: Jun 17, 2001
Hi Mark, Sorry about the passing of you friend and hopefully you'll be able to see his project for his widow quickly. I noticed that the project is located near the Austin area and I had a question about that area. My wife and I might have a business opportunity that could take us to the Austin area and we were curious about living in the area. Do you know if there are any "Aero Communities" in the immediate vicinty of Austin? If so do you know if they have a web site or other means of getting information about homes for sale at those communities? I'm currently completing the wings on my RV6 project and while I don't relish the idea of relocating myself and my wife "again", we might do it if the job opportunity is right. Thanks Mike Nellis - http://bmnellis.com Plainfield, IL RV6 N699BM (res) Building Flaps Stinson 108-2 N9666K ________________________________________________________________________________
Date: Jun 18, 2001
Listers, yesterday I posted a message about my late friend's rv-8 almost finished project for sale. My son attempted to load up some digital pictures on a website. Several people contacted me off-list that the text was there, but no pictures. Well my son says he has the pictures loaded correctly now for your viewing pleasure. (Thanks Bill VonDane & Cy Galley). Info on the project and the pictures are at: http://rv-8project.tripod.com/index.html I had hoped to make yall laugh with some antecdotes of my friend. But I am leaving town shortly. No time. Please spread the word to interested people so my friend's widow can sell the project. Asking price $40,000. My numbers are: 512/261-4122 (hm)& 512/626-7886 (cell) Mark Goldberg RV-8 N982RV flying ________________________________________________________________________________
Subject: Rv-8 kit for sale
Date: Jun 27, 2001
post message Hello, The RV-8 kit is still for sale; marriage and college dues draw landing lights already installed)..(gas tanks already done!) FUSELAGE NEW IN BOX. Extra tail just started available with kit as package deal. Please tell your friends.. Aircraft kit located in NY. 20 min North of Syracuse.. Local Mailboxes ETC will package and mail anywhere. 315-775-7913 home 315-772-4109 work 315-486-3117 cell brianpwallis(at)hotmail.com brianpwallis(at)aol.com Thank you for your time. Brian Wallis ________________________________________________________________________________
From: "Todd W. Rudberg" <todd_rudberg(at)yahoo.com>
Subject: RV8ers weight and balance.
Date: Jul 02, 2001
All, I would like to compile a list of RV8 weight and balance sheets. If you have completed this stage of your RV8, please email me the W&B for you ac and I will make a table. Include things like Engine, prop (weight and type) and battery location and any other points you think are important. I will post the results on my developing web site. I think this will really help those of us who are still making decisions affecting W&B. Like for instance, when I started my RV8 I weighed 230#s...I am now 175, that should help my ac weight problems a bit. I am dedicated to keeping weight down where possible. Thanks in advance for your help. Todd W. Rudberg RV-8 Wings (N232TB Reserved) mailto:todd_rudberg(at)yahoo.com www.geocities.com/todd_rudberg Home: (425)290-7526 Cell: (425)870-5300 ________________________________________________________________________________
Date: Jul 02, 2001
This weight and balance program for the RV-8 is great (and free)! www.geocities.com/ghale5224 -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Todd W. Rudberg Sent: Monday, July 02, 2001 11:10 AM Subject: RV8-List: RV8ers weight and balance. All, I would like to compile a list of RV8 weight and balance sheets. If you have completed this stage of your RV8, please email me the W&B for you ac and I will make a table. Include things like Engine, prop (weight and type) and battery location and any other points you think are important. I will post the results on my developing web site. I think this will really help those of us who are still making decisions affecting W&B. Like for instance, when I started my RV8 I weighed 230#s...I am now 175, that should help my ac weight problems a bit. I am dedicated to keeping weight down where possible. Thanks in advance for your help. Todd W. Rudberg RV-8 Wings (N232TB Reserved) mailto:todd_rudberg(at)yahoo.com www.geocities.com/todd_rudberg Home: (425)290-7526 Cell: (425)870-5300 ________________________________________________________________________________
Subject: RV-8 F-826, 827 & 842 heads up
Date: Jul 03, 2001
If you follow the plans and directions from Van's regarding the sequence of attaching the bottom skins on the RV-8 you could wind up not being able to line up the match holes in the 842 to the matching holes in the 826 and 827. Kevin Horton describes this problem with a suggested alternative installation method and solution in the archives. I have included an excerpt from his post below. As I have encountered the same problem, I suspect others have and will. This is sent in hopes it will alert other builders and save them another hassle. I suggest when you reach this stage, that you cleco the 842 to the 826 and 827 which will make sure the match holes line up before attaching the 826 and 827 to the rib structure. My version of the Orndoff videos doesn't mention this problem either so if you watch the video and follow the plans to the letter, you assume that attaching the 826, 827 and 842 bottom skins is straight forward. It isn't. Regards, Vince Himsl RV8 fuselage Moscow, Idaho USA Excerpt from Archive ---- Message: #66396 Date: Jan 17, 2000 From: Kevin Horton <khorton(at)cyberus.ca> Subject: RV-8 F-826, 827 & 842 gotcha Hi guys and gals, I'm drilling the skins to my RV-8 fuselage, and had a minor gotcha tonight. Not a real big deal, but I sure wish I could do it all over again, knowing what I know now. I drilled the F-826 & F-827 bottom center skins. They cleco to the F-804 at the front, and then just sit on top of the seat ribs until you drill and cleco them. So far so good (so I thought). Then I grabbed the F-842 aft bottom skin, and slipped it under the F-826 & F-827. It has match holes that are supposed to match up with holes at the aft end of the F-826 & F-827. Well, I quickly discovered that I couldn't match up with both the F-826 & F-827 at the same time. It turns out that there is enough slop in the holes clecoed at the front of the F-826 & F-827 to let the aft ends move slightly. I ended up with the aft ends of the F-826 & 827 about 3/32 inch too close together, i.e. the holes that should match up with the F-842 were 3/32 too close together. How do you prevent this from happening? Well, I would do two things differently if I could do it all over again. First, when drilling the F-822 (or F-890 for the -8A), I wouldn't drill out the holes that hold it to the F-804. Those are the holes that you cleco the F-826 & 827 to, so you will get a tighter fit if they are not drilled out yet. You have to drill them again when fitting the F-826 & 827 anyway, so there is no point in doing them when fitting the F-822. Second, when drilling the F-826 & 827, I would consider clecoing them to the F-804, and then putting the F-842 in place, clecoing the match holes in it to the F-826 & 827. Then I would drill the center hole at the aft edge of the F-826 & F-827 to lock them together. That way you have a reference to make sure that the match holes on the aft edges of the F-826 & 827 are right distance apart when fitting the F-842. Anyway, it wasn't a big disaster. I drilled a couple of extra holes to compensate for the figure 8 ones I've got now. It is on the bottom of the fuselage... ________________________________________________________________________________
Date: Jul 08, 2001
I have a nippondenso altenator taken from a chevy sprint.. it has the internal volt reg...the plug coming out of the back of it has three wires..one white, one light yellow, and one black....can't find the wiring diagram for the sprint anywhere...can some kind soul please tell me where the **** these wires go....?...no, they won't fit...there..{:~)...thank you so much... RV8A..waiting on exhaust pipes, then..paint.. ________________________________________________________________________________
Date: Jul 12, 2001
Subject: Whelen Strobe Wiring
From: "Ed O'Connor" <edwardoconnor(at)compuserve.com>
I am installing the terminals for my Whelen Strobes and need to know the wiring order for the color wires which plug into the central power supply. The drawing on top states Pin #1 is Anode and Pin #2 is Cathode and Pin #3 is Trigger. The Power supply is the A413AHDA-CF-14/28 The wire cable I purchased with power supply is Red, Black, Clear and an unshielded Ground wire. The strobes have corresponding color wires attached to them. I just can't figure out which color I should plug into which hole on the three pin plastic connector they furnished. Can anyone on list offer their expertise. Thanks in advance. E-mail off line if you desire to < Edwardoconnor(at)compuserve.com >. I only get the digest list the day after they are all compiled. Ed O'Connor/Sandy Creek Airpark/Panama City, FL N366RV RV-8/ working on fuselage installing ELT and Strobes behind Baggage Compartment. Landing Gear is next. ________________________________________________________________________________
Date: Jul 13, 2001
Subject: RV-8 Grove Gear Deal
Inspired by an excellent deal on Todds Canopy, I contacted Robbie Grove to inquire about a group discount on his Aluminum Gear and Dual Piston Wheel/Brake Sets. The gear saves 16 to 17lb vs. the steel gear (verified by a -8 customer) - and looks better to boot. Please see the Grove web site for details www.groveaircraft.com. I will delete these items from my Vans kits, its a couple hundred dollars difference. Robbie offered the following at a 10% discount, based on 3 orders. PN 1220-1 $1099.00 RV 8 Landing Gear Retrofit Kit PN 56-1 539.00 500 X 5 HP Wheel & Brake Assy PN 5013 2 x 38.60 ea $ 77.20 500 X 5 Axles PN 5710 4 x 3.00 ea $12.00 Spacers PN 5510 2 x 11.00 ea $22.00 Axle Nuts TOTAL $1749.20 10% Discount -174.92 TOTAL PRICE FOR ABOVE $1574.28 Grove Aircraft Company 1860-I Joe Crosson Drive El Cajon, CA 92020 1-888-GEARLEG (432-7534) Toll-Free 1-619-562-3274 Fax www.groveaircraft.com robbie(at)groveaircraft.com technical engineer teena(at)groveaircraft.com customer service Please let me know if there are any other takers... Thanks Frank Dombroski RV-8 One wing done, the other closing in. FB Fuse... ________________________________________________________________________________
Date: Jul 14, 2001
Subject: RV-8 Cooling ramp
Seems like this is geting harder. I am about to begin installing the forward belly skins and was studying drawings and found something I don't understand. Or should I say another thing I don't understand. For you RV-8 builders, drawing 36 - R2 (dated 6/98) on the exploded view, view AA and View FF all show 2 AN 257-P3 hinges attached to the 802KPP. The 11 1/2" hinge attaches to 802Kpp for the 867 cooling ramp. The other hinge 7" long also attaches to 802PP but will be covered by the 851PP. WHAT IS THE PURPOSE OF THE 7" hinge?? Vidio tapes do not address this hinge nor does Van's directions. Drawing 36A dated Feb/98 for RV-8A does not show this 7" hinge. Any help from those whoe have been here already? Ed O'Conor/Sandy Creek Airpark/Panama City FL RV-8/N366RV ________________________________________________________________________________
Subject: Tip Tanks & Check Valves
Date: Jul 14, 2001
We have installed the Van's tip tanks on our RV-8. We find that fuel will seep from the mains to the tips past the "one way" check valves. In poking around a bit on the www we find that there are all manner of check valves. Some are spring loaded and claim to be positively zero leaking. Others use a floating ball valve. Andair makes two, one of which is drilled to ALLOW "bleed back" It looks to me that check valves are used for a wide verity of purposes and they are not designed or made equal. Yet in the common aviation catalogs we've looked at no distinction is made. Any info on the zero leakage check valve of choice for use with tip tanks? Thanks Ronin Colman RV-8 N591RC 6+ hours ________________________________________________________________________________
From: "Arthur and Christine" <act(at)voyager.co.nz>
Date: Jul 15, 2001
The 7" hinge acts as a guide for the hinge pin through the cooling ramp. This pin is inserted through a hole in the side of the 851pp. Cheers Arthur Whitehead RV-8 installing baffles and gear leg fairings. -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Ed O'Connor Sent: Sunday, 15 July 2001 13:33 Subject: RV8-List: RV-8 Cooling ramp Seems like this is geting harder. I am about to begin installing the forward belly skins and was studying drawings and found something I don't understand. Or should I say another thing I don't understand. For you RV-8 builders, drawing 36 - R2 (dated 6/98) on the exploded view, view AA and View FF all show 2 AN 257-P3 hinges attached to the 802KPP. The 11 1/2" hinge attaches to 802Kpp for the 867 cooling ramp. The other hinge 7" long also attaches to 802PP but will be covered by the 851PP. WHAT IS THE PURPOSE OF THE 7" hinge?? Vidio tapes do not address this hinge nor does Van's directions. Drawing 36A dated Feb/98 for RV-8A does not show this 7" hinge. Any help from those whoe have been here already? Ed O'Conor/Sandy Creek Airpark/Panama City FL RV-8/N366RV ________________________________________________________________________________
Date: Jul 15, 2001
Subject: distance?
I'm fitting the wing tips to an RV8A ..(thinking of paint)..noticed that the plans call for 1-1/2 spacing of the screws/rivets holding the tip on....I have seen a LOT of RV's out on the ramp with spacing at least 4" apart..Is there any fast and set rule as to spacing here?..thanks.. ________________________________________________________________________________
Subject: distance?
Date: Jul 15, 2001
Most RV's don't have tip tanks, so the tip weight is less of an issue. We put ours @ 1.5 -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of old ogre Sent: Sunday, July 15, 2001 10:57 AM Subject: RV8-List: distance? I'm fitting the wing tips to an RV8A ..(thinking of paint)..noticed that the plans call for 1-1/2 spacing of the screws/rivets holding the tip on....I have seen a LOT of RV's out on the ramp with spacing at least 4" apart..Is there any fast and set rule as to spacing here?..thanks.. ________________________________________________________________________________
Subject: RE: RV8-List Digest: 1 Msgs - 07/13/01
Date: Jul 16, 2001
I wonder if this is possible for a 7 or 7A? - - - - - From: Frank Dombroski <f_dombroski(at)yahoo.com> Subject: RV8-List: RV-8 Grove Gear Deal Inspired by an excellent deal on Todds Canopy, I contacted Robbie Grove to inquire about a group discount on his Aluminum Gear and Dual Piston Wheel/Brake Sets. The gear saves 16 to 17lb vs. the steel gear (verified by a -8 customer) - and looks better to boot. Please see the Grove web site for details www.groveaircraft.com. I will delete these items from my Vans kits, its a couple hundred dollars difference. Robbie offered the following at a 10% discount, based on 3 orders. PN 1220-1 $1099.00 RV 8 Landing Gear Retrofit Kit PN 56-1 539.00 500 X 5 HP Wheel & Brake Assy PN 5013 2 x 38.60 ea $ 77.20 500 X 5 Axles PN 5710 4 x 3.00 ea $12.00 Spacers PN 5510 2 x 11.00 ea $22.00 Axle Nuts TOTAL $1749.20 10% Discount -174.92 TOTAL PRICE FOR ABOVE $1574.28 Grove Aircraft Company 1860-I Joe Crosson Drive El Cajon, CA 92020 1-888-GEARLEG (432-7534) Toll-Free 1-619-562-3274 Fax www.groveaircraft.com robbie(at)groveaircraft.com technical engineer teena(at)groveaircraft.com customer service Please let me know if there are any other takers... Thanks Frank Dombroski RV-8 One wing done, the other closing in. FB Fuse... ________________________________________________________________________________
Subject: Re: RE: RV8-List Digest: 1 Msgs - 07/13/01
Date: Jul 16, 2001
Frank, Is the Grove wheel and brake assembly usable on the steel landing gear? If so, how is it better than what Van's offers. I would go for the aluminum gear, but I have already received the steel gear. Larry RV-8 1251 Ready to mount the LG From: John Jessen <jjessen(at)CMBINFO.com> Subject: RV8-List: RE: RV8-List Digest: 1 Msgs - 07/13/01 Date: Mon, 16 Jul 2001 10:01:26 -0400 I wonder if this is possible for a 7 or 7A? - - - - - From: Frank Dombroski <f_dombroski(at)yahoo.com> Subject: RV8-List: RV-8 Grove Gear Deal Inspired by an excellent deal on Todds Canopy, I contacted Robbie Grove to inquire about a group discount on his Aluminum Gear and Dual Piston Wheel/Brake Sets. The gear saves 16 to 17lb vs. the steel gear (verified by a -8 customer) - and looks better to boot. Please see the Grove web site for details www.groveaircraft.com. I will delete these items from my Vans kits, its a couple hundred dollars difference. Robbie offered the following at a 10% discount, based on 3 orders. PN 1220-1 $1099.00 RV 8 Landing Gear Retrofit Kit PN 56-1 539.00 500 X 5 HP Wheel & Brake Assy PN 5013 2 x 38.60 ea $ 77.20 500 X 5 Axles PN 5710 4 x 3.00 ea $12.00 Spacers PN 5510 2 x 11.00 ea $22.00 Axle Nuts TOTAL $1749.20 10% Discount -174.92 TOTAL PRICE FOR ABOVE $1574.28 Grove Aircraft Company 1860-I Joe Crosson Drive El Cajon, CA 92020 1-888-GEARLEG (432-7534) Toll-Free 1-619-562-3274 Fax www.groveaircraft.com robbie(at)groveaircraft.com technical engineer teena(at)groveaircraft.com customer service Please let me know if there are any other takers... Thanks Frank Dombroski RV-8 One wing done, the other closing in. FB Fuse... ________________________________________________________________________________
Subject: FW: RV-8 Tailwheel Assembly Installation
Date: Jul 17, 2001
I have installed the tailwheel assembly and of course it isn't correct. Using the method shown in Orndoff video of placing the level on each side of the wheel axel mount I find that the mount has to be turned 13 degrees off center to show level. The axel itself seems to line up with the fuselage center line. Rotating the assembly until centered and level shows that the hole through the 409 was off by a little under 1/16 ". Looks like you know what too. Question: Before I order a new tailwheel assembly (ouch) and wd-409 and start over, are there alternative fixes and or suggestions? Regards and Thanks! Vince Himsl RV8 Fuselage Moscow, ID USA ________________________________________________________________________________
Subject: Re: FW: RV-8 Tailwheel Assembly Installation
Date: Jul 18, 2001
Vince: I'm not sure you need to do anything. If I understand correctly what you've said, you might be riding a little bit on one side of the tailwheel, and maybe it'll wear out a little sooner than otherwise (maybe not), but I wouldn't expect any ground handling problems. Just one man's opinion. George Kilishek N888GK Final assembly ----- Original Message ----- From: Vincent S. Himsl Sent: Tuesday, July 17, 2001 11:36 PM Subject: RV8-List: FW: RV-8 Tailwheel Assembly Installation I have installed the tailwheel assembly and of course it isn't correct. Using the method shown in Orndoff video of placing the level on each side of the wheel axel mount I find that the mount has to be turned 13 degrees off center to show level. The axel itself seems to line up with the fuselage center line. Rotating the assembly until centered and level shows that the hole through the 409 was off by a little under 1/16 ". Looks like you know what too. Question: Before I order a new tailwheel assembly (ouch) and wd-409 and start over, are there alternative fixes and or suggestions? Regards and Thanks! Vince Himsl RV8 Fuselage Moscow, ID USA = = = = Get more from the Web. FREE MSN Explorer download : http://explorer.msn.com ________________________________________________________________________________
From: "FtpBandit@web-unwired.net" <FtpBandit@web-unwired.net>
Subject: Louisville Kentucky Builders
Date: Jul 22, 2001
Hello, This is my first post so I hope I did it rite... I was just woundering if anyone is building in the Louisville Kentucky area? my neighbor and I are getting ready to order and build a 7a and a 9a in my garage and was wanting to get a support group together close to home. Thanks Jeff Garrett ________________________________________________________________________________
Date: Jul 23, 2001
Subject: Re: Louisville Kentucky Builders
Welcome to the list Jeff. This is one of the best support groups that you will find. I have several hundred pictures that I have downloaded from the various sites and they are all RV-8 photos showing something of interest. It has been very helpful. Don't forget the electrical listing when you get there. You can get a lot of help there too. Howard 1/2 of RV-8 80188 Sloooow build Working on wiring Mooresville, NC ________________________________________________________________________________
Date: Jul 26, 2001
Subject: Exhaust Systems??
All, I have an old tripacer crossover exhaust system thats been around a long time with lots of patches and welding. After much soul searching, I have decided not to trust the old relic and buy a new exhaust. Vans has one for $630, which is alot for a couple of pipes, and I was wondering if anyone has had good success with anything else? I do want to stay with stainless for obvious reasons and muffler shops have mostly carbon steel, which will quickly rust out. I ask if anyone has thought about this. thanks Dan Ward 81243 N417SN (reserved) Firewall forward ________________________________________________________________________________
Date: Jul 26, 2001
Subject: Re: Exhaust Systems??
believe me...after "playing" with an lycoming exhaust for several days, the vetterman (van's) is the ONLY way to go..it made it a pleasure to install..in fact it was about the only thing that has NOT given me some sort of trouble since the entire project began....by all means ..lay out the bucks ..you will not regret it.. RV8A thinking andsaving for paint. TwoAviators wrote: > > All, > > I have an old tripacer crossover exhaust system thats been around a long > time with lots of patches and welding. After much soul searching, I have > decided not to trust the old relic and buy a new exhaust. Vans has one for > $630, which is alot for a couple of pipes, and I was wondering if anyone > has had good success with anything else? > > I do want to stay with stainless for obvious reasons and muffler shops have > mostly carbon steel, which will quickly rust out. I ask if anyone has > thought about this. > > thanks > > Dan Ward > 81243 > N417SN (reserved) > Firewall forward > ________________________________________________________________________________
Date: Jul 27, 2001
Subject: Re: RV8 Exhaust
I am working with a local mfr who is designing a stainless or titanium sys for the -8. It will be several months until my QB fuse arrives and we finish the sys. If you are in need now - no juy... Regards Frank > From: TwoAviators <TwoAviators(at)lexcominc.net> > Subject: RV8-List: Exhaust Systems?? > > > > All, > > I have an old tripacer crossover exhaust system > thats been around a long > time with lots of patches and welding. After much > soul searching, I have > decided not to trust the old relic and buy a new > exhaust. Vans has one for > $630, which is alot for a couple of pipes, and I was > wondering if anyone > has had good success with anything else? > > I do want to stay with stainless for obvious reasons > and muffler shops have > mostly carbon steel, which will quickly rust out. I > ask if anyone has > thought about this. > > thanks > > Dan Ward > 81243 > N417SN (reserved) > Firewall forward > > > > > ________________________________________________________________________________
Date: Jul 27, 2001
Dan: My advice: buy the Vetterman exhaust from Van's. It's proven. It's a cinch to install. You won't find anything cheaper that works and has a decent service life. You'll have lots of other fun things to think about in firewall forward (like oil coolers, among others)...you don't need to reinvent the wheel on exhaust systems. Just one man's opinion. George Kilishek N888GK Final assembly >From: TwoAviators <TwoAviators(at)lexcominc.net> >Reply-To: rv8-list(at)matronics.com >To: rv8-list(at)matronics.com >Subject: RV8-List: Exhaust Systems?? >Date: Thu, 26 Jul 2001 22:29:45 -0400 > > >All, > >I have an old tripacer crossover exhaust system thats been around a long >time with lots of patches and welding. After much soul searching, I have >decided not to trust the old relic and buy a new exhaust. Vans has one for >$630, which is alot for a couple of pipes, and I was wondering if anyone >has had good success with anything else? > >I do want to stay with stainless for obvious reasons and muffler shops have >mostly carbon steel, which will quickly rust out. I ask if anyone has >thought about this. > >thanks > >Dan Ward >81243 >N417SN (reserved) >Firewall forward > > ________________________________________________________________________________
Date: Aug 04, 2001
From: Kevin & Theresa Horton <khorton(at)cyberus.ca>
Subject: AeroElectric-List: WEEKEND SEMINAR - Need list server relay
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" I used o participate in about a dozen list-server activities but he e-mail burden became too much. Matt Dralle graciously offered relief with his support of the Aero-Electric List. I would sincerely appreciate it if the folks who frequent the Aero-Electric List could relay the following information to other amateur built airplane list-servers on which they participate: Thanks! ----- Electrical Systems Weekend Seminar ----------- The next weekend seminar we're presenting starts two weeks from tomorrow, August 18, in Racine, WI. Dee and I will be driving from Wichita and we'd like a chance to meet many of you and talk about your project. We're meeting on the John H. Batten airport. Some of you may be able to fly in daily and join us for some down and dirty electro-speak. See: http://www.aeroelectric.com/Racine.html for times, location and local hotel information. Bob . . . ---------------------------------------------- ( "The Wright brothers flew right through the ) ( smoke screen of impossibility." ) ( Charles F. Kettering ) ---------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Subject: test
Date: Aug 05, 2001
test ________________________________________________________________________________
Date: Aug 29, 2001
Subject: RV-8 Forward Bottom Skin Insulation
I am about to begin riviting the forward bottom skins on to fuselage of my RV-8 and trying to decide if some kind of insulation could be installed between floor and outer skins. I searched the arcives and did not find anything about this. I know the plans call for using pro seal to seal the skins and ribs but thought someone might have installed some kind of lighweight foam insulation and if so was it worth it? Reply to list or to me at edwardoconnor(at)compuserve.com. Thanks: PS If anyone is thinking of installing the alumunum gear, I bought mine from Hammerhead. Fit but the gear legs are thicker and the steel mounting brackets are much higher. They require some modifications to the skins and the cross braces on the belly. Mine are also gun drilled for the brake lines and that required some changes to mounting the brake lines. If anyone needs more details contact me and I will explane the changes required. Ed OConnor/RV-8/Sandy Creek Airpark/Panama City Fl/N366RV ________________________________________________________________________________
Date: Aug 30, 2001
We did not put insulation in - very very hot floor. Went back and added it - as much as would fit, Huge improvement. I am about to begin riviting the forward bottom skins on to fuselage of my RV-8 and trying to decide if some kind of insulation could be installed between floor and outer skins. I searched the arcives and did not find anything about this. I know the plans call for using pro seal to seal the skins and ribs but thought someone might have installed some kind of lighweight foam insulation and if so was it worth it? Reply to list or to me at edwardoconnor(at)compuserve.com. Thanks: PS If anyone is thinking of installing the alumunum gear, I bought mine from Hammerhead. Fit but the gear legs are thicker and the steel mounting brackets are much higher. They require some modifications to the skins and the cross braces on the belly. Mine are also gun drilled for the brake lines and that required some changes to mounting the brake lines. If anyone needs more details contact me and I will explane the changes required. Ed OConnor/RV-8/Sandy Creek Airpark/Panama City Fl/N366RV ________________________________________________________________________________
Subject: 6 or 8 inch bench grinder?
Date: Aug 31, 2001
Sears has a sale on bench grinders. I was planning on a 6 inch. Is there any need for an 8 inch for RV building? The Scotch Brite wheels come in both. Thanks in advance. Kevin, RV8 tail ________________________________________________________________________________
Date: Aug 30, 2001
Subject: small questions
Small things... Facet boost pump is noisy, is this right? Accellerator pump housing runs into the K&N Filter element, is this right? thanks Dan ________________________________________________________________________________
Subject: Re: 6 or 8 inch bench grinder?
Date: Sep 02, 2001
Kevin: I built my plane with a 6" grinder. Never had a job where I wished I'd had a larger one. George Kilishek >From: "Kevin Hanson" <kmhanson3(at)home.com> >Reply-To: rv8-list(at)matronics.com >To: >Subject: RV8-List: 6 or 8 inch bench grinder? >Date: Fri, 31 Aug 2001 15:24:34 -0500 > > >Sears has a sale on bench grinders. I was planning on a 6 inch. Is there >any need for an 8 inch for RV building? The Scotch Brite wheels come in >both. > >Thanks in advance. > >Kevin, RV8 tail > > ________________________________________________________________________________
Subject: Empennage
Date: Sep 02, 2001
Guys, Where can I find a print for an adjustable rudder trim. I thought I saw one on an eight but forget where or who had it. I didn't need to know until now. Just starting. #841 Jim Nolan N444JN Warsaw, In. ________________________________________________________________________________
Subject: Re: Empennage
Date: Sep 02, 2001
Hi Jim, I am as well interested in a rudder trim. If you get information or a drawing, please tell me. romeo.victor@t-online.de Stephan Servatius # 80303 85461 Bockhorn Germany Jim Nolan schrieb: > > Guys, > Where can I find a print for an adjustable rudder trim. I thought I saw > one on an eight but forget where or who had it. I didn't need to know until > now. Just starting. #841 > > Jim Nolan > N444JN > Warsaw, In. > > Stephan Servatius Untere Hauptstr. 3 85461 Bockhorn Germany ________________________________________________________________________________
Date: Sep 02, 2001
Guys: I don't know of a design for adjustable rudder trim for an -8, but having flown a variety of RVs I don't know why you'd want one. This is simply not an airplane where rudder trim should be an issue in climb, descent or cruise. George Kilishek N888GK final assembly >From: romeo.victor@t-online.de (Stephan Servatius) >Reply-To: rv8-list(at)matronics.com >To: rv8-list(at)matronics.com >Subject: Re: RV8-List: Empennage >Date: Sun, 2 Sep 2001 17:43:41 +0200 > >Servatius) > >Hi Jim, > >I am as well interested in a rudder trim. If you get information or a >drawing, >please tell me. > >romeo.victor@t-online.de >Stephan Servatius ># 80303 >85461 Bockhorn >Germany > >Jim Nolan schrieb: > > > > Guys, > > Where can I find a print for an adjustable rudder trim. I thought I >saw > > one on an eight but forget where or who had it. I didn't need to know >until > > now. Just starting. #841 > > > > Jim Nolan > > N444JN > > Warsaw, In. > > > > > >Stephan Servatius >Untere Hauptstr. 3 >85461 Bockhorn >Germany > > ________________________________________________________________________________
Subject: Empennage
Date: Sep 03, 2001
I'd have to agree. In my TR182 I use the rudder trim frequently and expected to miss in on my RV-8. In practice that has not been the case at all. I do use the roll trim a good bit as fuel burns down. Guys: I don't know of a design for adjustable rudder trim for an -8, but having flown a variety of RVs I don't know why you'd want one. This is simply not an airplane where rudder trim should be an issue in climb, descent or cruise. George Kilishek N888GK final assembly >From: romeo.victor@t-online.de (Stephan Servatius) >Reply-To: rv8-list(at)matronics.com >To: rv8-list(at)matronics.com >Subject: Re: RV8-List: Empennage >Date: Sun, 2 Sep 2001 17:43:41 +0200 > >Servatius) > >Hi Jim, > >I am as well interested in a rudder trim. If you get information or a >drawing, >please tell me. > >romeo.victor@t-online.de >Stephan Servatius ># 80303 >85461 Bockhorn >Germany > >Jim Nolan schrieb: > > > > Guys, > > Where can I find a print for an adjustable rudder trim. I thought I >saw > > one on an eight but forget where or who had it. I didn't need to know >until > > now. Just starting. #841 > > > > Jim Nolan > > N444JN > > Warsaw, In. > > > > > >Stephan Servatius >Untere Hauptstr. 3 >85461 Bockhorn >Germany > > ________________________________________________________________________________
Date: Sep 04, 2001
rv6-list(at)matronics.com, rv7-list(at)matronics.com, rv8-list(at)matronics.com, rv9-list(at)matronics.com, rvcanada-list(at)matronics.com, rveurope-list(at)matronics.com
Subject: Van's Homecoming 2001 - A Photo Journal!
Hi RV Listers! Well, just back from Van's Homecoming BBQ and Fly-in up at the Aurora Airport and in a word, wow. Below is a URL link to a web page I did on the photos I took over the two days. There are multi-resolutions and preview thumbnails for easy viewing. http://www.matronics.com/rv-list/VansHomeComing2001/ Have a look and feel free to download any you'd like to keep or make your screen backdrops. If you haven't gone to a Homecoming before, or even if you have, I highly recommend the trip. Very inspirational. Best regards, Matt Dralle RV-4 Finish Kit - #1763 - N442RV Matronics EMail List Admin. -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft Great minds discuss ideas, Average minds discuss events, Small minds discuss people... ________________________________________________________________________________
Subject: Re: small questions
Date: Sep 05, 2001
>Facet boost pump is noisy, is this right? It's noisy until fuel is flowing through it. >Accellerator pump housing runs into the K&N Filter element, is this right? Don't know what kind of system you have. My carbureted -320 has the accel pump built into the carb. You mean primer? don't believe FI systems have an accelerator pump. Anyone else know? Bryan Jones -8 CFI, RV Transition Training Pearland, Texas ________________________________________________________________________________
Date: Sep 05, 2001
No accelerator pumps with FI systems - no reason for it as the change in intake pressure caused by opening the throttle results in a near instantaneous injection of the correct amount of fuel - the whole point of the operation. Also, FI's require a whole different breed of boost pump. I didn't note the earlier parts of this, but just in case - you cannot run pumps designed for carburetors (engine or boost) with a FI. The pressures are to low. Subject: Re: RV8-List: small questions >Facet boost pump is noisy, is this right? It's noisy until fuel is flowing through it. >Accellerator pump housing runs into the K&N Filter element, is this right? Don't know what kind of system you have. My carbureted -320 has the accel pump built into the carb. You mean primer? don't believe FI systems have an accelerator pump. Anyone else know? Bryan Jones -8 CFI, RV Transition Training Pearland, Texas ________________________________________________________________________________
From: "Larry Dysinger" <larrykdysinger(at)hotmail.com>
Subject: Re: Van's Homecoming 2001 - A Photo Journal!
Date: Sep 05, 2001
Matt, Great pics... Larry K. Dysinger From: dralle(at)matronics.com (Matt Dralle) rv6-list(at)matronics.com, rv7-list(at)matronics.com, rv8-list(at)matronics.com, rv9-list(at)matronics.com, rvcanada-list(at)matronics.com, rveurope-list(at)matronics.com Subject: RV8-List: Van's Homecoming 2001 - A Photo Journal! Date: Tue, 4 Sep 2001 13:59:35 -0700 Hi RV Listers! Well, just back from Van's Homecoming BBQ and Fly-in up at the Aurora Airport and in a word, wow. Below is a URL link to a web page I did on the photos I took over the two days. There are multi-resolutions and preview thumbnails for easy viewing. http://www.matronics.com/rv-list/VansHomeComing2001/ Have a look and feel free to download any you'd like to keep or make your screen backdrops. If you haven't gone to a Homecoming before, or even if you have, I highly recommend the trip. Very inspirational. Best regards, Matt Dralle RV-4 Finish Kit - #1763 - N442RV Matronics EMail List Admin. -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft Great minds discuss ideas, Average minds discuss events, Small minds discuss people... ________________________________________________________________________________
Subject: RV8a
Date: Sep 04, 2001
We are doing an RV8a QB and are waiting for the engine from Lycoming. My question is what are people doing for an oil cooler (heat exchanger) for the O-360 engine. Van's shows two positech units, one for "hot weather". I have heard from 2 of our local builders that they had trouble with the positech and changed to a Steward Warner out of Niagara Air Parts Also, any thoughts on installing on the firewall vs. the cowling intake. Thanks, Lorin Frank, Sacramento, CA 90% done, 60% to go. ________________________________________________________________________________
Subject: RV8a
Date: Sep 05, 2001
From the RV list, it seems that a Niagara or Stewart Warner is the way to go, especially in warmer climates (Southern US). I am installing the Niagara on the baffle behind the cylinder. Not yet done though, but soon. Mike Munn RV8 QB, engine installed, completing wiring. Email: mmunn(at)jajones.com -----Original Message----- From: lorin l frank [mailto:llfrank(at)earthlink.net] Sent: Tuesday, September 04, 2001 5:07 PM To: Rv8 list Subject: RV8-List: RV8a We are doing an RV8a QB and are waiting for the engine from Lycoming. My question is what are people doing for an oil cooler (heat exchanger) for the O-360 engine. Van's shows two positech units, one for "hot weather". I have heard from 2 of our local builders that they had trouble with the positech and changed to a Steward Warner out of Niagara Air Parts Also, any thoughts on installing on the firewall vs. the cowling intake. Thanks, Lorin Frank, Sacramento, CA 90% done, 60% to go. ________________________________________________________________________________
Subject: Re: RV8a
Date: Sep 05, 2001
My Niagra oil cooler goes on the aft side of the #4 cooling baffle. This works well with oil temps generally around 185 degrees F. For pictures, see http://rv8asite.homestead.com/oilcooler.html. Jerry Carter 8A, 37 hrs. ----- Original Message ----- From: "lorin l frank" <llfrank(at)earthlink.net> Sent: Tuesday, September 04, 2001 2:07 PM Subject: RV8-List: RV8a > > We are doing an RV8a QB and are waiting for the engine from Lycoming. My > question is what are people doing for an oil cooler (heat exchanger) for > the O-360 engine. Van's shows two positech units, one for "hot > weather". I have heard from 2 of our local builders that they had > trouble with the positech and changed to a Steward Warner out of Niagara > Air Parts > Also, any thoughts on installing on the firewall vs. the cowling intake. > Thanks, > Lorin Frank, Sacramento, CA 90% done, 60% to go. > > ________________________________________________________________________________
Subject: Re: RV8a
Date: Sep 05, 2001
Lorin, I asked a bunch of people as well as vendors (and rebuilders) of oil coolers at Osh this year and the overwhelming concensus is to stay away from positech. I am building an RV8A and putting in a Bart Lalonde 0-360. I plan to use a Swewart Warner unit. I live in Phoenix, AZ and need all the margin I can get. Bear in mind that this is a compilation of many conversations and note collecting. I have never used either one in an airplane. I have used a Stewart Warner as a mod on a Porsche 911S with excellent results. Bill Christie ----- Original Message ----- From: lorin l frank <llfrank(at)earthlink.net> Sent: Tuesday, September 04, 2001 2:07 PM Subject: RV8-List: RV8a > > We are doing an RV8a QB and are waiting for the engine from Lycoming. My > question is what are people doing for an oil cooler (heat exchanger) for > the O-360 engine. Van's shows two positech units, one for "hot > weather". I have heard from 2 of our local builders that they had > trouble with the positech and changed to a Steward Warner out of Niagara > Air Parts > Also, any thoughts on installing on the firewall vs. the cowling intake. > Thanks, > Lorin Frank, Sacramento, CA 90% done, 60% to go. > > ________________________________________________________________________________
Subject: RV8a
Date: Sep 05, 2001
I've been flying an -8 with an O-360 and the larger Positech cooler for two Florida summers now, and have not had any problems at all. I put it on the baffle, though it's a really tight fit. The thing's build like a tank, so I can't imagine what "problem" anyone is having with it, unless it's cooling performance. That being said, I'm not sure I wouldn't pick a different brand if I were doing it all over. Russell Duffy Navarre, FL 80587, N174KT (Flying 75hrs, FINALLY painted, installing Ellison and Inverted oil) ______________________ the O-360 engine. Van's shows two positech units, one for "hot weather". I have heard from 2 of our local builders that they had trouble with the positech and changed to a Steward Warner out of Niagara Air Parts Also, any thoughts on installing on the firewall vs. the cowling intake. Thanks, Lorin Frank, Sacramento, CA 90% done, 60% to go. ________________________________________________________________________________
Date: Sep 05, 2001
From: "Edward O'Connor" <EdwardOConnor(at)compuserve.com>
Subject: RV8-List Digest: 3 Msgs - 09/02/01
Check out Van Doran site. He had a link to another builder with pictures of an adjustable rudder trim. Can't remember the builders name who did the pictures but he had a bunch of modifications. Von Doran's Web site is listed in be builders group on VAn's web site. I have fabricated the parts for my adjustable rudder and will be installing in about a month. There are pictures of a Nav Aid instalation on the same site. I'm on road right now and don't have my regular E-mail and web site index with mo or I could tekk you more. ________________________________________________________________________________
From: "Sally and George" <aeronut58(at)hotmail.com>
Subject: RE: Positech Oil Cooler
Date: Sep 06, 2001
I'll confirm Russel's comments re: the Positech Cooler being a tight fit on the rear baffle of an O-360 in an RV-8. It fits, but requires some thought and design and/or cut and try for the installation. I've not flown it yet, so can't comment on cooling efficacy, but I'm happy with the way the installation finally worked out. George Kilishek N888GK Last .001% >From: "Russell Duffy" <rv82(at)home.com> >Reply-To: rv8-list(at)matronics.com >To: >Subject: RE: RV8-List: RV8a >Date: Wed, 5 Sep 2001 20:14:09 -0500 > > >I've been flying an -8 with an O-360 and the larger Positech cooler for two >Florida summers now, and have not had any problems at all. I put it on the >baffle, though it's a really tight fit. The thing's build like a tank, so >I >can't imagine what "problem" anyone is having with it, unless it's cooling >performance. That being said, I'm not sure I wouldn't pick a different >brand if I were doing it all over. > >Russell Duffy >Navarre, FL >80587, N174KT (Flying 75hrs, FINALLY painted, installing Ellison and >Inverted oil) > > >______________________ >the O-360 engine. Van's shows two positech units, one for "hot >weather". I have heard from 2 of our local builders that they had >trouble with the positech and changed to a Steward Warner out of Niagara >Air Parts >Also, any thoughts on installing on the firewall vs. the cowling intake. >Thanks, >Lorin Frank, Sacramento, CA 90% done, 60% to go. > > ________________________________________________________________________________
Date: Sep 17, 2001
Subject: how would?
I wonder how a RV would look with 50 cal guns, and bomb racks...might come in handy...HOPE NOT...seriously tho...has anyone put a belly tank for gas on a RV?... finished painting..almost RV8A ________________________________________________________________________________
Date: Sep 18, 2001
Subject: Proseal canopy?
All, I am installing canopy, and so far only thing shattered are my nerves. I have drilled the rivet holes, and can forsee the problems holding the canopy in alignment while drilling the canopy skirt. I would like to proseal or RTV the canopy to the frame, and then locate holes for skirt. When I finish rivet the skirt I'd like to proseal it on too. Has anyone done this? Has anyone not done this? Thanks Dan Ward RV8 N417SN Fitting canopy, nose cowling, wheel pants, about half finished. ________________________________________________________________________________
Date: Sep 18, 2001
Subject: Re: Proseal canopy?
on the first one I did the rivets...ugh!...crak!..on the next one I did the rtv bit..I sanded the frame to bare metal, and rtv'd the canopy on that....seemed to work fine...I then riveted the skirt on the frame, and ran a fiberglass tape from the skirt to the plexiglas, and that's it...seems to hold up well..the first one is flying now,with about 45hrs on it..so far no complaints...seemed to pass the inspection...since I have done this a couple more times, and it's worked out fine...good luck TwoAviators wrote: > > All, > > I am installing canopy, and so far only thing shattered are my nerves. I > have drilled the rivet holes, and can forsee the problems holding the > canopy in alignment while drilling the canopy skirt. I would like to > proseal or RTV the canopy to the frame, and then locate holes for skirt. > When I finish rivet the skirt I'd like to proseal it on too. Has anyone > done this? Has anyone not done this? > > Thanks > > Dan Ward > RV8 N417SN > Fitting canopy, nose cowling, wheel pants, about half finished. > > ________________________________________________________________________________
Date: Sep 18, 2001
Dan: I riveted my canopy per the plans and builder's manual. I endured much angst and worry that I'd screw it up, but...it turned out to be easy and everything was fine. The only slight negative that I can think of is that the pop rivets that hold the skirt to the canopy frame required some extra finishing to smooth everything off, but you'll have to do a lot of filling and sanding on the fiberglass skirt anyway, so I'm not sure this is worth worrying about. Using proseal might work. Then again, after hundreds of hours and several years in the hot sun it might possibly not be sufficient. The rivets have been field tested and we know they work. Just my experience/opinion. George Kilishek N888GK Final .0001% >From: TwoAviators <TwoAviators(at)lexcominc.net> >Reply-To: rv8-list(at)matronics.com >To: rv8-list(at)matronics.com >Subject: RV8-List: Proseal canopy? >Date: Tue, 18 Sep 2001 11:27:19 -0400 > > >All, > >I am installing canopy, and so far only thing shattered are my nerves. I >have drilled the rivet holes, and can forsee the problems holding the >canopy in alignment while drilling the canopy skirt. I would like to >proseal or RTV the canopy to the frame, and then locate holes for skirt. >When I finish rivet the skirt I'd like to proseal it on too. Has anyone >done this? Has anyone not done this? > >Thanks > >Dan Ward >RV8 N417SN >Fitting canopy, nose cowling, wheel pants, about half finished. > > ________________________________________________________________________________
Date: Sep 18, 2001
Subject: Pro Seal on Canopy
I had used pro seal on the edge to water seal the canopy on my last RV, and it worked just fine leaving a thin edge seal between the aluminum or FG and the glass. Paint will not adhere. Ron Smith ________________________________________________________________________________
Date: Sep 28, 2001
Subject: does anyone know
will the gear fairings for the RV6 fit on the RV8?...thanks... ________________________________________________________________________________
Subject: Re: does anyone know
Date: Sep 29, 2001
No. >From: old ogre <jollyd(at)ipns.com> >Reply-To: rv8-list(at)matronics.com >To: "RV-8-List (E-mail)" >Subject: RV8-List: does anyone know >Date: Fri, 28 Sep 2001 21:33:26 -0700 > > >will the gear fairings for the RV6 fit on the RV8?...thanks... > > ________________________________________________________________________________
Date: Sep 29, 2001
Subject: Canopy skirt fitting??
I am beginning to fit the canopy skirt to my -8, and find it looks like it will need to be split in the rear and then bridged with more fiberglass. The tailgroup and wheel fairings fit fairly well. thoughts? Thanks. Dan RV8, N417SN reserved Engine running, fitting canopy and nose fairing last. ________________________________________________________________________________
Date: Sep 29, 2001
On my RV-8 and two others of looked at during the building process, the fit of the rear of the canopy skirt was consistent, and really bad. My guess is that who ever is making these for Van's is simply unaware of the bad fit. One local RV-8 builder removed the rear part of the skirt and did it in aluminum. I am beginning to fit the canopy skirt to my -8, and find it looks like it will need to be split in the rear and then bridged with more fiberglass. The tailgroup and wheel fairings fit fairly well. thoughts? Thanks. Dan RV8, N417SN reserved Engine running, fitting canopy and nose fairing last. ________________________________________________________________________________
Subject: Re: Canopy skirt fitting??
Date: Sep 29, 2001
Dan: My canopy fit perfectly at the rear. I think it was a matter of blind luck, because I know of several builders here in the Dallas area who had to split and rebridge that area. Do what you have to do. George Kilishek N888GK Getting ready for airworthiness inspection >From: TwoAviators <TwoAviators(at)lexcominc.net> >Reply-To: rv8-list(at)matronics.com >To: rv8-list(at)matronics.com >Subject: RV8-List: Canopy skirt fitting?? >Date: Sat, 29 Sep 2001 14:52:41 -0400 > > >I am beginning to fit the canopy skirt to my -8, and find it looks like it >will need to be split in the rear and then bridged with more fiberglass. >The tailgroup and wheel fairings fit fairly well. > >thoughts? > >Thanks. > >Dan RV8, N417SN reserved >Engine running, fitting canopy and nose fairing last. > > ________________________________________________________________________________
Date: Sep 29, 2001
It's the skirt everyone is having problems with. > Dan: > > My canopy fit perfectly at the rear. I think it was a matter of blind luck, > because I know of several builders here in the Dallas area who had to split > and rebridge that area. > > Do what you have to do. > > George Kilishek > N888GK > Getting ready for airworthiness inspection > > > >From: TwoAviators <TwoAviators(at)lexcominc.net> > >Reply-To: rv8-list(at)matronics.com > >To: rv8-list(at)matronics.com > >Subject: RV8-List: Canopy skirt fitting?? > >Date: Sat, 29 Sep 2001 14:52:41 -0400 > > > > > >I am beginning to fit the canopy skirt to my -8, and find it looks like it > >will need to be split in the rear and then bridged with more fiberglass. > >The tailgroup and wheel fairings fit fairly well. > > > >thoughts? > > > >Thanks. > > > >Dan RV8, N417SN reserved > >Engine running, fitting canopy and nose fairing last. ________________________________________________________________________________
Date: Sep 29, 2001
if you really want to work work work..leave it as it is....otherwise split it in back...it's the only way I got mine to fit...sort-of...{:~) N-82ME TwoAviators wrote: > > I am beginning to fit the canopy skirt to my -8, and find it looks like it > will need to be split in the rear and then bridged with more fiberglass. > The tailgroup and wheel fairings fit fairly well. > > thoughts? > > Thanks. > > Dan RV8, N417SN reserved > Engine running, fitting canopy and nose fairing last. > > ________________________________________________________________________________
Date: Sep 29, 2001
We have two RV-8's at my airport, with two different skirts. They obviously came from different molds. My buddy's fit perfectly, but was very rough in texture. Mine was smooth as silk, but fit like crap. I cut mine in three places, and one side still fits like crap. Fortunately, it doesn't bother me that much. Like someone said, it's luck of the draw. Rusty Navarre, FL 80587, N174KT, flying 75 hrs. > I am beginning to fit the canopy skirt to my -8, and find it looks like it > will need to be split in the rear and then bridged with more fiberglass. > The tailgroup and wheel fairings fit fairly well. > > thoughts? ________________________________________________________________________________
Date: Sep 29, 2001
Now that's pretty interesting. Mine (and the other's) are dead smooth - maybe "pre-preg" They fit fine along the front 2/3 or so, then a gap. Van's does so much so very well, it really makes the few flaws jump out - like the RV-8 overheating problem the factory guys still contend does not exist. Ronin N591RC @ 50+ We have two RV-8's at my airport, with two different skirts. They obviously came from different molds. My buddy's fit perfectly, but was very rough in texture. Mine was smooth as silk, but fit like crap. I cut mine in three places, and one side still fits like crap. Fortunately, it doesn't bother me that much. Like someone said, it's luck of the draw. Rusty Navarre, FL 80587, N174KT, flying 75 hrs. > I am beginning to fit the canopy skirt to my -8, and find it looks like it > will need to be split in the rear and then bridged with more fiberglass. > The tailgroup and wheel fairings fit fairly well. > > thoughts? ________________________________________________________________________________
Date: Sep 29, 2001
Right Randy. I meant to say that my skirt fit perfectly. George >From: "Randy Lervold" <randy@rv-8.com> >Reply-To: rv8-list(at)matronics.com >To: >Subject: Re: RV8-List: Canopy skirt fitting?? >Date: Sat, 29 Sep 2001 17:28:01 -0700 > > >It's the skirt everyone is having problems with. > > > > Dan: > > > > My canopy fit perfectly at the rear. I think it was a matter of blind >luck, > > because I know of several builders here in the Dallas area who had to >split > > and rebridge that area. > > > > Do what you have to do. > > > > George Kilishek > > N888GK > > Getting ready for airworthiness inspection > > > > > > >From: TwoAviators <TwoAviators(at)lexcominc.net> > > >Reply-To: rv8-list(at)matronics.com > > >To: rv8-list(at)matronics.com > > >Subject: RV8-List: Canopy skirt fitting?? > > >Date: Sat, 29 Sep 2001 14:52:41 -0400 > > > > > > > > >I am beginning to fit the canopy skirt to my -8, and find it looks like >it > > >will need to be split in the rear and then bridged with more >fiberglass. > > >The tailgroup and wheel fairings fit fairly well. > > > > > >thoughts? > > > > > >Thanks. > > > > > >Dan RV8, N417SN reserved > > >Engine running, fitting canopy and nose fairing last. > > ________________________________________________________________________________
Date: Sep 30, 2001
Subject: RV Fly-In in Maryland
RVers, Come out and enjoy a nice fall get together of RV's on October 13th. Hosted by the MidAtl RV Wing, Check out Doug Reeves Site at... http://www.metronet.com/~dreeves/vaf.htm or... the MidATl RV Wing Site (message board) at.... http://groups.yahoo.com/group/Mid-AtlRVwing/messages Joe Czachorowski RV8 ________________________________________________________________________________
Subject: Finished RV8 Fuselage Jig?
Date: Oct 07, 2001
Hello, I am about to remove my RV8 from the fuselage jig for the first time as called for in the plans. However the plans say I will be putting the fuselage back on it later. As I plan to mount a car engine stand to the firewall, as discussed here and elsewhere, can I go ahead and get rid of the jig at this point? Thanks and regards Vince Himsl RV8 Fuselage Moscow, ID USA ________________________________________________________________________________
Date: Oct 07, 2001
Vince- I threw the jig away early like you are contemplating. Worked out OK... I had to do the bottom front skin and ribs while crouching/groveling (I had no way to rotate it upside down again) but it wasn't too bad. Matthew -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Vincent S. Himsl Subject: RV8-List: Finished RV8 Fuselage Jig? Hello, I am about to remove my RV8 from the fuselage jig for the first time as called for in the plans. However the plans say I will be putting the fuselage back on it later. As I plan to mount a car engine stand to the firewall, as discussed here and elsewhere, can I go ahead and get rid of the jig at this point? Thanks and regards Vince Himsl RV8 Fuselage Moscow, ID USA ________________________________________________________________________________
Date: Oct 08, 2001
Subject: Re: RV8-List Digest: 2 Msgs - 10/07/01
I'm just getting started and I'm looking for some advise on priming. Zinc chromate? or is something else better. Should I get in in a spray can, or paint it on, or use the sprayer on my air compressor? Thanks Jim Aylward Westfield MA ________________________________________________________________________________
Subject: Email address change
Date: Oct 08, 2001
Good morning friends, Please note my new email address is jack(at)IaJobs.com Old address pincjt(at)ix.netcom.com will be valid through end of month Jack RV8, wings Jack Textor PERSONNEL INCOPORATED 604 Locust, Suite 516 Des Moines, IA 50309 515-243-7687 phone 515-243-3350 fax Jack(at)IaJobs.com IaJobs.com ________________________________________________________________________________
Subject: Priming
Date: Oct 08, 2001
I had the same question (as did everybody). It looks like the standard is Veri-Prime, although some swear by other products. One thing about this product is that it doesn't need to be as heavily applied as the coats of zinc chromate that you're accostomed to seeing. Also, with so many products out today, it's important that you get a good respirator that's really designed for just that sort of thing. Ask the person you buy the product from which one he recommends. Don't skimp on this item- you'll be glad you didn't later. Also, be sure and use latex gloves and full eye protection- not just safety glasses. Happy priming! ________________________________________________________________________________
Subject: Re: Priming
Date: Oct 08, 2001
From http://www.ontariorvators.org, see http://pub.alxnet.com/poll?id=2123902&q=view for the current results of the question "What type of primer did you use/are you primarily using during building? (not external)" Phil > I had the same question (as did everybody). It looks like the standard > is Veri-Prime, although some swear by other products. One thing about > this product is that it doesn't need to be as heavily applied as the ________________________________________________________________________________
Subject: Sensenich pitch?
Date: Oct 08, 2001
Greetings, I was wondering what pitch everyone is using on their O-360 powered -8's. When I first ordered my prop, 83" was the recommendation. By the time it was ready to be produced, 85" was what I got. After a year of flying the 85", and especially following the installation of an Ellison TBI and LightSpeed ignition, I've found the 85" to be underpitched. Currently, I can lean to a max RPM of 2720 at 12,500, so it's time to let Sensenich twist it some more. I'll be getting repitched to an 87" next week. Anybody else flying anything over an 85"? Also, is anyone else going to Tracy Crook's Shady Bend fly-in later this month? The other local RV-8 (Bob Hargrave) and I will be flying over on Sat the 27th. Bob will be the one that looks depressed because I'm going to outrun his expensive constant speed prop on the way over :-) Fly-in info: http://www.rotaryaviation.com/invitation.html Note- I don't believe they can accommodate the general flying population at this strip due to parking limitations. The invitation is for RV's and rotary powered aircraft. See the web site for details. Russell Duffy N174KT, 80587, 75 hours Navarre, FL ________________________________________________________________________________
Date: Oct 08, 2001
Subject: Re: Sensenich pitch?
Russel I have a 83 Sensenich on my O360 RV-8. The engine has higher compression pistons and fuel injection etc. so that it produces about 200 horse power. I can get about 2200 rpm static and I have to pull it back about an inch at cruise to keep the rpm under redline. I am thinking about a repitch to 85 or more and would like to know how it works for you. Could you please email me after you have that done and let me know your results? Also what kind of static rpm are you getting now with your 85? Do you need to pull it back at cruise? Does Sensenich say they can repitch the prop and does it then become uncertified? Thanx for the info Chris Hukill Helifoto(at)aol.com ________________________________________________________________________________
Subject: priming
Date: Oct 08, 2001
Hi Jim, Hope I do this correctly, it's my first time. I'm a beginner as well, currently working on dimpling the HS. I work for a corporate jet manufactor and the only primer the paint department uses is Pratt Lambert epoxy primer. So after a little research found the it is made by Sherwin Williams Aerospace Division.So I called my local store and after they made a few phone calls they tried to sell me a zinc chromate primer which is a possible link to lung cancer. I've work at a few facilities and they will not allow it to be used even in an aerosol can. They are producing a zinc oxide primer, althought I haven't heard of it hazards or its performance. I got the number to the aerospace division and talked to a tech rep and he told me that the epoxy primers in his opinion were the best for the application. The preparation process should include alumiprep and alodine followed by epoxy primer. He said that the self etching primers were worthless if you were wanting corrosion preventive, which the alodine does. The process takes about 1minute for etch, rinse and 1min for alodine, rinse and air dry for 24hrs and then primer. Per the tech rep. after each part is prep with scothbrite prior to etching. I believe I have all the part number's and prices at work and will post them tommorrow. But of course all of this is up to the builder, to prime or not to prime. If I'm going to spend the time to do it, I want to do it right. I use that term loosely. Good luck priming. Forrest Chandler AR 8 emp ________________________________________________________________________________
Date: Oct 09, 2001
Chris, I'll certainly post the performance of my 87" pitch when I get it done and tested. The plan is to have it installed on the 20th, and I'll certainly do some initial testing then, and perhaps more later. I do have to pull the power back for cruise at any altitude that doesn't require oxygen, which is why I'm going ahead with the repitch. I'll loose a bit of climb, but that isn't an issue with an RV at sea level. My best measured cruise speed is 174 kts, which I calculated to be about 70% power at the time. Since then, I've added a noticeable amount of power with the Ellison TBI and Lightspeed ignition, but to be able to use it in cruise, I'll need more pitch. BTW- electronic ignition is the BEST money you'll ever spend on the engine. I'm expecting a 75% cruise speed in excess of 180 kts when I get the prop back. As for static RPM, believe it or not, I've never measured this. It will make an interesting before and after figure, so I'll try to check it this weekend when I have someone in the back seat as ballast. I don't believe there's a problem going from 83" to anything you'd want (85"-87"), but you'd have to ask Sensenich to be sure. You won't have to worry about "losing" the certification of the prop either, because they aren't certified to start with. I believe "experimental" is stamped right on the hub. These props were designed specifically for the RV series (thank you Sensenich), because no certified spam product can be twisted to anything close to the pitch we need. Also, be advised that Sensenich doesn't recommend using their (or anyone else's) aluminum prop with any engine that has been modified (high compression pistons) from a configuration that has been specifically tested. I've seen them state this in public forums on a few occasions. You'll have to decide how much of that is the lawyers wishes. Rusty Navarre, FL N174KT- 75 hrs ________________________________________________________________________________
Date: Oct 09, 2001
Rusty Thanx for the reply, and I'll be looking for your posting with the results. I should probably contact Sensenich and ask them about the 9.2 to 1 pistons that I have. They are 0320 H2AD stock lycoming pistons, and the engine was built by Aerosport Power ,who have an impeccable reputation amongst RV builders for reliability. Chris Hukill ________________________________________________________________________________
Date: Oct 10, 2001
tks chris > -----Original Message----- > From: Helifoto(at)aol.com [mailto:Helifoto(at)aol.com] > Sent: 9. oktober 2001 18:59 > Subject: Re: RV8-List: Sensenich pitch? > > > > Rusty > Thanx for the reply, and I'll be looking for your posting > with the results. I > should probably contact Sensenich and ask them about the 9.2 > to 1 pistons > that I have. They are 0320 H2AD stock lycoming pistons, and > the engine was > built by Aerosport Power ,who have an impeccable reputation > amongst RV > builders for reliability. > Chris Hukill > > > > > > > ________________________________________________________________________________
Subject: For Sale: RV-8 Horizontal Stabilizer kit (price lowered!)
Date: Oct 10, 2001
[OK, I really just want to get rid of my RV-8 HS parts, so I've dropped the price to "ridiculously low". Read on...] When the RV-7 came out, I decided to convert my RV-8 empennage to an RV-7, leaving me with a mostly-completed RV-8 horizontal stabilizer. I need more space in my garage as I get ready for the wing kit, so... I'm selling my RV-8 HS parts as a set for $75.00 (not including shipping). I'd prefer to sell to someone close enough to Beaverton, OR that I won't have to figure out how to ship it, but it's no big deal to ship the stuff either. According to Van's current prices, the set of raw parts is worth about $450 new, so this is a pretty good deal, methinks. If you think otherwise, make me an offer! Most everything has already been cut, drilled, bent, countersunk, dimpled, fluted to the point where priming and riveting the skeleton would be next. This includes cut, drilled, and bent HS-610/810, 814, and HS-602s. Workmanship is good -- definitely airworthy. Here's a description of what I've got: 2 x HS-404 RIB-ROOT FWD 2 x HS-405 RIB-ROOT MAIN 4 x HS-412PP-PC HINGE BRACKET 4 x HS-413PP-PC HINGE BRACKET 2 x HS-602 SPAR - FWD 2 x HS-603PP HORIZ. REAR SPAR 2 x HS-606 RIB-TIP 2 x HS-607 RIB-CENTER FWD 2 x HS-608 RIB-CENTER MAIN 2 x HS-609PP PP FLANGE STRIPS 1 x AA6-125X3/4X3/4X17 AL. ANGLE HS-610/810 2 x HS-801PP HORIZ STAB SKIN 1 x HS-814 PRE-CUT UNIT 1 x 8 PLANS EMP SET EMPENNAGE PLANS SET Parts not included because I reused them on my RV-7 kit: 2 x HS-411BPP-PC HINGE BRACKET 1 x VA-146 FLANGE BEARING Assorted rivets and bolts Contact me at jboone(at)earfeast.com or (503) 466-2877 for more information. - Jared Boone RV-7 Empennage Beaverton, OR ________________________________________________________________________________
Subject: RV8a
Date: Oct 11, 2001
We have the wings on and the Chief built panel in our RV8a QB. We are pretty much just waiting for the engine from Lycoming. We are having some trouble finding a spot to mount the compass on the top of the panel. Due to the instruments in the panel and their magnetic field we could not mount in the panel itself and on top of the panel is near allot of metal. What have others done, do balancing balls work? The panel has a GPS but I would still like to have a compass for backup on cross country trips. Does anyone know of a good source vinyl stripping for the outside of the plane in place of painting on the strips? Thanks, Lorin in Sacramento CA NX54LF ________________________________________________________________________________
Subject: Re: For Sale: RV-8 Horizontal Stabilizer kit (price lowered!)
Date: Oct 11, 2001
Jared: I am very interested in buying your Horizontal Stab. Kit. But i live in Kentucky. If we could figure out how to ship it I would buy it tomorrow. Al Grajek. algrajek(at)msn.com 858-361-9460 ----- Original Message ----- From: Jared Boone roups.com; rv-list(at)matronics.com; vansairforce(at)yahoogroups.com Subject: RV8-List: For Sale: RV-8 Horizontal Stabilizer kit (price lowered!) [OK, I really just want to get rid of my RV-8 HS parts, so I've dropped the price to "ridiculously low". Read on...] When the RV-7 came out, I decided to convert my RV-8 empennage to an RV-7, leaving me with a mostly-completed RV-8 horizontal stabilizer. I need more space in my garage as I get ready for the wing kit, so... I'm selling my RV-8 HS parts as a set for $75.00 (not including shipping). I'd prefer to sell to someone close enough to Beaverton, OR that I won't have to figure out how to ship it, but it's no big deal to ship the stuff either. According to Van's current prices, the set of raw parts is worth about $450 new, so this is a pretty good deal, methinks. If you think otherwise, make me an offer! Most everything has already been cut, drilled, bent, countersunk, dimpled, fluted to the point where priming and riveting the skeleton would be next. This includes cut, drilled, and bent HS-610/810, 814, and HS-602s. Workmanship is good -- definitely airworthy. Here's a description of what I've got: 2 x HS-404 RIB-ROOT FWD 2 x HS-405 RIB-ROOT MAIN 4 x HS-412PP-PC HINGE BRACKET 4 x HS-413PP-PC HINGE BRACKET 2 x HS-602 SPAR - FWD 2 x HS-603PP HORIZ. REAR SPAR 2 x HS-606 RIB-TIP 2 x HS-607 RIB-CENTER FWD 2 x HS-608 RIB-CENTER MAIN 2 x HS-609PP PP FLANGE STRIPS 1 x AA6-125X3/4X3/4X17 AL. ANGLE HS-610/810 2 x HS-801PP HORIZ STAB SKIN 1 x HS-814 PRE-CUT UNIT 1 x 8 PLANS EMP SET EMPENNAGE PLANS SET Parts not included because I reused them on my RV-7 kit: 2 x HS-411BPP-PC HINGE BRACKET 1 x VA-146 FLANGE BEARING Assorted rivets and bolts Contact me at jboone(at)earfeast.com or (503) 466-2877 for more information. - Jared Boone RV-7 Empennage Beaverton, OR = = = = = = ________________________________________________________________________________
Subject: Re: RV8a
Date: Oct 11, 2001
> We are having > some trouble finding a spot to mount the compass on the top of the > panel. Due to the instruments in the panel and their magnetic field we > could not mount in the panel itself and on top of the panel is near > allot of metal. > What have others done, do balancing balls work? I mounted mine on the glareshield in my RV-8. The built-in compass compensation screws worked well and I was able to swing it within a degree on all headings. Be sure and turn everything on and close your canopy when swinging it. Closing my canopy caused a 5 degree error and turning on the electri gyros caused another 5 degree error. Running the engine made do difference at all. You might want to consider having your roll bar deguassed if it's not permanently mounted... good insurance. Randy Lervold RV-8, #80500, N558RL, 133 hrs www.rv-8.com Home Wing VAF ________________________________________________________________________________
Subject: Re: RV8-List Digest: 3 Msgs - 10/11/01
From: "Bob Lueder" <Blueder(at)SUPERIORAIRPARTS.COM>
Date: Oct 12, 2001
10/12/2001 08:04:00 AM LP Aero plastics makes a compass mount block that attaches to the windshield. They are relatively inexpensive and they may provide a solution- normally they are used in Cessna aircraft. They list for 30.00 , LP can be reached at 800-957-2376. ________________________________________________________________________________
Date: Oct 12, 2001
Subject: Rv-8 Parking Brake
From: "Ed O'Connor" <edwardoconnor(at)compuserve.com>
I bought the Matco Parking brake valve Vans sells in his Catalog. It comes with no directions or suggetions on how and where to mount. Since my specality is copying or improving on what others have already spent untold hours figuring out, I was wondering if anyone had any pictures or descritptions on how/where to mount and how to run the control cable to set Brakes. I have an idea in mind but am sure someone has done it better. Reply on or off line. I only get the digest of the List the day after. I also searched the archives and only found posts that some individules had installed the valve but no descriptions on how they did it. Any help would be appreciated. Ed O'Connor/N366RV/Sandy Creek Airpark Working on Rudder Peddles/Brakes ________________________________________________________________________________
Date: Oct 13, 2001
Subject: Canopy Question
I have checked the archives and did not find an answer. On the RV-8 Canopy there are some factory marked trim lines. The directions are very specific as not to cut there to start with, but leave about a quarter inch and to cut slowly and take your time. All well and good. My question is that when you are finished cutting, how far does the bottom edge of the canopy extend down below the upper most piece of tubing on the 819 frame? (I think it is the 819). Right now my pardner and I have it trimed so that the factory mark is at the bottom of this tube and we still have about an inch and a half of spece above the canopy bow on the frame. Also on the rear of the canopy it appears that we need to cut more of the plexi away than the factory mark to get the plexi to lay against the rear bow of the canopy near the track. Does anyone have any sage advice or better yet some pictures. The pictures might save you 900 words or more. Howard Cochran Mooresville, NC 1/2 of 80188 Slooooow Build Canopy fitting, Panel wiring, fuel lines. ________________________________________________________________________________
Date: Oct 13, 2001
Subject: Re: Rv-8 Parking Brake
In a message dated 10/13/01 12:52:23 AM Eastern Daylight Time, edwardoconnor(at)compuserve.com writes: > I bought the Matco Parking brake valve Vans sells in his Catalog. It comes > with no directions or suggetions on how and where to mount. Since my > specality is copying or improving on what others have already spent untold > hours figuring out, I was wondering if anyone had any pictures or > descritptions on how/where to mount and how to run the control cable to set > Brakes. I have an idea in mind but am sure someone has done it better. > Reply on or off line. I only get the digest of the List the day after. I > also searched the archives and only found posts that some individules had > installed the valve but no descriptions on how they did it. Any help would > be appreciated. > > Ed O'Connor/N366RV/Sandy Creek Airpark > Working on Rudder Peddles/Brakes > > Please reply on list, I am having a similar dilema. I planned on mounting my valve at the bottom center of the rear bulkhead for the forward baggage compartment. I cant't figure how to run the brake control cable from this location due to the non-adjustable throw of the parking brake arm. Rick McBride ________________________________________________________________________________
Subject: Re: Canopy Question
Date: Oct 13, 2001
Hi Howard, I just trimmed my canopy also. About half way through cutting the canopy I re-read the instructions and found that I missed the part that says to use the dimensions on the drawing 44. The only dimension that I found was the one that tells where to put the front edge of the canopy. I think it is 3 1/4" from the rear baggage wall. Check that. I noticed that once I put the front edge there it seemed to line up better. OF COURSE I FOUND THAT RIGHT AFTER I CUT THE REAR PORTION OFF. Mine turned out to be fine but it sure was close. I did have to cut a hole bunch off the front to bring it down to the canopy bow. Ed Perry eperry(at)san.rr.com ----- Original Message ----- From: <W4PPN(at)aol.com> Subject: RV8-List: Canopy Question > > I have checked the archives and did not find an answer. > > On the RV-8 Canopy there are some factory marked trim lines. The directions > are very specific as not to cut there to start with, but leave about a > quarter inch and to cut slowly and take your time. All well and good. > > My question is that when you are finished cutting, how far does the bottom > edge of the canopy extend down below the upper most piece of tubing on the > 819 frame? (I think it is the 819). Right now my pardner and I have it > trimed so that the factory mark is at the bottom of this tube and we still > have about an inch and a half of spece above the canopy bow on the frame. > Also on the rear of the canopy it appears that we need to cut more of the > plexi away than the factory mark to get the plexi to lay against the rear bow > of the canopy near the track. > > Does anyone have any sage advice or better yet some pictures. The pictures > might save you 900 words or more. > > Howard Cochran > Mooresville, NC > 1/2 of 80188 Slooooow Build > Canopy fitting, Panel wiring, fuel lines. > > ________________________________________________________________________________
Date: Oct 13, 2001
Howard: Sounds like you might need to shift the canopy forward or backwards on the frame. George Kilishek N888GK Just about ready for inspection >From: W4PPN(at)aol.com >Reply-To: rv8-list(at)matronics.com >To: rv8-list(at)matronics.com >Subject: RV8-List: Canopy Question >Date: Sat, 13 Oct 2001 04:08:02 EDT > > >I have checked the archives and did not find an answer. > >On the RV-8 Canopy there are some factory marked trim lines. The >directions >are very specific as not to cut there to start with, but leave about a >quarter inch and to cut slowly and take your time. All well and good. > >My question is that when you are finished cutting, how far does the bottom >edge of the canopy extend down below the upper most piece of tubing on the >819 frame? (I think it is the 819). Right now my pardner and I have it >trimed so that the factory mark is at the bottom of this tube and we still >have about an inch and a half of spece above the canopy bow on the frame. >Also on the rear of the canopy it appears that we need to cut more of the >plexi away than the factory mark to get the plexi to lay against the rear >bow >of the canopy near the track. > >Does anyone have any sage advice or better yet some pictures. The pictures >might save you 900 words or more. > >Howard Cochran >Mooresville, NC >1/2 of 80188 Slooooow Build >Canopy fitting, Panel wiring, fuel lines. > > ________________________________________________________________________________
Date: Oct 13, 2001
Hi Howard, Thankfully, it's been a couple years since I did this, but here's what I remember. First, my canopy didn't have any factory marks, but I've heard they're pretty close if you have them. I don't recall anything critical about the amount of overhang that you leave over the canopy frame rail (819?- the mostly horizontal tube you rivet the canopy to). My advice would be to leave as much overhang as you can (at least an inch) until you get the canopy laying down properly everywhere. Once everything is in place, you can decide how much overhang you want to leave permanently. Originally, I think I left about 3/4 inch beyond the bottom of the tube, but noticed a few areas that had tiny little cracks forming at the edges of the plexi. This was probably from handling the canopy so much during the fitting. Just before I installed the canopy for good, I trimmed another 1/4 inch or so from the areas with the tiny cracks, to get rid of the affected area. That left me with about a half inch overhang in most places. If you want some pictures, drop me a mailing address off-list, and I'll send you a CD with everything I have. I'll open this offer up to anyone else on the list as well, and I'll do it for the low-low price of nothing. You just have to promise not to sue me if you copy something I did and find out it's a bad idea :-) Russell Duffy 80587, N174KT (flying 75 hrs) Navarre, FL My question is that when you are finished cutting, how far does the bottom edge of the canopy extend down below the upper most piece of tubing on the 819 frame? (I think it is the 819). Right now my pardner and I have it trimed so that the factory mark is at the bottom of this tube and we still have about an inch and a half of spece above the canopy bow on the frame. Also on the rear of the canopy it appears that we need to cut more of the plexi away than the factory mark to get the plexi to lay against the rear bow of the canopy near the track. ________________________________________________________________________________
Date: Oct 13, 2001
I installed the Matco parking brake valve on my RV8. I mounted it to the bulkhead were the lines would normally mount, that is on centerline, just aft of the pedals. The valve is easily reachable so no cable is required. One point of interest, the ports on the valve are spaced too close together to install a standard AN822 fitting, which means you have to use swivel fittings. These are available from Earls, but cost twenty some bucks each, and you need four of them. Chris Hukill ________________________________________________________________________________
Subject: Countersinking the F-804 Wing spar Flange
Date: Oct 14, 2001
Hello, I am attaching the skins to the fuselage but have hit a snag where the bottom F-822, F-826, and F-827 skins intersect the F-804 center section. I have dimpled all the skins which requires that I countersink the F-804 spar flange. Problem: The spar flange is not thick enough to do a proper countersink. I countersink by using a gage made out of scrap aluminum with a -4 dimple. I countersink till the gage lies flat against the flange. If I do that here, I enlarge the hole to point where cleco will not hold. Guess I am stumped. Would appreciate any help or suggestions from those who have been here. Regards and Thanks Vince Himsl RV8 fuselage Moscow, ID USA ________________________________________________________________________________
Date: Oct 14, 2001
Subject: Parking Brake RV-8
Thanks to all who posted their solutions to my brake question. I'v decided to mount the parking brake valve on a plate where the lines normally junctioned but going to fabricate a mounting plate bent back toward front of the airplane. This will put the valve on an angle instead of pointing straight down. Then using two 90 degree connectors on the input side, it should keep the valve from sticking so far down below the brace it attaches to. Then a 90 degree and a forty five degree on the output side. May try to get the swival type so I can use two 90 degree on the output. I'm also going to use the smaller flex lines that Heitman mentioned on his Web site from Pegasus Racing. The smaller lines look better as I thought the ones Vans sent were awful big. In addition, if it all works right, I'll be able to reach the lever with my hand and won't need a cable. If I can't reach it, then I'll maby attach an extension arm to it or rig a cable some how. Have to get it installed and get my seats made and sit in it to see the geometry. Will have digital pictures after I'm finished. At the rate I'm going, maby next month some time. Thanks again Ed O'Connor/N366RV/Sandy Creek Airpark ________________________________________________________________________________
Subject: Re: Countersinking the F-804 Wing spar Flange
Date: Oct 15, 2001
Vince: If I recall correctly, I just lightly machine countersunk the spar flange. The skin dimples won't fit perfectly inside, but after riveting nobody but you will know, and it won't affect the strength of the joint. George Kilishek N888GK Waiting for A/W inspection >From: "Vincent S. Himsl" <vhimsl(at)turbonet.com> >Reply-To: rv8-list(at)matronics.com >To: "RV-8 LIST" >Subject: RV8-List: Countersinking the F-804 Wing spar Flange >Date: Sun, 14 Oct 2001 10:08:32 -0700 > > >Hello, > >I am attaching the skins to the fuselage but have hit a snag where the >bottom F-822, F-826, and F-827 skins intersect the F-804 center section. > >I have dimpled all the skins which requires that I countersink the F-804 >spar flange. > >Problem: > >The spar flange is not thick enough to do a proper countersink. I >countersink by using a gage made out of scrap aluminum with a -4 dimple. I >countersink till the gage lies flat against the flange. > >If I do that here, I enlarge the hole to point where cleco will not hold. > >Guess I am stumped. Would appreciate any help or suggestions from those >who >have been here. > >Regards and Thanks > >Vince Himsl >RV8 fuselage >Moscow, ID USA > > ________________________________________________________________________________
Date: Oct 15, 2001
Rick That is where I mounted mine. Can reach it without a cable. May put a chain on it. Stan Mehrhoff Mounting the wings at the airport. ________________________________________________________________________________
Subject: Tank fit problem
Date: Oct 15, 2001
Good morning all, After dimpling tank edges the skin does not lay down flush with the spar and leading edge. The fit prior to dimpling was perfect. Have machine countersunk the spar to the correct depth and used # 8 dimple die on the tank. Would it be acceptable to file down the underside of the dimple, let's say 25% and try again. Also sent question to Van's. Thanks for the help! Jack PLEASE NOTE NEW WEB AND EMAIL, Thanks Jack www.IaJobs.com jack(at)IaJobs.com Jack Textor PERSONNEL INCORPORATED 604 Locust, Suite 516 Des Moines, IA 50309 515-243-7687 phone 515-243-3350 fax ________________________________________________________________________________
Date: Oct 15, 2001
First of all, make sure you used a #8 dimple die for a "screw" and not a "rivet". Dimple dies come in both flavors and the one for the rivet is slightly bigger (ie makes a bigger dimple then the one for the screw) then the one for the screw. If you're sure you got the right dimple die, test the depth of your spar countersinks with a test dimple on a small piece of .025. You'll probably find that you'll have to countersink a little more. Ron. -----Original Message----- From: Jack Textor [mailto:jack(at)IaJobs.com] Subject: RV8-List: Tank fit problem Good morning all, After dimpling tank edges the skin does not lay down flush with the spar and leading edge. The fit prior to dimpling was perfect. Have machine countersunk the spar to the correct depth and used # 8 dimple die on the tank. Would it be acceptable to file down the underside of the dimple, let's say 25% and try again. Also sent question to Van's. Thanks for the help! Jack PLEASE NOTE NEW WEB AND EMAIL, Thanks Jack www.IaJobs.com jack(at)IaJobs.com Jack Textor PERSONNEL INCORPORATED 604 Locust, Suite 516 Des Moines, IA 50309 515-243-7687 phone 515-243-3350 fax ________________________________________________________________________________
Date: Oct 15, 2001
here is a photo of my installation of the Matco parking brake valve on my RV8. Chris Hukill ________________________________________________________________________________
Subject: Thanks on tank fit ???
Date: Oct 16, 2001
Thanks to all that responded to my poor tank fit after dimpling, lots of good ideas. Van's said don't be too concerned with countersinking a little further. But.... Last night I actually installed some screws and I will be danged, everything seemed to fit well. Thanks, Jack PLEASE NOTE NEW WEB AND EMAIL, Thanks Jack www.IaJobs.com jack(at)IaJobs.com ________________________________________________________________________________
Date: Oct 17, 2001
Subject: primers
Has anyone used Pratt and Lambert's latex wash primer? It's an acrylic-zinc phosphate primer, and was recommended (by the guy selling it) as safe and effective. I am concerned about the "safe" part, and I like the idea of a water base. Jim Aylward empanage ________________________________________________________________________________
Date: Oct 17, 2001
Subject: primers
Has anyone used Pratt and Lambert's latex wash primer? It's an acrylic-zinc phosphate primer, and was recommended (by the guy selling it) as safe and effective. I am concerned about the "safe" part, and I like the idea of a water base. Jim Aylward empanage jimayl(at)aol.com ________________________________________________________________________________
Date: Oct 25, 2001
Subject: NEW Matronics Email List Feature! Browse Current List
Messages! Dear Listers, I have just finished building an all new Email List Web Browsing feature for the Matronics Email Lists. The new system allows you to use your web browser to view all of the current Email List messages. The system's indexes display all of the current List messages sorted by Subject, Author, Date, or Thread. Clicking on the URL links on these index pages will open another "Viewing Window" where the messages will be displayed. The format of the index pages and message viewing window are consistent with the existing Matronics Archive Search Engine and should be familiar to everyone. The messages available on this new List Browsing Feature span the previous 7 days of email for the given List. Each day the oldest day's messages are replaced with the current day's messages. The web pages are updated every 30 minutes with any new messages that are posted to the List during that time frame. Please have a look at the new Utility and let me know what you think! For ease of use, I've added a link to the new system on each of the List trailers that are appended to each List email message. I hope you will find the new system useful and also find it to be a handy companion to the Archive Search Engine. The new Email Browsing Utility can be found at the following URL: http://www.matronics.com/listbrowse From here, you can select any of the available Email Lists. Best regards, Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. Benjamin Franklin Historical Review of Pennsylvania, 1759 ________________________________________________________________________________
Subject: Setting 1/8 inch standard rivets
Date: Oct 26, 2001
Hi Group, While riveting my leading edge to the spar, the longer 5's, 6's and 7's 1/8 inch standard rivets would not set before destroying the head. I was using about a 2-pound bar and a 2x gun set at full power and tape on the heads. Very frustrating! I purchased a 3x and made a 4-5 pound bar out of some scrap steel and it really helped. I can now set the rivets in a second or two before they have a chance to work harden. Just wanted to pass the tip on. Jack Textor RV8, wings DSM PLEASE NOTE NEW WEB AND EMAIL www.IaJobs.com jack(at)IaJobs.com ________________________________________________________________________________
Subject: Re: Setting 1/8 inch standard rivets
Date: Oct 26, 2001
Jack, I absolutely agree. I started out with a 2X gun and about half way through the first wing, Avery had a special deal at Copperstate and I bought a 3X. I was amazed how easier it was to set the 1/8th rivets with just a couple hits. Bill Christie, RV8A, Phoenix ----- Original Message ----- From: Jack Textor <jack(at)IaJobs.com> Subject: RV8-List: Setting 1/8 inch standard rivets > > Hi Group, > While riveting my leading edge to the spar, the longer 5's, 6's and 7's 1/8 > inch standard rivets would not set before destroying the head. I was using > about a 2-pound bar and a 2x gun set at full power and tape on the heads. > Very frustrating! I purchased a 3x and made a 4-5 pound bar out of some > scrap steel and it really helped. I can now set the rivets in a second or > two before they have a chance to work harden. Just wanted to pass the tip > on. > Jack Textor > RV8, wings > DSM > > PLEASE NOTE NEW WEB AND EMAIL > www.IaJobs.com > jack(at)IaJobs.com > > ________________________________________________________________________________
Date: Oct 28, 2001
Subject: List Web Server Upgraded! Blazingly Fast Archive Searches!!
Dear Listers, As of this weekend, the Matronics Email List Web Server is now running on a brand new hardware platform and the latest version of RedHat Linux! The new hardware includes Dual 1.7GHz Xeon Processors, a 400MHz FSB motherboard, 1GB of 800MHz RAM, a Dual-Channel 160 MB/Sec Ultra-160 SCSI Controller, and an Ultra 160 36GB 15,000 RPM Seagate Cheetah hard drive. The performance of the new system is, in a word, breathtaking! In a variety of benchmark tests against the previous server, the new system is at *least* six times faster! This means that your Archive Search Engine queries will now come back in what seems like an instant! Single word searches of the 113MB RV-List Archive now return in 2-3 seconds, and searches of all other List Archives return in 1 second or less!! Performance enhancements in the download and viewing of all other web-based tools should also be noticeably improved as well. Please enjoy the new system performance and don't forget, the Annual Email List Fund Raiser is just around the corner!! :-) Best regards, Matt Dralle Email List Administrator Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. Benjamin Franklin Historical Review of Pennsylvania, 1759 ________________________________________________________________________________
Subject: Sensenich 87" report
Date: Oct 28, 2001
Greetings, As you may recall, my -8 has an O-360 with Ellison TBI and Lightspeed ignition, and I recently sent my 85" Sensenich prop off for a repitch to 87". Now that the prop is back on the plane, and I've flown it some, here are the less-than-complete results. Static RPM with the 85" was 2100 at sea level, and the 87" prop is 2025 RPM. Best cruise speed with the 85" was 174 kts at 8500 ft which was RPM limited. Best cruise at 8500 with the 87" prop was 179 kts. This is still RPM limited. I was able to produce 2730 RPM at 8500 with the 87" prop. This test was done in formation with another RV-8, that's equipped with a 180 hp engine (plus Lightspeed ignition) and a CS prop. The results- I can outrun him by 3-4 kts! We just won't talk about climb :-) This past weekend, I traveled to the Mecca of rotary powered aircraft (AKA Tracy Crooks fly-in), which was a 3 hour round trip with about a 40 kt wind at altitude. I ran as hard as I could, and saw 217 kts ground speed on the way there. This was at 9500 ft and about 2680 RPM. I'm still not able to run full throttle without redlining the engine, but there's certainly more power being used to turn the same RPM, because I'm burning about one GPH more fuel than before. The return trip... Ugh, 135-150 kts at various altitudes. I haven't done any official climb testing, but noticed that I was still getting 1400 FPM at 100 kts, 3000 ft, solo with full fuel. That's still pretty good in my book, though it's nothing compared to what some CS props can get. Bottom line- it was a good change, and I don't feel like 87" is over pitched by any definition. If you're using these numbers for comparison, make sure you remember that the Lightspeed ignition and Ellison probably add 10-15 HP, so your results may vary. Then again, get a Lightspeed, because that's where the majority of the HP comes from, and it's the best mod you can make. That's all folks. Now I need to find a project to install a rotary engine in. Anyone know of a nice cheap RV-3 project? While I'm dreaming, make it close to Florida :-) Rusty ________________________________________________________________________________
Date: Oct 29, 2001
I'm new on the list having had my RV8 for just over a week now. I have always wanted one and traded my Mooney in. Just never had time to build. I have a 85" Sensinich prop on my plane and find that at cruise altitudes, I cannot run but about 60% power to keep it under 2700 rpm. Have been considering having the prop repitched to 87 also. Good to hear your comments. However, my prop was repitched once by the previous builder/owner and I've heard that the props can only be repitched one time. Is this true? Maybe I could get something for a trade-in if I decided to go that route? Thanks for the good info on your experience. Some people have told me just to run it at 2800-2900 rpm but I would rather accept the 5-10mph slower cruise than put the additional stress on the engine. Besides, at 60% power, I'm really conserving fuel too. On another note. The oil pressure line going from the engine to the transducer mounted on the firewall is a small copper line with a compression fitting on the engine end. It has one loop in it before connecting to the transducer mounted on the firewall. Comming on the ramp last week that line broke at the compression fitting and oil pressure went to zero, of course. Shut the engine down immediatlely but still lost about two qts of oil on the ramp. It was an easy fix but I know this will probably happen again if I keep this set up. I read the construction manual and it recommends a flexible hose which I'm going to get. Any recommendations? I found a hose shop locally that can get the hose for me in a couple of days. I just need to let them know the type fittings on either end. I'm going to take the copper one off and take it to them. Going to do the same thing for the fuel pressure line too. BTW, they say the hose is made by aeroquip too. I forgot to ask them if I can get a restrictor in the hose as Van's suggest. If not, I think I can fabricate some type of restrictor to prevent a massive amount of oil loss if the situation ever happens again. I was amazed how much oil came out of that little 1/8" hose in such a short time. Oh well, thanks for any suggestions ahead of time and looking forward to being apart of this list. Fly Safe and Check Six! Johnny White -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Russell Duffy Subject: RV8-List: Sensenich 87" report Greetings, As you may recall, my -8 has an O-360 with Ellison TBI and Lightspeed ignition, and I recently sent my 85" Sensenich prop off for a repitch to 87". Now that the prop is back on the plane, and I've flown it some, here are the less-than-complete results. Static RPM with the 85" was 2100 at sea level, and the 87" prop is 2025 RPM. Best cruise speed with the 85" was 174 kts at 8500 ft which was RPM limited. Best cruise at 8500 with the 87" prop was 179 kts. This is still RPM limited. I was able to produce 2730 RPM at 8500 with the 87" prop. This test was done in formation with another RV-8, that's equipped with a 180 hp engine (plus Lightspeed ignition) and a CS prop. The results- I can outrun him by 3-4 kts! We just won't talk about climb :-) This past weekend, I traveled to the Mecca of rotary powered aircraft (AKA Tracy Crooks fly-in), which was a 3 hour round trip with about a 40 kt wind at altitude. I ran as hard as I could, and saw 217 kts ground speed on the way there. This was at 9500 ft and about 2680 RPM. I'm still not able to run full throttle without redlining the engine, but there's certainly more power being used to turn the same RPM, because I'm burning about one GPH more fuel than before. The return trip... Ugh, 135-150 kts at various altitudes. I haven't done any official climb testing, but noticed that I was still getting 1400 FPM at 100 kts, 3000 ft, solo with full fuel. That's still pretty good in my book, though it's nothing compared to what some CS props can get. Bottom line- it was a good change, and I don't feel like 87" is over pitched by any definition. If you're using these numbers for comparison, make sure you remember that the Lightspeed ignition and Ellison probably add 10-15 HP, so your results may vary. Then again, get a Lightspeed, because that's where the majority of the HP comes from, and it's the best mod you can make. That's all folks. Now I need to find a project to install a rotary engine in. Anyone know of a nice cheap RV-3 project? While I'm dreaming, make it close to Florida :-) Rusty ________________________________________________________________________________
Date: Oct 29, 2001
Johnny and all, This is a good subject that I felt I should address: >>However, my prop was repitched once by the previous builder/owner and I've heard that the props can only be repitched one time. Is this true? Actually this is not true. We allow for a total of 8 inches that a propeller can be pitched. All 72FM series propellers are manufactured as 83 pitches. If you receive an 85 pitch from us, it has been raised 2 inches. If you send us an 83 or an 85 (as Rusty did) and we raise it to an 87, that would be the same as ordering an 87 brand new from us, because we are still pitching up 4 inches from the original forging pitch. At that point we have gone up 4 inches of total pitch. We could conceivably repitch that same propeller back down to an 83 which would give us the final 8 total inches that we allow. I hope that my explanation makes sense and clears that up. On a specific note to Johnny: I have to assume that either your engine is producing more then 180 HP or you have some tach error. I would bet on the tach error. Before pitching the propeller, I would recommend having the tach calibrated. Most local FBO's or prop shops can do this very easily. Don't be surprised if they tell you that are showing a lower RPM then actual. This is always a good practice for everyone to adhere to. Ed Zercher ________________________________________________________________________________
Subject: capacitance fuel level senders
Date: Oct 29, 2001
I am getting ready to build the fuel tanks for my RV8 and plan on installing a flop tube to allow inverted flight. To eliminate any possible interference with a float sender, capacitance senders seem like the logical choice. Can anyone recommend a source for a high quality sender that will work in the RV8's tanks? Many seem to require access through the top of the tank which obviously won't work. I haven't decided on which manufacturer's gauges I will use, will the sender limit this or is a capacitance sender a universal signal? Thanks Tracy ________________________________________________________________________________
Subject: Re: capacitance fuel level senders
Date: Oct 29, 2001
Why don't you just order the capacitance sender kit from Vans for $50 or so? It's complete and designed for your tanks. You can see what they look like and how they are installed here. http://bmnellis.com/CapacitiveSender.htm Mike Nellis - http://bmnellis.com Plainfield, IL RV6 N699BM Reserved Mounting Control Surfaces Stinson 108-2 N9666K > > I am getting ready to build the fuel tanks for my RV8 and plan on installing > a flop tube to allow inverted flight. To eliminate any possible > interference with a float sender, capacitance senders seem like the logical > choice. > > Can anyone recommend a source for a high quality sender that will work in > the RV8's tanks? Many seem to require access through the top of the tank > which obviously won't work. I haven't decided on which manufacturer's > gauges I will use, will the sender limit this or is a capacitance sender a > universal signal? > > > Thanks > Tracy > > ________________________________________________________________________________
Date: Oct 29, 2001
Subject: Cool Graph on Archive Search Times...
Hi Listers, Below is a link to an interesting graph of the current Archive Search Engine ( http://www.matronics.com/search ) search times done on the 113Mb RV-List Archive file. The graph shows searches back through about Thursday. Based on the search times (shown in the Y axis), see if you can pick out the point at which the new Web Server hardware was installed... Impressive? :-) http://www.matronics.com/rv-list/RV-ListArchiveSearchTimes.jpg Best regards, Matt Dralle EMail List Admin. -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. Benjamin Franklin Historical Review of Pennsylvania, 1759 ________________________________________________________________________________
Date: Oct 29, 2001
I can't answer your question on the senders, however I would like to mention something that you may consider. I intended to install flop tubes in my Quickbuild 8, but because the tanks came completed, I didn't want to open them up to modify them for the flop tubes. Although I have an inverted oil system, and fuel injection, I didn't think that the type of aerobatics that I would be doing would require any sustained inverted or negative Gs, and the fuel in the lines would provide adequate inverted fuel supply, without flop tubes. During the flight testing period I did everything I could do to try to make the engine quit while inverted,during maneuvers, and after returning to positive G flight, and never got a cough. This included rolling 360s, hammerheads, and sustained inverted flight(maybe 10 second). The sustained inverted flight was limited by the high forward stick pressure that was required to keep the nose up, as this wing doesn't like to be upside down. These tests were accomplished feeding from both tanks(one at a time). Unless your intending to compete in advanced, or go after some sustained inverted record, I see no need for flop tubes, at least with my engine,fuel system configuration. Chris Hukill ________________________________________________________________________________
Date: Oct 31, 2001
Subject: Bill of sale?
Good news and bad news. I am almost finished (3-4 weeks) fitting wings. What is the procedure for getting a bill of sale from Vans, etc etc. Am I going to get hit with a giant tax bill or something like that? Thoughts please. Dan Ward 81243 almost there N417SN reserved. ________________________________________________________________________________
Subject: Re: Bill of sale?
Date: Oct 31, 2001
As for obtaining the BOS just call Van's they will mail it to you. As for the rest of the question, Boy, It all depends on Where you live, how long you have had the kit, was it delivered or will call. There is no real answer until you answer a bunch of questions. I suggest that you contact your State Board of Equalization. They will answer all your questions. If you do obtain information from them that would indicate you don't owe taxes or penalties for not paying up front, make sure to get it in writing. Each employee may have a different interpretation of the situation you describe to them. Ed Perry eperry(at)san.rr.com P.S. dodged the sales tax bullet ----- Original Message ----- From: TwoAviators <TwoAviators(at)lexcominc.net> Subject: RV8-List: Bill of sale? > > Good news and bad news. I am almost finished (3-4 weeks) fitting wings. > What is the procedure for getting a bill of sale from Vans, etc etc. Am I > going to get hit with a giant tax bill or something like that? Thoughts > please. > > Dan Ward > 81243 almost there > N417SN reserved. > > ________________________________________________________________________________
Date: Oct 31, 2001
From: "Ken Brooks" <kdbrv8r(at)charter.net> (by way of Matt Dralle <dralle(at)matronics.com>)
Subject: Photo of Lyle Hefel's Control Stick and Throttle Quadrant
Please see the photo at the new Matronics List Photo Share for Lyle Hefel's Throttle Quadrant at the following URL: http://www.matronics.com/ftp/Public/kdbrv8r@charter.net/ Ken ________________________________________________________________________________
Date: Nov 01, 2001
Subject: 2001 List Fund Raiser - Please Support Your Lists...
Dear Listers, During November of each year, I have a voluntary Email List Fund Raiser to support the continued operation, development, maintenance and upgrade of the Forums sponsored here. Your contributions go directly into improvements in the systems that support the Lists and to pay for the Internet connectivity primarily dedicated to supporting the Lists. This year, I've made some substantial improvements to the Lists and the supporting systems. These upgrades are focused on making your experience here faster, more enjoyable, and most importantly, informative. Here is a partial list of improvements that I've made on the systems this year: o Upgraded Web Server - Minimum 6X increase in performance * - Tons more high performance disk space and memory! - Increased availability and reliability - UPS Backup - Improved support for > 130,000 Archive Searches each year! * See http://www.matronics.com/rv-list/RV-SearchTime.jpg o Email System Disk Subsystem Upgrade - More storage and faster access times - Faster redistribution of List Messages - Processed over 45,000 List messages in 2001; 50,000 in 2000! o All new List Browse Feature * - Browse the last seven day's worth of List Messages - Quick access to current threads - Sort messages by Thread, Date, Subject, or Author * See http://www.matronics.com/listbrowse o All new Photo Share Feature * & - Simply email your photos and files to share - Scanned for viruses - Automatic Web Page Generation - Includes descriptions and poster information * See http://www.matronics.com/photoshare & Officially to be announced soon o Transition To High Performance Internet Service Provider - Improved reliability - Better access from most sites on the Internet - Improved throughput These are just some of the more visible improvements I've implemented this year. I'm always working to improve the behind the scenes operation of the Lists. I've built an elaborate system of message text and source address filtering mechanisms to assure that you only receive text data in the message, spam is nearly non-existent, computer viruses are never propagated through the Lists, and that message post redistribution is smooth and trouble free. This year has seen a lot of improvements in the Email List experience. If you enjoy the Forums here and make use of the many features, won't you take a moment and make a Contribution to support the continued operation and maintenance? Please note there is no advertising funding on the Lists. You don't see annoying banner ads in the Email messages or on any of the web pages. This just seems more friendly to me and makes the List experience just that much more personal. The operation of these Lists is supported *completely* through the donations of List Members just like you! Please take a moment to support your Lists by making a Secure Credit Card Contribution at the following web site: http://www.matronics.com/contribution Or you may send a personal check to: Matronics Email Lists c/o Matt Dralle PO Box 347 Livermore CA 94551-0347 I would like to thank everyone in advance for their Contribution and for their continued support over the past year! Best regards, Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 01, 2001
Subject: Re: RV-List: Well it's about that time of year again.......
Al Mojzisik misspelled the contribution page URL. "contributoin" is spelled: http://www.matronics.com/contribution :-) Matt >-------------- >--> RV-List message posted by: Al Mojzisik > >RV-Listers, > >I would just like to point out that it's November first and experienced >list members know what that means. It's time for our annual fund raiser for >Matt for providing us with this fabulous List so that we can get all the >help we need with our RV projects. Sometimes that help is technical and >sometimes it's mental. Most of us can't deny that the list has some value >to them. Well now is the time to tell Matt what the list means to you. Make >a donation to the Matronics List Services fund. It's purely voluntary. You >decide what it's worth to you. You just have to click on the link below and >you can make your donation via credit card. Or you can send Matt a check >at the address below. I will be making posts from time to time to remind >you of the continuing fund raiser and Matt will post a list of all donors >after the drive is over November 30th. I won't be tugging at your heart >strings this year and I won't be trying to shame you into donating. I'm >just going to leave it up to you to do the right thing for your >situation. Thanks for reading......... and let's make this a success for >Matt he's been working hard and making some great improvements. AL > >SSL Secure Web: http://www.matronics.com/contributoin > >USMail: Matronics >c/o Matt Dralle >PO Box 347 >Livermore CA 94551 > > >Al Mojzisik >InAir Instruments, LLC >Lift Reserve Indicator (LRI) >AOA and SO much more! >http://www.liftreserve.com > > >-------------- -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. Benjamin Franklin Historical Review of Pennsylvania, 1759 ________________________________________________________________________________
Date: Nov 01, 2001
Subject: New List Photos Available
http://www.matronics.com/photoshare/jtgarner@shentel.net Matt Dralle Email List Admin. -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. Benjamin Franklin Historical Review of Pennsylvania, 1759 ________________________________________________________________________________
Date: Nov 01, 2001
Subject: New Email List Photo Share Available
RV7-List(at)matronics.com, RV8-List(at)matronics.com, RV9-List(at)matronics.com
From: Matronics Email List Photo Share <pictures(at)matronics.com>
A new Email List Photo Share is now available at the following URL: http://www.matronics.com/photoshare/fasching@amigo.net/index.html --------------------------------- EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. --------------------------------- ________________________________________________________________________________
Date: Nov 03, 2001
Subject: rv-8 wings delay
Almost finished with the elevators/trim tabs, I decided, given the 8 week delay time as listed on Van's web site, to order the wings. On ordering, I was told an 8 week wait was what I should expect. Just got the receipt in the mail ...FEB 10, 2002!!!! Has anyone else had to wait 16 weeks for wings? should I order the fuse now too?! Jonathan Weiswasser Elevators ________________________________________________________________________________
Subject: Re: rv-8 wings delay
Date: Nov 04, 2001
Jonathan: I ordered my -8 wings this past June and received them in about 7 weeks. The 16 week time frame Van's gave you has got to be an error. Give them a call. Glenn Vokac ----- Original Message ----- From: "Jonathan Weiswasser" <jonweisw(at)rcn.com> Subject: RV8-List: rv-8 wings delay > > Almost finished with the elevators/trim tabs, I decided, given the 8 > week delay time as listed on Van's web site, to order the wings. On > ordering, I was told an 8 week wait was what I should expect. Just got > the receipt in the mail ...FEB 10, 2002!!!! Has anyone else had to wait > 16 weeks for wings? should I order the fuse now too?! > > Jonathan Weiswasser > Elevators > > ________________________________________________________________________________
Date: Nov 04, 2001
Subject: List Fund Raiser Off to a Slow Start...
Hi Listers, First I want to take everyone that has taken a minute already to make a Contribution to support the Email Lists in 2001! I also really appreciate all the kind words I've been receiving regarding the Lists and how much they mean to everyone. The testimonial means a lot to me and makes the many hours working on the system worth it!! Later in the month, I'll share a few of the kind words with the Lists. I've added a nifty new Bar Graph Thermometer to the message trailer that gives an up-to-the-minute percentage status of how many members have made a Contribution during 2001! It was a fun piece of code to write and hopefully will be a fun way to watch the Fund Raiser's Progress this year! As I've said in the past, the Lists are supported *completely* through your generous Contributions during the Fund Raiser and throughout the year. This includes all of the system and connectivity upgrades we seen, as well as makes the many hours I spend each month keeping the systems running even more enjoyable ;-). Won't you take a moment and make a Contribution right now to support your Lists? Its fast and easy with the On-line, SSL secure Credit Card system, or by direct US-Mailing a check. For complete information, please see the following URL: http://www.matronics.com/contribution Thank you in advance for your Generous Contribution!! Best regards, Matt Dralle Email List Administrator PS - Don't forget to monitor the Fund Raiser Bar Graph below! Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. Benjamin Franklin Historical Review of Pennsylvania, 1759 ________________________________________________________________________________
Date: Nov 06, 2001
Subject: New Email List Photo Share Available!
RV6-List(at)matronics.com, RV7-List(at)matronics.com
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: http://www.matronics.com/photoshare/kdbrv8r@charter.net/index.html --------------------------------- EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. --------------------------------- ________________________________________________________________________________
Date: Nov 08, 2001
Subject: What Listers Are Saying - Fund Raiser Continues...
Dear Listers, The 2001 List Fund Raiser is going well and I want to thank everyone that has already so generously made a Contribution to support the Lists! Below are some of the great comments and feedback members have been including along with their Contributions. Won't you make a Contribution today to support the continued operation and upgrade of your Lists? Its fast and easy using the SSL Secure Web Site or by simply sending a personal check. Complete information can be found at Contribution web site: http://www.matronics.com/contribution A give a special Thank You to all of those that have already contributed so far this year!! Matt Dralle Email List Administrator ================== What Listers Are Saying ==================== Great information site. - Edward S. This is the first thing I look at every day. - Ralph M. The new List option is WONDERFUL! - Kenyon B. ...new Search Software is absolutely fantastic!! - Bruce K. ...essential to my enjoyment of RV building and flying. - Douglas W. Great List! - Randall H. ...an invaluable service! - Carlos S. ...incredible service to the industry! - Alex M. Building wouldn't be the same without the "Great List". - Tom E. ...has helped the building process immensely. - Hap S. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 11, 2001
Subject: Have You Tried the New List Browse Feature??
Hi Listers, I've been getting a LOT of very positive feedback on the new Email List Browsing feature I added to the suite of List services a couple of weeks ago. A number of List members have written to say that they love the new List Browser because they can keep tabs on the latest List messages throughout the day without having to constantly check their email or wait for the Digest issue to come out. The List Browse Function allows you to use your web browser to view the current 7 day's worth of List messages for the give List. The indexes are updated every 30 minutes with any new messages that have been posted. You can sort all of the message indexes by Thread, Subject, Author, or Date and easily track and find current threads. You can check out the New List Browse Feature by going to the following URL and clicking on the List of your choice: http://www.matronics.com/listbrowse Please remember that November is List Fund Raiser month!! The continued operation and upgrade of the Email Lists are _entirely_ supported by YOUR Contributions and support. You'll never see annoying, flashing banner ads, or other forms of commercialism on these Lists. Just people sharing information, data, and stories about your favorite topic, plain (plane?) and simple. If you enjoy the Lists and all of the services here, won't you take moment and make a quick Contribution? It fast and easy using the SSL Secure Web site with your Visa or MasterCard. Or, you can also send a personal check to the address listed below. SSL Secure Web Site: http://www.matronics.com/contribution USMail: Matt Dralle c/o Matronics PO Box 347 Livermore, CA 94551-0347 Don't forget that the "List of Contributors" will be coming out in just a few short weeks! Don't you want to make sure you're name is on it? I would like to wish a special "Thank You" to everyone that has made a Contribution so far this year!! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 12, 2001
Subject: Free Copy of Van's New "THE RV STORY" Video!
Hey Listers! In support of the 2001 Email List Fund Raiser, Andy Gold of The Builder's Bookstore ( http://www.buildersbooks.com/ ) is donating a FREE COPY of the new edition of Van's "The RV Story" video (VHS) to any Email List Member making a Contribution of $50 or more! To take advantage of this wonderful Offer, please include the following information along with your Contribution, either in the Message Box if you Contribute on-line, or on a slip of paper if your Contribution is by check via the USMail: Van's RV Story Video Offer $50 or Greater Contributor [your name] [your shipping address] [your City, State and Zip Code] If you've already made a Contribution in 2001 of $50 or more and would like to receive the video, please drop me an email ( dralle(at)matronics.com ) and include the information shown above with the words "Video Offer" in the Subject line. Please note that this new edition of "The RV Story" will first be available in about 8 weeks. I want to thank Andy Gold and the Builder's Book Store for this *very generous* Contribution! If you haven't taken a moment to check out The Builder's Book Store web site yet, you owe it to yourself to have a look ( http://www.buildersbooks.com/ ). Andy has a fabulous selection of interesting, informative, and exceptionally useful books and videos on his site. Please have a look! Again, I would like to thank everyone that has so generously made a Contribution so far in this year's List Fund Raiser! Your Contributions make all of the Lists and Services found here possible - period. Thank you! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 12, 2001
Subject: Updated Email List Photo Share Available!
An Update to the Email List Photo Share below is available: Subject: Fuselage Roller http://www.matronics.com/photoshare/kdbrv8r@charter.net/index.html --------------------------------- EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. --------------------------------- ________________________________________________________________________________
Date: Nov 15, 2001
Subject: What They're Saying...
Hi Listers, The 2001 List Fund Raiser is currently underway and lot's of people have been making their Contribution and saying a lot of very nice things about the Lists and what they're daily-dose of Forum means to them! I've included a few more of the Lister comments below. Won't you take a moment to support your Lists this month? Its fast and easy by making a Secure Credit Card Contribution at the following web site: http://www.matronics.com/contribution Or by sending a personal check Contribution to: Matronics Email Lists c/o Matt Dralle PO Box 347 Livermore CA 94551-0347 For Complete information on the upgrades and improvements the Lists and servers have undergone this year, have a look at this URL: http://www.matronics.com/searching/getmsg_script.cgi?INDEX=113171908?KEYS=asdfasdf?LISTNAME=RV?HITNUMBER=4?SERIAL=1942094803?SHOWBUTTONS=NO Here's few more of the comments I've been receiving about what the Lists mean to its members: ====================== Not only a great way to help each other out, it's been a wonderful way to meet new friends. - Fred H. The List is invaluable to me... - Russell W. I absolutely love your Lists... - Scott C. ...you are tying all the builders together. - David A. The Lists continue to be an invaluable source of information. - Jeff O. I look forward to reading my Email every day... - Harvey S. They are invaluable resources to builders of all skill levels. - Kevin H. ...another year of excellent service. - Terry W. Way cool setup. - Chuck R. ...source of information, inspiration, support, and camaraderie. - Carlos S. I'd be lost without them... - Jeff O. ====================== Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 18, 2001
Subject: LOC
Hi Listers, The List of Contributors (LOC) is just around the corner! On December 1st I post a list of everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors? As a number of people have pointed out, the List seems at least, if not a whole lot more, valuable as a building/flying/recreating tool as a typical your magazine subscription. We won't even talk about a newsstand price... :-) Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa or M/C on the SSL Secure Web Site: http://www.matronics.com/contribution or by popping a personal check in the mail to: Matronics Email Lists c/o Matt Dralle PO Box 347 Livermore CA 94551-0347 !! Don't forget !! Andy Gold of the Builder's Book Store ( http://www.buildersbooks.com/ ) has generously donated a FREE copy of Van's new "The RV Story" video to anyone making a Contribution of $50 or more to support the Lists. For complete information on the _awesome_ offer, please see this URL: http://www.matronics.com/searching/getmsg_script.cgi?INDEX=113629625?KEYS=asdf?LISTNAME=RV?HITNUMBER=1?SERIAL=23392130806?SHOWBUTTONS=NO To make sure you get your video, be sure to follow the instructions at the URL above carefully! I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! I love to feel the love... :-) Best regards, Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 20, 2001
Subject: Michael Brown...
Hi Listers, In support of the 2001 Email List Fund Raiser, Michael Brown of Brown Aviation Tool Supply Co. ( http://www.browntool.com ) has generously offered to provide Gift Certificates to all Listers making Contributions of $30 or more this year! Making your Contribution to support these Email Lists and to qualify for the Brown Tool Gift Certificate is fast and easy by using the SSL Secure Credit Card Contribution Web Site at: http://www.matronics.com/contribution Or by sending a personal check Contribution to: Matronics Email Lists c/o Matt Dralle PO Box 347 Livermore CA 94551-0347 According to Michael, "The Gift Certificates have absolutely no strings attached and are as good as cash for anything from the Brown Tool Web Site or Catalog." The amount of your Gift Certificate is based on the size of your List Contribution and is according to the following: $100 or greater Contribution receives a $25 Gift Certificate! or $30-$99 Contribution receives a $10 Gift Certificate! ==================== How To Receive Your Certificate ==================== To receive your Brown Tool Gift Certificate, send an email message to: browntooloffer(at)matronics.com and include the following information: 1) Subject Line: Tool Offer 2) Which Gift Certificate you qualify for ($10 or $25) 3) [Your Name] 4) [Your Mailing Address] 5) [Your City, State Zip] ** Please only use the email address shown above ( browntooloffer(at)matronics.com ) to request your Gift Certificate! *** Anyone making a List Contribution of $30 or more in 2001 qualifies for the Gift Certificate! ==================== How To Receive Your Certificate ==================== You should receive your Gift Certificate from Brown Tool in about 2-4 weeks. I want to thank Michael Brown of Brown Aviation Tool Supply Co. for this wonderful offer in support of the Email Lists! If you haven't yet had a look at the Brown Tool Web Site ( http://www.browntool.com ), then you own it to yourself to take a peek! He has some great deals and good quality tools. And finally, I would like to thank everyone that has already made a Contribution in this year's Fund Raiser! Its YOUR support that keeps these Lists running and NOT ADVERTISING and FLASHING BANNER ADS... Thank you!! Matt Dralle Email List Administrator ________________________________________________________________________________
"Aaron Hughston"
Subject: For Sale
Date: Nov 21, 2001
Posting for a friend For Sale 1) completed RV-8 Tail Kit #1000 Asking $1400 2) RMI u-Encoder and u-Monitor. Both are assembled and tested. Comes with EGT & CHT probes and the gimbaled Compass attachment. Asking $2591 for both. Location is So. Cal. Contact Aaron Hughston @ vne200(at)hotmail.com Ed Perry eperry(at)san.rr.com ________________________________________________________________________________
Date: Nov 25, 2001
Subject: What Can You Say...?
Dear Listers, I've been getting a ton great comments on what the Lists mean to its members and I've included a few of them below. I'm sure _most_ of you can echo one or more of these sentiments to the tune of a nice List Contribution... :-) Just one more week until I post the 2001 List of Contributors! Won't you support the continued operation of these Lists by making a Contribution today and assure your place on the upcoming Contributor List? I'm sure your friends will be checking for your name on the LOC... ;-) SSL Secure Web Visa and MasterCard Contributions: http://www.matronics.com/contributions Personal Check via the US Mail: Matronics Email Lists c/o Matt Dralle PO Box 347 Livermore, CA 94551-0347 I want to thank everyone that has already made a Contribution this year! YOU make these Lists possible! Matt Dralle Email List Administrator =========================================================================== Can't live without my List everyday! - John B. Information you can't get anywhere else. - George D. ...one of the finest List sites on the Internet. - Dennis S. This List has saved my bacon more than once! - Larry H. Really invaluable service for a novice builder. - John B. ...got some useful help from the List. - Rocky S. A valuable resource. - Dennis N. This List is a Super resource... - Dwight F. ...couldn't have gotten this far without the resources on the List. - Jerry C. Great service to us builders... - Ronald M. ...someday we'll all meet in RV Heaven. Hey, how come there isn't an "RV-Heaven" List? - Louis W. The info I've gleaned from the List has saved me several thousand dollars... - Kevin H. ...the only International, Interesting, Up-to-date, List with the best search engine ever! - Hans L. ...check it ever day so I don't miss anything. - Jim B. Great List! - Douglas G. This List has saved me a few times already... - Thomas R. ...part of my morning wake up reading. - Dwight F. ...helped my make my plane better, safer, better looking, and built it quicker. - Kevin H. Have bought many items from the info the List gives. - Jim B. You meet the nicest people here. - George D. Informative, Amusing, Entertaining... - John B. ________________________________________________________________________________
Date: Nov 26, 2001
Subject: Don't Miss The Video...
Hey Listers! Just a reminder that in support of the 2001 Email List Fund Raiser, Andy Gold of The Builder's Bookstore ( http://www.buildersbooks.com/ ) is donating a FREE COPY of the new edition of Van's "The RV Story" video (VHS) to any List Member making a Contribution of $50 or more! To take advantage of this wonderful Offer, please include the following information along with your Contribution, either in the Message Box if you Contribute on-line, or on a slip of paper if your Contribution is by check via the USMail: Van's RV Story Video Offer $50 or Greater Contributor [your name] [your shipping address] [your City, State and Zip Code] If you've already made a Contribution of $50 or more during the 2001 Fund Raiser and would still like to receive the video, please drop me an email ( dralle(at)matronics.com ) and include the information shown above with the following Subject Line: Subject: Video Offer Please note that this new edition of "The RV Story" will first be available in about 8 weeks. I want to thank Andy Gold and the Builder's Book Store for this *very generous* Contribution! If you haven't taken a moment to check out The Builder's Book Store web site yet, you owe it to yourself to have a look ( http://www.buildersbooks.com/ ). Andy has a fabulous selection of interesting, informative, and exceptionally useful books and videos on his site. Please have a look! I would like to thank everyone that has so generously made a Contribution so far in this year's List Fund Raiser! Just a few more days until I send out the List of Contributors for 2001. Make your Contribution today to make sure your name is on the LOC!! Thank you! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2001
Subject: Brown Tool Gift Certificate Reminder...
Hi Listers, Just a reminder that in support of the 2001 Email List Fund Raiser, Michael Brown of Brown Aviation Tool Supply Co. ( http://www.browntool.com ) has generously offered to provide Gift Certificates to all Listers making Contributions of $30 or more this year! Making your Contribution to support these Email Lists and to qualify for the Brown Tool Gift Certificate is fast and easy by using the SSL Secure Credit Card Contribution Web Site at: http://www.matronics.com/contribution Or by sending a personal check Contribution to: Matronics Email Lists c/o Matt Dralle PO Box 347 Livermore CA 94551-0347 According to Michael, "The Gift Certificates have absolutely no strings attached and are as good as cash for anything from the Brown Tool Web Site or Catalog." The amount of your Gift Certificate is based on the size of your List Contribution and is according to the following: $100 or greater Contribution receives a $25 Gift Certificate! or $30-$99 Contribution receives a $10 Gift Certificate! ==================== How To Receive Your Certificate ==================== To receive your Brown Tool Gift Certificate, send an email message to: browntooloffer(at)matronics.com and include the following information: 1) Subject Line: Tool Offer 2) Which Gift Certificate you qualify for ($10 or $25) 3) [Your Name] 4) [Your Mailing Address] 5) [Your City, State Zip] ** Please only use the email address shown above ( browntooloffer(at)matronics.com ) to request your Gift Certificate! *** Anyone making a List Contribution of $30 or more in 2001 qualifies for the Gift Certificate! But, you have to follow the instructions above to receive it! ==================== How To Receive Your Certificate ==================== You should receive your Gift Certificate from Brown Tool in about 2-4 weeks. I want to thank Michael Brown of Brown Aviation Tool Supply Co. for this wonderful offer in support of the Email Lists! If you haven't yet had a look at the Brown Tool Web Site ( http://www.browntool.com ), then you own it to yourself to take a peek! He has some great deals and good quality tools. I would like to thank everyone that has already made a Contribution in this year's Fund Raiser! Thank you!! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2001
Subject: Contributors Down By 25%...
Dear Listers, First I want to thank everyone that has already so generously made a Contribution toward this year 2001 List Fund Raiser. It is your support that makes these Lists possible. Since there are only a couple more days until the official end of this year's drive, I want to share some statistics regarding this and previous Fund Raiser percentages. In years past, the percentage of members making a Contribution to support the Lists has typically been right around 23% of the total List population. This year, however, you'll note from the Contribution Meter that we're only at a little over 16% for some reason. This is down by roughly 7%, and translates into about a *30% decrease* in participation this year! I'm hoping that everyone is just waiting until the very last minute to make their Contribution this year, and that the needle on the Contribution Meter will still creep up to the normal 23% in the next few days! Saturday or Sunday I will be posting the 2001 List of Contributors, so you'll want to heat up that Contribution Web Site right away to make sure your name is on the 2001 LOC!! The SSL Secure Web Site: http://www.matronics.com/contribution The US Mail Address: Matronics Email Lists c/o Matt Dralle PO Box 347 Livermore, CA 94550-7227 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2001
Subject: [PLEASE READ] - Why Have A Fund Raiser Each Year?
Listers, A couple List Members have asked if the Lists are "in trouble financially" and wanted to know if this is why I was having a Fund Raiser. It got to thinking that perhaps I should explain why I have a Fund Raiser and also take the opportunity to express why I think the List Services here provide a far better experience than the commercial equivalents. I use the List Fund Raiser each year to offset the costs involved with running a high performance email list site such as this one. With the annual support from the List members through the PBS-like Fund Raiser, I have found I can run the entire site without having to inflect any of the members with those annoying banner ads flashing up all the time trying to sell Toner Cartridge Refills or other garbage nobody wants or needs. From the comments I've received over the years regarding the Lists, the great majority of the members really appreciate the non-commercialism of my List systems and don't mind my 'go-team-go' banter once a year to encourage members to support the Lists. I believe that the Lists services that I provide here offer a great many benefits over the commercial equivalents in a number of ways. The first feature I believe to be particularly significant is that you *cannot* receive a computer v*rus from any of my Lists directly. I've been on a few other List servers and have been unfortunate enough to download infected files people have innocently or not-so-innocently included with their posts. This just can't happen with my Lists; each incoming message is filtered and attachments stripped off prior to posting. I provide a Photo and File Share feature that allows members to share files and bitmaps with other members and everyone can be assured that these files will be prescanned for any sort of v*rus before they are posted. Safe and simple. Also, with this photo and file sharing technique, the Archives don't get loaded up with a great amount of bitmap "data" that slows the Archive Search times. Another feature of this system is the extensive List Archives that are available for download, browsing, and searching. The Archives go all the way back to the very beginning of each List and with the super fast Search Engine, the huge size of the Archives is a non-issue in quickly finding the data you're looking for. Another feature of the Archives, in my opinion, is that they have been primarily stripped of all the useless email header data and all the other header garbage that seems to build up in a typical email thread. I have received an extremely positive response from Listers regarding the new List Browse feature and the consensus is that the format and ease of use is outstanding. Members report that having the previous 7 days worth of messages online for easy browsing and sorting is hugely beneficial. And again, as with the real time distribution of List email, the messages are stripped of all the unnecessary email headers and potentially dangerous v*ruses. I've been running email Lists and services under the matronics.com domain since about 1989 starting with RV-List and 30 guys I knew who where building RVs. It has grown into nearly 40 different aviation-related Email Lists and an associated web site that receives over 500,000 hits each month!! With all the dot.bombs these days, I think there's a lot of value in supporting a service that has gone the long haul and is still providing and improving a high quality service at a price that's nearly free. I have to admit running these Lists is a labor of love and I hope it shows in the quality of the experience that you receive when you get a List Email Message, Search the Archives, or use the List Browser. The Lists will be here for a long time to come. If you just want to lurk a while for free, that's great and I encourage you to do so. If you use, appreciate, and receive value from these Lists, then please support them during the Annual List Fund Raiser! Thank you, Matt Dralle Email List Administrator ------------------------------------------ The SSL Secure Web Site: http://www.matronics.com/contribution The US Mail Address: Matronics Email Lists c/o Matt Dralle PO Box 347 Livermore, CA 94550-7227 ------------------------------------------ ________________________________________________________________________________
Date: Nov 30, 2001
Subject: Free Stuff Reminder...
Dear Listers, Don't forget that you can receive a free copy of Van's new Video, "The RV Story" with a $50 or greater contribution this year, or a $10 Gift Certificate from Brown Tool for a $30 or greater contribution or a $25 Gift Certificate for a $100 contribution. Below are two URLs for complete information on the two Offers. Please follow the respective instructions *carefully*. Van's Video Offer Information: http://www.matronics.com/searching/getmsg_script.cgi?INDEX=5781141?KEYS=asdf?LISTNAME=Yak?HITNUMBER=2?SERIAL=09092616692?SHOWBUTTONS=NO Brown Aviation Tool Gift Certificate Information: http://www.matronics.com/searching/getmsg_script.cgi?INDEX=5838463?KEYS=asdf?LISTNAME=Yak?HITNUMBER=2?SERIAL=09080216166?SHOWBUTTONS=NO I want to thank Andy Gold of the Builder's Bookstore and Michael Brown of Brown Aviation Tool Supply Co. for their generous offers in support the Lists this year!! Thank you, guys! I'd like to thank everyone that has already made a generous Contribution in support of the Lists! Thank you! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Dec 01, 2001
Subject: Comments...
Listers, Below are some of the comments I've received just this week alone from members along with their Contributions to support the Lists! What can I say? Wow. I really appreciate the kind words and extremely positive feedback and I would encourage you to read over a few of comments below. I think they really say a mouthful... The last couple of days have seen a huge increase in support!! Thank you to all that have Contributed and to those that have rallied support for the Lists! Since the response has been so wonderful recently, I plan to delay the posting of the 2001 List of Contributors a few days to assure that everyone will be included! Won't you make your Contribution today to support the Lists? ------------------------------------------ The SSL Secure Web Site: http://www.matronics.com/contribution The US Mail Address: Matronics Email Lists c/o Matt Dralle PO Box 347 Livermore, CA 94550-7227 ------------------------------------------ Thank you to everyone for the kind words and support! Matt Dralle Email List Admin. ======== Some Great Comments on What The Lists Mean to its Members ========== ...great source of information, education, relaxation, frustration, and socialization. - John H. Can't imagine what it would be like building with out the Lists... - Steven E. Look forward to the list every day. - Parker T. I really enjoy reading the banter... - Wesley H. ...enjoy the patter on construction tips and possible problem areas. - Richard N. Couldn't have built my RV-4 without the List and archives!! - Warren M. I have found the list to be a great help, especially for a first time builder. - Peter D. I thoroughly enjoy the List. - Larry B. The List is a great resource. - Dennis K. The list is great entertainment. - Gary Z. Can't say enough about the good information that I have received from reading the List. - Robert C. ...it's the best! - Steve F. I'm addicted to the List! - Rodney B. The list has been a wonderful resource of knowledge. - Doug B. As a first time builder, the lists have been my most important source of information. - James V. It [read the List] is the first thing I do every day is see what's new. - Billie F. The information available through the List has made my flying safer... - Dave R. I get much more information about my plane from this List than from all of my aviation magazines combined. - Roger H. I love the list!!!! - Ken L. Much better value than a magazine subscription. - Ted M. ...found it very useful. - Allan J. ...this list has been a great service to me. - Peter F. I cannot express just how USEFUL the Lists are. - Geoff T. ...a tremendous help to my RV-8 project and a way to meet some of the best people going. - Steve G. The List is invaluable, and the best I've ever seen. - Ed C. Like another family for many of us. - John H. The lists have saved a bunch of calls to Van's for guidance. - James V. I think I'm addicted... - Terry C. Love it! - David W. The information really helps... - Jim P. ...I find [it] very informative. - Real D. ...List keeps me motivated... - Cliff M. The exchange of information is really helpful... - M.N. Lots of great info on the List. - Larry D. ________________________________________________________________________________
Date: Dec 02, 2001
A new Email List Photo Share is available: Subject: Buick Aluminum Block http://www.matronics.com/photoshare/tbird@ptsi.net/index.html --------------------------------- EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. --------------------------------- ________________________________________________________________________________
Date: Dec 04, 2001
Subject: what the heck?
Couple of questions. 1. My "P" leads show grounded when the mag switch is turned off. However the engine keeps running. Thoughts? Maybe poor connection between the p lead and the mag contact? 2. I was planning to put a fuse, and toggle switch between the buss and voltage regulator to turn off the alternator. I am also seeing in some diagrams a 30 amp fuse in the output side too. Do I need to do that? Dan s/n 81243 Dang near there. ________________________________________________________________________________
Subject: Re: what the heck?
Date: Dec 04, 2001
Yes, without the fuse on the output side a short on the other side between fuse and alt. would leave your system unprotected. ----- Original Message ----- From: "TwoAviators" <TwoAviators(at)lexcominc.net> Subject: RV8-List: what the heck? > > Couple of questions. > > 1. My "P" leads show grounded when the mag switch is turned off. However > the engine keeps running. Thoughts? Maybe poor connection between the p > lead and the mag contact? > > 2. I was planning to put a fuse, and toggle switch between the buss and > voltage regulator to turn off the alternator. I am also seeing in some > diagrams a 30 amp fuse in the output side too. Do I need to do that? > > Dan > s/n 81243 > Dang near there. > > ________________________________________________________________________________
Date: Dec 04, 2001
Is the engine grounded? >From: "Wil Ramsey" <wilr(at)strato.net> >Reply-To: rv8-list(at)matronics.com >To: >Subject: Re: RV8-List: what the heck? >Date: Tue, 4 Dec 2001 11:25:08 -0500 > > >Yes, without the fuse on the output side a short on the other side between >fuse and alt. would leave your system unprotected. >----- Original Message ----- >From: "TwoAviators" <TwoAviators(at)lexcominc.net> >To: >Subject: RV8-List: what the heck? > > > > > > Couple of questions. > > > > 1. My "P" leads show grounded when the mag switch is turned off. However > > the engine keeps running. Thoughts? Maybe poor connection between the p > > lead and the mag contact? > > > > 2. I was planning to put a fuse, and toggle switch between the buss and > > voltage regulator to turn off the alternator. I am also seeing in some > > diagrams a 30 amp fuse in the output side too. Do I need to do that? > > > > Dan > > s/n 81243 > > Dang near there. > > > > > > ________________________________________________________________________________
Date: Dec 04, 2001
Regarding your mag P-lead issue... If you're using Bendix mags (S-20 type anyway), check to see that the lead is actually touching the contact inside the mag. You may have to bend the spring contact up to touch the lead end that threads into the mag housing. ________________________________________________________________________________
Date: Dec 05, 2001
Subject: Re: Fused alternator output
The requirement for a fused output depends upon the type of alternator/ voltage regulator that you are using. The internally regulated 40 amp automotive alternator that I am using has overcurrent protection as a function of the integral voltage regulator, that acts the same as a 40 amp fuse, hence no additional protection is required on the OUTPUT side. The INPUT side however requires a fused 5 amp feed. Chris Hukill flying RV-8 ________________________________________________________________________________
Date: Dec 06, 2001
Subject: [ Ken Brooks ] : New Email List Photo Share Available!
RV6-List(at)matronics.com, RV7-List(at)matronics.com, RV8-List(at)matronics.com, RV9-List(at)matronics.com, Homebuilt-List(at)matronics.com, Zenith-List(at)matronics.com, Tailwind-List(at)matronics.com, Kolb-List(at)matronics.com
A new Email List Photo Share is available: Subject: Portable Bench Power Tool Cart http://www.matronics.com/photoshare/kdbrv8r@charter.net.12.06.2001/index.html --------------------------------- EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. --------------------------------- ________________________________________________________________________________
Date: Dec 09, 2001
Subject: first flight
Flew RV-8 #80072 for the first time today. Flew great. Will forward pictures and numbers later next week. Stan Mehrhoff ________________________________________________________________________________
Date: Dec 10, 2001
Subject: Re: first flight
Way to go Stan!! Congratulations cheers Todd > >Flew RV-8 #80072 for the first time today. Flew great. Will forward pictures >and numbers later next week. > >Stan Mehrhoff > > ________________________________________________________________________________
Date: Dec 10, 2001
Congratulations. Be a little bit late with my 80303. Hope to be airborne in 2002. Stephan Servatius RV 8 Germany N188rv(at)aol.com schrieb: > > Flew RV-8 #80072 for the first time today. Flew great. Will forward pictures > and numbers later next week. > > Stan Mehrhoff > > Stephan Servatius Untere Hauptstr. 3 85461 Bockhorn Germany ________________________________________________________________________________
Date: Dec 11, 2001
Subject: New Photo Share Main Index Page - The Detail You Asked For...
Hi Listers! I've been noticing a lot of people having fun with the new Email List Photo and File Share feature and I've seen a great many hits on the various member pages. A number of you wrote to say that some additional topic data on the Main Photo Share Index page would certainly be helpful and I would have to agree. It took a little programming, and it was a job retrofitting to all of the older Shares, but I think you'll be pleased with the outcome! I've added Poster Name, Photo Share Subject, and Target Email List data to the Main Index. Clicking on a Subject text opens a new window with the Photo Share and the thumbnails. Have a look and feel free to submit your photos for sharing! The instructions are at the top of the Main Photo Share Index Page. The URL is: http://www.matronics.com/photoshare Enjoy!! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Dec 11, 2001
Subject: [ Howard Cochran ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Subject: RV-8 Rear Stick w/ "S" Bend http://www.matronics.com/photoshare/W4PPN@aol.com.12.11.2001/index.html --------------------------------- EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. Main Photo Share Index: http://www.matronics.com/photoshare --------------------------------- ________________________________________________________________________________
Date: Dec 11, 2001
Subject: [ Al Mojzisik ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Subject: Fiberglass Plenum http://www.matronics.com/photoshare/prober@iwaynet.net.12.11.2001/index.html --------------------------------- EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. Main Photo Share Index: http://www.matronics.com/photoshare --------------------------------- ________________________________________________________________________________
Date: Dec 11, 2001
Subject: [ Fabian Lefler ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Subject: Wing Jig http://www.matronics.com/photoshare/fablef@bellsouth.net.12.11.2001/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Dec 11, 2001
Subject: [ Rob Ray ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Subject: 160th F-16/RV Pilots http://www.matronics.com/photoshare/smokyray@yahoo.com.12.11.2001/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Dec 16, 2001
Subject: [ PLEASE READ ] : Matronics Network Upgrade Mon. 12/17/01
Listers, According to my ISP, Speakeasy, they will be doing some sort of "backbone upgrade" Monday, 12/17/01. Their message doesn't mention whether or not this will impact connectivity for any length of time. I wanted everyone to know that there might be a time when access to the Matronics Web Server and Email Lists might be unavailable. If there's a problem, I'll post a message from a different email address with details. Bottom line: Hopefully nobody will notice... Best regards, Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: The entire risk as to the quality.
Date: Dec 17, 2001
Should this software prove defective, you and not the author assume the entire cost of any service and/or repair. The author shall not be held liable for any loss of data, loss of revenue or any other direct or indirect damage or claims caused by this software package. ________________________________________________________________________________
Date: Dec 20, 2001
Subject: [ Paul Imhof ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Paul Imhof Subject: Miss America http://www.matronics.com/photoshare/Paul_Imhof@Dell.com.12.20.2001/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Date: Jan 04, 2002
Subject: Re: RV8-List Digest: 0 Msgs - 01/03/02
Happy New Year. I am build and 8A with 0-320 Lyc and a constant speed prop. Has anyone had experience with this combination, was wondering if it is still a good idea to put the battery in back to off set the weight of the CS? Thanks, Wil Ramsey ________________________________________________________________________________
Date: Jan 04, 2002
I have one I am building with the 160hp and C/S prop...with batt. on firewall...and have had one flying with this combo....no problem here... Wil Ramsey wrote: > > Happy New Year. > > I am build and 8A with 0-320 Lyc and a constant speed prop. Has anyone had > experience with this combination, was wondering if it is still a good idea > to put the battery in back to off set the weight of the CS? > > Thanks, > > Wil Ramsey > ________________________________________________________________________________
Date: Jan 06, 2002
Subject: [ Alex Peterson ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Alex Peterson Subject: VM11120A Vacuum switch http://www.matronics.com/photoshare/alexpeterson@usjet.net.01.06.2002/index.html -------------------------------------------- o EMAIL LIST PHOTO SHARE Share your files and photos with other List members simply by emailing the files to: pictures(at)matronics.com Please view the typical Share above and include the Description Text Fields as shown along with your submission of files and photos. o Main Photo Share Index: http://www.matronics.com/photoshare -------------------------------------------- ________________________________________________________________________________
Subject: Alternator B Leads
Date: Jan 11, 2002
What are you guys using for circuit protection for your alternator B leads and what size wire? Ed Perry eperry(at)san.rr.com ________________________________________________________________________________
Date: Jan 14, 2002
Subject: CASH PAID!!!
looking for a project that someone had to quit on, preferably a quickbuild rv-8 or partially started kit.. please email or call Bill Phillips 501-944-4357 ________________________________________________________________________________
Subject: RV-8 Thermo Acoustic Blanket
Date: Jan 14, 2002
Hello All, I am on the "homestretch" of my RV-8 project and will be installing insulation in various areas of the cockpit to both insulate and reduce noise. The material that I am going to use is manufactured by Orcon, a supplier to commercial aircraft manufacturers and is identical to that used to insulate their fuselages. It is a fiberglass-type with both sides covered by a high-tech material that prevents the insulation from giving you "the fiber itch" and also provides some degree of fire protection for a short period of time. The factory was kind enough to provide me with enough material to experiment on the best way to fashion the insulation during the project and that's my next task. As with so many others that have gone before me and made cottage industries out of small aspects of the aircraft building "adventure", I have a question for you: are there any RV-8 builders that would be interested in purchasing an insulation package for their project? As I've said, I'm not sure how the final product would look, but I am thinking that it would be a number of individual numbered pieces each sized for their area and possibly held secure with Velcro tape. Of course the area for the back-seater would be covered by the floor panels and I envision either cloth side covers or super lightweight aerospace hardcover material for the sidewalls (your choice, of course-I'm just the insulation guy). The price? I'm not sure yet depending upon time and materials. I'm just trying to gage interest. Maybe around a hundred bucks or so?-Just a guess. I DO know that after flying around in the back seat of my buddy's RV-8 that any help on the cold-soak issue would be welcome. If you're at all interested, send me a note and I'll keep you advised of what I find and my progress. Thanks for your time. Bill Sanford N511SF bsanford(at)silverlink.net ________________________________________________________________________________
Subject: RV-8 Fuselage tip
Date: Jan 14, 2002
Before you rip apart and toss your fuselage packing crate, check drawing 42 lower left corner. There you see the wood temporary floors you will need later when you are finishing up the fuselage. What you can do is take the 3/8 thick packing board with the paper backing and sandwich it together using liquid nails to get the 3/4 you need for the temporary floors. Let dry then cut. Saves you some bucks on the cost of 3/4 inch plywood and saves you an hour or so going to get it. One of the 4x8 sheets in nice condition should do it. You can pick the best sides to show. The paper backing actually will help when you or whoever can fit is sliding around inside. Regards, Vince Himsl RV8 Canoe (finally!) Moscow, ID 83843 ________________________________________________________________________________
Subject: Injected fuel filters
Date: Jan 15, 2002
Besides Airflow Performance, Has anybody run a fuel filter for an "injected engine" that will fit in the wing root and had success. Airflow says that there is no filter currently available besides theirs that will run reliably. Paper filters will swell and they say that gascolator screens are too fine. They recommend a 125 micron screen for the inlet prior to the fuel pump. My problem is that I don't want the filter in the cockpit. I imagine the smell of fuel being there for some time after I change the filter and spill it everywhere. Thanks, Ed Perry eperry(at)san.rr.com ________________________________________________________________________________
From: "Jim Norman" <jnorman(at)intermapsystems.com>
Date: Jan 16, 2002
Ed, Why not put the AFP filter in the wing root? It will fit just fine. I put my AFP filter on the firewall (inside a cool box), but I did put the entire AFP fuel pump in the wing root.... its a LOT bigger than the filter. jim Tampa -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Ed Perry Subject: RV8-List: Injected fuel filters Besides Airflow Performance, Has anybody run a fuel filter for an "injected engine" that will fit in the wing root and had success. Airflow says that there is no filter currently available besides theirs that will run reliably. Paper filters will swell and they say that gascolator screens are too fine. They recommend a 125 micron screen for the inlet prior to the fuel pump. My problem is that I don't want the filter in the cockpit. I imagine the smell of fuel being there for some time after I change the filter and spill it everywhere. Thanks, Ed Perry eperry(at)san.rr.com ________________________________________________________________________________
Subject: Re: Injected fuel filters
Date: Jan 16, 2002
Hi Jim, Please tell me why it is important to fit an additional fuel filter and not just a gascolator before the electric injection pump? I have only the gascolator and thereafter the pump. Is that wrong? Stephan Servatius RV8 Germany Jim Norman schrieb: > > > Ed, > Why not put the AFP filter in the wing root? It will fit > just fine. I put > my AFP filter on the firewall (inside a cool box), but I > did put the entire > AFP fuel pump in the wing root.... its a LOT bigger than > the filter. > > jim > Tampa > > -----Original Message----- > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of > Ed Perry > To: rv8list(at)yahoogroups.com; rv8-list(at)matronics.com > Subject: RV8-List: Injected fuel filters > > > > > Besides Airflow Performance, > > Has anybody run a fuel filter for an "injected engine" > that will fit in > the wing root and had success. Airflow says that there is > no filter > currently available besides theirs that will run > reliably. Paper filters > will swell and they say that gascolator screens are too > fine. They > recommend a 125 micron screen for the inlet prior to the > fuel pump. My > problem is that I don't want the filter in the cockpit. I > imagine the > smell of fuel being there for some time after I change > the filter and > spill it everywhere. > > Thanks, > Ed Perry > eperry(at)san.rr.com > > > ================= > Contributions of > other form > ================= > latest messages. > List members. > ================= > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > ================= > > > > > > ________________________________________________________________________________
Date: Jan 16, 2002
Hi Jim, I have not installed the wings yet and am concerned about 2 things with the AFP filters. 1) I was not sure how to access the filters in the wings, is there enough room between the wings and fuselage to get the required wrenches in there, If so can you estimate the distance between the fuselage and first wing rib/fuel tank? 2) Is cost...If I put one AFP in each wing I am close to $300. Granted it is probably the best method but I have also found an Aeromotive Filter that has a 100 micron filter that is 11/4" diameter and 3" long and rated for fuel injection, for $79 each. Ed Perry eperry(at)san.rr.com ----- Original Message ----- From: "Jim Norman" <jnorman(at)intermapsystems.com> Subject: RE: RV8-List: Injected fuel filters > > Ed, > Why not put the AFP filter in the wing root? It will fit just fine. I put > my AFP filter on the firewall (inside a cool box), but I did put the entire > AFP fuel pump in the wing root.... its a LOT bigger than the filter. > > jim > Tampa > > -----Original Message----- > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Ed Perry > To: rv8list(at)yahoogroups.com; rv8-list(at)matronics.com > Subject: RV8-List: Injected fuel filters > > > Besides Airflow Performance, > > Has anybody run a fuel filter for an "injected engine" that will fit in > the wing root and had success. Airflow says that there is no filter > currently available besides theirs that will run reliably. Paper filters > will swell and they say that gascolator screens are too fine. They > recommend a 125 micron screen for the inlet prior to the fuel pump. My > problem is that I don't want the filter in the cockpit. I imagine the > smell of fuel being there for some time after I change the filter and > spill it everywhere. > > Thanks, > Ed Perry > eperry(at)san.rr.com > > ________________________________________________________________________________
Date: Jan 16, 2002
Subject: Re: RV8-List Digest: 1 Msgs - 01/15/02
Put it in the firewall Bud Newhouse finishing ________________________________________________________________________________
Date: Jan 17, 2002
Subject: Re: RV8-List Digest: 1 Msgs - 01/13/02
Bill, I have a completed empennage (except for the fiberglass tip attachment). Its for sale along with the serial number, manuals, and documentation. I have lots of digital photos of the project. Steve Bend, OR 541-383-8277 >looking for a project that someone had to quit on, preferably a >quickbuild >rv-8 or partially started kit.. > > >please email or call >Bill Phillips >501-944-4357 > > ________________________________________________________________________________
Date: Jan 19, 2002
Subject: Re: RV8-List Digest: 6 Msgs - 01/14/02
Bill: Thanks for the post. I'd be interested, so please keep me in the loop. I'm a ways off but I'm aggregating pieces of info here and there for the right time. Thx. Sid Svanlaningham(at)cfl.rr.com ________________________________________________________________________________
Date: Jan 19, 2002
Subject: (no subject)
Hi, I would be interested in an insulation kit for my RV-8 QB. It is a great idea and thanks for the effort of trying first!! I just started the wings. Question: Does the WD-421 need any lubricant on the brass bushing. I reamed it out and it rotates very freely. I was just wondering what the effect of metal on metal would have after prolonged use. Thanks, Jim Sherry Boulder, CO
December 25, 2000 - January 21, 2002
RV8-Archive.digest.vol-ab
