RV8-Archive.digest.vol-ae
February 22, 2003 - August 20, 2003
      > of order and having  to take it apart to access something else? I was going
      > to wait on the wing / fuselage attach until the wings go on for good.
      > Thanks.
      > Al Grajek
      > RV8A
      Greg V. Miller
Date: Feb 22, 2003
Subject: Re: (no subject)
BRYAN, I HAVE DECIDED TO PASS ON THE ROCKETS. INSURANCE & OTHER THINGS INVOLVED. WOULD LIKE TO SEE PHOTOS OF YOUR 8. THANKS. DOUG ________________________________________________________________________________
Date: Feb 22, 2003
Subject: (no subject)
Gound loops in taildraggers are primarily caused by the pilot. A nose gear collapse on a nosedragger is more likely to be a design problem. Van's must know about the problem. I'd like to know if they have a plan to resolve it. Stan Sutterfield Tampa, FL RV-8A QB ________________________________________________________________________________
Date: Feb 22, 2003
I'm not convinced that nose gear collapse is a design problem of Van's. My understanding is that the possibility of nose gear collapse under extreme circumstances is an inherent problem of all tricycle gear airplanes, which is why conventional gear is considered more suitable for bush planes. Van's did have some concerns with the 6A nose gear which they addressed in an October '98 service bulletin. Have a look. There must be a lot of messages in the archives about it. I'm sure what was learned with the 6A problems was incorporated into the 8A design and manufacturing. I expect they are exactly the same parts. Terry RV-8A finish -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Speedy11(at)aol.com Subject: RV8-List: (no subject) Gound loops in taildraggers are primarily caused by the pilot. A nose gear collapse on a nosedragger is more likely to be a design problem. Van's must know about the problem. I'd like to know if they have a plan to resolve it. Stan Sutterfield Tampa, FL RV-8A QB ________________________________________________________________________________
Date: Feb 22, 2003
Hi Doug I am computer illiterate so don't know how to send pics. via e-mail. Send your snail mail address and I will mail some photos. Regards Bryan Dougpsr(at)aol.com wrote: > >BRYAN, I HAVE DECIDED TO PASS ON THE ROCKETS. INSURANCE & OTHER THINGS >INVOLVED. WOULD LIKE TO SEE PHOTOS OF YOUR 8. >THANKS. >DOUG > > > > ________________________________________________________________________________
Subject: F-804N Channel Cap Installation Heads UP
Date: Feb 25, 2003
Where: RV-8 Fuselage center section F-804C bulkheads Short: Recommend one does not drill the F-804N channel cap to the F-804C bulkheads until after mounting the F-816 cockpit rails. Long: When assembling the right and left control panels to the fuselage, I assumed (yes I know..) that I should drill and cleco the channel caps then also. Not a good idea as in order to align the F-804C flanges properly to the F-816 cockpit rails (much later in the plans) I have to remove the clecoes on the channel cap for proper center line alignment. The holes in the F-804C no longer line up with the pre-punched ones in the channel cap. Fortunately, most of mine lined up but many on the forward side for me did not requiring me to either make new channel caps from scratch or drill new holes between the existing pre punched ones. Haven't decided yet which way I will go. Regards, Vince Himsl RV8(SB) - Fuselage Moscow, ID USA ________________________________________________________________________________
Date: Feb 25, 2003
Vince, I drilled my channel caps way too soon and consequently got them spaced wrong, which became obvious when I put the armrests and the switch panel and the throttle quadrant in. Fortunately, mine was far enough off that I could reposition it and re-drill it in the proper location. Terry Where: RV-8 Fuselage center section F-804C bulkheads Short: Recommend one does not drill the F-804N channel cap to the F-804C bulkheads until after mounting the F-816 cockpit rails. Regards, Vince Himsl RV8(SB) - Fuselage Moscow, ID USA ________________________________________________________________________________
"RV List" , "RV8ListVANS" , "rv8-list"
Subject: Vancouver and Oregon RVers
Date: Mar 01, 2003
I am building an 8, and I will be in Vancouver Sunday Mar.2 until Friday. I may take a drive to Vans ( I still have not been able to get a ride in one) and look around. If anyone wants to show me thier RV give me a call or email me. 859-381-9460. Thanks. Al Grajek RV8 Finish kit ________________________________________________________________________________
Date: Mar 01, 2003
Date: Mar 08, 2003
Subject: [ James E. Bean ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: James E. Bean Subject: RV-8 Cooling Cowl Flap http://www.matronics.com/photoshare/jim-bean@att.net.03.08.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject: Fiber Optic Cable
Date: Mar 08, 2003
Has anyone run fiber optic cable to the nav lights to give a cabin indicator? Is there a better way to tell of the lights are on from inside the cockpit? Mike Duggan N918RV (Reserved) RV8AQB-- on wings. ________________________________________________________________________________
Subject: Re: Fiber Optic Cable
Date: Mar 08, 2003
put a little nixie light on the inst panel to tell you when the nav lites are on..that is what some of the big boys do...good luck! ----- Original Message ----- From: "Michael Duggan" <judge(at)dslextreme.com> Subject: RV8-List: Fiber Optic Cable > > Has anyone run fiber optic cable to the nav lights to give a cabin indicator? Is there a better way to tell of the lights are on from inside the cockpit? > > Mike Duggan > N918RV (Reserved) > RV8AQB-- on wings. > > ________________________________________________________________________________
From: "Michel Gordillo" <michelgordillo(at)telefonica.net>
Date: Mar 09, 2003
I have seen a very short piece of Fiber optic cable from de nav bulb to the top of the wing, pointing towards the pilot. Just enough to check if the light works, very easy, very light. Michel ----- Original Message ----- From: "Michael Duggan" <judge(at)dslextreme.com> Subject: RV8-List: Fiber Optic Cable > > Has anyone run fiber optic cable to the nav lights to give a cabin indicator? Is there a better way to tell of the lights are on from inside the cockpit? > > Mike Duggan > N918RV (Reserved) > RV8AQB-- on wings. > > ________________________________________________________________________________
Date: Mar 09, 2003
Why not use the position of the switch? - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com 2003 - The year of flight! > > --> > > > > Has anyone run fiber optic cable to the nav lights to give a cabin > indicator? Is there a better way to tell of the lights are > on from inside the cockpit? > > > > Mike Duggan > > N918RV (Reserved) > > RV8AQB-- on wings. ________________________________________________________________________________
Date: Mar 09, 2003
Subject: [ John Foy ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: John Foy Subject: http://www.matronics.com/photoshare/foyboy6@hot.rr.com.03.09.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject: Scratches in Aluminum
Date: Mar 12, 2003
How do you gauge if a scratch is too deep? My HS skin seems to have come with a scratch in it that is about 2 inches long. I might be able to sand it out but it would probably take something as course as 120 grit for how deep it is. and then more fine to polish it. Would this be acceptable for structural reasons? I can put it on the bottom and I'm sure the paint would cover it as well but I don't want to chance it if it is a safety issue. Also...uh oh, here we go.... is it a big deal not to prime the inside of the skins even though I've taken the time to prime all ribs and spars? Thanks, -Will Allen North Bend, Wa. RV8 emp ________________________________________________________________________________
Date: Mar 11, 2003
Subject: first engine failure, need help
rv6-list(at)matronics.com Well, I had my first engine failure and landed without incident. I need some help trouble shooting this one. On takeoff at FPR, at about 800 AGL, the engine lost most of its power. It was a sputter, followed my an almost shut down. It reminded me of the time I was setting up my fuel flow on the RMI and ran a tank try. I check the boost, it was confirmed on, mixture rich, and switch tanks. No luck. I jockeyed the throttle and mixture on the down wind, just to see if I could get more power and still no luck. I landed rwy 32 with no problems and after a few sputters to taxi clear, the engine completely shut down on the runway. I tried to restart on the ramp and the 3 year old battery also decided to quit. My plane is normally hangared, right now I'm doing my CFI at Aviator and the 4 has been left out for a week with half tanks. I thought it might had been fuel contamination or moisture, but the full cup samples I took after the long push to the ramp showed no problems with the fuel. No samples were inspected prior to the flight. It took about a minute to land and I was thinking that if it were water in the line it would have cleared and fired back up, but I've also heard that fuel injectors are more sensitive to water. Where to start, first thing tomorrow, after I order a new battery, I'll pull the filters and purge the system, but other than that I don't know what it could be. My system is an 0360, Bendix injector, and airflow performance boost/filter setup. I do have the RMI fuel flow transducer between the injector and flowdivider/spider. If anyone has any ideal where else I could look, please advise. Thanks, Carey Mills RV4 310 hours ________________________________________________________________________________
Date: Mar 12, 2003
Subject: Re: Scratches in Aluminum
I am using Rustoleum Primer in the spray cans. I give everything a light coat on the inside before driving the rivets and closing. It's a lot simpler than the mixing of the Sherwin Williams and other types and using the spray gun. Jim Nelson ________________________________________________________________________________
Date: Mar 12, 2003
The skins are alclad, that is they are coated with a thin coat of pure aluminum that provides excellent corrosion protection. I don't think your scratch is a structural problem, but in the process of sanding it out you will remove the alclad. Primer and paint will protect the skin. I would suggest that you keep the area sanded to just the scratch itself and avoid sanding the surrounding area. A 1" dia. Buffing wheel on a dremel or die grinder and some rouge will also work well to polish out the scratch. I am building my emp & wings I have only been priming the parts that are not alclad, i.e. ribs, extrusions, stiffeners. I live in the Northwest, read damp 6 months of the year and there are many RVs primed this way. (There are many with all parts primed also). I have been using Napa self etching rattle can primer which works well. The scratch resistance is not as good as Veriprime but for the interior of wings and emp. it should be fine. Chris Stone RV-8 Emp & wings -----Original Message----- From: linenwool(at)attbi.com [mailto:linenwool(at)attbi.com] Subject: RV8-List: Scratches in Aluminum How do you gauge if a scratch is too deep? My HS skin seems to have come with a scratch in it that is about 2 inches long. I might be able to sand it out but it would probably take something as course as 120 grit for how deep it is. and then more fine to polish it. Would this be acceptable for structural reasons? I can put it on the bottom and I'm sure the paint would cover it as well but I don't want to chance it if it is a safety issue. Also...uh oh, here we go.... is it a big deal not to prime the inside of the skins even though I've taken the time to prime all ribs and spars? Thanks, -Will Allen North Bend, Wa. RV8 emp direct advertising on the Matronics Forums. ________________________________________________________________________________
Date: Mar 12, 2003
If you're going to sand or buff any part of the alclad (or any other aluminum part for that matter) you absolutely must etch and alodine the surface. This process will not only assist in corrosion prevention, but allow for better adhesion of any primer and paint that you will apply. In the enviroment here in the Caribbean EVERYTHING is etched, alodined and primed. linenwool(at)attbi.com wrote: > > How do you gauge if a scratch is too deep? My HS skin seems to have come with > a scratch in it that is about 2 inches long. I might be able to sand it out > but it would probably take something as course as 120 grit for how deep it is. > and then more fine to polish it. Would this be acceptable for structural > reasons? I can put it on the bottom and I'm sure the paint would cover it as > well but I don't want to chance it if it is a safety issue. > > Also...uh oh, here we go.... is it a big deal not to prime the inside of the > skins even though I've taken the time to prime all ribs and spars? > > Thanks, > > -Will Allen > North Bend, Wa. > RV8 emp > ________________________________________________________________________________
Date: Mar 12, 2003
Suggest you lightly buff scratch, hit with a little primer (NAPA 7026 in spray cans is my personal choice along with the aluminum cleaner that is on the shelf right next to it) and move on. When the plane is done, you will be going completely over it anyway to repair the other dents, dings, gouges, etc. that you "will" have. I started out priming everything but now I am down to doing it only if the plans say so, else thinking about it if not. I will prime any area that gets pretty scratched up during the construction phase which for me is usually along the rivet line as I keep the plastic coating on till the last instant before riveting. Also I prime between two dissimilar metals. I lightly buff the affected area so as to increase the grip of the primer, not to remove the alcad finish. Personal RV-List Observation #1: One can get way too eaten up with this primer thing! Regards, Vince Himsl RV8 (SB) Fuselage/Finish/Saving up for engine Moscow, ID USA ________________________________________________________________________________
Date: Mar 13, 2003
Re vinyl film: I have been using a soldering iron to cut/melt a line adjacent to the rivet line then remove only a strip vinyl film at the rivet line. This leaves a protective film on the rest of the surface until ready for paint. Of course remove all film on the inside of the skins!! Chris Stone RV-8 Emp & Wings Newberg OR -----Original Message----- From: Vince Himsl [mailto:vhimsl(at)turbonet.com] Subject: RE: RV8-List: Scratches in Aluminum Suggest you lightly buff scratch, hit with a little primer (NAPA 7026 in spray cans is my personal choice along with the aluminum cleaner that is on the shelf right next to it) and move on. When the plane is done, you will be going completely over it anyway to repair the other dents, dings, gouges, etc. that you "will" have. I started out priming everything but now I am down to doing it only if the plans say so, else thinking about it if not. I will prime any area that gets pretty scratched up during the construction phase which for me is usually along the rivet line as I keep the plastic coating on till the last instant before riveting. Also I prime between two dissimilar metals. I lightly buff the affected area so as to increase the grip of the primer, not to remove the alcad finish. Personal RV-List Observation #1: One can get way too eaten up with this primer thing! Regards, Vince Himsl RV8 (SB) Fuselage/Finish/Saving up for engine Moscow, ID USA direct advertising on the Matronics Forums. ________________________________________________________________________________
Subject: Re: first engine failure, need help
Date: Mar 13, 2003
Carey, Make sure the liquid sample you took was in fact gas and not all water. I've taken full cups of pure water from my tanks and thought I was looking at fuel. Jim ----- Original Message ----- From: <Rvmils(at)aol.com> ; Subject: RV8-List: first engine failure, need help > > Well, I had my first engine failure and landed without incident. I need some > help trouble shooting this one. On takeoff at FPR, at about 800 AGL, the > engine lost most of its power. It was a sputter, followed my an almost shut > down. It reminded me of the time I was setting up my fuel flow on the RMI > and ran a tank try. I check the boost, it was confirmed on, mixture rich, > and switch tanks. No luck. I jockeyed the throttle and mixture on the down > wind, just to see if I could get more power and still no luck. I landed rwy > 32 with no problems and after a few sputters to taxi clear, the engine > completely shut down on the runway. I tried to restart on the ramp and the 3 > year old battery also decided to quit. > My plane is normally hangared, right now I'm doing my CFI at Aviator and the > 4 has been left out for a week with half tanks. I thought it might had been > fuel contamination or moisture, but the full cup samples I took after the > long push to the ramp showed no problems with the fuel. No samples were > inspected prior to the flight. It took about a minute to land and I was > thinking that if it were water in the line it would have cleared and fired > back up, but I've also heard that fuel injectors are more sensitive to water. > Where to start, first thing tomorrow, after I order a new battery, I'll pull > the filters and purge the system, but other than that I don't know what it > could be. My system is an 0360, Bendix injector, and airflow performance > boost/filter setup. I do have the RMI fuel flow transducer between the > injector and flowdivider/spider. If anyone has any ideal where else I could > look, please advise. > Thanks, > Carey Mills > RV4 310 hours > > ________________________________________________________________________________
Date: Mar 13, 2003
Subject: engine failure solved
rv8-list(at)matronics.com After trouble shooting the system, it turn out to be my fuel injector. I pick it up from Southeast Fuel Systems today and the problem was the bellows assembly. I bought this servo when I had my engine overhauled. The servo was overhauled by a company in Alabama, not sure the name, but they used a few after market PMA parts and Bill from Southeast seems to think that was the problem. The bellows assembly was stainless, instead of brass/berillum and I had excessive wear on a spacer. Just glad it happen a 600 ft in the pattern. My biggest concern was the lack of warning of the impending failure and the fact that I could not catch the problem on any of my inspections. I appreciate the help and use most of the ideals to trouble shoot the problem. Blue Skies, Carey Mills ________________________________________________________________________________
Date: Mar 13, 2003
> No samples were > inspected prior to the flight. > This has me just a bit puzzled. Sampling the fuel is almost a religion... with my CFI, and now with me. Wouldn't think to fly without a careful check of the fuel integrity (in addition to quantity). A good practice, I think, though it sounds like that may not be the issue here. Robert Jim Stone wrote: > > Carey, > Make sure the liquid sample you took was in fact gas and not all water. > I've taken full cups of pure water from my tanks and thought I was looking > at fuel. > Jim > ----- Original Message ----- > From: <Rvmils(at)aol.com> > To: ; ; > ; > Subject: RV8-List: first engine failure, need help > > > > > Well, I had my first engine failure and landed without incident. I need > some > > help trouble shooting this one. On takeoff at FPR, at about 800 AGL, the > > engine lost most of its power. It was a sputter, followed my an almost > shut > > down. It reminded me of the time I was setting up my fuel flow on the RMI > > and ran a tank try. I check the boost, it was confirmed on, mixture rich, > > and switch tanks. No luck. I jockeyed the throttle and mixture on the > down > > wind, just to see if I could get more power and still no luck. I landed > rwy > > 32 with no problems and after a few sputters to taxi clear, the engine > > completely shut down on the runway. I tried to restart on the ramp and > the 3 > > year old battery also decided to quit. > > My plane is normally hangared, right now I'm doing my CFI at Aviator and > the > > 4 has been left out for a week with half tanks. I thought it might had > been > > fuel contamination or moisture, but the full cup samples I took after the > > long push to the ramp showed no problems with the fuel. No samples were > > inspected prior to the flight. It took about a minute to land and I was > > thinking that if it were water in the line it would have cleared and fired > > back up, but I've also heard that fuel injectors are more sensitive to > water. > > Where to start, first thing tomorrow, after I order a new battery, I'll > pull > > the filters and purge the system, but other than that I don't know what it > > could be. My system is an 0360, Bendix injector, and airflow performance > > boost/filter setup. I do have the RMI fuel flow transducer between the > > injector and flowdivider/spider. If anyone has any ideal where else I > could > > look, please advise. > > Thanks, > > Carey Mills > > RV4 310 hours ________________________________________________________________________________
Date: Mar 14, 2003
Subject: Garmin 250XL
rv6-list(at)matronics.com, rv7-list(at)matronics.com, rv8-list(at)matronics.com, rv9-list(at)matronics.com, kr-list(at)matronics.com Hey guys, I have a garmin 250xl brand new, never been installed for sale. Store price is $2795, I will let it go to the first $2200. Please reply offline. Thanks, Scott ________________________________________________________________________________
From: "Clark, Thomas IFC" <Tom.Clark(at)utcfuelcells.com>
Date: Mar 14, 2003
-----Original Message----- From: BrownScottA(at)aol.com [mailto:BrownScottA(at)aol.com] rv6-list(at)matronics.com; rv7-list(at)matronics.com; rv8-list(at)matronics.com; rv9-list(at)matronics.com; kr-list(at)matronics.com Subject: RV8-List: Garmin 250XL Hey guys, I have a garmin 250xl brand new, never been installed for sale. Store price is $2795, I will let it go to the first $2200. Please reply offline. Thanks, Scott ________________________________________________________________________________
Date: Mar 14, 2003
Clark, Thomas IFC would like to recall the message, "RV8-List: Garmin 250XL". ________________________________________________________________________________
Date: Mar 18, 2003
Subject: Grove Gear Climb and Speed Data Part 2
Hi guys For those of you following this thread. I have been progressively adding Grove gear to my O-360/Hartzell powered RV-8. I was interested in how each additional component added (or subtracted) from speed and climb performance. Speed numbers were obtained by GPS with full throttle (about 19.4" MAP), EGT 1300, at 11,500 MSL--(This is about 65% power). Weight OAT Climb Rate to 11K Speed MPH Van's Standard Gear 1525 55F 1025 184 plain-no fairings/pants Grove Streamlined Gear 1514 43F 1242 185 plain--no fairings/pants Grove w/intersection 1515 50F 1252 187 fairings, access covers, but NO wheel pants. Grove w/all fairings and Data Coming Next Week wheel pants **Note: Stall speed (clean) was reduced by 7 knots with the addition of intersection fairings. See www.RV-8.com for the theory behind this -8 phenomenon. Rob Miller -8 N262RM "Bad Cat" 50 hours http://platinum.yahoo.com ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Tool Sets
I just purchased my airline ticket to go down to Sun 'n Fun here in a couple weeks, and am planning on checking for sale prices on the RV-8 tail kit as well as tool kits while I'm there. Just scanning the web, I found a RV tool kit from Avery (page 3 of their on-line catalog at http://www.averytools.com/) that looked like it had all (or at least most) of the tools necessary to build the RV. Obviously, buying new tools isn't the cheapest way to go, but I was wanting to get comments on the completeness of the kit and if there were items that would not be necessary in the kit. There is an active local RV builder's group, so if there are tools that are only used a couple times during the build process, these could probably be borrowed when necessary. The primary decision to make for this Avery tool kit is the choice between a 2x and 3x rivet gun. Does it really matter? Which is going to be better for the build process, or should I invest the extra money and eventually get one of each? If getting both is the suggestion, which should I get first with the tool kit? Also, regarding air tools, how large of a compressor (gallons) should I be looking for and what are the minimum flow ratings for different PSI that I should be looking for. Thanks for the clarification on these various items. Steve Avery RV Tool Kit SPECIAL PRICE: $1670.00 THIS 625 PIECE TOOL KIT INCLUDES: #2X / 3X AVERY RIVET GUN (your choice) #2015 BEEHIVE SPRING #2000 QUICK CHANGE SPRING #150 AIR TOOL REGULATOR #1001 22=F5 HAND RIVET & DIMPLING TOOL #9430 3=F5 AVERY HAND RIVET SQUEEZER #8005 6 PC. SQUEEZER SET MIX #3/32DDS 3/32=F5 RIVET DIMPLE DIE SET #1/8DDS 1/8=F5 RIVET DIMPLE DIE SET #6DDS #6 SCREW DIMPLE DIE SET #8DDS #8 SCREW DIMPLE DIE SET #1022 3/32=F5 POP RIVET DIMPLER #550 3/32=F5 VISE GRIP DIMPLER #610 BUCKING BAR #615 BUCKING BAR #620 BUCKING BAR #4704 1/8=F5 RIVET SET #4720 1/8=F5 DOUBLE OFFSET RIVET SET #1047 FLUSH SWIVEL RIVET SET #1048 BACK RIVET SET #500 FLUTING PLIER #575 HAND SEAMER #200 CLECO PLIER #1016 3/32=F5 CLECOS (325 PCS) #1017 1/8=F5 CLECOS (175 PCS) #2018 5/32=F5 CLECOS (20 PCS) #1012 1/2=F5 X 1/2=F5 SIDE GRIPS (5 PCS) #1014 1/2=F5 X 1=F5 SIDE GRIPS (5 PCS) #1042 EDGE ROLLING TOOL #1412 SIOUX 1/4=F5 AIR DRILL - 3600 RPM #40 #40 COBALT DRILLS (8 PCS) #30 #30 COBALT DRILLS (6 PCS) #21 #21 COBALT DRILLS (3 PCS) #19 #19 COBALT DRILLS (2 PCS) #12 #12 COBALT DRILLS (2 PCS) #1/4 1/4=F5 COBALT DRILL (1 PC) #12X40 #40 X 12=F5 EXTENSION DRILL #12X30 #30 X 12=F5 EXTENSION DRILL #1100 4 PC DRILL STOP SET #8105 TIGHT FIT ANGLE DRILL KIT #3140 #40 THREADED DRILLS (2 PCS) #3130 #30 THREADED DRILL (1 PC) #19360 COUNTERSINK CAGE #1051 #40 COUNTERSINK CUTTER #1052 #30 COUNTERSINK CUTTER #1054 #8 SCREW COUNTERSINK CUTTER #330 PILOT MARKING PENS (3 EA) #1246 12=F5 FLEXIBLE STEEL RULE #1007 RIVET GAUGE SET (4 PC) #1008 RIVET LENGTH GAUGE #58337 WISS OFFSET SNIPS - LEFT #58338 WISS OFFSET SNIPS - RIGHT #1046 SPEED DEBURRING TOOL #22022 ROYAL MULTI-BURR TOOL #3753 6=F5 S/BRITE CUT & POLISH WHEEL #710 CURVED TOOTH FILE #757 3/32=F5 DRIVE PIN PUNCH #758 1/8=F5 DRIVE PIN PUNCH #25500 SWIVEL HEAD POP RIVET TOOL ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: Tool Sets
Steve, If you don't have the preview plans yet, get them! It includes the drawings, a manual, accessories catalog. After you've been through this excellent primer, you'll be drooling to get started! :) There is a section with a good discussion on tools. Regarding the rivet gun they say "the 3x size is preffered by most builders, although good results are possible with the lighter duty 2x." Not having riveted a single rivet myself I can't say for sure but it sounds like its either/or. The plans also recommend a 1-1/2 to 2 hp compressor that develops 75psi and a 20gal tank if rotary (continous) tools are used. I haven't even gone flying in one yet and I've already gotten the 'rv grin' just going through the plans. :) John K --- Steve Waltner wrote: > > >... > > The primary decision to make for this Avery tool kit > is the choice > between a 2x and 3x rivet gun. Does it really > matter? Which is going to > be better for the build process, or should I invest > the extra money and > eventually get one of each? If getting both is the > suggestion, which > should I get first with the tool kit? > ===== - Everything that I care about in my life is priceless. Money (or income), on the other hand, is just a necessary annoyance of limited value. - The masters of mediocrity rule in the gray wasteland of Redmond, while the free mind basks in the serene clarity of Antarctica. - Since the dawn of human civilization there has been a 35% reduction in the number of plant and animal species on earth. Annually, humans consume 20% more natural resources than the earth can replenish. As parasites, we are killing the host... http://platinum.yahoo.com ________________________________________________________________________________
Date: Mar 21, 2003
At 08:36 PM 3/20/2003, you wrote: > >I just purchased my airline ticket to go down to Sun 'n Fun here in a >couple weeks, and am planning on checking for sale prices on the RV-8 >tail kit as well as tool kits while I'm there. Just scanning the web, I >found a RV tool kit from Avery (page 3 of their on-line catalog at >http://www.averytools.com/) that looked like it had all (or at least >most) of the tools necessary to build the RV. Obviously, buying new >tools isn't the cheapest way to go, but I was wanting to get comments >on the completeness of the kit and if there were items that would not >be necessary in the kit. Once you figure out the retail price of each tool you plan to buy, Ebay is the way to go, especially for big ticket items. The best bargains are typically not the shiny new "off-brand" tools in the box, but the well-used quality name brand tools. degree drill often typically go for well under $100, sometimes with an assortment of drills thrown in. Here are a couple of completed auctions: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2515107278&category=31482 or http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2406223375&category=26439 These units go for over $300 new. ________________________________________________________________________________
Date: Mar 21, 2003
You'll use every tool in the Avery kit on a pretty regular basis. You could probably get away without the C-Frame if your next door neighbor had one that you could use at a moments notice otherwise I would buy the whole kit. I can't tell you whether the 2x gun would work but I have the 3x gun that Avery sells in the kit and it works great. You will not need to get both to build an RV. Get the biggest air compressor that you can afford. I don't know what the flow rate is on mine, but it's a 30 gallon. The big air users are die grinders and spray guns. The rivet gun and a good drill don't use all that much air so for most of what you'll be doing just about any air compressor that you can find will work but you'll be glad you have the volume when you really have to use the die grinder on something. I have a small HVLP paint gun that I bought from Harbor Freight that works pretty well and since it's HVLP it doesn't use up a lot of air. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB (Reserved) - Fuselage http://www.myrv7.com ----- Original Message ----- From: "Steve Waltner" <swaltner(at)mac.com> Subject: RV8-List: Tool Sets > > I just purchased my airline ticket to go down to Sun 'n Fun here in a > couple weeks, and am planning on checking for sale prices on the RV-8 > tail kit as well as tool kits while I'm there. Just scanning the web, I > found a RV tool kit from Avery (page 3 of their on-line catalog at > http://www.averytools.com/) that looked like it had all (or at least > most) of the tools necessary to build the RV. Obviously, buying new > tools isn't the cheapest way to go, but I was wanting to get comments > on the completeness of the kit and if there were items that would not > be necessary in the kit. There is an active local RV builder's group, > so if there are tools that are only used a couple times during the > build process, these could probably be borrowed when necessary. > > The primary decision to make for this Avery tool kit is the choice > between a 2x and 3x rivet gun. Does it really matter? Which is going to > be better for the build process, or should I invest the extra money and > eventually get one of each? If getting both is the suggestion, which > should I get first with the tool kit? > > Also, regarding air tools, how large of a compressor (gallons) should I > be looking for and what are the minimum flow ratings for different PSI > that I should be looking for. > > Thanks for the clarification on these various items. > > Steve > > > Avery RV Tool Kit > > SPECIAL PRICE: $1670.00 > THIS 625 PIECE TOOL KIT INCLUDES: > #2X / 3X AVERY RIVET GUN (your choice) > #2015 BEEHIVE SPRING > #2000 QUICK CHANGE SPRING > #150 AIR TOOL REGULATOR > #1001 22=F5 HAND RIVET & DIMPLING TOOL > #9430 3=F5 AVERY HAND RIVET SQUEEZER > #8005 6 PC. SQUEEZER SET MIX > #3/32DDS 3/32=F5 RIVET DIMPLE DIE SET > #1/8DDS 1/8=F5 RIVET DIMPLE DIE SET > #6DDS #6 SCREW DIMPLE DIE SET > #8DDS #8 SCREW DIMPLE DIE SET > #1022 3/32=F5 POP RIVET DIMPLER > #550 3/32=F5 VISE GRIP DIMPLER > #610 BUCKING BAR > #615 BUCKING BAR > #620 BUCKING BAR > #4704 1/8=F5 RIVET SET > #4720 1/8=F5 DOUBLE OFFSET RIVET SET > #1047 FLUSH SWIVEL RIVET SET > #1048 BACK RIVET SET > #500 FLUTING PLIER > #575 HAND SEAMER > #200 CLECO PLIER > #1016 3/32=F5 CLECOS (325 PCS) > #1017 1/8=F5 CLECOS (175 PCS) > #2018 5/32=F5 CLECOS (20 PCS) > #1012 1/2=F5 X 1/2=F5 SIDE GRIPS (5 PCS) > #1014 1/2=F5 X 1=F5 SIDE GRIPS (5 PCS) > #1042 EDGE ROLLING TOOL > #1412 SIOUX 1/4=F5 AIR DRILL - 3600 RPM > #40 #40 COBALT DRILLS (8 PCS) > #30 #30 COBALT DRILLS (6 PCS) > #21 #21 COBALT DRILLS (3 PCS) > #19 #19 COBALT DRILLS (2 PCS) > #12 #12 COBALT DRILLS (2 PCS) > #1/4 1/4=F5 COBALT DRILL (1 PC) > #12X40 #40 X 12=F5 EXTENSION DRILL > #12X30 #30 X 12=F5 EXTENSION DRILL > #1100 4 PC DRILL STOP SET > #8105 TIGHT FIT ANGLE DRILL KIT > #3140 #40 THREADED DRILLS (2 PCS) > #3130 #30 THREADED DRILL (1 PC) > #19360 COUNTERSINK CAGE > #1051 #40 COUNTERSINK CUTTER > #1052 #30 COUNTERSINK CUTTER > #1054 #8 SCREW COUNTERSINK CUTTER > #330 PILOT MARKING PENS (3 EA) > #1246 12=F5 FLEXIBLE STEEL RULE > #1007 RIVET GAUGE SET (4 PC) > #1008 RIVET LENGTH GAUGE > #58337 WISS OFFSET SNIPS - LEFT > #58338 WISS OFFSET SNIPS - RIGHT > #1046 SPEED DEBURRING TOOL > #22022 ROYAL MULTI-BURR TOOL > #3753 6=F5 S/BRITE CUT & POLISH WHEEL > #710 CURVED TOOTH FILE > #757 3/32=F5 DRIVE PIN PUNCH > #758 1/8=F5 DRIVE PIN PUNCH > #25500 SWIVEL HEAD POP RIVET TOOL > > ________________________________________________________________________________
Subject: Tool Sets
Date: Mar 21, 2003
About the 2x vs. 3x rivet guns: I built my airframe with a 2x gun. It was great EXCEPT for some big rivets at the front of the fuselage where the longerons and the side skins and the firewall all come together with a steel fitting. I couldn't figure out why I couldn't set the rivets, but after some thought, realized that for the rivet to set, I had to shake that whole mass to bounce the rivet against the bucking bar. I backriveted the difficult ones and that worked fine. Next time, I'll have both a 2x and a 3x gun. Avery is great to do business with. Buy the kit, and figure on buying a lot more tools before you finish. Terry RV-8A #80729 Finishing ________________________________________________________________________________
Date: Mar 22, 2003
Subject: 7-Day Matronics List Browse Enhancement...
Dear Listers, Neil Hulin of the Zenith-List at Matronics wrote to me suggesting I add a "total of available messages" column to the 7-Day List Browse Main page, and it seemed like a great idea! I've made the modifications and I think many will find it extremely helpful as well. Have a look at the following URL: http://www.matronics.com/listbrowse/ Best regards, Matt Dralle Matronics Email List Admin... Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Mar 25, 2003
Subject: Grove Aero Gear Climb and Speed Data--Final Report
Hi guys For those of you following this thread. I have been progressively adding Grove gear to my O-360/Hartzell powered RV-8. I was interested in how each additional component added (or subtracted) from speed and climb performance. Speed numbers were obtained by GPS with full throttle (about 19.4" MAP), EGT 1300, at 11,500 MSL--(This is about 65% power). Weight OAT Climb Rate to 11K Speed MPH Van's Standard Gear 1525 55F 1025 184 plain-no fairings/pants Grove Streamlined Gear 1514 43F 1242 185 plain--no fairings/pants Grove w/intersection 1515 50F 1252 187 fairings, access covers, but NO wheel pants. Grove w/all fairings and 1518 60F 1312 195 wheel pants **Note: Stall speed (clean) was reduced by 7 knots with the addition of intersection fairings. See www.RV-8.com for the theory behind this -8 phenomenon. Rob Miller -8 N262RM "Bad Cat" 52 hours http://platinum.yahoo.com ________________________________________________________________________________
Date: Mar 25, 2003
Avery and Cleaveland both have good tools. As for rivet guns, get the 3X. You can adjust the air pressure down for the -3 rivets, and turn the pressure up some for the -4 rivets. The 2X gun hits fast and light and must be held on the rivet longer to make the shop head. The slower hitting 3X gun is more controllable, forms the shop head quicker, and will handle all your riveting needs. If you are bound and determined to buy a 2X gun, I have a brand new one I used a few times that I will sell you real cheap! After using a 3X gun, I never touch the 2X gun anymore. Mike Whitescarver RV-8A - Wings ________________________________________________________________________________
Date: Mar 25, 2003
I would also appreciate some advice regarding air tools. I purchased a kit that is partially completed. Only the finishing kit and some minor fuselage work remains. I just got home from Lowes where I purchased a Porter Cable 25 gallon, 6 hp compressor. I am wondering what tools I will need to buy in order to finish my project. I also bought a cheap combination pack of air tools, including a cut off tool that turns 2200 rpm. 1. Would I be better off buying a 3x rivet gun? (If the 2x would work well, Mike may have a buyer for his "real cheap" used gun :) 2. Would the cheap, 2200 rpm cut off tool be sufficient? 3. Is my new air compressor sufficient? It is still in the box and I can return it. The input of you experienced rivet pounders would be helpful. Tony Johnson RV8A Orlando Finishing ----- Original Message ----- From: <MWhites676(at)aol.com> Subject: Re: RV8-List: Tool Sets > > Avery and Cleaveland both have good tools. As for rivet guns, get the 3X. > You can adjust the air pressure down for the -3 rivets, and turn the pressure > up some for the -4 rivets. The 2X gun hits fast and light and must be held > on the rivet longer to make the shop head. The slower hitting 3X gun is more > controllable, forms the shop head quicker, and will handle all your riveting > needs. > If you are bound and determined to buy a 2X gun, I have a brand new one I > used a few times that I will sell you real cheap! After using a 3X gun, I > never touch the 2X gun anymore. > > Mike Whitescarver > RV-8A - Wings > > ________________________________________________________________________________
Date: Mar 31, 2003
About a week ago, someone asked about tool prices. I poked around a bit and remembered this wonderful price comparison web page dedicated specifically to RV tool vendors and prices. http://web.tampabay.rr.com/flrv7a/rvcontents.htm Better late than never, I suppose. ________________________________________________________________________________
Date: Apr 01, 2003
Subject: Matronics ISP Upgrade TODAY...
Dear Listers, The time has finally arrived for the Internet Service Provider (ISP) upgrade! You'll recall that I was looking into upgrading the existing SDSL connection from 768k to 1.1M. As it turned out, the copper line wouldn't support any speeds greater than the current 768k. In light of that news, I just bit-the-bullet and ordered a full, commercial-grade T1 connection. The T1 connection will provide a full-duplex, high priority, 1.5Mb Internet connection which should be a substantial performance enhancement for all of the List services! Pacbell delivered the T1 Loop last week and it tested out fine. This past weekend I pulled the tail circuit from the demark to the office. This afternoon, Tuesday 4/1/03, the ISP is suppose come and install the new router and bring up routing on a test subnet. Assuming that everything checks out okay with the T1, new router, and routing, I will have them swing the main Matronics subnet off the SDSL and onto the T1. In theory, the swing could be nearly transparent to users, but that's usually not the case... ;-) Please expect a bit of instability in connectivity this afternoon as we work though the transition issues. I will post a follow up message when everything is up and running on the new T1 line. Finally, please know that it is solely your Contributions that make these kinds of List upgrades happen! There is no advertising budget (aka, flashing banner ads and annoying pop up browser windows) to pay these bills; operational support is solely from List members like you during the yearly List Fund Raiser. If you would like to make your Contribution to support the Lists and upgrades like this T1 connectivity enhancement, please see the List Contribution Web Site where you can make your Contribution with a Credit Card, PayPal, or Personal Check. You can even get a free List Archive CDROM with a qualifying List Contribution! The URL is: http://www.matronics.com/contribution Thanks again to EVERYONE that made a generous Contribution last year and enabled this awesome upgrade to T1 service! Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Apr 02, 2003
Subject: Matronics ISP Upgrade COMPLETED!
Dear Listers, I just wanted to send out a quick note to let everyone know that the 1.5Mb T1 connection upgrade went smoothly today. They brought up the new line and router yesterday on a test subnet and today the ISP switched over connectivity about 12 noon with little to no incident. I just finished some performance testing, and it appears that actual throughput and interactive response is noticeably improved as advertised! Enjoy! Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Apr 02, 2003
Subject: [ Fred Stucklen ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Fred Stucklen Subject: Electronic Ignition Power http://www.matronics.com/photoshare/Fred.Stucklen@UTCFuelCells.com.04.02.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject: Good source for panel help
Date: Apr 06, 2003
For those who are looking to save yourselves from having to deal with the spaghetti at the back of your instrument panel, I strongly recommend Mark Krueger of Advantage Avionics. Mark has a wealth of experience and knowledge and stands behind his work. He is a great guy and he doesn't know that I'm sending this out. He bundles and wax ties wires so that it is as clean in the back as it is in the front. You get schematic drawings for your panel in the event that anything in the future requires repair. Truly the answer to your avionic needs. Contact info.: (909) 739-7779 Mark(at)AdvantageAvionics.com http://www.AdvantageAvionics.com Chris Kleen N515CW RV-6 - darn near there! ________________________________________________________________________________
Date: Apr 09, 2003
Subject: Purchased my Empennage Kit
Well, after a few years of sitting on the fence trying to decide if I would build an aircraft, then whether it would be a helicopter or airplane, then which airplane it would be, I've finally done it. I went down to SNF and placed an order for a RV-8 empennage kit and the Avery Tools tool kit. I picked up an air compressor from Sears last weekend, so I'm ready to go once I receive the two shipments and get my garage cleaned up a little bit to get some work space. It's an exciting time... BTW, thanks to everyone for your comments on my question a couple weeks ago regarding the tools that are necessary for building an RV. Steve RV-8 Empennage ________________________________________________________________________________
Subject: Re: Purchased my Empennage Kit
Date: Apr 09, 2003
Steve, Congratulations on a decision well made. I'm in the final stage on construction of my RV 8 and I can tell you it has been a great learning experience. I know more now about airplane systems than I had ever hoped to and the plane I'm about to complete is far nicer than any I had hoped to own. If you are considering a QB and I recommend that you do, remember that you need a lot of lead time on your orders. You can build your tail group in a couple weeks if you get after it. Try to tell yourself that you have already commited to buy your finish kit and your prop as well as that pesky expensive engine at the time you ordered your tail kit. I have just gone over the 2 year mark and I have only a couple thousand dollars and a couple months to go. You can build a IFR, GPS 200HP CS prop plane for under 60K if you watch for a few bargains and do some of the work yourself, like the panel and the paint and the interior. I even have smoke in mine that costs a whopping 20 bucks and works great. Good luck and remember that you don't have to build an airplane----------only one part at a time. Tom in Ky Rv 8 N38NE reserved ----- Original Message ----- From: "Steve Waltner" <swaltner(at)mac.com> Subject: RV8-List: Purchased my Empennage Kit > > Well, after a few years of sitting on the fence trying to decide if I > would build an aircraft, then whether it would be a helicopter or > airplane, then which airplane it would be, I've finally done it. I went > down to SNF and placed an order for a RV-8 empennage kit and the Avery > Tools tool kit. I picked up an air compressor from Sears last weekend, > so I'm ready to go once I receive the two shipments and get my garage > cleaned up a little bit to get some work space. It's an exciting time... > > BTW, thanks to everyone for your comments on my question a couple weeks > ago regarding the tools that are necessary for building an RV. > > Steve > RV-8 Empennage > > ________________________________________________________________________________
Subject: Cherry Blind Rivets explanation
Date: Apr 16, 2003
Hello listers! I'm looking for some advise on ordering blind rivets from A/C Spruce. I see the Cherry Max rivets that everyone talks about but also see commercial grade, N, Q, and assortments of others. So how do I go about deciding which are used for what applications? Are the Cherry Max the strongest of the group and if so, are there ever any reasons for wanting a rivet of less strength? ie: weight, overkill....etc? My immediate application is to put a blind rivet in place of an AN470AD4-4 that I drilled out and now have a #19 hole...oops, but I'm hoping to get enough info for future blind riveting applications as well. Thanks, -Will Allen North Bend, Wa. RV8 emp ________________________________________________________________________________
Subject: RV8s and Eggenfellner
Date: Apr 20, 2003
i'd like to hear about anyone building/flying RV8/8As with the Eggenfellner Subaru kit... his website is full of other RVs, and looks like there's a Yahoo listserv, but my browser refuses to let me onto that, at the moment... with the RV9s in particular, this looks like a great engine kit... i'll bet more and more builders choose it... i wouldn't be surprised if Van's makes it a standard option once it has more of a track record... but i'm not sure the 165 hp engine fits the RV8 mission, even supercharged... i'd like to hear from all of you on that... what would you expect for a 75% cruise speed with a supercharged 165 hp Eggenfellner kit in the RV8? Andrew Morgan Madison, WI (studying options) ________________________________________________________________________________
Date: Apr 21, 2003
Subject: Re: RV8s and Eggenfellner
Andrew, I am building an RV-8 QB. My Eggenfellner engine is in the lot now being built. I chose the Supercharger option mainly for cross-country. It will be at least a year before it is ready to fly. I like the looks of the RV-8 and since 98% of my flying will be solo thats what I got. I will be flying strictly for the fun of flying. If it goes 150, 170 or 180 MPH, so what. If you read about the Subaru engine on their site you will see it is a great engine. Again, it isn't the fasteset RV-8, I can live with that. An occasional roll will be aerobatic enough for me. Paul N9NM reserved ________________________________________________________________________________
Date: Apr 21, 2003
Oh, I'm sold on the RV8, love that airplane. I'm a big guy, so I appreciate elbow room, and while I plan to take anybody for a ride who'll ride along, I anticipate lots of solo flying, too, and don't want the lateral balance issues. I'm also looking for fun flying, cross-country trips, and sight-seeing, not racing. I don't even care about climb rate particularly, but I would like to see a 200+ mph cruise rate for the cross-country legs. Van's specs the RV8 for that. Plus the RV8 looks so cool, with that space bubble canopy. So far, the Eggenfellner seems like a great engine and kit, and if I were ready to buy today, I'd likely choose that. I'm just wondering whether, with the supercharger, it can pull an RV8 at 200 mph. Probably not, but on the Eggenfellner website, it shows that at 8000 feet, the Egg kit produces as many hp as a normally aspirated Lycoming 200 hp engine. And Van's suggests that 200 hp Lycoming can cruise at 200+ mph at 8000 ft in an RV8. Even so, given the extra range of the more efficient smaller engine, using less fuel per hour, the effective cross-country travel time is gonna be closer than a straight comparison of cruising speed might suggest. And cheaper fuel costs means more flying. But I'd like to hear more thoughts on the combination, Eggenfellner and RV8s. Thanks! -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of PSILeD(at)aol.com Subject: Re: RV8-List: RV8s and Eggenfellner Andrew, I am building an RV-8 QB. My Eggenfellner engine is in the lot now being built. I chose the Supercharger option mainly for cross-country. It will be at least a year before it is ready to fly. I like the looks of the RV-8 and since 98% of my flying will be solo thats what I got. I will be flying strictly for the fun of flying. If it goes 150, 170 or 180 MPH, so what. If you read about the Subaru engine on their site you will see it is a great engine. Again, it isn't the fasteset RV-8, I can live with that. An occasional roll will be aerobatic enough for me. Paul N9NM reserved ________________________________________________________________________________
vansairforce(at)yahoogroups.com
Subject: Microair 760 VHF users
Date: Apr 23, 2003
Listers: Is anyone out there using the Microair 760 VHF transreciever? If so, Are you using their intercom system, and if you are, are you happy with it? I am trying to decide whether I should use it or install a different intercom system. Thanks in advance for your comments. Al Grajek RV8 ________________________________________________________________________________
Date: Apr 23, 2003
Subject: Antennas
I am just finishing my empennage kit. A friend suggested that I begin to think and plan about the routing and placement of all the antennas at this time. I would appreciate any comments from other builders in regards on what works best and where. Thanks. Carl W. Lane Valparaiso, IN ________________________________________________________________________________
Subject: Re: Antennas
Date: Apr 23, 2003
I put antennas in the wing tips..got the antennas from RV list (parts)..work fine, and no "fishing poles" sticking all over the pland RV8A in aurora, or. ----- Original Message ----- From: <Gypmover(at)aol.com> Subject: RV8-List: Antennas > > I am just finishing my empennage kit. A friend suggested that I begin to think and plan about the routing and placement of all the antennas at this time. > > I would appreciate any comments from other builders in regards on what works best and where. > > Thanks. > Carl W. Lane > Valparaiso, IN > > ________________________________________________________________________________
Date: Apr 23, 2003
Subject: Phil Arter
Here's the link to Phil's obituary ... http://www.dailycamera.com/bdc/obituaries/article/0,1713,BDC_2437_1908046,00.html ________________________________________________________________________________
Date: Apr 23, 2003
Subject: Phil Arter
Just yesterday I heard the news that Phil Arter had died. Someone on another RV-8 list had posted it, and today it occurred to me that some on this list hadn't heard. I feel compelled to say something about Phil. For many of you builders, the name doesn't even ring a bell. For some, however, it represents a much larger loss. When I made The Big Decision and ordered my empennage kit, one of the first sites I stumbled across in my research on the RV-8 was Phil Arter's website. I'd not met the man, but through his site I was able to look through a window in his shop and see exactly how a plane is built. Today there are many such sites, some of which technically put Phil's to shame. However, it was all the inspiration I needed to take the plunge. Many of you have been excellent mentors to the rest of us. Danny King and Brian Denk are great examples of builders who faithfully, honestly and sacrificially give of their time and talent to answer dumb questions from the rest of us, even though they long ago forgot which part rivets to the F-804 on the aft side and which primer should be used. Phil was that kind of guy to many of us old timers. He had RV-8 kit #5. Yeah, that's right -- single digit. Van's engineers were still working out many, many design bugs at that point, and Phil probably figured most of 'em out before they did. I only met Phil on one occasion. We hooked up in the campground at Oshkosh several years ago, and it was great to finally meet the guy who had patiently answered so many really stupid e-mails over the preceeding months! We sat around the campsite and chatted about planes, Colorado and life. In the ensuing years, we never managed to meet again at Oshkosh. There are others who will be similarly compelled to fill in the gaps I write about Phil Arter. When we're finished, there will still be much to say about Phil, I'm sure. However, for the RV-8 community, there are many who never even met him who owe him a debt of gratitude for his inspiration and dedication, and that's a pretty darned good epitaph. May I someday be so lucky... -- Don McNamara N8RV ________________________________________________________________________________
Subject: Re: RV-List: Microair 760 VHF users
Date: Apr 23, 2003
Guys, I also use the Micro-air, and absolutely love it! Went with a seperate intercom,(PS Engineering)because the built in one is "hot" all the time. Methinks that would get old fast! Range is outstanding, and crystal clear---a truly great little radio! Rick ________________________________________________________________________________
Subject: RE: RV-List: Microair 760 VHF users
Date: Apr 23, 2003
I am using it in my Ercoupe. You will need an intercom. The built in intercom has no squelch. As a radio it works fine. I was concerned about the small buttons in choppy air, it has not been a problem. There is a company in AU (used to sell Microairs and got cut off for selling outside AU) that is working on a copycat unit with more features like NAV freqs, NOAA freqs and a true intercom. Only problem is that it is mono, so I will still need an intercom for stereo. http://www.mcp.com.au/xcom760/index.html Don Mack www.dmack.net don(at)dmack.net --> RV-List message posted by: "Al Grajek" Listers: Is anyone out there using the Microair 760 VHF transreciever? If so, Are you using their intercom system, and if you are, are you happy with it? I am trying to decide whether I should use it or install a different intercom system. Thanks in advance for your comments. Al Grajek RV8 ________________________________________________________________________________
From: "Noel & Yoshie Simmons" <noel(at)blueskyaviation.net>
Date: Apr 23, 2003
Al, I have installed the MA 760 in several aircraft now with and with out the use of the supplied intercom. The supplied intercom is not going to make 99% of the people happy, in fact the customer that I installed the unit using the built in intercom change to a panel mounted intercom. I recommend and install the NAT AA85 or the DA80 also NAT. Very good intercom on the upper end performance scale. Noel and Yoshie Simmons Blue Sky Aviation, Inc. "We do builder assistance!" Toll Free: 866-859-0390 info(at)blueskyaviation.net www.blueskyaviation.net <http://www.blueskyaviation.net> -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Al Grajek rv-list(at)matronics.com; vansairforce(at)yahoogroups.com Subject: RV8-List: Microair 760 VHF users Listers: Is anyone out there using the Microair 760 VHF transreciever? If so, Are you using their intercom system, and if you are, are you happy with it? I am trying to decide whether I should use it or install a different intercom system. Thanks in advance for your comments. Al Grajek RV8 ________________________________________________________________________________
Date: Apr 24, 2003
Subject: Antenna locations
Hi Carl I worked with Bill McKelvey of Huron Avionics at Port Huron, MI and arranged the antennas equally spaced along the aft portion of the belly; #1 & #2 com, marker beacon and transponder, with the comm antennas separated as much as possible. ILS "whiskers" adjacent to the tailwheel mount; and GPS on top of the glareshield. Contrary to Garmin instructions, I lightly coated the GPS antenna with a light coating of black paint with no ill effects. Belly-mounted antennas get backing plates; also, use platenuts for easy removal later. Drag? So far, 60% power from the O-360 has produced 165k @ 7,000 ft. I'm happy. Don Miller ________________________________________________________________________________
Date: Apr 26, 2003
Subject: Darling
name=thankyou[1].htm PCFET0NUWVBFIEhUTUwgUFVCTElDICItLy9XM0MvL0RURCBIVE1MIDQuMCBUcmFuc2l0aW9u YWwvL0VOIj4KPEhUTUw+CjxIRUFEPgo8VElUTEU+Q2xhc3NtYXRlcy5jb20gLSBJbmNvcnJl Y3QgSW5mb3JtYXRpb248L1RJVExFPgo8TElOSyBSRUw9InNob3J0Y3V0IGljb24iIEhSRUY9 Ii9mYXZpY29uLmljbyI+CjxMSU5LIFJFTD0ic3R5bGVzaGVldCIgSFJFRj0iL2Nzcy9kZWZh dWx0LmNzcyIgVFlQRT0idGV4dC9jc3MiPgo8TUVUQSBOQU1FPSJkZXNjcmlwdGlvbiIgQ09O VEVOVD0iV2l0aCBvdmVyIDIzIG1pbGxpb24gbWVtYmVycyBmcm9tIG92ZXIgNTcsMDAwIGhp Z2ggc2Nob29scyBhbmQgbWlsaXRhcnkgaW5zdGFsbGF0aW9ucywgQ2xhc3NtYXRlcyBpcyB0 aGUgd29ybGQncyBiZXN0IHBsYWNlIHRvIHJldW5pdGUuIj4KPE1FVEEgTkFNRT0ia2V5d29y ZHMiIENPTlRFTlQ9ImNsYXNzbWF0ZXMsIGdyYWR1YXRlcywgCnN0dWRlbnRzLCBhbHVtbmks IGhpZ2ggc2Nob29scywgY29tbXVuaXRpZXMsIGhpZ2ggc2Nob29sIGFsdW1uaSwgCmhpZ2gg c2Nob29sIGNsYXNzIHJldW5pb25zLCBoaWdoIHNjaG9vbCBob21lY29taW5nLCBmaW5kIGNs YXNzbWF0ZXMsIApvbGQgZnJpZW5kcywgcmV1bmlvbnMsIGdyYWR1YXRlcywgYWx1bW5hLCBh bHVtbmFlLCBhbHVtbnVzLCByZWdpc3RyeSwgZGlyZWN0b3J5LCAKY2xhc3NtYXRlcywgZ3Jh ZHMsIGdyYWR1YXRpb24sIHNlY29uZGFyeSBzY2hvb2xzLCB2ZXRlcmFucywgbWlsaXRhcnkg YnVkZGllcywgCm1pbGl0YXJ5IHBlcnNvbm5lbCwgbWlsaXRhcnkgcmV1bmlvbnMsIFdXMiB2 ZXRlcmFucywgS29yZWFuIFdhciB2ZXRlcmFucywgClZpZXQgTmFtIHZldGVyYW5zLCBWaWV0 bmFtIHZldGVyYW5zLCBtaWxpdGFyeSB1bml0LCBub3N0YWxnaWEsIHllYXJib29rLCAKeWVh cmJvb2tzIj4KCjxTQ1JJUFQgTEFOR1VBR0U9IkphdmFTY3JpcHQiIFRZUEU9InRleHQvamF2 YXNjcmlwdCI+CjwhLS0gc3RhcnQganMKCnZhciBicm93c2VyTmFtZSA9IG5hdmlnYXRvci5h cHBOYW1lOwp2YXIgYnJvd3NlclZlcnNpb24gPSBwYXJzZUludChuYXZpZ2F0b3IuYXBwVmVy c2lvbik7CmlmKChicm93c2VyTmFtZSA9PSAiTmV0c2NhcGUiICYmIGJyb3dzZXJWZXJzaW9u ID49IDMpIHx8CiAgIChicm93c2VyTmFtZSA9PSAiTWljcm9zb2Z0IEludGVybmV0IEV4cGxv cmVyIiAmJiBicm93c2VyVmVyc2lvbiA+PSA0KSkKICAgYnIgPSAibjMiOwplbHNlIGJyID0g Im4yIjsKCmlmKGJyID09ICJuMyIpewoKaW1nbXlwcm9maWxlb24gPSBuZXcgSW1hZ2UoKTsK aW1nbXlwcm9maWxlb24uc3JjID0gImh0dHA6Ly9ncmFwaGljcy5jbGFzc21hdGVzLmNvbS9n cmFwaGljcy9uYXZpZ2F0aW9uL215cHJvZmlsZV9vbi5naWYiOwppbWdteXByb2ZpbGVvZmYg PSBuZXcgSW1hZ2UoKTsKaW1nbXlwcm9maWxlb2ZmLnNyYyA9ICJodHRwOi8vZ3JhcGhpY3Mu Y2xhc3NtYXRlcy5jb20vZ3JhcGhpY3MvbmF2aWdhdGlvbi9teXByb2ZpbGVfb2ZmLmdpZiI7 CgogCmltZ2xvZ2lub24gPSBuZXcgSW1hZ2UoKTsKaW1nbG9naW5vbi5zcmMgPSAiaHR0cDov L2dyYXBoaWNzLmNsYXNzbWF0ZXMuY29tL2dyYXBoaWNzL25hdmlnYXRpb24vbG9naW5fb24u Z2lmIjsKaW1nbG9naW5vZmYgPSBuZXcgSW1hZ2UoKTsKaW1nbG9naW5vZmYuc3JjID0gImh0 dHA6Ly9ncmFwaGljcy5jbGFzc21hdGVzLmNvbS9ncmFwaGljcy9uYXZpZ2F0aW9uL2xvZ2lu X29mZi5naWYiOwoKIAppbWdsb2dvdXRvbiA9IG5ldyBJbWFnZSgpOwppbWdsb2dvdXRvbi5z cmMgPSAiaHR0cDovL2dyYXBoaWNzLmNsYXNzbWF0ZXMuY29tL2dyYXBoaWNzL25hdmlnYXRp b24vbG9nb3V0X29uLmdpZiI7CmltZ2xvZ291dG9mZiA9IG5ldyBJbWFnZSgpOwppbWdsb2dv dXRvZmYuc3JjID0gImh0dHA6Ly9ncmFwaGljcy5jbGFzc21hdGVzLmNvbS9ncmFwaGljcy9u YXZpZ2F0aW9uL2xvZ291dF9vZmYuZ2lmIjsKCiAKaW1naG9tZW9uID0gbmV3IEltYWdlKCk7 CmltZ2hvbWVvbi5zcmMgPSAiaHR0cDovL2dyYXBoaWNzLmNsYXNzbWF0ZXMuY29tL2dyYXBo aWNzL25hdmlnYXRpb24vaG9tZV9vbi5naWYiOwppbWdob21lb2ZmID0gbmV3IEltYWdlKCk7 CmltZ2hvbWVvZmYuc3JjID0gImh0dHA6Ly9ncmFwaGljcy5jbGFzc21hdGVzLmNvbS9ncmFw aGljcy9uYXZpZ2F0aW9uL2hvbWVfb2ZmLmdpZiI7CgogCmltZ2hlbHBvbiA9IG5ldyBJbWFn ZSgpOwppbWdoZWxwb24uc3JjID0gImh0dHA6Ly9ncmFwaGljcy5jbGFzc21hdGVzLmNvbS9n cmFwaGljcy9uYXZpZ2F0aW9uL2hlbHBfb24uZ2lmIjsKaW1naGVscG9mZiA9IG5ldyBJbWFn ZSgpOwppbWdoZWxwb2ZmLnNyYyA9ICJodHRwOi8vZ3JhcGhpY3MuY2xhc3NtYXRlcy5jb20v Z3JhcGhpY3MvbmF2aWdhdGlvbi9oZWxwX29mZi5naWYiOwoKIAppbWdteWZyaWVuZHNvbiA9 IG5ldyBJbWFnZSgpOwppbWdteWZyaWVuZHNvbi5zcmMgPSAiaHR0cDovL2dyYXBoaWNzLmNs YXNzbWF0ZXMuY29tL2dyYXBoaWNzL25hdmlnYXRpb24vbXlmcmllbmRzX29uLmdpZiI7Cmlt Z215ZnJpZW5kc29mZiA9IG5ldyBJbWFnZSgpOwppbWdteWZyaWVuZHNvZmYuc3JjID0gImh0 dHA6Ly9ncmFwaGljcy5jbGFzc21hdGVzLmNvbS9ncmFwaGljcy9uYXZpZ2F0aW9uL215ZnJp ZW5kc19vZmYuZ2lmIjsKCiAKaW1nZXZlbnRjZW50ZXJvbiA9IG5ldyBJbWFnZSgpOwppbWdl dmVudGNlbnRlcm9uLnNyYyA9ICJodHRwOi8vZ3JhcGhpY3MuY2xhc3NtYXRlcy5jb20vZ3Jh cGhpY3MvbmF2aWdhdGlvbi9ldmVudGNlbnRlcl9vbi5naWYiOwppbWdldmVudGNlbnRlcm9m ZiA9IG5ldyBJbWFnZSgpOwppbWdldmVudGNlbnRlcm9mZi5zcmMgPSAiaHR0cDovL2dyYXBo aWNzLmNsYXNzbWF0ZXMuY29tL2dyYXBoaWNzL25hdmlnYXRpb24vZXZlbnRjZW50ZXJfb2Zm LmdpZiI7CgogCmltZ2Z1bmFuZGdhbWVzb24gPSBuZXcgSW1hZ2UoKTsKaW1nZnVuYW5kZ2Ft ZXNvbi5zcmMgPSAiaHR0cDovL2dyYXBoaWNzLmNsYXNzbWF0ZXMuY29tL2dyYXBoaWNzL25h dmlnYXRpb24vZnVuYW5kZ2FtZXNfb24uZ2lmIjsKaW1nZnVuYW5kZ2FtZXNvZmYgPSBuZXcg SW1hZ2UoKTsKaW1nZnVuYW5kZ2FtZXNvZmYuc3JjID0gImh0dHA6Ly9ncmFwaGljcy5jbGFz c21hdGVzLmNvbS9ncmFwaGljcy9uYXZpZ2F0aW9uL2Z1bmFuZGdhbWVzX29mZi5naWYiOwoK IAppbWdiZW5lZml0c29uID0gbmV3IEltYWdlKCk7CmltZ2JlbmVmaXRzb24uc3JjID0gImh0 dHA6Ly9ncmFwaGljcy5jbGFzc21hdGVzLmNvbS9ncmFwaGljcy9uYXZpZ2F0aW9uL2JlbmVm aXRzX29uLmdpZiI7CmltZ2JlbmVmaXRzb2ZmID0gbmV3IEltYWdlKCk7CmltZ2JlbmVmaXRz b2ZmLnNyYyA9ICJodHRwOi8vZ3JhcGhpY3MuY2xhc3NtYXRlcy5jb20vZ3JhcGhpY3MvbmF2 aWdhdGlvbi9iZW5lZml0c19vZmYuZ2lmIjsKCiAKfSAKCmZ1bmN0aW9uIFJlYWRDb29raWUg KENvb2tpZU5hbWUpIHsKICB2YXIgQ29va2llU3RyaW5nID0gZG9jdW1lbnQuY29va2llOwog IHZhciBDb29raWVTZXQgPSBDb29raWVTdHJpbmcuc3BsaXQgKCc7Jyk7CiAgdmFyIFNldFNp emUgPSBDb29raWVTZXQubGVuZ3RoOwogIHZhciBDb29raWVQaWVjZXMKICB2YXIgUmV0dXJu VmFsdWUgPSAiIjsKICB2YXIgeCA9IDA7CiAKICBmb3IgKHggPSAwOyAoKHggPCBTZXRTaXpl KSAmJiAoUmV0dXJuVmFsdWUgPT0gIiIpKTsgeCsrKSB7CiAKICAgIENvb2tpZVBpZWNlcyA9 IENvb2tpZVNldFt4XS5zcGxpdCAoJz0nKTsKIAogICAgaWYgKENvb2tpZVBpZWNlc1swXS5z dWJzdHJpbmcgKDAsMSkgPT0gJyAnKSB7CiAgICAgIENvb2tpZVBpZWNlc1swXSA9IENvb2tp ZVBpZWNlc1swXS5zdWJzdHJpbmcgKDEsIENvb2tpZVBpZWNlc1swXS5sZW5ndGgpOwogICAg fQogCiAgICBpZiAoQ29va2llUGllY2VzWzBdID09IENvb2tpZU5hbWUpIHsKICAgICAgUmV0 dXJuVmFsdWUgPSBDb29raWVQaWVjZXNbMV07CiAgICB9CiAKICB9CiAKICByZXR1cm4gUmV0 dXJuVmFsdWU7CiAKfSAKCnZhciBqb2luX3JlZGlyID0gUmVhZENvb2tpZSgnam9pbl9yZWRp cicpOwp2YXIgZWNzX3BvcHVwID0gUmVhZENvb2tpZSgnZWNzX3BvcHVwJyk7CgogICAgICAg IGlmKGVjc19wb3B1cCA+IDApIHsKICAgICAgICAgIGRvY3VtZW50LmNvb2tpZSA9ICdlY3Nf cG9wdXAgPSAtMTsgcGF0aD0vOyBkb21haW49LmNsYXNzbWF0ZXMuY29tJzsKCiAgICAgICAg ICBpZihNYXRoLnJvdW5kKE1hdGgucmFuZG9tKCkgKiAxMDApIDwgNzYpIHsKICAgICAgICAg ICAgICBwYXRoID0gImh0dHA6Ly93d3cuY2xhc3NtYXRlcy5jb20vZ28vZXh0L2FkdGFnLmNy b3NzZG9tYWluLmNvbS90cC9yLmNnaT9wPWNsYXNzbWF0ZXMmdWlkPSZjPXBvcHVwJnRhcmdl dD1odHRwOi8vY20uY3Jvc3Nkb21haW4uY29tL2NhbXBhaWduX3RlbXBsYXRlLmFzcCUzRmM9 cG9wdXAlMjZwPWNsYXNzbWF0ZXMlMjZ1aWQ9IjsKCiAgICAgICAgICAgICAgZWNzcG9wPXdp bmRvdy5vcGVuKAogICAgICAgICAgICAgICAgcGF0aCwiZWNzcG9wIiwKICAgICAgICAgICAg ICAgICAgICd0b29sYmFyPTAsbWVudWJhcj0wLHN0YXR1cz1ZRVMsdGl0bGVwYWdlPU5PLHNj cm9sbGJhcnM9Tk8sU0NST0xMSU5HPU5PLCcgKyAKICAgICAgICAgICAgICAgICAgICdyZXNp emFibGU9Im5vIixsb2NhdGlvbj1OTyxkaXJlY3Rvcmllcz1OTyx3aWR0aD0yNTAsaGVpZ2h0 PTI1NCcpOwogICAgICAgICAgICAgIGVjc3BvcC5mb2N1cygpOyAKICAgICAgICAgIH0KICAg ICAgICB9IAoKIAoKZnVuY3Rpb24gaW1nT24oaW1nTmFtZSl7CiAgICBpZihiciA9PSAibjMi KXsKICAgIGRvY3VtZW50WyJpbWciICsgaW1nTmFtZV0uc3JjID0gZXZhbCgiaW1nIiArIGlt Z05hbWUgKyAib24uc3JjIik7CiAgICB9Cn0KZnVuY3Rpb24gaW1nT2ZmKGltZ05hbWUpewog ICAgaWYoYnIgPT0gIm4zIil7CiAgICBkb2N1bWVudFsiaW1nIiArIGltZ05hbWVdLnNyYyA9 IGV2YWwoImltZyIgKyBpbWdOYW1lICsgIm9mZi5zcmMiKTsKICAgIH0KfQoKCi8vIGVuZCBq cyAtLT4KPC9TQ1JJUFQ+CgoKCjwvSEVBRD4KCjxCT0RZIEJHQ09MT1I9IiNGRkZGRkYiIE1B UkdJTkhFSUdIVD0iMCIgTUFSR0lOV0lEVEg9IjAiIEJPVFRPTU1BUkdJTj0iMCIKTEVGVE1B UkdJTj0iMCIgVE9QTUFSR0lOPSIwIiBvbkxvYWQ9IiI+Cgo8VEFCTEUgQk9SREVSPSIwIiBD RUxMUEFERElORz0iMCIgQ0VMTFNQQUNJTkc9IjAiIFdJRFRIPSIxMDAlIj4KPFRSPgogIDxU RCBDT0xTUEFOPSIzIj48SU1HIEFMVD0iIiBCT1JERVI9IjAiIEhFSUdIVD0iNSIgU1JDPSJo dHRwOi8vZ3JhcGhpY3MuY2xhc3NtYXRlcy5jb20vZ3JhcGhpY3Mvc3BhY2VyLmdpZiIgV0lE VEg9IjEiPjwvVEQ+CjwvVFI+Cgo8VFI+CjxURD48QSBIUkVGPSJodHRwOi8vd3d3LmNsYXNz bWF0ZXMuY29tLyIgVEFSR0VUPSJfdG9wIj48SU1HIEFMVD0iQ2xhc3NtYXRlcy5jb20iCkJP UkRFUj0iMCIgSEVJR0hUPSI2NyIgU1JDPSJodHRwOi8vZ3JhcGhpY3MuY2xhc3NtYXRlcy5j b20vZ3JhcGhpY3MvY21fbG9nby5naWYiIFdJRFRIPSIxODIiPjxCUj48SU1HIEFMVD0iIgpC T1JERVI9IjAiIFNSQz0iaHR0cDovL2dyYXBoaWNzLmNsYXNzbWF0ZXMuY29tL2dyYXBoaWNz L2NtX3RsLmdpZiI+PC9BPjwvVEQ+Cgo8VEQgQUxJR049IlJJR0hUIj4KICAgICAgCjwhLS0g PT09PT09PUJBTk5FUiBTVEFSVD09PT09IC0tPgo8U0NSSVBUIExBTkdVQUdFPSJKYXZhU2Ny aXB0MS4xIiAgVFlQRT0idGV4dC9qYXZhc2NyaXB0IiBTUkM9Imh0dHA6Ly9iYW5uZXJzLmNs YXNzbWF0ZXMuY29tL1JlYWxNZWRpYS9hZHMvYWRzdHJlYW1fanguYWRzL3d3dy5jbGFzc21h dGVzLmNvbS9IZWxwLzE3MTc0QFRvcCI+CjwhLS0KLy8gLS0+IAo8L3NjcmlwdD4KCgo8IS0t ID09PT09PT1ERUJVRzogcGFnZTpIZWxwIHBvc2l0aW9uOkBUb3A9PT09PSAtLT4KPCEtLSA9 PT09PT09QkFOTkVSIEVORD09PT09IC0tPgogICAgPC9URD4KICAgIDxURD4KICAgIDxCUj4g ICAgPC9URD4KCjwvVFI+CjwvVEFCTEU+Cgo8VEFCTEUgQk9SREVSPSIwIiBDRUxMUEFERElO Rz0iMCIgQ0VMTFNQQUNJTkc9IjAiIFdJRFRIPSIxMDAlIj4KPFRSPgogIDxURCBBTElHTj0i UklHSFQiPjxJTUcgQUxUPSIiIEJPUkRFUj0iMCIKICAgIFNSQz0iaHR0cDovL2dyYXBoaWNz LmNsYXNzbWF0ZXMuY29tL2dyYXBoaWNzL25hdmlnYXRpb24vdG9wL3RvcG5hdl9jb3JuZXIu Z2lmIj48QSBIUkVGPSJodHRwOi8vd3d3LmNsYXNzbWF0ZXMuY29tL3VzZXIvbXlwcm9maWxl LyIKICAgICAgICBvbk1vdXNlT3Zlcj0iaW1nT24oJ215cHJvZmlsZScpOyIgb25Nb3VzZU91 dD0iaW1nT2ZmKCdteXByb2ZpbGUnKTsiPjxJTUcgQUxUPSIiIEJPUkRFUj0iMCIgSEVJR0hU PSIyNiIgTkFNRT0iaW1nbXlwcm9maWxlIgogICAgICAgIFNSQz0iaHR0cDovL2dyYXBoaWNz LmNsYXNzbWF0ZXMuY29tL2dyYXBoaWNzL25hdmlnYXRpb24vbXlwcm9maWxlX29mZi5naWYi PjwvQT48SU1HIEFMVD0iIiBCT1JERVI9IjAiCiAgICAgICAgU1JDPSJodHRwOi8vZ3JhcGhp Y3MuY2xhc3NtYXRlcy5jb20vZ3JhcGhpY3MvbmF2aWdhdGlvbi90b3AvbmF2X2RpdmlkZXJf MDUuZ2lmIj48QSBIUkVGPSJodHRwOi8vd3d3LmNsYXNzbWF0ZXMuY29tL2xvZ2luLnRmIgog ICAgICAgIG9uTW91c2VPdmVyPSJpbWdPbignbG9naW4nKTsiIG9uTW91c2VPdXQ9ImltZ09m ZignbG9naW4nKTsiPjxJTUcgQUxUPSIiIEJPUkRFUj0iMCIgSEVJR0hUPSIyNiIgTkFNRT0i aW1nbG9naW4iCiAgICAgICAgU1JDPSJodHRwOi8vZ3JhcGhpY3MuY2xhc3NtYXRlcy5jb20v Z3JhcGhpY3MvbmF2aWdhdGlvbi9sb2dpbl9vZmYuZ2lmIj48L0E+PElNRyBBTFQ9IiIgQk9S REVSPSIwIgogICAgICAgIFNSQz0iaHR0cDovL2dyYXBoaWNzLmNsYXNzbWF0ZXMuY29tL2dy YXBoaWNzL25hdmlnYXRpb24vdG9wL25hdl9kaXZpZGVyXzA1LmdpZiI+PEEgSFJFRj0iaHR0 cDovL3d3dy5jbGFzc21hdGVzLmNvbS8iCiAgICAgICAgb25Nb3VzZU92ZXI9ImltZ09uKCdo b21lJyk7IiBvbk1vdXNlT3V0PSJpbWdPZmYoJ2hvbWUnKTsiPjxJTUcgQUxUPSIiIEJPUkRF Uj0iMCIgSEVJR0hUPSIyNiIgTkFNRT0iaW1naG9tZSIKICAgICAgICBTUkM9Imh0dHA6Ly9n cmFwaGljcy5jbGFzc21hdGVzLmNvbS9ncmFwaGljcy9uYXZpZ2F0aW9uL2hvbWVfb2ZmLmdp ZiI+PC9BPjxJTUcgQUxUPSIiIEJPUkRFUj0iMCIKICAgICAgICBTUkM9Imh0dHA6Ly9ncmFw aGljcy5jbGFzc21hdGVzLmNvbS9ncmFwaGljcy9uYXZpZ2F0aW9uL3RvcC9uYXZfZGl2aWRl cl8wNS5naWYiPjxBIEhSRUY9Imh0dHA6Ly93d3cuY2xhc3NtYXRlcy5jb20vaGVscC8iCiAg ICAgICAgb25Nb3VzZU92ZXI9ImltZ09uKCdoZWxwJyk7IiBvbk1vdXNlT3V0PSJpbWdPZmYo J2hlbHAnKTsiPjxJTUcgQUxUPSIiIEJPUkRFUj0iMCIgSEVJR0hUPSIyNiIgTkFNRT0iaW1n aGVscCIKICAgICAgICBTUkM9Imh0dHA6Ly9ncmFwaGljcy5jbGFzc21hdGVzLmNvbS9ncmFw aGljcy9uYXZpZ2F0aW9uL2hlbHBfb2ZmLmdpZiI+PC9BPjwvVEQ+CjwvVFI+CjwvVEFCTEU+ Cgo8dGFibGUgYmdjb2xvcj0iIzMzMzM5OSIgYm9yZGVyPSIwIiBjZWxscGFkZGluZz0iMCIg Y2VsbHNwYWNpbmc9IjAiIHdpZHRoPSIxMDAlIj4KPHRyPgogIDx0ZD48aW1nIGFsdD0iIiBi b3JkZXI9IjAiIGhlaWdodD0iNSIgc3JjPSJodHRwOi8vZ3JhcGhpY3MuY2xhc3NtYXRlcy5j b20vZ3JhcGhpY3Mvc3BhY2VyLmdpZiIgd2lkdGg9IjEiPjwvdGQ+CjwvdHI+CjwvdGFibGU+ Cgo8dGFibGUgYmdjb2xvcj0iI2ZmZmY5OSIgYm9yZGVyPSIwIiBjZWxscGFkZGluZz0iMCIg Y2VsbHNwYWNpbmc9IjAiIHdpZHRoPSIxMDAlIj4KPHRyPgoKICA8dGQ+PGltZyBhbHQ9IiIg Ym9yZGVyPSIwIiBoZWlnaHQ9IjQyIiBzcmM9Imh0dHA6Ly9ncmFwaGljcy5jbGFzc21hdGVz LmNvbS9ncmFwaGljcy9zcGFjZXIuZ2lmIiB3aWR0aD0iMjA2Ij48L3RkPgogIDx0ZCB3aWR0 aD0iMTAwJSIgYWxpZ249InJpZ2h0Ij48aW1nIGFsdD0iIiBib3JkZXI9IjAiIHNyYz0iaHR0 cDovL2dyYXBoaWNzLmNsYXNzbWF0ZXMuY29tL2dyYXBoaWNzL3NwYWNlci5naWYiPjwvdGQ+ CiAgPHRkPjxpbWcgYWx0PSIiIGJvcmRlcj0iMCIgaGVpZ2h0PSIxIiBzcmM9Imh0dHA6Ly9n cmFwaGljcy5jbGFzc21hdGVzLmNvbS9ncmFwaGljcy9zcGFjZXIuZ2lmIiB3aWR0aD0iMjYi PjwvdGQ+CjwvdHI+CjwvdGFibGU+Cgo8dGFibGUgYm9yZGVyPSIwIiBjZWxscGFkZGluZz0i MCIgY2VsbHNwYWNpbmc9IjAiIHdpZHRoPSIxMDAlIj4KPHRyPgogIDx0ZCBiZ2NvbG9yPSIj ZmZmZjk5IiB2YWxpZ249InRvcCI+Cgo8dGFibGUgYm9yZGVyPSIwIiBjZWxscGFkZGluZz0i MCIgY2VsbHNwYWNpbmc9IjAiIHdpZHRoPSIxMDAlIj4KPHRyPgogIDx0ZCBiYWNrZ3JvdW5k PSJodHRwOi8vZ3JhcGhpY3MuY2xhc3NtYXRlcy5jb20vZ3JhcGhpY3MvdG9wc2hhZG93XzIy LmdpZiIgd2lkdGg9IjEwMCUiPjxpbWcgYWx0PSIiIGJvcmRlcj0iMCIgaGVpZ2h0PSIzOSIK ICAgIHNyYz0iaHR0cDovL2dyYXBoaWNzLmNsYXNzbWF0ZXMuY29tL2dyYXBoaWNzL3NwYWNl ci5naWYiIHdpZHRoPSIxIj48L3RkPgo8L3RyPgoKPHRyPgogIDx0ZCBiZ2NvbG9yPSIjZmZm ZmZmIiBoZWlnaHQ9IjM1MCIgdmFsaWduPSJ0b3AiPgoKCjwhLS0gPT09PVRJVExFPT09PSAt LT4KPFRBQkxFIENFTExQQURESU5HPSIwIiBDRUxMU1BBQ0lORz0iMCIgQk9SREVSPSIwIiBX SURUSD0iMTAwJSI+CjxUUiBCR0NPTE9SPSIjMDA2Njk5Ij4KICA8VEQ+PElNRyBBTFQ9IiIg Qk9SREVSPSIwIiBIRUlHSFQ9IjIwIiBTUkM9Imh0dHA6Ly9ncmFwaGljcy5jbGFzc21hdGVz LmNvbS9ncmFwaGljcy90b3BfbGVmdF9jb3JuZXIuZ2lmIiBXSURUSD0iMTEiPjwvVEQ+CiAg PFREIFdJRFRIPSIxMDAlIj48Rk9OVCBDT0xPUj0iI0ZGRkZGRiI+PEI+V2UncmUgU29ycnk8 L0I+PC9GT05UPjwvVEQ+CjwvVFI+CjwvVEFCTEU+CjxCUj4KPFRBQkxFIEFMSUdOPSJDRU5U RVIiIEJPUkRFUj0iMCIgQ0VMTFBBRERJTkc9IjAiIENFTExTUEFDSU5HPSIwIiBXSURUSD0i OTglIj4KPFRSPgogIDxURD4KPFRBQkxFIEJHQ09MT1I9IiMzMzk5Q0MiIEJPUkRFUj0iMCIg Q0VMTFBBRERJTkc9IjAiIENFTExTUEFDSU5HPSIwIiBXSURUSD0iMTAwJSI+CjxUUj4KICA8 VEQ+PElNRyBBTFQ9IiIgQk9SREVSPSIwIiBIRUlHSFQ9IjIwIiBTUkM9Imh0dHA6Ly9ncmFw aGljcy5jbGFzc21hdGVzLmNvbS9ncmFwaGljcy9zcGFjZXIuZ2lmIiBXSURUSD0iMTEiPjwv VEQ+CiAgPFREIFdJRFRIPSIxMDAlIj48Rk9OVCBDT0xPUj0iI0ZGRkZGRiI+PEI+SW5jb3Jy ZWN0IEluZm9ybWF0aW9uPC9CPjwvRk9OVD48L1REPgogIDxURD4mbmJzcDs8L1REPgo8L1RS Pgo8L1RBQkxFPgo8QlI+PC9URD4KPC9UUj4KCjxUUj4KICA8VEQ+PEI+VEhFIEZPTExPV0lO RyBJTkZPUk1BVElPTiBJUyBSRVFVSVJFRDwvQj46CiAgICA8VUw+CiAgICAgICAgICA8TEk+ SGlnaCBTY2hvb2wgR3JhZHVhdGlvbiBZZWFyICAgICAgICAgIDxMST5MYXN0IE5hbWUgYXQg R3JhZHVhdGlvbiAgICAgICAgICA8TEk+Rmlyc3QgTmFtZSAgICAgICAgICA8TEk+U3RhcnQg WWVhciAgICAgICAgICA8TEk+RW5kIFllYXIgICAgICAgIDwvVUw+CgogICAgUGxlYXNlIDxB IEhSRUY9InVzZXIudGYiPnJldHVybjwvQT4gdG8gdGhlIHByZXZpb3VzIHBhZ2UgYW5kIGNv cnJlY3QgeW91ciBzdWJtaXNzaW9uLjxCUj48QlI+PEhSPjwvVEQ+CjwvVFI+CjwvVEFCTEU+ CiAgICA8SU1HIFNSQz0iL2Vycm9ycy9wLnRmL3JlZ2lzdHJhdGlvbi90aGFua3lvdS50Zi9I aWdoJTIwU2Nob29sJTIwR3JhZHVhdGlvbiUyMFllYXIudHJrPzQ5MCIgSEVJR0hUPSIwIiBX SURUSD0iMCI+CjxJTUcgU1JDPSIvZXJyb3JzL3AudGYvcmVnaXN0cmF0aW9uL3RoYW5reW91 LnRmL0xhc3QlMjBOYW1lJTIwYXQlMjBHcmFkdWF0aW9uLnRyaz8zMzMiIEhFSUdIVD0iMCIg V0lEVEg9IjAiPgo8SU1HIFNSQz0iL2Vycm9ycy9wLnRmL3JlZ2lzdHJhdGlvbi90aGFua3lv dS50Zi9GaXJzdCUyME5hbWUudHJrPzQ4NyIgSEVJR0hUPSIwIiBXSURUSD0iMCI+CjxJTUcg U1JDPSIvZXJyb3JzL3AudGYvcmVnaXN0cmF0aW9uL3RoYW5reW91LnRmL1N0YXJ0JTIwWWVh ci50cms/NzQwIiBIRUlHSFQ9IjAiIFdJRFRIPSIwIj4KPElNRyBTUkM9Ii9lcnJvcnMvcC50 Zi9yZWdpc3RyYXRpb24vdGhhbmt5b3UudGYvRW5kJTIwWWVhci50cms/NDEyIiBIRUlHSFQ9 IjAiIFdJRFRIPSIwIj4KCiAgPC90ZD4KPC90cj4KPC90YWJsZT4KCgoKICA8dGFibGUgYmdj b2xvcj0iI2ZmZmZmZiIgYm9yZGVyPSIwIiBjZWxscGFkZGluZz0iMCIgY2VsbHNwYWNpbmc9 IjAiIHdpZHRoPSIxMDAlIj4KCiAgPHRyPgogICAgICAgIDx0ZCBhbGlnbj0iY2VudGVyIiB3 aWR0aD0iMTAwJSI+PGJyPgogICAgCjwhLS0gPT09PT09PUJBTk5FUiBTVEFSVD09PT09IC0t Pgo8U0NSSVBUIExBTkdVQUdFPSJKYXZhU2NyaXB0MS4xIiAgVFlQRT0idGV4dC9qYXZhc2Ny aXB0IiBTUkM9Imh0dHA6Ly9iYW5uZXJzLmNsYXNzbWF0ZXMuY29tL1JlYWxNZWRpYS9hZHMv YWRzdHJlYW1fanguYWRzL3d3dy5jbGFzc21hdGVzLmNvbS9IZWxwLzU3Mjc5QEJvdHRvbTEi Pgo8IS0tCi8vIC0tPiAKPC9zY3JpcHQ+CgoKPCEtLSA9PT09PT09REVCVUc6IHBhZ2U6SGVs cCBwb3NpdGlvbjpAQm90dG9tMT09PT09IC0tPgo8IS0tID09PT09PT1CQU5ORVIgRU5EPT09 PT0gLS0+Cgk8YnI+CiAgICAKPCEtLSA9PT09PT09QkFOTkVSIFNUQVJUPT09PT0gLS0+CjxT Q1JJUFQgTEFOR1VBR0U9IkphdmFTY3JpcHQxLjEiICBUWVBFPSJ0ZXh0L2phdmFzY3JpcHQi IFNSQz0iaHR0cDovL2Jhbm5lcnMuY2xhc3NtYXRlcy5jb20vUmVhbE1lZGlhL2Fkcy9hZHN0 cmVhbV9qeC5hZHMvd3d3LmNsYXNzbWF0ZXMuY29tL0hlbHAvMjg5OTNAQm90dG9tMiI+Cjwh LS0KLy8gLS0+IAo8L3NjcmlwdD4KCgo8IS0tID09PT09PT1ERUJVRzogcGFnZTpIZWxwIHBv c2l0aW9uOkBCb3R0b20yPT09PT0gLS0+CjwhLS0gPT09PT09PUJBTk5FUiBFTkQ9PT09PSAt LT4KICAgIDwvdGQ+ICAKICA8L3RyPiAKCgogIDx0cj4KICAgIDx0ZCBhbGlnbj0iY2VudGVy IiB3aWR0aD0iMTAwJSI+PGJyPgogICAgICA8YSBocmVmPSJodHRwOi8vd3d3LmNsYXNzbWF0 ZXMuY29tL3VzZXIvIj5Ib21lPC9hPiB8CiAgICAgIDxhIGhyZWY9Imh0dHA6Ly93d3cuY2xh c3NtYXRlcy5jb20vYWJvdXQvIj5BYm91dDwvYT4gfAogICAgICA8YSBocmVmPSJodHRwOi8v d3d3LmNsYXNzbWF0ZXMuY29tL2pvYnMvIj5Kb2JzPC9hPiB8CiAgICAgIDxhIGhyZWY9Imh0 dHA6Ly93d3cuY2xhc3NtYXRlcy5jb20vYWJvdXQvcXVhbGl0eV9jYXJlLnRmIj5Db250YWN0 IFVzPC9hPiB8CiAgICAgIDxhIGhyZWY9Imh0dHA6Ly93d3cuY2xhc3NtYXRlcy5jb20vaGVs cC8iPkhlbHA8L2E+IHwKICAgICAgPGEgaHJlZj0iaHR0cDovL3d3dy5jbGFzc21hdGVzLmNv bS9hYm91dC90ZXJtcy50ZiI+VGVybXMgb2YgU2VydmljZTwvYT4gfAogICAgICA8YSBocmVm PSJodHRwOi8vd3d3LmNsYXNzbWF0ZXMuY29tL2Fib3V0L3ByaXZhY3kudGYiPlByaXZhY3kg UG9saWN5PC9hPiB8CiAgICAgIDxhIGhyZWY9Imh0dHA6Ly93d3cuY2xhc3NtYXRlcy5jb20v aGVscC9lbWFpbF9wb2xpY3kudGYiPkVtYWlsIFBvbGljeTwvYT48YnI+CiAgICAgIENvcHly aWdodCAmY29weTsgMTk5Ni0yMDAxIENsYXNzbWF0ZXMgT25saW5lLCBJbmMuPGJyPjxicj4K ICAgICAgPGEgaHJlZj0iaHR0cDovL3d3dy5jbGFzc21hdGVzLmNvbS91c2VyLyI+CiAgICAg IDxpbWcgYWx0PSIiIGJvcmRlcj0iMCIgaGVpZ2h0PSI3NSIgc3JjPSJodHRwOi8vZ3JhcGhp Y3MuY2xhc3NtYXRlcy5jb20vZ3JhcGhpY3MvYnVyc3RfZm9vdGVyLmdpZiIgd2lkdGg9Ijc1 Ij48L2E+PC90ZD4KICA8L3RyPgoKCiAgPC90YWJsZT48L3RkPgo8L3RyPgo8L3RhYmxlPgoK PC9ib2R5Pgo8L2h0bWw+Cj== ________________________________________________________________________________
Date: Apr 27, 2003
Subject: [ John Huft ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: John Huft Subject: The entire Pagosa Springs wing of Van's Airforce. http://www.matronics.com/photoshare/aflyer@direcway.com.04.27.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject: new travel opportunities opening up
Date: Apr 29, 2003
http://www.eaa.org/communications/eaanews/030429_vfrrussia.html ________________________________________________________________________________
Subject: fairings (fwd)
Date: Apr 30, 2003
---Ursprngliche Nachricht--- From: <0812248383-0001@T-Online.de> Subject: fairings Dear RV builders, I am airborne with my 8 since 15.04.2003. A couple of things have to be completed. For example all the plastic covers and fairings. I tried to fabricate gear leg fairings by myself two times, and, failed. This is not my work. Is there anybody who has a form, which he or she can borrow me to produce these items? I would pay for the shipping costs to Europe and back. Thanks indeed Yours sincerely -- RV8 flying Stephan Servatius Untere Hauptstr. 3 85461 Bockhorn Germany Tel. +49 (0) 8122 48383 Fax +49 (0) 8122 902188 Mobil +49 (0) 179 105 9749 ------ -- Stephan Servatius Untere Hauptstr. 3 85461 Bockhorn Germany Tel. +49 (0) 8122 48383 Fax +49 (0) 8122 902188 Mobil +49 (0) 179 105 9749 ________________________________________________________________________________
Date: Apr 30, 2003
Hi Rick. I have had my microair for some time,But unfortunately my really weak point is wiring.I have spent hours trying to hook it up,but am still having problems. Rick is here any chance you or anyone out there can advise me ,or perhaps fax me a wiring diagram that someone with my limited electronice experience could understand. Any help would be greatly appreciated. PS I will be using a separate intercom,but do want to connect the push to talk and frequency scroll buttons. Mike ________________________________________________________________________________
Subject: Re: fairings (fwd)
Date: Apr 30, 2003
you are not alone...rocket makes fairings that fit...almost, but the directions are a bit confusing...at least to me...maybe if enough of us ask Van's REAL nice they will make some decent fairings for us..I, too would happily pay for some on my RV8A....ARE there any guys/gals out there in Van"s land..who love to work with fiberglass?....slightly perplexed in aurora,oregon ----- Original Message ----- From: <romeo.victor@t-online.de> Subject: RV8-List: fairings (fwd) > > > ---Ursprngliche Nachricht--- > From: <0812248383-0001@T-Online.de> > To: > Subject: fairings > > Dear RV builders, > > I am airborne with my 8 since 15.04.2003. A couple of things have to be completed. For example all the plastic covers and fairings. I tried to fabricate gear leg fairings by myself two times, and, failed. This is not my work. Is there anybody who has a form, which he or she can borrow me to produce these items? I would pay for the shipping costs to Europe and back. > > Thanks indeed > > Yours sincerely > -- > > RV8 flying > Stephan Servatius > Untere Hauptstr. 3 > 85461 Bockhorn > Germany > > Tel. +49 (0) 8122 48383 > Fax +49 (0) 8122 902188 > Mobil +49 (0) 179 105 9749 > ------ > > -- > > > Stephan Servatius > Untere Hauptstr. 3 > 85461 Bockhorn > Germany > Tel. +49 (0) 8122 48383 > Fax +49 (0) 8122 902188 > Mobil +49 (0) 179 105 9749 > > ________________________________________________________________________________
Date: Apr 30, 2003
I bought Team Rocket fairings for my RV-6A and they fit perfectly. I am building a RV-8 and plan to use the Grove faired aluminum gear legs so I will not have to mess with fiberglass as much. I would welcome news of any supplier of intersection fairings. Steve -----Original Message----- From: Jolly [mailto:jollyd(at)ipns.com] Subject: Re: RV8-List: fairings (fwd) you are not alone...rocket makes fairings that fit...almost, but the directions are a bit confusing...at least to me...maybe if enough of us ask Van's REAL nice they will make some decent fairings for us..I, too would happily pay for some on my RV8A....ARE there any guys/gals out there in Van"s land..who love to work with fiberglass?....slightly perplexed in aurora,oregon ----- Original Message ----- From: <romeo.victor@t-online.de> Subject: RV8-List: fairings (fwd) > > > ---Ursprngliche Nachricht--- > From: <0812248383-0001@T-Online.de> > To: > Subject: fairings > > Dear RV builders, > > I am airborne with my 8 since 15.04.2003. A couple of things have to > be completed. For example all the plastic covers and fairings. I tried to fabricate gear leg fairings by myself two times, and, failed. This is not my work. Is there anybody who has a form, which he or she can borrow me to produce these items? I would pay for the shipping costs to Europe and back. > > Thanks indeed > > Yours sincerely > -- > > RV8 flying > Stephan Servatius > Untere Hauptstr. 3 > 85461 Bockhorn > Germany > > Tel. +49 (0) 8122 48383 > Fax +49 (0) 8122 902188 > Mobil +49 (0) 179 105 9749 > ------ > > -- > > > Stephan Servatius > Untere Hauptstr. 3 > 85461 Bockhorn > Germany > Tel. +49 (0) 8122 48383 > Fax +49 (0) 8122 902188 > Mobil +49 (0) 179 105 9749 > > advertising on the Matronics Forums. Share: Share photos & files with other List members. ________________________________________________________________________________
Date: Apr 30, 2003
Mike, Bob Nuckolls (bob.nuckolls(at)cox.net) who wrote The Aeroelectric Connection about wiring homebuilt airplanes and answers questions on the Matronics aerolectric list used to sell the Microair radio along with a wiring harness for it. He wrote an installation manual to go with it. I just looked over the articles on his website (aeroelectric.com) and didn't see it, but Bob is very knowledgeable and responsive to questions. He does list an article about hooking a stereo music source into the Microair's monaural intercom. Terry -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of LitewoodsJoinery(at)aol.com Subject: Re: RV8-List: Re: RV-List: Microair 760 VHF users Hi Rick. I have had my microair for some time,But unfortunately my really weak point is wiring.I have spent hours trying to hook it up,but am still having problems. Rick is here any chance you or anyone out there can advise me ,or perhaps fax me a wiring diagram that someone with my limited electronice experience could understand. Any help would be greatly appreciated. PS I will be using a separate intercom,but do want to connect the push to talk and frequency scroll buttons. Mike ________________________________________________________________________________
Subject: Re: new travel opportunities opening up
Date: Apr 30, 2003
My wife and I would like to be involved in a flight to Russia if we could find a group that is going and is willing to have us tag along. Please consider us if you are planning a trip in the next couple of years. We will need to have some time to get ready. Thanks, Dave wander(at)echoweb.net ________________________________________________________________________________
Date: Apr 30, 2003
I think your looking for the following: The article is here: http://www.aeroelectric.com/Catalog/avionics/760vhf.html And the wiriing harness is here: http://www.aeroelectric.com/Catalog/avionics/760imB.pdf Jeff ----- Original Message ----- From: "Terry Watson" <terry(at)tcwatson.com> Subject: RE: RV8-List: Re: RV-List: Microair 760 VHF users > > Mike, > > Bob Nuckolls (bob.nuckolls(at)cox.net) who wrote The Aeroelectric Connection > about wiring homebuilt airplanes and answers questions on the Matronics > aerolectric list used to sell the Microair radio along with a wiring harness > for it. He wrote an installation manual to go with it. I just looked over > the articles on his website (aeroelectric.com) and didn't see it, but Bob is > very knowledgeable and responsive to questions. > > He does list an article about hooking a stereo music source into the > Microair's monaural intercom. > > Terry > > > -----Original Message----- > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of > LitewoodsJoinery(at)aol.com > To: rv8-list(at)matronics.com > Subject: Re: RV8-List: Re: RV-List: Microair 760 VHF users > > > Hi Rick. > I have had my microair for some time,But unfortunately my really weak point > is wiring.I have spent hours trying to hook it up,but am still having > problems. > Rick is here any chance you or anyone out there can advise me ,or perhaps > fax > me a wiring diagram that someone with my limited electronice experience > could > understand. > Any help would be greatly appreciated. > PS I will be using a separate intercom,but do want to connect the push to > talk and frequency scroll buttons. > > Mike > > ________________________________________________________________________________
Date: Apr 30, 2003
Hey Mike, the URL's the guys gave you are good to check out. I would particularly go for the harness Bob has, wasn't available when I did my radio install a few years ago. All I did was lay out the schematics for the Microair, and my intercom unit, and started wiring...worked great first time around! I was sitting in my plane IN the workshop where I was finishing it, and was talking to a buddy flying about 25 miles away! You will love this little radio! Rick >From: "Jeffrey" <dump(at)relaypoint.net> >Reply-To: rv8-list(at)matronics.com >To: >Subject: Re: RV8-List: Re: RV-List: Microair 760 VHF users >Date: Wed, 30 Apr 2003 11:41:54 -0700 > > >I think your looking for the following: > >The article is here: >http://www.aeroelectric.com/Catalog/avionics/760vhf.html > >And the wiriing harness is here: >http://www.aeroelectric.com/Catalog/avionics/760imB.pdf > > >Jeff ________________________________________________________________________________
Date: Apr 30, 2003
Subject: Propeller Info
I have an RV8 about 1/2 done with 75% to go. I have ordered an engine that is an IO360 parallel valve with 10:1 pistons, dual Light Speed Plasma III ignition and Bendix injection with cold airbox intake system. My question is about propellers, however. The new Hartzell blended airfoil performs well but has lots of operational restrictions. One RV8 driver did a good operational test of the two and three blade Whirl Wind blades and got nearly identical results. Has anyone done any comparison testing with the MT or other propellers? Tom Lloyd N842TL ________________________________________________________________________________
Date: Apr 30, 2003
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Subject: Re: Propeller Info
With that heavy engine up front the WW will save you ~30 lbs....................Just remembered with high compression pistons and elect ign WW will not sell you a prop. FWIW > > >I have an RV8 about 1/2 done with 75% to go. I have ordered an engine that >is an IO360 parallel valve with 10:1 pistons, dual Light Speed Plasma III >ignition and Bendix injection with cold airbox intake system. > >My question is about propellers, however. The new Hartzell blended airfoil >performs well but has lots of operational restrictions. One RV8 driver did a >good operational test of the two and three blade Whirl Wind blades and got >nearly identical results. Has anyone done any comparison testing with the MT >or other propellers? > >Tom Lloyd N842TL > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Apr 30, 2003
I am not sure if you are aware, but Hartzell has just introduced a "new" design that they have been working on in conjunction with Vans. I opted to wait for this one, and it does not have the operating range limitation. Not sure if that helps given your particular engine/power set up (my is simply an XP-360 with an Ellison), but it did remove the restrictions for me. Scott in MEM RV-8A cowling and baffles to go Lloyd wrote: > > I have an RV8 about 1/2 done with 75% to go. I have ordered an engine that > is an IO360 parallel valve with 10:1 pistons, dual Light Speed Plasma III > ignition and Bendix injection with cold airbox intake system. > > My question is about propellers, however. The new Hartzell blended airfoil > performs well but has lots of operational restrictions. One RV8 driver did a > good operational test of the two and three blade Whirl Wind blades and got > nearly identical results. Has anyone done any comparison testing with the MT > or other propellers? > > Tom Lloyd N842TL > ________________________________________________________________________________
Subject: IO-360C1-C6
Date: Apr 30, 2003
Hello Listers... Has anyone mounted an IO-360Cx i.e. angle valve Lyc on an RV? or more specifically on an RV-8? My Lyc. is off a Piper Arrow and will require remounting the throttle body from the back of the sump/plenum (rear facing) to the front of the sump/plenum (front facing). This in itself is not a problem. I am concerned about the extra weight of the engine and the different baffling required compared with the IO-360A1-B6. Chris Stone RV-8 Wings On the wet side of Oregon <http://www.a-dec.com/> ________________________________________________________________________________
Date: May 30, 2003
Chris: I have an IO-360-C1C from an Arrow in my RV-8. I had to buy a forward facing sump and the induction tubes that go with it (these are hard to find now I hear - I paid $600 for everything - call the aviation junk yards in trade-a-plane to find what you need) (I now have a rear facing sump sitting on the shelf now if anyone needs one). The weight certainly is not a problem as this angle valve engine is what Vans put in his prototype RV8. Though, Vans recommends putting the battery in the back to move the cg rearwards - especially if you have a constant speed prop to go with. Vans sells a snorkel so that you can use the lower cowl without the front center hole in it. Vans also sells a 200hp baffle kits which work very well. Mike Sices RV8 - ready to paint -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Chris Stone Subject: RV8-List: IO-360C1-C6 Hello Listers... Has anyone mounted an IO-360Cx i.e. angle valve Lyc on an RV? or more specifically on an RV-8? My Lyc. is off a Piper Arrow and will require remounting the throttle body from the back of the sump/plenum (rear facing) to the front of the sump/plenum (front facing). This in itself is not a problem. I am concerned about the extra weight of the engine and the different baffling required compared with the IO-360A1-B6. Chris Stone RV-8 Wings On the wet side of Oregon <http://www.a-dec.com/> ________________________________________________________________________________
Date: Apr 30, 2003
> I have an RV8 about 1/2 done with 75% to go. I have ordered an engine that > is an IO360 parallel valve with 10:1 pistons, dual Light Speed Plasma III > ignition and Bendix injection with cold airbox intake system. Sounds like you've got a real hot rod there, you are right to be concerned about prop durability and compatibility. > My question is about propellers, however. The new Hartzell blended airfoil > performs well but has lots of operational restrictions. One RV8 driver did a > good operational test of the two and three blade Whirl Wind blades and got > nearly identical results. That would be me who did the testing you're referring to, and the story can be found at www.rv-8.com/Prop.htm. The story however focuses on hard data so as to be as objective as possible. What is missing to a large extent from my story are the subjective impressions on the whole thing, so here's one such personal opinion that I think applies to you: consider the Whirl Wind 200C. One of the things that I can't quantify is that the 200C is one beefy unit that was designed from the get-go to be abused in daily hard core aerobatic use. Between the McCauley hub and the robust blades the 200C looks like it would withstand quite a bit more abuse than the more diminuative appearing 150. I'm now happily flying behind the 200C and on an overall basis I prefer it to the 150, for quantifiable, but mostly non-quantifiable reasons. Now on the other side of the coin Hartzell (and MT) does extensive vibration analysis and testing for certification purposes that the smaller experimental-only companies like WW can't or don't do. That doesn't mean they don't do their engineering homework however. WW in particular has had all their designs audited by a DER and done a fair amount of static testing, all of which yielded a very clean bill of health. What's missing is the expensive in-flight dynamic stress testing, which I understand is on their agenda eventually. And it has the benefit of being 12 lbs lighter than the 72" Hartzell, which sounds like you could use with an angle valve engine. > Has anyone done any comparison testing with the MT > or other propellers? Not that I'm aware of, but I might be tempted if someone had an MT delivered to my hangar. FWIW, Randy Lervold RV-8, 306 hrs www.rv-8.com ________________________________________________________________________________
Date: Apr 30, 2003
I guess I didn't express myself well. My engine is the lighter PARALLEL VALVE engine not the 80 lb heavier ANGLE VALVE engine. The engine is actually the Superior XP360 with some modifications. The mods are: 10:1 coated pistons, dual Plasma IIIs, Bendix injection on their new plastic cold airbox sump with a forward facing inlet. It is known as an Eagle IV XP from America's Aircraft Engines, Tulsa, OK. http://www.overhaul.com/eagle4.asp AAE is one of the three shops selected by Superior to build their engine. More power at 80lb less weight than a Lyc IO360-A1A. Thanks for your input. I'll keep looking. Randy your work was what caused me to wonder about further comparison data against the new Hartzell. Your enthusiasm for the C200 is exciting. The WW sounds like the winner of my $$$ at this writing but, I still have some time to search. I would like to know of anything heard about the MT. It is a good looking prop. Tom N842TL -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Randy Lervold Subject: Re: RV8-List: Propeller Info > I have an RV8 about 1/2 done with 75% to go. I have ordered an engine that > is an IO360 parallel valve with 10:1 pistons, dual Light Speed Plasma III > ignition and Bendix injection with cold airbox intake system. Sounds like you've got a real hot rod there, you are right to be concerned about prop durability and compatibility. > My question is about propellers, however. The new Hartzell blended airfoil > performs well but has lots of operational restrictions. One RV8 driver did a > good operational test of the two and three blade Whirl Wind blades and got > nearly identical results. That would be me who did the testing you're referring to, and the story can be found at www.rv-8.com/Prop.htm. The story however focuses on hard data so as to be as objective as possible. What is missing to a large extent from my story are the subjective impressions on the whole thing, so here's one such personal opinion that I think applies to you: consider the Whirl Wind 200C. One of the things that I can't quantify is that the 200C is one beefy unit that was designed from the get-go to be abused in daily hard core aerobatic use. Between the McCauley hub and the robust blades the 200C looks like it would withstand quite a bit more abuse than the more diminuative appearing 150. I'm now happily flying behind the 200C and on an overall basis I prefer it to the 150, for quantifiable, but mostly non-quantifiable reasons. Now on the other side of the coin Hartzell (and MT) does extensive vibration analysis and testing for certification purposes that the smaller experimental-only companies like WW can't or don't do. That doesn't mean they don't do their engineering homework however. WW in particular has had all their designs audited by a DER and done a fair amount of static testing, all of which yielded a very clean bill of health. What's missing is the expensive in-flight dynamic stress testing, which I understand is on their agenda eventually. And it has the benefit of being 12 lbs lighter than the 72" Hartzell, which sounds like you could use with an angle valve engine. > Has anyone done any comparison testing with the MT > or other propellers? Not that I'm aware of, but I might be tempted if someone had an MT delivered to my hangar. FWIW, Randy Lervold RV-8, 306 hrs www.rv-8.com ________________________________________________________________________________
Date: Apr 30, 2003
I believe that Randy Lervold's work was done on the HC-C2YK-1BF/F7666A-2 propeller. However, Hartzell recently came out with C2YR-1BF/F7496 or C2YR-1BF/F7496-2 which Vans now sells. Van did an article on it in the last RVator. They claim some improvement in the restrictions as well. Check it out on Vans page. Tom Lloyd N842TL ________________________________________________________________________________
Date: Apr 30, 2003
Correction: more power and less weight than an IO360 A1B 200 hp. -----Original Message----- From: Lloyd [mailto:tlloyd6250(at)comcast.net] Subject: RE: RV8-List: Propeller Info I guess I didn't express myself well. My engine is the lighter PARALLEL VALVE engine not the 80 lb heavier ANGLE VALVE engine. The engine is actually the Superior XP360 with some modifications. The mods are: 10:1 coated pistons, dual Plasma IIIs, Bendix injection on their new plastic cold airbox sump with a forward facing inlet. It is known as an Eagle IV XP from America's Aircraft Engines, Tulsa, OK. http://www.overhaul.com/eagle4.asp AAE is one of the three shops selected by Superior to build their engine. More power at 80lb less weight than a Lyc IO360-A1B. Thanks for your input. I'll keep looking. Randy your work was what caused me to wonder about further comparison data against the new Hartzell. Your enthusiasm for the C200 is exciting. The WW sounds like the winner of my $$$ at this writing but, I still have some time to search. I would like to know of anything heard about the MT. It is a good looking prop. Tom N842TL -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Randy Lervold Subject: Re: RV8-List: Propeller Info > I have an RV8 about 1/2 done with 75% to go. I have ordered an engine that > is an IO360 parallel valve with 10:1 pistons, dual Light Speed Plasma III > ignition and Bendix injection with cold airbox intake system. Sounds like you've got a real hot rod there, you are right to be concerned about prop durability and compatibility. > My question is about propellers, however. The new Hartzell blended airfoil > performs well but has lots of operational restrictions. One RV8 driver did a > good operational test of the two and three blade Whirl Wind blades and got > nearly identical results. That would be me who did the testing you're referring to, and the story can be found at www.rv-8.com/Prop.htm. The story however focuses on hard data so as to be as objective as possible. What is missing to a large extent from my story are the subjective impressions on the whole thing, so here's one such personal opinion that I think applies to you: consider the Whirl Wind 200C. One of the things that I can't quantify is that the 200C is one beefy unit that was designed from the get-go to be abused in daily hard core aerobatic use. Between the McCauley hub and the robust blades the 200C looks like it would withstand quite a bit more abuse than the more diminuative appearing 150. I'm now happily flying behind the 200C and on an overall basis I prefer it to the 150, for quantifiable, but mostly non-quantifiable reasons. Now on the other side of the coin Hartzell (and MT) does extensive vibration analysis and testing for certification purposes that the smaller experimental-only companies like WW can't or don't do. That doesn't mean they don't do their engineering homework however. WW in particular has had all their designs audited by a DER and done a fair amount of static testing, all of which yielded a very clean bill of health. What's missing is the expensive in-flight dynamic stress testing, which I understand is on their agenda eventually. And it has the benefit of being 12 lbs lighter than the 72" Hartzell, which sounds like you could use with an angle valve engine. > Has anyone done any comparison testing with the MT > or other propellers? Not that I'm aware of, but I might be tempted if someone had an MT delivered to my hangar. FWIW, Randy Lervold RV-8, 306 hrs www.rv-8.com ________________________________________________________________________________
Date: Apr 30, 2003
Scott, I was under the same impression but according to Whirlwind that's not necessarily true. Whirlwind's web site says the series 150 prop is not recommended for high compression or electronic ignition. I e-mailed them just yesterday and they told me an IO360 with a counterweight crank and electronic ignition is okay to use and they will be more than happy to sell you a prop. The series 200 prop is okay regardless of the crank. They appear to be selling a lot of 150 props. They're backordered until October. Rick McBride In a message dated 4/30/03 6:51:30 PM Eastern Daylight Time, bilinski@kyocera-wireless.com writes: > bilinski@kyocera-wireless.com> > > With that heavy engine up front the WW will save you ~30 > lbs....................Just remembered with high compression pistons and > elect ign WW will not sell you a prop. FWIW > > > > > > > >I have an RV8 about 1/2 done with 75% to go. I have ordered an engine that > >is an IO360 parallel valve with 10:1 pistons, dual Light Speed Plasma III > >ignition and Bendix injection with cold airbox intake system. > > > >My question is about propellers, however. The new Hartzell blended airfoil > >performs well but has lots of operational restrictions. One RV8 driver did > a > >good operational test of the two and three blade Whirl Wind blades and got > >nearly identical results. Has anyone done any comparison testing with the > MT > >or other propellers? > > > >Tom Lloyd N842TL > > > > > > > Scott Bilinski > Eng dept 305 > Phone (858) 657-2536 > Pager (858) 502-5190 > > ________________________________________________________________________________
From: "PAUL ANTOINETTE" <PaulAntoinette(at)msn.com>
Subject: Tank Construction & Princeton Sender
Date: Apr 30, 2003
I am currently working wings but do not yet have access to a shop large enough to accommodate a wing jig. To not slow progress I'm doing everything I can without having to assemble ribs to spars - I.e., flaps, ailerons, spar prep. I'm now to the point where tank assembly is just about the only thing left I can accommodate. Reviewing the instructions does not indicate any obvious requirement for having the wings in the jig and skinned prior to assembling the tanks. Before I proceed I'd like to know if I'm missing anything. Thoughts? My particular wing kit is all prepunched. Additionally - I'm installing Princeton Capacitance fuel senders as sold by Grand Rapids. Anyone have experience installing these senders? Is their fit compatible with the standard float type sender? Thank you for any assistance. mailto:paulantoinette(at)msn.com ________________________________________________________________________________
Date: May 01, 2003
we have installed an hio( helicopter ) 360 angle valve and machicned the sump so injection is forward no problem whatsoever and baffle kit works without problem had to modify somewhat the glasfibre airduct we bought from vans regards terje kobro-norway > -----Original Message----- > From: Chris Stone [mailto:Chris.Stone@a-dec.com] > Sent: 1. mai 2003 01:12 > To: rv8-list(at)matronics.com > Subject: RV8-List: IO-360C1-C6 > > > > Hello Listers... > > Has anyone mounted an IO-360Cx i.e. angle valve Lyc on an RV? or more > specifically on an RV-8? > My Lyc. is off a Piper Arrow and will require remounting the throttle > body from the back of the sump/plenum (rear facing) to the > front of the > sump/plenum (front facing). This in itself is not a problem. I am > concerned about the extra weight of the engine and the different > baffling required compared with the IO-360A1-B6. > > > Chris Stone > RV-8 Wings > On the wet side of Oregon > <http://www.a-dec.com/> > > > ========== > ========== > ========== > ========== > > > > > ________________________________________________________________________________
Date: May 01, 2003
Your right!! I hate giving out bad info. They wont sell you a prop on a modified engine UNLESS it has a counter weighted crank. > >Scott, > >I was under the same impression but according to Whirlwind that's not >necessarily true. Whirlwind's web site says the series 150 prop is not >recommended for high compression or electronic ignition. I e-mailed them >just yesterday and they told me an IO360 with a counterweight crank and >electronic ignition is okay to use and they will be more than happy to sell >you a prop. The series 200 prop is okay regardless of the crank. They >appear to be selling a lot of 150 props. They're backordered until October. > >Rick McBride > >In a message dated 4/30/03 6:51:30 PM Eastern Daylight Time, >bilinski@kyocera-wireless.com writes: > >> bilinski@kyocera-wireless.com> >> >> With that heavy engine up front the WW will save you ~30 >> lbs....................Just remembered with high compression pistons and >> elect ign WW will not sell you a prop. FWIW >> >> >> > >> > >> >I have an RV8 about 1/2 done with 75% to go. I have ordered an engine that >> >is an IO360 parallel valve with 10:1 pistons, dual Light Speed Plasma III >> >ignition and Bendix injection with cold airbox intake system. >> > >> >My question is about propellers, however. The new Hartzell blended airfoil >> >performs well but has lots of operational restrictions. One RV8 driver did >> a >> >good operational test of the two and three blade Whirl Wind blades and got >> >nearly identical results. Has anyone done any comparison testing with the >> MT >> >or other propellers? >> > >> >Tom Lloyd N842TL >> > >> > >> >> >> Scott Bilinski >> Eng dept 305 >> Phone (858) 657-2536 >> Pager (858) 502-5190 >> >> > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: May 02, 2003
Subject: Re: e: RV8-List:Jigs
Hi All. Well,just received my empanage kit for the RV 8 I am trying to find out about the jig and future jigs which I will need. Do any of you out there know if there are plans available,or at least dimensions which should be used. As you can all imagine,I am very excited about starting,but really want to get everything ready for construction before I start. Thank you in advance for any help. You can be sure that there will be many more questions :) I would also like to thank those of you who kindly helped me out with the wiring for my Microair 760.... Mike. ________________________________________________________________________________
Date: May 02, 2003
Subject: pics of RV8A airplane paint job
al(at)vtc.net, HWDJAD(at)aol.com, rdugas(at)bayou.com, Elrod3794(at)aol.com, jandgf(at)iamerica.net, jdgummere(at)dow.com, bobhalsell(at)yahoo.com, bobby.hargrave(at)att.net, Travlnbus(at)aol.com, cjohnson(at)jpjcpa.com, biff(at)mchsi.com, KellyRHoward(at)aol.com, PSILeD(at)aol.com, lois_memaw(at)yahoo.com, SIDLOVE(at)INU.NET, jeffnaul(at)msn.com, rentmoor(at)rochelle.net, capetrus(at)hotmail.com, Dwpetrus(at)aol.com, PRYORE(at)aol.com, rrogersjr(at)jam.rr.com, crogers1(at)jam.rr.com, RV-LIST(at)matronics.com, RV8-LIST(at)matronics.com, DerFlieger(at)aol.com, miketerry(at)kjlo.com, info(at)vansaircraft.com, WALLB(at)OIBANK.COM The paint and graphics were completed today. Check out the attached airplane. Wayne Petrus RV8A West Monroe, LA ________________________________________________________________________________
Date: May 03, 2003
Subject: [ Greg Hunsicker ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Greg Hunsicker Subject: 4 Ship Formation http://www.matronics.com/photoshare/gh2538@cjnetworks.com.05.03.03/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: May 03, 2003
Subject: Re: RV-8 Tail & Wing Jig
Mike, and other "newbies" scratching their heads about building jigs and fearing their plane will end up flying sideways: Van's plans call for the wing jig to be at least 115 inches long (it is in Van's instructions). The actual wing spar is 109 inches long on the plans, leaving space for fabricating wing spar attachment brackets. Van's plans recommend that this larger jig can be built early to use for the tail section also. I bought about a dozen kiln dried 8 foot 2x4 studs at Home Depot. I pawed through the stack and got them to unband a second stack so I could find the straightest ones with fewest knots. They were pretty helpful when I told them it was for a jig to built an actual airplane. I glued (contractors light yellow wood glue) and screwed (deck screws) three studs together to make a 4x6 post at either end. Since the steel rafters in my hanger were about 12 feet above the floor, I put two of the 2x4 studs on the outside of the three stud "sandwich" at the bottom end to go against the floor and cut a four to five foot piece to go in the center of the bottom studs so the full 8 foot stud in the center would reach up to adjust and attach to the rafter using a large C-clamp. Staggering the joints made the 4x6 post stronger, and having three separate pieces of wood glued and screwed together resists warpage (not to mention being cheaper). For the center horizontal beam I glued and screwed two 2x4 studs together again staggering the joints to make the 115 inch span. I put the 4 inch sides horizontal with the glued seam running across the upper edge. Since mine still took a bend of a 1/4 inch or so when I later drew a straight center line, yet remained perfectly level across the top, this is probably the better orientation rather than having the flat 4 inch face on top. I used lag bolts to screw a steel L-bracket to the bottom of each 4x6 inch post down against the floor, then violated my airport hanger lease by drilling a hole into the concrete floor and inserting one special bolt assembly into the hole at each end that the jig posts' L-bracket fit over to secure the jig post to the floor with a nut and lock washer. I didn't want it to shift if bumped into at the bottom. I used smaller metal L-brackets under the horizontal 4x4 beam that attached to either end using smaller deck wood screws. I screwed one end on to the vertical 4x6 upright post, then temporarily C-clamped the other end onto the other 4x6 upright post using a level. Then I got on a ladder and adjusted the tops of the two 4x6 vertical posts using a level before permanently tightening the C-clamps holding the upper stud to the rafter. With the two vertical 4x6 posts secure and level vertically, I levelled the horizontal 4x6 beam and screwed the second end to the 4x6 vertical posts. The horizontal post can be raised and lowered by removing the wood screws and then screwing them back into the 4x6 post at a different level. When the tail is done the horizontal piece will be removed. In three years of seasonal changes, my vertical posts are still dead straight with a level. My horizontal piece remained perfectly level over the year or so I was working on my tail section. Gluing and screwing multiple smaller studs together seems to avoid warpage that a single board will suffer. Pete Cowper (RV-8 #81139) Visalia Municipal Airport - California N666PC reserved ________________________________________________________________________________
Subject: Parachutes for Sale
Date: May 05, 2003
Two new strong Parachutes for sale. $1200.00 each new. One back and One seat. $600.00 each plus shipping and handling. E-mail salned(at)msn.com ________________________________________________________________________________
Subject: RV-8 QB gear leg drilling
Date: May 05, 2003
I am about to drill holes for the gear legs on my RV-8 Does anyone have sugestions or warnings on this procedure?? GEORGE H. INMAN ghinman(at)attcanada.ca CELL 204 799 7062 HOME 204 287 8334 ________________________________________________________________________________
Date: May 05, 2003
Subject: EDM-900
RV-8 builders. Has anyone out there purchased or installed the new J.P.Instruments, EDM-900, in an RV-8 yet? Glenn Broomell ________________________________________________________________________________
Date: May 05, 2003
Subject: EXPERMENTAL label location
Where is everyone placing the EXPERMENTAL labelon the 8? Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: May 05, 2003
Subject: Re: EXPERMENTAL label location
Mine is on both insides of the canopy skirt opposite the pax. Rob Miller N262RM -8 "Bad Cat" 57 hours --- Scott Bilinski <bilinski@kyocera-wireless.com> wrote: > <bilinski@kyocera-wireless.com> > > Where is everyone placing the EXPERMENTAL labelon the 8? > > > Scott Bilinski > Eng dept 305 > Phone (858) 657-2536 > Pager (858) 502-5190 > > > > > > __________________________________ http://search.yahoo.com ________________________________________________________________________________
Subject: EDM-900
Date: May 05, 2003
Hi Glenn, You are probably going to get a few responses like this one from people who don't want to do business with JPI. Go to the Matronics RV list archives and search for JPI to read about what they tried to do to Matronics a few years ago. I did see the new electronic panel a few months ago and it looked awfully nice. It seemed very readable, at least in the display. Terry RV-8A with Bluemountain EFIS-one on order Seattle RV-8 builders. Has anyone out there purchased or installed the new J.P.Instruments, EDM-900, in an RV-8 yet? ________________________________________________________________________________
Date: May 05, 2003
I put one inside along the canopy skirt, right side. FAA bought it. On Mon, 2003-05-05 at 13:00, Scott Bilinski wrote: > > Where is everyone placing the EXPERMENTAL labelon the 8? > > > Scott Bilinski > Eng dept 305 > Phone (858) 657-2536 > Pager (858) 502-5190 > > -- Greg V. Miller ________________________________________________________________________________
From: "Shane Summerhays" <ssummerhays(at)attbi.com>
Subject: -8 quickbuild gearleg drilling.
Date: May 06, 2003
George, my father and I have just completed drilling and fitting the gearlegs on our -8 and I will tell you it is quite a job. I would suggest you try and clamp the 803 down to use it as a drill guide. In our situation the 803 block rode up the drill slightly and it made our hole a little out of square to the longeron. we then cut a bushing and put it in the hole and used the inside of the bushing as a drill guide for a 1/4 inch bolt which we were able to tighten down then we increased the size to the 3/8 required. All of the other holes went well. The last bit of work was getting the clearance the plans require of .030 between the wear plate and the face of the 803 block. To get the block out you must disassemble the entire gear leg grind down the block and reassemble,torque and check the clearance with a feeler. We must have disassembled our gear leg about 6 times before we got the clearance correct. I hope this helps Shane Summerhays slc rv-6 super-8? ________________________________________________________________________________
Subject: super-8
Date: May 06, 2003
Has anyone out there built or is building a super-8? I am curious what steps were taken to convert your bird? Please post I am interested in your suggestions? You may aslo contact me via email ssummerhays(at)metacrawler.com shane summerhays rv-6 super-8? ________________________________________________________________________________
Date: May 06, 2003
Subject: Re: super-8
What is a super 8? > >Has anyone out there built or is building a super-8? I am curious what >steps were taken to convert your bird? Please post I am interested in >your suggestions? You may aslo contact me via email >ssummerhays(at)metacrawler.com >shane summerhays >rv-6 super-8? Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Subject: super-8
Date: May 06, 2003
That would be a 8 with a 0-540 in it. There are 4 in Indy and 2 in Louisville. All were helped along by John Marshall the Indy RV guru! -----Original Message----- From: Scott Bilinski [mailto:bilinski@kyocera-wireless.com] Subject: Re: RV8-List: super-8 <bilinski@kyocera-wireless.com> What is a super 8? > >Has anyone out there built or is building a super-8? I am curious what >steps were taken to convert your bird? Please post I am interested in >your suggestions? You may aslo contact me via email >ssummerhays(at)metacrawler.com >shane summerhays >rv-6 super-8? Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: May 06, 2003
Subject: RV-8A project for sale
Fuselage and wings complete. Canopy on and glassed in. Engine (IO-360) and prop (Hartzell Constant Speed), both with 61 hours since new, mounted. Lower cowl fit. Will sell airframe and engine seperate. Looking for offer. N188rv(at)aol.com for more info or pictures. Stan Mehrhoff ________________________________________________________________________________
Date: May 06, 2003
Subject: Super-8 details
So, I, and I think others would like to know more about the Super 8. How much does it weigh? How do you get a forward CG? What is the top speed? What is the climb rate? Please add anything else of interest. Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
From: "Crosley, Rich" <RCROSLEY(at)HRTEXTRON.TEXTRON.COM>
Subject: re: rv8-list: pic on rv8a paint job
Date: May 06, 2003
Wayne, Beautiful paint job. Is the graphic paint or decal? If decal, how hard was it to put on? Rich Crosley RV-8 ________________________________________________________________________________
Date: May 06, 2003
Subject: Final Cruise Performance Results
Hi Listers! After six years of building, and six months of testing, finishing, painting, modifying, checking, adjusting, etc. I'm, well, hmmm, DONE! It's Official. The details RV-8 New Lyc. O-360 A1A Hartzell Grove Aero SL Gearlegs 1100 lbs. empty Full Throttle, 1300 EGT, 19.4 MP, 2500 RPM ===== 65% Power/201.5 MPH How does this compare to what you guys are seeing?? Rob Miller -8 N262RM "Bad Cat" 58 hours __________________________________ http://search.yahoo.com ________________________________________________________________________________
Date: May 06, 2003
Subject: Re: Final Cruise Performance Results @ 11.5K
--- Rob Miller wrote: > > Hi Listers! > > After six years of building, and six months of testing, finishing, > painting, modifying, checking, adjusting, etc. I'm, well, hmmm, DONE! > It's Official. > > The details > > RV-8 > New Lyc. O-360 A1A > Hartzell > Grove Aero SL Gearlegs > 1100 lbs. empty > > > Full Throttle @ 11.5 MSL, 1300 EGT, 19.4 MP, 2500 RPM ===== 65% Power/201.5 MPH > > How does this compare to what you guys are seeing?? > > Rob Miller > -8 N262RM "Bad Cat" 58 hours > > __________________________________ > http://search.yahoo.com > > > > > > __________________________________ http://search.yahoo.com ________________________________________________________________________________
Date: May 06, 2003
Subject: Re: re: rv8-list: pic on rv8a paint job
It was painted by a local airbrush artist. He has a web site www.joeyhutsonart.com Thanks, Wayne Petrus ________________________________________________________________________________
Date: May 06, 2003
Mine is aligned with the rear canopy rail on the centerline. That's where Van puts his too. Ed Perry ----- Original Message ----- From: "Scott Bilinski" <bilinski@kyocera-wireless.com> Subject: RV8-List: EXPERMENTAL label location <bilinski@kyocera-wireless.com> > > Where is everyone placing the EXPERMENTAL labelon the 8? > > > Scott Bilinski > Eng dept 305 > Phone (858) 657-2536 > Pager (858) 502-5190 > > ________________________________________________________________________________
Date: May 06, 2003
Subject: Re: RV-8 QB gear leg drilling
GEORGE INMAN wrote: > > I am about to drill holes for the gear legs > on my RV-8 > Does anyone have sugestions or > warnings on this procedure?? > > GEORGE H. INMAN > ghinman(at)attcanada.ca > CELL 204 799 7062 > HOME 204 287 8334 > George - It's essential that the gear "box" nestle snugly against the inner skin before drilling, or else your gear leg might not be properly positioned to allow the outboard retainer blocks meet the curvature of the gear leg where they should. I'm sorry I can't use part numbers - my plans are at the hangar. Like Van says - think, then drill! Hope this helps Don Miller ________________________________________________________________________________
Date: May 06, 2003
Scott Bilinski wrote: > > Where is everyone placing the EXPERMENTAL labelon the 8? > > Scott Bilinski > Eng dept 305 > Phone (858) 657-2536 > Pager (858) 502-5190 > Hi Scott - After much thought, I placed mine under the right canopy sill in the back cockpit. The passenger can't miss it when he/she climbs in, and it's out of the way . . . Don Miller ________________________________________________________________________________
Date: May 06, 2003
Rob Miller wrote: > > Hi Listers! > > After six years of building, and six months of testing, finishing, > painting, modifying, checking, adjusting, etc. I'm, well, hmmm, DONE! > It's Official. > > The details > > RV-8 > New Lyc. O-360 A1A > Hartzell > Grove Aero SL Gearlegs > 1100 lbs. empty > > Full Throttle, 1300 EGT, 19.4 MP, 2500 RPM ===== 65% Power/201.5 MPH > > How does this compare to what you guys are seeing?? > > Rob Miller > -8 N262RM "Bad Cat" 58 hours > > __________________________________ > http://search.yahoo.com > Hi Rob I got N638DM certified on March 20 and flew it on March 23. Couldn't be happier. 638DM is similar to your -8; O 360 A1A, Hartzell C/S, IFR certified, 1127 empty, 205 mph @ 70% power @ 8,000 ft. Congratulations Don Miller ________________________________________________________________________________
Subject: POH
Date: May 07, 2003
Hi RVers, I am looking for performance data for my 8. I need them to create a POH for the german aviation authorities. Who has or knows an address to get them? -- RV8 Flying 2:34 h Stephan Servatius Untere Hauptstr. 3 85461 Bockhorn Germany Tel. +49 (0) 8122 48383 Fax +49 (0) 8122 902188 Mobil +49 (0) 179 105 9749 ________________________________________________________________________________
Date: May 08, 2003
Subject: E: RV8-List:Jigs
Just read your instructions. There are no jigs required. -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of LitewoodsJoinery(at)aol.com Subject: Re: RV8-List:Jigs Hi All. Well,just received my empanage kit for the RV 8 I am trying to find out about the jig and future jigs which I will need. Do any of you out there know if there are plans available,or at least dimensions which should be used. As you can all imagine,I am very excited about starting,but really want to get everything ready for construction before I start. Thank you in advance for any help. You can be sure that there will be many more questions :) I would also like to thank those of you who kindly helped me out with the wiring for my Microair 760.... Mike. ________________________________________________________________________________
Date: May 08, 2003
With prepunched holes jigs not needed but you might build the wing jig and modify it to hold Horizontal Stabilizer during fabrication. Don ----- Original Message ----- From: "Lloyd" <tlloyd6250(at)comcast.net> Subject: RE: RV8-List:Jigs > > Just read your instructions. There are no jigs required. > > -----Original Message----- > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of > LitewoodsJoinery(at)aol.com > To: rv8-list(at)matronics.com > Subject: Re: RV8-List:Jigs > > > Hi All. > Well,just received my empanage kit for the RV 8 > I am trying to find out about the jig and future jigs which I will need. > Do any of you out there know if there are plans available,or at least > dimensions which should be used. > As you can all imagine,I am very excited about starting,but really want to > get everything ready for construction before I start. > Thank you in advance for any help. > You can be sure that there will be many more questions :) > I would also like to thank those of you who kindly helped me out with the > wiring for my Microair 760.... > > Mike. > > ________________________________________________________________________________
Subject: Fuselage jig for free and rollbar dimensions
Date: May 10, 2003
Hi listers , Does anybody know what the correct dimensions of the roll bar (wd814) should be ? Mine measures 24"between the two little inboard tabs that point down. My fuselage measures 32" at that station. Both figures seem too exact to be chance but I am guessing that the roll bar is the one that needs to be adjusted. I could not find any dimensions on the plans .I should also add that my kit is an early pre powder coated one .(#255) If any one needs a fuselage jig in the B.C. Kelowna area I have one for the asking. Thanks.Colin. ________________________________________________________________________________
Date: May 10, 2003
Subject: Modified 7
name=Member[1].htm PEhUTUw+DQo8SEVBRD4NCjxUSVRMRT5BTUEgUHJvZ3JhbXMgRm9yIE1lbWJlcnM8L1RJVExF Pg0KPHNjcmlwdCBsYW5ndWFnZT0iSmF2YXNjcmlwdCI+DQpmdW5jdGlvbiBvcGVuX3dpbmRv dyhhcmcpew0KCW9wZW4oYXJnLCd3aW5kb3cnLCdzY3JvbGxiYXJzLHJlc2l6ZWFibGU9eWVz JykNCn0NCjwvc2NyaXB0Pg0KPC9oZWFkPg0KPGJvZHkgYmdjb2xvcj0iI0ZBRjdFNiI+PENF TlRFUj4NCjxUQUJMRSBDRUxMU1BBQ0lORz00IENFTExQQURESU5HPTQ+DQo8VFIgQUxJR049 Q0VOVEVSIFZBTElHTj1NSURETEU+DQo8VEQgQUxJR049Q0VOVEVSIFZBTElHTj10b3AgQ09M U1BBTj0xIFJPV1NQQU49MT4NCjxwIGFsaWduPSJjZW50ZXIiPg0KPGltZyBib3JkZXI9IjAi IHNyYz0iaHR0cDovL3d3dy5tb2RlbGFpcmNyYWZ0Lm9yZy9JbWFnZXMvbG9nb3JlZC5naWYi Pg0KPGJyPg0KPGJyPg0KPGEgaHJlZj0iaHR0cDovL3d3dy5tb2RlbGFpcmNyYWZ0Lm9yZy9U T0NzcGxhc2guaHRtIj5UYWJsZSBvZiBDb250ZW50czwvYT4NCjxicj4NCjxicj4NCjxhcHBs ZXQgY29kZT0ibmF2cHJvLmNsYXNzIiBjb2RlYmFzZT0iaHR0cDovL3d3dy5tb2RlbGFpcmNy YWZ0Lm9yZy9hcHBsZXQvbmF2cHJvIiB3aWR0aD0xMzAgaGVpZ2h0PTUyMCBNQVlTQ1JJUFQ+ DQo8cGFyYW0gbmFtZT1mb250IHZhbHVlPSJBcmlhbCxIZWx2ZXRpY2EsR2VuZXZhLFN3aXNz Ij4NCjxwYXJhbSBuYW1lPWZvbnRzdHlsZSB2YWx1ZT0iMSI+DQo8cGFyYW0gbmFtZT1zaXpl IHZhbHVlPSIxMiI+DQo8cGFyYW0gbmFtZT10YXJnZXQgdmFsdWU9InJpZ2h0Ij4NCg0KPHBh cmFtIG5hbWU9Ymdjb2xvciB2YWx1ZT0iRkFGN0U2Ij4NCjxwYXJhbSBuYW1lPWJ1dHRvbmNv bG9yIHZhbHVlPSJGRkZGRkYiPg0KPHBhcmFtIG5hbWU9YnV0dG9uc2hhcGUgdmFsdWU9InRy aWFuZ2xlIj4NCjxwYXJhbSBuYW1lPWJ1dHRvbiB2YWx1ZT0ieWVzIj4NCjxwYXJhbSBuYW1l PWxpbmVicmVhayB2YWx1ZT0ifCI+DQoNCjxwYXJhbSBuYW1lPWxldmVsIHZhbHVlPSIxMiI+ DQoNCjxwYXJhbSBuYW1lPWhtY29sb3IxIHZhbHVlPSIwMDAwNkEiPg0KPHBhcmFtIG5hbWU9 bm1jb2xvcjEgdmFsdWU9IkRFQkI4NyI+DQo8cGFyYW0gbmFtZT1oZm9udGNvbG9yMSB2YWx1 ZT0iRkZGRkZGIj4NCjxwYXJhbSBuYW1lPW5mb250Y29sb3IxIHZhbHVlPSIwMDAwMDAiPg0K DQo8cGFyYW0gbmFtZT1obWNvbG9yMiB2YWx1ZT0iNDgzRDhCIj4NCjxwYXJhbSBuYW1lPW5t Y29sb3IyIHZhbHVlPSI0ODNEOEIiPg0KPHBhcmFtIG5hbWU9aGZvbnRjb2xvcjIgdmFsdWU9 IkZGRjA4NyI+DQo8cGFyYW0gbmFtZT1uZm9udGNvbG9yMiB2YWx1ZT0iRkZGRkZGIj4NCg0K PHBhcmFtIG5hbWU9aG1jb2xvcjMgdmFsdWU9IkZGRjBBNyI+DQo8cGFyYW0gbmFtZT1ubWNv bG9yMyB2YWx1ZT0iOTU5Q0ZGIj4NCjxwYXJhbSBuYW1lPWhmb250Y29sb3IzIHZhbHVlPSIw MDAwNkEiPg0KPHBhcmFtIG5hbWU9bmZvbnRjb2xvcjMgdmFsdWU9IkZGRkZGRiI+DQoNCjxw YXJhbSBuYW1lPW1lbnUxIHZhbHVlPSJBYm91dCBBTUEiPg0KPHBhcmFtIG5hbWU9bWVudTFp MSB2YWx1ZT0iV2hhdCdzIE5ldyI+DQo8cGFyYW0gbmFtZT1tZW51MWkxdXJsIHZhbHVlPSJo dHRwOi8vd3d3Lm1vZGVsYWlyY3JhZnQub3JnL21haW4uaHRtIj4NCjxwYXJhbSBuYW1lPW1l bnUxaTF0YXJnZXQgdmFsdWU9Il9zZWxmIj4NCjxwYXJhbSBuYW1lPW1lbnUxaTIgdmFsdWU9 Ikd1ZXN0Ym9vayI+DQo8cGFyYW0gbmFtZT1tZW51MWkydXJsIHZhbHVlPSJodHRwOi8vd3d3 Lm1vZGVsYWlyY3JhZnQub3JnL2d1ZXN0Lmh0bSI+DQo8cGFyYW0gbmFtZT1tZW51MWkydGFy Z2V0IHZhbHVlPSJfYmxhbmsiPg0KPHBhcmFtIG5hbWU9bWVudTFpMyB2YWx1ZT0iV2hhdCBp cyBBTUE/Ij4NCjxwYXJhbSBuYW1lPW1lbnUxaTNpMSB2YWx1ZT0iSW50cm9kdWN0aW9uIj4N CjxwYXJhbSBuYW1lPW1lbnUxaTNpMXVybCB2YWx1ZT0iaHR0cDovL3d3dy5tb2RlbGFpcmNy YWZ0Lm9yZy9JbnRyby5odG0iPg0KPHBhcmFtIG5hbWU9bWVudTFpM2kxdGFyZ2V0IHZhbHVl PSJfc2VsZiI+DQo8cGFyYW0gbmFtZT1tZW51MWkzaTIgdmFsdWU9Ik1pc3Npb24gU3RhdGVt ZW50Ij4NCjxwYXJhbSBuYW1lPW1lbnUxaTNpMnVybCB2YWx1ZT0iaHR0cDovL3d3dy5tb2Rl bGFpcmNyYWZ0Lm9yZy92aXNpb24uaHRtIj4NCjxwYXJhbSBuYW1lPW1lbnUxaTNpMnRhcmdl dCB2YWx1ZT0iX3NlbGYiPg0KPHBhcmFtIG5hbWU9bWVudTFpNCB2YWx1ZT0iRXhlY3V0aXZl fENvdW5jaWwiPg0KPHBhcmFtIG5hbWU9bWVudTFpNGkxIHZhbHVlPSJDb250YWN0IE9mZmlj ZXJzIj4NCjxwYXJhbSBuYW1lPW1lbnUxaTRpMXVybCB2YWx1ZT0iaHR0cDovL3d3dy5tb2Rl bGFpcmNyYWZ0Lm9yZy9NYWlsZGlyZWMuaHRtIj4NCjxwYXJhbSBuYW1lPW1lbnUxaTRpMXRh cmdldCB2YWx1ZT0iX3NlbGYiPg0KPHBhcmFtIG5hbWU9bWVudTFpNGkyIHZhbHVlPSJNZWV0 aW5nIFNjaGVkdWxlIj4NCjxwYXJhbSBuYW1lPW1lbnUxaTRpMnVybCB2YWx1ZT0iaHR0cDov L3d3dy5tb2RlbGFpcmNyYWZ0Lm9yZy9FQy8wMWV4ZWNzY2hlZHVsZS5odG0iPg0KPHBhcmFt IG5hbWU9bWVudTFpNGkydGFyZ2V0IHZhbHVlPSJfc2VsZiI+DQo8cGFyYW0gbmFtZT1tZW51 MWk0aTMgdmFsdWU9IkVDIE5ld3MgYW5kfEluZm9ybWF0aW9uIj4NCjxwYXJhbSBuYW1lPW1l bnUxaTRpM3VybCB2YWx1ZT0iaHR0cDovL3d3dy5tb2RlbGFpcmNyYWZ0Lm9yZy9FYy9FQ05l d3MuaHRtIj4NCjxwYXJhbSBuYW1lPW1lbnUxaTRpM3RhcmdldCB2YWx1ZT0iX3NlbGYiPg0K PHBhcmFtIG5hbWU9bWVudTFpNSB2YWx1ZT0iQU1BIE5ld3MgYW5kfEluZm9ybWF0aW9uIj4N CjxwYXJhbSBuYW1lPW1lbnUxaTV1cmwgdmFsdWU9Imh0dHA6Ly93d3cubW9kZWxhaXJjcmFm dC5vcmcvTmV3cy9BTUFuZXdzLmh0bSI+DQo8cGFyYW0gbmFtZT1tZW51MWk1dGFyZ2V0IHZh bHVlPSJfc2VsZiI+DQo8cGFyYW0gbmFtZT1tZW51MWk2IHZhbHVlPSJTcGVjaWFsIEludGVy ZXN0fEdyb3VwcyI+DQo8cGFyYW0gbmFtZT1tZW51MWk2dXJsIHZhbHVlPSJodHRwOi8vd3d3 Lm1vZGVsYWlyY3JhZnQub3JnL1NpZy5odG0iPg0KPHBhcmFtIG5hbWU9bWVudTFpNnRhcmdl dCB2YWx1ZT0iX3NlbGYiPg0KPHBhcmFtIG5hbWU9bWVudTFpNyB2YWx1ZT0iU3VwcGx5ICZh bXA7IFNlcnZpY2UiPg0KPHBhcmFtIG5hbWU9bWVudTFpN2kxIHZhbHVlPSJTaG9wIEFNQSI+ DQo8cGFyYW0gbmFtZT1tZW51MWk3aTF1cmwgdmFsdWU9Imh0dHA6Ly93d3cubW9kZWxhaXJj cmFmdC5vcmcvU3VwcGx5L3NzYWQwMzAxL25ld3llYXJhZC5odG0iPg0KPHBhcmFtIG5hbWU9 bWVudTFpN2kxdGFyZ2V0IHZhbHVlPSJfYmxhbmsiPg0KPHBhcmFtIG5hbWU9bWVudTFpN2ky IHZhbHVlPSJQbGFucyI+DQo8cGFyYW0gbmFtZT1tZW51MWk3aTJ1cmwgdmFsdWU9Imh0dHA6 Ly93d3cubW9kZWxhaXJjcmFmdC5vcmcvcGxhbnMvcGxhbnNuZXcuaHRtIj4NCjxwYXJhbSBu YW1lPW1lbnUxaTdpMnRhcmdldCB2YWx1ZT0iX2JsYW5rIj4NCjxwYXJhbSBuYW1lPW1lbnUx aTdpMyB2YWx1ZT0iTWVtYmVyc2hpcHxTZXJ2aWNlcyBhbmR8UHJvZHVjdCBHdWlkZSI+DQo8 cGFyYW0gbmFtZT1tZW51MWk3aTN1cmwgdmFsdWU9Imh0dHA6Ly93d3cubW9kZWxhaXJjcmFm dC5vcmcvU3VwcGx5L0NhdGFsb2cuaHRtIj4NCjxwYXJhbSBuYW1lPW1lbnUxaTdpM3Rhcmdl dCB2YWx1ZT0iX2JsYW5rIj4NCjxwYXJhbSBuYW1lPW1lbnUxaTggdmFsdWU9IkVtcGxveW1l bnR8T3Bwb3J0dW5pdGllcyI+DQo8cGFyYW0gbmFtZT1tZW51MWk4dXJsIHZhbHVlPSJodHRw Oi8vd3d3Lm1vZGVsYWlyY3JhZnQub3JnL2hyL2hyLmh0bSI+DQo8cGFyYW0gbmFtZT1tZW51 MWk4dGFyZ2V0IHZhbHVlPSJfc2VsZiI+DQo8cGFyYW0gbmFtZT1tZW51MWk5IHZhbHVlPSJJ bnRlcm5hdGlvbmFsfEFlcm9tb2RlbGluZ3xDZW50ZXIiPg0KPHBhcmFtIG5hbWU9bWVudTFp OWkxIHZhbHVlPSJOZXcgSFEgQnVpbGRpbmciPg0KPHBhcmFtIG5hbWU9bWVudTFpOWkxdXJs IHZhbHVlPSJodHRwOi8vd3d3Lm1vZGVsYWlyY3JhZnQub3JnL0NvbXAvSUFDY29uc3RydWN0 aW9uLmh0bSI+DQo8cGFyYW0gbmFtZT1tZW51MWk5aTF0YXJnZXQgdmFsdWU9Il9ibGFuayI+ DQo8cGFyYW0gbmFtZT1tZW51MWk5aTIgdmFsdWU9IjIwMDEgU2NoZWR1bGUiPg0KPHBhcmFt IG5hbWU9bWVudTFpOWkydXJsIHZhbHVlPSJodHRwOi8vd3d3Lm1vZGVsYWlyY3JhZnQub3Jn L0NvbXAvMjAwMHNpdGVzY2hkLmh0bSI+DQo8cGFyYW0gbmFtZT1tZW51MWk5aTJ0YXJnZXQg dmFsdWU9Il9ibGFuayI+DQo8cGFyYW0gbmFtZT1tZW51MWk5aTMgdmFsdWU9IlNpdGUgSW5m b3JtYXRpb24iPg0KPHBhcmFtIG5hbWU9bWVudTFpOWkzdXJsIHZhbHVlPSJodHRwOi8vd3d3 Lm1vZGVsYWlyY3JhZnQub3JnL1NpdGUvU2l0ZS5odG0iPg0KPHBhcmFtIG5hbWU9bWVudTFp OWkzdGFyZ2V0IHZhbHVlPSJfc2VsZiI+DQoNCg0KPHBhcmFtIG5hbWU9bWVudTIgdmFsdWU9 Ik1lbWJlcnNoaXB8U2VydmljZXMiPg0KPHBhcmFtIG5hbWU9bWVudTJpMSB2YWx1ZT0iQmVu ZWZpdHMgT3ZlcnZpZXciPg0KPHBhcmFtIG5hbWU9bWVudTJpMXVybCB2YWx1ZT0iaHR0cDov L3d3dy5tb2RlbGFpcmNyYWZ0Lm9yZy9NZW0vT3ZlcnZpZXcuaHRtIj4NCjxwYXJhbSBuYW1l PW1lbnUyaTF0YXJnZXQgdmFsdWU9Il9zZWxmIj4NCjxwYXJhbSBuYW1lPW1lbnUyaTIgdmFs dWU9IlByb2dyYW1zfGZvciBNZW1iZXJzIj4NCjxwYXJhbSBuYW1lPW1lbnUyaTJpMSB2YWx1 ZT0iUHJvZ3JhbXN8Zm9yIE1lbWJlcnMiPg0KPHBhcmFtIG5hbWU9bWVudTJpMmkxdXJsIHZh bHVlPSJodHRwOi8vd3d3Lm1vZGVsYWlyY3JhZnQub3JnL01lbS9NZW1iZXIuaHRtIj4NCjxw YXJhbSBuYW1lPW1lbnUyaTJpMXRhcmdldCB2YWx1ZT0iX3NlbGYiPg0KPHBhcmFtIG5hbWU9 bWVudTJpMmkyIHZhbHVlPSJSQyBGbGlnaHR8SW5zdHJ1Y3Rpb24iPg0KPHBhcmFtIG5hbWU9 bWVudTJpMmkydXJsIHZhbHVlPSJodHRwOi8vd3d3Lm1vZGVsYWlyY3JhZnQub3JnL3Byb2dy YW1zL1JDZmxpZ2h0aW5zdHIuaHRtIj4NCjxwYXJhbSBuYW1lPW1lbnUyaTJpMnRhcmdldCB2 YWx1ZT0iX2JsYW5rZiI+DQo8cGFyYW0gbmFtZT1tZW51MmkyaTMgdmFsdWU9IkxlYWRlciBD bHVicyI+DQo8cGFyYW0gbmFtZT1tZW51MmkyaTN1cmwgdmFsdWU9Imh0dHA6Ly93d3cubW9k ZWxhaXJjcmFmdC5vcmcvcHJvZ3JhbXMvbGVhZGVyY2x1YnMuaHRtIj4NCjxwYXJhbSBuYW1l PW1lbnUyaTJpM3RhcmdldCB2YWx1ZT0iX2JsYW5rIj4NCjxwYXJhbSBuYW1lPW1lbnUyaTJp NCB2YWx1ZT0iRmx5aW5nIFNpdGV8QXNzaXN0YW5jZXxQcm9ncmFtIj4NCjxwYXJhbSBuYW1l PW1lbnUyaTJpNHVybCB2YWx1ZT0iaHR0cDovL3d3dy5tb2RlbGFpcmNyYWZ0Lm9yZy9Qcm9n cmFtcy9GU0NSRUxFQVNFLmh0bSI+DQo8cGFyYW0gbmFtZT1tZW51MmkyaTR0YXJnZXQgdmFs dWU9Il9zZWxmIj4NCjxwYXJhbSBuYW1lPW1lbnUyaTJpNSB2YWx1ZT0iQWlyIFNob3cgVGVh bXMiPg0KPHBhcmFtIG5hbWU9bWVudTJpMmk1dXJsIHZhbHVlPSJodHRwOi8vd3d3Lm1vZGVs YWlyY3JhZnQub3JnL3Byb2dyYW1zL2FzdC5odG0iPg0KPHBhcmFtIG5hbWU9bWVudTJpMmk1 dGFyZ2V0IHZhbHVlPSJfc2VsZiI+DQo8cGFyYW0gbmFtZT1tZW51MmkzIHZhbHVlPSJGQVEg Zm9yIE1lbWJlcnMiPg0KPHBhcmFtIG5hbWU9bWVudTJpM3VybCB2YWx1ZT0iaHR0cDovL3d3 dy5tb2RlbGFpcmNyYWZ0Lm9yZy9NZW0vRmFxbWVtYmVyLmh0bSI+DQo8cGFyYW0gbmFtZT1t ZW51MmkzdGFyZ2V0IHZhbHVlPSJfc2VsZiI+DQo8cGFyYW0gbmFtZT1tZW51Mmk0IHZhbHVl PSJNZW1iZXJzaGlwfEFwcGxpY2F0aW9ucyI+DQo8cGFyYW0gbmFtZT1tZW51Mmk0aTEgdmFs dWU9Ik1lbWJlcnNoaXB8QXBwbGljYXRpb24iPg0KPHBhcmFtIG5hbWU9bWVudTJpNGkxdXJs IHZhbHVlPSJodHRwOi8vd3d3Lm1vZGVsYWlyY3JhZnQub3JnL01lbS8wMW1lbWJlcnNoaXBh cHAuaHRtIj4NCjxwYXJhbSBuYW1lPW1lbnUyaTRpMXRhcmdldCB2YWx1ZT0iX2JsYW5rIj4N CjxwYXJhbSBuYW1lPW1lbnUyaTRpMiB2YWx1ZT0iSm9pbi9SZW5ldyBPbi1saW5lIj4NCjxw YXJhbSBuYW1lPW1lbnUyaTRpMnVybCB2YWx1ZT0iaHR0cDovL3d3dy5tb2RlbGFpcmNyYWZ0 Lm9yZy9OZXdzL29ubGluZXNwbGFzaC5odG0iPg0KPHBhcmFtIG5hbWU9bWVudTJpNGkydGFy Z2V0IHZhbHVlPSJfc2VsZiI+DQo8cGFyYW0gbmFtZT1tZW51Mmk0aTMgdmFsdWU9Ik1lbWJl cnNoaXB8QXBwbGljYXRpb24gKFBERikiPg0KPHBhcmFtIG5hbWU9bWVudTJpNGkzdXJsIHZh bHVlPSJodHRwOi8vd3d3Lm1vZGVsYWlyY3JhZnQub3JnL1BERi1GaWxlcy85MDIucGRmIj4N CjxwYXJhbSBuYW1lPW1lbnUyaTRpM3RhcmdldCB2YWx1ZT0iX2JsYW5rIj4NCjxwYXJhbSBu YW1lPW1lbnUyaTRpNCB2YWx1ZT0iQWZmaWxpYXRlfEFwcGxpY2F0aW9uIChQREYpIj4NCjxw YXJhbSBuYW1lPW1lbnUyaTRpNHVybCB2YWx1ZT0iaHR0cDovL3d3dy5tb2RlbGFpcmNyYWZ0 Lm9yZy9QREYtRmlsZXMvOTAzLnBkZiI+DQo8cGFyYW0gbmFtZT1tZW51Mmk0aTR0YXJnZXQg dmFsdWU9Il9ibGFuayI+DQo8cGFyYW0gbmFtZT1tZW51Mmk1IHZhbHVlPSJDaGFydGVyZWQg Q2x1YnMiPg0KPHBhcmFtIG5hbWU9bWVudTJpNXVybCB2YWx1ZT0iaHR0cDovL3d3dy5tb2Rl bGFpcmNyYWZ0Lm9yZy9jbHVicy9jbHVibWFpbi5odG0iPg0KPHBhcmFtIG5hbWU9bWVudTJp NXRhcmdldCB2YWx1ZT0iX3RvcCI+DQo8cGFyYW0gbmFtZT1tZW51Mmk2IHZhbHVlPSIyMDAx IENsdWIgQ2hhcnRlcnxSZW5ld2FsIEtpdCAoUERGKSI+DQo8cGFyYW0gbmFtZT1tZW51Mmk2 dXJsIHZhbHVlPSJodHRwOi8vd3d3Lm1vZGVsYWlyY3JhZnQub3JnL1BERi1maWxlcy9jbHVi a2l0LnBkZiI+DQo8cGFyYW0gbmFtZT1tZW51Mmk2dGFyZ2V0IHZhbHVlPSJfYmxhbmsiPg0K PHBhcmFtIG5hbWU9bWVudTJpNyB2YWx1ZT0iMjAwMSBNZW1iZXJzaGlwfE1hbnVhbCAoUERG KSI+DQo8cGFyYW0gbmFtZT1tZW51Mmk3dXJsIHZhbHVlPSJodHRwOi8vd3d3Lm1vZGVsYWly Y3JhZnQub3JnL1BERi1maWxlcy9tZW1hbnVsMDEucGRmIj4NCjxwYXJhbSBuYW1lPW1lbnUy aTd0YXJnZXQgdmFsdWU9Il9ibGFuayI+DQo8cGFyYW0gbmFtZT1tZW51Mmk4IHZhbHVlPSJB TUEgQ2x1YiBTZWFyY2giPg0KPHBhcmFtIG5hbWU9bWVudTJpOHVybCB2YWx1ZT0iaHR0cDov L2NsdWJzLmluLXRvdWNoLm5ldC9hbWFkaXN0cmljdGlpaS9DbHViTG9jYXRvci5odG0iPg0K PHBhcmFtIG5hbWU9bWVudTJpOHRhcmdldCB2YWx1ZT0iX2JsYW5rIj4NCjxwYXJhbSBuYW1l PW1lbnUyaTkgdmFsdWU9IlF1ZXJ5IEFNQXxNZW1iZXJzaGlwIj4NCjxwYXJhbSBuYW1lPW1l bnUyaTl1cmwgdmFsdWU9Imh0dHA6Ly93d3cuYW1hLWRpc3QtOC5vcmcvUXVlcnkuaHRtbCI+ DQo8cGFyYW0gbmFtZT1tZW51Mmk5dGFyZ2V0IHZhbHVlPSJfYmxhbmsiPg0KPHBhcmFtIG5h bWU9bWVudTJpMTAgdmFsdWU9IkFNQSBEb2N1bWVudHN8aW4gUERGIEZvcm1hdCI+DQo8cGFy YW0gbmFtZT1tZW51MmkxMHVybCB2YWx1ZT0iaHR0cDovL3d3dy5tb2RlbGFpcmNyYWZ0Lm9y Zy9QREYtZmlsZXMvYWNyb2JhdC5odG0iPg0KPHBhcmFtIG5hbWU9bWVudTJpMTB0YXJnZXQg dmFsdWU9Il9ibGFuayI+DQoNCjxwYXJhbSBuYW1lPW1lbnUzIHZhbHVlPSJFZHVjYXRpb24i Pg0KPHBhcmFtIG5hbWU9bWVudTNpMSB2YWx1ZT0iRWR1Y2F0aW9uYWx8UHJvZ3JhbXMiPg0K PHBhcmFtIG5hbWU9bWVudTNpMXVybCB2YWx1ZT0iaHR0cDovL3d3dy5tb2RlbGFpcmNyYWZ0 Lm9yZy9wcm9ncmFtcy9FZHVjYXRpb24uaHRtIj4NCjxwYXJhbSBuYW1lPW1lbnUzaTF0YXJn ZXQgdmFsdWU9Il9zZWxmIj4NCjxwYXJhbSBuYW1lPW1lbnUzaTIgdmFsdWU9IkVkdWNhdGlv bnxDb21taXR0ZWUiPg0KPHBhcmFtIG5hbWU9bWVudTNpMnVybCB2YWx1ZT0iaHR0cDovL3d3 dy5tb2RlbGFpcmNyYWZ0Lm9yZy9wcm9ncmFtcy9FZHVjb250YWN0Lmh0bSI+DQo8cGFyYW0g bmFtZT1tZW51M2kydGFyZ2V0IHZhbHVlPSJfc2VsZiI+DQo8cGFyYW0gbmFtZT1tZW51M2kz IHZhbHVlPSJTY2hvbGFyc2hpcHxJbmZvcm1hdGlvbiBhbmR8QXBwbGljYXRpb24iPg0KPHBh cmFtIG5hbWU9bWVudTNpM3VybCB2YWx1ZT0iaHR0cDovL3d3dy5tb2RlbGFpcmNyYWZ0Lm9y Zy9wcm9ncmFtcy9TY2hvbGFyc2hpcC5odG0iPg0KPHBhcmFtIG5hbWU9bWVudTNpM3Rhcmdl dCB2YWx1ZT0iX3NlbGYiPg0KPHBhcmFtIG5hbWU9bWVudTNpNCB2YWx1ZT0iRm9jdXMgb258 RWR1Y2F0aW9uIj4NCjxwYXJhbSBuYW1lPW1lbnUzaTR1cmwgdmFsdWU9Imh0dHA6Ly93d3cu bW9kZWxhaXJjcmFmdC5vcmcvcHJvZ3JhbXMvYW1hc29hcmluZy5odG0iPg0KPHBhcmFtIG5h bWU9bWVudTNpNHRhcmdldCB2YWx1ZT0iX2JsYW5rIj4NCjxwYXJhbSBuYW1lPW1lbnUzaTUg dmFsdWU9IkZ1dHVyZSBTY2llbnRpc3RzfGFuZCBFbmdpbmVlcnMgb2Z8QW1lcmljYSI+DQo8 cGFyYW0gbmFtZT1tZW51M2k1dXJsIHZhbHVlPSJodHRwOi8vd3d3LmZzZWEub3JnLyI+DQo8 cGFyYW0gbmFtZT1tZW51M2k1dGFyZ2V0IHZhbHVlPSJfYmxhbmsiPg0KDQoNCjxwYXJhbSBu YW1lPW1lbnU0IHZhbHVlPSJQdWJsaWNhdGlvbnMiPg0KPHBhcmFtIG5hbWU9bWVudTRpMSB2 YWx1ZT0iTW9kZWwgQXZpYXRpb24iPg0KPHBhcmFtIG5hbWU9bWVudTRpMXVybCB2YWx1ZT0i aHR0cDovL3d3dy5tb2RlbGFpcmNyYWZ0Lm9yZy9tYWcvaW5kZXguaHRtIj4NCjxwYXJhbSBu YW1lPW1lbnU0aTF0YXJnZXQgdmFsdWU9Il9ibGFuayI+DQo8cGFyYW0gbmFtZT1tZW51NGky IHZhbHVlPSJOYXRpb25hbHxOZXdzbGV0dGVycyI+DQo8cGFyYW0gbmFtZT1tZW51NGkydXJs IHZhbHVlPSJodHRwOi8vd3d3Lm1vZGVsYWlyY3JhZnQub3JnL05ld3MvTmV3c2xldHRlcnMu aHRtIj4NCjxwYXJhbSBuYW1lPW1lbnU0aTJ0YXJnZXQgdmFsdWU9Il9zZWxmIj4NCjxwYXJh bSBuYW1lPW1lbnU0aTMgdmFsdWU9IjIwMDEgTWVtYmVyc2hpcHxNYW51YWwgKFBERikiPg0K PHBhcmFtIG5hbWU9bWVudTRpM3VybCB2YWx1ZT0iaHR0cDovL3d3dy5tb2RlbGFpcmNyYWZ0 Lm9yZy9wZGYtZmlsZXMvbWVtYW51bDAxLnBkZiI+DQo8cGFyYW0gbmFtZT1tZW51NGkzdGFy Z2V0IHZhbHVlPSJfYmxhbmsiPg0KPHBhcmFtIG5hbWU9bWVudTRpNCB2YWx1ZT0iQ29tcGV0 aXRpb258UmVndWxhdGlvbnMiPg0KPHBhcmFtIG5hbWU9bWVudTRpNHVybCB2YWx1ZT0iaHR0 cDovL3d3dy5tb2RlbGFpcmNyYWZ0Lm9yZy9QREYtZmlsZXMvQ29tcHJlZy5odG0iPg0KPHBh cmFtIG5hbWU9bWVudTRpNHRhcmdldCB2YWx1ZT0iX2JsYW5rIj4NCg0KPHBhcmFtIG5hbWU9 bWVudTUgdmFsdWU9IkNvbXBldGl0aW9uIj4NCjxwYXJhbSBuYW1lPW1lbnU1aTEgdmFsdWU9 IkNvbnRlc3QgQ2FsZW5kYXIiPg0KPHBhcmFtIG5hbWU9bWVudTVpMXVybCB2YWx1ZT0iaHR0 cDovL3d3dy5tb2RlbGFpcmNyYWZ0Lm9yZy9Db21wL0NvbnRlc3QuaHRtIj4NCjxwYXJhbSBu YW1lPW1lbnU1aTIgdmFsdWU9IjIwMDEgTmF0cyI+DQo8cGFyYW0gbmFtZT1tZW51NWkydXJs IHZhbHVlPSJodHRwOi8vd3d3Lm1vZGVsYWlyY3JhZnQub3JnL0NvbXAvMjAwMU5hdHNmcm9u dC5odG0iPg0KPHBhcmFtIG5hbWU9bWVudTVpMyB2YWx1ZT0iQ29tcGV0aXRpb25zfERlcGFy dG1lbnR8SW5mb3JtYXRpb24iPg0KPHBhcmFtIG5hbWU9bWVudTVpM3VybCB2YWx1ZT0iaHR0 cDovL3d3dy5tb2RlbGFpcmNyYWZ0Lm9yZy9Db21wL0NvbXBldGl0aW9uLmh0bSI+DQoNCjxw YXJhbSBuYW1lPW1lbnU2IHZhbHVlPSJOYXRpb25hbCBNb2RlbHxBdmlhdGlvbiBNdXNldW0i Pg0KPHBhcmFtIG5hbWU9bWVudTZ1cmwgdmFsdWU9Imh0dHA6Ly93d3cubW9kZWxhaXJjcmFm dC5vcmcvc2l0ZS9tdXNldW0uaHRtIj4NCjxwYXJhbSBuYW1lPW1lbnU2dGFyZ2V0IHZhbHVl PSJfc2VsZiI+DQoNCjxwYXJhbSBuYW1lPW1lbnU3IHZhbHVlPSJMaW5rcyI+DQo8cGFyYW0g bmFtZT1tZW51N2kxIHZhbHVlPSJMaW5rcyBJbmZvcm1hdGlvbiI+DQo8cGFyYW0gbmFtZT1t ZW51N2kxdXJsIHZhbHVlPSJodHRwOi8vd3d3Lm1vZGVsYWlyY3JhZnQub3JnL2xpbmtzcmVx dWVzdC5odG0iPg0KPHBhcmFtIG5hbWU9bWVudTdpMXRhcmdldCB2YWx1ZT0iX3NlbGYiPg0K PHBhcmFtIG5hbWU9bWVudTdpMiB2YWx1ZT0iRGlzdHJpY3QgV2ViIFNpdGVzIj4NCjxwYXJh bSBuYW1lPW1lbnU3aTJ1cmwgdmFsdWU9Imh0dHA6Ly93d3cubW9kZWxhaXJjcmFmdC5vcmcv bGlua3MvZGlzdHJpY3RsaW5rcy5odG0iPg0KPHBhcmFtIG5hbWU9bWVudTdpMnRhcmdldCB2 YWx1ZT0iX3NlbGYiPg0KPHBhcmFtIG5hbWU9bWVudTdpMyB2YWx1ZT0iQ2hhcnRlcmVkIENs dWJ8V2ViIFNpdGVzIj4NCjxwYXJhbSBuYW1lPW1lbnU3aTN1cmwgdmFsdWU9Imh0dHA6Ly93 d3cubW9kZWxhaXJjcmFmdC5vcmcvL2NsdWJsaW5rL2NsdWJsaW5rcy5odG0iPg0KPHBhcmFt IG5hbWU9bWVudTdpM3RhcmdldCB2YWx1ZT0iX3NlbGYiPg0KPHBhcmFtIG5hbWU9bWVudTdp NCB2YWx1ZT0iT3RoZXIgTGlua3MiPg0KPHBhcmFtIG5hbWU9bWVudTdpNHVybCB2YWx1ZT0i aHR0cDovL3d3dy5tb2RlbGFpcmNyYWZ0Lm9yZy9saW5rcy9saW5rcy5odG0iPg0KPHBhcmFt IG5hbWU9bWVudTdpNHRhcmdldCB2YWx1ZT0iX3NlbGYiPg0KDQo8cGFyYW0gbmFtZT1tZW51 OCB2YWx1ZT0iQ29udGFjdCBVcyI+DQo8cGFyYW0gbmFtZT1tZW51OGkxIHZhbHVlPSJDb250 YWN0IFN0YWZmIj4NCjxwYXJhbSBuYW1lPW1lbnU4aTF1cmwgdmFsdWU9Imh0dHA6Ly93d3cu bW9kZWxhaXJjcmFmdC5vcmcvTWFpbGRpci5odG0iPg0KPHBhcmFtIG5hbWU9bWVudThpMXRh cmdldCB2YWx1ZT0iX3NlbGYiPg0KPHBhcmFtIG5hbWU9bWVudThpMiB2YWx1ZT0iQ29udGFj dCBFeGVjdXRpdmV8Q291bmNpbCI+DQo8cGFyYW0gbmFtZT1tZW51OGkydXJsIHZhbHVlPSJo dHRwOi8vd3d3Lm1vZGVsYWlyY3JhZnQub3JnL01haWxkaXJlYy5odG0iPg0KPHBhcmFtIG5h bWU9bWVudThpMnRhcmdldCB2YWx1ZT0iX3NlbGYiPg0KPHBhcmFtIG5hbWU9bWVudThpMyB2 YWx1ZT0iQ29udGFjdHxXZWJtYXN0ZXIiPg0KPHBhcmFtIG5hbWU9bWVudThpM3VybCB2YWx1 ZT0ibWFpbHRvOndlYm1hc3RlckBtb2RlbGFpcmNyYWZ0Lm9yZyI+DQo8cGFyYW0gbmFtZT1t ZW51OGkzdGFyZ2V0IHZhbHVlPSJfc2VsZiI+DQoNCg0KPHBhcmFtIG5hbWU9bWVudTkgdmFs dWU9IkpvaW4vUmVuZXcgTm93Ij4NCjxwYXJhbSBuYW1lPW1lbnU5aTEgdmFsdWU9Ik1lbWJl cnNoaXB8QXBwbGljYXRpb24gKEhUTUwpIj4NCjxwYXJhbSBuYW1lPW1lbnU5aTF1cmwgdmFs dWU9Imh0dHA6Ly93d3cubW9kZWxhaXJjcmFmdC5vcmcvTWVtLzAxbWVtYmVyc2hpcGFwcC5o dG0iPg0KPHBhcmFtIG5hbWU9bWVudTlpMXRhcmdldCB2YWx1ZT0iX2JsYW5rIj4NCjxwYXJh bSBuYW1lPW1lbnU5aTIgdmFsdWU9IlJlbmV3IE9ubGluZSI+DQo8cGFyYW0gbmFtZT1tZW51 OWkydXJsIHZhbHVlPSJodHRwOi8vd3d3Lm1vZGVsYWlyY3JhZnQub3JnL25ld3Mvb25saW5l c3BsYXNoLmh0bSI+DQo8cGFyYW0gbmFtZT1tZW51OWkydGFyZ2V0IHZhbHVlPSJfYmxhbmsi Pg0KPHBhcmFtIG5hbWU9bWVudTlpMyB2YWx1ZT0iTWVtYmVyc2hpcHxBcHBsaWNhdGlvbiAo UERGKSI+DQo8cGFyYW0gbmFtZT1tZW51OWkzdXJsIHZhbHVlPSJodHRwOi8vd3d3Lm1vZGVs YWlyY3JhZnQub3JnL1BERi1GaWxlcy85MDIucGRmIj4NCjxwYXJhbSBuYW1lPW1lbnU5aTN0 YXJnZXQgdmFsdWU9Il9ibGFuayI+DQo8cGFyYW0gbmFtZT1tZW51OWk0IHZhbHVlPSJBZmZp bGlhdGV8TWVtYmVyc2hpcHxBcHBsaWNhdGlvbiAoUERGKSI+DQo8cGFyYW0gbmFtZT1tZW51 OWk0dXJsIHZhbHVlPSJodHRwOi8vd3d3Lm1vZGVsYWlyY3JhZnQub3JnL1BERi1GaWxlcy85 MDMucGRmIj4NCjxwYXJhbSBuYW1lPW1lbnU5aTR0YXJnZXQgdmFsdWU9Il9ibGFuayI+DQo8 L2FwcGxldD48YnI+DQo8L1REPg0KPFREIEFMSUdOPUNFTlRFUiBWQUxJR049dG9wIENPTFNQ QU49MSBST1dTUEFOPTE+DQo8SDE+QU1BIFByb2dyYW1zIEZvciBNZW1iZXJzPC9IMT4NCjwv Q0VOVEVSPg0KPEEgTkFNRT0idG9wIj4NCjxkaXYgYWxpZ249ImxlZnQiPg0KPGI+UFJPTU9U SU5HIFRIRSBIT0JCWTwvYj4NCjwvZGl2Pg0KDQoNCiAgPHAgYWxpZ249ImxlZnQiPjxBIEhS RUY9IiNGbHlpbmcgU2l0ZSBIZWxwIj48aW1nIHNyYz0iL2ltYWdlcy9hbWFkb3QuZ2lmIiBB TElHTj1UT1AgV0lEVEg9MTcgSEVJR0hUPTE4IEJPUkRFUj0wIFZTUEFDRT0xIEhTUEFDRT01 IEFMVD0iKiI+Rmx5aW5nIFNpdGUgSGVscDwvQT4NCg0KICA8cCBhbGlnbj0ibGVmdCI+PEEg SFJFRj0iI0ludHJvLVBpbG90IFByb2dyYW0iPjxpbWcgc3JjPSIvaW1hZ2VzL2FtYWRvdC5n aWYiIEFMSUdOPVRPUCBXSURUSD0xNyBIRUlHSFQ9MTggQk9SREVSPTAgVlNQQUNFPTEgSFNQ QUNFPTUgQUxUPSIqIj5JbnRyby1QaWxvdCBQcm9ncmFtPC9BPg0KDQogIDxwIGFsaWduPSJs ZWZ0Ij48QSBIUkVGPSIjQWRvcHQtQS1TY2hvb2wiPjxpbWcgc3JjPSIvaW1hZ2VzL2FtYWRv dC5naWYiIEFMSUdOPVRPUCBXSURUSD0xNyBIRUlHSFQ9MTggQk9SREVSPTAgVlNQQUNFPTEg SFNQQUNFPTUgQUxUPSIqIj5BZG9wdC1BLVNjaG9vbDwvQT4NCg0KICA8cCBhbGlnbj0ibGVm dCI+PEEgSFJFRj0iI01hbGwgU2hvd3MiPjxpbWcgc3JjPSIvaW1hZ2VzL2FtYWRvdC5naWYi IEFMSUdOPVRPUCBXSURUSD0xNyBIRUlHSFQ9MTggQk9SREVSPTAgVlNQQUNFPTEgSFNQQUNF PTUgQUxUPSIqIj5NYWxsIFNob3dzPC9BPg0KDQogIDxwIGFsaWduPSJsZWZ0Ij48QSBIUkVG PSIjQWlyIFNob3cgVGVhbSAoQVNUKSBQcm9ncmFtIj48aW1nIHNyYz0iL2ltYWdlcy9hbWFk b3QuZ2lmIiBBTElHTj1UT1AgV0lEVEg9MTcgSEVJR0hUPTE4IEJPUkRFUj0wIFZTUEFDRT0x IEhTUEFDRT01IEFMVD0iKiI+QWlyIFNob3cgVGVhbSAoQVNUKSBQcm9ncmFtPC9BPg0KPFAg YWxpZ249ImxlZnQiPg0KDQo8ZGl2IGFsaWduPSJsZWZ0Ij4NCjxiPlNVUFBPUlRJTkcgRURV Q0FUSU9OPC9iPg0KPC9kaXY+DQoNCg0KICA8cCBhbGlnbj0ibGVmdCI+PEEgSFJFRj0iI1Nj aG9sYXJzaGlwcyI+PGltZyBzcmM9Ii9pbWFnZXMvYW1hZG90LmdpZiIgQUxJR049VE9QIFdJ RFRIPTE3IEhFSUdIVD0xOCBCT1JERVI9MCBWU1BBQ0U9MSBIU1BBQ0U9NSBBTFQ9IioiPlNj aG9sYXJzaGlwczwvQT4NCg0KICA8cCBhbGlnbj0ibGVmdCI+PEEgSFJFRj0iI0VkdWNhdG9y IFN1cHBvcnQiPjxpbWcgc3JjPSIvaW1hZ2VzL2FtYWRvdC5naWYiIEFMSUdOPVRPUCBXSURU SD0xNyBIRUlHSFQ9MTggQk9SREVSPTAgVlNQQUNFPTEgSFNQQUNFPTUgQUxUPSIqIj5FZHVj YXRvciBTdXBwb3J0PC9BPg0KDQogIDxwIGFsaWduPSJsZWZ0Ij48QSBIUkVGPSIjUmVuYXVk IFJlc2VhcmNoIExpYnJhcnkiPjxpbWcgc3JjPSIvaW1hZ2VzL2FtYWRvdC5naWYiIEFMSUdO PVRPUCBXSURUSD0xNyBIRUlHSFQ9MTggQk9SREVSPTAgVlNQQUNFPTEgSFNQQUNFPTUgQUxU PSIqIj5SZW5hdWQgUmVzZWFyY2ggTGlicmFyeTwvQT4NCjxQIGFsaWduPSJsZWZ0Ij4NCg0K PGRpdiBhbGlnbj0ibGVmdCI+DQo8Yj5SRUNPR05JWklORyBJTkRJVklEVUFMUzwvYj4NCjwv ZGl2Pg0KDQoNCiAgPHAgYWxpZ249ImxlZnQiPjxBIEhSRUY9IiNMZWFkZXIgTWVtYmVyIj48 aW1nIHNyYz0iL2ltYWdlcy9hbWFkb3QuZ2lmIiBBTElHTj1UT1AgV0lEVEg9MTcgSEVJR0hU PTE4IEJPUkRFUj0wIFZTUEFDRT0xIEhTUEFDRT01IEFMVD0iKiI+TGVhZGVyIE1lbWJlcjwv QT4NCg0KICA8cCBhbGlnbj0ibGVmdCI+PEEgSFJFRj0iI0xlYWRlciBDbHViIFByb2dyYW0i PjxpbWcgc3JjPSIvaW1hZ2VzL2FtYWRvdC5naWYiIEFMSUdOPVRPUCBXSURUSD0xNyBIRUlH SFQ9MTggQk9SREVSPTAgVlNQQUNFPTEgSFNQQUNFPTUgQUxUPSIqIj5MZWFkZXIgQ2x1YiBQ cm9ncmFtPC9BPg0KDQogIDxwIGFsaWduPSJsZWZ0Ij48QSBIUkVGPSIjQ29udGVzdCBEaXJl Y3RvciI+PGltZyBzcmM9Ii9pbWFnZXMvYW1hZG90LmdpZiIgQUxJR049VE9QIFdJRFRIPTE3 IEhFSUdIVD0xOCBCT1JERVI9MCBWU1BBQ0U9MSBIU1BBQ0U9NSBBTFQ9IioiPkNvbnRlc3Qg RGlyZWN0b3I8L0E+DQoNCiAgPHAgYWxpZ249ImxlZnQiPjxBIEhSRUY9IiNBcHByZWNpYXRp b24gQXdhcmRzIj48aW1nIHNyYz0iL2ltYWdlcy9hbWFkb3QuZ2lmIiBBTElHTj1UT1AgV0lE VEg9MTcgSEVJR0hUPTE4IEJPUkRFUj0wIFZTUEFDRT0xIEhTUEFDRT01IEFMVD0iKiI+QXBw cmVjaWF0aW9uIEF3YXJkczwvQT4NCg0KICA8cCBhbGlnbj0ibGVmdCI+PEEgSFJFRj0iI2xp ZmVtZW1iZXIuaHRtIj48aW1nIHNyYz0iL2ltYWdlcy9hbWFkb3QuZ2lmIiBBTElHTj1UT1Ag V0lEVEg9MTcgSEVJR0hUPTE4IEJPUkRFUj0wIFZTUEFDRT0xIEhTUEFDRT01IEFMVD0iKiI+ TGlmZSBNZW1iZXJzaGlwIEluZm9ybWF0aW9uPC9BPg0KDQo8UCBhbGlnbj0ibGVmdCI+DQoN CjxkaXYgYWxpZ249ImxlZnQiPg0KPGI+UEFSVElDSVBBVElORyBJTiBXT1JMRC1DTEFTUyBB RVJPTU9ERUxJTkcgQ09NUEVUSVRJT048L2I+DQo8L2Rpdj4NCg0KDQogIDxwIGFsaWduPSJs ZWZ0Ij48QSBIUkVGPSIjV29ybGQgQ2hhbXBpb25zaGlwcyI+PGltZyBzcmM9Ii9pbWFnZXMv YW1hZG90LmdpZiIgQUxJR049VE9QIFdJRFRIPTE3IEhFSUdIVD0xOCBCT1JERVI9MCBWU1BB Q0U9MSBIU1BBQ0U9NSBBTFQ9IioiPldvcmxkIENoYW1waW9uc2hpcHM8L0E+DQo8UCBhbGln bj0ibGVmdCI+DQoNCjxkaXYgYWxpZ249ImxlZnQiPg0KPGI+QURESVRJT05BTCBCRU5FRklU IFBMQU5TIEZPUiBNRU1CRVJTPC9iPg0KPC9kaXY+DQoNCg0KICA8cCBhbGlnbj0ibGVmdCI+ PEEgSFJFRj0iI092ZXJ2aWV3Ij48aW1nIHNyYz0iL2ltYWdlcy9hbWFkb3QuZ2lmIiBBTElH Tj1UT1AgV0lEVEg9MTcgSEVJR0hUPTE4IEJPUkRFUj0wIFZTUEFDRT0xIEhTUEFDRT01IEFM VD0iKiI+T3ZlcnZpZXc8L0E+DQo8UCBhbGlnbj0ibGVmdCI+DQoNCjxkaXYgYWxpZ249Imxl ZnQiPg0KPGI+QVZBSUxBQkxFIEJFTkVGSVRTPC9iPg0KPC9kaXY+DQoNCg0KICA8cCBhbGln bj0ibGVmdCI+PEEgSFJFRj0iI0dyb3VwIFRlcm0gTGlmZSBJbnN1cmFuY2UiPjxpbWcgc3Jj PSIvaW1hZ2VzL2FtYWRvdC5naWYiIEFMSUdOPVRPUCBXSURUSD0xNyBIRUlHSFQ9MTggQk9S REVSPTAgVlNQQUNFPTEgSFNQQUNFPTUgQUxUPSIqIj5Hcm91cCBUZXJtIExpZmUgSW5zdXJh bmNlPC9BPg0KDQogIDxwIGFsaWduPSJsZWZ0Ij48QSBIUkVGPSIjJDEwLDAwMCBBY2NpZGVu dCBJbnN1cmFuY2UiPjxpbWcgc3JjPSIvaW1hZ2VzL2FtYWRvdC5naWYiIEFMSUdOPVRPUCBX SURUSD0xNyBIRUlHSFQ9MTggQk9SREVSPTAgVlNQQUNFPTEgSFNQQUNFPTUgQUxUPSIqIj4k MTAsMDAwIEFjY2lkZW50IEluc3VyYW5jZTwvQT4NCg0KICA8cCBhbGlnbj0ibGVmdCI+PEEg SFJFRj0iI0V4Y2VzcyBNYWpvciBNZWRpY2FsIEdyb3VwIEluc3VyYW5jZSI+PGltZyBzcmM9 Ii9pbWFnZXMvYW1hZG90LmdpZiIgQUxJR049VE9QIFdJRFRIPTE3IEhFSUdIVD0xOCBCT1JE RVI9MCBWU1BBQ0U9MSBIU1BBQ0U9NSBBTFQ9IioiPkV4Y2VzcyBNYWpvciBNZWRpY2FsIEdy b3VwIEluc3VyYW5jZTwvQT4NCg0KICA8cCBhbGlnbj0ibGVmdCI+PEEgSFJFRj0iI1Zpc2lv biBDYXJlIFBsYW4iPjxpbWcgc3JjPSIvaW1hZ2VzL2FtYWRvdC5naWYiIEFMSUdOPVRPUCBX SURUSD0xNyBIRUlHSFQ9MTggQk9SREVSPTAgVlNQQUNFPTEgSFNQQUNFPTUgQUxUPSIqIj5W aXNpb24gQ2FyZSBQbGFuPC9BPg0KPENFTlRFUj4NCjxIUiBBTElHTj1jZW50ZXIgU0laRT0z IFdJRFRIPTgwJT4NCjwvQ0VOVEVSPg0KPEg0IGFsaWduPSJsZWZ0Ij5QUk9NT1RJTkcgVEhF IEhPQkJZPC9IND4NCg0KPGRpdiBhbGlnbj0ibGVmdCI+DQo8aW1nIHNyYz0iL2ltYWdlcy9h bWFkb3QuZ2lmIiBBTElHTj1UT1AgV0lEVEg9MTcgSEVJR0hUPTE4IEJPUkRFUj0wIFZTUEFD RT0wIEhTUEFDRT01IEFMVD0iKiI+PEI+PEEgTkFNRT0iRmx5aW5nIFNpdGUgSGVscCI+Rmx5 aW5nIFNpdGUgSGVscDwvQT48L0I+DQo8L2Rpdj4NCg0KDQogIDxwIGFsaWduPSJsZWZ0Ij4N CiAgQSBjb21wcmVoZW5zaXZlIHBhY2thZ2Ugb2Ygc3VwcG9ydCBtYXRlcmlhbHMgaXMgYXZh aWxhYmxlIGZyZWUgb2YgY2hhcmdlLiAgQW4gZXhjZWxsZW50IHZpZGVvIGlzIGFsc28gYXZh aWxhYmxlIGFuZCBtYXkgYmUgYm9ycm93ZWQgYnkgY2hhcnRlcmVkIGNsdWJzLiAgSW4gYWRk aXRpb24sIHF1YWxpZmllZCBBTUEgc3RhZmZlcnMgbWF5IHZpc2l0IGNsdWJzIGFuZCBsb2Nh bCBnb3Zlcm5tZW50IGFnZW5jaWVzIGZvciBtZWV0aW5nIHJlZ2FyZGluZyBzaXRlIGFjcXVp c2l0aW9uLiAgV3JpdGUgdG8gdGhlIDxBIEhSRUY9Im1haWx0bzpqbWVhbHlAbW9kZWxhaXJj cmFmdC5vcmciPk1hcmtldGluZyBEZXBhcnRtZW50PC9BPiBhdCBBTUEgSGVhZHF1YXJ0ZXJz Lg0KPFAgYWxpZ249ImxlZnQiPg0KDQo8ZGl2IGFsaWduPSJsZWZ0Ij4NCjxpbWcgc3JjPSIv aW1hZ2VzL2FtYWRvdC5naWYiIEFMSUdOPVRPUCBXSURUSD0xNyBIRUlHSFQ9MTggQk9SREVS PTAgVlNQQUNFPTAgSFNQQUNFPTUgQUxUPSIqIj48Qj48QSBOQU1FPSJJbnRyby1QaWxvdCBQ cm9ncmFtIj5JbnRyby1QaWxvdCBQcm9ncmFtPC9BPjwvQj4NCjwvZGl2Pg0KDQoNCiAgPHAg YWxpZ249ImxlZnQiPg0KICBBbiBpbnRyby1waWxvdCBwcm9ncmFtIGlzIGF2YWlsYWJsZSB0 byBhbGwgY2hhcnRlcmVkIGNsdWJzLiAgUXVhbGlmaWVkIHBpbG90cyBmcm9tIGNoYXJ0ZXJl ZCBjbHVicyAobGltaXRlZCB0byB0aHJlZSBwZXIgY2x1YikgbWF5IHBhcnRpY2lwYXRlLiAg SW5zdHJ1Y3RvcnMgY2FuIHRyYWluIG5vbi1BTUEgbWVtYmVycyB0byBmbHkgYWlycGxhbmVz IGR1cmluZyBhIHRpbWUgcGVyaW9kIG9mIDMwIGNvbnNlY3V0aXZlIGRheXMsIGFuZCBzdHVk ZW50cyBhcmUgY292ZXJlZCBieSB0aGUgbGlhYmlsaXR5IHByb3Zpc2lvbnMgb2YgdGhlIEFN QSBpbnN1cmFuY2UgcG9saWN5LiAgRnVsbCBkZXRhaWxzIGFyZSBhdmFpbGFibGUgZnJvbSB0 aGUgPEEgSFJFRj0ibWFpbHRvOmxvaXNwQG1vZGVsYWlyY3JhZnQub3JnIj5NZW1iZXJzaGlw IERlcGFydG1lbnQ8L0E+IGF0IEFNQSBIZWFkcXVhcnRlcnMuDQo8UCBhbGlnbj0ibGVmdCI+ DQoNCjxkaXYgYWxpZ249ImxlZnQiPg0KPGltZyBzcmM9Ii9pbWFnZXMvYW1hZG90LmdpZiIg QUxJR049VE9QIFdJRFRIPTE3IEhFSUdIVD0xOCBCT1JERVI9MCBWU1BBQ0U9MCBIU1BBQ0U9 NSBBTFQ9IioiPjxCPjxBIE5BTUU9IkFkb3B0LUEtU2Nob29sIj5BZG9wdC1BLVNjaG9vbDwv QT48L0I+DQo8L2Rpdj4NCg0KDQogIDxwIGFsaWduPSJsZWZ0Ij4NCiAgVGhlIEFjYWRlbXkg ZW5jb3VyYWdlcyBjbHVicyB0byBhZG9wdCBzY2hvb2xzIGluIHRoZWlyIGxvY2FsaXRpZXMu ICA8QSBIUkVGPSJtYWlsdG86YXByaWxoQG1vZGVsYWlyY3JhZnQub3JnIj5JbnN0cnVjdGlv bmFsIG1hdGVyaWFsPC9BPiB3aWxsIGJlIHByb3ZpZGVkIGJ5IEFNQS4gIE1hbnkgc3VwcGxp ZXJzIGFsc28gcHJvdmlkZSBlbGVtZW50YXJ5IGtpdHMgYXQgZGlzY291bnRlZCBwcmljZXMu ICBDb21tZW1vcmF0aXZlIHBpbnMgYW5kIHBhdGNoZXMgYXJlIGF2YWlsYWJsZSwgdXBvbiBy ZXF1ZXN0LCBmb3IgY2x1YiBtZW1iZXJzIHdobyBwYXJ0aWNpcGF0ZSBpbiB0aGUgcHJvZ3Jh bS4NCjxQIGFsaWduPSJsZWZ0Ij4NCg0KPGRpdiBhbGlnbj0ibGVmdCI+DQo8aW1nIHNyYz0i L2ltYWdlcy9hbWFkb3QuZ2lmIiBBTElHTj1UT1AgV0lEVEg9MTcgSEVJR0hUPTE4IEJPUkRF Uj0wIFZTUEFDRT0wIEhTUEFDRT01IEFMVD0iKiI+PEI+PEEgTkFNRT0iTWFsbCBTaG93cyI+ TWFsbCBTaG93czwvQT48L0I+DQo8L2Rpdj4NCg0KDQogIDxwIGFsaWduPSJsZWZ0Ij4NCiAg VGhlIEFNQSA8QSBIUkVGPSJtYWlsdG86ZXJpbmRAbW9kZWxhaXJjcmFmdC5vcmciPkhlYWRx dWFydGVycyBzdGFmZjwvQT4gd2lsbCBzaGlwIGZyZWUgaGFuZG91dCBtYXRlcmlhbHMgdG8g Y2hhcnRlcmVkIGNsdWJzIGFuZCBhd2FyZCBhIGNvbW1lbW9yYXRpdmUgcGluIHRvIHdvcmtl cnMuICBDbHVicyBuZWVkIHRvIG5vdGlmeSBBTUEgSGVhZHF1YXJ0ZXJzIDMwIGRheXMgcHJp b3IgdG8gdGhlaXIgcGxhbm5lZCBzaG93IHRvIGFsbG93IHRpbWUgZm9yIHNoaXBwaW5nLg0K PFAgYWxpZ249ImxlZnQiPg0KDQo8ZGl2IGFsaWduPSJsZWZ0Ij4NCjxpbWcgc3JjPSIvaW1h Z2VzL2FtYWRvdC5naWYiIEFMSUdOPVRPUCBXSURUSD0xNyBIRUlHSFQ9MTggQk9SREVSPTAg VlNQQUNFPTAgSFNQQUNFPTUgQUxUPSIqIj48Qj48QSBOQU1FPSJBaXIgU2hvdyBUZWFtIChB U1QpIFByb2dyYW0iPkFpciBTaG93IFRlYW0gKEFTVCkgUHJvZ3JhbTwvQT48L0I+DQo8L2Rp dj4NCg0KDQogIDxwIGFsaWduPSJsZWZ0Ij4NCiAgQU1BIGVuY291cmFnZXMgaGlnaGx5IHNr aWxsZWQgZmxpZXJzIHdobyBlbmpveSBwZXJmb3JtaW5nIGJlZm9yZSBhdWRpZW5jZXMgdG8g aW5xdWlyZSBhYm91dCB0aGUgQVNUIGFuZCBhbm51YWwgcmVwb3J0aW5nIHN0aXB1bGF0aW9u cy4gIEd1aWRlbGluZXMgZm9yIGZvcm1pbmcgYSB0ZWFtIGFyZSBhdmFpbGFibGUgdXBvbiBy ZXF1ZXN0LiBDb250YWN0IHRoZSA8QSBIUkVGPSJtYWlsdG86YXByaWxoQG1vZGVsYWlyY3Jh ZnQub3JnIj5Qcm9ncmFtcyBEZXBhcnRtZW50LjwvQT4NCjxINCBhbGlnbj0ibGVmdCI+U1VQ UE9SVElORyBFRFVDQVRJT048L0g0Pg0KDQoNCjxkaXYgYWxpZ249ImxlZnQiPg0KPGltZyBz cmM9Ii9pbWFnZXMvYW1hZG90LmdpZiIgQUxJR049VE9QIFdJRFRIPTE3IEhFSUdIVD0xOCBC T1JERVI9MCBWU1BBQ0U9MCBIU1BBQ0U9NSBBTFQ9IioiPjxCPjxBIE5BTUU9IlNjaG9sYXJz aGlwcyI+U2Nob2xhcnNoaXBzPC9BPjwvQj4gDQo8L2Rpdj4NCg0KDQogPHAgYWxpZ249Imxl ZnQiPg0KIFNldmVyYWwgc2Nob2xhcnNoaXBzIGFyZSBhd2FyZGVkIGFubnVhbGx5IHRvIHlv dW5nIEFNQSBtZW1iZXJzIGVudGVyaW5nIGEgY29sbGVnZSBvciB1bml2ZXJzaXR5LiAgQW5u dWFsIGF3YXJkcyB0b3RhbCBhcHByb3hpbWF0ZWx5ICQyMCwwMDAuICBJbnRlcmVzdGVkIGFw cGxpY2FudHMgbWF5IG9idGFpbiBkZXRhaWxzIGJ5IHdyaXRpbmcgdG8gPEEgSFJFRj0ibWFp bHRvOmphY2tmQG1vZGVsYWlyY3JhZnQub3JnIj5BTUEgSGVhZHF1YXJ0ZXJzLg0KPFAgYWxp Z249ImxlZnQiPg0KDQogPGRpdiBhbGlnbj0ibGVmdCI+DQo8aW1nIHNyYz0iL2ltYWdlcy9h bWFkb3QuZ2lmIiBBTElHTj1UT1AgV0lEVEg9MTcgSEVJR0hUPTE4IEJPUkRFUj0wIFZTUEFD RT0wIEhTUEFDRT01IEFMVD0iKiI+PC9hPjxCPjxBIE5BTUU9IkVkdWNhdG9yIFN1cHBvcnQi PkVkdWNhdG9yIFN1cHBvcnQ8L0E+PC9CPg0KPC9kaXY+DQoNCg0KICA8cCBhbGlnbj0ibGVm dCI+DQogIEEgY2xhc3Nyb29tIHBhY2thZ2UgaXMgYXZhaWxhYmxlIHRvIGVkdWNhdG9ycyB3 aG8gd3JpdGUgdG8gQU1BIEhlYWRxdWFydGVycyBvbiBzY2hvb2wgbGV0dGVyaGVhZC4gIFRo aXMgcGFja2FnZSBjb250YWlucyBzdWdnZXN0aW9ucyBmb3IgY2xhc3Nyb29tIGFjdGl2aXRp ZXMsIGxpc3RzIHNvdXJjZXMgb2YgbWF0ZXJpYWxzLCBhbmQgaWRlbnRpZmllcyBvdGhlciBj b21wYW5pZXMgYW5kIGFzc29jaWF0aW9ucyB3aGljaCBwcm92aWRlIGRvY3VtZW50YXRpb24g YW5kIGd1aWRhbmNlLiAgVGhlIHVzZSBvZiBtb2RlbCBhdmlhdGlvbiB0ZWNobmlxdWVzIGJ5 IHRlYWNoZXJzIGNhbiBlbmhhbmNlIGxlYXJuaW5nIG9wcG9ydHVuaXRpZXMgZm9yIHN0dWRl bnRzIGluIG1hdGhlbWF0aWNzIGFuZCB2YXJpb3VzIHNjaWVuY2VzLiBDb250YWN0IHRoZSA8 QSBIUkVGPSJtYWlsdG86amFja2ZAbW9kZWxhaXJjcmFmdC5vcmciPlByb2dyYW1zIERlcGFy dG1lbnQuPC9BPg0KPFAgYWxpZ249ImxlZnQiPg0KDQo8ZGl2IGFsaWduPSJsZWZ0Ij4NCjxp bWcgc3JjPSIvaW1hZ2VzL2FtYWRvdC5naWYiIEFMSUdOPVRPUCBXSURUSD0xNyBIRUlHSFQ9 MTggQk9SREVSPTAgVlNQQUNFPTAgSFNQQUNFPTUgQUxUPSIqIj48Qj48QSBOQU1FPSJSZW5h dWQgUmVzZWFyY2ggTGlicmFyeSI+UmVuYXVkIFJlc2VhcmNoIExpYnJhcnk8L0E+PC9CPg0K PC9kaXY+DQoNCg0KICA8cCBhbGlnbj0ibGVmdCI+DQogIExvY2F0ZWQgYXQgQU1BIEhlYWRx dWFydGVycyBpbiBNdW5jaWUsIEluZGlhbmEsIHRoZSBSZW5hdWQgbGlicmFyeSBpcyBvcGVu IGZvciByZXNlYXJjaC4gIFRoZSBsaWJyYXJ5IGlzIGEgZ3JlYXQgc291cmNlIGZvciByZXNl YXJjaCBhbmQgQU1BIGhpc3RvcmljYWwgaW5mb3JtYXRpb24uICBDb2xsZWN0aW9ucyBvZiBt b2RlbGluZyBtYWdhemluZXMgc3Bhbm5pbmcgbWFueSBkZWNhZGVzIGFyZSBhdmFpbGFibGUg Zm9yIGV4YW1pbmF0aW9uLiAgRGlyZWN0IGFsbCBpbnF1aXJpZXMgdG8gdGhlIDxBIEhSRUY9 Im1haWx0bzpyaWNoYXJkbEBtb2RlbGFpcmNyYWZ0Lm9yZyI+bGlicmFyaWFuPC9BPiBhdCAo NzY1KSAyODctMTI1NiBleHQuIDUwNS4NCg0KPENFTlRFUj4NCjxIUiBBTElHTj1jZW50ZXIg U0laRT0zIFdJRFRIPTgwJT4NCjwvQ0VOVEVSPg0KPEg0IGFsaWduPSJsZWZ0Ij5SRUNPR05J WklORyBJTkRJVklEVUFMUzwvSDQ+DQoNCg0KPGRpdiBhbGlnbj0ibGVmdCI+DQo8aW1nIHNy Yz0iL2ltYWdlcy9hbWFkb3QuZ2lmIiBBTElHTj1UT1AgV0lEVEg9MTcgSEVJR0hUPTE4IEJP UkRFUj0wIFZTUEFDRT0wIEhTUEFDRT01IEFMVD0iKiI+PEI+PEEgTkFNRT0iTGVhZGVyIE1l bWJlciI+TGVhZGVyIE1lbWJlcjwvQT48L0I+DQo8L2Rpdj4NCg0KDQogIDxwIGFsaWduPSJs ZWZ0Ij4NCiAgQSBwcm9ncmFtIGRlc2lnbmVkIHRvIHJlY29nbml6ZSBsZWFkZXJzIGluIHRo ZSBtb2RlbGluZyBjb21tdW5pdHkuICBUaHJlZSBjbGFzc2lmaWNhdGlvbnMgZXhpc3Q6ICBB ZG1pbmlzdHJhdGl2ZSwgSW5kdXN0cnksIGFuZCBTY2llbnRpZmljLiAgTWVtYmVycyByZWNv Z25pemVkIGluIHRoaXMgcHJvZ3JhbSBoZWxwIHRvIGFkbWluaXN0ZXIgQWNhZGVteSBhY3Rp dml0aWVzIGFzIHdlbGwgYXMgbWFpbnRhaW4gYW5kIHZvdGUgb24gdGhlIEFNQSBieWxhd3Mu ICBJbmZvcm1hdGlvbiBhbmQgYXBwbGljYXRpb25zIGFyZSBhdmFpbGFibGUgZm9ybSB0aGUg PEEgSFJFRj0ibWFpbHRvOmplYW5uaWVoQG1vZGVsYWlyY3JhZnQub3JnIj5NZW1iZXJzaGlw IERlcGFydG1lbnQ8L0E+IGF0IEFNQSBIZWFkcXVhcnRlcnMuDQo8UCBhbGlnbj0ibGVmdCI+ DQoNCjxkaXYgYWxpZ249ImxlZnQiPg0KPGltZyBzcmM9Ii9pbWFnZXMvYW1hZG90LmdpZiIg QUxJR049VE9QIFdJRFRIPTE3IEhFSUdIVD0xOCBCT1JERVI9MCBWU1BBQ0U9MCBIU1BBQ0U9 NSBBTFQ9IioiPjxCPjxBIE5BTUU9IkxlYWRlciBDbHViIFByb2dyYW0iPkxlYWRlciBDbHVi IFByb2dyYW08L0E+PC9CPg0KPC9kaXY+DQoNCg0KICA8cCBhbGlnbj0ibGVmdCI+DQogIElu IGFuIGVmZm9ydCB0byByZWNvZ25pemUgdGhlIGxlYWRlcnNoaXAgb2YgdGhlIGZpbmVzdCBh bmQgbW9zdCBkZWRpY2F0ZWQgQU1BIENoYXJ0ZXJlZCBDbHVicywgdGhlIEFjYWRlbXkgb2Zm ZXJzIHRoZSBMZWFkZXIgQ2x1YiBBd2FyZHMuICBUaGVzZSBhd2FyZHMgY2FuIGJlIGVhcm5l ZCBieSBhbnkgQU1BIENoYXJ0ZXJlZCBDbHViIHRoYXQgZGVtb25zdHJhdGVzIHRoZSBoaWdo ZXN0IHN0YW5kYXJkcyBvZiBjb21tdW5pdHkgc2VydmljZSwgaW52b2x2ZW1lbnQgYW5kIG1v ZGVsaW5nIGFjdGl2aXR5LiAgRm9yIGZ1cnRoZXIgaW5mb3JtYXRpb24gb24gcXVhbGlmaWNh dGlvbiwgcGxlYXNlIGNvbnRhY3QgdGhlIDxBIEhSRUY9Im1haWx0bzphcHJpbGhAbW9kZWxh aXJjcmFmdC5vcmciPlByb2dyYW1zIERlcGFydG1lbnQuPC9BPg0KPFAgYWxpZ249ImxlZnQi Pg0KDQo8ZGl2IGFsaWduPSJsZWZ0Ij4NCjxpbWcgc3JjPSIvaW1hZ2VzL2FtYWRvdC5naWYi IEFMSUdOPVRPUCBXSURUSD0xNyBIRUlHSFQ9MTggQk9SREVSPTAgVlNQQUNFPTAgSFNQQUNF PTUgQUxUPSIqIj48Qj48QSBOQU1FPSJDb250ZXN0IERpcmVjdG9yIj5Db250ZXN0IERpcmVj dG9yPC9BPjwvQj4NCjwvZGl2Pg0KDQoNCiAgPHAgYWxpZ249ImxlZnQiPg0KICBDb250ZXN0 IERpcmVjdG9ycyBhcmUgcmVzcG9uc2libGUgZm9yIG9yZ2FuaXppbmcgYW5kIHJ1bm5pbmcg Zmx5aW5nIGV2ZW50cyB0aHJvdWdoIHRoZSBBTUEgc2FuY3Rpb25pbmcgcHJvZ3JhbS4gIElu Zm9ybWF0aW9uIGFuZCBhcHBsaWNhdGlvbnMgYXJlIGF2YWlsYWJsZSBmcm9tIHRoZSA8QSBI UkVGPSJtYWlsdG86YW15d0Btb2RlbGFpcmNyYWZ0Lm9yZyI+Q29tcGV0aXRpb25zL1RlY2hu aWNhbCBEZXBhcnRtZW50PC9BPiBhdCBBTUEgSGVhZHF1YXJ0ZXJzLiBDYWxsICg3NjUpIDI4 Ny0xMjU2Lg0KPFAgYWxpZ249ImxlZnQiPg0KDQo8ZGl2IGFsaWduPSJsZWZ0Ij4NCjxpbWcg c3JjPSIvaW1hZ2VzL2FtYWRvdC5naWYiIEFMSUdOPVRPUCBXSURUSD0xNyBIRUlHSFQ9MTgg Qk9SREVSPTAgVlNQQUNFPTAgSFNQQUNFPTUgQUxUPSIqIj48Qj48QSBOQU1FPSJBcHByZWNp YXRpb24gQXdhcmRzIj5BcHByZWNpYXRpb24gQXdhcmRzPC9BPjwvQj4NCjwvZGl2Pg0KDQoN CiAgPHAgYWxpZ249ImxlZnQiPg0KICBDbHVicyBtYXkgcHVyY2hhc2UgYXBwcmVjaWF0aW9u IGF3YXJkcyBmb3IgZmx5aW5nIHNpdGUgcHJvdmlkZXJzIGFuZCBvdGhlcnMgd2hvIGFzc2lz dCBjaGFydGVyZWQgY2x1YnMgaW4gdGhlaXIgZW5kZWF2b3JzLiAgVGhlIEFNQSBjZXJ0aWZp Y2F0ZSBpcyBuaWNlbHkgZGVzaWduZWQgYW5kIGFycmFuZ2VkIGZvciBzaWduYXR1cmUgYnkg YSBjbHViIG9mZmljZXIuICBBIHdhbG51dC1tb3VudGVkIHBsYXF1ZSwgd2l0aCB1cCB0byAz MCB3b3JkcyBpbnNjcmliZWQgYnkgY2FsbGlncmFwaHkgYW5kIGRlY29yYXRlZCB3aXRoIGEg Z29sZCBzZWFsIGFuZCByZWQsIHdoaXRlLCBhbmQgYmx1ZSByaWJib24sIGlzIG9ubHkgJDI1 IHBvc3RwYWlkLiBDb250YWN0IHRoZSA8QSBIUkVGPSJtYWlsdG86YXByaWxoQG1vZGVsYWly Y3JhZnQub3JnIj5Qcm9ncmFtcyBEZXBhcnRtZW50LjwvQT4NCg0KICA8ZGl2IGFsaWduPSJs ZWZ0Ij4NCjxpbWcgc3JjPSIvaW1hZ2VzL2FtYWRvdC5naWYiIEFMSUdOPVRPUCBXSURUSD0x NyBIRUlHSFQ9MTggQk9SREVSPTAgVlNQQUNFPTAgSFNQQUNFPTUgQUxUPSIqIj48Qj48QSBO QU1FPSJsaWZlbWVtYmVyLmh0bSI+TGlmZSBNZW1iZXJzaGlwPC9BPjwvQj4NCiAgPC9kaXY+ DQoNCg0KICA8cCBhbGlnbj0ibGVmdCI+DQogIEZvciBhIGNvbnRyaWJ1dGlvbiBvZiAkMSw1 MDAsIHlvdSBiZWNvbWUgYW4gQU1BIGNvbnRyaWJ1dGluZyBtZW1iZXIgd2l0aCBMaWZlIG1l bWJlcnNoaXAgcHJpdmlsZWdlcy4gWW91ciBMaWZlIG1lbWJlcnNoaXAgcHJvdmlkZXMgYXV0 b21hdGljIGFubnVhbCByZW5ld2FsIG9mIEFNQSBtZW1iZXJzaGlwIHdoaWNoIGluY2x1ZGVz OjxCUj4NCk1vZGVsIEZsaWVyJ3MgbGljZW5zZTxCUj4NCjxJPk1vZGVsIEF2aWF0aW9uPC9J PjxCUj4NClBlcm1hbmVudCBicm9uemUgbGljZW5zZSBjYXJkPEJSPg0KTGlmZSBNZW1iZXIg Y2xvdGggcGF0Y2g8QlI+DQpDb250aW51aW5nIHJlY29nbml0aW9uIG9mIHlvdXIgY29udHJp YnV0aW9uIHRocm91Z2ggaXNzdWFuY2Ugb2Ygc3BlY2lhbCAiTCIgQU1BIG51bWJlci4gRXhh bXBsZTogTDMzMDxCUj4NCkNhbGwgb3Igd3JpdGUgPEEgSFJFRj0ibWFpbHRvOmplYW5uaWVo QG1vZGVsYWlyY3JhZnQub3JnIj5MaWZlIE1lbWJlciBDbGVyazwvQT4gYXQgQU1BIEhlYWRx dWFydGVycyBmb3IgYWRkaXRpb25hbCBpbmZvcm1hdGlvbi4NCjxDRU5URVI+DQoNCjxIUiBB TElHTj1jZW50ZXIgU0laRT0zIFdJRFRIPTgwJT4NCjwvQ0VOVEVSPg0KPEg0IGFsaWduPSJs ZWZ0Ij5QQVJUSUNJUEFUSU5HIElOIFdPUkxELUNMQVNTIEFFUk9NT0RFTElORyBDT01QRVRJ VElPTjwvSDQ+DQoNCg0KPGRpdiBhbGlnbj0ibGVmdCI+DQo8aW1nIHNyYz0iL2ltYWdlcy9h bWFkb3QuZ2lmIiBBTElHTj1UT1AgV0lEVEg9MTcgSEVJR0hUPTE4IEJPUkRFUj0wIFZTUEFD RT0wIEhTUEFDRT01IEFMVD0iKiI+PEI+PEEgTkFNRT0iV29ybGQgQ2hhbXBpb25zaGlwcyI+ V29ybGQgQ2hhbXBpb25zaGlwczwvQT48L0I+DQo8L2Rpdj4NCg0KDQogIDxwIGFsaWduPSJs ZWZ0Ij4NCiAgQW55IEFNQSBtZW1iZXIgaGFzIHRoZSBvcHBvcnR1bml0eSB0byByZXByZXNl bnQgdGhlIFUuUy5BLiBhbmQgQU1BIGluIGFuIGludGVybmF0aW9uYWwgYWVyb21vZGVsaW5n IGNvbXBldGl0aW9uIGV2ZW50LiAgVHJpYWxzIGZvciBzZWxlY3RpbmcgbWVtYmVycyBvZiB3 b3JsZCBjaGFtcGlvbnNoaXAgdGVhbXMgYXJlIGhlbGQgYW5udWFsbHkuICBEZXRhaWxzIGFy ZSBwdWJsaXNoZWQgaW4gTW9kZWwgQXZpYXRpb24gbWFnYXppbmUuICBUaGV5IGFyZSBhbHNv IG9idGFpbmFibGUgdGhyb3VnaCB0aGUgPEEgSFJFRj0ibWFpbHRvOnNrYWx1ZkBtb2RlbGFp cmNyYWZ0Lm9yZyI+Q29tcGV0aXRpb25zL1RlY2huaWNhbCBEZXBhcnRtZW50PC9BPiBhdCBB TUEgSGVhZHF1YXJ0ZXJzLiAgQWxsIGludGVybmF0aW9uYWwgZXZlbnRzIGFyZSBhdXRob3Jp emVkIGJ5IHRoZSA8QSBIUkVGPSJodHRwOi8vd3d3LmZhaS5vcmcvIj5G6WTpcmF0aW9uIEHp cm9uYXV0aXF1ZSBJbnRlcm5hdGlvbmFsZS48L0E+DQoNCjxDRU5URVI+DQo8SFIgQUxJR049 Y2VudGVyIFNJWkU9MyBXSURUSD04MCU+DQo8L0NFTlRFUj4NCjxINCBhbGlnbj0ibGVmdCI+ QURESVRJT05BTCBCRU5FRklUIFBMQU5TIEZPUiBNRU1CRVJTPC9IND4NCg0KDQo8ZGl2IGFs aWduPSJsZWZ0Ij4NCjxpbWcgc3JjPSIvaW1hZ2VzL2FtYWRvdC5naWYiIEFMSUdOPVRPUCBX SURUSD0xNyBIRUlHSFQ9MTggQk9SREVSPTAgVlNQQUNFPTAgSFNQQUNFPTUgQUxUPSIqIj48 Qj48QSBOQU1FPSJPdmVydmlldyI+T3ZlcnZpZXc8L0E+PC9CPg0KPC9kaXY+DQoNCg0KICA8 cCBhbGlnbj0ibGVmdCI+DQogIFRoZSBBY2FkZW15IG9mIE1vZGVsIEFlcm9uYXV0aWNzIGhh cyBlbnRlcmVkIGludG8gd29ya2luZyBhcnJhbmdlbWVudHMgd2l0aCBwcml2YXRlIGNvbXBh bmllcyB0aGF0IGhhdmUgYWdyZWVkIHRvIHByb3ZpZGUgdmFyaW91cyB0eXBlcyBvZiBpbnN1 cmFuY2UgcGxhbnMgdG8gQU1BIG1lbWJlcnMuICBUaGVzZSBwbGFucyBhcmUgYmFzZWQgb24g dGhlIGFiaWxpdHkgdG8gb2ZmZXIgYWR2YW50YWdlb3VzIHByaWNpbmcgc2NoZWR1bGVzIHRv IHRoZSBsYXJnZSAicG9vbCIgb2YgbWVtYmVyc2hpcCBjb250YWN0cy4NCg0KPENFTlRFUj4N CjxIUiBBTElHTj1jZW50ZXIgU0laRT0zIFdJRFRIPTgwJT4NCjwvQ0VOVEVSPg0KPEg0IGFs aWduPSJsZWZ0Ij5BVkFJTEFCTEUgQkVORUZJVFM8L0g0Pg0KDQoNCjxkaXYgYWxpZ249Imxl ZnQiPg0KPGltZyBzcmM9Ii9pbWFnZXMvYW1hZG90LmdpZiIgQUxJR049VE9QIFdJRFRIPTE3 IEhFSUdIVD0xOCBCT1JERVI9MCBWU1BBQ0U9MCBIU1BBQ0U9NSBBTFQ9IioiPjxCPjxBIE5B TUU9Ikdyb3VwIFRlcm0gTGlmZSBJbnN1cmFuY2UiPkdyb3VwIFRlcm0gTGlmZSBJbnN1cmFu Y2U8L0E+PC9CPg0KPC9kaXY+DQoNCg0KICA8cCBhbGlnbj0ibGVmdCI+DQogIFRoZSBpbnN1 cmFuY2UgY29tcGFueSBoYXMgcG9saWNpZXMgd2l0aCBkZWF0aCBiZW5lZml0cyBvZiB1cCB0 byAkMjAwLDAwMCAoaW4gJDEwLDAwMCBpbmNyZW1lbnRzKSBhdmFpbGFibGUgdG8gQU1BIG1l bWJlcnMgYW5kIHRoZWlyIHNwb3VzZXMsIGFuZCB1cCB0byAkMiw1MDAgZm9yIGVhY2ggb2Yg dGhlaXIgY2hpbGRyZW4uICBDYWxsIDEtODAwLTMyMy0yMTA2IGZvciBtb3JlIGluZm9ybWF0 aW9uLg0KPFAgYWxpZ249ImxlZnQiPg0KDQo8ZGl2IGFsaWduPSJsZWZ0Ij4NCjxpbWcgc3Jj PSIvaW1hZ2VzL2FtYWRvdC5naWYiIEFMSUdOPVRPUCBXSURUSD0xNyBIRUlHSFQ9MTggQk9S REVSPTAgVlNQQUNFPTAgSFNQQUNFPTUgQUxUPSIqIj48Qj48QSBOQU1FPSIkMTAsMDAwIEFj Y2lkZW50IEluc3VyYW5jZSI+JDEwLDAwMCBBY2NpZGVudCBJbnN1cmFuY2U8L0E+PC9CPg0K PC9kaXY+DQoNCg0KICA8cCBhbGlnbj0ibGVmdCI+DQogIFRoZSBpbnN1cmFuY2UgY29tcGFu eSBtYWtlcyBhY2NpZGVudCBpbnN1cmFuY2UgYXZhaWxhYmxlIHRvIEFNQSBtZW1iZXJzLiAg SXQgcHJvdmlkZXMgY292ZXJhZ2UgZm9yIGFjY2lkZW50YWwgZGVhdGgsIGxvc3Mgb2Ygc2ln aHQsIG9yIGRpc21lbWJlcm1lbnQgd2hpbGUgdHJhdmVsaW5nIHRvLCB3aGlsZSBhdCwgb3Ig d2hpbGUgcmV0dXJuaW5nIGZvcm0gYW4gQU1BIHNhbmN0aW9uZWQgZXZlbnQuIENhbGwgMS04 MDAtMzIzLTIxMDYgZm9yIG1vcmUgaW5mb3JtYXRpb24uDQo8UCBhbGlnbj0ibGVmdCI+DQoN CjxkaXYgYWxpZ249ImxlZnQiPg0KPGltZyBzcmM9Ii9pbWFnZXMvYW1hZG90LmdpZiIgQUxJ R049VE9QIFdJRFRIPTE3IEhFSUdIVD0xOCBCT1JERVI9MCBWU1BBQ0U9MCBIU1BBQ0U9NSBB TFQ9IioiPjxCPjxBIE5BTUU9IkV4Y2VzcyBNYWpvciBNZWRpY2FsIEdyb3VwIEluc3VyYW5j ZSI+RXhjZXNzIE1ham9yIE1lZGljYWwgR3JvdXAgSW5zdXJhbmNlPC9BPjwvQj4NCjwvZGl2 Pg0KDQoNCiAgPHAgYWxpZ249ImxlZnQiPg0KICBBTUEgbWVtYmVycyBjYW4gdGFrZSBhZHZh bnRhZ2Ugb2YgdXAgdG8gJDEgbWlsbGlvbiBpbiBhZmZvcmRhYmxlIGhvc3BpdGFsIGFuZCBt ZWRpY2FsIGdyb3VwIGluc3VyYW5jZSB0byBoZWxwIHNhZmVndWFyZCB0aGVpciBmYW1pbGll cyBhZ2FpbnN0IGNhdGFzdHJvcGhpYyBoZWFsdGggY2FyZSBleHBlbnNlcy4gIENhbGwgMS04 MDAtMzY4LTUzOTYgYW5kIGFzayBmb3IgTmF0aW9uYWwgQWVyb25hdXRpYyBBc3NvY2lhdGlv biBncm91cC4gIChUaGUgQWNhZGVteSBvZiBNb2RlbCBBZXJvbmF1dGljcyBpcyBhbiBhZmZp bGlhdGUgb2YgdGhlIE5hdGlvbmFsIEFlcm9uYXV0aWMgQXNzb2NpYXRpb24uKQ0KPFAgYWxp Z249ImxlZnQiPg0KDQo8ZGl2IGFsaWduPSJsZWZ0Ij4NCjxpbWcgc3JjPSIvaW1hZ2VzL2Ft YWRvdC5naWYiIEFMSUdOPVRPUCBXSURUSD0xNyBIRUlHSFQ9MTggQk9SREVSPTAgVlNQQUNF PTAgSFNQQUNFPTUgQUxUPSIqIj48Qj48QSBOQU1FPSJWaXNpb24gQ2FyZSBQbGFuIj5WaXNp b24gQ2FyZSBQbGFuPC9BPjwvQj4NCjwvZGl2Pg0KDQoNCiAgPHAgYWxpZ249ImxlZnQiPg0K ICBBTUEgaXMgcGxlYXNlZCB0byBhbm5vdW5jZSBhIG5ldyB2aXNpb24gY2FyZSBiZW5lZml0 IHByb2dyYW0gdGhyb3VnaCBPVVRMT09LIFZpc2lvbiBTZXJ2aWNlcy4gIEEgbmF0aW9ud2lk ZSBuZXR3b3JrIG9mIG92ZXIgMzcwMCBleWUgY2FyZSBwcm9mZXNzaW9uYWxzIGNhbiBzYXZl IHlvdSBhbmQgeW91ciBmYW1pbHkgaHVuZHJlZHMgb2YgZG9sbGFycyBvbiBhbGwgdGhlaXIg ZXlld2VhciBuZWVkcy4gIE9VVExPT0sgVmlzaW9uIFNlcnZpY2VzIG9mZmVycyB1cCB0byA1 MCUgc2F2aW5ncyBvbiBmcmFtZXMsIGRlc2lnbmVyIGZyYW1lcywgbGVuc2VzIG9mIGFsbCBr aW5kcywgb3B0aW9ucyBvZiBhbGwga2luZHMsIGFuZCBjb250YWN0IGxlbnNlcy4gIEFNQSBt ZW1iZXJzIG1heSBwdXJjaGFzZSB0aGUgT1VUTE9PSyBwcm9ncmFtIGZvciAkNi45NSAoYW5u dWFsIG1lbWJlcnNoaXApIGZvciB0aGUgZW50aXJlIGZhbWlseSwgYSA2MCUgc2F2aW5ncyBv ZmYgdGhlIHJlZ3VsYXIgYW5udWFsIHByaWNlIG9mICQxOC4wMC4gIFRoZSBwbGFuIGlzIHNp bXBsZSB0byB1c2U7IHByZXNlbnQgeW91ciBtZW1iZXJzaGlwIGNhcmQgYW5kIHBheSB0aGUg ZGlzY291bnRlZCBwcmljZSBhdCB0aW1lIG9mIHB1cmNoYXNlIC0gbm8gZm9ybXMgb3IgcGFw ZXJzIHRvIGZpbGUuICBUbyByZWNlaXZlIHlvdXIgbWVtYmVyc2hpcCBjYXJkLCBmb3J3YXJk IGEgY2hlY2sgb3IgbW9uZXkgb3JkZXIgZm9yICQ2Ljk1IHRvOiAgT3V0bG9vayBWaXNpb24g U2VydmljZXMsIDQwIE4uIENlbnRlciBTdC4sIFN1aXRlIDEwNCwgTWVzYSwgQVogODUyMDEu DQoNCjxDRU5URVI+DQoNCg0KPEhSIEFMSUdOPWNlbnRlciBTSVpFPTMgV0lEVEg9ODAlPg0K DQo8L0NFTlRFUj4NCiAgPHAgYWxpZ249ImxlZnQiPg0KUmV0dXJuIHRvPEEgSFJFRj0iI3Rv cCI+IHRvcDwvQT4gb2YgZG9jdW1lbnQuPFA+DQoNCg0KPEZPTlQgU0laRT0iLTEiPlRoaXMg cGFnZSwgYW5kIGFsbCBjb250ZW50cywgYXJlIENvcHlyaWdodCCpIDE5OTUtMjAwMSBieSBU aGUgQWNhZGVteQ0Kb2YgTW9kZWwgQWVyb25hdXRpY3MgSW5jLiwgTXVuY2llLCBJbmRpYW5h LiBUaGUgQU1BIFdpbmdzICZhbXA7IFRvcmNoIGFyZSB0cmFkZW1hcmtzIG9mIHRoZSBBY2Fk ZW15IG9mIE1vZGVsIEFlcm9uYXV0aWNzLiBBbGwgcmlnaHRzIHJlc2VydmVkLjxCUj4NCjxJ Pkxhc3QgTW9kaWZpZWQgNy8wMy8wMTwvST4NCjwvZm9udD4NCjxDRU5URVI+DQombmJzcDsN CjwvVEQ+DQo8L1RSPg0KPC9UQUJMRT4NCjxETD4NCjxEVD4NCjwvREw+DQo8L0JPRFk+DQo8 L0hUTUw+DQ=9 ________________________________________________________________________________
Date: May 11, 2003
Subject: super 8s & acro weight
Can someone email me a link that has details on how you install a 540 onto a RV8? Anyone know how much additional weight these installations are averaging? Also, how do you know for sure which acro weight limit is the one for your plane? ________________________________________________________________________________
Date: May 11, 2003
I had to widen my roll-over bar less than an inch (using an engine hoist) to get a good fit. Something's wrong if you have an eight inch discrepancy..... - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com 2003 - The year of flight! > -----Original Message----- > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of colin jordan > Sent: Sunday, May 11, 2003 12:21 AM > To: rv8-list(at)matronics.com > Subject: RV8-List: Fuselage jig for free and rollbar dimensions > > > > Hi listers , > > Does anybody know what the correct dimensions of the roll bar > (wd814) should be ? Mine measures 24"between the two little > inboard tabs that point down. My fuselage measures 32" at > that station. Both figures seem too exact to be chance but I > am guessing that the roll bar is the one that needs to be > adjusted. I could not find any dimensions on the plans .I > should also add that my kit is an early pre powder coated one .(#255) > > If any one needs a fuselage jig in the B.C. Kelowna area I > have one for the asking. > > Thanks.Colin. ________________________________________________________________________________
Subject: Kevins code
Date: May 11, 2003
Does anyone know how to decipher kevins post? ________________________________________________________________________________
From: "Dave Hamilton" <dshamilton(at)bellsouth.net>
Subject: Zener diodes
Date: May 11, 2003
I have an infinity stick grip with the starter button on the top right. I have been told that a zener diode wired properly will prevent the starter from engaging if the prop is already turning (if the ALT is producing power). Does anyone know how to wire these things in? Dave Hamilton ________________________________________________________________________________
Date: May 11, 2003
I'm using a second 'starter enable' switch on the console instead. Not flying yet. Is there an advantage to using the diode over the switch? - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com 2003 - The year of flight! > -----Original Message----- > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of > Dave Hamilton > Sent: Sunday, May 11, 2003 5:51 PM > To: rv8-list(at)matronics.com > Subject: RV8-List: Zener diodes > > > --> > > > I have an infinity stick grip with the starter button on the > top right. I have been told that a zener diode wired properly > will prevent the starter from engaging if the prop is already > turning (if the ALT is producing power). > > Does anyone know how to wire these things in? > > Dave Hamilton > ________________________________________________________________________________
Date: May 11, 2003
Subject: Re: Fuselage jig for free and rollbar dimensions
Listers, I measured my 8 QB today. S/N 81735, and got essentially the same measurements. If you place the roll bar on the fuselage I have about 1/4" slack. Rollbar needs to be opened up. Have you tried placing rollbar on fuselage? Paul ________________________________________________________________________________
rv-list(at)matronics.com, vansairforce(at)yahoogroups.com
Subject: Canoopy cuttin time
Date: May 12, 2003
Listers: I have searched the archives, but cant find what I am looking for. Does anybidy know of a good website, etc, that shows and explains well, the process of cutting and fitting the RV8 Canopy. Thanks Al Grajek ________________________________________________________________________________
Date: May 12, 2003
Subject: Re: Canoopy cuttin time
I believe Orndorffs finishing video shows it about as well as anything else. ________________________________________________________________________________
From: "Scott Clarkson" <sclarkson(at)tellurian.net>
Date: May 12, 2003
Al, Before you go and cut the flange off around the bottom, make sure you will have sufficient edge distance to the rivets on the sides. I ended up cutting the flange off with the cut-off wheel vertical instead of horizontal and took advantage of the thickness of the flange so I had enough material. Cutting with the wheel horizontal on Van's scribe line would have put me dangerously close to the edge which would have resulted in a cracked canopy and a lot of profanity. Scott Clarkson ----- Original Message ----- From: "Al Grajek" <algrajek(at)msn.com> ; ; Subject: RV8-List: Canoopy cuttin time > > Listers: > I have searched the archives, but cant find what I am looking for. Does > anybidy know of a good website, etc, that shows and explains well, the > process of cutting and fitting the RV8 Canopy. > Thanks > Al Grajek > > ________________________________________________________________________________
Date: May 12, 2003
Al Grajek wrote: > > Listers: > I have searched the archives, but cant find what I am looking for. Does > anybidy know of a good website, etc, that shows and explains well, the > process of cutting and fitting the RV8 Canopy. > Thanks > Al Grajek > Al - I have heard so much about the trepidations and timidity about dealing with the canopy. I was so snakebit I put it off until I could not avoid it anymore. My advice? It ain't that big of a deal. The canopy is like the rest of Van's kit; just follow the instructions and do it step by step, being careful and not using a lot of force. I think an important ingredient is heat. Plexiglass likes heat. I had the workshop at 80degF when I did my cutting. I used a diegrinder and it cut through the material like butter. Same for drilling. Get the material warm and use the special plexiglas drill bits. Sand down the edges with the final sanding at least a 400, and preferably a 600 grit until the edges look transparent. Under these conditions you'll find the plexiglas to be remarkably tough and capable of withstanding a lot of stress. Important; be sure you use the weak aluminum rivets when attaching to the canopy frame, and not the CS4-4 or equivilant. You will be sure to crack the canopy if you use the CS4s. Just follow the instructions, use your instincts, sense when you are about to apply what feels like too much force, and step back for a moment to reassure yourself that you're on the right track. You too will wind up with a good-looking, flawless canopy wondering how you did such a good job, just like I did. Keep on truckin' Don Miller ________________________________________________________________________________
Subject: Re: adverse yaw
Date: May 12, 2003
> the question is, IN FLIGHT, does the RV8 show > much "adverse yaw"? > > andrew morgan Adverse yaw? I go back and forth between my RV-8 and a glider and they couldn't be more different. I've never flown an aircraft with less adverse yaw than an RV, and of course gliders with their ailerons near the end of a 60' wingspan have LOTS of adverse yaw. Once above pattern speed you really use very little rudder in an RV (some will say none, but if you *really* want to keep the ball centered you are applying tiny bits of pressure when maneuvering). In the glider you put in a healthy does of rudder when banking the aircraft almost before the aileron. Cessnas, Citabrias, etc. are somewhere in the middle. My understanding is that adverse yaw is largely a function of wingspan and the leverage the extra drag of the outboard (rising, therefore increased drag) aileron has relative to the fuselage. Randy Lervold RV-8, 307 hrs. ________________________________________________________________________________
Subject: Re Roll bar
Date: May 12, 2003
Thanks Larry and Paul, I guess I did not explain my self well, I too only have about a 1/4 inch of play when I put the roll bar on the fuselage. The 24" was just a convenient place to measure on the roll bar and the 32" was to the outside of the fuselage.That said it would appear that the roll bar is the piece I need to work on. Larry I am curious how you used the engine hoist to spread your roll bar , I have tried the approved Van's method but neither my back nor my muscles were up to the job! ________________________________________________________________________________
Date: May 13, 2003
Subject: Re: Re Roll bar
Look at the builders hints in the RV White pages. There are pictures of a simple way to correct the problem. I am going to use this method. Paul ________________________________________________________________________________
Date: May 13, 2003
Look at this: http://bowenaero.com/pix/rollbar.jpg - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com 2003 - The year of flight! > --- colin jordan wrote: > > > > > > Thanks Larry and Paul, > > I guess I did not explain my self well, I too only have about a 1/4 > > inch of play when I put the roll bar on the fuselage. The > 24" was just > > a convenient place to measure on the roll bar and the 32" > was to the > > outside of the fuselage.That said it would appear that the > roll bar is > > the piece I need to work on. Larry I am curious how you used the > > engine hoist to spread your roll bar , I have tried the > approved Van's > > method but neither my back nor my muscles were up to the job! ________________________________________________________________________________
Subject: My Hat in the Ring
Date: May 14, 2003
Greetings, Listers! I'm a long-time listener, but now I must pipe up... Why? Because I am throwing my hat in the ring...my empennage and wing kits have been ordered, my brain filled over capacity by Becki & George Orndorff, and my pocketbook emptied by tool suppliers... So I shall soon begin to bash tin in earnest! THANK YOU ALL in advance for the support! Happy skies! -Scott Future RV-8 Builder (less than a week away...) ________________________________________________________________________________
Subject: Power Charts
Date: May 15, 2003
I'm looking for power charts for 75%, 65% and 55%. I will be using the XP360 engine with a Sensenick 72FM8S9-1-86 prop. Steve Glasgow ________________________________________________________________________________
Subject: Brake Break-in
Date: May 15, 2003
I remember reading a great article about break-in procedures for new brakes very recently but being the bone head I am I must have deleted it. Had to do with taxing with power and holding brakes. Can anyone help be in this regard. Steve Glasgow ________________________________________________________________________________
Date: May 15, 2003
Subject: Re: My Hat in the Ring
Hi Scott Welcome fellow addict. Your home will now be safer since all those bales of money you used to trip over in the middle of the night will all be gone! Remember that persistence is more importance than intelligence and skill. So stay with it, look at lots of finished airplanes, and ask plenty of questions. See you at a fly-in. Rob Miller -8 N262RM "Bad Cat" 62 hours Pictures available at www.homebuiltairplanes.com --- es_god@cap-es.net wrote: > > Greetings, Listers! I'm a long-time listener, but now I must pipe up... > Why? Because I am throwing my hat in the ring...my empennage and wing > kits > have been ordered, my brain filled over capacity by Becki & George > Orndorff, > and my pocketbook emptied by tool suppliers... So I shall soon begin to > bash tin in earnest! THANK YOU ALL in advance for the support! > > Happy skies! > -Scott > Future RV-8 Builder (less than a week away...) > > > > > > __________________________________ http://search.yahoo.com ________________________________________________________________________________
Date: May 16, 2003
Subject: Polished aluminum
I'd like to share ideas with people who love polished airplanes. I just went through the first phase of achieving a (hopefully) mirror finish on my -8, N638DM. It created a pretty shine, but I've got some swirls to work out and a heckofa mess to clean up. Tip #1; wear long-sleeved shirts and gloves, and do it outside if possible. Tip # 2; if using an oil-based polishing compound, a little flour on an old t-shirt will absorb the compound and help clean the inevitable spatter off the adjacent painted surfaces. Any other tips about achieving and preserving that shine? I'd like to hear from you. Don Miller ________________________________________________________________________________
Date: May 16, 2003
Subject: RV Fly-In at Post Air - 7L8 Indianapolis
Many of you may know that John Marshall, RV builder extraordinaire with 7 done and 2 under construction, has for years had a corn roast at his grass strip in Acton, IN on the July 4th weekend. This year however, mainly because of large attendance, the event is being moved to Martin Fall's Post Air airport (7L8) located at the SE corner of Indianapolis. So, all you RV drivers out there are invited to a Corn Roast at High Noon, July 5th, 2003. Any questions email me at tlloyd6250(at)comcast.net Tom Lloyd RV8 N842TL ________________________________________________________________________________
Date: May 16, 2003
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Subject: Re: Polished aluminum
In the 21 years of the RVAtor there was a article about protecting bare aluminium. There is this magic stuff that is used by the mobile home trailer company which builds all aluminium trailers. Sorry I dont have the name. > >I'd like to share ideas with people who love polished airplanes. I >just went through the first phase of achieving a (hopefully) mirror >finish on my -8, N638DM. It created a pretty shine, but I've got some >swirls to work out and a heckofa mess to clean up. Tip #1; wear >long-sleeved shirts and gloves, and do it outside if possible. Tip # >2; if using an oil-based polishing compound, a little flour on an old >t-shirt will absorb the compound and help clean the inevitable spatter >off the adjacent painted surfaces. Any other tips about achieving and >preserving that shine? I'd like to hear from you. > >Don Miller > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
From: "Noel & Yoshie Simmons" <noel(at)blueskyaviation.net>
Date: May 16, 2003
Don & list, I polished out a GlaStar several months ago using the NewVite system and the instructional video from the Swift Museum. After that I sealed the polished surface with a product I sell called Zoops Seal. This put a clear coat over the polish that is much more resistant to tarnishing. Finger prints that are left on for over a week are wiped off with a polish rag or washed away. I used about a quart of material on the GlaStar. With my 8A I am expecting to use just less than two quarts. Noel Simmons Blue Sky Aviation, Inc. "We do builder assistance!" Toll Free: 866-859-0390 info(at)blueskyaviation.net www.blueskyaviation.net RV-8A in progress IO-360-A1B6: Aero Composites CS: IK-2000: making the decision of radios. RV-6A in Progress O-320; fixed pitch; CH-601 panel with Dynon (WOW!) -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Don Miller Subject: RV8-List: Polished aluminum I'd like to share ideas with people who love polished airplanes. I just went through the first phase of achieving a (hopefully) mirror finish on my -8, N638DM. It created a pretty shine, but I've got some swirls to work out and a heckofa mess to clean up. Tip #1; wear long-sleeved shirts and gloves, and do it outside if possible. Tip # 2; if using an oil-based polishing compound, a little flour on an old t-shirt will absorb the compound and help clean the inevitable spatter off the adjacent painted surfaces. Any other tips about achieving and preserving that shine? I'd like to hear from you. Don Miller ________________________________________________________________________________
Date: May 16, 2003
Hello Guy's! I just moved my RV-4 from the Garage to the Hayward Airport to complete the engine and avionics and get this baby in the air. Anyone with a lead on an IO-320 or 360 / and any 2-1/4 inch instruments would be appreciated. Ron Patterson N8ZD (reserved) ________________________________________________________________________________
Subject: Re: Power Charts
Date: May 17, 2003
I went with an engine power monitor for this--love it. http://www.technologykitchen.com/projects.htm Greg RV8 N89GM, 250 hrs On Thu, 2003-05-15 at 05:27, willfly wrote: > > I'm looking for power charts for 75%, 65% and 55%. > > I will be using the XP360 engine with a Sensenick 72FM8S9-1-86 prop. > > Steve Glasgow > > -- Greg V. Miller ________________________________________________________________________________
Date: May 18, 2003
Subject: IO-360 induction
I am trying to fit the fiberglass induction pipe from Vans that goes to a front induction throttle body on an IO-360. It is a fairly old piece, part of a 1999 kit. The problem is that it dosn't clear the starter by a lot. What have people done with this? Were later examples better? I could chop a big piece out of the top of it and make it fit but glass is not my favorite medium. All-metal kit right! Also what would a chop job do to the airflow and the structural strength. Big vacuum inside. Anyway what is the community experience with this? TIA Jim Bean RV-8 engine room ________________________________________________________________________________
Date: May 18, 2003
Subject: Re: IO-360 induction
Jim, I haven't flown yet so I don't know how much clearance will be required, but one thing you can do is file some off the bottom of the starter. Bill at B&C said you can take off an eighth of an inch without a problem because of the thick casing. If you have a different brand you might check with the manufacturer. If you need more space then you'll have to cut out the area below the starter and reglass with as smooth a curve as possible. Danny King did this and said the airflow was fine. Good luck, Joel Harding On Sunday, May 18, 2003, at 04:26 PM, Jim Bean wrote: > > I am trying to fit the fiberglass induction pipe from Vans that goes to > a front induction throttle body on an IO-360. It is a fairly old piece, > part of a 1999 kit. The problem is that it dosn't clear the starter by > a > lot. What have people done with this? Were later examples better? > > I could chop a big piece out of the top of it and make it fit but glass > is not my favorite medium. All-metal kit right! Also what would a chop > job do to the airflow and the structural strength. Big vacuum inside. > Anyway what is the community experience with this? > > TIA Jim Bean > RV-8 engine room > > > _- > ====================================================================== > _- > ====================================================================== > _- > ====================================================================== > _- > ====================================================================== > > ________________________________________________________________________________
Subject: Dimmer switch
Date: May 19, 2003
I ourchased Vans Dimmer switches for my RV8. Thes come without the needed Knobs. The instuctions say that Radio Shack carries the knobs for the 1/8 " shaft. I have tried 5 Radio Shacks and online,but no luck. Does anyone know where I can get these. Thanks Al Grajek RV8 ________________________________________________________________________________
Date: May 19, 2003
Try www.mcmelectronics.com Chris Stone RV-8 Wings -----Original Message----- From: Al Grajek [mailto:algrajek(at)msn.com] rv-list(at)matronics.com; vansairforce(at)yahoogroups.com Subject: RV8-List: Dimmer switch I ourchased Vans Dimmer switches for my RV8. Thes come without the needed Knobs. The instuctions say that Radio Shack carries the knobs for the 1/8 " shaft. I have tried 5 Radio Shacks and online,but no luck. Does anyone know where I can get these. Thanks Al Grajek RV8 direct advertising on the Matronics Forums. ________________________________________________________________________________
Date: May 19, 2003
Subject: Re: Dimmer switch
Newark Electronics ________________________________________________________________________________
Date: May 20, 2003
Subject: Oxygen bottle size and mounting location
Hello I am going to purchase an oxygen system for the -8 and need to know where others have 'mounted' a portable system, which brand, size of bottle, and how it is working out. No luck in the archives. Rob Miller N262RM -8 "Bad Cat" 66 hours Pictures can be seen at www.homebuiltairplanes.com __________________________________ http://search.yahoo.com ________________________________________________________________________________
Date: May 20, 2003
Hi Jim, I installed an airbox from Brackett for the IO360 in the baffle of the left air intake. Then formed a fiberglass box with a 3" hose connection to the air intake. For the entry of the injection pump I formed a bowl with 3" connection to the pump. I'll be back from vacation in two weeks and send you a picture then. Stephan Servatius RV8 flying 2,5h 80303 Germany Jim Bean schrieb: > > I am trying to fit the fiberglass induction pipe from Vans that goes to > a front induction throttle body on an IO-360. It is a fairly old piece, > part of a 1999 kit. The problem is that it dosn't clear the starter by a > lot. What have people done with this? Were later examples better? > > I could chop a big piece out of the top of it and make it fit but glass > is not my favorite medium. All-metal kit right! Also what would a chop > job do to the airflow and the structural strength. Big vacuum inside. > Anyway what is the community experience with this? > > TIA Jim Bean > RV-8 engine room > > Stephan Servatius Untere Hauptstr. 3 85461 Bockhorn Germany ________________________________________________________________________________
Subject: Re: Oxygen bottle size and mounting location
Date: May 20, 2003
I didn't want to carry around the system when not needed so I bought a portable system from Nelson: 14 cu.ft. bottle with two Oxymizer cannulas. When I'm solo I secure it in the rear seat, and when there's someone back there we reset it on the flap housing and his/her left knee. Works well and I'm happy. Randy Lervold RV-8, 310 hrs. ----- Original Message ----- From: "Rob Miller" <rmill2000(at)yahoo.com> Subject: RV8-List: Oxygen bottle size and mounting location > > Hello > > I am going to purchase an oxygen system for the -8 and need to know where > others have 'mounted' a portable system, which brand, size of bottle, and > how it is working out. > > No luck in the archives. > > Rob Miller > N262RM -8 "Bad Cat" 66 hours > Pictures can be seen at www.homebuiltairplanes.com > > > __________________________________ > http://search.yahoo.com > > ________________________________________________________________________________
Date: May 21, 2003
Subject: Induction Planning
I searched the archives but found only a few related topics. I am building a RV-8A and I plan an IO-360. I currently have the scooped lower cowling designed for the O-360. It appears to me that the scooped cowling could be used with the IO-360 and may produce a good ram effect. Has anyone tried this and what results were obtained? I agree the smooth cowling looks nicer, but if I can get a good ram effect using the scooped cowling ... Stan Sutterfield Tampa, FL Wings ________________________________________________________________________________
Date: May 21, 2003
Subject: Re: Induction Planning
Funny you should ask...I am at the same point - I ordered the finish kit with plans for an O-360-A1A and since changed my mind and ordered (and have since mounted) an IO-360-M1B. So, I have the lower cowl for the A1A and have had to order the cowl for the M1B - an expensive mistake($500 incl shipping). I have researched this a little, and found that the scoop on the O-360 cowl is too low relative to the front of the throttle body to allow a reliable, unobstructed, filtered intake, hence the "snorkel" which vans provides which receives air from forward of cyl #2. I know of one individual who fab'd his own ram air intake for an angled valve IO-360 out of fiberglass and it looks great. Could point you in his direction if you want to contact me off the list. His work is impeccable - at the cost of more hours... Jon ________________________________________________________________________________
Date: May 21, 2003
I too will be mounting an IO-360 angle valve on my RV-8. I would be interested in an alternative to the snorkel intake. Chris Stone RV-8 wings Oregon -----Original Message----- From: jonweisw(at)rcn.com [mailto:jonweisw(at)rcn.com] Subject: Re: RV8-List: Induction Planning Funny you should ask...I am at the same point - I ordered the finish kit with plans for an O-360-A1A and since changed my mind and ordered (and have since mounted) an IO-360-M1B. So, I have the lower cowl for the A1A and have had to order the cowl for the M1B - an expensive mistake($500 incl shipping). I have researched this a little, and found that the scoop on the O-360 cowl is too low relative to the front of the throttle body to allow a reliable, unobstructed, filtered intake, hence the "snorkel" which vans provides which receives air from forward of cyl #2. I know of one individual who fab'd his own ram air intake for an angled valve IO-360 out of fiberglass and it looks great. Could point you in his direction if you want to contact me off the list. His work is impeccable - at the cost of more hours... Jon direct advertising on the Matronics Forums. ________________________________________________________________________________
Date: May 21, 2003
You IO-360 guys can you educate me as to why you went with a IO-360 200 hp instead of a IO-360 180 HP modified to 200 HP? You save 30 lbs from the front of the plane this way. > >I too will be mounting an IO-360 angle valve on my RV-8. I would be >interested in an alternative to the snorkel intake. > >Chris Stone >RV-8 wings >Oregon > >-----Original Message----- >From: jonweisw(at)rcn.com [mailto:jonweisw(at)rcn.com] >To: rv8-list(at)matronics.com >Subject: Re: RV8-List: Induction Planning > > >Funny you should ask...I am at the same point - I ordered the >finish kit with plans for an O-360-A1A and since changed my >mind and ordered (and have since mounted) an IO-360-M1B. So, >I have the lower cowl for the A1A and have had to order the >cowl for the M1B - an expensive mistake($500 incl shipping). > >I have researched this a little, and found that the scoop on >the O-360 cowl is too low relative to the front of the >throttle body to allow a reliable, unobstructed, filtered >intake, hence the "snorkel" which vans provides which >receives air from forward of cyl #2. I know of one individual >who fab'd his own ram air intake for an angled valve IO-360 >out of fiberglass and it looks great. Could point you in his >direction if you want to contact me off the list. His work is >impeccable - at the cost of more hours... > >Jon > > >direct advertising on the Matronics Forums. > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: May 21, 2003
From: "BUTLER, FRANCIS" <FRANCIS_BUTLER@butler-machinery.com>
reliability -----Original Message----- From: Scott Bilinski [mailto:bilinski@kyocera-wireless.com] Subject: RE: RV8-List: Induction Planning You IO-360 guys can you educate me as to why you went with a IO-360 200 hp instead of a IO-360 180 HP modified to 200 HP? You save 30 lbs from the front of the plane this way. > >I too will be mounting an IO-360 angle valve on my RV-8. I would be >interested in an alternative to the snorkel intake. > >Chris Stone >RV-8 wings >Oregon > >-----Original Message----- >From: jonweisw(at)rcn.com [mailto:jonweisw(at)rcn.com] >To: rv8-list(at)matronics.com >Subject: Re: RV8-List: Induction Planning > > >Funny you should ask...I am at the same point - I ordered the >finish kit with plans for an O-360-A1A and since changed my >mind and ordered (and have since mounted) an IO-360-M1B. So, >I have the lower cowl for the A1A and have had to order the >cowl for the M1B - an expensive mistake($500 incl shipping). > >I have researched this a little, and found that the scoop on >the O-360 cowl is too low relative to the front of the >throttle body to allow a reliable, unobstructed, filtered >intake, hence the "snorkel" which vans provides which >receives air from forward of cyl #2. I know of one individual >who fab'd his own ram air intake for an angled valve IO-360 >out of fiberglass and it looks great. Could point you in his >direction if you want to contact me off the list. His work is >impeccable - at the cost of more hours... > >Jon > > >direct advertising on the Matronics Forums. > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: May 21, 2003
Listers, IO 360 vs 0 360 modified to (200)hp When I was building my RV8 and deciding on an engine, I talked to everybody I could who was racing or into aerobatics and I received the same answer from all of them and that is: IO360 engines breathe better and deliver more actual power than the modified 0 360s. This answer came from guys who had tried both. The weight penalty is well worth the actual power output gained. My own experience racing my RV8 has confirmed the selection of the IO 360 that I have was the right choice for both power and speed and climb. I would also suggest that serious consideration also be given to a LIghtspeed electronic ignition. Dick Martin RV8 N233M the fast one > >reliability > >-----Original Message----- >From: Scott Bilinski [mailto:bilinski@kyocera-wireless.com] >To: rv8-list(at)matronics.com >Subject: RE: RV8-List: Induction Planning > > > >You IO-360 guys can you educate me as to why you went with a IO-360 200 hp >instead of a >IO-360 180 HP modified to 200 HP? You save 30 lbs from the front of the >plane this way. > > >> >>I too will be mounting an IO-360 angle valve on my RV-8. I would be >>interested in an alternative to the snorkel intake. >> >>Chris Stone >>RV-8 wings >>Oregon >> >>-----Original Message----- >>From: jonweisw(at)rcn.com [mailto:jonweisw(at)rcn.com] >>To: rv8-list(at)matronics.com >>Subject: Re: RV8-List: Induction Planning >> >> >> >>Funny you should ask...I am at the same point - I ordered the >>finish kit with plans for an O-360-A1A and since changed my >>mind and ordered (and have since mounted) an IO-360-M1B. So, >>I have the lower cowl for the A1A and have had to order the >>cowl for the M1B - an expensive mistake($500 incl shipping). >> >>I have researched this a little, and found that the scoop on >>the O-360 cowl is too low relative to the front of the >>throttle body to allow a reliable, unobstructed, filtered >>intake, hence the "snorkel" which vans provides which >>receives air from forward of cyl #2. I know of one individual >>who fab'd his own ram air intake for an angled valve IO-360 >>out of fiberglass and it looks great. Could point you in his >>direction if you want to contact me off the list. His work is >>impeccable - at the cost of more hours... >> >>Jon >> >> >>direct advertising on the Matronics Forums. >> >> > > >Scott Bilinski >Eng dept 305 >Phone (858) 657-2536 >Pager (858) 502-5190 > > ________________________________________________________________________________
From: "Gordon or Marge Comfort" <gcomfo(at)tc3net.com>
Date: May 21, 2003
----- Original Message ----- From: "richard martin" <martin333(at)athenet.net> Subject: RE: RV8-List: Induction Planning > > Listers, IO 360 vs 0 360 modified to (200)hp > When I was building my RV8 and deciding on an engine, I talked to everybody > I could who was racing or into aerobatics and I received the same answer from > all of them and that is: IO360 engines breathe better and deliver more actual > power than the modified 0 360s. This answer came from guys who had tried both. > The weight penalty is well worth the actual power output gained. My own experience > racing my RV8 has confirmed the selection of the IO 360 that I have was the > right choice for both power and speed and climb. I would also suggest that > serious consideration also be given to a LIghtspeed electronic ignition. > > Dick Martin > RV8 N233M > the fast one Dick: Nice to see you on the list. You might also mention that Monty Barrett and others have pretty much given up on non counterweighted engines for high output with constant speed metal props. Though heavier, the counterweighted crank offers significant advantages in addition to those you've mentioned. Gordon Comfort N363GC ________________________________________________________________________________
Subject: new builder
Date: May 22, 2003
hello, i'm a french new builder. just starting empennage kit, serial number 81939. i'm 44 yo and building in my house in Normandie. my first flight was in 1994 on microlight and 1997 on plane. i sold a Robin DR253( http://www.pilotlist.org/tagazous/bpoz.htm ) last month to buy the Van's kit . i'm hesitating between RV8A and RV8 (i have many hours on Mudry CAP10), performances are very similar. i prefer the RV8: look better, but i think that the RV8A is easier for sale. i find the CAFE Fondation performance report for the RV8A, but i didn't know anything about the RV8 (easy or hard to taxi with crosswind for example). what did you think about RV8 against RV8A ? for engine, my project is 180hp with a fixed wood prop (3blades like the CAP10 homebuilt F-PYIF http://fderieux.9online.fr/fpyif.htm it's me on the flying picture) did you know how is the inverted flight on a RV8(8) ? thanks for discussion about engine ! sorry for my bad english ! Olivier Le Carbonnier 7, place Cauchoise 76000 Rouen France olcdlm(at)wanadoo.fr ICQ#: 82067330 empennage http://www.pilotlist.org http://nav2000.com/LF7622 Yvetot http://nav2000.com/LFOP Rouen http://www.pilotlist.org/trombino/lecarbonnier.html ________________________________________________________________________________
Date: May 22, 2003
Scott, Make no mistake, a parallel valve 180 HP engine is an ideal engine for most RV's. That fact influences the Supply/Demand curve to the point where I could buy a used Angle Valve 360 for less than a used 180 HP. Reason One My engine comes with a counterbalanced crank. (Very desirable with a metal propeller) Reason Two My engine is 200 HP while still Certified Reason Three Should I wish to forego the Certification, The angle valve engine responds to mods even better than the parallel valve. i.e. 230HP or more. Reason Four Engine already comes with Fuel Injection and allows me to use Cowl without inlet projection which I think looks better. Reason Five For me, these 5 reasons were enough to put up with the 30#'s, Heck I could recoup the 30#'s by just going on a diet! Your mileage may vary! Esten Spears, RV8A, N922ES (reserve), Finishing up Fuse, Leeward Air Ranch, Ocala, FL ----- Original Message ----- From: "Scott Bilinski" <bilinski@kyocera-wireless.com> Subject: RE: RV8-List: Induction Planning <bilinski@kyocera-wireless.com> > > You IO-360 guys can you educate me as to why you went with a IO-360 200 hp > instead of a > IO-360 180 HP modified to 200 HP? You save 30 lbs from the front of the > plane this way. ________________________________________________________________________________
Date: May 22, 2003
Sure... I found a low time IO-360-C1C6 out of a Piper Arrow. The owner of which made me an offer I couldn't refuse! $20K to $30K for an engine was a budget buster. I plan to offset some of the increased weight by using a Whirlwind prop and light weight governor and starter. Chris Stone RV-8 Wings -----Original Message----- From: Scott Bilinski [mailto:bilinski@kyocera-wireless.com] Subject: RE: RV8-List: Induction Planning --> <bilinski@kyocera-wireless.com> You IO-360 guys can you educate me as to why you went with a IO-360 200 hp instead of a IO-360 180 HP modified to 200 HP? You save 30 lbs from the front of the plane this way. > >I too will be mounting an IO-360 angle valve on my RV-8. I would be >interested in an alternative to the snorkel intake. > >Chris Stone >RV-8 wings >Oregon > >-----Original Message----- >From: jonweisw(at)rcn.com [mailto:jonweisw(at)rcn.com] >To: rv8-list(at)matronics.com >Subject: Re: RV8-List: Induction Planning > > >Funny you should ask...I am at the same point - I ordered the >finish kit with plans for an O-360-A1A and since changed my >mind and ordered (and have since mounted) an IO-360-M1B. So, >I have the lower cowl for the A1A and have had to order the >cowl for the M1B - an expensive mistake($500 incl shipping). > >I have researched this a little, and found that the scoop on >the O-360 cowl is too low relative to the front of the >throttle body to allow a reliable, unobstructed, filtered >intake, hence the "snorkel" which vans provides which >receives air from forward of cyl #2. I know of one individual >who fab'd his own ram air intake for an angled valve IO-360 >out of fiberglass and it looks great. Could point you in his >direction if you want to contact me off the list. His work is >impeccable - at the cost of more hours... > >Jon > > >direct advertising on the Matronics Forums. > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 direct advertising on the Matronics Forums. ________________________________________________________________________________
Date: May 22, 2003
Olivier... I decided on the RV-8 for its esthetic beauty. Sure the ground handling is better in the -8A... BUT, Would you fly a tri gear P-51? Or Extra 300? The -8 I have flown has good ground handling. You DO have to fly it all the way through the landing. Like any taildragger... You're not done flying 'till the prop stops! Whatever you decide you won't be disappointed! They both are wonderful flying aircraft. Chris Stone RV-8 Wings -----Original Message----- From: olc [mailto:olcdlm(at)wanadoo.fr] Subject: RV8-List: new builder hello, i'm a french new builder. just starting empennage kit, serial number 81939. i'm 44 yo and building in my house in Normandie. my first flight was in 1994 on microlight and 1997 on plane. i sold a Robin DR253( http://www.pilotlist.org/tagazous/bpoz.htm ) last month to buy the Van's kit . i'm hesitating between RV8A and RV8 (i have many hours on Mudry CAP10), performances are very similar. i prefer the RV8: look better, but i think that the RV8A is easier for sale. i find the CAFE Fondation performance report for the RV8A, but i didn't know anything about the RV8 (easy or hard to taxi with crosswind for example). what did you think about RV8 against RV8A ? for engine, my project is 180hp with a fixed wood prop (3blades like the CAP10 homebuilt F-PYIF http://fderieux.9online.fr/fpyif.htm it's me on the flying picture) did you know how is the inverted flight on a RV8(8) ? thanks for discussion about engine ! sorry for my bad english ! Olivier Le Carbonnier 7, place Cauchoise 76000 Rouen France olcdlm(at)wanadoo.fr ICQ#: 82067330 empennage http://www.pilotlist.org http://nav2000.com/LF7622 Yvetot http://nav2000.com/LFOP Rouen http://www.pilotlist.org/trombino/lecarbonnier.html direct advertising on the Matronics Forums. ________________________________________________________________________________
Date: May 22, 2003
I bought a Mountain High EDS-011 kit and an oxymiser for the back seater. I get 6 to 8 hrs with two users and now fly Xcountry up to 17500ft. Never have paid more than $10 for a fill. The kevlar cylinder is very light and narrow. Its straped vertically to the back of the pilot seat. I do need to remove the rear stick though. Like it. See www.mhoxygen.com/index.phtml?nav_id=28&product_id=64 rv8 n89gm, 260hrs Greg > > > > Hello > > I am going to purchase an oxygen system for the -8 and need to know where > others have 'mounted' a portable system, which brand, size of bottle, and > how it is working out. > > No luck in the archives. > > Rob Miller > N262RM -8 "Bad Cat" 66 hours > Pictures can be seen at www.homebuiltairplanes.com > > > __________________________________ > http://search.yahoo.com > > > > > > ________________________________________________________________________________
Date: May 22, 2003
Subject: RV gross weight
Has anyone had an RV certified at a gross weight higher than Van's recommends? Has anyone tried to get a gross weight increase on an RV already flying? Thanks, Doug Preston RV8 N127EK DNA ________________________________________________________________________________
Subject: Re: RV gross weight
Date: May 22, 2003
Gross weight was not a parameter of interest to the FAA when I had mine certified. I have no gross weight stamped on the ID plate-only the data was that specifically required by Feds--make, model, serial number (which you make up), and date of manufacture. I don't think experimental planes have a legal gross weight limit to worry about. Nothing in the operating limitations says anything about gross weight. Please correct me if this is wrong. That said, I have not been able to load my RV8 over Van's gross limit so far. I did weight our luggage once at 116 lb. But with the two of us, and full fuel, I think we were still 20 lb under Vans recommendation. Note that Alaska store-boughts can operate at 15% over gross legally. RV8 N89GM, 250 hrs. Greg On Thu, 2003-05-22 at 20:55, Dougpsr(at)aol.com wrote: > > Has anyone had an RV certified at a gross weight higher than Van's > recommends? Has anyone tried to get a gross weight increase on an RV already flying? > Thanks, > Doug Preston > RV8 N127EK > > DNA > > > > ________________________________________________________________________________
Date: May 23, 2003
Scott, I concur with Esten and would also add reliability to his list of reasons. The counterbalanced crank to me is perhaps the most important plus on this engine.I have just made my decision to go with a Hartzell prop and after talking to Hartzel it is obvious that there are no problems with vibration on this engine even if you are using Lightspeed ignition. Building RV8 tail,wings done working on fuselage. Colin. ________________________________________________________________________________
Date: May 24, 2003
Subject: Canopy Skirt Attach Seal
From: "Edward O'Connor" <edwardoconnor(at)compuserve.com>
I am geting closer to attaching the skirt to the Plexy and Frame. What have others used to seal between the skirt and the plexiglass? Is it necessary to put some kind of selant between the two to keep water from seeping in while sitting on ground or can I seal with some kind of non RTV along the skirt/canopy junction after riviting it to frame? Searched archives but couldn't find a reference to this. Ed O'Connor/N366RV/Panama City Fl ________________________________________________________________________________
Date: May 24, 2003
Subject: Re: Canopy Skirt Attach Seal
Edward O'Connor wrote: > > I am geting closer to attaching the skirt to the Plexy and Frame. What have > others used to seal between the skirt and the plexiglass? Is it necessary > to put some kind of selant between the two to keep water from seeping in > while sitting on ground or can I seal with some kind of non RTV along the > skirt/canopy junction after riviting it to frame? Searched archives but > couldn't find a reference to this. > Ed O'Connor/N366RV/Panama City Fl > Ed & list - If you are like most of the -8 builders I know, you will find the canopy skirt to be one of the more annoying tasks in the project. Just work steadily, keep your cool, resign yourself to a significant amount of cutting/fitting/sanding, and you too will wind up with a nice fit and a good seal. I had to cut the skirt in half and re-join it at the aft end. Cleco'd the skirt to the frame, sanded the aft-most point to a nice curve, and then started the glass work. I simply used a small amount of moulding clay to fair the canopy track to the curve of the skirt, applied shipping tape over the clay, and smeared a lot of release agent over the tape and on the areas of the fuselage where the skirt will sit with the canopy closed. (I would have applied tape to these areas too if I knew then what I know now; the fit you get is so tight that a layer of paint makes a big difference in tightness!) I then mixed a generous amount of Gougon resin and microbaloons to a peanut-butter consistency, applied it to the skirt where there were gaps between the fuselage and skirt, closed the canopy and watched the resin ooz to the exact shape of the fuselage. It perfectly closed a 3/16" gap I had on the left side. The following morning, I popped the skirt off and started sanding to the right exterior shape. A lotta work, but you'll love the result. At 200 mph in the wintertime, you don't need a blast of cold air on your passenger. Hope this helps. By the way - when you get to the point of riveting the canopy/frame/skirt together, examine each rivet to make sure you've got an aluminum rivet and not a cs-4! If you attempt to install a cs-4, you will crack the canopy for sure. Don N638DM ________________________________________________________________________________
Subject: Canopy Skirt to Plexi
Date: May 24, 2003
Ed; I think you were asking about sealing the canopy skirt to the plexi after it is in place. What I do is after everything is fitted and rivited I put a strip of masking tape around the very top of the skirt and another about 1/8" or so up on the plexi. Then I mix up some of that wonderful fuel tank sealer, remember that stuff, and use the rounded end of a popsicle stick to smooth it into the space between the two tapes. It's paintable after its cured and I've had good success with this on 3 RV6s and 2 RV8s. Just finished and flew 8# 81692 last weekend. Jerry Wilcox ________________________________________________________________________________
Date: May 24, 2003
I used a light weight clear silicon sealant made for windshields. It is very fluid and weeped into plexi-skirt joint. I also cut my skirt in half to get better fit-then joined the halves with a .032 plate. I notched the center canopy rail under the plate and installed a key lock in the plate. n89gm, 260 hrs Greg On Fri, 2003-05-23 at 23:22, Edward O'Connor wrote: > > I am geting closer to attaching the skirt to the Plexy and Frame. What have > others used to seal between the skirt and the plexiglass? Is it necessary > to put some kind of selant between the two to keep water from seeping in > while sitting on ground or can I seal with some kind of non RTV along the > skirt/canopy junction after riviting it to frame? Searched archives but > couldn't find a reference to this. > Ed O'Connor/N366RV/Panama City Fl > > -- Greg V. Miller ________________________________________________________________________________
Subject: First Flight N926MM
Date: May 27, 2003
Hi All fellow listers, Today at about 12:30pm My Tech Counc. Fred LaForge took to the sky with my RV-8, injected 180/CS . I flew chase with Gary Hart in his RV-6. As far as I could tell it all went really well. We ate lunch after he landed, and then my mom gave me the OK so I was out of there. Full throttle looked down to check oil pressure and it was too late, already airborne and clmbing like crazy. Fred followed in his RV-4 with RV-7 builder Robert Paisley. we took a long hot flight out to the practice area and after some slow flight and quick manuevers we came back to Cable and landed. It was my first hour and it was too short but the OAT at 7,000' was over 100 and we had to get back. So here are all those answers to the questions I had about first flights. Takeoff roll-no idea, but short. Rate of climb 110kts 1680'/min. Cruise at 6500' no gear fairings 125-130kts at 24/2400. All my temps were good the hottest cylinder was #3 at 405 during climb and then 385 level. Coolest was #1 335. Oil temp was 210-212 in the desert and 204 climbing out in the city. I have a firewall mounted 7 row S/W oil cooler and an aluminum plenum. The GPS showed a continous 150-155kts but I was told that if I wanted to fly to OSH with the group I'd have to put the fairings on and speed it up. I can't thank the lists and the people at CCB enough for making all this possible, without all this good advise and talented help I would still be working on the tail kit. Like Rosie says, "Keep Pounding those rivets" Ed Perry N926MM RV-8 180/CS 1.5 hrs. ________________________________________________________________________________
tomscherder(at)hotmail.com, vansairforce(at)yahoogroups.com
Date: May 28, 2003
Listers: I am trying to decide the best way to route the wiring from the engie instruments to the firewall in An RV8. With the location of the baggage compartment, it seems you may have to go under it or run a conduit thru it? Also what is the best way to route the pitot and static lines. I am up to the panel, but not sure how to get the lines behind the panel unless I just run the under it, bnut they will just be hanging there? ANy suggetsions. Thanks. Al Grajek ________________________________________________________________________________
Date: May 28, 2003
Subject: Re:
I rivited an angle piece from the firewall to the instrument panel just under the baggage floor and on the left side. All the wires are suspended from that with cushion clamps. As for going under the panel, just bundle them up with a cushion clamp. Jim Bean RV-8 engine room Al Grajek wrote: > > Listers: > I am trying to decide the best way to route the wiring from the engie > instruments to the firewall in An RV8. With the location of the baggage > compartment, it seems you may have to go under it or run a conduit thru it? > Also what is the best way to route the pitot and static lines. I am up to > the panel, but not sure how to get the lines behind the panel unless I just > run the under it, bnut they will just be hanging there? ANy suggetsions. > Thanks. > Al Grajek > > > > > > > ________________________________________________________________________________
Date: May 29, 2003
Subject: EAA Chapter 71 Bakersfield BBQ & Fly-in May 31st
That's right this Saturday, May 31st make your plans to fly in to Bakersfield Mun5), spend the day with us. EAA Chapter 71 is putting on one hell of a BBQ. Lots of fast airplanes & good people. We will be serving around 2:30-3:00 Tri-tip, beans, Salad, Bread, & Beverages. The local weather man says it will be another beautiful day in Bakersfield. Any questions please call Tim Barnes (661) 393-7519 or John Harmon (661) 836-1028.................................See ya there! ________________________________________________________________________________
Date: May 29, 2003
Subject: Re: [rv8list] Alternate canopie
I really like the idea of a windshield with a longer forward slope. We need to convince Todd there is a market for it. Some background first; A friend and neighbor (Ray Parker) started this thread about three days ago. Ray is fitting a new windshield that he cut out of a 1/4" Todds Canopy. What he didn't tell you was that he sent Todd a fiberglass mold he made from his thin (>.10") fitted Vans Windshield. Todd was to send him a thicker windshield made from the mold. Todd was told there was myself and another RV8 Builder right here at Leeward Air Ranch that also would like to purchase thicker RV8 Windshields only. After 6 weeks of thinking about it, Todd just sent Ray a 1/4" Canopy for him to cut a windshield out of. He wasn't convinced there was a market for thicker windshields for RV 8's. Maybe we could do a poll on the RV list and present results to Todd. Esten Spears, RV8A, 80922, N922ES (reserved) CANOPY! Leeward Air Ranch, Ocala, FL ----- Original Message ----- From: "Terry Watson" <terrywatson3(at)attbi.com> Subject: RE: [rv8list] Alternate canopie There is quite a bit in the Matronics archives about Todd's canopies, but I have an idea or suggestion. One of the nicest looking RV-8's I have seen in photos had the windscreen modified to continue the slope down to the top of the forward fuselage at a less steep angle than the standard canopy. I apologize for not remembering the builder, but the plane had several interesting ideas very skillfully incorporated into it. Since we cut off the windscreen and do the final fitting separately, perhaps we could get Todd to do a mold for blowing just the windscreen, which could be thicker than the canopy itself to better resist bird strikes. It could also be a different tint if that helped. Maybe no tint with a dark tint canopy? I'm happy with Van's canopy, but I haven't fit the windscreen yet. Terry RV-8A #80729 Seattle [Non-text portions of this message have been removed] Get A Free Psychic Reading! Your Online Answer To Life's Important Questions. http://us.click.yahoo.com/Lj3uPC/Me7FAA/CNxFAA/1yWplB/TM Information exchange for builders of Vans Aircraft RV-8 kits. IF YOU WISH TO UNSUBSCRIBE, PLEASE SEND AN EMAIL TO : rv8list-unsubscribe(at)egroups.com ________________________________________________________________________________
Date: May 29, 2003
Esten/Ray I would be interested in purchasing one of the 1/4" windshields only for the RV8. I have thought about this for some time and think that it would improve drag reduction and speed as well a provide safety from bird strikes. I would prefer it to be the same tint as Vans windshield. I have over 700 hours on my RV8 and find that the standard tint used by Van is quite comfortable in all light situations. Dick Martin RV8 N233M the fast one > > I really like the idea of a windshield with a longer forward slope. We >need to convince Todd there is a market for it. Some background first; > A friend and neighbor (Ray Parker) started this thread about three days >ago. Ray is fitting a new windshield that he cut out of a 1/4" Todds Canopy. >What he didn't tell you was that he sent Todd a fiberglass mold he made from >his thin (>.10") fitted Vans Windshield. Todd was to send him a thicker >windshield made from the mold. Todd was told there was myself and another >RV8 Builder right here at Leeward Air Ranch that also would like to purchase >thicker RV8 Windshields only. After 6 weeks of thinking about it, Todd just >sent Ray a 1/4" Canopy for him to cut a windshield out of. He wasn't >convinced there was a market for thicker windshields for RV 8's. > Maybe we could do a poll on the RV list and present results to Todd. >Esten Spears, RV8A, 80922, N922ES (reserved) CANOPY! Leeward Air Ranch, >Ocala, FL >----- Original Message ----- >From: "Terry Watson" <terrywatson3(at)attbi.com> >To: >Subject: RE: [rv8list] Alternate canopie > > >There is quite a bit in the Matronics archives about Todd's canopies, but I >have an idea or suggestion. One of the nicest looking RV-8's I have seen in >photos had the windscreen modified to continue the slope down to the top of >the forward fuselage at a less steep angle than the standard canopy. I >apologize for not remembering the builder, but the plane had several >interesting ideas very skillfully incorporated into it. Since we cut off >the windscreen and do the final fitting separately, perhaps we could get >Todd to do a mold for blowing just the windscreen, which could be thicker >than the canopy itself to better resist bird strikes. It could also be a >different tint if that helped. Maybe no tint with a dark tint canopy? I'm >happy with Van's canopy, but I haven't fit the windscreen yet. > >Terry >RV-8A #80729 >Seattle > > >[Non-text portions of this message have been removed] > > >Get A Free Psychic Reading! Your Online Answer To Life's Important >Questions. >http://us.click.yahoo.com/Lj3uPC/Me7FAA/CNxFAA/1yWplB/TM > >Information exchange for builders of Vans Aircraft RV-8 kits. > >IF YOU WISH TO UNSUBSCRIBE, PLEASE SEND AN EMAIL TO : > >rv8list-unsubscribe(at)egroups.com > > ________________________________________________________________________________
Subject: for sale
Date: May 30, 2003
RV8a almost ready for inspection..family issues force sale..0320-160hp..c/s/prop..and more..$74,500.00 or best offer..503-678-3343 ________________________________________________________________________________
Subject: Re:
Date: May 30, 2003
how did you apply corosion protect ? product (Alodine 1200, TURCO, PAC33) ? olc Olivier ICQ#: 82067330 olcdlm(at)wanadoo.fr http://www.pilotlist.org http://nav2000.com/LF7622 Yvetot http://nav2000.com/LFOP Rouen http://www.vansaircraft.com/public/rv-8int.htm plan n81939 empennage ________________________________________________________________________________
Date: May 30, 2003
Subject: Re: Re: [rv8list] Alternate canopy REPLY FROM TODD
Charlie, Yahoo removed your attachment. What did Todd say? I've received about half a dozen emails from others saying they too were interested in a 1/4" more sloping windshield only for the RV8. I was going to attach them all to an email asking him to reconsider. Esten Spears, RV8A, 80922, N922ES (reserved) Leeward Air Ranch, Ocala, FL ----- Original Message ----- From: "Charles Kuss" <chaskuss(at)yahoo.com> Subject: Fwd: Re: [rv8list] Alternate canopy REPLY FROM TODD > Listers, > I forwarded several of the comments regarding a > desire for a thicker windscreen to Todd Silver. Please > see his reply below. It appears we need to take a poll > to see if there is sufficient interest in doing this. > Charlie Kuss > > Note: forwarded message attached. > > > __________________________________ > > [Non-text portions of this message have been removed] > > > Get A Free Psychic Reading! Your Online Answer To Life's Important Questions. > http://us.click.yahoo.com/Lj3uPC/Me7FAA/ySSFAA/1yWplB/TM > > Information exchange for builders of Vans Aircraft RV-8 kits. > > IF YOU WISH TO UNSUBSCRIBE, PLEASE SEND AN EMAIL TO : > > rv8list-unsubscribe(at)egroups.com > > ________________________________________________________________________________
Date: May 30, 2003
Subject: Alternate canopy REPLY FROM TODD
Count another RV8 builder for the canopy. Chuck Petersen cat2fly(at)yahoo.com Esten Spears wrote: Charlie, Yahoo removed your attachment. What did Todd say? I've received about half a dozen emails from others saying they too were interested in a 1/4" more sloping windshield only for the RV8. I was going to attach them all to an email asking him to reconsider. Esten Spears, RV8A, 80922, N922ES (reserved) Leeward Air Ranch, Ocala, FL ----- Original Message ----- From: "Charles Kuss" Subject: Fwd: Re: [rv8list] Alternate canopy REPLY FROM TODD > Listers, > I forwarded several of the comments regarding a > desire for a thicker windscreen to Todd Silver. Please > see his reply below. It appears we need to take a poll > to see if there is sufficient interest in doing this. > Charlie Kuss > > Note: forwarded message attached. > > > __________________________________ > > [Non-text portions of this message have been removed] > > > Get A Free Psychic Reading! Your Online Answer To Life's Important Questions. > http://us.click.yahoo.com/Lj3uPC/Me7FAA/ySSFAA/1yWplB/TM > > Information exchange for builders of Vans Aircraft RV-8 kits. > > IF YOU WISH TO UNSUBSCRIBE, PLEASE SEND AN EMAIL TO : > > rv8list-unsubscribe(at)egroups.com > > --------------------------------- Free online calendar with sync to Outlook(TM). ________________________________________________________________________________
Subject: Re: Alternate canopy REPLY FROM TODD
Date: May 31, 2003
Chuck Add me to the list for a thicker more sloping wndshield. I am cutting the canopy today so I will need to know something fairly soon. Thanks for you effort Paul Schattauer RV8 # 9 760 Amster Green Dr, Atlanta GA 30350 770 394 8370 >From: chuck petersen <cat2fly(at)yahoo.com> >Reply-To: rv8-list(at)matronics.com >To: rv8-list(at)matronics.com >Subject: RV8-List: Alternate canopy REPLY FROM TODD >Date: Fri, 30 May 2003 23:57:22 -0700 (PDT) > > >Count another RV8 builder for the canopy. > >Chuck Petersen >cat2fly(at)yahoo.com > >Esten Spears wrote: > >Charlie, >Yahoo removed your attachment. What did Todd say? I've received about >half a dozen emails from others saying they too were interested in a 1/4" >more sloping windshield only for the RV8. I was going to attach them all to >an email asking him to reconsider. >Esten Spears, RV8A, 80922, N922ES (reserved) Leeward Air Ranch, Ocala, FL >----- Original Message ----- >From: "Charles Kuss" >To: >Subject: Fwd: Re: [rv8list] Alternate canopy REPLY FROM TODD > > > > Listers, > > I forwarded several of the comments regarding a > > desire for a thicker windscreen to Todd Silver. Please > > see his reply below. It appears we need to take a poll > > to see if there is sufficient interest in doing this. > > Charlie Kuss > > > > Note: forwarded message attached. > > > > > > __________________________________ > > > > [Non-text portions of this message have been removed] > > > > > > Get A Free Psychic Reading! Your Online Answer To Life's Important >Questions. > > http://us.click.yahoo.com/Lj3uPC/Me7FAA/ySSFAA/1yWplB/TM > > > > Information exchange for builders of Vans Aircraft RV-8 kits. > > > > IF YOU WISH TO UNSUBSCRIBE, PLEASE SEND AN EMAIL TO : > > > > rv8list-unsubscribe(at)egroups.com > > > > > > >--------------------------------- >Free online calendar with sync to Outlook(TM). > > ________________________________________________________________________________
From: "Gerald Kinman" <gerald.kinman(at)verizon.net>
Subject: RV8 Windshield
Date: May 31, 2003
Add my name to the list of builders that need that .250" windshield. I am almost ready to glass that part in and am tempted to buy a whole canopy if I was certain the bubble section was truly a .250" thickness. Anybody out there that has installed one of Todd's canopies that can verify that? Gerald K 80271 ________________________________________________________________________________
Date: Jun 01, 2003
Subject: Re: RV8 Windshield
Gerald, There is no one uniform thickness dimension. The thickness dimension varies with the amount of stretch in the area you choose to measure. The Canopies Vans sends out are blown from .187" sheet. Their thickness will vary between .187" and .100" Unfortunately the maximum stretch and therefore the .100" thickness occurs at the center where you cut the windshield from the canopy. Todd's .250" Canopies have the same stretching and therefore thinning, but they start from .250" instead of .187" and so are significantly thicker. Esten Spears, RV8A, 80922, N922ES (reserved) CANOPY!, Leeward Air Ranch, Ocala, FL ----- Original Message ----- From: "Gerald Kinman" <gerald.kinman(at)verizon.net> Subject: RV8-List: RV8 Windshield > > Add my name to the list of builders that need that .250" windshield. I am almost ready to glass that part in and am tempted to buy a whole canopy if I was certain the bubble section was truly a .250" thickness. Anybody out there that has installed one of Todd's canopies that can verify that? > Gerald K 80271 > > ________________________________________________________________________________
Date: Jun 01, 2003
I have one of Todd's .25 inch canopies and the thinnest portion is the top which was correctly stated earlier as .133" -- Michael Stephan EAA Chapter 168 RV-8 builder > From: "Gerald Kinman" <gerald.kinman(at)verizon.net> > Reply-To: rv8-list(at)matronics.com > Date: Sat, 31 May 2003 21:18:52 -0500 > To: > Subject: RV8-List: RV8 Windshield > > > Add my name to the list of builders that need that .250" windshield. I am > almost ready to glass that part in and am tempted to buy a whole canopy if I > was certain the bubble section was truly a .250" thickness. Anybody out there > that has installed one of Todd's canopies that can verify that? > Gerald K 80271 ________________________________________________________________________________
From: "PAUL ANTOINETTE" <PaulAntoinette(at)msn.com>
Subject: thicker canopy
Date: Jun 01, 2003
I am about a year and a half from requiring, but would also be interested in a thicker canopy. Any word on noise reduction? ________________________________________________________________________________
Date: Jun 01, 2003
That was probably the most fun you ever had with your pants on! Congratulations!!! Tom Lloyd N842TL Indy ----- Original Message ----- From: Ed Perry <eperry(at)san.rr.com> Subject: RV8-List: First Flight N926MM > > Hi All fellow listers, > > Today at about 12:30pm My Tech Counc. Fred LaForge took to the sky with my RV-8, injected 180/CS . I flew chase with Gary Hart in his RV-6. As far as I could tell it all went really well. We ate lunch after he landed, and then my mom gave me the OK so I was out of there. Full throttle looked down to check oil pressure and it was too late, already airborne and clmbing like crazy. Fred followed in his RV-4 with RV-7 builder Robert Paisley. we took a long hot flight out to the practice area and after some slow flight and quick manuevers we came back to Cable and landed. It was my first hour and it was too short but the OAT at 7,000' was over 100 and we had to get back. > So here are all those answers to the questions I had about first flights. Takeoff roll-no idea, but short. Rate of climb 110kts 1680'/min. Cruise at 6500' no gear fairings 125-130kts at 24/2400. All my temps were good the hottest cylinder was #3 at 405 during climb and then 385 level. Coolest was #1 335. Oil temp was 210-212 in the desert and 204 climbing out in the city. I have a firewall mounted 7 row S/W oil cooler and an aluminum plenum. The GPS showed a continous 150-155kts but I was told that if I wanted to fly to OSH with the group I'd have to put the fairings on and speed it up. > I can't thank the lists and the people at CCB enough for making all this possible, without all this good advise and talented help I would still be working on the tail kit. > > Like Rosie says, "Keep Pounding those rivets" > > Ed Perry > N926MM RV-8 180/CS > 1.5 hrs. > > ________________________________________________________________________________
Date: Jun 02, 2003
Subject: Re: thicker canopy
For all of you who are interested in a thicker more streamlined windscreen for your RV8 - one of the guys in my EAA chapter 186 did just that last year and here is the info he gave me: Aircraft Plastics 9785 Julie Ct. Tipp City, OH 45371 937-669-2677 937-669-2777 fax cost one year ago was $200 plus shipping, five week turnaround, color #2515 to match Vans tint. > > >I am about a year and a half from requiring, but would also be interested >in a thicker canopy. Any word on noise reduction? > > ________________________________________________________________________________
Date: Jun 01, 2003
Subject: [ Len Leggette ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Len Leggette Subject: Newly Painted RV-8A http://www.matronics.com/photoshare/Lenleg@aol.com.06.01.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jun 01, 2003
Subject: [ Wayne Petrus ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Wayne Petrus Subject: RV8A pics http://www.matronics.com/photoshare/Dwpetrus@aol.com.06.01.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jun 01, 2003
Subject: [ Dave Pohl ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Dave Pohl Subject: Ted Gauthier's RV6 http://www.matronics.com/photoshare/drpohl@comcast.net.06.01.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jun 01, 2003
Subject: [ Cash Copeland ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Cash Copeland Subject: First Flight RV6 N46FC http://www.matronics.com/photoshare/JusCash@aol.com.06.01.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jun 01, 2003
Subject: [ Tom Garner ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Tom Garner Subject: Oil cooler door http://www.matronics.com/photoshare/jtgarner@shentel.net.06.01.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jun 01, 2003
Subject: [ Bill Gunn ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Bill Gunn Subject: Gear Fairings Source http://www.matronics.com/photoshare/WGUNN@dot.state.tx.us.06.01.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jun 02, 2003
Aircraft Plastics are the people that supply Vans with canopies. Todd at Todd's Canopies emailed me three days ago he was going to work on a setup that would blow two windshields at once. His objective is to be able to sell a RV8 Windshield only that is thicker and more streamlined for a price that is hopefully significantly below this Aircraft Plastics price. Esten Spears, RV8A, 80922, N922ES (reserved), CANOPY!, Leeward Air Ranch, Ocala, FL ----- Original Message ----- From: "Doug Ritter" <d.d.ritter(at)verizon.net> Subject: Re: RV8-List: thicker canopy > > For all of you who are interested in a thicker more streamlined windscreen > for your RV8 - one of the guys in my EAA chapter 186 did just that last > year and here is the info he gave me: > > Aircraft Plastics > 9785 Julie Ct. > Tipp City, OH 45371 > 937-669-2677 > 937-669-2777 fax > > cost one year ago was $200 plus shipping, five week turnaround, color #2515 > to match Vans tint. > > > > > > > >I am about a year and a half from requiring, but would also be interested > >in a thicker canopy. Any word on noise reduction? > > > > > > ________________________________________________________________________________
Subject: Thick RV-8 Canopy
Date: Jun 02, 2003
I too am interested in the thicker RV-8 canopy. Count me in. Chris Stone RV-8 Wings Newberg, OR rv8iator(at)earthlink.net ________________________________________________________________________________
Subject: RE: RV8-List Digest: 2 Msgs - 06/02/03
Date: Jun 04, 2003
I had the nose gear of my RV8a collapse on landing at a grass field. The nose gear of the 8 is the same as the 6 but carries more weight. We flipped over and the canopy broke allowing us to crawl out with minor injuries. This is the reason for the thin Plexiglass. I would not want to be trapped in an upside down RV. Lorin > [Original Message] > From: RV8-List Digest Server <rv8-list-digest(at)matronics.com> > To: RV8-List Digest List > Date: 6/2/03 11:57:09 PM > Subject: RV8-List Digest: 2 Msgs - 06/02/03 > > * > > ================================================== > Online Versions of Today's List Digest Archive > ================================================== > > Today's complete RV8-List Digest can be also be found in either > of the two Web Links listed below. The .html file includes the Digest > formatted in HTML for viewing with a web browser and features Hyperlinked > Indexes and Message Navigation. The .txt file includes the plain ASCII > version of the RV8-List Digest and can be viewed with a generic > text editor such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/rv8-list/Digest.RV8-List.2003-06-02.html > > Text Version: > > http://www.matronics.com/digest/rv8-list/Digest.RV8-List.2003-06-02.txt > > > ================================================ > EMail Version of Today's List Digest Archive > ================================================ > > > RV8-List Digest Archive > --- > Total Messages Posted Mon 06/02/03: 2 > > > Today's Message Index: > ---------------------- > > 1. 05:58 AM - Re: thicker canopy (Esten Spears) > 2. 06:36 AM - Thick RV-8 Canopy (Chris Stone) > > > > ________________________________ Message 1 _____________________________________ > > > From: Esten Spears <ewspears(at)comcast.net> > Subject: Re: RV8-List: thicker canopy > > > Aircraft Plastics are the people that supply Vans with canopies. > Todd at Todd's Canopies emailed me three days ago he was going to work > on a setup that would blow two windshields at once. His objective is to be > able to sell a RV8 Windshield only that is thicker and more streamlined for > a price that is hopefully significantly below this Aircraft Plastics price. > Esten Spears, RV8A, 80922, N922ES (reserved), CANOPY!, Leeward Air Ranch, > Ocala, FL > > ----- Original Message ----- > From: "Doug Ritter" <d.d.ritter(at)verizon.net> > Subject: Re: RV8-List: thicker canopy > > > > > > For all of you who are interested in a thicker more streamlined windscreen > > for your RV8 - one of the guys in my EAA chapter 186 did just that last > > year and here is the info he gave me: > > > > Aircraft Plastics > > 9785 Julie Ct. > > Tipp City, OH 45371 > > 937-669-2677 > > 937-669-2777 fax > > > > cost one year ago was $200 plus shipping, five week turnaround, color > #2515 > > to match Vans tint. > > > > > > > > > > > > > >I am about a year and a half from requiring, but would also be interested > > >in a thicker canopy. Any word on noise reduction? > > > > > > > > > > > > > > > > > ________________________________ Message 2 _____________________________________ > > > Subject: RV8-List: Thick RV-8 Canopy > From: "Chris Stone" <Chris.Stone@a-dec.com> > > > I too am interested in the thicker RV-8 canopy. > > Count me in. > > Chris Stone > RV-8 Wings > Newberg, OR > > rv8iator(at)earthlink.net > > > > > > > > > > > > > > > > > --- Lorin Frank --- llfrank(at)earthlink.net ________________________________________________________________________________
From: "Dr. Kevin P. Leathers" <DrLeathers(at)822heal.com>
Subject: Re: RE: RV8-List Digest: 2 Msgs - 06/02/03
Date: Jun 04, 2003
Thanks Lorin, Does anyone know if Van's has addresssed the weak nosegear situation? This seems like something that happens a lot and it should be an simple matter to beef up the gear. Doc ----- Original Message ----- From: "Lorin Frank" <llfrank(at)earthlink.net> Subject: RV8-List: RE: RV8-List Digest: 2 Msgs - 06/02/03 > > I had the nose gear of my RV8a collapse on landing at a grass field. The > nose gear of the 8 is the same as the 6 but carries more weight. We flipped > over and the canopy broke allowing us to crawl out with minor injuries. > This is the reason for the thin Plexiglass. I would not want to be trapped > in an upside down RV. Lorin > > > > [Original Message] > > From: RV8-List Digest Server <rv8-list-digest(at)matronics.com> > > To: RV8-List Digest List > > Date: 6/2/03 11:57:09 PM > > Subject: RV8-List Digest: 2 Msgs - 06/02/03 > > > > * > > > > ================================================== > > Online Versions of Today's List Digest Archive > > ================================================== > > > > Today's complete RV8-List Digest can be also be found in either > > of the two Web Links listed below. The .html file includes the Digest > > formatted in HTML for viewing with a web browser and features Hyperlinked > > Indexes and Message Navigation. The .txt file includes the plain ASCII > > version of the RV8-List Digest and can be viewed with a generic > > text editor such as Notepad or with a web browser. > > > > HTML Version: > > > > > > > > Text Version: > > > > > > > > > > ================================================ > > EMail Version of Today's List Digest Archive > > ================================================ > > > > > > RV8-List Digest Archive > > --- > > Total Messages Posted Mon 06/02/03: 2 > > > > > > Today's Message Index: > > ---------------------- > > > > 1. 05:58 AM - Re: thicker canopy (Esten Spears) > > 2. 06:36 AM - Thick RV-8 Canopy (Chris Stone) > > > > > > > > ________________________________ Message 1 > _____________________________________ > > > > > > From: Esten Spears <ewspears(at)comcast.net> > > Subject: Re: RV8-List: thicker canopy > > > > > > Aircraft Plastics are the people that supply Vans with canopies. > > Todd at Todd's Canopies emailed me three days ago he was going to work > > on a setup that would blow two windshields at once. His objective is to be > > able to sell a RV8 Windshield only that is thicker and more streamlined > for > > a price that is hopefully significantly below this Aircraft Plastics > price. > > Esten Spears, RV8A, 80922, N922ES (reserved), CANOPY!, Leeward Air Ranch, > > Ocala, FL > > > > ----- Original Message ----- > > From: "Doug Ritter" <d.d.ritter(at)verizon.net> > > Subject: Re: RV8-List: thicker canopy > > > > > > > > > > For all of you who are interested in a thicker more streamlined > windscreen > > > for your RV8 - one of the guys in my EAA chapter 186 did just that last > > > year and here is the info he gave me: > > > > > > Aircraft Plastics > > > 9785 Julie Ct. > > > Tipp City, OH 45371 > > > 937-669-2677 > > > 937-669-2777 fax > > > > > > cost one year ago was $200 plus shipping, five week turnaround, color > > #2515 > > > to match Vans tint. > > > > > > > > > > > > > > > > > > > >I am about a year and a half from requiring, but would also be > interested > > > >in a thicker canopy. Any word on noise reduction? > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________ Message 2 > _____________________________________ > > > > > > Subject: RV8-List: Thick RV-8 Canopy > > From: "Chris Stone" <Chris.Stone@a-dec.com> > > > > > > I too am interested in the thicker RV-8 canopy. > > > > Count me in. > > > > Chris Stone > > RV-8 Wings > > Newberg, OR > > > > rv8iator(at)earthlink.net > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- Lorin Frank > --- llfrank(at)earthlink.net > > ________________________________________________________________________________
Subject: Nose gear
Date: Jun 04, 2003
Please, before you panic all of the A model builders and thinkinaboutbeinabuilders out there, have a look at the archives. If something breaks it doesn't necessarily mean it's too weak. While you are at it, you might search on the "weak wing theory" too. Also, have a look at past issues of the Rvator. My own conclusion is that nose gear aircraft are susceptible to damage in rough fields and nose gear first touchdowns. Making it stronger usually means making it heavier and/or making it more expensive. I am not convinced that Van's doesn't have it right. I would be helpful to hear a more detailed account from Lorin as to what happened. Terry RV-8A finishing Seattle -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of Dr. Kevin P. Leathers Subject: Re: RV8-List: RE: RV8-List Digest: 2 Msgs - 06/02/03 Thanks Lorin, Does anyone know if Van's has addresssed the weak nosegear situation? This seems like something that happens a lot and it should be an simple matter to beef up the gear. Doc ________________________________________________________________________________
Date: Jun 04, 2003
From: Scott Bilinski <bilinski@kyocera-wireless.com>
I know they change the radius's on the gear but thats it. I cant tell you when that was done but quite a few years back (3~4?). When flying with Mike Seager we started and ended the flight on a grass strip, always lifted the nose at about 30~40 MPH and held it about 6' off the ground until lift off. On landing held the nose off as long as possible and touched the nose wheel down at about 20-30 MPH? I was worried about the bumps we were hitting. He said nothing to worry about. I cant imagine a bump big enough to fold the gear back, especially if holding the nose gear up on landing and touchdown. A final note, RV's are NOT built for flight training, they do not have the extra robust nose gear a 152/172 has. This basically means you had better know what your doing especially if your landing on grass strips. Becoming too comfortable and letting your guard down and not keeping that nose wheel off the ground as soon/as long as possible can cost you. I do not fly off of grass and probably never will, this is just my impression after talking with Mike. > > >Thanks Lorin, > >Does anyone know if Van's has addresssed the weak nosegear situation? This >seems like something that happens a lot and it should be an simple matter to >beef up the gear. > >Doc > > >----- Original Message ----- >From: "Lorin Frank" <llfrank(at)earthlink.net> >To: "RV8-List Digest Server" >Subject: RV8-List: RE: RV8-List Digest: 2 Msgs - 06/02/03 > > >> >> I had the nose gear of my RV8a collapse on landing at a grass field. The >> nose gear of the 8 is the same as the 6 but carries more weight. We >flipped >> over and the canopy broke allowing us to crawl out with minor injuries. >> This is the reason for the thin Plexiglass. I would not want to be trapped >> in an upside down RV. Lorin >> >> >> > [Original Message] >> > From: RV8-List Digest Server <rv8-list-digest(at)matronics.com> >> > To: RV8-List Digest List >> > Date: 6/2/03 11:57:09 PM >> > Subject: RV8-List Digest: 2 Msgs - 06/02/03 >> > >> > * >> > >> > ================================================== >> > Online Versions of Today's List Digest Archive >> > ================================================== >> > >> > Today's complete RV8-List Digest can be also be found in either >> > of the two Web Links listed below. The .html file includes the Digest >> > formatted in HTML for viewing with a web browser and features >Hyperlinked >> > Indexes and Message Navigation. The .txt file includes the plain ASCII >> > version of the RV8-List Digest and can be viewed with a generic >> > text editor such as Notepad or with a web browser. >> > >> > HTML Version: >> > >> > >> > >> > Text Version: >> > >> > >> > >> > >> > ================================================ >> > EMail Version of Today's List Digest Archive >> > ================================================ >> > >> > >> > RV8-List Digest Archive >> > --- >> > Total Messages Posted Mon 06/02/03: 2 >> > >> > >> > Today's Message Index: >> > ---------------------- >> > >> > 1. 05:58 AM - Re: thicker canopy (Esten Spears) >> > 2. 06:36 AM - Thick RV-8 Canopy (Chris Stone) >> > >> > >> > >> > ________________________________ Message 1 >> _____________________________________ >> > >> > >> > From: Esten Spears <ewspears(at)comcast.net> >> > Subject: Re: RV8-List: thicker canopy >> > >> > >> > Aircraft Plastics are the people that supply Vans with canopies. >> > Todd at Todd's Canopies emailed me three days ago he was going to >work >> > on a setup that would blow two windshields at once. His objective is to >be >> > able to sell a RV8 Windshield only that is thicker and more streamlined >> for >> > a price that is hopefully significantly below this Aircraft Plastics >> price. >> > Esten Spears, RV8A, 80922, N922ES (reserved), CANOPY!, Leeward Air >Ranch, >> > Ocala, FL >> > >> > ----- Original Message ----- >> > From: "Doug Ritter" <d.d.ritter(at)verizon.net> >> > Subject: Re: RV8-List: thicker canopy >> > >> > >> > > >> > > For all of you who are interested in a thicker more streamlined >> windscreen >> > > for your RV8 - one of the guys in my EAA chapter 186 did just that >last >> > > year and here is the info he gave me: >> > > >> > > Aircraft Plastics >> > > 9785 Julie Ct. >> > > Tipp City, OH 45371 >> > > 937-669-2677 >> > > 937-669-2777 fax >> > > >> > > cost one year ago was $200 plus shipping, five week turnaround, color >> > #2515 >> > > to match Vans tint. >> > > >> > > >> > >> > > > >> > > > >> > > >I am about a year and a half from requiring, but would also be >> interested >> > > >in a thicker canopy. Any word on noise reduction? >> > > > >> > > > >> > > >> > > >> > >> > >> > >> > >> > >> > >> > ________________________________ Message 2 >> _____________________________________ >> > >> > >> > Subject: RV8-List: Thick RV-8 Canopy >> > From: "Chris Stone" <Chris.Stone@a-dec.com> >> > >> > >> > I too am interested in the thicker RV-8 canopy. >> > >> > Count me in. >> > >> > Chris Stone >> > RV-8 Wings >> > Newberg, OR >> > >> > rv8iator(at)earthlink.net >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> >> >> --- Lorin Frank >> --- llfrank(at)earthlink.net >> >> > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Jun 04, 2003
Subject: Re: Nose gear
Terry Watson wrote: >My own conclusion is that nose gear aircraft are susceptible to damage in >rough fields and nose gear first touchdowns. --- To get a ticket today, is it even necessary to demonstrate competence with rough and/or short field skills? Dunno... When I got mine it was a required part of the training. Is it still? Might explain some of these nose gear reports. Steve ________________________________________________________________________________
Date: Jun 14, 2003
Subject: [ Jerry A Wilcox ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Jerry A Wilcox Subject: RV8 Engine Instillation with Custom Exhaust System http://www.matronics.com/photoshare/jerrywilcox@rogers.com.06.14.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jun 14, 2003
A new Email List Photo Share is available: Poster: Jerry A Wilcox Subject: RV8 #81692 Just prior to first flight http://www.matronics.com/photoshare/jerrywilcox@rogers.com.2.06.14.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject: Link to RV8 photo's with Chopped / lowered Canopy
Date: Jun 17, 2003
From: "BUTLER, FRANCIS" <FRANCIS_BUTLER@butler-machinery.com>
"RV-Yahoo list (E-mail)" > http://www.butler-machinery.com/rv8/rv8.html > ________________________________________________________________________________
Date: Jun 19, 2003
Subject: Slick Slider
Has anyone done a sliding canopy like Francis Butler's for an RV-4? see.... http://www.butler-machinery.com/rv8/rv8.html This looks like it would be terrific on my -4. Ron Patterson RV-4 (fwf) N8ZD (reserved) ________________________________________________________________________________
Subject: tailwheel fairing
Date: Jun 19, 2003
Hi Rvers, I intended to install the tailwheel fairing on my 8. When I hold it in my hand, I wasn't quite sure, if the full swivel would still work with it installed. Who has an idea, drawing, how to install it? What is the best way to start? Regards RV8 D-EBRV Flying 3 hours -- Stephan Servatius Untere Hauptstr. 3 85461 Bockhorn Germany Tel. +49 (0) 8122 48383 Fax +49 (0) 8122 902188 Mobil +49 (0) 179 105 9749 ________________________________________________________________________________
Subject: Re: Slick Slider
Date: Jun 20, 2003
Yes, Greg Klema has a slider with a crank ala Lyle Hefle in His RV4. I have pictures if you need. Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org Always looking for articles for the Experimenter ----- Original Message ----- From: "Ron Patterson" <scc_ron(at)yahoo.com> Subject: RV8-List: Slick Slider > > Has anyone done a sliding canopy like Francis Butler's for an RV-4? > see.... http://www.butler-machinery.com/rv8/rv8.html > This looks like it would be terrific on my -4. > Ron Patterson > RV-4 (fwf) > N8ZD (reserved) > > ________________________________________________________________________________
Date: Jun 20, 2003
Subject: Re: RV8-List Digest: 2 Msgs - 06/19/03
N880RV flies! Number one RV-8 kit built and flown by Dave Hamilton Sent in by Vern Darley,II [vern_at_mindspring.com] Peachtree City, Georgia- Falcon RV Squadron today announced the first flight of Dave Hamilton's RV-8, N880RV. Various family members and fellow RV'ers watched as the beautiful RV-8 reached pattern height before reaching the end of the runway. With the watchful eye of wingman John Hess flying safety chase/camera ship in his award-winning RV-4, Dave climbed to 6,500' and gave his new bird it's first aerial workout after 7+ years of construction. Dave's kit was the first RV-8 kit shipped. N880RV is equipped for IFR with a Garmin 430,GTX 327, GMA 340,and a three axis autopilot. A three-bladed prop,200 HP Lycoming, Grove landing gear, "Holy" Cowl and plenum compliment Dave's outstanding workmanship. A beautifully-designed green, white,and gold color scheme are planned when the phase one hours are flown off. After the flight, friends and family retired to a nearby restaurant to celebrate. What a great airplane! What a great bunch of people! What a great design! Thanks Vans! ________________________________________________________________________________
Date: Jun 22, 2003
Subject: [ Meketa ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Meketa Subject: RV8 flap actuator http://www.matronics.com/photoshare/acgm@gvtc.com.06.22.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject: re:QB Kit
Date: Jun 24, 2003
RV-8 Quick Build Kit for sale. Call 928-474-9121 evenings ________________________________________________________________________________
Date: Jun 25, 2003
Subject: Oshkosh RV-8 Builders' Meetings
OK, gang, it's fast becoming "that time of the year" again -- Oshkosh b'gosh! For the last several years, a group of RV-8/-8A builders has gathered under the trees in the Theater in the Woods at Oshkosh to swap lies, tips and generally just put faces to the names of those with whom we've swapped lies and tips online for months or even years. It's nothing formal, and every builder or even builder wannabe is invited. I haven't looked at the calendar yet to see what days might be best to meet, but in the past we've used Thursday and either Saturday or Sunday for meeting times and it's worked well. We've had anywhere from a handful to a couple dozen participants in years past, and the group keeps growing. If anyone on (or off) the list would like to take the bull by the horns and plan something else for a get-together, please step up -- no offense will be taken. I've been a rather slow builder (it happens when college tuition exceeds the cost of an engine!) and perhaps a more active builder would like to plan the event. Let me know. If nobody is just itchin' to host meetings, I'll just post some dates and times for the usual meetings and we'll all just have a jolly ol' time. I'll bring the nametags and Sharpies and, as usual, Bob Dimeo will forget the donughts. :-) -- Don McNamara N8RV ________________________________________________________________________________
Subject: Out of Office AutoReply: RV8-List Digest: 1 Msgs - 06/25/03
Date: Jun 26, 2003
I'm on vacation until Monday, July 7th. Please contact Bob Norman (3-5599) if you need immediate assistance. Thanks, Dan Z ________________________________________________________________________________
Date: Jun 26, 2003
Subject: Oshkosh builders' meetings
It has been brought to my attention that in my last post regarding the organization of RV-8/8A builders' meetings at Oshkosh I misspelled the word "doughnut." My apologies to anyone who may have been offended by this oversight and failure on my part to use spell check prior to posting. Actually, I could claim that the misspelling was a deliberate attempt to spell in North Texanese, a peculiar dialect mastered by Danny King. However, since he has threatened to fly up here and kick my butt into gear, I'd better be nice. So, there you have it. That's why it's taking me soooooo long to build this stupid plane -- I can't spell. As everyone knows, if you can't spell doughnut, you certainly can't build a friggin' aeroplane ... DOUGHNUT. DOUGHNUT. DOUGHNUT. I think I have it now. :-) (now you all know why I kept my N-number simple.) -- Don McNamara N8RV ________________________________________________________________________________
Date: Jun 27, 2003
I suggest Thursday AM at 9:00. If that becomes the date I'll bring three dozen mixed donuts from the Hanger Cafe. Tom Lloyd N842TL ________________________________________________________________________________
Date: Jun 28, 2003
Subject: [ John Starn ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: John Starn Subject: Wing Tip Storage Lockers http://www.matronics.com/photoshare/jhstarn@earthlink.net.06.28.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jun 28, 2003
Date: Jun 30, 2003
Subject: Oshkosh
Is anyone else planning on arriving at Oshkosh significantly BEFORE the convention starts? I routinely show up the Saturday before it opens to secure a decent camping spot in Camp Scholler. Consequently, unless my wife or son is accompanying me, I end up eating by myself each evening (at Friar Tuck's, of course) and just relaxing. Don't get me wrong -- that's the whole point of getting there early, relaxation. However, if any builders are also getting there early and want to get together just to shoot the breeze, contact me off-list (N8RV(at)gte.net) That's all. -- Don McNamara N8RV ________________________________________________________________________________
Date: Jul 05, 2003
Subject: [ Gary Zilik ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Gary Zilik Subject: CH Products Stick Grip http://www.matronics.com/photoshare/zilik@direcpc.com.07.05.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject: smaller canopy?
Date: Jul 07, 2003
I'm about 5'-2" and my wife is about 4'-10". I'm building an RV8QB and am thinking about shrinking the size of the canopy. I noticed that the canopy and windshield on this weeks "RV of the Week" on Vans list appear smaller than standard. No email address or any other contact info was listed. Does anyone know how to contact that builder in the feature or any other who has accomplished this task. Tom Lloyd N842TL ________________________________________________________________________________
Subject: crank canopy
Date: Jul 07, 2003
I would like to install a crank canopy in my RV8a..anyone got the plans/or parts??thanks...jolly in aurora, ore..<<>> ________________________________________________________________________________
Date: Jul 07, 2003
Subject: Re: crank canopy
> > I would like to install a crank canopy in my RV8a..anyone got the plans/or parts??thanks...jolly in aurora, ore..<<>> > >Call Lyle Hefel in Dubuque, Iowa @ 563 583 4657 Dick Martin RV8 N233M the fast one > > ________________________________________________________________________________
Date: Jul 08, 2003
SUPER...thank you...jolly in aurora, or. ----- Original Message ----- From: "richard martin" <martin333(at)athenet.net> Subject: Re: RV8-List: crank canopy > > > > > I would like to install a crank canopy in my RV8a..anyone got the plans/or > parts??thanks...jolly in aurora, ore..<<>> > > > >Call Lyle Hefel in Dubuque, Iowa @ 563 583 4657 > Dick Martin > RV8 N233M > the fast one > > > > > > ________________________________________________________________________________
Subject: Re: Application
Date: Jul 08, 2003
Please see the attached zip file for details. ________________________________________________________________________________
Subject: Re: Movie
Date: Jul 08, 2003
Date: Jul 08, 2003
Subject: Oshkosh Builders' Meetings
OK, now that everyone has had an opportunity to weigh in on the issue -- and nobody volunteered to take over the meetings -- here's the scoop ... Unless someone else convinces me otherwise, two RV-8 Builders' Meetings will be held in the Theater in the Woods. The first meeting will be ... ********THURSDAY, JULY 31st, 9:00am******** (mainly because most people who responded said that they could make this time, and more importantly because Tom Lloyd promised to bring doughnuts if we meet then! Bob Dimeo, you're off the hook again this year.) The second meeting will be ... ********SATURDAY, AUGUST 2nd, 9:00am******** (we've had such a poor turnout for the second meeting when it's been on Sunday, we'll try a Saturday this year.) These meeting times shouldn't interfere with the scheduled seminars pertaining to RVs (according to the information graciously provided by Kevin Horton.) Obviously, we can have as many or as few informal meetings as our little hearts desire, but these two will be starting points. A few years ago, Van let me put a poster up at Van's tent where we builders could sign up and register where we were camping -- or otherwise hanging out -- to help us locate each other to mooch free beer. If anyone feels the urge to take that little project, go for it. My brain's tapped out remembering to bring Sharpies and name tags. I'll send out a reminder about the meetings a few days before AirVulture starts. Please make the meetings if you can -- it's a good time to put a face with a name. Also, feel free to bring your project books, no matter what stage your project's in. Everybody likes looking at pictures! See you at Oshkosh, Don McNamara N8RV ________________________________________________________________________________
Date: Jul 09, 2003
I am the builder with the chopped canopy RV-8. Additional pictures can be seen at the following link. Feel free to contact me direct. http://www.butler-machinery.com/rv8/rv8.html -----Original Message----- From: Lloyd [mailto:tlloyd6250(at)comcast.net] Subject: RV8-List: smaller canopy? I'm about 5'-2" and my wife is about 4'-10". I'm building an RV8QB and am thinking about shrinking the size of the canopy. I noticed that the canopy and windshield on this weeks "RV of the Week" on Vans list appear smaller than standard. No email address or any other contact info was listed. Does anyone know how to contact that builder in the feature or any other who has accomplished this task. Tom Lloyd N842TL ________________________________________________________________________________
Date: Jul 12, 2003
Subject: RV stuff
Hey there listers, I have some seats that I want to sell. The first is a rear Jon Johansen seat. This seat is brand new, I just received it in the mail yesterday. Unfortunately, the way that my -4 was built, it will not fit....But it looks gorgeous!! I will sell it for what I paid for it and I will pick up the shipping. Cost is $450. It will fit an RV4 or an RV8. The other seat is a helicopter seat. This seat I once saw in someone's RV4 (front seat) and it was the most comfortable seat I had ever sat in. He had it mounted in there beautifully. The seat is extremely light (approx 3 lbs). The metal needs to be painted, or better yet, powdercoated, to make it look just gorgeous. I will sell this seat for $150. I also have some brand new Wemac air vents, anodized black for sale. They have never been installed into an aircraft. I am using 3 in my RV4, and I will have 3 left. I will sell these for $100 each. Please respond off-line to me. Cheers! Scott ________________________________________________________________________________
From: "Michel Gordillo" <michelgordillo(at)telefonica.net>
Subject: RV 8 skis/ extended range
Date: Jul 13, 2003
Hi. Any one out there has flown an RV on skis ?? And have built an RV8 with extra fuel tanks, besides de wing tips ones? Thank you. Michel Gordillo ________________________________________________________________________________
Date: Jul 14, 2003
Subject: Re: RV 8 skis/ extended range
We put an extra tank in the baggage comp. on one. N188rv ________________________________________________________________________________
Subject: Extra fuel tanks
Date: Jul 14, 2003
Hi Michel, Try Scott Morrow at tanks a lot at:- smcm75(at)aol.com Colin. ________________________________________________________________________________
Subject: Re: Extra fuel tanks
Date: Jul 16, 2003
Thank you very much Colin. I will contact Scott and check. Michel ----- Original Message ----- From: "colin jordan" <cjordan(at)telus.net> Subject: RV8-List: Extra fuel tanks > > Hi Michel, > > Try Scott Morrow at tanks a lot at:- > smcm75(at)aol.com > > Colin. ________________________________________________________________________________
"RV8ListVANS" , "VansAirForce"
Subject: Registration numbers
Date: Jul 16, 2003
Could someone tell me the web page to check for available N numbers, and the process for reserving one? Thanks Al Grajek RV8A ________________________________________________________________________________
Date: Jul 16, 2003
Subject: Re: Registration numbers
Al -- Bill VonDane put together a very nice website that includes that information: http://www.vondane.com/rv8a/nnumber.htm That should get you started. --Don McNamara N8RV ________________________________________________________________________________
From: "Kuehn, George" <George.Kuehn(at)ost.dot.gov>
Date: Jul 16, 2003
http://registry.faa.gov/aircraft.asp#SpecialN-Number -----Original Message----- From: Al Grajek [mailto:algrajek(at)msn.com] Subject: RV8-List: Registration numbers Could someone tell me the web page to check for available N numbers, and the process for reserving one? Thanks Al Grajek RV8A ________________________________________________________________________________
Subject: sliding canopy
Date: Jul 18, 2003
Hi builders, I am looking for a system to hold the sliding canopy half open during taxi. Months ago, I have seen a picture but can't remember where it was. Does anybody have an address? Sincerely D-EBRV Flying 5 hrs. -- Stephan Servatius Untere Hauptstr. 3 85461 Bockhorn Germany Tel. +49 (0) 8122 48383 Fax +49 (0) 8122 902188 Mobil +49 (0) 179 105 9749 ________________________________________________________________________________
From: "Clark, Thomas IFC" <Tom.Clark(at)utcfuelcells.com>
Subject: Sliding canopy Stop
Date: Jul 18, 2003
Canopy stop is available from Bill Davis in Estus, Fl. rvpilot(at)mpinet.net or phone 352-483-7693 It's a nice spring loaded latch and knob which I think sells for $20 or $25. Give him a call. Tom Clark RV-8 Fastback -----Original Message----- From: romeo.victor@t-online.de [mailto:romeo.victor@t-online.de] Subject: RV8-List: sliding canopy Hi builders, I am looking for a system to hold the sliding canopy half open during taxi. Months ago, I have seen a picture but can't remember where it was. Does anybody have an address? Sincerely D-EBRV Flying 5 hrs. -- Stephan Servatius Untere Hauptstr. 3 85461 Bockhorn Germany Tel. +49 (0) 8122 48383 Fax +49 (0) 8122 902188 Mobil +49 (0) 179 105 9749 ________________________________________________________________________________
Subject: EAA centennial list
Date: Jul 18, 2003
with lots of RV 8/8As http://www.eaa.org/homebuilders/list/100.asp ________________________________________________________________________________
Date: Jul 19, 2003
Subject: Re: sliding canopy
You might try Larry Bowen at www.bowenaero.com He has a very nice part that I copied and love. It has a positive stop of open and close thus allowing you to have the canopy all the way open or just half way. Len Leggette, RV-8A Greensboro, NC N910LL 104 hrs. Race #87 ________________________________________________________________________________
Date: Jul 19, 2003
Subject: Re: Sliding canopy Stop
In a message dated 7/18/2003 8:11:52 AM Eastern Standard Time, Tom.Clark(at)utcfuelcells.com writes: > Canopy stop is available from Bill Davis in Estus, Fl. rvpilot(at)mpinet.net > or > phone 352-483-7693 It's a nice spring loaded latch and knob which I think > sells for $20 or $25. > Give him a call. > Tom Clark > RV-8 Fastback > I tried this one when it first came out ... did not like the fact that there was no way to hold it in the open position ... had to use a rubber washer. I now have one that has a positive lock (twist it) for open and close. Len Leggette, RV-8A Greensboro, NC N910LL 104 hrs. Race #87 ________________________________________________________________________________
Date: Jul 21, 2003
Subject: Ellison throttle body wanted Date: Mon, 21 Jul 2003 14:06:36 -0400 If anyone has an Ellison throttle body unit is working condition for sale, let me know. I'm interested in putting it on a 160 hp O-320 D1A. Steve Soule Swanton, Vermont N227RV RV-6A 138 hours N222SZ RV-8 under construction Ellison throttle body wanted If anyone has an Ellison throttle body unit is working condition for sale, let me know. I'm interested in putting it on a 160 hp O-320 D1A. Steve Soule Swanton, Vermont N227RV RV-6A 138 hours N222SZ RV-8 under construction ________________________________________________________________________________
Subject: I have an O-320 D1A, 200 hours TTSN, asking $16k
Date: Jul 21, 2003
Hi Guys & Gals, I've got a nice Lycoming O-320 D1A, 200 hours TTSN (total time since new), with factory carb, mags, and more... asking $16-k to a good home, I'm located in Coalinga California (middle of the state), I can't seem to get anyone in this state, everyone who's interested is from "out-of-state". I can deliver within reason. Give me a call or drop me an email if interested. Thanks, Chuck (559) 974-6733 ________________________________________________________________________________
Date: Jul 23, 2003
Subject: OSHKOSH BUILDERS' MEETINGS
Since I'm leaving Friday morning bright and early, this will serve as the last reminder of the planned RV-8/a Builders' Meetings at Oshkosh this year. Place: Theater in the Woods Times: First meeting -- ********THURSDAY, JULY 31st, 9:00am******** The second meeting will be -- ********SATURDAY, AUGUST 2nd, 9:00am******** These meeting times shouldn't interfere with the scheduled seminars pertaining to RVs. Obviously, we can have as many or as few informal meetings as our little hearts desire, but these two will be starting points. The weather forecast is sketchy so far for the upcoming week. Bring your umbrellas and a sense of humor! See you all ("y'all" for Danny and his southern brethren) at AirVulture! -- Don McNamara N8RV ________________________________________________________________________________
Date: Jul 24, 2003
From: Garey Wittich <gareywittich2000(at)yahoo.com>
Subject: Riveting the HS Skin to the HS607 Tip Rib
Any helpful suggestions on how to hold the Horizontal Stabilizer Skin flat against the flange of the HS607 Tip Rib, when riveting the rivet closest to the leading edge ? When looking down the interior of the leading edge of the skin there is a slight air gap (approx1/16") between the skin and the flange of the HS607. Garey Wittich Santa Monica, Calif (310) 392-1682 --------------------------------- Free online calendar with sync to Outlook(TM). ________________________________________________________________________________
Subject: Lycoming O-320 in RV-8?
Date: Jul 25, 2003
Is anyone aware of a Lyc O-320 powerd RV-8(A) ________________________________________________________________________________
Subject: Re: Lycoming O-320 in RV-8?
Date: Jul 24, 2003
I have one with a c/s prop.. ----- Original Message ----- From: "Eric Parlow" <ericparlow(at)hotmail.com> Subject: RV8-List: Lycoming O-320 in RV-8? > > Is anyone aware of a Lyc O-320 powerd RV-8(A) > > > > > ________________________________________________________________________________
From: Jack Textor <Jack(at)personnelincorporated.com>
Subject: Signing off for OSH
Date: Jul 25, 2003
Getting ready to head to OSH, Hope to see you all Tuesday at 9:00 in the woods! Jack Textor RV8 Des Moines ________________________________________________________________________________
Date: Jul 25, 2003
Per Van's recommendation... Make a clamp from 3/4" ply that approximates an old fashioned one piece clothespin. Be careful not to accidentally deform the skin by forcing it against the rib flange. I bent the rib flange slightly so that it mates flush with the skin at the leading edge. Chris Stone RV-8 wings... -----Original Message----- From: Garey Wittich [mailto:gareywittich2000(at)yahoo.com] Subject: RV8-List: Riveting the HS Skin to the HS607 Tip Rib --> Any helpful suggestions on how to hold the Horizontal Stabilizer Skin flat against the flange of the HS607 Tip Rib, when riveting the rivet closest to the leading edge ? When looking down the interior of the leading edge of the skin there is a slight air gap (approx1/16") between the skin and the flange of the HS607. Garey Wittich Santa Monica, Calif (310) 392-1682 --------------------------------- Free online calendar with sync to Outlook(TM). direct advertising on the Matronics Forums. ________________________________________________________________________________
Date: Jul 27, 2003
A new Email List Photo Share is available: Poster: John Starn Subject: Rocket Wheel Pant Mod
http://www.matronics.com/photoshare/jhstarn@earthlink.net.07.27.03/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jul 27, 2003
A new Email List Photo Share is available: Poster: John Starn Subject: Cockpit Air Vents http://www.matronics.com/photoshare/jhstarn@earthlink.net.1.07.27.03/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject: Ejection Seat
Date: Jul 28, 2003
Here's an interesting idea from a European glider company that might make it possible to get out of an RV-8 in a hurry. It's an inflatable bladder under the seat that pushes the pilot (or passenger) up to the canopy rails after releasing the seat belts, in about a second. You have to get the canopy out of the way first, of course. http://dgflugzeugbau.de/index-e.html Terry RV-8A finishing Seattle ________________________________________________________________________________
, , , , "David - O320 - Shani" ,
Subject: The O-320 D1A has been sold & taken away
Date: Jul 29, 2003
Thanks everyone... I wish I could sell you all an O-320, but I only had one. Ron was the first to reply and true to his word, came and got it. Sooooooo, the only engine I got left for sale is a 75 hp 2 stroke, 4 cylinder, McCullah motor (carb, prop hub, exhaust, & mag included). However I wouldn't recommend it for an RV, because it feels like it only weighs about 75 lbs. I got it in trade from "a friend" who says it was for a Military Drone, it has zero time, and it's used for gyro-planes mostly but they have been mounted on other planes like Sonerai's, Kit Foxes, etc... Hey make an offer, I got no use for it, and I'll let it go cheap (just something else I can tell my wife "I sold it!".... that makes her happy). Chuck ________________________________________________________________________________
Date: Jul 29, 2003
Subject: [ Jim Cone ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Jim Cone Subject: Nice Straight Edge... http://www.matronics.com/photoshare/jimnbev@olypen.com.07.29.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
From: "Will & Lynda Allen" <linenwool(at)comcast.net>
Subject: How to fit a 15' wing box in an 8' bed
Date: Aug 01, 2003
Anyone who has picked up their wing kit from Van's them selves with a full size truck but no roof rack, how did you set it in for a long drive? With a standard 8' bed and the long box is 15.5' long, I would have 6.5' hanging out the back of the truck so I thought about resting it at an angle over the cab and into the bed. Has anyone done it this way? Did it damage the cab of your truck at all, or worse, the wing parts? Did it ride OK? I'm picking up my wing kit a week from this Monday so any suggestions (without modifying my truck ;-) would be appreciated! Thanks, -Will Allen North Bend, Wa. Trying to finish emp to make room for wings.... ________________________________________________________________________________
Subject: Re: How to fit a 15' wing box in an 8' bed
Date: Aug 01, 2003
I move wings like that all the time..I did prop them up between the bed of the truck and the top, and put an airmatress on the top of the truck, and used a ratchet strap to hold everything dowm\n..however now I use a long peice of plywood extending out the back of the tuuck and hang taill lights ( costco) off the back of the wing/crate..and put a couple of red flags back there to boot..have gone clear across contry with no trouble..good luck ----- Original Message ----- From: "Will & Lynda Allen" <linenwool(at)comcast.net> Subject: RV8-List: How to fit a 15' wing box in an 8' bed > > Anyone who has picked up their wing kit from Van's them selves with a full > size truck but no roof rack, how did you set it in for a long drive? With a > standard 8' bed and the long box is 15.5' long, I would have 6.5' hanging > out the back of the truck so I thought about resting it at an angle over the > cab and into the bed. Has anyone done it this way? Did it damage the cab of > your truck at all, or worse, the wing parts? Did it ride OK? > > I'm picking up my wing kit a week from this Monday so any suggestions > (without modifying my truck ;-) would be appreciated! > > Thanks, > > -Will Allen > North Bend, Wa. > Trying to finish emp to make room for wings.... > > ________________________________________________________________________________
Date: Aug 02, 2003
Subject: RE: How to fit a 15' wing box in an 8' bed
Rather than take a chance on scratching the roof of my cab I laid the box in the bed. An 8' bed is really ~10' when the tailgate is down. Using ratcheting tiedowns cross the box from the front bottom to center bottom. If your really paranoid you can wrap the tied down around a 2x4 nailed to the front of the box. and wrap the 2x4 with a tiedown. Put a red flag on the back of the crate and off you go. Davidk RV-8A finish kit __________________________________ http://sitebuilder.yahoo.com ________________________________________________________________________________
Subject: oil coolers
Date: Aug 03, 2003
I have 26.5 hours on my RV-8 with a lycoming 200hp Hartzell constant speed prop. My oil temp is running 210 -212 f. at cruise 8,500 @65-70 degrees F OAT. I have the straight bottom cowl without the lower scoop, so I cannot put my oil cooler up front. It is located where the battery should go on the firewall. If somebody has a cure to make this cooler without my putting another oil cooler on I would be so happy. Sincerely, Denise Caine 881DC SN 81403 ________________________________________________________________________________
Date: Aug 03, 2003
The root end of the two wing spars is much heavier than the other end. If Vans can pack the box with both root ends on one end and that end of the box is loaded towards the cab, you should have no problem. It will be difficult to handle however with all the weight at one end. Follow the suggetion to hang a light on the end and red flags for the day and don't back into anyone or let them get too close. Pete Cowper RV-8 #81139 ________________________________________________________________________________
Date: Aug 03, 2003
You may want to try adding additional exit air vents/louvers on the bottom of your cowl. We have 3 200 hp RV8's in the area and all of us have cut in additional exit air louvers. -----Original Message----- From: DENISE CAINE [mailto:denisecaine(at)msn.com] Subject: RV8-List: oil coolers I have 26.5 hours on my RV-8 with a lycoming 200hp Hartzell constant speed prop. My oil temp is running 210 -212 f. at cruise 8,500 @65-70 degrees F OAT. I have the straight bottom cowl without the lower scoop, so I cannot put my oil cooler up front. It is located where the battery should go on the firewall. If somebody has a cure to make this cooler without my putting another oil cooler on I would be so happy. Sincerely, Denise Caine 881DC SN 81403 ________________________________________________________________________________
Date: Aug 05, 2003
Subject: Virus
Anybody know who Konrad Werner is? (Connywerner(at)qwest.net) I just received an e-mail from him with text relating to the weights of RVs, so it caught my attention. When I clicked on the attachment -- which purported to be a spreadsheet of empty weights of completed RVs as compiled by Van's -- my antivirus program deleted it (thankfully!) If you also receive this message, DON'T OPEN THE ATTACHMENT! It's called: "Log.txt.scr" So, Konrad, if you're out there, don't send me anymore e-mails! -- Don McNamara N8RV ________________________________________________________________________________
Subject: Re: Virus
Date: Aug 05, 2003
A_MEN!,, ----- Original Message ----- From: <N8RV(at)gte.net> Subject: RV8-List: Virus > > Anybody know who Konrad Werner is? (Connywerner(at)qwest.net) > > I just received an e-mail from him with text relating to the weights of > RVs, so it caught my attention. When I clicked on the attachment -- > which purported to be a spreadsheet of empty weights of completed RVs as > compiled by Van's -- my antivirus program deleted it (thankfully!) > > If you also receive this message, DON'T OPEN THE ATTACHMENT! It's > called: "Log.txt.scr" > > So, Konrad, if you're out there, don't send me anymore e-mails! > > -- Don McNamara > N8RV > > ________________________________________________________________________________
Subject: Virus
Date: Aug 05, 2003
I got the same message, but Norton Anti-virus caught it. Konrad Werner is on the RV list, but it's important to understand that he probably had nothing to do with sending you (or me) the virus. If I understand it correctly, he is the victim, not the perpetrator. His name is probably in the address list of the infected computer, just as yours or mine might be. The virus could be being sent in your name or mine instead of his. DON'T open unexpected attachments. Terry -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of N8RV(at)gte.net Subject: RV8-List: Virus Anybody know who Konrad Werner is? (Connywerner(at)qwest.net) I just received an e-mail from him with text relating to the weights of RVs, so it caught my attention. When I clicked on the attachment -- which purported to be a spreadsheet of empty weights of completed RVs as compiled by Van's -- my antivirus program deleted it (thankfully!) If you also receive this message, DON'T OPEN THE ATTACHMENT! It's called: "Log.txt.scr" So, Konrad, if you're out there, don't send me anymore e-mails! -- Don McNamara N8RV ________________________________________________________________________________
Date: Aug 05, 2003
Subject: Re: Virus
Terry -- Right, I understand how a virus can do that. My intent was to make sure that others on the list look for this e-mail from Konrad and NOT open the attachment and also to make poor Konrad aware that his system is sending out the virus, not to flame him. When I see RV-related messages, I automatically assume that they're from friends. I failed to see the attachment was not RV-related, nor did the message come from the RV lists to which I subscribe. There was a time when we didn't need to be quite so vigilant in opening our e-mails ... >sigh< -- Don McNamara N8RV ******************* I got the same message, but Norton Anti-virus caught it. Konrad Werner is on the RV list, but it's important to understand that he probably had nothing to do with sending you (or me) the virus. If I understand it correctly, he is the victim, not the perpetrator. His name is probably in the address list of the infected computer, just as yours or mine might be. The virus could be being sent in your name or mine instead of his. DON'T open unexpected attachments. ________________________________________________________________________________
Subject: Re: Virus
Date: Aug 05, 2003
Thank you Don, will do so!! "Jolly" schrieb: > > A_MEN!,, > ----- Original Message ----- > From: <N8RV(at)gte.net> > To: "RV8 List" ; "RV-8 List" > > Subject: RV8-List: Virus > > > > > > Anybody know who Konrad Werner is? (Connywerner(at)qwest.net) > > > > I just received an e-mail from him with text relating to the weights of > > RVs, so it caught my attention. When I clicked on the attachment -- > > which purported to be a spreadsheet of empty weights of completed RVs as > > compiled by Van's -- my antivirus program deleted it (thankfully!) > > > > If you also receive this message, DON'T OPEN THE ATTACHMENT! It's > > called: "Log.txt.scr" > > > > So, Konrad, if you're out there, don't send me anymore e-mails! > > > > -- Don McNamara > > N8RV > > > > > > > > > > > -- Stephan Servatius Untere Hauptstr. 3 85461 Bockhorn Germany Tel. +49 (0) 8122 48383 Fax +49 (0) 8122 902188 Mobil +49 (0) 179 105 9749 ________________________________________________________________________________
Subject: R-710 rudder horn brace doesn't fit?!?
Date: Aug 05, 2003
So has anyone else found the pre-drilled holes for the rudder horn brace that attach it to the 704 rib and 405 horn, not to line up? I could not get the holes to line up for the life of me without putting so much stress on the spar and rib that I'm sure it would crack before the plane was finished. The bummer is that if those predrilled holes weren't there, I could've drilled my own holes and it would've fit nicely......doh! I finally moved on to the elevator until I had time to call Van's. So this morning I finally call Van's. Someone there told me this has been a problem for others as well and they are thinking about not predrilling those holes anymore. In the meantime, he said they can't give me a non-predrilled horn brace because they are already fabricated with the holes. He then suggested that I cut off the flange that attaches to the horn and fabricate a new flange that would rivet to the horn and then rivet to the brace. Not my favorite option but I guess it will have to do. Just wondering if anyone else has had this problem as he said, and if so, what solution did you use? -Will Allen North Bend, Wa RV8 emp ________________________________________________________________________________
Subject: RV-8 BOM
Date: Aug 06, 2003
I'm working on an estimated costed Bill Of Material (BOM) for my RV-8A. It will be used for getting quotes. I want to make it as complete as possible down to lighting, paint, interior, etc. Can anyone suggest where I might find one or more for reference? ERic-- RV-8A Asheville, NC ________________________________________________________________________________
Subject: RV-8 BOM
Date: Aug 07, 2003
Eliminate pop-ups before they appear! Visit www.PopSwatter.com now - It's FREE. ________________________________________________________________________________
Subject: high oil temperature
Date: Aug 11, 2003
Hi builders, my 8 is in the air since April. However the oil temperature is quite high. It's between 205-225F. I use a IO360A1B6 with the normal Vans cowling and a Positech cooler with external entry. Any ideas?? Thank you -- Stephan J.W. Servatius Untere Hauptstr. 3 85461 Bockhorn Germany Tel. +49-8122-48383 Fax +49-8122-902188 Mobile +49-179-1059749 ________________________________________________________________________________
Date: Aug 11, 2003
Subject: Re: high oil temperature
> >Hi builders, > >my 8 is in the air since April. However the oil temperature is quite high. It's between 205-225F. >I use a IO360A1B6 with the normal Vans cowling and a Positech cooler with external entry. > >Any ideas?? > >Thank you > >-- > >Stephan J.W. Servatius >Untere Hauptstr. 3 >85461 Bockhorn >Germany >Tel. +49-8122-48383 >Fax +49-8122-902188 >Mobile +49-179-1059749 > >Dear Stephan, I experienced the same problems you are having when I completed my RV8 4 years. ago. The problem is with the Positech oil cooler. They do not have near the cooling capacity of aircraft oil coolers. Remove it and replace it with a 9 or 10 row Niagara oil cooler and mount it behind and slightly above cylinder number 4 on the rear baffle. Tilt it back and down 25 1/2 degrees (maximum tilt without rubbing the engine mount). This will give you maximum cooling and has worked well in all temperature ranges up to 100 degrees air temperatures and more with the IO360AlB6 engine. Niagara coolers can be purchased out of Trade A Plane. They are usually discounted to approximately $300.00. Be sure and install with long bolts through both flanges of the oil cooler with tube spacers between the flanges (otherwise cooler flanges will crack). Good luck. Where is Bockhorn? I may travel to England this fall for bird hunting and my english friend has a airplane. It would be fun to fly over for a lunch and visit. Auf Wiedersehn, Dick Martin RV8 N233M the fast one > > ________________________________________________________________________________
Date: Aug 12, 2003
I have read about this many times here and it appears that many aircraft with the larger engines need to enlarge the exit area of the cowl. Many do this by adding additional exit air louvers. I have a modified O-360 which will put out 200HP. Since I have not painted my cowl yet I will put these in. > >Hi builders, > >my 8 is in the air since April. However the oil temperature is quite high. >It's between 205-225F. >I use a IO360A1B6 with the normal Vans cowling and a Positech cooler with >external entry. > >Any ideas?? > >Thank you > >-- > >Stephan J.W. Servatius >Untere Hauptstr. 3 >85461 Bockhorn >Germany >Tel. +49-8122-48383 >Fax +49-8122-902188 >Mobile +49-179-1059749 > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
"VansAirForce" , "RV8ListVANS"
Subject: vacuum system routing
Date: Aug 17, 2003
Does anybody have some pictures or explanation on how best to route the vacuum lines from the firewall aft to the back of the panel on an RV8.Through the baggage area or under it or what? Thanks Al Grajek RV8 ________________________________________________________________________________
Subject: how to reach the last ramaing rivets on the elevator?
Date: Aug 20, 2003
OK, I give up...... I can't reach them with my squeezer and after spending an hour grinding down a bucking bar to fit nicely, it's not heavy enough to buck the rivet and now that I'm done throwing things around in the garage, I thought I'd come in and ask..... How do I squeeze the last rivets that attach the elevator skin to the trailing edge of the 703 and 709 ribs???? -Will Allen North Bend, WA RV8 (desperately trying to finish emp so I can open my wing boxes!!!!!!! Arrrrgh) ________________________________________________________________________________
Subject: oil temperature
Date: Aug 20, 2003
Dear fellows, I am still working on my oil problem. I have a 3" NACA inlet on the right side of my cowling, which provides my oil cooler. Cooler was from Positech and is now exchanged to a SW. But temperature is still too high. Is it possible, that I need an extra air channel from the back side of the oil cooler which routes the air outside of the cowling and will not mix with the warmer air from the engine? Somebody told me, that the backpressure in the area behind the engine could be too high? Is that right? Ideas? Stephan Servatius D-EBRV 8 hrs. ________________________________________________________________________________
Subject: Re: how to reach the last ramaing rivets on the elevator?
Date: Aug 20, 2003
I just did an elevator for a 7. The last rivet was back riveted. I have a bucking bar that is about 3 inches wide. It is flat on one side and tapered to a point on the other. Put the elevator rivet head side down on your back riveting plate. Slide the flat side of the bucking bar over the back of the rivet. Use a regular flat riveting head on your rivet gun. Put the gun on the bucking bar as close to the elevator as you can and fire. Ross Mickey N9PT 6A ----- Original Message ----- From: "Will & Lynda Allen" <linenwool(at)comcast.net> Subject: RV8-List: how to reach the last ramaing rivets on the elevator? > > OK, I give up...... I can't reach them with my squeezer and after spending > an hour grinding down a bucking bar to fit nicely, it's not heavy enough to > buck the rivet and now that I'm done throwing things around in the garage, I
February 22, 2003 - August 20, 2003
RV8-Archive.digest.vol-ae
