RV8-Archive.digest.vol-al
October 20, 2007 - July 20, 2008
      >-----Original Message-----
      >From: owner-rv8-list-server(at)matronics.com
      >[mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of James Gray
      >Sent: Thursday, October 18, 2007 2:26 PM
      >To: rv8-list(at)matronics.com
      >Subject: Re: RV8-List: Re: RV8-Instrument Panel
      >And that brings me to my pet peeve, and this will probably draw the ire
      >of several builders, but the RV-8 essentially is designed as any center
      >line military airplane would be designed, the stick is in the right hand
      >and the throttle is in the left.  As a result, the free hand is the left
      >hand. Military designers try to lay out switches so the right hand NEVER
      >has to leave the stick during periods of high work load.
      >Jim
      >Jim: I appreciate your viewpoint on control layout and I do not quarrel
      >with it. That said, I am not persuaded by your argument. My -8 will
      >resemble my -4 which has the com radio and transponder on the right along
      >with exterior light switches. With the -4 it turns out that when I reach
      >for a knob or switch with my right hand, somehow, as if by magic, my left
      >hand is on the stick.Vice versaif necessary for urgent attention to
      >throttle or prop. In panel center are GRT EFIS Sport above and Garmin 496
      >below. TheTrio EZ pilot replaces the turn and slip.
      >Gordon Comfort
      >N363GC
      >________________________________________________________________________
      >Email and AIM finally together. You've gotta check out free AOL Mail! -
      >http://mail.aol.com
Date: Oct 20, 2007
From: George Inman 204 287 8334 <ghinman(at)mts.net>
Subject: Aileron pushtube holes in fuselauge
Has anyone had to enlarge the holes in the fuselage where the aileron push tubes pass through? I want to put in boots,but need to know if I might have to enlarge the holes when wings are mounted. RV-8 QB. -- George H. Inman ghinman(at)mts.net ________________________________________________________________________________
Subject: Re: Aileron pushtube holes in fuselauge
Date: Oct 21, 2007
There is plenty of room. Should be no need to enlarge. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________________________________________________________
Date: Oct 21, 2007
Yes, I had to enlarge both sides. Used a Dremel. I did it when I was trial fitting the ailerons, before the wings went on. Watch the movement from the bellcrank to where it connects with the aileron. Steve Gregory RV-8QB Livermore, CA -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of George Inman 204 287 8334 Sent: Saturday, October 20, 2007 7:08 PM Subject: RV8-List: Aileron pushtube holes in fuselauge Has anyone had to enlarge the holes in the fuselage where the aileron push tubes pass through? I want to put in boots,but need to know if I might have to enlarge the holes when wings are mounted. RV-8 QB. -- George H. Inman ghinman(at)mts.net ________________________________________________________________________________
Subject: Re: RV8a Electric Aileron Trim
Date: Oct 22, 2007
Dear Fellow RV-8a Builders, I have the spring type trim setup, but have not installed it yet. Good friend told me that most folks use the manual spring trim if they are installing an auto pilot system and or use the electric trim system if not. I do not plan to install an auto pilot so is the electric system really recommended ? I have electric aileron trim on my present plane and I like how?manageable and easy it is. Who has the electric trim without auto pilot in their 8 and how does it compare to spring system ? Advantages/disadvantages? Hope to hear from someone and best regards, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Mon, 22 Oct 2007 2:57 am Subject: RV8-List Digest: 2 Msgs - 10/21/07 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-10-21&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-10-21&Archive=RV8 =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Sun 10/21/07: 2 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 03:01 AM - Re: Aileron pushtube holes in fuselauge (Steve Glasgow) 2. 10:04 AM - Re: Aileron pushtube holes in fuselauge (Steve Gregory) ________________________________ Message 1 _____________________________________ From: "Steve Glasgow" <willfly(at)carolina.rr.com> Subject: Re: RV8-List: Aileron pushtube holes in fuselauge There is plenty of room. Should be no need to enlarge. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________ Message 2 _____________________________________ From: "Steve Gregory" <sgregory(at)best.com> Subject: RE: RV8-List: Aileron pushtube holes in fuselauge Yes, I had to enlarge both sides. Used a Dremel. I did it when I was trial fitting the ailerons, before the wings went on. Watch the movement from the bellcrank to where it connects with the aileron. Steve Gregory RV-8QB Livermore, CA -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of George Inman 204 287 8334 Sent: Saturday, October 20, 2007 7:08 PM Subject: RV8-List: Aileron pushtube holes in fuselauge Has anyone had to enlarge the holes in the fuselage where the aileron push tubes pass through? I want to put in boots,but need to know if I might have to enlarge the holes when wings are mounted. RV-8 QB. -- George H. Inman ghinman(at)mts.net ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Oct 22, 2007
I have the electric trim and love it, Its very easy to use on stick. You don't have to move your hand off the stick. go for the electric . All the best Kirk RV-8 Sent from my iPhone On Oct 22, 2007, at 4:05 PM, japhillipsga(at)aol.com wrote: > Dear Fellow RV-8a Builders, I have the spring type trim setup, but > have not installed it yet. Good friend told me that most folks use > the manual spring trim if they are installing an auto pilot system > and or use the electric trim system if not. I do not plan to install > an auto pilot so is the electric system really recommended ? I have > electric aileron trim on my present plane and I like how manageable > and easy it is. Who has the electric trim without auto pilot in > their 8 and how does it compare to spring system ? Advantages/ > disadvantages? Hope to hear from someone and best regards, Bill of > Georgia > > > -----Original Message----- > From: RV8-List Digest Server <rv8-list(at)matronics.com> > To: RV8-List Digest List > Sent: Mon, 22 Oct 2007 2:57 am > Subject: RV8-List Digest: 2 Msgs - 10/21/07 > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest > formatted > in HTML for viewing with a web browser and features Hyperlinked > Indexes > and Message Navigation. The .txt file includes the plain ASCII > version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-10-21&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-10-21&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Sun 10/21/07: 2 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 03:01 AM - Re: Aileron pushtube holes in fuselauge (Steve > Glasgow) > 2. 10:04 AM - Re: Aileron pushtube holes in fuselauge (Steve > Gregory) > > > ________________________________ Message 1 > _____________________________________ > > > From: "Steve Glasgow" <willfly(at)carolina.rr.com> > Subject: Re: RV8-List: Aileron pushtube holes in fuselauge > > > There is plenty of room. Should be no need to enlarge. > > Steve Glasgow-Cappy > N123SG RV-8 > Cappy's Toy > > > ________________________________ Message 2 > _____________________________________ > > > From: "Steve Gregory" <sgregory(at)best.com> > Subject: RE: RV8-List: Aileron pushtube holes in fuselauge > > > Yes, I had to enlarge both sides. Used a Dremel. I did it when I > was trial > fitting the ailerons, before the wings went on. Watch the movement > from the > bellcrank to where it connects with the aileron. > > Steve Gregory > RV-8QB > Livermore, CA > > -----Original Message----- > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of George > Inman 204 > 287 8334 > Sent: Saturday, October 20, 2007 7:08 PM > Subject: RV8-List: Aileron pushtube holes in fuselauge > > > Has anyone had to enlarge the holes in the > fuselage where the aileron push tubes pass through? > I want to put in boots,but need to know if I might have to > enlarge the holes when wings are mounted. > RV-8 QB. > > -- > > George H. Inman > ghinman(at)mts.net > > > Email and AIM finally together. You've gotta check out free AOL Mail! > > ________________________________________________________________________________
Date: Oct 22, 2007
Same for me. Get the electric aileron trim. I have both aileron and elevator trim on an Infinity stick coolie hat, to a homebrew relay system. I'm very happy with the set up. Carl Froehlich RV-8A (350 hrs) Dogwood Airpark (VA42) _____ From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Kirk&Laura Groves Sent: Monday, October 22, 2007 5:10 PM Subject: Re: RV8-List: Re: RV8a Electric Aileron Trim I have the electric trim and love it, Its very easy to use on stick. You don't have to move your hand off the stick. go for the electric . All the best Kirk RV-8 Sent from my iPhone On Oct 22, 2007, at 4:05 PM, japhillipsga(at)aol.com wrote: Dear Fellow RV-8a Builders, I have the spring type trim setup, but have not installed it yet. Good friend told me that most folks use the manual spring trim if they are installing an auto pilot system and or use the electric trim system if not. I do not plan to install an auto pilot so is the electric system really recommended ? I have electric aileron trim on my present plane and I like how manageable and easy it is. Who has the electric trim without auto pilot in their 8 and how does it compare to spring system ? Advantages/disadvantages? Hope to hear from someone and best regards, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Mon, 22 Oct 2007 2:57 am Subject: RV8-List Digest: 2 Msgs - 10/21/07 * ======================== Online Versions of Today's List Digest Archive ======================== Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: <http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapte r 07-10-21&Archive=RV8> http://www.matronics.com/digest/digestview.php?Style=82701 <http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapte r 07-10-21&Archive=RV8> &View=html&Chapter 07-10-21&Archive=RV8 Text Version: <http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-10-21&Archive=RV8> http://www.matronics.com/digest/digestview.php?Style=82701 <http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-10-21&Archive=RV8> &View=txt&Chapter 07-10-21&Archive=RV8 =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Sun 10/21/07: 2 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 03:01 AM - Re: Aileron pushtube holes in fuselauge (Steve Glasgow) 2. 10:04 AM - Re: Aileron pushtube holes in fuselauge (Steve Gregory) ________________________________ Message 1 _____________________________________ From: "Steve Glasgow" < <mailto:willfly(at)carolina.rr.com> willfly(at)carolina.rr.com> Subject: Re: RV8-List: Aileron pushtube holes in fuselauge There is plenty of room. Should be no need to enlarge. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________ Message 2 _____________________________________ From: "Steve Gregory" < <mailto:sgregory(at)best.com> sgregory(at)best.com> Subject: RE: RV8-List: Aileron pushtube holes in fuselauge Yes, I had to enlarge both sides. Used a Dremel. I did it when I was trial fitting the ailerons, before the wings went on. Watch the movement from the bellcrank to where it connects with the aileron. Steve Gregory RV-8QB Livermore, CA -----Original Message----- From: <mailto:owner-rv8-list-server(at)matronics.com> owner-rv8-list-server(at)matronics.com [mailto: owner-rv8-list-server(at)matronics.com] On Behalf Of George Inman 204 287 8334 Sent: Saturday, October 20, 2007 7:08 PM Subject: RV8-List: Aileron pushtube holes in fuselauge Has anyone had to enlarge the holes in the fuselage where the aileron push tubes pass through? I want to put in boots,but need to know if I might have to enlarge the holes when wings are mounted. RV-8 QB. -- George H. Inman ghinman(at)mts.net _____ Email and AIM finally together. You've gotta check out free AOL Mail <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?ncid=A OLAOF00020000000970> ! href="http://www.matronics.com/Navigator?RV8-List">http://www.matronics.com/ Navigator?RV8-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Oct 22, 2007
I have electric aileron and elevator trim on my RV-8. I did something different and mounted the elevator trim switch on the throttle. It has worked out quite well and is in a handy place. I would really suggest you install a autopilot while you are building. It is much easier now than later. I thought that altitude hold was not necessary until the first cross country. That is when I learned how pitch sensitive the RV is while fighting with maps. I'm now in the middle of adding altitude hold. Talk about one step forward and six backwards. Tom Schad RV-8 N558TX ----- Original Message ----- From: Carl Froehlich To: rv8-list(at)matronics.com Sent: Monday, October 22, 2007 5:20 PM Subject: RE: RV8-List: Re: RV8a Electric Aileron Trim Same for me. Get the electric aileron trim. I have both aileron and elevator trim on an Infinity stick coolie hat, to a homebrew relay system. I'm very happy with the set up. Carl Froehlich RV-8A (350 hrs) Dogwood Airpark (VA42) ------------------------------------------------------------------------- ----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Kirk&Laura Groves Sent: Monday, October 22, 2007 5:10 PM To: rv8-list(at)matronics.com Subject: Re: RV8-List: Re: RV8a Electric Aileron Trim I have the electric trim and love it, Its very easy to use on stick. You don't have to move your hand off the stick. go for the electric . All the best Kirk RV-8 Sent from my iPhone On Oct 22, 2007, at 4:05 PM, japhillipsga(at)aol.com wrote: Dear Fellow RV-8a Builders, I have the spring type trim setup, but have not installed it yet. Good friend told me that most folks use the manual spring trim if they are installing an auto pilot system and or use the electric trim system if not. I do not plan to install an auto pilot so is the electric system really recommended ? I have electric aileron trim on my present plane and I like how manageable and easy it is. Who has the electric trim without auto pilot in their 8 and how does it compare to spring system ? Advantages/disadvantages? Hope to hear from someone and best regards, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> To: RV8-List Digest List Sent: Mon, 22 Oct 2007 2:57 am Subject: RV8-List Digest: 2 Msgs - 10/21/07 * Online Versions of Today's List Digest Archive Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html& Chapter 07-10-21&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&C hapter 07-10-21&Archive=RV8 ======================= EMail Version of Today's List Digest Archive ======================= ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Sun 10/21/07: 2 ---------------------------------------------------------- Today's Message Index:---------------------- 1. 03:01 AM - Re: Aileron pushtube holes in fuselauge (Steve Glasgow) 2. 10:04 AM - Re: Aileron pushtube holes in fuselauge (Steve Gregory) ________________________________ Message 1 "Steve Glasgow" Subject: Re: RV8-List: Aileron pushtube holes in fuselauge There is plenty of room. Should be no need to enlarge. Steve Glasgow-CappyN123SG RV-8Cappy's Toy ________________________________ Message 2 "Steve Gregory" Subject: RE: RV8-List: Aileron pushtube holes in fuselauge Yes, I had to enlarge both sides. Used a Dremel. I did it when I was trialfitting the ailerons, before the wings went on. Watch the movement from thebellcrank to where it connects with the aileron. Steve Gregory RV-8QBLivermore, CA -----Original Message-----From: owner-rv8-list-server(at)matronics.com[mailto:owner-rv8-list-server@matronic s.com] On Behalf Of George Inman 204287 8334Sent: Saturday, October 20, 2007 7:08 PMSubject: RV8-List: Aileron pushtube holes in fuselauge Has anyone had to enlarge the holes in thefuselage where the aileron push tubes pass through? I want to put in boots,but need to know if I might have toenlarge the holes when wings are mounted. RV-8 QB. -- George H. Inmanghinman(at)mts.net ------------------------------------------------------------------------- --- Email and AIM finally together. You've gotta check out free AOL Mail! href="http://www.matronics.com/Navigator?RV8-List">http://www.matronics .com/Navigator?RV8-Listhref="http://forums.matronics.com">http://forums .matronics.com ________________________________________________________________________________
Date: Oct 22, 2007
Bill: I have electric trim and am very happy with it. Flew the first couple of years without autopilot but now have that also ... still love the electric trim when not flying on autopilot. Len Leggette, RV-8A Greensboro, NC N910LL 595 hrs In a message dated 10/22/2007 4:08:14 PM Eastern Daylight Time, japhillipsga(at)aol.com writes: Dear Fellow RV-8a Builders, I have the spring type trim setup, but have not installed it yet. Good friend told me that most folks use the manual spring trim if they are installing an auto pilot system and or use the electric trim system if not. I do not plan to install an auto pilot so is the electric system really recommended ? I have electric aileron trim on my present plane and I like how manageable and easy it is. Who has the electric trim without auto pilot in their 8 and how does it compare to spring system ? Advantages/disadvantages? Hope to hear from someone and best regards, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Mon, 22 Oct 2007 2:57 am Subject: RV8-List Digest: 2 Msgs - 10/21/07 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: _http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-10-21&Archive=RV8_ (http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-10-21&Archive=RV8) Text Version: _http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-10-21&Archive=RV8_ (http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-10-21&Archive=RV8) =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Sun 10/21/07: 2 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 03:01 AM - Re: Aileron pushtube holes in fuselauge (Steve Glasgow) 2. 10:04 AM - Re: Aileron pushtube holes in fuselauge (Steve Gregory) ________________________________ Message 1 _____________________________________ From: "Steve Glasgow" <_willfly(at)carolina.rr.com_ (mailto:willfly(at)carolina.rr.com) > Subject: Re: RV8-List: Aileron pushtube holes in fuselauge There is plenty of room. Should be no need to enlarge. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________ Message 2 _____________________________________ From: "Steve Gregory" <_sgregory(at)best.com_ (mailto:sgregory(at)best.com) > Subject: RE: RV8-List: Aileron pushtube holes in fuselauge Yes, I had to enlarge both sides. Used a Dremel. I did it when I was trial fitting the ailerons, before the wings went on. Watch the movement from the bellcrank to where it connects with the aileron. Steve Gregory RV-8QB Livermore, CA -----Original Message----- From: _owner-rv8-list-server(at)matronics.com_ (mailto:owner-rv8-list-server(at)matronics.com) [_mailto:owner-rv8-list-server(at)matronics.com_ (mailto:owner-rv8-list-server(at)matronics.com?) ] On Behalf Of George Inman 204 287 8334 Sent: Saturday, October 20, 2007 7:08 PM Subject: RV8-List: Aileron pushtube holes in fuselauge Has anyone had to enlarge the holes in the fuselage where the aileron push tubes pass through? I want to put in boots,but need to know if I might have to enlarge the holes when wings are mounted. RV-8 QB. -- George H. Inman _ghinman(at)mts.net_ (mailto:ghinman(at)mts.net) ____________________________________ Email and AIM finally together. You've gotta check out free _AOL Mail_ (http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?ncid=AOLAOF000 20000000970) ! (http://www.matronics.com/Navigator?RV8-List) ________________________________________________________________________________
Subject: Re: RV8-List Fuel Vent lines
Date: Oct 24, 2007
Rv-8 fellows, I'm working on my plumbing, fuel and brake. The plans shows the end of the vent tubing out the floor and bent forward. Is there a particular important reason why the drip end is pointed forward as opposed to to the rear ? I think I saw a couple RVs at Sun n Fun with the tubes rearward. Second question: The plans shows the brake lines going to the landing gear weldment and exit down at the leg. What have you all done in the past ? ?Make a separate hole in the floor near the weldment that you can snap in a plastic sleeve for friction protection or enlarge the gear hole and run it out against the steel leg ? Thanks ahead of time and best regards, Bill of Georgia? -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Wed, 24 Oct 2007 2:57 am Subject: RV8-List Digest: 0 Msgs - 10/23/07 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-10-23&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-10-23&Archive=RV8 =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Tue 10/23/07: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Oct 24, 2007
Hello Bill, Regarding the vents: I assume that the vents are pointed forward to insure that the fuel tanks have slight positive pressure in them when in flight, vs a possible vacuum if the vents were pointed aft. In addition, pointing the vents aft may cause a little siphoning of fuel out of the vents. Regarding brake lines: On my RV-8, the way I plumbed the brake lines was strictly per plans; run the lines from the brake fitting bracket out to the landing gear towers along the bottom edge of the rear baggage compartment bulkhead, and into the middle lightening hole in the landing gear "towers". From there the brake lines run down to the bottom of the towers where they attach to bulkhead elbows that penetrate the fuselage bottom (inside the gear towers). The location for this is identified in the plans. I have attached a picture where you can see left brake line run inside the fuselage. Skylor RV-8 QB Under construction N808SJ --- japhillipsga(at)aol.com wrote: > Rv-8 fellows, I'm working on my plumbing, fuel and > brake. The plans shows the end of the vent tubing > out the floor and bent forward. Is there a > particular important reason why the drip end is > pointed forward as opposed to to the rear ? I think > I saw a couple RVs at Sun n Fun with the tubes > rearward. Second question: The plans shows the brake > lines going to the landing gear weldment and exit > down at the leg. What have you all done in the past > ? ?Make a separate hole in the floor near the > weldment that you can snap in a plastic sleeve for > friction protection or enlarge the gear hole and run > it out against the steel leg ? Thanks ahead of time > and best regards, Bill of Georgia? > > > -----Original Message----- > From: RV8-List Digest Server > > To: RV8-List Digest List > > Sent: Wed, 24 Oct 2007 2:57 am > Subject: RV8-List Digest: 0 Msgs - 10/23/07 > > > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found > in either of the > two Web Links listed below. The .html file includes > the Digest formatted > in HTML for viewing with a web browser and features > Hyperlinked Indexes > and Message Navigation. The .txt file includes the > plain ASCII version > of the RV8-List Digest and can be viewed with a > generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-10-23&Archive=RV8 > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-10-23&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Tue > 10/23/07: 0 > > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > > > > > ________________________________________________________________________ > Email and AIM finally together. You've gotta check > out free AOL Mail! - http://mail.aol.com > __________________________________________________ ________________________________________________________________________________
Date: Oct 24, 2007
When building my RV-8A there were reports of RVs having forced landings or collapsed fuel tanks caused by clogged vent lines, typically mud daubers. I read a couple of articles on aircraft vent lines and the clear recommendation was to not have a vent line smaller than 3/8=94. I ended up transitioning from =BC to 3/8 inch line about 10 inches before the vent line exited the bottom of the fuselage. For the portion sticking out in the wind, I cut the end of the 3/8=94 tubing at a 45 degree angle and then epoxied (JB Weld) a piece of aluminum window screen over the 45 degree bevel. Once the epoxy was set I smoothed out the edges on a scotch bright wheel. The bevel faces into the wind to provide a positive pressure on the vent line, as is standard. The 3/8=94 tubing is big enough to allow for attaching the window screen and the window screen eliminates the mud dauber problem. Carl Froehlich RV-8A (360 hrs) Dogwood Airpark (VA-42) _____ From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of japhillipsga(at)aol.com Sent: Wednesday, October 24, 2007 1:51 PM Subject: RV8-List: Re: RV8-List Fuel Vent lines Rv-8 fellows, I'm working on my plumbing, fuel and brake. The plans shows the end of the vent tubing out the floor and bent forward. Is there a particular important reason why the drip end is pointed forward as opposed to to the rear ? I think I saw a couple RVs at Sun n Fun with the tubes rearward. Second question: The plans shows the brake lines going to the landing gear weldment and exit down at the leg. What have you all done in the past ? Make a separate hole in the floor near the weldment that you can snap in a plastic sleeve for friction protection or enlarge the gear hole and run it out against the steel leg ? Thanks ahead of time and best regards, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Wed, 24 Oct 2007 2:57 am Subject: RV8-List Digest: 0 Msgs - 10/23/07 * Online Versions of Today's List Digest Archive Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701 <http://www.matronics.com/digest/digestview.php?Style=82701&View=html &Chapte r 07-10-23&Archive=RV8> &View=html&Chapter 07-10-23&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701 <http://www.matronics.com/digest/digestview.php?Style=82701&View=txt& Chapter 07-10-23&Archive=RV8> &View=txt&Chapter 07-10-23&Archive=RV8 ====================== EMail Version of Today's List Digest Archive ====================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Tue 10/23/07: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- _____ size=2 width="100%" align=center> Email and AIM finally together. You've gotta check out free AOL Mail <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?nci d=A OLAOF00020000000970> ! ________________________________________________________________________________
From: "Mile High Aviation" <joe@mile-high-aviation.com>
Subject: Best Prices Offered Anywhere
Date: Oct 25, 2007
Mile High Aviation We Will Not Be Undersold! ASA Pathfinder CX-2 Electronic Flight Computer CX-2 Flight Computer Price $61.95 Retail Price $80.00 To Order Call: 401-228-6677 Http://WWW.MILE-HIGH-AVIATION.COM ________________________________________________________________________________
Subject: Fuel Vent lines
Date: Oct 26, 2007
Bill, On my pre-punched RV-8a the plans call for a 45 degree bulkhead fitting in the hole in the landing gear weldment. The fitting goes in from the bottom with the nut up at the weldment. Orient the 45 degree fitting so that it aims down the gear leg. Cheers, Guy From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of japhillipsga(at)aol.com Sent: Wednesday, October 24, 2007 11:51 AM Subject: RV8-List: Re: RV8-List Fuel Vent lines Rv-8 fellows, I'm working on my plumbing, fuel and brake. The plans shows the end of the vent tubing out the floor and bent forward. Is there a particular important reason why the drip end is pointed forward as opposed to to the rear ? I think I saw a couple RVs at Sun n Fun with the tubes rearward. Second question: The plans shows the brake lines going to the landing gear weldment and exit down at the leg. What have you all done in the past ? Make a separate hole in the floor near the weldment that you can snap in a plastic sleeve for friction protection or enlarge the gear hole and run it out against the steel leg ? Thanks ahead of time and best regards, Bill of Georgia ________________________________________________________________________________
Date: Oct 27, 2007
Subject: [ Rob Ray ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Rob Ray Lists: Rocket-List,RV-List,RV3-List,RV4-List,RV6-List,RV7-List,RV8-List,RV9-List,RV10-List Subject: Bigger Tires http://www.matronics.com/photoshare/smokyray@yahoo.com.10.27.2007/index.html ---------------------------------------------------------- o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ---------------------------------------------------------- ________________________________________________________________________________
Date: Oct 31, 2007
Subject: Wing root faring at bottom
What did some of you builders do where the wing root faring meets the skin that extends from the bottom of fuselage to the wing? The holes provided in the wing root faring do not seem to provide enough attachement points. RV-8 QB. -- George H. Inman ghinman(at)mts.net ________________________________________________________________________________
Date: Nov 01, 2007
Subject: November is Matronics Email List Fund Raiser Month!
Dear Listers, You've probably noticed that there are no banner ads or pop-up windows or spam from any of the List and Forum services at Matronics. These include, for example: The Email List Postings - http://www.matronics.com/listbrowse The Email List Forum Site - http://forums.matronics.com The List Wiki - http://wiki.matronics.com The List Search Engine - http://www.matronics.com/search This is because I have always enjoyed a List experience that was completely about the sport we enjoy - airplanes - and not about advertising! But running a high performance, highly available service like this isn't free and a fair amount of money in terms of computer upgrades, business-class Internet connectivity, and electricity. Consequently, many similar sites turn to advertising to support these costs. Advertising that you have to look at each and every time you read an email message or browse the their web site. Rather than subject my List community to another constant commercial bombardment, I have chosen to hold a PBS-like fund raiser each year in November to support the continued operation and upgrade of the List services. It's solely through the Contributions of List members that the Lists and Forums continue to be possible! During the month, I will be sending out a Fund Raiser reminder message every few days and I ask for your patience and understanding during the month throughout these regular messages. Think of them as PBS' Pledge Breaks... :-) To minimize the impact of the Fund Raiser on the List community, I implemented a new feature late last year specifically related to making Contributions. If you are an Email List subscriber, once you make a Contribution using the online web site, you will no longer receive the email from me regarding the Fund Raiser! There are a couple of exceptions to this, however. If someone replies to a Contribution message I've sent, you might receive that. Additionally, the messages will always be posted to the Forums site. To a first order, however, once you make a Contribution, you won't get my email messages about the Fund Raiser for the rest of the month. For Contributions by check, the squelch will take effect once the check is received. There is a whole new line up of really great Contribution gifts this year! When you make a qualifying Contribution, you can select one of the many free gifts that are available during the Fund Raiser. These gifts are provided through the generous support of a number of our industry's leading supporters including: Bob Nuckolls - AeroElectric - http://www.aeroelectric.com Andy Gold - Builder's Bookstore - http://www.buildersbooks.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com Please visit these guy's respective sites, as they have some great products to offer and are generously supporting the Matronics List Fund Raiser. You can make your List Contribution using any one of three secure methods this year including using a credit card, PayPal, or by personal check. From the Contribution site, you can select any one of this year's free gifts with a qualifying Contribution amount. The Contribution page is pretty loooonnnnng this year in order to list great selection of great gifts available so be sure to scroll all the way to the bottom of the web page to see everything that's available! Please make a List Support Contribution: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous support! Your Contributions truely keep this operation afloat! Thank you, Matt Dralle Matronics Email List Forum Administrator ________________________________________________________________________________
Subject: Re: RV8 Canopy Gluing procedure
Date: Nov 02, 2007
Dear RV builders, I down loaded the Eric Wolf procedure for gluing the canopy to the frame for RV-8 using Sikaflex. Looks like it may be a good option to rivets and screws. Question is if you not riveting through the canopy to the steel frame behind it how do you mount the fiberglass canopy side skins? Do you glue them on as well ? Hope to hear from you all, Best regards, Bill of Georgia ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Nov 02, 2007
Bill of Georgia, After cracking one canopy I decided against pop-rivets. If just one pulls out of the frame and expands in the canopy it cracks. What we did on our second one, which I don't know if it is right, is to drill the canopy to the frame, fit and drill the skirt to the canopy holes (marked by a reference line on tape to match drill them), expand the holes in the canopy to allow for thermal expansion, apply the canopy with sikaflex and clecos holding it in place until it dries and then screw the skirt on (thru the canopy and into the frame) with flathead screws. We put the screws in a little countersunk to the skirt and then put a thin layer of very fine fiberglass over the screws so they will not show cracks in the paint later as many do. Also, if you use a little excess sikaflex and then drag over it with a popsicle stick on the edges it make for a beautiful finish. The excess that pushes to the side pulls off easily once it dries a little since it has a rubbery texture. Does that make sense? Ours turned out nice. Also, for cutting the canopy, I used one of the dremel diamond disks from Lowe's (the one with holes in it like swiss cheese). It was expensive but worth it...much better and more controlable than the original large disk I used on the first canopy.I've used it for awhile now on other things like the cowling and it has not worn out. Dennis of Texas ________________________________________________________________________________
Date: Nov 02, 2007
Hey Bill, I glued my skirts to the frame and the canopy. I used small pieces of gard en hose for spacers; use the thinnest hose you can find. I then clamped th e canopy in place and tack glued it to the frame. I then taped out the are a I didn't want the glue to go and finsih glued the rest. I didi the same with the skirts clamping and taping them in place. I did the canopy all in one piece after it was clamped, by climbing thru the fwd. baggage compartm ent. It came out very nice and I have no fear of cracking like my friend w ho riveted his. Write me back at rice737(at)msn.com if you would like more in fo. If you would like to speak we can exchange numbers then. Paul Rice RV8 N64PR 40 hours and loving it eDate: Fri, 2 Nov 2007 14:14:26 -0400From: japhillipsga(at)aol.comDear RV buil ders, I down loaded the Eric Wolf procedure for gluing the canopy to the fr ame for RV-8 using Sikaflex. Looks like it may be a good option to rivets a nd screws. Question is if you not riveting through the canopy to the steel frame behind it how do you mount the fiberglass canopy side skins? Do you g lue them on as well ? Hope to hear from you all, Best regards, Bill of Geor gia ________________________________________________________________________________
Date: Nov 03, 2007
Dennis, so if I understand, you drill holes for the skirt through the canopy, enlarged them so there would be no chance for expansion cracks, then used screws to attach the skirts to the steel frame under the canopy? Could you have used pull rivets to attach them without effecting the canopy ? You wouldn't by any chance have a photo or two just laying about you could send ? And this saw blade, did you use it on a Drimmal or air tool? Got any idea the part number ? Lastly, I'm still trying to figure out exactly where the brake lines are supposed to exit the fuselage for a 8A. You wouldn't be building an 8A and have a photo of that as well ? I know I'm an info sponge, but I promise if I ever learn anything or know anything about this plane I'll pass it on to the next info sponge. Best regards, Bill PS: Sorry for you and your first canopy. ************************************** ________________________________________________________________________________
Date: Nov 04, 2007
Subject: List Fund Raiser
Dear Listers, Just a reminder that November is the Matronics Email List Fund Raiser month. I've got a bunch of really nice incentive gifts this year. There's really something for everyone! Please make a Contribution today: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 05, 2007
Hi Bill, No...our canopy skirt is on the outside of the canopy like everyone elses. What we did was to place a piece of tape (masking...electrical can stain it) coming up from the hole drilled in the canopy. A line is drawn on the tape leading to the hole. A mark is made on the line exactly 2 inches from the hole (or one inch, as long as you know the distance). You can then mark it on the skirt as you're hold it on the canopy by projecting the now partially covered line 2 inches to mark the skirt where the hole would lie under it. Hard to describe unless you see it but it works great. We started with small holes and then expanded them. The problem we had originally was a rivet expanded in the plexiglass after it was unable to get a grip in the hole we drilled in the frame. I don't know the drimmel part number (discarded box) but it is about a 1 1/4 inch diam disk that comes already attached to a mandrel. It has holes in it around the perimeter of the disk. It was very expensive ($20 ish) but is very durable. It was made by drimmel. Hope that helps! Dennis ________________________________________________________________________________
Date: Nov 05, 2007
Dennis, I'm sorry I just can't picture what you did. I thought with the glue you did not drill any holes in the canopy? But you can certainly drill and screw or pull rivet the bottom of the skirt to the frame. Did you just glue the top edge of the skirt to the outside of the canopy ? I'm a bit confused. Maybe I could visualize it with a photo. Thanks, Bill? -----Original Message----- From: DONKEYVET(at)aol.com Sent: Mon, 5 Nov 2007 9:21 am Subject: Re: RV8-List: Re: RV8 Canopy Gluing procedure Hi Bill, ? No...our canopy skirt is on the outside of the canopy like everyone elses. What we did was to place a piece of tape (masking...electrical can stain it) coming up from the hole drilled in the canopy. A line is drawn on the tape leading to the hole. A mark is made on the?line exactly 2 inches from?the hole?(or one inch, as long as you know the distance). You can then mark it on the skirt as you're hold it on the canopy by projecting the now partially covered line 2 inches to mark the skirt where the hole would lie under it. Hard to describe unless you see it but it works great. We started with small holes and then expanded them. The problem we had originally was a?rivet expanded in the plexiglass after it was unable to get a grip in the hole we drilled in the frame. ? I don't know the drimmel part number (discarded box) but it is about a ?1 1/4 inch diam disk that comes already attached to a mandrel. It has holes in it around the perimeter of the disk. It was very expensive ($20 ish) but is very durable. It was made by drimmel. ? Hope that helps! ? Dennis See what's new ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Nov 05, 2007
I'll send you a private message with my phone number. There's lots of ways to do this and mind isn't the only way. ________________________________________________________________________________
Date: Nov 07, 2007
Subject: What Listers Are Saying...
November is Matronics List Fund Raiser month and a number people been sending some really nice comments regarding the Lists. I thought I'd share a few below. The Lists are completely supported by your Contributions. All of the bills for new hardware, connectivity, and electricity are paid by the generous support of the List members. Please make your Contribution today to support the continued operation of the List and Forums: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ================= What Listers Are Saying ================ Flying and building is much safer with this List!! Robert D. Thanks for having and maintaining such a great resource to all of us builders and flyers. Wayne E. Love the fact that you haven't caved to advertising! Peter J. ..a great resource!! Robert C. Not building at the moment, but the Lists keeps me right up to date with what's going on. Chris D. The web forum has been running great. James O. I enjoy this [List] site very much... Paul C. This is a great list! Albert G. ..a valuable resource! Roger C. I am deployed to Pakistan right now, and being able to go on-line and keep up with the aircraft discussions helps keep the aircraft building dream alive in my mind! Gregory C. ..fantastic service! Roger M. ..clearly a work of passion! Mike C. It is a great service to us! Kevin C. The list is a wonderful resource... Ralph O. [The Lists] have been the single greatest resource in building my RV-9A and now my RV-10. Albert G. ..a valuable and always improving service. Dick S. STILL THE BEST BARGAIN AROUND!! Owen B. ..such a valuable tool. Jon M. [The Lists] have been an invaluable resource for me as a Zenith homebuilder. David G. The opportunity to meet (on line at least) many other interesting builders and to make some new friends is truly appreciated. Albert G. ________________________________________________________________________________
Subject: Re: RV8- Parking Brake Valve
Date: Nov 08, 2007
RV-8 & 8A builders, has anyone modified the brake system to include a parking brake valve? I put one in my 601XL and would not have a plane without one. Problem with the 8 I'm building is right where the valve should be logically is split by the forward baggage compartment floor. Anybody affixed it somewhere else ? Also, Van's is selling a parking valve. Looks to be the same one Spruce lists at $ 109.00, somewhat less than Van. Hope to hear from you, Bill of Georgia ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-11-07&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-11-07&Archive=RV8 =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Wed 11/07/07: 1 ---------------------------------------------------------- Today's Message Index: ---------------------- 0. 12:23 AM - What Listers Are Saying... (Matt Dralle) ________________________________ Message 0 _____________________________________ From: Matt Dralle <dralle(at)matronics.com> Subject: RV8-List: What Listers Are Saying... November is Matronics List Fund Raiser month and a number people been sending some really nice comments regarding the Lists. I thought I'd share a few below. The Lists are completely supported by your Contributions. All of the bills for new hardware, connectivity, and electricity are paid by the generous support of the List members. Please make your Contribution today to support the continued operation of the List and Forums: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ================= What Listers Are Saying =============== Flying and building is much safer with this List!! Robert D. Thanks for having and maintaining such a great resource to all of us builders and flyers. Wayne E. Love the fact that you haven't caved to advertising! Peter J. ..a great resource!! Robert C. Not building at the moment, but the Lists keeps me right up to date with what's going on. Chris D. The web forum has been running great. James O. I enjoy this [List] site very much... Paul C. This is a great list! Albert G. ..a valuable resource! Roger C. I am deployed to Pakistan right now, and being able to go on-line and keep up with the aircraft discussions helps keep the aircraft building dream alive in my mind! Gregory C. ..fantastic service! Roger M. ..clearly a work of passion! Mike C. It is a great service to us! Kevin C. The list is a wonderful resource... Ralph O. [The Lists] have been the single greatest resource in building my RV-9A and now my RV-10. Albert G. ..a valuable and always improving service. Dick S. STILL THE BEST BARGAIN AROUND!! Owen B. ..such a valuable tool. Jon M. [The Lists] have been an invaluable resource for me as a Zenith homebuilder. David G. The opportunity to meet (on line at least) many other interesting builders and to make some new friends is truly appreciated. Albert G. ________________________________________________________________________ Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com ________________________________________________________________________________
Date: Nov 09, 2007
Various people have done it. I'll be using the same method(-ish) as Kevin... http://www.kilohotel.com/rv8/article.php?story=Parking_Brake_Valve -- Jeff Preou Hamilton, New Zealand From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of japhillipsga(at)aol.com Sent: Friday, 9 November 2007 5:06 a.m. Subject: RV8-List: Re: RV8- Parking Brake Valve RV-8 & 8A builders, has anyone modified the brake system to include a parking brake valve? I put one in my 601XL and would not have a plane without one. Problem with the 8 I'm building is right where the valve should be logically is split by the forward baggage compartment floor. Anybody affixed it somewhere else ? Also, Van's is selling a parking valve. Looks to be the same one Spruce lists at $ 109.00, somewhat less than Van. Hope to hear from you, Bill of Georgia ############################################################ This e-mail message has been scanned for Viruses and Content and cleared by NetIQ MailMarshal and Symantec Antivirus ############################################################ ________________________________________________________________________________
Subject: Safety-Trim servo controller
Date: Nov 08, 2007
Fellow RV Builders, This is a cross posted message to make you aware of an important new product for our RV's. I'm an RV-10 Builder and normally post on that email list, however this product applies to all RVs. TCW Technologies has introduced a series of new electronic servo controllers specifically designed for the Ray Allen series of trim servos used in our RV aircraft. This new series of controllers is called Safety-Trim and provides many features not previously available. Safety-Trim prevents trim run-away conditions by providing a time limited servo operation with each activation of a trim switch. Safety-Trim additionally provides speed control and simplified trim switch wiring. Safety-Trim works on both 12 and 24 volt systems and is short circuit and reverse polarity protected. Additionally, models are available that provide 2 speed preset operation of the trim system. Allowing fast responding trim at slow airspeeds and slow responding trim at cruise airspeeds. To learn all about this innovative new product please visit www.tcwtech.com Thank you, Bob Newman RV-10 40176 TCW Technologies rnewman(at)tcwtech.com ________________________________________________________________________________
Date: Nov 08, 2007
We made a brace to mount on the bottom of the baggage floor and attach to the same bulkheads and braces as the floor. We did this after the fact. (everything already installed) Worked well only we had to change the lengths of the brake lines because there connection points moved several inches. Chuck Chappell From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of japhillipsga(at)aol.com Sent: Thursday, November 08, 2007 8:06 AM Subject: RV8-List: Re: RV8- Parking Brake Valve RV-8 & 8A builders, has anyone modified the brake system to include a parking brake valve? I put one in my 601XL and would not have a plane without one. Problem with the 8 I'm building is right where the valve should be logically is split by the forward baggage compartment floor. Anybody affixed it somewhere else ? Also, Van's is selling a parking valve. Looks to be the same one Spruce lists at $ 109.00, somewhat less than Van. Hope to hear from you, Bill of Georgia ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701 <http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapte r 07-11-07&Archive=RV8> &View=html&Chapter 07-11-07&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701 <http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-11-07&Archive=RV8> &View=txt&Chapter 07-11-07&Archive=RV8 =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Wed 11/07/07: 1 ---------------------------------------------------------- Today's Message Index: ---------------------- 0. 12:23 AM - What Listers Are Saying... (Matt Dralle) ________________________________ Message 0 _____________________________________ From: Matt Dralle <dralle(at)matronics.com> Subject: RV8-List: What Listers Are Saying... November is Matronics List Fund Raiser month and a number people been sending some really nice comments regarding the Lists. I thought I'd share a few below. The Lists are completely supported by your Contributions. All of the bills for new hardware, connectivity, and electricity are paid by the generous support of the List members. Please make your Contribution today to support the continued operation of the List and Forums: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ================= What Listers Are Saying =============== Flying and building is much safer with this List!! Robert D. Thanks for having and maintaining such a great resource to all of us builders and flyers. Wayne E. Love the fact that you haven't caved to advertising! Peter J. ..a great resource!! Robert C. Not building at the moment, but the Lists keeps me right up to date with what's going on. Chris D. The web forum has been running great. James O. I enjoy this [List] site very much... Paul C. This is a great list! Albert G. ..a valuable resource! Roger C. I am deployed to Pakistan right now, and being able to go on-line and keep up with the aircraft discussions helps keep the aircraft building dream alive in my mind! Gregory C. ..fantastic service! Roger M. ..clearly a work of passion! Mike C. It is a great service to us! Kevin C. The list is a wonderful resource... Ralph O. [The Lists] have been the single greatest resource in building my RV-9A and now my RV-10. Albert G. ..a valuable and always improving service. Dick S. STILL THE BEST BARGAIN AROUND!! Owen B. ..such a valuable tool. Jon M. [The Lists] have been an invaluable resource for me as a Zenith homebuilder. David G. The opportunity to meet (on line at least) many other interesting builders and to make some new friends is truly appreciated. Albert G. _____ Email and AIM finally together. You've gotta check out free AOL Mail <http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/index.htm?ncid=A OLAOF00020000000970> ! ________________________________________________________________________________
Date: Nov 08, 2007
Subject: Re: Safety-Trim servo controller
Bob, I'm all for free enterprise, but it sounds like you're hawking a product that competes with a Matronics product. Is that acccurate? And, if so, isn't it ... uh ... a bit presumptuous to post this announcement on the Matronics bulletin board? Just asking, that's all ... -- Don McNamara N8RV ----- Original Message ----- From: Bob-tcw To: rv8-list(at)matronics.com Sent: Thursday, November 08, 2007 1:23 PM Subject: RV8-List: Safety-Trim servo controller Fellow RV Builders, This is a cross posted message to make you aware of an important new product for our RV's. I'm an RV-10 Builder and normally post on that email list, however this product applies to all RVs. TCW Technologies has introduced a series of new electronic servo controllers specifically designed for the Ray Allen series of trim servos used in our RV aircraft. This new series of controllers is called Safety-Trim and provides many features not previously available. Safety-Trim prevents trim run-away conditions by providing a time limited servo operation with each activation of a trim switch. Safety-Trim additionally provides speed control and simplified trim switch wiring. Safety-Trim works on both 12 and 24 volt systems and is short circuit and reverse polarity protected. Additionally, models are available that provide 2 speed preset operation of the trim system. Allowing fast responding trim at slow airspeeds and slow responding trim at cruise airspeeds. To learn all about this innovative new product please visit www.tcwtech.com Thank you, Bob Newman RV-10 40176 TCW Technologies rnewman(at)tcwtech.com ________________________________________________________________________________
Date: Nov 08, 2007
Don, I don't believe I'm being presumptuous. Although, Safety-Trim and the Matronics Governor both control trim servo's I believe there are significant differences between the two products and fellow RV builders have been quite interested in our new product. Safety-trim offers 2 speed adjustable preset control of up to two servos as well as run-away trim protection. I hope you and other builders will take a look at the products we have to offer. Respectfully, Bob Newman www.tcwtech.com ________________________________________________________________________________
Date: Nov 09, 2007
Subject: If You Got This Email, You Haven't Made A Contribution Yet!
:-) Dear Listers, If you received this particular Matronics List Email message, its because you haven't yet made a Contribution to support your Lists! Implemented for the first time last year, the Matronics system selectively sends out the Contribution messages to those that forgot to whip out the 'ol credit card this year to support the continued operation and upgrade of the Matronics Email Lists! Don't you wish PBS worked that way? :-) You heard that right. Once you make your Contribution, these support requests messages during November will suddenly stop coming to your personal email inbox! I wanted to implement something like this for a number of years, but it was always such a daunting task to modify the back-end List processing code, that I just kept putting it off. Finally last year, I just decided to bite the bullet and put the code-pounding time it to make it work. A few days later, bam! A working system! I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site like this. It also goes to pay for the commercial-grade Internet connection and to pay the rather huge electric bill to keep the computer gear running and the air conditioner powered up. I run ALL of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercialism that is so prevalent on the Internet these days and I particularly don't want to have it on my Email List site. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator [Please note the following regarding the selective posting system. There are certain circumstances where you might still see a Contribution related message. These situations include if someone replies to one of the messages, or when using the List Browse feature, or when accessing List message via the Forum. Since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Subject: Las Vegas Rvers
Date: Nov 09, 2007
I am going to be in LAS next week on business. I would love to hook up with a local rver, maybe for a ride, or just to look at airplanes, whatever. Al Grajek RV8 LEX 859-361-9460 ________________________________________________________________________________
Date: Nov 11, 2007
Subject: Post Mortem - Matronics List Pummeled By Spam...
Dear Listers, Over a 3-day period, Thursday 11/8 though Saturday 11/10, the Matronics Lists were pummeled with over 450,000 spam emails causing posting delays and a few duplicate messages. Yeah, I really said nearly half a million spams! The good news is that I don't believe a single one of them actually made it to the Lists thanks to the aggressive List filtering code and the Barracuda spam filter. The bad news was that it caused quite a back log of email messages starting Friday and continuing until late Saturday when I noticed that delivery seemed a bit sluggish. By about 11pm on Saturday night, I had managed to get the backlog cleared out of the spam filter by temporarily adjusting some of the filtering. A check of the queues this morning, and everything looks like its working great and there are no incoming filtering delays and spam levels appear to be back to "normal". There were a number of people asking what was going on, so I thought that I'd send out a follow up post mortem on the event... November is the annual List Fund Raiser. Your contribution directly enables me to buy systems like the Barracuda spam filter that keep the List free of that garbage. Please make a contribution to support your Lists! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 12, 2007
I planned to put my Matco parking brake valve in similar to Kevin's, but as Kevin mentioned, the direction of the control cable would be backwards if the cable came from the top as it would pretty much have to. Grove Aircraft just came out with a new parking brake valve similar to the Cleveland or Matco valve however the control arm can be clocked in 4 positions allowing you to get it so that you can pull the arm from the top to close it. I'm replacing my MAtco Valve with Grove's. Paul Trotter Jeff Preou wrote: > > Various people have done it. Ill be using the same method(-ish) as Kevin > > http://www.kilohotel.com/rv8/article.php?story=Parking_Brake_Valve > > -- > > Jeff Preou > > Hamilton, New Zealand > > *From:* owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com] *On Behalf Of > *japhillipsga(at)aol.com > *Sent:* Friday, 9 November 2007 5:06 a.m. > *To:* rv8-list(at)matronics.com > *Subject:* RV8-List: Re: RV8- Parking Brake Valve > > > RV-8 & 8A builders, has anyone modified the brake system to include a parking brake valve? I put one in my 601XL and would not have a plane without one. Problem with the 8 I'm building is right > > > where the valve should be logically is split by the forward baggage compartment floor. Anybody > > > affixed it somewhere else ? Also, Van's is selling a parking valve. Looks to be the same one Spruce > > > lists at $ 109.00, somewhat less than Van. Hope to hear from you, Bill of Georgia > > > ------------------------------------------------------------------------ > This e-mail message has been scanned for Viruses and Content and > cleared by *NetIQ MailMarshal * > ------------------------------------------------------------------------ > * > > > * ________________________________________________________________________________
Date: Nov 13, 2007
Hey thanks for that Paul. I'll check that out and probably go that way too. Glad I didn't buy the Matco now... -- Jeff Preou Hamilton, New Zealand -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Paul Trotter Sent: Tuesday, 13 November 2007 4:50 p.m. Subject: Re: RV8-List: Re: RV8- Parking Brake Valve I planned to put my Matco parking brake valve in similar to Kevin's, but as Kevin mentioned, the direction of the control cable would be backwards if the cable came from the top as it would pretty much have to. Grove Aircraft just came out with a new parking brake valve similar to the Cleveland or Matco valve however the control arm can be clocked in 4 positions allowing you to get it so that you can pull the arm from the top to close it. I'm replacing my MAtco Valve with Grove's. Paul Trotter Jeff Preou wrote: > > Various people have done it. I'll be using the same method(-ish) as Kevin... > > http://www.kilohotel.com/rv8/article.php?story=Parking_Brake_Valve > > -- > > Jeff Preou > > Hamilton, New Zealand > > *From:* owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com] *On Behalf Of > *japhillipsga(at)aol.com > *Sent:* Friday, 9 November 2007 5:06 a.m. > *To:* rv8-list(at)matronics.com > *Subject:* RV8-List: Re: RV8- Parking Brake Valve > > > RV-8 & 8A builders, has anyone modified the brake system to include a parking brake valve? I put one in my 601XL and would not have a plane without one. Problem with the 8 I'm building is right > > > where the valve should be logically is split by the forward baggage compartment floor. Anybody > > > affixed it somewhere else ? Also, Van's is selling a parking valve. Looks to be the same one Spruce > > > lists at $ 109.00, somewhat less than Van. Hope to hear from you, Bill of Georgia > > ------------------------------------------------------------------------ > This e-mail message has been scanned for Viruses and Content and > cleared by *NetIQ MailMarshal * > ------------------------------------------------------------------------ > * > > > * ############################################################ This e-mail message has been scanned for Viruses and Content and cleared by NetIQ MailMarshal and Symantec Antivirus ############################################################ ________________________________________________________________________________
Date: Nov 13, 2007
Subject: List of Contributors
Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by popping a personal check in the mail to: Matt Dralle / Matronics PO Box 347 Livermore CA 94551-0347 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
From: "Russell Lassetter" <rblassett(at)alltel.net>
Subject: Construction/Restoration
Date: Nov 14, 2007
Hello all, I would like to offer my aircraft construction/restoration services to the group. I have a 40' X 60' hangar in NE Georgia and have a lifetime of experience with various aircraft. I can construct large projects for $15.00 per hour with first-class workmanship. Please email me directly or give me a call. Russ Lassetter 202 Aviation Blvd. Cleveland, GA 30528 706-348-7514 rblassett(at)alltel.net ________________________________________________________________________________
Date: Nov 15, 2007
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least 0 or 0 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some lame magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support the Lists? Contribution Page: http://www.matronics.com/contribution Again, I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 16, 2007
From: Garey Wittich <gareywittich2000(at)yahoo.com>
Subject: VS Skin Question
Greetings: I have an "older" Emhennage Kit (with an older Dwg 6PP for the VS) and just saw a "newer" Dwg 6 for the Vert Stabilizer. Where the VS Skin meets the 2 bottom Ribs (VS-705 and VS-704), it says - "Leave open for empennage fairing attach ....." Are these 6 places (each side of VS Skin) dimpled for nutplates or what ???? Otherwords what should I do to these 6 places while building the VS, if anything ??? Do not have the "newer instructions" that explain what goes on at these places. Thanks for your help, Garey Be a better pen pal. Text or chat with friends inside Yahoo! Mail. See how. http://overview.mail.yahoo.com/ ________________________________________________________________________________
Date: Nov 16, 2007
Gary, I built the older emmpanage and put in nut plates on both sides. I'm not sure if it's right yet because I haven't got to the point where the fairing is placed. David Thomas -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Garey Wittich Sent: Friday, November 16, 2007 11:51 AM Subject: RV8-List: VS Skin Question Greetings: I have an "older" Emhennage Kit (with an older Dwg 6PP for the VS) and just saw a "newer" Dwg 6 for the Vert Stabilizer. Where the VS Skin meets the 2 bottom Ribs (VS-705 and VS-704), it says - "Leave open for empennage fairing attach ....." Are these 6 places (each side of VS Skin) dimpled for nutplates or what ???? Otherwords what should I do to these 6 places while building the VS, if anything ??? Do not have the "newer instructions" that explain what goes on at these places. Thanks for your help, Garey Be a better pen pal. Text or chat with friends inside Yahoo! Mail. See how. http://overview.mail.yahoo.com/ ________________________________________________________________________________
Date: Nov 17, 2007
I am mounting the tail fairing among other things before moving my extremely slow built RV8 to a hanger for final assembly and yes, I am getting close. I must have a 'really' old 6pp because mine makes no mention of leaving open spots for the fairing. Pity, as Drawing 43 clearly shows where I need to mount the fairing. No matter, as (sneak peak) the fairing will attach (dwg 43) with 509-8r8 screws into k1000-08 nutplates mounted to those locations. You will fit the fairing to your assembled tail section and drill through the fairing (it is somewhat translucent) through the VS or HS, deburr, and then mount the nutplates. This is most easily accomplished by having NOT done anything prior. So... I would recommend you do nothing to those spots until instructed to do so in the plans which I believe is the finish kit. Regards, Vince H. RV8 - Finish -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Garey Wittich Sent: Friday, November 16, 2007 11:51 AM Subject: RV8-List: VS Skin Question Greetings: I have an "older" Emhennage Kit (with an older Dwg 6PP for the VS) and just saw a "newer" Dwg 6 for the Vert Stabilizer. Where the VS Skin meets the 2 bottom Ribs (VS-705 and VS-704), it says - "Leave open for empennage fairing attach ....." Are these 6 places (each side of VS Skin) dimpled for nutplates or what ???? Otherwords what should I do to these 6 places while building the VS, if anything ??? Do not have the "newer instructions" that explain what goes on at these places. Thanks for your help, Garey Be a better pen pal. Text or chat with friends inside Yahoo! Mail. See how. http://overview.mail.yahoo.com/ ________________________________________________________________________________
Date: Nov 18, 2007
Subject: Please Make a Contribution to Support Your Lists...
Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! And pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 20, 2007
Subject: [Please Read] Why I Have A Fund Raiser...
Dear Listers, Each year I like to explain why I have a Fund Raiser and also take the opportunity to express why I think the List Services here provide a superior experience over the commercial equivalents. I use the List Fund Raiser each year to offset the costs involved with running a high performance email list site such as this one. With the annual support from the List members through the PBS-like Fund Raiser, I have found I can run the entire site without having to inflect any of the members with those annoying banner ads flashing up all the time trying to sell little-blue-pills or other garbage nobody wants or needs. From the comments I've received over the years regarding the Lists, the great majority of the members really appreciate the non-commercialism of my List systems and don't mind my 'go-team-go' banter once a year during November to encourage members to support the Lists. I believe that the Lists services that I provide here offer many benefits over the commercial equivalents in a number of ways. The first feature I believe to be significant is that you cannot receive a computer v*rus from any of these Lists directly. Each incoming message is filtered and dangerous attachments stripped off prior to posting. I also provide a Photo and File Share feature that allows members to share files and bitmaps with other members and everyone can be assured that these files will be prescanned for any sort of v*rus before they are posted. More recently, I have enabled limited posting of a number of file formats including pictures and PDFs. Another very important feature of this system in my opinion is the extensive List Archives that are available for download, browsing, and searching. The Archives go all the way back to the very beginning of each List and with the very fast Search Engine, the huge size of some of the Archives is a non-issue in quickly finding the data you're looking for. And added just a couple of years ago is the new Email List Forum that allows members who prefer the Web BBS-style of List interaction. The beauty of the new List Forums is that they contain the exact same content that is distributed via email. Messages posted via email are cross-posted to the respective Forum and vice versa. The Forums also allow for another convenient method of sharing pictures and other files (http://forums.matronics.com ). Additionally, added recently is the List Wiki that allows members to build their own "Online List Encyclopedia" of sorts, documenting various aspects of their project for all to share ( http://wiki.matronics.com ). I've been running email Lists and services under the matronics.com domain since about 1989 starting with RV-List and 30 guys I knew and who where also building RVs. It has grown into nearly 70 different aviation-related Email Lists and an associated web site that receives over 34,000,000 hits each year!! Additionally, the List Email system forwarded well over 77,000 postings last year, accounting for an unbelievable 33,000,000 (yes, that's 33 MILLION) email messages delivered to Matronics List subscribers! I think there's a lot of value in supporting a service that has gone the long haul and is still providing and improving a high quality service all _without any advertising budget_! I have to admit running these Lists is a labor of love and I hope it shows in the quality of the experience that you receive when you get a List Email Message, Search the Archives, use the List Browser, or surf the Forums and Wiki sites. The Lists will be here for a long time to come. If you just want to lurk a while for free, that's great and I encourage you to do so. If you use, appreciate, and receive value from these Lists, then please support them during the Annual List Fund Raiser! List Contribution Web Site: http://www.matronics.com/contribution Thank you, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 22, 2007
Subject: What Are You Thankful For...?
Dear Listers, Here in the United States, Thursday is our National day of Thanksgiving. Many of us will be traveling to be with our families and friends to share in generous feasts of plenty and giving thanks for many blessings that have been bestowed upon us. Many Listers have expressed over the last couple of weeks how thankful they are for the Email Lists and Forums here on the Matronics servers and for all of the assistance and comradery they have experienced being a part of the Lists. One of my favorite kind of comments is when write to me and says something like, "Its the first thing I do in the morning while I'm having my morning coffee!". That's a wonderful tribute to the purpose and function of these Lists. Its always great to hear I'm not the only one that jumps out of bed each morning to check my List email!! Won't you take a minute today and show your appreciation for these Lists and for their continued operation and upgrade? The List Contribution Site is: http://www.matronics.com/contribution Thank you in advance for your kind consideration, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 24, 2007
Subject: Comments
Dear Listers, Below are a few more of the nice comments Listers have been making along with their Contributions in support of the Lists this year. Please make your Contribution today to support the continued operation and upgrade of these services. Remember, there is _no advertising budget_ to keep these Lists funded. It is solely through your generosity that they continue. Please make a Contribution: http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List and Forum Administrator ------------------------------What Listers Are Saying------------------------------ The list has been invaluable in the building of my Zenith CH701. George R Thanks for keeping the lists a non-commercial venue for us to gather and share knowledge. Neal G What a fantastic resource! Ralph C It's a pretty cheep troubleshooting tool with and unlimited resource of personal knowledge. Bruce G A full house of Info & Ideas... Ellery B I really enjoy the Piet list. Steven D The Lists are an indispensable resource for those of us building OBAM aircraft. Bret S ..a great service. Frank D ..all in all it is a great resource if you ask specific questions. Richard S Your list has really helped me in my first build. Michael W Always a pleasure to support this great resource... Richard W I enjoy the lists very much, they are very beneficial. Bob L Great place to chat with other builders and Flyers. Ellery B Your lists are a great service to builders and owners! Richard D A real good place for someone that is starting to get interested into flying without investing any money at first. Ellery B The list has been an great help to my building process. David B I'm close to finishing my Zenith 601 thanks to you and the Zenith List. Jeff D ________________________________________________________________________________
Subject: FAR 91.205 Requirements for Whiskey Compass
Date: Nov 25, 2007
Regards Whiskey Compass. FAR for VFR Day only, says a "Magnetic Direction Indicator" is required. No where does it say independent, mechanical or non electric. If you have a Magnetometer or EFIS that provides Magnetic Direction Information I would say you are OK. If your EFS only provides TRK you may have a problem. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________________________________________________________
Subject: Forward baggage shelf maintenance
Date: Nov 26, 2007
A question for those who flying and maintaining there RV8. How often if ever do you remove the forward baggage shelf? I ask because I have made a bracket to mount the park brake but have just realised I would need undo the brake line to remove it and release the baggage shelf from the park brake bracket. Should I redesign it or move on? Thanks Greg 82070 ________________________________________________________________________________
Date: Nov 25, 2007
My 8A has been flying for 5 years. I had the forward baggage shelf out twice. I mounted my parking brake vertically on the bulkhead aft of the baggage shelf. I used two pieces of 0.040 x3/4" angle as brackets such that the parking brake valve extended below the bulkhead. This made plumbing much easier and does not interfere with removing the shelf. Carl Froehlich RV-8A (375 hrs) RV-10 (wings) Dogwood Airpark (VA42) _____ From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Greg Sent: Sunday, November 25, 2007 6:19 PM Subject: RV8-List: Forward baggage shelf maintenance A question for those who flying and maintaining there RV8. How often if ever do you remove the forward baggage shelf? I ask because I have made a bracket to mount the park brake but have just realised I would need undo the brake line to remove it and release the baggage shelf from the park brake bracket. Should I redesign it or move on? Thanks Greg 82070 ________________________________________________________________________________
Date: Nov 26, 2007
Subject: Make Sure You're Listed! List of Contributors Published Dec
1! Dear Listers, The List of Contributors (LOC) is just around the corner! On December 1st I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. As a number of people have pointed out in their Contribution comments, these Lists seems at least as valuable of a building/flying/recreating tool as a typical your magazine subscription! And how interactive is a magazine, after all? Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle PO Box 347 Livermore CA 94551-0347 USA (Please include your email address on the check!) I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2007
Subject: [Please Read] What are "The Lists" and Who's This Matt Dralle?
Dear Listers, Who is Matt Dralle and what exactly are these Lists? Well, I've been working in the information technology industry for nearly 25 years primarily in computer networking design and implementation. I have also done extensive work in web development and CGI design during that time, along with some embedded system development as well. I started the Matronics Email Lists back in 1990 with about 30 fellow RV builders from around the world. Since that time, I have added 63 other kinds of aircraft related Lists to the line up and numerous other List related services such as the Forums, Wiki, Archives and Search Engine just to name a few. For flexibility and reliability, I have chosen to run all of my own servers here locally. Other List-related systems include a 1 Gigabit, fully switched network infrastructure, a commercial-grade Netscreen firewall, a Barracuda spam filter, a local T1 Internet router, and a commercial-grade business T1 Internet connection with full static addressing. The computer servers found here include a quad-processor Xeon Linux server for List web services, a dual-processor Xeon Linux system dedicated to the email processing List functions, and another P4 Linux system serving as a remote storage disk farm for the archives, databases, and for an on-line hard drive-based backup system with 3.2 Terra Bytes of storage! This entire system is protected by three large, commercial-grade uninterrupted power supply (UPS) systems that assure the Lists are available even during a local power outage! Speaking of power, imagine how much electricity it takes to run all of these systems. One month last Summer, I had a staggering $1368 bill for electricity alone! I recently upgraded all of the computer racking infrastructure including new power feeds and dedicated air conditioning for the room that serves as the Computer Center for the Matronics Email Lists. Last year I added another rack to house the MONSTER quad-processor web system that didn't quite fit into the first rack! Here's a composite photo of the List Computer Center before the addition of the second rack: http://www.matronics.com/MattDralle-ListComputerCenter.jpg As you can see, I take running these Lists very seriously and I am dedicated to providing an always-on, 24x7x365 experience for each and every Lister. But building and running this system isn't cheap. As I've stated before, I don't support any of these systems with commercial advertising on the Lists. It is supported 100% through List member Contributions! That means you... and you... and YOU! To that end, I hold a List Fund Raiser each November and ask that members make a small Contribution to support the continued operation and upgrade of this ever-expanding system. Its solely YOUR Contributions that keeps it running! Won't you please take a moment to make a Contribution to support these Lists! http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle PO Box 347 Livermore CA 94551-0347 USA (Please include your email address on the check!) There are some great gifts available with qualifying Contribution levels too! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: RE: RV-List
Date: Nov 27, 2007
Hi Matt et al: I receive the RV-8 list (and others) in digest format. Over the last month or so, there have been several days (4? 5?) that the rv-8 digest has not come through, while the others have come through just fine. Has anyone else experienced this, or anything like it? Is there a problem with my account, or some problem with the server? Tnx- glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Nov 27, 2007
Date: Nov 28, 2007
Subject: Wow! A Ton of Comments!
Dear Listers, I've been getting a ton of great comments from Listers along with their List Support Contributions lately! I've shared a bunch more below. Please read over some of them and see what your fellow Listers think of the Lists and Forums. There are just a couple more days left before the official end of this year's Fund Raiser. Please make a Contribution today to support the continued upgrade and operation of these services. There are still lots of awesome gifts available, so browse the extensive selection and pickup a nice item along with your qualifying Contribution. http://www.matronics.com/contribution Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator ----------- What Listers Are Saying About The Lists ----------- In the big picture, you are most certainly saving lives. The fact that you do it at a very good level of service, quality, and simplicity is just icing on the cake. We all owe you a debt of gratitude. Bruce M Can't go a single day without reading my lists. Even when I am overseas. Terry W Best list ever. No comparison. Johann J I get the digest for the two lists I subscribe to each morning -- they go great with my coffee! I can't tell you how much I've learned from this great service... Mark S ..great lists, best on the Net! Robert S It is very nice to enjoy a SPAM free list. Ken L You run a great list. Makes a builder feel like there's lots of help out there for the asking, and it's appreciated. Steve T The list is a very valuable resource. Thomas S You run a good list. James G Thanks for a great forum. Jimmy Y Thanks for a well-maintained list(s). Michael M Great job! Worth every penny! Stephen T Helps me learn and think about issues I didn't know I didn't know. Martin H I find the list very useful... Robert F What you do provides me with daily contact with a passion of my life, aviation. Wendell M ..the list it is very valuable information. Dwayne H ..a great service to homebuilders. Andrew H I have learned quite a lot from reading the Forums. I have been reading at the forum pages and I like the way it works. Ron L [The List] makes a builder feel like there's lots of help out there for the asking, and it's appreciated. Steve T The list service many purposes, not the least of which is motivation to join my fellow RVer in completing my project and getting in the air. John S Thanks for running a great site. Its simplicity is its greatness. Don't know how I would have been successful without it. Timothy F ..terrific service to experimental and general aviation. James F You have a well run operation. I am happy to support what you do. Mark S A wonderful service to the GA community. David M Great list - let's keep it ad-free! Ben C They have been of great help, learning and friendship for all the members Worldwide. Great job of yours, a little idea that grew really big and wonderful. Gary G ..a thoroughly enjoyable and informative List. John W A GREAT LEARNING TOOL!! Dwayne Y This is a very well-run list and it is a valuable resource for the Pietenpol enthusiast. Graham H Thanks for running this great site - helps those of us on the east of the pond keep in touch. Malcolm H Thanks for the major contribution to my continuing education program. Oldbob S I'm just getting started in the building process & find Matronics to be the most valuable site. Scott D Without the information and encouragement from the listers my project would have been sitting in the corner of my shop collecting dust long ago. Now it's almost ready for final assemble and covering. Edward G Great List. No Ads, just RV-10 builders. Keep it going. Rick E Wonderful source of info for building & flying... Graham H The Yak-list is a superb single source to get answers to questions on the operation of these aircraft. Craig W This list is valuable to everyone and your hard work is very much appreciated. Jim S ________________________________________________________________________________
Date: Nov 29, 2007
Subject: Just Two Days Left...
Dear Listers, There are just a couple days left for this year's List Fund Raiser. Over all, participation has been good, but things have been pretty slow this week for some reason. If you've been putting off making your Contribution until the last minute, this is it! The last minute, that is... :-) Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Please make a Contribution today! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2007
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, Its November 30th and that means a couple of things. Its my 44th birthday for one, but I'm trying to forget about that... But, it also means that its that last official day of the Matronics Email List Fund Raiser! If you been drooling over one of the really sweet free gifts that are available this year with a qualifying Contribution, then now is the time to jump on one!! If you've been meaning to make a Contribution, but just keep putting it off, then now is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! Rather than the guy that, er, ah, forgot (or whatever)... :-) I want to thank everyone that has so generously made a Contribution so far this year in support of our Lists. It is your generosity that keeps this operation a float and I don't ever forget it. Hopefully everyone will feel the same. The List Contribution page is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Thank you all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 06, 2007
Subject: Matronics List Fund Raiser - 2007 List of Contributors
Dear Listers, I would like to thank everyone that made a Contribution in support of the Lists this year! It was really nice to hear all great comments people had regarding the Lists! As I have said many times before, running these Lists is a labor of love. Your generosity during the List Fund Raiser underscores the great sentiments people have made regarding the Lists. If you haven't yet made a Contribution in support of this year's Fund Raiser please feel free to do so. The great List Fund Raiser gifts will be available on the Contribution site for just a little while longer, so hurry and make your Contribution and get your great gift! Once again, the URL for the Contribution web site is: http://www.matronics.com/contribution I would like to thank Andy Gold of the Builder's Bookstore ( http://www.buildersbooks.com ), Jon Croke of Homebuilt HELP ( http://www.homebuilthelp.com ) and Bob Nuckolls of AeroElectric ( http://www.aeroelectric.com ) for their extremely generous support during this year's Fund Raiser through the contribution of discounted merchandise. These are great guys that support the aviation industry and I encourage each and every Lister to have a look at their products. Thank you Andy, Jon and Bob!! Your support is very much appreciated! And finally, below you will find a web link to the 2007 List of Contributors current as of 12/6/07! Have a look at this list of names as these are the people that make all of these List services possible! I can't thank each of you enough for your support and great feedback during this year's Fund Raiser! THANK YOU! http://www.matronics.com/loc/2007.html I will be shipping out all of the gifts in the next few weeks and hope to have everything out by the end of the month. In most cases, gifts will be shipped via US Postal Service. Once again, thank you for making this year's List Fund Raiser successful! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Safety-Trim Group Buy
Date: Dec 11, 2007
Dear Fellow RV Builders, TCW Technologies and SteinAir are pleased to announce a group buy is now available on our new servo trim controller. Safety-Trim is an electronic trim servo controller that resolves the issues with run-away trim conditions plus it provides 2 speed trim operation as well as greatly simplified switch wiring. For all the detail please follow this direct link: http://www.vansairforce.com/community/showthread.php?t=24478 Thank you, Bob Newman TCW Technologies www.tcwtech.com ________________________________________________________________________________
Date: Dec 15, 2007
Subject: Gel Coated Fairings
Greetings: Have an "older" Emphennage Kit (circa 1999) that came with Gel Coated F.G. Fairings. 1) Do the "newer" Kits from Vans still come with the Gel Coated Fairings ? 2) My understanding from reading the Archieves is that the Gel Coat is used over Polyester Resin F.G. parts and not over Epoxy Resin F.G. Parts. Is this true ? 3) Is it worth buying from Vans the "newer" NON Gel Coated Fairings (assuming they come that way now) than trying to work with the existing Gel Coated fairings that I have ? 4) What is the purpose of the Gel Coat - mold release ? 5) What Grit / Method used - would you recommend to take off the Gel Coat (and not digging into the F.G. weave) ? 6) Is it recommended to remove ALL the Gel Coat down to the F.G. weave so that any "flexing" of the F.G. fairing will not crack any final Top Coat of paint in the future ? [My Fairing on the TOP of the VS will be removable for access to the VOR Antenna - should that be necessary and could flex during removal and crack the Top Coat of paint.] 7) Any helpful HINTS on getting a nice Fairing / Skin edge line where the Fairing meets the Skin and still keeping the Fairing removable ? [Will be using #6 Screws into Nutplates riveted to the F.G. Fairing] Appreciate your helpful inputs, Garey Wittich Santa Monica, CA Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Date: Dec 16, 2007
Subject: Re: Gel Coated Fairings
Garey, Yes to all. I have a mixture of newer and older gel coated fairings. The newer ones from Vans are epoxy and are not gel coated. I wish they had never gel coated the old ones. I believe it was done to get a nice looking, smoother product, but it ends up causing a lot more work and aggravation. The gel coat also aids in mold release. My old empennage fairing from Vans is not gel coated, but I bought a Fairings, etc empennage fairing anyway and did not use the Van's one. All of my tip fairings are gel coated and we're grinding off all of the gel coat and recovering with new glass and then sanding for hours to get something decent. We use a belt sander to remove the gel - grit about 60. I don't believe you need to worry about the paint cracking on the VS fairing. That fairing is somewhat stiff and flexing shouldn't be much of a problem. I glassed in the trailing edge of all the tip fairings and that stiffened them up even more. My upper tip fairing is removable also. You can see how I did the tip fairings on my web site at _www.rv-8a.net_ (http://www.rv-8a.net) . Go to the 2007 page and scroll down to 24-27 Feb. If you'll pay for shipping, you can have my Van's empennage fairing. It is new as I received it and is not gel coated. Regards, Stan Sutterfield Have an "older" Emphennage Kit (circa 1999) that came with Gel Coated F.G. Fairings. 1) Do the "newer" Kits from Vans still come with the Gel Coated Fairings ? 2) My understanding from reading the Archieves is that the Gel Coat is used over Polyester Resin F.G. parts and not over Epoxy Resin F.G. Parts. Is this true ? 3) Is it worth buying from Vans the "newer" NON Gel Coated Fairings (assuming they come that way now) than trying to work with the existing Gel Coated fairings that I have ? 4) What is the purpose of the Gel Coat - mold release ? 5) What Grit / Method used - would you recommend to take off the Gel Coat (and not digging into the F.G. weave) ? 6) Is it recommended to remove ALL the Gel Coat down to the F.G. weave so that any "flexing" of the F.G. fairing will not crack any final Top Coat of paint in the future ? [My Fairing on the TOP of the VS will be removable for access to the VOR Antenna - should that be necessary and could flex during removal and crack the Top Coat of paint.] 7) Any helpful HINTS on getting a nice Fairing / Skin edge line where the Fairing meets the Skin and still keeping the Fairing removable ? [Will be using #6 Screws into Nutplates riveted to the F.G. Fairing] Appreciate your helpful inputs, **************************************See AOL's top rated recipes (http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004) ________________________________________________________________________________
Date: Jan 03, 2008
Subject: firewall to prop flange
Does anyone know the distance from prop flange to firewall? I am working on an engine mount design. -- Blake C. Lewis ________________________________________________________________________________
Subject: Mounting Antenna - backing plate
Date: Jan 04, 2008
Hello, I am mounting the comm. Antenna just aft of the right foot well and the transponder blade antenna just aft of the baggage floor. I would like to know if anyone installed their antennas in roughly these same locations without backing plates and more importantly, without problems? Vince H. Idaho 'Getting Close' (yep I said that last year) ________________________________________________________________________________
Date: Jan 04, 2008
I have mine in about this location, but with a backing plate (.032" if I remember correctly). Not sure why you would not want to use a backing plate. Carl Froehlich RV-8A (375 hrs) RV-10 (wings) _____ From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Vince-Himsl Sent: Friday, January 04, 2008 8:03 PM Subject: RV8-List: Mounting Antenna - backing plate Hello, I am mounting the comm. Antenna just aft of the right foot well and the transponder blade antenna just aft of the baggage floor. I would like to know if anyone installed their antennas in roughly these same locations without backing plates and more importantly, without problems? Vince H. Idaho 'Getting Close' (yep I said that last year) ________________________________________________________________________________
Subject: static Rpm
Date: Jan 21, 2008
I am completing my RV 8 that has a O-360-A1A , Ma 4-5 Carb and a Sens fixed pitched prop purchased from Vans installed. I would like an idea of what Static RPM I should be looking for? Thanks , Ed Clegg edwclg(at)gmail.com ________________________________________________________________________________
Subject: Re: tire pressure
Date: Jan 27, 2008
Hi, What is best tire pressure for RV-8? Thanks, John ________________________________________________________________________________
Date: Jan 27, 2008
I use 32psi and have had good tire wear and handling with it Kirk Sent from my iPhone On Jan 27, 2008, at 12:57 PM, "John Ellis" wrote: > > Hi, > > What is best tire pressure for RV-8? > > Thanks, > > John > > ________________________________________________________________________________
Date: Jan 27, 2008
Subject: Mounting RV8 - F-827c flap fairing after the floor is installed
Fef: F-827c Dwgs 28 and 43 mounting flap fairing views DD and EE Hello, I permanently installed the floors thinking I had everything covered. Not quite, seems those seven holes on the bottom of the fuselage that have been staring back at me for several years belong to the flap fairing and I now cannot access them from inside the fuselage. Removing the floor is not an option so I am wondering if someone has unique solution before I grab the pop rivets. Thanks, Vince H. (Finish) I see the light at the end of the tunnel. Unfortunately this is the fourth tunnel in a row. ________________________________________________________________________________
Subject: Re: Mounting RV8 - F-827c flap fairing after the floor is installed
Date: Jan 27, 2008
The solution is called cherry max rivets. That is what I did. In fact, I probably used 50 of them in my RV-8. They aren't cheap, but they work well. ----- Original Message ----- From: Vincent S. Himsl To: rv8-list(at)matronics.com Sent: Sunday, January 27, 2008 5:52 PM Subject: RV8-List: Mounting RV8 - F-827c flap fairing after the floor is installed Fef: F-827c Dwgs 28 and 43 mounting flap fairing views DD and EE Hello, I permanently installed the floors thinking I had everything covered. Not quite, seems those seven holes on the bottom of the fuselage that have been staring back at me for several years belong to the flap fairing and I now cannot access them from inside the fuselage. Removing the floor is not an option so I am wondering if someone has unique solution before I grab the pop rivets. Thanks, Vince H. (Finish) I see the light at the end of the tunnel. Unfortunately this is the fourth tunnel in a row. ________________________________________________________________________________
Date: Jan 28, 2008
I did the same thing. Use Pop rivets and no one will ever know the differen ce. Al Grajek Date: Sun, 27 Jan 2008 15:52:02 -0800From: vhimsl(at)adelphia.netTo: rv8-list@ matronics.comSubject: RV8-List: Mounting RV8 - F-827c flap fairing after th e floor is installed Fef: F-827c Dwgs 28 and 43 mounting flap fairing views DD and EE Hello, I permanently installed the floors thinking I had everything covered. Not q uite, seems those seven holes on the bottom of the fuselage that have been staring back at me for several years belong to the flap fairing and I now c annot access them from inside the fuselage. Removing the floor is not an option so I am wondering if someone has unique solution before I grab the pop rivets. Thanks, Vince H. (Finish) I see the light at the end of the tunnel. Unfortunately this is the fourth tunnel in a row. ________________________________________________________________________________
Date: Feb 08, 2008
I run 40psi with no problems Read this topic online here: http://forums.matronics.com/viewtopic.php?p=162984#162984 ________________________________________________________________________________
Date: Feb 10, 2008
Subject: Re: RV-8a Wing Mounting
Fellow Builders, I'm about to mount my wings for the first time. Any of you fellows got any good tips for success and happiness? Is there a best side to mount first? When fitting is it recommended to install all eight bolts in the main spar ? Hope to hear something and best regards, Bill of Georgia ************** Biggest Grammy Award surprises of all time on AOL Music. (http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp00300000002548) ________________________________________________________________________________
Date: Feb 11, 2008
Three bodies to do my wings.. Drift pins, Boelube, hardware store bolts, re member to provide dihedral (someone lifting the wingtip) to get final bolts aligned. Use "persuasion". Digital level and measured a bunch of times. E nded up +/- 0.1 degree - or so. When drilling aft spar, make sure drill did n't slip off intended location (ask me how I know ). 4 plumb bobs and a las er line work great for eliminating sweep. After getting wings on, don't for get the bottom nut plates and wing fairings - may have to adjust fuselage a lignment on cradle to provide access. Bottom line - follow Vans instruction s - including the download from the website. Booger N192NM ________________________________________________________________________________
Subject: RV-8a Wing Mounting
Date: Feb 11, 2008
Also, you may want to put your bolts in the freezer overnight to help get t hem in, it is a very tight fit. Getting them out is fun too. I also under drilled my rear spare so that after my first flight I could move the aft s par up or down to off set a heavy wing. Luckily, I didn't have to, it flew straight and level first time, so I just brought them up to size and insta lled the proper bolts. Paul Rice RV8 60 hours flying fun From: pvalovich(at)dcscorp.comTo: rv8-list(at)matronics.comDate: Mon, 11 Feb 2008 Three bodies to do my wings.. Drift pins, Boelube, hardware store bolts, re member to provide dihedral (someone lifting the wingtip) to get final bolts aligned. Use =93persuasion=94. Digital level and measured a bunch of times . Ended up +/- 0.1 degree ' or so. When drilling aft spar, make sure dri ll didn=92t slip off intended location (ask me how I know ). 4 plumb bobs a nd a laser line work great for eliminating sweep. After getting wings on, d on=92t forget the bottom nut plates and wing fairings ' may have to adjus t fuselage alignment on cradle to provide access. Bottom line ' follow Va ns instructions ' including the download from the website. Booger N192NM ________________________________________________________________________________
Date: Feb 11, 2008
From: George Inman 204 287 8334 <ghinman(at)mts.net>
Fellow Builders, I'm about to mount my wings for the first time. Any of you fellows got any good tips for success and happiness? Is there a best side to mount first? When fitting is it recommended to install all eight bolts in the main spar ? Hope to hear something and best regards, Bill of Georgia Bill I made alignment pins by forming a point on some store bought bolts. Buy some store bought 7/16' bolts to mount the wings temporary. You will remove the wings at least once to attach platenuts after match drilling the holes where fuselage meets wing at bottom. If you have the Quickbuild make sure they did not put rivets where you will put platenuts.remove them before first mounting of wings. When final mounting ,the close tolerance bolts are a tight fit.I taped them in with a brass hammer and a bucking bar on the opposite side.I also used some LP lubricant. I had three people to hold the wing while I taped in bolts. I installed the bolts from rear,because you cannot insert bottom bolts from forward. I do not think there is a reason to mount a side first. Any questions feel free to send me an E-Mail -- George H. Inman ghinman(at)mts.net ________________________________________________________________________________
Subject: RE: RV-8a Wing Mounting
Date: Feb 11, 2008
Hi Bill- I'm chipping away at an 8, not an 8A, but I don't think there are any differences in mounting the wings. I believe the only drivers for picking an installation order are logistics. IE, what are the physical constraints in the assembly location that will make one assembly order preferential over another? I had no trouble installing the wings with the aid of one other person. Once the wings were in place and pinned, I did all the rest myself. Also, I didn't install any of the bolts. They are cad plated expensive bolts, and I didn't want to necessarily damage the plating or threads. Also, the ends are fairly square and don't lend themselves to being used to align the holes very well. Consequently, I got an appropriate variety and number of hardware store bolts and ground them all to drift pins. That allowed me to use them to coax the final alignment of the wings and to verify that all the bolt holes lined up at the same time. The lack of edge distance in the rear attach hardware limits how much wiggle room you have rigging the wings. You probably will need very little, anyway. One thing I discovered in this process was the number of inaccuracies in my QB kit. The canopy rails aren't parallel, which was cause for me to scratch my head trying to set / determine the true fuselage attitude. Likewise, the planar section of the aft upper surface of the wing really isn't all that planar. I ended up averaging the values for the canopy rails as well as taking a reading adjacent to each wing rib, writing it at each station, and averaging them. This gave me a 'fudge factor' to apply to the raw reading at the station where the rigging measurements were taken. FWIW- glen matejcek aerobubba(at)earthlink.net > > Fellow Builders, I'm about to mount my wings for the first time. Any of you > fellows got any good tips for success and happiness? Is there a best side to > mount first? When fitting is it recommended to install all eight bolts in the > main spar ? Hope to hear something and best regards, Bill of Georgia ________________________________________________________________________________
Subject: Re: RV8-List Digest: 1 Msgs - 02/10/08
Date: Feb 11, 2008
Hi Bill, If you use 'hardware store' bolts for fitting make sure you take your mic. with you. Sometimes they are oversize. For final assy. use Lubriplate. Seems to work best. Check your NAS bolts in their carrythrough spar holes before test assy. so that you will know that there are no problems. If there are, it will likely be misalignment of the F-804Cs (my experience on a QB; both sides). Art Loring, Jr RV-8 QB O-320 CS 35 HRs. -------------- Original message ---------------------- From: RV8-List Digest Server <rv8-list(at)matronics.com> > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 0 > 8-02-10&Archive=RV8 > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08 > -02-10&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Sun 02/10/08: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 05:11 PM - Re: RV-8a Wing Mounting (JAPhillipsGA(at)aol.com) > > > > ________________________________ Message 1 > _____________________________________ > > > From: JAPhillipsGA(at)aol.com > Subject: RV8-List: Re: RV-8a Wing Mounting > > Fellow Builders, I'm about to mount my wings for the first time. Any of you > fellows got any good tips for success and happiness? Is there a best side to > mount first? When fitting is it recommended to install all eight bolts in the > main spar ? Hope to hear something and best regards, Bill of Georgia > > > ************** > Biggest Grammy Award surprises of all time on AOL Music. > > (http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp00300000002 > 548) > > > > > > > > ________________________________________________________________________________
Date: Feb 11, 2008
My bolts had both boelube and freezer visit and they went in extremy hard. If you have an RV 8A DO NOT DRIVE THE BOLTS ALL THE WAY IN BEFORE YOU PUT ON THE NUT. It was hard to get them in but it was ten times harder to get them out so you could get the nu on. Otherwise a piece of cake HA HA. Ulf -----Original Message----- From: Paul Rice <rice737(at)msn.com> Subj: RE: RV8-List: RV-8a Wing Mounting Date: Mon 11 Feb 2008 10:33 Size: 1K Also, you may want to put your bolts in the freezer overnight to help get them in, it is a very tight fit. Getting them out is fun too. I also under drilled my rear spare so that after my first flight I could move the aft spar up or down to off set a heavy wing. Luckily, I didn't have to, it flew straight and level first time, so I just brought them up to size and installed the proper bolts. Paul Rice RV8 60 hours flying fun From: pvalovich(at)dcscorp.com Date: Mon, 11 Feb 2008 09:34:58 -0500 Subject: Re: RV8-List: RV-8a Wing Mounting ________________________________________________________________________________
Date: Feb 12, 2008
George, thanks for the info. When you were test fitting did you install the four smaller size bolts per wing as well as the four 7/16 bolts? Bill -----Original Message----- From: George Inman 204 287 8334 <ghinman(at)mts.net> Sent: Mon, 11 Feb 2008 10:43 am Subject: RV8-List: RV-8a Wing Mounting ? Fellow Builders, I'm about to mount my wings for the first time. Any of you fellows got any good tips for success and happiness? Is there a best side to mount first? When fitting is it recommended to install all eight bolts in the main spar ? Hope to hear something and best regards, Bill of Georgia? ? ? Bill? ? I made alignment pins by forming a point on some? store bought bolts.? ? Buy some store bought 7/16' bolts to mount the wings? temporary.? ? You will remove the wings at least once to attach? platenuts after match drilling the holes where fuselage? meets wing at bottom.? ? If you have the Quickbuild make sure they did not? put rivets where you will put platenuts.remove them? before first mounting of wings.? ?When final mounting ,the close tolerance bolts are? a tight fit.I taped them in with a brass hammer and a? bucking bar on the opposite side.I also used some? LP lubricant.? ? I had three people to hold the wing while I taped in bolts.? ?I installed the bolts from rear,because you cannot? insert bottom bolts from forward.? ?I do not think there is a reason to mount a side first.? ?Any questions feel free to send me an E-Mail? ? -- ? George H. Inman? ghinman(at)mts.net? ? ? ? ________________________________________________________________________ ________________________________________________________________________________
Date: Feb 13, 2008
Subject: Re: RV-8a Wing MountingRV-8a Wing Mounting
Look in Vans website under Construction FAQs - it's the last file: Wing Inc idence Drilling. Booger ________________________________________________________________________________
Subject: Re: RV8a- Ailerion & Wing Tip Match
Date: Feb 26, 2008
RV-8 Builders, I got a problem. I have the wings mounted on my 8a. I attached the ailerons and set them to the template provided by Van (cut out plywood). Added the flaps and with plenty of careful trimming they line up with the ailerons and fuselage bottom. All is well. Then I put on the fiberglass wing tips and they don't line up with the aileron. Sooooo. Do I go with the template or the wing tip ? I want the bird to fly right, but I also want it to look right. Hope to hear from some folks that have solved this problem. Thanks, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Tue, 26 Feb 2008 2:57 am Subject: RV8-List Digest: 0 Msgs - 02/25/08 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-02-25&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-02-25&Archive=RV8 =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Mon 02/25/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________ ________________________________________________________________________________
Date: Feb 26, 2008
I'm not a fan of the wood template. It's a broad stroke on something that, imho, can be a lot more precise. On my RV-7 (same wings as yours), I used the extended centerline that bisects the main wing rib tooling holes, and I made sure the ailerons' trailing edges were dead nuts on that extended line. More accurate technique imho. YMMV Sharpie www.rvproject.com ----- Original Message ----- From: japhillipsga(at)aol.com To: rv8-list(at)matronics.com Sent: Tuesday, February 26, 2008 10:15 AM Subject: RV8-List: Re: RV8a- Ailerion & Wing Tip Match RV-8 Builders, I got a problem. I have the wings mounted on my 8a. I attached the ailerons and set them to the template provided by Van (cut out plywood). Added the flaps and with plenty of careful trimming they line up with the ailerons and fuselage bottom. All is well. Then I put on the fiberglass wing tips and they don't line up with the aileron. Sooooo. Do I go with the template or the wing tip ? I want the bird to fly right, but I also want it to look right. Hope to hear from some folks that have solved this problem. Thanks, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> To: RV8-List Digest List Sent: Tue, 26 Feb 2008 2:57 am Subject: RV8-List Digest: 0 Msgs - 02/25/08 * Online Versions of Today's List Digest Archive Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html& Chapter 08-02-25&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&C hapter 08-02-25&Archive=RV8 ====================== EMail Version of Today's List Digest Archive ====================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Mon 02/25/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Date: Feb 26, 2008
Sharpie, is this centerline/deadnuts technique shown on the plans somewhere? Thanks Bill -----Original Message----- From: Dan Checkoway <dan(at)rvproject.com> Sent: Tue, 26 Feb 2008 1:50 pm Subject: Re: RV8-List: Re: RV8a- Ailerion & Wing Tip Match I'm not a fan of the wood template.? It's a broad stroke on something that, imho, can be a lot more precise. ? On my RV-7 (same wings as yours), I used the extended centerline that bisects the main wing rib tooling holes, and I made sure the ailerons' trailing edges were dead nuts on that extended line.? More accurate technique imho.? YMMV ? Sharpie www.rvproject.com ----- Original Message ----- From: japhillipsga(at)aol.com Sent: Tuesday, February 26, 2008 10:15 AM Subject: RV8-List: Re: RV8a- Ailerion & Wing Tip Match RV-8 Builders, I got a problem. I have the wings mounted on my 8a. I attached the ailerons and set them to the template provided by Van (cut out plywood). Added the flaps and with plenty of careful trimming they line up with the ailerons and fuselage bottom. All is well. Then I put on the fiberglass wing tips and they don't line up with the aileron. Sooooo. Do I go with the template or the wing tip ? I want the bird to fly right, but I also want it to look right. Hope to hear from some folks that have solved this problem. Thanks, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Tue, 26 Feb 2008 2:57 am Subject: RV8-List Digest: 0 Msgs - 02/25/08 * Online Versions of Today's List Digest Archive Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-02-25&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-02-25&Archive=RV8 ====================== EMail Version of Today's List Digest Archive ====================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Mon 02/25/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- href="http://www.matronics.com/Navigator?RV8-List">http://www.matronics.com/Navigator?RV8-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________ ________________________________________________________________________________
Date: Feb 26, 2008
Bill, I had the same problem on my 8a. I went with the template. I had to split the wing tip ends and adjust to fit the ailerons. Results were ok. ray south caroline RV-8 Builders, I got a problem. I have the wings mounted on my 8a. I > attached the ailerons and set them to the template provided by Van (cut > out plywood). Added the flaps and with plenty of careful trimming they > line up with the ailerons and fuselage bottom. All is well. Then I put on > the fiberglass wing tips and they don't line up with the aileron. Sooooo. > Do I go with the template or the wing tip ? I want the bird to fly right, > but I also want it to look right. Hope to hear from some folks that have > solved this problem. Thanks, Bill of Georgia > > -----Original Message----- > From: RV8-List Digest Server <rv8-list(at)matronics.com> > To: RV8-List Digest List > Sent: Tue, 26 Feb 2008 2:57 am > Subject: RV8-List Digest: 0 Msgs - 02/25/08 > > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-02-25&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-02-25&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Mon 02/25/08: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > ________________________________________________________________________ > ________________________________________________________________________________
Date: Feb 26, 2008
It may be. It has been a while. I honestly don't remember where I saw it or read about it. I think it was in the RV-7 construction manual. If memory serves, it mentioned that the wing profile template would be printed on the inside of the crate (it was not), and that an alternate method involves using the tooling holes. It may be mentioned on a Construction FAQ on Van's site. Don't hold me to that...check with Van's if you're unsure. In any case, YMMV, but this "priority" order of things worked great for me (my plane is no slouch speed-wise): 1. Set the ailerons precisely in trail. 2. Align the flaps to the ailerons. 3. Align the wing tips to the ailerons. 4. Rig the pushrods/bellcranks with the ailerons held exactly in trail. On a side-by-side RV (I know this is the RV-8 list, but I'm mentioning it regardless), make sure the elevators are rigged & clamped in trail while you rig your aileron pushrods & bellcranks. There's a "triangulation" effect on the side-by-side RVs since the aileron & elevator control movements are linked. Sharpie ----- Original Message ----- From: japhillipsga(at)aol.com To: rv8-list(at)matronics.com Sent: Tuesday, February 26, 2008 11:03 AM Subject: Re: RV8-List: Re: RV8a- Ailerion & Wing Tip Match Sharpie, is this centerline/deadnuts technique shown on the plans somewhere? Thanks Bill -----Original Message----- From: Dan Checkoway <dan(at)rvproject.com> To: rv8-list(at)matronics.com Sent: Tue, 26 Feb 2008 1:50 pm Subject: Re: RV8-List: Re: RV8a- Ailerion & Wing Tip Match I'm not a fan of the wood template. It's a broad stroke on something that, imho, can be a lot more precise. On my RV-7 (same wings as yours), I used the extended centerline that bisects the main wing rib tooling holes, and I made sure the ailerons' trailing edges were dead nuts on that extended line. More accurate technique imho. YMMV Sharpie www.rvproject.com ----- Original Message ----- From: japhillipsga(at)aol.com To: rv8-list(at)matronics.com Sent: Tuesday, February 26, 2008 10:15 AM Subject: RV8-List: Re: RV8a- Ailerion & Wing Tip Match RV-8 Builders, I got a problem. I have the wings mounted on my 8a. I attached the ailerons and set them to the template provided by Van (cut out plywood). Added the flaps and with plenty of careful trimming they line up with the ailerons and fuselage bottom. All is well. Then I put on the fiberglass wing tips and they don't line up with the aileron. Sooooo. Do I go with the template or the wing tip ? I want the bird to fly right, but I also want it to look right. Hope to hear from some folks that have solved this problem. Thanks, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> To: RV8-List Digest List Sent: Tue, 26 Feb 2008 2:57 am Subject: RV8-List Digest: 0 Msgs - 02/25/08 * Online Versions of Today's List Digest Archive Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html& Chapter 08-02-25&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&C hapter 08-02-25&Archive=RV8 ====================== EMail Version of Today's List Digest Archive ====================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Mon 02/25/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ------------------------------------------------------------------------- --- href="http://www.matronics.com/Navigator?RV8-List">http://www.matronics .com/Navigator?RV8-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Feb 26, 2008
Also remember that there is quite a bit of adjustment available when installing the wingtip. It can be joggled around to line up with just about anything... Manny japhillipsga(at)aol.com wrote: Sharpie, is this centerline/deadnuts technique shown on the plans somewhere? Thanks Bill -----Original Message----- From: Dan Checkoway <dan(at)rvproject.com> Sent: Tue, 26 Feb 2008 1:50 pm Subject: Re: RV8-List: Re: RV8a- Ailerion & Wing Tip Match I'm not a fan of the wood template. It's a broad stroke on something that, imho, can be a lot more precise. On my RV-7 (same wings as yours), I used the extended centerline that bisects the main wing rib tooling holes, and I made sure the ailerons' trailing edges were dead nuts on that extended line. More accurate technique imho. YMMV Sharpie www.rvproject.com ----- Original Message ----- From: japhillipsga(at)aol.com To: rv8-list(at)matronics.com Sent: Tuesday, February 26, 2008 10:15 AM Subject: RV8-List: Re: RV8a- Ailerion & Wing Tip Match RV-8 Builders, I got a problem. I have the wings mounted on my 8a. I attached the ailerons and set them to the template provided by Van (cut out plywood). Added the flaps and with plenty of careful trimming they line up with the ailerons and fuselage bottom. All is well. Then I put on the fiberglass wing tips and they don't line up with the aileron. Sooooo. Do I go with the template or the wing tip ? I want the bird to fly right, but I also want it to look right. Hope to hear from some folks that have solved this problem. Thanks, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Tue, 26 Feb 2008 2:57 am Subject: RV8-List Digest: 0 Msgs - 02/25/08 * Online Versions of Today's List Digest Archive Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-02-25&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-02-25&Archive=RV8 ======================= EMail Version of Today's List Digest Archive ======================= ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Mon 02/25/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- --------------------------------- href="http://www.matronics.com/Navigator?RV8-List">http://www.matronics.com/Navigator?RV8-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c --------------------------------- Never miss a thing. Make Yahoo your homepage. ________________________________________________________________________________
Date: Feb 26, 2008
Finishing up on my 8A QB and had the same problem. Talked to factory but they weren't much help. I think I recall the wing tips sometimes get distorted and use the template. I did get them close. We'll see when I fly. Jesse-Oregon painting ----- Original Message ----- From: japhillipsga(at)aol.com To: rv8-list(at)matronics.com Sent: Tuesday, February 26, 2008 10:15 AM Subject: RV8-List: Re: RV8a- Ailerion & Wing Tip Match RV-8 Builders, I got a problem. I have the wings mounted on my 8a. I attached the ailerons and set them to the template provided by Van (cut out plywood). Added the flaps and with plenty of careful trimming they line up with the ailerons and fuselage bottom. All is well. Then I put on the fiberglass wing tips and they don't line up with the aileron. Sooooo. Do I go with the template or the wing tip ? I want the bird to fly right, but I also want it to look right. Hope to hear from some folks that have solved this problem. Thanks, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> To: RV8-List Digest List Sent: Tue, 26 Feb 2008 2:57 am Subject: RV8-List Digest: 0 Msgs - 02/25/08 * Online Versions of Today's List Digest Archive Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html& Chapter 08-02-25&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&C hapter 08-02-25&Archive=RV8 ====================== EMail Version of Today's List Digest Archive ====================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Mon 02/25/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Subject: Re: RV8-Aileron & Flap Neutral Set
Date: Feb 27, 2008
Dear RV Builders, thanks to all of you for your prompt responses and assistance. With your help I found the more actuate method for setting neutral on DWG 12A and checked last night. Sure enough the cut out plywood template I laboriously sawed out was wrong. Using the steel rod on the machine bolt holes at the end of the wing method revealed that the tips are in fact correct, but my sawed out template was off near 9/16th at the tip end. So lesson learned. Do not rely on the paper transfer/saw out of plywood template method. It is inaccurate. Thanks again to all you fellows that brought this to light. I owe you and best regards, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Wed, 27 Feb 2008 2:57 am Subject: RV8-List Digest: 7 Msgs - 02/26/08 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-02-26&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-02-26&Archive=RV8 =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Tue 02/26/08: 7 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 10:19 AM - Re: RV8a- Ailerion & Wing Tip Match (japhillipsga(at)aol.com) 2. 10:54 AM - Re: Re: RV8a- Ailerion & Wing Tip Match (Dan Checkoway) 3. 11:07 AM - Re: Re: RV8a- Ailerion & Wing Tip Match (japhillipsga(at)aol.com) 4. 11:13 AM - Re: Re: RV8a- Ailerion & Wing Tip Match (planecrazzy(at)wildblue.net) 5. 11:35 AM - Re: Re: RV8a- Ailerion & Wing Tip Match (Dan Checkoway) 6. 12:33 PM - Re: Re: RV8a- Ailerion & Wing Tip Match (manuel weber) 7. 09:30 PM - Re: Re: RV8a- Ailerion & Wing Tip Match (Jesse Laub) ________________________________ Message 1 _____________________________________ Subject: RV8-List: Re: RV8a- Ailerion & Wing Tip Match From: japhillipsga(at)aol.com RV-8 Builders, I got a problem. I have the wings mounted on my 8a. I attached the ailerons and set them to the template provided by Van (cut out plywood). Added the flaps and with plenty of careful trimming they line up with the ailerons and fuselage bottom. All is well. Then I put on the fiberglass wing tips and they don't line up with the aileron. Sooooo. Do I go with the template or the wing tip ? I want the bird to fly right, but I also want it to look right. Hope to hear from some folks that have solved this problem. Thanks, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Tue, 26 Feb 2008 2:57 am Subject: RV8-List Digest: 0 Msgs - 02/25/08 * ================================================ Online Versions of Today's List Digest Archive ================================================ Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-02-25&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-02-25&Archive=RV8 ============================================== EMail Version of Today's List Digest Archive ============================================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Mon 02/25/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________ ________________________________ Message 2 _____________________________________ From: "Dan Checkoway" <dan(at)rvproject.com> Subject: Re: RV8-List: Re: RV8a- Ailerion & Wing Tip Match I'm not a fan of the wood template. It's a broad stroke on something that, imho, can be a lot more precise. On my RV-7 (same wings as yours), I used the extended centerline that bisects the main wing rib tooling holes, and I made sure the ailerons' trailing edges were dead nuts on that extended line. More accurate technique imho. YMMV Sharpie www.rvproject.com ----- Original Message ----- From: japhillipsga(at)aol.com To: rv8-list(at)matronics.com Sent: Tuesday, February 26, 2008 10:15 AM Subject: RV8-List: Re: RV8a- Ailerion & Wing Tip Match RV-8 Builders, I got a problem. I have the wings mounted on my 8a. I attached the ailerons and set them to the template provided by Van (cut out plywood). Added the flaps and with plenty of careful trimming they line up with the ailerons and fuselage bottom. All is well. Then I put on the fiberglass wing tips and they don't line up with the aileron. Sooooo. Do I go with the template or the wing tip ? I want the bird to fly right, but I also want it to look right. Hope to hear from some folks that have solved this problem. Thanks, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> To: RV8-List Digest List Sent: Tue, 26 Feb 2008 2:57 am Subject: RV8-List Digest: 0 Msgs - 02/25/08 * Online Versions of Today's List Digest Archive Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html& Chapter 08-02-25&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&C hapter 08-02-25&Archive=RV8 ===================== EMail Version of Today's List Digest Archive ===================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Mon 02/25/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ------------------------------------------------------------------------- ----- ________________________________ Message 3 _____________________________________ Subject: Re: RV8-List: Re: RV8a- Ailerion & Wing Tip Match From: japhillipsga(at)aol.com Sharpie, is this centerline/deadnuts technique shown on the plans somewhere? Thanks Bill -----Original Message----- From: Dan Checkoway <dan(at)rvproject.com> Sent: Tue, 26 Feb 2008 1:50 pm Subject: Re: RV8-List: Re: RV8a- Ailerion & Wing Tip Match I'm not a fan of the wood template.? It's a broad stroke on something that, imho, can be a lot more precise. ? On my RV-7 (same wings as yours), I used the extended centerline that bisects the main wing rib tooling holes, and I made sure the ailerons' trailing edges were dead nuts on that extended line.? More accurate technique imho.? YMMV ? Sharpie www.rvproject.com ----- Original Message ----- From: japhillipsga(at)aol.com Sent: Tuesday, February 26, 2008 10:15 AM Subject: RV8-List: Re: RV8a- Ailerion & Wing Tip Match RV-8 Builders, I got a problem. I have the wings mounted on my 8a. I attached the ailerons and set them to the template provided by Van (cut out plywood). Added the flaps and with plenty of careful trimming they line up with the ailerons and fuselage bottom. All is well. Then I put on the fiberglass wing tips and they don't line up with the aileron. Sooooo. Do I go with the template or the wing tip ? I want the bird to fly right, but I also want it to look right. Hope to hear from some folks that have solved this problem. Thanks, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Tue, 26 Feb 2008 2:57 am Subject: RV8-List Digest: 0 Msgs - 02/25/08 * Online Versions of Today's List Digest Archive Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-02-25&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-02-25&Archive=RV8 ===================== EMail Version of Today's List Digest Archive ===================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Mon 02/25/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- href="http://www.matronics.com/Navigator?RV8-List">http://www.matronics.com/Navigator?RV8-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________ ________________________________ Message 4 _____________________________________ Subject: Re: RV8-List: Re: RV8a- Ailerion & Wing Tip Match From: planecrazzy(at)wildblue.net Bill, I had the same problem on my 8a. I went with the template. I had to split the wing tip ends and adjust to fit the ailerons. Results were ok. ray south caroline RV-8 Builders, I got a problem. I have the wings mounted on my 8a. I > attached the ailerons and set them to the template provided by Van (cut > out plywood). Added the flaps and with plenty of careful trimming they > line up with the ailerons and fuselage bottom. All is well. Then I put on > the fiberglass wing tips and they don't line up with the aileron. Sooooo. > Do I go with the template or the wing tip ? I want the bird to fly right, > but I also want it to look right. Hope to hear from some folks that have > solved this problem. Thanks, Bill of Georgia > > -----Original Message----- > From: RV8-List Digest Server <rv8-list(at)matronics.com> > To: RV8-List Digest List > Sent: Tue, 26 Feb 2008 2:57 am > Subject: RV8-List Digest: 0 Msgs - 02/25/08 > > > * > > ================================================ > Online Versions of Today's List Digest Archive > ================================================ > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-02-25&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-02-25&Archive=RV8 > > > ============================================== > EMail Version of Today's List Digest Archive > ============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Mon 02/25/08: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > ________________________________________________________________________ > ________________________________ Message 5 _____________________________________ From: "Dan Checkoway" <dan(at)rvproject.com> Subject: Re: RV8-List: Re: RV8a- Ailerion & Wing Tip Match It may be. It has been a while. I honestly don't remember where I saw it or read about it. I think it was in the RV-7 construction manual. If memory serves, it mentioned that the wing profile template would be printed on the inside of the crate (it was not), and that an alternate method involves using the tooling holes. It may be mentioned on a Construction FAQ on Van's site. Don't hold me to that...check with Van's if you're unsure. In any case, YMMV, but this "priority" order of things worked great for me (my plane is no slouch speed-wise): 1. Set the ailerons precisely in trail. 2. Align the flaps to the ailerons. 3. Align the wing tips to the ailerons. 4. Rig the pushrods/bellcranks with the ailerons held exactly in trail. On a side-by-side RV (I know this is the RV-8 list, but I'm mentioning it regardless), make sure the elevators are rigged & clamped in trail while you rig your aileron pushrods & bellcranks. There's a "triangulation" effect on the side-by-side RVs since the aileron & elevator control movements are linked. Sharpie ----- Original Message ----- From: japhillipsga(at)aol.com To: rv8-list(at)matronics.com Sent: Tuesday, February 26, 2008 11:03 AM Subject: Re: RV8-List: Re: RV8a- Ailerion & Wing Tip Match Sharpie, is this centerline/deadnuts technique shown on the plans somewhere? Thanks Bill -----Original Message----- From: Dan Checkoway <dan(at)rvproject.com> To: rv8-list(at)matronics.com Sent: Tue, 26 Feb 2008 1:50 pm Subject: Re: RV8-List: Re: RV8a- Ailerion & Wing Tip Match I'm not a fan of the wood template. It's a broad stroke on something that, imho, can be a lot more precise. On my RV-7 (same wings as yours), I used the extended centerline that bisects the main wing rib tooling holes, and I made sure the ailerons' trailing edges were dead nuts on that extended line. More accurate technique imho. YMMV Sharpie www.rvproject.com ----- Original Message ----- From: japhillipsga(at)aol.com To: rv8-list(at)matronics.com Sent: Tuesday, February 26, 2008 10:15 AM Subject: RV8-List: Re: RV8a- Ailerion & Wing Tip Match RV-8 Builders, I got a problem. I have the wings mounted on my 8a. I attached the ailerons and set them to the template provided by Van (cut out plywood). Added the flaps and with plenty of careful trimming they line up with the ailerons and fuselage bottom. All is well. Then I put on the fiberglass wing tips and they don't line up with the aileron. Sooooo. Do I go with the template or the wing tip ? I want the bird to fly right, but I also want it to look right. Hope to hear from some folks that have solved this problem. Thanks, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> To: RV8-List Digest List Sent: Tue, 26 Feb 2008 2:57 am Subject: RV8-List Digest: 0 Msgs - 02/25/08 * Online Versions of Today's List Digest Archive Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html& Chapter 08-02-25&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&C hapter 08-02-25&Archive=RV8 ===================== EMail Version of Today's List Digest Archive ===================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Mon 02/25/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ------------------------------------------------------------------------- --- href="http://www.matronics.com/Navigator?RV8-List">http://www.matronics .com/Navigator?RV8-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________ Message 6 _____________________________________ From: manuel weber <flyinwithme99(at)yahoo.com> Subject: Re: RV8-List: Re: RV8a- Ailerion & Wing Tip Match Also remember that there is quite a bit of adjustment available when installing the wingtip. It can be joggled around to line up with just about anything... Manny japhillipsga(at)aol.com wrote: Sharpie, is this centerline/deadnuts technique shown on the plans somewhere? Thanks Bill -----Original Message----- From: Dan Checkoway <dan(at)rvproject.com> Sent: Tue, 26 Feb 2008 1:50 pm Subject: Re: RV8-List: Re: RV8a- Ailerion & Wing Tip Match I'm not a fan of the wood template. It's a broad stroke on something that, imho, can be a lot more precise. On my RV-7 (same wings as yours), I used the extended centerline that bisects the main wing rib tooling holes, and I made sure the ailerons' trailing edges were dead nuts on that extended line. More accurate technique imho. YMMV Sharpie www.rvproject.com ----- Original Message ----- From: japhillipsga(at)aol.com To: rv8-list(at)matronics.com Sent: Tuesday, February 26, 2008 10:15 AM Subject: RV8-List: Re: RV8a- Ailerion & Wing Tip Match RV-8 Builders, I got a problem. I have the wings mounted on my 8a. I attached the ailerons and set them to the template provided by Van (cut out plywood). Added the flaps and with plenty of careful trimming they line up with the ailerons and fuselage bottom. All is well. Then I put on the fiberglass wing tips and they don't line up with the aileron. Sooooo. Do I go with the template or the wing tip ? I want the bird to fly right, but I also want it to look right. Hope to hear from some folks that have solved this problem. Thanks, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Tue, 26 Feb 2008 2:57 am Subject: RV8-List Digest: 0 Msgs - 02/25/08 * Online Versions of Today's List Digest Archive Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-02-25&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-02-25&Archive=RV8 ======================= EMail Version of Today's List Digest Archive ======================= ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Mon 02/25/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- --------------------------------- href="http://www.matronics.com/Navigator?RV8-List">http://www.matronics.com/Navigator?RV8-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c --------------------------------- Never miss a thing. Make Yahoo your homepage. ________________________________ Message 7 _____________________________________ From: "Jesse Laub" <jesse(at)casco.net> Subject: Re: RV8-List: Re: RV8a- Ailerion & Wing Tip Match Finishing up on my 8A QB and had the same problem. Talked to factory but they weren't much help. I think I recall the wing tips sometimes get distorted and use the template. I did get them close. We'll see when I fly. Jesse-Oregon painting ----- Original Message ----- From: japhillipsga(at)aol.com To: rv8-list(at)matronics.com Sent: Tuesday, February 26, 2008 10:15 AM Subject: RV8-List: Re: RV8a- Ailerion & Wing Tip Match RV-8 Builders, I got a problem. I have the wings mounted on my 8a. I attached the ailerons and set them to the template provided by Van (cut out plywood). Added the flaps and with plenty of careful trimming they line up with the ailerons and fuselage bottom. All is well. Then I put on the fiberglass wing tips and they don't line up with the aileron. Sooooo. Do I go with the template or the wing tip ? I want the bird to fly right, but I also want it to look right. Hope to hear from some folks that have solved this problem. Thanks, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> To: RV8-List Digest List Sent: Tue, 26 Feb 2008 2:57 am Subject: RV8-List Digest: 0 Msgs - 02/25/08 * Online Versions of Today's List Digest Archive Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html& Chapter 08-02-25&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&C hapter 08-02-25&Archive=RV8 ===================== EMail Version of Today's List Digest Archive ===================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Mon 02/25/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Subject: 5th Annual Leeward Air Ranch Invitational Fly in
Date: Feb 27, 2008
Plan to visit us on your way to Sun n Fun! Tell your fellow RVators about it! Leeward RVators are planning The 5th Annual INVITATIONAL RV FLY-IN for Saturday, April 5, 2008. If you are interested in attending please send an e-mail to Esten Spears giving Names, Address, RV Type, and if not flying your RV in; Mode of arrival. Esten will respond with an invitation containing Event, Flying, and Driving Information. Keep in mind that this is BY INVITATION ONLY. Richard Dayton is the Event Manager. If you have further questions he can be contacted at rdayton34472(at)comcast.net Send your e-mail to Esten at: ewspears(at)comcast.net Esten Spears, Leeward Air Ranch 9127 SE 72nd Avenue Ocala, FL 34472 352-347-3523 ________________________________________________________________________________
Subject: Re: 5th Annual Leeward Air Ranch Invitational Fly in
Date: Feb 27, 2008
Esten, I would like to attend. Dick Martin RV8 N233M ----- Original Message ----- From: "Esten Spears" <ewspears(at)comcast.net> Sent: Wednesday, February 27, 2008 11:55 AM Subject: RV8-List: 5th Annual Leeward Air Ranch Invitational Fly in > > Plan to visit us on your way to Sun n Fun! Tell your fellow RVators about > it! > > Leeward RVators are planning The 5th Annual INVITATIONAL RV FLY-IN for > Saturday, April 5, 2008. If you are interested in attending please send an > e-mail to Esten Spears giving Names, Address, RV Type, and if not flying > your RV in; Mode of arrival. Esten will respond with an invitation > containing Event, > Flying, and Driving Information. Keep in mind that this is BY INVITATION > ONLY. > > Richard Dayton is the Event Manager. If you have further questions he can > be contacted at rdayton34472(at)comcast.net > > Send your e-mail to Esten at: ewspears(at)comcast.net > > Esten Spears, Leeward Air Ranch > 9127 SE 72nd Avenue > Ocala, FL 34472 > 352-347-3523 > > > ________________________________________________________________________________
Subject: Re: RV8a Flap Fairing-
Date: Mar 03, 2008
RvA Builders, I have a question concerning the left flap fairing. Where the left fairing mounts over the steel step plate the fairing has three # 30 PP holes that would be drilled for attachment as a tail dragger. For the 8A model should the three holes be drilled through the step plate? I am concerned about weakling the plate with three holes in line just to lap the fairing. The plans don't address the issue. Who drilled and riveted the fairing to the plate ? Also I expect with time the step plate will flex with use. Will that warp the fairing ? Next to building the baggage door that dammed left side fairing has been the meanest job so far. Hope to hear from the folks that know, best regards, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Mon, 3 Mar 2008 2:57 am Subject: RV8-List Digest: 0 Msgs - 03/02/08 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-03-02&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-03-02&Archive=RV8 =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Sun 03/02/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________________
Date: Mar 11, 2008
From: Garey Wittich <gareywittich2000(at)yahoo.com>
Subject: Rudder Counter Balance Weight / Rod End Bearings
Greetings: 1) Have an "older" RUDDER Dwg 7PP which does not show the how far the 3 Rod End Bearings are suppose to be screwed into their associated Nut Plates mounted on the Rudder Spar. What are the dimensions and where are they measured from ????? 2) Looking at the LEAD COUNTER BALANCE WEIGHT, one of the 2 pre-drilled holes is closer to the "end" of the lead weight than the other. Which Weights "hole" goes forward toward the front of the rudder AND is the Ribs (R803) tooling hole used to mount the Lead Weight OR are 2 new holes drilled to mount the weight ???? Assume the Lead Weight should be placed as close to the "leading edge"of the Rib (R803) as possible, is this true ???? Need a little clarification. Thanks, Garey ( Santa Monica, CA) Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs ________________________________________________________________________________
Date: Mar 11, 2008
From: Christopher Stone <rv8iator(at)earthlink.net>
Subject: Re: Rudder Counter Balance Weight / Rod End Bearings
Garey... I started out using the same dimension called out for the horz. stab/elevator. Some adjustment is required upon final assembly after the emp. is mounted to the fuse. Chris Stone RV-8 x2 -----Original Message----- >From: Garey Wittich <gareywittich2000(at)yahoo.com> >Sent: Mar 11, 2008 11:10 AM >To: rv8-list(at)matronics.com >Subject: RV8-List: Rudder Counter Balance Weight / Rod End Bearings > > >Greetings: > >1) Have an "older" RUDDER Dwg 7PP which does not show >the how far the 3 Rod End Bearings are suppose to be >screwed into their associated Nut Plates mounted on >the Rudder Spar. What are the dimensions and where >are they measured from ????? > >2) Looking at the LEAD COUNTER BALANCE WEIGHT, one of >the 2 pre-drilled holes is closer to the "end" of the >lead weight than the other. > Which Weights "hole" goes forward toward the front of >the rudder AND is the Ribs (R803) tooling hole used to >mount the Lead Weight OR are 2 new holes drilled to >mount the weight ???? Assume the Lead Weight should >be placed as close to the "leading edge"of the Rib >(R803) as possible, is this true ???? > >Need a little clarification. Thanks, Garey ( Santa >Monica, CA) > > >Never miss a thing. Make Yahoo your home page. >http://www.yahoo.com/r/hs > > ________________________________________________________________________________
Subject: RV-8A Aileron Stops
Date: Mar 17, 2008
Dear Fellow RV-8 Builders, I can't seem to find in the written instructions info for setting the swing limits for the ailerons. I see where the drawings shows where to put the stop, but I need to know how far up and down the aileron can travel. Who can help me out? Also, are we to put the stops on both ailerons? One to stop up and the other to stop down? Thanks, Bill of Georgia? -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Mon, 17 Mar 2008 1:57 am Subject: RV8-List Digest: 0 Msgs - 03/16/08 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-03-16&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-03-16&Archive=RV8 =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Sun 03/16/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________________
Date: Mar 17, 2008
Subject: Re: RV-8A Aileron Stops
Hey Bill, Have you seen any planes out there with the plastic spacers in the aileron hinge used to limit the travel of the ailerons. Just did mine this way. Simple and elegant. _http://bowenaero.com/mt/2007/12/aileron-stops.html_ (http://bowenaero.com/mt/2007/12/aileron-stops.html) better link _http://www.rv8.ch/article.php?story 040924215600851_ (http://www.rv8.ch/article.php?story 040924215600851) Dennis **************It's Tax Time! Get tips, forms, and advice on AOL Money & Finance. (http://money.aol.com/tax?NCID=aolprf00030000000001) ________________________________________________________________________________
Date: Mar 17, 2008
The manual shows up and down degree's Of min and max travel and yes both use Travel stops Danny Sent from cell On Mar 17, 2008, at 8:31 AM, japhillipsga(at)aol.com wrote: > Dear Fellow RV-8 Builders, I can't seem to find in the written > instructions info for setting the swing limits for the ailerons. I > see where the drawings shows where to put the stop, but I need to > know how far up and down the aileron can travel. Who can help me > out? Also, are we to put the stops on both ailerons? One to stop up > and the other to stop down? Thanks, Bill of Georgia > > > -----Original Message----- > From: RV8-List Digest Server <rv8-list(at)matronics.com> > To: RV8-List Digest List > Sent: Mon, 17 Mar 2008 1:57 am > Subject: RV8-List Digest: 0 Msgs - 03/16/08 > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest > formatted > in HTML for viewing with a web browser and features Hyperlinked > Indexes > and Message Navigation. The .txt file includes the plain ASCII > version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-03-16&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-03-16&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Sun 03/16/08: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > Supercharge your AIM. Get the AIM toolbar for your browser. > > ________________________________________________________________________________
Date: Mar 17, 2008
The control throw specs are in Chapter 15 page 2. Up 25 to 32 deg, down 15 to 17 deg. Good luck. George -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of japhillipsga(at)aol.com Sent: Monday, March 17, 2008 8:32 AM Subject: RV8-List: RV-8A Aileron Stops Dear Fellow RV-8 Builders, I can't seem to find in the written instructions info for setting the swing limits for the ailerons. I see where the drawings shows where to put the stop, but I need to know how far up and down the aileron can travel. Who can help me out? Also, are we to put the stops on both ailerons? One to stop up and the other to stop down? Thanks, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Mon, 17 Mar 2008 1:57 am Subject: RV8-List Digest: 0 Msgs - 03/16/08 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Ch apter 08-03-16&Archive=RV8 <http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapte r 08-03-16&Archive=RV8> Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Cha pter 08-03-16&Archive=RV8 <http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-03-16&Archive=RV8> =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Sun 03/16/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- _____ Supercharge your AIM. Get the AIM toolbar <http://download.aim.com/client/aimtoolbar?NCID=aolcmp00300000002586> for your browser. ________________________________________________________________________________
Date: Mar 18, 2008
George, thanks for the info. My dear Wife found the chart last night for me and again I had to suffer under her wagging tongue of humiliation and jest. I hate it when she finds something I looked for for days! Best regards, Bill -----Original Message----- From: George Steube <at6c(at)bellsouth.net> Sent: Mon, 17 Mar 2008 1:44 pm Subject: RE: RV8-List: RV-8A Aileron Stops The control throw specs are in Chapter 15 page 2.? Up 25 to 32 deg, down 15 to 17 deg.? Good luck. George ? -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of japhillipsga(at)aol.com Sent: Monday, March 17, 2008 8:32 AM Subject: RV8-List: RV-8A Aileron Stops ? Dear Fellow RV-8 Builders, I can't seem to find in the written instructions info for setting the swing limits for the ailerons. I see where the drawings shows where to put the stop, but I need to know how far up and down the aileron can travel. Who can help me out? Also, are we to put the stops on both ailerons? One to stop up and the other to stop down? Thanks, Bill of Georgia? -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Mon, 17 Mar 2008 1:57 am Subject: RV8-List Digest: 0 Msgs - 03/16/08 * ? ?? Online Versions of Today's List Digest Archive ? Today's complete RV8-List Digest can also be found in either of the two Web Links listed below.? The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation.? The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. ? HTML Version: ? ??? http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-03-16&Archive=RV8 ? Text Version: ? ??? http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-03-16&Archive=RV8 ? ? ====================== ?? EMail Version of Today's List Digest Archive ====================== ? ???????????---------------------------------------------------------- ?????????????????????????? RV8-List Digest Archive ????????????????????????????????????? --- ???????????????????? Total Messages Posted Sun 03/16/08: 0 ?????????? ---------------------------------------------------------- ? Today's Message Index: ---------------------- ? ? ? ? ? ? ? ? ? Supercharge your AIM. Get the AIM toolbar for your browser. ? ? ????????? - The RV8-List Email Forum - ?? --> http://www.matronics.com/Navigator?RV8-List ?????????????? - MATRONICS WEB FORUMS - ?? --> http://forums.matronics.com ???????????? - List Contribution Web Site - ? Thank you for your generous support! ????????????????????????????? -Matt Dralle, List Admin. ?? --> http://www.matronics.com/contribution ? ________________________________________________________________________________
Subject: Re: RV8-List Digest: 4 Msgs - 03/17/08
Date: Mar 18, 2008
Hi Bill, One further comment. One up-stop on each side. These become down-stops for the opposite sides. The aileron stop and it's location is shown on dwg. 13A. Art Loring Jr. RV-8, N211XZ, flying -------------- Original message ---------------------- From: RV8-List Digest Server <rv8-list(at)matronics.com> > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 0 > 8-03-17&Archive=RV8 > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08 > -03-17&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Mon 03/17/08: 4 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 06:36 AM - RV-8A Aileron Stops (japhillipsga(at)aol.com) > 2. 09:03 AM - Re: RV-8A Aileron Stops (DONKEYVET(at)aol.com) > 3. 09:10 AM - Re: RV-8A Aileron Stops (sportypilot) > 4. 11:50 AM - Re: RV-8A Aileron Stops (George Steube) > > > > ________________________________ Message 1 > _____________________________________ > > > Subject: RV8-List: RV-8A Aileron Stops > From: japhillipsga(at)aol.com > > Dear Fellow RV-8 Builders, I can't seem to find in the written instructions info > for setting the swing limits for the ailerons. I see where the drawings shows > where to put the stop, but I need to know how far up and down the aileron can > travel. Who can help me out? Also, are we to put the stops on both ailerons? > One to stop up and the other to stop down? Thanks, Bill of Georgia? > > > -----Original Message----- > From: RV8-List Digest Server <rv8-list(at)matronics.com> > Sent: Mon, 17 Mar 2008 1:57 am > Subject: RV8-List Digest: 0 Msgs - 03/16/08 > > > * > > ================================================ > Online Versions of Today's List Digest Archive > ================================================ > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter > 08-03-16&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter > 08-03-16&Archive=RV8 > > > ============================================== > EMail Version of Today's List Digest Archive > ============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Sun 03/16/08: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > ________________________________ Message 2 > _____________________________________ > > > From: DONKEYVET(at)aol.com > Subject: Re: RV8-List: RV-8A Aileron Stops > > Hey Bill, > > Have you seen any planes out there with the plastic spacers in the aileron > hinge used to limit the travel of the ailerons. Just did mine this way. Simple > > and elegant. > > _http://bowenaero.com/mt/2007/12/aileron-stops.html_ > (http://bowenaero.com/mt/2007/12/aileron-stops.html) > > better link > > _http://www.rv8.ch/article.php?story 040924215600851_ > (http://www.rv8.ch/article.php?story 040924215600851) > > > Dennis > > > **************It's Tax Time! Get tips, forms, and advice on AOL Money & > Finance. (http://money.aol.com/tax?NCID=aolprf00030000000001) > > ________________________________ Message 3 > _____________________________________ > > > From: sportypilot <sportypilot(at)stx.rr.com> > Subject: Re: RV8-List: RV-8A Aileron Stops > > The manual shows up and down degree's > Of min and max travel and yes both use > Travel stops > > Danny > > Sent from cell > > On Mar 17, 2008, at 8:31 AM, japhillipsga(at)aol.com wrote: > > > Dear Fellow RV-8 Builders, I can't seem to find in the written > > instructions info for setting the swing limits for the ailerons. I > > see where the drawings shows where to put the stop, but I need to > > know how far up and down the aileron can travel. Who can help me > > out? Also, are we to put the stops on both ailerons? One to stop up > > and the other to stop down? Thanks, Bill of Georgia > > > > > > -----Original Message----- > > From: RV8-List Digest Server <rv8-list(at)matronics.com> > > To: RV8-List Digest List > > Sent: Mon, 17 Mar 2008 1:57 am > > Subject: RV8-List Digest: 0 Msgs - 03/16/08 > > > > * > > > > ================================================ > > Online Versions of Today's List Digest Archive > > ================================================ > > > > Today's complete RV8-List Digest can also be found in either of the > > two Web Links listed below. The .html file includes the Digest > > formatted > > in HTML for viewing with a web browser and features Hyperlinked > > Indexes > > and Message Navigation. The .txt file includes the plain ASCII > > version > > of the RV8-List Digest and can be viewed with a generic text editor > > such as Notepad or with a web browser. > > > > HTML Version: > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter > 08-03-16&Archive=RV8 > > > > Text Version: > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter > 08-03-16&Archive=RV8 > > > > > > ============================================== > > EMail Version of Today's List Digest Archive > > ============================================== > > > > > > ---------------------------------------------------------- > > RV8-List Digest Archive > > --- > > Total Messages Posted Sun 03/16/08: 0 > > ---------------------------------------------------------- > > > > > > Today's Message Index: > > ---------------------- > > > > > > Supercharge your AIM. Get the AIM toolbar for your browser. > > > > > > ________________________________ Message 4 > _____________________________________ > > > From: "George Steube" <at6c(at)bellsouth.net> > Subject: RE: RV8-List: RV-8A Aileron Stops > > The control throw specs are in Chapter 15 page 2. Up 25 to 32 deg, down 15 > to 17 deg. Good luck. > George > > -----Original Message----- > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com]On Behalf Of > japhillipsga(at)aol.com > Sent: Monday, March 17, 2008 8:32 AM > Subject: RV8-List: RV-8A Aileron Stops > > Dear Fellow RV-8 Builders, I can't seem to find in the written instructions > info for setting the swing limits for the ailerons. I see where the drawings > shows where to put the stop, but I need to know how far up and down the > aileron can travel. Who can help me out? Also, are we to put the stops on > both ailerons? One to stop up and the other to stop down? Thanks, Bill of > Georgia > > > -----Original Message----- > From: RV8-List Digest Server <rv8-list(at)matronics.com> > Sent: Mon, 17 Mar 2008 1:57 am > Subject: RV8-List Digest: 0 Msgs - 03/16/08 > > > * > > ================================================ > Online Versions of Today's List Digest Archive > ================================================ > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Ch > apter 08-03-16&Archive=RV8 > <http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapte > r 08-03-16&Archive=RV8> > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Cha > pter 08-03-16&Archive=RV8 > <http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter > 08-03-16&Archive=RV8> > > > ============================================== > EMail Version of Today's List Digest Archive > ============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Sun 03/16/08: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > _____ > > Supercharge your AIM. Get the AIM toolbar > <http://download.aim.com/client/aimtoolbar?NCID=aolcmp00300000002586> for > your browser. > > > > > > > > > ________________________________________________________________________________
Date: Mar 20, 2008
Bill, Sorry for the late reply. The plastic we bought had a 1/2 inch outter diameter and that seems to work great for the aileron travel limits! I might have some left over but I'm leaving town in a matter of minutes. Back Monday. Do you still have my phone number. We could talk about sending you some then. Dennis **************Create a Home Theater Like the Pros. Watch the video on AOL Home. (http://home.aol.com/diy/home-improvement-eric-stromer?video=15?ncid=aolhom00030000000001) ________________________________________________________________________________
Subject: RV8 LED Panel Flood Lighting diversions
Date: Mar 27, 2008
Hello, While you are in the dark, literally and figuratively, playing with panel flood lighting ideas for your RV8 try this: Place a piece of aluminum (or steel) tape on the underside of the glare screen, both sides, near the roll bar. Now bounce the light from an LED flashlight off these pieces of tape instead of trying to illuminate the panel directly. You will find that this bounce effect creates a more even and broader coverage. But see for yourself. I am assuming you are using LED lights. The best (price, ease of installation, effectiveness) flood lighting available for the RV8 (IMHO) however, is the $13.00 Energizer LED forehead light that has the two white lights with one red in the center. The whites are too bright for flying but the center red LED and lens distributes the red in an almost perfect pattern across the panel illuminating not only the panel but the side areas (throttle/mixture and fuel tank handle) as well. A very fun trick is to take one of these forehead lights and remove the two white LED lights and put one green and one red in their place. Take one of the removed white ones and put it in the center (removing the center red). Now use it to look at your airspeed indicator. Instead of washing out the color bands, this combination makes them almost fluoresce. Red responds to red, green to green, and yellow to green plus red. Switch to the lone center white light and observe how it provides a broad and clear blue/white glow to your panel identical to the red one. For those of you trying to sync the brightness of your LEDs so that one area or instrument doesn't blind you while everything else is very dim you will need to create a custom resistor divider network for each overly bright LED. The trick is that most of us know to put resistors in series with an LED (usually multiples of 300 ohms) but we are less aware of fact that placing an additional resistor in parallel with the LED dramatically affects its behavior. For the LED lights I am using, I placed two 300 ohum resistors in series and one in parallel with an amber LED to get it to mimic the response and brightness of the incandescent type lights found in my (used) versions of the King radios and transponders. I will forego telling you about how I modified USB laptop keyboard lights from the Dollar Store (yep, the Dollar Store) for use as my flood lights. Now to figure out how to tone down the Ray Allen LED trim indicators (they're different). Half bright is too bright. Regards Vince H. Idaho RV8 VSB (Very Slow Built) Finish ________________________________________________________________________________
Date: Mar 28, 2008
Subject: QB for sale
Hello RVators, I have an RV-8 empenage, quickbuild, finishing, and firewall forward kits as well as additional parts such as prop gov, FI fuel pump, Grove landing gear, more. After constructing only the tail group, I reluctantly must sell all. All other parts new in original packaging. Will not consider selling individual parts. Cost over $36K, make offer. Located in northern CA. Contact Larry xsmiller(at)yahoo.com ________________________________________________________________________________
Date: Mar 28, 2008
Subject: Fuel Tank Nutplates
Fellow RV Builders, I'm about to remove my wings for storage until painting, but before I put them up I want to rivet in the nutplates that hold the root farings on. Should these holes at the edge of the tanks be dimpled or countersunk ? Seem like they are pretty close to the Proseal and I'd hate to make a leak. What does everybody else do ? Thanks, Bill of Georgia ************** Create a Home Theater Like the Pros. Watch the video on AOL Home. (http://home.aol.com/diy/home-improvement-eric-stromer?video=15&ncid=aolhom00030000000001) ________________________________________________________________________________
Date: Mar 29, 2008
Just carefully squeeze the rivets in the nutplates and you shouldn't have a problem. CJ _____ From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of JAPhillipsGA(at)aol.com Sent: Friday, March 28, 2008 11:22 PM Subject: RV8-List: Fuel Tank Nutplates Fellow RV Builders, I'm about to remove my wings for storage until painting, but before I put them up I want to rivet in the nutplates that hold the root farings on. Should these holes at the edge of the tanks be dimpled or countersunk ? Seem like they are pretty close to the Proseal and I'd hate to make a leak. What does everybody else do ? Thanks, Bill of Georgia ************** Create a Home Theater Like the Pros. Watch the video on AOL Home. (http://home.aol.com/diy/home-improvement-eric-stromer?video=15&ncid=aolhom0 0030000000001) ________________________________________________________________________________
Date: Mar 29, 2008
Subject: Two New Lists Added to the Matronics Lineup!
Dear Listers, I've added two new Email Lists to the Matronics List and Forum lineup today. These include the Rans-List and RV12-List. Please surf over to the Matronics List Subscription page and sign up for these new Lists if they are of interest to you: http://www.matronics.com/subscribe Full support on the Forums, List Browse, Archives, etc. is available. Rans-List: http://www.matronics.com/Navigator?Rans-List RV12-List http://www.matronics.com/Navigator?RV12-List Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Mar 29, 2008
From: "RAY SHEFFIELD" <planecrazzy(at)wildblue.net>
Subject: Re: Fuel Tank Nutplates
Hi Carl, Use #6 screws, 3/8 dia 3/32 dimple die, and #6 dimple die with flat on sides to clear tank edges. Pro seal doesn't harden completely ,so the dimpling shouldn't cause leaking. ray On Sat, Mar 29, 2008 at 9:23 AM, Carl Bell wrote: > Just carefully squeeze the rivets in the nutplates and you shouldn't have > a problem. CJ > ------------------------------ > > *From:* owner-rv8-list-server(at)matronics.com [mailto: > owner-rv8-list-server(at)matronics.com] *On Behalf Of *JAPhillipsGA(at)aol.com > *Sent:* Friday, March 28, 2008 11:22 PM > *To:* rv8-list(at)matronics.com > *Subject:* RV8-List: Fuel Tank Nutplates > > > Fellow RV Builders, I'm about to remove my wings for storage until > painting, but before I put them up I want to rivet in the nutplates that > hold the root farings on. Should these holes at the edge of the tanks be > dimpled or countersunk ? Seem like they are pretty close to the Proseal and > I'd hate to make a leak. What does everybody else do ? Thanks, Bill of > Georgia > > > ************** > Create a Home Theater Like the Pros. Watch the video on AOL Home. > ( > http://home.aol.com/diy/home-improvement-eric-stromer?video=15&ncid=aolhom00030000000001) > > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > * * > > * > > * > > ________________________________________________________________________________
Date: Mar 30, 2008
Ray, what does "flat on sides" mean? Thanks, Bill ************** Create a Home Theater Like the Pros. Watch the video on AOL Home. (http://home.aol.com/diy/home-improvement-eric-stromer?video=15&ncid=aolhom00030000000001) ________________________________________________________________________________
Date: Mar 30, 2008
Bill, The female die will be 1/2" in dia., grind a flat to clear the edge of the tank. Hope that helps. ray On Sun, Mar 30, 2008 at 2:59 PM, wrote: > Ray, what does "flat on sides" mean? Thanks, Bill > > > ************** > Create a Home Theater Like the Pros. Watch the video on AOL Home. > ( > http://home.aol.com/diy/home-improvement-eric-stromer?video=15&ncid=aolhom00030000000001) > > > * > > > * > > ________________________________________________________________________________
Subject: Fw: "We Love RV's" Invitational Luncheon April 5th at Leeward
Air Ranch
Date: Apr 02, 2008
REMINDER - REMINDER - REMINDER - REMINDER - The Leeward Air Ranch RVators are having their Annual "We Love RV's" Invitational Luncheon April 5th at Leeward Air Ranch, (FD04), near Ocala, FL. April 5th is the weekend before Sun n Fun. We expect a lot of out of state RV's since we are only 67NM North of Lakeland (LAL) We are tentatively setting the 6th as a rain date. This gathering is by invitation only. If you think you can make it, Please email Esten Spears, ewspears(at)comcast.net with names of people that will attend with you. (wife, kids, or friends) Also would like to know what RV or other plane you will be arriving in. If you plan to drive in let me know that. I will email you back with an Invitation including flying and driving information. Please inform any other RV Enthusiasts you know about our Gathering and have them email me with the info I've asked for. The many RVators at Leeward Air Ranch Hope you can make it! ________________________________________________________________________________
Subject: EFIS One Price Slashed!!!
Date: Apr 02, 2008
Well OK, I dropped it a little, and added OBO. BLUE MOUNTAIN EFIS ONE $7,200 OBO FOR SALE Never flown, just back from BMA with memory upgrade and a clean bill of health. This unit provides: Autopilot (servos sold separately), ADI/HSI, compass, Airspeed, Altimeter, Altitude alerter, encoder, VSI, Slip/Skid, Turn and Bank, Clock, OAT, GPS, Moving map, Navigation database, Fuel totalizer, Flight data recorder, Fuel Level, Fuel Flow, Tachometer, Manifold Press, Coolant Temp, Voltmeter, Oil Press, Oil Temp, CHT, EGT, Ammeter, no need for vacuum system Asking less than 1/2 price of new, $7200 OBO Thanks Larry 602-363-2888 Charlie 602-763-7131 -------- C D Wambolt RV-8 Fastback (Showplanes) N8390 CHD (Chandler AZ) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=174528#174528 ________________________________________________________________________________
Date: Apr 06, 2008
Subject: Torque Values in AC43.13-1B
Table 7-1 list recommended values, BUT it does not say these are the FINAL Torque Value or the DESIRED Torque Value. Maybe the FRICTION Torque (which I have not tried to measure yet) is so small that DESIRED Torque is approx equal to Final Torque ???? I know: FRICTION Torque + DESIRED Torque = FINAL Torque Value So what does Table 7-1 show DESIRED or FINAL Torque ??? Thanks, Garey You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost. http://tc.deals.yahoo.com/tc/blockbuster/text5.com ________________________________________________________________________________
Subject: Re: RV8- Sikaflex Canopy Info
Date: Apr 15, 2008
Dear Builders, I'm going to use Sika adhesive to attach my canopy. Todd's canopy's has a couple page DIY instructions from Bob & Karen Brown that describes the U295, cleaner and primer process. When I found the Sika products on the web there are various cleaners and primers listed and the only 295 is listed as 295UV not U295. I understand you have to have the correct three products. Who out there knows is 295UV the same as U295 ?? and which primer and cleaner is appropriate for the canopy and 295 adhesive? I appreciate any help, thanks, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Tue, 15 Apr 2008 2:57 am Subject: RV8-List Digest: 0 Msgs - 04/14/08 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-04-14&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-04-14&Archive=RV8 =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Mon 04/14/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________________
Date: Apr 15, 2008
Hi I am also working on my canopy and would like the use Sika. Has anyone out their done it on an RV 7 or RV 9 slider using the horizontal square side tube that runs from the forward bow the rear bow? If so out did you attach the canopy skirt with out drilling? Any help is really appreciated. I have printed all the articles, instruction and list information, but I mostly find RV 8 instructions. I could really use some help on how to do it on a RV 7 Slider. Thanks CJ _____ From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of japhillipsga(at)aol.com Sent: Tuesday, April 15, 2008 2:14 PM Subject: RV8-List: Re: RV8- Sikaflex Canopy Info Dear Builders, I'm going to use Sika adhesive to attach my canopy. Todd's canopy's has a couple page DIY instructions from Bob & Karen Brown that describes the U295, cleaner and primer process. When I found the Sika products on the web there are various cleaners and primers listed and the only 295 is listed as 295UV not U295. I understand you have to have the correct three products. Who out there knows is 295UV the same as U295 ? and which primer and cleaner is appropriate for the canopy and 295 adhesive? I appreciate any help, thanks, Bill of Georgia -----Original Message----- From: RV8-List Digest Server <rv8-list(at)matronics.com> Sent: Tue, 15 Apr 2008 2:57 am Subject: RV8-List Digest: 0 Msgs - 04/14/08 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701 <http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapte r 08-04-14&Archive=RV8> &View=html&Chapter 08-04-14&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701 <http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-04-14&Archive=RV8> &View=txt&Chapter 08-04-14&Archive=RV8 =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Mon 04/14/08: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- _____ Get the MapQuest <http://www.mapquest.com/toolbar?NCID=mpqmap00030000000003> Toolbar, Maps, Traffic, Directions & More! ________________________________________________________________________________
Date: Apr 16, 2008
Subject: Drawing REVISIONS for RV8
Greetings: I called Vans and they (Bruce) could not help me - said they do not have the old Dwgs 4PP (Elevator) and 5PP (Trim Tab, etc) anymore. I have OLD emphennage drawings dating back to 1999 for my RV-8A. My Dwg 4PP is dated 1999, Rev 1 My Dwg 5PP is dated 1999, no Rev. Does anybody have these Dwgs and can they tell me what the LATEST Revision is for each and what that Revision entails. Your help would be GREATLY appreciated !!!!! Garey Wittich Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Date: Apr 17, 2008
Subject: Re: Drawing REVISIONS for RV8
Garey, I wish I could help, but mine are even older - 1996. I'm very surprised - and very disappointed - that Van's doesn't have every drawing they published. Stan Sutterfield I called Vans and they (Bruce) could not help me - said they do not have the old Dwgs 4PP (Elevator) and 5PP (Trim Tab, etc) anymore. I have OLD emphennage drawings dating back to 1999 for my RV-8A. My Dwg 4PP is dated 1999, Rev 1 My Dwg 5PP is dated 1999, no Rev. Does anybody have these Dwgs and can they tell me what the LATEST Revision is for each and what that Revision entails. Your help would be GREATLY appreciated !!!!! Garey Wittich **************Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. (http://autos.aol.com/used?NCID=aolcmp00300000002851) ________________________________________________________________________________
Date: Apr 17, 2008
Mine are dated 6/01 with 2 revisions on DWG 5 dated 2/02 ? R2 E-714 trim detail R1 E-720J K & L measurements no revisons on DWG 4 More details avaliable if ya need Dan -8 in the garage Speedy11(at)aol.com wrote: Garey, I wish I could help, but mine are even older - 1996. I'm very surprised - and very disappointed - that Van's doesn't have every drawing they published. Stan Sutterfield I called Vans and they (Bruce) could not help me - said they do not have the old Dwgs 4PP (Elevator) and 5PP (Trim Tab, etc) anymore. I have OLD emphennage drawings dating back to 1999 for my RV-8A. My Dwg 4PP is dated 1999, Rev 1 My Dwg 5PP is dated 1999, no Rev. Does anybody have these Dwgs and can they tell me what the LATEST Revision is for each and what that Revision entails. Your help would be GREATLY appreciated !!!!! Garey Wittich --------------------------------- Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos. ________________________________________________________________________________
From: "tom.gregorski(at)juno.com" <tom.gregorski(at)juno.com>
Date: Apr 19, 2008
Subject: Flying an RV8
I just finished my RV8 and it had its first flight by an experienced RV driver. I took some lessons in a RV7, but I am not comfortable flying it and scared to fly mine. I am having a hard time getting good landings. I am used to flaring over the runway, but he teaches flying it to about a foot over the runway and then bleeding off the airspeed until it quits flying. He does this because of the abrupt stalls and does not want it to happen too high above the runway. Is this the way others fly RVs. I would like some other opinions. I did stall the RV7 and the stall is very rapid without any warning. Thanks, Tom _____________________________________________________________ Succeed in Your Weight Loss Goals. Easiest Protein Diet. Click Now! http://thirdpartyoffers.juno.com/TGL2121/fc/Ioyw6i3nsBcTXbt66paa5AbdxSBwZiXthpzfzrEWHlSjlTMSLBJIAc/ ________________________________________________________________________________
Date: Apr 19, 2008
Hey Tom, There are many different techniques to landing any airplane. I find that I use the same/similar technique on every aircraft I fly be it an RV to Boei ng. The method you mentioned is good for learning where the wheels are on the first couple of landings, but then I would transition to landing your p lane just as you would land a Cessna. Come down final at stall speed plus about 30 percent, flare and find the ground. Go take a few lessons in a Cu b if you can find one, it is more difficult to land than an RV. If you are even a little comfortable in it, you will have no trouble in your 8. I d on't think the 8 has an abrupt stall, mine gives me plenty of warning with a shutter of the tail. You will also feel the controls getting a lot light er. Go up and stall it a few times, straight ahead and fly it around for a while at stall plus 30 percent and in no time at all, you will not even ne ed and airspeed indicator to know that you are right in the sweet spot. Good Luck, Paul RV8 with 75 hours of fun> From: tom.gregorski(at)juno.com> Date: Sat, 19 Apr 2 orski(at)juno.com>> > I just finished my RV8 and it had its first flight by an experienced RV driver. I took some lessons in a RV7, but I am not comforta ble flying it and scared to fly mine. I am having a hard time getting good landings. I am used to flaring over the runway, but he teaches flying it to about a foot over the runway and then bleeding off the airspeed until it q uits flying. He does this because of the abrupt stalls and does not want it to happen too high above the runway. Is this the way others fly RVs. I wou ld like some other opinions. I did stall the RV7 and the stall is very rapi d without any warning. Thanks, Tom> _______________________________________ ______________________> Succeed in Your Weight Loss Goals. Easiest Protein Diet. Click Now!> http://thirdpartyoffers.juno.com/TGL2121/fc/Ioyw6i3nsBcTX ========================> _ ===============> > > ________________________________________________________________________________
Date: Apr 20, 2008
Subject: Re: Flying an RV8
I'm got about 230 hrs in my 8 and I almost never do a 3 point. Mine wheel lands very well and tends to crow hop a lot when doing a 3 pt. I believe this is because the critical angle of attack is greater than the 3 pt attitude angle of attack hence it tends to still be flying with the wheels on the ground. 65 knots seems to be a nice speed for final, wheel it on, keep it straight and you won't have any trouble. Bill N84WJ rv-8.blogspot.com On Sun, Apr 20, 2008 at 2:57 AM, RV8-List Digest Server wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-04-19&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-04-19&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Sat 04/19/08: 2 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 06:08 AM - Flying an RV8 (tom.gregorski(at)juno.com) > 2. 02:58 PM - Re: Flying an RV8 (Paul Rice) > > > ________________________________ Message 1 _____________________________________ > > > From: "tom.gregorski(at)juno.com" <tom.gregorski(at)juno.com> > Subject: RV8-List: Flying an RV8 > > > I just finished my RV8 and it had its first flight by an experienced RV driver. > I took some lessons in a RV7, but I am not comfortable flying it and scared to > fly mine. I am having a hard time getting good landings. I am used to flaring > over the runway, but he teaches flying it to about a foot over the runway and > then bleeding off the airspeed until it quits flying. He does this because of > the abrupt stalls and does not want it to happen too high above the runway. > Is this the way others fly RVs. I would like some other opinions. I did stall > the RV7 and the stall is very rapid without any warning. Thanks, Tom > _____________________________________________________________ > Succeed in Your Weight Loss Goals. Easiest Protein Diet. Click Now! > http://thirdpartyoffers.juno.com/TGL2121/fc/Ioyw6i3nsBcTXbt66paa5AbdxSBwZiXthpzfzrEWHlSjlTMSLBJIAc/ > > > ________________________________ Message 2 _____________________________________ > > > From: Paul Rice <rice737(at)msn.com> > Subject: RE: RV8-List: Flying an RV8 > > > Hey Tom, > > There are many different techniques to landing any airplane. I find that I > use the same/similar technique on every aircraft I fly be it an RV to Boei > ng. The method you mentioned is good for learning where the wheels are on > the first couple of landings, but then I would transition to landing your p > lane just as you would land a Cessna. Come down final at stall speed plus > about 30 percent, flare and find the ground. Go take a few lessons in a Cu > b if you can find one, it is more difficult to land than an RV. If you are > even a little comfortable in it, you will have no trouble in your 8. I d > on't think the 8 has an abrupt stall, mine gives me plenty of warning with > a shutter of the tail. You will also feel the controls getting a lot light > er. Go up and stall it a few times, straight ahead and fly it around for a > while at stall plus 30 percent and in no time at all, you will not even ne > ed and airspeed indicator to know that you are right in the sweet spot. > > Good Luck, > > Paul > RV8 with 75 hours of fun> From: tom.gregorski(at)juno.com> Date: Sat, 19 Apr 2 > orski(at)juno.com>> > I just finished my RV8 and it had its first flight by an > experienced RV driver. I took some lessons in a RV7, but I am not comforta > ble flying it and scared to fly mine. I am having a hard time getting good > landings. I am used to flaring over the runway, but he teaches flying it to > about a foot over the runway and then bleeding off the airspeed until it q > uits flying. He does this because of the abrupt stalls and does not want it > to happen too high above the runway. Is this the way others fly RVs. I wou > ld like some other opinions. I did stall the RV7 and the stall is very rapi > d without any warning. Thanks, Tom> _______________________________________ > ______________________> Succeed in Your Weight Loss Goals. Easiest Protein > Diet. Click Now!> http://thirdpartyoffers.juno.com/TGL2121/fc/Ioyw6i3nsBcTX > ========================> _ > ===============> > > > > ________________________________________________________________________________
Subject: Leading edge dings - tip
Date: Apr 25, 2008
Hello, PROBLEM: One wing with two dings; both are between ribs on the leading edge; one on gas tank, the other further outboard and neither accessible by reaching inside. Both dings were what you would get if someone laid a =BC=94 drill perpendicular to the leading edge and whacked it with a mallet. The damage was limited to the dinged area and there was no deformation of the surrounding leading edge. PROCEDURE: I know it sounds bizarre, but take a weighted rubber mallet and from the outside (counter intuitive I know) start gently taping around the ding. How gentle? Gentle enough that you would tap anywhere on the wing without worrying about denting it. Tap over, around, above and below as you don=92t know where your tapping will have the most effect. After a little bit you gain a better feel for what force you can safely apply to the tapping. Grab a chair though, as this will take awhile. I started noticing results after three to five minutes of continuous tapping. What results? Both dings actually started working themselves out! MY =91THEORY=92: The leading edge skin is stressed like a drum head. You tap the skin (drum head) with the mallet pushing it in and the skin rebounds. That rebound force over time works to return the dinged area to its original position. Another way to do this, for the more daring, is to replace the mallet with your variable trigger/force rivet gun. Set up a machine-gun type tapping around the ding once again so gentle you would not hesitate to do it elsewhere on the wing. You may transition to this by putting a piece of rubber, grommet, rubber washer, etc. under the rivet head. Alas, some dings are so severe, i.e. dents, or located in places, i.e. the rib line that this technique will not work. Even so, my technique is pretty much =91what have you got to lose=92? Hope this saves some one from tearing apart their wing or gas tank. With luck I will not have to test this technique again. Regards, Vince H. Idaho RV8 Glacier Built (Moved to airport last weekend, beginning registration paperwork=85getting close) ________________________________________________________________________________
Subject: RE: Leading edge dings - tip
Date: Apr 26, 2008
HI Vince- Sorry to hear of the dings in the unflown bird- sounds like a page out of my life! That's an interesting technique for ding removal, but I'm curious about what work hardening / fatigue issues may crop up. Would you let us know if any cracks develop in the affected areas? Tnx- glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Apr 26, 2008
Guys, Out of curiosity, since I have a little ding myself in the middle of the left fuel tank, what it wrong with a little Super-fil if you are painting your plane? I suspect through the years you will get more dings, would this not be an acceptable cosmetic fix? Carl W Bell (CJ) Building RV 7A - N947CB http://www.mykitlog.com/carlbell carlbell(at)gforcecable.com -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of glen matejcek Sent: Saturday, April 26, 2008 8:12 AM Subject: RV8-List: RE: Leading edge dings - tip HI Vince- Sorry to hear of the dings in the unflown bird- sounds like a page out of my life! That's an interesting technique for ding removal, but I'm curious about what work hardening / fatigue issues may crop up. Would you let us know if any cracks develop in the affected areas? Tnx- glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Apr 26, 2008
Subject: Four New Email Lists At Matronics!!
Dear Listers, I have added four new Lists to the Matronics line up today. These include the following categories: Citabria-List Citabria, Decathlon, Scout, and Champ Zenith601-List Zenair Zodiac CH 601 Zenith640-List Zenair Zodiac CH 640 Zenith701801-List Zenair STOL CH 701 and CH 801 All services are enabled and now available including Search, Browse, Digest, Archives, Forums, Chat, etc., etc. etc...: Citabria: http://www.matronics.com/navigator?citabria-list Zenith601: http://www.matronics.com/navigator?zenith601-list Zenith640: http://www.matronics.com/navigator?zenith640-list Zenith701801: http://www.matronics.com/navigator?zenith701801-list To subscribe, go to the Matronics Email List Subscription Form: http://www.matronics.com/subscribe To check the new Lists out on the Matronics Forum go here: http://forums.matronics.com Enjoy the new Lists!! Don't forget me during the Fund Raiser! :-) Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: May 03, 2008
Subject: RV-8 Quick build kit for sale
Well I;m going to sell my -8 Quick build kit, Fuselage, wings and tail, Tail is 95% done, floors and some basic details have been done in the fuselage, I have not touched the wings. This is 2 years old I have only a few hundred hours in to it, it has been fun but for me my dream will come at a better time in my life. Until then,, The plane is in Lake Stevens Washington. near Seattle / Arlington. new from Vans is about $24,500.00 and 3-4 months out. Quick build quality looks excellent. Great jump start for a builder. Will possibly trade for antique tail-drager cub, champ, Citabra or ? best offer over 20k Dan 425 754 0112 ________________________________________________________________________________
Date: May 03, 2008
Subject: For Sale - Navaid AP-1 Autopilot - New!
Fellow Homebuilders, I have decided to go with a two-axis auto pilot in my RV-4 project and am selling my single-axis Navid AP-1. This is a brand new unit with all of accessories, manual, analog Loran/GPS input, and S-2 servo. It has never been installed. No scratches. Current price from Navaid is $1300 US. I will sell for $1100 plus shipping to anywhere in the world. I can accept Visa/MC. First come, first served. Please email me off list at dralle(at)matronics.com if you are interested. Below is a picture of the actual unit and included accessories. Matt Dralle List Admin / RV-4 Builder Emacs! ________________________________________________________________________________
Subject: Flap alignment problems - tip
Date: May 05, 2008
Hello, If you are encountering alignment problems in mounting you flaps; like an unacceptable gap between wing skin and flap, and or the rolled flap top skin is hitting the flap brace before flap is in trail, I suggest the following: Inspect the top skin, flap brace, flap hinge intersection and make sure that you have the hinge on the bottom (or where your plans say it should be) with the brace sandwiched between the hinge and the top skin. For some reason, I had sandwiched the hinge between the brace and top skin on my right wing causing the above problems. I mention this because you most likely won't catch this when you are measuring to find out what went wrong. This will lead you to the archives where I 'gleaned' that the flap prematurely contacting the flap brace is a 'common problem' and the fix is to notch the rolled flap top skin. I wonder how many of those 'common problems' were the result of a misplaced hinge? Anyway, the fix is 'relatively' simple. Remove the rivets, reposition the hinge to the bottom and rivet back in place. In my case the gap is gone and the flap is in trail when the rolled skin contacts the brace. If not in your case, you will probably need to add a little more 'roll' to the flap skin. I used flush rivets where the flap brace steps up on the spar. I also took this opportunity to drill a pin hole in the aileron mounting bracket to facilitate removal and insertion of the flaps when the wing is mounted to the fuselage. BTW, don't toss the internal cutouts when you make your templates for the holding the flaps/ailerons in trail. They work great later inside the wing ends for a quick alignment check and also for inserting (or tracing onto 1" foam and inserting those) into the wing tips to give them body while you drill and clecoe.. Regards, Vince H. Idaho RV8 - N8432 (reserved) The fuselage is at the hanger. I am finishing up wingtips (now that flap problem is solved), submitting FAA paperwork, and emailing the list when I should be in bed. ________________________________________________________________________________
Subject: LED-xpak position lights and Van's wing tip position light extensions
Date: May 05, 2008
Hello, I purchased the LED-Xpak position/strobe light system through ACS. I have the old style flat top wing tips. I also purchased the A600 fiber glass wingtip extensions from Van's. I knew they were specifically for the Whelen system and that they would most likely have to be modified to fit the xpak housings. Sure enough, the LED-Xpak housing is longer and narrower so you will have to do some filling in at the ends using micro balloons. You will also have to sand the side of the mounting area. This requires some glass layups on the inside of the mount. The housing requires nuts for mounting so for reasons of access, you will have to use the plate nut installation option on the wing tips. The Xpak housing does mount nicely to the A600 'Whelen' pad so the extra layup is to cover the extra length. This is cosmetic not structural, hence the micro balloons. The fiber glass layups on the inside are to prevent break through when you sand the side to match the more narrow xpak housing. I spent about four to five hours total modifying the Whelen wingtip extensions to fit the xpak housings. I like the look so the extra effort was worth it too me. Why the xpak system? Simple, I refuse to spend seven or eight hundred dollars (more for the Whelen LED system) for 4 light bulbs and a flash. Regards, Vince H. Idaho RV8 - Glacier Built ________________________________________________________________________________
Date: May 09, 2008
Subject: For Sale - RMI uMonitor - NEW - All Probes and Upgrades!
Dear Listers, I am selling a new, never used, fully assembled RMI uMonitor with all the probes for a 4-cylinder engine including Fuel Flow, 4ea EGT, 4ea CGT, Carb Temp, and Manifold pressure. The uMonitor just had all of the latest hardware and software updates factory installed including the new high contrast LCD display supporting Fahrenheit temp readings AND the new LED fiberoptic backlight. Also included is the Aircraft Extras RM-1B plugin harness extender for the uMonitor which greatly simplifies the wiring installation. The uMonitor is in new condition with no scratches and all installation material and manuals. The pictures below are of the actual unit for sale. The table below lists all of the items included. I have nearly $2800 invested in this complete system. I will sell it for $2200 plus shipping to anywhere in the world. I can accept Visa/MC. First come, first served. Please email me off list at dralle(at)matronics.com if you are interested. Matt Dralle List Admin / RV-4 Builder 1ea - RMI microMONITOR Assembled . . . . . . . . . . . . . .$1299.00 $1299.00 1ea - Factory Upgrade of LCD (Fahrenheit Temp Display), . . . . Fiberoptic LED Backlight, Latest Firmware. . . . . .$ 399.00 $ 399.00 1ea - Manifold Pressure Sensor 10.0 to 59.0 InHg. . . . . . $ 68.00 $ 68.00 2ea - EGT/CHT Multiplex Switch 2 to 6 cylinders . . . . . . $ 60.00 $ 120.00 1ea - Fuel Flow sensor, FloScan 201B-6 - .6 to 60.0 GPH. . .$ 230.00 $ 230.00 1ea - Carb Temp Sensor . . . . . . . . . . . . . . . . . . .$ 55.00 $ 55.00 4ea - EGT Thermocouple - tubing clamp type . . . . . . . . .$ 65.00 $ 260.00 4ea - CHT Thermocouple - bayonet type. . . . . . . . . . . .$ 50.00 $ 200.00 1ea - RM-1B Harness Expander, Aircraft Extras. . . . . . . .$ 155.00 $ 155.00 ---------------------------------------------------------------------------------- . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . $2786.00 ________________________________________________________________________________
Date: May 09, 2008
Subject: For Sale - Skyforce Skymap IIIC - NEW - Latest Database
Dear Listers, I am selling my new-in-box Skyforce Skymap IIIC full color GPS moving map with Topo. The database and firmware were just upgraded 05/2008. Includes a Panel Mounting bracket, GPS Antenna, cigarette lighter adapter, carrying case, and all manuals. Brand new, never used. No scratches. The pictures below are of the actual unit. The LCD color display on the IIIC is extremely nice and very bright. Gives altitude readout. RS232 output. I have over $2500 invested in this complete system. I will sell it for $2200 plus shipping to anywhere in the world. I can accept Visa/MC. First come, first served. Please email me off list at dralle(at)matronics.com if you are interested. Matt Dralle List Admin / RV-4 Builder 1ea - Skyforce Skymap IIIC w/ GPS and Americas Database. . .$2367.00 . .$2367.00 1ea - Panel Mount. . . . . . . . . . . . . . . . . . . . . . .$98.00 . . .$98.00 1ea - Firmware and Database Update 5/8/2008. . . . . . . . . .$50.00 . . .$50.00 --------------------------------------------------------------------------------- . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . $2515.00 ________________________________________________________________________________
Date: May 09, 2008
Subject: For Sale - RMI uEncoder - NEW - Assembled
Dear Listers, I am selling a new, never used, fully assembled RMI uEncoder. The uEncoder just had all of the latest hardware and software updates factory installed including the new high contrast LCD display supporting Fahrenheit temp readings AND the new LED fiberoptic backlight. The uEncoder displays airspeed, altitude, fpm, OAT, and outputs Mode C data for most transponders. The uEncoder is in new condition with no scratches and all installation material and manuals. The pictures below are of the actual unit for sale. The table below lists all of the items included. I have nearly $1500 invested in this complete system. I will sell it for $1100 plus shipping to anywhere in the world. I can accept Visa/MC. First come, first served. Please email me off list at dralle(at)matronics.com if you are interested. Matt Dralle List Admin / RV-4 Builder 1ea - RMI microENCODER ASSEMBLED . . . . . . . . . . . . . . . .$1179.00 . $1179.00 1ea - RMI Factory Upgrade of LCD (Fahrenheit Temp, US Miles), . . . . . . Fiberoptic LED Backlight, Latest Firmware . . . . . $ 315.00 . $ 315.00 ------------------------------------------------------------------------------------- . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .$1494.00 ________________________________________________________________________________
Date: May 09, 2008
From: Garey Wittich <gareywittich2000(at)yahoo.com>
Subject: Settting the correct Spacing (Gap) between VS Top Rib and Rudder
Top Rib Greetings: The construction of my RV8A (RV7 and RV9 are the same) the Rudders Top Rib swings OVER the top Rib of the VS. There is suppose to be a "Gap" between the two Ribs so that there is no interference (rubbing of them together) as the Rudder is moved. My question is - how do you set this Gap up ??? It seems to me that the Rod End Bearings on the Rudder Spar need to be screwed into the Rudder Spar the " Final" distance so that the Gap can be set up properly BEFORE the Rudder Skin is finally riveted to the Rudders Top Rib (R703) which sets this Gap. My understanding the dimensions for screwing the Rod End Bearings as shown on the Drawing 7 is only "approximate" and needs to be fined tuned later = this could change this Gap distance. Or if one marks a center-line on the flange of the Rudders Top Rib and aligns the pre-punched holes in the Rudder Skin directly over the "center of this line", does it Guarantee automatic clearance and a constant Gap distance when the Rod End bearings are set to their "Final" screwed-in distance ?????? The Orndorff Tapes show the Rod End bearings installed in the Rudder Spar (no Rod End Bearing dimensions given) and mounted to the VS and the Gap set by bending Up the Rudders Top Rib (R703) to parallel the VS Top Rib. Maybe I am missing something. So what worked for you - set the Rod End Bearings "approx" or align the pre-punched holes in the Rudder Skin directly over the marked center-line on the Rudders Top Rib flange and THEN rivet the Rudder Skin ???? Once the Rudder Skin is riveted to the Rudders Top Rib, the Rudders Top Rib is fixed and can NOT be readjusted to get the "correct Gap" later. Appreciate your help, Garey Wittich Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Date: May 10, 2008
Subject: Re: Settting the correct Spacing (Gap) between VS Top Rib and
Rudder Top Rib On Fri, 9 May 2008, Garey Wittich wrote: > > Greetings: > > The construction of my RV8A (RV7 and RV9 are the > same) the Rudders Top Rib swings OVER the top Rib of > the VS. There is suppose to be a "Gap" between the > two Ribs so that there is no interference (rubbing of > them together) as the Rudder is moved. > > My question is - how do you set this Gap up ??? On mine, I had to file the top of the VS down a bit to get the needed gap. Given the pre-punched holes, there isn't a lot you can play with, other than changing how far the rod ends are screwed in, move the top ones a bit further out than the bottom (keeping them in line of course). Brian Huffaker, DSWL (bifft(at)xmission.com) RV-8A 80091 riviting fuse. 1/4 Starduster II N23UT flying ________________________________________________________________________________
Date: May 16, 2008
Subject: RV8 project for sale
RV8 #970 tail and wings complete and inspected (Canada) prior to closure. Excellent workmanship mentored by OSH workmanship award winner. Many reasons for selling, all of them sad but ...my loss , your gain . $10K US includes all tools and builders logbook/plans (avery, Cleveland dies, cp straight and angle drills, cp pneumatic squeezer and a lot of extras) Items crated and ready to ship. Located in Edmonton Alberta Robert Baxter robbax(at)shaw.ca robert.baxter(at)shell.com 780-464-1719 Mobile 780-901-9959 ________________________________________________________________________________
Subject: Prop lever creep
Date: May 25, 2008
Has anyone had the prop lever (middle of the 3 levers) creep and if you lock it down all the time its very annoying since that also locks down the throttle (and mixture). Applying just enough locking doesn't work since to stop the creep also immobilizes the other two....any ideas? Thanks Neil-RV8A Brookhaven LI NY ________________________________________________________________________________
Subject: RE: RV8-List Digest: 1 Msgs - 05/25/08
Date: May 26, 2008
No ideas on a solution, but that sure is an intriguing problem. Please report back when you figure out why this is happening and how you fixed it... Tnx- glen matejcek aerobubba(at)earthlink.net > [Original Message] > From: RV8-List Digest Server <rv8-list(at)matronics.com> > To: RV8-List Digest List > Date: 5/26/2008 3:04:02 AM > Subject: RV8-List Digest: 1 Msgs - 05/25/08 > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-05-25&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2008-05-25&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Sun 05/25/08: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 07:08 PM - Prop lever creep (neilmark(at)aol.com) > > > > ________________________________ Message 1 _____________________________________ > > > Subject: RV8-List: Prop lever creep > From: neilmark(at)aol.com > > Has anyone had the prop lever (middle of the 3 levers) creep and if you lock it > down all the time its very annoying since that also locks down the throttle (and > mixture). Applying just enough locking doesn't work since to stop the creep > also immobilizes the other two....any ideas? > Thanks > Neil-RV8A > Brookhaven LI NY > > > > > > > ________________________________________________________________________________
Date: May 26, 2008
Subject: Re: Prop lever creep
That's an interesting observation, I had never thought that the way all levers are on the same locking mechanism, that there may be instances that adjusting another setting could move one of the other levers.... I fly a twin Comanche that has the same set up....all 6 levers locked on the same axis...but never seemed to have that trouble... I will look again at the set up the Comanche uses and get back with you later...maybe some ideas here... neilmark(at)aol.com wrote: Has anyone had the prop lever (middle of the 3 levers) creep and if you lock it down all the time its very annoying since that also locks down the throttle (and mixture). Applying just enough locking doesn't work since to stop the creep also immobilizes the other two....any ideas? Thanks Neil-RV8A Brookhaven LI NY --------------------------------- Stay informed, get connected and more with AOL on your phone. ________________________________________________________________________________
Date: May 27, 2008
You could take the spring off the Gov. if you have that kind, but just remember that if your push pull cable breaks that the prop might be stuck in the last position. I have taken the spring off of all mine, that allows me to run less tension on the levers making for smoother operation. Remember if the push-pull where to fail it would be like landing a fix pitch. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=184988#184988 ________________________________________________________________________________
Date: May 27, 2008
I put a very light spring between the govenor [ MT ] and the bracket mount to counteract the strong tension. Works great! ----- Original Message ----- From: neilmark(at)aol.com To: rv8-list(at)matronics.com Sent: Monday, May 26, 2008 3:05 AM Subject: RV8-List: Prop lever creep Has anyone had the prop lever (middle of the 3 levers) creep and if you lock it down all the time its very annoying since that also locks down the throttle (and mixture). Applying just enough locking doesn't work since to stop the creep also immobilizes the other two....any ideas? Thanks Neil-RV8A Brookhaven LI NY ------------------------------------------------------------------------- ----- Stay informed, get connected and more with AOL on your phone. ________________________________________________________________________________
Subject: Balancing the Elevators
Date: May 27, 2008
Hello, Does one balance each Horizontal Stabilizer section separately (trim the lead weights) or as a completed unit connected to the push rods and control column. Thanks, Vince H. RV-8 (Glacier built) - Registered and in hanger for final assembly. ________________________________________________________________________________
Date: May 27, 2008
I did each separately as it was just as easy as doing it connected. Recommend leaving enough weight on to have the elevator trailing edge up. You will need this to compensate for paint (not an insignificant weight change as it is all aft of the hinge point). I ended up adding weight back after painting - and then fixing the paint job where I cut into the elevator fairing. Carl Froehlich RV-8A (425 hrs) RV-10 (flaps) From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Vince-Himsl Sent: Tuesday, May 27, 2008 7:10 PM Subject: RV8-List: Balancing the Elevators Hello, Does one balance each Horizontal Stabilizer section separately (trim the lead weights) or as a completed unit connected to the push rods and control column. Thanks, Vince H. RV-8 (Glacier built) - Registered and in hanger for final assembly. ________________________________________________________________________________
Date: May 28, 2008
I am assuming, since i could not find the balance criteria in the plans, that the balance values are "zero" for all surfaces? Is this correct? Is it safe to fly the aircraft with some positive balance (trailing edge up for paint compensation) ? Carl Froehlich wrote: I did each separately as it was just as easy as doing it connected. Recommend leaving enough weight on to have the elevator trailing edge up. You will need this to compensate for paint (not an insignificant weight change as it is all aft of the hinge point). I ended up adding weight back after painting and then fixing the paint job where I cut into the elevator fairing. Carl Froehlich RV-8A (425 hrs) RV-10 (flaps) From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Vince-Himsl Sent: Tuesday, May 27, 2008 7:10 PM Subject: RV8-List: Balancing the Elevators Hello, Does one balance each Horizontal Stabilizer section separately (trim the lead weights) or as a completed unit connected to the push rods and control column. Thanks, Vince H. RV-8 (Glacier built) Registered and in hanger for final assembly. http://www.matronics.com/Navigator?RV8-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 28, 2008
I asked Van's about this several years ago and got a "no opinion" response. I would say the amount of weight difference here can be characterized as cosmetic. I just did not like the "droopy elevator" look when parked. Carl From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of manuel weber Sent: Wednesday, May 28, 2008 5:57 PM Subject: RE: RV8-List: Balancing the Elevators I am assuming, since i could not find the balance criteria in the plans, that the balance values are "zero" for all surfaces? Is this correct? Is it safe to fly the aircraft with some positive balance (trailing edge up for paint compensation) ? Carl Froehlich wrote: I did each separately as it was just as easy as doing it connected. Recommend leaving enough weight on to have the elevator trailing edge up. You will need this to compensate for paint (not an insignificant weight change as it is all aft of the hinge point). I ended up adding weight back after painting - and then fixing the paint job where I cut into the elevator fairing. Carl Froehlich RV-8A (425 hrs) RV-10 (flaps) From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Vince-Himsl Sent: Tuesday, May 27, 2008 7:10 PM Subject: RV8-List: Balancing the Elevators Hello, Does one balance each Horizontal Stabilizer section separately (trim the lead weights) or as a completed unit connected to the push rods and control column. Thanks, Vince H. RV-8 (Glacier built) - Registered and in hanger for final assembly. http://www.matronics.com/Navigator?RV8-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 28, 2008
Subject: Re: RV8-List Digest: 4 Msgs - 05/27/08
Hi Vince- IIRC, when I did mine, the side with the trim tab would just about balance without trimming the weight and before paint. With paint, it won't be able to balance itself. Hence I would recommend waiting until after paint and do the two sides together. This was with the electric trim servo in the elevator. FWIW- >From: "Vince-Himsl" <vhimsl(at)roadrunner.com> >Subject: RV8-List: Balancing the Elevators > >Hello, > > >Does one balance each Horizontal Stabilizer section separately (trim the >lead weights) or as a completed unit connected to the push rods and control >column. > > >Thanks, > > >Vince H. > >RV-8 (Glacier built) - Registered and in hanger for final assembly. > Glen Matejcek ________________________________________________________________________________
Subject: Balancing the Elevators - Ans from Vans
Date: May 29, 2008
Received this from Van's The elevators should be balanced individually - disconnect them from the pushrod and each other. The lead weight will probably be too heavy and you will need to remove some of it. However, if you have not painted the elevators leave the weight about 2-3 oz too heavy so they will balance when painted. It is better for the lead weight to be too heavy than too light, but it is not critical. vans Thanks to all Vince H. RV-8 Glacier Built Moscow, ID _____ From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of manuel weber Sent: Wednesday, May 28, 2008 2:57 PM Subject: RE: RV8-List: Balancing the Elevators I am assuming, since i could not find the balance criteria in the plans, that the balance values are "zero" for all surfaces? Is this correct? Is it safe to fly the aircraft with some positive balance (trailing edge up for paint compensation) ? Carl Froehlich wrote: I did each separately as it was just as easy as doing it connected. Recommend leaving enough weight on to have the elevator trailing edge up. You will need this to compensate for paint (not an insignificant weight change as it is all aft of the hinge point). I ended up adding weight back after painting - and then fixing the paint job where I cut into the elevator fairing. Carl Froehlich RV-8A (425 hrs) RV-10 (flaps) From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Vince-Himsl Sent: Tuesday, May 27, 2008 7:10 PM Subject: RV8-List: Balancing the Elevators Hello, Does one balance each Horizontal Stabilizer section separately (trim the lead weights) or as a completed unit connected to the push rods and control column. Thanks, Vince H. RV-8 (Glacier built) - Registered and in hanger for final assembly. http://www.matronics.com/Navigator?RV8-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 29, 2008
Subject: Re: Balancing the Elevators - Ans from Vans
Interesting, when I asked Vans the same question they said not to bother balancing them seperately, just do them together. I guess it depends on who you talk to there. Paul ----- Original Message ----- From: Vince-Himsl Date: Thursday, May 29, 2008 10:44 am Subject: RE: RV8-List: Balancing the Elevators - Ans from Vans > Received this from Van's > > > > The elevators should be balanced individually - disconnect them > from the > > pushrod and each other. The lead weight will probably be too > heavy and you > > will need to remove some of it. However, if you have not painted > the > > elevators leave the weight about 2-3 oz too heavy so they will balance > > when > > painted. It is better for the lead weight to be too heavy than > too light, > > but it is > > not critical. > > > > vans > > > > Thanks to all > > Vince H. > > RV-8 Glacier Built > > Moscow, ID > > _____ > > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of manuel weber > Sent: Wednesday, May 28, 2008 2:57 PM > To: rv8-list(at)matronics.com > Subject: RE: RV8-List: Balancing the Elevators > > > > I am assuming, since i could not find the balance criteria in > the plans, > that the balance values are "zero" for all surfaces? > > > > Is this correct? > > > > Is it safe to fly the aircraft with some positive balance > (trailing edge up > for paint compensation) ? > > Carl Froehlich wrote: > > I did each separately as it was just as easy as doing it connected. > > > > Recommend leaving enough weight on to have the elevator trailing > edge up. > You will need this to compensate for paint (not an insignificant > weightchange as it is all aft of the hinge point). I ended up > adding weight back > after painting - and then fixing the paint job where I cut into > the elevator > fairing. > > > > Carl Froehlich > > RV-8A (425 hrs) > > RV-10 (flaps) > > > > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Vince-Himsl > Sent: Tuesday, May 27, 2008 7:10 PM > To: rv8-list(at)matronics.com > Subject: RV8-List: Balancing the Elevators > > > > Hello, > > > > Does one balance each Horizontal Stabilizer section separately > (trim the > lead weights) or as a completed unit connected to the push rods > and control > column. > > > > Thanks, > > > > Vince H. > > RV-8 (Glacier built) - Registered and in hanger for final assembly. > > > > > > > > http://www.matronics.com/Navigator?RV8-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > > > ________________________________________________________________________________
Date: May 30, 2008
On most aircraft, the service information will outline a fairly narrow window for balance criteria, and this can be either positive, negative, or neutral. I am very suprised there is nothing in the plans or instructions for the RV-8, unless "balanced" means "neutral" and there is no tolerance. Carl Froehlich wrote: I asked Vans about this several years ago and got a no opinion response. I would say the amount of weight difference here can be characterized as cosmetic. I just did not like the droopy elevator look when parked. Carl From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of manuel weber Sent: Wednesday, May 28, 2008 5:57 PM Subject: RE: RV8-List: Balancing the Elevators I am assuming, since i could not find the balance criteria in the plans, that the balance values are "zero" for all surfaces? Is this correct? Is it safe to fly the aircraft with some positive balance (trailing edge up for paint compensation) ? Carl Froehlich wrote: I did each separately as it was just as easy as doing it connected. Recommend leaving enough weight on to have the elevator trailing edge up. You will need this to compensate for paint (not an insignificant weight change as it is all aft of the hinge point). I ended up adding weight back after painting and then fixing the paint job where I cut into the elevator fairing. Carl Froehlich RV-8A (425 hrs) RV-10 (flaps) From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Vince-Himsl Sent: Tuesday, May 27, 2008 7:10 PM Subject: RV8-List: Balancing the Elevators Hello, Does one balance each Horizontal Stabilizer section separately (trim the lead weights) or as a completed unit connected to the push rods and control column. Thanks, Vince H. RV-8 (Glacier built) Registered and in hanger for final assembly. http://www.matronics.com/Navigator?RV8-List http://forums.matronics.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV8-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 30, 2008
Balancing the surfaces individually is the industry standard and makes some sense as far as physics is concerned.... The dynamics involved, and I only understand it on a very limited level, can be affected if you balance the surfaces as an assembly. ie, if one is way under balance and you compensate by adding weight to the other surface. My opinion is to balance separately. ptrotter(at)optonline.net wrote: Interesting, when I asked Vans the same question they said not to bother balancing them seperately, just do them together. I guess it depends on who you talk to there. Paul ----- Original Message ----- From: Vince-Himsl Date: Thursday, May 29, 2008 10:44 am Subject: RE: RV8-List: Balancing the Elevators - Ans from Vans > Received this from Van's > > > > The elevators should be balanced individually - disconnect them > from the > > pushrod and each other. The lead weight will probably be too > heavy and you > > will need to remove some of it. However, if you have not painted > the > > elevators leave the weight about 2-3 oz too heavy so they will balance > > when > > painted. It is better for the lead weight to be too heavy than > too light, > > but it is > > not critical. > > > > vans > > > > Thanks to all > > Vince H. > > RV-8 Glacier Built > > Moscow, ID > > _____ > > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of manuel weber > Sent: Wednesday, May 28, 2008 2:57 PM > To: rv8-list(at)matronics.com > Subject: RE: RV8-List: Balancing the Elevators > > > > I am assuming, since i could not find the balance criteria in > the plans, > that the balance values are "zero" for all surfaces? > > > > Is this correct? > > > > Is it safe to fly the aircraft with some positive balance > (trailing edge up > for paint compensation) ? > > Carl Froehlich wrote: > > I did each separately as it was just as easy as doing it connected. > > > > Recommend leaving enough weight on to have the elevator trailing > edge up. > You will need this to compensate for paint (not an insignificant > weightchange as it is all aft of the hinge point). I ended up > adding weight back > after painting - and then fixing the paint job where I cut into > the elevator > fairing. > > > > Carl Froehlich > > RV-8A (425 hrs) > > RV-10 (flaps) > > > > From: owner-rv8-list-server(at)matronics.com > [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Vince-Himsl > Sent: Tuesday, May 27, 2008 7:10 PM > To: rv8-list(at)matronics.com > Subject: RV8-List: Balancing the Elevators > > > > Hello, > > > > Does one balance each Horizontal Stabilizer section separately > (trim the > lead weights) or as a completed unit connected to the push rods > and control > column. > > > > Thanks, > > > > Vince H. > > RV-8 (Glacier built) - Registered and in hanger for final assembly. > > > > > > > > http://www.matronics.com/Navigator?RV8-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > > > ________________________________________________________________________________
Subject: Aluminum Repair Videos web site
Date: May 31, 2008
I came across this really cool web site with videos for showing how to repair aluminum (other stuff too). http://www.muggyweld.com/video.html Vince H. RV8 - In hanger for final assembly Moscow, ID ________________________________________________________________________________
Date: May 31, 2008
Subject: Bending Trailing Edge of a "One" Piece Rudder Skin
Greetings: A note that might help you. With the 1/8" dowel rod taped to the inside of the trailing edge of the Rudder Skin, I placed a towel inside the Skin covering the Skin Stiffeners. Using Vans recommended wood bending brake I was able to bend the Skin so it just touched the Rudder's Spar. It took about 9 compressions of the Skin to accomplish this - each time it got closer to touching the Spar. During the bending of the Skin the Stiffeners did NOT do any damage to the Skin because of the towel - even though they came in contact with the Skin during the last 2 or 3 compressions. The Skin came out flat until the last 1/8" (as desired) of the trailing edge near the bottom and top Ribs and the worst was 3/8" along the trailing edge. To get the desired 1/8" radius, I took my Hand Seamer (about 2" wide) and put 6 layers of masking tape on each jaw surface for padding - so as not to dent the Skin. Placed the Hand Seamer's rear edge about 1/2" from the trailing edge and gave a gentle squeeze (a few times as required) where the radius needed to be better - making sure the Squeezer was applying EQUAL pressure on both sides of the Skin. This worked well - no dented Skin. The Wooden Brake I made was made out of a straight (in length) 2" X 8" that had been sawed in half to make 2, 2" X 4"s. The bending surfaces were "plained" with a carpenters adjustable electrical plainer to make them absolutely "smooth" and covered with Duct Tape. Hope this helps someone, Garey (Santa Monica, CA) ________________________________________________________________________________
From: "Will Allen" <will(at)flipsideaerobatics.com>
Subject: RV8 tail and mostly unfinished wings for sale
Date: Jun 28, 2008
RV8 completed tail and 15% completed wings for sale. Hoping for kit price or best reasonable offer. Usual story, no time to finish cause I=92m flying aerobatics too much ;) can give more info and pics on request. Oh, I=92m in the Seattle area. Thanks, Will Allen (425) 785-9922 will(at)flipsideaerobatics.com www.flipsideaerobatics.com Checked by AVG. 6/28/2008 7:00 AM ________________________________________________________________________________
Subject: RE:List: Audio panel
Date: Jul 03, 2008
That's what I used as well. Good unit, good price, good support. glen matejcek aerobubba(at)earthlink.net > Hi: > > I am looking for an audio panel, the round type, 2/1/4 due to lack > of space...where would be the best place to find one, hopefully a used > one. > > Cannot afford, a new one, too much for my wallet.. > > any suggestions appreciated. > > > bert > > rv6a > > This is the only one I know of, although it is not stereo. > > http://www.ps-engineering.com/pma4000.shtml ________________________________________________________________________________
Date: Jul 03, 2008
Subject: Audio panel
Subject: Places to list RV8 kit for sale?
Date: Jul 05, 2008
Can anyone guide me to the best place to advertise my tail and wing kit that I=92m trying to sell? I=92m not sure if craigslist would hit the right people. Will Allen (425) 785-9922 will(at)flipsideaerobatics.com www.flipsideaerobatics.com Checked by AVG. 10:15 AM ________________________________________________________________________________
Date: Jul 05, 2008
www.vansairforce.com _____ From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Will Allen Sent: Saturday, July 05, 2008 10:19 PM Subject: RV8-List: Places to list RV8 kit for sale? Can anyone guide me to the best place to advertise my tail and wing kit that I'm trying to sell? I'm not sure if craigslist would hit the right people. Will Allen (425) 785-9922 will(at)flipsideaerobatics.com www.flipsideaerobatics.com Checked by AVG. 10:15 AM ________________________________________________________________________________
From: "Reginald C. Smith, Sr." <smirdrv(at)hotmail.com>
Subject: RE: RV-List: Places to list RV8 kit for sale?
Date: Jul 05, 2008
Barnstormers is one of the best places to advertise... Folks from all over the country see the ads. try them: www.barnstormers.com RC. RV-6 Wings/Tail starting fuselage. From: will(at)flipsideaerobatics.comTo: rv8-list(at)matronics.com=3B rv-list@matr onics.comSubject: RV-List: Places to list RV8 kit for sale?Date: Sat=2C 5 J Can anyone guide me to the best place to advertise my tail and wing kit tha t I=92m trying to sell? I=92m not sure if craigslist would hit the right pe ople. Will Allen (425) 785-9922 will(at)flipsideaerobatics.com www.flipsideaerobatics.com _________________________________________________________________ The i=92m Talkaton. Can 30-days of conversation change the world? http://www.imtalkathon.com/?source=EML_WLH_Talkathon_ChangeWorld ________________________________________________________________________________
Subject: Re: Places to list RV8 kit for sale?
Date: Jul 05, 2008
Places to list RV8 kit for sale?Will, What exactly are you selling and what are you asking for it? If it is something I need at a great price it would be fairly easy to make the transaction. Mitch Black Olympia, WA 206-245-8960 ----- Original Message ----- From: Tony Johnson To: rv8-list(at)matronics.com Sent: Saturday, July 05, 2008 7:24 PM Subject: RE: RV8-List: Places to list RV8 kit for sale? www.vansairforce.com ------------------------------------------------------------------------- ----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Will Allen Sent: Saturday, July 05, 2008 10:19 PM To: rv8-list(at)matronics.com; rv-list(at)matronics.com Subject: RV8-List: Places to list RV8 kit for sale? Can anyone guide me to the best place to advertise my tail and wing kit that I'm trying to sell? I'm not sure if craigslist would hit the right people. Will Allen (425) 785-9922 will(at)flipsideaerobatics.com www.flipsideaerobatics.com Checked by AVG. 10:15 AM href="http://www.matronics.com/Navigator?RV8-List">http://www.matronics .com/Navigator?RV8-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jul 05, 2008
I sold mine on Barnstormers.com David Thomas From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Will Allen Sent: Saturday, July 05, 2008 7:19 PM Subject: RV8-List: Places to list RV8 kit for sale? Can anyone guide me to the best place to advertise my tail and wing kit that I'm trying to sell? I'm not sure if craigslist would hit the right people. Will Allen (425) 785-9922 will(at)flipsideaerobatics.com www.flipsideaerobatics.com Checked by AVG. 10:15 AM ________________________________________________________________________________
Date: Jul 06, 2008
Subject: Grove Streamlined Gear For RV-8...
RV Listers, Grove makes a streamlined, airfoiled landing gear for the RV-8. Saves having to use the fiberglass. They also have the brake line embedded within the gear leg. Over all, they weigh a few pounds less. Does anyone have any experience with these gear legs? What is the cost differential over the stock ones? Do they fit as good or better than stock? Should an RV-8 builder bother with the hassle of deleting the stock ones from the Van's kit and ordering these? And another historic question... Why-o-why did Van's get away from the super sweet looking swept-back, Whitman-style gear on the RV-8? The spring steel, forward facing gear on the RV-8 just look dopy... Matt ________________________________________________________________________________
Date: Jul 06, 2008
Better in every aspect except price. They probably cost about 2000$ and vans will take 500 off. Well worth it. j -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Sunday, July 06, 2008 12:08 PM Subject: RV8-List: Grove Streamlined Gear For RV-8... RV Listers, Grove makes a streamlined, airfoiled landing gear for the RV-8. Saves having to use the fiberglass. They also have the brake line embedded within the gear leg. Over all, they weigh a few pounds less. Does anyone have any experience with these gear legs? What is the cost differential over the stock ones? Do they fit as good or better than stock? Should an RV-8 builder bother with the hassle of deleting the stock ones from the Van's kit and ordering these? And another historic question... Why-o-why did Van's get away from the super sweet looking swept-back, Whitman-style gear on the RV-8? The spring steel, forward facing gear on the RV-8 just look dopy... Matt ________________________________________________________________________________
Date: Jul 07, 2008
I'm doing the Grove gear and though my plane is a long way from flying I can tell you that the groves are very nice indeed. Cost is obviously a fa ctor but I felt it was worth it. I guess only time will tell when I taxi/ take off/land the first time. Check out this entry (and subsequent others) in my kitlog for the install ation thereof:- http://www.mykitlog.com/users/display_log.php?user=jpreou&project=45& category=0&log=45580&row=150 Other builders have good websites as well, and a google search will turn up a whole lot more info for you. -- Jeff ________________________________ From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server@m atronics.com] Sent: Mon 7/7/2008 04:08 Subject: RV8-List: Grove Streamlined Gear For RV-8... RV Listers, Grove makes a streamlined, airfoiled landing gear for the RV-8. Saves ha ving to use the fiberglass. They also have the brake line embedded withi n the gear leg. Over all, they weigh a few pounds less. Does anyone have any experience with these gear legs? What is the cost d ifferential over the stock ones? Do they fit as good or better than stoc k? Should an RV-8 builder bother with the hassle of deleting the stock ones from the Van's kit and ordering these? And another historic question... Why-o-why did Van's get away from the su per sweet looking swept-back, Whitman-style gear on the RV-8? The spring steel, forward facing gear on the RV-8 just look dopy... Matt ############################################################ This e-mail message has been scanned for Viruses and Content and cleared by NetIQ MailMarshal and Symantec Antivirus ############################################################ ________________________________________________________________________________
Subject: Re: Grove Streamlined Gear For RV-8...
Date: Jul 06, 2008
Matt, I have the non-airfoil shaped Grove gear on my -8 and have about 350 hours on them so far. First of all the gear has performed flawlessly and was a very easy retrofit. I always seem to take a bit of a hit for my position but I believe you ought to strongly consider the non-airfoil gear as well. The reason being is that first, they are about six pounds lighter than the airfoil shaped gear and seventeen pounds lighter than Van's steel gear. I verified this against the steel gear that I still have in my basement (they're for sale if anyone is interested in a good deal). Second, they're less expensive than the airfoil shaped gear. And third, you really don't save much time with regard to the fiberglass. I used the fiberglass gear fairing Mark Frederick sells for the F-1 Rocket. It's a perfect fit and extremely easy to attach. You simply glue the trailing edge together and you're done. The rectangular shape of the gear automatically aligns the fiberglass fairing. If you want top and bottom intersection fairings, like most people do, you still have install them on with the airfoil shaped gear. If you make your own that's where most of the fiberglass work comes into play. The only real benefit to the airfoil shaped gear in my opinion is if your really want a polished aluminum gear. But the loss of six pound, especially up front for an -8, is pretty significant. Rick McBride http://www.mykitlog.com/rickrv8/> ----- Original Message ----- From: Jeff Preou<mailto:jeff(at)preou.com> To: rv8-list(at)matronics.com Sent: Sunday, July 06, 2008 4:40 PM Subject: RE: RV8-List: Grove Streamlined Gear For RV-8... I'm doing the Grove gear and though my plane is a long way from flying I can tell you that the groves are very nice indeed. Cost is obviously a factor but I felt it was worth it. I guess only time will tell when I taxi/take off/land the first time. Check out this entry (and subsequent others) in my kitlog for the installation thereof:- http://www.mykitlog.com/users/display_log.php?user=jpreou&project=45& category=0&log=45580&row=150<http://www.mykitlog.com/users/display_ log.php?user=jpreou&project=45&category=0&log=45580&row=150> Other builders have good websites as well, and a google search will turn up a whole lot more info for you. -- Jeff ________________________________ From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] Sent: Mon 7/7/2008 04:08 To: Jeff Preou; rv8-list(at)matronics.com Subject: RV8-List: Grove Streamlined Gear For RV-8... > RV Listers, Grove makes a streamlined, airfoiled landing gear for the RV-8. Saves having to use the fiberglass. They also have the brake line embedded within the gear leg. Over all, they weigh a few pounds less. Does anyone have any experience with these gear legs? What is the cost differential over the stock ones? Do they fit as good or better than stock? Should an RV-8 builder bother with the hassle of deleting the stock ones from the Van's kit and ordering these? And another historic question... Why-o-why did Van's get away from the super sweet looking swept-back, Whitman-style gear on the RV-8? The spring steel, forward facing gear on the RV-8 just look dopy... Matt ############################################################ This e-mail message has been scanned for Viruses and Content and cleared by NetIQ MailMarshal and Symantec Antivirus ############################################################ ________________________________________________________________________________
Date: Jul 07, 2008
Yes=2C But>> I have the airfoil gear on my 8 and they are SWEEEET. If you c an afford the difference it is worth it. And the drilled brake lines are gr eat. Al Grajek From: rickrv8(at)msn.comTo: rv8-list(at)matronics.comSubject: Re: RV8-List: Grove Streamlined Gear For RV-8...Date: Sun=2C 6 Jul 2008 17:49:04 -0400 Matt=2C I have the non-airfoil shaped Grove gear on my -8 and have about 350 hours on them so far. First of all the gear has performed flawlessly and was a v ery easy retrofit. I always seem to take a bit of a hit for my position bu t I believe you ought to strongly consider the non-airfoil gear as well. T he reason being is that first=2C they are about six pounds lighter than the airfoil shaped gear and seventeen pounds lighter than Van's steel gear. I verified this against the steel gear that I still have in my basement (the y're for sale if anyone is interested in a good deal). Second=2C they're l ess expensive than the airfoil shaped gear. And third=2C you really don't save much time with regard to the fiberglass. I used the fiberglass gear f airing Mark Frederick sells for the F-1 Rocket. It's a perfect fit and ext remely easy to attach. You simply glue the trailing edge together and you' re done. The rectangular shape of the gear automatically aligns the fiberg lass fairing. If you want top and bottom intersection fairings=2C like mos t people do=2C you still have install them on with the airfoil shaped gear. If you make your own that's where most of the fiberglass work comes into play. The only real benefit to the airfoil shaped gear in my opinion is if your really want a polished aluminum gear. But the loss of six pound=2C e specially up front for an -8=2C is pretty significant. Rick McBride http://www.mykitlog.com/rickrv8/ ----- Original Message ----- From: Jeff Preou Sent: Sunday=2C July 06=2C 2008 4:40 PM Subject: RE: RV8-List: Grove Streamlined Gear For RV-8... I'm doing the Grove gear and though my plane is a long way from flying I ca n tell you that the groves are very nice indeed. Cost is obviously a factor but I felt it was worth it. I guess only time will tell when I taxi/take o ff/land the first time. Check out this entry (and subsequent others) in my kitlog for the installation thereof:-http://www.mykitlog.com/users/display_ log.php?user=jpreou&project=45&category=0&log=45580&row=150 Other builders have good websites as well=2C and a google search will turn up a whole lot more info for you.--Jeff ________________________________From: o wner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics. com]Sent: Mon 7/7/2008 04:08To: Jeff Preou=3B rv8-list(at)matronics.comSubject : RV8-List: Grove Streamlined Gear For RV-8...--> RV8-List message posted b y: Matt Dralle RV Listers=2CGrove makes a streamlined =2C airfoiled landing gear for the RV-8. Saves having to use the fiberglas s. They also have the brake line embedded within the gear leg. Over all =2C they weigh a few pounds less.Does anyone have any experience with these gear legs? What is the cost differential over the stock ones? Do they fi t as good or better than stock?Should an RV-8 builder bother with the hassl e of deleting the stock ones from the Van's kit and ordering these?And anot her historic question... Why-o-why did Van's get away from the super sweet looking swept-back=2C Whitman-style gear on the RV-8? The spring steel=2C forward facing gear on the RV-8 just look dopy...Matt###################### ######################################This e-mail message has been scanned for Viruses and Contentand cleared by NetIQ MailMarshal and Symantec Antivi rus############################################################ ________________________________________________________________________________
Subject: Hydraulic fluid
Date: Jul 07, 2008
Subject: tail wheel
Date: Jul 07, 2008
Where do you get the single pushrod instead of the chains and springs for the RV-8 tail wheel? ________________________________________________________________________________
Date: Jul 09, 2008
Subject: Re: tail wheel
Goggle silver bullet On 7/7/08, Ron Keilin wrote: > > Where do you get the single pushrod instead of the chains and springs for > the RV-8 tail wheel? > > * > > * > > ________________________________________________________________________________
Date: Jul 09, 2008
Subject: Yahoo! Auto Response
Dear All, I am on vacation until July 21. I will be checking my e-mail but maybe not at frequent as usual. I will be in the US and can be reach via my cell phone. If you need to reach me urgently please call my mobile or call the office and talk to Kathy she knows how to reach me. Office phone +1770-631-2600 and ext 0 for Kathy. Have a great summer. Ulf Petersson ________________________________________________________________________________
Date: Jul 10, 2008
Ron, I presume that you are refering to the tailwheel steering aparatus similar to my RV8. Mine was made and sold by Terry Jantzi who I think has discontinued the business and sold it to a third party. I don't know who. If I hear of whoever is making them now, I will let you know. See you in January. Dick Martin RV8 N233M ----- Original Message ----- From: Ron Keilin To: rv8-list(at)matronics.com Sent: Monday, July 07, 2008 4:59 PM Subject: RV8-List: tail wheel Where do you get the single pushrod instead of the chains and springs for the RV-8 tail wheel? ________________________________________________________________________________
From: "Greg Hunsicker" <greg(at)furnacesafetyconsultants.com>
Subject: tail wheel
Date: Jul 10, 2008
www.fullthrottleconcepts.com This linkage works great and is oh high quality. I used Jantzi link for many years but this one has been superior for the past 3 years Greg Hunsicker RV-8 600 hrs From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of dick martin Sent: Thursday, July 10, 2008 7:46 PM Subject: Re: RV8-List: tail wheel Ron, I presume that you are refering to the tailwheel steering aparatus similar to my RV8. Mine was made and sold by Terry Jantzi who I think has discontinued the business and sold it to a third party. I don't know who. If I hear of whoever is making them now, I will let you know. See you in January. Dick Martin RV8 N233M ----- Original Message ----- From: Ron Keilin <mailto:rkeilin(at)cfl.rr.com> Sent: Monday, July 07, 2008 4:59 PM Subject: RV8-List: tail wheel Where do you get the single pushrod instead of the chains and springs for the RV-8 tail wheel? href="http://www.matronics.com/Navigator?RV8-List">http://www.matronics.com/ Navigator?RV8-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Subject: tail wheel
Date: Jul 10, 2008
www.fullthrottleconceptsonline.com From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Greg Hunsicker Sent: Thursday, July 10, 2008 8:20 PM Subject: RE: RV8-List: tail wheel www.fullthrottleconcepts.com This linkage works great and is oh high quality. I used Jantzi link for many years but this one has been superior for the past 3 years Greg Hunsicker RV-8 600 hrs From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of dick martin Sent: Thursday, July 10, 2008 7:46 PM Subject: Re: RV8-List: tail wheel Ron, I presume that you are refering to the tailwheel steering aparatus similar to my RV8. Mine was made and sold by Terry Jantzi who I think has discontinued the business and sold it to a third party. I don't know who. If I hear of whoever is making them now, I will let you know. See you in January. Dick Martin RV8 N233M ----- Original Message ----- From: Ron Keilin <mailto:rkeilin(at)cfl.rr.com> Sent: Monday, July 07, 2008 4:59 PM Subject: RV8-List: tail wheel Where do you get the single pushrod instead of the chains and springs for the RV-8 tail wheel? href="http://www.matronics.com/Navigator?RV8-List">http://www.matronics.com/ Navigator?RV8-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c - The RV8-List Email Forum - --> http://www.matronics.com/Navigator?RV8-List - MATRONICS WEB FORUMS - --> http://forums.matronics.com - List Contribution Web Site - Thank you for your generous support! -Matt Dralle, List Admin. --> http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 11, 2008
Subject: Tail Wheel Steering
I think this is what you are looking for: http://www.rivethead-aero.com/web1-1_012.htm Martin Sobel RV-8 Wings N61MV 7040 Treymore Court Sarasota, FL 34243-5500 941-359-8693 941-539-4806 (Cell) 941-355-7732 (Fax) ________________________________________________________________________________
Subject: Pitot Plumbing
Date: Jul 11, 2008
Stan Loer stazel(at)cpros.com I'm looking for suggestions for installing an extra pitot line in my left Q/B wing for input to the Dynon AOA system. I'm sure I can figure something out, but suspect it's been done more than once already. Just haven't seen anything specifically addressing this on builders' web sites. ________________________________________________________________________________
From: "Paul Wilson" <paul(at)wilsonnet.flyer.co.uk>
Subject: Parts for sale
Date: Jul 15, 2008
Hello listers, I spotted these RV8 parts for sale in the UK on the Afors web site today, they may do someone some good. Paul http://www.afors.com/index.php?page=adview&adid=9873&imid=0 http://www.afors.com/index.php?page=adview&adid=9874&imid=0 ________________________________________________________________________________
Date: Jul 17, 2008
Subject: 10:1 Compression / IO-360 200 HP
Does anyone have any experience with 10:1 compression in a IO-360 200 HP engine? * What are the down sides of running 10:1 in that engine? * What is the HP gain? * What is the impact to TBO? * What is the impact to reliability? If you've done it, would you do it again, or just go with the standard 8.7:1 compression? Matt Dralle RV-8 #82880 ________________________________________________________________________________
Date: Jul 17, 2008
Matt, I think I can answer your questions. * The down side to running 10:1 pistons in the 200 hp IO-360 is the increase in cylinder pressures and bearing loads, particularly the rod bearings. * We see an increase of approximately 6-8 HP on our dynamometer. * You can just about count on a 1,000 hour TBO with 10:1 pistons * See last answer! TBO's are subjective and more dependant on operator input, maintenance and frequency of use, or lack thereof. Hope this helps, Allen BPE, Inc. -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Thursday, July 17, 2008 10:56 AM Subject: RV8-List: 10:1 Compression / IO-360 200 HP Does anyone have any experience with 10:1 compression in a IO-360 200 HP engine? * What are the down sides of running 10:1 in that engine? * What is the HP gain? * What is the impact to TBO? * What is the impact to reliability? If you've done it, would you do it again, or just go with the standard 8.7:1 compression? Matt Dralle RV-8 #82880 ________________________________________________________________________________
Date: Jul 20, 2008
Subject: RV-8 "Tall-man" Option...
Fellow Listers, What exactly does the RV-8 "Tall-man" option entail? What modifications are made to the seat, weldment, etc? I'm not finding any mention of it on the plans. If you order the Tall-man option with the QB kit, can you opt for the "Regular-man" option at build time? Knowing nothing about what it actually is, I assume it pushes the weldment back some allowing you to mount the pilot's seat further aft. While I am a "Tall-man", my preference would actually be to increase the pilot's seat back recline amount by moving the weldment back, but leaving the bottom of the seat in the normal position. Is this possible? Does anyone have any detailed pictures of what the Tall-man option looks like and specifically how it differs from the Regular-man option? Thanks! Matt Dralle RV-8 #82880 ________________________________________________________________________________
Date: Jul 20, 2008
Matt, The "Tall-man" option is exactly what you want then. All it is, is a different seat back weldment that lets the seat back recline further than stock. The bottom of the seat remains in the standard location. Guy -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Sunday, July 20, 2008 10:55 AM Subject: RV8-List: RV-8 "Tall-man" Option... Fellow Listers, What exactly does the RV-8 "Tall-man" option entail? What modifications are made to the seat, weldment, etc? I'm not finding any mention of it on the plans. If you order the Tall-man option with the QB kit, can you opt for the "Regular-man" option at build time? Knowing nothing about what it actually is, I assume it pushes the weldment back some allowing you to mount the pilot's seat further aft. While I am a "Tall-man", my preference would actually be to increase the pilot's seat back recline amount by moving the weldment back, but leaving the bottom of the seat in the normal position. Is this possible? Does anyone have any detailed pictures of what the Tall-man option looks like and specifically how it differs from the Regular-man option? Thanks! Matt Dralle RV-8 #82880 ________________________________________________________________________________
Date: Jul 20, 2008
Awesome! How perfect! Thanks! Matt At 10:37 AM 7/20/2008 Sunday, you wrote: > >Matt, > >The "Tall-man" option is exactly what you want then. All it is, is a >different seat back weldment that lets the seat back recline further than >stock. The bottom of the seat remains in the standard location. > >Guy > >-----Original Message----- >From: owner-rv8-list-server(at)matronics.com >[mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Matt Dralle >Sent: Sunday, July 20, 2008 10:55 AM >To: rv8-list(at)matronics.com >Subject: RV8-List: RV-8 "Tall-man" Option... > > >Fellow Listers, > >What exactly does the RV-8 "Tall-man" option entail? What modifications are >made to the seat, weldment, etc? I'm not finding any mention of it on the >plans. If you order the Tall-man option with the QB kit, can you opt for >the "Regular-man" option at build time? > >Knowing nothing about what it actually is, I assume it pushes the weldment >back some allowing you to mount the pilot's seat further aft. While I am a >"Tall-man", my preference would actually be to increase the pilot's seat >back recline amount by moving the weldment back, but leaving the bottom of >the seat in the normal position. Is this possible? > >Does anyone have any detailed pictures of what the Tall-man option looks >like and specifically how it differs from the Regular-man option? > >Thanks! > >Matt Dralle >RV-8 #82880 > > Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jul 20, 2008
Matt It bolts on using the same holes as the regular weldment. It reclines the seat about another inch=2C slightly reducing the rear seat passengers space . Works great for me and I'm 5'11" Paul
October 20, 2007 - July 20, 2008
RV8-Archive.digest.vol-al
