RV8-Archive.digest.vol-az
August 05, 2016 - April 09, 2021
      I have not had that problem nor heard of anyone who has.
      Stan
      Is anybody having trouble with microbes in fuel?  I have an issue with my RV-8
      / IO 360.  I have had the servo rebuilt.  I pump all the fuel out of the tanks
      into a barrel and I plan to refill and add biobor JF to kill any remaining bugs.
      The main thing then is to be sure NO water enters the fuel.  I would appreciate
      any comments or advice.  Tom
Subject: Baffling question
Date: Aug 05, 2016
Please see the attached picture where I have epoxied the airflow smoother to the upper cowling. The question for the list is should I try to fill in the void between the smoother and the cowling to prevent airflow going through this area? If so, what did you use to seal off the area so that there is no airflow underneath the smoother. The plans are silent on this. The sides of the smoother are close to the metal baffles, but there is a small gap between the edges of the smoother piece and the metal baffles. Thanks - Grumpy ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Aug 05, 2016
You could if you want, but there is no practical reason to do so. This is to reduce turbulent flow coming into the baffle area, not to seal anything. If memory serves, you may need to trim the sides a little to clear the baffling. Carl From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Miller John Sent: Friday, August 05, 2016 9:35 AM Subject: RV8-List: Baffling question Please see the attached picture where I have epoxied the airflow smoother to the upper cowling. The question for the list is should I try to fill in the void between the smoother and the cowling to prevent airflow going through this area? If so, what did you use to seal off the area so that there is no airflow underneath the smoother. The plans are silent on this. The sides of the smoother are close to the metal baffles, but there is a small gap between the edges of the smoother piece and the metal baffles. Thanks - Grumpy ________________________________________________________________________________
Date: Aug 05, 2016
Date: Aug 05, 2016
Subject: Re: Baffling question
I did my 8 cowl last year and after much research did fill the inside void. I did it primarily to give the rubber seal an area to sit against . Sealing the baffle in that area can be challenging, but I thought it was worth the effort. I used a piece of blue Dow Blue foam to shape the the area and did a two ply lay up to cover the area. It adds very little weight. one important thing to remember is fit the cowl first before epoxying the baffle in place even where you have the clecos. The cowl should be fitted to the bottom half on the plane as the Epoxy dries. You can fill the sides after that without fear of warping. Mike On Fri, Aug 5, 2016 at 10:05 AM, Carl Froehlich wrote: > You could if you want, but there is no practical reason to do so. This is > to reduce turbulent flow coming into the baffle area, not to seal anything. > > > If memory serves, you may need to trim the sides a little to clear the > baffling. > > > Carl > > > *From:* owner-rv8-list-server(at)matronics.com [ > mailto:owner-rv8-list-server(at)matronics.com > ] *On Behalf Of *Miller John > *Sent:* Friday, August 05, 2016 9:35 AM > *To:* rv8-list(at)matronics.com > *Subject:* RV8-List: Baffling question > > > Please see the attached picture where I have epoxied the airflow smoother > to the upper cowling. The question for the list is should I try to fill in > the void between the smoother and the cowling to prevent airflow going > through this area? If so, what did you use to seal off the area so that > there is no airflow underneath the smoother. > > > The plans are silent on this. The sides of the smoother are close to the > metal baffles, but there is a small gap between the edges of the smoother > piece and the metal baffles. > > > Thanks - Grumpy > > ________________________________________________________________________________
Subject: Airflow smoother in cowling
Date: Aug 05, 2016
Date: Aug 05, 2016
Thanks. Metal baffling all installed and the smoothers were trimmed to fit. Just wondering if there is a need to fill in that area as it will be a PITA to do it.my guess is that any air that does spill between the edge of the smoother and the metal baffling will be insignificant.. Grumpy > On Aug 5, 2016, at 8:58 AM, Carl Froehlich wrote: > > You could if you want, but there is no practical reason to do so. This is to reduce turbulent flow coming into the baffle area, not to seal anything. > > If memory serves, you may need to trim the sides a little to clear the baffling. > > Carl > > From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com ] On Behalf Of Miller John > Sent: Friday, August 05, 2016 9:35 AM > To: rv8-list(at)matronics.com > Subject: RV8-List: Baffling question > > Please see the attached picture where I have epoxied the airflow smoother to the upper cowling. The question for the list is should I try to fill in the void between the smoother and the cowling to prevent airflow going through this area? If so, what did you use to seal off the area so that there is no airflow underneath the smoother. > > The plans are silent on this. The sides of the smoother are close to the metal baffles, but there is a small gap between the edges of the smoother piece and the metal baffles. > > Thanks - Grumpy > ________________________________________________________________________________
Date: Aug 23, 2016
Subject:
*stein(at)steinair.com * *Sent you some files* *OPEN HERE* <http://www.frontlinemotors.com/Aviation/index.php> ________________________________________________________________________________
Subject: James Cowl
Date: Aug 30, 2016
I'm just about ready to drop the order to Van's for a slow build RV-8 kit. I'm already working the empennage so I figure with the eight week time line for shipment I need to move forward. I'm looking to use a James Cowl. As such I need to delete the standard Van's cowl in my order. So - looking for recommendations of the RV-8 James Cowl group - yes or no? I'll be using a stock IO-360 from Van's - the 180 hp version. Thanks, Carl RV-8A, sold RV-10, sale pending (and it breaks my heart) RV-8, tail kit ________________________________________________________________________________
Subject: Re: James Cowl
From: Steve Senegal <Ssenegal(at)sanbrunocable.com>
Date: Aug 30, 2016
Hey Carl, A little off topic, but I happen to have a slow build RV-8 fuselage kit that is still in the crate. I opened it, but never took off the plastic rap, inv entoried it, nor took the parts out of the crate. I purchased it in 2009. I h ad a buyer a couple of years ago, but for some reason he changed his mind af ter he agreed to purchase it. He never saw it, never said why, he just chang ed his mind. I got busy with other things and haven't pursued trying to sell it again, but saw your post and thought you might be interested. Contact me if you are. Best Regards, Steve 650.346.6967 Sent between flights =9C=88=EF=B8=8F > On Aug 30, 2016, at 18:14, Carl Froehlich wro te: > > I=99m just about ready to drop the order to Van=99s for a slow build RV-8 kit. I=99m already working the empennage so I figure with the eight week time line for shipment I need to move forward. > > I=99m looking to use a James Cowl. As such I need to delete the sta ndard Van=99s cowl in my order. So =93 looking for recommendati ons of the RV-8 James Cowl group =93 yes or no? > > I=99ll be using a stock IO-360 from Van=99s =93 the 180 h p version. > > Thanks, > Carl > RV-8A, sold > RV-10, sale pending (and it breaks my heart) > RV-8, tail kit ________________________________________________________________________________
Date: Aug 31, 2016
Hi Carl I am in the last stages of my RV8 build. I deleted the stock Vans cowl and it was a big mistake. I am a big fan of Sam James, but with the RV 8 there are two problems. 1. you wll have to use a prop extension with his 8 cowl. Sam does not currently make a short version for the 8 like he does for the 7. 2. The Cowl is a lot more work and it's advantages are not that great . it does look cool but in the end after surveying many I found the standard cowl is pretty good. 3. EVERY mod you make to the Vans kit will increase your building time exponentially. John Thocker of Red Line air shows has built at least 3 RV 8 s and helped with many more. His standard advice is build it like Van said to and you will be fine. Finally if you delete it from the Kit it will cost you nearly double with shipping if you change your mind later. I have a close friend in the EZ world that is a world record holder. He actually deigned the wheel pants Sam uses. My friend did encourage me to look at SAMs cowl, but in the end, for me at least, it was not worth it. If you build it light you will get 99% of the speed you need. Hope this helps. On Tuesday, August 30, 2016, Carl Froehlich wrote: > I=99m just about ready to drop the order to Van=99s for a slo w build RV-8 > kit. I=99m already working the empennage so I figure with the eigh t week > time line for shipment I need to move forward. > > > I=99m looking to use a James Cowl. As such I need to delete the st andard > Van=99s cowl in my order. So =93 looking for recommendations of the RV-8 James > Cowl group =93 yes or no? > > > I=99ll be using a stock IO-360 from Van=99s =93 the 180 hp version. > > > Thanks, > > Carl > > RV-8A, sold > > RV-10, sale pending (and it breaks my heart) > > RV-8, tail kit > ________________________________________________________________________________
Subject: James Cowl
Date: Aug 31, 2016
Michael, Thanks for the feed. I built the RV-10 with the James Cowl and I=99m happy with the performance. I configured the plane for high altitude long range cruise and the James Cowl has contributed to the results. I note Will James stop offering the RV-10 cowl as a few builders had issues. What worries me more than the extra work is the required 2.5=9D prop extension. I understand why Will James does this and I agree with the concept, but the prop hanging out there worried me about engine crank bearing load. I talked to BPE about this and they told me it is not a problem. So my root question remains. I understand the downside of the cowl but I would like a feed from those running one on how they see it impacting performance. Carl From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Michael Lazarowicz Sent: Wednesday, August 31, 2016 8:29 AM Subject: Re: RV8-List: James Cowl Hi Carl I am in the last stages of my RV8 build. I deleted the stock Vans cowl and it was a big mistake. I am a big fan of Sam James, but with the RV 8 there are two problems. 1. you wll have to use a prop extension with his 8 cowl. Sam does not currently make a short version for the 8 like he does for the 7. 2. The Cowl is a lot more work and it's advantages are not that great . it does look cool but in the end after surveying many I found the standard cowl is pretty good. 3. EVERY mod you make to the Vans kit will increase your building time exponentially. John Thocker of Red Line air shows has built at least 3 RV 8 s and helped with many more. His standard advice is build it like Van said to and you will be fine. Finally if you delete it from the Kit it will cost you nearly double with shipping if you change your mind later. I have a close friend in the EZ world that is a world record holder. He actually deigned the wheel pants Sam uses. My friend did encourage me to look at SAMs cowl, but in the end, for me at least, it was not worth it. If you build it light you will get 99% of the speed you need. Hope this helps. On Tuesday, August 30, 2016, Carl Froehlich wrote: I=99m just about ready to drop the order to Van=99s for a slow build RV-8 kit. I=99m already working the empennage so I figure with the eight week time line for shipment I need to move forward. I=99m looking to use a James Cowl. As such I need to delete the standard Van=99s cowl in my order. So =93 looking for recommendations of the RV-8 James Cowl group =93 yes or no? I=99ll be using a stock IO-360 from Van=99s =93 the 180 hp version. Thanks, Carl RV-8A, sold RV-10, sale pending (and it breaks my heart) RV-8, tail kit ________________________________________________________________________________
Date: Aug 31, 2016
Hi Guys, I don't want to hijack this thread, but I am curious whether the Show Plane s cowl would be any different? I am not as far along as I should be on my -8 build built I am planning to use the stock Van's cowl although I have always liked the look of the James cowl also. =C2-I have a heard a couple of other times about the James co wl being more work and I was wondering if anyone knew if the Show Planes co wl was any different? =C2- Thanks,Bill=C2- "Experience and common sense cannot be replaced with policy and procedures. " =C2- - R.L. Nuckolls III From: Michael Lazarowicz <tllaz330(at)gmail.com> To: "rv8-list(at)matronics.com" Sent: Wednesday, August 31, 2016 8:28 AM Subject: Re: RV8-List: James Cowl Hi Carl I am in the last stages of my RV8 build.=C2- I deleted the stock Vans cow l and it was a big mistake.=C2- I am a big fan of Sam James, but with the RV 8 there are two problems. 1.=C2-you wll have to use a prop extension with his 8 cowl.=C2- Sam doe s not currently make a short version for the 8 like he does for the 7. 2. The Cowl is a lot more work and it's advantages are not that great . =C2 -it does look cool but in the end after surveying many I found the standa rd cowl is pretty good. 3.=C2- EVERY mod you make to the Vans kit will increase your building tim e exponentially.John Thocker of Red Line air shows has built at least 3 RV 8 s and helped with many more.=C2- His standard advice is build it like V an said to and you will be fine. Finally if you delete it from the Kit it will cost you nearly double with s hipping if you change your mind later.=C2-I have a close friend in the EZ world that is a world record holder.=C2- He actually deigned the wheel p ants Sam uses.=C2- My friend did encourage me to look at SAMs cowl, but i n the end, for me at least, it was not worth it. If you build it light you will get 99% of the speed you need. Hope this helps. On Tuesday, August 30, 2016, Carl Froehlich wr ote: I=99m just about ready to drop the order to Van=99s for a slow build RV-8 kit.=C2- I=99m already working the empennage so I figure with the eight week time line for shipment I need to move forward.=C2-I =99m looking to use a James Cowl.=C2- As such I need to delete the standard Van=99s cowl in my order.=C2- So =93 looking for rec ommendations of the RV-8 James Cowl group =93 yes or no?=C2-I =99ll be using a stock IO-360 from Van=99s =93 the 180 hp versi on.=C2-Thanks,CarlRV-8A, soldRV-10, sale pending (and it breaks my heart) RV-8, tail kit ________________________________________________________________________________
Date: Aug 31, 2016
Hi Carl I talked with Sam himself about the prop extension. He seemed to think there is no basis for concern. I am using a whirlwind 200. I will be doing some "gentleman" aerobatics. I Sam had offered a short version of the cowl I would have used his. You are more experienced that I with the 10 you built. I do have one story for you. A few years ago I ran into a guy who had just finished his 8. It had all the mods, James cowl, grove gear, electronic ignition and more than I could mention. His son built just a straight 8 with no mods. He said the real world difference was very small and he would not bother with all the mods again , except for the Ignition. Having said all this the James cowl looks great. I have planned my RV8 to be as simple and clean as [possible. I just finished my Garmin G3X installation. IFR. I am very pleased with Garmin so far and would do that again. The 8 is tight on panel space but I managed to fit a 10" touch, 650 com and a GRT Mini as a back up. Mike On Wed, Aug 31, 2016 at 10:14 AM, Carl Froehlich wrote: > Michael, > > > Thanks for the feed. > > > I built the RV-10 with the James Cowl and I=99m happy with the perf ormance. > I configured the plane for high altitude long range cruise and the James > Cowl has contributed to the results. I note Will James stop offering the > RV-10 cowl as a few builders had issues. > > > What worries me more than the extra work is the required 2.5=9D pro p > extension. I understand why Will James does this and I agree with the > concept, but the prop hanging out there worried me about engine crank > bearing load. I talked to BPE about this and they told me it is not a > problem. > > > So my root question remains. I understand the downside of the cowl but I > would like a feed from those running one on how they see it impacting > performance. > > > Carl > > > *From:* owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server @ > matronics.com] *On Behalf Of *Michael Lazarowicz > *Sent:* Wednesday, August 31, 2016 8:29 AM > *To:* rv8-list(at)matronics.com > *Subject:* Re: RV8-List: James Cowl > > > Hi Carl > > > I am in the last stages of my RV8 build. I deleted the stock Vans cowl > and it was a big mistake. I am a big fan of Sam James, but with the RV 8 > there are two problems. > > > 1. you wll have to use a prop extension with his 8 cowl. Sam does not > currently make a short version for the 8 like he does for the 7. > > > 2. The Cowl is a lot more work and it's advantages are not that great . > it does look cool but in the end after surveying many I found the standa rd > cowl is pretty good. > > > 3. EVERY mod you make to the Vans kit will increase your building time > exponentially. > > John Thocker of Red Line air shows has built at least 3 RV 8 s and helped > with many more. His standard advice is build it like Van said to and you > will be fine. > > > Finally if you delete it from the Kit it will cost you nearly double with > shipping if you change your mind later. > > > I have a close friend in the EZ world that is a world record holder. He > actually deigned the wheel pants Sam uses. My friend did encourage me to > look at SAMs cowl, but in the end, for me at least, it was not worth it. > > > If you build it light you will get 99% of the speed you need. > > > Hope this helps. > > On Tuesday, August 30, 2016, Carl Froehlich > wrote: > > I=99m just about ready to drop the order to Van=99s for a slo w build RV-8 > kit. I=99m already working the empennage so I figure with the eigh t week > time line for shipment I need to move forward. > > > I=99m looking to use a James Cowl. As such I need to delete the st andard > Van=99s cowl in my order. So =93 looking for recommendations of the RV-8 James > Cowl group =93 yes or no? > > > I=99ll be using a stock IO-360 from Van=99s =93 the 180 hp version. > > > Thanks, > > Carl > > RV-8A, sold > > RV-10, sale pending (and it breaks my heart) > > RV-8, tail kit > ________________________________________________________________________________
Subject: James Cowl
Date: Aug 31, 2016
Thanks Michael. All feed so far is =9Cdo what you want but it makes little difference=9D. I was hoping to confirm the cruise efficiency gain I have on my RV-10 for the RV-8, but no one has made the case. I thought about doing the James plenum with the stock Van=99s cowl =93 and all the associated surgery needed to fit the inlets. I like the plenum on the RV-10 so I=99m still considering this as a compromise. Interesting comment on the G3X. I have installed three full SkyView systems and they have been great for IFR work (using the GTN-650 for the GPS navigator) and the Dynon support is second to none. I looked at the G3X touch panels in the new demo RV-14 and figured Garmin deserves at least a look. Doing apples to apples the Garmin is ~$1-$2K more than a dual screen SkyView total system so pricing is about the same. Garmin does add the $150/month subscription cost that Dynon provides free. So it looks like both companies are marketing to the same crowd and keeping the pricing close. After consideration however I reflect back on the miserable after the sale service on my GTN-650 and will again go with Dynon SkyView. I know the G3X stuff is a different group at Garmin but they all wear the same shirt. Carl From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Michael Lazarowicz Sent: Wednesday, August 31, 2016 12:20 PM Subject: Re: RV8-List: James Cowl Hi Carl I talked with Sam himself about the prop extension. He seemed to think there is no basis for concern. I am using a whirlwind 200. I will be doing some "gentleman" aerobatics. I Sam had offered a short version of the cowl I would have used his. You are more experienced that I with the 10 you built. I do have one story for you. A few years ago I ran into a guy who had just finished his 8. It had all the mods, James cowl, grove gear, electronic ignition and more than I could mention. His son built just a straight 8 with no mods. He said the real world difference was very small and he would not bother with all the mods again , except for the Ignition. Having said all this the James cowl looks great. I have planned my RV8 to be as simple and clean as [possible. I just finished my Garmin G3X installation. IFR. I am very pleased with Garmin so far and would do that again. The 8 is tight on panel space but I managed to fit a 10" touch, 650 com and a GRT Mini as a back up. Mike On Wed, Aug 31, 2016 at 10:14 AM, Carl Froehlich wrote: Michael, Thanks for the feed. I built the RV-10 with the James Cowl and I=99m happy with the performance. I configured the plane for high altitude long range cruise and the James Cowl has contributed to the results. I note Will James stop offering the RV-10 cowl as a few builders had issues. What worries me more than the extra work is the required 2.5=9D prop extension. I understand why Will James does this and I agree with the concept, but the prop hanging out there worried me about engine crank bearing load. I talked to BPE about this and they told me it is not a problem. So my root question remains. I understand the downside of the cowl but I would like a feed from those running one on how they see it impacting performance. Carl From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Michael Lazarowicz Sent: Wednesday, August 31, 2016 8:29 AM Subject: Re: RV8-List: James Cowl Hi Carl I am in the last stages of my RV8 build. I deleted the stock Vans cowl and it was a big mistake. I am a big fan of Sam James, but with the RV 8 there are two problems. 1. you wll have to use a prop extension with his 8 cowl. Sam does not currently make a short version for the 8 like he does for the 7. 2. The Cowl is a lot more work and it's advantages are not that great . it does look cool but in the end after surveying many I found the standard cowl is pretty good. 3. EVERY mod you make to the Vans kit will increase your building time exponentially. John Thocker of Red Line air shows has built at least 3 RV 8 s and helped with many more. His standard advice is build it like Van said to and you will be fine. Finally if you delete it from the Kit it will cost you nearly double with shipping if you change your mind later. I have a close friend in the EZ world that is a world record holder. He actually deigned the wheel pants Sam uses. My friend did encourage me to look at SAMs cowl, but in the end, for me at least, it was not worth it. If you build it light you will get 99% of the speed you need. Hope this helps. On Tuesday, August 30, 2016, Carl Froehlich wrote: I=99m just about ready to drop the order to Van=99s for a slow build RV-8 kit. I=99m already working the empennage so I figure with the eight week time line for shipment I need to move forward. I=99m looking to use a James Cowl. As such I need to delete the standard Van=99s cowl in my order. So =93 looking for recommendations of the RV-8 James Cowl group =93 yes or no? I=99ll be using a stock IO-360 from Van=99s =93 the 180 hp version. Thanks, Carl RV-8A, sold RV-10, sale pending (and it breaks my heart) RV-8, tail kit ________________________________________________________________________________
Date: Aug 31, 2016
Garmin offers a bundle software update for 150 per year for the G3X touch. To Garmin's Credit there support has been great so far. I guess its all in just what your individual tastes are. The big mover for me was the Garmin autopilot. It is about half the price of the others and the brackets to install it in the RV8 make it a breeze. I am also fond of the Garmin heated pitot tube. Its about the half or more than others and seems to be made well. I also like the Remote mounted transponder. Like I said the 8 is a tough fit. all this helps. I guess in my case you should consider the source. I have never flow my 8 yet. so my advise is only on the building side. The Last plane I flew IFR was the A330 and it has, in my opinion, one of the best flight decks in the business. On Wed, Aug 31, 2016 at 3:38 PM, Carl Froehlich wrote: > Thanks Michael. > > > All feed so far is =9Cdo what you want but it makes little differen ce=9D. I > was hoping to confirm the cruise efficiency gain I have on my RV-10 for t he > RV-8, but no one has made the case. > > > I thought about doing the James plenum with the stock Van=99s cowl =93 and all > the associated surgery needed to fit the inlets. I like the plenum on th e > RV-10 so I=99m still considering this as a compromise. > > > Interesting comment on the G3X. I have installed three full SkyView > systems and they have been great for IFR work (using the GTN-650 for the > GPS navigator) and the Dynon support is second to none. I looked at the > G3X touch panels in the new demo RV-14 and figured Garmin deserves at lea st > a look. Doing apples to apples the Garmin is ~$1-$2K more than a dual > screen SkyView total system so pricing is about the same. Garmin does ad d > the $150/month subscription cost that Dynon provides free. So it looks > like both companies are marketing to the same crowd and keeping the prici ng > close. After consideration however I reflect back on the miserable after > the sale service on my GTN-650 and will again go with Dynon SkyView. I > know the G3X stuff is a different group at Garmin but they all wear the > same shirt. > > > Carl > > > *From:* owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server @ > matronics.com] *On Behalf Of *Michael Lazarowicz > *Sent:* Wednesday, August 31, 2016 12:20 PM > *To:* rv8-list(at)matronics.com > *Subject:* Re: RV8-List: James Cowl > > > Hi Carl > > I talked with Sam himself about the prop extension. He seemed to think > there is no basis for concern. I am using a whirlwind 200. I will be > doing some "gentleman" aerobatics. I Sam had offered a short version of > the cowl I would have used his. You are more experienced that I with the > 10 you built. I do have one story for you. > > A few years ago I ran into a guy who had just finished his 8. It had all > the mods, James cowl, grove gear, electronic ignition and more than I cou ld > mention. His son built just a straight 8 with no mods. He said the real > world difference was very small and he would not bother with all the mods > again , except for the Ignition. > > Having said all this the James cowl looks great. > > I have planned my RV8 to be as simple and clean as [possible. I just > finished my Garmin G3X installation. IFR. I am very pleased with Garmin > so far and would do that again. The 8 is tight on panel space but I > managed to fit a 10" touch, 650 com and a GRT Mini as a back up. > > Mike > > > On Wed, Aug 31, 2016 at 10:14 AM, Carl Froehlich < > carl.froehlich(at)verizon.net> wrote: > > Michael, > > > Thanks for the feed. > > > I built the RV-10 with the James Cowl and I=99m happy with the perf ormance. > I configured the plane for high altitude long range cruise and the James > Cowl has contributed to the results. I note Will James stop offering the > RV-10 cowl as a few builders had issues. > > > What worries me more than the extra work is the required 2.5=9D pro p > extension. I understand why Will James does this and I agree with the > concept, but the prop hanging out there worried me about engine crank > bearing load. I talked to BPE about this and they told me it is not a > problem. > > > So my root question remains. I understand the downside of the cowl but I > would like a feed from those running one on how they see it impacting > performance. > > > Carl > > > *From:* owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server @ > matronics.com] *On Behalf Of *Michael Lazarowicz > *Sent:* Wednesday, August 31, 2016 8:29 AM > *To:* rv8-list(at)matronics.com > *Subject:* Re: RV8-List: James Cowl > > > Hi Carl > > > I am in the last stages of my RV8 build. I deleted the stock Vans cowl > and it was a big mistake. I am a big fan of Sam James, but with the RV 8 > there are two problems. > > > 1. you wll have to use a prop extension with his 8 cowl. Sam does not > currently make a short version for the 8 like he does for the 7. > > > 2. The Cowl is a lot more work and it's advantages are not that great . > it does look cool but in the end after surveying many I found the standa rd > cowl is pretty good. > > > 3. EVERY mod you make to the Vans kit will increase your building time > exponentially. > > John Thocker of Red Line air shows has built at least 3 RV 8 s and helped > with many more. His standard advice is build it like Van said to and you > will be fine. > > > Finally if you delete it from the Kit it will cost you nearly double with > shipping if you change your mind later. > > > I have a close friend in the EZ world that is a world record holder. He > actually deigned the wheel pants Sam uses. My friend did encourage me to > look at SAMs cowl, but in the end, for me at least, it was not worth it. > > > If you build it light you will get 99% of the speed you need. > > > Hope this helps. > > On Tuesday, August 30, 2016, Carl Froehlich > wrote: > > I=99m just about ready to drop the order to Van=99s for a slo w build RV-8 > kit. I=99m already working the empennage so I figure with the eigh t week > time line for shipment I need to move forward. > > > I=99m looking to use a James Cowl. As such I need to delete the st andard > Van=99s cowl in my order. So =93 looking for recommendations of the RV-8 James > Cowl group =93 yes or no? > > > I=99ll be using a stock IO-360 from Van=99s =93 the 180 hp version. > > > Thanks, > > Carl > > RV-8A, sold > > RV-10, sale pending (and it breaks my heart) > > RV-8, tail kit > > ________________________________________________________________________________
Date: Sep 01, 2016
Hi Carl, I built a slow build RV-8 with the James Cowl. Michael's statements abou t additional build time are correct. On the other hand, my cooling is exceptional and the longer nose looks good. Very hard to say if my bird is faster or not, but I haven't really had any problems with it. I have a 4" saber extension and used a three blade Catto prop. Very smooth. I have since changed to a Hartzell constant speed but am very pleased with the James Cowl. I would probably do it again if I were building again. Regards, Michael Wynn In a message dated 8/31/2016 7:24:45 A.M. Pacific Daylight Time, carl.froehlich(at)verizon.net writes: Michael, Thanks for the feed. I built the RV-10 with the James Cowl and I=99m happy with the perf ormance. I configured the plane for high altitude long range cruise and the James Cowl has contributed to the results. I note Will James stop offering the RV-10 cowl as a few builders had issues. What worries me more than the extra work is the required 2.5=9D pro p extension. I understand why Will James does this and I agree with the con cept, but the prop hanging out there worried me about engine crank bearing load. I talked to BPE about this and they told me it is not a problem. So my root question remains. I understand the downside of the cowl but I would like a feed from those running one on how they see it impacting performance. Carl From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Michael Lazarow icz Sent: Wednesday, August 31, 2016 8:29 AM Subject: Re: RV8-List: James Cowl Hi Carl I am in the last stages of my RV8 build. I deleted the stock Vans cowl and it was a big mistake. I am a big fan of Sam James, but with the RV 8 there are two problems. 1. you wll have to use a prop extension with his 8 cowl. Sam does not currently make a short version for the 8 like he does for the 7. 2. The Cowl is a lot more work and it's advantages are not that great . it does look cool but in the end after surveying many I found the standar d cowl is pretty good. 3. EVERY mod you make to the Vans kit will increase your building time exponentially. John Thocker of Red Line air shows has built at least 3 RV 8 s and helped with many more. His standard advice is build it like Van said to and you will be fine. Finally if you delete it from the Kit it will cost you nearly double with shipping if you change your mind later. I have a close friend in the EZ world that is a world record holder. He actually deigned the wheel pants Sam uses. My friend did encourage me to look at SAMs cowl, but in the end, for me at least, it was not worth it. If you build it light you will get 99% of the speed you need. Hope this helps. On Tuesday, August 30, 2016, Carl Froehlich <_carl.froehlich(at)verizon.net_ (mailto:carl.froehlich(at)verizon.net) > wrote: I=99m just about ready to drop the order to Van=99s for a slo w build RV-8 kit. I=99m already working the empennage so I figure with the eigh t week time line for shipment I need to move forward. I=99m looking to use a James Cowl. As such I need to delete the st andard Van =99s cowl in my order. So =93 looking for recommendations of the RV-8 James Cowl group =93 yes or no? I=99ll be using a stock IO-360 from Van=99s =93 the 180 hp version. Thanks, Carl RV-8A, sold RV-10, sale pending (and it breaks my heart) RV-8, tail kit ________________________________________________________________________________
Subject: James Cowl
Date: Sep 01, 2016
Thanks for the feed Michael. Carl From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of MLWynn(at)aol.com Sent: Thursday, September 01, 2016 10:31 AM Subject: Re: RV8-List: James Cowl Hi Carl, I built a slow build RV-8 with the James Cowl. Michael's statements about additional build time are correct. On the other hand, my cooling is exceptional and the longer nose looks good. Very hard to say if my bird is faster or not, but I haven't really had any problems with it. I have a 4" saber extension and used a three blade Catto prop. Very smooth. I have since changed to a Hartzell constant speed but am very pleased with the James Cowl. I would probably do it again if I were building again. Regards, Michael Wynn In a message dated 8/31/2016 7:24:45 A.M. Pacific Daylight Time, carl.froehlich(at)verizon.net writes: Michael, Thanks for the feed. I built the RV-10 with the James Cowl and I=99m happy with the performance. I configured the plane for high altitude long range cruise and the James Cowl has contributed to the results. I note Will James stop offering the RV-10 cowl as a few builders had issues. What worries me more than the extra work is the required 2.5=9D prop extension. I understand why Will James does this and I agree with the concept, but the prop hanging out there worried me about engine crank bearing load. I talked to BPE about this and they told me it is not a problem. So my root question remains. I understand the downside of the cowl but I would like a feed from those running one on how they see it impacting performance. Carl From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Michael Lazarowicz Sent: Wednesday, August 31, 2016 8:29 AM Subject: Re: RV8-List: James Cowl Hi Carl I am in the last stages of my RV8 build. I deleted the stock Vans cowl and it was a big mistake. I am a big fan of Sam James, but with the RV 8 there are two problems. 1. you wll have to use a prop extension with his 8 cowl. Sam does not currently make a short version for the 8 like he does for the 7. 2. The Cowl is a lot more work and it's advantages are not that great . it does look cool but in the end after surveying many I found the standard cowl is pretty good. 3. EVERY mod you make to the Vans kit will increase your building time exponentially. John Thocker of Red Line air shows has built at least 3 RV 8 s and helped with many more. His standard advice is build it like Van said to and you will be fine. Finally if you delete it from the Kit it will cost you nearly double with shipping if you change your mind later. I have a close friend in the EZ world that is a world record holder. He actually deigned the wheel pants Sam uses. My friend did encourage me to look at SAMs cowl, but in the end, for me at least, it was not worth it. If you build it light you will get 99% of the speed you need. Hope this helps. On Tuesday, August 30, 2016, Carl Froehlich wrote: I=99m just about ready to drop the order to Van=99s for a slow build RV-8 kit. I=99m already working the empennage so I figure with the eight week time line for shipment I need to move forward. I=99m looking to use a James Cowl. As such I need to delete the standard Van=99s cowl in my order. So =93 looking for recommendations of the RV-8 James Cowl group =93 yes or no? I=99ll be using a stock IO-360 from Van=99s =93 the 180 hp version. Thanks, Carl RV-8A, sold RV-10, sale pending (and it breaks my heart) RV-8, tail kit ________________________________________________________________________________
Date: Sep 01, 2016
Mike Wyn makes the point well. If you like the James Cowl. you should do it, Particularly since you have done one on your RV10. I am experiencing a very frustrating problem with my G3X installation. Everything is working well except fro one notable exception. The 23 ES transponder doe not want to talk to the AHARS GDU25. If you are familiar with the G3X system it checks all the connected devises on the configuration page. IF they are working you get a green check mark in the box next to the device in the configuration mode. Te only one that does not get the check is the Transponder a 23ES. I get a red X. There is no communication between it and the 25. I have checked the connection (only three wires) so many times I can see the pin numbers in my sleep. Garmin support has been great. I sent them screen shots of all the relevant pages and they could see no errors. I comes down to three possibility's 1. Wired wrong, I have checked it every way I know how to the point of even running new wires directly between the units. 2. The transponder is bad. Garmin sent me a new unit. Same problem. 3. The GDU25 is bad. Garmin is sending me a new one. Christer at Stein Air has been there helping me all the way. I cannot say enough about his support. I did have Stein produce a master interconnect drawing for my installation. It was worth penny. I believe all my wiring is Ok. Just wondering if anyone else has seen this problem? Mike On Thu, Sep 1, 2016 at 3:51 PM, Carl Froehlich wrote: > Thanks for the feed Michael. > > > Carl > > > *From:* owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server @ > matronics.com] *On Behalf Of *MLWynn(at)aol.com > *Sent:* Thursday, September 01, 2016 10:31 AM > *To:* rv8-list(at)matronics.com > *Subject:* Re: RV8-List: James Cowl > > > Hi Carl, > > > I built a slow build RV-8 with the James Cowl. Michael's statements abou t > additional build time are correct. On the other hand, my cooling is > exceptional and the longer nose looks good. Very hard to say if my bird is > faster or not, but I haven't really had any problems with it. I have a 4 " > saber extension and used a three blade Catto prop. Very smooth. I have > since changed to a Hartzell constant speed but am very pleased with the > James Cowl. I would probably do it again if I were building again. > > > Regards, > > > Michael Wynn > > > In a message dated 8/31/2016 7:24:45 A.M. Pacific Daylight Time, > carl.froehlich(at)verizon.net writes: > > Michael, > > > Thanks for the feed. > > > I built the RV-10 with the James Cowl and I=99m happy with the perf ormance. > I configured the plane for high altitude long range cruise and the James > Cowl has contributed to the results. I note Will James stop offering the > RV-10 cowl as a few builders had issues. > > > What worries me more than the extra work is the required 2.5=9D pro p > extension. I understand why Will James does this and I agree with the > concept, but the prop hanging out there worried me about engine crank > bearing load. I talked to BPE about this and they told me it is not a > problem. > > > So my root question remains. I understand the downside of the cowl but I > would like a feed from those running one on how they see it impacting > performance. > > > Carl > > > *From:* owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server @ > matronics.com ] *On Behalf Of *Micha el > Lazarowicz > *Sent:* Wednesday, August 31, 2016 8:29 AM > *To:* rv8-list(at)matronics.com > *Subject:* Re: RV8-List: James Cowl > > > Hi Carl > > > I am in the last stages of my RV8 build. I deleted the stock Vans cowl > and it was a big mistake. I am a big fan of Sam James, but with the RV 8 > there are two problems. > > > 1. you wll have to use a prop extension with his 8 cowl. Sam does not > currently make a short version for the 8 like he does for the 7. > > > 2. The Cowl is a lot more work and it's advantages are not that great . > it does look cool but in the end after surveying many I found the standa rd > cowl is pretty good. > > > 3. EVERY mod you make to the Vans kit will increase your building time > exponentially. > > John Thocker of Red Line air shows has built at least 3 RV 8 s and helped > with many more. His standard advice is build it like Van said to and you > will be fine. > > > Finally if you delete it from the Kit it will cost you nearly double with > shipping if you change your mind later. > > > I have a close friend in the EZ world that is a world record holder. He > actually deigned the wheel pants Sam uses. My friend did encourage me to > look at SAMs cowl, but in the end, for me at least, it was not worth it. > > > If you build it light you will get 99% of the speed you need. > > > Hope this helps. > > On Tuesday, August 30, 2016, Carl Froehlich > wrote: > > I=99m just about ready to drop the order to Van=99s for a slo w build RV-8 > kit. I=99m already working the empennage so I figure with the eigh t week > time line for shipment I need to move forward. > > > I=99m looking to use a James Cowl. As such I need to delete the st andard > Van=99s cowl in my order. So =93 looking for recommendations of the RV-8 James > Cowl group =93 yes or no? > > > I=99ll be using a stock IO-360 from Van=99s =93 the 180 hp version. > > > Thanks, > > Carl > > RV-8A, sold > > RV-10, sale pending (and it breaks my heart) > > RV-8, tail kit > > ________________________________________________________________________________
From: Scott Clarkson <scottclarkson(at)optonline.net>
Date: Sep 01, 2016
Hello All, It's been a number of years since I completed my RV-8 but I installed the Ja mes cowl and did it without the prop spacer. I had met Sam James at Sun N Fu n and after an hour of conversation I committed to buy his set up. The iron ic part of our conversation was we talked about all aspects of the install.. .except the fact that it needed the prop extension. After received it and r ealizing my situation I searched the Internet high and low and found and spo ke with John Huft from Colorado. He installed the James cowl minus prop ext ension on his -8 so I emulated his set up. He was more than willing to shar e his install so I decided if he pulled it off so could I. The task was mon umental. It required cutting off and re-profiling the entire front of the c owl and reworking it for a seamless flow with the 200RV spinner. A slight b lister for the starter was required as well as cutting apart the plenum and l owering it all the way down to the lift ring. I also had to make clearance f or the Sky Dynamics 4-1 exhaust collector and installed a ram air butterfly f or the intake. I also used a Sky Dynamics adapter to reposition the fuel in jector servo to horizontal but I had to cut and reweld it to line up with th e cowl intake. Custom mixture and throttle bracket, sanding, swearing, fill ing, more sanding, on and on. The result? Superb cooling in the AZ heat, great looking, and no two place R V can touch it. Definitely a rewarding feeling but a huge undertaking. Scott Clarkson N360SC Sent from my iPad > On Sep 1, 2016, at 7:53 PM, Michael Lazarowicz wrote: > > Mike Wyn makes the point well. If you like the James Cowl. you should do i t, Particularly since you have done one on your RV10. > > I am experiencing a very frustrating problem with my G3X installation. Ev erything is working well except fro one notable exception. The 23 ES transp onder doe not want to talk to the AHARS GDU25. If you are familiar with the G3X system it checks all the connected devises on the configuration page. I F they are working you get a green check mark in the box next to the device i n the configuration mode. Te only one that does not get the check is the Tr ansponder a 23ES. I get a red X. There is no communication between it and t he 25. I have checked the connection (only three wires) so many times I can see the pin numbers in my sleep. > > Garmin support has been great. I sent them screen shots of all the releva nt pages and they could see no errors. I comes down to three possibility's 1. Wired wrong, I have checked it every way I know how to the point of eve n running new wires directly between the units. 2. The transponder is bad. Garmin sent me a new unit. Same problem. 3. The GDU25 is bad. Garmin i s sending me a new one. > > Christer at Stein Air has been there helping me all the way. I cannot say enough about his support. I did have Stein produce a master interconnect d rawing for my installation. It was worth penny. I believe all my wiring is Ok. Just wondering if anyone else has seen this problem? > > Mike > > >> On Thu, Sep 1, 2016 at 3:51 PM, Carl Froehlich wrote: >> Thanks for the feed Michael. >> >> >> >> Carl >> >> >> >> From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server@m atronics.com] On Behalf Of MLWynn(at)aol.com >> Sent: Thursday, September 01, 2016 10:31 AM >> To: rv8-list(at)matronics.com >> Subject: Re: RV8-List: James Cowl >> >> >> >> Hi Carl, >> >> >> >> I built a slow build RV-8 with the James Cowl. Michael's statements abou t additional build time are correct. On the other hand, my cooling is excep tional and the longer nose looks good. Very hard to say if my bird is faste r or not, but I haven't really had any problems with it. I have a 4" saber e xtension and used a three blade Catto prop. Very smooth. I have since chan ged to a Hartzell constant speed but am very pleased with the James Cowl. I would probably do it again if I were building again. >> >> >> >> Regards, >> >> >> >> Michael Wynn >> >> >> >> In a message dated 8/31/2016 7:24:45 A.M. Pacific Daylight Time, carl.fro ehlich(at)verizon.net writes: >> >> Michael, >> >> >> >> Thanks for the feed. >> >> >> >> I built the RV-10 with the James Cowl and I=99m happy with the perf ormance. I configured the plane for high altitude long range cruise and the James Cowl has contributed to the results. I note Will James stop offering the RV-10 cowl as a few builders had issues. >> >> >> >> What worries me more than the extra work is the required 2.5=9D pro p extension. I understand why Will James does this and I agree with the conc ept, but the prop hanging out there worried me about engine crank bearing lo ad. I talked to BPE about this and they told me it is not a problem. >> >> >> >> So my root question remains. I understand the downside of the cowl but I would like a feed from those running one on how they see it impacting perfo rmance. >> >> >> >> Carl >> >> >> >> From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server@m atronics.com] On Behalf Of Michael Lazarowicz >> Sent: Wednesday, August 31, 2016 8:29 AM >> To: rv8-list(at)matronics.com >> Subject: Re: RV8-List: James Cowl >> >> >> >> Hi Carl >> >> >> >> I am in the last stages of my RV8 build. I deleted the stock Vans cowl a nd it was a big mistake. I am a big fan of Sam James, but with the RV 8 the re are two problems. >> >> >> >> 1. you wll have to use a prop extension with his 8 cowl. Sam does not cu rrently make a short version for the 8 like he does for the 7. >> >> >> >> 2. The Cowl is a lot more work and it's advantages are not that great . i t does look cool but in the end after surveying many I found the standard co wl is pretty good. >> >> >> >> 3. EVERY mod you make to the Vans kit will increase your building time e xponentially. >> >> John Thocker of Red Line air shows has built at least 3 RV 8 s and helped with many more. His standard advice is build it like Van said to and you w ill be fine. >> >> >> >> Finally if you delete it from the Kit it will cost you nearly double with shipping if you change your mind later. >> >> >> >> I have a close friend in the EZ world that is a world record holder. He a ctually deigned the wheel pants Sam uses. My friend did encourage me to loo k at SAMs cowl, but in the end, for me at least, it was not worth it. >> >> >> >> If you build it light you will get 99% of the speed you need. >> >> >> >> Hope this helps. >> >> On Tuesday, August 30, 2016, Carl Froehlich w rote: >> >> I=99m just about ready to drop the order to Van=99s for a slo w build RV-8 kit. I=99m already working the empennage so I figure wit h the eight week time line for shipment I need to move forward. >> >> >> >> I=99m looking to use a James Cowl. As such I need to delete the st andard Van=99s cowl in my order. So =93 looking for recommendat ions of the RV-8 James Cowl group =93 yes or no? >> >> >> >> I=99ll be using a stock IO-360 from Van=99s =93 the 180 hp version. >> >> >> >> Thanks, >> >> Carl >> >> RV-8A, sold >> >> RV-10, sale pending (and it breaks my heart) >> >> RV-8, tail kit >> > ________________________________________________________________________________
Date: Sep 01, 2016
Hello All, It's been a number of years since I completed my RV-8 but I installed the Ja mes cowl and did it without the prop spacer. I had met Sam James at Sun N Fu n and after an hour of conversation I committed to buy his set up. The iron ic part of our conversation was we talked about all aspects of the install.. .except the fact that it needed the prop extension. After received it and r ealizing my situation I searched the Internet high and low and found and spo ke with John Huft from Colorado. He installed the James cowl minus prop ext ension on his -8 so I emulated his set up. He was more than willing to shar e his install so I decided if he pulled it off so could I. The task was mon umental. It required cutting off and re-profiling the entire front of the c owl and reworking it for a seamless flow with the 200RV spinner. A slight b lister for the starter was required as well as cutting apart the plenum and l owering it all the way down to the lift ring. I also had to make clearance! for the Sky Dynamics 4-1 exhaust collector and installed a ram air butterfl y for the intake. I also used a Sky Dynamics adapter to reposition the fuel injector servo to horizontal but I had to cut and reweld it to line up with the cowl intake. Custom mixture and throttle bracket, sanding, swearing, f illing, more sanding, on and on. The result? Superb cooling in the AZ heat, great looking, and no two place R V can touch it. Definitely a rewarding feeling but a huge undertaking. Scott Clarkson N360SC Sent from my iPad > On Sep 1, 2016, at 7:53 PM, Michael Lazarowicz wrote: > > Mike Wyn makes the point well. If you like the James Cowl. you should do i t, Particularly since you have done one on your RV10. > > I am experiencing a very frustrating problem with my G3X installation. Ev erything is working well except fro one notable exception. The 23 ES transp onder doe not want to talk to the AHARS GDU25. If you are familiar with the G3X system it checks all the connected devises on the configuration page. I F they are working you get a green check mark in the box next to the device i n the configuration mode. Te only one that does not get the check is the Tr ansponder a 23ES. I get a red X. There is no communication between it and t he 25. I have checked the connection (only three wires) so many times I can see the pin numbers in my sleep. > > Garmin support has been great. I sent them screen shots of all the releva nt pages and they could see no errors. I comes down to three possibility's 1. Wired wrong, I have checked it every way I know how to the point of eve n running new wires directly between the units. 2. The transponder is bad. Garmin sent me a new unit. Same problem. 3. The GDU25 is bad. Garmin i s sending me a new one. > > Christer at Stein Air has been there helping me all the way. I cannot say enough about his support. I did have Stein produce a master interconnect d rawing for my installation. It was worth penny. I believe all my wiring is Ok. Just wondering if anyone else has seen this problem? > > Mike > > >> On Thu, Sep 1, 2016 at 3:51 PM, Carl Froehlich wrote: >> Thanks for the feed Michael. >> >> >> >> Carl >> >> >> >> From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server@m atronics.com] On Behalf Of MLWynn(at)aol.com >> Sent: Thursday, September 01, 2016 10:31 AM >> To: rv8-list(at)matronics.com >> Subject: Re: RV8-List: James Cowl >> >> >> >> Hi Carl, >> >> >> >> I built a slow build RV-8 with the James Cowl. Michael's statements abou t additional build time are correct. On the other hand, my cooling is excep tional and the longer nose looks good. Very hard to say if my bird is faste r or not, but I haven't really had any problems with it. I have a 4" saber e xtension and used a three blade Catto prop. Very smooth. I have since chan ged to a Hartzell constant speed but am very pleased with the James Cowl. I would probably do it again if I were building again. >> >> >> >> Regards, >> >> >> >> Michael Wynn >> >> >> >> In a message dated 8/31/2016 7:24:45 A.M. Pacific Daylight Time, carl.fro ehlich(at)verizon.net writes: >> >> Michael, >> >> >> >> Thanks for the feed. >> >> >> >> I built the RV-10 with the James Cowl and I=99m happy with the perf ormance. I configured the plane for high altitude long range cruise and the James Cowl has contributed to the results. I note Will James stop offering the RV-10 cowl as a few builders had issues. >> >> >> >> What worries me more than the extra work is the required 2.5=9D pro p extension. I understand why Will James does this and I agree with the conc ept, but the prop hanging out there worried me about engine crank bearing lo ad. I talked to BPE about this and they told me it is not a problem. >> >> >> >> So my root question remains. I understand the downside of the cowl but I would like a feed from those running one on how they see it impacting perfo rmance. >> >> >> >> Carl >> >> >> >> From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server@m atronics.com] On Behalf Of Michael Lazarowicz >> Sent: Wednesday, August 31, 2016 8:29 AM >> To: rv8-list(at)matronics.com >> Subject: Re: RV8-List: James Cowl >> >> >> >> Hi Carl >> >> >> >> I am in the last stages of my RV8 build. I deleted the stock Vans cowl a nd it was a big mistake. I am a big fan of Sam James, but with the RV 8 the re are two problems. >> >> >> >> 1. you wll have to use a prop extension with his 8 cowl. Sam does not cu rrently make a short version for the 8 like he does for the 7. >> >> >> >> 2. The Cowl is a lot more work and it's advantages are not that great . i t does look cool but in the end after surveying many I found the standard co wl is pretty good. >> >> >> >> 3. EVERY mod you make to the Vans kit will increase your building time e xponentially. >> >> John Thocker of Red Line air shows has built at least 3 RV 8 s and helped with many more. His standard advice is build it like Van said to and you w ill be fine. >> >> >> >> Finally if you delete it from the Kit it will cost you nearly double with shipping if you change your mind later. >> >> >> >> I have a close friend in the EZ world that is a world record holder. He a ctually deigned the wheel pants Sam uses. My friend did encourage me to loo k at SAMs cowl, but in the end, for me at least, it was not worth it. >> >> >> >> If you build it light you will get 99% of the speed you need. >> >> >> >> Hope this helps. >> >> On Tuesday, August 30, 2016, Carl Froehlich w rote: >> >> I=99m just about ready to drop the order to Van=99s for a slo w build RV-8 kit. I=99m already working the empennage so I figure wit h the eight week time line for shipment I need to move forward. >> >> >> >> I=99m looking to use a James Cowl. As such I need to delete the st andard Van=99s cowl in my order. So =93 looking for recommendat ions of the RV-8 James Cowl group =93 yes or no? >> >> >> >> I=99ll be using a stock IO-360 from Van=99s =93 the 180 hp version. >> >> >> >> Thanks, >> >> Carl >> >> RV-8A, sold >> >> RV-10, sale pending (and it breaks my heart) >> >> RV-8, tail kit >> > ________________________________________________________________________________
Subject: Airport Courtesy Cars App/Website Update
Date: Sep 02, 2016
ACC's app is still free in the app stores, and on the web. Currently over 11,000 active pilots are using it, and several businesses and FBO' offer fuel and other product discounts. I recently added a Facebook page which will include updates and events. If you are on Facebook please take a look and like it at www.facebook.com/airportcourtesycars Thanks! -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Smart Phone App and www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460183#460183 ________________________________________________________________________________
Date: Nov 01, 2016
Subject: Test, Ignore...
RV-8 at Catalina Island... Emacs! Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 01, 2016
Subject: PLEASE READ - Matronics Email List 2016 Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 24 different gifts to choose from! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Corbin Glowacki of My Pilot Store http://www.mypilotstore.com George Race of Race Consulting http://www.mrrace.com/ Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product line. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 03, 2016
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 05, 2016
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 06, 2016
Subject: Re: RV8-List Digest: 0 Msgs - 11/02/16
Please take me off your list!!!!! Sent from my iPhone > On Nov 3, 2016, at 12:04 AM, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 16-11-02&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 16-11-02&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Wed 11/02/16: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > ________________________________________________________________________________
Date: Nov 07, 2016
Date: Nov 09, 2016
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 11, 2016
Subject: Make Sure You're Listed! List of Contributors Published in
December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 13, 2016
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that ilk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 15, 2016
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 17, 2016
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some point, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 23 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Subject: Re: What's Your Contribution Used For?
Date: Nov 17, 2016
please remove me from you list On 11/17/2016 12:06 PM, Matt Dralle wrote: > > Dear Listers, > > You might have wondered at some point, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 23 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. > > But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. > > It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! > > List Contribution Web Site: > > http://www.matronics.com/contribution > > or, you can send a personal check to the following address: > > Matronics / Matt Dralle > 581 Jeannie Way > Livermore, CA 94550 > > Thank you for your support! > > Matt Dralle > Email List Administrator > > ________________________________________________________________________________
Date: Nov 19, 2016
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 21, 2016
Subject: RV towbar
Date: Nov 22, 2016
Anyone have ideas for a tow bar hooked up to golf cart for towing and RV8A.? I have two hand held tow bars that I use (one in baggage comp for on the road) The other in hanger, getting harder to push uphill would appreciate any suggestions, Please email me directly with comments at avdilger(at)yahoo.com Thanks Al Dilger L45 Bakersfield, CA ________________________________________________________________________________
Date: Nov 23, 2016
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 26, 2016
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2016
Date: Nov 28, 2016
Subject: Fund Raiser Behind By 28% - Please Contribute Today!
Dear Listers, The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 28%. Please take this opportunity to show your support for the Matronics Lists and Forums! Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List and Forums Administrator ________________________________________________________________________________
Date: Nov 29, 2016
Subject: Just Two Days Left! - Still Behind...
Dear Listers, There are just two more days left in this years List Fund Raiser. We are still way behind last year in terms of the number of contributions and total contribution amount. I really want to keep providing these services to the homebuilt community, but it take resources. Since there's no advertising budget or deep pockets to keep the operation a float, its solely your generosity during the Fund Raiser that keeps things going. Please make a Contribution today. If you've been putting off showing your support for the Lists, now is the time to do it! Make a contribution with a Credit Card or though PayPal at that Matronics Contribution web site: http://www.matronics.com/contribution Or, drop a check in the mail: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2016
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 53! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Airport Courtesy Cars App Closing?
Date: Dec 16, 2016
IMPORTANT! If you are a user of the app version of Airport Courtesy Cars, please view it for an important message about the possible closure of the app, or view the page here: https://www.airportcourtesycars.com/app-status.html -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Smart Phone App and www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464010#464010 ________________________________________________________________________________
Subject: Re: Airport Courtesy Cars App Closing?
Date: Dec 18, 2016
I am happy to report that thanks to donations, the site continues. View the donors or add your name by clicking here: https://www.airportcourtesycars.com/thank-you-donors-.html Thanks, Glenn -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Smart Phone App and www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464135#464135 ________________________________________________________________________________
Date: Dec 24, 2016
Subject: 2016 List of Contributors
Dear Listers, The 2016 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Andy, Bob, George, and Jon for their generous support through the supply of many great gifts this year!! These guys have some excellent products and I encourage you to visit their respective web sites: Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com Bob Nucklolls - AeroElectric - http://www.aeroelectric.com George Race - Race Consulting - http://www.mrrace.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com And finally, I'm proud to present The 2016 Fund Raiser List of Contributors: http://www.matronics.com/loc/2016.html Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Subject: Airport Cafe's Now Listed in ACC's
Date: Dec 31, 2016
I have just added over 50 airport cafs (and still growing) to current listings in the Airport Courtesy Cars website and app (just in case your courtesy car isnt available when you arrive!) These listings are highlighted in red so you can easily find them. If you have any additions or corrections, please email them directly to me at airportcars101(at)gmail.com. Thanks and Happy New Year! Glenn PS, Submit your ramp fee's experience also for inclusion in the website/app! -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Smart Phone App and www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464550#464550 ________________________________________________________________________________
Subject: RE: RV8-List Digest: 1 Msgs - 12/31/16
Date: Jan 01, 2017
You have our airport restaurants on the list here is Idaho! Thanks!! Paul Collins N337DP -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of RV8-List Digest Server Sent: Sunday, January 1, 2017 1:04 AM Subject: RV8-List Digest: 1 Msgs - 12/31/16 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 16-12-31&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2016-12-31&Archive=RV8 =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Sat 12/31/16: 1 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 11:40 AM - Airport Cafe's Now Listed in ACC's (gbrasch) ________________________________ Message 1 _____________________________________ Subject: RV8-List: Airport Cafe's Now Listed in ACC's From: "gbrasch" <gmbrasch(at)gmail.com> I have just added over 50 airport cafs (and still growing) to current listings in the Airport Courtesy Cars website and app (just in case your courtesy car isnt available when you arrive!) These listings are highlighted in red so you can easily find them. If you have any additions or corrections, please email them directly to me at airportcars101(at)gmail.com. Thanks and Happy New Year! Glenn PS, Submit your ramp fee's experience also for inclusion in the website/app! -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Smart Phone App and www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=464550#464550 ________________________________________________________________________________
Date: Apr 15, 2017
Subject: Matronics Internet Connectivity Upgrades April 17-18 2017
Dear Matronics Email List an/or Forum User, The Matronics Internet connectivity will be upgraded on April 17 through April 18, 2017. During the upgrade connections to the Matronics and AeroElectric web servers may be unavailable. Additionally, Matronics Email List email will not be redistributed. Internet Connectivity bandwidth will be significantly increased by a factor of 7X for downloads and 50X for uploads, which represents a significant increase in performance. Reliability should also increase in terms. I will send out a follow up message when the upgrade has been completed. Best Regards, Matt Dralle Matronics Email List and Forum Admin. Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jun 17, 2017
Subject: Re: RV8-List Digest: 0 Msgs - 06/16/17
STOP PLEASE Sent from my iPhone > On Jun 17, 2017, at 3:03 AM, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 17-06-16&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 17-06-16&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Fri 06/16/17: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > ________________________________________________________________________________
Subject: Major Upgrade to Airport Courtesy Cars Site-Please Read.
Date: Oct 01, 2017
If you are a user of the Airport Courtesy Cars site, I would like to inform you of a major upgrade and improvement. Effective mid December, A.C.C.'s will be fully web based, and will continue to be a secure site. Many of you over the past couple of years have asked for these improvements, the biggest user request being the site does not work on certain devices. By converting A.C.C's to a web based site, the advantage is clear, the site will now work on any device. Also, there is no possibility of bugs or crashes like an app. The information will be the same. During this transition period, it is important for you to bookmark the web address on your device so your service remains uninterrupted. For further information, click on the large red banner on the main page of the site, or here: https://www.airportcourtesycars.com/app-update.html -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473223#473223 ________________________________________________________________________________
Subject: Re: RV8-List Digest: 0 Msgs - 10/09/17
Date: Oct 10, 2017
I have been using Michelin Aviator tires on my RV8A 500-5 and cant complain, just wondering what others have experienced in their tire selection. Appreciate the input Al Dilger Bakersfield CA L45 EAA chapter 71 > On Oct 10, 2017, at 12:04 AM, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 17-10-09&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 17-10-09&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Mon 10/09/17: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > ________________________________________________________________________________
Date: Oct 11, 2017
Subject: Re: RV8-List Digest: 1 Msgs - 10/10/17
I use the same ones and have had some wear. I rotate the tires side to side and get better life. It must be the way the gear sets, but they work! Paul Collins N8ZV Sent from my iPhone > On Oct 11, 2017, at 01:04, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 17-10-10&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 17-10-10&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Tue 10/10/17: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 08:05 PM - Re: RV8-List Digest: 0 Msgs - 10/09/17 (Al Dilger) > > > > ________________________________ Message 1 _____________________________________ > > > From: Al Dilger <avdilger(at)yahoo.com> > Subject: RV8-List: Re: RV8-List Digest: 0 Msgs - 10/09/17 > > > I have been using Michelin Aviator tires on my RV8A 500-5 and cant complain, just > wondering what others have experienced in their tire selection. > Appreciate the input > Al Dilger Bakersfield CA L45 EAA chapter 71 >> On Oct 10, 2017, at 12:04 AM, RV8-List Digest Server > wrote: >> >> * >> >> ================================================ >> Online Versions of Today's List Digest Archive >> ================================================ >> >> Today's complete RV8-List Digest can also be found in either of the >> two Web Links listed below. The .html file includes the Digest formatted >> in HTML for viewing with a web browser and features Hyperlinked Indexes >> and Message Navigation. The .txt file includes the plain ASCII version >> of the RV8-List Digest and can be viewed with a generic text editor >> such as Notepad or with a web browser. >> >> HTML Version: >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 17-10-09&Archive=RV8 >> >> Text Version: >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 17-10-09&Archive=RV8 >> >> >> ============================================== >> EMail Version of Today's List Digest Archive >> ============================================== >> >> >> ---------------------------------------------------------- >> RV8-List Digest Archive >> --- >> Total Messages Posted Mon 10/09/17: 0 >> ---------------------------------------------------------- >> >> >> Today's Message Index: >> ---------------------- >> >> >> >> >> >> >> >> >> >> > > > > > > > > ________________________________________________________________________________
Date: Nov 01, 2017
Subject: PLEASE READ - Matronics Email List 2017 Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are 9 great gifts to choose from! There's something for everyone, to be sure. Please make your List Contribution using any one of three secure methods including using a Credit Card, PayPal, or by Personal Check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 03, 2017
Subject: Help Keep Airport Courtesy Cars Running
Date: Nov 04, 2017
Last November, a few people (out of thousands) complained to me that my fundraising efforts for the Airport Courtesy Cars site were too often. In response, I will only ask for donations once a year, in November. In the past few months I have transferred all the data to a web based platform. As a result, the site will work on ANY device with no bugs, crashes, or Android and Apple permissions required. Please refer to website for more details. The site now lists over 1,830 courtesy cars across the U.S. I receive a very small percent of my operating costs from advertisers. Most of my expenses are covered from small donations from pilots like you. I take no salary. Please consider any donation to keep the site up and running in the coming year. Donations can be made via the secure PayPal tab on the site (you don not need a PayPal account), or by mailing your donation to: Airport Courtesy Cars. P.O. Box 85762, Tucson, Arizona 85754. All donors will be listed on the donor page (unless you request not to be). Any donation is greatly appreciated. Please share this post with a fellow pilot who might benefit from A.C.C.s You can continue to email me your updates and suggestions to: airportcars101(at)gmail.com Thank you, Glenn www.airportcourtesycars.com -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474309#474309 ________________________________________________________________________________
Date: Nov 05, 2017
Date: Nov 07, 2017
Date: Nov 09, 2017
Date: Nov 11, 2017
Date: Nov 13, 2017
Date: Nov 15, 2017
Subject: Reminder
Date: Nov 17, 2017
Date: Nov 19, 2017
Date: Nov 21, 2017
Date: Nov 24, 2017
Date: Nov 26, 2017
Date: Nov 28, 2017
Date: Nov 29, 2017
Date: Nov 30, 2017
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 54! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2017
Subject: Re: [Please Read] - Last Official Day of List Fund Raiser!
Can you please unsubscribe me from the rv7 and Rv8 list? Sent from my iPhone > On Nov 30, 2017, at 9:42 AM, Matt Dralle wrote: > > > Dear Listers, > > It's November 30th and that always means a couple of things. Its my birthday again - 54! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! > > If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! > > I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! > > I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. > > The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: > > http://www.matronics.com/contribution > > Or, by dropping a personal check in the mail to: > > Matt Dralle / Matronics > 581 Jeannie Way > Livermore CA 94550 > USA > > Thank you in advance! > > Matt Dralle > Matronics Email List Administrator > > > > > > ________________________________________________________________________________
Subject: Re: Help Keep Airport Courtesy Cars Running
Date: Dec 06, 2017
Thanks to those of you who donated this past month and year to help keep Airport Courtesy Cars website up and running. Your names are posted on the donor page. This month ACCs will transform to a fully web based platform that will work on any device, bug and permission free. Just bookmark the website on your home screen. Continued donations are greatly appreciated, along with new listings or corrections. See you next November. Glenn -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=476166#476166 ________________________________________________________________________________
Date: Dec 17, 2017
Subject: 2017 List of Contributors
Dear Listers, The 2017 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors (LOC). It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 And finally, I'm proud to present The 2017 Fund Raiser List of Contributors: http://www.matronics.com/loc Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Subject: PC 680
Date: Mar 12, 2018
I have a PC 680 battery in my RV 8 and am wondering how long on average will one last. Mine has been installed for almost 6 years. Thanks Ed Clegg Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478620#478620 ________________________________________________________________________________
Subject: Re: PC 680
Date: Mar 12, 2018
I am on my fourth PC 680 in 6 years. My current primary is 1 year old and the secondary is 2 years old. Im amazed yours still holds a charge. Sent from my iPhone > On Mar 12, 2018, at 11:03 AM, edwclg wrote: > > > I have a PC 680 battery in my RV 8 and am wondering how long on average will one last. > Mine has been installed for almost 6 years. > Thanks > > Ed Clegg > > > > > Read this topic online here: > > https://nam03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D478620%23478620&data=02%7C01%7C%7C866f29c0a0704459e5c408d5883c16af%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636564714013838509&sdata=yohPs82xgSx8TPPop7zCauvBRGIGVEQIuONICht30H4%3D&reserved=0 > > > > > > > > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: PC 680
Date: Mar 12, 2018
I run two PC-625s (two are needed to hit my IFR electrical power reserve target). Both are used for engine start and in normal mode run in parallel. I replace one battery every three years - so no battery is older than six years. I started out replacing one every two years but found they still had a lot of life left in them. The pulled batteries go on to a second life in various tractors. Note - I once killed a new battery by leaving the master on. While some say you can beat new life into abused Odyssey batteries, it is better to replace the battery and then experiment on the dead one for service in a tractor. Carl -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of ALBERT THOMAS Sent: Monday, March 12, 2018 1:57 PM Subject: Re: RV8-List: PC 680 I am on my fourth PC 680 in 6 years. My current primary is 1 year old and the secondary is 2 years old. Im amazed yours still holds a charge. Sent from my iPhone > On Mar 12, 2018, at 11:03 AM, edwclg wrote: > > > I have a PC 680 battery in my RV 8 and am wondering how long on average will one last. > Mine has been installed for almost 6 years. > Thanks > > Ed Clegg > > > > > Read this topic online here: > > https://nam03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforum > s.matronics.com%2Fviewtopic.php%3Fp%3D478620%23478620&data=02%7C01%7C% > 7C866f29c0a0704459e5c408d5883c16af%7C84df9e7fe9f640afb435aaaaaaaaaaaa% > 7C1%7C0%7C636564714013838509&sdata=yohPs82xgSx8TPPop7zCauvBRGIGVEQIuON > ICht30H4%3D&reserved=0 > > > > > > > > > ________________________________________________________________________________
Date: Mar 12, 2018
Subject: Re: PC 680
I change mine out every three years as a precautionary measure. So far no battery failures. That may be overkill, but it affords me some peace of mind and Im willing to pay for that. Craig Gallenbach RV8A N184CG 600hrs since 2008 > On Mar 12, 2018, at 1:56 PM, ALBERT THOMAS wrote: > > > I am on my fourth PC 680 in 6 years. My current primary is 1 year old and the secondary is 2 years old. Im amazed yours still holds a charge. > > Sent from my iPhone > >> On Mar 12, 2018, at 11:03 AM, edwclg wrote: >> >> >> I have a PC 680 battery in my RV 8 and am wondering how long on average will one last. >> Mine has been installed for almost 6 years. >> Thanks >> >> Ed Clegg >> >> >> >> >> Read this topic online here: >> >> https://nam03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D478620%23478620&data=02%7C01%7C%7C866f29c0a0704459e5c408d5883c16af%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636564714013838509&sdata=yohPs82xgSx8TPPop7zCauvBRGIGVEQIuONICht30H4%3D&reserved=0 >> >> >> >> >> >> >> >> >> > > > > ________________________________________________________________________________
Subject: Re: PC 680
Date: Mar 12, 2018
There's a pretty big sample size on the VAF rv site=2E The guys who have sh ort lived pc680s are usually the ones using 'maintainers' regularly=2E AGM batteries last a long time if not needlessly cycled by leaving a maintainer on them=2E I ran a cheap pc625 equivalent in my rv4 for about 6 years, and it still had around 65% of its capacity left=2E It does pay to check capa city at annual, especially if you're electrically dependent=2E Being able t o crank the engine isn't a good indicator of capacity=2E Charlie On Mar 12, 2018, 12:07 PM, at 12:07 PM, edwclg wrote: >--> R V8-List message posted by: "edwclg" > >I have a PC 680 battery in my RV 8 and am wondering how long on average >will one last=2E >Mine has been installed for almost 6 years=2E >Thanks > >Ed Clegg > > >Read this topic online here: > >http://forums=2Ematronics=2Ecom/viewtopic =2Ephp?p=478620#478620 > > ======================= >_ -= - The RV8-List Email Forum - atures Navigator to browse ubscription, = Photoshare, and much much more: ics=2Ecom/Navigator?RV8-List ====================== = - MATRONICS WEB FORUMS - vailable via the Web Forums! =2Ecom =============== MATRONICS LIST WIKI - ! your generous support! ist Admin=2E ======== ________________________________________________________________________________
Subject: Re: PC 680
Date: Mar 12, 2018
I end up replacing my 680 every 2 years. At about the one and half year mark, in the winter they get weak and have trouble turning the cold engine, especially after sitting 2 to 3 weeks. My battery is in the rear if the plane, that may make a difference compared to engine compartment installs. Been that way for the 10 years or so Ive been flying the airplane. Paul Rice RV8 2007 ________________________________________ From: owner-rv8-list-server(at)matronics.com <owner-rv8-list-server(at)matronics.com> on behalf of Carl Froehlich Sent: Monday, March 12, 2018 2:24:24 PM Subject: RE: RV8-List: PC 680 I run two PC-625s (two are needed to hit my IFR electrical power reserve target). Both are used for engine start and in normal mode run in parallel. I replace one battery every three years - so no battery is older than six years. I started out replacing one every two years but found they still had a lot of life left in them. The pulled batteries go on to a second life in various tractors. Note - I once killed a new battery by leaving the master on. While some say you can beat new life into abused Odyssey batteries, it is better to replace the battery and then experiment on the dead one for service in a tractor. Carl -----Original Message----- From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of ALBERT THOMAS Sent: Monday, March 12, 2018 1:57 PM Subject: Re: RV8-List: PC 680 I am on my fourth PC 680 in 6 years. My current primary is 1 year old and the secondary is 2 years old. Im amazed yours still holds a charge. Sent from my iPhone > On Mar 12, 2018, at 11:03 AM, edwclg wrote: > > > I have a PC 680 battery in my RV 8 and am wondering how long on average will one last. > Mine has been installed for almost 6 years. > Thanks > > Ed Clegg > > > Read this topic online here: > > https://nam03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fforum > s.matronics.com%2Fviewtopic.php%3Fp%3D478620%23478620&data=02%7C01%7C% > 7C866f29c0a0704459e5c408d5883c16af%7C84df9e7fe9f640afb435aaaaaaaaaaaa% > 7C1%7C0%7C636564714013838509&sdata=yohPs82xgSx8TPPop7zCauvBRGIGVEQIuON > ICht30H4%3D&reserved=0 > > ________________________________________________________________________________
Date: Mar 12, 2018
Subject: Re: PC 680
I have never had a problem starting even after leaving it for a month. Also, have never used a maintainer on it. However I did order another figuring 6 years is long enough. This is a good discussion. Nice to have all this feed back. Ed clegg On Mon, Mar 12, 2018 at 3:10 PM, Charlie England wrote: > There's a pretty big sample size on the VAF rv site. The guys who have > short lived pc680s are usually the ones using 'maintainers' regularly. AG M > batteries last a long time if not needlessly cycled by leaving a maintain er > on them. I ran a cheap pc625 equivalent in my rv4 for about 6 years, and it > still had around 65% of its capacity left. > > It does pay to check capacity at annual, especially if you're electricall y > dependent. Being able to crank the engine isn't a good indicator of > capacity. > > Charlie > On Mar 12, 2018, at 12:07 PM, edwclg wrote: >> >> >> I have a PC 680 battery in my RV 8 and am wondering how long on average will one last. >> Mine has been installed for almost 6 years. >> Thanks >> >> Ed Clegg >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=478620#478620.com/Navigato r?RV8-List">http://www.matronics.com/Navigator?RV8-List< --> http://forums.matro--> < http://forums.matronics.com>http://wiki.matronics.matronics.com/contributio n">http://www.matronics.com/contribution >> ------------------------------ >> >> >> >> >> ________________________________________________________________________________
Date: Mar 13, 2018
Subject: Re: PC 680
I think that there are two things that prematurely kill the Odssey batteries: 1. not charging at high enough of a voltage 2. Slow drains while sitting I've got my voltage regulated at 14.4 volts and when the battery disconnects the only parasitic load is the Dynon keep alive. I've got two PC625s, one for cranking, one for backup. I do the same as a lot of guys, add a new one to the emergency position every 2 years(thinking about three) and make the old emergency one the new cranking battery. Batteries are substantially more reliable if you avoid cranking on them. I took year off work to travel and the plane sat for 9 months with a 2 year old battery, I came back and it started right up with no charging. Bill Judge RV-8 N84WJ 1360 hrs http://rv-8.blogspot.com/ ________________________________________________________________________________
Date: Mar 13, 2018
Subject: Re: PC 680
Ed, I agree - a very good discussion. I concur with all of the comments. I started out replacing 1 battery (two on board) every two years. Cap checks showed the old battery to still be very capable - can't remember the exact numbers - I had the guys in my FBO check it for me. I changed to 4 year swapout and I have had virtually no issues even with occasional long sit times. However, I am replacing the entire panel - EFIS, txpndr, radios, AP - and the batteries have been sitting unused and uncharged for 6 months. So, as part of the overall upgrade, I decided to install EarthX LiFePo4 batteries. I'm having to make new battery mounts since the EarthX have slightly different dimensions. It is always something, isn't it? I'll send an update later in the year when I have some experience with the new batteries. One thing is for sure, they are much lighter than the PC680s. Stan Sutterfield RV-8A ________________________________________________________________________________
Subject: AirNav.com Now Linked to Airport Courtesy Cars
Date: Apr 04, 2018
Airport Courtesy Cars website has been updated to link to AirNav.com. Click on any of the over 1,850 airport IDs within the site and you will be taken to the AirNav.com page for that airport. Please note Airport Courtesy Cars is now fully web based and works on any device. We have also added many locations with MOGAS. Have a great flying season and please consider a small donation to keep this site running and get your name added to the donor page. Thanks, Glenn -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479075#479075 ________________________________________________________________________________
Subject: VS-809
Date: Apr 10, 2018
Anyone have an extra Vert Stab Fiberglass fairing they would like to sell? email avdilger(at)yahoo.com Thx ________________________________________________________________________________
Subject: Re: RV8-List Digest: 0 Msgs - 06/25/18
Date: Jun 26, 2018
Been wondering about a few RV issues. 1=Does anyone know of an accurate fuel measuring device for RVs? (RV8A) I have Garmin G3X Touch with the Stewart Warner floats. Because the throw (depth of tank) is relatively short the gauges read 16 gal when full (21g) and stay there until there is about 13g left, aside from that they are pretty accurate. Im thinking that a dipstick type of gauge attached to the bottom of the fuel cap could be worked out..Any thoughts??? 2= I would like to see an improvement to the canopy rollers, it seems to me that a hard rubber wheel would work better. 3= I remember when building I had seen a mod to allow the pilot seat back to move more rearward (My seat back sits up too straight) wonder if there is a more simple way to accommodate that then changing and modifying the center support bar. Thanks, always looking for improvements > On Jun 25, 2018, at 23:44, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-06-25&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-06-25&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Mon 06/25/18: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > ________________________________________________________________________________
Date: Jun 26, 2018
On Tue, 26 Jun 2018, Al Dilger wrote: > > Been wondering about a few RV issues. > 1=Does anyone know of an accurate fuel measuring device for RVs? (RV8A) I have Garmin G3X Touch with the Stewart Warner floats. > Because the throw (depth of tank) is relatively short the gauges read 16 gal when full (21g) and stay there until there is about 13g left, aside from that they are pretty accurate. > Im thinking that a dipstick type of gauge attached to the bottom of the fuel cap could be worked out..Any thoughts??? A dipstick would have the same problem in the opposite direction, reading nothing for the last few gallons. Also you couldn't use it in flight. Would be easy enough to calibrate one starting from an empty tank. > 2= I would like to see an improvement to the canopy rollers, it seems >to me that a hard rubber wheel would work better. Would be an easy change to make, but don't see why rubber wheels would be an improvement. > 3= I remember when building I had seen a mod to allow the pilot seat >back to move more rearward (My seat back sits up too straight) wonder if >there is a more simple way to accommodate that then changing and >modifying > the center support bar. That would be the "tall pilot option" that Van's sells, they say it is for 6'6" and up, I'm only 6'4" and have it. Have to duck to close the canopy if wearing headset. It is just a different center bar with the main support further back. The extruded angle that forms the sides of the seatback are also left longer. If you have short legs, you could move the seatback hinge forward to get a steeper angle and use the standard center bar. This would mean less leg room, need a different size/shape seat cushion. You wouldn't have as bit a flat space before the slope up at the front of the seat. Brian Huffaker, DSWL (bifft(at)xmission.com) RV-8A N609HZ in test period ________________________________________________________________________________
Date: Jun 28, 2018
Subject: Re: RV8 Issues
Al, I'm planning to switch to the Van's fuel floats. One option I can recommend against is the Princeton Capacitance Probes. I have calibrated them 6 times - emptying the tanks each time and refilling in 1 gallon increments. It took hours and the probes have never indicated accurately. They occasionally indicate a quantity that is known to be near the reading, but then begin to erratically go from full to empty and everything in between. I strongly recommend against them. There is probably a way to mount a dip stick on the gas cap, but I doubt it is worth the effort. I use the fuel flow and manually calculate. It has been remarkably accurate. Agree that the canopy rollers need improvement. I've disliked them since I installed them. If you come up with a good solution I'd like to hear about it. Other than changing the seat back support (which you do not want to do) I know of no way to adjust it aft. I have never worried about it because I'm 5'-10" and my son is 6', so the current situation is not a problem for us. Are you currently building or is your airplane finished? I made numerous "improvements" to my 8A during building and I am currently gutting it to install all new radios-EFIS-AP-ADSB. Thinking about a supercharger-normalized. Where are you located? You should come and race with us at Reno. Regards, Stan Sutterfield Been wondering about a few RV issues. 1=Does anyone know of an accurate fuel measuring device for RVs? (RV8A) I have Garmin G3X Touch with the Stewart Warner floats. Because the throw (depth of tank) is relatively short the gauges read 16 gal when full (21g) and stay there until there is about 13g left, aside from that they are pretty accurate. Im thinking that a dipstick type of gauge attached to the bottom of the fuel cap could be worked out..Any thoughts??? 2= I would like to see an improvement to the canopy rollers, it seems to me that a hard rubber wheel would work better. 3= I remember when building I had seen a mod to allow the pilot seat back to move more rearward (My seat back sits up too straight) wonder if there is a more simple way to accommodate that then changing and modifying the center support bar. Thanks, always looking for improvements ________________________________________________________________________________
Date: Jun 28, 2018
Hmm, I would expect that adding much power, whether via supercharger, turbocharger or bigger engine would be of some concern. Van's states a Vne for most of their models, including the -8 at 200kts or 230 mph true airspeed. I am familiar with an -8 with the IO-390 engine that can get very close to that Vne in level flight. The Vne is set due to the design flutter speed. Vans has a white paper that is mostly aimed at the 10, against turbo-normalizing, which does the calculation that if 75% power can be maintained to 12,000 ft, the aircraft can exceed that Vne at that power setting. Everyone makes their own choices with experimental amateur built. I choose to pay attention to that Vne with my -10. http://vansaircraft.com/pdf/hp_limts.pdf On 6/27/2018 9:31 PM, speedy11(at)aol.com wrote: > Are you currently building or is your airplane finished? I made > numerous "improvements" to my 8A during building and I am currently > gutting it to install all new radios-EFIS-AP-ADSB. Thinking about a > supercharger-normalized. > Where are you located? > You should come and race with us at Reno. > Regards, > Stan Sutterfield ________________________________________________________________________________
Subject: Re: RV8-List Digest: 1 Msgs - 06/28/18
Date: Jun 29, 2018
Good point, I think the cost alone makes it unreasonable > On Jun 28, 2018, at 23:52, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-06-28&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-06-28&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Thu 06/28/18: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 06:46 AM - Re: Re: RV8 Issues (Kelly McMullen) > > > > ________________________________ Message 1 _____________________________________ > > > Subject: Re: RV8-List: Re: RV8 Issues > From: Kelly McMullen <kellym(at)aviating.com> > > > Hmm, > I would expect that adding much power, whether via supercharger, > turbocharger or bigger engine would be of some concern. Van's states a > Vne for most of their models, including the -8 at 200kts or 230 mph true > airspeed. I am familiar with an -8 with the IO-390 engine that can get > very close to that Vne in level flight. The Vne is set due to the design > flutter speed. Vans has a white paper that is mostly aimed at the 10, > against turbo-normalizing, which does the calculation that if 75% power > can be maintained to 12,000 ft, the aircraft can exceed that Vne at that > power setting. Everyone makes their own choices with experimental > amateur built. I choose to pay attention to that Vne with my -10. > http://vansaircraft.com/pdf/hp_limts.pdf > > On 6/27/2018 9:31 PM, speedy11(at)aol.com wrote: > >> Are you currently building or is your airplane finished? I made >> numerous "improvements" to my 8A during building and I am currently >> gutting it to install all new radios-EFIS-AP-ADSB. Thinking about a >> supercharger-normalized. >> Where are you located? >> You should come and race with us at Reno. >> Regards, >> Stan Sutterfield > > > > > > > > ________________________________________________________________________________
Date: Jul 29, 2018
Subject: Re: Matt's repair
I recently had an incident on takeoff (strong gust forced me off side of runway) and left gear attach point was forced up into the fuselage when it hit the edge of an intersecting taxiway. It caused the exact same airframe damage that Matt had on his RV-8 in landing incident. I never heard how the repair went or if it was successful and how hard was the repair job. Id love to hear something from Matt or others on how it went. Tracy Crook Sent from my iPad >> On Jun 26, 2018, at 11:57, Brian Huffaker wrote: >> >> On Tue, 26 Jun 2018, Al Dilger wrote: >> >> >> Been wondering about a few RV issues. >> 1=Does anyone know of an accurate fuel measuring device for RVs? (RV8A) I have Garmin G3X Touch with the Stewart Warner floats. >> Because the throw (depth of tank) is relatively short the gauges read 16 gal when full (21g) and stay there until there is about 13g left, aside from that they are pretty accurate. >> Im thinking that a dipstick type of gauge attached to the bottom of the fuel cap could be worked out..Any thoughts??? > > A dipstick would have the same problem in the opposite direction, reading > nothing for the last few gallons. Also you couldn't use it in flight. > Would be easy enough to calibrate one starting from an empty tank. > >> 2= I would like to see an improvement to the canopy rollers, it seems >> to me that a hard rubber wheel would work better. > > Would be an easy change to make, but don't see why rubber wheels would be > an improvement. > >> 3= I remember when building I had seen a mod to allow the pilot seat >> back to move more rearward (My seat back sits up too straight) wonder if >> there is a more simple way to accommodate that then changing and >> modifying >> the center support bar. > > That would be the "tall pilot option" that Van's sells, they say it is > for 6'6" and up, I'm only 6'4" and have it. Have to duck to close the > canopy if wearing headset. It is just a different center bar with the > main support further back. The extruded angle that forms the sides of the > seatback are also left longer. > > If you have short legs, you could move the seatback hinge forward to > get a steeper angle and use the standard center bar. This would mean less > leg room, need a different size/shape seat cushion. You wouldn't have as > bit a flat space before the slope up at the front of the seat. > > Brian Huffaker, DSWL (bifft(at)xmission.com) > RV-8A N609HZ in test period ________________________________________________________________________________
Date: Jul 30, 2018
Tracy, Sorry to hear about your misfortune.=C2- Matt wound up replacing his fuse lage.=C2- Not a small nor inexpensive endeavor.=C2-=C2- Details can be found here.... http://www.mattsrv8.com/users/category.php?user=MattsRV8&project=2273&c ategory=9041 Good luck and let us know what you decide. Bill Settle=C2- "Experience and common sense cannot be replaced with policy and procedures. " =C2- - R.L. Nuckolls III From: Tracy Crook <rwstracy(at)gmail.com> To: rv8-list(at)matronics.com Sent: Sunday, July 29, 2018 2:25 PM Subject: Re: RV8-List: Matt's repair I recently had an incident on takeoff (strong gust forced me off side of ru nway) and left gear attach point was forced up into the fuselage when it hi t the edge of an intersecting taxiway. It caused the exact same airframe da mage that Matt had on his RV-8 in landing incident. I never heard how the repair went or if it was successful and how hard was the repair job.=C2- I=99d love to hear something from Matt or other s on how it went. Tracy Crook Sent from my iPad >> On Jun 26, 2018, at 11:57, Brian Huffaker wrote: >> >> On Tue, 26 Jun 2018, Al Dilger wrote: >> >> >> Been wondering about a few RV issues. >> 1=Does anyone know of an accurate fuel measuring device for RV =99s? (RV8A) I have Garmin G3X Touch with the Stewart Warner floats. >> Because the =9Cthrow=9D (depth of tank) is relatively short the gauges read 16 gal when full (21g) and stay there until there is about 13g left, aside from that they are pretty accurate. >> Im thinking that a dipstick type of gauge attached to the bottom of the fuel cap could be worked out..Any thoughts??? > > A dipstick would have the same problem in the opposite direction, reading > nothing for the last few gallons.=C2- Also you couldn't use it in fligh t. > Would be easy enough to calibrate one starting from an empty tank. > >> 2= I would like to see an improvement to the canopy rollers, it seems >> to me that a hard rubber wheel would work better. > > Would be an easy change to make, but don't see why rubber wheels would be > an improvement. > >> 3= I remember when building I had seen a mod to allow the pilot seat >> back to move more rearward (My seat back sits up too straight) wonder if >> there is a more simple way to accommodate that then changing and >> modifying >>=C2- =C2- the center support bar. > > That would be the "tall pilot option" that Van's sells, they say it is > for 6'6" and up, I'm only 6'4" and have it.=C2- Have to duck to close t he > canopy if wearing headset.=C2- It is just a different center bar with t he > main support further back.=C2- The extruded angle that forms the sides of the > seatback are also left longer. > > If you have short legs, you could move the seatback hinge forward to > get a steeper angle and use the standard center bar.=C2- This would mea n less > leg room, need a different size/shape seat cushion.=C2- You wouldn't ha ve as > bit a flat space before the slope up at the front of the seat. > > Brian Huffaker, DSWL (bifft(at)xmission.com) > RV-8A N609HZ in test period S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jul 30, 2018
Thanks for the link Bill, just what I needed. As Matt noted, the RV-8 gear will take even hard landing loads but not strai ght up vertical loads. My damage was almost exactly what Matt's was except m y gear leg (same as Matt's) was not bent and I had no wing damage except for the wing tank rib. The wheel pant shattered on impact with the edge of the taxiway and part of it fell off somewhere during my flight around the patte rn. I heard it flopping around then stop. The exciting part was the fuel spraying into the cabin from the damaged tank rib. As a side note, I was glad I had plumbed the fuel line in rubber hose instead of aluminum. It probably would have broken off like the aluminum ve nt line did and I=99d have never made it around to land. I=99m in the process of drilling out skin rivets and exposing the stru cture and while it=99s not going to be a picnic, I=99m going to a t least give repairing the fuselage a try. Tracy Crook > On Jul 30, 2018, at 05:53, Bill Settle wrote: > > Tracy, > > Sorry to hear about your misfortune. Matt wound up replacing his fuselage . Not a small nor inexpensive endeavor. > > Details can be found here.... > > http://www.mattsrv8.com/users/category.php?user=MattsRV8&project=2273& category=9041 > > Good luck and let us know what you decide. > > Bill Settle > > > > > "Experience and common sense cannot be replaced with policy and procedures ." > > - R.L. Nuckolls III > > > From: Tracy Crook <rwstracy(at)gmail.com> > To: rv8-list(at)matronics.com > Sent: Sunday, July 29, 2018 2:25 PM > Subject: Re: RV8-List: Matt's repair > > > I recently had an incident on takeoff (strong gust forced me off side of r unway) and left gear attach point was forced up into the fuselage when it hi t the edge of an intersecting taxiway. It caused the exact same airframe dam age that Matt had on his RV-8 in landing incident. > > I never heard how the repair went or if it was successful and how hard was the repair job. I=99d love to hear something from Matt or others on h ow it went. > > Tracy Crook > > Sent from my iPad > > >> On Jun 26, 2018, at 11:57, Brian Huffaker wrote: > >> > > ________________________________________________________________________________
Date: Jul 30, 2018
Tracy, Please post some pictures for us when you can. grumpy N82W (in the paint shop now!) > On Jul 30, 2018, at 1:43 PM, Tracy Crook wrote: > > Thanks for the link Bill, just what I needed. > > As Matt noted, the RV-8 gear will take even hard landing loads but not straight up vertical loads. My damage was almost exactly what Matt's was except my gear leg (same as Matt's) was not bent and I had no wing damage except for the wing tank rib. The wheel pant shattered on impact with the edge of the taxiway and part of it fell off somewhere during my flight around the pattern. I heard it flopping around then stop. > > The exciting part was the fuel spraying into the cabin from the damaged tank rib. As a side note, I was glad I had plumbed the fuel line in rubber hose instead of aluminum. It probably would have broken off like the aluminum vent line did and I=99d have never made it around to land. > > I=99m in the process of drilling out skin rivets and exposing the structure and while it=99s not going to be a picnic, I=99m going to at least give repairing the fuselage a try. > > Tracy Crook > > On Jul 30, 2018, at 05:53, Bill Settle > wrote: > >> Tracy, >> >> Sorry to hear about your misfortune. Matt wound up replacing his fuselage. Not a small nor inexpensive endeavor. >> >> Details can be found here.... >> >> http://www.mattsrv8.com/users/category.php?user=MattsRV8&project=2273& category=9041 <http://www.mattsrv8.com/users/category.php?user=MattsRV8&project=2273 &category=9041> >> >> Good luck and let us know what you decide. >> >> Bill Settle >> >> >> >> >> "Experience and common sense cannot be replaced with policy and procedures." >> >> - R.L. Nuckolls III >> >> >> From: Tracy Crook <rwstracy(at)gmail.com <mailto:rwstracy(at)gmail.com>> >> To: rv8-list(at)matronics.com >> Sent: Sunday, July 29, 2018 2:25 PM >> Subject: Re: RV8-List: Matt's repair >> > >> >> I recently had an incident on takeoff (strong gust forced me off side of runway) and left gear attach point was forced up into the fuselage when it hit the edge of an intersecting taxiway. It caused the exact same airframe damage that Matt had on his RV-8 in landing incident. >> >> I never heard how the repair went or if it was successful and how hard was the repair job. I=99d love to hear something from Matt or others on how it went. >> >> Tracy Crook >> >> Sent from my iPad >> >> >> On Jun 26, 2018, at 11:57, Brian Huffaker > wrote: >> >> >> >> ________________________________________________________________________________
Subject: Re: RV8-List Digest: 3 Msgs - 07/30/18
Date: Jul 31, 2018
Ouch.thats a bummer..no small task > On Jul 30, 2018, at 23:42, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-07-30&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-07-30&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Mon 07/30/18: 3 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 04:53 AM - Re: Matt's repair (Bill Settle) > 2. 11:43 AM - Re: Matt's repair (Tracy Crook) > 3. 02:49 PM - Re: Matt's repair (John Miller) > > > > ________________________________ Message 1 _____________________________________ > > > From: Bill Settle <billsettle(at)bellsouth.net> > Subject: Re: RV8-List: Matt's repair > > Tracy, > Sorry to hear about your misfortune.=C2- Matt wound up replacing his fuse > lage.=C2- Not a small nor inexpensive endeavor.=C2-=C2- > Details can be found here.... > http://www.mattsrv8.com/users/category.php?user=MattsRV8&project=2273&c > ategory=9041 > > Good luck and let us know what you decide. > Bill Settle=C2- > > > "Experience and common sense cannot be replaced with policy and procedures. > " > > =C2- - R.L. Nuckolls III > > From: Tracy Crook <rwstracy(at)gmail.com> > To: rv8-list(at)matronics.com > Sent: Sunday, July 29, 2018 2:25 PM > Subject: Re: RV8-List: Matt's repair > > > I recently had an incident on takeoff (strong gust forced me off side of ru > nway) and left gear attach point was forced up into the fuselage when it hi > t the edge of an intersecting taxiway. It caused the exact same airframe da > mage that Matt had on his RV-8 in landing incident. > > I never heard how the repair went or if it was successful and how hard was > the repair job.=C2- I=99d love to hear something from Matt or other > s on how it went. > > Tracy Crook > > Sent from my iPad > >>> On Jun 26, 2018, at 11:57, Brian Huffaker wrote: >>> >>> On Tue, 26 Jun 2018, Al Dilger wrote: >>> >>> >>> Been wondering about a few RV issues. >>> 1=Does anyone know of an accurate fuel measuring device for RV > =99s? (RV8A) I have Garmin G3X Touch with the Stewart Warner floats. >>> Because the =9Cthrow=9D (depth of tank) is relatively short > the gauges read 16 gal when full (21g) and stay there until there is about > 13g left, aside from that they are pretty accurate. >>> Im thinking that a dipstick type of gauge attached to the bottom of the > fuel cap could be worked out..Any thoughts??? >> >> A dipstick would have the same problem in the opposite direction, reading >> nothing for the last few gallons.=C2- Also you couldn't use it in fligh > t. >> Would be easy enough to calibrate one starting from an empty tank. >> >>> 2= I would like to see an improvement to the canopy rollers, it seems >>> to me that a hard rubber wheel would work better. >> >> Would be an easy change to make, but don't see why rubber wheels would be >> an improvement. >> >>> 3= I remember when building I had seen a mod to allow the pilot seat >>> back to move more rearward (My seat back sits up too straight) wonder if >>> there is a more simple way to accommodate that then changing and >>> modifying >>> =C2- =C2- the center support bar. >> >> That would be the "tall pilot option" that Van's sells, they say it is >> for 6'6" and up, I'm only 6'4" and have it.=C2- Have to duck to close t > he >> canopy if wearing headset.=C2- It is just a different center bar with t > he >> main support further back.=C2- The extruded angle that forms the sides > of the >> seatback are also left longer. >> >> If you have short legs, you could move the seatback hinge forward to >> get a steeper angle and use the standard center bar.=C2- This would mea > n less >> leg room, need a different size/shape seat cushion.=C2- You wouldn't ha > ve as >> bit a flat space before the slope up at the front of the seat. >> >> Brian Huffaker, DSWL (bifft(at)xmission.com) >> RV-8A N609HZ in test period > > S - > WIKI - > - > =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. > > > > > ________________________________ Message 2 _____________________________________ > > > From: Tracy Crook <rwstracy(at)gmail.com> > Subject: Re: RV8-List: Matt's repair > > Thanks for the link Bill, just what I needed. > > As Matt noted, the RV-8 gear will take even hard landing loads but not strai > ght up vertical loads. My damage was almost exactly what Matt's was except m > y gear leg (same as Matt's) was not bent and I had no wing damage except for > the wing tank rib. The wheel pant shattered on impact with the edge of the > taxiway and part of it fell off somewhere during my flight around the patte > rn. I heard it flopping around then stop. > > The exciting part was the fuel spraying into the cabin from the damaged tank > rib. As a side note, I was glad I had plumbed the fuel line in rubber hose > instead of aluminum. It probably would have broken off like the aluminum ve > nt line did and I=99d have never made it around to land. > > I=99m in the process of drilling out skin rivets and exposing the stru > cture and while it=99s not going to be a picnic, I=99m going to a > t least give repairing the fuselage a try. > > Tracy Crook > >> On Jul 30, 2018, at 05:53, Bill Settle wrote: >> >> Tracy, >> >> Sorry to hear about your misfortune. Matt wound up replacing his fuselage > . Not a small nor inexpensive endeavor. >> >> Details can be found here.... >> >> http://www.mattsrv8.com/users/category.php?user=MattsRV8&project=2273& > category=9041 >> >> Good luck and let us know what you decide. >> >> Bill Settle >> >> >> >> >> "Experience and common sense cannot be replaced with policy and procedures > ." >> >> - R.L. Nuckolls III >> >> >> From: Tracy Crook <rwstracy(at)gmail.com> >> To: rv8-list(at)matronics.com >> Sent: Sunday, July 29, 2018 2:25 PM >> Subject: Re: RV8-List: Matt's repair >> >> >> I recently had an incident on takeoff (strong gust forced me off side of r > unway) and left gear attach point was forced up into the fuselage when it hi > t the edge of an intersecting taxiway. It caused the exact same airframe dam > age that Matt had on his RV-8 in landing incident. >> >> I never heard how the repair went or if it was successful and how hard was > the repair job. I=99d love to hear something from Matt or others on h > ow it went. >> >> Tracy Crook >> >> Sent from my iPad >> >>>> On Jun 26, 2018, at 11:57, Brian Huffaker wrote: >>>> >> >> > > ________________________________ Message 3 _____________________________________ > > > From: John Miller <gengrumpy(at)aol.com> > Subject: Re: RV8-List: Matt's repair > > Tracy, > > Please post some pictures for us when you can. > > grumpy > N82W (in the paint shop now!) > >> On Jul 30, 2018, at 1:43 PM, Tracy Crook wrote: >> >> Thanks for the link Bill, just what I needed. >> >> As Matt noted, the RV-8 gear will take even hard landing loads but not > straight up vertical loads. My damage was almost exactly what Matt's > was except my gear leg (same as Matt's) was not bent and I had no wing > damage except for the wing tank rib. The wheel pant shattered on impact > with the edge of the taxiway and part of it fell off somewhere during my > flight around the pattern. I heard it flopping around then stop. >> >> The exciting part was the fuel spraying into the cabin from the > damaged tank rib. As a side note, I was glad I had plumbed the fuel > line in rubber hose instead of aluminum. It probably would have broken > off like the aluminum vent line did and I=99d have never made it > around to land. >> >> I=99m in the process of drilling out skin rivets and exposing > the structure and while it=99s not going to be a picnic, I=99m > going to at least give repairing the fuselage a try. >> >> Tracy Crook >> >> On Jul 30, 2018, at 05:53, Bill Settle > wrote: >> >>> Tracy, >>> >>> Sorry to hear about your misfortune. Matt wound up replacing his > fuselage. Not a small nor inexpensive endeavor. >>> >>> Details can be found here.... >>> >>> > http://www.mattsrv8.com/users/category.php?user=MattsRV8&project=2273& > category=9041 > <http://www.mattsrv8.com/users/category.php?user=MattsRV8&project=2273 > &category=9041> >>> >>> Good luck and let us know what you decide. >>> >>> Bill Settle >>> >>> >>> >>> >>> "Experience and common sense cannot be replaced with policy and > procedures." >>> >>> - R.L. Nuckolls III >>> >>> >>> From: Tracy Crook <rwstracy(at)gmail.com <mailto:rwstracy(at)gmail.com>> >>> To: rv8-list(at)matronics.com >>> Sent: Sunday, July 29, 2018 2:25 PM >>> Subject: Re: RV8-List: Matt's repair >>> > > >>> >>> I recently had an incident on takeoff (strong gust forced me off side > of runway) and left gear attach point was forced up into the fuselage > when it hit the edge of an intersecting taxiway. It caused the exact > same airframe damage that Matt had on his RV-8 in landing incident. >>> >>> I never heard how the repair went or if it was successful and how > hard was the repair job. I=99d love to hear something from Matt > or others on how it went. >>> >>> Tracy Crook >>> >>> Sent from my iPad >>> >>>>> On Jun 26, 2018, at 11:57, Brian Huffaker > wrote: >>>>> >>> >>> > > > > > > > > ________________________________________________________________________________
Subject: RV-8 Wing tank removal
Date: Aug 09, 2018
Working on the takeoff damage to the RV-8 and need to remove the tank for ac cess and to repair the tank damage. I=99ve removed all the screws aro und the perimeter of the tank and the three 3/16=9D bolts at the root i nto the spar web. . That=99s all I recall holding on the tank but it r efuses to budge more than maybe .03=9D away from its position. Are there any other fasteners holding the tank on? I=99m in CO away f rom my plans. Any ideas on tank removal if that=99s not the problem? Thanks for any info or suggestions, Tracy Crook ________________________________________________________________________________
Date: Aug 09, 2018
Subject: Re: RV-8 Wing tank removal
On Thu, 9 Aug 2018, Tracy Crook wrote: > Working on the takeoff damage to the RV-8 and need to remove the tank >for access and to repair the tank damage. Ive removed all the screws >around the perimeter of the tank and the three 3/16 bolts at the root >into the spar web. . Thats all I recall holding on the tank but it >refuses to budge more than maybe .03 away from its position. There are about 21 3/16" bolts in the spar web going into the "z-angles" on the back of the tank. If you only removed three at the root you left most of them in. The rest can be removed through the wing access holes on the bottom. Many are in the next rib bay over from the access hole, so use a mirror and a flashlight to check that you got them all. There are three in pretty much every rib bay behind the tank, except where the wing walk is. Other than that when I removed a tank to fix a fuel leak, it took a harder pull than I was expecting to pop the skin dimples out. Brian Huffaker, DSWL (bifft(at)xmission.com) RV-8A 80091 Test flying ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Aug 09, 2018
Yes - many more 3/16=9D bolts holding the Z braces to the spar. Access them via the bottom inspection plates. Carl > On Aug 9, 2018, at 6:15 PM, Tracy Crook wrote: > > Working on the takeoff damage to the RV-8 and need to remove the tank for a ccess and to repair the tank damage. I=99ve removed all the screws ar ound the perimeter of the tank and the three 3/16=9D bolts at the root into the spar web. . That=99s all I recall holding on the tank but i t refuses to budge more than maybe .03=9D away from its position. > > Are there any other fasteners holding the tank on? I=99m in CO away from my plans. Any ideas on tank removal if that=99s not the problem ? > > Thanks for any info or suggestions, > Tracy Crook > ________________________________________________________________________________
Date: Aug 09, 2018
There are like 12 or 15 bolts AN-3 through the back of the spar and into z b rackets on the back of the tank. All accessed through the inspection hatch es. Bob Newman TCW Technologies, LLC 610-928-3420 > On Aug 9, 2018, at 6:15 PM, Tracy Crook wrote: > > Working on the takeoff damage to the RV-8 and need to remove the tank for a ccess and to repair the tank damage. I=99ve removed all the screws ar ound the perimeter of the tank and the three 3/16=9D bolts at the root into the spar web. . That=99s all I recall holding on the tank but i t refuses to budge more than maybe .03=9D away from its position. > > Are there any other fasteners holding the tank on? I=99m in CO away from my plans. Any ideas on tank removal if that=99s not the problem ? > > Thanks for any info or suggestions, > Tracy Crook > ________________________________________________________________________________
Date: Aug 09, 2018
Hey Tracy, Same tank as the -7, AFAIK. The z brackets are behind every rib, if memory serves. I think I can email you that page from the -7 plans, if you want. You can slip stuff like old credit cards or other thin items between the back edge of the tank & the spar to lift the dimples prior to removing the tank. I've pulled the tanks on the -4 several times. I usually pull out the root end slightly first, using a wedge between the nose attach angles. Then, if needed, I wedge something in the slight V between the other end of the tank skin and the wing leading edge skin, and push the root end back aft. This will shift the tank inboard and move the outboard end forward slightly. Makes the rest of the removal go easier for me. Charlie On 8/9/2018 6:21 PM, Tcwtech wrote: > There are like 12 or 15 bolts AN-3 through the back of the spar and > into z brackets on the back of the tank. All accessed through the > inspection hatches. > > Bob Newman > TCW Technologies, LLC > 610-928-3420 > > On Aug 9, 2018, at 6:15 PM, Tracy Crook > wrote: > >> Working on the takeoff damage to the RV-8 and need to remove the tank >> for access and to repair the tank damage. Ive removed all the >> screws around the perimeter of the tank and the three 3/16 >> bolts at the root into the spar web. . >> Thats all I recall holding on the tank but it refuses to budge more >> than maybe .03 away from its position. >> >> Are there any other fasteners holding the tank on? Im in CO away >> from my plans. Any ideas on tank removal if thats not the problem? >> >> Thanks for any info or suggestions, >> Tracy Crook >> --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 10, 2018
Thank you guys. Ah, the things you forget after 17 years (holy =F0=9F=92=A9 , been that long?). I had recently pulled a tank on the -4 which doesn=99t have the braces . I should be able to get it from this info but thanks for offer of the pla ns Charlie. A copy of RV8 plans showing PN of left forward & bottom fwd. fuse parts woul d be handy if anyone has it scanned. Will be ready to order parts soon. Tracy Crook Sent from my iPad > On Aug 9, 2018, at 18:14, Charlie England wrote: > > Hey Tracy, > > Same tank as the -7, AFAIK. The z brackets are behind every rib, if memory serves. I think I can email you that page from the -7 plans, if you want. > > You can slip stuff like old credit cards or other thin items between the b ack edge of the tank & the spar to lift the dimples prior to removing the ta nk. I've pulled the tanks on the -4 several times. I usually pull out the ro ot end slightly first, using a wedge between the nose attach angles. Then, i f needed, I wedge something in the slight V between the other end of the tan k skin and the wing leading edge skin, and push the root end back aft. This w ill shift the tank inboard and move the outboard end forward slightly. Makes the rest of the removal go easier for me. > > Charlie > >> On 8/9/2018 6:21 PM, Tcwtech wrote: >> There are like 12 or 15 bolts AN-3 through the back of the spar and into z brackets on the back of the tank. All accessed through the inspection hat ches. >> >> Bob Newman >> TCW Technologies, LLC >> 610-928-3420 >> >> On Aug 9, 2018, at 6:15 PM, Tracy Crook wrote: >> >>> Working on the takeoff damage to the RV-8 and need to remove the tank fo r access and to repair the tank damage. I=99ve removed all the screws around the perimeter of the tank and the three 3/16=9D bolts at the r oot into the spar web. . That=99s all I recall holding on the tank bu t it refuses to budge more than maybe .03=9D away from its position. >>> >>> Are there any other fasteners holding the tank on? I=99m in CO aw ay from my plans. Any ideas on tank removal if that=99s not the probl em? >>> >>> Thanks for any info or suggestions, >>> Tracy Crook >>> > > > Virus-free. www.avast.com ________________________________________________________________________________
Date: Aug 10, 2018
It's not as good as having the paper plans to spread out in front of you, but you can get a thumb drive containing the entire manual from Van's for about $10. Find a laptop & copy it to the cloud, & copy back to your ipad. I'll check with Andy to see if he has a 'soft' copy, and email those pages to you if he does. Charlie On 8/10/2018 7:52 AM, Tracy Crook wrote: > Thank you guys. Ah, the things you forget after 17 years (holy , > been that long?). > > I had recently pulled a tank on the -4 which doesnt have the braces. > I should be able to get it from this info but thanks for offer of the > plans Charlie. > > A copy of RV8 plans showing PN of left forward & bottom fwd. fuse > parts would be handy if anyone has it scanned. Will be ready to order > parts soon. > > Tracy Crook > > > Sent from my iPad > > On Aug 9, 2018, at 18:14, Charlie England > wrote: > >> Hey Tracy, >> >> Same tank as the -7, AFAIK. The z brackets are behind every rib, if >> memory serves. I think I can email you that page from the -7 plans, >> if you want. >> >> You can slip stuff like old credit cards or other thin items between >> the back edge of the tank & the spar to lift the dimples prior to >> removing the tank. I've pulled the tanks on the -4 several times. I >> usually pull out the root end slightly first, using a wedge between >> the nose attach angles. Then, if needed, I wedge something in the >> slight V between the other end of the tank skin and the wing leading >> edge skin, and push the root end back aft. This will shift the tank >> inboard and move the outboard end forward slightly. Makes the rest of >> the removal go easier for me. >> >> Charlie >> >> On 8/9/2018 6:21 PM, Tcwtech wrote: >>> There are like 12 or 15 bolts AN-3 through the back of the spar and >>> into z brackets on the back of the tank. All accessed through the >>> inspection hatches. >>> >>> Bob Newman >>> TCW Technologies, LLC >>> 610-928-3420 >>> >>> On Aug 9, 2018, at 6:15 PM, Tracy Crook >> > wrote: >>> >>>> Working on the takeoff damage to the RV-8 and need to remove the >>>> tank for access and to repair the tank damage. Ive removed all >>>> the screws around the perimeter of the tank and the three 3/16 >>>> bolts at the root into the spar web. >>>> . Thats all I recall holding on the tank but it refuses to budge >>>> more than maybe .03 away from its position. >>>> >>>> Are there any other fasteners holding the tank on? Im in CO away >>>> from my plans. Any ideas on tank removal if thats not the problem? >>>> >>>> Thanks for any info or suggestions, >>>> Tracy Crook >>>> >> >> >> >> Virus-free. www.avast.com >> >> >> >> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Aug 10, 2018
No joy on the soft copy, but he's built/rebuilt several -8s. Want me to see if he has an extra set of printed plans he'd sell, if no one can send you a pdf of those pages? On Fri, Aug 10, 2018 at 9:21 AM, Charlie England wrote: > It's not as good as having the paper plans to spread out in front of you, > but you can get a thumb drive containing the entire manual from Van's for > about $10. Find a laptop & copy it to the cloud, & copy back to your ipad . > > I'll check with Andy to see if he has a 'soft' copy, and email those page s > to you if he does. > > Charlie > > On 8/10/2018 7:52 AM, Tracy Crook wrote: > > Thank you guys. Ah, the things you forget after 17 years (holy =F0=9F=92 =A9, been > that long?). > > I had recently pulled a tank on the -4 which doesn=99t have the bra ces. I > should be able to get it from this info but thanks for offer of the plans > Charlie. > > A copy of RV8 plans showing PN of left forward & bottom fwd. fuse parts > would be handy if anyone has it scanned. Will be ready to order parts so on. > > Tracy Crook > > > Sent from my iPad > > On Aug 9, 2018, at 18:14, Charlie England wrote: > > Hey Tracy, > > Same tank as the -7, AFAIK. The z brackets are behind every rib, if memor y > serves. I think I can email you that page from the -7 plans, if you want. > > You can slip stuff like old credit cards or other thin items between the > back edge of the tank & the spar to lift the dimples prior to removing th e > tank. I've pulled the tanks on the -4 several times. I usually pull out t he > root end slightly first, using a wedge between the nose attach angles. > Then, if needed, I wedge something in the slight V between the other end of > the tank skin and the wing leading edge skin, and push the root end back > aft. This will shift the tank inboard and move the outboard end forward > slightly. Makes the rest of the removal go easier for me. > > Charlie > > On 8/9/2018 6:21 PM, Tcwtech wrote: > > There are like 12 or 15 bolts AN-3 through the back of the spar and into z > brackets on the back of the tank. All accessed through the inspection > hatches. > > Bob Newman > TCW Technologies, LLC > 610-928-3420 > > On Aug 9, 2018, at 6:15 PM, Tracy Crook wrote: > > Working on the takeoff damage to the RV-8 and need to remove the tank for > access and to repair the tank damage. I=99ve removed all the screw s around > the perimeter of the tank and the three 3/16=9D bolts at the root i nto the > spar web. . That=99s all I recall holding on the tank but it refus es to > budge more than maybe .03=9D away from its position. > > Are there any other fasteners holding the tank on? I=99m in CO awa y from my > plans. Any ideas on tank removal if that=99s not the problem? > > Thanks for any info or suggestions, > Tracy Crook > > > Virus-free . > www.avast.com > > <#m_-7912319691652924726_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> > > ________________________________________________________________________________
Date: Aug 10, 2018
Thanks Charlie. The thumb drive is a perfect solution. It will be here by t he time I need it. Tracy > On Aug 10, 2018, at 08:46, Charlie England wrote: > > No joy on the soft copy, but he's built/rebuilt several -8s. Want me to se e if he has an extra set of printed plans he'd sell, if no one can send you a pdf of those pages? > >> On Fri, Aug 10, 2018 at 9:21 AM, Charlie England w rote: >> It's not as good as having the paper plans to spread out in front of you, but you can get a thumb drive containing the entire manual from Van's for a bout $10. Find a laptop & copy it to the cloud, & copy back to your ipad. >> >> I'll check with Andy to see if he has a 'soft' copy, and email those page s to you if he does. >> >> Charlie >> >>> On 8/10/2018 7:52 AM, Tracy Crook wrote: >>> Thank you guys. Ah, the things you forget after 17 years (holy =F0=9F=92 =A9, been that long?). >>> >>> I had recently pulled a tank on the -4 which doesn=99t have the br aces. I should be able to get it from this info but thanks for offer of the plans Charlie. >>> >>> A copy of RV8 plans showing PN of left forward & bottom fwd. fuse parts w ould be handy if anyone has it scanned. Will be ready to order parts soon. >>> >>> Tracy Crook >>> >>> >>> >>> Sent from my iPad >>> >>> On Aug 9, 2018, at 18:14, Charlie England wrote: >>> >>>> Hey Tracy, >>>> >>>> Same tank as the -7, AFAIK. The z brackets are behind every rib, if mem ory serves. I think I can email you that page from the -7 plans, if you want . >>>> >>>> You can slip stuff like old credit cards or other thin items between t he back edge of the tank & the spar to lift the dimples prior to removing th e tank. I've pulled the tanks on the -4 several times. I usually pull out th e root end slightly first, using a wedge between the nose attach angles. The n, if needed, I wedge something in the slight V between the other end of the tank skin and the wing leading edge skin, and push the root end back aft. T his will shift the tank inboard and move the outboard end forward slightly. M akes the rest of the removal go easier for me. >>>> >>>> Charlie >>>> >>>>> On 8/9/2018 6:21 PM, Tcwtech wrote: >>>>> There are like 12 or 15 bolts AN-3 through the back of the spar and in to z brackets on the back of the tank. All accessed through the inspection hatches. >>>>> >>>>> Bob Newman >>>>> TCW Technologies, LLC >>>>> 610-928-3420 >>>>> >>>>> On Aug 9, 2018, at 6:15 PM, Tracy Crook wrote: >>>>> >>>>>> Working on the takeoff damage to the RV-8 and need to remove the tank for access and to repair the tank damage. I=99ve removed all the scr ews around the perimeter of the tank and the three 3/16=9D bolts at th e root into the spar web. . That=99s all I recall holding on the tank but it refuses to budge more than maybe .03=9D away from its position . >>>>>> >>>>>> Are there any other fasteners holding the tank on? I=99m in CO away from my plans. Any ideas on tank removal if that=99s not the pr oblem? >>>>>> >>>>>> Thanks for any info or suggestions, >>>>>> Tracy Crook >>>>>> >>>> >>>> >>>> Virus-free. www.avast.com >> > ________________________________________________________________________________
Subject: Re: RV8-List Digest: 0 Msgs - 08/12/18
Date: Aug 13, 2018
anyone ever changed out the Vans fuel valve for an Andair in RV10? Would appreciate some feedback if so..Thanks Al Dilger L45 > On Aug 12, 2018, at 23:42, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-08-12&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-08-12&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Sun 08/12/18: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > ________________________________________________________________________________
Date: Aug 13, 2018
Not sure you intended this for the RV-8 list. Yes, many RV-10 builders including myself have installed the Andair valve. Best done with the shaft extension. Kelly On 8/13/2018 4:02 PM, Al Dilger wrote: > > anyone ever changed out the Vans fuel valve for an Andair in RV10? > Would appreciate some feedback if so..Thanks > Al Dilger > L45 > >> On Aug 12, 2018, at 23:42, RV8-List Digest Server wrote: >> >> * >> >> ================================================= >> Online Versions of Today's List Digest Archive >> ================================================= >> >> Today's complete RV8-List Digest can also be found in either of the >> two Web Links listed below. The .html file includes the Digest formatted >> in HTML for viewing with a web browser and features Hyperlinked Indexes >> and Message Navigation. The .txt file includes the plain ASCII version >> of the RV8-List Digest and can be viewed with a generic text editor >> such as Notepad or with a web browser. >> >> HTML Version: >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-08-12&Archive=RV8 >> >> Text Version: >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-08-12&Archive=RV8 >> >> >> =============================================== >> EMail Version of Today's List Digest Archive >> =============================================== >> >> >> ---------------------------------------------------------- >> RV8-List Digest Archive >> --- >> Total Messages Posted Sun 08/12/18: 0 >> ---------------------------------------------------------- >> >> >> Today's Message Index: >> ---------------------- >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Sep 09, 2018
Subject: Auto Response: RV8-List Digest: 0 Msgs - 09/08/18
Thank you for the email. Please know that Howard has passed away. If you are NOT a solicitor, please contact his wife Judy at tudulu2(at)aol.com ________________________________________________________________________________
Subject: Re: RV8-List Digest: 0 Msgs - 09/12/18
Date: Sep 13, 2018
Anyone changed a fuel selector valve on RV10? need some advice thanks Al Dilger L45 Bakersfield CA > On Sep 12, 2018, at 23:43, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-09-12&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-09-12&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Wed 09/12/18: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > ________________________________________________________________________________
Subject: Re: RV8-List Digest: 0 Msgs - 10/08/18
Date: Oct 09, 2018
Have a friends RV10 with two rivets on left wing fuel tank ( top inboard fwd under wing walk) which are leaking fuel, very slight leak, only when tank is full. Anyone have any luck with this ? Word from Vans is the stiffeners are not attached to the rib so it has become a small problem from people walking on that part of the wing getting in and out causes the rivets to stretch. Im thinking of trying Permatex Thread Sealant or Loctite 290 first then Pro Seal if they dont work. (also looking at Click Bond Patch) prior to doing the complete removal of tank etc. Would appreciate any input from anyone who has experienced this. Thanks AL DILGER L45 RV8A N315DF > On Oct 8, 2018, at 23:42, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-10-08&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-10-08&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Mon 10/08/18: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > ________________________________________________________________________________
Date: Oct 14, 2018
Subject: Re: RV8-List Digest: 0 Msgs - 10/13/18
Had. Fuel drain leak on my leg strut and wheel pants Blue dye for a week........ (RV8A) Tried everything, acetone, alcohol, 100LL, carb cleaner best so far but still not getting it, anyone have any idea. Took them off letting them soak in the sun, but I think Im just going to have to repaint them. Bummer! Thx for any suggestions Sent from my iPad > On Oct 13, 2018, at 23:42, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-10-13&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-10-13&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Sat 10/13/18: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > ________________________________________________________________________________
Date: Oct 14, 2018
100LL dye will stain to a limited degree. 100LL will remove most of it with the least paint damage. MEK will be a bit stronger in removal, but can attack some paints as well. On 10/14/2018 3:22 PM, Al Dilger wrote: > > Had. Fuel drain leak on my leg strut and wheel pants > Blue dye for a week........ (RV8A) > Tried everything, acetone, alcohol, 100LL, carb cleaner best so far but still not getting it, anyone have any idea. > Took them off letting them soak in the sun, but I think Im just going > to have to repaint them. > Bummer! > Thx for any suggestions > Sent from my iPad > >> On Oct 13, 2018, at 23:42, RV8-List Digest Server wrote: >> >> * >> >> ================================================= >> Online Versions of Today's List Digest Archive >> ================================================= >> >> Today's complete RV8-List Digest can also be found in either of the >> two Web Links listed below. The .html file includes the Digest formatted >> in HTML for viewing with a web browser and features Hyperlinked Indexes >> and Message Navigation. The .txt file includes the plain ASCII version >> of the RV8-List Digest and can be viewed with a generic text editor >> such as Notepad or with a web browser. >> >> HTML Version: >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-10-13&Archive=RV8 >> >> Text Version: >> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-10-13&Archive=RV8 >> >> >> =============================================== >> EMail Version of Today's List Digest Archive >> =============================================== >> >> >> ---------------------------------------------------------- >> RV8-List Digest Archive >> --- >> Total Messages Posted Sat 10/13/18: 0 >> ---------------------------------------------------------- >> >> >> Today's Message Index: >> ---------------------- >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Oct 15, 2018
Try going easy on it with lacquer thinner. Chris Sent from my iPhone > On Oct 14, 2018, at 8:46 PM, Kelly McMullen wrote: > > > 100LL dye will stain to a limited degree. 100LL will remove most of it with the least paint damage. MEK will be a bit stronger in removal, but can attack some paints as well. > >> On 10/14/2018 3:22 PM, Al Dilger wrote: >> Had. Fuel drain leak on my leg strut and wheel pants >> Blue dye for a week........ (RV8A) >> Tried everything, acetone, alcohol, 100LL, carb cleaner best so far but still not getting it, anyone have any idea. >> Took them off letting them soak in the sun, but I think Im just going >> to have to repaint them. >> Bummer! >> Thx for any suggestions >> Sent from my iPad >>> On Oct 13, 2018, at 23:42, RV8-List Digest Server wrote: >>> >>> * >>> >>> ================================================= >>> Online Versions of Today's List Digest Archive >>> ================================================= >>> >>> Today's complete RV8-List Digest can also be found in either of the >>> two Web Links listed below. The .html file includes the Digest formatted >>> in HTML for viewing with a web browser and features Hyperlinked Indexes >>> and Message Navigation. The .txt file includes the plain ASCII version >>> of the RV8-List Digest and can be viewed with a generic text editor >>> such as Notepad or with a web browser. >>> >>> HTML Version: >>> >>> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-10-13&Archive=RV8 >>> >>> Text Version: >>> >>> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-10-13&Archive=RV8 >>> >>> >>> =============================================== >>> EMail Version of Today's List Digest Archive >>> =============================================== >>> >>> >>> ---------------------------------------------------------- >>> RV8-List Digest Archive >>> --- >>> Total Messages Posted Sat 10/13/18: 0 >>> ---------------------------------------------------------- >>> >>> >>> Today's Message Index: >>> ---------------------- >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> > > > ________________________________________________________________________________
Date: Oct 14, 2018
Going out on a limb here but toothpaste or a very light rubbing compound ( auto parts store detailing section) might save the day here Sent from my iPhone > On Oct 15, 2018, at 09:15, Chris Lynch wrote: > > > Try going easy on it with lacquer thinner. > Chris > > Sent from my iPhone > >> On Oct 14, 2018, at 8:46 PM, Kelly McMullen wrote: >> >> >> 100LL dye will stain to a limited degree. 100LL will remove most of it with the least paint damage. MEK will be a bit stronger in removal, but can attack some paints as well. >> >>> On 10/14/2018 3:22 PM, Al Dilger wrote: >>> Had. Fuel drain leak on my leg strut and wheel pants >>> Blue dye for a week........ (RV8A) >>> Tried everything, acetone, alcohol, 100LL, carb cleaner best so far but still not getting it, anyone have any idea. >>> Took them off letting them soak in the sun, but I think Im just going >>> to have to repaint them. >>> Bummer! >>> Thx for any suggestions >>> Sent from my iPad >>>> On Oct 13, 2018, at 23:42, RV8-List Digest Server wrote: >>>> >>>> * >>>> >>>> ================================================= >>>> Online Versions of Today's List Digest Archive >>>> ================================================= >>>> >>>> Today's complete RV8-List Digest can also be found in either of the >>>> two Web Links listed below. The .html file includes the Digest formatted >>>> in HTML for viewing with a web browser and features Hyperlinked Indexes >>>> and Message Navigation. The .txt file includes the plain ASCII version >>>> of the RV8-List Digest and can be viewed with a generic text editor >>>> such as Notepad or with a web browser. >>>> >>>> HTML Version: >>>> >>>> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-10-13&Archive=RV8 >>>> >>>> Text Version: >>>> >>>> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-10-13&Archive=RV8 >>>> >>>> >>>> =============================================== >>>> EMail Version of Today's List Digest Archive >>>> =============================================== >>>> >>>> >>>> ---------------------------------------------------------- >>>> RV8-List Digest Archive >>>> --- >>>> Total Messages Posted Sat 10/13/18: 0 >>>> ---------------------------------------------------------- >>>> >>>> >>>> Today's Message Index: >>>> ---------------------- >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >> >> >> > > > > ________________________________________________________________________________
Date: Oct 15, 2018
I think you might remove the stain with more fuel. It will pick up the dye then wipe immediately with a cleaner of some sort. I would try that before painting again. On Sun, Oct 14, 2018 at 9:25 PM S H wrote: > > Going out on a limb here but toothpaste or a very light rubbing compound ( > auto parts store detailing section) might save the day here > > Sent from my iPhone > > > On Oct 15, 2018, at 09:15, Chris Lynch wrote: > > > > > > Try going easy on it with lacquer thinner. > > Chris > > > > Sent from my iPhone > > > >> On Oct 14, 2018, at 8:46 PM, Kelly McMullen > wrote: > >> > >> > >> 100LL dye will stain to a limited degree. 100LL will remove most of it > with the least paint damage. MEK will be a bit stronger in removal, but c an > attack some paints as well. > >> > >>> On 10/14/2018 3:22 PM, Al Dilger wrote: > >>> Had. Fuel drain leak on my leg strut and wheel pants > >>> Blue dye for a week.......=F0=9F=98-. (RV8A) > >>> Tried everything, acetone, alcohol, 100LL, carb cleaner best so far > but still not getting it, anyone have any idea. > >>> Took them off letting them soak in the sun, but I think I=99m j ust going > >>> to have to repaint them. > >>> Bummer! > >>> Thx for any suggestions > >>> Sent from my iPad > >>>> On Oct 13, 2018, at 23:42, RV8-List Digest Server < > rv8-list(at)matronics.com> wrote: > >>>> > >>>> * > >>>> > >>>> ====================== == > >>>> Online Versions of Today's List Digest Archive > >>>> ====================== == > >>>> > >>>> Today's complete RV8-List Digest can also be found in either of the > >>>> two Web Links listed below. The .html file includes the Digest > formatted > >>>> in HTML for viewing with a web browser and features Hyperlinked > Indexes > >>>> and Message Navigation. The .txt file includes the plain ASCII > version > >>>> of the RV8-List Digest and can be viewed with a generic text editor > >>>> such as Notepad or with a web browser. > >>>> > >>>> HTML Version: > >>>> > >>>> > http://www.matronics.com/digest/digestview.php?Style=82701&View=html& Chapter 18-10-13&Archive=RV8 > >>>> > >>>> Text Version: > >>>> > >>>> > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&C hapter 18-10-13&Archive=RV8 > >>>> > >>>> > >>>> ====================== > >>>> EMail Version of Today's List Digest Archive > >>>> ====================== > >>>> > >>>> > >>>> ---------------------------------------------------------- > >>>> RV8-List Digest Archive > >>>> --- > >>>> Total Messages Posted Sat 10/13/18: 0 > >>>> ---------------------------------------------------------- > >>>> > >>>> > >>>> Today's Message Index: > >>>> ---------------------- > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >> > >> > >> > > > > > > > > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Oct 15, 2018
Subject: Re: 100LL Stain
Al, I use 100LL to remove 100LL. Stan Sutterfield ________________________________________________________________________________
Subject: Re: RV8-List Digest: 2 Msgs - 10/15/18
Date: Oct 16, 2018
thanks for all the suggestions, nothing has helped, using gas only removes what hasnt been on too long. think it sat for over a week before I saw it just going to repaint them. (could not find MEKthank you California!!!) > On Oct 15, 2018, at 23:43, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-10-15&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-10-15&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Mon 10/15/18: 2 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 05:04 AM - Re: Re: RV8-List Digest: 0 Msgs - 10/13/18 (Jim Combs) > 2. 10:54 AM - Re: 100LL Stain (speedy11(at)aol.com) > > > > ________________________________ Message 1 _____________________________________ > > > From: Jim Combs <jiminlexky(at)gmail.com> > Subject: Re: RV8-List: Re: RV8-List Digest: 0 Msgs - 10/13/18 > > I think you might remove the stain with more fuel. It will pick up the dye > then wipe immediately with a cleaner of some sort. I would try that before > painting again. > > On Sun, Oct 14, 2018 at 9:25 PM S H wrote: > >> >> Going out on a limb here but toothpaste or a very light rubbing compound > ( >> auto parts store detailing section) might save the day here >> >> Sent from my iPhone >> >>> On Oct 15, 2018, at 09:15, Chris Lynch wrote: >>> >>> >>> Try going easy on it with lacquer thinner. >>> Chris >>> >>> Sent from my iPhone >>> >>>> On Oct 14, 2018, at 8:46 PM, Kelly McMullen >> wrote: >>>> >>>> >>>> 100LL dye will stain to a limited degree. 100LL will remove most of it >> with the least paint damage. MEK will be a bit stronger in removal, but c > an >> attack some paints as well. >>>> >>>>> On 10/14/2018 3:22 PM, Al Dilger wrote: >>>>> Had. Fuel drain leak on my leg strut and wheel pants >>>>> Blue dye for a week.......=F0=9F=98-. (RV8A) >>>>> Tried everything, acetone, alcohol, 100LL, carb cleaner best so far >> but still not getting it, anyone have any idea. >>>>> Took them off letting them soak in the sun, but I think I=99m j > ust going >>>>> to have to repaint them. >>>>> Bummer! >>>>> Thx for any suggestions >>>>> Sent from my iPad >>>>>> On Oct 13, 2018, at 23:42, RV8-List Digest Server < >> rv8-list(at)matronics.com> wrote: >>>>>> >>>>>> * >>>>>> >>>>>> ===================== > = >>>>>> Online Versions of Today's List Digest Archive >>>>>> ===================== > = >>>>>> >>>>>> Today's complete RV8-List Digest can also be found in either of the >>>>>> two Web Links listed below. The .html file includes the Digest >> formatted >>>>>> in HTML for viewing with a web browser and features Hyperlinked >> Indexes >>>>>> and Message Navigation. The .txt file includes the plain ASCII >> version >>>>>> of the RV8-List Digest and can be viewed with a generic text editor >>>>>> such as Notepad or with a web browser. >>>>>> >>>>>> HTML Version: >>>>>> >>>>>> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=html& > Chapter 18-10-13&Archive=RV8 >>>>>> >>>>>> Text Version: >>>>>> >>>>>> >> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&C > hapter 18-10-13&Archive=RV8 >>>>>> >>>>>> >>>>>> ===================== > >>>>>> EMail Version of Today's List Digest Archive >>>>>> ===================== > >>>>>> >>>>>> >>>>>> ---------------------------------------------------------- >>>>>> RV8-List Digest Archive >>>>>> --- >>>>>> Total Messages Posted Sat 10/13/18: 0 >>>>>> ---------------------------------------------------------- >>>>>> >>>>>> >>>>>> Today's Message Index: >>>>>> ---------------------- >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>> >>>> >>>> >>> >>> >>> >>> >> > ========== > ========== > ========== > ========== > ========== >> >> > > ________________________________ Message 2 _____________________________________ > > > From: speedy11(at)aol.com > Subject: RV8-List: Re: 100LL Stain > > Al, > > > I use 100LL to remove 100LL. > > > Stan Sutterfield > > > > > > > ________________________________________________________________________________
Subject: Re: RV8-List Digest: 0 Msgs - 10/18/18
Date: Oct 19, 2018
Anybody have a mod for the rear seat side panels on RV8A ? Where flap actuator rods are, wasted much needed storage space, trying to get some ideas Thx N315DF L45 Bakersfield CA > On Oct 18, 2018, at 23:42, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-10-18&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-10-18&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Thu 10/18/18: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > ________________________________________________________________________________
Date: Oct 21, 2018
Subject: Re: RV8-List Digest: 1 Msgs - 10/19/18
Al, In the front seat, I hinged my arm rests inboard and placed a "drop down" CB tray underneath. One could easily do the same thing in either cockpit and add a storage box under it. I also added small storage compartments below the rear cockpit throttle and on the opposite side, as well, but they proved to be not very useful. If you want photos send me a note at my email. Regards, Stam Sutterfield From: Al Dilger <avdilger(at)yahoo.com> Subject: RV8-List: Re: RV8-List Digest: 0 Msgs - 10/18/18 Anybody have a mod for the rear seat side panels on RV8A ? Where flap actuator rods are, wasted much needed storage space, trying to get some ideas Thx N315DF L45 Bakersfield CA ________________________________________________________________________________
Date: Oct 27, 2018
Subject: 3D Model of RV-8 for Home Designer Pro...?
Does Anyone have a 3D model of an RV-8 or RV-4 for Home Designer Pro? A Cessna 210, the only airplane that comes with, but, meh.... Thanks! Matt Dralle Emacs! - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 210+ Hours TTSN - Version 2.0 Now Flying! RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 300+ Hours - Full Flyer Mode! RV-4 #1763 N804RV "The Kiss me Kate" http://www.mattsrv4.com Status: Electrical and Instrument Panel... Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Subject: Re: 3D Model of RV-8 for Home Designer Pro...?
Date: Oct 27, 2018
Nothing in the email, Matt. grumpy > On Oct 27, 2018, at 1:44 PM, Matt Dralle wrote: > ________________________________________________________________________________
Date: Oct 27, 2018
Attachment was inline. Here's a bitmap file attachment. Sample of Home Designer Pro of my hangar/workshop design. Need an RV-8 in there not a C-210... ;-P https://www.homedesignersoftware.com/products/home-designer-pro/?gclid=CjwKCAjwmdDeBRA8EiwAXlarFuCfLeiSk7xntqgnrJm4-oGrxSzbAXbFNcLhUmMZUwNSgqAEgx3ykBoCDscQAvD_BwE At 11:53 AM 10/27/2018 Saturday, John Miller wrote: > >Nothing in the email, Matt. > >grumpy > >> On Oct 27, 2018, at 1:44 PM, Matt Dralle wrote: >> Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 01, 2018
Subject: PLEASE READ - Matronics Email List 2018 Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are 9 great gifts to choose from! There's something for everyone, to be sure. Please make your List Contribution using any one of three secure methods including using a Credit Card, PayPal, or by Personal Check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 03, 2018
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 03, 2018
Subject: Re: Please Make A Contribution To Support Your Lists
Please remove from all lists Sent from my iPhone > On Nov 3, 2018, at 11:11 AM, Matt Dralle wrote: > > > Dear Listers, > > There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. > > Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! > > You may use a Credit Card or Paypal at the Matronics Contribution Site here: > > http://www.matronics.com/contribution > > or, you can send a personal check to the following address: > > Matronics / Matt Dralle > 581 Jeannie Way > Livermore, CA 94550 > > Thank you in advance for your generous support! > > Matt Dralle > Matronics Email List and Forum Administrator > > > > > > > ________________________________________________________________________________
Date: Nov 05, 2018
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2018
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that ilk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, Commercial-greade Internet Connection, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 09, 2018
Subject: List Contribution - Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 11, 2018
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 13, 2018
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 15, 2018
Subject: Make Sure You're Listed! List of Contributors Coming Soon!
Dear Listers, There's just two more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 17, 2018
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 19, 2018
Subject: LOC
Dear Listers, Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by popping a personal check in the mail to: Matronics Email Lists c/o Matt Dralle 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 21, 2018
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 23, 2018
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 25, 2018
Date: Nov 27, 2018
Subject: What's My Contribution Used For?
Dear Listers, Some have asked, "What's my Contribution used for?" and that's a good question. Here are just a few examples of what your direct List support enables. It provides for the very expensive, commercial-grade Internet connection used on the List insuring maximum performance and minimal contention when accessing List services. It pays for the regular system hardware and software upgrades enabling the highest performance possible for services such as the Archive Search Engine, List Browser, and Forums. It pays for narly 30 years (yeah, I really said *30* years) worth of online archive data available for instant random search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power this List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. How many places on the Internet can you make all those statements these days? It is YOUR CONTRIBUTION that directly enables these many aspects of these valuable List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport... List Contribution Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2018
Dear Listers, There are just a Two days left for this year's List Fund Raiser! If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2018
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 55! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 19, 2018
Subject: 2018 List of Contributors
Dear Listers, The 2018 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 And finally, I'm proud to present The 2018 Fund Raiser List of Contributors: http://www.matronics.com/loc Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Subject: unsuscribe
Date: Feb 23, 2019
Germn Walas www.globalworld.com.ar >From USA (+01) 786-207-4816 Desde Arg. (+54) 11 5-984-1301 Skype: gwalas www.linkedin.com/in/germanwalas/ -----Original Message----- From: owner-rv8-list-server(at)matronics.com On Behalf Of RV8-List Digest Server Sent: Saturday, February 23, 2019 2:43 AM Subject: RV8-List Digest: 0 Msgs - 02/22/19 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV8-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV8-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-02-22&Archive=RV8 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 2019-02-22&Archive=RV8 =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV8-List Digest Archive --- Total Messages Posted Fri 02/22/19: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________________
Date: May 03, 2019
Great post.Thanks for sharing :) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=489083#489083 ________________________________________________________________________________
Date: May 29, 2019
Subject: Sat Jun 1st Fly in L45 Bakersfield
Sent from my iPad ________________________________________________________________________________
Subject: Re: RV8-List Digest: 0 Msgs - 10/04/19
Date: Oct 05, 2019
Anyone have a line on Canopy release handle for back seat pax on RV8A? Appreciate any input Thx Al Dilger N315DF Sent from my iPad > On Oct 4, 2019, at 11:43 PM, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 19-10-04&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 19-10-04&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Fri 10/04/19: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > ________________________________________________________________________________
Date: Oct 05, 2019
Date: Oct 06, 2019
Subject: Re: Rear Seat Canopy Release Handle
Al,What I tell my passengers is, if I am unable to help, to reach forward t o open the canopy using the front seat handle.=C2- If you sit in the rear seat you should find that the forward handle is reachable.=C2- Even some one who is short, such as a child, can reach it.=C2- In fact, small peopl e can reach it easier because they can squeeze forward easier than large pe ople.=C2- Adults should have no problem reaching the handle.I tell them t o turn the handle 90 degrees counterclockwise to release and then pull symm etrically on both sides of the canopy.I also keep a canopy breaker tool in the cockpit for them to use in case the airplane is inverted and resting on the canopy, thus making it difficult to slide even though they can reach t he handle.As far as a secondary handle added for the rear seat, I have not heard of anyone doing that.Regards,=C2-Stan Sutterfield Subject: RV8-List: Re: RV8-List Digest: 0 Msgs - 10/04/19 From: al dilger <avdilger(at)yahoo.com> Anyone have a line on Canopy release handle for back seat pax on RV8A? Appreciate any input Thx Al Dilger N315DF ________________________________________________________________________________
Date: Nov 01, 2019
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are 9 great gifts to choose from! There's something for everyone, to be sure. Please make your List Contribution using any one of three secure methods including using a Credit Card, PayPal, or by Personal Check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Builder-Pilot ________________________________________________________________________________
Date: Nov 01, 2019
Subject: PLEASE READ - Matronics Email List 2019 Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are 12 great gifts to choose from! There's something for everyone, to be sure. Please make your List Contribution using any one of three secure methods including using a Credit Card, PayPal, or by Personal Check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Builder-Pilot ________________________________________________________________________________
Date: Nov 03, 2019
Date: Nov 03, 2019
Please take me off your lists, no more RV's.=C2- Thanks, Ray Grenier -----Original Message----- From: Matt Dralle <dralle(at)matronics.com> Sent: Sun, Nov 3, 2019 6:50 am Subject: RV8-List: Please Make A Contribution To Support Your Lists Dear Listers, There is no advertising income to support the Matronics Email Lists and For ums.=C2- The operation is supported 100% by your personal Contributions d uring the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services.=C2- You can pick up a really nice gift for mak ing your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here : =C2- =C2- =C2- =C2- http://www.matronics.com/contribution or, you can send a personal check to the following address: =C2- =C2- =C2- =C2- Matronics / Matt Dralle =C2- =C2- =C2- =C2- 581 Jeannie Way =C2- =C2- =C2- =C2- Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Nov 05, 2019
Date: Nov 07, 2019
Date: Nov 09, 2019
Date: Nov 11, 2019
Date: Nov 13, 2019
Dear Listers, There's just a few more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 14, 2019
Subject: Value of the List...
Date: Nov 17, 2019
Subject: Re: Performance Numbers - IO-390/Hartzell/RV-8
Date: Nov 18, 2019
How many numbers... Numbers are one of the most common mysteries of mankind. Every number you meet in your life means something specific. This is called numerology. I believe in numbers and that they have energy. As strange as it may sound my words - I'm not crazy) If you want to read about numbers - go here https://www.sunsigns.org/angel-number-555-meaning/ and find out what they stand for. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=493102#493102 ________________________________________________________________________________
Date: Nov 19, 2019
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 21, 2019
Subject: Reminder
Dear Listers, A quick reminder that November is the annual List Fund Raiser. The Matronics Lists are 100% member supported and all of the operational costs are provided for my your Contributions during this time of the year. Your personal Contribution makes a big difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running! http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 23, 2019
Subject: [Please Read] What are "The Lists" and Who's This Matt Dralle?
Dear Listers, Who is Matt Dralle and what exactly are these Lists? Well, I've been working in the information technology industry for over 35 years primarily in computer networking design and implementation. I have also done extensive work in web development and CGI design during that time, along with a fair amount of embedded system and software development as well. I started the Matronics Email Lists back in 1990 with about 30 fellow RV builders from around the world. Since that time, I have added 80 other kinds of aircraft related Lists to the line up and numerous other List related services such as the Forums, Wiki, Archives and Search Engine just to name a few. For flexibility and reliability, I have chosen to run all of my own servers here locally. Other List-related systems include a 1 Gigabit, fully switched network infrastructure, a commercial-grade Netscreen firewall, a Barracuda spam filter, a local 1G Internet router, and a commercial-grade business 1Gb/s Internet connection with full static addressing. The computer servers found here include a quad-processor Xeon Linux server for List web services, a dual-processor Xeon Linux system dedicated to the email processing List functions, and another P4 Linux system serving as a remote storage disk farm for the archives, databases, and for an on-line hard drive-based backup system with 3.2 Terra Bytes of storage! This entire system is protected by three large, commercial-grade uninterrupted power supply (UPS) systems that assure the Lists are available even during a local power outage! Speaking of power, imagine how much electricity it takes to run all of these systems. One month a couple of Summers ago, I had a staggering $1368 bill for electricity alone! Recently, I upgraded all of the computer racking infrastructure including new power feeds and dedicated air conditioning for the room that serves as the Computer Center for the Matronics Email Lists. As you can see, I take running these Lists very seriously and I am dedicated to providing an always-on, 24x7x365 experience for each and every Lister. But, building and running this system isn't cheap. As I've stated before, I don't support any of these systems with commercial advertising on the Lists. It is supported 100% through List member Contributions! That means you... and you... and YOU! To that end, I hold a List Fund Raiser each November and ask that members make a small Contribution to support the continued operation and upgrade of this ever-expanding system. Its solely YOUR Contributions that keeps it running! Won't you please take a moment to make a Contribution to support these Lists! http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550-7227 USA There are some great gifts available with qualifying Contribution levels too! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 25, 2019
Dear Listers, The List of Contributors (LOC) is just around the corner with just few more days in this year's Fund Raiser! Later in December I will post a list of everyone that so generously made a Contribution to support the Lists this year. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 25, 2019
Subject: Re: Make Sure You're Listed!
Please unsubscribe me from all lists. Thank you Sent from my iPhone > On Nov 25, 2019, at 1:13 PM, Matt Dralle wrote: > > > Dear Listers, > > The List of Contributors (LOC) is just around the corner with just few more days in this year's Fund Raiser! Later in December I will post a list of everyone that so generously made a Contribution to support the Lists this year. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. > > Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. > > Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: > > http://www.matronics.com/contribution > > Or, by dropping a personal check in the mail to: > > Matt Dralle / Matronics > 581 Jeannie Way > Livermore CA 94550 > > I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! > > Thank you! > > Matt Dralle > Matronics Email List Administrator > > > > > ________________________________________________________________________________
Date: Nov 28, 2019
Subject: What Are You Thankful For...?
Dear Listers, Here in the United States, Thursday is our National day of Thanksgiving. Many of us will be traveling to be with our families and friends to share in generous feasts of plenty and giving thanks for many blessings that have been bestowed upon us. Many Listers have expressed over the last couple of weeks how thankful they are for the Email Lists and Forums here on the Matronics servers and for all of the assistance and comradery they have experienced being a part of the Lists. One of my favorite kind of comments is when write to me and says something like, "Its the first thing I do in the morning while I'm having my morning coffee!". That's a wonderful tribute to the purpose and function of these Lists. Its always great to hear I'm not the only one that jumps out of bed each morning to check my List email!! Won't you take a minute today and show your appreciation for these Lists and for their continued operation and upgrade? The List Contribution Site is: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you in advance for your kind consideration, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2019
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 56! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 27, 2019
Subject: 2019 List of Contributors
Dear Listers, The 2019 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 And finally, I'm proud to present The 2019 Fund Raiser List of Contributors: http://www.matronics.com/loc Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Subject: Re: RV8-List Digest: 0 Msgs - 01/24/20
Date: Jan 25, 2020
Hi All, Well Im ticked off, went to hanger today to do a breakfast flight, left main fuel drain dripped fuel, stained the gear leg fairing (white epoxy paint). Had this happen once before..I seldom ever drain the sumps in my RV8A because in almost seven years I have never had any water or sediment. The last time I did it I thought, "well its been years might as well check , drained both, no water no debriscame back a week later, both o rings in both petcocks bad, both gear leg fairings, both wheel pants stained so bad I had to repaint them all. (I found nothing to remove the stain, 100LL worked the best) Now I have to do it again, (at least its only one side) but Im pissed. Im seriously thinking of removing the petcocks and insert plugs then just drain at condition inspection. I wish there were better quality drains or petcocks to avoid this problem. In over 50 years in Aviation been so rare, now twice on my own airplane, petcocks probably made in China. So frustrating Wonder if anyone has seen a cap or plug that covers the petcock so if it does leak slightly it wont stain the paint. Al Dilger Bakersfield CA L45 RV8A N315DF > On Jan 24, 2020, at 23:44, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 20-01-24&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 20-01-24&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Fri 01/24/20: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > ________________________________________________________________________________
Date: Jan 26, 2020
Subject: Re: RV8-List Digest: 1 Msgs - 01/25/20
Al,I have the same frustrations.=C2- And I use the same techniques.I drai n the tanks and replace the sump valves every three years.StanDaytona Beach Hi All, Well Im ticked off, went to hanger today to do a breakfast flight, left main fuel drain dripped fuel, stained the gear leg fairing (white epoxy pai nt). Had this happen once before..I seldom ever drain the sumps in my RV8A becau se in almost seven years I have never had any water or sediment. The last time I did it I thought, "well its been years might as well check , drained both, no water no debriscame back a week later, both o rings in both petcoc ks bad, both gear leg fairings, both wheel pants stained so bad I had to repaint them all. (I found nothing to remove the st ain, 100LL worked the best)=C2- Now I have to do it again, (at least its only one side) but Im pissed. Im seriously thinking of removing the petcocks and insert plugs then just d rain at condition inspection. I wish there were better quality drains or petcocks to avoid this problem. =C2- In over 50 years in Aviation been so rare, now twice on my own airplane, petco cks probably made in China. So frustrating Wonder if anyone has seen a cap or plug that covers the petcock so if it do es leak slightly it wont stain the paint. Al Dilger Bakersfield CA L45 RV8A N315DF ________________________________________________________________________________
Subject: Re: RV8-List Digest: 0 Msgs - 02/07/20
Date: Feb 08, 2020
Hi Folks, I have an RV8A which now for the second time I have had fuel drains leak, not realizing it until days later, fuel dye stain down gear leg fairing and wheel pants. I rarely drain my sumps after years, have never had any water, the two times Ive done it, they leaked. Im aware of sediment or O rings going bad, careful to make sure its reseated after draining (or at least it appears) I have JD Air Parts Drain Fairings on the drains which look nice and are aerodynamically efficient. So after fixing this a second time, by removing the stained fairings, sand and repaint, replaced the drains. I think I found the cause.the Drain Fairings that the drains go through are about .150 thick, which only allowed about .200 of the threads of drain to go into wing (this normally would be ok however I apparently didnt get any thread sealant on those first few threads because I didnt want to get sealant on the O ring.) I removed and replaced the drains without the old drain fairings, so I know there good now. I really do like the looks of the Drain fairings and have found out that JD AirParts have redesigned the Fairings so they are not held on by the drain but with a clamp and set screw. (The old ones required you to take the drain out to get it off the new ones can go on/off without messing with the drain, which was the reason for the redesign) So I will probably order the new ones soon ($68 pair) What brings me to all this is, has anyone had same experience with the stain? The problem of course is the drain sitting directly above the gear leg fairing. I found it impossible to get the stain off, the most effective, was using more fuel but only worked if hadnt been on too long. I tried every cleaner, degreaser, compound etcNothing worked. I am now thinking of Paint Protective Film on the gear leg fairings and wonder if anyone has any input on this. Im going to try this on the workbench first. Also I have cut two pieces of 1/2 plastic tubing about one foot long to place over the drain after flying, while its sitting in the hanger so if it leaks, it drains on the floor and not fairing, Thanks for any input Al Dilger Bakersfield CA L45 N315DF > On Feb 7, 2020, at 23:44, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 20-02-07&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 20-02-07&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Fri 02/07/20: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > ________________________________________________________________________________
Date: Mar 03, 2020
Subject: Test; List Server Issues Resolved...
Dear Listers, The Matronics Email List Server was having some issues and not accepting incoming posts for a couple of days. It is resolved now. Sorry for the hassle... Matt Dralle Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Date: Jun 07, 2020
Subject: A few questions
UlYgOCBsaXN0ZXJzLCBhIGZld8KgcXVlc3Rpb25zIGZvciB5b3VyIGNvbGxlY3RpdmUgd2lzZG9t OjEuIERpZCBhbnlvbmXCoHdyYXAgb3Igb3RoZXJ3aXNlwqBwcm90ZWN0IHRoZSBTQ0FUIHR1Ymlu ZyB0aGF0IHJ1bnMgZnJvbSB0aGUgcmlnaHQgd2luZyBOQUNBIGlubGV0IHRvIHRoZSBmcmVzaCBh aXIgdmVudCBpbiB0aGUgcmVhciBzZWF0PzIuIEhvdyBkaWQgeW91IHJvdXRlIHRoZSBzdGF0aWMg YWlyIHR1YmluZyBmcm9tIHRoZSBidWxraGVhZCBiZWhpbmQgdGhlIHJlYXIgc2VhdCB0byB0aGUg aW5zdHJ1bWVudCBwYW5lbD8zLiBEaWQgeW91IGluc3RhbGwgaW5zdHJ1bWVudHMgb3IgZW5naW5l LyBmaXJld2FsbCBmb3J3YXJkIGZpcnN0P8KgNC4gQW55b25lIGhhdmUgYSBnb29kIG9yIGJhZCBl eHBlcmllbmNlIHdpdGggYW4gQWR2YW5jZWQgRmxpZ2h0IFN5c3RlbXMgcGFuZWw/NS4gSWYgeW91 IGhhdmUgcmVhciBzZWF0IHJ1ZGRlciBwZWRhbHMsIGhvdyBkaWQgeW91IHJvdXRlIHRoZSBjYWJs ZXMgYXJvdW5kIHRoZSByZWFyIGZvb3R3ZWxscz8gQW55IHRyb3VibGUgd2l0aCBnZXR0aW5nIHNt b290aCB0cmF2ZWw/wqA2LiBIYXMgYW55b25lIHVzZWQgYSBEeW5vbiBBb0EgcGl0b3QgdHViZSBh bmQgc3RhdGljIGFpciBzeXN0ZW0gd2l0aCBub24tRHlub24gYXZpb25pY3M/Ny4gQ2FuIEkgcnVu IGNvYXggY2FibGVzIGZvciBib3RoIFZIRiBjb21tIHJhZGlvcyBuZXh0IHRvIGVhY2ggb3RoZXIg b3IgZG8gdGhleSBuZWVkIHNlcGFyYXRpb24/wqBUaGFua3MhIFN0YXkgc2FmZSwgc2FuZSwgYW5k IGhlYWx0aHkgb3V0IHRoZXJlLsKgdi9yLFAywqBTZW50IGZyb20gbXkgR2FsYXh5IFRhYsKuIFMy ________________________________________________________________________________
Date: Jun 12, 2020
Subject: A few questions, take 2
Matt, The last attempt came out as random characters. Can we try again? Much obli ged.=C2- >>>>>>>>>>>>>>>>>>>>>RV 8 listers, a few=C2-questions for your collective wisdom: 1. Did anyone=C2-wrap or otherwise=C2-protect the SCAT tubing that runs from the right wing NACA inlet to the fresh air vent in the rear seat? 2. How did you route the static air tubing from the bulkhead behind the rea r seat to the instrument panel? 3. Did you install instruments or engine/ firewall forward first?=C2- 4. Anyone have a good or bad experience with an Advanced Flight Systems pan el? 5. If you have rear seat rudder pedals, how did you route the cables around the rear footwells? Any trouble with getting smooth travel?=C2- 6. Has anyone used a Dynon AoA pitot tube and static air system with non-Dy non avionics? 7. Can I run coax cables for both VHF comm radios next to each other or do they need separation?=C2- Thanks! Stay safe, sane, and healthy out there.=C2- v/r,P2 ________________________________________________________________________________
Date: Jun 12, 2020
Subject: Re: A few questions, take 2
Quoting pplous(at)aol.com: > 1. Did anyonewrap or otherwiseprotect the SCAT tubing that runs > from the right wing NACA inlet to the fresh air vent in the rear seat? No, figured that the SCAT tubing was enough protection itself. It isn't carrying fuel or electricity, so the worst that could happen is it leaks air. > 2. How did you route the static air tubing from the bulkhead behind > the rear seat to the instrument panel? Didn't route from the back seat to the instrument panel. The plans show a forward NACA intake ahead of the panel for the front seat vent. > 3. Did you install instruments or engine/ firewall forward first? Did engine first and then instruments. Wouldn't have anything to hook up the engine instruments otherwise. > 4. Anyone have a good or bad experience with an Advanced Flight > Systems panel? > 5. If you have rear seat rudder pedals, how did you route the cables > around the rear footwells? Any trouble with getting smooth travel? > 6. Has anyone used a Dynon AoA pitot tube and static air system with > non-Dynon avionics? None of these apply to my plane. > 7. Can I run coax cables for both VHF comm radios next to each other > or do they need separation? Coax is shielded so it should be ok. Checking Aeroelectric connection I don't find anything recommending against it. Brian Huffaker, DSWL RV-8A N609HZ test flying ________________________________________________________________________________
Date: Jun 12, 2020
Check out: http://www.mattsrv8.com Matt RV-8 400+ hours > > > Quoting pplous(at)aol.com: > >> 1. Did anyonewrap or otherwiseprotect the SCAT tubing that runs >> from the right wing NACA inlet to the fresh air vent in the rear seat? > > No, figured that the SCAT tubing was enough protection itself. It > isn't carrying fuel or electricity, so the worst that could happen is > it leaks air. > >> 2. How did you route the static air tubing from the bulkhead behind >> the rear seat to the instrument panel? > > Didn't route from the back seat to the instrument panel. The plans > show a forward NACA intake ahead of the panel for the front seat vent. > >> 3. Did you install instruments or engine/ firewall forward first? > > Did engine first and then instruments. Wouldn't have anything to hook > up the engine instruments otherwise. > >> 4. Anyone have a good or bad experience with an Advanced Flight >> Systems panel? >> 5. If you have rear seat rudder pedals, how did you route the cables >> around the rear footwells? Any trouble with getting smooth travel? >> 6. Has anyone used a Dynon AoA pitot tube and static air system with >> non-Dynon avionics? > > None of these apply to my plane. > > >> 7. Can I run coax cables for both VHF comm radios next to each other >> or do they need separation? > > Coax is shielded so it should be ok. Checking Aeroelectric > connection I don't find anything recommending against it. > > Brian Huffaker, DSWL > RV-8A N609HZ test flying > > -- ________________________________________________________________________________
Date: Jun 13, 2020
I dont get to input to very many of these questions - here is one I can comfortably answer: Re question #7 running coax cables together - I have two coax cables (RG400 - the expensive gold stuff) running together to a Garmin 480 and an SL-30 - in nearly 11 years there has never been a problem - important thing is to terminate the cables correctly - if youre not sure ask for help - and please dont ask how i know that Dan Bergeron 11 years and 863 hours on RV-7A - N307TB > On Jun 12, 2020, at 6:02 PM, bifft(at)xmission.com wrote: > > > > Quoting pplous(at)aol.com: > >> 1. Did anyone wrap or otherwise protect the SCAT tubing that runs from the right wing NACA inlet to the fresh air vent in the rear seat? > > No, figured that the SCAT tubing was enough protection itself. It isn't carrying fuel or electricity, so the worst that could happen is it leaks air. > >> 2. How did you route the static air tubing from the bulkhead behind the rear seat to the instrument panel? > > Didn't route from the back seat to the instrument panel. The plans show a forward NACA intake ahead of the panel for the front seat vent. > >> 3. Did you install instruments or engine/ firewall forward first? > > Did engine first and then instruments. Wouldn't have anything to hook up the engine instruments otherwise. > >> 4. Anyone have a good or bad experience with an Advanced Flight Systems panel? >> 5. If you have rear seat rudder pedals, how did you route the cables around the rear footwells? Any trouble with getting smooth travel? >> 6. Has anyone used a Dynon AoA pitot tube and static air system with non-Dynon avionics? > > None of these apply to my plane. > > >> 7. Can I run coax cables for both VHF comm radios next to each other or do they need separation? > > Coax is shielded so it should be ok. Checking Aeroelectric connection I don't find anything recommending against it. > > Brian Huffaker, DSWL > RV-8A N609HZ test flying > > > > ________________________________________________________________________________
Date: Jun 22, 2020
Subject: After prop overhaul
I may be repeating knowledge already well known but I didn't know. After getting my prop back from overhaul by Sensenich I couldn't get the front spinner plate to align with the spinner. It is attached to the prop dome with 4 capscrews. It seemed that the dome had to be rotated slightly. The Sensenich rep said no don't do that. The problem is that the dome is screwed on and torqued and so doesn't return to the same position it was in when you drilled the holes. He says this is a common problem with some Pipers. The Sensenich solution is to make the holes in the plate into slots. This is what I did. Another solution is to just make a new spinner plate. It only means installing 6 nutplates. cheers Jim ________________________________________________________________________________
Subject: Rv-8 kit for sale
Date: Jun 23, 2020
Hi all, I am about to order and RV8 kit. (I do not want an -A) I would prefer to acquire an in-progress kit if possible. Before I order new, is anyone interested in selling? I am near Waukesha, WI. KUES Thx. Dave Leikam 414-807-5499 ________________________________________________________________________________
Subject: Over 2000 Courtesy Cars
Date: Aug 12, 2020
AirportCourtesyCars.com website has just surpassed over 2000 courtesy car listings at over 1,540 locations nationwide. Listings include pilot comments, car pictures and more. The website is kept updated with new listings and corrections by pilots like you. You can contact the owner, Glenn Brasch with updates at airportcars101(at)gmail.com Funding of the site is dependent mostly on donations, which are much appreciated. -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=497705#497705 ________________________________________________________________________________
Date: Oct 17, 2020
Subject: Re: RV8-List Digest: 0 Msgs - 10/16/20
Has anyone had problems with the Vans supplied throttle/mixture cables for RV 8s'? Both bound up after 8 years, I replaced them and now have an issue with mixture cables' throw reduced to under 2 inches resulting in inability to shut a/c down with mixture. Thanks, Ed Clegg On Sat, Oct 17, 2020 at 2:46 AM RV8-List Digest Server < rv8-list(at)matronics.com> wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 20-10-16&Archive=RV8 > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 20-10-16&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Fri 10/16/20: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > ________________________________________________________________________________
Date: Oct 18, 2020
Subject: Re: RV8-List Digest: 1 Msgs - 10/17/20
Ed,Those cable require regular maintenance.=C2- If you don't they will te nd to bind.=C2- That is true of all cables, not just Van's.Personally I s pray them with Kroil at each annual, and sometime more often.=C2- Sprayin g the outside of the cable housing is sufficient and allow it to creep insi de.=C2- It is easy to see when it has absorbed inside.=C2- There are ce rtain sections of my cables that I can't spray to to limited access, but th ey are mostly straight sections and thus, less likely to bind.Regards,Stan Sutterfield From: edward Clegg <edwclg(at)gmail.com> Subject: RV8-List: Re: RV8-List Digest: 0 Msgs - 10/16/20 Has anyone had problems with the Vans supplied throttle/mixture cables for RV 8s'? Both bound up after 8 years, I replaced them and now have an issue with mixture cables' throw reduced to under 2 inches resulting in inability to shut a/c down with mixture. Thanks, Ed Clegg ________________________________________________________________________________
Date: Oct 19, 2020
Subject: Re: RV8-List Digest: 1 Msgs - 10/18/20
Thanks Stan, The Kroil will actually penetrate the outer cover? Ed On Mon, Oct 19, 2020 at 2:47 AM RV8-List Digest Server < rv8-list(at)matronics.com> wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 20-10-18&Archive=RV8 > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 20-10-18&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Sun 10/18/20: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 03:10 PM - Re: RV8-List Digest: 1 Msgs - 10/17/20 ( > speedy11(at)aol.com) > > > ________________________________ Message 1 > _____________________________________ > > > From: speedy11(at)aol.com > Subject: RV8-List: Re: RV8-List Digest: 1 Msgs - 10/17/20 > > Ed,Those cable require regular maintenance.=C2- If you don't they will te > nd to bind.=C2- That is true of all cables, not just Van's.Personally I s > pray them with Kroil at each annual, and sometime more often.=C2- Sprayin > g the outside of the cable housing is sufficient and allow it to creep insi > de.=C2- It is easy to see when it has absorbed inside.=C2- There are ce > rtain sections of my cables that I can't spray to to limited access, but th > ey are mostly straight sections and thus, less likely to bind.Regards,Stan > Sutterfield > > From: edward Clegg <edwclg(at)gmail.com> > Subject: RV8-List: Re: RV8-List Digest: 0 Msgs - 10/16/20 > > Has anyone had problems with the Vans supplied throttle/mixture cables for > RV 8s'? > Both bound up after 8 years, I replaced them and now have an issue with > mixture cables' throw reduced to under 2 inches resulting in inability to > shut a/c down with mixture. > Thanks, > Ed Clegg > > ________________________________________________________________________________
Date: Oct 20, 2020
Subject: Re: RV8-List Digest: 1 Msgs - 10/19/20
Yes, it will.=C2- Try it.=C2- You will see it soak into the cable housi ng.Stan From: edward Clegg <edwclg(at)gmail.com> Subject: RV8-List: Re: RV8-List Digest: 1 Msgs - 10/18/20 Thanks Stan, The Kroil will actually penetrate the outer cover? Ed ________________________________________________________________________________
Date: Nov 01, 2020
Subject: Matronics List Fund Raiser Postponed During 2020...
Dear Listers, Normally, in November I hold a List Fund Raiser where I ask Listers to make a Contribution to support the operation and upkeep of these List resources. In light of the happenings during this 2020 season, I have decided to postpone the Fund Raiser this year and encourage members to focus on their families and personal needs. I want to thank everyone that has supported the Lists in the past. Despite the uncertain times we're experiencing right now, I want to assure everyone that I fully intend to continue supporting the Lists as I always have; with no anticipated degradation in service levels. Happy Holidays to all my friends around the world! Matt Dralle Matronics List Manager ________________________________________________________________________________
Subject: FS: Lightspeed Dual Plasma III
Date: Dec 11, 2020
Absolutely like new. Comes complete with all wiring harnesses, spark plug leads, 2 extra coils, manual, coils, pick up sensors with mounting brackets, 2 pick up rings (one with magnets at 39 degrees and one at 45 degree). I had high compression pistons and had to have one with different magnet location. 492 hours on system. Performing flawlessly when removed from engine in late November. I just changed engines and my new engine came with Pmags. Email me for photos. len.leggette(at)gmail.com $2000 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=499648#499648 ________________________________________________________________________________
Date: Jan 05, 2021
Subject: Need Built and Tested Left PP QB Fuel Tank for RV-8...
Dear Listers, After my landing mishap in 2011, the replacement left fuel tank I had built for my PP QB RV-8 has big leaks in at least four places. Slosh would probably fix it, but everybody including Van's says "don't slosh!". Does anyone have a lead on a Pre-Punched, preferably Quick Build LEFT Fuel Tank for an RV-8 that is in 10/10 condition? Maybe from an RV-8 that had only right wing damage. I would like a tank that is proven to not leak with no damage, and with a fixed fuel pickup. I would love to get my RV-8 back in the air. The prospect of building a new fuel tank from parts seems daunting and time consuming right now, and prone to dealing with leaks again. Thank you, Matt Dralle RV-8 N998RV http://www.mattsrv8.com ________________________________________________________________________________
Subject: Re: Need Built and Tested Left PP QB Fuel Tank for RV-8...
Date: Jan 05, 2021
Matt, Mooney Aircraft has specified a top coat PR1005 since at least 1975 for all of their fuel tanks. I have had the pleasure of both removing and applying this sealant(as well as a complete reseal of one and partial other tank). PR1005 does none of the bad things alleged by Vans and others. In fact the chemicals that break down the Vans and (Mooney) Proseal (PR1422?) will only soften the PR1005. This Buna N "slosh" coating is best applied with a brush before the tank is closed, or through an access panel. Cleanup is generally MEK or acetone. The procedure to find leaks in a Mooney tank is to open one access panel, apply soapy water solution, close with a scrap piece of plexiglass and duct tape, then pull about 1/2 psi or less vacuum And look for bubbles with a flash light. Where it bubbles is where the leak is. Where the leak shows on the outside is how the fuel runs from inside leak to where it shows outside. The Mooney tank actually gets 3 coats because in the last century they built the wing, then sealed the tanks afterwards...no wet riveting at all. The Coats are PR1422, PR1428 and PR1005. Otherwise known as B compound, A compound and cherry juice. Done right a tank seal was good for at least 20-30 years. I don't know if it is easier to drill out the tank back plate or to cut access panels as needed. Those are Proseal brand numbers. They do cross reference to Flamemaster Chemseal that meets the exact same milspecs for a lot less money. Just another route to solving the problem. I think Vans at one time would sell a built and tested tank for a price. Kelly On 1/5/2021 5:48 PM, Matt Dralle wrote: > > > Dear Listers, > > After my landing mishap in 2011, the replacement left fuel tank I had > built for my PP QB RV-8 has big leaks in at least four places. Slosh > would probably fix it, but everybody including Van's says "don't slosh!". > > Does anyone have a lead on a Pre-Punched, preferably Quick Build LEFT > Fuel Tank for an RV-8 that is in 10/10 condition? Maybe from an RV-8 > that had only right wing damage. I would like a tank that is proven to > not leak with no damage, and with a fixed fuel pickup. > > I would love to get my RV-8 back in the air. The prospect of building a > new fuel tank from parts seems daunting and time consuming right now, > and prone to dealing with leaks again. > > Thank you, > > Matt Dralle > RV-8 N998RV > http://www.mattsrv8.com > > > > > > ________________________________________________________________________________
Subject: Re: RV8-List Digest: 0 Msgs - 02/09/21
Date: Feb 10, 2021
Any RV ers in SOCAL that have purchased a MiniMax Drill powered Tug? I have tried the A2 Best Tug (which is very good but spendy) Id like to know if anyone has had experience with, or owns one for their RV. I have an RV8A and would like to try before I buy..Thanks N315DF Bakersfield CA L45 > On Feb 9, 2021, at 23:44, RV8-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV8-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV8-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 21-02-09&Archive=RV8 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 21-02-09&Archive=RV8 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV8-List Digest Archive > --- > Total Messages Posted Tue 02/09/21: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > ________________________________________________________________________________
Date: Feb 10, 2021
August 05, 2016 - April 09, 2021
RV8-Archive.digest.vol-az
