RV8-Archive.digest.vol-ba
April 09, 2021 - Present
> Today's Message Index:
Im looking for a set of RV-8 ailerons.
Dave Leikam
414-807-5499
Subject: | Re: Major Upgrade to Airport Courtesy Cars Site-Please Read. |
From: | "FrankJScott" <frankjscott38(at)gmail.com> |
For the person asking about cigar humidor sale, davidoff humidor no 4, desktop humidor cherry maple, vigilant cigar cabinets, cigar cabinet table, I highly recommend this top rated electric humidors advice (http://glazbenioglasnik.com/forum/viewtopic.php?f=50&t=430916) and don't forget how to setup a desktop humidors, acrylic desktop humidor with hygrometer, cigar humidor travel case, digital hygrometer for cigar humidor boveda, cigar humidor humidity too high, cigar humidor for beginners, desktop humidor cherry maple, look at this newest electric humidors recommendations (http://cotdien.com/threads/how-do-i-find-the-most-excellent-electric-humidor-now-tip-75.1069872/) alongside all cigar cabinet accesories, cigar humidor travel case, whynter cigar humidor drawers, vintage cigar cabinet on stand, diy cigar humidor cabinet, desktop humidor plans, new cigar humidor humidifier, try this excellent electric humidors recommendations (http://bb.kulichki.net/viewtopic.php?p=376822) for galiner cigar humidor travel case, small desktop humidor ratings, brookstone desktop humidors, profile. See More Newest Tenpoint Crossbow Today (https://www.forumibubapadanguru.com/viewtopic.php?f=8&t=688&p=170462#p170462) e55eb43
http://forums.matronics.com/viewtopic.php?p=501595#501595
Subject: | Aileron stop inboard or outboard? |
RV-8 Listers,
It looks like I need an aileron stop on the left wing to keep one of the aileron
actuator rods from contacting the side of the hole it goes through at full stick
throw. (I've already cut out the hole to the edge of the actuator support.)
Van's plans show installing the stop on the inboard actuator bracket near where
the actuator rod connects. There is another bracket, much easier to get to,
on the outboard edge of the wing. Why not put the aileron stop there?
Thanks!
v/r,P2
Subject: | Re: Aileron stop inboard or outboard? |
Quoting PRESTON PLOUS :
> RV-8 Listers,
> the aileron actuator rods from contacting the side of the hole it
> goes through at full stick throw. (I've already cut out the hole to
> the edge of the actuator support.) Van's plans show installing the
> stop on the inboard actuator bracket near where the actuator rod
> connects. There is another bracket, much easier to get to, on the
Just thinking out loud here, but if it is closer to the push rod
you don't put a twisting force on the aileron when it hits the stop.
Brian Huffaker, DSWL
RV-8A N609HZ flying
Keep in mind that when you get ready to fly, you legs may serve as your
aileron stops, depending on your leg position relative to the stick. My
DAR worried about my aileron encountering a little interference at the
aft right position, on my -10, until I pointed out that even if Twiggy
were the pilot, you couldn't get the stick that far right. May be
different with your setup.
>> RV-8 Listers,
>> the aileron actuator rods from contacting the side of the hole it goes
>> through at full stick throw. (I've already cut out the hole to the
>> edge of the actuator support.) Van's plans show installing the stop on
>> the inboard actuator bracket near where the actuator rod connects.
>> There is another bracket, much easier to get to, on the outboard edge
> Just thinking out loud here, but if it is closer to the push rod you
> RV-8A N609HZ flying
https://vansairforce.net/community/showthread.php?t=168372
> On 30 May 2021, at 17:43, PRESTON PLOUS wrote:
> =EF=BB
> RV-8 Listers,
ileron actuator rods from contacting the side of the hole it goes through at
full stick throw. (I've already cut out the hole to the edge of the actuato
r support.) Van's plans show installing the stop on the inboard actuator bra
cket near where the actuator rod connects. There is another bracket, much ea
sier to get to, on the outboard edge of the wing. Why not put the aileron st
op there?
> Thanks!
> v/r,
> P2
From: | Michael Lazarowicz <tllaz330(at)gmail.com> |
There is a much easier way to make a stop. You make a nylon bushing that
goes on one of the bolts. Just search under Aileron Stop on vans forum
there are lots of examples .
> > RV-8 Listers,
> RV-8A N609HZ flying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That=99s what I have on my 8 and it works great.
> Sent from my iPhone
> =EF=BB
> RV-8 Listers,
> aileron actuator rods from contacting the side of the hole it goes throug
h
> at full stick throw. (I've already cut out the hole to the edge of the
> actuator support.) Van's plans show installing the stop on the inboard
> actuator bracket near where the actuator rod connects. There is another
> bracket, much easier to get to, on the outboard edge of the wing. Why not
> Thanks!
> v/r,
> P2
Subject: | Matronics List Forum Web Site Fully Restored... |
Dear Listers,
There has been an issue with the database used to drive the Matronics Lists Forums
Web Site for a few days. I finally got to the bottom of the issue today.
It appears the functionality has been fully restored.
Matronics List Administrator
Subject: | OAT Probe and SL30 Nav/Com |
Hi All, I recently have a red X on TAS and OAT on my Garmin G3X
While I have not troubleshooted the wiring yet (but will soon) Im wondering if
anyone else has had this issue. Changing the harness is a giant pain so I would
rather just cut off the old one and splice in a new.
Problem is Garmin charges $475 for a GTP59 probe and 3 wire coax which is highway
robbery.
Ive looked into Davtron probe for about $100 but cant find anyone to let me know
if it will work.
Seemingly how different can it be?
Anyone have any experience with this?
Also Im getting a COMM FAIL
indicator on my SL30 intermittently
IT still works if I turn the radio off then back on, then left it on in the hangar
for 2 hours with battery charger on and NO Fail.
Garmin answer is send to them which they now FLAT RATE repair
for $875. So if you send them the unit and they dont find anything wrong its still
$875.
Apparently Garmin dealers are n to allowed to open up the box.
They will put power on it but thats all.
Sort of a ripoff if you ask me.
Id appreciate any input THX
avdilger(at)yahoo.com
Subject: | PLEASE READ - Matronics Email List 2018 Fund Raiser During November! |
Dear Listers,
Each November I hold a PBS-like fund raiser to support the continued operation
and upgrade of the Email List and Fourm Services at Matronics. It's solely through
the Contributions of List members (you) that these Matronics Lists are possible.
You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements.
During the month of November, I will be sending out List messages every couple
of days reminding everyone that the Fund Raiser is underway. I ask for your patience
and understanding during the Fund Raiser and throughout these regular
messages. The Fund Raiser is only financial support mechanism I have to pay all
of the bills associated with running these lists. YOUR personal Contribution
counts!
This year we have a really HUGE and TERRIFIC line up of free gifts to go along
with the various Contribution levels. In fact, there are 10 great gifts to choose
from! There's something for everyone, to be sure.
Last year because of the COVID hardships everyone was feeling, I opted to not have
a Fund Rasiser, and carried the finicial burden solely myself. I'm hoping
this year everyone will dig in make make up for the lost year.
Please make your List Contribution using any one of three secure methods including
using a Credit Card, PayPal, or by Personal Check. All three methods afford
you the opportunity to select one of this year's free gifts with a qualifying
Contribution amount!!
To make your Contribution, please visit the secure web site:
I would like to thank everyone in advance for their generous financial AND moral
support over the years!
Thank you!
RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot
Subject: | Please Make A Contribution To Support Your Lists |
Dear Listers,
There is no advertising income to support the Matronics Email Lists and Forums.
The operation is supported 100% by your personal Contributions during the November
Fund Raiser.
Please make your Contribution today to support the continued operation and upgrade
of these services. You can pick up a really nice gift for making your Contribution
too!
You may use a Credit Card or Paypal at the Matronics Contribution Site here:
https://matronics.com/contribution
or, you can send a personal check to the following address:
Matronics / Matt Dralle
581 Jeannie Way
Livermore, CA 94550
Thank you in advance for your generous support!
Matronics Email List and Forum Administrator
Subject: | Coming Soon - The List of Contributors - Please Make A Contribution |
Today!
Each year at the end of the List Fund Raiser, I post a message acknowledging everyone
that so generously made a Contribution to support the Lists. Its my way
of publicly thanking everyone that took a minute to show their appreciation
for the Lists.
Please take a moment and assure that your name is on that List of Contributors
(LOC)! As a number of members have pointed out over the years, the List seems
at least as valuable a building/entertainment tool as your typical magazine subscription!
Assure that your name is on this year's LOC! Show others that you appreciate the
Lists. Making a Contribution to support the Lists is fast and easy using your
Credit card or Paypal on the Secure Web Site:
or by dropping a personal check in the mail to:
Matt Dralle / Matronics
581 Jeannie Way
Livermore CA 94550
I would like to thank everyone that has so generously made a Contribution thus
far in this year's List Fund Raiser! Remember that its YOUR support that keeps
these Lists going and improving! Don't forget to include a little comment about
how the Lists have helped you!
Best regards,
Subject: | [PLEASE READ] Why I Have A Fund Raiser... |
Since the beginning, the Matronics List and Forum experience has been free from
advertising. I have been approached by fair number of vendors wanting to tap
into the large volume of activity across the various lists hosted here, but have
always flatly refused. Everywhere you go on the Internet these days, a user
is pummeled with flashing banners and videos and ads for crap that they don't
want. Yahoo, Google and that ilk are not "free". The user must constantly
endure their barrage of commercialism thrust into their face at an ever increasing
rate. Enough is enough, and the Lists at Matronics choose not to succumb
to that.
That being said, running a service of this size is not "free". It costs a lot
of money to maintain the hardware, pay for the electricity, Commercial-greade
Internet Connection, air conditioning, maintenance contracts, etc, etc. etc.
I choose to hold a PBS-like fund raiser each year during the month of November
where I simply send out a short email every other day asking the members to make
a small contribution to support the operation. That being said, that contribution
is completely voluntary and non-compulsory. Many members choose not
to contribute and that's fine.
However, a very modest percentage of the members do choose to make a contribution
and it is that financial support that keeps the Lists running. And that's
it. To my way of thinking, it is a much more pleasant way of maintaining the
Lists and Forums. The other 11 months of the year, you don't see a single advertisement
or request for support. That's refreshing and that is a List and Forum
that I want to belong to. I think other people feel the same way.
Won't you please take a minute to make your Contribution today and support these
Lists?
Or, drop a personal check in the mail to:
581 Jeannie Way
Livermore CA 94550
USA
Thank you for your support!
Email List Admin.
to that.
Lists?
581 Jeannie Way
Livermore CA 94550
USA
Email List Admin.
Subject: | List Contribution - Value of the List... |
If you look forward to checking your List email everyday (and a lot of you have
written to say that you do!), then you're probably getting at least $20 or $30
worth of Entertainment from the Lists each year. You'd pay twice that for a
subscription to some magazine or even a dinner out. Isn't the List worth at least
that much to you? Wouldn't it be great if you could pay that amount and get
a well-managed media source free of advertising, SPAM, and viruses? Come to
think of it, you do... :-)
Lists?
581 Jeannie Way
Livermore CA 94550
USA
I want to say THANK YOU to everyone that has made a Contribution thus far during
this year's List Fund Raiser!! These Lists are made possible exclusively through
YOUR generosity!!
Email List Admin.
Subject: | A List Contribution - It's Your Personal Squelch Button... |
There is an automatic "squelch button" of sorts for the Fund Raiser messages.
Here's how it works... As soon as a List member makes a Contribution through
the Matronics Fund Raiser web site, their email address is automatically added
to this year's Contributor List and they instantly cease to receive further Fund
Raiser messages for the rest of the month! Its just that simple! :-)
I really do appreciate each and every one of your individual Contributions to support
the Lists. It is your support that enables me to upgrade the hardware
and software that are required to run a List Site such as this one. It also goes
to pay for the commercial-grade Internet connection and to pay the huge electric
bill to keep the computer gear running and the air conditioner powered
on. I run all of the Matronics Email List and Forums sites here locally which
allows me to control and monitor every aspect of the system for the utmost in
reliably and performance. Your personal Contribution matters because, when combined
with other Listers such as yourself, it pays the bills to keep this site
up and running. I accept exactly ZERO advertising dollars for the Matronics
Lists sites. I can't stand the pop-up ads and all other commercials that are
so prevalent on the Internet these days and I particularly don't want to have
it on my Email List sites.
If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email
Lists, please make a Contribution to keep it that way!!
581 Jeannie Way
Livermore, CA 94550
Thank you!
[Note that there are certain circumstances where you might still see a Contribution
related message. For example, if someone replies to one of the messages,
when using the List Browse feature, or when accessing List message via the Forum.
The system keys on the given email address and since most of these are anonymous
public access methods, there is no simple way to filter them.]
Subject: | Make Sure You're Listed! List of Contributors Coming Soon! |
Dear Listers,
There's just a few more days left in this year's List Fund Raiser and that means
the List of Contributors (LOC) is just around the corner! In December I post
a list of everyone that so generously made a Contribution to support the Lists.
Its my way of publicly thanking everyone that took a minute to show their
appreciation for the Lists.
Won't you take minute and assure that your name is on the upcoming LOC? Tell others
that you appreciate the Lists. Making a Contribution to support the Lists
is fast and easy using your Visa, MasterCard, or Paypal account:
581 Jeannie Way
Livermore CA 94550
far during this year's List Fund Raiser! Remember that its YOUR support that
keeps these Lists running and improving! Don't forget to include a little comment
about how the Lists have helped you!
Thank you!
Dear Listers,
581 Jeannie Way
Livermore CA 94550
Thank you!
Dear Listers,
A quick reminder that November is the annual Matronics List Fund Raiser. The Lists
are 100% member supported and all of the operational costs are covered solely
through your Contributions during this time of the year.
*Your* personal Contribution makes a difference and keeps all of the Matronics
Email Lists and Forums completely ad-free.
Please make your Contribution today to keep these services up and running for another
great year!
Use a credit card or your PayPal account here:
Or, by sending a personal check to:
581 Jeannie Way
Livermore CA 94550
Thank you in advance!
Today!
for the Lists. Please take a moment and assure that your name is on that List
of Contributors (LOC)! As a number of members have pointed out over the years,
the List seems at least as valuable a building / entertainment tool as your
581 Jeannie Way
Livermore CA 94550
how the Lists have
helped you!
Best regards,
Dear Listers,
great year!
581 Jeannie Way
Livermore CA 94550
Dear Listers,
that so generously made a Contribution to support the Lists. Its sort
of my way of publicly thanking everyone that took a minute to show their appreciation
for the Lists.
Won't you take a moment and assure that your name is on that List of Contributors
(LOC)? As a number of members have pointed out over the years, the List seems
at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment
Please take minute and assure that your name is on this year's LOC! Show others
that you appreciate the Lists. Making a Contribution to support the Lists is
fast and easy using your Credit card or Paypal on the Secure Web Site:
or by popping a personal check in the mail to:
c/o Matt Dralle
581 Jeannie Way
Livermore CA 94550
how the Lists have
helped you!
Best regards,
Email List Administrator
Subject: | Just Two Days Left... |
Dear Listers,
There are just a Two days left for this year's List Fund Raiser! If you've been
putting off making a Contribution until the last minute, well, this is it!
The last minute, that is... :-) There are some GREAT new gift selections to choose
from this year. I personally want at least three of them! There's probably
something you can't live without too! And, best of all it supports your
Lists!
Please remember that there isn't any sort of commercial advertising on the Lists
and the *only* means of keeping these Lists running is through your Contributions
during this Fund Raiser. Let's make this a "Black Friday" for the Lists!
Please make a Contribution today!
581 Jeannie Way
Livermore CA 94550
Thank you!
Subject: | [Please Read] - Last Official Day of List Fund Raiser! |
Dear Listers,
It's November 30th and that always means a couple of things. Its my birthday again
- 58! :-) But it also means that it's that last official day of the Matronics
Email List Fund Raiser! If you been thinking about picking up one of those
really nice incentive gifts now is the time to jump on it!!
If you've been meaning to make a Contribution this month but have been putting
it off for some reason, NOW is the time!
I will be posting the List of Contributors in a few days, so you'll probably want
to be known as a person that supported the Lists!
I want to thank everyone that has so generously made a Contribution this year in
support of our Lists. It is your generosity that keeps this operation running
and I don't ever forget it.
The List Contribution Web Site is fast and easy. Please support our habit by making
your Contribution right now:
Or, by dropping a personal check in the mail to:
581 Jeannie Way
Livermore CA 94550
USA
Subject: | RV-8A project for sale |
I have an RV-8A project that I have decided to not complete. I am
located in Lexington, KY
The Empanage, Fuselage and Wing kits are finished. The fuselage has
fuel pump and fuel selector installed.
Please contact me off list if you are interested.
Thanks, JIm Combs
(RV-10 Flying)
JimInLexKy(at)gmail.com
Subject: | 2021 List of Contributors |
Dear Listers,
The 2021 Matronics Email List and Forum Fund Raiser officially ended a couple of
weeks ago and it's time that I published this year's List of Contributors (LOC).
It is the people on this list that directly make these Email Lists and Forums
possible! Their generous Contributions keep the servers and Internet connection
up and running!
You can still show your support this year and pick up a great gift at the same
time. The Contribution Web Site is fast, easy, and secure:
581 Jeannie Way
Livermore CA 94550
And finally, I'm proud to present The 2021 Fund Raiser List of Contributors (LOC):
https://matronics.com/loc
Thank you again to everyone that made a Contribution this year!!
Matronics Email List & Forum Administrator
Subject: | Canopy Handle Question... |
Does anyone know where you get this external canopy handle? I got it on my
RV-8, but I can't seem to find/remember where I purchased it.
But, really, what I want to do it remove the handle so I can get the
internal handle re-powder coated. But, the pinch-lock in the external handle
is so tight, it won't come off even with the screw completely removed.
Any help you could lend would be most appreciated.
N998RV
Subject: | Re: RV8-List Digest: 1 Msgs - 03/05/22 |
Matt,I didn't see a photo with your question, so I'm not sure what it looks
like.=C2- But, is it more "aerodynamic" than Vans with rounded edges and
polished with your name engraved on it?If so, then it is probably like min
e.=C2- I can dig through my records to see where I bought it.Let me know.
Stan Sutterfieldspeedy11(at)aol.com
Subject: RV8-List: Canopy Handle Question...
e
N998RV
Subject: | Matronics Email & Email List Server Back Online... |
Dear Listers,
Last week the Matronics email server developed a system problem. I was on travel
and unable to address it until today.
I'm happyy to report the server is 100% back online now and fully operational.
Dear Listers,
Dear Matronics Listers and Matronics Forums Users,
Earlier this week, the database that drives the Matronics Forums System developed
an issue. I was on travel without myy laptop and unable to address the issue
until today.
the Forums and Email Lists are 100% back up and full online!
Subject: | PLEASE READ - Matronics Email List 2022 Fund Raiser During November! |
Dear Listers,
During the month of November I will be sending out List messages every couple of
and understanding during the Fund Raiser and throughout these regular messages.
counts!
This year we have a really TERRIFIC line up of free gifts to go along with the
various Contribution levels. There's something for everyone, to be sure.
Thank you!
Dear Listers,
Fund Raiser.
too!
581 Jeannie Way
Livermore, CA 94550
Dear Listers,
great year!
581 Jeannie Way
Livermore CA 94550
want. Yahoo, Google and that elk are not "free". The user must constantly
to that.
of money to maintain the hardware, pay for the electricity, air conditioning,
maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser
each year during the month of November where I simply send out a short email
every other day asking the members to make a small contribution to support the
operation. That being said, that contribution is completely voluntary and non-compulsory.
Many members choose not to contribute and that's fine.
Lists?
581 Jeannie Way
Livermore CA 94550
USA
Email List Admin.
Dear Listers,
that so generously made a Contribution to support the Lists. It's sort
for the Lists.
(LOC)?
c/o Matt Dralle
581 Jeannie Way
Livermore CA 94550
Best regards,
Where do we find the LOC?
On Wed, Nov 9, 2022 at 1:03 AM Matt Dralle wrote:
> Dear Listers,
> acknowledging everyone that so generously made a Contribution to support
> the Lists. It's sort of my way of publicly thanking everyone that took a
> minute to show their appreciation for the Lists.
> Contributors (LOC)?
> others that you appreciate the Lists. Making a Contribution to support the
> Lists is fast and easy using your Credit card or Paypal on the Secure Web
> Site:
> c/o Matt Dralle
> 581 Jeannie Way
> Livermore CA 94550
> thus far in this year's List Fund Raiser! Remember that its YOUR support
> that keeps these Lists going and improving! Don't forget to include a
> little comment about how the Lists have helped you!
> Best regards,
> Matt Dralle
It's published after the Fund Raiser; I will send out a link to it.
Matt
> > Dear Listers,
everyone that so generously made a Contribution to support the Lists. It's
sort of my way of publicly thanking everyone that took a minute to show their
(LOC)?
is fast and easy using your Credit card or Paypal on the Secure Web Site:
> > https://matronics.com/contribution (https://matronics.com/contribution)
> > c/o Matt Dralle
> > 581 Jeannie Way
> > Livermore CA 94550
thus far in this year's List Fund Raiser! Remember that its YOUR support that
keeps these Lists going and improving! Don't forget to include a little comment
> > Best regards,
> > Matt Dralle
> > List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV8-List
> > FORUMS -
> > eferrer" target="_blank">http://forums.matronics.com
> > WIKI -
> > errer" target="_blank">http://wiki.matronics.com
> > b Site -
> > -Matt Dralle, List Admin.
> > ="noreferrer" target="_blank">https://matronics.com/contribution
http://forums.matronics.com/viewtopic.php?p=508638#508638
Subject: | Please Make a Contribution to Support Your Lists... |
Dear Listers,
Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution
today to support the continued operation and upgrade of these great
List services!! Pick up a really nice free gift with your qualifying Contribution
too!
The Contribution Site is fast and easy:
581 Jeannie Way
Livermore CA 94551-0347
Thank you!
Dear Listers,
581 Jeannie Way
Livermore CA 94550
Thank you!
Subject: | What's Your Contribution Used For? |
Dear Listers,
You might have wondered at some point, "What's my Contribution used for?" Here
are just a few examples of what your direct List support enables... It provides
for the expensive, commercial-grade Internet connection used on the List.
It pays for the regular system hardware and software upgrades enabling the highest
performance possible for List services such as the Archive Search Engine,
List Browser, and the Web Forums. It pays for the over 25 years of on-line
archive data always available for instant search and access. And, it offsets
the many hours spent writing, developing, and maintaining the custom applications
that power these List Service such as the List Browse, Search Engine, Forums,
and Wiki.
But most importantly, your List Contribution enables a forum where you and your
peers can communicate freely in an environment that is free from moderation,
censorship, advertising, commercialism, SPAM, and computer viruses.
It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List
services. Please support it today with your List Contribution. Its one of
the best investments you can make in your Sport!
List Contribution Web Site:
581 Jeannie Way
Livermore, CA 94550
Today!
Each year at the end of the List Fund Raiser, I post a message and link acknowledging
Its my way of publicly thanking everyone that took a minute to show their appreciation
for the Lists.
at least as valuable a building / entertainment tool as your typical magazine
subscription!
581 Jeannie Way
Livermore CA 94550
Best regards,
581 Jeannie Way
Livermore, CA 94550
Thank you!
[ Note 1: There are certain circumstances where you might still see a Contribution
public access methods, there is no simple way to filter them. ]
[ Note 2: For part of the 2022 Fund Raiser year, the Squelch Function was broken.
It's fixed now. I'm sorry about that... ]
Today!
581 Jeannie Way
Livermore CA 94550
how the Lists have
helped you!
Best regards,
Dear Listers,
Lists!
581 Jeannie Way
Livermore CA 94550
Thank you!
Dear Listers,
It's November 30th and that always means a couple of things. Today is my birthday
again - 59! :-) I've been running these Lists since I was 28!
But, it also means that it's that last official day of the Matronics Email List
Fund Raiser! If you been thinking about picking up one of those really nice
581 Jeannie Way
Livermore CA 94550
USA
Subject: | 2022 List of Contributors (LOC)... |
Dear Listers,
The 2022 Matronics Email List and Forum Fund Raiser officially ended a couple of
weeks ago and it's time that I published this year's List of Contributors.
up and running!
581 Jeannie Way
Livermore CA 94550
And finally, I'm proud to present The 2022 Fund Raiser List of Contributors:
Subject: | Matronics Email List Digest Operational Change... |
Dear Matronics Listers,
Beginning December 16, 2022, I am planning to modify the way Matronics List Digest
Email is handled. A Digest message will be sent daily ONLY if there is at
least ONE message posted to the Realtime List on the given day. If there are
no messages posted *No Digest will be sent*.
This change is being made to soften the SPAM filtering effect in the Internet at
large on the "Matronics.com" domain. Matronics.com is frequently unceremoniously
blocked because of perceived "SPAM" content. For example, yahoo.com along
with a number of other significant domains has been blocking matronics.com
for a long time.
Hopefully, this operational change will address the issue.
Subject: | Nylon #2 Phillips Screw Driver Bits...? |
Hi Fellow RV Builders,
After 12 years since the test-flight, I finally got my RV-8 painted! Cascade
Customs and Design in Bend Oregon did an outrageously awesome job! She is a
beaut!
I had them put all new cad-plated screw hardware back in after painting. I
decided that gold hardware against the red, just didn't look as finished as
I'd hoped. So, I counted all the screws and had them paint the appropriate
number of screws plus some spares with the intent of swapping all the
unpainted with painted.
The problem is the standard steel Phillips screw driver bits seems to chip
the paint in the screw pretty easily.
I thought that I've seen #2 Phillips NYLON screw driver tips somewhere a
while back? But I can't seem to find them now? Does anyone have a lead on
Nylon #2 bits?
RV-8 N998RV "Ruby Vixen"
https://youtu.be/57ihMKzMojE
Subject: | Re: Nylon #2 Phillips Screw Driver Bits...? |
Matt,
Nylon won't be strong enough to turn those screws in nut plates. You might
want to consider replacing the A/C Phillips head screws with Torx head scr
ews [SS or Cad] from a supplier like MSC Direct or McMaster-Carr
=C2-
e Customs and Design in Bend Oregon did an outrageously awesome job!=C2-
She is a beaut!
=C2-
I had them put all new cad-plated screw hardware back in after painting.=C2
- I decided that gold hardware against the red, just didn=99t look
as finished as I=99d hoped.=C2- So, I counted all the screws and ha
d them paint the appropriate number of screws plus some spares with the int
ent of swapping all the unpainted with painted.
=C2-
the paint in the screw pretty easily.=C2-
=C2-
I thought that I=99ve seen #2 Phillips NYLON screw driver tips somewh
ere a while back?=C2- But I can=99t seem to find them now?=C2- Do
es anyone have a lead on Nylon #2 bits?
=C2-
=C2-
RV-8 N998RV =9CRuby Vixen=9D
=C2-
=C2-
=C2-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: | eduardo cresta hill <eduardocrestahill(at)hotmail.com> |
Subject: | Nylon #2 Phillips Screw Driver Bits...? |
Perhaps a plastic screwdriver toy (Amazon)
De: owner-rv8-list-server(at)matronics.com en nombre de Matt Dralle
Enviado: martes, 3 de enero de 2023 21:08
Para: rv-list(at)matronics.com ; rv8-list(at)matronics.com
; rv7-list(at)matronics.com
Asunto: RV8-List: Nylon #2 Phillips Screw Driver Bits...?
Hi Fellow RV Builders,
After 12 years since the test-flight, I finally got my RV-8 painted! Cascad
e Customs and Design in Bend Oregon did an outrageously awesome job! She i
s a beaut!
I had them put all new cad-plated screw hardware back in after painting. I
decided that gold hardware against the red, just didn=92t look as finished
as I=92d hoped. So, I counted all the screws and had them paint the appro
priate number of screws plus some spares with the intent of swapping all th
e unpainted with painted.
The problem is the standard steel Phillips screw driver bits seems to chip
the paint in the screw pretty easily.
I thought that I=92ve seen #2 Phillips NYLON screw driver tips somewhere a
while back? But I can=92t seem to find them now? Does anyone have a lead
on Nylon #2 bits?
RV-8 N998RV =93Ruby Vixen=94
https://youtu.be/57ihMKzMojE
Subject: | Re: Nylon #2 Phillips Screw Driver Bits...? |
Just cover the screws with round circles of vinyl wrap (use big hole paper
punch) after inserted and torqued down. With a hair dryer, the vinyl will
shrink wrap into screw and be indistinguishable from paint. And when you n
eed to remove them, the vinyl will (should) peel out easily. Or be bold.
Polish, dip heads in polyurethane (very optional) and call it a design elem
ent. Nylon screws will just break off where you can't get at them.
RV8-N8432
From: owner-rv8-list-server(at)matronics.com <owner-rv8-list-server(at)matronics.
com> on behalf of Charles Kuss
Sent: Tuesday, January 3, 2023 4:26 PM
Subject: Re: RV8-List: Nylon #2 Phillips Screw Driver Bits...?
Matt,
Nylon won't be strong enough to turn those screws in nut plates. You might
want to consider replacing the A/C Phillips head screws with Torx head scre
ws [SS or Cad] from a supplier like MSC Direct or McMaster-Carr
s a beaut!
on Nylon #2 bits?
[cid:uERRhBOBbyp956bwAa5E]
[cid:j8woHe86sypbvIekbprD]
Subject: | PLEASE READ - Matronics Email List 2023 Fund Raiser During November! |
Dear Listers,
Each November I hold a PBS-like fund raiser to support the continued operation
and upgrade of the Email List and Fourm Services at Matronics. It's solely through
the Contributions of List members (you) that these Matronics Lists are possible.
You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com, or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse, etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements.
During the month of November I will be sending out List messages every couple of
days reminding everyone that the Fund Raiser is underway. I ask for your patience
and understanding during the Fund Raiser and throughout these regular messages.
The Fund Raiser is only financial support mechanism I have to pay all
of the bills associated with running these lists. YOUR personal Contribution
counts!
This year we have a really TERRIFIC line up of free gifts to go along with the
various Contribution levels. There's something for everyone, to be sure.
Please make your List Contribution using any one of three secure methods including
using a Credit Card, PayPal, or by Personal Check. All three methods afford
you the opportunity to select one of this year's free gifts with a qualifying
Contribution amount!!
To make your Contribution, please visit the secure web site:
https://matronics.com/contribution
I would like to thank everyone in advance for their generous financial AND moral
support over the years!
Thank you!
RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot
Subject: | Please Make A Contribution To Support Your Lists |
Dear Listers,
There is no advertising income to support the Matronics Email Lists and Forums.
The operation is supported 100% by your personal Contributions during the November
Fund Raiser.
Please make your Contribution today to support the continued operation and upgrade
of these services. You can pick up a really nice gift for making your Contribution
too!
You may use a Credit Card or Paypal at the Matronics Contribution Site here:
or, you can send a personal check to the following address:
Matronics / Matt Dralle
581 Jeannie Way
Livermore, CA 94550
Thank you in advance for your generous support!
Matronics Email List and Forum Administrator
Subject: | Coming Soon - The List of Contributors - Please Make A Contribution |
Today!
Each year at the end of the List Fund Raiser, I post a message acknowledging everyone
that so generously made a Contribution to support the Lists. Its my way
of publicly thanking everyone that took a minute to show their appreciation
for the Lists.
Please take a moment and assure that your name is on that List of Contributors
(LOC)! As a number of members have pointed out over the years, the List seems
at least as valuable a building / entertainment tool as your typical magazine
subscription!
Assure that your name is on this year's LOC! Show others that you appreciate the
Lists. Making a Contribution to support the Lists is fast and easy using your
Credit card or Paypal on the Secure Web Site:
or by dropping a personal check in the mail to:
Matt Dralle / Matronics
581 Jeannie Way
Livermore CA 94550
I would like to thank everyone that has so generously made a Contribution thus
far in this year's List Fund Raiser! Remember that its YOUR support that keeps
these Lists going and improving! Don't forget to include a little comment about
how the Lists have
helped you!
Best regards,
Dear Listers,
A quick reminder that November is the annual Matronics List Fund Raiser. The Lists
are 100% member supported and all of the operational costs are covered solely
through your Contributions during this time of the year.
*Your* personal Contribution makes a difference and keeps all of the Matronics
Email Lists and Forums completely ad-free.
Please make your Contribution today to keep these services up and running for another
great year!
Use a credit card or your PayPal account here:
Or, by sending a personal check to:
581 Jeannie Way
Livermore CA 94550
Thank you in advance!
Subject: | Please Make a Contribution to Support Your Lists... |
Dear Listers,
Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution
today to support the continued operation and upgrade of these great
List services!! Pick up a really nice free gift with your qualifying Contribution
too!
The Contribution Site is fast and easy:
581 Jeannie Way
Livermore CA 94551-0347
Thank you!
Subject: | [PLEASE READ] Why I Have A Fund Raiser... |
Since the beginning, the Matronics List and Forum experience has been free from
advertising. I have been approached by fair number of vendors wanting to tap
into the large volume of activity across the various lists hosted here, but have
always flatly refused.
Everywhere you go on the Internet these days, a user is pummeled with flashing
banners and videos and ads for crap that they don't want. Yahoo, Google and that
ilk are not "free". The user must constantly endure their barrage of commercialism
thrust into their
face at an ever increasing rate. Enough is enough, and the Lists at Matronics
choose not to succumb to that.
That being said, running a service of this size is not "free". It costs a lot
of money to maintain the hardware, pay for the electricity, Commercial-greade
Internet Connection, air conditioning, maintenance contracts, etc, etc. etc.
I choose to hold a PBS-like
fund raiser each year during the month of November where I simply send out a short
email every other day asking the members to make a small contribution to support
the operation. That being said, that contribution is completely voluntary
and non-compulsory.
Many members choose not to contribute and that's fine.
However, a very modest percentage of the members do choose to make a contribution
and it is that financial support that keeps the Lists running. And that's
it. To my way of thinking, it is a much more pleasant way of maintaining the
Lists and Forums. The other
11 months of the year, you don't see a single advertisement or request for support.
That's refreshing and that is a List and Forum that I want to belong to.
I think other people feel the same way.
Won't you please take a minute to make your Contribution today and support these
Lists?
Or, drop a personal check in the mail to:
581 Jeannie Way
Livermore CA 94550
USA
Thank you for your support!
Email List Admin.
Subject: | A List Contribution - It's Your Personal Squelch Button... |
There is an automatic "squelch button" of sorts for the Fund Raiser messages.
Here's how it works... As soon as a List member makes a Contribution through
the Matronics Fund Raiser web site, their email address is automatically added
to this year's Contributor
List and they instantly cease to receive further Fund Raiser messages for the rest
of the month! Its just that simple! :-)
I really do appreciate each and every one of your individual Contributions to support
the Lists. It is your support that enables me to upgrade the hardware
and software that are required to run a List Site such as this one. It also goes
to pay for the
commercial-grade Internet connection and to pay the huge electric bill to keep
the computer gear running and the air conditioner powered on. I run all of the
Matronics Email List and Forums sites here locally which allows me to control
and monitor every aspect
of the system for the utmost in reliably and performance. Your personal Contribution
matters because, when combined with other Listers such as yourself, it
pays the bills to keep this site up and running. I accept exactly ZERO advertising
dollars for the
Matronics Lists sites. I can't stand the pop-up ads and all other commercials
that are so prevalent on the Internet these days and I particularly don't want
to have it on my Email List sites.
If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email
Lists, please make a Contribution to keep it that way!!
581 Jeannie Way
Livermore, CA 94550
Thank you!
[ Note 1: There are certain circumstances where you might still see a Contribution
related message. For example, if someone replies to one of the messages,
when using the List Browse feature, or when accessing List message via the Forum.
The system keys on the
given email address and since most of these are anonymous public access methods,
there is no simple way to filter them. ]
Today!
for the Lists.
subscription!
581 Jeannie Way
Livermore CA 94550
how the Lists have
helped you!
Best regards,
Subject: | Just A Few Days Left... |
Dear Listers,
There are just a few days left for this year's List Fund Raiser. If you've been
putting off making a Contribution until the last minute, well, this is it!
The last minute, that is... :-) There are some GREAT new gift selections to choose
from this year. I
personally want at least three of them! There's probably something you can't live
without too! And, best of all it supports your Lists!
Please remember that there isn't any sort of commercial advertising on the Lists
and the *only* means of keeping these Lists running is through your Contributions
during this Fund Raiser.
Please make a Contribution today!
581 Jeannie Way
Livermore CA 94550
Thank you!
Subject: | Make Sure You're Listed! List of Contributors Coming Soon! |
Dear Listers,
There's just a few more days left in this year's List Fund Raiser and that means
the List of Contributors (LOC) is just around the corner! In December I post
a list of everyone that so generously made a Contribution to support the Lists.
Its my way of publicly
thanking everyone that took a minute to show their appreciation for the Lists.
Won't you take minute and assure that your name is on the upcoming LOC? Tell others
that you appreciate the Lists. Making a Contribution to support the Lists
is fast and easy using your Visa, MasterCard, or Paypal account:
581 Jeannie Way
Livermore CA 94550
far during this year's List Fund Raiser! Remember that its YOUR support that
keeps these Lists running and improving! Don't forget to include a little comment
about how the Lists have
helped you!
Thank you!
Subject: | [Please Read] - Last Official Day of List Fund Raiser! |
Dear Listers,
It's November 30th and that always means a couple of things. Its my birthday again
- 60! :-) But it also means that it's that last official day of the Matronics
Email List Fund Raiser! If you been thinking about picking up one of those
really nice incentive
gifts now is the time to jump on it!!
If you've been meaning to make a Contribution this month but have been putting
it off for some reason, NOW is the time!
I will be posting the List of Contributors in a few days, so you'll probably want
to be known as a person that supported the Lists!
I want to thank everyone that has so generously made a Contribution this year in
support of our Lists. It is your generosity that keeps this operation running
and I don't ever forget it.
The List Contribution Web Site is fast and easy. Please support our habit by making
your Contribution right now:
Or, by dropping a personal check in the mail to:
581 Jeannie Way
Livermore CA 94550
USA
Subject: | 2023 List of Contributors (LOC)... |
Dear Listers,
The 2023 Matronics Email List and Forum Fund Raiser officially ended a couple of
weeks ago and it's time that I published this year's List of Contributors.
It is the people on this list that directly make these Email Lists and Forums
possible! Their generous
Contributions keep the servers and Internet connection up and running!
You can still show your support this year and pick up a great gift at the same
time. The Contribution Web Site is fast, easy, and secure:
581 Jeannie Way
Livermore CA 94550
And finally, I'm proud to present The 2023 Fund Raiser List of Contributors:
https://matronics.com/loc
Thank you again to everyone that made a Contribution this year!!
Matronics Email List & Forum Administrator
Subject: | Matronics Web Forums Back Online... |
There was a database issue impacting the Matronics Web Forums for a few day. I
have resolved the issue
and am happy to report the Forums are fully back online and operational.
Subject: | Matronics Web Repaired - Now Back Online... |
The main Matronics Web Server had a pretty major disk corruption. After a LOT
of work I was able to rebuild it and fully restore it from a
recent backup. I am a believer in regular backups, especially now!
Sorry it took so long, but I was really pulling my hair out on this one...
April 09, 2021 - Present
RV8-Archive.digest.vol-ba
