RV9-Archive.digest.vol-ap
August 23, 2004 - December 28, 2004
      >Reply-To: rv9-list(at)matronics.com
      >To:
      >Subject: RV9-List: Fuel valve
      >Date: Mon, 23 Aug 2004 19:39:27 +0100
      >Could someone remind me about the positions on the VANS supplied valve.
      >One position is L Tank, one R Tank. Am I correct in thinking the other two
      >are both 'OFF' or is one 'Both'? I am just getting some labelling made up
      >and cant get to the valve.
      >Thanks, Steve.
      >#90360
      >UK
      Get ready for school! Find articles, homework help and more in the Back to
Subject: Rudder wiring question
Date: Aug 23, 2004
For those of you who elected to put a marker light/strobe on the rudder (mounted in the lower fiberglass faring), how did you run the wire? Seems that getting the wire out of the fuselage and into the rudder, including the necessary flexing, is a bit of a problem. I want to avoid having it chafe or break from flexing. Thanks, Bob Smith ________________________________________________________________________________
Subject: Both Tanks & Dauz fasteners
Date: Aug 24, 2004
Two questions: 1. Has anyone figured out a way to have a "both" setting on an RV fuel valve? Say 2 fuel pumps or somehting, with pressure sensors? I'm sure someone has a "both" set-up??? 2. Could someone point me to a website with a good decription of attaching an RV cowling with something easier than a piano hinge. I have heard many use Dauz fasteners (sp?)? Thanks, Bryan http://search.msn.click-url.com/go/onm00200636ave/direct/01/ ________________________________________________________________________________
Date: Aug 24, 2004
Bob I just asked Van's guys about this same point. Their suggestion is to drill a small through the bulkheads and place a plastic grommet in the hole. My thought was to heat shrink tubing protect them and rout them through the small holes that exist. Their answer is better, safer and done. A 1/4 inch grommet hole should do. Tad. 7A "Bob Smith" wrote: > > >For those of you who elected to put a marker light/strobe on the rudder >(mounted in the lower fiberglass faring), how did you run the wire? Seems >that getting the wire out of the fuselage and into the rudder, including the >necessary flexing, is a bit of a problem. I want to avoid having it chafe >or break from flexing. > >Thanks, > >Bob Smith > > ________________________________________________________________________________
Date: Aug 24, 2004
Subject: wing tip trailing edge alignment
The trailing edges of my wing tips are about .3 inches lower then the trailing edges of the ailerons. I adjusted the aileron positions using the fixture that uses the key tooling holes in the outer wing rib. The ailerons align okay with the flaps in their full up position. Has anyone else encountered this? Jib Ray ________________________________________________________________________________
Subject: Re: Both Tanks & Dauz fasteners
Date: Aug 24, 2004
> Two questions: > > 1. Has anyone figured out a way to have a "both" setting on an RV fuel > valve? Say 2 fuel pumps or somehting, with pressure sensors? I'm sure > someone has a "both" set-up??? In a low wing airplane, you would not want a 'both' position. The reason for this is that the fuel will tend to pump from the path of least resistance, which may be an empty tank! > 2. Could someone point me to a website with a good decription of attaching > an RV cowling with something easier than a piano hinge. I have heard many > use Dauz fasteners (sp?)? Dzus fasteners work great but are expensive and are visible, where the piano hinge is invisible, cheap and simple. Dale ________________________________________________________________________________
Date: Aug 24, 2004
Bryan, Don't be too quick to switch from piano hinge. They do a good job of spreading the stress on the fiberglass edge of your cowling. Va'n's does not reccomend Dauz fasteners and some folks who did it anyway have had trouble with causing cracks. The piano hinge is not really all that difficult and provides a nice fit. Dennis Thomas RV-9, N164DV 87.2 hours and loving it ________________________________________________________________________________
Subject: Both Tanks & Dzus fasteners
Date: Aug 24, 2004
Hmmmm......I'm not totally sure I agree with that. Couple of things: 1) The "Dauz" Fasteners mentioned are "Dzus" fastners, and not normally used on cowls. They are little fastners that hook over a springy pice of wire and are generally used on things like belly skins of Husky's, Scout's, etc.. 2) The fasteners used for the RV cowls are the Skybolt fasteners (http://www.skybolt.com). They are specially made fasteners for cowls, being adjustable camlock type fasteners, but superior in a few ways. 3) I'm unaware of anyone who used the skybolt fasteners having cracking problems, but I am aware of LOTS of piano hing installations having craking after a couple hundred hours. There are a lot of RV's with craked eyes on the piano hinges. 4) Yes, the piano hinges work fine, but the folded hinges are prone to cracking, which is why a number of people buy the higher dollar extruded hinge to begin with. The fast glass guys often use extruded carbon fiber hinges to alleviate the cracking problems of the old folded hinges. Now, like a lot of things one method seems to work fine and is quite attractive (hinges). That being said, and coming from someone who actually has one of each flying - 1 RV with hinges and 1 RV with the skybolt fasteners, and like nearly 100% of everyone I've spoken with in similar situations (those that have actually used both), I'll never go back to hinges again. There are a couple areas where the hinges are just so far superior that it isn't really even debatable, but here's where the skybolt fasteners are a life saver. First, around the upper firewall curves - NO more scratched, burned hands, no more cussing, swearing, etc.. Second, at the bottom of the firewall/cowl - No more burnt wrists trying to get the pins out along side the hot exhaust. There are a number of people who just buy the skybolt fasteners for the firewall (as that is where the majority of the hinges cracked) and still use the hinges for the cowl sides. I think that would still be just fine. In the end, I can whip the skybolt cowl on and off in literally a minute or two with no fuss, mess, or anything. It's like a lot of things, you like something just fine until you actually try the other, then you'll never go back. They skybolt stuff is pricey, but well worth it. I'm guessing the cracking stories are referring to the hinges, not the skybolts. Take a look at the archives and you'll find a TON of incidents from cracked hinge eyes, and lot's of good feedback on the skybolt fasteners. No comparision between the two! Anyway, I'm in no way associated with the Skybolt company, just someone who is flying with one of each and would rather use the skybolt fasteners any day, hands down! BTW, I called a couple guys at Van's today just to see if they were against the skybolt fasteners, and actually the only negative I heard was the price! Regarding Dzus fasteners, of course they wouldn't recommend them, in a cowl application they would not work well. Any fastener you use on the cowl of that type needs to be depth adjustable and standard camlock/southco/dzus fasteners are not. Just my 2 cents! Cheers, Stein Bruch RV6's, Minneapolis -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of DThomas773(at)aol.com Subject: Re: RV9-List: Both Tanks & Dauz fasteners Bryan, Don't be too quick to switch from piano hinge. They do a good job of spreading the stress on the fiberglass edge of your cowling. Va'n's does not reccomend Dauz fasteners and some folks who did it anyway have had trouble with causing cracks. The piano hinge is not really all that difficult and provides a nice fit. Dennis Thomas RV-9, N164DV 87.2 hours and loving it ________________________________________________________________________________
From: "Steve Sampson" <SSampson.SLN21(at)london.edu>
Subject: Fuel valve
Date: Aug 24, 2004
Ross/ Konrad - thanks, Steve. --- ________________________________________________________________________________
Subject: Re: wing tip trailing edge alignment
Date: Aug 24, 2004
Hi, I did encounter this, I slit the wingtip TE and part way up the outside...maybe about 1/3 from the TE, then epoxy/floxed the TE and laid up FG cloth on the inside of the slit in the 1/3 part of the tip...it worked...just a lot of extra work and sanding/filling. Harold Kovac, filling the rivet dimples on both wings, then the Fuse ----- Original Message ----- From: "Jib Ray" <jib(at)interwoof.com> Subject: RV9-List: wing tip trailing edge alignment > > The trailing edges of my wing tips are about .3 inches lower then the > trailing edges of the ailerons. I adjusted the aileron positions using the > fixture that uses the key tooling holes in the outer wing rib. The ailerons > align okay with the flaps in their full up position. > > Has anyone else encountered this? > > Jib Ray > > ________________________________________________________________________________
Date: Aug 24, 2004
Slitting the edges sounds like a good way to make the adjustment. I have considered flying it before making any changes. Jib Ray ________________________________________________________________________________
Date: Aug 24, 2004
I riveted the wingtip on and made an access panel on the lower forward third of the tip...used nutplates & screws , opening 4 x 7 & 12 fasteners. I can get in past my elbow and reach anything i need to access. Harold----- Original Message ----- From: "Jib Ray" <jib(at)interwoof.com> Subject: Re: RV9-List: wing tip trailing edge alignment > > Slitting the edges sounds like a good way to make the adjustment. I have > considered flying it before making any changes. > > Jib Ray > > ________________________________________________________________________________
Subject: Re: Still on List
Date: Aug 24, 2004
Thanks Andy, Glad to know I'm still connected. I see there was still fuel in his left tank? He didn't switch tanks when the engine started rumbling? I suppose we all need re-current emergency procedure training so it becomes second nature. Then in the process of landing maybe not enough time? I guess it is easy to say to fill your tanks before flight each time, but circumstances can always creep in. Thanks again, Terry 9A fuselage >From: Andy Karmy <andy(at)karmy.com> >Reply-To: rv9-list(at)matronics.com >To: rv9-list(at)matronics.com >Subject: Re: RV9-List: Still on List >Date: Wed, 18 Aug 2004 06:16:46 -0700 > > >No, we are here, It's just quiet now... I was just sitting here >thinking about the RV9 accident at Westport, and how that must really >suck! > >You would think that 28 gallons would get you from Eugene to Westport, >however in this case it didn't (or wasn't there in the first place). >This is the second 9A that we have lost due to fuel management, let's >all be careful out there! > >- Andy Karmy > RV9A - 250hrsTT! > andy(at)karmy.com > >On Aug 17, 2004, at 11:49 AM, Terry Hobert wrote: > > > > > I haven't recieved any RV9 mail in days. Just quiet or did I get > > disconnected? > > > > Terry Hobert RV9A Fuselage/finish kit > > ________________________________________________________________________________
Date: Aug 24, 2004
I had to do the same thing on my left wingtip. Slice, drill out and make a new tip rib, and reinstall everything. I think the secret to getting this right is to first use the aileron jig to position the aileron in trail and figure out a way to hold it perfectly in position. Then, start to fit the wing tip and drill the attachment holes while holding the TE of the tip inline with the aileron. The challenge is to clamp/hold the wing tip rib in position and drill it with the aileron in place. -Clay PS.. DO NOT make a Both position on the fuel valve. A leaky cap and full fuel on one side can suck the opposite tank dry in nothing flat. --- Harold Kovac wrote: > > > Hi, > I did encounter this, I slit the wingtip TE and part > way up the > outside...maybe about 1/3 from the TE, then > epoxy/floxed the TE and laid up > FG cloth on the inside of the slit in the 1/3 part > of the tip...it > worked...just a lot of extra work and > sanding/filling. > Harold Kovac, filling the rivet dimples on both > wings, then the Fuse > ----- Original Message ----- > From: "Jib Ray" <jib(at)interwoof.com> > To: > Subject: RV9-List: wing tip trailing edge alignment > > > > > > > The trailing edges of my wing tips are about .3 > inches lower then the > > trailing edges of the ailerons. I adjusted the > aileron positions using the > > fixture that uses the key tooling holes in the > outer wing rib. The > ailerons > > align okay with the flaps in their full up > position. > > > > Has anyone else encountered this? > > > > Jib Ray > > > > > __________________________________ ________________________________________________________________________________
Subject: Re: Rudder wiring question
Date: Aug 25, 2004
I drilled a hole between the lowest 2 steel hinge attach brackets, on the far right side (looking from the rear). Then wrapped the wire with spiral wrap and ran them through. From there I simply dropped them into the lower fiberglass part on the rudder and ran them back. I put a connector on all wires with about a 4" pigtail on the light fixture so I can remove the light, disconnect the wires, then pull the wire bundle out the front of the rudder to remove it. The wires really don't flex much with rudder movement. - Andy Karmy andy(at)karmy.com On Aug 23, 2004, at 2:28 PM, Bob Smith wrote: > > > For those of you who elected to put a marker light/strobe on the rudder > (mounted in the lower fiberglass faring), how did you run the wire? > Seems > that getting the wire out of the fuselage and into the rudder, > including the > necessary flexing, is a bit of a problem. I want to avoid having it > chafe > or break from flexing. > > Thanks, > > Bob Smith > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Date: Sep 25, 2004
I used the skybolt kit in my RV8A. I've been flying over 2 years and have had no cracking. There is some bowing between the ones across the top only while flying from air pressure changes. It is very easy and fast to remove and replace the cowling. I'm going to do it again on my RV9A, but will use camlocs from Spruce because the skybolt kit is so expensive. I do like their template and connector tools, though. Wayne Danville, VA ________________________________________________________________________________
Date: Aug 24, 2004
Subject: RE remove from service:
My Name is Mike King and My e mail address is mamrking(at)earthling.net please remove me from you service. I have completed my rv9 and no longer wish to get the service thank you. Mike King R ________________________________________________________________________________
Date: Aug 25, 2004
From: Garey Wittich <gareywittich2000(at)yahoo.com>
Subject: "Need Extra Hands" in building a RV-8A QB - Santa Monica, Calif
rv8-list(at)matronics.com, rv9-list(at)matronics.com, rv-list(at)matronics.com Greetings: Any Builders who live in the Santa Monica, Calif area. Building a RV-8A QB in my garage 5 minutes from Santa Monica Airport and "need extra hands". Willing to help somebody with their project TOO. My wife does not want to get involved and the local EAA Chapter is all composite builders. At the rate I am making progress it will take me 5 life times to complete !!!!! Thanks, Garey Wittich (310) 392-1682 __________________________________ ________________________________________________________________________________
Subject: IFR instruments
Date: Aug 25, 2004
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
, , , 1.7 SUSPICIOUS_RECIPS Similar addresses in recipient list Hi Guys, I was almost convinced the Garmin GNS 430 hooked to a Dynon and a Digitrack A/P was the almost perfect base to a light weight IFR setup for an RV-7, then I see that BMA has come out with the EFIS Lite G3 which has the GPS, and an electronic version of the VOR/GS receiver that can be driven by an SL30 Navcom. Apparently this system drives a BMA 2 axis autopilot. Looking at all of this gives me aN IFR panel for about $11k including the transponder and 2 axis A/P. The similar setup using the GNS 430 comes in at about $14.5K with single axis A/P. Anyone have any experience or thoughts on this set up? I haven't started IFR training yet so I'm fumbling a little on all the requirements...Not sure about the "indicator lights" (marker beacon?) that are apparently built into the Nav head that the GNS 430 would drive. Frank ________________________________________________________________________________
Subject: Eggenfellner engine package on Ebay
Date: Aug 25, 2004
For those who might be interested in an Eggenfellner firewall forward engine package for the RV9A I've put one up for bid on Ebay. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item2487928910 If the link doesn't work try: Ebay motors/parts&accessories/aviation parts/engines Thanks, Kelly Wilson ________________________________________________________________________________
Date: Aug 25, 2004
I believe that the indicator lights you are referring to reference the requirement that for a GPS to be IFR certified you have to have an indicator displaying what is driving the CDI. This is an effort to make sure you dont think your doing something like following a localizer when in reality the instrument is being driven by the GPS. -- John -----Original Message----- Hi Guys, I haven't started IFR training yet so I'm fumbling a little on all the requirements...Not sure about the "indicator lights" (marker beacon?) that are apparently built into the Nav head that the GNS 430 would drive. Frank --- ________________________________________________________________________________
Subject: First flight
Date: Aug 26, 2004
Yesterday, after waiting seven weeks for an inspection and another twelve days for the inspector to finish the paperwork, RV9A N61DX took to the air. Aside from high cylinder temps, everything went well. This is a nice airplane! Dale ________________________________________________________________________________
Date: Aug 26, 2004
Wayne What is the part number of those fastners from spruce and do they install the same way as the skybolts. Do you have any pictures on you installations. Tad Sargent RV7A "Wayne Williams" wrote: > >I used the skybolt kit in my RV8A. I've been flying over 2 years and have >had no cracking. There is some bowing between the ones across the top only >while flying from air pressure changes. It is very easy and fast to remove >and replace the cowling. I'm going to do it again on my RV9A, but will use >camlocs from Spruce because the skybolt kit is so expensive. I do like their >template and connector tools, though. > >Wayne >Danville, VA > > ________________________________________________________________________________
Date: Aug 26, 2004
Subject: Re: First flight
Hey Dale congratulations. Hope you locate cooling solution and enjoy your airplane. Dennis Thomas ________________________________________________________________________________
Date: Aug 26, 2004
Subject: Cad 3 view
Can anyone point me to a cad 3 view drawing of a RV9A? Thanks peter ________________________________________________________________________________
Subject: Camlocs for the cowl
Date: Aug 27, 2004
See if this helps: SK-OS CLocR Plush Flush Stainless Steel Grommet $2.21 R4G Retainer Ring for CLocR $0.22 SK4002-1S S/S SLOTTED CLOCR $2.79 SK245-4 CLocR Floating Aluminum Receptacle ADJ I also used this reference: http://www.rv-8.com/Cowl.htm#Cowl%20fasteners Wayne (Thanks, Randy, for an excellent web site.) ________________________________________________________________________________
Date: Aug 27, 2004
From: "Joosten, Craig" <CJoosten(at)infiltratorsystems.net>
Subject: Re: RV9-List: First flight Date: Fri, 27 Aug 2004 08:03:10 -0400 Congratulations Dale, it is a beautiful plane! Craig http://www.w3.org/TR/REC-html40"> Congratulations Dale, it is a beautiful plane! Craig ________________________________________________________________________________
Date: Aug 28, 2004
Dale - how high were the temps? Steve. -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of Dale Larsen Subject: RV9-List: First flight Yesterday, after waiting seven weeks for an inspection and another twelve days for the inspector to finish the paperwork, RV9A N61DX took to the air. Aside from high cylinder temps, everything went well. This is a nice airplane! Dale --- ________________________________________________________________________________
Subject: Pitot tube hole
Date: Aug 28, 2004
As I built the wings I diligently followed Van's directions and drilled the hole for the pitot tube when they called for it. Now, before I close up the wings I realized I would like to install the Dynon EFIS unit along with their pitot tube so I can also have an AOA indicator. The problem is that the bracket I bought to hold the pitot tube doesn't cover the hole I have already drilled for the Van's tube. What do you suggest I do? A) Leave the hole open? B) Drill out the two adjacent rivets and put a small plate behind the spar web flange to cover the hole and put move the Pitot tube down? C) Return the Dynon pitot tube, due w/o the AOA, and just use the Dynon EFIS with the Van's pitot? Thanks for the help. Bill RV-9 Wings (Fuselage on order) SN: 90737 ________________________________________________________________________________
Subject: Re: Pitot tube hole
Date: Aug 28, 2004
I had exactly the same dilemma, I used the plate and a nice(almost) round piece to fill the drill hole. it worked out OK Harold Kovac -90373 finishing the wings ________________________________________________________________________________
Date: Aug 28, 2004
Subject: Insurance for non aviation engined RV's
Has anybody been through the dilemma of researching the viability of insuring an RV9A with a non Van's approved engine? Specifically the Egenfellner Subaru. So far Insurer's either will not write period, or the cost is prohibitive. Any comments will be welcome but keep in mind there are pro's and con's for both. Doing the Ben Franklin approach is an interesting study. Thanks ________________________________________________________________________________
Subject: Re: Insurance for non aviation engined RV's
Date: Aug 28, 2004
Go to the Eggenfellner site, http://eggenfellneraircraft.com/ (FAQ page) and/or the subaruaircraft(at)yahoo.com group, and you'll find there hasn't been a problem insuring those firewall forward complete engines. ----- Original Message ----- From: "Nigel Goad" <sirlegin(at)sbcglobal.net> Subject: RV9-List: Insurance for non aviation engined RV's > > Has anybody been through the dilemma of researching the viability of insuring an RV9A with a non Van's approved engine? Specifically the Egenfellner Subaru. So far Insurer's either will not write period, or the cost is prohibitive. > Any comments will be welcome but keep in mind there are pro's and con's for both. Doing the Ben Franklin approach is an interesting study. > Thanks > > ________________________________________________________________________________
Date: Aug 29, 2004
Bill, to fill the old pitot tube hole, I epoxied a sheet of Alclad on the backside. After curing, I filled the indentation with fiberglass, and after curing that, I finished it with Superfill. Here is a hint: when you install the Gretz mount, DO NOT rivet it to the wing skin until after riveting on the skin. Also, my Dynon did not go deep enough into the Gretz to get sufficient edge clearance for the screws that hold on the Dynon. I had to do some hand filing to get the two to mate. Leland Cleaning up the wiring "As I built the wings I diligently followed Van's directions and drilled the hole for the pitot tube when they called for it. Now, before I close up the wings I realized I would like to install the Dynon EFIS unit along with their pitot tube so I can also have an AOA indicator. The problem is that the bracket I bought to hold the pitot tube doesn't cover the hole I have already drilled for the Van's tube. What do you suggest I do? A) Leave the hole open? B) Drill out the two adjacent rivets and put a small plate behind the spar web flange to cover the hole and put move the Pitot tube down? C) Return the Dynon pitot tube, due w/o the AOA, and just use the Dynon EFIS with the Van's pitot?" ________________________________________________________________________________
Date: Aug 27, 2004
rv7-list(at)matronics.com, rv10-list(at)matronics.com, rv8-list(at)matronics.com, rv3-list(at)matronics.com, rv4-list(at)matronics.com
Subject: Van's Homecoming-- Where to eat
1.70 SUSPICIOUS_RECIPS Similar addresses in recipient list Scrumptous breakfast both Saturday & Sunday will be served right at Van's--pancakes, eggs, ham, sausage, bacon, coffee & orange juice. And lunch on Saturday, burgers, corn on the cob. Served by EAA Chapter 902. Don't miss out! ________________________________________________________________________________
From: "Larry PERRYMAN" <larry.perryman(at)atofina.com>
Date: Aug 30, 2004
08/30/2004 03:30:38 PM, Serialize complete at 08/30/2004 03:30:38 PM Nigel, Contact Falcon Insurance. They cover my Egg/ RV-9A with little or no penalty for the engine combo. They consider it a proven package like a Lycoming. Regards, Larry Perryman N9159S ________________________________________________________________________________
Date: Sep 02, 2004
Subject: Template for landing gear sockets
Help. Instructions on page 8-8 cal out the use of the template located on DWG 34 to locate the hole for the landing gear sockets & brake lines in the F 972 lower skin. I can not find this template. I either don't see it or it's not there. I really don't see how the gear would affect the F 972 lower skin. This is for a tail dragger. Thanks, Roger Ping 90869 ________________________________________________________________________________
Subject: RE: Template for landing gear sockets
Date: Sep 03, 2004
Roger, That would be for nosewheel planes.. I don't think it applies to your taildragger. (If you look at drawing 34A, you'll see the template but again, it's for nosewheel planes) Matthew Brandes, Van's RV-9A (Fuselage) EAA Chapter 868/91/1329 www.n523rv.com <http://www.n523rv.com/> ________________________________________________________________________________
Date: Sep 03, 2004
Subject: Re: Template for landing gear sockets
Hi Roger, The landing gear on your tail dragger mount in the engine mount. They require you to trim out a slight amount on the lower firewall flange a small cut out in the lower engine cowl. When you get to that point it will be quite obvious where and how much to cut. In the lower engine cowl I would suggest you cut out just enough for clearance at first. After you have installed gear leg fairings and made your intersection fairings you can enlarge the cut outs in the cowl a bit more (closer to the edge of intersection fairing) which will make removing engine a great deal easier. Good Luck. Dennis Thomas RV9, on the way to the Homecoming at Aurora. ________________________________________________________________________________
Date: Sep 03, 2004
what is the contact information for fairings, etc? -------------- Original message -------------- > > Hi Roger, > The landing gear on your tail dragger mount in the engine mount. They > require you to trim out a slight amount on the lower firewall flange a small > cut > out in the lower engine cowl. When you get to that point it will be quite > obvious where and how much to cut. > In the lower engine cowl I would suggest you cut out just enough for > clearance at first. After you have installed gear leg fairings and made your > intersection fairings you can enlarge the cut outs in the cowl a bit more > (closer to > the edge of intersection fairing) which will make removing engine a great deal > easier. > Good Luck. > > Dennis Thomas > RV9, on the way to the Homecoming at Aurora. > > > > > > what is the contact information for fairings, etc? -------------- Original message -------------- -- RV9-List message posted by: DThomas773(at)aol.com Hi Roger, The landing gear on your tail dragger mount in the engine mount. They require you to trim out a slight amount on the lower firewall flange a small cut out in the lower engine cowl. When you get to that point it will be quite obvious where and how much to cut. In the lower engine cowl I would suggest you cut out just enough for clearance at first. After you have installed gear leg fairings and made your intersection fairings you can enlarge the cut outs in the cowl a bit more (closer to the edge of intersection fairing) which will make removing engine a great deal easier. Good Luck. Dennis Thomas RV9, on the way to the Homecoming at Aurora. rowse Digests: http://www.matronics.com/digest/rv9-list ________________________________________________________________________________
Subject: Fairings Etc.
Date: Sep 03, 2004
http://www.fairings-etc.com/ Fairings-Etc. Bob Snedaker Shop Phone: 623/536-0951 Cell Phone: 623/203-9795 email: bob@fairings-etc.com Matthew Brandes, Van's RV-9A (Fuselage) EAA Chapter 868/91/1329 www.n523rv.com ________________________________________________________________________________
Date: Sep 05, 2004
Subject: New product announcement: affordable VG's
rvcanada-list(at)matronics.com, rveurope-list(at)matronics.com, rvsoutheast-list(at)matronics.com, sailplane-list(at)matronics.com, seaplane-list(at)matronics.com, skymaster-list(at)matronics.com, smithmini-list(at)matronics.com Hey folks, I double checked and Matt Dralle's earlier post says it's OK to post about new aviation products as long as the message doesn't come off as having a "flavor" of "traditional spam". Don't worry I'm not going to try to sell you anything that supposedly makes any of your body parts larger (or smaller) and this product is directly aviation related :) I'm just an airplane builder, owner, pilot, and aviation nut who wants to tell you where you can find more information about a great new product. I've been selling kits of vortex generators (VG's) for only $95 and my customers are telling me they really like the performance gains they're seeing. VG's are great for reducing stall speeds and allow you to land slower, shorter, and safer. I invite you to check out my site at www.landshorter.com and see what you think. My VG's can be quickly installed for testing using removable double-stick tape and come with a 100% money-back guarantee so why not try them out on your plane? You'll be really glad you did :) Thanks and let's keep 'em flying! Joa Harrison The VG Guy www.landshorter.com 1-877-272-1414 (toll free) ________________________________________________________________________________
Date: Sep 11, 2004
Subject: [ Bob Olds ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Bob Olds Subject: Vortex generators on RV-4 http://www.matronics.com/photoshare/Oldsfolks@aol.com.09.11.2004/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
From: "William Mcbride" <billmcbride(at)earthlink.net>
Subject:
Date: Sep 17, 2004
Dear Friends, My new email address is: BMcB(at)sbcglobal.net. Hope to hear from you all real soon. Bill McBride ________________________________________________________________________________
Subject: N369TM is flying in central Missouri
Date: Sep 21, 2004
From: "McIntosh, Todd" <McIntoshT(at)health.missouri.edu>
After 3 years and 2 months, N369TM (SN 90395) is flying. Without paint except for the internal surfaces which received a coat of PPG Epoxy primer, but with a full interior from Flight Line Interiors and a basic IFR panel, empty weight came in at 1070. It is powered by a new Aerosport O-320 with a new Sensenich prop pitched as recommended by Vans. After a little over 4 hours on its first couple of flights yesterday I am extremely pleased (grinning) and happy to say that it flies true and will not need any trim tabs or adjustments. Only a couple of squawks; I need to tighten the swivel in the nose wheel slightly and adjust the engine idle speed since it is a little low. No firm performance numbers at this point but I will post them as I get things calibrated (though it is far better than the C-150 I have been sharing!). ________________________________________________________________________________
Subject: Re: N369TM is flying in central Missouri
Date: Sep 21, 2004
09/21/2004 03:19:06 PM, Serialize complete at 09/21/2004 03:19:06 PM Todd, Congratulations on joining the club. Where are you flying out of? Enjoy the fruits of your labors now. Regards, Larry Perryman N194DL 90288 ________________________________________________________________________________
Date: Sep 21, 2004
congratulations. Hope you have a lot of blue skies days to enjoy your -9A. JC - Aracaju - Brasil ________________________________________________________________________________
Date: Sep 21, 2004
Great!!! Congratulations -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of McIntosh, Todd Subject: RV9-List: N369TM is flying in central Missouri After 3 years and 2 months, N369TM (SN 90395) is flying. Without paint except for the internal surfaces which received a coat of PPG Epoxy primer, but with a full interior from Flight Line Interiors and a basic IFR panel, empty weight came in at 1070. It is powered by a new Aerosport O-320 with a new Sensenich prop pitched as recommended by Vans. After a little over 4 hours on its first couple of flights yesterday I am extremely pleased (grinning) and happy to say that it flies true and will not need any trim tabs or adjustments. Only a couple of squawks; I need to tighten the swivel in the nose wheel slightly and adjust the engine idle speed since it is a little low. No firm performance numbers at this point but I will post them as I get things calibrated (though it is far better than the C-150 I have been sharing!). ________________________________________________________________________________
From: "Ernest Kells" <ernest.kells(at)sympatico.ca>
Subject: Rectangular Hole Cutout on the Prepunched Panel
Date: Sep 22, 2004
I have decided not to use at this time the rectangular hole in the prepunched panel. I need to buy or make a black hole cover. It is a standard cutout - 2.75 by 6.25. I have looked in all my catalogues and can find nothing. Does anyone know a source for hole covers for this standard width hole? I really don't want to fabricate this out of a sheet of aluminum. Thanks ________________________________________________________________________________
Subject: Re: Rectangular Hole Cutout on the Prepunched Panel
Date: Sep 22, 2004
09/22/2004 02:56:38 PM, Serialize complete at 09/22/2004 02:56:38 PM Ernest, Contact an avionics shop. They should have them or know who does. Regards, Larry Perryman ________________________________________________________________________________ Received-SPF: none (mail.corridor.net: domain of rv6(at)lockhart.net does not designate any permitted senders)
Subject: ANOTHER RV9A FLYING
Date: Sep 22, 2004
FIRST FLIGHT JUNE I 2004.''WOW'' WHAT AN AIRPLANE. Stats ENGINE AEROSPORTS 0-360 PROP SENSENCH 72 /85 PANEL IFR WITH STEAM GAUGES Weight 1059# PAINTED Climb 2000fpm Cruise 175 MPH INDICATED @8500 ft. Stall full flap 45 mph FUEL BURN 8 GPH AT CRUISE I have built and flown 5 other RV6-a and this is by far the finest airplane I have ever flown of this type. Hope all of you have the same experience that I have. Blue Skies and safe flying to all Ted F. Jones N669TJ ________________________________________________________________________________
Date: Sep 22, 2004
Congrats TED JONES I hope you and your airplane have a lot of time of full pleasure. > FIRST FLIGHT JUNE I 2004.''WOW'' WHAT AN AIRPLANE. Is there some modifications in the engine compartiment in use a Lyco 360 instead of Lyco 320? We have a friend here in Brasil thinking about to use a 360 engine in a -9A. JC - Aracaju - Brasil #90997 -9A QB Waiting for the kit ________________________________________________________________________________
Date: Sep 23, 2004
Subject: Re: ANOTHER RV9A FLYING
Ted, I thought a 320 was as big as you were supposed to put on a 9!!?? Glen Bankston RV-9A wings TED JONES wrote: > >FIRST FLIGHT JUNE I 2004.''WOW'' WHAT AN AIRPLANE. >Stats >ENGINE AEROSPORTS 0-360 >PROP SENSENCH 72 /85 >PANEL IFR WITH STEAM GAUGES >Weight 1059# PAINTED >Climb 2000fpm >Cruise 175 MPH INDICATED @8500 ft. >Stall full flap 45 mph >FUEL BURN 8 GPH AT CRUISE >I have built and flown 5 other RV6-a and this is by far the finest airplane I have ever flown of this type. Hope all of you have the same experience that I have. > >Blue Skies and safe flying to all > >Ted F. Jones >N669TJ > > > > ________________________________________________________________________________
Date: Sep 23, 2004
It's called a Super 9 GZ G B wrote: > > Ted, > > I thought a 320 was as big as you were supposed to put on > a 9!!?? > > Glen Bankston > RV-9A wings > > > TED JONES wrote: > > >> >>FIRST FLIGHT JUNE I 2004.''WOW'' WHAT AN AIRPLANE. >>Stats >>ENGINE AEROSPORTS 0-360 >>PROP SENSENCH 72 /85 >>PANEL IFR WITH STEAM GAUGES >>Weight 1059# PAINTED >>Climb 2000fpm >>Cruise 175 MPH INDICATED @8500 ft. >>Stall full flap 45 mph >>FUEL BURN 8 GPH AT CRUISE >>I have built and flown 5 other RV6-a and this is by far the finest airplane I have ever flown of this type. Hope all of you have the same experience that I have. >> >>Blue Skies and safe flying to all >> >>Ted F. Jones >>N669TJ >> >> >> >> > > > > > > > > ________________________________________________________________________________
Subject: Canopy: Tip-up vs Slider/Synergy Air
Date: Sep 25, 2004
RV-9A Group, I just picked up my Preview Plans and some videos the other day from Van's. Where can I find information on deciding on a canopy configuration. I'm a long way from needing to decide, but I'm curious. Slider vs Tip-up. I've only had one ride in the Van's demo -9A, with the slider. I use to fly a Grumman AA-5 which also had a sliding canopy. It is very nice on the ground on hot days. However, the visibility in the tip-up looks incredible. What are the pros and cons of each? Also, has anybody on the list gone to the 1-day Synergy Air metalworking class? I live near Portland, Oregon, so Eugene is not very far. Has anybody done the 6-day quick-build empenage class at Synergy? Is it worth the $$$$? Thanks, Bob Gresli Hillsboro OR (HIO) ________________________________________________________________________________
Date: Sep 25, 2004
Subject: Re: Canopy: Tip-up vs Slider/Synergy Air
Bob, I did the Synergy Air course last year and it was very good. You will learn a lot. Plan for a very loooong day if you commute, starting the class at 8 & ending around 6. Closer to home there is the Henry Gorgas course, which is a 2 day thing & it is over on the west side somewhere. Henry gets good reviews, also. Slider vs. tip up: On the RV List the consensus seems to be the work involved is about equal in terms of time and difficulty. The big advantages of the tip up as I recall is instrument access and unobstructed visibility, while the slider has the cool factor. I believe the slider is safer if the plane goes on it's back because of the location of the roll bar--draw a straight line from the nose to the tip of the tail and look at where the roll bar is in relation to your head & you'll see what I mean. On the other hand, Mike Robertson of the FAA says there is no difference. Regarding instrument access, the tip up advantage can be negated a little by using a modular panel in the slider. And at Van's homecoming a couple years ago, I saw a tip up left open and there seemed to be a lot of stress on the thing when a breeze came up. No problem, of course, with the slider. Richard Scott At 12:46 PM 9/25/2004, you wrote: > >RV-9A Group, > >I just picked up my Preview Plans and some videos the other day from Van's. > >Where can I find information on deciding on a canopy configuration. I'm a >long way from needing to decide, but I'm curious. Slider vs Tip-up. > >I've only had one ride in the Van's demo -9A, with the slider. I use to >fly a Grumman AA-5 which also had a sliding canopy. It is very nice on >the ground on hot days. However, the visibility in the tip-up looks >incredible. > >What are the pros and cons of each? > >Also, has anybody on the list gone to the 1-day Synergy Air metalworking >class? I live near Portland, Oregon, so Eugene is not very far. > >Has anybody done the 6-day quick-build empenage class at Synergy? Is it >worth the $$$$? > >Thanks, > >Bob Gresli >Hillsboro OR (HIO) > > ________________________________________________________________________________
Date: Sep 26, 2004
Greetings Bob- Just wanted to let you know that you may not have to choose between a slider and a canopy! I saw a guy at OSH this year who is offering a combination slider / tip up canopy. It's pretty slick, so I grabbed one of his brochures. His website is www.aircraftextras.com. Noah Forden ________________________________________________________________________________
Date: Sep 26, 2004
Hi Guys, I chose the slider because I wanted to be able to utilize the baggage area easier. If you use the slider canopy and use the "tip up" modification that "aircraftextras.com" has for sale, you can use the baggage area with ease. I saw it at Oshkosh and watched the designer open and close the canopy with ease. The access to the baggage area to me is important as my wife and I will be using out "9" for cross countrys. The original slider makes for a tight loading arrangement and the tip up canopy the same. Just a thought and a consideration. Jim Nelson N599RV (reserved) ________________________________________________________________________________
Subject: Diesel engines in RV9
Date: Sep 26, 2004
Hi Anyone any experience of fitting diesels in 9's and the performance that resulted? Considering the Wilksch 120 engine. Cost of AVGAS in the UK is now extortionate so a diesel equipped 9 appears to be the answer. David Wilson Ready to order kit with 3 friends ________________________________________________________________________________
From: "vicwj(at)earthlink.net" <vicwj(at)earthlink.net>
Date: Sep 26, 2004
Original Message: ----------------- From: Richard Scott rscott(at)cascadeaccess.com Date: Sat, 25 Sep 2004 18:26:04 -0700 List, Would someone with a tip-up comment on taxing with the canopy slightly open for venilation. Perhaps using a saftey strap to keep it from flying up! Vic Subject: Re: RV9-List: Canopy: Tip-up vs Slider/Synergy Air Bob, I did the Synergy Air course last year and it was very good. You will learn a lot. Plan for a very loooong day if you commute, starting the class at 8 & ending around 6. Closer to home there is the Henry Gorgas course, which is a 2 day thing & it is over on the west side somewhere. Henry gets good reviews, also. Slider vs. tip up: On the RV List the consensus seems to be the work involved is about equal in terms of time and difficulty. The big advantages of the tip up as I recall is instrument access and unobstructed visibility, while the slider has the cool factor. I believe the slider is safer if the plane goes on it's back because of the location of the roll bar--draw a straight line from the nose to the tip of the tail and look at where the roll bar is in relation to your head & you'll see what I mean. On the other hand, Mike Robertson of the FAA says there is no difference. Regarding instrument access, the tip up advantage can be negated a little by using a modular panel in the slider. And at Van's homecoming a couple years ago, I saw a tip up left open and there seemed to be a lot of stress on the thing when a breeze came up. No problem, of course, with the slider. Richard Scott At 12:46 PM 9/25/2004, you wrote: > >RV-9A Group, > >I just picked up my Preview Plans and some videos the other day from Van's. > >Where can I find information on deciding on a canopy configuration. I'm a >long way from needing to decide, but I'm curious. Slider vs Tip-up. > >I've only had one ride in the Van's demo -9A, with the slider. I use to >fly a Grumman AA-5 which also had a sliding canopy. It is very nice on >the ground on hot days. However, the visibility in the tip-up looks >incredible. > >What are the pros and cons of each? > >Also, has anybody on the list gone to the 1-day Synergy Air metalworking >class? I live near Portland, Oregon, so Eugene is not very far. > >Has anybody done the 6-day quick-build empenage class at Synergy? Is it >worth the $$$$? > >Thanks, > >Bob Gresli >Hillsboro OR (HIO) > > ________________________________________________________________________________
Date: Sep 26, 2004
Subject: fuel
Hi everyone: The avgs 100LL in Brasil costs R$4.60/liter, it means US$6.14/gal. Several airplanes owners are changing the carbs and/or fuel injection system to burn alcohol RS$1,6/liter <==> US$2.13/gal. There isnt alcohol in airports gas stations, only out of airport gas stations. The problem is some airport management dont agree to bring alcohol from a gas station in some bulks and fill up the tanks. It could be done in airclubs without problem. Lycos engines could burn 87 octanes fuel. We call it "avcar". Avcar costs R$2,00/liter <==> US$2.67/gal. The problem of bringing fuel from out of airport gas station is the same. JC - Aracaju - Brasil #90997 -9A QB waiting for the kit. ________________________________________________________________________________
Date: Sep 26, 2004
Does that give you the best or worst of both worlds? Extra weight and complexity means lower useful load and longer build time. :( I selected the tip-up because of the unobstructed view it offers. Still, I think the slider wins major "cool" points. Bill R. SN: 90737 -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Noah Forden Subject: RV9-List: Canopy: Tip-up vs Slider Greetings Bob- Just wanted to let you know that you may not have to choose between a slider and a canopy! I saw a guy at OSH this year who is offering a combination slider / tip up canopy. It's pretty slick, so I grabbed one of his brochures. His website is www.aircraftextras.com. Noah Forden == direct advertising on the Matronics Forums. == == == ________________________________________________________________________________
Subject: fuel
Date: Sep 26, 2004
Interesting thought. I believe the Germans tried that in WWII but I'm not sure how successful it was. As I understand it, alcohol absorbs water, thus it isn't considered a good option for aircraft use. In the US, aircraft with auto fuel STC's can't run auto fuel with alcohol (Gasahol is what we call it up here.) because of the water absorption issue. I would think installing a diesel or auto engine conversion would be a better option for you. Bill Repucci RV-9 SN: 90737 Waiting for the fuselage kit. -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of jc(at)INFONET.COM.BR Subject: RV9-List: fuel Hi everyone: The avgs 100LL in Brasil costs R$4.60/liter, it means US$6.14/gal. Several airplanes owners are changing the carbs and/or fuel injection system to burn alcohol RS$1,6/liter <==> US$2.13/gal. There isnt alcohol in airports gas stations, only out of airport gas stations. The problem is some airport management dont agree to bring alcohol from a gas station in some bulks and fill up the tanks. It could be done in airclubs without problem. Lycos engines could burn 87 octanes fuel. We call it "avcar". Avcar costs R$2,00/liter <==> US$2.67/gal. The problem of bringing fuel from out of airport gas station is the same. JC - Aracaju - Brasil #90997 -9A QB waiting for the kit. == direct advertising on the Matronics Forums. == == == ________________________________________________________________________________
Date: Sep 26, 2004
Better yet, has anyone ever installed a radial engine on an RV-6, -7, or -9? I think it would look something like a Spartan Exec and sound just as good as the Exec looks. Bill R. -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of david wilson Subject: RV9-List: Diesel engines in RV9 Hi Anyone any experience of fitting diesels in 9's and the performance that resulted? Considering the Wilksch 120 engine. Cost of AVGAS in the UK is now extortionate so a diesel equipped 9 appears to be the answer. David Wilson Ready to order kit with 3 friends == direct advertising on the Matronics Forums. == == == ________________________________________________________________________________
Date: Sep 26, 2004
Subject: fuel
Hi Bill: Thats the best of using alcohol fuel. They dont need to drain the tanks :-)). Some papers show the maximum water absorption is 3% of the total volume. No problem burnning it. The major problem in using alcohol is the consuption. It is bigger than avgas consuption. If the compression of the engine is raised by machinning the cilinders the maximum power output will be raised too. JC - Aracaju - Brasil #90997 -9A QB waiting for the kit ________________________________________________________________________________
Subject: Primer-I am finally out of the SW wash primer
Date: Sep 26, 2004
Fellow builders, I just finished primering the wing skins and I am finally out of the SW wash primer. I am very disappointed in this product and do not recommend it. Years ago I used a wash primer similar to the SW on my RV-4 with very little problems, however the SW was a real nightmare. My main issue is spitting of chunks of semi congealed primer on the surface and runs. I mixed the primer per the directions, tried different pressures and different guns, but still similar results. I live in Arizona and the climate is a bit dry which may have contributed. The inside of my wing skins are speckled with primer, but know one will see this. Now that I am finished primering all my wing components I will be using the AKZO primer on the fuselage. It may be more of a little hassle to set up, but the results appear so much more consistent then the SW primer. Paul RV-4/RV-7A ________________________________________________________________________________
Date: Sep 26, 2004
Mine is a tip up and I'm now at 125 hours. I always leave it unlocked and partially open on the ground. On the ground it gets very warm if left closed but you can release the latch and lift it up and prop it open with the lifting handle rotated to hold it up. Works out fine. It doesn't need to be held down. I'm told that if you forget to latch it before take off it just lifts up a bit and cannot be closed or opened further before you land and close it. Dennis Thomas ________________________________________________________________________________
Subject: SW wash primer
Date: Sep 27, 2004
I had the same problem the first time I used the SW wash primer. Another RV builder solved my problem. The first thing you have to do is stir the paint with a drill motor long enough to completely mix the paint. The second is to mix the paint one part paint to two parts activator instead of one to one and a half. After I did that it works great and sticks like concrete. After I mixed the paint the first time it doesn't take but a minute to remix it later when you get ready to paint again, but it is necessary to stir the paint very well. I've used PPG 271 epoxy primer over the Sherwin Williams wash primer and then top coated and had no problem with adhesion or reactions. Jim Wright RV-9A 90919 Empennage finished working on wings ________________________________________________________________________________
Date: Sep 27, 2004
Subject: Fwd: Slider
>Listers, This apparently was sent directly to me by mistake from a Bryan Carr. Relevant to the slider vs. tip-up discussion. Richard Scott >Had a friend go into the water after an engine failure. >He had a tip up. >The aircraft flipped over when the gear hit. >He couldn't get the canopy open. >He and his passenger drowned. >Get a slider. > ________________________________________________________________________________
Date: Sep 27, 2004
> David Wilson > Ready to order kit with 3 friends I didn't know this was an option back when I ordered my kit #59. They just started calling at all hours and showing up at the workshop. Now that I'm flying, there's even more of them! (sorry, I couldn't resist ; ) ________________________________________________________________________________
Subject: Nosewheel shimmy
Date: Sep 28, 2004
All, I have a problem with my 9-A nosegear. On landing, there is a shimmy in the vertical direction. This is not noticable to the pilot, but observers have commented about it. Anyone else have this problem? Thanks, Dale ________________________________________________________________________________
Date: Sep 28, 2004
Subject: Re: Nosewheel shimmy
I have a feeling my nose gear is doing this to some degree, although I can't feel anything. I always keep the nose gear off the ground as long as possible on rollout. My hypothesis is that the nose wheel doesn't roll freely all the way around... there is a point in the rotation with more resistance that causes the whole gear to move back and forth. My nose wheel doesn't "spin" freely when I take the weight off of it. Should it? --clay --- Dale Larsen <slickrock@been-there.com> wrote: > <slickrock@been-there.com> > > All, > > I have a problem with my 9-A nosegear. On landing, > there is a shimmy in the > vertical direction. This is not noticable to the > pilot, but observers have > commented about it. > > Anyone else have this problem? > > Thanks, > > Dale > _______________________________ Declare Yourself - Register online to vote today! http://vote.yahoo.com ________________________________________________________________________________
Date: Sep 28, 2004
First, consider how the nose gear is designed. What other way is it going to move? Secondly, make sure your onlookers are not confusing wheel pant movement with gear leg movement. If you don't feel it, chances are its just some small amount of wheel pant movement. Finally, make sure your nose gear leg fits snugly into the engine mount receptacle. If there is play between the gear leg and tube, you can wrap a feeler gauge blade (find the one that fits best with weight off the wheel) around the gear leg to take up the slack and secure it with a bit of silicone sealer around the leg. Regarding free turning nose wheels. This bugs the crap outta me. Yes our wheels should spin freely without sticky spots. But the design of the Cleveland wheel is such that you cannot tighten the front axle without causing bearings to bind. It should have had a machined spacer and shims or used straight bearings instead of tapered bearings. Bogus design... Because we cannot tighten the front axle bolt, and the axle bolt is the primary mounting method for the wheel pant, this leads to shimmying wheel pants, binding bearings, and scored nose gear forks. I just had a nose wheel go flat (just before takeoff fortunately) and when I removed the wheel, there was clear evidence that the spacers were spinning against the nose fork and on the axle bolt. Not good. I know others have drilled and tapped small screws to prevent the spacers from spinning, but the real fix would be a different front wheel. In short,,, don't worry about shimmy if you don't feel it, but keep an eye on your front axle bolt. Gary ________________________________________________________________________________
Date: Sep 28, 2004
Gary, I'm flying without pants (on the gear that is...) and the gear fits snugly in the socket. I have watched it shimmy myself, when my buddy landed it. It looks like the front wheel is out of round (which it isn't). It moves 1 to 1-1/2 inches at about a 3 Hz rate. Maybe the wheel is out of balance? Dale ----- Original Message ----- From: <fcs(at)jlc.net> Subject: Re: RV9-List: Nosewheel shimmy > > > First, consider how the nose gear is designed. What other way is it going > to move? Secondly, make sure your onlookers are not confusing wheel pant > movement with gear leg movement. If you don't feel it, chances are its > just some small amount of wheel pant movement. Finally, make sure your > nose gear leg fits snugly into the engine mount receptacle. If there is > play between the gear leg and tube, you can wrap a feeler gauge blade (find > the one that fits best with weight off the wheel) around the gear leg to > take up the slack and secure it with a bit of silicone sealer around the > leg. > > Regarding free turning nose wheels. This bugs the crap outta me. Yes our > wheels should spin freely without sticky spots. But the design of the > Cleveland wheel is such that you cannot tighten the front axle without > causing bearings to bind. It should have had a machined spacer and shims > or used straight bearings instead of tapered bearings. Bogus design... > Because we cannot tighten the front axle bolt, and the axle bolt is the > primary mounting method for the wheel pant, this leads to shimmying wheel > pants, binding bearings, and scored nose gear forks. I just had a nose > wheel go flat (just before takeoff fortunately) and when I removed the > wheel, there was clear evidence that the spacers were spinning against the > nose fork and on the axle bolt. Not good. I know others have drilled and > tapped small screws to prevent the spacers from spinning, but the real fix > would be a different front wheel. > > In short,,, don't worry about shimmy if you don't feel it, but keep an eye > on your front axle bolt. > > Gary > > ________________________________________________________________________________
Date: Sep 28, 2004
Hey Guys, you solve this problem easily by replacing the thing with a tail wheel. Dennis Thomas RV-9 126 hours ________________________________________________________________________________
Date: Sep 28, 2004
Yelp but why go backwards???? -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of DThomas773(at)AOL.COM Subject: Re: RV9-List: Nosewheel shimmy Hey Guys, you solve this problem easily by replacing the thing with a tail wheel. Dennis Thomas RV-9 126 hours ________________________________________________________________________________
"RV Matronics List"
Subject: Windshield Frame
Date: Sep 28, 2004
on mail5 I visited a local builder who had fabricated an aluminum panel at the base of the windshield and along the canopy frame on both an RV-6A and -7A. It looked very nice and neat and he said he did it because he didn't like fiberglass (I understand that!). It was screwed in place to both the cowl and the screen and sealed with silicone. Has anybody else done this? I'm considering doing this because of the neat appearance and also I think replacing a cracked screen would be infinitely easier. Any thoughts out there in RV Land? Doug Fischer 90706 Wings Jenison, MI ________________________________________________________________________________
From: "Albert Gardner" <spudnut(at)worldnet.att.net>
Date: Sep 28, 2004
I've had the same problem from time to time. Once, when I landed, the nose gear shadow was just in front of the wing and I could see the gear was moving fore and aft. When it does this I can feel some vibration. At first I thought it started after the nose gear first touched but now it's clear it starts when the mains touch and the nose wheel is still off the ground. It seems to be affected by tire pressure and axel bolt tightness but I don't see why since it starts before the nose wheel touches. So now I just keep the nose gear off the ground as long as possible. Why, yesterday, I kept it off until I got out and tied it down on the ramp! Albert Gardner RV-9A 872RV Yuma, AZ ________________________________________________________________________________
Date: Sep 29, 2004
> It moves 1 to 1-1/2 inches at about a 3 Hz rate. > Maybe the wheel is out of balance? > Dale Wow, and you say you can't feel this?!? I suppose it is possible that your tube is folded or pinched inside the tire, causing major imbalance. If you think this is the case, you should immediately take the wheel apart and check. Trust me, you don't want to experience a flat tire. Some degree of bouncing is to be expected with a spring type nose gear leg, but that's way more than I have seen. Check your axle bolt tension while you're at it and make sure your wheel is rotating freely. Also check your nose fork breakout tension. If it is too loose the wheel can wobble violently from side to side just as it touches the pavement. Use a fish-scale to actually set it per Vans instructions. The fork must have a good bit of tension and not just swivel freely. If you can't find the culprit, I would give Vans a call and see if they have any further clues. ________________________________________________________________________________
Date: Sep 29, 2004
Subject: Re: Windshield Frame
I know an RV6 builder who used sheet metal on the front of his windscreen for the same reason. He intends to redo it the future but it looks great to me. This guy is a real perfectionist, the best technician at a government Lab, and a superb craftsman. It is also the third plane he built. I would try it as I had such a bear of a time with the slider canopy skirts that I finally made those out of fiberglass. Leland in Kalifornia Almost ready to install the windscreen "I visited a local builder who had fabricated an aluminum panel at the base of the windshield and along the canopy frame on both an RV-6A and -7A. It lookedvery nice and neat and he said he did it because he didn't like fiberglass (Iunderstand that!). It was screwed in place to both the cowl and the screen andsealed with silicone. Has anybody else done this? I'm considering doing thisbecause of the neat appearance and also I think replacing a cracked screen would be infinitely easier. Any thoughts out there in RV Land?" ________________________________________________________________________________
Date: Sep 30, 2004
Axle bolt tension is good, breakout tension is adjusted per plans with a fish scale. Tire pressure is good, and wheel rotates freely. On closer investigation, it only occurs at the end of the rollout, when you start to brake hard. If you don't brake at all, it dosent shimmy. I would think that if it were due to a balance condition that it would be poportional to the speed of the wheel. No shimmy on takeoff. > > > > It moves 1 to 1-1/2 inches at about a 3 Hz rate. > > Maybe the wheel is out of balance? > > Dale > > Wow, and you say you can't feel this?!? I suppose it is possible that > your tube is folded or pinched inside the tire, causing major imbalance. > If you think this is the case, you should immediately take the wheel apart > and check. Trust me, you don't want to experience a flat tire. Some > degree of bouncing is to be expected with a spring type nose gear leg, but > that's way more than I have seen. Check your axle bolt tension while > you're at it and make sure your wheel is rotating freely. Also check your > nose fork breakout tension. If it is too loose the wheel can wobble > violently from side to side just as it touches the pavement. Use a > fish-scale to actually set it per Vans instructions. The fork must have a > good bit of tension and not just swivel freely. If you can't find the > culprit, I would give Vans a call and see if they have any further clues. > > ________________________________________________________________________________
Date: Sep 30, 2004
Is your brake rotors true ? ----- Original Message ----- From: "Dale Larsen" <slickrock@been-there.com> Subject: Re: RV9-List: Nosewheel shimmy > > Axle bolt tension is good, breakout tension is adjusted per plans with a > fish scale. Tire pressure is good, and wheel rotates freely. > > On closer investigation, it only occurs at the end of the rollout, when you > start to brake hard. If you don't brake at all, it dosent shimmy. I would > think that if it were due to a balance condition that it would be > poportional to the speed of the wheel. > > No shimmy on takeoff. > ________________________________________________________________________________
Date: Sep 30, 2004
Oops, "Are" your brake rotors true ? Its been a rough morning :) > Is your brake rotors true ? > > ----- Original Message ----- > From: "Dale Larsen" <slickrock@been-there.com> > To: > Sent: Thursday, September 30, 2004 12:48 PM > Subject: Re: RV9-List: Nosewheel shimmy > > > > > > Axle bolt tension is good, breakout tension is adjusted per plans with a > > fish scale. Tire pressure is good, and wheel rotates freely. > > > > On closer investigation, it only occurs at the end of the rollout, when you > > start to brake hard. If you don't brake at all, it dosent shimmy. I would > > think that if it were due to a balance condition that it would be > > poportional to the speed of the wheel. > > > > No shimmy on takeoff. > > > ________________________________________________________________________________
Date: Sep 30, 2004
> Axle bolt tension is good, breakout tension is adjusted per plans with a > fish scale. Tire pressure is good, and wheel rotates freely. > On closer investigation, it only occurs at the end of the rollout, when you > start to brake hard. If you don't brake at all, it dosent shimmy. I would > think that if it were due to a balance condition that it would be > poportional to the speed of the wheel. > No shimmy on takeoff. OK, now it's getting strange... Have you EVER overtightened the axle bolt? The only theory I can cook up to explain your symptoms is as follows: If your bearings are scored or damaged, then independent application of brakes will naturally increase the side-loads on the bearings. If the bearings are scored or damaged in any way, this could cause binding and wheel hop. ...boy is that a stretch, but... Anyone else got a theory to offer? ________________________________________________________________________________
Date: Sep 30, 2004
At this point, you may want to verify that your nose gear leg is not bent or installed crooked to. ________________________________________________________________________________
Subject: Nose Wheel Shimmy
Date: Sep 30, 2004
I had the same problem, I took a piece of tubing and cut it to the propper length so that I could tighten the nose wheel bolt and keep the spacers from turning and still have the nose wheel turn easy. Use a piece of dowel just long enough to hold the tubing between the spacers and slide the dowel out with the nose wheel bolt, leaving the tubing onthe bolt between the spacers while installing the wheel. Laurel McKone N120LM ________________________________________________________________________________
Date: Oct 01, 2004
>... and rubbing against the wheel pant He said his wheel pants are not installed. A rubbing tire will carve it's shape into the wheel pant opening in one or two landings, but you're right to suspect this if the gap were very close. Somehow I think this is a bearing issue... I have no idea what VANS was thinking to select a double-taper bearing type wheel in this application. If the wheel were mounted in an inflexible fork with a more reasonable adjustible axle tension, this would work fine. But the RV nose fork is not as strong as it looks and a simple bolt that cannot be tightened down and has no cotter pin to secure it, is just not right. To use the same bolt to secure the wheel pant is equally bogus. The bolt can't be tightened!!! ________________________________________________________________________________
Subject: Dynon Pitot Tube vs. Gretz mount
Date: Oct 01, 2004
(The following is not intended to point a finger at either Warren Gretz or the people at Dynon, it is simply a request for information from the RV builder community.) Last weekend was spent cutting the left wing skin and fitting the Gretz pitot tube mast, which is supposed to hold the Dynon pitot tube I bought for my future EFIS system. After cutting the wing skin, drilling holes in the ribs for the AOA line, etc. I test fit the mast and all looked good until I slid the pitot tube down the mast and found the pre-drilled holes in the mast that are to hold the pitot tube in place wouldn't leave any room for proper edge distance . I'm currently talking to both Dynon and Warren Gretz about a solution. BTW, both the Gretz mount and the Dynon unit seem to be top quality items and I do expect there will be an easy resolution. (I smudged the chrome pitot tube bracket so the flash wouldn't wash it out. The chrome finish on the mast appears to be top notch.) You can see a picture of what I'm talking about here: http://www.repucci.com/bill/images/dynon%20and%20gretz.jpg If any of you has a factory built pitot tube laying around, could you measure the shoulder depth and send me a note? The Dynon unit is supposed to be identical to what Cessna uses. Thanks for your help. Bill SN: 90737 Finishing up the wings and waiting for the next big box. www.repucci.com/bill/baf.html ________________________________________________________________________________
Subject: Re: e: RV9-List:Mounting O320
Date: Oct 01, 2004
What is the trick to installing an O320 on a dynafocal mount? Thanks, Ned ________________________________________________________________________________
Date: Oct 01, 2004
Ned, I found it was easiest to put the engine mount on the engine, bottom dynafocal mounts first, then top. Then mount it all to the firewall. It takes a lot of patience and persuasion (rubber mallet) to get the last two bolts in. Others may have an easier method, but that's what worked for me. Dale ----- Original Message ----- From: "923te" <923te(at)cox.net> Subject: Re: RV9-List:Mounting O320 > > What is the trick to installing an O320 on a dynafocal mount? > > Thanks, > Ned > > ________________________________________________________________________________
Date: Oct 01, 2004
Date: Oct 02, 2004
Subject: Long trip to Aurora-OR
Hi everyone: opportunity to learn some tips and see another RVs. I must tell you that in Brasil we have only three RVs flying, may be one or two more. I never flew an RV in my life. Just bought it from internet adds and comments in magazines. Ill depart from Aracaju - Brasil, Oct, 10th, to VANs factory, Aurora-OR, by Boeing. A ~5,000 NM trip. Just to pick up my QB and drive it to Houston-TX, another long trip, by Chevy 2500, from Mike. My arrival date in Seattle, Oct,11th, 07:00 am, arrive in Portland, Oct,11th, aft, Stay in Aurora till Oct, 14th, aft. Any RVs friend will be nice to meet. JC - Aracaju - Brasil #90997 waiting for the kit ________________________________________________________________________________
Date: Oct 02, 2004
Ned, Due to the angle of the bolts, it is an ordeal. Go here for instructions: http://www.vansairforce.net/articles/IllustratedGuideToEngineHanging/engineh anging.htm I hung mine solo in about 4 hours time. Get a helper! Good Luck, Jerry Calvert Edmond Ok N296JC RV6 ----- Original Message ----- From: "923te" <923te(at)cox.net> Subject: Re: RV9-List:Mounting O320 > > What is the trick to installing an O320 on a dynafocal mount? > > Thanks, > Ned > > ________________________________________________________________________________
Date: Oct 02, 2004
Subject: Re: Dynon Pitot Tube vs. Gretz mount
I had the same problem. I put a mark around the pitot about 1/8 or 3/16 from the edge of the ground area. I used the belt sander very carefully and extended the ground area. Looks great. However, it would be better if they coordinated since they did recommend a gretz mount. ________________________________________________________________________________
Date: Oct 02, 2004
That's the answer I've heard from one other. I did start with a different mount but after seeing how the Gretz attached to the wing, I ordered it. The other mount simply had the holes closer to the end of the mount. That's why I'm curious about the edge distance on a factory (certified) pitot tube. Bill -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of JohnCClarkVA(at)cs.com Subject: Re: RV9-List: Dynon Pitot Tube vs. Gretz mount I had the same problem. I put a mark around the pitot about 1/8 or 3/16 from the edge of the ground area. I used the belt sander very carefully and extended the ground area. Looks great. However, it would be better if they coordinated since they did recommend a gretz mount. == direct advertising on the Matronics Forums. == == == ________________________________________________________________________________
Subject: Copperstate Fly-in and the DRDT-2
Date: Oct 02, 2004
Fellow RV builders, The DRDT-2 (Deep Reach Dimpling Tool) from ExperimentalAero (www.experimentalaero.com) will be at the Copperstate Fly-in (Casa Grande, AZ) www.copperstate.org . Stop by the Avery Tools booth and see the tool that makes dimpling easy, consistent, quiet, safe and less fatiguing then the standard impact c-frame dimpler. I had hoped to have a dimpling contest between the DRDT-2 and the impact c-frame dimpler. The Copperstate organizers don't permit noisy demonstrations that will interfere with the other businesses in the vendor booth area. So the only demonstrations of a deep reach dimpling tool at the Fly-in will be the DRDT-2. The DRDT-2 will be at the Avery Tools Booth Saturday 10/9/04. Paul ________________________________________________________________________________
Date: Oct 03, 2004
In a message dated 10/2/04 1:58:35 AM Central Daylight Time, rv9-list-digest(at)matronics.com writes: I'm currently talking to both Dynon and Warren Gretz about a solution. BTW, both the Gretz mount and the Dynon unit seem to be top quality items and I do expect there will be an easy resolution. Bill: Please post what the resolution to this issue turns out to be...I have a Gretz mount already installed and I'm about to order my DYNON Pitot tube... Thanks. Doug Lomheim 90116 "ONCE YOU HAVE TASTED FLIGHT YOU WILL WALK THIS EARTH WITH YOUR EYES TURNED SKYWARD. FOR THERE YOU HAVE BEEN, AND THERE YOU LONG TO RETURN" Leonardo Da Vinci ________________________________________________________________________________
Subject: Souther Arizona RV builders?
Date: Oct 03, 2004
Fellow Southern Arizona RV builders. I am building a RV-7A in Tucson Arizona (wings 80% complete) and I am trying to get a list of RV builders (not owners) here in Southern Arizona. Please chime in with the type and status of your project. You can contact me directly at merems(at)cox.net or post directly to the newsgroup. ________________________________________________________________________________
Subject: Re: Souther Arizona RV builders?
Date: Oct 03, 2004
Roger Evenson, Tucson. RV-9A, Finishing kit. ----- Original Message ----- From: "Merems" <merems(at)cox.net> ; ; ; Subject: RV9-List: Souther Arizona RV builders? > > Fellow Southern Arizona RV builders. > > I am building a RV-7A in Tucson Arizona (wings 80% complete) and I am trying to get a list of RV builders (not owners) here in Southern Arizona. Please chime in with the type and status of your project. You can contact me directly at merems(at)cox.net or post directly to the newsgroup. > > ________________________________________________________________________________
Subject: PROSEAL SHELF LIFE
Date: Oct 04, 2004
HOWDY LISTERS.. CAN ANYONE TELL ME IF PROSEAL AFTER A YEAR IN THE REFIGERATOR IS STILL GOOD. I HAVE ONLY USED IT TWICE. I AM SAVING MYSELF FOR THE FINAL ABUSE WITH THE TANKS. THANKS DAVID #90079 AILERON,AND FLAPS DONE HOWDY LISTERS.. CAN ANYONE TELL ME IF PROSEAL AFTER A YEAR IN THE REFIGERATOR IS STILL GOOD. I HAVE ONLY USED IT TWICE. I AM SAVING MYSELF FOR THE FINAL ABUSE WITH THE TANKS. THANKS DAVID #90079 AILERON,AND FLAPS DONE ________________________________________________________________________________
Date: Oct 03, 2004
Subject: Re: PROSEAL SHELF LIFE
Hi Dave, The catalogue, or someone says the stuff is only good for 6 months. I have a can I've had for over 4 years and it still works fine. If your concerned you might mix up a tiny batch and see how it sets up. Once when doing my tanks I mixed a batch without quite enough catalyst and it didn't set up right away but after about 3 days it was fine. Dennis ________________________________________________________________________________
Date: Oct 04, 2004
From: Howard Crawford <crawfordh(at)mac.panasonic.com>
Subject: RE: RV9-List: PROSEAL SHELF LIFE Date: Mon, 4 Oct 2004 10:12:45 -0400 David, My two cents worth. I would not use outdated pro-seal in the fuel tank application. Reason being once the tanks are complete and you have a problem with leaks cause by the old pro-seal, the repairs are going to be very difficult unless you install inter tank access plates before assembly of the tanks. Pro-seal is cheap compared to the aggregation that you will will run into because of outdated material. Yes, pro-seal will have a longer shelf life by being stored in the frig, but at what time is the material no longer good? There are a lot of highly educated people that develop this type of material, and they say the date is the date that pro-seal shelf life has expired. David if you have just one open container of pro seal in the frig, I can tell you that it will not be enough sealant in that one container to do the fuel tanks. I finished my tanks for the RV10 about 30 days ago. What I did was purchase the premixed 3 OZ tubes which can be purchased from Vans or from other distributors. Let me tell you that you will only be able to apply 3 oz a day which will take 4 to 5 hours to complete including clean up of tools, tank and self. At about the three hour level the sealant is setting up so you must plan what you want to accomplish in 3 hours. Not only do you have fresh sealant everyday, but it is so easy to mix, stick in a calking gun and apply as needed. I used about 20 oz of sealant per tank, and about half of that was waste. I would use the old Pro-seal on other sealant jobs that do not have the importance that the fuel tanks have. For what is worth. Howard RV-10 #10017 N10XV Fuselage assembly. -----Original Message----- From: kikideemax(at)comcast.net [mailto:kikideemax(at)comcast.net] Subject: RV9-List: PROSEAL SHELF LIFE HOWDY LISTERS.. CAN ANYONE TELL ME IF PROSEAL AFTER A YEAR IN THE REFIGERATOR IS STILL GOOD. I HAVE ONLY USED IT TWICE. I AM SAVING MYSELF FOR THE FINAL ABUSE WITH THE TANKS. THANKS DAVID #90079 AILERON,AND FLAPS DONE ________________________________________________________________________________
Date: Oct 04, 2004
10/04/2004 05:29:41 PM, Serialize complete at 10/04/2004 05:29:41 PM Mine worked just fine. If there is any doubt, mix up a bit and put it our to cure. If it cures out OK, then use it. As I remember it, ProSeal has a shelf life of about a year without refrigeration and refrigeration extends it. Regards, Larry Perryman kikideemax(at)comcast.net Sent by: owner-rv9-list-server(at)matronics.com 10/03/2004 08:38 PM Please respond to rv9-list To: rv9-list(at)matronics.com (matronics e-mail) cc: Subject: RV9-List: PROSEAL SHELF LIFE HOWDY LISTERS.. CAN ANYONE TELL ME IF PROSEAL AFTER A YEAR IN THE REFIGERATOR IS STILL GOOD. I HAVE ONLY USED IT TWICE. I AM SAVING MYSELF FOR THE FINAL ABUSE WITH THE TANKS. THANKS DAVID #90079 AILERON,AND FLAPS DONE HOWDY LISTERS.. CAN ANYONE TELL ME IF PROSEAL AFTER A YEAR IN THE REFIGERATOR IS STILL GOOD. I HAVE ONLY USED IT TWICE. I AM SAVING MYSELF FOR THE FINAL ABUSE WITH THE TANKS. THANKS DAVID #90079 AILERON,AND FLAPS DONE ________________________________________________________________________________
Date: Oct 05, 2004
I don't know much about RVs (well, make that nothing, actually) but Velocity aircraft have had some of the same issue about nose wheel shimmy...with equal resolution--marginal. However, you're issue about the shimmy associated with braking may be a somewhat different and may be related to harmonic vibrations through the gear legs that are caused by braking action. The harmonic vibration can be easily mistaken for shimmy in the nose wheel. Just an alternative thought. Chuck -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of Dale Larsen Subject: Re: RV9-List: Nosewheel shimmy Axle bolt tension is good, breakout tension is adjusted per plans with a fish scale. Tire pressure is good, and wheel rotates freely. On closer investigation, it only occurs at the end of the rollout, when you start to brake hard. If you don't brake at all, it dosent shimmy. I would think that if it were due to a balance condition that it would be poportional to the speed of the wheel. No shimmy on takeoff. > > > > It moves 1 to 1-1/2 inches at about a 3 Hz rate. > > Maybe the wheel is out of balance? > > Dale > > Wow, and you say you can't feel this?!? I suppose it is possible that > your tube is folded or pinched inside the tire, causing major imbalance. > If you think this is the case, you should immediately take the wheel apart > and check. Trust me, you don't want to experience a flat tire. Some > degree of bouncing is to be expected with a spring type nose gear leg, but > that's way more than I have seen. Check your axle bolt tension while > you're at it and make sure your wheel is rotating freely. Also check your > nose fork breakout tension. If it is too loose the wheel can wobble > violently from side to side just as it touches the pavement. Use a > fish-scale to actually set it per Vans instructions. The fork must have a > good bit of tension and not just swivel freely. If you can't find the > culprit, I would give Vans a call and see if they have any further clues. > > ________________________________________________________________________________
Subject: intercom wiring harness
Date: Oct 06, 2004
I am puzzling through the process of wiring the intercom in my RV 9. I am using the intercom wiring harness from Vans and haven't found a reference in the instruction or on drawing op23 for wires rz5 and rz6. Does anyone out there have a suggestion for me. Support at Vans is also researching this. John Kerr 90616 I am puzzling through the process of wiring the intercom in my RV 9. I am using the intercom wiring harness from Vans and haven't found a reference in the instruction or on drawing op23 for wires rz5 and rz6. Does anyone out there have a suggestion for me. Support at Vans is also researching this. John Kerr 90616 ________________________________________________________________________________
From: "RICHARD HUTSON" <rhutson(at)midsouth.rr.com>
Subject: Re: intercom wiring harness
Date: Oct 06, 2004
Easy way out is to call John Stark and get an approach Hub with the pre wired cables, it becomes a plug and play devise. ----- Original Message ----- > I am puzzling through the process of wiring the intercom in my RV 9. I am using the intercom wiring harness from Vans and haven't found a reference in the instruction or on drawing op23 for wires rz5 and rz6. > > Does anyone out there have a suggestion for me. Support at Vans is also > researching this. > > John Kerr > 90616 > > I am puzzling through the process of wiring the intercom in my RV 9. I am > using the intercom wiring harness from Vans and haven't found a reference > in the instruction or on drawing op23 for wires rz5 and rz6. > > Does anyone out there have a suggestion for me. Support at Vans is also > researching this. > > John Kerr > 90616 > > > ________________________________________________________________________________
Date: Oct 10, 2004
I have now spoken to both Warren Gretz and the good people at Dynon about the Pitot tube issue. The following is what I have learned. Yes, the holes are close but you don't "match drill" the pitot tube to the same hole size as the Gretz mount. You drill and tap four holes for a #6 machine screw. This should give you enough edge clearance. The screws should then be secured with loc-tight. (sp?) Apparently the air load on the pitot tube, even at 200 mph, isn't that significant according to Dynon. The other option is to order the unfinished mount from Warren Gretz, shorten it, and drill the holes as you see fit, then have the mount chromed. I'm going to try and drill the holes as Dynon suggests (next weekend) and will let everyone know how it goes. Bill RV-9 SN: 90737 Wings -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Bill Repucci Subject: RV9-List: Dynon Pitot Tube vs. Gretz mount (The following is not intended to point a finger at either Warren Gretz or the people at Dynon, it is simply a request for information from the RV builder community.) Last weekend was spent cutting the left wing skin and fitting the Gretz pitot tube mast, which is supposed to hold the Dynon pitot tube I bought for my future EFIS system. After cutting the wing skin, drilling holes in the ribs for the AOA line, etc. I test fit the mast and all looked good until I slid the pitot tube down the mast and found the pre-drilled holes in the mast that are to hold the pitot tube in place wouldn't leave any room for proper edge distance . I'm currently talking to both Dynon and Warren Gretz about a solution. BTW, both the Gretz mount and the Dynon unit seem to be top quality items and I do expect there will be an easy resolution. (I smudged the chrome pitot tube bracket so the flash wouldn't wash it out. The chrome finish on the mast appears to be top notch.) You can see a picture of what I'm talking about here: http://www.repucci.com/bill/images/dynon%20and%20gretz.jpg If any of you has a factory built pitot tube laying around, could you measure the shoulder depth and send me a note? The Dynon unit is supposed to be identical to what Cessna uses. Thanks for your help. Bill SN: 90737 Finishing up the wings and waiting for the next big box. www.repucci.com/bill/baf.html == direct advertising on the Matronics Forums. == == == ________________________________________________________________________________
Subject: flaps in trail
Date: Oct 11, 2004
after trial fitting the wings and getting the incidence right on with a digital level and installing the ailerons positioned with the guide bolted to the outboard rib and the flaps aligned with the aileron, I find that the flap trailing edge is about 1/2" below the bottom of the fuselage. A recent item someone provided suggested that this might happen and a need to bend the overlapping piece up to "kiss" the bottom skin. Am I missing something? John after trial fitting the wings and getting the incidence right on with a digital level and installing the ailerons positioned with the guide bolted to the outboard rib and the flaps aligned with the aileron, I find that the flap trailing edge is about 1/2" below the bottom of the fuselage. A recent item someone provided suggested that this might happen and a need to bend the overlapping piece up to "kiss" the bottom skin. Am I missing something? John ________________________________________________________________________________
Date: Oct 11, 2004
Subject: Photos of wind shield
Im looking to see if any one out there my be able to email me some photos of the wind shield attachment and finishing for a slider for an RV9. Im looking foe the spacing and finishing and filling on the sides where the skirts meet the front windshield.....Neil Corella ________________________________________________________________________________
Subject: Re: Photos of wind shield
From: "Larry PERRYMAN" <larry.perryman(at)atofina.com>
Date: Oct 11, 2004
10/11/2004 11:15:55 PM, Serialize complete at 10/11/2004 11:15:55 PM Neil Not sure just what you are asking. The directions fro mounting the windshield show how to mount it to the roll over bar and the front skin. Once you have it attached, fill in the gap at the bottom of the windshield with something like micro balloons or Super Poly Fill. Use two layers of electrical tape (the widest you can get) to define the edge of the fiberglass layup. Lay up one strip of fiberglass around the bottom of the windshield and then lay one up over the bow that just comes down and touches the one from the front. On the next ply, have the one on the bow come over the first layup and butt the second one for the front of the windshield to it. That way they will interlock at the lowest corner. They need to come down to the edge of the top forward skin so you can maintain that line in the finished layup. Once you have it all layed up and cured out, sand to a nice contour with the skin. It should smooth out and blend with the front skin so that the layup disappears into the front skin. Lay up the glass until it is about 3/16 inch or greater thick. I did not do this at first and had the lip that extends back over my slider canopy get cracked several times. The thicker the layup, the more you have to work with to make everything smooth. If you are referring to the side skin of the canopy, it needs to come up to the windshield and be covered over by the fiberglass layup. The side skirts are the hardest part of the canopy for me. I went through three sets of skins before I got one that was at least marginally acceptable Regards, Larry Perryman Neilekins(at)AOL.COM Sent by: owner-rv9-list-server(at)matronics.com 10/11/2004 03:39 PM Please respond to rv9-list To: rv9-list(at)matronics.com cc: Subject: RV9-List: Photos of wind shield Im looking to see if any one out there my be able to email me some photos of the wind shield attachment and finishing for a slider for an RV9. Im looking foe the spacing and finishing and filling on the sides where the skirts meet the front windshield.....Neil Corella ________________________________________________________________________________
Subject: Favorite tube bending tool ?
Date: Oct 11, 2004
I mushed my first attempt at bending the aluminum fuel line - tried the coiled spring tube bending kit (so called) - I must be missing something, can't see how they could ever work. I see several tools out there on various aircraft tool websites that look like junior version of the electrical conduit bending tools. Does anyone have a recommendation/favorite ? g ========================================================== Gerry Filby gerf(at)gerf.com Home: 415 239 4846 Cell: 415 203 9177 ________________________________________________________________________________
Date: Oct 11, 2004
G, I used a Superior Tools lever-type tube bender on my fuel pickup tubes with great success. I bought it from Lowes: http://www.lowes.com/lkn?action=productDetail&productId=28178-943-66575 Hope this helps. Mike 90709 wings...deposit on fuse mailed last week -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Gerry Filby Subject: RV9-List: Favorite tube bending tool ? I mushed my first attempt at bending the aluminum fuel line - tried the coiled spring tube bending kit (so called) - I must be missing something, can't see how they could ever work. I see several tools out there on various aircraft tool websites that look like junior version of the electrical conduit bending tools. Does anyone have a recommendation/favorite ? g ========================================================== Gerry Filby gerf(at)gerf.com Home: 415 239 4846 Cell: 415 203 9177 ________________________________________________________________________________
Subject: Re: Favorite tube bending tool ?
Date: Oct 11, 2004
Gerry, I use a tubing bender I purchased from Harbor Freight. It works fine. Paul ----- Original Message ----- From: Gerry Filby To: rv9-list(at)matronics.com Sent: Monday, October 11, 2004 3:53 PM Subject: RV9-List: Favorite tube bending tool ? I mushed my first attempt at bending the aluminum fuel line - tried the coiled spring tube bending kit (so called) - I must be missing something, can't see how they could ever work. I see several tools out there on various aircraft tool websites that look like junior version of the electrical conduit bending tools. Does anyone have a recommendation/favorite ? g Gerry Filby gerf(at)gerf.com Home: 415 239 4846 Cell: 415 203 9177 ________________________________________________________________________________
Date: Oct 12, 2004
Well, not really for sale, but I have an idea I'll give away. Builders and tinkers (I know--that's repetitive) are always buying things, which means they also have things to sell. Builders, trying to unload good 'stuff', are denigrated to sheepish posts to the List, mentioning they have a few odd items for anyone interested. Of course, there are a few brazen ones that make no attempt to respect the prohibition against commercialism on the list and make half hearted attempts to camouflage their efforts--but fool no one. Nonetheless, I've seen few people that resent being exposed to a good buy or a good product. Why should the willing sellers need to feel ashamed to expose willing buyers to a good deal? The solution? How about a separate 'For Sale' List where builder can list/unload their surplus items, rather than have to make some lame reference to Ebay. A separate list for 'Vendors' may even have merit. There's a few products out there I'd like to know about that may not have the exposure of a Garmin or King, et al. The feedback the sellers/vendors would face on the list would keep them pretty honest and help all of us sort out the good from the bad. Probably been tried, and abandoned already, but its worth a thought. No? Chuck ________________________________________________________________________________
Subject: Idea For Sale
Date: Oct 12, 2004
Date: Oct 12, 2004
Subject: Re: Idea For Sale
Hi Chuck, I think this is a terrific idea. I wanted a new GPS and to partially fund it I rounded up a bunch of stuff in my hangar and listed it on Ebay. It all sold and for good prices but,,,,, just at pay off time, PayPal crashed and now a bunch of folks are sitting around, unable to access thier accounts. Know way to know if they have paid or not. Money has been sent but not received and thier is no way to talk to Ebay or PayPal. I would support any effort you make in this direction. Dennis Thomas ________________________________________________________________________________
Date: Oct 12, 2004
try: http://www.b2g3.com/boards/board.cgi?&user=vansairforce ----- Original Message ----- From: "Chuck Jensen" <cjensen(at)dts9000.com> Subject: RV9-List: Idea For Sale > > Well, not really for sale, but I have an idea I'll give away. > > Builders and tinkers (I know--that's repetitive) are always buying things, > which means they also have things to sell. Builders, trying to unload good > 'stuff', are denigrated to sheepish posts to the List, mentioning they have > a few odd items for anyone interested. Of course, there are a few brazen > ones that make no attempt to respect the prohibition against commercialism > on the list and make half hearted attempts to camouflage their efforts--but > fool no one. Nonetheless, I've seen few people that resent being exposed to > a good buy or a good product. Why should the willing sellers need to feel > ashamed to expose willing buyers to a good deal? > > The solution? How about a separate 'For Sale' List where builder can > list/unload their surplus items, rather than have to make some lame > reference to Ebay. A separate list for 'Vendors' may even have merit. > There's a few products out there I'd like to know about that may not have > the exposure of a Garmin or King, et al. The feedback the sellers/vendors > would face on the list would keep them pretty honest and help all of us sort > out the good from the bad. > > Probably been tried, and abandoned already, but its worth a thought. No? > > Chuck > > ________________________________________________________________________________
Date: Oct 12, 2004
I am also about to attach the windscreen but the directions that say to scuff the aluminum and Plexiglas with 40 to 80 grit emory cloth are daunting. I fear that a rough grit like this will remove all of the Alclad from the aluminum and cause the Plexiglas to crack. Has anybody used a lesser grit paper, or even ScothBrite, and still had good adhesion to the fiberglass? Leland in Pleasanton ________________________________________________________________________________
Date: Oct 12, 2004
Vans reply is not to be shy about scuffing it up.. you want a really good bond and it all gets covered up with the glass anyway so the alclad removal is pretty much a none issue in that area. -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of Leland Subject: Re: RV9-List: Photos of wind shield I am also about to attach the windscreen but the directions that say to scuff the aluminum and Plexiglas with 40 to 80 grit emory cloth are daunting. I fear that a rough grit like this will remove all of the Alclad from the aluminum and cause the Plexiglas to crack. Has anybody used a lesser grit paper, or even ScothBrite, and still had good adhesion to the fiberglass? Leland in Pleasanton ________________________________________________________________________________
Date: Oct 13, 2004
> Ditto Peter Laurence > Hi Chuck, > I think this is a terrific idea. I wanted a new GPS and to partially fund it > I rounded up a bunch of stuff in my hangar and listed it on Ebay. It all > sold and for good prices but,,,,, just at pay off time, PayPal crashed and now a > bunch of folks are sitting around, unable to access thier accounts. Know way > to know if they have paid or not. Money has been sent but not received and > thier is no way to talk to Ebay or PayPal. > I would support any effort you make in this direction. > > Dennis Thomas > > ________________________________________________________________________________
Date: Oct 14, 2004
Subject: wing skins
Hello, I am ready to rivet the wing skins on. I am somewhat unclear on which direction to rivet in. I see it says start with the middle rib, then I guess you go one rib at a time (while also doing the spar rivets) left and right until they are all done (except for the overlap). But do I start in the middle of the rib and work towards the leading edge, then go back and work the rib towards the trailing edge? Or, doesn't matter? Glen Bankston Moultrie, GA ________________________________________________________________________________
Subject: wing skins
Date: Oct 14, 2004
Glen, I started at the forward end of the rib and worked aft on each rib and then riveted inboard or outboard on the main spar as I finished a rib. I had a partner helping so I saved the rear spar rivets for when I had to work alone. Turned out nicely. Mike SC 90709 wings...fuse on order -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of G B Subject: RV9-List: wing skins Hello, I am ready to rivet the wing skins on. I am somewhat unclear on which direction to rivet in. I see it says start with the middle rib, then I guess you go one rib at a time (while also doing the spar rivets) left and right until they are all done (except for the overlap). But do I start in the middle of the rib and work towards the leading edge, then go back and work the rib towards the trailing edge? Or, doesn't matter? Glen Bankston Moultrie, GA advertising on the Matronics Forums. ________________________________________________________________________________
Subject: Re: wing skins
From: Larry PERRYMAN <larry.perryman(at)atofina.com>
Date: Oct 14, 2004
21, 2004) at 10/14/2004 08:55:11 PM, Serialize complete at 10/14/2004 08:55:11 PM Start at the rear spar in the middle and go out and down so that you are riveting in a "V" pattern toward the main spar. This will allow you to reach all the rivets by lifting the main spar edge and getting your arm and bucking bar into the wing. You will finish up through the lightening holes on each end of the skin and through the inspection holes. The wing walk area is probably the hardest since there are so many ribs in such a small space.. Wear a long sleeve shirt to protect your arms. Regards, Larry Perryman N194DL G B Sent by: owner-rv9-list-server(at)matronics.com 10/14/2004 09:56 AM Please respond to rv9-list To: RV9 List cc: Subject: RV9-List: wing skins Hello, I am ready to rivet the wing skins on. I am somewhat unclear on which direction to rivet in. I see it says start with the middle rib, then I guess you go one rib at a time (while also doing the spar rivets) left and right until they are all done (except for the overlap). But do I start in the middle of the rib and work towards the leading edge, then go back and work the rib towards the trailing edge? Or, doesn't matter? Glen Bankston Moultrie, GA ________________________________________________________________________________
Date: Oct 14, 2004
I did mine starting at the rear area and worked forward and side to side. Take your time to notice what pattern you may need in certain areas in terms of access to the rivets. Another thing that worked well for me, I helped a friend do his wings per Van's instructions on a flat table, then did mine. My wings were still hanging on the stands and I did mine that way. We both agreed hands down it was easier standing and reaching down into the wing to buck, than on a table. Just my .02. Glenn in Arizona 90623 fuselage. ----- Original Message ----- From: "G B" <microsys(at)alltel.net> Subject: RV9-List: wing skins > > Hello, > > I am ready to rivet the wing skins on. > > I am somewhat unclear on which direction to rivet in. > > I see it says start with the middle rib, then I guess you > go one rib at a time (while also doing the spar rivets) left > and right until they are all done (except for the overlap). > But do I start in the middle of the rib and work towards the > leading edge, then go back and work the rib towards the trailing > edge? Or, doesn't matter? > > Glen Bankston > Moultrie, GA > > ________________________________________________________________________________
Date: Oct 14, 2004
PS, Glenn, forgot to mention this in the 1st reply, make sure you back rivet the top skins on! It is easy to do and the results are beautiful! Glenn in Arizona. ----- Original Message ----- From: "Glenn Brasch" <gbrasch(at)earthlink.net> Subject: Re: RV9-List: wing skins > > I did mine starting at the rear area and worked forward and side to side. > Take your time to notice what pattern you may need in certain areas in terms > of access to the rivets. Another thing that worked well for me, I helped a > friend do his wings per Van's instructions on a flat table, then did mine. > My wings were still hanging on the stands and I did mine that way. We both > agreed hands down it was easier standing and reaching down into the wing to > buck, than on a table. Just my .02. Glenn in Arizona 90623 fuselage. > ----- Original Message ----- > From: "G B" <microsys(at)alltel.net> > To: "RV9 List" > Subject: RV9-List: wing skins > > > > > > Hello, > > > > I am ready to rivet the wing skins on. > > > > I am somewhat unclear on which direction to rivet in. > > > > I see it says start with the middle rib, then I guess you > > go one rib at a time (while also doing the spar rivets) left > > and right until they are all done (except for the overlap). > > But do I start in the middle of the rib and work towards the > > leading edge, then go back and work the rib towards the trailing > > edge? Or, doesn't matter? > > > > Glen Bankston > > Moultrie, GA > > > > > > ________________________________________________________________________________
Subject: wing skins
Date: Oct 14, 2004
Were you able to rivet in the J-stringers by yourself? Thanks! Mike SC 90709 wings...fuse on order -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Larry PERRYMAN Subject: Re: RV9-List: wing skins --> Start at the rear spar in the middle and go out and down so that you are riveting in a "V" pattern toward the main spar. This will allow you to reach all the rivets by lifting the main spar edge and getting your arm and bucking bar into the wing. You will finish up through the lightening holes on each end of the skin and through the inspection holes. The wing walk area is probably the hardest since there are so many ribs in such a small space.. Wear a long sleeve shirt to protect your arms. Regards, Larry Perryman N194DL G B Sent by: owner-rv9-list-server(at)matronics.com 10/14/2004 09:56 AM Please respond to rv9-list To: RV9 List cc: Subject: RV9-List: wing skins Hello, I am ready to rivet the wing skins on. I am somewhat unclear on which direction to rivet in. I see it says start with the middle rib, then I guess you go one rib at a time (while also doing the spar rivets) left and right until they are all done (except for the overlap). But do I start in the middle of the rib and work towards the leading edge, then go back and work the rib towards the trailing edge? Or, doesn't matter? Glen Bankston Moultrie, GA advertising on the Matronics Forums. ________________________________________________________________________________
Subject: wing skins
Date: Oct 14, 2004
21, 2004) at 10/14/2004 10:52:45 PM, Serialize complete at 10/14/2004 10:52:45 PM Mike, I was able to reach everything that I needed to reach that way. Put it in the notch in the rib and cleco it in the middle. Rivet the middle and work out as you do the skin and ribs. It is just another horizontal rib. I did both of my wings on the table and did not have any trouble with them. When finished, I had 1/64th inch twist in the wing. I am going from memory since my wings were done over two years ago. Don't remember any issues going by what Van's said to do on them. The plans have changed a bit since then. Just make sure that you have done everything that you want to do inside the wing before you close it up. I would install a empty conduit down the wing or at least some pull strings through a bunch of grommets for that additional wire that you will need later. Regards, Larry Perryman Kit 90288 "Mike Hoover" Sent by: owner-rv9-list-server(at)matronics.com 10/14/2004 03:31 PM Please respond to rv9-list To: cc: Subject: RE: RV9-List: wing skins Were you able to rivet in the J-stringers by yourself? Thanks! Mike SC 90709 wings...fuse on order ________________________________________________________________________________
Date: Oct 17, 2004
Subject: Autopilots
TruTrak versus Trio any comments out there? I'm about to order and I'm leaning towards the Trio EZ PilotII over the Digitrak. Thanks Roger Ping 90869 Fuselage 70% finishing kit in hand ________________________________________________________________________________
Date: Oct 17, 2004
Subject: Re: Autopilots
Lots of opinions out there. Check the archives. I LOVE my TruTrak DFC 250. Ross Mickey N9PT 110 hrs and counting -----Original Message----- From: Roger Ping <rpping(at)qwest.net> Subject: RV9-List: Autopilots TruTrak versus Trio any comments out there? I'm about to order and I'm leaning towards the Trio EZ PilotII over the Digitrak. Thanks Roger Ping 90869 Fuselage 70% finishing kit in hand ________________________________________________________________________________
Subject: Where to mount the flap foot pedals.
Date: Oct 17, 2004
I am 6 foot 1 inch, and have tested various postions to secure flap foot pedals, and have found the maxium postion was just simply too far, but the shortest postion seems good, but of course this does not make sense. I am sure there are five foot pilots who can fly this plane by reaching the pedals, right, so being 6 plus feet, it doesn't make sense this (short??) position is right. Is there any other individual around my height, who can help me out, where did you final place the pedals. ( I am using the chair kit sold by vans) Also the gap between the pedals and the floor seems quite large, is our feet to rest in the pedal (hang in there) or, are tippy toes resting against the bottom edge of them. Bill, having fun fun fun, just love this challenge. ________________________________________________________________________________
Date: Oct 18, 2004
Subject: Re: Where to mount the flap foot pedals.
Bill, I am 6'3", but my sitting height was the maximum the Air Force allowed. SO, my legs are more like a six footer. I find that the most comfortable position is when your legs make a 90 degree angle. Stretching out, even in the car, is uncomforable in the long run I think. Glen wings ________________________________________________________________________________
Date: Oct 18, 2004
Hello, What are flap foot pedals? Mike ----- Original Message ----- From: G B <microsys(at)alltel.net> Date: Monday, October 18, 2004 7:47 am Subject: Re: RV9-List: Where to mount the flap foot pedals. > > Bill, > > I am 6'3", but my sitting height was the maximum the Air Force > allowed.SO, my legs are more like a six footer. I find that the > most comfortable > position is when your legs make a 90 degree angle. Stretching > out, even > in the car, is uncomforable in the long run I think. > > Glen > wings > > > _- > _- > _- > _- > ======================================================================== > > > > ________________________________________________________________________________
Date: Oct 18, 2004
I think he means rudder pedals. ________________________________________________________________________________
From: "Aaron Frechette" <right-stuff(at)comcast.net>
Subject: Capacitive Vs. Float Fuel Level Senders
Date: Oct 18, 2004
I'm getting ready to order my wing kit and don't have any feelings either way on what type of fuel level sender to plan for. Anyone out there have some insight into the pros and cons of capacitive versus float type fuel level senders? ________________________________________________________________________________
From: "John Oliveira" <oliveira(at)frontiernet.net>
Subject: Re: Capacitive Vs. Float Fuel Level Senders
Date: Oct 19, 2004
Cost against capacitive. All these really cool instruments are great, but shoot cost up in a hurry. Gauges for capacitive are 10x as most are really cool digital. Before you know it you will be into flow sensors and all kinds of stuff. Capacitive are mechanically simple - no moving parts. John Oliveira ----- Original Message ----- From: "Aaron Frechette" <right-stuff(at)comcast.net> Subject: RV9-List: Capacitive Vs. Float Fuel Level Senders > > > I'm getting ready to order my wing kit and don't have any feelings either > way on what type of fuel level sender to plan for. Anyone out there have > some insight into the pros and cons of capacitive versus float type fuel > level senders? > > > ________________________________________________________________________________
Subject: Canopy Drill Bits
Date: Oct 19, 2004
Hello all, drillin through the canopy soon... but I still haven't got the plexi bits. The manual says to drill number 30 first then enlarge the holes. I have noticed on may builders sites that they just used the regular #30 bit, which seems to make sense b/c I notice that the plexi bits only seem to be sold in 1/8", 3/16" etc. Did everyone else do this or just sub the 1/8" bit then enlarge some holes??? Which Plexi bits do you really need anyway? I was just planning to buy QTY:2 of the 1/8" and 3/16" bits. Thanks, Bryan ________________________________________________________________________________
Subject: Re: Canopy Drill Bits
Date: Oct 19, 2004
21, 2004) at 10/19/2004 05:11:07 PM, Serialize complete at 10/19/2004 05:11:07 PM Bryan, You need to drill the holes larger than the screws so that the plexi can shrink and expand with heat and cold. Hole it to tight and it will crack. The plexi bits are nothing more than the straight blade tile bits sold at Home Depot and others. Do not use a regular bit as it will tend to bite into the plexi and WILL crack it. The bit will act like a screw. Try some of the excess you cut off the canopy to practice drilling on before you try the actual canopy. See what works for you. Regards, Larry Perryman "Bryan Flood" Sent by: owner-rv9-list-server(at)matronics.com 10/19/2004 09:10 AM Please respond to rv9-list To: rv9-list(at)matronics.com cc: Subject: RV9-List: Canopy Drill Bits Hello all, drillin through the canopy soon... but I still haven't got the plexi bits. The manual says to drill number 30 first then enlarge the holes. I have noticed on may builders sites that they just used the regular #30 bit, which seems to make sense b/c I notice that the plexi bits only seem to be sold in 1/8", 3/16" etc. Did everyone else do this or just sub the 1/8" bit then enlarge some holes??? Which Plexi bits do you really need anyway? I was just planning to buy QTY:2 of the 1/8" and 3/16" bits. Thanks, Bryan ________________________________________________________________________________
Date: Oct 19, 2004
----- Original Message ----- From: "Aaron Frechette" <right-stuff(at)comcast.net> Subject: RV9-List: Capacitive Vs. Float Fuel Level Senders Check with AP/AI's who have to work on and calibrate them. All that I have asked choose the float type. > > I'm getting ready to order my wing kit and don't have any feelings either way on what type of fuel level sender to plan for. Anyone out there have some insight into the pros and cons of capacitive versus float type fuel level senders? > > ________________________________________________________________________________
Date: Oct 19, 2004
I believe by RV-9A plans said to drill with #40 bits first through both the plexi and the frame. Countersink appropriate holes to appropriate sizes. Then drill canopy with 5/32" plexi drill - 1/32 greater than the 1/8 #30 drill (+ or - 0.003"). (This gives a little slack for the plexi to move under load. Finally, drill the canopy frame with #30 drill to match size of rivet. Mike Duiven N711ED (Reserved) ----- Original Message ----- From: "Bryan Flood" <bryanflood(at)hotmail.com> Subject: RV9-List: Canopy Drill Bits > > Hello all, drillin through the canopy soon... but I still haven't got the > plexi bits. The manual says to drill number 30 first then enlarge the holes. > I have noticed on may builders sites that they just used the regular #30 > bit, which seems to make sense b/c I notice that the plexi bits only seem to > be sold in 1/8", 3/16" etc. Did everyone else do this or just sub the 1/8" > bit then enlarge some holes??? Which Plexi bits do you really need anyway? I > was just planning to buy QTY:2 of the 1/8" and 3/16" bits. > > Thanks, > > Bryan > > > ________________________________________________________________________________
Date: Oct 19, 2004
I chose the basic float type senders and the Van's gauges. The gauges don't begin to register until you have burned down the first 3 to 4 gallons. After that, they seem to be quite accurate, in level flight. If you make a hard turn (especially if not perfectly coordinated), or if you get into real bumpy air, it will disturb the reading for a bit. Dennis Thomas ________________________________________________________________________________
Date: Oct 19, 2004
Bryan, Everyone is right about the holes being oversized. They must be larger or you will have problems, either now or later. You can make a plexi bit out of a regular bit, giving you access to all the sizes you could need. There is no rake on the leading edge of a plexi bit; it is square to the face that you are drilling. If you want to try making one, use a Dremel and basically grind (?dull?) the cutting edge of the bit until the sharp edge is parallel to the centerline of the bit and it doesn't try to "dig in." You won't have to take off all that much. Try the bit on scraps until you are SURE it won't dig in and crack. Plexi bits are about the easiest thing there is to sharpen, and you can use the cheapest bits you can find as plexi won't dull them anyway. I would always opt for "professional" bits, but this has gotten me out of a couple of jams. Bob Kelly, 90854 On 10/19/04, Bryan Flood wrote: > > Hello all, drillin through the canopy soon... but I still haven't got the > plexi bits. The manual says to drill number 30 first then enlarge the > holes. I have noticed on may builders sites that they just used the > regular #30 bit, which seems to make sense b/c I notice that the plexi > bits only seem to be sold in 1/8", 3/16" etc. Did everyone else do this or > just sub the 1/8" bit then enlarge some holes??? Which Plexi bits do you > really need anyway? I was just planning to buy QTY:2 of the 1/8" and 3/16" > bits. > > Thanks, > > Bryan ________________________________________________________________________________
Date: Oct 19, 2004
Subject: Re: RV9-List Digest: 4 Msgs - 10/18/04
I installed capacitance senders in both tanks. I also installed the Advanced Control System Engine Monitor. Both tanks were built the same and I made absolutely sure the wiring for the sender was perfect. I never could get the left tank capacitance sender to work. Replaced everything external to the tank and still would not work. Finally, installed a float in that tank. Float works fine in the left tank and the capacitance works fine in the right tank. My opinion, not worth the extra trouble and expense. Go with the floats. Easy to fix when there is a problem. Flying with 80 hours. Jim Murray 90430 --- RV9-List Digest Server wrote: > * > > ================================================== > Online Versions of Today's List Digest Archive > ================================================== > > Today's complete RV9-List Digest can also be found > in either of the > two Web Links listed below. The .html file includes > the Digest formatted > in HTML for viewing with a web browser and features > Hyperlinked Indexes > and Message Navigation. The .txt file includes the > plain ASCII version > of the RV9-List Digest and can be viewed with a > generic text editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/rv9-list/Digest.RV9-List.2004-10-18.html > > Text Version: > > > http://www.matronics.com/digest/rv9-list/Digest.RV9-List.2004-10-18.txt > > > ================================================ > EMail Version of Today's List Digest Archive > ================================================ > > > > > RV9-List Digest Archive > --- > Total Messages Posted Mon > 10/18/04: 4 > > > > > Today's Message Index: > ---------------------- > > 1. 08:48 AM - Re: Where to mount the flap foot > pedals. (G B) > 2. 05:04 PM - Re: Where to mount the flap foot > pedals. (Michael Ice) > 3. 05:06 PM - Re: Where to mount the flap foot > pedals. (DThomas773(at)AOL.COM) > 4. 11:37 PM - Capacitive Vs. Float Fuel Level > Senders (Aaron Frechette) > > > > ________________________________ Message 1 > _____________________________________ > > > From: G B <microsys(at)alltel.net> > Subject: Re: RV9-List: Where to mount the flap foot > pedals. > > > > Bill, > > I am 6'3", but my sitting height was the maximum the > Air Force allowed. > SO, my legs are more like a six footer. I find that > the most comfortable > position is when your legs make a 90 degree angle. > Stretching out, even > in the car, is uncomforable in the long run I think. > > Glen > wings > > > > > > > ________________________________ Message 2 > _____________________________________ > > > From: Michael Ice <aurbo(at)ak.net> > Subject: Re: RV9-List: Where to mount the flap foot > pedals. > > > > Hello, > > What are flap foot pedals? > > Mike > > ----- Original Message ----- > From: G B <microsys(at)alltel.net> > Subject: Re: RV9-List: Where to mount the flap foot > pedals. > > > > > > Bill, > > > > I am 6'3", but my sitting height was the maximum > the Air Force > > allowed.SO, my legs are more like a six footer. I > find that the > > most comfortable > > position is when your legs make a 90 degree angle. > Stretching > > out, even > > in the car, is uncomforable in the long run I > think. > > > > Glen > > wings > > > > > > _- > > _- > > _- > > _- > > > ======================================================================== > > > > > > > > > > > > > > > ________________________________ Message 3 > _____________________________________ > > > From: DThomas773(at)AOL.COM > Subject: Re: RV9-List: Where to mount the flap foot > pedals. > > > I think he means rudder pedals. > > > > > > > ________________________________ Message 4 > _____________________________________ > > > From: "Aaron Frechette" <right-stuff(at)comcast.net> > Subject: RV9-List: Capacitive Vs. Float Fuel Level > Senders > > > > I'm getting ready to order my wing kit and don't > have any feelings either way on > what type of fuel level sender to plan for. Anyone > out there have some insight > into the pros and cons of capacitive versus float > type fuel level senders? > > > > > > > > > > > > > > Contributions > any other > === message truncated === __________________________________ ________________________________________________________________________________
Date: Oct 19, 2004
A UniBit works very well on Plexiglas ----- Original Message ----- From: "Bob Kelly" <mmpi(at)missionmedia.org> Subject: Re: RV9-List: Canopy Drill Bits > > Bryan, > > Everyone is right about the holes being oversized. They must be larger or > you will have problems, either now or later. You can make a plexi bit out > of a regular bit, giving you access to all the sizes you could need. There > is no rake on the leading edge of a plexi bit; it is square to the face > that you are drilling. If you want to try making one, use a Dremel and > basically grind (?dull?) the cutting edge of the bit until the sharp edge > is parallel to the centerline of the bit and it doesn't try to "dig in." > You won't have to take off all that much. Try the bit on scraps until you > are SURE it won't dig in and crack. Plexi bits are about the easiest thing > there is to sharpen, and you can use the cheapest bits you can find as > plexi won't dull them anyway. I would always opt for "professional" bits, > but this has gotten me out of a couple of jams. > > Bob Kelly, 90854 > > On 10/19/04, Bryan Flood wrote: > > > > Hello all, drillin through the canopy soon... but I still haven't got the > > plexi bits. The manual says to drill number 30 first then enlarge the > > holes. I have noticed on may builders sites that they just used the > > regular #30 bit, which seems to make sense b/c I notice that the plexi > > bits only seem to be sold in 1/8", 3/16" etc. Did everyone else do this or > > just sub the 1/8" bit then enlarge some holes??? Which Plexi bits do you > > really need anyway? I was just planning to buy QTY:2 of the 1/8" and 3/16" > > bits. > > > > Thanks, > > > > Bryan > > ________________________________________________________________________________
From: "Albert Gardner" <spudnut(at)worldnet.att.net>
Date: Oct 19, 2004
I have the capacitive tanks and use an EI fuel gage. Couldn't be happier. Also recently installed EI's fuel computer and I'm now even happier than I was. Albert Gardner RV-9A 872RV 300+ hours. Yuma, AZ ________________________________________________________________________________
Subject: Tampa, FL Area Builders/Flyers?
Date: Oct 20, 2004
I found myself traveling to Tampa, FL next week with nothing to do on Wednesday night (Oct. 27th). Any Tampa Bay builders/flyers out there willing to take me up for a ride (if flying) or want to show off their project under construction? Hec.. I'd be willing to buck or drive some rivets. :-) I arrive at TPA at 4:40pm and will be staying at the Trade Winds Grand Island Resort. Matthew Brandes, Van's RV-9A (Fuselage/Finish) EAA Chapter 868/91/1329 www.n523rv.com <http://www.n523rv.com/> ________________________________________________________________________________
From: Michael Schipper <mike(at)learningplanet.com>
Subject: Re: Tampa, FL Area Builders/Flyers?
Date: Oct 20, 2004
If you want to re-route your trip through Dallas, I have some rivets that need bucking! :-) Mike Schipper www.my9a.com On Oct 20, 2004, at 10:16 AM, Matthew Brandes wrote: > > I found myself traveling to Tampa, FL next week with nothing to do on > Wednesday night (Oct. 27th). Any Tampa Bay builders/flyers out there > willing to take me up for a ride (if flying) or want to show off their > project under construction? Hec.. I'd be willing to buck or drive some > rivets. :-) > > I arrive at TPA at 4:40pm and will be staying at the Trade Winds Grand > Island Resort. > > Matthew Brandes, > Van's RV-9A (Fuselage/Finish) > EAA Chapter 868/91/1329 > www.n523rv.com <http://www.n523rv.com/> > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Date: Oct 23, 2004
Subject: [ Neal George ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Neal George Subject: 110v Hobbs Meter http://www.matronics.com/photoshare/Neal.George@MAXWELL.AF.MIL.10.23.2004/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject: Subaru engine package
Date: Oct 25, 2004
I have a Subaru engine fwf package up for bid on Ebay: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item2497075950&ssPageNameADME:B:LC:MT:1 ________________________________________________________________________________
Date: Oct 25, 2004
Invalid Item The item you requested () is invalid, still pending, or no longer in our database. Please check the number and try again. If this message persists, the item has either not started and is not yet available for viewing, or has expired and is no longer available. ________________________________________________________________________________
Subject: Finish kit arrival & SW JetFlex
Date: Oct 25, 2004
Sure has been quite in the group lately.... Picked up my finish kit today from Roadway. Cost was $408.99!! That is from OR to KS. I called Van's to confirm that price and Anne said it was right. It is higher than other kits because it ships under a different Class because of the canopy. At 4ft x 8ft, it barely fit in my truck but saved myself some $$$ by picking it up myself. On another note, I painted the interior this past weekend. I used the Sherwin Williams JetFlex water-soluable in a flat 'Subtle White' color. The white isn't so subtle but it came out well. I'll get a closer look tonight after it has had time to cure to see how good of a job I really did. Here's hoping everyone is making progress are their projects! Matthew Brandes, Van's RV-9A (Starting the finish) EAA Chapter 868/91/1329 www.n523rv.com <http://www.n523rv.com/> ________________________________________________________________________________
Subject: Pitot tubing question
Date: Oct 26, 2004
I am completing my left wing (RV-7) and getting ready to install the pitot tubing. The plans are a bit unclear in this area. I know the tubing passes through the snap bushing to the wing root, however how have most of you terminated the tubing. Did you leave a short length (at the root), flare it and bend it 90 degrees. Did you install a 90 degree bulkhead fitting in the root rib? If so what was your procedure for flaring the end? Any help would be appreciated. Paul ________________________________________________________________________________
Date: Oct 27, 2004
Subject: Re: Pitot tubing question
Hi Paul, I just left about 14 inches extra at the wing route and finished the bends, flared the end and installed the fittings when we hung the wings. At that point you know exactly where you want to go. If the wings are going to be stored for a while be sure to put a red warning flag on the end so a careless visitor doesn't wlak into it. ________________________________________________________________________________
Subject: Spruce ACS control cables.
Date: Oct 27, 2004
I saw a post here a few days ago about spruces' control cables supplied by ACS and went to the hanger to measure the one I had ordered a few months back and recieved about 3 weeks ago. It did not fit the RV Kit. All the dimensions I supplied to spruce were correct but another dimension (the distance from the second bulkhead fitting to the end) was not the correct length for the RV. This was not a dimension that I supplied or Spruce required. Also missing was the plastic coating that the Van's cables from ACS have. Turns out that Van's orders a double Custom cable when only a single custom and stanard cables were available from spruce (or somehting like that). So anyway to make a long story short I paid $88 for the wrong cable, Spruce refunded $44 and now I have to pay $139 for the right cable (Which minus the refund is $95, more than I paid for the original cable!) I'm not convinced Spruce knows exactly what is going on either, so I would caution everyone to get all of the relevant dimensions for their control cables before ordering custom cables from Spruce. I do have to say however ACS does make some nice looking cables, just be really carefull when ordering from Spruce so you don't end up paying a bunch extra and have to wait for Custom cables to be made. Bryan ________________________________________________________________________________
Date: Oct 27, 2004
Great timing for this question. I just test fitted my Dynon pitot tube last night and posted some pictures. You can see what I did at the bottom of the wing section of my web site. www.repucci.com/bill/baf.html. Bill -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Merems rv7-list(at)matronics.com; RV-9A(at)yahoogroups.com; rv9-list(at)matronics.com Subject: RV9-List: Pitot tubing question I am completing my left wing (RV-7) and getting ready to install the pitot tubing. The plans are a bit unclear in this area. I know the tubing passes through the snap bushing to the wing root, however how have most of you terminated the tubing. Did you leave a short length (at the root), flare it and bend it 90 degrees. Did you install a 90 degree bulkhead fitting in the root rib? If so what was your procedure for flaring the end? Any help would be appreciated. Paul == == == == ________________________________________________________________________________
Subject: Flap trailing edge thickness
Date: Oct 27, 2004
Folks I used T-88 expoxy between the skins and AEX wedge of the trailing edges of the elevators, rudder and ailersons with good results - very straight and even. Today I completed the right flap and realized that I had a thicker layer of epoxy between each skin and the AEX wedge. Consequently the very edge of the trailing edge is a little thicker than my previous efforts - I would say its 2.5 mm at worst and generally 2mm along the span. My other effots were about 1.5 mm. I've trawled the lists and the Net but haven't found anything definitive - is it a bad think to have that thick a trailing edge ? I see some notes that you want a "knife edge" if you can get it. g ========================================================== Gerry Filby gerf(at)gerf.com ________________________________________________________________________________
Subject: Re: Flap trailing edge thickness
Date: Oct 28, 2004
21, 2004) at 10/28/2004 03:39:18 PM, Serialize complete at 10/28/2004 03:39:18 PM The trailing edge will work just fine. The original trailing edge on RVs was folded into the skin and much thicker. The idea of using an adhesive on the trailing edge came from the user community, not from Vans. The idea is to have a smooth transition for the air flowing over the wing. That small difference will have little effect when flying. It is cosmetic more than functional. It might matter if you are building a plane to be Grand Champion at Oshkosh instead of a trusty flyer. Make sure that you round the corners of the flaps and ailerons. I have a gash in my leg from a sharp corner that I left on the left flap. You can bet that it is gone now. It cut through a pair of bluejeans and into my leg as I walked by. Round is better. Regards, Larry Perryman ________________________________________________________________________________
Date: Oct 28, 2004
-----Original Message----- From: Gerry Filby <gerf(at)gerf.com> Subject: RV9-List: Flap trailing edge thickness GERRY You realy dont want a knife edge trailing edge bad for air flow.what you might do is file all trailing edges squair. as i did. this way you can bring edge thickness equal on all . and have a better final fit and finish. Bob Watson N194BN 250 plus hr,s Folks I used T-88 expoxy between the skins and AEX wedge of the trailing edges of the elevators, rudder and ailersons with good results - very straight and even. Today I completed the right flap and realized that I had a thicker layer of epoxy between each skin and the AEX wedge. Consequently the very edge of the trailing edge is a little thicker than my previous efforts - I would say its 2.5 mm at worst and generally 2mm along the span. My other effots were about 1.5 mm. I've trawled the lists and the Net but haven't found anything definitive - is it a bad think to have that thick a trailing edge ? I see some notes that you want a "knife edge" if you can get it. g ========================================================== Gerry Filby gerf(at)gerf.com ________________________________________________________________________________
Date: Oct 29, 2004
I forwarded this question to an airfoil designer.. Here's his reply to my question of a sharp vs. 1/8" square trailing edge. -Clay Theoretically, a sharper edge is better because of a better defined stagnation point, but in real life it won't make any difference at all. The boundary layer is pretty thick by the time it reaches that far anyway. John --- Gerry Filby wrote: > > > > Folks > > I used T-88 expoxy between the skins and AEX wedge > of the > trailing edges of the elevators, rudder and > ailersons with good > results - very straight and even. > > Today I completed the right flap and realized that I > had a > thicker layer of epoxy between each skin and the AEX > wedge. > Consequently the very edge of the trailing edge is a > little > thicker than my previous efforts - I would say its > 2.5 mm at > worst and generally 2mm along the span. My other > effots were > about 1.5 mm. > > I've trawled the lists and the Net but haven't found > anything > definitive - is it a bad think to have that thick a > trailing > edge ? I see some notes that you want a "knife > edge" if you > can get it. > > g > > ========================================================== > > Gerry Filby > gerf(at)gerf.com > __________________________________ ________________________________________________________________________________
From: "Steve Sampson" <SSampson.SLN21(at)london.edu>
Subject: Master clylinder fittings
Date: Oct 30, 2004
I am trying to get the fluid to stay in the brake syste. (Oh I wish it was easy as electricity!) I am now down to one leak but this is not responding to cursing. The fitting on the low pressure (top) side of one of the master clyinders persists in weeping. Two questions: 1) I notice in DWG36 dated 7/27/00 the plan indicates I should be using a brass fitting (F 69-F-04*02). In fact I am using some nylon fittings, similar to the F271 on the back of the reservoir, and presumably these were what was supplied but its too long ago to remember. I have no brass parts left over. Did others get nylon? 2) Anyone had leak problems with these? How to cure. It is very hard to tell which bit is leaking, probably where the pipe from the reservoir comes in. Help and moral support needed! Thanks, Steve. PS Needless to say every time I go down there I knock the jamjar of brake fluid over. What fun eh! --- ________________________________________________________________________________
Subject: Aileron Trailing Edge Construction
Date: Oct 30, 2004
What did you folks do for the aileron trailing edges in terms of using Pro Seal or epoxy or whatever for finishing your trailing edge riveting? I noticed the plans do not call for bonding prior to riveting. Your suggestions are appreciated in advance. Glenn in Arizona -9A 90623, about to start fuselage. ________________________________________________________________________________
Date: Oct 30, 2004
Subject: Re: Master clylinder fittings
Steve I had leak problems as well. Here is the fix. The masters cylinders use brass fittings unless you have dual brakes then the pilot side subs the AN fittings for one of each left and right top holes. The brass fittings should be rotated sloooooly and I can't stress that enough one more revolution than you think it can handle. Slowly so as not to break the fitting or the master cylinder. You do not need any pipe thread compound as these are pipe thread and they are tapered. Tighten each fitting one more rotation until it stops leaking and your done. Finally pump the lines untill all air is gone then pump some more to ensure its done. Tad Sargent Sargentclt(at)CS.com RV7A ________________________________________________________________________________
Subject: Pitot Tubing routing-continued
Date: Oct 30, 2004
1.27 SUBJ_HAS_UNIQ_ID Subject contains a unique ID Fellow RV builders, I am finishing my RV-7 wings and installing the standard pitot tube system. I emailed the group and received some very good information. Most builders are using nylon tubing and transitioning from the aluminum tube somewhere in the wing. However if you follow Van's instructions and use the "center" hole in the main ribs, the aluminum tubing will block access to the center fuel tank "Z" bracket bolt, not a good thing. So it appears to me that if you are going to run the tubing down the "center" hole, you better transition to nylon tubing before it blocks the bolt. This means you really need to transition to nylon tubing right behind the AN bulkhead fitting for the pitot tube. Am I off base? If I knew of this before I skinned (top skin) my wings, I might have drilled a tube routing hole further aft in the main rib to accommodate the aluminum tubing. Paul (RV-4/RV-7A) ________________________________________________________________________________
Date: Oct 30, 2004
Subject: Re: Pitot Tubing routing-continued
Paul, if this causes a problem with a bolt, etc then drill a hole and move it down the rib or around the problem. Personally I moved the pitot holes the the bottom of the wing to avoid the bellcrank and torque tube. The moral is its your airplane do what you want within reason. I does not matter where the holes are. My .02 worth Tad Sargent Sargentclt(at)CS.com RV7A ________________________________________________________________________________
Date: Oct 30, 2004
Teflon tape is a big help on this little rascals. ________________________________________________________________________________
Date: Oct 30, 2004
It is even easier without any leaks or twisted off fittings from over ease in turning then there is alphacrocryliate (crazy glue) which sets up and maintains the "clocking" of your fittings. The Dope part seals and then doesn't leak. This only works on pipe type taper fittings not the flared joints which do not use any sealant. If these leak there are small soft metal "V-seals" that will fix damaged fittings. They go between the nose of the fitting and the flared tube. Cy Galley - Chair, AirVenture Emergency Aircraft Repair A Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot ----- Original Message ----- From: <Sargentclt(at)cs.com> Subject: Re: RV9-List: Master clylinder fittings > > Steve I had leak problems as well. Here is the fix. The masters cylinders > use brass fittings unless you have dual brakes then the pilot side subs the AN > fittings for one of each left and right top holes. The brass fittings should > be rotated sloooooly and I can't stress that enough one more revolution than > you think it can handle. Slowly so as not to break the fitting or the master > cylinder. You do not need any pipe thread compound as these are pipe thread > and they are tapered. Tighten each fitting one more rotation until it stops > leaking and your done. Finally pump the lines untill all air is gone then pump > some more to ensure its done. > > Tad Sargent > Sargentclt(at)CS.com > RV7A > > ________________________________________________________________________________
Date: Oct 30, 2004
Just a little piece of Teflon tape in your system can make big problems. Makes your brakes work weird. ----- Original Message ----- From: <DThomas773(at)AOL.COM> Subject: Re: RV9-List: Master clylinder fittings > > Teflon tape is a big help on this little rascals. > > ________________________________________________________________________________
Date: Oct 30, 2004
Subject: Re: Aileron Trailing Edge Construction
Glenn Do the same as the instructions for the rudder and elevators. Use proseal or T-88 or whatever works for you before you rivet the AEX wedge to the skins. Actually, I know a couple of builders that got fairly good edges without bonding the AEX wedge. However, Proseal worked best for me. Peter On 30 Oct 2004 at 11:50, Glenn Brasch wrote: > > What did you folks do for the aileron trailing edges in terms of using > Pro Seal or epoxy or whatever for finishing your trailing edge > riveting? I noticed the plans do not call for bonding prior to > riveting. Your suggestions are appreciated in advance. Glenn in > Arizona -9A 90623, about to start fuselage. > > > advertising on the Matronics Forums. > http://www.matronics.com/chat > ==== > > > > ________________________________________________________________________________
Date: Oct 30, 2004
When I first put my brake sytem together I had multiple leaks. I consulted my A.I. and he suggested putting Teflon Tape on the fittings. I completely removed all the the fittings and put them back, using teflon tape. I am now at 140 hours and have had no problems and no leaks. I hear all the horror storys and warnings about the tape but if you put the tape it on your fittings and not in your system how can you have a problem? Fix it and get on with it. Dennis Thomas ________________________________________________________________________________
Date: Oct 30, 2004
Little bits of tape can get by the threads and get into your system, take it from those who have had it happen in hydraulic applications and fuel systems. Tape should be used for water systems not any hydraulic systems, that is for teflon paste which also prevents the fittings from galling during assembly. -------Original Message------- From: rv9-list(at)matronics.com Date: 10/30/04 19:45:58 Subject: Re: RV9-List: Master clylinder fittings When I first put my brake sytem together I had multiple leaks. I consulted my A.I. and he suggested putting Teflon Tape on the fittings. I completely removed all the the fittings and put them back, using teflon tape. I am now at 140 hours and have had no problems and no leaks. I hear all the horror storys and warnings about the tape but if you put the tape it on your fittings and not in your system how can you have a problem? Fix it and get on with it. Dennis Thomas ________________________________________________________________________________
Date: Oct 31, 2004
The problem with Teflon tape generally is not with the first application. It is the second that pushes the pieces into your system and plugs small orifices or prevent the seals in you master cylinder from doing their job. Can you get lucky? Of course! but why take the chance? Cy Galley - Chair, AirVenture Emergency Aircraft Repair A Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot ----- Original Message ----- From: <DThomas773(at)AOL.COM> Subject: Re: RV9-List: Master clylinder fittings > > When I first put my brake sytem together I had multiple leaks. I consulted > my A.I. and he suggested putting Teflon Tape on the fittings. I completely > removed all the the fittings and put them back, using teflon tape. I am now at > 140 hours and have had no problems and no leaks. I hear all the horror storys > and warnings about the tape but if you put the tape it on your fittings and not > in your system how can you have a problem? Fix it and get on with it. > > Dennis Thomas > > ________________________________________________________________________________
Date: Oct 31, 2004
Thanks for all the replies guys, but I still dont understand did VANS ship you brass or nylon fittings? Thanks, Steve. -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of Steve Sampson Subject: RV9-List: Master clylinder fittings I am trying to get the fluid to stay in the brake syste. (Oh I wish it was easy as electricity!) I am now down to one leak but this is not responding to cursing. The fitting on the low pressure (top) side of one of the master clyinders persists in weeping. Two questions: 1) I notice in DWG36 dated 7/27/00 the plan indicates I should be using a brass fitting (F 69-F-04*02). In fact I am using some nylon fittings, similar to the F271 on the back of the reservoir, and presumably these were what was supplied but its too long ago to remember. I have no brass parts left over. Did others get nylon? 2) Anyone had leak problems with these? How to cure. It is very hard to tell which bit is leaking, probably where the pipe from the reservoir comes in. Help and moral support needed! Thanks, Steve. PS Needless to say every time I go down there I knock the jamjar of brake fluid over. What fun eh! --- This email has been scanned by the MessageLabs Email Security System on behalf of the London Business School community. For more information please visit http://www.messagelabs.com/email This email has been scanned by the MessageLabs Email Security System on behalf of the London Business School community. For more information please visit http://www.messagelabs.com/email --- --- ________________________________________________________________________________
Date: Oct 31, 2004
Check my web site. I tried to use epoxy on the rudder but didn't like the results so before I riveted it I used a head gun to take it apart, cleaned it, and then dry riveted them by hand using a squeezer and flat dies ground to the proper angle. When it came time to do the elevators I created the jig to hold wedge so I could countersink them at the correct angel and once again hand squeezed them. There are pictures on my web site, www.repucci.com/bill/baf.html. They came out very straight, my tech advisor was astonished. Send me a note, if you have any other questions. Bill -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Glenn Brasch Subject: RV9-List: Aileron Trailing Edge Construction What did you folks do for the aileron trailing edges in terms of using Pro Seal or epoxy or whatever for finishing your trailing edge riveting? I noticed the plans do not call for bonding prior to riveting. Your suggestions are appreciated in advance. Glenn in Arizona -9A 90623, about to start fuselage. == == == == ________________________________________________________________________________
Subject: Wingtip lenses installation
Date: Oct 31, 2004
Where am I supposed to find instructions for installing the wingtip plexi? I don't see it in the manual and mine did not come with any separate instructions. Thanks. Wayne Danville, VA RV9A ________________________________________________________________________________
Date: Nov 01, 2004
Brass. Tad S. RV7A"Steve Sampson" wrote: > >Thanks for all the replies guys, but I still dont understand did VANS ship >you brass or nylon fittings? Thanks, Steve. > >-----Original Message----- >From: owner-rv9-list-server(at)matronics.com >[mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of Steve Sampson >To: rv9-list(at)matronics.com >Subject: RV9-List: Master clylinder fittings > > >I am trying to get the fluid to stay in the brake syste. (Oh I wish it was >easy as electricity!) > >I am now down to one leak but this is not responding to cursing. The fitting >on the low pressure (top) side of one of the master clyinders persists in >weeping. Two questions: > >1) I notice in DWG36 dated 7/27/00 the plan indicates I should be using a >brass fitting (F 69-F-04*02). In fact I am using some nylon fittings, >similar to the F271 on the back of the reservoir, and presumably these were >what was supplied but its too long ago to remember. I have no brass parts >left over. Did others get nylon? > >2) Anyone had leak problems with these? How to cure. It is very hard to tell >which bit is leaking, probably where the pipe from the reservoir comes in. >Help and moral support needed! > >Thanks, Steve. > >PS Needless to say every time I go down there I knock the jamjar of brake >fluid over. What fun eh! > >--- > > >This email has been scanned by the MessageLabs Email Security System >on behalf of the London Business School community. >For more information please visit http://www.messagelabs.com/email > > >This email has been scanned by the MessageLabs Email Security System >on behalf of the London Business School community. >For more information please visit http://www.messagelabs.com/email > >--- > >--- > > ________________________________________________________________________________
Date: Nov 02, 2004
Subject: Re: Wingtip lenses installation
The instruction sheet comes with the parts in bag #967. Cliff #90667 wings ----- Original Message ----- From: "Wayne Williams" <rwayne(at)gamewood.net> Subject: RV9-List: Wingtip lenses installation > > Where am I supposed to find instructions for installing the wingtip plexi? I > don't see it in the manual and mine did not come with any separate > instructions. > Thanks. > > Wayne > Danville, VA > RV9A > > ________________________________________________________________________________
Subject: Horizontal Stabilizer Ribs
Date: Nov 09, 2004
I just started the RV9 empennage kit and ran into a snag fitting the 904's to the front spar. While the three 1/8 pre-punched holes in the front flange of the ribs match the three corresponding ones in the spar the top and bottom 3/32 holes in the rib flange really dont' want to match their partners in the spar flange. I can get a cleco in them with a lot of bending and pushing but I'm concerned that when it's time to match drill the skin thru the spar and into the rib I'll end up with, at best, an oversized hole in the rib and, at worst, two holes in the front of each rib. Clearly there is something not bent correctly but I can't figure out what. This is my first metal airplane (currently I'm a Kitfox builder/flier) so I have virtually no background to draw on. Bill Chenoweth Albion, Maine ________________________________________________________________________________
Date: Nov 09, 2004
Subject: Re: Horizontal Stabilizer Ribs
Bill, I just finished the HS about 3 weeks ago. You will run into all sorts of little problems like this. Pushing and bending is part of the process, with limitations of course. Did you "Flute" the ribs? Mike Ice Anchorage, Alaska RV-9 standard build, elevators ----- Original Message ----- From: "Chenoweth" <chenoweth(at)gwi.net> Subject: RV9-List: Horizontal Stabilizer Ribs > > I just started the RV9 empennage kit and ran into a snag fitting the 904's to the front spar. > > While the three 1/8 pre-punched holes in the front flange of the ribs match the three corresponding ones in the spar the top and bottom 3/32 holes in the rib flange really dont' want to match their partners in the spar flange. > > I can get a cleco in them with a lot of bending and pushing but I'm concerned that when it's time to match drill the skin thru the spar and into the rib I'll end up with, at best, an oversized hole in the rib and, at worst, two holes in the front of each rib. > > Clearly there is something not bent correctly but I can't figure out what. This is my first metal airplane (currently I'm a Kitfox builder/flier) so I have virtually no background to draw on. > > Bill Chenoweth > Albion, Maine > > ________________________________________________________________________________
From: "Hebert, Richard" <Richard.Hebert@t-mobile.com>
Date: Nov 09, 2004
Hi Bill, We built the RV-9A empenage at the Alexander Technical Center in Griffin, GA and didn't have any problems getting the 904s to line up. You will have to drill the pre-punched wholes out with the appropriate drill bits and this should help to get the fit right. If the alignment is off significantly, you may need Van's to resend you replacement pieces. I've attached pictures of the front spar before and after riveting. Everything worked out as planned. Hope this helps....and happy building... Richard Hebert/Ray Abadie Atlanta GA RV-9A -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of Chenoweth Subject: RV9-List: Horizontal Stabilizer Ribs I just started the RV9 empennage kit and ran into a snag fitting the 904's to the front spar. While the three 1/8 pre-punched holes in the front flange of the ribs match the three corresponding ones in the spar the top and bottom 3/32 holes in the rib flange really dont' want to match their partners in the spar flange. I can get a cleco in them with a lot of bending and pushing but I'm concerned that when it's time to match drill the skin thru the spar and into the rib I'll end up with, at best, an oversized hole in the rib and, at worst, two holes in the front of each rib. Clearly there is something not bent correctly but I can't figure out what. This is my first metal airplane (currently I'm a Kitfox builder/flier) so I have virtually no background to draw on. Bill Chenoweth Albion, Maine ________________________________________________________________________________
Subject: Share documentation?
Date: Nov 10, 2004
After 3 years and 8 months, and 2550 hours, N937RK (90291) came to life last Saturday, with the first engine start. It ran beautifully, and fired on the first crank. BTW, the engine is a new AeroSportPower O-320-D2A swinging a Sensenich metal prop. I'm now faced with the weight and balance an lots of "paper work" to go to the FAA. Hopefully we will be flying this month or at least by year end. What I am looking for is some documentation assistances. Any of you who are flying the 9A willing to share your documentation with me? I'm looking for weight and balance data or spreadsheet, Flight testing plans, flight numbers, Checklists, POH or any other documentation that might speed my paper work along. It need not be in beautiful format, I'll take what ever I can get. You can send it directly to my email address: Ronald_P_Murray(at)msn.com Ron Murray 90291 Ready to fly Lake Norman Airpark, NC ________________________________________________________________________________
Subject: Re: Share documentation?
Date: Nov 10, 2004
21, 2004) at 11/10/2004 03:56:39 PM, Serialize complete at 11/10/2004 03:56:39 PM Ron. Check the files section of the yahoo groups RV9 and Subaru sections. You can get there from Doug Reeves RV List. I put POH, W&B, Test plan and other docs out there from my 9. Regards, Larry Perryman 90288 N194DL - 175 hrs "Ron Murray" Sent by: owner-rv9-list-server(at)matronics.com 11/10/2004 08:07 AM Please respond to rv9-list To: cc: Subject: RV9-List: Share documentation? After 3 years and 8 months, and 2550 hours, N937RK (90291) came to life last Saturday, with the first engine start. It ran beautifully, and fired on the first crank. BTW, the engine is a new AeroSportPower O-320-D2A swinging a Sensenich metal prop. I'm now faced with the weight and balance an lots of "paper work" to go to the FAA. Hopefully we will be flying this month or at least by year end. What I am looking for is some documentation assistances. Any of you who are flying the 9A willing to share your documentation with me? I'm looking for weight and balance data or spreadsheet, Flight testing plans, flight numbers, Checklists, POH or any other documentation that might speed my paper work along. It need not be in beautiful format, I'll take what ever I can get. You can send it directly to my email address: Ronald_P_Murray(at)msn.com Ron Murray 90291 Ready to fly Lake Norman Airpark, NC ________________________________________________________________________________
Date: Nov 10, 2004
I'm 90-120 days behind Ron in this process but would like to share in the wealth if you all would CC me with the requested information. John Kerr 90616, RV9 -------------- Original message -------------- > > After 3 years and 8 months, and 2550 hours, N937RK (90291) came to life last > Saturday, with the first engine start. It ran beautifully, and fired on the > first crank. BTW, the engine is a new AeroSportPower O-320-D2A swinging a > Sensenich metal prop. I'm now faced with the weight and balance an lots of > "paper work" to go to the FAA. Hopefully we will be flying this month or at > least by year end. > > What I am looking for is some documentation assistances. Any of you who are > flying the 9A willing to share your documentation with me? I'm looking for > weight and balance data or spreadsheet, Flight testing plans, flight numbers, > Checklists, POH or any other documentation that might speed my paper work along. > It need not be in beautiful format, I'll take what ever I can get. > > You can send it directly to my email address: > Ronald_P_Murray(at)msn.com > > Ron Murray > 90291 > Ready to fly > Lake Norman Airpark, NC > > > > > > I'm 90-120 days behind Ron in this process but would like to share in the wealth if you all would CC me with the requested information. John Kerr 90616, RV9 -------------- Original message -------------- -- RV9-List message posted by: "Ron Murray" After 3 years and 8 months, and 2550 hours, N937RK (90291) came to life last Saturday, with the first engine start. It ran beautifully, and fired on the first crank. BTW, the engine is a new AeroSportPower O-320-D2A swinging a Sensenich metal prop. I'm now faced with the weight and balance an lots of "paper work" to go to the FAA. Hopefully we will be flying this month or at least by year end. What I am looking for is some documentation assistances. Any of you who are flying the 9A willing to share your documentation with me? I'm looking for weight and balance data or spreadsheet, Flight testing plans, flight numbers, Checklists, POH or any other docume ntation that might speed my paper work along. It need not be in beautiful format, I'll take what ever I can get. You can send it directly to my email address: Ronald_P_Murray(at)msn.com Ron Murray 90291 Ready to fly Lake Norman Airpark, NC for your generous support! http://www.matronics.com/archives ________________________________________________________________________________
Date: Nov 10, 2004
Subject: Empennage Video
I have the RV9 Empennage video by Orndorff if anyone is interested. I only viewed it once and will let it go for $24.00. If anyone is interested please contact me off list. ________________________________________________________________________________
Subject: Aileron Twist
Date: Nov 10, 2004
I just completed an aileron. I had no problems whatsoever in the assembly and took the advice of a fellow builder in the trailing edge, which came out near perfect and straight. The problem is when I lay the completed structure flat on a table, one side of the trailing edge is flush, the other is off the table by almost 1/2". Again, the trailing edge is straight, and if I push down on it, it brings up a forward corner. I cannot imagine how this occurred and wondering if anyone else has had this happen. I can only assume this twist should not be, and if it stays, the flaps and/or tips will not be aligned properly when assembled. Your comments are appreciated in advance. Glenn in AZ. ________________________________________________________________________________
Date: Nov 11, 2004
Glenn, you've been bitten by the classic "straight-but-not-true" bug. You are correct in your assessment that it will not be lined up when you hang it on the wing. You will need to drill out the rivets in the innermost and outermost ribs and possibly even the trailing edge rivets and have at it again, this time on a perfectly flat surface. I did the same thing on my first aileron, but I sensed that it was going bad after a small number of rivets. My solution was to stand the wings on their nose-stand cradles and build the flaps and ailerons while hinged in place. This way I could use my fuselage longeron angles as clamps along the entire trailing edge during construction and be absolutely guaranteed of straight and true trailing edges. You can still pre-rivet the stiffeners and forward rows of rivets, but if you clamp them together like this when you do the trailing edge and end ribs, you should have an easier time with it. You only need to "tack" a few rivets to set the shape, then you can remove them to do the final riveting. In case anyone is wondering, during normal flight maneuvers the ailerons are so sensitive that I rarely see them move more than about 1/2" up or down. ...thus a 1/2" twist is an obvious no-go and must be fixed. Gary ________________________________________________________________________________
Date: Nov 11, 2004
Sounds to me like you haven't fluted the ribs or you haven't fluted them enough. There may be a small mis-alignment, but you should still be able to get the cleco in the hole. Also I did have a single bad rib in my kit, it was stamped backwards and all of the "factory flutes" fell right on top of the holes. The flutes should always be between rivet holes, never on a hole. Van's promptly replaced my rib, but I doubt you got an entire batch of bad ribs. Jen Coull Lake Worth, FL 90349 - Tanks ________________________________________________________________________________
Date: Nov 11, 2004
Subject: CH Products Control Stick Switches Electrical Specifications
There has been discussions about the CH Products control sticks (http://www.chproducts.com/retail/aircraft.html) on the newsgroups lately. I have two of them, but there was a question about what the switch ratings were. I contacted Kevin Williamson of CH Products and he was kind enough to supply me with a set of sample switches (from Omron) and the part numbers thereof. I downloaded the complete data sheet from the web, reviewed the specifications and then called the Omron factory representative. There are a few minor errors in the datasheet available on the web, so the rep emailed me the revised (corrected) sheets. I also discussed with him the specifications listed and got clarification, although it turned out that when I received the revised data sheets, the specification is very clear now. The bottom line is that the electrical rating for all three different switches is: 1-50mA, at 5-24V. The explanation for the ratings is: 1. The lower values (1 mA at 5V) are to make sure that the switch sees enough energy when switching to keep the contacts clean. Any lower values would not guarantee that the contacts will always make proper contact over the life of the switch. If for some reason the load being switched is too low, a resistor could be added in parallel with the load to increase the current to at least 1 mA. 2. The higher values (50 mA at 24V) are the maximum values that should be switched that will not damage the switch. Switching any higher loads will risk damaging the contacts - either welding them shut or warping them or causing excessive arc damage - and will certainly shorten the life of the switch. 3. These ratings are for a resistive load, so if they are to be used with a relay or motor the contacts MUST be protected with a diode or other type of snubber network! Of course, the manufacturer always has a margin in the design so if one chooses to switch 55mA at 14V (for instance), the switch will probably still have a reasonable life. However, pushing them to 100 mA or more will definitely shorten the life and may result in a catastrophic failure at some point. These switches are rated for a lot of actuations so their use in an airplane should be no problem. The hat switches are rated for 300,000 operations (minimum), the switches on the top face of the stick are rated for 100,000 operations (minimum) and the trigger (typically used for push-to-talk) is rated for 1,000,000 operations (minimum). To put these numbers in perspective, let's assume you make one flight every day for ten years. For each flight you could use the hat switch to trim the airplane 82 times in each direction, you could actuate the flaps (assuming that is what you use the two gray switches on the top of the stick for) 27 times each up and down and you could push-to-talk 274 times. I am satisfied that the switches used are as robust as you will find and the ratings are adequate for the task. Just don't go overboard on what you connect direct to the switches and your CH Products control stick will have a long and happy life! Dick Tasker ________________________________________________________________________________
Date: Nov 11, 2004
Hi Glenn, the same thing happened to me. Makes you wonder if the predrilled holes aren't a little off. I did notice the twist before riveting the other side together on my first one so I broke out some extra weight (lead bullets) and when I was done it came out pretty close. As I remember 5/32". I do, although, have noticeable diagonal wave in the reflection off the bottom skin. I paid very close attention on my next aileron and still ended up with a very slight twist after using LOTS of weight. I think when the plans say weight they mean WEIGHT! I talked to a professional builder in the area and he said press on. He's seen a lot worse. I guess it's up to you. Shouldn't cost too much and only a couple of days to build another one if that's what you choose to do. You can always press on and build another in the future. Don't let it get you down. Keep pounding! Roger Ping 90869 fuselage Peoria AZ -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Glenn Brasch Subject: RV9-List: Aileron Twist I just completed an aileron. I had no problems whatsoever in the assembly and took the advice of a fellow builder in the trailing edge, which came out near perfect and straight. The problem is when I lay the completed structure flat on a table, one side of the trailing edge is flush, the other is off the table by almost 1/2". Again, the trailing edge is straight, and if I push down on it, it brings up a forward corner. I cannot imagine how this occurred and wondering if anyone else has had this happen. I can only assume this twist should not be, and if it stays, the flaps and/or tips will not be aligned properly when assembled. Your comments are appreciated in advance. Glenn in AZ. ________________________________________________________________________________
Date: Nov 11, 2004
Subject: Re: Aileron Twist
Hi Glenn, I had the same problem with my first aileron, sacrificed it and built another. I thought my problem lay in not having the assembly on a dead flat surface when I drilled the first ribs to the balance bar. Dennis ________________________________________________________________________________
Date: Nov 14, 2004
Subject: [ Keith T Uhls ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Keith T Uhls Lists: RV-List,RV6-List,RV7-List,RV9-List Subject: RV-7 with GRT EFIS and Dynon http://www.matronics.com/photoshare/keithuhls@juno.com.11.14.2004/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The RV9-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: rv9-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/RV9-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/rv9-list _-= Browse Digests: http://www.matronics.com/digest/rv9-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/rv9-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
Subject: LOE 5 Move
rv8list(at)yahoogroups.com, rv9-list(at)matronics.com.1.70.SUSPICIOUS_RECIPS.Similar.addresses.in.recipient.list I just noticed on the Land Of Enchantment website that they are moving the fly-in to a new location at 5T6. While I have been to the museum there, which is nice, it looks to be in the middle of nowhere, far from lodging and no rental cars. Tell me it aint so. My wife and I really enjoy Las Cruces, I for one vote for not moving the fly-in. Someone in the know need to fill us in on the reasons for the move. Gary _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The RV9-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: rv9-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/RV9-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/rv9-list _-= Browse Digests: http://www.matronics.com/digest/rv9-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/rv9-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Subject: Bandsaw question
Date: Nov 14, 2004
It seems the old bandsaw I had been using might have finally bit the dust. It was a cheap 14" saw my brother gave me but was variable speed and worked great for cutting aluminum. The problem is the company that built it is no longer around so parts may not be available. With the thought that I may have to replace it in mind, I would like to solicit some recommendations from my fellow builders. What bandsaw would you recommend for cutting aluminum. Bill RV-9 SN: 90737 Fuselage _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The RV9-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: rv9-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/RV9-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/rv9-list _-= Browse Digests: http://www.matronics.com/digest/rv9-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/rv9-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 15, 2004
Subject: Re: Bandsaw question
Bill, I have the Ryobi 9" bandsaw from Home Depot. It ran about $120. It works fine but at times I wish it had a deeper throat. The trick is in the blade. If I remember correctly, Home Depot only sells two blades, both intended for wood. The finest, it may be a 16 tooth/inch, is adequate for aluminum but it dulls instantly on steel. The great thing about Home Depot is their return policy. Leland Expecting a Catto 3-blade prop Saturday "It seems the old bandsaw I had been using might have finally bit the dust. It was a cheap 14" saw my brother gave me but was variable speed and worked great for cutting aluminum. The problem is the company that built it is no longer around so parts may not be available. With the thought that I may have to replace it in mind, I would like to solicit some recommendations from my fellow builders. What bandsaw would you recommend for cutting aluminum." _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The RV9-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: rv9-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/RV9-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/rv9-list _-= Browse Digests: http://www.matronics.com/digest/rv9-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/rv9-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 15, 2004
there was a short thread a couple of months ago about mounting the Dynon pitot bracket. I was not clear on the suggestions and haven't been able to noodle through the process on my own. The hole called out on the plans is drilled, but it seems problematic to mount the dynon pitot there. Help John 90616 there was a short thread a couple of months ago about mounting the Dynon pitot bracket. I was not clear on the suggestions and haven't been able to noodle through the process on my own. The hole called out on the plans is drilled, but it seems problematic to mount the dynon pitot there. Help John 90616 ________________________________________________________________________________
Date: Nov 15, 2004
Bill, The little Delta seems to be very popular and a good buy; often on sale. I went with a Grizzly and doubt that I have anything much better. Grizzly sells a variety of blades & you may be able to get one from them to fit whatever you buy. Can also have blades custom made--there are shops with blade welding machines that can take bulk blade stock and weld it to whatever length you need, so any tooth count density can be had. Richard Scott RV-9 Emp At 06:42 PM 11/14/2004, you wrote: > >It seems the old bandsaw I had been using might have finally bit the >dust. It was a cheap 14" saw my brother gave me but was variable speed >and worked great for cutting aluminum. The problem is the company that >built it is no longer around so parts may not be available. > >With the thought that I may have to replace it in mind, I would like to >solicit some recommendations from my fellow builders. > >What bandsaw would you recommend for cutting aluminum. > >Bill >RV-9 >SN: 90737 >Fuselage ________________________________________________________________________________
Date: Nov 15, 2004
Thanks for all of you who replied. I was able to find the part I needed, which was a new drive belt. The company that made my saw went out of business 11 years ago and I was having a hard time locating a replacement belt. It turns out that my drive belt is just a VERY big O-ring and I was able to locate them on the web today. I should have a replacement in three days. As for bandsaw blades, I found a very good site for ordering custom blades, www.ebandsawblades.com. I should have a new batch of blades, cut to my custom length by next week. (18 TPI, 1/4" X 57") (The saw I have I would never recommend for woodworking but seems to work good on the light cutting required for the -9 and does have a 14" throat, which works out well. More so since it has three speeds and I can slow it down for cutting metal.) Bill -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Richard Scott Subject: Re: RV9-List: Bandsaw question Bill, The little Delta seems to be very popular and a good buy; often on sale. I went with a Grizzly and doubt that I have anything much better. Grizzly sells a variety of blades & you may be able to get one from them to fit whatever you buy. Can also have blades custom made--there are shops with blade welding machines that can take bulk blade stock and weld it to whatever length you need, so any tooth count density can be had. Richard Scott RV-9 Emp At 06:42 PM 11/14/2004, you wrote: > >It seems the old bandsaw I had been using might have finally bit the >dust. It was a cheap 14" saw my brother gave me but was variable speed >and worked great for cutting aluminum. The problem is the company that >built it is no longer around so parts may not be available. > >With the thought that I may have to replace it in mind, I would like to >solicit some recommendations from my fellow builders. > >What bandsaw would you recommend for cutting aluminum. > >Bill >RV-9 >SN: 90737 >Fuselage ________________________________________________________________________________
Subject: W-918 aileron pushrod
Date: Nov 15, 2004
Just received my wing kit this Saturday and while completing the inventory found that I didn't have an ST4130-035X1/2X 48". I was sent one only 38" long. Looking at DWG.15 it shows the pushrod needing to be 27 1/8 inches long. I assume that the intent was to cut the 48" rod in half and end hardwre makes up the remaining 3 1/8 inches. My question is, what is the proper length on the pushrod? is the DWG correct or is the 38" rod long enough to fabricate two pushrods (~22" long). Bill 90930 (N930RV Res) ________________________________________________________________________________
Date: Nov 16, 2004
From: Gregory Richardson <rv9flyer(at)sbcglobal.net>
Subject: Re: W-918 aileron pushrod
Bill, If you look at the print again, you will find that the pushrod is 27 1/8 from bolt center to bolt center. 22 inches comes to mind as what I made both of mine, but I can't remember if there is a part of an inch there or not. I determined the length by turning my bearing ends onto the tube insert to the point where I wanted them to rest setting adjustment freeplay. Again if memory serves me correctly, I turned the screw into the rod end to the halfway point, which is required by building practices, and then I split the difference of the remaining screw. I then placed the bosses that sit against the tube end together, and placed the center of the bearing at 27 1/8 inch on a tape measure, and the resultant length appearing in the center of the other bearing is what the tube needs to be cut to. I still managed to screw my first one up so the caveat of measure three times and cut once doubly applies here. Good luck, and keep pounding rivets. Greg Bill Cary wrote: Just received my wing kit this Saturday and while completing the inventory found that I didn't have an ST4130-035X1/2X 48". I was sent one only 38" long. Looking at DWG.15 it shows the pushrod needing to be 27 1/8 inches long. I assume that the intent was to cut the 48" rod in half and end hardwre makes up the remaining 3 1/8 inches. My question is, what is the proper length on the pushrod? is the DWG correct or is the 38" rod long enough to fabricate two pushrods (~22" long). Bill 90930 (N930RV Res) ________________________________________________________________________________
Date: Nov 16, 2004
Subject: Re: Dynon/Gretz mounting problem
John, take a look at the mount offered at http://www.safeair1.com/index.htm. It may fit without modification, unlike the Gretz mount. The safeair1 mount is cheaper and requires painting, but so does the Dynon probe. Bill Repucci posted some pictures somewhere showing the modification needed to the Gretz mount. Leland "there was a short thread a couple of months ago about mounting the Dynon pitot bracket. I was not clear on the suggestions and haven't been able to noodle through the process on my own. The hole called out on the plans is drilled, but it seems problematic to mount the dynon pitot there. Help John 90616" ________________________________________________________________________________
Date: Nov 16, 2004
I got the wrong push rod too. Van's sent me another. Bryan From: "Bill Cary" <williamc(at)abac.com> Subject: RV9-List: W-918 aileron pushrod Just received my wing kit this Saturday and while completing the inventory found that I didn't have an ST4130-035X1/2X 48". I was sent one only 38" long. Looking at DWG.15 it shows the pushrod needing to be 27 1/8 inches long. I assume that the intent was to cut the 48" rod in half and end hardwre makes up the remaining 3 1/8 inches. My question is, what is the proper length on the pushrod? is the DWG correct or is the 38" rod long enough to fabricate two pushrods (~22" long). Bill 90930 (N930RV Res) ________________________________________________________________________________
Subject: fuel/ Vent line length
Date: Nov 16, 2004
Has anyone measured the distance from the fuselage to wing tank fittings (fuel and vent)? I have already drilled my wing angles and forgot to measure the length for where to put the tubing flare on the fuel and vent lines. Thanks! Wayne Williams Danville, VA RV9A ________________________________________________________________________________
Date: Nov 16, 2004
SNIP > Just received my wing kit this Saturday and while completing the inventory found that I didn't have an ST4130-035X1/2X 48". I was sent one only 38" long. First, thanks for all the help. I emailed Van's support department today and they replied back within 2 hours. Indeed I was sent the wrong length rod. They will be sending another 36" rod so I'll be cutting both of them down to something like 23". Glad I took the time to measure and glance at the drawings during inventory. Bill 90930 ________________________________________________________________________________
Date: Nov 17, 2004
Bill, Glad you got it straightened out. I dug back into my files and memory, and found that I had cut both of my pushrods to 22 7/16". Again, measure three times and cut twice, but that is what I found mine to work out to for what its worth. Good luck and keep pounding rivets. Greg (RV9A fuselage) Bill Cary wrote: SNIP > Just received my wing kit this Saturday and while completing the inventory found that I didn't have an ST4130-035X1/2X 48". I was sent one only 38" long. First, thanks for all the help. I emailed Van's support department today and they replied back within 2 hours. Indeed I was sent the wrong length rod. They will be sending another 36" rod so I'll be cutting both of them down to something like 23". Glad I took the time to measure and glance at the drawings during inventory. Bill 90930 ________________________________________________________________________________
Subject: RE:
Date: Nov 21, 2004
Dck - why do you say it must be mounted further aft? Steve. -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of Richard Tasker Subject: Re: RV9-List: RE: Now, if you are actually asking about where to mount the Gretz mount on the wing, then you are correct that the hole location recommended by Van's for the standard pitot is not suitable. The Gretz mount must be located more aft in the wing skin. I believe (if I remember correctly) that the Gretz mount comes with appropriate instructions for this aspect. Dick Tasker --- ________________________________________________________________________________
Date: Nov 21, 2004
From: "Richard E. Tasker" <retasker(at)optonline.net>
Subject: Re: RE:
I assumed that you were referring to the hole in the spar flange and bottom skin as recommended by Van's for their standard pitot tube. The Gretz mount is designed to be mounted on the bottom skin aft of the spar flange. Dick Steve Sampson wrote: > >Dck - why do you say it must be mounted further aft? Steve. > >-----Original Message----- >From: owner-rv9-list-server(at)matronics.com >[mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of Richard Tasker >To: rv9-list(at)matronics.com >Subject: Re: RV9-List: RE: > > >Now, if you are actually asking about where to mount the Gretz mount on >the wing, then you are correct that the hole location recommended by >Van's for the standard pitot is not suitable. The Gretz mount must be >located more aft in the wing skin. I believe (if I remember correctly) >that the Gretz mount comes with appropriate instructions for this aspect. > >Dick Tasker > >--- > > > > ________________________________________________________________________________
Subject: RE:
Date: Nov 21, 2004
I think the reason the Dynon Pitot tube is mounted further aft is this pitot tube incorporates the ports for their AOA. The instructions that come with the Gretz mount show you exactly where to mount it, which is a few inches further aft than where Van's places the their simple pitot tube. Since my -9 isn't flying yet, I have no idea if where I placed it will work or not. I just assumed the location recommended by Gretz was accurate. There is a picture of the pitot tube installation on the wing page of my web site. Back to building. Bill RV-9 (Yes, with the little wheel in back.) SN: 90737 N941WR (Reserved) Fuselage www.repucci.com/bill/baf.html -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Steve Sampson Subject: RE: RV9-List: RE: --> Dck - why do you say it must be mounted further aft? Steve. -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of Richard Tasker Subject: Re: RV9-List: RE: Now, if you are actually asking about where to mount the Gretz mount on the wing, then you are correct that the hole location recommended by Van's for the standard pitot is not suitable. The Gretz mount must be located more aft in the wing skin. I believe (if I remember correctly) that the Gretz mount comes with appropriate instructions for this aspect. Dick Tasker --- ________________________________________________________________________________
Subject: RV 9A questions
Date: Nov 21, 2004
I'm new to the site. I'm trying to decide between the 7A and the 9A. I'm not interested in the aerobatics, just good flying, some good xcountries, insurance rates, and something that's not a handful. The 9 seems the ticket, but a lot of others are intent on future desires to do aerobatics.. any opinions. And by the way, how long after the empennage kit is ordered does it take to deliver? Tks Ron ________________________________________________________________________________
Date: Nov 21, 2004
Subject: Re: RV 9A questions
Hi Ron, I think emp kits are in stock and you usually get same day shipping. It just depends where you are but I think 5 days is normal. I'm flying my RV-9 and love it. But I don't know if if I would try to talk you out of a 7. The 9 is really easy to fly. I have a problem getting consistant good landings. It is a real springy gear and likes to bounce. Dennis Thomas ________________________________________________________________________________
Date: Nov 21, 2004
Ron Brown wrote: > >I'm new to the site. I'm trying to decide between the 7A and the 9A. I'm not interested in the aerobatics, just good flying, some good xcountries, insurance rates, and something that's not a handful. The 9 seems the ticket, but a lot of others are intent on future desires to do aerobatics.. >any opinions. And by the way, how long after the empennage kit is ordered does it take to deliver? >Tks >Ron > If I was sure I wouldn't want acro in the future, I'd probably build the -9. Virtually no penalty in cruise at the same hp & significantly lower landing speeds=potentially safer operation. Of course, you aren't supposed to go over 160hp & that will limit cruise speeds when compared to a 200hp -7.... Charlie flying acro in a -4; -7 wings ________________________________________________________________________________
Date: Nov 22, 2004
Ron, Folks at Van's told me that the 9 is such a nice plane that if any of the employees were going somewhere & they had a choice the ALL chose the 9. This was before the 10 came along. So if aerobatics are not in your future, that suggests to me that the 9 is an obvious choice. BUT, a friend is building a 7 and is about as far along as I am, finishing up the emp. It looks like the 7 emp is easier to build and the instructions definitely are laid out better. What I remember is that there is only one trailing edge wedge on the 7 (less drilling, dimpling/countersinking, less room for error, less fussing) and the skins are usually heavier (less chance of screwing up by denting a skin). I think there were a couple other things, also. OTOH, he might see some things on the 9 that seem easier. So if all other things were equal and ease of building was a concern, I would go with the 7, but if flying characteristics were important do the 9. And Dennis, if you bounce a lot, you may be touching down too fast. I had the same problem with my '41 Interstate Cadet. Took it up on a dead calm morning, checked the ASI against a handheld GPS in 4 directions and when the ASI showed 60 the GPS said 75! Started landing slower & that solved the problem. Richard Scott At 11:35 AM 11/21/2004, you wrote: > >I'm new to the site. I'm trying to decide between the 7A and the 9A. I'm >not interested in the aerobatics, just good flying, some good xcountries, >insurance rates, and something that's not a handful. The 9 seems >the ticket, but a lot of others are intent on future desires to do >aerobatics.. >any opinions. And by the way, how long after the empennage kit is ordered >does it take to deliver? >Tks >Ron > > ________________________________________________________________________________
Date: Nov 22, 2004
Ron, I also struggled with that decision. I ultimately chose the -9A because it better suited my mission profile, i.e., cross-country day/night VFR. I'm a low-time pilot, looking for good cruise, economy and low insurance rates. I think you answered your own question. If I choose to go the aerobatics route, I'll buy/build something else. I think there are probably better aerobatic platforms on the market than the -7. Ron Brown wrote: > >I'm new to the site. I'm trying to decide between the 7A and the 9A. I'm not interested in the aerobatics, just good flying, some good xcountries, insurance rates, and something that's not a handful. The 9 seems the ticket, but a lot of others are intent on future desires to do aerobatics.. >any opinions. And by the way, how long after the empennage kit is ordered does it take to deliver? >Tks >Ron > > > > ________________________________________________________________________________
Date: Nov 22, 2004
From: "Don/Marcia Piermattei" <dlpier(at)lamar.colostate.edu>
Subject: RV-9A question
I'm new to the site. I'm trying to decide between the 7A and the 9A Ron, I previously built and flew an RV-6. Having about 50 hours in my 9A I can tell you it is a delightful flier. It is much more stable in cruise than the -6, and is just as nimble in any nonaerobatic manuever. It is very easy to consistently land well in my hands. I used wood stiffeners on the main gear and do not find it at all springy. I believe it is more forgiving of aft CG loading than the -6 was. I also believe it will be easier to sell if you ever decide to, as any Cessna driver could convert with 2 hours of instruction. I'll be glad to answer any other questions off line. Don Piermattei N192DP Donald L. Piermattei DVM, PhD 5000 E County Rd 92 Carr, CO 80612 970/568-9047 Fax 970/568-7279 ________________________________________________________________________________
Subject: Engines
Date: Nov 23, 2004
What engine are most thinking of using? I'm leaning towards an 0-360 180hp fixed pitch. Seems to me the extra 20hp (over the recommended 160hp) will make up for not having a CS prop on climb. Wayne -- Checked by AVG Anti-Virus. ________________________________________________________________________________
Subject: Engines
Date: Nov 23, 2004
I am probably going with a 160 HP 0-320 and a constant speed prop because of landing at my farm which is only 1200 feet long. -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Wayne Williams Subject: RV9-List: Engines What engine are most thinking of using? I'm leaning towards an 0-360 180hp fixed pitch. Seems to me the extra 20hp (over the recommended 160hp) will make up for not having a CS prop on climb. Wayne -- Checked by AVG Anti-Virus. ________________________________________________________________________________
Subject: Engines
Date: Nov 23, 2004
Wayne Superior Engines has a paper on using the 0-360 on the 9. If I remember correctly they are saying restrict power on take off, but have it available at altitude. Might check their web site. I am really considering it. Ken -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Wayne Williams Subject: RV9-List: Engines What engine are most thinking of using? I'm leaning towards an 0-360 180hp fixed pitch. Seems to me the extra 20hp (over the recommended 160hp) will make up for not having a CS prop on climb. Wayne -- Checked by AVG Anti-Virus. ________________________________________________________________________________
Date: Nov 23, 2004
Subject: Re: Engines
Wayne, Just bought a 160 hp O-320 780 hours TTSN out of an RV-6A trashed by Hurricane Charlie. Leaning toward a three blade Catto prop in cruise configuration (66" diameter X 70" pitch by their way of measurement.) Catto seems to be a good compromise for my flying, and all props, even CS, are compromises. Light weight, quieter than two blade, not too expensive, and with proven performance. Hope it works out as well as the theory! Good luck on your choice! Bob Kelly, 90854 On 11/23/04, Wayne Williams wrote: > > What engine are most thinking of using? I'm leaning towards an 0-360 180hp > fixed pitch. > Seems to me the extra 20hp (over the recommended 160hp) will make up for > not having a CS prop on climb. > > > Wayne > > ________________________________________________________________________________
Date: Nov 23, 2004
I think I would talk to Van's before going with a bigger engine. I have a 150 HP 0-320 and it will drag me along 190 MPH, gross loaded. The 0-360 must weigh more and would complicate weight and balance. It would seem easy to over stress the air frame and just really what are the advantages? Dennis Thomas ________________________________________________________________________________
Date: Nov 23, 2004
Get an eci 160 hp kit for that thing..You will love it ________________________________________________________________________________
Date: Nov 23, 2004
Dennis, It is only 8 lbs more but will come in handy in my high DA environment. I spoke with a Vans engineer at OSH who told me it would work fine, as long as you don't exceed Vne or redline. That was off the record of course. I will probably go with the ECI O-360. Glenn in AZ. -9 Fuse. ----- Original Message ----- From: <DThomas773(at)AOL.COM> Subject: Re: RV9-List: Engines > > I think I would talk to Van's before going with a bigger engine. I have a > 150 HP 0-320 and it will drag me along 190 MPH, gross loaded. The 0-360 must > weigh more and would complicate weight and balance. It would seem easy to over > stress the air frame and just really what are the advantages? > > Dennis Thomas ________________________________________________________________________________
Date: Nov 23, 2004
Subject: Prop X Engine
Hi there: Ive received an e-mail from Sensenich about a vibration coupling between an O-320, 9:1 high compression pistons Aerosport engine and a 70" x 82" Sensenich prop. Does anyone has some info about it? Thanks in advance JC - Aracaju - Brasil RV-9A QB #90997 ________________________________________________________________________________
Date: Nov 23, 2004
Wayne, I am going that route also. By having pitch of the prop set for cruise, you should not get over 2500 rpm on take off (less than 160 hp) and when you get up to alt. the extra 20 hp will get us on our way. This is from the Mahlon (sp) at Mattituck. I have it heard that this makes our bird a "Super 9" :-)))) Jim ________________________________________________________________________________
From: "sdellangelo(at)netzero.com" <sdellangelo(at)netzero.com>
Date: Nov 24, 2004
I am going to use an O-320-E3D that I got used "mid time". I will overhaul with 9:1 pistons, probably a single lightspeed, probably Ellison TBI (since it did not come with a carb) and maybe an ASI cam. Hoping for around 170hp without the extra 8ish pounds. Going to use a Sensenich 70 X 81" or 82" prop. If I had not found the used engine I was planning to do the ECI O-360 kit or else the O-320 kit with overhauled rods. Scott DellAngelo #90598 - Fuselage all drilled and starting to come apart for the last time tonight Plainfield, IL NetZero HiSpeed $14.95. Visit Sam Goody, Suncoast or MediaPlay Stores. ________________________________________________________________________________
Date: Nov 24, 2004
>Hi there: >Ive received an e-mail from Sensenich about a vibration coupling >between an >O-320, >9:1 >high compression pistons Aerosport engine and a 70" x 82" Sensenich >prop. >Does anyone has some info about it? >Thanks in advance >JC - Aracaju - Brasil >RV-9A QB >#90997 JC, Let me know what you find out as this list has been/is my plan. 9:1 and Sensenich 81 or 82. I wonder how Catto props stand up to flight in the rain? Maybe I should check into one of them as people seem to like them and you lose the 2600 rpm restriction I bet. Scott DellAngelo #90598 Fuselage Plainfield, IL NetZero HiSpeed $14.95. Visit Sam Goody, Suncoast or MediaPlay Stores. ________________________________________________________________________________
Subject: wing tip lenses
Date: Nov 24, 2004
does anyone have suggestions/instructions for installing the clear lenses in the point of the wing tip. If I had any they have been "misfiled". John Kerr 90616, finishing wiring,assembly, etc pre-paint does anyone have suggestions/instructions for installing the clear lenses in the point of the wing tip. If I had any they have been "misfiled". John Kerr 90616, finishing wiring,assembly, etc pre-paint ________________________________________________________________________________
Date: Nov 24, 2004
Subject: Re: wing tip lenses
Hi John, Mine came as 1peice. It looks a small bubble and you need to cut it in half to make the 2 lenses. Pretty simple and straight forward task. Dennis ________________________________________________________________________________
Date: Nov 24, 2004
after cutting and fitting, how did you attach it to the fairing. did you do more than "eye-ball" the position/strobe to the fairing? Thanks, John -------------- Original message -------------- > > Hi John, > Mine came as 1peice. It looks a small bubble and you need to cut it in half > to make the 2 lenses. Pretty simple and straight forward task. > > Dennis > > > > > > after cutting and fitting, how did you attach it to the fairing. did you do more than "eye-ball" the position/strobe to the fairing? Thanks, John -------------- Original message -------------- -- RV9-List message posted by: DThomas773(at)aol.com Hi John, Mine came as 1peice. It looks a small bubble and you need to cut it in half to make the 2 lenses. Pretty simple and straight forward task. Dennis tronics.com/contribution ________________________________________________________________________________
Date: Nov 24, 2004
Hi John, I don't have the specifics, but I do know a great website where you can get some information with great pictures of how to "Install Wingtip Lens". Randy Pflanzer has a great website where he is buidling his F1 Rocket. If you go to the site and look at his section on installing the wingtip lens, you'll get some great information. Check it out. http://f1rocket.home.comcast.net/index.html Hope this helps..... Richard Hebert RV-9A Empenage Complete -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of kerrjohna(at)comcast.net Subject: RV9-List: wing tip lenses does anyone have suggestions/instructions for installing the clear lenses in the point of the wing tip. If I had any they have been "misfiled". John Kerr 90616, finishing wiring,assembly, etc pre-paint does anyone have suggestions/instructions for installing the clear lenses in the point of the wing tip. If I had any they have been "misfiled". John Kerr 90616, finishing wiring,assembly, etc pre-paint ________________________________________________________________________________
Date: Nov 24, 2004
Subject: Catto Prop
Hi Scott Delllangelo: I live in the northeast region of Brasil, and in the summer time weve got a lot of sparsed rain in our heading. My last airplane, a FASCINATION (Germany ultralight airplane), had a composite propeller, and Ive got a lot problems in the leading edge surface. http://www.cattoprops.com/index.html This is the answer from Mr Craig, form rep Catto Propellers about it.: "Hello JC, The way that my propeller is manufactured, the type of composite structure is very durable to rain... Here is how it works.... I have many customers in eastern US and rain is a big concern there.. If you pull the rpm back to 2200 to 2300 rpm, you will not have any erosion at all of the leading edge in medium rain... However in your situation, an area of lots of rain, I would highly recommend the use of PropGuard Leading Edge Tape.. I stock the material and install it on propellers for my customers for this type of flying. With the PropGuard Tape installed, you can fly through rain at full throttle and not hurt anything.. The cost is only $85 for the three bladed prop installed.. It will last about 2 to 3 years, you pull it off and install new tape.. It is very easy to install and is STC'd. Regards, Craig Catto" Gimme an answer. JC RV-9A QB #90997 ________________________________________________________________________________
Date: Nov 24, 2004
I used # 6 nutplates and countersink machine screws, at first 1 each, top and bottom on the rear inside corner. After flying a bit they seem to lifting some so I added another nutplate on the bottom, halfway between the rear corner and leading edge. I have the combination,strobe and position lights and did just eyeball their location. Be sure they are far enough to the rear that they will be clear of the lense surface. Dennis ________________________________________________________________________________
From: "Steve Sampson" <SSampson.SLN21(at)london.edu>
Subject: RE:
Date: Nov 24, 2004
Richard/Bill - Sorry not to come back sooner, but I have been away. Yes I guess the center of the mount is very slightly aft, however the head itself is in fact further forward. I have just pulled out the VANS and Gretz instructions since you had me worried. In fact I doubt it is that sensitive in practice either. I also have not yet flown. Regards, Steve. #90360 --- ________________________________________________________________________________
Date: Nov 24, 2004
thanks. it looks to be a great resource. John -------------- Original message -------------- > > Hi John, > I don't have the specifics, but I do know a great website where you can get > some information with great pictures of how to "Install Wingtip Lens". Randy > Pflanzer has a great website where he is buidling his F1 Rocket. If you go to > the site and look at his section on installing the wingtip lens, you'll get some > great information. Check it out. > > http://f1rocket.home.comcast.net/index.html > > Hope this helps..... > > Richard Hebert > RV-9A Empenage Complete > > -----Original Message----- > From: owner-rv9-list-server(at)matronics.com > [mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of > kerrjohna(at)comcast.net > To: rv9-list(at)matronics.com > Subject: RV9-List: wing tip lenses > > > > does anyone have suggestions/instructions for installing the clear lenses in the > point of the wing tip. If I had any they have been "misfiled". > > John Kerr > 90616, finishing wiring,assembly, etc pre-paint > > does anyone have suggestions/instructions for installing the clear lenses in the > point of the wing tip. If I had any they have been "misfiled". > > John Kerr > 90616, finishing wiring,assembly, etc pre-paint > > > > > > thanks. it looks to be a great resource. John -------------- Original message -------------- -- RV9-List message posted by: "Hebert, Richard" <RICHARD.HEBERT@T-MOBILE.COM> Hi John, I don't have the specifics, but I do know a great website where you can get some information with great pictures of how to "Install Wingtip Lens". Randy Pflanzer has a great website where he is buidling his F1 Rocket. If you go to the site and look at his section on installing the wingtip lens, you'll get some great information. Check it out. http://f1rocket.home.comcast.net/index.html Hope this helps..... Richard Hebert RV-9A Empenage Complete -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of kerrj ohna(at)comcast.net To: rv9-list(at)matronics.com Subject: RV9-List: wing tip lenses -- RV9-List message posted by: kerrjohna(at)comcast.net does anyone have suggestions/instructions for installing the clear lenses in the point of the wing tip. If I had any they have been "misfiled". John Kerr 90616, finishing wiring,assembly, etc pre-paint does anyone have suggestions/instructions for installing the clear lenses in the point of the wing tip. If I had any they have been "misfiled". John Kerr 90616, finishing wiring,assembly, etc pre-paint ________________________________________________________________________________
Subject: Engines
Date: Nov 24, 2004
I have about 200 hours on my RV-9A with a 160hp engine and the 79 pitch Senesenich prop. I settled on this option after reading Van's article in the forth issue, 2001, of the RVator on why not to use more than 160hp. I have developed the following numbers over the 200 hours and you may wish to use them in considering your final engine and prop choice. Full throttle at 8000' is 188 miles an hour and 2580 RPM. Not an area one would want to cruise at with the 2600 limit. Therefore, I cruse at 2450 and 180 miles an hour. At this power setting the true airspeed is maintained over a wide range of altitudes. I fly with a group of RV-6's (most with 180 HP and constant speed props). They say they have to reduce their power about 1"MP for me to stay up with them. A T-18 also flies with us and he and I have identical airspeed for the same RPM. I am based at an elevation of 5600' and on initial takeoff roll I get 2230 RPM. The initial climb is never less than 1000ft/min. With a normal range of 1000 to 1500 ft/min. Performance wise I am very happy with this combination and feel it was the right choice and does not exceed the designers limits. The one thing I am still working on is how to get it slowed down to the 100mph initial flap speed and not fly a very long pattern. The airplane is very clean and will gain speed very quickly if one lowers the nose just a little and you will not be able to get it to flap speed. A constant speed prop would be nice to help this flight dynamic. The trade off is the forward CG. If one does go to a constant speed prop you may wish to calculate the impact on the CG and plan accordingly. Dick ________________________________________________________________________________
Subject: RE:Engines
Date: Nov 25, 2004
I really appreciate everyone's input on engine/ props. Some great information and widely diverse opinions. Wayne Danville, Va ________________________________________________________________________________
Subject: Vert Stab...lighting?
Date: Nov 25, 2004
Happy Thanksgiving!!! I am getting ready to start on my VS and am reading ahead in the manual. I noticed that it stated I should include lighting or provisions for lighting prior to closing up with the rear spar. I was under the impression that I could hold off for a while until I plunged in to the lighting of the aircraft. What exactly should I be doing at this point? Does Van mean that I should just be sure to allow a straight shot opening to the upper fiberglass (which I will be doing much much later) or do I have to drop the cash and wire in my lighting package now? Also, do most of you install some kind tubing to later serve as conduit? Thanks as always. Will #91056 ________________________________________________________________________________
Date: Nov 25, 2004
Lighting can be done later.. tubing is a good idea, especially in the wings but not required in most places if you tie it well so as not to rub or move much. However we used tubing most places as it makes it easier to add things later if needed. We are at the engine stage and just now working on lights so you do not need to get in a huge rush yet but always good to think ahead as to how you will accomplish it when the time comes.. Good luck. -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of William Couvillon Subject: RV9-List: Vert Stab...lighting? Happy Thanksgiving!!! I am getting ready to start on my VS and am reading ahead in the manual. I noticed that it stated I should include lighting or provisions for lighting prior to closing up with the rear spar. I was under the impression that I could hold off for a while until I plunged in to the lighting of the aircraft. What exactly should I be doing at this point? Does Van mean that I should just be sure to allow a straight shot opening to the upper fiberglass (which I will be doing much much later) or do I have to drop the cash and wire in my lighting package now? Also, do most of you install some kind tubing to later serve as conduit? Thanks as always. Will #91056 ________________________________________________________________________________
Date: Nov 25, 2004
Subject: Re: Vert Stab...lighting?
You just need to decide where your going to locate your rear nav light, if your going to install one. The top of the vert stab or the rudder bottom are comon places to put them. Wherever you put them you will need to be sure you can accomodate wire. I put mine on the rear of the rudder bottom, put a disconnect at the front and then put spiral wrap around it until it passed throught the main spar of the vert stab. Dennis ________________________________________________________________________________
Date: Nov 27, 2004
Subject: Lister Comments - Please Support The Lists
Dear Listers, Wow! People have been including some very nice comments along with their Contributions lately! I've included another set of below and will send another set in a couple of days. Guys, I really appreciate your kind words and support. In the last few days, the contributions have really started to come in and its looking like support this year may slightly surpass last year's. There's still a few days left in this year's Fund Raiser, so if you've been waiting until the last minute to make your Contribution, now's the time! Make Your Contribution Today: http://www.matronics.com/contribution Thank you! Matt Dralle Email List Administrator ----------------- More of What Listers Are Saying... -------------------- Every morning 5:30 am, coffee and the "List". It's how I start my day. Robert G. The list is still my favorite aviation magazine. Roger H. Great resource, without the distraction of pop ups and ads! Douglas D. I look forward to my daily list reading almost as much as my coffee! Hal K. Great service! Aaron G. I have made some great friends, because of it! Bob D. Great resource!! Richard S. I learn something of value every time I read the messages. Stan S. Great list! Thomas E. Now that I am close to completion of my [homebuilt], I look back and wonder how I could ever have made it this far without [the Lists]. Jeff O. Outstanding site and administration. Anthony S. Great forum for our projects. Darrel M. I have become a List Addict! George M. A very helpful resource for me. Dennis K. Great for staying up on the latest. Forrest L. Valuable benefit for the users. George A. Great tool for all [builders]. Tony M. Can't tell you how much I appreciate the archives. Ken B. I really enjoy the sharing of information and the "discussions" that come up. Ross S. [The List] reminds us home builders that help is just a few clicks away. Danny W. A great resource! Christopher S. Always a pleasure to support this list! Richard W. Thanks for helping all of us build better aircraft. John P. Great list(s)for data, info and making friends. John S. [The] List has helped me much with my building process. Raimo T. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 28, 2004
clamav-milter version 0.80j on mail5.iserv.net My intention is a 160hp IO-320 with C.S. prop. The biggest reason? There are no rpm restrictions on the 320. When I fly, I don't want to have to remember what rpms aren't good for constant operation on the third Tuesday of months that end in "R", etc. I've seen the posts about true horsepower at 7,500 feet, but I'll settle for the lower power and go with Van's recommendation - he knows the plane more than I do. I live in lower elevations, so high-altitude take-off operations will be rare to non-existent. Doug ----- Original Message ----- From: "Wayne Williams" <rwayne(at)gamewood.net> Subject: RV9-List: Engines > > What engine are most thinking of using? I'm leaning towards an 0-360 180hp > fixed pitch. > Seems to me the extra 20hp (over the recommended 160hp) will make up for not > having a CS prop on climb. > > > Wayne > > > -- > Checked by AVG Anti-Virus. > > ________________________________________________________________________________
Subject: wheel fairings
Date: Nov 29, 2004
does anyone have some hints for getting the wheel pants in the right position? 1" spacer, joggle lined up with the bracket 808 and no way to get the middle of the trailing edge up to 8 5/8"....... does anyone have some hints for getting the wheel pants in the right position? 1" spacer, joggle lined up with the bracket 808 and no way to get the middle of the trailing edge up to 8 5/8"....... ________________________________________________________________________________
Date: Nov 29, 2004
From: "coolmate_04(at)cashette.com" <no-reply(at)cashette.com>
Subject: Re: wheel fairings
Dear Friend: Thank you for your email. Your message has not reached my Inbox because you are not yet on my Approved List. To reach my Inbox, please click on this link. When I respond to your message, you will be automatically added to my Approved List! Warm regards, coolmate_04(at)cashette.com __________________________ Note from Cashette: If you don't see any link above, copy and paste the link below to your browser: http://home.cashette.com/myCashette/newUser.do?ms=kerrjohna%40comcast.net&mr=coolmate_04%40cashette.com&rid=coolmate_04&sec=UHrF&dt=1101756882819 If you are a business, click Business. -----Original Message:----- From: kerrjohna(at)comcast.net Subject: RV9-List: wheel fairings __________________________ Cashette stops spam. 100% effective and free! Go to http://home.cashette.com ________________________________________________________________________________
Subject: The Skinny on LOE
Date: Nov 29, 2004
Well, after calling the Chamber of Commerce, Mayors Office, and other various city and airport offices, I think I finally got the skinny on why LOE is moving. Once again, it boils down to personalities and politics. I was told there is a personality conflict between Red and the owners of Adventure Aviation. Red decided to pull out. The details I was given do not bear repeating, but IMHO I think both parties should work out their differences, especially in light of the post on Doug Reeves site questioning the new facilities. I spoke with the staff of Adventure Aviation, who assured me they will be hosting and welcoming the fly-in again next year and hopefully in the years to come. They have already send out invitation cards to people who registered this past year, and are planning on sending out more cards in the future.. So LOE 2005 at Las Cruces is on! I hope this helps folks out. I was just a curious party. Glenn in Arizona -9A fuselage. ________________________________________________________________________________
Date: Nov 29, 2004
From: "dedgemon(at)knology.net" <dedgemon(at)knology.net>
Subject: Engines
Hi folks. Here are some more performance numbers for those who are interested. I've only flown about 15 hours on my new 9A but I'm starting to develop a feel for the performance. Yesterday I finally installed the main wheel pants and gear leg fairings. The nosewheel and leg are still bare. 8000' density altitude. Full throttle (21.5" MAP) and 2650 rpm resulted in 162 knots TAS. 8000' density altitude. Full throttle (21.5" MAP) and 2400 rpm resulted in 155 knots TAS. I saw a 10-12 knot increase by installing the mainwheel pants and gear fairings. I would guess that the nose gear pant and fairings would give me another 4-5 knots, so that'll put it at about 166-167 knots. I'm using an Aerosport O-320 D1A with a Hartzell prop. Empty weight is 1080 lbs. Loading for the above numbers was 1080 for the plane, 210 for the pilot, and 150 for the fuel. Initial climb rate for this setup at full throttle and 2650 rpm was 1900- 2000 fpm at 100 knots. At 25" and 2500 rpm I was seeing 1300-1400 fpm. ________________________________________________________________________________
Date: Nov 29, 2004
Hi "dedgemon(at)knology.net" Thanks for the numbers. Keep going and send us new and so good numbers. Is your O-320 D1A configured with high compression pistons? JC - Aracaju - Brasil RV-9A QB #90997 ________________________________________________________________________________
Subject: ProSeal curing?
Date: Nov 29, 2004
Fellow builders, I am sealing up my fuel tanks and wanted some information about curing time and temperature. When I began sealing (multiple day event) a cold front came in and the temperature dropped in the 50's during the day (shop temp around 60). Shop temp dropped during the night to low 50's I think. The next day it was a little warmer heated the shop a little (small electric heater) shop temp around 65. Nighttime temp mid 50's. Next day warmer still, nighttime temps mid 50's. Then rather cold again with nighttime temps below freezing, shop time overnight high 40's I think. During the sealing process (using cartridges) I would dispense about half the cartridge and refrigerate the remainder. About 2 to 3 hours later I would use the remainder stored in the refrigerator. As I mentioned I had several sealing sessions and am finding that the ProSeal is curing at different rates. Some are rather slow, some are faster. What have others experienced when it came to temperature and time? How long does it take to cure when experiencing the temperature swings like I have. I now am running the heater all night to keep the shop warmer. Paul ________________________________________________________________________________
Subject: Re-application of Proseal over Proseal
Date: Nov 29, 2004
Fellow builders, I am in the process of sealing my tanks and am ready to install the rear baffle. The inboard and outboard ribs when install/sealed a few days ago. After examining some of the filleting on the inside of the inboard and outboard ribs, I may want to add some additional sealant to increase the fillet in a few locations. What preparation other then cleaning with MEK/Acetone is recommended? Even though I worked in a open/ventilated shop, I inhaled way to many MEK and ProSeal fumes during the sealing process over the last week. Know wonder my Thanksgiving dinner tasted like ProSeal. Paul ________________________________________________________________________________
Date: Nov 30, 2004
JC, My O-320 is a stock D1A which is 160HP with 8.5:1 pistons. Nothing fancy except for ignition. I'm running one Slick impulse mag on the left side and a lighspeed electronic on the right side. ________________________________________________________________________________
Subject: Suggestion for drilling the hinge points in the tip-up canopy
frame.
Date: Nov 30, 2004
Take it for what it's worth.. but here is what I did to drill the hinge point hole in the WD-716 TIP-UP canopy frame. So you've done all the drilling of the plastic hinge blocks and have them in position. You have the tip-up frame in place with the C-702 skin cleco'd on. Now the instructions tell you to drill a 1/4" hole in the hinge point using the 1/4" hole in the blocks as a guide.. and to only drill enough to get the hole started... AND to use an angle drill to do it since you have limited access. Well.. I didn't have a threaded 1/4" bit to use with my angle drill and I didn't want to stick a normal bit in there and just mark it as that would leave room for error, so I had to get creative. What resulted is what I _think_ is a better way of drilling these holes. I bought a piece of 1/4" OD 4130 steel tube from the local airparts store with a wall thickness of .049. I then enlarged the ID hole to #19. I cut a ~1" piece off and then inserted that piece into the 1/4" hole already in the plastic block. Then I used my threaded #19 drill bit in the angle drill to drill a pilot hole. I did this to both sides then pulled the frame off and enlarged the holes to the correct size. (If you have a 3" bit, I would go ahead and drill all the way through, I can't see a reason not too. My short 1" bit wasn't getting the shavings out, so I only went deep enough to get a good start on the hole.) Using the short piece of pipe gives you a very accurate positioning of the drill bit without a chance of enlarging the hole in the plastic blocks. It also takes away any possible error if you had just marked the hole and drilled. Again, take it FWIW. Matthew RV-9A Finishing http://www.n523rv.com #90569 ________________________________________________________________________________
Subject: First Flight - N937RK
Date: Dec 05, 2004
First time builders, Ron and Kandy Murray our proud to announce that the first flight of their RV-9A, N937RK, serial number 90291, occurred on December 3, 2004 (12-3-4). It flew from Lake Norman Airpark, NC with 26,000 hour test pilot, Van Lawless at the controls. It was a beautiful 30 minute flight with over 20 fellow builders and neighbors watching. The flight was uneventful with only a slight heavy left wing reported. The airplane is complete with full paint and basic interior. It took us 3 years and 8 months to build the "slow build" for a total construction time of 2568 hours. The airplane is equipped with an Aero Sport Power O-320-D2A engine, turning a 70 by 80 Sensenich fixed pitch prop. The panel is equipped with full IFR gyros, an AOA, a full complement of Electronics International instruments, King KMD-150 color multiple function display, ICOM com, and Garmin transponder. The airplane in full dress weighed in at 1106 pounds. This is a day we have dreamed of, as we drove those rivets. It was an unbelievable sight to see our labor of love flying over our heads. Hang in there builders, your day will arrive before you know it! Ron Murray, Mooresville, NC ________________________________________________________________________________
Subject: empennage options
Date: Dec 05, 2004
I am about to place the order for the empennage. Please give some thoughts on the electric elevator trim option. Where is the control switch mounted? Tks Ron ________________________________________________________________________________
Date: Dec 05, 2004
Subject: Re: empennage options
Ron, I opted for the electric option. It costs a bit more, but is lighter and allows more options in mounting the control. The switch can be mounted almost anywhere, as long as it is in easy reach and not where it can be pressed accidentally. If you are tall (as I am,) the manual control can rub against your leg. Many prefer to have the trim on a "hat" switch on the control stick, usually one on each stick. I am going with a centrally mounted switch for ease of wiring. All in all, it is just a preference. I think I could live with either system. On 12/06/04, Ron Brown wrote: > > I am about to place the order for the empennage. Please give some thoughts > on the electric elevator trim option. Where is the control switch mounted? > Tks > Ron > ________________________________________________________________________________
Date: Dec 05, 2004
Subject: Re: First Flight - N937RK
Ron, Congratulations! May all your flights be as wonderful as that first flight. Sharing your joy is the engine of our passion. Bob Kelly, 90854 On 12/05/04, Ron Murray wrote: > > First time builders, Ron and Kandy Murray our proud to announce that the > first flight of their RV-9A, N937RK, serial number 90291, occurred on > December 3, 2004 (12-3-4). It flew from Lake Norman Airpark, NC with > 26,000 hour test pilot, Van Lawless at the controls. It was a beautiful 30 > minute flight with over 20 fellow builders and neighbors watching. The > flight was uneventful with only a slight heavy left wing reported. The > airplane is complete with full paint and basic interior. It took us 3 > years and 8 months to build the "slow build" for a total construction time > of 2568 hours. > > > The airplane is equipped with an Aero Sport Power O-320-D2A engine, > turning a 70 by 80 Sensenich fixed pitch prop. The panel is equipped with > full IFR gyros, an AOA, a full complement of Electronics International > instruments, King KMD-150 color multiple function display, ICOM com, and > Garmin transponder. The airplane in full dress weighed in at 1106 pounds. > > > This is a day we have dreamed of, as we drove those rivets. It was an > unbelievable sight to see our labor of love flying over our heads. Hang in > there builders, your day will arrive before you know it! > > > Ron Murray, Mooresville, NC > > > > > > > Regards -- ________________________________________________________________________________
Date: Dec 05, 2004
Congratulations. What a great accomplishment for you and your partner. Good Luck and Happy Flying! Dennis Thomas RV9 N164DV 145 hours ________________________________________________________________________________
Date: Dec 05, 2004
I am flying the 9 taildragger with electric trim. I did my transition training in the factory 9 taildragger and it has manual trim. They both work quite well and seemed easy enough to get used to. I think for actual ease of flying I like the manual better but also think the electric is lighter and far easier to install. Dennis Thomas RV9 N164DV 145 hours ________________________________________________________________________________
Date: Dec 05, 2004
The control switch is usually mounted on the control stick. However, I prefer to have a trim wheel between the seats a la Grumman. This can be accomplished by using Eric Jones's trim wheel that utilizes pulse width modulation to control a MAC servo. Check it out on his web site at www.perihelion.com Peter On 5 Dec 2004 at 19:04, Ron Brown wrote: > > I am about to place the order for the empennage. Please give some > thoughts on the electric elevator trim option. Where is the control > switch mounted? Tks Ron > > > advertising on the Matronics Forums. > > > > > ________________________________________________________________________________
Date: Dec 05, 2004
Congratulations Ron and Kandy...I can see those RV smiles clear out here in Arizona. Fly Safe... Bob Snedaker Fairings-Etc. bob@fairings-etc.com > > From: "Ron Murray" <Ronald_P_Murray(at)msn.com> > Date: 2004/12/05 Sun PM 05:38:11 EST > To: > Subject: RV9-List: First Flight - N937RK > > > First time builders, Ron and Kandy Murray our proud to announce that the first flight of their RV-9A, N937RK, serial number 90291, occurred on December 3, 2004 (12-3-4). It flew from Lake Norman Airpark, NC with 26,000 hour test pilot, Van Lawless at the controls. It was a beautiful 30 minute flight with over 20 fellow builders and neighbors watching. The flight was uneventful with only a slight heavy left wing reported. The airplane is complete with full paint and basic interior. It took us 3 years and 8 months to build the "slow build" for a total construction time of 2568 hours. > > > The airplane is equipped with an Aero Sport Power O-320-D2A engine, turning a 70 by 80 Sensenich fixed pitch prop. The panel is equipped with full IFR gyros, an AOA, a full complement of Electronics International instruments, King KMD-150 color multiple function display, ICOM com, and Garmin transponder. The airplane in full dress weighed in at 1106 pounds. > > > This is a day we have dreamed of, as we drove those rivets. It was an unbelievable sight to see our labor of love flying over our heads. Hang in there builders, your day will arrive before you know it! > > > Ron Murray, Mooresville, NC > > > > > > > ________________________________________________________________________________
From: "Joosten, Craig" <CJoosten(at)infiltratorsystems.net>
Subject: first flight N937RK
Date: Dec 06, 2004
Congratulations Ron & Kandy! Please keep us posted as you build hours. Craig Congratulations Ron Kandy! Please keep us posted as you build hours. Craig ________________________________________________________________________________
Date: Dec 06, 2004
Congratulations Ron, It only gets better from here! I hope to catch up to you down at Sun-N-Fun this year. Gary Newsted, 200 hours on the 9E and loving it more every flight. ________________________________________________________________________________
Date: Dec 06, 2004
perihelion.com domain is for sale. Is he out of business? plaurence@the-beach.net wrote: > >The control switch is usually mounted on the control stick. However, I prefer to have >a trim wheel between the seats a la Grumman. This can be accomplished by using >Eric Jones's trim wheel that utilizes pulse width modulation to control a MAC servo. > >Check it out on his web site at www.perihelion.com > > >Peter > >On 5 Dec 2004 at 19:04, Ron Brown wrote: > > > >> >>I am about to place the order for the empennage. Please give some >>thoughts on the electric elevator trim option. Where is the control >>switch mounted? Tks Ron >> >> >>advertising on the Matronics Forums. >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Dec 06, 2004
OOPS! Try http://www.periheliondesign.com/ On 6 Dec 2004 at 16:52, SkyKing wrote: > > perihelion.com domain is for sale. Is he out of business? > > plaurence@the-beach.net wrote: > > > > >The control switch is usually mounted on the control stick. However, > >I prefer to have a trim wheel between the seats a la Grumman. This > >can be accomplished by using Eric Jones's trim wheel that utilizes > >pulse width modulation to control a MAC servo. > > > >Check it out on his web site at www.perihelion.com > > > > > >Peter > > > >On 5 Dec 2004 at 19:04, Ron Brown wrote: > > > > > > > >> > >>I am about to place the order for the empennage. Please give some > >>thoughts on the electric elevator trim option. Where is the control > >>switch mounted? Tks Ron > >> > >> > >>advertising on the Matronics Forums. > >> > >> > >> > >> > >> > > > > > > > > > > > advertising on the Matronics Forums. > > > > > ________________________________________________________________________________
From: "Ernest Kells" <ernest.kells(at)sympatico.ca>
Date: Dec 07, 2004
As a daytime VFR pilot I am a fan of Van's "simple is better" thinking. I have only PTT buttons on the sticks. I would normally retrim after each throttle adjustment (take-off, landing, altitude change, etc). These are times when you don't like to look down to see what you are doing in the cockpit. Imagine how you hold a target pistol. When I am holding the throttle in the fingers of my right hand the pitch trim switch is just in front of my thumb. It is the only rocker switch beside switches that push (to prime), rotate (to dim), toggle (flaps), etc. Sitting in my cockpit making airplane sounds it seems very intuitive, every time. Requires no hand movement. ----- Original Message ----- From: <plaurence@the-beach.net> Subject: Re: RV9-List: empennage options > > The control switch is usually mounted on the control stick. However, I prefer to have > a trim wheel between the seats a la Grumman. This can be accomplished by using > Eric Jones's trim wheel that utilizes pulse width modulation to control a MAC servo. > > Check it out on his web site at www.perihelion.com > > > Peter > > On 5 Dec 2004 at 19:04, Ron Brown wrote: > > > > > I am about to place the order for the empennage. Please give some > > thoughts on the electric elevator trim option. Where is the control > > switch mounted? Tks Ron > > > > > > advertising on the Matronics Forums. > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 07, 2004
Subject: EZ Pilot servo wing installation
I=92m installing an EZ Pilot servo in my right wing tip, attached to the last rib inside the wing tip. I=92m trying to figure out how to get from the small rodend at the servo to a rodend that will attach to the push-pull tube bolt, =BC=94. If someone has been there before and can give me the tubing sizes it would save me a lot of time trying to figure out what tube with what wall thickness will fit into the next tube etc. Maybe I=92m looking at this wrong. Thanks in advance. Roger Ping 90869 working: fuselage, wings, installations=85etc. ________________________________________________________________________________
Subject: bearing grease
Date: Dec 07, 2004
Has anyone had problems with wheel bearing grease being too thick? I assembled my wheels last night and used a grease I had on hand labeled "High temp disk brake bearing grease". It seeemed a little thicker than the stuff that was on the main wheel bearings as delivered. At any rate I assembled the wheels and they seems fairly hard to turn. The wheels all turn smoothly but, It takes at least a few pounds of force on the tire to start them in motion and there is definitely no "free-wheeling". Are everyones wheels this stiff or is it just b/c I used thicker grease??? ________________________________________________________________________________
Subject: Trim Cable
Date: Dec 07, 2004
Has anyone seen a trim wheel system installed in an RV ala cessna, piper instead of the vernier control? ________________________________________________________________________________
Subject: Fuel tank to main skin gap?
Date: Dec 07, 2004
Fellow builders, I just placed my finished left fuel tank (RV-7A) on my wing and noticed a gap between the aft edge of the tank skin and the forward edge of the main skins on my wing (top and bottom gap equal). I opted to wait to match drill and dimple the leading edge junction until after sealing the tanks. I have measured the edge distance of the screw holes in the tank skin and compared this to the center distance from the nutplate holes (countersinked) to the forward edge of the main tank skins, both are 5/16". So what this means is that there is a buildup of tolerances or ProSeal that is pushing the tank forward slightly. I would say that the gap is approximately 0.040. However the tank to leading edge junction (at the nose) is pretty much of a perfect match. So the screw holes in the tank don't line up with the nutplates perfectly. I was generous with "buttering" the ProSeal on both the "Z" bracket and tank rib aft flanges but not over generous. I know there is a very thin layer of ProSeal that maybe contributing to this gap, but not that much. When I built my RV-4 (old school) you could line everything up without any gaps because you put all the hole. With the match punched, you can't adjust things at all. What have other experienced after mounting the tanks. Paul (RV-4/RV-7A) ________________________________________________________________________________
Subject: RE: Trim Cable
Date: Dec 08, 2004
I've seen a picture somewhere on some RV builders website that had a trim system in it. I can't remember where I saw it but if I do, I'll post it. In the meantime, you might be able to get this mechanism to work for you. http://www.aircraftspruce.com/catalog/elpages/ranstrimsys.php Matthew Brandes, Van's RV-9A (Finish Kit) EAA Chapter 868/91/1329 www.n523rv.com <http://www.n523rv.com/> ________________________________________________________________________________
Subject: RE: EZ Pilot servo wing installation
Date: Dec 08, 2004
Roger, I would email Trio Avionics and ask them. I asked them about mounting it in the wing itself near the bellcrank and they sent me some pictures of the installation in an RV-7. I'm sure they'll tell you what sort of hardware you need for mounting it in the wing-tip, since this is a common location. Matthew Brandes, Van's RV-9A (Finish Kit) EAA Chapter 868/91/1329 www.n523rv.com <http://www.n523rv.com/> ________________________________________________________________________________
Subject: Subaru Performance
Date: Dec 09, 2004
From: "Bruce Anthony" <bruce.anthony(at)holidaycompanies.com>
Anyone with a Subaru care to give us a status report on your numbers? Fuel consumption, package type, maintenance costs, unexpected issues? I'd rather here it from you than the manufacturers. I'm thinking engines now, and I liked the NSI package (Eggenfellner, too) at Oshkosh, but I'm still wondering. Bruce Anthony RV-9A, Wings Rosemount, MN ________________________________________________________________________________
Subject: f6111
Date: Dec 09, 2004
can anyone help me with the fitting and installation of the F6111 rear deck stiffeners. I can't find a manual reference and the notation on the drawing of using prepunched holes in skin as guide doesn't help with regard to adjusting the length for proper fit. John Kerr, getting to the final fit and finish can anyone help me with the fitting and installation of the F6111 rear deck stiffeners. I can't find a manual reference and the notation on the drawing of using prepunched holes in skin as guide doesn't help with regard to adjusting the length for proper fit. John Kerr, getting to the final fit and finish ________________________________________________________________________________
Date: Dec 09, 2004
Subject: Re: Subaru Performance
Take a look at the archives on subaruaircraft(at)yahoogroups.com. There has been a lot of discussion lately regarding performance. Also look at the "NEW" page on www.eggenfellneraircraft.com where actual results are posted. Dick Tasker Bruce Anthony wrote: > >Anyone with a Subaru care to give us a status report on your numbers? Fuel consumption, package type, maintenance costs, unexpected issues? I'd rather here it from you than the manufacturers. > >I'm thinking engines now, and I liked the NSI package (Eggenfellner, too) at Oshkosh, but I'm still wondering. > > >Bruce Anthony >RV-9A, Wings >Rosemount, MN > > > > ________________________________________________________________________________
Date: Dec 09, 2004
Subject: Re: f6111
This comes up periodically. You can search the archives for one. I have attached an answer I gave a few months ago. Additionally I have pictures I can send but do you have broadband or dialup? Previous comments: I just went through this (and have purchased two new to replace the ones I cut too much!). Basically, there were NO instructions in my plans (RV9A). I called Van's and they sent me a single sheet printout that had more info, but still no guidance. Basically, you only have to cut a small amount from the top section so it fits against the baggage bulkhead. Draw a line in the center of the part where the holes will be drilled and start at the bottom drilling and clecoing. The bottom section (next to the longeron) does not get trimmed (unless you need to snip a bit from the flange so the part doesn't rub the longeron. When you get near the top, the end should fit under the skin so it shares one rivet with the skin/bulkhead. Carefully trim a little from the rear flange and possibly from the main section bit-by-bit until it will go under the skin and allow you to drill the last rivet with the skin/bulkhead. The trick is to trim just a little at a time. The first one I did, was horrible (since I had no idea how to proceed). The second was pretty good (could have been a little better but was acceptable). Since I had to replace one, I just bought them both and will replace them both now that I know how to do it. Dick Tasker P.S. They came out great this time! kerrjohna(at)comcast.net wrote: > >can anyone help me with the fitting and installation of the F6111 rear deck stiffeners. I can't find a manual reference and the notation on the drawing of using prepunched holes in skin as guide doesn't help with regard to adjusting the length for proper fit. > >John Kerr, getting to the final fit and finish > >can anyone help me with the fitting and installation of the F6111 rear deck stiffeners. I can't find a manual reference and the notation on the drawing of using prepunched holes in skin as guide doesn't help with regard to adjusting the length for proper fit. > >John Kerr, getting to the final fit and finish > > ________________________________________________________________________________
From: Michael Schipper <mike(at)learningplanet.com>
Subject: Re: f6111
Date: Dec 09, 2004
John, I had trouble with mine as well, and I was fortunate to have someone else send me some pictures, so hopefully I can help you out. I documented my installation at the following page: http://www.my9a.com/fuse10.asp#111104 Hope this helps, Mike Schipper www.my9a.com On Dec 9, 2004, at 10:09 AM, kerrjohna(at)comcast.net wrote: can anyone help me with the fitting and installation of the F6111 rear deck stiffeners. I can't find a manual reference and the notation on the drawing of using prepunched holes in skin as guide doesn't help with regard to adjusting the length for proper fit. John Kerr, getting to the final fit and finish can anyone help me with the fitting and installation of the F6111 rear deck stiffeners. I can't find a manual reference and the notation on the drawing of using prepunched holes in skin as guide doesn't help with regard to adjusting the length for proper fit. John Kerr, getting to the final fit and finish ________________________________________________________________________________
Date: Dec 09, 2004
Subject: Re: bearing grease
Bryan, I'm just finishing up my 9-A and had the very same problem with especially the nose wheel, but to a lesser extent the main wheels. I spoke to Ken at Van's who said "they'll loosen up after a while," but still doesn't seem quite right to me. So you're not alone. Bill McBride #90802 Bryan Flood wrote: Has anyone had problems with wheel bearing grease being too thick? I assembled my wheels last night and used a grease I had on hand labeled "High temp disk brake bearing grease". It seeemed a little thicker than the stuff that was on the main wheel bearings as delivered. At any rate I assembled the wheels and they seems fairly hard to turn. The wheels all turn smoothly but, It takes at least a few pounds of force on the tire to start them in motion and there is definitely no "free-wheeling". Are everyones wheels this stiff or is it just b/c I used thicker grease??? ________________________________________________________________________________
Date: Dec 10, 2004
Subject: Re: f6111
John, My kit didn't come with instructions either, but here is what I did. First, I traced the shape of the F-6111 onto the back of a regular office file folder and made a template. After cutting out the template, I placed it against the skin and tried to figure out which part of the curve in the template most closely matched the contour of the skin. I then marked a few spots on the template to indicate where a few of the pre-punched holes in the skin would meet the F-6111. Next, I folded the paper template at each end to simulate the spots where I would cut the F-6111. I then took the paper template and laid it back on the actual F-6111 and marked the spots where I thought it should be cut. I then double-checked my measurements and cut the F-6111. Next, I match-drilled the holes. As others have mentioned, I then had to do some "trial and error" grinding to get it to fit exactly the way I wanted it. I ended up using the portion of the F-6111 that is between the tooling holes. I believe that some builders have made the F-6111 a little longer than mine and they have one of the tooling holes in the finished part. My F-6111 starts about 1/8" above the longeron, but it does not overlap the flange of the F-706 bulkhead. I tapered the flange of the F-6111 so it rests next to the F-706 flange. It took longer than I expected, but I'm happy with the results. Hope this helps, Mark ________________________________________________________________________________
Subject: Elevator balance
Date: Dec 12, 2004
Now they are painted the elevator with the electric trim in it is tail heavy. Is it important they are balanced individually, or just as a pair since they effectively become one? Thanks, Steve. #90360 --- ________________________________________________________________________________
Date: Dec 12, 2004
Subject: Re: Elevator balance
Hi Steve, I've not heard this discussed before but my elevators are balanced as a pair. If they were disconnected they would definitely not balance. My airplane is flying just fine. Dennis Thomas 90164 145 hours ________________________________________________________________________________
Date: Dec 14, 2004
Dave - thanks for that. I was expecting (hoping) for a bit more response. Steve #90360 PS 145 hours in how many months!? -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of DThomas773(at)AOL.COM Subject: Re: RV9-List: Elevator balance Hi Steve, I've not heard this discussed before but my elevators are balanced as a pair. If they were disconnected they would definitely not balance. My airplane is flying just fine. Dennis Thomas 90164 145 hours --- ________________________________________________________________________________
Date: Dec 13, 2004
First flight was Feb 20 this year. Keep hacking because you are building a great little airplane. Dennis ________________________________________________________________________________
Date: Dec 14, 2004
Steve, If you mean the airplane is tail heavy in flight, you can adjust this by shimming the front of the vertical stab. Adjust it so that the elevator is neutral when you are straight and level. You will notice that the front mount for the VS is designed so that this is quite easy. Don't go more that .020 inch at a time. If you mean the static balance of the elevator, paint could upset this a bit. There is more elevator surface area on the trail side of the hinge. Therefore more paint, more weight. Static balance is easily corredted by adding or removing more weight. The balance of the elevator, if I understand correctly is mostly to prevent flutter. A slight imbalance should not have much of an effect at all in flight. The effect of gravity on an elevator travelling at 100 KTS is negligible compared to the aerodynamic forces. If both elevators are static balanced individually, then the pair will be static balanced when tied together. However on another pair, one could be heavy on the leading side, the other equally heavy on the trailing side and both would balance out as a pair. They would not balance individually. Which is better? I don't know for sure, but I don't think it matters much at all. I balanced mine individually, and it took no adjustments when they were tied together as one. And it flys just fine.... REALLY fine. Dale > Now they are painted the elevator with the electric trim in it is tail > heavy. Is it important they are balanced individually, or just as a pair > since they effectively become one? > Thanks, Steve. > #90360 ________________________________________________________________________________
Date: Dec 14, 2004
Subject: Re: Trim Cable
Try Eric Jones' site at http://www.periheliondesigns.com He has a trim wheel that can control a MAC or RAC servo so that the only connection is two 22ga wires. Peter ----- Original Message ----- From: "D.Munz" <182ppl(at)comcast.net> Subject: RV9-List: Trim Cable > > Has anyone seen a trim wheel system installed in an RV ala cessna, piper > instead of the vernier control? > > > ________________________________________________________________________________
Date: Dec 14, 2004
Actually you would do better to use http://www.periheliondesign.com (no "s"). ;-) Dick Tasker Peter Laurence wrote: > >Try Eric Jones' site at http://www.periheliondesigns.com > >He has a trim wheel that can control a MAC or RAC servo so that the only >connection is two 22ga wires. > >Peter > > > ________________________________________________________________________________
Date: Dec 18, 2004
Subject: [ Jim Jewell ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Jim Jewell Subject: RV6-A lower cowl engine air intake seal http://www.matronics.com/photoshare/jjewell@telus.net.12.18.2004/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject: Has anyone put an 0-290 in a RV9/9A?
Date: Dec 18, 2004
New to the list and I'm curious if anyone has put an 0-290 in for power? Suggestions? Regrets? Experiences? All responses appreciated. ________________________________________________________________________________
Date: Dec 19, 2004
Greg, I have an O-290 that that will power my -9. I did talk to a gentleman in Canada two weeks ago who built a -9A with this engine. (It is now for sale in trade-a-plane due to a change in interest, read: antique car restorations.) He spoke VERY highly of the combination and really appreciated the cruise / GPH factor. He was truing at 170 mph (true) with the low fuel burn of the -290. BTW, this was his second RV, the first being a -320 powered -6 and he thought the -9A was a superior aircraft. The prop he used was a 70" by 70" Colin Walker wood prop. There are some comments from him on the "Things to Consider" page of my web site, http://www.repucci.com/bill/things_to_consider.html. I got a great deal on the -290 but it will need to have the accessory case changed to one that can use a fuel pump, these are O-235 parts so they are readily available, they just take time and money. I expect to start pulling my engine apart in a few months so I will know more about the conversion then. Bill RV-9 SN: 90737 Fuselage N941WR (Reserved) -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Greg Bartel Subject: RV9-List: Has anyone put an 0-290 in a RV9/9A? New to the list and I'm curious if anyone has put an 0-290 in for power? Suggestions? Regrets? Experiences? All responses appreciated. ________________________________________________________________________________
Subject: Subject: Engines-List: Another O-290 for sale
Date: Dec 19, 2004
I posted this on the engines list and then figured why not spread it around. Call me if you need any more info. --> Engines-List message posted by: "Rob W M Shipley" Ron wrote: "If our friend still has it, there is a steal on a 0-290 that has been rebuilt by a professional aircraft engine builder. Dyno tested @ 140 HP. It is a certified engine and the last asking price was $10,000. If interested, email Ron at rgdplg(at)radiowire.net" I too have an O-290 which I decided to sell. Please note this is not a certified engine. I bought this from a fellow Chapter 14 club member. It was used until fairly recently in his Tailwind and reportedly has about 65 hours on it since a full rebuild. It was removed when he decided to change to a Jabiru in the hopes (vain) of getting more performance. It comes complete with several spares and engine manuals. There is also a prop and spinner which I am willing to sell with it. It has been filled with 30 weight oil and the bores wiped with STP whilst I have had it. I live in the San Diego area but would be willing to deliver up to a couple of hundred miles. I am asking for $6,000 with the prop and spinner and $5,600 for just the engine. Buyer to pay s & h if required. For any more information please feel free to call me directly at 619 916 8059 or email robshipley(at)gmail.com . Rob Rob W M Shipley N919RV (res) Fuselage .....still! Now planning on a Mazda Renesis engine! Checked by AVG Anti-Virus. ________________________________________________________________________________
Subject: Dynon pitot
Date: Dec 21, 2004
After investigating a leak in the pitot line Dynon tell me not to worry since it has a drain built in and this is the leak. However it raises the issue as to how you test the pitot system if there is this leak, since it will disguise any other leak that may exist. What have others done? Thanks, Steve. #90360 PS One other thought, how much leakage can one have before it causes siginificant ASI errors? -- Checked by AVG Anti-Virus. ________________________________________________________________________________
Date: Dec 22, 2004
Subject: Re:Dynon pitot
Steve, I simply pressured up the pitot line and called it quits. A pitot leakage of this sort is found on many Piper aircraft such as the Warrior and Cherokee. When I performed a static test with a "calibrated" pressure source, read that as "homemade manometer", the Dynon read from 6% high to 2% low, while Van's analogue gauge read from three to five percent low. I wonder what the error will be in flight. Leland Installing the empennage >After investigating a leak in the pitot line Dynon tell me not to worry >since it has a drain built in and this is the leak. However it raises the >issue as to how you test the pitot system if there is this leak, since it >will disguise any other leak that may exist. What have others done? > >Thanks, Steve. >#90360 > >PS One other thought, how much leakage can one have before it causes >siginificant ASI errors? > > > ________________________________________________________________________________
Date: Dec 23, 2004
Leland, Understand the "homemade manometer," but would like to know where to get a chart of airspeed vs. inches H2O. Could you share that one? Thanks, Bob Kelly, fuse on main gear On 12/23/04, Leland wrote: > > Steve, I simply pressured up the pitot line and called it quits. A pitot > leakage of this sort is found on many Piper aircraft such as the Warrior > and Cherokee. When I performed a static test with a "calibrated" > pressure source, read that as "homemade manometer", the Dynon read from > 6% high to 2% low, while Van's analogue gauge read from three to five > percent low. I wonder what the error will be in flight. > Leland > Installing the empennage > >> After investigating a leak in the pitot line Dynon tell me not to worry >> since it has a drain built in and this is the leak. However it raises the >> issue as to how you test the pitot system if there is this leak, since it >> will disguise any other leak that may exist. What have others done? >> >> Thanks, Steve. >> #90360 >> >> PS One other thought, how much leakage can one have before it causes >> siginificant ASI errors? ________________________________________________________________________________
Date: Dec 23, 2004
Leland - thanks for the reply. I dont quite understand. Since the Dynon head has a leak I cant pressurise the line. Well I suppose if I had a constant flow of air I could, but the leakage is not insignificant. Do you mean that you had a long loop of manometer so you kept raising one end as the pressure dropped? Did the 'calibrated' source supply air continuously? I am really puzzled about this. Since it is a drain according to Dynon it must leak quite a bit to pass water. Happy Christmas, Steve. PS It sounds as though we continue to be at abount the same point. I have ben fitting the empenage and general snags prior to pushing it into the hanger for the wings. -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of Leland Subject: RV9-List: Re:Dynon pitot Steve, I simply pressured up the pitot line and called it quits. A pitot leakage of this sort is found on many Piper aircraft such as the Warrior and Cherokee. When I performed a static test with a "calibrated" pressure source, read that as "homemade manometer", the Dynon read from 6% high to 2% low, while Van's analogue gauge read from three to five percent low. I wonder what the error will be in flight. Leland Installing the empennage >After investigating a leak in the pitot line Dynon tell me not to worry >since it has a drain built in and this is the leak. However it raises the >issue as to how you test the pitot system if there is this leak, since it >will disguise any other leak that may exist. What have others done? > >Thanks, Steve. >#90360 > >PS One other thought, how much leakage can one have before it causes >siginificant ASI errors? > > This email has been scanned by the MessageLabs Email Security System on behalf of the London Business School community. For more information please visit http://www.messagelabs.com/email -- Checked by AVG Anti-Virus. -- Checked by AVG Anti-Virus. ________________________________________________________________________________
Subject: F-661EF flap bearing block
Date: Dec 24, 2004
I need to fabricate the F-661EF flap bearing blocks but can't find the .750 UHMW plastic blocks they are made from. My packing list does not have them under item number or description. Anyone else who has run into this and could help out I would appreciate it. Thanks and Merry Christmas ________________________________________________________________________________
Subject: Re: F-661EF flap bearing block
Date: Dec 24, 2004
Look in the bag marked RV-6 Common Bag. It is a larger sealed bag with misc. parts. I just went through this with Vans, it is a frequent question they get. Hope this helps. Glenn in Arizona -9A fuselage. ----- Original Message ----- From: "K.Wilson" <fr8dawg8(at)cinci.rr.com> Subject: RV9-List: F-661EF flap bearing block > > I need to fabricate the F-661EF flap bearing blocks but can't find the .750 UHMW plastic blocks they are made from. My packing list does not have them under item number or description. Anyone else who has run into this and could help out I would appreciate it. Thanks and Merry Christmas > > ________________________________________________________________________________
Date: Dec 24, 2004
Try looking in the Flap motor actuator parts bag ----- Original Message ----- From: K.Wilson To: rv9-list(at)matronics.com Sent: Friday, December 24, 2004 2:41 PM Subject: RV9-List: F-661EF flap bearing block I need to fabricate the F-661EF flap bearing blocks but can't find the .750 UHMW plastic blocks they are made from. My packing list does not have them under item number or description. Anyone else who has run into this and could help out I would appreciate it. Thanks and Merry Christmas ________________________________________________________________________________
Date: Dec 25, 2004
Subject: Re: Re: Re:Dynon pitot
Steve, when I tested my Dynon it was without the pitot tube in the circuit. I simply pressurized the line going to the control panel. I also wondered if the Dynon accounted for the air leak in the pitot, and that is one reason why I did the pressure test. I noticed that the Dynon and my Van's analogue gauge differed in readings. I called Dynon and was assured that everything would work out, but I am not yet reassured. Van's gauge reads some 4-8 mph high over the range of 117 to 199 mph, and the Dynon reads low by 4-5 mph over the same range. It seems that a leaky pitot tube would read even lower. And yes, my manometer was simply the tubing leading to the Dynon. (When I started pressure testing, I found a lot of leaks in the connections, and in the static system too. Upon advice from two different pitot/static calibration shops, I used the high quality threaded connectors from the likes of Wick's and ACS rather than the cheap barbed connectors sold by Van's. There was a fatal accident due to a low-altitude stall in an RV6 in Florida some two years ago. The builder's friend conjectured that this accident occurred because the RV had a leaky pitot/static system.) Bob, assuming the airspeed gauges were calibrated at 29.92 inches of mercury and 20 degrees Celsius, the airspeed in mph can be calculated by multiplying the square root of the difference in meniscus height, measured in inches, by the value 45.43. For other conditions, the airspeed can be calculated by the formula: AirSpeed =SquareRoot[2*WaterMassDensity*Gravity*WaterColumnHeightDifference/AirMassDensity], where the value of AirMassDensity can be gotten from the CRC Handbook of Chemistry and Physics. If you want more detail, I could email you a copy of my Excel spreadsheet. Leland Installing the empennage and elevator control tubes (getting the washers in is a bitch) > > ________________________________________________________________________________
Date: Dec 25, 2004
Leland, Thanks for the formula. I knew 5" H2O was around 100 mph and have used a monometer to compare instruments in the past, but didn't know anything beyond that. The spreadsheet should be a help if it isn't too much trouble. mmpi at missionmedia.org I used REALLY stiff grease to hold the washers in place on the control tubes. Almost tar-like. You might try something like that, safer I feel than the super-glue I hear some people use while assembling them. Still, it is trial and error. If you don't have any really stiff grease, try sitting a tub of wheel bearing grease on the top shelf with the top ajar for 15 years or so. Don't ask how I know! Thanks, Bob Kelly, 90854 > Bob, assuming the airspeed gauges were calibrated at 29.92 inches of > mercury and 20 degrees Celsius, the airspeed in mph can be calculated by > multiplying the square root of the difference in meniscus height, measured > in inches, by the value 45.43. For other conditions, the airspeed can be > calculated by the formula: AirSpeed > =SquareRoot[2*WaterMassDensity*Gravity*WaterColumnHeightDifference/AirMassDensity], > where the value of AirMassDensity can be gotten from the CRC Handbook of > Chemistry and Physics. If you want more detail, I could email you a copy > of my Excel spreadsheet. > > Leland > Installing the empennage and elevator control tubes (getting the washers > in is a bitch) ________________________________________________________________________________
From: "Steve Sampson" <SSampson.SLN21(at)london.edu>
Date: Dec 27, 2004
Leland - I tend to degrease washers with MEK and then attach a 'wing' of masking tape on one side to hold them by as I push the bolt through. When the bolt is through I yank hard on the tape. It works most of the time for me. Steve. PS Then introduce some oil/grease to make up forwaht was removed. -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of Leland Subject: RV9-List: Re: Re: Re:Dynon pitot .................... Leland Installing the empennage and elevator control tubes (getting the washers in is a bitch) > -- Checked by AVG Anti-Virus. ________________________________________________________________________________
Date: Dec 28, 2004
Subject: Re:Re: Re: Re:Dynon pitot
Steve, sounds like a useful trick. Bob Kelly suggested holding the washer on with stiff grease. For the last batch, I made a washer holder from 032 aluminum and kept trying until it worked. I suppose the best way would be for me to cough up $43 for a "washer wrench": http://www5.mailordercentral.com/clevtool/prodinfo.asp?number=WWR4&variation=&aitem=3&mitem=3 Leland >Leland - I tend to degrease washers with MEK and then attach a 'wing' of >masking tape on one side to hold them by as I push the bolt through. When >the bolt is through I yank hard on the tape. It works most of the time for >me. Steve. > >PS Then introduce some oil/grease to make up for what was removed. > > > > > ________________________________________________________________________________
Date: Dec 28, 2004
Isn't that the type of thing Santa is supposed to give you? Or at least your in-laws, in my case? BTW, they are a buck cheaper from Avery's. Bill RV-9 www.repucci.com/bill/baf.html Working on the fuselage and still stunned by the tools my in-laws gave me for Christmas. Not to mention the two days my Father in-law spent driving rivets with me over Thanksgiving. -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Leland Subject: RV9-List: Re:Re: Re: Re:Dynon pitot Steve, sounds like a useful trick. Bob Kelly suggested holding the washer on with stiff grease. For the last batch, I made a washer holder from 032 aluminum and kept trying until it worked. I suppose the best way would be for me to cough up $43 for a "washer wrench": http://www5.mailordercentral.com/clevtool/prodinfo.asp?number=WWR4&varia tion=&aitem=3&mitem=3 Leland >Leland - I tend to degrease washers with MEK and then attach a 'wing' >of masking tape on one side to hold them by as I push the bolt through. >When the bolt is through I yank hard on the tape. It works most of the >time for me. Steve. > >PS Then introduce some oil/grease to make up for what was removed. > > > > > ________________________________________________________________________________
Subject: H2AD modifications
Date: Dec 28, 2004
Merry Christmas to every one! What a surprise it was to find that my certified H2AD (1200 since major, with log books), would result in a 2 to 4 inch bump on the cowling, require minor modifications to the baffles, special engine mounts, (comes at no extra charge with finishing kit), and a modified exhaust system. I did not like that! Now, I am going to sell this engine, and buy a new one. I have checked with Van's and Vetterman's, they said the engine mount, and exhaust system will fit their new D1A. This is a good thing for me. The message to the group is to think ahead and decide if you can live with these types of modifications. A lot of builders willingly trade the bump on the cowling in order to save thousands of dollars. Nice thing about the RV is you can change your mind. Bill, in Canada, finishing and FWF C-GDRJ ________________________________________________________________________________
Date: Dec 28, 2004
Subject: Re: H2AD modifications
Bill, My tech counselor has the same engine in his -6. He removed the engine driven fuel pump and went with 2 electric fuel pumps and does not have the cowl bumps. Tad Sargent Sargentclt(at)CS.com RV7A ________________________________________________________________________________
Date: Dec 28, 2004
Subject: Performance numbers
For those of you sitill building, I thought a few performance numbers might be of interest. I took these yesterday while flying off my 40 hours. The conditions are as follows. RV-9A, O-320 D1A, Hartzell prop, empty weight 1080 3/4 fuel + 210 lbs pilot + 20 pounds of god knows what else = 1472 lbs Main gear pants and fairings installed, nose wheel and leg still bare (to lazy to finish it) At each altitude I paused long enough for the airplane to accelerate and stablized then leaned to ~ 50 deg ROP. 8500 msl 8340 DA 2 deg. C OAT 2400 rpm @ 22.1 MAP (Wide Open Throttle) EGTs 1364 1285 1321 1291 spread = 79 CHTs 347 358 352 338 spread = 20 156 knots TAS Note that if 2650 rpm is used here we see 162 knots TAS for roughly 75% power 10500 msl 10420 DA -1 deg. C OAT 2400 rpm @ 20.4 MAP (Wide Open Throttle) EGTs 1336 1265 1291 1262 spread = 74 CHTs 337 333 336 325 spread = 12 154 knots TAS climb rate at 10500 ~ 1200 fpm 12500 msl 12370 DA -5 deg. C OAT 2400 rpm @ 19.0 MAP (Wide Open Throttle) EGTs 1310 1229 1247 1228 spread = 82 CHTs 343 330 339 325 spread = 18 151 knots TAS climb rate at 12500 ~ 1000 fpm ________________________________________________________________________________
August 23, 2004 - December 28, 2004
RV9-Archive.digest.vol-ap
