RV9-Archive.digest.vol-ar
April 17, 2005 - October 23, 2005
Date: Apr 17, 2005
Subject: [Please Read] Matronics Email Server Upgrade Complete!
Dear Listers, The upgrade of the Matronics Email Server can be considered complete at this time. All known issues related to the upgrade process have been resolved and email services are running normal. The Nightly Digest processing has not yet been tested and will wait for tonight's update. If you encounter any odd behavior with respect to the Matronics Email Server over the next few days, please contact me via email at dralle(at)matronics.com or if that fails try dralle(at)speakeasy.net. Thanks to everyone for being patient through this arduous process of a major system upgrade! Matt Dralle Email List Administrator At 12:37 PM 4/16/2005 Saturday, Matt Dralle wrote: >Dear Listers, > >I will be upgrading the Matronics Email Server this weekend. This >includes some hardware improvements - more memory, faster, more capable >processors - as well as a complete operating system upgrade from >scratch. I hope to have both the old system and the new system running at >the same time to minimize the actual impact of the upgrade. > >Hopefully there will be little actual downtime during the transition, but >a few posts may get lost in the shuffle. If you don't see your post show >up on the List in the normal amount of time (plus a little bit), then >please just try posting it again. > >Upgrading the Matronics Email Server operating system (from Redhat Linux >7.2 to Redhat Linux WS 4) is a sizeable undertaking and requires a great >deal of work to port all of the utilities, programs, and scripts over to >the new system. As I've already mentioned, both the old and new systems >will be on line at the same time, so interruption should be held to an >absolute minimal. You might see a couple of odd test messages during the >cut-over or other odd messages; please just ignore them. > >I have setup a new System Status Web Page that I will use to update List >Members on the current status of the email and web systems. Please refer >to it as often as you like: > > http://www.matronics.com/SystemStatus/ > > >Thank you for your continued support of the List Services at >Matronics! Its your yearly Contributions that make these major upgrades >possible! > >Best regards, > >Matt Dralle >Matronics Email List Administrator Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Re: Best location to mount strobe power supply in RV-7/9
Date: Apr 18, 2005
mounted mine behind the baggage bulkhead on the 729a bellcrank rib -------------- Original message -------------- > > I installed mine underneath the baggage floor (and fabricated an access > hatch). You can see the details at > > http://www3.telus.net/aviation/flying/RV-9A/photos/Electrical/Electrical_photos. > html > about half way down > > Vern Little > > Merems wrote: > > > > >Fellow RV builders, > > > >I am trying to determine the best location to mount my strobe power supply > (central supply) in my RV-7A. Any thoughts would be helpful. Pros and Cons. > > > >Thanks, > > > >Paul > > > > > > > > > > > > > > mounted mine behind the baggage bulkhead on the 729a bellcrank rib -------------- Original message -------------- -- RV9-List message posted by: rv-9a-online I installed mine underneath the baggage floor (and fabricated an access hatch). You can see the details at http://www3.telus.net/aviation/flying/RV-9A/photos/Electrical/Electrical_photos. html about half way down Vern Little Merems wrote: -- RV9-List message posted by: "Merems" Fellow RV builders, I am trying to determine the best location to mount my strobe power supply (central supply) in my RV-7A. Any thoughts would be helpful. Pros and Cons. Thanks, Paul > ; ________________________________________________________________________________
Subject: Elevator end-caps and trailing edge thickness
Date: Apr 20, 2005
10:27:15, Serialize by Router on slcnot1/SCT(Release 6.0.4|June 01, 2004) at 04/20/2005 10:27:17, Serialize complete at 04/20/2005 10:27:17, Itemize by SMTP Server on sctmnot9/SCT(Release 6.0.5|March 27, 2005) at 04/20/2005 12:27:17, Serialize by Router on sctmnot9/SCT(Release 6.0.5|March 27, 2005) at 04/20/2005 12:27:18, Serialize complete at 04/20/2005 12:27:18 I have a question about the fiberglass end-caps for the elevator. The thickness of the fiberglass at the trailing edge of the cap is significantly thicker than the trailing edge of the elevator where they meet up. Is it OK, or even desirable, to sand down the fiberglass so the trailing edge matches? Or will this make the fiberglass cap too thin and weak? Thanks, Bob Smith ________________________________________________________________________________
Subject: Re: Elevator end-caps and trailing edge thickness
Date: Apr 20, 2005
I had a similar question, although in the other direction - I ended up with the trailing edge of my aileron (same construction process) thicker than I'd expected. The advice I received from the group was that it made little or no difference. I think you can assume the same for the fiberglass tip of the elevator. You'll probably do more harm than good reducing its thickness. Best of luck ... __g__ > > > I have a question about the fiberglass end-caps for the elevator. The > thickness of the fiberglass at the trailing edge of the cap is > significantly > thicker than the trailing edge of the elevator where they meet > up. Is it > OK, or even desirable, to sand down the fiberglass so the trailing edge > matches? Or will this make the fiberglass cap too thin and weak? > > Thanks, > > Bob Smith > > > > > > > ________________________________________________________________________________
Date: Apr 20, 2005
autolearn=no version=2.63 Bob I had the same problem with mine. One of them was over 1/4" thick at the end and the other about 1/4". They looked really ugly. Also, the fit was not good - they were somewhat twisted. I used a dremel cut-off wheel (you could use a hack saw) to open up the trailing edge. I followed up the joint line about 4" and kept removing material until the trailing edge was an acceptable thickness - about 1/8". I used a structural adhesive compatable with fibreglass (Proform Structural Adhesive #PF704, flexible plastic repair kit - works well on FG) and rebonded the opened up joint. Make sure that there is no twist when rebonding. I also used the Proform to fill some nasty blemishes on the elevator tips. Don't sand the outside of the fibreglass, because the outside is gelcoat, which gives you a nice smooth finish. Hope this helps. Cliff, 9A wings/fuse Chase, BC - Original Message ----- From: "Bob Smith" <rvator(at)lindonnet.com> Subject: RV9-List: Elevator end-caps and trailing edge thickness > > I have a question about the fiberglass end-caps for the elevator. The > thickness of the fiberglass at the trailing edge of the cap is significantly > thicker than the trailing edge of the elevator where they meet up. Is it > OK, or even desirable, to sand down the fiberglass so the trailing edge > matches? Or will this make the fiberglass cap too thin and weak? > > Thanks, > > Bob Smith > > > -- > > -- ________________________________________________________________________________
Date: Apr 21, 2005
Subject: Dynon Magnetomer Calibration
Yesterday I taxied over to the airport compass rose and calibrated my Dynon D10A with remote magnetometer. After aligning and calibrating to each of the four principal directions, I was surprised and pleased to find that the calculated correction was only one degree. On taxing back to the hangar, the Dynon compass agreed with GPS readings to a degree or so. This was a surprise because I installed the magnetometer bracket with steel nutplates and screws. And it was mounted too close to a shoulder-harness cable. Leland Waiting for the FAA Registration Branch to catch up on paperwork ________________________________________________________________________________
Date: Apr 21, 2005
Subject: DAC x FAA
Hi Leland: Our similar FAA, we call it DAC (Departamento de Aviao Civil) charged me almost US$ 250,00 for taxes to create a airworthiness certificate and Nnumbers. Here, in Brasil, we need an approval from an enginneer specialized in aviation, and 50 hours flying in a restricted area in order to receive a definite airworthness certificate. These enginneer charged me US$700.00 plus air tickets from Rio de Janeiro to my workshop. He wants to assist the weight and balance task. JC - Aracaju - Brasil #90997 -9A QB engine http://websites.expercraft.com/jcmm/ ________________________________________________________________________________
Date: Apr 22, 2005
Subject: Centre section bolts
I'm at the stage of fitting the 904 centre sections together with the spacers to match-drill the bottom skin and the 904 H side plates. The problem is with the 7/16" bolts through the 904 centre sections being REALLY tight. I realize that these need to have a really snug fit, but these bolts seem to be too tight - I need to use a fairly heavy blow with the dead-blow hammer (soft face) to get these bolts to move, even with them oiled. I don't want to damage the bolts or the aluminum pieces. Any suggestions? Please. Cliff 9A wings/fuse Chase, BC ________________________________________________________________________________
Date: Apr 23, 2005
Subject: Re: RV9-List Digest:1 Msgs - 04/22/05
Cliff, When you riveted the 904-D L&R and the 904-C L&R to the 904 E&F parts, and you just clecoed the parts together and riveted without a bolt thru them, you may have a slight mis-alignment of the holes. Happened to me and others. Van's wasn't much help, so I took a step drill and very slowly and carefully, used it (by hand) as a reamer to trim the 904 D & C plate holes to line up with the 904 E&F holes. It doesn't take much, so go slow and do it by hand. No more hammering bolts in those holes for me. If this is still not clear let me know and I'll try to give you more info. James J Varney RV-7A Fuse > > I'm at the stage of fitting the 904 centre sections together with the spacers to > match-drill the bottom skin and the 904 H side plates. The problem is with > the 7/16" bolts through the 904 centre sections being REALLY tight. > > I realize that these need to have a really snug fit, but these bolts seem to be > too tight - I need to use a fairly heavy blow with the dead-blow hammer (soft > face) to get these bolts to move, even with them oiled. I don't want to damage > the bolts or the aluminum pieces. > > Any suggestions? Please. > Cliff 9A wings/fuse > Chase, BC > > > > > > > > > > > > > > > > > > > > > > > -- "More than anything else the sensation is one of perfect peace mingled with an excitement that strains every nerve to the utmost, if you can conceive of such a combination." -- Wilbur Wright ________________________________________________________________________________
Date: Apr 23, 2005
Be sure to lubricate bolts. --- "James J. Varney" wrote: > > > Cliff, > > When you riveted the 904-D L&R and the 904-C L&R to > the 904 E&F parts, > and you just clecoed the parts together and riveted > without a bolt thru > them, you may have a slight mis-alignment of the > holes. > > Happened to me and others. Van's wasn't much help, > so I took a step > drill and very slowly and carefully, used it (by > hand) as a reamer to > trim the 904 D & C plate holes to line up with the > 904 E&F holes. It > doesn't take much, so go slow and do it by hand. No > more hammering bolts > in those holes for me. > > If this is still not clear let me know and I'll try > to give you more info. > > James J Varney > RV-7A Fuse > > > > > > I'm at the stage of fitting the 904 centre > sections together with the spacers to > > match-drill the bottom skin and the 904 H side > plates. The problem is with > > the 7/16" bolts through the 904 centre sections > being REALLY tight. > > > > I realize that these need to have a really snug > fit, but these bolts seem to be > > too tight - I need to use a fairly heavy blow with > the dead-blow hammer (soft > > face) to get these bolts to move, even with them > oiled. I don't want to damage > > the bolts or the aluminum pieces. > > > > Any suggestions? Please. > > Cliff 9A wings/fuse > > Chase, BC > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > "More than anything else the sensation > is one of perfect peace mingled with > an excitement that strains every nerve > to the utmost, if you can conceive of such > a combination." > > -- Wilbur Wright > > > > browse > Subscriptions page, > FAQ, > > > > > > ________________________________________________________________________________
Subject: re: Centre section bolts
Date: Apr 25, 2005
Cliff, Use store bought 7/16" bolts when doing the initial fitting.. don't use the bolts that came with the kit as these are NAS close tolerance bolts and will require some force to get in. You only use these when you mate the wings for the final time. A lot of builders stick them in the freezer overnight to get them to shrink just a bit and then use some lubricant to put them in. Matthew Brandes, Van's RV-9A (Finish Kit) #90569 <http://www.n523rv.com/> http://www.n523rv.com EAA Chapter 1329 President EAA Chapter 868 Web Editor ________________________________________________________________________________
Date: Apr 25, 2005
NAS bolts into the spar. I used the NAS bolts - ordered 8 more - just to get the holes to open up a microscopic amount so that when it should be time to put the wings on it should not be too much of a hassle. My method was to use Boelube and press down on the bolts as I turned them back and forth with a wrench. I did not use a mallet except for those bolts that went in easily. I figure that the holes were machine to fit the NAS bolts however the anodizing process built up a layer of oxide which made the hole a hair smaller. By forcing the NAS bolt in with rotating motions, some of the oxide is stripped off thereby making the hole just a bit larger. Very unscientific but I believe it should enable me to get the bolts in more easily when putting the wings on. Michle RV8 Fuselage > -----Original Message----- > From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list- > server(at)matronics.com] On Behalf Of Matthew Brandes > Sent: Monday, April 25, 2005 3:59 PM > To: rv9-list(at)matronics.com > Subject: RV9-List: re: Centre section bolts > > > Cliff, > > Use store bought 7/16" bolts when doing the initial fitting.. don't use > the > bolts that came with the kit as these are NAS close tolerance bolts and > will > require some force to get in. You only use these when you mate the wings > for the final time. A lot of builders stick them in the freezer > overnight > to get them to shrink just a bit and then use some lubricant to put them > in. > > > Matthew Brandes, > Van's RV-9A (Finish Kit) > #90569 > <http://www.n523rv.com/> http://www.n523rv.com > > EAA Chapter 1329 President > EAA Chapter 868 Web Editor > > > > > ________________________________________________________________________________
Date: Apr 25, 2005
Subject: Re: re: Centre section bolts
autolearn=no version=2.63 Thanks, guys, for all the suggestions. Cliff ----- Original Message ----- From: <owner-rv9-list-server(at)matronics.com> Subject: RE: RV9-List: re: Centre section bolts > > NAS bolts into the spar. > > I used the NAS bolts - ordered 8 more - just to get the holes to open up a > microscopic amount so that when it should be time to put the wings on it > should not be too much of a hassle. > > My method was to use Boelube and press down on the bolts as I turned them > back and forth with a wrench. I did not use a mallet except for those bolts > that went in easily. > > I figure that the holes were machine to fit the NAS bolts however the > anodizing process built up a layer of oxide which made the hole a hair > smaller. By forcing the NAS bolt in with rotating motions, some of the oxide > is stripped off thereby making the hole just a bit larger. > > Very unscientific but I believe it should enable me to get the bolts in more > easily when putting the wings on. > > Michle > RV8 Fuselage > > > -----Original Message----- > > From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list- > > server(at)matronics.com] On Behalf Of Matthew Brandes > > Sent: Monday, April 25, 2005 3:59 PM > > To: rv9-list(at)matronics.com > > Subject: RV9-List: re: Centre section bolts > > > > > > Cliff, > > > > Use store bought 7/16" bolts when doing the initial fitting.. don't use > > the > > bolts that came with the kit as these are NAS close tolerance bolts and > > will > > require some force to get in. You only use these when you mate the wings > > for the final time. A lot of builders stick them in the freezer > > overnight > > to get them to shrink just a bit and then use some lubricant to put them > > in. > > > > > > Matthew Brandes, > > Van's RV-9A (Finish Kit) > > #90569 > > <http://www.n523rv.com/> http://www.n523rv.com > > > > EAA Chapter 1329 President > > EAA Chapter 868 Web Editor > > > > > > > > > > > > > -- > > -- ________________________________________________________________________________
From: "Steve Sampson" <SSampson.SLN21(at)london.edu>
Subject: Nose gear design
Date: May 02, 2005
I have read the March 10 letter on the 'letters and SB's' section of the VANS web site but really do not know what it is describing. Is it a larger wheel? It does not say that, but it does describe a larger axle / ground clearance. Can anyone enlighten me? (I would have thought the distance between the centre of the wheel and the ground was controled by its diameter!) A shame VANS did not see fit to invest in a plan. Has anyone got one? Can they scan it? Thanks, Steve. G-IINI #90360 -- ________________________________________________________________________________
Subject: Climb rates
Date: May 02, 2005
I was doing some of the flight tests we have to do here in the UK and I have some pretty reliable climb info which I thought I would share. I know I was very interested when I was building. #90360 RV9A O-320-E2D & electric c/s MT prop - 150hp Gross = 1617lbs 90mph climb 1635 fpm 100mph climb at 1645 fpm These seem slightly better than VANS numbers. That I cant explain but I think they are quite repeatable. I suspect best climb will turn out at 105 or 110mph. Below 90 it falls off badly. Ambient temp at surface 68F, climbs between 1000' and 3000' on 1013mb Speed? I still have no idea. Its harder to do accurately than I ever believed. Keep riveting, Steve. G-IINI -- ________________________________________________________________________________
Date: May 02, 2005
Subject: Re: RV9-List Digest:1 nose gear
Steve Van's letter addresses the distance between the NOSE STRUT AXLE and the ground, not the wheel axle. I happen to agree with Van's that you cannot design anything, especially a nose gear that is fool-proof and fail-proof. I've seen a lot of collapsed nose gears over the years and almost all were a result of pilot abuse. The most by far are bounced landings and the pilot allowed the nose to drop. And some where they just landed it on the nose. And of course there were a few where the pilot took a short excursion through a ditch or a frozen snow bank. A very small percentage were a result of linkage or unabused structural failure. Bob ________________________________________________________________________________
Date: May 02, 2005
Subject: IO-320; Catto props
I posted this to the general RV list but I thought I'd post here too -not sure how many 9 builders/flyers subscribe to the master list as well... (The first part concerns my vacillating between a 7/9 and why I decided on the 9.) First of all, for anybody who followed the thread, I did decide to go with the 9A over the 7. I was originally going to just put my order on hold until I got a chance to fly both the 7A and 9A but did enough research and got enough private mails from people on the list to convince me. And I'm never going to get the chance to fly either in IMC as a demo anyway. I sort of liked the possibility of sport aerobatics at some point but XC and especially IFR suitability and stability are much more important to me. Can't have everything. (It wasn't that I didn't know the differences between the 9 and the 7 - I did - but I guess I had convinced myself that since many ppl fly IFR in 6s/7s, I could too. And maybe I could, but I'd rather have the stable ride. Single-pilot IMC in my C-152 is demanding enough for me - I'd rather not increase the workload.) Going to the 9 is fitting, though, since seeing the 9A prototype at OSH 2000 was what initially inspired me to get my PPL. It was the first kitplane I ever wanted, and now I've come full-circle indeed. (I was almost embarrassed to call Van's again after just changing my order from a 10 to a 7A, but the girl laughed and said this is not terribly uncommon. They hadn't started putting together my QB kit.) Question regarding engines. I'm not at all sure I'd want to go FI (I'm trying to keep the costs down, since my panel is gonna cost a bundle, and I like the simplicity of the carb), but I noticed that Van's offers no FWF kit for the IO-320. I am sure there are those out there with FI 320s - how much of a pain was it? Where is your servo mounted? Are you using the stock cowl with the scoop? 2nd question: Experiences with the 3-bladed Catto prop? It looks to me like they make great stuff. I did search the archive and see some positive reports. I would be really interested in seeing numbers to compare to the 79 pitch Sensenich that Van's recommends. TIA. ________________________________________________________________________________
Date: May 02, 2005
Subject: [ Mike Holland ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Mike Holland Lists: RV-List,RV6-List,RV7-List,RV8-List,RV9-List,RV10-List Subject: Quickbuild Fuel Pickup Issue http://www.matronics.com/photoshare/hollandm@pacbell.net.05.02.2005/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: May 03, 2005
Bob, The issue is that it just does not handle soft ground very well with the small wheels. Perhaps somthing that is uncommon in the USA. I think you are mostly on formal runways. The drag is huge on the mains when you land on a soft dirt strip so with the stick against the rear stop the nosewheel soon comes down and there is nothing you can do. The drag is even huger on the nosewheel. It also makes takeoff poor since getting the nosewheel in the air is very dificult. Until you do there is a huge load on the small nosewheel since the aircraft probably has a negative angle of attack. Once you get the nosewheel airborn almost immeadiatly you are fklying. On tarmac I am sure, and in the air it is fantastic. the good news is that it is so easy to land so there is no reason to bounce. Steve. G-IINI -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of Bobdeva(at)aol.com Subject: RV9-List: Re: RV9-List Digest:1 nose gear Steve Van's letter addresses the distance between the NOSE STRUT AXLE and the ground, not the wheel axle. I happen to agree with Van's that you cannot design anything, especially a nose gear that is fool-proof and fail-proof. I've seen a lot of collapsed nose gears over the years and almost all were a result of pilot abuse. The most by far are bounced landings and the pilot allowed the nose to drop. And some where they just landed it on the nose. And of course there were a few where the pilot took a short excursion through a ditch or a frozen snow bank. A very small percentage were a result of linkage or unabused structural failure. Bob This email has been scanned by the MessageLabs Email Security System on behalf of the London Business School community. For more information please visit http://www.messagelabs.com/email -- -- ________________________________________________________________________________
Subject: OFF THE TOPIC: Young Eagle Credits
Date: May 10, 2005
From: "Nightingale Michael" <NightingaleMichaelV(at)JohnDeere.com>
"RV-9 LIST (RV-9 LIST)" FILETIME=[8811EFC0:01C55562] Our EAA chapter is sending three young men (we sent two young ladies last year) to the Advanced Aviation Air Academy during Airventure. If anyone has any YOUNG EAGLE CREDITS that are not spoken for PLEASE contact me OFF the list. In the last six year EAA Chapter 75 and the QCAA (Quad City Airmen's Association) has sent 12 young to the Air Academy. PLEASE help us continue introducing young people to General Aviation. This is the only thing the YOUNG EAGLE CREDITS can be used for; to help pay up to half the tuition for each attendee. Thank You Michael V. Nightingale @ DEERE & Co. Computer Center 400 19th ST MOLINE, IL. 61265 309-314-6806 cell NightingaleMichaelV(at)JohnDeere.com I fly because it releases my mind from the tyranny of petty things . . . Antoine de Saint-Exupry ________________________________________________________________________________
Subject: trim -manual- tab horns
Date: May 11, 2005
Hello All, Does anyone know the seize of the hole where the nylon clevis 1032 is attached. I want to drill this hole in the two horns before priming, painting and riveting them to the tab. Thanks. Jef in Belgium; 91031. ________________________________________________________________________________
Date: May 11, 2005
I was informed off list that the clevis pin is 1/8". Thanks. Jef. -----Oorspronkelijk bericht----- Van: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] Namens Jef Vervoort Verzonden: woensdag 11 mei 2005 10:39 Aan: rv9-list(at)matronics.com Onderwerp: RV9-List: trim -manual- tab horns Hello All, Does anyone know the seize of the hole where the nylon clevis 1032 is attached. I want to drill this hole in the two horns before priming, painting and riveting them to the tab. Thanks. Jef in Belgium; 91031. ________________________________________________________________________________
Subject: F-705G - Tip up canopy only ... ?
Date: May 12, 2005
I know these angles are required for the tip-up canopy and I'm fairly sure should be ommited completely for the slider canopy, but wanted to check with others ... can anyone confirm ? __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: May 12, 2005
Gerry, You're correct. Those are only for the tip up. I am building a slider so I have already studied the plans ten times to make sure. Regards, Mike 90709 fuse...waiting on bigger workshop to be built -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Gerry Filby Subject: RV9-List: F-705G - Tip up canopy only ... ? I know these angles are required for the tip-up canopy and I'm fairly sure should be ommited completely for the slider canopy, but wanted to check with others ... can anyone confirm ? __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Subject: Adhesive from H#$*%
Date: May 14, 2005
I got a piece of aluminum from Aircraft Spruce that has clear plastic on one side. After pealing the plastic off, there was an adhesive film left behind. This stuff is like pro seal. I haven't found anything that will cut it off the aluminum. Lacquer thinner, acetone, even methyl ethyl death wont cut it. Does anyone know what will cut this stuff off? Bob Perkinson Hendersonville, TN. RV9A If Nothing Changes Nothing Changes! ________________________________________________________________________________
Date: May 14, 2005
Try Goo Gone. Ralph Livermore Wings > -----Original Message----- > From: owner-rv9-list-server(at)matronics.com > [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Bob > Perkinson > Sent: Saturday, May 14, 2005 5:40 PM > To: Matronics RV-9 List > Subject: RV9-List: Adhesive from H#$*% > > > > > I got a piece of aluminum from Aircraft Spruce that has clear > plastic on one side. After pealing the plastic off, there > was an adhesive film left behind. This stuff is like pro > seal. I haven't found anything that will cut it off the > aluminum. Lacquer thinner, acetone, even methyl ethyl death > wont cut it. Does anyone know what will cut this stuff off? > > > Bob Perkinson > Hendersonville, TN. > RV9A > If Nothing Changes > Nothing Changes! > > > > > > > ________________________________________________________________________________
Date: May 14, 2005
Subject: Re: Adhesive from H#$*%
I had the same problem... but what I thought was adhesive residue was in fact, corrosion. It had to be sanded off. As far as I know, the plastic film does not use adhesive. Vern Little Bob Perkinson wrote: > >I got a piece of aluminum from Aircraft Spruce that has clear plastic on one >side. After pealing the plastic off, there was an adhesive film left >behind. This stuff is like pro seal. I haven't found anything that will >cut it off the aluminum. Lacquer thinner, acetone, even methyl ethyl death >wont cut it. Does anyone know what will cut this stuff off? > > >Bob Perkinson >Hendersonville, TN. >RV9A >If Nothing Changes >Nothing Changes! > > > > ________________________________________________________________________________
Date: May 17, 2005
Subject: RE: RV9-List Digest: 4 Msgs - 05/14/05
From: "EXT-Allen, David" <david.allen(at)boeing.com>
--> RV9-List message posted by: "EXT-Allen, David" Try Goo Gone to remove adhesive from aluminum. -----Original Message----- From: RV9-List Digest Server [mailto:rv9-list-digest(at)matronics.com] Subject: RV9-List Digest: 4 Msgs - 05/14/05 * ================================================== Online Versions of Today's List Digest Archive ================================================== Today's complete RV9-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV9-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/rv9-list/Digest.RV9-List.2005-05-14.html Text Version: http://www.matronics.com/digest/rv9-list/Digest.RV9-List.2005-05-14.txt ================================================ EMail Version of Today's List Digest Archive ================================================ RV9-List Digest Archive --- Total Messages Posted Sat 05/14/05: 4 Today's Message Index: ---------------------- 1. 05:41 PM - Adhesive from H#$*% (Bob Perkinson) 2. 06:53 PM - Re: Adhesive from H#$*% (Ralph Cloud) 3. 07:02 PM - Re: Adhesive from H#$*% () 4. 09:47 PM - Re: Adhesive from H#$*% (rv-9a-online) ________________________________ Message 1 _____________________________________ Date: Tue, 17 May 2005 04:57:39 -0700 From: "Bob Perkinson" <bobperk(at)bellsouth.net> Subject: RV9-List: Adhesive from H#$*% --> RV9-List message posted by: "Bob Perkinson" I got a piece of aluminum from Aircraft Spruce that has clear plastic on one side. After pealing the plastic off, there was an adhesive film left behind. This stuff is like pro seal. I haven't found anything that will cut it off the aluminum. Lacquer thinner, acetone, even methyl ethyl death wont cut it. Does anyone know what will cut this stuff off? Bob Perkinson Hendersonville, TN. RV9A If Nothing Changes Nothing Changes! ________________________________ Message 2 _____________________________________ Date: Tue, 17 May 2005 04:57:39 -0700 From: "Ralph Cloud" <rv9ralph(at)flash.net> Subject: RE: RV9-List: Adhesive from H#$*% --> RV9-List message posted by: "Ralph Cloud" Try Goo Gone. Ralph Livermore Wings > -----Original Message----- > From: owner-rv9-list-server(at)matronics.com > [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Bob > Perkinson > Sent: Saturday, May 14, 2005 5:40 PM > To: Matronics RV-9 List > Subject: RV9-List: Adhesive from H#$*% > > > --> RV9-List message posted by: "Bob Perkinson" > > > I got a piece of aluminum from Aircraft Spruce that has clear > plastic on one side. After pealing the plastic off, there > was an adhesive film left behind. This stuff is like pro > seal. I haven't found anything that will cut it off the > aluminum. Lacquer thinner, acetone, even methyl ethyl death > wont cut it. Does anyone know what will cut this stuff off? > > > Bob Perkinson > Hendersonville, TN. > RV9A > If Nothing Changes > Nothing Changes! > > > > > > > ________________________________ Message 3 _____________________________________ Date: Tue, 17 May 2005 04:57:39 -0700 From: <dthomas773(at)sbcglobal.net> Subject: Re: RV9-List: Adhesive from H#$*% --> RV9-List message posted by: Did you try a detergent or soap of any kind? Do not archive --- Bob Perkinson wrote: > --> RV9-List message posted by: "Bob Perkinson" > > > I got a piece of aluminum from Aircraft Spruce that > has clear plastic on one > side. After pealing the plastic off, there was an > adhesive film left > behind. This stuff is like pro seal. I haven't > found anything that will > cut it off the aluminum. Lacquer thinner, acetone, > even methyl ethyl death > wont cut it. Does anyone know what will cut this > stuff off? > > > Bob Perkinson > Hendersonville, TN. > RV9A > If Nothing Changes > Nothing Changes! > > > > browse > Subscriptions page, > FAQ, > > > > > > ________________________________ Message 4 _____________________________________ Date: Tue, 17 May 2005 04:57:39 -0700 From: rv-9a-online <rv-9a-online(at)telus.net> Subject: Re: RV9-List: Adhesive from H#$*% --> RV9-List message posted by: rv-9a-online I had the same problem... but what I thought was adhesive residue was in fact, corrosion. It had to be sanded off. As far as I know, the plastic film does not use adhesive. Vern Little Bob Perkinson wrote: >--> RV9-List message posted by: "Bob Perkinson" > >I got a piece of aluminum from Aircraft Spruce that has clear plastic >on one side. After pealing the plastic off, there was an adhesive film >left behind. This stuff is like pro seal. I haven't found anything >that will cut it off the aluminum. Lacquer thinner, acetone, even >methyl ethyl death wont cut it. Does anyone know what will cut this >stuff off? > > >Bob Perkinson >Hendersonville, TN. >RV9A >If Nothing Changes >Nothing Changes! > > > > ________________________________________________________________________________
Subject: Flaps -- Manual or Electric
Date: May 26, 2005
I'm about ready to place an order for the RV9A wings kit and must make a decision regarding flaps. How about some pros and cons on the subject. Dave Allen RV9A Empennage ________________________________________________________________________________
Date: May 26, 2005
Subject: Re: Flaps -- Manual or Electric
I like the electric my self...Neil ________________________________________________________________________________
Date: May 26, 2005
David Unless Van has made a recent change, electric flaps have always been standard on the RV-9/9A. Dean Van Winkle RV-9A Fuselage/Finish ----- Original Message ----- From: "EXT-Allen, David" <david.allen(at)boeing.com> Subject: RV9-List: Flaps -- Manual or Electric > > I'm about ready to place an order for the RV9A wings kit and must make a > decision regarding flaps. > > How about some pros and cons on the subject. > > Dave Allen > RV9A Empennage > > ________________________________________________________________________________
Date: May 26, 2005
For your consideration: I like the electric flaps and some builders have installed the optional kit that gives you flap positioning with just a flip of the switch. When they're down, flipping the switch will raise them completely. Several builders felt the electric trim system didn't give sensitive enough control so have installed a switch that selects reduced trim voltage when flaps are raised, and full trim voltage when flaps are deployed. Some have the flap switch on the stick grip but mine is on the panel near the throttle so that I can raise the flaps with my hand on the throttle. Some have a flap position indicator on the panel, some use the stripped matching lines on the trailing edge of the wing method and some just look out the window to see flap position. Apparently whatever method you pick, it will turn out to be the best way of doing things. Albert Gardner RV-9A 872RV Yuma, AZ ________________________________________________________________________________
From: Michael Schipper <mike(at)learningplanet.com>
Date: May 26, 2005
You don't get a choice on this one. The -9A comes standard with electric flaps, and there is no mention in the plans for a manual flap option. Mike Schipper -9A #90768 - Finishing www.my9a.com On May 26, 2005, at 6:44 AM, EXT-Allen, David wrote: > I'm about ready to place an order for the RV9A wings kit and must make > a > decision regarding flaps. ________________________________________________________________________________
Date: May 26, 2005
Hi Allen, as the other posts have pointed out the only choice is electric. You could probably design a manual system but the electric systems works very well. I chose to keep mine as simple as possible, just the 2 position momentary contact switch on the panel. It takes 8 seconds from full up to full down. I can easily look out the window and see the position or believe it or not you can hear when the motor comes to the end of it's travel. Denis Thomas RV9 N164DV 186 hours --- "EXT-Allen, David" wrote: > > > I'm about ready to place an order for the RV9A wings > kit and must make a > decision regarding flaps. > > How about some pros and cons on the subject. > > Dave Allen > RV9A Empennage > > > > browse > Subscriptions page, > FAQ, > > > > > > ________________________________________________________________________________
"'Gill, Bill'"
Subject: Aircraft Registration form
Date: May 27, 2005
I recently submitted my Aircraft Registration form (AC Form 8050-1) and as feared it was kicked back for a minor mistake that I thought I would warn those who haven't registered about. At the bottom of the form in the signature blocks you must PRINT your name below your signature. The form tells you this right about the signature block but if you aren't paying attention, it is easily missed. Matthew Brandes, Van's RV-9A (Finish Kit) #90569 <http://www.n523rv.com/> http://www.n523rv.com EAA Chapter 1329 President EAA Chapter 868 Web Editor ________________________________________________________________________________
Date: May 28, 2005
Subject: Re: RV9-List Digest: 1 Msgs - 05/27/05
Mathew, my registration form has been kicked back three times, once for the same problem you mentioned. My advice is for builders to register at least 2-3 months before planning to call for an inspection. You can't get an inspection until you have the registration in hand. Leland Still waiting N137LC > >From: "Matthew Brandes" <matthew(at)n523rv.com> > "'Gill, Bill'" >Subject: RV9-List: Aircraft Registration form > > >I recently submitted my Aircraft Registration form (AC Form 8050-1) and as >feared it was kicked back for a minor mistake that I thought I would warn >those who haven't registered about. > >At the bottom of the form in the signature blocks you must PRINT your name >below your signature. The form tells you this right about the signature >block but if you aren't paying attention, it is easily missed. > >Matthew Brandes, >Van's RV-9A (Finish Kit) > > ________________________________________________________________________________
Subject: RE: RV9-List Digest: 6 Msgs - 05/26/05
Date: May 31, 2005
As several of you have pointed out, electric flaps is standard on the RV9A. Sorry I wasn't up to speed on that. But I'm glad I made the post anyway because of all the interesting discussion on electric flap options. Dave Allen RV9A Empennage -----Original Message----- From: RV9-List Digest Server [mailto:rv9-list-digest(at)matronics.com] Subject: RV9-List Digest: 6 Msgs - 05/26/05 * ================================================== Online Versions of Today's List Digest Archive ================================================== Today's complete RV9-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV9-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/rv9-list/Digest.RV9-List.2005-05-26.html Text Version: http://www.matronics.com/digest/rv9-list/Digest.RV9-List.2005-05-26.txt ================================================ EMail Version of Today's List Digest Archive ================================================ RV9-List Digest Archive --- Total Messages Posted Thu 05/26/05: 6 Today's Message Index: ---------------------- 1. 04:47 AM - Flaps -- Manual or Electric (EXT-Allen, David) 2. 04:54 AM - Re: Flaps -- Manual or Electric (Neilekins(at)aol.com) 3. 05:16 AM - Re: Flaps -- Manual or Electric (Dean) 4. 05:49 AM - Re: Flaps -- Manual or Electric (Albert Gardner) 5. 06:22 AM - Re: Flaps -- Manual or Electric (Michael Schipper) 6. 07:19 AM - Re: Flaps -- Manual or Electric () ________________________________ Message 1 _____________________________________ Subject: RV9-List: Flaps -- Manual or Electric From: "EXT-Allen, David" <david.allen(at)boeing.com> --> I'm about ready to place an order for the RV9A wings kit and must make a decision regarding flaps. How about some pros and cons on the subject. Dave Allen RV9A Empennage ________________________________ Message 2 _____________________________________ From: Neilekins(at)aol.com Subject: Re: RV9-List: Flaps -- Manual or Electric I like the electric my self...Neil ________________________________ Message 3 _____________________________________ From: "Dean" <dvanwinkle(at)royell.net> Subject: Re: RV9-List: Flaps -- Manual or Electric David Unless Van has made a recent change, electric flaps have always been standard on the RV-9/9A. Dean Van Winkle RV-9A Fuselage/Finish ----- Original Message ----- From: "EXT-Allen, David" <david.allen(at)boeing.com> Subject: RV9-List: Flaps -- Manual or Electric > > I'm about ready to place an order for the RV9A wings kit and must make > a decision regarding flaps. > > How about some pros and cons on the subject. > > Dave Allen > RV9A Empennage > > ________________________________ Message 4 _____________________________________ From: "Albert Gardner" <ibspud(at)adelphia.net> Subject: Re: RV9-List: Flaps -- Manual or Electric For your consideration: I like the electric flaps and some builders have installed the optional kit that gives you flap positioning with just a flip of the switch. When they're down, flipping the switch will raise them completely. Several builders felt the electric trim system didn't give sensitive enough control so have installed a switch that selects reduced trim voltage when flaps are raised, and full trim voltage when flaps are deployed. Some have the flap switch on the stick grip but mine is on the panel near the throttle so that I can raise the flaps with my hand on the throttle. Some have a flap position indicator on the panel, some use the stripped matching lines on the trailing edge of the wing method and some just look out the window to see flap position. Apparently whatever method you pick, it will turn out to be the best way of doing things. Albert Gardner RV-9A 872RV Yuma, AZ ________________________________ Message 5 _____________________________________ From: Michael Schipper <mike(at)learningplanet.com> Subject: Re: RV9-List: Flaps -- Manual or Electric --> You don't get a choice on this one. The -9A comes standard with electric flaps, and there is no mention in the plans for a manual flap option. Mike Schipper -9A #90768 - Finishing www.my9a.com On May 26, 2005, at 6:44 AM, EXT-Allen, David wrote: > I'm about ready to place an order for the RV9A wings kit and must make > a > decision regarding flaps. ________________________________ Message 6 _____________________________________ From: <dthomas773(at)sbcglobal.net> Subject: Re: RV9-List: Flaps -- Manual or Electric Hi Allen, as the other posts have pointed out the only choice is electric. You could probably design a manual system but the electric systems works very well. I chose to keep mine as simple as possible, just the 2 position momentary contact switch on the panel. It takes 8 seconds from full up to full down. I can easily look out the window and see the position or believe it or not you can hear when the motor comes to the end of it's travel. Denis Thomas RV9 N164DV 186 hours --- "EXT-Allen, David" wrote: > > > I'm about ready to place an order for the RV9A wings > kit and must make a > decision regarding flaps. > > How about some pros and cons on the subject. > > Dave Allen > RV9A Empennage > > > > browse > Subscriptions page, > FAQ, > > > > > > ________________________________________________________________________________
Date: May 31, 2005
Subject: Elevator trim tab
After installing the trim tab on the left elevator, it appears that the trim tab, when in the neutral position with the inboard surface of the elevator is twisted as the outboard trim is about 1/4" out of neutral when I put a straight edge along the rib axis. The trailing edge of the trim tab is staight. Is this normal or where did I go wrong? More importantly, any way to correct it short of building a new trim tab? Thanks for any suggestions. ________________________________________________________________________________
Subject: Re: Elevator trim tab
Date: May 31, 2005
You could try twisting it, but the best solution might be to order new trim tab parts and move on to something else. Come back to the trim tab in a week or two when the new parts arrive and try it again. The twist you describe may not be an issue for flight, but these are inexpensive parts to replace. Regards, Mike Schipper www.my9a.com On May 31, 2005, at 7:54 AM, Nigel Goad wrote: > > After installing the trim tab on the left elevator, it appears that > the trim tab, when in the neutral position with the inboard surface of > the elevator is twisted as the outboard trim is about 1/4" out of > neutral when I put a straight edge along the rib axis. The trailing > edge of the trim tab is staight. > Is this normal or where did I go wrong? More importantly, any way to > correct it short of building a new trim tab? > Thanks for any suggestions. ________________________________________________________________________________
Date: May 31, 2005
I would take a close look at the elevator. The possibility that a twist was built into it, is stronger than building a twist into the trim tab. Bob Perkinson Hendersonville, TN. RV9A If Nothing Changes Nothing Changes! -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com]On Behalf Of Nigel Goad Subject: RV9-List: Elevator trim tab After installing the trim tab on the left elevator, it appears that the trim tab, when in the neutral position with the inboard surface of the elevator is twisted as the outboard trim is about 1/4" out of neutral when I put a straight edge along the rib axis. The trailing edge of the trim tab is staight. Is this normal or where did I go wrong? More importantly, any way to correct it short of building a new trim tab? Thanks for any suggestions. ________________________________________________________________________________
Date: Jun 01, 2005
Subject: Re: RV9-List Digest: 4 Msgs - 05/31/05
Date: Jun 01, 2005
Subject: cabin carpet?
Has anyone come up with a good way to fasten a carpet down? I insulated with Ensolite and then carefully fit a piece of carpet. Problem is every time I push forward with my feet to exit, the carpet slides forward slightly. After a dozen or so flights it's bunched up ahead of the rudder pedals. I don't want to glue it down nor do I want any fasteners through the belly. Ideas, Please! Gotta be be an easy, simple way. Thanks, Bob D ________________________________________________________________________________
Date: Jun 01, 2005
(snip)Has anyone come up with a good way to fasten a carpet down? How about Velcro??? ________________________________________________________________________________
Date: Jun 01, 2005
Subject: Re: cabin carpet?
Try Carpet tape. Available at your local building supply (Lowe's, etc.) Jeff Bobdeva(at)aol.com wrote: > >Has anyone come up with a good way to fasten a carpet down? I insulated with >Ensolite and then carefully fit a piece of carpet. Problem is every time I >push forward with my feet to exit, the carpet slides forward slightly. After a >dozen or so flights it's bunched up ahead of the rudder pedals. I don't want to >glue it down nor do I want any fasteners through the belly. Ideas, Please! >Gotta be be an easy, simple way. > >Thanks, Bob D > > > > ________________________________________________________________________________
Date: Jun 01, 2005
Bob, My floor carpet is glued to 1/2" padding and then some heavy cardboard material, the kind they use in upholstery. It is then laid in the floor sections with the end butting against the firewall. This makes the whole assembly rigid enough that the carpet does not bunch up when getting in/out, and is still easily removable. No fasteners. Dale ----- Original Message ----- From: <Bobdeva(at)aol.com> Subject: RV9-List: cabin carpet? > > Has anyone come up with a good way to fasten a carpet down? I insulated > with > Ensolite and then carefully fit a piece of carpet. Problem is every time I > push forward with my feet to exit, the carpet slides forward slightly. > After a > dozen or so flights it's bunched up ahead of the rudder pedals. I don't > want to > glue it down nor do I want any fasteners through the belly. Ideas, > Please! > Gotta be be an easy, simple way. > > Thanks, Bob D > > > ________________________________________________________________________________
Date: Jun 02, 2005
I read an article of applying a thin layer of construction adhesive to the bottom of the carpet. I have not tried it yet thought. Tad Sargent Sargentclt(at)CS.com RV7A ________________________________________________________________________________
Date: Jun 02, 2005
On my airplane we used velcro and attached it with a rubber cement our local upholstery shop gave us. That glue didn't hold. We re-glued it with a 5 minute epoxy and now it's fine. Dennis Thomas --- Sargentclt(at)cs.com wrote: > > I read an article of applying a thin layer of > construction adhesive to the > bottom of the carpet. I have not tried it yet > thought. > > Tad Sargent > Sargentclt(at)CS.com > RV7A > > > > browse > Subscriptions page, > FAQ, > > > > > > ________________________________________________________________________________
Subject: F-623 Baggage Compt Corner Ribs
Date: Jun 02, 2005
0.25 HELO_DYNAMIC_DHCP Relay HELO'd using suspicious hostname (DHCP) 0.74 HELO_DYNAMIC_HCC Relay HELO'd using suspicious hostname (HCC) 1.40 HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP addr 1) Scratchin' my head once again ... The plans seem to indicate that the edge of the F-623 baggage corner rib abuts the edge of the lower flange of the F-705A bulkhead channel ... then the F-623A attach strip overlaps and connects the two. But when I lay out the parts like this the apex of the rib's 'triangle' doesn't line up with the similar apex along the edge of the F-976 skin and the aft end of the rib protrudes beyond the line joining the ends of the adjascent ribs. It just doesn't look right. Furthermore the forward end of the rib outboard flange is factory shaped such that it might overlap on the inside of the flange of the F-705D bulkhead verticle channel - a single rivet passing through the skin, the bulkhead flange and then the rib flange. (Confused yet ? I am.) The only solution I can see is to trim away part of the forward web and inboard flange of the rib - but I don't see any note of this in the plans or instructions. Anyone got any insight into this ? __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Subject: RE: RV7-List: F-623 Baggage Compt Corner Ribs
Date: Jun 03, 2005
Gerry: I just did the same part the other day and that joggle confused me because it suggests the flange fits inside the bulkhead flange. But if you do that, you can't get the edge of the corner rib to line up flush with the bottom skin, although I have seen some Web sites that have suggested cutting aroudn etc. Don't bother. Hack it off. The two flanges, the web,etc whee it meets the flange of the side of the bulkhead and the top. Front and back (I left the back intact until we mated the center and aft section on Thursday and then it was much easier to see why you have to do the same to the rear section. It takes awhile to see this on the plans. They really needed a zoomed-in overhead shot here. Disclaimer: I see you posted this to both the 9 and 7 groups. I'm building a 7. I have no idea if the situation is the same with the 9. Bob St. Paul -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Gerry Filby Subject: RV7-List: F-623 Baggage Compt Corner Ribs --> RV7-List message posted by: Gerry Filby Scratchin' my head once again ... ________________________________________________________________________________
Subject: Wing conduit
Date: Jun 08, 2005
Will anyone tell me where to buy the wiring conduit for the wings and what outside and inside diameter it should be? ________________________________________________________________________________
Subject: Re: Wing conduit
Date: Jun 08, 2005
----- Original Message ----- From: "D.Munz" <182ppl(at)comcast.net> Subject: RV9-List: Wing conduit > > Will anyone tell me where to buy the wiring conduit for the wings and what > outside and inside diameter it should be? > From Van's Accessories Catalog. Nylon corrugated tube. 0.810" OD. Duct NT5/8, 25 or 50ft rolls. Use 3/4" dia holes. Tom C RV9 N793JT (reserved) ________________________________________________________________________________
Date: Jun 08, 2005
I used the Van's stuff too - but I found the corrugation annoying to work with - isn't there a white non-corrugated type available from somewhere ? And why is it corrugated - what's the benefit ? g > > > > ----- Original Message ----- > From: "D.Munz" <182ppl(at)comcast.net> > To: > Subject: RV9-List: Wing conduit > > > > > > Will anyone tell me where to buy the wiring conduit for the wings and what > > outside and inside diameter it should be? > > > > From Van's Accessories Catalog. Nylon corrugated tube. 0.810" OD. Duct > NT5/8, 25 or 50ft rolls. Use 3/4" dia holes. > Tom C > RV9 N793JT (reserved) > > > > > > > ________________________________________________________________________________
Date: Jun 08, 2005
Tom, For what it's worth I bought enough of the conduit for both wings and the fuselage and then had a change of heart and got the snap bushings instead. Figured it would be an easier installation, easier to add stuff later, and didn't require making nice 3/4 inch holes. I've got two of them in each rib to be sure I'll have enough capacity for whatever I decide to run. Plus my RV7A neighbor did the same thing. We both now have 50 feet of conduit sitting around. If you leave near me come by and I'll give you mine. Bill Albion, Maine - Having fun with wing tanks. ----- Original Message ----- From: "Tom Callender" <tcallender(at)alltel.net> Subject: Re: RV9-List: Wing conduit > > > ----- Original Message ----- > From: "D.Munz" <182ppl(at)comcast.net> > To: > Subject: RV9-List: Wing conduit > > > > > > Will anyone tell me where to buy the wiring conduit for the wings and what > > outside and inside diameter it should be? > > > > From Van's Accessories Catalog. Nylon corrugated tube. 0.810" OD. Duct > NT5/8, 25 or 50ft rolls. Use 3/4" dia holes. > Tom C > RV9 N793JT (reserved) > > ________________________________________________________________________________
From: "Charles Hagerty" <chagerty(at)worldnet.att.net>
Date: Jun 08, 2005
I'm using a clear non-corrugated 1/2" plastic water line pipe from Home Depot. You can put the supplied bushing in the hole and this stuff slides easily (with a little lubrication) through the bushing. Double protection and light weight. Chuck Hagerty RV-7A finish kit ----- Original Message ----- From: "Gerry Filby" <gerf(at)gerf.com> Subject: Re: RV9-List: Wing conduit > > > I used the Van's stuff too - but I found the corrugation > annoying to work with - isn't there a white non-corrugated type > available from somewhere ? And why is it corrugated - what's > the benefit ? > > g > >> >> >> >> ----- Original Message ----- >> From: "D.Munz" <182ppl(at)comcast.net> >> To: >> Subject: RV9-List: Wing conduit >> >> >> > >> > Will anyone tell me where to buy the wiring conduit for the wings and >> > what >> > outside and inside diameter it should be? >> > >> >> From Van's Accessories Catalog. Nylon corrugated tube. 0.810" OD. Duct >> NT5/8, 25 or 50ft rolls. Use 3/4" dia holes. >> Tom C >> RV9 N793JT (reserved) >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jun 08, 2005
Here <http://www.myrv10.com/N104CD/fuselage/20050517/index.html> is a suggestion from a fellow RV-10 builder. He is using optical fiber plenum. Larry Rosen RV-10 #356 Waiting on QB Wings ________________________________________________________________________________
Date: Jun 08, 2005
D.Munz wrote: > >Will anyone tell me where to buy the wiring conduit for the wings and what outside and inside diameter it should be? > Here are a few untested ideas I'm considering. AL flashing from the bldg supply rolled into a tube & 'glued' in the holes Same thing out of plastic sheet Ripstop nylon sewn into a tube The goal for me is minimum weight & maximizing space in the conduit for wires. The electrical & fiber conduit I've been able to find is fairly thick & quite a bit heavier than any of the above will be but will be a lot less work. Grommets by themselves will allow the wire to move a bit more & probably rub on either the skin or spar. Might be a wear issue after a few thousand hours of flying. Charlie ________________________________________________________________________________
Date: Jun 08, 2005
This stuff looks good but how would I get my hands on 40'? It looks like the minimum order is 1000'. ----- Original Message ----- From: "Larry" <LarryRosen(at)comcast.net> Subject: Re: RV9-List: Wing conduit > > Here <http://www.myrv10.com/N104CD/fuselage/20050517/index.html> is a > suggestion from a fellow RV-10 builder. He is using optical fiber plenum. > > Larry Rosen > RV-10 #356 > Waiting on QB Wings > > > ________________________________________________________________________________
Subject: WD-409 ... where to powder coat ...
Date: Jun 08, 2005
0.25 HELO_DYNAMIC_DHCP Relay HELO'd using suspicious hostname (DHCP) 0.74 HELO_DYNAMIC_HCC Relay HELO'd using suspicious hostname (HCC) 1.40 HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP addr 1) (WD-409 tail wheel spring mount) Seems like folks used to get this ready coated from Vans ... mine's bare metal - Oh Well. But on the upside - its pre-drilled to the spring, which seems to be a new thing ... Any recommendations on where I can get this puppy coated in the SF Bay Area ? __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Jun 09, 2005
Gerry, the corrugated wing conduit can be stretched, thus making it smaller in diameter. So if you drill holes through the wing ribs of the diameter of the conduit between the raised areas then stretch it (takes two people), you'll find when you release it that it stays put. That's what I did on my Rv-8A, on my 8 I just routed wires and stuff through the tooling holes in the ribs and secured 'em with small tie wraps. Much easier ........... Walt Shipley -----Original Message----- From: Gerry Filby <gerf(at)gerf.com> Subject: Re: RV9-List: Wing conduit I used the Van's stuff too - but I found the corrugation annoying to work with - isn't there a white non-corrugated type available from somewhere ? And why is it corrugated - what's the benefit ? g > > > > ----- Original Message ----- > From: "D.Munz" <182ppl(at)comcast.net> > To: > Subject: RV9-List: Wing conduit > > > > > > Will anyone tell me where to buy the wiring conduit for the wings and what > > outside and inside diameter it should be? > > > > From Van's Accessories Catalog. Nylon corrugated tube. 0.810" OD. Duct > NT5/8, 25 or 50ft rolls. Use 3/4" dia holes. > Tom C > RV9 N793JT (reserved) > > > > > > > ________________________________________________________________________________
Subject: Brake line toque
Date: Jun 09, 2005
What is the recommended torque for the ferrel nuts that connect the high pressure line to the master cylinders? Already searched archives. Randy RV9A Finishing ________________________________________________________________________________
Subject: RE: Brake line toque
Date: Jun 13, 2005
0.00 HTML_NONELEMENT_00_10 BODY: 0% to 10% of HTML elements are non-standard Randy, I didn't see anyone reply to your message.... from what I've read/seen, there is no torque value for the AN fittings. You tighten it until it doesn't leak. :-) I've hard just past hand tight is enough but don't quote me on that. Matthew Brandes, Van's RV-9A (Finish Kit) #90569 <http://www.n523rv.com/> http://www.n523rv.com EAA Chapter 1329 President EAA Chapter 868 Web Editor ________________________________________________________________________________
Date: Jun 13, 2005
Subject: Re: RE: Brake line toque
Hi Matt, I had a lot of trouble with leaks on my brake lines. On the advice of a freind I used teflon tape which cured the leaks but since then I have been told this is a totally wrong thing to do. Cy Galley told us that teflon works until you need to undo a fitting and then it gets into the system and clogs it up. So far I'm OK. Denis Thomas --- Matthew Brandes wrote: > > > Randy, > > I didn't see anyone reply to your message.... from > what I've read/seen, > there is no torque value for the AN fittings. You > tighten it until it > doesn't leak. :-) I've hard just past hand tight is > enough but don't quote > me on that. > > Matthew Brandes, > Van's RV-9A (Finish Kit) > #90569 > <http://www.n523rv.com/> http://www.n523rv.com > > EAA Chapter 1329 President > EAA Chapter 868 Web Editor > > > > browse > Subscriptions page, > FAQ, > > > > > > ________________________________________________________________________________
Date: Jun 13, 2005
Subject: Not happy with the trailing edges
Date: Jun 13, 2005
My elevator trailing edges are structuraly sound but I dont think they look good. Would it effect flight characteristics a great deal if I used epoxy or the like to fill in the gaps and make the trailing edge and the bottom rivets smooth before painting? ________________________________________________________________________________
Date: Jun 14, 2005
I don't think flight characteristis will be affected but airplane value will be decreased. This is not a corvette, what you have is an aircraft elevator built IAW Vans instructions and acceptable practices and procedures. Unless you're a world renowned expert don't argue with success. My 2 cents for what it's worth....A&P for 29 years. -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of D.Munz Subject: RV9-List: Not happy with the trailing edges My elevator trailing edges are structuraly sound but I dont think they look good. Would it effect flight characteristics a great deal if I used epoxy or the like to fill in the gaps and make the trailing edge and the bottom rivets smooth before painting? ________________________________________________________________________________
Subject: Re: Not happy with the trailing edges
Date: Jun 14, 2005
I used T-88 (epoxy) from Aircraft Spruce instead of Pro-Seal in all my trailing edges - you should be fine ... g > > > My elevator trailing edges are structuraly sound but I dont > think they look good. Would it effect flight characteristics a > great deal if I used epoxy or the like to fill in the gaps and > make the trailing edge and the bottom rivets smooth before > painting? > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Subject: U-813D Allen Screw rubbing tire warning
Date: Jun 14, 2005
0.00 HTML_NONELEMENT_00_10 BODY: 0% to 10% of HTML elements are non-standard I was attaching the U-813D forward nose wheel pant brackets last night on the WD-630 nose wheel weldment and noticed that the allen screw came within .032" of actually rubbing on the tire! I emailed Van's and they said to stick a couple more washers on it or grind down the screw. Just something to watch for... a blown tire could lead to bad things happening. Matthew Brandes, Van's RV-9A (Engine/Electrical/Fiberglass) #90569 <http://www.n523rv.com/> http://www.n523rv.com EAA Chapter 1329 President EAA Chapter 868 Web Editor ________________________________________________________________________________
Date: Jun 14, 2005
use pro-seal then file squair did that to mine looks great. -----Original Message----- From: "D.Munz" <182ppl(at)comcast.net> Subject: RV9-List: Not happy with the trailing edges My elevator trailing edges are structuraly sound but I dont think they look good. Would it effect flight characteristics a great deal if I used epoxy or the like to fill in the gaps and make the trailing edge and the bottom rivets smooth before painting? ________________________________________________________________________________
Date: Jun 18, 2005
Subject: [ Henry Hore ] : New Email List Photo Share Available!
A new Email List Photo Share is available: Poster: Henry Hore <elsa-henry@darlor-watch.com> Lists: RV-List,RV6-List,RV7-List,RV8-List,RV9-List Subject: Leveling RV6-A Fuselage http://www.matronics.com/photoshare/elsa-henry@darlor-watch.com.06.18.2005/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
"'DellAngelo, Scott M'" , "'Brian Meyette'"
Subject: Bad instructions for nosewheel pant construction
Date: Jun 20, 2005
I've recently been working on the wheelpants and finally managed to finish them this past weekend besides sanding/finishing them. I ran into a problem with the nosehweel that I thought I'd pass along. (Long winded...) We all know how bad the instructions get by the time you get to the fuselage. For some reason, I decided to follow the instructions when constructing the nosewheel pant. The instructions note that there are 'dimples' in the back half of the pant that mark the axle bolt centerline. You drill these two dimples out to 3/8" and then attached the U-813 bracket. So I checked my pant and sure enough, there were two small dimples. So I blindly make the aft wheel pant and get it mounted on the nose. Then I start trying to fit the front cap, only to run into problems. No matter how I positioned the wheel pant, it would rub on something. Either the WD-631 stop or the nose fork itself. Dag nabbit! I looked at the plans and looked at my wheel pant and it seemed like it was positioned correctly for the most part.. but it was lopsided a bit and appeared to be a bit too far aft. I fired off an email to Van's (no reply yet) and also to Jerry T. who I knew had recently done his. His reply: "Use the dimensions on the print, not any 'dimples' you may have found. I had the same problem until I checked the print dimensions." So I looked at the plans and noted the 16" dimension from the aft edge to the center of the axle bolt hole. Mine measured about 16 1/4" and the height of the holes along the side were about 1/8" different, causing the lopsided look. Since a new wheel pant would be $100, I attempted and successfully patched all the holes I made and drilled new ones using the plan dimensions. They came about better this time. Although I still think the aft half could have come forward more since I was not able to get the 6 13/16" dimension for the height of the aft end without it rubbing. I had to push it down farther. So be warned.... don't follow the instructions in this area. Matthew Brandes, Van's RV-9A (Finish Kit) #90569 http://www.n523rv.com EAA Chapter 1329 President EAA Chapter 868 Web Editor ________________________________________________________________________________
Date: Jun 20, 2005
Subject: Re: Bad instructions for nosewheel pant construction
Great news I had the same issue on my 7A. When all is said and done you may need a new ring clamp to hold the leg fairing in place. I get a gentle rub at full turn of the wheel. I also noticed the clamp is visible so I made a fairing on the from cap to hide it. Wait till you get to the baffle install. These plans are written in crayon. Tad Sargent Sargentclt(at)CS.com RV7A ________________________________________________________________________________
Date: Jun 21, 2005
Subject: Gear fairing clamp: was: Bad instructions for nosewheel pant
construction Just as a question (I'm getting real close to doing the fiberglass,) has anyone tried the safety wire type clamp on the gear leg fairing? I made one of the clamp-makers after seeing one at Oshkosh last year. It clamps as good as any hose clamp and of course they are very light and inexpensive, once you have the machine. Since they don't stick up at all, I would think they would work really well in this application, but I haven't tried them on fiberglass. Putting them on takes some space for the machine, but I doubt if this is an issue. Two or three double loops should hold anything. If you haaven't seen one of these devices, I found one at http://www.gemplers.com/a/shop/product.asp?T1=HC8&src=21TL002 Bob Kelly On 06/21/05, Sargentclt(at)cs.com wrote: > > Great news I had the same issue on my 7A. When all is said and done you > may need a new ring clamp to hold the leg fairing in place. I get a gentle > rub at full turn of the wheel. I also noticed the clamp is visible so I > made a fairing on the from cap to hide it. Wait till you get to the baffle > install. These plans are written in crayon. > > Tad Sargent > Sargentclt(at)CS.com > RV7A > > > > > > > Regards -- ________________________________________________________________________________
Subject: RE: Gear fairing clamp: was: Bad instructions for nosewheel
pant
Date: Jun 22, 2005
Bob, It would be interesting to try this but I'm wondering how well it would work in this application since the two pieces it is clamping are hard surface. This probably works great for rubber houses that will compress. I think there is a chance that the faring would rotate a bit using this. Dunno... but you're right.. it wouldn't take up much space. Matthew Brandes, Van's RV-9A (Finish Kit) #90569 <http://www.n523rv.com/> http://www.n523rv.com EAA Chapter 1329 President EAA Chapter 868 Web Editor ________________________________________________________________________________
"RV10 Group" ,
Subject: Paper or Plastic-A warning about primers
Date: Jun 26, 2005
Fellow builders, Please take the time to read this email. I spent a bit of time writing it in the hopes that it prevent another builder/builders from experiencing my blunder this morning. I will try my literary skills this morning to help entertain and educate. This may be a little long winded but I need to vent. Southern Arizona may sound like the great place to live. Warm winters, beautiful sunsets, low humidity, wide open spaces and great flying weather makes this state seem ideal. However, the summers can be another story. At 5:30 this morning the temperature is 80 degrees and rising. The morning sun is angling into the entrance of my shop (my garage door faces east). The temperature is rising and I know I only have about an hour to setup and spray my primer before Mother Nature forces me to quit for the day; I spray my primer outside like many RV builders. You might be asking yourself why not primer late in the day when the sun is going down or at least in the shade? Midday the temperature is over 100, by late afternoon (when my garage casts a shadow providing shade) the temperature is hovering around 104-106. This is way too hot to spray. At this temp and low humidity most of the primer dries before it reaches the parts. Not to mention the surface temperature of the parts is a bit too high. In addition, the afternoons are a bit breezy while the mornings are pretty calm. The mornings are the only option for me this time of year. I proceeded to setup my 4'x8' wire mesh paint platform and drop clothes (painters plastics) outside the entrance to my shop. I had decided to debur and prep many of RV-7A fuselage parts so I could spray them at the same time-more efficient I thought. I would guess that I had about 75% or more of the fuselage components (excluding the skins) ready for primer painting. That is a very large number of parts. It has taken a lot of time to clean and prep all these parts, I started weeks back. I am on my second RV. My first was an RV-4 years ago. Back then I used a wash primer but I don't remember the brand, it was gray in color, very similar to the Sherwin Williams (SW) wash primer. Unfortunately it was no longer available. I decided to use the SW wash primer on my RV-7A. I used it on the empennage and wings, but I was never happy with the results. Spitting chunks was a big problem. I never had that problem with the old gray wash primer on my RV-4. When I built my RV-4 I sprayed my primer using a Docken spray gun. This is a very simple siphon gun that is similar to the Badger hobby store paint guns. It used disposable 16 oz cups. It made cleaning up after spaying quick and easy, just through the cup away when you were done. As I mentioned, I was not happy with the results I was getting from the SW wash primer. I decided to use the AKSO epoxy primer for the rest of my RV-7A project. And since I was using a new primer, I bought a new gun (HVLP) to apply it. Now this is where the paper or plastic fits into this long winded story. Like the SW wash primer, the AKSO is a two component system. I had several 16 oz cups left over from my Docken spray gun days and I have been using them for mixing the SW wash primer prior to loading spray gun cup. These cups are wax-coated paper cups (Dixie brand) and over 20 years old. These cups did the job, but I was running out of them. They seemed to be the "perfect" size for the amount of primer I was mixing. A week ago I used the AKSO for the first time. The most significant difference between the SW wash and the AKSO is the AKSO requires a 30 minute induction time. This means you mix the two components and wait 30 minutes before spraying. This gives the two components time to react with each other. The results were great. I only had a short time to spray so I wanted to learn the behavior of the new gun and primer to help me plan my larger primer session for this weekend. Yesterday was a good day. I sprayed two groups of parts. By 7:30 in the morning the temperature was approaching 90 degrees and I couldn't see through my goggles well (yes I use a respirator). All the parts in the group were well coated and it was time to cleanup. One more early morning primer session and all the parts would be coated, then on to assembly, the fun stuff. So this morning I would finish the job. Everything was set in place; parts were on the spray platform and now it was time to mix the paint. I have been using my Black and Decker Workmate (if you never used one, they are great tool to have around the shop-one of my most used tools) as a surface to mix my paints. I laid plastic over it to protect it from any spills and it was also sitting on some plastic as well. The Workmate was in the shop so the primers weren't exposed to the heat and sunlight. I had used up all my 16 oz. cups the day before and I had shopped around weeks earlier trying to find a replacement. I only found smaller paper cups available in the local supermarkets but they had larger disposable plastic cups. So I bought the plastic due to their size. I wanted paper but I needed the larger cup size. Life was good, everything was ready to primer and I mixed two batches of primer (14 oz. each) in my new plastic cups. And off I went to work on a few other things in the shop while I waited for the induction time (30 minutes) to pass. After 15 minutes had passed, I went to stir the primer. I noticed one of the cups was "sagging" a bit. Alarm bells in my head went off immediately. I grabbed the trashcan. I knew what was going to happen. The dam was leaking and it was about to rupture. Just as I lifted up the trashcan the cup dissolved away. None of the primer made it into the trashcan. Fourteen ounces of the best primer was now on the floor and covering the base of the Workmate (the plastic covering the surface didn't extend all the way down to the base). But I knew this was just the beginning. Within seconds, the second cup dissolved before I could get the trashcan under it and more epoxy made it onto the floor. Did I mention my shop floor is coated with an epoxy (two part-water based-gray)? So now I am staring at a rather large epoxy mess that only acetone will clean up. But acetone will also dissolve my epoxy floor coating. Profanities flew and the odor of acetone filled the air. All is cleaned up now. My epoxy coated floor looks chemically abused and my Workmate base is camouflage colored and ready to report for military duty. I have wasted precious primer and delayed my progress once again. Hopefully next Friday I will have everything rapped up. The moral of the story is: When given the choice paper or plastic, choose paper. ________________________________________________________________________________
Date: Jun 26, 2005
Subject: Re: Paper or Plastic-A warning about primers
Thanks for the entertaining and well written post. I just had to laugh as the story played out. I am not laughing at you but rather with you. Because in situations like that that is all you can do. No one was hurt and your workmate now has a little olive drab character. Thanks for the advice Larry Rosen Merems wrote: > >Fellow builders, > >Please take the time to read this email. I spent a bit of time writing it in the hopes that it prevent another builder/builders from experiencing my blunder this morning. > >I will try my literary skills this morning to help entertain and educate. This may be a little long winded but I need to vent. > >Southern Arizona may sound like the great place to live. Warm winters, beautiful sunsets, low humidity, wide open spaces and great flying weather makes this state seem ideal. However, the summers can be another story. > >At 5:30 this morning the temperature is 80 degrees and rising. The morning sun is angling into the entrance of my shop (my garage door faces east). The temperature is rising and I know I only have about an hour to setup and spray my primer before Mother Nature forces me to quit for the day; I spray my primer outside like many RV builders. You might be asking yourself why not primer late in the day when the sun is going down or at least in the shade? Midday the temperature is over 100, by late afternoon (when my garage casts a shadow providing shade) the temperature is hovering around 104-106. This is way too hot to spray. At this temp and low humidity most of the primer dries before it reaches the parts. Not to mention the surface temperature of the parts is a bit too high. In addition, the afternoons are a bit breezy while the mornings are pretty calm. The mornings are the only option for me this time of year. > >I proceeded to setup my 4'x8' wire mesh paint platform and drop clothes (painters plastics) outside the entrance to my shop. I had decided to debur and prep many of RV-7A fuselage parts so I could spray them at the same time-more efficient I thought. I would guess that I had about 75% or more of the fuselage components (excluding the skins) ready for primer painting. That is a very large number of parts. It has taken a lot of time to clean and prep all these parts, I started weeks back. > >I am on my second RV. My first was an RV-4 years ago. Back then I used a wash primer but I don't remember the brand, it was gray in color, very similar to the Sherwin Williams (SW) wash primer. Unfortunately it was no longer available. I decided to use the SW wash primer on my RV-7A. I used it on the empennage and wings, but I was never happy with the results. Spitting chunks was a big problem. I never had that problem with the old gray wash primer on my RV-4. When I built my RV-4 I sprayed my primer using a Docken spray gun. This is a very simple siphon gun that is similar to the Badger hobby store paint guns. It used disposable 16 oz cups. It made cleaning up after spaying quick and easy, just through the cup away when you were done. > >As I mentioned, I was not happy with the results I was getting from the SW wash primer. I decided to use the AKSO epoxy primer for the rest of my RV-7A project. And since I was using a new primer, I bought a new gun (HVLP) to apply it. > >Now this is where the paper or plastic fits into this long winded story. > >Like the SW wash primer, the AKSO is a two component system. I had several 16 oz cups left over from my Docken spray gun days and I have been using them for mixing the SW wash primer prior to loading spray gun cup. These cups are wax-coated paper cups (Dixie brand) and over 20 years old. These cups did the job, but I was running out of them. They seemed to be the "perfect" size for the amount of primer I was mixing. > >A week ago I used the AKSO for the first time. The most significant difference between the SW wash and the AKSO is the AKSO requires a 30 minute induction time. This means you mix the two components and wait 30 minutes before spraying. This gives the two components time to react with each other. The results were great. I only had a short time to spray so I wanted to learn the behavior of the new gun and primer to help me plan my larger primer session for this weekend. > >Yesterday was a good day. I sprayed two groups of parts. By 7:30 in the morning the temperature was approaching 90 degrees and I couldn't see through my goggles well (yes I use a respirator). All the parts in the group were well coated and it was time to cleanup. One more early morning primer session and all the parts would be coated, then on to assembly, the fun stuff. So this morning I would finish the job. > >Everything was set in place; parts were on the spray platform and now it was time to mix the paint. I have been using my Black and Decker Workmate (if you never used one, they are great tool to have around the shop-one of my most used tools) as a surface to mix my paints. I laid plastic over it to protect it from any spills and it was also sitting on some plastic as well. The Workmate was in the shop so the primers weren't exposed to the heat and sunlight. > >I had used up all my 16 oz. cups the day before and I had shopped around weeks earlier trying to find a replacement. I only found smaller paper cups available in the local supermarkets but they had larger disposable plastic cups. So I bought the plastic due to their size. I wanted paper but I needed the larger cup size. > >Life was good, everything was ready to primer and I mixed two batches of primer (14 oz. each) in my new plastic cups. And off I went to work on a few other things in the shop while I waited for the induction time (30 minutes) to pass. After 15 minutes had passed, I went to stir the primer. I noticed one of the cups was "sagging" a bit. > >Alarm bells in my head went off immediately. I grabbed the trashcan. I knew what was going to happen. The dam was leaking and it was about to rupture. Just as I lifted up the trashcan the cup dissolved away. None of the primer made it into the trashcan. Fourteen ounces of the best primer was now on the floor and covering the base of the Workmate (the plastic covering the surface didn't extend all the way down to the base). But I knew this was just the beginning. Within seconds, the second cup dissolved before I could get the trashcan under it and more epoxy made it onto the floor. Did I mention my shop floor is coated with an epoxy (two part-water based-gray)? So now I am staring at a rather large epoxy mess that only acetone will clean up. But acetone will also dissolve my epoxy floor coating. Profanities flew and the odor of acetone filled the air. > >All is cleaned up now. My epoxy coated floor looks chemically abused and my Workmate base is camouflage colored and ready to report for military duty. I have wasted precious primer and delayed my progress once again. Hopefully next Friday I will have everything rapped up. > >The moral of the story is: > >When given the choice paper or plastic, choose paper. > > > > ________________________________________________________________________________
From: "Steve Sampson" <SSampson.SLN21(at)london.edu>
Subject: Performance numbers G-IINI
Date: Jun 27, 2005
Power % TAS (mph) TAS (Knts) Pressure Alt Manifold RPM Run 4 74.7 184 160 8000 22.3 2560 Run 3 66.0 171 149 8000 21.2 2440 Run 2 71.4 169 147 5000 23 2440 Run 1 61.6 155 135 3200 21 2430 0.869 Note: 150HP O-320 I thought all you builders might like to see some flight test data...above. Its from G-IINI #90360. The TAS are calculated by the method shown at http://www.kilohotel.com/rv8/rvlinks/ssec.html . In summary each run is three runs to work out the wind effect, with data recorded from the GPS. The prop is a two blade c/s electric MT. Our flight testing showed that at 74.7% power, 8000feet we were doing 184mph (or 160Knts). Since VANS quote 172mph on 135 hp and 186mph on 160 at 75% I feel G-IINI is performing as advertised. Keep riveting, Steve. #90360, G-IINI PS Gus my performance issues are all about ASI errors which I have not yet sorted. I am very suspicious of the drain holes in the Dynon pitot head. ________________________________________________________________________________
Date: Jun 27, 2005
Subject: Hangar rental
My quickbuild fuselage and wings have arrived, I need a rough idea as to the amount of working hours until the wings are final attached so I can sort out timing for hangar rental. Any suggestions welcome Thanks ________________________________________________________________________________
Subject: Elevator horn alignment
Date: Jun 28, 2005
My RV9A instructions say to clamp the powder coated elevator horn in place and align it with the centerline of the elevator spar before drilling it to the spar and to the inboard rib. Anyone have a suggestion on how to do this alignment? Thanks for your help. Dave Allen RV9A Empennage ________________________________________________________________________________
Subject: RE: RV9-List Digest: 2 Msgs - 06/26/05
Date: Jun 28, 2005
Thanks for the good story. And this could very well save me from a similar fate. I hate to paint and I sometimes do a less than professional analysis of things like this. Dave Allen, RV9A empennage -----Original Message----- From: RV9-List Digest Server [mailto:rv9-list-digest(at)matronics.com] Subject: RV9-List Digest: 2 Msgs - 06/26/05 * ================================================== Online Versions of Today's List Digest Archive ================================================== Today's complete RV9-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV9-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/rv9-list/Digest.RV9-List.2005-06-26.html Text Version: http://www.matronics.com/digest/rv9-list/Digest.RV9-List.2005-06-26.txt ================================================ EMail Version of Today's List Digest Archive ================================================ RV9-List Digest Archive --- Total Messages Posted Sun 06/26/05: 2 Today's Message Index: ---------------------- 1. 06:11 PM - Paper or Plastic-A warning about primers (Merems) 2. 07:03 PM - Re: Paper or Plastic-A warning about primers (Larry Rosen) ________________________________ Message 1 _____________________________________ From: "Merems" <merems(at)cox.net> "RV10 Group" , Subject: RV9-List: Paper or Plastic-A warning about primers Fellow builders, Please take the time to read this email. I spent a bit of time writing it in the hopes that it prevent another builder/builders from experiencing my blunder this morning. I will try my literary skills this morning to help entertain and educate. This may be a little long winded but I need to vent. Southern Arizona may sound like the great place to live. Warm winters, beautiful sunsets, low humidity, wide open spaces and great flying weather makes this state seem ideal. However, the summers can be another story. At 5:30 this morning the temperature is 80 degrees and rising. The morning sun is angling into the entrance of my shop (my garage door faces east). The temperature is rising and I know I only have about an hour to setup and spray my primer before Mother Nature forces me to quit for the day; I spray my primer outside like many RV builders. You might be asking yourself why not primer late in the day when the sun is going down or at least in the shade? Midday the temperature is over 100, by late afternoon (when my garage casts a shadow providing shade) the temperature is hovering around 104-106. This is way too hot to spray. At this temp and low humidity most of the primer dries before it reaches the parts. Not to mention the surface temperature of the parts is a bit too high. In addition, the afternoons are a bit breezy while the mornings are pretty calm. The mornings are the only option for me this time of year. I proceeded to setup my 4'x8' wire mesh paint platform and drop clothes (painters plastics) outside the entrance to my shop. I had decided to debur and prep many of RV-7A fuselage parts so I could spray them at the same time-more efficient I thought. I would guess that I had about 75% or more of the fuselage components (excluding the skins) ready for primer painting. That is a very large number of parts. It has taken a lot of time to clean and prep all these parts, I started weeks back. I am on my second RV. My first was an RV-4 years ago. Back then I used a wash primer but I don't remember the brand, it was gray in color, very similar to the Sherwin Williams (SW) wash primer. Unfortunately it was no longer available. I decided to use the SW wash primer on my RV-7A. I used it on the empennage and wings, but I was never happy with the results. Spitting chunks was a big problem. I never had that problem with the old gray wash primer on my RV-4. When I built my RV-4 I sprayed my primer using a Docken spray gun. This is a very simple siphon gun that is similar to the Badger hobby store paint guns. It used disposable 16 oz cups. It made cleaning up after spaying quick and easy, just through the cup away when you were done. As I mentioned, I was not happy with the results I was getting from the SW wash primer. I decided to use the AKSO epoxy primer for the rest of my RV-7A project. And since I was using a new primer, I bought a new gun (HVLP) to apply it. Now this is where the paper or plastic fits into this long winded story. Like the SW wash primer, the AKSO is a two component system. I had several 16 oz cups left over from my Docken spray gun days and I have been using them for mixing the SW wash primer prior to loading spray gun cup. These cups are wax-coated paper cups (Dixie brand) and over 20 years old. These cups did the job, but I was running out of them. They seemed to be the "perfect" size for the amount of primer I was mixing. A week ago I used the AKSO for the first time. The most significant difference between the SW wash and the AKSO is the AKSO requires a 30 minute induction time. This means you mix the two components and wait 30 minutes before spraying. This gives the two components time to react with each other. The results were great. I only had a short time to spray so I wanted to learn the behavior of the new gun and primer to help me plan my larger primer session for this weekend. Yesterday was a good day. I sprayed two groups of parts. By 7:30 in the morning the temperature was approaching 90 degrees and I couldn't see through my goggles well (yes I use a respirator). All the parts in the group were well coated and it was time to cleanup. One more early morning primer session and all the parts would be coated, then on to assembly, the fun stuff. So this morning I would finish the job. Everything was set in place; parts were on the spray platform and now it was time to mix the paint. I have been using my Black and Decker Workmate (if you never used one, they are great tool to have around the shop-one of my most used tools) as a surface to mix my paints. I laid plastic over it to protect it from any spills and it was also sitting on some plastic as well. The Workmate was in the shop so the primers weren't exposed to the heat and sunlight. I had used up all my 16 oz. cups the day before and I had shopped around weeks earlier trying to find a replacement. I only found smaller paper cups available in the local supermarkets but they had larger disposable plastic cups. So I bought the plastic due to their size. I wanted paper but I needed the larger cup size. Life was good, everything was ready to primer and I mixed two batches of primer (14 oz. each) in my new plastic cups. And off I went to work on a few other things in the shop while I waited for the induction time (30 minutes) to pass. After 15 minutes had passed, I went to stir the primer. I noticed one of the cups was "sagging" a bit. Alarm bells in my head went off immediately. I grabbed the trashcan. I knew what was going to happen. The dam was leaking and it was about to rupture. Just as I lifted up the trashcan the cup dissolved away. None of the primer made it into the trashcan. Fourteen ounces of the best primer was now on the floor and covering the base of the Workmate (the plastic covering the surface didn't extend all the way down to the base). But I knew this was just the beginning. Within seconds, the second cup dissolved before I could get the trashcan under it and more epoxy made it onto the floor. Did I mention my shop floor is coated with an epoxy (two part-water based-gray)? So now I am staring at a rather large epoxy mess that only acetone will clean up. But acetone will also dissolve my epoxy floor coating. Profanities flew and the odor of acetone filled the air. All is cleaned up now. My epoxy coated floor looks chemically abused and my Workmate base is camouflage colored and ready to report for military duty. I have wasted precious primer and delayed my progress once again. Hopefully next Friday I will have everything rapped up. The moral of the story is: When given the choice paper or plastic, choose paper. ________________________________ Message 2 _____________________________________ From: Larry Rosen <LarryRosen(at)comcast.net> Subject: Re: RV9-List: Paper or Plastic-A warning about primers Thanks for the entertaining and well written post. I just had to laugh as the story played out. I am not laughing at you but rather with you. Because in situations like that that is all you can do. No one was hurt and your workmate now has a little olive drab character. Thanks for the advice Larry Rosen Merems wrote: > >Fellow builders, > >Please take the time to read this email. I spent a bit of time writing >it in the hopes that it prevent another builder/builders from experiencing my blunder this morning. > >I will try my literary skills this morning to help entertain and >educate. This may be a little long winded but I need to vent. > >Southern Arizona may sound like the great place to live. Warm winters, >beautiful sunsets, low humidity, wide open spaces and great flying weather makes this state seem ideal. However, the summers can be another story. > >At 5:30 this morning the temperature is 80 degrees and rising. The >morning sun is angling into the entrance of my shop (my garage door faces east). The temperature is rising and I know I only have about an hour to setup and spray my primer before Mother Nature forces me to quit for the day; I spray my primer outside like many RV builders. You might be asking yourself why not primer late in the day when the sun is going down or at least in the shade? Midday the temperature is over 100, by late afternoon (when my garage casts a shadow providing shade) the temperature is hovering around 104-106. This is way too hot to spray. At this temp and low humidity most of the primer dries before it reaches the parts. Not to mention the surface temperature of the parts is a bit too high. In addition, the afternoons are a bit breezy while the mornings are pretty calm. The mornings are the only option for me this time of year. > >I proceeded to setup my 4'x8' wire mesh paint platform and drop clothes >(painters plastics) outside the entrance to my shop. I had decided to debur and prep many of RV-7A fuselage parts so I could spray them at the same time-more efficient I thought. I would guess that I had about 75% or more of the fuselage components (excluding the skins) ready for primer painting. That is a very large number of parts. It has taken a lot of time to clean and prep all these parts, I started weeks back. > >I am on my second RV. My first was an RV-4 years ago. Back then I used >a wash primer but I don't remember the brand, it was gray in color, very similar to the Sherwin Williams (SW) wash primer. Unfortunately it was no longer available. I decided to use the SW wash primer on my RV-7A. I used it on the empennage and wings, but I was never happy with the results. Spitting chunks was a big problem. I never had that problem with the old gray wash primer on my RV-4. When I built my RV-4 I sprayed my primer using a Docken spray gun. This is a very simple siphon gun that is similar to the Badger hobby store paint guns. It used disposable 16 oz cups. It made cleaning up after spaying quick and easy, just through the cup away when you were done. > >As I mentioned, I was not happy with the results I was getting from the >SW wash primer. I decided to use the AKSO epoxy primer for the rest of my RV-7A project. And since I was using a new primer, I bought a new gun (HVLP) to apply it. > >Now this is where the paper or plastic fits into this long winded >story. > >Like the SW wash primer, the AKSO is a two component system. I had >several 16 oz cups left over from my Docken spray gun days and I have been using them for mixing the SW wash primer prior to loading spray gun cup. These cups are wax-coated paper cups (Dixie brand) and over 20 years old. These cups did the job, but I was running out of them. They seemed to be the "perfect" size for the amount of primer I was mixing. > >A week ago I used the AKSO for the first time. The most significant >difference between the SW wash and the AKSO is the AKSO requires a 30 minute induction time. This means you mix the two components and wait 30 minutes before spraying. This gives the two components time to react with each other. The results were great. I only had a short time to spray so I wanted to learn the behavior of the new gun and primer to help me plan my larger primer session for this weekend. > >Yesterday was a good day. I sprayed two groups of parts. By 7:30 in the >morning the temperature was approaching 90 degrees and I couldn't see through my goggles well (yes I use a respirator). All the parts in the group were well coated and it was time to cleanup. One more early morning primer session and all the parts would be coated, then on to assembly, the fun stuff. So this morning I would finish the job. > >Everything was set in place; parts were on the spray platform and now >it was time to mix the paint. I have been using my Black and Decker Workmate (if you never used one, they are great tool to have around the shop-one of my most used tools) as a surface to mix my paints. I laid plastic over it to protect it from any spills and it was also sitting on some plastic as well. The Workmate was in the shop so the primers weren't exposed to the heat and sunlight. > >I had used up all my 16 oz. cups the day before and I had shopped >around weeks earlier trying to find a replacement. I only found smaller paper cups available in the local supermarkets but they had larger disposable plastic cups. So I bought the plastic due to their size. I wanted paper but I needed the larger cup size. > >Life was good, everything was ready to primer and I mixed two batches >of primer (14 oz. each) in my new plastic cups. And off I went to work on a few other things in the shop while I waited for the induction time (30 minutes) to pass. After 15 minutes had passed, I went to stir the primer. I noticed one of the cups was "sagging" a bit. > >Alarm bells in my head went off immediately. I grabbed the trashcan. I >knew what was going to happen. The dam was leaking and it was about to rupture. Just as I lifted up the trashcan the cup dissolved away. None of the primer made it into the trashcan. Fourteen ounces of the best primer was now on the floor and covering the base of the Workmate (the plastic covering the surface didn't extend all the way down to the base). But I knew this was just the beginning. Within seconds, the second cup dissolved before I could get the trashcan under it and more epoxy made it onto the floor. Did I mention my shop floor is coated with an epoxy (two part-water based-gray)? So now I am staring at a rather large epoxy mess that only acetone will clean up. But acetone will also dissolve my epoxy floor coating. Profanities flew and the odor of acetone filled the air. > >All is cleaned up now. My epoxy coated floor looks chemically abused >and my Workmate base is camouflage colored and ready to report for military duty. I have wasted precious primer and delayed my progress once again. Hopefully next Friday I will have everything rapped up. > >The moral of the story is: > >When given the choice paper or plastic, choose paper. > > > > ________________________________________________________________________________
Subject: Re: Elevator horn alignment
Date: Jun 28, 2005
My elevator spars were pre-drilled for the horns. Unless you have a very old kit I expect yours are too. With the holes already there it turns out to be pretty easy. Bill, Now doing wing tanks. ----- Original Message ----- From: "EXT-Allen, David" <david.allen(at)boeing.com> Subject: RV9-List: Elevator horn alignment > > My RV9A instructions say to clamp the powder coated elevator horn in > place and align it with the centerline of the elevator spar before > drilling it to the spar and to the inboard rib. > > Anyone have a suggestion on how to do this alignment? > > Thanks for your help. > > Dave Allen > RV9A Empennage > > ________________________________________________________________________________
Date: Jun 29, 2005
Mine weren't predrilled but the alignment wasn't critical. I think the important thing is to make both sides the same. Small differences are taken care of when you align the elevators and then drill the holes that connect them to each other and the elevator push/pull tube. Albert Gardner RV-9A N872RV 500 hours Yuma, AZ -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of EXT-Allen, David Subject: RV9-List: Elevator horn alignment My RV9A instructions say to clamp the powder coated elevator horn in place and align it with the centerline of the elevator spar before drilling it to the spar and to the inboard rib. Anyone have a suggestion on how to do this alignment? Thanks for your help. Dave Allen RV9A Empennage ________________________________________________________________________________
Subject: Fire Extinguisher installation
Date: Jun 30, 2005
What's the consensus on the best location to mount a small 2# Fire Extinguisher in the RV9 cockpit? Mine is about 3 1/2" in diameter and about 12" long. Rick Luck N109RV ________________________________________________________________________________
Subject: Re: Fire Extinguisher installation
Date: Jun 30, 2005
Mount it on the floor, behind the co-pilot seat, (poprivets) just in front of the flap actuator on the angled portion of the floor. You can reach it easily from the pilot's seat and it won't be in the way otherwise. Your oxygen cylinder will go easily on the aft side of the flap support column on the centerline. Don't put it anywhere forward since it will always be in the way. Mike Holland N192MH ----- Original Message ----- From: "rluck" <rluck(at)prodigy.net> Subject: RV9-List: Fire Extinguisher installation > > What's the consensus on the best location to mount a small 2# Fire > Extinguisher in the RV9 cockpit? Mine is about > 3 1/2" in diameter and about 12" long. > > Rick Luck > N109RV > > > ________________________________________________________________________________
Date: Jul 02, 2005
Subject: [ eanderson(at)carolina.rr.com ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: eanderson(at)carolina.rr.com Lists: RV-List,RV3-List,RV4-List,RV6-List,RV7-List,RV8-List,RV9-List,RV10-List Subject: Brake Line Failure http://www.matronics.com/photoshare/eanderson@carolina.rr.com.07.02.2005/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Subject: Wanted: 3/32 clecos
Date: Jul 02, 2005
I'm just starting a RV-10 kit and find I need additional silver clecos. If anyone has 1 or 2 hundred for sale, I'm interested. Albert Gardner RV-9A N872RV Yuma, AZ ________________________________________________________________________________
Date: Jul 07, 2005
Subject: Re: Wanted: 3/32 clecos
Albert, I found that Brown has the best prices on clecos & if you spend $85 or more they ship for free. In fact, last time we ordered about 300 clecos, they gave us a volume discount of a few cents each. I think they came in at $.32 each. Richard Scott RV-9A Wings At 12:41 PM 7/2/2005, you wrote: > > >I'm just starting a RV-10 kit and find I need additional silver clecos. If >anyone has 1 or 2 hundred for sale, I'm interested. >Albert Gardner >RV-9A N872RV >Yuma, AZ > > ________________________________________________________________________________
Date: Jul 10, 2005
I purchased some used clecos fro www.contrysidewalk.com look in the tool shed. Here is the specific link <http://www.countrysidewalk.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=C&Category_Code=TSUTCL>They are $0.25 each. Used but in my experience they are in good condition. Watch out for the shipping charge. It could make the new ones from brown tool more attractive. Larry Rosen Richard Scott wrote: > >Albert, > >I found that Brown has the best prices on clecos & if you spend $85 or more >they ship for free. In fact, last time we ordered about 300 clecos, they >gave us a volume discount of a few cents each. I think they came in at >$.32 each. > >Richard Scott >RV-9A >Wings > >At 12:41 PM 7/2/2005, you wrote: > > >> >> >>I'm just starting a RV-10 kit and find I need additional silver clecos. If >>anyone has 1 or 2 hundred for sale, I'm interested. >>Albert Gardner >>RV-9A N872RV >>Yuma, AZ >> >> >> >> > > > > ________________________________________________________________________________
Date: Jul 14, 2005
Subject: List Digest Truncation Fixed!!
Dear Listers, I finally figured out today what was causing the occasional truncation of the daily List Digest emails. Seems that every once in a while a message would contain a single "." (period) on line all by itself. The mailers would see this and assume that this was the universal emailer signal for "end of message", and consequently wouldn't process any of the rest of the Digest message. I've put in a filter today to remove any of these sequences so we should be back in business on the Digests. Best regards, Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Electrical Tools-Wiring Supplies-Harnesses and More
Date: Jul 15, 2005
Hi Everyone, With Matt Dralle's permission, I wanted to let everyone on the list know that Affordable Panels has added electrical tools, electrical supplies, wiring harnesses and more to our inventory. We have some of the lowest prices on everything from tools, terminals, connectors, wire, electroluminescent lighting, etc. Our wiring harnesses for all Trutrak Autopilots are available in "Standard" and "Wing Root Disconnect" form, and we also offer harnesses for the Dynon EFIS, Flightcom and many others at the very best prices. Our full page catalog will be out in a couple of weeks. In the mean time, anyone interested can download the electrical portion of our catalog here. http://www.affordablepanels.com/electrical.htm All electrical orders placed on-line or faxed with a total above $175.00 will ship free via UPS GROUND. Best Regards, Fabian Lefler www.affordablepanels.com ________________________________________________________________________________
Date: Jul 16, 2005
From: Garey Wittich <gareywittich2000(at)yahoo.com>
Subject: A GUIDE TO AIRCRAFT PAINTING & CORROSION CONTROL
> This Information comes from my own research which I did for > my RV-8A, which I am building. Information applies to both Aluminum and Composite aircraft. This is the 3th printing. > > --------------- ------------- ------------ > > SAVE YOURSELF hundreds of hours of research time and > building time, by using the comprehensive > > "Guide to Painting & Corrosion Control of Aluminum > and > Composite Aircraft" > > This book took over 600+ hours of research time by > me, > a fussy RV-8A Builder. Contains 69 pages of the > latest, practical information - summarized and > gathered from MIL Standards, Paint Shops, Builders > like you (what worked or didn't), Airframe Mfgs, > etc. > Covers products from PP&G, Dupont, Sherwin W'ms, > Sterling, Poly Fiber, Deft, Randolph Paints, PRC De > Soto, US Paints, Aircraft Finishing Systems, 3M, > etc. > > Some of the Topics covered in the 30 Sections are: > * Aircraft Paints vs Auto Paints and Other > Considerations > * Corrosion Control > * Spray Guns - selecting, adjusting, using > and painting problems > * Brushes / Rollers used with Primers & > Paints > * Prep Methods for Painting - Fiberglass, > Steel and Aluminum > * Epoxy Primers for Aluminum - MIL & > Commercial, Solvent & Water Reducible > * Primers for Fiberglass & Steel > * Wash Primers & Self Etching Primers > * Other Primers - Zinc Chromate,Zinc Oxide, > Enamel > * Paint Types: MIL & Non MIL Polyurethanes > Enamel Types > Acrylics - Lacquers & Enamels > * Acid Etch / Conversion Coatings (Alodine) > * Selecting a Paint Shop > * 3M Cleaning Pads, Liquid Cleaner > compatibility > * Paint Booths and their Construction > * References - MIL Standards & Tech Orders > * Directory of Aircraft Paint Mfgs, Distrib- > utors, etc. E-Mail addresses, phone > numbers, Application Notes > > YOUR AIRPLANE is judged by it's Paint Job and it is > costly too, so have the latest "Information" in > order > to make good decisions. Contains plenty of "Do's" > and > "Don'ts" that save you time, money and frustration. > > Send a check for $26 to (includes Postage within the > US) to: > Garey Wittich RV-8A Builder > 58 Village Parkway > Santa Monica, CA. 90405 > > __________________________________ http://mobile.yahoo.com/learn/mail ________________________________________________________________________________
"RV10 Group" ,
Subject: DRDT-2 dimpling tool at Oshkosh
Date: Jul 17, 2005
Fellow RV builders. The DRDT-2 (www.experimentalaero.com) will be on display at the EAA sheet metal workshop and or the Avery Tool booth at Oshkosh. I will be at AirVenture from Monday through Saturday. Stop by and give the DRDT-2 a test drive. For those of you who already own one, I'd enjoy meeting you so stop by and say hi. Paul Merems ExperimentalAero ________________________________________________________________________________
Subject: Needed: Ride home from Osh on Sunday to Kansas City
Date: Jul 25, 2005
I've managed to get a ride up to Osh on Thursday so now I'm trying to find a ride home on Sunday. If anyone has an open seat coming back on Sunday, and it going south somewhere near Kansas City (any Texans?), I'd love to hitch a ride. You can catch me via email or on cellphone at 913-706-3087. Matthew Brandes, Van's RV-9A (Wiring) #90569 http://www.n523rv.com EAA Chapter 1329 President EAA Chapter 868 Web Editor ________________________________________________________________________________
Subject: Engine decision time ...
Date: Aug 05, 2005
0.25 HELO_DYNAMIC_DHCP Relay HELO'd using suspicious hostname (DHCP) 0.74 HELO_DYNAMIC_HCC Relay HELO'd using suspicious hostname (HCC) 1.40 HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP addr 1) Fellow builders, Its that daunting and exciting time to decide what engine to put in my RV9 (taildragger). I've decided to rule out the auto conversions and go Lycosaur (IO-320 or 360) but I could use a like a little help deciding which. The 9 fuselage is pretty much identical to the 7, so it will take a 360. I know Van's recommends the 320 as the max for the 9 presumably to limit the possibility of exceeding Vne for the airframe etc etc. I'm wondering if folks already flying their 9s are getting max performance as advertised with the 320 and thus there's no purpose to putting in the 360. My mission is fastest possible cruise for frequent trips up and down the California coast from my home base in San Francisco to destinations like LA, San Diego, Tahoe, Portland, Seattle with the occassional coast to coast jaunt. Resale value is probably less of a concern to me - I can't ever see myself selling this puppy. Any experiences, thoughts, rants, prejudices and musings will be most welcome :) __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 05, 2005
Subject: Re: Engine decision time ...
The reason for not exceeding 160hp is that the airframe isn't designed for it and can't handle it long-term. I have read accounts from those who have used 360s finding stress cracks in the tail after several hundred hours. You would be wise to listen to the factory recommendations on this issue. Gerry Filby wrote: > > >Fellow builders, > >Its that daunting and exciting time to decide what engine to >put in my RV9 (taildragger). I've decided to rule out the auto >conversions and go Lycosaur (IO-320 or 360) but I could use a >like a little help deciding which. The 9 fuselage is pretty >much identical to the 7, so it will take a 360. I know Van's >recommends the 320 as the max for the 9 presumably to limit the >possibility of exceeding Vne for the airframe etc etc. > >I'm wondering if folks already flying their 9s are getting max >performance as advertised with the 320 and thus there's no >purpose to putting in the 360. My mission is fastest possible >cruise for frequent trips up and down the California coast from >my home base in San Francisco to destinations like LA, San >Diego, Tahoe, Portland, Seattle with the occassional coast to >coast jaunt. Resale value is probably less of a concern to me >- I can't ever see myself selling this puppy. > >Any experiences, thoughts, rants, prejudices and musings will >be most welcome :) > >__g__ > >========================================================== >Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 > > > > ________________________________________________________________________________
Date: Aug 05, 2005
Thanks for your response Paul, I'm guessing that's because the tail for the 9 is larger than the 7 therefore greater twisting forces are possible - do you know by chance where the cracks appeared ? g > > > The reason for not exceeding 160hp is that the airframe isn't designed > for it and can't handle it long-term. I have read accounts from those > who have used 360s finding stress cracks in the tail after several > hundred hours. You would be wise to listen to the factory > recommendations on this issue. > > Gerry Filby wrote: > > > > > > >Fellow builders, > > > >Its that daunting and exciting time to decide what engine to > >put in my RV9 (taildragger). I've decided to rule out the auto > >conversions and go Lycosaur (IO-320 or 360) but I could use a > >like a little help deciding which. The 9 fuselage is pretty > >much identical to the 7, so it will take a 360. I know Van's > >recommends the 320 as the max for the 9 presumably to limit the > >possibility of exceeding Vne for the airframe etc etc. > > > >I'm wondering if folks already flying their 9s are getting max > >performance as advertised with the 320 and thus there's no > >purpose to putting in the 360. My mission is fastest possible > >cruise for frequent trips up and down the California coast from > >my home base in San Francisco to destinations like LA, San > >Diego, Tahoe, Portland, Seattle with the occassional coast to > >coast jaunt. Resale value is probably less of a concern to me > >- I can't ever see myself selling this puppy. > > > >Any experiences, thoughts, rants, prejudices and musings will > >be most welcome :) > > > >__g__ > > > >========================================================== > >Gerry Filby gerf(at)gerf.com > > Tel: 415 203 9177 > > > > > > > > > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 05, 2005
I do not recall where the cracks were, other than "tail" - I remember that that particular account caused me to rule out a 360 entirely. I believe there's more to it than the larger tail, too - the metal is thinner in some cases on the 9. Hey, you'll burn quite a bit less gas with a 320 anyway. And the difference in cruise speed is quite minimal. ~Paul 9A #1176 Gerry Filby wrote: > > >Thanks for your response Paul, > >I'm guessing that's because the tail for the 9 is larger than >the 7 therefore greater twisting forces are possible - do you >know by chance where the cracks appeared ? > >g > > > >> >>The reason for not exceeding 160hp is that the airframe isn't designed >>for it and can't handle it long-term. I have read accounts from those >>who have used 360s finding stress cracks in the tail after several >>hundred hours. You would be wise to listen to the factory >>recommendations on this issue. >> >>Gerry Filby wrote: >> >> >> >>> >>> >>>Fellow builders, >>> >>>Its that daunting and exciting time to decide what engine to >>>put in my RV9 (taildragger). I've decided to rule out the auto >>>conversions and go Lycosaur (IO-320 or 360) but I could use a >>>like a little help deciding which. The 9 fuselage is pretty >>>much identical to the 7, so it will take a 360. I know Van's >>>recommends the 320 as the max for the 9 presumably to limit the >>>possibility of exceeding Vne for the airframe etc etc. >>> >>>I'm wondering if folks already flying their 9s are getting max >>>performance as advertised with the 320 and thus there's no >>>purpose to putting in the 360. My mission is fastest possible >>>cruise for frequent trips up and down the California coast from >>>my home base in San Francisco to destinations like LA, San >>>Diego, Tahoe, Portland, Seattle with the occassional coast to >>>coast jaunt. Resale value is probably less of a concern to me >>>- I can't ever see myself selling this puppy. >>> >>>Any experiences, thoughts, rants, prejudices and musings will >>>be most welcome :) >>> >>>__g__ >>> >>>========================================================== >>>Gerry Filby gerf(at)gerf.com >>> Tel: 415 203 9177 >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Aug 05, 2005
I too looked hard at engine size, mainly because I favored the 360. But the tail differences, stories about cracks and the spar "stub" that is sandwiched into the fuselage being so much smaller than the RV 6, and Vans recommendation is enough for me. I just can' imagine what the feeling would be in those last final seconds after the plane started coming apart at 8000 feet as you started telling yourself, "Van really knows best". John Disher, last 10% taking 90% -------Original Message------- From: Gerry Filby Date: 08/05/05 14:55:47 Subject: Re: RV9-List: Engine decision time ... Thanks for your response Paul, I'm guessing that's because the tail for the 9 is larger than the 7 therefore greater twisting forces are possible - do you know by chance where the cracks appeared ? g > > > The reason for not exceeding 160hp is that the airframe isn't designed > for it and can't handle it long-term. I have read accounts from those > who have used 360s finding stress cracks in the tail after several > hundred hours. You would be wise to listen to the factory > recommendations on this issue. > > Gerry Filby wrote: > > > > > > >Fellow builders, > > > >Its that daunting and exciting time to decide what engine to > >put in my RV9 (taildragger). I've decided to rule out the auto > >conversions and go Lycosaur (IO-320 or 360) but I could use a > >like a little help deciding which. The 9 fuselage is pretty > >much identical to the 7, so it will take a 360. I know Van's > >recommends the 320 as the max for the 9 presumably to limit the > >possibility of exceeding Vne for the airframe etc etc. > > > >I'm wondering if folks already flying their 9s are getting max > >performance as advertised with the 320 and thus there's no > >purpose to putting in the 360. My mission is fastest possible > >cruise for frequent trips up and down the California coast from > >my home base in San Francisco to destinations like LA, San > >Diego, Tahoe, Portland, Seattle with the occassional coast to > >coast jaunt. Resale value is probably less of a concern to me > >- I can't ever see myself selling this puppy. > > > >Any experiences, thoughts, rants, prejudices and musings will > >be most welcome :) > > > >__g__ > > > > > >Gerry Filby gerf(at)gerf.com > > Tel: 415 203 9177 > > > > > > > > > > -- __g__ Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 05, 2005
Hi Gerry. I would think seriously about putting more than 160 HP in your 9. The empennage and wings very different from the 7. Your in SF? Come down to Watsonville and fly my 9. It only has 150 HP and I can usually eak out 190 MPH. I don't do it other than very short test because it redlines the prop. --- Gerry Filby wrote: > > > > Fellow builders, > > Its that daunting and exciting time to decide what > engine to > put in my RV9 (taildragger). I've decided to rule > out the auto > conversions and go Lycosaur (IO-320 or 360) but I > could use a > like a little help deciding which. The 9 fuselage > is pretty > much identical to the 7, so it will take a 360. I > know Van's > recommends the 320 as the max for the 9 presumably > to limit the > possibility of exceeding Vne for the airframe etc > etc. > > I'm wondering if folks already flying their 9s are > getting max > performance as advertised with the 320 and thus > there's no > purpose to putting in the 360. My mission is > fastest possible > cruise for frequent trips up and down the California > coast from > my home base in San Francisco to destinations like > LA, San > Diego, Tahoe, Portland, Seattle with the occassional > coast to > coast jaunt. Resale value is probably less of a > concern to me > - I can't ever see myself selling this puppy. > > Any experiences, thoughts, rants, prejudices and > musings will > be most welcome :) > > __g__ > > ========================================================== > > Gerry Filby > gerf(at)gerf.com > Tel: 415 203 9177 > > > > browse > Subscriptions page, > FAQ, > > > > > > ________________________________________________________________________________
Date: Aug 05, 2005
Gerry and gang.... The RV-7 now uses the same rudder as the -9. This was a change they made about a year or more ago. The rudder cracking is usually along the trailing edge of the rudder and is caused by the flexing near the ends of the stiffeners on the skin. It is recommended that you proseal or glue the ends of the stiffeners to the skin to keep the skin from flexing and developing cracks. (Not to say that a larger engine isn't contributing to the problem.. but RV-9's with O-320's also develop the problems.. ask Andy K.) I fall in line with everyone else on the engine choice... stick with an (I)O-320 as Van's recommends... get a 160hp if you want. All the numbers I've seen have been close or right on with what Van's advertises. Besides.. do you really want to run near the top end speed all the time?? Are you _really_ going to notice 5-10mph difference at the top end?? Just my $.05 worth Matthew Brandes, Van's RV-9A (Wiring) #90569 http://www.n523rv.com EAA Chapter 1329 President EAA Chapter 868 Web Editor ________________________________________________________________________________
Date: Aug 05, 2005
Phew ! I used T-88 on my trailing edges so I'm hoping cracking won't be something I have to deal with. If folks are getting the performance with 160hp then, as you say, it doesn't make sense to divert from the plans. Thx g > > > Gerry and gang.... > > The RV-7 now uses the same rudder as the -9. This was a change > they made > about a year or more ago. The rudder cracking is usually along > the trailing > edge of the rudder and is caused by the flexing near the ends of the > stiffeners on the skin. It is recommended that you proseal or > glue the ends > of the stiffeners to the skin to keep the skin from flexing and > developing > cracks. (Not to say that a larger engine isn't contributing to the > problem.. but RV-9's with O-320's also develop the problems.. > ask Andy K.) > > I fall in line with everyone else on the engine choice... stick with an > (I)O-320 as Van's recommends... get a 160hp if you want. All > the numbers > I've seen have been close or right on with what Van's > advertises. Besides.. > do you really want to run near the top end speed all the time?? Are you > _really_ going to notice 5-10mph difference at the top end?? > > Just my $.05 worth > > Matthew Brandes, > Van's RV-9A (Wiring) > #90569 > http://www.n523rv.com > > EAA Chapter 1329 President > EAA Chapter 868 Web Editor > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 05, 2005
Let's see... spend 3000 hours to build an airplane that cruises 40 kt faster than a 'spam can'. If you fly 100 hrs per year in the RV, it would be about 130 hours to cover the same distance in a '172. So you save 30 hours per year by having an RV rather than a 172. Break even is 100 years. Putting an O-360 in might reduce the break-even to 95 years. So let's not kid ourselves that we're building an airplane to save time. We're building because we enjoy it, and flying an RV is a lot more fun than flying a 172. It's a bonus to get where we are going quickly and in style. One bit of advice that I got was to install an oxygen system, fly high to take advantage of favourable winds and weather and, save time that way. Vern Little RV-9A in fiberglass hell Gerry Filby wrote: > > >Thanks for your response Paul, > >I'm guessing that's because the tail for the 9 is larger than >the 7 therefore greater twisting forces are possible - do you >know by chance where the cracks appeared ? > >g > > > >> >>The reason for not exceeding 160hp is that the airframe isn't designed >>for it and can't handle it long-term. I have read accounts from those >>who have used 360s finding stress cracks in the tail after several >>hundred hours. You would be wise to listen to the factory >>recommendations on this issue. >> >>Gerry Filby wrote: >> >> >> >>> >>> >>>Fellow builders, >>> >>>Its that daunting and exciting time to decide what engine to >>>put in my RV9 (taildragger). I've decided to rule out the auto >>>conversions and go Lycosaur (IO-320 or 360) but I could use a >>>like a little help deciding which. The 9 fuselage is pretty >>>much identical to the 7, so it will take a 360. I know Van's >>>recommends the 320 as the max for the 9 presumably to limit the >>>possibility of exceeding Vne for the airframe etc etc. >>> >>>I'm wondering if folks already flying their 9s are getting max >>>performance as advertised with the 320 and thus there's no >>>purpose to putting in the 360. My mission is fastest possible >>>cruise for frequent trips up and down the California coast from >>>my home base in San Francisco to destinations like LA, San >>>Diego, Tahoe, Portland, Seattle with the occassional coast to >>>coast jaunt. Resale value is probably less of a concern to me >>>- I can't ever see myself selling this puppy. >>> >>>Any experiences, thoughts, rants, prejudices and musings will >>>be most welcome :) >>> >>>__g__ >>> >>>========================================================== >>>Gerry Filby gerf(at)gerf.com >>> Tel: 415 203 9177 >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Aug 06, 2005
Paul, I have chosen the IO 360 for my "9". The reason is I have the option of using low compression pistons and using any type of gas as the fuel situation becomes fluid.(?) The low comp. pistons give me 167 hp. And I am using a fixed pitch prop (buying the engine with a solid crank so I won't add a controable pitch later). This will not let me get over 160 hp on take off because of the high pitch required for the RV's. I flight, at low altitudes, I will control my power to less than 75% to not exceed the airframe requirements. However at altitude, where the hp starts to run down, I will have the extra hp to keep it at the 160 hp level. I am going to be using my "9" as a cross country bird as I live in Florida and have relatives in the Ill. area and Louisiana area. I am also retiring in three years and I want to travel back out west. The extra hp will be available for the high country. At this point, Mattituck is building my IO 360 in the standard 180 HP configuration with 2 "P" mags. This leaves me the option of low compression pistons if the situation on gas in this country changes. I want to keep flying even if I have to use car gas to do it. Does this confuse you ? Took me a while to get here but I am comfortable with the fact that I will have to watch my power. I have the GRT EFIS system and monitoring power will be as simple as looking at the engine power percentage readout. Power at altitude was the determining issue. Now if I can get my wife to consider Oxygen, I can go even higher and still get good speed. Plus most of the flying will be against the wind as we leave Florida. With the prevailing NW winds in this country, I will not watch the cars match my speed on the ground. (done that and don't like it). I'm at the wiring phase of my "9" with the canopy next. Jim Nelson ________________________________________________________________________________
Date: Aug 06, 2005
Hi Pete, I'm in St.Petersburg. Actually Seminole which is a bit north and west. We are south of Largo about 1/2 mile east of the coast. Jim ________________________________________________________________________________
Date: Aug 06, 2005
I'll throw my $.02 in. On the Superior Air Parts XP 360 website they have a position paper on why you can use "their" derated XP-360 in a Vans RV-9. Why? They want you to buy their engine. Just remember - higher HP = higher GPH!! Personally, I will use a IO-320 clone. Also, in a RVator from several issues back, Vans addressed the effect on Vne of carrying too much HP to higher altitudes. The fuse, verticle stabilizer and rudder are identical between the 7 & 9 series. The cracks were from the rivets on the stiffners on the rudder. I have seen these same cracks on a RV-4 rudder, however on the 4 the cracks were on the hinge end of the stiffners. My personal, uneducated theory on the origin of the cracks is from work hardening the metal from over "smacking" the dimpler on the skins and over driving the rivets on the stiffners. Ralph RV9A wings, fuse in box Livermore, CA ________________________________________________________________________________
Subject: RE: RV9-List Digest: 4 Msgs - 08/06/05
Date: Aug 07, 2005
It is true that it takes a certain amount of fuel to obtain a certain horsepower. By limiting his power, he'll also be limiting his fuel right?! Also, we're not talking about the difference between an RV and a Mig 15 that burns 80 gals for a high speed pass down the runway here are we?! Mark www.4sierratango.com >From: "Ralph Cloud" <rv9ralph(at)flash.net> >Subject: RE: RV9-List: Engine decision time ... > > >I'll throw my $.02 in. On the Superior Air Parts XP 360 website they >have a position paper on why you can use "their" derated XP-360 in a >Vans RV-9. Why? They want you to buy their engine. Just remember - >higher HP = higher GPH!! > >Personally, I will use a IO-320 clone. Also, in a RVator from several >issues back, Vans addressed the effect on Vne of carrying too much HP to >higher altitudes. > >The fuse, verticle stabilizer and rudder are identical between the 7 & 9 >series. The cracks were from the rivets on the stiffners on the rudder. >I have seen these same cracks on a RV-4 rudder, however on the 4 the >cracks were on the hinge end of the stiffners. My personal, uneducated >theory on the origin of the cracks is from work hardening the metal from >over "smacking" the dimpler on the skins and over driving the rivets on >the stiffners. > >Ralph >RV9A wings, fuse in box >Livermore, CA ________________________________________________________________________________
Date: Aug 07, 2005
Mark You are right, about 20,000 BTUs per pound of AV gas. If the volumetric efficiency is the same, producing the same HP, the only extra fuel burn would be from the increase in weight and friction difference of the larger engine, maybe 1 percent. The really sad part is we only get about 30 - 40 percent efficiency. This is where the auto conversion people can point and laugh at us using a Lycosaur. We lose about 40 - 45 percent out the exhaust and 15 to 20 percent in cooling, and 5 - 10 percent to friction. So their turbo charged water cooled engines are much better in that respect. At least for me the stupid human variable that burns more fuel, I tend to want to push the throttle a little more, go a little faster....hey it's only 75%. Maybe instead of looking at an O-320 or O-360 I should start looking for that 118 hp engine vans gives specs on... Ken -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Mark Taylor Subject: RV9-List: RE: RV9-List Digest: 4 Msgs - 08/06/05 It is true that it takes a certain amount of fuel to obtain a certain horsepower. By limiting his power, he'll also be limiting his fuel right?! Also, we're not talking about the difference between an RV and a Mig 15 that burns 80 gals for a high speed pass down the runway here are we?! Mark www.4sierratango.com >From: "Ralph Cloud" <rv9ralph(at)flash.net> >Subject: RE: RV9-List: Engine decision time ... > > >I'll throw my $.02 in. On the Superior Air Parts XP 360 website they >have a position paper on why you can use "their" derated XP-360 in a >Vans RV-9. Why? They want you to buy their engine. Just remember - >higher HP = higher GPH!! > >Personally, I will use a IO-320 clone. Also, in a RVator from several >issues back, Vans addressed the effect on Vne of carrying too much HP to >higher altitudes. > >The fuse, verticle stabilizer and rudder are identical between the 7 & 9 >series. The cracks were from the rivets on the stiffners on the rudder. >I have seen these same cracks on a RV-4 rudder, however on the 4 the >cracks were on the hinge end of the stiffners. My personal, uneducated >theory on the origin of the cracks is from work hardening the metal from >over "smacking" the dimpler on the skins and over driving the rivets on >the stiffners. > >Ralph >RV9A wings, fuse in box >Livermore, CA ________________________________________________________________________________
Date: Aug 08, 2005
Thanks to all of you for your helpful posts - lots of food for thought ! g > > > > Fellow builders, > > Its that daunting and exciting time to decide what engine to > put in my RV9 (taildragger). I've decided to rule out the auto > conversions and go Lycosaur (IO-320 or 360) but I could use a > like a little help deciding which. The 9 fuselage is pretty > much identical to the 7, so it will take a 360. I know Van's > recommends the 320 as the max for the 9 presumably to limit the > possibility of exceeding Vne for the airframe etc etc. > > I'm wondering if folks already flying their 9s are getting max > performance as advertised with the 320 and thus there's no > purpose to putting in the 360. My mission is fastest possible > cruise for frequent trips up and down the California coast from > my home base in San Francisco to destinations like LA, San > Diego, Tahoe, Portland, Seattle with the occassional coast to > coast jaunt. Resale value is probably less of a concern to me > - I can't ever see myself selling this puppy. > > Any experiences, thoughts, rants, prejudices and musings will > be most welcome :) > > __g__ > > ========================================================== > Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 09, 2005
From: Gregory Richardson <rv9flyer(at)sbcglobal.net>
Gerry, I tried to stay out of this, cause it's kinda like which came first, the chicken or the egg. I however began working out numbers one day, which I think you should really do prior to deciding on either engine. I spoke unofficially to Van's staff at Oshkosh, and found that IF you really derate the 360 to 160 horses, they really don't think it will hurt. I approached this from the standpoint of 320's becomming somewhat hard to come by, however Lycosaur just released a 320 experimental version just like the experimental 360, and should prove to inject more engines into the masses. I personally am going to go ahead and install an O-320 and inject it, for the following reasons. It has a tried and proven fuel burn of 8.5 gph, versus whatever I end up with in the IO360, I don't have to sweat the bigger engine at 10,000', and redline is redline. I would urge you to work out the same problem that I did on your trusty E6B, and see where it leaves you for your trip lengths. I once compared a Spamcan 172 at 120 kts, to a Piper turbo Dakota at 145kts. I found that on a trip length of 500 miles, I would arrive a sum total of 43 minutes faster, but burn 15 gallons more fuel. Now we all pride ourselves on flying straight to the dest., but know that it rarely happens. I found that with the higher operating costs, it was not worth it to me. Work out your own usual trips, and work it at a cruise of what Van calls out, versus a "high" cruise. I think you will find that it is only minutes, and really not worth the extra trouble and worry. After all, we started this cause we wanted to fly, not sit on the ground. Good luck in your decision. Greg Richardson RV-9a fuselage Thanks to all of you for your helpful posts - lots of food for thought ! g > > > > Fellow builders, > > Its that daunting and exciting time to decide what engine to > put in my RV9 (taildragger). I've decided to rule out the auto > conversions and go Lycosaur (IO-320 or 360) but I could use a > like a little help deciding which. The 9 fuselage is pretty > much identical to the 7, so it will take a 360. I know Van's > recommends the 320 as the max for the 9 presumably to limit the > possibility of exceeding Vne for the airframe etc etc. > > I'm wondering if folks already flying their 9s are getting max > performance as advertised with the 320 and thus there's no > purpose to putting in the 360. My mission is fastest possible > cruise for frequent trips up and down the California coast from > my home base in San Francisco to destinations like LA, San > Diego, Tahoe, Portland, Seattle with the occassional coast to > coast jaunt. Resale value is probably less of a concern to me > - I can't ever see myself selling this puppy. > > Any experiences, thoughts, rants, prejudices and musings will > be most welcome :) > > __g__ > > ========================================================== > Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 09, 2005
Subject:
rv7-list(at)matronics.com, rv8-list(at)matronics.com, rv9-list(at)matronics.com, Listers, Gary VanRemortel just sent me an update to the RV Yeller Pages and it can be found here: http://www.matronics.com/YellerPages/ Thanks Gary!! Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Van's Firewall Forward Kit ... worth the money ?
Date: Aug 10, 2005
0.25 HELO_DYNAMIC_DHCP Relay HELO'd using suspicious hostname (DHCP) 0.74 HELO_DYNAMIC_HCC Relay HELO'd using suspicious hostname (HCC) 1.40 HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP addr 1) More shopping decisions ... Van's Firewall Forward kit for the RV-9 (constant speed prop) is some $4,300. Whilst Van's kits are usually very good value for money, I was wondering what experiences people had with this kit. Were you happy with the qauality ? Were there things missing or things not needed ? Did you still have to fork out for extras ? Would you buy it again ? PS Most likely I'm going to get an IO-320 from Aerosport which might have some bearing on the cost effectiveness of the FWF kit. __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 10, 2005
Subject: Re: Van's Firewall Forward Kit ... worth the money ?
Hi Gerry, I used the firewall forward kit and believed what they told me, which was it is little cheaper than buying the individual parts piece meal. It makes the job a lot easier. The only waste I noticed was in the wiring kit. It is a genric kit to wire any RV. Consequently their was quite a bit of extra cables. Dennis --- Gerry Filby wrote: > > > > More shopping decisions ... > > Van's Firewall Forward kit for the RV-9 (constant > speed prop) > is some $4,300. Whilst Van's kits are usually very > good value > for money, I was wondering what experiences people > had with > this kit. > > Were you happy with the qauality ? > Were there things missing or things not needed ? > Did you still have to fork out for extras ? > Would you buy it again ? > > PS Most likely I'm going to get an IO-320 from > Aerosport which > might have some bearing on the cost effectiveness of > the FWF kit. > > __g__ > > ========================================================== > > Gerry Filby > gerf(at)gerf.com > Tel: 415 203 9177 > > > > browse > Subscriptions page, > FAQ, > > > > > > ________________________________________________________________________________
Date: Aug 10, 2005
Hi Gerry: Ive bought the engine from Aerosport and there is nothing to complain about the deal and the engine. Excellent. Into the FWF kit from VANS you could personalise the itens. For example: if you decide to buy a carb engine you dont need the material for injector one. The best thing to do is to ask VANS a list of material in the FWF and remove or add some itens. JC - Aracaju - Brasil PU-JCI RV-9A QB Flying ________________________________________________________________________________
Date: Aug 10, 2005
Definitely 80% of the wiring part of the kit was useless. Most of the wires were for other models and unless you are going to install Vans prepunched panel most of the smaller wires are useless also. I just cut them up and used them as I could. Although, what do you do when you have to crimp a 003 wire? -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Gerry Filby Subject: RV9-List: Van's Firewall Forward Kit ... worth the money ? More shopping decisions ... Van's Firewall Forward kit for the RV-9 (constant speed prop) is some $4,300. Whilst Van's kits are usually very good value for money, I was wondering what experiences people had with this kit. Were you happy with the qauality ? Were there things missing or things not needed ? Did you still have to fork out for extras ? Would you buy it again ? PS Most likely I'm going to get an IO-320 from Aerosport which might have some bearing on the cost effectiveness of the FWF kit. __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 11, 2005
Gerry, Since I'm building a really unusual combination (RV-9 tip-up w/ an O-290-D2 & a throttle quadrant rather than the Cessna style throttle) The FWF and finishing kits are a bit of a challenge. For example, my plane will require the O-235 cowl (Didn't know they were different) and an O-320 exhaust stack. I called Van's and they sent me the FWF parts list. From that I selected the items I needed and am about to place the order. It turns out that Van's doesn't discount the times in the FWF kit so you don't loose any money by adding and/or deleting items from the kit. Bill Repucci www.repucci.com/bill/baf.html -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Roger Ping Subject: RE: RV9-List: Van's Firewall Forward Kit ... worth the money ? Definitely 80% of the wiring part of the kit was useless. Most of the wires were for other models and unless you are going to install Vans prepunched panel most of the smaller wires are useless also. I just cut them up and used them as I could. Although, what do you do when you have to crimp a 003 wire? -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Gerry Filby Subject: RV9-List: Van's Firewall Forward Kit ... worth the money ? More shopping decisions ... Van's Firewall Forward kit for the RV-9 (constant speed prop) is some $4,300. Whilst Van's kits are usually very good value for money, I was wondering what experiences people had with this kit. Were you happy with the qauality ? Were there things missing or things not needed ? Did you still have to fork out for extras ? Would you buy it again ? PS Most likely I'm going to get an IO-320 from Aerosport which might have some bearing on the cost effectiveness of the FWF kit. __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 12, 2005
YES. ----- Original Message ----- From: "Gerry Filby" <gerf(at)gerf.com> Subject: RV9-List: Van's Firewall Forward Kit ... worth the money ? > > > More shopping decisions ... > > Van's Firewall Forward kit for the RV-9 (constant speed prop) > is some $4,300. Whilst Van's kits are usually very good value > for money, I was wondering what experiences people had with > this kit. > > Were you happy with the qauality ? > Were there things missing or things not needed ? > Did you still have to fork out for extras ? > Would you buy it again ? > > PS Most likely I'm going to get an IO-320 from Aerosport which > might have some bearing on the cost effectiveness of the FWF kit. > > __g__ > > ========================================================== > Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 > > > > > > ________________________________________________________________________________
Subject: convert from tip up to slider?
Date: Aug 14, 2005
I am just beginning the quick build fuselage. Does anyone know if it is possible/feasible to convert from tip up canopy style to slider canopy at this early stage? Thanks. Lance J ________________________________________________________________________________
Subject: Re: convert from tip up to slider?
Date: May 14, 2005
I just finnished the slider a month or so ago, and I wouldn't switch if you have already started , each of them have positive and negative issues you didn't say how far along you are on the tip up but I don't think it would be worth changing if you have the finnish kit already.. build it, fly it , and do it on the next one.. :) Danny.. ----- Original Message ----- From: "Lance Sorensen" <lancej(at)charter.net> Subject: RV9-List: convert from tip up to slider? > > I am just beginning the quick build fuselage. Does anyone know if > it is possible/feasible to convert from tip up canopy style to > slider canopy > at this early stage? Thanks. > > Lance J > > > ________________________________________________________________________________
Subject: Roller tappets - another ~ - OUCH !!
Date: Aug 16, 2005
0.25 HELO_DYNAMIC_DHCP Relay HELO'd using suspicious hostname (DHCP) 0.74 HELO_DYNAMIC_HCC Relay HELO'd using suspicious hostname (HCC) 1.40 HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP addr 1) Folks, Looks like adding the roller tappet option to your 320 or 360 is going to add another $3-4000 to the price (that's Aerosport's current estimate). I've been hunting around and haven't found much discussion on the upgrade apart from various announcements from Delphi and Lycoming. This "new technology" solves premature wear and corrosion only ? They also enable alternate cam profiles ? (Not likely for this first timer.) Is it worth it ? If the subject's been beaten to death already I'd happily take a link to some reference ... __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 16, 2005
Subject: Re: Roller tappets - another ~ - OUCH !!
Gerry, I purchased an O-320 from Aero Sport with roller tappets. They were very careful in representing the advantages... solving premature wear, and not performance benefits. There will probably be a bit of performance boost due to lower friction, but that's it. Why did I purchase roller tappets? It looks to me that the industry is changing over... Lycoming is going this way, for example. Eventually, your engine will be the 'old style' or the 'new style'. I think this may affect resale value. More significantly, if it saves an overhaul later on, it will pay for itself. Realistically, if you fly every week, it probably won't matter. On the west coast (BC), there can be bad weather for weeks, and it's a high humidity/salt air environment. Anything to delay corrosion problems is worth it. I was a bit put off by the $4K additional price tag, but I went ahead anyway (it fits in my budget). I hope to have the first Aero Sport O-320 roller cam engine flying this fall. Vern Little RV-9A Gerry Filby wrote: > > >Folks, > >Looks like adding the roller tappet option to your 320 or 360 >is going to add another $3-4000 to the price (that's Aerosport's >current estimate). > >I've been hunting around and haven't found much discussion on >the upgrade apart from various announcements from Delphi and >Lycoming. This "new technology" solves premature wear and >corrosion only ? They also enable alternate cam profiles ? (Not >likely for this first timer.) > >Is it worth it ? > >If the subject's been beaten to death already I'd happily take >a link to some reference ... > >__g__ > >========================================================== >Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 > > > > ________________________________________________________________________________
Date: Aug 16, 2005
the cost/benefit analysis seems a little extensive for a quick list response, but you have begun the process of looking at the cost, not add benefit (savings), how much you fly and how long you will fly at the current rate. How many overhauls per set of roller tappets? -------------- Original message -------------- > > > Folks, > > Looks like adding the roller tappet option to your 320 or 360 > is going to add another $3-4000 to the price (that's Aerosport's > current estimate). > > I've been hunting around and haven't found much discussion on > the upgrade apart from various announcements from Delphi and > Lycoming. This "new technology" solves premature wear and > corrosion only ? They also enable alternate cam profiles ? (Not > likely for this first timer.) > > Is it worth it ? > > If the subject's been beaten to death already I'd happily take > a link to some reference ... > > __g__ > > ========================================================== > Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 > > > > > > the cost/benefit analysis seems a little extensive for a quick list response, but you have begun the process of looking at the cost, not add benefit (savings), how much you fly and how long you will fly at the current rate. How many overhauls per set of roller tappets? -------------- Original message -------------- -- RV9-List message posted by: Gerry Filby Folks, Looks like adding the roller tappet option to your 320 or 360 is going to add another $3-4000 to the price (that's Aerosport's current estimate). I've been hunting around and haven't found much discussion on the upgrade apart from various announcements from Delphi and Lycoming. This "new technology" solves premature wear and corrosion only ? They also enable alternate cam profiles ? (Not likely for this first timer.) Is it worth it ? If the subject's been beaten to death already I'd happily take a link to some reference ... __g__ ======================================= =================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Aug 16, 2005
Hi Gerry, Yes, I also checked out the roller cam. I would like to do it but for a 20% bump on the price, No WAY. I would go for a grand more but no way the 3 - 4000 extra. The marketing people have lost their way---- Jim Nelson IO-360 on order from Mattituck ________________________________________________________________________________
Date: Aug 16, 2005
Don't know if you all realize this or not but the price doesn't consist of just the roller cam and followers, it is a brand new engine kit. Zero time on every part AND built from all OEM parts. Big difference. Call or email us, we would be more than happy to discuss the kit engine in detail. Allen Barrett BPE, Inc. www.barrettprecisionengines.com (918) 835-1089 phone -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of James H Nelson Subject: Re: RV9-List: Roller tappets - another ~ - OUCH !! Hi Gerry, Yes, I also checked out the roller cam. I would like to do it but for a 20% bump on the price, No WAY. I would go for a grand more but no way the 3 - 4000 extra. The marketing people have lost their way---- Jim Nelson IO-360 on order from Mattituck ________________________________________________________________________________
Date: Aug 18, 2005
Subject: (no subject)
N951DM flew for the first time last Thurs. Still smiling!!In my first few test flights,am getting higher than desired cylinder head temps on #3 and 4(Aerosport o-320), Am also getting a lot of advice on the cause and would like to hear from anyone with the same type experience,especially the hot weather(Az,Nm,So Cal). What did you do,etc. I redid some baffling(helped some) Anybody enlarge the exit on the cowl?? Thanks, Dick Migas 951DM, flying...... ________________________________________________________________________________
Date: Aug 18, 2005
Subject: high CHT temp.
Hi Dick : Ivew got the same problem. Aerosport O-320 D2A. Till now I did nothing since my -9A is inside the paint shop. In my first flight Ive climbed to FL035. The ground temp was 83F and during the climb the CHT raise to 450F, full throtle. First thing Ill do will be sealling the baffling front part with crankcase. Keep me informed. JC - Aracaju - Brasil PU-JCI RV-9A QB 1030 h bulding : 2,5 h flying ________________________________________________________________________________
Subject: Re: (no subject)
Date: Aug 18, 2005
Dick, Congratulations on the safe flight! I think that you will find that new cylinders will run hot for the first 10-15 hours. I first flew mine in 90-100 degree weather from an airport at 4250 feet MSL. I too was concerned about the high temps which sometimes were very near the upper CHT limit. In such weather, I was advised to keep climbs slow, carefully watching the CHT. I found that just as the old heads told me, the temps gradually decreased with time. 3 and 4 are still slightly hotter even after 98 hours. This makes sense to me because they are in the back, with 3 for some reason slightly hotter than 4. I noted a similar trend with the oil temp. The oil temp kept getting lower until around 40 hours, when it leveled off, and has been flat ever since. I used straight mineral oil for the first 20 tach hours, then switched to 15-50. I think that it may be too soon to consider modifying cowling, since you haven't really broken the engine in yet. I find that the standard Van's configuration for me is adequate, and I have no cooling problems. Even during steep climbs on 100 degree days. This was my experience, but you may want to consult Aerosport or your local A&P. Dale ----- Original Message ----- From: <KDMIGAS(at)aol.com> Subject: RV9-List: (no subject) > > N951DM flew for the first time last Thurs. Still smiling!!In my first few > test flights,am getting higher than desired cylinder head temps on #3 and > 4(Aerosport o-320), Am also getting a lot of advice on the cause and would > like to > hear from anyone with the same type experience,especially the hot > weather(Az,Nm,So Cal). What did you do,etc. > I redid some baffling(helped some) > Anybody enlarge the exit on the cowl?? > Thanks, > Dick Migas 951DM, flying...... > > > ________________________________________________________________________________
Date: Aug 18, 2005
At OSH this year, I noticed a number of examples of raised baffles in front of #1 and #2 to increase the temperatures there and increase the downflow further back. It might help. N927BJ (90616) is in the paint booth right now and will be beginning final assembly next week at KLGU John Kerr -------------- Original message -------------- > > Dick, > > Congratulations on the safe flight! > > I think that you will find that new cylinders will run hot for the first > 10-15 hours. I first flew mine in 90-100 degree weather from an airport at > 4250 feet MSL. I too was concerned about the high temps which sometimes > were very near the upper CHT limit. In such weather, I was advised to keep > climbs slow, carefully watching the CHT. I found that just as the old > heads told me, the temps gradually decreased with time. 3 and 4 are still > slightly hotter even after 98 hours. This makes sense to me because they > are in the back, with 3 for some reason slightly hotter than 4. > > I noted a similar trend with the oil temp. The oil temp kept getting lower > until around 40 hours, when it leveled off, and has been flat ever since. I > used straight mineral oil for the first 20 tach hours, then switched to > 15-50. > > I think that it may be too soon to consider modifying cowling, since you > haven't really broken the engine in yet. I find that the standard Van's > configuration for me is adequate, and I have no cooling problems. Even > during steep climbs on 100 degree days. > > This was my experience, but you may want to consult Aerosport or your local > A&P. > > Dale > > ----- Original Message ----- > From: > To: > Subject: RV9-List: (no subject) > > > > > > N951DM flew for the first time last Thurs. Still smiling!!In my first few > > test flights,am getting higher than desired cylinder head temps on #3 and > > 4(Aerosport o-320), Am also getting a lot of advice on the cause and would > > like to > > hear from anyone with the same type experience,especially the hot > > weather(Az,Nm,So Cal). What did you do,etc. > > I redid some baffling(helped some) > > Anybody enlarge the exit on the cowl?? > > Thanks, > > Dick Migas 951DM, flying...... > > > > > > > > > > > > At OSH this year, I noticed a number of examples of raised baffles in front of #1 and #2 to increase the temperatures there and increase the downflow further back. It might help. N927BJ (90616) is in the paint booth right now and will be beginning final assembly next week at KLGU John Kerr -------------- Original message -------------- -- RV9-List message posted by: "Dale Larsen" <SLICKROCK@BEEN-THERE.COM> Dick, Congratulations on the safe flight! I think that you will find that new cylinders will run hot for the first 10-15 hours. I first flew mine in 90-100 degree weather from an airport at 4250 feet MSL. I too was concerned about the high temps which sometimes were very near the upper CHT limit. In such weather, I was advised to keep climbs slow, carefully watching the CHT. I found that just as the old heads told me, the temps gradually decreased with time. 3 and 4 are still slightly hotter even after 98 hours. This makes sense to me because they are in the back, with 3 for some reason slightly hotter than 4. I noted a simi lar trend with the oil temp. The oil temp kept getting lower until around 40 hours, when it leveled off, and has been flat ever since. I used straight mineral oil for the first 20 tach hours, then switched to 15-50. I think that it may be too soon to consider modifying cowling, since you haven't really broken the engine in yet. I find that the standard Van's configuration for me is adequate, and I have no cooling problems. Even during steep climbs on 100 degree days. This was my experience, but you may want to consult Aerosport or your local AP. Dale ----- Original Message ----- From: <KDMIGAS(at)AOL.COM> To: Subject: RV9-List: (no subject) -- RV9-List message posted by: KDMIGAS(at)aol.com N951DM flew for the first time last Thurs. Still smiling!!In my first few test flights,am getting higher than desired cylinder head temps on #3 and 4(Aerosport o-320), Am also getting a lot of advice on the cause and would like to hear from anyone with the same type experience,especially the hot weather(Az,Nm,So Cal). What did you do,etc. I redid some baffling(helped some) Anybody enlarge the exit on the cowl?? Thanks, Dick Migas 951DM, flying...... ________________________________________________________________________________
Subject: Nosewheel collapse another view
Date: Aug 19, 2005
Gents, I too am building an RV-7A and have been following the discussions about the recent nosewheel collapse. I am concerned about this situation as many of you are. I have talked with Ken Krueger (Van's engineering), who I have a tremendous respect for, about some of these recent accidents. I am certain Van's Aircraft takes this situation very seriously. However if you step back and ask yourself are there a few RV'As out there that have had the highest number of landings to date, where would you find them? What kind of landing have they seen? Grass or paved runways? My best guess is these are the RV-7A and RV-9A prototypes at Van's Aircraft. Who flies these? Van's staff. Where have they landed? Grass or pavement? Both. Have they taxied on grass? Yes. Have they botched a few landing? I would think so. Now I would bet these two aircraft have 10 times or more the numbers of landing then any another RV's out there and their nose gears haven't collapsed. I am not saying there isn't a issue, I am just giving you another view to understand possibly why Van's Aircraft appears to have "no comment" when it comes to this issue. In all the postings about this issue, no one has mentioned the possibility of improper heat treating of the gear leg. If I recall this was an issue sometime ago with some main gear legs on RV's. This might be the root cause. This can be easily determined by sending the nose gear leg off to any qualified machine shop who can perform a hardness test on the leg. This will help determine if the gear was heat treated properly. Food for thought. Paul ________________________________________________________________________________
Subject: Re: Nosewheel collapse another view
Date: Aug 21, 2005
This is the voice of experience speaking. On landing number 17 on a hard surface runway and no previous bad landings, I managed to partially retract the nose gear on my 9A. Damage was relatively minor: the gear leg, the front piece on the wheel fairing, the gear leg fairing, and of course the prop. The outer 2" of the prop required refurbishing and 1/2" was removed from each end. The engine was not stopped by the ground contact (I thought about going around but with 3000' of runway left, I stopped the engine and made another landing) and fortunately there was no damage to the crankshaft. The root cause of the gear leg failure was a bad landing. I was warned by a local RV expert before my first flight to land slow and keep the nose wheel up until the mains are down, other wise I would likely damage the nose gear. So here I was with 4100' feet of runway ahead and some big white numbers on the approach end (the ones that we are supposed to hit, right) and about 70 knots of air speed and no wind (70 knots of ground speed!). I put it on the numbers and after the unusual noise I became airborne again. In the next 1000' (I had plenty of airspeed to keep flying), I decided to kill the engine and land. A guy, who was in his yard on the airport, walked up to the nose down airplane to help me push it back to the hanger and he commented that he thought that I was going "a little fast". If the nose gear leg had not bent, if it had been stronger, then the engine mount and fire wall may have been damaged. A much bigger problem. I think that Van's has designed a very good airplane and if we who fly them can treat them right, they will serve us well. Dick Jones 90062 ----- Original Message ----- From: "Merems" <merems(at)cox.net> Subject: RV9-List: Nosewheel collapse another view > > Gents, > > I too am building an RV-7A and have been following the discussions about > the recent nosewheel collapse. I am concerned about this situation as > many of you are. > > I have talked with Ken Krueger (Van's engineering), who I have a > tremendous respect for, about some of these recent accidents. I am > certain Van's Aircraft takes this situation very seriously. However if > you step back and ask yourself are there a few RV'As out there that have > had the highest number of landings to date, where would you find them? > What kind of landing have they seen? Grass or paved runways? My best > guess is these are the RV-7A and RV-9A prototypes at Van's Aircraft. Who > flies these? Van's staff. Where have they landed? Grass or pavement? > Both. Have they taxied on grass? Yes. Have they botched a few landing? > I would think so. Now I would bet these two aircraft have 10 times or > more the numbers of landing then any another RV's out there and their nose > gears haven't collapsed. > > I am not saying there isn't a issue, I am just giving you another view to > understand possibly why Van's Aircraft appears to have "no comment" when > it comes to this issue. > > In all the postings about this issue, no one has mentioned the possibility > of improper heat treating of the gear leg. If I recall this was an issue > sometime ago with some main gear legs on RV's. This might be the root > cause. This can be easily determined by sending the nose gear leg off to > any qualified machine shop who can perform a hardness test on the leg. > This will help determine if the gear was heat treated properly. > > Food for thought. > > Paul > > > ________________________________________________________________________________
Date: Aug 21, 2005
Subject: Richard bad landing
Thanks Richard: For your courage to tell us about your bad landing. Now, Ive got only 3 landings in my -9a. Still looking for the best approach speed. The first landing, with a lot of strong emotion, after 1030 hs bulding it, Ive put down half flaps and trimmed the -9A to 70 kt on a long final. The climb is something about - 300 to -400 fpm. Ive flared above the numbers and waited for the stall. It tooks a long time to arrive, may be 300 feet. Put it down on the mains and at this time I decided not to cut the stick control, the sticks lenght is appropriate. To maintain the nose high without power, Ive put something like 20 pounds on top of stick. The second one Ive trimmed it to 60 kt. The stall occours at 42 kt and something 100 feet after flare. The third one Ive tried to approach with 60 kt, trimmed it to 55 kt in a short final, but due to 10 to 17 kts gust cross winds, Ive aborted the landing and tried another one. The last was unventfull 60 kt approach and flare. What about your numbers? JC - Aracaju - Brasil #90997 Flying http://websites.expercraft.com/jcmm ________________________________________________________________________________
Date: Aug 21, 2005
Subject: Re: Richard bad landing
I can tell you the #s I used. About 75 knots approach speed. Just bring it down to the run way and hold it off until it settles down on the ground ________________________________________________________________________________
Date: Aug 21, 2005
my builder # is 90939 neilsplane .com ________________________________________________________________________________
Subject: Shimming required?
Date: Aug 21, 2005
Gents, Have any other builders needed to shim about 0.063" (1/16") between the F-724 (Aft Fuselage Bulkhead) bottom flange and the F-623 (Corner Rib). To refresh some of your memory this is the F-623 is bottom corner rib that extends to the side of the baggage bay to the side skins. This is the rib that get notched for the flap pushrod and also get trimmed for the step tube to clear. The F-724 is the vertical bulkhead in the baggage bay. It appears that without shimming the side skins will not line up properly with the bottom skin and corner rib flange. Attached is a image from the plan set. Any thoughts? Paul ________________________________________________________________________________
Date: Aug 21, 2005
Paul, Didn't get the attachment, but did you trimmed the aft end of the 623 corner rib so that it will clear the flange of the 706 bulkhead? Mike SC 90709 fuse -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Merems Subject: RV9-List: Shimming required? Gents, Have any other builders needed to shim about 0.063" (1/16") between the F-724 (Aft Fuselage Bulkhead) bottom flange and the F-623 (Corner Rib). To refresh some of your memory this is the F-623 is bottom corner rib that extends to the side of the baggage bay to the side skins. This is the rib that get notched for the flap pushrod and also get trimmed for the step tube to clear. The F-724 is the vertical bulkhead in the baggage bay. It appears that without shimming the side skins will not line up properly with the bottom skin and corner rib flange. Attached is a image from the plan set. Any thoughts? Paul ________________________________________________________________________________
Subject: Nose Gear Collapse
Date: Aug 21, 2005
OK it's true confession time. I had a nose gear collapse on my RV-9A with a little over 20 hours on it a little over a month ago. At first I was so frustrated with the situation that I did not want to talk about it. But we went to Oshkosh and talked to Van's, Aero Sport Power, and Sensenich about the incident. We are now on the road to recovery having sent our brand new engine back to Aero Sport Power for tear down and inspection, ordered a new gear leg and associated parts and placed an order for a new prop. Here's what happened. On Friday, July 8th, 2005 at around 10:30 AM, the aircraft was cleared to land on a 6400 X 150' newly repaved runway and landed normally. During the roll out, the control stick was held in the aft position holding the nose wheel off the ground as the airplane slowed down. At about 35 knots, a gust of wind picked up the airplane about a foot off the runway. The control stick was held in the aft position waiting for the aircraft to settle back to the runway. However, the nose wheel contacted the runway first, resulting in a couple of porpoises. After the second porpoises the nose gear collapsed and bent 90 degrees rearward destroying the front of the nose gear fairing, and scraping the nose gear fork on the front edge. The tire and wheel assembly was not damaged and appears to be OK. Other than the nose gear, the fuselage sustained no damage. As a result of the above, the prop contacted the ground bending the prop tips about 5 inches rearward. The airplane remained on the pavement during the entire incident. The engine did not stop and was shut down normally. No other damage to the airplane has been discovered and no injuries were incurred. The wings were removed and the airplane was placed on a trailer, and returned to its home base. What are the lessons to be learned? For one, be aware of the fact that the nose gear is fragile and should be treated that way. As one person at Oshkosh told me, "the nose gear is to be used only to keep the nose off the ground when the airplane is parked." Maybe over stated, but worth considering. More food for thought, Ron Murray 90291 N937RK Lake Norman Airpark, NC ________________________________________________________________________________
Date: Aug 21, 2005
Neilekins(at)aol.com wrote: > >I can tell you the #s I used. About 75 knots approach speed. Just bring it >down to the run way and hold it off until it settles down on the ground > Apparently we've uncovered Van's 1st deception in performance numbers. It would seem that the -9's stall speed has been grossly understated in the literature. :-) Seriously, what are your -9's showing at stall, both indicated & gps readings compared on a nice calm morning? I fly final in my -4 at 75 *mph* & it still floats a bit. Do they stall up around 55-60 kts indicated? That would indicate a significant low-speed pitot-static error. Not a big deal as long as everything is flown by indicated speeds & the asi is placarded to show it. On the other hand, if they stall in the mid 40's indicated as Van claims, 75 kts could be a reasonable low cruise speed. It would be very hard to land a nosewheel aircraft that much above stall. Charlie ________________________________________________________________________________
Date: Aug 22, 2005
I have the flight data captured from my EFIS/One during a landing. (also the climb, and various speed runs at different altitudes) It shows an indicated airspeed of 39KTS and GPS groundspeed of 40KTS at the point of touchdown. This is at 1720' density altitude. I normally fly my initial approach at 70KTS, then short final try to be around 65KTS. If I need to make a short landing, I'll take it down to 60KTS to keep the flare short. The worst thing you can do is touch the ground going too fast. The plane will try to fly again. Be ready to add power and go around if a gust lifts you off the ground. The stick should be back and you should stall while inches above the ground.. resulting in a squeaker every time. Then gradually keep pulling back to hold the nose up as long as possible. My complete spreadsheet of EFIS captured flight data is available on the RV-9A yahoo group in the files section. http://groups.yahoo.com/group/RV-9A/files/ Look for RV9APerformanceData.xls -Clay --- Charlie England wrote: > > > Neilekins(at)aol.com wrote: > > > > >I can tell you the #s I used. About 75 knots > approach speed. Just bring it > >down to the run way and hold it off until it > settles down on the ground > > > > Apparently we've uncovered Van's 1st deception in > performance numbers. > It would seem that the -9's stall speed has been > grossly understated in > the literature. :-) Seriously, what are your -9's > showing at stall, both > indicated & gps readings compared on a nice calm > morning? I fly final in > my -4 at 75 *mph* & it still floats a bit. > > Do they stall up around 55-60 kts indicated? That > would indicate a > significant low-speed pitot-static error. Not a big > deal as long as > everything is flown by indicated speeds & the asi is > placarded to show > it. On the other hand, if they stall in the mid 40's > indicated as Van > claims, 75 kts could be a reasonable low cruise > speed. It would be very > hard to land a nosewheel aircraft that much above > stall. > > Charlie > > ________________________________________________________________________________
Date: Aug 22, 2005
From: "dedgemon(at)knology.net" <dedgemon(at)knology.net>
Subject: RV9 landing (was nose gear, etc..)
Folks, It sure sounds like some people are landing these airplanes too fast. I thought I would add my procedures to the mix just for what their worth. I started flying my 9A in October and currently have 110 hours and a couple of hundred (at least) landings. Note that I am based on a 2000' grass strip and regularly fly off of hard surface also. My "normal" landing is something like the following. 1. Enter downwind and start slowing the airplane 2. Somewhere abeam the numbers be established at 80 knots or a little slower. 3. Deploy "full" flaps and slow to 70 knots. 4. Retard throttle (perhaps fully if still high) and turn base, then final. 5. I "normally" fly final at 70 knots unless I've got company on my wing. 6. Near the numbers (before the flare) start getting the speed down into the low 60 knot range unless its really windy. 7. Flare about a foot off of the ground and hold nose high as the speed bleeds off. 8. Keep nose up with stick as needed. Some thoughts. 1. My 9A stalls at 50 knots with full flaps and gross weight, 45 knots at full flaps and solo. So, you definately don't want to be blazing over the numbers at 70 knots, UNLESS, you're comfortable slowing the airplane while at 1 - 2 feet altitude. This is quite doable and normally if I'm flying with other RV's (6's, 7's, etc..) behind me, then I fly 80 knots to the numbers and slow over the runway. HOWEVER, I absolutely don't touch down at those speeds. I hold it off until it stalls on at about 50. 2. Approach angle. Steep is definately better here. Shallow approaches under power cause all sorts of problems. The airplane wants to drop out from under you after it gets slow (not as bad as a 6,7,8 but its still an issue). A easier landing is to be relatively high so that you are needing less and less power as you go down final. Also at shorter fields a steeper approach allows you a shorter landing (in any airplane). Try practicing your landings and make each approach a litter steeper than the last. You'll be suprised at how easy it is to get rid of the altitude with full flaps at 70 knots or below. 3. I guess that I typically cross the aimpoint (whereever that is going to be today, numbers, etc..) at 60 knots or less, zero (and I do mean zero) throttle with the nose coming up quite a bit. Ideally I want to here the mains hit at stall speed with the nose "way" above the horizon. Honestly its just like landing a 172 except easier. The airplane handles better, you can see better, etc.. 4. I often wonder it the quys that land on their noses are sitting high enough to see well. You want to be all the way up into the canopy as high as possible. This makes seeing over the nose easy and leads to much more precise flare and roundout. Hope this helps. -- David Edgemon RV-9A N42DE ________________________________________________________________________________
Date: Aug 22, 2005
Could Clay or someone else rpovide me with a copy of the performance profile cited. I don't have access to the yahoo site. TIA, John Kerr -------------- Original message -------------- > > I have the flight data captured from my EFIS/One > during a landing. (also the climb, and various speed > runs at different altitudes) > > It shows an indicated airspeed of 39KTS and GPS > groundspeed of 40KTS at the point of touchdown. This > is at 1720' density altitude. > > I normally fly my initial approach at 70KTS, then > short final try to be around 65KTS. If I need to make > a short landing, I'll take it down to 60KTS to keep > the flare short. > > The worst thing you can do is touch the ground going > too fast. The plane will try to fly again. Be ready > to add power and go around if a gust lifts you off the > ground. The stick should be back and you should stall > while inches above the ground.. resulting in a > squeaker every time. Then gradually keep pulling back > to hold the nose up as long as possible. > > My complete spreadsheet of EFIS captured flight data > is available on the RV-9A yahoo group in the files > section. http://groups.yahoo.com/group/RV-9A/files/ > Look for RV9APerformanceData.xls > > -Clay > > --- Charlie England wrote: > > > > > > > Neilekins(at)aol.com wrote: > > > > > > > >I can tell you the #s I used. About 75 knots > > approach speed. Just bring it > > >down to the run way and hold it off until it > > settles down on the ground > > > > > > > Apparently we've uncovered Van's 1st deception in > > performance numbers. > > It would seem that the -9's stall speed has been > > grossly understated in > > the literature. :-) Seriously, what are your -9's > > showing at stall, both > > indicated & gps readings compared on a nice calm > > morning? I fly final in > > my -4 at 75 *mph* & it still floats a bit. > > > > Do they stall up around 55-60 kts indicated? That > > would indicate a > > significant low-speed pitot-static error. Not a big > > deal as long as > > everything is flown by indicated speeds & the asi is > > placarded to show > > it. On the other hand, if they stall in the mid 40's > > indicated as Van > > claims, 75 kts could be a reasonable low cruise > > speed. It would be very > > hard to land a nosewheel aircraft that much above > > stall. > > > > Charlie > > > > > > > > > > > > > Could Clay or someone else rpovide me with a copy of the performance profile cited. I don't have access to the yahoo site. TIA, John Kerr -------------- Original message -------------- -- RV9-List message posted by: Clay R I have the flight data captured from my EFIS/One during a landing. (also the climb, and various speed runs at different altitudes) It shows an indicated airspeed of 39KTS and GPS groundspeed of 40KTS at the point of touchdown. This is at 1720' density altitude. I normally fly my initial approach at 70KTS, then short final try to be around 65KTS. If I need to make a short landing, I'll take it down to 60KTS to keep the flare short. The worst thing you can do is touch the ground going too fast. The plane will try to fly again. Be ready to add power and go around if a gust lifts you off the ground. The stick shoul d be back and you should stall while inches above the ground.. resulting in a squeaker every time. Then gradually keep pulling back to hold the nose up as long as possible. My complete spreadsheet of EFIS captured flight data is available on the RV-9A yahoo group in the files section. http://groups.yahoo.com/group/RV-9A/files/ Look for RV9APerformanceData.xls -Clay --- Charlie England wrote: -- RV9-List message posted by: Charlie England Neilekins(at)aol.com wrote: -- RV9-List message posted by: Neilekins(at)aol.com I can tell you the #s I used. About 75 knots approach speed. Just bring it down to the run way and hold it off until it settles down on the ground Apparently we've uncovered Van's 1st deception in performance numbers. It would seem that the -9's stall speed has been grossly understated in the literature. :-) Seriously, what are your -9's showing at stall, both indicated gps readings compared on a nice calm morning? I fly final in my -4 at 75 *mph* it still floats a bit. Do they stall up around 55-60 kts indicated? That would indicate a significant low-speed pitot-static error. Not a big deal as long as everything is flown by indicated speeds the asi is placarded to show it. On the other hand, if they stall in the mid 40's indicated as Van claims, 75 kts could be a reasonable low cruise speed. It would be very hard to land a nosewheel aircraft that much above stall. Charlie ________________________________________________________________________________
Subject: Flap pushrod cutout
Date: Aug 23, 2005
Fellow builders, I am preparing my bottom center fuselage skin for riveting and I am trying to determine the cutout size for the flap pushrod. I have had the side skins on and I know there is a slot cut in the side skin for the flap pushrod. There is a 3/32 hole in bottom skin that lines up with this slot. I believe this slot and hole are to joined/enlarged together to form the slot for the pushrod, however I can't seem to find the proper reference in the drawings or instructions. If you can enlighten me I would appreciate it. Paul ________________________________________________________________________________
Date: Aug 24, 2005
After you install the wings and flaps, you hook up the flaps to the flap actuator tube and cut away any skin that interferes with flap movement as it goes up and down. That will give you the smallest hole possible. Afterward, you cleanup/trim away more skin as required for adequate clearance in use. Albert Gardner 9-0132 N872RV Yuma, AZ -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Merems Subject: RV9-List: Flap pushrod cutout Fellow builders, I am preparing my bottom center fuselage skin for riveting and I am trying to determine the cutout size for the flap pushrod. I have had the side skins on and I know there is a slot cut in the side skin for the flap pushrod. There is a 3/32 hole in bottom skin that lines up with this slot. I believe this slot and hole are to joined/enlarged together to form the slot for the pushrod, however I can't seem to find the proper reference in the drawings or instructions. If you can enlighten me I would appreciate it. Paul ________________________________________________________________________________
Date: Aug 24, 2005
Subject: RE: Flap pushrod cutout
Hi Merens: Leave this job to the final assembly. After the wings and flaps are in their place. It will be easier to trim the smallest hole necessary. JC - Aracaju - Brasil -9A QB #90997 flying ________________________________________________________________________________
Date: Aug 24, 2005
Gents, Thanks for the input on the flap pushrod cutout. I had thought that because of the advanced nature of the kit Van's would have given more information on the cutout. I thought I was having a senior moment (not finding it in the plans or instructions). Paul ________________________________________________________________________________
Subject: Manual trim cable attachment at aft end
Date: Sep 06, 2005
I was playing with the elevators and the manual trim cable this weekend. I was trying to figure out how the aft end of the trim cable gets secured when I found the nut welded to a small steel plate in the manual trim hardware bag. I can only assume that this somehow gets attached to the access cover which then holds the cable in place. Questions: - Are there seperate manual trim instructions somewhere? I can find no reference in the instructions and the plans only have a small picture of this that I could find. - Did you just rivet this nut/steel plate to the access cover? Seems that if you did it this way it would be a challenge to 'turn' the access cover/nut onto the trim cable. (I positioned my manual trim cable higher on a center post, so I have no slack to pull it out farther.) I'm thinking a nutplate on the back side of the steel plate to attach it to the access cover. That would allow you to remove the access cover without removing the trim cable and such. Matthew Brandes, Van's RV-9A (Wiring) #90569 <http://www.n523rv.com/> http://www.n523rv.com EAA Chapter 1329 President EAA Chapter 868 Web Editor ________________________________________________________________________________
Date: Sep 06, 2005
Hey Matthew, Got your post and was thinking about this. I haven't gotten anywhere near having to worry about it, but I did some thinking on it awhile back while my shed was being built and I couldn't do any real building. DWG 4, MANUAL TRIM ASSY view shows the steel plate with the nut welded to it riveted to the cover plate. I'm thinking that once set, there is really no need to even access this area except to deal with the trim components for some reason. Looks like you would need to have this in place and then hook up the other end in the cockpit last so you can have the slack you need to get it into place. Just trying to figure it out for myself too. Regards, Mike 90709 fuse -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Matthew Brandes Subject: RV9-List: Manual trim cable attachment at aft end I was playing with the elevators and the manual trim cable this weekend. I was trying to figure out how the aft end of the trim cable gets secured when I found the nut welded to a small steel plate in the manual trim hardware bag. I can only assume that this somehow gets attached to the access cover which then holds the cable in place. Questions: - Are there seperate manual trim instructions somewhere? I can find no reference in the instructions and the plans only have a small picture of this that I could find. - Did you just rivet this nut/steel plate to the access cover? Seems that if you did it this way it would be a challenge to 'turn' the access cover/nut onto the trim cable. (I positioned my manual trim cable higher on a center post, so I have no slack to pull it out farther.) I'm thinking a nutplate on the back side of the steel plate to attach it to the access cover. That would allow you to remove the access cover without removing the trim cable and such. Matthew Brandes, Van's RV-9A (Wiring) #90569 <http://www.n523rv.com/> http://www.n523rv.com EAA Chapter 1329 President EAA Chapter 868 Web Editor ________________________________________________________________________________
Subject: RE: Manual trim cable attachment at aft end
Date: Sep 06, 2005
Mike, Thanks for the reply because you helped me make the decision. I hadn't thought about just unmounting the trim knob at the front and then push it out enough to turn the whole access cover w/ nut attached onto the cable and then pull it back in to mount. The only downside to this is that I had some wires running along with the trim cable. I'll have to attach those to different locations. So I'll be riveting that nut/steel plate to the access cover and I'll pull the trim cable in/out as necessary to get it on/off. Matthew Brandes, Van's RV-9A (Wiring) #90569 http://www.n523rv.com EAA Chapter 1329 President EAA Chapter 868 Web Editor ________________________________________________________________________________
Date: Sep 06, 2005
Dear Listers, I will be taking the Matronics Web Server down for a few hours today, Tuesday September 6 2005 for a chassis upgrade. Archive browsing and searching along with subscription services will be unavailable for be processed normally during the upgrade. Please check the Matronics System Status Page for updates (although this page resides on the web server and won't be available during the upgrade): http://www.matronics.com/SystemStatus/ Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Sep 06, 2005
Subject: Re: Manual trim cable attachment at aft end
Great question and timely. I offer another option. Drill the welded plate and install a nutplate. Then you can screw on a #8. I think this allows easier adjustment when and if needed. Just my .02 worth. Tad S. -7A painting ________________________________________________________________________________
Date: Sep 07, 2005
Tad, Sounds like what Matthew was talking about. Question: Will there be a tendency for the steel plate/nut to want to pivot on that #8 screw? If I see it right, there will be a platenut on the top side of the steel plate and that plate will be countersunk on the bottom for the cover plate's dimple. Seem like this might create the opportunity for the steel plate/nut to want to pivot, considering frequent use and vibration. Perhaps just another preflight check point. Just searching for answers, Mike 9A fuse -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Sargentclt(at)cs.com Subject: Re: RV9-List: Manual trim cable attachment at aft end Great question and timely. I offer another option. Drill the welded plate and install a nutplate. Then you can screw on a #8. I think this allows easier adjustment when and if needed. Just my .02 worth. Tad S. -7A painting ________________________________________________________________________________
Date: Sep 07, 2005
Subject: Jacking Points
Unlike most of you, I didn't build my RV-9A but bought it instead. It's time for the it's first Annual since I've owned it and the local A&P at our field will be doing it. He asked me about jacking points for lifting the plane to service the landing gear. I've looked through the builders manual and have found several references where you're instructed to jack the plane up while installing and adjusting landing gear and such but haven't come across anything specifically about where to place the jack stands when lifting the plane when it's at it's finished weight. Can you use the tie-down threaded points or do you have to fabicate some kind of a padded cradle or saddle for under the wing and get it as close to the fuselage as possible? Thanks in advance. Rick Luck N109RV ________________________________________________________________________________
Date: Sep 07, 2005
Someone smarter than me may have a different view. I think the attach point of the clevis end and the two penetration points where the cable passes through would be enough to hold everything in its place. The rotation point may be on the vertical axis ie. to loosen the jamb nut, however I do not believe this will happen. I have not installed the cable attach bolt yet however this is just a talking point. Tad ________________________________________________________________________________
Subject: Re: Jacking Points
Date: Sep 07, 2005
Rick: I've been flying my 9A almost 3 years and I jack it using the tie down points. I use a piece of 3/8 NC all-thread about 5" long with a nut on it and thread the all-thread into the tie down about 1.5" with the nut set about 1/4" below the skin. My homemade jack uses a piece of 3/8" sch 40 pipe sliding inside a piece of 3/4'" pipe that is welded to the jack frame. Note that when the all-thread is viewed from the front of the plane, it is not verticle but assumes the angle of the wings diehedral plus 90 degrees. I tilt my entire jack so that this initial angle is accounted for. When you jack the wing about a foot, which is required to get a tire off the floor, that angle increases another 3 or 4 degrees. Make sure that there is enough slop in your system to accomodate this angle change. You do not want a failure of this jack to result in a hole in the wing and possibly severe damage to the aileron controls. Dick Jones 90062 ----- Original Message ----- From: "RICK LUCK" <rluck(at)prodigy.net> Subject: RV9-List: Jacking Points > > Unlike most of you, I didn't build my RV-9A but bought it instead. It's > time for the it's first Annual since I've owned it and the local A&P at > our field will be doing it. He asked me about jacking points for lifting > the plane to service the landing gear. I've looked through the builders > manual and have found several references where you're instructed to jack > the plane up while installing and adjusting landing gear and such but > haven't come across anything specifically about where to place the jack > stands when lifting the plane when it's at it's finished weight. Can you > use the tie-down threaded points or do you have to fabicate some kind of a > padded cradle or saddle for under the wing and get it as close to the > fuselage as possible? Thanks in advance. Rick Luck N109RV > > > ________________________________________________________________________________
Subject: pitot line routing
Date: Sep 08, 2005
looking for some help in determining the best way to route the pitot and angle of attack tubes through to the Dynon on the panel for my 9A. Out of the paint booth and deep into final assembly. John Kerr 90616, N926BJ looking for some help in determining the best way to route the pitot and angle of attack tubes through to the Dynon on the panel for my 9A. Out of the paint booth and deep into final assembly. John Kerr 90616, N926BJ ________________________________________________________________________________
Date: Sep 08, 2005
Subject: Re: pitot line routing
John: here is what I did: From the wing root, I routed the lines aft under the seat floor, through a hole in the seat floor, ran them straight up through a hole in the armrest, then forward underneath the top longeron to the panel. Saves drilling a big hole in the spar ;-) Vern Little, RV-9A kerrjohna(at)comcast.net wrote: > >looking for some help in determining the best way to route the pitot and angle of attack tubes through to the Dynon on the panel for my 9A. > >Out of the paint booth and deep into final assembly. > >John Kerr >90616, N926BJ > >looking for some help in determining the best way to route the pitot and angle of attack tubes through to the Dynon on the panel for my 9A. > >Out of the paint booth and deep into final assembly. > >John Kerr >90616, N926BJ > > > > ________________________________________________________________________________
Date: Sep 11, 2005
Subject: ExperCraft build log
Fellow builders, This is an invite to those who need a method for creating a project log and Web site. Even if you've already started your log using another system this one is worth a look. ExperCraft Simple Log is free for builders and is a great way to create a comprehensive log and Web site. It's very easy to use. http://www.expercraft.com Enjoy! Rob -- Rob Riggen building a Vans RV7 http://websites.expercraft.com/rriggen ________________________________________________________________________________
Subject: DWG 5, Detail B
Date: Sep 12, 2005
1.53 RCVD_NUMERIC_HELO Received: contains an IP address used for HELO Suggestions please. The An4-12A bolt through elevator horns and the HS 911 assembly fits too close to the horn shaft to tighten. Are there "small-headed" bolts available or can one be fabricated? John Kerr, RV9 Out of the paint booth and on to final assembly Suggestions please.The An4-12A bolt through elevator horns and the HS 911 assembly fits too close to the horn shaft to tighten. Are there "small-headed" bolts available or can one be fabricated? John Kerr, RV9 Out of the paint booth and on to final assembly ________________________________________________________________________________
Date: Sep 12, 2005
Subject: Wheel pants
As I crawl around on the floor doing my best imitation of a "Monkey Mating a Football", I know that there has to be a better way. I can't help but believe that the erroneous way I did the nose gear pant is a little simpler. Instead of riviting the pant to the brackets, I left the brackets affixed to the gear and fastened the pant to it with screws and recessed washers.. My big dilemma is how do you fasten a tow bar to the nose gear, and what sort of a piece of equipment would you use? I realize that anything you use on that nose gear has to be used very gently, but there has to be a way to move this thing around, by hand, on the ground John Disher "Spending 90% of the time on the last 10% ________________________________________________________________________________
Subject: 60amp Alternator kit
Date: Sep 12, 2005
I have an older lycoming 0320 (no letters) and I am planning on buying the alt locally (honda lifetime waranty) I was planning on buying the brackets and plug from vans, but I don't know if the 60amp alt is boss mount or case mount anyone have any info on this ? Danny.. ________________________________________________________________________________
Date: Sep 12, 2005
Subject: Re: Wheel pants
John Disher wrote: > is a little simpler. Instead of riviting the pant to the brackets, I > left the brackets affixed to the gear and fastened the pant to it with > screws and recessed washers.. > > My big dilemma is how do you fasten a tow bar to the nose gear, and what > sort of a piece of equipment would you use? I realize that anything you Fortunately for you, you ignored Van's instructions. I hate having to pull the axle bolt out to remove my nose pant. Anyway, since my brackets are riveted on, I had to poke two sets of holes in the wheel pant to access the axle bolt/nut and the two hex head screws. I made the holes in the pant for the axle bolt large enough to fit my towbar into and latch onto this bolt. Works great. The tow bar is a "Bogi Bar", available from Spruce and others. I know others have also used the holes for the hex bolts that hold the forward bracket in the same manner. -- Tim Coldenhoff N194TC - Flying! http://rv9a.deru.com ________________________________________________________________________________
Subject: holes in wing ribs & wires
Date: Sep 14, 2005
Deburring the ribs before priming and having made an extra hole of 0.750 inch according the Vans drawing in their FAQ section, I still have this questions: I plan to use the Duct NT 5/8-50 conduit for the wiring of nav light (LED), strobe and maybe halogen landing light in the wing tips. The Bob Archer VOR antenna in the wing tip seems very interesting. Is it good practice to run the coax cable for such Vor antenna in the same conduit? Should I make other holes in the ribs for wires or tubes, maybe for an Efis that I plan. I suppose it is much easier now than later. Thanks. Jef in Belgium; 91031. ________________________________________________________________________________
From: "Neil Henderson" <neil.mo51(at)btopenworld.com>
Subject: Side Sliping
Date: Sep 17, 2005
Listers What's the general thinking re side slipping. I seem to recall a posting sugesting this manouver should not be carried out with full flaps deployed. Input would be most helpful in planning finals into short strips. Neil Henderson RV9A G-CCZT ________________________________________________________________________________
Date: Sep 17, 2005
Subject: Re: Side Sliping
In a 172, slips should be 'avoided' with flaps extended. This is different than 'prohibited'. The reason I was told is that both flap extension and slipping change the airflow over the elevator and pitch authority is compromised. Doing both at the same time makes it worse. That said, if you practice it and know how the aircraft responds, it quite an effective maneuver. On a low wing aircraft, however, slipping has it's own hazards... potential fuel starvation from the low wing, for example. Having said all that... who's got real-world experience with this? Vern Little -9A Neil Henderson wrote: > >Listers > >What's the general thinking re side slipping. I seem to recall a posting sugesting this manouver should not be carried out with full flaps deployed. Input would be most helpful in planning finals into short strips. > >Neil Henderson RV9A G-CCZT > > > > ________________________________________________________________________________
Date: Sep 17, 2005
I could be wrong here but I thought flaps in the early 172's w/ 40 degrees of flap were to be avoided. I used to slip a 1972 172 that our club used to have all the time. The nose would bob up and down, nothing bad, you just had to be aware of it. With 30 degrees, the plane wouldn't do bob at all. As for slipping an RV, I asked that question on www.vansairforce.net forum and the reply was simple, don't worry, the RV's are great slippers. My next question is, how is the -9 for spins? Bill -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of rv-9a-online Subject: Re: RV9-List: Side Sliping In a 172, slips should be 'avoided' with flaps extended. This is different than 'prohibited'. The reason I was told is that both flap extension and slipping change the airflow over the elevator and pitch authority is compromised. Doing both at the same time makes it worse. That said, if you practice it and know how the aircraft responds, it quite an effective maneuver. On a low wing aircraft, however, slipping has it's own hazards... potential fuel starvation from the low wing, for example. Having said all that... who's got real-world experience with this? Vern Little -9A Neil Henderson wrote: >--> > >Listers > >What's the general thinking re side slipping. I seem to recall a >posting sugesting this manouver should not be carried out with full >flaps deployed. Input would be most helpful in planning finals into >short strips. > >Neil Henderson RV9A G-CCZT > > > > ________________________________________________________________________________
Date: Sep 17, 2005
William D. Thompson describes this "pitch pumping" phenomenon in his book, Cessna Wings for the World. "When the larger dorsal fin was adopted in the 1972 C-172L, this side-slip pitch phenomenon was eliminated, but the cautionary placard was retained. In the higher powered C-172P and C-R172 the placard was applicable to a mild 'pumping' motion resulting from flap outboard-end vortex impingement on the horizontal tail at some combinations of side-slip angle, power, and airspeed." Unless Vans says otherwise, I wouldn't worry about it in a low-wing airplane. I think the flap outboard-end vortex in an RV misses the horizontal stabilizer. [By the way, I've seen the flap outboard-end vortex in a Boeing 757 during a misty landing and you don't want to be anywhere near one, much worse than the wing-tip vortex.] Regards, Dan Malwitz -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Bill Repucci Subject: RE: RV9-List: Side Sliping I could be wrong here but I thought flaps in the early 172's w/ 40 degrees of flap were to be avoided. I used to slip a 1972 172 that our club used to have all the time. The nose would bob up and down, nothing bad, you just had to be aware of it. With 30 degrees, the plane wouldn't do bob at all. As for slipping an RV, I asked that question on www.vansairforce.net forum and the reply was simple, don't worry, the RV's are great slippers. My next question is, how is the -9 for spins? Bill -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of rv-9a-online Subject: Re: RV9-List: Side Sliping In a 172, slips should be 'avoided' with flaps extended. This is different than 'prohibited'. The reason I was told is that both flap extension and slipping change the airflow over the elevator and pitch authority is compromised. Doing both at the same time makes it worse. That said, if you practice it and know how the aircraft responds, it quite an effective maneuver. On a low wing aircraft, however, slipping has it's own hazards... potential fuel starvation from the low wing, for example. Having said all that... who's got real-world experience with this? Vern Little -9A Neil Henderson wrote: >--> > >Listers > >What's the general thinking re side slipping. I seem to recall a >posting sugesting this manouver should not be carried out with full >flaps deployed. Input would be most helpful in planning finals into >short strips. > >Neil Henderson RV9A G-CCZT > > > > ________________________________________________________________________________
Date: Sep 18, 2005
Subject: Re:Side Sliping
Here is a post that I copied a year ago from one of the lists. I slip comfortably in my -9 and it works fine, but watch the nose. Leland RV9A with 34 hours Yes full flap slips work just fine with the 9a, I have heard from others that some of the other RVs dont slip well, but my 9a seems to nicely come down if you slow it a bit and throw it into a slip.Now, cross controlled stalls, thats another matter. There I was at 6000ft doing my flight test cards like a good little test pilot... Hum ok, time for the cross controlled stall series, slow down, feed in rudder and aileron until fully crossed, keep pulling... holding.... bam Im inverted looking up/down at the ground! Yikes, continue the roll through to right side up. WOW what what that all about? Well, climb back to 6000 and try it again, same thing... Hum, note to self, never feed in full rudder and aileron while in the traffic pattern.Now dont get me wrong, you have to have the nose way up, everything is looking very strange and feeling totally out of any sense of normal before you even get close to this happening, but it was fun! Andy > >From: "Neil Henderson" <neil.mo51(at)btopenworld.com> >Subject: RV9-List: Side Sliping > > >Listers > >What's the general thinking re side slipping. I seem to recall a posting sugesting >this manouver should not be carried out with full flaps deployed. Input would >be most helpful in planning finals into short strips. > >Neil Henderson RV9A G-CCZT > > > > ________________________________________________________________________________
Date: Sep 18, 2005
On Sep 18, 2005, at 8:42 AM, Leland wrote: > > ....Now, cross > controlled stalls, thats another matter. There I was at 6000ft doing my > flight test cards like a good little test pilot... Hum ok, time for the > cross controlled stall series, slow down, feed in rudder and aileron > until fully crossed, keep pulling... holding.... bam Im inverted > looking up/down at the ground! Howdy, New to the list. I am considering an RV9a (as opposed to a tattered old certified plane). I have a couple of questions, one regarding the above statement. Due to the experimental nature it seems that there would be a bit of the unknown when performing maneuvers such as these. So, how do you conduct such "experiments" without worry of over-stressing the a/c? Secondly, I understand that the -9 is not fully aerobatically rated. My assumption is the longer wingspan. Is there anything else? Is there anything a person could reasonably do during the building process to bring it up to aerobatic standards? Anybody know what +/- g's a -9 is rated for? Thanks for your time! Regards, Ron Tyler "First there was nothing... then it exploded" ________________________________________________________________________________
Date: Sep 18, 2005
The -9 is rated for +4,4 and -1,8 G. The wing skins on the -7 (aerobatic one) is thicker than the 9s wing skin. JC - Aracaju - Brasil PU-JCI Flying ________________________________________________________________________________
Subject: Re:
Date: Sep 18, 2005
So he went inverted and didn't rip the wings off ? I didn't know the 9 could do that safely.. is a roll considered aerobatic ? Danny.. ----- Original Message ----- From: <jc(at)INFONET.COM.BR> > > The -9 is rated for +4,4 and -1,8 G. > The wing skins on the -7 (aerobatic one) is thicker than the 9s wing skin. > JC - Aracaju - Brasil > PU-JCI > Flying > > > ________________________________________________________________________________
Subject: Re: Side Slipping
Date: Sep 19, 2005
From: "DellAngelo, Scott M" <SDellAngelo(at)usg.com>
0.15 HTML_TEXT_AFTER_BODY BODY": rv9-list(at)matronics.com It's not the maneuvers that rip wings off airplanes, it's the g's. Flip, roll, tumble, loop, whatever while pulling less than +4.4 and it'll do fine. If you want to do aerobatics then build an RV of any number less than a 9. I once rode in a Pitts S-2B with a very competent pilot and we did ALL kinds of wild stuff while only pulling about 5 g's. More than one RV9 has done a loop. Kevin Shannon did when he built his and a picture in the vansairforce website shows that Cameron K (forget the full last name) must have in his too. The RV-9 has thinner wing skins and longer wings, those are two of the obvious reasons that it would not handle as much. +4.4 is better rated than your average Cessna, Piper, etc. Most are normal category at +3.8. If you have never been exposed to real g's, 4.4 is getting pretty serious. In the Pitts we barely made it to 5 and only once, and that was enough to get me feeling not so good. Scott #90598 Firewall Forward N598SD reserved Plainfield, IL ________________________________________________________________________________
Date: Sep 19, 2005
Subject: Aerobatic, to be or not to be
Hi there: Just to remember, the turbulence create great G forces in an airplane. An aerobatic aiplane supports G forces up to 9s like an EXTRA-300. A normal or utility category is about 3,8 and an -9 is 4,4. To make a good looping maneuver we must imput something around 3 Gs in an airplane. Could imagine what will happen if the turbulence add more 3 Gs in a -9A during the end of a looping maneuver? Go to -7 in order to do aerobatics. The -9 is a wonderfull travelling machine. JC - Aracaju - Brasil -9A flying/travelling PU-JCI ________________________________________________________________________________
Date: Sep 19, 2005
Subject: C&S speed X fixed pitch prop
Danny: My -9 is flying with a beatifull fixed pitch three blade CATTO prop. But at 10.000 to 12.000 feet (due to high clouds) I felt the necessity of a variable pitch prop. At the time I was working in a firewall forward Ive never think about to spend some more US$ and install a governor, cables and all of the stuff to upgrade to a C&S prop. May be its your time now to think about it. Isnt it? JC - Aracaju - Brasil -9A PU-JCI ________________________________________________________________________________
Date: Sep 19, 2005
Ron, when you get the "9" kit, replace (almost) all of the parts with those from a "7" kit and you will be fully aerobatic. Seriously, you can't make the RV-9(a) aerobatic. When I'm letting down into KYUM and airspeed is near the yellow arc, I always find a few bumps and at that moment, an image of the wing spar/center spar attachment pops into my head. I always pull off a little power at that point. This plane flies well, lands great and - at even at today's gas prices - is fairly cheap to fly. Albert Gardner RV-9A N872RV 580 hrs, 21 states, Baja, and Oshkosh twice. Yuma, AZ Howdy, New to the list. Secondly, I understand that the -9 is not fully aerobatically rated. My assumption is the longer wingspan. Is there anything else? Is there anything a person could reasonably do during the building process to bring it up to aerobatic standards? Regards, Ron Tyler ________________________________________________________________________________
Date: Sep 19, 2005
I have to wonder if that little stubby main spar with such a short overlap area isn't a good bit weaker too. John Disher still chasing wheel pants around -------Original Message------- From: DellAngelo, Scott M Date: 09/19/05 03:41:33 Subject: RV9-List: Re: Side Slipping It's not the maneuvers that rip wings off airplanes, it's the g's. Flip, roll, tumble, loop, whatever while pulling less than +4.4 and it'll do fine. If you want to do aerobatics then build an RV of any number less than a 9. I once rode in a Pitts S-2B with a very competent pilot and we did ALL kinds of wild stuff while only pulling about 5 g's. More than one RV9 has done a loop. Kevin Shannon did when he built his and a picture in the vansairforce website shows that Cameron K (forget the full last name) must have in his too. The RV-9 has thinner wing skins and longer wings, those are two of the obvious reasons that it would not handle as much. +4.4 is better rated than your average Cessna, Piper, etc. Most are normal category at +3.8. If you have never been exposed to real g's, 4.4 is getting pretty serious. In the Pitts we barely made it to 5 and only once, and that was enough to get me feeling not so good. Scott #90598 Firewall Forward N598SD reserved Plainfield, IL ________________________________________________________________________________
Date: Sep 19, 2005
On Sep 19, 2005, at 8:13 AM, Albert Gardner wrote: > > Ron, when you get the "9" kit, replace (almost) all of the parts with > those > from a "7" kit and you will be fully aerobatic. Seriously, you can't > make > the RV-9(a) aerobatic. Thanks everyone for your replies! I am really torn between the -7 and -9... sigh. Regards, Ron Tyler "Enjoy being here while getting there." ________________________________________________________________________________
Date: Sep 20, 2005
JC, I am curious. What happened at 10 to 12 thousand feet? Dan Planning an RV-9 -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of jc(at)INFONET.COM.BR Subject: RV9-List: C&S speed X fixed pitch prop Danny: My -9 is flying with a beatifull fixed pitch three blade CATTO prop. But at 10.000 to 12.000 feet (due to high clouds) I felt the necessity of a variable pitch prop. At the time I was working in a firewall forward Ive never think about to spend some more US$ and install a governor, cables and all of the stuff to upgrade to a C&S prop. May be its your time now to think about it. Isnt it? JC - Aracaju - Brasil -9A PU-JCI ________________________________________________________________________________
Subject: FW: Compass Correction Card spreadsheet
Date: Sep 20, 2005
INNOCENT GLOBAL 0.0000 1.0000 -4.4912 -----Original Message----- From: Albert Gardner [mailto:ibspud(at)adelphia.net] Subject: Compass Correction Card spreadsheet Well, an archive search didn't turn up any hits but I thought I remembered a posting about a spreadsheet program that would print a correction card. Anyone familiar with this? Albert Gardner Yuma, AZ ________________________________________________________________________________
Date: Sep 21, 2005
Hy Danny; Adjusting the mixture we clearly note the reducing in the airspeed. Something like 130kt IAS. The fixed prop is very eficient in just one small range of density altitude. With a variable pitch is possible to increase the prop eficiency. Now I know it would be good to build provisions for an upgrade from fixed prop to a C&S prop. JC - Aracaju - Brasil PU-JCI #90997 Flying good ________________________________________________________________________________
Date: Sep 21, 2005
JC, That makes sense. The propeller advance ratio, J = V/(N*D), where V is TRUE airspeed. I like the simplicity of the fixed prop, but to go fast up high (145 KIAS at 10 to 15 thousand feet) I'll need to use a constant speed prop. You've been a great help. Obrigado, Dan ---- jc(at)INFONET.COM.BR wrote: > > Hy Danny; > Adjusting the mixture we clearly note the reducing in the airspeed. Something like 130kt > IAS. The fixed prop is very eficient in just one small range of density altitude. With a > variable pitch is possible to increase the prop eficiency. > Now I know it would be good to build provisions for an upgrade from fixed prop to a C&S > prop. > JC - Aracaju - Brasil > PU-JCI > #90997 > Flying good > > > > > > ________________________________________________________________________________
Subject: Aircraft Registration fees and sales tax
Date: Sep 21, 2005
INNOCENT GLOBAL 0.0236 1.0000 -4.1506 Fellow builders, I am a few years away from completing my RV-7 but I wanted to find more information about some of the aircraft registration costs others are paying for the RV's. In addition if there is a one time sales tax payment required to register the aircraft. I had heard that here in Arizona they will asses the aircraft and charge you a sales tax if no sales taxes were paid on or all parts of the kit project. Since most of us are purchasing our kits and engines from out of state, there isn't any state sales tax charged when purchasing. I don't want to start any rumors, just trying to get the facts. Paul ________________________________________________________________________________
Date: Sep 21, 2005
When you register the plane with the feds, AZ will send you a form that they will use to calculate the amount of tax. I called and told them the plane was not yet done and they said tell them when it was finished. Unlike many others I had listed a value on the bill-of-sale I included with the application for federal registration. It's not required by the feds and I suggest you leave it blank. After the plane was flying I contacted AZ tax people and paid the one-time tax (about 7 or 8% I think). There is no legal way to get around AZ tax for most of us. Albert Gardner Yuma, AZ ________________________________________________________________________________
Date: Sep 23, 2005
Subject: re[21]
"Ci-iallis Sof-tabs" is better than Pfizer V-iiaggrra and normal Ci-ialis because: - Guarantes 36 hours lasting - Safe to take, no side effectts at all - Boost and increase se-xual perfoormance - Haarder e-rectiiions and quick recharge - Proven and c-ertified by e-xperts and d-octors - only $2 per tabs - Special offeer! These prices - are valid u-ntil 30th of September ! Cllick hereee: http://gsullivan-consulting.com depositor inhale hundredth perth seethe sari dreyfuss flagging wappinger pam classificatory demented fine dyeing brusque theretofore amateurish equipotent knowledge stu protozoan buxom siva nose dance inequitable coolheaded mung braggart document goldwater sanitate doldrum alive aura eclectic debility dogtooth argue fine barycentric mushroom atlantes ernie immobile bough shitepoke bayesian presentational whup anteroom debby accumulate grenade ________________________________________________________________________________
Date: Sep 23, 2005
Here in South Carolina we have that plus Personal Property Tax issues. I have an H-35 Bonanza that they felt deserved to pay a $1400.00 a year PPT and then I built a Kitfox, and I got an inquiry from the Assessors Office as to its value. I told them in that the legal definition of value is what a willing buyer and a willing seller will exchange an item for, and I will never sell the airplane because of liability issues, it has no value. They weren't buying that, and said that I had to affix a value. I told them that I was sure it was worth more than my neighbors gun collection, but surely worth less than his wife's antique furniture collection, How much do they pay? They said that they pay nothing because those things don't have a title and they only tax titled items, so because my hobby produces an item that it titled, I have to pay tax. I told them that I realized everybody needs to pay their fair share and I am willing to do that, so long as it is reasonable, but if they get carried away on the Kitfox like they did on that 40+ year old Bonanza, I would spend $300.00 to form a Delaware Corporation, which would then own the airplanes, and they would get nothing. They sent out a $1250.00 tax bill on the Kitfox and now I have a Management Corporation that owns both airplanes and it costs me about $150.00 a year for Corporate tax and the fee for the Delaware Company that handles everything for out of state Corporation owners. You might want to look into this. -------Original Message------- From: Albert Gardner Date: 09/21/05 20:54:35 Subject: RE: RV9-List: Aircraft Registration fees and sales tax When you register the plane with the feds, AZ will send you a form that they will use to calculate the amount of tax. I called and told them the plane was not yet done and they said tell them when it was finished. Unlike many others I had listed a value on the bill-of-sale I included with the application for federal registration. It's not required by the feds and I suggest you leave it blank. After the plane was flying I contacted AZ tax people and paid the one-time tax (about 7 or 8% I think). There is no legal way to get around AZ tax for most of us. Albert Gardner Yuma, AZ ________________________________________________________________________________
Subject: Project Insurance
Date: Sep 25, 2005
All, Where can insurance be had to cover my project? How much will it cost me per year?. Homeowners wont even talk to me about it, as far as they are concerned it is just a pile of junk. Bob Perkinson Hendersonville, TN. ________________________________________________________________________________
Date: Sep 25, 2005
From: Gary Robertson <gary.robertson(at)sbcglobal.net>
Subject: Re: Project Insurance
Darn good question. As the Rita winds blew through DFW, Texas, I watched a questionable OLD tree (HUGE) that leans over my outside workshop (hangar:) I wondered what would happen should a limb break and come crashing down through the roof. These are 40-50' limbs, about 18" across. All my completed empennage parts are hanging from the inside roof joists. Gary Robertson RV-9, Slider Wings........ Bob Perkinson wrote: All, Where can insurance be had to cover my project? How much will it cost me per year?. Homeowners wont even talk to me about it, as far as they are concerned it is just a pile of junk. Bob Perkinson Hendersonville, TN. ________________________________________________________________________________
Date: Sep 25, 2005
Bob, Call the EAA insurance and they will provide builder coverage for a premium of 1% of the value. Bob Berube RV-9 -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Bob Perkinson Subject: RV9-List: Project Insurance All, Where can insurance be had to cover my project? How much will it cost me per year?. Homeowners wont even talk to me about it, as far as they are concerned it is just a pile of junk. Bob Perkinson Hendersonville, TN. ________________________________________________________________________________
Date: Sep 25, 2005
Bob, I have had very good luck with pricing and customer service from SkySmith Insurance in Iowa. Glenn in Arizona -9A fuselage. ----- Original Message ----- From: "Bob Perkinson" <bobperk(at)bellsouth.net> Subject: RV9-List: Project Insurance > > All, > Where can insurance be had to cover my project? How much will it cost me > per year?. Homeowners wont even talk to me about it, as far as they are > concerned it is just a pile of junk. > > Bob Perkinson > Hendersonville, TN. > > ________________________________________________________________________________
Date: Sep 25, 2005
Check again with your home owners, mine (Liberty Mutual) does cover the project as long as it is in the house. I doubt it will cover my time, which is something I need to clarify with my agent. Bill -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Bob Perkinson Subject: RV9-List: Project Insurance All, Where can insurance be had to cover my project? How much will it cost me per year?. Homeowners wont even talk to me about it, as far as they are concerned it is just a pile of junk. Bob Perkinson Hendersonville, TN. ________________________________________________________________________________
Date: Sep 26, 2005
Subject: Air Filter - Air Box Installation
In doing the annual on my RV, our A&P has found kind of an unusual air fitler installation. As you guys probably know, the bottom of the accelerator pump extends about 1/2" below the surface of the carburator, where the top of the air box is attached. The accerator pump bottom then extends about 1/2" into the air box. Unfortunately, where it protrudes into the air box just happens to line up exactly with where the edge of the air filter mates up to the top of the air box. The solution that the builder of my plane used was to simply cut out a knotch in the air filter gasket edge about 1/2" and then re-form a new seal around the accelerator pump w/ RTV silicone. We're looking for an improvement, to eliminate the possibility of some RTV material becoming dislodged from the makeshift gasket and being ingested into the carb. We've looked at offsetting the air box so it's not centered on the carb inlet but then we're worried about missalignment with the air inlet in the cowling. We've also discussed using an automotive air filter that consists of a wire basket and foam filter, thinking we could deform the wire basket to mis the accerator pump hump and the foam would still conform to the basket, essentially creating a filter that wasn't perfectly round. Have any of you run into this problem and if so, what was your solution? Thanks for the help. Rick Luck ________________________________________________________________________________
Date: Sep 26, 2005
I built a spacer out of alum (I was thinking it was 5/8" but maybe only 1/2") so that I didn't have to modify the filter. As I recall, Van's solution was as described below and apparently works OK. With the spacer you have to tilt the air box up slightly also. Albert Gardner Yuma, AZ -----Original Message----- In doing the annual on my RV, our A&P has found kind of an unusual air fitler installation. As you guys probably know, the bottom of the accelerator pump extends about 1/2" below the surface of the carburator, where the top of the air box is attached. The accerator pump bottom then extends about 1/2" into the air box. Unfortunately, where it protrudes into the air box just happens to line up exactly with where the edge of the air filter mates up to the top of the air box. The solution that the builder of my plane used was to simply cut out a knotch in the air filter gasket edge about 1/2" and then re-form a new seal around the accelerator pump w/ RTV silicone. ________________________________________________________________________________
From: Michael Schipper <mike(at)learningplanet.com>
Subject: Re: Air Filter - Air Box Installation
Date: Sep 26, 2005
It sounds like the builder followed Van's instructions on installing the air filter. The instructions do state to take care that there are no loose pieces of sealant that could be sucked into the intake. There may be a better solution, but this is the way mine is, and I would expect just about every other RV has theirs done the same way. Mike Schipper www.my9a.com On Sep 26, 2005, at 10:33 AM, RICK LUCK wrote: > > In doing the annual on my RV, our A&P has found kind of an unusual > air fitler installation. As you guys probably know, the bottom of > the accelerator pump extends about 1/2" below the surface of the > carburator, where the top of the air box is attached. The > accerator pump bottom then extends about 1/2" into the air box. > Unfortunately, where it protrudes into the air box just happens to > line up exactly with where the edge of the air filter mates up to > the top of the air box. The solution that the builder of my plane > used was to simply cut out a knotch in the air filter gasket edge > about 1/2" and then re-form a new seal around the accelerator pump > w/ RTV silicone. We're looking for an improvement, to eliminate > the possibility of some RTV material becoming dislodged from the > makeshift gasket and being ingested into the carb. We've looked at > offsetting the air box so it's not centered on the carb inlet but > then we're worried about missalignment with the air inlet in the cowl! > ing. > We've also discussed using an automotive air filter that consists > of a wire basket and foam filter, thinking we could deform the wire > basket to mis the accerator pump hump and the foam would still > conform to the basket, essentially creating a filter that wasn't > perfectly round. Have any of you run into this problem and if so, > what was your solution? Thanks for the help. Rick Luck > > ________________________________________________________________________________
Date: Sep 26, 2005
I got mine through Falcon. (referred by EAA) 1% of the covered value seems to be standard. I now have my regular insurance with Falcon. They beat Avemco by a mile! Bob D ________________________________________________________________________________
Subject: RE: Air Filter - Air Box Installation
Date: Sep 27, 2005
This is how the SJ cowl handles the air filter. They use a cone shaped K&N filter. I'm not sure if this could be adapted to the Van's cowling setup or not. http://www.jamesaircraft.com/files/banjobox0025.JPG http://www.jamesaircraft.com/filter_housing.jpg Matthew Brandes, Van's RV-9A (Wiring) #90569 <http://www.n523rv.com/> http://www.n523rv.com EAA Chapter 1329 President EAA Chapter 868 Web Editor ________________________________________________________________________________
Subject: Follow-up - BPE Engine Rebuild Seminar
Date: Sep 28, 2005
This past Saturday, in front of 27 fellow aviators and with the assistance of Allen and Mike from Barrett Precision Engines (http://www.barrettprecisionengines.com), I rebuilt my Lycoming O-320-D2J. I purchased this engine almost two years ago and decided that it needed an overhaul before flying. I tossed out the idea of an engine rebuild seminar for our local EAA chapter members to Allen Barrett at BPE and he bit. I wanted to be involved in the tear down and rebuild of the engine but didn't feel comfortable doing it myself. Allen saw an opportunity to share his wealth of knowledge and get some exposure out of the deal. It was a perfect match. On Friday, May 13th, my wife and I drove down to Tulsa, OK (from Kansas City) and we took the engine apart with the assistance of their lead shop tech Mike. It went very smoothly and only took a couple of hours. The other shop people got a kick out of some farm boy from Kansas tearing an engine apart. (Pictures at: http://n523rv.com/engine). We were generally pleased with the condition of the engine, however, things took a bad turn for the worse when the crank was rejected for pitting, the pistons had cracks and the mags were shot. We moved forward with the overhaul and set a date of September 24th for the seminar. I promoted the seminar in various places, primarily among our local EAA chapters. Saturday, September 24th arrived and it was a perfect day. Allen and Mike arrived the night before with all the pieces of the engine and had it all setup in EAA Chapter 91's hangar ready to go. We started the day at 8:00 with some coffee and donuts while Allen talked about the process we were about to through. We also talked about how to purchase engine cores and what to watch for. (The city decided that it would be a good day to repave the only road leading to the airport, so we gave attendee's a little extra time to arrive.) About 9:00am we moved to the hangar area to start the build. All of the parts had been previously checked and dimensioned, so it was merely a task of assembling the parts. Since this was my engine, I worked with Mike to do the assembly while Allen narrated and fielded questions. We broke for lunch around 12:00 at which point we had the case halves on and the accessory had just been bolted on. My wife served us a wonder lunch of lasagna, salad and garlic bread. After lunch we went back out and finished assembling the engine with completion coming around 5:15 or so. We stopped several times throughout the day to let people come up and get a closer look at what we had done. (Can't have 27 people standing around you at once.) It's actually quite amazing that we ran into no major issues. Allen and Mike brought every part and every tool we needed to assemble the engine. Early in the day, they realized that we were missing a castle nut for the oil pump housing. The plan was to continue with the build and they would remove the accessory case from the engine when they got the engine back to Tulsa and replace the nut. Just as we were finishing up installing the accessory case, Mike pulled out the fittings for the oil cooler lines to install and found the castle nut nicely sitting inside one of them! Obviously be careful where nuts and bolts can fall. During lunch, Mike and Allen pulled the accessory case off and installed the nut and safetied the oil pump housing. The other small issue that came up at the very wend was not having a push-rod the correct length to bring one of the rockers into tolerance. I was no big deal as they installed one as soon as they got back to Tulsa. FINAL ANALYSIS: The engine seminar was a great idea and it came together very well. All of the participants were extremely appreciative of the opportunity. Mike, Allen and the crew at BPE were fantastic to work with. I'm certainly glad that I did not attempt the overhaul on my own, the engines are pretty basic but there are a lot of things you need to know. I'll never again purchase a used engine! If you need an engine or an engine overhaul, give Allen a call... you won't be sorry. (918-835-1089) Thanks go out to my wife for making lunch and the members of EAA Chapter 91 for allowing us to use their beautiful hangar! Matthew Brandes, Van's RV-9A (Wiring) #90569 <http://www.n523rv.com/> http://www.n523rv.com EAA Chapter 1329 President EAA Chapter 868 Web Editor ________________________________________________________________________________
Date: Sep 30, 2005
Subject: Builder assistance available
Greetings You want an RV but don't have the time to build it. I can help. I am a machinist by trade. I completed an RV-6 in 2200 hrs. (no prepunced holes) and assisted on 2 others. I am available to work on a project full time. I am located in Lodi, CA. Bud Newhall RV-6(at)comcast.net 209-334-2911 ________________________________________________________________________________
Subject: Flap & aileron attach brackets.
Date: Oct 02, 2005
Hello everyone. Question: I am preparing to install the flap attach brackets (925-a) to the ribs and was wondering if I could do this before installing the top wing skins. In theory this would make the riviting easier by allowing me to use the squeezer for all. Am I missing something? Would not installing the skins not give the skeleton enough rigidity to allow for proper bracket install? Your input would be welcome. ________________________________________________________________________________
Subject: Re: Flap & aileron attach brackets.
Date: Oct 02, 2005
Good question. I asked Bruce Reynolds at Van's this very thing. He didn't know if it was ok (he hasn't built a 9) but thought it was. Also asked Scott Risan (also of Van's) and he felt it was fine. I know of at least one builder who has done this also. So, I did it that way but I haven't got the top skins on yet so I'm not sure if there are any traps here. I can tell you that my squeezer doesn't want to do rivets that long so I used a 3x gun. However, you are absolutely right that riveting is a lot easier with the top skins off. One thing I did do was to have either a top or bottom skin clecoed on to guarantee alignment when I drilled the brackets and when I drove the first one or two rivets on each. There is also a bit of a story regarding aligning the middle flap hangar if you're interested. Bill in Maine ----- Original Message ----- From: "D.Munz" <182ppl(at)comcast.net> Subject: RV9-List: Flap & aileron attach brackets. > > Hello everyone. Question: I am preparing to install the flap attach brackets (925-a) to the ribs and was wondering if I could do this before installing the top wing skins. In theory this would make the riviting easier by allowing me to use the squeezer for all. Am I missing something? Would not installing the skins not give the skeleton enough rigidity to allow for proper bracket install? Your input would be welcome. > > ________________________________________________________________________________
Subject: DRDT-2 dimpling tool at the Copperstate Fly-In Oct 7-8th
Date: Oct 02, 2005
INNOCENT GLOBAL 0.1887 1.0000 -1.9730 Fellow RV builders, The ExperimentalAero DRDT-2 dimpling tool (experimentalaero.com) will at the Avery Tool booth at the CopperState Fly-in (Casa Grande, AZ) next weekend Oct 7-8th. Stop by and give it a test drive. Sincerely, Paul Merems ExperimentalAero ________________________________________________________________________________
Date: Oct 02, 2005
The double offset rivet set I bought from Averys did the job without deviating from the plans/manual. Perhaps a bit uncomfortable, but get used to it...the fuse kit is next! Also, my middle flap bracket aligned perfectly with no adjustment. Thanks Vans! Mike SC 9A fuse...hoping to roll over the canoe this week -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of Chenoweth Subject: Re: RV9-List: Flap & aileron attach brackets. Good question. I asked Bruce Reynolds at Van's this very thing. He didn't know if it was ok (he hasn't built a 9) but thought it was. Also asked Scott Risan (also of Van's) and he felt it was fine. I know of at least one builder who has done this also. So, I did it that way but I haven't got the top skins on yet so I'm not sure if there are any traps here. I can tell you that my squeezer doesn't want to do rivets that long so I used a 3x gun. However, you are absolutely right that riveting is a lot easier with the top skins off. One thing I did do was to have either a top or bottom skin clecoed on to guarantee alignment when I drilled the brackets and when I drove the first one or two rivets on each. There is also a bit of a story regarding aligning the middle flap hangar if you're interested. Bill in Maine ----- Original Message ----- From: "D.Munz" <182ppl(at)comcast.net> Subject: RV9-List: Flap & aileron attach brackets. > > Hello everyone. Question: I am preparing to install the flap attach brackets (925-a) to the ribs and was wondering if I could do this before installing the top wing skins. In theory this would make the riviting easier by allowing me to use the squeezer for all. Am I missing something? Would not installing the skins not give the skeleton enough rigidity to allow for proper bracket install? Your input would be welcome. > > ________________________________________________________________________________
Date: Oct 04, 2005
Subject: Lycoming 360 MT Propeller 183-59 blade echange offer
Hi All, MT Propeller and Less Drag Products, Inc. is offering a blade exchange program for the Lycoming 360 3 blade MT Propeller. If you have the MTV-12, or MTV-18, 3 blade MT Propeller on your Lycoming 360 engine, you can exchange your present 183-59 blades for the new 183-59b blades. You might be interested in this offer if you would like to remove the mid range RPM restriction on your Lycoming 360 engine, and increase your cruise speed by about 5 mph. MT Propeller is offering to exchange your present three 183-59 blades with a new set of 183-59b blades for about the same price as a single 183-59b blade. (The list price for a single replacement 183-59b blade is $2,430.) Less Drag Products, Inc. will coordinate the actual blade set replacement for your propeller, based on your location and replacement blade set availability. Please contact Less Drag Products, Inc. directly at _jim(at)lessdrag.com_ (mailto:jim(at)lessdrag.com) to obtain a schedule and cost estimate. Regards, Jim Ayers Less Drag Products, Inc. (805) 499-8646 FAX ________________________________________________________________________________
Subject: Flap actuator center bearing block mounting
Date: Oct 06, 2005
1.66 HELO_DYNAMIC_DHCP Relay HELO'd using suspicious hostname (DHCP) 1.28 HELO_DYNAMIC_HCC Relay HELO'd using suspicious hostname (HCC) 1.36 HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP addr 1) I'm installing the powder coated flap actuator weldment behind the seats. The plans call for platenuts on the underside of the seat rib to secure the center bearing block. I'm wondering why they don't use a simple nut, bolt and washer. I'm thinking of just bringing the bolt up from the underside and putting the washer and nyloc nut on the top. Seems like a lot of effort to install platenuts for not very much gain. What have others done here ? __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Oct 06, 2005
Subject: Re: Flap actuator center bearing block mounting
Gerry, If you do as you propose, how will you get a wrench on the bolt to tighten the nyloc nut on the top side of the bearing block. Nut plates are very easy to install (you only have to install them 1 time) and you don't have to get on both ends of the bolt to tighten. There is No need to get on the other side of the baggage floor to get access to the bolt head. I installed nut plates on all of the seat and baggage floor ribs to make it easy to remove the floor panels for annual inspections... Gerry Filby wrote: > > >I'm installing the powder coated flap actuator weldment behind >the seats. The plans call for platenuts on the underside of >the seat rib to secure the center bearing block. I'm wondering >why they don't use a simple nut, bolt and washer. I'm thinking >of just bringing the bolt up from the underside and putting the >washer and nyloc nut on the top. Seems like a lot of effort to >install platenuts for not very much gain. What have others >done here ? > >__g__ > >========================================================== >Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 > > > > ________________________________________________________________________________
Date: Oct 06, 2005
Hmm. If you can't get a wrench on top of the bearing block to tighten a nut, how can you do so to tighten down the bolt into the platenut ? If I understand you right, you've changed all the LP-4 rivets called out for the baggage floors in favor of nutlplates and screws ? Why do you need to remove the baggage floors for inspection ? The only thing to inspect is the pushrod assembly that runs through the tunnel - and that I have used platenuts/screws per the drawings. Not being combative, just trying to understand ... g > > > Gerry, If you do as you propose, how will you get a wrench on the bolt > to tighten the nyloc nut on the top side of the bearing block. Nut > plates are very easy to install (you only have to install them 1 time) > and you don't have to get on both ends of the bolt to tighten. There is > No need to get on the other side of the baggage floor to get access to > the bolt head. I installed nut plates on all of the seat and baggage > floor ribs to make it easy to remove the floor panels for annual > inspections... > > Gerry Filby wrote: > > > > > > >I'm installing the powder coated flap actuator weldment behind > >the seats. The plans call for platenuts on the underside of > >the seat rib to secure the center bearing block. I'm wondering > >why they don't use a simple nut, bolt and washer. I'm thinking > >of just bringing the bolt up from the underside and putting the > >washer and nyloc nut on the top. Seems like a lot of effort to > >install platenuts for not very much gain. What have others > >done here ? > > > >__g__ > > > >========================================================== > >Gerry Filby gerf(at)gerf.com > > Tel: 415 203 9177 > > > > > > > > > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Oct 06, 2005
Gerry, If the bolt is coming up through the rib from under the baggage floor, when you start to tighten the nut, the bolt will turn. How will you keep the bolt from turning when the floors are already in place preventing access to the bolt. I installed platenuts rather than rivets so that I could inspect under the seat and baggage floor to check for corrosion. I am not talking about the center channel which already has nut plates giving you access. Gerry Filby wrote: > > >Hmm. If you can't get a wrench on top of the bearing block to >tighten a nut, how can you do so to tighten down the bolt into >the platenut ? If I understand you right, you've changed all >the LP-4 rivets called out for the baggage floors in favor of >nutlplates and screws ? Why do you need to remove the baggage >floors for inspection ? The only thing to inspect is the >pushrod assembly that runs through the tunnel - and that I have >used platenuts/screws per the drawings. > >Not being combative, just trying to understand ... > >g > > > >> >>Gerry, If you do as you propose, how will you get a wrench on the bolt >>to tighten the nyloc nut on the top side of the bearing block. Nut >>plates are very easy to install (you only have to install them 1 time) >>and you don't have to get on both ends of the bolt to tighten. There is >>No need to get on the other side of the baggage floor to get access to >>the bolt head. I installed nut plates on all of the seat and baggage >>floor ribs to make it easy to remove the floor panels for annual >>inspections... >> >>Gerry Filby wrote: >> >> >> >>> >>> >>>I'm installing the powder coated flap actuator weldment behind >>>the seats. The plans call for platenuts on the underside of >>>the seat rib to secure the center bearing block. I'm wondering >>>why they don't use a simple nut, bolt and washer. I'm thinking >>>of just bringing the bolt up from the underside and putting the >>>washer and nyloc nut on the top. Seems like a lot of effort to >>>install platenuts for not very much gain. What have others >>>done here ? >>> >>>__g__ >>> >>>========================================================== >>>Gerry Filby gerf(at)gerf.com >>> Tel: 415 203 9177 >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Oct 06, 2005
The two floor ribs, either side of the control rod tunnel, have their flanges pointing inwards [shiver runs down spine, runs out to look at the drawings, phew! I did read the drawings right]. The bearing block is bolted through this rib flange and the floor. So you have access to the bolt head from inside the control rod tunnel which has a removable cover. This is the same access you would use to rivet on the nutplates since the instructions have you rivet through the floor and rib after the floor is installed. I have already gone with the blind rivets, per the drawings, for the baggage floors and they are already in place. I admit that its a nice idea to be able to remove the floors, but I'm past that stage already and I made sure to Akzo prime the bottom skin and the ribs, so I'm not overly concerned about corrosion in this area. Having said that, if I did this again I would replace those skins with a slightly heavier gauge sheet - they are real flimsy. g > > > Gerry, If the bolt is coming up through the rib from under the baggage > floor, when you start to tighten the nut, the bolt will turn. How will > you keep the bolt from turning when the floors are already in place > preventing access to the bolt. I installed platenuts rather > than rivets > so that I could inspect under the seat and baggage floor to check for > corrosion. I am not talking about the center channel which already has > nut plates giving you access. > > Gerry Filby wrote: > > > > > > >Hmm. If you can't get a wrench on top of the bearing block to > >tighten a nut, how can you do so to tighten down the bolt into > >the platenut ? If I understand you right, you've changed all > >the LP-4 rivets called out for the baggage floors in favor of > >nutlplates and screws ? Why do you need to remove the baggage > >floors for inspection ? The only thing to inspect is the > >pushrod assembly that runs through the tunnel - and that I have > >used platenuts/screws per the drawings. > > > >Not being combative, just trying to understand ... > > > >g > > > > > > > >> > >>Gerry, If you do as you propose, how will you get a wrench on the bolt > >>to tighten the nyloc nut on the top side of the bearing block. Nut > >>plates are very easy to install (you only have to install them 1 time) > >>and you don't have to get on both ends of the bolt to tighten. There is > >>No need to get on the other side of the baggage floor to get access to > >>the bolt head. I installed nut plates on all of the seat and baggage > >>floor ribs to make it easy to remove the floor panels for annual > >>inspections... > >> > >>Gerry Filby wrote: > >> > >> > >> > >>> > >>> > >>>I'm installing the powder coated flap actuator weldment behind > >>>the seats. The plans call for platenuts on the underside of > >>>the seat rib to secure the center bearing block. I'm wondering > >>>why they don't use a simple nut, bolt and washer. I'm thinking > >>>of just bringing the bolt up from the underside and putting the > >>>washer and nyloc nut on the top. Seems like a lot of effort to > >>>install platenuts for not very much gain. What have others > >>>done here ? > >>> > >>>__g__ > >>> > >>>========================================================== > >>>Gerry Filby gerf(at)gerf.com > >>> Tel: 415 203 9177 > >>> > >>> > >>> > >>> > >>> > >>> > >> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Oct 06, 2005
Gerry, You are correct. The rib flange is toward the (center) tunnel. It has been a long time since I worked on the center section of the fuse and I was thinking the flange was towards the outside. I live in South Fla and with the high humidity and living so close to the ocean, corrosion is a big problem . That is why I made all of the floors removable buy using nut plates. Gerry Filby wrote: > > >The two floor ribs, either side of the control rod tunnel, have >their flanges pointing inwards [shiver runs down spine, runs >out to look at the drawings, phew! I did read the drawings >right]. The bearing block is bolted through this rib flange >and the floor. So you have access to the bolt head from inside >the control rod tunnel which has a removable cover. This is >the same access you would use to rivet on the nutplates since >the instructions have you rivet through the floor and rib after >the floor is installed. > >I have already gone with the blind rivets, per the drawings, >for the baggage floors and they are already in place. I admit >that its a nice idea to be able to remove the floors, but I'm >past that stage already and I made sure to Akzo prime the >bottom skin and the ribs, so I'm not overly concerned about >corrosion in this area. Having said that, if I did this again >I would replace those skins with a slightly heavier gauge sheet >- they are real flimsy. > >g > > > >> >>Gerry, If the bolt is coming up through the rib from under the baggage >>floor, when you start to tighten the nut, the bolt will turn. How will >>you keep the bolt from turning when the floors are already in place >>preventing access to the bolt. I installed platenuts rather >>than rivets >>so that I could inspect under the seat and baggage floor to check for >>corrosion. I am not talking about the center channel which already has >>nut plates giving you access. >> >>Gerry Filby wrote: >> >> >> >>> >>> >>>Hmm. If you can't get a wrench on top of the bearing block to >>>tighten a nut, how can you do so to tighten down the bolt into >>>the platenut ? If I understand you right, you've changed all >>>the LP-4 rivets called out for the baggage floors in favor of >>>nutlplates and screws ? Why do you need to remove the baggage >>>floors for inspection ? The only thing to inspect is the >>>pushrod assembly that runs through the tunnel - and that I have >>>used platenuts/screws per the drawings. >>> >>>Not being combative, just trying to understand ... >>> >>>g >>> >>> >>> >>> >>> >>>> >>>>Gerry, If you do as you propose, how will you get a wrench on the bolt >>>>to tighten the nyloc nut on the top side of the bearing block. Nut >>>>plates are very easy to install (you only have to install them 1 time) >>>>and you don't have to get on both ends of the bolt to tighten. There is >>>>No need to get on the other side of the baggage floor to get access to >>>>the bolt head. I installed nut plates on all of the seat and baggage >>>>floor ribs to make it easy to remove the floor panels for annual >>>>inspections... >>>> >>>>Gerry Filby wrote: >>>> >>>> >>>> >>>> >>>> >>>>> >>>>> >>>>>I'm installing the powder coated flap actuator weldment behind >>>>>the seats. The plans call for platenuts on the underside of >>>>>the seat rib to secure the center bearing block. I'm wondering >>>>>why they don't use a simple nut, bolt and washer. I'm thinking >>>>>of just bringing the bolt up from the underside and putting the >>>>>washer and nyloc nut on the top. Seems like a lot of effort to >>>>>install platenuts for not very much gain. What have others >>>>>done here ? >>>>> >>>>>__g__ >>>>> >>>>>========================================================== >>>>>Gerry Filby gerf(at)gerf.com >>>>> Tel: 415 203 9177 >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Oct 06, 2005
Thanks Jim, I appreciate your taking the time to discuss the options ... g > > > Gerry, You are correct. The rib flange is toward the (center) > tunnel. > It has been a long time since I worked on the center section of > the fuse > and I was thinking the flange was towards the outside. > I live in South Fla and with the high humidity and living so close to > the ocean, corrosion is a big problem . That is why I made all of the > floors removable buy using nut plates. > > Gerry Filby wrote: > > > > > > >The two floor ribs, either side of the control rod tunnel, have > >their flanges pointing inwards [shiver runs down spine, runs > >out to look at the drawings, phew! I did read the drawings > >right]. The bearing block is bolted through this rib flange > >and the floor. So you have access to the bolt head from inside > >the control rod tunnel which has a removable cover. This is > >the same access you would use to rivet on the nutplates since > >the instructions have you rivet through the floor and rib after > >the floor is installed. > > > >I have already gone with the blind rivets, per the drawings, > >for the baggage floors and they are already in place. I admit > >that its a nice idea to be able to remove the floors, but I'm > >past that stage already and I made sure to Akzo prime the > >bottom skin and the ribs, so I'm not overly concerned about > >corrosion in this area. Having said that, if I did this again > >I would replace those skins with a slightly heavier gauge sheet > >- they are real flimsy. > > > >g > > > > > > > >> > >>Gerry, If the bolt is coming up through the rib from under the baggage > >>floor, when you start to tighten the nut, the bolt will turn. How will > >>you keep the bolt from turning when the floors are already in place > >>preventing access to the bolt. I installed platenuts rather > >>than rivets > >>so that I could inspect under the seat and baggage floor to check for > >>corrosion. I am not talking about the center channel which already has > >>nut plates giving you access. > >> > >>Gerry Filby wrote: > >> > >> > >> > >>> > >>> > >>>Hmm. If you can't get a wrench on top of the bearing block to > >>>tighten a nut, how can you do so to tighten down the bolt into > >>>the platenut ? If I understand you right, you've changed all > >>>the LP-4 rivets called out for the baggage floors in favor of > >>>nutlplates and screws ? Why do you need to remove the baggage > >>>floors for inspection ? The only thing to inspect is the > >>>pushrod assembly that runs through the tunnel - and that I have > >>>used platenuts/screws per the drawings. > >>> > >>>Not being combative, just trying to understand ... > >>> > >>>g > >>> > >>> > >>> > >>> > >>> > >>>> > >>>>Gerry, If you do as you propose, how will you get a wrench on the bolt > >>>>to tighten the nyloc nut on the top side of the bearing block. Nut > >>>>plates are very easy to install (you only have to install them 1 time) > >>>>and you don't have to get on both ends of the bolt to tighten. There is > >>>>No need to get on the other side of the baggage floor to get access to > >>>>the bolt head. I installed nut plates on all of the seat and baggage > >>>>floor ribs to make it easy to remove the floor panels for annual > >>>>inspections... > >>>> > >>>>Gerry Filby wrote: > >>>> > >>>> > >>>> > >>>> > >>>> > >>>>> > >>>>> > >>>>>I'm installing the powder coated flap actuator weldment behind > >>>>>the seats. The plans call for platenuts on the underside of > >>>>>the seat rib to secure the center bearing block. I'm wondering > >>>>>why they don't use a simple nut, bolt and washer. I'm thinking > >>>>>of just bringing the bolt up from the underside and putting the > >>>>>washer and nyloc nut on the top. Seems like a lot of effort to > >>>>>install platenuts for not very much gain. What have others > >>>>>done here ? > >>>>> > >>>>>__g__ > >>>>> > >>>>>========================================================== > >>>>>Gerry Filby gerf(at)gerf.com > >>>>> Tel: 415 203 9177 > >>>>> > >>>>> > >>>>> > >>>>> > >>>>> > >>>>> > >>>>> > >>>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>> > >>> > >>> > >>> > >> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Subject: KitLog Pro-first use
Date: Oct 15, 2005
INNOCENT GLOBAL 0.0000 1.0000 -4.4912 Fellow RV builders, I just installed KitLog Pro and started using it. I am finishing up my RV-7A fuselage and I have been less then diligent in entering daily progress in my Excel spread sheet that I was using as a building log. While I was up at the Copperstate Fly-in I passed by the KitLog booth and spent a few minutes with Paul Besing and I let him try to convince me why I should part with my money when I had my Excel log working. After a few minutes I realized that I could do more with the KitLog then my Excel spreadsheet log. I also realized that KitLog may just help me be more diligent with my entries. In addition the reports you can create will definitely help when it comes time to prepare for aircraft certification. I installed the program without incident and I was up and running. Now I can take all my digital photos and organize them in the log. This is something I couldn't do with my Excel spreadsheet. In addition I can post them to the KitLog website so others can see them or just for a second backup to my computer. The only things I wish it could do is while entering the data randomly pop-up inspirational messages like: "Your doing a great job" "Looks like a Grand Champion in the making" "Now you only have 29,999 rivets to go" "Your in the home stretch" "Measure twice cut once" Food for thought Paul Merems (RV-4/RV-7A) ________________________________________________________________________________
Subject: Canopy jettison
Date: Oct 16, 2005
I have just installed the C627 spring on the WD620 canopy jettison handle. Spring won't compress enough to allow release pins to clear WD716 canopy frame for jettison. Checked for proper clocking of WD619 canopy release shaft, and ears point outboard as directed. Without the spring everything works perfectly. It appears that the spring is too heavy a guage to permit the almost 3 to 1 compression required by the full stroke. Any experiences on this? RV9A finishing C-FYOO (reserve) Randy ________________________________________________________________________________
Subject: RE: RV9-List Digest: 1 Msgs - 10/15/05
Date: Oct 16, 2005
I would like to unsubscribe from this group. Thank you. -----Original Message----- From: owner-rv9-list-server(at)matronics.com [mailto:owner-rv9-list-server(at)matronics.com] On Behalf Of RV9-List Digest Server Subject: RV9-List Digest: 1 Msgs - 10/15/05 * ================================================== Online Versions of Today's List Digest Archive ================================================== Today's complete RV9-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV9-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/rv9-list/Digest.RV9-List.2005-10-15.html Text Version: http://www.matronics.com/digest/rv9-list/Digest.RV9-List.2005-10-15.txt ================================================ EMail Version of Today's List Digest Archive ================================================ RV9-List Digest Archive --- Total Messages Posted Sat 10/15/05: 1 Today's Message Index: ---------------------- 1. 04:19 PM - KitLog Pro-first use (Merems) ________________________________ Message 1 _____________________________________ From: "Merems" <merems(at)cox.net> Subject: RV9-List: KitLog Pro-first use INNOCENT GLOBAL 0.0000 1.0000 -4.4912 Fellow RV builders, I just installed KitLog Pro and started using it. I am finishing up my RV-7A fuselage and I have been less then diligent in entering daily progress in my Excel spread sheet that I was using as a building log. While I was up at the Copperstate Fly-in I passed by the KitLog booth and spent a few minutes with Paul Besing and I let him try to convince me why I should part with my money when I had my Excel log working. After a few minutes I realized that I could do more with the KitLog then my Excel spreadsheet log. I also realized that KitLog may just help me be more diligent with my entries. In addition the reports you can create will definitely help when it comes time to prepare for aircraft certification. I installed the program without incident and I was up and running. Now I can take all my digital photos and organize them in the log. This is something I couldn't do with my Excel spreadsheet. In addition I can post them to the KitLog website so others can see them or just for a second backup to my computer. The only things I wish it could do is while entering the data randomly pop-up inspirational messages like: "Your doing a great job" "Looks like a Grand Champion in the making" "Now you only have 29,999 rivets to go" "Your in the home stretch" "Measure twice cut once" Food for thought Paul Merems (RV-4/RV-7A) ________________________________________________________________________________
Subject: Re: Canopy jettison
Date: Oct 17, 2005
Randy: I had the same problem. I drilled another hole about 1.75" down and stretched out the spring. Works fine. Ron Russ ----- Original Message ----- From: "Randy Russell" <rer51(at)netscape.ca> Subject: RV9-List: Canopy jettison > > I have just installed the C627 spring on the WD620 canopy jettison handle. > Spring won't compress enough to allow release pins to clear WD716 canopy > frame for jettison. Checked for proper clocking of WD619 canopy release > shaft, and ears point outboard as directed. Without the spring everything > works perfectly. It appears that the spring is too heavy a guage to permit > the almost 3 to 1 compression required by the full stroke. Any > experiences on this? RV9A finishing C-FYOO (reserve) Randy > > > ________________________________________________________________________________
Subject: FOR SALE: RV-9A step kit (left & right) ... My stupidity is
your gain.
Date: Oct 17, 2005
1.66 HELO_DYNAMIC_DHCP Relay HELO'd using suspicious hostname (DHCP) 1.28 HELO_DYNAMIC_HCC Relay HELO'd using suspicious hostname (HCC) 1.36 HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP addr 1) What a dummy ... I'm building the RV-9 taildragger and I opted for the step kit. I'm tired of them sitting on the shelf mocking me ... Van's list price is $170 - yours for $85 (2 for the price of one) plus whatever shipping cost (PayPal). They're unpainted, raw steel - just as they came from Vans. First email to gerf(at)gerf.com plus payment received gets them. __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Oct 18, 2005
From: "Michael T. Ice" <aurbo(at)ak.net> is your gain.
Subject: Re: FOR SALE: RV-9A step kit (left & right) ... My stupidity
is your gain. Gerry, Why not put them on a tail dragger? I am building the 9 as well and although I have never seen a 9 in person I have seen lots of other tail dragger and they (some) have steps. Is the 9 low enough that you can easily step up on the wing? Mike Ice Anchorage, AK. ----- Original Message ----- From: "Gerry Filby" <gerf(at)gerf.com> Subject: RV9-List: FOR SALE: RV-9A step kit (left & right) ... My stupidity is your gain. > > What a dummy ... I'm building the RV-9 taildragger and I opted > for the step kit. I'm tired of them sitting on the shelf > mocking me ... > > Van's list price is $170 - yours for $85 (2 for the price of > one) plus whatever shipping cost (PayPal). > > They're unpainted, raw steel - just as they came from Vans. > First email to gerf(at)gerf.com plus payment received gets them. > > __g__ > > ========================================================== > Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 > > > ________________________________________________________________________________
Date: Oct 18, 2005
is your gain. Mike & Gerry, I am building a -9 here in the Dallas/Fort Worth area of Texas. A local builder has what I believe is the first -9 to fly. I recently saw this plane in person, and while I didn't physically get up into the cockpit, the wing is very low, and looks VERY easy to step up on. I have a few photos of this -9 if you send your email address, I will fwd them. It is a beautiful bird! Take care, Gary Robertson -9, About to start on wings...... "Michael T. Ice" , UNEXPECTED_DATA_AFTER_ADDRESS(at).SYNTAX-ERROR. wrote: Gerry, Why not put them on a tail dragger? I am building the 9 as well and although I have never seen a 9 in person I have seen lots of other tail dragger and they (some) have steps. Is the 9 low enough that you can easily step up on the wing? Mike Ice Anchorage, AK. ----- Original Message ----- From: "Gerry Filby" Subject: RV9-List: FOR SALE: RV-9A step kit (left & right) ... My stupidity is your gain. > > What a dummy ... I'm building the RV-9 taildragger and I opted > for the step kit. I'm tired of them sitting on the shelf > mocking me ... > > Van's list price is $170 - yours for $85 (2 for the price of > one) plus whatever shipping cost (PayPal). > > They're unpainted, raw steel - just as they came from Vans. > First email to gerf(at)gerf.com plus payment received gets them. > > __g__ > > ========================================================== > Gerry Filby gerf(at)gerf.com > Tel: 415 203 9177 > > > ________________________________________________________________________________
is your gain.
Date: Oct 18, 2005
There is no point to te steps on the tail dragger, the wing walk is plenty low enough to the ground to step up. All you achieve by adding them is extra drag ! g > > > > Mike & Gerry, > > I am building a -9 here in the Dallas/Fort Worth area of Texas. > A local builder has what I believe is the first -9 to fly. I > recently saw this plane in person, and while I didn't > physically get up into the cockpit, the wing is very low, and > looks VERY easy to step up on. I have a few photos of this -9 > if you send your email address, I will fwd them. It is a > beautiful bird! > > Take care, > > Gary Robertson > -9, About to start on wings...... > > "Michael T. Ice" , > UNEXPECTED_DATA_AFTER_ADDRESS@.SYNTAX-ERROR. wrote: > > Gerry, > > Why not put them on a tail dragger? > > I am building the 9 as well and although I have never seen a 9 > in person I > have seen lots of other tail dragger and they (some) have > steps. Is the 9 > low enough that you can easily step up on the wing? > > Mike Ice > Anchorage, AK. > ----- Original Message ----- > From: "Gerry Filby" > To: > Subject: RV9-List: FOR SALE: RV-9A step kit (left & right) ... > My stupidity > is your gain. > > > > > > What a dummy ... I'm building the RV-9 taildragger and I opted > > for the step kit. I'm tired of them sitting on the shelf > > mocking me ... > > > > Van's list price is $170 - yours for $85 (2 for the price of > > one) plus whatever shipping cost (PayPal). > > > > They're unpainted, raw steel - just as they came from Vans. > > First email to gerf(at)gerf.com plus payment received gets them. > > > > __g__ > > > > ========================================================== > > Gerry Filby gerf(at)gerf.com > > Tel: 415 203 9177 > > > > > > > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Oct 18, 2005
is your gain. Hi Gerry, No you certainly don't need steps on a 9. Even small children easily step over the flaps onto the wingwalk. To the folks in Texas who thinks they are the first taildragger 9, I'm really curious. When was the first flight? I have always thought mine was the first to fly. See this year's Van's calender, month of March. My first flight was 2/22/04. Dennis Thomas RV-9,N164DV 236 hours and loving it --- Gary Robertson wrote: > > > Mike & Gerry, > > I am building a -9 here in the Dallas/Fort Worth > area of Texas. A local builder has what I believe > is the first -9 to fly. I recently saw this plane > in person, and while I didn't physically get up into > the cockpit, the wing is very low, and looks VERY > easy to step up on. I have a few photos of this -9 > if you send your email address, I will fwd them. It > is a beautiful bird! > > Take care, > > Gary Robertson > -9, About to start on wings...... > > "Michael T. Ice" , > UNEXPECTED_DATA_AFTER_ADDRESS@.SYNTAX-ERROR. wrote: > your gain. > > Gerry, > > Why not put them on a tail dragger? > > I am building the 9 as well and although I have > never seen a 9 in person I > have seen lots of other tail dragger and they (some) > have steps. Is the 9 > low enough that you can easily step up on the wing? > > Mike Ice > Anchorage, AK. > ----- Original Message ----- > From: "Gerry Filby" > To: > Subject: RV9-List: FOR SALE: RV-9A step kit (left & > right) ... My stupidity > is your gain. > > > > > > What a dummy ... I'm building the RV-9 taildragger > and I opted > > for the step kit. I'm tired of them sitting on the > shelf > > mocking me ... > > > > Van's list price is $170 - yours for $85 (2 for > the price of > > one) plus whatever shipping cost (PayPal). > > > > They're unpainted, raw steel - just as they came > from Vans. > > First email to gerf(at)gerf.com plus payment received > gets them. > > > > __g__ > > > > > ========================================================== > > Gerry Filby gerf(at)gerf.com > > Tel: 415 203 9177 > > > > > > > > > > browse > Subscriptions page, > FAQ, > > > > > > ________________________________________________________________________________
is your gain.
Date: Oct 18, 2005
The first flight of N9TD (a Texas RV-9) was made by Dave Austin on Jan 30th 2004.. The aircraft was built and owned by Tin Donham. I now own the airplane. Vic ----- Original Message ----- From: <dthomas773(at)sbcglobal.net> Subject: Re: RV9-List: FOR SALE: RV-9A step kit (left & right) ... My stupidity is your gain. > > Hi Gerry, > No you certainly don't need steps on a 9. Even small > children easily step over the flaps onto the wingwalk. > > To the folks in Texas who thinks they are the first > taildragger 9, I'm really curious. When was the first > flight? I have always thought mine was the first to > fly. See this year's Van's calender, month of March. > My first flight was 2/22/04. > > Dennis Thomas > RV-9,N164DV > 236 hours and loving it > --- Gary Robertson > wrote: > >> >> >> Mike & Gerry, >> >> I am building a -9 here in the Dallas/Fort Worth >> area of Texas. A local builder has what I believe >> is the first -9 to fly. I recently saw this plane >> in person, and while I didn't physically get up into >> the cockpit, the wing is very low, and looks VERY >> easy to step up on. I have a few photos of this -9 >> if you send your email address, I will fwd them. It >> is a beautiful bird! >> >> Take care, >> >> Gary Robertson >> -9, About to start on wings...... >> >> "Michael T. Ice" , >> UNEXPECTED_DATA_AFTER_ADDRESS@.SYNTAX-ERROR. wrote: >> your gain. >> >> Gerry, >> >> Why not put them on a tail dragger? >> >> I am building the 9 as well and although I have >> never seen a 9 in person I >> have seen lots of other tail dragger and they (some) >> have steps. Is the 9 >> low enough that you can easily step up on the wing? >> >> Mike Ice >> Anchorage, AK. >> ----- Original Message ----- >> From: "Gerry Filby" >> To: >> Subject: RV9-List: FOR SALE: RV-9A step kit (left & >> right) ... My stupidity >> is your gain. >> >> >> > >> > What a dummy ... I'm building the RV-9 taildragger >> and I opted >> > for the step kit. I'm tired of them sitting on the >> shelf >> > mocking me ... >> > >> > Van's list price is $170 - yours for $85 (2 for >> the price of >> > one) plus whatever shipping cost (PayPal). >> > >> > They're unpainted, raw steel - just as they came >> from Vans. >> > First email to gerf(at)gerf.com plus payment received >> gets them. >> > >> > __g__ >> > >> > >> > ========================================================== >> > Gerry Filby gerf(at)gerf.com >> > Tel: 415 203 9177 >> > >> > >> > >> >> >> >> browse >> Subscriptions page, >> FAQ, >> >> >> >> >> >> > > > ________________________________________________________________________________
is your gain.
Date: Oct 18, 2005
Interesting point - I wonder how many 9s are now flying ? > > > Hi Gerry, > No you certainly don't need steps on a 9. Even small > children easily step over the flaps onto the wingwalk. > > To the folks in Texas who thinks they are the first > taildragger 9, I'm really curious. When was the first > flight? I have always thought mine was the first to > fly. See this year's Van's calender, month of March. > My first flight was 2/22/04. > > Dennis Thomas > RV-9,N164DV > 236 hours and loving it > --- Gary Robertson > wrote: > > > > > > > Mike & Gerry, > > > > I am building a -9 here in the Dallas/Fort Worth > > area of Texas. A local builder has what I believe > > is the first -9 to fly. I recently saw this plane > > in person, and while I didn't physically get up into > > the cockpit, the wing is very low, and looks VERY > > easy to step up on. I have a few photos of this -9 > > if you send your email address, I will fwd them. It > > is a beautiful bird! > > > > Take care, > > > > Gary Robertson > > -9, About to start on wings...... > > > > "Michael T. Ice" , > > UNEXPECTED_DATA_AFTER_ADDRESS@.SYNTAX-ERROR. wrote: > > your gain. > > > > Gerry, > > > > Why not put them on a tail dragger? > > > > I am building the 9 as well and although I have > > never seen a 9 in person I > > have seen lots of other tail dragger and they (some) > > have steps. Is the 9 > > low enough that you can easily step up on the wing? > > > > Mike Ice > > Anchorage, AK. > > ----- Original Message ----- > > From: "Gerry Filby" > > To: > > Subject: RV9-List: FOR SALE: RV-9A step kit (left & > > right) ... My stupidity > > is your gain. > > > > > > > > > > What a dummy ... I'm building the RV-9 taildragger > > and I opted > > > for the step kit. I'm tired of them sitting on the > > shelf > > > mocking me ... > > > > > > Van's list price is $170 - yours for $85 (2 for > > the price of > > > one) plus whatever shipping cost (PayPal). > > > > > > They're unpainted, raw steel - just as they came > > from Vans. > > > First email to gerf(at)gerf.com plus payment received > > gets them. > > > > > > __g__ > > > > > > > > > ========================================================== > > > Gerry Filby gerf(at)gerf.com > > > Tel: 415 203 9177 > > > > > > > > > > > > > > > > > browse > > Subscriptions page, > > FAQ, > > > > > > > > > > > > > > > > > > > -- __g__ ========================================================== Gerry Filby gerf(at)gerf.com Tel: 415 203 9177 ________________________________________________________________________________
Date: Oct 18, 2005
is your gain. Tim's plane is the one I was referring to when I said I had recently seen one. Nice plane! It was also interesting hearing Tim's build story...as a fireman, he had 48-hours stretches at a time to build, build, build (24-on, 48-off). I enjoyed speaking with him. I know the -9 was his second RV to build, and it is my understanding that he is now building a third. Hey Vic, where are you located? Gary Robertson N104GR Reserved -9 (working on wings) Vic Jacko wrote: The first flight of N9TD (a Texas RV-9) was made by Dave Austin on Jan 30th 2004.. The aircraft was built and owned by Tin Donham. I now own the airplane. Vic ----- Original Message ----- From: Subject: Re: RV9-List: FOR SALE: RV-9A step kit (left & right) ... My stupidity is your gain. > > Hi Gerry, > No you certainly don't need steps on a 9. Even small > children easily step over the flaps onto the wingwalk. > > To the folks in Texas who thinks they are the first > taildragger 9, I'm really curious. When was the first > flight? I have always thought mine was the first to > fly. See this year's Van's calender, month of March. > My first flight was 2/22/04. > > Dennis Thomas > RV-9,N164DV > 236 hours and loving it > --- Gary Robertson > wrote: > >> >> >> Mike & Gerry, >> >> I am building a -9 here in the Dallas/Fort Worth >> area of Texas. A local builder has what I believe >> is the first -9 to fly. I recently saw this plane >> in person, and while I didn't physically get up into >> the cockpit, the wing is very low, and looks VERY >> easy to step up on. I have a few photos of this -9 >> if you send your email address, I will fwd them. It >> is a beautiful bird! >> >> Take care, >> >> Gary Robertson >> -9, About to start on wings...... >> >> "Michael T. Ice" , >> UNEXPECTED_DATA_AFTER_ADDRESS@.SYNTAX-ERROR. wrote: >> your gain. >> >> Gerry, >> >> Why not put them on a tail dragger? >> >> I am building the 9 as well and although I have >> never seen a 9 in person I >> have seen lots of other tail dragger and they (some) >> have steps. Is the 9 >> low enough that you can easily step up on the wing? >> >> Mike Ice >> Anchorage, AK. >> ----- Original Message ----- >> From: "Gerry Filby" >> To: >> Subject: RV9-List: FOR SALE: RV-9A step kit (left & >> right) ... My stupidity >> is your gain. >> >> >> > >> > What a dummy ... I'm building the RV-9 taildragger >> and I opted >> > for the step kit. I'm tired of them sitting on the >> shelf >> > mocking me ... >> > >> > Van's list price is $170 - yours for $85 (2 for >> the price of >> > one) plus whatever shipping cost (PayPal). >> > >> > They're unpainted, raw steel - just as they came >> from Vans. >> > First email to gerf(at)gerf.com plus payment received >> gets them. >> > >> > __g__ >> > >> > >> > ========================================================== >> > Gerry Filby gerf(at)gerf.com >> > Tel: 415 203 9177 >> > >> > >> > >> >> >> >> browse >> Subscriptions page, >> FAQ, >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Oct 18, 2005
is your gain. Wow! You beat me by 3 weeks and a day. I have always told everyone I was first. I guess I will need to back track. Dennis Thomas --- Vic Jacko wrote: > > > The first flight of N9TD (a Texas RV-9) was made > by Dave Austin on Jan > 30th 2004.. The aircraft was built and owned by > Tin Donham. > > I now own the airplane. > > Vic > ----- Original Message ----- > From: <dthomas773(at)sbcglobal.net> > To: > Subject: Re: RV9-List: FOR SALE: RV-9A step kit > (left & right) ... My > stupidity is your gain. > > > > > > > Hi Gerry, > > No you certainly don't need steps on a 9. Even > small > > children easily step over the flaps onto the > wingwalk. > > > > To the folks in Texas who thinks they are the > first > > taildragger 9, I'm really curious. When was the > first > > flight? I have always thought mine was the first > to > > fly. See this year's Van's calender, month of > March. > > My first flight was 2/22/04. > > > > Dennis Thomas > > RV-9,N164DV > > 236 hours and loving it > > --- Gary Robertson > > wrote: > > > >> > >> > >> Mike & Gerry, > >> > >> I am building a -9 here in the Dallas/Fort Worth > >> area of Texas. A local builder has what I > believe > >> is the first -9 to fly. I recently saw this > plane > >> in person, and while I didn't physically get up > into > >> the cockpit, the wing is very low, and looks VERY > >> easy to step up on. I have a few photos of this > -9 > >> if you send your email address, I will fwd them. > It > >> is a beautiful bird! > >> > >> Take care, > >> > >> Gary Robertson > >> -9, About to start on wings...... > >> > >> "Michael T. Ice" , > >> UNEXPECTED_DATA_AFTER_ADDRESS@.SYNTAX-ERROR. > wrote: > is > >> your gain. > >> > >> Gerry, > >> > >> Why not put them on a tail dragger? > >> > >> I am building the 9 as well and although I have > >> never seen a 9 in person I > >> have seen lots of other tail dragger and they > (some) > >> have steps. Is the 9 > >> low enough that you can easily step up on the > wing? > >> > >> Mike Ice > >> Anchorage, AK. > >> ----- Original Message ----- > >> From: "Gerry Filby"
April 17, 2005 - October 23, 2005
RV9-Archive.digest.vol-ar
