RVSouthEast-Archive.digest.vol-ac
September 16, 2004 - October 12, 2004
      >> Larry Vetterman suggested the turn downs -- the way his exhaust use to
      >> be.
      >> Right now things are so loud, I'd give up five knots for some relief.
      >> I'll try some insulation first.
      >> Thanks,
      >> Larry Bowen
      >> Larry(at)BowenAero.com
      >> http://BowenAero.com
      >> Dennis & Lori Millsap said:
      >>> Dennis says that he's noticed that he should add more foam to the side
      >>> panels--more for noise than anything. He treated the firewall primarily
      >>> for
      >>> heat (he thought) but it's the noise that gets ya.
      >>> What do you mean by "turn downs"? Dennis cut his exhaust pipes off. You
      >>> don't want them hanging down in the airstream. Let them be loud, but
      >>> for
      >>> goodness sake, don't let them slow ya down! GRIN!
      >>> Actually, it puts undue stress on your exhaust system having them
      >>> hanging
      >>> out in the wind. Dennis broke a bracket or two before he cut them off.
      >>> Lori
      >>> N464DM, RV-6A, 300+ hours
      >>> ----- Original Message -----
      >>> From: "Larry Bowen" <Larry(at)bowenaero.com>
      >>> To:
      >>> Subject: RE: RVSouthEast-List: Flakes in fuel
      >>>> I ordered this last night:
      >>>> http://www.aircraftspruce.com/catalog/appages/dampingpanels.php
      >>>> Does dampening the firewall give the most gain for the effort?  Or do
      >>>> the
      >>>> sidewalls need to be done too?
      >>>> I'm thinking of getting some turn-downs for the exhaust pipes too...
      >>>> Larry Bowen
      >>>> > -----Original Message-----
      >>>> > From: Steve Glasgow [mailto:willfly(at)carolina.rr.com]
      >>>> > Sent: Wednesday, September 15, 2004 9:17 PM
      >>>> > To: rvsoutheast-list(at)matronics.com
      >>>> > Subject: Re: RVSouthEast-List: Flakes in fuel
      >>>> > Mike and I used Koolmat Heat Barrier from Spruce around page 123.
      >>>> > Used spray glue to hold it in place, no problems so far.
      >>>> > Just cut and paste!
      >>>> > Sorry to hear of the latest problem, better to quit after
      >>>> > start than after takeoff.  I promise after you have done your
      >>>> > time (40 hours) you will just fly it and put it to bed.  I
      >>>> > know you can't wait.
      >>>> > Steve
      >>>> > To:
      >>>> > > Thanks.
      >>>> > > I'm down for now.  I had to send the Rose ignition module
      >>>> > back.  It quite
      >>>> > > Sunday shortly after start-up.  Anyway, I'm taking the
      >>>> > opportunity to
      >>>> > > tweak
      >>>> > > some things and sound proof the firewall.  Boy that thing
      >>>> > is loud!!  Any
      >>>> > > tips for me related to sound-proofing?  Anyone?  Bueller?
      >>>> > > Larry Bowen
      >>>> > >> Sent: Wednesday, September 15, 2004 8:23 PM
      >>>> > >> They are very small!  A spec for sure!
      >>>> > >> I even had them in OSH during preflight before I left.
      >>>> > >> Again congrats on the event and many more to come.
      >>>> > >> Steve
      >>>> > >> To:
      >>>> > >> > Like corn flakes sized flakes?  Or specs?  Proseal is
      >>>> > >> blakish, but doesn't
      >>>> > >> > break down from fuel.  Maybe it's from the fuel truck or
      >>>> > >> inground tank.
      >>>> > >> > I'd
      >>>> > >> > monitor to try to establish a trend, if any......
      >>>> > >> > Larry Bowen
      >>>> > >> >> Sent: Wednesday, September 15, 2004 4:46 PM
      >>>> > >> >> To: SERV
      >>>> > >> >> Subject: RVSouthEast-List: Flakes in fuel
      >>>> > >> >> During preflight when the aircraft has set for some time,
      >>>> > >> >> when I drain fuel from under the wing I find some brown or
      >>>> > >> >> blackish flakes.  It takes about 6 ounces of draining to
      >>>> > >> >> clear up the flakes.
      >>>> > >> >> Has anyone experienced something similar?
      >>>> > >> >> I have a OB 8.  Could it be the tanks sealer is dissolving?
      >>>> > >> >> Thanks,
      >>>> > >> >> Steve Glasgow
      >>>> > >> >> Matronics Forums.
Subject: Re: Noise (was Flakes in fuel)
Date: Sep 16, 2004
Larry are you still using that in-the-ear headset? I was just wondering if that's the best choice for a noisy plane like an RV. I bought the lightspeed crosscountry anr headset and the noise doesn't seem too bad to me as a new rv driver. Actually, not bad at all, even with the anr turned off. I haven't done anything to the firewall. My exhaust pipes do have an angled section at the ends. is that the turn down you're talking about? Robert Dickson RV-6A 0-360, CS 21 hours, new cylinder #3 back tomorrow, I hope. On Sep 16, 2004, at 7:42 AM, Larry Bowen wrote: > > > Larry Vetterman suggested the turn downs -- the way his exhaust use to > be. > Right now things are so loud, I'd give up five knots for some relief. > I'll try some insulation first. > > Thanks, > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > Dennis & Lori Millsap said: >> >> >> Dennis says that he's noticed that he should add more foam to the side >> panels--more for noise than anything. He treated the firewall >> primarily >> for >> heat (he thought) but it's the noise that gets ya. >> >> What do you mean by "turn downs"? Dennis cut his exhaust pipes off. >> You >> don't want them hanging down in the airstream. Let them be loud, but >> for >> goodness sake, don't let them slow ya down! GRIN! >> >> Actually, it puts undue stress on your exhaust system having them >> hanging >> out in the wind. Dennis broke a bracket or two before he cut them off. >> >> Lori >> N464DM, RV-6A, 300+ hours >> ----- Original Message ----- >> From: "Larry Bowen" <Larry(at)bowenaero.com> >> To: >> Subject: RE: RVSouthEast-List: Flakes in fuel >> >> >> >>> >>> I ordered this last night: >>> >>> http://www.aircraftspruce.com/catalog/appages/dampingpanels.php >>> >>> Does dampening the firewall give the most gain for the effort? Or do >>> the >>> sidewalls need to be done too? >>> >>> I'm thinking of getting some turn-downs for the exhaust pipes too... >>> >>> - >>> Larry Bowen >>> Larry(at)BowenAero.com >>> http://BowenAero.com >>> >>> >>>> -----Original Message----- >>>> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >>>> Sent: Wednesday, September 15, 2004 9:17 PM >>>> To: rvsoutheast-list(at)matronics.com >>>> Subject: Re: RVSouthEast-List: Flakes in fuel >>>> >>>> --> >>>> >>>> Mike and I used Koolmat Heat Barrier from Spruce around page 123. >>>> >>>> Used spray glue to hold it in place, no problems so far. >>>> Just cut and paste! >>>> >>>> Sorry to hear of the latest problem, better to quit after >>>> start than after takeoff. I promise after you have done your >>>> time (40 hours) you will just fly it and put it to bed. I >>>> know you can't wait. >>>> >>>> Steve >>>> >>>> ----- Original Message ----- >>>> From: "Larry Bowen" <Larry(at)bowenaero.com> >>>> To: >>>> Subject: RE: RVSouthEast-List: Flakes in fuel >>>> >>>> >>>>> >>>>> >>>>> Thanks. >>>>> >>>>> I'm down for now. I had to send the Rose ignition module >>>> back. It quite >>>>> Sunday shortly after start-up. Anyway, I'm taking the >>>> opportunity to >>>>> tweak >>>>> some things and sound proof the firewall. Boy that thing >>>> is loud!! Any >>>>> tips for me related to sound-proofing? Anyone? Bueller? >>>>> >>>>> - >>>>> Larry Bowen >>>>> Larry(at)BowenAero.com >>>>> http://BowenAero.com >>>>> >>>>> >>>>>> -----Original Message----- >>>>>> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >>>>>> Sent: Wednesday, September 15, 2004 8:23 PM >>>>>> To: rvsoutheast-list(at)matronics.com >>>>>> Subject: Re: RVSouthEast-List: Flakes in fuel >>>>>> >>>>>> --> >>>>>> >>>>>> They are very small! A spec for sure! >>>>>> >>>>>> I even had them in OSH during preflight before I left. >>>>>> >>>>>> Again congrats on the event and many more to come. >>>>>> >>>>>> Steve >>>>>> >>>>>> >>>>>> ----- Original Message ----- >>>>>> From: "Larry Bowen" <Larry(at)bowenaero.com> >>>>>> To: >>>>>> Subject: RE: RVSouthEast-List: Flakes in fuel >>>>>> >>>>>> >>>>>>> >>>>>>> >>>>>>> Like corn flakes sized flakes? Or specs? Proseal is >>>>>> blakish, but doesn't >>>>>>> break down from fuel. Maybe it's from the fuel truck or >>>>>> inground tank. >>>>>>> I'd >>>>>>> monitor to try to establish a trend, if any...... >>>>>>> >>>>>>> - >>>>>>> Larry Bowen >>>>>>> Larry(at)BowenAero.com >>>>>>> http://BowenAero.com >>>>>>> >>>>>>> >>>>>>>> -----Original Message----- >>>>>>>> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >>>>>>>> Sent: Wednesday, September 15, 2004 4:46 PM >>>>>>>> To: SERV >>>>>>>> Subject: RVSouthEast-List: Flakes in fuel >>>>>>>> >>>>>>>> --> >>>>>>>> >>>>>>>> During preflight when the aircraft has set for some time, >>>>>>>> when I drain fuel from under the wing I find some brown or >>>>>>>> blackish flakes. It takes about 6 ounces of draining to >>>>>>>> clear up the flakes. >>>>>>>> >>>>>>>> Has anyone experienced something similar? >>>>>>>> >>>>>>>> I have a OB 8. Could it be the tanks sealer is dissolving? >>>>>>>> >>>>>>>> Thanks, >>>>>>>> >>>>>>>> Steve Glasgow >>>>>>>> >>>>>>>> >>>>>>>> ============ >>>>>>>> Matronics Forums. >>>>>>>> ============ >>>>>>>> ============ >>>>>>>> ============ >>>>>>>> >>>>>>>> >>>>>>>> >>>>>>>> >>>>>>>> >>>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>> >>>>>> >>>>>> ============ >>>>>> ============ >>>>>> ============ >>>>>> ============ >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>>> >>>>> >>>>> >>>>> >>>> >>>> >>>> ============ >>>> ============ >>>> ============ >>>> ============ >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >> >> > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Date: Sep 16, 2004
Koolmat has a fireproof rubbery like material on one side the side toward the back of the airplane and fiberglass impregnated on the side toward the firewall. It is much more substantive and stops almost all the oil canning of the firewall. I have a piece for you, where do I send it. I will get it in today's mail if you send me an address ASAP. Steve ----- Original Message ----- From: "Larry Bowen" <Larry(at)bowenaero.com> Subject: Re: RVSouthEast-List: Noise (was Flakes in fuel) > > > How is the coolmat different? Do you have a piece of scrap left I could > see? > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > Steve Glasgow said: >> >> >> Larry, I'm not happy with your choice of insulation. I got some of the >> one >> you are getting and some of the Koolmat before I decided. If I not >> mistaken >> the Koolmat is far superior. >> >> Just my thought. >> >> Steve >> >> >> ----- Original Message ----- >> From: "Larry Bowen" <Larry(at)bowenaero.com> >> To: >> Subject: Re: RVSouthEast-List: Noise (was Flakes in fuel) >> >> >>> >>> >>> Larry Vetterman suggested the turn downs -- the way his exhaust use to >>> be. >>> Right now things are so loud, I'd give up five knots for some relief. >>> I'll try some insulation first. >>> >>> Thanks, >>> >>> - >>> Larry Bowen >>> Larry(at)BowenAero.com >>> http://BowenAero.com >>> >>> Dennis & Lori Millsap said: >>>> >>>> >>>> Dennis says that he's noticed that he should add more foam to the side >>>> panels--more for noise than anything. He treated the firewall primarily >>>> for >>>> heat (he thought) but it's the noise that gets ya. >>>> >>>> What do you mean by "turn downs"? Dennis cut his exhaust pipes off. You >>>> don't want them hanging down in the airstream. Let them be loud, but >>>> for >>>> goodness sake, don't let them slow ya down! GRIN! >>>> >>>> Actually, it puts undue stress on your exhaust system having them >>>> hanging >>>> out in the wind. Dennis broke a bracket or two before he cut them off. >>>> >>>> Lori >>>> N464DM, RV-6A, 300+ hours >>>> ----- Original Message ----- >>>> From: "Larry Bowen" <Larry(at)bowenaero.com> >>>> To: >>>> Subject: RE: RVSouthEast-List: Flakes in fuel >>>> >>>> >>>> >>>>> >>>>> I ordered this last night: >>>>> >>>>> http://www.aircraftspruce.com/catalog/appages/dampingpanels.php >>>>> >>>>> Does dampening the firewall give the most gain for the effort? Or do >>>>> the >>>>> sidewalls need to be done too? >>>>> >>>>> I'm thinking of getting some turn-downs for the exhaust pipes too... >>>>> >>>>> - >>>>> Larry Bowen >>>>> Larry(at)BowenAero.com >>>>> http://BowenAero.com >>>>> >>>>> >>>>> > -----Original Message----- >>>>> > From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >>>>> > Sent: Wednesday, September 15, 2004 9:17 PM >>>>> > To: rvsoutheast-list(at)matronics.com >>>>> > Subject: Re: RVSouthEast-List: Flakes in fuel >>>>> > >>>>> > --> >>>>> > >>>>> > Mike and I used Koolmat Heat Barrier from Spruce around page 123. >>>>> > >>>>> > Used spray glue to hold it in place, no problems so far. >>>>> > Just cut and paste! >>>>> > >>>>> > Sorry to hear of the latest problem, better to quit after >>>>> > start than after takeoff. I promise after you have done your >>>>> > time (40 hours) you will just fly it and put it to bed. I >>>>> > know you can't wait. >>>>> > >>>>> > Steve >>>>> > >>>>> > ----- Original Message ----- >>>>> > From: "Larry Bowen" <Larry(at)bowenaero.com> >>>>> > To: >>>>> > Subject: RE: RVSouthEast-List: Flakes in fuel >>>>> > >>>>> > >>>>> > > >>>>> > > >>>>> > > Thanks. >>>>> > > >>>>> > > I'm down for now. I had to send the Rose ignition module >>>>> > back. It quite >>>>> > > Sunday shortly after start-up. Anyway, I'm taking the >>>>> > opportunity to >>>>> > > tweak >>>>> > > some things and sound proof the firewall. Boy that thing >>>>> > is loud!! Any >>>>> > > tips for me related to sound-proofing? Anyone? Bueller? >>>>> > > >>>>> > > - >>>>> > > Larry Bowen >>>>> > > Larry(at)BowenAero.com >>>>> > > http://BowenAero.com >>>>> > > >>>>> > > >>>>> > >> -----Original Message----- >>>>> > >> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >>>>> > >> Sent: Wednesday, September 15, 2004 8:23 PM >>>>> > >> To: rvsoutheast-list(at)matronics.com >>>>> > >> Subject: Re: RVSouthEast-List: Flakes in fuel >>>>> > >> >>>>> > >> --> >>>>> > >> >>>>> > >> They are very small! A spec for sure! >>>>> > >> >>>>> > >> I even had them in OSH during preflight before I left. >>>>> > >> >>>>> > >> Again congrats on the event and many more to come. >>>>> > >> >>>>> > >> Steve >>>>> > >> >>>>> > >> >>>>> > >> ----- Original Message ----- >>>>> > >> From: "Larry Bowen" <Larry(at)bowenaero.com> >>>>> > >> To: >>>>> > >> Subject: RE: RVSouthEast-List: Flakes in fuel >>>>> > >> >>>>> > >> >>>>> > >> > >>>>> > >> > >>>>> > >> > Like corn flakes sized flakes? Or specs? Proseal is >>>>> > >> blakish, but doesn't >>>>> > >> > break down from fuel. Maybe it's from the fuel truck or >>>>> > >> inground tank. >>>>> > >> > I'd >>>>> > >> > monitor to try to establish a trend, if any...... >>>>> > >> > >>>>> > >> > - >>>>> > >> > Larry Bowen >>>>> > >> > Larry(at)BowenAero.com >>>>> > >> > http://BowenAero.com >>>>> > >> > >>>>> > >> > >>>>> > >> >> -----Original Message----- >>>>> > >> >> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >>>>> > >> >> Sent: Wednesday, September 15, 2004 4:46 PM >>>>> > >> >> To: SERV >>>>> > >> >> Subject: RVSouthEast-List: Flakes in fuel >>>>> > >> >> >>>>> > >> >> --> >>>>> > >> >> >>>>> > >> >> During preflight when the aircraft has set for some time, >>>>> > >> >> when I drain fuel from under the wing I find some brown or >>>>> > >> >> blackish flakes. It takes about 6 ounces of draining to >>>>> > >> >> clear up the flakes. >>>>> > >> >> >>>>> > >> >> Has anyone experienced something similar? >>>>> > >> >> >>>>> > >> >> I have a OB 8. Could it be the tanks sealer is dissolving? >>>>> > >> >> >>>>> > >> >> Thanks, >>>>> > >> >> >>>>> > >> >> Steve Glasgow >>>>> > >> >> >>>>> > >> >> >>>>> > >> >> ============ >>>>> > >> >> Matronics Forums. >>>>> > >> >> ============ >>>>> > >> >> ============ >>>>> > >> >> ============ >>>>> > >> >> >>>>> > >> >> >>>>> > >> >> >>>>> > >> >> >>>>> > >> >> >>>>> > >> >> >>>>> > >> > >>>>> > >> > >>>>> > >> > >>>>> > >> >>>>> > >> >>>>> > >> ============ >>>>> > >> ============ >>>>> > >> ============ >>>>> > >> ============ >>>>> > >> >>>>> > >> >>>>> > >> >>>>> > >> >>>>> > >> >>>>> > >> >>>>> > > >>>>> > > >>>>> > > >>>>> > >>>>> > >>>>> > ============ >>>>> > ============ >>>>> > ============ >>>>> > ============ >>>>> > >>>>> > >>>>> > >>>>> > >>>>> > >>>>> > >>>>> >>>>> >>>> >>>> >>> >>> >>> >> >> > > > ________________________________________________________________________________
Date: Sep 16, 2004
I plan on using those, but right now I'm using the new pair of Telex ANR's. The stick-it-in-your-ear headsets worked fine as passenger in Len's plane. He just has firewall insulation, I think. Thanks, - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Robert Dickson said: > <robert@thenews-journal.com> > > Larry > are you still using that in-the-ear headset? I was just wondering if > that's the best choice for a noisy plane like an RV. I bought the > lightspeed crosscountry anr headset and the noise doesn't seem too bad > to me as a new rv driver. Actually, not bad at all, even with the anr > turned off. I haven't done anything to the firewall. My exhaust pipes > do have an angled section at the ends. is that the turn down you're > talking about? > > Robert Dickson > RV-6A 0-360, CS > 21 hours, new cylinder #3 back tomorrow, I hope. > > > On Sep 16, 2004, at 7:42 AM, Larry Bowen wrote: > >> >> >> Larry Vetterman suggested the turn downs -- the way his exhaust use to >> be. >> Right now things are so loud, I'd give up five knots for some relief. >> I'll try some insulation first. >> >> Thanks, >> >> - >> Larry Bowen >> Larry(at)BowenAero.com >> http://BowenAero.com >> >> Dennis & Lori Millsap said: >>> >>> >>> Dennis says that he's noticed that he should add more foam to the side >>> panels--more for noise than anything. He treated the firewall >>> primarily >>> for >>> heat (he thought) but it's the noise that gets ya. >>> >>> What do you mean by "turn downs"? Dennis cut his exhaust pipes off. >>> You >>> don't want them hanging down in the airstream. Let them be loud, but >>> for >>> goodness sake, don't let them slow ya down! GRIN! >>> >>> Actually, it puts undue stress on your exhaust system having them >>> hanging >>> out in the wind. Dennis broke a bracket or two before he cut them off. >>> >>> Lori >>> N464DM, RV-6A, 300+ hours >>> ----- Original Message ----- >>> From: "Larry Bowen" <Larry(at)bowenaero.com> >>> To: >>> Subject: RE: RVSouthEast-List: Flakes in fuel >>> >>> >>> >>>> >>>> I ordered this last night: >>>> >>>> http://www.aircraftspruce.com/catalog/appages/dampingpanels.php >>>> >>>> Does dampening the firewall give the most gain for the effort? Or do >>>> the >>>> sidewalls need to be done too? >>>> >>>> I'm thinking of getting some turn-downs for the exhaust pipes too... >>>> >>>> - >>>> Larry Bowen >>>> Larry(at)BowenAero.com >>>> http://BowenAero.com >>>> >>>> >>>>> -----Original Message----- >>>>> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >>>>> Sent: Wednesday, September 15, 2004 9:17 PM >>>>> To: rvsoutheast-list(at)matronics.com >>>>> Subject: Re: RVSouthEast-List: Flakes in fuel >>>>> >>>>> --> >>>>> >>>>> Mike and I used Koolmat Heat Barrier from Spruce around page 123. >>>>> >>>>> Used spray glue to hold it in place, no problems so far. >>>>> Just cut and paste! >>>>> >>>>> Sorry to hear of the latest problem, better to quit after >>>>> start than after takeoff. I promise after you have done your >>>>> time (40 hours) you will just fly it and put it to bed. I >>>>> know you can't wait. >>>>> >>>>> Steve >>>>> >>>>> ----- Original Message ----- >>>>> From: "Larry Bowen" <Larry(at)bowenaero.com> >>>>> To: >>>>> Subject: RE: RVSouthEast-List: Flakes in fuel >>>>> >>>>> >>>>>> >>>>>> >>>>>> Thanks. >>>>>> >>>>>> I'm down for now. I had to send the Rose ignition module >>>>> back. It quite >>>>>> Sunday shortly after start-up. Anyway, I'm taking the >>>>> opportunity to >>>>>> tweak >>>>>> some things and sound proof the firewall. Boy that thing >>>>> is loud!! Any >>>>>> tips for me related to sound-proofing? Anyone? Bueller? >>>>>> >>>>>> - >>>>>> Larry Bowen >>>>>> Larry(at)BowenAero.com >>>>>> http://BowenAero.com >>>>>> >>>>>> >>>>>>> -----Original Message----- >>>>>>> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >>>>>>> Sent: Wednesday, September 15, 2004 8:23 PM >>>>>>> To: rvsoutheast-list(at)matronics.com >>>>>>> Subject: Re: RVSouthEast-List: Flakes in fuel >>>>>>> >>>>>>> --> >>>>>>> >>>>>>> They are very small! A spec for sure! >>>>>>> >>>>>>> I even had them in OSH during preflight before I left. >>>>>>> >>>>>>> Again congrats on the event and many more to come. >>>>>>> >>>>>>> Steve >>>>>>> >>>>>>> >>>>>>> ----- Original Message ----- >>>>>>> From: "Larry Bowen" <Larry(at)bowenaero.com> >>>>>>> To: >>>>>>> Subject: RE: RVSouthEast-List: Flakes in fuel >>>>>>> >>>>>>> >>>>>>>> >>>>>>>> >>>>>>>> Like corn flakes sized flakes? Or specs? Proseal is >>>>>>> blakish, but doesn't >>>>>>>> break down from fuel. Maybe it's from the fuel truck or >>>>>>> inground tank. >>>>>>>> I'd >>>>>>>> monitor to try to establish a trend, if any...... >>>>>>>> >>>>>>>> - >>>>>>>> Larry Bowen >>>>>>>> Larry(at)BowenAero.com >>>>>>>> http://BowenAero.com >>>>>>>> >>>>>>>> >>>>>>>>> -----Original Message----- >>>>>>>>> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >>>>>>>>> Sent: Wednesday, September 15, 2004 4:46 PM >>>>>>>>> To: SERV >>>>>>>>> Subject: RVSouthEast-List: Flakes in fuel >>>>>>>>> >>>>>>>>> --> >>>>>>>>> >>>>>>>>> During preflight when the aircraft has set for some time, >>>>>>>>> when I drain fuel from under the wing I find some brown or >>>>>>>>> blackish flakes. It takes about 6 ounces of draining to >>>>>>>>> clear up the flakes. >>>>>>>>> >>>>>>>>> Has anyone experienced something similar? >>>>>>>>> >>>>>>>>> I have a OB 8. Could it be the tanks sealer is dissolving? >>>>>>>>> >>>>>>>>> Thanks, >>>>>>>>> >>>>>>>>> Steve Glasgow >>>>>>>>> >>>>>>>>> >>>>>>>>> ============ >>>>>>>>> Matronics Forums. >>>>>>>>> ============ >>>>>>>>> ============ >>>>>>>>> ============ >>>>>>>>> >>>>>>>>> >>>>>>>>> >>>>>>>>> >>>>>>>>> >>>>>>>>> >>>>>>>> >>>>>>>> >>>>>>>> >>>>>>> >>>>>>> >>>>>>> ============ >>>>>>> ============ >>>>>>> ============ >>>>>>> ============ >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>> >>>>>> >>>>>> >>>>> >>>>> >>>>> ============ >>>>> ============ >>>>> ============ >>>>> ============ >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>> >>>> >>> >>> >> >> >> _- >> ======================================================================= >> _- >> ======================================================================= >> _- >> ======================================================================= >> _- >> ======================================================================= >> > >> >> > > ________________________________________________________________________________
From: "James E. Clark" <james(at)nextupventures.com>
Subject: Noise (was Flakes in fuel)
Date: Sep 16, 2004
Larry, Someone once told me the cheapest noise insulation kit for an RV is a set of Bose (or insert your favorites) noise cancelling headsets. We have some noise deadening stuff in our RV6 but if you take the headsets off it is STILL loud! I have used both the Bose Series X (best feel to me) and the DRE 6000 (best value to me) . Both (and I am sure MANY others) are fine. James ________________________________________________________________________________
Date: Sep 16, 2004
Got 'em. I have the high-end Telex ANR's. It was loud with the ANR on; off, my ears started bleeding. Just kidding.... Thanks, - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com James E. Clark said: > > > Larry, > > Someone once told me the cheapest noise insulation kit for an RV is a set > of > Bose (or insert your favorites) noise cancelling headsets. > > We have some noise deadening stuff in our RV6 but if you take the headsets > off it is STILL loud! > > I have used both the Bose Series X (best feel to me) and the DRE 6000 > (best > value to me) . Both (and I am sure MANY others) are fine. > > > James > > ________________________________________________________________________________
Date: Sep 16, 2004
Subject: [Fwd: AOPA ePilot -- North Carolina Airspace Bulletin]
FYI ============ A special notice to AOPA members in the central North Carolina area ==> ATTENTION PILOTS <== AOPA is sending this message to advise pilots in and near Charlotte, North Carolina, that the FAA is expected to issue a notam restricting flight in the area during President Bush's planned visit on Friday, September 17. Based on information from the Bush campaign, the president will be in the area for an event at 3:45 p.m. local time. AOPA anticipates that the notam will establish a large temporary flight restriction (TFR) limiting general aviation flight. Typically, these presidential travel-related TFRs are 60 nautical miles in diameter (30-nm radius) and contain one or more smaller general aviation no-fly zones. AOPA will post the notam on AOPA Online ( http://www.aopa.org/whatsnew/notams.html ) as soon as possible after it is issued. A graphic will also be available. Because TFR airspace frequently changes, AOPA strongly encourages pilots to obtain a briefing and CHECK NOTAMS before every flight. TFR violators will be intercepted and forced to land. ==> HELPFUL WEB LINKS <== AOPA's Real-Time Flight Planner provides graphical depictions of TFRs ( http://www.aopa.org/flight_planner/ ). Check the FAA's TFR Web site ( http://tfr.faa.gov ). Download the AOPA Air Safety Foundation's intercept procedures card ( http://download.aopa.org/epilot/2003/intercept.pdf )or review ASF's "Know Before You Go" program ( http://www.aopa.org/asf/know_before/ ). ==> MAKE SURE YOU'RE PROTECTED <== SIGN UP FOR AOPA'S LEGAL SERVICES PLAN Because of the heavy call volume from members and the changing climate for FAA regulations and increased vigilance, we want to remind you to consider the AOPA Legal Services Plan protection. For more information or to start your coverage immediately, call 800/USA-AOPA or visit AOPA Online ( http://www.aopa.org/info/legalservices7/ ). ==> CONTACTING AOPA <== ********************************************************************* * If you have additional questions about TFRs or any other * * airspace or aviation matter, contact our AOPA Pilot Information * * Center at 800/USA-AOPA. You can also reach us via e-mail * * ( mailto:pilotassist(at)aopa.org ). * ********************************************************************* Having difficulty using this service? Contact ( mailto:epilot(at)aopa.org ). AOPA, 421 Aviation Way, Frederick, Maryland 21701. Telephone: 800/USA-AOPA or 301/695-2000 Copyright (c) 2004. Aircraft Owners and Pilots Association. ________________________________________________________________________________
Date: Sep 16, 2004
Subject: Re: Flakes in fuel
Larry: I am sorry to hear you have joined the ranks of electronic ignition owners who have had unexpected trouble. I know exactly what that's like :-( I sent my Rose module back on a one-way trip to Chattanooga a long time ago, about halfway through my test period, and have been happily flying along behind dual mags ever since. (It's all in the archives...) I burn more fuel, have less horsepower, and use expensive aviation plugs, but I sleep well at night and I don't anticipate getting stuck in the Bahamas with an ignition problem . I wish these things worked as claimed 100% of the time, as I'd happily be a customer. I would love to have all the pruported benefits with no reliability hassles, but after a faulty experience, I remain gun-shy about these ignitions. To paraphrase one father in ancient times, "Jeff, Klaus: I _want_ to believe. Help thou my unbelief!" Meanwhile the LASAR is the only one that turns my head even for a moment. Hope you get it all ironed out. At least you won't have to split the case to solve this one :-) I'm hunkered down waiting for the rain to hit, and for the UPS man to bring my blank instrument panel from Van's, so I can repair to the Bat Cave for top secret panel upgrades... -Stormy ________________________________________________________________________________
Date: Sep 16, 2004
Just as I suspected; your problem is Flakes in the cockpit! >>Right now things are so loud, I'd give up five knots for some relief. << What kind of statement is that?! This is about SPEED, Larry, not your ears. Grow a pair (of ear plugs) and flog that new rocket for all she's worth. To heck with the decibels; we've got knots!!!!! YEE-HAW! -Stormy (too much coffee this morning, I guess) ________________________________________________________________________________
Subject: Jeff Rose Ignition
Date: Sep 16, 2004
I recently heard the JR has stopped selling his systems but will continue to service those fielded. Larry, I too am sorry to hear about your electronic ignition problems. Like Stormy, I'm running2 mags and would love to install an electronic ignition system, but everytime I hear about a problem it makes me glad to have the basic "old" sysytem. Good Luck, Bob Martin ps..I use Lightspeed ANR's.....and yes it is LOUD if I take them off....actually deafening!! ________________________________________________________________________________
Subject: Flakes in fuel
Date: Sep 16, 2004
Larry: I did the firewall and floor. I came back and added the floor more for vibration, but it helped with noise, too. Wayne -----Original Message----- From: owner-rvsoutheast-list-server(at)matronics.com [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of Steve Glasgow Subject: Re: RVSouthEast-List: Flakes in fuel Larry I really don't know about the sides. Mine are not done and I don't seem to have a problem. Do you have the Viterman EX? I experimented with some down turns but never flew with them. Do you get exhaust stains on the belly and or oil. I'm told almost all RV get some. On mine I found I could minimize it by adjusting the exhaust stacks. You might check with Dan he even has some kind of muffler on his. Do you use a noise CNX headset. Mine works well to combat the noise. Steve ----- Original Message ----- From: "Larry Bowen" <Larry(at)bowenaero.com> Subject: RE: RVSouthEast-List: Flakes in fuel > > > I ordered this last night: > > http://www.aircraftspruce.com/catalog/appages/dampingpanels.php > > Does dampening the firewall give the most gain for the effort? Or do the > sidewalls need to be done too? > > I'm thinking of getting some turn-downs for the exhaust pipes too... > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > >> -----Original Message----- >> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >> Sent: Wednesday, September 15, 2004 9:17 PM >> To: rvsoutheast-list(at)matronics.com >> Subject: Re: RVSouthEast-List: Flakes in fuel >> >> --> >> >> Mike and I used Koolmat Heat Barrier from Spruce around page 123. >> >> Used spray glue to hold it in place, no problems so far. >> Just cut and paste! >> >> Sorry to hear of the latest problem, better to quit after >> start than after takeoff. I promise after you have done your >> time (40 hours) you will just fly it and put it to bed. I >> know you can't wait. >> >> Steve >> >> ----- Original Message ----- >> From: "Larry Bowen" <Larry(at)bowenaero.com> >> To: >> Subject: RE: RVSouthEast-List: Flakes in fuel >> >> >> > >> > >> > Thanks. >> > >> > I'm down for now. I had to send the Rose ignition module >> back. It quite >> > Sunday shortly after start-up. Anyway, I'm taking the >> opportunity to >> > tweak >> > some things and sound proof the firewall. Boy that thing >> is loud!! Any >> > tips for me related to sound-proofing? Anyone? Bueller? >> > >> > - >> > Larry Bowen >> > Larry(at)BowenAero.com >> > http://BowenAero.com >> > >> > >> >> -----Original Message----- >> >> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >> >> Sent: Wednesday, September 15, 2004 8:23 PM >> >> To: rvsoutheast-list(at)matronics.com >> >> Subject: Re: RVSouthEast-List: Flakes in fuel >> >> >> >> --> >> >> >> >> They are very small! A spec for sure! >> >> >> >> I even had them in OSH during preflight before I left. >> >> >> >> Again congrats on the event and many more to come. >> >> >> >> Steve >> >> >> >> >> >> ----- Original Message ----- >> >> From: "Larry Bowen" <Larry(at)bowenaero.com> >> >> To: >> >> Subject: RE: RVSouthEast-List: Flakes in fuel >> >> >> >> >> >> > >> >> > >> >> > Like corn flakes sized flakes? Or specs? Proseal is >> >> blakish, but doesn't >> >> > break down from fuel. Maybe it's from the fuel truck or >> >> inground tank. >> >> > I'd >> >> > monitor to try to establish a trend, if any...... >> >> > >> >> > - >> >> > Larry Bowen >> >> > Larry(at)BowenAero.com >> >> > http://BowenAero.com >> >> > >> >> > >> >> >> -----Original Message----- >> >> >> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >> >> >> Sent: Wednesday, September 15, 2004 4:46 PM >> >> >> To: SERV >> >> >> Subject: RVSouthEast-List: Flakes in fuel >> >> >> >> >> >> --> >> >> >> >> >> >> During preflight when the aircraft has set for some time, >> >> >> when I drain fuel from under the wing I find some brown or >> >> >> blackish flakes. It takes about 6 ounces of draining to >> >> >> clear up the flakes. >> >> >> >> >> >> Has anyone experienced something similar? >> >> >> >> >> >> I have a OB 8. Could it be the tanks sealer is dissolving? >> >> >> >> >> >> Thanks, >> >> >> >> >> >> Steve Glasgow >> >> >> >> >> >> >> >> >> ============ >> >> >> Matronics Forums. >> >> >> ============ >> >> >> ============ >> >> >> ============ >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > >> >> > >> >> > >> >> >> >> >> >> ============ >> >> ============ >> >> ============ >> >> ============ >> >> >> >> >> >> >> >> >> >> >> >> >> > >> > >> > >> >> >> ============ >> ============ >> ============ >> ============ >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Sep 16, 2004
In a message dated 9/15/2004 4:47:09 PM Eastern Standard Time, willfly(at)carolina.rr.com writes: > I have a OB 8. Could it be the tanks sealer is dissolving? > > Thanks, > > Steve Glasgow > Steve: Sounds like a little bit of proseal may be coming out ... you could easiely remove the tank drain completely and drain several gallons out ... or when you get the tanks down in fuel ... pull out the tank drain and let the last few gallons completely wash out the wing .. Len ________________________________________________________________________________
Date: Sep 16, 2004
Subject: Radomir - Virginia Fly In
Radomir: If by some miracle we get to go on Sunday ... we can talk by email on Saturday. You can also call me at home : 336-605-4762. I am on the west coast until Friday night. Len ________________________________________________________________________________
Subject: Re: Radomir - Virginia Fly In
Date: Sep 17, 2004
The web site for the Virginia Fly In shows canceled both days and no mention of a rain date. Steve Glasgow ----- Original Message ----- From: <Lenleg(at)aol.com> Subject: RVSouthEast-List: Radomir - Virginia Fly In > > Radomir: > > If by some miracle we get to go on Sunday ... we can talk by email on > Saturday. You can also call me at home : 336-605-4762. > > I am on the west coast until Friday night. > > Len > > > ________________________________________________________________________________
Date: Sep 17, 2004
Subject: Fwd: [RV-8] Carolina Sport Flyers Annual Fall Fly-in
In a message dated 9/17/2004 7:48:24 AM Eastern Standard Time, patches11us(at)yahoo.com writes: > :~) > Carolina Sport Flyers Annual fall fly-in > October 15th,16th &17th 2004 > Lee County Airport(52j)Bishopville,SC > http://www.airnav.com/airport/52j > > Food and drinks served all day on Sat 16th by a local church with all > proceeds going to the church to help with a rebuild. > > Any one that flies in will receive a attendance desk plaque > Young eagles rides on Sat 16th > Ultralight/Sport planes on display and flying > Intro flight lessons > Ultralight/ Sportplane dealers > > We will also be doing trophys and ribbons again this year on Sat 16th. > Farthest Distance Flown > Oldest 2 place > Oldest single place > Best in show > Best 2 place > Best single place > Crowd favorite > > Also we we be selling raffle tickets for some neat prizes. > Thanks to all who came last year and Hope to see you all here again > this year. Pass the word!!!! > > For more Info: > John Davis > patches11us@y... > From: "John W.Davis" <patches11us(at)yahoo.com> List-Unsubscribe: Date: Fri, 17 Sep 2004 11:18:23 -0000 Subject: [RV-8] Carolina Sport Flyers Annual Fall Fly-in :~) Carolina Sport Flyers Annual fall fly-in October 15th,16th & 17th 2004 Lee County Airport(52j)Bishopville,SC http://www.airnav.com/airport/52j Food and drinks served all day on Sat 16th by a local church with all proceeds going to the church to help with a rebuild. Any one that flies in will receive a attendance desk plaque Young eagles rides on Sat 16th Ultralight/Sport planes on display and flying Intro flight lessons Ultralight/ Sportplane dealers We will also be doing trophys and ribbons again this year on Sat 16th. Farthest Distance Flown Oldest 2 place Oldest single place Best in show Best 2 place Best single place Crowd favorite Also we we be selling raffle tickets for some neat prizes. Thanks to all who came last year and Hope to see you all here again this year. Pass the word!!!! For more Info: John Davis patches11us@y... --- End forwarded message --- Click Here! <*> To visit your group on the web, go to: http://groups.yahoo.com/group/RV-8/ <*> To unsubscribe from this group, send an email to: RV-8-unsubscribe(at)yahoogroups.com http://docs.yahoo.com/info/terms/ ________________________________________________________________________________
Subject: Re: Fwd: [RV-8] Carolina Sport Flyers Annual Fall Fly-in
Date: Sep 17, 2004
This could be fun! Steve Glasgow ----- Original Message ----- From: <Lenleg(at)aol.com> Subject: RVSouthEast-List: Fwd: [RV-8] Carolina Sport Flyers Annual Fall Fly-in > > In a message dated 9/17/2004 7:48:24 AM Eastern Standard Time, > patches11us(at)yahoo.com writes: > >> :~) >> Carolina Sport Flyers Annual fall fly-in >> October 15th,16th &17th 2004 >> Lee County Airport(52j)Bishopville,SC >> http://www.airnav.com/airport/52j >> >> Food and drinks served all day on Sat 16th by a local church with all >> proceeds going to the church to help with a rebuild. >> >> Any one that flies in will receive a attendance desk plaque >> Young eagles rides on Sat 16th >> Ultralight/Sport planes on display and flying >> Intro flight lessons >> Ultralight/ Sportplane dealers >> >> We will also be doing trophys and ribbons again this year on Sat 16th. >> Farthest Distance Flown >> Oldest 2 place >> Oldest single place >> Best in show >> Best 2 place >> Best single place >> Crowd favorite >> >> Also we we be selling raffle tickets for some neat prizes. >> Thanks to all who came last year and Hope to see you all here again >> this year. Pass the word!!!! >> >> For more Info: >> John Davis >> patches11us@y... >> > > > To: RV-8(at)yahoogroups.com > From: "John W.Davis" <patches11us(at)yahoo.com> > List-Unsubscribe: > Date: Fri, 17 Sep 2004 11:18:23 -0000 > Subject: [RV-8] Carolina Sport Flyers Annual Fall Fly-in > > > :~) > Carolina Sport Flyers Annual fall fly-in > October 15th,16th & 17th 2004 > Lee County Airport(52j)Bishopville,SC > http://www.airnav.com/airport/52j > > Food and drinks served all day on Sat 16th by a local church with all > proceeds going to the church to help with a rebuild. > > Any one that flies in will receive a attendance desk plaque > Young eagles rides on Sat 16th > Ultralight/Sport planes on display and flying > Intro flight lessons > Ultralight/ Sportplane dealers > > We will also be doing trophys and ribbons again this year on Sat 16th. > Farthest Distance Flown > Oldest 2 place > Oldest single place > Best in show > Best 2 place > Best single place > Crowd favorite > > Also we we be selling raffle tickets for some neat prizes. > Thanks to all who came last year and Hope to see you all here again > this year. Pass the word!!!! > > For more Info: > John Davis > patches11us@y... > --- End forwarded message --- > > > Click Here! > > > <*> To visit your group on the web, go to: > http://groups.yahoo.com/group/RV-8/ > > <*> To unsubscribe from this group, send an email to: > RV-8-unsubscribe(at)yahoogroups.com > > http://docs.yahoo.com/info/terms/ > > > ________________________________________________________________________________
Date: Sep 17, 2004
Subject: Weather
Guys: I have been in the Northwest all week .... all I have seen is rain ... every single day .. now I am heading back home to NC and it is going to rain for a week .... Can someone tell me what a blue sky looks like !!! Len Leggette, RV-8A Greensboro, NC N910LL 275 hrs ________________________________________________________________________________
Date: Sep 17, 2004
Steve I notices your address is carolina. I bought the 3/4in mat for the firewall and plan to use it. After paying $60 for 6 feet I found a place in Huntersville that sells 3/8 mat for $7. The name is Muscle Motorsports. They are a NASCAR outlet. Yes it is the same material. Tad 7A "Steve Glasgow" wrote: > >Koolmat has a fireproof rubbery like material on one side the side toward >the back of the airplane and fiberglass impregnated on the side toward the >firewall. It is much more substantive and stops almost all the oil canning >of the firewall. > >I have a piece for you, where do I send it. I will get it in today's mail >if you send me an address ASAP. > >Steve > >----- Original Message ----- >From: "Larry Bowen" <Larry(at)bowenaero.com> >To: >Subject: Re: RVSouthEast-List: Noise (was Flakes in fuel) > > >> >> >> How is the coolmat different? Do you have a piece of scrap left I could >> see? >> >> - >> Larry Bowen >> Larry(at)BowenAero.com >> http://BowenAero.com >> >> Steve Glasgow said: >>> >>> >>> Larry, I'm not happy with your choice of insulation. I got some of the >>> one >>> you are getting and some of the Koolmat before I decided. If I not >>> mistaken >>> the Koolmat is far superior. >>> >>> Just my thought. >>> >>> Steve >>> >>> >>> ----- Original Message ----- >>> From: "Larry Bowen" <Larry(at)bowenaero.com> >>> To: >>> Subject: Re: RVSouthEast-List: Noise (was Flakes in fuel) >>> >>> >>>> >>>> >>>> Larry Vetterman suggested the turn downs -- the way his exhaust use to >>>> be. >>>> Right now things are so loud, I'd give up five knots for some relief. >>>> I'll try some insulation first. >>>> >>>> Thanks, >>>> >>>> - >>>> Larry Bowen >>>> Larry(at)BowenAero.com >>>> http://BowenAero.com >>>> >>>> Dennis & Lori Millsap said: >>>>> >>>>> >>>>> Dennis says that he's noticed that he should add more foam to the side >>>>> panels--more for noise than anything. He treated the firewall primarily >>>>> for >>>>> heat (he thought) but it's the noise that gets ya. >>>>> >>>>> What do you mean by "turn downs"? Dennis cut his exhaust pipes off. You >>>>> don't want them hanging down in the airstream. Let them be loud, but >>>>> for >>>>> goodness sake, don't let them slow ya down! GRIN! >>>>> >>>>> Actually, it puts undue stress on your exhaust system having them >>>>> hanging >>>>> out in the wind. Dennis broke a bracket or two before he cut them off. >>>>> >>>>> Lori >>>>> N464DM, RV-6A, 300+ hours >>>>> ----- Original Message ----- >>>>> From: "Larry Bowen" <Larry(at)bowenaero.com> >>>>> To: >>>>> Subject: RE: RVSouthEast-List: Flakes in fuel >>>>> >>>>> >>>>> >>>>>> >>>>>> I ordered this last night: >>>>>> >>>>>> http://www.aircraftspruce.com/catalog/appages/dampingpanels.php >>>>>> >>>>>> Does dampening the firewall give the most gain for the effort? Or do >>>>>> the >>>>>> sidewalls need to be done too? >>>>>> >>>>>> I'm thinking of getting some turn-downs for the exhaust pipes too... >>>>>> >>>>>> - >>>>>> Larry Bowen >>>>>> Larry(at)BowenAero.com >>>>>> http://BowenAero.com >>>>>> >>>>>> >>>>>> > -----Original Message----- >>>>>> > From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >>>>>> > Sent: Wednesday, September 15, 2004 9:17 PM >>>>>> > To: rvsoutheast-list(at)matronics.com >>>>>> > Subject: Re: RVSouthEast-List: Flakes in fuel >>>>>> > >>>>>> > --> >>>>>> > >>>>>> > Mike and I used Koolmat Heat Barrier from Spruce around page 123. >>>>>> > >>>>>> > Used spray glue to hold it in place, no problems so far. >>>>>> > Just cut and paste! >>>>>> > >>>>>> > Sorry to hear of the latest problem, better to quit after >>>>>> > start than after takeoff. I promise after you have done your >>>>>> > time (40 hours) you will just fly it and put it to bed. I >>>>>> > know you can't wait. >>>>>> > >>>>>> > Steve >>>>>> > >>>>>> > ----- Original Message ----- >>>>>> > From: "Larry Bowen" <Larry(at)bowenaero.com> >>>>>> > To: >>>>>> > Subject: RE: RVSouthEast-List: Flakes in fuel >>>>>> > >>>>>> > >>>>>> > > >>>>>> > > >>>>>> > > Thanks. >>>>>> > > >>>>>> > > I'm down for now. I had to send the Rose ignition module >>>>>> > back. It quite >>>>>> > > Sunday shortly after start-up. Anyway, I'm taking the >>>>>> > opportunity to >>>>>> > > tweak >>>>>> > > some things and sound proof the firewall. Boy that thing >>>>>> > is loud!! Any >>>>>> > > tips for me related to sound-proofing? Anyone? Bueller? >>>>>> > > >>>>>> > > - >>>>>> > > Larry Bowen >>>>>> > > Larry(at)BowenAero.com >>>>>> > > http://BowenAero.com >>>>>> > > >>>>>> > > >>>>>> > >> -----Original Message----- >>>>>> > >> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >>>>>> > >> Sent: Wednesday, September 15, 2004 8:23 PM >>>>>> > >> To: rvsoutheast-list(at)matronics.com >>>>>> > >> Subject: Re: RVSouthEast-List: Flakes in fuel >>>>>> > >> >>>>>> > >> --> >>>>>> > >> >>>>>> > >> They are very small! A spec for sure! >>>>>> > >> >>>>>> > >> I even had them in OSH during preflight before I left. >>>>>> > >> >>>>>> > >> Again congrats on the event and many more to come. >>>>>> > >> >>>>>> > >> Steve >>>>>> > >> >>>>>> > >> >>>>>> > >> ----- Original Message ----- >>>>>> > >> From: "Larry Bowen" <Larry(at)bowenaero.com> >>>>>> > >> To: >>>>>> > >> Subject: RE: RVSouthEast-List: Flakes in fuel >>>>>> > >> >>>>>> > >> >>>>>> > >> > >>>>>> > >> > >>>>>> > >> > Like corn flakes sized flakes? Or specs? Proseal is >>>>>> > >> blakish, but doesn't >>>>>> > >> > break down from fuel. Maybe it's from the fuel truck or >>>>>> > >> inground tank. >>>>>> > >> > I'd >>>>>> > >> > monitor to try to establish a trend, if any...... >>>>>> > >> > >>>>>> > >> > - >>>>>> > >> > Larry Bowen >>>>>> > >> > Larry(at)BowenAero.com >>>>>> > >> > http://BowenAero.com >>>>>> > >> > >>>>>> > >> > >>>>>> > >> >> -----Original Message----- >>>>>> > >> >> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >>>>>> > >> >> Sent: Wednesday, September 15, 2004 4:46 PM >>>>>> > >> >> To: SERV >>>>>> > >> >> Subject: RVSouthEast-List: Flakes in fuel >>>>>> > >> >> >>>>>> > >> >> --> >>>>>> > >> >> >>>>>> > >> >> During preflight when the aircraft has set for some time, >>>>>> > >> >> when I drain fuel from under the wing I find some brown or >>>>>> > >> >> blackish flakes. It takes about 6 ounces of draining to >>>>>> > >> >> clear up the flakes. >>>>>> > >> >> >>>>>> > >> >> Has anyone experienced something similar? >>>>>> > >> >> >>>>>> > >> >> I have a OB 8. Could it be the tanks sealer is dissolving? >>>>>> > >> >> >>>>>> > >> >> Thanks, >>>>>> > >> >> >>>>>> > >> >> Steve Glasgow >>>>>> > >> >> >>>>>> > >> >> >>>>>> > >> >> ============ >>>>>> > >> >> Matronics Forums. >>>>>> > >> >> ============ >>>>>> > >> >> ============ >>>>>> > >> >> ============ >>>>>> > >> >> >>>>>> > >> >> >>>>>> > >> >> >>>>>> > >> >> >>>>>> > >> >> >>>>>> > >> >> >>>>>> > >> > >>>>>> > >> > >>>>>> > >> > >>>>>> > >> >>>>>> > >> >>>>>> > >> ============ >>>>>> > >> ============ >>>>>> > >> ============ >>>>>> > >> ============ >>>>>> > >> >>>>>> > >> >>>>>> > >> >>>>>> > >> >>>>>> > >> >>>>>> > >> >>>>>> > > >>>>>> > > >>>>>> > > >>>>>> > >>>>>> > >>>>>> > ============ >>>>>> > ============ >>>>>> > ============ >>>>>> > ============ >>>>>> > >>>>>> > >>>>>> > >>>>>> > >>>>>> > >>>>>> > >>>>>> >>>>>> >>>>> >>>>> >>>> >>>> >>>> >>> >>> >> >> >> > > ________________________________________________________________________________
Subject: Re: Weather
Date: Sep 17, 2004
Blue sky would look like an illusion. Steve ----- Original Message ----- From: <Lenleg(at)aol.com> Subject: RVSouthEast-List: Weather > > Guys: > > I have been in the Northwest all week .... all I have seen is rain ... > every > single day .. > now I am heading back home to NC and it is going to rain for a week .... > > Can someone tell me what a blue sky looks like !!! > > Len Leggette, RV-8A > Greensboro, NC N910LL > 275 hrs > > > ________________________________________________________________________________
Date: Sep 20, 2004
Subject: Shirts and Caps Mailed !!
SERV: I mailed shirts and caps today !!! Hope everyone is happy with the end product !!! Thanks again Wayne8 for your efforts in making this happen !! Len ________________________________________________________________________________
Subject: Re: Shirts and Caps Mailed !!
Date: Sep 20, 2004
Thanks to both Wayne 8 and Len for all your efforts. I know I will be satisfied. Steve Glasgow ----- Original Message ----- From: <Lenleg(at)aol.com> Subject: RVSouthEast-List: Shirts and Caps Mailed !! > > SERV: > > I mailed shirts and caps today !!! Hope everyone is happy with the end > product !!! > > Thanks again Wayne8 for your efforts in making this happen !! > > Len > > > ________________________________________________________________________________
Date: Sep 20, 2004
In a message dated 9/20/04 2:02:27 PM Eastern Daylight Time, willfly(at)carolina.rr.com writes: Thanks to both Wayne 8 and Len for all your efforts. I know I will be satisfied. Steve Glasgow Don't say that so fast ... your order was screwed up !!! For some reason the company did not make your black shirt. Wayne8 is getting it done !! Len ________________________________________________________________________________
Date: Sep 20, 2004
Hey I'm in no hurry. Steve ----- Original Message ----- From: <Lenleg(at)aol.com> Subject: Re: RVSouthEast-List: Shirts and Caps Mailed !! > > > In a message dated 9/20/04 2:02:27 PM Eastern Daylight Time, > willfly(at)carolina.rr.com writes: > > Thanks to both Wayne 8 and Len for all your efforts. > I know I will be satisfied. > > Steve Glasgow > > > Don't say that so fast ... your order was screwed up !!! For some reason > the company did not make your black shirt. Wayne8 is getting it done !! > > Len > > > ________________________________________________________________________________
Date: Sep 21, 2004
Subject: Re: RV6A under contract for sale
In a message dated 9/20/04 9:58:10 PM Eastern Daylight Time, eregensburg(at)triad.rr.com writes: Well Len It finally had to happen - I just agreed to sell my 6A . $ 69 K and its going to Yankeeville - north Sadly Ed Ed: I agree it is sad but glad we had the opportunity to meet and fly together ... great thing about RVs !!! Please continue to try to be a part of SERV ... you never know what kind of plane is in your future !!! (and we will even welcome your Cessna !!) Len ________________________________________________________________________________
Date: Sep 21, 2004
Subject: Sunday at Stantons?????
Guys: Looks like the weather is going to be nice on Sunday .... lets try to get together for some flying .... could even include Larry Bowen in his new 8 !!! A few ideas: 1. Stantons for BBQ 2. Greenville/Farmville area to meet our new NC resident (and ECU employee)... Dennis M. 3. Air Harbor ... to see Wayne8's new place 4. Lauringburg ... visit the grass strip and see antique/movie planes and tractors 5. Myrtle Beach for seafood We must take advantage of this wonderful weather !!! Len ________________________________________________________________________________
Date: Sep 21, 2004
Subject: James - Columbia
Formaiton practice on Sunday afternoon ???????????? Len ________________________________________________________________________________
Date: Sep 21, 2004
Yes, I am interested. Paul D. Franzon Alumni Distinguished Professor of ECE 443 EGRC paulf(at)ncsu.edu 919.515.7351 fax. 919.515.2285 www.ece.ncsu.edu/erl/faculty/paulf.html USPS : ECE Box 7914, NCSU, Raleigh NC 27695 FedEx: EGRC 419, 2410 Campus Shore Dr., Raleigh NC 27606 -----Original Message----- From: owner-rvsoutheast-list-server(at)matronics.com [mailto:owner-rvsoutheast-list-server(at)matronics.com] On Behalf Of Lenleg(at)aol.com Subject: RVSouthEast-List: James - Columbia Formaiton practice on Sunday afternoon ???????????? Len ________________________________________________________________________________
Date: Sep 21, 2004
Subject: Re: Sunday at Stantons?????
I hope to have the EI back on the plane and be back in the air by this weekend, but with all of 1.9 hours on it and only 5 landings -- there is no way I am ready to "leave the nest" yet. And at five hours am back down again to change the oil. Anyway, at least am flying!!!! I'll be joining you guys in the near future, but not yet.... - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Lenleg(at)aol.com said: > > Guys: > > Looks like the weather is going to be nice on Sunday .... lets try to get > together for some flying .... could even include Larry Bowen in his new 8 > !!! > > A few ideas: > > 1. Stantons for BBQ > > 2. Greenville/Farmville area to meet our new NC resident (and ECU > employee)... Dennis M. > > 3. Air Harbor ... to see Wayne8's new place > > 4. Lauringburg ... visit the grass strip and see antique/movie planes > and > tractors > > 5. Myrtle Beach for seafood > > We must take advantage of this wonderful weather !!! > > Len > > ________________________________________________________________________________
Date: Sep 21, 2004
From: "Linzel Gray Civ 43 CES/CECP" <Gray.Linzel(at)pope.af.mil>
After I did a top overhaul the shop said to run straight mineral oil and fly at no less than 75% power (full throttle at 8000 ft) for the first 25 hours or until oil consumption stabilized in order to seat the rings. I changed oil earlier as engine didn't seem to burn much oil. Is 5 hours for the first oil change now the deal for a new engine? It makes sense, just curious. Gray -----Original Message----- From: Larry Bowen [mailto:Larry(at)bowenaero.com] Subject: Re: RVSouthEast-List: Sunday at Stantons????? I hope to have the EI back on the plane and be back in the air by this weekend, but with all of 1.9 hours on it and only 5 landings -- there is no way I am ready to "leave the nest" yet. And at five hours am back down again to change the oil. Anyway, at least am flying!!!! I'll be joining you guys in the near future, but not yet.... - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Lenleg(at)aol.com said: > > Guys: > > Looks like the weather is going to be nice on Sunday .... lets try to get > together for some flying .... could even include Larry Bowen in his new 8 > !!! > > A few ideas: > > 1. Stantons for BBQ > > 2. Greenville/Farmville area to meet our new NC resident (and ECU > employee)... Dennis M. > > 3. Air Harbor ... to see Wayne8's new place > > 4. Lauringburg ... visit the grass strip and see antique/movie planes > and > tractors > > 5. Myrtle Beach for seafood > > We must take advantage of this wonderful weather !!! > > Len > > == == == == ________________________________________________________________________________
Date: Sep 21, 2004
In a message dated 9/21/04 11:58:48 AM Eastern Daylight Time, Gray.Linzel(at)pope.af.mil writes: After I did a top overhaul the shop said to run straight mineral oil and fly at no less than 75% power (full throttle at 8000 ft) for the first 25 hours or until oil consumption stabilized in order to seat the rings. I changed oil earlier as engine didn't seem to burn much oil. Is 5 hours for the first oil change now the deal for a new engine? It makes sense, just curious. Gray That is what Bob Barrows told us to do with his engines. Len ________________________________________________________________________________
Date: Sep 21, 2004
Subject: Re: James - Columbia
how 'bout lunch at wadesboro and lite formation after burgers. bill c. --- Lenleg(at)aol.com wrote: > Lenleg(at)aol.com > > Formaiton practice on Sunday afternoon ???????????? > > Len > > > > - > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RVSouthEast-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ ________________________________________________________________________________
Date: Sep 21, 2004
In a message dated 9/21/04 12:20:49 PM Eastern Daylight Time, bill28104(at)yahoo.com writes: how 'bout lunch at wadesboro and lite formation after burgers. bill c. Hey ... I like it .... what do you guys think ?? Len ________________________________________________________________________________
Date: Sep 21, 2004
I'm out! Wish I didn't have to work. Steve ----- Original Message ----- From: <Lenleg(at)aol.com> Subject: RVSouthEast-List: Fwd: [RV-8] Carolina Sport Flyers Annual Fall Fly-in > > In a message dated 9/17/2004 7:48:24 AM Eastern Standard Time, > patches11us(at)yahoo.com writes: > >> :~) >> Carolina Sport Flyers Annual fall fly-in >> October 15th,16th &17th 2004 >> Lee County Airport(52j)Bishopville,SC >> http://www.airnav.com/airport/52j >> >> Food and drinks served all day on Sat 16th by a local church with all >> proceeds going to the church to help with a rebuild. >> >> Any one that flies in will receive a attendance desk plaque >> Young eagles rides on Sat 16th >> Ultralight/Sport planes on display and flying >> Intro flight lessons >> Ultralight/ Sportplane dealers >> >> We will also be doing trophys and ribbons again this year on Sat 16th. >> Farthest Distance Flown >> Oldest 2 place >> Oldest single place >> Best in show >> Best 2 place >> Best single place >> Crowd favorite >> >> Also we we be selling raffle tickets for some neat prizes. >> Thanks to all who came last year and Hope to see you all here again >> this year. Pass the word!!!! >> >> For more Info: >> John Davis >> patches11us@y... >> > > > To: RV-8(at)yahoogroups.com > From: "John W.Davis" <patches11us(at)yahoo.com> > List-Unsubscribe: > Date: Fri, 17 Sep 2004 11:18:23 -0000 > Subject: [RV-8] Carolina Sport Flyers Annual Fall Fly-in > > > :~) > Carolina Sport Flyers Annual fall fly-in > October 15th,16th & 17th 2004 > Lee County Airport(52j)Bishopville,SC > http://www.airnav.com/airport/52j > > Food and drinks served all day on Sat 16th by a local church with all > proceeds going to the church to help with a rebuild. > > Any one that flies in will receive a attendance desk plaque > Young eagles rides on Sat 16th > Ultralight/Sport planes on display and flying > Intro flight lessons > Ultralight/ Sportplane dealers > > We will also be doing trophys and ribbons again this year on Sat 16th. > Farthest Distance Flown > Oldest 2 place > Oldest single place > Best in show > Best 2 place > Best single place > Crowd favorite > > Also we we be selling raffle tickets for some neat prizes. > Thanks to all who came last year and Hope to see you all here again > this year. Pass the word!!!! > > For more Info: > John Davis > patches11us@y... > --- End forwarded message --- > > > Click Here! > > > <*> To visit your group on the web, go to: > http://groups.yahoo.com/group/RV-8/ > > <*> To unsubscribe from this group, send an email to: > RV-8-unsubscribe(at)yahoogroups.com > > http://docs.yahoo.com/info/terms/ > > > ________________________________________________________________________________
Date: Sep 21, 2004
Hmmm. We have our annual Chapter Meeting on Sunday. MUST attend. (About 1 PM until about 4 PM) Any consideration for Saturday? James (of *course* I would be tied up when the weather gets great! :-( ) > -----Original Message----- > From: owner-rvsoutheast-list-server(at)matronics.com > [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of > Lenleg(at)aol.com > Sent: Tuesday, September 21, 2004 9:29 AM > To: rvsoutheast-list(at)matronics.com > Subject: RVSouthEast-List: James - Columbia > > > Formaiton practice on Sunday afternoon ???????????? > > Len > > ________________________________________________________________________________
Subject: Wow!!!
Date: Sep 21, 2004
Hey Guys the Shirt and Cap came today. Really nice. Awesome!! Thanks again Len and Wayne8 Steve Glasgow ________________________________________________________________________________
Date: Sep 21, 2004
Sounds good on Sunday. Also, there's a pig pickin at Thomasville (Hiatt Field) N97 from 11am-2pm Saturday. Does anyone know anything about this? Mike Barbee ________________________________________________________________________________
Date: Sep 21, 2004
Subject: Re: Wow!!!
DITTO, Bill C. --- Steve Glasgow wrote: > Glasgow" > > Hey Guys the Shirt and Cap came today. Really nice. > Awesome!! > > Thanks again Len and Wayne8 > > Steve Glasgow > > > > - > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RVSouthEast-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ ________________________________________________________________________________
Date: Sep 21, 2004
Subject: Re: Wow!!!
Yes, thanks Mike B ________________________________________________________________________________
Date: Sep 22, 2004
In a message dated 9/21/04 4:53:41 PM Eastern Daylight Time, james(at)nextupventures.com writes: Hmmm. We have our annual Chapter Meeting on Sunday. MUST attend. (About 1 PM until about 4 PM) Any consideration for Saturday? James (of *course* I would be tied up when the weather gets great! :-( ) I will be leaving for the ECU football game around noon on Saturday ... so I better not plan for Saturday .... I will be flying early Sat morn !!!! Len ________________________________________________________________________________
Subject: Hickory Airports
Date: Sep 22, 2004
Hi Guys, I just got a call from an old friend Tim Berry, who was one of the original members of the Mid-Atlantic RV Wing formation team. Tim is looking to move to the Hickory, NC area and would like some help identifying airports that would welcome him and his RV8. Since Im located in the far east (Elizabeth City) I wont be of much help to Tim and his quest for a good airport. So I hope the rest of you can email or call Tim and pass along some information and suggestions as to where to look and what to look out for. Tims phone #270 924 3674 Email: Ifly2retire(at)earthlink.net Thanks Curtis Hinkley N815RV ________________________________________________________________________________
Date: Sep 22, 2004
Subject: Re: Hickory Airports
In a message dated 9/22/04 10:14:55 AM Eastern Daylight Time, N815RV(at)adelphia.net writes: I just got a call from an old friend Tim Berry, who was one of the original members of the Mid-Atlantic RV Wing formation team. Tim is looking to move to the Hickory, NC area and would like some help identifying airports that would welcome him and his RV8. Since Im located in the far east (Elizabeth City) I wont be of much help to Tim and his quest for a good airport. So I hope the rest of you can email or call Tim and pass along some information and suggestions as to where to look and what to look out for. Tims phone #270 924 3674 Email: Ifly2retire(at)earthlink.net Thanks Curtis Hinkley N815RV Curtis & Tim: Good to hear from you !!! Didn't know what you were up to these days !! My partners are from Hickory ... I get up there very often ... only about 1 1/2 hours by car and a short RV flight from Winston-Salem. The Hickory airport is quite nice ... lots of GA activity .. lost all their airline service. Don't know the situation about hangers. I don't remember anyone in SERV from Hickory but you could check the Vans list. Tim ... welcome to NC ... the majority of the activity so far in SERV is closer to the Greensboro, Winston-Salem, Charlotte, Raleight area. We look forward to you joining us. Please go to _serv(at)bowenaero.com_ (mailto:serv(at)bowenaero.com) and sign up !! Let me know when you get to town and we will keep you informed of the SERV activities !! Len Leggette, RV-8A Greensboro, N.C. N910LL 273 hrs ________________________________________________________________________________
Date: Sep 22, 2004
Len, My old fllying club in FAY is having thier ann cookout at Grays Creek Airport in Fayetteville on Sunday afternoon. (2GC) The SERV is invited and I am planning to go and would like for a bunch of us to go together if possible. Whould this be something that you would be interested in doing? I plan to leave after church. W8. ________________________________________________________________________________
Date: Sep 22, 2004
Tim , you might look into lower creek in lenoir hky is now charging apron fees of up to 50 dollars you might need to look into it before hand. Ben rv6 ________________________________________________________________________________
Date: Sep 22, 2004
In a message dated 9/22/04 1:34:00 PM Eastern Daylight Time, N184FN(at)aol.com writes: Len, My old fllying club in FAY is having thier ann cookout at Grays Creek Airport in Fayetteville on Sunday afternoon. (2GC) The SERV is invited and I am planning to go and would like for a bunch of us to go together if possible. Whould this be something that you would be interested in doing? I plan to leave after church. W8. Guys ... exactly the type thing we are looking for ... We have several options now: 1. Fayetteville with Wayne8 2. Wadesboro for burgers My vote is for Fayetteville and support Wayne8 with lots of RVs !!! Len ________________________________________________________________________________
Date: Sep 22, 2004
In a message dated 9/22/04 2:23:42 PM Eastern Daylight Time, SnakedoctorRV6(at)aol.com writes: Tim , you might look into lower creek in lenoir hky is now charging apron fees of up to 50 dollars you might need to look into it before hand. Ben rv6 Ben: I learn to fly from Lower Creek in Lenoir !! What is an apron fee? Len ________________________________________________________________________________
Date: Sep 22, 2004
Hey for you guys in NC the Farmville EAA chapter 960 has their annual fly-in this Saturday the 25th also Dennis M. plane is based there RV 6A, hope to see you there. ----- Original Message ----- From: <Lenleg(at)aol.com> Subject: RVSouthEast-List: Sunday at Stantons????? > > Guys: > > Looks like the weather is going to be nice on Sunday .... lets try to get > together for some flying .... could even include Larry Bowen in his new 8 !!! > > A few ideas: > > 1. Stantons for BBQ > > 2. Greenville/Farmville area to meet our new NC resident (and ECU > employee)... Dennis M. > > 3. Air Harbor ... to see Wayne8's new place > > 4. Lauringburg ... visit the grass strip and see antique/movie planes and > tractors > > 5. Myrtle Beach for seafood > > We must take advantage of this wonderful weather !!! > > Len > > ________________________________________________________________________________
Date: Sep 22, 2004
Is that Farmville NC or Va ________________________________________________________________________________
Date: Sep 22, 2004
In a message dated 9/22/04 4:36:22 PM Eastern Daylight Time, N184FN(at)aol.com writes: Is that Farmville NC or Va North Carolina .... Dennis Millsap moved up to head up the ROTC program at ECU ... hope I am telling all this correct ... I know his wife Lori monitors the site .... so she can chime in !! Len ________________________________________________________________________________
Date: Sep 22, 2004
It is Farmville NC , N08 is the airport ID. ----- Original Message ----- From: <N184FN(at)aol.com> Subject: Re: RVSouthEast-List: Sunday at Stantons????? > > Is that Farmville NC or Va > > ________________________________________________________________________________
Date: Sep 22, 2004
You are correct. ----- Original Message ----- From: <Lenleg(at)aol.com> Subject: Re: RVSouthEast-List: Sunday at Stantons????? > > > In a message dated 9/22/04 4:36:22 PM Eastern Daylight Time, N184FN(at)aol.com > writes: > > Is that Farmville NC or Va > > > North Carolina .... > > Dennis Millsap moved up to head up the ROTC program at ECU ... hope I am > telling all this correct ... I know his wife Lori monitors the site .... so she > can chime in !! > > Len > > ________________________________________________________________________________
Date: Sep 22, 2004
Let me throw my two cents worth in here.... This picnic that Wayne8 is talking about is put on by the Cape Fear Aero Association, and is one of our most fun events of the year. It is very informal, just come as you are and be prepared for good hamburgers and hotdogs. Just leave a little money in the kitty for next year. We give rides to any kids that want to go up, and then just go up and play as much as we can stand it. Len, this is a great excuse to show up as a group formation and show these guys what a real arrival looks like. You guys come on down. The location is Grays Creek, 2GC, about six miles due south of Fayetteville airport, FAY. Hope to see everybody there. If there is a group, we can gather up over Eastover Air Ranch and go to 2GC from there. What do you guys think? David Davenport RV-6 ----- Original Message ----- From: <Lenleg(at)aol.com> Subject: Re: RVSouthEast-List: James - Columbia > > > In a message dated 9/22/04 1:34:00 PM Eastern Daylight Time, N184FN(at)aol.com > writes: > > Len, My old fllying club in FAY is having thier ann cookout at Grays Creek > Airport in Fayetteville on Sunday afternoon. (2GC) The SERV is invited and > I > am planning to go and would like for a bunch of us to go together if > possible. > Whould this be something that you would be interested in doing? I plan to > leave after church. W8. > > > Guys ... exactly the type thing we are looking for ... > > We have several options now: > > 1. Fayetteville with Wayne8 > > 2. Wadesboro for burgers > > My vote is for Fayetteville and support Wayne8 with lots of RVs !!! > > Len > > ________________________________________________________________________________
Date: Sep 22, 2004
That's what I've been told to do by my engine guy. My advice would be to follow whatever your engine dude tells you. If nothing else, when things break, you can at least be able to say you were following his directions, and thus, perhaps, get better support making things right. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Linzel Gray Civ 43 CES/CECP said: > After I did a top overhaul the shop said to run straight mineral oil and fly at no less than 75% power (full throttle at 8000 ft) for the first 25 hours or until oil consumption stabilized in order to seat the rings. I changed oil earlier as engine didn't seem to burn much oil. Is 5 hours for the first oil change now the deal for a new engine? It makes sense, just curious. > Gray > -----Original Message----- > From: Larry Bowen [mailto:Larry(at)bowenaero.com] > To: rvsoutheast-list(at)matronics.com > Subject: Re: RVSouthEast-List: Sunday at Stantons????? > > I hope to have the EI back on the plane and be back in the air by this weekend, but with all of 1.9 hours on it and only 5 landings -- there is no way I am ready to "leave the nest" yet. > And at five hours am back down again to change the oil. Anyway, at least > am flying!!!! I'll be joining you guys in the near future, but not yet.... > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > Lenleg(at)aol.com said: >> Guys: >> Looks like the weather is going to be nice on Sunday .... lets try to > get >> together for some flying .... could even include Larry Bowen in his > new 8 >> !!! >> A few ideas: >> 1. Stantons for BBQ >> 2. Greenville/Farmville area to meet our new NC resident (and ECU employee)... Dennis M. >> 3. Air Harbor ... to see Wayne8's new place >> 4. Lauringburg ... visit the grass strip and see antique/movie planes and >> tractors >> 5. Myrtle Beach for seafood >> We must take advantage of this wonderful weather !!! >> Len > == > == > == > == ________________________________________________________________________________
Date: Sep 22, 2004
I'm in for sunday at greys creek...also sat. is fly-in/airshow/pancake breakfast at Wison, nc all day. bill c. --- DAVID DAVENPORT wrote: > DAVENPORT" > > Let me throw my two cents worth in here.... This > picnic that Wayne8 is > talking about is put on by the Cape Fear Aero > Association, and is one of our > most fun events of the year. It is very informal, > just come as you are and > be prepared for good hamburgers and hotdogs. Just > leave a little money in > the kitty for next year. We give rides to any kids > that want to go up, and > then just go up and play as much as we can stand it. > Len, this is a great > excuse to show up as a group formation and show > these guys what a real > arrival looks like. You guys come on down. The > location is Grays Creek, 2GC, > about six miles due south of Fayetteville airport, > FAY. Hope to see > everybody there. If there is a group, we can gather > up over Eastover Air > Ranch and go to 2GC from there. What do you guys > think? > > David Davenport > RV-6 > ----- Original Message ----- > From: <Lenleg(at)aol.com> > To: > Subject: Re: RVSouthEast-List: James - Columbia > > > Lenleg(at)aol.com > > > > > > In a message dated 9/22/04 1:34:00 PM Eastern > Daylight Time, > N184FN(at)aol.com > > writes: > > > > Len, My old fllying club in FAY is having thier > ann cookout at Grays > Creek > > Airport in Fayetteville on Sunday afternoon. (2GC) > The SERV is invited > and > > I > > am planning to go and would like for a bunch of us > to go together if > > possible. > > Whould this be something that you would be > interested in doing? I plan > to > > leave after church. W8. > > > > > > Guys ... exactly the type thing we are looking for > ... > > > > We have several options now: > > > > 1. Fayetteville with Wayne8 > > > > 2. Wadesboro for burgers > > > > My vote is for Fayetteville and support Wayne8 > with lots of RVs !!! > > > > Len > > > > > > > > - > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RVSouthEast-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ ________________________________________________________________________________
Date: Sep 22, 2004
Len, You forgot to mentiion that there are also some *attempts* at activity in Columbia (SC) too. :-) Welcome to SERV guys. James > -----Original Message----- > From: owner-rvsoutheast-list-server(at)matronics.com > [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of > Lenleg(at)aol.com > Sent: Wednesday, September 22, 2004 12:16 PM > To: rvsoutheast-list(at)matronics.com > Subject: Re: RVSouthEast-List: Hickory Airports > > > In a message dated 9/22/04 10:14:55 AM Eastern Daylight Time, > N815RV(at)adelphia.net writes: > > I just got a call from an old friend Tim Berry, who was one of > the original > members of the Mid-Atlantic RV Wing formation team. Tim is > looking to move > to the Hickory, NC area and would like some help identifying > airports that > would welcome him and his RV8. > > Since Im located in the far east (Elizabeth City) I wont be of much help > to Tim and his quest for a good airport. So I hope the rest of you can > email or call Tim and pass along some information and suggestions as to > where to look and what to look out for. > > Tims phone #270 924 3674 > Email: Ifly2retire(at)earthlink.net > > Thanks > > Curtis Hinkley > N815RV > > > Curtis & Tim: > > Good to hear from you !!! Didn't know what you were up to these days !! > > My partners are from Hickory ... I get up there very often ... > only about 1 > 1/2 hours by car and a short RV flight from Winston-Salem. The Hickory > airport is quite nice ... lots of GA activity .. lost all their > airline service. > Don't know the situation about hangers. I don't remember anyone > in SERV from > Hickory but you could check the Vans list. > > Tim ... welcome to NC ... the majority of the activity so far in SERV is > closer to the Greensboro, Winston-Salem, Charlotte, Raleight > area. We look > forward to you joining us. > > Please go to _serv(at)bowenaero.com_ (mailto:serv(at)bowenaero.com) > and sign up > !! Let me know when you get to town and we will keep you > informed of the SERV > activities !! > > Len Leggette, RV-8A > Greensboro, N.C. N910LL > 273 hrs > > ________________________________________________________________________________
Date: Sep 23, 2004
Its a fee the fbo is charging to park for any time your there.I was takling to an faa inspector last weekend and he was telling me about it.He said that the restaurant there is upset about it.Because people are not flying in to eat. Ben ________________________________________________________________________________
Date: Sep 23, 2004
In a message dated 9/22/04 5:43:29 PM Eastern Daylight Time, ddavenport5(at)nc.rr.com writes: Let me throw my two cents worth in here.... This picnic that Wayne8 is talking about is put on by the Cape Fear Aero Association, and is one of our most fun events of the year. It is very informal, just come as you are and be prepared for good hamburgers and hotdogs. Just leave a little money in the kitty for next year. We give rides to any kids that want to go up, and then just go up and play as much as we can stand it. Len, this is a great excuse to show up as a group formation and show these guys what a real arrival looks like. You guys come on down. The location is Grays Creek, 2GC, about six miles due south of Fayetteville airport, FAY. Hope to see everybody there. If there is a group, we can gather up over Eastover Air Ranch and go to 2GC from there. What do you guys think? David Davenport RV-6 I am in !!! Meet at Eastover sounds good !!! Brief on the ground and plan the arrival at Grays Creek !! What time ?? Len ________________________________________________________________________________
Date: Sep 23, 2004
In a message dated 9/22/04 11:27:29 PM Eastern Daylight Time, james(at)nextupventures.com writes: You forgot to mentiion that there are also some *attempts* at activity in Columbia (SC) too. :-) We are going to turn the "attempts" in reality .... as soon as you retire from some of your many activities !!! Len ________________________________________________________________________________
Date: Sep 23, 2004
In a message dated 9/23/04 2:15:49 AM Eastern Daylight Time, SnakedoctorRV6(at)aol.com writes: Its a fee the fbo is charging to park for any time your there.I was takling to an faa inspector last weekend and he was telling me about it.He said that the restaurant there is upset about it.Because people are not flying in to eat. Ben I have flown into Hickory many times but not in the last 2 or 3 months .... I will not fly back into there if this is true !!! Len Leggette, RV-8A Greensboro, N.C. N910LL 273 hrs ________________________________________________________________________________
Date: Sep 23, 2004
I also have flow into hky many times.I,am just going on what was passed on to me.You might need to check before you go iguess is what i,am saying. Ben ________________________________________________________________________________
Date: Sep 23, 2004
See comments at: http://www.airnav.com/airport/KHKY/PROFILE#c I also heard about $50.. but that was some sort of confusion of some kind.. forgot the details.. $25 as mentioned on AirNav is still way too much... isn't even CLT cheaper than that :) Radomir --- SnakedoctorRV6(at)aol.com wrote: > SnakedoctorRV6(at)aol.com > > I also have flow into hky many times.I,am just going > on what was passed on to > me.You might need to check before you go iguess is > what i,am saying. > > Ben _______________________________ Declare Yourself - Register online to vote today! http://vote.yahoo.com ________________________________________________________________________________
Date: Sep 23, 2004
What happens if you refuse to pay? FBO has no authority, IMO, to collect anything unless I use their services. I could see a fee for over-night services, but just dropping someone off?! I have plenty of "fees" removed from each pay check..... - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Rad Z said: > > See comments at: > > http://www.airnav.com/airport/KHKY/PROFILE#c > > > I also heard about $50.. but that was some sort of > confusion of some kind.. forgot the details.. > > $25 as mentioned on AirNav is still way too much... > isn't even CLT cheaper than that :) > > Radomir > > > --- SnakedoctorRV6(at)aol.com wrote: > >> SnakedoctorRV6(at)aol.com >> >> I also have flow into hky many times.I,am just going >> on what was passed on to >> me.You might need to check before you go iguess is >> what i,am saying. >> >> Ben > > > _______________________________ > Declare Yourself - Register online to vote today! > http://vote.yahoo.com > > ________________________________________________________________________________
Date: Sep 23, 2004
In a message dated 9/23/04 11:32:15 AM Eastern Daylight Time, microsmurfer(at)yahoo.com writes: $25 as mentioned on AirNav is still way too much... isn't even CLT cheaper than that :) Somehow this seems un-American .... wonder if AOPA and EAA know about this . Len ________________________________________________________________________________
Date: Sep 23, 2004
> Somehow this seems un-American .... wonder if AOPA > and EAA know about this . > > Len > $25 just doesn't sound right... especially if you're just dropping off someone. Larry, well, it depends. If the ramp is "their property" (or leased etc..) they can charge whatever they want (parking fee, just like the city charges you via the parking meter). And send you a bill if you refuse to pay... then comes the collection agency etc.. I am guessing.. I don't know.. I don't wanna find out either :) It's plain wrong, IMHO. on the other hand I could see where they may be trying to recover the cost of lease/ownership/maintenance of the FBO itself.. too much traffic not a lot of sales? I guess they dont' sell that much gas? :) Radomir __________________________________ ________________________________________________________________________________
Date: Sep 23, 2004
Where are apron fees documented? NOTAMS? AFD? I don't see anything on airnav. No public notice = no collection if I turn around and leave. IMO. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Rad Z said: > > >> Somehow this seems un-American .... wonder if AOPA >> and EAA know about this . >> >> Len >> > > > $25 just doesn't sound right... especially if you're > just dropping off someone. > > Larry, well, it depends. If the ramp is "their > property" (or leased etc..) they can charge whatever > they want (parking fee, just like the city charges you > via the parking meter). And send you a bill if you > refuse to pay... then comes the collection agency > etc.. I am guessing.. I don't know.. I don't wanna > find out either :) > > It's plain wrong, IMHO. on the other hand I could see > where they may be trying to recover the cost of > lease/ownership/maintenance of the FBO itself.. too > much traffic not a lot of sales? > > I guess they dont' sell that much gas? :) > > Radomir > > > __________________________________ > > ________________________________________________________________________________
Subject: Noise
Date: Sep 23, 2004
Thanks for the koolmat Steve. It looks like good stuff. I'm confused which side faces the heat. There seems to examples of either way. Here it's even on the forward side of the firewall: http://www.koolmat.com/aircraft.shtml - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] > Sent: Thursday, September 16, 2004 9:07 AM > To: rvsoutheast-list(at)matronics.com > Subject: Re: RVSouthEast-List: Noise (was Flakes in fuel) > > --> > > Koolmat has a fireproof rubbery like material on one side the > side toward the back of the airplane and fiberglass > impregnated on the side toward the firewall. It is much more > substantive and stops almost all the oil canning of the firewall. > > I have a piece for you, where do I send it. I will get it in > today's mail if you send me an address ASAP. > > Steve > > ----- Original Message ----- > From: "Larry Bowen" <Larry(at)bowenaero.com> > To: > Subject: Re: RVSouthEast-List: Noise (was Flakes in fuel) > > > > > > > > How is the coolmat different? Do you have a piece of scrap > left I could > > see? > > > > - > > Larry Bowen > > Larry(at)BowenAero.com > > http://BowenAero.com > > > > Steve Glasgow said: > >> > >> > >> Larry, I'm not happy with your choice of insulation. I > got some of the > >> one > >> you are getting and some of the Koolmat before I decided. If I not > >> mistaken > >> the Koolmat is far superior. > >> > >> Just my thought. > >> > >> Steve > >> > >> > >> ----- Original Message ----- > >> From: "Larry Bowen" <Larry(at)bowenaero.com> > >> To: > >> Subject: Re: RVSouthEast-List: Noise (was Flakes in fuel) > >> > >> > >>> > >>> > >>> Larry Vetterman suggested the turn downs -- the way his > exhaust use to > >>> be. > >>> Right now things are so loud, I'd give up five knots for > some relief. > >>> I'll try some insulation first. > >>> > >>> Thanks, > >>> > >>> - > >>> Larry Bowen > >>> Larry(at)BowenAero.com > >>> http://BowenAero.com > >>> > >>> Dennis & Lori Millsap said: > >>>> > >>>> > >>>> Dennis says that he's noticed that he should add more > foam to the side > >>>> panels--more for noise than anything. He treated the > firewall primarily > >>>> for > >>>> heat (he thought) but it's the noise that gets ya. > >>>> > >>>> What do you mean by "turn downs"? Dennis cut his exhaust > pipes off. You > >>>> don't want them hanging down in the airstream. Let them > be loud, but > >>>> for > >>>> goodness sake, don't let them slow ya down! GRIN! > >>>> > >>>> Actually, it puts undue stress on your exhaust system having them > >>>> hanging > >>>> out in the wind. Dennis broke a bracket or two before he > cut them off. > >>>> > >>>> Lori > >>>> N464DM, RV-6A, 300+ hours > >>>> ----- Original Message ----- > >>>> From: "Larry Bowen" <Larry(at)bowenaero.com> > >>>> To: > >>>> Subject: RE: RVSouthEast-List: Flakes in fuel > >>>> > >>>> > >>>> > >>>>> > >>>>> I ordered this last night: > >>>>> > >>>>> http://www.aircraftspruce.com/catalog/appages/dampingpanels.php > >>>>> > >>>>> Does dampening the firewall give the most gain for the > effort? Or do > >>>>> the > >>>>> sidewalls need to be done too? > >>>>> > >>>>> I'm thinking of getting some turn-downs for the exhaust > pipes too... > >>>>> > >>>>> - > >>>>> Larry Bowen > >>>>> Larry(at)BowenAero.com > >>>>> http://BowenAero.com > >>>>> > >>>>> > >>>>> > -----Original Message----- > >>>>> > From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] > >>>>> > Sent: Wednesday, September 15, 2004 9:17 PM > >>>>> > To: rvsoutheast-list(at)matronics.com > >>>>> > Subject: Re: RVSouthEast-List: Flakes in fuel > >>>>> > > >>>>> > --> > >>>>> > > >>>>> > Mike and I used Koolmat Heat Barrier from Spruce > around page 123. > >>>>> > > >>>>> > Used spray glue to hold it in place, no problems so far. > >>>>> > Just cut and paste! > >>>>> > > >>>>> > Sorry to hear of the latest problem, better to quit after > >>>>> > start than after takeoff. I promise after you have done your > >>>>> > time (40 hours) you will just fly it and put it to bed. I > >>>>> > know you can't wait. > >>>>> > > >>>>> > Steve > >>>>> > > >>>>> > ----- Original Message ----- > >>>>> > From: "Larry Bowen" <Larry(at)bowenaero.com> > >>>>> > To: > >>>>> > Subject: RE: RVSouthEast-List: Flakes in fuel > >>>>> > > >>>>> > > >>>>> > > > >>>>> > > > >>>>> > > Thanks. > >>>>> > > > >>>>> > > I'm down for now. I had to send the Rose ignition module > >>>>> > back. It quite > >>>>> > > Sunday shortly after start-up. Anyway, I'm taking the > >>>>> > opportunity to > >>>>> > > tweak > >>>>> > > some things and sound proof the firewall. Boy that thing > >>>>> > is loud!! Any > >>>>> > > tips for me related to sound-proofing? Anyone? Bueller? > >>>>> > > > >>>>> > > - > >>>>> > > Larry Bowen > >>>>> > > Larry(at)BowenAero.com > >>>>> > > http://BowenAero.com > >>>>> > > > >>>>> > > > >>>>> > >> -----Original Message----- > >>>>> > >> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] > >>>>> > >> Sent: Wednesday, September 15, 2004 8:23 PM > >>>>> > >> To: rvsoutheast-list(at)matronics.com > >>>>> > >> Subject: Re: RVSouthEast-List: Flakes in fuel > >>>>> > >> > >>>>> > >> --> > >>>>> > >> > >>>>> > >> They are very small! A spec for sure! > >>>>> > >> > >>>>> > >> I even had them in OSH during preflight before I left. > >>>>> > >> > >>>>> > >> Again congrats on the event and many more to come. > >>>>> > >> > >>>>> > >> Steve > >>>>> > >> > >>>>> > >> > >>>>> > >> ----- Original Message ----- > >>>>> > >> From: "Larry Bowen" <Larry(at)bowenaero.com> > >>>>> > >> To: > >>>>> > >> Subject: RE: RVSouthEast-List: Flakes in fuel > >>>>> > >> > >>>>> > >> > >>>>> > >> > > >>>>> > >> > > >>>>> > >> > Like corn flakes sized flakes? Or specs? Proseal is > >>>>> > >> blakish, but doesn't > >>>>> > >> > break down from fuel. Maybe it's from the fuel truck or > >>>>> > >> inground tank. > >>>>> > >> > I'd > >>>>> > >> > monitor to try to establish a trend, if any...... > >>>>> > >> > > >>>>> > >> > - > >>>>> > >> > Larry Bowen > >>>>> > >> > Larry(at)BowenAero.com > >>>>> > >> > http://BowenAero.com > >>>>> > >> > > >>>>> > >> > > >>>>> > >> >> -----Original Message----- > >>>>> > >> >> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] > >>>>> > >> >> Sent: Wednesday, September 15, 2004 4:46 PM > >>>>> > >> >> To: SERV > >>>>> > >> >> Subject: RVSouthEast-List: Flakes in fuel > >>>>> > >> >> > >>>>> > >> >> --> > >>>>> > >> >> > >>>>> > >> >> During preflight when the aircraft has set for > some time, > >>>>> > >> >> when I drain fuel from under the wing I find > some brown or > >>>>> > >> >> blackish flakes. It takes about 6 ounces of draining to > >>>>> > >> >> clear up the flakes. > >>>>> > >> >> > >>>>> > >> >> Has anyone experienced something similar? > >>>>> > >> >> > >>>>> > >> >> I have a OB 8. Could it be the tanks sealer is > dissolving? > >>>>> > >> >> > >>>>> > >> >> Thanks, > >>>>> > >> >> > >>>>> > >> >> Steve Glasgow > >>>>> > >> >> > >>>>> > >> >> > >>>>> > >> >> ============ > >>>>> > >> >> Matronics Forums. > >>>>> > >> >> ============ > >>>>> > >> >> ============ > >>>>> > >> >> ============ > >>>>> > >> >> > >>>>> > >> >> > >>>>> > >> >> > >>>>> > >> >> > >>>>> > >> >> > >>>>> > >> >> > >>>>> > >> > > >>>>> > >> > > >>>>> > >> > > >>>>> > >> > >>>>> > >> > >>>>> > >> ============ > >>>>> > >> ============ > >>>>> > >> ============ > >>>>> > >> ============ > >>>>> > >> > >>>>> > >> > >>>>> > >> > >>>>> > >> > >>>>> > >> > >>>>> > >> > >>>>> > > > >>>>> > > > >>>>> > > > >>>>> > > >>>>> > > >>>>> > ============ > >>>>> > ============ > >>>>> > ============ > >>>>> > ============ > >>>>> > > >>>>> > > >>>>> > > >>>>> > > >>>>> > > >>>>> > > >>>>> > >>>>> > >>>> > >>>> > >>> > >>> > >>> > >> > >> > > > > > > > > > ============ > ============ > ============ > ============ > > > > > > ________________________________________________________________________________
Subject: Re: Noise
Date: Sep 23, 2004
Mine is spray glued to the inside of the baggage compartment with the fiberglass side glued to the back side of the firewall. It is going to be a pain since you are already together. I did mine before the top piece was on. I would suggest templates out of thin cardboard cut to fit, then you can cut holes for the nuts and bolts that go through the firewall. I used some hardwall tubing sharpened and hammered out the holes for the nuts and bolts. You will be suppressed how well it deadens the sound and stops the oil canning. Later, Steve ----- Original Message ----- From: "Larry Bowen" <Larry(at)bowenaero.com> Subject: RE: RVSouthEast-List: Noise > > > Thanks for the koolmat Steve. It looks like good stuff. > > I'm confused which side faces the heat. There seems to examples of either > way. Here it's even on the forward side of the firewall: > > http://www.koolmat.com/aircraft.shtml > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > >> -----Original Message----- >> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >> Sent: Thursday, September 16, 2004 9:07 AM >> To: rvsoutheast-list(at)matronics.com >> Subject: Re: RVSouthEast-List: Noise (was Flakes in fuel) >> >> --> >> >> Koolmat has a fireproof rubbery like material on one side the >> side toward the back of the airplane and fiberglass >> impregnated on the side toward the firewall. It is much more >> substantive and stops almost all the oil canning of the firewall. >> >> I have a piece for you, where do I send it. I will get it in >> today's mail if you send me an address ASAP. >> >> Steve >> >> ----- Original Message ----- >> From: "Larry Bowen" <Larry(at)bowenaero.com> >> To: >> Subject: Re: RVSouthEast-List: Noise (was Flakes in fuel) >> >> >> > >> > >> > How is the coolmat different? Do you have a piece of scrap >> left I could >> > see? >> > >> > - >> > Larry Bowen >> > Larry(at)BowenAero.com >> > http://BowenAero.com >> > >> > Steve Glasgow said: >> >> >> >> >> >> Larry, I'm not happy with your choice of insulation. I >> got some of the >> >> one >> >> you are getting and some of the Koolmat before I decided. If I not >> >> mistaken >> >> the Koolmat is far superior. >> >> >> >> Just my thought. >> >> >> >> Steve >> >> >> >> >> >> ----- Original Message ----- >> >> From: "Larry Bowen" <Larry(at)bowenaero.com> >> >> To: >> >> Subject: Re: RVSouthEast-List: Noise (was Flakes in fuel) >> >> >> >> >> >>> >> >>> >> >>> Larry Vetterman suggested the turn downs -- the way his >> exhaust use to >> >>> be. >> >>> Right now things are so loud, I'd give up five knots for >> some relief. >> >>> I'll try some insulation first. >> >>> >> >>> Thanks, >> >>> >> >>> - >> >>> Larry Bowen >> >>> Larry(at)BowenAero.com >> >>> http://BowenAero.com >> >>> >> >>> Dennis & Lori Millsap said: >> >>>> >> >>>> >> >>>> Dennis says that he's noticed that he should add more >> foam to the side >> >>>> panels--more for noise than anything. He treated the >> firewall primarily >> >>>> for >> >>>> heat (he thought) but it's the noise that gets ya. >> >>>> >> >>>> What do you mean by "turn downs"? Dennis cut his exhaust >> pipes off. You >> >>>> don't want them hanging down in the airstream. Let them >> be loud, but >> >>>> for >> >>>> goodness sake, don't let them slow ya down! GRIN! >> >>>> >> >>>> Actually, it puts undue stress on your exhaust system having them >> >>>> hanging >> >>>> out in the wind. Dennis broke a bracket or two before he >> cut them off. >> >>>> >> >>>> Lori >> >>>> N464DM, RV-6A, 300+ hours >> >>>> ----- Original Message ----- >> >>>> From: "Larry Bowen" <Larry(at)bowenaero.com> >> >>>> To: >> >>>> Subject: RE: RVSouthEast-List: Flakes in fuel >> >>>> >> >>>> >> >>>> >> >>>>> >> >>>>> I ordered this last night: >> >>>>> >> >>>>> http://www.aircraftspruce.com/catalog/appages/dampingpanels.php >> >>>>> >> >>>>> Does dampening the firewall give the most gain for the >> effort? Or do >> >>>>> the >> >>>>> sidewalls need to be done too? >> >>>>> >> >>>>> I'm thinking of getting some turn-downs for the exhaust >> pipes too... >> >>>>> >> >>>>> - >> >>>>> Larry Bowen >> >>>>> Larry(at)BowenAero.com >> >>>>> http://BowenAero.com >> >>>>> >> >>>>> >> >>>>> > -----Original Message----- >> >>>>> > From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >> >>>>> > Sent: Wednesday, September 15, 2004 9:17 PM >> >>>>> > To: rvsoutheast-list(at)matronics.com >> >>>>> > Subject: Re: RVSouthEast-List: Flakes in fuel >> >>>>> > >> >>>>> > --> >> >>>>> > >> >>>>> > Mike and I used Koolmat Heat Barrier from Spruce >> around page 123. >> >>>>> > >> >>>>> > Used spray glue to hold it in place, no problems so far. >> >>>>> > Just cut and paste! >> >>>>> > >> >>>>> > Sorry to hear of the latest problem, better to quit after >> >>>>> > start than after takeoff. I promise after you have done your >> >>>>> > time (40 hours) you will just fly it and put it to bed. I >> >>>>> > know you can't wait. >> >>>>> > >> >>>>> > Steve >> >>>>> > >> >>>>> > ----- Original Message ----- >> >>>>> > From: "Larry Bowen" <Larry(at)bowenaero.com> >> >>>>> > To: >> >>>>> > Subject: RE: RVSouthEast-List: Flakes in fuel >> >>>>> > >> >>>>> > >> >>>>> > > >> >>>>> > > >> >>>>> > > Thanks. >> >>>>> > > >> >>>>> > > I'm down for now. I had to send the Rose ignition module >> >>>>> > back. It quite >> >>>>> > > Sunday shortly after start-up. Anyway, I'm taking the >> >>>>> > opportunity to >> >>>>> > > tweak >> >>>>> > > some things and sound proof the firewall. Boy that thing >> >>>>> > is loud!! Any >> >>>>> > > tips for me related to sound-proofing? Anyone? Bueller? >> >>>>> > > >> >>>>> > > - >> >>>>> > > Larry Bowen >> >>>>> > > Larry(at)BowenAero.com >> >>>>> > > http://BowenAero.com >> >>>>> > > >> >>>>> > > >> >>>>> > >> -----Original Message----- >> >>>>> > >> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >> >>>>> > >> Sent: Wednesday, September 15, 2004 8:23 PM >> >>>>> > >> To: rvsoutheast-list(at)matronics.com >> >>>>> > >> Subject: Re: RVSouthEast-List: Flakes in fuel >> >>>>> > >> >> >>>>> > >> --> >> >>>>> > >> >> >>>>> > >> They are very small! A spec for sure! >> >>>>> > >> >> >>>>> > >> I even had them in OSH during preflight before I left. >> >>>>> > >> >> >>>>> > >> Again congrats on the event and many more to come. >> >>>>> > >> >> >>>>> > >> Steve >> >>>>> > >> >> >>>>> > >> >> >>>>> > >> ----- Original Message ----- >> >>>>> > >> From: "Larry Bowen" <Larry(at)bowenaero.com> >> >>>>> > >> To: >> >>>>> > >> Subject: RE: RVSouthEast-List: Flakes in fuel >> >>>>> > >> >> >>>>> > >> >> >>>>> > >> > >> >>>>> > >> > >> >>>>> > >> > Like corn flakes sized flakes? Or specs? Proseal is >> >>>>> > >> blakish, but doesn't >> >>>>> > >> > break down from fuel. Maybe it's from the fuel truck or >> >>>>> > >> inground tank. >> >>>>> > >> > I'd >> >>>>> > >> > monitor to try to establish a trend, if any...... >> >>>>> > >> > >> >>>>> > >> > - >> >>>>> > >> > Larry Bowen >> >>>>> > >> > Larry(at)BowenAero.com >> >>>>> > >> > http://BowenAero.com >> >>>>> > >> > >> >>>>> > >> > >> >>>>> > >> >> -----Original Message----- >> >>>>> > >> >> From: Steve Glasgow [mailto:willfly(at)carolina.rr.com] >> >>>>> > >> >> Sent: Wednesday, September 15, 2004 4:46 PM >> >>>>> > >> >> To: SERV >> >>>>> > >> >> Subject: RVSouthEast-List: Flakes in fuel >> >>>>> > >> >> >> >>>>> > >> >> --> >> >>>>> > >> >> >> >>>>> > >> >> During preflight when the aircraft has set for >> some time, >> >>>>> > >> >> when I drain fuel from under the wing I find >> some brown or >> >>>>> > >> >> blackish flakes. It takes about 6 ounces of draining to >> >>>>> > >> >> clear up the flakes. >> >>>>> > >> >> >> >>>>> > >> >> Has anyone experienced something similar? >> >>>>> > >> >> >> >>>>> > >> >> I have a OB 8. Could it be the tanks sealer is >> dissolving? >> >>>>> > >> >> >> >>>>> > >> >> Thanks, >> >>>>> > >> >> >> >>>>> > >> >> Steve Glasgow >> >>>>> > >> >> >> >>>>> > >> >> >> >>>>> > >> >> ============ >> >>>>> > >> >> Matronics Forums. >> >>>>> > >> >> ============ >> >>>>> > >> >> ============ >> >>>>> > >> >> ============ >> >>>>> > >> >> >> >>>>> > >> >> >> >>>>> > >> >> >> >>>>> > >> >> >> >>>>> > >> >> >> >>>>> > >> >> >> >>>>> > >> > >> >>>>> > >> > >> >>>>> > >> > >> >>>>> > >> >> >>>>> > >> >> >>>>> > >> ============ >> >>>>> > >> ============ >> >>>>> > >> ============ >> >>>>> > >> ============ >> >>>>> > >> >> >>>>> > >> >> >>>>> > >> >> >>>>> > >> >> >>>>> > >> >> >>>>> > >> >> >>>>> > > >> >>>>> > > >> >>>>> > > >> >>>>> > >> >>>>> > >> >>>>> > ============ >> >>>>> > ============ >> >>>>> > ============ >> >>>>> > ============ >> >>>>> > >> >>>>> > >> >>>>> > >> >>>>> > >> >>>>> > >> >>>>> > >> >>>>> >> >>>>> >> >>>> >> >>>> >> >>> >> >>> >> >>> >> >> >> >> >> > >> > >> > >> >> >> ============ >> ============ >> ============ >> ============ >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Sep 23, 2004
hey james, do you have something planned for saturday? i'm up for visiting or going somewhere and doing a little formating. sunday is tied up for u and may be wet. i'm open both days. bill c. --- Lenleg(at)aol.com wrote: > Lenleg(at)aol.com > > > In a message dated 9/22/04 1:34:00 PM Eastern > Daylight Time, N184FN(at)aol.com > writes: > > Len, My old fllying club in FAY is having thier ann > cookout at Grays Creek > Airport in Fayetteville on Sunday afternoon. (2GC) > The SERV is invited and > I > am planning to go and would like for a bunch of us > to go together if > possible. > Whould this be something that you would be > interested in doing? I plan to > leave after church. W8. > > > Guys ... exactly the type thing we are looking for > ... > > We have several options now: > > 1. Fayetteville with Wayne8 > > 2. Wadesboro for burgers > > My vote is for Fayetteville and support Wayne8 with > lots of RVs !!! > > Len > > > > - > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RVSouthEast-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ ________________________________________________________________________________
From: "James E. Clark" <james(at)nextupventures.com>
Date: Sep 24, 2004
Might be able to do a little on Saturday. Depends on how several other irons in the fire shake out. Will let you know. I definitely **WANT** to. James > -----Original Message----- > From: owner-rvsoutheast-list-server(at)matronics.com > [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of bill > crothers > Sent: Thursday, September 23, 2004 8:56 PM > To: rvsoutheast-list(at)matronics.com > Subject: Re: RVSouthEast-List: James - Columbia > > > > > hey james, do you have something planned for saturday? > i'm up for visiting or going somewhere and doing a > little formating. sunday is tied up for u and may be > wet. i'm open both days. bill c. > --- Lenleg(at)aol.com wrote: > > > Lenleg(at)aol.com > > > > > > In a message dated 9/22/04 1:34:00 PM Eastern > > Daylight Time, N184FN(at)aol.com > > writes: > > > > Len, My old fllying club in FAY is having thier ann > > cookout at Grays Creek > > Airport in Fayetteville on Sunday afternoon. (2GC) > > The SERV is invited and > > I > > am planning to go and would like for a bunch of us > > to go together if > > possible. > > Whould this be something that you would be > > interested in doing? I plan to > > leave after church. W8. > > > > > > Guys ... exactly the type thing we are looking for > > ... > > > > We have several options now: > > > > 1. Fayetteville with Wayne8 > > > > 2. Wadesboro for burgers > > > > My vote is for Fayetteville and support Wayne8 with > > lots of RVs !!! > > > > Len > > > > > > > > - > > Contributions > > any other > > Forums. > > > > http://www.matronics.com/chat > > > > http://www.matronics.com/subscription > > http://www.matronics.com/FAQ/RVSouthEast-List.htm > > http://www.matronics.com/archives > > http://www.matronics.com/photoshare > > http://www.matronics.com/emaillists > > > > > > > > > > > > > > > __________________________________ > > ________________________________________________________________________________
Date: Sep 24, 2004
Larry, the "Flight Guide" publication always has landing fees listed in their airport info listings. Another good reason that those little brown binders are good to have around. David ----- Original Message ----- From: "Larry Bowen" <Larry(at)bowenaero.com> Subject: Re: RVSouthEast-List: Hickory Airports > > Where are apron fees documented? NOTAMS? AFD? I don't see anything on > airnav. No public notice = no collection if I turn around and leave. > IMO. > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > Rad Z said: > > > > > >> Somehow this seems un-American .... wonder if AOPA > >> and EAA know about this . > >> > >> Len > >> > > > > > > $25 just doesn't sound right... especially if you're > > just dropping off someone. > > > > Larry, well, it depends. If the ramp is "their > > property" (or leased etc..) they can charge whatever > > they want (parking fee, just like the city charges you > > via the parking meter). And send you a bill if you > > refuse to pay... then comes the collection agency > > etc.. I am guessing.. I don't know.. I don't wanna > > find out either :) > > > > It's plain wrong, IMHO. on the other hand I could see > > where they may be trying to recover the cost of > > lease/ownership/maintenance of the FBO itself.. too > > much traffic not a lot of sales? > > > > I guess they dont' sell that much gas? :) > > > > Radomir > > > > > > __________________________________ > > > > > > ________________________________________________________________________________
Date: Sep 24, 2004
Subject: DESTINATIONS
FYI- - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ==================== FLYING DESTINATIONS IN THE MIDATLANTIC REGION THIS WEEKEND: WILSON, NORTH CAROLINA. An EAA Chapter 1047 Annual Fly-in takes place September 25 at Wilson Industrial Air Center (W03). Pancake breakfast, static displays, skydivers, vendors, childen's activities, and plenty of food. Contact Tom Gregorski, 252/291-8810. REIDSVILLE, NORTH CAROLINA. The Third Annual Air Force Junior ROTC Fly-in takes place September 25 at Rockingham County Shiloh (78N) from 11 a.m. to 3 p.m. Featuring a hamburger/hot dog lunch, airplane rides, car cruise on the field, ROTC displays, World War II veteran airman display, and giveaways. Visit the Web site ( http://www.shilohairport.org ). CUMBERLAND, MARYLAND. An EAA Chapter 426 Fly-in Breakfast takes place September 26 at Greater Cumberland Regional (CBE) from 7 to 11 a.m. Contact Harry Dolly, 814/356-3773. NEXT WEEKEND: DARLINGTON, SOUTH CAROLINA. A Fall Fly-in takes place October 1 through 3 at Darlington County Jetport (UDG). Fly-in for all aircraft classes. Barbecue on the field Friday; judging and a banquet Saturday. Contact Jim Wilson, 843/753-7138. FRANKLIN, NORTH CAROLINA. The Macon County Aviation Celebration takes place October 2 at Macon County (1A5). The daylong celebration of aviation includes vintage aircraft, skydivers, food, and fun for the entire family. Fly-ins welcome. Contact Tony Angel, 800/336-7829, or visit the Web site ( http://www.franklin-chamber.com ). WINCHESTER, VIRGINIA. An EAA Chapter 186 Fall Fly-in takes place October 2 and 3 at Winchester Regional (OKV). Fly-in and pancake breakfast, aircraft judging, Young Eagle flights, and more. Contact Ms. Tangy Mooney, 703/361-0294, or visit the Web site ( http://www.eaa186.org ). ________________________________________________________________________________
Subject: Re: DESTINATIONS
Date: Sep 24, 2004
Dont forget Farmville NC [Flanagan Field N08] EAA chapter 960, September 25 th, plane rides, lunch, Short wing piper club, experimentals, UL, Vintage. George ----- Original Message ----- From: "Larry Bowen" <Larry(at)bowenaero.com> Subject: RVSouthEast-List: DESTINATIONS > > FYI- > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > ==================== > > FLYING DESTINATIONS IN THE MIDATLANTIC REGION THIS WEEKEND: > WILSON, NORTH CAROLINA. An EAA Chapter 1047 Annual Fly-in takes place > September 25 at Wilson Industrial Air Center (W03). Pancake breakfast, > static displays, skydivers, vendors, childen's activities, and plenty > of food. Contact Tom Gregorski, 252/291-8810. > > REIDSVILLE, NORTH CAROLINA. The Third Annual Air Force Junior ROTC Fly-in > takes place September 25 at Rockingham County Shiloh (78N) from 11 a.m. > to 3 p.m. Featuring a hamburger/hot dog lunch, airplane rides, car cruise > on the field, ROTC displays, World War II veteran airman display, and > giveaways. Visit the Web site ( http://www.shilohairport.org ). > > CUMBERLAND, MARYLAND. An EAA Chapter 426 Fly-in Breakfast takes place > September 26 at Greater Cumberland Regional (CBE) from 7 to 11 a.m. > Contact Harry Dolly, 814/356-3773. > > NEXT WEEKEND: > DARLINGTON, SOUTH CAROLINA. A Fall Fly-in takes place October 1 > through 3 at Darlington County Jetport (UDG). Fly-in for all aircraft > classes. Barbecue on the field Friday; judging and a banquet Saturday. > Contact Jim Wilson, 843/753-7138. > > FRANKLIN, NORTH CAROLINA. The Macon County Aviation Celebration takes > place October 2 at Macon County (1A5). The daylong celebration of > aviation includes vintage aircraft, skydivers, food, and fun for the > entire family. Fly-ins welcome. Contact Tony Angel, 800/336-7829, or > visit the Web site ( http://www.franklin-chamber.com ). > > WINCHESTER, VIRGINIA. An EAA Chapter 186 Fall Fly-in takes place October 2 > and 3 at Winchester Regional (OKV). Fly-in and pancake breakfast, aircraft > judging, Young Eagle flights, and more. Contact Ms. Tangy Mooney, > 703/361-0294, or visit the Web site ( http://www.eaa186.org ). > > ________________________________________________________________________________
Date: Sep 24, 2004
Subject: AOA port installation
Hey guys, getting ready to install the AOA port, so I can move on with the wing. Which dimple dies are good for #4 screws? I don't have #4 d.d. set.. wondering if 1/8" dimples would work.. I suppose a hole is needed at the bottom of leading edge so the upper port can be drained.. Any recommendations on size of this hole? Anything else to pay special attention to? Thanks! Radomir _______________________________ Declare Yourself - Register online to vote today! http://vote.yahoo.com ________________________________________________________________________________
Date: Sep 24, 2004
Subject: Re: AOA port installation
In a message dated 9/24/04 3:02:58 PM Eastern Daylight Time, microsmurfer(at)yahoo.com writes: Which dimple dies are good for #4 screws? I don't have #4 d.d. set.. wondering if 1/8" dimples would work.. You could use the 1/8" but I think I have a set for #4 ... I used the #4 screws in my wingtips ... I will look over the weekend and let you know !! Len ________________________________________________________________________________
Date: Sep 24, 2004
You have the PSS AOA? I don't remember how I dimpled, but I remember having to file 100 degree angles on the screws to fit nicely in the dimple. Fun. I did a #30 hole on the bottom. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Rad Z said: > > Hey guys, > > getting ready to install the AOA port, so I can move > on with the wing. > > Which dimple dies are good for #4 screws? I don't > have #4 d.d. set.. wondering if 1/8" dimples would > work.. > > I suppose a hole is needed at the bottom of leading > edge so the upper port can be drained.. Any > recommendations on size of this hole? > > Anything else to pay special attention to? > > Thanks! > Radomir > > > _______________________________ > Declare Yourself - Register online to vote today! > http://vote.yahoo.com > > ________________________________________________________________________________
Date: Sep 24, 2004
Radomir: I did use the #30 and it worked great. I also connected a metal tube (chromed copper) so it extends a little below the bottom skin. This allows me to drain the top port by simply pushing up on the tube. Remember to seal the port to the skin. (I used form-a-gasket as recommended in the instructions.) Wayne -----Original Message----- From: owner-rvsoutheast-list-server(at)matronics.com [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of Rad Z Subject: RVSouthEast-List: AOA port installation Hey guys, getting ready to install the AOA port, so I can move on with the wing. Which dimple dies are good for #4 screws? I don't have #4 d.d. set.. wondering if 1/8" dimples would work.. I suppose a hole is needed at the bottom of leading edge so the upper port can be drained.. Any recommendations on size of this hole? Anything else to pay special attention to? Thanks! Radomir _______________________________ Declare Yourself - Register online to vote today! http://vote.yahoo.com ________________________________________________________________________________
Date: Sep 24, 2004
Thanks everyone for prompt responses. I'll try out 1/8 d.d. set on a scrap piece first to see how it'll work out. If these screws are "wrong" (not 100 deg.) I'll just temporarily place them there and then maybe get "real" screws later (from microfasteners, I guess). Is this form-a-gasket available at auto parts stores? I have some blue RTV.. not sure if that'd work for sealing. (trying to never crack open that proseal I have in the freezer :) Radomir __________________________________ ________________________________________________________________________________
Date: Sep 24, 2004
ok, guys...who's going where saturday? bill c. --- gtamvakis(at)earthlink.net wrote: > > > Dont forget Farmville NC [Flanagan Field N08] EAA > chapter 960, September 25 > th, plane rides, lunch, Short wing piper club, > experimentals, UL, Vintage. > > George > ----- Original Message ----- > From: "Larry Bowen" <Larry(at)bowenaero.com> > To: "serv" > Subject: RVSouthEast-List: DESTINATIONS > > > Bowen" > > > > > FYI- > > > > - > > Larry Bowen > > Larry(at)BowenAero.com > > http://BowenAero.com > > > > ==================== > > > > FLYING DESTINATIONS IN THE MIDATLANTIC REGION THIS > WEEKEND: > > WILSON, NORTH CAROLINA. An EAA Chapter 1047 Annual > Fly-in takes place > > September 25 at Wilson Industrial Air Center > (W03). Pancake breakfast, > > static displays, skydivers, vendors, childen's > activities, and plenty > > of food. Contact Tom Gregorski, 252/291-8810. > > > > REIDSVILLE, NORTH CAROLINA. The Third Annual Air > Force Junior ROTC Fly-in > > takes place September 25 at Rockingham County > Shiloh (78N) from 11 a.m. > > to 3 p.m. Featuring a hamburger/hot dog lunch, > airplane rides, car cruise > > on the field, ROTC displays, World War II veteran > airman display, and > > giveaways. Visit the Web site ( > http://www.shilohairport.org ). > > > > CUMBERLAND, MARYLAND. An EAA Chapter 426 Fly-in > Breakfast takes place > > September 26 at Greater Cumberland Regional (CBE) > from 7 to 11 a.m. > > Contact Harry Dolly, 814/356-3773. > > > > NEXT WEEKEND: > > DARLINGTON, SOUTH CAROLINA. A Fall Fly-in takes > place October 1 > > through 3 at Darlington County Jetport (UDG). > Fly-in for all aircraft > > classes. Barbecue on the field Friday; judging and > a banquet Saturday. > > Contact Jim Wilson, 843/753-7138. > > > > FRANKLIN, NORTH CAROLINA. The Macon County > Aviation Celebration takes > > place October 2 at Macon County (1A5). The daylong > celebration of > > aviation includes vintage aircraft, skydivers, > food, and fun for the > > entire family. Fly-ins welcome. Contact Tony > Angel, 800/336-7829, or > > visit the Web site ( > http://www.franklin-chamber.com ). > > > > WINCHESTER, VIRGINIA. An EAA Chapter 186 Fall > Fly-in takes place October 2 > > and 3 at Winchester Regional (OKV). Fly-in and > pancake breakfast, aircraft > > judging, Young Eagle flights, and more. Contact > Ms. Tangy Mooney, > > 703/361-0294, or visit the Web site ( > http://www.eaa186.org ). > > > > > > > > - > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RVSouthEast-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ ________________________________________________________________________________
From: "Dennis & Lori Millsap" <dwmillsap(at)hyperlogic.net>
Date: Sep 24, 2004
Thanks for the reminder...Dennis's RV-6A will be there, but he doesn't get back from Colorado's hunting trip until 5pm tomorrow afternoon, so the girls and I will be standing guard. Y'all come see us! Hey, Len, what football game will you be coming to soon? We are looking forward to meeting you in person. Lori PS Hi, George! ~~~~~~~~~~~~~~~~~~ Lori & Dennis Millsap N464DM, RV-6A RV-10 empecone complete, #40112 ----- Original Message ----- From: <gtamvakis(at)earthlink.net> Subject: Re: RVSouthEast-List: DESTINATIONS > > Dont forget Farmville NC [Flanagan Field N08] EAA chapter 960, September 25 > th, plane rides, lunch, Short wing piper club, experimentals, UL, Vintage. > > George ________________________________________________________________________________
Date: Sep 24, 2004
How do I unsubscribe from this email? ________________________________________________________________________________
Date: Sep 24, 2004
And follow the instructions. HTH -----Original Message----- From: owner-rvsoutheast-list-server(at)matronics.com [mailto:owner-rvsoutheast-list-server(at)matronics.com] On Behalf Of RondaFagan(at)aol.com Subject: Re: RVSouthEast-List: AOA port installation How do I unsubscribe from this email? ________________________________________________________________________________
Date: Sep 24, 2004
Bill, We have lot going on here in Columbia this weekend but if you fly down and get there by 12:00 the BBQ is on me. We can do some formation flying before or after that. I have some things to check out on the plane and some things to do late afternoon that will keep me close to home but we could work something out. Whadday think?? James KCUB > -----Original Message----- > From: owner-rvsoutheast-list-server(at)matronics.com > [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of bill > crothers > Sent: Friday, September 24, 2004 5:45 PM > To: rvsoutheast-list(at)matronics.com > Subject: Re: RVSouthEast-List: DESTINATIONS > > > > > ok, guys...who's going where saturday? bill c. > --- gtamvakis(at)earthlink.net wrote: > > > > > > > Dont forget Farmville NC [Flanagan Field N08] EAA > > chapter 960, September 25 > > th, plane rides, lunch, Short wing piper club, > > experimentals, UL, Vintage. > > > > George > > ----- Original Message ----- > > From: "Larry Bowen" <Larry(at)bowenaero.com> > > To: "serv" > > Subject: RVSouthEast-List: DESTINATIONS > > > > > > Bowen" > > > > > > > > FYI- > > > > > > - > > > Larry Bowen > > > Larry(at)BowenAero.com > > > http://BowenAero.com > > > > > > ==================== > > > > > > FLYING DESTINATIONS IN THE MIDATLANTIC REGION THIS > > WEEKEND: > > > WILSON, NORTH CAROLINA. An EAA Chapter 1047 Annual > > Fly-in takes place > > > September 25 at Wilson Industrial Air Center > > (W03). Pancake breakfast, > > > static displays, skydivers, vendors, childen's > > activities, and plenty > > > of food. Contact Tom Gregorski, 252/291-8810. > > > > > > REIDSVILLE, NORTH CAROLINA. The Third Annual Air > > Force Junior ROTC Fly-in > > > takes place September 25 at Rockingham County > > Shiloh (78N) from 11 a.m. > > > to 3 p.m. Featuring a hamburger/hot dog lunch, > > airplane rides, car cruise > > > on the field, ROTC displays, World War II veteran > > airman display, and > > > giveaways. Visit the Web site ( > > http://www.shilohairport.org ). > > > > > > CUMBERLAND, MARYLAND. An EAA Chapter 426 Fly-in > > Breakfast takes place > > > September 26 at Greater Cumberland Regional (CBE) > > from 7 to 11 a.m. > > > Contact Harry Dolly, 814/356-3773. > > > > > > NEXT WEEKEND: > > > DARLINGTON, SOUTH CAROLINA. A Fall Fly-in takes > > place October 1 > > > through 3 at Darlington County Jetport (UDG). > > Fly-in for all aircraft > > > classes. Barbecue on the field Friday; judging and > > a banquet Saturday. > > > Contact Jim Wilson, 843/753-7138. > > > > > > FRANKLIN, NORTH CAROLINA. The Macon County > > Aviation Celebration takes > > > place October 2 at Macon County (1A5). The daylong > > celebration of > > > aviation includes vintage aircraft, skydivers, > > food, and fun for the > > > entire family. Fly-ins welcome. Contact Tony > > Angel, 800/336-7829, or > > > visit the Web site ( > > http://www.franklin-chamber.com ). > > > > > > WINCHESTER, VIRGINIA. An EAA Chapter 186 Fall > > Fly-in takes place October 2 > > > and 3 at Winchester Regional (OKV). Fly-in and > > pancake breakfast, aircraft > > > judging, Young Eagle flights, and more. Contact > > Ms. Tangy Mooney, > > > 703/361-0294, or visit the Web site ( > > http://www.eaa186.org ). > > > > > > > > > > > > > > - > > Contributions > > any other > > Forums. > > > > http://www.matronics.com/chat > > > > http://www.matronics.com/subscription > > http://www.matronics.com/FAQ/RVSouthEast-List.htm > > http://www.matronics.com/archives > > http://www.matronics.com/photoshare > > http://www.matronics.com/emaillists > > > > > > > > > > > > > > > __________________________________ > > ________________________________________________________________________________
Date: Sep 25, 2004
Was offered a free ticket to Wake-Boston College game last nite. its at noon. thx, but will be going to Greys Creek tomorrow. hope to get together soon since wx is excellent..regards, bill --- "James E. Clark" wrote: > Clark" > > Bill, > > We have lot going on here in Columbia this weekend > but if you fly down and > get there by 12:00 the BBQ is on me. We can do some > formation flying before > or after that. > > I have some things to check out on the plane and > some things to do late > afternoon that will keep me close to home but we > could work something out. > > Whadday think?? > > James > KCUB > > > > -----Original Message----- > > From: owner-rvsoutheast-list-server(at)matronics.com > > > [mailto:owner-rvsoutheast-list-server(at)matronics.com]On > Behalf Of bill > > crothers > > Sent: Friday, September 24, 2004 5:45 PM > > To: rvsoutheast-list(at)matronics.com > > Subject: Re: RVSouthEast-List: DESTINATIONS > > > > > crothers > > > > > > ok, guys...who's going where saturday? bill c. > > --- gtamvakis(at)earthlink.net wrote: > > > > > > > > > > > Dont forget Farmville NC [Flanagan Field N08] > EAA > > > chapter 960, September 25 > > > th, plane rides, lunch, Short wing piper club, > > > experimentals, UL, Vintage. > > > > > > George > > > ----- Original Message ----- > > > From: "Larry Bowen" <Larry(at)bowenaero.com> > > > To: "serv" > > > Subject: RVSouthEast-List: DESTINATIONS > > > > > > > > > Bowen" > > > > > > > > > > > FYI- > > > > > > > > - > > > > Larry Bowen > > > > Larry(at)BowenAero.com > > > > http://BowenAero.com > > > > > > > > ==================== > > > > > > > > FLYING DESTINATIONS IN THE MIDATLANTIC REGION > THIS > > > WEEKEND: > > > > WILSON, NORTH CAROLINA. An EAA Chapter 1047 > Annual > > > Fly-in takes place > > > > September 25 at Wilson Industrial Air Center > > > (W03). Pancake breakfast, > > > > static displays, skydivers, vendors, childen's > > > activities, and plenty > > > > of food. Contact Tom Gregorski, 252/291-8810. > > > > > > > > REIDSVILLE, NORTH CAROLINA. The Third Annual > Air > > > Force Junior ROTC Fly-in > > > > takes place September 25 at Rockingham County > > > Shiloh (78N) from 11 a.m. > > > > to 3 p.m. Featuring a hamburger/hot dog lunch, > > > airplane rides, car cruise > > > > on the field, ROTC displays, World War II > veteran > > > airman display, and > > > > giveaways. Visit the Web site ( > > > http://www.shilohairport.org ). > > > > > > > > CUMBERLAND, MARYLAND. An EAA Chapter 426 > Fly-in > > > Breakfast takes place > > > > September 26 at Greater Cumberland Regional > (CBE) > > > from 7 to 11 a.m. > > > > Contact Harry Dolly, 814/356-3773. > > > > > > > > NEXT WEEKEND: > > > > DARLINGTON, SOUTH CAROLINA. A Fall Fly-in > takes > > > place October 1 > > > > through 3 at Darlington County Jetport (UDG). > > > Fly-in for all aircraft > > > > classes. Barbecue on the field Friday; judging > and > > > a banquet Saturday. > > > > Contact Jim Wilson, 843/753-7138. > > > > > > > > FRANKLIN, NORTH CAROLINA. The Macon County > > > Aviation Celebration takes > > > > place October 2 at Macon County (1A5). The > daylong > > > celebration of > > > > aviation includes vintage aircraft, skydivers, > > > food, and fun for the > > > > entire family. Fly-ins welcome. Contact Tony > > > Angel, 800/336-7829, or > > > > visit the Web site ( > > > http://www.franklin-chamber.com ). > > > > > > > > WINCHESTER, VIRGINIA. An EAA Chapter 186 Fall > > > Fly-in takes place October 2 > > > > and 3 at Winchester Regional (OKV). Fly-in and > > > pancake breakfast, aircraft > > > > judging, Young Eagle flights, and more. > Contact > > > Ms. Tangy Mooney, > > > > 703/361-0294, or visit the Web site ( > > > http://www.eaa186.org ). > > > > > > > > > > > > > > > > > > > > - > > > Contributions > > > any other > > > Forums. > > > > > > http://www.matronics.com/chat > > > > > > http://www.matronics.com/subscription > > > > http://www.matronics.com/FAQ/RVSouthEast-List.htm > > > http://www.matronics.com/archives > > > http://www.matronics.com/photoshare > > > http://www.matronics.com/emaillists > > > > > > > > > > > > > > > > > > > > > > > > __________________________________ > > > > > > > > - > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RVSouthEast-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > === message truncated === _______________________________ Express yourself with Y! Messenger! Free. Download now. ________________________________________________________________________________
Date: Sep 25, 2004
Subject: Re: James - Columbia
what time do we meet at/over Eastover to go to GC? haven't been to Eastover, whats identifier? bill c. --- DAVID DAVENPORT wrote: > DAVENPORT" > > Let me throw my two cents worth in here.... This > picnic that Wayne8 is > talking about is put on by the Cape Fear Aero > Association, and is one of our > most fun events of the year. It is very informal, > just come as you are and > be prepared for good hamburgers and hotdogs. Just > leave a little money in > the kitty for next year. We give rides to any kids > that want to go up, and > then just go up and play as much as we can stand it. > Len, this is a great > excuse to show up as a group formation and show > these guys what a real > arrival looks like. You guys come on down. The > location is Grays Creek, 2GC, > about six miles due south of Fayetteville airport, > FAY. Hope to see > everybody there. If there is a group, we can gather > up over Eastover Air > Ranch and go to 2GC from there. What do you guys > think? > > David Davenport > RV-6 > ----- Original Message ----- > From: <Lenleg(at)aol.com> > To: > Subject: Re: RVSouthEast-List: James - Columbia > > > Lenleg(at)aol.com > > > > > > In a message dated 9/22/04 1:34:00 PM Eastern > Daylight Time, > N184FN(at)aol.com > > writes: > > > > Len, My old fllying club in FAY is having thier > ann cookout at Grays > Creek > > Airport in Fayetteville on Sunday afternoon. (2GC) > The SERV is invited > and > > I > > am planning to go and would like for a bunch of us > to go together if > > possible. > > Whould this be something that you would be > interested in doing? I plan > to > > leave after church. W8. > > > > > > Guys ... exactly the type thing we are looking for > ... > > > > We have several options now: > > > > 1. Fayetteville with Wayne8 > > > > 2. Wadesboro for burgers > > > > My vote is for Fayetteville and support Wayne8 > with lots of RVs !!! > > > > Len > > > > > > > > - > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RVSouthEast-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > __________________________________ ________________________________________________________________________________
Subject: FW: [RV-8] RV 8/8A Empennage Kit for sale
Date: Sep 25, 2004
FYI - This might be the same tail as the 7/7A, not sure. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: David Blackwell [mailto:blackwellsf340(at)hotmail.com] > Sent: Friday, September 24, 2004 10:08 PM > To: RV-8(at)yahoogroups.com > Subject: [RV-8] RV 8/8A Empennage Kit for sale > > Inventoried and rear spar built. Electric trim option and > full plans set Other project forces sale. Located in Advance NC. $1400 > > David Blackwell > 336-940-5912 > > blackwellsf340(at)hotmail.com > > > > > > > > > --------------------~--> > http://us.click.yahoo.com/J8kdrA/y20IAA/yQLSAA/jrDrlB/TM > ------~-> > > > > <*> To visit your group on the web, go to: > http://groups.yahoo.com/group/RV-8/ > > <*> To unsubscribe from this group, send an email to: > RV-8-unsubscribe(at)yahoogroups.com > > http://docs.yahoo.com/info/terms/ > > > > ________________________________________________________________________________
Subject: James - Columbia
Date: Sep 25, 2004
http://www.airnav.com/airport/6NC3 I didn't hear of or don't remember the time........ - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: bill crothers [mailto:bill28104(at)yahoo.com] > Sent: Saturday, September 25, 2004 9:51 AM > To: rvsoutheast-list(at)matronics.com > Subject: Re: RVSouthEast-List: James - Columbia > > --> > > what time do we meet at/over Eastover to go to GC? > haven't been to Eastover, whats identifier? bill c. > --- DAVID DAVENPORT wrote: > > > DAVENPORT" > > > > Let me throw my two cents worth in here.... This picnic > that Wayne8 is > > talking about is put on by the Cape Fear Aero Association, > and is one > > of our most fun events of the year. It is very informal, > just come as > > you are and be prepared for good hamburgers and hotdogs. > Just leave a > > little money in the kitty for next year. We give rides to any kids > > that want to go up, and then just go up and play as much as we can > > stand it. > > Len, this is a great > > excuse to show up as a group formation and show these guys > what a real > > arrival looks like. You guys come on down. The location is Grays > > Creek, 2GC, about six miles due south of Fayetteville airport, FAY. > > Hope to see everybody there. If there is a group, we can gather up > > over Eastover Air Ranch and go to 2GC from there. What do you guys > > think? > > > > David Davenport > > RV-6 > > ----- Original Message ----- > > From: <Lenleg(at)aol.com> > > To: > > Subject: Re: RVSouthEast-List: James - Columbia > > > > > > Lenleg(at)aol.com > > > > > > > > > In a message dated 9/22/04 1:34:00 PM Eastern > > Daylight Time, > > N184FN(at)aol.com > > > writes: > > > > > > Len, My old fllying club in FAY is having thier > > ann cookout at Grays > > Creek > > > Airport in Fayetteville on Sunday afternoon. (2GC) > > The SERV is invited > > and > > > I > > > am planning to go and would like for a bunch of us > > to go together if > > > possible. > > > Whould this be something that you would be > > interested in doing? I plan > > to > > > leave after church. W8. > > > > > > > > > Guys ... exactly the type thing we are looking for > > ... > > > > > > We have several options now: > > > > > > 1. Fayetteville with Wayne8 > > > > > > 2. Wadesboro for burgers > > > > > > My vote is for Fayetteville and support Wayne8 > > with lots of RVs !!! > > > > > > Len > > > > > > > > > > > > > > - > > Contributions > > any other > > Forums. > > > > http://www.matronics.com/chat > > > > http://www.matronics.com/subscription > > http://www.matronics.com/FAQ/RVSouthEast-List.htm > > http://www.matronics.com/archives > > http://www.matronics.com/photoshare > > http://www.matronics.com/emaillists > > > > > > > > > > > > > > > > > __________________________________ > > > ============ > Matronics Forums. > ============ > ============ > ============ > > > > > > ________________________________________________________________________________
Date: Sep 25, 2004
I'll just go straight to GC and be there about noon. look forward to seeing whoever can make it, shud be great day... --- Larry Bowen wrote: > Bowen" > > http://www.airnav.com/airport/6NC3 > > I didn't hear of or don't remember the time........ > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > > > -----Original Message----- > > From: bill crothers [mailto:bill28104(at)yahoo.com] > > Sent: Saturday, September 25, 2004 9:51 AM > > To: rvsoutheast-list(at)matronics.com > > Subject: Re: RVSouthEast-List: James - Columbia > > > crothers > > --> > > > > what time do we meet at/over Eastover to go to GC? > > haven't been to Eastover, whats identifier? bill > c. > > --- DAVID DAVENPORT > wrote: > > > > > DAVENPORT" > > > > > > Let me throw my two cents worth in here.... This > picnic > > that Wayne8 is > > > talking about is put on by the Cape Fear Aero > Association, > > and is one > > > of our most fun events of the year. It is very > informal, > > just come as > > > you are and be prepared for good hamburgers and > hotdogs. > > Just leave a > > > little money in the kitty for next year. We give > rides to any kids > > > that want to go up, and then just go up and play > as much as we can > > > stand it. > > > Len, this is a great > > > excuse to show up as a group formation and show > these guys > > what a real > > > arrival looks like. You guys come on down. The > location is Grays > > > Creek, 2GC, about six miles due south of > Fayetteville airport, FAY. > > > Hope to see everybody there. If there is a > group, we can gather up > > > over Eastover Air Ranch and go to 2GC from > there. What do you guys > > > think? > > > > > > David Davenport > > > RV-6 > > > ----- Original Message ----- > > > From: <Lenleg(at)aol.com> > > > To: > > > Subject: Re: RVSouthEast-List: James - Columbia > > > > > > > > > Lenleg(at)aol.com > > > > > > > > > > > > In a message dated 9/22/04 1:34:00 PM Eastern > > > Daylight Time, > > > N184FN(at)aol.com > > > > writes: > > > > > > > > Len, My old fllying club in FAY is having > thier > > > ann cookout at Grays > > > Creek > > > > Airport in Fayetteville on Sunday afternoon. > (2GC) > > > The SERV is invited > > > and > > > > I > > > > am planning to go and would like for a bunch > of us > > > to go together if > > > > possible. > > > > Whould this be something that you would be > > > interested in doing? I plan > > > to > > > > leave after church. W8. > > > > > > > > > > > > Guys ... exactly the type thing we are looking > for > > > ... > > > > > > > > We have several options now: > > > > > > > > 1. Fayetteville with Wayne8 > > > > > > > > 2. Wadesboro for burgers > > > > > > > > My vote is for Fayetteville and support Wayne8 > > > with lots of RVs !!! > > > > > > > > Len > > > > > > > > > > > > > > > > > > > > - > > > Contributions > > > any other > > > Forums. > > > > > > http://www.matronics.com/chat > > > > > > http://www.matronics.com/subscription > > > > http://www.matronics.com/FAQ/RVSouthEast-List.htm > > > http://www.matronics.com/archives > > > http://www.matronics.com/photoshare > > > http://www.matronics.com/emaillists > > > > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________ > > > > > > ============ > > Matronics Forums. > > ============ > > ============ > > ============ > > > > > > > > > > > > > > > > - > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RVSouthEast-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > === message truncated === __________________________________ ________________________________________________________________________________
Subject: Sunday meeting
Date: Sep 26, 2004
Hey guys, are we still on for 2:00PM at Eastover Airpark to meet up for flying in to Grays Creek? Who's going to be there? David Dvaenport RV-6 N168DD ________________________________________________________________________________
Date: Sep 26, 2004
Bill C. was going straight to GC at noon. Haven't heard from the others.... - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: DAVID DAVENPORT [mailto:ddavenport5(at)nc.rr.com] > Sent: Sunday, September 26, 2004 8:16 AM > To: rvsoutheast-list(at)matronics.com > Subject: RVSouthEast-List: Sunday meeting > > --> > > Hey guys, are we still on for 2:00PM at Eastover Airpark to > meet up for flying in to Grays Creek? Who's going to be there? > > David Dvaenport > RV-6 N168DD > > > ============ > Matronics Forums. > ============ > ============ > ============ > > > > > > ________________________________________________________________________________
Date: Sep 26, 2004
Subject: Re: Sunday meeting
David, I'm coming, but haven't been to Eastover. whats identifier. will they still be having lunch that late at GC? --- DAVID DAVENPORT wrote: > DAVENPORT" > > Hey guys, are we still on for 2:00PM at Eastover > Airpark to meet up for flying in to Grays Creek? > Who's going to be there? > > David Dvaenport > RV-6 N168DD > > > > - > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RVSouthEast-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > _______________________________ Declare Yourself - Register online to vote today! http://vote.yahoo.com ________________________________________________________________________________
Date: Sep 26, 2004
I might make the final appearance of mine - its sold and moving to Boston first week in October. Ed "Ditch" > >Bill C. was going straight to GC at noon. Haven't heard from the others.... > >- >Larry Bowen >Larry(at)BowenAero.com >http://BowenAero.com > > >> -----Original Message----- >> From: DAVID DAVENPORT [mailto:ddavenport5(at)nc.rr.com] >> Sent: Sunday, September 26, 2004 8:16 AM >> To: rvsoutheast-list(at)matronics.com >> Subject: RVSouthEast-List: Sunday meeting >> >> --> >> >> Hey guys, are we still on for 2:00PM at Eastover Airpark to >> meet up for flying in to Grays Creek? Who's going to be there? >> >> David Dvaenport >> RV-6 N168DD >> >> >> ============ >> Matronics Forums. >> ============ >> ============ >> ============ >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Sep 26, 2004
Bill, the ID is 6NC3. We will have plenty of time since they won't start serving the food until around 3-4 PM. See you at Eastover David ----- Original Message ----- From: "bill crothers" <bill28104(at)yahoo.com> Subject: Re: RVSouthEast-List: Sunday meeting > > David, I'm coming, but haven't been to Eastover. > whats identifier. will they still be having lunch > that late at GC? > --- DAVID DAVENPORT wrote: > > > DAVENPORT" > > > > Hey guys, are we still on for 2:00PM at Eastover > > Airpark to meet up for flying in to Grays Creek? > > Who's going to be there? > > > > David Dvaenport > > RV-6 N168DD > > > > > > > > - > > Contributions > > any other > > Forums. > > > > http://www.matronics.com/chat > > > > http://www.matronics.com/subscription > > http://www.matronics.com/FAQ/RVSouthEast-List.htm > > http://www.matronics.com/archives > > http://www.matronics.com/photoshare > > http://www.matronics.com/emaillists > > > > > > > > > > > > > > > _______________________________ > Declare Yourself - Register online to vote today! > http://vote.yahoo.com > > ________________________________________________________________________________
Date: Sep 26, 2004
Sorry i missed you guys...didn't get this message until i got home. ed, mike b. and i waited til 2:30 thinking it was lunch burgers. i left looking at dark low clouds to east. heard you coming in w/ a 3 ship formation when i'm 10 miles west. oh well, there's next time. sure got hungrey waiting...bill c. --- DAVID DAVENPORT wrote: > DAVENPORT" > > Bill, the ID is 6NC3. We will have plenty of time > since they won't start > serving the food until around 3-4 PM. See you at > Eastover > > David > ----- Original Message ----- > From: "bill crothers" <bill28104(at)yahoo.com> > To: > Subject: Re: RVSouthEast-List: Sunday meeting > > > crothers > > > > > David, I'm coming, but haven't been to Eastover. > > whats identifier. will they still be having lunch > > that late at GC? > > --- DAVID DAVENPORT > wrote: > > > > > DAVENPORT" > > > > > > Hey guys, are we still on for 2:00PM at Eastover > > > Airpark to meet up for flying in to Grays Creek? > > > Who's going to be there? > > > > > > David Dvaenport > > > RV-6 N168DD > > > > > > > > > > > > - > > > Contributions > > > any other > > > Forums. > > > > > > http://www.matronics.com/chat > > > > > > http://www.matronics.com/subscription > > > > http://www.matronics.com/FAQ/RVSouthEast-List.htm > > > http://www.matronics.com/archives > > > http://www.matronics.com/photoshare > > > http://www.matronics.com/emaillists > > > > > > > > > > > > > > > > > > > > > > > > _______________________________ > > Declare Yourself - Register online to vote today! > > http://vote.yahoo.com > > > > > > > > - > Contributions > any other > Forums. > > http://www.matronics.com/chat > > http://www.matronics.com/subscription > http://www.matronics.com/FAQ/RVSouthEast-List.htm > http://www.matronics.com/archives > http://www.matronics.com/photoshare > http://www.matronics.com/emaillists > > > > > > _______________________________ Declare Yourself - Register online to vote today! http://vote.yahoo.com ________________________________________________________________________________
Date: Sep 26, 2004
How about a meeting in my basement where all of you experienced builders can help me finish riveting my wing skins on? I thought some of you -3, -4, & -6 builders might be interested in the inter workings of an RV-9 wing. Bill R. Huntersville, NC www.repucci.com/bill/baf.html -----Original Message----- From: owner-rvsoutheast-list-server(at)matronics.com [mailto:owner-rvsoutheast-list-server(at)matronics.com] On Behalf Of DAVID DAVENPORT Subject: RVSouthEast-List: Sunday meeting --> Hey guys, are we still on for 2:00PM at Eastover Airpark to meet up for flying in to Grays Creek? Who's going to be there? David Dvaenport RV-6 N168DD == direct advertising on the Matronics Forums. == == == ________________________________________________________________________________
Date: Sep 26, 2004
Sure. Date? Time? Directions? - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Bill Repucci [mailto:bill(at)repucci.com] > Sent: Sunday, September 26, 2004 7:29 PM > To: rvsoutheast-list(at)matronics.com > Subject: RE: RVSouthEast-List: Sunday meeting > > --> > > How about a meeting in my basement where all of you > experienced builders can help me finish riveting my wing skins on? > > I thought some of you -3, -4, & -6 builders might be > interested in the inter workings of an RV-9 wing. > > Bill R. > Huntersville, NC > www.repucci.com/bill/baf.html > > -----Original Message----- > From: owner-rvsoutheast-list-server(at)matronics.com > [mailto:owner-rvsoutheast-list-server(at)matronics.com] On > Behalf Of DAVID DAVENPORT > To: rvsoutheast-list(at)matronics.com > Subject: RVSouthEast-List: Sunday meeting > > > --> > > Hey guys, are we still on for 2:00PM at Eastover Airpark to > meet up for flying in to Grays Creek? Who's going to be there? > > David Dvaenport > RV-6 N168DD > > > == > direct advertising on the Matronics Forums. > == > == > == > > > ============ > Matronics Forums. > ============ > ============ > ============ > > > > > > ________________________________________________________________________________
Date: Sep 26, 2004
Bill if you need a hand riveting call my office 704-987-0191 Tad Sargent 7A "Bill Repucci" wrote: > >How about a meeting in my basement where all of you experienced builders >can help me finish riveting my wing skins on? > >I thought some of you -3, -4, & -6 builders might be interested in the >inter workings of an RV-9 wing. > >Bill R. >Huntersville, NC >www.repucci.com/bill/baf.html > >-----Original Message----- >From: owner-rvsoutheast-list-server(at)matronics.com >[mailto:owner-rvsoutheast-list-server(at)matronics.com] On Behalf Of DAVID >DAVENPORT >To: rvsoutheast-list(at)matronics.com >Subject: RVSouthEast-List: Sunday meeting > > >--> > >Hey guys, are we still on for 2:00PM at Eastover Airpark to meet up for >flying in to Grays Creek? Who's going to be there? > >David Dvaenport >RV-6 N168DD > > >== >direct advertising on the Matronics Forums. >== >== >== > > ________________________________________________________________________________
Date: Sep 26, 2004
Tad, Thanks for the offer, I'll give you a call. The real problem is my new job has me working in Raleigh all week, which leaves very little time for me to spend with my new bride. Bill -----Original Message----- From: owner-rvsoutheast-list-server(at)matronics.com [mailto:owner-rvsoutheast-list-server(at)matronics.com] On Behalf Of Sargentclt(at)cs.com Subject: RE: RVSouthEast-List: Sunday meeting Bill if you need a hand riveting call my office 704-987-0191 Tad Sargent 7A "Bill Repucci" wrote: >--> > >How about a meeting in my basement where all of you experienced >builders can help me finish riveting my wing skins on? > >I thought some of you -3, -4, & -6 builders might be interested in the >inter workings of an RV-9 wing. > >Bill R. >Huntersville, NC >www.repucci.com/bill/baf.html > >-----Original Message----- >From: owner-rvsoutheast-list-server(at)matronics.com >[mailto:owner-rvsoutheast-list-server(at)matronics.com] On Behalf Of DAVID >DAVENPORT >To: rvsoutheast-list(at)matronics.com >Subject: RVSouthEast-List: Sunday meeting > > >--> > >Hey guys, are we still on for 2:00PM at Eastover Airpark to meet up for >flying in to Grays Creek? Who's going to be there? > >David Dvaenport >RV-6 N168DD > > >== >direct advertising on the Matronics Forums. >== >== >== > > == direct advertising on the Matronics Forums. == == == ________________________________________________________________________________
Date: Sep 27, 2004
In a message dated 9/24/04 5:57:56 PM Eastern Daylight Time, dwmillsap(at)hyperlogic.net writes: Thanks for the reminder...Dennis's RV-6A will be there, but he doesn't get back from Colorado's hunting trip until 5pm tomorrow afternoon, so the girls and I will be standing guard. Y'all come see us! Hey, Len, what football game will you be coming to soon? We are looking forward to meeting you in person. Lori Sorry Lori .... I did not check email all weekend ... I was at the game on Saturday against Cincinnati. We tailgate in spot # 259 behind Minges Colesium in what is called "lower parking". Please come by the next home game .... Len ________________________________________________________________________________
Date: Sep 27, 2004
In a message dated 9/25/04 8:21:04 AM Eastern Daylight Time, bill28104(at)yahoo.com writes: Was offered a free ticket to Wake-Boston College game last nite. its at noon. thx, but will be going to Greys Creek tomorrow. hope to get together soon since wx is excellent..regards, bill Bill: Mike Barbee said we just missed you at Greys Creek ... Dave, John, and I arrived right after you. We got held up at Eastover but finally got over to Greys Creek around 2:00pm or a little after. Sorry we missed you. Len Leggette, RV-8A Greensboro, N.C. N910LL 276 hrs ________________________________________________________________________________
Date: Sep 27, 2004
Subject: Fwd: Reminder - EAA Chapter Fly-in Winchester, VA
In a message dated 9/25/04 8:03:12 AM Eastern Daylight Time, Mid-AtlRVwing(at)yahoogroups.com writes: We would like to remind you of this upcoming event. EAA Chapter Fly-in Winchester, VA Date: Saturday, October 2, 2004 Displays, judging, fly-bye's, Breakfast, Lunch From: Mid-AtlRVwing(at)yahoogroups.com List-Unsubscribe: Date: 25 Sep 2004 12:02:37 -0000 Subject: [Mid-AtlRVwing] Reminder - EAA Chapter Fly-in Winchester, VA Click Here! We would like to remind you of this upcoming event. EAA Chapter Fly-in Winchester, VA Date: Saturday, October 2, 2004 Displays, judging, fly-bye's, Breakfast, Lunch <*> To visit your group on the web, go to: http://groups.yahoo.com/group/Mid-AtlRVwing/ <*> To unsubscribe from this group, send an email to: Mid-AtlRVwing-unsubscribe(at)yahoogroups.com http://docs.yahoo.com/info/terms/ ________________________________________________________________________________
Date: Sep 27, 2004
In a message dated 9/26/04 11:16:47 PM Eastern Daylight Time, bill(at)repucci.com writes: Thanks for the offer, I'll give you a call. The real problem is my new job has me working in Raleigh all week, which leaves very little time for me to spend with my new bride. Bill Bill: You have really set yourself up for this one ... I just can't resist .... I don't know how much help I can be on the plane but maybe I can help with your other problem !!!! JUST KIDDING !!!! Len Leggette, RV-8A Greensboro, N.C. N910LL 276 hrs ________________________________________________________________________________
Date: Sep 28, 2004
Subject: Goldsboro Members
Mike Barbee: I have four names on the Van's Builders list for Goldsboro. I don't know which is the nice young couple based there but they would be wonderful to get to your fly-in ... you might want to try to write all four of these and see which one it is. William Savage 111 Windyfield Dr Goldsboro, NC 27530 Christopher Mallory 110 Planters Place Goldsboro, NC 27530 Patrick Pence 611 E. Beech St. Goldsboro, NC 27530 Darrell Ham 204 Benton St. Goldsboro, NC 27530 Good luck !! Len ________________________________________________________________________________
Date: Sep 28, 2004
Subject: Greys Creek Fly In
SERV: A little recap for those of you that did not make the Greys Creek Fly In. Wayne8 and I departed Greensboro around 1:00pm to meet up with Dave Davenport and John Wilson at Eastover Airpark just north of Fayetteville for the short flight over to Greys Creek. As Wayne8 and I arrived Dave and John were on the ground already judging our approaches and landings !!! We laid out our plans for a flight of three ... yes Wayne8 decided not to make the trip over with us for reasons only he will be able to give ..... John led us over and into trail for a low pass down the runway .... love my RV !!! We circled to land on 25 (which is very narrow !!) and back taxi . There were probably 30 or so planes on the ground including a few SERV members, Ed Regensburg, Mike Barbee, and Bill Carothers had just departed. There was one other recently completed RV-6A without paint that I saw takeoff but did not get the opportunity to say hello ... might be Robert from Fayetteville ????? Loved the atmoshpere at Greys Creek .. a small country airport ... with lots of nice people. Mike Barbee probably had the most fun ... he flew in with a friend that recently purchased the Giles 202 with the awesome paint job that was featured in Sport Aviation about 6 months ago ... Primal Fear ... or something like that. He let me touch the controls and I am not sure I could fly the darn thing ... those controls are unbelievable .. extremely smooth and I am sure it does not take much to move the plane !!! Mike said they flew togther and his friend would just turn it inverted and fly along with them !!! It was a lot of fun ... hope more of you will make it next time !!! Anyone going to Winchester ... Darlington ... etc this weekend? Len ________________________________________________________________________________
Date: Sep 28, 2004
Subject: Fwd: Hurricane
In a message dated 9/28/04 9:51:32 AM Eastern Daylight Time, pat_hatch(at)msn.com writes: Hi Len, Well the RV-4 got finished off...after Frances it was pinned under the roof trusses but did not have major damage. Now it is burried under the concrete block wall that collapsed on top of it. I'll send you pictures as soon as I can. Insurance has already agreed that it is now totalled so I'll get full value. Home is OK. We are headed back there today from Orlando where we have been staying in a hotel. The rental hangar I was in got blown down, so I sustained even more damage to all my hangar stuff. The good news is the the -6 and -7 are fine. I had flown them down to a safe hangar in Ft. Pierce. We are already making plans to build a new, modern, hurricane-proof hangar! I'll fill in all the details when we get settled back home. But right now we are going back to no power, water or sewer. We have a generator so that will help. Hope to have electricity back in a few days. Later, Pat From: "Fletcher Hatch" <pat_hatch(at)msn.com> Subject: RE: Hurricane Date: Tue, 28 Sep 2004 12:50:21 +0000 Hi Len, Well the RV-4 got finished off...after Frances it was pinned under the roof trusses but did not have major damage. Now it is burried under the concrete block wall that collapsed on top of it. I'll send you pictures as soon as I can. Insurance has already agreed that it is now totalled so I'll get full value. Home is OK. We are headed back there today from Orlando where we have been staying in a hotel. The rental hangar I was in got blown down, so I sustained even more damage to all my hangar stuff. The good news is the the -6 and -7 are fine. I had flown them down to a safe hangar in Ft. Pierce. We are already making plans to build a new, modern, hurricane-proof hangar! I'll fill in all the details when we get settled back home. But right now we are going back to no power, water or sewer. We have a generator so that will help. Hope to have electricity back in a few days. Later, Pat >From: Lenleg(at)aol.com >To: pat_hatch(at)msn.com >Subject: Hurricane >Date: Tue, 28 Sep 2004 07:51:20 EDT > >Pat: > >I hate to even be sending this email but ... how did you make out this >time? > > >Len Leggette, RV-8A >Greensboro, N.C. N910LL >276 hrs > > ________________________________________________________________________________
Date: Sep 28, 2004
Subject: Re: Goldsboro Members
Thanks,Len Mike ________________________________________________________________________________
Date: Sep 29, 2004
Subject: Re: Greys Creek Fly In
Hi Len, Sounds like Greys Creek was lots of fun. I plan on making it to Winchester or Darlington this weedend either Saturday or Sunday. Winchester on Saturday is my preference but would be open to either. Just got my new "Southeast RV Spuadron" hat and shirts in the mail this week. They look great and I'm ready to wear them! Ron Archer N247AR RV-6 IPJ ________________________________________________________________________________
Subject: SERFI
Date: Sep 28, 2004
Any of you folks planning on going to SERF this weekend? Ed Rv-6A N494BW Rotary Powered Matthews, NC ________________________________________________________________________________
Subject: Never To Old!
Date: Sep 29, 2004
That's A Little Too Close Airman Forced To Land After Close Encounter With Presidential TFR The pilot of a small aircraft was forced to land Wednesday, after his aircraft got just a little too close to President Bush, who was on a campaign swing through King Of Prussia and the western part of the Keystone State. WPVI-TV reports the 84-year old pilot from New Jersey and his passenger were up for one of those $50 cups of coffee when they were intercepted. They were forced to land at Pottstown-Limerick Airport and questioned by both the FBI and Secret Service. "He was in the wrong place at the wrong time," said airport operations manager Chris Jordan. "The gentleman was just going for a cup of coffee in Chester County and didn't quite make it." There were conflicting reports of just who forced the elderly pilot down -- a state police helicopter or USAF F-15 jets. WPVI reported the jet crews fired flares to get the civilian's attention before escorting him to Pottstown-Limerick. After more than three hours of questioning, the pilot and his passenger were allowed to go free. There was no immediate indication on whether the pilot, whose name wasn't released, would be charged with violating restricted airspace. Watch our for those TFR's. Steve Glasgow 704-362-0005 704-281-7884 ________________________________________________________________________________
Date: Sep 29, 2004
If you're looking for opinions for Saturday, Darlington has more antique & classic planes, whereas Winchester is pretty much "across the board". Being an old plane buff, I would prefer Darlington Saturday, but I'm like Ron, I'll go either way. Somebody make it a tie-breaker. Len, your levels of decorum concering last Sunday are amazing. Someone owes you some big hush money. David N168DD ----- Original Message ----- From: <rlarv6(at)juno.com> Subject: Re: RVSouthEast-List: Greys Creek Fly In > > > Hi Len, > Sounds like Greys Creek was lots of fun. I plan on making it to Winchester or Darlington this weedend either Saturday or Sunday. Winchester on Saturday is my preference but would be open to either. Just got my new "Southeast RV Spuadron" hat and shirts in the mail this week. They look great and I'm ready to wear them! > > Ron Archer > N247AR > RV-6 IPJ > > ________________________________________________________________________________
Subject: SERFI
Date: Sep 29, 2004
I can't, but in case others are on the fence, here is more info: http://www.serfi.org/ - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Ed Anderson [mailto:eanderson(at)carolina.rr.com] > Sent: Tuesday, September 28, 2004 2:28 PM > To: rvsoutheast-list(at)matronics.com > Subject: RVSouthEast-List: SERFI > > --> > > Any of you folks planning on going to SERF this weekend? > > Ed > > Rv-6A N494BW Rotary Powered > Matthews, NC > > > ============ > Matronics Forums. > ============ > ============ > ============ > > > > > > ________________________________________________________________________________
Subject: SERFI
Date: Sep 29, 2004
Two RV's out of Columbia plan to make the trip (early Saturday morning). You headed down Ed? James > -----Original Message----- > From: owner-rvsoutheast-list-server(at)matronics.com > [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of Larry > Bowen > Sent: Wednesday, September 29, 2004 7:09 PM > To: rvsoutheast-list(at)matronics.com > Subject: RE: RVSouthEast-List: SERFI > > > > > I can't, but in case others are on the fence, here is more info: > > http://www.serfi.org/ > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > > > -----Original Message----- > > From: Ed Anderson [mailto:eanderson(at)carolina.rr.com] > > Sent: Tuesday, September 28, 2004 2:28 PM > > To: rvsoutheast-list(at)matronics.com > > Subject: RVSouthEast-List: SERFI > > > > --> > > > > Any of you folks planning on going to SERF this weekend? > > > > Ed > > > > Rv-6A N494BW Rotary Powered > > Matthews, NC > > > > > > ============ > > Matronics Forums. > > ============ > > ============ > > ============ > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: SERFI
Date: Sep 29, 2004
Yes, James, I plan to head out tomorrow morning (Friday). Are you one of the two RVs headed down from Columbia? Ed ----- Original Message ----- From: "James E. Clark" <james(at)nextupventures.com> Subject: RE: RVSouthEast-List: SERFI > > Two RV's out of Columbia plan to make the trip (early Saturday morning). > > You headed down Ed? > > James > > > > -----Original Message----- > > From: owner-rvsoutheast-list-server(at)matronics.com > > [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of Larry > > Bowen > > Sent: Wednesday, September 29, 2004 7:09 PM > > To: rvsoutheast-list(at)matronics.com > > Subject: RE: RVSouthEast-List: SERFI > > > > > > > > > > I can't, but in case others are on the fence, here is more info: > > > > http://www.serfi.org/ > > > > - > > Larry Bowen > > Larry(at)BowenAero.com > > http://BowenAero.com > > > > > > > -----Original Message----- > > > From: Ed Anderson [mailto:eanderson(at)carolina.rr.com] > > > Sent: Tuesday, September 28, 2004 2:28 PM > > > To: rvsoutheast-list(at)matronics.com > > > Subject: RVSouthEast-List: SERFI > > > > > > --> > > > > > > Any of you folks planning on going to SERF this weekend? > > > > > > Ed > > > > > > Rv-6A N494BW Rotary Powered > > > Matthews, NC > > > > > > > > > ============ > > > Matronics Forums. > > > ============ > > > ============ > > > ============ > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: SERFI
Date: Sep 30, 2004
Yes, Ken (+ a passenger) along with Patty and I are coming in our two RVs. James > -----Original Message----- > From: owner-rvsoutheast-list-server(at)matronics.com > [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of Ed > Anderson > Sent: Wednesday, September 29, 2004 9:37 AM > To: rvsoutheast-list(at)matronics.com > Subject: Re: RVSouthEast-List: SERFI > > > > > Yes, James, I plan to head out tomorrow morning (Friday). Are you one of > the two RVs headed down from Columbia? > > Ed > ----- Original Message ----- > From: "James E. Clark" <james(at)nextupventures.com> > To: > Subject: RE: RVSouthEast-List: SERFI > > > > > > > Two RV's out of Columbia plan to make the trip (early Saturday morning). > > > > You headed down Ed? > > > > James > > > > > > > -----Original Message----- > > > From: owner-rvsoutheast-list-server(at)matronics.com > > > [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of Larry > > > Bowen > > > Sent: Wednesday, September 29, 2004 7:09 PM > > > To: rvsoutheast-list(at)matronics.com > > > Subject: RE: RVSouthEast-List: SERFI > > > > > > > > > > > > > > > I can't, but in case others are on the fence, here is more info: > > > > > > http://www.serfi.org/ > > > > > > - > > > Larry Bowen > > > Larry(at)BowenAero.com > > > http://BowenAero.com > > > > > > > > > > -----Original Message----- > > > > From: Ed Anderson [mailto:eanderson(at)carolina.rr.com] > > > > Sent: Tuesday, September 28, 2004 2:28 PM > > > > To: rvsoutheast-list(at)matronics.com > > > > Subject: RVSouthEast-List: SERFI > > > > > > > > --> > > > > > > > > Any of you folks planning on going to SERF this weekend? > > > > > > > > Ed > > > > > > > > Rv-6A N494BW Rotary Powered > > > > Matthews, NC > > > > > > > > > > > > ============ > > > > Matronics Forums. > > > > ============ > > > > ============ > > > > ============ > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 30, 2004
Subject: Darlington (UDG) Saturday?
Guys: I vote for Darlington on Saturday !! I would prefer to go early in the morning ... I will not plan to stay all day ... make a morning out of it !! Anyone want to meet somewhere along the way? Len Leggette, RV-8A Greensboro, N.C. N910LL 276 hrs ________________________________________________________________________________
Subject: Re: SERFI
Date: Sep 29, 2004
Ok, look forward to seeing everyone there at SERFI Ed ----- Original Message ----- From: "James E. Clark" <james(at)nextupventures.com> Subject: RE: RVSouthEast-List: SERFI > > Yes, > > Ken (+ a passenger) along with Patty and I are coming in our two RVs. > > James > > > > -----Original Message----- > > From: owner-rvsoutheast-list-server(at)matronics.com > > [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of Ed > > Anderson > > Sent: Wednesday, September 29, 2004 9:37 AM > > To: rvsoutheast-list(at)matronics.com > > Subject: Re: RVSouthEast-List: SERFI > > > > > > > > > > Yes, James, I plan to head out tomorrow morning (Friday). Are you one of > > the two RVs headed down from Columbia? > > > > Ed > > ----- Original Message ----- > > From: "James E. Clark" <james(at)nextupventures.com> > > To: > > Subject: RE: RVSouthEast-List: SERFI > > > > > > > > > > > > Two RV's out of Columbia plan to make the trip (early Saturday morning). > > > > > > You headed down Ed? > > > > > > James > > > > > > > > > > -----Original Message----- > > > > From: owner-rvsoutheast-list-server(at)matronics.com > > > > [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of Larry > > > > Bowen > > > > Sent: Wednesday, September 29, 2004 7:09 PM > > > > To: rvsoutheast-list(at)matronics.com > > > > Subject: RE: RVSouthEast-List: SERFI > > > > > > > > > > > > > > > > > > > > I can't, but in case others are on the fence, here is more info: > > > > > > > > http://www.serfi.org/ > > > > > > > > - > > > > Larry Bowen > > > > Larry(at)BowenAero.com > > > > http://BowenAero.com > > > > > > > > > > > > > -----Original Message----- > > > > > From: Ed Anderson [mailto:eanderson(at)carolina.rr.com] > > > > > Sent: Tuesday, September 28, 2004 2:28 PM > > > > > To: rvsoutheast-list(at)matronics.com > > > > > Subject: RVSouthEast-List: SERFI > > > > > > > > > > --> > > > > > > > > > > Any of you folks planning on going to SERF this weekend? > > > > > > > > > > Ed > > > > > > > > > > Rv-6A N494BW Rotary Powered > > > > > Matthews, NC > > > > > > > > > > > > > > > ============ > > > > > Matronics Forums. > > > > > ============ > > > > > ============ > > > > > ============ > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Darlington (UDG) Saturday?
Date: Sep 30, 2004
Len, how does 45J, Rockingham sound for a meeting place? What time would you have in mind? David ----- Original Message ----- From: <Lenleg(at)aol.com> Subject: RVSouthEast-List: Darlington (UDG) Saturday? > > Guys: > > I vote for Darlington on Saturday !! I would prefer to go early in the > morning ... I will not plan to stay all day ... make a morning out of it !! > > Anyone want to meet somewhere along the way? > > Len Leggette, RV-8A > Greensboro, N.C. N910LL > 276 hrs > > ________________________________________________________________________________
Date: Oct 01, 2004
In a message dated 9/30/04 8:41:21 PM Eastern Daylight Time, ddavenport5(at)nc.rr.com writes: Len, how does 45J, Rockingham sound for a meeting place? What time would you have in mind? David I am pretty open for time .. I just have to get home to get some yard work done ... anytime early in the morning is great ... ??????? Len ________________________________________________________________________________
Date: Oct 01, 2004
Len, how does 9:30 at 45J sound? By the way, I need to do yard work as well, so we are on the same sheet of music here. David ----- Original Message ----- From: <Lenleg(at)aol.com> Subject: Re: RVSouthEast-List: Darlington (UDG) Saturday? > > > In a message dated 9/30/04 8:41:21 PM Eastern Daylight Time, > ddavenport5(at)nc.rr.com writes: > > Len, how does 45J, Rockingham sound for a meeting place? What time would you > have in mind? > > David > > > I am pretty open for time .. I just have to get home to get some yard work > done ... anytime early in the morning is great ... ??????? > > Len > > ________________________________________________________________________________
Date: Oct 01, 2004
In a message dated 10/1/2004 8:30:24 PM Eastern Daylight Time, ddavenport5(at)nc.rr.com writes: Len, how does 9:30 at 45J sound? By the way, I need to do yard work as well, so we are on the same sheet of music here. David That sounds great ... hope the weather allows ... we have had fog all day and they are calling for light rain, fog, and mostly cloudy all morning. Len ________________________________________________________________________________
Date: Oct 01, 2004
I'll call you in the morning, and we''ll tackle the weather question then. Talk to you in the morning. David ----- Original Message ----- From: <Lenleg(at)aol.com> Subject: Re: RVSouthEast-List: Darlington (UDG) Saturday? > > > In a message dated 10/1/2004 8:30:24 PM Eastern Daylight Time, > ddavenport5(at)nc.rr.com writes: > > > Len, how does 9:30 at 45J sound? By the way, I need to do yard work as well, > so we are on the same sheet of music here. > > David > > > That sounds great ... hope the weather allows ... we have had fog all day > and they are calling for light rain, fog, and mostly cloudy all morning. > > Len > > ________________________________________________________________________________
Date: Oct 02, 2004
Looks like the Columbia Crew might be going to Darlington instead of SERFI (weather). Hope to see some of the SERV gang there (Darlington). James > -----Original Message----- > From: owner-rvsoutheast-list-server(at)matronics.com > [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of DAVID > DAVENPORT > Sent: Friday, October 01, 2004 11:01 PM > To: rvsoutheast-list(at)matronics.com > Subject: Re: RVSouthEast-List: Darlington (UDG) Saturday? > > > > > I'll call you in the morning, and we''ll tackle the weather question then. > Talk to you in the morning. > > David > ----- Original Message ----- > From: <Lenleg(at)aol.com> > To: > Subject: Re: RVSouthEast-List: Darlington (UDG) Saturday? > > > > > > > > In a message dated 10/1/2004 8:30:24 PM Eastern Daylight Time, > > ddavenport5(at)nc.rr.com writes: > > > > > > Len, how does 9:30 at 45J sound? By the way, I need to do yard work as > well, > > so we are on the same sheet of music here. > > > > David > > > > > > That sounds great ... hope the weather allows ... we have had > fog all day > > and they are calling for light rain, fog, and mostly cloudy all morning. > > > > Len > > > > > > ________________________________________________________________________________
Date: Oct 01, 2004
Does not look like I will be going to either, ceiling down to 200 (or less), fog and less than 1/4 mile visibility again today. Ed Anderson ----- Original Message ----- From: "James E. Clark" <james(at)nextupventures.com> Subject: RE: RVSouthEast-List: Darlington (UDG) Saturday? > > Looks like the Columbia Crew might be going to Darlington instead of SERFI > (weather). > > Hope to see some of the SERV gang there (Darlington). > > James > > > > -----Original Message----- > > From: owner-rvsoutheast-list-server(at)matronics.com > > [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of DAVID > > DAVENPORT > > Sent: Friday, October 01, 2004 11:01 PM > > To: rvsoutheast-list(at)matronics.com > > Subject: Re: RVSouthEast-List: Darlington (UDG) Saturday? > > > > > > > > > > I'll call you in the morning, and we''ll tackle the weather question then. > > Talk to you in the morning. > > > > David > > ----- Original Message ----- > > From: <Lenleg(at)aol.com> > > To: > > Subject: Re: RVSouthEast-List: Darlington (UDG) Saturday? > > > > > > > > > > > > > In a message dated 10/1/2004 8:30:24 PM Eastern Daylight Time, > > > ddavenport5(at)nc.rr.com writes: > > > > > > > > > Len, how does 9:30 at 45J sound? By the way, I need to do yard work as > > well, > > > so we are on the same sheet of music here. > > > > > > David > > > > > > > > > That sounds great ... hope the weather allows ... we have had > > fog all day > > > and they are calling for light rain, fog, and mostly cloudy all morning. > > > > > > Len > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 02, 2004
Understood Ed. We did not get a chance to leave Columbia until after 1 PM (almost 2 PM) due to the same weather. Flew down as a flight of THREE RVs. After we got there it RAINED! After the rain passed, we decided we had best make it back to Columbia. As we were taxiing out 2 RVs from NC flew in, saw us leaving and did a low pass. One of them was the yellow and white "Songbird". There were at least two other RV6's there and an RV8. Not bad for an "Antique and Classic Fly-in". I expect there will be a LOT more next year of the weather is good. Hope to see ya in Columbia again one of these days. James > -----Original Message----- > From: owner-rvsoutheast-list-server(at)matronics.com > [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of Ed > Anderson > Sent: Friday, October 01, 2004 10:05 AM > To: rvsoutheast-list(at)matronics.com > Subject: Re: RVSouthEast-List: Darlington (UDG) Saturday? > > > > > Does not look like I will be going to either, ceiling down to 200 > (or less), > fog and less than 1/4 mile visibility again today. > > Ed Anderson > > ----- Original Message ----- > From: "James E. Clark" <james(at)nextupventures.com> > To: > Subject: RE: RVSouthEast-List: Darlington (UDG) Saturday? > > > > > > > Looks like the Columbia Crew might be going to Darlington > instead of SERFI > > (weather). > > > > Hope to see some of the SERV gang there (Darlington). > > > > James > > > > > > > -----Original Message----- > > > From: owner-rvsoutheast-list-server(at)matronics.com > > > [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of DAVID > > > DAVENPORT > > > Sent: Friday, October 01, 2004 11:01 PM > > > To: rvsoutheast-list(at)matronics.com > > > Subject: Re: RVSouthEast-List: Darlington (UDG) Saturday? > > > > > > > > > > > > > > > I'll call you in the morning, and we''ll tackle the weather question > then. > > > Talk to you in the morning. > > > > > > David > > > ----- Original Message ----- > > > From: <Lenleg(at)aol.com> > > > To: > > > Subject: Re: RVSouthEast-List: Darlington (UDG) Saturday? > > > > > > > > > > > > > > > > > > In a message dated 10/1/2004 8:30:24 PM Eastern Daylight Time, > > > > ddavenport5(at)nc.rr.com writes: > > > > > > > > > > > > Len, how does 9:30 at 45J sound? By the way, I need to do yard work > as > > > well, > > > > so we are on the same sheet of music here. > > > > > > > > David > > > > > > > > > > > > That sounds great ... hope the weather allows ... we have had > > > fog all day > > > > and they are calling for light rain, fog, and mostly cloudy all > morning. > > > > > > > > Len > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 02, 2004
In a message dated 10/2/2004 8:52:40 PM Eastern Daylight Time, james(at)nextupventures.com writes: There were at least two other RV6's there and an RV8. Not bad for an "Antique and Classic Fly-in". I expect there will be a LOT more next year of the weather is good. Sounds like Mike Barbee. Len ________________________________________________________________________________
Subject: Home movies
Date: Oct 03, 2004
Lousy wx means more time wasted in front of the computer. Check out the video of my second flight on my website. Still working on the first flight video.... - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Oct 03, 2004
Awesome!! It's nice to hear all the details, like speed callouts etc.. But weird to hear myself on the radio :) Keep 'em coming. Radomir -----Original Message----- Subject: RVSouthEast-List: Home movies Lousy wx means more time wasted in front of the computer. Check out the video of my second flight on my website. Still working on the first flight video.... ________________________________________________________________________________
Date: Oct 03, 2004
Yes, That was Ben & Mike ________________________________________________________________________________
Subject: aileron bellcrank
Date: Oct 04, 2004
Hey guys, I'm installing the aileron bellcrank, and was wondering about the brass bushing that goes through. It's now sticking out, by about 1/32" on each side. When installed, that allows the bellcrank to actually move up/down a little bit. Is that OK? Also, the nut is barely on the bolt in that situation.. I'd say 1-2 threads are showing (hard to say due to the locking plastic being there).I guess it goes a bit deeper, if we don't count that plastic. Does this sound right? Is bellcrank supposed to move even slightly between the brackets? Thanks! Radomir ________________________________________________________________________________
Date: Oct 04, 2004
Sounds just right. The brass should be whats compressed between the other parts, allowing the bellcrank to spin freely (and go up/down a little). If you aren't happy with the threads showing on the bolt, try a thin washer. If you don't have these already, buy 100. You'll use 'em later. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Radomir Zaric [mailto:vitez(at)carolina.rr.com] > Sent: Monday, October 04, 2004 10:16 PM > To: rvsoutheast-list(at)matronics.com > Subject: RVSouthEast-List: aileron bellcrank > > --> > > Hey guys, > > > I'm installing the aileron bellcrank, and was wondering about > the brass bushing that goes through. It's now sticking out, > by about 1/32" on each side. When installed, that allows the > bellcrank to actually move up/down a little bit. Is that OK? > > > Also, the nut is barely on the bolt in that situation.. I'd > say 1-2 threads are showing (hard to say due to the locking > plastic being there).I guess it goes a bit deeper, if we > don't count that plastic. > > > Does this sound right? Is bellcrank supposed to move even > slightly between the brackets? > > > Thanks! > > Radomir > > > ============ > Matronics Forums. > ============ > ============ > ============ > > > > > > ________________________________________________________________________________
Subject: Stomy's
Date: Oct 05, 2004
OK I finally have a weekend off and I'm planning on going to Stormy's. How about some info on time, rwy, L/L, etc. Come in Stormy! By the way my shoulder is sore so don't count on any lumberjack stuff. Steve Glasgow 704-362-0005 704-281-7884 ________________________________________________________________________________
Date: Oct 05, 2004
Subject: Re: Stomy's
Timely inquiry, Steve, as I was just about to post a question to gauge the general interest level... I'm still planning onthe get-together Saturday. Wx prog looks good. Fall colors are just beginning, but promising. No lumberjacking will be expected of guests- that was a joke. I am serious about grilling some shrimp as well as tube-steaks, but need a head count to help with that. RWY info is best had from AirNav.com under airport identifier 12VA. We'll monitor 122.85 on the handie-talkie for a Unicom of sorts. Aiming for an afternoon start time of about 3pm and winding down by 6 to give everyone a chance to get home (dark is about 7 by now). We'll supply food and drinks; no need for anyone to bring anything thing time unless they just want to. Covered dish contributions will not be turned away :-) Len- check with Larry Small to see if he can make it. "Rain date" of the following Saturday would be fine with me, as would Sunday the 10th. I'd be glad to move the event in case of weather or low anticipated turnout; it's a "group call" as far as I am concerned. -Stormy ________________________________________________________________________________
Date: Oct 05, 2004
In a message dated 10/5/04 12:33:48 PM Eastern Daylight Time, SportAV8R(at)aol.com writes: "Rain date" of the following Saturday would be fine with me, as would Sunday the 10th. I'd be glad to move the event in case of weather or low anticipated turnout; it's a "group call" as far as I am concerned. -Stormy It is very doubtful that I will be able to attend as we start the Furniture Market first thing Sunday morning. If I get a break I may try to do a quick up and back ... just have to see how the week goes and how the morning on Saturday goes. Len ________________________________________________________________________________
Date: Oct 05, 2004
Subject: Pace Anual Pigpicking
I was up at Pace today and Tommy's son Ben asked me to invite the RV group . Serving starts at 2PM , Saturday the 9th. If the date changes for the RV get=together this would be a good place to go. ________________________________________________________________________________
Date: Oct 05, 2004
Subject: incedence angle
Has anybody had to change the incedence angle? I have to use too much nose down trim to maintain level flight. The elevator is in trail with the horizontal stab. with a lot of trim. I have added 1 washer under the front spar with little emprovement. Any ideas of how much I will have to raise it? ________________________________________________________________________________
Date: Oct 05, 2004
Charlie: This is usually a CG issue. I'd discuss it with Van's before changing the incidence angle. You may be able to fix it by moving your battery to the front, or something like that. Wayne -----Original Message----- From: owner-rvsoutheast-list-server(at)matronics.com [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of Charlie Hall Subject: RVSouthEast-List: incedence angle Has anybody had to change the incedence angle? I have to use too much nose down trim to maintain level flight. The elevator is in trail with the horizontal stab. with a lot of trim. I have added 1 washer under the front spar with little emprovement. Any ideas of how much I will have to raise it? ________________________________________________________________________________
Date: Oct 05, 2004
Subject: Stomy's Fall Fly-in: it's fish-or-cut-bait time!
Okay, gang: who's in and who's out? I need to know what's best for the bunch of ya. Here are the date choices (all are equally fine with me): Saturday, Oct 9. Sunday, Oct 10. Saturday Ot 16. Sunday, Oct 17. Afternoon fly-in BBQ thing with fall colors to look at, ten adorable puppies to pet, horseshoes to pitch, etc, etc. (If anyone wanted to overnight camp or RON at the house, they'd be welcome to - we will have a campfire going and a place to set a tent, with amenities.) We're talking afternoon here, around 3pm start time, going until everyone has to scatter before dark. Everything on my end is rather easily thrown together at the last minute, so your votes will largely determine the date we do this. But I need to know who is interested in what dates (parties are more fun if your guests show up!) The fall foliage will likely peak here the weekend of the 16th, FWIW. Circulate this on the MARV and OVRV lists, too, please. I don't want to compete with anyone else's parade, but I'd like to invite everyone who might be interested. -Stormy ________________________________________________________________________________
Date: Oct 05, 2004
Subject: Re: Stomy's Fall Fly-in: it's fish-or-cut-bait time!
Hi Stormy, We're be out of town Oct. 9 & 10 for granddaughter's first birthday. Mike Barbee ________________________________________________________________________________
Subject: Stomy's Fall Fly-in: it's fish-or-cut-bait time!louisa
gang
Date: Oct 06, 2004
Stormy when ever you set it up.......we will try to be there......we are like neighbors! my -6 is down with a leaking fuel tank, but we have it under control. Larrys -6 is good to go! Looking forward to flying into your place in the fall... Our hanger buddy Bill has his Long-ez back but sure he will pass on the grass strip. We will try to bring him right seat. Bob Martin, Louisa Va >From: SportAV8R(at)aol.com >Reply-To: rvsoutheast-list(at)matronics.com >To: rvsoutheast-list(at)matronics.com >Subject: RVSouthEast-List: Stomy's Fall Fly-in: it's fish-or-cut-bait time! >Date: Tue, 05 Oct 2004 21:11:19 -0400 > > >Okay, gang: who's in and who's out? I need to know what's best for the >bunch of ya. > >Here are the date choices (all are equally fine with me): >Saturday, Oct 9. >Sunday, Oct 10. >Saturday Ot 16. >Sunday, Oct 17. > >Afternoon fly-in BBQ thing with fall colors to look at, ten adorable >puppies to pet, horseshoes to pitch, etc, etc. (If anyone wanted to >overnight camp or RON at the house, they'd be welcome to - we will have a >campfire going and a place to set a tent, with amenities.) We're talking >afternoon here, around 3pm start time, going until everyone has to scatter >before dark. > >Everything on my end is rather easily thrown together at the last minute, >so your votes will largely determine the date we do this. But I need to >know who is interested in what dates (parties are more fun if your guests >show up!) The fall foliage will likely peak here the weekend of the 16th, >FWIW. > >Circulate this on the MARV and OVRV lists, too, please. I don't want to >compete with anyone else's parade, but I'd like to invite everyone who >might be interested. > >-Stormy > > ________________________________________________________________________________
Subject: Stomy's
Date: Oct 05, 2004
At the rate I'm going, I'll be on the 50 mile leash for a while. So I'm a definate "don't know". - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: SportAV8R(at)aol.com [mailto:SportAV8R(at)aol.com] > Sent: Tuesday, October 05, 2004 12:33 PM > To: rvsoutheast-list(at)matronics.com > Subject: Re: RVSouthEast-List: Stomy's > > > Timely inquiry, Steve, as I was just about to post a question > to gauge the general interest level... > > I'm still planning onthe get-together Saturday. Wx prog > looks good. Fall colors are just beginning, but promising. > No lumberjacking will be expected of guests- that was a joke. > I am serious about grilling some shrimp as well as > tube-steaks, but need a head count to help with that. > > RWY info is best had from AirNav.com under airport identifier > 12VA. We'll monitor 122.85 on the handie-talkie for a Unicom > of sorts. > > Aiming for an afternoon start time of about 3pm and winding > down by 6 to give everyone a chance to get home (dark is > about 7 by now). We'll supply food and drinks; no need for > anyone to bring anything thing time unless they just want to. > Covered dish contributions will not be turned away :-) > > Len- check with Larry Small to see if he can make it. > > "Rain date" of the following Saturday would be fine with me, > as would Sunday the 10th. I'd be glad to move the event in > case of weather or low anticipated turnout; it's a "group > call" as far as I am concerned. > > -Stormy > > > ============ > Matronics Forums. > ============ > ============ > ============ > > > > > > ________________________________________________________________________________
Date: Oct 06, 2004
Subject: Re: incedence angle
In a message dated 10/5/04 8:36:07 PM Eastern Daylight Time, N136CH(at)webtv.net writes: Has anybody had to change the incedence angle? I have to use too much nose down trim to maintain level flight. The elevator is in trail with the horizontal stab. with a lot of trim. I have added 1 washer under the front spar with little emprovement. Any ideas of how much I will have to raise it? Are you sure it is not the setting of the trim ... if the elevator is in trail with the stab ... the trim light should be in the center ... Len ________________________________________________________________________________
Date: Oct 06, 2004
In a message dated 10/5/04 9:11:55 PM Eastern Daylight Time, SportAV8R(at)aol.com writes: Okay, gang: who's in and who's out? I need to know what's best for the bunch of ya. Here are the date choices (all are equally fine with me): Saturday, Oct 9. Sunday, Oct 10. Saturday Ot 16. Sunday, Oct 17. I hate to even chime in here since I don't even know if I can come or not but ... If I can come it would be this Saturday ... the weekend of the 16th I am at the Furniture Market for the entire weekend ...but again my vote should not count !! Len ________________________________________________________________________________
Date: Oct 06, 2004
In a message dated 10/5/04 10:12:57 PM Eastern Daylight Time, Larry(at)bowenaero.com writes: At the rate I'm going, I'll be on the 50 mile leash for a while. So I'm a definate "don't know". We have a trip to Florida planned ... I do not want to hear this stuff ... Fly that plane !!! Len ________________________________________________________________________________
Date: Oct 06, 2004
I'm getting there. But everytime I fly, there is something else to look at. Last night the xpdr was dead. Flew a little without it, then came back to troubleshoot. It was one of those disassemble, check, find nothing, reassemble, and now it works things. - Larry Bowen, RV-8, 6 hrs. Larry(at)BowenAero.com http://BowenAero.com Lenleg(at)aol.com said: > > > In a message dated 10/5/04 10:12:57 PM Eastern Daylight Time, > Larry(at)bowenaero.com writes: > > At the rate I'm going, I'll be on the 50 mile leash for a while. So I'm > a > definate "don't know". > > > We have a trip to Florida planned ... I do not want to hear this stuff ... > Fly that plane !!! > > Len > > ________________________________________________________________________________
Date: Oct 06, 2004
In a message dated 10/6/04 8:56:05 AM Eastern Daylight Time, Larry(at)bowenaero.com writes: I'm getting there. But everytime I fly, there is something else to look at. Last night the xpdr was dead. Flew a little without it, then came back to troubleshoot. It was one of those disassemble, check, find nothing, reassemble, and now it works things. You should be doing like I did .... fly early every morning for an hour too ... I know you start to work too early but maybe on weekends !! Len ________________________________________________________________________________
Date: Oct 06, 2004
Hi Stormy, We're be out of town Oct. 9 & 10 for granddaughter's first birthday. Mike Barbee Thanks, Mike. Have a good one. We will factor that into the decision - I'll try to make a final call by tomorrow am at the latest. -Stormy ________________________________________________________________________________
Date: Oct 06, 2004
Subject: Re: Stomy's Fall Fly-in: it's fish-or-cut-bait time!louisa
gang Stormy when ever you set it up.......we will try to be there......we are like neighbors! Bob: gotcha, buddy. Glad to hear you're "in" no matter what :-) -Stormy ________________________________________________________________________________
Date: Oct 06, 2004
Subject: Stomy's
At the rate I'm going, I'll be on the 50 mile leash for a while. So I'm a definate "don't know". We'll put you down as a back-seater, then :-) -Stormy ________________________________________________________________________________
Date: Oct 06, 2004
If I can come it would be this Saturday ... the weekend of the 16th I am at the Furniture Market for the entire weekend ...but again my vote should not count !! Len Okay, Len. Zap! - you're disenfranchised, just like that! Since I hope to see you, we'll lean towards this Saturday, and maybe even let some dead people and illegal aliens vote in this one. -Stormy ________________________________________________________________________________
Date: Oct 06, 2004
Subject: Larry's transponder troubles
Last night the xpdr was dead. Flew a little without it, then came back to troubleshoot. It was one of those disassemble, check, find nothing, reassemble, and now it works things. LArry- this has happened to me twice at least. Once (and subsequent times) it was attributed to an oily film building up on the belly-mounted antenna. Remove all exhaust scum with a rag (and WD-40 if needed) and see how she does. Other time it was broken coax center conductor in a concealed antenna setup I made. Paid $250 to Garmin to be told the box worked fine on their bench! A caveat: last time I was in INT airspace I was tiold my transponder was inop, despite the fact that I was seeing interrogation hits on the panel light... then he told the next aircraft the same thing, "I only have you as a primary target." I suspect INT's radar is squirrely and needs a kick in the klystron. -Stormy ________________________________________________________________________________
Date: Oct 06, 2004
Subject: Re: Larry's transponder troubles
Thanks for the tips. I happened to clean the underside yesterday and the antenna was fairly clean. I think in this case it was the reseating in the tray that cured it. Prior to that it was dead...as in no lights or other signs of life. It reminded me I need to send in the warrenty card for my Apollo stuff!! I have an appointment Monday for the xpdr/encoder/pitot/static check. I guess if there are more serious problems they will be uncovered then. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com SportAV8R(at)aol.com said: > > Last night the xpdr was dead. Flew a little without it, then came > back to troubleshoot. It was one of those disassemble, check, find > nothing, reassemble, and now it works things. > > LArry- > > this has happened to me twice at least. Once (and subsequent times) it > was attributed to an oily film building up on the belly-mounted antenna. > Remove all exhaust scum with a rag (and WD-40 if needed) and see how she > does. > > Other time it was broken coax center conductor in a concealed antenna > setup I made. Paid $250 to Garmin to be told the box worked fine on their > bench! > > A caveat: last time I was in INT airspace I was tiold my transponder was > inop, despite the fact that I was seeing interrogation hits on the panel > light... then he told the next aircraft the same thing, "I only have you > as a primary target." I suspect INT's radar is squirrely and needs a kick > in the klystron. > > -Stormy > > ________________________________________________________________________________
Subject: Brake Fires and HYD Fluid
Date: Oct 06, 2004
Someone had a brake fire that started after an overheated caliper leaked fluid on a hot disk. The fluid flashed and lit the resin in the fiberglass wheel pant, as well as the tire sidewall. The brake worked fine, with only slightly higher pedal pressure required even when on fire. Why did the seal leak at some temperature well below a failure temperature for the rest of the brake? And why did the fluid catch fire? It turns out the Cleveland piston seal for the little 30-9 caliper is an ordinary MS28775-218 nitrile o-ring. Nitrile's temperature rating is - 65F to +275 F. Cleveland's tech manual specifies either Mil-H-5606 or Mil-H-83282 as acceptable. Turns out that Mil-H-83282 was created because the military was tired of setting it's airplanes on fire. Mil-H-5606 is the standard red hydraulic fluid, it is a petroleum base, and turns out to have a very low flash point. The Mil-H-83282 is also red, and compatible with 5606 fluid as well as seals created for 5606. However, it is a synthetic, with much higher flash and burn points, and is self-extinguishing when removed from the ignition source. Note the flash points of the two fluids. Aeroshell 41 (Mil-H-5606) is 104 C, which is only 219 F. Aeroshell 31 (Mil-H-83282) is 237 C, or 458 F. A flash point of 219 F means that when a Cleveland caliper seal fails at something above 275, the fluid is already hot enough to light when it hits a hot disk and vaporizes inside the pant. Live and learn. I always assumed standard "mil-spec red brake fluid" was something special. It's not. It's just another one of those "always done it that way" things prevalent with light airplanes. I said all that to say this. Wayne Williams and I are trying to get some of the good stuff, Aeroshell 31 (Mil-H-83282). The problem is we can only get it in lots of 6 gallons. If you are interested in getting some please let me know. Steve Glasgow 704-362-0005 704-281-7884 ________________________________________________________________________________
Date: Oct 06, 2004
Subject: Re: Brake Fires and HYD Fluid
I'll take some, a quart or two. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Steve Glasgow said: > > > > Someone had a brake fire that started after an overheated caliper leaked > fluid on a hot disk. The fluid flashed and lit the resin in the > fiberglass > wheel pant, as well as the tire sidewall. The brake worked fine, with > only > slightly higher pedal pressure required even when on fire. > > Why did the seal leak at some temperature well below a failure temperature > for the rest of the brake? And why did the fluid catch fire? > > It turns out the Cleveland piston seal for the little 30-9 caliper is an > ordinary MS28775-218 nitrile o-ring. Nitrile's temperature rating is - > 65F > to +275 F. Cleveland's tech manual specifies either Mil-H-5606 or > Mil-H-83282 as acceptable. Turns out that Mil-H-83282 was created because > the military was tired of setting it's airplanes on fire. Mil-H-5606 is > the > standard red hydraulic fluid, it is a petroleum base, and turns out to > have > a very low flash point. The Mil-H-83282 is also red, and compatible with > 5606 fluid as well as seals created for 5606. However, it is a synthetic, > with much higher flash and burn points, and is self-extinguishing when > removed from the ignition source. > > Note the flash points of the two fluids. Aeroshell 41 (Mil-H-5606) is 104 > C, which is only 219 F. Aeroshell 31 (Mil-H-83282) is 237 C, or 458 F. > > A flash point of 219 F means that when a Cleveland caliper seal fails at > something above 275, the fluid is already hot enough to light when it hits > a > hot disk and vaporizes inside the pant. > > Live and learn. I always assumed standard "mil-spec red brake fluid" was > something special. It's not. > It's just another one of those "always done it that way" things prevalent > with light airplanes. > > > I said all that to say this. Wayne Williams and I are trying to get some > of > the good stuff, Aeroshell 31 (Mil-H-83282). The problem is we can only > get > it in lots of 6 gallons. > > If you are interested in getting some please let me know. > > Steve Glasgow > 704-362-0005 > 704-281-7884 > > ________________________________________________________________________________
Date: Oct 05, 2004
Steve, I would be interested in a quart myself. Ed Anderson RV-6A N494BW Rotary Powered Matthews ----- Original Message ----- From: "Larry Bowen" <Larry(at)bowenaero.com> Subject: Re: RVSouthEast-List: Brake Fires and HYD Fluid > > I'll take some, a quart or two. > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > Steve Glasgow said: > > > > > > > > Someone had a brake fire that started after an overheated caliper leaked > > fluid on a hot disk. The fluid flashed and lit the resin in the > > fiberglass > > wheel pant, as well as the tire sidewall. The brake worked fine, with > > only > > slightly higher pedal pressure required even when on fire. > > > > Why did the seal leak at some temperature well below a failure temperature > > for the rest of the brake? And why did the fluid catch fire? > > > > It turns out the Cleveland piston seal for the little 30-9 caliper is an > > ordinary MS28775-218 nitrile o-ring. Nitrile's temperature rating is - > > 65F > > to +275 F. Cleveland's tech manual specifies either Mil-H-5606 or > > Mil-H-83282 as acceptable. Turns out that Mil-H-83282 was created because > > the military was tired of setting it's airplanes on fire. Mil-H-5606 is > > the > > standard red hydraulic fluid, it is a petroleum base, and turns out to > > have > > a very low flash point. The Mil-H-83282 is also red, and compatible with > > 5606 fluid as well as seals created for 5606. However, it is a synthetic, > > with much higher flash and burn points, and is self-extinguishing when > > removed from the ignition source. > > > > Note the flash points of the two fluids. Aeroshell 41 (Mil-H-5606) is 104 > > C, which is only 219 F. Aeroshell 31 (Mil-H-83282) is 237 C, or 458 F. > > > > A flash point of 219 F means that when a Cleveland caliper seal fails at > > something above 275, the fluid is already hot enough to light when it hits > > a > > hot disk and vaporizes inside the pant. > > > > Live and learn. I always assumed standard "mil-spec red brake fluid" was > > something special. It's not. > > It's just another one of those "always done it that way" things prevalent > > with light airplanes. > > > > > > I said all that to say this. Wayne Williams and I are trying to get some > > of > > the good stuff, Aeroshell 31 (Mil-H-83282). The problem is we can only > > get > > it in lots of 6 gallons. > > > > If you are interested in getting some please let me know. > > > > Steve Glasgow > > 704-362-0005 > > 704-281-7884 > > > > > > ________________________________________________________________________________
gang
Date: Oct 06, 2004
Stormy, I could make it either Sunday this week-end, or either day next week-end. Count my vote as one of the dead or illegal alien ones. David N168DD ----- Original Message ----- From: <SportAV8R(at)aol.com> Subject: Re: RVSouthEast-List: Stomy's Fall Fly-in: it's fish-or-cut-bait time!louisa gang > > Stormy > when ever you set it up.......we will try to be there......we are like > neighbors! > > Bob: gotcha, buddy. Glad to hear you're "in" no matter what :-) > > -Stormy > > ________________________________________________________________________________
Date: Oct 06, 2004
Larry if your woes continue there is a Tech in Charlotte who is very reasonable. I bought my Garmin 320 from him. He is retired for the avionics business and has all the necessary tools and knowledge to troubleshoot your problem. Tad S. 7A ________________________________________________________________________________
Date: Oct 06, 2004
I'll take a quart Mike Barbee ________________________________________________________________________________
Date: Oct 06, 2004
Untested, but I think I solved it tonight. The little arm that holds the xpdr to the tray was not right. Now it is. We'll find out tomorrow. Thanks, - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Sargentclt(at)cs.com [mailto:Sargentclt(at)cs.com] > Sent: Wednesday, October 06, 2004 8:17 PM > To: rvsoutheast-list(at)matronics.com > Subject: Re: RVSouthEast-List: Larry's transponder troubles > > > Larry if your woes continue there is a Tech in > Charlotte who is very reasonable. I bought my Garmin 320 > from him. He is retired for the avionics business and has > all the necessary tools and knowledge to troubleshoot your problem. > > Tad S. 7A > > > ============ > Matronics Forums. > ============ > ============ > ============ > > > > > > ________________________________________________________________________________
Date: Oct 07, 2004
Subject: Re: transponder
In a message dated 10/6/04 8:18:00 PM Eastern Daylight Time, Sargentclt(at)cs.com writes: > ............. there is a Tech in Charlotte who is very > reasonable. He is retired from the avionics > business and has all the necessary tools and knowledge to troubleshoot your > problem. > > Tad S. 7A > Tad, Could you please give me his name? I need to have my Garman 327/encoder checked as I assume the FAA will require proof that it has been done when they visit soon. Dale Ensing RV6A Aero Plantation ________________________________________________________________________________
Date: Oct 07, 2004
My FAA guy said I could do that after the inspection. I have a appt at 8A7 to do it Monday. - Larry Bowen, RV-8, 7.2 hours. Larry(at)BowenAero.com http://BowenAero.com DWENSING(at)aol.com said: > > In a message dated 10/6/04 8:18:00 PM Eastern Daylight Time, > Sargentclt(at)cs.com writes: > > >> ............. there is a Tech in Charlotte who is very >> reasonable. He is retired from the avionics >> business and has all the necessary tools and knowledge to troubleshoot >> your >> problem. >> >> Tad S. 7A >> > Tad, > Could you please give me his name? I need to have my Garman 327/encoder > checked as I assume the FAA will require proof that it has been done when > they > visit soon. > Dale Ensing > RV6A > Aero Plantation > > ________________________________________________________________________________
Date: Oct 07, 2004
In a message dated 10/6/04 8:25:42 PM Eastern Daylight Time, TWOBARBEE(at)wmconnect.com writes: I would take some also. Len Leggette ________________________________________________________________________________
Date: Oct 07, 2004
Subject: Stomy's Fall Fly-in: latest developments
I dislike indecisiveness, especially in myself. Yet decisions like this are never easy... I figure if we hold the fly-in as planned Saturday, we might have about 4 planes show up (maybe). The next weekend we might have a different 4 show up. I'm almost the only respondent who said he could make it either weekend :-) Here're the facts: The guy who rents our hayfields just sprinkled turkey litter all over the farm, and it's going to have a pungent smell until the next rain, which is not for awhile. =:O The leaves have just barely begun to show any fall color here. They will peak in about 2 more weeks. I was really getting impatient to have a get-together this weekend, but I'm up for it either time. --- The only solutions seem to be to have no fly-in at all, or have two on successive weekends. Let's do the Solomon thing and "cut the baby in half," thus: the real Fall Fly-In will be NEXT Saturday, October 16th. We will be hangin' out here THIS Saturday, the 9th, with the welcome mat out for anyone who wants to drop in for a real informal time, including some victuals. This way I (hopefully) still get to visit with Leggs, whereas maybe Smoozer and some of the Ohio Valley Boys can make it the following Saturday. My family may shoot me for doing this twice in a row, but - hey, I love airplanes, airplane people, and socials :-) So there it is; you are ALL invited BOTH times, and I will quit worrying about who can come when. Like the guy says, we'll keep the light on for ya. No skin off my nose if nobody shows either weekend; I _love_ shrimp on the grill; more for me :-) Let's say 2 pm both days, finishing by 5:30. Unicom will be 122.85 and navigational data is listed on AirNav.com under "12VA." -Stormy ________________________________________________________________________________
Date: Oct 08, 2004
Subject: Fwd: October Meeting EAA 108
In a message dated 10/8/04 12:35:35 PM Eastern Daylight Time, gbray(at)netmcr.com writes: Hello everyone , Our October meeting was originally scheduled for the fly-in at Pace Field in Ridgeway Va. tomorrow 10/9. I am sorry to report that, understandably, due to the circumstances regarding Tommy passing away, the fly-in / barbeque has been cancelled. Therefore, I see no other option than to cancel our October meeting altogether. We will plan to meet back at Shiloh in November. Thank You Greg Bray From: "Greg & Vicky Bray" <gbray(at)netmcr.com> "Ray & Lorraine Judd" , "Ray Sharp" , "Ritchie & Mechelle Jones" , "Roger Dodson" , "Roger Jennings" , "Stephen Austin" , "Stephen Wooten" , "Terry Gallion" , "Thomas C Freeman" , "Tim Rothrock" , "Tim Stauffer" , "Tommy Redmon" , "Tony Morgan" , "Tracy Gough" , "Walter Wiley" , "Wilton Little" , "Greg Bray" , "Shirley Wheeler" , "Morton Lester" Subject: October Meeting Date: Fri, 8 Oct 2004 12:34:53 -0400 Hello everyone , Our October meeting was originally scheduled for the fly-in at Pace Field in Ridgeway Va. tomorrow 10/9. I am sorry to report that, understandably, due to the circumstances regarding Tommy passing away,=20the fly-in / barbeque has been cancelled. Therefore, I see no other option than to cancel our October meeting altogether. We will plan to meet back at Shiloh in November. =20 Thank You =20 Greg Bray Hello everyone , Our October meeting was originally scheduled for the fly-in at Pace Field in Ridgeway Va. tomorrow 10/9. I am sorry to report that, understandably, due to the circumstances regarding Tommy passing away, the fly-in / barbeque has been cancelled. Therefore, I see no other option than to cancel our October meeting altogether. We will plan to meet back at Shiloh in November. Thank You Greg Bray ________________________________________________________________________________
Date: Oct 09, 2004
Subject: Pace
I Think the msg from Greg (Chapter 8) was in error. I was up there several times this week and they were preparing. Ben Pace asked me to spread the word. They won't begin serving until 2PM. Runway 18-36 is in good shape and common traffic frequency is 122.9. ________________________________________________________________________________
Subject: Soft feild handling question for RV-6A
Date: Oct 09, 2004
Is there any problems landing a RV-6A, or traildragger for that matter, on turf? I have an opportunity to buy a RV-6A with all major subcomponent construction complete, i.e., the wings are ready for mounting, ailerons and flaps are complete. It still needs interior, instrument panel and FWF. It would be based out central PA on a 3000 foot grass strip. It's not the roughest field I've ever landed on but it does have some bumps. I've been told that the RV crowd in PA doesn't like the feild because of problems with wheel pants getting torn off. Can yins (that PA talk - means y'all) confirm or deny this vicious rumor? ________________________________________________________________________________
Subject: Re: Soft feild handling question for RV-6A
Date: Oct 08, 2004
John, It may depend on which model wheel pants the aircraft has. The older RV-6s had wheel pants that provided a bit more clearance that the newer "Pressure Recovery" types. I have operated my RV-6a with the older wheel pants out of some fairly rough grass/dirt strips with no problem (thus far). Ed Ed Anderson RV-6A N494BW Rotary Powered Matthews, NC ----- Original Message ----- From: "John Ciambrone" <wopwopwop(at)verizon.net> Subject: RVSouthEast-List: Soft feild handling question for RV-6A > > Is there any problems landing a RV-6A, or traildragger for that matter, on > turf? > > I have an opportunity to buy a RV-6A with all major subcomponent > construction complete, i.e., the wings are ready for mounting, ailerons and > flaps are complete. It still needs interior, instrument panel and FWF. It > would be based out central PA on a 3000 foot grass strip. It's not the > roughest field I've ever landed on but it does have some bumps. > > I've been told that the RV crowd in PA doesn't like the feild because of > problems with wheel pants getting torn off. Can yins (that PA talk - means > y'all) confirm or deny this vicious rumor? > > ________________________________________________________________________________
Date: Oct 09, 2004
>>Is there any problems landing a RV-6A, or traildragger for that matter, on turf?<>It would be based out central PA on a 3000 foot grass strip. It's not the roughest field I've ever landed on but it does have some bumps. I've been told that the RV crowd in PA doesn't like the feild because of problems with wheel pants getting torn off. << Well, that would prejudice me against that field somewhat, too! The only times I've sustained wheelpant damage on the RV have been in chuck-holes, ditches and other unmarked hazards, and on a rough runway that wasn't even seeded yet. I don't know what I was thinking that day going in there, but there was peer pressure being applied... Oh, yeah, there was the time I flew in too-deep snow off my own strip, and the time I brought it in for touchdown with a flat nosewheel tire that I was unaware of. In all, it's hard to blame a strip that's only moderately bumpy for damage. For the mnost part, it's the pilot's smoothness, not the sod's, that influences the outcome. -Stormy ________________________________________________________________________________
Date: Oct 09, 2004
In a message dated 10/9/04 1:06:03 PM Eastern Daylight Time, wopwopwop(at)verizon.net writes: Is there any problems landing a RV-6A, or traildragger for that matter, on turf? I have an opportunity to buy a RV-6A with all major subcomponent construction complete, i.e., the wings are ready for mounting, ailerons and flaps are complete. It still needs interior, instrument panel and FWF. It would be based out central PA on a 3000 foot grass strip. It's not the roughest field I've ever landed on but it does have some bumps. I've been told that the RV crowd in PA doesn't like the feild because of problems with wheel pants getting torn off. Can yins (that PA talk - means y'all) confirm or deny this vicious rumor? We have several guys that live on grass strips that can answer better than me ... but I have landed my 8A on grass strips on many ocassions. I always baby my nose gear whether it is on pavement or grass ... thats the way Mike Seager taught me. I lift the nose as soon as it will come up then hold it off the runway until the plane wants to fly off ... kinda like a soft field takeoff except I don't force the plane off the ground early ... On landing I hold the nose off the ground as long as it will stay off. I find the most harsh time for the fairings is on rollout if you are going too fast and also taxiing too fast. I am sure Stormy, Wayne8, and some of the other guys that live on grass strips will chime in !! Len Leggette, RV-8A Greensboro, N.C. N910LL 279 hrs ________________________________________________________________________________
Subject: Sat.
Date: Oct 09, 2004
Any reports from events at Stormy's or Pace today? I was out a little bit, but went to HKY for some family affairs. I did some poor landings at EXX on the way back..... - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Oct 09, 2004
Subject: Re: Sat.
Any reports from events at Stormy's or Pace today? I was out a little bit, but went to HKY for some family affairs. I did some poor landings at EXX on the way back..... - Larry Bowen Good for you, Larry. It's important to stay current in all flight maneuvers, so practicing some poor landings every now and then makes good sense; it's easy to forget how to make poor ones after you get good ;-) I showed up for my fly-in today, which is also good, because no one else did. I ate all the food myself and probably gained 10 pounds. I thought about going to Pace, but would have felt terrible if someone had shown up at my place while I was away, so I stayed pretty much local in my aerial meanderings today. -Stormy ________________________________________________________________________________
Subject: Sat.
Date: Oct 09, 2004
Sorry it was a bust. Larry Small called me today asking about your place and next weekend. If he has an open seat, I may fill it. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: SportAV8R(at)aol.com [mailto:SportAV8R(at)aol.com] > Sent: Saturday, October 09, 2004 9:54 PM > To: rvsoutheast-list(at)matronics.com > Subject: Re: RVSouthEast-List: Sat. > > > Any reports from events at Stormy's or Pace today? I was out > a little bit, but went to HKY for some family affairs. I did > some poor landings at EXX on the way back..... > > - > Larry Bowen > > Good for you, Larry. It's important to stay current in all > flight maneuvers, so practicing some poor landings every now > and then makes good sense; it's easy to forget how to make > poor ones after you get good ;-) > > I showed up for my fly-in today, which is also good, because > no one else did. I ate all the food myself and probably > gained 10 pounds. I thought about going to Pace, but would > have felt terrible if someone had shown up at my place while > I was away, so I stayed pretty much local in my aerial > meanderings today. > > -Stormy > > > ============ > Matronics Forums. > ============ > ============ > ============ > > > > > > ________________________________________________________________________________
Subject: [RV10] 4th Annual Coastal Georgia Fall Fly In
Date: Oct 09, 2004
From: "Richard Sipp" <rsipp(at)earthlink.net> > Greetings: > > Mark your flying schedule for Saturday October 16. That's the date for the > 4th annual Coastal Georgia Fall Fly In. > > Place: Eagle Neck Airpark 1GA0 located on the Georgia coastline half way > between Savannah and St. Simons Island. > > Barbeque is served around noon. Eagle Neck is home to 3 completed RVs and 3 > more under construction including a 10. Any type aircraft welcome. Make a > weekend of it and tour Savannah, book some great off shore fishing or tidal > marsh canoeing. > > Please RSVP to the sender for more information, airport briefing etc. > > Dick Sipp > RV4 250DS > RV10 110DV #65 ________________________________________________________________________________
Date: Oct 10, 2004
Subject: Pace
I am on a tether like Larry so I went to Pace. There was about 40 airplanes there including 3 RVs, my 4, Jerome Tuttle's 4, and Dana Breda's 6, not quite as many airplanes as usual. The food was great. ________________________________________________________________________________
Subject: Pace
Date: Oct 10, 2004
Anything tricky about landing at Pace? Dana told me about the deer. Anything else? Pretty smooth? I couldn't make it Saturday, but today would have been a good day to go for some "cheap" fuel. Winds right down the runway..... - Larry Bowen, RV-8, 11.5 hrs. Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Charlie Hall [mailto:N136CH(at)webtv.net] > Sent: Sunday, October 10, 2004 12:33 PM > To: rvsoutheast-list(at)matronics.com > Subject: RVSouthEast-List: Pace > > (Charlie Hall) > > I am on a tether like Larry so I went to Pace. There was > about 40 airplanes there including 3 RVs, my 4, Jerome > Tuttle's 4, and Dana Breda's 6, not quite as many airplanes > as usual. The food was great. > > > ============ > Matronics Forums. > ============ > ============ > ============ > > > > > > ________________________________________________________________________________
Date: Oct 10, 2004
Subject: Re: Pace
Pace is really nice... wide, 3000' long. It was very a smooth landing on the north end and just a bit bumpy taking off from the south end. I have the standard wheelpants and had no problems. I was there maybe 7-8 years ago and thought I was going to lose the pants on takeoff, but it's great now. Didn't see any deer, but somebody said there were a bunch of turkeys on the runway earlier in the day (and I don't think he meant the pilots... :>)) Dana Larry Bowen wrote: > >Anything tricky about landing at Pace? Dana told me about the deer. >Anything else? Pretty smooth? > >I couldn't make it Saturday, but today would have been a good day to go for >some "cheap" fuel. Winds right down the runway..... > >- >Larry Bowen, RV-8, 11.5 hrs. >Larry(at)BowenAero.com >http://BowenAero.com > > > > >>-----Original Message----- >>From: Charlie Hall [mailto:N136CH(at)webtv.net] >>Sent: Sunday, October 10, 2004 12:33 PM >>To: rvsoutheast-list(at)matronics.com >>Subject: RVSouthEast-List: Pace >> >>(Charlie Hall) >> >>I am on a tether like Larry so I went to Pace. There was >>about 40 airplanes there including 3 RVs, my 4, Jerome >>Tuttle's 4, and Dana Breda's 6, not quite as many airplanes >>as usual. The food was great. >> >> >>============ >>Matronics Forums. >>============ >>============ >>============ >> >> >> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Oct 10, 2004
Subject: Sat.
Sorry it was a bust. Larry Small called me today asking about your place and next weekend. If he has an open seat, I may fill it. - Larry Bowen No problem, Larry. All in all, I had a great weekend. Flew 4 young eagles today in severe clear with light turbulence. Perfect day for aviation. Next weekend, the foliage will be better, the odor around here lessened, and I will be more prepared for full-blown hospitality. I think scheduling it for the late afternoon is a bit weird, though. Maybe we'd attract more folk with a lunchtime start, don't you think?? Days are too short now to design the barbecue as a "supper." Tried out my new wingtip antenna today, and the SWR bandwidth seems unbelievably wide. Up in the air measurements were postponed due to a glitch in the antenna analyzer not wanting to run off its internal batteries. A work-around was soldered up tonight on at the test bench, and I will be checking in flight SWR next time I'm up (with a flight engineer in the right seat.) -Stormy ________________________________________________________________________________
Subject: Sat.
Date: Oct 10, 2004
I agree earlier is better this time of year. - Larry Bowen, RV-8 @ 8A7, 11.5 Hrs. Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: SportAV8R(at)aol.com [mailto:SportAV8R(at)aol.com] > Sent: Sunday, October 10, 2004 11:03 PM > To: rvsoutheast-list(at)matronics.com > Subject: RE: RVSouthEast-List: Sat. > > > > --> > > Sorry it was a bust. Larry Small called me today asking > about your place and next weekend. If he has an open seat, I > may fill it. > > - > Larry Bowen > > No problem, Larry. All in all, I had a great weekend. Flew > 4 young eagles today in severe clear with light turbulence. > Perfect day for aviation. Next weekend, the foliage will be > better, the odor around here lessened, and I will be more > prepared for full-blown hospitality. I think scheduling it > for the late afternoon is a bit weird, though. Maybe we'd > attract more folk with a lunchtime start, don't you think?? > Days are too short now to design the barbecue as a "supper." > > Tried out my new wingtip antenna today, and the SWR bandwidth > seems unbelievably wide. Up in the air measurements were > postponed due to a glitch in the antenna analyzer not wanting > to run off its internal batteries. A work-around was > soldered up tonight on at the test bench, and I will be > checking in flight SWR next time I'm up (with a flight > engineer in the right seat.) > > -Stormy > > > ============ > Matronics Forums. > ============ > ============ > ============ > > > > > > ________________________________________________________________________________
Subject: Saturday Young Eagles?
Date: Oct 11, 2004
Stormy, Sorry we didn't show as well......Larry took his -6 and went to Hickory to visit a friend, meanwhile he left "this" friend without wings.......:-( we did repair the fuel tank today and will now let the Proseal dry for 7 days....... Question?..young eagles.......insurance? we have been looking into our coverage while taking pax up for rides......which we love to do! but see that Experimentals can only get 100,000 coverage per person. I looked at the EAA young eagles program and they offer a 1,000,000. policy if you are a member and have them sign a wavier before going up........ We realize that most people we take up done know the difference between a RV and a Cessna...and are starting to wonder if it is worth the risk..... Any thoughts? Bob .......Louisa Gang >From: SportAV8R(at)aol.com >Reply-To: rvsoutheast-list(at)matronics.com >To: rvsoutheast-list(at)matronics.com >Subject: RE: RVSouthEast-List: Sat. >Date: Sun, 10 Oct 2004 23:03:17 -0400 > > >Sorry it was a bust. Larry Small called me today asking about your place >and next weekend. If he has an open seat, I may fill it. > >- >Larry Bowen > >No problem, Larry. All in all, I had a great weekend. Flew 4 young eagles >today in severe clear with light turbulence. Perfect day for aviation. >Next weekend, the foliage will be better, the odor around here lessened, >and I will be more prepared for full-blown hospitality. I think scheduling >it for the late afternoon is a bit weird, though. Maybe we'd attract more >folk with a lunchtime start, don't you think?? Days are too short now to >design the barbecue as a "supper." > >Tried out my new wingtip antenna today, and the SWR bandwidth seems >unbelievably wide. Up in the air measurements were postponed due to a >glitch in the antenna analyzer not wanting to run off its internal >batteries. A work-around was soldered up tonight on at the test bench, and >I will be checking in flight SWR next time I'm up (with a flight engineer >in the right seat.) > >-Stormy > > ________________________________________________________________________________
Date: Oct 11, 2004
I fly my 6 off of a grass field for the last 19 months with no trouble,and put about 400 hrs on it since then.So i don,t think you will have any problems. Ben ________________________________________________________________________________
Date: Oct 11, 2004
Subject: Re: Pace
In a message dated 10/10/2004 8:45:32 PM Eastern Daylight Time, Larry(at)bowenaero.com writes: Larry Bowen, RV-8, 11.5 hrs. Look at this guys .... a star is born ... 11.5 hours now !!! Way to go Larry ... you are just about ready for a long cross country RV flight !!! Len ________________________________________________________________________________
Date: Oct 11, 2004
Subject: Re: Saturday Young Eagles?
You raise some valid points, Bob. The YE program is still in effect as far as I know. However, the most recent rides I gave were to college students, no parents around, without any forms signed, and even these may be out of bounds for YE eligibility by virtue of their age. There does come a time where you have to decide not to let "reality" impede too much on the freedom you wish you had to live and fly as a free man ;-) and at that point I just throw caution to the wind and take folks up for their long-awaited plane ride. Their smiles make it seem worthwhile (and the squeals from the girls during the rolls :-) I had an eight year old wink at me in church yesterday, and I know it's because I took her for a plane ride last week; her parents say she hasn't stopped talking about it since! I know there are legions of John Edwardses out there just waiting for the next ambulance to chase, but you can't let those @$$holes run your life (well, you can, but that's a conscious choice, and everyone will have their own comfort level in that area.) In short, I'm doing what I want, as reasonably as seems right, and hoping I continue to get away with it, liability-wise. I try never to cut corners with anything safety-related. At this stage, general aviation needs all the allies it can get, and the more people we introduce to our passtime, the better. It's alot like taking a hoplophobe to the shooting range; prejudices can be overcome in one fun afternoon. I continue to believe the risks are worth the return. -Stormy ________________________________________________________________________________
Subject: Pace
Date: Oct 11, 2004
True. The radius of this 50 mile circle can be covered very quickly! On the downside, all this fuel is expensive! - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Lenleg(at)aol.com [mailto:Lenleg(at)aol.com] > Sent: Monday, October 11, 2004 8:48 AM > To: rvsoutheast-list(at)matronics.com > Subject: Re: RVSouthEast-List: Pace > > > In a message dated 10/10/2004 8:45:32 PM Eastern Daylight > Time, Larry(at)bowenaero.com writes: > Larry Bowen, RV-8, 11.5 hrs. > Look at this guys .... a star is born ... 11.5 hours now !!! > Way to go Larry ... you are just about ready for a long cross > country RV flight !!! > > Len > > > ============ > Matronics Forums. > ============ > ============ > ============ > > > > > > ________________________________________________________________________________
Date: Oct 11, 2004
In a message dated 10/11/2004 9:25:40 AM Eastern Standard Time, SportAV8R(at)aol.com writes: > The YE program is still in effect as far as I know. However, the most > recent rides I gave were to college students, no parents around, without any > forms signed, and even these may be out of bounds for YE eligibility by virtue of > their age. There does come a time where you have to decide not to let > "reality" impede too much on the freedom you wish you had to live and fly as a > free man ;-) and at that point I just throw caution to the wind and take folks > up for their long-awaited plane ride. Their smiles make it seem worthwhile > (and the squeals from the girls during the rolls :-) > > I had an eight year old wink at me in church yesterday, and I know it's > because I took her for a plane ride last week; her parents say she hasn't stopped > talking about it since! I know there are legions of John Edwardses out > there just waiting for the next ambulance to chase, but you can't let those > @$$holes run your life (well, you can, but that's a conscious choice, and everyone > will have their own comfort level in that area.) > > In short, I'm doing what I want, as reasonably as seems right, and hoping I > continue to get away with it, liability-wise. I try never to cut corners > with anything safety-related. At this stage, general aviation needs all the > allies it can get, and the more people we introduce to our passtime, the better. > It's alot like taking a hoplophobe to the shooting range; prejudices can be > overcome in one fun afternoon. I continue to believe the risks are worth > the return. > > > -Stormy > One of the best responses to the question I have ever read ... thank you Stormy !! Len ________________________________________________________________________________
Subject: Young Eagles?
Date: Oct 12, 2004
Len, Stormy and guys, Great response Stormy........ The YE program is still in effect and growing. The age is 7 to 17 . the EAA has the forms they will send you for free, you just have to email and ask for some....I ordered 5 just to get some and see what they looked like. It is a release that must be signed by a guardian. as well the name and address for the files at EAA for the offical head counts. We agree with your logic.....or at least I do. I don't want to be "insurance poor" or let it affect the reason I fly....I truly believe half the fun of flying is introducing it to non flyers as evident by the number of times I fly solo to just fly.....hardly any! of course now I love to fly in pairs and that even tops giving rides, but I digress from the subject..... Our situation is a little different as Tripp and I are partners and anything one does, the other will be dragged into by the ownership thing.......so we are looking at the whole thing with that in mind. One solution was to only give rides to family and Young Eagles in the RV and rent a spam can for all others. But that brings up the RV guys and prospective builders and such..... We would like to make a release that we could get people outside the family and young eagles read and sign. One that would tell them what they are about to do.....relating to the Expermental Catagory, etc...and that they agree to accept the 100,000 limit for .........well lets hope nothing, but it would make them think as well........I doubt anything we write up would ever stand up in court, but it would raise awareness levels. Any ideas or information along this line would be appreaciated. This is an important topic, not to be dwelled on but brought up now and then to help us make the right decisions from time to time........ Bob Martin, Louisa County Gang > >SportAV8R(at)aol.com writes: > > > The YE program is still in effect as far as I know. However, the most > > recent rides I gave were to college students, no parents around, without >any > > forms signed, and even these may be out of bounds for YE eligibility by >virtue of > > their age. There does come a time where you have to decide not to let > > "reality" impede too much on the freedom you wish you had to live and >fly as a > > free man ;-) and at that point I just throw caution to the wind and take >folks > > up for their long-awaited plane ride. Their smiles make it seem >worthwhile > > (and the squeals from the girls during the rolls :-) > > > > I had an eight year old wink at me in church yesterday, and I know it's > > because I took her for a plane ride last week; her parents say she >hasn't stopped > > talking about it since! I know there are legions of John Edwardses out > > there just waiting for the next ambulance to chase, but you can't let >those > > @$$holes run your life (well, you can, but that's a conscious choice, >and everyone > > will have their own comfort level in that area.) > > > > In short, I'm doing what I want, as reasonably as seems right, and >hoping I > > continue to get away with it, liability-wise. I try never to cut >corners > > with anything safety-related. At this stage, general aviation needs all >the > > allies it can get, and the more people we introduce to our passtime, the >better. > > It's alot like taking a hoplophobe to the shooting range; prejudices >can be > > overcome in one fun afternoon. I continue to believe the risks are >worth > > the return. > > > > > > -Stormy > > > >One of the best responses to the question I have ever read ... thank you >Stormy !! > >Len > ________________________________________________________________________________
Date: Oct 12, 2004
Subject: MP Problems Solved
The great mystery of my "slow" plane has been solved thanks to all on the different RV list. It seems I was getting a very high MP reading everytime I compared with someone else .... my Rky Mtn uMonitor was reading high ... not their fault but mine !!! I did not calibrate the unit correctly .... I was reading 4" too high !!! Or to put another way I was flying 4" lower setting than everyone else ... that is giving up a lot of MP !! But on the good side ... I have discovered additional speed with no mods !!!! Len Leggette, RV-8A Greensboro, N.C. N910LL 280 hrs AND GETTING FASTER !!!!! ________________________________________________________________________________
Date: Oct 12, 2004
Subject: Re: MP Problems Solved
Congrats on the recent installation of your supercharger!! - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Lenleg(at)aol.com said: > > The great mystery of my "slow" plane has been solved thanks to all on the > different RV list. It seems I was getting a very high MP reading > everytime I > compared with someone else .... my Rky Mtn uMonitor was reading high ... > not > their fault but mine !!! > > I did not calibrate the unit correctly .... I was reading 4" too high !!! > Or to put another way I was flying 4" lower setting than everyone else > ... > that is giving up a lot of MP !! > > But on the good side ... I have discovered additional speed with no mods > !!!! > > Len Leggette, RV-8A > Greensboro, N.C. N910LL > 280 hrs > > > AND GETTING FASTER !!!!! > > ________________________________________________________________________________
Date: Oct 12, 2004
Great-- now I won't be able to keep up with you or Larry! Wayne -----Original Message----- From: owner-rvsoutheast-list-server(at)matronics.com [mailto:owner-rvsoutheast-list-server(at)matronics.com]On Behalf Of Lenleg(at)aol.com Subject: RVSouthEast-List: MP Problems Solved The great mystery of my "slow" plane has been solved thanks to all on the different RV list. It seems I was getting a very high MP reading everytime I compared with someone else .... my Rky Mtn uMonitor was reading high ... not their fault but mine !!!
September 16, 2004 - October 12, 2004
RVSouthEast-Archive.digest.vol-ac
