Rocket-Archive.digest.vol-ai
July 06, 2002 - November 22, 2002
Subject: | Re: 3 blade prop |
In a message dated Sat, 6 Jul 2002 6:05:30 AM Eastern Standard Time, jrstone(at)insightbb.com
writes:
> Has anyone tried the new three blade Hartzel prop (HC-13YR-RF /F7693DF)?
> This is the prop Team Rocket is selling.
> John Harmon tried the HC-13YR-RF /F7693F model and reports a decrease in
> performance in all areas (take off roll distance, rate of
> climb, cruise
> speed).
Hey Jim:
The "D" twist I requested from Hartzell brings the 7693D 3 blade to within 1 lb
of thrust compared to the 8475D two blade. Close enough for me! And the ride
is much smoother. But, run the numbers for your ship -- the extra 12 lb might
be too much weight for the gear setup on the HR2. The MT is another option, but
I can say that they don't have the right blade...YET. Stay tuned -- I'm working
with them to get one of their 3 blades to run equal to the 8475J 2 blade I'm
currently using. Talks about smooth -- that MT makes the ship feel like there
is an electric motor on the nose. Unbelievable...
Cheers
Mark
Team Rocket LP
From: | "Loren Harmon" <landsharmon(at)attbi.com> |
Subject: | tailwheel weight & TW bearings |
You probably won't, John... but how many HRII pilots have already?
Loren
-----Original Message-----
[mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of
Hr2pilot(at)aol.com
Subject: Re: Rocket-List: tailwheel weight & TW bearings
The prototype 42HR is less than 20# on the tail and the Rocket III is
12#
does this mean I well damage my prop? I also got 1500 hr. on my first
tailwheel.
Subject: | VideoCam'sInCockpit |
Has anyone done this ?
I want the real-time video to be available to both pilot and passenger in
Harmon Rocket (tandem) with selectable views. Probably a LCD in front and
back. Would involve mounting some lipstick cameras here and there on the
airframe, inside and out. Views I'm interested in are 1) taxi 2) wide angle shot forward from tail 3)
passenger monitor 4) instrument panel view
If a cam had joystick and wiggle room like an automobile mirror, the
back-seater could entertain onself with views every which way.
Where does one buy this stuff ? Little 12v cameras ? Must be a catalog.
I've seen it on display in Singapore...in fact bought a little 12v 4x4 LCD
there and ran it off my JVC video cam. Etc.
John Meyers Rocket 1/2 done, Golden, CO
Subject: | Re: tailwheel weight & TW bearings |
In a message dated 07/06/2002 7:08:04 PM Pacific Daylight Time,
landsharmon(at)attbi.com writes:
> Loren
Accidentally, or deliberately?
There is a rumor that at least one HRII received a new engine and new prop
from a "engine run-up prop strike" on a runout engine and junk prop. At the
insurance companies expense? Or at the expense of all of the Rocket owners?
Jim Ayers
HRII Lyc. O-540-A1D5 core rebuilt as an IO-540-C4B5
Listers... anyone know from memory the firing order of O-540 ? Guess I
ought to snag a service manual too !
(Arnold ((Arn-Air)) in Iowa is building one mag and leads for me... needs
firing order, layout, and lengths... I am laying out the lengths but have
questions below:)
I am planning Lightspeed Electronic on one side. Anyone with that
Ignition??.. Do you fire all the lower plugs with Electronic ? Uppers with
mag.? Is there a favorite mag (right or left) to replace with the Electronic
Thanks in advance, John
John Meyers Golden, CO
John : Lycomings Direct Drive engine overhaul manual , Section 4 -Ignition
system
4-5. Engine firing order.4 cylinder engines (except LIO series) 1-3-2-4 .
LIO series 1-4-2-3. 6 cylinder engines 1-4-5-2-3-6. LIO series
1-6-3-2-5-4. 8 cylinder engines 1-5-8-3-2-6-7-4 .
problably more information then you wanted but quoted it direct.
Terry E. Cole
In a message dated 7/6/2002 4:07:48 AM Pacific Daylight Time,
jrstone(at)insightbb.com writes:
> performance in all areas (take off roll distance, rate of climb, cruise
> speed). I called Hartzel a couple of times to ask them if we should
> expect an increase in performance, but they haven't called back.
> Bruce Bohannon is using the DF model on his Tiger, has anyone had any
> feedback on how it is doing?
> Thanks,
> Jim
> Louisville
Bruce Bohannon and his Flying Tiger will be at Bakersfield on Monday June 8
for a Exxon sponsered BBQ I will ask him and repost
Tim Barnes
Meangreen RV-4
In a message dated 07/07/2002 12:34:42 PM Pacific Daylight Time,
MeangreenRV4(at)aol.com writes:
> Tim Barnes
> Meangreen RV-4
What time? And what part of town?? :-)
Jim Ayers
In a message dated 7/7/2002 3:34:50 PM Pacific Daylight Time, LesDrag(at)aol.com
writes:
> 8
> > Tim Barnes
> > Meangreen RV-4
> Jim Ayers
7:00pm at L45, this is a Chapter 71 meeting / BBQ
is that June 8th, 2003 ? ?
----- Original Message -----
Subject: Re: Rocket-List: 3 blade prop
From: | "Bob & Toodie Marshall" <rtmarshall(at)osbtown.com> |
Hello Rocketeers! How many of you folks out there with flying rockets
are having minor oil cooling problems? I have been having problems when
I slow down to enter a pattern, this apparently is normal, angle/ vs. /
airflow, some discussion can be useful to attempt to drop temps 20
degrees, this would allow some latitude and a little bit of slow flying.
My temps reach 225 Deg. after landing and run around 195 to 205 at
cruise, still using mineral @ 50 hrs, Has anybody seen a temp drop after
switching to multigrade. My cooler is mounted at rear cyl, left aft
baffle, this is the Stewart Warner that's recommended. any discussion ,
ideas would be helpful to all. thanks for your time. Bob, Truckee,Ca
Temps of 195 to 200 are just about perfect for cruise temps. Red line
is
245 and Lycoming reccomends for long life to keep cruise temps below 220. I
would say that having your oil heat up when taxiing in are no big deal. I
notice no difference in oil temps with different oils.
Tom Martin
[mailto:owner-rocket-list-server(at)matronics.com]On Behalf Of Bob & Toodie
Marshall
Subject: Rocket-List: Cooling
In a message dated 7/10/2002 11:52:31 AM Central Daylight Time,
fairlea(at)execulink.com writes:
> line is
> I
Bob:
I concur with what Tom Martin says above.
I did some manipulation of my cooling system to reduce theleakage and burbles
inside the pressure chamber -- this made a substantial difference. Heck, and
I'm running one of those small Setrab coolers! Have a look at the duct
leading to the cooler -- I'll wager it has a substantial bump at the upper
area of the inlet, maybe causing some turbulence inside the cooler duct.
I replaced all the rubber around the perimeter of the cooling chamber with
short pcs of formed angle, and then laid a sheet of 032 6061 over the top,
more or less making a plenum chamber. It works good, but I need to smooth the
flow over the rt rear cyl a bit by adding a curved pc of aluminum at that
upper square corner.
The outlet area is generally enough, as long as you have a support to keep it
open in flight!
Cheers!
Mark
Team Rocket LP
Maybe this idea has been put forth before. I don't recall it though.
I was at Walmart last night and found a 12' rope light for $8. It's the
stuff that can be used for decorative lighting around fireplaces, etc.
Sorta like Christmas lights except that the lights are protected inside
plastic tubing.
So what? Well, this is just the ticket for extra light inside a wing panel
during riveting since it's not too bright and doesn't get hot. I plan to
use my rope light in about a month when I close the rear fuselage of the
Rocket. I'll have a cool, flexible light that won't break, blind, or burn
me while I'm squirming around inside!
Our Walmart was also clearing out mini die grinders, cordless drills, and
Black and Decker's version of a Dremel tool. The B&D unit is FAR, FAR
superior to the Dremel, BTW.
Vince Frazier
1946 Stinson, NC97535, flying
F-1H Rocket, "Six Shooter", N540VF reserved,
canopy installation stage
http://www.usi.edu/science/chemistry/vfrazier/page1.html
Subject: | engines for sale |
Hi Fellas:
An HR2 builder in Daytona called this AM -- seems a local fella has 2 ea
IO-540s to sell -- might even have time left one 'em, as the price ($8500
ea?) is a bit higher than a core price would be...
Call Pat Elliot at Blue Max A/C Engines: 386.485.0088
Good luck!
Mark
Hey Mark,
Sound like a good idea. Next time you pull your cowl, take a picture of
your cooler for us all copy.
Jim Stone
Subject: Re: Rocket-List: Cooling
Red
> > line is
220.
> > I
I
> Bob:
burbles
and
the
it
> open in flight!
> Cheers!
> Mark
> Team Rocket LP
Subject: | Fwd: F-1 Rocket For Sale |
NOTICE:...PRICE OF THE F-1 ROCKET KIT HAS BEEN REDUCED TO $ 64000.00 FOR
IMMEDIATE SALE..
Date: Fri, 28 Jun 2002 10:42:24 EDT
Subject: F-1 Rocket For Sale
F-1 ROCKET QUICK BUILD KIT FOR SALE. iNCLUDED WITH THE KIT, IO540-D4A5, 285
H.P. First run wide deck Eng. Professionally built by Bart LeLonde of Aero
Sport Power. Enging has New Millenium Cylinders with 9:2/1 pistons, New Con
Rods w/ high strength Con rod bolts, Jeff Rose Electronic Ign, New starter,
alternator, New Overhauled Bendix fuel injection with the 95' ell, Flywheel
with ring gear, Vac. pump w/adapter, Oil filter adapter w/ filter and
vernatherm valve. Fuselage is on gear, Wings are completly built, with
landing lights in each wing, wing tips complete with strobes/nav lights in
each wingtip, The tail is the F-1 tail and is completed, Brake pedals are
primed, painted and mounted, along w/ master cyl., Torque tube finished,
Electric flaps installed, Batt. box and Elt tray primed, painted and
installed, along w/ master solonoid, Windshield bow promed painted and
installed, front seatback support finished primed and painted, All interior
including baggage area, primed and painted. (A med. grey. ), All interior
upholstry panels cut to size, With finish kit, all components to finish the
kit. Approximately 400 hours labor in kit. Reasonably priced at $
66,500.00. Contact me off line ONLY at 254 853-2426, or email
jones15183(at)aol.com. ...............................SERIOUS Inquiries only.
thanks, Billy Waters
Subject: | Re: Rocket-List Digest: 1 Msgs - 07/09/02 |
I think that we Rocketeer's should announce that there are "X" number of RV's
flying and add the number of HRII's and publish the total. We could upstage
Van everytime he comes up on a significant number, and emphasize that we are
proud of our crafts heritage, even if RVG is ashamed of our little "bastards"
with the big engines.
83 HR II,s is the last count I got.
Van's looking down on HRII's ?, (IMNSHO) I don't think so. You can't buy
a -4 kit but you can still get that which is required to complete an HRII.
Lawsuits could be the reason Van's is MUM on talking or giving any type of
approval for any modifications. Why would anyone take on any respocibilty
for F-2, HRIII etc without control. No one (including HR hisself) has bad
mouthed Van for his stand
in my presence. HRII #78 N561FS. KABONG
Subject: Rocket-List: Re: Rocket-List Digest: 1 Msgs - 07/09/02
Think you Jonn, Well said.
The Rocket Man.
Jack, I just looked at Van's web site and the RV-4 kit is still there. The
RV-6 and RV-6A don't have kit prices. There may be other changes but those
were the ones I saw.
Tom Gummo
Subject: Re: Rocket-List: Re: Rocket-List Digest: 1 Msgs - 07/09/02
> To:
BTW, didn't someone on the list reort that Van's said when asked about the
RV-$ kit.
"What would the rocket boys do if I stop making the RV-4 kits?"
Tom Gummo
Apple Valley, CA
rocket #78
OK, OK. Damn, Ole Gummibear won't let me git 'way wit nothin.
Question ? ? What would happen iff'en Van's started to pre-punch the -4
kits like he's been a do'n with the rest of the pack. I would ask: How
many -4 complete kits has Van's sold since the -8 and how many "parts" to
new builders ? I guess I could ask Vans or JH hisself, BUT I really don't
want to know. As my ole pappy usta say, let sleeping dogs lie less they
awake & bite ya'll where it hurts. KABONG
The
those
Yes. Van did say at Sun'n fun that he would not have any orphens, and what
would the rocket builders do if we did not have the 4 kits. Terry E. Cole
I was departing SNA - John Wayne/Orange County/Santa Ana airport and a
VERY pleasant female controller asked me if I knew a Rocket driver named
Rick who was flying from SNA to Payson AZ.
I said "Screw Rick. My Rocket is faster and climbs higher and Baby,
I'm Rob.
I'll make room in the back seat. I'll return and slip it on in!"
Unfortunately, I said I would put out her personal ad on the net
server......
Hot SWF seeks Rocket driver named Rick.
Share romantic fantasy at disneyworld - afterward we'll indulge
ourselves on my radar screen. You bust the minimums and I'll discipline
you.
Looks/age unimportant - send photo of Rocket, c/o Control Tower SNA.
Hey Rick, I'm heading back down today and brought my Mickey Ears!
Damn Right Archive
Thanks for the entertainment Rob!
\"Dotty Ray\""
This for the followers of the list that recall my search of
information on behalf of one of my EAA Chapter members. Byron Cannon,
the N-11 builder, is fading fast. As you know the chapter members put
the finishing touchs on his plane and attempted to fly it at least once
while he could still get to the airport to see it. He had used a VW
engine for power and during taxi tests one of the spoke wheels folded
under due to side stress. The second attempt was to fly with repaired
gear only to have the tail wheel prove to be ineffected in control and
some damage was done to its attaching points. The plane was taken back
to the hanger without flying with yet another folded wheel..
That was several weeks ago and now it appears to be too late to get
in a flight for him. His family would like to sell and/or donate the
plane for display. We have new wheels (light motorcycle) for the plane.
If you have or know of who would be interested in obtaining a
beautiful N-11 please advise on-line.
We at the chapter are planning a service and missing man flight for
his family. Byron was one of the C-46 pilots that flew CAF's China Doll
in Southeast Asia when they were both in the service of their country.
KABONG
You may be a Redneck pilot if:
1. Your stall warning plays DIXIE.
2. Your cross-country flight plan uses flea markets as checkpoints.
3. You think sectionals should show trailer parks.
4. You've ever used moonshine as AV-Gas.
5. Your 172's wheel pants have mud flaps with a chrome silhouette of a
reclining nude.
6. Your toothpick keeps poking your mike.
7. You've ever taxied around the airport just drinking beer.
8. You wouldn't be caught dead in a Grumman Yankee.
9. You use an old sweet mix sack as a windsock.
10. You constantly confuse "Beechcraft" with "Beechnut."
11. You've never flown a nose-wheel airplane.
12. You refer to formation flying as "We got us a convoy."
13. Your matched set of lightweight flying luggage is 3 grocery bags from
Piggly Wiggly.
14. You have a gun rack in the rear window.
15. You have more than one roll of duct tape holding your cowling on.
16. You figure mud and manure in your weight and balance calculations.
17. You siphon gas from your tractor to go flying.
18. You've never landed at an actual airport even though you've been flying
for over 20-years.
19. You've ever ground looped to avoid hitting a cow.
20. You consider anything over 500-ft AGL as High Altitude Flying.
21. There are parts on your aircraft labeled "John Deere."
22. You don't own a current sectional, but have all the Texaco road maps for
your area.
23. There's a brown streak down each side of your airplane; exhaust on the
right side and tobacco on the left.
24. You have to buzz the strip to chase off the livestock before landing.
25. You use an old parachute for a portable hanger.
26. You've ever landed on Main Street for a cup of coffee.
27. The tread pattern, if any, on all three of your tires is different.
28. You have a pair of fuzzy dice and some small copper shoes hanging from
the Magnetic Compass.
29. You put straw in the baggage compartment so your dogs don't get cold.
30. You've got matching bumper stickers on each side of the vertical
stabilizer.
31. There are grass stains on the tips of your propeller.
32. Somewhere on your plane, there's a bumper sticker that reads "I'd rather
be fishing."
33. You navigate with your ADF tuned to only AM country stations.
34. You think an ultra light is a new sissy beer from Budweiser.
35. Just before the crash, everybody on the UNICOM heard you say, "Hey
Y'all-Watch This!"
Subject: | Re: RV-List: UPSAT GX60 -- 4G maximum?! |
"rocket-list(at)matronics.com"
Dan--
Obviously, you've never operated a high-energy particle accelerator! Ah, the
memories of Brookehaven and Switzerland at CERN. Electrons have mass (let's
say about 10 GeV (giga electron-volts) and mass is affected by gravity. We
also know that a GPS receiver is nothing more than a VERY sensitive clock.
Now, then, when you exceed 4 g, the electons get bogged down in the GPS
receiver and get out just a tad slower--but slow enough to be detected by the
GPS clock. If you're tracking more than four GPS satellites, some of them
will be to the West and some of them to the East of you. The slow electrons
will make the GPS clock think that you are farther away from the westerly
satellites and perversely conversely farther away from the easterly
satellites so that the triangulation calculations in the software will not
reconcile. GPS receivers that are rated for aerobatics have thicker wires
and a series of small op-amps that will "accelerate" the electrons depending
on the internal g-meter reading (manufacturers call this "g-force electron
drift"). This is why airplanes such as the Extra 300 cost so much more. You
also made a major mistake in actually reading one of the manuals for
electronic equipment, since they have to be back-translated from Chinese
character figures--what's the Chinese character for electron-volts?
Just trying to help.
Boyd.
Dan Checkoway wrote:
> --> RV-List message posted by: "Dan Checkoway"
> In the specs for the UPSAT GX60 IFR GPS/Comm, it says:
> "Acceleration 4G maximum"
> Anybody know what the deal is with this? Is this horizontal acceleration?
> )_( Dan
From: | Scot Stambaugh <stambaug(at)qualcomm.com> |
Ooooohhhh man is it getting thick out here;~}
More than likely the G-limit has to do with the packaging and mechanical
strength of the unit. Often circuit boards are held in the chassis with
plastic clips and other similar medium duty hardware. Internal wiring is
connected to the circuit boards through connectors. The connectors are
soldered to the circuit board and the mass of the wire harness would pull
at the solder joints under high G loads. We used test out boxes at 6 G
continuous and 10 G spike but our units were fixed in a large rack of
equipment and only had to withstand earth quake type activity.
scot
At 11:52 AM 7/26/2002, you wrote:
>Dan--
>Boyd.
> > )_( Dan
For what it is worth a GPS receiver tracks the GPS satellite's signals with
what is called a phased lock loop. This phased lock loop uses an estimate
of where the vehicle is to assure that the loop locks onto the correct cycle
in the transmitted signal. This works fine in slow moving vehicles, such as
cars, or fixed location survey instruments. For highly maneuverable
vehicles, such as aircraft, the loop will loose lock unless it is aided with
a prediction capability that provides an estimate of acceleration between
update times. The UPSAT GX60 IFR GPS/Comm receiver probably does not have
an acceleration aiding device, such as an accelerometer, to aid in the
trajectory prediction process. Military aircraft use their inertial
navigation systems to provide a "precise" estimate of the vehicles location
to aid the phase lock loops in their GPS receivers when undergoing highly
dynamic maneuvers. As you well know, the cost of military systems are beyond
the range of many weekend aviators.
Subject: Rocket-List: Re: RV-List: UPSAT GX60 -- 4G maximum?!
> Dan--
the
(let's
We
the
electrons
depending
You
> Boyd.
acceleration?
> > )_( Dan
Subject: | Engine and prop for sale |
Folks,
I have an IO540 C4B5, 285hp engine for sale. Engine has been completely
overhauled by Don George in Orlando and comes with started, alternator,
airflow performance injection kit, and Rose electronic igntion. Asking $26k.
Also, I have a new Hartzell 3 bladed prop for sale. Asking $6900.
Please email me or call 561-373-3797.
Scott
Subject: | Re: Engine and prop for sale |
Scott... I would be interested in that prop.
Regards, John
John Meyers Golden, CO HR2
Rocket II's rule at Oshkosh 02
Subject: | Re: (no subject) |
What happened? Did someone win Grand Champion? Did a bunch show well? Some
of us sat at home, TELL ALL! Congrats to John for the best home built design
out there, lazy man copies included(mine).
Howard
Congratulations To Alan Webb , Medford Or. Grand Champion Oshkosh 2002 HR II
Congratulations David Howe Lemoore Ca. Reserve Grand Champion 2002 HR II
Congratulations as well... Those projects were absolutely #1 and deserved..
Larry F-1 #001
Subject: | RE: Rocket-List Digest: 3 Msgs - 07/29/02 |
FWIW, I was at Oshkosh from Sunday thru Saturday a.m. I'll try to get the pics
posted tomorrow if they're aren't any fires here at work to put out.
I counted at least 8 Rockets(or variants)attending. I tried to get pics of each.
I took a bunch of pics of David Howe's engine installation. Very nice stuff.
David was gracious enough to remove his cowling while Jim Stone and I were there.
Suddenly there were about 50 people around it. I had to wonder how many
of them were HR builders or just tire kickers? Anyway, you should have seen the
procedure that David used to get the cowl off without scratching any paint.
A real Mr. Gadget with all sorts of devices that did this and that. I particularly
liked the telescoping jack that he used to support the carb air inlet
during the lower cowl removal. I don't know if he'll win any awards, but it's
possible. At least he should get a "Wow, that's a bitchin' Rocket award." I'm
always patting myself on the back because I'm doing such a fine job on the
Rocket.... then I get a kick in the groin when I see the stupendous quality of
the stuff at Osh. Oh well, mine is for GO not for SHOW. :-)
Mark Frederick was there with the usual F-1 stuff. He also was showing a cockpit
mock up of the proposed F-2 Rocket. It's similar to an RV-6 layout but with
the option of tricycle retract.... COOL! I want one.
I finally got to meet John Harmon. Even got a way cool HR t-shirt from him to
strut around in at the EAA meetings. I'll have to update a few items on my website
based on info he shared with me. It was great to meet him and his new HRIII
was very cool to see also. WOW! looks like fun!
I should have my canopy bubble from Todd Silver delivered today or tomorrow. I'll
let everyone know how it looks. If it looks as good as the prototype he made
for me, it will be perfect. BTW, I saw lots of the stock RV-8 bubbles that
were at Oshkosh that were very wavy.... what's up with that? Yuck.
BTW, I looked everywhere for Luc and Fred. Wonder where they were?
Vince Frazier
CONGRATULATIONS!! Wow! I guess HRIIs did rule at Osh '02. Great job
guys. Looking forward to the write up and pics in SA. Maybe someone has
some pics that we could all view a little early?
David
Subject: Rocket-List: (no subject)
II
> John
We have a builder here at Apple Valley Airport who has won two awards at OSH
for an RV-4 and RV-6A.
He just laughs when he leaves my hangar {at least, he doesn't do it to my
face :-) }.
I am just glad my bird flies.
Please pass on my best wishes to the two award winners.
Tom
Apple Valley, CA
II
> John
WE WILL BE CROSSING THE BORDER IN WASHINGTON INTO CANADA ON AUGUST 24
FLYING THE ALASKAN HWY TO
WHEREVER THE WEATHER IS BEST! RETURNING TO THE US BORDER SEPT 1ST. NO
CAMPING MOTELS ONLY. IF YOU CAN (NOT WANT) TO GO AND HAVE A FLYING
AIRPLANE CONTACT ME.
HARRY PAINE
hpaine(at)earthlink.net
Guys,
It occurs to me that if you switched a few vowels around then Mark Frederick's
airplane would be "Chick Sex." Hmmmmmm, I like the sound of that. I wonder what
Cheryl would think?
Yes, yes, I have dain bramage from updating my website with Oshkosh pics. If you're
interested, click the url below and then browse around to the Airshow pics
link. Heck, I put pics everywhere.... pictures of various cockpits are in
the fuselage page and pics of David Howe's engine installation are on the engine
page. There are other pics scattered elsewhere..... even I can't remember
what I did with them all.
I'm gonna need a S-L-O-W airplane to commute to the airport. I can't get excited
about ultralights, but a Storch could be flown outta my backyard. Anyone know
where I can get a set of Slepcev Storch plans? Nestor won't sell 'em anymore
'cause he wants to sell the whole (grossly overpriced) kit.
Vince Frazier
<http://www.usi.edu/science/chemistry/vfrazier/page1.html>
Subject: | Re: canopy options |
In a message dated 8/1/2002 7:39:47 AM Pacific Daylight Time,
bipetype(at)hotmail.com writes:
> Hi Folks,
> Has anyone out there looked into building an F1 - either quick build or
> slow
> build - with a tip over canopy instead of the slider? Is it "do-able?" I
> like formation flying and it would be nice to not have to look around a
> windshield frame.
> Thanks.
> Tim - Pittsburgh
Why yes they have......its called a Harmon Rocket II
If you want that type of canopy on a "slow build" you need to get in touch
with John Harmon because I don't think Team Rocket offers it, and besides
John is the guy. John Lauer
Guys,
Lui was gracious enough to send me some more Rocket pics taken at Tom Martin's
recently. They're posted under the miscellaneous photos section about 1/3 of
the way down this page. There are 47 new ones.
http://www.usi.edu/science/chemistry/vfrazier/fuselage_construction.htm
Lui's pics are vastly superior in quality to the ones I took. I had a cheap digital
camera that wasn't worth the price of the batteries it used.
If you can't access my site, try again later. Our servers are having spasms today
and it's NOT your computer.
Have fun,
Vince Frazier
Hey Vince,
just wanted to tell you that I really appreciate your posts, and your great
website!
I have drooled over the Rocket ever since the II came out--even got a chance
to sit in John's original II at Sun-n-Fun a few years back.(Yes, us
"Bubba's", as Van calls large pilots, fit very well indeed in the Rocket!)
Anyway, I plan on building a Rocket in the future(have a rag n tube
taildragger I built and have been flying for a bit), and your GREAT info
really keeps me enthused about my Rocket project that WILL take place!!
This also goes for the rest of you builders/flyers of Rockets--keep it going
please!
Rick
http://www.hotmail.com
Does anyone know Alan Webb and David Howe's e-mail addresses? I would like
to congratulate them personally on doing the Rocket's so proud at the Big "O"
Les Featherston, morocketman@AOL
F-1 ROCKET KIT, ENGINE, PROP,INSTRUMENTS FOR SALE I have for sale an F-1
Rocket kit, a completely overhauled IO-540 C4B5 engine (overhauled by Don
George), and a new Hartzell 3-bladed prop. Instrumentation includes but not
limited to: new Garmin 250XL radio, fuel guages, fuel pressure, EI
volt/ammeter, manifold pressure guage, and more. Also included is a NavAid
autopilot unit. Unit servo is installed and attached to the torgue tube.
Wings are closed up and I have position and strobe lights as well as a tail
white light. Also included is a F-1 Rocket tailgroup. Skeleton is built,
ready to be skinned. This F-1 Rocket kit is extremely far along in its build.
Electrical sub-panel complete including all circuit breakers installed.
Interior Fuselage is complete. Fuel system complete with the exception of the
installation of the electric fuel pump (included). Engine has the airflow
performance kit, starter, alternator, Rose electronic ignition with the ring
gear for high powered engines. Master solenoid, starter solenoid are
included. Almost everything needed to complete rocket is included. Rocket
could be flying in approx 5 months with some effort. Will sell this plane at
an absolute steal at $70K!!!! I have much more than $70k in just parts for
this plane. This is your chance to get into a Rocket economically. Call
561-848-3418 or cell 561-373-3797.
From: | "Wilson, James Mike" <james.mike.wilson(at)intel.com> |
All,
I have an RV-4, AIO 360-200+hp angle valve, 125 hours. I won't go into about
the plane but it is very custom. It weights 1078 empty with wood prop. I
have a wood prop because I can afford a wood prop. In any case, the plane is
configured such that I can move the battery to behind the passenger (from
the firewall) to shift W&B to rear for either heavier CS prop or just to
make it more fun to fly. The problem with more fun to fly is less utility
W&B. My config right now is limited to 210lb passenger or 175 passenger +
25lb baggage. With battery in rear, keeping wood prop, I am limited to 175lb
passenger. Bottom line, I have learned that to keep the RV4 fun to fly, one
has to sacrifice utility. I am expecting this to be true with the Rocket
also. I know there is no free lunch.
My questions:
My empty CG % of MAC is 16.22%. What is typical % of MAC for a Rocket?
How do you manage W&B in a Rocket?
What are typical passenger / baggage capacities?
Is there a design description written up somewhere I could read?
Does anyone out there do real acro in a Rocket (i.e. competition)?
Thanks, Mike
Subject: | SearchingForParts |
Listers, Looking for:
1) Wheel pant mounting plates for HR-2
I see archive reference to Rob Attaway's. Any good ? Will they fit
Van's 2-piece
pants ?
2) Plastic laminate or sheet. What are trade names and where available ?
This would be laminate or sheet that could be cut to panel or sub-panel
shapes and
engraved with placards etc.
Thanks, John Meyers Golden, CO
Subject: | Re: Fw: Chub's Thoughts About Aviation |
hey your cool wanna be jet jockey you plagerised it from the classic jet
journal
what a low life give the credit where its due
Forwarded to me by my father, a retired jet jockey, who received it as a
forward from a long list of retired jet jockeys. I have no idea of the
original source, and have no pretensions about my own qualifications. Just
thought it was good reading.
Subject: Re: Rocket-List: Fw: Chub's Thoughts About Aviation
> journal
Congradulations Keith Peterson # 84 Harmon Rocket II To fly
Right on Steve. It was good reading. Some guys just don't know how to kick
back.....
Weav
> From: <Fouga434(at)aol.com>
> To:
> > journal
Congratulations to Keith Peterson upon flying his HRII. Does anyone have
his e-mail address or phone number?
Does anybody have a complete list of Rocketeers,
builders/flyers of Harmon Rockets?
Does
anybody have the equivilent of a P.O.H. for the Rocket? Checklists? That
they would not mind sharing without any liability assumed or expected. Use
at your own risk.
If not, does
anybody have an interest in assembling P.O.H. or checklists in a forum on the
internet? I have some ideas, but would certainly appreciate any feedback.
Thanks, Les Featherston morocketman(at)AOL.com 417-466-4663 Mt.
Vernon,MO HRII #127, N206KT, hope to fly
soooooooooooon!
Sounds like a great idea. I nominate you Les!
Jim
Subject: Re: Rocket-List: (no subject)
anyone have
Rocketeers,
> Does
Use
> at your own risk.
> If not, does
the
> soooooooooooon!
plagerism is the issue.... real men don't take credit for stuff of
others..... fellows you all support wanna beeee attitude the list was copied
verbatim from classic jet journal that arrived in my mail box the night
before......
go to cja website or get youir own issue its great reading but lets be honest
Get a life.........
copied
> before......
honest
I got one... seems like the walter mitties are flying steroided RVs with a
fourth lever marked afterburner
Subject: | Fw: Chub's Thoughts About Aviation |
[mailto:owner-rocket-list-server(at)matronics.com]On Behalf Of Fouga434(at)aol.com
* Rocket-List message posted by: Fouga434(at)aol.com
before
* Plagerism-smagerism. You think CJA originated that article? Versions
have been around since fighter pilots were first thought up. Like one of
the other guys said, "Lighten up!"
* Lee Taylor
May be an F1 builder?
Get a life and a spell/grammar checker!
From: | "Paul Besing" <azpilot(at)extremezone.com> |
He never took credit for the post in the first place!! If he printed it in
a magazine or newsletter or something, I could understand giving credit.
But an email to a list for entertainment?
Take some Xanex and relax my friend.
Paul Besing
RV-6A Sold (Waiting on the RV-10)
Kitlog Pro Builder's Log Software
http://www.kitlog.com
copied
> before......
honest
My father flew the T-6, F-80, F-84, F-86, F-100, F-102, F-106, F-104, and
some others that I forget, but he still remembers.
My brother flys F-18s and MD80s.
I fly a Volkswagen Jetta, no afterburner.
I don't "wanna be" anything.
Just a quick note to let folks know that in my weekly website update this week,
I posted a building tip regarding a way to secure the elevator trim hinge pin.
It's not particularly innovative and I didn't think of it first, but it is
a tip none the less just in case you've never seen it before.
The empennage is just about done and my QB should arrive in the next week or two.
Then the real fun will begin.
Have a great week!
Randy #95
http://mywebpages.comcast.net/f1rocket/
Subject: | RE: Rocket-List Digest: 17 Msgs - 08/23/02 |
SNIP plagerism is the issue.... real men don't take credit for stuff of
others..... SNIP
Holy $#%
! Please don't ever look at my website then. I think all of it is copied from
somewhere.
Studies show that 99.9999% of us never, ever have an original thought in our entire
lives, just replays of stuff that's been thought of before. The 0.0001%
who do are called geniuses. Ouch, the truth hurts.
Studies also show that ANYTHING found on the internet belongs in the 99.9999% pile!
Have fun and try not to take this digital age stuff too seriously!
All in fun,
Vince
Subject: | Re: good relations |
A good reminder for you too John. You've changed.
ROCKET-LIST POLICY STATEMENT: The purpose of the Rocket-List is to
provide a forum of discussion for things related to the construction
and flying the Rocket-series aircraft. This Rocket-List is intended
for use by Rocket pilots, builders and enthusiasts. The List's goals
are to serve as an information resource to its members; to deliver
high-quality content; to provide moral support; to foster comaraderie
among builders and pilots; to promote the construction of safe, well-built
aircraft; and to support the safe operation thereof. Reaching these goals
requires the participation and cooperation of each and every member of the
Rocket-List.
> From: Hr2pilot(at)aol.com
Ok all.... Can't we let this crap go? Let's get back to airplanes,
building and flying.
I finally got the white slip for registration of my Rocket. Now, the FAA or
a DAR can finally inspect it and sign it off. Hope to get it through the
process by October.
Weav
Subject: Rocket-List: Re: good relations
well-built
goals
the
> Rocket-List.
Subject: | Fuel Syst Question |
Guys... some data on this exists in Archives but I want some current
opinions.
FUEL SYSTEM. I have an overhauled RSA and most of the fuel feed system
from Airflow Performance. I am puzzling over that neato fuel filter, ...
like where to install it, if at all. Some of my RV friends here in DEN are
saying to install the fuel filter any which way, high or low, ahead of the
firewall... no gascolator ! Seems pretty experimental to me... I'm an
old-enough geezer to have flown many years exclusively behind firewalls with
those little metal or glass bottles sitting low, just above the hot exhaust
pipes. So far, so good.
As I think about it though, what the heck is a gascolator accomplishing
anyway if I put the AFP filter in-line. It will do a better job of particle
filtration than a gascolator screen, and ... I think it will be easier to
plumb ahead of the firewall. I am loath to place the filter under the cabin
floor... though I've seen it done.
Looking for water ? Still have the wing tank drains at the low points.
Opinions and or experiences please.
Thanks John Meyers Golden, CO HR2 1/2 done
Subject: | Re: Fuel Syst Question |
I used a fuel filter that is also a water catch. I mounted it just forward
of the fuel valve in the access area behind the firewall and between your
legs. My fuel flow transducer is also located in the same general area. This
keeps the area ahead of the firewall less crammed.......
Weav
Subject: Rocket-List: Fuel Syst Question
> opinions.
are
the
with
exhaust
particle
cabin
Subject: | Fuel System Question |
Hey John-
I don't have a gas collator on my rocket and here in Utah with an
average humidity around 20% I never see water in my fuel tank drain
samples. In 265 hours of flying I have had one engine cough. It lasted
about one second. I think it may have been water in the fuel after a
night in the Idaho back country. Can't be sure... but it may have been
moisture. My fuel filters are race car type about 1.5 in. in dia x 4"
long and are located between the tanks and the fuel selector valve in
the forward stick bay. They are easy to access for annual inspections
and are horizontally oriented. If you Velcro the stick surround panel to
the longerons/floor beams you won't need tools to access them and you
won't have as many ugly screws to look at. The filters rarely have any
dirt or debris in them - mostly just a tiny bit of lint.
Ron Carter N230RC
JOHNTMEY(at)aol.com
opinions.
system
are
the
an
with
exhaust
particle
to
cabin
John Meyers, forget the gascolator if its higher than your fuel drains in
level flight. if not it could catch that bit of water ? I use on one mine
but never get any H2O anyway ? most gas suppliers do a pretty good job of
water filtertration, as always we are the manufacturers. keep on trucking
you will be flying before you know it ! Bob, Truckee,CA ----- Original
Message -----
> opinions.
are
the
with
exhaust
particle
cabin
Subject: | Misc. Digest Comments |
Good Info on the #2 cylinder TT! I'm running hot #5 with runner up of
#2, Oil cooler behind #5
(would like some more info on the cooler scoop/baffle Bob).
The Desert Storm camo paint scheme is a thing of the past as N540RM is
in the paint shop. What next? a pillow for my butt?
Boyd, How are those girly, Patty Wagstaff muffins (Lord J-7764-31)
working out? Any apparent sag in the engine? I've got about 1/8" droop
after 180hrs.
Let's keep it lively!
John; I punch the sumps on my tanks very religiously and upon cleaning
the gascolator this annual I found some corrosion and in the bowl that had to
come from water. The aircraft was in the hanger while I was in Florida four
months. I power flush this with the boost pump on. I have the complete
Airflow system to which you are referring and they include drawings to
install. If you don't have them call Airflow. They are very accommodating. TT
in Indy
Subject: | Getting Bounced From Matronics Lists... |
Dear Listers,
I have two programs I run regularly to purge the various Matronics email
lists of bad email addresses. I referred to these as my Email Weasels and
there is a daily version that is run automatically every night at midnight
and there is a and a monthly version that I run by hand at roughly 30-day
intervals.
The Daily Weasel grinds through the 8 to 10mb of bounced email that is
generated each day looking for obvious things like "user unknown", "host
unknown", and other things that usually mean the user's email address
doesn't exist any longer. The Daily Weasel has been purging 5 to 10 email
addresses each night.
The Monthly Weasel gets more serious about the task and sends a single
message to each list member with specially generated headers and content
information. Any bounces or replies to these messages are considered
errors and the email address is eligible for purging. This program is
particularly useful for "weaseling out" email addresses that are actually
being forwarded to by another email address that is subscribed to a List
and otherwise would not be identifiable. The Monthly Weasel purges roughly
100 nonexistent email addresses each month when it is run.
To check to see if your address has been removed by either of the Email
Weasel programs, you can check the Weasel Status Web Page at the following URL:
http://www.matronics.com/unsubscribed
If you find your email address on the Weasel List, but are certain that
everything is working fine now, simply go the Matronics Subscription page
and resubscribe your address. No harm, no foul. The subscription URL is:
http://www.matronics.com/subscribe
That all having been said, I've noticed that the Daily Weasel may have been
getting a little too aggressive in purging addresses recently and a number
of people have written asking if and why they'd been dropped from the List.
A couple of months ago I rewrote the Daily Weasel program to include a
wider variety of errors and more aggressively purge. One of the new purge
criteria that I added seems to occur a fair amount of the time (Connection
Deferred) even though the address is really okay.
As of today, I've removed the Connection Deferred criteria from the Daily
Weasel Rule set and this should decrease the number of "false positives"
and unnecessary unsubscribed.
Again, if you get unsubscribed by either of the Email Weasel utilities,
simply go to the subscription page and resubscribe:
Best regards,
Matronics Email List Admin.
They that can give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety.
Benjamin Franklin
Historical Review of Pennsylvania, 1759
Can anyone tell me how much travel is required to get the flaps to 40
degrees? I'm building up the electric flap stuff and need to know the
amount of up and down motion needed at the aft end of the flap weldment.
Russ
HRII, Maui
Hi Russ,
I've got 5 3/4 inches of travel from flaps up to full down (42 deg). My
push tubes are 6 1/8" long.
Hope this helps.
Jim Stone
Louisville
Subject: Rocket-List: Flap travel
> Thanks,
> Russ
> HRII, Maui
Subject: | Re: Official Usage Guideline [Please Read] [Monthly Posting] |
Please remove me from the rocket list and the RV list. My plans to build will
be on hold for some time. Thank you.
Larry W. Carr (LarryWCarr(at)aol.com)
"RV List"
Subject: | Golden West Air Race |
The Aircraft Spruce Golden West Race was run today from Apple Valley
Airport.
Where were the RV series aircraft????
It turns out that only 19 planes entered.
The was only one Harmon Rocket and one RV-8.
There were 8 or 9 plastic planes. :-(
Anyway, I wasn't able to find any results.
Tom Gummo
Bouncing Three Pointers and Smooth as Glass Two Pointers :-)
Subject: | Re: Golden West Air Race |
Thats OK Tom everyone will get another chance on the Oct.11th Copperstate
Race. IF Jim (A/S Pres.) follows thru with plans for a high HP class at
Copperstate maybe we'll get the RV and Rocket racers at APV on the 10th and
ready to race on the 11th. For more info get a hold of Aircraft Spruce and
express your interest in same. KABONG
Subject: Rocket-List: Golden West Air Race
> Airport.
> Tom Gummo
"RV List"
Subject: | New Class for Copperstate Race in Oct. |
Below is an email I just recieved from Jim Irwin of Aircraft Spruce.
Below that is the news release for the race.
Anyway, if enough people will enter, he will start a new 180+ HP or
unlimited class for the race.
Time to show off those bigger engines.
John Harmon, you were going to Copperstate anyway, why don't you set the
pace?
As long as there are no more than two other unlimited racers,
I might be able to get a third place plaque. :-)
Tom Gummo
Apple Valley, CA
EAA Chapter 768 Pres
Owner of the Slowest and Ugliest Harmon Rocket - N561FS
but It is mine,
It is paid for,
and It flys great. (Thanks Van and John)
Subject: Re: Velocity Crash
> Tom,
> Thanks for the nice email on Friday regarding the Golden West Air Race and
> the update on the Velocity Crash. I'm glad that the guys got out of the
> aircraft OK! We appreciate all of the help you gave us once again at
Apple
> Valley; we enjoy sponsoring these races and working with the good people
at
> EAA Chapter 768. We certainly can have an unlimited class for the
> Copperstate and if we get enough entrants above 180 hp we will add the
class
> for the race in October; put the word out!
> Thanks again for all your help, and we'll see you next month.
> Best Regards,
> Jim Irwin
> President, Aircraft Spruce
AIRCRAFT SPRUCE SCHEDULES SEVENTH ANNUAL COPPERSTATE DASH AIR RACE
Corona, CA - Aircraft Spruce & Specialty will host the sixth annual
Copperstate Dash Air Race this October on Friday the 11th. Co-sponsored by
the EAA, the 286-nautical mile race is run between Apple Valley Airport
(APV) in Victorville, CA and Coolidge Airport (P08), south of Phoenix. Most
participants fly in the race and then visit the Copperstate Fly-In at the
new Phoenix Regional Grand Valley (A39) Airport which runs October 10 - 13.
The race is open to homebuilt and certificated aircraft, which race in
separate categories.
The four categories consist of Millennium, for aircraft with engines up to
180 horsepower; Phoenix for up to 160 horsepower; Flash Gordon for up to 120
horsepower and the Road Runners for those with 90 horsepower or less. Each
category will have separate divisions for Experimentals and factory built
aircraft. Pilots race against the clock and the three fastest times in each
group are the winners. Plaques and gift certificates totaling $4,000 are
presented to the winners each year during the Copperstate Fly-In Awards
Banquet.
Any pilot with current ratings and an appropriate airworthy aircraft can
enter. There is a $30 non-refundable entry fee, payable to Aircraft Spruce,
due with each entry form. All pilots must carry a $1 million liability
policy that covers their flying to, during, and after the race. Temporary
fuselage fuel tanks are not allowed and all pilots are required to obey the
FARs. The race requires VFR conditions enroute, which has never been a
problem in the past.
"The Copperstate Dash is an exciting air race," said Aircraft Spruce
President Jim Irwin. "People participate to have fun, and judging from the
quips we hear on the radio, they do have a good time. Some people take the
race very seriously, of course, but a lot of people simply run the course to
be able to say they spent a day as an air race pilot. Many of the
competitors come back year after year. It's a great way to get to a
fly-in."
Entry forms can be obtained by calling Jerry Aguilar at Aircraft Spruce &
Specialty: (800) 824-1930; fax (909) 372-0555; or write to Jerry at 225
Airport Circle, Corona, CA 91720. Forms must be submitted by October 7.
List,
I am about to label up my RV-8 panel and cockpit and was looking for some
recommendations on the best approach. My panel is "Van's gray" and am looking
to use black lettering. I would like to do this right the first time and make
it look professional.
Give me some help here,
Tom C.
RV-8 Fastback
List,
looking
make
Tom C.
RV-8 Fastback
Hi, Tom.
One of the most effective ways, and the least expensive, is Letraset
transfer lettering. This is a transfer type lettering, which you apply to
your panel any way you want, one letter at a time. It basically involves
getting the transfer sheets, which are available in well-stocked office
supply stores, then positioning the sheet where you want them, rubbing the
sheet over the letter being transferred with a pencil, which transfers the
letter off the sheet onto your panel. When the complete lettering job is
done, then a clear protective coat is sprayed over the top, and it looks
professionally silkscreened.
Properly done, the lettering applied this way is as durable as any
professionally done silkscreening job, and looks as good. The letter sheets
are available in multitudes of colors, sizes, font styles, just about any
way that you could possibly want. Check into the tutorial info that is
available, follow the instructions faithfully, and you will have a beautiful
job. It is somewhat demanding in that each and every letter must be
hand-transferred, and your job is only as good as the care you take to get
everything aligned and spaced properly, but it is an easy and cheap way of
attaining a professional, durable job. And isn't that what we all want?
I would caution that you not neglect the final clear-coat protective
finish. The lettering looks great as applied, and is pretty tough, but
without the clear-coat protective finish, it will get rubbed off eventually.
The whole idea is to do it right the first time, so that it doesn't require
redoing next year. Follow the instructions faithfully, and you will have
the least problems. I've been using these systems for what seems like a
hundred years, and every time I try to shortcut the system, I get to do it
over again, right.
Lee Taylor
From: | Hurd Maj Danny A <HurdDA(at)3DIV.USMC.MIL> |
TOM,
ANOTHER OPTION IS THE HANDHELD, SELF CONTAINED "BROTHER P-TOUCH" LABEL
MAKER. AVAILABLE AT OFFICE DEPOT/STAPLES FOR $39/49/59, DEPENDING ON THE
OPTIONS YOU WANT. TAPES ARE VARYING WIDTH FROM 3/8 TO 1", ABOUT $10 PER
TAPE BUT IT LASTS ALONG TIME. DIFFERENT COLORS OF TAPE AVAILABLE...BLACK ON
CLEAR, BLACK ON WHITE, RED ON CLEAR ETC.
NEAT THING ABOUT THE P-TOUCH IS YOU COMPOSE THE LABEL ON THE LCD SCREEN, AND
CAN CHANGE TEXT ATTRIBUTES LIKE FONT SIZE, BOLD, ITALIC, UNDERLINE, TWO-ROW
ETC. THEN HIT PRINT, PRESS THE CUT-OFF BUTTON, PEEL THE BACK OFF AND YOU
HAVE A PRE-SPACED, SELF ADHISIVE, DURABLE LABEL...IF ITS NOT THE WAY YOU
LIKE, CHANGE THE ATTRIBUTES AND PRINT AGAIN. MOST USEFUL FOR ME WAS THE
BLACK ON CLEAR. JUST LIKE 3M SCOTH MAGIC TAPE, THE CLEAR PART IS NEARLY
INVISIBLE.
DAN HURD
HRII 666XX
Subject: RE: Rocket-List: pANEL LABELS
List,
looking
make
Tom C.
RV-8 Fastback
Hi, Tom.
Letraset
over again, right.
Lee Taylor
Subject: | Re: pANEL LABELS |
Buy a sheet of rub on transfers from Aircraft Spruce. Those sheets have
have every control you can think of and then some. You can transfer the
whole word or control name at one time--not letter at a time. Much easier
to align. Clear coat afterwards of course. White on grey makes a very
readable combination. Black would work better however on a real light grey.
Works good, looks great.
Dave
Hey Fred Weaver--when is your rocket going to fly?? Missed you at Golden
West.
Dave
> List,
> looking
> make
> Tom C.
> RV-8 Fastback
> Hi, Tom.
is Letraset
sheets
beautiful
protective
eventually.
require
> over again, right.
> Lee Taylor
I'll offer yet another option.
I have a printer attached to my PC that is capable of printing using a
white ribbon. It is an ALPS-1600 printer. It is used to print color
photographs. If you want black lettering, then any printer will do.
Go to your local hobby shop and buy blank decal paper in 8.5 X 11
size. Compose all your labels using WORD or whatever and print them
out. Apply them with decal set and clearcoat after you're all done.
The decals are a little more tricky to apply than the clear label
stock, but easier to hide with the clearcoat. This is the closest
thing you can get to actual silk screening.
I do have a picture of my RV-6 panel on my website under "F1 Rocket
Project" and "Instrument Panel".
Randy
F1 Rocket #95
Date: Tuesday, September 10, 2002 10:45 pm
Subject: Rocket-List: pANEL LABELS
> List,
> for some
> am looking
> time and make
> Tom C.
> RV-8 Fastback
> _-
=======================================================================_
-= - The Rocket-List Email Forum -
> _-
-= !! NEW !!
> _-
-= List Related Information
> _-
Subject: | Re: When am I going to fly? |
Would love to fly tomorrow BUT....... I'm in the middle of moving my
residence up to Sutter Creek. It's sucking up all my time right now. I hope
to get down to Phoenix and get the airplane final inspected and it's ready
for gas. Won't be long...
Couldn't go to Golden West because of the move AND I have the Tailwind down
to swap out the oil cooler and associated oil lines. Also adding a
Vernitherm. The crankcase also seems to have developed a crack near the boss
that tensions the belt for the alternator. After we get a thorough
examination of that area I will either get it TIG welded OR will buy another
case. I'm sending the exhaust pipes down to Custom Thermal Coatings for
Ceramic coating. Bottom line? Tailwind ought to be flying again in about a
month.
Hope you enjoyed Golden West...
Weav
Subject: Re: Rocket-List: pANEL LABELS
> West.
> Dave
> From: "Lee" <leetay(at)idcomm.com>
> To:
> > List,
some
> > looking
> > make
> > Tom C.
> > RV-8 Fastback
> > Hi, Tom.
> is Letraset
to
involves
the
the
is
any
> sheets
any
> beautiful
get
of
want?
> protective
> eventually.
> require
have
it
> > over again, right.
> > Lee Taylor
From: | Scot Stambaugh <sstambaugh(at)qualcomm.com> |
Subject: | looking for rocket guy |
I met a Guy at the Bakersfield Rocket Fly-in who arrived in his purple and
gray Rocket with a Sierra Flight systems EFIS 2000 in the panel. If you
are out there on the list could you please respond as I have some questions
about where you mounted the AHRS unit in your airplane.
thanks,
Scot Stambaugh
Randy,
Better start putting a bug up Dynon's butt, as they claim a top speed of
220KT on the Dynon EFIS system. That should only eliminate about half of
their potential buyers! Or, maybe that is enough for an F1. ;-)
Russ Werner
HRII
> Randy
> F1 Rocket #95
> From: Ski2001a(at)aol.com
> > List,
> > for some
> > am looking
> > time and make
> > Tom C.
> > RV-8 Fastback
> > _-
> > _-
> -= !! NEW !!
> > _-
> > _-
Very funny. Won't be enough for mine.
That's one of the reasons for the backup airspeed indicator. The other
reason is so that I can tell my HR flying friends exactly how much
slower than me they are flying!
Blue skies.
Randy
Date: Wednesday, September 11, 2002 12:34 pm
Subject: Re: Rocket-List: Panel
> Randy,
> speed of
> half of
> Russ Werner
> HRII
> From: "Randy Pflanzer" <F1Rocket(at)comcast.net>
> To:
> using a
> color> photographs. If you want black lettering, then any printer
> will do.
> > Randy
> > F1 Rocket #95
> > > List,
> > > for some
> > > am looking
> > > time and make
> > > Tom C.
> > > RV-8 Fastback
> > > _-
> > > _-
> -= !! NEW !!
> > > _-
> > > _-
> _-
> _-
-= !! NEW !!
> _-
> _-
Without any further thought, I would call Jim Younkin at Trutrak. It is
supposed to be "trutrakflightsystems.com" , but I cannot get them on the web.
I use my search engine and type in "trutrak autopilots", and they come up
everytime. I purchased their DFC-250, and
although I am still a couple of months till flying, I am convincenced you
cannot do better. I checked all the features of everybody, and no one comes
close for the $$$$. The best part is that the TruTrak A/P has it's own
inertial platform. It is not dependent upon a turn coordinator or other
instrument. I consider this a fantastic redundancy feature, since it would
avoid the problems that besat (according to the latest accident reports)
John F. Kennedy, JR. and Govenor Mel Carnahan's accidents. Its like having
multi-instrument redundancy without having another instrument. i.e. I am
installing a vacuum gyro horizon, and the electric TruTrak A/P. If perchance
Dynon comes thru, the vacuum horizon goes in the hole where I planned an
electric turn coordinator.
Tell Jim I sent you and you"ll probably not get a discount, but it will help
to introduce you to one of the finest gentlemen in aviation, not to mention
the autopilot guru of the Century. (There's a pretty good joke hidden in
there!) Les Featherston
417-466-4663 HRII N206KT 97% finished only 61% left to finish!
Subject: | Panel Letters & Electrical |
Thanks guys... I got the idea on clear coat for placards now.
Electrical comment: Several months ago, someone asked if the RV8 (rear battery)
electrical kit from Vans would work in HR. I tried that and it has worked pretty
good. Nice to have Van's plan and all the parts. That long, expensive #2
cable from battery to starter-solenoid fits OK with the starter solenoid being
clamped conveniently to the engine mount in such a way as to make use of the
cable length without cuts. Still need to customize a #2 from the solenoid
to the starter. This process brings up a couple questions: I got advice that
my new Sky-Tec starter has a built-in solenoid and doesnt' need another ship's
solenoid. Yikes ! Is that true ? (in which case the big ole' #2 is too
short) and ...
(2) the ship's starter solenoid should be mounted horizontal so that g-loads won't
close it (engage the starter)... almost sounds like urban legend ... anyone
have advice on that ?
From: | "Dallas Benham" <dlbenham(at)smithville.net> |
Subject: | Re: Panel Letters & Electrical |
John: the following is from Sky- tech advertising skytecair.com I believe
the solenoid you
are referring to is the actuator. See next to last line in the ad below. (I installed
a sky tec on
398DB and used the original firewall mounted starter solenoid. Works great!!!!!)
Highly
recommended
by me since my original Delco-Remy puked!
Dallas
Specifications:
Type: 6-Pole Permanent Magnet, 4.3:1 planetary gear-reduction.
Weight: 7.8 pounds.
Power Output: Typical 2.03BHp @ 90% of rated battery voltage.
Torque: Typical 230 ft/lb @112 RPM @ 90% of rated battery voltage.
Current: Typical, cranking new IO-540 @ 160RPM:
185A @42ft/lb (12 Volt Starter)
95A @ 42ft/lb (24 Volt Starter)
Actuator: Electromechanical Solenoid (no Bendix Drive!)
Mount: Precision-machined cast aluminum
Hi John, Likewise on my Sky-Tec starter. Used the ships existing solinoid
with good results. I love the starter as my RV-4 powered with Lycoming
IO-360 will almost taxi to the end of the runway with starter power alone.
Of course I don't do this because with that much torque the engine (usually)
starts on the second blade. By the way, how much "g" loading did you
calculate would be required to close the horizontal starter solinoid??? As I
recall, you are too old for 7 or 10 "g"s! My old fighter pilot "roids"
cannot stand over two "g"s anymore. Sorry, I forgot the list was not for
personal info.
You guy's who are flying (Rocketeers), please
keep telling us who are building (Rocketears) how great the Rocket's are.
Les
Featherston HRII #127 N206KT 97% finished only 61% left.
Rocket men,
If one were to take on a Harmon project, would an RV-8 tail be desirable over
the stock -4 tail? If so, how adaptable is a -8 tail to the -4 fus?
Bryan
The trip to alaska in 266HP was great. She flew like a swiss watch. 6100
miles 32.5 hours 320 gals, flew real low power setting of 2200 rpm and 20"
at 8-10 K averaging 11.5 -12 gph 170 -180 kts true. To bad so sad to those
who bailed out on me! you guys missed a terrific time. 266hhp flew so well
when I got her trimed out and had flown an hour or so & getting butt freeze
I would have my 25 yr old son matt take over for a while so I could stretch
then I would notice we were slightly off course but still straight & level
and I would ask "You got it? Hed say I thot you did!! This must have
happened at least five times on the trip. For those that are interested in
the full blow trip report & pictures email me off the list ! & when I get
done with everything I can email you.
Harry Paine
266HP HR11a
Bryan
I have used an RV8 tail on both of my HRIIs. It is a lot easier to build
than a 4 tail and I believe the added vertical tail surfaces are a benefit.
Some argue that the elevators are a little small but I can only say that I
have not experienced any problems.
Tom Martin
[mailto:owner-rocket-list-server(at)matronics.com]On Behalf Of Pender
Subject: Rocket-List: Tail feathers
Rocket men,
over the stock -4 tail? If so, how adaptable is a -8 tail to the -4 fus?
Bryan
Harry
I think a full blown report of your trip, on this list, is in order. My
longest flight to date is from southern ontario, canada, to Prescott
Arizona. These planes are amazing cross country machines. Tell us about
your adventure to Alaska.
Tom Martin
[mailto:owner-rocket-list-server(at)matronics.com]On Behalf Of Harry Paine
Subject: Rocket-List: Alaska trip
Harry Paine
266HP HR11a
Bryan,
An F-1 tail would be even better for more tail surface, and are
available through Team Rocket. They are more like an RV-4 tail to
build.
Loren Harmon
>Harry
> order. My
Hm I might but Don't want to bore everyone with details that don't concern
aviation but I think for my own benefit are needed.
here is just one pic. The two guy in front of the damn good airplane DGA-15
howard are my son (tall blond guy) and Lynn Ellis
onwer of ellis air service who gave us a flight seeing ride in the howard
over wrangell national park. It was spectacular!
Harry
>Tom Martin
>From: owner-rocket-list-server(at)matronics.com
>To: Boyd C. Braem
>Harry Paine
>266HP HR11a
Subject: | Re: Tail feathers |
In a message dated 9/12/2002 10:55:18 PM Central Daylight Time,
pender(at)airmail.net writes:
> Bryan
Hey Bryan:
The 4 emp allows some wiggle in turbulence (smallish V sfcs), but has the
correct elev sizing. The -8 emp reduces the wiggle, but the elevs are right
at min size. The F1 emp has the best of both, plus the better TE design and
attach points.
All will fit the same attach points on the fuse.
Cheers
Mark
Subject: | More on tail feathers |
Who can tell me, of all the rv series which has the elevator with the greatest
surface area? (aside from the F1 which I assume is the largest).
Bryan
Guys,
A Rocket won his class in the last Golden West Air Race:
Unlimited Place Pilot - Aircraft - Time - Avg. Speed Kts
1st Jim Webber - Harmon Rocket 260HP- 1:41:11 - 199.24
2nd Doug Shell - Velocity 300HP- 1:49:14 - 184.56
They fly GREAT. Thanks John and Van.
Tom Gummo
Apple Valley, CA
N561FS - Flying Rocket #78 -
Subject: Re: Rocket-List: Panel Letters & Electrical
solinoid
(usually)
As I
> personal info.
please
> Les
There you have it! Thanks Mark!
BP
Subject: Re: Rocket-List: Tail feathers
desirable
fus?
> > Bryan
> Hey Bryan:
right
and
> attach points.
> Cheers
> Mark
John--
1. Advice from Robert Nuckolls (host of the AeroElectric List) is to use a separate
contactor with an IN5400 diode (Radio Shack) across the coil (your contactor
may have the diode built-in) with the Sky-Tech starter. From the contactor
to the starter, you can use #2 welding cable which is much more flexible and
doesn't have to be "clocked".
2. The g-forces that we see in our planes will not close the starter contactor
points.
Boyd
RV-Super 6
Venice, FL
pretty good. Nice to have Van's plan and all the parts. That long, expensive
#2 cable from battery to starter-solenoid fits OK with the starter solenoid being
the cable length without cuts. Still need to customize a #2 from the solenoid
short) and ...
won't close it (engage the starter)... almost sounds like urban legend ... anyone
Harry--
That's almost exactly what I get with 325 hp and 50% power. 9,500 - 10,500
msl, 19 - 20" map, 2200 rpm, 11.5 gph and 195 mph. Hartzell M2YR 80" prop
and RSA fuel injection. LightSpeed EI and Bendix mag.
Let's hear about the trip!
Boyd
RV-Super 6
Venice, FL (second oldest avg. population in the USA)
> Harry Paine
> 266HP HR11a
Subject: | I once considered this airplane |
MY Opinion only
Questair Venture unsafe at any speed!!
A former fighter pilot was killed at the Reno National Championship Air
Races when his sport class racer disintegrated at about 300 mph and plunged
100 feet into sagebrush.
Tommy Rose of Hickory, Miss., a member of the Mississippi Air National
Guard, died Friday in the crash directly opposite the grandstands at the
Reno Stead airport 10 miles north of Reno.
Reno Air Racing Association President Mike Houghton said in a statement
that the plane apparently got caught in wake turbulence or rough air from
another plane, which caused the plane's nose to bob and the tail to fall off.
Rose had been competing in the sport class since its inception in 1998. He
was making his fourth appearance at the annual air races.
It was the 15th fatality in the 39-year history of the races and the first
since 1999.
The race was red-flagged.
As other pilots began to land, another Questair Venture flown by Michael
Dacey of Pismo Beach, Calif., groundlooped off the runway and crashed after
two attempts to land, witnesses said. Dacey emerged from the plane unharmed.
"He touched down and kind of went off the runway, then powered up and went
around,"said fellow pilot Darryl Greenmayer."This time, the gear collapsed,
causing the plane to go left and groundloop, or spin around on the ground."
After investigators had a chance to check the scene, the afternoon's final
race was held with the unlimiteds taking to the air. Race officials said
the championships would continue through Sunday.
A moment of silence was observed before Saturday's sport class race.
Sport class planes are kit-built aircraft powered by a 650 cubic inch
engine in the 300 horsepower range. Questair produces one of the kits used
for the planes.
Information from: Reno Gazette-Journal
At the rate they are being crashed there won't be any left to fly
Harry Paine
Subject: | Knight Aircraft Upholstery for Rocket |
Rocket Builders:
I have been in the upholstery business for 28 years and have been making
upholstery products for kitplanes for 16 years. I have interior kits
available for the Harmon Rocket. I also have cabin covers and other items.
I am the supplier of upholstery products for several kitplane manufacturers.
A list of other kitplane interior products available upon request.
For more information, call Knight Aircraft Interiors, Inc., at (702)
207-6681 or e-mail me at knightair(at)lv.rmci.net. If you e- mail for
information, please mention either "Knight" or "Upholstery" in your
reference line so I can give your request my immediate attention. Photos
Sincerely,
KNIGHT AIRCRAFT INTERIORS, INC.
"Fly by Knight" Upholstery Products
Sam Knight
From: | "gretz aero" <warrengretz(at)gretzaero.com> |
"Tailwind-List" ,
"RV-List" ,
"Rocket-List" ,
"Lancair-List" ,
"Glasair-List" ,
"EZ-List" ,
"AeroElectric-List" ,
"Avionics-List"
Subject: | Gretz Aero at Copperstate |
Hello listers,
This is inform you that Gretz Aero will have a booth at Copperstate EAA Regional
Fly-In this year. The dates of the Fly-In are October 10, 11, 12, and 13th.
The Gretz Aero booth will be in booth spaces 11,12 and 13. Stop by and say hello.
We will have "show special" pricing on some popular items.
Copperstate is at a new location this year and is located south of the Phoenix metro area at the Phoenix Regional Grand Valley Airport (A39). Copperstate has a webpage at http://www.copperstate.org for more information.
You can visit the Gretz Aero webpage at http://www.gretzaero.com to get an idea of the Gretz Aero products before you arrive at Copperstate.
See you there!
Warren Gretz
Gretz Aero
720-308-0010 cell days
303-770-3811 home office, evenings and weekends
So is the rocket emp. sold as a kit or is it some parts changes to the -4
emp?
Also curious if or why not the titanium gear would fit on a -4.
Mike RV4
-----Original Message-----
> Bryan
Hey Bryan:
attach points.
Cheers
Mark
The F1 rocket tail kit is a complete kit, There are no RV parts included.
As for the titanium gear legs fitting a RV4, no, they will not. The motor
mount gear sockets are different. Modifying your project is always your
option, I like the feel of the titanium gear legs.
Tom Martin
[mailto:owner-rocket-list-server(at)matronics.com]On Behalf Of Wilson,
James Mike
Subject: RE: Rocket-List: Tail feathers
emp?
Mike RV4
> Bryan
Hey Bryan:
attach points.
Cheers
Mark
From: | "Kendall Garrison" <kgarrison(at)hot.rr.com> |
Subject: | Re: Knight Aircraft Upholstery for Rocket |
Please send some info my way. I am working on an F1 Rocket and will need
some interior work down the road and want to check out all my options. My
physical address is:
Kendall Garrison
9513 Casa Grande
Woodway, TX 76712
Kendall
----- Original Message -----
Subject: Rocket-List: Knight Aircraft Upholstery for Rocket
> Rocket Builders:
items.
manufacturers.
> Sincerely,
> Sam Knight
I am creating a document and I need V-speeds for the rocket. Does anybody
have a good estimate for the following:
Vx Best angle of climb
Vy Best Rate of climb
Vso Stall dirty
Vs1 stall clean
Va Maneuvering speed
White arc
Green arc
yellow arc
Vne never exceed
Thanks for your help,
scot
For an HRII contact John Harmon: hr2pilot(at)aol.com
For an F-1 contact Mark Fredericks: mlfred(at)aol.com
> Vso Stall dirty
> Vs1 stall clean
> White arc
> Green arc
> yellow arc
> Vne never exceed
> scot
As much as I hate to part with this plane I cannot own two rockets at the
same time. My next project is nearing completion and I am selling my Harmon
Rocket. This is the third airplane that I have build, and the second
rocket. It is well equiped, 150 hours TT. If you are interested, or know of
some one who is, please email me privately at fairlea(at)execulink.com or call
519-631-1369. Please forgive me for this commercial email, I will not abuse
the list further. Thank you
Tom Martin
Subject: | Re: rocket for sale |
Most rocket folks, being of kindrid spirit in some ways, need to know
this.. what is this next project?? I mean you are giving up a flying
rocket for it.... :)
Subject: Rocket-List: rocket for sale
the
Harmon
of
call
abuse
Tom Martin
I am working on a F1, all the pieces are in place, and I am looking forward
to another first flight later this year or early next.
Tom
the
Harmon
of
call
abuse
Tom Martin
>Hi!
>I have just searched the internet for the word "bakoland", and I got a hit
>on this web-address:
>http://www.ultraviolet.org/mail-archives/matronics.2000/22020.html
>Here you posted a message entitled "Rocket-List: Annual Bakoland BBQ" on
>2000-06-05. You see, this word has a special meaning to a lot of people in
>Norway. It is a kind of slang for a place where everything is messed up
>and people have gone crazy, though almost always used in a positive sense.
>I would be very pleased if you could briefly explain what the word means
>in the context you used it. It may sound like a geographical site. Could
>this really be true? It would have been amazing if there in fact exists a
>place called Bakoland.
>Regards,
>Halvor Midtfjellse
>Oslo, Norway
>email: halvormidtfjellse(at)hotmail.com
>MSN Photos is the easiest way to share and print your photos:
>http://photos.msn.com/support/worldwide.aspx
E:\EUDORA\OUTGOING\OUTGOING\ROCKET\PICTURES\ROCKET.JPG;
E:\EUDORA\OUTGOING\OUTGOING\ROCKET\PICTURES\ROCKET2.JPG;
Kendall,
Thank you for your inquiry about Rocket upholstery products and request for
photos. Samples of fabrics will be provided upon request. Please indicate
what type fabric you are interested in and what color range. The photo of
the canopy cover shown is for the RV-8 but is similar to the Rocket cover.
As I mentioned before, I have several interior upholstery products for other
models of kitplanes. Prices and photos are available.
If you have any further questions or comments or if you were unable to read
any attachment, please let me know. You may contact me at telephone number
(702) 207-6681 or e-mail: knightair(at)lv.rmci.net. If you e-mail, please put
"Upholstery" or "Knight" in your reference line so that I may give your
As I have attached pricing and product information below, be sure to scroll
down to find this information.
Sincerely,
Sam Knight
_____MORE INFORMATION FOLLOWS_____
1439 South Abadan Street
Las Vegas, Nevada 89142-3713
Phone: (702) 207-6681
Fax: (702) 207-4780
HARMON ROCKET
SEATS - STANDARD FOAM CUSHIONS UPHOLSTERED
Cordura . . . . . . . . . . . . . . . . . . . . . . . $ 445.00
Velour . . . . . . . . . . . . . . . . . . . . . . . $ 480.00
Tweeds . . . . . . . . . . . . . . . . . . . . . . . $ 480.00
Leather . . . . . . . . . . . . . Call for Information/Pricing
SEATS - TEMPERFOAM - ARE SUNMATE CUSHIONS UPHOLSTERED
Velour . . . . . . . . . . . . . . . . Call for Information
Cordura . . . . . . . . . . . . . . . Call for Information
Tweeds . . . . . . . . . . . . . . . . Call for Information
Leather . . . . . . . . . . . . . . . Call for Information
Seats are pleated through 1/2 inch foam and velcro in place for easy
installation and removal. Seats can be made with or without lumbar support.
Front bottom cushion is cut out for crotch strap. If you do not need the
crotch strap cut out, please let me know. The builder needs to make a
platform for front seat bottom. Temper foam can be used for cushions.
Please call for more information. I also have back pads and booster cushions.
CARPET BY THE YARD
. . . . . . . . . . . . . . . . . . . . . . . . . . $ 20.00
CORDURA BY THE YARD
. . . . . . . . . . . . . . . . . . . . . . . . . . $ 17.50
VELOUR BY THE YARD
. . . . . . . . . . . . . . . . . . . . . . . . . . $ 27.00
TWEEDS BY THE YARD
CANOPY COVER . . . . . . . . . . . Call for Information/Pricing
The canopy cover is made of Evolution 4 fabric and is water repellent and
will not rot or mildew. Nylon straps wrap around the aircraft to secure the
canopy cover in place. A storage bag is included for the canopy cover.
Colors include shadow gray as the standard color with optional colors of
desert tan and harbor blue.
UPHOLSTERY COLOR CHART
CORDURA
1A - Beige
4A - Red
5A - Burgundy
6A - Green
6B - Forest Green
8A - Royal Blue
8B - Navy Blue
9A - Gray
10A - Black
VELOUR
V1 - Beige
V2 - Red
V3 - Maroon
V4 - Black
V5 - Gray
V6 - Charcoal
V7 - Royal Blue
V9 - Forest Green
V10 - Turquoise
V11 - Mauve
V12 - Brown
TWEEDS
Black
Blue
Gray
Sand
Turquoise
Green
Burgundy
Brown
Teal
LEATHER - Call for Colors Available
Fax: (702) 207-4780
O R D E R F O R M
To place your order, please call KNIGHT AIRCRAFT INTERIORS, INC., at
telephone number (702) 207-6681, between the hours of 9:00 A.M. and 5:00
P.M. (Pacific Standard Time), Monday through Friday. For your convenience,
you may also copy this order form and mail or fax it to me. When your order
is received, I will call you to review the options and confirm your total
charges (including any applicable shipping and handling charges). For this
purpose, please include your daytime and evening telephone numbers. Thank you!
SOLD TO:
Address: _______________________________________________________
City: ________________ State: ______________ Zip: __________
Telephone: (Day) ________________ (Eves) ____________________
SHIP TO:
(No Post Office Boxes)
City: ________________ State: ______________ Zip: ___________
PAYMENT: Money Order _____ Cashier's Check _____
MAKE PAYABLE TO SAM KNIGHT.
Model of Plane / Quantity / Description / Color / Price / Total
NO REFUNDS Subtotal _______ FOR
EXPERIMENTAL AIRCRAFT ONLY Sales Tax* _______
PRODUCTS DO NOT MEET FAA Shipping and Handling Costs _______
CERTIFICATION REQUIREMENTS Total _______
*Nevada residents add 7.25% sales tax.
Shipping costs vary and will be included on all orders. To avoid delays,
please do not send payment prior to receiving a confirmed total for your
order. Upholstery products and prices for all items are subject to change.
>Kendall Garrison
>9513 Casa Grande
>Woodway, TX 76712
>Thanks
>Kendall
>From: "Sam Knight" <knightair(at)lv.rmci.net>
>To:
>> Rocket Builders:
>items.
>manufacturers.
>> Sincerely,
>> Sam Knight
Subject: | Re: Fwd: Bakoland |
Well to tell the truth I have never heard of Bakoland, but if someone used it
it is probably conjured from our city name which is Bakersfield. We are at
the southern end of the San Jaquine Valley approlimately half way between Los
Angeles and San Francisco. Closer to LA. We are EAA Chapter 71 (the
Bakersfield Bunch and home of the Harmon Rocket) Prior to the Rocket we were
known as a hotbed of RV aircraft. We have a fly in Barbecue the first
Saturday of June every year that is well atttended by homebuilt and other
aircraft. There you have it, hope that clears it up for you. John Lauer
Subject: | webpage info and pictures on CD |
A few guys have asked me if I could burn a CD for them with all the handy Rocket
pictures and building info that's on my Rocket website. I finally bought a
CD burner and a big stack of blank CDs so now the answer is YES!
My home computer, which is out in the workshop next to the Rocket, connects to
the internet through a painfully slow modem. Previously I couldn't conveniently
look at my own webpage when I was at home. With the CD, I can look at photos
of other Rockets to see how they did it without tying up my telephone line
for hours. It allows my teenagers to tie up the phone instead! :-)
I put everything on the disk, text, photos, stupid airplane noises, all the HTML,
etc.... everything that's on my website.
To use it, simply insert the CD in your computer, right click on the START button,
click on EXPLORE, find the file you want to see and click on it. You don't
have to download or install anything from the CD to your C: drive unless you
want to. It should load right from the CD.
Assuming that you have a web browser installed, you should be able to click on
the HTML document (i.e. the name of each webpage) and view it normally in your
browser. The page should pop up and everything should work normally just like
it does online... except without the downloading wait. Of course, this assumes
that your PC is running a reasonably recent version of WINDOWS. For MAC or
other systems, well I'm not a computer expert so you be the judge whether this
will work for you.
If you'd like a copy, send me $10 to cover postage, supplies, time to go to the
post office, etc. I'll make updates available for $5. I'm not trying to make
any money, just trying to keep the wife from griping about unnecessary spending.
(Lot's of luck!)
Furthermore, if you get one and it's not what you thought, doesn't work, etc...
just send it back and I'll give you a refund. And if you think it's the greatest
thing ever.... oh man, get a life! :-)
Please reply off list with questions. If you want a disk, just send the money
to the address below. It shouldn't take more than 5 to 10 days, depending on
the U.S. mail.
Vince Frazier
3965 Caborn Road
Mount Vernon, IN 47620
812-464-1839 work
812-985-7309 home
1946 Stinson, NC97535, flying
F-1H Rocket, "Six Shooter", N540VF reserved,
canopy installation stage
Since nobody else is talking....
Last night the weather guy on local TV was talking about hurricane Lille. He mentioned
that a 25mph wind puts 50 pounds of pressure on an average size window.
50mph produced 250 pounds and 125mph produced 1250 pounds.
I didn't catch the exact pressure units or window size, but that's not important.
It made me wonder how much pressure is placed on the inside of the cowling at 250mph?
Yikes! Or on the front of that plexiglas bubble protecting your face.
Double yikes!
Vince
Subject: | Re: cowl pressure |
I never have understood why everyone used the top of the cowl for part of the
baffling. It causes all of the cowl surfaces to be providing upward
pressure. (Bernoulli's on the outside top surface, "pressure" on forward 3/4
of the inside top surface, impact pressure exceeding bernoulli's on the
outside bottom surface, and "vacuum" on the inside bottom surface.)
It is also very inefficient. In the typical Van's cowl (which is cleaner
than most manufacturers), there is a 70% net flow loss in the air just going
from the air inlet to the engine cylinders.
JMHO
Jim Ayers
Less Drag Products, Inc.
Okay, having said that give us the solution that utilizes that lost 70%
flow (or a large portion thereof).
Subject: Re: Rocket-List: cowl pressure
the
3/4
going
> JMHO
> Jim Ayers
Don't worry Vince, I doubt that Lille will have much blow left to her by the
time she comes this far north.
I don't like that pressure progression you speak of, I'm removing two
cylinders and lowering my Vne.
No seriously, this exponential increase in pressure with IAS is one reason
guys use a plenum, it keeps the cowl from blimping out.
Stoner
Subject: Rocket-List: cowl pressure
He mentioned that a 25mph wind puts 50 pounds of pressure on an average size
window.
important.
at 250mph? Yikes! Or on the front of that plexiglas bubble protecting your
face. Double yikes!
> Vince
Vince-
I recently did some simple drag calculations for a project and a basic
drag equation is: Drag in pounds of force = area in square feet x
coefficient of drag for the body in question x velocity squared in mph /
400. So whats an appropriate Cd? Lets look at a few examples. A flat
plate is 1.2, a naca 62-015 airfoil (close to a rocket airfoil) is .012
if I recall correctly. A low drag automobile is about .31-.36.
(announcers voice, with enthusiasm)
Now you too can calculate your own drag forces with simple math! Don't
you feel lucky!
Ron Carter
[mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of Frazier,
Vincent A
Lille. He mentioned that a 25mph wind puts 50 pounds of pressure on an
important.
cowling at 250mph? Yikes! Or on the front of that plexiglas bubble
protecting your face. Double yikes!
Vince
Dam it Spock, just give me the answer!
Subject: RE: Rocket-List: cowl pressure
> Vince-
> you feel lucky!
> Ron Carter
> Vincent A
> To: rocket-list(at)matronics.com
> important.
> Vince
The solution is easy. Don't let the air expand and contract.
It is the implementation that is difficult. (I've been working on that.)
1.) On any engine baffling, don't let ANY air get through except through the
cylinders. (Learn to love the appearance of RTV. :-) )
2.) If it won't hold water, it won't hold air. (Air is slipperier.)
Jim Ayers
Jim
Do you have any ideas on how we can improve the flow of exit air from the
engine cowling?
Tom Martin
Jim Ayers
> Jim
from the
> engine cowling?
> Tom Martin
The first thing would be to determine how much differential you have.
A simple manometer with probes before the baffling, and behind, along
with a few flights should help determine the delta.
In numerous cases, it is the exit that is the culprit, and a row or two of
louvers will help. (short of cowl flaps).
Archie
From: | "Richard V. Reynolds" <rvreynolds(at)macs.net> |
czech-list(at)matronics.com, europa-list(at)matronics.com, ez-list(at)matronics.com,
glasair-list(at)matronics.com, homebuilt-list(at)matronics.com,
kolb-list(at)matronics.com, kr-list(at)matronics.com, lancair-list(at)matronics.com,
pelican-list(at)matronics.com, pietenpol-list(at)matronics.com,
piper-list(at)matronics.com, pitts-list(at)matronics.com,
rocket-list(at)matronics.com, rv4-list(at)matronics.com, rv6-list(at)matronics.com,
rv7-list(at)matronics.com, rv8-list(at)matronics.com, sonerai-list(at)matronics.com,
tailwind-list(at)matronics.com, ultralight-list(at)matronics.com,
warbird-list(at)matronics.com, yak-list(at)matronics.com,
zenith-list(at)matronics.com
Subject: | EAA Chapter 339 Fall Fly-In |
Saturday, October 19, 2002, Hampton Roads Exec (PVG), Virginia, 9AM till
7PM
Hampton Roads Exec (PVG) is 27nm SW of Norfolk, Virginia (253 radial
?ORF)
AWOS 118.375
CTAF 123.0
The weather will be a perfect Virginia fall day!
Aircraft parking is off taxiway between Rwy 23 and T-Hangars East of
Airport Terminal
Schedule of Events
Fly-In Begins 9AM
Food all Day 10AM ? 3PM
Poker Run (Walk Around Field)
Project Visits on Field
Aircraft Judging 11AM ? 3PM, All Categories, Antiques, Classics,
Homebuilts, Warbirds
Social Hour 4PM
Dinner 5PM ? 7PM, BBQ Sandwiches, Chicken, Drinks
Local motels/hotels are available
For More Information
Frank Toy 757-460-3680
ftoy(at)att.net
Richard Reynolds 757-627-8743
EAA Chapter 339
http://home.earthlink.net/~avyator/
Hampton Roads Exec Airport
http://www.hamptonroadsexecutiveairport.com/index.html
Subject: | RE: Rocket-List Digest: 7 Msgs - 10/02/02 |
SNIP 1.) On any engine baffling, don't let ANY air get through except through the
Jim Ayers SNIP
Do I use a garden hose, or should I submerge the whole fuselage in a swimming pool,
Titanic style?
Seriously though... anyone got any pictures of their plenum to share. Particularly
the intersection of the inlets and the plenum. I'm using the standard rectangular
inlets, not the round ones.
Thx,
Vince
Mooney aircraft did just that (pressure plenum box within the cowl) made
out of aluminum 44 years ago !!. I purchased a Velocity hi-temp epoxy
plenum box/chamber from Velocity aircraft as a starting point for my
plenum. Very easy to adapt and install. Check out Velocitys web page,
look under engine accessories. Other plastic aircraft companies
(Berikute (spelling), West Virginia cousins of the Veri-ez lot, or
others may have a simular offering too)
> Jim
from the
> engine cowling?
> Tom Martin
Archie
Just comments. Recently I have installed two sets of louvers on the cowls
of airplanes, one a Cessna 185, and a new Skybolt. Both were installed on
the lower aft side of the cowling, which theoretically is a low-pressure
area. The Cessna has flown quite a bit, and the difference is rather
dramatic. He is experiencing approximately a 15-degree cooler CHT, and more
even overall cylinder temps.
The lesson is indicative of long-held knowledge-getting the cooling air
OUT
is usually the problem. If we can reduce the pressure in the lower part of
the cowl, then the cooling velocity past the cylinders increases, and
cooling efficiency is greater. Louvers do seem to be an easy way to
accomplish this, if there is any kind of cooling problem. Much easier than
cowl flaps, and more effective. In cold temps in the wintertime, it is very
easy to just make a simple, attractive screw-on cover plate, to close up the
louvers if they are too effective. The size of the plate can be adjusted to
open or close the louver area, as experimentation will determine.
the louver plates inside or outside the cowling. The effectiveness is
unchanged, but they do look better when installed inside, and the cowling
hole is carefully matched to their openings. I initially thought that they
would be nice outside, but in the long run, they look tacked on that way.
If the cowling cutout hole is carefully made, it is almost invisible that
the louvers are added to the inside.
There can be some discussion about forming the louvers directly into the
cowl. (It isn't hard to do). Basically, my thinking is that IF this is
done, there probably should be a reinforcing ring around the formed louvers
anyway, as cutting them into the metal of the cowl introduces a large number
of stress points in the cowl, which will probably eventually produce cracks.
If you have to make a reinforcing ring around the louvers anyway, why not
just do the easy thing, and use some of the commercially-available louver
plates? Very debatable point, and one only you, in your individual
application, can answer for you.
Lee Taylor
Lee
Louvers might very well do the job for cooling, but what I am looking
for
is information regarding smoothing the airflow out of the existing opening.
How much exit opening is required vs. the inlet size and what kind of
metal/baffling is required to clean up the outlet area. If we can increase
the speed that the air exits the cowling it will not only cool more
effectively it should also reduce cooling air drag. If anyone has any
pictures of installations like this I would be most appreciative. Exhaust
augmentation is another option to increase exit airflow and it would be
interesting to get comments from some who have tried this method.
Tom Martin
> Jim
from the
> engine cowling?
> Tom Martin
Archie
air OUT
the
Lee Taylor
(stuff cut) what I am looking for is information regarding smoothing the
airflow out of the existing opening. How much exit opening is required vs.
the inlet size and what kind of metal/baffling is required to clean up the
Tom Martin
Tracy Saylor seems to have an answer to this. The last time I looked, Tracy
had four individual pipes (ending horizontally under the engine sump) that
were custom trimmed. He said he just kept cutting them shorter, and his
performance kept getting better.
However, I'm not sure who is willing to have their exhaust pipes end inside
the cowl under the back of the oil sump. (I believe Tracy's system works
because he has the LightSpeed dual electronic ignition. Just adding one and
one, but sometimes it comes out three. go figure. :-) )
Jim Ayers
IO-540 C4B5 1300 SMOH -0 STOH $ 14,600.00 call Dave (386)-255-0342
Interesting discussion. My rivet partner has a -8 and I noticed a rolled
piece with about a 1" to 1 1/2" radius at the bottom of the firewall
transitioning to the fuselage bottom; I supposed this was to help ease the
sharp corner for the exit air. My question to the aero guys is how
effective this might be and is it worth doing on our Rockets ????
Larry E. James
New Concepts Prototyping HR2 fuselage
phone 206 633 3111
fax 206 633 3114
larry(at)ncproto.com
This electronic message is intended only for the individual(s) to whom it is
addressed and may contain information that is privileged, confidential, or
exempt from disclosure under applicable law. If you have received this
electronic message in error, would you please notify me immediately by
return email, or by telephone (collect). Thank you.
>I noticed a rolled
I believe this is recommended on the 4 also. I'm planning to see if I can
make it happen in the Rocket also.
As to the cooling drag, it seems, plenum or not, that you are going to have
a fair bit of drag going through the fins and all and the variable is more a
function of inlet size and outlet size.
Russ
HRII
From: | "Dave O'Donnell" <daveodonnell(at)direcway.com> |
Ok so we need an IO 540 engine for a rocket.
I need an education. Help!
1. Special engine mounts such as dynafocal preferred?
2. Suffixes appear to be important. As & Bs appear to carry a 1400 hr
TBO. Ks & S's look attractive with a 2,000 hr tbo and 300 hp rating.
3. Compression? Can you take a D suffix and go to 9.5:1 pistons and get
300hp, have a lighter motor & reasonably hope for 2000 tbo? I notice
that the Ds appear to be taller than a K or S, is that significant?
4. I have a vague memory about Team Rocket or someone with an
inverted oil system for the IO540s, but do not see it on the Web
catalog.
5. Ideal aside what is generally available? It's pointless to talk
about an S if they just are not available on the used market. The As &
Bs appear common but what would it take (if you can) upgrade these in
rpm (2700)& (300) hp?
Dave O
Funny.
I thought the Rocket was designed around the IO-540-C4B5.
Stock - 260 hp at 2700 RPM.
I think I heard that after Lycon had played with John's IO-540-C4B5 in his
HRIII, it produced 380 hp. I would guess that the TBO could be less than
2000 hrs. :-)
Jim Ayers
LyCon built up the IO-540 C4B5 for the Super 6 back in 1998. It puts
out 325
hp at 2800 rpm with 10:1 pistons. Recommended TBO is 1,000 hrs.
Boyd
Venice, FL
LesDrag(at)aol.com wrote:
> Funny.
> 2000 hrs. :-)
> Jim Ayers
I'm pretty sure John's engine is an Angle Valve....not a hopped up C4B5...
Weav
Subject: Re: FW: Rocket-List: (Engines)
> out 325
> Boyd
> Venice, FL
> > Funny.
his
than
> > 2000 hrs. :-)
> > Jim Ayers
The engine in the Rocket III started life as a IO-540-C4B5 nerrow deck, at
Reno we
wher burning over 32 GPH @26.7 " and 2980RPM, Reno is 5,000 '
Hey Boyd-
How do you know it puts out "325 hp at 2800 rpm ...." ? Whose dyno did you
use? JBB
> out 325
> Boyd
> Venice, FL
> > Funny.
> > 2000 hrs. :-)
> > Jim Ayers
The dyno at LyCon before they shipped the engine out.
jamesbaldwin(at)attglobal.net wrote:
> Hey Boyd-
> use? JBB
> > out 325
> > Boyd
> > Venice, FL
> > > Funny.
> > > 2000 hrs. :-)
> > > Jim Ayers
Subject: | O/AEIO/IO-540 Emergency AD |
Great News!
FAA Emergency AD 2002-20-52/Lycoming Service Bulletin 554 (9/30/02) for
O-540, IO-540, AEIO-540 and TIO-540 is out for replacement of the
"zinc-plated crankshaft gear retaining bolts".
Boyd
Subject: | Re: O/AEIO/IO-540 Emergency AD |
> Great News!
> Boyd
Superior sent a bulletin indicating use of their bolts
is not included in the AD.
Archie
I just received an Emergency Airworthiness Directive that appears will ground the
Lycoming six cylinder fleet.
Anyone else get one ? Apparently the bolt that holds the gear on the crankshaft
is failing.
I have 10 flying hours or seven days to fix it.
Bryan Carr
HR 11
ground the Lycoming six cylinder fleet.
crankshaft is failing.
> Bryan Carr
> HR 11
Read it carefully. Some people are jumping to conclusions prematurely.
Also, if you purchased the bolt from Superior, they claim their bolts
are not affected.
Believe it or not, one engine ran for almost 50 hours without a bolt
installed.
(it eventually failed, when the gear fell off, of course).
Archie
From: | "Kendall Garrison" <KGarrison(at)hot.rr.com> |
I have an IO 540 on a 77 Piper Lance. The engine was a factory rebuild in
May of '98 which was the time in question. I talked to a service rep today
and they told me that it was subject to the AD only if your engine serial
number is listed in the AD or Service Bulletin 544. If your engine is not
listed, you are in the clear or so they claim.
Good Luck
Kendall Garrison
Subject: Re: Rocket-List: I0 540
> > Bryan Carr
> > HR 11
> are not affected.
> installed.
> Archie
I spoke with Lycon this evening. They indicated that Lycoming MIGHT be
rewriting AD to include ALL engines with overhaul or manufacture since 1996.
The Zinc coated bolts are the "bad" ones and are gold in color. Due to the
difficulties in matching part lots and specific engines and times of
overhaul, combined with parts inventories which may be on shelves for
extended periods, it may mean direct inspection is necessary to be sure.
today
> Good Luck
> Kendall Garrison
> From: "Archie" <archie97(at)earthlink.net>
> To:
> > > Bryan Carr
> > > HR 11
> > are not affected.
> > installed.
> > Archie
From: | "Paul Besing" <azpilot(at)extremezone.com> |
I've been hearing about this AD alot lately. All over the aiport I keep
hearing people complaining about doing it. It appears that there are ALOT
of engines effected by this AD. Make absolutely sure you are clear on this
AD. Apparently it's pretty serious. Lycoming is taking a major hit,
because new airplanes are under warranty and they are taking back many, many
engines. Plus they are having to pay the labor to remove and re install the
engines.
Paul Besing
RV-6A Sold (Waiting on the RV-10)
Kitlog Pro Builder's Log Software
http://www.kitlog.com
1996.
> From: "Kendall Garrison" <KGarrison(at)hot.rr.com>
> To:
in
> today
serial
not
> > Good Luck
> > Kendall Garrison
> > To:
will
> > > > Bryan Carr
> > > > HR 11
> > > are not affected.
> > > installed.
> > > Archie
Prob'ly the one at Lycon..... hahahahaha.... They're always
optimistic..
On Monday, October 7, 2002, at 10:01 PM, jamesbaldwin(at)attglobal.net
wrote:
> Hey Boyd-
> you
> use? JBB
>> out 325
>> Boyd
>> Venice, FL
>>> Funny.
>>> in his
>>> than
>>> 2000 hrs. :-)
>>> Jim Ayers
Rocketeers,
Lycoming has the info on their website under support, publications, service letters.
The criteria for which engines are affected is spelled out on the below
bulletin.
Hope this doesn't affect your engine,
Jim Stone
652 Oliver Street
Williamsport, PA 17701 U.S.A.
Tel. 570-323-6181
Fax. 570-327-7101
www.lycoming.textron.com
September 30, 2002
Supplement No. 1
To
Service Bulletin No. 554
In response to customer comments, Supplement No. 1 to Lycoming Service Bulletin
No. 554 offers more
specific information to assist in the identification of affected engines.
Service Bulletin No. 554 affects:
1. All factory new, factory rebuilt, and factory overhauled engines listed in Table
1.
NOTE
The presence of any letter prefix or suffix added to any of the serial numbers
does not
exempt the engine from compliance.
2. All O, IO, TIO, LTIO and AEIO-540 engines that have had a crankshaft bolt replaced
during field
maintenance or field overhaul between November 27, 1996 and November 10, 1998.
NOTE
Service Bulletin No. 554 does not affect engines with single drive dual magnetos.
=A9 2002 by Lycoming "All Rights Reserved"
MANDATORY
SERVICE BULLETIN
> engines.
> Paul Besing
> From: "Tom Hall" <tomhall(at)starband.net>
> To:
> 1996.
> > To:
> in
> > today
> serial
> not
> > > Good Luck
> > > Kendall Garrison
> > > To:
> will
> > > > > Bryan Carr
> > > > > HR 11
> > > > are not affected.
> > > > installed.
> > > > Archie
I still have my engine sitting off the plane. I'll probably remove the
accessory case and see what bolt I have. If it is okay, it will cost me the
gasket and the time.
Can any of you experienced mechanics tell me how much more is involved it I
elect to remove the sump and replace the entire gasket rather than cut it at
the sump as Lycoming recommends? What else is a consumable part?
Russ Werner
> Rocketeers,
service letters. The criteria for which engines are affected is spelled out
on the below bulletin.
> Jim Stone
> 652 Oliver Street
> Tel. 570-323-6181
> Fax. 570-327-7101
> September 30, 2002
> Supplement No. 1
> To
Bulletin No. 554 offers more
in Table 1.
> NOTE
numbers does not
bolt replaced during field
1998.
> NOTE
magnetos.
> MANDATORY
> SERVICE BULLETIN
> From: "Paul Besing" <azpilot(at)extremezone.com>
> To:
ALOT
this
many
the
> > engines.
> > Paul Besing
> > To:
> > 1996.
the
sure.
> > > To:
rebuild
> > in
rep
> > > today
> > serial
is
> > not
> > > > Good Luck
> > > > Kendall Garrison
> > > > To:
appears
> > will
the
> > > > > > Bryan Carr
> > > > > > HR 11
prematurely.
bolts
> > > > > are not affected.
bolt
> > > > > installed.
> > > > > Archie
Russ--
Lycoming SB 554 lists the serial numbers of the affected engines (Table I).
Service instructions for dissambly, replacement and reassembly are found in
Lycoming SB 475B. These are available in .pdf format from Lycomings web page
under "publications".
Boyd
> Russ Werner
> From: "Jim Stone" <jrstone(at)insightbb.com>
> To:
> > Rocketeers,
> > Jim Stone
> > 652 Oliver Street
> > Tel. 570-323-6181
> > Fax. 570-327-7101
> > September 30, 2002
> > Supplement No. 1
> > To
> in Table 1.
> > NOTE
> numbers does not
> 1998.
> > NOTE
> magnetos.
> > MANDATORY
> > SERVICE BULLETIN
> > To:
> ALOT
> this
> many
> the
> > > engines.
> > > Paul Besing
> > > To:
> > > 1996.
> the
> sure.
> > > > To:
> rebuild
> > > in
> rep
> > > > today
> > > serial
> is
> > > not
> > > > > Good Luck
> > > > > Kendall Garrison
> > > > > To:
> appears
> > > will
> the
> > > > > > > Bryan Carr
> > > > > > > HR 11
> prematurely.
> bolts
> > > > > > are not affected.
> bolt
> > > > > > installed.
> > > > > > Archie
From: | "Wiethe, Philip (P.J.)" <pwiethe(at)ford.com> |
I know an engine builder in Florida who builds airboat engines and some experimental
aircraft engines
who is selling a rebuilt IO-540 for experimental use for $14000. The engine was
built for a plane builder who passed away
before taking delivery. The engine has some custom work - port work and cryogenic
treating, not sure what else.
Sounds like a good deal. The seller is:
Steve Woosley
(813)-659-4721
"Rocket List"
Guys and Gals,
Well, Avemco when off the deep end.
Last year was 4488.00 and this year
they want 5719.00.
Their quote is:
Bodily Injury and Property Damage for
100,00 each person;
1,000,000 property damgage;
1,000,000 each accident = 732.00
Aircraft damage In Flight for
110,000 value;
deductible:
500 NOT IN MOTION;
2,000 IN MOTION = 4954.00
Medical expenses for
1,000 each person = 33.00
Pilots:
Thomas L. Gummo - Com - IFR yes - Age 54 - TT 3500 - ME 3200 - RG 3200 - MM
80 - TW 150
Joseph P. Fitzgerald - ATP, ASMEL - IFR yes - Age 47 - TT 6130 - MM 7 - RG
2200 - TW 1600
Aircraft data:
N561FS
Harmon Rocket II, Engine IO-540 J4A5 80 Hours, Day VFR + (No strobes; but
nav, taxi, and landing lights; electric Attitude and DG), not painted.
Stored at APV, hangared yes.
Guess it is time to look for another company.
Tom Gummo
PS. if I had 5700 dollars laying around, it would be painted :-)
From: | "Bob & Toodie Marshall" <rtmarshall(at)osbtown.com> |
Subject: | Re: Insurance AGAIN |
Hey Tom, don't feel like the lone ranger, I even have a couple of
instructor ratings, CFII, CFIG and a couple thousand tailwheel, instructing
and towing gliders, your quote is very close to mine, so I opt out on the
hull, The EAA is touting Falcon, ask for a quote and let us know. They are
supposed to understand EAA problems? Good luck, Bob Marshall.
Subject: Rocket-List: Insurance AGAIN
> Guys and Gals,
> they want 5719.00.
> Their quote is:
> 100,00 each person;
> 110,000 value;
> deductible:
> 500 NOT IN MOTION;
> Pilots:
MM
> 80 - TW 150
> 2200 - TW 1600
> Aircraft data:
> N561FS
> Tom Gummo
Subject: | Another first flight |
Congradulations,Dean Berry.AZ # 85
7PM
Hampton Roads Exec (PVG) is 13.5nm SW of Norfolk, Virginia (253 radial
(ORF)
AWOS 118.375
CTAF 123.0
The weather will really be a perfect Virginia fall day!
Airport Terminal
Schedule of Events
Fly-In Begins 9AM
Food all Day 10AM - 3PM
Aircraft Judging 11AM - 3PM, All Categories, Antiques, Classics,
Social Hour 4PM
Dinner 5PM - 7PM, BBQ Sandwiches, Chicken, Drinks
ftoy(at)att.net
EAA Chapter 339
From: | "dave rossiter" <daverossiter717(at)hotmail.com> |
Tom, check with Lad Gardner at Falcon(EAA Insurance) as far as I know the
only game in town for my F1 Rocket. Dave
>From: "Tom Gummo" <t.gummo(at)verizon.net>
>Reply-To: rocket-list(at)matronics.com
>To: "RV List" , "Rocket List"
>Date: Sat, 12 Oct 2002 14:32:21 -0700
>Guys and Gals,
>they want 5719.00.
>Their quote is:
>100,00 each person;
>110,000 value;
>deductible:
>500 NOT IN MOTION;
>Pilots:
>80 - TW 150
>2200 - TW 1600
>Aircraft data:
>N561FS
>Tom Gummo
http://resourcecenter.msn.com/access/plans/2monthsfree.asp
Has JT from Nationair tried to quote the rockets? He does so much better
for the RV's than Avemco, I would think he could do something for the Rocket
guys, too. I'd love to build an HR2 but I wouldn't be able to insure it!
Paul Besing
From: "dave rossiter" <daverossiter717(at)hotmail.com>
Subject: Re: Rocket-List: Insurance AGAIN
> >Guys and Gals,
> >they want 5719.00.
> >Their quote is:
> >100,00 each person;
> >110,000 value;
> >deductible:
> >500 NOT IN MOTION;
> >Pilots:
MM
> >80 - TW 150
RG
> >2200 - TW 1600
> >Aircraft data:
> >N561FS
> >Tom Gummo
He is working up a quote for me.
I will post the results.
I think as an unemployed builder I will have to go with liability only.
No matter what company has the lowest quote.
Tom
Rocket
> Paul Besing
> To:
the
> > >Guys and Gals,
> > >they want 5719.00.
> > >Their quote is:
> > >100,00 each person;
> > >110,000 value;
> > >deductible:
> > >500 NOT IN MOTION;
> > >Pilots:
3200 -
> MM
> > >80 - TW 150
> RG
> > >2200 - TW 1600
> > >Aircraft data:
> > >N561FS
but
> > >Tom Gummo
Any chance on lowering the policy below $100K? I hear that they really
don't like to overinsure. 100K sometimes is the cutoff between high and
astronomical rates, from what I understand.
Paul Besing
> >Guys and Gals,
> >they want 5719.00.
> >Their quote is:
> >100,00 each person;
> >110,000 value;
> >deductible:
> >500 NOT IN MOTION;
> >Pilots:
MM
> >80 - TW 150
RG
> >2200 - TW 1600
> >Aircraft data:
> >N561FS
> >Tom Gummo
I am waiting on the quote.
Thanks.
I will post my result.
Tom
> >Guys and Gals,
> >they want 5719.00.
> >Their quote is:
> >100,00 each person;
> >110,000 value;
> >deductible:
> >500 NOT IN MOTION;
> >Pilots:
MM
> >80 - TW 150
RG
> >2200 - TW 1600
> >Aircraft data:
> >N561FS
> >Tom Gummo
In a message dated 10/15/2002 9:05:12 PM Pacific Daylight Time,
t.gummo(at)verizon.net writes:
> Tom
> To:
> Rocket
> > Paul Besing
Try Sky Smith Insurance, I was talking with Scott Smith, he said he has
couple of companys that will write the HRII but they are still a bit pricey,
any way its worth a call.
Tim Barnes
Meangreen RV-4
Subject: | Re: Rocket Insurance |
Tom,
Call Dan Paves with Wilson Paves & Assoc.
661-327-3111
He has a line on Insurance for the Rockets.
Christina
Congratulations Allan Webb Grand champion Copperstate fly in. You cleaned
house 02
Subject: | Re: (no subject) |
Does anyone have pictures of the new Grand Champion?
Jim
Subject: Rocket-List: (no subject)
> house 02
Subject: | Electric Aileron Trim |
I'm working with the RV8 aileron trim kit and was wondering if anyone has
experience with mounting it in a Rocket II/F1. It appears fairly straight
forward.
I'm planning on putting the servo just in front of the spar with the springs
catching the front edge of the stick weldment. Vans supplied springs seem
way too stiff, so I may substitute some lighter ones of the same length.
For the ends of the sliding tube, I have ordered cool flanged spherical
bearings from ACS (pn FNM5).
This may go out the window if I decide to mount the autopilot servo in front
of the spar. A wing rib mount for the autopilot will solve that.
Any thoughts, rocketeers?
Russ Werner
Maui
Subject: | Re: Electric Aileron Trim |
In a message dated 10/21/2002 1:20:36 PM Central Daylight Time, russ(at)maui.net
writes:
Hey Russ:
I've seen it mounted as called out in the -8 plans -- worked OK. The AP servo
does fit nicely in the front bay....
You'll have to shorten the tube to allow for the closer spacing of the floor
ribs. I'd keep those supplied springs handy -- weaker ones might not give the
trim authority required.
Cheers
Mark
Russ,
If you decide to go with an autopilot:
http://www.trutrakflightsystems.com/ttfsproducts.html#Digitrak
$1,800 for a digital autopilot that also tracks the GPS. I attended an EAA
meeting Sunday where the owner (Jim Younkin) spoke. This is a very
impressive unit for the money!
Chip Gibbons
[mailto:owner-rocket-list-server(at)matronics.com]On Behalf Of Russ Werner
Subject: Rocket-List: Electric Aileron Trim
forward.
Russ Werner
Maui
Russ,
I put in the RV-8 kit and put in the general area suggested for
the -8. It will clear the flap actuator. If you use TruTrak AP , then
clearances become alittle more critical, but it will all work and be rear of
the spar and aileron tubes. Care must be used with AP servo to avoid heel
wells. If you need photo, let me know.
Tom #15
> forward.
springs
front
> Russ Werner
> Maui
I agree with Mark. RV-8 springs are too long due to greater distance between
stringers than in Rocket, so actually the holes in the actuator tube of the
aileron trim will need some adjustment inward and this may actually lead to
them being too loose, so they may require springs to be shorter.
Tom Hall
Subject: Re: Rocket-List: Electric Aileron Trim
russ(at)maui.net
> writes:
springs
seem
> Hey Russ:
servo
floor
the
> Cheers
> Mark
It seems that the important dimension is the distance between the two cotter
pins on the sliding tube. The height you have that tube affects that too.
I just about have it worked out. I'm installing the Navaid A/P and the
electric trim in front of the 404. Space is NOT a problem, not is access
later.
Russ
between
the
to
> Tom Hall
> From: <Mlfred(at)aol.com>
> To:
> russ(at)maui.net
> > writes:
> springs
> seem
length.
> > Hey Russ:
> servo
> floor
give
> the
> > Cheers
> > Mark
Russ,
We are saying the same thing,I think. The holes that I was
referencing are the holes that the cotter pins go thru. If you would please
let me(us) know what you come up with dimension-wise. I haven't tackled that
particular problem yet and that info would be helpful. I considered leaving
holes same distance if they would work between stringers and shortening
springs, but it looked like that moving holes in and shortening springs or
replacing with shorter springs was going to be necessary. Any info will be
appreciated.
Tom
cotter
> later.
> Russ
Subject: | Re: RV-List: Ready-to-install Spinner |
Duct tape.... use several layers of good ole duct tape to outline the
openning on the spinner. It may not be perfect against the "ham fisted" but
it gives protection for the little slip of the wheel. Warning: Cut the
same day you put it on and take it off as soon as the cut is completed.
(works witth fibreglas and plastic too). KABONG
Subject: Re: RV-List: Ready-to-install Spinner
> --> RV-List message posted by: Larry Bowen
> You can't buff it out?
> -LB
> --- Sluggo wrote:
> > --> RV-List message posted by: "Sluggo"
> > Ah, here was the "rub", as they say. The Orndorff's also said that a
Dremel
> > was the way to go and should be "simple and hard to make a mistake."
Well,
> > maybe for you all. Ham-fisted me let the Dremel get away and walk
nicely
> > across the spinner, leaving a lovely etched trail, as well as a ruined
> > pricey polished spinner, in its wake.
I'll document what I come up with. The keel beams in front of the spar are
plenty far enough apart to use the stock springs. The servo only has 1.2
inches of travel, so the whole thing should be pretty easy. I'm waiting for
a spherical bearing to come in from ACS before finishing it. Should be in
the next 2 days.
Russ
> Russ,
please
that
leaving
> appreciated.
> Tom
> From: "Russ Werner" <russ(at)maui.net>
> To:
> cotter
too.
access
> > later.
> > Russ
Just a quick note to let everyone know that I updated my web site this evening
with over 20 pictures of my wing construction. Included in the pictures are some
related to installing the VonDane Landing lights in the Rocket wing tips.
I should finish up the wing this week with additional pictures to follow.
Randy Pflanzer
F1 Rocket #95
http://mywebpages.comcast.net/f1rocket/
From: | "flyseaplane" <flyseaplane(at)netzero.net> |
Subject: | Someone from the RV list is sending me a virus |
Someone from the RV list has been sending me the W32Klez@mm virus for a few
days now.
The W32.Bugbear@mm just came through today. This must be a new one.
Folks, If you don't have Norton Anti-Virus, I strongly suggest you get it.
(it's only $20 from numerous places online)
I don't want to hear one person come back and say "Well, I have McAfee...."
McAfee does not work like Norton Symantec does. I had McAfee installed on my
Hewlitt-Packard when I bought it brand new, and the computer slowly began
acting up. I installed Norton and it immediately found 28 viruses on my
computer. So much for McAfee. Never again!
Anyways, I just wanted you to know that my Norton system has been nabbing
these viruses from the RV list, so you all might want to go ahead and run a
virus scan. I am going to send this same message to the Harmon Rocket list,
because it might be coming from there, I haven't determined which list is
sending me the virus.
Take care all, and happy building!
Linc
Linc,
McAfee, like Norton, must be kept updated. I suggest McAfee Clinic for
broad band users. There's nothing wrong with McAfee if you keep the virus
files updated.
Chip Gibbons
[mailto:owner-rocket-list-server(at)matronics.com]On Behalf Of flyseaplane
Subject: Rocket-List: Someone from the RV list is sending me a virus
days now.
Linc
Subject: | Re: Rocket- virus is from RV-8 list |
Dear Rocket Listers,
I did some digging and found the virus came in on the RV-8 list, from a
sender named "Sally and George" and the message was title "cabin floor heat"
I tried to send them a reply letting them know what they were doing, and it
came back undeliverable. The e-mail address is Australian.
Happy Building!
Linc
Subject: | Story on trip to alaska |
The short version: Totals 33 Hrs 350 gals of fuel 5 qts oil approx 6300
miles fantastic trip fantastic airplane and would do it again!
The long version. note vince frazer has some pictures on his web site I
will try and get some more up later.
266hp trip to Alaska.
Having wanted to fly to Alaska for the last ten years I finally decided to
do it! I thot it would be cool to fly with other people so I advertised on
the rocket list and some other places and some guys were ready to go, but
they all bailed on me so I decided to go on my own. I asked my 25yr old son
Matt to go with me and he said "sure pops." We set the date to leave on
August 23rd and return on Sept 1st or 2nd. It would be mainly a
sightseeing & hiking trip & maybe some fishing. No camping because there is
absoutly no room for any gear if you fly with two people.
To fly to Alaska is not like flying to Oshkosh. In order to legally fly
there you are supposed to carry enough food & water for two weeks, survival
gear that includes a flare gun, knives, hatchet, fishing gear, medical kit
for two people, Big rifles, etc. etc. Yeah right!!! Plus about 15lbs of
flight gear. Hmm I have Harmon rocket not Cessna 210 truck! It also cost
$50.00 for the privilege of carrying a gun in Canada. Quick weight &
balance & space available says it ain't gonna happen. I called my friend up
in Alaska and asked him what I really needed to have and that's what I did
minus the gun. All said & weighed I had about 85lbs of baggage dispersed in
every nook I could find in the airplane. Fortunately my 6'1' son only
weights in at 160 and I am 170 so we were okay weight & balance wise but at
the big line of maximum aft a cg. (I would come to appreciate this more later!)
In preparation to this trip I made a shakedown run to Bryce Canyon, and
Grand Canyon. There were some problems with my Navaid wing leveler so I
sent it back to them and they fixed it and sent it right back. I was
curious to see what kind of a fuel burn I would have at low power settings
and what type of airspeed to expect. I flew most of the 4hrs at 9500-10500
ASL at 20"MP 2200 RPM averaging between 11.5- 12.3 GPH at 170-175 knots
which would give me about 3.5hrs flying time. That's about 1 hr longer than
my butt can stand in one sitting, my son seconds that! Using these
numbers I started to plan the trip loosely using 2 -2.7 hour legs.
Day One
Took off from French Valley Airport Ca F70 11:30 A.M.. Arrived in San Luis
Obispo to pickup son at 12:45, made nice landing. Put son & his baggage in
and took off for Grants Pass Ore. cruised @ 10,500 nice flight till Oregon
border then lots of smoke just like a bad day in LA basin only blue in
color. First time I have flown up there and never saw Mt Shasta 14,000ft..
Last I heard the Biscuit fire & others had burned approx 500,000 acres! Got
beat up bad over the siskiyous and made three landings at Grants Pass. Hmm
airplane really lands different at max gross and aft CG. Filled up with 29
gallons of $2.20 gas after flying 454 nm 2.7 hrs. No place to eat so we get
the proverbial vending machine food and blast off to Lynden Washington.
Lynden is small Dutch town with a small 2500 ft runway and 50' trees at one
end. I make one good landing and called our host for a ride into town. We
stayed at a very nice bed & breakfast and eat a huge meal at Dutch Mothers.
I am pooped after flying 6 hours so we just hang out at the B&B and go to bed.
Day Two
Lynden is four miles from the Canadian Border so once you take off you are
in the pattern of Abbotsford where you check into customs. We made a long 3
minute trip to Abbotsford
and landed there about 10:30am. Customs man was very curt and abrupt with
no smiles but allowed us to proceed after a brief interrogation about what
when how where and how much time we were going to spend in his country.
Departed about 11:00am for Prince
George after filing mandatory flight plan. Flew up Frazier river canyon
about 8500 beautiful areas till you pass 100 mile house then it gets kind
of flat. Arrive in Prince George about 2.5 hrs later and make one landing
sort of. My rear seater is starting to grade my landings. From Prince
George you have three routes available to get up to Alaska. One is called
the Cassair closer to the coast and subject to more storm track type
weather and was low clouds & rain. Two is called the TRENCH 400 miles of
nothing down a narrow valley with no fuel stops. I'm not ready for that yet
so It was never a consideration. Three is the Alaskan Hiway by way of Ft
Nelson. Weather is reported to be good on this one so its number 3. We
blast off about 2:30. Rear seater is making noises about no food, we didn't
refuel at the restaurant and had vending food? Instead.
We arrive in Ft Nelson around 5:00 get reprimanded by tower guy who said I
didn't call five miles out, which I did. I'm getting old & crotchety so
when we landed I gave him a piece of my mind about his lack of traffic and
failure to reply on my first call 20 miles out.
He backed of a little bit and said he didn't hear me. Rear seater is
talking to gas man who says yeah there is some extra food in the
refrigerator in the pilots lounge Matt disappears into pilots lounge comes
back about ten minutes later with smile & crumbs on face. Gassed up rocket
and co-pilot and headed for Whitehorse Yukon. Took off 5:15PM it was about
90 F and clear blue but that would change. We took an airway out of Ft
nelson that leads to Watson lake but does not follow the highway for about
150 miles I didn't think much about this till I noticed two things one
being there was absolutely no civilization below us at all. Having suffered
engine failures in other aircraft this was not a good feeling. Number two
is ceiling keeps getting lower and mountains are being obscured. I tell
Matt we are altering course to fly over the hiway we overfly the Laird
river and I look at the chart and notice name of rapids below us is "
Rapids of the Drowned" HMMM. Maybe another reason to get back over the
Hiway! Ceiling is still lowering and light rain is now falling we are
right over the highway flying between mountain passes when ceiling stops
lowering about 1500 AGL. As we get close to Watson lake it starts pouring
hard. This is the first real test of rain in the airplane. ( it hasn't
rained in southern California for about 9 months) Matt complained about
water on his neck and I see water coming in through right hand front corner
of canopy where it is real hard to seal. I stuff rag in spot and water
stops coming in. It stops raining hard and just rains lightly for about 100
more miles as we follow the winding Alcan making our trip longer, but more
relaxed. I told Matt the hiway was my friend in case of a problem. One bush
pilot told me when flying a cub with big tanks for six hours he had to pee
right now so he landed on the highway watered some tress and took off again! .
We arrive in Whitehorse Yukon 8:00PM still very light out, sunset isn't
till about 9:00 pm. I open the canopy and a cold 50 F breeze hits me in the
face! Wow 30 F difference in 2.5 hours.
Everything is closed except the tower and he recommends motel across the
street which has caf rear seater smiles. I haven't eaten since morning in
Washington but am not too hungry just pretty darn pooped out. Flew about 7
hrs 1300 miles today and was a little tense on last leg so I rest for a
while before dinner and have a beer.
Day Three Four Five
Plan on flying to Alaska Sunday morning and staying up there for a few
days. Go over to nav Canada office that has complete weather information
and it doesn't look good at all. I gas the plane up and the guy says where
are you staying? I said across the street and he says why don't you stay
at our pilots hotel? Its cheaper! The room is fine for us and I can see
266HP from the window so it works out great. We check out of the fancy
motel & into the pilots roost. I call my friend Lynn Ellis who owns a
flight service in Gulkana AK and he says its raining and don't bother
coming today. While taking to the flight briefer he says hey why don't you
rent a car and drive to Skagway Alaska, it a beautiful drive and has lots
of lakes & rivers. Hmmm I'll get to Alaska if I have to fly or drive. we
rent the car and have a great time. Skagway has lots of little tourist type
shops, and fishing boat charters if you want. There is also a narrow gauge
railway that runs during the summer. We drive back that night and plan on
going to Alaska next day.
Monday morning is scattered to broken with multiple layers and Lynn says
its VFR we can see blue sky so we take off hoping that Northway Ak our
customs point of entry will be VFR. On the way up we decided to make a
detour to flight see Kashkawulsh glacier, it is one of the largest in
Canada and can only be seen from the air unless you hike in a long ways. I
call flight service and tell them my intentions and he say fine and we fly
over an awesome sight where two glacier collide together. After a 20 minute
side trip we head back to our original course contact FSS on 126.7and find
out that Northway is still reporting 500 broken and 5 miles. I didn't want
to deal with that type of weather so we Land at Beaver Creek Canada, a nice
gravel strip and I make a nice soft field landing. They actually have a
little tower there and the lady was real friendly and let us know about
when the weather in Northway went VFR. After about 1 hr delay we continue
up to Alaska! Land at Northway about 1:30 check into custom pay $25.00 for
?? and fill up with gas @ $2.95/gal yikes! We blast off for Gulkana about
45 minutes away and again make some low level cloud pass detours but arrive
in Gulkana about 2:15 but hey we crossed a time change so its now 1:15
Alaska time. Cool because Lynn cannot meet with us till 2:00 PM when his
paying flight seeing tour is done. Lynn returns from his flight seeing tour
and comes over and shake hands and asks if were ready for a ride in his
pride and joy a "1943 Damn Good Airplane -15 " otherwise known as a Howard
DGA-15 N681CF Ser. # 909 E/W 2767 Lbs. Gross Weight 4500
Lbs. Total fuel 118 Gal. Useful Load with full fuel 1025 lbs. It is a
beautiful restoration that he has for a while be doesn't fly as much as he
would like. I had once considered buying one of these beautiful airplanes
before I built the rocket and there were five people in the Paine House. So
I asked to get a ride in one once we got up there and I was to give him a
rocket ride. He has the Howard all set to go and he does a preflight and we
get in and it like climbing into a big tall airplane. He talks a lot about
the big PW985 up front and the proper care and feeding of one and says you
really don't want to get moving until all the temps are in the green. Those
of us who whine about the lack of visibility in our rockets in three point
don't have a clue about what bad visibility is. In the Howard you have a
real good view of the instrument panel and out the side window which is a
cool roll down hand crank affair. Taxing out we made S turns all the way.
Runup looks good and we take the runway and 450 horses wake up and the
runway becomes visible as the tail comes up and we are on our way up about
1000 fpm at 130 mph pretty good for a 3900lb airplane made in 1943! At this
power setting were burning about 35 gph but Lynn backs off on the power and
we do a cruise climb about 800 fpm and 120 at around 25gph at 1900RPM!
These old engine run high MP and low rpm and its pretty quiet inside. Once
in the air visibility is good over the nose and sideways. We fly towards
Wrangel-Elias National Park and have a blast in the Howard it just sort of
lumbers along and for a 3900lb airplane is fairly responsive. It has one
peculiar quirk being when you start a turn it doesn't stop turning with
neutral aileron it will just keep on rolling over.... Instead of
neutralizing a turn with aileron you pull back on the yoke! Lynn said the
reason for this peculiar behavior is the Howard has no dihedral in the
wing. Benny Howard did this for one reason to go faster! We fly over some
beautiful mountains and glaciers. Down in the valley the colors are
starting to turn because it is considered fall now in Alaska. Lynn points
out that Mt Wrangel is an active volcano and you can actually see some
steam rising from it. He said the park service doesn't allow mining in the
park anymore and that was his main source of income for along time flying
miners in & out of otherwise unreachable areas. On the way back out over
some of the mountains at about 500 ft AGL he shows us what he calls the
locals answer to the park service it is a piece of solid rock about 100 ft
high about 20ft in dia and arranged in such a way that it looks like a
perfect one finger salute! The locals call it "The Finger." We drop down
even lower and look for caribou or moose. After looking in the spots Lynn
usually sees game and seeing none he remarked that the park service has
over protected the predators and they have depleted the game. Once out of
the mountains he hands the controls over to me and I play around a little
bit and realize this is big airplane cruising along at around 140 -150 mph
and 1800 rpm was great. We head back to Gulkana and I give the controls
back to him and he says that the Howard is tricky to land and no two
landings are alike and I said" yea the rocket when loaded up is the same
way." Of course he does a squeaker. Unfortunately he has another paying
customer at 4:00 and it is now 3:45 so he can't take a rocket ride. The
weather is supposed to go IFR with rain & low clouds tonight and stay that
way for three days. We say our good byes and Lynn says now that I know the
way up here bring your buddies with you next time. We tank up and blast
off around 4:30 and head back the way we came land 2.5 hrs later at
Whitehorse at 8:00 PM local. Matt had wanted to take a shortcut over the
mountains thru the glaciers but a guy did that about a year ago in an Piper
Arrow and they never have seen him again. We would have had to fly VFR on
top and that is illegal in Canada. You have to file IFR if you want to fly
on top of clouds, We check in with customs again and then check
tomorrow's forecast and the lady says that systems we were running from is
coming in with rain off & on all day. we decide to not go to Dawson Creek
an just tour downtown Whitehorse and maybe do some fishing. Next day is
cloudy and rainy and we take our time going downtown. Fishing doesn't sound
to good as only two salmon were counted in the fish ladder the day before
and we can't find a place to rent any gear. (we didn't take any because of
the space limitations) That Night we see the Frantic Follies a vaudeville
act that is very well know up north of the 60 parallel. We had a good laugh
and went to bed that night ready to say good bye to Alaska and the Yukon.
The weather lady has told us Wednesday would be a good day to get out of dodge.
Day Six
We get up early next morning and its kind of ugly but four other planes all
have same Idea. Two are piper cub with huge tanks under their belly so they
can fly about 8 hrs! One is a Cessna 172 and one is a Cessna 182 and one is
a Harmon rocket. I meet with all the pilots and we agree on a common
frequency to talk on and all agree to take the TRENCH back down toward
Prince George. Weather lady gives us a good pilot report from the trench
except for a 20kt headwind so we blast off for Watson lake. We land to
refuel airplane and copilot (I finally realize they both need refueling
after 2.5hs between stops.) We taxi to gas pit and the guy say's sorry you
can't get any gas! I Says What? He says well you can get gas if you hand
over the keys you forgot to turn in at the motel!! All of us did that! I
guess we were in such aa hurry to leave we forgot about the keys.
We get gassed up and I put in some way points in the GPS that aren't on the
map but are on a nice handout about the trench that Flight Service gave us.
Turns out there are quite a few strips to land at if you do have a problem
but they are rough. I lead the pack first and cruise at 5500 agl at 20" and
2200 we show 150kt gs ugh ! I do quick calculation and tell Matt we aren't
gonna make Prince George because the headwind is 25-30 knots
plus it is beating us up fairly good but I turn on the Nav Aid and it
handles the turbulence
really good. I talk to Bill in the Cessna 172 for about hr and then I get
out of range but everyone seems to have enough gas to make Mackenzie BC a
town on the Williston lake
that will knock off about 100 miles. It take about 21/2 hours to make
Mackenzie and it was flying over some of the most remote territory of the
whole trip. But hey we saved about 150 miles and got to sweat bullets about
fuel but when I landed in we only took 29 gals so hey I hand another hour
easy but darn it seemed like forever on that leg. We ask the FBO who has
the most reasonable motel and that's where we went. We refueled our tired
bodies and went back to the motel and their was Bill !! He had made it down
just fine and was pooped too. Williston Lake is about 200 miles long with
no boats in it, but thats another story.
You may have noticed I haven't said anything about the bugs. That because
there were none that bugged us. I got my first mosquito bite of the trip in
McKenzie and more in Golden. But I was pleasantly surprised never having to
break out the 100% DEET that was bought just for this trip.
Day 7,8,9
Up early but not bright as there is some ground fog and then multilayered
clouds up to 20,000. We get all packed up and wait Bill is still in bed and
we think of doing the same thing but after an hour it burns off to about
500 broken and I see some blue sky over the runway so we blast off about
9:30 am and head down the Trench again to Golden BC a small town outside of
Banff national park. Its about two hours 400 miles right down the center of
the Canadian Rockies with breathtaking views. The trench on this portion is
narrower with a more dramatic valley bottom to mountaintop with glaciers,
waterfalls, cascades, flowing into a verdant green river & mountain lake
valleys. It is impossible to fly straight to Golden withou making some
detours and get some closer looks at these sights. It is really a flight
seeing paradise and makes you appreciate God's handiwork.. Unfortunately
the pictures don't do the sights justice.
t
We arrive in Golden BC about 12:00 and I cant believe I have to take off
my jacket first time in 6 days. It's a beautiful sunny day and we are antsy
to go to the national parks. I refuel the airplane and there is no card
swipe for the credit card, there is just a book to put your name in and
card number, Wow what a concept. There was a phone number to call after you
fill up and I did so. A pleasant guy by the name of Greg Swanson shows up
and comment on what a beautiful plane I'm flying. He made instant Points!
We started talking about planes and it turns out he has had a piper cub and
now flys cessna 172XP with 195HP. I asked him where we could stay in town
and he says why not at my motel! (Big Bend Hotel) It's the cheapest in
town! Wow twist my arm. I wasn't able to get a car rental reservation ahead
of time but I thot it wouldn't be a problem... wrong no cars in town at
all. I asked Greg if he knew on anyone who would rent a car he said no.
Then I got a little desperate and ask if he has a courtesy car or something
he might rent us himself. He thinks for a minute and says you might be able
to rent my daughters car that I just got for her. It's a stick shift and
she hasn't learned how to drive it yet. Greg gets on the phone asks here if
its okay she said sure so we Greg scores a hat trick with us gas, lodging
and transportation. He also has one of the local watering holes and
restaurant!
If you have never seen the Canadian Rockies they are strikingly beautiful
and are a must see if you like mountains, hiking, animals, fishing etc.
etc. We spent the next two days sightseeing, and hiking. The Road to Jasper
National Park from Lake Louise is about 120 miles and about 2.5 hrs if you
don't make any stops. We never made it in a whole day there are too many
kodak picture moments. Saturday morning is another gorgeous sunny day and I
have promised to give Greg a rocket ride! Matt does some shopping in town
and Greg gives me a sight seeing tour of Jasper park and many glaciers some
of which he has landed on. Hmm they look kinda different upside down! He
had a big smile on his face when we got back and said Wow! What a plane! I
couldn't agree more. We load up, say good bye and head back to the states.
We spend the night in John Day Ore and then one refueling stop for airplane
and passengers in Auburn, Ca , then Drop off Matt in San Luis Obispo and
head Back to French Valley, Cal. Totals 33 Hrs 350 gals of fuel 5 qts oil
approx 6300 miles fantastic trip fantastic airplane and would do it again
in a heartbeat!
Harry Paine
266HP
Subject: | Re: Story on trip to alaska |
Hey Harry,
GREAT STORY!!!
Rick
http://resourcecenter.msn.com/access/plans/freeactivation.asp
Subject: | Free Panel Layout, No Obligation |
Hello Everyone!!
We here at Electronic Technologies in New Smyrna Beach Florida would like to offer you a free panel layout with no obligations at all. We can show you what your panel could or will look like. All ready have a panel and just need some equipment? We can sell you radios and other equipment at great prices because we are OEM with many manufacturers including Garmin, UPS Aviation Technologies/Apollo, BF Goodrich, Bose, Vision Microsystems, Electronics International, Chelton Flight Systems, TruTrak Flight Systems, PS Engineering, Kelly Manufacturing, Mid Continent, United Instruments and many others. We are also providing Four Winds Aircraft ( www.fourwindsaircraft.com ) with all of their panels, including their prototype panel. Just need a radio stack built? We can do that to!!! Want to build it yourself? We can provide you with all the wire, labels, equipment, wiring diagrams or anything else you need. Please visit our website, www.electronictechnologies.net , or email us at etech(at)ucnsb.net . You can also give us a call at the number below. Thanks a lot
Rick Case
1501 Airway Circle
New Smyrna Beach, FL32168
(386) 426-1213
Thanks Harry for taking the time to write this trip up. Plenty of helpful
hints for anyone else wanting to do the same ride.
Fred
----- Original Message -----
Subject: Rocket-List: Story on trip to alaska
son
is
survival
up
in
at
later!)
than
> Day One
Luis
Got
get
one
Mothers.
bed.
> Day Two
landing
yet
didn't
suffered
corner
100
bush
again! .
the
> Day Three Four Five
type
minute
find
nice
arrive
tour
So
we
Those
this
and
Piper
is
sound
laugh
dodge.
> Day Six
all
they
is
you
the
us.
and
about
down
in
to
> Day 7,8,9
and
of
of
is
> t
antsy
you
and
ahead
something
able
if
> restaurant!
Jasper
I
some
states.
airplane
> in a heartbeat!
> Harry Paine
> 266HP
Subject: | GI-106A for sale |
Hello Everyone,
We have an extra GI-106A that belongs to a customer for sale. Has never been installed
or used. Still in original box with install kit and install manual.
Customer was going to get two CDIs, but decided to get an HSI and a CDI. Customer
asking $1398.37 plus S&H. We can pre-wire for a small additonal fee.
If interested, please call or email.
Rick Case
1501 Airway Circle
New Smyrna Beach, FL 32168
(386) 426-1213
"Rocket-List Digest List"
I do quite a bit of aerobatics but seldom pull more than 4 g's. The new aerobatic
mounts may be overkill, but it would be nice to put them on and forget about
engine sag forever. I currently have Lord J-9613-12's and with 375 hours on
them and they show some sag and deterioration.
Click this to see a promotional ad for Lord's new Aerobatic Mounts. P/N J-7764-31.
http://www.lordcorp.com/news/2001/veteran_aerobatic_pilots_say_new_lord_mounts_take_best_of_show.htm
I found that these new mounts cost about $102 each and it takes about 6 months
to get them. The J-9613-12's which I now have cost about $84 each and are available
immediately.
Does anyone have anything good or bad to say about the new J-7764-31 Lord Aerobatic
Mounts?
Subject: | Apollo GX-65 IFR Enroute GPS/Comm for sale |
Brand new unit, $2487.50. Install Kit and manuals included. Shipping and Handling
charges vary based on shipping method (i.e. next day air will be more than
ground). Other units available as well. Ask For Rick.
1501 Airway Circle
(386) 426-1213
Subject: | oil cooler for cabin heat |
From: | "Bob Japundza" <Bob.Japundza(at)realmed.com> |
I was looking at the pictures of David Howe's engine installation over on Vince's
website and noticed that he's pulling cabin heat from the back of the oil cooler.
Does anyone know how well this works on a rocket? I recall that this
didn't work too well on the RV's, but that wouldn't be an apples-to-apples comparision.
Insert funny joke if you'd like.
Bob Japundza
RV-6 built, F1 building
Subject: | Re: Engine Mounts |
John--
I have the 7764-31 mounts on the Super 6 with about 100 hrs on them. Work great
and look brand new. About a year ago, Lord had a quiet little promotion campaign
for these mounts and were offering them to experimental aerobatic pilots
in exchange for a testimonial--I heard about this
from Tom Whelan (IO-540 RV-8). Can't remember the guy's name, but it was handled
thru their marketing department. Originally, (1998) I had the Barry mounts
that were recommended by Harmon Rocket at that time (Mooney 20M catalogue item,
I believe) and after 300 hrs the bottom muffins
were deformed.
Interestingly, I just had an A&P/IA show me the proper way to pull the accessory
case on the -540 and replace that &%#$$#** crankshaft gear retaining bolt (turns
out I had the "bad" zinc-plated one and Lycoming covered the parts and labor
even tho my engine is a -EXP, but it was built
by LyCon and they stand behind their work) and he wanted to know particulars about
these mounts because he knew my reputation for flying that little plane pretty
hard and he was impressed by how "good" the mounts looked.
As a side note on Rocket aerobatics: the most common two-blade prop is the Hartzell
M2YR-1BF, which has a 4" prop extension and is limited to 4 g's. Hartzell
also does not recommend "gyroscopic" maneuvers with this prop as it may be
exposed to side loading that may not register
accurately on your g-meter.
I'll have more to say about these mounts after I have the same number of hours
on them as the Barry ones.
Boyd
RV-Super 6
Venice, FL
on them and they show some sag and deterioration.
immediately.
Mounts?
> John
Is there a prop for the Rocket that does not require an extension (and
therefore reduce the +6 to +4)?
Chip Gibbons
[snip]
Hartzell M2YR-1BF, which has a 4" prop extension and is limited to 4 g's.
Hartzell also does not recommend "gyroscopic" maneuvers with this prop as it
may be exposed to side loading that may not register
[snip]
Do you realy want to do 6+ G's ?
I would really like to not be limited by +4 g's.
-----Original Message-----
Hr2pilot(at)aol.com
Subject: Re: Rocket-List: Engine Mounts
You may be happier and better off with a Pitts or an Extra. The Rocket II
airframe is good for at least + and - 6 G's
Subject: | 2002 List Fund Raiser - Please Support Your Lists... |
Dear Listers,
During November of each year, I have a voluntary Email List Fund Raiser to
support the continued operation, development, maintenance and upgrade of
the Email Forums sponsored here. Your Contributions go directly into
improvements in the systems that support the Lists and to pay for the
Internet connectivity primarily dedicated to supporting the Lists.
The traffic on the Lists continues to grow and the numbers are nothing
short of impressive! Here are some statistics that show much traffic the
Lists generated last year alone:
11/01/2001 - 10/31/2002
Web server hits: 8,700,000 (727,000/mo)
Incoming Email Posts: 51,259 (4,271/mo) *
* This number is multiplied by the total number of email addresses
subscribed to the given List. The actual number of email message processed
is in the 50,000,000 range for last year!!
The new Internet provider, Speakeasy, has been providing extremely fast and
reliable service over the last year, and this has certainly been a
refreshing change from previous providers!
There were a couple of new features added at the tail-end of last year
including the new List Browse Feature ( http://www.matronics.com/listbrowse
), and the List Photoshare which have been both very popular. Many people
have written to say how much they enjoy the on-line browsing capability of
current week's messages. The 184 new Photoshares (
http://www.matronics.com/photoshare ) added over the last year attests to
its acceptance and appreciation in the community as well.
I have upgraded both the email and web server OS systems recently to the
latest - well almost the latest - version of Redhat Linux and Kernel
2.4.19, both of which have been working very well and quite reliably.
What does the future hold? Well, something pretty exciting I'm
hoping... I am currently evaluating a new, commercially available software
package that runs under Linux and provides a complete web-based Email List
service akin to what those other guys use. The difference will be that
there won't be any annoying advertisements and popup ads on the Matronics
system!! The system will continue to be dedicated to furthering Lists
activities and not trying to sell you something you don't want. My hope is
to keep most if not all of the current functionality in place and add the
new software system over the top. Some of the system will be replaced
(like majordomo), but the lists will work much like they do today - only
BETTER! As I mentioned, I am currently in the evaluation stage of this and
have yet to select a final product. Suffice to say some facelifts are
definitely on the way!
Unlike many of the other "list servers" on the web these days, I have a
strict no-commercial-advertisement policy on the Matronics Lists and
associated List websites. I have been approached by a number of vendors
recently with advertising deals that have been very tempting. However, my
commitment to providing a grass-roots, non-commercial environment
prevails! Commercialism on the Internet seems to be increasing
exponentially every year with more and more SPAM and pop up ads, not to
mention the ever increasing Virus attacks. My goal with the Matronics List
Service is to provide my members with a commercial-free, safe, and
high-performance system in which to share information, ideas, and
camaraderie.
I recoup my upgrade, maintenance, and operating costs by having a List Fund
Raiser once a year during November. During this time, I ask List members
to donate a small amount of money to support the continued operation of the
Lists over the upcoming year. Contributions in the $20, $30, and $50 range
are common. This year I have completely revamped the Contribution website,
and have added the ability to use PayPal to make your Contribution in
addition to the traditional Visa/MC and Personal Check Options. Its easier
and faster than ever before to make your Contribution!! For those who are
accustomed to using PayPal to make Internet purchases, will appreciate the
ease and speed of using this handy method of payment to make their List
Contribution.
The best news this year, however, is that I have a couple of fantastic Gift
offers to support the List Fund Raiser! Andy Gold of The Builder's
Bookstore ( http://www.buildersbooks.com ) will be generously donating a
FREE Jeppesen Flight Bag to anyone making a $50 or more List Contribution
during the Fund Raiser! This is a great bag and something you'll surely
what to get your hands on. Thanks Andy, for this great incentive!!
In addition to the great Flight Bag, I will also be offering a FREE
Matronics List Archive CDROM for a $50 or greater Contribution! This is a
complete set of archives for all Email Lists currently hosted by
Matronics. The Archives date back to the beginning of the each List. In
the case of the RV-List, for example, this includes archives all the way
back to 1990! That's about 133Mb alone! Also included on the CD is a copy
of Chip Gibbion's Windows Archive Search Utility and a precompiled
search-index for each archive on the CD.
Better yet?! You can get BOTH the Flight Bag AND the Archive CD for a
Contribution of $75 or more which is actually LESS than the combined retail
price on the two items!!! How can you go wrong? Get some great stuff AND
support your Lists at the same time!
Over the next month I'll be posting a few reminder messages about the List
Fund Raiser, and I ask for your patience and understanding during the
process. Remember that the Lists are *completely* funded through the
generous Contributions of its members. That's it! There's no support from
a bloated advertising budget or deep pockets somewhere. Its all made
possible through YOUR support!
I would like to take this opportunity to thank everyone who supports the
List this year. Your generosity contributes directly to the quality of the
experience here.
To make your List Contribution using a Visa or MasterCard, PalPal, or with
a Personal Check, please go to the URL link below. Here you can find
additional details on this year's great free Gifts as well as additional
information on the various methods of payment.
SSL Secure Contribution Web Site:
http://www.matronics.com/contributions
Again, I would like to thank everyone who supports the Lists this
year! Your Contributions truly make it all possible!!
Thank you!
Unless you're a regular, young, and have excellent neck muscle control
youre blacking out around 4.5 to 5 Gs!!! Trust me on that one I know! I
regularly pull around 3 maybe 3.5 in a loop and thats it. I agree with John
if you want to hit 6gs get a Pitts
Harry Paine
266Hp the Alaskan gypsy
Harry Paine
I appreciate everyone's concern for my well being, maybe we can continue
this thread on Matt's aerobatic list. As for the Rocket itself, my question
remains: Is there a prop available for the Rocket which does not
effectively limit the aircraft to +4 g's?
Subject: | RV8 or RV tail for Harmon Rocket? |
Hi,
I'm about to start a HR2. Plans are on the way.
Was wondering which tail kit I should build ie RV4 or RV8?
Tony
Tony
You have three choices. The easiest to build would be the RV8, I have
used
it on two rockets and it works fine although some feel the elevators might
be too small. This has not been my experience. The RV4 tail has been used
on most rockets with success, it is a harder build but doable. The other
option is the F1 tail which has been designed specifically for these types
of planes. It is not quite as easy to build as a Rv8 tail but the parts are
very nice and the final product has quite a nice distinctive look.
Tom Martin
[mailto:owner-rocket-list-server(at)matronics.com]On Behalf Of Blair
Subject: Rocket-List: RV8 or RV tail for Harmon Rocket?
Hi,
Tony
Subject: | Re: RV8 or RV tail for Harmon Rocket? |
There are a lot of RV tails out there for as little as $400 ,The RV-6 tail
has also been used.
Subject: | New List Digest Feature!! [Please Read] |
Dear Listers,
I've added a new feature to the Digest format of the Lists tonight. At the
top of each digest you will find a new Index Listing of all of the messages
found within that Digest including the Message Number, Subject, Poster, and
Time of Day posted.
I've also added a "Message Number" header to each message within the Digest
so that its easy to find 'just the message' you were looking for!
Sorry for the double posting of the digests tonight - the first time I
didn't quite have the code right and a few "bogus" entries made it into the
Index. I went ahead and reposted the Digest so that everyone could see how
the Index-to-Message mapping really worked.
Special 'thanks' to Gary Hall for not only suggesting a Digest Index, but
also supplying a few samples on how it might look. Gary, I think you'll be
quite pleased with the format!
Don't forget that were right in the middle of this year's List Fund Raiser
and if you haven't already made your Contribution, you own it to yourself
to check out the great free Gifts that are available this year with your
qualifying Contribution.
The Lists are operated completely though the support of it members, and so
its up to YOU to get that credit card out and make that $20, $30, or $50
show of support for the continued operation of the Lists.
Won't you take a couple of minutes and make a quick Contribution on the all
new, streamlined List Support web site? I've also added a
Payment-through-PayPal option this year, and this is proving a very popular
method of payment. Don't forget to check out the great free gifts you can
get with a qualifying Contribution this year. I can't believe how popular
they've been this year! Hurry and get your's today and support the Lists
at the same time!
Here's the SSL Secure URL for making your Contribution:
Thank you for your Support!!
Matronics Email List Admin.
Subject: | Rocket prop and "G" limits |
I received the following from MT propellers this morning:
we do not have any G-Limits on our propellers, with any hub used. The latest
configuration for the F-1 Rocket, designed in cooperation with Mark Fredrick
is:
Propeller MTV-9-B/198-52 with Spinner P-810-A.
The hub is a 172 mm extended version, but since we have a different hub
design, not comparable to any Hartzell designated extension.
For the Harmon Rocket, it could be possible to use a different spinner,
because we assume a different cowling is used, but the deviation shall be
minor.
Best regards
Gerd R. Muehlbauer
President
MT-Propeller Entwicklung GmbH
So, that's the good news. The bad news? MTV-9-B/198-52: $9,170 P-810-A:
$1,130. Total damage: $11,300.
Chip Gibbons
Subject: | Re: Rocket prop and "G" limits;MT vs Hartzell pricing |
In a message dated 11/6/2002 7:23:38 AM Central Standard Time,
gibbons@cox-internet.com writes:
> Regards,
> Chip Gibbons
Hey Chip:
Those are retail prices...which I will gladly accept! But,...
I sell the prop + spinner for $8750. Shipping is not quite straightforward,
tho. You can have an un-assembled prop shipped to an assy shop near you, and
you can then drive over & pick it up. Shipping in this case runs about $250,
and assy about $300. Shipping the assembled prop direct will set you back
about $1100 (shipping, customs, etc).
FY2003 pricing on the 3 blade Hartzell w/composite spinner looks to be about
$8500 with shipping about $200 or so.
So, the prices are not that far apart. The Hartzell weighs about 75 lbs
w/spinner; the MT closer to 52 lbs.
Cheers!
Mark
Hi Chip,
Call Mark I think he can come up with a better price for the MT.
If you have it shipped disassembled - there are assembly outfits in the
US -
it'll knock another couple of hundreds off.
You should hear it running,- absolutely smooth. No comparison to a
Hartzell.
Wolfgang (F1, No.77)
[mailto:owner-rocket-list-server(at)matronics.com] On Behalf Of Gibbons
Subject: Rocket-List: Rocket prop and "G" limits
latest
Fredrick
is:
be
minor.
Best regards
Gerd R. Muehlbauer
President
P-810-A:
Chip Gibbons
Contribution
In a message dated 11/6/02 6:51:42 AM Mountain Standard Time, Mlfred(at)aol.com
writes:
Gents, There are some archival notes about the development of the MT for the
HR/F-1... what is the current status if anyone is running the MT ?? Mark ??
Quest: 1 How does the MT @ 52# compare with Hartzell 2-blade for weight?
2) Is it compatible with the usual governors ?
3) If received unassembled, can any prop shop figure it out or do certain
ones specialize in the MT ? (Who might serve Colorado ?)
4) Is the MT spinner metal... can be polished ??
Thanks, John Meyers Golden CO
In a message dated 11/6/2002 8:58:09 AM Central Standard Time,
JOHNTMEY(at)aol.com writes:
> the
Hey John:
MT has designed a blade special for the F1/HR series. It does work very well
indeed, as I see the same IAS at the same RPM/MP/fuel flow as before. Smooth
as a watch, too. This particular aspect is eerie -- you absolutely canot tell
any RPM change if you are judging from the vibration frequency -- you have to
watch the tach!
The blades are tuned to 2100 RPM @ 10,000MSL, as is the 'D twist' 3 blade
Hartzell.
No change, if you use the non-coounterweighted version.
You bet -- no change. Due to the very low blade inertia level, MT recommends
using a faster acting gov, like the CZ units we sell. These govs are 2 1/2
lbs lighter than a comparable Woodward, and cost $1150 new.
If you are not going to run an inverted system, I'd recommend using the
counterweighted type prop, which costs about $600 more. A scenario where you
wuld lose oil pressure, and prop control right after that, would be a
complete disaster, as the engine would spool up so fast (the MT blades have
bvery little inertia). The different style prop would remove that
possibility, but I suspect it would weigh a bit more.
Go to the MT website and look under distributors for an assembly shop in your
area -- there is one in the Broomfield CO area.
Nope -- composite. They will paint the prop & spinner any color you want for
$150 extra.
Cheers!
Mark
> the
Hey John:
watch the tach!
Hartzell.
$150 extra.
Cheers!
Mark
> the
Hey John:
watch the tach!
Hartzell.
$150 extra.
Cheers!
Mark
Subject: | Lycoming Service Bulletin |
As of November 4, Lycoming has now made SB 554 apply to all factory and
field IO-540 overhauls since November 27, 1996, where the bolt was replaced.
Another fine Lycoming product!
Enjoy
Russ
Subject: | Re: Lycoming Service Bulletin crankshaft bolts |
>Enjoy
>Russ
Listers:
This aad and service bulletin we rather poorly written. My engine was field
overhauled during the suspect time frame which is
between 11-96 thru 11-98. The crankshaft bolt was replaced and therefore
suspect. However it turns out that Superior Air Parts
also manufactored and sold those bolts also. These bolts are not affected
because they used a different manufactor. Thelycoming bolt is identified by
the number STD 2209 and is supposed to golden in color.
the superior bolt has stamped on the head "SL" and could be silver, or
different shades of gold. their part number is
SL- 2209
Alrighty then......... if you rebuilder used superior bolts you're okay..
if he used lycoming ones have fun.
Harry Paine
>HP
266HP the Alaskan Gypsy.
Seems many were using the bolt color to determine which lyc bolt they have
installed. Now, in the latest update to the SB, lyc says:
"2. Plating of the bolt can result in a wide range of coloration;
therefore, using the color of the bolt
is not a reliable method of identifying acceptability."
Just when I thought this would be easy! You can see the bolt through the
right mag hole, but now that isn't good enough, apparently.
Russ
> This ad and service bulletin we rather poorly written. My engine was field
by
> SL- 2209
Subject: | List Fund Raiser - What Listers Are Saying... |
Dear Listers,
First, I'd like say *thank you* to everyone that's already made a
Contribution to this year's List Fund Raiser! Thank you! If you haven't
already made a Contribution, won't you take a movement and show your
support for these valuable services? Since there's no advertising or other
forms of direct commercialism on the forums to support the Lists, its soley
YOUR GENEROSITY that keeps them running!!
Won't please take a minute and make a Contribution via the SSL secure web
site via Credit Card, Paypal, or personal check. Here's the URL:
This year, I've been getting some *really* nice comments from Contributors
and I thought I'd pass along a few of them below. What does the List mean
to *you*?
Thank you for your support!!
Email List Administrator
_________________ What your fellow Listers are saying... _________________
...great service!!
Greg B.
They have been a great assistance to me in building my RV-8.
Kevin H.
...very much appreciated.
Donald M.
Great site...
Angus F.
...invaluable resource.
Ronald C
[The List] has played a big part in continuing my project at
those times when I got stuck for some reason.
Jeff D.
Although I am only a reader, I find the list very helpful.
Oswaldo F.
The lists are a fantastic resource and are helping me very much...
Kenyon B.
The list is part of my life.
Ron C.
The CD will free up some hard disk space on my personal PC.
Jeff D.
...unbelievably useful.
Dan O.
...dependable and valued source of builder information.
Jerry C.
My daily lifeline!
Owen B.
...frequently get questions answered on the List.
Billy W.
Don't know how any first-time builder could get by without the lists.
Rick R.
...great source of information and motivation.
Jef V.
Super resource!
David P.
The information presented is very helpful to the building process.
James B.
Wonderful Service!
Wendell D.
The lists are great!
F. Robert M.
...very valuable to this builder.
William C.
Subject: | Re: Rocket-List Digest: 9 Msgs - 11/06/02 |
Does anyone have experience or opinion on the ACI composite props for the
F1?
According to the wording in the Lycoming SB 554 and I Quote" Lycoming
requires that the crankshaft gear retaining bolt be replaced with the new
bolt P/N STD-2209
( cadium plated) and SILVER in color. Not gold.....billy
I guess it shoul be replaced with a new Lyc. bolt just for peace of mind.billy
From: | "Loren Harmon" <landsharmon(at)attbi.com> |
I talked to the designer of the ACI prop extensively at Sun n Fun in
April. He seemed very knowledgeable and the prop is all composite and
even lighter than the MT. It looks great and sounds like a real
performer if you believe the Lancair IV performance report. The
drawbacks... $15,000 for the prop and as of last April he didn't have
one optimized for the Rocket. It sounded like he was willing to make
one, and I thought that Mark was going to get one for evaluation, but I
don't think that it came about. I'll be looking for them again next
April. Their website is www.aerocomposites.com
Loren Harmon
s/n 76
I used Lycon, who built up my engine. The AD specifies:
Warranty is available for material required for bolt replacement (Kit
05K19987). Labor for installation
will be reimbursed in accordance with the current revision of Removal and
Installation Labor Allowance
Guidebook, SSP-875 through an authorized Lycoming Distributor, using the
standard Warranty Procedure
and provided the removed retaining bolt is returned to Lycoming with the
engine serial numbers.
----- Original Message ----- > Could you provide the details and or a point
of contact to get a parts kit
> at Lycomings expense?
Subject: | Lycoming parts kit(crank bolt SB) |
For anyone interested in a repair kit to fix the crank bolt Service bulletin, I
just ordered one from A.E.R.O. Aviation Co. The kit included 10 gaskets (sump,
accessory,fuel pump and other accessorys), the bolt (Superior brand), and lockplate.
The cost of the kit was 48 bucks plus shipping.
Six Clear,
Jim Stone
Subject: | List Fund Raiser Continues... |
Marie Murillo
Dear Listers,
Just a quick reminder this morning that we're well into this year's Email
List Fund Raiser. Response has been great so far and there has been a lot
of interest in the Gift options. Speaking of those Gifts, I received a
sample of the Jeppesen Flight Bag from Andy Gold of the Builder's Bookstore
http://www.buildersbooks.com this weekend, and let me just say that this is
an extremely fine quality unit. Its very light, folds down into a very
small form for storage, and will hold a whole lot of your "pilot
stuff"! For a mere $50 List Contribution, one of these very nice bags
could be yours! You'll be the envy of all your friends.
Won't you make a Contribution today to support the these valuable Email
List Services? Please remember that its YOUR generosity that entirely
supports the continued operation and upgrade of the Lists. That's it - no
ads, no banners - just good clean fun; that is, with your support of course!
Please take a moment and make a generous Contribution today. It only takes
a minute using the newly redesigned Contribution Web Site where you can use
either a Credit Card, PayPal, or a Personal Check to make your donation.
The URL for the SSL Secure Contribution web site is:
And I'd like to say a special "thank you!" to everyone one who has made
Contribution so far this year!! I really appreciate your generosity!
Best regards,
Subject: | There's a new yahoo group |
Just wanted to let you all know that there's a new yahoo group called experimental
avionics...here's the link if you want to take a look
http://groups.yahoo.com/group/ExperimentalAvionics/
From: | "gretz aero" <warrengretz(at)gretzaero.com> |
"Avionics-List" ,
"RV-List" ,
"Rocket-List" ,
"AeroElectric-List"
Subject: | Heated pitot tube prices going up |
Hello Listers,
I just found out that the price of the heated pitot tubes I sell is going up. The
manufacture notified me that beginning at the first of the year the price is
going to increase. I do not know how much yet. I am sure I will have to increase
my price as well when this happens.
I currently have a good supply of both the PH502-12CR and the AN5814 pitot tubes
in stock and will be receiving another batch at the first of next month at the
lower price. My advice is to purchase this item now before the first of the
new year and save some money.
You can order by calling me or place your order on my website at http://www.gretzaero.com I hope to hear from you soon.
Warren Gretz
Gretz Aero
720-308-0010 cell days
303-770-3811 home office, evenings and weekends
Subject: | Service Bulletin |
If anyone has questions regarding complying with the latest Lycoming SB as a
do-it-yourselfer let me know. I did it this afternoon and it is no big
deal.
Russ
Subject: | Re: Service Bulletin |
Russ,
How many hours did take you?
Did you remove the sump as well to avoid cutting the gasket and possible
future oil leak?
Any tips or gotchas?
Jim
Starting on mine today or tomorrow.
Subject: Rocket-List: Service Bulletin
a
> deal.
> Russ
Here's what I found:
You have to remove the magneto(s), oil filter adapter, fuel pump, and if you
have one, the vacuum pump. If you have a tach drive cover, remove that too,
as you can use the hole to look through when you put the accessory cover
back on later. Remove the tach cable if you have one of those (antique?).
Undo all the hose clamps holding the intake pipes to the sump and slide the
2" hoses up onto the intake tubes. That will give you a space of about 1/4"
at each pipe so you can drop the sump. I removed the accessory cover first,
but I think it would be easier to get things apart if you remove the sump
first, as gravity will help you here.
Replace THE DEMON BOLT. Torque is 17 ft/lbs.
On re-assembly, I put the sump on first and that worked out well. I used
assembly lube on the fuel pump arm and the tach drive shaft. When you put
on the accessory case, you need to make the tach drive find the hole in the
casting and it is a bit awkward. Sight through the hole mentioned before
and you can see it. The gasket for the accessory case is extra long on
both lower ends and needs to be trimmed. It will be easier to do this
before you put any gasket adhesive on it.
If you have a B&C Oil filter adapter, get a gasket now, as Lycoming does not
include that in the kit. I'm waiting for mine now. If I was ready to fly,
I'd modify the Lycoming gasket and bolt it on now. It needs a bigger
opening in the center.
Total time for me for just the engine repair without R&R: about 4 hours. I
think Lycoming will pay 20 hours total for the entire job of R&R and Repair.
Be sure to safety wire everything properly.
If you think this job is a pain in the ass, don't. Have fun. The folks
who's bolt failed have the pain in the ass.
Aloha,
Russ
> Russ,
> future oil leak?
> Jim
hey russ, how long did it take you to do the job? billy
I got real lucky... The scope through the right mag hole proved that the bolt
was a bright silver color.. The correct one...
Larry #001
That's not good enough anymore. The SB was amended to require replacement
of any colored bolt.
Russ
bolt
Actually, I doubt I needed to remove the oil filter adapter. Oh well!
Russ
Dear Listers,
Wow, I can't belive some of the nice things people have been saying about
the Lists in that little message box on the Contribution form! I've
included more of the great comments since the last WLAS. Thank you to
everyone that has made a Contribution thus far and for all the great
feedback! Please know that I really appreciate the comments and support!!
Have a look at some of your fellow members thoughts below and decide if the
Lists mean at least that much to you or perhaps even more...
Won't you take a moment and make a Contribution to support these
Commercial-Free, SPAM-Free, Virus-Free, high-performance List
services? Its your direct support through this yearly Fund Raiser that
enables all of these valuable services you've come to expect of the
Matronics Lists.
Thank you for your Contribution!!
SSL Secure Web Site - http://www.matronics.com/contribution
EMail List Administrator
=================== What Listers Are Saying - II ====================
I check this List 4 to 5 times a day...
-Bruce B.
These are without a doubt among the best managed
Lists to which I subscribe.
-Terry W.
Thank you for providing such a wonderful service.
-Roy W.
...fine service!
-Christopher A.
Best list on the Internet!
-Geroge A.
Great list with a host of features.
-David A.
Having built part of a kit... ...I know exactly how
much this list means to me and others.
-Curtis H.
As always... you've got a real cool & very useful
service going...
-Chuck R.
I shudder to think of the trouble I would have had
getting this project airborne without this list!
-Grant C.
...enjoy everyone's input.
-Doug P.
I read the [the List] every day...
-Ronald S.
Whenever I feel like not building on my day
off....I open my mail and the [the List] gets me
pumped and ready to hit it!
-Tom E.
The Digest Message subject list is an excellent
addition.
-Kevin S.
Certainly the [the List] has been a valuable source
for building support and advice, but there's another
benefit,... the wonderful friends that we meet and
keep for years and years!
-Fred H.
What a great forum to exchange ideas and info.
-Terry L.
The List is my daily RV fix.
-Neil H.
I always received comments and suggestions when
I requested them.
-Thomas G.
Best resource a builder could ever have. A daily
must!
-Robert C.
Thanks for your gift - these web sites!
-Tom P.
...great info.
-Richard W.
The List empowers all RV builders to achieve success...
-Mark G.
I've been reading the postings for a month now and
decided to take the plunge as a result of the
helpfulness and spirit of cooperation I observed.
-Tim P.
...invaluable service.
-Ford F.
I check in at least twice daily for my e-mail "Fix".
-John S.
Its worth every penny of my contribution.
-Paul M.
Wonderful web site and it keeps getting better.
-Jim H.
A valuable list which has certainly helped me.
-Andrew G.
...the List helps so many.
-Don J.
I really appreciate the site and find it interesting
to speak to people who are into this type of aircraft.
-Larry M.
This is a great recreation for me.
-Larry B.
[The List] keeps me up to date and provides a fantastic
resource for information.
-Terry F.
Lists are a great resource!
-Daniel S.
...great service and professional administration of
the Lists.
-Chris R.
I really appreciate the List.
-Edward O.
Worth every penny, and then some!
-Kenyon B.
...great service.
-Ralph H.
Your unselfish contribution to the experimental
aircraft movement is very much appreciated!
-Alex M.
Great help on the Aeroelectric list.
-Bruce B.
It helps on a daily basis.
-Tim G.
Thanks for providing this outstanding service to us!
-Michel T.
Russ... Im sad to say that you may be correct... Im again in TN and my wife
said there was a phone message from the engine builder that we needed to
change the bolt anyway... Sh-------... Larry
Subject: | LOC Coming Soon... |
Dear Listers,
This year's List of Contributors (LOC) is just around the corner. I'll be
posting the LOC on or about December 1. The List of Contributors is a
directory of everyone's name that made a Contribution during this year's
List Fund Raiser. Its kind of my way of publicly thanking everyone that so
generously made a Contribution to support the continued operation and
upgrade of these Lists.
Support your Lists today and make sure that your name is on the upcoming
LOC! Your friends will be checking no doubt to see if YOU make your
Contribution because THEY did! :-)
Support Contribution Info - http://www.matronics.com/contribution
Thank you!
Subject: | [PLEASE READ] - Why Do I Have A Fund Raiser Each Year? |
Dear Listers,
I got to thinking today that perhaps I should explain why I have a Fund
Raiser and also take the opportunity to express why I think the List
Services here provide a far better experience than the commercial
equivalents.
I use the List Fund Raiser each year to offset the costs involved with
running a high performance email list site such as this one. With the
annual support from the List members through the PBS-like Fund Raiser, I
have found I can run the entire site without having to inflect any of the
members with those annoying banner ads flashing up all the time trying to
sell Toner Cartridge Refills or other garbage nobody wants or needs. From
the comments I've received over the years regarding the Lists, the great
majority of the members really appreciate the non-commercialism of my List
systems and don't mind my 'go-team-go' banter once a year to encourage
members to support the Lists.
I believe that the Lists services that I provide here offer a great many
benefits over the commercial equivalents in a number of ways. The first
feature I believe to be particularly significant is that you *cannot*
receive a computer v*rus from any of my Lists directly. I've been on a few
other List servers and have been unfortunate enough to download infected
files people have innocently or not-so-innocently included with their
posts. This just can't happen with my Lists; each incoming message is
filtered and attachments stripped off prior to posting. I provide a Photo
and File Share feature that allows members to share files and bitmaps with
other members and everyone can be assured that these files will be
prescanned for any sort of v*rus before they are posted. Safe and
simple. Also, with this photo and file sharing technique, the Archives
don't get loaded up with a huge amounts of bitmap "data" that slows the
Archive Search times.
Another feature of this system is the extensive List Archives that are
available for download, browsing, and searching. The Archives go all the
way back to the very beginning of each List and with the super fast Search
Engine, the huge size of the Archives is a non-issue in quickly finding the
data you're looking for. Another feature of the Archives, in my opinion,
is that they have been primarily stripped of all the useless email header
data and all the other header garbage that seems to build up in a typical
email thread.
I have received an extremely positive response from Listers regarding the
List Browse feature and the consensus is that the format and ease of use is
outstanding. Members report that having the previous 7 days worth of
messages online for easy browsing and sorting is hugely beneficial. And
again, as with the real time distribution of List email, the messages are
stripped of all the unnecessary email headers and potentially dangerous
v*ruses. I am currently working on the additional ability to post and/or
reply directly from the List Browse interface. More on this upcoming
feature in the next week or so.
I've been running email Lists and services under the matronics.com domain
since about 1989 starting with RV-List and 30 guys who I knew and who where
also building RVs. It has grown into over 40 different aviation-related
Email Lists and an associated web site that receives over 9,000,000 hits
each year!! Additionally, the List email system forwards well over
50,000,000 (yes, that 50 MILLION) email messages to subscribers each
year! With all the dot.bombs these days, I think there's a lot of value in
supporting a service that has gone the long haul and is still providing and
improving a high quality service at a price that's nearly free.
I have to admit running these Lists is a labor of love and I hope it shows
in the quality of the experience that you receive when you get a List Email
Message, Search the Archives, or use the List Browser. The Lists will be
here for a long time to come. If you just want to lurk a while for free,
that's great and I encourage you to do so. If you use, appreciate, and
receive value from these Lists, then please support them during the Annual
List Fund Raiser!
Thank you,
The SSL Secure Web Site:
Subject: | FW: RV6a For Sale |
July 06, 2002 - November 22, 2002
Rocket-Archive.digest.vol-ai
