RotaxEngines-Archive.digest.vol-bc
October 10, 2012 - January 15, 2013
      Now, there are different types of load test equipment out there.  You could
      go with the old favorite Resistor Bank which puts a heavy duty load on the
      battery and returns a meter reading of condition.  They are big, bulky and
      require a cool down between uses.  And deplete the charge in the battery.
       So after you check the battery you should re-charge the battery.  OLD
      SCHOOL but it does work.
      New School - I have been very satisfied with a simple digital unit that is
      offered by Harbor Freight that gives you Voltage, % of Life, Condition and
      INTERNAL RESISTANCE.  The internal resistance is very important.  It tells
      the condition and if the battery is capable of taking and holding a charge.
       It also give you an idea of how many years you have left on the battery.
      The idea of a battery tender is a great idea as long as you have AC at your
      plane.  If you are like me and are tied down without AC - You can still do
      the battery tending with a Solar Panel.  How big a solar panel?  In this
      case use the American Theory - Bigger is Better.  I found a 5 Amp panel and
      ordered a controller for it.  Yes, you can over charge with a solar panel
      if the current is high enough, ergo the controller.  Mine hooks directly to
      the battery through an all rubber trailer hitch plug & jack.
      BUT!  Perform the series of test I sent.  As the saying goes: There are
      no mechanics in a can.  You just have to find and eliminate the problem
      through procedure and dirty hands.
      Barry
      PS
      I would rather get my hands dirty on a plane than a car.  GAUD I hate cars.
       All they have to do is get me to the plane and I have more problems with
      them than planes.  :-)
      On Tue, Oct 9, 2012 at 12:43 PM, JohnF  wrote:
      > 117 hrs on the Rotax. No real problems but a few days ago when turning the
      > start switch the starter did not engage, but seemed to "jam" and didn't
      > turn. Upon retrying it engaged and started normally. I suspected a low
      > battery, but overnight charging didn't change anything. This morning again
      > with as fully charged battery it did the same thing, but started right up
      > on second try.
      > I tried to demonstrate this to two other pilots and everything was normal;
      > prop turned over immediately with nothing abnormal happening on two
      > consecutive starts.
      > I seems (a wild guess) that the starter gear teeth are hitting, rather
      > than meshing, with the engine.
      > Not to sure what to make of this.
      > John
Subject: Re: Rotax 9112 ULS Starter Oddity
Date: Oct 10, 2012
FlyaDive and Thom, I have a hangar with power...will check battery terminal voltage and see how it compares to Thom's data...I have thinking about this problem and now lean toward thinking it MIGHT be the starter relay because of a clicking-like sound when the problem arises. I plan to remove, clean and re-tighten all connections from the battery to the starter relay and then on to the starter itself...will do this today and report results. Thanks for the help John ----- Original Message ----- From: FLYaDIVE To: rotaxengines-list(at)matronics.com Sent: Wednesday, October 10, 2012 7:09 AM Subject: Re: RotaxEngines-List: Rotax 9112 ULS Starter Oddity JohnF: As a follow up to Thom's suggestion: Voltage checking will put you in the ball park but, you have to identify the type of battery you are using. Is it a: Wet Cell Aircraft Wet Cell Sealed Battery Aircraft Sealed Battery If it is a Wet Cell then the method of testing should be a Hydrometer. They tell so much, even by just by looking at the color of the electrolyte you can get information on the condition of the battery. Clear is good - Brown is Bad. Reading the Specific Gravity (SG) will tell you the charge. Why do I mention Aircraft Battery Vs just Battery? Because the SG of the electrolyte is different between the two. The Aircraft Battery has a higher SG. AND therefore a Higher Voltage if you use a voltmeter. With Aircraft you could read a higher voltage while the condition (Amperage) of the battery is poor. This is true for comparison between both batteries and even types Wet Vs Sealed. Next method of testing and probably the best is a load test. Now, there are different types of load test equipment out there. You could go with the old favorite Resistor Bank which puts a heavy duty load on the battery and returns a meter reading of condition. They are big, bulky and require a cool down between uses. And deplete the charge in the battery. So after you check the battery you should re-charge the battery. OLD SCHOOL but it does work. New School - I have been very satisfied with a simple digital unit that is offered by Harbor Freight that gives you Voltage, % of Life, Condition and INTERNAL RESISTANCE. The internal resistance is very important. It tells the condition and if the battery is capable of taking and holding a charge. It also give you an idea of how many years you have left on the battery. The idea of a battery tender is a great idea as long as you have AC at your plane. If you are like me and are tied down without AC - You can still do the battery tending with a Solar Panel. How big a solar panel? In this case use the American Theory - Bigger is Better. I found a 5 Amp panel and ordered a controller for it. Yes, you can over charge with a solar panel if the current is high enough, ergo the controller. Mine hooks directly to the battery through an all rubber trailer hitch plug & jack. BUT! Perform the series of test I sent. As the saying goes: There are no mechanics in a can. You just have to find and eliminate the problem through procedure and dirty hands. Barry PS I would rather get my hands dirty on a plane than a car. GAUD I hate cars. All they have to do is get me to the plane and I have more problems with them than planes. :-) On Tue, Oct 9, 2012 at 12:43 PM, JohnF wrote: 117 hrs on the Rotax. No real problems but a few days ago when turning the start switch the starter did not engage, but seemed to "jam" and didn't turn. Upon retrying it engaged and started normally. I suspected a low battery, but overnight charging didn't change anything. This morning again with as fully charged battery it did the same thing, but started right up on second try. I tried to demonstrate this to two other pilots and everything was normal; prop turned over immediately with nothing abnormal happening on two consecutive starts. I seems (a wild guess) that the starter gear teeth are hitting, rather than meshing, with the engine. Not to sure what to make of this. John ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Oct 10, 2012
You should also insure that there is only a minimal voltage drop offered by battery cables and connectors.- Put a remote starter switch on the firew all mounted starter solenoid so that you can manually operate the starter w ith ignition off.- With a volt meter connected from starter input to grou nd, monitor the actual voltage present at the starter input terminal during cranking of engine.- 12-volt starters require a minimum of 9.0-9.5 vol ts across the primary motor winding to avoid-"stall".- A connection tha t is causing as much as .50 volt drop in a high current carrying circuit wi ll also become hot to the touch (good idea to touch connectors as a practic al test for high resistance connection).- The test just-described is co mmonly used by competent automotive technicians, when diagnosing sluggish a utomotive starters, prior to replacing either starter or battery.- To the untrained observer, a starter motor in stall mode will send current toward infinity and pull battery voltage down...often-resulting in misdiagnosis .- The auto owner will often end up being told that both starter and batt ery are defective!- - The Sky-Tec starter has greatly improved cold weather starting for my 912 U L Rotax engine.- This starter is on steroids when I turn the ignition key .- Last winter I made one ski trip to Bessemer in upper Michigan.-When I-returned to the airport,-I had-no concerns about engine cranking sp eed on engine start up.- The engine fired up immediately and I was on my way for the return trip home. Dave Weaver- --- On Wed, 10/10/12, Thom Riddle wrote: From: Thom Riddle <riddletr(at)gmail.com> Subject: RotaxEngines-List: Re: Rotax 9112 ULS Starter Oddity Date: Wednesday, October 10, 2012, 7:05 AM JohnF, You said that it occurred again when the battery was fully charged. Do you have a volt meter in your airplane? If not, after fully charging the batter y, before you try starting it in the morning, disconnect the charger and pu t a multi-meter (V-Ohm) meter on the battery to see what the actual voltage is. For a 12 volt lead acid battery the charge states are indicated by the foll owing approximate voltages: volts- ---charge-state 12.7+---100% 12.4- - ---75% 12.2- - ---50% 12.0- - ---25% 11.8- - - ---0% If your battery does not come up to at least 12.4 volts, it is probably rea dy for replacement. To keep them in good shape, a battery tender should be used during periods when the airplane is not flown often. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385032#385032 le, List Admin. ________________________________________________________________________________
Subject: Rotax 912 UL - Re-starting Problem
Date: Oct 10, 2012
I have recently begun having a problem restarting my engine after flying, landing and then doing a re-start. The engine is hot so I follow the correct procedure of keeping the choke closed and cracking the throttle. In the past I have had no problem on re-starting using this method, but now the engine will try to start and it will run very rough for some seconds (5 to 10 seconds), but then it quits. I repeat the start, but the same thin occurs. If I let the engine sit for say 5 to 10 minutes and try again the engine will start as normal. This is occurring every time I fly, land, cut the engine off, and then try to restart. Every thing else is fine. I can=99t figure out what may be causing this. Any suggestions? Hugh G. McKay III, P.E. Allegro 2000 Rotax 912 UL, 579 hours ________________________________________________________________________________
Date: Oct 10, 2012
Subject: Re: Rotax 912 UL - Re-starting Problem
On 09:11 AM 10/10/2012, Hugh McKay wrote: > Any suggestions? Vapor lock? -- Bob Comperini e-mail: bob@fly-ul.com WWW: http://www.fly-ul.com ________________________________________________________________________________
Date: Oct 10, 2012
Check that the choke/enriching circuit is completely closed and check the pl ug gaps. Sent from my iPad On Oct 10, 2012, at 11:11 AM, "Hugh McKay" wrote: > I have recently begun having a problem restarting my engine after flying, l anding and then doing a re-start. The engine is hot so I follow the correct p rocedure of keeping the choke closed and cracking the throttle. In the past I have had no problem on re-starting using this method, but now the engine wi ll try to start and it will run very rough for some seconds (5 to 10 seconds ), but then it quits. I repeat the start, but the same thin occurs. If I let the engine sit for say 5 to 10 minutes and try again the engine will start a s normal. This is occurring every time I fly, land, cut the engine off, and t hen try to restart. Every thing else is fine. I can=99t figure out wha t may be causing this. Any suggestions? > > Hugh G. McKay III, P.E. > Allegro 2000 > Rotax 912 UL, 579 hours > ________________________________________________________________________________
Date: Oct 10, 2012
Hugh: What is your definition of a 'choke closed'? Once an engine is warmed up - hot. You do not close the choke... Choke should be open to allow max air flow. Choking an engine adds more fuel than air. One method to prove this would be to inspect your spark plugs to see if they are WET next time you have this issue. If wet, then there is more fuel that the combustion process requires. Barry On Wed, Oct 10, 2012 at 12:11 PM, Hugh McKay wrote: > I have recently begun having a problem restarting my engine after > flying, landing and then doing a re-start. The engine is hot so I follow > the correct procedure of keeping the choke closed and cracking the > throttle. In the past I have had no problem on re-starting using this > method, but now the engine will try to start and it will run very rough f or > some seconds (5 to 10 seconds), but then it quits. I repeat the start, bu t > the same thin occurs. If I let the engine sit for say 5 to 10 minutes and > try again the engine will start as normal. This is occurring every time I > fly, land, cut the engine off, and then try to restart. Every thing else is > fine. I can=92t figure out what may be causing this. Any suggestions? > > Hugh G. McKay III, P.E. > Allegro 2000 > Rotax 912 UL, 579 hours > ________________________________________________________________________________
Subject: Starter Oddity
Date: Oct 10, 2012
I did my best to insure good contact on all points from battery to starter. The RV-12 that this Rotax 912 ULS is installed in is incredibly difficult to get at things aft of the engine...no room for even your hands in most cases unless you want to physically pull the engine - not a pleasant prospect. I found nothing suspicious excent that my cheapo digital multimete shows battery terminal voltage well over 14 volts, so I am disregarding that reading... After doing what I could about terminal condition I tried the starter without any ignition turned on. I did 10 prop starts and stops with no abnormal outcomes. I waited a while and did another 10, again no problems. I again waited a while and did another 10 and still no problems. (Battery seemed very strong during this effort) I hate intermittent problems; I know they always come back to bite you. For now I am going to leave things alone and see what turns up. Will post outcome. John ________________________________________________________________________________
Date: Oct 10, 2012
Subject: Re: Starter Oddity
John: Doing voltage checks with a meter that you are not comfortable with or that reads incorrect is a waste of time. Get a second meter of a different brand and compare the two. Use a simple NEW 1.5 VDC (D Cell) and see what that reads, then stack 8 D Cells and verify the meter accuracy (1.5 V x 8 12V). Doing your 10 prop starts is totally useless, SINCE there is a strong possibility the problem is your Starter Relay. As I mentioned before repeated starts burns off or knocks off carbon on the contacts and give a FALSE - Positive. Here is a test for that: 1 - REMOVE the wire TO the starter. 2 - Close the switch so the Starter Relay is engaged. {DO NOT DISENGAGE THE STARTER SWITCH ONCE YOU START THIS TEST} 3 - Read the Voltage across (INPUT to OUTPUT) the Starter Relay [INPUT to Ground... OUTPUT to Ground] - It should read the SAME as the Voltage going INTO (INPUT) the Starter Relay. 4 - Next with the Starter RELAY still closed {DO NOT DISENGAGE THE STARTER SWITCH ONCE YOU START THIS TEST} Read the Voltage ACROSS the Starter Relay - It should Read ZERO VOLTS. Any voltage means REPLACE the starter. 5 - A variation on the above test - With the Starter Relay STILL closed - {DO NOT DISENGAGE THE STARTER SWITCH ONCE YOU START THIS TEST} Read the RESISTANCE across the INPUT to OUTPUT terminals of the Starter Relay. - It should read ZERO OHMS on the LOWEST SCALE. ALSO - - - ZERO out the meter resistance OR subtract the meter resistance from your reading. Anything between 0 and 0.1 Ohms accept... ANYTHING OVER that - Replace the Starter Relay. John, if yo would like to add pictures please do so - They Help! Barry On Wed, Oct 10, 2012 at 2:03 PM, JohnF wrote: > ** > I did my best to insure good contact on all points from battery to > starter. The RV-12 that this Rotax 912 ULS is installed in is incredibly > difficult to get at things aft of the engine...no room for even your hands > in most cases unless you want to physically pull the engine - not a > pleasant prospect. > > I found nothing suspicious excent that my cheapo digital multimete shows > battery terminal voltage well over 14 volts, so I am disregarding that > reading... > > After doing what I could about terminal condition I tried the starter > without any ignition turned on. I did 10 prop starts and stops with no > abnormal outcomes. I waited a while and did another 10, again no problems. > I again waited a while and did another 10 and still no problems. (Battery > seemed very strong during this effort) > > I hate intermittent problems; I know they always come back to bite you. > For now I am going to leave things alone and see what turns up. > > Will post outcome. > > John > > * > > * > > ________________________________________________________________________________
Date: Oct 10, 2012
A poor ground and or corrosion will also cause this. Of course a bad relay too. Do the cheap things first. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385087#385087 ________________________________________________________________________________
Date: Oct 10, 2012
Hi Hugh, Make sure the float level in the carbs are at 10.5mm in height from the outside edge of the carb. When were the carbs last rebuilt? If it is over 5 years regardless of hours you may want to do an overhaul. Check the floats and make sure one isn't sinking (flooding) under pressure right after you stop. Plug gap between .023 - .027 and not over 75 hours old. new fuel pump or old? Do you have a fuel re-circulation line? -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385088#385088 ________________________________________________________________________________
Date: Oct 11, 2012
Roger, I don't quite understand your first sentence. Please explain in further detail. Carbs have not been "rebuilt" since new (550 hours on the carbs - 5 years and 3 months ). I guess to check the floats to see if one is "sinking" just take the bowl off and fill it with gas and see if the float "floats" or "sinks". Right? I will check the plug gap. Old original fuel pump. I do have a fuel recirculation line. Hugh G. McKay III, P.E. Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com -----Original Message----- From: Roger Lee Sent: Wednesday, October 10, 2012 9:53 PM Subject: RotaxEngines-List: Re: Rotax 912 UL - Re-starting Problem Hi Hugh, Make sure the float level in the carbs are at 10.5mm in height from the outside edge of the carb. When were the carbs last rebuilt? If it is over 5 years regardless of hours you may want to do an overhaul. Check the floats and make sure one isn't sinking (flooding) under pressure right after you stop. Plug gap between .023 - .027 and not over 75 hours old. new fuel pump or old? Do you have a fuel re-circulation line? -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385088#385088 ________________________________________________________________________________
Date: Oct 11, 2012
Hi Hugh, To check float levels you do just remove the bowls and put fuel in with the floats. The float pins should be equal to the fuel level. To check the float arm level you need to turn the carb upside down. Place a mm ruler and place it on the edge of the carb and measure the distance of the float arm up on the ruler. The proper height is 10.5mm. This controls fuel level in the bowl which has a big impact on the way the engine runs. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385122#385122 ________________________________________________________________________________
Subject: 912 UL vibration
Date: Oct 12, 2012
Hello List Yesterday I started the engine on the Kitfox IV I'm rebuilding. It's a 912UL from 1997 with 375 hours that I purchased about 6 months back. Before i purchased it, was checked by a qualified Rotax mechanic who among other things, changed a number of rubber parts. Before starting it, I manually checked the carb valves so that they were visually in a similar position. Anyway, the engine seems to have a rather strong vibration to it so I haven't run it for much more than 20-30 seconds at the time. I haven't had the carb valves aligned exactly with a pressure gauge, but the vibration is much more than what I would expect if it were just due to carb misalignment. And it doesn't seem to be the prop (a 3-blade Duc whose pitch has been set with the appropriate instrument). I called the Rotax mechanic who checked it and he suggested checking the carbs for obstructions which I have now done (I found an insect inside the left carb, but that didnt seem to change anything). I'll blow some compressed air through them today just to make sure that everything is clean. Does anyone have any suggestions as to what I could try next? The closest Rotax mechanic is a 5 hour drive from where I am in Sicily so I don't want to call him out before I have tried everything that I can do personally. Sacha ________________________________________________________________________________
Date: Oct 12, 2012
Subject: Re: 912 UL vibration
Hi Sacha I would double check that the prop isnt too corse first, a pair of vacuum gauges are the way to go too sinc the carbs, you could be way out by just visually checking the throttle linkage. Ivor On 12 October 2012 06:28, U wrote: > > Hello List > > Yesterday I started the engine on the Kitfox IV I'm rebuilding. It's a > 912UL from 1997 with 375 hours that I purchased about 6 months back. > Before i purchased it, was checked by a qualified Rotax mechanic who among > other things, changed a number of rubber parts. > > Before starting it, I manually checked the carb valves so that they were > visually in a similar position. Anyway, the engine seems to have a rather > strong vibration to it so I haven't run it for much more than 20-30 seconds > at the time. I haven't had the carb valves aligned exactly with a pressure > gauge, but the vibration is much more than what I would expect if it were > just due to carb misalignment. And it doesn't seem to be the prop (a > 3-blade Duc whose pitch has been set with the appropriate instrument). > > I called the Rotax mechanic who checked it and he suggested checking the > carbs for obstructions which I have now done (I found an insect inside the > left carb, but that didnt seem to change anything). I'll blow some > compressed air through them today just to make sure that everything is > clean. > > Does anyone have any suggestions as to what I could try next? The closest > Rotax mechanic is a 5 hour drive from where I am in Sicily so I don't want > to call him out before I have tried everything that I can do personally. > > Sacha > > ________________________________________________________________________________
Date: Oct 12, 2012
Hi Ivor, I just tried it with another prop and the vibrations are gone. Now I can sto p torturing those poor carbs :-/ although I will have them synced with a vac uum gauge. Thank you On Oct 12, 2012, at 9:28, PHILLIPS I wrote: > Hi Sacha > > I would double check that the prop isnt too corse first, > a pair of vacuum gauges > are the way to go too sinc the carbs, you could be way out by just visual ly checking > the throttle linkage. > > Ivor > > On 12 October 2012 06:28, U wrote: > > Hello List > > Yesterday I started the engine on the Kitfox IV I'm rebuilding. It's a 912 UL from 1997 with 375 hours that I purchased about 6 months back. Before i p urchased it, was checked by a qualified Rotax mechanic who among other thing s, changed a number of rubber parts. > > Before starting it, I manually checked the carb valves so that they were v isually in a similar position. Anyway, the engine seems to have a rather st rong vibration to it so I haven't run it for much more than 20-30 seconds at the time. I haven't had the carb valves aligned exactly with a pressure ga uge, but the vibration is much more than what I would expect if it were just due to carb misalignment. And it doesn't seem to be the prop (a 3-blade Du c whose pitch has been set with the appropriate instrument). > > I called the Rotax mechanic who checked it and he suggested checking the c arbs for obstructions which I have now done (I found an insect inside the le ft carb, but that didnt seem to change anything). I'll blow some compressed air through them today just to make sure that everything is clean. > > Does anyone have any suggestions as to what I could try next? The closest R otax mechanic is a 5 hour drive from where I am in Sicily so I don't want to call him out before I have tried everything that I can do personally. > > Sacha > > > ========== > -List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-L ist > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Oct 12, 2012
On my Duc propeller, two of the blades were a newer vintage and one was an o lder blade of the same model. It turns out the newer blades are lighter than the older ones and this is what was creating the vibration. I swapped out t he old blade for a new one and it now runs perfect... On Oct 12, 2012, at 10:41, Sacha wrote: > Hi Ivor, > I just tried it with another prop and the vibrations are gone. Now I can s top torturing those poor carbs :-/ although I will have them synced with a v acuum gauge. > > Thank you > > On Oct 12, 2012, at 9:28, PHILLIPS I wrote: > >> Hi Sacha >> >> I would double check that the prop isnt too corse first, >> a pair of vacuum gauges >> are the way to go too sinc the carbs, you could be way out by just visua lly checking >> the throttle linkage. >> >> Ivor >> >> On 12 October 2012 06:28, U wrote: >> >> Hello List >> >> Yesterday I started the engine on the Kitfox IV I'm rebuilding. It's a 91 2UL from 1997 with 375 hours that I purchased about 6 months back. Before i purchased it, was checked by a qualified Rotax mechanic who among other thi ngs, changed a number of rubber parts. >> >> Before starting it, I manually checked the carb valves so that they were v isually in a similar position. Anyway, the engine seems to have a rather st rong vibration to it so I haven't run it for much more than 20-30 seconds at the time. I haven't had the carb valves aligned exactly with a pressure ga uge, but the vibration is much more than what I would expect if it were just due to carb misalignment. And it doesn't seem to be the prop (a 3-blade Du c whose pitch has been set with the appropriate instrument). >> >> I called the Rotax mechanic who checked it and he suggested checking the c arbs for obstructions which I have now done (I found an insect inside the le ft carb, but that didnt seem to change anything). I'll blow some compressed air through them today just to make sure that everything is clean. >> >> Does anyone have any suggestions as to what I could try next? The closest Rotax mechanic is a 5 hour drive from where I am in Sicily so I don't want t o call him out before I have tried everything that I can do personally. >> >> Sacha >> >> >> ========== >> -List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines- List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> >> >> ========================== ========= ========================== ========= ========================== ========= ========================== ========= >> ________________________________________________________________________________
Date: Oct 12, 2012
No blades should ever be swapped from a set. These are usually picked for For their weight And balanced together with that hub. If you do try and mix blades then they have to be balanced. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385228#385228 ________________________________________________________________________________
Date: Oct 13, 2012
Roger: A friend of mine has a Rotax and a three blade prop (pusher). I do Dynamic Balancing on Lycoming and Continental engines. I would like to do dynamic balancing for him BUT, since there is not a ring-gear where would I place the weights? Barry On Fri, Oct 12, 2012 at 10:16 PM, Roger Lee wrote: > > No blades should ever be swapped from a set. These are usually picked for > For their weight And balanced together with that hub. If you do try and > mix blades then they have to be balanced. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=385228#385228 > > ________________________________________________________________________________
Date: Oct 13, 2012
Hi Barry, Unfortunately there are many different prop mounts that people use on their planes. Some have backing plates and spinners, prop hub extensions, ext... If they don't have a backing plate then you may be stuck with putting a large washer on one of the prop mounting bolts. If you do that it could take a little more weight because it is closer to the center of mass. Or you could get him to put a backing plate and spinner on his plane and would benefit from better air flow and the balance. With the backing plate you can then move the weight out farther from the center. Just so many of you know as a tidbit fact. It is more important and affects the flow of air to have a spinner on a pusher over a tractor prop. The air flow is affected more and in a positive way. Which is funny because we seem to always put spinners on tractor props. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385246#385246 ________________________________________________________________________________
Date: Oct 13, 2012
Roger: Would you recommend a Rear bulkhead and Spinner combination for a Ryan S12. It currently has a skullcap but I remember reading a lot about Long EZ types with fancy spinners that improved cooling and added a bit of speed. Barry On Sat, Oct 13, 2012 at 10:43 AM, Roger Lee wrote: > > Hi Barry, > > Unfortunately there are many different prop mounts that people use on > their planes. Some have backing plates and spinners, prop hub extensions, > ext... > If they don't have a backing plate then you may be stuck with putting a > large washer on one of the prop mounting bolts. If you do that it could > take a little more weight because it is closer to the center of mass. Or > you could get him to put a backing plate and spinner on his plane and would > benefit from better air flow and the balance. With the backing plate you > can then move the weight out farther from the center. > Just so many of you know as a tidbit fact. It is more important and > affects the flow of air to have a spinner on a pusher over a tractor prop. > The air flow is affected more and in a positive way. > Which is funny because we seem to always put spinners on tractor props. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=385246#385246 > > ________________________________________________________________________________
Date: Oct 14, 2012
Thank you Roger Is the balancing you refer to a DIY job or does it require specialized equipment? Sacha ________________________________________________________________________________
Date: Oct 14, 2012
Sacha: The post about balancing was posted by me, Barry. There a a couple of ways of doing balancing - Static and Dynamic. Static only requires a set of edge knives and spindle. This will put you in the ball park. Dynamic can be done - With quite difficulty - Using different old fashion equipment such as the vibratalk or the string & washer. I went with a bit more modern approach using a photo eye for RPM and an accelerometer to measure the displacement. Can it be done by the good builder? Yes. But, not many a builder will invest an additional $1500 to $2500 for the equipment - Much easier to get it done for $250 by an A&P. Barry On Sat, Oct 13, 2012 at 10:33 PM, Sacha wrote: > > Thank you Roger > > Is the balancing you refer to a DIY job or does it require specialized > equipment? > > Sacha > > ________________________________________________________________________________
Date: Oct 14, 2012
Subject: 912 i
On behalf of my quest for a definitive understanding of the 912 i electrical system requirements.. Has somebody found a circuit diagram of the central item called Fuse Box yet? Thanks, Jan de Jong ________________________________________________________________________________
Date: Oct 14, 2012
Thanks Barry, No A&Ps where I am, otherwise I'd gladly farm out this kind of stuff, even i f A&Ps here (I'm in Italy) are no way as cheap as the US :( The prop seems to be fine now, so I'll just leave it as it is until I find s omeone who can take a look at it... On 14/ott/2012, at 15:20, FLYaDIVE wrote: > Sacha: > > The post about balancing was posted by me, Barry. > There a a couple of ways of doing balancing - Static and Dynamic. > Static only requires a set of edge knives and spindle. This will put you i n the ball park. > Dynamic can be done - With quite difficulty - Using different old fashion e quipment such as the vibratalk or the string & washer. I went with a bit mo re modern approach using a photo eye for RPM and an accelerometer to measure the displacement. > Can it be done by the good builder? Yes. But, not many a builder will in vest an additional $1500 to $2500 for the equipment - Much easier to get it d one for $250 by an A&P. > > Barry > > On Sat, Oct 13, 2012 at 10:33 PM, Sacha wrote: > > Thank you Roger > > Is the balancing you refer to a DIY job or does it require specialized equ ipment? > > Sacha > > ========== > -List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-L ist > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Oct 14, 2012
Hi Sacha, Three different types of balancing. One is done at the prop factory where they make sure each blade weighs as close to the same as possible and makes sure the hub is also in a balanced state. This is then sold as a set. You can do two balances. One is the static balance and put very simply is just like doing an auto wheel. You put it on a spindle or a balancer and look for the heavy side which usually is on the bottom and then add weight at the 12 o'clock position to make the prop equal weight all the way around so there is no heavy side. Some hang it on string. The last balance is a dynamic balance. I spent $4K for my dynamic prop balancer. This machine is attached to the plane and you run it up near your cruise rpm on the ground and add weights where it suggest to get rid of any out of balance situations. Solid props like wood or carbon fiber like a Warp are more likely to be out of balance to a higher degree than the newer lighter hollow carbon fiber composite props. Wood can also wick up moisture which will throw them out of balance. If you have mis-matched blades for your prop they need to be checked for weight and at least a static balance. Hi Thom, Your probably right about air flow with a fully exposed engine. I learned this from an engineer at Sensenich that did his PHD on this very subject. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385314#385314 ________________________________________________________________________________
Subject: Re: 912 i
Date: Oct 14, 2012
Hi Jan, Unless info you need is in the Installation manual you probably won't see it until they come out with a Heavy manit. manual. The lack of the Heavy manual is one reason you don't see any classes on the injected engine yet. They are still pulling all the last details together. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385323#385323 ________________________________________________________________________________
Date: Oct 14, 2012
Scaha: If you want to do about a weeks worth of research you can find the needed components to make up your own dynamic balancer. The cost would be about $150 US. The only area that you may have problems with is writing the computer code. There are four fairly simple cods for a balancer: 1 - Choice of prop 2 blade & 3 blade. Others such as 4 and even 6 blade are multiples of the 2 & 3 blade. 2 - RPM - This is done by identifying one blade and calling it #1 with a reflective sticky strip. Then a simple photo eye sends and receives a signal off the reflective strip. Count the reflections and you have RPM 3 - Accelerometer - Well, here you can go from simple to VERY elaborate BUT! All the operations are the same. Simple as most balancers are use ONLY one (1) axis. The 'Y' axis. The out put is a voltage that varies in amplitude as the vibration increases. And the unit of vibration is IPS (Inches Per Second) Yes you can use mmPS. 4 - This one becomes a little difficult You have to correlate the RPM with the #1 blade to a o'clock position so you know WHERE in relation to the #1 Blade the HEAVY point is. Here is where RPM is converted to SECONDS and the VOLTAGE output of the accelerometer is given a plot of inches OR mm. Once you know where the Heavy Vibration Point is you add 180 Deg to that point to find where you should add weight to balance it out. YES - you could also remove weight fro the heavy point BUT very few people do that. AND that is probably a good idea. NEXT PROBLEM: What if you find the heavy point is between blades? Or, what if there is no place to mount your balance weight? This goes back to the question I posted where a friend had a Rotax and a three blade prop and NO place to mount the balance weights. Well, What you can do is start playing with the indexing of the prop on the drive shaft. This brings up all sorts on questions and old wives tails - Since supposedly a compression stroke on the #1 cylinder does not matter since there is a gear box. Theory may say one thing while practicality says something else. The proof is in the pudding. There a one other way other than a computer program but that has its own problems ... That would be by using an Oscilloscope and set up a Lissajous Pattern showing RPM Vs Accelerometer. Do the simple things first - Static balance the prop. Make sure the prop tracks true. Check you mounts - vibration dampeners - airframe and all components mounted on the engine as well as any cowlings. Barry On Sun, Oct 14, 2012 at 2:32 PM, U wrote: > Thanks Barry, > > No A&Ps where I am, otherwise I'd gladly farm out this kind of stuff, even > if A&Ps here (I'm in Italy) are no way as cheap as the US :( > > The prop seems to be fine now, so I'll just leave it as it is until I find > someone who can take a look at it... > > > On 14/ott/2012, at 15:20, FLYaDIVE wrote: > > Sacha: > > The post about balancing was posted by me, Barry. > There a a couple of ways of doing balancing - Static and Dynamic. > Static only requires a set of edge knives and spindle. This will put you > in the ball park. > Dynamic can be done - With quite difficulty - Using different old fashion > equipment such as the vibratalk or the string & washer. I went with a bit > more modern approach using a photo eye for RPM and an accelerometer to > measure the displacement. > Can it be done by the good builder? Yes. But, not many a builder will > invest an additional $1500 to $2500 for the equipment - Much easier to get > it done for $250 by an A&P. > > Barry > > On Sat, Oct 13, 2012 at 10:33 PM, Sacha wrote: > >> >> Thank you Roger >> >> Is the balancing you refer to a DIY job or does it require specialized >> equipment? >> >> Sacha >> >> ========== >> -List" target="_blank"> >> http://www.matronics.com/Navigator?RotaxEngines-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > * > > * > > * > > ________________________________________________________________________________
Date: Oct 15, 2012
Subject: Re: 912 i
Hi Roger, I hoped that someone would have "hacked" it for me by now. But there does not seem to be a lot of amateur action on the 912 i. Which makes sense ofcourse because it is an expensive toy. The Installation Manual generates as many questions as it answers. Some of the "what", none of the "why". And it contains errors. It is not very urgent yet. I will save my list of questions and revisit later. Jan On 10/15/2012 12:12 AM, Roger Lee wrote: > > Hi Jan, > > Unless info you need is in the Installation manual you probably won't see it until they come out with a Heavy manit. manual. The lack of the Heavy manual is one reason you don't see any classes on the injected engine yet. They are still pulling all the last details together. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > ________________________________________________________________________________
Date: Oct 15, 2012
Roger, Barry, While adding a washer will certainly work why not paint the prop tips and add more paint on the light blade? For a pusher, especially one on a two stroke powered aircraft you will get a fair amount of oil and dirt that sticks to the blades and affects the balance. Part of my yearly maintenance is to clean and repaint the prop, test the balance, and use the tip paint to get the prop to Rotax specs for a new prop, less than half a gram of imbalance. I also recommend Balance Masters prop dynamic prop balancers. They are very light and really do the job of getting rid of that last little bit and countering for bug and oil buildup during flight. Rick Girard On Sat, Oct 13, 2012 at 9:43 AM, Roger Lee wrote: > > Hi Barry, > > Unfortunately there are many different prop mounts that people use on > their planes. Some have backing plates and spinners, prop hub extensions, > ext... > If they don't have a backing plate then you may be stuck with putting a > large washer on one of the prop mounting bolts. If you do that it could > take a little more weight because it is closer to the center of mass. Or > you could get him to put a backing plate and spinner on his plane and would > benefit from better air flow and the balance. With the backing plate you > can then move the weight out farther from the center. > Just so many of you know as a tidbit fact. It is more important and > affects the flow of air to have a spinner on a pusher over a tractor prop. > The air flow is affected more and in a positive way. > Which is funny because we seem to always put spinners on tractor props. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=385246#385246 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Oct 15, 2012
Rick: Painting the prop will work for STATIC balancing of the prop. But, what happens when the heavy point is at a rotational degree location tat is out in space. NO PHYSICAL location to add or remove weight? Not all the balancing is of the prop. Things like Engine, Spinner and Mounts contribute to vibration. AND how much paint is required? What happens when the paint is worn off? Slow changes in vibration is not noticeable over long periods of time... The body just gets use to it. The plane and insturments on the other had react to it - Shortened life. The idea of oil on the prop causing imbalance is very possible but also very arguable. Since the prop is spinning wouldn't there be an equal amount of oil spray on each blade? Who know, who cares... Just wipe the prop down after each landing. Balance Masters - This is another one of those theories/myths that has not been truly proven or disproven. I did a little balancing experiment at work with the same idea of a movable mass (mercury) and found it did NOT always balance out, it was 2 time yes, 15 times no. And my testing was Mercury Vs Accelerometer. Way too many variables to get repeated results. The better way of doing a moving weight balance system is a Washing Machine. Check it out - Pretty cool ideas there. Barry On Mon, Oct 15, 2012 at 11:31 AM, Richard Girard wrote: > Roger, Barry, While adding a washer will certainly work why not paint the > prop tips and add more paint on the light blade? For a pusher, especially > one on a two stroke powered aircraft you will get a fair amount of oil and > dirt that sticks to the blades and affects the balance. Part of my yearly > maintenance is to clean and repaint the prop, test the balance, and use the > tip paint to get the prop to Rotax specs for a new prop, less than half a > gram of imbalance. > I also recommend Balance Masters prop dynamic prop balancers. They are > very light and really do the job of getting rid of that last little bit and > countering for bug and oil buildup during flight. > > Rick Girard > > On Sat, Oct 13, 2012 at 9:43 AM, Roger Lee wrote: > >> > >> >> Hi Barry, >> >> Unfortunately there are many different prop mounts that people use on >> their planes. Some have backing plates and spinners, prop hub extensions, >> ext... >> If they don't have a backing plate then you may be stuck with putting a >> large washer on one of the prop mounting bolts. If you do that it could >> take a little more weight because it is closer to the center of mass. Or >> you could get him to put a backing plate and spinner on his plane and would >> benefit from better air flow and the balance. With the backing plate you >> can then move the weight out farther from the center. >> Just so many of you know as a tidbit fact. It is more important and >> affects the flow of air to have a spinner on a pusher over a tractor prop. >> The air flow is affected more and in a positive way. >> Which is funny because we seem to always put spinners on tractor props. >> >> -------- >> Roger Lee >> Tucson, Az. >> Light Sport Repairman - Maintenance Rated >> Rotax Repair Center - Heavy Maint. Rated >> Home 520-574-1080 TRY HOME FIRST >> Cell 520-349-7056 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=385246#385246 >> >> >> >> >> >> >> >> ========== >> -List" target="_blank"> >> http://www.matronics.com/Navigator?RotaxEngines-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > > > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > It isn't necessary to have relatives in Kansas City in order to be unhappy. > - Groucho Marx > > > * > > * > > ________________________________________________________________________________
Date: Oct 16, 2012
Barry, Yep, the paint on the tips is just for static balance, but I can get to .1 gram and it does seem to help. How much is my experiment. I shoot a little heavy so as the volatiles flash off the prop moves toward balance. Not perfect, but cheap and keeps the prop in good shape. My testing of the Balance Masters concept was on my Shovelhead Harley. I have them on both the crank and the clutch basket. It takes a little while to settle in once I'm up to road speed, but I can feel the vibration go away and I really notice the difference after a long haul. Since the engine is bolted directly to the frame it is much more noticeable than on either my airplane of trike, but they do seem to work there, too. Rick On Mon, Oct 15, 2012 at 11:13 AM, FLYaDIVE wrote: > Rick: > > Painting the prop will work for STATIC balancing of the prop. But, what > happens when the heavy point is at a rotational degree location tat is out > in space. NO PHYSICAL location to add or remove weight? Not all the > balancing is of the prop. Things like Engine, Spinner and Mounts > contribute to vibration. AND how much paint is required? What happens > when the paint is worn off? Slow changes in vibration is > not noticeable over long periods of time... The body just gets use to it. > The plane and insturments on the other had react to it - Shortened life. > The idea of oil on the prop causing imbalance is very possible but also > very arguable. Since the prop is spinning wouldn't there be an equal > amount of oil spray on each blade? Who know, who cares... Just wipe the > prop down after each landing. > > Balance Masters - This is another one of those theories/myths that has not > been truly proven or disproven. I did a little balancing experiment at > work with the same idea of a movable mass (mercury) and found it did NOT > always balance out, it was 2 time yes, 15 times no. And my testing was > Mercury Vs Accelerometer. Way too many variables to get repeated results. > The better way of doing a moving weight balance system is a Washing > Machine. Check it out - Pretty cool ideas there. > > Barry > > > On Mon, Oct 15, 2012 at 11:31 AM, Richard Girard wrote: > >> Roger, Barry, While adding a washer will certainly work why not paint the >> prop tips and add more paint on the light blade? For a pusher, especially >> one on a two stroke powered aircraft you will get a fair amount of oil and >> dirt that sticks to the blades and affects the balance. Part of my yearly >> maintenance is to clean and repaint the prop, test the balance, and use the >> tip paint to get the prop to Rotax specs for a new prop, less than half a >> gram of imbalance. >> I also recommend Balance Masters prop dynamic prop balancers. They are >> very light and really do the job of getting rid of that last little bit and >> countering for bug and oil buildup during flight. >> >> Rick Girard >> >> On Sat, Oct 13, 2012 at 9:43 AM, Roger Lee wrote: >> >>> ssadiver1(at)yahoo.com> >>> >>> Hi Barry, >>> >>> Unfortunately there are many different prop mounts that people use on >>> their planes. Some have backing plates and spinners, prop hub extensions, >>> ext... >>> If they don't have a backing plate then you may be stuck with putting a >>> large washer on one of the prop mounting bolts. If you do that it could >>> take a little more weight because it is closer to the center of mass. Or >>> you could get him to put a backing plate and spinner on his plane and would >>> benefit from better air flow and the balance. With the backing plate you >>> can then move the weight out farther from the center. >>> Just so many of you know as a tidbit fact. It is more important and >>> affects the flow of air to have a spinner on a pusher over a tractor prop. >>> The air flow is affected more and in a positive way. >>> Which is funny because we seem to always put spinners on tractor props. >>> >>> -------- >>> Roger Lee >>> Tucson, Az. >>> Light Sport Repairman - Maintenance Rated >>> Rotax Repair Center - Heavy Maint. Rated >>> Home 520-574-1080 TRY HOME FIRST >>> Cell 520-349-7056 >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=385246#385246 >>> >>> >>> >>> >>> >>> >>> >>> ========== >>> -List" target="_blank"> >>> http://www.matronics.com/Navigator?RotaxEngines-List >>> ========== >>> http://forums.matronics.com >>> ========== >>> le, List Admin. >>> ="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> >> >> >> -- >> Zulu Delta >> Mk IIIC >> Thanks, Homer GBYM >> >> It isn't necessary to have relatives in Kansas City in order to be >> unhappy. >> - Groucho Marx >> >> >> * >> >> ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Radiator cleaning
Date: Oct 16, 2012
Hi All, I'm after some tips on how we clean oil cooler/ radiator fins of accumulated gunge ie fine coating of oil from oil change drips mixed with dust. Even though cooling is the least of my worries with these radiators, I would like them to be clean. If anything they struggle to reach a satisfactory working temperature despite being taped up over winter. Thanks Geoff Bell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385510#385510 ________________________________________________________________________________
Subject: Re: Radiator cleaning
Date: Oct 16, 2012
Hi Geoff, Flush the fins with either a water based or a regular solvent. Then flush well with water to make sure here isn't any residual. Then I personally blow it out to help dry it and remove any residual with air pressure. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385517#385517 ________________________________________________________________________________
Date: Oct 16, 2012
Geoff: Use any product that would cut oil. It is all dependent on ease of access to all sides of the cooler and if can you remove any drippings. As I was writing this I had an idea... I just deleted all that I wrote here is the Simple, Quick and Inexpensive idea... Get a can of Spray Engine Cleaner at any automotive store. Most require a warm engine - Then Spray the cleaner on - Then wait a few minutes - Then wash it off with a garden hose <-- High pressure helps. Let it dry thoroughly - Air Hose will help. And you are done. Barry On Tue, Oct 16, 2012 at 6:12 PM, Gtblu wrote: > > Hi All, > > I'm after some tips on how we clean oil cooler/ radiator fins of > accumulated gunge ie fine coating of oil from oil change drips mixed with > dust. Even though cooling is the least of my worries with these radiators, > I would like them to be clean. If anything they struggle to reach a > satisfactory working temperature despite being taped up over winter. > > Thanks > Geoff Bell > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=385510#385510 > > ________________________________________________________________________________
Date: Oct 17, 2012
Geoff, If you use engine cleaner be sure to read all the caveats on the package. And make sure you can do it wherever. Last one I used softened my asphalt driveway even though I had a plastic tarp on a frame to catch the water. You don't need some guy walking up and introducing himself as the EPA investigator (yes it does happen) For my money I'd go with one of the Simple Green type cleaners that's certified for aluminum. Rick Girard On Tue, Oct 16, 2012 at 7:01 PM, FLYaDIVE wrote: > Geoff: > > Use any product that would cut oil. It is all dependent on ease of access > to all sides of the cooler and if can you remove any drippings. > As I was writing this I had an idea... I just deleted all that I wrote > here is the Simple, Quick and Inexpensive idea... Get a can of Spray > Engine Cleaner at any automotive store. Most require a warm engine - Then > Spray the cleaner on - Then wait a few minutes - Then wash it off with a > garden hose <-- High pressure helps. > Let it dry thoroughly - Air Hose will help. And you are done. > > Barry > > > On Tue, Oct 16, 2012 at 6:12 PM, Gtblu wrote: > >> >> Hi All, >> >> I'm after some tips on how we clean oil cooler/ radiator fins of >> accumulated gunge ie fine coating of oil from oil change drips mixed with >> dust. Even though cooling is the least of my worries with these radiators, >> I would like them to be clean. If anything they struggle to reach a >> satisfactory working temperature despite being taped up over winter. >> >> Thanks >> Geoff Bell >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=385510#385510 >> >> >> >> >> >> >> >> ========== >> -List" target="_blank"> >> http://www.matronics.com/Navigator?RotaxEngines-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Oct 17, 2012
Water based biodegradable "Oil Eater" is an excellent choice and works very well on greased clean ups including floors and greasy stove tops. Best non destructive stuff I have used. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385594#385594 ________________________________________________________________________________
Date: Oct 17, 2012
Hi Richard: Yea, I heard that one about Simple Green for aluminum. It really makes me wonder. SOAP, well any soap that cleans is ALKALINE and alkaline will etch, attack or corrode aluminum... Use what ever of those words works best for you. Alkaline is used to clean aluminum before doing things like anodizing or painting. Yea, I know the term Acid Etch... Well it is only a term used to sell a product, for some reason the public understands ACID better than ALKALINE. Any one out there have any litmus paper? Run your own test to prove what I am saying. EPA! Kick them in the garage-keys. Then shoot them with the same arrow used to kill a deer. AHhhhh, New Jersey.... You can smell the dead deer alongside the road. E.P.A. - Extremely Prejudice Agency <--- Against Common Sense, they approved MTBE and Ethanol. Barry On Wed, Oct 17, 2012 at 3:28 PM, Richard Girard wrote: > Geoff, If you use engine cleaner be sure to read all the caveats on the > package. And make sure you can do it wherever. Last one I used softened my > asphalt driveway even though I had a plastic tarp on a frame to catch the > water. You don't need some guy walking up and introducing himself as the > EPA investigator (yes it does happen) For my money I'd go with one of the > Simple Green type cleaners that's certified for aluminum. > > Rick Girard > > On Tue, Oct 16, 2012 at 7:01 PM, FLYaDIVE wrote: > >> Geoff: >> >> Use any product that would cut oil. It is all dependent on ease of >> access to all sides of the cooler and if can you remove any drippings. >> As I was writing this I had an idea... I just deleted all that I wrote >> here is the Simple, Quick and Inexpensive idea... Get a can of Spray >> Engine Cleaner at any automotive store. Most require a warm engine - Then >> Spray the cleaner on - Then wait a few minutes - Then wash it off with a >> garden hose <-- High pressure helps. >> Let it dry thoroughly - Air Hose will help. And you are done. >> >> Barry >> >> >> On Tue, Oct 16, 2012 at 6:12 PM, Gtblu wrote: >> >>> >>> Hi All, >>> >>> I'm after some tips on how we clean oil cooler/ radiator fins of >>> accumulated gunge ie fine coating of oil from oil change drips mixed with >>> dust. Even though cooling is the least of my worries with these radiators, >>> I would like them to be clean. If anything they struggle to reach a >>> satisfactory working temperature despite being taped up over winter. >>> >>> Thanks >>> Geoff Bell >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=385510#385510 >>> >>> >>> >>> >>> >>> >>> >>> ========== >>> -List" target="_blank"> >>> http://www.matronics.com/Navigator?RotaxEngines-List >>> ========== >>> http://forums.matronics.com >>> ========== >>> le, List Admin. >>> ="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> >> * >> >> ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > > > -- > Zulu Delta > Mk IIIC > Thanks, Homer GBYM > > It isn't necessary to have relatives in Kansas City in order to be unhappy. > - Groucho Marx > > > * > > * > > ________________________________________________________________________________
Date: Oct 17, 2012
Hydrogen embrittlement. A number of solvents will cut hydrocarbons and clean metal. Know whether what you are using does damage before taking chances. Research the consequence of the wrong solvents. Eight years ago Simple Green did not have an approved aluminum cleaner. Now they have one which will not cause embrittlement, swelling of tefzel insullation or galvanic action on the material you are trying to clean. Now there is a Simple Green Aviation Cleaner. Sodium Hydroxide is an alkaline. Try a scrap piece before you destroy former aircraft grade parts. Know the MSDS. Heat and water can do some amazing stuff. John On Wed, Oct 17, 2012 at 6:42 PM, FLYaDIVE wrote: > Hi Richard: > > Yea, I heard that one about Simple Green for aluminum. > It really makes me wonder. SOAP, well any soap that cleans is ALKALINE > and alkaline will etch, attack or corrode aluminum... Use what ever of > those words works best for you. Alkaline is used to clean aluminum before > doing things like anodizing or painting. Yea, I know the term Acid Etch... > Well it is only a term used to sell a product, for some reason the public > understands ACID better than ALKALINE. > Any one out there have any litmus paper? Run your own test to prove what > I am saying. > EPA! Kick them in the garage-keys. Then shoot them with the same arrow > used to kill a deer. AHhhhh, New Jersey.... You can smell the dead deer > alongside the road. E.P.A. - Extremely Prejudice Agency <--- Against > Common Sense, they approved MTBE and Ethanol. > > Barry > > > On Wed, Oct 17, 2012 at 3:28 PM, Richard Girard wrote: > >> Geoff, If you use engine cleaner be sure to read all the caveats on the >> package. And make sure you can do it wherever. Last one I used softened my >> asphalt driveway even though I had a plastic tarp on a frame to catch the >> water. You don't need some guy walking up and introducing himself as the >> EPA investigator (yes it does happen) For my money I'd go with one of the >> Simple Green type cleaners that's certified for aluminum. >> >> Rick Girard >> >> On Tue, Oct 16, 2012 at 7:01 PM, FLYaDIVE wrote: >> >>> Geoff: >>> >>> Use any product that would cut oil. It is all dependent on ease of >>> access to all sides of the cooler and if can you remove any drippings. >>> As I was writing this I had an idea... I just deleted all that I wrote >>> here is the Simple, Quick and Inexpensive idea... Get a can of Spray >>> Engine Cleaner at any automotive store. Most require a warm engine - Then >>> Spray the cleaner on - Then wait a few minutes - Then wash it off with a >>> garden hose <-- High pressure helps. >>> Let it dry thoroughly - Air Hose will help. And you are done. >>> >>> Barry >>> >>> >>> On Tue, Oct 16, 2012 at 6:12 PM, Gtblu wrote: >>> >>>> >>>> Hi All, >>>> >>>> I'm after some tips on how we clean oil cooler/ radiator fins of >>>> accumulated gunge ie fine coating of oil from oil change drips mixed with >>>> dust. Even though cooling is the least of my worries with these radiators, >>>> I would like them to be clean. If anything they struggle to reach a >>>> satisfactory working temperature despite being taped up over winter. >>>> >>>> Thanks >>>> Geoff Bell >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=385510#385510 >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> ========== >>>> -List" target="_blank"> >>>> http://www.matronics.com/Navigator?RotaxEngines-List >>>> ========== >>>> http://forums.matronics.com >>>> ========== >>>> le, List Admin. >>>> ="_blank">http://www.matronics.com/contribution >>>> ========== >>>> >>>> >>>> >>>> >>> * >>> >>> ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List >>> tp://forums.matronics.com >>> _blank">http://www.matronics.com/contribution >>> * >>> >>> >> >> >> -- >> Zulu Delta >> Mk IIIC >> Thanks, Homer GBYM >> >> It isn't necessary to have relatives in Kansas City in order to be >> unhappy. >> - Groucho Marx >> >> >> * >> >> ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > * > > * > > ________________________________________________________________________________
Date: Oct 18, 2012
Thanks guys for tips. I'm inclined to think the oil and dust is better than embrittlement. (Nice term! ) I'm not being compromised on the cooling process, so it is only cosmetic, and to see if there are leaks developing. cheers Geoff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385649#385649 ________________________________________________________________________________
Subject: New fuel pump for 912 part number 893110
Date: Oct 23, 2012
Hi List I had to replace my fuel pump today and bought the new fuel pump, part number 893110. Anyone know what the third barb is for (looks like a fuel overflow) and how it should be installed? I can't find the manual for it anywhere on the web. Regards Sacha ________________________________________________________________________________
Date: Oct 23, 2012
Subject: Re: New fuel pump for 912 part number 893110
Hello Sacha. You are correct, it is a fuel overflow if the pump fails. Best regards, Johann G. Z701 ----- Upprunaleg skilabo ----- Fr: "Sacha" Til: rotaxengines-list(at)matronics.com Sent: rijudagur, 23. Oktber, 2012 12:55:57 Efni: RotaxEngines-List: New fuel pump for 912 part number 893110 Hi List I had to replace my fuel pump today and bought the new fuel pump, part number 893110. Anyone know what the third barb is for (looks like a fuel overflow) and how it should be installed? I can't find the manual for it anywhere on the web. Regards Sacha ________________________________________________________________________________
Date: Oct 23, 2012
Thanks Johann Does anyone have a pointer to some installation instructions? I have asked the retailer and Rotax so far but still waiting for a response. Sacha On Oct 23, 2012, at 15:46, joeing701(at)simnet.is wrote: > > Hello Sacha. > > You are correct, it is a fuel overflow if the pump fails. > > Best regards, > Johann G. > Z701 > > ----- Upprunaleg skilabo ----- > Fr: "Sacha" > Til: rotaxengines-list(at)matronics.com > Sent: rijudagur, 23. Oktber, 2012 12:55:57 > Efni: RotaxEngines-List: New fuel pump for 912 part number 893110 > > > Hi List > I had to replace my fuel pump today and bought the new fuel pump, part number 893110. Anyone know what the third barb is for (looks like a fuel overflow) and how it should be installed? I can't find the manual for it anywhere on the web. > Regards > Sacha > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 23, 2012
Hi Sacha, Attach a hose (it can be of the clear plastic type) to your third nipple. It is a drain. Run it down and out any where you want to the edge of the cowling or opening. Do not put it out in the air stream. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385903#385903 ________________________________________________________________________________
Date: Oct 24, 2012
Johann and Roger Thank you ________________________________________________________________________________
Date: Oct 24, 2012
If it is a drain line for gas why would you put on a clear plastic line? Better to use an aluminum line or if you are really pressed a Tygon (yellow) plastic line. At least with the Tygon you know the fuel will not attack it and possibly cause a collapsed line; where you will loose your venting. Why is putting it out in the air stream a problem? Barry On Tue, Oct 23, 2012 at 10:51 PM, Roger Lee wrote: > > Hi Sacha, > > Attach a hose (it can be of the clear plastic type) to your third nipple. > It is a drain. Run it down and out any where you want to the edge of the > cowling or opening. Do not put it out in the air stream. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=385903#385903 > > ________________________________________________________________________________
Date: Oct 23, 2012
According to Rotax that can change the pressure. And yes, Rotax does want a line connected to that nipple as opposed to not attaching a hose to it (to prevent fuel from dripping down onto the hot exhaust) - Bob Comperini On Oct 23, 2012, at 9:08 PM, FLYaDIVE wrote: > Why is putting it out in the air stream a problem? > > Barry > ________________________________________________________________________________
From: Pete Christensen <pchristensen10(at)austin.rr.com>
Date: Oct 24, 2012
Barry, You should'nt doubt what Roger says. He knows more about Rotax 9 series eng ines than anyone I know. I use the clear plastic hose from an oxygen cannul a for the overflow on my Rotax carbs. Works great and last for years. Pete On Oct 23, 2012, at 11:08 PM, FLYaDIVE wrote: > If it is a drain line for gas why would you put on a clear plastic line? B etter to use an aluminum line or if you are really pressed a Tygon (yellow) p lastic line. At least with the Tygon you know the fuel will not attack it a nd possibly cause a collapsed line; where you will loose your venting. Why i s putting it out in the air stream a problem? > > Barry > > On Tue, Oct 23, 2012 at 10:51 PM, Roger Lee wrote: > >> >> Hi Sacha, >> >> Attach a hose (it can be of the clear plastic type) to your third nipple. It is a drain. Run it down and out any where you want to the edge of the co wling or opening. Do not put it out in the air stream. >> >> -------- >> Roger Lee >> Tucson, Az. >> Light Sport Repairman - Maintenance Rated >> Rotax Repair Center - Heavy Maint. Rated >> Home 520-574-1080 TRY HOME FIRST >> Cell 520-349-7056 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=385903#385903 >> >> >> >> >> >> >> >> ========== >> -List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines- List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Oct 24, 2012
It's just a drain hose if the fuel pump pukes any fuel. It most likely won't happen. It doesn't hold any fuel and it should just sit there for the "just in case" moment. It's just a way to route any dumped fuel away from the engine if such an event would occur. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=385953#385953 ________________________________________________________________________________
Date: Oct 25, 2012
Pete: Davehr'yay, noh praver'yay --- Trust but Verify. Only a fool follows blindly. And why would you use such an odd ball undocumented item (your oxygen cannula tubing)? There are clearly better items for the handling of gas; approved items.. All you have to do is read AC 43-13. Roger's knowledge in not in question. His reasoning is. Maybe Roger would explain why he recommends non approved item for handling gas. W.W.R.D. [What Would Rotax Do?] I just read Roger's response: " It's just a drain hose if the fuel pump pukes any fuel. It most likely won't happen. It doesn't hold any fuel and it should just sit there for the "just in case" moment. It's just a way to route any dumped fuel away from the engine if such an event would occur." This is acceptable to you! If it is so benign why not use a paper straw? It would be so much easier to use a proper item that is fuel approved. It is not like it is expensive or difficult to obtain. Barry http://www.youtube.com/embed/Fos4EPUOsHo?feature=player_embedded On Wed, Oct 24, 2012 at 7:25 AM, Pete Christensen < pchristensen10(at)austin.rr.com> wrote: > Barry, > > You should'nt doubt what Roger says. He knows more about Rotax 9 series > engines than anyone I know. I use the clear plastic hose from an oxygen > cannula for the overflow on my Rotax carbs. Works great and last for years. > > Pete > > On Oct 23, 2012, at 11:08 PM, FLYaDIVE wrote: > > If it is a drain line for gas why would you put on a clear plastic line? > Better to use an aluminum line or if you are really pressed a Tygon > (yellow) plastic line. At least with the Tygon you know the fuel will not > attack it and possibly cause a collapsed line; where you will loose your > venting. Why is putting it out in the air stream a problem? > > Barry > > On Tue, Oct 23, 2012 at 10:51 PM, Roger Lee wrote: > >> > >> >> Hi Sacha, >> >> Attach a hose (it can be of the clear plastic type) to your third nipple. >> It is a drain. Run it down and out any where you want to the edge of the >> cowling or opening. Do not put it out in the air stream. >> >> -------- >> Roger Lee >> Tucson, Az. >> Light Sport Repairman - Maintenance Rated >> Rotax Repair Center - Heavy Maint. Rated >> Home 520-574-1080 TRY HOME FIRST >> Cell 520-349-7056 >> >> ________________________________________________________________________________
Date: Oct 25, 2012
I fly an experimental. I'm experimenting. Get over it. Pete On Oct 25, 2012, at 12:31 PM, FLYaDIVE wrote: > Pete: > > Davehr'yay, noh praver'yay --- Trust but Verify. > > Only a fool follows blindly. And why would you use such an odd ball undoc umented item (your oxygen cannula tubing)? There are clearly better items f or the handling of gas; approved items.. All you have to do is read AC 43-1 3. > > Roger's knowledge in not in question. His reasoning is. Maybe Roger would explain why he recommends non approved item for handling gas. > W.W.R.D. [What Would Rotax Do?] > > I just read Roger's response: " It's just a drain hose if the fuel pump p ukes any fuel. It most likely won't happen. It doesn't hold any fuel and it s hould just sit there for the "just in case" moment. It's just a way to route any dumped fuel away from the engine if such an event would occur." > This is acceptable to you! If it is so benign why not use a paper straw? It would be so much easier to use a proper item that is fuel approved. It i s not like it is expensive or difficult to obtain. > > > > > Barry > > > > http://www.youtube.com/embed/Fos4EPUOsHo?feature=player_embedded > > > > > On Wed, Oct 24, 2012 at 7:25 AM, Pete Christensen wrote: >> Barry, >> >> You should'nt doubt what Roger says. He knows more about Rotax 9 series e ngines than anyone I know. I use the clear plastic hose from an oxygen cann ula for the overflow on my Rotax carbs. Works great and last for years. >> >> Pete >> >> On Oct 23, 2012, at 11:08 PM, FLYaDIVE wrote: >> >>> If it is a drain line for gas why would you put on a clear plastic line? Better to use an aluminum line or if you are really pressed a Tygon (yello w) plastic line. At least with the Tygon you know the fuel will not attack i t and possibly cause a collapsed line; where you will loose your venting. W hy is putting it out in the air stream a problem? >>> >>> Barry >>> >>> On Tue, Oct 23, 2012 at 10:51 PM, Roger Lee wrote: om> >>>> >>>> Hi Sacha, >>>> >>>> Attach a hose (it can be of the clear plastic type) to your third nippl e. It is a drain. Run it down and out any where you want to the edge of the c owling or opening. Do not put it out in the air stream. >>>> >>>> -------- >>>> Roger Lee >>>> Tucson, Az. >>>> Light Sport Repairman - Maintenance Rated >>>> Rotax Repair Center - Heavy Maint. Rated >>>> Home 520-574-1080 TRY HOME FIRST >>>> Cell 520-349-7056 > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Oct 25, 2012
Pete: Did you build the plane? Barry On Thu, Oct 25, 2012 at 2:42 PM, Pete Christensen < pchristensen10(at)austin.rr.com> wrote: > I fly an experimental. I'm experimenting. Get over it. > > Pete > > > On Oct 25, 2012, at 12:31 PM, FLYaDIVE wrote: > > Pete: > > Davehr'yay, noh praver'yay --- Trust but Verify. > > Only a fool follows blindly. And why would you use such an odd ball > undocumented item (your oxygen cannula tubing)? There are clearly better > items for the handling of gas; approved items.. All you have to do is read > AC 43-13. > > Roger's knowledge in not in question. His reasoning is. Maybe Roger would > explain why he recommends non approved item for handling gas. > W.W.R.D. [What Would Rotax Do?] > > I just read Roger's response: " It's just a drain hose if the fuel pump > pukes any fuel. It most likely won't happen. It doesn't hold any fuel and > it should just sit there for the "just in case" moment. It's just a way to > route any dumped fuel away from the engine if such an event would occur." > This is acceptable to you! If it is so benign why not use a paper straw? > It would be so much easier to use a proper item that is fuel approved. It > is not like it is expensive or difficult to obtain. > > > Barry > > > http://www.youtube.com/embed/Fos4EPUOsHo?feature=player_embedded > > > On Wed, Oct 24, 2012 at 7:25 AM, Pete Christensen < > pchristensen10(at)austin.rr.com> wrote: > >> Barry, >> >> You should'nt doubt what Roger says. He knows more about Rotax 9 series >> engines than anyone I know. I use the clear plastic hose from an oxygen >> cannula for the overflow on my Rotax carbs. Works great and last for years. >> >> Pete >> >> On Oct 23, 2012, at 11:08 PM, FLYaDIVE wrote: >> >> If it is a drain line for gas why would you put on a clear plastic line? >> Better to use an aluminum line or if you are really pressed a Tygon >> (yellow) plastic line. At least with the Tygon you know the fuel will not >> attack it and possibly cause a collapsed line; where you will loose your >> venting. Why is putting it out in the air stream a problem? >> >> Barry >> >> On Tue, Oct 23, 2012 at 10:51 PM, Roger Lee wrote: >> >>> ssadiver1(at)yahoo.com> >>> >>> Hi Sacha, >>> >>> Attach a hose (it can be of the clear plastic type) to your third >>> nipple. It is a drain. Run it down and out any where you want to the edge >>> of the cowling or opening. Do not put it out in the air stream. >>> >>> -------- >>> Roger Lee >>> Tucson, Az. >>> Light Sport Repairman - Maintenance Rated >>> Rotax Repair Center - Heavy Maint. Rated >>> Home 520-574-1080 TRY HOME FIRST >>> Cell 520-349-7056 >>> >>> > * > > * > > * > > > * > > ________________________________________________________________________________
Date: Oct 25, 2012
Barry, Here's Roger's original recommendation: "Attach a hose (it can be of the clear plastic type) to your third nipple. It is a drain. Run it down and out any where you want to the edge of the cowling or opening. Do not put it out in the air stream." I don't see where his recommendation is to use something that's completely incompatible with gasoline. Plastic takes in a lot of territory. I've attached McMaster Carr's Chemical Compatibility chart for just one type that I picked out, PVC. Some is recommended for gasoline, some isn't, and this chart is for tubing that will hold gasoline, not just sit there holding nothing but air, waiting for some gas to run through it. Pete didn't specify anything either, other oxygen system cannula tubing. No chemical formulation. Again, takes in a lot of territory. How exactly is your wise council any better? Use aluminum you say. What alloy? What hardness? Work hardened? Heat treated? WTF? My ex-wife liked to leap to conclusions and start running her mouth. That was the primary reason I booted her fat butt out the door. Rick Girard On Thu, Oct 25, 2012 at 1:52 PM, FLYaDIVE wrote: > Pete: > > Did you build the plane? > > Barry > > On Thu, Oct 25, 2012 at 2:42 PM, Pete Christensen < > pchristensen10(at)austin.rr.com> wrote: > >> I fly an experimental. I'm experimenting. Get over it. >> >> Pete >> >> >> On Oct 25, 2012, at 12:31 PM, FLYaDIVE wrote: >> >> Pete: >> >> Davehr'yay, noh praver'yay --- Trust but Verify. >> >> Only a fool follows blindly. And why would you use such an odd ball >> undocumented item (your oxygen cannula tubing)? There are clearly >> better items for the handling of gas; approved items.. All you have to do >> is read AC 43-13. >> >> Roger's knowledge in not in question. His reasoning is. Maybe Roger >> would explain why he recommends non approved item for handling gas. >> W.W.R.D. [What Would Rotax Do?] >> >> I just read Roger's response: " It's just a drain hose if the fuel pump >> pukes any fuel. It most likely won't happen. It doesn't hold any fuel and >> it should just sit there for the "just in case" moment. It's just a way to >> route any dumped fuel away from the engine if such an event would occur." >> This is acceptable to you! If it is so benign why not use a paper straw? >> It would be so much easier to use a proper item that is fuel approved. It >> is not like it is expensive or difficult to obtain. >> >> >> >> >> Barry >> >> >> >> http://www.youtube.com/embed/Fos4EPUOsHo?feature=player_embedded >> >> >> >> >> On Wed, Oct 24, 2012 at 7:25 AM, Pete Christensen < >> pchristensen10(at)austin.rr.com> wrote: >> >>> Barry, >>> >>> You should'nt doubt what Roger says. He knows more about Rotax 9 series >>> engines than anyone I know. I use the clear plastic hose from an oxygen >>> cannula for the overflow on my Rotax carbs. Works great and last for years. >>> >>> Pete >>> >>> On Oct 23, 2012, at 11:08 PM, FLYaDIVE wrote: >>> >>> If it is a drain line for gas why would you put on a clear plastic line? >>> Better to use an aluminum line or if you are really pressed a Tygon >>> (yellow) plastic line. At least with the Tygon you know the fuel will not >>> attack it and possibly cause a collapsed line; where you will loose your >>> venting. Why is putting it out in the air stream a problem? >>> >>> Barry >>> >>> On Tue, Oct 23, 2012 at 10:51 PM, Roger Lee wrote: >>> >>>> ssadiver1(at)yahoo.com> >>>> >>>> Hi Sacha, >>>> >>>> Attach a hose (it can be of the clear plastic type) to your third >>>> nipple. It is a drain. Run it down and out any where you want to the edge >>>> of the cowling or opening. Do not put it out in the air stream. >>>> >>>> -------- >>>> Roger Lee >>>> Tucson, Az. >>>> Light Sport Repairman - Maintenance Rated >>>> Rotax Repair Center - Heavy Maint. Rated >>>> Home 520-574-1080 TRY HOME FIRST >>>> Cell 520-349-7056 >>>> >>>> >> * >> >> * >> >> * >> >> 3D============================================ >> > >> >> 3D============================================ >> 3D============================================ >> 3D============================================ >> >> * >> >> > * > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Oct 26, 2012
Subject: Pre-oiling 912ULS
Greetings all: I looked in the archives and didn't see an answer so here goes: I have a 912ULS, in the crate I bought it in 2005. I just unwrapped it and would like to pressurize the oil system with engine oil since the engine has been sitting so long and I am very concerned about roating the engine (dry) to get the internal pump to move oil. I have a 12 volt oil pump, return tank and accessories to accomplish this, however I have a question: Can I simply feed the oil pump inlet hose-barb with oil pressure to circulate oil throughout the gallery? I am concerned the pump will not pass oil if the engine is not turning. Alternately I could remove the pressure sender and feed the gallery from there unless there is some reason not to. My preference is to feed through the larger oil pump inlet in the hipe of greater flow through the gallery. I plan to return the oil by draining the crankcase through the return hosebarb and back into the return tank. Any thoughts or suggestions to circulate oil through my engine? Thanks, Jim Kolb Mark3X 912ULS 80% completed ________________________________________________________________________________
Subject: Re: Pre-oiling 912ULS
Date: Oct 26, 2012
Hi Jim, You will need to do a good oil purge. Here is the Rotax link to a video: http://www.rotax-owner.com/information-reg/expanded-video-instructions-reg/33-exp-si-912-018 In the Installation manual section 13.10 page 78 (Oil Purge) are the same instructions. I would advise that you go to the Rotax Owner website and download the 5 manuals you will need for your engine. They will be very helpful and almost all your answers will be there. This is very important for this first start, but is easy to do. If It was my first start I would do it twice. It's very easy. twice just means rotating the prop twice as much. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386073#386073 ________________________________________________________________________________
Date: Oct 26, 2012
Hi Roger, Thanks for the response. I agree on the value of the Rotax Owner site. For years I got the updates, and am now reviewing the latest docs. I just joined the pay portion (is paying to play new?) and reviewed the video. The procedure does make sense, and I recall in the maintenance class they stressed the critical importance of purging. That said my question is can I pump oil into the engine *without* rotating it? The procedure suggests air pressure against the tank to force oil into a turning engine. I am fortunate to have an electric oil pump so I don't need the air pressure. I am several months from engine start, and have had the engine in its crate, wrapped in plastic for years. I want to circulate oil without rotating what I fear are dry (or nearly so) bearing journals. When engine start comes I will follow this purging procedure to the letter. Until then I wish to circulate oil, without first turning the engine. I will re-examine the engine docs to look at the oil pump/bypass topology, but to save time I was asking if anyone on this list knew if oil can be pumped past a stationary oil pump. My intent is to rig up my system and pump fresh oil through the gallery several times a month until engine installation. If I am lucky perhaps that will make up for having a new engine in mothballs so long. Do you (or anyone else) know if a non-turning engine will allow oil under pressure past it? Thanks, Jim --- On Fri, 10/26/12, Roger Lee wrote: > From: Roger Lee <ssadiver1(at)yahoo.com> > Subject: RotaxEngines-List: Re: Pre-oiling 912ULS > To: rotaxengines-list(at)matronics.com > Date: Friday, October 26, 2012, 3:47 PM > --> RotaxEngines-List message > posted by: "Roger Lee" > > Hi Jim, > > You will need to do a good oil purge. > > Here is the Rotax link to a video: > http://www.rotax-owner.com/information-reg/expanded-video-instructions-reg/33-exp-si-912-018 > > In the Installation manual section 13.10 page 78 (Oil Purge) > are the same instructions. > > I would advise that you go to the Rotax Owner website and > download the 5 manuals you will need for your engine. They > will be very helpful and almost all your answers will be > there. > > This is very important for this first start, but is easy to > do. If It was my first start I would do it twice. It's very > easy. twice just means rotating the prop twice as much. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=386073#386073 > > > > > > > > RotaxEngines-List Email Forum - > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Oct 26, 2012
Your going to have to rotate the engine to get into critical areas and past the pump. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386086#386086 ________________________________________________________________________________
Date: Oct 27, 2012
Jim, Roger is correct that you must rotate the engine to get oil through the system even if externally pressurizing the inlet side of the pump. The reason is that the oil pump on the front of the engine is a positive displacement pump, which will allow very little oil (if any) to pass if it is not turning. BTW, when the engine is running, the inlet side of the oil pump is at lower than atmospheric pressure, never pressurized. I'm not recommending this but you could pressurize the oil system on the outlet side of the pump through the oil pressure relief valve port. If you do this, make sure you remove the relief valve and spring and that the applied pressure is controlled within the allowable range. I don't think it is necessary to do this but in theory it could be done this way. With a $20,000 engine, why not just follow the manufacturer's directions? It is certainly simpler and Rotax doesn't leave much to chance. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386100#386100 ________________________________________________________________________________
Date: Oct 27, 2012
Thom, Roger: Appreciate the confirmation and suggestions! Point certainly taken regarding adherence to the Rotax procedure. My problem is I waited so long to maintain this engine I am concerned the journals will score if I rotate the engine without adding oil first. I regret not following the Rotax procedure 5 years ago. I had the same though with regard to pressurizing the upstream side of the galley, and am studying the gallery details in the manual now. Thanks all, and have a great weekend. -Jim --- On Sat, 10/27/12, Thom Riddle wrote: > From: Thom Riddle <riddletr(at)gmail.com> > Subject: RotaxEngines-List: Re: Pre-oiling 912ULS > To: rotaxengines-list(at)matronics.com > Date: Saturday, October 27, 2012, 5:14 AM > --> RotaxEngines-List message > posted by: "Thom Riddle" > > Jim, > Roger is correct that you must rotate the engine to get oil > through the system even if externally pressurizing the inlet > side of the pump. The reason is that the oil pump on > the front of the engine is a positive displacement pump, > which will allow very little oil (if any) to pass if it is > not turning. BTW, when the engine is running, the inlet side > of the oil pump is at lower than atmospheric pressure, never > pressurized. > > I'm not recommending this but you could pressurize the oil > system on the outlet side of the pump through the oil > pressure relief valve port. If you do this, make sure you > remove the relief valve and spring and that the applied > pressure is controlled within the allowable range. I don't > think it is necessary to do this but in theory it could be > done this way. > > With a $20,000 engine, why not just follow the > manufacturer's directions? It is certainly simpler and Rotax > doesn't leave much to chance. > > -------- > Thom Riddle > Buffalo, NY (9G0) > > Kolb Slingshot SS-021 > Jabiru 2200A #1574 > > Diamond Katana DA20-A1 > Rotax 912 F3 > > Don't worry about old age... it doesn't last very long. > - Anonymous > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=386100#386100 > > > > > > > > RotaxEngines-List Email Forum - > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Oct 28, 2012
Jim: As they say your idea is Spot On. The entire idea of Pre-Oiling is to saturate and cover all the rotating parts PRIOR to rotating the the engine. To rotate the engine prior to pre-oiling or during pre-oiling is counter productive. Since your engine is from 2005 the two questions that come up are: 1 - Where was the engine stored, was it kept in a low humidity area? 2 - Was the engine 'pickled', that is to say - Oiled with a preservative oil that does not run off the engine areas? When it comes to 'pickling' a little research has to be done: 1 - Does Rotax make a storage oil? If so use it. 2 - If Rotax does NOT make a storage oil, use any storage oil you can obtain. Remember you are NOT running on this oil ONLY storing with it. Yes - You do run the engine for a short time just to coat the insides of the engine BUT, that is a SHORT TIME and it is WITHOUT LOADS. Special Note: Take a look at Page 8 - 2 Para 8.2 It states that preservation is for only one year and if stored for more than one year the preservation procedure should be repeated every year. Have you been doing that? If not - Start with that procedure prior to Pre-Oiling. Why do i say that? Only because Pre-Oiling takes care of the engine NOT the gearbox gears. Do everything you can to get those gears wet with oil - SHORT of rotating them - Without oil. So, how should you Pre-Oil? 1 - Take a look at the manual - Page 7-6 Figure 3 . 2 - Notice the Oil Flow Direction. It goes OUT of the Oil Cooler (item 5) - Into the Engine - Out of the engine and into the Oil Tank (item 4). 3 - I do not know if the picture I attached will get through. If it does not contact me directly and I will send it directly to you. 4 - This picture is of a Pre-Oiler I made. It can handle oil pressure up to 150 PSI. YOU pick the oil pressure your engine operates at and Pre-Oil at that pressure. 5 - Use the engine operating pressure so any valves will be opened by the pressure and the oil spray will cover the same areas as during normal operation. 6 - Since the engine has an Oil Pressure Regulator (item 1), you should pressure the pre-oiler higher than operating pressure and because the pressure drops in the pre-oilier quickly as volume of oil drops. 7 - Monitor the Oil Pressure Gauge of the plane/engine, since the Oil Pressure Sensor (item 2) is hooked up. There will probably be only a small deflection since the pre-oilier is applying pressure for only a short time. 8 - Now, here I have to ask a question. Does the Oil Pump (item 3) have a reverse flow check valve? If YES then you are limited to pre-oilier flow direction. If NO then - Use the Pre-Oilier in BOTH directions - The IN and the OUT. 9 - When I Pre-Oil, it is done with one (1) quart of oil in each direction - From the Oil Cooler into the Engine and then Into the Engine on the OUTPUT side of the Engine. See note 8. 10 - Now, here you have some options: a> You can leave the Oil Tank (item 4) attached and it will catch any oil that makes it to the exit of the engine. And remember to hook up a overflow tube to Vent Tube (item 7). I really doubt if this will ever happen, or... b> Put a Plug on the Engine Exit line/hose so it develops a good pressure to spray the oil all around inside the engine. The Pictures: Pic #1 is a general overview Pic #2 shows the fittings. One thing you can not see is the inside of the unit. From the oil line on the outside is a nylon pick-up tube that goes to the bottom of the unit. You will see a Shrader valve on top. I hook up a 12VDC portable tire pump. Pressurize the unit to 125 PSI, you can leave the tire pump on and running when you open the valve. This system is so easy that I pre-oil anytime the engine sits for a month or more. Barry On Fri, Oct 26, 2012 at 5:13 PM, Jim Clayton wrote: > > Greetings all: > > I looked in the archives and didn't see an answer so here goes: > > I have a 912ULS, in the crate I bought it in 2005. I just unwrapped it > and would like to pressurize the oil system with engine oil since the > engine has been sitting so long and I am very concerned about roating the > engine (dry) to get the internal pump to move oil. I have a 12 volt oil > pump, return tank and accessories to accomplish this, however I have a > question: > > Can I simply feed the oil pump inlet hose-barb with oil pressure to > circulate oil throughout the gallery? I am concerned the pump will not > pass oil if the engine is not turning. > > Alternately I could remove the pressure sender and feed the gallery from > there unless there is some reason not to. My preference is to feed through > the larger oil pump inlet in the hipe of greater flow through the gallery. > > I plan to return the oil by draining the crankcase through the return > hosebarb and back into the return tank. > > Any thoughts or suggestions to circulate oil through my engine? > > Thanks, Jim > > Kolb Mark3X > 912ULS > 80% completed > > ________________________________________________________________________________
Date: Oct 29, 2012
Hi Barry,=0A=0A=C2-=0A=0AThanks for the confirmation regarding a possibly dry engine=0Abeing rotated to introduce oil.=C2- Your pvc=0Apre-oiler is really cool!=C2- Thanks for the=0Apics.=0A=0A=C2-=0A=0AI purchased the engine around 2005.=C2- I peeled back the plastic, took a bunch of=0Apic tures and rewrapped it tightly sealing the plastic and reassembled the crat e.=C2- The crate lived the next 7 plus years in my=0Aspare bedroom, tempe rature controlled.=C2-=0AFast forward to last week.=C2- I=0Aopened it a nd pulled the engine out of the crate.=C2- Close inspection showed the en gine was still=0Aexternally slightly oily, and the crankcase has remnants o f the oil used during=0Athe test run at the factory.=C2- All good=0Anews I think.=0A=0A=C2-=0A=0AAfter much consideration I decided to inject oil into the=0Apressure sender port.=C2- As was confirmed=0Aby this list =99s experts the oil pump is a positive displacement type (no=0Asurprise ) so I needed to inject oil upstream of the pump if I desire gallery=0Aoil pressure without turning.=C2- I didn=99t=0Ainject at the pressure r egulator as suggested cause I didn=99t have ready access=0Ato the met ric fitting holding the spring, and I wasn=99t sure if I would simply =0Avent oil directly to the crankcase bypassing the gallery if I took the =0Aregulator apart.=C2- So I went with the=0Apressure sensor port.=0A=0A =C2-=0A=0AI removed the pressure sender and fed it oil (semi-syn=0Amotorc ycle formulation since it will touch the wet clutch in the gearbox) at 40 =0Ato 55psi from a 12 volt pump.=C2- Added a=0Atee in the pipe and 6 feet of sealed tubing (see pic) to act as a pressure accumulator=0Aso the pump doesn=99t chatter.=C2- Worked out=0Ato 3 seconds of pump runtime to 12 seconds of resting.=C2- After running all day the pump wasn=99t even=0Awarm.=C2- I opened the valve covers and saw=0Aoil coming out the pushrods, confirming the oil gallery is pressurized.=0A=0A=C2-=0A=0ANext I raised the drain line to trap oil in the engine (see=0Apic), and used it as a sight glass to predict the level in the crankcase.=C2- The level was also high enough to submerge=0Athe bottom passage to the gearbox (see pic of open gearbox from the servicing=0Aclass).=C2- Then I leaned the engine left=0Aand right, forward and back to submerge the pistons/pins and slosh oil around=0Ain the gearbox.=C2- Drained the crankcase,=0Aput a couple of tablespoon of oil into each sparkplug hole.=C2- Finally, after hours of oil circulation I=0Aturned the engine over, plugs still out.=C2-=0A=0A=0A =C2-=0A=0ANote I was using a clean bucket for the oil supply.=C2- I see m to have misplaced my oil tank.=C2- I will look around for it a little l onger=0Abefore I worry about buying another!=0A=0A=C2-=0A=0AI offer this only for entertainment purposes and don=99t=0Asuggest anyone perform this procedure without approval from your Rotax=0Adealer.=C2- My engine i s long out of=0Awarranty and I alone am responsible for the outcome.=C2- I intend to keep the engine in this oiling regime=0Auntil I am ready to sta rt it; at which time I will purge the system and confirm=0Alifter status pe r the Rotax procedure. =0A=0A=C2-=0A=0A-Jim --- On Sun, 10/28/12, FLYaDIVE wrote: From: FLYaDIVE <flyadive(at)gmail.com> Subject: Re: RotaxEngines-List: Pre-oiling 912ULS Date: Sunday, October 28, 2012, 6:37 AM Jim: As they say your idea is Spot On. =C2-The=C2-entire=C2-idea of Pre-Oi ling is to saturate and cover all the rotating parts PRIOR to rotating the the engine. =C2-To rotate the engine prior to pre-oiling or during pre-oi ling is counter productive. =C2-=0A=0A Since your engine is from 2005 the two questions that come up are:1 - Where was the engine stored, was it kept in a low humidity area?=0A=0A2 - Was th e engine 'pickled', that is to say - Oiled with a=C2-preservative=C2-oi l that does not run off the engine areas? When it comes to 'pickling' a little research has to be done:=0A=0A1 - Does Rotax make a storage oil? =C2-If so use it.2 - If Rotax does NOT make a storage oil, use any storage oil you can obtain. =C2-Remember you are NOT running on this oil ONLY storing with it. =C2-=0A=0AYes - You do run the engine for a short time just to coat the insides of the engine BUT, that i s a SHORT TIME and it is WITHOUT LOADS. Special Note: =C2-Take a look at Page 8 - 2 Para 8.2=0A=0AIt states that =C2-preservation=C2-is for only one year and if stored for more than on e year the=C2-preservation=C2-procedure should be repeated every year. =C2-Have you been doing that?=0A=0AIf not - Start with that procedure pri or to Pre-Oiling.Why do i say that? =C2-Only because Pre-Oiling takes car e of the engine NOT the gearbox gears. =C2-Do everything you can to get t hose gears wet with oil - SHORT of rotating them - Without oil.=0A=0ASo, ho w should you Pre-Oil?1 - Take a look at the manual - Page 7-6 Figure 3 .2 - Notice the Oil Flow Direction. =C2-It goes OUT of the Oil Cooler (item 5 ) - Into the Engine - Out of the engine and into the Oil Tank (item 4).=0A =0A3 - I do not know if the picture I attached will get through. =C2-If i t does not contact me directly and I will send it directly to you.4 - This picture is of a Pre-Oiler I made. =C2-It can handle oil pressure up to 15 0 PSI. =C2-YOU pick the oil pressure your engine operates at and Pre-Oil at that pressure. =C2-=0A=0A5 - Use the engine operating pressure so any valves will be opened by the pressure and the oil spray will cover the same areas as during normal operation.6 - Since the engine has an Oil Pressure Regulator (item 1), you should pressure the pre-oiler higher than operating pressure and because the pressure drops in the pre-oilier=C2-quickly as volume of oil drops.=0A=0A7 - Monitor the Oil Pressure Gauge of the plane/e ngine, since the Oil Pressure Sensor (item 2) is hooked up. =C2-There wil l probably be only a small deflection since the pre-oilier=C2-is applying pressure for only a short time.=0A=0A8 - Now, here I have to ask a questio n. =C2-Does the Oil Pump (item 3) have a reverse flow check valve? =C2- If YES then you are limited to pre-oilier flow direction.=C2-If NO then - Use the Pre-Oilier=C2-in BOTH directions - The IN and the OUT.=0A=0A9 - When I Pre-Oil, it is done with one (1) quart of oil in each direction - Fr om the Oil Cooler into the Engine and then Into the Engine on the OUTPUT si de of the Engine. =C2-See note 8. =C2-=0A=0A10 - Now, here you have som e options: =C2-a> You can leave the Oil Tank (item 4) attached and it wil l catch any oil that makes it to the exit of the engine. =C2-And remember to hook up a overflow tube to Vent Tube (item 7). =C2-I really doubt if this will ever happen, or...=0A=0Ab> Put a Plug on the Engine Exit line/hos e so it develops a good pressure to spray the oil all around inside the eng ine. The Pictures:=0APic #1 is a general overview=C2-Pic #2 shows the fittings . =C2-One thing you can not see is the inside of the unit. =C2-From the oil line on the outside is a nylon pick-up tube that goes to the bottom of the unit.=0AYou will see a Shrader valve on top. =C2-I hook up a 12VDC p ortable=C2-tire pump. =C2-Pressurize the unit to 125 PSI, you can leave the tire pump on and running when you open the valve. =C2- =0AThis system is so easy that I pre-oil anytime the engine sits for a mont h or more.=0A Barry On Fri, Oct 26, 2012 at 5:13 PM, Jim Clayton wrote: m> =0A=0A=0A =0AGreetings all: =0A =0AI looked in the archives and didn't see an answer so here goes: =0A =0AI have a 912ULS, in the crate I bought it in 2005. =C2-I just unwrappe d it and would like to pressurize the oil system with engine oil since the engine has been sitting so long and I am very concerned about roating the e ngine (dry) to get the internal pump to move oil. =C2-I have a 12 volt oi l pump, return tank and accessories to accomplish this, however I have a qu estion: =0A=0A=0A =0ACan I simply feed the oil pump inlet hose-barb with oil pressure to circ ulate oil throughout the gallery? =C2-I am concerned the pump will not pa ss oil if the engine is not turning. =0A =0AAlternately I could remove the pressure sender and feed the gallery from there unless there is some reason not to. =C2-My preference is to feed t hrough the larger oil pump inlet in the hipe of greater flow through the ga llery. =0A=0A=0A =0AI plan to return the oil by draining the crankcase through the return ho sebarb and back into the return tank. =0A =0AAny thoughts or suggestions to circulate oil through my engine? =0A =0AThanks, Jim =0A =0AKolb Mark3X =0A912ULS =0A80% completed =0A =0A========== =0A-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines -List =0A========== =0Ahttp://forums.matronics.com =0A========== =0Ale, List Admin. =0A="_blank">http://www.matronics.com/contribution =0A========== =0A =0A =0A =0A =0A ________________________________________________________________________________
Date: Oct 30, 2012
Jim Clayton a crit : > > I offer this only for entertainment purposes and dont suggest anyone > perform this procedure without approval from your Rotax dealer. My > engine is long out of warranty and I alone am responsible for the > outcome. I intend to keep the engine in this oiling regime until I am > ready to start it; at which time I will purge the system and confirm > lifter status per the Rotax procedure. > > > Jim, In my opinion, you did well, though it might be overkill. Nothing wrong with having the engine thoroughly oiled before use. Someone mentioned possible problems with the gearbox : you can't do much harm to the gears by turning the engine by hand a few turns, even if they happened to be dry. Very few jounals in the Rotax, so the main issue migth be moving the pistons in a dry cylinder. Not sure, but you certainly took care of this by injecting some oil through the plug holes before turning anything. Apart from this, no much risk with piston pins etc... If correctly drained, too much oil will not harm the engine. FWIW, Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Oct 29, 2012
just a thought on a bit off subject.. but looking at the pic of the back side of the gearbox... has anyone thought of plugging the oil journal holes in a gearbox... tapping a plug hole in the top and filling it with 90 gear oil... would solve a lot of issues with 912 and the oil debates. and the problems with excessive wear.. i am not sure of effects of slipper clutching.. just talking bout gears only boxes.... -------- Ross Aalexander: CH701 driver 912ul 589tt It only takes two things to fly, airspeed and money Read this topic online here: http://forums.matronics.com/viewtopic.php?p=386255#386255 ________________________________________________________________________________
Date: Oct 31, 2012
Jim: Sorry for the delay in responding, I'm in NJ and we lost power for the last day or so. HEY :-) Really great contraption. I love your set up. You have just done a better job of oiling than Rotax ever would. The idea of the sight tube (Egyptian Water Level) for oil level is a great idea. Now you now know exactly the level oil and what was covered. Good Job Old Man. Now, don't be surprised if you make a lot of smoke on your first start up. It will last only a few seconds and only those outside the plane will notice IF they pay attention. The prop blast will disperse things rapidly. Getting oil to the gears is the next big issue. Lots of moving parts and lots of metal on metal contact areas. If you were to: 1 - Remove the spark plugs. 2 - Ground the Mags. 3 - Totally flood the gear area - AND - 4 - Then turn the engine over by hand or with a heavy duty 1/2" Electric Drill. You will have covered all bases and will have that Totally Warm Fuzzy Feeling. 5 - You could also squirt some oil in the cylinders prior to turning over the engine by hand. The only really rough Metal on Metal area is the rings and cylinder - Extra oil there worn hurt. Great Job - Keep us informed. Barry On Mon, Oct 29, 2012 at 6:56 PM, Jim Clayton wrote: > Hi Barry,**** > > ** ** > > Thanks for the confirmation regarding a possibly dry engine being rotated > to introduce oil. Your pvc pre-oiler is really cool! Thanks for the pic s. > **** > > ** ** > > I purchased the engine around 2005. I peeled back the plastic, took a > bunch of pictures and rewrapped it tightly sealing the plastic and > reassembled the crate. The crate lived the next 7 plus years in my spare > bedroom, temperature controlled. Fast forward to last week. I opened it > and pulled the engine out of the crate. Close inspection showed the engi ne > was still externally slightly oily, and the crankcase has remnants of the > oil used during the test run at the factory. All good news I think.**** > > ** ** > > After much consideration I decided to inject oil into the pressure sender > port. As was confirmed by this list=92s experts the oil pump is a positi ve > displacement type (no surprise) so I needed to inject oil upstream of the > pump if I desire gallery oil pressure without turning. I didn=92t inject at > the pressure regulator as suggested cause I didn=92t have ready access to the > metric fitting holding the spring, and I wasn=92t sure if I would simply vent > oil directly to the crankcase bypassing the gallery if I took the regulat or > apart. So I went with the pressure sensor port.**** > > ** ** > > I removed the pressure sender and fed it oil (semi-syn motorcycle > formulation since it will touch the wet clutch in the gearbox) at 40 to > 55psi from a 12 volt pump. Added a tee in the pipe and 6 feet of sealed > tubing (see pic) to act as a pressure accumulator so the pump doesn=92t > chatter. Worked out to 3 seconds of pump runtime to 12 seconds of > resting. After running all day the pump wasn=92t even warm. I opened th e > valve covers and saw oil coming out the pushrods, confirming the oil > gallery is pressurized.**** > > ** ** > > Next I raised the drain line to trap oil in the engine (see pic), and use d > it as a sight glass to predict the level in the crankcase. The level was > also high enough to submerge the bottom passage to the gearbox (see pic o f > open gearbox from the servicing class). Then I leaned the engine left an d > right, forward and back to submerge the pistons/pins and slosh oil around > in the gearbox. Drained the crankcase, put a couple of tablespoon of oil > into each sparkplug hole. Finally, after hours of oil circulation I turn ed > the engine over, plugs still out. **** > > ** ** > > Note I was using a clean bucket for the oil supply. I seem to have > misplaced my oil tank. I will look around for it a little longer before I > worry about buying another!**** > > ** ** > > I offer this only for entertainment purposes and don=92t suggest anyone > perform this procedure without approval from your Rotax dealer. My engin e > is long out of warranty and I alone am responsible for the outcome. I > intend to keep the engine in this oiling regime until I am ready to start > it; at which time I will purge the system and confirm lifter status per t he > Rotax procedure. **** > > ** ** > > -Jim**** > > --- On *Sun, 10/28/12, FLYaDIVE * wrote: > > > From: FLYaDIVE <flyadive(at)gmail.com> > Subject: Re: RotaxEngines-List: Pre-oiling 912ULS > To: rotaxengines-list(at)matronics.com > Date: Sunday, October 28, 2012, 6:37 AM > > Jim: > > As they say your idea is Spot On. The entire idea of Pre-Oiling is to > saturate and cover all the rotating parts PRIOR to rotating the the engin e. > To rotate the engine prior to pre-oiling or during pre-oiling is counter > productive. > > Since your engine is from 2005 the two questions that come up are: > 1 - Where was the engine stored, was it kept in a low humidity area? > 2 - Was the engine 'pickled', that is to say - Oiled with > a preservative oil that does not run off the engine areas? > > When it comes to 'pickling' a little research has to be done: > 1 - Does Rotax make a storage oil? If so use it. > 2 - If Rotax does NOT make a storage oil, use any storage oil you can > obtain. Remember you are NOT running on this oil ONLY storing with it. > Yes - You do run the engine for a short time just to coat the insides of > the engine BUT, that is a SHORT TIME and it is WITHOUT LOADS. > > Special Note: Take a look at Page 8 - 2 Para 8.2 > It states that preservation is for only one year and if stored for more > than one year the preservation procedure should be repeated every year. > Have you been doing that? > If not - Start with that procedure prior to Pre-Oiling. > Why do i say that? Only because Pre-Oiling takes care of the engine NOT > the gearbox gears. Do everything you can to get those gears wet with oil - > SHORT of rotating them - Without oil. > So, how should you Pre-Oil? > 1 - Take a look at the manual - Page 7-6 Figure 3 . > 2 - Notice the Oil Flow Direction. It goes OUT of the Oil Cooler (item 5 ) > - Into the Engine - Out of the engine and into the Oil Tank (item 4). > 3 - I do not know if the picture I attached will get through. If it does > not contact me directly and I will send it directly to you. > 4 - This picture is of a Pre-Oiler I made. It can handle oil pressure up > to 150 PSI. YOU pick the oil pressure your engine operates at and Pre-Oi l > at that pressure. > 5 - Use the engine operating pressure so any valves will be opened by the > pressure and the oil spray will cover the same areas as during normal > operation. > 6 - Since the engine has an Oil Pressure Regulator (item 1), you should > pressure the pre-oiler higher than operating pressure and because the > pressure drops in the pre-oilier quickly as volume of oil drops. > 7 - Monitor the Oil Pressure Gauge of the plane/engine, since the Oil > Pressure Sensor (item 2) is hooked up. There will probably be only a sma ll > deflection since the pre-oilier is applying pressure for only a short tim e. > 8 - Now, here I have to ask a question. Does the Oil Pump (item 3) have a > reverse flow check valve? If YES then you are limited to pre-oilier flow > direction. > If NO then - Use the Pre-Oilier in BOTH directions - The IN and the OUT. > 9 - When I Pre-Oil, it is done with one (1) quart of oil in each directio n > - From the Oil Cooler into the Engine and then Into the Engine on the > OUTPUT side of the Engine. See note 8. > 10 - Now, here you have some options: > a> You can leave the Oil Tank (item 4) attached and it will catch any oil > that makes it to the exit of the engine. And remember to hook up a > overflow tube to Vent Tube (item 7). I really doubt if this will ever > happen, or... > b> Put a Plug on the Engine Exit line/hose so it develops a good pressure > to spray the oil all around inside the engine. > > The Pictures: > Pic #1 is a general overview > Pic #2 shows the fittings. One thing you can not see is the inside of th e > unit. From the oil line on the outside is a nylon pick-up tube that goes > to the bottom of the unit. > You will see a Shrader valve on top. I hook up a 12VDC portable tire > pump. Pressurize the unit to 125 PSI, you can leave the tire pump on and > running when you open the valve. > > This system is so easy that I pre-oil anytime the engine sits for a month > or more. > > Barry > > On Fri, Oct 26, 2012 at 5:13 PM, Jim Clayton http://mc/ compose?to=jspc78(at)yahoo.com> > > wrote: > tp://mc/compose?to=jspc78(at)yahoo.com> > > > > Greetings all: > > I looked in the archives and didn't see an answer so here goes: > > I have a 912ULS, in the crate I bought it in 2005. I just unwrapped it > and would like to pressurize the oil system with engine oil since the > engine has been sitting so long and I am very concerned about roating the > engine (dry) to get the internal pump to move oil. I have a 12 volt oil > pump, return tank and accessories to accomplish this, however I have a > question: > > Can I simply feed the oil pump inlet hose-barb with oil pressure to > circulate oil throughout the gallery? I am concerned the pump will not > pass oil if the engine is not turning. > > Alternately I could remove the pressure sender and feed the gallery from > there unless there is some reason not to. My preference is to feed throu gh > the larger oil pump inlet in the hipe of greater flow through the gallery . > > I plan to return the oil by draining the crankcase through the return > hosebarb and back into the return tank. > > Any thoughts or suggestions to circulate oil through my engine? > > Thanks, Jim > > Kolb Mark3X > 912ULS > 80% completed > > ========== > -List" target="_blank"> > http://www.matronics.com/Navigator?RotaxEngines-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > ________________________________________________________________________________
Date: Oct 31, 2012
Hi Barry/All: Thanks! =C2-I am running the pump 30 minutes a day so the overkill makes me feel better about storing the engine for so long :-) I agree with respect to the gearbox. =C2-While I did lean the engine forw ard while the crankcase was full, I am concerned about the big bearings on the prop shaft. =C2-I was thinking of again removing the fuel pump, putti ng a couple of pints of oil in, and closing it up. =C2-Then with several helpers turning the engine upside down. =C2-This would trap oil at the=C2 -prop-shaft=C2-end. =C2-Leave it=C2-upside down=C2-for perhaps a couple of hours to marinate two big bearings. =C2-Looking at the photos I took in the servicing class, I suspect those bearings need a bit of splash to keep those two lubed. =C2-I figure an hour or so marinating maybe soa k in enough oil to suffice. =C2-Once done I will turn it right side up, a nd allow all the oil to drain. I am several months from mounting the engine on the plane, so this system w ill stay in place awhile. =C2-Wish I could find the oil tank as the open bucket has to go. =C2-I will post=C2-separately=C2-asking if anyone h as a spare oil tank (I know...not likely). -Jim --- On Wed, 10/31/12, FLYaDIVE wrote: From: FLYaDIVE <flyadive(at)gmail.com> Subject: Re: RotaxEngines-List: Pre-oiling 912ULS Date: Wednesday, October 31, 2012, 7:15 AM Jim: Sorry for the delay in responding, I'm in NJ and we lost power for the last day or so. =C2- =0AHEY =C2-:-) =C2-Really great contraption. =C2-I love your set up. =C2-You have just done a better job of oiling than Rotax ever would. =C2 -The idea of the sight tube (Egyptian Water Level) for oil level is a gre at idea. =C2-Now you now know=C2-exactly=C2-the level oil and what wa s covered. =C2-Good Job Old Man.=0A Now, don't be surprised if you make a lot of smoke on your first start up. =C2-It will last only a few seconds and only those outside the plane will notice IF they pay attention. =C2-The prop blast will disperse things ra pidly.=0A Getting oil to the gears is the next big issue. =C2-Lots of moving parts and lots of metal on metal contact areas. =C2-If you were to:1 - Remove t he spark plugs.=0A2 - Ground the Mags.3 - Totally flood the gear area - AND =C2--=C2-4 - Then turn the engine over by hand or with a heavy duty 1/ 2" Electric Drill.=0AYou will have covered all bases and will have that Tot ally Warm Fuzzy Feeling.5 - You could also squirt some oil in the cylinders prior to turning over the engine by hand. =C2-=0AThe only really rough M etal on Metal area is the rings and cylinder - Extra oil there worn hurt. Great Job - Keep us informed.=0A Barry On Mon, Oct 29, 2012 at 6:56 PM, Jim Clayton wrote: =0A=0AHi Barry,=0A=0A=C2-=0A=0AThanks for the confirmation regarding a po ssibly dry engine=0Abeing rotated to introduce oil.=C2- Your pvc=0Apre-oi ler is really cool!=C2- Thanks for the=0Apics.=0A=0A=C2-=0A=0AI purchas ed the engine around 2005.=C2- I peeled back the plastic, took a bunch of =0Apictures and rewrapped it tightly sealing the plastic and reassembled th e crate.=C2- The crate lived the next 7 plus years in my=0Aspare bedroom, temperature controlled.=C2-=0AFast forward to last week.=C2- I=0Aopene d it and pulled the engine out of the crate.=C2- Close inspection showed the engine was still=0Aexternally slightly oily, and the crankcase has remn ants of the oil used during=0Athe test run at the factory.=C2- All good =0Anews I think.=0A=0A=C2-=0A=0AAfter much consideration I decided to inj ect oil into the=0Apressure sender port.=C2- As was confirmed=0Aby this l ist=99s experts the oil pump is a positive displacement type (no=0Asu rprise) so I needed to inject oil upstream of the pump if I desire gallery =0Aoil pressure without turning.=C2- I didn=99t=0Ainject at the pre ssure regulator as suggested cause I didn=99t have ready access=0Ato the metric fitting holding the spring, and I wasn=99t sure if I would simply=0Avent oil directly to the crankcase bypassing the gallery if I too k the=0Aregulator apart.=C2- So I went with the=0Apressure sensor port. =0A=0A=C2-=0A=0AI removed the pressure sender and fed it oil (semi-syn=0A motorcycle formulation since it will touch the wet clutch in the gearbox) a t 40=0Ato 55psi from a 12 volt pump.=C2- Added a=0Atee in the pipe and 6 feet of sealed tubing (see pic) to act as a pressure accumulator=0Aso the p ump doesn=99t chatter.=C2- Worked out=0Ato 3 seconds of pump runtim e to 12 seconds of resting.=C2- After running all day the pump wasn =99t even=0Awarm.=C2- I opened the valve covers and saw=0Aoil coming out the pushrods, confirming the oil gallery is pressurized.=0A=0A=C2-=0A=0AN ext I raised the drain line to trap oil in the engine (see=0Apic), and used it as a sight glass to predict the level in the crankcase.=C2- The level was also high enough to submerge=0Athe bottom passage to the gearbox (see pic of open gearbox from the servicing=0Aclass).=C2- Then I leaned the en gine left=0Aand right, forward and back to submerge the pistons/pins and sl osh oil around=0Ain the gearbox.=C2- Drained the crankcase,=0Aput a coupl e of tablespoon of oil into each sparkplug hole.=C2- Finally, after hours of oil circulation I=0Aturned the engine over, plugs still out.=C2-=0A =0A=0A=C2-=0A=0ANote I was using a clean bucket for the oil supply.=C2- I seem to have misplaced my oil tank.=C2- I will look around for it a li ttle longer=0Abefore I worry about buying another!=0A=0A=C2-=0A=0AI offer this only for entertainment purposes and don=99t=0Asuggest anyone pe rform this procedure without approval from your Rotax=0Adealer.=C2- My en gine is long out of=0Awarranty and I alone am responsible for the outcome. =C2- I intend to keep the engine in this oiling regime=0Auntil I am ready to start it; at which time I will purge the system and confirm=0Alifter st atus per the Rotax procedure. =0A=0A=C2-=0A=0A-Jim --- On Sun, 10/28/12, FLYaDIVE wrote: =0A From: FLYaDIVE <flyadive(at)gmail.com> Subject: Re: RotaxEngines-List: Pre-oiling 912ULS =0ADate: Sunday, October 28, 2012, 6:37 AM Jim: As they say your idea is Spot On. =C2-The=C2-entire=C2-idea of Pre-Oi ling is to saturate and cover all the rotating parts PRIOR to rotating the the engine. =C2-To rotate the engine prior to pre-oiling or during pre-oi ling is counter productive. =C2-=0A=0A=0A Since your engine is from 2005 the two questions that come up are:1 - Where was the engine stored, was it kept in a low humidity area?=0A=0A=0A2 - Was the engine 'pickled', that is to say - Oiled with a=C2-preservative=C2 -oil that does not run off the engine areas? When it comes to 'pickling' a little research has to be done:=0A=0A=0A1 - D oes Rotax make a storage oil? =C2-If so use it.2 - If Rotax does NOT make a storage oil, use any storage oil you can obtain. =C2-Remember you are NOT running on this oil ONLY storing with it. =C2-=0A=0A=0AYes - You do r un the engine for a short time just to coat the insides of the engine BUT, that is a SHORT TIME and it is WITHOUT LOADS. Special Note: =C2-Take a look at Page 8 - 2 Para 8.2=0A=0A=0AIt states th at=C2-preservation=C2-is for only one year and if stored for more than one year the=C2-preservation=C2-procedure should be repeated every year . =C2-Have you been doing that?=0A=0A=0AIf not - Start with that procedur e prior to Pre-Oiling.Why do i say that? =C2-Only because Pre-Oiling take s care of the engine NOT the gearbox gears. =C2-Do everything you can to get those gears wet with oil - SHORT of rotating them - Without oil.=0A=0A =0ASo, how should you Pre-Oil?1 - Take a look at the manual - Page 7-6 Figu re 3 .2 - Notice the Oil Flow Direction. =C2-It goes OUT of the Oil Coole r (item 5) - Into the Engine - Out of the engine and into the Oil Tank (ite m 4).=0A=0A=0A3 - I do not know if the picture I attached will get through. =C2-If it does not contact me directly and I will send it directly to yo u.4 - This picture is of a Pre-Oiler I made. =C2-It can handle oil pressu re up to 150 PSI. =C2-YOU pick the oil pressure your engine operates at a nd Pre-Oil at that pressure. =C2-=0A=0A=0A5 - Use the engine operating pr essure so any valves will be opened by the pressure and the oil spray will cover the same areas as during normal operation.6 - Since the engine has an Oil Pressure Regulator (item 1), you should pressure the pre-oiler higher than operating pressure and because the pressure drops in the pre-oilier=C2 -quickly as volume of oil drops.=0A=0A=0A7 - Monitor the Oil Pressure Gau ge of the plane/engine, since the Oil Pressure Sensor (item 2) is hooked up . =C2-There will probably be only a small deflection since the pre-oilier =C2-is applying pressure for only a short time.=0A=0A=0A8 - Now, here I h ave to ask a question. =C2-Does the Oil Pump (item 3) have a reverse flow check valve? =C2-If YES then you are limited to pre-oilier flow directio n.=C2-If NO then - Use the Pre-Oilier=C2-in BOTH directions - The IN an d the OUT.=0A=0A=0A9 - When I Pre-Oil, it is done with one (1) quart of oil in each direction - From the Oil Cooler into the Engine and then Into the Engine on the OUTPUT side of the Engine. =C2-See note 8. =C2-=0A=0A=0A1 0 - Now, here you have some options: =C2-a> You can leave the Oil Tank (i tem 4) attached and it will catch any oil that makes it to the exit of the engine. =C2-And remember to hook up a overflow tube to Vent Tube (item 7) . =C2-I really doubt if this will ever happen, or...=0A=0A=0Ab> Put a Plu g on the Engine Exit line/hose so it develops a good pressure to spray the oil all around inside the engine. The Pictures:=0A=0APic #1 is a general overview=C2-Pic #2 shows the fitti ngs. =C2-One thing you can not see is the inside of the unit. =C2-From the oil line on the outside is a nylon pick-up tube that goes to the bottom of the unit.=0A=0AYou will see a Shrader valve on top. =C2-I hook up a 1 2VDC portable=C2-tire pump. =C2-Pressurize the unit to 125 PSI, you can leave the tire pump on and running when you open the valve. =C2- =0A=0AThis system is so easy that I pre-oil anytime the engine sits for a m onth or more.=0A Barry On Fri, Oct 26, 2012 at 5:13 PM, Jim Clayton wrote: .com> =0A=0A=0A=0A =0AGreetings all: =0A =0AI looked in the archives and didn't see an answer so here goes: =0A =0AI have a 912ULS, in the crate I bought it in 2005. =C2-I just unwrappe d it and would like to pressurize the oil system with engine oil since the engine has been sitting so long and I am very concerned about roating the e ngine (dry) to get the internal pump to move oil. =C2-I have a 12 volt oi l pump, return tank and accessories to accomplish this, however I have a qu estion: =0A=0A=0A=0A =0ACan I simply feed the oil pump inlet hose-barb with oil pressure to circ ulate oil throughout the gallery? =C2-I am concerned the pump will not pa ss oil if the engine is not turning. =0A =0AAlternately I could remove the pressure sender and feed the gallery from there unless there is some reason not to. =C2-My preference is to feed t hrough the larger oil pump inlet in the hipe of greater flow through the ga llery. =0A=0A=0A=0A =0AI plan to return the oil by draining the crankcase through the return ho sebarb and back into the return tank. =0A =0AAny thoughts or suggestions to circulate oil through my engine? =0A =0AThanks, Jim =0A =0AKolb Mark3X =0A912ULS =0A80% completed =0A =0A========== =0A-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines -List =0A========== =0Ahttp://forums.matronics.com =0A========== =0Ale, List Admin. =0A="_blank">http://www.matronics.com/contribution =0A========== =0A =0A =0A =0A =0A ========================0A=0A ________________________________________________________________________________
Date: Oct 31, 2012
Subject: Spare 912ULS oil tank?
Greetings, Does anyone have a spare oil tank they would be interested in selling/renting/loaning? I will use it for my ground oiling scheme as detailed in other posts, and hope/expect to replace it with the original once I find it after 7 years of storage. Thanks, Jim Kolb Mark 3 Xtra 912ULS Building, 90% California, Bay Area. ________________________________________________________________________________
Date: Oct 31, 2012
Jim, I've been following your re-oiling saga from the first, and really can't quite figure out what you are trying to accomplish. You preserve an engine or other metal part by giving it a coat of oil to keep water off the metal, to keep it from rusting. Periodic re-coating renews this protection. I assume you have the preservation spec from Rotax? Extended soaking metal in oil does nothing for its long term wear characteristics, as the oil does not "soak into" the metal. We used to use metal containers to hold oil because they are impervious to the oil. If your gears or bearings have rusted, no amount of oiling is going to remove the rust. Much better to maybe just open it up and look to see if you actually have rust, and remove it chemically or replace the parts. Or if parts are seized, remove the dried oil with a solvent. Or am I missing something? (I could see maybe soaking a dried out seal in the hopes of reviving it, but again, I'd just figure on replacing them if they leak.) Gerry Visel (ex-gearbox engineer for 30+ years, but now doing high tech toilets!) > Hi Barry/All: > > Thanks! I am running the pump 30 minutes a day so the overkill makes > me feel better about storing the engine for so long :-) > > I agree with respect to the gearbox. While I did lean the engine > forward while the crankcase was full, I am concerned about the big > bearings on the prop shaft. I was thinking of again removing the fuel > pump, putting a couple of pints of oil in, and closing it up. Then > with several helpers turning the engine upside down. This would trap > oil at the prop-shaft end. Leave it upside down for perhaps a couple > of hours to marinate two big bearings. Looking at the photos I took > in the servicing class, I suspect those bearings need a bit of splash > to keep those two lubed. I figure an hour or so marinating maybe soak > in enough oil to suffice. Once done I will turn it right side up, and > allow all the oil to drain. > > I am several months from mounting the engine on the plane, so this > system will stay in place awhile. Wish I could find the oil tank as > the open bucket has to go. I will post separately asking if anyone > has a spare oil tank (I know...not likely). > > -Jim ________________________________________________________________________________
Date: Nov 01, 2012
Subject: PLEASE READ - Matronics Email List Fund Raiser During
November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's through solely through the Contributions of List members that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. Your personal Contribution counts! Once again, this year I've got a terrific line up of free gifts to go along with the various Contribution levels. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on Matronics Lists and have been either donated or provided at substantially discounted rates. This year, these generous people include: Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and very useful aviation-related product line. I would like publicly to thank Bob, Andy, and Jon for their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you for your support! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 01, 2012
Hi Gerry, Sorry, I may not have been clear. I am pretty handy in the material sciences, and do realize (for the purposes of this discussion) metals are not porous :-) The engine was internally (inside the valve covers), and externally oily, and there is no evidence anywhere of corrosion or moisture damage. It spent all its time in my care tightly wrapped in plastic and stored in a temperature controlled space. I was using engineering slang to describe my desire to allow the the bearing races/rollers/balls and the plain bearing journals to flush away the old, possibly dried manufacturing oils and replace them with fresh Rotax approved oils. Another goal is to wet, as best I can, the backs of the many oil seals present. One of the Kolb builders, some years ago, was in my situation, and when the engine was finally started, it ran great, but all the seals began leaking requiring replacement within the first few months. My hope is to try and avoid that. I am considering applying some kind of silicone spray to the external seal lips to further my goal to save whatever seals I can. Specifically regarding the large bearings supporting the prop shaft, after studying my photos of the engine we messed with in the servicing class, I noticed the bearing cages and possibly some kind of wiper *might* slow the flow of replacement oil as detailed above in my goals. Clearly these structures are designed to work best in a running engine with much oil splash. I surmised, if that was true I could flood the area and allow oil to seep past any obstructing structures and complete the oil replacement. As others on the list have correctly suggested this is a good time for a preservative oil. I chose to use standard approved oil for this engine instead for two reasons: --I was concerned the clutch could be affected by a bad choice on my part, and I didn't want to wait and get possibly ambiguous guidance from Rotax --The approved standard oil was locally available, and sure to work, however it would need periodic refreshing, something my oiling rig will address nicely. My professional engineering experience has taught me the extra effort to prevent a problem is usually worth the time. Particularly in my case: I have big investment in brand new engine whose warranty has long since expired. So I cooked up all these steps to satisfy myself. As I mentioned before, I offer this purely for its entertainment value and reference. I don't suggest anyone follow suit. Thanks, Jim --- On Wed, 10/31/12, Gerry Visel wrote: > From: Gerry Visel <gcvisel(at)gmail.com> > Subject: Re: RotaxEngines-List: Pre-oiling 912ULS > To: rotaxengines-list(at)matronics.com > Date: Wednesday, October 31, 2012, 5:34 PM > --> RotaxEngines-List message > posted by: Gerry Visel > > Jim, > > I've been following your re-oiling saga > from the first, and really > can't quite figure out what you are trying to > accomplish. You preserve > an engine or other metal part by giving it a coat of oil to > keep water > off the metal, to keep it from rusting. Periodic > re-coating renews this > protection. I assume you have the preservation spec > from Rotax? > > Extended soaking metal in oil does nothing > for its long term wear > characteristics, as the oil does not "soak into" the > metal. We used to > use metal containers to hold oil because they are impervious > to the oil. > > If your gears or bearings have rusted, no > amount of oiling is going > to remove the rust. Much better to maybe just open it > up and look to > see if you actually have rust, and remove it chemically or > replace the > parts. Or if parts are seized, remove the dried oil > with a solvent. > > Or am I missing something? (I could > see maybe soaking a dried out > seal in the hopes of reviving it, but again, I'd just figure > on > replacing them if they leak.) > > Gerry Visel > (ex-gearbox engineer for 30+ years, but now doing high tech > toilets!) > > > Hi Barry/All: > > > > Thanks! I am running the pump 30 minutes a day so > the overkill makes > > me feel better about storing the engine for so long :-) > > > > > I agree with respect to the gearbox. While I did > lean the engine > > forward while the crankcase was full, I am concerned > about the big > > bearings on the prop shaft. I was thinking of > again removing the fuel > > pump, putting a couple of pints of oil in, and closing > it up. Then > > with several helpers turning the engine upside > down. This would trap > > oil at the prop-shaft end. Leave it upside down > for perhaps a couple > > of hours to marinate two big bearings. Looking at > the photos I took > > in the servicing class, I suspect those bearings need a > bit of splash > > to keep those two lubed. I figure an hour or so > marinating maybe soak > > in enough oil to suffice. Once done I will turn > it right side up, and > > allow all the oil to drain. > > > > I am several months from mounting the engine on the > plane, so this > > system will stay in place awhile. Wish I could > find the oil tank as > > the open bucket has to go. I will post separately > asking if anyone > > has a spare oil tank (I know...not likely). > > > > -Jim > > > RotaxEngines-List Email Forum - > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Nov 01, 2012
Jim: You are right on about what you are saying and the procedure you are planing to use. Two suggestions: 1 - On your gaskets - DO NOT tighten any Screws, Nuts or Bolts more than they already are. To do so could distort the shape of the gasket and creates a leak. Start from the known you have and run it for a while AND even if it does leak - LET IT. Let it leak for a while and see if temperature and hot oil bring back some life to the gaskets. 2 - I understand your idea of using silicone spray on the gaskets - But - I would run a test first. Take a piece of gasket material. Weigh it and measure the thickness and if you have the ability the diameter of a punched out hole such as where a bolt may go through. Then subject it to the silicone you plan on using. Most silicone's are very close in substance except for particle size. The big difference is in the mobilization agent. And what happens when the agent evaporates off. Better to know this before you address the engine itself. Best of luck, Barry > I am considering applying some kind of silicone spray to the external seal > lips to further my goal to save whatever seals I can. > > Specifically regarding the large bearings supporting the prop shaft, after > studying my photos of the engine we messed with in the servicing class, I > noticed the bearing cages and possibly some kind of wiper *might* slow the > flow of replacement oil as detailed above in my goals. Clearly these > structures are designed to work best in a running engine with much oil > splash. I surmised, if that was true I could flood the area and allow oil > to seep past any obstructing structures and complete the oil replacement. > > As others on the list have correctly suggested this is a good time for a > preservative oil. I chose to use standard approved oil for this engine > instead for two reasons: > > --I was concerned the clutch could be affected by a bad choice on my part, > and I didn't want to wait and get possibly ambiguous guidance from Rotax > > --The approved standard oil was locally available, and sure to work, > however it would need periodic refreshing, something my oiling rig will > address nicely. > > My professional engineering experience has taught me the extra effort to > prevent a problem is usually worth the time. Particularly in my case: I > have big investment in brand new engine whose warranty has long since > expired. So I cooked up all these steps to satisfy myself. As I mentioned > before, I offer this purely for its entertainment value and reference. I > don't suggest anyone follow suit. > > Thanks, Jim > ________________________________________________________________________________
Date: Nov 02, 2012
Subject: 912iS paper
Those interested in the design of the 912iS may want to buy SAE paper nr 2012-32-0049. By 3 Rotax engineers and recently presented at an SAE conference. It costs $23 and can only be printed, during 24 hours, not saved. Some of the figures need to be printed separately to make some very small print readable (primitive but working procedure: zoom to maximise on screen, copy screen to clipboard, paste into picture viewer like Irfanview, crop in picture viewer and print/save). I found it interesting. A lot of questions were answered, quite a view remain. Jan de Jong ________________________________________________________________________________
Date: Nov 01, 2012
Great suggestions, Barry. -Thanks! -I will do some testing with the spr ay first. In other news -looked up a new oil tank on the Lockwood site....$800 some thing!! -ok, back to searching my shop. -Jim --- On Thu, 11/1/12, FLYaDIVE wrote: From: FLYaDIVE <flyadive(at)gmail.com> Subject: Re: RotaxEngines-List: Pre-oiling 912ULS Date: Thursday, November 1, 2012, 1:32 PM Jim: You are right on about what you are saying and the procedure you are planin g to use. Two suggestions:1 - On your gaskets - DO NOT tighten any Screws, Nuts or Bo lts more than they already are. -To do so could-distort-the shape of the gasket and creates a leak. -Start from the known you have and run it for a while AND even if it does leak - LET IT. -Let it leak for a while a nd see if temperature and hot oil bring back some life to the gaskets.=0A2 - I-understand-your idea of using silicone spray on the gaskets - But - I would run a test first. -Take a piece of gasket material. -Weigh it and measure the thickness and if you have the ability the diameter of a pun ched out hole such as where a bolt may go through. -Then subject it to th e silicone you plan on using. -Most-silicone's-are very close in subs tance except for particle size. -The big-difference-is in the-mobil ization-agent. -And what happens when the agent evaporates off. -Bett er to know this before you address the engine itself.=0A Best of luck, Barry =0AI am considering applying some kind of silicone spray to the external se al lips to further my goal to save whatever seals I can. =0A =0ASpecifically regarding the large bearings supporting the prop shaft, aft er studying my photos of the engine we messed with in the servicing class, I noticed the bearing cages and possibly some kind of wiper *might* slow th e flow of replacement oil as detailed above in my goals. -Clearly these s tructures are designed to work best in a running engine with much oil splas h. -I surmised, if that was true I could flood the area and allow oil to seep past any obstructing structures and complete the oil replacement. =0A=0A =0AAs others on the list have correctly suggested this is a good time for a preservative oil. -I chose to use standard approved oil for this engine instead for two reasons: =0A =0A--I was concerned the clutch could be affected by a bad choice on my par t, and I didn't want to wait and get possibly ambiguous guidance from Rotax =0A =0A--The approved standard oil was locally available, and sure to work, how ever it would need periodic refreshing, something my oiling rig will addres s nicely. =0A =0AMy professional engineering experience has taught me the extra effort to prevent a problem is usually worth the time. -Particularly in my case: I have big investment in brand new engine whose warranty has long since expi red. -So I cooked up all these steps to satisfy myself. -As I mentioned before, I offer this purely for its entertainment value and reference. - I don't suggest anyone follow suit. =0A=0A =0AThanks, Jim ======================0A=0A ________________________________________________________________________________
Date: Nov 02, 2012
Subject: Re: Pre-oiling 912ULS
Jim: For testing you could make a tank from PVC piping. It will handle the pressure if any and also the temperature. You could also install a simple oil filter in line. I know you will find the tank... Of course it will be in the last place you look. ;-) Barry On Thu, Nov 1, 2012 at 8:36 PM, Jim Clayton wrote: > Great suggestions, Barry. Thanks! I will do some testing with the spray > first. > > In other news looked up a new oil tank on the Lockwood site....$800 > something!! ok, back to searching my shop. > > -Jim > > > --- On *Thu, 11/1/12, FLYaDIVE * wrote: > > > From: FLYaDIVE <flyadive(at)gmail.com> > > Subject: Re: RotaxEngines-List: Pre-oiling 912ULS > To: rotaxengines-list(at)matronics.com > Date: Thursday, November 1, 2012, 1:32 PM > > Jim: > > You are right on about what you are saying and the procedure you are > planing to use. > > Two suggestions: > 1 - On your gaskets - DO NOT tighten any Screws, Nuts or Bolts more than > they already are. To do so could distort the shape of the gasket and > creates a leak. Start from the known you have and run it for a while AND > even if it does leak - LET IT. Let it leak for a while and see if > temperature and hot oil bring back some life to the gaskets. > 2 - I understand your idea of using silicone spray on the gaskets - But - > I would run a test first. Take a piece of gasket material. Weigh it and > measure the thickness and if you have the ability the diameter of a punch ed > out hole such as where a bolt may go through. Then subject it to the > silicone you plan on using. Most silicone's are very close in substance > except for particle size. The big difference is in the mobilization agen t. > And what happens when the agent evaporates off. Better to know this > before you address the engine itself. > > Best of luck, > > Barry > > > I am considering applying some kind of silicone spray to the external sea l > lips to further my goal to save whatever seals I can. > > Specifically regarding the large bearings supporting the prop shaft, afte r > studying my photos of the engine we messed with in the servicing class, I > noticed the bearing cages and possibly some kind of wiper *might* slow th e > flow of replacement oil as detailed above in my goals. Clearly these > structures are designed to work best in a running engine with much oil > splash. I surmised, if that was true I could flood the area and allow oi l > to seep past any obstructing structures and complete the oil replacement. > > As others on the list have correctly suggested this is a good time for a > preservative oil. I chose to use standard approved oil for this engine > instead for two reasons: > > --I was concerned the clutch could be affected by a bad choice on my part , > and I didn't want to wait and get possibly ambiguous guidance from Rotax > > --The approved standard oil was locally available, and sure to work, > however it would need periodic refreshing, something my oiling rig will > address nicely. > > My professional engineering experience has taught me the extra effort to > prevent a problem is usually worth the time. Particularly in my case: I > have big investment in brand new engine whose warranty has long since > expired. So I cooked up all these steps to satisfy myself. As I mention ed > before, I offer this purely for its entertainment value and reference. I > don't suggest anyone follow suit. > > Thanks, Jim > > *www.ow" target="_blank" href="http://www.buildersbooks.com">www.buil dersbooofollow" target="_blank" href="http://www.matronics.com/contribu tion">h="nofollow" target="_blank" href="http://www.matronics.com/Nav igator?RotaxEngines-List">http://www.matronics.com/Navigator?RotaxEngines-L ist========= > * > > * > =========== =========== =========== =========== > * > > -- *Barry* *=93Chop=92d Liver=94* * * *YOU ARE NOT * *WE ARE* *BECAUSE WE WERE * *YOU ARE* * * *The words to be inserted are VETERANS=92 and FREE* *Thank you Veterans!* ________________________________________________________________________________
Date: Nov 02, 2012
Hi Barry, Good idea! Thanks, Jim --- On Fri, 11/2/12, FLYaDIVE wrote: From: FLYaDIVE <flyadive(at)gmail.com> Subject: Re: RotaxEngines-List: Pre-oiling 912ULS Date: Friday, November 2, 2012, 5:17 AM Jim: For testing you could make a tank from PVC piping. =C2-It will handle the pressure if any and also the temperature. =C2-You could also install a s imple oil filter in line.I know you will find the tank... Of course it will be in the last place you look. =C2-;-)=0A Barry On Thu, Nov 1, 2012 at 8:36 PM, Jim Clayton wrote: =0AGreat suggestions, Barry. =C2-Thanks! =C2-I will do some testing wit h the spray first.=0A In other news =C2-looked up a new oil tank on the Lockwood site....$800 s omething!! =C2-ok, back to searching my shop. -Jim --- On Thu, 11/1/12, FLYaDIVE wrote: =0A From: FLYaDIVE <flyadive(at)gmail.com> Subject: Re: RotaxEngines-List: Pre-oiling 912ULS =0ATo: rotaxengines-list(at)matronics.com Date: Thursday, November 1, 2012, 1:32 PM Jim: You are right on about what you are saying and the procedure you are planin g to use.=0A Two suggestions:1 - On your gaskets - DO NOT tighten any Screws,=0A Nuts or Bolts more than they already are. =C2-To do so could=C2-distort=C2-t he shape of the gasket and creates a leak. =C2-Start from the known you h ave and run it for a while AND even if it does leak - LET IT. =C2-Let it leak for a while and see if temperature and hot oil bring back some life to the gaskets.=0A=0A2 - I=C2-understand=C2-your idea of using silicone s pray on the gaskets - But - I would run a test first. =C2-Take a piece of gasket material. =C2-Weigh it and measure the thickness and if you have the ability the diameter of a punched out hole such as where a bolt may go through. =C2-Then subject it to the silicone you plan on using. =C2-Mos t=C2-silicone's=C2-are very close in substance except for particle size . =C2-The big=C2-difference=C2-is in the=C2-mobilization=C2-agent . =C2-And what happens when the agent evaporates off. =C2-Better to kno w this before you address the engine itself.=0A=0A Best of luck, Barry =0AI am considering applying some kind of silicone spray to the external se al lips to further my goal to save whatever seals I can. =0A =0ASpecifically regarding the large bearings supporting the prop shaft, aft er studying my photos of the engine we messed with in the servicing class, I noticed the bearing cages and possibly some kind of wiper *might* slow th e flow of replacement oil as detailed above in my goals. =C2-Clearly thes e structures are designed to work best in a running engine with much oil sp lash. =C2-I surmised, if that was true I could flood the area and allow o il to seep past any obstructing structures and complete the oil replacement . =0A=0A=0A =0AAs others on the list have correctly suggested this is a good time for a preservative oil. =C2-I chose to use standard approved oil for this engi ne instead for two reasons: =0A =0A--I was concerned the clutch could be affected by a bad choice on my par t, and I didn't want to wait and get possibly ambiguous guidance from Rotax =0A =0A--The approved standard oil was locally available, and sure to work, how ever it would need periodic refreshing, something my oiling rig will addres s nicely. =0A =0AMy professional engineering experience has taught me the extra effort to prevent a problem is usually worth the time. =C2-Particularly in my case : I have big investment in brand new engine whose warranty has long since e xpired. =C2-So I cooked up all these steps to satisfy myself. =C2-As I mentioned before, I offer this purely for its entertainment value and refer ence. =C2-I don't suggest anyone follow suit. =0A=0A=0A =0AThanks, Jim =0A=0Awww.ow" target="_blank" href="http://www.buildersbooks.com">www.b uildersbooofollow" target="_blank" href="http://www.matronics.com/contr ibution">h="nofollow" target="_blank" href="http://www.matronics.com/ Navigator?RotaxEngines-List">http://www.matronics.com/Navigator?RotaxEngine s-List===========0A=0A=0A=0A=0A_blank">www.aeroelectric .com=0A.com" target="_blank">www.buildersbooks.com=0A="_blank">www.home builthelp.com=0A_blank">http://www.matronics.com/contribution=0Aist" target ="_blank">http://www.matronics.com/Navigator?RotaxEngines-List=0Atp://for ums.matronics.com=0A=0A -- Barry=0A=0A=9CChop=99d Liver=9D=0A=0A=C2-=0A=0AYOU ARE NOT =0A=0AWE ARE=0A=0ABECAUSE WE WERE =0A=0AYOU ARE=0A=0A=C2-=0A=0AThe wo rds to be inserted are VETERANS=99 and FREEThank you Veterans! ======================0A=0A ________________________________________________________________________________
Date: Nov 02, 2012
Guys - I don't know how it happened, but my Veteran's Day message became attached to an email. I can only blame it on Google. Go figure, yet the words are still true. Check 6 Barry ________________________________________________________________________________
Date: Nov 03, 2012
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Re: Spare 912ULS oil tank?
Date: Nov 03, 2012
Theres nothing super-special about the rotax tank.Other motor are sumpless.The seadoo dealer can get one off a webber 750 or the off road guys use the webber also.It is a tank with a screen to deair the oil,800$ is fraud.Its time to get away from this ripoff. ----- Original Message ----- From: "Jim Clayton" <jspc78(at)yahoo.com> Sent: Wednesday, October 31, 2012 5:07 PM Subject: RotaxEngines-List: Spare 912ULS oil tank? > > Greetings, > > Does anyone have a spare oil tank they would be interested in > selling/renting/loaning? I will use it for my ground oiling scheme as > detailed in other posts, and hope/expect to replace it with the original > once I find it after 7 years of storage. > > Thanks, Jim > > Kolb Mark 3 Xtra > 912ULS > Building, 90% > California, Bay Area. > > > ________________________________________________________________________________
From: Pete Christensen <pchristensen10(at)austin.rr.com>
Date: Nov 04, 2012
There was one on Barnstormers. On Nov 3, 2012, at 9:26 PM, "ray" wrote: > > Theres nothing super-special about the rotax tank.Other motor are sumpless.The seadoo dealer can get one off a webber 750 or the off road guys use the webber also.It is a tank with a screen to deair the oil,800$ is fraud.Its time to get away from this ripoff. > ----- Original Message ----- From: "Jim Clayton" <jspc78(at)yahoo.com> > To: > Sent: Wednesday, October 31, 2012 5:07 PM > Subject: RotaxEngines-List: Spare 912ULS oil tank? > > >> >> Greetings, >> >> Does anyone have a spare oil tank they would be interested in selling/renting/loaning? I will use it for my ground oiling scheme as detailed in other posts, and hope/expect to replace it with the original once I find it after 7 years of storage. >> >> Thanks, Jim >> >> Kolb Mark 3 Xtra >> 912ULS >> Building, 90% >> California, Bay Area. > > > > > ________________________________________________________________________________
Date: Nov 05, 2012
Subject: Coming Soon - The List of Contributors - Please Make
A Contribution Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Make sure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 05, 2012
Thanks! --- On Sun, 11/4/12, Pete Christensen wrote: > From: Pete Christensen <pchristensen10(at)austin.rr.com> > Subject: Re: RotaxEngines-List: Spare 912ULS oil tank? > To: "rotaxengines-list(at)matronics.com" > Date: Sunday, November 4, 2012, 5:18 AM > --> RotaxEngines-List message > posted by: Pete Christensen > > There was one on Barnstormers. > > On Nov 3, 2012, at 9:26 PM, "ray" > wrote: > > > > > > Theres nothing super-special about the rotax tank.Other > motor are sumpless.The seadoo dealer can get one off a > webber 750 or the off road guys use the webber also.It is a > tank with a screen to deair the oil,800$ is fraud.Its time > to get away from this ripoff. > > ----- Original Message ----- From: "Jim Clayton" <jspc78(at)yahoo.com> > > To: > > Sent: Wednesday, October 31, 2012 5:07 PM > > Subject: RotaxEngines-List: Spare 912ULS oil tank? > > > > > Clayton > >> > >> Greetings, > >> > >> Does anyone have a spare oil tank they would be > interested in selling/renting/loaning? I will use it > for my ground oiling scheme as detailed in other posts, and > hope/expect to replace it with the original once I find it > after 7 years of storage. > >> > >> Thanks, Jim > >> > >> Kolb Mark 3 Xtra > >> 912ULS > >> Building, 90% > >> California, Bay Area. > > > > > > > > > > > > > Lists This Month -- > Some AWESOME FREE Gifts!) > Raiser. Click on > more about > Gifts provided > www.aeroelectric.com > www.buildersbooks.com > www.homebuilthelp.com > -Matt > Dralle, List Admin. > RotaxEngines-List Email Forum - > - MATRONICS WEB FORUMS - > > > > ________________________________________________________________________________
Date: Nov 06, 2012
Subject: A Message From AeroElectric's Bob Nuckolls...
Dear Listers, The well known Bob Nuckolls of the AeroElectric posted a great message Monday on the AeroElectric-List regarding the Matronics Lists and the importance of supporting the operation during the Fund Raiser. Please take a minute to read Bob's commentary below, reposted to the other Matronics Lists with his permission... Date: Mon, 05 Nov 2012 08:58:41 -0600 From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> Subject: AeroElectric-List: Re: Please Make A Contribution Today! At 02:14 AM 11/5/2012, Matt Dralle wrote: > > Each year at the end of the List Fund Raiser, I post a message > acknowledging everyone that so generously made a Contribution to > support the Lists. Its my way of publicly thanking everyone that > took a minute to show their appreciation for the Lists. > I will add my voice to this suggestion. It's easy to enjoy the benefits of what's available to us off-the-shelves at the corner mega-marts. It's seldom that we give pause to learn and understand the processes and tools that made it possible to reach out and select from dozens of options. This, and all civil societies, runs on talent, energy and mobility. Mobility exploited by thousands of hands, machines and transportation that figure into the 'infrastructure' that puts the boxes of Wheaties and Pop Tarts on the shelves. See "I pencil" http://tinyurl.com/36xkhq Any break in that chain of time, talent and resources at least interrupts if not totally halts flow of that benefit. Matt's room full of byte-thrashers is like the natural gas pumping station a few miles from my house. If those pumps stop, who ever is expecting the furnace to come on at the other end of the pipe is at risk for reduced service and/or higher costs for that service. Matt's yearly endeavor to keep his pumps running is a trivial burden on the members of the Lists but of incalculable value to those who participate on them. No donation is too small. We go to a fly-in a willingly chuck a few bucks into the coffee can at the drinks and donuts table, let's chuck a few bucks into Matt's coffee can too. 50,000 pounds of value doesn't get to the shelves on time if one 18-wheeler runs out of gas. The T-bytes of data flow we all enjoy don't get from your keyboard to the screens of others unless Matt pays the light bill and strokes the machines to keep them happy. No, $5 won't get you a free copy of the 'Connection or a fuel sampler but it will go toward the assurance that logging onto your favorite List will open doors that you would be sorely missed should you find that hitting the return key doesn't produce the expected response. $5 from every List customer on Matt's system will go a very long way to keeping the byte-pumps running. $More$ will go a long way to upgrading the size and quality of the machines as the old ones get long in the tooth. No matter what size of donation you choose . . . please do it now . . . Bob . . . Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 08, 2012
Subject: Make A List Contribution - It's Your Personal Squelch
Button... There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 10, 2012
Subject: Please Support The Lists...
Dear Listers, Just a reminder that November is the Matronics Email List Fund Raiser month. There are some very nice incentive gifts to choose from as well! Please make your Contribution today at: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 12, 2012
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some pointd, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 22 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Subject: Airbox with servo
Date: Nov 12, 2012
Dear friends. I am new to the list. Would like to share with you my implementation of TWC's servo on a Rotax Airbox for my 912. Please find attached a couple of pics, and a link for a small video. http://youtu.be/KwuVpV9ycjo The servo has been programmed not to fully open, as in my experience, only a little hot air is enough to rise the intake temp. a good few degrees. Comments and feedback welcome! With warmest regards, Luis. ________________________________________________________________________________
Date: Nov 12, 2012
Who is TWC and do they have a web site? -- Craig From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Luis Peromarta Regert Sent: Monday, November 12, 2012 8:31 AM Subject: RotaxEngines-List: Airbox with servo Dear friends. I am new to the list. Would like to share with you my implementation of TWC's servo on a Rotax Airbox for my 912. Please find attached a couple of pics, and a link for a small video. <http://youtu.be/KwuVpV9ycjo> http://youtu.be/KwuVpV9ycjo The servo has been programmed not to fully open, as in my experience, only a little hot air is enough to rise the intake temp. a good few degrees. Comments and feedback welcome! With warmest regards, Luis. ________________________________________________________________________________
Subject: Re: Airbox with servo
Date: Nov 13, 2012
Looks very nice. Can you share more details/how the servo is programmed? No a ir box on my Kitfox but thinking of installing one. Sacha On Nov 12, 2012, at 17:31, Luis Peromarta Regert wrote: > Dear friends. > > I am new to the list. Would like to share with you my implementation of TW C's servo on a Rotax Airbox for my 912. Please find attached a couple of pic s, and a link for a small video. > > http://youtu.be/KwuVpV9ycjo > > The servo has been programmed not to fully open, as in my experience, only a little hot air is enough to rise the intake temp. a good few degrees. > > Comments and feedback welcome! > > With warmest regards, > > Luis. > > > > > > > ________________________________________________________________________________
Date: Nov 13, 2012
All details here. http://www.tcwtech.com/control_valve_servo_kit.htm Sorry for the typo, I meant TCW, not TWC. Best regards, LP. El 13/11/2012, a las 09:00, RotaxEngines-List Digest Server escribi=F3: > From: "Craig Payne" <craig(at)craigandjean.com> > Subject: RE: RotaxEngines-List: Airbox with servo > > Who is TWC and do they have a web site? > > > -- Craig ________________________________________________________________________________
Date: Nov 13, 2012
Luis: That is some SWEET welding. Barry On Mon, Nov 12, 2012 at 11:31 AM, Luis Peromarta Regert wrote: > Dear friends. > > I am new to the list. Would like to share with you my implementation of > TWC's servo on a Rotax Airbox for my 912. Please find attached a couple of > pics, and a link for a small video. > > http://youtu.be/KwuVpV9ycjo > > The servo has been programmed not to fully open, as in my experience, only > a little hot air is enough to rise the intake temp. a good few degrees. > > Comments and feedback welcome! > > With warmest regards, > > Luis. > > ________________________________________________________________________________
Date: Nov 14, 2012
Subject: Make Sure You're Listed! List of Contributors Published
in December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Rotax 912 Preheating
Date: Nov 14, 2012
Hello Group. There is an article in this month's EAA Bits and Pieces for Canada about preheating engines. It mentions the temps that trigger preheating for Continentals and Lycomings. I have not been able to find sugesstions for the Rotax 912. Does anyone know what the temperature would have to dip to require a preheat for the Rotax 912 ? Thanks. Regards, Damien Graham N48TK ________________________________________________________________________________
Date: Nov 14, 2012
Subject: Re: Rotax 912 Preheating
Damien: Pre-heating is a function of FREEZING which starts at either 0 C or 32 F. It is NOT a function of Manufacture. So unless ROTAX uses a different freezing point - - - Kelvin maybe - - - Start Pre-heating at the freezing point. Pre-heating is also helpful when it comes to PLASTICS. Many a knob and gear have become loose or broken when the temps drop. Personally - I begin to function slower as the temps get lower, so it is just as important to me to be Pre-Heated. Barry On Wed, Nov 14, 2012 at 10:57 AM, Damien wrote: > ** > Hello Group. > There is an article in this month's EAA Bits and Pieces for Canada about > preheating engines. It mentions the temps that trigger preheating for > Continentals and Lycomings. I have not been able to find sugesstions for > the Rotax 912. Does anyone know what the temperature would have to dip to > require a preheat for the Rotax 912 ? Thanks. > Regards, > Damien Graham > N48TK > > * > > * > > ________________________________________________________________________________
Date: Nov 14, 2012
Please explain what the freezing point of water has to do with when to preheat an engine that is cooled with a combination of antifreeze and air. Raymond Julian Kettle River, MN. "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine On 11/14/2012 09:58 PM, FLYaDIVE wrote: > Damien: > > Pre-heating is a function of FREEZING which starts at either 0 C or 32 > F. It is NOT a function of Manufacture. So unless ROTAX uses a > different freezing point - - - Kelvin maybe - - - Start Pre-heating at > the freezing point. > Pre-heating is also helpful when it comes to PLASTICS. Many a knob > and gear have become loose or broken when the temps drop. Personally > - I begin to function slower as the temps get lower, so it is just as > important to me to be Pre-Heated. > > Barry > > On Wed, Nov 14, 2012 at 10:57 AM, Damien > wrote: > > Hello Group. > There is an article in this month's EAA Bits and Pieces for Canada > about preheating engines. It mentions the temps that trigger > preheating for Continentals and Lycomings. I have not been able to > find sugesstions for the Rotax 912. Does anyone know what the > temperature would have to dip to require a preheat for the Rotax > 912 ? Thanks. > Regards, > Damien Graham > N48TK > > * > > _blank">www.aeroelectric.com > .com" target="_blank">www.buildersbooks.com > ="_blank">www.homebuilthelp.com > _blank">http://www.matronics.com/contribution > ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List > tp://forums.matronics.com > > * > > > * > > > * ________________________________________________________________________________
Date: Nov 15, 2012
Hi Raymond: The theory is this: There is water in the oil. There is water condensed on the metal parts of the engine. When the water freezes it creates ice crystals - Some of these ice crystals are between parts such as connecting rods and journals of the crank shaft. When water freezes it expands - This puts uneven pressure on the connected parts. Journals, guides and bearings. Squeezing out the oil. If there is Water in those areas there is NO oil in those areas - So there is the possibility of metal to metal ware. This is the THEORY - It has some merit. But, Adam Ant has not gotten inside the engine and taken pictures so I don't know 1,000%. I do KNOW this: A pre-heated engine starts easier than a non-pre-heated engine. A plane that I fly, an RV6, won't even think of starting at temps near freezing. Which brings up a second theory: Most aircraft engines have very sloppy tolerances between mating parts. If you have a better than average engine with close tolerances and there are dissimilar metals in contact (Steel and Aluminum) each metal has a different coefficient of expansion. Aluminum expands more than steel. You could put higher pressures and uneven pressure on mating parts. Chose which ever theory you like - But, Pre-Heat. Your engine will like you for it. And may even last longer. Barry On Wed, Nov 14, 2012 at 11:29 PM, rayj wrote: > Please explain what the freezing point of water has to do with when to > preheat an engine that is cooled with a combination of antifreeze and air. > > Raymond Julian > Kettle River, MN. > > "And you know that I could have me a million more friends, > and all I'd have to lose is my point of view." - John Prine > > On 11/14/2012 09:58 PM, FLYaDIVE wrote: > > Damien: > > Pre-heating is a function of FREEZING which starts at either 0 C or 32 > F. It is NOT a function of Manufacture. So unless ROTAX uses a different > freezing point - - - Kelvin maybe - - - Start Pre-heating at the freezing > point. > Pre-heating is also helpful when it comes to PLASTICS. Many a knob and > gear have become loose or broken when the temps drop. Personally - I begin > to function slower as the temps get lower, so it is just as important to me > to be Pre-Heated. > > Barry > > On Wed, Nov 14, 2012 at 10:57 AM, Damien wrote: > >> Hello Group. >> There is an article in this month's EAA Bits and Pieces for Canada about >> preheating engines. It mentions the temps that trigger preheating for >> Continentals and Lycomings. I have not been able to find sugesstions for >> the Rotax 912. Does anyone know what the temperature would have to dip to >> require a preheat for the Rotax 912 ? Thanks. >> Regards, >> Damien Graham >> N48TK >> >> * >> >> _blank">www.aeroelectric.com >> .com" target="_blank">www.buildersbooks.com >> ="_blank">www.homebuilthelp.com >> _blank">http://www.matronics.com/contribution >> ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List >> tp://forums.matronics.com >> * >> >> > * > > * > > > * > > * > > ________________________________________________________________________________
Date: Nov 15, 2012
some are getting close "dissimilar metals in contact (Steel and Aluminum) each metal has a differentcoefficientofexpansion. Aluminumexpandsmore than steel. You could put higher pressures and uneven pressure on mating parts. " this is one of the main reasons but another is the oil... oil only.... there is no water in an engine that runs often. one that sits for long perionds may... may have some condensation filter in..... but its the oil... shelll sport 4 is like cement , or molassis , or thick glue.. at lower temps....it cant be pumped or moved through a cold engine... try it ... a lot of metal clankin goin on till the oil is warmed and if you dont pre warm it ... its the friction from metal on metal that has to do the warmin up... . i have 100wat bulb on under the engine cowl from now till spring... and a bear blanket wrapped on the outside... live near detoit / toronto. any time the temp is below35/37 degrees i change oil to 0w40amsoil syn. and use the light....at temps below 20deg F i also us a propane heater for 30min . no one has to pre heat... but everyone should..alway... these engines are a big investment... try leaving $16000.00 at the curb and see if it needs warming in at night... it will just leave mysteriously... your engine is the same .. it will just leave you... one little part at a time... . all / any oil is the same to varying degrees... some are using 50w .. put that in the fridge over night and do a fluid test... it no longer is fluid...its rock hard.. 0wXX will be better but still is not great.. -------- Ross Aalexander: CH701 driver 912ul 589tt It only takes two things to fly, airspeed and money Read this topic online here: http://forums.matronics.com/viewtopic.php?p=387950#387950 ________________________________________________________________________________
Date: Nov 15, 2012
Hi Ross: There is always water in oil. Of course you reduce the quantity by flying often. An easy way to prove this to yourself is: After a flight - Open up your Oil Cap. What do you see coming out? A white vapor. That white vapor is water. Now, take a smooth sheet of aluminum and hold it in the vapor. What do you see? Water condensing on the aluminum. Part of the normal COMBUSTION process is water - http://en.wikipedia.org/wiki/Combustion And as combustion gases get past the rings of the pistons they get into the crank area of the engine. OIL is in the crank area of the engine and the oil absorbs the water. Another way of proving this is: Do this out side. Take a quart of NEW oil. Put it in a glass jar. Weigh the oil & jar - ACCURATELY - Gram Scale Put another Larger Glass jar over the first. Set up the second glass jar so it is raised an inch with 5 blocks around the edge. It has to breathe - Just like an engine. Let it sit OUTSIDE for a couple of months - [Requirement - You can't live in the Sara Desert] Weigh the oil & glass jar... Guess what? It became heaver - WATER was absorbed into the oil. Another proof: In the cold weather - DURING PRE-FLIGHT - Slowly and carefully pull out your dipstick (NO! Not that one!!!) - Look at the clear droplets that are on it. That is water. If it is on your dipstick, it is in your engine. If it is in your engine, it is in your oil. YES running an engine does reduce the amount of water but not totally. Hope this explains things. Barry On Thu, Nov 15, 2012 at 8:14 AM, dashwood wrote: > dashwoodlock(at)hotmail.com> > > some are getting close "dissimilar metals in contact (Steel and > Aluminum) each metal has a different=EF=BDcoefficient=EF=BDof=EF =BDexpansion.=EF=BD > Aluminum=EF=BDexpands=EF=BDmore than steel. =EF=BDYou could put higher pressures and > uneven pressure on mating parts. " > this is one of the main reasons but another is the oil... oil only.... > there is no water in an engine that runs often. one that sits for long > perionds may... may have some condensation filter in..... but its the > oil... shelll sport 4 is like cement , or molassis , or thick glue.. a t > lower temps....it cant be pumped or moved through a cold engine... try it > ... a lot of metal clankin goin on till the oil is warmed and if you don t > pre warm it ... its the friction from metal on metal that has to do the > warmin up... . i have 100wat bulb on under the engine cowl from now till > spring... and a bear blanket wrapped on the outside... live near detoit / > toronto. any time the temp is below35/37 degrees i change oil to > 0w40amsoil syn. and use the light....at temps below 20deg F i also us a > propane heater for 30min . > no one has to pre heat... but everyone should..alway... these engines > are a big investment... try leaving $16000.00 at the curb and see if it > needs warming in at night... it will just leave mysteriously... your > engine is the same .. it will just leave you... one little part at a > time... . all / any oil is the same to varying degrees... some are using > 50w .. put that in the fridge over night and do a fluid test... it no > longer is fluid...its rock hard.. 0wXX will be better but still is not > great.. > > -------- > Ross Aalexander: CH701 driver 912ul 589tt > It only takes two things to fly, airspeed and money > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=387950#387950 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Nov 15, 2012
Barry, Do you preheat your car? With it's big oil sump, you'll see lots more water there. Somehow they last for many hundreds of thousands of miles without (most people) preheating. (If you drive a diesel, this does not apply due to the higher compression ratios. I preheated my old Benz, even with its glow plugs, to help it turn over easier.) However, water in engines all gets boiled off during operation, so the only water you will see is from what might have condensed inside since last shutdown. I think you are worried too much about its effects. If it was a serious issue, you sure would have at least seen a procedure for how to do it in the engine owner's manual. That said, I sure agree that it is sure a whole lot easier to start a pre-heated engine when it is really cold outside! Gerry On Thu, Nov 15, 2012 at 7:46 AM, FLYaDIVE wrote: > Hi Ross: > > There is always water in oil. Of course you reduce the quantity by > flying often. > An easy way to prove this to yourself is: > After a flight - Open up your Oil Cap. What do you see coming out? A > white vapor. That white vapor is water. Now, take a smooth sheet of > aluminum and hold it in the vapor. What do you see? Water condensing on > the aluminum. > > Part of the normal COMBUSTION process is water - > ________________________________________________________________________________
Date: Nov 15, 2012
Gerry: You did not spend much time thinking through your email. 1 - You did not ask where I live -- - I could live in Florida and never require pre-heating. I could live in Alaska or North Dakota and have to pre-heat all winter long. Did you know that in extreme cold areas such as Alaska and North Dakota, if the plane is going to sit for a few days and then be flown, they remove the oil and bring it in a heated area. 2 - The size of the sump (not a sump but an oil pan) on a car is usually about 4 quarts. The size on Lycoming and Continental is 8 quarts so the CAR is a much smaller capacity. And capacity has nothing to do with it. It is the environment and the number of hours flown. 3 - Yes cars do go for hunderds of thousands of miles. The average car is used EVERYDAY do you fly your plane everyday? Not a good comparison. 4 - DIESEL - Diesel fuel is why diesel engines are pre-heated NOT the compression ratio. The GLOW PLUGS on a diesel are there to START COMBUSTION by pre-heating the inside of the cylinder. They are kept glowing by the combustion process. Diesel fuel GELS at low temperatures, a gelled fuel is extremely difficult to burn. Want to learn something - Take a small 3" diameter pan. Put in 1/8" of diesel fuel. Throw a match into it. What do you thinks will happen? NOTHING! NOTHING - The match will go out. That should show you how POOR diesel fuel is as an accelerant. My Diesel Rabbit had two pre heaters, one in the dipstick and one on the oil pan. Both raised the temp under the hood enough to heat a Metal Cased Cartage Oil Filter enough to prevent gelling. Oh, I live in NJ so I get both hot and cold temps. 5 - You did not comprehend my last post. WATER is also added to the oil through COMBUSTION. ALL the water is NOT boiled off as you think. Other wise why is there water vapor (Steam) coming out of your oil cap when opened. 6 - Yes I am worried about effects of cold starts - After all I have $18,000 invested in my engine NOT counting the plane, or the people that fly in it. 7 - Seven as in CRAPS you loose - " If it was a serious issue, you sure would have at least seen a procedure for how to do it in the engine owner's manual." You are so willing blindly trust a manual as to not use common sense and consider who ever wrote and accepted the manual could have missed writing the section on COLD STARTS! OR - OR you don't think BUSINESS comes before common sense? Think on how many planes are built WITHOUT a cowl. How do you preheat an engine without a cowl? How many engines would NOT be sold if the plane was to be used in colder areas such as NJ - IF - The manual said: Pre-heat at 32 F and below. RTFQS Barry On Thu, Nov 15, 2012 at 11:42 AM, Gerry Visel wrote: > Barry, > > Do you preheat your car? With it's big oil sump, you'll see lots more > water there. Somehow they last for many hundreds of thousands of miles > without (most people) preheating. (If you drive a diesel, this does not > apply due to the higher compression ratios. I preheated my old Benz, even > with its glow plugs, to help it turn over easier.) However, water > in engines all gets boiled off during operation, so the only water you will > see is from what might have condensed inside since last shutdown. I think > you are worried too much about its effects. If it was a serious issue, you > sure would have at least seen a procedure for how to do it in the engine > owner's manual. > > That said, I sure agree that it is sure a whole lot easier to start a > pre-heated engine when it is really cold outside! > > Gerry > > On Thu, Nov 15, 2012 at 7:46 AM, FLYaDIVE wrote: > >> Hi Ross: >> >> There is always water in oil. Of course you reduce the quantity by >> flying often. >> An easy way to prove this to yourself is: >> After a flight - Open up your Oil Cap. What do you see coming out? A >> white vapor. That white vapor is water. Now, take a smooth sheet of >> aluminum and hold it in the vapor. What do you see? Water condensing on >> the aluminum. >> >> Part of the normal COMBUSTION process is water - >> > > * > > > * > > ________________________________________________________________________________
Date: Nov 15, 2012
Get a life, guy. On Thu, Nov 15, 2012 at 12:05 PM, FLYaDIVE wrote: > > You did not spend much time thinking through your email. > ________________________________________________________________________________
Date: Nov 15, 2012
Sorry folks, I didn't know. I've learned my lesson. Raymond Julian Kettle River, MN. "And you know that I could have me a million more friends, and all I'd have to lose is my point of view." - John Prine On 11/15/2012 12:34 PM, Gerry Visel wrote: > Get a life, guy. > > On Thu, Nov 15, 2012 at 12:05 PM, FLYaDIVE > wrote: > > > You did not spend much time thinking through your email. > > > * > > > * ________________________________________________________________________________
Date: Nov 16, 2012
Subject: Who is Matt Dralle & What Are The Lists?
Dear Listers, Who is Matt Dralle and what exactly are these Lists anyway? I've been working in the Information Technology industry for over 28 years, primarily in computer networking design and implementation and more recently as an embedded software engineer. I have also done a fair amount of work in web design and development. I started the Matronics Email Lists way back in 1990 shortly after I started building my RV-4 with about 30 fellow RV builders from around the world. Since that time, I have added many other types of aircraft related Lists to the line up and numerous other List related services such as the Forums, Wiki, Archives and Search Engine just to name a few. For flexibility and reliability, I have chosen to run all of my own servers locally. Other List-related systems include a 1 Gigabit, fully switched network infrastructure, a commercial-grade Netscreen firewall, a Barracuda spam filter, a local T1 Internet router, and a bonded dual T1 commercial-grade business Internet connection with full static addressing. The computer servers include a dual quad-core Linux server for List web services with 24GB of memory, a quad -core Linux system dedicated to the email processing List functions, and another standalone Linux system serving as a remote storage disk farm for the archives, databases, and for an on-line hard drive-based backup system with multi-terra byts of online storage. This entire system is protected by three large, commercial-grade uninterrupted power supply systems (UPS) that assure the Lists are available even during a local power outage! Speaking of power, imagine how much electricity it takes to run all of these systems. On the average, the elctric bill is in the neighborhood of $7000-$8000/yr and the newly upgraded dual-T1 Internet connection runs roughly $6000/yr. A while back, I upgraded all of the computer racking infrastructure including new power feeds and dedicated air conditioning for the room that serves as the Computer Center for the Matronics Email Lists and followed that upgrade up with a second rack upgrade to house the MONSTER web system that didn't quite fit into the first rack! Here's a composite photo of the List Computer Center prior to the addition of the second rack: http://www.matronics.com/MattDralle-ListComputerCenter.jpg As you can see, I take running these Lists very seriously and I am dedicated to providing an always-on, 24x7x365 experience for each and every Lister. But building and running this system isn't cheap. As I've mentioned many times before, I don't use commercial advertisments to support any of these systems. It is supported 100% through List member Contributions! That means you... and you... and YOU! To that end, I hold a List Fund Raiser each November and ask that members make a Contribution to support the continued operation and upgrade of this ever-expanding system. Its solely YOUR Contributions that keeps it running! Please make a Contribution today to support these Lists! http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 16, 2012
http://www.eaa.org/bitsandpieces/articles/2012-11_cold-weather-operations.asp http://www.avweb.com/news/maint/182846-1.html -------- Ross Aalexander: CH701 driver 912ul 589tt It only takes two things to fly, airspeed and money Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388104#388104 ________________________________________________________________________________
Date: Nov 16, 2012
Hi Ross & Gaggle: While we al agree that pre-heating is helpful and benificial to our engines after reading the EAA news letter "Bits & Pieces" one has to note a few things: 1 - It was written by by Christine Wetherell , Tanis Aircraft whom is a member of TANIS AIRCRAFT as she even states. So take what is offered with a grain of salt. 2 - She also makes the statement: "Often, preheating is the only way to get a cold engine started. Cold fuel doesn't vaporize well,...". That is NOT a requirement. In the racing world of cars there is a device know as a COOL CAN (look it up) it is a can that has coil of copper tubing inside it - Into the can you put Dry Ice. This is to LOWER the temperature of the gas flowing to the engine. What this does is raise the Specific Gravity (density) of the gas so MORE molecules of gas are delivered into the combustion chamber. This increases the Horse Power of the delivered fuel . Vaporization takes place inside the cylinder (think high temps). Atomization takes place in the carburetor (think a super fine spray of particles). 3 - She uses the term Cold Soaked - In the engineering field this refers to a steady state temperature for a period of 24 hours or more as called out in particular environmental testing. Not really appropriate for normal day night temperature cycling. But, I think we all get the idea that she means - The engine has been cold and unused for a long time . 4 - Now, this one is TOTALLY WRONG - If you read about 2/3 the way down you will find this quote which is taken from a Continental Service Letter (SL): "Preheating is required whenever the engine has been exposed to temperatures at or below 20=B0F/-7=B0C (wind chill factor) for a period of two hours or more." - This is totally incorrect. Why? Because engines CANNOT experience windchill factor. Windchill is the process of evaporation of moisture off the skin which reduced the applied temperature to an effective temperature. The engine does NOT have skin. ALSO - in most cases the engine is under the cowl so it does not even experience wind blowing across it. The person who wrote this for Continental was incorrect and the person that regurgitated incorrect information did not bother to do their job. The point where pre-heating becomes advantageous is the freezing point 0 C/32 F. Some engines are temperamental and require it at higher temperatures. I know one O-360 Lycoming that complains around 40 to 45 F. I don't know why. "If you tell a lie loud enough and long enough, it becomes the truth." Leni n Do your homework people. Barry ================== On Fri, Nov 16, 2012 at 8:23 AM, dashwood wrote: > dashwoodlock(at)hotmail.com> > > > http://www.eaa.org/bitsandpieces/articles/2012-11_cold-weather-operations .asp > > > http://www.avweb.com/news/maint/182846-1.html > > -------- > Ross Aalexander: CH701 driver 912ul 589tt > It only takes two things to fly, airspeed and money > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=388104#388104 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Nov 16, 2012
... In the racing world of cars there is a device know as a COOL CAN (look it up) it is a can that has coil of copper tubing inside it - Into the can you put Dry Ice. This is to LOWER the temperature of the gas flowing to the engine. What this does is raise the Specific Gravity (density) of the gas so MORE molecules of gas are delivered into the combustion chamber.... When I was a drag racer nearly 50 years ago, I built my own cool cans, but the purpose for it was not as you stated. The real purpose was to eliminate vapor lock on hot summer days. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388120#388120 ________________________________________________________________________________
Date: Nov 16, 2012
Hey Thom: You don't look that old. :-) I did my racing in the late '60's and early '70's. RACEWAY PARK, Englishtown, NJ I never heard of the cool can being used for vapor lock. All dependent on the location of the can and length of the fuel run that might be a concern. But, in those days engine compartments were HUGE - So big I was able to climb right in under the hood - Legs and all. Just to do a intake manifold or a valve job. With all that room I can't see how heat could build that high, the can was also to be located as close to the Carb as possible. So that would eliminate the possibility of vapor lock forming. Vapor Lock - Possible but I don't think probable. Well, at least I never experienced that problem. Here are links about how others used the cool can: http://forums.corral.net/forums/5-0-5-8-engine-tech/556895-whos-running-fuel-cool-can-cooler.html http://blogs.superchevy.com/6274849/chevy-tech/keep-your-fuel-cool/ http://grassrootsmotorsports.com/forum/grm/fuel-cool-can/10560/page1/ And the list goes on... No mention of Vapor Lock. Back then I did not know about Density Altitude. But today a friend that still races has an entire computer program that addresses Density Altitude and he changes his injectors for the particular conditions. He still believes in the COOL CAN. Hey, it can't hoit! Barry On Fri, Nov 16, 2012 at 11:45 AM, Thom Riddle wrote: > > > > ... In the racing world of cars there is a device know as a COOL > CAN (look it up) it is a can that has coil of copper tubing inside it - > Into the can you put Dry Ice. This is to LOWER the temperature of the gas > flowing to the engine. What this does is raise the Specific Gravity > (density) of the gas so MORE molecules of gas are delivered into the > combustion chamber.... > > > When I was a drag racer nearly 50 years ago, I built my own cool cans, but > the purpose for it was not as you stated. The real purpose was to eliminate > vapor lock on hot summer days. > > -------- > Thom Riddle > Buffalo, NY (9G0) > > Kolb Slingshot SS-021 > Jabiru 2200A #1574 > > Diamond Katana DA20-A1 > Rotax 912 F3 > > Don't worry about old age... it doesn't last very long. > - Anonymous > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=388120#388120 > > ________________________________________________________________________________
Date: Nov 18, 2012
Subject: Prop-Balancing a TD
Hi Gaggle: A bit of an unusual question. I have balanced props using dynamic balancing on planes, but, they were all trike gear. Now I want to balance the prop on an RV6 (Tail Dragger). Since there is a nose up attitude and the prop is not sitting S&L, my thoughts are; asymmetric loading would affect the outcome. And two things would happen: 1 - The prop would not reach the highest possible RPM and 2 - I would be fighting the asymmetric loading and never be able to achieve a balance in the S&L configuration. So, if I am correct about my concerns; how can I secure the plane in a S&L ground attitude? Thanks Gaggle, Barry PS I want to do this so bad because I just did a plane where I was able to reduce the displacement from 0.38 to 0.04 IPS WOW! What a noticeable physical difference that made. ________________________________________________________________________________
Subject: Re: Prop-Balancing a TD
Date: Nov 18, 2012
Where aare you located? I'd love to have my prop balanced, but I doubt there's anyone doing this within a few hundred miles of me. (Central Colorado) ----- Original Message ----- From: FLYaDIVE To: rotaxengines-list(at)matronics.com Sent: Sunday, November 18, 2012 9:29 AM Subject: RotaxEngines-List: Prop-Balancing a TD Hi Gaggle: A bit of an unusual question. I have balanced props using dynamic balancing on planes, but, they were all trike gear. Now I want to balance the prop on an RV6 (Tail Dragger). Since there is a nose up attitude and the prop is not sitting S&L, my thoughts are; asymmetric loading would affect the outcome. And two things would happen: 1 - The prop would not reach the highest possible RPM and 2 - I would be fighting the asymmetric loading and never be able to achieve a balance in the S&L configuration. So, if I am correct about my concerns; how can I secure the plane in a S&L ground attitude? Thanks Gaggle, Barry PS I want to do this so bad because I just did a plane where I was able to reduce the displacement from 0.38 to 0.04 IPS WOW! What a noticeable physical difference that made. ________________________________________________________________________________
Date: Nov 18, 2012
Hi John: Well, I'm a bit further than a few hundred from you... All the way out in NJ. Wish I was closer. Barry On Sun, Nov 18, 2012 at 12:25 PM, JohnF wrote: > ** > Where are you located? I'd love to have my prop balanced, but I doubt > there's anyone doing this within a few hundred miles of me. (Central > Colorado) > > > ----- Original Message ----- > *From:* FLYaDIVE > *To:* rotaxengines-list(at)matronics.com > *Sent:* Sunday, November 18, 2012 9:29 AM > *Subject:* RotaxEngines-List: Prop-Balancing a TD > > Hi Gaggle: > > A bit of an unusual question. > I have balanced props using dynamic balancing on planes, but, they were > all trike gear. > Now I want to balance the prop on an RV6 (Tail Dragger). > Since there is a nose up attitude and the prop is not sitting S&L, my > thoughts are; asymmetric loading would affect the outcome. > And two things would happen: > 1 - The prop would not reach the highest possible RPM and > 2 - I would be fighting the asymmetric loading and never be able > to achieve a balance in the S&L configuration. > > So, if I am correct about my concerns; how can I secure the plane in a S&L > ground attitude? > > Thanks Gaggle, > > Barry > > PS > I want to do this so bad because I just did a plane where I was able to > reduce the displacement from 0.38 to 0.04 IPS > WOW! What a noticeable physical difference that made. > > > * > > href="http://www.aeroelectric.com">www.aeroelectric.com > href="http://www.buildersbooks.com">www.buildersbooks.com > href="http://www.homebuilthelp.com">www.homebuilthelp.com > href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.matronics.com/Navigator?RotaxEngines-List > href="http://forums.matronics.com">http://forums.matronics.com > * > > * > > * > > ________________________________________________________________________________
Date: Nov 19, 2012
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 19, 2012
The same technology used to dynamically balance an airplane propellor is used to balance helicopter rotors. It does not matter what the angle of the rotating disk is with respect to the earth's gravitational field. It is measuring the rotating mass imbalance with respect to its rotational center axis. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388322#388322 ________________________________________________________________________________
Date: Nov 19, 2012
I'm with Thom, I to balance props and have owned a helicopter. The angle won't make any difference. It is the rotating mass. You do not need full in flight rpm. I use 4800-5000 on the ground to balance. This depends on each persons prop rpm setup on their individual plane. The balancing instrument doesn't care because you just plug that number in and it gets divided by 2.43 any way because we have the gear reduction. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388324#388324 ________________________________________________________________________________
Date: Nov 19, 2012
...I doubt there's anyone doing this within a few hundred miles of me. (Central Colorado) .... Many active FBOs with repair stations offer dynamic prop balancing. They are getting more and more common as the price of equipment comes down. If I was doing mechanic work even half-time, I'd buy one but I'm still trying to be retired and only do actual work on other's airplanes once in a while. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 Jabiru 2200A #1574 Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=388325#388325 ________________________________________________________________________________
Date: Nov 21, 2012
Subject: Some Nice Comments...
Dear Listers, I've been getting some very nice comments from Listers along with their List Support Contributions. I've shared a number of them below. Please read them over and see what your fellow Listers think of the Lists and Forums. Please make a Contribution today to support the continued upgrade and operation of these services. There are lots of sweet gifts available this year, so please browse the nice selection and pickup something fun with your qualifying Contribution! You may use a credit card or your PayPal account here: http://www.matronics.com/contribution Or feel free to send a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator -------------------- What Listers Are Saying About The Lists -------------------- I have been flying my Pietenpol for a month now and am enjoying the fruits of ten hard years of work. I seriously doubt it would ever have been finished but for the help, encouragement and friendships I've received and made through the Pietenpol list. Douwe B Outstanding service to the flying community. George A Matt, I look forward to support each others projects, Glenn B Great list!!! Thanks for all your efforts! Roger C Thank you for keeping up the lists. Without it i would never have completed my aircraft. Stan S Keep up the good work my friend. I don't think I could ever finish my Pietenpol Air Camper without the help I get from this List. Tom S Thank you for keeping these list alive. Lee V The List is invaluable!! Svein J Thanks for continuing to provide the list service! Earl S You have a really GREAT service. Thankyou so much I've been on for nearly 30 years and I still check-in every morning. John B I rely fully on the lists which govern my every decision. The flexibility provides the security I seek. Fergus K My RV 7 Finally flies... 7 years of Matronics.com certainly helped. Martin H Great service here, thanks! I am just getting back to a project I dropped for a few years, great to see your site and all the folks again! James C Thanks for the great site. Robert U The Rotax list is good and the AeroElectric list outstanding! Jay H Thank you for a great resource! Jack T Thanks for your great record of outstanding service to the homebuilding community! Larry W This service is invaluable. Michael W You're doing a great job Matt. Robert D Thanks for all your work, its a great asset to all. John F Thank you for your time & effort Matt! Ted W Matt, been a follower since 2005 on the -10 list, now starting an -8. Keep up the great work! John M Still my favorite place to hang out. William W I'm not a Piet builder, but this is the most informative and congenial list I've ever run across. Please forgive my lurking-I learn a LOT here! Ken M Many thanks for keeping this alive, keep pushing! Adrian C Thanks! Please keep r going! Rich Z Many thanks for your hard work. Robert C Thanks for the Lists! I probably need to subscribe to a few more... John M Been a quick 14 years. Think I subscribed to the Kolb List in 1998, when I got my first computer. Thanks for keeping everything running smoothly for all these years. John H Great resource - thank you. David M I don't post very much, but get the postings, a lot of really practical info. John N Great job Matt, thanks for all you do. Roger M Thanks for ANOTHER great year, Matt! True grassroots experimental aviation has been pushed aside in many ways. But the List represents the evolution of this great tradition of home-building. One man, the plans, the tools, and the List - that's all you need to build the dream! Robert B This message board is a real help to my project and creating friendships. John S Many thanks for your continuing excellent work. Mike G Thank you for your work Matt. Your lists have helped me a great deal during the construction of my plane. Hal B Nice List Van E These lists are priceless for builders. Ronald C Thanks for keeping me in touch with the Pulsar community. Otto S Thanks for keeping up this great warbird sight!! Yak Ron Thanks for providing all the lists for so many years. H H Thanks for all that you do. Your dedication is much appreciated! Warren H Best service on the internet! Owen B I have learned so much from the "list". Nick C Great Service You Are Providing! Giffen M Thanks so much for maintaining these great resources. Dave S I no longer fly due to age and health problems, but I still enjoy the reading from other pilots. Dallas S This is a wonderful site. Robert B Useful service over the last year - thanks. Om T -------------------- What Listers Are Saying About The Lists -------------------- ________________________________________________________________________________
Date: Nov 23, 2012
Subject: "Black Friday" For List Fund Raiser...?
Dear Listers, The number of List subscriptions are up by a fair amount this year, but support during this year's Fund Raiser is substantially behind last year, and there's only about a week left until the end of the Fund Raiser. I have always preferred a non-commercial List experience as many, many members have also expressed that they do as well. However, if the yearly fund raiser cannot generate sufficient funds to keep the bills paid, other sources of income might be required including some sort of advertising. Please don't let that happen! Your personal Contribution of $20 or $30 goes a long ways to keeping this operation a float. Please make sure your name is on this year's List of Contributors! The List Contribution site is secure, quick, and easy: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you in advance for your support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 25, 2012
Subject: Just A Few More Days To Make Your List Contribution...
There is less than a week left in this year's List Fund Raiser and only a few short days to grab one of the great Contribution Gifts available this year. Support is still significantly lagging behind last year at this point but hopefully it will pick up here towards the end. Please remember that it is solely the Contributions of List members that keeps the Lists up and running as there is no commercialism or advertising on the Matronics Lists and Forums. The List Contribution web site is secure, fast, and easy and you can use a credit card, Paypal, or a personal check: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I want to thank everyone that has already made a generous contribution to support the Lists! Thank you! Matt Dralle Matronics EMail List and Forum Administrator ________________________________________________________________________________
Date: Nov 26, 2012
Subject: Contributions Down By 23%...
Dear Listers, As of today, Contributions to the Matronics List Fund Raiser are lagging behind last year at this time by roughly 23%. I have a Fund Raiser each year simply to cover my operating costs for the Lists. I *do not* accept any advertising income to support the Lists and rely solely on the Contributions of members to keep the expenses paid. I run all of my own servers and they are housed here locally, and the Internet connection is a commercial-grade, dual T1 connection with public address space. I also maintain a full backup system that does nightly backups of all List-related data so that in the event of a server crash, all of the Lists and the many years of List archive data could be restored onto a new server in a matter of hours. All of this costs a fair amount of money, not to mention a significant amount of my personal time. I have a Fund Raiser each year to cover these costs and I ask that members that feel they receive a benefit from my investments make a modest Contribution each year to support the continued operation and upgrade of these services. If you enjoy the Lists, please make a Contribution today. I also offer some incentive gifts for larger Contribution levels. At the Contribution Web Site, you can use a credit card, Paypal, or personal check to show your support for the continuation of these services: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2012
Subject: Make Sure You're Listed! List of Contributors Coming
in December! Dear Listers, There's just a couple more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 28, 2012
Subject: Just 3 Days Left - Please Make Your List Contribution
Today! There are only three days left until the end of this year's List Fund Raiser. Please take a minute to show your support as so many others have this year and make sure YOUR name is on the forthcoming List of Contributors! Its quick and easy using the secure web site with a credit card or PayPal: http://www.matronics.com/contribution or by sending your personal check to: Matronics Lists c/o Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your support of these List services! Matt Dralle Matronics Email and Forum Administrator ________________________________________________________________________________
Subject: Oil in Turbo on 914
Date: Nov 28, 2012
Looking for some advice. My 914 hasn't been run for about 18 months. Oil has been collecting in the bottom of the turbo. I have the hose between the turbo and intercooler disconnected and I can suck up oil with paper towels in that opening. After about 2 months, the oil leaks back in. Any suggestions on what could be causing this? And can I run the engine with the turbo to intercooler to intake disconnected? I'm assuming it would just run like a 912 but not sure. I would only do that for testing. Thanks, Brad Europa XS with Rotax 914 ________________________________________________________________________________
Subject: Re: Oil in Turbo on 914
Date: Nov 28, 2012
You should clean and blow out each line with oil to the turbo. If the check valve sticks which is probably what is happening with oil in the turbo it just needs cleaning. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=389356#389356 ________________________________________________________________________________
Date: Nov 29, 2012
Subject: Just Two Days Left! - Still Behind...
Dear Listers, There are just two more days left in this years List Fund Raiser. Over the last couple of weeks I have received some more really nice comments from members on what the Lists have meant to them. I have included a few more of them below. Please read over the comments and ponder on your own feelings about the Lists and the support and camaraderie you have found here. We are still behind last year in terms of the number of contributions. I really want to keep providing these services to the homebuilt community, but it take resources. Since there's no advertising budget or deep pockets to keep the operation a float, its solely your generosity during the Fund Raiser that keeps things going. Please make a Contribution today. If you've been putting off showing your support for the Lists, now is the time to do it! Make a contribution with a Credit Card or though PayPal at that Matronics Contribution web site: http://www.matronics.com/contribution Or, drop a check in the mail: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your support! Matt Dralle Matronics Email List Administrator ==================== A Few List Member Comments ===================== I have been flying my Pietenpol for a month now and am enjoying the fruits of ten hard years of work. I seriously doubt it would ever have been finished but for the help, encouragement and friendships I've received and made through the Pietenpol list. Douwe B Hey-Long time subscriber, zero-time contributor. Just a note of thanks. This is first time I have the resources to contribute. Thanks for carrying a lightweight for years and a special thanks for your time and effort. Billy R My 601 hd is flying with the help with the listers. Noel G A very useful facility. Graeme B ..great site! Robert C Great Pietenpol site! Don Y Not active but always interested in keeping up. Enjoy when I can. Richard R Dave and Tim from Aircrafters just want to reiterate our thanks for hosting the lists. Tim F. I don't have a lot to give at this time of year, but I hope my contribution helps none the less. I really enjoy the message board. Mark C Thanks to your continued work on maintaining these lists. Ralph C The lists and the various contributors have been a great help while I was building and also now that I'm flying. Albert G Very helpful tools for the homebuilder. Vaughn T We appreciate your great help! Richard H Many of our customers have expressed to us that you provide them with an invaluable service - and we agree! Bill B I Fly a Quicksilver GT400 but love to read what the Kolb boys have to say and it was on your list that I found out about the Yamaha product Ring Free,, now called engine med, that shit works.. no carbon in my rings or any to speak of with the use of the Yamaha product with a premix 503 with over 300 hrs of use.. thanks to your Kolb bulletin board. Robert B You are providing a valuable service that helps a lot of people through information sharing. When I built my Pietenpol over 40 years ago we were largely on our own, working without a resource like this list. Graham H Thanks for the opportunity to link us all, keep the good work! Peter B ________________________________________________________________________________
Date: Nov 30, 2012
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, Its November 30th and that always means a couple of things. Its my birthday again; number 49 actually! But it also means that its that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 10, 2012
Subject: EGT Probes
FOR SALE EGT PROBE MICRO-1000 K TYPE 90 Deg smooth bend mounting tube GROUNDED CLAMP MOUNTING for the exhaust pipes ACS PRICE $56 EA ---> $224 <--- This is HIGH All 4 probes $180 <--- SAVE Probes were used for less than one (1) hour Let me know what type of connector end you require I will install them for you FREE. Need a Male - Female Connector ends? Will install for FREE and supply the mating end for FREE. Barry ________________________________________________________________________________
Date: Dec 10, 2012
Subject: 2012 List of Contributors
Dear Listers, The 2012 Matronics Email List and Forum Fund Raiser officially ended about a week ago and its time that I publish this year's List of Contributors. It is the people on this list that directly make the Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Bob, Jon, and Andy for their generous support through the supply of great gifts this year!! These guys have some excellent products and I encourage you to visit their respective web sites: Bob Nucklolls - AeroElectric - http://www.aeroelectric.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com And finally, I'm proud to present The 2012 Fund Raiser List of Contributors: http://www.matronics.com/loc/2012.html Thanks again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Rotax 914 Right Mag rough
Date: Dec 11, 2012
Hello All. Rotax 914 engine, Aircraft in the SE England, temp about +3 first flight for about 6 weeks. Fuel Mogas, Full Charged Battery, Engine Gurgled,Full Choke on Start. I had difficulty in starting the engine, it took a long time before it fired and when it did i had ?? Detonation or Pre ignition not sure which term would suit but the engine fire to soon and pushed the piston down before it passed over TDC causing sudden stopping ,or Prop flickering to too and throw, not good. Is there a way to stop this happening , or control settings to use for cold starts., the plane has a tendency to do this. I have a second problem, on the Right Mag i get a drop and it goes into rough running misfiring banging, From memory i can,t remember if its the top or bottom plugs on the Right Key Position, but all the plugs changed about 25 or 30 hours ago. Another Question with regards to the Coils, 4 of them. Are they all the same, ie, no timings involved can use any other one, Its just a Coil ?? is that correct. With regards to the Fuel Mogas, thinking of trying Mogas Super (UK) spec. Regards Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390302#390302 ________________________________________________________________________________
Subject: EGT Indications
Date: Dec 12, 2012
Hi All, I have a 912S and recently have noticed a trend of higher exhaust gas temps on the rear two cylinders. I know that CHT will read higher on the two rear cylinders but not sure if that same reason would apply to EGT as well. The temps are just 20 to 30 degrees below max. About to take off the cowlings and start my annual and wanted to hear some thoughts on this subject from you all. Thanks. Troy Maynor Europa Monowheel Classic 195 hours 912S Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390319#390319 ________________________________________________________________________________
Date: Dec 13, 2012
Subject: AvGas Available at local MoGas Stations
Gang: I was just informed of an article in the NEWARK STAR LEDGER (NEWARK, NJ NEWSPAPER), Page 21. Gas Stations being shut down because they are selling AVIATION GAS!!! Too bad I did not know which station were selling it... I would have loaded up! Especially at $3.60 a Gallon. <-- High Test. Maybe it was in the REGULAR Pumps at $3.26 a Gallon??? But, the questions have to be asked: 1 - If there is so much control over AvGas <--- So they say as to keep prices high. Where was the control on the delivery? 2 - Was AvGAs put into uncontrolled MoGas delivery vehicles? 3 - Was MoGas put into uncontrolled AvGas delivery vehicles? 4 - Have the Controlled Delivery Vehicles now been contaminated with MoGas? 5 - OMG ! ! ! ... What will our Ever Vigilant EPA do now that LEAD is being burned by surface vehicles? And... 6 - Who picks up the $TAB$ on the destroyed Catalytic Converters. <--- NJ in all their wisdom has done away with automobile inspection. Except for EMISSIONS TESTING. So, if your car fails and you don't even know you had a load of AvGas who pays for the repairs??? AND even if you do know... WHO PAYS! No coffee as yet so these are the only questions I can come up with at this time. Maybe you have a few to ask? Barry ________________________________________________________________________________
Date: Dec 13, 2012
Subject: Re: AvGas Available at local MoGas Stations
I believe it was jet fuel.=0A=0A=0A=0A=0A________________________________ =0AFrom: FLYaDIVE <flyadive(at)gmail.com>=0ATo: grumman-gang <grumman-gang@mai lman.xmission.com>=0ASent: Thu, December 13, 2012 8:32:50 AM=0ASubject: Rot axEngines-List: AvGas Available at local MoGas Stations=0A=0AGang: =0A=0AI was just informed of an article in the NEWARK STAR LEDGER (NEWARK, NJ =0ANE WSPAPER), Page 21.=0A=0AGas Stations being shut down because they are selli ng AVIATION GAS!!!=0A=0AToo bad I did not know which station were selling i t... I would have loaded up! =0A-Especially at $3.60 a Gallon. <-- High T est. -Maybe it was in the REGULAR Pumps =0Aat $3.26 a Gallon???=0ABut, th e questions have to be asked:=0A1 - If there is so much control over AvGas <--- So they say as to keep prices =0Ahigh. -Where was the control on the delivery?=0A2 - Was AvGAs put into-uncontrolled-MoGas delivery vehicle s?=0A3 - Was MoGas put into uncontrolled AvGas delivery vehicles?=0A4 - Hav e the Controlled Delivery Vehicles now been-contaminated-with MoGas?=0A 5 - OMG ! ! ! ... What will our Ever Vigilant EPA do now that LEAD is being =0Aburned by surface vehicles? And...=0A6 - Who picks up the $TAB$ on the -destroyed-Catalytic-Converters. <--- NJ in all =0Atheir-wisdom-h as done away with automobile inspection. -Except =0Afor-EMISSIONS-TES TING. -So, if your car fails and you don't even know you had a =0Aload of AvGas who pays for the repairs??? -AND even if you do know... WHO PAYS! =0A=0ANo coffee as yet so these are the only questions I can come up with a ====== =0A ________________________________________________________________________________
Date: Dec 13, 2012
Correction, AV Web said it was 100 LL=0A=0A=0A=0A=0A_______________________ _________=0AFrom: FLYaDIVE <flyadive(at)gmail.com>=0ATo: grumman-gang <grumman -gang(at)mailman.xmission.com>=0ASent: Thu, December 13, 2012 8:32:50 AM=0ASub ject: RotaxEngines-List: AvGas Available at local MoGas Stations=0A=0AGang: =0A=0AI was just informed of an article in the NEWARK STAR LEDGER (NEWARK, NJ =0ANEWSPAPER), Page 21.=0A=0AGas Stations being shut down because they are selling AVIATION GAS!!!=0A=0AToo bad I did not know which station were selling it... I would have loaded up! =0A-Especially at $3.60 a Gallon. < -- High Test. -Maybe it was in the REGULAR Pumps =0Aat $3.26 a Gallon??? =0ABut, the questions have to be asked:=0A1 - If there is so much control o ver AvGas <--- So they say as to keep prices =0Ahigh. -Where was the cont rol on the delivery?=0A2 - Was AvGAs put into-uncontrolled-MoGas delive ry vehicles?=0A3 - Was MoGas put into uncontrolled AvGas delivery vehicles? =0A4 - Have the Controlled Delivery Vehicles now been-contaminated-with MoGas?=0A5 - OMG ! ! ! ... What will our Ever Vigilant EPA do now that LEA D is being =0Aburned by surface vehicles? And...=0A6 - Who picks up the $TA B$ on the-destroyed-Catalytic-Converters. <--- NJ in all =0Atheir-w isdom-has done away with automobile inspection. -Except =0Afor-EMISSI ONS-TESTING. -So, if your car fails and you don't even know you had a =0Aload of AvGas who pays for the repairs??? -AND even if you do know... WHO PAYS!=0A=0ANo coffee as yet so these are the only questions I can come up with at this =0Atime.=0AMaybe you have a few to ask?=0A=0A=0ABarry=0A _ -======================== -======================== ========= =0A ________________________________________________________________________________
Date: Dec 13, 2012
FYI, See -- http://www.nj.com/mercer/index.ssf/2012/12/three_mercer_county_gas_statio.html for the full story. Looks like Jet Fuel. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Dec 13, 2012, at 8:19 AM, FLYaDIVE wrote: Gang: I was just informed of an article in the NEWARK STAR LEDGER (NEWARK, NJ NEWSPAPER), Page 21. Gas Stations being shut down because they are selling AVIATION GAS!!! Too bad I did not know which station were selling it... I would have loaded up! Especially at $3.60 a Gallon. <-- High Test. Maybe it was in the REGULAR Pumps at $3.26 a Gallon??? But, the questions have to be asked: 1 - If there is so much control over AvGas <--- So they say as to keep prices high. Where was the control on the delivery? 2 - Was AvGAs put into uncontrolled MoGas delivery vehicles? 3 - Was MoGas put into uncontrolled AvGas delivery vehicles? 4 - Have the Controlled Delivery Vehicles now been contaminated with MoGas? 5 - OMG ! ! ! ... What will our Ever Vigilant EPA do now that LEAD is being burned by surface vehicles? And... 6 - Who picks up the $TAB$ on the destroyed Catalytic Converters. <--- NJ in all their wisdom has done away with automobile inspection. Except for EMISSIONS TESTING. So, if your car fails and you don't even know you had a load of AvGas who pays for the repairs??? AND even if you do know... WHO PAYS! No coffee as yet so these are the only questions I can come up with at this time. Maybe you have a few to ask? Barry ________________________________________________________________________________
From: "Clive Richards" <s.clive.richards(at)homecall.co.uk>
Subject: Re: Rotax 914 Right Mag rough
Date: Dec 13, 2012
Alan If you go to www.conairsports.co.uk web site you can find link to download their good article on the Rotax plus installation & on line maintenance manuals for free. They also sell a soft start module to delay firing to retro fit to the Ducati ignition modules if required. If you have a recent engine according to the manual the soft start is built in to use but will requires connecting. I have no experience of running a Rotax as yet as plane build is not completed and the engine is not new, a previous owner suggested the soft start module would be a good idea. Be aware that each ignition module fires 2 plugs at the same time one on compression stroke before TDC & the other I presume on exhaust stroke on another cylinder. Regards Clive ----- Original Message ----- From: "Alan Carter" <alancarteresq(at)onetel.net> Sent: Tuesday, December 11, 2012 9:53 PM Subject: RotaxEngines-List: Rotax 914 Right Mag rough > > > Hello All. > Rotax 914 engine, > Aircraft in the SE England, temp about +3 first flight for about 6 weeks. > Fuel Mogas, Full Charged Battery, Engine Gurgled,Full Choke on Start. > I had difficulty in starting the engine, it took a long time before it > fired and when it did i had ?? Detonation or Pre ignition not sure which > term would suit > but the engine fire to soon and pushed the piston down before it passed > over TDC causing sudden stopping ,or Prop flickering to too and throw, not > good. > Is there a way to stop this happening , or control settings to use for > cold starts., the plane has a tendency to do this. > I have a second problem, on the Right Mag i get a drop and it goes into > rough running misfiring banging, From memory i can,t remember if its the > top or bottom plugs on the Right Key Position, but all the plugs changed > about 25 or 30 hours ago. > Another Question with regards to the Coils, 4 of them. > Are they all the same, ie, no timings involved can use any other one, > Its just a Coil ?? is that correct. > With regards to the Fuel Mogas, thinking of trying Mogas Super (UK) spec. > > Regards > Alan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=390302#390302 > > > ________________________________________________________________________________
From: "Joe & Jan Connell" <jconnell(at)fmwildblue.com>
Date: Dec 13, 2012
Interesting reading in current issue of Sport Aviation. See link below: http://www.sportaviationonline.org/sportaviation/201212#pg28 It sites CHT responds to EGT in regards to fuel burn and rpm (especially totally air-cooled engines). Your heads have oil cooling to help. Any major changes in outside air temps? Where are you located? Joe Connell Kitfox II N95JJ Subject: RotaxEngines-List: EGT Indications From: "Troy Maynor" <wingnut54(at)charter.net> Hi All, I have a 912S and recently have noticed a trend of higher exhaust gas temps on the rear two cylinders. I know that CHT will read higher on the two rear cylinders but not sure if that same reason would apply to EGT as well. The temps are just 20 to 30 degrees below max. About to take off the cowlings and start my annual and wanted to hear some thoughts on this subject from you all. Thanks. Troy Maynor Europa Monowheel Classic 195 hours 912S ________________________________________________________________________________
Date: Dec 13, 2012
Hi Clive. How can a Ducati ignition system cost as much as the bike, these parts are well over priced at a guess i would say to replace the system would set you back about 3000. I have been told to try starting on one mag, but my switch goes through L&R before start, to do this i would nee to ground out one of the mags temporally, but not sure how to do this,? Yes i have been to the Web site you mentioned. I knew about the double spark, and as you guess its on the exhaust stroke of another cylinder, but don,t know the reason why this is done,?? I also have heard of cars with double sparks not sure if this is the same or means a double spark on the combustion stroke,? Anybody. Regards Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390407#390407 ________________________________________________________________________________
Date: Dec 13, 2012
Hi Y'all, I can't speak to the costs involved in the various bits and pieces of the engine other than to say that they do seem pricey. Clive, to start on one mag, you would have to install a single pole-single-throw switch (like this one, the S700-1-2 ON-OFF, from B & C http://www.bandc.biz/toggleswitch-singlepole.aspx ) to ground one of the ignition modules. Each module has the equivalent of a "P-Lead" on a magneto system. This wire, when grounded, shuts off the ignition module, just like grounding the P-Lead shuts off a magneto. The switch would have to be installed in parallel with one of those wires to provide an alternate ground. Not difficult, just a bit of a PITA. See the Rotax 914 Installation Manual, Sections 19.4.3 & 19.4.4 for more information. The reason for using a "wasted spark" system is simplicity. In the flat 4 with 180 crank throws there are two pistons at TDC every 180. One on the compression stroke and one on the exhaust stroke. At the same time there are two pistons at BDC. That makes it easy to just fire the plugs every 180 in the two pistons going to TDC. This is done with two tabs, 180 apart, on the flywheel. Every half rev a tab goes through the trigger coil firing the two cylinders where the pistons are heading for TDC. Super simple, easy to do & firing the plug on the exhaust stroke doesn't hurt anything. To try and fire each cylinder individually, would add a lot of mechanical and electrical complexity that's just not needed. I hope this helps. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Dec 13, 2012, at 2:25 PM, Alan Carter wrote: Hi Clive. How can a Ducati ignition system cost as much as the bike, these parts are well over priced at a guess i would say to replace the system would set you back about 3000. I have been told to try starting on one mag, but my switch goes through L&R before start, to do this i would nee to ground out one of the mags temporally, but not sure how to do this,? Yes i have been to the Web site you mentioned. I knew about the double spark, and as you guess its on the exhaust stroke of another cylinder, but don,t know the reason why this is done,?? I also have heard of cars with double sparks not sure if this is the same or means a double spark on the combustion stroke,? Anybody. Regards Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390407#390407 ________________________________________________________________________________
Date: Dec 13, 2012
Alan: If you have the standard (Usually a BENDIX) OFF - Right - Left - START switch it automatically grounds the RIGHT Mag during START. That is because the Left Mag is an Impulse Mag. And you do not want to create a KICKBACK situation with the Right Mag. During STARTING the Right & Left mags have a timing difference. We are talking Lycoming & Continental type engines. Barry On Thu, Dec 13, 2012 at 3:25 PM, Alan Carter wrot e: > alancarteresq(at)onetel.net> > > Hi Clive. > How can a Ducati ignition system cost as much as the bike, these parts ar e > well over priced at a guess i would say to replace the system would set y ou > back about =A33000. > > I have been told to try starting on one mag, but my switch goes through > L&R before start, to do this i would nee to ground out one of the mags > temporally, but not sure how to do this,? > > Yes i have been to the Web site you mentioned. > I knew about the double spark, and as you guess its on the exhaust stroke > of another cylinder, but don,t know the reason why this is done,?? > > I also have heard of cars with double sparks not sure if this is the same > or means a double spark on the combustion stroke,? > > Anybody. > Regards > Alan > > ________________________________________________________________________________
Date: Dec 13, 2012
Alan Discription of ACS & Bendix switch connections as used on most light aircraft. Off Connects (inner GRD) L R Terminals together which are used to earth both magnetos Right Connects (inner GRD) L Terminals together which are used to earth the left magneto Left Connects (inner GRD) R Terminals together which are used to earth the right magneto Both Connect no Terminals together Start Connects BAT S Terminals together for starter solenoid and (inner GRD) (outer GRD) Terminals together which are used to earth right magneto if required by fitting a link between R & (outer GRD) terminals and BO LR L Terminals together not used in the circuit I have In the circuit that I have used for a continental 0-200 a negative feed is connected to BAT , the starter solonid to S. the Magneto screens which are earthed at the magneto end are connected to the (inner GRD) terminal the The Right magneto is connected to R The left magneto is connected to L And There is a link on the switch connecting R To the adjacent (outer) GRD terminal. Why two seperate terminals are marked GRD I have no idea. As both magnetos have impulse couplings I since removed (outer GRD) R link. By firing two plugs with each rotation of the engine one pickup coil can be used to fire two cylinders & removes the need for a distributor. hope this helps Clive ----- Original Message ----- From: "Alan Carter" <alancarteresq(at)onetel.net> Sent: Tuesday, December 11, 2012 9:53 PM Subject: RotaxEngines-List: Rotax 914 Right Mag rough > > > Hello All. > Rotax 914 engine, >> Regards > Alan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=390302#390302 > > > ________________________________________________________________________________
Date: Dec 13, 2012
Hello All. Its getting a bit complicated for me, but as far as i can make out, the coils fire two plugs at a time, every 180% of the fly wheel, its a dual ignition system but to keep it simple look at it as a single ignition system, so the distributor is disposed of due to the dual sparks, So as two pistons are coming up there barrels one on compression and one one exhaust both plugs spark, then this same happens again as the other two come up there barrels in turn. So to stop kick back , spin the engine faster or make the spark occur later , preferably after TDC. Is that roughly correct Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390415#390415 ________________________________________________________________________________
Date: Dec 13, 2012
Hi Again. Would warming the engine for 15 minutes with a couple of Hair driers blowing hot air into the cowling help.?? Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390417#390417 ________________________________________________________________________________
Date: Dec 13, 2012
Alan, You got it! And Super or Super Plus Mogas. From the Rotax 914 Operators Manual: Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Dec 13, 2012, at 5:07 PM, Alan Carter wrote: Hello All. Its getting a bit complicated for me, but as far as i can make out, the coils fire two plugs at a time, every 180% of the fly wheel, its a dual ignition system but to keep it simple look at it as a single ignition system, so the distributor is disposed of due to the dual sparks, So as two pistons are coming up there barrels one on compression and one one exhaust both plugs spark, then this same happens again as the other two come up there barrels in turn. So to stop kick back , spin the engine faster or make the spark occur later , preferably after TDC. Is that roughly correct Alan ________________________________________________________________________________
Date: Dec 14, 2012
From: "peter.rees01(at)tiscali.co.uk" <peter.rees01(at)tiscali.co.uk>
I think that some of the europa owners who live in properly cold countries do tricks like this (or a heat pad on a timer). P ----Original Message---- From: alancarteresq(at)onetel.net Date: 13/12/2012 23:23 Subj: RotaxEngines-List: Re: Rotax 914 Right Mag rough Hi Again. Would warming the engine for 15 minutes with a couple of Hair driers blowing hot air into the cowling help.?? Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390417#390417 Bookstore www.buildersbooks.com ________________________________________________________________________________
Date: Dec 14, 2012
Alan That appears to be correct the module from Conair will provide the delay you require at a price on one ignition module. & you will need to start on this one only. If you have the ignition switch I described you can achieve this by fitting the link R to outer GRD terminal R will be the non delayed ignition & you will start on the left. I noticed an ERROR in my description the feed to BAT terminal should read positive as negative is earth . If you have the later Rotax modules you just need to provide a feed from the start switch wires 26 on schematic in manual. to provide the delay on both. Pre heating the engine in cold weather is a good idea if you can achieve this. All the best Clive ----- Original Message ----- From: "Alan Carter" <alancarteresq(at)onetel.net> Sent: Thursday, December 13, 2012 11:07 PM Subject: RotaxEngines-List: Re: Rotax 914 Right Mag rough > > > Hello All. > Its getting a bit complicated for me, but as far as i can make out, the > coils fire two plugs at a time, every 180% of the fly wheel, its a dual > ignition system but to keep it simple look at it as a single ignition > system, so the distributor is disposed of due to the dual sparks, So as > two pistons are coming up there barrels one on compression and one one > exhaust both plugs spark, then this same happens again as the other two > come up there barrels in turn. > So to stop kick back , spin the engine faster or make the spark occur > later , > preferably after TDC. > > Is that roughly correct > > Alan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=390415#390415 > > > ________________________________________________________________________________
Date: Dec 14, 2012
Alan Roger has a good point about fuel. Also if you are using garage fuel it will not keep very long so use immediately, I suggest you use 91UL if you can get it as this is Avgas without the lead and will keep much longer. ----- Original Message ----- From: Robert Borger To: rotaxengines-list(at)matronics.com Sent: Thursday, December 13, 2012 11:31 PM Subject: Re: RotaxEngines-List: Re: Rotax 914 Right Mag rough Alan, You got it! And Super or Super Plus Mogas. From the Rotax 914 Operators Manual: Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Dec 13, 2012, at 5:07 PM, Alan Carter wrote: Alan ________________________________________________________________________________
Date: Dec 14, 2012
Hi All. Phoned Con Air today the Soft Start Module with the 4 pin connectors is for early engines around the year 2000 like mine, it cost about 140 but you have to be wired in the cockpit to be able to start on one mag. You can also purchase a Rotax kit that consists of 2 modules it retards both ignitions and requires NO cockpit wiring of mags switches, but this kits about 550 probably plus Vat ?? but Will only work with the later 6 pin connections on the later engines. For me, Change Fuel to Super Plus, if no good, then wire for 1 mag start,. if no good, fit Soft Start Module. or wait till summer before i fly. As you can see i would rather berry my head in the sand and hope it would go away. My last job was replacing the battery in the GPS and also wiring the main battery for external charging. I have just looked at the wheel struts why is there no little pad to put a jack under.? Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390436#390436 ________________________________________________________________________________
Date: Dec 14, 2012
Hi Alan, Good plan. I need to install some sort of external charging capability too. And I'm with you on the jack pad issue! Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Dec 14, 2012, at 6:35 AM, Alan Carter wrote: Hi All. Phoned Con Air today the Soft Start Module with the 4 pin connectors is for early engines around the year 2000 like mine, it cost about 140 but you have to be wired in the cockpit to be able to start on one mag. You can also purchase a Rotax kit that consists of 2 modules it retards both ignitions and requires NO cockpit wiring of mags switches, but this kits about 550 probably plus Vat ?? but Will only work with the later 6 pin connections on the later engines. For me, Change Fuel to Super Plus, if no good, then wire for 1 mag start,. if no good, fit Soft Start Module. or wait till summer before i fly. As you can see i would rather berry my head in the sand and hope it would go away. My last job was replacing the battery in the GPS and also wiring the main battery for external charging. I have just looked at the wheel struts why is there no little pad to put a jack under.? Alan ________________________________________________________________________________
Date: Dec 14, 2012
Alan, Just a word of caution on fuels. In the UK Super-Plus unleaded is generally refined to meet a standard BS 7800, not EN228. The only Mogas fuel currently approved by CAA and LAA is that refined to EN228, and without ethanol. The reason that the Super-Plus unleaded fuels are not approved is that the vapour pressure of the blend is very high compared with EN228 Mogas or Avgas. This could lead to an increased risk of vapour locking in flight. Regards Brian Davies From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Robert Borger Sent: 13 December 2012 23:32 Subject: Re: RotaxEngines-List: Re: Rotax 914 Right Mag rough Alan, You got it! And Super or Super Plus Mogas. From the Rotax 914 Operators Manual: Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Dec 13, 2012, at 5:07 PM, Alan Carter wrote: Hello All. Its getting a bit complicated for me, but as far as i can make out, the coils fire two plugs at a time, every 180% of the fly wheel, its a dual ignition system but to keep it simple look at it as a single ignition system, so the distributor is disposed of due to the dual sparks, So as two pistons are coming up there barrels one on compression and one one exhaust both plugs spark, then this same happens again as the other two come up there barrels in turn. So to stop kick back , spin the engine faster or make the spark occur later , preferably after TDC. Is that roughly correct Alan No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Dec 14, 2012
Hi Bob. In the UK i saw in a motor cycle shop a complete charging unit made by Suzuki, eye washer connectors for the battery and a the other end of the wire a flat plastic plate about 1.1/2"x 1" with a rubber plug covering the connector, guard to cover the terminals. The plate was moulded with a plastic retaining clip on the back, a small rectangle hole would need to be cut for it, and it would self fix into it, either inside the plane or on the skin outside, Suzuki have there own shaped plugs so yo would need to buy the whole lot including the maintenance charger. It looked a neat job. I leave my charging lead dangling out of the small air vent at the front side of the cockpit. .I,m just going to plug in and blow the tyers up, as one is a bit low. The Suzuki,s Plate would be neater. How the hell do i change a tyre if i get a flat away from base.? Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390442#390442 ________________________________________________________________________________
Date: Dec 14, 2012
Hi Brian. Thanks for the information, As far as i know Super Plus has no Ethanol in it, ? but will test when i get a test kit as i want to check out EN228 . I will also ask in the Europa list if anyone tests for ethanol ? The vapour locking , don,t know much about this, but more likely in hot weather maybe ?? If its OK with you, No Names mentioned , i will just say a friend posted this to me , can anyone update about the vapour locking, Different country,s have different rules so it may be in regular use. So might get some feed back. Regards Alan From: Brian Davies Sent: Friday, December 14, 2012 1:53 PM Subject: RE: RotaxEngines-List: Re: Rotax 914 Right Mag rough Alan, Just a word of caution on fuels. In the UK Super-Plus unleaded is generally refined to meet a standard BS 7800, not EN228. The only Mogas fuel currently approved by CAA and LAA is that refined to EN228, and without ethanol. The reason that the Super-Plus unleaded fuels are not approved is that the vapour pressure of the blend is very high compared with EN228 Mogas or Avgas. This could lead to an increased risk of vapour locking in flight. Regards Brian Davies From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Robert Borger Sent: 13 December 2012 23:32 Subject: Re: RotaxEngines-List: Re: Rotax 914 Right Mag rough Alan, You got it! And Super or Super Plus Mogas. From the Rotax 914 Operators Manual: Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Dec 13, 2012, at 5:07 PM, Alan Carter wrote: Hello All. Its getting a bit complicated for me, but as far as i can make out, the coils fire two plugs at a time, every 180% of the fly wheel, its a dual ignition system but to keep it simple look at it as a single ignition system, so the distributor is disposed of due to the dual sparks, So as two pistons are coming up there barrels one on compression and one one exhaust both plugs spark, then this same happens again as the other two come up there barrels in turn. So to stop kick back , spin the engine faster or make the spark occur later , preferably after TDC. Is that roughly correct Alan No virus found in this message. Checked by AVG - www.avg.com Version: 2013.0.2805 / 12/14/12 ________________________________________________________________________________
Date: Dec 14, 2012
Hi Alan, I need to put something like that charging plug together for my battery. I'll contact the folks who make my charger to see if they have or can come up with such. The way I remove/replace a tire is with a suitably sized saw horse with a well padded top. I get under the wing and lift with my legs, my back supporting the wing. Then I pull the saw horse (I don't know what you Brits call it, but I'll provide a picture if you need) under the wing and let the wing down on the padding. If all is properly sized, the sawhorse will support the wing with the wheel just off the ground. It's a heck of a lot easier and better if you have someone else to help, but if this old fart can accomplish it alone almost anyone who doesn't have a bad back should be able to do it. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Dec 14, 2012, at 8:09 AM, Alan Carter wrote: Hi Bob. In the UK i saw in a motor cycle shop a complete charging unit made by Suzuki, eye washer connectors for the battery and a the other end of the wire a flat plastic plate about 1.1/2"x 1" with a rubber plug covering the connector, guard to cover the terminals. The plate was moulded with a plastic retaining clip on the back, a small rectangle hole would need to be cut for it, and it would self fix into it, either inside the plane or on the skin outside, Suzuki have there own shaped plugs so yo would need to buy the whole lot including the maintenance charger. It looked a neat job. I leave my charging lead dangling out of the small air vent at the front side of the cockpit. .I,m just going to plug in and blow the tyers up, as one is a bit low. The Suzuki,s Plate would be neater. How the hell do i change a tyre if i get a flat away from base.? Alan ________________________________________________________________________________
Date: Dec 14, 2012
Hi Bob "Don,t know what the Brits call it", There,s only me, and i call it a saw horse. I can even make one. Advanced C&Gs in Carpentry and Joinery many years ago. Going back to Fuel, A friend mail me with this. In the UK Super-Plus unleaded is generally refined to meet a standard BS 7800, not EN228. The only Mogas fuel currently approved by CAA and LAA is that refined to EN228, and without ethanol. The reason that the Super-Plus unleaded fuels are not approved is that the vapour pressure of the blend is very high compared with EN228 Mogas or Avgas. This could lead to an increased risk of vapour locking in flight. I think there is no ethanol in Super Plus , but don,t know much about vapour locking, would have thought only in summer temps, but does anybody use Super Plus fuel, or can give some input on this subject as the fuel is approved by Rotax. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390445#390445 ________________________________________________________________________________
Date: Dec 15, 2012
Regarding portable jack for tire(tyre) changing, I built something simple and lightweight for my Kolb Slingshot which has an axle that extends inboard from the axle fitting. Your airplane may have a different setup and might require a different connection, but the principle is the same. A block with an axle and two wheels, plus a removable handle for leverage. The over-center characteristic is the key. Note in the short YouTube video I made that I put the wedge (cut from the top, under the raised end to keep it from falling if the airplane is accidentally pushed when on the jack. http://www.youtube.com/watch?v=4ars22PxPjE&list=UUXuIm2BjpicnSovZDhKc06w&index=8 or http://tinyurl.com/bmkps9g The prototype shown in this video was made of simple pine board. It broke in time, so it should be made of hardwood or other stronger material for durability. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 no engine FOR SALE Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390475#390475 ________________________________________________________________________________
Date: Dec 15, 2012
Very Nice Thom.... Sweet & Simple Barry On Sat, Dec 15, 2012 at 8:59 AM, Thom Riddle wrote: > > > > Regarding portable jack for tire(tyre) changing, I built something simple > and lightweight for my Kolb Slingshot which has an axle that extends > inboard from the axle fitting. Your airplane may have a different setup and > might require a different connection, but the principle is the same. > > A block with an axle and two wheels, plus a removable handle for leverage. > The over-center characteristic is the key. Note in the short YouTube video > I made that I put the wedge (cut from the top, under the raised end to keep > it from falling if the airplane is accidentally pushed when on the jack. > > > http://www.youtube.com/watch?v=4ars22PxPjE&list=UUXuIm2BjpicnSovZDhKc06w&index=8 > > or > > http://tinyurl.com/bmkps9g > > The prototype shown in this video was made of simple pine board. It broke > in time, so it should be made of hardwood or other stronger material for > durability. > > -------- > Thom Riddle > Buffalo, NY (9G0) > > Kolb Slingshot SS-021 > no engine > FOR SALE > > Diamond Katana DA20-A1 > Rotax 912 F3 > > Don't worry about old age... it doesn't last very long. > - Anonymous > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=390475#390475 > > ________________________________________________________________________________
Date: Dec 15, 2012
Thom that is a great idea. I am going to make one myself. Regards, Damien Sent from my iPad On Dec 15, 2012, at 9:55 AM, FLYaDIVE wrote: > Very Nice Thom.... > > Sweet & Simple > > Barry > > On Sat, Dec 15, 2012 at 8:59 AM, Thom Riddle wrote: m> >> >> Regarding portable jack for tire(tyre) changing, I built something simple and lightweight for my Kolb Slingshot which has an axle that extends inboar d from the axle fitting. Your airplane may have a different setup and might r equire a different connection, but the principle is the same. >> >> A block with an axle and two wheels, plus a removable handle for leverage . The over-center characteristic is the key. Note in the short YouTube video I made that I put the wedge (cut from the top, under the raised end to keep it from falling if the airplane is accidentally pushed when on the jack. >> >> http://www.youtube.com/watch?v=4ars22PxPjE&list=UUXuIm2BjpicnSovZDhKc 06w&index=8 >> >> or >> >> http://tinyurl.com/bmkps9g >> >> The prototype shown in this video was made of simple pine board. It broke in time, so it should be made of hardwood or other stronger material for du rability. >> >> -------- >> Thom Riddle >> Buffalo, NY (9G0) >> >> Kolb Slingshot SS-021 >> no engine >> FOR SALE >> >> Diamond Katana DA20-A1 >> Rotax 912 F3 >> >> Don't worry about old age... it doesn't last very long. >> - Anonymous >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=390475#390475 >> >> >> >> >> >> >> >> ========== >> ="_blank">www.aeroelectric.com >> ooks.com" target="_blank">www.buildersbooks.com >> et="_blank">www.homebuilthelp.com >> ="_blank">http://www.matronics.com/contribution >> le, List Admin. >> ========== >> -List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines- List >> ========== >> http://forums.matronics.com >> ========== >> >> >> > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Dec 15, 2012
If you make one and want to be able to use it on soft ground, take a small piece of plywood with you for the over-center jack to sit/work on. Otherwise it will just sink into soft surface. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 no engine FOR SALE Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390485#390485 ________________________________________________________________________________
Subject: OFF>L>R>Both>Start
Date: Dec 15, 2012
Hello ALL First off all its a Rotax 914 ignition system. The" Mag Key Switch" is OFF>L>R>Both>Start. There are 4 Mag Coils each having two HT leads going to the plugs. The 4 Mag Coil Units are mounted all together on a bracket attached to the engine. As far as i can make out, the: TOP 2 Mag Coil Units go to the TOP Plugs. BOTTOM 2 Mag Coil Units go to the BOTTOM Plugs. Again as far as i can make out from the"Cockpit Mag Switch", Key at (L) goes to the TOP Coils and TOP Plugs and with the Key at (R) goes to the BOTTOM Coils,and BOTTOM Plugs. Are you keeping up with this ! or am i confusing myself. With the Key in position (L) which Two Coils Units are Working, ie Live and (sparking) going to which plugs.? Which Mag Drop am i Checking.? I would say i am Checking the Left Mag which is the Top Coils Units going to the Top plugs, and the Mag Drop i see is due to the Right Mag being off line. But Hay,With the key at (L) Am i Grounding out the (Left) mag, so its the other one,??which is live ? ie the (Right) mag that is working ??and i am seeing how good it is. Confusing , Sometimes things are not what they seem to be. So which is it you Petrol Heads. Requards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390504#390504 ________________________________________________________________________________
Date: Dec 16, 2012
Subject: Re: OFF>L>R>Both>Start
Alan: It is very simple. Don't overload yourself with too much info. OFF = BOTH MAGs are Grounded. L = Left = Left MAG is HOT -and Right MAG is Grounded. R = Right = Right MAG is HOT - and Left MAG is Grounded. BOTH = BOTH MAGS are HOT. NO MAGs are Grounded. START = START the engine by Grounding the Right MAG and Turning ON the Starter Motor. The rule to remember is: MAGs are ALWAYS HOT. The only way of removing a MAG from the system is to GROUND out the output of the MAG... To electrical Ground. NOW, of course I have to confuse things here just a bit. I have to ask you and the gaggle a couple of questions: Does Rotax use an IMPULSE Coupler on one MAG? Or... Does Rotax use TWO IMPULSE Copuler's - One on each MAG? I'll explain my question later. Barry On Sat, Dec 15, 2012 at 9:22 PM, Alan Carter wrote: > alancarteresq(at)onetel.net> > > Hello ALL > First off all its a Rotax 914 ignition system. > The" Mag Key Switch" is OFF>L>R>Both>Start. > There are 4 Mag Coils each having two HT leads going to the plugs. > The 4 Mag Coil Units are mounted all together on a bracket attached to the > engine. > As far as i can make out, the: > TOP 2 Mag Coil Units go to the TOP Plugs. > BOTTOM 2 Mag Coil Units go to the BOTTOM Plugs. > > Again as far as i can make out from the"Cockpit Mag Switch", Key at (L) > goes to the TOP Coils and TOP Plugs and with the Key at (R) goes to the > BOTTOM Coils,and BOTTOM Plugs. > Are you keeping up with this ! or am i confusing myself. > > With the Key in position (L) which Two Coils Units are Working, ie Live > and (sparking) going to which plugs.? > > Which Mag Drop am i Checking.? > > I would say i am Checking the Left Mag which is the Top Coils Units going > to the Top plugs, and the Mag Drop i see is due to the Right Mag being off > line. > > But Hay,With the key at (L) Am i Grounding out the (Left) mag, so its the > other one,??which is live ? ie the (Right) mag that is working ??and i am > seeing how good it is. > > Confusing , Sometimes things are not what they seem to be. > > So which is it you Petrol Heads. > Requards. > Alan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=390504#390504 > > ________________________________________________________________________________
From: "Duncan & Ami" <ami-mcfadyean(at)talktalk.net>
Date: Dec 16, 2012
<<.... or wait till summer before i fly.>> Or stick a hairdrier under the cowl for 20 minutes prior to start up. This works for me, even when the engine has been cold soaked at -3C. Duncan McF. -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Alan Carter Sent: 14 December 2012 12:36 Subject: RotaxEngines-List: Re: Rotax 914 Right Mag rough --> Hi All. Phoned Con Air today the Soft Start Module with the 4 pin connectors is for early engines around the year 2000 like mine, it cost about 140 but you have to be wired in the cockpit to be able to start on one mag. You can also purchase a Rotax kit that consists of 2 modules it retards both ignitions and requires NO cockpit wiring of mags switches, but this kits about 550 probably plus Vat ?? but Will only work with the later 6 pin connections on the later engines. For me, Change Fuel to Super Plus, if no good, then wire for 1 mag start,. if no good, fit Soft Start Module. or wait till summer before i fly. As you can see i would rather berry my head in the sand and hope it would go away. My last job was replacing the battery in the GPS and also wiring the main battery for external charging. I have just looked at the wheel struts why is there no little pad to put a jack under.? Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390436#390436 ________________________________________________________________________________
Date: Dec 16, 2012
Hello Barry. Many thanks, So far so good all makes sense. With regards to: Does Rotax use an IMPULSE Coupler on one MAG? Or... Does Rotax use TWO IMPULSE Copuler's - One on each MAG? I'll explain my question later. I have no idea : But the 914 engine is year 2000, and has 4 pin connectors. I replaced a coil some time ago, but can,t remember how i traced the faulty one, except i swapped them around, go really fed up and decided if i every have to do this job again i will know where every lead goes. So on every HT cable i placed coloured cable tie,s . (Red being Port side, ie Left and Green Being Starboard side, ie Right. ie (as in Nav lights) So all my Left mag HT leads are Red, going to the top set of coils marked with Red stickers. And all my Right mag HT leads are Green,going to the Bottom set of coils which you,v guessed it has Green stickers on them. And on my Rotary Mag Switch in the cockpit i have a little sticker L >Red and R>Green . So when i do my mag check i say to myself. L =Port which is Red markers and its the 2 Red Coils with its 4 Red Leads which are the Top Plugs that i am checking. And you have confirmed position L = live. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390514#390514 ________________________________________________________________________________
Date: Dec 16, 2012
Barry, You are absolutely correct for a magneto based system. Rotax does not use magnetos. Rotax uses a CDI (Capacitive Discharge Ignition) system, a type of electronic ignition that does not require a separate power source. Like a mag, the ignition module is grounded to prevent it from firing. Your explanation is, again, correct for the Rotax if you substitute "ignition module" for "MAG." Where it falls apart is when you went to "Impulse Coupler." Because it's not a mag, there are no impulse couplers. The Rotax CDI system is triggered by a pair of tabs on the flywheel. Below ~800 RPM the system triggers on the trailing edge of the tab (4=BABTDC or 3=BAATDC depending on the age of the system). Once the engine starts, >800 RPM, the system triggers on the leading edge of the tab. Most Rotax folks use the term "MAG" for simplicity sake, because that's what most folks are familiar with. Kind of like the "Choke" which isn't really a choke, it's a separate little carb which is activated to provide a richer mixture on startup. Same function as the choke on a "normal" engine, just a different physical implementation. Alan, The only sure way to determine which module is grounded when your key is in any specific position is by making a continuity check from the back of the key to the grounding lead on each ignition module. Or, I guess you could put the key in a position and see which of your grounding leads has continuity to ground, that is, which is grounded. Your older system uses 4 modules, my system is just enough newer (2002) to use only two modules, labeled A & B. So, I guess I should really have my two grounding switches labeled A & B rather than L & R. And on the 914. one module fires the upper and the other module the lower plugs. On the 912 & 912S, a module fires the upper on one side and lower on the other. The Rotax 9xx engines aren't your daddy's Lycoming/Continental. Twin carbs, CDI, gearbox and most happy when turning over 5000 RPM while burning 4 - 5 gph. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Dec 16, 2012, at 12:34 AM, FLYaDIVE wrote: Alan: It is very simple. Don't overload yourself with too much info. OFF = BOTH MAGs are Grounded. L = Left = Left MAG is HOT -and Right MAG is Grounded. R = Right = Right MAG is HOT - and Left MAG is Grounded. BOTH = BOTH MAGS are HOT. NO MAGs are Grounded. START = START the engine by Grounding the Right MAG and Turning ON the Starter Motor. The rule to remember is: MAGs are ALWAYS HOT. The only way of removing a MAG from the system is to GROUND out the output of the MAG... To electrical Ground. NOW, of course I have to confuse things here just a bit. I have to ask you and the gaggle a couple of questions: Does Rotax use an IMPULSE Coupler on one MAG? Or... Does Rotax use TWO IMPULSE Copuler's - One on each MAG? I'll explain my question later. Barry ________________________________________________________________________________
Date: Dec 16, 2012
Hi Barry ,Bob. Barry i like your description, Ground and live, and Bob i follow what you are saying as in my younger days the old Cessna 150 had a impulse mag, and that was the left one, and as far as i can remember with the key at start it started on the left impulse mag only. You mention A&B modules, My system Has A&B ignition from the "two flat electronic ignition modules" located laying over the the 4 coil units. To find the Continuity grounding ete, to check which is left and right. I think you said on the 914 ignition "A" fires the Top Plugs, so provided the person that built my Europa connected the mag wire the correct way round ie Ignition A to the Left key position i think i have it colour labeled up correct So when i do my mag check i say to myself. L =(Port which is my Red marked system) electronic ignition module "A" plus the 2 Upper Red marked Coils, plus the 4 Red marked HT Leads which are going to the Top Plugs. To check this out i need to continuity ground the mags , I will have to do it the incorrect way and take a chance, Start the engine with all the Top leads off, and turn the key to the (L) if it stops it means L = top plugs, confirming all is correct as i have marked. Which is what i would be hoping and think this will be the case. Alan Continued :: Part 2 I want a separate starter press button switch. So the plan is to find on the back of my rotary ignition switch the + power live lead and its return lead to the starter solenoid. Extend these two wires so they reach the new push to start switch which will be mounted about 10" away fro the mag switch. Leave all the mag leads intact on the rotary switch , so now i can still key select individual mags, The end goal will be to fitt the Soft start module. This is a photo of the Rotax Switch http://www.ekmpowershop2.com/ekmps/shops/conairsports/conair-soft-start-module-ssm-735-p.asp It has 3 terminals, ?? Alan . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390536#390536 ________________________________________________________________________________
Date: Dec 16, 2012
Alan, Do not operate the engine with any spark plug wires removed. Never pull a spark plug wire when the engine is running. Don't turn over the engine with a spark plug wire removed to look for a spark. You will destroy the module to which the plug is connected. That spark energy has to go somewhere and if you don't put it in a plug it is dumped in the module and can fry the module. Very expensive test method to ensure you kill a module. Locate the proper grounding lead on each module and check for continuity to the switch. Or, put the switch on, say, Left, this would ground the "Right" mag (ignition module) then see which module has the grounding lead continuity to ground. If it is wired as per the installation guide, only one will show continuity to ground. That will tell you which module (A or B) is wired to left or right. Then you can disconnect the battery ground wire, put the switch in start and see if either ignition module is grounded for a single module start. If you find one is grounded for start, you can put the soft start module on the other module and go straight with your ignition switch setup. If it is not grounding either module, then you will have to install a separate grounding switch for one module and put the soft start on the other module. Part 2: Not a bad idea. But you might consider going the full route and dump the rotary ignition switch all together and go with separate grounding switches for each module and a separate push button or spring loaded toggle starter switch. With the push button starter switch, this is my set up. There are even ways you can do this with two toggle switches, rather than three. One switch is a simple SPST to ground one ignition. The other is a DPTT (Double Pole Triple Throw) switch with positions: closed (grounding a module), open (ungrounding), closed (voltage to starter solenoid) which is spring loaded to the center. { http://www.bandc.biz/toggleswitch-doublepole.aspx S700-2-5 (ON)-OFF-ON }. I think Bob Nuckolls has a couple Z diagrams which show the use of this switch. If not, I can show you how to wire it and can provide pictures and confirmation tests as to switch positions and continuities. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Dec 16, 2012, at 12:27 PM, Alan Carter wrote: Hi Barry ,Bob. Barry i like your description, Ground and live, and Bob i follow what you are saying as in my younger days the old Cessna 150 had a impulse mag, and that was the left one, and as far as i can remember with the key at start it started on the left impulse mag only. You mention A&B modules, My system Has A&B ignition from the "two flat electronic ignition modules" located laying over the the 4 coil units. To find the Continuity grounding ete, to check which is left and right. I think you said on the 914 ignition "A" fires the Top Plugs, so provided the person that built my Europa connected the mag wire the correct way round ie Ignition A to the Left key position i think i have it colour labeled up correct So when i do my mag check i say to myself. L =(Port which is my Red marked system) electronic ignition module "A" plus the 2 Upper Red marked Coils, plus the 4 Red marked HT Leads which are going to the Top Plugs. To check this out i need to continuity ground the mags , I will have to do it the incorrect way and take a chance, Start the engine with all the Top leads off, and turn the key to the (L) if it stops it means L = top plugs, confirming all is correct as i have marked. Which is what i would be hoping and think this will be the case. Alan Continued :: Part 2 I want a separate starter press button switch. So the plan is to find on the back of my rotary ignition switch the + power live lead and its return lead to the starter solenoid. Extend these two wires so they reach the new push to start switch which will be mounted about 10" away fro the mag switch. Leave all the mag leads intact on the rotary switch , so now i can still key select individual mags, The end goal will be to fitt the Soft start module. This is a photo of the Rotax Switch http://www.ekmpowershop2.com/ekmps/shops/conairsports/conair-soft-start-module-ssm-735-p.asp It has 3 terminals, ?? Alan ________________________________________________________________________________
Date: Dec 16, 2012
Subject: Re: Rotax 914 Right Mag Rough
PLEASE don't make something complicated out of something simple. To change a wheel or whatever on a Zenair Zodiac, simply get your shoulders under the spar and lift the wheel off the ground. My 70-year-old-legs are plenty strong enough. (Further outboard gives you a mechanical advantage. You are lifting less than 200 pounds.) Support it with some cardboard boxes or whatever is handy. Make sure the support is under the spar. A blanket or coat or whatever over the support is probably a good idea. This is simple, it is quick, it is portable, it is foolproof (even by me!). Take 10 seconds to try it before making a (complicated) jack. [Perhaps other aircraft are much heavier than a Zodiac???] John Goodings, C-FGPJ, CH601HD Zodiac with R912S, Carp/Ottawa/Toronto ________________________________________________________________________________
Date: Dec 16, 2012
Hi Bob. OK will not try it. will re read all. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390554#390554 ________________________________________________________________________________
Date: Dec 17, 2012
John Goodings, Following was the original question about tyre changing: How the hell do i change a tyre if i get a flat away from base.? Your self lift procedure is fine for getting the tyre/tire off the ground. Do you carry large carboard boxes around with you when you fly? How about a saw horse or other bulky object on which you can support the wing you lift way out away from the wheel? -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 no engine FOR SALE Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=390597#390597 ________________________________________________________________________________
Date: Dec 17, 2012
Robert: THANK YOU for explaining the system. AND it is a CDI System... That is way better than a MAG. Thanks Robert, Barry On Sun, Dec 16, 2012 at 8:04 AM, Robert Borger wrote: > Barry, > > You are absolutely correct for a magneto based system. Rotax does not us e > magnetos. Rotax uses a CDI (Capacitive Discharge Ignition) system, a typ e > of electronic ignition that does not require a separate power source. Li ke > a mag, the ignition module is grounded to prevent it from firing. Your > explanation is, again, correct for the Rotax if you substitute "ignition > module" for "MAG." > > Where it falls apart is when you went to "Impulse Coupler." Because it's > not a mag, there are no impulse couplers. The Rotax CDI system is > triggered by a pair of tabs on the flywheel. Below ~800 RPM the system > triggers on the trailing edge of the tab (4=BABTDC or 3=BAATDC depending on the > age of the system). Once the engine starts, >800 RPM, the system trigger s > on the leading edge of the tab. > > Most Rotax folks use the term "MAG" for simplicity sake, because that's > what most folks are familiar with. > > Kind of like the "Choke" which isn't really a choke, it's a separate > little carb which is activated to provide a richer mixture on startup. > Same function as the choke on a "normal" engine, just a different physic al > implementation. > > Alan, > > The only sure way to determine which module is grounded when your key is > in any specific position is by making a continuity check from the back of > the key to the grounding lead on each ignition module. Or, I guess you > could put the key in a position and see which of your grounding leads has > continuity to ground, that is, which is grounded. Your older system uses 4 > modules, my system is just enough newer (2002) to use only two modules, > labeled A & B. So, I guess I should really have my two grounding switche s > labeled A & B rather than L & R. And on the 914. one module fires the > upper and the other module the lower plugs. On the 912 & 912S, a module > fires the upper on one side and lower on the other. > > The Rotax 9xx engines aren't your daddy's Lycoming/Continental. Twin > carbs, CDI, gearbox and most happy when turning over 5000 RPM while burni ng > 4 - 5 gph. > > Blue skies & tailwinds, > Bob Borger > Europa XS Tri, Rotax 914, Airmaster C/S Prop. > Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP > 3705 Lynchburg Dr. > Corinth, TX 76208-5331 > Cel: 817-992-1117 > rlborger(at)mac.com > > On Dec 16, 2012, at 12:34 AM, FLYaDIVE wrote: > > Alan: > > It is very simple. Don't overload yourself with too much info. > OFF = BOTH MAGs are Grounded. > L = Left = Left MAG is HOT -and Right MAG is Grounded. > R = Right = Right MAG is HOT - and Left MAG is Grounded. > BOTH = BOTH MAGS are HOT. NO MAGs are Grounded. > START = START the engine by Grounding the Right MAG and Turning ON the > Starter Motor. > > The rule to remember is: MAGs are ALWAYS HOT. > The only way of removing a MAG from the system is to GROUND out the outpu t > of the MAG... To electrical Ground. > > NOW, of course I have to confuse things here just a bit. I have to ask > you and the gaggle a couple of questions: > Does Rotax use an IMPULSE Coupler on one MAG? Or... > Does Rotax use TWO IMPULSE Copuler's - One on each MAG? > I'll explain my question later. > > Barry > ________________________________________________________________________________
Date: Dec 17, 2012
Alan I suspect you will find your igintion switch is marked as my discription so BAT terminal is positive from a fuse or circuit breaker & S goes to starter solenoid. The Push button you show will have a common terminal with one of the other terminals will be open to this & the other closed. If your ignition switch is as I described you can as I previously said link the outer ground terminal GRD to R terminal you will then start on the module connected to the L terminal. (It is the inner GRD terminal which is the one actualy connected to ground) As others have stated to check make sure engine cannot start or turn on starter remove plug on lead from the switch at an ignition module check with a multimeter on continuity (Ohms) range that the wire from the switch is connected to ground (engine block) in off position then check in left right both & start positions a modual is live when not connected to ground you can mark left or right as appropriate check which coil pack this moudule is pluged into to see which plugs it fires. Refit plug after testing. Clive ----- Original Message ----- From: "Alan Carter" <alancarteresq(at)onetel.net> Sent: Sunday, December 16, 2012 9:17 PM Subject: RotaxEngines-List: Re: OFF>L>R>Both>Start > > > Hi Bob. > OK will not try it. will re read all. > Alan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=390554#390554 > > > ________________________________________________________________________________
Date: Jan 01, 2013
Subject: Auto-response
Away on holiday from the 22 December 2012 till 29 January 2013 Wishing you a happy festive season . Merry Christmas and a Happy New Year from Viorel ... ________________________________________________________________________________
Subject: Rotax Spark Plugs - 582 - NGK B8ES question
Date: Jan 02, 2013
Hi, I=99m using NGK B8ES spark plugs on my Rotax 582. Does anyone have an equivalent spark plug number for one that does not have the screw-on tip? Thanks guys. Joe Connell Kitfox II / 582 ________________________________________________________________________________
Date: Jan 02, 2013
Subject: Re: Rotax Spark Plugs - 582 - NGK B8ES question
> >Im using NGK B8ES spark plugs on my Rotax 582. Does anyone have an equivalent spark plug number for one that does not have the screw-on tip? yes, NGK does make a "solid top" version of this plug. It's normally not available at your local auto parts store. Often NAPA stores can order it for you. It's NGK part number 3683 http://www.ngksparkplugs.com/pdf/StocktoPart11x17.pdf -- Bob Comperini e-mail: bob@fly-ul.com WWW: http://www.fly-ul.com ________________________________________________________________________________
Subject: Re: RotaxEngines-List Digest: 2 Msgs - 01/02/13
Date: Jan 03, 2013
Thanks Bob. It appears they are also available at ATV and road bike shops. Thanks again, Joe -----Original Message----- From: RotaxEngines-List Digest Server Sent: Thursday, January 03, 2013 2:00 AM Subject: RotaxEngines-List Digest: 2 Msgs - 01/02/13 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RotaxEngines-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RotaxEngines-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-01-02&Archive=RotaxEngines Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 13-01-02&Archive=RotaxEngines =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RotaxEngines-List Digest Archive --- Total Messages Posted Wed 01/02/13: 2 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 07:48 AM - Rotax Spark Plugs - 582 - NGK B8ES question (Joe & Jan Connell) 2. 08:00 AM - Re: Rotax Spark Plugs - 582 - NGK B8ES question (Bob Comperini) ________________________________ Message 1 _____________________________________ From: "Joe & Jan Connell" <jconnell(at)fmwildblue.com> Subject: RotaxEngines-List: Rotax Spark Plugs - 582 - NGK B8ES question Hi, I=99m using NGK B8ES spark plugs on my Rotax 582. Does anyone have an equivalent spark plug number for one that does not have the screw-on tip? Thanks guys. Joe Connell Kitfox II / 582 ________________________________ Message 2 _____________________________________ From: Bob Comperini <bob@fly-ul.com> Subject: Re: RotaxEngines-List: Rotax Spark Plugs - 582 - NGK B8ES question > >Im using NGK B8ES spark plugs on my Rotax 582. Does anyone have an >equivalent spark plug number for one that does not have the screw-on tip? yes, NGK does make a "solid top" version of this plug. It's normally not available at your local auto parts store. Often NAPA stores can order it for you. It's NGK part number 3683 http://www.ngksparkplugs.com/pdf/StocktoPart11x17.pdf -- Bob Comperini e-mail: bob@fly-ul.com WWW: http://www.fly-ul.com ________________________________________________________________________________
Subject: Yacco AVX500 or Aero Shell sport plus
Date: Jan 05, 2013
Hi there all, happy new year and good flights! I maintain two ships (an Europa XS and of a MCR 4S) both equipped with a Rotax 912 ULS, both inherited with each their specific oil : Yacco for the Europa and Aero Shell for the MCR. Both oils listed by Rotax but I wish I could have only one supplier and only one shelf. Any advice concerning the change from oil to another one. What could be the best process? Max Cointe mcointe(at)free.fr MCR 4S #27-2002 / 1550 heures F-PLDJ 912ULSFR / MT-Prop MTV7A and F-PMLH Europa_TriGear Kit #560 912ULS Airmaster 450 hours ________________________________________________________________________________
Subject: Re: Yacco AVX500 or Aero Shell sport plus
Date: Jan 05, 2013
Max, I don't know the Yacco, but the Shell is supposed to be great. I'll be swit ching from Mobil to the Shell at annual time in Feb. Blue skies and tailwinds, Bob Borger Europa XS, Tri, Rotax 914, Airmaster. Sent from my iPhone On Jan 5, 2013, at 8:07, Max Cointe wrote: Hi there all, happy new year and good flights! I maintain two ships (an Europa XS and of a MCR 4S) both equipped with a Rot ax 912 ULS, both inherited with each their specific oil : Yacco for the Euro pa and Aero Shell for the MCR. Both oils listed by Rotax but I wish I could have only one supplier and only one shelf Any advice concerning th e change from oil to another one. What could be the best process? Max Cointe mcointe(at)free.fr MCR 4S #27-2002 / 1550 heures F-PLDJ 912ULSFR / MT-Prop MTV7A and F-PMLH Europa_TriGear Kit #560 912ULS Airmaster 450 hours ________________________________________________________________________________
Date: Jan 05, 2013
Aero Shell Sport Plus 4 will absolutely be a better overall choice. It was designed in the UK just for the Rotax and has a specific additive package with the 912 in mind. The other oil is just a substitute because not all oils are available every where in the world so Rotax gave owners some options, but it not a very conclusive list as they can't test all oils. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=391666#391666 ________________________________________________________________________________
Date: Jan 06, 2013
Max, To add to what Roger said, the transition from one oil to another approved oil does not require any special process. When next oil change time comes, drain as usual, changing filter of course, and add the new oil. The residual oil left in cooler etc and new oil will mix and your engine will not notice the difference or that there is a small mix of old with new. -------- Thom Riddle Buffalo, NY (9G0) Kolb Slingshot SS-021 no engine FOR SALE Diamond Katana DA20-A1 Rotax 912 F3 Don't worry about old age... it doesn't last very long. - Anonymous Read this topic online here: http://forums.matronics.com/viewtopic.php?p=391701#391701 ________________________________________________________________________________
Date: Jan 15, 2013
Subject: spark plug caps for 912UL
I am in the process of changing the spark plug wires on my older 912 UL (mid 90's). I am also doing a resistance check on the caps and have found at least one of them out of the Rotax lower limits (4400 ohms) . All of them so far have run about 4600 ohms vs the 5000 they should be. Is there someplace I can buy NGK VDO5FMH plug caps without paying the almost $50 a piece that Rotax charges ? I can get VDO5EMH caps on line for about $7 each but I believe they take solid tip plugs vs the threaded that Rotax calls for. I have not been able to locate the "F" caps either locally or "on line" Thanks, Dick Maddux 912UL Milton,Fl ________________________________________________________________________________
Subject: Re: spark plug caps for 912UL
Date: Jan 15, 2013
Dick, Try Google - In UK lots come up at prices under 10. Regards, David Joyce Catz631(at)aol.com wrote: > I am in the process of changing the spark plug wires on >my older 912 UL > (mid 90's). I am also doing a resistance check on the >caps and have found at > least one of them out of the Rotax lower limits (4400 >ohms) . All of them > so far have run about 4600 ohms vs the 5000 they should >be. > Is there someplace I can buy NGK VDO5FMH plug caps >without paying the > almost $50 a piece that Rotax charges ? I can get > VDO5EMH caps on line for > about $7 each but I believe they take solid tip plugs vs >the threaded that > Rotax calls for. > I have not been able to locate the "F" caps either >locally or "on line" > > > Thanks, > > Dick > Maddux > > 912UL > > > Milton,Fl > ________________________________________________________________________________
Date: Jan 15, 2013
Hi Dick. Just out of interest what problem are you getting with your plugs, is it miss firing ?? Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=392334#392334 ________________________________________________________________________________
Date: Jan 15, 2013
Dick, Did some searching and found a french company, LorAvia, which sells them for 11.00 or about $14.68 each. http://loravia.com/shop/en/spark-plug-connector-vdo5fmh-nc?keyword=VDO5F MH&description=true&model=1 If it comes up in French, click on the Brit flag in the upper right and search on the part number. I haven't found any US dealers other than the Rotax dealers who want $50+/- each for them. Hopefully, someone else can come up with a U.S. source at a reasonable price. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop. Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Jan 15, 2013, at 7:02 AM, Catz631(at)aol.com wrote: I am in the process of changing the spark plug wires on my older 912 UL (mid 90's). I am also doing a resistance check on the caps and have found at least one of them out of the Rotax lower limits (4400 ohms) . All of them so far have run about 4600 ohms vs the 5000 they should be. Is there someplace I can buy NGK VDO5FMH plug caps without paying the almost $50 a piece that Rotax charges ? I can get VDO5EMH caps on line for about $7 each but I believe they take solid tip plugs vs the threaded that Rotax calls for. I have not been able to locate the "F" caps either locally or "on line" Thanks, Dick Maddux 912UL Milton,Fl ________________________________________________________________________________
Date: Jan 15, 2013
Is it possible that there is a substitute from the world of motorcycles?=0A =0A=0A=0A=0A________________________________=0AFrom: Robert Borger <rlborge r(at)mac.com>=0ATo: rotaxengines-list(at)matronics.com=0ASent: Tue, January 15, 2 013 10:22:02 AM=0ASubject: Re: RotaxEngines-List: spark plug caps for 912UL =0A=0ADick, =0A=0ADid some searching and found a french company, LorAvia, w hich sells them for =0A11.00=C2-=82=AC=C2-or about $14.68 each.=0A =0Ahttp://loravia.com/shop/en/spark-plug-connector-vdo5fmh-nc?keyword=VDO 5FMH&description=true&model=1=C2-=0A=0A=0AIf it comes up in French, c lick on the Brit flag in the upper right and search =0Aon the part number. =0A=0AI haven't found any US dealers other than the Rotax dealers who want $50+/- each =0Afor them.=0A=0AHopefully, someone else can come up with a U. S. source at a reasonable price.=0A=0A=0ABlue skies & tailwinds,=0ABob Borg er=0AEuropa XS Tri, Rotax 914, Airmaster=C2-C/S Prop.=0ALittle Toot Sport Biplane, Lycoming=C2-Thunderbolt AEIO-320 EXP=0A3705 Lynchburg Dr.=0ACor inth, TX =C2-76208-5331=0ACel: 817-992-1117=0Arlborger(at)mac.com=0A=0AOn Ja n 15, 2013, at 7:02 AM, Catz631(at)aol.com wrote:=0A=0AI am in the process of changing the spark plug wires on my older 912 UL (mid =0A90's). I am also d oing a resistance check on the caps and have found at least =0Aone of them out of the Rotax lower limits (4400 ohms)=C2-. All of them so far have =0Arun about 4600 ohms vs the 5000 they should be. =0A=0A=C2-Is there som eplace I can buy NGK VDO5FMH plug caps without paying the almost =0A$50 a p iece that Rotax charges ? I can get=C2- VDO5EMH caps on line for about $7 =0Aeach but I believe they take solid tip plugs vs the threaded that Rotax calls =0Afor.=0A=C2-I have not been able to locate the "F" caps either l ocally or "on line"=0A=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2- =0A=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- Thanks,=0A =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2- Dick Maddux=0A=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2- 912UL=0A=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-Milton,Fl=C2- ________________________________________________________________________________
Date: Jan 15, 2013
NGK VD05FMH caps seem to be available for a mere $6.30 each from www.ngk.com/product.aspx?zpid 087 Regards David Joyce Arthur Glaser wrote: > Is it possible that there is a substitute from the world >of motorcycles? > > > > > ________________________________ >From: Robert Borger <rlborger(at)mac.com> > To: rotaxengines-list(at)matronics.com > Sent: Tue, January 15, 2013 10:22:02 AM > Subject: Re: RotaxEngines-List: spark plug caps for >912UL > > Dick, > > Did some searching and found a french company, LorAvia, >which sells them for > 11.00or about $14.68 each. > > http://loravia.com/shop/en/spark-plug-connector-vdo5fmh-nc?keyword=VDO5FMH&description=true&model=1 > > > If it comes up in French, click on the Brit flag in the >upper right and search > on the part number. > > I haven't found any US dealers other than the Rotax >dealers who want $50+/- each > for them. > > Hopefully, someone else can come up with a U.S. source >at a reasonable price. > > > Blue skies & tailwinds, > Bob Borger > Europa XS Tri, Rotax 914, AirmasterC/S Prop. > Little Toot Sport Biplane, LycomingThunderbolt AEIO-320 >EXP > 3705 Lynchburg Dr. > Corinth, TX 76208-5331 > Cel: 817-992-1117 > rlborger(at)mac.com > > On Jan 15, 2013, at 7:02 AM, Catz631(at)aol.com wrote: > > I am in the process of changing the spark plug wires on >my older 912 UL (mid > 90's). I am also doing a resistance check on the caps >and have found at least > one of them out of the Rotax lower limits (4400 ohms). >All of them so far have > run about 4600 ohms vs the 5000 they should be. > > Is there someplace I can buy NGK VDO5FMH plug caps >without paying the almost > $50 a piece that Rotax charges ? I can get VDO5EMH caps >on line for about $7 > each but I believe they take solid tip plugs vs the >threaded that Rotax calls > for. > I have not been able to locate the "F" caps either >locally or "on line" > > >Thanks, > >Dick Maddux > >912UL > Milton,Fl ________________________________________________________________________________
Date: Jan 15, 2013
It is not clear to me from the information given on these caps that they are specifically for fitting the threaded end of the spark plug after the tip is removed (as required by Rotax), or if they are for fitting over the cap that comes on the plug. Can you answer this? Hugh G. McKay III, P.E. Allegro 2000 Rotax 912 UL -----Original Message----- From: David Joyce Sent: Tuesday, January 15, 2013 1:40 PM Subject: Re: RotaxEngines-List: spark plug caps for 912UL NGK VD05FMH caps seem to be available for a mere $6.30 each from www.ngk.com/product.aspx?zpid 087 Regards David Joyce Arthur Glaser wrote: > Is it possible that there is a substitute from the world of motorcycles? > > > ________________________________ >From: Robert Borger <rlborger(at)mac.com> > To: rotaxengines-list(at)matronics.com > Sent: Tue, January 15, 2013 10:22:02 AM > Subject: Re: RotaxEngines-List: spark plug caps for 912UL > > Dick, > Did some searching and found a french company, LorAvia, which sells them > for 11.00 or about $14.68 each. > > http://loravia.com/shop/en/spark-plug-connector-vdo5fmh-nc?keyword=VDO5FMH&description=true&model=1 > > If it comes up in French, click on the Brit flag in the upper right and > search on the part number. > > I haven't found any US dealers other than the Rotax dealers who want > $50+/- each for them. > > Hopefully, someone else can come up with a U.S. source at a reasonable > price. > > > Blue skies & tailwinds, > Bob Borger > Europa XS Tri, Rotax 914, Airmaster C/S Prop. > Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP > 3705 Lynchburg Dr. > Corinth, TX 76208-5331 > Cel: 817-992-1117 > rlborger(at)mac.com > > On Jan 15, 2013, at 7:02 AM, Catz631(at)aol.com wrote: > > I am in the process of changing the spark plug wires on my older 912 UL > (mid 90's). I am also doing a resistance check on the caps and have found > at least one of them out of the Rotax lower limits (4400 ohms) . All of > them so far have run about 4600 ohms vs the 5000 they should be. > Is there someplace I can buy NGK VDO5FMH plug caps without paying the > almost $50 a piece that Rotax charges ? I can get VDO5EMH caps on line > for about $7 each but I believe they take solid tip plugs vs the threaded > that Rotax calls for. > I have not been able to locate the "F" caps either locally or "on line" > Thanks, > Dick > Maddux > 912UL > > Milton,Fl ________________________________________________________________________________
Date: Jan 15, 2013
Hugh, I've attached a part number buildup guide from NGK so that you can see how the part numbers are assigned. By using the guide you can determine the specification for each resistor cover. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=392369#392369 Attachments: http://forums.matronics.com//files/resistor_covers_535.pdf ________________________________________________________________________________
Date: Jan 15, 2013
Hugh, couldn't say, but at that prie why not buy one & check tht it is the same item? DJ "Hugh McKay" wrote: > > > It is not clear to me from the information given on >these caps that they are specifically for fitting the >threaded end of the spark plug after the tip is removed >(as required by Rotax), or if they are for fitting over >the cap that comes on the plug. Can you answer this? > > Hugh G. McKay III, P.E. > Allegro 2000 > Rotax 912 UL > > -----Original Message----- From: David Joyce > Sent: Tuesday, January 15, 2013 1:40 PM > To: rotaxengines-list(at)matronics.com > Subject: Re: RotaxEngines-List: spark plug caps for >912UL > > > > NGK VD05FMH caps seem to be available for a mere $6.30 > each from www.ngk.com/product.aspx?zpid 087 Regards > David Joyce > > > Arthur Glaser wrote: >> Is it possible that there is a substitute from the world >>of motorcycles? >> >> >> >> >> ________________________________ >>From: Robert Borger <rlborger(at)mac.com> >> To: rotaxengines-list(at)matronics.com >> Sent: Tue, January 15, 2013 10:22:02 AM >> Subject: Re: RotaxEngines-List: spark plug caps for >>912UL >> >> Dick, >> Did some searching and found a french company, LorAvia, >>which sells them for 11.00 or about $14.68 each. >> >> http://loravia.com/shop/en/spark-plug-connector-vdo5fmh-nc?keyword=VDO5FMH&description=true&model=1 >> >> If it comes up in French, click on the Brit flag in the >>upper right and search on the part number. >> >> I haven't found any US dealers other than the Rotax >>dealers who want $50+/- each for them. >> >> Hopefully, someone else can come up with a U.S. source >>at a reasonable price. >> >> >> Blue skies & tailwinds, >> Bob Borger >> Europa XS Tri, Rotax 914, Airmaster C/S Prop. >> Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 >>EXP >> 3705 Lynchburg Dr. >> Corinth, TX 76208-5331
October 10, 2012 - January 15, 2013
RotaxEngines-Archive.digest.vol-bc
