RotaxEngines-Archive.digest.vol-bf
October 24, 2013 - June 24, 2014
      Filter Area
      Install the LARGEST surface area size, filter that will fit.  It will
      filter better with much less chance of clogging AND it will even increase
      the fuel capacity of your plane ;-)
      Now, where to get such a filter?
      On the RV6 that I fly, I installed a clear plastic Automotive Fuel Filter,
      on each wing tank.  Look for a LARGE filter that advertises the working
      fuel pressure [WP or SBWP].  Because of this planes fuel line location I
      can see the filters while flying the plane.  It is my first line of defense
      for fuel contamination.
      After the filters there is a Boost Pump then the Gascolator (Personally I
      do not like Gascolators as they are difficult to service both at pre-flight
      and safety inspection.  And, I have never seen any contamination collected
      in them. A good thing, but if the inline filters work and the boost pump
      filter works...  More is not always better; then comes the mechanical fuel
      pump.
      Here in the States the cost of these filters is around: $3 to $5 each (USD).
      As a side note:  I have seen some very large fuel filters that look like
      they could store a liter.  They are metal bodied and cost about $8 to $15
      USD.  Two of them would increase your planes fuel capacity and time.
      *Barry*
      NJ has taken the next step.  They are identifying cars with bad drivers.
      You will notice some cars with a large red "R" on them.   That is to
      identify the drivers as "R"estricted.  Restricted is just a polite way of
      saying Bad Drivers.  Be cautious around them.
Subject: RE: fuel filter
Date: Oct 24, 2013
Hi Barry, thanks for your comments. My setup is as follows (a/c is a Kitfox): 8mm (5/16=94) ID hoses going from: Wing tanks =E8 header tank (located behind the seat) =E8 Gascolator (ACS) =E8 Electrical fuel pump (no inbuilt filter; there is a line that bypasses the fuel pump and has a one-way valve ' just in case the fuel pump gets blocked) =E8 Mechanical Fuel pump =E8 Engine and return line to Gascolator I understand your comments about 30 vs 15 microns, however=85 I=92m thinking that if the Rotax installation manual says 30 and then 15 there must be a reason=85 so I=92d rather follow their instructions exactly. So this means I=92m thinking of putting the 15 micron fuel filter between the Mechanical Fuel Pump and the Engine Summarizing what you have said, you recommend: - Able to withstand at least twice the max fuel pressure in the lines - With a large surface area My question is: what fuel filters do people on this list use/recommend? Some brand names and/or a photo or two would be much appreciated! From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of FLYaDIVE Sent: Thursday, 24 October, 2013 16:25 Subject: Re: RotaxEngines-List: RE: fuel filter Hello Sacha: The Pressurized Vs Unpressurized locations is dependent on the installation set-up you have. Basically the Unpressurized side is coming from the fuel tank and the Pressurized is everything after the Fuel Pump. Do you have a Electric Boost Pump installed? That is usually installed 'upstream' - Before the mechanical fuel pump so - - The unpressurized is now BEFORE the electric boost pump, which may have its own built in filter (Faucet). I really do not see any reason why there should be two different micron size filters. There are three requirements: 1 - What ever filter you chose it MUST be able to handle TWICE the maximum fuel pressure. 2 - The micron size should be small enough to catch the smallest size particle that could cause a problem. Since there is a suggestion/requirement to use a 15 micron filter, I would use that size in both locations. Why pass on a dirt particle from one filter and part of a system further down and maybe into a difficult to reach part of the system. 3 - Fuel flow is dependent on a few factors: Fuel Pressure Fuel Line Size - Both Diameter and Length Filter Area Install the LARGEST surface area size, filter that will fit. It will filter better with much less chance of clogging AND it will even increase the fuel capacity of your plane ;-) Now, where to get such a filter? On the RV6 that I fly, I installed a clear plastic Automotive Fuel Filter, on each wing tank. Look for a LARGE filter that advertises the working fuel pressure [WP or SBWP]. Because of this planes fuel line location I can see the filters while flying the plane. It is my first line of defense for fuel contamination. After the filters there is a Boost Pump then the Gascolator (Personally I do not like Gascolators as they are difficult to service both at pre-flight and safety inspection. And, I have never seen any contamination collected in them. A good thing, but if the inline filters work and the boost pump filter works... More is not always better; then comes the mechanical fuel pump. Here in the States the cost of these filters is around: $3 to $5 each (USD). As a side note: I have seen some very large fuel filters that look like they could store a liter. They are metal bodied and cost about $8 to $15 USD. Two of them would increase your planes fuel capacity and time. *Barry* NJ has taken the next step. They are identifying cars with bad drivers. You will notice some cars with a large red "R" on them. That is to identify the drivers as "R"estricted. Restricted is just a polite way of saying Bad Drivers. Be cautious around them. -List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Fuel filter
Date: Oct 28, 2013
Hi. Just read your post. I have a Rotax 914, many years ago, entry in log book states. Fuel Filters Removed and Gasalator Fitted, Have had no trouble with Gasolator, but read many times engine failure filter blocked. regards. Alan Hi Alan, For some reason I never got your reply - I just happened to see it today as I was browsing the website. So sorry for not replying earlier. I went back and tried to find the source for the 30 and 15 micron thing I mentioned in the first post. This is very strange: I couldn't find anything of the kind in the installation manual. I'm beginning to think I dreamed it all up in the first place now. The only filter I have is a Gascolator, so I guess my installation is fine after all. Anyway, thanks to you and to Barry for your replies. and sorry for wasting your time and for putting incorrect information out there. For the record, the copy of the installation manual that I have (Ed.2/Rev.0 Aug 2012) says: Coarse filter: On fuel tank as per certification (whatever that means) Fine filter: In the feedline from the tanks to the pumps, an additional fine filter with mesh size 0.1mm (so 100 microns not 30 or 15.) has to be provided. The filter has to be controllable for service. A combination of filter/water-trap (gascolator) is recommended. Sacha ________________________________________________________________________________
Subject: Re: fuel filter
Date: Oct 29, 2013
That's OK Sacha. Sometimes I think the more junk you put between the tank and the engine you are upping your odds of trouble, my engine has done about 450 hours without any fuel problems, I always refill using a filter at the tank cap. However Andair do some nice fuel line components, Just one thing of interest, when putting the rubber hose on any fuel line component, always use a rubber lubricant, as you may just dislodge a small piece of rubber that may end up blocking the carb jet, then EFATO. So make sure all is clean. Regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411701#411701 ________________________________________________________________________________
Date: Oct 29, 2013
>EFATO Everything F=99d After That Occurs??? Michael ------------------------------------------------------------------------- ------- ------------------------------------------------------------------------- ------- -----Original Message----- From: Alan Carter Sent: Tuesday, October 29, 2013 1:39 PM Subject: RotaxEngines-List: Re: fuel filter That's OK Sacha. Sometimes I think the more junk you put between the tank and the engine you are upping your odds of trouble, my engine has done about 450 hours without any fuel problems, I always refill using a filter at the tank cap. However Andair do some nice fuel line components, Just one thing of interest, when putting the rubber hose on any fuel line component, always use a rubber lubricant, as you may just dislodge a small piece of rubber that may end up blocking the carb jet, then EFATO. So make sure all is clean. Regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411701#411701 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Oct 30, 2013
Thanks Alan for the tips. I'm all for keeping it simple: no filters or valves in the tanks, they are both directly connected to the header tank. One central fuel shutoff valve between the header tank and the fuel pumps. One thing I did do the other day is clean out the fuel tanks (they're about 10 years old). It was quite a simple thing to do: stuck a 2m piece of garden hose in the tank with a hole two thirds the way down where I inserted the compressed air pistol pointed towards the outside. The Venturi effect sucked out all the petrol/gasoline but also quite a bit of muck... Looked like small bits of reddish plastic but I was told its normal fuel residue that builds up over the years. ________________________________________________________________________________
Date: Nov 01, 2013
Subject: PLEASE READ - Matronics Email List Fund Raiser During
November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 30 different gifts to choose from - more than we've ever had before! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Corbin Glowacki of My Pilot Store http://www.mypilotstore.com George Race of Race Consulting http://www.mrrace.com/ Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product line. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 04, 2013
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 06, 2013
Subject: Network Issues At Matronics Last Few Days...
Dear Listers, Starting sometime on Friday November 1st, my Internet Service Provider (ISP) began "upgrading" their Domain Name Servers (DNS). DNS servers allow the resolution of computer names such as "www.matronics.com" to real addresses such as 64.81.74.3. This also impacts email delivery as well, since there is another layer of resolution that applies to email names. Because of this upgrade on the part of my ISP, DNS service started getting unreliable around Friday sometime, but I didn't notice it until sometime on Saturday. When I used a tool called "nslookup" to test the resolution of name-to-address, about 50-75% of the time my ISP's servers would response with an "SERVFAIL" indicating that they didn't know the answer. I opened a ticket with the ISP on Saturday, and by Sunday afternoon I had no feedback on the ticket so I called in to support. "We upgrading the DNS servers, and it should back by Sunday at 5pm." 5pm came and went with no resolution. Well, long story short by Tuesday morning things were still not fixed and in fact much worse. So, I opted to move all my DNS service to a different service provider. I have a lot of DNS entries, so it took a while to get everything moved over. It generally takes about 24 hours for a change like that to fully propagate across the Internet which would be Wednesday morning sometime. I've noticed that the Matronics web server traffic is picking up again, so many sites have already propagated the new information. I really should have just moved the DNS on Saturday when I first noticed the troubles, but with stuff like this, you just keep believing that it gonna be fixed any minute now.... And, in fact, that's what my ISP kept telling me... Its always a giant bummer when stuff like this happens and particularly during the Fund Raiser. I apologize to anyone that has tried to make a Contribution in the last few days and had issues or was simply unable to connect. By the time you read this email, the DNS should be fully propagated, and I ask that you please try again. The Contribution web site URL is: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your kind consideration and patience, Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 07, 2013
Subject: Coming Soon - The List of Contributors - Please Make
A Contribution Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 09, 2013
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 11, 2013
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 11, 2013
Subject: Matronics Email Disruption Fixed...
Dear Listers, Starting around midnight this morning 11/11/13, the Matronics Barracuda spam filter that receives all incoming email from the Internet, developed a problem and started rejecting all incoming email. I just got off the phone with the Barracuda technical support and we have If you have posted to any of the Lists during this time, you will need to resend your email to the respective List. My apologies for the disruption! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 13, 2013
Subject: Please Make A List Contribution Today; Some Nice Comments...
Dear Listers, I've been getting some very nice comments from Listers along with their List Support Contributions. I've shared a number of them below. Please read them over and see what your fellow Listers think of the Lists and Forums. Please make a Contribution today to support the continued upgrade and operation of these services. There are lots of really nice gifts available this year, so please browse the selections and pickup something fun with your qualifying Contribution! You may use a credit card or your PayPal account here: http://www.matronics.com/contribution Or feel free to send a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator -------------------- What Listers Are Saying About The Lists -------------------- I wondered off for a few years & am coming back. I firmly believe you provide greater value to us than some magazine subscriptions. William F Thanks for helping me connect to people have truly blazed the trail. Terry M Thank you for the time and effort you put into keeping these lists going. I am on the verge of flying my RV 8 and would not be here without the help of Matronics. Michael W Thank you for providing a valuable service. Vaughn T Matt I like your forums. Jerry D Thank you for another year of service. Oscar Z Been a "member" for years - this has been a fantastic resource and a great gift to the aviation community. Reade G Thanks for the many years of support to RV builders. Roy H Best run list on the net. Roger C Thanks for your excellent forum! Fred D Truly respect your work and service to many readers!! Fergus K Thanks for an ad-free list! William A Thank you for your GREAT service. I read it every day. John B ..great service! Ralph C Thanks so much for being there. Your contribution to aviation knowledge is invaluable. Benjamin B Thank you for providing the list service. It's great! William V I'd never have finished my Glasair without them. Ronald C Thank you Matt for the valuable forum, am pleased to contribute! Jeffrey J Fine service. Byron G Thanks for your support of our community! Kenneth B -------------------- What Listers Are Saying About The Lists -------------------- ________________________________________________________________________________
Date: Nov 15, 2013
Subject: Make Sure You're Listed! List of Contributors Published
in December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 18, 2013
Subject: Fund Raiser Behind By 25% - Please Contribute Today!
Dear Listers, The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 25%. We got off to a slow start this year with the network DNS issues on the kickoff weekend, so please take this opportunity to show your support for the Matronics Lists and Forums! Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List and Forums Administrator ________________________________________________________________________________
Subject: 912 Fuel Injection Bolt on
Date: Nov 18, 2013
There is a company from Norway advertising on Barnstormers that they have a bolt on kit to add fuel injection to the Rotax 912UL or 912ULS. Any opinions on this? Roger, have you heard of this? Thanks. Regards, Damien N48TK Sent from my iPad ________________________________________________________________________________
Subject: Re: 912 Fuel Injection Bolt on
Date: Nov 19, 2013
Hi Damien, I have heard of a company here in the US, but not overseas. I know nothing about the after market fuel injection systems. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413461#413461 ________________________________________________________________________________
Date: Nov 19, 2013
Roger Air performance in Spartenburg SC does>>>I have one... John McMahon Gallatin,Tn -----Original Message----- From: Roger Lee Sent: Tuesday, November 19, 2013 7:17 PM Subject: RotaxEngines-List: Re: 912 Fuel Injection Bolt on Hi Damien, I have heard of a company here in the US, but not overseas. I know nothing about the after market fuel injection systems. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413461#413461 ________________________________________________________________________________
Date: Nov 20, 2013
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 20, 2013
Hey John, Tell us more about it. Is it easy to install? Performance? Economy increase ? Was your original engine a 912 or 912S -----Original Message----- From: "John McMahon" <rv6(at)earthlink.net> Sent: =8E11/=8E19/=8E2013 8:24 PM Subject: Re: RotaxEngines-List: Re: 912 Fuel Injection Bolt on Roger Air performance in Spartenburg SC does>>>I have one... John McMahon Gallatin,Tn -----Original Message----- From: Roger Lee Sent: Tuesday, November 19, 2013 7:17 PM Subject: RotaxEngines-List: Re: 912 Fuel Injection Bolt on Hi Damien, I have heard of a company here in the US, but not overseas. I know nothing about the after market fuel injection systems. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413461#413461 ________________________________________________________________________________
Date: Nov 20, 2013
OK I will try to help you as much as possible.. The web page to his site http://airflowperformance.com/ The owner is Don Rivera His number is 864-576-4512 he is located on the Spartanburg,SC airport.... He has been making fuel injecting systems for 25+ years or so... I have built 2 Vans aircraft and knew of him for some time he has a fantastic reputation with us builders.. I let my medical run out as I have a condition (diabetes+74 yrs old) so I purchased a Just Aircraft Kit (Highlander) with a new 912 Rotax eng while at the factory at that time there was a lot of talk about fuel inj systems and Dons name came up!!!! There are 5 planes with his systems working perfect..... The reason I did this is 1=smother running at all alt.. 2=no more sync issue.. 3=more horsepower( about 8 to 10 HP) 4=no computer systems in use!!!All bendix type eng that has proved...(bolt on kit) The Negative issues are 1=more money to spent 2=if you install on new eng,it voids warrantee... Hope this helps,I can send some pic if needed.... John McMahon From: Keith Sent: Wednesday, November 20, 2013 8:53 AM Subject: RE: RotaxEngines-List: Re: 912 Fuel Injection Bolt on Hey John, Tell us more about it. Is it easy to install? Performance? Economy increase? Was your original engine a 912 or 912S ------------------------------------------------------------------------- ------- From: John McMahon Sent: =8E11/=8E19/=8E2013 8:24 PM Subject: Re: RotaxEngines-List: Re: 912 Fuel Injection Bolt on Roger Air performance in Spartenburg SC does>>>I have one... John McMahon Gallatin,Tn -----Original Message----- From: Roger Lee Sent: Tuesday, November 19, 2013 7:17 PM Subject: RotaxEngines-List: Re: 912 Fuel Injection Bolt on Hi Damien, I have heard of a company here in the US, but not overseas. I know nothing about the after market fuel injection systems. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413461#413461 ________________________________________________________________________________
Date: Nov 22, 2013
Subject: Please Make A Contribution Today...
Dear Listers, A quick reminder that November is the annual List Fund Raiser and the List of Contributors is quickly approching. The Matronics Lists are 100% member supported and all of the operational costs are provided for by your Contributions during this time of the year. Your personal Contribution makes a big difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running! http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Thinking about buying a Firefly?
Date: Nov 24, 2013
I was wondering if a firefly with a 447 engine plus parachute and 5 gallons of fuel will fly a pilot that is around 225lbs. I would be taking off at a elevation of around 80ft, airport in New Jersey. Also which prop would be best for me, a 2 blade wood prop or a 3 blade powerfin? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413940#413940 ________________________________________________________________________________
Date: Nov 24, 2013
Subject: Re: Thinking about buying a Firefly?
The firefly will haul up aloft. You might find the plane a bit of a little tight fit for a guy your size but height seems a bigger issue than weight. I am 210 5'10 and was comfortable in the firefly I sat in. Personally I perfer a three blade over a two blade anyday. They say a two blade will give you better climb performance. I had a three blade GSC prop on a Phantom and switched to a two blade to achieve better climb performance. I was sorely disappointed. Although it did climb better vibration was more apparent and the climb performance was not worth what i gave up in smoother operation. I went back to the three blade. I would recommend a three blade Warp Drive over the Powerfin if you can find one. Its the best prop I've ever ran. I have a Powerfin on a Phantom now and there is blade movement inside the hub with everything tourqued down to specs. I'm going to replace it with a Warp Drive once I run this engine out. On Nov 24, 2013 11:55 AM, "Firefly2013" wrote: > jschepis(at)comcast.net> > > I was wondering if a firefly with a 447 engine plus parachute and 5 > gallons of fuel will fly a pilot that is around 225lbs. I would be taking > off at a elevation of around 80ft, airport in New Jersey. > > Also which prop would be best for me, a 2 blade wood prop or a 3 blade > powerfin? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413940#413940 > > ________________________________________________________________________________
Date: Nov 24, 2013
Vance: If you consider what you, are expected from a 3 blade Vs 2 blade... Then YES - You will be disappointed. The advantage of a 3 blade are: Lower Tip Speed at the same RPM Less noise Better Vertical Speed (VSI) More Ground clearance Easier to do static prop balance. Easier to do dynamic prop balancing The advantages of a 2 blade are: Higher IAS Disadvantages of a 3 Blade: Lower IAS. A bit scary to Hand Prop. In the winter you collect (more) snow & ice in the spinner. When you ding a prop you usually ding 2 or more blades of the prop. Doing R&R of the cowling is a bit more tricky. Even though your logic was not correct the main thing is you are happy with the prop you chosen. *Barry* *=93Chop=92d Liver=94* NJ has taken the next step. They are identifying cars with bad drivers. You will notice some cars with a large red "R" on them. That is to identify the drivers as "R"estricted. Restricted is just a polite way of saying Bad Drivers. Be cautious around them. On Sun, Nov 24, 2013 at 4:25 PM, Vance Simons wrote : > The firefly will haul up aloft. You might find the plane a bit of a littl e > tight fit for a guy your size but height seems a bigger issue than weight . > I am 210 5'10 and was comfortable in the firefly I sat in. > > Personally I perfer a three blade over a two blade anyday. They say a two > blade will give you better climb performance. I had a three blade GSC pro p > on a Phantom and switched to a two blade to achieve better climb > performance. I was sorely disappointed. Although it did climb better > vibration was more apparent and the climb performance was not worth what i > gave up in smoother operation. I went back to the three blade. I would > recommend a three blade Warp Drive over the Powerfin if you can find one. > Its the best prop I've ever ran. I have a Powerfin on a Phantom now and > there is blade movement inside the hub with everything tourqued down to > specs. I'm going to replace it with a Warp Drive once I run this engine o ut. > On Nov 24, 2013 11:55 AM, "Firefly2013" wrote: > >> jschepis(at)comcast.net> >> >> I was wondering if a firefly with a 447 engine plus parachute and 5 >> gallons of fuel will fly a pilot that is around 225lbs. I would be takin g >> off at a elevation of around 80ft, airport in New Jersey. >> >> Also which prop would be best for me, a 2 blade wood prop or a 3 blade >> powerfin? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=413940#413940 >> >> >> >> >> >> >> >> ========== >> ="_blank">www.aeroelectric.com >> ooks.com" target="_blank">www.buildersbooks.com >> et="_blank">www.homebuilthelp.com >> et="_blank">www.mypilotstore.com >> "_blank">www.mrrace.com >> ="_blank">http://www.matronics.com/contribution >> le, List Admin. >> ========== >> -List" target="_blank"> >> http://www.matronics.com/Navigator?RotaxEngines-List >> ========== >> http://forums.matronics.com >> ========== >> >> >> >> * > =========== m> ldersbooks.com> .com> com> om/contribution> =========== www.matronics.com/Navigator?RotaxEngines-List> =========== =========== > * > > ________________________________________________________________________________
Date: Nov 25, 2013
Subject: [PLEASE READ] Why I Have A Fund Raiser...
>From the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that elk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 25, 2013
[quote="rvsimons"]The firefly will haul up aloft. You might find the plane a bit of a little tight fit for a guy your size but height seems a bigger issue than weight. I am 210 5'10 and was comfortable in the firefly I sat in. I was wondering if a firefly with a 447 engine plus parachute and 5 gallons of fuel will fly a pilot that is around 225lbs. I would be taking off at a elevation of around 80ft, airport in New Jersey. Also which prop would be best for me, a 2 blade wood prop or a 3 blade powerfin? Thanks Rvsimons, I'm 5' 10" so I guess it would be ok for me. I was looking to buy a firefly I saw forsale, but I think I am going to wait and get sport pilot licence as that would give me more choices. I want to fly something with a 4 stroke, that I can trailer to avoid paying hanger fee's in case I don't have time for flying allot, I don't want to be stuck paying for things I'm not using. The phantom is the plane that I would really want, they look like a well constructed ultralight. I believe I read you have to inspect those wire's good to make sure the tangs or whatever they are called do not become elongated. How do you like the Phantom? It would be my first choice except for the need for a hanger. I think a firestar with a rotax 912 or someother 4 stroke would work for me because I could keep it trialered in my yard and hook it up when I want to go flying? And hopefully sell it if I get bored with it. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414052#414052 ________________________________________________________________________________
Date: Nov 25, 2013
THe "R" on New Jersey Licence plates is showing support the Rutgers University Scarlet Knights. http://www.alumni.rutgers.edu/s/896/2col.aspx?sid=896&pgid=349 https://www.govtrack.us/states/nj/bills/2012-2013/s753 Thanks for the info [quote="BARRY CHECK 6"]Vance: If you consider what you, are expected from a 3 blade Vs 2 blade... Then YES - You will be disappointed. The advantage of a 3 blade are: Lower Tip Speed at the same RPM Less noise Better Vertical Speed (VSI) More Ground clearance Easier to do static prop balance. Easier to do dynamic prop balancing The advantages of a 2 blade are: Higher IAS Disadvantages of a 3 Blade: Lower IAS. A bit scary to Hand Prop. In the winter you collect (more) snow & ice in the spinner. When you ding a prop you usually ding 2 or more blades of the prop. Doing R&R of the cowling is a bit more tricky. Even though your logic was not correct the main thing is you are happy with the prop you chosen. *Barry* *Chopd Liver* NJ has taken the next step. They are identifying cars with bad drivers. You will notice some cars with a large red "R" on them. That is to identify the drivers as "R"estricted. Restricted is just a polite way of saying Bad Drivers. Be cautious around them. On Sun, Nov 24, 2013 at 4:25 PM, Vance Simons wrote: > The firefly will haul up aloft. You might find the plane a bit of a little > tight fit for a guy your size but height seems a bigger issue than weight Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414054#414054 ________________________________________________________________________________
Date: Nov 26, 2013
Subject: Of Pencils & Airplanes [Repost From AeroElectric-List]...
[Dear Listers, last week, Bob Nuckolls of the AeroElectric fame, posted a very nice message discussing the Lists and Forums at Matronics. It is a very insightful piece and I asked Bob if I could forward it to the rest of the Lists for the other members to enjoy and contemplate as well. He gladly agreed, and so below I have included the text from that message. Enjoy. -Matt Dralle, Matronics Email List and Forum Administrator] "As most of you know, Matt's ISP was fiddling with some crucial details for the exchange of data on the 'net a few weeks ago. The Lists, Matt's business site, and AeroElectric.com got really flakey. . . I was 'unhooked' from the List and all of three of my e-mail services for several days. Out of business and out of touch. After two days, I was beginning to worry. I had no idea as to root cause nor was there a time table for resolution . . . I began to mull over plan-B options. Of course, plan-B would have entailed seeking a new home for aeroelectric.com and ancillary services. NOT a quick, inexpensive or happy thing to contemplate. The time talents and resources that go into fabrication and maintenance of some of the 'simplest' features of our lives often go unnoticed . . . not because they're unappreciated . . . but simply because we're unaware of their significance. I will invite you all to read an essay by one Leonard Read written in 1958 titled "I pencil". See: http://tinyurl.com/me3q3hj It's a fascinating and well crafted peek into a society of unacquainted, self-interested individuals who exploited uncountable windows of opportunity for what has been called "spontaneous order" in the manufacture and sales of the simple wood pencil. The point of citing Mr. Read's essay is to examine two features of the human experience that contribute to the success of this List and our various interests in airplanes. The first point I'd like to make is that we cannot know the millions of individuals who contributed to the materials and infrastructure that make this List possible. We sit at the top of a pyramid of work-product derived from the time, talents and resources of millions of people who we'll never know. Another feature I'd like to emphasis is our ignorance of the criticality for any single component for a host of materials and components for the manufacture and sales of a simple pencil or an affordable airplane. Suppose any one of the materials or processes described in Read's essay were simply unavailable. How would that impact the price of a pencil? Would the pencil even continue to exist at it's new price? The really big question is, "How might some seemingly small loss ripple throughout the economy of our existence?" The time, talent and resources that support infrastructure for this List, my website, Matt's website, and our e-mails cannot be accurately known. That infrastructure stands on an exceedingly complex array of activities that arose from the ingenuity and spontaneous organization of free- market enterprises. But from our perch at the top of this pyramid we need only look down a few layers and see that this resource upon which we depend is vulnerable. There are risks we all assume . . . Matt could get t-boned in an intersection tomorrow. Lightning could strike the pole behind his facility and do catastrophic damage to the hardware. Yours truly could take a deer through the windshield on his way to Wichita some morning. Other risks are less catastrophic. They include things like amateurish behaviors by maintainers of the Internet highway's potholes. Perhaps some material critical to the manufacture of terabyte hard drives dries up. Or maybe the cost of keeping the lights on and the bytes herded become more than Matt can justify given his personal needs for existence. Several times a year I get an opportunity to plant new seeds of thought in the minds of fellow citizens. One of my favorites is to be standing in a long line at Panera's waiting to purchase a bagel and coffee and hear somebody in line complaining about the wait. I suggest to them that to wait in line for a much desired product is a GOOD thing. Not having to wait is a BAD thing if there is not enough business to encourage them to be open tomorrow. It goes without saying that few, if any of us, possess the talents, resources or motivation to step up and do what Matt does. At last count, there were about 1600 individuals who subscribe to this List [Aeroelectric-List]. . . certainly many more make up the population of subscribers to all of the Lists on Matronics. A few years back, Matt was besieged by legal trials and tribulations over the naming of his products . . . seems somebody claimed ownership of the words 'scan' and/or 'scanner' . . . We here on the AeroElectric-List perceived a risk to Matt's operations and came up with several thousands of dollars to contribute to his defense fund. We need make no greater 'investment' in Matt's operations now than it takes to stand in a line for a Quarter-Pounder Combo . . . or a fist full of pencils. You and I can have no more positive influence over the manufacture of pencils and hard drives than to continue to purchase such things and encourage those with the time, talent and resources to continue doing what they do best. Let's contribute to the comfortable maintenance of this service which is probably more valuable than we know. Just a little bit from thousands of us on the Matronics Lists can make a big difference. Bob . . ." Please take a minute to make your Contribution today: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 26, 2013
Subject: Joint Release Announcement from TSFlightlines and Aircraft
Specialty
From: Aircraft Specialty <aircraftspecialty(at)gmail.com>
Tom of www.tsflightlines.com and Steve of www.aircraftspecialty.com are extremely excited to announce a joint collaboration project we have been working on for several months. Today we are announcing that we have developed a complete RV-12 hose retrofit kit. Please click here for the press release.<http://aircraftspecialty.com/PDF%20Documents/Rotax%20912%20press%20release.pdf> There is more information located on our websites at www.tsflightlines.comand www.aircraftspecialty.com Please feel free to contact Tom or I with any questions that you may have. We are very excited about this new kit and the ability to offer Rotax owners a better alternative for fuel hose replacements. ________________________________________________________________________________
Date: Nov 27, 2013
Subject: Make Sure You're Listed! List of Contributors Coming
Soon! Dear Listers, There's just a few more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2013
Subject: Just Two Days Left...
Dear Listers, There are just a couple days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least four of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2013
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again; the big 50, in fact! But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Restart the engine after a flight
Date: Dec 09, 2013
Hi There All, I have a 912ULS mounted on an Europa XS with almost 500 hours which runs perfectly=85 when it runs: - Cold start is easy and ok even in cold weather (assuming battery is correctly charged and can drive the engine to 600 rpm) - Restart after a 30 minutes stop following a flight is difficult with bubbles visible via the overflow tube creating irregular run and smell of gasoline. After few (long) seconds it comes back to normal and shows no other symptoms. Any advice? Max Cointe mcointe(at)free.fr F-PMLH Europa XS_TriGear Kit #560-2003 912ULS/AirmasterAP332 490 hours F-PLDJ Dyn=92A=E9ro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1600 heures ________________________________________________________________________________
From: "Jonathan(at)Entry.co.za" <jonathan(at)entry.co.za>
Subject: Re: Restart the engine after a flight
Date: Dec 09, 2013
Hi Max, Do you have a Return to tank? I have had the same problem for 500+hrs. I do NOT have a return to tank. I found it to be a build up of pressure in the fuel line, under the cowl of my Zenith CH601XLb. (All the heat seems to come out of the engine.) The fuel pump has a check valve, and hence the fuel will not return on it's own. All I do now is switch off the fuel, when taxiing to the hangar, and when I stop I open the oil filler cowl flap, to let out the hot air. The lack of fuel in the lines, (used up in the taxi) and the little bit of extra cooling seems to have helped a lot with this rich start problem. I also find that if I let it stand for an hour, the problem also goes away. Hope this helps Jonathan ----- Original Message ----- From: Max Cointe (Free) To: rotaxengines-list(at)matronics.com Sent: Monday, December 09, 2013 4:25 PM Subject: RotaxEngines-List: Restart the engine after a flight Hi There All, I have a 912ULS mounted on an Europa XS with almost 500 hours which runs perfectly. when it runs: - Cold start is easy and ok even in cold weather (assuming battery is correctly charged and can drive the engine to 600 rpm) - Restart after a 30 minutes stop following a flight is difficult with bubbles visible via the overflow tube creating irregular run and smell of gasoline. After few (long) seconds it comes back to normal and shows no other symptoms. Any advice? Max Cointe mcointe(at)free.fr F-PMLH Europa XS_TriGear Kit #560-2003 912ULS/AirmasterAP332 490 hours F-PLDJ Dyn'A=E9ro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1600 heures ________________________________________________________________________________
From: Pete Christensen <pchristensen10(at)austin.rr.com>
Date: Dec 09, 2013
Sounds like flooding. I turn off my fuel valve and let it run awhile before shutting down. Seems to take care of that problem. Pete Leander, Tx On Dec 9, 2013, at 8:25 AM, "Max Cointe (Free)" wrote: > Hi There All, > > I have a 912ULS mounted on an Europa XS with almost 500 hours which runs p erfectly when it runs: > - Cold start is easy and ok even in cold weather (assuming batter y is correctly charged and can drive the engine to 600 rpm) > - Restart after a 30 minutes stop following a flight is difficult with bubbles visible via the overflow tube creating irregular run and smell of gasoline. After few (long) seconds it comes back to normal and shows no o ther symptoms. > Any advice? > > Max Cointe > mcointe(at)free.fr > F-PMLH Europa XS_TriGear > Kit #560-2003 912ULS/AirmasterAP332 490 hours > > F-PLDJ Dyn=99A=C3=A9ro MCR 4S > Kit #27-2002 912ULSFR/MTProp MTV7A 1600 heures > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ________________________________________________________________________________
Date: Dec 09, 2013
I had the same problem. Balanced the carbs, and all was well. Vernon. From: Pete Christensen Sent: Monday, December 09, 2013 6:20 PM Subject: Re: RotaxEngines-List: Restart the engine after a flight Sounds like flooding. I turn off my fuel valve and let it run awhile before shutting down. Seems to take care of that problem. Pete Leander, Tx On Dec 9, 2013, at 8:25 AM, "Max Cointe (Free)" wrote: Hi There All, I have a 912ULS mounted on an Europa XS with almost 500 hours which runs perfectly when it runs: - Cold start is easy and ok even in cold weather (assuming battery is correctly charged and can drive the engine to 600 rpm) - Restart after a 30 minutes stop following a flight is difficult with bubbles visible via the overflow tube creating irregular run and smell of gasoline. After few (long) seconds it comes back to normal and shows no other symptoms. Any advice? Max Cointe mcointe(at)free.fr F-PMLH Europa XS_TriGear Kit #560-2003 912ULS/AirmasterAP332 490 hours F-PLDJ Dyn=99A=C3=A9ro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1600 heures ========= ctric.com >www.buildersbooks.com uilthelp.com otstore.com matronics.com/contribution ========= st">http://www.matronics.com/Navigator?RotaxEngines-List ========= cs.com ========= ________________________________________________________________________________
Date: Dec 09, 2013
Don=92t know your fuel piping situation, but it clearly sounds like you are flooding the engine. If you have an electric fuel pump in line with the mechanical pump that is on the engine turn the electric pump off and try starting the engine using the Rotax start procedure for a hot or warm engine. Don=92t use the cold engine start procedure. Hugh G. McKay III, P.E. Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com From: Vernon Mitchell Sent: Monday, December 09, 2013 12:05 PM Subject: Re: RotaxEngines-List: Restart the engine after a flight I had the same problem. Balanced the carbs, and all was well. Vernon. From: Pete Christensen Sent: Monday, December 09, 2013 6:20 PM Subject: Re: RotaxEngines-List: Restart the engine after a flight Sounds like flooding. I turn off my fuel valve and let it run awhile before shutting down. Seems to take care of that problem. Pete Leander, Tx On Dec 9, 2013, at 8:25 AM, "Max Cointe (Free)" wrote: Hi There All, I have a 912ULS mounted on an Europa XS with almost 500 hours which runs perfectly when it runs: - Cold start is easy and ok even in cold weather (assuming battery is correctly charged and can drive the engine to 600 rpm) - Restart after a 30 minutes stop following a flight is difficult with bubbles visible via the overflow tube creating irregular run and smell of gasoline. After few (long) seconds it comes back to normal and shows no other symptoms. Any advice? Max Cointe mcointe(at)free.fr F-PMLH Europa XS_TriGear Kit #560-2003 912ULS/AirmasterAP332 490 hours F-PLDJ Dyn=99A=C3=A9ro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1600 heures ========= ctric.com >www.buildersbooks.com uilthelp.com otstore.com matronics.com/contribution ========= st">http://www.matronics.com/Navigator?RotaxEngines-List ========= cs.com ========= href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.mypilotstore.com">www.mypilotstore.com href="http://www.mrrace.com">www.mrrace.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www. matronics.com/Navigator?RotaxEngines-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Dec 09, 2013
Hi Max, As someone ask, do you have an electric pump? Are you starting with just a single pump? Are you using the choke on the second start? What is the idle set for (after it warms)? Do you apply any throttle during the start? When was the last time you did a carb sync? What are your plugs gapped at? These all play an important part and if you can fill in these questions I would bet we can help. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415283#415283 ________________________________________________________________________________
Date: Dec 10, 2013
Hi Roger, many thanks to you and to everyone who answered. I have a fuel tank return and an electric fuel pump. After warm the idle set is 1600 rpm. I do use the hot start procedure with no shoke (at least usually. For this one I'm not really sure). The carb sync should be correct as the engine runs with no vibe whatever is the rpm. The sparkplugs have 15 hours and standard gap. All opinions converge to a flood which could have been induced by using a (not awared) wrong procedure and/or some vapor lock, which I already experimented but at higher weather temp. I will anyhow retain the process to close the fuel valve before turning of the engine Max Cointe mcointe(at)free.fr F-PMLH Europa XS_TriGear Kit #560-2003 912ULS/AirmasterAP332 490 hours F-PLDJ DynAro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1600 heures -----Message d'origine----- De: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] De la part de Roger Lee Envoy: mardi 10 dcembre 2013 05:03 : rotaxengines-list(at)matronics.com Objet: RotaxEngines-List: Re: Restart the engine after a flight --> Hi Max, As someone ask, do you have an electric pump? Are you starting with just a single pump? Are you using the choke on the second start? What is the idle set for (after it warms)? Do you apply any throttle during the start? When was the last time you did a carb sync? What are your plugs gapped at? These all play an important part and if you can fill in these questions I would bet we can help. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415283#415283 ________________________________________________________________________________
Date: Dec 10, 2013
Carb's can be out of sync quite a bit and many would never know. If they haven't been synced within the last 100 hrs. they are over due. Your idle for a ULS is too low and this will add to hard starts if the throttle is left closed to that mark. This will add to excessive vibration to if you actually idle that low. Either set the idle up to around 1700-1800 or at least crack the throttle when starting. I don't know what standard gap is. I get them in shop shop from .020 to .038. The proper gap should be between .023-.027. During the winter either .023 cold climate or .025 for the southwest where winter climates are a little milder. Narrow gaps for cold weather and wider gaps for hot weather. There is a possibility of a little vapor lock. Are your fuel hoses in fire sleeve? This will not only protect you, but help a little with heat build up on the hose and vapor production. There is a slight possibility that you need to adjust your float level in the bowls. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415309#415309 ________________________________________________________________________________
Date: Dec 10, 2013
Subject: Running rich
I have a 912 ULS in a RV-12. It has run rich from day one. Another flyer on the field had a similar problem and he raised both needles one notch, leaner mixture, which cured his problem. I decided to give that a try, as well as running rich, the EGT were around 1230. The left carb. needle was set at the second notch down and I moved that to the third notch. The right carb. was already at the third notch! I moved that one down to the fourth notch. I have not started it yet as today was too cold and wanted to see if there were any comments first. It seems odd that the two needles would be in different positions as this was an engine directly from the factory. The plugs on both sides looked the same, a fairly light coating of black soot that was easy to remove but below that was black color on the ceramic that was very hard to remove. Fuel consumption has not been high, right around 5 gals./hour. Henry ________________________________________________________________________________
Subject: Re: Running rich
Date: Dec 11, 2013
Hi Henry, Your right that the factory needle clip position is the 3 notch down from the top. Moving the clip to the bottom or fourth notch will richen it. Moving it up to the 2nd from the top will lean it. I allows the needle to sit down further into the main jet. Cold dry OAT's help lean your mixture. Don't take black dry sooty plugs as being too rich if you have been idling. That is normal many times. Once the engine is run up to let's say 4K rpm and run for a few minutes that goes away. Pay more attention to EGT's and what plugs look like if you shut down from higher rpms. The leaner clip position from factory will be the 2nd notch from the top. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415378#415378 ________________________________________________________________________________
Subject: WTB 912ul
Date: Dec 11, 2013
I'm looking for a 80 hp 912. Please PM me if you know of anything along those lines. Thanks EG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415403#415403 ________________________________________________________________________________
Subject: early GTR EIS manual 912
Date: Dec 14, 2013
Does anyone have the wiring diagram for an early Grand Rapides EIS ? This one has the two plug connection and is model EIS 3 adv-w/912. I have the operators manual but cant find the wiring diagram. Grand Rapids does have anything for this old of a model.... Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415543#415543 ________________________________________________________________________________
Date: Dec 16, 2013
Subject: 2013 List of Contributors
Dear Listers, The 2013 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Andy, Bob, Corbin, George, and Jon for their generous support through the supply of many great gifts this year!! These guys have some excellent products and I encourage you to visit their respective web sites: Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com Bob Nucklolls - AeroElectric - http://www.aeroelectric.com Corbin Glowacki - My Pilot Store - http://www.mypilotstore.com George Race - Race Consulting - http://www.mrrace.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com And finally, I'm proud to present The 2013 Fund Raiser List of Contributors: http://www.matronics.com/loc/2013.html Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Subject: CarbMate
Date: Dec 28, 2013
I used a Carb Mate synchronizer once and found I was fumbling around a lot to get the carbs balanced. If, for examle, the LED light is offset to the right, do you loosen , or tighten the cable feed to that right side carb? Or do either to the left side? Instructions didn't provide any clues. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416293#416293 ________________________________________________________________________________
Subject: Re: CarbMate
Date: Dec 29, 2013
Hi John, This is one of my dislikes about electronic devices. I still prefer gauges. You can't diagnose with electronic devices. I have used them, but always gone back to gauge. The easiest way to check and see is to move a carb throttle arm and watch the indicator. If you do it to both one at a time then you can watch the indicator move to where you want it and then know how far and which carb to adjust. I think gauges are faster. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416318#416318 ________________________________________________________________________________
Date: Dec 29, 2013
Hi John, I use a balancing tool similar to the Carb Mate to do my synchronizing. First, only adjust one side, never both sides. All you are trying to do is get one side to match the other. If you try to adjust both sides youll be chasing it all day long. Pick a side to adjust and make a small adjustment on the ferrule, really doesnt matter which way, all you want to see is which way the Carb Mate changes. If it improves, that's the way you want to adjust to balance. If the Carb Mate goes the wrong way, you want to adjust the ferrule in the other direction. Then continue to make adjustments till you get the Carb Mate centered at highest resolution. Its really quite easy once you get the hang of it. Rotax-Owner.com has a good video review of the Carb Mate which includes a demonstration on its use. You should check it out. If you are a member of Rotax-Owner.com there are other excellent, detailed, videos available on carb balancing the 912/914. If you arent a member of Rotax-Owner.com I highly recommend joining to gain access to all their other videos and to their informational e-mailing. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (50 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Dec 28, 2013, at 3:40 PM, JohnF wrote: I used a Carb Mate synchronizer once and found I was fumbling around a lot to get the carbs balanced. If, for examle, the LED light is offset to the right, do you loosen , or tighten the cable feed to that right side carb? Or do either to the left side? Instructions didn't provide any clues. ________________________________________________________________________________
Date: Dec 29, 2013
Thank you, Bob, for your iinformation. I appreciate it. I am in an RV-12 with 190 hours on it now...many minor items have come up but so far nothing major which I hope continues because if you need to get at the starter or other major things the entire engine would have to be pulled...a real pain...the RV-12 with the Rotax 912uls is pretty crowded. Again, thank you John ----- Original Message ----- From: "Robert Borger" <rlborger(at)mac.com> Sent: Sunday, December 29, 2013 9:55 AM Subject: Re: RotaxEngines-List: CarbMate Hi John, I use a balancing tool similar to the Carb Mate to do my synchronizing. First, only adjust one side, never both sides. All you are trying to do is get one side to match the other. If you try to adjust both sides youll be chasing it all day long. Pick a side to adjust and make a small adjustment on the ferrule, really doesnt matter which way, all you want to see is which way the Carb Mate changes. If it improves, that's the way you want to adjust to balance. If the Carb Mate goes the wrong way, you want to adjust the ferrule in the other direction. Then continue to make adjustments till you get the Carb Mate centered at highest resolution. Its really quite easy once you get the hang of it. Rotax-Owner.com has a good video review of the Carb Mate which includes a demonstration on its use. You should check it out. If you are a member of Rotax-Owner.com there are other excellent, detailed, videos available on carb balancing the 912/914. If you arent a member of Rotax-Owner.com I highly recommend joining to gain access to all their other videos and to their informational e-mailing. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (50 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Dec 28, 2013, at 3:40 PM, JohnF wrote: I used a Carb Mate synchronizer once and found I was fumbling around a lot to get the carbs balanced. If, for examle, the LED light is offset to the right, do you loosen , or tighten the cable feed to that right side carb? Or do either to the left side? Instructions didn't provide any clues. ________________________________________________________________________________
Date: Dec 29, 2013
The problem with doing it with a blind adjustment to just make them match is if you screw one out that increases one carb's rpm then it usually will be too far out to set the idle. As a general rule you want to adjust the carb that is getting a little more fuel/air and pull that cable back to retard it some. Then when you go to idle you will still have adjustment. The gauges will tell you exactly which carb to adjust and by how much and how far off they are. The gauge will tell you before you spend a lot of time trying to make an adjustment if the cable lengths are close enough or too far apart to make an adjustment to get them synced and they will tell you if the idle circuit is clogged. The carbmate won't tell you any of that and you may spend a 1-3 hours working on it when using a set of gauge would have told you those things in seconds to a couple of minutes. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416344#416344 ________________________________________________________________________________
Date: Dec 29, 2013
Thank you, Roger. I think before my next condition inspection I want to get gauges...I noticed you recommend liquid-filled gauges that dampen the movement, which makes sense. Would you be kind enough to recommend model/brand of gauges you use. I also plan to purchase a dynamic prop balancer to use during the condtion inspection, so before balancing the prop it seems important to get the carbs right. Right now I am debating between the Dyna Vibe and the ACES unit...both seem like they would do the job, with the ACES a suggested weight is provided, but otherwise they seem about the same. The ACES unit uses the formula that I could do myself. They cost the same, so its a toss up but the Dyna Vibe seems a tad easier to use. Again, thanks for your help. I really appreciate it. John ----- Original Message ----- From: "Roger Lee" <ssadiver1(at)yahoo.com> Sent: Sunday, December 29, 2013 2:16 PM Subject: RotaxEngines-List: Re: CarbMate > > The problem with doing it with a blind adjustment to just make them match > is if you screw one out that increases one carb's rpm then it usually will > be too far out to set the idle. As a general rule you want to adjust the > carb that is getting a little more fuel/air and pull that cable back to > retard it some. Then when you go to idle you will still have adjustment. > The gauges will tell you exactly which carb to adjust and by how much and > how far off they are. The gauge will tell you before you spend a lot of > time trying to make an adjustment if the cable lengths are close enough or > too far apart to make an adjustment to get them synced and they will tell > you if the idle circuit is clogged. The carbmate won't tell you any of > that and you may spend a 1-3 hours working on it when using a set of gauge > would have told you those things in seconds to a couple of minutes. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=416344#416344 > > > ________________________________________________________________________________
Date: Dec 30, 2013
Hi John, No special brad. I don't buy top dollar, but don't buy cheap either. When you get them just pull a vacuum on them at the same time and make sure they are reading the same. Put an in line needle valve in each vacuum line to pinch it down to dampen the impulses even more. You can buy every thing you need except the gauges at Ace Aviation (Ace Hardware). :) here is a picture of a simple carb sync tool that works very well and doesn't cost a lot. I have ab Aces dynamic prop balancer. It is fairly pricey for a one time owner unless you plan on doing a lot of planes. Wouldn't it be cheaper ($300) to just pay someone a one time fee. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416392#416392 Attachments: http://forums.matronics.com//files/carb_sync_150_483.jpg ________________________________________________________________________________
Subject: Carb sync for beginners
Date: Dec 30, 2013
PROCEDURES FOR MECHANICAL AND PNEUMATIC SYNCHRONIZATION OF THE 912 CARB'S: This will get you through the basics and after you do a sync or two it will get easier and you will get better. This is not an official document and is only meant for your edification and will get you through a carb sync. Some experienced people that do carb syncs on a 912s may vary some, but the basics ideas are the same. Mechanical Synch of the Carburetors Do this First Bowden cables adjustment screws (cable housing adjuster) should be centered, but not mandatory. By having the Bowden cable adjustments in the middle of their adjustment range will give you a little more adjustment when you get to that part of the procedure. Adjust throttle cables so that both carb throttle arms move simultaneously to both extremes (open and closed). Ensure Idle Mixture Control Screw is properly set (on the bottom of each carb). Screw them all the way in then back out 1 turns. Reverse the throttle arm springs so they pull toward closed throttle just to facilitate mechanical sync. Unscrew the Idle Stop Screw. Make sure the throttle is closed in the cockpit. With a .004 feeler gauge between the screw and the arm tighten the screw until it just touches. There should be minimal friction on the feeler gauge. Remove the feeler gauge and screw the Idle Stop Screw in 1 turn. Return springs to original configuration (i.e., pulling the throttle arms toward to the open position). Connect the Pneumatic Synch Tool It is imperative to have the engine up to the operating temperature. Remove one end of the rubber crossover compensating tube between the two intake manifolds or connect to the top of the intake manifolds or use the cross over tube rubber hose pinch off method shown in Rotax owner videos. All these attachment methods will work. Hook up gauges or electronic sync tool. Secure one end of a gauge or electronic device to the rubber end of the compensating tube and the other to the gauge at the 90 degree fitting coming out of the intake manifold where the compensating tube hose was removed. Secure both attachments with a hose clamps to prevent leaks. Leaks will affect the results of your sync process. You can hook up your sync tool at the small screw on top of the intake manifold, but then you have to pinch off the rubber hose between the carbs on the cross over compensating line. I find this is just more work and you need to make sure the rubber hose on the compensating tubes are long enough (usually newer engines) and you dont allow any leaks between the carbs. Many people have to cut the tube shorter and make the rubber hose longer to pinch it if you have an older engine with short rubber connecting tubes. I think it is easier and faster by just pulling the hose off as originally described and it facilitates complete carb separation. Make sure you have good brakes, use wheel chocks and or if you have not so good brakes or no wheel chocks then tie your plane down and always have someone in the cockpit. Never do this alone while running an engine and no one in the cockpit.. On Idle Synch NOTE* Many people like to do the high rpm or off idle adjustment first and then do the idle set. I would do the high rpm sync first because it will affect the idle sync. Note* The gauge or carb with the lower vacuum number is getting more air/fuel and the gauge or carb with the higher vacuum number is getting less air/fuel. Bring the cockpit throttle lever to idle stop. Ideal idle RPM is approximately 1700-1800 rpm depending on your specific aircraft and needs. Adjust idle setting to this value. The 912UL 80 HP can handle a little lower idle rpm over the 912ULS 100 HP due to compression ratio. If the idle is high (say, 1900), adjust the carb with the lower vacuum number on the gauge because that is the one getting more air/fuel. Retard the Idle Set Screw until the vacuum numbers are the same. Example: If one gauge is at 15 of vacuum and one at 14 of vacuum retard the lower 14 until it drops to 15 to equal the other carb which will now lower your idle rpm. If idle is low (say, 1600), adjust the carb with the higher value, it is getting less air/fuel. Advance the Idle Set Screw until the vacuum readings are the same. Example: If one carb is at 15 and one at 14 turn the idle stop screw in on the carb with 15 of vacuum to match the one with 14. This will raise the overall idle rpm. Needles should now match. Off Idle or high rpm Synch If while running the engine the gauge needles shake then you will need to install or close down the inline needle valves until the gauge needles stop shaking and pulsating. Now the needles will likely show different vacuum readings. Do this sync before the idle sync because this sync usually will affect your idle sync set point. Run engine at approximately 3500 RPM. Do the Off Idle synchronizations at this rpm. I prefer 3500 rpm to start since that is closer to where you run the engine. You may find that setting the balance at lower rpms doesnt stay very accurate and that as you move up in rpm to 4000-4500 rpm they are out of sync again. Set them at the higher rpm or at least double check the higher rpm when you think you are done. There is a good chance they wont be in sync if you used a low ( -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416396#416396 Attachments: http://forums.matronics.com//files/carb_sync_150_818.jpg ________________________________________________________________________________
Date: Dec 31, 2013
Subject: Re: CarbMateCarbMate
John, I too use a similar unit for carb syncing. It's for a twin motorcycle actually. But on my older Kitfox I have a bell crank throttle system and have a device called a "throttle link" attached to the back of one of the throttle cables. It has a knob allowing me to adjust the throttle cable length in very small increments. I can thus sync the carbs without even getting out of the aircraft. I just look at the gauge on the carb sync instrument I have attached to the carbs, turn the knob on the throttle link, and I am synced in about 30 seconds !. This is really a neat item ! Go to Highwing LLC if you are curious. This will most likely not work on your aircraft but it is a great idea that has been working for years for me. Lowell has had some great ideas that he has developed . Dick Maddux Kitfox 4, 912UL ________________________________________________________________________________
Subject: Rotax 5 Year Replacement of Hoses etc
Date: Jan 02, 2014
There's a periodic (5 year interval) hose and rubber parts replacement requirement for the 912ULS... Can anyone on the list provide your experience regarding the likely cost of that maintenance... i.e., typical # of hours to accomplish in a Rotax shop, and rough cost of the component parts (using authorized Rotax parts)? Thanks, Jim Graham NOVA Light Flight--KHWY Tecnam Sierra N25HV ________________________________________________________________________________
Subject: Re: Rotax 5 Year Replacement of Hoses etc
Date: Jan 04, 2014
Hi Jim, I do about 20 hose changes a year. Your parts cost will be around $1000-$1200 for parts if you do it right. Depending on the shop and the plane type the total could cost with labor could cost any where from $2000-$4000. You can buy some things locally and will be the same as what you will buy from a Rotax distributor because they don't use Rotax parts for some things. Rotax doesn't supply everything. Time depends on the plane. it could be anywhere from a 1-2 days. All fuel and oil lines should be in fire sleeve. You should not use cheap serrated worm drive clamps like you use on a garden hose for fuel hoses. Use either Oetiker clamps or fuel injection clamps. These are both types of good sealing band clamps. The fire sleeve should have Band-It clamps, but an Oetiker band clamp will work. Don't use crap parts. Blow out each fuel line with air before the install. Throwing this together with parts from an hardware store and baling wire isn't the right way. It's your hide and your passengers hide that are on the line. If you do things the wrong way and try to cut too many corners and cause engine damage or an off field landing may cost you really big bucks for cutting those corners. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416585#416585 ________________________________________________________________________________
Date: Jan 05, 2014
Roger What style(s) of Oetiker clamps do you use and on which hoses? Thanks -------- Frank McDonald Kitfox S7 912S, Sensenich Composite 3 Blade Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416596#416596 ________________________________________________________________________________
Date: Jan 05, 2014
Oetiker one ear clamps. Here is an article that will help. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416600#416600 Attachments: http://forums.matronics.com//files/the_task_at_hand_160.docx ________________________________________________________________________________
Date: Jan 05, 2014
Roger, thanks for your cost summary, plus the good quality reminders. Maintenance-wise and quality-wise, we have always been committed not to cut corners, so this periodic hose replacement will be a costly implementation of that principle--but that's the reason we're planning for it now, just a bit ahead of time--to be sure we can cover the costs when we have them. Appreciate your assistance. Jim Graham ________________________________________________________________________________
Subject: New Rotax service info releases
Date: Jan 20, 2014
FYI, Here is new service info for the new software version for BUDS for the IS engine. This one will only affect about 10-12 people in the US. http://legacy.rotaxowner.com/si_tb_info/serviceinfo/si-912i-003r2.pdf Here is new service info for the Teflon fuel lines that feed the carbs if you have them. No longer on the 5 year replacement program. http://legacy.rotaxowner.com/si_tb_info/serviceinfo/si-912-022.pdf -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417301#417301 ________________________________________________________________________________
Date: Jan 20, 2014
Subject: Fuel pump replacement
I have complied with the instructions to replace the fuel pump, installed a fuel pressure sensor. When flying at @5000 rpm I am showing about 4.2 - 4. 7 psi with the electric fuel pump on. When I turn it off and rely solely on the newly installed mechanical pump the pressure drops only slightly. But other times when I turn off the electric pump it fall below the 2.7 psi ala rm I have set on my EIS. The engine continues to run fine. Anyone else had similar experience?=0A=0A=0A-=0ASTAN 2=0ARans S7-S=0ARotax 912 ULS=0A ________________________________________________________________________________
Subject: Re: Fuel pump replacement
Date: Jan 21, 2014
Hi Stan, Do you have a re-circulation line? These new pumps new them. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417347#417347 ________________________________________________________________________________
Date: Jan 22, 2014
Subject: Re: RotaxEngines-List Digest: 1 Msgs - 01/21/14
Yes I have the line returning fuel to the gascolator. Is that significant? =0A=0A=0A-=0ASTAN 2=0A=0A=0A=0AOn Wednesday, January 22, 2014 2:20 AM, Ro taxEngines-List Digest Server wrote:=0A =0A*=0A=0A===================== =====0A- Online Versions of Today's List Digest Archive=0A== ========================0A=0A Today's complete RotaxEngines-List Digest can also be found in either of th e =0Atwo Web Links listed below.- The .html file includes the Digest form atted =0Ain HTML for viewing with a web browser and features Hyperlinked In dexes =0Aand Message Navigation.- The .txt file includes the plain ASCII version =0Aof the RotaxEngines-List Digest and can be viewed with a generic text editor =0Asuch as Notepad or with a web browser. =0A=0AHTML Version: =0A=0A- - http://www.matronics.com/digest/digestview.php?Style=82701& View=html&Chapter 14-01-21&Archive=RotaxEngines=0A=0AText Version: =0A=0A- - http://www.matronics.com/digest/digestview.php?Style=82701& View=txt&Chapter 14-01-21&Archive=RotaxEngines=0A=0A=0A==== ====================0A- EMail Vers ion of Today's List Digest Archive=0A============ ============0A=0A=0A- - - - - ------------ ----------------------------------------------=0A- - - - - - - - - - - - - RotaxEngines-List Digest Archive=0A- - - - - - - - - - - - - - - - - - - ---=0A- - - - - - - - - - Total Messages Posted Tue 01/21/14: 1 =0A- - - - - --------------------------------------------------- -------=0A=0A=0AToday's Message Index:=0A----------------------=0A=0A- - 1. 04:45 AM - Re: Fuel pump replacement- (Roger Lee)=0A=0A=0A=0A____ ____________________________- Message 1- ______________________________ Fuel pump replacement=0AFrom: "Roger Lee" <ssadiver1(at)yahoo.com>=0A=0A=0AHi Stan,=0A=0ADo you have a re-circulation line? These new pumps new them.=0A =0A--------=0ARoger Lee=0ATucson, Az.=0ALight Sport Repairman - Maintenance Rated=0ARotax Repair Center - Heavy Maint. Rated=0AHome 520-574-1080- TR Y HOME FIRST=0ACell 520-349-7056=0A=0A=0ARead this topic online here:=0A=0A http://forums.matronics.com/viewtopic.php?p=417347#417347=0A=0A=0A=0A=0A =========================0A =================== ________________________________________________________________________________
Subject: Rotax mechanic at SAC
From: Kevin Klinefelter <klinefelter.kevin(at)gmail.com>
Date: Jan 22, 2014
Anyone know if there is a Rotax mechanic at or near Sacremento Executive airport? Thanks, Kevin ________________________________________________________________________________
Date: Jan 22, 2014
Yes it's significant, but in a good way. You really need one with the new pump. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417435#417435 ________________________________________________________________________________
Date: Jan 22, 2014
Subject: Re: Rotax mechanic at SAC
Hi Kevin=0AThere was a few guys based out of Oakland when CPS were active b ut I'm sure there are others in your area. You might want to contact the we stern sales contact for the Aerotrek LSA aircraft http://www.aerotrek.aero/ -if your seeking service for the 912/914.-=0A-=0A-I have yet to mee t-anyone in the bayarea-that really-knows 2cycle that know what-the y are doing. I feel they read stuff off the web and fill in the rest as the y go.=0A-=0ASorry I can't be of more help=0AMike=0ALivermore.CA=0A=0A=0A_ _______________________________=0A=0A--> RotaxEngines-List message posted b y: Kevin Klinefelter =0A=0AAnyone know if ther e is a Rotax mechanic at or near Sacremento Executive airport?=0AThanks, Ke vin ________________________________________________________________________________
Date: Jan 22, 2014
Look here. http://www.rainbowaviation.com/repairman.htm and here http://rotaxirmt.com/ or Jeremy McGregor in Tracy, CA 209-481-5881 -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417440#417440 ________________________________________________________________________________
Date: Jan 22, 2014
Mike and Roger, Thanks for your replies. Kevin > On Jan 22, 2014, at 1:30 PM, Michael Woolson wrote : > > Hi Kevin > There was a few guys based out of Oakland when CPS were active but I'm sur e there are others in your area. You might want to contact the western sales contact for the Aerotrek LSA aircraft http://www.aerotrek.aero/ if your see king service for the 912/914. > > I have yet to meet anyone in the bayarea that really knows 2cycle that kn ow what they are doing. I feel they read stuff off the web and fill in the r est as they go. > > Sorry I can't be of more help > Mike > Livermore.CA > > vin(at)gmail.com> > > Anyone know if there is a Rotax mechanic at or near Sacremento Executive a irport? > Thanks, Kevin > > > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jan 23, 2014
From: "Ralph K. Hallett III" <n100rh(at)sbcglobal.net>
Subject: Re: RotaxEngines-List Digest: 6 Msgs - 01/22/14
Kevin, There is a fellow at Gnoss KDVO in Navato, CA name is Bill Sherlock. He's from England and really knows the Rotax family. I'll find his phone number and send it to you. Ralph On 1/23/2014 12:01 AM, RotaxEngines-List Digest Server wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RotaxEngines-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RotaxEngines-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 14-01-22&Archive=RotaxEngines > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 14-01-22&Archive=RotaxEngines > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RotaxEngines-List Digest Archive > --- > Total Messages Posted Wed 01/22/14: 6 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 11:09 AM - Re: RotaxEngines-List Digest: 1 Msgs - 01/21/14 (Stan Tew) > 2. 11:25 AM - Rotax mechanic at SAC (Kevin Klinefelter) > 3. 12:11 PM - Re: RotaxEngines-List Digest: 1 Msgs - 01/21/14 (Roger Lee) > 4. 01:30 PM - Re: Rotax mechanic at SAC (Michael Woolson) > 5. 02:45 PM - Re: Rotax mechanic at SAC (Roger Lee) > 6. 06:27 PM - Re: Rotax mechanic at SAC (Kevin Klinefelter) > > > > ________________________________ Message 1 _____________________________________ > > > From: Stan Tew <stan_tew(at)yahoo.com> > Subject: RotaxEngines-List: Re: RotaxEngines-List Digest: 1 Msgs - 01/21/14 > > Yes I have the line returning fuel to the gascolator. Is that significant? > =0A=0A=0A-=0ASTAN 2=0A=0A=0A=0AOn Wednesday, January 22, 2014 2:20 AM, Ro > taxEngines-List Digest Server wrote:=0A > =0A*=0A=0A==================== > =====0A- Online Versions of Today's List Digest Archive=0A= > ========================0A=0A > Today's complete RotaxEngines-List Digest can also be found in either of th > e =0Atwo Web Links listed below.- The .html file includes the Digest form > atted =0Ain HTML for viewing with a web browser and features Hyperlinked In > dexes =0Aand Message Navigation.- The .txt file includes the plain ASCII > version =0Aof the RotaxEngines-List Digest and can be viewed with a generic > text editor =0Asuch as Notepad or with a web browser. =0A=0AHTML Version: > =0A=0A- - http://www.matronics.com/digest/digestview.php?Style=82701& > View=html&Chapter 14-01-21&Archive=RotaxEngines=0A=0AText Version: > =0A=0A- - http://www.matronics.com/digest/digestview.php?Style=82701& > View=txt&Chapter 14-01-21&Archive=RotaxEngines=0A=0A=0A=== > ====================0A- EMail Vers > ion of Today's List Digest Archive=0A=========== > ============0A=0A=0A- - - - - ------------ > ----------------------------------------------=0A- - - - - - > - - - - - - - RotaxEngines-List Digest Archive=0A- - - > - - - - - - - - - - - - - - - - ---=0A- > - - - - - - - - - Total Messages Posted Tue 01/21/14: 1 > =0A- - - - - --------------------------------------------------- > -------=0A=0A=0AToday's Message Index:=0A----------------------=0A=0A- > - 1. 04:45 AM - Re: Fuel pump replacement- (Roger Lee)=0A=0A=0A=0A____ > ____________________________- Message 1- ______________________________ > Fuel pump replacement=0AFrom: "Roger Lee" <ssadiver1(at)yahoo.com>=0A=0A=0AHi > Stan,=0A=0ADo you have a re-circulation line? These new pumps new them.=0A > =0A--------=0ARoger Lee=0ATucson, Az.=0ALight Sport Repairman - Maintenance > Rated=0ARotax Repair Center - Heavy Maint. Rated=0AHome 520-574-1080- TR > Y HOME FIRST=0ACell 520-349-7056=0A=0A=0ARead this topic online here:=0A=0A > http://forums.matronics.com/viewtopic.php?p=417347#417347=0A=0A=0A=0A=0A > =========================0A > ================== > > ________________________________ Message 2 _____________________________________ > > > Subject: RotaxEngines-List: Rotax mechanic at SAC > From: Kevin Klinefelter <klinefelter.kevin(at)gmail.com> > > > Anyone know if there is a Rotax mechanic at or near Sacremento Executive airport? > Thanks, Kevin > > > ________________________________ Message 3 _____________________________________ > > > Subject: RotaxEngines-List: Re: RotaxEngines-List Digest: 1 Msgs - 01/21/14 > From: "Roger Lee" <ssadiver1(at)yahoo.com> > > > Yes it's significant, but in a good way. You really need one with the new pump. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417435#417435 > > > ________________________________ Message 4 _____________________________________ > > > From: Michael Woolson <mrwoolson(at)prodigy.net> > Subject: Re: RotaxEngines-List: Rotax mechanic at SAC > > Hi Kevin=0AThere was a few guys based out of Oakland when CPS were active b > ut I'm sure there are others in your area. You might want to contact the we > stern sales contact for the Aerotrek LSA aircraft http://www.aerotrek.aero/ > -if your seeking service for the 912/914.-=0A-=0A-I have yet to mee > t-anyone in the bayarea-that really-knows 2cycle that know what-the > y are doing. I feel they read stuff off the web and fill in the rest as the > y go.=0A-=0ASorry I can't be of more help=0AMike=0ALivermore.CA=0A=0A=0A_ > _______________________________=0A=0A--> RotaxEngines-List message posted b > y: Kevin Klinefelter =0A=0AAnyone know if ther > e is a Rotax mechanic at or near Sacremento Executive airport?=0AThanks, Ke > vin > > ________________________________ Message 5 _____________________________________ > > > Subject: RotaxEngines-List: Re: Rotax mechanic at SAC > From: "Roger Lee" <ssadiver1(at)yahoo.com> > > > Look here. > http://www.rainbowaviation.com/repairman.htm > > and here > > http://rotaxirmt.com/ > > or Jeremy McGregor in Tracy, CA 209-481-5881 > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417440#417440 > > > ________________________________ Message 6 _____________________________________ > > > From: Kevin Klinefelter <klinefelter.kevin(at)gmail.com> > Subject: Re: RotaxEngines-List: Rotax mechanic at SAC > > Mike and Roger, > Thanks for your replies. > Kevin > >> On Jan 22, 2014, at 1:30 PM, Michael Woolson wrote > : >> Hi Kevin >> There was a few guys based out of Oakland when CPS were active but I'm sur > e there are others in your area. You might want to contact the western sales > contact for the Aerotrek LSA aircraft http://www.aerotrek.aero/ if your see > king service for the 912/914. >> >> I have yet to meet anyone in the bayarea that really knows 2cycle that kn > ow what they are doing. I feel they read stuff off the web and fill in the r > est as they go. >> >> Sorry I can't be of more help >> Mike >> Livermore.CA >> >> > vin(at)gmail.com> >> Anyone know if there is a Rotax mechanic at or near Sacremento Executive a > irport? >> Thanks, Kevin >> >> >> >> >> >> >> > 3D===============3 > D============== > ============== > 3D===============3 > D============== > ============== > 3D===============3 > D============== > ============== > 3D===============3 > D============== > ============== > > > > > > > ________________________________________________________________________________
Date: Jan 23, 2014
Kevin, Take a look at Website link, http://aircraftserviceuk.com/ Bill really knows the little devil inside out! Ralph On 1/23/2014 12:01 AM, RotaxEngines-List Digest Server wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RotaxEngines-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RotaxEngines-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 14-01-22&Archive=RotaxEngines > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 14-01-22&Archive=RotaxEngines > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RotaxEngines-List Digest Archive > --- > Total Messages Posted Wed 01/22/14: 6 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 11:09 AM - Re: RotaxEngines-List Digest: 1 Msgs - 01/21/14 (Stan Tew) > 2. 11:25 AM - Rotax mechanic at SAC (Kevin Klinefelter) > 3. 12:11 PM - Re: RotaxEngines-List Digest: 1 Msgs - 01/21/14 (Roger Lee) > 4. 01:30 PM - Re: Rotax mechanic at SAC (Michael Woolson) > 5. 02:45 PM - Re: Rotax mechanic at SAC (Roger Lee) > 6. 06:27 PM - Re: Rotax mechanic at SAC (Kevin Klinefelter) > > > > ________________________________ Message 1 _____________________________________ > > > From: Stan Tew <stan_tew(at)yahoo.com> > Subject: RotaxEngines-List: Re: RotaxEngines-List Digest: 1 Msgs - 01/21/14 > > Yes I have the line returning fuel to the gascolator. Is that significant? > =0A=0A=0A-=0ASTAN 2=0A=0A=0A=0AOn Wednesday, January 22, 2014 2:20 AM, Ro > taxEngines-List Digest Server wrote:=0A > =0A*=0A=0A==================== > =====0A- Online Versions of Today's List Digest Archive=0A= > ========================0A=0A > Today's complete RotaxEngines-List Digest can also be found in either of th > e =0Atwo Web Links listed below.- The .html file includes the Digest form > atted =0Ain HTML for viewing with a web browser and features Hyperlinked In > dexes =0Aand Message Navigation.- The .txt file includes the plain ASCII > version =0Aof the RotaxEngines-List Digest and can be viewed with a generic > text editor =0Asuch as Notepad or with a web browser. =0A=0AHTML Version: > =0A=0A- - http://www.matronics.com/digest/digestview.php?Style=82701& > View=html&Chapter 14-01-21&Archive=RotaxEngines=0A=0AText Version: > =0A=0A- - http://www.matronics.com/digest/digestview.php?Style=82701& > View=txt&Chapter 14-01-21&Archive=RotaxEngines=0A=0A=0A=== > ====================0A- EMail Vers > ion of Today's List Digest Archive=0A=========== > ============0A=0A=0A- - - - - ------------ > ----------------------------------------------=0A- - - - - - > - - - - - - - RotaxEngines-List Digest Archive=0A- - - > - - - - - - - - - - - - - - - - ---=0A- > - - - - - - - - - Total Messages Posted Tue 01/21/14: 1 > =0A- - - - - --------------------------------------------------- > -------=0A=0A=0AToday's Message Index:=0A----------------------=0A=0A- > - 1. 04:45 AM - Re: Fuel pump replacement- (Roger Lee)=0A=0A=0A=0A____ > ____________________________- Message 1- ______________________________ > Fuel pump replacement=0AFrom: "Roger Lee" <ssadiver1(at)yahoo.com>=0A=0A=0AHi > Stan,=0A=0ADo you have a re-circulation line? These new pumps new them.=0A > =0A--------=0ARoger Lee=0ATucson, Az.=0ALight Sport Repairman - Maintenance > Rated=0ARotax Repair Center - Heavy Maint. Rated=0AHome 520-574-1080- TR > Y HOME FIRST=0ACell 520-349-7056=0A=0A=0ARead this topic online here:=0A=0A > http://forums.matronics.com/viewtopic.php?p=417347#417347=0A=0A=0A=0A=0A > =========================0A > ================== > > ________________________________ Message 2 _____________________________________ > > > Subject: RotaxEngines-List: Rotax mechanic at SAC > From: Kevin Klinefelter <klinefelter.kevin(at)gmail.com> > > > Anyone know if there is a Rotax mechanic at or near Sacremento Executive airport? > Thanks, Kevin > > > ________________________________ Message 3 _____________________________________ > > > Subject: RotaxEngines-List: Re: RotaxEngines-List Digest: 1 Msgs - 01/21/14 > From: "Roger Lee" <ssadiver1(at)yahoo.com> > > > Yes it's significant, but in a good way. You really need one with the new pump. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417435#417435 > > > ________________________________ Message 4 _____________________________________ > > > From: Michael Woolson <mrwoolson(at)prodigy.net> > Subject: Re: RotaxEngines-List: Rotax mechanic at SAC > > Hi Kevin=0AThere was a few guys based out of Oakland when CPS were active b > ut I'm sure there are others in your area. You might want to contact the we > stern sales contact for the Aerotrek LSA aircraft http://www.aerotrek.aero/ > -if your seeking service for the 912/914.-=0A-=0A-I have yet to mee > t-anyone in the bayarea-that really-knows 2cycle that know what-the > y are doing. I feel they read stuff off the web and fill in the rest as the > y go.=0A-=0ASorry I can't be of more help=0AMike=0ALivermore.CA=0A=0A=0A_ > _______________________________=0A=0A--> RotaxEngines-List message posted b > y: Kevin Klinefelter =0A=0AAnyone know if ther > e is a Rotax mechanic at or near Sacremento Executive airport?=0AThanks, Ke > vin > > ________________________________ Message 5 _____________________________________ > > > Subject: RotaxEngines-List: Re: Rotax mechanic at SAC > From: "Roger Lee" <ssadiver1(at)yahoo.com> > > > Look here. > http://www.rainbowaviation.com/repairman.htm > > and here > > http://rotaxirmt.com/ > > or Jeremy McGregor in Tracy, CA 209-481-5881 > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417440#417440 > > > ________________________________ Message 6 _____________________________________ > > > From: Kevin Klinefelter <klinefelter.kevin(at)gmail.com> > Subject: Re: RotaxEngines-List: Rotax mechanic at SAC > > Mike and Roger, > Thanks for your replies. > Kevin > >> On Jan 22, 2014, at 1:30 PM, Michael Woolson wrote > : >> Hi Kevin >> There was a few guys based out of Oakland when CPS were active but I'm sur > e there are others in your area. You might want to contact the western sales > contact for the Aerotrek LSA aircraft http://www.aerotrek.aero/ if your see > king service for the 912/914. >> >> I have yet to meet anyone in the bayarea that really knows 2cycle that kn > ow what they are doing. I feel they read stuff off the web and fill in the r > est as they go. >> >> Sorry I can't be of more help >> Mike >> Livermore.CA >> >> > vin(at)gmail.com> >> Anyone know if there is a Rotax mechanic at or near Sacremento Executive a > irport? >> Thanks, Kevin >> >> >> >> >> >> >> > 3D===============3 > D============== > ============== > 3D===============3 > D============== > ============== > 3D===============3 > D============== > ============== > 3D===============3 > D============== > ============== > > > > > > > ________________________________________________________________________________
Subject: Dyna Vibe Prop Dynamic Balancer Question
Date: Jan 24, 2014
Maybe Roger Lee can answer this one: I purchased a Dyna Vibe dynamic prop balancer and the instructions seem clear except for this statement: "If the accelerometer cable is pointing away from the center of the bub, then the angle reported by the Dyna Vibe is the HEAVY spot (where to remove weight, or 180 degrees from where to add weight.) If you flip it so the accelerometer cable is pointing toward the hub, then the reading will indicate the light spot (where to ADD weight.)" Question: How can be orientation of the cable (not the accelerometer) change what the reading angle means? (ie, heavy or light) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417551#417551 ________________________________________________________________________________
Subject: Re: Dyna Vibe Prop Dynamic Balancer Question
Date: Jan 25, 2014
Hi John, Sorry I'm out of the info loop on this one. I don't have a clue. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417561#417561 ________________________________________________________________________________
Date: Jan 25, 2014
John: I missed the question... I have a Dyna Vibe, how can I help? Barry On Sat, Jan 25, 2014 at 7:47 AM, Roger Lee wrote: > > Hi John, > > Sorry I'm out of the info loop on this one. I don't have a clue. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417561#417561 > > ________________________________________________________________________________
Date: Jan 25, 2014
Hi John: I just read the original post. The answer is: It Can't! It has to be a misprint. I'm thinking it is easier to describe the accelerometer by identifying the cable as apposed to the mounting threads. Which will be hidden when mounted. Can you tell me what page that statement is on? And also what revision of the manual you are reading? If you really wanted to attempt something crazy, YES, you could make a mount that points the accelerometer way from the HUB (Center of the shaft). And that would give you the Lite Point, but, you would probably be adding all sorts of erroneous vibrations due to the extended size of the bracket. I do not understand why Dyna Vibe did not simply have the feature of REVERSING the math or the output of the accelerometer. Or why they used such a large housing for the accelerometer; phones and iPads have surface mount accelerometers that are only 0.100" high and 0.250" square. Take that and pot it and you are done. Oh, well! It works. Barry On Fri, Jan 24, 2014 at 11:49 PM, JohnF wrote: > > Maybe Roger Lee can answer this one: > > I purchased a Dyna Vibe dynamic prop balancer and the instructions seem > clear except for this statement: > > "If the accelerometer cable is pointing away from the center of the bub, > then the angle reported by the Dyna Vibe is the HEAVY spot (where to remove > weight, or 180 degrees from where to add weight.) If you flip it so the > accelerometer cable is pointing toward the hub, then the reading will > indicate the light spot (where to ADD weight.)" > > Question: How can be orientation of the cable (not the accelerometer) > change what the reading angle means? (ie, heavy or light) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417551#417551 > > ________________________________________________________________________________
Date: Jan 25, 2014
Barry, thank you for the response. The statement is on page 33 of the manual, second paragraph from the bottom. I have version 1-07. I am repeating below the answer I got from Dyna Vibe which I will have to read and re-read several times to try to understand it.. One other question I have is just exactly what is the 'axis of the accelerometer' - is the vertical orientation of the unit, or some rotational position? I don't have a clue. Anyway, here is the answer from RPX...maybe you can help me clarify what they are telliing me. Fun question. It has to do with the timing of the signals and what the accelerometer "feels" vs when it feels it with respect to the optical tach signal. If the accelerometer is rotated 180 degrees then the signals are backwards. That's why the solution flips (heavy vs light). If you are 90 degrees, then you will sense engine rotation in addition to vibration but the vibration will be rotated 90 degrees and mixed with rotational vibration. So that's not really useful. If you are at 45 degrees, then you will sense rotation and vibration, but at a complex angle. So the math would be quite convolved. You would have to separate rotation, x vibration, and y vibration, which can't be done without more sensors to see what is going on. But I don't think you are looking for the literal answer to your question. So the actual answer is that you want the axis of the accelerometer pointing toward the center of rotation. If it isn't, then you start sensing rotational vibration which isn't what you are looking for. And if the sensor is backwards, then the math in the meter will be backwards. Which explains the heavy vs light statement Thanks again for your ehlp. John ----- Original Message ----- From: FLYaDIVE To: rotaxengines-list(at)matronics.com Sent: Saturday, January 25, 2014 6:42 AM Subject: Re: RotaxEngines-List: Dyna Vibe Prop Dynamic Balancer Question Hi John: I just read the original post. The answer is: It Can't! It has to be a misprint. I'm thinking it is easier to describe the accelerometer by identifying the cable as apposed to the mounting threads. Which will be hidden when mounted. Can you tell me what page that statement is on? And also what revision of the manual you are reading? If you really wanted to attempt something crazy, YES, you could make a mount that points the accelerometer way from the HUB (Center of the shaft). And that would give you the Lite Point, but, you would probably be adding all sorts of erroneous vibrations due to the extended size of the bracket. I do not understand why Dyna Vibe did not simply have the feature of REVERSING the math or the output of the accelerometer. Or why they used such a large housing for the accelerometer; phones and iPads have surface mount accelerometers that are only 0.100" high and 0.250" square. Take that and pot it and you are done. Oh, well! It works. Barry On Fri, Jan 24, 2014 at 11:49 PM, JohnF wrote: Maybe Roger Lee can answer this one: I purchased a Dyna Vibe dynamic prop balancer and the instructions seem clear except for this statement: "If the accelerometer cable is pointing away from the center of the bub, then the angle reported by the Dyna Vibe is the HEAVY spot (where to remove weight, or 180 degrees from where to add weight.) If you flip it so the accelerometer cable is pointing toward the hub, then the reading will indicate the light spot (where to ADD weight.)" Question: How can be orientation of the cable (not the accelerometer) change what the reading angle means? (ie, heavy or light) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417551#417551 ========== -List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Jan 25, 2014
John: The answer can be quite confusing. Why? Because I'm an engineer and there are no simple answers ;-) Ok, the short version: There are Three (3) primary axis's: X - Y - Z X - is the Horizontal axis from Left to Right. Y - Is the Vertical axis and is perpendicular to the X axis consider the letter L Z - is ... Harder to explain, take the letter L and draw a line from the point where the Vertical and Horizontal come together BUT - Draw it straight out towards you. Now, 'axis of the accelerometer'. That is the way it is mounted... It should be Vertical - Straight Up and Down. AND mounted ON TOP of the engine - - - What Dyna Vibe is also explaining is the relationship between the Accelerometer and the Photo Eye for obtaining the RPM. ALL your reading will be in reference to the photo eye and what you deem the #1 blade of the prop. The degree position of rotation is in relationship to the photo eye. SO... If the Accelerometer is mounted on the Center-Line (C/L) of the engine and the photo eye is off to one side (as in the pictures in the manual) the degree indication of the Heavy point will NOT align with the Accelerometer. AND THIS will drive you crazy when you try to put the balance weights on. Example: The Dyna Vibe will say the heavy point is 090 Deg... You add 180 Deg and get 270 Deg... BUT! The photo eye is OFF C/L to the right (facing) by say 1"... That will ADD about 15 Deg to the 270 reading and give you 285 Deg for the lite point. If you do not consider this little fact you will chasing your tail trying to find the prop balance point. How do you correct this error? Make a bracket that puts the Accelerometer and Photo Eye on the same Vertical Y axis. I should sell these brackets but the price would be too high... I read the response from Dyna Vibe... Yea, I understand it but it is not very clear. They could have done a better job. Go with my above explanation and things will work out correctly. Now, my question: What plane and engine are you trying to balance? I want to balance a friends Rotax Pusher but there is NO ring gear/flywheel, where can I put the weights? It is also a three (3) blade prop. <-- That makes no difference - Can do! Barry On Sat, Jan 25, 2014 at 10:30 AM, JohnF wrote: > Barry, thank you for the response. The statement is on page 33 of the > manual, second paragraph from the bottom. I have version 1-07. I am > repeating below the answer I got from Dyna Vibe which I will have to read > and re-read several times to try to understand it.. > > One other question I have is just exactly what is the 'axis of the > accelerometer' - is the vertical orientation of the unit, or some > rotational position? I don't have a clue. > > Anyway, here is the answer from RPX...maybe you can help me clarify what > they are telliing me. > > > Fun question. > > It has to do with the timing of the signals and what the accelerometer > =93feels=94 vs when it feels it with respect to the optical tach signal. If the > accelerometer is rotated 180 degrees then the signals are backwards. That =92s > why the solution flips (heavy vs light). If you are 90 degrees, then you > will sense engine rotation in addition to vibration but the vibration wil l > be rotated 90 degrees and mixed with rotational vibration. So that=92s no t > really useful. If you are at 45 degrees, then you will sense rotation and > vibration, but at a complex angle. So the math would be quite convolved. > You would have to separate rotation, x vibration, and y vibration, which > can=92t be done without more sensors to see what is going on. > > But I don=92t think you are looking for the literal answer to your > question. So the actual answer is that you want the axis of the > accelerometer pointing toward the center of rotation. If it isn=92t, then you > start sensing rotational vibration which isn=92t what you are looking for . > And if the sensor is backwards, then the math in the meter will be > backwards. Which explains the heavy vs light statement > Thanks again for your ehlp. > > John > > > ----- Original Message ----- > *From:* FLYaDIVE > *To:* rotaxengines-list(at)matronics.com > *Sent:* Saturday, January 25, 2014 6:42 AM > *Subject:* Re: RotaxEngines-List: Dyna Vibe Prop Dynamic Balancer Questio n > > Hi John: > > I just read the original post. > The answer is: It Can't! > It has to be a misprint. > I'm thinking it is easier to describe the accelerometer by identifying th e > cable as apposed to the mounting threads. Which will be hidden when mount ed. > Can you tell me what page that statement is on? And also what revision o f > the manual you are reading? > > If you really wanted to attempt something crazy, YES, you could make a > mount that points the accelerometer way from the HUB (Center of the > shaft). And that would give you the Lite Point, but, you would probably be > adding all sorts of erroneous vibrations due to the extended size of the > bracket. I do not understand why Dyna Vibe did not simply have the featu re > of REVERSING the math or the output of the accelerometer. Or why they > used such a large housing for the accelerometer; phones and iPads have > surface mount accelerometers that are only 0.100" high and 0.250" square. > Take that and pot it and you are done. Oh, well! It works. > > Barry > > > On Fri, Jan 24, 2014 at 11:49 PM, JohnF wrote: > >> >> Maybe Roger Lee can answer this one: >> >> I purchased a Dyna Vibe dynamic prop balancer and the instructions seem >> clear except for this statement: >> >> "If the accelerometer cable is pointing away from the center of the bub, >> then the angle reported by the Dyna Vibe is the HEAVY spot (where to rem ove >> weight, or 180 degrees from where to add weight.) If you flip it so the >> accelerometer cable is pointing toward the hub, then the reading will >> indicate the light spot (where to ADD weight.)" >> >> Question: How can be orientation of the cable (not the accelerometer) >> change what the reading angle means? (ie, heavy or light) >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=417551#417551 >> >> >> >> >> >> >> >> ========== >> -List" target="_blank"> >> http://www.matronics.com/Navigator?RotaxEngines-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > href="http://www.matronics.com/Navigator?RotaxEngines-List ">http://www.matronics.com/Naviga tor?RotaxEngines-List <http://www.matronics.com/Navigator?RotaxEngines-List > > href="http://forums.matronics.com ">http:/ /forums.matronics.com <http://forums.matronics.com> > href="http://www.matronics.com/contribution ">http://www.matronics.com/c > * > > * > =========== www.matronics.com/Navigator?RotaxEngines-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Jan 25, 2014
Right you are John! "I agree that RXP could improve their manual.....its hard to write clearly when you have total knowledge of the subject and are writing to someone else that isn't on board yet. You can easily forget to be detailed enough to satisfy the uninformed mind. Cheers John" John: I wrote many a procedure and manual and you have to write as if the person reading is not in the room with you and had no knowledge of the subject. I use to say many a tech writer cannot see the forest, for the trees. Just look at Micro Soft... The information they supplied was totally accurate, but totally useless. Barry On Sat, Jan 25, 2014 at 10:30 AM, JohnF wrote: > Barry, thank you for the response. The statement is on page 33 of the > manual, second paragraph from the bottom. I have version 1-07. I am > repeating below the answer I got from Dyna Vibe which I will have to read > and re-read several times to try to understand it.. > > One other question I have is just exactly what is the 'axis of the > accelerometer' - is the vertical orientation of the unit, or some > rotational position? I don't have a clue. > > Anyway, here is the answer from RPX...maybe you can help me clarify what > they are telliing me. > > > Fun question. > > It has to do with the timing of the signals and what the accelerometer > =93feels=94 vs when it feels it with respect to the optical tach signal. If the > accelerometer is rotated 180 degrees then the signals are backwards. That =92s > why the solution flips (heavy vs light). If you are 90 degrees, then you > will sense engine rotation in addition to vibration but the vibration wil l > be rotated 90 degrees and mixed with rotational vibration. So that=92s no t > really useful. If you are at 45 degrees, then you will sense rotation and > vibration, but at a complex angle. So the math would be quite convolved. > You would have to separate rotation, x vibration, and y vibration, which > can=92t be done without more sensors to see what is going on. > > But I don=92t think you are looking for the literal answer to your > question. So the actual answer is that you want the axis of the > accelerometer pointing toward the center of rotation. If it isn=92t, then you > start sensing rotational vibration which isn=92t what you are looking for . > And if the sensor is backwards, then the math in the meter will be > backwards. Which explains the heavy vs light statement > Thanks again for your ehlp. > > John > > > ----- Original Message ----- > *From:* FLYaDIVE > *To:* rotaxengines-list(at)matronics.com > *Sent:* Saturday, January 25, 2014 6:42 AM > *Subject:* Re: RotaxEngines-List: Dyna Vibe Prop Dynamic Balancer Questio n > > Hi John: > > I just read the original post. > The answer is: It Can't! > It has to be a misprint. > I'm thinking it is easier to describe the accelerometer by identifying th e > cable as apposed to the mounting threads. Which will be hidden when mount ed. > Can you tell me what page that statement is on? And also what revision o f > the manual you are reading? > > If you really wanted to attempt something crazy, YES, you could make a > mount that points the accelerometer way from the HUB (Center of the > shaft). And that would give you the Lite Point, but, you would probably be > adding all sorts of erroneous vibrations due to the extended size of the > bracket. I do not understand why Dyna Vibe did not simply have the featu re > of REVERSING the math or the output of the accelerometer. Or why they > used such a large housing for the accelerometer; phones and iPads have > surface mount accelerometers that are only 0.100" high and 0.250" square. > Take that and pot it and you are done. Oh, well! It works. > > Barry > > > On Fri, Jan 24, 2014 at 11:49 PM, JohnF wrote: > >> >> Maybe Roger Lee can answer this one: >> >> I purchased a Dyna Vibe dynamic prop balancer and the instructions seem >> clear except for this statement: >> >> "If the accelerometer cable is pointing away from the center of the bub, >> then the angle reported by the Dyna Vibe is the HEAVY spot (where to rem ove >> weight, or 180 degrees from where to add weight.) If you flip it so the >> accelerometer cable is pointing toward the hub, then the reading will >> indicate the light spot (where to ADD weight.)" >> >> Question: How can be orientation of the cable (not the accelerometer) >> change what the reading angle means? (ie, heavy or light) >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=417551#417551 >> >> >> >> >> >> >> >> ========== >> -List" target="_blank"> >> http://www.matronics.com/Navigator?RotaxEngines-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > href="http://www.matronics.com/Navigator?RotaxEngines-List ">http://www.matronics.com/Naviga tor?RotaxEngines-List <http://www.matronics.com/Navigator?RotaxEngines-List > > href="http://forums.matronics.com ">http:/ /forums.matronics.com <http://forums.matronics.com> > href="http://www.matronics.com/contribution ">http://www.matronics.com/c > * > > * > =========== www.matronics.com/Navigator?RotaxEngines-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Subject: spark plug wire pulled out of ignition coil 912ul
Date: Feb 07, 2014
During some obviously ham handed treatment trying to get my ignition mounted I pulled one of the spark plug wires out of the ignition coil. Has anyone experienced this and is there a fix short of buying a new coil ? thanks EG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=418317#418317 ________________________________________________________________________________
Subject: Re: spark plug wire pulled out of ignition coil 912ul
Date: Feb 08, 2014
Hi Skip, yes they can. They just screw in place over a threaded spike inside the coil insertion point. Same as the spark plug boot. Trim it back 1/4" - 3/8" to get clean undamaged wire. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=418345#418345 ________________________________________________________________________________
Subject: Introduction John Hauck
Date: Feb 10, 2014
Hi Folks: My name is John Hauck. Have owned and flown with Rotax 912 (before the days of the 912UL and ULS) beginning in 1992. Started out with a 912, then two 912ULS's. Have accumulated a little over 3,000 hours on these engine during the past 22 years. I fly a 1992 Kolb MKIII. The first 220 hours on the airframe I used a 582, that promptly seized in 1993. What a difference the 912 engines made on the MKIII. Hope to learn more about our engines here. Maybe I can pass along some of the experiences I have had flying two and four stroke Rotax engines for the past 30 years. -------- John Hauck MKIII/912ULS hauck's holler Titus, Alabama Read this topic online here: http://forums.matronics.com/viewtopic.php?p=418457#418457 ________________________________________________________________________________
Subject: 912 Spark Plugs
Date: Feb 10, 2014
Hi Folks: I've been using iridium spark plugs in my 95 Nissan V6, Suzuki DRZ400E, and Honda Ricon, for some time now with excellent results. My questions to the Rotax Engine List are: Has anyone experimented with NGK DCPR7EIX/DCPR8EIX spark plugs in the 912UL/912ULS engines? Anyone have any info from ROTAX reference use of iridium plugs? I have never had any problems with DCPR7E/DCPR8E plugs in my 912UL/912ULS engines. Thanks, -------- John Hauck MKIII/912ULS hauck's holler Titus, Alabama Read this topic online here: http://forums.matronics.com/viewtopic.php?p=418464#418464 ________________________________________________________________________________
Subject: Re: 912 Spark Plugs
Date: Feb 10, 2014
The iridium's will work, but I don't know if you really get any more for your money. They are almost triple the price. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=418506#418506 ________________________________________________________________________________
Date: Feb 10, 2014
Over the years we have gotten good results running the standard plug well past the 100 and 200 hour limits for the 912ULS and 912UL. John Williamson went past 200 hours with his 912ULS. I've been flying these engines for a long time. I always hate to change them because I can never see any increase in performance with a new set of plugs. Back in the days of the 912, 1993, a DCPR7ES cost about 9.00 each. Rotax was the only supplier. I contacted the US Distributor for NGK to find another source, but there was none. There was nothing extraordinary about the DCPR7ES, but ROTAX's price. I think the iridium plugs will go much, much further. Eventually, Rotax will probably start supplying them. If I didn't have a fresh set of DCPR8ES plugs to install, I'd spring for a set of iridium. My main concern was if they had the same rib pattern and screw off nuts. From photos, looks like they have the ribs and specs indicate screw off nuts. I'll have to wait another 100 hours to do some experimenting. Surprised no one has not already tried them. -------- John Hauck MKIII/912ULS hauck's holler Titus, Alabama Read this topic online here: http://forums.matronics.com/viewtopic.php?p=418509#418509 ________________________________________________________________________________
Subject: Greetings from Iceland
From: =?utf-8?Q?J=C3=B3hann_Gestur_J=C3=B3hannsson?= <joeing701(at)simnet.is>
Date: Feb 11, 2014
Hello John and welcome to the Rotax list. Glad to hear from you again. We will definetly benifit from your experience on this list. Good to hear that you are still enjoying your Kolb. My plane is a Zenith 701 with a Rotax 912 ul. Building one with the uls. First flight scheduled in 2015. Look forward to hear your comments on the list. Johann G. Iceland. Sent from my iPad ________________________________________________________________________________
Date: Feb 11, 2014
You can buy NGK DCPR8E plugs for about $2.80 each ($22.40 total). Iridium's are about $9 each ($72 total). You can afford to have new plugs 3 times for the price of iridium's. Iridium's will still need to be gapped and cleaned. Any leaded fuel will still deposit lead. I know you travel a lot so you may use 100LL more often than some? -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=418523#418523 ________________________________________________________________________________
Date: Feb 11, 2014
I found NGK Iridium Plugs, DCPR8EIX, last night for 6.99 at the local O'reilly's Auto. I get a 10% military discount, so that brings them down to 6.30 each. I can afford that. Only time I ever fouled a plug was a DCPR7E on the 912 during a flight to Alaska in 1994. Wasn't a problem, just an annoyance until I got on the ground in Sault Saint Marie, Ontario, where I cleaned it with my pin knife. Haven't had a problem with lead fouling on the 912 or the 912ULS's since. Yes, I burn a lot of 100LL. All one can get on cross country flights. On a normal flight out West I will fly about 75 hours and burn 375 gals of 100LL. I fly at 5,000 rpm and higher, always. Don't believe in babying the 912. That and a little Marvel Mystery Oil keeps the 912ULS happy. On one trip to Alaska I used Alcor TCP. Didn't seem to do any better job than the MMO. I believe I will get a little improvement with the iridium plugs. Will only know once I get them installed and when the weather gets a bit better, get some time on them. Thanks for the info from Roger Lee and the welcome from Johann J, an old friend from the Kolb List. -------- John Hauck MKIII/912ULS hauck's holler Titus, Alabama Read this topic online here: http://forums.matronics.com/viewtopic.php?p=418537#418537 ________________________________________________________________________________
Subject: Refitting the fly wheel
Date: Feb 12, 2014
Hello Rotax owners. I am about to re-fit the fly wheel on my Rotax 912 uls engine after installing a new stator assy. The heavy maintenance manual states that it should be tightened to 45 Nm + 180 deg. Angle to rotation. This should be around 1062 in/pounds. This is a lot for only one stop bolt on the crankshaft. Will this procedure be safe for the crankshaft not to twist under all this force? Regards, Johann G. Sent from my iPad ________________________________________________________________________________
Subject: Re: Refitting the fly wheel
Date: Feb 12, 2014
This is about 88 ft/lbs. The one on the PTO side inside the gearbox gets around 149 ft/lbs. It isn't so bad when you compare. 45nm is 398 in/lbs or 33 ft/lbs. I'm not 100% sure what the extra 180 degree turn would yield, but is common on head bolts and the like to apply a certain torque followed by a certain amount of degree turn. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=418638#418638 ________________________________________________________________________________
From: =?iso-8859-1?Q?J=F3hann_J=F3hannsson?= <joeing701(at)simnet.is>
Date: Feb 13, 2014
Thank you again, Roger, for you help. It was not as extreme as I had thought when I had the right tool. Flywheel torqued according to the manual. Best regards, Johann G. On 13.2.2014, at 00:39, Roger Lee wrote: > > This is about 88 ft/lbs. The one on the PTO side inside the gearbox gets around 149 ft/lbs. It isn't so bad when you compare. 45nm is 398 in/lbs or 33 ft/lbs. I'm not 100% sure what the extra 180 degree turn would yield, but is common on head bolts and the like to apply a certain torque followed by a certain amount of degree turn. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=418638#418638 > > > > > > > > > > ________________________________________________________________________________
Subject: Oil Thermostat
From: "Richard Wheelwright" <rpwheelwright(at)yahoo.co.uk>
Date: Feb 16, 2014
Oil Thermostat I'm considering fitting the Oil thermostat supplyed by Conair in the UK (Approved LAA Mod) My Question is. After removing my cowl and considering the best location to mount the thermostat, Does anyone have any pictures of a suggested location. As the thermostat is quite large with the hose connections fitted to it. Thank you in advance Richard Wheelwright G-IRPW Read this topic online here: http://forums.matronics.com/viewtopic.php?p=418803#418803 ________________________________________________________________________________
Subject: Re: Oil Thermostat
Date: Feb 16, 2014
Mocal A0T2-7 -8AN Male. Mount where vacuum pump would mount. Jim -----Original Message----- From: Richard Wheelwright Sent: Sunday, February 16, 2014 1:29 PM Subject: RotaxEngines-List: Oil Thermostat Oil Thermostat I'm considering fitting the Oil thermostat supplyed by Conair in the UK (Approved LAA Mod) My Question is. After removing my cowl and considering the best location to mount the thermostat, Does anyone have any pictures of a suggested location. As the thermostat is quite large with the hose connections fitted to it. Thank you in advance Richard Wheelwright G-IRPW Read this topic online here: http://forums.matronics.com/viewtopic.php?p=418803#418803 ________________________________________________________________________________
Date: Feb 16, 2014
From: Richard Wheelwright <rpwheelwright(at)yahoo.co.uk>
Jim,=0A- - Thank you for your reply. Yes that sounds like a good locati on. The only thing with that is the LAA mod instructions only says Do not m ount directly to the Engine. Other wise it would be good to go.=0A=0ARegard s=0A-=0A===================== =========================0A =0ARichard Wheelwright=0A================ =====0A=0A=0A=0AOn Sunday, 16 February 2014, 21:21, Jim Roberts wrote:=0A =0AMocal A0T2-7 -8AN Male.- Mount where vacuum pump would mount.=0AJim=0A=0A=0A-----Original Message----- =0AFrom: Richard Wheelwright=0ASent: Sunday, February 16, 2014 1:29 PM=0ATo: rotaxengines-l ist(at)matronics.com=0ASubject: RotaxEngines-List: Oil Thermostat=0A=0A--> Rot axEngines-List message posted by: "Richard Wheelwright" =0A=0A=0AOil Thermostat=0A=0AI'm considering fitting the Oil thermo stat supplyed by Conair in the UK =0A(Approved LAA Mod) My Question is. Aft er removing my cowl and considering =0Athe best location to mount the therm ostat, Does anyone have any pictures of =0Aa suggested location. As the the rmostat is quite large with the hose =0Aconnections fitted to it.=0A=0AThan k you in advance=0A=0ARichard Wheelwright=0AG-IRPW=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=41880 3#418803 ________________________________________________________________________________
Date: Feb 16, 2014
Richard For what it worth, here are pictures of a THERMOSTASIS oil thermostat installed on 912ULS in my RANS S6S Works perfect for me Nati Illinois, US On Sun, Feb 16, 2014 at 1:29 PM, Richard Wheelwright < rpwheelwright(at)yahoo.co.uk> wrote: > rpwheelwright(at)yahoo.co.uk> > > Oil Thermostat > > I'm considering fitting the Oil thermostat supplyed by Conair in the UK > (Approved LAA Mod) My Question is. After removing my cowl and considering > the best location to mount the thermostat, Does anyone have any pictures of > a suggested location. As the thermostat is quite large with the hose > connections fitted to it. > > Thank you in advance > > Richard Wheelwright > G-IRPW > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=418803#418803 > > ________________________________________________________________________________
From: Aircraft Specialty <aircraftspecialty(at)gmail.com>
Date: Feb 16, 2014
Date: Feb 21, 2014
The iridium electrode plugs feature perhaps the lowest rate of electrode lo ss or wear over time.- They make sense for high energy ignition systems. - The Rotax ignition system is a low energy system where standard spark p lug electrode wear over time is very low.- I appreciate the low maintenan ce of iridium spark plugs in my autos, but do not feel they are a good inve stment for my Rotax 912.- I consider iridium spark plugs in my autos to b e life time plugs.- I have a Toyota that is at 200,000 miles with the ori ginal iridium spark plugs still performing as if the auto were new.--Af ter first 100,000 miles, the electrode gap had changed only 1.5 - 2.0 thous andths!- When I do pull them, I check for gas leakage around the porcelai n insulator before regaping and reinstallation.- Some auto manufacturers spec their autos equipped with iridium spark plugs for spark plug service a fter 100,000 miles.=0ADavid Weaver N012GR=0A- =0A =0A=0A_________________ _______________=0A From: Roger Lee <ssadiver1(at)yahoo.com>=0ATo: rotaxengines -list(at)matronics.com =0ASent: Monday, February 10, 2014 6:49 PM=0ASubject: R otaxEngines-List: Re: 912 Spark Plugs=0A =0A=0A--> RotaxEngines-List messa ge posted by: "Roger Lee" =0A=0AThe iridium's will wor k, but I don't know if you really get any more for your money. They are alm ost triple the price.=0A=0A--------=0ARoger Lee=0ATucson, Az.=0ALight Sport Repairman - Maintenance Rated=0ARotax Repair Center - Heavy Maint. Rated =0AHome 520-574-1080- TRY HOME FIRST=0ACell 520-349-7056=0A=0A=0A=0A=0ARe ad this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p =========================0A - - - - - - - - - - - - - -Matt Dralle, List Adm ===== ________________________________________________________________________________
Date: Feb 21, 2014
David: You are using reverse logic. The poorer the ignition system the more you should do to improve it. Not to keep it poor. The advantage of iridium or platinum plugs are: 1 - Harder denser material which will not reverse deposit, deteriorating away the electrode. 2 - Higher corrosion protection so the electrodes will not rust away loosing material. 3 - Higher resistance to erosion at high temperatures both from the heat of the engine and the heat of the electric spark. 4 - Lower electrical resistance. 5 - Smaller surface area which reduces carbon and lead fouling. I know, I know, this sounds like reverse logic, doesn't it! - Because you would think that MORE area would be required so when you get carbon and lead fouling more area would be available for the spark to jump across the electrodes. NOT SO! Better conduction, with smaller area, allows the carbon and lead fouling to be blown off an NOT get a foot hold. Contrary to popular opinion - More is not always better. Consider the Massive Electro Plugs - No where near as good as the 'BY' series or the better iridium plugs. I do not understand why a new engines like the Rotax do not have a modern ignition system. You would think that all that was learned over the past 104 years of aviation and automobiles - SOME of it would be applied to today's engines. Car ignition systems of today produce 60,000 to 100,000 Volts to make a spark. Yes, there are some systems today that are up there, some, very few. As for co$t. I don't think you will find anyone else as tight fist'd as I. And even so when you compare: A basic plug of $2.50 Vs a iridium plug of $7.50 ... What are you talking about a $5 difference!!! That would be $25 more for an entire engine that cost you $18,000! $25 would buy you about 4.5 gallons of AvGas or 6.5 gallons of MoGas. How much is it worth NOT to get stranded and NOT have to pull & clean the plugs? This is one area where I want to hedge my bet. Barry On Fri, Feb 21, 2014 at 9:08 AM, David Weaver wrote: > The iridium electrode plugs feature perhaps the lowest rate of electrode > loss or wear over time. They make sense for high energy ignition systems. > The Rotax ignition system is a low energy system where standard spark plug > electrode wear over time is very low. I appreciate the low maintenance of > iridium spark plugs in my autos, but do not feel they are a good investment > for my Rotax 912. I consider iridium spark plugs in my autos to be life > time plugs. I have a Toyota that is at 200,000 miles with the original > iridium spark plugs still performing as if the auto were new. After first > 100,000 miles, the electrode gap had changed only 1.5 - 2.0 thousandths! > When I do pull them, I check for gas leakage around the porcelain insulator > before regaping and reinstallation. Some auto manufacturers spec their > autos equipped with iridium spark plugs for spark plug service after > 100,000 miles. > David Weaver N012GR > > *From:* Roger Lee > *To:* rotaxengines-list(at)matronics.com > *Sent:* Monday, February 10, 2014 6:49 PM > *Subject:* RotaxEngines-List: Re: 912 Spark Plugs > > > The iridium's will work, but I don't know if you really get any more for > your money. They are almost triple the price. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopnbsp; -Matt > Dralle,=========== > > > * > > > * > > ________________________________________________________________________________
Date: Feb 21, 2014
I have a set of DCPR8EIX NGK's to install as soon as I get a chance. Anxious to see how they perform in the 912ULS compared to the DCPR8E NGK's. If I get a little more power, I'll take it. If I get a little bit better fuel burn, I'll take that too. I paid twice as much for the iridium plugs as I would have for standard plugs. I'm sure I can get 200 hours out of them, we did that with DCPR8E's in the 912ULS. At the rate I have been flying the last couple years, those iridium plugs may last the rest of my life. ;-) -------- John Hauck MKIII/912ULS hauck's holler Titus, Alabama Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419114#419114 ________________________________________________________________________________
Subject: Rotax 91X 26 amp Gen2 $137.50 per amp
Date: Feb 21, 2014
Hi Group Those who have a Rotax 91X know things aren't cheap. Here's a 26 amp Gen2 for $137.50 per amp: http://sportair.aero/12-epapower/epapower/ Ron Parigoris BTW if you are a real die hard you can put one on the 130 HP 915 for $57,250 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=419116#419116 ________________________________________________________________________________
Date: Feb 21, 2014
I have over 350 hours on a 912-UL engine burning no-lead auto fuel.- I pu rchased an extra set of standard NGK plugs so I could have a clean extra se t to swap out on periodic inspection.- It appears that the standard plugs may last for the first 1,000 hours of engine operation simply by cleaning and readjusting electrode gap as necessary.- I know some believe cleaning spark plugs to be improper procedure and dirty plugs should be replaced. - It is hard for me to change what I have learned from experience working on gas engines from the time that we were polarizing replacement voltage r egulators on automotive electrical system with generators.- When it comes time to replace the-manufacturer specked-spark plugs, I will install t he iridium equivalent and fully expect to see no change in engine performan ce.-=0ADave Weaver N912GR=0A =0A=0A________________________________=0A Fr om: John Hauck =0ATo: rotaxengines-list(at)matronics.com =0ASent: Friday, February 21, 2014 7:05 AM=0ASubject: RotaxEngines-List: R Hauck" =0A=0AI have a set of DCPR8EIX NGK's to insta ll as soon as I get a chance.- Anxious to see how they perform in the 912 ULS compared to the DCPR8E NGK's.- If I get a little more power, I'll tak e it.- If I get a little bit better fuel burn, I'll take that too.=0A=0AI paid twice as much for the iridium plugs as I would have for standard plug s.- I'm sure I can get 200 hours out of them, we did that with DCPR8E's i n the 912ULS.=0A=0AAt the rate I have been flying the last couple years, th ose iridium plugs may last the rest of my life.- ;-)=0A=0A--------=0AJohn Hauck=0AMKIII/912ULS=0Ahauck's holler=0ATitus, Alabama=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p= - - - - - - - - - - - - - -Matt Dralle, List Adm ===== ________________________________________________________________________________
Date: Feb 21, 2014
Hi Folks: The 912UL is much easier on spark plugs than the 912ULS, having discovered this by flying 1250.0 hours with my 912 (bought it before the 912UL/912ULS were developed), and 2,000.0+ hours on my 912ULS's. On a steady diet of MOGAS, the 912UL might just make it to 1,000.0 hours on a set of plugs, but I imagine there won't be much left of the electrode and ground strap. I pulled my old DCPR8ES's out of the 912ULS this morning and replaced with DCPR8EIX's. Comparing the two plugs it seems to me that the newer technology will work a lot better in my engine. I am going to think positive and hope for a slight improvement in performance. I can use all I can get. I have three tractors that sport generators and voltage regulators. However, I polarize the generator and not the regulator. My first generator was on a 1931 Model A Ford I drove to school back in the mid-50's. However, back then I didn't know the first thing about polarizing generators. ;-) Looking forward to flying with the iridium plugs as soon as my airstrip dries out from the thunder storms last night, and I get the cow manure spread out to dry. The cows love to crap on my airstrip. I have a diamond drag I made out of 6 truck tires. I use the old antique tractors to pull the drag to spread the manure which helps it dry faster. Kills two birds with one stone. Gets the old gals some exercise and helps keep the cow crap off my airplane. john h Kolb MKIII - 3,231.8 hours 912ULS - 663.3 hours Titus, Alabama I have over 350 hours on a 912-UL engine burning no-lead auto fuel It is hard for me to change what I have learned from experience working on gas engines from the time that we were polarizing replacement voltage regulators on automotive electrical system with generators. When it comes time to replace the manufacturer specked spark plugs, I will install the iridium equivalent and fully expect to see no change in engine performance. Dave Weaver N912GR ________________________________________________________________________________
Subject: Re: 914 Alternator Options
Date: Mar 16, 2014
Jan, I am planning to fly to the event in Sweden at end of May. With regard to flying through Netherlands can you recommend any advice with regard to navigation and recommended stops. Regards David Park dpark748(at)hotmail.co.uk On 3 Aug 2013, at 20:02, Jan de Jong wrote: > > Hi Jacques. > > The 912iS alternator is oil cooled and needs the 912iS engine block, so that option seems definitely out. > > Jan de Jong > > > > > > > ________________________________________________________________________________
Subject: Ethanol Free MoGas
Date: Mar 26, 2014
Friends, I found this site which lists service stations in the USA & Canada offering ethanol free MoGas. http://pure-gas.org/ Select your state or province and check for availability in your area. Good luck! So far, I haven't found a source in my locality :-( Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914 w/ Intercooler & Airmaster C/S Prop Little Toot Sport Biplane, Lycoming AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 H: 940-497-2123 C: 817-992-1117 ________________________________________________________________________________
Date: Mar 27, 2014
Subject: Oil Lines and Aluminum AN Fittings
Anybody using aluminum AN fittings on their oil lines on a 912? With an oil cooler? For approximately how many hours? I've been told I must convert to steel for all the oil line end fittings. Tough to do with AN fittings and decent routing. Next: Anybody using AN non-banjo fittings to attach fuel lines to the carbs? I found an 8mm male to -3 AN male steel adapter, but have 1/4" fuel lines so need to convert to -4. I can only find -3 AN to -4 AN converters in aluminum. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. ________________________________________________________________________________
Date: Mar 27, 2014
Hi Guy, I have alum AN fittings on my LO cooler and have had them for 1000 hrs...no issues. I just have the barbed fittings and fuel hose with clamps to the carbs. Take care, Mark Donahue -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Guy Buchanan Sent: Thursday, March 27, 2014 7:25 PM Subject: RotaxEngines-List: Oil Lines and Aluminum AN Fittings --> Anybody using aluminum AN fittings on their oil lines on a 912? With an oil cooler? For approximately how many hours? I've been told I must convert to steel for all the oil line end fittings. Tough to do with AN fittings and decent routing. Next: Anybody using AN non-banjo fittings to attach fuel lines to the carbs? I found an 8mm male to -3 AN male steel adapter, but have 1/4" fuel lines so need to convert to -4. I can only find -3 AN to -4 AN converters in aluminum. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. ________________________________________________________________________________
Subject: oil change question
Date: Apr 06, 2014
I just changed the oil at 19 hours from first start. I was going to change it at 20 hours but had the cowl off so went ahead. Drained the tank after burping the engine and replaced the filter. After putting 3.25 qts. back in the tank, which is just a little less than what I drained out, the oil level is above the dipstick hole. Pulled the prop. through 15-20 revolutions and ran the starter for 6-7 seconds, ignition off, no oil pressure and level did not go down. Pressurized the tank, via the oil blow by line, to about 7-8 # with no change. This did not happen when I first filled the tank with oil. What am I doing wrong? Is it safe to start and check the oil pressure within 30 seconds? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421612#421612 ________________________________________________________________________________
Subject: Re: oil change question
Date: Apr 06, 2014
If your start switch is also the master you have no power to the senders in the start mode. Check for pressure just as you release the start mode but the switch is still on. Jim -----Original Message----- From: krazydoc33 Sent: Sunday, April 06, 2014 11:28 AM Subject: RotaxEngines-List: oil change question I just changed the oil at 19 hours from first start. I was going to change it at 20 hours but had the cowl off so went ahead. Drained the tank after burping the engine and replaced the filter. After putting 3.25 qts. back in the tank, which is just a little less than what I drained out, the oil level is above the dipstick hole. Pulled the prop. through 15-20 revolutions and ran the starter for 6-7 seconds, ignition off, no oil pressure and level did not go down. Pressurized the tank, via the oil blow by line, to about 7-8 # with no change. This did not happen when I first filled the tank with oil. What am I doing wrong? Is it safe to start and check the oil pressure within 30 seconds? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421612#421612 ________________________________________________________________________________
Subject: Re:_RotaxEngines-List:_oil_change_question?
Date: Apr 06, 2014
WW91IGFyZSBwcm9iYWJseSBiZWluZyBhIGxpdHRsZSBpbXBhdGllbnQgd2l0aCB5b3VyIGV4cGVj dGF0aW9ucyBvZiBvaWwgcHJlc3N1cmUgaW4gNiBvciA3IHNlY29uZHMuDQoNCkFyZSB5b3Ugc3Vy ZSB0aGF0IHlvdSBkaWQgbm90IHR1cm4gdGhlIGVuZ2luZSBhdCBhbGwsIGZvcndhcmRzIG9yIGJh Y2t3YXJkcyB3aGVuIHlvdXIgb2lsIHRhbmsgd2FzIGVtcHR5Pw0KDQpJZiBzbyB5b3UgY291bGQg aGF2ZSBnb3QgYWlyIGludG8gdGhlIG9pbCBzeXN0ZW0uICBUaGUgb2lsIHB1bXAgd2lsbCBub3Qg cHVtcCBhaXIhISEgSWYgeW91IGRpZCB0aGVuIHlvdSB3aWxsIG5lZWQgdG8gYmxlZWQgdGhlIG9p bCBzeXN0ZW0gZnJvbSBzY3JhdGNoLiAgU2VlIHRoZSBSb3RheCBtYW51YWwgZm9yIHByb2NlZHVy ZS4NCg0KSSBleHBlY3QgeW91IGp1c3QgZGlkIG5vdCBtb3RvciB0aGUgZW5naW5lIGxvbmcgZW5v dWdoLiAgUmVtb3ZlIG9uZSBwbHVnIGZyb20gZWFjaCBjeWxpbmRlciBhbmQgbW90b3IgZm9yIDIw IHNlY3Mgb3IgdW50aWwgb2lsIHByZXNzdXJlIHJpc2VzLiAgSWYgeW91IHN0aWxsIGRvbuKAmXQg Z2V0IHB4IHRoZW4gYmxlZWQgdGhlIG9pbCBzeXN0ZW0uDQoNCg0KUmVnYXJkcyANCg0KUGV0ZSBK ZWZmZXJzDQoNCg0KDQoNCg0KDQpGcm9tOiBKaW0gUm9iZXJ0cw0KU2VudDog4oCOU3VuZGF54oCO LCDigI424oCOIOKAjkFwcmls4oCOIOKAjjIwMTQg4oCOMTfigI464oCONDQNClRvOiByb3RheGVu Z2luZXMtbGlzdEBtYXRyb25pY3MuY29tDQoNCg0KDQoNCg0KLS0+IFJvdGF4RW5naW5lcy1MaXN0 IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiSmltIFJvYmVydHMiIDxqbmpyb2JAZ21haWwuY29tPg0KDQpJ ZiB5b3VyIHN0YXJ0IHN3aXRjaCBpcyBhbHNvIHRoZSBtYXN0ZXIgeW91IGhhdmUgbm8gcG93ZXIg dG8gdGhlIHNlbmRlcnMgaW4gDQp0aGUgc3RhcnQgbW9kZS4gQ2hlY2sgZm9yIHByZXNzdXJlIGp1 c3QgYXMgeW91IHJlbGVhc2UgdGhlIHN0YXJ0IG1vZGUgYnV0IA0KdGhlIHN3aXRjaCBpcyBzdGls bCBvbi4NCkppbQ0KDQotLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLSANCkZyb206IGtyYXp5ZG9j MzMNClNlbnQ6IFN1bmRheSwgQXByaWwgMDYsIDIwMTQgMTE6MjggQU0NClRvOiByb3RheGVuZ2lu ZXMtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSb3RheEVuZ2luZXMtTGlzdDogb2lsIGNo YW5nZSBxdWVzdGlvbg0KDQotLT4gUm90YXhFbmdpbmVzLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6 ICJrcmF6eWRvYzMzIiA8Z2FsYXh5b25lQGp1bm8uY29tPg0KDQpJIGp1c3QgY2hhbmdlZCB0aGUg b2lsIGF0IDE5IGhvdXJzIGZyb20gZmlyc3Qgc3RhcnQuIEkgd2FzIGdvaW5nIHRvIGNoYW5nZSAN Cml0IGF0IDIwIGhvdXJzIGJ1dCBoYWQgdGhlIGNvd2wgb2ZmIHNvIHdlbnQgYWhlYWQuIERyYWlu ZWQgdGhlIHRhbmsgYWZ0ZXIgDQpidXJwaW5nIHRoZSBlbmdpbmUgYW5kIHJlcGxhY2VkIHRoZSBm aWx0ZXIuIEFmdGVyIHB1dHRpbmcgMy4yNSBxdHMuIGJhY2sgaW4gDQp0aGUgdGFuaywgd2hpY2gg aXMganVzdCBhIGxpdHRsZSBsZXNzIHRoYW4gd2hhdCBJIGRyYWluZWQgb3V0LCB0aGUgb2lsIGxl dmVsIA0KaXMgYWJvdmUgdGhlIGRpcHN0aWNrIGhvbGUuIFB1bGxlZCB0aGUgcHJvcC4gdGhyb3Vn aCAxNS0yMCByZXZvbHV0aW9ucyBhbmQgDQpyYW4gdGhlIHN0YXJ0ZXIgZm9yIDYtNyBzZWNvbmRz LCBpZ25pdGlvbiBvZmYsIG5vIG9pbCBwcmVzc3VyZSBhbmQgbGV2ZWwgZGlkIA0Kbm90IGdvIGRv d24uIFByZXNzdXJpemVkIHRoZSB0YW5rLCB2aWEgdGhlIG9pbCBibG93IGJ5IGxpbmUsIHRvIGFi b3V0IDctOCAjIA0Kd2l0aCBubyBjaGFuZ2UuIFRoaXMgZGlkIG5vdCBoYXBwZW4gd2hlbiBJIGZp cnN0IGZpbGxlZCB0aGUgdGFuayB3aXRoIG9pbC4gDQpXaGF0IGFtIEkgZG9pbmcgd3Jvbmc/IElz IGl0IHNhZmUgdG8gc3RhcnQgYW5kIGNoZWNrIHRoZSBvaWwgcHJlc3N1cmUgd2l0aGluIA0KMzAg c2Vjb25kcz8NCg0KDQoNCg0KUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOg0KDQpodHRwOi8v Zm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTQyMTYxMiM0MjE2MTINCg0KDQoN Cg0KDQoNCg0KDQoNCg0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgIC0gVGhlIFJvdGF4RW5naW5lcy1M aXN0IEVtYWlsIEZvcnVtIC0NCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5h dmlnYXRvciB0byBicm93c2UNCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExp c3QgVW4vU3Vic2NyaXB0aW9uLA0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5 IEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToN Cl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/Um90YXhF bmdpbmVzLUxpc3QNCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdF QiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhl IFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20N Cl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRl IC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQpfLT0gICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQpfLT0gICAt LT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KXy09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0 ________________________________________________________________________________
Date: Apr 06, 2014
Krazy, NO! If you truly believe you don't have oil pressure it is definitely NOT safe to start the engine. The 912 does not tolerate no or low oil pressure and long before that 30 seconds is up your engine will be toast. Suggest you pull the top spark plugs from all cylinders and spin the engine by hand until you hear the engine burp. If you cannot get the engine to burp and you still believe the engine has no oil pressure, pull the oil pressure sender and install a mechanical gauge like this: http://www.summitracing.com/parts/sww-82323/overview/ as a test unit. Yeah, it will double the price of your oil change but an extra $40 is cheaper by far than a new engine. Rick Girard On Sun, Apr 6, 2014 at 12:28 PM, wrote: > You are probably being a little impatient with your expectations of oil > pressure in 6 or 7 seconds. > Are you sure that you did not turn the engine at all, forwards or > backwards when your oil tank was empty? > If so you could have got air into the oil system. The oil pump will not > pump air!!! If you did then you will need to bleed the oil system from > scratch. See the Rotax manual for procedure. > I expect you just did not motor the engine long enough. Remove one plug > from each cylinder and motor for 20 secs or until oil pressure rises. If > you still don't get px then bleed the oil system. > > Regards > Pete Jeffers > > *From:* Jim Roberts > *Sent:* Sunday, 6 April 2014 17:44 > *To:* rotaxengines-list(at)matronics.com > > > If your start switch is also the master you have no power to the senders > in > the start mode. Check for pressure just as you release the start mode but > the switch is still on. > Jim > > -----Original Message----- > From: krazydoc33 > Sent: Sunday, April 06, 2014 11:28 AM > To: rotaxengines-list(at)matronics.com > Subject: RotaxEngines-List: oil change question > > > I just changed the oil at 19 hours from first start. I was going to change > it at 20 hours but had the cowl off so went ahead. Drained the tank after > burping the engine and replaced the filter. After putting 3.25 qts. back > in > the tank, which is just a little less than what I drained out, the oil > level > is above the dipstick hole. Pulled the prop. through 15-20 revolutions and > ran the starter for 6-7 seconds, ignition off, no oil pressure and level > did > not go down. Pressurized the tank, via the oil blow by line, to about 7-8 > # > with no change. This did not happen when I first filled the tank with oil. > What am I doing wrong? Is it safe to start and check the oil pressure > within > 30 seconds? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421612#421612 > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Apr 07, 2014
SnVzdCB0byBjbGFyaWZ5IHdoYXQgSSBzYWlkLCBzaW5jZSBSaWNoYXJkIHNlZW1zIGNvbmZ1c2Vk LCB3aGVuIEkgc2FpZCDigJhtb3RvcuKAmSB0aGUgZW5naW5lIGZvciAyMCBzZWNzIEkgZGlkIHNh eSB3aXRoIHRoZSBwbHVncyByZW1vdmVkLCBtZWFuaW5nIHRvIHJvdGF0ZSB0aGUgZW5naW5lIG9u IHRoZSBzdGFydGVyIG1vdG9yIGZvciAyMCBzZWNzLg0KDQogIGllIERPIE5PVCBTVEFSVCB0aGUg ZW5naW5lLCBqdXN0IHJvdGF0ZSBpdCBvbiB0aGUgc3RhcnRlciBtb3RvciBmb3IgMjAgc2Vjcy4N Cg0KSSBhbSBzb3JyeSBpZiBJIGNvbmZ1c2VkIHlvdS4NCg0KUGV0ZSBKZWZmZXJzDQoNCg0KDQoN Cg0KDQpGcm9tOiBSaWNoYXJkIEdpcmFyZA0KU2VudDog4oCOTW9uZGF54oCOLCDigI434oCOIOKA jkFwcmls4oCOIOKAjjIwMTQg4oCOMDLigI464oCONTENClRvOiByb3RheGVuZ2luZXMtbGlzdEBt YXRyb25pY3MuY29tDQoNCg0KDQoNCg0KS3JhenksIE5PISBJZiB5b3UgdHJ1bHkgYmVsaWV2ZSB5 b3UgZG9uJ3QgaGF2ZSBvaWwgcHJlc3N1cmUgaXQgaXMgZGVmaW5pdGVseSBOT1Qgc2FmZSB0byBz dGFydCB0aGUgZW5naW5lLiBUaGUgOTEyIGRvZXMgbm90IHRvbGVyYXRlIG5vIG9yIGxvdyBvaWwg cHJlc3N1cmUgYW5kIGxvbmcgYmVmb3JlIHRoYXQgMzAgc2Vjb25kcyBpcyB1cCB5b3VyIGVuZ2lu ZSB3aWxsIGJlIHRvYXN0Lg0KU3VnZ2VzdCB5b3UgcHVsbCB0aGUgdG9wIHNwYXJrIHBsdWdzIGZy b20gYWxsIGN5bGluZGVycyBhbmQgc3BpbiB0aGUgZW5naW5lIGJ5IGhhbmQgdW50aWwgeW91IGhl YXIgdGhlIGVuZ2luZSBidXJwLiBJZiB5b3UgY2Fubm90IGdldCB0aGUgZW5naW5lIHRvIGJ1cnAg YW5kIHlvdSBzdGlsbCBiZWxpZXZlIHRoZSBlbmdpbmUgaGFzIG5vIG9pbCBwcmVzc3VyZSwgcHVs bCB0aGUgb2lsIHByZXNzdXJlIHNlbmRlciBhbmQgaW5zdGFsbCBhIG1lY2hhbmljYWwgZ2F1Z2Ug bGlrZSB0aGlzOiBodHRwOi8vd3d3LnN1bW1pdHJhY2luZy5jb20vcGFydHMvc3d3LTgyMzIzL292 ZXJ2aWV3LyBhcyBhIHRlc3QgdW5pdC4gWWVhaCwgaXQgd2lsbCBkb3VibGUgdGhlIHByaWNlIG9m IHlvdXIgb2lsIGNoYW5nZSBidXQgYW4gZXh0cmEgJDQwIGlzIGNoZWFwZXIgYnkgZmFyIHRoYW4g YSBuZXcgZW5naW5lLg0KDQoNCg0KDQpSaWNrIEdpcmFyZA0KDQoNCg0KDQpPbiBTdW4sIEFwciA2 LCAyMDE0IGF0IDEyOjI4IFBNLCA8cGplZmZlcnNAdGFsa3RhbGsubmV0PiB3cm90ZToNCg0KDQoN Cg0KWW91IGFyZSBwcm9iYWJseSBiZWluZyBhIGxpdHRsZSBpbXBhdGllbnQgd2l0aCB5b3VyIGV4 cGVjdGF0aW9ucyBvZiBvaWwgcHJlc3N1cmUgaW4gNiBvciA3IHNlY29uZHMuDQoNCkFyZSB5b3Ug c3VyZSB0aGF0IHlvdSBkaWQgbm90IHR1cm4gdGhlIGVuZ2luZSBhdCBhbGwsIGZvcndhcmRzIG9y IGJhY2t3YXJkcyB3aGVuIHlvdXIgb2lsIHRhbmsgd2FzIGVtcHR5Pw0KDQpJZiBzbyB5b3UgY291 bGQgaGF2ZSBnb3QgYWlyIGludG8gdGhlIG9pbCBzeXN0ZW0uICBUaGUgb2lsIHB1bXAgd2lsbCBu b3QgcHVtcCBhaXIhISEgSWYgeW91IGRpZCB0aGVuIHlvdSB3aWxsIG5lZWQgdG8gYmxlZWQgdGhl IG9pbCBzeXN0ZW0gZnJvbSBzY3JhdGNoLiAgU2VlIHRoZSBSb3RheCBtYW51YWwgZm9yIHByb2Nl ZHVyZS4NCg0KSSBleHBlY3QgeW91IGp1c3QgZGlkIG5vdCBtb3RvciB0aGUgZW5naW5lIGxvbmcg ZW5vdWdoLiAgUmVtb3ZlIG9uZSBwbHVnIGZyb20gZWFjaCBjeWxpbmRlciBhbmQgbW90b3IgZm9y IDIwIHNlY3Mgb3IgdW50aWwgb2lsIHByZXNzdXJlIHJpc2VzLiAgSWYgeW91IHN0aWxsIGRvbuKA mXQgZ2V0IHB4IHRoZW4gYmxlZWQgdGhlIG9pbCBzeXN0ZW0uDQoNCg0KDQoNClJlZ2FyZHMgDQoN ClBldGUgSmVmZmVycw0KDQoNCg0KDQoNCg0KRnJvbTogSmltIFJvYmVydHMNClNlbnQ6IFN1bmRh eSwgNiBBcHJpbCAyMDE0IDE3OjQ0DQpUbzogcm90YXhlbmdpbmVzLWxpc3RAbWF0cm9uaWNzLmNv bQ0KDQoNCg0KDQoNCg0KDQotLT4gUm90YXhFbmdpbmVzLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6 ICJKaW0gUm9iZXJ0cyIgPGpuanJvYkBnbWFpbC5jb20+DQoNCklmIHlvdXIgc3RhcnQgc3dpdGNo IGlzIGFsc28gdGhlIG1hc3RlciB5b3UgaGF2ZSBubyBwb3dlciB0byB0aGUgc2VuZGVycyBpbiAN CnRoZSBzdGFydCBtb2RlLiBDaGVjayBmb3IgcHJlc3N1cmUganVzdCBhcyB5b3UgcmVsZWFzZSB0 aGUgc3RhcnQgbW9kZSBidXQgDQp0aGUgc3dpdGNoIGlzIHN0aWxsIG9uLg0KSmltDQoNCi0tLS0t T3JpZ2luYWwgTWVzc2FnZS0tLS0tIA0KRnJvbToga3Jhenlkb2MzMw0KU2VudDogU3VuZGF5LCBB cHJpbCAwNiwgMjAxNCAxMToyOCBBTQ0KVG86IHJvdGF4ZW5naW5lcy1saXN0QG1hdHJvbmljcy5j b20NClN1YmplY3Q6IFJvdGF4RW5naW5lcy1MaXN0OiBvaWwgY2hhbmdlIHF1ZXN0aW9uDQoNCi0t PiBSb3RheEVuZ2luZXMtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogImtyYXp5ZG9jMzMiIDxnYWxh eHlvbmVAanVuby5jb20+DQoNCkkganVzdCBjaGFuZ2VkIHRoZSBvaWwgYXQgMTkgaG91cnMgZnJv bSBmaXJzdCBzdGFydC4gSSB3YXMgZ29pbmcgdG8gY2hhbmdlIA0KaXQgYXQgMjAgaG91cnMgYnV0 IGhhZCB0aGUgY293bCBvZmYgc28gd2VudCBhaGVhZC4gRHJhaW5lZCB0aGUgdGFuayBhZnRlciAN CmJ1cnBpbmcgdGhlIGVuZ2luZSBhbmQgcmVwbGFjZWQgdGhlIGZpbHRlci4gQWZ0ZXIgcHV0dGlu ZyAzLjI1IHF0cy4gYmFjayBpbiANCnRoZSB0YW5rLCB3aGljaCBpcyBqdXN0IGEgbGl0dGxlIGxl c3MgdGhhbiB3aGF0IEkgZHJhaW5lZCBvdXQsIHRoZSBvaWwgbGV2ZWwgDQppcyBhYm92ZSB0aGUg ZGlwc3RpY2sgaG9sZS4gUHVsbGVkIHRoZSBwcm9wLiB0aHJvdWdoIDE1LTIwIHJldm9sdXRpb25z IGFuZCANCnJhbiB0aGUgc3RhcnRlciBmb3IgNi03IHNlY29uZHMsIGlnbml0aW9uIG9mZiwgbm8g b2lsIHByZXNzdXJlIGFuZCBsZXZlbCBkaWQgDQpub3QgZ28gZG93bi4gUHJlc3N1cml6ZWQgdGhl IHRhbmssIHZpYSB0aGUgb2lsIGJsb3cgYnkgbGluZSwgdG8gYWJvdXQgNy04ICMgDQp3aXRoIG5v IGNoYW5nZS4gVGhpcyBkaWQgbm90IGhhcHBlbiB3aGVuIEkgZmlyc3QgZmlsbGVkIHRoZSB0YW5r IHdpdGggb2lsLiANCldoYXQgYW0gSSBkb2luZyB3cm9uZz8gSXMgaXQgc2FmZSB0byBzdGFydCBh bmQgY2hlY2sgdGhlIG9pbCBwcmVzc3VyZSB3aXRoaW4gDQozMCBzZWNvbmRzPw0KDQoNCg0KDQpS ZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6DQoNCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNv bS92aWV3dG9waWMucGhwP3A9NDIxNjEyIzQyMT09PT0NCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNz LmNvbXNwOyAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCl9uYnNwOyAgICAg ICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KPT09PT09PQ0K DQoNCg0KDQoNCg0KDQoNCg0KLS0gDQoNClp1bHUgRGVsdGENCg0KTWsgSUlJQw0KDQpUaGFua3Ms IEhvbWVyIEdCWU0NCg0KDQoNCg0KSXQgaXNuJ3QgbmVjZXNzYXJ5IHRvIGhhdmUgcmVsYXRpdmVz IGluIEthbnNhcyBDaXR5IGluIG9yZGVyIHRvIGJlIHVuaGFwcHkuDQogIC0gR3JvdWNobyBNYXJ4 DQoNCg0KDQoNCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAtIFRoZSBSb3RheEVuZ2luZXMtTGlzdCBF bWFpbCBGb3J1bSAtDQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0 b3IgdG8gYnJvd3NlDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVu L1N1YnNjcmlwdGlvbiwNCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93 c2UsIENoYXQsIEZBUSwNCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQpfLT0N Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JvdGF4RW5naW5l cy1MaXN0DQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9S VU1TIC0NCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIg Rm9ydW1zIQ0KXy09DQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQpfLT0N Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09DQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQpf LT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KXy09ICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KXy09ICAgLS0+IGh0 dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCl8tPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 ________________________________________________________________________________
Date: Apr 07, 2014
From: william sullivan <williamtsullivan(at)att.net>
Subject: Bing 54
- It's been a while since I looked in my Bing 54, so I have to ask.- Wh at is the proper installation of the sieve sleeve in the carb bowl?- Bott om of the jet, or slid all the way up?=0A=0A---------- ------------------------- ------------------------- ---------------- Bill Sullivan=0A--- ------------------------- ------------------------- ----------------------- Winds or Locks, Ct.=0A------------------- ------------------------- ------------------------- -------- Kolb Firestar, 447=0A ________________________________________________________________________________
Date: Apr 07, 2014
Oil change should be simple. Rotate the prop before you drain oil or remove the filter and never again until the oil is back in the tank and the filter installed. 3 qts. of oil. If you introduce too much air into the system then you will need to do a full Rotax oil purge. There is no need to go there. If you are using Aero Shell Sport Plus 4 then they are liters and just use all 3 liters. This should put you at the top of the dip stick. You can not pre-fill the new Rotax oil filters because of the check valve in the filter. Leave the plugs in place and rotate the prop 20 times +/- it doesn't need to be exact. You must leave the plugs in place because the only way for oil to get back to the oil tank is by crankcase pressure. If you remove the plugs you lose that. Then start the engine and the pressure is usually there within a 1-3 seconds because the system still has oil in it. I would not personally turn the engine over with the ignition off. First it isn't necessary and if done wrong under certain conditions can cause damage. If you have any questions please don't hesitate to call. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421699#421699 ________________________________________________________________________________
Subject: 912 run on
Date: Apr 07, 2014
I was syncing the carbs on my 912ul and tried to shut the engine down but turning off the ignition switches did absolutely nothing. I cycled them several time but the engine kept running. I finally shut off the fuel and waited for it to quit. I checked the grounding on the switches and everything was in order. The funny thing is the switches had been working fine before and have been since this occasion. The Rotax manual says this is possible if the engine is shut down hot but in this case the motor was barely warm.. Anyone have any ideas ? Thanks EG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421706#421706 ________________________________________________________________________________
Date: Apr 07, 2014
Subject: Re: 912 run on
Hi It is not possible for the engine to keep on running if the ignition switches are in the off position, and you said that you checked continuity to ground, correct? It is very possible that as part of the carb sync you messed up with the aluminum tube that connects the two carbs together, this tube is located very close to the electronic ignition modules and it is possible that while messing with it, you actually broke the "kill" wires leading from the ignition switches in the cockpit to the electronic modules, I would suggest checking continuity to ground starting right on the kill connection at the module location itself. Nati RANS 6 912ULS, Illinois On Mon, Apr 7, 2014 at 10:56 AM, egp8111 wrote: > > I was syncing the carbs on my 912ul and tried to shut the engine down but > turning off the ignition switches did absolutely nothing. I cycled them > several time but the engine kept running. I finally shut off the fuel and > waited for it to quit. I checked the grounding on the switches and > everything was in order. The funny thing is the switches had been working > fine before and have been since this occasion. The Rotax manual says this > is possible if the engine is shut down hot but in this case the motor was > barely warm.. Anyone have any ideas ? > Thanks > EG > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421706#421706 > > ________________________________________________________________________________
Date: Apr 07, 2014
EG: Did the engine run smooth after you shut off the ignition switches? If so then check the grounding of your switches again. Check further down the wiring not just at the switch to ground. If the engine ran rough then you could have a HOT SPOT in one or more cylinders. A hot spot can cause run-on, dieseling, and pre-ignition. If this is the case check the plugs first, then the area inside the cylinders where the plugs screw into. You are LQQKing small hang-nails of metal. These will heat up, hold the temps and fire-off a fuel air mixture. Barry On Mon, Apr 7, 2014 at 11:56 AM, egp8111 wrote: > > I was syncing the carbs on my 912ul and tried to shut the engine down but > turning off the ignition switches did absolutely nothing. I cycled them > several time but the engine kept running. I finally shut off the fuel and > waited for it to quit. I checked the grounding on the switches and > everything was in order. The funny thing is the switches had been working > fine before and have been since this occasion. The Rotax manual says this > is possible if the engine is shut down hot but in this case the motor was > barely warm.. Anyone have any ideas ? > Thanks > EG > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421706#421706 > > ________________________________________________________________________________
Date: Apr 07, 2014
You bought a RatTax On Sun, Apr 6, 2014 at 12:28 PM, krazydoc33 wrote: > > I just changed the oil at 19 hours from first start. I was going to change > it at 20 hours but had the cowl off so went ahead. Drained the tank after > burping the engine and replaced the filter. After putting 3.25 qts. back in > the tank, which is just a little less than what I drained out, the oil > level is above the dipstick hole. Pulled the prop. through 15-20 > revolutions and ran the starter for 6-7 seconds, ignition off, no oil > pressure and level did not go down. Pressurized the tank, via the oil blow > by line, to about 7-8 # with no change. This did not happen when I first > filled the tank with oil. What am I doing wrong? Is it safe to start and > check the oil pressure within 30 seconds? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421612#421612 > > ________________________________________________________________________________
Date: Apr 07, 2014
Sorry Doc, But this is the biggest failure on Rotax's part, they did not eliminating a ridiculous problem. All these engines and all these years and all they could do is offer a complicated solution. Would deal with a car that had this issue? Barry On Sun, Apr 6, 2014 at 12:28 PM, krazydoc33 wrote: > > I just changed the oil at 19 hours from first start. I was going to change > it at 20 hours but had the cowl off so went ahead. Drained the tank after > burping the engine and replaced the filter. After putting 3.25 qts. back in > the tank, which is just a little less than what I drained out, the oil > level is above the dipstick hole. Pulled the prop. through 15-20 > revolutions and ran the starter for 6-7 seconds, ignition off, no oil > pressure and level did not go down. Pressurized the tank, via the oil blow > by line, to about 7-8 # with no change. This did not happen when I first > filled the tank with oil. What am I doing wrong? Is it safe to start and > check the oil pressure within 30 seconds? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=421612#421612 > > ________________________________________________________________________________
Date: Apr 07, 2014
I would look at grounding at the ignition switch and up at the ignition modules on the 6 pin connectors. White wire in the corner. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421750#421750 ________________________________________________________________________________
Date: Apr 07, 2014
Hi Jim, The panel is a Dynon skyView, when the master is on so are all the senders. As others have suggested the oil pump needed to be primed. I think what happened is that I left the oil filter off overnight to let it drain down and it also drained the oil pump down too. I purged the system per the Rotax manual and all is now well. I did remove all the top plugs to be able to spin the engine over easier. This engine has always run with a black sooty exhaust pipe. The front two plugs have a black sooty deposit on them but the two rear plugs look fine, a light brown color. Any suggestions? Thanks. Henry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421752#421752 ________________________________________________________________________________
Subject: Bing 54
Date: Apr 07, 2014
Rick, I was under the impression the main jet well screen was an air dam to prevent air bubbles from entering the main jet well that could lean out the mixture. john h mkIII Titus, Alabama William, The screen should sit in the well cast into the float bowl as a final coarse filter to keep crap out of the main jet. Rick Girard ________________________________________________________________________________
Date: Apr 08, 2014
100LL or car gas? Jim -----Original Message----- From: krazydoc33 Sent: Monday, April 07, 2014 8:57 PM Subject: RotaxEngines-List: Re: oil change question Hi Jim, The panel is a Dynon skyView, when the master is on so are all the senders. As others have suggested the oil pump needed to be primed. I think what happened is that I left the oil filter off overnight to let it drain down and it also drained the oil pump down too. I purged the system per the Rotax manual and all is now well. I did remove all the top plugs to be able to spin the engine over easier. This engine has always run with a black sooty exhaust pipe. The front two plugs have a black sooty deposit on them but the two rear plugs look fine, a light brown color. Any suggestions? Thanks. Henry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421752#421752 ________________________________________________________________________________
Date: Apr 08, 2014
Hi Henry, Some of the things you are talking about are normal and there are some tips I can give you. Give me a call. I'll be able to put your mind at rest. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421771#421771 ________________________________________________________________________________
Date: Apr 09, 2014
Hi Jim, So far nothing but 91 octane automotive fuel, and all from the same gas station which is right across the road from the air park. Maybe time to try another one? Roger, I will give you a call or maybe stop by there? Henry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421817#421817 ________________________________________________________________________________
Date: Apr 09, 2014
Subject: CHT reading failure
The 912S sat out the winter months while we worked through the gig list from the aircraft's annual. The only change to the engine was replacing an O-ring on the coolant inlet of the number 4 head. On startup last Sunday, the engine started and ran fine however the MGL EFIS would not show CHT readings. I've verified that the wires from the senders to the RDAX unit are connected, but the day closed out before I could get any further. It seems unlikely that both senders would fail at once but I would still like to verify that they're working properly. Does anyone have or know of a resistance chart for Rotax CHT senders? Thanks, Rick Girard It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Subject: Re: CHT reading failure
Date: Apr 09, 2014
Hi rick, I can almost guarantee it isn't the two separate CHT senders. Somewhere there is a bad connection. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421836#421836 ________________________________________________________________________________
Date: Apr 09, 2014
I have read auto fuel will cause the exhaust pipe to be black. Jim -----Original Message----- From: krazydoc33 Sent: Wednesday, April 09, 2014 8:54 AM Subject: RotaxEngines-List: Re: oil change question Hi Jim, So far nothing but 91 octane automotive fuel, and all from the same gas station which is right across the road from the air park. Maybe time to try another one? Roger, I will give you a call or maybe stop by there? Henry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421817#421817 ________________________________________________________________________________
Date: Apr 09, 2014
If your engine is operating properly neither fuel makes the exhaust black. too much idling and too low an idle rpm might. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421861#421861 ________________________________________________________________________________
Date: Apr 10, 2014
Rick, Here is a VDO chart of temp sensors. Jim Butcher Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421867#421867 Attachments: http://forums.matronics.com//files/temperatureresistancechart_124.pdf ________________________________________________________________________________
Date: Apr 12, 2014
Exact same thing happened to me about 50 engine hours ago. I tried reaching under the instrument panel to ground the switch terminals - no luck. Finally just let it run out of fuel. Next time it worked just fine, and has for over a year. Can't explain it.......Fred Read this topic online here: http://forums.matronics.com/viewtopic.php?p=421948#421948 ________________________________________________________________________________
Date: Apr 16, 2014
Subject: Matronics Web Server Down for Repair (PLEASE READ)...
Dear Listers, Late Tuesday night 4/15/2014, the Matronics Web server crashed due to a multi-disk RAID 5 failure. The system has complete data backups, but I will likely have to order some replacement disks to rebuild the system. I'll work as quickly as I can to restore the Matronics Web Server. The Matronics EMAIL server is NOT impacted by this issue. All normal Matronics Email List mail will flow as usual. However, the Matronics Web Forums interface will not be available. Also impacted by the Web Server outage will be the AeroElectric web site. I will try to post daily updates on the Web Server restoration status. I apologize for the inconvenience... :-( Best regards, Matt Dralle Matronics Email List and Forum Admin. Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Apr 17, 2014
Subject: Matronics Web Server Repaired and ONLINE! (PLEASE READ)
Dear Listers, The new hard drives for the Matronics web server arrived today, Thursday 4/17/2014 and the RAID5 disk array rebuild went very smoothly. Web server is back online and fully functional! No data or files were lost. Additionally, those that frequent the AeroElectric web site will find that it has been restored as well. Best regards, Matt Dralle Matronics Email List and Forum Admin. Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Blinking Charge Light
Date: Apr 24, 2014
Our electrical system has worked without a problem for 500 hours and 5 years. Recently the charge lite has begun to blink on and off while in flight. It is still on solid at low rpm or engine off and gets dimmer and finally goes off as the rpm is increased (around 3000 rpm). But during cruise at 5000 rpm, it blinks off and on. And this behavior seems a little intermittent. First noticed it 2 flights ago. The next flight was fine and today it was fine for the first half of the flight and then blinked the last half. Yet the engine monitor shows the voltage constant at 13.2 volts and current into the battery varying between 2 and 4 amps. These are the same as have been for years. Any ideas or suggestions? Jim & Heather Europa XS 914 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422329#422329 ________________________________________________________________________________
From: Kevin Klinefelter <klinefelter.kevin(at)gmail.com>
Subject: Re: Blinking Charge Light
Date: Apr 24, 2014
Check the gound connection for corrosion. Kevin > On Apr 24, 2014, at 12:58 PM, "h&jeuropa" wrote: > > > Our electrical system has worked without a problem for 500 hours and 5 years. Recently the charge lite has begun to blink on and off while in flight. It is still on solid at low rpm or engine off and gets dimmer and finally goes off as the rpm is increased (around 3000 rpm). But during cruise at 5000 rpm, it blinks off and on. And this behavior seems a little intermittent. First noticed it 2 flights ago. The next flight was fine and today it was fine for the first half of the flight and then blinked the last half. > > Yet the engine monitor shows the voltage constant at 13.2 volts and current into the battery varying between 2 and 4 amps. These are the same as have been for years. > > Any ideas or suggestions? > > Jim & Heather > Europa XS 914 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=422329#422329 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 24, 2014
The Charge Light is blinking. That only tells you that the indicator light is blinking. Start there. The fault may only be the light. If the light checks OK then move on to grounds, the wiring, etc. Think of all the stories of the parts replacement technician at the local auto dealer. His computer says the MAP sensor is bad. He replaces it and one of two things happen. The problem goes away but actually it is cured because the act of disconnecting it "cleaned" the connection. Or, the computers says the oxygen sensor is bad. Replacing it does one of the same two things. The next day the guy's wife loses the gas cap. A new one is installed and, voila, the problem goes away. On 4/24/2014 8:17 PM, Kevin Klinefelter wrote: > > Check the gound connection for corrosion. > Kevin > > >> On Apr 24, 2014, at 12:58 PM, "h&jeuropa" wrote: >> >> >> Our electrical system has worked without a problem for 500 hours and 5 years. Recently the charge lite has begun to blink on and off while in flight. It is still on solid at low rpm or engine off and gets dimmer and finally goes off as the rpm is increased (around 3000 rpm). But during cruise at 5000 rpm, it blinks off and on. And this behavior seems a little intermittent. First noticed it 2 flights ago. The next flight was fine and today it was fine for the first half of the flight and then blinked the last half. >> >> Yet the engine monitor shows the voltage constant at 13.2 volts and current into the battery varying between 2 and 4 amps. These are the same as have been for years. >> >> Any ideas or suggestions? >> >> Jim & Heather >> Europa XS 914 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=422329#422329 >> >> >> >> >> >> >> >> >> >> > > -- Sent from my Gateway E4610D Lyle ________________________________________________________________________________
Subject: Problem on 912ULS
Date: Apr 27, 2014
Hi There all, Cold start ok, run smooth @2500 rpm, when temp ok can run till 5800 rpm but test @3850 rpm fails on EACH (same on one or the other) circuit alone : loose 700 RPM and runs rough and not equilibrated. Back to a quasi smooth run when on both circuits! Any Idea? Max Cointe mcointe(at)free.fr F-PMLH Europa XS_TriGear Kit #560-2003 912ULS/AirmasterAP332 490 hours F-PLDJ DynAro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1600 heures -----Message d'origine----- De: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] De la part de rparigoris Envoy: mercredi 4 juillet 2012 00:36 : rotaxengines-list(at)matronics.com Objet: RotaxEngines-List: I wish there was a Rotax 9XX video like this. --> I wish there was a 9XX video like this: http://jalopnik.com/5922349/watch-an-engine-rebuild-itself-in-this-3000+phot o-stop+motion-video Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377182#377182 ________________________________________________________________________________
Subject: Re: Problem on 912ULS
Date: Apr 27, 2014
You need to check the ignition grounds at the switch and at the ignition modules and check all other wires at the modules plugs. If you loose 700 rpm it can't be running smooth as you think. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422435#422435 ________________________________________________________________________________
Subject: Oil Filter
Date: Apr 27, 2014
Date: Apr 27, 2014
- Max- Are you talking about a magneto test?- If so, you may have a dir ty plug or bad wire on each circuit.=0A=0A----------- ------------------------- ------------------------- -- Bill Sullivan=0A=0A=0A=0A=0A________________________________=0A From : Max Cointe (Free) =0ATo: rotaxengines-list(at)matronics.com =0ASent: Sunday, April 27, 2014 5:48 AM=0ASubject: RotaxEngines-List: Prob (Free)" =0A=0AHi There all,=0A=0ACold start ok, run smoot h @2500 rpm, when temp ok can run till 5800 rpm but=0Atest @3850 rpm fails on EACH (same on one or the other) circuit alone :=0Aloose 700 RPM and runs rough and not equilibrated. Back to a quasi smooth=0Arun when on both circ =============== ________________________________________________________________________________
Date: Apr 27, 2014
Hi Bill and Roger Lee, Thks both for your answers. As a matter of fact I just mixed and matched the plugs on cylinders 2 and 4 on the lower sparks. So on one mag whichever it was the cylinders 2 and 4 weren=92t lighted. So I have asked someone to kick my a.. after having reconnected everything right! Have good flights, rgds Max Cointe mcointe(at)free.fr F-PMLH Europa XS_TriGear Kit #560-2003 912ULS/AirmasterAP332 490 hours F-PLDJ Dyn=92A=E9ro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1600 heures De : owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] De la part de william sullivan Envoy=E9 : dimanche 27 avril 2014 17:01 =C0 : rotaxengines-list(at)matronics.com Objet : Re: RotaxEngines-List: Problem on 912ULS Max- Are you talking about a magneto test? If so, you may have a dirty plug or bad wire on each circuit. Bill Sullivan _____ From: Max Cointe (Free) <mcointe(at)free.fr> Sent: Sunday, April 27, 2014 5:48 AM Subject: RotaxEngines-List: Problem on 912ULS Hi There all, Cold start ok, run smooth @2500 rpm, when temp ok can run till 5800 rpm but test @3850 rpm fails on EACH (same on one or the other) circuit alone : loose 700 RPM and runs rough and not equilibrated. Back to a quasi smooth run when on both circuits! Any ref="http://www.matronics.com/Navigator?RotaxEngines-List" target="_bla//forums.matronics.com/" = --> <http://www.matronics.com/contribution> ________________________________________________________________________________
Date: Apr 28, 2014
yep, that would do it. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422505#422505 ________________________________________________________________________________
Date: Apr 29, 2014
Problem solved! Pulled each fast-on terminal off the regulator and pushed it back on again, cleaning the contact. Also cleaned the ground connection. All is well. Thanks for the suggestions. Jim & Heather Read this topic online here: http://forums.matronics.com/viewtopic.php?p=422558#422558 ________________________________________________________________________________
Date: May 05, 2014
Subject: rotax 377 freeair
I being stupid as a hell bought an engine ,a rotax 377 that was used "less tyhan 100 hrs" in a wind tunnel in a trackter configuration. I must say tha t i had never seen a 377 and all i kneww was that they produced 35 hp and t he general consensus was that the 377 was a good solid engine and that the plane I was building would be very happy with it .i am building a KOlB Fire fly- a pusher and i came to find out that everybody says that being a KOL B it- would never work unless it had fan cooling!=0A------ My question is has any one ever changed a freeair 377 or 447 to fan cooling ? How many parts other than the fan and the cooling shrouds are there to cha nge ? If any one has please lend me your experence . thanks in advance Chri s=0A=0Ap.s. I also read somewhere online that the aluminum shrouds are no g ood anybody know why?=0A=0A-=0AChris Davis=0AKXP 503 492 hrs=0AGlider Pil ot=0ADisabled from crash building Firefly ________________________________________________________________________________
Date: May 08, 2014
is there anyone here=0A=0A=C2-=0AChris Davis=0AKXP 503 492 hrs=0AGlider P ilot=0ADisabled from crash building Firefly?=0AOn Sunday, April 27, 2014 1: 21 PM, Max Cointe (Free) wrote:=0A =0AHi Bill and Roger L ee,=0A>=C2-=0A>Thksboth for your answers. As a matter of fact I just mixe d and matched the plugs on cylinders 2 and 4 on the lower sparks. So on one mag whichever it was the cylinders 2 and 4 weren=99t lighted. So I h ave asked someone to kick my a.. after having =C2-reconnected everything right!=0A>Have good flights, rgds=0A>=C2-=0A>Max=C2- Cointe=0A>mcointe@ free.fr=0A>F-PMLH Europa XS_TriGear=0A>Kit #560-2003 912ULS/AirmasterAP332 490 hours=0A>=C2-=0A>F-PLDJ Dyn=99A=C3=A9ro MCR 4S =0A>Kit #27-2002 912ULSFR/MTProp MTV7A 1600 heures=0A>=C2-=0A>De=C2-:owner-rotaxengines -list-server(at)matronics.com [mailto:owner-rotaxengines-list-server@matronics .com] De la part de william sullivan=0A>Envoy=C3=A9=C2-: dimanche 27 avri l 2014 17:01=0A>=C3=C2-: rotaxengines-list(at)matronics.com=0A>Objet=C2 -: Re: RotaxEngines-List: Problem on 912ULS=0A>=C2-=0A>=C2- Max- Are you talking about a magneto test?=C2- If so, you may have a dirty plug or bad wire on each circuit.=0A>=0A>=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2- Bill Sullivan=0A>=C2-=0A>=C2- =0A>=0A>________________________________=0A>=0A>From:Max Cointe (Free) =0A>To: rotaxengines-list(at)matronics.com =0A>Sent: Sunday, Apri l 27, 2014 5:48 AM=0A>Subject: RotaxEngines-List: Problem on 912ULS=0A>=0A> fr>=0A>=0A>Hi There all,=0A>=0A>Cold start ok, run smooth @2500 rpm, when t emp ok can run till 5800 rpm but=0A>test @3850 rpm fails on EACH (same on o ne or the other) circuit alone :=0A>loose 700 RPM and runs rough and not eq uilibrated. Back to a quasi smooth=0A>run when on both circuits!=0A>Any ref ="http://www.matronics.com/Navigator?RotaxEngines-List" target="_bla//f orums.matronics.com/" ==C2- --> =0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A>=C2- =0A>=C2-=0A>=C2-=0A> =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2- - The RotaxEngines-List Email Forum -=0A>--> http://www.matronics.co m/Navigator?RotaxEngines-List=0A> =C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2- - MATRONICS WEB FORUMS -=0A>- -> http://forums.matronics.com=0A> =C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2- - List Contribution Web Site -=0A>Thank y ou for your generous support!=0A>=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- -Matt Dralle, Lis ============= =0A>=0A> ________________________________________________________________________________
Date: May 08, 2014
Chris,=0A=0AYes, we're out here. =C2-I remember that you posted a questi on a while back. =C2-And I remember that I didn't have an answer for you at that time. =C2-Perhaps there were no other answers as well. =C2-Tr y posting the question again and see if it helps.=0ABlue skies & tailwinds ,=0ABob Borger=0AEuropa XS Tri, Rotax 914 w/ Intercooler & Airmaster C/S P rop=0ALittle Toot Sport Biplane, Lycoming AEIO-320 EXP=0A3705 Lynchburg Dr .=0ACorinth, TX 76208-5331=0AH: 940-497-2123=0AC: 817-992-1117=0A=0AOn May 08, 2014, at 08:23 AM, chris davis wrote:=0A=0Ais t here anyone here=0A=C2-=0AChris Davis=0AKXP 503 492 hrs=0AGlider Pilot=0A Disabled from crash building Firefly? ________________________________________________________________________________
Subject: oil low pessure
Date: May 20, 2014
Hi there all, Oil pressure on the 912S fitted on my MCR 4S) is ever low, under 2 bars and just over the red line... Is there a way to trim it? BTW it is not much more on the 912S on my Europa, just above 3 bars. Cheers, Max Cointe mcointe(at)free.fr F-PMLH Europa XS_TriGear Kit #560-2003 912ULS/AirmasterAP332 490 hours F-PLDJ DynAro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1600 heures -----Message d'origine----- De: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] De la part de rparigoris Envoy: mercredi 4 juillet 2012 00:36 : rotaxengines-list(at)matronics.com Objet: RotaxEngines-List: I wish there was a Rotax 9XX video like this. --> I wish there was a 9XX video like this: http://jalopnik.com/5922349/watch-an-engine-rebuild-itself-in-this-3000+phot o-stop+motion-video Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377182#377182 ________________________________________________________________________________
Date: May 20, 2014
May be time to replace the oil pressure sending unit. I still hard mount mine. They do not last long. One of these days I will remote mount and see if I can get more hours out of it. john h mkIII Titus, Alabama Hi there all, Oil pressure on the 912S fitted on my MCR 4S) is ever low, under 2 bars and just over the red line... Is there a way to trim it? BTW it is not much more on the 912S on my Europa, just above 3 bars. Cheers, Max Cointe mcointe(at)free.fr ________________________________________________________________________________
Date: May 20, 2014
Subject: Re: oil low pessure
From: William Daniell <wdaniell.longport(at)gmail.com>
Max I had the same thing, turned out to be air in the system. Will William Daniell LONGPORT +57 310 295 0744 On Tue, May 20, 2014 at 8:15 AM, John Hauck wrote: > jhauck(at)elmore.rr.com> > > May be time to replace the oil pressure sending unit. I still hard mount > mine. They do not last long. One of these days I will remote mount and > see > if I can get more hours out of it. > > john h > mkIII > Titus, Alabama > > > Hi there all, > > Oil pressure on the 912S fitted on my MCR 4S) is ever low, under 2 bars > and > just over the red line... Is there a way to trim it? > BTW it is not much more on the 912S on my Europa, just above 3 bars. > Cheers, > > > Max Cointe > mcointe(at)free.fr > > ________________________________________________________________________________
Date: May 20, 2014
29 psi to 43 psi is within the guidelines, but anything below 40 psi seems a bit low to be real. The number one cause for low readings is the sending unit. They cost about $35. Single pole sender: http://www.egauges.com/ProductDetails.asp?ProductCode=360-004 Double pole sender: http://www.egauges.com/ProductDetails.asp?ProductCode=360-430 The second cause is air in the oil sending line. The other item that should be done is install the new oil pressure regulator cone, spring and cap screw. It only takes about 5 min. and cost is around $75. The old ball bearing can and will cause lower readings for some. Never add shims unless you put an inline mechanical gauge in the oil line to test the real pressure or like the majority of people will actually over pressure the system because they never checked it and the readings were lying to them. Volume is more important than pressure. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423505#423505 ________________________________________________________________________________
Date: May 20, 2014
The first question I would ask myself is weather there is a real problem of low oil pressure or is it a simply an indication problem. The way to verify it is to (temporary) plumb a mechanical oil gauge using a T fitting and to compare the readings of the Rotax provided sensor with the mechanical one. Depending on the outcome of this test will be the diagnostic/corrections actions Nati RANS S6S 912ULS, Illinois On Tue, May 20, 2014 at 8:27 AM, William Daniell < wdaniell.longport(at)gmail.com> wrote: > Max I had the same thing, turned out to be air in the system. > Will > > William Daniell > LONGPORT > +57 310 295 0744 > > > On Tue, May 20, 2014 at 8:15 AM, John Hauck wrote: > >> jhauck(at)elmore.rr.com> >> >> May be time to replace the oil pressure sending unit. I still hard mount >> mine. They do not last long. One of these days I will remote mount and >> see >> if I can get more hours out of it. >> >> john h >> mkIII >> Titus, Alabama >> >> >> Hi there all, >> >> Oil pressure on the 912S fitted on my MCR 4S) is ever low, under 2 bars >> and >> just over the red line... Is there a way to trim it? >> BTW it is not much more on the 912S on my Europa, just above 3 bars. >> Cheers, >> >> >> Max Cointe >> mcointe(at)free.fr >> >> >> >> >> ========== >> - >> nes-List" target="_blank"> >> http://www.matronics.com/Navigator?RotaxEngines-List >> ========== >> MS - >> k">http://forums.matronics.com >> ========== >> e - >> -Matt Dralle, List Admin. >> t="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > > * > > ________________________________________________________________________________
Subject: Uneven Mag Drop 912 ULS
Date: May 22, 2014
This looks like a case of "It was working until I fixed it" Annual condition inspection; new plugs at 0.027-inches, carbmate showed exact balance, Dyna Vibe gave engine smoothness like a turbine, cylinder differential pressure almost perfect all cylinders, began using non-ethanol 91-octane gas, no oil consumption, crossover fittings (hoses) all tight, cruise speed normal, climb out at max throttle 5,000+ then over 5,100 after a few moments while still over the runway. Spark plug wires firmly attached "Killing" A side ignition, mag drop averages 150 rpm "Killing" B side ignition, mag drop averages 290 rpm, so it looks like a problem with the A side ignition. Next try will be new plugs (again) on top of cyl #1 & 2 new plugs (again) on bottom of cyl #4 & 3 to eliminate a bad new plug. Anything else to check? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423608#423608 ________________________________________________________________________________
Subject: Re: Uneven Mag Drop 912 ULS
Date: May 22, 2014
What rpm are you doing the mag drop at? Plugs are worth checking / replacing and gaps. Since you pulled the plug boots off you may have inadvertently pulled the plug wire a little too much where it goes into the boot. It wouldn't hurt to unscrew each one and trim the wire back 1/4" and then thread the boot back on. I even think 150 is a little high if the rpm is 3500 and under. Average is 50-100. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423611#423611 ________________________________________________________________________________
Date: May 22, 2014
Roger, I run up to 4,000 rpm and then 'kill' each circuit in turn. I have never 'unscrewed' a plug boot...I assume I can hold the main wire and twist on the 'plug' end that would connect to the top of the spark plug. I am picking up 4 new plugs tomorrow and will gap and install...will try that plug wire trimming and reattaching. Thanks for the input Roger...I wish you were a bit closer, I would just fly down to Tuscon and put the whole thing into your hands ! John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423614#423614 ________________________________________________________________________________
Date: May 23, 2014
John, I had almost the exact same problem except the mag drop was about 350 rpm on one side when checked at 4,000 rpm. What I found was that I had switched the two top left plug wires. #2 went to #4 plug & #4 went to #2 plug. The surprise was that it ran as well as it did with the plug wires reversed. Some idiot (me) had mismarked the cylinders when pulling the wires off. Henry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423628#423628 ________________________________________________________________________________
Date: May 23, 2014
Hi There All, Did the same as the length of the wire pushed me to switch them. On two mags at least all cylinders are lighted at the right time, but with one mag one cylinder is not lighted at the right time... Max Cointe mcointe(at)free.fr F-PMLH Europa XS_TriGear Kit #560-2003 912ULS/AirmasterAP332 490 hours F-PLDJ DynAro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1600 heures -----Message d'origine----- De: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] De la part de krazydoc33 Envoy: vendredi 23 mai 2014 10:29 : rotaxengines-list(at)matronics.com Objet: RotaxEngines-List: Re: Uneven Mag Drop 912 ULS --> John, I had almost the exact same problem except the mag drop was about 350 rpm on one side when checked at 4,000 rpm. What I found was that I had switched the two top left plug wires. #2 went to #4 plug & #4 went to #2 plug. The surprise was that it ran as well as it did with the plug wires reversed. Some idiot (me) had mismarked the cylinders when pulling the wires off. Henry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423628#423628 ________________________________________________________________________________
Date: May 23, 2014
John, I had a similar problem one time so I walked down the airport with my new plugs to a friends hanger. He had a spark plug "bomb" checker as part of his Champion spark plug cleaner unit. We checked the new plugs and sure enough, one of them would not fire under air pressure. I threw that one in the bin checked another and soon I was "back in business." So, you might have a bad "new" plug. Dick Maddux 912 UL ________________________________________________________________________________
Subject: Rotax 914 Turbo Warning Lights
Date: May 23, 2014
Hi All Rotax 914 warning lights. TCU switch ON. I have a Europa 914, Red warning light ?!!!!! Amber warning light ?!!!! What are they for, What should I know about them. Many thanks. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423638#423638 ________________________________________________________________________________
Subject: Re: Rotax 914 Turbo Warning Lights
Date: May 23, 2014
Alan,=0A=0AIf you don't have copies of the various 914 manuals, go to Rota x-Owner.com and download them.=0A=0ARotax Operators Manual, Section 4.4) C aution lamps -- Page 4-4 Subsections 4.4.1-4.4.3 describes the illuminatio n of the red and orange warning lamps and what the meaning is.=0A=0ASectio n 3.4) Engine start -- page 3-7 Lamps describes the self test illumination on start.=0ABlue skies & tailwinds,=0ABob Borger=0AEuropa XS Tri, Rotax 9 14 w/ Intercooler & Airmaster C/S Prop=0ALittle Toot Sport Biplane, Lycomi ng AEIO-320 EXP=0A3705 Lynchburg Dr.=0ACorinth, TX 76208-5331=0AH: 940-497 -2123=0AC: 817-992-1117=0A=0AOn May 23, 2014, at 08:56 AM, Alan Carter wrote:=0A=0A-- =C2- =C2-> RotaxEngines-List me ssage posted by: "Alan Carter" =0A=0AHi All=0ARotax 914 warning lights. TCU switch ON.=0AI hav e a Europa 914, =0ARed warning light ?!!!!! =0AAmber warning light ?!!!!=0A =0AWhat are they for, What should I know about them.=0AMany thanks.=0AAlan =0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.c = -- =C2- =C2- =C2- =C2-> http://www.matronics.com/Navigator?Rot ====================0A=0A=0A=0A ________________________________________________________________________________
Date: May 23, 2014
Hi Bob. Hope you are well, nice weather here in the UK. Well ," Blinking" lot to remember. I will make up a small emergency check list for that lot. Many thanks, Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423653#423653 ________________________________________________________________________________
Date: May 23, 2014
Hi Bob. Warning Lamps. I have a small plastic reservoir for the engine coolant, I take it the unit is a sealed radiator system, but I have noticed over a period of time the level has gone down a little, is this normal. Also why is there not a warning light which illuminates if the coolant level is getting low. Regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423661#423661 ________________________________________________________________________________
Date: May 23, 2014
plugs can be bad out of the box. I have had two over the years. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423669#423669 ________________________________________________________________________________
Date: May 23, 2014
I found all plugs on the A side very black and sooty. Had perhaps 3 or 4 hours total running time on them. I trimmed the spark plug wires back 1/4-inch and reinstalled the boots, and made absolutely certain the boots were correctly and well seated on the new spark plugs that I just purchased and set to 0.027. Have not yet run the engine..my time at the airport is very limited because I am a care taker for my invalid wife, and I can only 'get away' for a few hours at a time...tomorrow I hope to run the plane and see if I made any progress. I appreciate the help I have been give more than you might expect. John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423673#423673 ________________________________________________________________________________
Date: May 23, 2014
Hi Alan, Reasonably well over here. On the final stages of getting my Europa back in the air after the fuel tank replacement. Have to do some engine ground run tests tomorrow morning. Positive tests and weather permitting I might have it back in the air on Sunday. Weather may go to poop on Sunday though. And is certain forecast for poop on Monday. And I depart for Chennai, India on Tuesday. Will be there for almost 4 weeks on business. Id like to have the Europa ready to fly when I get back so I can have some fun and do some cross country travel. Yes, Blinking lot to remember. Mostly remember that if they come on in flight its a bad thing. Not a bad idea to add to the emergency check list either. As to the coolant levels. Yes, they seem to go down over time. Im not sure why. Give me some recent flight time starting in late June and well see what we come up with. As to a warning light for coolant level, I guess thatd be your coolant or CHT temperature indicators. Enjoy the good weather while you can! Best, Bob On May 23, 2014, at 12:58 PM, Alan Carter wrote: Hi Bob. Hope you are well, nice weather here in the UK. Well ," Blinking" lot to remember. I will make up a small emergency check list for that lot. Many thanks, Alan ________________________________________________________________________________
From: Ivor Phillips <ivor.phillips(at)ntlworld.com>
Date: May 24, 2014
I fitted a small float to my expansion bottle wired to a led on my panel, and pleased to say it's performed well over the last five years, A couple of years ago one of my water bleed screws developed a leak and it gave me a heads up earlier than a high water temperature would have done, so worth doing IMO, The Rotax900 series are renowned for loosing a bit of coolant from the water pump drain hole if left inactive for any length of time, Ivor Phillips Sent from my iPad > On 23 May 2014, at 22:13, Robert Borger wrote: > > > Hi Alan, > > Reasonably well over here. On the final stages of getting my Europa back in the air after the fuel tank replacement. Have to do some engine ground run tests tomorrow morning. Positive tests and weather permitting I might have it back in the air on Sunday. Weather may go to poop on Sunday though. And is certain forecast for poop on Monday. And I depart for Chennai, India on Tuesday. Will be there for almost 4 weeks on business. Id like to have the Europa ready to fly when I get back so I can have some fun and do some cross country travel. > > Yes, Blinking lot to remember. Mostly remember that if they come on in flight its a bad thing. > > Not a bad idea to add to the emergency check list either. > > As to the coolant levels. Yes, they seem to go down over time. Im not sure why. Give me some recent flight time starting in late June and well see what we come up with. As to a warning light for coolant level, I guess thatd be your coolant or CHT temperature indicators. > > Enjoy the good weather while you can! > > Best, > Bob > > > On May 23, 2014, at 12:58 PM, Alan Carter wrote: > > > Hi Bob. > Hope you are well, nice weather here in the UK. > Well ," Blinking" lot to remember. > I will make up a small emergency check list for that lot. > Many thanks, > Alan > > > > > ________________________________________________________________________________
Date: May 24, 2014
The mystery deepens I ran the engine after new plugs on the A side and now the problem has shifted to the B side. I was getting too much rpm drop when the B side was turned off, now the excessive rpm drop occurs when the A side is turned off. First mag drop checks at 3500 showed 70 rpm drop running with the B side only operating, and 170 rpm drop when the A side only was operating. Then at 4,000 rpm the first mag checks showed a rpm drop of 160 and 130 on A and B side. I thought it was fixed...but.... Subsequent mag checks consistently showed the when the A side was killed the rpm dropped an average of 385 rpm (4 tries), and when the B side was killed the average of 4 tries showed a drop of 120 rpm. This switching of excessive mag drop from the A side to the B side seems to indicate some sort of bad connection or other intermittent fault. Its interesting to note that the first tries showed normal and acceptable rpm drops as the mags were 'killed' but subsequent tries showed bad drops on the opposite side from yesterday's trials. I am really confused now. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423744#423744 ________________________________________________________________________________
Date: May 24, 2014
I have been really thinking about this problem, and recalled that two years ago I had a situation where I was getting serious rpm drops during mag checks. A local A&P and an experienced RV builder were helping me. We noticed that if the top cowling was off everything was fine. When fully assembled with the top cowling back on, the mag drop was seriously down again. I found an exhaust pipe slightly out of the 'socket' on the muffler. When fully cowled the engine was 'sucking' up exhaust fumes, and naturally the engine didn't work well. With the top cowling off there was plenty of free air and the engine worked fine. I am going to pull the cowling again and closely inspect for possible exhaust leaks. Anything else you can suggest? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423749#423749 ________________________________________________________________________________
Date: May 25, 2014
Ivor> I fitted a small float to my expansion bottle wired to a led on my panel Hi Ivor, Do you have a reference for the part you used for the float? Regards, sacha ________________________________________________________________________________
Date: May 25, 2014
Subject: Re: RotaxEngines-List Digest: 3 Msgs - 05/24/14
Subject: Re: Blue coolant tubing for Rotax 912S From: John Goodings <goodings(at)yorku.ca> We need to replace the large thin-walled blue coolant tubing on our Rotax 912S. I should be grateful if someone can tell me (a) the diameter; (b) the length we need, (c) possible suppliers, and (d) a Canadian supplier if that is possible. Our CH601HD is in Ottawa (Carp), and I have to order the tubing from Toronto. All I can recall is that this tubing has a rather special diameter, and is rather hard to find. Thanks for your help. John Goodings, C-FGPJ, CH601HD with R912S, Toronto/Ottawa/Carp ________________________________________________________________________________
Date: May 25, 2014
Date: May 25, 2014
My hope of finding a easy fix to my mag drop problem faded when no exhaust leaks were found.. bad mag drop with or without cowling on/off. Next effort will be to recheck carb balance in case that somehow got screwed up. ('tho I don't really expect this is the problem, but everything I can think of needs to be done !) Problem was on A side ignition, then switched to B side, and is staying on the B side being the problem. Problem exists if mag run up is done at 3500 or 4000, and same results if reading an MGL tach I have installed instead of the Dynon D-180's tach.) Failing in this, I guess the only thing left to try is to replace plugs and trim plug wires a bit on the remaining 4 plugs on which I have not done this. /John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423779#423779 ________________________________________________________________________________
Date: May 26, 2014
Hello Ivor. Looks like Lydd is going to become more active know Manston is closed. I would like to fit an indicator the same as you have done, sounds a good idea, is there something you can drill and attach to the filler cap. Can you give some info on this. Regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423797#423797 ________________________________________________________________________________
Date: May 26, 2014
Hi alan I drilled into the side of the plastic expansion bottle that Rotax supplied, I put her midway so the level would need to drop to minimum before the sensor triggered, I will try and turn up the type of float sensor I used from my records and let you no, It's a simple wiring job once you are through the firewall, Regards Ivor Sent from my iPad > On 26 May 2014, at 08:51, "Alan Carter" wrote: > > > Hello Ivor. > Looks like Lydd is going to become more active know Manston is closed. > I would like to fit an indicator the same as you have done, sounds a good idea, is there something you can drill and attach to the filler cap. > Can you give some info on this. > Regards. > Alan > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=423797#423797 > > > > > > > > > > ________________________________________________________________________________
Date: May 26, 2014
Alan, For my money it doesn't really matter what level the fluid is in the bottle as long as the level in the header tank is OK, and I assume you check that frequently as part of your preparation for flight. The bottle is just there to make any fluid pushed out by thermal expansion recoverable as I see it. Why add weight and complication? regards, David Joyce, G-XSDJ Ivor Phillips wrote: > > > Hi alan > I drilled into the side of the plastic expansion bottle >that Rotax supplied, I put her midway so the level would >need to drop to minimum before the sensor triggered, > I will try and turn up the type of float sensor I used >from my records and let you no, > It's a simple wiring job once you are through the >firewall, > Regards > Ivor > Sent from my iPad > >> On 26 May 2014, at 08:51, "Alan Carter" >> wrote: >> >> >> >> Hello Ivor. >> Looks like Lydd is going to become more active know >>Manston is closed. >> I would like to fit an indicator the same as you have >>done, sounds a good idea, is there something you can >>drill and attach to the filler cap. >> Can you give some info on this. >> Regards. >> Alan >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=423797#423797 >> >> >> >> >> >> >> >> >> >> > > >Un/Subscription, >http://www.matronics.com/Navigator?RotaxEngines-List >Forums! >Admin. > > > ________________________________________________________________________________
Date: May 26, 2014
I doubt seriously your uneven mag drop is caused by your carbs. It most likely is an ignition problem. I have dealt with similar problems with my old (mid 90's) 912 UL. During my last event I "bit the bullet" and bought new ignition wires and caps when I was having bad mag drops. This cured the problem. Now in my case the wires/caps were old and probably needed replacement anyway so I didn't feel too bad about it. I was able to save on the wire /plugs thru online vendors. I think if you clip the wires or search out a bad plug (bomb check them),you will find your problem. My opinion Dick Maddux Fox 4 912UL ________________________________________________________________________________
Date: May 26, 2014
All wires should have been trimmed. All plug gaps re-checked. I would do both of these first. Black sooty plugs under 3500 rpm can be very normal and can move to different plugs at times and is different for every engine. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423804#423804 ________________________________________________________________________________
Date: May 26, 2014
Dick, I agree with you. The carbs are not likely to be my mag drop problem. Prior to a lot of work during the annual condx inspection things were fine. Some thing I probably did is causing my problem, and I am at a loss for what it might be, so I am going back over everything I did to try to eliminate any remote possibility. Thanks for your input. John ----- Origin.al Message ----- From: Catz631(at)aol.com To: rotaxengines-list(at)matronics.com Sent: Monday, May 26, 2014 6:40 AM Subject: Re: RotaxEngines-List: Uneven Mag Drop 912 ULS I doubt seriously your uneven mag drop is caused by your carbs. It most l ikely is an ignition problem. I have dealt with similar problems with my ol d (mid 90's) 912 UL. During my last event I "bit the bullet" and bought new ignition wires and caps when I was having bad mag drops. This cured the problem. Now in my ca se the wires/caps were old and probably needed replacement anyway so I didn 't feel too bad about it. I was able to save on the wire /plugs thru online vendors. I think if you clip the wires or search out a bad plug (bomb check them) ,you will find your problem. My opinion Dick Maddux Fox 4 912UL --- This email is free from viruses and malware because avast! Antivirus protec tion is active. http://www.avast.com ________________________________________________________________________________
Date: May 26, 2014
Thanks, Roger...have trimmed the A side, and doing the B side this morning and going over the carb balance even tho I doubt it is involved, but the mag drop was OK prior to a lot of work during the annual condx inspection, so I have to think it was something I did. I still may have to fly to Tuscon and drop it into your hands !!! John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423806#423806 ________________________________________________________________________________
Date: May 26, 2014
Please remove me for this list!!! Sent from my iPhone > On May 26, 2014, at 8:21 AM, "JohnF" wrote: > > Dick, > > I agree with you. The carbs are not likely to be my mag drop problem. Prio r to a lot of work during the annual condx inspection things were fine. Some thing I probably did is causing my problem, and I am at a loss for what it m ight be, so I am going back over everything I did to try to eliminate any re mote possibility. Thanks for your input. > > John > ----- Origin.al Message ----- > From: Catz631(at)aol.com > To: rotaxengines-list(at)matronics.com > Sent: Monday, May 26, 2014 6:40 AM > Subject: Re: RotaxEngines-List: Uneven Mag Drop 912 ULS > > I doubt seriously your uneven mag drop is caused by your carbs. It most li kely is an ignition problem. I have dealt with similar problems with my old ( mid 90's) 912 UL. > During my last event I "bit the bullet" and bought new ignition wires and c aps when I was having bad mag drops. This cured the problem. Now in my case t he wires/caps were old and probably needed replacement anyway so I didn't fe el too bad about it. I was able to save on the wire /plugs thru online vendo rs. > I think if you clip the wires or search out a bad plug (bomb check them), you will find your problem. > My opinion > Dick Maddux > Fox 4 > 912UL > > > ist">http://www.matronics.com/Navigator?RotaxEngines-List > ics.com > .matronics.com/contribution > > > > > This email is free from viruses and malware because avast! Antivirus prote ction is active. > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
From: Pete Christensen <pchristensen10(at)austin.rr.com>
Date: May 26, 2014
Kelly, Go here. http://www.matronics.com/subscription/ > On May 26, 2014, at 8:23 AM, Richard Kelley wrote : > > Please remove me for this list!!! > > Sent from my iPhone > >> On May 26, 2014, at 8:21 AM, "JohnF" wrote: >> >> Dick, >> >> I agree with you. The carbs are not likely to be my mag drop problem. Pri or to a lot of work during the annual condx inspection things were fine. Som ething I probably did is causing my problem, and I am at a loss for what it m ight be, so I am going back over everything I did to try to eliminate any re mote possibility. Thanks for your input. >> >> John >> ----- Origin.al Message ----- >> From: Catz631(at)aol.com >> To: rotaxengines-list(at)matronics.com >> Sent: Monday, May 26, 2014 6:40 AM >> Subject: Re: RotaxEngines-List: Uneven Mag Drop 912 ULS >> >> I doubt seriously your uneven mag drop is caused by your carbs. It most l ikely is an ignition problem. I have dealt with similar problems with my old (mid 90's) 912 UL. >> During my last event I "bit the bullet" and bought new ignition wires and caps when I was having bad mag drops. This cured the problem. Now in my cas e the wires/caps were old and probably needed replacement anyway so I didn't feel too bad about it. I was able to save on the wire /plugs thru online ve ndors. >> I think if you clip the wires or search out a bad plug (bomb check them) ,you will find your problem. >> My opinion >> Dick Maddux >> Fox 4 >> 912UL >> >> >> ist">http://www.matronics.com/Navigator?RotaxEngines-List >> ics.com >> .matronics.com/contribution >> >> >> >> >> This email is free from viruses and malware because avast! Antivirus prot ection is active. >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: May 26, 2014
John, Easy ways just don't work! Well, they do, but only for those people that won the lottery. In simple terms, even if you had a exhaust leak, it very we'll Would Not give you a Mag drop. Nor would an out of tune Carb. Nor would the point of running With or Without the cowling on. That logic would follow checking the air pressure in your tires for the Mag drop! IF the Mag drop was good on one Mag, you are STILL using the SAME Carb for the Good Mag as for the Bad Mag , no reason why it would change for the second Mag ... Do ya see the logic there? Next is the Exhaust System. If there was an Exhaust leak, it would depend where the leak was... An exhaust valve leak would leak on either Mag so No difference in Mag check with this scenario. If it was a pipe or muffler leaking it would again be the same leak no matter which Mag you were on, so No difference in Mag check with this scenario either. This is the way you go about checking out a Mag Drop Problem: 1 - Clean the plugs. 2 - TRIPLE check the Timing. 3 - Check the condition AND resistance of the spark plug wires. 4 - Did you ever DROP a spark plug? If so - Replace it, don't think about it, do it. OR, test it on a Pressure-Voltage Spark Plug checking station. Those are your ONLY options when it come to plugs. 5 - This is a bit more difficult - Check the Voltage coming out of your Mag. You will need a High Voltage Probe Volt Meter, not many people have them. 6 - Question: Do you get a Mag drop at BOTH low RPM and high RPM? If so, then go back to #1 and run through the steps... 1 thru 5. If it only happens at High RPM then there could be a voltage breakdown of a component and an overhaul is needed. Problem being - You have a Rotax and both Low and High are both High when you consider the small delta between the two ranges. SO... What Next? SWAP out the Mag with one of known GOOD working condition. These are your options. Go through the steps and I'm positive you will find the problem. Barry On Sunday, May 25, 2014, JohnF wrote: > > My hope of finding a easy fix to my mag drop problem faded when no exhaust > leaks were found.. bad mag drop with or without cowling on/off. > > Next effort will be to recheck carb balance in case that somehow got > screwed up. ('tho I don't really expect this is the problem, but everything > I can think of needs to be done !) > > Problem was on A side ignition, then switched to B side, and is staying on > the B side being the problem. Problem exists if mag run up is done at 3500 > or 4000, and same results if reading an MGL tach I have installed instead > of the Dynon D-180's tach.) > > Failing in this, I guess the only thing left to try is to replace plugs > and trim plug wires a bit on the remaining 4 plugs on which I have not done > this. > > /John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=423779#423779 > > ________________________________________________________________________________
Date: May 26, 2014
John I had a similar problem, it was a bad connection in the bundle of wires that sits on top of the engine Will William Daniell LONGPORT +57 310 295 0744 On Mon, May 26, 2014 at 8:11 AM, JohnF wrote: > Dick, > > I agree with you. The carbs are not likely to be my mag drop problem. > Prior to a lot of work during the annual condx inspection things were fine. > Something I probably did is causing my problem, and I am at a loss for what > it might be, so I am going back over everything I did to try to eliminate > any remote possibility. Thanks for your input. > > John > > ----- Origin.al Message ----- > *From:* Catz631(at)aol.com > *To:* rotaxengines-list(at)matronics.com > *Sent:* Monday, May 26, 2014 6:40 AM > *Subject:* Re: RotaxEngines-List: Uneven Mag Drop 912 ULS > > I doubt seriously your uneven mag drop is caused by your carbs. It most > likely is an ignition problem. I have dealt with similar problems with my > old (mid 90's) 912 UL. > During my last event I "bit the bullet" and bought new ignition wires and > caps when I was having bad mag drops. This cured the problem. Now in my > case the wires/caps were old and probably needed replacement anyway so I > didn't feel too bad about it. I was able to save on the wire /plugs thru > online vendors. > I think if you clip the wires or search out a bad plug (bomb check > them),you will find your problem. > My opinion > Dick Maddux > Fox 4 > 912UL > > * > > ist">http://www.matronics.com/Navigator?RotaxEngines-List > ics.com <http://ics.com> > .matronics.com/contribution <http://matronics.com/contribution> > > * > > > ------------------------------ > <http://www.avast.com/> > > This email is free from viruses and malware because avast! Antivirus<http://www.avast.com/>protection is active. > > * > > > * > > ________________________________________________________________________________
Date: May 26, 2014
Progress on the mag drop ! Taking suggestions from you folks, I trimmed back the plug wires on the ignition side that I had not yet done. As expected, mag balance was perfect. As to exhaust leak...prior experience has shown me that a serious leak, one pipe 1/2 way out of the 'socket' on the muffler...definitely and repeatedly showed that mag drop was OK with the top cowling off, but bad with it one. An A&P and an experienced builder working with me saw this at least three times before I figured out what the problem was. Fixing the exhaust pipe into the muffler fixed everything. As to today....the mag drop, average of 10 'runs' is now only 14 rpm difference between A and B sides. I still am not happy with the drop, its 227 rpm drop on A side, and 241 rpm drop on B side. I have buttoned up the cowling and will fly tomorrow, weather permitting, and run the plane hard for about 30 minutes and see if that changes anything. My guess now is that the wire into the boot on cyl #4, bottom, was too far back in; trimming it as Roger and others suggested fixed the large difference in mag drops. My appreciation for all the help. John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423817#423817 ________________________________________________________________________________
Date: May 26, 2014
John, Easy ways just don't work! Well, they do, but only for those people that won the lottery. In simple terms, even if you had a exhaust leak, it very we'll Would Not give you a Mag drop. Nor would an out of tune Carb. Nor would the point of running With or Without the cowling on. That logic would follow checking the air pressure in your tires for the Mag drop! IF the Mag drop was good on one Mag, you are STILL using the SAME Carb for the Good Mag as for the Bad Mag , no reason why it would change for the second Mag ... Do ya see the logic there? Next is the Exhaust System. If there was an Exhaust leak, it would depend where the leak was... An exhaust valve leak would leak on either Mag so No difference in Mag check with this scenario. If it was a pipe or muffler leaking it would again be the same leak no matter which Mag you were on, so No difference in Mag check with this scenario either. This is the way you go about checking out a Mag Drop Problem: 1 - Clean the plugs. 2 - TRIPLE check the Timing. 3 - Check the condition AND resistance of the spark plug wires. 4 - Did you ever DROP a spark plug? If so - Replace it, don't think about it, do it. OR, test it on a Pressure-Voltage Spark Plug checking station. Those are your ONLY options when it come to plugs. 5 - This is a bit more difficult - Check the Voltage coming out of your Mag. You will need a High Voltage Probe Volt Meter, not many people have them. 6 - Question: Do you get a Mag drop at BOTH low RPM and high RPM? If so, then go back to #1 and run through the steps... 1 thru 5. If it only happens at High RPM then there could be a voltage breakdown of a component and an overhaul is needed. Problem being - You have a Rotax and both Low and High are both High when you consider the small delta between the two ranges. SO... What Next? SWAP out the Mag with one of known GOOD working condition. These are your options. Go through the steps and I'm positive you will find the problem. Barry On Mon, May 26, 2014 at 2:07 PM, JohnF wrote: > > Progress on the mag drop ! > > Taking suggestions from you folks, I trimmed back the plug wires on the > ignition side that I had not yet done. > > As expected, mag balance was perfect. > > As to exhaust leak...prior experience has shown me that a serious leak, > one pipe 1/2 way out of the 'socket' on the muffler...definitely and > repeatedly showed that mag drop was OK with the top cowling off, but bad > with it one. An A&P and an experienced builder working with me saw this at > least three times before I figured out what the problem was. Fixing the > exhaust pipe into the muffler fixed everything. > > As to today....the mag drop, average of 10 'runs' is now only 14 rpm > difference between A and B sides. I still am not happy with the drop, its > 227 rpm drop on A side, and 241 rpm drop on B side. I have buttoned up the > cowling and will fly tomorrow, weather permitting, and run the plane hard > for about 30 minutes and see if that changes anything. > > My guess now is that the wire into the boot on cyl #4, bottom, was too far > back in; trimming it as Roger and others suggested fixed the large > difference in mag drops. > > My appreciation for all the help. > > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=423817#423817 > > ________________________________________________________________________________
Date: May 27, 2014
I don't quite agree David, if unbeknown to you one of your hoses/ connections developed a leak when airborne you would be unaware until the level dropped below the pressure cap bottle, Once it had done so it would effectively stop circulating through the radiator and your temperature would start climbing upwards, The sensor is a couple of grams at most and IMO would give me a heads up long before it got critical, My expansion bottle is centre of the firewall as high as possible so cannot be seen without removing the top cowl, I of course visually check it but on a long flight it nice to know that nothing untoward is happening, For people interested in the sensor I used its a DE4 PPS 10 A01. Website http://www.deeter.co.uk/products/float-switch-liquid-level-sensors-overview/40-series-horizontal-liquid-level-sensor-float-switch Regards Ivor Sent from my iPad > On 26 May 2014, at 11:19, "David Joyce" wrote: > > > Alan, For my money it doesn't really matter what level the fluid is in the bottle as long as the level in the header tank is OK, and I assume you check that frequently as part of your preparation for flight. The bottle is just there to make any fluid pushed out by thermal expansion recoverable as I see it. Why add weight and complication? regards, David Joyce, G-XSDJ > > > Ivor Phillips wrote: >> Hi alan >> I drilled into the side of the plastic expansion bottle that Rotax supplied, I put her midway so the level would need to drop to minimum before the sensor triggered, >> I will try and turn up the type of float sensor I used from my records and let you no, >> It's a simple wiring job once you are through the firewall, >> Regards >> Ivor >> Sent from my iPad >>> On 26 May 2014, at 08:51, "Alan Carter" wrote: >>> Hello Ivor. >>> Looks like Lydd is going to become more active know Manston is closed. >>> I would like to fit an indicator the same as you have done, sounds a good idea, is there something you can drill and attach to the filler cap. >>> Can you give some info on this. >>> Regards. >>> Alan >>> Read this topic online here: >>> http://forums.matronics.com/viewtopic.php?p=423797#423797 >> Un/Subscription, >> http://www.matronics.com/Navigator?RotaxEngines-List >> Forums! >> Admin. > > > > ________________________________________________________________________________
Date: May 27, 2014
Ivor Phillips a crit : > > I don't quite agree David, if unbeknown to you one of your hoses/ connections developed a leak when airborne you would be unaware until the level dropped below the pressure cap bottle, Ivor and all, In my opinion, monitoring the coolant *pressure* would be preferable, since pressure would be more closely related to the primary cause -leak in the circuit - than the consequence - low coolant level. Be prepared for some additional head-scratching, like is always the case when you monitor a new parameter. One word of caution : anytime one opens the pressure cap of the expansion tank, one breaks the syphon, so it's not the best way to check the coolant level. Better monitor the level in the translucent overflow bottle, without disturbing the coolant circuit. Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: May 27, 2014
Ivor, It is not often I disagree with you, but I would guess that a leaking or burst hose will let fluid out and air out of/in to the radiator system without producing sufficient suction to empty out the overflow bottle, so that you could boil without your level sensor saying anything. On the other hand boiling the coolant is something that is very noticeable in air - you get blue fluid all over the screen - experienced when I was trying to do a 5 min full power climb to satisfy the LAA with one of my early model props.! Regards, David Ivor Phillips wrote: > > > I don't quite agree David, if unbeknown to you one of >your hoses/ connections developed a leak when airborne >you would be unaware until the level dropped below the >pressure cap bottle, > Once it had done so it would effectively stop >circulating through the radiator and your temperature >would start climbing upwards, > The sensor is a couple of grams at most and IMO would >give me a heads up long before it got critical, > My expansion bottle is centre of the firewall as high as >possible so cannot be seen without removing the top cowl, >I of course visually check it but on a long flight it >nice to know that nothing untoward is happening, >For people interested in the sensor I used its a DE4 PPS >10 A01. Website > > http://www.deeter.co.uk/products/float-switch-liquid-level-sensors-overview/40-series-horizontal-liquid-level-sensor-float-switch > > Regards > Ivor > Sent from my iPad > >> On 26 May 2014, at 11:19, "David Joyce" >> wrote: >> >> >> >> Alan, For my money it doesn't really matter what level >>the fluid is in the bottle as long as the level in the >>header tank is OK, and I assume you check that frequently >>as part of your preparation for flight. The bottle is >>just there to make any fluid pushed out by thermal >>expansion recoverable as I see it. Why add weight and >>complication? regards, David Joyce, G-XSDJ >> >> >> Ivor Phillips wrote: >>> >>> Hi alan >>> I drilled into the side of the plastic expansion bottle >>>that Rotax supplied, I put her midway so the level would >>>need to drop to minimum before the sensor triggered, >>> I will try and turn up the type of float sensor I used >>>from my records and let you no, >>> It's a simple wiring job once you are through the >>>firewall, >>> Regards >>> Ivor >>> Sent from my iPad >>>> On 26 May 2014, at 08:51, "Alan Carter" >>>> wrote: >>>> >>>> Hello Ivor. >>>> Looks like Lydd is going to become more active know >>>>Manston is closed. >>>> I would like to fit an indicator the same as you have >>>>done, sounds a good idea, is there something you can >>>>drill and attach to the filler cap. >>>> Can you give some info on this. >>>> Regards. >>>> Alan >>>> Read this topic online here: >>>> http://forums.matronics.com/viewtopic.php?p=423797#423797 >>> Un/Subscription, >>> http://www.matronics.com/Navigator?RotaxEngines-List >>> Forums! >>> Admin. >> >> >> >> > > >Un/Subscription, >http://www.matronics.com/Navigator?RotaxEngines-List >Forums! >Admin. > > > ________________________________________________________________________________
Date: May 27, 2014
Many Thanks All. Ivan thanks for your link. I would think with a small leak which could occur in flight or a leak the occurs when warming up and stops when the engine is hot would take coolant from the reservoir, as you can not see the reservoir with the cowlings on I think it is a nice idea to have a warning light as its so simple to install. Myself I would like to find a Small sensor probe that I could drill a hole in the reservoir filler cap and fix this sensor probe. Anybody know of such a think,? Can always find a new cap. Regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423875#423875 ________________________________________________________________________________
Subject: 912 only putting out 12.5 volts
Date: May 27, 2014
My grand Rapids unit shows 12.5 volts. Goes down to 12.3 with radio and transponder on. landing light or strobes take it below 12.0. Installed new regulator( Kawasaki) and new battery. Still persist. Any Ideas ?? -------- Dennis Singleton Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423891#423891 ________________________________________________________________________________
Date: May 28, 2014
I see what you are say David but in my case it works well, my Expansion bottle is set high in the centre of the firewall and has a positive head of pressure back to the filler cap, Twice I have had small leaks, one from a hose clip before changing to the spring clamp type and once from a bottom hose bleed nipple that I had fitted, Both times I was aware of the coolant loss long before it became critical, I take your point that with a burst hose it probably wouldn't react quickly enough but thats were my water temperature sender with voice activated Dynon shouting high temperature in my ears would get my complete attention, Regards ivor Sent from my iPad > On 27 May 2014, at 14:58, "David Joyce" wrote: > > > Ivor, It is not often I disagree with you, but I would guess that a leaking or burst hose will let fluid out and air out of/in to the radiator system without producing sufficient suction to empty out the overflow bottle, so that you could boil without your level sensor saying anything. On the other hand boiling the coolant is something that is very noticeable in air - you get blue fluid all over the screen - experienced when I was trying to do a 5 min full power climb to satisfy the LAA with one of my early model props.! > Regards, David > > > Ivor Phillips wrote: >> I don't quite agree David, if unbeknown to you one of your hoses/ connections developed a leak when airborne you would be unaware until the level dropped below the pressure cap bottle, >> Once it had done so it would effectively stop circulating through the radiator and your temperature would start climbing upwards, The sensor is a couple of grams at most and IMO would give me a heads up long before it got critical, My expansion bottle is centre of the firewall as high as possible so cannot be seen without removing the top cowl, I of course visually check it but on a long flight it nice to know that nothing untoward is happening, >> For people interested in the sensor I used its a DE4 PPS 10 A01. Website >> http://www.deeter.co.uk/products/float-switch-liquid-level-sensors-overview/40-series-horizontal-liquid-level-sensor-float-switch >> Regards >> Ivor >> Sent from my iPad >>> On 26 May 2014, at 11:19, "David Joyce" wrote: >>> Alan, For my money it doesn't really matter what level the fluid is in the bottle as long as the level in the header tank is OK, and I assume you check that frequently as part of your preparation for flight. The bottle is just there to make any fluid pushed out by thermal expansion recoverable as I see it. Why add weight and complication? regards, David Joyce, G-XSDJ >>> Ivor Phillips wrote: >>>> Hi alan >>>> I drilled into the side of the plastic expansion bottle that Rotax supplied, I put her midway so the level would need to drop to minimum before the sensor triggered, >>>> I will try and turn up the type of float sensor I used from my records and let you no, >>>> It's a simple wiring job once you are through the firewall, >>>> Regards >>>> Ivor >>>> Sent from my iPad >>>>> On 26 May 2014, at 08:51, "Alan Carter" wrote: >>>>> Hello Ivor. >>>>> Looks like Lydd is going to become more active know Manston is closed. >>>>> I would like to fit an indicator the same as you have done, sounds a good idea, is there something you can drill and attach to the filler cap. >>>>> Can you give some info on this. >>>>> Regards. >>>>> Alan >>>>> Read this topic online here: >>>>> http://forums.matronics.com/viewtopic.php?p=423797#423797 >>>> Un/Subscription, >>>> http://www.matronics.com/Navigator?RotaxEngines-List >>>> Forums! >>>> Admin. >> Un/Subscription, >> http://www.matronics.com/Navigator?RotaxEngines-List >> Forums! >> Admin. > > > > ________________________________________________________________________________
Subject: Re: 912 only putting out 12.5 volts
Date: May 28, 2014
Dennis, have you checked a direct voltage at the battery to compare? My newly fitted MGL EMS showed only about 11volts, but the battery voltage was 12.9 and there was an adjustment in the set up program that allowed me to make the two read identically. Regards, David Joyce, G-XSDJ "dsingleton" wrote: > > > My grand Rapids unit shows 12.5 volts. Goes down to 12.3 >with radio and transponder on. landing light or strobes >take it below 12.0. Installed new regulator( Kawasaki) >and new battery. Still persist. Any Ideas ?? > > -------- > Dennis Singleton > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=423891#423891 > > > > > > > >Un/Subscription, >http://www.matronics.com/Navigator?RotaxEngines-List >Forums! >Admin. > > > ________________________________________________________________________________
Date: May 28, 2014
David Joyce a crit : > > > > Dennis, have you checked a direct voltage at the battery to compare? > My newly fitted MGL EMS showed only about 11volts, but the battery > voltage was 12.9 and there was an adjustment in the set up program > that allowed me to make the two read identically. +1 Also please give additional information : - Was your electrical system performing well before ? - Or is it a new or modified installation, etc. ? - Is a description of schematics of your power circuit available ? - Have you checked that your actual installation is in accordance with the intended schematics ? - Did you check every connection ? - Etc.. Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: May 30, 2014
What if the overflow bottle was mounted on the cockpit side of the firewall where it was visible at all times? On May 28, 2014, at 2:04 AM, Ivor Phillips wrote: > > I see what you are say David but in my case it works well, my Expansion bottle is set high in the centre of the firewall and has a positive head of pressure back to the filler cap, > Twice I have had small leaks, one from a hose clip before changing to the spring clamp type and once from a bottom hose bleed nipple that I had fitted, > Both times I was aware of the coolant loss long before it became critical, > I take your point that with a burst hose it probably wouldn't react quickly enough but thats were my water temperature sender with voice activated Dynon shouting high temperature in my ears would get my complete attention, > > Regards > ivor > > Sent from my iPad > >> On 27 May 2014, at 14:58, "David Joyce" wrote: >> >> >> Ivor, It is not often I disagree with you, but I would guess that a leaking or burst hose will let fluid out and air out of/in to the radiator system without producing sufficient suction to empty out the overflow bottle, so that you could boil without your level sensor saying anything. On the other hand boiling the coolant is something that is very noticeable in air - you get blue fluid all over the screen - experienced when I was trying to do a 5 min full power climb to satisfy the LAA with one of my early model props.! >> Regards, David >> >> >> Ivor Phillips wrote: >>> I don't quite agree David, if unbeknown to you one of your hoses/ connections developed a leak when airborne you would be unaware until the level dropped below the pressure cap bottle, >>> Once it had done so it would effectively stop circulating through the radiator and your temperature would start climbing upwards, The sensor is a couple of grams at most and IMO would give me a heads up long before it got critical, My expansion bottle is centre of the firewall as high as possible so cannot be seen without removing the top cowl, I of course visually check it but on a long flight it nice to know that nothing untoward is happening, >>> For people interested in the sensor I used its a DE4 PPS 10 A01. Website >>> http://www.deeter.co.uk/products/float-switch-liquid-level-sensors-overview/40-series-horizontal-liquid-level-sensor-float-switch >>> Regards >>> Ivor >>> Sent from my iPad >>>> On 26 May 2014, at 11:19, "David Joyce" wrote: >>>> Alan, For my money it doesn't really matter what level the fluid is in the bottle as long as the level in the header tank is OK, and I assume you check that frequently as part of your preparation for flight. The bottle is just there to make any fluid pushed out by thermal expansion recoverable as I see it. Why add weight and complication? regards, David Joyce, G-XSDJ >>>> Ivor Phillips wrote: >>>>> Hi alan >>>>> I drilled into the side of the plastic expansion bottle that Rotax supplied, I put her midway so the level would need to drop to minimum before the sensor triggered, >>>>> I will try and turn up the type of float sensor I used from my records and let you no, >>>>> It's a simple wiring job once you are through the firewall, >>>>> Regards >>>>> Ivor >>>>> Sent from my iPad >>>>>> On 26 May 2014, at 08:51, "Alan Carter" wrote: >>>>>> Hello Ivor. >>>>>> Looks like Lydd is going to become more active know Manston is closed. >>>>>> I would like to fit an indicator the same as you have done, sounds a good idea, is there something you can drill and attach to the filler cap. >>>>>> Can you give some info on this. >>>>>> Regards. >>>>>> Alan >>>>>> Read this topic online here: >>>>>> http://forums.matronics.com/viewtopic.php?p=423797#423797 >>>>> Un/Subscription, >>>>> http://www.matronics.com/Navigator?RotaxEngines-List >>>>> Forums! >>>>> Admin. >>> Un/Subscription, >>> http://www.matronics.com/Navigator?RotaxEngines-List >>> Forums! >>> Admin. >> >> >> >> > > > > > ________________________________________________________________________________
Date: May 31, 2014
When the fluid boils the cockpit could be filled with steam. That would certainly get your attention! Regards Brian Davies -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Joel Milloway Sent: 31 May 2014 06:20 Subject: Re: RotaxEngines-List: Re: Rotax 914 Turbo Warning Lights --> What if the overflow bottle was mounted on the cockpit side of the firewall where it was visible at all times? On May 28, 2014, at 2:04 AM, Ivor Phillips wrote: > --> > > I see what you are say David but in my case it works well, my > Expansion bottle is set high in the centre of the firewall and has a > positive head of pressure back to the filler cap, Twice I have had > small leaks, one from a hose clip before changing to the spring clamp > type and once from a bottom hose bleed nipple that I had fitted, Both > times I was aware of the coolant loss long before it became critical, > I take your point that with a burst hose it probably wouldn't react > quickly enough but thats were my water temperature sender with voice > activated Dynon shouting high temperature in my ears would get my > complete attention, > > Regards > ivor > > Sent from my iPad > >> On 27 May 2014, at 14:58, "David Joyce" wrote: >> >> --> >> >> Ivor, It is not often I disagree with you, but I would guess that a leaking or burst hose will let fluid out and air out of/in to the radiator system without producing sufficient suction to empty out the overflow bottle, so that you could boil without your level sensor saying anything. On the other hand boiling the coolant is something that is very noticeable in air - you get blue fluid all over the screen - experienced when I was trying to do a 5 min full power climb to satisfy the LAA with one of my early model props.! >> Regards, David >> >> >> Ivor Phillips wrote: >>> --> >>> I don't quite agree David, if unbeknown to you one of your hoses/ >>> connections developed a leak when airborne you would be unaware until the level dropped below the pressure cap bottle, Once it had done so it would effectively stop circulating through the radiator and your temperature would start climbing upwards, The sensor is a couple of grams at most and IMO would give me a heads up long before it got critical, My expansion bottle is centre of the firewall as high as possible so cannot be seen without removing the top cowl, I of course visually check it but on a long flight it nice to know that nothing untoward is happening, >>> For people interested in the sensor I used its a DE4 PPS 10 A01. Website >>> http://www.deeter.co.uk/products/float-switch-liquid-level-sensors-o >>> verview/40-series-horizontal-liquid-level-sensor-float-switch >>> Regards >>> Ivor >>> Sent from my iPad >>>> On 26 May 2014, at 11:19, "David Joyce" wrote: >>>> --> >>>> Alan, For my money it doesn't really matter what level the fluid is >>>> in the bottle as long as the level in the header tank is OK, and I >>>> assume you check that frequently as part of your preparation for flight. The bottle is just there to make any fluid pushed out by thermal expansion recoverable as I see it. Why add weight and complication? regards, wrote: >>>>> --> >>>>> Hi alan >>>>> I drilled into the side of the plastic expansion bottle that Rotax >>>>> supplied, I put her midway so the level would need to drop to >>>>> minimum before the sensor triggered, I will try and turn up the >>>>> type of float sensor I used from my records and let you no, It's a >>>>> simple wiring job once you are through the firewall, Regards Ivor >>>>> Sent from my iPad >>>>>> On 26 May 2014, at 08:51, "Alan Carter" wrote: >>>>>> --> >>>>>> Hello Ivor. >>>>>> Looks like Lydd is going to become more active know Manston is closed. >>>>>> I would like to fit an indicator the same as you have done, sounds a good idea, is there something you can drill and attach to the filler cap. >>>>>> Can you give some info on this. >>>>>> Regards. >>>>>> Alan >>>>>> Read this topic online here: >>>>>> http://forums.matronics.com/viewtopic.php?p=423797#423797 >>>>> Un/Subscription, >>>>> http://www.matronics.com/Navigator?RotaxEngines-List >>>>> Forums! >>>>> Admin. >>> Un/Subscription, >>> http://www.matronics.com/Navigator?RotaxEngines-List >>> Forums! >>> Admin. >> >> >> >> > > > > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: May 31, 2014
Thats the whole point right :) On May 31, 2014, at 1:46 AM, Brian Davies wrote: > > When the fluid boils the cockpit could be filled with steam. That would > certainly get your attention! > > Regards > > Brian Davies > > -----Original Message----- > From: owner-rotaxengines-list-server(at)matronics.com > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Joel > Milloway > Sent: 31 May 2014 06:20 > To: rotaxengines-list(at)matronics.com > Subject: Re: RotaxEngines-List: Re: Rotax 914 Turbo Warning Lights > > --> > > What if the overflow bottle was mounted on the cockpit side of the firewall > where it was visible at all times? > On May 28, 2014, at 2:04 AM, Ivor Phillips > wrote: > >> --> >> >> I see what you are say David but in my case it works well, my >> Expansion bottle is set high in the centre of the firewall and has a >> positive head of pressure back to the filler cap, Twice I have had >> small leaks, one from a hose clip before changing to the spring clamp >> type and once from a bottom hose bleed nipple that I had fitted, Both >> times I was aware of the coolant loss long before it became critical, >> I take your point that with a burst hose it probably wouldn't react >> quickly enough but thats were my water temperature sender with voice >> activated Dynon shouting high temperature in my ears would get my >> complete attention, >> >> Regards >> ivor >> >> Sent from my iPad >> >>> On 27 May 2014, at 14:58, "David Joyce" > wrote: >>> >>> --> >>> >>> Ivor, It is not often I disagree with you, but I would guess that a > leaking or burst hose will let fluid out and air out of/in to the radiator > system without producing sufficient suction to empty out the overflow > bottle, so that you could boil without your level sensor saying anything. On > the other hand boiling the coolant is something that is very noticeable in > air - you get blue fluid all over the screen - experienced when I was trying > to do a 5 min full power climb to satisfy the LAA with one of my early model > props.! >>> Regards, David >>> >>> >>> Ivor Phillips wrote: >>>> --> >>>> I don't quite agree David, if unbeknown to you one of your hoses/ >>>> connections developed a leak when airborne you would be unaware until > the level dropped below the pressure cap bottle, Once it had done so it > would effectively stop circulating through the radiator and your temperature > would start climbing upwards, The sensor is a couple of grams at most and > IMO would give me a heads up long before it got critical, My expansion > bottle is centre of the firewall as high as possible so cannot be seen > without removing the top cowl, I of course visually check it but on a long > flight it nice to know that nothing untoward is happening, >>>> For people interested in the sensor I used its a DE4 PPS 10 A01. > Website >>>> http://www.deeter.co.uk/products/float-switch-liquid-level-sensors-o >>>> verview/40-series-horizontal-liquid-level-sensor-float-switch >>>> Regards >>>> Ivor >>>> Sent from my iPad >>>>> On 26 May 2014, at 11:19, "David Joyce" > wrote: >>>>> --> >>>>> Alan, For my money it doesn't really matter what level the fluid is >>>>> in the bottle as long as the level in the header tank is OK, and I >>>>> assume you check that frequently as part of your preparation for > flight. The bottle is just there to make any fluid pushed out by thermal > expansion recoverable as I see it. Why add weight and complication? regards, > wrote: >>>>>> --> >>>>>> Hi alan >>>>>> I drilled into the side of the plastic expansion bottle that Rotax >>>>>> supplied, I put her midway so the level would need to drop to >>>>>> minimum before the sensor triggered, I will try and turn up the >>>>>> type of float sensor I used from my records and let you no, It's a >>>>>> simple wiring job once you are through the firewall, Regards Ivor >>>>>> Sent from my iPad >>>>>>> On 26 May 2014, at 08:51, "Alan Carter" > wrote: >>>>>>> --> >>>>>>> Hello Ivor. >>>>>>> Looks like Lydd is going to become more active know Manston is > closed. >>>>>>> I would like to fit an indicator the same as you have done, sounds a > good idea, is there something you can drill and attach to the filler cap. >>>>>>> Can you give some info on this. >>>>>>> Regards. >>>>>>> Alan >>>>>>> Read this topic online here: >>>>>>> http://forums.matronics.com/viewtopic.php?p=423797#423797 >>>>>> Un/Subscription, >>>>>> http://www.matronics.com/Navigator?RotaxEngines-List >>>>>> Forums! >>>>>> Admin. >>>> Un/Subscription, >>>> http://www.matronics.com/Navigator?RotaxEngines-List >>>> Forums! >>>> Admin. >>> >>> >>> >>> >> >> >> >> >> > > > > > > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: May 31, 2014
I was once comfortable checking the overflow bottle level. not any more. A friend had a small leak in one of his hoses and the first indication he had was an overheat indication. When he landed his over flow bottle was at the normal level but he had no coolant in the pressure reservoir. Over time the coolant had slowly leaked ender pressure and on cool down the system sucked in air instead of coolant from the reserve bottle. I now check for leaks, bottle level and coolant in the pressure tank. Carl ----- Original Message ----- From: "GTH" <gilles.thesee(at)free.fr> Sent: Tuesday, May 27, 2014 8:33 AM Subject: Re: RotaxEngines-List: Re: Rotax 914 Turbo Warning Lights > > Ivor Phillips a crit : >> >> >> I don't quite agree David, if unbeknown to you one of your hoses/ >> connections developed a leak when airborne you would be unaware until the >> level dropped below the pressure cap bottle, > > Ivor and all, > > In my opinion, monitoring the coolant *pressure* would be preferable, > since pressure would be more closely related to the primary cause -leak in > the circuit - than the consequence - low coolant level. > Be prepared for some additional head-scratching, like is always the case > when you monitor a new parameter. > > One word of caution : anytime one opens the pressure cap of the expansion > tank, one breaks the syphon, so it's not the best way to check the coolant > level. Better monitor the level in the translucent overflow bottle, > without disturbing the coolant circuit. > > Best regards, > -- > Gilles > http://contrails.free.fr > > > ________________________________________________________________________________
From: "Richard Collings" <rcollings(at)talktalk.net>
Date: Jun 02, 2014
Hi everyone. I think the experienced pilots amongst our community need to stop this right now and I don=99t class myself in that group. Imagine the situation, say on take off, your busy in the cockpit to say the least and you see the engine temp rise into the red, what do you do, you can=99t shut down, you must expedite a safe landing asap. If you have time before the engine seizes try to do an abbreviated circuit and radio your intention with a Pan call and pray you can get back down in one piece. I am sure other pilots will offer differing scenarios. The point is if on top of the considerable work load the pilot has, he now has to somehow manage boiling water and steam in the cabin, he isn=99t going to do it. Sorry for being blunt. Richard only 700ish hrs 75 on type From: Joel Milloway Sent: Saturday, May 31, 2014 2:40 PM Subject: Re: RotaxEngines-List: Re: Rotax 914 Turbo Warning Lights Thats the whole point right :) On May 31, 2014, at 1:46 AM, Brian Davies wrote: When the fluid boils the cockpit could be filled with steam. That would certainly get your attention! Regards Brian Davies -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Joel Milloway Sent: 31 May 2014 06:20 To: rotaxengines-list(at)matronics.com Subject: Re: RotaxEngines-List: Re: Rotax 914 Turbo Warning Lights --> What if the overflow bottle was mounted on the cockpit side of the firewall where it was visible at all times? On May 28, 2014, at 2:04 AM, Ivor Phillips wrote: --> I see what you are say David but in my case it works well, my Expansion bottle is set high in the centre of the firewall and has a positive head of pressure back to the filler cap, Twice I have had small leaks, one from a hose clip before changing to the spring clamp type and once from a bottom hose bleed nipple that I had fitted, Both times I was aware of the coolant loss long before it became critical, I take your point that with a burst hose it probably wouldn't react quickly enough but thats were my water temperature sender with voice activated Dynon shouting high temperature in my ears would get my complete attention, Regards ivor Sent from my iPad On 27 May 2014, at 14:58, "David Joyce" wrote: --> Ivor, It is not often I disagree with you, but I would guess that a leaking or burst hose will let fluid out and air out of/in to the radiator system without producing sufficient suction to empty out the overflow bottle, so that you could boil without your level sensor saying anything. On the other hand boiling the coolant is something that is very noticeable in air - you get blue fluid all over the screen - experienced when I was trying to do a 5 min full power climb to satisfy the LAA with one of my early model props.! Regards, David Ivor Phillips wrote: --> I don't quite agree David, if unbeknown to you one of your hoses/ connections developed a leak when airborne you would be unaware until the level dropped below the pressure cap bottle, Once it had done so it would effectively stop circulating through the radiator and your temperature would start climbing upwards, The sensor is a couple of grams at most and IMO would give me a heads up long before it got critical, My expansion bottle is centre of the firewall as high as possible so cannot be seen without removing the top cowl, I of course visually check it but on a long flight it nice to know that nothing untoward is happening, For people interested in the sensor I used its a DE4 PPS 10 A01. Website http://www.deeter.co.uk/products/float-switch-liquid-level-sensors-o verview/40-series-horizontal-liquid-level-sensor-float-switch Regards Ivor Sent from my iPad On 26 May 2014, at 11:19, "David Joyce" wrote: --> Alan, For my money it doesn't really matter what level the fluid is in the bottle as long as the level in the header tank is OK, and I assume you check that frequently as part of your preparation for flight. The bottle is just there to make any fluid pushed out by thermal expansion recoverable as I see it. Why add weight and complication? regards, wrote: --> Hi alan I drilled into the side of the plastic expansion bottle that Rotax supplied, I put her midway so the level would need to drop to minimum before the sensor triggered, I will try and turn up the type of float sensor I used from my records and let you no, It's a simple wiring job once you are through the firewall, Regards Ivor Sent from my iPad On 26 May 2014, at 08:51, "Alan Carter" wrote: --> Hello Ivor. Looks like Lydd is going to become more active know Manston is closed. I would like to fit an indicator the same as you have done, sounds a good idea, is there something you can drill and attach to the filler cap. Can you give some info on this. Regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423797#423797 Un/Subscription, http://www.matronics.com/Navigator?RotaxEngines-List Forums! Admin. Un/Subscription, http://www.matronics.com/Navigator?RotaxEngines-List Forums! Admin. ----- No virus found in this message. Checked by AVG - http://www.m &n - &nbs --> http://www.matronics.com/co================ ________________________________________________________________________________
Subject: Re: Rotax 914 Turbo Warning Lights
Date: Jun 02, 2014
Folks: I believe the 912 series engines are primarily oil cooled, with some water and air cooling to help. The engine can be flown at reduced power for some time after a complete loss of coolant without seizing. Before I sacrificed myself and my airplane, I'd fly to a safe landing area to fix the problem. john h MKIII Near - Burns Junction, Oregon From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Richard Collings Sent: Monday, June 02, 2014 6:18 AM Subject: Re: RotaxEngines-List: Re: Rotax 914 Turbo Warning Lights Hi everyone. I think the experienced pilots amongst our community need to stop this right now and I don=99t class myself in that group. Imagine the situation, say on take off, your busy in the cockpit to say the least and you see the engine temp rise into the red, what do you do, you can=99t shut down, you must expedite a safe landing asap. If you have time before the engine seizes try to do an abbreviated circuit and radio your intention with a Pan call and pray you can get back down in one piece. I am sure other pilots will offer differing scenarios. The point is if on top of the considerable work load the pilot has, he now has to somehow manage boiling water and steam in the cabin, he isn=99t going to do it. Sorry for being blunt. Richard only 700ish hrs 75 on type From: Joel Milloway <mailto:dirtfly7(at)yahoo.com> Sent: Saturday, May 31, 2014 2:40 PM Subject: Re: RotaxEngines-List: Re: Rotax 914 Turbo Warning Lights Thats the whole point right :) On May 31, 2014, at 1:46 AM, Brian Davies wrote: When the fluid boils the cockpit could be filled with steam. That would certainly get your attention! Regards Brian Davies -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Joel Milloway Sent: 31 May 2014 06:20 Subject: Re: RotaxEngines-List: Re: Rotax 914 Turbo Warning Lights --> What if the overflow bottle was mounted on the cockpit side of the firewall where it was visible at all times? On May 28, 2014, at 2:04 AM, Ivor Phillips wrote: --> I see what you are say David but in my case it works well, my Expansion bottle is set high in the centre of the firewall and has a positive head of pressure back to the filler cap, Twice I have had small leaks, one from a hose clip before changing to the spring clamp type and once from a bottom hose bleed nipple that I had fitted, Both times I was aware of the coolant loss long before it became critical, I take your point that with a burst hose it probably wouldn't react quickly enough but thats were my water temperature sender with voice activated Dynon shouting high temperature in my ears would get my complete attention, Regards ivor Sent from my iPad On 27 May 2014, at 14:58, "David Joyce" wrote: --> Ivor, It is not often I disagree with you, but I would guess that a leaking or burst hose will let fluid out and air out of/in to the radiator system without producing sufficient suction to empty out the overflow bottle, so that you could boil without your level sensor saying anything. On the other hand boiling the coolant is something that is very noticeable in air - you get blue fluid all over the screen - experienced when I was trying to do a 5 min full power climb to satisfy the LAA with one of my early model props.! Regards, David Ivor Phillips wrote: --> I don't quite agree David, if unbeknown to you one of your hoses/ connections developed a leak when airborne you would be unaware until the level dropped below the pressure cap bottle, Once it had done so it would effectively stop circulating through the radiator and your temperature would start climbing upwards, The sensor is a couple of grams at most and IMO would give me a heads up long before it got critical, My expansion bottle is centre of the firewall as high as possible so cannot be seen without removing the top cowl, I of course visually check it but on a long flight it nice to know that nothing untoward is happening, For people interested in the sensor I used its a DE4 PPS 10 A01. Website http://www.deeter.co.uk/products/float-switch-liquid-level-sensors-o verview/40-series-horizontal-liquid-level-sensor-float-switch Regards Ivor Sent from my iPad On 26 May 2014, at 11:19, "David Joyce" wrote: --> Alan, For my money it doesn't really matter what level the fluid is in the bottle as long as the level in the header tank is OK, and I assume you check that frequently as part of your preparation for flight. The bottle is just there to make any fluid pushed out by thermal expansion recoverable as I see it. Why add weight and complication? regards, wrote: --> Hi alan I drilled into the side of the plastic expansion bottle that Rotax supplied, I put her midway so the level would need to drop to minimum before the sensor triggered, I will try and turn up the type of float sensor I used from my records and let you no, It's a simple wiring job once you are through the firewall, Regards Ivor Sent from my iPad On 26 May 2014, at 08:51, "Alan Carter" wrote: --> Hello Ivor. Looks like Lydd is going to become more active know Manston is closed. I would like to fit an indicator the same as you have done, sounds a good idea, is there something you can drill and attach to the filler cap. Can you give some info on this. Regards. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=423797#423797 Un/Subscription, http://www.matronics.com/Navigator?RotaxEngines-List Forums! Admin. Un/Subscription, http://www.matronics.com/Navigator?RotaxEngines-List Forums! Admin. ----- No virus found in this message. Checked by AVG - http://www.m &n - &nbs --> http://www.matronics.com/co================ = <http://www.matronics.com/contribution> <http://www.matronics.com/contribution> <http://www.matronics.com/contribution> <http://www.matronics.com/contribution> <http://www.matronics.com/contribution> href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www. matronics.com/Navigator?RotaxEngines-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jun 03, 2014
Your 912 was designed to run at least 30 min. without coolant. Coolant only cools the heads and not the rest of the engine like a car. You can help control temps after total coolant loss by flying at reduced throttle settings. If temps exceed the maximum on the heads the you should have the heads tested for hardness. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=424293#424293 ________________________________________________________________________________
Subject: Rotax 912 Mogas - ATSM ethanol question
Date: Jun 19, 2014
I run ethanol free mogas in my 912 (Diamond Katana) currently. I noticed in my AFM that Diamond allows fuel that meets the ATSM D4814 fuel standard as well as 100LL. I believe this standard allows up to 10% ethanol but the ATSM website charges $60 for the pdf file. Does anyone know if I am correct and that normal auto fuel pump gas is ATSM D4814 compliant. This would let me buy some of my fuel at my local gas station. Thanks for any help. -John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425157#425157 ________________________________________________________________________________
Date: Jun 20, 2014
Everything you might want to know about mogas can be found in this Chevron technical review ; http://www.chevronwithtechron.com/products/documents/69083_motorgas_tech_rev iew.pdf Your specific question is discussed on page 45 of that document. The answer to your question about "normal auto fuel" seems to be: maybe J Be sure to read the final paragraph on page 94, where Chevron tries to scare us into not using mogas in aircraft engines. Best regards, Rob Housman Irvine, California Europa XS Rotax 914 S/N A070 Airframe complete Avionics in progress -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of JohnE Sent: Thursday, June 19, 2014 9:55 PM Subject: RotaxEngines-List: Rotax 912 Mogas - ATSM ethanol question j_l_walsh(at)yahoo.com> I run ethanol free mogas in my 912 (Diamond Katana) currently. I noticed in my AFM that Diamond allows fuel that meets the ATSM D4814 fuel standard as well as 100LL. I believe this standard allows up to 10% ethanol but the ATSM website charges $60 for the pdf file. Does anyone know if I am correct and that normal auto fuel pump gas is ATSM D4814 compliant. This would let me buy some of my fuel at my local gas station. Thanks for any help. -John Read this topic online here: <http://forums.matronics.com/viewtopic.php?p=425157#425157> http://forums.matronics.com/viewtopic.php?p=425157#425157 http://www.matronics.com/Navigator?RotaxEngines-List http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Rotax 912 Mogas - ATSM ethanol question
Date: Jun 20, 2014
ASTM is okay with auto fuel. As an example many of the SLSA aircraft are ASTM compliant and allowed to use auto fuel. ASTM isn't the same nor have the teeth that the FAR's do. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425164#425164 ________________________________________________________________________________
Date: Jun 20, 2014
Thanks for the link, I'll read it in a bit. Diamond Aircraft changed the language in the AFM for my Katana regarding fuel specification. If the fuel meets ASTM D4814 it is allowable which is great because ethanol free gasoline is hard to find. I'm lucky that there are 2-3 airports within 50nm that sell it. I understand that Rotax allows up to 10% ethanol. -John rob(at)hyperion-ef.com wrote: > Everything you might want to know about mogas can be found in this Chevron technical review ; http://www.chevronwithtechron.com/products/documents/69083_motorgas_tech_review.pdf (http://www.chevronwithtechron.com/products/documents/69083_motorgas_tech_review.pdf) Your specific question is discussed on page 45 of that document. > > The answer to your question about normal auto fuel seems to be: maybe J > > Be sure to read the final paragraph on page 94, where Chevron tries to scare us into not using mogas in aircraft engines. > > > Best regards, > > Rob Housman > Irvine, California > Europa XS > Rotax 914 > S/N A070 > Airframe complete > Avionics in progress > > > > -- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425166#425166 ________________________________________________________________________________
Date: Jun 21, 2014
Something to investigate... In Canada, SHELL V-Power at every gas station is ethanol free. I have contacted SHELL a number of times over the years and every time have been assured that at every gas station the premium blend V-Power is guaranteed to be ethanol free. Not sure in other countries what SHELL offers. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425206#425206 ________________________________________________________________________________
Subject: air entering fuel system on suction side - or is my
Pierburg electrical pump broken?
Date: Jun 22, 2014
Hi Folks, Yesterday was supposed to be my final fuel flow test before taking to the air again. I have recently installed a fuel return line in my 912 system and also a fuel pressure gauge. The a/c is a Kitfox tri-gear, so high-wing with tanks in each wing and a header tank located behind the seats. The fuel flow test was performed on the ground with the aircraft in "take-off" attitude with tail on the ground (approx 17 degrees). Previous tests showed 100 l/hr (26 gal/hr) at the exit of the electrical fuel pump and before the mechanical pump. This time, to be more realistic, I measured the fuel flow after the mechanical fuel pump, at the entry of the 4-way junction that goes the carbs and to the fuel return line. In 18 minutes, the pump put out 18 litres, so 60 l/hr (16 gal/hr), which is still acceptable, though 40% lower than the first measurement. But then, something strange happened: the fuel flow went down dramatically, to approx. 20 l/hr (just over 5 gal/hr). I checked the gascolator and found it to be clean. A further investigation revealed that the fuel that was being pushed out contained some air bubbles, which to me means that air must be entering the fuel circuit on the suction side of the electrical pump. Or else the electrical fuel pump is somehow broken and is letting air in. A further data point is that if I hook up all the hoses and run the electrical fuel pump the fuel pressure gauge indicates lower than usual pressure (0.25 bar instead of 0.45 bar). So before I go and investigate the suction side of the fuel system I'd like to ask any experts out there: 1) Is it possible that I damaged the electrical fuel pump by letting it run continuously for 20 minutes? 2) Is anyone aware of such failure modes for the Pierburg electrical fuel pump? 3) How would you go about investigating the suction side of the fuel system? My idea was to disconnect the hose at the exit of the fuel pump and clamp it closed and then pressurize the circuit between the header tank and the exit of the electrical fuel pump with an airline and search for bubbles using soap water. Thanks in advance for any help... the weather is beautiful flying weather but I'm grounded until I can sort this out :(:(:( Sacha ________________________________________________________________________________
Date: Jun 22, 2014
From: william sullivan <williamtsullivan(at)att.net>
Subject: Re: air entering fuel system on suction side - or is
my Pierburg electrical pump broken? Sacha- I can think of a couple of things to check before blaming the pump. First, are the tanks vented? Are the vents functioning? Second, make sure that there isn't something blocking the fuel intake. I had this problem once on a new piece of equipment with a diesel engine. It would sit and run at full throttle for hours, but if it went down the street it would suck air, and shut the engine down. It drove us nuts for a while, until we pulled the fuel tank and found a 1" square piece of masking tape drifting around in the fuel. When it sloshed over to the sucker tube, it blocked it and shut down the engine. Air in the fuel always makes me think of that. We found it by pulling the plug at the bottom and trying to drain it. The fuel would stop running. Poke a wire in there, and it would run again. It was invisible when soaked with fuel. We had to pull the tank to get it out. The tape had been used to cover all openings when shipped from one factory to another, and a piece dropped in when the manufacturer pulled it off. Bill Sullivan -------------------------------------------- On Sun, 6/22/14, Sacha wrote: Subject: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? To: rotaxengines-list(at)matronics.com Date: Sunday, June 22, 2014, 3:56 AM --> RotaxEngines-List message posted by: "Sacha" Hi Folks, Yesterday was supposed to be my final fuel flow test before taking to the air again. I have recently installed a fuel return line in my 912 system and also a fuel pressure gauge. The a/c is a Kitfox tri-gear, so high-wing with tanks in each wing and a header tank located behind the seats.---- A further investigation revealed that the fuel that was being pushed out contained some air bubbles, which to me means that air must be entering the fuel circuit on the suction side of the electrical pump. RotaxEngines-List Email Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jun 22, 2014
Hi! Sacha, Have you checked the thimble filter in the Pierburg electrical pump? It needs a very sharp needle or pointed hooked instrument but only apply it to the plastic collar and be careful replacing it with a wooden very blunt pencil pushed home in to place very carefully, do not damage the gauze filter element because they will NOT supply a replacement .....it would need an entirely new pump. Regards Bob Harrison Europa G-PTAG c/w 914 Rotax and two electric fuel pumps. -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Sacha Sent: 22 June 2014 08:57 Subject: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? Hi Folks, Yesterday was supposed to be my final fuel flow test before taking to the air again. I have recently installed a fuel return line in my 912 system and also a fuel pressure gauge. The a/c is a Kitfox tri-gear, so high-wing with tanks in each wing and a header tank located behind the seats. The fuel flow test was performed on the ground with the aircraft in "take-off" attitude with tail on the ground (approx 17 degrees). Previous tests showed 100 l/hr (26 gal/hr) at the exit of the electrical fuel pump and before the mechanical pump. This time, to be more realistic, I measured the fuel flow after the mechanical fuel pump, at the entry of the 4-way junction that goes the carbs and to the fuel return line. In 18 minutes, the pump put out 18 litres, so 60 l/hr (16 gal/hr), which is still acceptable, though 40% lower than the first measurement. But then, something strange happened: the fuel flow went down dramatically, to approx. 20 l/hr (just over 5 gal/hr). I checked the gascolator and found it to be clean. A further investigation revealed that the fuel that was being pushed out contained some air bubbles, which to me means that air must be entering the fuel circuit on the suction side of the electrical pump. Or else the electrical fuel pump is somehow broken and is letting air in. A further data point is that if I hook up all the hoses and run the electrical fuel pump the fuel pressure gauge indicates lower than usual pressure (0.25 bar instead of 0.45 bar). So before I go and investigate the suction side of the fuel system I'd like to ask any experts out there: 1) Is it possible that I damaged the electrical fuel pump by letting it run continuously for 20 minutes? 2) Is anyone aware of such failure modes for the Pierburg electrical fuel pump? 3) How would you go about investigating the suction side of the fuel system? My idea was to disconnect the hose at the exit of the fuel pump and clamp it closed and then pressurize the circuit between the header tank and the exit of the electrical fuel pump with an airline and search for bubbles using soap water. Thanks in advance for any help... the weather is beautiful flying weather but I'm grounded until I can sort this out :(:(:( Sacha ________________________________________________________________________________
Date: Jun 23, 2014
Subject: Cylinder head coolant leak?
I'm working on a 912ULS from a windstorm-damaged plane that I'm pulling out to put in a homebuilt. The engine sat on the airplane for about a year after the airframe was totaled. All logs OK, looks very well cared for. But, #2 cylinder had about 1/4 cup of coolant in it. Good thing no one tried to start the engine, it was hydro locked by that. The spark plugs had some rust on the electrodes. I haven't pulled the head off yet but assume the valves will be in trouble too. The other cyls look OK. Is this a commonly seen problem? I have to guess there is some corrosion or a crack between the coolant passage and the valve. There's no coolant in the oil. Suggestions? David Josephson ________________________________________________________________________________
Date: Jun 23, 2014
> On Jun 22, 2014, at 14:26, william sullivan wrote: > > First, are the tanks vented? Are the vents functioning? Second, make sure that there isn't something blocking the fuel intake. Thanks Bill. I've been away from the hangar (and email) for a few days but I will check it this week. ________________________________________________________________________________
Date: Jun 23, 2014
Bob thank you. I will check it this week. Hopefully I don't need a new pump.... > On Jun 22, 2014, at 19:52, "Bob Harrison" wrote: > > Have you checked the thimble filter in the Pierburg electrical pump? ________________________________________________________________________________
Date: Jun 24, 2014
Hi Bill, I took the header tank off today, emptied and cleaned it. It had some silicon gasket material left over from when I installed the fuel level sender. Occasionally bits would float around and block the exit orifice and cause fuel flow to slow down substantially, exactly as you described. I expect things will go back to normal as soon as I re-mount the tank. Thanks again for the help! Regards, Sacha -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of william sullivan Sent: Sunday, 22 June, 2014 14:27 Subject: Re: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? --> Sacha- I can think of a couple of things to check before blaming the pump. First, are the tanks vented? Are the vents functioning? Second, make sure that there isn't something blocking the fuel intake. I had this problem once on a new piece of equipment with a diesel engine. It would sit and run at full throttle for hours, but if it went down the street it would suck air, and shut the engine down. It drove us nuts for a while, until we pulled the fuel tank and found a 1" square piece of masking tape drifting around in the fuel. When it sloshed over to the sucker tube, it blocked it and shut down the engine. Air in the fuel always makes me think of that. We found it by pulling the plug at the bottom and trying to drain it. The fuel would stop running. Poke a wire in there, and it would run again. It was invisible when soaked with fuel. We had to pull the tank to get it out. The tape had been used to cover all openings when shipped from one factory to another, and a piece dropped in when the manufacturer pulled it off. Bill Sullivan -------------------------------------------- On Sun, 6/22/14, Sacha wrote: Subject: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? To: rotaxengines-list(at)matronics.com Date: Sunday, June 22, 2014, 3:56 AM --> RotaxEngines-List message posted by: "Sacha" Hi Folks, Yesterday was supposed to be my final fuel flow test before taking to the air again. I have recently installed a fuel return line in my 912 system and also a fuel pressure gauge. The a/c is a Kitfox tri-gear, so high-wing with tanks in each wing and a header tank located behind the seats.---- A further investigation revealed that the fuel that was being pushed out contained some air bubbles, which to me means that air must be entering the fuel circuit on the suction side of the electrical pump. RotaxEngines-List Email Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jun 24, 2014
my Pierburg electrical pump broken? Sacha- nice find. I have also had trouble with Teflon tape. If you overlap the end of a fitting, it will tear off and clog a filter. Good luck. -------------------------------------------- On Tue, 6/24/14, Sacha wrote: Subject: RE: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? To: rotaxengines-list(at)matronics.com Date: Tuesday, June 24, 2014, 11:16 AM --> RotaxEngines-List message posted by: "Sacha" Hi Bill, I took the header tank off today, emptied and cleaned it. It had some silicon gasket material left over from when I installed the fuel level sender. Occasionally bits would float around and block the exit orifice and cause fuel flow to slow down substantially, exactly as you described. I expect things will go back to normal as soon as I re-mount the tank. Thanks again for the help! Regards, Sacha -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of william sullivan Sent: Sunday, 22 June, 2014 14:27 To: rotaxengines-list(at)matronics.com Subject: Re: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? --> Sacha- I can think of a couple of things to check before blaming the pump. First, are the tanks vented? Are the vents functioning? Second, make sure that there isn't something blocking the fuel intake. I had this problem once on a new piece of equipment with a diesel engine. It would sit and run at full throttle for hours, but if it went down the street it would suck air, and shut the engine down. It drove us nuts for a while, until we pulled the fuel tank and found a 1" square piece of masking tape drifting around in the fuel. When it sloshed over to the sucker tube, it blocked it and shut down the engine. Air in the fuel always makes me think of that. We found it by pulling the plug at the bottom and trying to drain it. The fuel would stop running. Poke a wire in there, and it would run again. It was invisible when soaked with fuel. We had to pull the tank to get it out. The tape had been used to cover all openings when shipped from one factory to another, and a piece dropped in when the manufacturer pulled it off. Bill Sullivan -------------------------------------------- On Sun, 6/22/14, Sacha wrote: Subject: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? To: rotaxengines-list(at)matronics.com Date: Sunday, June 22, 2014, 3:56 AM --> RotaxEngines-List message posted by: "Sacha" Hi Folks, Yesterday was supposed to be my final fuel flow test before taking to the air again. I have recently installed a fuel return line in my 912 system and also a fuel pressure gauge. The a/c is a Kitfox tri-gear, so high-wing with tanks in each wing and a header tank located behind the seats.---- A further investigation revealed that the fuel that was being pushed out contained some air bubbles, which to me means that air must be entering the fuel circuit on the suction side of the electrical pump. RotaxEngines-List Email Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. RotaxEngines-List Email Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jun 24, 2014
Silicone seal/products don't get along well with gasoline.
October 24, 2013 - June 24, 2014
RotaxEngines-Archive.digest.vol-bf
