RotaxEngines-Archive.digest.vol-bg
June 24, 2014 - December 07, 2014
      They are not fuel resistant and will cause many fuel related
      problems.
      Rock House, Oregon
      -----Original Message-----
From: owner-rotaxengines-list-server(at)matronics.com
[mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Sacha Sent: Tuesday, June 24, 2014 9:16 AM
Subject: air entering fuel system on
suction side - or is my Pierburg electrical pump broken? Hi Bill, I took the header tank off today, emptied and cleaned it. It had some silicon gasket material left over from when I installed the fuel level sender. Occasionally bits would float around and block the exit orifice and cause fuel flow to slow down substantially, exactly as you described. I expect things will go back to normal as soon as I re-mount the tank. Thanks again for the help! Regards, Sacha -----Original Message-----
[mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of william sullivan Sent: Sunday, 22 June, 2014 14:27 Subject: Re: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? --> Sacha- I can think of a couple of things to check before blaming the pump. First, are the tanks vented? Are the vents functioning? Second, make sure that there isn't something blocking the fuel intake. I had this problem once on a new piece of equipment with a diesel engine. It would sit and run at full throttle for hours, but if it went down the street it would suck air, and shut the engine down. It drove us nuts for a while, until we pulled the fuel tank and found a 1" square piece of masking tape drifting around in the fuel. When it sloshed over to the sucker tube, it blocked it and shut down the engine. Air in the fuel always makes me think of that. We found it by pulling the plug at the bottom and trying to drain it. The fuel would stop running. Poke a wire in there, and it would run again. It was invisible when soaked with fuel. We had to pull the tank to get it out. The tape had been used to cover all openings when shipped from one factory to another, and a piece dropped in when the manufacturer pulled it off. Bill Sullivan -------------------------------------------- On Sun, 6/22/14, Sacha wrote: Subject: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? To: rotaxengines-list(at)matronics.com Date: Sunday, June 22, 2014, 3:56 AM --> RotaxEngines-List message posted by: "Sacha" Hi Folks, Yesterday was supposed to be my final fuel flow test before taking to the air again. I have recently installed a fuel return line in my 912 system and also a fuel pressure gauge. The a/c is a Kitfox tri-gear, so high-wing with tanks in each wing and a header tank located behind the seats.---- A further investigation revealed that the fuel that was being pushed out contained some air bubbles, which to me means that air must be entering the fuel circuit on the suction side of the electrical pump. RotaxEngines-List Email Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. = Photoshare, and much much more: http://www.matronics.com/Navigator?RotaxEngines-List = = = ________________________________________________________________________________
Subject: Re: air entering fuel system on suction side - or is
Date: Jun 24, 2014
Yes indeed. I should have just mounted the sender with the cork gasket that came with it. > On Jun 24, 2014, at 19:02, "John Hauck" wrote: > > Silicone seal/products don't get along well with gasoline. > They are not fuel resistant and will cause many fuel related > problems. ________________________________________________________________________________
Subject: Magnetic plug torque
Date: Jun 24, 2014
Hello. I have a 14 year old 80 HP 912UL. I had the magnetic plug changed out a couple of years ago because it had been stripped. I have a question about the torque. I went to the Rotax class in Sebring over the winter and my notes say that the torque is 100 inch pounds, max of 140 in pounds. The maintenance manual that I have says 18.5 foot pounds, which is 222 inch pounds. Probably my notes are wrong, but I just want to be sure because 222 inch pounds sounds like a lot. Thanks. Regards, Damien N48TK Sent from my iPad ________________________________________________________________________________
Subject: Re: Magnetic plug torque
Date: Jun 24, 2014
OK, I just answered my own question. I checked the newest on-line maintenance manual and the torque for the magnetic plug is 18.5 foot pounds. I should have checked before bothering the Matronics list. Thanks. Regards, Damien N48TK Sent from my iPad > On Jun 24, 2014, at 6:33 PM, Damien Graham wrote: > > > Hello. I have a 14 year old 80 HP 912UL. I had the magnetic plug changed out a couple of years ago because it had been stripped. I have a question about the torque. I went to the Rotax class in Sebring over the winter and my notes say that the torque is 100 inch pounds, max of 140 in pounds. The maintenance manual that I have says 18.5 foot pounds, which is 222 inch pounds. > Probably my notes are wrong, but I just want to be sure because 222 inch pounds sounds like a lot. Thanks. > Regards, > Damien > N48TK > > Sent from my iPad > > > > ________________________________________________________________________________
Date: Jun 24, 2014
Hi Damien, You are correct. That said I find 18.5 ft/lbs a little too much and makes removal a little too hard. That is one reason why the old style with the #40 Torx head stripped out, not ot mention some didn't seat the driver all the way to the bottom of the plug before they applied pressure to unscrew it. The whole idea is to tighten the plug so it won't leak or back out. I usually use less torque and it is secured on top of the torque with safety wire. I have never had one loosen in all my years. Try a little less torque it will work just fine. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425413#425413 ________________________________________________________________________________
Date: Jun 25, 2014
From: william sullivan <williamtsullivan(at)att.net>
my Pierburg electrical pump broken? Sacha- Never use any of the RTV sealants with a cork/rubber gasket. The RTV will cause the gasket to crumble later on. I think the solvent in the RTV dissolves the latex. Bill Sullivan -------------------------------------------- On Tue, 6/24/14, Sacha wrote: Subject: Re: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? To: "rotaxengines-list(at)matronics.com" Date: Tuesday, June 24, 2014, 3:17 PM --> RotaxEngines-List message posted by: Sacha Yes indeed. I should have just mounted the sender with the cork gasket that came with it. > On Jun 24, 2014, at 19:02, "John Hauck" wrote: > > Silicone seal/products don't get along well with gasoline. > They are not fuel resistant and will cause many fuel related > problems. RotaxEngines-List Email Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jun 25, 2014
Bill Thank you. I'm not sure what RTV is. I used some red stuff which I thought was for engine gaskets. I think Motorsil was the brand. Anyway just to be sure I'll remove it as it serves no useful purpose. Sacha > On Jun 25, 2014, at 15:26, william sullivan wrote: > > > Sacha- Never use any of the RTV sealants with a cork/rubber gasket. The RTV will cause the gasket to crumble later on. I think the solvent in the RTV dissolves the latex. > > Bill Sullivan > -------------------------------------------- > On Tue, 6/24/14, Sacha wrote: > > Subject: Re: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? > To: "rotaxengines-list(at)matronics.com" > Date: Tuesday, June 24, 2014, 3:17 PM > > --> RotaxEngines-List message > posted by: Sacha > > Yes indeed. I should have just mounted the sender with the > cork gasket that came with it. > >>> On Jun 24, 2014, at 19:02, "John Hauck" >> wrote: >> >> Silicone seal/products don't get along well with > gasoline. >> They are not fuel resistant and will cause many fuel > related >> problems. > > > RotaxEngines-List Email Forum - > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > > > > > > ________________________________________________________________________________
Date: Jun 25, 2014
Roger: Thanks very much for the reply. Have you ever thought about opening a subsidiary in the NorthEast ??? Regards, Damien Sent from my iPad > On Jun 24, 2014, at 9:39 PM, "Roger Lee" wrote: > > > Hi Damien, > > You are correct. That said I find 18.5 ft/lbs a little too much and makes removal a little too hard. That is one reason why the old style with the #40 Torx head stripped out, not ot mention some didn't seat the driver all the way to the bottom of the plug before they applied pressure to unscrew it. The whole idea is to tighten the plug so it won't leak or back out. I usually use less torque and it is secured on top of the torque with safety wire. I have never had one loosen in all my years. Try a little less torque it will work just fine. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425413#425413 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 26, 2014
my Pierburg electrical pump broken? RTV stands for "Room Temperature Vulcanizing". Comes in a tube, and has at least 3 colors- blue, red, and black, indicating useful temperature, and whether or not it cures in the presence of air, or the absence of it. It is designed to take the place of gaskets, or to skim coat paper ones. Works great, except on the cork gaskets. You can find it at an auto parts store. -------------------------------------------- On Wed, 6/25/14, Sacha wrote: Subject: Re: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? To: "rotaxengines-list(at)matronics.com" Date: Wednesday, June 25, 2014, 12:40 PM --> RotaxEngines-List message posted by: Sacha Bill Thank you. I'm not sure what RTV is. I used some red stuff which I thought was for engine gaskets. I think Motorsil was the brand. Anyway just to be sure I'll remove it as it serves no useful purpose. Sacha > On Jun 25, 2014, at 15:26, william sullivan wrote: > sullivan > > Sacha- Never use any of the RTV sealants with a cork/rubber gasket. The RTV will cause the gasket to crumble later on. I think the solvent in the RTV dissolves the latex. > > Bill Sullivan > -------------------------------------------- > On Tue, 6/24/14, Sacha wrote: > > Subject: Re: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? > To: "rotaxengines-list(at)matronics.com" > Date: Tuesday, June 24, 2014, 3:17 PM > > --> RotaxEngines-List message > posted by: Sacha > > Yes indeed. I should have just mounted the sender with the > cork gasket that came with it. > >>> On Jun 24, 2014, at 19:02, "John Hauck" >> wrote: >> >> Silicone seal/products don't get along well with > gasoline. >> They are not fuel resistant and will cause many fuel > related >> problems. > > > RotaxEngines-List Email Forum - > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > > > > > > RotaxEngines-List Email Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: air entering fuel system on suction side - or is
Date: Jun 26, 2014
RTV stands for "Room Temperature Vulcanizing". Comes in a tube, and has at least 3 colors- blue, red, and black, indicating useful temperature, and whether or not it cures in the presence of air, or the absence of it. It is designed to take the place of gaskets, or to skim coat paper ones. Works great, except on the cork gaskets. You can find it at an auto parts store. -------------------------------------------- Bill S: Are all RTV sealants fuel safe? Are they to be confused with silicone seal? john h Rock House, Oregon ________________________________________________________________________________
Date: Jun 26, 2014
my Pierburg electrical pump broken? John- I know that one is fuel resistant- red, I think. Pretty sure it's silicone seal. My experience is very limited, so I only remember some of the cautions with the stuff. I had a friend who bought a used Cadillac with a freshly rebuilt motor. The cork oil pan gasket dissolved, and cost him an engine rebuild. -------------------------------------------- On Thu, 6/26/14, John Hauck wrote: Subject: RE: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? To: rotaxengines-list(at)matronics.com Date: Thursday, June 26, 2014, 10:10 AM --> RotaxEngines-List message posted by: "John Hauck" RTV stands for "Room Temperature Vulcanizing". Comes in a tube, and has at least 3 colors- blue, red, and black, indicating useful temperature, and whether or not it cures in the presence of air, or the absence of it. It is designed to take the place of gaskets, or to skim coat paper ones. Works great, except on the cork gaskets. You can find it at an auto parts store. -------------------------------------------- Bill S: Are all RTV sealants fuel safe? Are they to be confused with silicone seal? john h Rock House, Oregon RotaxEngines-List Email Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jun 26, 2014
John- I know that one is fuel resistant- red, I think. Pretty sure it's silicone seal. My experience is very limited, so I only remember some of the cautions with the stuff. I had a friend who bought a used Cadillac with a freshly rebuilt motor. The cork oil pan gasket dissolved, and cost him an engine rebuild. -------------------------------------------- Bill S: Back in 1987, silicone seal caused a low power situation that put me into the Sebring High School football field. Had used silicone seal to seal the vent hole in the Ken Brock seat tank filler cap so I could convert to a vent that exited the bottom of the aircraft and prevent fuel from dumping inboard should I go upside down on the ground again. Tiny balls of silicone seal effectively blocked the valves in the squeeze bulbs we used to use back then. john h mkIII Rock House, OR ________________________________________________________________________________
Date: Jun 26, 2014
my Pierburg electrical pump broken? I seem to remember that silicone seal (RTV) was being used at automotive factories to replace a lot of gaskets, some time in the 1980's. Worked great for differential covers, etc. The biggest problem I ran into was that we weren't sure where, or what type, to use. Best bet is to bring your glasses to the auto parts store and read all that very tiny print on the packages. Where I worked, the most common type was blue- we called it "Blue Goo". Stunk like hell, and hardened in the tube if it sat around for a while. Maybe Roger or somebody with a lot more practical knowledge can chime in on this. I was in truck equipment, not automotive. -------------------------------------------- On Thu, 6/26/14, John Hauck wrote: Subject: RE: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? To: rotaxengines-list(at)matronics.com Date: Thursday, June 26, 2014, 11:28 AM --> RotaxEngines-List message posted by: "John Hauck" John- I know that one is fuel resistant- red, I think. Pretty sure it's silicone seal. My experience is very limited, so I only remember some of the cautions with the stuff. I had a friend who bought a used Cadillac with a freshly rebuilt motor. The cork oil pan gasket dissolved, and cost him an engine rebuild. -------------------------------------------- Bill S: Back in 1987, silicone seal caused a low power situation that put me into the Sebring High School football field. Had used silicone seal to seal the vent hole in the Ken Brock seat tank filler cap so I could convert to a vent that exited the bottom of the aircraft and prevent fuel from dumping inboard should I go upside down on the ground again. Tiny balls of silicone seal effectively blocked the valves in the squeeze bulbs we used to use back then. john h mkIII Rock House, OR RotaxEngines-List Email Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: in-line fuel filters - can you recommend any?
Date: Jun 27, 2014
After my issues with my feeder tank becoming blocked with silicone gasket material, I have cleaned the tanks and header tank. Now I'd like to install an in-line filter between each wing-tank and the header tank. (I already have a gascolator between the header tank and the fuel pump, so the purpose of the in-line filters is really just to stop any goo getting to the header tank and blocking the fuel supply line to the engine). Are there any in-line filters that are NOT recommended? I've heard that plastic in-line filters are not advisable. Metal sounds safe, but is not easily inspectable. Glass doesn't sound so safe. What are folks using? ACS has a couple of different options but none (except the most expensive one "Micron 10") come with fuel flow and pressure drop specs. ________________________________________________________________________________
Date: Jun 27, 2014
Subject: Re: in-line fuel filters - can you recommend any?
This <http://www.summitracing.com/parts/sum-230102/overview/>is similar to what I use, except it's between the header and engine. It's huge and I don't think it could ever reasonably clog. I don't filter into the header tank if you except the finger filters <http://www.aircraftspruce.com/catalog/appages/fingstrainers.php?clickkey=18612> in the tank outlets to keep out the big chunks. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. On 6/27/2014 6:14 AM, Sacha wrote: > > After my issues with my feeder tank becoming blocked with silicone gasket > material, I have cleaned the tanks and header tank. > > Now I'd like to install an in-line filter between each wing-tank and the > header tank. (I already have a gascolator between the header tank and the > fuel pump, so the purpose of the in-line filters is really just to stop any > goo getting to the header tank and blocking the fuel supply line to the > engine). > ________________________________________________________________________________
Date: Jun 27, 2014
Purolator Proline glass filter with plastic screen filter. You can get them at most any auto store. I install them in line and once screwed together I safety wire across it to keep from spinning apart. I never used any filter with a paper type filter or ones I cant see through to inspect. Here is a picture of the filter. http://www.google.com/imgres?imgurl=http%3A%2F%2Fwww.dellortoshop.com%2Fc ontents%2Fmedia%2Fpro896_sytec_in_line_fuel_filter_element_replacement_ds.j pg&imgrefurl=http%3A%2F%2Fwww.dellortoshop.com%2Fcontents%2Fen-us%2Fd31_D ellorto_SH1_and_SH2_Parts_Shop.html&h=300&w=249&tbnid=CKnixi_WQ9eHbM% 3A&zoom=1&q=pro-line%20fuel%20filters&docid=lT0-I-ZbpjTqcM&ei=D8KtU 9b7HomhyASenoDgAw&tbm=isch&ved=0CCYQMygJMAk&iact=rc&uact=3&page=2 &start=6&ndsp=6 Vance After my issues with my feeder tank becoming blocked with silicone gasket material, I have cleaned the tanks and header tank. Now I'd like to install an in-line filter between each wing-tank and the header tank. (I already have a gascolator between the header tank and the fuel pump, so the purpose of the in-line filters is really just to stop any goo getting to the header tank and blocking the fuel supply line to the engine). Are there any in-line filters that are NOT recommended? I've heard that plastic in-line filters are not advisable. Metal sounds safe, but is not easily inspectable. Glass doesn't sound so safe. What are folks using? ACS has a couple of different options but none (except the most expensive one "Micron 10") come with fuel flow and pressure drop specs. ________________________________________________________________________________
Date: Jun 27, 2014
I have used these on three differ airplanes and never had a problem with them. Easy to inspect and easy to change filters in. Vance On Jun 27, 2014 6:19 AM, "Sacha" wrote: > > After my issues with my feeder tank becoming blocked with silicone gasket > material, I have cleaned the tanks and header tank. > > Now I'd like to install an in-line filter between each wing-tank and the > header tank. (I already have a gascolator between the header tank and the > fuel pump, so the purpose of the in-line filters is really just to stop any > goo getting to the header tank and blocking the fuel supply line to the > engine). > > Are there any in-line filters that are NOT recommended? I've heard that > plastic in-line filters are not advisable. Metal sounds safe, but is not > easily inspectable. Glass doesn't sound so safe. What are folks using? > ACS has a couple of different options but none (except the most expensive > one "Micron 10") come with fuel flow and pressure drop specs. > > ________________________________________________________________________________
Date: Jun 28, 2014
The glass tube can be replaced with a 7/8" OD .058" 6061 tube of the same length. I have been using that set up since the first one I bought developed a crack in the glass the first night I had it installed. Never had a problem with aluminum. Easy to inspect by simply disassembling. john h Kolb MKIII - 3,280.0 hours Titus, Alabama I have used these on three differ airplanes and never had a problem with them. Easy to inspect and easy to change filters in. ________________________________________________________________________________
Date: Jun 28, 2014
Ok so I got rid of all the silicone sealant and cleaned the cork gasket which seals the VDO sender (it's quite a big gasket with a 40mm diameter hole in the centre and five 5mm holes for the screws around the perimeter). Well guess what? The cork seal leaks badly. So I'm back to square one, I need to find a way to seal the VDO sender on the top of my header tank. I have some silicone rubber which I thought of cutting to size and using. What do folks think? Another solution would be to use the same red silicone sealant as I used before but only to apply it on the exterior of the tank. I'm concerned it might eat into the cork though as someone (John?) mentioned. ________________________________________________________________________________
Date: Jun 29, 2014
Folks, Thanks a lot for all the suggestions regarding filters. Guy, regarding the finger filters, do you happen have a picture of how they are installed? My wing tanks have no strainers to remove water in the fuel but it's something I've been wanting to install. Sacha ________________________________________________________________________________
Date: Jun 28, 2014
I would definitely keep silicon sealant away from any fuel system. Your silicone coated cork gasket is trash. Silicone seal causes the gasket to squeeze out and leak. You can get several fuel tank sealant cartridges from Aircraft Spruce that work well. Also cut your own gasket. john h Kolb MKIII Boise, Idaho -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Sacha Sent: Saturday, June 28, 2014 3:38 PM Subject: Re: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? Ok so I got rid of all the silicone sealant and cleaned the cork gasket which seals the VDO sender (it's quite a big gasket with a 40mm diameter hole in the centre and five 5mm holes for the screws around the perimeter). Well guess what? The cork seal leaks badly. So I'm back to square one, I need to find a way to seal the VDO sender on the top of my header tank. I have some silicone rubber which I thought of cutting to size and using. What do folks think? Another solution would be to use the same red silicone sealant as I used before but only to apply it on the exterior of the tank. I'm concerned it might eat into the cork though as someone (John?) mentioned. = Photoshare, and much much more: http://www.matronics.com/Navigator?RotaxEngines-List = = = ________________________________________________________________________________
my Pierburg
Date: Jun 28, 2014
Get a new gasket. The buy some Hylomar. This is meant to be used around fuel and will not leak. Do not over use it. I little thin film on each surface will seal just fine. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425695#425695 ________________________________________________________________________________
Date: Jun 28, 2014
Vance, As far as I can tell from their website, Purolator no longer makes the Proline filter or the Clearview filter that preceded it. You can find a version of the filter at auto parts stores under the Mr. Gasket brand. You have to be really careful as they market two kinds and the quality difference between them is dramatic. You can tell them apart by the center section that threads into the ends. The cheapos, that I wouldn't put on ANYTHING, much less an aircraft, has a flat molded piece about 1/8" thick in the center. It has no way to seal the filter element and on some the threads are so poorly molded that the ends are not held parallel so the seals are very unevenly compressed against the glass body of the filter. This model usually comes with plastic barbed fittings to accommodate three sizes of fuel line. The chrome plating on the ends usually has so much build up on the thread that you cannot substitute aluminum or brass barbed fittings for the plastic. The better quality version has a round center section and a jam nut to seal the filter. They also have one piece ends that have the barbed fitting as a unit. Unfortunately they are only available in 5/16" and 3/8" sizes. Bottom line, any Clearview style filter from the auto parts stores has to be carefully inspected to make sure it is robust enough to be put on an aircraft. If you cannot tell while it's in the package, ask the counter person to take it out of the package for you. If they won't do it, go to another store. Inspecting the filter before buying will save you the hassle of having to take it back later. Rick Girard On Sat, Jun 28, 2014 at 5:07 PM, Sacha wrote: > > Folks, > Thanks a lot for all the suggestions regarding filters. > Guy, regarding the finger filters, do you happen have a picture of how > they are installed? My wing tanks have no strainers to remove water in the > fuel but it's something I've been wanting to install. > Sacha > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jun 28, 2014
No picture. The finger strainers are pipe thread reducers attached to course mesh finger size screens. The male is threaded into the Kitfox's fiberglass tank, bedded with 2-part polysulfide sealant. (Yes, the expensive stuff. As an aside for all you other guys debating RTV. I tried everything in the auto and plumbing store trying to seal 100LL fittings. The only thing that worked absolutely reliably was the ACS 2-part polysulfide.) I then have a male pipe to barb adapter threaded into the finger female. Hose attaches to the barb. Very straight-forward if you can use pipe threads in your tank. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. On 6/28/2014 3:07 PM, Sacha wrote: > > Folks, > Thanks a lot for all the suggestions regarding filters. > Guy, regarding the finger filters, do you happen have a picture of how they are installed? My wing tanks have no strainers to remove water in the fuel but it's something I've been wanting to install. > Sacha > > ________________________________________________________________________________
Date: Jun 29, 2014
Subject: New to Carb Synch in 912. Should Carbs behave the same
at all rpms?
Hi, After attending a couple of seminars and watching the videos, I felt I could run my firts Carb Synch... I followed the manual and run first the mechanical adjustment followed by the pneumatic ones at 3000 rpm. All good here. Issue came when, out of curiosity, I wanted to check if carbs would be balanced also at the high rpms when I would be flying, so I started adjusting, not for 3000 as per the manual, but playing up and down. The thing is that, no matter which rpm I would synchronise for, the results would not be the same all way in the rest of the rpm, so I started to believe that I had a different behaviour in the carbs. I asked the shop that does usually my maintenance and both carbs were cleaned and needles changed 10 h ago. So here I am, doubting if my readings are wrong, If I need to check again carbs or if I'm only good to build airframes, but unable to tune engines... For those of you with more experience, any suggestion/comments pls Thanks in advance Godo RV12 in Barcelona, Spain Last data: Rigth vs Left Carb mmH reading 4500 rpm +0.5 mm 4000 rpm +0.0 mm 3500 rpm -1.5 mm 3000 rpm -2.5 mm 2500 rpm -2.5 mm ________________________________________________________________________________
Date: Jun 29, 2014
I was figuratively biting my tongue, hoping this topic would go away withou t killing anyone but seeing so many responses in the Daily Digest I decided to add my two cents.- Forgive me if I come across as a bit pushy on this topic as fuel filters and aircraft fuel system design are a bit of a pet p eeve of mine.=0A=0ABased on standard aircraft design, there should be a coa rse finger screen on the outlet of each tank, this is filter number one whi ch keeps large chunks of debris from entering the fuel delivery system.- Each tank should have a sediment drain to check for and eliminate debris an d water which can accumulate in the tank.- At the lowest point in the fue l system there needs to be another sediment drain as this is also where wat er can accumulate.- A properly designed gascolator should be installed in the system, often at the lowest point in lieu of a low point drain.- The gascolator should be the type which has a sediment bowl with drain and a f airly fine mesh screen in the top which acts as filter number two.- Final ly, the fuel pumps used on Rotax engines have a fine mesh screen in them (a ccording to Phil Lockwood) which acts as a final filter before the fuel ent ers the carburetors.- If particulate can get through these three filters, then it will go through the engine without hurting anything.=0A=0A=0ASo essentially, a pro perly designed fuel system has three stages of filtration.- Why would you want to add another level of filtration to your fuel system?- =0A=0A=0AI n his talk on 912 maintenance, Phil Lockwood tells an entertaining story ab out getting a bad batch of fuel in his older carburated car.- The fuel ha d some kind of very fine particulate suspended in it which plugged his fuel filter and made for very poor performance, eventually killing the engine. - Phil replaced the fuel filter and the new one plugged again within a fe w minutes as he still had the bad fuel in his fuel tank.- Since he was in the middle of nowhere and did not have another fuel filter, Phil removed t he fuel filter all together until he reached his destination and the car ra n fine for the remainder of the trip.- As long as the particulate is smal l enough to not plug the carburetor jets, it is not going to hurt anything in the engine.- However, if a fine particulate accumulates on a too fine of filtration media, the particulate could interrupt fuel flow to the engin e.=0A=0AFuel systems in homebuilts/ultralights/LSAs are one place where we need to pay close attention to what has been done in the certified world. - Adding components into the fuel system where they should not be can be dangerous and should be done only with extreme caution. If your aircraft fu el system is not set up according to standard design, that should be your g oal, not adding fuel filters for the sake of =0Aadding fuel filters.- Of course, fuel injection systems like that on the 912iS is another issue but I am not experienced with the iS installation so cannot comment on its filt ration requirements.=0A=0A=0AThere, I will get down off my soapbox.- I ho pe I have given you guys something to think about without coming across as too preachy.=0A=0ADoug M=0ACH-701, Rotax 912UL- =0A ________________________________________________________________________________
Date: Jun 29, 2014
................and don't forget the thimble filter in the electric Pierburg fuel pumps x 2 on the 914 engine. Regards Bob Harrison Europa /Rotax 914 From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of MacDonald Doug Sent: 29 June 2014 14:08 Subject: RotaxEngines-List: in-line fuel filters - can you recommend any? I was figuratively biting my tongue, hoping this topic would go away without killing anyone but seeing so many responses in the Daily Digest I decided to add my two cents. Forgive me if I come across as a bit pushy on this topic as fuel filters and aircraft fuel system design are a bit of a pet peeve of mine. Based on standard aircraft design, there should be a coarse finger screen on the outlet of each tank, this is filter number one which keeps large chunks of debris from entering the fuel delivery system. Each tank should have a sediment drain to check for and eliminate debris and water which can accumulate in the tank. At the lowest point in the fuel system there needs to be another sediment drain as this is also where water can accumulate. A properly designed gascolator should be installed in the system, often at the lowest point in lieu of a low point drain. The gascolator should be the type which has a sediment bowl with drain and a fairly fine mesh screen in the top which acts as filter number two. Finally, the fuel pumps used on Rotax engines have a fine mesh screen in them (according to Phil Lockwood) which acts as a final filter before the fuel enters the carburetors. If particulate can get through these three filters, then it will go through the engine without hurting anything. So essentially, a properly designed fuel system has three stages of filtration. Why would you want to add another level of filtration to your fuel system? In his talk on 912 maintenance, Phil Lockwood tells an entertaining story about getting a bad batch of fuel in his older carburated car. The fuel had some kind of very fine particulate suspended in it which plugged his fuel filter and made for very poor performance, eventually killing the engine. Phil replaced the fuel filter and the new one plugged again within a few minutes as he still had the bad fuel in his fuel tank. Since he was in the middle of nowhere and did not have another fuel filter, Phil removed the fuel filter all together until he reached his destination and the car ran fine for the remainder of the trip. As long as the particulate is small enough to not plug the carburetor jets, it is not going to hurt anything in the engine. However, if a fine particulate accumulates on a too fine of filtration media, the particulate could interrupt fuel flow to the engine. Fuel systems in homebuilts/ultralights/LSAs are one place where we need to pay close attention to what has been done in the certified world. Adding components into the fuel system where they should not be can be dangerous and should be done only with extreme caution. If your aircraft fuel system is not set up according to standard design, that should be your goal, not adding fuel filters for the sake of adding fuel filters. Of course, fuel injection systems like that on the 912iS is another issue but I am not experienced with the iS installation so cannot comment on its filtration requirements. There, I will get down off my soapbox. I hope I have given you guys something to think about without coming across as too preachy. Doug M CH-701, Rotax 912UL ________________________________________________________________________________
Date: Jun 29, 2014
I recommend you use HYLOMAR sealant made in the USA under licence and developed by Rolls Royce Aero Engines for all fuel and oil related joints. But use it very sparingly and especially as mentioned on the instructions. I would never make any oil or fuel related joint without it. Regards Bob Harrison Rolls Royce Aero Engine trained .Europa G-PTAG Rotax 914 -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of John Hauck Sent: 28 June 2014 23:11 Subject: RE: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? --> I would definitely keep silicon sealant away from any fuel system. Your silicone coated cork gasket is trash. Silicone seal causes the gasket to squeeze out and leak. You can get several fuel tank sealant cartridges from Aircraft Spruce that work well. Also cut your own gasket. john h Kolb MKIII Boise, Idaho -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Sacha Sent: Saturday, June 28, 2014 3:38 PM Subject: Re: RotaxEngines-List: air entering fuel system on suction side - or is my Pierburg electrical pump broken? Ok so I got rid of all the silicone sealant and cleaned the cork gasket which seals the VDO sender (it's quite a big gasket with a 40mm diameter hole in the centre and five 5mm holes for the screws around the perimeter). Well guess what? The cork seal leaks badly. So I'm back to square one, I need to find a way to seal the VDO sender on the top of my header tank. I have some silicone rubber which I thought of cutting to size and using. What do folks think? Another solution would be to use the same red silicone sealant as I used before but only to apply it on the exterior of the tank. I'm concerned it might eat into the cork though as someone (John?) mentioned. = Photoshare, and much much more: http://www.matronics.com/Navigator?RotaxEngines-List = = = ________________________________________________________________________________
Date: Jun 29, 2014
I fly a kitfox 912 ul and have the exact fuel system you describe. in 400 hours never had a problem. take care Don On Jun 29, 2014 6:14 AM, "MacDonald Doug" wrote: > I was figuratively biting my tongue, hoping this topic would go away > without killing anyone but seeing so many responses in the Daily Digest I > decided to add my two cents. Forgive me if I come across as a bit pushy on > this topic as fuel filters and aircraft fuel system design are a bit of a > pet peeve of mine. > > Based on standard aircraft design, there should be a coarse finger screen > on the outlet of each tank, this is filter number one which keeps large > chunks of debris from entering the fuel delivery system. Each tank should > have a sediment drain to check for and eliminate debris and water which can > accumulate in the tank. At the lowest point in the fuel system there needs > to be another sediment drain as this is also where water can accumulate. A > properly designed gascolator should be installed in the system, often at > the lowest point in lieu of a low point drain. The gascolator should be > the type which has a sediment bowl with drain and a fairly fine mesh screen > in the top which acts as filter number two. Finally, the fuel pumps used > on Rotax engines have a fine mesh screen in them (according to Phil > Lockwood) which acts as a final filter before the fuel enters the > carburetors. If particulate can get through these three filters, then it > will go through the engine without hurting anything. > > So essentially, a properly designed fuel system has three stages of > filtration. Why would you want to add another level of filtration to your > fuel system? > > In his talk on 912 maintenance, Phil Lockwood tells an entertaining story > about getting a bad batch of fuel in his older carburated car. The fuel > had some kind of very fine particulate suspended in it which plugged his > fuel filter and made for very poor performance, eventually killing the > engine. Phil replaced the fuel filter and the new one plugged again within > a few minutes as he still had the bad fuel in his fuel tank. Since he was > in the middle of nowhere and did not have another fuel filter, Phil removed > the fuel filter all together until he reached his destination and the car > ran fine for the remainder of the trip. As long as the particulate is > small enough to not plug the carburetor jets, it is not going to hurt > anything in the engine. However, if a fine particulate accumulates on a > too fine of filtration media, the particulate could interrupt fuel flow to > the engine. > > Fuel systems in homebuilts/ultralights/LSAs are one place where we need to > pay close attention to what has been done in the certified world. Adding > components into the fuel system where they should not be can be dangerous > and should be done only with extreme caution. If your aircraft fuel system > is not set up according to standard design, that should be your goal, not > adding fuel filters for the sake of adding fuel filters. Of course, fuel > injection systems like that on the 912iS is another issue but I am not > experienced with the iS installation so cannot comment on its filtration > requirements. > > There, I will get down off my soapbox. I hope I have given you guys > something to think about without coming across as too preachy. > > Doug M > CH-701, Rotax 912UL > > * > > > * > > ________________________________________________________________________________
Subject: What is this cheesy material in my oil cooler?
From: "CharlieTango" <ed.cesnalis(at)mammothlakesinsulation.com>
Date: Jul 01, 2014
This CTSW has had high oil temps for the last 6 years. I sent the oil cooler to Hot Flush and after a bunch of metal this cheesy material started coming loose. What is it? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425840#425840 Attachments: http://forums.matronics.com//files/cheesy_material_from_oil_cooler_848.jpg ________________________________________________________________________________
Date: Jul 01, 2014
Sacha, Take a fresh cork gasket and copy it to sheet stock that is impervious to gas. McMaster Carr has a chart of materials and uses so you can find what you need. >From the directions for use on the red RTV (in black bold letters): "Not recommended for use on head gaskets or parts in contact with gasoline." Rick Girard On Sun, Jun 29, 2014 at 9:04 AM, Bob Harrison wrote: > ptag.dev(at)tiscali.co.uk> > > I recommend you use HYLOMAR sealant made in the USA under licence and > developed by Rolls Royce Aero Engines for all fuel and oil related joints. > But use it very sparingly and especially as mentioned on the instructions. > I would never make any oil or fuel related joint without it. > Regards > Bob Harrison Rolls Royce Aero Engine trained .Europa G-PTAG Rotax 914 > > > -----Original Message----- > From: owner-rotaxengines-list-server(at)matronics.com > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of John > Hauck > Sent: 28 June 2014 23:11 > To: rotaxengines-list(at)matronics.com > Subject: RE: RotaxEngines-List: air entering fuel system on suction side - > or is my Pierburg electrical pump broken? > > --> > > I would definitely keep silicon sealant away from any fuel system. > > Your silicone coated cork gasket is trash. Silicone seal causes the gasket > to squeeze out and leak. > > You can get several fuel tank sealant cartridges from Aircraft Spruce that > work well. Also cut your own gasket. > > john h > Kolb MKIII > Boise, Idaho > > -----Original Message----- > From: owner-rotaxengines-list-server(at)matronics.com > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Sacha > Sent: Saturday, June 28, 2014 3:38 PM > To: rotaxengines-list(at)matronics.com > Subject: Re: RotaxEngines-List: air entering fuel system on suction side - > or is my Pierburg electrical pump broken? > > > > Ok so I got rid of all the silicone sealant and cleaned the cork gasket > which seals the VDO sender (it's quite a big gasket with a 40mm diameter > hole in the centre and five 5mm holes for the screws around the perimeter). > > Well guess what? The cork seal leaks badly. So I'm back to square one, I > need to find a way to seal the VDO sender on the top of my header tank. I > have some silicone rubber which I thought of cutting to size and using. > What > do folks think? > > Another solution would be to use the same red silicone sealant as I used > before but only to apply it on the exterior of the tank. I'm concerned it > might eat into the cork though as someone (John?) mentioned. > > = > Photoshare, and much much more: > http://www.matronics.com/Navigator?RotaxEngines-List > = > = > = > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jul 01, 2014
Subject: Re: What is this cheesy material in my oil cooler?
I have no idea what it is, but save it and weigh it on a fine scale- like a reloading scale. Then when you find out what it is, you can weigh the new part and find out how much might still be in there. I once had some red plastic like that clog up a hydraulic system. It turned out to be part of a sight indicator on the oil filter. It had cracked, and somebody pushed the red indicator back into the hole, and screwed a plug in on top of it. The pump chewed it up, and it jammed the hydraulic system valves. We kept cleaning the system, saving parts and weighing them, and comparing against a new part. Bill Sullivan -------------------------------------------- On Tue, 7/1/14, CharlieTango wrote: Subject: RotaxEngines-List: What is this cheesy material in my oil cooler? To: rotaxengines-list(at)matronics.com Date: Tuesday, July 1, 2014, 11:12 AM --> RotaxEngines-List message posted by: "CharlieTango" This CTSW has had high oil temps for the last 6 years. I sent the oil cooler to Hot Flush and after a bunch of metal this cheesy material started coming loose. What is it? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425840#425840 Attachments: http://forums.matronics.com//files/cheesy_material_from_oil_cooler_848.jpg RotaxEngines-List Email Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jul 01, 2014
Rick, Bob and John, Thanks for the tips I got it, silicone and gasoline don=99t mix! McMaster Carr what a great website, wish we had such a thing in Europe! Turns out I=99m heading to the US tomorrow so I might stock up on a few things. Sacha ________________________________________________________________________________
Date: Jul 01, 2014
Subject: Re: New to Carb Synch in 912. Should Carbs behave
the same at all rpms?
Gordo, You will see some variation at different RPM's than what you used to set the two carbs due to things like airflow differences between the two carbs, manifolds, heads, valve flows, even the amount of oil on the air filters. You can drive yourself crazy trying to chase it down (been there, done that. I once swapped air cleaners after I had balanced the carbs as close as my nice liquid filled gauges would allow, and the carbs were out of balance by over 1" of vacuum. It's a wonder I have any hair left. :-} I did briefly think about making a dedicated flow bench for testing air cleaners after they had been cleaned and re-oiled. Thank goodness the urge passed). Fortunately Rotax put a balance tube the two manifolds. That damps out the small differences once everything is set. If you were to connect to the carb vacuum ports after the balance tube is reconnected you would not be able to find those minor differences. Rick Girard On Sun, Jun 29, 2014 at 6:49 AM, Godo Barrenechea wrote: > Hi, > > After attending a couple of seminars and watching the videos, I felt I > could run my firts Carb Synch... > > I followed the manual and run first the mechanical adjustment followed by > the pneumatic ones at 3000 rpm. All good here. > > Issue came when, out of curiosity, I wanted to check if carbs would be > balanced also at the high rpms when I would be flying, so I started > adjusting, not for 3000 as per the manual, but playing up and down. > > The thing is that, no matter which rpm I would synchronise for, the > results would not be the same all way in the rest of the rpm, so I started > to believe that I had a different behaviour in the carbs. I asked the shop > that does usually my maintenance and both carbs were cleaned and needles > changed 10 h ago. > > So here I am, doubting if my readings are wrong, If I need to check again > carbs or if I'm only good to build airframes, but unable to tune engines... > > For those of you with more experience, any suggestion/comments pls > > Thanks in advance > Godo > RV12 in Barcelona, Spain > > Last data: > > Rigth vs Left Carb mmH reading > 4500 rpm +0.5 mm > 4000 rpm +0.0 mm > 3500 rpm -1.5 mm > 3000 rpm -2.5 mm > 2500 rpm -2.5 mm > > * > > > * > > -- Zulu Delta Mk IIIC Thanks, Homer GBYM It isn't necessary to have relatives in Kansas City in order to be unhappy. - Groucho Marx ________________________________________________________________________________
Date: Jul 02, 2014
Forgive me if I come across as a bit pushy on this topic as fuel filters and aircraft fuel system design are a bit of a pet peeve of mine. Not at all, I=99m here to learn and constructive comments are always welcome. Based on standard aircraft design, there should be 1) a coarse finger screen on the outlet of each tank, this is filter number one which keeps large chunks of debris from entering the fuel delivery system. 2) Each tank should have a sediment drain to check for and eliminate debris and water which can accumulate in the tank. 3) At the lowest point in the fuel system there needs to be another sediment drain as this is also where water can accumulate. A properly designed gascolator should be installed in the system, often at the lowest point in lieu of a low point drain. The gascolator should be the type which has a sediment bowl with drain and a fairly fine mesh screen in the top which acts as filter number two. 4) Finally, the fuel pumps used on Rotax engines have a fine mesh screen in them (according to Phil Lockwood) which acts as a final filter before the fuel enters the carburetors. If particulate can get through these three filters, then it will go through the engine without hurting anything. So essentially, a properly designed fuel system has three stages of filtration. Why would you want to add another level of filtration to your fuel system? I have 3 and 4 and suppose I wanted to install 1 (finger screens) and 2 (tank drain). My wing tanks are made of epoxy resin that=99s a few mm thick. How would you go about installing such fittings? I managed in the past to install a tank vent by threading a hole in the wing tank and screwing in a =C2=BC=9D NPT hose barb, with a counter-nut on the inside of the tank. But what if installing a counter-nut is not feasible? Are there any alternative methods? What kind of glue/sealant should be used? Would one use Alum Flange Fittings? I have zero experience in these matters and need some guidance as to best practice. ________________________________________________________________________________
Date: Jul 01, 2014
If yours is like mine the tank exit is buried in the lower aft corner of the tank. This makes it very difficult to secondarily reinforce, since it's hard to get enough bond area for the reinforcement. Best would be to adhere a tapered 1/4" thick G-10 tapping plate where you want the exit, then cover that with about 10 plies of 8oz fiberglass, tapering or sequencing so that the edges taper. This would give you a little less than 1/2" to tap into for the NPT finger strainers. (If you want to just glue a tapping plate externally, you'll have to extend well onto the tank sidewall to get enough adherence area to enable you do drill and tap the plate. Unfortunately the drilling and/or tapping process usually pries the tapping plate off the tank anyway. Been there...) Bulkhead fittings usually make you move well away from the edge/corner of the tank, making you loose capacity. Unfortunately, in this case I can't think of an easy solution. As to sealant, again I would use ACS 2-part polysulfide. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. On 7/1/2014 4:41 PM, Sacha wrote: > But what if installing a counter-nut is not feasible? Are there any > alternative methods? What kind of glue/sealant should be used? Would > one use Alum Flange Fittings? I have zero experience in these > matters and need some guidance as to best practice. ________________________________________________________________________________
Date: Jul 02, 2014
Did you know that many drones are powered by a Rotax engine? On Tuesday, July 1, 2014, william sullivan wrote: > williamtsullivan(at)att.net > > > I have no idea what it is, but save it and weigh it on a fine scale- > like a reloading scale. Then when you find out what it is, you can weigh > the new part and find out how much might still be in there. I once had > some red plastic like that clog up a hydraulic system. It turned out to be > part of a sight indicator on the oil filter. It had cracked, and somebody > pushed the red indicator back into the hole, and screwed a plug in on top > of it. The pump chewed it up, and it jammed the hydraulic system valves. > We kept cleaning the system, saving parts and weighing them, and comparing > against a new part. > > Bill Sullivan > -------------------------------------------- > On Tue, 7/1/14, CharlieTango > wrote: > > Subject: RotaxEngines-List: What is this cheesy material in my oil cooler? > To: rotaxengines-list(at)matronics.com > Date: Tuesday, July 1, 2014, 11:12 AM > > --> RotaxEngines-List message > posted by: "CharlieTango" > > > This CTSW has had high oil temps for the last 6 years. > I sent the oil cooler to Hot Flush and after a bunch of > metal this cheesy material started coming loose. > > What is it? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425840#425840 > > > Attachments: > > > http://forums.matronics.com//files/cheesy_material_from_oil_cooler_848.jpg > > > RotaxEngines-List Email Forum - > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > -- Sent from Gmail Mobile ________________________________________________________________________________
Subject: Can the 912ULS be hand started?
Date: Jul 09, 2014
I recently landed at a remote dry lake in my RV-4 with a Lycoming engine. When I attempted to start, my starter would not engage. Luckily I was able to hand prop the engine to get it started. If a similar situation occurred with my ROTAX 912 ULS powered RANS, would I be able to hand prop to get the engine started? -------- Mike Marker Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426401#426401 ________________________________________________________________________________
Subject: Re: Can the 912ULS be hand started?
Date: Jul 09, 2014
It isn't supposed to be done and can get you hurt. I did see a video once where someone pulled it off, but that was a rare exception. This is not a Lycoming or Conti. with a low compression ratio and loose tolerances with mags. We have almost 11:1 compression and a CDI ignition which requires the engine to rotate at a certain speed to cause the trigger coils to fire enough energy to cause a spark and then we hope that compression doesn't kickback and break our hand. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426402#426402 ________________________________________________________________________________
Date: Jul 09, 2014
Hi I Mike Never done it myself but there is a guy on YouTube who has hand propped a 91 2.... http://www.youtube.com/watch?v=-JUBrHYsh4E Sacha > On 9 Jul 2014, at 18:43, "Mike M" wrote: > > > I recently landed at a remote dry lake in my RV-4 with a Lycoming engine. When I attempted to start, my starter would not engage. Luckily I was able to hand prop the engine to get it started. If a similar situation occurred with my ROTAX 912 ULS powered RANS, would I be able to hand prop to get the engine started? > > -------- > Mike Marker > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426401#426401 > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Jul 09, 2014
Mike M/Folks: Prior to my first flight to Alaska in 1994, I hand propped my 912 80 HP. There wasn't a 912UL designation in 1994. I hand propped the 912 once to insure I could if the need arose when I was on the ground in a remote location. Biggest problem hand propping was the Warp Drive Prop with very thin, sharp blade edges. A major consideration hand propping the 912 when alone in a remote location was the possibility of injury. Was the gamble of injury worth getting the 912 started, or wait until someone came along with jumper cables. My current engine, a 912ULS, has never been hand propped and I do not intend to attempt it. The increased compression ratio would make it difficult to hand prop, especially equipped with the Warp Drive. Not worth the chance of getting injured. If it was a life or death situation, I might give it a try. Gloves would help to pull the prop through. john h Kolb MKIII White Sulphur Springs, Montana ************************************** I recently landed at a remote dry lake in my RV-4 with a Lycoming engine. When I attempted to start, my starter would not engage. Luckily I was able to hand prop the engine to get it started. If a similar situation occurred with my ROTAX 912 ULS powered RANS, would I be able to hand prop to get the engine started? -------- Mike Marker ________________________________________________________________________________
Date: Jul 10, 2014
Thanks for the good info on hand starting issues for the 912S...high compression, potential kick back, and thin prop blades and achieving sufficient RPM to for the ignition system to spark. I can foresee a situation where a battery dies or starter system fails at a remote landing site, which would result in a long walk out of 10- 20 miles. In this case I would be like to have the option to attempt a hand start. It would be good to know that it is at least possible to hand start the 912S based on the knowledge that someone out there in the ROTAX world has successfully done it. -------- Mike Marker Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426417#426417 ________________________________________________________________________________
Date: Jul 10, 2014
Hi Group FWIW I took a bike ride by the model flying field a few weeks ago and took a look at a 3 cell 1300mA Lithium Polymer pack. It was a Thunder something or other (Thunder Power?). Anyway it was about a third the size of a pack of cigarettes and said it could output 80C! The guy said folks have gotten stuck with their cars and used them to get going again. If you are not charging and discharging a battery in flight I think the chance of a battery getting all hot and bothered are pretty remote. That's not the case after you just started your plane with it though, so careful monitoring for a few minutes is prudent. I believe the self discharge rate is not too bad on LiPos. We know you are going to get a substantial voltage drop, so it would be worth someone considering this option to try a 3 cell pack, perhaps even a 4 cell pack. I have a NiMh total loss pack for my 914. It can a fuel pump, in an emergency can probably get me started too: http://www.europaowners.org/main.php?g2_itemId=87439 Ron Parigoris ________________________________________________________________________________
Date: Jul 10, 2014
There are now lithium ion packs that are smaller than a paperback that can start your car. Here is a link to a review of three of them: http://www.cnet.com/news/pocket-sized-jump-starters/ -- Craig On Thu, Jul 10, 2014 at 4:56 AM, wrote: > Hi Group > > FWIW I took a bike ride by the model flying field a few weeks ago and took > a look at a 3 cell 1300mA Lithium Polymer pack. > > It was a Thunder something or other (Thunder Power?). Anyway it was about > a third the size of a pack of cigarettes and said it could output 80C! > > The guy said folks have gotten stuck with their cars and used them to get > going again. > > If you are not charging and discharging a battery in flight I think the > chance of a battery getting all hot and bothered are pretty remote. That's > not the case after you just started your plane with it though, so careful > monitoring for a few minutes is prudent. > > I believe the self discharge rate is not too bad on LiPos. We know you are > going to get a substantial voltage drop, so it would be worth someone > considering this option to try a 3 cell pack, perhaps even a 4 cell pack. > > I have a NiMh total loss pack for my 914. It can a fuel pump, in an > emergency can probably get me started too: > > http://www.europaowners.org/main.php?g2_itemId=87439 > > Ron Parigoris > > * > > > * > > ________________________________________________________________________________
Date: Jul 10, 2014
Good question Mike! Let's see... Which prop do you have? Two blade or Three blade? With a three blade your chances of getting hit with the following blade are 66.6% higher than with a two blade. The gearbox is a reduction in RPM from the engine to the prop. So, reversing the gear reduction the engine should turn Faster than the prop increasing your chances of starting... As long as you have the strength to swing the prop. What kind of ignition system do you have? Things like vacuum advancing decrease your chances of hand propping because a higher Engine RPM is required for starting. If you have a RANS Pusher, I would think you would be in deep yogurt! If a tractor, yea, you do stand a better chance. Not great, but better. Anyone out ther with success in this area. Anyone that is still in one piece? Barry On Wednesday, July 9, 2014, Mike M wrote: > > > > I recently landed at a remote dry lake in my RV-4 with a Lycoming engine. > When I attempted to start, my starter would not engage. Luckily I was > able to hand prop the engine to get it started. If a similar situation > occurred with my ROTAX 912 ULS powered RANS, would I be able to hand prop > to get the engine started? > > -------- > Mike Marker > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426401#426401 > > -- Sent from Gmail Mobile ________________________________________________________________________________
Date: Jul 10, 2014
I think typically you have to have the engine turning at 300 rpm or greater for the engine to even start. That's why when you try and start on a dead battery or a low battery may result in no start. On Jul 10, 2014 6:46 PM, "FLYaDIVE" wrote: > Good question Mike! > > Let's see... > Which prop do you have? > Two blade or Three blade? > With a three blade your chances of getting hit with the following blade > are 66.6% higher than with a two blade. > The gearbox is a reduction in RPM from the engine to the prop. So, > reversing the gear reduction the engine should turn Faster than the prop > increasing your chances of starting... As long as you have the strength to > swing the prop. > What kind of ignition system do you have? Things like vacuum advancing > decrease your chances of hand propping because a higher Engine RPM is > required for starting. > If you have a RANS Pusher, I would think you would be in deep yogurt! > If a tractor, yea, you do stand a better chance. Not great, but better. > > Anyone out ther with success in this area. Anyone that is still in one > piece? > > Barry > > > On Wednesday, July 9, 2014, Mike M wrote: > >> >> I recently landed at a remote dry lake in my RV-4 with a Lycoming engine. >> When I attempted to start, my starter would not engage. Luckily I was >> able to hand prop the engine to get it started. If a similar situation >> occurred with my ROTAX 912 ULS powered RANS, would I be able to hand prop >> to get the engine started? >> >> -------- >> Mike Marker >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=426401#426401 >> >> >> >> >> >> >> >> ========== >> -List" target="_blank"> >> http://www.matronics.com/Navigator?RotaxEngines-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > > -- > Sent from Gmail Mobile > > * > > > * > > ________________________________________________________________________________
Date: Jul 11, 2014
Subject: Re: Re: Can the 912ULS be hand started?
No way can you spin a 912S fast enough by hand to start it. I've seen one of these pocket-sized jump starters in action, and it's truly amazing! Definitely the way to go. *http://www.cnet.com/news/pocket-sized-jump-starters/ <http://www.cnet.com/news/pocket-sized-jump-starters/>* *JG* ________________________________________________________________________________
Date: Jul 12, 2014
I agree with everyone else post. Forget about hand propping as a back up. It most likely will never happen so I wouldn't even put it in my mental toolbox. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426539#426539 ________________________________________________________________________________
Date: Jul 17, 2014
Hi Guy What do you think of the idea of gluing aluminum welding flanges to the out side of the tank using two-part epoxy resin/glue or some other adhesive. Wou ld it work? Once the flanges are glued i could drill holes in the tank and then screw t he finger strainers/fuel drains in place. The flange for the fuel port could be cut so that it can sit lower down. Sacha > On Jul 2, 2014, at 2:35, Guy Buchanan wrote: > > If yours is like mine the tank exit is buried in the lower aft corner of t he tank. This makes it very difficult to secondarily reinforce, since it's h ard to get enough bond area for the reinforcement. Best would be to adhere a tapered 1/4" thick G-10 tapping plate where you want the exit, then cover t hat with about 10 plies of 8oz fiberglass, tapering or sequencing so that th e edges taper. This would give you a little less than 1/2" to tap into for the NPT finger strainers. (If you want to just glue a tapping plate ext ernally, you'll have to extend well onto the tank sidewall to get enough adh erence area to enable you do drill and tap the plate. Unfortunately the dril ling and/or tapping process usually pries the tapping plate off the tank any way. Been there...) > > Bulkhead fittings usually make you move well away from the edge/corner of t he tank, making you loose capacity. Unfortunately, in this case I can't thin k of an easy solution. > > As to sealant, again I would use ACS 2-part polysulfide. > > Guy Buchanan > Ramona, CA > Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded > Now a glider pilot, too. > > > >> On 7/1/2014 4:41 PM, Sacha wrote: >> But what if installing a counter-nut is not feasible? Are there any alte rnative methods? What kind of glue/sealant should be used? Would one use A lum Flange Fittings? I have zero experience in these matters and need some guidance as to best practice. > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Rough Running
Date: Jul 17, 2014
I have a 912 UL engine (671 hours TSN) on my Allegro 2000 E-LSA. I routinely changed the 8 plugs yesterday. Have done this numerous times without any problem. Immediately upon starting the engine it was difficult to start and when it finally did start it ran with difficulty and was very very rough especially around 2000 to 2500 rpm (almost wanted to jump out of the engine mounts). I stopped the engine immediately and rechecked all that I had done. Everything appeared to be correct. The wires were connected correctly and were tight on the plugs themselves. The engine was running fine before I changed the plugs. Nothing was done except to pull off the plug caps, remove the old plugs, install new NG DCPR7E plugs with small amount of heat transfer compound on threads, new electrode gap was 0.030, torqued to 177 in.lb, and plug caps reinstalled tight. Removing the plug caps from the plugs is difficult because of how tight they fit. The caps have to be =9Cwiggled=9D some to get them to begin to release to be pulled off. Since I have done this routinely for a number of times (6 times since new) I thought I may have damaged one of the plug caps. The problem is clearly an engine ignition problem and the only place where the plug wires have been handled or manipulated is at the plug caps where I have to physically pull off the caps to remove and replace the plugs. If I have damaged the wire/cap connection inside the cap how do I find this out? How do I check the individual plug wires for the proper resistance since one end of each wire is connected to the solid state ignition modules? I notice that the Rotax Maintenance Manual states that heat conduction compound can lead to ignition problems and the spark plug seat and threads in the cylinder should be cleaned to remove any residue of the heat conduction compound. How do you clean the seat and threads in the cylinder? Remember, I have done nothing but replaced the plugs. Any help and or advice would be appreciated. Hugh G. McKay III, P.E. Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Allegro 2000 N661WW Rotax 912 UL 671 hours Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com ________________________________________________________________________________
Date: Jul 17, 2014
First, I would regap plugs to .025. Second, double check that spark plug wires are on the correct cylinders. If the engine was running normally before you changed plugs, then the problem is something that was changed by you during the plug replacement. john h mkIII Thermopolis, WY From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Hugh McKay Sent: Thursday, July 17, 2014 7:08 AM Subject: RotaxEngines-List: Rough Running I have a 912 UL engine (671 hours TSN) on my Allegro 2000 E-LSA. I routinely changed the 8 plugs yesterday. Have done this numerous times without any problem. Immediately upon starting the engine it was difficult to start and when it finally did start it ran with difficulty and was very very rough especially around 2000 to 2500 rpm (almost wanted to jump out of the engine mounts). I stopped the engine immediately and rechecked all that I had done. Everything appeared to be correct. The wires were connected correctly and were tight on the plugs themselves. The engine was running fine before I changed the plugs. Nothing was done except to pull off the plug caps, remove the old plugs, install new NG DCPR7E plugs with small amount of heat transfer compound on threads, new electrode gap was 0.030, torqued to 177 in.lb, and plug caps reinstalled tight. Removing the plug caps from the plugs is difficult because of how tight they fit. The caps have to be =9Cwiggled=9D some to get them to begin to release to be pulled off. Since I have done this routinely for a number of times (6 times since new) I thought I may have damaged one of the plug caps. The problem is clearly an engine ignition problem and the only place where the plug wires have been handled or manipulated is at the plug caps where I have to physically pull off the caps to remove and replace the plugs. If I have damaged the wire/cap connection inside the cap how do I find this out? How do I check the individual plug wires for the proper resistance since one end of each wire is connected to the solid state ignition modules? I notice that the Rotax Maintenance Manual states that heat conduction compound can lead to ignition problems and the spark plug seat and threads in the cylinder should be cleaned to remove any residue of the heat conduction compound. How do you clean the seat and threads in the cylinder? Remember, I have done nothing but replaced the plugs. Any help and or advice would be appreciated. Hugh G. McKay III, P.E. Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Allegro 2000 N661WW Rotax 912 UL 671 hours Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com ________________________________________________________________________________
Date: Jul 17, 2014
Hi Hugh, I would start by being really, really sure that you have the plug leads on the correct plugs. Regards Brian Davies From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Hugh McKay Sent: 17 July 2014 14:08 Subject: RotaxEngines-List: Rough Running I have a 912 UL engine (671 hours TSN) on my Allegro 2000 E-LSA. I routinely changed the 8 plugs yesterday. Have done this numerous times without any problem. Immediately upon starting the engine it was difficult to start and when it finally did start it ran with difficulty and was very very rough especially around 2000 to 2500 rpm (almost wanted to jump out of the engine mounts). I stopped the engine immediately and rechecked all that I had done. Everything appeared to be correct. The wires were connected correctly and were tight on the plugs themselves. The engine was running fine before I changed the plugs. Nothing was done except to pull off the plug caps, remove the old plugs, install new NG DCPR7E plugs with small amount of heat transfer compound on threads, new electrode gap was 0.030, torqued to 177 in.lb, and plug caps reinstalled tight. Removing the plug caps from the plugs is difficult because of how tight they fit. The caps have to be =9Cwiggled=9D some to get them to begin to release to be pulled off. Since I have done this routinely for a number of times (6 times since new) I thought I may have damaged one of the plug caps. The problem is clearly an engine ignition problem and the only place where the plug wires have been handled or manipulated is at the plug caps where I have to physically pull off the caps to remove and replace the plugs. If I have damaged the wire/cap connection inside the cap how do I find this out? How do I check the individual plug wires for the proper resistance since one end of each wire is connected to the solid state ignition modules? I notice that the Rotax Maintenance Manual states that heat conduction compound can lead to ignition problems and the spark plug seat and threads in the cylinder should be cleaned to remove any residue of the heat conduction compound. How do you clean the seat and threads in the cylinder? Remember, I have done nothing but replaced the plugs. Any help and or advice would be appreciated. Hugh G. McKay III, P.E. Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Allegro 2000 N661WW Rotax 912 UL 671 hours Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com ________________________________________________________________________________
Date: Jul 17, 2014
It looks very similar to what I had during last 50 hours maintenance (on my MCR 4S). It wasn=99t the first visit I did and so I was very surprised to see how bad the engine was running after. And maybe I could still be there scratching my head (no hairs to pull out) if someone didn=99t came to show me that the lower wires were inverted on cylinders 2 and 4! Quite difficult to start, bad running on both mags and almost a shut down when running on =9Cmag 1=9D or =9Cmag2=9D. So for me double check your wires (or triple or ask someone to do it for you, no shame!) Max Cointe mcointe(at)free.fr F-PMLH Europa XS_TriGear Kit #560-2003 912ULS/AirmasterAP332 520 hours F-PLDJ Dyn=99A=C3=A9ro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1650 heures De : owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] De la part de Hugh McKay Envoy=C3=A9 : jeudi 17 juillet 2014 15:08 =C3 : Rotax Engines Objet : RotaxEngines-List: Rough Running I have a 912 UL engine (671 hours TSN) on my Allegro 2000 E-LSA. I routinely changed the 8 plugs yesterday. Have done this numerous times without any problem. Immediately upon starting the engine it was difficult to start and when it finally did start it ran with difficulty and was very very rough especially around 2000 to 2500 rpm (almost wanted to jump out of the engine mounts). I stopped the engine immediately and rechecked all that I had done. Everything appeared to be correct. The wires were connected correctly and were tight on the plugs themselves. The engine was running fine before I changed the plugs. Nothing was done except to pull off the plug caps, remove the old plugs, install new NG DCPR7E plugs with small amount of heat transfer compound on threads, new electrode gap was 0.030, torqued to 177 in.lb, and plug caps reinstalled tight. Removing the plug caps from the plugs is difficult because of how tight they fit. The caps have to be =9Cwiggled=9D some to get them to begin to release to be pulled off. Since I have done this routinely for a number of times (6 times since new) I thought I may have damaged one of the plug caps. The problem is clearly an engine ignition problem and the only place where the plug wires have been handled or manipulated is at the plug caps where I have to physically pull off the caps to remove and replace the plugs. If I have damaged the wire/cap connection inside the cap how do I find this out? How do I check the individual plug wires for the proper resistance since one end of each wire is connected to the solid state ignition modules? I notice that the Rotax Maintenance Manual states that heat conduction compound can lead to ignition problems and the spark plug seat and threads in the cylinder should be cleaned to remove any residue of the heat conduction compound. How do you clean the seat and threads in the cylinder? Remember, I have done nothing but replaced the plugs. Any help and or advice would be appreciated. Hugh G. McKay III, P.E. Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Allegro 2000 N661WW Rotax 912 UL 671 hours Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com ________________________________________________________________________________
Subject: Re: Rough Running
Date: Jul 17, 2014
When I replaced the plugs I did one at a time to make sure I connected the correct plug wire to the correct cylinder. Went Back and checked again today and the wires are correct. I also have the cylinder number marked on each valve cover, and each plug wire has a yellow band from the factory showing the number of the cylinder it goes to. Everything is correct. If the wires are connected correct, what would be my next step in finding the problem? Hugh G. McKay III, P.E. Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com From: Max Cointe (Free) Sent: Thursday, July 17, 2014 10:02 AM Subject: RE: RotaxEngines-List: Rough Running It looks very similar to what I had during last 50 hours maintenance (on my MCR 4S). It wasn=99t the first visit I did and so I was very surprised to see how bad the engine was running after. And maybe I could still be there scratching my head (no hairs to pull out) =C2 if someone didn=99t came to show me that the lower wires were inverted on cylinders 2 and 4! Quite difficult to start, bad running on both mags and almost a shut down when running on =9Cmag 1=9D or =9Cmag2=9D. So for me double check your wires (or triple or ask someone to do it for you, no shame!) Max=C2 Cointe mcointe(at)free.fr F-PMLH Europa XS_TriGear Kit #560-2003 912ULS/AirmasterAP332 520 hours F-PLDJ Dyn=99A=C3=A9ro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1650 heures De : owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] De la part de Hugh McKay Envoy=C3=A9 : jeudi 17 juillet 2014 15:08 =C3 : Rotax Engines Objet : RotaxEngines-List: Rough Running I have a 912 UL engine (671 hours TSN) on my Allegro 2000 E-LSA. I routinely changed the 8 plugs yesterday. Have done this numerous times without any problem. Immediately upon starting the engine it was difficult to start and when it finally did start it ran with difficulty and was very very rough especially around 2000 to 2500 rpm (almost wanted to jump out of the engine mounts). I stopped the engine immediately and rechecked all that I had done. Everything appeared to be correct. The wires were connected correctly and were tight on the plugs themselves. The engine was running fine before I changed the plugs. Nothing was done except to pull off the plug caps, remove the old plugs, install new NG DCPR7E plugs with small amount of heat transfer compound on threads, new electrode gap was 0.030, torqued to 177 in.lb, and plug caps reinstalled tight. Removing the plug caps from the plugs is difficult because of how tight they fit. The caps have to be =9Cwiggled=9D some to get them to begin to release to be pulled off. Since I have done this routinely for a number of times (6 times since new) I thought I may have damaged one of the plug caps. The problem is clearly an engine ignition problem and the only place where the plug wires have been handled or manipulated is at the plug caps where I have to physically pull off the caps to remove and replace the plugs. If I have damaged the wire/cap connection inside the cap how do I find this out? How do I check the individual plug wires for the proper resistance since one end of each wire is connected to the solid state ignition modules? I notice that the Rotax Maintenance Manual states that heat conduction compound can lead to ignition problems and the spark plug seat and threads in the cylinder should be cleaned to remove any residue of the heat conduction compound. How do you clean the seat and threads in the cylinder? Remember, I have done nothing but replaced the plugs. Any help and or advice would be appreciated. Hugh G. McKay III, P.E. Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Allegro 2000 N661WW Rotax 912 UL 671 hours Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com ________________________________________________________________________________
Date: Jul 17, 2014
Put the old plugs back in. The problem stated with the new plugs. Many new products fail right out of the box. The consumer is now quality control. On 7/17/2014 1:31 PM, Hugh McKay wrote: > When I replaced the plugs I did one at a time to make sure I connected > the correct plug wire to the correct cylinder. Went Back and checked > again today and the wires are correct. I also have the cylinder number > marked on each valve cover, and each plug wire has a yellow band from > the factory showing the number of the cylinder it goes to. Everything > is correct. If the wires are connected correct, what would be my next > step in finding the problem? > Hugh G. McKay III, P.E. > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > Ph. 704-661-8271 > Fax 704-483-5466 > email hgmckay(at)bellsouth.net > http://www.wwegeo.com > *From:* Max Cointe (Free) > *Sent:* Thursday, July 17, 2014 10:02 AM > *To:* rotaxengines-list(at)matronics.com > > *Subject:* RE: RotaxEngines-List: Rough Running > > It looks very similar to what I had during last 50 hours maintenance > (on my MCR 4S). It wasnt the first visit I did and so I was very > surprised to see how bad the engine was running after. And maybe I > could still be there scratching my head (no hairs to pull out) if > someone didnt came to show me that the lower wires were inverted on > cylinders 2 and 4! Quite difficult to start, bad running on both mags > and almost a shut down when running on mag 1 or mag2. > > So for me double check your wires (or triple or ask someone to do it > for you, no shame!) > > Max Cointe > > mcointe(at)free.fr > > F-PMLH Europa XS_TriGear > > Kit #560-2003 912ULS/AirmasterAP332 520 hours > > F-PLDJ DynAro MCR 4S > > Kit #27-2002 912ULSFR/MTProp MTV7A 1650 heures > > *De :*owner-rotaxengines-list-server(at)matronics.com > [mailto:owner-rotaxengines-list-server(at)matronics.com] *De la part de* > Hugh McKay > *Envoy :* jeudi 17 juillet 2014 15:08 > * :* Rotax Engines > *Objet :* RotaxEngines-List: Rough Running > > I have a 912 UL engine (671 hours TSN) on my Allegro 2000 E-LSA. I > routinely changed the 8 plugs yesterday. Have done this numerous times > without any problem. Immediately upon starting the engine it was > difficult to start and when it finally did start it ran with > difficulty and was very very rough especially around 2000 to 2500 rpm > (almost wanted to jump out of the engine mounts). I stopped the engine > immediately and rechecked all that I had done. Everything appeared to > be correct. The wires were connected correctly and were tight on the > plugs themselves. The engine was running fine before I changed the > plugs. Nothing was done except to pull off the plug caps, remove the > old plugs, install new NG DCPR7E plugs with small amount of heat > transfer compound on threads, new electrode gap was 0.030, torqued to > 177 in.lb, and plug caps reinstalled tight. > > Removing the plug caps from the plugs is difficult because of how > tight they fit. The caps have to be wiggled some to get them to > begin to release to be pulled off. Since I have done this routinely > for a number of times (6 times since new) I thought I may have damaged > one of the plug caps. The problem is clearly an engine ignition > problem and the only place where the plug wires have been handled or > manipulated is at the plug caps where I have to physically pull off > the caps to remove and replace the plugs. If I have damaged the > wire/cap connection inside the cap how do I find this out? How do I > check the individual plug wires for the proper resistance since one > end of each wire is connected to the solid state ignition modules? I > notice that the Rotax Maintenance Manual states that heat conduction > compound can lead to ignition problems and the spark plug seat and > threads in the cylinder should be cleaned to remove any residue of the > heat conduction compound. How do you clean the seat and threads in the > cylinder? Remember, I have done nothing but replaced the plugs. Any > help and or advice would be appreciated. > > Hugh G. McKay III, P.E. > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > Allegro 2000 > > N661WW > > Rotax 912 UL > > 671 hours > > Ph. 704-661-8271 > Fax 704-483-5466 > email hgmckay(at)bellsouth.net > http://www.wwegeo.com > > * > > href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.matronics.com/Navigator?RotaxEngines-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > * > > > * -- Lyle Sent from my Gateway E4610D desktop ________________________________________________________________________________
Date: Jul 17, 2014
On Thu, Jul 17, 2014 at 2:44 PM, Lyle Peterson wrote: > Put the old plugs back in. The problem stated with the new plugs. Many > new products fail right out of the box. The consumer is now quality > control. > > On 7/17/2014 1:31 PM, Hugh McKay wrote: > > When I replaced the plugs I did one at a time to make sure I connected > the correct plug wire to the correct cylinder. Went Back and checked agai n > today and the wires are correct. I also have the cylinder number marked o n > each valve cover, and each plug wire has a yellow band from the factory > showing the number of the cylinder it goes to. Everything is correct. If > the wires are connected correct, what would be my next step in finding th e > problem? > > Hugh G. McKay III, P.E. > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > Ph. 704-661-8271 > Fax 704-483-5466 > email hgmckay(at)bellsouth.net > http://www.wwegeo.com > > *From:* Max Cointe (Free) > *Sent:* Thursday, July 17, 2014 10:02 AM > *To:* rotaxengines-list(at)matronics.com > *Subject:* RE: RotaxEngines-List: Rough Running > > > It looks very similar to what I had during last 50 hours maintenance (on > my MCR 4S). It wasn=C3=A2=82=AC=84=A2t the first visit I did and so I was very surprised > to see how bad the engine was running after. And maybe I could still be > there scratching my head (no hairs to pull out) =C3=82 if someone didn=C3 =A2=82=AC=84=A2t > came to show me that the lower wires were inverted on cylinders 2 and 4! > Quite difficult to start, bad running on both mags and almost a shut down > when running on =C3=A2=82=AC=C5=93mag 1=C3=A2=82=AC or =C3=A2=82 =AC=C5=93mag2=C3=A2=82=AC . > > So for me double check your wires (or triple or ask someone to do it for > you, no shame!) > > > Max=C3=82 Cointe > > mcointe(at)free.fr > > F-PMLH Europa XS_TriGear > > Kit #560-2003 912ULS/AirmasterAP332 520 hours > > > F-PLDJ Dyn=C3=A2=82=AC=84=A2A=C3=83=C2=A9ro MCR 4S > > Kit #27-2002 912ULSFR/MTProp MTV7A 1650 heures > > > *De :* owner-rotaxengines-list-server(at)matronics.com [ > mailto:owner-rotaxengines-list-server(at)matronics.com > ] *De la part de* Hugh McKa y > *Envoy=C3=83=C2=A9 :* jeudi 17 juillet 2014 15:08 > *=C3=83=82=AC :* Rotax Engines > *Objet :* RotaxEngines-List: Rough Running > > > I have a 912 UL engine (671 hours TSN) on my Allegro 2000 E-LSA. I > routinely changed the 8 plugs yesterday. Have done this numerous times > without any problem. Immediately upon starting the engine it was difficul t > to start and when it finally did start it ran with difficulty and was ver y > very rough especially around 2000 to 2500 rpm (almost wanted to jump out of > the engine mounts). I stopped the engine immediately and rechecked all th at > I had done. Everything appeared to be correct. The wires were connected > correctly and were tight on the plugs themselves. The engine was running > fine before I changed the plugs. Nothing was done except to pull off the > plug caps, remove the old plugs, install new NG DCPR7E plugs with small > amount of heat transfer compound on threads, new electrode gap was 0.030, > torqued to 177 in.lb, and plug caps reinstalled tight. > > > Removing the plug caps from the plugs is difficult because of how tight > they fit. The caps have to be =C3=A2=82=AC=C5=93wiggled=C3=A2=82=AC some to get them to begin to > release to be pulled off. Since I have done this routinely for a number o f > times (6 times since new) I thought I may have damaged one of the plug > caps. The problem is clearly an engine ignition problem and the only plac e > where the plug wires have been handled or manipulated is at the plug caps > where I have to physically pull off the caps to remove and replace the > plugs. If I have damaged the wire/cap connection inside the cap how do I > find this out? How do I check the individual plug wires for the proper > resistance since one end of each wire is connected to the solid state > ignition modules? I notice that the Rotax Maintenance Manual states that > heat conduction compound can lead to ignition problems and the spark plug > seat and threads in the cylinder should be cleaned to remove any residue of > the heat conduction compound. How do you clean the seat and threads in th e > cylinder? Remember, I have done nothing but replaced the plugs. Any help > and or advice would be appreciated. > > > Hugh G. McKay III, P.E. > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > > Allegro 2000 > > N661WW > > Rotax 912 UL > > 671 hours > > Ph. 704-661-8271 > Fax 704-483-5466 > email hgmckay(at)bellsouth.net > http://www.wwegeo.com > > * > > href="http://www.matronics.com/Navigator?RotaxEngines-List" >http://www.matronics.com/Naviga tor?RotaxEngines-List <http://www.matronics.com/Navigator?RotaxEngines-List > > href="http://forums.matronics.com" >http:/ /forums.matronics.com <http://forums.matronics.com> > href="http://www.matronics.com/contribution" >http://www.matronics.com/c > * > > > -- > Lyle > > Sent from my Gateway E4610D desktop > > > * > =========== www.matronics.com/Navigator?RotaxEngines-List> =========== =========== om/contribution> =========== > > * > > Hi Hugh Download from here: http://contrails.free.fr/temp/9xx_heavy_maintenance_d05014.pdf the 912 heavy maintenance manual. Go to section 74,scroll down to page 22, it will tell you what you are suppose to see in terms of electrical resistance on different reference points in the ignition system . Check resistance from the internal of the plug connector to ground on all spark plug connectors, any reading in the range of 10.5 to 12.7 K ohm is a good reading (I summarized the connector resistance with the high voltage coil resistance, the last two lines on page 22). If all is well in that area then I would say that you have one or more faulty spark plugs, or may be the method of gaping you used is wrong altogether? (replaced inch units with MM units?) If you get some suspicious readings measuring the 8 connectors to ground, continue troubleshooting by separating the connectors from the wires, measuring the stand alone connector resistance and then the wire end to ground, compare to correct values as shown in page 22. Good luck, tell us please what was the happy end of the story Nati Niv RANS S6S 912ULS Illinois ________________________________________________________________________________
Date: Jul 17, 2014
I had a similiar, but somewhat more gentle problem after a plug change rece ntly. Roger Lee, at the Tucson Rotax Service Center, gave me a solution...w hen pulling the plug wires off it is easy to pull back the wire inside the cable....try this...remove the caps from the plug wires, and trim about 1/4 -inch off the cable, then reinsert the top cap of the plug wire assembly ba ck onto the plug top. If the wire had pulled back it would cause the proble m you have. Hope this helps. ----- Original Message ----- From: Lyle Peterson To: rotaxengines-list(at)matronics.com Sent: Thursday, July 17, 2014 1:44 PM Subject: Re: RotaxEngines-List: Rough Running Put the old plugs back in. The problem stated with the new plugs. Many new products fail right out of the box. The consumer is now quality contro l. On 7/17/2014 1:31 PM, Hugh McKay wrote: When I replaced the plugs I did one at a time to make sure I connected the correct plug wire to the correct cylinder. Went Back and checked again today and the wires are correct. I also have the cylinder number marked on each valve cover, and each plug wire has a yellow band from the factory sho wing the number of the cylinder it goes to. Everything is correct. If the w ires are connected correct, what would be my next step in finding the probl em? Hugh G. McKay III, P.E. Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com From: Max Cointe (Free) Sent: Thursday, July 17, 2014 10:02 AM To: rotaxengines-list(at)matronics.com Subject: RE: RotaxEngines-List: Rough Running It looks very similar to what I had during last 50 hours maintenance (o n my MCR 4S). It wasn=99t the first visit I did and so I was very sur prised to see how bad the engine was running after. And maybe I could still be there scratching my head (no hairs to pull out) =C2 if someone didn =99t came to show me that the lower wires were inverted on cylinders 2 a nd 4! Quite difficult to start, bad running on both mags and almost a shut down when running on =9Cmag 1=9D or =9Cmag2=9D. So for me double check your wires (or triple or ask someone to do it fo r you, no shame!) Max=C2 Cointe mcointe(at)free.fr F-PMLH Europa XS_TriGear Kit #560-2003 912ULS/AirmasterAP332 520 hours F-PLDJ Dyn=99A=C3=A9ro MCR 4S Kit #27-2002 912ULSFR/MTProp MTV7A 1650 heures De : owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxen gines-list-server(at)matronics.com] De la part de Hugh McKay Envoy=C3=A9 : jeudi 17 juillet 2014 15:08 =C3 : Rotax Engines Objet : RotaxEngines-List: Rough Running I have a 912 UL engine (671 hours TSN) on my Allegro 2000 E-LSA. I rout inely changed the 8 plugs yesterday. Have done this numerous times without any problem. Immediately upon starting the engine it was difficult to start and when it finally did start it ran with difficulty and was very very rou gh especially around 2000 to 2500 rpm (almost wanted to jump out of the eng ine mounts). I stopped the engine immediately and rechecked all that I had done. Everything appeared to be correct. The wires were connected correctly and were tight on the plugs themselves. The engine was running fine before I changed the plugs. Nothing was done except to pull off the plug caps, re move the old plugs, install new NG DCPR7E plugs with small amount of heat t ransfer compound on threads, new electrode gap was 0.030, torqued to 177 in =2Elb, and plug caps reinstalled tight. Removing the plug caps from the plugs is difficult because of how tight they fit. The caps have to be =9Cwiggled=9D some to get them t o begin to release to be pulled off. Since I have done this routinely for a number of times (6 times since new) I thought I may have damaged one of th e plug caps. The problem is clearly an engine ignition problem and the only place where the plug wires have been handled or manipulated is at the plug caps where I have to physically pull off the caps to remove and replace th e plugs. If I have damaged the wire/cap connection inside the cap how do I find this out? How do I check the individual plug wires for the proper resi stance since one end of each wire is connected to the solid state ignition modules? I notice that the Rotax Maintenance Manual states that heat conduc tion compound can lead to ignition problems and the spark plug seat and thr eads in the cylinder should be cleaned to remove any residue of the heat co nduction compound. How do you clean the seat and threads in the cylinder? R emember, I have done nothing but replaced the plugs. Any help and or advice would be appreciated. Hugh G. McKay III, P.E. Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Allegro 2000 N661WW Rotax 912 UL 671 hours Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.ma tronics.com/Navigator?RotaxEngines-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c -- Lyle Sent from my Gateway E4610D desktop --- This email is free from viruses and malware because avast! Antivirus protec tion is active. http://www.avast.com ________________________________________________________________________________
Date: Jul 17, 2014
The Rotax plug gap spec is .023 to .027. The wide gap for hot months and the narrow gap for cold winter months. If you want to just use .025 it won't hurt a thing. Absolutely no anti seize on any Rotax plugs... It should be the silicone based heat sync paste. Do not let it get down on the tips or it will cause mis-firing. Keep the paste on the upper 1/2 - 2/3 of the top of the plug threads. Leave the bottom 1/2 1/3 clean threads. If you yank a plug boot off too hard you may dislocate or pull the wire tip out of it's threaded anchor inside the boot. Always grab the plug boot and try not to be ham fisted. Just wiggle it back and forth as you pull. Many have found that they swapped plug wires even though they thought they were right. Just double check. If it shook this hard then it isn't just one plug wire or plug being an issue. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426860#426860 ________________________________________________________________________________
Date: Jul 18, 2014
Hugh, I had this happen to me on 2 occasions. The first one occurred when I reversed two of the plug wires when a friend walked into my hanger when I was working on the plane. I got distracted (won't do that again) The second one happened when I put new plugs in the engine as you have. After much checking I finally removed the new plugs and "bomb" checked them in my friends Champion spark plug checker. I found that one of the new plugs would not fire when pressure was applied to it. I chucked that plug in the bin and installed another new plug(after checking it) Problem solved. Dick Maddux 912UL ________________________________________________________________________________
Date: Jul 18, 2014
Hugh, OK, let me add my 2 on the subject. Last year at annual condition inspection I replaced the plugs on my 914. Ran like a sewing machine before the annual. Ran rough as a cob after. All the plug wires in the right places. Investigated the ignition module wiring, OK. Played with balancing the carbs. Nothing helped. Pulled the new plugs and inspected them, one at a time. One of the new plugs had a cracked insulator between the center electrode and outer case. You could see it after the run because the crack was stained brown. Replaced that plug and the engine ran much better. Smoothed out beautifully when I went back and rebalanced the carbs. Check all those new plugs. One or more could be bad. If you have the facilities, pressure (or bomb) check them as well. If all your plug wires go to the right place, I bet you have one or two bad plugs. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (50 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com ________________________________________________________________________________
Subject: 8th Annual 2014 Page, AZ. Fly-In
Date: Jul 19, 2014
8th Annual 2014 Page, AZ. Fly-In (WOW, Who would have thought, 8 years) Lake Powell, Monument Valley, Bryce Canyon, Zion, Grand Canyon, Bullfrog Marina Resort... Make those reservations now. It's time again to work on the Page, AZ Fly-In. We changed a few things last year that added some new fun. We did the river raft trip the day before the actual Fly-In day. It was a great raft trip. I would highly recommend it. We changed up some of the routes last year which turned out well so we'll do it again. The Page, AZ. Fly-In date is October 16-19, 2014 We will fly the Grand Canyon, Lake Powell, Monument Valley (breakfast), Zion Canyon and Bryce Canyon (breakfast), Bullfrog Marina and Resort (breakfast). I have blocked off 35 rooms. We will be at the Holiday Inn with a rate of $66 (2 queen beds). I hope to have a record number of CT's and LSA aircraft for our Page Fly-In. Just like last year make the reservations early so you don't miss out and the hotel won't hold all 40 rooms forever. Do not wait this year. Book it now and you can cancel up to 24 hours before Oct. 16th. Get it booked and reserved, then if you have to cancel you can, but if you wait again then you may not be staying with the rest of us and at your own peril for rates and possibly a different hotel. They book darn near the whole town in October. You must tell them you are with the "CT Group and ask to speak with Courtney" for your reference and the rate of $66 a night. We will arrive Thursday morning, Oct. 16th. and head home Oct. 19th. Sunday or Monday morning. Breakfast is free in the mornings. This hotel has not only a continental breakfast, but a full breakfast. I talked to the people at the Ranch House Grill and they will cater our evening meals again. We will have evening meals together Thursday, Friday and Saturday. Holiday Inn Express PAGE-LAKE POWELL Ask for Courtney or Andrea Smith 751 South Navajo Drive, Page, AZ 86040 928-645-9000 We will fly into the Page airport - KPGA. We are staying with Classic FBO and with our group we should get a 30 cent discount on fuel. Classic is not the first FBO next to the runway, but the second one behind them. The Antelope Canyon tour and the Dam tour is open if anyone wants. These are land tours. You guys are welcome to invite other planes that are not CT's and everyone is welcome. Find some more LSA's. I will develop GPS coordinates for all our routes and post them so you can enter them in your own GPS. I have a plan to better deal with all our planes for our flights so they are not crowded in the mornings or evenings. Don't miss this, we always have fun. p.s. I would like everyone coming to shoot me an email so I can put together a roster, make name tags and set up call signs like we did last year. If you attended last year and we had your personal info then just say you are coming. If you did not come last year then I would like the email to include: N#, Names of you and co-pilot, cell phone number, city, state. This is a big help for me to last year to organize our fly outs since we have so many planes and gives old friends and new friends a way to contact each other if need be. Thanks, Roger Lee Something new has been added. (This was lots of fun last year) You must refer to this Reservation Number: 70361 and tell them you are with the CT group. A 1/2 day raft trip on Wed. Oct. 15th from Glen Canyon Dam down to Lee's Ferry. The trip starts in Page (at 1100 hrs) where we will take a shuttle bus down below the dam. We will board a 20-22 person raft and travel down river for about 1.5 hrs. and get out for drinks and photos. Then back in and on down close to Lee's Ferry. Then we turn around a high speed boat back to the start. There is no white water just a nice trip down through the canyons. The cost for all of this is $87 a person. The phone number for the reservations is 928-645-9175. Don't be left out, I know of at least 6 people that have already signed up so don't be late to make the boat, sign up now. They have a 48 hr. cancellation policy and you get it all back except a $7 charge. This means you will have to arrive in Page Oct. 15th. BRING YOUR HAT, SUNGLASSES AND SUNSCREEN. Here is the link: http://raftthecanyon...day-raft-trips/ What are you waiting for, let's go, I'm already signed up. ;) Saturday Bomb drop and spot landing fun at Cal-Black airport a few miles NE of Page, AZ. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426926#426926 ________________________________________________________________________________
Subject: Re: 8th Annual 2014 Page, AZ. Fly-In
Date: Jul 19, 2014
The Page Fly-In attendees list was just updated. WHY ISN'T YOUR NAME ON THE LIST? Come join us. It will be the best trip you ever had. Scenery and friends like none other. p.s. Don't forget to send Roger your personal info as it is ask for in the original post. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426929#426929 ________________________________________________________________________________
Date: Jul 19, 2014
Hi Roger Just wondering if a Canadian with a KITFOX Vixen would be welcome!!! I am presently building an enclosed trailer for my Vixen with the intention of traveling to AZ for a few months this winter. I am towing it with a Sprinter Campervan. I would organize my trip to come through the Page area at this time.. I could arrive in time to setup my plane and join you CT folks on the flying trips. Don Hudgeon 14008 Nesbitt Ave Summerland,BC V0H 1Z1 250 494-9042 don(at)hudgeon.com KITFOX Vixen C-FOXK 912UL IVO IFA prop. Cheers Don On Sat, Jul 19, 2014 at 7:05 AM, Roger Lee wrote: > > The Page Fly-In attendees list was just updated. > > WHY ISN'T YOUR NAME ON THE LIST? > > Come join us. It will be the best trip you ever had. Scenery and friends > like none other. > > p.s. > Don't forget to send Roger your personal info as it is ask for in the > original post. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426929#426929 > > ________________________________________________________________________________
Date: Jul 19, 2014
Subject: Re: in-line fuel filters - can you recommend any?
Sorry for the late reply, Sacha, I've been out of town. That might work. You must be very careful to sand, clean, then use something like MetalPrep <http://www.aircraftspruce.com/catalog/cspages/metalprep.php?clickkey=99083>, then Alodine, to prep the surface of the aluminum so you get a really good bond. It will seriously ruin your day to have this flange pop off with the finger strainer in place, thereby letting the entire tank of fuel drain into your wing. >:o (Meaning: I would never do it, unless I glassed over it after bonding it.) Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. On 7/16/2014 8:50 PM, Sacha wrote: > What do you think of the idea of gluing aluminum welding flanges to > the outside of the tank using two-part epoxy resin/glue or some other > adhesive. Would it work? > > Once the flanges are glued i could drill holes in the tank and then > screw the finger strainers/fuel drains in place. > The flange for the fuel port could be cut so that it can sit lower down. ________________________________________________________________________________
Date: Jul 19, 2014
Hi Don, All are welcome. We have aircraft of all types and speeds. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426988#426988 ________________________________________________________________________________
Date: Jul 20, 2014
Thanks Roger I will plan on attending. Cheers Don On Sat, Jul 19, 2014 at 10:58 PM, Roger Lee wrote: > > Hi Don, > > All are welcome. We have aircraft of all types and speeds. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426988#426988 > > ________________________________________________________________________________
Subject: polyethylene tanks and fuel ports (used to be in-line
filters)
Date: Jul 21, 2014
Hi Guy, thank for your feedback yeah, those are scary thoughts. I did mean to add =9Cand then glass them over=9D to my original post in fact. But it turns out my wing tanks are not made of resin after all; a friend who is more knowledgeable than me in these matters told me they look like they are polyethylene, or maybe a kind of nylon, like the Kitfox header tank. So gluing will be difficult and I=99m not sure glassing them will work either: it looks like I will not be able to fit finger strainers (or fuel drain valves) to either wing tank as I can=99t find a viable way to attach the fuel ports/aluminum flanges to the tank walls. (As they need to be close to the trailing edge of the wing, it=99s not feasible to fit a counter-nut on the inside of the tank either). Instead of finger strainers on each wing, I=99m thinking of fitting a single finger strainer to the header tank. It looks like this can be done without too much difficulty if I can tin-solder some brass mesh to the fuel port (the finger strainers they sell at ACS seem to be made that way in fact I=99m having trouble finding brass mesh so I may have to cut some from one of the ACS strainers). sacha From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Guy Buchanan Sent: Sunday, 20 July, 2014 07:07 Subject: Re: RotaxEngines-List: in-line fuel filters - can you recommend any? Sorry for the late reply, Sacha, I've been out of town. That might work. You must be very careful to sand, clean, then use something like MetalPrep <http://www.aircraftspruce.com/catalog/cspages/metalprep.php?clickkey=9 9083> , then Alodine, to prep the surface of the aluminum so you get a really good bond. It will seriously ruin your day to have this flange pop off with the finger strainer in place, thereby letting the entire tank of fuel drain into your wing. >:o (Meaning: I would never do it, unless I glassed over it after bonding it.) Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. On 7/16/2014 8:50 PM, Sacha wrote: What do you think of the idea of gluing aluminum welding flanges to the outside of the tank using two-part epoxy resin/glue or some other adhesive. Would it work? Once the flanges are glued i could drill holes in the tank and then screw the finger strainers/fuel drains in place. The flange for the fuel port could be cut so that it can sit lower down. ________________________________________________________________________________
Date: Jul 20, 2014
Hi Don, I usually trailer my Kitfox to Page at the same time as the CT flyin and have used the large gravel area just past the main transient ramp to park the trailer if the ramp is expected to be loaded. Last year the lady who had airport management duties and wears other hats for the town was concerned about having room for my rig until I negotiated an arrangement to have the on site airport maintenance guys work with me to make sure I was not "in the way". If you end up using the gravel area expect to deal with sand burs. By the way, I will do two forums at Air Venture this year, the usual tips on touring by motorhome and folding wing plane. Not much changed in the forums since the last forums at Sun N Fun, Sebring and Copper State. Hope you get to have FUN! Robert (Bob) Jones Kitfox IV 912 Enclosed trailer > Hi Roger > Just wondering if a Canadian with a KITFOX Vixen would be welcome!!! > > I am presently building an enclosed trailer for my Vixen with the > intention > of traveling to AZ for a few months this winter. I am towing it with a > Sprinter Campervan. > I would organize my trip to come through the Page area at this time.. I > could arrive in time to setup my plane and join you CT folks on the flying > trips. > > Don Hudgeon > 14008 Nesbitt Ave > Summerland,BC > V0H 1Z1 > 250 494-9042 > don(at)hudgeon.com > > KITFOX Vixen C-FOXK > 912UL IVO IFA prop. > > Cheers > Don > > > On Sat, Jul 19, 2014 at 7:05 AM, Roger Lee wrote: > >> >> >> The Page Fly-In attendees list was just updated. >> >> WHY ISN'T YOUR NAME ON THE LIST? >> >> Come join us. It will be the best trip you ever had. Scenery and friends >> like none other. >> >> p.s. >> Don't forget to send Roger your personal info as it is ask for in the >> original post. >> >> -------- >> Roger Lee >> Tucson, Az. >> Light Sport Repairman - Maintenance Rated >> Rotax Repair Center - Heavy Maint. Rated >> Home 520-574-1080 TRY HOME FIRST >> Cell 520-349-7056 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=426929#426929 >> >> >> >> >> >> >> >> >> >> >> > ________________________________________________________________________________
Date: Jul 20, 2014
Subject: Re: polyethylene tanks and fuel ports (used to be
in-line filters) On 7/20/2014 3:49 PM, Sacha wrote: > > But it turns out my wing tanks are not made of resin after all; a > friend who is more knowledgeable than me in these matters told me they > look like they are polyethylene, or maybe a kind of nylon, like the > Kitfox header tank. So gluing will be difficult and Im not sure > glassing them will work either: > It's true. Nothing sticks reliably to polyethylene. It has to be welded. > > Instead of finger strainers on each wing, Im thinking of fitting a > single finger strainer to the header tank. It looks like this can be > done without too much difficulty if I can tin-solder some brass mesh > to the fuel port (the finger strainers they sell at ACS seem to be > made that way in fact Im having trouble finding brass mesh so I may > have to cut some from one of the ACS strainers). > I think the ACS strainers use steel mesh. Call them, they should be able to tell you. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. ________________________________________________________________________________
in-line filters)
Date: Jul 21, 2014
I have one here and it looks like bronze or brass. It's tin-soldered to a 1/2" male 3/8" female NPT fitting. > On Jul 21, 2014, at 5:53, Guy Buchanan wrote: > > I think the ACS strainers use steel mesh. ________________________________________________________________________________
Subject: Oil Usage with Oil Injectin?
Date: Jul 26, 2014
Roger or others. With a 582, one take off and one landing, cruising at 5800 rpm what should the oil usage be? Should it use the equivalent of 50-1 (12 gallons of gas used and 32 ounces of oil) or will be it somewhat less. At idle the mark on the oil pump lever is slightly advanced from the mark on the pump which indicates it should be using more oil than normal? Is the same lever used on all engines? Seems like each displacement engine should use different amount of oil since they all use different amounts of fuel per throttle opening? Just trying to know what is right since this is the first Rotax I have used with oil injection. Thanks Dennis -------- Dennis Long Oakland TN 2000 Aeroprakt A20 Vista Cruiser Previously Kolb Mark IIIC, 94 Firestar, 84 Ultrastar. 700+hours since 1/1/2009 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427366#427366 ________________________________________________________________________________
Date: Jul 26, 2014
Subject: Re: Oil Usage with Oil Injectin?
I measured rates between 50 and 70 to one, and ground idle time definitely kept things more toward the 50 side of things. Indeed it was hard to get it up toward 70. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. On 7/26/2014 7:47 AM, Thumper wrote: > > Roger or others. > With a 582, one take off and one landing, cruising at 5800 rpm what should the oil usage be? Should it use the equivalent of 50-1 (12 gallons of gas used and 32 ounces of oil) or will be it somewhat less. At idle the mark on the oil pump lever is slightly advanced from the mark on the pump which indicates it should be using more oil than normal? Is the same lever used on all engines? Seems like each displacement engine should use different amount of oil since they all use different amounts of fuel per throttle opening? Just trying to know what is right since this is the first Rotax I have used with oil injection. > > Thanks > Dennis > > -------- > Dennis Long > Oakland TN > 2000 Aeroprakt A20 Vista Cruiser > Previously Kolb Mark IIIC, 94 Firestar, 84 Ultrastar. > 700+hours since 1/1/2009 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427366#427366 > > ________________________________________________________________________________
Date: Jul 27, 2014
Subject: Re: RotaxEngines-List Digest: 1 Msgs - 07/26/14
I flew for over 10 years with oil injection. I just filled the reservoir at the beginning of each flight. Do this especially if you are planning a lon g trip with couple of fuel stops. Also, take a bottle with you. It is small , lightweight and has NO substitute.=0A=0A-=0ASTAN 2=0A=0A=0AOn Sunday, J uly 27, 2014 2:14 AM, RotaxEngines-List Digest Server wrote:=0A =0A=0A=0A*=0A=0A============ ==============0A- Online Versions of Today's L ist Digest Archive=0A================== ========0A=0AToday's complete RotaxEngines-List Digest can al so be found in either of the =0Atwo Web Links listed below.- The .html fi le includes the Digest formatted =0Ain HTML for viewing with a web browser and features Hyperlinked Indexes =0Aand Message Navigation.- The .txt fil e includes the plain ASCII version =0Aof the RotaxEngines-List Digest and c an be viewed with a generic text editor =0Asuch as Notepad or with a web br owser. =0A=0AHTML Version:=0A=0A- - http://www.matronics.com/digest/dig estview.php?Style=82701&View=html&Chapter 14-07-26&Archive=RotaxE ngines=0A=0AText Version:=0A=0A- - http://www.matronics.com/digest/dige stview.php?Style=82701&View=txt&Chapter 14-07-26&Archive=RotaxEng ines=0A=0A=0A==================== ====0A- EMail Version of Today's List Digest Archive=0A=== =====================0A=0A=0A- - - - - ---------------------------------------------------------- =0A- - - - - - - - - - - - - RotaxEngines-List D igest Archive=0A- - - - - - - - - - - - - - - - - - - ---=0A- - - - - - - - - - Total Messa ges Posted Sat 07/26/14: 1=0A- - - - - ------------------------- ---------------------------------=0A=0A=0AToday's Message Index:=0A-------- --------------=0A=0A- - 1. 07:48 AM - Oil Usage with Oil Injectin?- (Thumper)=0A=0A=0A=0A________________________________- Message 1- _____ : RotaxEngines-List: Oil Usage with Oil Injectin?=0AFrom: "Thumper" <dlong1 957(at)yahoo.com>=0A=0A=0ARoger or others.- =0A- - - With a 582, one t ake off and one landing, cruising at 5800 rpm what should=0Athe oil usage b e?- Should it use the equivalent of 50-1 (12 gallons of gas used=0Aand 32 ounces of oil) or will be it somewhat less.- At idle the mark on the=0Ao il pump lever is slightly advanced from the mark on the pump which indicate s=0Ait should be using more oil than normal?- Is the same lever used on a ll engines?=0ASeems like each displacement engine should use different amou nt of oil since=0Athey all use different amounts of fuel per throttle openi ng?- Just trying=0Ato know what is right since this is the first Rotax I have used with oil injection.=0A=0A=0AThanks=0ADennis=0A=0A--------=0ADenni s Long=0AOakland TN=0A2000 Aeroprakt A20 Vista Cruiser=0APreviously Kolb Ma rk IIIC, 94 Firestar, 84 Ultrastar.=0A700+hours since 1/1/2009=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p - - - - - - - - - - - - -Matt Dralle, List Admin. ==== ________________________________________________________________________________
Date: Jul 28, 2014
in-line filters)
Sacha: Why go through all that headache. Come off the fuel tank at the lowest point in the delivery system. Install two items; a T fitting with a sump drain and just before it an inline clear or translucent fuel filter. One on EACH tank, if you have two tanks. This way you now have a water drain at the lowest point in the system AND you have a simple replaceable fuel filter. MUCH, Much better than just a screen. If you can replace the filters Annually at Inspection time. Simple, easy, and very effective. The rule you must follow is: The filter as well as your fuel lines must be able to feed fuel at 3 times the full flow rate of your engine. GPH/GPM. And of course that means a larger surface / filtering area than the screen will ever be. Barry On Sun, Jul 20, 2014 at 6:49 PM, Sacha wrote: > Hi Guy, thank for your feedback yeah, those are scary thoughts. I did > mean to add =9Cand then glass them over=9D to my original pos t in fact. > > > But it turns out my wing tanks are not made of resin after all; a friend > who is more knowledgeable than me in these matters told me they look like > they are polyethylene, or maybe a kind of nylon, like the Kitfox header > tank. So gluing will be difficult and I=99m not sure glassing the m will > work either: it looks like I will not be able to fit finger strainers (or > fuel drain valves) to either wing tank as I can=99t find a viable w ay to > attach the fuel ports/aluminum flanges to the tank walls. (As they need to > be close to the trailing edge of the wing, it=99s not feasible to f it a > counter-nut on the inside of the tank either). > > > Instead of finger strainers on each wing, I=99m thinking of fitting a single > finger strainer to the header tank. It looks like this can be done witho ut > too much difficulty if I can tin-solder some brass mesh to the fuel port > (the finger strainers they sell at ACS seem to be made that way in fact > I=99m having trouble finding brass mesh so I may have to cut some f rom one of > the ACS strainers). > > > sacha > > > *From:* owner-rotaxengines-list-server(at)matronics.com [mailto: > owner-rotaxengines-list-server(at)matronics.com] *On Behalf Of *Guy Buchanan > *Sent:* Sunday, 20 July, 2014 07:07 > *To:* rotaxengines-list(at)matronics.com > *Subject:* Re: RotaxEngines-List: in-line fuel filters - can you > recommend any? > > > Sorry for the late reply, Sacha, I've been out of town. > > That might work. You must be very careful to sand, clean, then use > something like MetalPrep > <http://www.aircraftspruce.com/catalog/cspages/metalprep.php?clickkey=9 9083>, > then Alodine, to prep the surface of the aluminum so you get a really goo d > bond. It will seriously ruin your day to have this flange pop off with th e > finger strainer in place, thereby letting the entire tank of fuel drain > into your wing. >:o (Meaning: I would never do it, unless I glassed over > it after bonding it.) > > Guy Buchanan > Ramona, CA > Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded > Now a glider pilot, too. > > > On 7/16/2014 8:50 PM, Sacha wrote: > > What do you think of the idea of gluing aluminum welding flanges to the > outside of the tank using two-part epoxy resin/glue or some other adhesiv e. > Would it work? > > > Once the flanges are glued i could drill holes in the tank and then scre w > the finger strainers/fuel drains in place. > > The flange for the fuel port could be cut so that it can sit lower down. > > > http://www.matronics.com/Navigator?RotaxEngines-List > > http://forums.matronics.com - List Contribution Web generous =EF =BD -Matt Dralle, List href="http://www.matroni cs.com/contribution">http://www.matronics.com/c > > > * > =========== www.matronics.com/Navigator?RotaxEngines-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Jul 29, 2014
in-line filters) For those that use ACS gascolators that=C2-are several years old.=C2- T here is now a rubber seal ring that is rated for auto fuel with ethanol.=C2 - I found that over time my ACS rubber seal washer had hardened and neede d to be replaced.=C2- The newer upgraded seal washer is available from Ai r Spruce.=C2- I like the approach of filtering fuel with only a fire wall mounted gascolator.=C2- I have the Aero Designs after date sump drains =C2-installed on=C2-the bottom of both wings.=C2- I shaped a stream l ine fillet of micro around each protruding drain valve for esthetic reasons and to lower any generated airflow turbulence.=0ADave Weaver N912GR =0A=0A =0AOn Monday, July 28, 2014 7:51 AM, FLYaDIVE wrote: =0A =0A=0A=0ASacha:=0A=0AWhy go through all that headache. =C2-=0ACome o ff the fuel tank at the lowest point in the delivery system.=0AInstall two items; a T fitting with a sump drain and just before it an inline clear or translucent fuel filter. =C2-One on EACH tank, if you have two tanks.=0AT his way you now have a water drain at the lowest point in the system AND=0A you have a simple replaceable fuel filter. =C2-MUCH, Much better than jus t a screen. =0AIf you can replace the filters Annually at Inspection time. =0ASimple, easy, and very effective. =0AThe rule you must follow is: =C2- The filter as well as your fuel lines must be able to feed fuel at 3 times the full flow rate of your engine. =C2-GPH/GPM. =C2-And of course that means a larger surface / filtering area than the screen will ever be. =0A =0ABarry=0A=0A=0A=0AOn Sun, Jul 20, 2014 at 6:49 PM, Sacha wrote:=0A=0AHi Guy, thank for your feedback yeah, those are sca ry thoughts.=C2- I did mean to add =9Cand then glass them over =9D to my original post in fact. =0A>=C2-=0A>But it turns out my wing tanks are not made of resin after all; a friend who is more knowledgeable than me in these matters told me they look like they are polyethylene, or m aybe a kind of nylon, like the Kitfox header tank.=C2- =C2-So gluing wi ll be difficult and I=99m not sure glassing them will work either: it looks like I will not be able to fit finger strainers (or fuel drain valve s) to either wing tank as I can=99t find a viable way to attach the f uel ports/aluminum flanges to the tank walls.=C2- (As they need to be clo se to the trailing edge of the wing, it=99s not feasible to fit a cou nter-nut on the inside of the tank either). =0A>=C2-=0A>Instead of finger strainers on each wing, I=99m thinking of fitting a single finger st rainer to the header tank.=C2- It looks like this can be done without too much difficulty if I can tin-solder some brass mesh to the fuel port (the finger strainers they sell at ACS seem to be made that way in fact I=99m having trouble finding brass mesh so I may have to cut some fr om one of the ACS strainers). =0A>=C2-=0A>sacha =0A>=C2-=0A>=C2- =0A> From:owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengine s-list-server(at)matronics.com] On Behalf Of Guy Buchanan=0A>Sent: Sunday, 20 July, 2014 07:07=0A>To: rotaxengines-list(at)matronics.com=0A>Subject: Re: Rot axEngines-List: in-line fuel filters - can you recommend any? =0A>=C2-=0A >Sorry for the late reply, Sacha, I've been out of town. =0A>=0A>That might work. You must be very careful to sand, clean, then use something like Met alPrep, then Alodine, to prep the surface of the aluminum so you get a real ly good bond. It will seriously ruin your day to have this flange pop off w ith the finger strainer in place, thereby letting the entire tank of fuel d rain into your wing. >:o=C2- (Meaning: I would never do it, unless I glas sed over it after bonding it.)=0A>=0A>Guy Buchanan=0A>Ramona, CA=0A>Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded=0A>Now a glider pilot, t oo.=0A>=0A>=0A>=0A>=0A>On 7/16/2014 8:50 PM, Sacha wrote:=0A>What do you th ink of the idea of =C2-gluing aluminum welding flanges to the outside of the tank using two-part epoxy resin/glue or some other adhesive. Would it w ork?=0A>>=C2-=0A>>Once the flanges are glued i could drill holes in the t ank =C2-and then screw the finger strainers/fuel drains in place.=C2- =0A>>The flange for the fuel port could be cut so that it can sit lower dow n.=C2- =0A>=C2-=0A>=C2-http://www.matronics.com/Navigator?RotaxEngine s-List =0A>http://forums.matronics.com/=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2- - List Contribution Web generous =EF=BD=C2-=C2-=C2- =C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2--Matt Dralle, List href=" http://www.matronics.com/contribution">http://www.matronics.com/c= =0A> =C2- =0A>ist" target="_blank">http://www.matronics.com/Navigator?RotaxE ngines-List=0Atp://forums.matronics.com=0A_blank">http://www.matronics.com/ =========================0A ======================= ________________________________________________________________________________
Date: Jul 29, 2014
in-line filters)
I use ONLY a gascolator on my 912 UL and in 490 hours have never had a fuel contamination issue. I use non ethanol mogas exclusively except when travelling and 100LL is all that is available. I purchase fuel directly from the bulk agent. I might be wrong but too many filters on a gravity system may not be the answer. Take care Don On Tue, Jul 29, 2014 at 9:27 AM, David Weaver wrote: > For those that use ACS gascolators that are several years old. There is > now a rubber seal ring that is rated for auto fuel with ethanol. I found > that over time my ACS rubber seal washer had hardened and needed to be > replaced. The newer upgraded seal washer is available from Air Spruce. I > like the approach of filtering fuel with only a fire wall mounted > gascolator. I have the Aero Designs after date sump drains installed > on the bottom of both wings. I shaped a stream line fillet of micro arou nd > each protruding drain valve for esthetic reasons and to lower any generat ed > airflow turbulence. > Dave Weaver N912GR > > > On Monday, July 28, 2014 7:51 AM, FLYaDIVE wrote: > > > Sacha: > > Why go through all that headache. > Come off the fuel tank at the lowest point in the delivery system. > Install two items; a T fitting with a sump drain and just before it an > inline clear or translucent fuel filter. One on EACH tank, if you have t wo > tanks. > This way you now have a water drain at the lowest point in the system AND > you have a simple replaceable fuel filter. MUCH, Much better than just a > screen. > If you can replace the filters Annually at Inspection time. > Simple, easy, and very effective. > The rule you must follow is: The filter as well as your fuel lines must > be able to feed fuel at 3 times the full flow rate of your engine. > GPH/GPM. And of course that means a larger surface / filtering area tha n > the screen will ever be. > > Barry > > > On Sun, Jul 20, 2014 at 6:49 PM, Sacha wrote: > > Hi Guy, thank for your feedback yeah, those are scary thoughts. I did > mean to add =9Cand then glass them over=9D to my original pos t in fact. > > But it turns out my wing tanks are not made of resin after all; a friend > who is more knowledgeable than me in these matters told me they look like > they are polyethylene, or maybe a kind of nylon, like the Kitfox header > tank. So gluing will be difficult and I=99m not sure glassing the m will > work either: it looks like I will not be able to fit finger strainers (or > fuel drain valves) to either wing tank as I can=99t find a viable w ay to > attach the fuel ports/aluminum flanges to the tank walls. (As they need to > be close to the trailing edge of the wing, it=99s not feasible to f it a > counter-nut on the inside of the tank either). > > Instead of finger strainers on each wing, I=99m thinking of fitting a single > finger strainer to the header tank. It looks like this can be done witho ut > too much difficulty if I can tin-solder some brass mesh to the fuel port > (the finger strainers they sell at ACS seem to be made that way in fact > I=99m having trouble finding brass mesh so I may have to cut some f rom one of > the ACS strainers). > > sacha > > > *From:* owner-rotaxengines-list-server(at)matronics.com [mailto: > owner-rotaxengines-list-server(at)matronics.com] *On Behalf Of *Guy Buchanan > *Sent:* Sunday, 20 July, 2014 07:07 > *To:* rotaxengines-list(at)matronics.com > *Subject:* Re: RotaxEngines-List: in-line fuel filters - can you > recommend any? > > Sorry for the late reply, Sacha, I've been out of town. > > That might work. You must be very careful to sand, clean, then use > something like MetalPrep > <http://www.aircraftspruce.com/catalog/cspages/metalprep.php?clickkey=9 9083>, > then Alodine, to prep the surface of the aluminum so you get a really goo d > bond. It will seriously ruin your day to have this flange pop off with th e > finger strainer in place, thereby letting the entire tank of fuel drain > into your wing. >:o (Meaning: I would never do it, unless I glassed over > it after bonding it.) > > Guy Buchanan > Ramona, CA > Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded > Now a glider pilot, too. > > > On 7/16/2014 8:50 PM, Sacha wrote: > > What do you think of the idea of gluing aluminum welding flanges to the > outside of the tank using two-part epoxy resin/glue or some other adhesiv e. > Would it work? > > Once the flanges are glued i could drill holes in the tank and then scre w > the finger strainers/fuel drains in place. > The flange for the fuel port could be cut so that it can sit lower down. > > > http://www.matronics.com/Navigator?RotaxEngines-List > > http://forums.matronics.com/ - List Contribution Web generous =EF =BD -Matt Dralle, List href="http://www.matroni cs.com/contribution">http://www.matronics.com/c > > > * > > ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-Li st <http://www.matronics.com/Navigator?RotaxEngines-List> > tp://forums.matronics.com <http://forums.matronics.com> > _blank">http://www.matronics.com/contribution > > * > > > *cs.com/Navigator?RotaxEngines-List <http://cs.com/Navigator?RotaxEngines -List>" target="_blank" rel="nofollow">http --> http://www.matronics.co m/con=============== > > <http://forums.matronics.com/>* > > > * > =========== www.matronics.com/Navigator?RotaxEngines-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Jul 29, 2014
in-line filters)
Don: The issue is a brass screen that is difficult or impossible to install Vs a functional in-line filter that does a better job then either the Gascolator or brass screen. I know you guys are experimental - But, do you know the issue with Gascolators and their bail? They require a second safety wire to hold the bail. And the Gascolator does not filter as fine as an inline $3.50 filter. And the Gascolator is not designed for fine filtering. It is designed for water separation. As long as you sump it at ever flight. My suggestion: Keep the Gascolator, I'm sure Sacha plans on doing that - AND - Install the in-line filter for a total worry free operation. Barry On Tue, Jul 29, 2014 at 4:09 PM, Don Hudgeon wrote: > I use ONLY a gascolator on my 912 UL and in 490 hours have never had a > fuel contamination issue. I use non ethanol mogas exclusively except when > travelling and 100LL is all that is available. I purchase fuel directly > from the bulk agent. > > I might be wrong but too many filters on a gravity system may not be the > answer. > > Take care > Don > > > On Tue, Jul 29, 2014 at 9:27 AM, David Weaver > wrote: > >> For those that use ACS gascolators that are several years old. There is >> now a rubber seal ring that is rated for auto fuel with ethanol. I foun d >> that over time my ACS rubber seal washer had hardened and needed to be >> replaced. The newer upgraded seal washer is available from Air Spruce. I >> like the approach of filtering fuel with only a fire wall mounted >> gascolator. I have the Aero Designs after date sump drains installed >> on the bottom of both wings. I shaped a stream line fillet of micro aro und >> each protruding drain valve for esthetic reasons and to lower any genera ted >> airflow turbulence. >> Dave Weaver N912GR >> >> >> On Monday, July 28, 2014 7:51 AM, FLYaDIVE wrote : >> >> >> Sacha: >> >> Why go through all that headache. >> Come off the fuel tank at the lowest point in the delivery system. >> Install two items; a T fitting with a sump drain and just before it an >> inline clear or translucent fuel filter. One on EACH tank, if you have two >> tanks. >> This way you now have a water drain at the lowest point in the system AN D >> you have a simple replaceable fuel filter. MUCH, Much better than just a >> screen. >> If you can replace the filters Annually at Inspection time. >> Simple, easy, and very effective. >> The rule you must follow is: The filter as well as your fuel lines must >> be able to feed fuel at 3 times the full flow rate of your engine. >> GPH/GPM. And of course that means a larger surface / filtering area th an >> the screen will ever be. >> >> Barry >> >> >> On Sun, Jul 20, 2014 at 6:49 PM, Sacha wrote: >> >> Hi Guy, thank for your feedback yeah, those are scary thoughts. I did >> mean to add =9Cand then glass them over=9D to my original po st in fact. >> >> But it turns out my wing tanks are not made of resin after all; a friend >> who is more knowledgeable than me in these matters told me they look lik e >> they are polyethylene, or maybe a kind of nylon, like the Kitfox header >> tank. So gluing will be difficult and I=99m not sure glassing th em will >> work either: it looks like I will not be able to fit finger strainers (o r >> fuel drain valves) to either wing tank as I can=99t find a viable way to >> attach the fuel ports/aluminum flanges to the tank walls. (As they need to >> be close to the trailing edge of the wing, it=99s not feasible to fit a >> counter-nut on the inside of the tank either). >> >> Instead of finger strainers on each wing, I=99m thinking of fittin g a >> single finger strainer to the header tank. It looks like this can be do ne >> without too much difficulty if I can tin-solder some brass mesh to the f uel >> port (the finger strainers they sell at ACS seem to be made that way in >> fact I=99m having trouble finding brass mesh so I may have to cut some from >> one of the ACS strainers). >> >> sacha >> >> >> *From:* owner-rotaxengines-list-server(at)matronics.com [mailto: >> owner-rotaxengines-list-server(at)matronics.com] *On Behalf Of *Guy Buchana n >> *Sent:* Sunday, 20 July, 2014 07:07 >> *To:* rotaxengines-list(at)matronics.com >> *Subject:* Re: RotaxEngines-List: in-line fuel filters - can you >> recommend any? >> >> Sorry for the late reply, Sacha, I've been out of town. >> >> That might work. You must be very careful to sand, clean, then use >> something like MetalPrep >> <http://www.aircraftspruce.com/catalog/cspages/metalprep.php?clickkey= 99083>, >> then Alodine, to prep the surface of the aluminum so you get a really go od >> bond. It will seriously ruin your day to have this flange pop off with t he >> finger strainer in place, thereby letting the entire tank of fuel drain >> into your wing. >:o (Meaning: I would never do it, unless I glassed >> over it after bonding it.) >> >> Guy Buchanan >> Ramona, CA >> Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded >> Now a glider pilot, too. >> >> >> >> >> On 7/16/2014 8:50 PM, Sacha wrote: >> >> What do you think of the idea of gluing aluminum welding flanges to the >> outside of the tank using two-part epoxy resin/glue or some other adhesi ve. >> Would it work? >> >> Once the flanges are glued i could drill holes in the tank and then >> screw the finger strainers/fuel drains in place. >> The flange for the fuel port could be cut so that it can sit lower down. >> >> >> >> http://www.matronics.com/Navigator?RotaxEngines-List >> >> http://forums.matronics.com/ - List Contribution Web generous =EF=BD -Matt Dralle, List href="http://www.matr onics.com/contribution">http://www.matronics.com/c >> >> >> >> * >> >> ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-L ist <http://www.matronics.com/Navigator?RotaxEngines-List> >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> >> *cs.com/Navigator?RotaxEngines-List <http://cs.com/Navigator?RotaxEngine s-List>" target="_blank" rel="nofollow">http --> http://www.matronics.c om/con=============== >> >> <http://forums.matronics.com/>* >> >> >> >> * >> >> ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-L ist <http://www.matronics.com/Navigator?RotaxEngines-List> >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > * > =========== www.matronics.com/Navigator?RotaxEngines-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
in-line fi
Date: Jul 30, 2014
As with Barry I also have the inline filters and gascolator. Have had this arrangement for about 5 years now with no problems. My primary reason for installing the inline filters (about a foot or so below the wing tanks) was to check for possible flaking off of the wing tank sloshing compound as has happened with other Kitfox owners in the past. Even though I only use ethanol free car gas in my 912 I just want to have a check point as I get into the cockpit. Dick Maddux Kitfox 4 912UL ________________________________________________________________________________
in-line filters)
Date: Jul 30, 2014
Thank you all for your suggestions. I=99m planning to keep the gascolator because it=99s currently installed at the lowest point in the whole fuel system and would be where water is most likely to accumulate. Water could also accumulate in the wings (I have recently been reading www.sumpthis.com which I would recommended if you=99re interested in this issue) and I would also ideally want a sump drain in each wing. If I can=99t install one there, I will probably follow Barry=99s suggestions to install one on a T-fitting just outside the wing fuel port. As far as in-line fuel filters between the wings and the header tank, I sympathize with the view that too many filters can potentially be a problem with a gravity feed system, but I am also leaning towards including them because a) there are no strainers in the wings to stop gunk from getting into the feeder tank and b) there are two such filters, so they would both have to clog up in order to affect fuel flow and c) even if they did end up blocking fuel flow from the wings, my header tanks will hold 13 litres (3.8 gals) which is enough for almost an hour of flying around looking for a place to land. Of course, if I do install them I=99ll have to re-run all the fuel flow tests and make sure they are satisfactory. I have a fuel pressure gauge mounted so this will also be useful to gauge the resistance offered by any in-line filter. Again, thanks all for the helpful and stimulating comments. Sacha ________________________________________________________________________________
Subject: Low RPM on Takeoff???
Date: Aug 04, 2014
Recently my 912ULS engine started only going to 5000rpm on takeoff with full throttle. Previously it always went directly to 5500rpm or so upon application of full power. Now it only goes above 5000rpm once it has been flying for a few minutes. Once flying it will still go to 5500+ even in a climb so it isn't like it is just the climbing load on take off that is holding it back. No changes have been made to the engine so I don't know what would cause the RPM drop. It is enough that takes offs now need 1000+ feet where as before 500-600ft was enough. There is definitely a noticeable difference. I have checked the carburetor linkages - full throw to the stops there. Drained the gas in case it was old and replaced it with fresh new gas - no change. Tried it with half a tank of 100LL to give it an octane boost - no change. Checked the spark plugs - still clean after only 25hrs of use. Nothing stuck on the rads. Oil topped up. So - any idea as to what might cause the drop in rpm? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427986#427986 ________________________________________________________________________________
Subject: Re: Low RPM on Takeoff???
Date: Aug 05, 2014
Don't know whether 912S works the same way as 914, but a leak of fuel/air from the carb fuel bowl will do just that on a 914. David Joyce "tmitton" wrote: > > > Recently my 912ULS engine started only going to 5000rpm >on takeoff with full throttle. > > Previously it always went directly to 5500rpm or so upon >application of full power. Now it only goes above 5000rpm >once it has been flying for a few minutes. Once flying it >will still go to 5500+ even in a climb so it isn't like >it is just the climbing load on take off that is holding >it back. > > No changes have been made to the engine so I don't know >what would cause the RPM drop. It is enough that takes >offs now need 1000+ feet where as before 500-600ft was >enough. There is definitely a noticeable difference. > > I have checked the carburetor linkages - full throw to >the stops there. Drained the gas in case it was old and >replaced it with fresh new gas - no change. Tried it with >half a tank of 100LL to give it an octane boost - no >change. Checked the spark plugs - still clean after only >25hrs of use. Nothing stuck on the rads. Oil topped up. > > So - any idea as to what might cause the drop in rpm? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427986#427986 > > > > > > > >Un/Subscription, >http://www.matronics.com/Navigator?RotaxEngines-List >Forums! >Admin. > > > ________________________________________________________________________________
From: kerrimikehickman <kerrimikehickman(at)aol.com>
Date: Aug 05, 2014
I had that exact problem w/912ULS...=0A=0A=0A-Findings: very small hairline crack/approx. 2mm long in very small indentation (or igin unknown) in top of one carb housing...=0A(discovered after sending carbs to LEAF for routine ultrasonic cleaning/rubber rep lacement).=0A=0A=0A--Result: replacement of carb top housing led t o normal engine operation at all power settings.=0ACheers=0AMike=0A =0A=0A-----Original Message-----=0AFrom: tmitton <tmitton99(at)gmail.com>=0AT o: rotaxengines-list =0ASent: Mon, Aug 4, 2014 6:12 pm=0ASubject: RotaxEngines-List: Low RPM on Takeoff ton99(at)gmail.com>=0A=0ARecently my 912ULS engine started only going to 5000rpm on takeoff with full =0Athrottle.=0A=0APreviously it always went directly to 5500rpm or so upon application of fu ll =0Apower. Now it only goes above 5000rpm once it has be en flying for a few minutes. =0AOnce flying it will still go to 5500+ even in a climb so it isn't like it is =0A just the climbing load on take off that is holding it back . =0A=0ANo changes have been made to the engine so I don't know what would cause the RPM =0Adrop. It is enough that takes offs now need 1000+ feet where as before 500-600ft =0A was enough. There is definitely a noticeable difference. =0A=0AI have checked the carburetor linkages - full throw to the stops there. Drained =0Athe gas in case it was old and rep laced it with fresh new gas - no change. Tried =0Ait with half a tank of 100LL to give it an octane boost - no c hange. Checked the =0Aspark plugs - still clean after only 2 5hrs of use. Nothing stuck on the rads. =0AOil topped up.=0A =0ASo - any idea as to what might cause the drop in rpm? =0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics =========================== =========================== =========================== = - MATRONICS WEB FORUMS - =========================== =========================== =========================== ===============0A=0A=0A=0A=0A =0A=0A ________________________________________________________________________________
Date: Aug 07, 2014
Sounds like a STUCK VALVE or STUCK RINGS. Or a Temperature issue with the Mags. Temperature required to expand something. Either way it is a ROTAX... What else would you expect! Barry I am looking for a Zenith 601 with a Continental O-200 or Lycoming O-235 On Mon, Aug 4, 2014 at 8:11 PM, tmitton wrote: > > Recently my 912ULS engine started only going to 5000rpm on takeoff with > full throttle. > > Previously it always went directly to 5500rpm or so upon application of > full power. Now it only goes above 5000rpm once it has been flying for a > few minutes. Once flying it will still go to 5500+ even in a climb so it > isn't like it is just the climbing load on take off that is holding it back. > > No changes have been made to the engine so I don't know what would cause > the RPM drop. It is enough that takes offs now need 1000+ feet where as > before 500-600ft was enough. There is definitely a noticeable difference. > > I have checked the carburetor linkages - full throw to the stops there. > Drained the gas in case it was old and replaced it with fresh new gas - no > change. Tried it with half a tank of 100LL to give it an octane boost - no > change. Checked the spark plugs - still clean after only 25hrs of use. > Nothing stuck on the rads. Oil topped up. > > So - any idea as to what might cause the drop in rpm? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427986#427986 > > ________________________________________________________________________________
Date: Aug 07, 2014
5000 rpm on take off would equate to approximately 5600 rpm WOT flat and level. That should be about where you want to be for the average person. If the compression test is normal (I expect it to be) and the carbs sync up well, the mag drops are fairly equal and temps are all still what they used to be then it could be your rpm gauge. If rpms were to really fall off that much then there has to be changes going on somewhere else. You don't loose 500 rpm with no other affects. If you have an air leak that should show up by syncing the carbs (do this at 3500 rpm) or by spraying some starting fluid around the intake manifold and carb sockets and if the rpm jumps up you have a leak. Check the prop blades for equal pitch. If you can find nothing then rte-pitch the prop and see where that takes you. I have to ask. Are you sure about your numbers? -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428172#428172 ________________________________________________________________________________
Date: Aug 07, 2014
Positive about the numbers. Re-torqued all the prop bolts to spec (fixed pitch, wooden prop) and nothing changed. Still 5000rpm WOT on the ground, 5500+rpm WOT in the air. This sounds like good numbers but it WAS 5400+rpm WOT on the ground last week! Might try the starting fluid spray around the carbs next and see what happens. Thanks, Todd Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428192#428192 ________________________________________________________________________________
Date: Aug 09, 2014
Air density change (temperature, humidity) will cause a difference in static RPM, but 500 is a lot. Also check your air filter. Carl ----- Original Message ----- From: "tmitton" <tmitton99(at)gmail.com> Sent: Thursday, August 07, 2014 11:10 PM Subject: RotaxEngines-List: Re: Low RPM on Takeoff??? > > Positive about the numbers. Re-torqued all the prop bolts to spec (fixed > pitch, wooden prop) and nothing changed. Still 5000rpm WOT on the ground, > 5500+rpm WOT in the air. This sounds like good numbers but it WAS 5400+rpm > WOT on the ground last week! > > Might try the starting fluid spray around the carbs next and see what > happens. > > Thanks, > > Todd > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=428192#428192 > > > ________________________________________________________________________________
Date: Aug 10, 2014
Thanks for all the help so far...but no solution yet. We have checked just about everything everybody suggests but no luck. Went over the carbs with a magnifying glass - couldn't see any leaks. sprayed it with hair spray just in case to try to seal anything micro small. We even took out and inspected the diaphragms up close. No obvious intermittent grounds. Engine runs fine most of the time. Mag check drops about 50rpm both sides every time. Burning through premium gas regularly and diligently checking for water now. All the rubber connectors into and out of the carbs are in good shape without cracks. Changed the oil, cleaned or replaced the filters (air, gas and oil) and lubed every other moving part. Even changed to a brand new backup propeller we had and carefully tourqued all the bolts in place. We have marginally improved - WOT to about 5100 on first application and up to about 5300 after the 800ft run before t/o. (As high as we want in the air). Having a professional Rotax mechanic take a look but I will be very surprised if he finds anything obvious after our detailed examinations. Oh well - it still gets off the ground and pulls the plane along (Tecnam P96 Golf) so we still fly! Just wondering where our previous get up and go went? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428265#428265 ________________________________________________________________________________
Date: Aug 11, 2014
If your throttle levers are spring activated, they may not be pulling the throttles wide open. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of tmitton Sent: Sunday, August 10, 2014 10:16 AM Subject: RotaxEngines-List: Re: Low RPM on Takeoff??? Thanks for all the help so far...but no solution yet. We have checked just about everything everybody suggests but no luck. Went over the carbs with a magnifying glass - couldn't see any leaks. sprayed it with hair spray just in case to try to seal anything micro small. We even took out and inspected the diaphragms up close. No obvious intermittent grounds. Engine runs fine most of the time. Mag check drops about 50rpm both sides every time. Burning through premium gas regularly and diligently checking for water now. All the rubber connectors into and out of the carbs are in good shape without cracks. Changed the oil, cleaned or replaced the filters (air, gas and oil) and lubed every other moving part. Even changed to a brand new backup propeller we had and carefully tourqued all the bolts in place. We have marginally improved - WOT to about 5100 on first application and up to about 5300 after the 800ft run before t/o. (As high as we want in the air). Having a professional Rotax mechanic take a look but I will be very surprised if he finds anything obvious after our detailed examinations. Oh well - it still gets off the ground and pulls the plane along (Tecnam P96 Golf) so we still fly! Just wondering where our previous get up and go went? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428265#428265 ________________________________________________________________________________
Subject: Re: RotaxEngines-List Digest: 1 Msgs - 08/09/14
Date: Aug 12, 2014
Friend had a similar problem. Torn carb diaphram. Sent from my iPhone > On Aug 10, 2014, at 12:01 AM, RotaxEngines-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RotaxEngines-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RotaxEngines-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 14-08-09&Archive=RotaxEngines > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 14-08-09&Archive=RotaxEngines > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RotaxEngines-List Digest Archive > --- > Total Messages Posted Sat 08/09/14: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 08:09 AM - Re: Re: Low RPM on Takeoff??? (Carl) > > > > ________________________________ Message 1 _____________________________________ > > > From: Carl <b.carl(at)sympatico.ca> > Subject: Re: RotaxEngines-List: Re: Low RPM on Takeoff??? > > > Air density change (temperature, humidity) will cause a difference in static > RPM, but 500 is a lot. Also check your air filter. > Carl > > ----- Original Message ----- > From: "tmitton" <tmitton99(at)gmail.com> > Sent: Thursday, August 07, 2014 11:10 PM > Subject: RotaxEngines-List: Re: Low RPM on Takeoff??? > > >> >> Positive about the numbers. Re-torqued all the prop bolts to spec (fixed >> pitch, wooden prop) and nothing changed. Still 5000rpm WOT on the ground, >> 5500+rpm WOT in the air. This sounds like good numbers but it WAS 5400+rpm >> WOT on the ground last week! >> >> Might try the starting fluid spray around the carbs next and see what >> happens. >> >> Thanks, >> >> Todd >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=428192#428192 > > > > > > > > > ________________________________________________________________________________
Date: Aug 12, 2014
Friend had a similar problem. Torn carb diaphragm (sp). Was that a case of a Ham Handed Wrench Turner or Rotax Design? On Tue, Aug 12, 2014 at 5:01 PM, Marty Santic wrote: > marty.santic(at)gmail.com> > > Friend had a similar problem. Torn carb diaphram. > > Sent from my iPhone > > > On Aug 10, 2014, at 12:01 AM, RotaxEngines-List Digest Server < > rotaxengines-list(at)matronics.com> wrote: > > > > * > > > > ================================================= > > Online Versions of Today's List Digest Archive > > ================================================= > > > > Today's complete RotaxEngines-List Digest can also be found in either of > the > > two Web Links listed below. The .html file includes the Digest formatted > > in HTML for viewing with a web browser and features Hyperlinked Indexes > > and Message Navigation. The .txt file includes the plain ASCII version > > of the RotaxEngines-List Digest and can be viewed with a generic text > editor > > such as Notepad or with a web browser. > > > > HTML Version: > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 14-08-09&Archive=RotaxEngines > > > > Text Version: > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 14-08-09&Archive=RotaxEngines > > > > > > =============================================== > > EMail Version of Today's List Digest Archive > > =============================================== > > > > > > ---------------------------------------------------------- > > RotaxEngines-List Digest Archive > > --- > > Total Messages Posted Sat 08/09/14: 1 > > ---------------------------------------------------------- > > > > > > Today's Message Index: > > ---------------------- > > > > 1. 08:09 AM - Re: Re: Low RPM on Takeoff??? (Carl) > > > > > > > > ________________________________ Message 1 > _____________________________________ > > > > > > From: Carl <b.carl(at)sympatico.ca> > > Subject: Re: RotaxEngines-List: Re: Low RPM on Takeoff??? > > > > > > Air density change (temperature, humidity) will cause a difference in > static > > RPM, but 500 is a lot. Also check your air filter. > > Carl > > > > ----- Original Message ----- > > From: "tmitton" <tmitton99(at)gmail.com> > > Sent: Thursday, August 07, 2014 11:10 PM > > Subject: RotaxEngines-List: Re: Low RPM on Takeoff??? > > > > > >> > >> Positive about the numbers. Re-torqued all the prop bolts to spec (fixed > >> pitch, wooden prop) and nothing changed. Still 5000rpm WOT on the > ground, > >> 5500+rpm WOT in the air. This sounds like good numbers but it WAS > 5400+rpm > >> WOT on the ground last week! > >> > >> Might try the starting fluid spray around the carbs next and see what > >> happens. > >> > >> Thanks, > >> > >> Todd > >> > >> > >> Read this topic online here: > >> > >> http://forums.matronics.com/viewtopic.php?p=428192#428192 > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Removal Of 912 UL Gear Box
Date: Aug 15, 2014
Does the removal and reinstallation of the gear box on a 912 UL engine require that the oil lubrication system be =9Cvented=9D according to SI-04-1997 R3 before engine re-start? Hugh G. McKay III, P.E. Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com ________________________________________________________________________________
Subject: Re: Removal Of 912 UL Gear Box
Date: Aug 15, 2014
No, no oil purge after a gearbox installation. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428502#428502 ________________________________________________________________________________
From: =?iso-8859-1?Q?J=F3hann_J=F3hannsson?= <joeing701(at)simnet.is>
Subject: Clamp for the carb rubber socket
Date: Aug 15, 2014
Hello Rotax list members. Does anyone know where I can buy the clamp for the carburetor rubber socket on the Rotax 912 engine. I do have the rubber sockets but no clamp. Do not want to order the new rubber just to get the clamp. Johann G. Iceland. . ________________________________________________________________________________
Date: Aug 15, 2014
Johann: Contact Ronnie Smith at South Mississippi Light Aircraft. He'll send you one. http://www.flysmla.com/ Hope all is well in Iceland. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Jhann Jhannsson Sent: Friday, August 15, 2014 12:45 PM Subject: RotaxEngines-List: Clamp for the carb rubber socket Hello Rotax list members. Does anyone know where I can buy the clamp for the carburetor rubber socket on the Rotax 912 engine. I do have the rubber sockets but no clamp. Do not want to order the new rubber just to get the clamp. Johann G. Iceland. . ________________________________________________________________________________
Subject: Re: Clamp for the carb rubber socket
Date: Aug 15, 2014
How do you have new sockets without a new clamp? Rotax carb sockets come with clamps. The old clamps are gold and the new clamps are silver. You can use the old clamp if you put an 8mm spacer in on the screw. This will keep you from over tightening the clamp. I see you live in Iceland so some of the below may not apply. I hope these new sockets aren't JBM carb sockets or some other aftermarket part. I have seen several lately and they are not up to standard. The rubber gets too soft when hot, the carbs do not snap into place near as well. I just had a Sky Ranger in my shop. The clamps were down even past the 8mm safe stop. I put my fingers against the carb while I was checking something and it came out of the socket way to easily. I did the same to the other side and it did the same. I showed the owner the difference on a Rotax carb flange and he made me change his out back to a Rotax part. If you squeeze the out side ends of a JBM socket it is very soft and squeezable when hot and the Rotax is not. The Rotax rubber carb flange has deeper recessed groves so the carb seats in much tighter and doesn't easily push out of the socket. The Rotax socket holds the carb in better than the JBM even without the use of a clamp on the Rotax flange. There will be a new article out on the Rotax-Owner forum blog shortly about liability and aftermarket parts. It is worth reading. Even if you own an Experimental aircraft(in the US) you can still be held liable for sub-standard parts. It would be very easy to prove and hold you the owner up for at least a partial liable payout. The MFG of the part will be on the hook, but so would you. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428526#428526 ________________________________________________________________________________
Date: Aug 15, 2014
I hope these new sockets aren't JBM carb sockets or some other aftermarket part. I have seen several lately and they are not up to standard. Roger Lee I fly a Kolb MKIII pusher with a 912S. I use JBM carb sockets and his stainless steel exhaust springs (on a Titan exhaust system). The SS springs are great. I bought a set of 5 (1 for a spare) several years ago to replace the Rotax springs I had been using. Couldn't keep Rotax springs from breaking. The JBM sockets have been on the engine for a few years and a couple trans-continental flights. They seem to be performing as good as the original Rotax sockets. I had to change out the Rotax sockets after a few years because they started failing. I first noticed black streaks on top each intake manifold. Took a while to figure out the streaks were being made by the decomposing Rotax sockets which had also developed deep cracks. So far the JBM sockets are staying together. I have to check to see if my JBM sockets are "soft and squeezable" when hot, and if they are going to fall off when I least expect it. Getting ready to fly from Alabama to the Rock House near Burns Junction, Oregon. I don't want to lose a carb. For the most part I do use Rotax repair parts. A few items I do not: -Fram Tough Guard 3614 or 3600 oil filters (I can hear the gasps from here). Been flying these since the beginning. -VDO oil pressure sending units. Not the one that came in the engine. -NGK Iridium Spark Plugs DCPR8EIX. I flew from Alabama to Sun and Fun this year, plus local flying. Performance seems to be about the same. I haven't had a chance to see if they help performance or not, but will get a better look at them on my flight to Oregon and back. I have had good luck with the 912 series engines. I have been flying them on my present airplane since 1994. After more than 3,200.0 hours I have never had an engine failure. Wish I could have said that about the two strokes I flew. john h mkIII ________________________________________________________________________________
Subject: Oil Pressure on Rotax 912UL
Date: Aug 16, 2014
Hello. I have a 14 year old Rotax 912UL 80hp engine. When I powered up for a flight last week the VDO oil pressure gauge was reading high off the scale. I pulled the cowling and found that the wire had come loose from the sender. A non-aviation mechanic friend and I managed to damage the sender so I order a new VDO sender from Aircraft Spruce. My IA was helping me with some upgrades on my Zodiac and he replaced the sender today. When I powered up today the oil pressure gauge was still reading high, 135, but it was not off the scale. I shut down and powered up again and it read 120. We are wondering if the VDO oil pressure gauge was affected by the earlier off scale readings when the wire was broken. If so, will the gauge come back to normal readings or should I buy a new VDO oil pressure gauge and see if that fixes the problem? Thanks. Regards, Damien Grtaham N48TK ________________________________________________________________________________
Subject: Re: Oil Pressure on Rotax 912UL
Date: Aug 16, 2014
Had the same problem and I had ordered the 5 bar sender and not 10 bar sender. They will exchange if that is the problem. Sent from my iPhone > On Aug 16, 2014, at 5:22 PM, Damien Graham wrote: > > > Hello. I have a 14 year old Rotax 912UL 80hp engine. When I powered up for a flight last week the VDO oil pressure gauge was reading high off the scale. I pulled the cowling and found that the wire had come loose from the sender. A non-aviation mechanic friend and I managed to damage the sender so I order a new VDO sender from Aircraft Spruce. > My IA was helping me with some upgrades on my Zodiac and he replaced the sender today. When I powered up today the oil pressure gauge was still reading high, 135, but it was not off the scale. I shut down and powered up again and it read 120. > We are wondering if the VDO oil pressure gauge was affected by the earlier off scale readings when the wire was broken. If so, will the gauge come back to normal readings or should I buy a new VDO oil pressure gauge and see if that fixes the problem? Thanks. > Regards, > Damien Grtaham > N48TK > > > > ________________________________________________________________________________
Date: Aug 16, 2014
Thanks very much. Regards, Damien Sent from my iPad > On Aug 16, 2014, at 7:02 PM, Alan Sandul wrote: > > > Had the same problem and I had ordered the 5 bar sender and not 10 bar sender. They will exchange if that is the problem. > > Sent from my iPhone > >> On Aug 16, 2014, at 5:22 PM, Damien Graham wrote: >> >> >> Hello. I have a 14 year old Rotax 912UL 80hp engine. When I powered up for a flight last week the VDO oil pressure gauge was reading high off the scale. I pulled the cowling and found that the wire had come loose from the sender. A non-aviation mechanic friend and I managed to damage the sender so I order a new VDO sender from Aircraft Spruce. >> My IA was helping me with some upgrades on my Zodiac and he replaced the sender today. When I powered up today the oil pressure gauge was still reading high, 135, but it was not off the scale. I shut down and powered up again and it read 120. >> We are wondering if the VDO oil pressure gauge was affected by the earlier off scale readings when the wire was broken. If so, will the gauge come back to normal readings or should I buy a new VDO oil pressure gauge and see if that fixes the problem? Thanks. >> Regards, >> Damien Grtaham >> N48TK > > > > > ________________________________________________________________________________
Date: Aug 16, 2014
I think "bar 5" or "bar 10" is stamped on the side of the sensor's hex nut. -- Craig On Sat, Aug 16, 2014 at 5:07 PM, Damien Graham wrote: > dgraham7(at)twcny.rr.com> > > Thanks very much. > Regards, > Damien > > Sent from my iPad > > > On Aug 16, 2014, at 7:02 PM, Alan Sandul wrote: > > > > > > Had the same problem and I had ordered the 5 bar sender and not 10 bar > sender. They will exchange if that is the problem. > > > > Sent from my iPhone > > > >> On Aug 16, 2014, at 5:22 PM, Damien Graham > wrote: > >> > dgraham7(at)twcny.rr.com> > >> > >> Hello. I have a 14 year old Rotax 912UL 80hp engine. When I powered up > for a flight last week the VDO oil pressure gauge was reading high off the > scale. I pulled the cowling and found that the wire had come loose from the > sender. A non-aviation mechanic friend and I managed to damage the sender > so I order a new VDO sender from Aircraft Spruce. > >> My IA was helping me with some upgrades on my Zodiac and he replaced > the sender today. When I powered up today the oil pressure gauge was still > reading high, 135, but it was not off the scale. I shut down and powered up > again and it read 120. > >> We are wondering if the VDO oil pressure gauge was affected by the > earlier off scale readings when the wire was broken. If so, will the gauge > come back to normal readings or should I buy a new VDO oil pressure gauge > and see if that fixes the problem? Thanks. > >> Regards, > >> Damien Grtaham > >> N48TK > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 17, 2014
You need a gauge to go up to at least 100 psi. The max oil pressure can be up to 72 psi. If the oil pressure sender has something on the threads it won't ground properly. Make sure all your grounds are tight because this will cause this type of issue. Senders are more often at fault than the gauge itself by a long shot. Before you do anything put a mechanical gauge on the oil system to check the real pressure. This can be done down at the sender. Usually the port right in front of the oil pressure sender can be used. It is only plugged off with a screw. It is a 1/8"x27 NPT. You can use an inexpensive gauge of 100 psi from Ace Hardware. If you have the old style oil pressure regulator ball-bearing this migh be adding to your problems. Even if you don't get the extended TBO it is worth spending the $75 and ten minutes to install it. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428603#428603 ________________________________________________________________________________
Date: Aug 17, 2014
Thanks Roger. I always appreciate your advice. Regards, Damien On Aug 17, 2014, at 10:39 AM, Roger Lee wrote: > > You need a gauge to go up to at least 100 psi. The max oil pressure can be up to 72 psi. > If the oil pressure sender has something on the threads it won't ground properly. Make sure all your grounds are tight because this will cause this type of issue. Senders are more often at fault than the gauge itself by a long shot. > Before you do anything put a mechanical gauge on the oil system to check the real pressure. This can be done down at the sender. Usually the port right in front of the oil pressure sender can be used. It is only plugged off with a screw. It is a 1/8"x27 NPT. You can use an inexpensive gauge of 100 psi from Ace Hardware. If you have the old style oil pressure regulator ball-bearing this migh be adding to your problems. Even if you don't get the extended TBO it is worth spending the $75 and ten minutes to install it. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=428603#428603 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 17, 2014
Thanks Craig. I found the 10 bar stamp on the original sender. I will order the correct replacement. Thanks again. Regards, Damien On Aug 16, 2014, at 8:27 PM, Craig Payne wrote: > I think "bar 5" or "bar 10" is stamped on the side of the sensor's hex nut. > > -- Craig > > > On Sat, Aug 16, 2014 at 5:07 PM, Damien Graham wrote: > > Thanks very much. > Regards, > Damien > > Sent from my iPad > > > On Aug 16, 2014, at 7:02 PM, Alan Sandul wrote: > > > > > > Had the same problem and I had ordered the 5 bar sender and not 10 bar sender. They will exchange if that is the problem. > > > > Sent from my iPhone > > > >> On Aug 16, 2014, at 5:22 PM, Damien Graham wrote: > >> > >> > >> Hello. I have a 14 year old Rotax 912UL 80hp engine. When I powered up for a flight last week the VDO oil pressure gauge was reading high off the scale. I pulled the cowling and found that the wire had come loose from the sender. A non-aviation mechanic friend and I managed to damage the sender so I order a new VDO sender from Aircraft Spruce. > >> My IA was helping me with some upgrades on my Zodiac and he replaced the sender today. When I powered up today the oil pressure gauge was still reading high, 135, but it was not off the scale. I shut down and powered up again and it read 120. > >> We are wondering if the VDO oil pressure gauge was affected by the earlier off scale readings when the wire was broken. If so, will the gauge come back to normal readings or should I buy a new VDO oil pressure gauge and see if that fixes the problem? Thanks. > >> Regards, > >> Damien Grtaham > >> N48TK > > > > > > > > > > > > > ========== > - > xEngines-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List > ========== > FORUMS - > _blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > target="_blank">http://www.matronics.com/contribution > ========== > > > > > > > > ________________________________________________________________________________
Date: Aug 17, 2014
NOT LIKELY! Since your VDO sending unit is ELECTRIC and since the sending unit has ONLY a low voltage and high voltage limit - Even it the real pressure increased to 500 PSI the output of the sending unit STILL would be ONLY the max allowed by the unit. Ergo, it would NOT damage the indicator gauge. NOW! What you and the group should do is take Voltage reading Vs Pressure indications. Post those readings to the group and PLOT the resultants... Voltage Vs Pressure. Now, knowing those values you should be able to say: X Voltage (Low End) = X Pressure, Y Voltage (Middle) = Y Pressure, Z Voltage (High End) = Z Pressure and this would be Max Pressure readable by the gauge. Crazy question: Is there a manual for the unit which gives a check value? I also noticed there are a few different sending units... Which unit do you have? Which did you replace it with? Here is a unit that reads from a Low of 11.4 PSI to a high of 150 PSI. NOW! This unit even give a resistance value of 0 to 180 Ohms. You can either read the output voltage across the sending unit or remove the wires and read the resistance. But, the question is WHY is the pressure dropping each time? COLD oil will cause high oil pressures and as the oil temp increases the pressure will drop. Is that what you are seeing? Barry On Sat, Aug 16, 2014 at 5:22 PM, Damien Graham wrote: > dgraham7(at)twcny.rr.com> > > Hello. I have a 14 year old Rotax 912UL 80hp engine. When I powered up for > a flight last week the VDO oil pressure gauge was reading high off the > scale. I pulled the cowling and found that the wire had come loose from the > sender. A non-aviation mechanic friend and I managed to damage the sender > so I order a new VDO sender from Aircraft Spruce. > My IA was helping me with some upgrades on my Zodiac and he replaced the > sender today. When I powered up today the oil pressure gauge was still > reading high, 135, but it was not off the scale. I shut down and powered up > again and it read 120. > We are wondering if the VDO oil pressure gauge was affected by the earlier > off scale readings when the wire was broken. If so, will the gauge come > back to normal readings or should I buy a new VDO oil pressure gauge and > see if that fixes the problem? Thanks. > Regards, > Damien Grtaham > N48TK ________________________________________________________________________________
Subject: Re: rough running at 3400 RPM and above
Date: Aug 19, 2014
Doug, Your descriptions read as if I had written them myself, therefore I was very eager to read to the bottom and see your eventual solution, but I found... NOTHING! Did you ever solve your problem? I have not. My early model Rotax 912UL with Bing 64 carbs runs very smooth up to 3500 RPM but after that it stumbles/vibrates so badly that it looses power and refuses to push through 4100. but when I pull carb-heat it immediately smooths out and allows me to push it to 4300 RPMs for short periods before falling off dramatically. With the carb-heat "solution" I too came to the early opinion that I was running lean. But I have one significant difference from yours: my plugs are so sooty black they foul about every third flight when I change them. Which leads me to think our identical problems are not plug or fuel related. (I had been running rich plugs to attempt to balance my white #4 cylinder plug due to a factory recognized poor design of the intake header. I have since changed my strategy but that is another issue). I have torn apart my fuel system from one end to the other, cleaned carbs, checked jets, replaced seals and vitnum tipped needles, reset float levels, changed plugs and adjusted plug gaps many times, re-attached the plug wires in their seats and boots, etc. etc. Each time I spend days messing with it until I seem to have solved the problem, go for a few flights before the problem comes back, first small vibrations at the higher end, then more significant vibrations and at progressively lower RPMs until it becomes unflyable again. This has gone on for three years and has greatly mangled my enthusiasm for flying as it keeps me circling my private strip in frustration. Speculations: Recently I had a loose alternator belt on my truck and the engine started to loose power and run very poorly but it continued to run at low RPMs. I tightened the belt and solved my problem. It got me to thinking that I may be having a similar problem with my magnetos. This is so recent a thought that I have not yet began to explore how to check my mags when the engine won't run in the region that needs testing. Then I found your thread here. PLEASE tell me you finally figured out the actual solution but failed to post it here! I am very, very interested. - Kyle Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428766#428766 ________________________________________________________________________________
Date: Aug 19, 2014
My first flight to Alaska in 1994, my 912 had a similar problem. Eventually raised the fuel needles one notch and corrected the problem. Seems the old 80 horse is really sensitive to lean conditions at midrange. The way I eventually discovered the fix was pulling the enricher full on during flight at about 4,200 rpm. The engine gained 200 rpm. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of kyle Ponsford Sent: Tuesday, August 19, 2014 12:07 PM Subject: RotaxEngines-List: Re: rough running at 3400 RPM and above --> Doug, Your descriptions read as if I had written them myself, therefore I was very eager to read to the bottom and see your eventual solution, but I found... NOTHING! Did you ever solve your problem? I have not. My early model Rotax 912UL with Bing 64 carbs runs very smooth up to 3500 RPM but after that it stumbles/vibrates so badly that it looses power and refuses to push through 4100. but when I pull carb-heat it immediately smooths out and allows me to push it to 4300 RPMs for short periods before falling off dramatically. With the carb-heat "solution" I too came to the early opinion that I was running lean. But I have one significant difference from yours: my plugs are so sooty black they foul about every third flight when I change them. Which leads me to think our identical problems are not plug or fuel related. (I had been running rich plugs to attempt to balance my white #4 cylinder plug due to a factory recognized poor design of the intake header. I have since changed my strategy but that is another issue). I have torn apart my fuel system from one end to the other, cleaned carbs, checked jets, replaced seals and vitnum tipped needles, reset float levels, changed plugs and adjusted plug gaps many times, re-attached the plug wires in their seats and boots, etc. etc. Each time I spend days messing with it until I seem to have solved the problem, go for a few flights before the problem comes back, first small vibrations at the higher end, then more significant vibrations and at progressively lower RPMs until it becomes unflyable again. This has gone on for three years and has greatly mangled my enthusiasm for flying as it keeps me circling my private strip in frustration. Speculations: Recently I had a loose alternator belt on my truck and the engine started to loose power and run very poorly but it continued to run at low RPMs. I tightened the belt and solved my problem. It got me to thinking that I may be having a similar problem with my magnetos. This is so recent a thought that I have not yet began to explore how to check my mags when the engine won't run in the region that needs testing. Then I found your thread here. PLEASE tell me you finally figured out the actual solution but failed to post it here! I am very, very interested. - Kyle Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428766#428766 ________________________________________________________________________________
From: =?utf-8?Q?J=C3=B3hann_Gestur_J=C3=B3hannsson?= <joeing701(at)simnet.is>
Date: Aug 19, 2014
Hello Kyle. My friend had the exact same problem you have. He had been messing with his Rotax 912 ul engine since he bought it. Same as your experiance, seemed to have solved it but the rough running always came back. Finally he found the problem. The Stator was the original part and had been a recallmon that part, but it had not been replaced at the correct time. So my advice is to replace the stator. You can find the recall information from the Rotax on the stator. Hope this helps, Johann G. Sent from my iPad > On Aug 19, 2014, at 5:06 PM, "kyle Ponsford" wrote: > > > Doug, > Your descriptions read as if I had written them myself, therefore I was very eager to read to the bottom and see your eventual solution, but I found... NOTHING! > Did you ever solve your problem? I have not. > > My early model Rotax 912UL with Bing 64 carbs runs very smooth up to 3500 RPM but after that it stumbles/vibrates so badly that it looses power and refuses to push through 4100. but when I pull carb-heat it immediately smooths out and allows me to push it to 4300 RPMs for short periods before falling off dramatically. With the carb-heat "solution" I too came to the early opinion that I was running lean. > But I have one significant difference from yours: my plugs are so sooty black they foul about every third flight when I change them. Which leads me to think our identical problems are not plug or fuel related. > (I had been running rich plugs to attempt to balance my white #4 cylinder plug due to a factory recognized poor design of the intake header. I have since changed my strategy but that is another issue). > > I have torn apart my fuel system from one end to the other, cleaned carbs, checked jets, replaced seals and vitnum tipped needles, reset float levels, changed plugs and adjusted plug gaps many times, re-attached the plug wires in their seats and boots, etc. etc. > Each time I spend days messing with it until I seem to have solved the problem, go for a few flights before the problem comes back, first small vibrations at the higher end, then more significant vibrations and at progressively lower RPMs until it becomes unflyable again. This has gone on for three years and has greatly mangled my enthusiasm for flying as it keeps me circling my private strip in frustration. > > Speculations: > Recently I had a loose alternator belt on my truck and the engine started to loose power and run very poorly but it continued to run at low RPMs. > I tightened the belt and solved my problem. > It got me to thinking that I may be having a similar problem with my magnetos. This is so recent a thought that I have not yet began to explore how to check my mags when the engine won't run in the region that needs testing. > Then I found your thread here. > PLEASE tell me you finally figured out the actual solution but failed to post it here! I am very, very interested. > > - Kyle > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=428766#428766 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 19, 2014
Johann G., I am grateful for your information/suggestion and will tackle that idea immediately! Thanks, - Kyle Read this topic online here: http://forums.matronics.com/viewtopic.php?p=428799#428799 ________________________________________________________________________________
Date: Aug 20, 2014
Subject: Re: RotaxEngines-List Re: rough running at 3400 RPM
and above Kyle, I'm not sure if I'm the Doug you are referring to or not but I had a similar issue with my engine when I first started running it on my plane an d the issue was the chokes were not closed completely.- At higher RPM, sa y 3400 RPM and higher, the enrichener/choke circuit acts like an airbleed i nto the intake system which causes a lean stumble (thus why carb heat helps ).- As for the rich indications on the-plugs, I have no idea but first step is make sure your enricher circuit is absolutely closed after the engi ne starts.=0A=0ADoug M=0ACH-701/ Rotax 912UL=0A=0A =0A=0A__________________ List: Re: rough running at 3400 RPM and above=0AFrom: "kyle Ponsford" <wild _kyle(at)hotmail.com>=0A=0A=0ADoug,=0AYour descriptions read as if I had writt en them myself, therefore I was very eager=0Ato read to the bottom and see your eventual solution, but I found... NOTHING!=0ADid you ever solve your p roblem? I have not. ________________________________________________________________________________
Date: Aug 20, 2014
Kyle. I might have missed something, but have you had the carbs balanced. I had all sorts of drama, until the carbs were balanced. Good luck. Vernon. South Africa. -------------------------------------------------- From: "kyle Ponsford" <wild_kyle(at)hotmail.com> Sent: Wednesday, August 20, 2014 1:22 AM Subject: RotaxEngines-List: Re: rough running at 3400 RPM and above > > > Johann G., > I am grateful for your information/suggestion and will tackle that idea > immediately! > Thanks, > - Kyle > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=428799#428799 > > > ________________________________________________________________________________
Date: Aug 22, 2014
From: TheWanderingWench <thewanderingwench(at)yahoo.com>
Subject: If you're curious about flying cross-countries...
I'll be giving a Webinar on Wednesday, Aug. 27 @ 5:00 p.m. Pacific Daylight Time. It's titled Pushing Your Limits: Tips for Flying Long Cross Country Flights, and it's based on the numerous long cross country flights I've mad e. (Lots of photos!).=0A=0AIt's sponsored by EAA, but you don't need to be an EAA member to register. And...it's free!!!=0A=0ATo "attend" the Webinar, you need audio speakers on your computer and a broadband connection.=0A=0A =0AIf you're interested, attached is the Webinar registration.=C2-=0A=0AA rty Trost=0ASandy, Oregon=0A=0A=C2-=0Awww.LessonsFromTheEdge.com/uladvent ure2009.htm=0A=0A"Life's a daring adventure or nothing"=0A=0AHelen Keller =0A=0A"I refuse to tip toe through life just to arrive safely at death."=0A =0A=0A=0A=0A =0A=0A=0AEAA Webinars=0A=C2-=0A=C2-=0A=0A=C2-=0A=0ACheck out our upcoming webinars =C2- : : =C2- View this email online =0A=C2 - =0A =C2-=0AEAA Webinars Schedule=0AWe've announced our August - September webinars that you can enjoy from the comfort of your home. EAA W ebinars are free to all aviation enthusiasts, but pre-registration is recom mended since space is limited to the first 1,000 registrants. =0AUpcoming w ebinars include the following topics and presenters:=0A August 6 - 7 p.m. C DT =0AHow to Get Your Own Aerobatic Practice Area=0APresenter: Darren Pleas =0AKeeping Flying Affordable=0APresenter: Scott Sky Smith=0A=0AAugust 27 - =0AFAA AMT & Wings Credit=0APresenter: Mike Busch =0A=0ASeptember 10 - 7 p. =0APresenter: Michael Combs =0A=C2- =C2- =C2- =0A=C2-=0ARegister todayfor these upcoming free webinars! =0A=0A=0AAudio speakers and a broadb and Internet connection are required to participate in the webinars. Visit the webinars page for more information about EAA=99s Webinars. =0A=0A ________________________________=0A =0A=C2-=0AEAA gratefully acknowledges the support of Aircraft Spruce and Specialty Co. for their generous sponso rship of our webinar programs. =0A=C2-=0A Member Benefits : : Join EA A : : Support EAA : : EAA.org =0ATo make sure you continue receiving our e mails to your inbox (not bulk or junk folders), =0Aplease add membership@ea a.org to your address book or safe sender list. =0A=C2-=0AThis message w as sent to webinars(at)eaa.org =0AIt was sent from: Experimental Aircraft Asso ciation, Inc. 3000 Poberezny Road, Oshkosh, WI 54902=0Amembership(at)eaa.org =0A800-236-4800 :: 920-426-4800=0ACopyright 2013=0ADisclaimer/Privacy=C2- Policy =0A=C2-=0AManage Your Subscription ________________________________________________________________________________
Date: Aug 22, 2014
Update: Investigating the idea that my problem was the Stator, I was eventually led to Lockwood Aviation in Sebring Florida and spoke to their technician named Kerry, who, really impressed me with his knowledge and confidence in explaining, first; that my Stator was fine, and second; what my problem was. For those curious about both issues: The stator has two functions; providing power to the magnetos, and charging the battery. When it fails the first, the engine just quits. when it fails the second the battery won't charge. I have neither symptom. Kerry convinced me that my entire problem was carburetor related. It seems that Vernon (along with several others) are correct. My "unsolvable" problem has been in a lack of understanding the distinction between Synchronizing and Balancing when everyone seemed to use the words interchangeably, such as sync/balance. So now that I know there is a difference, let me explain for others, who, like me, are confused in thinking they are one in the same. I am familiar with syncing carbs on my snowmachine. Yes I have done this with my airplane... several times. So, I was convinced that "Yes, I have done that, thank you very much," ...but in fact, I had not balanced my carbs. It appears that this is my problem. (I have sent Kerry my carbs for a complete "fresh start" rebuild and will Post my results when I get them remounted and balanced). So here is the short of synchronizing carbs: It is the adjustment of the throttle cables to ensure that both carb slides open at the same amount at the same time. I am very careful to do this as accurately as possible and after setting, this should remain continuous until disconnecting the throttle cables for any reason. To me, this is a "one time event," though in my desperation I have checked and rechecked them and found them fine. BUT: balancing carbs is adjusting the fuel screws between carbs so that they suck the same. This takes a set of vacuum gauges or even a simple home-made set of water bottles explained on youtube. This is something that needs regular rechecks as it changes with vibration and such. I confess, I have never balanced my carbs, but now intend to make this a regular maintenance procedure. As I said, I will post my results when I get my carbs back and reinstalled, but at this point I am confident that I finally understand my problem, perhaps this can help others too. - Kyle Read this topic online here: http://forums.matronics.com/viewtopic.php?p=429123#429123 ________________________________________________________________________________
Date: Aug 22, 2014
=0ABalancing is great (I personally always referred to it as 'syncing' after 'adjusting' the idle/full throttle throws) but I 'm not a 912 mechanic either... =0AI'd recommend the Rotax-own ers.com website for a wealth of information if you've not be en there. =0AAlthough balancing can be accomplished many ways I personally highly recommend the Carbmate. It made it so qu ick and "stupid" easy I balance my carbs much more often w hich has helped make a very noticeable difference in my 912 performance year-round. Costs $100 bucks but immeasurably worth in to me.=0AMike=0A=0A-----Original Message-----=0AFrom: kyle Ponsford =0ATo: rotaxengines-list =0ASent: Fri, Aug 22, 2014 12:43 pm=0ASubject: RotaxEngine s-List: Re: rough running at 3400 RPM and above=0A=0A=0A--> Ro taxEngines-List message posted by: "kyle Ponsford" =0A=0AUpdate:=0AInvestigating the idea that my problem was t he Stator, I was eventually led to =0ALockwood Aviation in S ebring Florida and spoke to their technician named Kerry, =0Aw ho, really impressed me with his knowledge and confidence in explaining, first; =0Athat my Stator was fine, and second; wha t my problem was.=0A=0AFor those curious about both issues:=0ATh e stator has two functions; providing power to the magnetos, and charging the =0Abattery. When it fails the first, the en gine just quits. when it fails the =0Asecond the battery won 't charge.=0AI have neither symptom.=0A=0AKerry convinced me that my entire problem was carburetor related. It seems that =0AVer non (along with several others) are correct.=0AMy "unsolvable" p roblem has been in a lack of understanding the distinction =0A between Synchronizing and Balancing when everyone seemed to use the words =0Ainterchangeably, such as sync/balance. So now that I know there is a difference, =0Alet me explain for others, who, like me, are confused in thinking they are one =0Ain the same.=0A=0AI am familiar with syncing carbs on my snowmach ine. Yes I have done this with my =0Aairplane... several tim es. So, I was convinced that "Yes, I have done that, =0Ath ank you very much," ...but in fact, I had not balanced my carbs. It appears =0Athat this is my problem. (I have sent Kerry my carbs for a complete "fresh =0Astart" rebuild and w ill Post my results when I get them remounted and balanced). =0A=0ASo here is the short of synchronizing carbs: It is the adjustment of the =0Athrottle cables to ensure that both ca rb slides open at the same amount at the =0Asame time. I am very careful to do this as accurately as possible and a fter =0Asetting, this should remain continuous until disconnecting the throttle cables =0Afor any reason. To me, this is a "one time event," though in my desperation I =0Ahave checked and rechecked them and found them fine.=0A=0ABUT: balancing carb s is adjusting the fuel screws between carbs so that they =0Asuck the same. This takes a set of vacuum gauges or eve n a simple home-made set =0Aof water bottles explained on yo utube. This is something that needs regular =0Arechecks as it changes with vibration and such.=0AI confess, I have never bal anced my carbs, but now intend to make this a regular =0Am aintenance procedure.=0A=0AAs I said, I will post my results w hen I get my carbs back and reinstalled, but =0Aat this po int I am confident that I finally understand my problem,=0Aper haps this can help others too.=0A=0A- Kyle=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=429 =========================== =========================== =========================== -Matt Dralle =========================== ========0A=0A=0A=0A=0A =0A ________________________________________________________________________________
Date: Aug 22, 2014
Subject: Invitation to my Webinar - and the Registration URL
Hi folks -=0A=0AApparently the registration form I sent in my last e-mail d idn't come through.=0A=0ASo...here is the URL to register. You do NOT need to be an EAA member to register.- =0A=0A=0APUSHING YOUR LIMITS: Tips for Flying Long Cross Country Flights=0A- =0A- - - - - =0APUSHING Y OUR LIMITS: Tips for Flying Long Cross Country Flights=0APresenter: Arty Tr ost Arty Trost has been flying two-cycle powered ultralights and ultralight -type experimental aircraft for 25 years. She has taken cross county flying to the extreme: for the past fifteen years she has made annual long distan ce flights averaging 3-4 weeks and sev... =0AView on www2.gotomeeting.com Preview by Yahoo =0A- =0A-=0A-Arty=0A=0A=0Awww.LessonsFromTheEdge.co m/uladventure2009.htm=0A=0A=0A"Life's a daring adventure or nothing"=0AHele n Keller=0A=0A=0A"I refuse to tip toe through life just to arrive safely at death." ________________________________________________________________________________
Date: Aug 23, 2014
Even though the Carbmate and Syncromate can split a hair what they can't do at all is diagnose several carb problems at a glance or just by looking can't tell you which carb to adjust, which way and by approximately how much. They can't tell you if the cable needs to be lengthened or shortened at the throttle arm, but only that they are out of sync. They do work well, but after you disconnect the electronic device and hook the carbs back up the hair splitting is gone. I think the analog gauges still hold a distinct advantage over the electronic balancer's and in many Rotax classes we have come to the same conclusion. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=429192#429192 ________________________________________________________________________________
Date: Aug 23, 2014
Roger, why don't you out together a kit of the gauges you use and offer it for sale? I'd probably buy one johnwf Read this topic online here: http://forums.matronics.com/viewtopic.php?p=429194#429194 ________________________________________________________________________________
Date: Aug 24, 2014
All applicable kudos to Roger if he does decide to produce a gauge set for syncing 912/914 carbs but it would be a redundant product.- Lockwood sell s a very nice analog gauge set with applicable hoses, valves, and fittings for about $90.00.- I purchased one about five years ago and have used it several times.=0A=0Ahttp://www.lockwood.aero/p-2586-carb-synchronization-ki ect: RotaxEngines-List: Re: rough running at 3400 RPM and above=0AFrom: "Jo hnF" =0A=0A=0ARoger, why don't you out together a ki t of the gauges you use and offer it for=0Asale?- I'd probably buy one=0A johnwf ________________________________________________________________________________
Date: Aug 24, 2014
Gauges are all over the market as some have pointed out. All you need is 2 vacuum gauges that go from 0 to 30 in. I prefer liquid filled gauges.Buy some vacuum tubing from the auto store or Ace Hardware )about 10'), buy two needle valves from Ace (install them about 6" from the gauges) and then buy a 3/8" barbed fitting and reducers to fit the small vacuum tube (sand off the barbs so it is smooth), then get a 6" piece of poly tubing to fit on the other vacuum tube. When you sync the carbs push off the left or right side rubber hose that is on the carb balance tube. Now the carbs are separated. Then put the smooth brass end in the rubber hose and slide the poly hose over the 90 degree fitting on top of the air intake. Start your engines! p.s. The clear hose in the picture is for demo and it should be regular vacuum hose. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=429205#429205 Attachments: http://forums.matronics.com//files/carb_sync_150_169.jpg ________________________________________________________________________________
Date: Aug 24, 2014
And the best thing I have found to use is a twin engine manifold press. gage. Ollie Sent from my iPad > On Aug 23, 2014, at 8:18 PM, "Roger Lee" wrote: > > > Even though the Carbmate and Syncromate can split a hair what they can't do at all is diagnose several carb problems at a glance or just by looking can't tell you which carb to adjust, which way and by approximately how much. They can't tell you if the cable needs to be lengthened or shortened at the throttle arm, but only that they are out of sync. > > They do work well, but after you disconnect the electronic device and hook the carbs back up the hair splitting is gone. > > I think the analog gauges still hold a distinct advantage over the electronic balancer's and in many Rotax classes we have come to the same conclusion. > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=429192#429192 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 24, 2014
Subject: Vacuum gauge carb synch setup
After I completed Rotax training at Lockwood Aviation in the spring of 2007 I came home and built a setup just like the one that Lockwood sells. It worked great except for one thing. The fuel valves used in the setup to dampen the pulses in engine vacuum were just too coarse in adjustment. Several times I accidentally closed the valve and didn't notice until I made a cable adjustment and got no change in gauge reading. Figuring I was going to be using these for the rest of my life, I sold the first set on eBay and went looking for better gauges and valves. I found everything at McMaster Carr. I bought 4" (my old eyes need all the help they can get and I don't have to worry about my glasses getting blown off in the prop blast) stainless steel case glycerin filled gauges, p/n 38605K3 and needle valves p/n 4995K13. Let me warn you before you look them up they're pricey. To make sure they were well protected I bought a nice case from Harbor Freight p/n 69318 to protect them. The needle valves give me precise control so I can adjust for about .2 in of wiggle in the needles. I set them once and I can't remember ever adjusting them again. Whatever you use in your vacuum gauge setup, two tips: Use at least 5 feet of line to connect them to the engine. That gives you plenty of room to keep the gauges out of the engine compartment and out of harm's way. Put a union connection in the at the engine end. Not all engines take the same size of hose to connect them to the intake manifold. The union allows you to change out the ends quickly so you don't have to waste time improvising if the owner is watching, or helping do the carb synch. Rick Girard - Trust those who seek, doubt those who find. ________________________________________________________________________________
Subject: Re: Low RPM on Takeoff???
Date: Aug 26, 2014
Latest update...no change or improvement. Still WOT on ground of 5100 max. - sent ignition modules back to Rotec in BC and received a 100% good/clean bill of health. - fixed intermittent ground through one "mag" switch - cleaned low time plugs - removed carbs and rubbers again, inspected up close under magnifying glass and replaced them. One carb seemed to be very slightly "wet" (seemed to be gas versus water condensation) around the o-ring on outlet side rubber boot when disassembled. No obvious cracks or flattened O-ring but new ones on order for replacement. Next step: carbs going out to experts for inspection while we try new carbs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=429423#429423 ________________________________________________________________________________
Subject: AN fuel line fittings
Date: Sep 04, 2014
Has any one gone to the trouble (and expense) of using AN fittings on their fuel or oil lines, i.e. used Aeroquip or Stratoflex fittings? How'd that work out for ya? -------- Frank McDonald Kitfox S7 912S, Sensenich Composite 3 Blade Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=430002#430002 ________________________________________________________________________________
Date: Sep 04, 2014
Subject: Re: AN fuel line fittings
Lots of people do, indeed possibly most out there. I used them throughout, my only question was whether to use aluminum of steel. I used steel and brass on fuel, and used steel on a couple of the oil lines; the rest aluminum. Hope it works, as I'm not quite flying yet. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. On 9/4/2014 3:00 PM, frank3 wrote: > > Has any one gone to the trouble (and expense) of using AN fittings on their fuel or oil lines, i.e. used Aeroquip or Stratoflex fittings? How'd that work out for ya? > > -------- > Frank McDonald > Kitfox S7 > 912S, Sensenich Composite 3 Blade > Acworth, GA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=430002#430002 > > ________________________________________________________________________________
Date: Sep 05, 2014
Hello Guy, One problem with brass is that it may corrode in such a way to block your small orifices- although I think that with fuel it would be ok. The reason for this is that brass will corrode in the presence of water (as do other metals, but I have noticed that brass will do that in a pain in the arse way in particular situations). Because you are using brass in your fuel lines it shouldn't be a problem- except where you have small orifices. But it looks as if you have that figured out. Johannesburg Jay ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ HH Enterprises * Aircraft assembly, repair, wiring and avionics * Flight instruction * General and Electrical Engineering services (NHD Elec Eng, BTech Elec Eng, GDE ELec Eng) * Great dinner parties and conversation * General adventuring, climbing, kayaking and living Blog: <http://www.rawhyde.wordpress.com/> www.rawhyde.wordpress.com Cel: 083 300 8675 Email: jay(at)horriblehyde.com ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Guy Buchanan Sent: 05 September 2014 02:45 AM Subject: Re: RotaxEngines-List: AN fuel line fittings Lots of people do, indeed possibly most out there. I used them throughout, my only question was whether to use aluminum of steel. I used steel and brass on fuel, and used steel on a couple of the oil lines; the rest aluminum. Hope it works, as I'm not quite flying yet. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. On 9/4/2014 3:00 PM, frank3 wrote: Has any one gone to the trouble (and expense) of using AN fittings on their fuel or oil lines, i.e. used Aeroquip or Stratoflex fittings? How'd that work out for ya? -------- Frank McDonald Kitfox S7 912S, Sensenich Composite 3 Blade Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=430002#430002 ________________________________________________________________________________
Date: Sep 05, 2014
From: Don Maxwell <DonMaxwell(at)abstractconcreteworks.com>
Subject: Bad Carburetor Floats
Has anyone heard recently of new Rotax four-stroke engines with faulty carburetor floats? I'm curious because I know of three brand new engines--one 912ULS, two 914UL--that have had multiple floats fill with gasoline and sink within the first 50 hours of operation in new airplanes. Each of these engines has had at least two bad floats and one had 3 of 4. I don't know the engine serial numbers, but all three engines are on brand new, factory-fresh S-LSA Seareys, all produced within a few weeks of each other. The sunken floats caused flooding in all three engines--so severe that the engine wouldn't run at low throttle settings and soon the 914s wouldn't run at all with either fuel pump on. One owner had to make an emergency landing by turning the fuel pumps off until the engine stumbled and then switching one on just long enough to get it running again. One of the 914s had fuel staining in an air box drain hose. Fuel was discovered running from the 912 carburetor vent while burping the engine during preflight. Lockwood is assisting the owners, and one hopes that by now Rotax has been informed. But The Question is: How many more bad floats are in service? ________________________________________________________________________________
Subject: Re: Bad Carburetor Floats
Date: Sep 05, 2014
I haven't heard of any sudden failed in floats on new planes. That said it is possible Bing got a bad batch. It is the outside coating on the float that seals the airy foam inside from the fuel. If the outside gets a hole then fuel can enter the inside of the float. The floats and carbs are made by Bing here in the US. I have seen sunken floats, but it isn't that common. I did just have a bad float on an RV12 with 60 hrs. Symptoms are fuel smell and fuel coming out the vent. If you suspect a bad float by a rough running engine and fuel venting then just pop the bowl off and look at the floats in the fuel. The pins that stick out the side of the float should be equal to the fuel level. If the float is bad that pin and float will be down under the fuel level. These are covered by warranty if you are still under your warranty. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=430059#430059 ________________________________________________________________________________
Date: Sep 05, 2014
Thankfully the brass parts are limited to 3/8" openings and I don't plan on running alcohol fuel, so it shouldn't be a problem. Guy On 9/5/2014 2:47 AM, Jay Hyde wrote: > > Hello Guy, > > One problem with brass is that it may corrode in such a way to block > your small orifices- although I think that with fuel it would be ok. > The reason for this is that brass will corrode in the presence of > water (as do other metals, but I have noticed that brass will do that > in a pain in the arse way in particular situations). Because you are > using brass in your fuel lines it shouldnt be a problem- except where > you have small orifices. > > But it looks as if you have that figured out > > Johannesburg Jay > > ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ > > *HH Enterprises *** > > * Aircraft assembly, repair, wiring and avionics > * Flight instruction > * General and Electrical Engineering services > > (NHD Elec Eng, BTech Elec Eng, GDE ELec Eng) > > * Great dinner parties and conversation > * General adventuring, climbing, kayaking and living > > Blog: www.rawhyde.wordpress.com <http://www.rawhyde.wordpress.com/> > > Cel: 083 300 8675 > > Email: jay(at)horriblehyde.com > > ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ > > *From:*owner-rotaxengines-list-server(at)matronics.com > [mailto:owner-rotaxengines-list-server(at)matronics.com] *On Behalf Of > *Guy Buchanan > *Sent:* 05 September 2014 02:45 AM > *To:* rotaxengines-list(at)matronics.com > *Subject:* Re: RotaxEngines-List: AN fuel line fittings > > Lots of people do, indeed possibly most out there. I used them > throughout, my only question was whether to use aluminum of steel. I > used steel and brass on fuel, and used steel on a couple of the oil > lines; the rest aluminum. Hope it works, as I'm not quite flying yet. > > Guy Buchanan > Ramona, CA > Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded > Now a glider pilot, too. > > > On 9/4/2014 3:00 PM, frank3 wrote: > > > > > Has any one gone to the trouble (and expense) of using AN fittings on their fuel or oil lines, i.e. used Aeroquip or Stratoflex fittings? How'd that work out for ya? > > > > -------- > > Frank McDonald > > Kitfox S7 > > 912S, Sensenich Composite 3 Blade > > Acworth, GA > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=430002#430002 > > > > > > > > > > > > > > > > > > > > > > > > * * > * * > http://www.matronics.com/Navigator?RotaxEngines-List > http://forums.matronics.com > http://www.matronics.com/contribution > * * > * > > > * ________________________________________________________________________________
Date: Sep 05, 2014
Sounds like having one or two in the repair kit might not be a bad idea. Speaking of which, what 912 spares do you guys generally carry? I was thinking: * Float * Needle * Fuel filter * Spark plug(s) * 1 qt. oil Can't think of anything else. Carb boot? Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. On 9/5/2014 7:08 AM, Don Maxwell wrote: > Has anyone heard recently of new Rotax four-stroke engines with faulty > carburetor floats? > > I'm curious because I know of three brand new engines--one 912ULS, two > 914UL--that have had multiple floats fill with gasoline and sink > within the first 50 hours of operation in new airplanes. Each of these > engines has had at least two bad floats and one had 3 of 4. I don't > know the engine serial numbers, but all three engines are on brand > new, factory-fresh S-LSA Seareys, all produced within a few weeks of > each other. > > The sunken floats caused flooding in all three engines--so severe that > the engine wouldn't run at low throttle settings and soon the 914s > wouldn't run at all with either fuel pump on. One owner had to make > an emergency landing by turning the fuel pumps off until the engine > stumbled and then switching one on just long enough to get it running > again. > > One of the 914s had fuel staining in an air box drain hose. Fuel was > discovered running from the 912 carburetor vent while burping the > engine during preflight. > > Lockwood is assisting the owners, and one hopes that by now Rotax has > been informed. > > But The Question is: How many more bad floats are in service? > > * > > > * ________________________________________________________________________________
Date: Sep 05, 2014
With a Rotax you could go all the way to Alaska and back without using any oil. There is virtually no oil consumption on the road tax per Lockwood at Oshkosh. On Sep 5, 2014 1:50 PM, "Guy Buchanan" wrote: > Sounds like having one or two in the repair kit might not be a bad idea. > Speaking of which, what 912 spares do you guys generally carry? I was > thinking: > > - Float > - Needle > - Fuel filter > - Spark plug(s) > - 1 qt. oil > > Can't think of anything else. Carb boot? > Guy Buchanan > Ramona, CA > Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded > Now a glider pilot, too. > > On 9/5/2014 7:08 AM, Don Maxwell wrote: > > Has anyone heard recently of new Rotax four-stroke engines with faulty > carburetor floats? > > I'm curious because I know of three brand new engines--one 912ULS, two > 914UL--that have had multiple floats fill with gasoline and sink within the > first 50 hours of operation in new airplanes. Each of these engines has had > at least two bad floats and one had 3 of 4. I don't know the engine serial > numbers, but all three engines are on brand new, factory-fresh S-LSA > Seareys, all produced within a few weeks of each other. > > The sunken floats caused flooding in all three engines--so severe that the > engine wouldn't run at low throttle settings and soon the 914s wouldn't run > at all with either fuel pump on. One owner had to make an emergency > landing by turning the fuel pumps off until the engine stumbled and then > switching one on just long enough to get it running again. > > One of the 914s had fuel staining in an air box drain hose. Fuel was > discovered running from the 912 carburetor vent while burping the engine > during preflight. > > Lockwood is assisting the owners, and one hopes that by now Rotax has been > informed. > > But The Question is: How many more bad floats are in service? > > > * > > > * > > ________________________________________________________________________________
Date: Sep 05, 2014
Hi Jay & Gaggle: Brass does not corrode. It can oxidize the same as aluminum, forming Brass Oxide. As for small orifices - There should NOT be any small orifices in a fuel system. There is a simple and basic requirement that the fuel line have a diameter large enough to supply twice the full power hourly fuel flow of the engine under a gravity feed system. Now, there are BRASS nozzles used on many Lycoming & Continental engines for the Primer Lines which are quite small. In the range of 0.060" Diameter. So, once again orifice size in not an issue. MANY carburetors use brass nozzles and valve seats internally - So, once again orifice size in not an issue. Sorry Jay, your information is not correct. Barry On Fri, Sep 5, 2014 at 5:47 AM, Jay Hyde wrote: > Hello Guy, > > One problem with brass is that it may corrode in such a way to block your > small orifices- although I think that with fuel it would be ok. The reason > for this is that brass will corrode in the presence of water (as do other > metals, but I have noticed that brass will do that in a pain in the arse > way in particular situations). Because you are using brass in your fuel > lines it shouldn't be a problem- except where you have small orifices. > > But it looks as if you have that figured out... > > Johannesburg Jay > > ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ > > *HH Enterprises * > > - Aircraft assembly, repair, wiring and avionics > - Flight instruction > - General and Electrical Engineering services > > (NHD Elec Eng, BTech Elec Eng, GDE ELec Eng) > > - Great dinner parties and conversation > - General adventuring, climbing, kayaking and living > > > Blog: www.rawhyde.wordpress.com > > Cel: 083 300 8675 > > Email: jay(at)horriblehyde.com > > ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ > > > *From:* owner-rotaxengines-list-server(at)matronics.com [mailto: > owner-rotaxengines-list-server(at)matronics.com] *On Behalf Of *Guy Buchanan > *Sent:* 05 September 2014 02:45 AM > *To:* rotaxengines-list(at)matronics.com > *Subject:* Re: RotaxEngines-List: AN fuel line fittings > > > Lots of people do, indeed possibly most out there. I used them throughout, > my only question was whether to use aluminum of steel. I used steel and > brass on fuel, and used steel on a couple of the oil lines; the rest > aluminum. Hope it works, as I'm not quite flying yet. > > Guy Buchanan > Ramona, CA > Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded > Now a glider pilot, too. > > > On 9/4/2014 3:00 PM, frank3 wrote: > > > Has any one gone to the trouble (and expense) of using AN fittings on their fuel or oil lines, i.e. used Aeroquip or Stratoflex fittings? How'd that work out for ya? > > > -------- > > Frank McDonald > > Kitfox S7 > > 912S, Sensenich Composite 3 Blade > > Acworth, GA > > > Read this topic online here: > > > http://forums.matronics.com/viewtopic.php?p=430002#430002 > > > http://www.matronics.com/Navigator?RotaxEngines-List > > http://forums.matronics.com > > http://www.matronics.com/contribution > > > * > > > * > > ________________________________________________________________________________
Date: Sep 05, 2014
I think I agree on the corrosion, unless it's electrolytic. As to the orifices, there is one in the stock return line. Not sure what size it is, but it is pretty small, certainly smaller than .06". Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. On 9/5/2014 11:59 AM, FLYaDIVE wrote: > Hi Jay & Gaggle: > > Brass does not corrode. It can oxidize the same as aluminum, forming > Brass Oxide. As for small orifices - There should NOT be any small > orifices in a fuel system. There is a simple and basic requirement > that the fuel line have a diameter large enough to supply twice the > full power hourly fuel flow of the engine under a gravity feed system. > Now, there are BRASS nozzles used on many Lycoming & Continental > engines for the Primer Lines which are quite small. In the range of > 0.060" Diameter. So, once again orifice size in not an issue. MANY > carburetors use brass nozzles and valve seats internally - So, once > again orifice size in not an issue. > Sorry Jay, your information is not correct. > > Barry > > > On Fri, Sep 5, 2014 at 5:47 AM, Jay Hyde > wrote: > > Hello Guy, > > One problem with brass is that it may corrode in such a way to > block your small orifices- although I think that with fuel it > would be ok. The reason for this is that brass will corrode in > the presence of water (as do other metals, but I have noticed that > brass will do that in a pain in the arse way in particular > situations). Because you are using brass in your fuel lines it > shouldnt be a problem- except where you have small orifices. > > But it looks as if you have that figured out > > Johannesburg Jay > > ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ > > *HH Enterprises *** > > * Aircraft assembly, repair, wiring and avionics > * Flight instruction > * General and Electrical Engineering services > > (NHD Elec Eng, BTech Elec Eng, GDE ELec Eng) > > * Great dinner parties and conversation > * General adventuring, climbing, kayaking and living > > Blog: www.rawhyde.wordpress.com <http://www.rawhyde.wordpress.com/> > > Cel: 083 300 8675 > > Email: jay(at)horriblehyde.com > > ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ > > *From:*owner-rotaxengines-list-server(at)matronics.com > > [mailto:owner-rotaxengines-list-server(at)matronics.com > ] *On Behalf > Of *Guy Buchanan > *Sent:* 05 September 2014 02:45 AM > *To:* rotaxengines-list(at)matronics.com > > *Subject:* Re: RotaxEngines-List: AN fuel line fittings > > Lots of people do, indeed possibly most out there. I used them > throughout, my only question was whether to use aluminum of steel. > I used steel and brass on fuel, and used steel on a couple of the > oil lines; the rest aluminum. Hope it works, as I'm not quite > flying yet. > > Guy Buchanan > Ramona, CA > Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded > Now a glider pilot, too. > > > On 9/4/2014 3:00 PM, frank3 wrote: > > > > > Has any one gone to the trouble (and expense) of using AN fittings on their fuel or oil lines, i.e. used Aeroquip or Stratoflex fittings? How'd that work out for ya? > > > > -------- > > Frank McDonald > > Kitfox S7 > > 912S, Sensenich Composite 3 Blade > > Acworth, GA > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=430002#430002 > > > > > > > > > > > > > > > > > > > > > > > > * * > > * * > > http://www.matronics.com/Navigator?RotaxEngines-List > > http://forums.matronics.com > > http://www.matronics.com/contribution > > * * > > * > > ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > * > > > * ________________________________________________________________________________
Date: Sep 05, 2014
Guy: You cannot agree to the corrosion as it is nonexistent. Did you read my post? Just in case you missed it:- Hi Jay & Gaggle: Brass does not corrode. It can oxidize the same as aluminum, forming Brass Oxide. As for small orifices - There should NOT be any small orifices in a fuel system. There is a simple and basic requirement that the fuel line have a diameter large enough to supply twice the full power hourly fuel flow of the engine under a gravity feed system. Now, there are BRASS nozzles used on many Lycoming & Continental engines for the Primer Lines which are quite small. In the range of 0.060" Diameter. So, once again orifice size in not an issue. MANY carburetors use brass nozzles and valve seats internally - So, once again orifice size in not an issue. Sorry Jay, your information is not correct. Barry ======================== And if you wonder what my qualifications are for making my statements, I was a QA Manager and Technical Sales Engineer for a metal coatings company for 8 years and a QA Test Engineer for 20+ working years of my life. Add to that the little fact about brass being used in carbs for decades you will realize Jay in incorrect. Barry On Fri, Sep 5, 2014 at 7:15 PM, Guy Buchanan wrote: > I think I agree on the corrosion, unless it's electrolytic. As to the > orifices, there is one in the stock return line. Not sure what size it is, > but it is pretty small, certainly smaller than .06". > > Guy Buchanan > Ramona, CA > Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded > Now a glider pilot, too. > > > On 9/5/2014 11:59 AM, FLYaDIVE wrote: > > Hi Jay & Gaggle: > > Brass does not corrode. It can oxidize the same as aluminum, forming > Brass Oxide. As for small orifices - There should NOT be any small > orifices in a fuel system. There is a simple and basic requirement that > the fuel line have a diameter large enough to supply twice the full power > hourly fuel flow of the engine under a gravity feed system. Now, there are > BRASS nozzles used on many Lycoming & Continental engines for the Primer > Lines which are quite small. In the range of 0.060" Diameter. So, once > again orifice size in not an issue. MANY carburetors use brass nozzles and > valve seats internally - So, once again orifice size in not an issue. > Sorry Jay, your information is not correct. > > Barry > > > On Fri, Sep 5, 2014 at 5:47 AM, Jay Hyde wrote: > >> Hello Guy, >> >> One problem with brass is that it may corrode in such a way to block your >> small orifices- although I think that with fuel it would be ok. The reason >> for this is that brass will corrode in the presence of water (as do other >> metals, but I have noticed that brass will do that in a pain in the arse >> way in particular situations). Because you are using brass in your fuel >> lines it shouldn't be a problem- except where you have small orifices. >> >> But it looks as if you have that figured out... >> >> Johannesburg Jay >> >> ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ >> >> *HH Enterprises * >> >> - Aircraft assembly, repair, wiring and avionics >> - Flight instruction >> - General and Electrical Engineering services >> >> (NHD Elec Eng, BTech Elec Eng, GDE ELec Eng) >> >> - Great dinner parties and conversation >> - General adventuring, climbing, kayaking and living >> >> >> >> Blog: www.rawhyde.wordpress.com >> >> Cel: 083 300 8675 >> >> Email: jay(at)horriblehyde.com >> >> ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ >> >> >> >> *From:* owner-rotaxengines-list-server(at)matronics.com [mailto: >> owner-rotaxengines-list-server(at)matronics.com] *On Behalf Of *Guy Buchanan >> *Sent:* 05 September 2014 02:45 AM >> *To:* rotaxengines-list(at)matronics.com >> *Subject:* Re: RotaxEngines-List: AN fuel line fittings >> >> >> >> Lots of people do, indeed possibly most out there. I used them >> throughout, my only question was whether to use aluminum of steel. I used >> steel and brass on fuel, and used steel on a couple of the oil lines; the >> rest aluminum. Hope it works, as I'm not quite flying yet. >> >> Guy Buchanan >> Ramona, CA >> Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded >> Now a glider pilot, too. >> >> >> >> On 9/4/2014 3:00 PM, frank3 wrote: >> >> >> >> >> Has any one gone to the trouble (and expense) of using AN fittings on their fuel or oil lines, i.e. used Aeroquip or Stratoflex fittings? How'd that work out for ya? >> >> >> >> -------- >> >> Frank McDonald >> >> Kitfox S7 >> >> 912S, Sensenich Composite 3 Blade >> >> Acworth, GA >> >> >> >> >> >> >> >> >> >> Read this topic online here: >> >> >> >> http://forums.matronics.com/viewtopic.php?p=430002#430002 >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> http://www.matronics.com/Navigator?RotaxEngines-List >> >> http://forums.matronics.com >> >> http://www.matronics.com/contribution >> >> >> >> * >> >> ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > > > * > > > * > > ________________________________________________________________________________
Date: Sep 05, 2014
If you look at the shear numbers of Rotax engines with Bing carbs on them then any failure rate is very minuscule. They tend to hold up well for long periods. I don't know of a single person that carries carb parts as spares. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=430088#430088 ________________________________________________________________________________
Date: Sep 05, 2014
20 years ago I flew a 17,400.0 sm flight. I had a spare set of spark plugs for my 912 80 hp. In 1993, there was no 912UL or ULS. I had 100 hours on the oil when I got to North Pole, Alaska. Got the guys at Bradley Sky Ranch to run me down to NAPA to pick up two qts of Mobile I and a Fram PH3614. I dumped my spare qt of oil in the tank, and never carried any spare oil after that. That was 3,000.0 plus hours and three 912's ago. On that flight I flew 232.0 hours in 41 days. Averaged 8 hours per day for the 30 days I actually flew. The only engine problem I had was occasional spark plug lead fouling. When that happened, I would feel a periodic tapping in the airframe. Next landing, pull the plugs, take my pen knife, clean out the lead, put them back in and keep on flying. I was extremely impressed with the 912 on that flight, and every long flight since then. I did have a carb tuning problem that I encountered once I got up into BC where the temps dropped on me. Didn't know it at the time, nor did any of the Rotax experts from Eric Tucker right on down, what to do with me as I sat weathered-in at Deadhorse, AK. Only on my return to Alabama, where I had no fear of losing a carb part if I should be so club fisted, did I finally solve my problem. On a flight down to Ronnie Smith's in Lucedale, MS, I was flying with some slower ULs. Flying at about 4,200 rpm there was a really rough spot. I don't know why, but I pulled on the enricher. The engine picked up 200 rpm. Push off the enricher, the engine lost 200 rpm and ran a rough again. When I landed I raised the fuel needles one notch. That fixed my problem, a midrange, very lean condition. Never had that problem with my 912ULS's. They have run great, right out of the box, hot or cold weather. Getting ready to fly from Alabama to my friends at the Rock House, near Burns Junction, Oregon. Plan to depart first light Sunday morning, if I can get up and get going that early. Route of flight is Sherman, TX, Clovis, NM, Los Lunas, NM, Gallup, NM, Monument Valley, UT, Bryce Canyon, UT, Ely, NV, Owyhee, NV, and finally the Rock House, OR. We are having our annual/semi-annual Kolb (and any other airplane) Flyin. A bunch of us have been getting together since 2003 when we had our first Monument Valley Kolb Unplanned/Unorganized Flyin. Plan to RON Sherman, Los Lunas, MV, and Elko. Give me a shout if you have time for a cup of coffee and I am in your neck of the woods. john hauck Kolb MKIII Titus, Alabama 334-315-2621 If you look at the shear numbers of Rotax engines with Bing carbs on them then any failure rate is very minuscule. They tend to hold up well for long periods. I don't know of a single person that carries carb parts as spares. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=430088#430088 ________________________________________________________________________________
Date: Sep 06, 2014
There are lots of small orifices in fuel systems. That's how carbs work. (supplying fuel through small orifices). The standard Rotax fuel return system uses a fuel return through a small orifice. Regards Brian Davies From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of FLYaDIVE Sent: 06 September 2014 00:41 Subject: Re: RotaxEngines-List: AN fuel line fittings Guy: You cannot agree to the corrosion as it is nonexistent. Did you read my post? Just in case you missed it:- Hi Jay & Gaggle: Brass does not corrode. It can oxidize the same as aluminum, forming Brass Oxide. As for small orifices - There should NOT be any small orifices in a fuel system. There is a simple and basic requirement that the fuel line have a diameter large enough to supply twice the full power hourly fuel flow of the engine under a gravity feed system. Now, there are BRASS nozzles used on many Lycoming & Continental engines for the Primer Lines which are quite small. In the range of 0.060" Diameter. So, once again orifice size in not an issue. MANY carburetors use brass nozzles and valve seats internally - So, once again orifice size in not an issue. Sorry Jay, your information is not correct. Barry ======================== And if you wonder what my qualifications are for making my statements, I was a QA Manager and Technical Sales Engineer for a metal coatings company for 8 years and a QA Test Engineer for 20+ working years of my life. Add to that the little fact about brass being used in carbs for decades you will realize Jay in incorrect. Barry On Fri, Sep 5, 2014 at 7:15 PM, Guy Buchanan wrote: I think I agree on the corrosion, unless it's electrolytic. As to the orifices, there is one in the stock return line. Not sure what size it is, but it is pretty small, certainly smaller than .06". Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. On 9/5/2014 11:59 AM, FLYaDIVE wrote: Hi Jay & Gaggle: Brass does not corrode. It can oxidize the same as aluminum, forming Brass Oxide. As for small orifices - There should NOT be any small orifices in a fuel system. There is a simple and basic requirement that the fuel line have a diameter large enough to supply twice the full power hourly fuel flow of the engine under a gravity feed system. Now, there are BRASS nozzles used on many Lycoming & Continental engines for the Primer Lines which are quite small. In the range of 0.060" Diameter. So, once again orifice size in not an issue. MANY carburetors use brass nozzles and valve seats internally - So, once again orifice size in not an issue. Sorry Jay, your information is not correct. Barry On Fri, Sep 5, 2014 at 5:47 AM, Jay Hyde wrote: Hello Guy, One problem with brass is that it may corrode in such a way to block your small orifices- although I think that with fuel it would be ok. The reason for this is that brass will corrode in the presence of water (as do other metals, but I have noticed that brass will do that in a pain in the arse way in particular situations). Because you are using brass in your fuel lines it shouldn't be a problem- except where you have small orifices. But it looks as if you have that figured out. Johannesburg Jay ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ HH Enterprises * Aircraft assembly, repair, wiring and avionics * Flight instruction * General and Electrical Engineering services (NHD Elec Eng, BTech Elec Eng, GDE ELec Eng) * Great dinner parties and conversation * General adventuring, climbing, kayaking and living Blog: www.rawhyde.wordpress.com <http://www.rawhyde.wordpress.com/> Cel: 083 300 8675 Email: jay(at)horriblehyde.com ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Guy Buchanan Sent: 05 September 2014 02:45 AM Subject: Re: RotaxEngines-List: AN fuel line fittings Lots of people do, indeed possibly most out there. I used them throughout, my only question was whether to use aluminum of steel. I used steel and brass on fuel, and used steel on a couple of the oil lines; the rest aluminum. Hope it works, as I'm not quite flying yet. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. On 9/4/2014 3:00 PM, frank3 wrote: Has any one gone to the trouble (and expense) of using AN fittings on their fuel or oil lines, i.e. used Aeroquip or Stratoflex fittings? How'd that work out for ya? -------- Frank McDonald Kitfox S7 912S, Sensenich Composite 3 Blade Acworth, GA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=430002#430002 http://www.matronics.com/Navigator?RotaxEngines-List http://forums.matronics.com http://www.matronics.com/contribution ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
From: "Katherine Martin" <dm3since1946(at)blomand.net>
Subject: Re: RotaxEngines-List Digest: 0 Msgs - 09/16/14
Date: Sep 17, 2014
RotaxEngines-List Digest Server wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RotaxEngines-List Digest can also be found in >either of the > two Web Links listed below. The .html file includes the Digest >formatted > in HTML for viewing with a web browser and features Hyperlinked >Indexes > and Message Navigation. The .txt file includes the plain ASCII >version > of the RotaxEngines-List Digest and can be viewed with a generic >text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 14-09-16&Archive=RotaxEngines > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 14-09-16&Archive=RotaxEngines > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RotaxEngines-List Digest Archive > --- > Total Messages Posted Tue 09/16/14: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > > > ________________________________________________________________________________
Subject: 912 Gearbox Sealant Loctite 5910 and 574
Date: Sep 26, 2014
I need to seal the mating surfaces of the gearbox on my Rotax 912 UL upon reassembly after a 700 hour disassemble and inspection. I am having a real difficulty in finding the Rotax recommended Loctite 5910 in small quantities for this. When I can find it, it is in tubes costing $50 (US) per tube. I only need a very small quantity. Upon researching the product I find it is an Oximine Silicone, thixotropic, oil resistant, RTV paste. I can find Permatex Ultra Black at my local auto store which is basically the same (an Oximine Silicone, thixotropic, oil resistant, RTV paste). The cured properties of both appear to be the same. Why must a Loctite product be used? Are there other equal products that can be used? What are other mechanics using for this? Gearbox is back and ready to be reinstalled. Hugh G. McKay III, P.E. Allegro 2000 Rotax 912 UL 700 hours N661WW Ph. 704-661-8271 email hgmckay(at)bellsouth.net ________________________________________________________________________________
Date: Sep 27, 2014
Subject: Re: 912 Gearbox Sealant Loctite 5910 and 574
My last 912ULS has had a leaky gearbox seal since shortly after I bought it. Tried Loctite 5910, when Rotax changed to this sealant, but it still leaked a little. Finally, found Permatex "The Right Stuff". It works. Cleaned the mating surfaces with MEK. Made sure no oil was leaking from engine to contaminate the sealing surfaces. I also used The Right Stuff to seal the intake and exhaust push rod covers where they entered the No. 1 cylinder head. Got the idea from someone who had a leaky cover and did the same thing. Cleaned the joints with brake cleaner. Thoroughly dried. Applied The Right Stuff in the joints, rubbed it in with my finger. Let it dry for 24 hours. Hasn't leaked since, push rod covers or gear box. I am currently finishing up a 3 week flight from Alabama to Monument Valley, UT, and up to friends in the SE corner of Oregon. Currently in El Dorado,KS. Another two days to fly back to my home in Titus, AL. I have flown about 60.0 hours this trip and the engine is oil free. Sure is a good feeling to land, check the engine, and not see oil seepage. You all may be interested to know I flew direct from Morgan, UT to Rock Springs, WY, to Fort Collins/Loveland Airport, CO. This is my 22d transcontinental flight since 2003 in this airplane. First time I have been able to fly direct over the Rockies in this area. The weather was perfect. Had some turbulence, but bad. Climbed and cruised 15,000 feet MSL to clear the mountains. The 912ULS did good. john h Kolb MKIII El Dorado, KS ---- Hugh McKay wrote: > I need to seal the mating surfaces of the gearbox on my Rotax 912 UL upon reassembly after a 700 hour disassemble and inspection. I am having a real difficulty in finding the Rotax recommended Loctite 5910 in small quantities for this. When I can find it, it is in tubes costing $50 (US) per tube. I only need a very small quantity. Upon researching the product I find it is an Oximine Silicone, thixotropic, oil resistant, RTV paste. I can find Permatex Ultra Black at my local auto store which is basically the same (an Oximine Silicone, thixotropic, oil resistant, RTV paste). The cured properties of both appear to be the same. > > Why must a Loctite product be used? Are there other equal products that can be used? What are other mechanics using for this? Gearbox is back and ready to be reinstalled. > > Hugh G. McKay III, P.E. > Allegro 2000 > Rotax 912 UL > 700 hours > N661WW > Ph. 704-661-8271 > email hgmckay(at)bellsouth.net ________________________________________________________________________________
Date: Sep 27, 2014
Sorry for the omission. I flew 6.0 hours today in Kansas wind, right on the nose. I am worn out. I am three days out of SE Oregon. The turbulence over the Rockies was not bad. Weather at Rock Springs, WY, was perfect. Never seen anything but wind, rain, and cold at Rock Springs. Had a good idea I could make it over the mountains direct. john h > You all may be interested to know I flew direct from Morgan, UT to Rock Springs, WY, to Fort Collins/Loveland Airport, CO. This is my 22d transcontinental flight since 2003 in this airplane. First time I have been able to fly direct over the Rockies in this area. The weather was perfect. Had some turbulence, but "NOT" bad. Climbed and cruised 15,000 feet MSL to clear the mountains. The 912ULS did good. > > john h > Kolb MKIII > El Dorado, KS > > > > ---- Hugh McKay wrote: > > I need to seal the mating surfaces of the gearbox on my Rotax 912 UL upon reassembly after a 700 hour disassemble and inspection. I am having a real difficulty in finding the Rotax recommended Loctite 5910 in small quantities for this. When I can find it, it is in tubes costing $50 (US) per tube. I only need a very small quantity. Upon researching the product I find it is an Oximine Silicone, thixotropic, oil resistant, RTV paste. I can find Permatex Ultra Black at my local auto store which is basically the same (an Oximine Silicone, thixotropic, oil resistant, RTV paste). The cured properties of both appear to be the same. > > > > Why must a Loctite product be used? Are there other equal products that can be used? What are other mechanics using for this? Gearbox is back and ready to be reinstalled. > > > > Hugh G. McKay III, P.E. > > Allegro 2000 > > Rotax 912 UL > > 700 hours > > N661WW > > Ph. 704-661-8271 > > email hgmckay(at)bellsouth.net > > > > > ________________________________________________________________________________
Date: Sep 27, 2014
You all may be interested to know I flew direct from Morgan, UT to Rock Springs, WY, to Fort Collins/Loveland Airport, CO. This is my 22d transcontinental flight since 2003 in this airplane. First time I have been able to fly direct over the Rockies in this area. The weather was perfect. Had some turbulence, but bad. Climbed and cruised 15,000 feet MSL to clear the mountains. The 912ULS did good. john h Kolb MKIII El Dorado, KS Wow John congratulations! If you ever come by Santa Fe, NM, get in touch, I'd love to meet up. I'll be moving there next week. Unfortunately the Kitfox will be staying here in Italy, I'll have to see what I can get my hands on when I'm there. Sacha Kitfox 4, Tri-gear, 912UL Italy ________________________________________________________________________________
Date: Sep 28, 2014
Loctite 5910 is the European equivalent of our Loctite 598. Use loctite 598 to seal the gearbox. Loctite 574 is not used any more. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=431213#431213 ________________________________________________________________________________
Subject: Mechanical Fuel Pump gasket
Date: Oct 06, 2014
I have just had my Rotax 912 UL Gearbox off and inspected after 700 hours. I am ready to reinstall it, and need to know if it is necessary to replace the existing mechanical fuel pump/gearbox gasket. The original gasket is in perfect condition. Advice and counsel would be appreciated. Hugh G. McKay III, P.E. Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com ________________________________________________________________________________
Subject: Re: Mechanical Fuel Pump gasket
Date: Oct 06, 2014
If it wasn't leaking to start with you can re-use it. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=431594#431594 ________________________________________________________________________________
Date: Oct 07, 2014
If it ain't broke don't fix it! But then again you went this far - Why not! But then again it is a Rotax. I want a CH601 so bad, just not with a Rotax... O-200 or O-235. On Mon, Oct 6, 2014 at 5:21 PM, Hugh McKay wrote: > I have just had my Rotax 912 UL Gearbox off and inspected after 700 > hours. I am ready to reinstall it, and need to know if it is necessary to > replace the existing mechanical fuel pump/gearbox gasket. The original > gasket is in perfect condition. Advice and counsel would be appreciated. > > Hugh G. McKay III, P.E. > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > Ph. 704-661-8271 > Fax 704-483-5466 > email hgmckay(at)bellsouth.net > http://www.wwegeo.com > ________________________________________________________________________________
Date: Nov 01, 2014
Subject: PLEASE READ - Matronics Email List Fund Raiser During
November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 30 different gifts to choose from - more than we've ever had before! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Corbin Glowacki of My Pilot Store http://www.mypilotstore.com George Race of Race Consulting http://www.mrrace.com/ Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product line. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 03, 2014
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 05, 2014
Subject: Coming Soon - The List of Contributors - Please Make
A Contribution Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2014
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 10, 2014
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 12, 2014
Subject: Make Sure You're Listed! List of Contributors Published
in December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Understanding generator / alternator disconnect requirement
Date: Nov 12, 2014
The wiring diagram in the Rotax 914 installation manual shows the R,B+,L and C wires from the integrated generator's regulator-rectifier are all disconnected, via relay 58 when the master is turned off. For the external alternator it shows the B+ as being connected directly to the battery, while the IG (and L) wires are disconnected when the master is turned off. The text notes that the integrated generator's regulator-rectifier must be disconnected to avoid running the battery down. The text does not mention any such requirement for the external alternator. Neither the text nor the diagram say whether or not relay 58 is supplied by Rotax with the engine. All this raises the following questions for this neophyte: 1. Is relay 58 included with the engine? 2. Does the external alternator need to be disconnected to avoid drawing down the battery? 3. What do the indicator lamps for each of the charging devices actually indicate? 4. Are the indicator lamps considered optional? 5. If installed, can the indicator lamps be LEDs? 6. Are the L and IG wires on the external alternator only for lighting the indicator lamp or do they serve some additional purpose? I know it's a lot of questions, but none of them seem to be answered in any of the Rotax documentation. Ken Read this topic online here: http://forums.matronics.com/viewtopic.php?p=433525#433525 ________________________________________________________________________________
Subject: Re: Understanding generator / alternator disconnect
requirement
Date: Nov 13, 2014
Hi Ken Welcome to the Rotax forum. The other really good places to get Rotax information are Rotax-Owner.com (Rob is very knowledgeable on 914) and of course the factory website, Rotax-aircraft-engines.com. I'll try to help you with your questions. Relay 58 is not included with the engine. You can get suitable relays from B&C Specialty or Stein Avionics or many other places. The external alternator is a conventional automotive style alternator and really doesn't need to disconnected. However, circuit breakers 43 and 45 will disconnect it and many prefer to start their engine with the alternator off line. Indicator lights 36 illuminate when their respective alternator is not operating. Funny I hadn't noticed they both have the same number 36! In an experimental aircraft you can do whatever you like. Probably you have other means of indicating the operation of the alternators such as voltmeters and or ammeters. But the lights don't add weight and do give you indication of what is happening. Yes, you can use LEDs. Be sure they have current limiting resistors. In both cases, the L lead is where the negative lead of the LED connects. I have a LED on my 914 (no external alternator). Others should answer about the external alternator, but I believe it is internally regulated which means the IG wire is used to sense system voltage which in turn is used by the regulator to control the alternator. I could be mistaken in this so check with others. The regulator 13 has proven to be temperature sensitive. Be sure you provide cooling air to it, mount it on a metal surface if possible and put a temperature indicating strip on it to be sure it stays below 80C. You should have the same strips on the ignition modules. I also drilled a small hole in the fin and connected the ground wire there rather than using one of the mounting bolts to get a more secure physical connection. Using LED lighting for position and strobes, you may not need the external alternator. In my Europa I have 914, two screen EFIS, GNS430 nav-com-gps, transponder, audio panel , xm weather and AeroLED lights. In cruise the built in alternator puts out less than 10 amps. AeroElectric Connection has a pretty good electrical system design, Z-16 for a Rotax. Hope this is helpful. Jim Butcher Read this topic online here: http://forums.matronics.com/viewtopic.php?p=433611#433611 ________________________________________________________________________________
Date: Nov 13, 2014
requirement Thanks Jim, definitely helpful. Do you have any experience with the hall effect current sensor available from GRT? Are they accurate? I will be monitoring bus voltages but that's not going to allow me to monitor both alternators and am thinking the hall effect sensors might be best bet. Agree about rotax-owner.com being superb. I am a paid subscriber. Ken On Thu, Nov 13, 2014 at 10:31 AM, h&jeuropa wrote: > butcher43(at)att.net> > > Hi Ken > > Welcome to the Rotax forum. The other really good places to get Rotax > information are Rotax-Owner.com (Rob is very knowledgeable on 914) and of > course the factory website, Rotax-aircraft-engines.com. > > I'll try to help you with your questions. > > Relay 58 is not included with the engine. You can get suitable relays > from B&C Specialty or Stein Avionics or many other places. > > The external alternator is a conventional automotive style alternator and > really doesn't need to disconnected. However, circuit breakers 43 and 45 > will disconnect it and many prefer to start their engine with the > alternator off line. > > Indicator lights 36 illuminate when their respective alternator is not > operating. Funny I hadn't noticed they both have the same number 36! > > In an experimental aircraft you can do whatever you like. Probably you > have other means of indicating the operation of the alternators such as > voltmeters and or ammeters. But the lights don't add weight and do give > you indication of what is happening. > > Yes, you can use LEDs. Be sure they have current limiting resistors. In > both cases, the L lead is where the negative lead of the LED connects. I > have a LED on my 914 (no external alternator). > > Others should answer about the external alternator, but I believe it is > internally regulated which means the IG wire is used to sense system > voltage which in turn is used by the regulator to control the alternator. > I could be mistaken in this so check with others. > > The regulator 13 has proven to be temperature sensitive. Be sure you > provide cooling air to it, mount it on a metal surface if possible and put > a temperature indicating strip on it to be sure it stays below 80C. You > should have the same strips on the ignition modules. I also drilled a small > hole in the fin and connected the ground wire there rather than using one > of the mounting bolts to get a more secure physical connection. > > Using LED lighting for position and strobes, you may not need the external > alternator. In my Europa I have 914, two screen EFIS, GNS430 nav-com-gps, > transponder, audio panel , xm weather and AeroLED lights. In cruise the > built in alternator puts out less than 10 amps. > > AeroElectric Connection has a pretty good electrical system design, Z-16 > for a Rotax. > > Hope this is helpful. > > Jim Butcher > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=433611#433611 > > ________________________________________________________________________________
requirement
Date: Nov 13, 2014
Ken, Yes Hall Effect current sensors are accurate and easy to install. I actually have two, one on the output of the alternator and one on the positive lead of the battery to monitor system performance. I use a switch to select which one is the input to my EIS. You can use the 50 amp sensor and run the wire thru twice to make it a 25 amp sensor. Also be aware that the bus voltage may not be what it says. If you have a GRT EIS, the voltage the EIS measures is it's input and is accurate. If it is being fed from a E Buss, there probably is a diode in the circuit which drops the voltage. Just compare what EIS reports and a voltmeter on your battery to see the difference. If you have a multiple input EFIS, there are probably diodes in it too. Again, compare to a voltmeter. Mine drop about .4 volts. BTW, just click "reply to post" to keep all the posts in one thread. Makes it easier when you look for this again in 5 years!! Jim Butcher Read this topic online here: http://forums.matronics.com/viewtopic.php?p=433623#433623 ________________________________________________________________________________
Date: Nov 13, 2014
requirement You completely lost me when you say to run the wire twice through the 50 amp to make it a 25 amp. Also, I do not see any link that says "Reply to Post" so I guess I'll just have to use the "Reply" button. Ken On Thu, Nov 13, 2014 at 12:25 PM, h&jeuropa wrote: > butcher43(at)att.net> > > Ken, > > Yes Hall Effect current sensors are accurate and easy to install. I > actually have two, one on the output of the alternator and one on the > positive lead of the battery to monitor system performance. I use a switch > to select which one is the input to my EIS. > > You can use the 50 amp sensor and run the wire thru twice to make it a 25 > amp sensor. > > Also be aware that the bus voltage may not be what it says. If you have a > GRT EIS, the voltage the EIS measures is it's input and is accurate. If it > is being fed from a E Buss, there probably is a diode in the circuit which > drops the voltage. Just compare what EIS reports and a voltmeter on your > battery to see the difference. If you have a multiple input EFIS, there > are probably diodes in it too. Again, compare to a voltmeter. Mine drop > about .4 volts. > > BTW, just click "reply to post" to keep all the posts in one thread. > Makes it easier when you look for this again in 5 years!! > > Jim Butcher > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=433623#433623 > > ________________________________________________________________________________
requirement
Date: Nov 13, 2014
Ken, As you did this time, just hit Post Reply. A Hall Effect sensor measures the magnetic field generated when current passes thru a wire. More current, stronger field. Notice that the sensor looks like a doughnut. It is the amount or strength of the magnetic field within the doughnut that is measured and is proportional to the current in the wire. The sensor outputs a voltage proportional to the amps. The amp rating of the sensor is how many amps are required for the sensor to output it's maximum voltage. If you put 75 amps thru a 50 amp sensor, it wont be damaged but it will not output a voltage that corresponds to 75 amps. So if you run the wire thru the doughnut twice, there is twice the field inside. The sensor says there is X amps. But since X is generated by the wire thru twice, the wire is actually carrying X2 amps. So a 50 amp sensor can be a 25 / 16.6 / 12.5 etc sensor. You might want to do this to get better resolution. Say you have a 50 amp sensor. That means it will output it's max voltage (5 volts for ones like the GRT) when there is 50 amps. But your alternator only is capable of 25 amps. So when the alternator is at 25 amps the sensor will output 2.5 volts. And 5 amps would be .5 volts. If you double the wire, those become 5 and 1 volts so you can see small changes easier. This help? Jim Read this topic online here: http://forums.matronics.com/viewtopic.php?p=433632#433632 ________________________________________________________________________________
Date: Nov 13, 2014
requirement
Yes I think I follow Thanks. On Nov 13, 2014 2:33 PM, "h&jeuropa" wrote: > butcher43(at)att.net> > > Ken, > > As you did this time, just hit Post Reply. > > A Hall Effect sensor measures the magnetic field generated when current > passes thru a wire. More current, stronger field. Notice that the sensor > looks like a doughnut. It is the amount or strength of the magnetic field > within the doughnut that is measured and is proportional to the current in > the wire. > > The sensor outputs a voltage proportional to the amps. The amp rating of > the sensor is how many amps are required for the sensor to output it's > maximum voltage. If you put 75 amps thru a 50 amp sensor, it wont be > damaged but it will not output a voltage that corresponds to 75 amps. > > So if you run the wire thru the doughnut twice, there is twice the field > inside. The sensor says there is X amps. But since X is generated by the > wire thru twice, the wire is actually carrying X2 amps. > > So a 50 amp sensor can be a 25 / 16.6 / 12.5 etc sensor. You might want > to do this to get better resolution. Say you have a 50 amp sensor. That > means it will output it's max voltage (5 volts for ones like the GRT) when > there is 50 amps. But your alternator only is capable of 25 amps. So when > the alternator is at 25 amps the sensor will output 2.5 volts. And 5 amps > would be .5 volts. If you double the wire, those become 5 and 1 volts so > you can see small changes easier. > > This help? > > Jim > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=433632#433632 > > ________________________________________________________________________________
Date: Nov 14, 2014
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 15, 2014
requirement
ROTAX.... Yea, one thread, you got that right... "You can use the 50 amp sensor and run the wire thru twice to make it a 25 amp sensor." Isn't that the other way around? On Thu, Nov 13, 2014 at 4:25 PM, h&jeuropa wrote: > butcher43(at)att.net> > > Ken, > > Yes Hall Effect current sensors are accurate and easy to install. I > actually have two, one on the output of the alternator and one on the > positive lead of the battery to monitor system performance. I use a switch > to select which one is the input to my EIS. > > You can use the 50 amp sensor and run the wire thru twice to make it a 25 > amp sensor. > > Also be aware that the bus voltage may not be what it says. If you have a > GRT EIS, the voltage the EIS measures is it's input and is accurate. If it > is being fed from a E Buss, there probably is a diode in the circuit which > drops the voltage. Just compare what EIS reports and a voltmeter on your > battery to see the difference. If you have a multiple input EFIS, there > are probably diodes in it too. Again, compare to a voltmeter. Mine drop > about .4 volts. > > BTW, just click "reply to post" to keep all the posts in one thread. > Makes it easier when you look for this again in 5 years!! > > Jim Butcher > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=433623#433623 > > ________________________________________________________________________________
Date: Nov 17, 2014
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some point, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 23 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 19, 2014
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 21, 2014
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that elk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 23, 2014
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 24, 2014
Subject: Fund Raiser Behind By 20% - Please Contribute Today!
Dear Listers, The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 20%. Please take this opportunity to show your support for the Matronics Lists and Forums! Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List and Forums Administrator ________________________________________________________________________________
Date: Nov 25, 2014
Subject: Make Sure You're Listed! List of Contributors Coming
Soon! Dear Listers, There's just a few more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 25, 2014
Subject: SB-912-065/914-046
Did the weight check per the Service Bulletin and found a heavy float. You can see the crack on the lower edge of the left hand float in the picture. Called both Lockwood and the Bing Agency to get the status of new float availability. None at this time, Rotax is working with Bing and Bing's float supplier to fix the problem. Fortunately, I saved the old floats when I rebuilt the carbs 18 months ago. Rick Girard Believe those who are seeking the truth, doubt those who find it. -Andre Gide ________________________________________________________________________________
Subject: Re: SB-912-065/914-046
Date: Nov 26, 2014
Shocking, that it is taking so long to sort out. Will Rotax replace them free of charge? Vernon From: Richard Girard Sent: Wednesday, November 26, 2014 4:31 AM Subject: RotaxEngines-List: SB-912-065/914-046 Did the weight check per the Service Bulletin and found a heavy float. You can see the crack on the lower edge of the left hand float in the picture. Called both Lockwood and the Bing Agency to get the status of new float availability. None at this time, Rotax is working with Bing and Bing's float supplier to fix the problem. Fortunately, I saved the old floats when I rebuilt the carbs 18 months ago. Rick Girard Believe those who are seeking the truth, doubt those who find it. -Andre Gide ________________________________________________________________________________
Date: Nov 26, 2014
Subject: Giving Thanks - Your List Contribution...
Dear Listers, Here in the United States, Thursday is our National day of Thanksgiving. Many of us will be traveling to be with our families and friends to share in generous feasts of plenty and giving thanks for the many blessings that have been bestowed upon us. Many Listers have expressed over the last couple of weeks how thankful they are for the Email Lists and Forums here on the Matronics servers and for all of the assistance and comradery they have experienced being a part of the Lists. One of my favorite comments is when someone writes to me and says something like, "Its the first thing I do in the morning while I'm having my morning coffee!". That's a wonderful tribute to the purpose and function of these Lists. Its always great to hear I'm not the only one that jumps out of bed each morning to check my List email!! Won't you take a minute today and show your appreciation for these Lists and for their continued operation and upgrade? The List Contribution Site is: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance for your kind consideration, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
From: "AmphibFlyer" <SeaRey(at)AbstractConcreteWorks.com>
Date: Nov 27, 2014
rickofudall wrote: > Did the weight check per the Service Bulletin and found a heavy float. You can see the crack on the lower edge of the left hand float in the picture. My 914 is 15 years old; but I replaced both carbs last year with new ones that I bought on Ebay. (The price was hardly more than the cost of a rebuuild kit.) Everything was fine for several months, but then I started smelling gasoline in turbulence, and occasionally the engine would flood after a flight and was hard to re-start. Sometimes the next day after flying I'd see that a bit of gasoline had run down the side of the pylon (it's a high-wing pusher SeaRey) and onto the turtledeck below. I worked around that by turning off the fuel pumps about 30 seconds before switching the engine off. That prevented flooding, but made me anxious, even though the engine ran just fine otherwise. Then three people I knew with brand new engines had similar but much worse problems. The engine would load up and sometime quit when idling. Then in flight at low throttle settings. One got so bad that the only way the pilot could keep the engine running in flight was to turn both fuel pumps OFF! When the engine would begin to stutter he'd flip on one pump for a few seconds. It was a scary situation for him, but he managed to reach an airport and land safely. Eventually Rotax issued the SB. And THEN I had a look at the serial numbers on my "new" carbs. Sure enough, they were in the range that Rotax cited. So a few days ago I took the floats out and weighed them: 3 g, 3 g, 3 g, 2.9 g--all within the acceptable range, but very close to Rotax's maximum pair weight of 7 g. Furthermore, 2 of the 4 floats were abraded and had chips worse than those in Rick's photo. They had been in service for about 200 hours. I replaced them with unused floats from a carb kit that I bought about 8 years ago. Those floats weighed only 0.5 g less than the faulty floats but they had no cracks or chips. I've flown the airplane about 5 hours since then without smelling gasoline in flight, and the engine doesn't flood, and there's no gas seeping out anywhere. So I'm calling it fixed, at least for now. Anyone with an engine or carbs in the worry range of serial numbers should take that SB VERY seriously! And if they notice any of the symptoms I've described, I'd urge them to stay on the ground until they can check the floats. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=434855#434855 ________________________________________________________________________________
Date: Nov 28, 2014
Vernon, When I called Lockwood tech support I was told the procedure is to order new floats and with them will come a warranty form. Fill out the form, send it in with the old floats and you get a refund. So, yes, it appears Rotax is supporting the S/B. Now all we need are new floats. Rick On Wed, Nov 26, 2014 at 7:11 AM, vernon mitchell wrote: > Shocking, that it is taking so long to sort out. Will Rotax replace them > free of charge? > Vernon > > *From:* Richard Girard > *Sent:* Wednesday, November 26, 2014 4:31 AM > *To:* rotaxengines-list(at)matronics.com > *Subject:* RotaxEngines-List: SB-912-065/914-046 > > Did the weight check per the Service Bulletin and found a heavy float. You > can see the crack on the lower edge of the left hand float in the picture. > Called both Lockwood and the Bing Agency to get the status of new float > availability. None at this time, Rotax is working with Bing and Bing's > float supplier to fix the problem. Fortunately, I saved the old floats when > I rebuilt the carbs 18 months ago. > > Rick Girard > > > Believe those who are seeking the truth, doubt those who find it. > -Andre Gide > > * > > > * > > -- Believe those who are seeking the truth, doubt those who find it. -Andre Gide ________________________________________________________________________________
Date: Nov 28, 2014
Subject: Just Two Days Left! - Still Behind...
Dear Listers, There are just two more days left in this years List Fund Raiser. We are still way behind last year in terms of the number of contributions and total contribution amount. I really want to keep providing these services to the homebuilt community, but it take resources. Since there's no advertising budget or deep pockets to keep the operation a float, its solely your generosity during the Fund Raiser that keeps things going. Please make a Contribution today. If you've been putting off showing your support for the Lists, now is the time to do it! Make a contribution with a Credit Card or though PayPal at that Matronics Contribution web site: http://www.matronics.com/contribution Or, drop a check in the mail: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your support! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 28, 2014
Rick: did you get that in writing? Does their website support what was said. Barry On Fri, Nov 28, 2014 at 11:34 AM, Richard Girard wrote: > Vernon, When I called Lockwood tech support I was told the procedure is to > order new floats and with them will come a warranty form. Fill out the > form, send it in with the old floats and you get a refund. So, yes, it > appears Rotax is supporting the S/B. Now all we need are new floats. > > Rick > > On Wed, Nov 26, 2014 at 7:11 AM, vernon mitchell > wrote: > >> Shocking, that it is taking so long to sort out. Will Rotax replace >> them free of charge? >> Vernon >> >> *From:* Richard Girard >> *Sent:* Wednesday, November 26, 2014 4:31 AM >> *To:* rotaxengines-list(at)matronics.com >> *Subject:* RotaxEngines-List: SB-912-065/914-046 >> >> Did the weight check per the Service Bulletin and found a heavy float. >> You can see the crack on the lower edge of the left hand float in the >> picture. >> Called both Lockwood and the Bing Agency to get the status of new float >> availability. None at this time, Rotax is working with Bing and Bing's >> float supplier to fix the problem. Fortunately, I saved the old floats when >> I rebuilt the carbs 18 months ago. >> >> Rick Girard >> >> >> ________________________________________________________________________________
Date: Nov 29, 2014
Barry, No, I'm just reporting what I was told. What's your point? Rick On Fri, Nov 28, 2014 at 10:57 AM, FLYaDIVE wrote: > Rick: > > did you get that in writing? Does their website support what was said. > > Barry > > On Fri, Nov 28, 2014 at 11:34 AM, Richard Girard > wrote: > >> Vernon, When I called Lockwood tech support I was told the procedure is >> to order new floats and with them will come a warranty form. Fill out the >> form, send it in with the old floats and you get a refund. So, yes, it >> appears Rotax is supporting the S/B. Now all we need are new floats. >> >> Rick >> >> On Wed, Nov 26, 2014 at 7:11 AM, vernon mitchell >> wrote: >> >>> Shocking, that it is taking so long to sort out. Will Rotax replace >>> them free of charge? >>> Vernon >>> >>> *From:* Richard Girard >>> *Sent:* Wednesday, November 26, 2014 4:31 AM >>> *To:* rotaxengines-list(at)matronics.com >>> *Subject:* RotaxEngines-List: SB-912-065/914-046 >>> >>> Did the weight check per the Service Bulletin and found a heavy float. >>> You can see the crack on the lower edge of the left hand float in the >>> picture. >>> Called both Lockwood and the Bing Agency to get the status of new float >>> availability. None at this time, Rotax is working with Bing and Bing's >>> float supplier to fix the problem. Fortunately, I saved the old floats when >>> I rebuilt the carbs 18 months ago. >>> >>> Rick Girard >>> >>> >>> * > > > * > > -- Believe those who are seeking the truth, doubt those who find it. -Andre Gide ________________________________________________________________________________
Date: Nov 29, 2014
Soon! Dear Listers, There's just two more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2014
Rich: I am very cautious... Some may say skeptical. Only because as much as we love our planes, others love our wallets. I do not see why we should buy a new set of floats (you already paid for the first set). It would seam very simple to just: a> ROTAX/Lockwood create an online form to be filled out and issue either a cash credit, written check or ship you new floats. Or... b> ROTAX/Lockwood should accept a simple letter from those affected along with the old style float and send out a new floats. Why should we have to BUY a new set and then WAIT for them to credit us! If it is not in writing it does not exist. Perry Mason 101. Barry On Sat, Nov 29, 2014 at 11:12 AM, Richard Girard wrote: > Barry, No, I'm just reporting what I was told. What's your point? > > Rick > > On Fri, Nov 28, 2014 at 10:57 AM, FLYaDIVE wrote: > >> Rick: >> >> did you get that in writing? Does their website support what was said. >> >> Barry >> >> On Fri, Nov 28, 2014 at 11:34 AM, Richard Girard >> wrote: >> >>> Vernon, When I called Lockwood tech support I was told the procedure is >>> to order new floats and with them will come a warranty form. Fill out the >>> form, send it in with the old floats and you get a refund. So, yes, it >>> appears Rotax is supporting the S/B. Now all we need are new floats. >>> >>> Rick >>> >>> On Wed, Nov 26, 2014 at 7:11 AM, vernon mitchell >>> wrote: >>> >>>> Shocking, that it is taking so long to sort out. Will Rotax replace >>>> them free of charge? >>>> Vernon >>>> >>>> *From:* Richard Girard >>>> *Sent:* Wednesday, November 26, 2014 4:31 AM >>>> *To:* rotaxengines-list(at)matronics.com >>>> *Subject:* RotaxEngines-List: SB-912-065/914-046 >>>> >>>> Did the weight check per the Service Bulletin and found a heavy float. >>>> You can see the crack on the lower edge of the left hand float in the >>>> picture. >>>> Called both Lockwood and the Bing Agency to get the status of new float >>>> availability. None at this time, Rotax is working with Bing and Bing's >>>> float supplier to fix the problem. Fortunately, I saved the old floats when >>>> I rebuilt the carbs 18 months ago. >>>> >>>> Rick Girard >>>> >>>> >>>> * >> >> _blank">www.aeroelectric.com <http://www.aeroelectric.com> >> .com" target="_blank">www.buildersbooks.com <http://www.buildersbooks.com> >> ="_blank">www.homebuilthelp.com <http://www.homebuilthelp.com> >> ="_blank">www.mypilotstore.com <http://www.mypilotstore.com> >> ank">www.mrrace.com <http://www.mrrace.com> >> _blank">http://www.matronics.com/contribution >> ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List >> tp://forums.matronics.com <http://forums.matronics.com> >> >> * >> >> > > > -- > > > Believe those who are seeking the truth, doubt those who find it. > -Andre Gide > > * > > > * > > ________________________________________________________________________________
Date: Nov 29, 2014
Hi Guys, New to this site and have been reading very good comments on Rotax and anyth ing to do with Pulsar III aircraft. Have had many issues since rebuild of pl ane and issues with 912ULS. Just a FYI for float issue. Rotax SB-912-065-R1, Material Info-2.2, covers R otax paying for all required to test but doesn't indicate about paying upfro nt or refund later. Will try to get more involved with forum as time permits. Good luck, Alan Sent from my iPad > On Nov 29, 2014, at 12:53 PM, FLYaDIVE wrote: > > Rich: > > I am very cautious... Some may say skeptical. Only because as much as we love our planes, others love our wallets. I do not see why we should buy a new set of floats (you already paid for the first set). It would seam very simple to just: > a> ROTAX/Lockwood create an online form to be filled out and issue either a cash credit, written check or ship you new floats. Or... > b> ROTAX/Lockwood should accept a simple letter from those affected along w ith the old style float and send out a new floats. > > Why should we have to BUY a new set and then WAIT for them to credit us! > > If it is not in writing it does not exist. Perry Mason 101. > > Barry > >> On Sat, Nov 29, 2014 at 11:12 AM, Richard Girard wr ote: >> Barry, No, I'm just reporting what I was told. What's your point? >> >> Rick >> >>> On Fri, Nov 28, 2014 at 10:57 AM, FLYaDIVE wrote: >>> Rick: >>> >>> did you get that in writing? Does their website support what was said. >>> >>> Barry >>> >>>> On Fri, Nov 28, 2014 at 11:34 AM, Richard Girard w rote: >>>> Vernon, When I called Lockwood tech support I was told the procedure is to order new floats and with them will come a warranty form. Fill out the f orm, send it in with the old floats and you get a refund. So, yes, it appear s Rotax is supporting the S/B. Now all we need are new floats. >>>> >>>> Rick >>>> >>>>> On Wed, Nov 26, 2014 at 7:11 AM, vernon mitchell wrote: >>>>> Shocking, that it is taking so long to sort out. Will Rotax replace th em free of charge? >>>>> Vernon >>>>> >>>>> From: Richard Girard >>>>> Sent: Wednesday, November 26, 2014 4:31 AM >>>>> To: rotaxengines-list(at)matronics.com >>>>> Subject: RotaxEngines-List: SB-912-065/914-046 >>>>> >>>>> Did the weight check per the Service Bulletin and found a heavy float. You can see the crack on the lower edge of the left hand float in the pictu re. >>>>> Called both Lockwood and the Bing Agency to get the status of new floa t availability. None at this time, Rotax is working with Bing and Bing's flo at supplier to fix the problem. Fortunately, I saved the old floats when I r ebuilt the carbs 18 months ago. >>>>> >>>>> Rick Girard >>>>> >>>>> >>> >>> >>> >>> _blank">www.aeroelectric.com >>> >>> .com" target="_blank">www.buildersbooks.com >>> ="_blank">www.homebuilthelp.com >>> ="_blank">www.mypilotstore.com >>> ank">www.mrrace.com >>> _blank">http://www.matronics.com/contribution >>> ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-L ist >>> tp://forums.matronics.com >>> >> >> >> >> >> -- >> >> >> Believe those who are seeking the truth, doubt those who find it. >> -Andre Gide >> >> >> >> _blank">www.aeroelectric.com >> .com" target="_blank">www.buildersbooks.com >> ="_blank">www.homebuilthelp.com >> ="_blank">www.mypilotstore.com >> ank">www.mrrace.com >> _blank">http://www.matronics.com/contribution >> ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-Li st >> tp://forums.matronics.com >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Nov 30, 2014
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 51, so don't reminde me! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 01, 2014
rickofudall wrote: > ...Called both Lockwood and the Bing Agency to get the status of new float availability. None at this time, Rotax is working with Bing and Bing's float supplier to fix the problem. ... > Rick Girard > Here's an update on Rick's post: I just talked on the phone with Dean at Lockwood. He says that Rotax hasn't yet announced a remedy for the bad float problem (other than to check them every 25 hours) and therefore Lockwood still has the old, potentially bad, floats. He says that float replacement will work like a standard warranty claim. You buy new floats and submit a warranty claim for the bad floats. You'll need to demonstrate that the floats actually are bad--by weighing them individually or by photographing them floating in gasoline while in a carb bowl. I think he said that the pin should be at the fuel level; if not, they're bad. (A 912 bowl will work as well as a 914 bowl and is easier because you don't have to hold the bigfat bolt and o-ring in there to keep the gas from running out.) In the meantime, all engines, carbs, and floats in the worry range should be checked every 25 hours. That includes brand new floats that you might buy to replace your bad ones--until Rotax gets the float supply problem fixed. =Don Maxwell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435209#435209 ________________________________________________________________________________
Date: Dec 06, 2014
Subject: Magnetic plug
OK. I have stripped the magnetic plug and can't get it out with the torx. What are my options? I do have the new hex head replacement but that doesn't help til I get the old one out. Any help would be greatly appreciated. Dan Wilde ________________________________________________________________________________
Date: Dec 06, 2014
Subject: Re: Magnetic plug
1 - BP Blast 2 - Drill it out... Then use a EZOut... 3 - What material is it made of? You may want to use a SQUARE EZOut. 4 - Another trick it so use HEAT... Heat around the plug and cool the plug, then quickly use the EZOut . Barry ________________________________________________________________________________
Date: Dec 06, 2014
Hi Dan, This is easy. I have done many. Give me a call and I'll tell you two ways to do it in seconds.. Roger Lee Tucson, AZ 520-574-1080 -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435435#435435 ________________________________________________________________________________
Date: Dec 06, 2014
I experienced the same problem somewhere back there since I started flying 912 engines in 1994. If I remember correctly, I smacked it with flat faced brass drift and a 2 lb hammer, then broke it loose with a pair of Vise Grips. I too had a new mag plug to replace the one I buggered up. Personally, I would never use an Ease It Out on anything. If you screw up and break the tip off one, you are really screwed. Also, I don't think I would use heat on the gear box or cases, or for that matter, anything on the 912. Worth what you paid for it. Your mileage may vary. john h MKIII Titus, Alabama 1 - BP Blast 2 - Drill it out... Then use a EZOut... 3 - What material is it made of? You may want to use a SQUARE EZOut. 4 - Another trick it so use HEAT... Heat around the plug and cool the plug, then quickly use the EZOut . Barry ________________________________________________________________________________
Date: Dec 06, 2014
What I have done is get a large flat punch the size of the OD of the plug and give it a shock blow and then if you don't have an internal allen head remover, I have actually used a chisel,not to sharp, and on the OD of the plug,give it a good shot in the counterclockwise direction to snap it loose and it will come out. Not an expert, but this has worked on stripped plugs in the hydraulic industry, and actually on my 912ULS, and worked fine. Good you have a new one, but I am still using the original. Maybe wait till someone else may have a better solution, but this worked for me. Alan Sent from my iPad > On Dec 6, 2014, at 5:55 PM, Dan Wilde wrote: > > > OK. I have stripped the magnetic plug and can't get it out with the torx. What are my options? I do have the new hex head replacement but that doesn't help til I get the old one out. Any help would be greatly appreciated. > > Dan Wilde > > > > ________________________________________________________________________________
Date: Dec 06, 2014
The plug is magnetic so is steel but the magnetic insert in the interior is a separate piece and I would be concerned if drilling out it may become dislodged and fall inside the crankcase,which brings up another issue. The plug is not secured with Loctite so heating won't help,as the plug will expand before the case, but cooling it quickly with CO2 may help but try the chisel method because it worked for me. I just checked my plug and it has a small notch where I used the dull chisel to get it out and is still there with no issue. Mind you I didn't totally strip the Allen/Torx as I saw it wasn't coming out and used the Allen wrench to tighten it back in and the notch is there for loosening it the next check. Good you have a new one to replace the old one if you wish. Rotax so it's not cheap. Alan Sent from my iPad > On Dec 6, 2014, at 5:55 PM, Dan Wilde wrote: > > > OK. I have stripped the magnetic plug and can't get it out with the torx. What are my options? I do have the new hex head replacement but that doesn't help til I get the old one out. Any help would be greatly appreciated. > > Dan Wilde > > > > ________________________________________________________________________________
Date: Dec 06, 2014
A good mechanic does not break off EZ Outs. Heat is quite acceptable... After all heat is generated by the gear box. You are not brazing you are just creating a delta in the heat between the male and female threads - That is why I mentioned cool the plug... ICE works very good for that. What is the plug made of? What is the case made of? I'm guessing that the case is cast? If so - You feel it is acceptable to pound on the case with a brass drift and a 2 Lb hammer... OUCH! Did I hear that case CRACK! Barry On Sat, Dec 6, 2014 at 6:24 PM, John Hauck wrote: > I experienced the same problem somewhere back there since I started flying > 912 engines in 1994. > > > If I remember correctly, I smacked it with flat faced brass drift and a > 2 lb hammer, then broke it loose with a pair of Vise Grips. I too had a > new mag plug to replace the one I buggered up. > > > Personally, I would never use an Ease It Out on anything. If you screw > up and break the tip off one, you are really screwed. > > > Also, I don't think I would use heat on the gear box or cases, or for that > matter, anything on the 912. > > > Worth what you paid for it. Your mileage may vary. > > > john h > > MKIII > > Titus, Alabama > > > 1 - BP Blast > > 2 - Drill it out... Then use a EZOut... > > 3 - What material is it made of? > > You may want to use a SQUARE EZOut. > > 4 - Another trick it so use HEAT... Heat around the plug and cool the > plug, then quickly use the EZOut . > > > Barry > > > * > > > * > > ________________________________________________________________________________
Date: Dec 07, 2014
A sharp cold chisel, applied to the edge of the flange. May be able to knock it loose just with that. If not apply a flat face punch to the notch made by the chisel. I've done it several times easily. JG ________________________________________________________________________________
Date: Dec 07, 2014
Smacking it with a brass drift and a hammer is the method that was taught to me in Rotax school. It works well and pops it loose so you can turn it with an allen.I have done it many times that way. Dick Maddux 912UL ________________________________________________________________________________
Date: Dec 07, 2014
Maybe you could use a Dremel-like tool to cut a groove in the plug. Then use a large screwdriver in the groove and Vise Grips to get the plug moving. Michael ------------------------------------------------------------------------- ------- ------------------------------------------------------------------------- ------- ----- Original Message ----- From: "Roger Lee" <ssadiver1(at)yahoo.com> Sent: Saturday, December 06, 2014 3:19 PM Subject: RotaxEngines-List: Re: Magnetic plug > > Hi Dan, > > This is easy. I have done many. Give me a call and I'll tell you two ways to do it in seconds.. > > Roger Lee > Tucson, AZ > 520-574-1080 > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435435#435435 > > >
June 24, 2014 - December 07, 2014
RotaxEngines-Archive.digest.vol-bg
