RotaxEngines-Archive.digest.vol-bh
December 07, 2014 - May 17, 2016
      > No virus found in this message.
      > Checked by AVG - www.avg.com
      12/07/14
Subject: Re: Magnetic plug
Date: Dec 07, 2014
It can come out two ways. One way is to use a small set of vise grip pliers and there is enough shoulder to grab it. You can use a small butane torch and heat the case around it. Try to direct the heat on the case and not the plug. Then have someone use a metal rod on it and rap it with a hammer as you apply force with the vise grips. Comes right out. The other way is to use a Dremel tool with a cut off blade. Put a straght grove in the plug and use a large tip screwdriver to turn with a wrench attached to the screwdriver shaft for additional leverage and it will come right out. Again heat the case and rap it with a hammer and metal rod. Do not cut so deep in the screw plug with the Dremel to damage the case sealing edge. Both of these ways work and are easy to do. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435461#435461 ________________________________________________________________________________
From: =?utf-8?Q?Gert_Dalgaard_S=C3=B8rensen?= <stabelvej9(at)gmail.com>
Date: Dec 08, 2014
Go to Rotax site, and follow the instructions in the learning video for exactly this subject - there is a procedure for what you do when a hex is stripped - what tool to use, and what spares to get. =93Magnetic plug removal=94, SB 914-034 Regards Gert Dalgaard Europa Mono / 914 / 1000 hrs. OY-GDS > Den 07/12/2014 kl. 20.19 skrev Michael Orth : > > Maybe you could use a Dremel-like tool to cut a groove in the plug. > Then use a large screwdriver in the groove and Vise Grips to get the plug moving. > Michael > ----- Original Message ----- > From: "Roger Lee" <ssadiver1(at)yahoo.com <mailto:ssadiver1(at)yahoo.com>> > To: > > Sent: Saturday, December 06, 2014 3:19 PM > Subject: RotaxEngines-List: Re: Magnetic plug > > > > > > Hi Dan, > > > > This is easy. I have done many. Give me a call and I'll tell you two ways to do it in seconds.. > > > > Roger Lee > > Tucson, AZ > > 520-574-1080 > > > > -------- > > Roger Lee > > Tucson, Az. > > Light Sport Repairman - Maintenance Rated > > Rotax Repair Center - Heavy Maint. Rated > > Home 520-574-1080 TRY HOME FIRST > > Cell 520-349-7056 > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=435435#435435 <http://forums.matronics.com/viewtopic.php?p=435435#435435> > > > > > > > > > > > > > > > > ========== > > Support Your Lists This Month -- > > Get Some the Annual Contribution link Terrific Free href="http://www.aeroelectric.com <http://www.aeroelectric.com/>">www.aeroelectric.com <http://www.aeroelectric.com/> > > href="http://www.buildersbooks.com <http://www.buildersbooks.com/>">www.buildersbooks.com <http://www.buildersbooks.com/> > > href="http://www.homebuilthelp.com <http://www.homebuilthelp.com/>">www.homebuilthelp.com <http://www.homebuilthelp.com/> > > href="http://www.mypilotstore.com <http://www.mypilotstore.com/>">www.mypilotstore.com <http://www.mypilotstore.com/> > > href="http://www.mrrace.com <http://www.mrrace.com/>">www.mrrace.com > > --> http://www.matronics.com/contribution <http://www.matronics.com/contribution> > > Features Browse, Chat, href="http://www.matronics.com/Navigator?RotaxEngines-List <http://www.matronics.com/Navigator?RotaxEngines-List>">http://www.matroni cs.com/Navigator?RotaxEngines-List <http://www.matronics.com/Navigator?RotaxEngines-List> > > bsp; via the href="http://forums.matronics.com <http://forums.matronics.com/>">http://forums.matronics.com <http://forums.matronics.com/> > > ========== > > > > > > > > > > > > ----- > > No virus found in this message. > > Checked by AVG - www.avg.com <http://www.avg.com/> > > Version: 12/07/14 > > > > <http://www.aeroelectric.com/> <http://www.buildersbooks.com/> <http://www.homebuilthelp.com/> <http://www.mypilotstore.com/> <http://www.matronics.com/contribution> <http://www.matronics.com/Navigator?RotaxEngines-List> > > ________________________________________________________________________________
Subject: Engine boosting
Date: Dec 16, 2014
Hi Group I have a 914. The Garett Air Cooled Turbo that the 914 uses has been around for some time (I think it is very close to the one on my 1983 GLT50 (245) Volvo Turbo Wagon). Curiosity question: Can a "much more better" designed air pump reduce heating of air? I was at the New York Bike show over the weekend. One bike really caught my eye: A Kawasaki H2(R). It's a track bike with a H2 model that will be street legal (I'm sure less powerful). Anyway the H2R has a 1,000cc Super Charged engine that is claimed to produce 300hp. 300hp per liter, quite impressive. Specifications are still a bit vague, but 14K may be close to redline? Anyway supposedly Kawasaki did their homework (drawing from their affiliates that know about turbine design) and their H2R design uses ~ a 2.5" diameter centrifugal compressor with the larger stage being an 18 blade design. It is driven from the crankshaft via chain off crank, then planetary gears that can spin turbine up to 140,000rpm, spewing out air centrifugally at up to a little more than 1,000mph. Just a note, the bike I saw (and heard run) had single speed gearing, but patent Kawasaki has is for 1,2 or 3 speed. 3 speed would make for a lot of air at lower rpms (or high altitude!). The gearing on the single speed was a little under 10 to 1 of crank speed. The interesting thing is it doesn't have an inter-cooler. Kawasaki mentions it doesn't need an inter-cooler because the "miracle shaped blades) make less heat than if it were traditionally shaped (whatever that means". The super-charger is at the rear of the engine and it has an aluminium combiner/air-box sitting on top of the engine. I don't know much about fluid dynamics. Can anyone shed some light: If a more efficient design is had for a compressor that compresses air to boost intake pressure to an engine, give me an idea of how much less heat might be produced. I know on my 1983 Volvo, it had a 4 cylinder engine with a 2,300cc displacement. Stock out of the factory without an inter-cooler the turbo would raise air temp as much as 145 degrees F. If you installed the factory offered inter-cooler, instead of raising the air temp going into your engine 145F, it would only raise the air temp 45F. The inter-cooler came with a device that would wait until you got to 3,750rpm, then it would increase boost. Sincerely Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435789#435789 ________________________________________________________________________________
Date: Dec 16, 2014
According to the "ideal gas law" (which is a pretty good approximation for air at the pressure in the intake manifold) PV = nRT so no matter what kind of compressor/turbo is used, for a given amount of compression there is a predictable change in temperature. Of course, if there is a difference in the inefficiency of the turbos being compared that could make a difference but I suspect that the differences will be minor compared to the theoretical temperature change. Best regards, Rob Housman Irvine, California Europa XS Rotax 914 S/N A070 Airframe complete Avionics in progress -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of rparigoris Sent: Tuesday, December 16, 2014 3:25 PM Subject: RotaxEngines-List: Engine boosting --> Hi Group I have a 914. The Garett Air Cooled Turbo that the 914 uses has been around for some time (I think it is very close to the one on my 1983 GLT50 (245) Volvo Turbo Wagon). Curiosity question: Can a "much more better" designed air pump reduce heating of air? I was at the New York Bike show over the weekend. One bike really caught my eye: A Kawasaki H2(R). It's a track bike with a H2 model that will be street legal (I'm sure less powerful). Anyway the H2R has a 1,000cc Super Charged engine that is claimed to produce 300hp. 300hp per liter, quite impressive. Specifications are still a bit vague, but 14K may be close to redline? Anyway supposedly Kawasaki did their homework (drawing from their affiliates that know about turbine design) and their H2R design uses ~ a 2.5" diameter centrifugal compressor with the larger stage being an 18 blade design. It is driven from the crankshaft via chain off crank, then planetary gears that can spin turbine up to 140,000rpm, spewing out air centrifugally at up to a little more than 1,000mph. Just a note, the bike I saw (and heard run) had single speed gearing, but patent Kawasaki has is for 1,2 or 3 speed. 3 speed would make for a lot of air at lower rpms (or high altitude!). The gearing on the single speed was a little under 10 to 1 of crank speed. The interesting thing is it doesn't have an inter-cooler. Kawasaki mentions it doesn't need an inter-cooler because the "miracle shaped blades) make less heat than if it were traditionally shaped (whatever that means". The super-charger is at the rear of the engine and it has an aluminium combiner/air-box sitting on top of the engine. I don't know much about fluid dynamics. Can anyone shed some light: If a more efficient design is had for a compressor that compresses air to boost intake pressure to an engine, give me an idea of how much less heat might be produced. I know on my 1983 Volvo, it had a 4 cylinder engine with a 2,300cc displacement. Stock out of the factory without an inter-cooler the turbo would raise air temp as much as 145 degrees F. If you installed the factory offered inter-cooler, instead of raising the air temp going into your engine 145F, it would only raise the air temp 45F. The inter-cooler came with a device that would wait until you got to 3,750rpm, then it would increase boost. Sincerely Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435789#435789 ________________________________________________________________________________
Date: Dec 16, 2014
Rob, Just FYI. Here is a link to a company that is using a 912 and 912S, a centrifugal blower, and getting around 25hp to 45hp extra. http://www.flygas.info/en/news-en.html Keith ********************************************************************************** -------------------------------------------- On Tue, 12/16/14, Rob Housman <rob@hyperion-ef.com> wrote: Subject: RE: RotaxEngines-List: Engine boosting To: rotaxengines-list(at)matronics.com Date: Tuesday, December 16, 2014, 5:44 PM --> RotaxEngines-List message posted by: "Rob Housman" <rob@hyperion-ef.com> According to the "ideal gas law" (which is a pretty good approximation for air at the pressure in the intake manifold) PV = nRT so no matter what kind of compressor/turbo is used, for a given amount of compression there is a predictable change in temperature. Of course, if there is a difference in the inefficiency of the turbos being compared that could make a difference but I suspect that the differences will be minor compared to the theoretical temperature change. Best regards, Rob Housman Irvine, California Europa XS Rotax 914 S/N A070 Airframe complete Avionics in progress -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of rparigoris Sent: Tuesday, December 16, 2014 3:25 PM To: rotaxengines-list(at)matronics.com Subject: RotaxEngines-List: Engine boosting --> Hi Group I have a 914. The Garett Air Cooled Turbo that the 914 uses has been around for some time (I think it is very close to the one on my 1983 GLT50 (245) Volvo Turbo Wagon). Curiosity question: Can a "much more better" designed air pump reduce heating of air? I was at the New York Bike show over the weekend. One bike really caught my eye: A Kawasaki H2(R). It's a track bike with a H2 model that will be street legal (I'm sure less powerful). Anyway the H2R has a 1,000cc Super Charged engine that is claimed to produce 300hp. 300hp per liter, quite impressive. Specifications are still a bit vague, but 14K may be close to redline? Anyway supposedly Kawasaki did their homework (drawing from their affiliates that know about turbine design) and their H2R design uses ~ a 2.5" diameter centrifugal compressor with the larger stage being an 18 blade design. It is driven from the crankshaft via chain off crank, then planetary gears that can spin turbine up to 140,000rpm, spewing out air centrifugally at up to a little more than 1,000mph. Just a note, the bike I saw (and heard run) had single speed gearing, but patent Kawasaki has is for 1,2 or 3 speed. 3 speed would make for a lot of air at lower rpms (or high altitude!). The gearing on the single speed was a little under 10 to 1 of crank speed. The interesting thing is it doesn't have an inter-cooler. Kawasaki mentions it doesn't need an inter-cooler because the "miracle shaped blades) make less heat than if it were traditionally shaped (whatever that means". The super-charger is at the rear of the engine and it has an aluminium combiner/air-box sitting on top of the engine. I don't know much about fluid dynamics. Can anyone shed some light: If a more efficient design is had for a compressor that compresses air to boost intake pressure to an engine, give me an idea of how much less heat might be produced. I know on my 1983 Volvo, it had a 4 cylinder engine with a 2,300cc displacement. Stock out of the factory without an inter-cooler the turbo would raise air temp as much as 145 degrees F. If you installed the factory offered inter-cooler, instead of raising the air temp going into your engine 145F, it would only raise the air temp 45F. The inter-cooler came with a device that would wait until you got to 3,750rpm, then it would increase boost. Sincerely Ron Parigoris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435789#435789 Lists This Month -- Some AWESOME FREE Gifts!) Raiser. Click on more about Gifts provided www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com www.mypilotstore.com www.mrrace.com -Matt Dralle, List Admin. RotaxEngines-List Email Forum - - MATRONICS WEB FORUMS - ________________________________________________________________________________
Date: Dec 24, 2014
Subject: 2014 List of Contributors
Dear Listers, The 2014 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Andy, Bob, Corbin, George, and Jon for their generous support through the supply of many great gifts this year!! These guys have some excellent products and I encourage you to visit their respective web sites: Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com Bob Nucklolls - AeroElectric - http://www.aeroelectric.com Corbin Glowacki - My Pilot Store - http://www.mypilotstore.com George Race - Race Consulting - http://www.mrrace.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com And finally, I'm proud to present The 2014 Fund Raiser List of Contributors: http://www.matronics.com/loc/2014.html Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Subject: Re: Engine boosting
Date: Dec 25, 2014
Rob is exactly correct. Compression always increases energy, in this case heat. For a given compression ratio, there will always be the same increase in heat energy and if starting from the same temperature, always ending at the same higher temperature irrespective of fan blade design. As for "Flygas", not in my airplane! There's something reassuring about ground up system design and review of all affected parts in terms of flight reliability. Happy Holidays and Safe Flight! -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436250#436250 ________________________________________________________________________________
Date: Dec 25, 2014
From: William Daniell <wdaniell.longport(at)gmail.com>
Where I live in Colombia they developed a turbo for the stock 912 before the 914 came out. It uses a Mitsubishi turbo with the standard carbs albeit adjusted. I hear that you can get 39" but I only use 33" but given that I fly out of SKGY MSL 8500 this gives 500' minute performance with two adults aboard my ICPStol. The system is pretty much what you would imagine with the four exhausts feeding the turbo which has the standard vehicle blow off valve but with a weaker spring than the vehicle one. I had manual adjustment with a vernier for a while which also worked fine but added work. The cold side feeds an airbox which feeds the carbs. I like this set up and I have flow nearly 500 hours on it without a problem except once when I fitted normal paper carb bowl gaskets which let in air and high MP. Cork gaskets solved the problem. I had an engine tear down by a rotax certified mechanic at 500 hours and all tolerances where within spec. A lot of people use this set up here and I have never heard of any problems except when the boost is set too high 40" +. In fact due to the complexity of the 914 in many ways it seems a more reliable option. Will William Daniell LONGPORT +57 310 295 0744 On Thu, Dec 25, 2014 at 10:43 AM, rampil wrote: > > Rob is exactly correct. Compression always increases energy, in this > case heat. For a given compression ratio, there will always be the same > increase in heat energy and if starting from the same temperature, > always ending at the same higher temperature irrespective of fan blade > design. > > As for "Flygas", not in my airplane! There's something reassuring about > ground up system design and review of all affected parts in terms of > flight reliability. > > Happy Holidays and Safe Flight! > > -------- > Ira N224XS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=436250#436250 > > ________________________________________________________________________________
Date: Dec 26, 2014
William - Merry Christmas! It is not wear on moving parts that would be of concern, it is instead the added stress on the crank, the rods, the pistons and the cylinders/heads. Remember the rotax gets its performance from light weight alloys which are designed to just meet expected stress, not the added stress of running at an MP 10 - 30% higher than design. The 914 is not just a 912 with a blower bolted on, some moving parts were also upgraded. In experimental aviation fooling around with your engine is certainly permissible, even encouraged, if you know what you are doing. There is even a Rotax-designated service center in Mississippi that does all kinds of mods to stock engines for the Highlander / SuperSTOL crowd. All I said in my initial comments is that for my aircraft, I would not markedly diminish the reliability of my engine for a small gain in power and an even smaller gain in speed. Your mileage will vary. I use my 912s Europa for 1000 nm cross country trips from 0 - 1000' MSL airports. I like a reliable engine! -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436284#436284 ________________________________________________________________________________
Date: Dec 26, 2014
Ira likewise Merry Christmas. Yes I had the same thoughts about stress hence keeping the boost to 33" and reduce power to 30" within 3 minutes of take off. I cruise at 27". Also I suppose my need taking off at 8500' is slightly out of the normal operating range and requires extraordinary measures! However the local mechanics tell me that the internals of the 914 are the same as the 912 and certainly the anecdotal reliability "stats" would suggest that the mod doesn't over stress the engine. At 27" I am burning 4 gals and hour. The downside of the mod in my opinion is weight, complexity and heat albeit this is less complex than a 914. If I were flying at sea level I would choose a 912s as an excellent balance weight simplicity and power. Interestingly enough the only major issue that I have heard of with rotax here was a 912s on mogas. Even the premium mogas here is of very poor quality and in a friend's aircraft this caused detonation which cracked a piston. Quality gas is a must in high compression engines. Will William Daniell LONGPORT +57 310 295 0744 On Fri, Dec 26, 2014 at 10:16 AM, rampil wrote: > > William - Merry Christmas! > > It is not wear on moving parts that would be of concern, it is instead > the added stress on the crank, the rods, the pistons and the > cylinders/heads. > > Remember the rotax gets its performance from light weight alloys which are > designed to just meet expected stress, not the added stress of running at > an MP 10 - 30% higher than design. > > The 914 is not just a 912 with a blower bolted on, some moving parts were > also upgraded. > > In experimental aviation fooling around with your engine is certainly > permissible, even encouraged, if you know what you are doing. There is > even a Rotax-designated service center in Mississippi that does all > kinds of mods to stock engines for the Highlander / SuperSTOL crowd. > > All I said in my initial comments is that for my aircraft, I would not > markedly > diminish the reliability of my engine for a small gain in power and an even > smaller gain in speed. Your mileage will vary. I use my 912s Europa for > 1000 nm cross country trips from 0 - 1000' MSL airports. I like a reliable > engine! > > -------- > Ira N224XS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=436284#436284 > > ________________________________________________________________________________
Subject: Re: Oil pressure at 145 psi
Date: Jan 17, 2015
Henry, If your oil pressure sender is directly attached to the oil pump, its probably a dead or damaged sender. Vibration usually kills them over time. Not recommending you do this, but I moved my sender from the engine block to the firewall and have a length of pressure hose from the block to the sender. So far, no problems. Blue skies & tailwinds, Bob Borger Europa XS Tri, Rotax 914, Airmaster C/S Prop (90 hrs). Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP 3705 Lynchburg Dr. Corinth, TX 76208-5331 Cel: 817-992-1117 rlborger(at)mac.com On Jan 17, 2015, at 4:20 PM, henry.voris wrote: Cruze'n along with the trusty 912 ULS turning 4,800 RPM when I notice the oil pressure is pegged at 145 psi. The factory sez 73 psi is max. Smartly I execute a 180 turn and retrace the ten miles to the airport. While taxiing back to the shadeport I goof with the throttle and see that the oil pressure rises and falls with the RPM, but by the time it gets to 4,000 RPM we're showing 100 psi. Inspection shows no leakage. I'm hoping it's something cheap, easy and on top... Any help troubleshooting this would be most appreciated... Thanks in advance. Henry -------- Henry Firefly Five-Charlie-Bravo ________________________________________________________________________________
Subject: 503 Oil Cable end wearing out
Date: Jan 23, 2015
This 503 came from the factory without oil injection. At 80 hours I installed an injection system. The engine now has 136 hours so only 56 hours on this cable. You can see it is worn about 1/4 of the way through the barrel swedge on both ends where it contacts the oil pump lever. The pump lever is not worn at all. I noticed the swedge is brass. Too soft??? I have lubed it with LPS about every 10 hours. The engine is on a Kitfox so I had California Power Sports make a cable with the 503 oiler swedge on the pump end and a barrel swedge to fit the Kitfox throttle reverser bellcrank on the other end. I think I gave them measurements either too short for the inner cable or too long for the outer cable. I had to put both lock nuts on the adjuster below the bracket as shown to make the line on the lever line up at 3000 rpm. This caused the cable to not pull straight up on the lever at full throttle as shown in the photos. Could that be my problem I really like the convenience of the injection and it is supposed to be better for the engine but this is no good. Anyone else have this problem or have any ideas. I called CPS and they do not custom make cables anymore. -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437518#437518 Attachments: http://forums.matronics.com//files/post_130_0_35242800_1420669680_504.jpg http://forums.matronics.com//files/post_130_0_61384800_1420677060_thumb_966.jpg ________________________________________________________________________________
Date: Jan 23, 2015
Subject: Re: 503 Oil Cable end wearing out
Tom, I started flying ultralights in '78 with a Pterodactyl, currently own a Hornet and a Trike. I've had oil injection on a Maxair only which I think is just something else to go wrong. I understand what you're saying about oil injection but to me, adding oil to a 5 gallon can of fuel is much more reliable. Just takes a little effort is all & you eliminate a possible break in the chain. When the guy who originally ran CPS sold out, we all lost an incredibly knowledgeable guy who put out a fantastic catalog, loaded with not only great products but also with an explanation of what they do on almost every page. I don't have a lot of confidence in the new folks. Bill Catalina Tallahassee blumax008(at)aol.com -----Original Message----- From: Tom Jones <nahsikhs(at)elltel.net> Sent: Fri, Jan 23, 2015 10:40 am Subject: RotaxEngines-List: 503 Oil Cable end wearing out This 503 came from the factory without oil injection. At 80 hours I installed an injection system. The engine now has 136 hours so only 56 hours on this cable. You can see it is worn about 1/4 of the way through the barrel swedge on both ends where it contacts the oil pump lever. The pump lever is not worn at all. I noticed the swedge is brass. Too soft??? I have lubed it with LPS about every 10 hours. The engine is on a Kitfox so I had California Power Sports make a cable with the 503 oiler swedge on the pump end and a barrel swedge to fit the Kitfox throttle reverser bellcrank on the other end. I think I gave them measurements either too short for the inner cable or too long for the outer cable. I had to put both lock nuts on the adjuster below the bracket as shown to make the line on the lever line up at 3000 rpm. This caused the cable to not pull straight up on the lever at full throttle as shown in the photos. Could that be my problem I really like the convenience of the injection and it is supposed to be better for the engine but this is no good. Anyone else have this problem or have any ideas. I called CPS and they do not custom make cables anymore. -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437518#437518 Attachments: http://forums.matronics.com//files/post_130_0_35242800_1420669680_504.jpg http://forums.matronics.com//files/post_130_0_61384800_1420677060_thumb_966.jpg ________________________________________________________________________________
Date: Jan 23, 2015
Tom: Looking at your pictures three (3) things come to mind: 1 - This may sound very strange but with over 20 years in QA and test engineering - The cable has a LEFT TWIST to it. I have see many strange ware patterns with LEFT TWIST cable. See if you can find a RIGHT TWIST cable. If you go to a bicycle shop they may have the Right Twist cable and be able to swag the end fittings. 2 - The PLATE that guides the cable is not at the same angle as the arm... Twist the plate so it points more to the arm. 3 - The way you fitted the adjustment fitting and nuts is the way most people and probably the instructions show. BUT! The distance between the end of the adjustment fitting and the arm is TOO SMALL. You want a nice smooth arcing of the cable as it exits the adjustment fitting and the arm. MOVE the double nut mounting point as high - close to the end of the adjustment threads as possible. I do understand that this may not be due to the SUPPLIED parts. Time to be smarter than the manufacture and utilize the Experimental part of the planes certification. Another trick/item comes to mind... GREASE the cable and inside of the cable guide with a Teflon based grease. Make sure it can handle the temperature range. I would guess a range of +250 F to -20 F should cover the requirements. Barry On Fri, Jan 23, 2015 at 10:39 AM, Tom Jones wrote: > > This 503 came from the factory without oil injection. At 80 hours I > installed an injection system. The engine now has 136 hours so only 56 > hours on this cable. You can see it is worn about 1/4 of the way through > the barrel swedge on both ends where it contacts the oil pump lever. The > pump lever is not worn at all. I noticed the swedge is brass. Too soft??? I > have lubed it with LPS about every 10 hours. > > The engine is on a Kitfox so I had California Power Sports make a cable > with the 503 oiler swedge on the pump end and a barrel swedge to fit the > Kitfox throttle reverser bellcrank on the other end. I think I gave them > measurements either too short for the inner cable or too long for the outer > cable. > > I had to put both lock nuts on the adjuster below the bracket as shown to > make the line on the lever line up at 3000 rpm. This caused the cable to > not pull straight up on the lever at full throttle as shown in the photos. > Could that be my problem > > I really like the convenience of the injection and it is supposed to be > better for the engine but this is no good. Anyone else have this problem or > have any ideas. I called CPS and they do not custom make cables anymore. > > -------- > Tom Jones > Classic IV > 503 Rotax, 72 inch Two blade Warp > Ellensburg, WA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=437518#437518 > > > Attachments: > > http://forums.matronics.com//files/post_130_0_35242800_1420669680_504.jpg > > http://forums.matronics.com//files/post_130_0_61384800_1420677060_thumb_966.jpg > > ________________________________________________________________________________
Date: Jan 23, 2015
Thanks for the ideas guys. I was seriously considering removing the oil injection. I just had the engine resealed by a Rotax service center and asked his opinion on the cable and on removing the injection. He said it is a high wear item and convinced me to see if I can get the cable to last longer. I often don't fly for two weeks or more and then need to drain the fuel if using premix. I am going to get s new cable made and will ask them to use a right hand lay cable. I'll also make sure it is the proper length so I can adjust the end of the adjuster up higher near the bracket. I have been doing more research and since I posted this morning I found LEAF Aviation's catalog has a stainless steel oil cable end for the 503. The only others I have found in catalogs seem to be brass. More opinions still welcome if anyone has some. -------- Tom Jones Classic IV 503 Rotax, 72 inch Two blade Warp Ellensburg, WA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437534#437534 ________________________________________________________________________________
Date: Jan 23, 2015
Tom, Use a good quality motorcycle cable oil. I prefer one with graphite lubricant added to the oil. Soak the cable with the lube a day or two before installing it and hang it up to let the excess oil run out. Make sure when you install it that the cable guide is aligned with actuating lever on the pump at mid stroke to minimize side pressure on the cable and housing. Personally, I premix for my 582 but only because the engine came already converted on my aircraft. The advantage to the injection system is that at mid throttle, i.e. cruise settings, it reduces oil to fuel ratio to about 70 to 1 and consequently reduces carbon packing in the rings. Rick Girard On Fri, Jan 23, 2015 at 2:55 PM, Tom Jones wrote: > > Thanks for the ideas guys. > > I was seriously considering removing the oil injection. I just had the > engine resealed by a Rotax service center and asked his opinion on the > cable and on removing the injection. He said it is a high wear item and > convinced me to see if I can get the cable to last longer. I often don't > fly for two weeks or more and then need to drain the fuel if using premix. > > I am going to get s new cable made and will ask them to use a right hand > lay cable. I'll also make sure it is the proper length so I can adjust the > end of the adjuster up higher near the bracket. > > I have been doing more research and since I posted this morning I found > LEAF Aviation's catalog has a stainless steel oil cable end for the 503. > The only others I have found in catalogs seem to be brass. > > More opinions still welcome if anyone has some. > > -------- > Tom Jones > Classic IV > 503 Rotax, 72 inch Two blade Warp > Ellensburg, WA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=437534#437534 > > -- Believe those who are seeking the truth, doubt those who find it. -Andre Gide ________________________________________________________________________________
Subject: 2015 wish list
Date: Jan 23, 2015
When you have problems with the annoying signal that bother you sometimes from the base station, while you dont have any good idea to do with that, then you may need a cell phone signal jammer to help you get rid of such things. Or maybe you own a car, and you dont want to be interrupted by other interference from other vehicles when you are on the phone in your car, then you may need a car remote control jammer, which can work well as a nice assistant. Or if you are trying to avoid of being stalked by others, then you may need to pick up some powerful anti-tracking items to help you to get rid of such conditions. Most of them will be provided on jammerinthebox.com, there always can be suitable for you or just meet your demand perfectly. For we have been researching and kept improving the quality in this field for decades, all of them can be professionals in the market, you will need them. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437541#437541 ________________________________________________________________________________
Date: Feb 27, 2015
Subject: Harness for "old" SMD electronic modules
I have an older engine that uses the 965-358 modules and have been dealing with ignition problems over the years that has mainly been broken wire related. If and when I have to replace a module I learned in a recent Rotax class that these modules are hard to come by and very expensive. A recent vendor catalog had them listed for over $1300 vs about $950 for a current edition.(probably NOS if they still have them) Saw one on EBAY for $400 but what kind of shape is it in and how many hours under what conditions ? I ran across a man in England that makes a "plug and play" harness to adapt the new modules to the' Plug and pin" system on my old engine. This would allow me to use the new modules on my old engine and they would be available should I have a failure. So ,I ordered the harness which should be arriving soon. This harness is not cheap as the parts from Rotax are expensive but at least the harness will allow me to continue flying. Installation from cowling off to cowling on takes about an hour according to the maker. Thought I would pass this on so that should anyone else in this situation be interested at least you would have an out. Let me know and I will pass on the gentleman's name and address. He said he will make these on an individual basis as there are currently 3 different module systems I believe. My engine used the first generation system (after the "box") Dick Maddux 912UL ________________________________________________________________________________
Subject: General Aviation News and CTFlier.com
Date: Feb 27, 2015
http://generalaviationnews.com/2015/02/26/ct-typeclub/ -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438802#438802 ________________________________________________________________________________
Subject: 2015 Annual Page, AZ Fly-In
Date: Feb 28, 2015
More info here: http://ctflier.com/index.php?/topic/315 ... az-fly-in/ The time has come. If you said you were going to wait until next year then that time has come. This will be my last year to be the front runner for this event. Someone else can take it over (it isn't that tough). If no one does then this is our last and it's time to step up and come have fun with us one last time. More fun than you can have in any one place with people from all over the country. After I get the river trip setup then you all can copy and paste this post to other flying websites. All are welcome CT or not. Annual 2015 Page, AZ. Fly-In biggrin.gifLake Powell, Monument Valley, Bryce Canyon, Zion, Grand Canyon, Bullfrog Marina Resort... Make those reservations now. It's time again to work on the Page, AZ Fly-In. We changed a few things last year that added some new fun. We did the river raft trip the day before the actual Fly-In day. It was a great raft trip. I would highly recommend it. We changed up some of the routes last year which turned out well so we'll do it again. The Page, AZ. Fly-In date is October 15-18, 2015 We will fly the Grand Canyon, Lake Powell, Monument Valley (breakfast), Zion Canyon and Bryce Canyon (breakfast), Bullfrog Marina and Resort (breakfast). I have blocked off 30 rooms. We will be at the Clarion Inn with a rate of $65 (2 queen beds). I hope to have a record number of CT's and LSA aircraft for our Page Fly-In. Just like last year make the reservations early so you don't miss out and the hotel won't hold all 30 rooms forever. Do not wait this year. Book it now and you can cancel up to 24 hours before Oct. 15th. Get it booked and reserved, then if you have to cancel you can, but if you wait again then you may not be staying with the rest of us and at your own peril for rates and possibly a different hotel. They book darn near the whole town in October. "You must tell them you are with the CT Group" for your reference and the rate of $65 a night. We will arrive Thursday morning, Oct. 15th. and head home Oct. 18th. Sunday or Monday morning. Breakfast is free in the mornings. This hotel has not only a continental breakfast, but a full breakfast. I talked to the people at the Ranch House Grill and they will cater our evening meals again. We will have evening meals together Thursday, Friday and Saturday. Clarion Inn Ask for Illisa IF you have any issues with your reservations. 751 South Navajo Drive, Page, AZ 86040 928-645-9000 We will fly into the Page airport - KPGA. We are staying with Classic FBO and with our group we should get a 30 cent discount on fuel. Classic is not the first FBO next to the runway, but the second one behind them. The Antelope Canyon tour and the Dam tour is open if anyone wants. These are land tours. You guys are welcome to invite other planes that are not CT's and everyone is welcome. Find some more LSA's. I will develop GPS coordinates for all our routes and post them so you can enter them in your own GPS. I have a plan to better deal with all our planes for our flights so they are not crowded in the mornings or evenings. Don't miss this, we always have fun. p.s. biggrin.gif I would like everyone coming to shoot me an email so I can put together a roster and make name tags. If you attended last year and we have your personal info then just say you are coming. If you did not come last year then I would like the email to include: N#, Names of you and co-pilot, cell phone number, city, state. This is a big help for me to last year to organize our fly outs since we have so many planes and gives old friends and new friends a way to contact each other if need be. Thanks, Roger Lee The River Raft trip (don't miss it). Give me a couple more days to get this trip set up so don't call them until you see a reservation number posted. You must refer to this Reservation Number: (to be announced) and tell them you are with the CT group. A 1/2 day raft trip on Wed. Oct. 14th from Glen Canyon Dam down to just above Lee's Ferry. The trip starts in Page (at 1100 hrs) where we will take a shuttle bus down below the dam. We will board a 20-22 person raft and travel down river for about 1.5 hrs. and get out for drinks and photos. Then back in and on down close to Lee's Ferry. Then we turn around a high speed boat back to the start. There is no white water just a nice trip down through the canyons. The cost for all of this is $87 a person. The phone number for the reservations is 928-645-9175. Don't be left out, I know of at least 6 people that have already signed up so don't be late to make the boat, sign up now. They have a 48 hr. cancellation policy and you get it all back except a $7 charge. This means you will have to arrive in Page Oct. 13th. BRING YOUR HAT, SUNGLASSES AND SUNSCREEN. Here is the link: http://raftthecanyon...day-raft-trips/ What are you waiting for, let's go, I'm already signed up. ;) -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438815#438815 ________________________________________________________________________________
Subject: Re: 2015 Annual Page, AZ Fly-In
Date: Mar 01, 2015
Roger, Please add me to the list for Page. Thanks for the non-CT invitation. Gary R. Roberts 4030 N Paseo De Los Rancheros Tucson, AZ 85745 grroberts3(at)juno.com cell 520.307-7231 N2174B Marchetti S205R Co-Pilot to be determined You and I talked about my Europa/Rotax build a few years ago. We nearly went flying in your CT, but aborted on taxi due to winds. Gary R. Roberts grroberts3(at)juno.co > On Feb 28, 2015, at 14:48, Roger Lee wrote: > > > More info here: > > http://ctflier.com/index.php?/topic/315 ... az-fly-in/ > > > The time has come. If you said you were going to wait until next year then that time has come. This will be my last year to be the front runner for this event. Someone else can take it over (it isn't that tough). If no one does then this is our last and it's time to step up and come have fun with us one last time. More fun than you can have in any one place with people from all over the country. > > After I get the river trip setup then you all can copy and paste this post to other flying websites. All are welcome CT or not. > > > Annual 2015 Page, AZ. Fly-In > > > biggrin.gifLake Powell, Monument Valley, Bryce Canyon, Zion, Grand Canyon, Bullfrog Marina Resort... > Make those reservations now. It's time again to work on the Page, AZ Fly-In. We changed a few things last year that added some new fun. We did the river raft trip the day before the actual Fly-In day. It was a great raft trip. I would highly recommend it. > We changed up some of the routes last year which turned out well so we'll do it again. > > The Page, AZ. Fly-In date is October 15-18, 2015 > > We will fly the Grand Canyon, Lake Powell, Monument Valley (breakfast), Zion Canyon and Bryce Canyon (breakfast), Bullfrog Marina and Resort (breakfast). > > I have blocked off 30 rooms. We will be at the Clarion Inn with a rate of $65 (2 queen beds). I hope to have a record number of CT's and LSA aircraft for our Page Fly-In. Just like last year make the reservations early so you don't miss out and the hotel won't hold all 30 rooms forever. > > Do not wait this year. Book it now and you can cancel up to 24 hours before Oct. 15th. Get it booked and reserved, then if you have to cancel you can, but if you wait again then you may not be staying with the rest of us and at your own peril for rates and possibly a different hotel. They book darn near the whole town in October. > > "You must tell them you are with the CT Group" for your reference and the rate of $65 a night. We will arrive Thursday morning, Oct. 15th. and head home Oct. 18th. Sunday or Monday morning. Breakfast is free in the mornings. This hotel has not only a continental breakfast, but a full breakfast. > I talked to the people at the Ranch House Grill and they will cater our evening meals again. We will have evening meals together Thursday, Friday and Saturday. > > > Clarion Inn > > Ask for Illisa IF you have any issues with your reservations. > 751 South Navajo Drive, Page, AZ 86040 > 928-645-9000 > > We will fly into the Page airport - KPGA. > We are staying with Classic FBO and with our group we should get a 30 cent discount on fuel. > Classic is not the first FBO next to the runway, but the second one behind them. > > The Antelope Canyon tour and the Dam tour is open if anyone wants. These are land tours. > You guys are welcome to invite other planes that are not CT's and everyone is welcome. Find some more LSA's. > > I will develop GPS coordinates for all our routes and post them so you can enter them in your own GPS. I have a plan to better deal with all our planes for our flights so they are not crowded in the mornings or evenings. > > > Don't miss this, we always have fun. > > p.s. biggrin.gif > I would like everyone coming to shoot me an email so I can put together a roster and make name tags. If you attended last year and we have your personal info then just say you are coming. If you did not come last year then I would like the email to include: N#, Names of you and co-pilot, cell phone number, city, state. > This is a big help for me to last year to organize our fly outs since we have so many planes and gives old friends and new friends a way to contact each other if need be. > > Thanks, > Roger Lee > > The River Raft trip (don't miss it). Give me a couple more days to get this trip set up so don't call them until you see a reservation number posted. > You must refer to this Reservation Number: (to be announced) and tell them you are with the CT group. > A 1/2 day raft trip on Wed. Oct. 14th from Glen Canyon Dam down to just above Lee's Ferry. > The trip starts in Page (at 1100 hrs) where we will take a shuttle bus down below the dam. We will board a 20-22 person raft and travel down river for about 1.5 hrs. and get out for drinks and photos. Then back in and on down close to Lee's Ferry. Then we turn around a high speed boat back to the start. There is no white water just a nice trip down through the canyons. The cost for all of this is $87 a person. The phone number for the reservations is 928-645-9175. > Don't be left out, I know of at least 6 people that have already signed up so don't be late to make the boat, sign up now. They have a 48 hr. cancellation policy and you get it all back except a $7 charge. This means you will have to arrive in Page Oct. 13th. > BRING YOUR HAT, SUNGLASSES AND SUNSCREEN. > Here is the link: http://raftthecanyon...day-raft-trips/ > > What are you waiting for, let's go, I'm already signed up. ;) > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438815#438815 > > > > > > > > > > > ____________________________________________________________ > Have you been injured? > Get a free evaluation today to see what your injury case is worth. > http://thirdpartyoffers.juno.com/TGL3155/54f23a51abc5f3a512e4dmp06vuc > ________________________________________________________________________________
Date: Mar 01, 2015
Hi Gary, Got it. Look forward to seeing you there. p.s. Thanks for sending it to my regular email. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438860#438860 ________________________________________________________________________________
Subject: Rotax float exchange process
Date: Mar 10, 2015
Just to be clear on the float exchange process. There are lots of orders out there pending so please be patient as only so many orders can be filled at a time. For Kodiak (Rotax Bahamas) customers areas: For non-certified engines (UL) In the USA, and in other regions where warranty service is administered by the ROTAX distributor Kodiak (American Samoa, Antigua And Barbuda, Argentina, Aruba, Bahamas, Barbados, Belize, Bermuda, Bolivia, Brazil, Cayman Islands, Chile, Colombia, Costa Rica, Cuba, Diego Garcia, Dominica, Dominican Republic, Ecuador, El Salvador, French Guiana, Grenada, Guam, Guatemala, Guyana, Haiti, Honduras, Jamaica, Martinique, Mexico, Netherlands Antilles, Nicaragua, Panama, Paraguay, Peru, Puerto Rico, Saint Kitts And Nevis, Saint Lucia, Saint Pierre And Miquelon, Saint Vincent And The Grenadines, Suriname, Trinidad And Tobago, Turks And Caicos Islands, Uruguay, Venezuela, Virgin Islands)... Customers with non-certified (UL) engines, that have affected serial numbers must contact their respective independent Service Centre, (iSC). At that time they may purchase the parts from the iSC. When the old parts are returned and the paperwork is submitted with valid serial number, a credit will be issued back to the customer. (The iSC will require the customer to return the old floats, tagged with the engine serial number, before the customer can receive a refund.) For customers who prefer to have the parts changed by a qualified independent Rotax Maintenance Technician, (iRMT), contact your service provider directly to make appropriate arrangements. If you don't have an engine in the serial range, but did purchase individual floats within the affected time period these can be included, but you will need to have your invoice as proof of purchase. Your distributor you purchased from may be able to help you if you did not keep the invoice. p.s. Just to let people know that these floats are the same, but have a dimple on the new floats. They are the same float material, but the difference is that instead of only two test performed before shipment they now get a third test and the new test is a pressure test. This process finds any floats susceptible to sinking. Any floats that you may have with marks on them or scratches DO NOT affect the float as far as fuel absorption. Floats technically can last for the life of the engine. What could wear out is the float guide and pin from vibration and rubbing over time, but even this isn't very prevalent. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439233#439233 ________________________________________________________________________________
Subject: 5-Year Rotax Rubber Replacement
Date: Mar 16, 2015
On my RV-12, with Rotax 912ULS I am thinking of replacing all hoses with the Aircraft Specialty (AS) PTFE hoses. The 5-year replacement "kit" from Cal. Power Systems, seems to have some hoses that duplicate (more or less) those that I will be using from Aircraft Specialty. I need to know what rubber parts to purchase beyond those from AS, particularly the carb parts. Can anyone point me in the right direction? Hopefully Roger Lee can help with this....Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439440#439440 ________________________________________________________________________________
Subject: Re: 5-Year Rotax Rubber Replacement
Date: Mar 16, 2015
Just some food for thought. This is certainly a personal preference item. I have done 7-8 RV12 hose changes. Those Teflon hoses are expensive, but yes they are the best. If just the fuel aren't they $500+? They are supposed to be a 10 year hose? If you add oil hoses that has to be up around $1000. The standard rubber fuel hose would be about $15-$20. If you double that for the 10 year mark that has a pretty big price difference. The standard 13mm (1/2") oil hoses would normally cost around $35-$45 verses over $500+ for Teflon. If you are switching to the Teflon hose and since these are pre-made you will need new fittings for these new hose to fit them to the engine. They may come with them I do not know, you would hope so. They may or may not come with fire sleeve I don't know. There is a good chance they come ready to go with fittings and fire sleeve. That said you would have labor included for the second hose change and that may be around $500-$800. Depending on the shop that changes the hoses a normal full hose change parts and labor may cost any where from $2500-$4000. The high end number would be a little more expensive shops. If you use the Teflon fuel hoses you will still need: 13mm oil hose (from Spruce) 17mm coolant hose from Spruce 25mm (1") coolant hose 90 degree 17mm coolant hose carb diaphragms Carb sockets 66mm carb balance tube hose Oetiker band clamps or fuel injection clamps for standard fuel hose Fuel injection clamps for the oil line. Band-It band clamps for the fire sleeve. Fire sleeve may be re-usable if the hose lengths are the same. The thing with Spruce's kit is they assume you will take certain things apart and will need things like crush washers. The thing is you don't need to disturb the fitting just pull the hose off and replace it. I usually need need as many parts as they want to sell so when I need things I just buy specific parts and that can save quite a bit which I can then pass on to the customer. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439450#439450 ________________________________________________________________________________
Date: Mar 19, 2015
Hi Roger, Aeroquip 666 is supposed to be a service life unlimited product. Why assume a ten year replacement, instead of on-condition? Of course on the rotax we need to use real aerospace 666, not the cheaper automotive hose lacking the interior conductive carbon strip. Having said that, I will share a brief cautionary tale. I removed the crappy VDO oil pressure transducer, replacing it with a modern, aerospace rated (read expensive) transducer I mounted on the firewall. I chose Aeroquip666 with appropriate fittings from the block to the transducer. The hose and the fittings were about $100. The hose worked great for years until.....I was charging my main battery and the ground momentarily made contact with the stainless braid of this hose. Unknown to me at the time, the 20 Amp charge current perforated the teflon liner. No obvious sign on the ground... About a mile off the runway, my cockpit filled with smoke from oil spray onto my muffler. Under engine running oil pressure, that pinhole sprayed quite a bit of oil. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439591#439591 ________________________________________________________________________________
Date: Mar 20, 2015
Rooms are going quick. I just talked to the Hotel and managed to book 5 more rooms. The total rooms now is 35 and we already have 25 reserved. If you are going to come don't wait too long before you reserve a room. 10 more rooms isn't very many. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439687#439687 ________________________________________________________________________________
Date: Mar 20, 2015
fascinating post Your event makes me think about going beyond basics that have demonstrated proven reliability over time BJ Kitfox IV 912 > > Hi Roger, > > Aeroquip 666 is supposed to be a service life unlimited product. Why > assume a ten year replacement, instead of on-condition? > > Of course on the rotax we need to use real aerospace 666, not the cheaper > automotive hose lacking the interior conductive carbon strip. > > Having said that, I will share a brief cautionary tale. > > I removed the crappy VDO oil pressure transducer, replacing it with > a modern, aerospace rated (read expensive) transducer I mounted on the > firewall. I chose Aeroquip666 with appropriate fittings from the block to > the transducer. The hose and the fittings were about $100. > > The hose worked great for years until.....I was charging my main battery > and the ground momentarily made contact with the stainless braid of this > hose. Unknown to me at the time, the 20 Amp charge current perforated > the teflon liner. No obvious sign on the ground... About a mile off the > runway, my cockpit filled with smoke from oil spray onto my muffler. > Under engine running oil pressure, that pinhole sprayed quite a bit of > oil. > > -------- > Ira N224XS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439591#439591 > > ________________________________________________________________________________
Subject: Engine noise in Radio and Headset
Date: Mar 31, 2015
I have an Allegro 2000 E-LSA with a Rotax 912 UL engine using the standard Rotax Voltage regulator. After 600 +/- hours I am getting a lot of =9Cnoise=9D in my head sets when I use the radio push-to-talk transmit button. The radio is an ICOM IC-A200 VHF Transceiver using a Comant CI 121 VHF Antenna. When using the P-T button to transmit I can actually hear the engine rpm, especially at low rpms. At higher rpms the noise is not as bad but it is still there as noise. The voltage regulator is wired per the Rotax engine wiring diagram with the addition of two 10,000 Mf capacitors in parallel. Can anyone give me advice as to how to eliminate this =9Cnoise=9D? Hugh G. McKay III, P.E. Fellow, L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net Allegro 2000 E-LSA N661WW Rotax 912 UL 689 hours ________________________________________________________________________________
Subject: Re: Engine noise in Radio and Headset
Date: Mar 31, 2015
Hugh, I would check the noise canceling capacitors. They do fail with exposure to heat and humidity and they are not hard to check. The following document will help you to understand the various failure modes of the different types of capacitors. http://www.electrocube.com/electrocube/assets/File/documentation-files/capac itor-documents/electrocube-tech-bulletin-why-capacitors-fail.pdf Good luck, Larry Edson N4362C Sent from my iPad > On Mar 31, 2015, at 4:26 PM, Hugh McKay wrote: > > I have an Allegro 2000 E-LSA with a Rotax 912 UL engine using the standard Rotax Voltage regulator. After 600 +/- hours I am getting a lot of =9C noise=9D in my head sets when I use the radio push-to-talk transmit bu tton. The radio is an ICOM IC-A200 VHF Transceiver using a Comant CI 121 VHF Antenna. When using the P-T button to transmit I can actually hear the engi ne rpm, especially at low rpms. At higher rpms the noise is not as bad but i t is still there as noise. The voltage regulator is wired per the Rotax engi ne wiring diagram with the addition of two 10,000 Mf capacitors in parallel. > > Can anyone give me advice as to how to eliminate this =9Cnoise =9D? > > Hugh G. McKay III, P.E. Fellow, L.M. ASCE > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > Ph. 704-661-8271 > Fax 704-483-5466 > email hgmckay(at)bellsouth.net > Allegro 2000 E-LSA N661WW > Rotax 912 UL 689 hours > > ________________________________________________________________________________
Date: Apr 01, 2015
Also worth checking all the earth connections, including the aerial for corrosion, not just visually. Undo and clean all connections. Particularly, check the regulator earth. Regards Brian Davies From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Larry Edson Sent: 01 April 2015 02:41 Subject: Re: RotaxEngines-List: Engine noise in Radio and Headset Hugh, I would check the noise canceling capacitors. They do fail with exposure to heat and humidity and they are not hard to check. The following document will help you to understand the various failure modes of the different types of capacitors. http://www.electrocube.com/electrocube/assets/File/documentation-files/ca pacitor-documents/electrocube-tech-bulletin-why-capacitors-fail.pdf Good luck, Larry Edson N4362C Sent from my iPad On Mar 31, 2015, at 4:26 PM, Hugh McKay wrote: I have an Allegro 2000 E-LSA with a Rotax 912 UL engine using the standard Rotax Voltage regulator. After 600 +/- hours I am getting a lot of =9Cnoise=9D in my head sets when I use the radio push-to-talk transmit button. The radio is an ICOM IC-A200 VHF Transceiver using a Comant CI 121 VHF Antenna. When using the P-T button to transmit I can actually hear the engine rpm, especially at low rpms. At higher rpms the noise is not as bad but it is still there as noise. The voltage regulator is wired per the Rotax engine wiring diagram with the addition of two 10,000 Mf capacitors in parallel. Can anyone give me advice as to how to eliminate this =9Cnoise=9D? Hugh G. McKay III, P.E. Fellow, L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net Allegro 2000 E-LSA N661WW Rotax 912 UL 689 hours ________________________________________________________________________________
Date: Apr 02, 2015
Subject: Re: Engine noise in Radio and Headset Engine noise
in Radio a I agree with Brian, That was the cause on my bird. I disconnected the leads,cleaned them and sprayed with "contact cleaner"...did the job Dick Maddux 912 UL ________________________________________________________________________________
Subject: New Aero Shell Sport Plus 4
Date: Apr 22, 2015
The new formula changed the wear additive package (increased the levels of anti-wear materials) and the most significant is a change of the base oil used. This is now a custom formula for Rotax and not anything like the motorcycle blend that they started with. It took more than 4 years of testing in Rotax engines. I think it was 8 blends they tested long term in flight school engines back at the factory that all ran up to TBO. They then selected the best one of the batch." http://www.transair.co.uk/sp+AeroShell-Sport-PLUS-4-Oil-Aeroshell-Sport-Plus-4-Oil-12x-1-Ltr-ROTAX-912-914-Series+2675CASE "Thomas Uhr, General Manager BRP-Powertrain said, The collaboration of BRP-Rotax with Shell goes back to 2004. Our decision to work with the AeroShell team on the development of the new formulation for AeroShell Oil Sport Plus 4 was based on the benefits the new formulation would provide to our customers. This joint development is supported by 40 years of Rotax aircraft engines, 25 years and more than 50.000 engines produced within the Rotax 912/914 engines with more than 45 million hours of flight." -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441118#441118 ________________________________________________________________________________
Date: Apr 22, 2015
Subject: Re: New Aero Shell Sport Plus 4
And only $14 per quart... On 4/22/2015 8:04 AM, Roger Lee wrote: > > The new formula changed the wear additive package (increased the levels of anti-wear materials) and the most significant is a change of the base oil used. This is now a custom formula for Rotax and not anything like the motorcycle blend that they started with. It took more than 4 years of testing in Rotax engines. I think it was 8 blends they tested long term in flight school engines back at the factory that all ran up to TBO. They then selected the best one of the batch." > > > http://www.transair.co.uk/sp+AeroShell-Sport-PLUS-4-Oil-Aeroshell-Sport-Plus-4-Oil-12x-1-Ltr-ROTAX-912-914-Series+2675CASE > > > > "Thomas Uhr, General Manager BRP-Powertrain said, The collaboration of BRP-Rotax with Shell goes back to 2004. Our decision to work with the AeroShell team on the development of the new formulation for AeroShell Oil Sport Plus 4 was based on the benefits the new formulation would provide to our customers. This joint development is supported by 40 years of Rotax aircraft engines, 25 years and more than 50.000 engines produced within the Rotax 912/914 engines with more than 45 million hours of flight." > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=441118#441118 > > ________________________________________________________________________________
Date: Apr 22, 2015
Subject: Rotax HD Starter for a 912 on ebay
I'm pretty sure it has less than 690 hours and it is in good working condition. If anyone is interested. ________________________________________________________________________________
Date: Apr 22, 2015
I would like to know what is wrong with the currently approved oils that would warrant use of this oil? Doesn't make much sense to me, but I am sure it does to Rotax! Hugh G. McKay III, P.E. Fellow, L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com -----Original Message----- From: Guy Buchanan Sent: Wednesday, April 22, 2015 11:20 AM Subject: Re: RotaxEngines-List: New Aero Shell Sport Plus 4 And only $14 per quart... On 4/22/2015 8:04 AM, Roger Lee wrote: > > The new formula changed the wear additive package (increased the levels of > anti-wear materials) and the most significant is a change of the base oil > used. This is now a custom formula for Rotax and not anything like the > motorcycle blend that they started with. It took more than 4 years of > testing in Rotax engines. I think it was 8 blends they tested long term > in flight school engines back at the factory that all ran up to TBO. They > then selected the best one of the batch." > > http://www.transair.co.uk/sp+AeroShell-Sport-PLUS-4-Oil-Aeroshell-Sport-Plus-4-Oil-12x-1-Ltr-ROTAX-912-914-Series+2675CASE > "Thomas Uhr, General Manager BRP-Powertrain said, The collaboration > of BRP-Rotax with Shell goes back to 2004. Our decision to work with the > AeroShell team on the development of the new formulation for AeroShell Oil > Sport Plus 4 was based on the benefits the new formulation would provide > to our customers. This joint development is supported by 40 years of Rotax > aircraft engines, 25 years and more than 50.000 engines produced within > the Rotax 912/914 engines with more than 45 million hours of flight." > > -------- > Roger Lee > Tucson, Az. > Light Sport Repairman - Maintenance Rated > Rotax Repair Center - Heavy Maint. Rated > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=441118#441118 > > ________________________________________________________________________________
Date: Apr 23, 2015
VGFsa2luZyB3aXRoIFNoZWxsIG9pbCBlbmdpbmVlcnMgYXQgU2VicmluZyBMU0EgRVhQTyBzaG9y dGx5IGFmdGVyIFNoZWxsICYgVG8gdGF4IGludHJvZHVjZWQgU3BvcnQgUGx1cyA0IG9pbCBmb3Ig b3VyIDkxMnMsIMKgYW4gYXNobGVzcyBkaXNwZXJzYW50IHdhcyBhZGRlZCB0byBob2xkIGxlYWQg aW4gc3VzcGVuc2lvbiB3aXRoaW4gdGhlIG9pbCBzbyB0aGUgc3VzcGVuZGVkIGxlYWQgY2FuIGJl IGNhcnJpZWQgb3V0IGF0IG9pbCBjaGFuZ2UgcmF0aGVyIHRoYW4gYWxsb3cgZXhjZXNzIGxlYWQg dG8gYWNjdW11bGF0ZSBhcyBzbHVkZ2UgaW4gdGhlIGdlYXIgY2FzZSBhbmQgZWxzZXdoZXJlIGlu IHRoZSBlbmdpbmUgd2hlcmUgaXQgY2FuIGNhdXNlIGRhbWFnZS4KQSBsZWFkIGRpc3BlcnNhbnQg YWRkaXRpdmUgwqBwYWNrYWdlIGlzIG5vdCBuZWVkZWQgaW4gbW90b3JjeWNsZSBlbmdpbmUgb2ls IHRoYXQgd2UgaGF2ZSBiZWVuIHVzaW5nIGluIG91ciBSb3RheCA5MTIgc2VyaWVzIGVuZ2luZXMs IGJlY2F1c2UgbW9zdCBtb3RvcmN5Y2xlcyB1c2UgdW5sZWFkZWQgZ2FzLsKgClNoZWxsIGRvZXMg bm90IGFkdmVydGlzZSB0aGF0IGFzaGxlc3MgZGVwcmVzc2FudCAoQUQpIGlzIGluIHRoZSBvaWwg Zm9ybXVsYXRlZCBmb3Igb3VyIDkxMnMgYmVjYXVzZSBMeWNvbWluZyAmIENvbnRpbmVudGFsIG93 bmVycyBtaWdodCB0aGluayB0aGUgb2lsIGNhbiBiZSB1c2VkIGluIHRoZWlyIGFpcmNyYWZ0IGVu Z2luZXMsIHdoaWNoIGlzIG5vdCB0aGUgY2FzZSBiZWNhdXNlIHRoZSBhbnRpIHdlYXIgYWRkaXRp dmUgcGFja2FnZSBpbiBTcG9ydCBQbHVzIDQgY2FuIGNhdXNlIGNvbWJ1c3Rpb24gY2hhbWJlciBk ZXBvc2l0cyB0aGF0IGxlYWQgdG8gZGV0b25hdGlvbiBpbiBhaXIgY29vbGVkIGFpcmNyYWZ0IGVu Z2luZXMgd2hpY2ggaGF2ZSBtdWNoIGdyZWF0ZXIgYmxvdyBieSBmcm9tIHdpZGUgcGlzdG9uIHRv IGN5bGluZGVyIHRvbGVyYW5jZXMgdGhhbiBvdXIgOTEycy4KVGhpcyBpcyBtb3JlIHNwZWNpZmMg dGhhbiBzb21lIG9mIHRoZSBpbmZvIHdlIGdldCBhbmQgb2J2aW91c2x5IGl0IHdvdWxkIGJlIGJl c3QgdG8gZ2V0IHRoZSBtb3N0IGN1cnJlbnQgaW5mbyBkaXJlY3RseSBmcm9tIFNoZWxsIG9yIFJv dGF4IHJhdGhlciB0aGFuIHNlY29uZCBoYW5kIHRocnUgbXkgdW5kZXJzdGFuZGluZyBvZiB0aGUg bWF0dGVyLiBJZiBJIGNhdGNoIHVwIHdpdGggYSBTaGVsbCBvciBSb3RheCByZXAgaGVyZSBhdCBT IE4gRiB3aG8gaXMgdGVjaG5pY2FsbHkgdXAgb24gU3BvcnQgUGx1cyA0IEknbGwgdHJ5IHRvIHBp Y2sgaGlzIGJyYWluIGFuZCByZXBvcnQgYmFjayBpZiBkaWZmZXJlbnQuCkJKIEtpdGZveCBJViwg wqBSb3RheCA5MTIKCgpTZW50IGZyb20gbXkgVmVyaXpvbiBXaXJlbGVzcyA0RyBMVEUgc21hcnRw aG9uZQoKCi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS0KRnJvbTogSHVnaCBNY0th eSA8aGdtY2theUBiZWxsc291dGgubmV0PiAKRGF0ZTowNC8yMi8yMDE1ICA3OjE0IFBNICAoR01U LTA1OjAwKSAKVG86IHJvdGF4ZW5naW5lcy1saXN0QG1hdHJvbmljcy5jb20gClN1YmplY3Q6IFJl OiBSb3RheEVuZ2luZXMtTGlzdDogTmV3IEFlcm8gU2hlbGwgU3BvcnQgUGx1cyA0IAoKLS0+IFJv dGF4RW5naW5lcy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiSHVnaCBNY0theSIgPGhnbWNrYXlA YmVsbHNvdXRoLm5ldD4KCkkgd291bGQgbGlrZSB0byBrbm93IHdoYXQgaXMgd3Jvbmcgd2l0aCB0 aGUgY3VycmVudGx5IGFwcHJvdmVkIG9pbHMgdGhhdCAKd291bGQgd2FycmFudCB1c2Ugb2YgdGhp cyBvaWw/IERvZXNuJ3QgbWFrZSBtdWNoIHNlbnNlIHRvIG1lLCBidXQgSSBhbSBzdXJlIAppdCBk b2VzIHRvIFJvdGF4IQoKSHVnaCBHLiBNY0theSBJSUksIFAuRS4gRmVsbG93LCBMLk0uIEFTQ0UK U2VuaW9yIENvbnN1bHRhbnQKV29ybGR3aWRlIEVuZ2luZWVyaW5nIEluYy4KNDA5MCBOb3J0aCBO QyBId3kuIDE2CkRlbnZlciwgTkMgMjgwMzcKClBoLiA3MDQtNjYxLTgyNzEKRmF4IDcwNC00ODMt NTQ2NgplbWFpbCBoZ21ja2F5QGJlbGxzb3V0aC5uZXQKaHR0cDovL3d3dy53d2VnZW8uY29tCi0t LS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tIApGcm9tOiBHdXkgQnVjaGFuYW4KU2VudDogV2VkbmVz ZGF5LCBBcHJpbCAyMiwgMjAxNSAxMToyMCBBTQpUbzogcm90YXhlbmdpbmVzLWxpc3RAbWF0cm9u aWNzLmNvbQpTdWJqZWN0OiBSZTogUm90YXhFbmdpbmVzLUxpc3Q6IE5ldyBBZXJvIFNoZWxsIFNw b3J0IFBsdXMgNAoKLS0+IFJvdGF4RW5naW5lcy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBHdXkg QnVjaGFuYW4gPGdlYnVjaGFuYW5AY294Lm5ldD4KCkFuZCBvbmx5ICQxNCBwZXIgcXVhcnQuLi4K Ck9uIDQvMjIvMjAxNSA4OjA0IEFNLCBSb2dlciBMZWUgd3JvdGU6Cj4gLS0+IFJvdGF4RW5naW5l cy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiUm9nZXIgTGVlIiA8c3NhZGl2ZXIxQHlhaG9vLmNv bT4KPgo+IFRoZSBuZXcgZm9ybXVsYSBjaGFuZ2VkIHRoZSB3ZWFyIGFkZGl0aXZlIHBhY2thZ2Ug KGluY3JlYXNlZCB0aGUgbGV2ZWxzIG9mIAo+IGFudGktd2VhciBtYXRlcmlhbHMpIGFuZCB0aGUg bW9zdCBzaWduaWZpY2FudCBpcyBhIGNoYW5nZSBvZiB0aGUgYmFzZSBvaWwgCj4gdXNlZC4gIFRo aXMgaXMgbm93IGEgY3VzdG9tIGZvcm11bGEgZm9yIFJvdGF4IGFuZCBub3QgYW55dGhpbmcgbGlr ZSB0aGUgCj4gbW90b3JjeWNsZSBibGVuZCB0aGF0IHRoZXkgc3RhcnRlZCB3aXRoLiAgSXQgdG9v ayBtb3JlIHRoYW4gNCB5ZWFycyBvZiAKPiB0ZXN0aW5nIGluIFJvdGF4IGVuZ2luZXMuICBJIHRo aW5rIGl0IHdhcyA4IGJsZW5kcyB0aGV5IHRlc3RlZCBsb25nIHRlcm0gCj4gaW4gZmxpZ2h0IHNj aG9vbCBlbmdpbmVzIGJhY2sgYXQgdGhlIGZhY3RvcnkgdGhhdCBhbGwgcmFuIHVwIHRvIFRCTy4g IFRoZXkgCj4gdGhlbiBzZWxlY3RlZCB0aGUgYmVzdCBvbmUgb2YgdGhlIGJhdGNoLiIKPiAKPiBo dHRwOi8vd3d3LnRyYW5zYWlyLmNvLnVrL3NwK0Flcm9TaGVsbC1TcG9ydC1QTFVTLTQtT2lsLUFl cm9zaGVsbC1TcG9ydC1QbHVzLTQtT2lsLTEyeC0xLUx0ci1ST1RBWC05MTItOTE0LVNlcmllcysy Njc1Q0FTRQo+ICAgIlRob21hcyBVaHIsIEdlbmVyYWwgTWFuYWdlciBCUlAtUG93ZXJ0cmFpbiBz YWlkLCDDouKCrMWTVGhlIGNvbGxhYm9yYXRpb24gCj4gb2YgQlJQLVJvdGF4IHdpdGggU2hlbGwg Z29lcyBiYWNrIHRvIDIwMDQuIE91ciBkZWNpc2lvbiB0byB3b3JrIHdpdGggdGhlIAo+IEFlcm9T aGVsbCB0ZWFtIG9uIHRoZSBkZXZlbG9wbWVudCBvZiB0aGUgbmV3IGZvcm11bGF0aW9uIGZvciBB ZXJvU2hlbGwgT2lsIAo+IFNwb3J0IFBsdXMgNCB3YXMgYmFzZWQgb24gdGhlIGJlbmVmaXRzIHRo ZSBuZXcgZm9ybXVsYXRpb24gd291bGQgcHJvdmlkZSAKPiB0byBvdXIgY3VzdG9tZXJzLiBUaGlz IGpvaW50IGRldmVsb3BtZW50IGlzIHN1cHBvcnRlZCBieSA0MCB5ZWFycyBvZiBSb3RheCAKPiBh aXJjcmFmdCBlbmdpbmVzLCAyNSB5ZWFycyBhbmQgbW9yZSB0aGFuIDUwLjAwMCBlbmdpbmVzIHBy b2R1Y2VkIHdpdGhpbiAKPiB0aGUgUm90YXggOTEyLzkxNCBlbmdpbmVzIHdpdGggbW9yZSB0aGFu IDQ1IG1pbGxpb24gaG91cnMgb2YgZmxpZ2h0LiIKPgo+IC0tLS0tLS0tCj4gUm9nZXIgTGVlCj4g VHVjc29uLCBBei4KPiBMaWdodCBTcG9ydCBSZXBhaXJtYW4gLSBNYWludGVuYW5jZSBSYXRlZAo+ IFJvdGF4IFJlcGFpciBDZW50ZXIgLSBIZWF2eSBNYWludC4gUmF0ZWQKPiBIb21lIDUyMC01NzQt MTA4MCAgVFJZIEhPTUUgRklSU1QKPiBDZWxsIDUyMC0zNDktNzA1Ngo+Cj4KPgo+Cj4gUmVhZCB0 aGlzIHRvcGljIG9ubGluZSBoZXJlOgo+Cj4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3Zp ZXd0b3BpYy5waHA/cD00NDExMTgjNDQxMTE4Cj4KPgo+Cj4KPgo+Cj4KPgo+Cj4KCgoKCgpfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQpfLT0gICAgICAgICAgLSBUaGUgUm90YXhFbmdpbmVzLUxpc3QgRW1haWwgRm9ydW0gLQpfLT0g VXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0 aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLApfLT0g QXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQ aG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT0gICAtLT4gaHR0cDovL3d3dy5t YXRyb25pY3MuY29tL05hdmlnYXRvcj9Sb3RheEVuZ2luZXMtTGlzdApfLT0KXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAg ICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRl bnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0KXy09ICAgLS0+IGh0dHA6 Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgIC0gTGlzdCBD b250cmlidXRpb24gV2ViIFNpdGUgLQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBz dXBwb3J0IQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExp c3QgQWRtaW4uCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9u Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09CgoKCg= ________________________________________________________________________________
Date: Apr 23, 2015
Hi Hugh, Nothing really wrong with the old Aero Shell, they justed wanted to tune it up and make it better for its specific 912 application. They went through a lot of time and money to try and find areas they could improve on. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441166#441166 ________________________________________________________________________________
Date: Apr 23, 2015
I wonder if this means we can now burn 100LL AvGas in our 912 engines without penalty of the previously required cleaning of the gear reduction clutch and more frequent oil changes? On Thu, Apr 23, 2015 at 4:47 AM, bjones wrote: > Talking with Shell oil engineers at Sebring LSA EXPO shortly after Shell & > To tax introduced Sport Plus 4 oil for our 912s, an ashless dispersant w as > added to hold lead in suspension within the oil so the suspended lead can > be carried out at oil change rather than allow excess lead to accumulate as > sludge in the gear case and elsewhere in the engine where it can cause > damage. > A lead dispersant additive package is not needed in motorcycle engine oi l > that we have been using in our Rotax 912 series engines, because most > motorcycles use unleaded gas. > Shell does not advertise that ashless depressant (AD) is in the oil > formulated for our 912s because Lycoming & Continental owners might think > the oil can be used in their aircraft engines, which is not the case > because the anti wear additive package in Sport Plus 4 can cause combusti on > chamber deposits that lead to detonation in air cooled aircraft engines > which have much greater blow by from wide piston to cylinder tolerances > than our 912s. > This is more specifc than some of the info we get and obviously it would > be best to get the most current info directly from Shell or Rotax rather > than second hand thru my understanding of the matter. If I catch up with a > Shell or Rotax rep here at S N F who is technically up on Sport Plus 4 I' ll > try to pick his brain and report back if different. > BJ Kitfox IV, Rotax 912 > > > Sent from my Verizon Wireless 4G LTE smartphone > > > -------- Original message -------- > From: Hugh McKay <hgmckay(at)bellsouth.net> > Date:04/22/2015 7:14 PM (GMT-05:00) > To: rotaxengines-list(at)matronics.com > Subject: Re: RotaxEngines-List: New Aero Shell Sport Plus 4 > > hgmckay(at)bellsouth.net> > > I would like to know what is wrong with the currently approved oils that > would warrant use of this oil? Doesn't make much sense to me, but I am > sure > it does to Rotax! > > Hugh G. McKay III, P.E. Fellow, L.M. ASCE > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > Ph. 704-661-8271 > Fax 704-483-5466 > email hgmckay(at)bellsouth.net > http://www.wwegeo.com > -----Original Message----- > From: Guy Buchanan > Sent: Wednesday, April 22, 2015 11:20 AM > To: rotaxengines-list(at)matronics.com > Subject: Re: RotaxEngines-List: New Aero Shell Sport Plus 4 > > > And only $14 per quart... > > On 4/22/2015 8:04 AM, Roger Lee wrote: > ssadiver1(at)yahoo.com> > > > > The new formula changed the wear additive package (increased the levels > of > > anti-wear materials) and the most significant is a change of the base > oil > > used. This is now a custom formula for Rotax and not anything like the > > motorcycle blend that they started with. It took more than 4 years of > > testing in Rotax engines. I think it was 8 blends they tested long ter m > > in flight school engines back at the factory that all ran up to TBO. > They > > then selected the best one of the batch." > > > > > http://www.transair.co.uk/sp+AeroShell-Sport-PLUS-4-Oil-Aeroshell-Sport-P lus-4-Oil-12x-1-Ltr-ROTAX-912-914-Series+2675CASE > > "Thomas Uhr, General Manager BRP-Powertrain said, =C3=A2=82=AC=C5 =93The collaboration > > of BRP-Rotax with Shell goes back to 2004. Our decision to work with th e > > AeroShell team on the development of the new formulation for AeroShell > Oil > > Sport Plus 4 was based on the benefits the new formulation would provid e > > to our customers. This joint development is supported by 40 years of > Rotax > > aircraft engines, 25 years and more than 50.000 engines produced within > > the Rotax 912/914 engines with more than 45 million hours of flight." > > > > -------- > > Roger Lee > > Tucson, Az. > > Light Sport Repairman - Maintenance Rated > > Rotax Repair Center - Heavy Maint. Rated > > Home 520-574-1080 TRY HOME FIRST > > Cell 520-349-7056 > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=441118#441118 > > > > > > > > > > > > > > > > > > > > > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Apr 23, 2015
Great question! anyone with authority like to comment on that? On Apr 23, 2015 4:19 PM, "Dennis Tubbs" wrote: > I wonder if this means we can now burn 100LL AvGas in our 912 engines > without penalty of the previously required cleaning of the gear reduction > clutch and more frequent oil changes? > > On Thu, Apr 23, 2015 at 4:47 AM, bjones wrote: > >> Talking with Shell oil engineers at Sebring LSA EXPO shortly after Shell >> & To tax introduced Sport Plus 4 oil for our 912s, an ashless dispersan t >> was added to hold lead in suspension within the oil so the suspended lea d >> can be carried out at oil change rather than allow excess lead to >> accumulate as sludge in the gear case and elsewhere in the engine where it >> can cause damage. >> A lead dispersant additive package is not needed in motorcycle engine >> oil that we have been using in our Rotax 912 series engines, because mos t >> motorcycles use unleaded gas. >> Shell does not advertise that ashless depressant (AD) is in the oil >> formulated for our 912s because Lycoming & Continental owners might thin k >> the oil can be used in their aircraft engines, which is not the case >> because the anti wear additive package in Sport Plus 4 can cause combust ion >> chamber deposits that lead to detonation in air cooled aircraft engines >> which have much greater blow by from wide piston to cylinder tolerances >> than our 912s. >> This is more specifc than some of the info we get and obviously it would >> be best to get the most current info directly from Shell or Rotax rather >> than second hand thru my understanding of the matter. If I catch up with a >> Shell or Rotax rep here at S N F who is technically up on Sport Plus 4 I 'll >> try to pick his brain and report back if different. >> BJ Kitfox IV, Rotax 912 >> >> >> Sent from my Verizon Wireless 4G LTE smartphone >> >> >> -------- Original message -------- >> From: Hugh McKay <hgmckay(at)bellsouth.net> >> Date:04/22/2015 7:14 PM (GMT-05:00) >> To: rotaxengines-list(at)matronics.com >> Subject: Re: RotaxEngines-List: New Aero Shell Sport Plus 4 >> >> hgmckay(at)bellsouth.net> >> >> I would like to know what is wrong with the currently approved oils that >> would warrant use of this oil? Doesn't make much sense to me, but I am >> sure >> it does to Rotax! >> >> Hugh G. McKay III, P.E. Fellow, L.M. ASCE >> Senior Consultant >> Worldwide Engineering Inc. >> 4090 North NC Hwy. 16 >> Denver, NC 28037 >> >> Ph. 704-661-8271 >> Fax 704-483-5466 >> email hgmckay(at)bellsouth.net >> http://www.wwegeo.com >> -----Original Message----- >> From: Guy Buchanan >> Sent: Wednesday, April 22, 2015 11:20 AM >> To: rotaxengines-list(at)matronics.com >> Subject: Re: RotaxEngines-List: New Aero Shell Sport Plus 4 >> t >> > >> >> And only $14 per quart... >> >> On 4/22/2015 8:04 AM, Roger Lee wrote: >> ssadiver1(at)yahoo.com> >> > >> > The new formula changed the wear additive package (increased the level s >> of >> > anti-wear materials) and the most significant is a change of the base >> oil >> > used. This is now a custom formula for Rotax and not anything like th e >> > motorcycle blend that they started with. It took more than 4 years of >> > testing in Rotax engines. I think it was 8 blends they tested long >> term >> > in flight school engines back at the factory that all ran up to TBO. >> They >> > then selected the best one of the batch." >> > >> > >> http://www.transair.co.uk/sp+AeroShell-Sport-PLUS-4-Oil-Aeroshell-Sport- Plus-4-Oil-12x-1-Ltr-ROTAX-912-914-Series+2675CASE >> > "Thomas Uhr, General Manager BRP-Powertrain said, =C3=A2=82=AC=C5 =93The >> collaboration >> > of BRP-Rotax with Shell goes back to 2004. Our decision to work with >> the >> > AeroShell team on the development of the new formulation for AeroShell >> Oil >> > Sport Plus 4 was based on the benefits the new formulation would >> provide >> > to our customers. This joint development is supported by 40 years of >> Rotax >> > aircraft engines, 25 years and more than 50.000 engines produced withi n >> > the Rotax 912/914 engines with more than 45 million hours of flight." >> > >> > -------- >> > Roger Lee >> > Tucson, Az. >> > Light Sport Repairman - Maintenance Rated >> > Rotax Repair Center - Heavy Maint. Rated >> > Home 520-574-1080 TRY HOME FIRST >> > Cell 520-349-7056 >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=441118#441118 >> > >> > >> > >> > >> > >> > >> > >> > >> >http://www --> htt=EF=BD -Matt Dralle, List >> Admin.<======= >> >> >> >> <http://forums.matronics.com> >> > > * > =========== www.matronics.com/Navigator?RotaxEngines-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Apr 23, 2015
100LL, lead is lead no matter what oil. If you are using 100LL then you need semi synthetic and not full synthetic. If you are using 91 oct. then either oil is okay. For the 1500 hr. Engines or a 2000 hr. Engine using lead more than 30% of the time the gearbox gets inspected and cleaned at 600 hrs. If you fail to do this the overload clutch at about 800 hours will be leaded enough to be non functional. The 2000 hr. Engines using91 oct. has a 1000 hr. Gearbox inspection. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441195#441195 ________________________________________________________________________________
Date: Apr 25, 2015
Really?=0AShell's website merely confirms that the packaging has been changed; the oil remains the same as previously. It's n ot new.=0A=0A=0ADuncan McF.=0A=0A=0A=0A-----Original Message-----=0AFrom: Roger Lee =0ATo: rotaxengines-list(at)matronics.com=0ASe nt: Wed, 22 Apr 2015 16:16=0ASubject: RotaxEngines-List: New Aer o Shell Sport Plus 4=0A=0A=0A--> RotaxEngines-List message posted by: "Roger Lee" =0A=0AThe new formula changed the wear additive package (increased the levels of =0Aanti-wear materials) and the most significant is a change of the base oil used. =0AThis is now a custom formula for Rotax and not anything like the motorcycle =0Ablend that they started wi th. It took more than 4 years of testing in Rotax =0Aen gines. I think it was 8 blends they tested long term in flight school engines =0Aback at the factory that all ran up to TBO. They then selected the best one of =0Athe ba tch."=0A =0A =0Ahttp://www.transair.co.uk/sp+AeroShell-Sport-PLUS-4-Oil-Aero shell-Sport-Plus-4-Oil-12x-1-Ltr-ROTAX-912-914-Series+2675CASE=0A =0A =0A =0A"Thomas Uhr, General Manager BRP-Powertrain said, =C3=A2=82=AC =C5=93The collaboration of =0ABRP-Rotax with Shell goes back to 2004. Our decision to work with the AeroShell =0Ateam on the development of the new formulation for AeroShell Oil Sport Plus 4 =0Awas based on the benefits the new formulation woul d provide to our customers. =0AThis joint development is suppo rted by 40 years of Rotax aircraft engines, 25 =0Ayears and more than 50.000 engines produced within the Rotax 912/914 eng ines =0Awith more than 45 million hours of flight."=0A=0A------- -=0ARoger Lee=0ATucson, Az.=0ALight Sport Repairman - Maintenance Rated=0ARotax Repair Center - Heavy Maint. Rated=0AHome 520-574-10 80 TRY HOME FIRST=0ACell 520-349-7056=0A=0A=0A=0A=0ARead this top ic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=441118#44 =========================== =========================== =========================== -Matt Dralle, Li =========================== =========================== =====0A=0A=0A=0A=0A =0A ________________________________________________________________________________
Date: Apr 25, 2015
Subject: Old style 912ULS SMD module up on ebay
I converted my older 912 USL to the soft-start start modules. These have 690 hours on them and worked fine when I removed them. Rotax part number 966 721. Lockwood sells these new for more than $1000. They might be useful for spares but I recommend against trying to change them in the air. ________________________________________________________________________________
Date: Apr 26, 2015
Hi Duncan, The oil is a new formulation. It isn't the same. The additive package and the base stock has been altered. Got this right from Rotax. They have been working on the new formula for the last 4 years and tried some different combinations. The reason it took so long is that you have to have time to put a bunch of hours on engines and then tear them down. The new red bottle is to help delineate from the older formula in the black bottle. I'll be back at Rotax in three weeks and see what additional info I can get. -------- Roger Lee Tucson, Az. Light Sport Repairman - Maintenance Rated Rotax Repair Center - Heavy Maint. Rated Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441339#441339 ________________________________________________________________________________
Subject: 912 rough running below 3000 rpm
From: "flynn elliott" <foxflynn(at)worldonline.co.za>
Date: May 22, 2015
Hi Guys, could really use some help with a 912s. After leaving my Foxbat for two months , she started up just fine as usual but ran as rough as hell untill 3000rpm and up where the motor runs smooth as silk. As always the fuel had been drained and fresh put in after the layup. We have since cleaned the carbs, put new float bowl gaskets, a fresh set of plugs and had my A P balance the carbs, which were real close anyway. The start up is instant as always has been, the mag drop is inconsistant, sometimes between 100 and 200 and very rough below below 3000rpm yet back to its usual 50rpm drop above. Original plugs went back in and gave the same result. I flew for half an hour yesterday in the hope of clearing the problem but no way, as I closed the throttle for landing we were back to a very rough motor. Any help would be more than appreciated. Thanks Flynn Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442457#442457 ________________________________________________________________________________
Date: May 22, 2015
Insure both idle jets are completely open. Over the years I have discovered a rough or no run 912ULS below 3000 rpm is idle jet related. Idle jet is extremely small. A tiny bit of trash makes a lot of difference on fuel flow. For what it is worth. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of flynn elliott Sent: Friday, May 22, 2015 11:12 AM Subject: RotaxEngines-List: 912 rough running below 3000 rpm Hi Guys, could really use some help with a 912s. After leaving my Foxbat for two months , she started up just fine as usual but ran as rough as hell untill 3000rpm and up where the motor runs smooth as silk. As always the fuel had been drained and fresh put in after the layup. We have since cleaned the carbs, put new float bowl gaskets, a fresh set of plugs and had my A P balance the carbs, which were real close anyway. The start up is instant as always has been, the mag drop is inconsistant, sometimes between 100 and 200 and very rough below below 3000rpm yet back to its usual 50rpm drop above. Original plugs went back in and gave the same result. I flew for half an hour yesterday in the hope of clearing the problem but no way, as I closed the throttle for landing we were back to a very rough motor. Any help would be more than appreciated. Thanks Flynn Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442457#442457 ________________________________________________________________________________
From: "Flynn Elliott" <foxflynn(at)worldonline.co.za>
Date: May 22, 2015
Thanks John, will pull them out and double check Again . -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of John Hauck Sent: 22 May 2015 06:25 PM Subject: RE: RotaxEngines-List: 912 rough running below 3000 rpm --> Insure both idle jets are completely open. Over the years I have discovered a rough or no run 912ULS below 3000 rpm is idle jet related. Idle jet is extremely small. A tiny bit of trash makes a lot of difference on fuel flow. For what it is worth. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of flynn elliott Sent: Friday, May 22, 2015 11:12 AM Subject: RotaxEngines-List: 912 rough running below 3000 rpm Hi Guys, could really use some help with a 912s. After leaving my Foxbat for two months , she started up just fine as usual but ran as rough as hell untill 3000rpm and up where the motor runs smooth as silk. As always the fuel had been drained and fresh put in after the layup. We have since cleaned the carbs, put new float bowl gaskets, a fresh set of plugs and had my A P balance the carbs, which were real close anyway. The start up is instant as always has been, the mag drop is inconsistant, sometimes between 100 and 200 and very rough below below 3000rpm yet back to its usual 50rpm drop above. Original plugs went back in and gave the same result. I flew for half an hour yesterday in the hope of clearing the problem but no way, as I closed the throttle for landing we were back to a very rough motor. Any help would be more than appreciated. Thanks Flynn Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442457#442457 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: May 22, 2015
I run a single strand copper wire through them to insure they are clean. Copper won't scratch the jet. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Flynn Elliott Sent: Friday, May 22, 2015 1:19 PM Subject: RE: RotaxEngines-List: 912 rough running below 3000 rpm --> Thanks John, will pull them out and double check Again . -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of John Hauck Sent: 22 May 2015 06:25 PM Subject: RE: RotaxEngines-List: 912 rough running below 3000 rpm --> Insure both idle jets are completely open. Over the years I have discovered a rough or no run 912ULS below 3000 rpm is idle jet related. Idle jet is extremely small. A tiny bit of trash makes a lot of difference on fuel flow. For what it is worth. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of flynn elliott Sent: Friday, May 22, 2015 11:12 AM Subject: RotaxEngines-List: 912 rough running below 3000 rpm Hi Guys, could really use some help with a 912s. After leaving my Foxbat for two months , she started up just fine as usual but ran as rough as hell untill 3000rpm and up where the motor runs smooth as silk. As always the fuel had been drained and fresh put in after the layup. We have since cleaned the carbs, put new float bowl gaskets, a fresh set of plugs and had my A P balance the carbs, which were real close anyway. The start up is instant as always has been, the mag drop is inconsistant, sometimes between 100 and 200 and very rough below below 3000rpm yet back to its usual 50rpm drop above. Original plugs went back in and gave the same result. I flew for half an hour yesterday in the hope of clearing the problem but no way, as I closed the throttle for landing we were back to a very rough motor. Any help would be more than appreciated. Thanks Flynn Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442457#442457 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: May 22, 2015
Good thought John Thanks -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of John Hauck Sent: 22 May 2015 08:57 PM Subject: RE: RotaxEngines-List: 912 rough running below 3000 rpm --> I run a single strand copper wire through them to insure they are clean. Copper won't scratch the jet. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Flynn Elliott Sent: Friday, May 22, 2015 1:19 PM Subject: RE: RotaxEngines-List: 912 rough running below 3000 rpm --> Thanks John, will pull them out and double check Again . -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of John Hauck Sent: 22 May 2015 06:25 PM Subject: RE: RotaxEngines-List: 912 rough running below 3000 rpm --> Insure both idle jets are completely open. Over the years I have discovered a rough or no run 912ULS below 3000 rpm is idle jet related. Idle jet is extremely small. A tiny bit of trash makes a lot of difference on fuel flow. For what it is worth. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of flynn elliott Sent: Friday, May 22, 2015 11:12 AM Subject: RotaxEngines-List: 912 rough running below 3000 rpm Hi Guys, could really use some help with a 912s. After leaving my Foxbat for two months , she started up just fine as usual but ran as rough as hell untill 3000rpm and up where the motor runs smooth as silk. As always the fuel had been drained and fresh put in after the layup. We have since cleaned the carbs, put new float bowl gaskets, a fresh set of plugs and had my A P balance the carbs, which were real close anyway. The start up is instant as always has been, the mag drop is inconsistant, sometimes between 100 and 200 and very rough below below 3000rpm yet back to its usual 50rpm drop above. Original plugs went back in and gave the same result. I flew for half an hour yesterday in the hope of clearing the problem but no way, as I closed the throttle for landing we were back to a very rough motor. Any help would be more than appreciated. Thanks Flynn Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442457#442457 ----- No virus found in this message. Checked by AVG - www.avg.com ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: Idle jet clogged
Date: May 22, 2015
I agree. Pull the idle jet and run a small strand of copper wire through the extremely tiny hole in the center. You may need to do the same with the mixture orifice located in the corner of the bowl. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442464#442464 ________________________________________________________________________________
Subject: Re: 912 rough running below 3000 rpm
Date: May 22, 2015
I agree. Pull the idle jet and run a small strand of copper wire through the extremely tiny hole in the center. You may need to do the same with the mixture orifice located in the corner of the bowl. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442465#442465 ________________________________________________________________________________
Date: May 22, 2015
Roger, I always called that the "enricher jet" in the "enricher well". Have no idea what the correct nomenclature of them are. I iced up the idle jets on my 912ULS in 2000 going in to Toad River, BC. Engine quite as soon as it went through 3,000 rpm. Would start and run normal above 3,000, but not below it. Went across the Alaska Highway, got a cup of coffee, came back and the engine idled like a sewing machine. Conditions were conducive to icing. Learned then that 912's don't like the idle jet to be out of tune. -------- John Hauck MKIII/912ULS hauck's holler Titus, Alabama Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442467#442467 ________________________________________________________________________________
Date: May 23, 2015
Thanks Roger, as soon as I can escape from work I will do just that and give feed back. Flynn -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: 23 May 2015 12:23 AM Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm I agree. Pull the idle jet and run a small strand of copper wire through the extremely tiny hole in the center. You may need to do the same with the mixture orifice located in the corner of the bowl. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442465#442465 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: May 23, 2015
I have seen the problem you have described.=C2- When a carb idle jet beco mes blocked, the engine will shake at RPM below 3,000.=C2- Then the float s of both carbs begin to bounce, which contributes to the engine running ro ugh (floats become incompetent).=C2- By removing the float bowls of both carbs you can remove the idle jet in each carb for inspection under a brigh t lite.=C2- I found a very small spec of fuel hose lining blocked a jet o n one of my carbs.=C2- Probably happened when I installed a carb fuel hos e on a barb fitting.Dave Weaver N912GR On Friday, May 22, 2015 2:52 PM, Flynn Elliott wrote: line.co.za> Good thought John Thanks -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of John Hauck Sent: 22 May 2015 08:57 PM Subject: RE: RotaxEngines-List: 912 rough running below 3000 rpm --> I run a single strand copper wire through them to insure they are clean. Copper won't scratch the jet. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Flynn Elliott Sent: Friday, May 22, 2015 1:19 PM Subject: RE: RotaxEngines-List: 912 rough running below 3000 rpm --> Thanks John, will pull them out and double check Again . -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of John Hauck Sent: 22 May 2015 06:25 PM Subject: RE: RotaxEngines-List: 912 rough running below 3000 rpm --> Insure both idle jets are completely open. Over the years I have discovered a rough or no run 912ULS below 3000 rpm is idle jet related. Idle jet is extremely small.=C2- A tiny bit of trash makes a lot of diffe rence on fuel flow. For what it is worth. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of flynn elliott Sent: Friday, May 22, 2015 11:12 AM Subject: RotaxEngines-List: 912 rough running below 3000 rpm Hi Guys, could really use some help with a 912s. After leaving my Foxbat for two months , she started up just fine as usual but ran as rough as hell untill 3000rpm and up where the motor runs smooth as silk. As always the fuel had been drained and fresh put in after the layup. We have since cleaned the carbs, put new float bowl gaskets, a fresh set of plugs and had my A P balance the carbs, which were real close anyway. The start up is instant as always has been, the mag drop is inconsistant, sometimes between 100 and 200=C2- and very rough below below 3000rpm yet back to its usual 50rpm drop above. Original plugs went back in and gave the same result. I flew for half an hour yesterday in the hope of clearing the problem but n o way, as I closed the throttle for landing we were back to a very rough motor. Any help would be more than appreciated. Thanks Flynn Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442457#442457 ----- No virus found in this message. Checked by AVG - www.avg.com ----- No virus found in this message. Checked by AVG - www.avg.com - S - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: May 23, 2015
Hi Dave, Thanks for your input, every one seems to be in the same mind over this issue. Will get on it asap and report back . Flynn Sent: 23 May 2015 06:26 PM Subject: Re: RotaxEngines-List: 912 rough running below 3000 rpm I have seen the problem you have described. When a carb idle jet becomes blocked, the engine will shake at RPM below 3,000. Then the floats of both carbs begin to bounce, which contributes to the engine running rough (floats become incompetent). By removing the float bowls of both carbs you can remove the idle jet in each carb for inspection under a bright lite. I found a very small spec of fuel hose lining blocked a jet on one of my carbs. Probably happened when I installed a carb fuel hose on a barb fitting. Dave Weaver N912GR On Friday, May 22, 2015 2:52 PM, Flynn Elliott wrote: Good thought John Thanks -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of John Hauck Sent: 22 May 2015 08:57 PM Subject: RE: RotaxEngines-List: 912 rough running below 3000 rpm --> I run a single strand copper wire through them to insure they are clean. Copper won't scratch the jet. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Flynn Elliott Sent: Friday, May 22, 2015 1:19 PM Subject: RE: RotaxEngines-List: 912 rough running below 3000 rpm --> Thanks John, will pull them out and double check Again . -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of John Hauck Sent: 22 May 2015 06:25 PM Subject: RE: RotaxEngines-List: 912 rough running below 3000 rpm --> Insure both idle jets are completely open. Over the years I have discovered a rough or no run 912ULS below 3000 rpm is idle jet related. Idle jet is extremely small. A tiny bit of trash makes a lot of difference on fuel flow. For what it is worth. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of flynn elliott Sent: Friday, May 22, 2015 11:12 AM Subject: RotaxEngines-List: 912 rough running below 3000 rpm Hi Guys, could really use some help with a 912s. After leaving my Foxbat for two months , she started up just fine as usual but ran as rough as hell untill 3000rpm and up where the motor runs smooth as silk. As always the fuel had been drained and fresh put in after the layup. We have since cleaned the carbs, put new float bowl gaskets, a fresh set of plugs and had my A P balance the carbs, which were real close anyway. The start up is instant as always has been, the mag drop is inconsistant, sometimes between 100 and 200 and very rough below below 3000rpm yet back to its usual 50rpm drop above. Original plugs went back in and gave the same result. I flew for half an hour yesterday in the hope of clearing the problem but no way, as I closed the throttle for landing we were back to a very rough motor. Any help would be more than appreciated. Thanks Flynn Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442457#442457 ----- No virus found in this message. Checked by AVG - www.avg.com ----- No virus found in this message. C======================== No virus found in this message. Checked by AVG - www.avg.com 05/23/15 ________________________________________________________________________________
Date: May 23, 2015
Here's another thought. At mid range or less throttle, one of the carb slides may stick in the barrel, unbalancing the engine. Did you A&P try balancing down in the throttle range where you see the trouble? -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442517#442517 ________________________________________________________________________________
Date: May 24, 2015
Yes I did. We are now going to strip everything, to see if possibly there is a bit of junk floating around somewhere. -------------------------------------------------- From: "rampil" <ira.rampil(at)gmail.com> Sent: Sunday, May 24, 2015 7:03 AM Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm > > Here's another thought. > > At mid range or less throttle, one of the carb > slides may stick in the barrel, unbalancing > the engine. Did you A&P try balancing > down in the throttle range where you see the > trouble? > > -------- > Ira N224XS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442517#442517 > > > ________________________________________________________________________________
Date: May 24, 2015
Subject: Re: 912 rough running below 3000 rpm912 rough running
below 3 Flynn, I had that problem once and finally narrowed it down to the carb operating cables. One would stick during throttle reduction causing an imbalance. I replaced the cables and problem solved. I tried to lube them first but that didn't work well. Just another idea. Dick Maddux 912UL ________________________________________________________________________________
below 3
Date: May 24, 2015
Hi Dick, You're right and one thing we never seem to think about very often on the up front side of an issue. Cables on engines that are getting older or live in humid climates can get a little sticky. Just a little bit of friction from rust, corrosion or even just a slightly bent cable will cause carb unbalance. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442527#442527 ________________________________________________________________________________
below 3
Date: May 24, 2015
Although it did not show up during the balancing, it is worthwhile looking at it again. Vernon From: Catz631(at)aol.com Sent: Sunday, May 24, 2015 2:00 PM Subject: Re: RotaxEngines-List: 912 rough running below 3000 rpm912 rough running below 3 Flynn, I had that problem once and finally narrowed it down to the carb operating cables. One would stick during throttle reduction causing an imbalance. I replaced the cables and problem solved. I tried to lube them first but that didn't work well. Just another idea. Dick Maddux 912UL ________________________________________________________________________________
below 3
Date: May 24, 2015
Hi Roger, we think we have the cable's covered, but as Vernon said we will for sure double check. -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: 24 May 2015 03:33 PM Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm912 rough running below 3 Hi Dick, You're right and one thing we never seem to think about very often on the up front side of an issue. Cables on engines that are getting older or live in humid climates can get a little sticky. Just a little bit of friction from rust, corrosion or even just a slightly bent cable will cause carb unbalance. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442527#442527 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: May 24, 2015
Blow the carbs out with carb cleaner and then follow it with air pressure air. Don't blow against the diaphragm with high pressure air. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442543#442543 ________________________________________________________________________________
Date: May 25, 2015
Good advice, thanks Roger. -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: 25 May 2015 12:55 AM Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm Blow the carbs out with carb cleaner and then follow it with air pressure air. Don't blow against the diaphragm with high pressure air. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442543#442543 ----- No virus found in this message. Checked by AVG - www.avg.com ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: Re: REMOVE Re: RotaxEngines-List Digest: 0 Msgs - 05/29/15
Date: May 30, 2015
> On May 30, 2015, at 12:01 AM, RotaxEngines-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RotaxEngines-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RotaxEngines-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 15-05-29&Archive=RotaxEngines > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 15-05-29&Archive=RotaxEngines > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RotaxEngines-List Digest Archive > --- > Total Messages Posted Fri 05/29/15: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 02, 2015
Latest update, Idle jets cleaned, copper wire passed through although nothing appeared in terms of crud, ran motor seemed better, closed throttle for landing and we were back to rough running. This morning pulled idle jets again, able to see through one but not the other. Cleaned the hell out of it over a white cloth yet no crud seemed to appear although I can now clearly see through it. Motor now idles at 1800 rpm reasonably well yet appears to be hunting slightly whether on left mag, right mag, or both, mag drop 50rpm both. All cables smooth and returning to stops. Fuel lines flushed. Fresh fuel. Fresh filter New plugs. Maybe I am looking for a smooth smooth 912 idle that doesn't exist, we don't have another at the field to compare. It has been suggested that ignition packs are at fault although that seems highly unlikely as the motor starts on the click and cruises super smooth. Many thanks to all for help and suggestions. Flynn -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: 25 May 2015 12:55 AM Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm Blow the carbs out with carb cleaner and then follow it with air pressure air. Don't blow against the diaphragm with high pressure air. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442543#442543 ----- No virus found in this message. Checked by AVG - www.avg.com ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 02, 2015
Saw this kind of thing once on an aircraft that sat a while with auto fuel in the tanks. The evaporating fuel left some residue which then re-liquified somewhat in the new fuel and wreaked havoc on the fuel system. Problem was the evidence was very hard to see and the effects very subtle, as the residue basically "plated" the entire fuel system with a very light coating of sludge, which would, after some hours, always lead to either a fuel filter clogging, or a jet clogging, or something similar. The only solution was to put a Facet fuel pump on the tank exit line and re-circulate fuel through the tank for days on end, replenishing the fuel occasionally, to clean out the tank sludge. I hope this isn't your problem but I thought I'd put it out there. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. ________________________________________________________________________________
Date: Jun 02, 2015
Thanks for that Guy, if I don't solve this by other means then fortunately the wing tanks can come out. Flynn -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Guy Buchanan Sent: 02 June 2015 06:34 PM Subject: Re: RotaxEngines-List: Re: 912 rough running below 3000 rpm --> Saw this kind of thing once on an aircraft that sat a while with auto fuel in the tanks. The evaporating fuel left some residue which then re-liquified somewhat in the new fuel and wreaked havoc on the fuel system. Problem was the evidence was very hard to see and the effects very subtle, as the residue basically "plated" the entire fuel system with a very light coating of sludge, which would, after some hours, always lead to either a fuel filter clogging, or a jet clogging, or something similar. The only solution was to put a Facet fuel pump on the tank exit line and re-circulate fuel through the tank for days on end, replenishing the fuel occasionally, to clean out the tank sludge. I hope this isn't your problem but I thought I'd put it out there. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded Now a glider pilot, too. ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 02, 2015
Hi Flynn, This isn't the ignition modules, wrong symptoms. This is either fuel or the gearbox. The carbs are clean and nothing is in the mixture jet (corner of the float bowl) or the idle jet? I take it the idle is in sync and it isn't set too low an rpm? If the gearbox is a little on the loose side it could need a re-shim. This can be intermittent due to load changes when there is an rpm change. Have the float armatures that the float push up on been set to the proper height of 10.5mm from the edge of the carb to the top of the float armature? (You may have a tad bit of flooding). Could the floats themselves be a little heavy causing some mild flooding? -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442919#442919 ________________________________________________________________________________
Date: Jun 03, 2015
Thanks Roger, would you clarify exactly where to measure 10.5mm. i.e armatures up or down and what area of edge of carb. Thanks -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: 03 June 2015 01:48 AM Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm Hi Flynn, This isn't the ignition modules, wrong symptoms. This is either fuel or the gearbox. The carbs are clean and nothing is in the mixture jet (corner of the float bowl) or the idle jet? I take it the idle is in sync and it isn't set too low an rpm? If the gearbox is a little on the loose side it could need a re-shim. This can be intermittent due to load changes when there is an rpm change. Have the float armatures that the float push up on been set to the proper height of 10.5mm from the edge of the carb to the top of the float armature? (You may have a tad bit of flooding). Could the floats themselves be a little heavy causing some mild flooding? -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442919#442919 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 03, 2015
Hi Flynn, The carb must be off the engine and held upside down. Take a MM ruler and stand it upright (straight up) on the outside lip of the carb. Now slide it over towards the float armature so you can see the ruler marks next to the float armature. The top of the float armature should be 10.5mm. If it is not just bend the tab where the float needle is suspended to obtain the proper 10.5mm height. This is what controls the fuel level in the bowl as the floats push up against it. If it is off adjustment it can cause some flooding and rough running. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442934#442934 ________________________________________________________________________________
Date: Jun 03, 2015
Hi Roger, When I have done this job in the past I used a special Rotax tool for the correct set up. It was drawn to my attention that the dimension you refer to varies with engine type ie 912ul 912uls and 914. Your clarification on this may be appreciated by many or just me. Pete -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: 03 June 2015 15:01 Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm Hi Flynn, The carb must be off the engine and held upside down. Take a MM ruler and stand it upright (straight up) on the outside lip of the carb. Now slide it over towards the float armature so you can see the ruler marks next to the float armature. The top of the float armature should be 10.5mm. If it is not just bend the tab where the float needle is suspended to obtain the proper 10.5mm height. This is what controls the fuel level in the bowl as the floats push up against it. If it is off adjustment it can cause some flooding and rough running. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442934#442934 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 03, 2015
Rotax does have a special measurement tool the slips over the main jet nipple area. I was doing this before that tool came out so just stuck with the mm ruler and saved about $35. :) Most don't want to spend the money on what many would consider a one time use part, but either way works and gets the job done. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442940#442940 ________________________________________________________________________________
Date: Jun 03, 2015
Roger, My query was more about the dimension of 10.5 mm. I was told (and the tool indicates) that different figures apply to the 912, 912s and 914 engines. I am not too sure how critical this is but the dimensions on the tool are quite different. Pete -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: 03 June 2015 16:31 Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm Rotax does have a special measurement tool the slips over the main jet nipple area. I was doing this before that tool came out so just stuck with the mm ruler and saved about $35. :) Most don't want to spend the money on what many would consider a one time use part, but either way works and gets the job done. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442940#442940 ----- No virus found in this message. Checked by AVG - www.avg.com ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 03, 2015
Pete, If that is the case, I would be very interested. Vernon. -------------------------------------------------- From: "Peter Jeffers" <pjeffers(at)talktalk.net> Sent: Wednesday, June 03, 2015 4:34 PM Subject: RE: RotaxEngines-List: Re: 912 rough running below 3000 rpm > > > Hi Roger, > When I have done this job in the past I used a special Rotax tool for the > correct set up. > It was drawn to my attention that the dimension you refer to varies with > engine type ie 912ul 912uls and 914. Your clarification on this may be > appreciated by many or just me. > Pete > > -----Original Message----- > From: owner-rotaxengines-list-server(at)matronics.com > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger > Lee > Sent: 03 June 2015 15:01 > To: rotaxengines-list(at)matronics.com > Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm > > > Hi Flynn, > > The carb must be off the engine and held upside down. Take a MM ruler and > stand it upright (straight up) on the outside lip of the carb. Now slide > it > over towards the float armature so you can see the ruler marks next to the > float armature. The top of the float armature should be 10.5mm. If it is > not > just bend the tab where the float needle is suspended to obtain the proper > 10.5mm height. This is what controls the fuel level in the bowl as the > floats push up against it. If it is off adjustment it can cause some > flooding and rough running. > > -------- > Roger Lee > Tucson, Az. > Rotax Instructor & Rotax IRC > Light Sport Repairman > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442934#442934 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > > ________________________________________________________________________________
Date: Jun 03, 2015
Hi Vernon, Some years ago I renewed all the maintainable bits of my carbs on a 912ul. This included the brass pivot arm . At the time I rather naively assumed that it was just a replacement item and fitted it as supplied in a Rotax kit. I flew the aircraft and had no problem at all until I throttled back at top of climb at which time the engine ran very rough. So rough that I declared an emergency. The simple fix was to correctly adjust the float levels in both carbs using the Rotax tool.The tool has steps in it for the different 900 series engines. I have absolutely no problem doing this with a tape measure as Roger has described, but according to which engine you are working on depends what dimension you should be working to. I look forward to Roger's reply as he is the oracle on these matters. Pete -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of vernon mitchell Sent: 03 June 2015 18:21 Subject: Re: RotaxEngines-List: Re: 912 rough running below 3000 rpm --> Pete, If that is the case, I would be very interested. Vernon. -------------------------------------------------- From: "Peter Jeffers" <pjeffers(at)talktalk.net> Sent: Wednesday, June 03, 2015 4:34 PM Subject: RE: RotaxEngines-List: Re: 912 rough running below 3000 rpm > > > Hi Roger, > When I have done this job in the past I used a special Rotax tool for > the correct set up. > It was drawn to my attention that the dimension you refer to varies > with engine type ie 912ul 912uls and 914. Your clarification on this > may be appreciated by many or just me. > Pete > > -----Original Message----- > From: owner-rotaxengines-list-server(at)matronics.com > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of > Roger Lee > Sent: 03 June 2015 15:01 > To: rotaxengines-list(at)matronics.com > Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm > > --> > > Hi Flynn, > > The carb must be off the engine and held upside down. Take a MM ruler > and stand it upright (straight up) on the outside lip of the carb. Now > slide it over towards the float armature so you can see the ruler > marks next to the float armature. The top of the float armature should > be 10.5mm. If it is not just bend the tab where the float needle is > suspended to obtain the proper 10.5mm height. This is what controls > the fuel level in the bowl as the floats push up against it. If it is > off adjustment it can cause some flooding and rough running. > > -------- > Roger Lee > Tucson, Az. > Rotax Instructor & Rotax IRC > Light Sport Repairman > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442934#442934 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 03, 2015
Yes Pete, I will be looking forward to Rogers reply as well. Small things like that, can make a big difference. Vernon -------------------------------------------------- From: "Peter Jeffers" <pjeffers(at)talktalk.net> Sent: Wednesday, June 03, 2015 8:35 PM Subject: RE: RotaxEngines-List: Re: 912 rough running below 3000 rpm > > > Hi Vernon, > Some years ago I renewed all the maintainable bits of my carbs on a 912ul. > This included the brass pivot arm . At the time I rather naively assumed > that it was just a replacement item and fitted it as supplied in a Rotax > kit. I flew the aircraft and had no problem at all until I throttled back > at > top of climb at which time the engine ran very rough. So rough that I > declared an emergency. > The simple fix was to correctly adjust the float levels in both carbs > using > the Rotax tool.The tool has steps in it for the different 900 series > engines. I have absolutely no problem doing this with a tape measure as > Roger has described, but according to which engine you are working on > depends what dimension you should be working to. I look forward to > Roger's > reply as he is the oracle on these matters. > Pete > > -----Original Message----- > From: owner-rotaxengines-list-server(at)matronics.com > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of vernon > mitchell > Sent: 03 June 2015 18:21 > To: rotaxengines-list(at)matronics.com > Subject: Re: RotaxEngines-List: Re: 912 rough running below 3000 rpm > > --> > > Pete, > If that is the case, I would be very interested. > Vernon. > > -------------------------------------------------- > From: "Peter Jeffers" <pjeffers(at)talktalk.net> > Sent: Wednesday, June 03, 2015 4:34 PM > To: > Subject: RE: RotaxEngines-List: Re: 912 rough running below 3000 rpm > >> >> >> Hi Roger, >> When I have done this job in the past I used a special Rotax tool for >> the correct set up. >> It was drawn to my attention that the dimension you refer to varies >> with engine type ie 912ul 912uls and 914. Your clarification on this >> may be appreciated by many or just me. >> Pete >> >> -----Original Message----- >> From: owner-rotaxengines-list-server(at)matronics.com >> [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of >> Roger Lee >> Sent: 03 June 2015 15:01 >> To: rotaxengines-list(at)matronics.com >> Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm >> >> --> >> >> Hi Flynn, >> >> The carb must be off the engine and held upside down. Take a MM ruler >> and stand it upright (straight up) on the outside lip of the carb. Now >> slide it over towards the float armature so you can see the ruler >> marks next to the float armature. The top of the float armature should >> be 10.5mm. If it is not just bend the tab where the float needle is >> suspended to obtain the proper 10.5mm height. This is what controls >> the fuel level in the bowl as the floats push up against it. If it is >> off adjustment it can cause some flooding and rough running. >> >> -------- >> Roger Lee >> Tucson, Az. >> Rotax Instructor & Rotax IRC >> Light Sport Repairman >> Home 520-574-1080 TRY HOME FIRST >> Cell 520-349-7056 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=442934#442934 >> >> >> >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com >> >> >> >> >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > > ________________________________________________________________________________
Date: Jun 03, 2015
This is an excellent example of what is great with Matronics. I too look forward to Roger's response. Although rather than call him an "Oracle", google answers "A response which is typically one that is ambiguous or obscure". I would prefer you use the term Pontiff as in officiating such as at mass. I hold Rotax as the ultimate authority and this is no time for ambiguous or obscure dogmatic answers. I like your method mentioned above. I love the 912iS with Fadec. John Cox. On Wed, Jun 3, 2015 at 12:11 PM, vernon mitchell wrote: > vernon11(at)xsinet.co.za> > > Yes Pete, > I will be looking forward to Rogers reply as well. Small things > like that, can make a big difference. > Vernon > > -------------------------------------------------- > From: "Peter Jeffers" <pjeffers(at)talktalk.net> > Sent: Wednesday, June 03, 2015 8:35 PM > To: > Subject: RE: RotaxEngines-List: Re: 912 rough running below 3000 rpm > >> pjeffers(at)talktalk.net> >> >> Hi Vernon, >> Some years ago I renewed all the maintainable bits of my carbs on a 912ul. >> This included the brass pivot arm . At the time I rather naively assumed >> that it was just a replacement item and fitted it as supplied in a Rotax >> kit. I flew the aircraft and had no problem at all until I throttled back >> at >> top of climb at which time the engine ran very rough. So rough that I >> declared an emergency. >> The simple fix was to correctly adjust the float levels in both carbs >> using >> the Rotax tool.The tool has steps in it for the different 900 series >> engines. I have absolutely no problem doing this with a tape measure as >> Roger has described, but according to which engine you are working on >> depends what dimension you should be working to. I look forward to >> Roger's >> reply as he is the oracle on these matters. >> Pete >> >> -----Original Message----- >> From: owner-rotaxengines-list-server(at)matronics.com >> [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of vernon >> mitchell >> Sent: 03 June 2015 18:21 >> To: rotaxengines-list(at)matronics.com >> Subject: Re: RotaxEngines-List: Re: 912 rough running below 3000 rpm >> >> --> >> >> >> Pete, >> If that is the case, I would be very interested. >> Vernon. >> >> -------------------------------------------------- >> From: "Peter Jeffers" <pjeffers(at)talktalk.net> >> Sent: Wednesday, June 03, 2015 4:34 PM >> To: >> Subject: RE: RotaxEngines-List: Re: 912 rough running below 3000 rpm >> >>> >>> >>> Hi Roger, >>> When I have done this job in the past I used a special Rotax tool for >>> the correct set up. >>> It was drawn to my attention that the dimension you refer to varies >>> with engine type ie 912ul 912uls and 914. Your clarification on this >>> may be appreciated by many or just me. >>> Pete >>> >>> -----Original Message----- >>> From: owner-rotaxengines-list-server(at)matronics.com >>> [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of >>> Roger Lee >>> Sent: 03 June 2015 15:01 >>> To: rotaxengines-list(at)matronics.com >>> Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm >>> >>> --> >>> >>> >>> Hi Flynn, >>> >>> The carb must be off the engine and held upside down. Take a MM ruler >>> and stand it upright (straight up) on the outside lip of the carb. Now >>> slide it over towards the float armature so you can see the ruler >>> marks next to the float armature. The top of the float armature should >>> be 10.5mm. If it is not just bend the tab where the float needle is >>> suspended to obtain the proper 10.5mm height. This is what controls >>> the fuel level in the bowl as the floats push up against it. If it is >>> off adjustment it can cause some flooding and rough running. >>> >>> -------- >>> Roger Lee >>> Tucson, Az. >>> Rotax Instructor & Rotax IRC >>> Light Sport Repairman >>> Home 520-574-1080 TRY HOME FIRST >>> Cell 520-349-7056 >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=442934#442934 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> ----- >>> No virus found in this message. >>> Checked by AVG - www.avg.com >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jun 03, 2015
A glimmer of hope, pulled the jets yet again and this time also the mixture needles and gave them a clean and a light blast of air, along with the brass down pipe attached to the carb body, reassembled and fired up, smooth as silk at idle and throttle progression for around fifteen seconds then back to lumpy running. Think I dislodged a tiny piece of something which may have got pushed back with the fuel flow. I get the impression the culprit is sitting in the carb body, will now have to take the carbs off for a strip down be it that maybe only one carb is causing the problems. Oh ,and float levels are spot on. Flynn -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: 03 June 2015 04:01 PM Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm Hi Flynn, The carb must be off the engine and held upside down. Take a MM ruler and stand it upright (straight up) on the outside lip of the carb. Now slide it over towards the float armature so you can see the ruler marks next to the float armature. The top of the float armature should be 10.5mm. If it is not just bend the tab where the float needle is suspended to obtain the proper 10.5mm height. This is what controls the fuel level in the bowl as the floats push up against it. If it is off adjustment it can cause some flooding and rough running. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442934#442934 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 03, 2015
The 912UL and ULS are the same measurements. They are the same carbs just different jetting. When the carbs come off you must flush through every orifice and jet in the bowl and carb body and leave no stone unturned. It only takes a very tiny piece of debris to cause this rough running. Your symptoms do sound like you move a piece of debris, but after it runs it moves again. I absolutely know you don't want to hear this, but I think you missed something on the cleaning. Every little hole and crevice needs to be flushed then blown out with air. Blow the air in more than one direction where possible. I have seen a few owners have difficulty here because they left one stone unturned. Thanks for the vote of confidence, but no "Oracle" here just an owner like everyone else and happy to pass on what I learn in all the Rotax schools and what I have been able to see over the years. matter of fact I just spent all last week back at Rotax for another school. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442958#442958 ________________________________________________________________________________
Date: Jun 04, 2015
Hi Roger, I have now had the chance to read up on some old documents that I have and can now confirm that the setup dimensions for the floats on the 912l and 912s engines are both the same ie 10.5 mm but the 914 is quite different. Pete ps I cannot quite relate the dimensions on the Rotax setup tool to the dimension you quote because it is measuring in a different place, so can't quote the equivalent figure for the 914. Perhaps you have that figure to pass on to the Forum. -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: 04 June 2015 01:32 Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm The 912UL and ULS are the same measurements. They are the same carbs just different jetting. When the carbs come off you must flush through every orifice and jet in the bowl and carb body and leave no stone unturned. It only takes a very tiny piece of debris to cause this rough running. Your symptoms do sound like you move a piece of debris, but after it runs it moves again. I absolutely know you don't want to hear this, but I think you missed something on the cleaning. Every little hole and crevice needs to be flushed then blown out with air. Blow the air in more than one direction where possible. I have seen a few owners have difficulty here because they left one stone unturned. Thanks for the vote of confidence, but no "Oracle" here just an owner like everyone else and happy to pass on what I learn in all the Rotax schools and what I have been able to see over the years. matter of fact I just spent all last week back at Rotax for another school. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442958#442958 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 04, 2015
Hi Pete, Hope everything is well. You right. Just a small adjustment: the tool are the same but measurements are different. Heavy Maintenance 73-00-00 3.3.8 shows this in detail. BTW LN-STE now 600 hours. Greece this summer. -- Mvh Stephan ________________________________________________________________________________
Date: Jun 04, 2015
Pete, Page 30 in chapter 73-00-00 Heavy Maint Manual has the details. I will try to attach to this message. Brian Davies -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Peter Jeffers Sent: 04 June 2015 10:35 Subject: RE: RotaxEngines-List: Re: 912 rough running below 3000 rpm --> Hi Roger, I have now had the chance to read up on some old documents that I have and can now confirm that the setup dimensions for the floats on the 912l and 912s engines are both the same ie 10.5 mm but the 914 is quite different. Pete ps I cannot quite relate the dimensions on the Rotax setup tool to the dimension you quote because it is measuring in a different place, so can't quote the equivalent figure for the 914. Perhaps you have that figure to pass on to the Forum. -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: 04 June 2015 01:32 Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm --> The 912UL and ULS are the same measurements. They are the same carbs just different jetting. When the carbs come off you must flush through every orifice and jet in the bowl and carb body and leave no stone unturned. It only takes a very tiny piece of debris to cause this rough running. Your symptoms do sound like you move a piece of debris, but after it runs it moves again. I absolutely know you don't want to hear this, but I think you missed something on the cleaning. Every little hole and crevice needs to be flushed then blown out with air. Blow the air in more than one direction where possible. I have seen a few owners have difficulty here because they left one stone unturned. Thanks for the vote of confidence, but no "Oracle" here just an owner like everyone else and happy to pass on what I learn in all the Rotax schools and what I have been able to see over the years. matter of fact I just spent all last week back at Rotax for another school. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442958#442958 ----- No virus found in this message. Checked by AVG - www.avg.com ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 08, 2015
Hi Roger, Carbs now stripped again, thoroughly cleaned out , new o rings ect. Roughness at idle remains the same. Just for the hell of it we turned the mixture screw in to lean the mixture, at just on 1/2 a turn out I now have a very smooth idle ! rpm through the rest of the range is unafected. Will I be running the motor to lean , from what info I get the mixture screw only effects low rpm operation i.e idle. Thanks Flynn -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: 04 June 2015 02:32 AM Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm The 912UL and ULS are the same measurements. They are the same carbs just different jetting. When the carbs come off you must flush through every orifice and jet in the bowl and carb body and leave no stone unturned. It only takes a very tiny piece of debris to cause this rough running. Your symptoms do sound like you move a piece of debris, but after it runs it moves again. I absolutely know you don't want to hear this, but I think you missed something on the cleaning. Every little hole and crevice needs to be flushed then blown out with air. Blow the air in more than one direction where possible. I have seen a few owners have difficulty here because they left one stone unturned. Thanks for the vote of confidence, but no "Oracle" here just an owner like everyone else and happy to pass on what I learn in all the Rotax schools and what I have been able to see over the years. matter of fact I just spent all last week back at Rotax for another school. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442958#442958 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 08, 2015
Flynn, There is a product called "Colortune spark plug". You can't use them under load but it's really neat device for setting mixtures. I used them extensively in the distant past tuning Weber and Dell'Orto carbs. Among others, Amazon sells them here http://www.amazon.com/Colortune-for-14mm-Spark-Plug/dp/B000E9VGNM This one's a 14mm thread size. Regards, Otto Szorenyi -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Flynn Elliott Sent: Monday, June 08, 2015 08:17 Subject: RE: RotaxEngines-List: Re: 912 rough running below 3000 rpm --> Hi Roger, Carbs now stripped again, thoroughly cleaned out , new o rings ect. Roughness at idle remains the same. Just for the hell of it we turned the mixture screw in to lean the mixture, at just on 1/2 a turn out I now have a very smooth idle ! rpm through the rest of the range is unafected. Will I be running the motor to lean , from what info I get the mixture screw only effects low rpm operation i.e idle. Thanks Flynn -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: 04 June 2015 02:32 AM Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm --> The 912UL and ULS are the same measurements. They are the same carbs just different jetting. When the carbs come off you must flush through every orifice and jet in the bowl and carb body and leave no stone unturned. It only takes a very tiny piece of debris to cause this rough running. Your symptoms do sound like you move a piece of debris, but after it runs it moves again. I absolutely know you don't want to hear this, but I think you missed something on the cleaning. Every little hole and crevice needs to be flushed then blown out with air. Blow the air in more than one direction where possible. I have seen a few owners have difficulty here because they left one stone unturned. Thanks for the vote of confidence, but no "Oracle" here just an owner like everyone else and happy to pass on what I learn in all the Rotax schools and what I have been able to see over the years. matter of fact I just spent all last week back at Rotax for another school. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442958#442958 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 08, 2015
Flynn, While looking around on the Net I also found this interesting looking toy that might interest you. http://www.americanmuscle.com/plx-dm6-afr-sensor-module-combo.html Otto S. -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Flynn Elliott Sent: Monday, June 08, 2015 08:17 Subject: RE: RotaxEngines-List: Re: 912 rough running below 3000 rpm --> Hi Roger, Carbs now stripped again, thoroughly cleaned out , new o rings ect. Roughness at idle remains the same. Just for the hell of it we turned the mixture screw in to lean the mixture, at just on 1/2 a turn out I now have a very smooth idle ! rpm through the rest of the range is unafected. Will I be running the motor to lean , from what info I get the mixture screw only effects low rpm operation i.e idle. Thanks Flynn ________________________________________________________________________________
Date: Jun 08, 2015
Hi Flynn, The mixture screw is more for the low rpm. When you cleaned the carbs did you remove the mixture screw on the bottom and blow through this orifice? Did you remove or at least blow through the mixture jet located in the corner of the bowl in both directions? Is the mixture screw now out 1.5 turns and was it when all this started? If you put a set of carb sync gauges on do the carbs sync at idle or is one carb considerably off over the other? -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443218#443218 ________________________________________________________________________________
From: "Flynn Elliott" <foxflynn(at)worldonline.co.za>
Date: Jun 08, 2015
-----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: 08 June 2015 04:12 PM Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm Hi Flynn, The mixture screw is more for the low rpm. When you cleaned the carbs did you remove the mixture screw on the bottom and blow through this orifice? Yes Did you remove or at least blow through the mixture jet located in the corner of the bowl in both directions? Yes,removed and pumped fuel and air from both ends. Is the mixture screw now out 1.5 turns and was it when all this started? No, just .5 out at the moment to get smooth idle, at 1 .5 idle is rough. Setting was 1.5 before this started, prior to this issue they have never been touched. If you put a set of carb sync gauges on do the carbs sync at idle or is one carb considerably off over the other? Carb sync gauges are on the way to me, should have them in a few days. Thanks Flynn -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443218#443218 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 08, 2015
Thanks Otto. -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of OS Sent: 08 June 2015 04:01 PM Subject: RE: RotaxEngines-List: Re: 912 rough running below 3000 rpm Flynn, While looking around on the Net I also found this interesting looking toy that might interest you. http://www.americanmuscle.com/plx-dm6-afr-sensor-module-combo.html Otto S. -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Flynn Elliott Sent: Monday, June 08, 2015 08:17 Subject: RE: RotaxEngines-List: Re: 912 rough running below 3000 rpm --> Hi Roger, Carbs now stripped again, thoroughly cleaned out , new o rings ect. Roughness at idle remains the same. Just for the hell of it we turned the mixture screw in to lean the mixture, at just on 1/2 a turn out I now have a very smooth idle ! rpm through the rest of the range is unafected. Will I be running the motor to lean , from what info I get the mixture screw only effects low rpm operation i.e idle. Thanks Flynn ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jul 07, 2015
Subject: boost bottles
=EF=BBdose any one on the list have experience with boost bottles on rot ax two cycle engines ________________________________________________________________________________
Subject: 914 High Altitude Performance
Date: Jul 11, 2015
We recently did a flight at a Density Altitude of 15000 ft. We were unable to maintain 30 in manifold pressure, the fuel flow was about 6.4 gph and the throttle position was 100%. We subsequently adjusted the wastegate cable less than 1 turn and replaced all the spring style clamps on our airbox pressure and manifold pressure instrumentation hoses with wraps of safety wire and now we easily get 30 in manifold pressure with fuel flow of 5.5 gph and throttle position around 70%. When looking into this, we referred to the 914 performance charts found in chapter 5 of the Operators Manual and the critical flying altitude in chapter 2. Chapter 2 states that continuous performance manifold pressure is available up to 16000 feet when operated at ISA temperature and pressure. Yet the Performance graph for non-standard conditions, shows when the temperature difference from standard condition is 0 (so standard ISA conditions) the power drops from 74kw at SL to 66 kw at 16000 ft. This seems to conflict with the critical altitude statement. And we have a copy of an early 914 Operators Manual (1996 05 10) where the same chart shows constant power at 0 deg difference up to 16000 ft. It also shows the same example as the current chart, Max continuous power at 10000ft, and the result is 74.9 kw versus the current chart that results in 72 kw. Just looking for an explanation of the charts and definition of critical altitude. Thanks Jim & Heather Europa XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444658#444658 ________________________________________________________________________________
Subject: 582 grey head ignition
Date: Jul 12, 2015
Hi fellow 2-stroke flyers, I am currently working on testruns and (hopefully) testflights with my restoration project Pulsar 1, equipped with Rotax 582 grey head. A few testflights had to be cancelled, because one of the two ignitions failed in the run-up before take-off. So far, we could not find the cause of this failure. It does not fail constantly, sometimes it works and sometimes it doesn't! We suspect one of the ignition coils. Does anyone recognise this problem? Cheers, Bart Verstuurd vanaf mijn iPad ________________________________________________________________________________
Subject: Re: 582 grey head ignition
Date: Jul 12, 2015
I'm going to say broken ignition (not plug) wire. See this on the 912 all the time. Use a continuity tester with needles to poke through the insulation. Work the wires to find the break. Guy B. Sent from my iPod > On Jul 12, 2015, at 11:45 AM, Bart Rond wrote: > > > Hi fellow 2-stroke flyers, > > I am currently working on testruns and (hopefully) testflights with my restoration project Pulsar 1, equipped with Rotax 582 grey head. > A few testflights had to be cancelled, because one of the two ignitions failed in the run-up before take-off. So far, we could not find the cause of this failure. > It does not fail constantly, sometimes it works and sometimes it doesn't! > We suspect one of the ignition coils. Does anyone recognise this problem? > > Cheers, Bart > > Verstuurd vanaf mijn iPad > > > > ________________________________________________________________________________
Date: Jul 12, 2015
Bart, I use a guy in Naples, FL named Rick Davis. He's one of the old pros of 4 & 2 stroke motors. I'll see if I can find his web site for you.... https://rotaxrick.wordpress.com/ He can help you with just about anything. Best idea is to email him. He stays busy! Bill Catalina blumax008(at)aol.com -----Original Message----- From: Bart Rond <bartrond(at)hotmail.com> Sent: Sun, Jul 12, 2015 2:46 pm Subject: RotaxEngines-List: 582 grey head ignition Hi fellow 2-stroke flyers, I am currently working on testruns and (hopefully) testflights with my restoration project Pulsar 1, equipped with Rotax 582 grey head. A few testflights had to be cancelled, because one of the two ignitions failed in the run-up before take-off. So far, we could not find the cause of this failure. It does not fail constantly, sometimes it works and sometimes it doesn't! We suspect one of the ignition coils. Does anyone recognise this problem? Cheers, Bart Verstuurd vanaf mijn iPad - The RotaxEngines-List Email Forum - Navigator to browse Un/Subscription, Photoshare, and much much more: http://www.matronics.com/Navigator?RotaxEngines-List - MATRONICS WEB FORUMS - Forums! http://forums.matronics.com - List Contribution Web Site - -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 13, 2015
Subject: 912 ULS Fuel Pressure
My 912 ULS mounted in my Rans S7-S has 438 hr. I replaced the old style mechanical pump as recommended by Rotax. I have an electric fuel pump and fuel pressure gauge. I usually take off with the electric pump running in addition to the mechanical pump. When I level off to cruise I turn off the electric pump. My pressure usually is about 4.5 psi. Last week I was flying and noticed the EIS warning light and it identified my fuel pressure to be about 0.9 psi. I quickly turned on the electric pump. The pressure went to about 3.5 psi. I flew back and landed without incident. The engine never faltered. Any suggestion on how to test the mechanical pump? Any suggestion on what the problem might be? I have not had opportunity to remove the cowl to make any visual checks. Stan Tew N29TD ________________________________________________________________________________
Subject: Re: 912 ULS Fuel Pressure
Date: Jul 14, 2015
You can put a 10 psi gauge inline with the fuel at the balance tube assembly or if you don't have one then just plumb it inline. If your electric pump is plumbed in series it has a check valve that could cause an issue until it gets turned on. I doubt it's the mechanical pump, but you won't know for sure until you put a gauge inline. Possibly the fuel pressure gauge, again an unknow until you put a gauge inline. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444772#444772 ________________________________________________________________________________
Date: Jul 14, 2015
"T" a mechanical pressure gauge into your fuel line. john h Fort Lewis, WA From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Stan Tew Sent: Monday, July 13, 2015 3:47 PM Subject: RotaxEngines-List: 912 ULS Fuel Pressure My 912 ULS mounted in my Rans S7-S has 438 hr. I replaced the old style mechanical pump as recommended by Rotax. I have an electric fuel pump and fuel pressure gauge. I usually take off with the electric pump running in addition to the mechanical pump. When I level off to cruise I turn off the electric pump. My pressure usually is about 4.5 psi. Last week I was flying and noticed the EIS warning light and it identified my fuel pressure to be about 0.9 psi. I quickly turned on the electric pump. The pressure went to about 3.5 psi. I flew back and landed without incident. The engine never faltered. Any suggestion on how to test the mechanical pump? Any suggestion on what the problem might be? I have not had opportunity to remove the cowl to make any visual checks. Stan Tew N29TD ________________________________________________________________________________
Date: Jul 15, 2015
Hi Roger,and all who offered advice, The rough running is now in the history books. After cleaning the carbs yet again, blowing air around and through every nook and cranny all over a white towel with no crud to be seen whatsoever, I reassembeled the carbs with new jet 'o' rings etc. Put the carbs back on and balanced with gauges then a borrowed Carbmate (which is fantastic to use) Fired up the motor and to my great surprise my 912 was back to her old self, smooth as silk. I sooo wish we found some crapp in the carbs if only to tell me the problem !! Many many thanks for the help. Flynn -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: 03 June 2015 04:01 PM Subject: RotaxEngines-List: Re: 912 rough running below 3000 rpm Hi Flynn, The carb must be off the engine and held upside down. Take a MM ruler and stand it upright (straight up) on the outside lip of the carb. Now slide it over towards the float armature so you can see the ruler marks next to the float armature. The top of the float armature should be 10.5mm. If it is not just bend the tab where the float needle is suspended to obtain the proper 10.5mm height. This is what controls the fuel level in the bowl as the floats push up against it. If it is off adjustment it can cause some flooding and rough running. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442934#442934 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jul 15, 2015
Hi Flynn, Glad it worked out. Sometimes when you clean the carbs the tiniest spec goes flying out and the eye never sees it. It may have been a passage that only had a partial obstruction to cause the roughness. It's happened to me. I have learned not to piecemeal everything and just bugle down and just the job top to bottom and 100% and that eliminates that as a potential problem. Over all it will take less time in the long run and be a lot less frustrating. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444807#444807 ________________________________________________________________________________
Date: Jul 19, 2015
Bart, Don't know if you've had any luck with this issue, but here are some more things to check. Wire/Coil and Wire/Boot connection. Trim a quarter inch or so (6mm) from the each end of the wire so that the screw inside the coil and boot can get a firm connection. While you have the boots off, check them for proper resistance, they should be 5 ohms. If they are too much more consider replacing them. You can get generics that are 1/10 the price Rotax charges. Test the spark plug leads, too. They're wire core and s/b zero ohms. Test your mag switches for intermittent failure. Just use an ohm meter and flip the switch a couple of dozen times and see if the switch has a failure. Rick Girard On Sun, Jul 12, 2015 at 2:19 PM, Guy Buchanan wrote: > > I'm going to say broken ignition (not plug) wire. See this on the 912 all > the time. Use a continuity tester with needles to poke through the > insulation. Work the wires to find the break. > > Guy B. > > Sent from my iPod > > > On Jul 12, 2015, at 11:45 AM, Bart Rond wrote: > > > > > > > > Hi fellow 2-stroke flyers, > > > > I am currently working on testruns and (hopefully) testflights with my > restoration project Pulsar 1, equipped with Rotax 582 grey head. > > A few testflights had to be cancelled, because one of the two ignitions > failed in the run-up before take-off. So far, we could not find the cause > of this failure. > > It does not fail constantly, sometimes it works and sometimes it doesn't! > > We suspect one of the ignition coils. Does anyone recognise this problem? > > > > Cheers, Bart > > > > Verstuurd vanaf mijn iPad > > > > > > > > > > -- Believe those who are seeking the truth, doubt those who find it. -Andre Gide ________________________________________________________________________________
Date: Jul 19, 2015
so that the screw inside the coil and boot can get a firm connection. While you have the boots off, check them for proper resistance, they should be 5 ohms. If they are too much more consider replacing them. You can get generics that are 1/10 the price Rotax charges. Rick.... You just mentioned something that is dear to all our hearts. ($$$). Could you tell us where to buy coil generics at 1/10th. the price of similar Rotax. I was just shocked by the price of a single Bing 54 carb. Thank You! Bill in Tallahassee blumax008(at)aol.com -----Original Message----- From: Richard Girard <aslsa.rng(at)gmail.com> Sent: Sun, Jul 19, 2015 9:43 am Subject: Re: RotaxEngines-List: 582 grey head ignition Bart, Don't know if you've had any luck with this issue, but here are some more things to check. Wire/Coil and Wire/Boot connection. Trim a quarter inch or so (6mm) from the each end of the wire so that the screw inside the coil and boot can get a firm connection. While you have the boots off, check them for proper resistance, they should be 5 ohms. If they are too much more consider replacing them. You can get generics that are 1/10 the price Rotax charges. Test the spark plug leads, too. They're wire core and s/b zero ohms. Test your mag switches for intermittent failure. Just use an ohm meter and flip the switch a couple of dozen times and see if the switch has a failure. Rick Girard On Sun, Jul 12, 2015 at 2:19 PM, Guy Buchanan wrote: I'm going to say broken ignition (not plug) wire. See this on the 912 all the time. Use a continuity tester with needles to poke through the insulation. Work the wires to find the break. Guy B. Sent from my iPod > On Jul 12, 2015, at 11:45 AM, Bart Rond < bartrond(at)hotmail.com> wrote: > > > Hi fellow 2-stroke flyers, > > I am currently working on testruns and (hopefully) testflights with my restoration project Pulsar 1, equipped with Rotax 582 grey head. > A few testflights had to be cancelled, because one of the two ignitions failed in the run-up before take-off. So far, we could not find the cause of this failure. > It does not fail constantly, sometimes it works and sometimes it doesn't! > We suspect one of the ignition coils. Does anyone recognise this problem? > > Cheers, Bart > > Verstuurd vanaf mijn iPad > > > > =========== - xEngines-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List =========== FORUMS - eferrer" target="_blank">http://forums.matronics.com =========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution =========== -- Believe those who are seeking the truth, doubt those who find it. -Andre Gide ________________________________________________________________________________
Date: Jul 20, 2015
Subject: Vapor lock 914
Friend has been having problems with "vapor lock" particularly at take off power. Aircraft is Pelican, high wing, L and R wing tanks feeding through a L-Both-R-OFF selector to a gascolator, then through two Facet pumps in series to carburetors, with airbox. Return line is T-eed back to the gascolator. Most lines fire-sleeved. Could the problem be fixed by taking the fuel return back to a wing tank ? ________________________________________________________________________________
Date: Jul 20, 2015
Subject: Re: Vapor lock 914
For what it is worth, the LAA approved arrangement for the 914 in a Europa takes the return line back to the main tank situated in the fuselage. There is substantial return flow which means that you are getting rapid supply as far as the pressure relief valve of fuel at the (hopefully low) temperature of the main tank. In >1000hrs flying this arrangement in often very hot conditions, have never had serious vapour lock problems. Regards , David Joyce On 2015-07-20 13:54, Peter Thomson wrote: > Friend has been having problems with "vapor lock" particularly at take off power. > > Aircraft is Pelican, high wing, L and R wing tanks feeding through a L-Both-R-OFF selector to a gascolator, then through two Facet pumps in series to carburetors, with airbox. Return line is T-eed back to the gascolator. Most lines fire-sleeved. > > Could the problem be fixed by taking the fuel return back to a wing tank ? > Links: ------ [1] http://www.matronics.com/Navigator?RotaxEngines-List [2] http://forums.matronics.com [3] http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 20, 2015
Is the gascolator forward of the firewall (like cessnas) or in the fuselage (like old pipers or my Europa)? Location and temperature make a difference. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444976#444976 ________________________________________________________________________________
Date: Jul 20, 2015
Why does he think it is vapor lock? It could be something different especially at take off when things haven't had a good opportunity to get really hot. Why couldn't it be fuel starvation? All the Flight Design's have their recirculation line go back into the gascolator which is in the lower part of the engine compartment. None of them anywhere has ever had an issue. There is plenty of cool fuel moving through here to prevent vapor lock. If your gascolator were to be to near a heat source then it could be affected. Depending on which of his fuel lines are not fire sleeved then maybe this may contribute. You can plumb the recirculation line back to a header tank, the wing or the gascolator and all are acceptable. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=444985#444985 ________________________________________________________________________________
Date: Jul 21, 2015
HI Stan One year ago I had the same symptoms that you had. I believe this was caused by the fact that the electric pump has a slightly higher pressure than the engine pump and this causes the engine pump to stop pumping while the electric pump is "on." This stagnation of fuel in the engine pump during TO/Climb cause that fuel to vaporize and a momentary loss of pressure when the electric pump is turned "OFF". I've moved my gascolator, filter and boost pump to the rear compartment and firesleeved all the lines. I also ran a return line to my right wing tank. Seam to have helped some but I still see the pressure drop and the occasional warning light when I turn the boost pump "OFF". Never affected the engine but always ready to reselect to boost pump. After shutdown on a hot day burning auto fuel, put an ear close to the engine pump; bet you will hear the fuel boiling. Carl ----- Original Message ----- From: Stan Tew To: rotaxengines-list(at)matronics.com Sent: Monday, July 13, 2015 6:47 PM Subject: RotaxEngines-List: 912 ULS Fuel Pressure My 912 ULS mounted in my Rans S7-S has 438 hr. I replaced the old style mechanical pump as recommended by Rotax. I have an electric fuel pump and fuel pressure gauge. I usually take off with the electric pump running in addition to the mechanical pump. When I level off to cruise I turn off the electric pump. My pressure usually is about 4.5 psi. Last week I was flying and noticed the EIS warning light and it identified my fuel pressure to be about 0.9 psi. I quickly turned on the electric pump. The pressure went to about 3.5 psi. I flew back and landed without incident. The engine never faltered. Any suggestion on how to test the mechanical pump? Any suggestion on what the problem might be? I have not had opportunity to remove the cowl to make any visual checks. Stan Tew N29TD ________________________________________________________________________________
Date: Jul 21, 2015
Peter, That is not vapor lock! That is IMPROPER part insulation. 1- Two boost pumps are not required. 2- The boost pump should be after the fuel selector. 3- What size lines are being used? 4- Gascolators... I hate them! They must be located at the very lowest point in the fuel system. They are a pain to maintain. Their are AD's concerning the safety wire procedure and the drain valve. They give a false sense of security. And, they don't work very well. My guess is you are flooding the carb. Not starving it. Do you have a fuel flow gauge? Check what the MAX fuel flow is from the engine manufacturer and comparing it to what you are seeing. Since you are both a gravity feed and a boost pump feed flooding is more than likely your issue. So, to answer your question about a return line back to the tank! YES, that would be my suggestion also. Next question: What FACET pump do you have? Some of their pumps stop fuel flow or have a high resistance to fuel flow once the pump is turned off. Next question: Many builders think bigger and more is better. What fuel flow rate does your pump supply? Next question: Did the designer say boost pump? Prove to yourself that it is vapor lock. Bet you can't! IF you think it is vapor lock use AvGas and wrap aluminum foil crumpled around the hoses. You can also build a "COOL CAN"... A coil of copper tubing in a metal coffee can where you pack in Dry Ice. This will definitely eliminate vapor lock and increase the SG of the fuel and increase the HP. But, my money is still on flooding. Barry On Monday, July 20, 2015, Peter Thomson wrote: > Friend has been having problems with "vapor lock" particularly at take off > power. > > Aircraft is Pelican, high wing, L and R wing tanks feeding through a > L-Both-R-OFF selector to a gascolator, then through two Facet pumps in > series to carburetors, with airbox. Return line is T-eed back to the > gascolator. Most lines fire-sleeved. > > Could the problem be fixed by taking the fuel return back to a wing tank ? > > > * > > > * > > -- Sent from Gmail Mobile ________________________________________________________________________________
Date: Jul 21, 2015
Hi Richard and Guy, Thanks for the tips, you were both right! So far I was able to track it down to either the generator or the wires to ignition box 2. Sunday we switched o ut the ign.box for a spare one and the problem stayed the same. I also measu red the coils in the generator, the kill switches and the wires that connect them, no problem there. When I interchanged the connectors of the wires to t he kill switches, the problem moved to the other switch. Today I mounted new connectors in the white and green wire between the gener ator and the e-box, no change, the engine still stopped with ign2 ON and ign 1 OFF. Not all the time tough, but after a few minutes of taxiing!! Then I was sure I had it fixed, when I cut the white and green wire close to the generator housing and connected new wires instead. The engine kept runn ing all the time on both ignitions!! So I cut the engine to put insulation on all connections and secure all wire s with tie-ripps, and then the downer occurred: the engine only ran on ign.1 and ign.2 did NOT function anymore! Enough to go absolutely insane.... To be continued! Bart Verstuurd vanaf mijn iPad > Op 19 jul. 2015 om 15:42 heeft Richard Girard het vo lgende geschreven: > > Bart, Don't know if you've had any luck with this issue, but here are some more things to check. > Wire/Coil and Wire/Boot connection. Trim a quarter inch or so (6mm) from t he each end of the wire so that the screw inside the coil and boot can get a firm connection. While you have the boots off, check them for proper resist ance, they should be 5 ohms. If they are too much more consider replacing th em. You can get generics that are 1/10 the price Rotax charges. Test the spa rk plug leads, too. They're wire core and s/b zero ohms. > Test your mag switches for intermittent failure. Just use an ohm meter and flip the switch a couple of dozen times and see if the switch has a failure . > > Rick Girard > > > > > >> On Sun, Jul 12, 2015 at 2:19 PM, Guy Buchanan wrote: > >> >> I'm going to say broken ignition (not plug) wire. See this on the 912 all the time. Use a continuity tester with needles to poke through the insulati on. Work the wires to find the break. >> >> Guy B. >> >> Sent from my iPod >> >> > On Jul 12, 2015, at 11:45 AM, Bart Rond wrote: >> > m> >> > >> > Hi fellow 2-stroke flyers, >> > >> > I am currently working on testruns and (hopefully) testflights with my r estoration project Pulsar 1, equipped with Rotax 582 grey head. >> > A few testflights had to be cancelled, because one of the two ignitions failed in the run-up before take-off. So far, we could not find the cause o f this failure. >> > It does not fail constantly, sometimes it works and sometimes it doesn' t! >> > We suspect one of the ignition coils. Does anyone recognise this proble m? >> > >> > Cheers, Bart >> > >> > Verstuurd vanaf mijn iPad >> > >> > >> > >> > >> >> >> ========== >> - >> xEngines-List" rel="noreferrer" target="_blank">http://www.matronics. com/Navigator?RotaxEngines-List >> ========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributio n >> ========== >> >> >> > > > > -- > > > Believe those who are seeking the truth, doubt those who find it. > -Andre Gide > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 22, 2015
I have exactly the same experience, this was after fitting the new mechanical pump which operates at a slightly higher pressure, it didn't happen before the new pump was fitted.? The drop in pressure does not effect the engine performance but am wary of switching the electric pump back on if required. Regards Dave Park G-LDVO On 21 Jul 2015, at 22:29, Carl wrote: > HI Stan > One year ago I had the same symptoms that you had. I believe this was caused by the fact that the electric pump has a slightly higher pressure than the engine pump and this causes the engine pump to stop pumping while the electric pump is "on." This stagnation of fuel in the engine pump during TO/Climb cause that fuel to vaporize and a momentary loss of pressure when the electric pump is turned "OFF". > I've moved my gascolator, filter and boost pump to the rear compartment and firesleeved all the lines. I also ran a return line to my right wing tank. Seam to have helped some but I still see the pressure drop and the occasional warning light when I turn the boost pump "OFF". Never affected the engine but always ready to reselect to boost pump. > After shutdown on a hot day burning auto fuel, put an ear close to the engine pump; bet you will hear the fuel boiling. > Carl > > ----- Original Message ----- > From: Stan Tew > To: rotaxengines-list(at)matronics.com > Sent: Monday, July 13, 2015 6:47 PM > Subject: RotaxEngines-List: 912 ULS Fuel Pressure > > My 912 ULS mounted in my Rans S7-S has 438 hr. I replaced the old style mechanical pump as recommended by Rotax. I have an electric fuel pump and fuel pressure gauge. I usually take off with the electric pump running in addition to the mechanical pump. When I level off to cruise I turn off the electric pump. My pressure usually is about 4.5 psi. Last week I was flying and noticed the EIS warning light and it identified my fuel pressure to be about 0.9 psi. I quickly turned on the electric pump. The pressure went to about 3.5 psi. I flew back and landed without incident. The engine never faltered. > > Any suggestion on how to test the mechanical pump? Any suggestion on what the problem might be? I have not had opportunity to remove the cowl to make any visual checks. > > Stan Tew > N29TD > > > href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.m atronics.com/Navigator?RotaxEngines-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > > ________________________________________________________________________________
Date: Jul 22, 2015
Enough to go absolutely insane.... Tell me about it Bart. I've been flying two cycle UL's since '78. I thought I knew all the mysteries of the 2-cycle engine. Right. Had a carb leaking fuel badly on my Hornet. Changed it. The replacement leaked just as bad. Changed to a 3rd. carb...same thing. All three were rather old carbs that used Ethanol back when I couldn't get E-free. Finally, I took one (Bing 54) off my Trike that I knew worked okay and fitted it. Didn't leak. I consulted two old time 2-cycle operators: Beaver Borne in Reserve, LA and Rick Davis in Naples, FL. They too were at a loss. I took all carbs apart & found eroded Viton tips we're pretty sure was due to Ethanol & causing the Viton to not seal properly - and causing fuel overflow into float bowl and engine failure. Bottom line, don't use E fuel. Photo was taken in 2010 when I couldn't get any E-free fuel. blumax008(at)aol.com -----Original Message----- From: Bart Rond <bartrond(at)hotmail.com> Sent: Tue, Jul 21, 2015 5:49 pm Subject: Re: RotaxEngines-List: 582 grey head ignition Hi Richard and Guy, Thanks for the tips, you were both right! So far I was able to track it down to either the generator or the wires to ignition box 2. Sunday we switched out the ign.box for a spare one and the problem stayed the same. I also measured the coils in the generator, the kill switches and the wires that connect them, no problem there. When I interchanged the connectors of the wires to the kill switches, the problem moved to the other switch. Today I mounted new connectors in the white and green wire between the generator and the e-box, no change, the engine still stopped with ign2 ON and ign1 OFF. Not all the time tough, but after a few minutes of taxiing!! Then I was sure I had it fixed, when I cut the white and green wire close to the generator housing and connected new wires instead. The engine kept running all the time on both ignitions!! So I cut the engine to put insulation on all connections and secure all wires with tie-ripps, and then the downer occurred: the engine only ran on ign.1 and ign.2 did NOT function anymore! Enough to go absolutely insane.... To be continued! Bart Verstuurd vanaf mijn iPad Op 19 jul. 2015 om 15:42 heeft Richard Girard < aslsa.rng(at)gmail.com> het volgende geschreven: Bart, Don't know if you've had any luck with this issue, but here are some more things to check. Wire/Coil and Wire/Boot connection. Trim a quarter inch or so (6mm) from the each end of the wire so that the screw inside the coil and boot can get a firm connection. While you have the boots off, check them for proper resistance, they should be 5 ohms. If they are too much more consider replacing them. You can get generics that are 1/10 the price Rotax charges. Test the spark plug leads, too. They're wire core and s/b zero ohms. Test your mag switches for intermittent failure. Just use an ohm meter and flip the switch a couple of dozen times and see if the switch has a failure. Rick Girard On Sun, Jul 12, 2015 at 2:19 PM, Guy Buchanan wrote: I'm going to say broken ignition (not plug) wire. See this on the 912 all the time. Use a continuity tester with needles to poke through the insulation. Work the wires to find the break. Guy B. Sent from my iPod > On Jul 12, 2015, at 11:45 AM, Bart Rond < bartrond(at)hotmail.com> wrote: > > > Hi fellow 2-stroke flyers, > > I am currently working on testruns and (hopefully) testflights with my restoration project Pulsar 1, equipped with Rotax 582 grey head. > A few testflights had to be cancelled, because one of the two ignitions failed in the run-up before take-off. So far, we could not find the cause of this failure. > It does not fail constantly, sometimes it works and sometimes it doesn't! > We suspect one of the ignition coils. Does anyone recognise this problem? > > Cheers, Bart > > Verstuurd vanaf mijn iPad > > > > =========== - xEngines-List" rel="noreferrer" target="_blank"> http://www.matronics.com/Navigator?RotaxEngines-List =========== FORUMS - eferrer" target="_blank"> http://forums.matronics.com =========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank"> http://www.matronics.com/contribution =========== -- Believe those who are seeking the truth, doubt those who find it. -Andre Gide D============================================= Engines-List"">http://www.matronics.com/Navigator?RotaxEngines-List D============================================= //forums.matronics.com D============================================= ot;">http://www.matronics.com/contribution D============================================= ________________________________________________________________________________
Date: Jul 23, 2015
Subject: Turbo lubrication question
From: William Daniell <wdaniell.longport(at)gmail.com>
I believe that on the older 914s the turbo has a scavenge pump. However I am looking through the part catalog to find a replacement and I see that in the latest on there is a pressure line from the oil pump and a suction line...the implication being that the scavenge pump has been removed?? Also I cant find the scavenge pump in the turbo section of the catalog. Does anyone know where to find the part no? Second question: has anyone run a turbo with a reduced or straight through "silencer". I have read that turbos have a strong sound suppressing effect. My reason is that I was wondering whether I could loose the weight of the silencer. Many thanks Will William Daniell LONGPORT +57 310 295 0744 ________________________________________________________________________________
Date: Jul 23, 2015
Subject: Re: Turbo lubrication question
Sorry...please cancel my last - I worked it out Will William Daniell LONGPORT +57 310 295 0744 On Thu, Jul 23, 2015 at 7:52 AM, William Daniell < wdaniell.longport(at)gmail.com> wrote: > I believe that on the older 914s the turbo has a scavenge pump. > > However I am looking through the part catalog to find a replacement and I > see that in the latest on there is a pressure line from the oil pump and a > suction line...the implication being that the scavenge pump has been > removed?? > > Also I cant find the scavenge pump in the turbo section of the catalog. > > Does anyone know where to find the part no? > > Second question: has anyone run a turbo with a reduced or straight > through "silencer". I have read that turbos have a strong sound > suppressing effect. My reason is that I was wondering whether I could > loose the weight of the silencer. > > Many thanks > > Will > > William Daniell > LONGPORT > +57 310 295 0744 > > * > > > * > > ________________________________________________________________________________
Date: Aug 03, 2015
Subject: RE: RotaxEngines-List Digest: 0 Msgs - 08/02/15
CgoKU2VudCBmcm9tIG15IFNhbXN1bmcgc21hcnRwaG9uZSBvbiBBVCZUCgotLS0tLS0tLSBPcmln aW5hbCBtZXNzYWdlIC0tLS0tLS0tClN1YmplY3Q6IFJvdGF4RW5naW5lcy1MaXN0IERpZ2VzdDog MCBNc2dzIC0gMDgvMDIvMTUgCkZyb206IFJvdGF4RW5naW5lcy1MaXN0IERpZ2VzdCBTZXJ2ZXIg PHJvdGF4ZW5naW5lcy1saXN0QG1hdHJvbmljcy5jb20+IApUbzogUm90YXhFbmdpbmVzLUxpc3Qg RGlnZXN0IExpc3QgPHJvdGF4ZW5naW5lcy1saXN0LWRpZ2VzdEBtYXRyb25pY3MuY29tPiAKQ0M6 ICAKCioKCj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 CsKgwqAgT25saW5lIFZlcnNpb25zIG9mIFRvZGF5J3MgTGlzdCBEaWdlc3QgQXJjaGl2ZQo9PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQoKVG9kYXkncyBj b21wbGV0ZSBSb3RheEVuZ2luZXMtTGlzdCBEaWdlc3QgY2FuIGFsc28gYmUgZm91bmQgaW4gZWl0 aGVyIG9mIHRoZSAKdHdvIFdlYiBMaW5rcyBsaXN0ZWQgYmVsb3cuwqAgVGhlIC5odG1sIGZpbGUg aW5jbHVkZXMgdGhlIERpZ2VzdCBmb3JtYXR0ZWQgCmluIEhUTUwgZm9yIHZpZXdpbmcgd2l0aCBh IHdlYiBicm93c2VyIGFuZCBmZWF0dXJlcyBIeXBlcmxpbmtlZCBJbmRleGVzIAphbmQgTWVzc2Fn ZSBOYXZpZ2F0aW9uLsKgIFRoZSAudHh0IGZpbGUgaW5jbHVkZXMgdGhlIHBsYWluIEFTQ0lJIHZl cnNpb24gCm9mIHRoZSBSb3RheEVuZ2luZXMtTGlzdCBEaWdlc3QgYW5kIGNhbiBiZSB2aWV3ZWQg d2l0aCBhIGdlbmVyaWMgdGV4dCBlZGl0b3IgCnN1Y2ggYXMgTm90ZXBhZCBvciB3aXRoIGEgd2Vi IGJyb3dzZXIuIAoKSFRNTCBWZXJzaW9uOgoKwqDCoMKgIGh0dHA6Ly93d3cubWF0cm9uaWNzLmNv bS9kaWdlc3QvZGlnZXN0dmlldy5waHA/U3R5bGU9ODI3MDEmVmlldz1odG1sJkNoYXB0ZXI9MjAx NS0wOC0wMiZBcmNoaXZlPVJvdGF4RW5naW5lcwoKVGV4dCBWZXJzaW9uOgoKwqDCoMKgIGh0dHA6 Ly93d3cubWF0cm9uaWNzLmNvbS9kaWdlc3QvZGlnZXN0dmlldy5waHA/U3R5bGU9ODI3MDEmVmll dz10eHQmQ2hhcHRlcj0yMDE1LTA4LTAyJkFyY2hpdmU9Um90YXhFbmdpbmVzCgoKPT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09CsKgwqAgRU1haWwgVmVyc2lv biBvZiBUb2RheSdzIExpc3QgRGlnZXN0IEFyY2hpdmUKPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09CgoKwqDCoMKgwqDCoMKgwqDCoMKgwqAgLS0tLS0tLS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLQrCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIFJvdGF4RW5naW5l cy1MaXN0IERpZ2VzdCBBcmNoaXZlCsKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC0tLQrCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIFRvdGFsIE1lc3NhZ2VzIFBvc3RlZCBTdW4gMDgv MDIvMTU6IDAKwqDCoMKgwqDCoMKgwqDCoMKgwqAgLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLQoKClRvZGF5J3MgTWVzc2FnZSBJbmRleDoK LS0tLS0tLS0tLS0tLS0tLS0tLS0tLQoKCgoKCgoKXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09wqDCoMKgwqDCoMKgwqDCoMKg IC0gVGhlIFJvdGF4RW5naW5lcy1MaXN0IEVtYWlsIEZvcnVtIC0KXy09IFVzZSB0aGUgTWF0cm9u aWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQpfLT0gdGhlIG1hbnkgTGlzdCB1 dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwKXy09IEFyY2hpdmUgU2VhcmNo ICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLApfLT0gUGhvdG9zaGFyZSwgYW5k IG11Y2ggbXVjaCBtb3JlOgpfLT0KXy09wqDCoCAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29t L05hdmlnYXRvcj9Sb3RheEVuZ2luZXMtTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09wqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoCAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQgY29u dGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT3CoMKgIC0tPiBo dHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20KXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoCAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0KXy09wqAgVGhhbmsgeW91IGZv ciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhCl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgpf LT3CoMKgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09CgoK Cgo ________________________________________________________________________________
Subject: 912 Radiator Cap
Date: Aug 09, 2015
This is old news, but I recently confirmed the 912 radiator cap is BMW part number 17112345074. I purchased it here <http://www.2wheelpros.com/oem-parts/bmw-radiator-cap-17112345074-part.html>for about half the cost of the Rotax unit. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. flying again. Now a glider pilot, too. ________________________________________________________________________________
Subject: Re: 912 Radiator Cap
Date: Aug 11, 2015
Hi Guy, Do you happen to know if the BMW part has the same pressure pop-off as the currently supplied Rotax part? -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=445823#445823 ________________________________________________________________________________
Date: Aug 11, 2015
Well I haven't tested it but it has the 1.2 stamped on top and looks and feels identical. I suspect it's the same part. Guy Sent from my iPod > On Aug 11, 2015, at 7:30 AM, rampil wrote: > > > Hi Guy, > Do you happen to know if the BMW part has the same pressure pop-off > as the currently supplied Rotax part? > > -------- > Ira N224XS > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=445823#445823 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: 912 80hp violent vibration on cold start
From: "michaelrosenberg" <mickyrosenberg(at)icloud.com>
Date: Aug 25, 2015
Hi guys, I know this thread was from a while ago, however did you ever find the solution Froghair. This is the only post I have found with identical problems to mine. It is only on cold start.... However, I am from South Australia and a cold day is in the order of 60F. Hardly cold enough to warrant preheating the engine. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=446415#446415 ________________________________________________________________________________
Date: Aug 25, 2015
Most of the time these starting issues come from only a couple of things. Weak battery and or too small a size wire for the starting system and or battery. Carbs not synced, Idle rpm too low or too high, Old black colored starter. The newer gold colored high torque starter is better. It doesn't turn faster just harder. Using a primer system instead of the regular choke setup. (This is a big one.) -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=446418#446418 ________________________________________________________________________________
Date: Aug 25, 2015
Cheers, The battery is brand new, cables are fine etc. Carbs are synced and floats are fine. It does have the black start motor however it cranks over quite hard and starts almost instantaneously, The issue is when it starts it has an ungodly resonance for around 10-30 seconds. In that time it won't accept any throttle response until it comes out of that period then it runs smooth. There are a few reports on the forums of indentical issues, however none seem to report back with the issue or solution. Michael Read this topic online here: http://forums.matronics.com/viewtopic.php?p=446419#446419 ________________________________________________________________________________
Date: Aug 25, 2015
Try increasing the idle speed or open the throttle a touch more at startup Dave > On Aug 25, 2015, at 8:16 PM, michaelrosenberg wrote: > > > Cheers, > > The battery is brand new, cables are fine etc. Carbs are synced and floats are fine. It does have the black start motor however it cranks over quite hard and starts almost instantaneously, > > The issue is when it starts it has an ungodly resonance for around 10-30 seconds. In that time it won't accept any throttle response until it comes out of that period then it runs smooth. > > There are a few reports on the forums of indentical issues, however none seem to report back with the issue or solution. > > Michael > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=446419#446419 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 25, 2015
Micky, What is your startup procedure? How do you set the starting carburetors and the throttle? What is your normal, all warmed up idle speed ? Rick Girard On Tue, Aug 25, 2015 at 8:16 PM, michaelrosenberg wrote: > mickyrosenberg(at)icloud.com> > > Cheers, > > The battery is brand new, cables are fine etc. Carbs are synced and float s > are fine. It does have the black start motor however it cranks over quite > hard and starts almost instantaneously, > > The issue is when it starts it has an ungodly resonance for around 10-30 > seconds. In that time it won't accept any throttle response until it come s > out of that period then it runs smooth. > > There are a few reports on the forums of indentical issues, however none > seem to report back with the issue or solution. > > Michael > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=446419#446419 > > =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Aug 25, 2015
I have tried many different options for starting from a lot of different advice. All options end with the same issue which is perfectly describe from Froghair on the initial post of this thread. Basically, cold weather starry is: Fuel pump on (5secs or leave on) Enriched on Throttle closed Start Engine cranks over well and immediately fires and starts, resonance or shacking happens for 10-30 seconds. Slowely removing enriched or adding throttle has no effect. I can pith the throttle to the firewall and has zero response. Engine probably resonated at around 1000RPM(ish)...... No throttle response means I can not effect this. Once everything smoothed out I warm it up at approx 2000RPM and it will idle around 16-1800RPM. Once it moved out of this resonant time, it purrs. I can only put it down to a fuel delivery or enriched issue. Once I get the engine running smooth at idle, I added some enriched to see what would happen and exactly the same symptoms occurred. Engine wound back to low RPM and resonated again. I kind of expected it to happen in this scenario, how ever the starting issue I have no control over. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=446424#446424 ________________________________________________________________________________
From: Pete Christensen <pchristensen10(at)austin.rr.com>
Date: Aug 25, 2015
I may have had something similar. It turned out to be a sticking float that took a few shakes to unstick. Pete Leander, Tx Kitfox 3 > On Aug 25, 2015, at 8:16 PM, michaelrosenberg wrote: > > > Cheers, > > The battery is brand new, cables are fine etc. Carbs are synced and floats are fine. It does have the black start motor however it cranks over quite hard and starts almost instantaneously, > > The issue is when it starts it has an ungodly resonance for around 10-30 seconds. In that time it won't accept any throttle response until it comes out of that period then it runs smooth. > > There are a few reports on the forums of indentical issues, however none seem to report back with the issue or solution. > > Michael > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=446419#446419 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 25, 2015
Michael, 1000 RPM is way too low for idle on the Rotax 80 hp engine. It will always run rough below about 1800 RPM, and idle speeds lower than that are very hard on the gear box. I am not at all surprised to hear that your idle is quite rough at 1,000 RPM. Your idle should be 1800-2000 RPM, minimum. If it runs smooth at that speed, it's fine. Regards, Paul Kuntz On Tue, Aug 25, 2015 at 7:31 PM, michaelrosenberg wrote: > mickyrosenberg(at)icloud.com> > > I have tried many different options for starting from a lot of different > advice. All options end with the same issue which is perfectly describe > from Froghair on the initial post of this thread. > > Basically, cold weather starry is: > > Fuel pump on (5secs or leave on) > Enriched on > Throttle closed > Start > > Engine cranks over well and immediately fires and starts, resonance or > shacking happens for 10-30 seconds. Slowely removing enriched or adding > throttle has no effect. I can pith the throttle to the firewall and has > zero response. Engine probably resonated at around 1000RPM(ish)...... No > throttle response means I can not effect this. > > Once everything smoothed out I warm it up at approx 2000RPM and it will > idle around 16-1800RPM. > > Once it moved out of this resonant time, it purrs. > > I can only put it down to a fuel delivery or enriched issue. Once I get > the engine running smooth at idle, I added some enriched to see what would > happen and exactly the same symptoms occurred. Engine wound back to low RPM > and resonated again. I kind of expected it to happen in this scenario, how > ever the starting issue I have no control over. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=446424#446424 > > ________________________________________________________________________________
Date: Aug 25, 2015
Oops, sorry, I missed the part about no throttle response, which is obviously the real problem. Yes, it sounds like a fuel delivery issue, but I don't have any good ideas to offer. Paul Kuntz On Tue, Aug 25, 2015 at 9:03 PM, Paul Kuntz wrote: > Michael, > > 1000 RPM is way too low for idle on the Rotax 80 hp engine. It will > always run rough below about 1800 RPM, and idle speeds lower than that are > very hard on the gear box. I am not at all surprised to hear that your > idle is quite rough at 1,000 RPM. Your idle should be 1800-2000 RPM, > minimum. If it runs smooth at that speed, it's fine. > > Regards, > Paul Kuntz > > On Tue, Aug 25, 2015 at 7:31 PM, michaelrosenberg < > mickyrosenberg(at)icloud.com> wrote: > >> mickyrosenberg(at)icloud.com> >> >> I have tried many different options for starting from a lot of different >> advice. All options end with the same issue which is perfectly describe >> from Froghair on the initial post of this thread. >> >> Basically, cold weather starry is: >> >> Fuel pump on (5secs or leave on) >> Enriched on >> Throttle closed >> Start >> >> Engine cranks over well and immediately fires and starts, resonance or >> shacking happens for 10-30 seconds. Slowely removing enriched or adding >> throttle has no effect. I can pith the throttle to the firewall and has >> zero response. Engine probably resonated at around 1000RPM(ish)...... No >> throttle response means I can not effect this. >> >> Once everything smoothed out I warm it up at approx 2000RPM and it will >> idle around 16-1800RPM. >> >> Once it moved out of this resonant time, it purrs. >> >> I can only put it down to a fuel delivery or enriched issue. Once I get >> the engine running smooth at idle, I added some enriched to see what would >> happen and exactly the same symptoms occurred. Engine wound back to low RPM >> and resonated again. I kind of expected it to happen in this scenario, how >> ever the starting issue I have no control over. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=446424#446424 >> >> >> >> >> >> >> >> >> >> >> > ________________________________________________________________________________
Date: Aug 25, 2015
Have you tried this. This technique was developed by a neighbor and fellow Kitfox builder owner. His engine is one of the very early 912 ULSs - long before slipper clutches and soft start modules. I also use it on my 80 hp and it starts running very smoothly. This is the method. Throttle full out, pull choke - ignitions off, crank for ten to fifteen seconds. Wait ten or fifteen seconds throttle in one to 1-1/2 turns. Ignitions both on, pull choke crank. Mine usually starts over revved a tad but smooth as glass. Lowell -------------------------------------------------- From: "michaelrosenberg" <mickyrosenberg(at)icloud.com> Sent: Tuesday, August 25, 2015 7:31 PM Subject: RotaxEngines-List: Re: 912 80hp violent vibration on cold start > > > I have tried many different options for starting from a lot of different > advice. All options end with the same issue which is perfectly describe > from Froghair on the initial post of this thread. > > Basically, cold weather starry is: > > Fuel pump on (5secs or leave on) > Enriched on > Throttle closed > Start > > Engine cranks over well and immediately fires and starts, resonance or > shacking happens for 10-30 seconds. Slowely removing enriched or adding > throttle has no effect. I can pith the throttle to the firewall and has > zero response. Engine probably resonated at around 1000RPM(ish)...... No > throttle response means I can not effect this. > > Once everything smoothed out I warm it up at approx 2000RPM and it will > idle around 16-1800RPM. > > Once it moved out of this resonant time, it purrs. > > I can only put it down to a fuel delivery or enriched issue. Once I get > the engine running smooth at idle, I added some enriched to see what would > happen and exactly the same symptoms occurred. Engine wound back to low > RPM and resonated again. I kind of expected it to happen in this scenario, > how ever the starting issue I have no control over. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=446424#446424 > > > ________________________________________________________________________________
Date: Aug 25, 2015
My own experience with my second 912, an early 912S (before the ULS designation). No clutch and HD starter. Engine started violently shaking both carbs enough to aeriate the fuel in the float bowls. This is why throttle above idle only caused more shake, aggravated the situation, and no increase in rpm. Before Rotax came out with the clutch/HD starter upgrade (at owners expense) my start procedure was by the book with the exception of cracking the throttle to about where 2,000 rpm would be. This helped some, but the startups were still violent and put a lot of stress on the engine and the airframe. When the update became available for the 912S, I had Ronnie Smith of South Mississippi Light Aircraft, Lucedale, MS, install. From that point on, the 912S started like a baby when book procedures were followed, summer and winter. Idled nice and smooth. My current 912ULS had the clutch and HD starter from the factory. Never had a start problem with it as long as I kept the spark plug gaps closed up to about .020". john h Kolb MKIII, N101AB Hyder, Alaska/Stewart, BC From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Paul Kuntz Sent: Tuesday, August 25, 2015 9:07 PM Subject: Re: RotaxEngines-List: Re: 912 80hp violent vibration on cold start Oops, sorry, I missed the part about no throttle response, which is obviously the real problem. Yes, it sounds like a fuel delivery issue, but I don't have any good ideas to offer. Paul Kuntz On Tue, Aug 25, 2015 at 9:03 PM, Paul Kuntz wrote: Michael, 1000 RPM is way too low for idle on the Rotax 80 hp engine. It will always run rough below about 1800 RPM, and idle speeds lower than that are very hard on the gear box. I am not at all surprised to hear that your idle is quite rough at 1,000 RPM. Your idle should be 1800-2000 RPM, minimum. If it runs smooth at that speed, it's fine. Regards, Paul Kuntz On Tue, Aug 25, 2015 at 7:31 PM, michaelrosenberg wrote: I have tried many different options for starting from a lot of different advice. All options end with the same issue which is perfectly describe from Froghair on the initial post of this thread. Basically, cold weather starry is: Fuel pump on (5secs or leave on) Enriched on Throttle closed Start Engine cranks over well and immediately fires and starts, resonance or shacking happens for 10-30 seconds. Slowely removing enriched or adding throttle has no effect. I can pith the throttle to the firewall and has zero response. Engine probably resonated at around 1000RPM(ish)...... No throttle response means I can not effect this. Once everything smoothed out I warm it up at approx 2000RPM and it will idle around 16-1800RPM. Once it moved out of this resonant time, it purrs. I can only put it down to a fuel delivery or enriched issue. Once I get the engine running smooth at idle, I added some enriched to see what would happen and exactly the same symptoms occurred. Engine wound back to low RPM and resonated again. I kind of expected it to happen in this scenario, how ever the starting issue I have no control over. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=446424#446424 - xEngines-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List FORUMS - eferrer" target="_blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
From: "AmphibFlyer" <SeaRey(at)AbstractConcreteWorks.com>
Date: Aug 26, 2015
froghair wrote: > Wondered if anyone has experienced this: > > On cold start, anytime OAT is below ~60F, with full choke (enricher), engine will start but shake violently as though not running on all cylinders. I have to coax it to take any throttle increase for up to ~30 seconds. As soon as it will take throttle, it breaks out of this 'harmonic' and runs normally and will do so until allowed to cool back down to ambient temperature. Mick, another possibility is that the gearbox needs shimming. There's a mandatory 600 hour inspection of the gearbox, but it can need this work even at 300 hours if the engine has often been allowed to idle below about 1800 rpm, especially with a heavy prop. The gearbox contains a dog clutch that's supposed to accommodate the strong pulsing when a cylinder fires at low rpm, but what wears first is the Belleville washers (which are springs that look like washers). When they get loose, or when the prop shaft gets excessively worn, the cylinders will fire, but the rpm won't increase to the point where the spark timing can advance from the retarded start timing to the advanced run timing. (I forget the specific degrees.) When this happens the engine is likely to rock violently. If it does start, it will then run smoothly and will restart when still warm. For a while, until the wear gets worse; then it won't start, period. One sign of this condition is that the engine might make a chicka-chicka-chicka sound when it's trying to start. The remedy is to remove the gearbox and add shims until the Belleville washers are tight enough. Gearbox removal is easy, but you'll need a good Rotax shop to do the shimming. A somewhat similar condition is when the sprag clutch (the starter drive) gets worn. When that happens the engine will fire once and the starter will disengage immediately--too soon to keep the crankshaft turning until the next cylinder can fire. That's quite violent on the 100 hp 912S, but I've not seen it on the 80 hp 912 or the 914. (The gearbox repair is much easier to do, by the way.) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=446442#446442 ________________________________________________________________________________
Date: Aug 26, 2015
CiAgICAKSSByZWNlbnRseSBoYWQgY2FyYnMgZ29uZSB0aHJ1IGJ5IGFhIGV4cGVyaWVuY2VkIFJv dGF4IHNob3AuwqBGbG9hdCBib3dsIGdhc2tldCBkaWQgbm90IEZVTExZIHNlYXQsIGFsbG93aW5n IGZ1ZWwgZGFtcG5lc3MgdW5kZXIgYm93bC7CoDkxMiA4MCBocCBFbmdpbmUgcmFuIHZlcnkgcm91 Z2ggdXAgdG8gbWF5YmUgMjUwMCBycG0sIHByb2JhYmx5IHN1Y2tsaW5nIGFpciBhbmQgcnVubmlu ZyBsZWFuIHdpdGggcG9wcGluZy9iYWNrZmlyZS4gQSBUYXAgd2l0aCBzbWFsbCBiYWxsIHBhbiBo YW1tZXIgdXB3YXJkIHVuZGVyIGZsb2F0IGJvd2wgc29sdmVkICJsZWFrIiBBTkQgcm91Z2ggbG93 IHJwbSBydW5uaW5nLlllcywgSSBrbm93IGEgcGFydGljbGUgY291bGQgaGF2ZSBiZWVuIGRpc2xv ZGdlZCBvciBmbG9hdCBtYXkgaGF2ZSBiZWVuIGJ1bXBlZCBmcmVlIEJVVCBsZWFrIHN0b3BwZWQg YW5kIGxlYW4gcnVubmluZyBiYWNrIGZpcmUgZGlzc2FwcGVhcmVkIHRvZ2V0aGVyIHNvIEkgYmV0 IHRoZSB0d28gd2VyZSBjYXVzZWQgYnkgZmxvYXQgYm93bCBub3QgYmVpbmcgc2VhdGVkIGFsbG93 aW5nIGZ1ZWwgb3V0IGFuZCBhaXIgaW4uQkogS2l0Zm94IElWIDkxMiBXYXJwIERyaXZlLgoKU2Vu dCBmcm9tIG15IFZlcml6b24gV2lyZWxlc3MgNEcgTFRFIHNtYXJ0cGhvbmUKCi0tLS0tLS0tIE9y aWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS0KRnJvbTogUm9nZXIgTGVlIDxzc2FkaXZlcjFAeWFob28u Y29tPiAKRGF0ZTogMDgvMjUvMjAxNSAgMjA6NDYgIChHTVQtMDU6MDApIApUbzogcm90YXhlbmdp bmVzLWxpc3RAbWF0cm9uaWNzLmNvbSAKU3ViamVjdDogUm90YXhFbmdpbmVzLUxpc3Q6IFJlOiA5 MTIgODBocCB2aW9sZW50IHZpYnJhdGlvbiBvbiBjb2xkIHN0YXJ0IAoKLS0+IFJvdGF4RW5naW5l cy1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiUm9nZXIgTGVlIiA8c3NhZGl2ZXIxQHlhaG9vLmNv bT4KCk1vc3Qgb2YgdGhlIHRpbWUgdGhlc2Ugc3RhcnRpbmcgaXNzdWVzIGNvbWUgZnJvbSBvbmx5 IGEgY291cGxlIG9mIHRoaW5ncy4gCgpXZWFrIGJhdHRlcnkgYW5kIG9yIHRvbyBzbWFsbCBhIHNp emUgd2lyZSBmb3IgdGhlIHN0YXJ0aW5nIHN5c3RlbSBhbmQgb3IgYmF0dGVyeS4KCkNhcmJzIG5v dCBzeW5jZWQsCgpJZGxlIHJwbSB0b28gbG93IG9yIHRvbyBoaWdoLAoKT2xkIGJsYWNrIGNvbG9y ZWQgc3RhcnRlci4gVGhlIG5ld2VyIGdvbGQgY29sb3JlZCBoaWdoIHRvcnF1ZSBzdGFydGVyIGlz IGJldHRlci4gSXQgZG9lc24ndCB0dXJuIGZhc3RlciBqdXN0IGhhcmRlci4KClVzaW5nIGEgcHJp bWVyIHN5c3RlbcKgIGluc3RlYWQgb2YgdGhlIHJlZ3VsYXIgY2hva2Ugc2V0dXAuIChUaGlzIGlz IGEgYmlnIG9uZS4pCgotLS0tLS0tLQpSb2dlciBMZWUKVHVjc29uLCBBei4KUm90YXggSW5zdHJ1 Y3RvciAmYW1wOyBSb3RheCBJUkMKTGlnaHQgU3BvcnQgUmVwYWlybWFuIApIb21lIDUyMC01NzQt MTA4MMKgIFRSWSBIT01FIEZJUlNUCkNlbGwgNTIwLTM0OS03MDU2CgoKCgpSZWFkIHRoaXMgdG9w aWMgb25saW5lIGhlcmU6CgpodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBo cD9wPTQ0NjQxOCM0NDY0MTgKCgoKCgoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoCAtIFRo ZSBSb3RheEVuZ2luZXMtTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBM aXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBtYW55IExpc3QgdXRpbGl0 aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERv d25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNo IG11Y2ggbW9yZToKXy09Cl8tPcKgwqAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZp Z2F0b3I/Um90YXhFbmdpbmVzLUxpc3QKXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQg YWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0KXy09wqDCoCAtLT4gaHR0cDov L2ZvcnVtcy5tYXRyb25pY3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKg wqAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPcKgIFRoYW5rIHlvdSBmb3IgeW91 ciBnZW5lcm91cyBzdXBwb3J0IQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4KXy09wqDC oCAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpfLT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQoKCgo ________________________________________________________________________________
Date: Aug 26, 2015
What do you expect! On Tuesday, August 25, 2015, michaelrosenberg wrote: > mickyrosenberg(at)icloud.com > > > I have tried many different options for starting from a lot of different > advice. All options end with the same issue which is perfectly describe > from Froghair on the initial post of this thread. > > Basically, cold weather starry is: > > Fuel pump on (5secs or leave on) > Enriched on > Throttle closed > Start > > Engine cranks over well and immediately fires and starts, resonance or > shacking happens for 10-30 seconds. Slowely removing enriched or adding > throttle has no effect. I can pith the throttle to the firewall and has > zero response. Engine probably resonated at around 1000RPM(ish)...... No > throttle response means I can not effect this. > > Once everything smoothed out I warm it up at approx 2000RPM and it will > idle around 16-1800RPM. > > Once it moved out of this resonant time, it purrs. > > I can only put it down to a fuel delivery or enriched issue. Once I get > the engine running smooth at idle, I added some enriched to see what would > happen and exactly the same symptoms occurred. Engine wound back to low RPM > and resonated again. I kind of expected it to happen in this scenario, how > ever the starting issue I have no control over. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=446424#446424 > > -- Sent from Gmail Mobile ________________________________________________________________________________
Date: Oct 04, 2015
Subject: Re: RotaxEngines-List Digest: 0 Msgs - 10/02/15
G On 03/10/2015 5:13 PM, "RotaxEngines-List Digest Server" < rotaxengines-list(at)matronics.com> wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RotaxEngines-List Digest can also be found in either of > the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RotaxEngines-List Digest and can be viewed with a generic text > editor > such as Notepad or with a web browser. > > HTML Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 15-10-02&Archive=RotaxEngines > > Text Version: > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 15-10-02&Archive=RotaxEngines > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RotaxEngines-List Digest Archive > --- > Total Messages Posted Fri 10/02/15: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > ________________________________________________________________________________
Date: Oct 04, 2015
Zxxcxz . .z On 03/10/2015 5:13 PM, "RotaxEngines-Lismt Digest Server" < rotaxengines-list(at)matronics.com> wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RotaxEngines-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RotaxEngines-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 15-10-02&Archive=RotaxEngines > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 15-10-02&Archive=RotaxEngines > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RotaxEngines-List Digest Archive > --- > Total Messages Posted Fri 10/02/15: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > ________________________________________________________________________________
Subject: Heavy duty starter for Rotax 914?
Date: Oct 13, 2015
Hi all, since I'm planning to move (the much lighter) LiFePo battery http://www.accu-24.de/ALIANT-LiFePO4-Ultralight-Battery-X4-13-2-V-92-Ah from the baggage compartment onto the right footwell and having to change the Rotax sprug clutch this winter (lots of kick backs on starting), I'm also thinking about installing a heavy duty starter like this one http://silent-hektik.com/UL_912_Anlasser.htm . I seem to remember, that it's most advisable to retrofit it on the 912 S with its higher compression. Did anyone of you install such a heavy duty starter on the 912 or 914 or is it just overkill for this engine? Regards Roland PH-ZTI Europa XS TG 914 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447868#447868 ________________________________________________________________________________
Subject: Re: Heavy duty starter for Rotax 914?
Date: Oct 13, 2015
Hi Roland. Get the Soft start model, from Con Air. Problem solved. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447869#447869 ________________________________________________________________________________
Date: Oct 13, 2015
Hi Alan, I watched the Bully Hawk Video - also a good idea to cure the kick back, but one also needs to deactivate one ignition circuit on starting to get the best results. I'll also consider this - thanks. Regards Roland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447871#447871 ________________________________________________________________________________
Date: Oct 13, 2015
Hi, Roland. I take it you have a Key ignition switch and not two separate on and off switches. If so you can still use the same switch as L and R mag, All you need do is deactivate the starter position and take those wires to a separate Starter Button. Job Done. The Soft Start then takes about 20 minutes to fit. Its an easy job to do. Alan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447882#447882 ________________________________________________________________________________
Date: Oct 13, 2015
Or you can disable the hard start module by routing it through a switch you'll keep off when you start. In my case it was avionics power, which I don't switch on until after start. Once started I switch on the avionics, which also activates my B, non soft start, module. That allowed me to use my existing key switch as before. It also allows me to kill the B module before I shut down, which helps as well. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. flying again. Now a glider pilot, too. On 10/13/2015 8:12 AM, Alan Carter wrote: > > Hi, Roland. > > I take it you have a Key ignition switch and not two separate on and off switches. > If so you can still use the same switch as L and R mag, > All you need do is deactivate the starter position and take those wires to a separate Starter Button. > Job Done. > The Soft Start then takes about 20 minutes to fit. > Its an easy job to do. > > Alan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447882#447882 > > ________________________________________________________________________________
Date: Oct 13, 2015
So does that mean if you switch off the avionics master because you have an electrical fault that you lose one of your ignition systems? Hm... Brian Davies -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Guy Buchanan Sent: 13 October 2015 17:49 Subject: Re: RotaxEngines-List: Re: Heavy duty starter for Rotax 914? --> Or you can disable the hard start module by routing it through a switch you'll keep off when you start. In my case it was avionics power, which I don't switch on until after start. Once started I switch on the avionics, which also activates my B, non soft start, module. That allowed me to use my existing key switch as before. It also allows me to kill the B module before I shut down, which helps as well. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. flying again. Now a glider pilot, too. On 10/13/2015 8:12 AM, Alan Carter wrote: > --> > > Hi, Roland. > > I take it you have a Key ignition switch and not two separate on and off switches. > If so you can still use the same switch as L and R mag, All you need > do is deactivate the starter position and take those wires to a separate Starter Button. > Job Done. > The Soft Start then takes about 20 minutes to fit. > Its an easy job to do. > > Alan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=447882#447882 > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Oct 13, 2015
Yes it does, but my avionics are simple in the extreme and very unlikely to catch fire. Any shorts should be handled by the fuses. Not optimal, I know, but best I could do without a major rework. (The install was a retrofit.) Guy On 10/13/2015 10:51 AM, Brian Davies wrote: > > So does that mean if you switch off the avionics master because you have an > electrical fault that you lose one of your ignition systems? Hm... > > Brian Davies > > -----Original Message----- > From: owner-rotaxengines-list-server(at)matronics.com > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Guy > Buchanan > Sent: 13 October 2015 17:49 > To: rotaxengines-list(at)matronics.com > Subject: Re: RotaxEngines-List: Re: Heavy duty starter for Rotax 914? > > --> > > Or you can disable the hard start module by routing it through a switch > you'll keep off when you start. In my case it was avionics power, which I > don't switch on until after start. Once started I switch on the avionics, > which also activates my B, non soft start, module. That allowed me to use my > existing key switch as before. It also allows me to kill the B module before > I shut down, which helps as well. > > Guy Buchanan > Ramona, CA > Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. flying again. > Now a glider pilot, too. > > > On 10/13/2015 8:12 AM, Alan Carter wrote: >> --> >> >> Hi, Roland. >> >> I take it you have a Key ignition switch and not two separate on and off > switches. >> If so you can still use the same switch as L and R mag, All you need >> do is deactivate the starter position and take those wires to a separate > Starter Button. >> Job Done. >> The Soft Start then takes about 20 minutes to fit. >> Its an easy job to do. >> >> Alan >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=447882#447882 >> >> >> >> >> >> >> >> >> >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Oct 13, 2015
This starter is longer and depending on your engine mounts may be too long. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=447917#447917 ________________________________________________________________________________
Subject: engine numbers..?
Date: Oct 14, 2015
Forgive the ignorance- I have just returned to the fold and find 914UL engines have now a S/N in the 6,773,xxx range. Hospital time and a long sojourn have left me wondering what happened to my S/N 4.418.xxx 914UL engine.=99 Save meFerg ________________________________________________________________________________
Subject: Arblast PV50 Propeller C/S Motor Replacment.
Date: Oct 16, 2015
Hello All on Forum. This is for Arblast PV50 flyes if you ever need a new motor, maybe worth copying. First of all i must say a big thank you to Ms Tendai Mugweni who gave me an excellent help and service, as an Ex CAA Examiner I rarely would give 10/10 but the score is 11. So if you need a motor this is the place to go. Electro Mechanical Systems Ltd www.ems-limited.co.uk Tel: 0118 9817391 Arblast Propellers as you know have ceased trading so spares are difficult to obtain, I have been looking for the small electric motor which changes the propellers pitch. After many e-mail and phone calls i have finally tracked down the components, I have done all the hard work so here it is my PV50 flyers. CS Unit Drive. Its a small electric motor which drives a planetary gear head which then mechanically turns a jack screw forward or backwards either increases or decreases the blade pitch angle. The amount of and aft movement of the jack screw is controlled by two micro switches, connected to the DC motor and reversing the polarity changes the motors direction of rotation . This is the motor and fitting kit, the Gear Head is at extra cost and not listed here, but its 246 to 1 drive ratio gear head if you need one. Note the first two numbers refer to the motors diameter ie 23 or 22 the last two numbers are the voltage 12 or 06. Seems to me that all the PV50s CS unit had 6 volt motors on the aircrafts 12v system as mine is and i expect yours is, when measured gives 11.9v at the terminal on the motor. On the motors end a small plastic plate cover states FAULHABER Made in Germany , 2224U006SR, R59, 3909. The R59 denotes the motor has coils at the segment end. The 2224U0006SR isnt a like for like replacement for the 2224U006SR-59, due to the special option 59, which means that the motor has coils for end/commutator seg secured with special adhesive So your identical replacement would be a 2224U006SR, R59, 3909, But i have used the 2224U006SR. at 67.5 which works well, But an upgrade to match the aircrafts system of 12v would be the 2342S12CR at 167.5 but in doing this you would need the G23m16 fitting kit to attach it to the Gear Head, ( i have not done this yet but think the fitting kit is the blue alloy collar in which the two ie Motor and Gear Head are joined in with adhesive.) The Gear Head is 246 to 1 as used by Arblast but it is possible to have a 406 to 1 which is slower but puts the motor under less load, but better go for the more expensive 12v motor. Back at the rear of this lot is a housing with the two Micro Switches which have a diode across two of the terminal, The mirco switches levers run along a shaft and are set at the propeller Fine and Course stops. Removal of Motor. To remove the Motor, unsolder or cut the two wires as close as possible to the motors terminals, Remove the tape from the shaft. The Blue Alloy Collar with light pressure applied to a pair of grips turn the Collar to brake seal, then unscrew by hand, Gently withdraw the motor and pinion from the gear box. Be careful not to disturb the planetary gears as you withdraw motor and pinion, and the fine metal gear retaining washer in front of the gear box. With the motor now out, On a table look for and remove the fine hair wire U clip. Which is Bond in at one end, ( God knows what this is for, seems to doing nothing as i see it) ???? Be careful not to loose it. ( But if you can see a use for it, i would like to know.) Remove the Blue Collar from the motor, by unscrewing the 3 small screws inside the collar. Now pull the collar off from the motor, the two surfaces may have been bonded with Loctite 638, mine was not. (But it is Recommend as listed in text.) Now you have the little motor in your hand. Replace in reverse order. When bonding the motor to the gearhead we suggest you use adhesive Loctite 638 this offers high strength, high temperature resistance and is ideal for bonding small gaps. Before re soldering the wire two the motor, hold the wires on terminals to check the prop works in correct direction/ toggle switch up for fine, toggle down for course. change wires round the other way if it dose not work, check, then finally solder wires onto terminals. No Workshop Manual is Available , So that,s it. DC Motors. 1-4pcs 2342S012CR 119.08 + VAT Due to stock availability in Switzerland (subject to prior sales) the lead time is estimated at 2 3 working weeks from receipt of an order/payment. 1-4pcs 2224U006SR 56.25 + VAT Due to stock availability at EMS(subject to prior sales) therefore please consider 2-3 working days from receipt of an order/payment. Fitting kits are generally provided free of charge when ordered with a gearhead but when ordered separately please note the buy prices would be as follows; G23m18 (Kit required when fitting a 2224U006SR to 23/1 gearhead) 18.85 + VAT please consider 2-3 working weeks G23m16 ( Kit required when fitting a 2342S012CR to 23/1 gearhead) 21.15 + VAT please consider 2-3 working weeks 12v Motor,2342S012CR DC Motor plus Fitting Kit G23M1623/1 168.28 including VAT please consider 2-3 working weeks Kindest regards Ms Tendai Mugweni Electro Mechanical Systems Ltd www.ems-limited.co.uk Tel: 0118 9817391 I have done all the hard work Mr Jeffers as instructed .Happy days Regards. Alan[/b] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448008#448008 ________________________________________________________________________________
Subject: Spark Plug Wires
Date: Oct 31, 2015
I was putting the plug wire back on one of the lower spark plugs and the wire just crumbled in my hand. It appears all the bottom plug wires are brittle and need replaced. Do I need to replace the upper ones too? All the wires are original, 650 hours on them. I have gotten the old spark plug cap off and it appears reusable. The wire appears to be normal wire core spark plug wire that I can get at an auto parts house. My question is how to get the old wire out of the ignition coil. I understand the wire twists into the coil like it does the spark plug cap, but there is tubing similar to heat shrink on the wire and over the end of the coil. The tubing seems to prevent "just untwisting" the wire from the coil. Do I cut the wire near the coil and slit the tubing to get it off? Can I reuse the tubing? If not, is it just heat shrink and what size? Do I need to purchase it from Rotax? Can the wires be removed from the coils without taking the modules and coils off the engine? The spark plug cap measures the proper resistance, so can it be reused? How do you measure the pull off force required? Is there a source for the caps that is less expensive than Rotax? Thanks for your help. Jim Butcher Europa XS Rotax 914 650 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448420#448420 ________________________________________________________________________________
Date: Oct 31, 2015
Subject: Re: Spark Plug Wires
I would replace all upper and lower without question. All caps also. This ho you maintain a good running engine. ________________________________________________________________________________
Date: Nov 01, 2015
Subject: PLEASE READ - Matronics Email List Fund Raiser During
November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 30 different gifts to choose from - more than we've ever had before! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Andy is a very generous guy and I encourage you to visit his web site. I would like publicly to thank Andy for his generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 01, 2015
Jim In my case I replaced the wires with Rotax 2 stroke wires from Spruce. I could not find any info that said the 2 stroke wires could not be used. They are much cheaper than the 4 stroke wires. Have had them on my engine for 2 years now. I replaced all the end caps with the exact same endcaps (per a google search of the cap number) at about 1/2 to 1/3 the price that Rotax charges. You can check the caps for resistance using an ohmmeter and decide if you want to keep any. In my case I just decided to replace all. I also reused the tubing that goes over the wires. I shot a little Kroil under the tube and used a vice to get the tubing off. It wasn't easy but it worked. The wires look nice and work great correcting a mis fire I was having. Dick Maddux Rotax 912UL ________________________________________________________________________________
Date: Nov 01, 2015
Jim, It has been years since I did what you plan to do. First, as I recall, I found the ourltside diameter of the insulation to be unique to Rotax. In other words, I had to search a bit to find the wire needed - that is if you want to reuse the wire to coil sleeves. Regarding the sleeves, I found that they were glued to both wire and coil fittings. I was able to massage them to break the bond. At least in my case, the glue hardened to a brittle consistency and could be separated. What you might try is a piece of stiff wire with the end flattened with a hammer, then rounded to spoon profile and smoothed. Use this to push between the sleeve and the coil fitting. The wires indeed are removable by unscrewing them from the coil. I was able to re-use the spark plug caps. I have a friend that did find after market caps. I am out of the country now with limited resources, but try searching for Aerobuilders. A link should come up out if Caldwell, Idaho. There should be a phone number there. His name is Mark Ferkin. Lowell Fitt On Oct 31, 2015 8:45 AM, "h&jeuropa" wrote: > butcher43(at)att.net> > > I was putting the plug wire back on one of the lower spark plugs and the > wire just crumbled in my hand. It appears all the bottom plug wires are > brittle and need replaced. Do I need to replace the upper ones too? All > the wires are original, 650 hours on them. > > I have gotten the old spark plug cap off and it appears reusable. The > wire appears to be normal wire core spark plug wire that I can get at an > auto parts house. > > My question is how to get the old wire out of the ignition coil. I > understand the wire twists into the coil like it does the spark plug cap, > but there is tubing similar to heat shrink on the wire and over the end of > the coil. The tubing seems to prevent "just untwisting" the wire from the > coil. Do I cut the wire near the coil and slit the tubing to get it off? > Can I reuse the tubing? If not, is it just heat shrink and what size? Do > I need to purchase it from Rotax? > > Can the wires be removed from the coils without taking the modules and > coils off the engine? > > The spark plug cap measures the proper resistance, so can it be reused? > How do you measure the pull off force required? Is there a source for the > caps that is less expensive than Rotax? > > Thanks for your help. > > Jim Butcher > Europa XS > Rotax 914 650 hours > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=448420#448420 > > ________________________________________________________________________________
Date: Nov 04, 2015
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 04, 2015
I would replace all wires. Do not use heat shrink tubing over the wire ends at the coil. This is not heat shrink tubing and you may have issues trying to use heat shrink. This other tubing is thicker and setup to handle the electrical discharge leaks from the coils. As Dick mentioned the plug caps if needed can be found els where other than Rotax. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=448712#448712 ________________________________________________________________________________
Subject: ROTAX 914 engine oil
Date: Nov 04, 2015
I have recently begun to prepare to run the title engine for the first time. I turned to the engine oil specs to find that the one recommended is AeroSHELL Sport plus 4 - not available in Canada. I have therefore sent the following to Austria: =9CWould you be kind enough to send me a case of AeroSHELL Sport plus 4 engine oil so that, placed in my oil reservoir, I can fly to U.S.A. to buy a case of AeroSHELL Sport plus 4 oil? Fergus Kyle Europa C-FFGG" ________________________________________________________________________________
Subject: Re: ROTAX 914 engine oil
Date: Nov 04, 2015
I go with the Honda HP4 10-40w. You might find that in Canada. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. flying again. Now a glider pilot, too. On 11/4/2015 11:39 AM, Fergus Kyle wrote: > I have recently begun to prepare to run the title engine for the first > time. > I turned to the engine oil specs to find that the one recommended is > AeroSHELL Sport plus 4 - not available in Canada. > I have therefore sent the following to Austria: Would you be kind > enough to send me a case of AeroSHELL Sport plus 4 engine oil so that, > placed in my oil reservoir, I can fly to U.S.A. to buy a case of > AeroSHELL Sport plus 4 oil? > Fergus Kyle > Europa C-FFGG" > ________________________________________________________________________________
Date: Nov 04, 2015
aero shell sport plus 4 is available through arcraft spruce in brantford an d rotec in britich columbia... i switch to amsole 5/ 40 or 10 /40 motercycl e oil in the winter months...=C2- From: Fergus Kyle <f.kyle(at)sympatico.ca> To: rotaxengines-list(at)matronics.com Sent: Wednesday, November 4, 2015 2:39 PM Subject: RotaxEngines-List: ROTAX 914 engine oil I have recently begun to prepare to run the title engine for the first tim e. I turned to the engine oil specs to find that the one recommended is Aer oSHELL Sport plus 4 - not available in Canada. I=C2-have=C2-therefore s ent the following to Austria: =C2-=9CWould you be kind enough to se nd me a=C2-case of AeroSHELL Sport plus 4 engine oil so that, placed in m y oil reservoir, I can fly to U.S.A. to buy a case of AeroSHELL Sport plus 4 oil?=C2-Fergus KyleEuropa C-FFGG" ________________________________________________________________________________
Date: Nov 04, 2015
I've used Shell Rotella T-6 full synthetic, and sometimes make my own semi-synthetic by mixing T-6 and Rotella dino oil 50/50, for the past several thousand hours. Never had a problem with it. Seems to suspend lead as well as the full dino recommended by Rotax. Wal-Mart sells for less than 20.00 a gal. Don't want to shock the Rotax purist, but I have also used Fram filters since my first 912 back in 1993, plus another two 912ULS engines since then. My filter of choice is the Fram TG 3614 (that's the Tough Guard filter). Only time I have flown with Rotax oil filters was the one that came with each new engine. Same for spark plug connectors. Last time I found some on line they were about 4 or 5 dollars each. Searched the part number on the connector. john h Kolb MKIII hauck's holler, Alabama From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Dashwoodlock Sent: Wednesday, November 04, 2015 4:10 PM Subject: Re: RotaxEngines-List: ROTAX 914 engine oil aero shell sport plus 4 is available through arcraft spruce in brantford and rotec in britich columbia... i switch to amsole 5/ 40 or 10 /40 motercycle oil in the winter months... _____ From: Fergus Kyle <f.kyle(at)sympatico.ca> Sent: Wednesday, November 4, 2015 2:39 PM Subject: RotaxEngines-List: ROTAX 914 engine oil I have recently begun to prepare to run the title engine for the first time. I turned to the engine oil specs to find that the one recommended is AeroSHELL Sport plus 4 - not available in Canada. I have therefore sent the following to Austria: =9CWould you be kind enough to send me a case of AeroSHELL Sport plus 4 engine oil so that, placed in my oil reservoir, I can fly to U.S.A. to buy a case of AeroSHELL Sport plus 4 oil? Fergus Kyle Europa C-FFGG" ________________________________________________________________________________
Date: Nov 05, 2015
Subject: Coming Soon - The List of Contributors - Please Make
A Contribution Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2015
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 09, 2015
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 11, 2015
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that ilk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 13, 2015
Subject: Make Sure You're Listed! List of Contributors Published
in December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 15, 2015
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 16, 2015
Subject: List Contribution - Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 18, 2015
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some point, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 23 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 20, 2015
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 22, 2015
Date: Nov 23, 2015
Subject: Fund Raiser Behind By 22% - Please Contribute Today!
Dear Listers, The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 22%. Please take this opportunity to show your support for the Matronics Lists and Forums! Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List and Forums Administrator ________________________________________________________________________________
Date: Nov 24, 2015
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 25, 2015
Subject: What Are You Thankful For...?
Dear Listers, Here in the United States, Thursday is our National day of Thanksgiving. Many of us will be traveling to be with our families and friends to share in generous feasts of plenty and giving thanks for the many blessings that have been bestowed upon us. Many Listers have expressed over the last couple of weeks how thankful they are for the Email Lists and Forums here on the Matronics servers and for all of the assistance and comradery they have experienced being a part of the Lists. One of my favorite comments is when someone writes to me and says something like, "Its the first thing I do in the morning while I'm having my morning coffee!". That's a wonderful tribute to the purpose and function of these Lists. Its always great to hear I'm not the only one that jumps out of bed each morning to check my List email!! Won't you take a minute today and show your appreciation for these Lists and for their continued operation and upgrade? The List Contribution Site is: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance for your kind consideration, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 27, 2015
Subject: Make Sure You're Listed! List of Contributors Coming
Soon! Dear Listers, There's just three more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 28, 2015
Subject: Fund Raiser - Just Two Days Left! - Still Well Behind...
Dear Listers, There are just two more full days left in this year's List Fund Raiser. Over the last couple of weeks I have received some really nice comments from members on what the Lists have meant to them and I really appreciate the feedback! At this point, unfortunately, we are still well behind last year in total Contributions to support the continued operation of these services. I really want to keep providing these Lists and Forums to the home built community, but it takes resources. Since there's no advertising budget or deep pockets to keep the operation a float, it's *solely your generosity* during the yearly Fund Raiser that keeps things going. Please make a Contribution today so that I can keep the bills paid and the services and systems turned on. If you've been putting off showing your support for the Lists, now is the time to do it! To make a contribution with a Credit Card or though PayPal at that Matronics Contribution web site: http://www.matronics.com/contribution Or, drop a check in the mail: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 USA Thank you in advance for your support! It is very much appreciated... Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2015
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that elk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 30, 2015
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 52, so don't remind me! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2015
Subject: Re: RotaxEngines-List Digest: 1 Msgs - 11/29/15
RG9uZQoKClNlbnQgZnJvbSBTYW1zdW5nIE1vYmlsZQoKLS0tLS0tLS0gT3JpZ2luYWwgbWVzc2Fn ZSAtLS0tLS0tLQpGcm9tOiBSb3RheEVuZ2luZXMtTGlzdCBEaWdlc3QgU2VydmVyIDxyb3RheGVu Z2luZXMtbGlzdEBtYXRyb25pY3MuY29tPiAKRGF0ZToxMS8zMC8yMDE1ICAxOjAyIEFNICAoR01U LTA3OjAwKSAKVG86IFJvdGF4RW5naW5lcy1MaXN0IERpZ2VzdCBMaXN0IDxyb3RheGVuZ2luZXMt bGlzdC1kaWdlc3RAbWF0cm9uaWNzLmNvbT4gClN1YmplY3Q6IFJvdGF4RW5naW5lcy1MaXN0IERp Z2VzdDogMSBNc2dzIC0gMTEvMjkvMTUgCgoqCgo9PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PQrCoMKgIE9ubGluZSBWZXJzaW9ucyBvZiBUb2RheSdzIExp c3QgRGlnZXN0IEFyY2hpdmUKPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0KClRvZGF5J3MgY29tcGxldGUgUm90YXhFbmdpbmVzLUxpc3QgRGlnZXN0IGNh biBhbHNvIGJlIGZvdW5kIGluIGVpdGhlciBvZiB0aGUgCnR3byBXZWIgTGlua3MgbGlzdGVkIGJl bG93LsKgIFRoZSAuaHRtbCBmaWxlIGluY2x1ZGVzIHRoZSBEaWdlc3QgZm9ybWF0dGVkIAppbiBI VE1MIGZvciB2aWV3aW5nIHdpdGggYSB3ZWIgYnJvd3NlciBhbmQgZmVhdHVyZXMgSHlwZXJsaW5r ZWQgSW5kZXhlcyAKYW5kIE1lc3NhZ2UgTmF2aWdhdGlvbi7CoCBUaGUgLnR4dCBmaWxlIGluY2x1 ZGVzIHRoZSBwbGFpbiBBU0NJSSB2ZXJzaW9uIApvZiB0aGUgUm90YXhFbmdpbmVzLUxpc3QgRGln ZXN0IGFuZCBjYW4gYmUgdmlld2VkIHdpdGggYSBnZW5lcmljIHRleHQgZWRpdG9yIApzdWNoIGFz IE5vdGVwYWQgb3Igd2l0aCBhIHdlYiBicm93c2VyLiAKCkhUTUwgVmVyc2lvbjoKCsKgwqDCoCBo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vZGlnZXN0L2RpZ2VzdHZpZXcucGhwP1N0eWxlPTgyNzAx JlZpZXc9aHRtbCZDaGFwdGVyPTIwMTUtMTEtMjkmQXJjaGl2ZT1Sb3RheEVuZ2luZXMKClRleHQg VmVyc2lvbjoKCsKgwqDCoCBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vZGlnZXN0L2RpZ2VzdHZp ZXcucGhwP1N0eWxlPTgyNzAxJlZpZXc9dHh0JkNoYXB0ZXI9MjAxNS0xMS0yOSZBcmNoaXZlPVJv dGF4RW5naW5lcwoKCj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PQrCoMKgIEVNYWlsIFZlcnNpb24gb2YgVG9kYXkncyBMaXN0IERpZ2VzdCBBcmNoaXZlCj09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQoKCsKgwqDCoMKg wqDCoMKgwqDCoMKgIC0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tLS0KwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqDCoCBSb3RheEVuZ2luZXMtTGlzdCBEaWdlc3QgQXJjaGl2ZQrCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKg wqDCoCAtLS0KwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCBUb3RhbCBN ZXNzYWdlcyBQb3N0ZWQgU3VuIDExLzI5LzE1OiAxCsKgwqDCoMKgwqDCoMKgwqDCoMKgIC0tLS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0KCgpU b2RheSdzIE1lc3NhZ2UgSW5kZXg6Ci0tLS0tLS0tLS0tLS0tLS0tLS0tLS0KCsKgwqDCoMKgIDAu IDA5OjMyIEFNIC0gW1BMRUFTRSBSRUFEXSBXaHkgSSBIYXZlIEEgRnVuZCBSYWlzZXIuLi7CoMKg IChNYXR0IERyYWxsZSkKCgoKX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX1/CoCBNZXNz YWdlIDDCoCBfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fCgoKVGltZTogMDk6 MzI6NTUgQU0gUFNUIFVTCkZyb206IE1hdHQgRHJhbGxlIDxkcmFsbGVAbWF0cm9uaWNzLmNvbT4K U3ViamVjdDogUm90YXhFbmdpbmVzLUxpc3Q6IFtQTEVBU0UgUkVBRF0gV2h5IEkgSGF2ZSBBIEZ1 bmQgUmFpc2VyLi4uwqDCoMKgwqDCoMKgwqDCoCAKCgoKU2luY2UgdGhlIGJlZ2lubmluZywgdGhl IE1hdHJvbmljcyBMaXN0IGFuZCBGb3J1bSBleHBlcmllbmNlIGhhcyBiZWVuIGZyZWUgZnJvbQph ZHZlcnRpc2luZy7CoCBJIGhhdmUgYmVlbiBhcHByb2FjaGVkIGJ5IGZhaXIgbnVtYmVyIG9mIHZl bmRvcnMgd2FudGluZyB0byB0YXAKaW50byB0aGUgbGFyZ2Ugdm9sdW1lIG9mIGFjdGl2aXR5IGFj cm9zcyB0aGUgdmFyaW91cyBsaXN0cyBob3N0ZWQgaGVyZSwgYnV0IGhhdmUKYWx3YXlzIGZsYXRs eSByZWZ1c2VkLsKgIEV2ZXJ5d2hlcmUgeW91IGdvIG9uIHRoZSBJbnRlcm5ldCB0aGVzZSBkYXlz LCBhIHVzZXIKaXMgcHVtbWVsZWQgd2l0aCBmbGFzaGluZyBiYW5uZXJzIGFuZCB2aWRlb3MgYW5k IGFkcyBmb3IgY3JhcCB0aGF0IHRoZXkgZG9uJ3QKd2FudC7CoCBZYWhvbywgR29vZ2xlIGFuZCB0 aGF0IGVsayBhcmUgbm90ICJmcmVlIi7CoCBUaGUgdXNlciBtdXN0IGNvbnN0YW50bHkKZW5kdXJl IHRoZWlyIGJhcnJhZ2Ugb2YgY29tbWVyY2lhbGlzbSB0aHJ1c3QgaW50byB0aGVpciBmYWNlIGF0 IGFuIGV2ZXIgaW5jcmVhc2luZwpyYXRlLsKgIEVub3VnaCBpcyBlbm91Z2gsIGFuZCB0aGUgTGlz dHMgYXQgTWF0cm9uaWNzIGNob29zZSBub3QgdG8gc3VjY3VtYgp0byB0aGF0LgoKVGhhdCBiZWlu ZyBzYWlkLCBydW5uaW5nIGEgc2VydmljZSBvZiB0aGlzIHNpemUgaXMgbm90ICJmcmVlIi7CoCBJ dCBjb3N0cyBhIGxvdApvZiBtb25leSB0byBtYWludGFpbiB0aGUgaGFyZHdhcmUsIHBheSBmb3Ig dGhlIGVsZWN0cmljaXR5LCBhaXIgY29uZGl0aW9uaW5nLAptYWludGVuYW5jZSBjb250cmFjdHMs IGV0YywgZXRjLiBldGMuwqAgSSBjaG9vc2UgdG8gaG9sZCBhIFBCUy1saWtlIGZ1bmQgcmFpc2Vy CmVhY2ggeWVhciBkdXJpbmcgdGhlIG1vbnRoIG9mIE5vdmVtYmVyIHdoZXJlIEkgc2ltcGx5IHNl bmQgb3V0IGEgc2hvcnQgZW1haWwKZXZlcnkgb3RoZXIgZGF5IGFza2luZyB0aGUgbWVtYmVycyB0 byBtYWtlIGEgc21hbGwgY29udHJpYnV0aW9uIHRvIHN1cHBvcnQgdGhlCm9wZXJhdGlvbi7CoCBU aGF0IGJlaW5nIHNhaWQsIHRoYXQgY29udHJpYnV0aW9uIGlzIGNvbXBsZXRlbHkgdm9sdW50YXJ5 IGFuZCBub24tY29tcHVsc29yeS4KTWFueSBtZW1iZXJzIGNob29zZSBub3QgdG8gY29udHJpYnV0 ZSBhbmQgdGhhdCdzIGZpbmUuCgpIb3dldmVyLCBhIHZlcnkgbW9kZXN0IHBlcmNlbnRhZ2Ugb2Yg dGhlIG1lbWJlcnMgZG8gY2hvb3NlIHRvIG1ha2UgYSBjb250cmlidXRpb24KYW5kIGl0IGlzIHRo YXQgZmluYW5jaWFsIHN1cHBvcnQgdGhhdCBrZWVwcyB0aGUgTGlzdHMgcnVubmluZy7CoCBBbmQg dGhhdCdzCml0LsKgIFRvIG15IHdheSBvZiB0aGlua2luZywgaXQgaXMgYSBtdWNoIG1vcmUgcGxl YXNhbnQgd2F5IG9mIG1haW50YWluaW5nIHRoZQpMaXN0cyBhbmQgRm9ydW1zLsKgIFRoZSBvdGhl ciAxMSBtb250aHMgb2YgdGhlIHllYXIsIHlvdSBkb24ndCBzZWUgYSBzaW5nbGUgYWR2ZXJ0aXNl bWVudApvciByZXF1ZXN0IGZvciBzdXBwb3J0LsKgIFRoYXQncyByZWZyZXNoaW5nIGFuZCB0aGF0 IGlzIGEgTGlzdCBhbmQgRm9ydW0KdGhhdCBJIHdhbnQgdG8gYmVsb25nIHRvLsKgIEkgdGhpbmsg b3RoZXIgcGVvcGxlIGZlZWwgdGhlIHNhbWUgd2F5LgoKV29uJ3QgeW91IHBsZWFzZSB0YWtlIGEg bWludXRlIHRvIG1ha2UgeW91ciBDb250cmlidXRpb24gdG9kYXkgYW5kIHN1cHBvcnQgdGhlc2UK TGlzdHM/IAoKwqDCoMKgwqDCoMKgwqAgaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1 dGlvbgoKT3IsIGRyb3AgYSBwZXJzb25hbCBjaGVjayBpbiB0aGUgbWFpbCB0bzogCgrCoMKgwqDC oMKgwqDCoCBNYXR0IERyYWxsZSAvIE1hdHJvbmljcyAKwqDCoMKgwqDCoMKgwqAgNTgxIEplYW5u aWUgV2F5IArCoMKgwqDCoMKgwqDCoCBMaXZlcm1vcmUgQ0EgOTQ1NTAKwqDCoMKgwqDCoMKgwqAg VVNBCgpUaGFuayB5b3UgZm9yIHlvdXIgc3VwcG9ydCEgCgpNYXR0IERyYWxsZSAKRW1haWwgTGlz dCBBZG1pbi4gCgoKCgoKXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0KXy09Cl8tPcKgwqDCoMKgwqDCoCAtLSBQbGVhc2UgU3VwcG9y dCBZb3VyIExpc3RzIFRoaXMgTW9udGggLS0KXy09wqDCoMKgwqDCoMKgwqDCoMKgwqAgKEFuZCBH ZXQgU29tZSBBV0VTT01FIEZSRUUgR2lmdHMhKQpfLT0KXy09wqDCoCBOb3ZlbWJlciBpcyB0aGUg QW5udWFsIExpc3QgRnVuZCBSYWlzZXIuwqAgQ2xpY2sgb24KXy09wqDCoCB0aGUgQ29udHJpYnV0 aW9uIGxpbmsgYmVsb3cgdG8gZmluZCBvdXQgbW9yZSBhYm91dApfLT3CoMKgIHRoaXMgeWVhcidz IFRlcnJpZmljIEZyZWUgSW5jZW50aXZlIEdpZnRzIHByb3ZpZGVkCl8tPcKgwqAgYnk6Cl8tPcKg wqAgCl8tPcKgwqDCoMKgICogVGhlIEJ1aWxkZXIncyBCb29rc3RvcmUgd3d3LmJ1aWxkZXJzYm9v a3MuY29tCl8tPQpfLT3CoMKgIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlOgpfLT0KXy09wqDC oCAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpfLT0KXy09wqDCoCBU aGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEKXy09Cl8tPcKgwqDCoMKgwqDCoMKg wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLU1hdHQgRHJhbGxl LCBMaXN0IEFkbWluLgpfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT0KXy09wqDCoMKgwqDCoMKgwqDCoMKgIC0gVGhlIFJvdGF4 RW5naW5lcy1MaXN0IEVtYWlsIEZvcnVtIC0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVh dHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3Vj aCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwKXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQs IDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLApfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBt b3JlOgpfLT0KXy09wqDCoCAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9S b3RheEVuZ2luZXMtTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oCAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2 YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhCl8tPQpfLT3CoMKgIC0tPiBodHRwOi8vZm9ydW1z Lm1hdHJvbmljcy5jb20KXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtIExp c3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0KXy09wqAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVy b3VzIHN1cHBvcnQhCl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgpfLT3CoMKgIC0tPiBo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09CgoKCgo ________________________________________________________________________________
Date: Dec 01, 2015
Subject: Looking for Rotax 912 80 HP
Does anyone of you have a Rotax 912 for sale, or do you know anyone who does? If so please let me know. I am looking primarily for an engine in Europe. Thank you. Best regards, George Nielsen The Hague, the Netherlands ________________________________________________________________________________
Date: Dec 19, 2015
Subject: Auction For P113 eMag To Support Matronics List Fund
Raiser Dear Listers, Bob Nuckolls of the AeroElectric fame has generously put a new eMag P113 electronic 4-cylinder mag up for sale on EBay. Bob has pledged to donate all of the proceeds from this auction in support of this year's Matronics Fund Raiser. If you are in the market for one of these great electronic ignitions (I have two eMags on my RV-8 and love them), please bid on this one! http://www.ebay.com/itm/151920582478 Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 19, 2015
Subject: 2015 List of Contributors
Dear Listers, The 2015 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Andy, Bob, and George for their generous support through the supply of many great gifts this year!! These guys have some excellent products and I encourage you to visit their respective web sites: Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com Bob Nucklolls - AeroElectric - http://www.aeroelectric.com George Race - Race Consulting - http://www.mrrace.com And finally, I'm proud to present The 2015 Fund Raiser List of Contributors: http://www.matronics.com/loc/2015.html Thanks again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Subject: Wanted - RING MOUNT for 912ULS, also OIL TANK for same
Date: Jan 21, 2016
Wanted - RING MOUNT for 912ULS, also OIL TANK for same -------- David Walters 01474 816817 dave(at)robotas.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452171#452171 ________________________________________________________________________________
Subject: SCAM!!
Date: Feb 02, 2016
Hello listers, I was victim of online purchase fraud and I send out a warning to you all! It concerns the purchase of a Rotax engine that was offered on craigslist. All personal data and bankaccount seemed legitable, but my money is gone and no engine!! Be carefull! Bart Rond Verstuurd vanaf mijn iPad ________________________________________________________________________________
Subject: Re: SCAM!!
Date: Feb 02, 2016
Sorry to hear about that. Details would be very useful, including names if you feel legally confident in revealing them. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. flying again. Now a glider pilot, too. On 2/2/2016 4:02 AM, Bart Rond wrote: > > Hello listers, > > I was victim of online purchase fraud and I send out a warning to you all! > It concerns the purchase of a Rotax engine that was offered on craigslist. > All personal data and bankaccount seemed legitable, but my money is gone and no engine!! > Be carefull! > > Bart Rond > > Verstuurd vanaf mijn iPad > > ________________________________________________________________________________
Subject: SCAM!!
Date: Feb 02, 2016
Wow!! Thanking you for Info. BEWARE!!! > Subject: Re: RotaxEngines-List: SCAM!! > To: rotaxengines-list(at)matronics.com > From: gebuchanan(at)cox.net > Date: Tue=2C 2 Feb 2016 09:16:06 -0800 > > > > Sorry to hear about that. Details would be very useful=2C including names > if you feel legally confident in revealing them. > > Guy Buchanan > Ramona=2C CA > Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. flying again. > Now a glider pilot=2C too. > > > > On 2/2/2016 4:02 AM=2C Bart Rond wrote: m> > > > > Hello listers=2C > > > > I was victim of online purchase fraud and I send out a warning to you a ll! > > It concerns the purchase of a Rotax engine that was offered on craigsli st. > > All personal data and bankaccount seemed legitable=2C but my money is g one and no engine!! > > Be carefull! > > > > Bart Rond > > > > Verstuurd vanaf mijn iPad > > > > > > > > > > =========== =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Re: SCAM!!
Date: Feb 02, 2016
Sent from my iPad > On Feb 2, 2016, at 11:15 AM, bro Sister wrot e: > > Wow!! > > Thanking you for Info. > > BEWARE!!! > > > Subject: Re: RotaxEngines-List: SCAM!! > > To: rotaxengines-list(at)matronics.com > > From: gebuchanan(at)cox.net > > Date: Tue, 2 Feb 2016 09:16:06 -0800 > > t> > > > > Sorry to hear about that. Details would be very useful, including names > > if you feel legally confident in revealing them. > > > > Guy Buchanan > > Ramona, CA > > Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. flying again. > > Now a glider pilot, too. > > > > > > > > On 2/2/2016 4:02 AM, Bart Rond wrote: om> > > > > > > Hello listers, > > > > > > I was victim of online purchase fraud and I send out a warning to you a ll! > > > It concerns the purchase of a Rotax engine that was offered on craigsl ist. > > > All personal data and bankaccount seemed legitable, but my money is go ne and no engine!! > > > Be carefull! > > > > > > Bart Rond > > > > > > Verstuurd vanaf mijn iPad > > > > > ============= > > > > > > ________________________________________________________________________________
Subject: Re: SCAM!!
Date: Feb 02, 2016
I'll assume you went thru PayPal. 1. Never fill out the papal purchase or seller sale agreement. That gives out way to much info to be used against you. 2. PayPal doesn't send you a email that details the transaction and tells you to send money. The scammer sent that to you. Now if you didn't deal with PayPal which holds the money until you become a happy camper with the deal. Just remember 1&2. If your selling the 1&2 still applies and 3. If PayPal shows some one put money In your account that shows on bottom but at top of that page shows no money, the transaction has not been funded. Go into your account that shows all your transaction it most likely won't show a completed transaction. [Embarassed] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452546#452546 ________________________________________________________________________________
Subject: Rotax oil tank
Date: Mar 08, 2016
Hi all. Looking for a rotax oil tank for my 914. Would like one as new and unused as possible. Please pm or email me. Many thanks Frank Xuereb kit#165 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453567#453567 ________________________________________________________________________________
Subject: Re: Rotax oil tank
Date: Mar 08, 2016
Call Leading Edge because they do have used parts many times, but not always. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453589#453589 ________________________________________________________________________________
Date: Mar 08, 2016
Hello Rodger, thanks very much for the lead. Forgot to say that I am in the UK and looking for a source on here if possible. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453593#453593 ________________________________________________________________________________
Subject: 582 volts to high
Date: Apr 02, 2016
I have a 582 grey head model 90 My volt meter at 3000 rpm reads 14.25 and 5500 is 15.50 I replaced it with one from CPS # 866-080 the same one that ran for 125 hr and it reads the same could it be bad or is there something else to look for I put new battery in checked wire connection and grounds . Thinking of going to the 3phase one from Cps any info would help thanks. Jerry. Kitfox 2 Magalia cal 530-228-5185 Sent from my iPhone ________________________________________________________________________________
Subject: Re: 582 volts to high
Date: Apr 02, 2016
That sounds like a normal no-load output Dave Alberti 414-699-9312 > On Apr 2, 2016, at 9:13 AM, Jerry wrote: > > > I have a 582 grey head model 90 My volt meter at 3000 rpm reads 14.25 and 5500 is 15.50 I replaced it with one from CPS # 866-080 the same one that ran for 125 hr and it reads the same could it be bad or is there something else to look for I put new battery in checked wire connection and grounds . Thinking of going to the 3phase one from Cps any info would help thanks. Jerry. Kitfox 2 > Magalia cal 530-228-5185 > Sent from my iPhone > > > > > ________________________________________________________________________________
Date: Apr 02, 2016
Jerry: Normal charge is 13.8 VDC to 14.2 VDC. As you know 15.5 VDC is too high and can overcharge the battery. SO, the simple cure is to Turn Something On! And then read the voltage. OR! If you are the Electrical Type, just install a Zenor Diode with a value between 13.8 to 14.2 VDC and a resistor to handle the over voltage. 15.5 - 14.2 = 1.4 VDC ... 1.4 VDC @ say 3 Amps = 4.2 Watts // 1.4 VDC / 3 Amps = 0.43 Ohms... Easy enough to get a 0.5 Ohm resistor at 5 Watts. This will limit your voltage to 14.2 VDC for charging. Less expensive than buying a ... Barry On Sat, Apr 2, 2016 at 10:13 AM, Jerry wrote: > > I have a 582 grey head model 90 My volt meter at 3000 rpm reads 14.25 and > 5500 is 15.50 I replaced it with one from CPS # 866-080 the same one that > ran for 125 hr and it reads the same could it be bad or is there something > else to look for I put new battery in checked wire connection and grounds > . Thinking of going to the 3phase one from Cps any info would help thanks. > Jerry. Kitfox 2 > Magalia cal 530-228-5185 > Sent from my iPhone > > ________________________________________________________________________________
Date: Apr 19, 2016
Subject: Matronics Web Server Back Online
Dear Listers, The Matronics Web server lost a critical system hard drive yesterday 4/18/2016. I have been working feverishly for the last 24 hours to repair the system and get the Matronics Forums and other web-based resources back online. Email services were not impacted in anyway. back online and all resources were successfully restored from a backup. My apologies for the down time. Matt Dralle Matronics Email and Forum Admin ________________________________________________________________________________
Date: Apr 26, 2016
Subject: RE: RotaxEngines-List Digest: 0 Msgs - 04/25/16
UGxlYXNlIHJlbW92ZSBtZSBmcm9tIHRoZSBsaXN0LiDCoFRoYW5rcywgUGF1bMKgCgoKU2VudCB2 aWEgdGhlIFNhbXN1bmcgR2FsYXh5IFPCriA2LCBhbiBBVCZUIDRHIExURSBzbWFydHBob25lLS0t LS0tLS0gT3JpZ2luYWwgbWVzc2FnZSAtLS0tLS0tLQpGcm9tOiBSb3RheEVuZ2luZXMtTGlzdCBE aWdlc3QgU2VydmVyIDxyb3RheGVuZ2luZXMtbGlzdEBtYXRyb25pY3MuY29tPiAKRGF0ZTogMDQv MjYvMjAxNiAgMjowMiBBTSAgKEdNVC0wNjowMCkgClRvOiBSb3RheEVuZ2luZXMtTGlzdCBEaWdl c3QgTGlzdCA8cm90YXhlbmdpbmVzLWxpc3QtZGlnZXN0QG1hdHJvbmljcy5jb20+IApTdWJqZWN0 OiBSb3RheEVuZ2luZXMtTGlzdCBEaWdlc3Q6IDAgTXNncyAtIDA0LzI1LzE2IAoKKgoKID09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09CsKgwqAgT25saW5l IFZlcnNpb25zIG9mIFRvZGF5J3MgTGlzdCBEaWdlc3QgQXJjaGl2ZQogPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KClRvZGF5J3MgY29tcGxldGUgUm90 YXhFbmdpbmVzLUxpc3QgRGlnZXN0IGNhbiBhbHNvIGJlIGZvdW5kIGluIGVpdGhlciBvZiB0aGUg CnR3byBXZWIgTGlua3MgbGlzdGVkIGJlbG93LsKgIFRoZSAuaHRtbCBmaWxlIGluY2x1ZGVzIHRo ZSBEaWdlc3QgZm9ybWF0dGVkIAppbiBIVE1MIGZvciB2aWV3aW5nIHdpdGggYSB3ZWIgYnJvd3Nl ciBhbmQgZmVhdHVyZXMgSHlwZXJsaW5rZWQgSW5kZXhlcyAKYW5kIE1lc3NhZ2UgTmF2aWdhdGlv bi7CoCBUaGUgLnR4dCBmaWxlIGluY2x1ZGVzIHRoZSBwbGFpbiBBU0NJSSB2ZXJzaW9uIApvZiB0 aGUgUm90YXhFbmdpbmVzLUxpc3QgRGlnZXN0IGFuZCBjYW4gYmUgdmlld2VkIHdpdGggYSBnZW5l cmljIHRleHQgZWRpdG9yIApzdWNoIGFzIE5vdGVwYWQgb3Igd2l0aCBhIHdlYiBicm93c2VyLiAK CkhUTUwgVmVyc2lvbjoKCsKgwqDCoCBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vZGlnZXN0L2Rp Z2VzdHZpZXcucGhwP1N0eWxlPTgyNzAxJlZpZXc9aHRtbCZDaGFwdGVyPTIwMTYtMDQtMjUmQXJj aGl2ZT1Sb3RheEVuZ2luZXMKClRleHQgVmVyc2lvbjoKCsKgwqDCoCBodHRwOi8vd3d3Lm1hdHJv bmljcy5jb20vZGlnZXN0L2RpZ2VzdHZpZXcucGhwP1N0eWxlPTgyNzAxJlZpZXc9dHh0JkNoYXB0 ZXI9MjAxNi0wNC0yNSZBcmNoaXZlPVJvdGF4RW5naW5lcwoKCiA9PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KwqDCoCBFTWFpbCBWZXJzaW9uIG9mIFRvZGF5 J3MgTGlzdCBEaWdlc3QgQXJjaGl2ZQogPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09CgogCsKgwqDCoMKgwqDCoMKgwqDCoMKgIC0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0KwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCBSb3RheEVuZ2luZXMtTGlzdCBE aWdlc3QgQXJjaGl2ZQrCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtLS0KwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqDCoMKgwqDCoCBUb3RhbCBNZXNzYWdlcyBQb3N0ZWQgTW9uIDA0LzI1LzE2OiAw CsKgwqDCoMKgwqDCoMKgwqDCoMKgIC0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0KIAogClRvZGF5J3MgTWVzc2FnZSBJbmRleDoKLS0tLS0t LS0tLS0tLS0tLS0tLS0tLQogCiAKIAogCiAKCgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT3CoMKgwqDCoMKgwqDCoMKgwqAg LSBUaGUgUm90YXhFbmdpbmVzLUxpc3QgRW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25p Y3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0 aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2gg JiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQg bXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT3CoMKgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20v TmF2aWdhdG9yP1JvdGF4RW5naW5lcy1MaXN0Cl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT3CoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqDCoMKgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQpfLT0gU2FtZSBncmVhdCBjb250 ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyEKXy09Cl8tPcKgwqAgLS0+IGh0 dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09wqDCoMKgwqDCoMKgwqDCoMKg wqDCoMKgwqAgLSBORVcgTUFUUk9OSUNTIExJU1QgV0lLSSAtCl8tPSBBZGQgc29tZSBpbmZvIHRv IHRoZSBNYXRyb25pY3MgRW1haWwgTGlzdCBXaWtpIQpfLT3CoMKgIC0tPiBodHRwOi8vd2lraS5t YXRyb25pY3MuY29tCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtIExpc3QgQ29u dHJpYnV0aW9uIFdlYiBTaXRlIC0KXy09wqAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1 cHBvcnQhCl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgwqAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgpfLT3CoMKgIC0tPiBodHRwOi8v d3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09CiAKIAoKCgo ________________________________________________________________________________
Date: Apr 26, 2016
You have to remove yourself I=99m afraid Paul =93 instructions here: http://www.matronics.com/subscription/ HTH Paul M From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Paul Sent: 26 April 2016 10:16 Subject: RotaxEngines-List: RE: RotaxEngines-List Digest: 0 Msgs - 04/25/16 Please remove me from the list. Thanks, Paul Sent via the Samsung Galaxy S=C2=AE 6, an AT&T 4G LTE smartphone -------- Original message -------- From: RotaxEngines-List Digest Server <rotaxengines-list(at)matronics.com > Date: 04/26/2016 2:02 AM (GMT-06:00) > Subject: RotaxEngines-List Digest: 0 Msgs - 04/25/16 * Online Versions of Today's List Digest Archive Today's complete RotaxEngines-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RotaxEngines-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701 <http://www.matronics.com/digest/digestview.php?Style=82701&View=html &Chapter 16-04-25&Archive=RotaxEngines> &View=html&Chapter 16-04-25&Archive=RotaxEngines Text Version: http://www.matronics.com/digest/digestview.php?Style=82701 <http://www.matronics.com/digest/digestview.php?Style=82701&View=txt& Chapter 16-04-25&Archive=RotaxEngines> &View=txt&Chapter 16-04-25&Archive=RotaxEngines ====================== EMail Version of Today's List Digest Archive ====================== ---------------------------------------------------------- RotaxEngines-List Digest Archive --- Total Messages Posted Mon 04/25/16: 0 ---------------------------------------------------------- Today's Message Index: ---------------------- ________________________________________________________________________________
From: Stephen Richards <stephencliverichards(at)gmail.com>
Date: Apr 26, 2016
UGF1bCB0byByZW1vdmUgeW91ciBzZWxmIGZyb20gbGlzdCB1c2UgbmF2aWdhdG9yIG9uIHdlYiBz ZWUgYm90dG9tIG9mIHBvc3QgZm9yIGFkZHJlc3MNCkNsaXZlIA0KDQotLS0tLU9yaWdpbmFsIE1l c3NhZ2UtLS0tLQ0KRnJvbTogIlBhdWwiIDxwYXVsQHNpZ3NvbG5zLmNvbT4NClNlbnQ6IOKAjjI2 L+KAjjA0L+KAjjIwMTYgMTA6MjINClRvOiAicm90YXhlbmdpbmVzLWxpc3RAbWF0cm9uaWNzLmNv bSIgPHJvdGF4ZW5naW5lcy1saXN0QG1hdHJvbmljcy5jb20+DQpTdWJqZWN0OiBSb3RheEVuZ2lu ZXMtTGlzdDogUkU6IFJvdGF4RW5naW5lcy1MaXN0IERpZ2VzdDogMCBNc2dzIC0gMDQvMjUvMTYN Cg0KUGxlYXNlIHJlbW92ZSBtZSBmcm9tIHRoZSBsaXN0LiAgVGhhbmtzLCBQYXVsIA0KDQoNCg0K DQoNCg0KU2VudCB2aWEgdGhlIFNhbXN1bmcgR2FsYXh5IFPCriA2LCBhbiBBVCZUIDRHIExURSBz bWFydHBob25lDQotLS0tLS0tLSBPcmlnaW5hbCBtZXNzYWdlIC0tLS0tLS0tDQpGcm9tOiBSb3Rh eEVuZ2luZXMtTGlzdCBEaWdlc3QgU2VydmVyIDxyb3RheGVuZ2luZXMtbGlzdEBtYXRyb25pY3Mu Y29tPiANCkRhdGU6IDA0LzI2LzIwMTYgMjowMiBBTSAoR01ULTA2OjAwKSANClRvOiBSb3RheEVu Z2luZXMtTGlzdCBEaWdlc3QgTGlzdCA8cm90YXhlbmdpbmVzLWxpc3QtZGlnZXN0QG1hdHJvbmlj cy5jb20+IA0KU3ViamVjdDogUm90YXhFbmdpbmVzLUxpc3QgRGlnZXN0OiAwIE1zZ3MgLSAwNC8y NS8xNiANCg0KDQoqDQoNCj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09DQogICBPbmxpbmUgVmVyc2lvbnMgb2YgVG9kYXkncyBMaXN0IERpZ2VzdCBBcmNo aXZlDQo9PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0K DQpUb2RheSdzIGNvbXBsZXRlIFJvdGF4RW5naW5lcy1MaXN0IERpZ2VzdCBjYW4gYWxzbyBiZSBm b3VuZCBpbiBlaXRoZXIgb2YgdGhlIA0KdHdvIFdlYiBMaW5rcyBsaXN0ZWQgYmVsb3cuICBUaGUg Lmh0bWwgZmlsZSBpbmNsdWRlcyB0aGUgRGlnZXN0IGZvcm1hdHRlZCANCmluIEhUTUwgZm9yIHZp ZXdpbmcgd2l0aCBhIHdlYiBicm93c2VyIGFuZCBmZWF0dXJlcyBIeXBlcmxpbmtlZCBJbmRleGVz IA0KYW5kIE1lc3NhZ2UgTmF2aWdhdGlvbi4gIFRoZSAudHh0IGZpbGUgaW5jbHVkZXMgdGhlIHBs YWluIEFTQ0lJIHZlcnNpb24gDQpvZiB0aGUgUm90YXhFbmdpbmVzLUxpc3QgRGlnZXN0IGFuZCBj YW4gYmUgdmlld2VkIHdpdGggYSBnZW5lcmljIHRleHQgZWRpdG9yIA0Kc3VjaCBhcyBOb3RlcGFk IG9yIHdpdGggYSB3ZWIgYnJvd3Nlci4gDQoNCkhUTUwgVmVyc2lvbjoNCg0KICAgIGh0dHA6Ly93 d3cubWF0cm9uaWNzLmNvbS9kaWdlc3QvZGlnZXN0dmlldy5waHA/U3R5bGU9ODI3MDEmVmlldz1o dG1sJkNoYXB0ZXI9MjAxNi0wNC0yNSZBcmNoaXZlPVJvdGF4RW5naW5lcw0KDQpUZXh0IFZlcnNp b246DQoNCiAgICBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vZGlnZXN0L2RpZ2VzdHZpZXcucGhw P1N0eWxlPTgyNzAxJlZpZXc9dHh0JkNoYXB0ZXI9MjAxNi0wNC0yNSZBcmNoaXZlPVJvdGF4RW5n aW5lcw0KDQoNCj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQ0KICAgRU1haWwgVmVyc2lvbiBvZiBUb2RheSdzIExpc3QgRGlnZXN0IEFyY2hpdmUNCj09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCiAgICAgICAg ICAgLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLQ0KICAgICAgICAgICAgICAgICAgICAgICAgICAgUm90YXhFbmdpbmVzLUxpc3QgRGlnZXN0 IEFyY2hpdmUNCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLS0tDQogICAg ICAgICAgICAgICAgICAgICBUb3RhbCBNZXNzYWdlcyBQb3N0ZWQgTW9uIDA0LzI1LzE2OiAwDQog ICAgICAgICAgIC0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LS0tLS0tLS0tLS0NCg0KDQpUb2RheSdzIE1lc3NhZ2UgSW5kZXg6DQotLS0tLS0tLS0tLS0tLS0t LS0tLS0tDQoNCg0KDQoNCg0KDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgLSBUaGUgUm90YXhFbmdp bmVzLUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVy ZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2gg YXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwg Ny1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBt b3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9S b3RheEVuZ2luZXMtTGlzdA0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05J Q1MgV0VCIEZPUlVNUyAtDQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZp YSB0aGUgV2ViIEZvcnVtcyENCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNz LmNvbQ0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgICAtIE5FVyBNQVRST05JQ1MgTElTVCBX SUtJIC0NCl8tPSBBZGQgc29tZSBpbmZvIHRvIHRoZSBNYXRyb25pY3MgRW1haWwgTGlzdCBXaWtp IQ0KXy09ICAgLS0+IGh0dHA6Ly93aWtpLm1hdHJvbmljcy5jb20NCl8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAg ICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQpfLT0gIFRoYW5rIHlvdSBmb3Ig eW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg LU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNz LmNvbS9jb250cmlidXRpb24NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09 ________________________________________________________________________________
Subject: High oil temp on 912UL
Date: May 13, 2016
Aircraft: Europa Classic Tri Gear Engine : Rotax 912 UL (80HP) TT 440 hours Propeller: Airmaster I am having a major problem with excessive oil temperature. The Europa Classic is not brilliant when it comes to cooling due to the design feature of having the oil cooler mounted behind the left hand coolant radiator and I have carried out all the recommended mods suggested by other Europa owners to improve cooling. These have helped and but now the weather is getting warmer (21 degrees!) I have discovered things have taken a turn for the worse. My last three flights have been a nightmare due to soaring oil temperature. For example, yesterday I started my take off roll with an oil temp of 80C and had to reduce power and level off after less than two minutes (1300 ft) with the oil temp approaching 130C and CHT of 120C. Cruising at that level quickly drops the CHT to 110C but the oil takes an age to fall below 120C. If I can get the aircraft into the cruise above 2500ft the temps stabilise at just below 110C Oil and 100C CHT, the problem is I just cant get that high at the moment. I have not changed anything on the aircraft so I am assuming it must be an engine problem. The oil level is always correct and I use Aeroshell Sport Plus 4 and Rotax filters. The oil has done less than 20 hours and I use MOGAS with no ethanol. Oil pressure is OK and is about 2.8 3 Bar at a normal cruise. Does anyone have any ideas what could possibly be causing this problem? I really hope so as I am not going anywhere as things stand! Gordon Grant Europa Classic G-BWFH -------- Gordon Grant G-BWFH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=456185#456185 ________________________________________________________________________________
Subject: Re: High oil temp on 912UL
Date: May 13, 2016
http://www.batinc.net/laminova.htm These work on the short tail Rans S7. Jim -----Original Message----- From: GBWFH2010 Sent: Friday, May 13, 2016 9:39 AM Subject: RotaxEngines-List: High oil temp on 912UL Aircraft: Europa Classic Tri Gear Engine : Rotax 912 UL (80HP) TT 440 hours Propeller: Airmaster I am having a major problem with excessive oil temperature. The Europa Classic is not brilliant when it comes to cooling due to the design feature of having the oil cooler mounted behind the left hand coolant radiator and I have carried out all the recommended mods suggested by other Europa owners to improve cooling. These have helped and but now the weather is getting warmer (21 degrees!) I have discovered things have taken a turn for the worse. My last three flights have been a nightmare due to soaring oil temperature. For example, yesterday I started my take off roll with an oil temp of 80C and had to reduce power and level off after less than two minutes (1300 ft) with the oil temp approaching 130C and CHT of 120C. Cruising at that level quickly drops the CHT to 110C but the oil takes an age to fall below 120C. If I can get the aircraft into the cruise above 2500ft the temps stabilise at just below 110C Oil and 100C CHT, the problem is I just cant get that high at the moment. I have not changed anything on the aircraft so I am assuming it must be an engine problem. The oil level is always correct and I use Aeroshell Sport Plus 4 and Rotax filters. The oil has done less than 20 hours and I use MOGAS with no ethanol. Oil pressure is OK and is about 2.8 3 Bar at a normal cruise. Does anyone have any ideas what could possibly be causing this problem? I really hope so as I am not going anywhere as things stand! Gordon Grant Europa Classic G-BWFH -------- Gordon Grant G-BWFH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=456185#456185 ________________________________________________________________________________
Date: May 13, 2016
Gordon, I bought a larger oil cooler from Rotax when I decided to go for the 912S, which runs much hotter than the 912. Then I modified the lower cowling with the new location for the oil cooler under the propellor. It slides in from the inside when the cowling is attached and is thus isolated from engine vibration. This was all done during the build and we don't have the the problems with certification. Peter Timm British Columbia, Canada On 2016-05-13, at 8:32 AM, Jim Roberts wrote: > > http://www.batinc.net/laminova.htm These work on the short tail Rans S7. > Jim > > -----Original Message----- From: GBWFH2010 > Sent: Friday, May 13, 2016 9:39 AM > To: rotaxengines-list(at)matronics.com > Subject: RotaxEngines-List: High oil temp on 912UL > > > Aircraft: Europa Classic Tri Gear > Engine : Rotax 912 UL (80HP) TT 440 hours > Propeller: Airmaster > > I am having a major problem with excessive oil temperature. The Europa Classic is not brilliant when it comes to cooling due to the design feature of having the oil cooler mounted behind the left hand coolant radiator and I have carried out all the recommended mods suggested by other Europa owners to improve cooling. These have helped and but now the weather is getting warmer (21 degrees!) I have discovered things have taken a turn for the worse. > > My last three flights have been a nightmare due to soaring oil temperature. For example, yesterday I started my take off roll with an oil temp of 80C and had to reduce power and level off after less than two minutes (1300 ft) with the oil temp approaching 130C and CHT of 120C. Cruising at that level quickly drops the CHT to 110C but the oil takes an age to fall below 120C. If I can get the aircraft into the cruise above 2500ft the temps stabilise at just below 110C Oil and 100C CHT, the problem is I just cant get that high at the moment. > > I have not changed anything on the aircraft so I am assuming it must be an engine problem. The oil level is always correct and I use Aeroshell Sport Plus 4 and Rotax filters. The oil has done less than 20 hours and I use MOGAS with no ethanol. Oil pressure is OK and is about 2.8 3 Bar at a normal cruise. > > Does anyone have any ideas what could possibly be causing this problem? I really hope so as I am not going anywhere as things stand! > > Gordon Grant > Europa Classic G-BWFH > > -------- > Gordon Grant > > G-BWFH > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=456185#456185 > > > > > > > > > > > > > > ________________________________________________________________________________
Date: May 14, 2016
Gordon I have a Kitfox and my problem is that the oil temp is too cool. When I first bought the aircraft the prior owner had a large soft aluminum sheet with fins (about 3/8 inch fins) wrapped around the oil tank acting as a heat sink. It was attached by two large hose clamps. I removed it as it was drawing too much heat out of the oil. I have seen these things used around oil filters in cars to cool the oil. I don't have a clue is to what they are called or where to get them but it might be worth a shot to try it. It looks to be rather inexpensive and was pretty effective on my airplane. In my case the large oil cooler is more than enough You might try a goggle search and see what you come up with or maybe another member would know what they are called. Might be a cheap fix to reduce some heat. Good luck, Dick ________________________________________________________________________________
Date: May 15, 2016
HI Gordon, What coolant are you running? If it's Evans get rid of it and use 50/50. Evans carries a 20F-30F heat penalty do to poor heat absorption and dissipation. Next check the oil hoses when hot to make sure none have a narrowed radius in them. Some people have too tight a bend and that narrows the hose I.D and slows the oil flow. You should have a 13mm opening all the way through the oil hose lines. Heat exchangers usually don't work here unless they are open air engines. Tight cowled engines don't fair well. Depending on the number of hours on the engine you may need the oil cooler flushed from accumulated debris. If the oil temp wasn't an issue before then something is now restricting its flow. Usually these problems are not an exotic fix. They are something simple that most people overlook. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=456256#456256 ________________________________________________________________________________
Date: May 15, 2016
Roger, Thank you for the advice and I will check all these out. Regards Gordon -------- Gordon Grant G-BWFH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=456260#456260 ________________________________________________________________________________
Subject: Question on 912 O-rings
Date: May 16, 2016
There seem to be differing reports on whether you need the cylinder-to-case o-ring on standard 912UL and ULS. Comments? Are there recommended alternate sources? Confirmation that they are ordinary buna-n or Viton? Thanks! David Josephson Santa Cruz ________________________________________________________________________________
Subject: Re: Question on 912 O-rings
Date: May 16, 2016
There is an "O" ring at the base of the cylinders. See Parts manual section 72-20-00 pg. 16. Item #14 and part #250510. It is a Viton 87mmx2mm "O" ring. I buy my "O" rings from Maryland Metrics -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=456278#456278 ________________________________________________________________________________
Date: May 16, 2016
Get the size from the IPC then look for it at McMaster Carr. They have an extensive supply of differing materials and a good chart to help make a selection. Rick Girard On Mon, May 16, 2016 at 2:37 AM, D L Josephson wrote: > dlj04(at)josephson.com> > > There seem to be differing reports on whether you need the > cylinder-to-case o-ring on standard 912UL and ULS. Comments? Are there > recommended alternate sources? Confirmation that they are ordinary buna-n > or Viton? Thanks! > > David Josephson > Santa Cruz > > =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx>
December 07, 2014 - May 17, 2016
RotaxEngines-Archive.digest.vol-bh
