RotaxEngines-Archive.digest.vol-bj
September 01, 2017 - November 21, 2018
      > I apologize for the long description.
      > Henry
Subject: Re: RotaxEngines-List Digest: 0 Msgs - 08/30/17
Date: Sep 01, 2017
Please change my e-mail to *rtoth4310(at)gmail.com* Thanks Robert Toth On 8/31/2017 3:04 AM, RotaxEngines-List Digest Server wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RotaxEngines-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RotaxEngines-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 17-08-30&Archive=RotaxEngines > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 17-08-30&Archive=RotaxEngines > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RotaxEngines-List Digest Archive > --- > Total Messages Posted Wed 08/30/17: 0 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > > > > > > > > > ________________________________________________________________________________
Subject: Re: 912 fuel problems
Date: Sep 05, 2017
75 hours over three years means auto fuel sat in the tank unused for some long periods. From what I've heard auto fuel only has about a two week shelf life. I worked on a Kitfox that had sat for long periods with auto fuel in its tanks, and the fuel left deposits in the tanks which, when re-filled, would soften and migrate to the filters, plugging them. It took only minutes for the filters to become plugged enough to kill the engine. The challenge was that you couldn't /see /the deposits, but you could sure feel it when you tried to drive fuel through them. Your two symptoms of requiring choke to run and inability to attain full rpm indicate a fuel flow problem, as you've already guessed and proven. If your tanks have become "varnished", you'll have to clean them thoroughly. On the Kitfox we rigged a fuel pump and circulated fuel through the tanks continuously for two weeks, replacing the cycled fuel daily, until the varnish was eliminated enough for it to run continuously. Guy Buchanan Ramona, CA Kitfox IV-1200 / 912-S / Warp 3cs / 600 hrs Glider pilot, too On 9/1/2017 7:37 AM, Henry Roden wrote: > > 1) Is this a normal throw for this cam? > 2) Why does it need so much choke when it did not do so before all the > fuel problems. > 3) Is there something else I am missing that would cause these symptoms? > Since pulling off the fuel pump off another mechanic remarked that the > engine seemed very stiff to pull over with the prop, it had always > been that way since new and I had attributed it to the engine gearbox > combination. I removed the top plugs and the gearbox and the engine > and the gearbox are each quite smooth but not when the gearbox is > mounted back on the engine. It feels like the plugs are still in and > there is compression pressure causing resistance? > I apologize for the long description. > Henry > ________________________________________________________________________________
Subject: Re: New Rotax 912UL/ULS & 912iS Service Class
Date: Sep 07, 2017
We are about full for the class. If you are thinking about coming you may want to call CPS. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=472596#472596 ________________________________________________________________________________
Date: Sep 11, 2017
Subject: Re: RotaxEngines-List Digest: 1 Msgs - 09/05/17
Thanks for the couple of replies on the fuel tank and fuel pump problem. It was a fuel flow problem as was evidenced by the need for choke and not able to get full RPMs. The fuel had not sat in that tank very long as it was a new tank that I had built. This Rotax engine was one of the ones that came under the SB-912-063 requiring a fuel pump replacement. They must have had a batch that had a short service life. The fuel pressure with only the engine mechanical pump on was about 0.5 psi, it took awhile to find this as with both pumps on the fuel pressure was ~2.5 psi. With a new mechanical pump only fuel pressure is ~4.5 psi and with both pumps on it rises to ~5.4 psi. The engine now starts and runs fine. Thanks again. Henry On Wed, Sep 6, 2017 at 1:03 AM, RotaxEngines-List Digest Server < rotaxengines-list(at)matronics.com> wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RotaxEngines-List Digest can also be found in either of > the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RotaxEngines-List Digest and can be viewed with a generic text > editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style > 82701&View=html&Chapter 17-09-05&Archive=RotaxEngines > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style > 82701&View=txt&Chapter 17-09-05&Archive=RotaxEngines > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RotaxEngines-List Digest Archive > --- > Total Messages Posted Tue 09/05/17: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 10:43 AM - Re: 912 fuel problems (Guy Buchanan) > > > ________________________________ Message 1 > _____________________________________ > > > Subject: Re: RotaxEngines-List: 912 fuel problems > From: Guy Buchanan <gebuchanan(at)cox.net> > > 75 hours over three years means auto fuel sat in the tank unused for > some long periods. From what I've heard auto fuel only has about a two > week shelf life. I worked on a Kitfox that had sat for long periods with > auto fuel in its tanks, and the fuel left deposits in the tanks which, > when re-filled, would soften and migrate to the filters, plugging them. > It took only minutes for the filters to become plugged enough to kill > the engine. The challenge was that you couldn't /see /the deposits, but > you could sure feel it when you tried to drive fuel through them. Your > two symptoms of requiring choke to run and inability to attain full rpm > indicate a fuel flow problem, as you've already guessed and proven. If > your tanks have become "varnished", you'll have to clean them > thoroughly. On the Kitfox we rigged a fuel pump and circulated fuel > through the tanks continuously for two weeks, replacing the cycled fuel > daily, until the varnish was eliminated enough for it to run continuously. > > Guy Buchanan > Ramona, CA > Kitfox IV-1200 / 912-S / Warp 3cs / 600 hrs > Glider pilot, too > > On 9/1/2017 7:37 AM, Henry Roden wrote: > > > > 1) Is this a normal throw for this cam? > > 2) Why does it need so much choke when it did not do so before all the > > fuel problems. > > 3) Is there something else I am missing that would cause these symptoms? > > Since pulling off the fuel pump off another mechanic remarked that the > > engine seemed very stiff to pull over with the prop, it had always > > been that way since new and I had attributed it to the engine gearbox > > combination. I removed the top plugs and the gearbox and the engine > > and the gearbox are each quite smooth but not when the gearbox is > > mounted back on the engine. It feels like the plugs are still in and > > there is compression pressure causing resistance? > > I apologize for the long description. > > Henry > > > > ________________________________________________________________________________
Subject: Re: 912 80hp violent vibration on cold start
Date: Sep 21, 2017
mick are you still in the Tulsa, hows the Kolb? -------- kenw Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473050#473050 ________________________________________________________________________________
Subject: Major Upgrade to Airport Courtesy Cars Site-Please
Read.
Date: Oct 01, 2017
If you are a user of the Airport Courtesy Cars site, I would like to inform you of a major upgrade and improvement. Effective mid December, A.C.C.'s will be fully web based, and will continue to be a secure site. Many of you over the past couple of years have asked for these improvements, the biggest user request being the site does not work on certain devices. By converting A.C.C's to a web based site, the advantage is clear, the site will now work on any device. Also, there is no possibility of bugs or crashes like an app. The information will be the same. During this transition period, it is important for you to bookmark the web address on your device so your service remains uninterrupted. For further information, click on the large red banner on the main page of the site, or here: https://www.airportcourtesycars.com/app-update.html -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473234#473234 ________________________________________________________________________________
Subject: hard Starting Rotax 912ULS
Date: Oct 01, 2017
Rotax normally started on first or second blade over. Since last annual where new plugs were installed starting takes several tries. Battery is on a tender and strong. Fuel pressure normal. OAT mild. After starting ( typically on 3rd try) engine runs just fine. Correct plugs, correct gap, fresh fuel. Suggestions? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473258#473258 ________________________________________________________________________________
Date: Oct 02, 2017
Subject: Re: hard Starting Rotax 912ULS
Correct leads? Dave Park Sent from my iPad > On 2 Oct 2017, at 04:10, JohnF wrote: > > > Rotax normally started on first or second blade over. Since last annual where new plugs were installed starting takes several tries. > > Battery is on a tender and strong. Fuel pressure normal. OAT mild. > After starting ( typically on 3rd try) engine runs just fine. > > Correct plugs, correct gap, fresh fuel. > > Suggestions? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473258#473258 > > > > > > > > > ________________________________________________________________________________
Date: Oct 04, 2017
After a lot of thought about hard starting, I took a hint from another RV-12 pilot and ran the engine on the ground at 4,000 RPM for about 4 minutes, in the hope that oil fouling of the plugs might be involved, and that the high RPM run might help clear things up. This is because I typically have to taxi about 3/4 mile after landing to my hangar which might possibly cause oil fouling. This morning it was fairly chilly so I put on the engine heater (space heater ducted into the engine cowl) for about 40 minutes. Upon starting, the engine fired up on the first blade over, just as in the past. I am going to make it a practice to run the engine at fairly high RPM for a few minutes just prior to shut down when back at the hangar and see if I get consistent results. Thanks for you input. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473330#473330 ________________________________________________________________________________
Date: Oct 04, 2017
Be sure that your spark plugs are appropriately gapped (.023 in winter and .027 in summer -- I use 0.025 year-round here in moderate Northern California). Be sure that your throttle is fully closed for the first cold start of the day and the "choke" is at least partially "on". The instant the engine fires, ease in a bit of throttle and then gradually remove the choke. Alternatively, apply "full choke and fully closed throttle" and crank the engine over for a few revs with the ignition "off" and then stop. Then turn the choke off, crack the throttle, turn the ignition "on", and start the engine. In over 550 hours of my RV-12's operation the aforementioned standard ROTAX operating procedure has worked well. We have extensive taxiing and ground idle operations here at our controlled airport and I do not think that this negatively influences subsequent starting of the engine. IMHO, the "4,000 rpm for 4 minutes" is likely a waste of your time and results in unnecessary wear on your engine. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473333#473333 ________________________________________________________________________________
Date: Oct 04, 2017
Thanks, DHeal..... I will try your starting technique and see how that works. I like it better than the high speed run I tried. I always gap plugs to .025 year in and out as you do. New plugs every annual because they are so inexpensive. 325 hours on the plane and this odd starting thing just came up...again, thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473334#473334 ________________________________________________________________________________
Date: Oct 08, 2017
I had a similar-sounding problem with my Rotax 912ULS. It turned out to be the sprag clutch. When the problem began, the engine started better when warm but would not start when cold. When I finally changed it out, I found metal in it. ________________________________________________________________________________
Subject: Re: 914 Carb Drip Trays
Date: Oct 08, 2017
Hi Jim. Yes I agree the later design made it a lot easier. After reading your article I got my drip bowls modified to make things easier in the future. Many thanks FRANK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473427#473427 ________________________________________________________________________________
Date: Oct 09, 2017
On 01:08 PM 10/7/2017, John Elling wrote: >I had a similar-sounding problem with my Rotax 912ULS. It turned out to be the sprag clutch. When the problem began, the engine started better when warm but would not start when cold. When I finally changed it out, I found metal in it. What was the problem? Was the engine not turning over fast enough? ________________________________________________________________________________
Subject: Re: RotaxEngines-List Digest: 1 Msgs - 10/09/17
Date: Oct 10, 2017
Right. A few weak revolutions at best. Often no revolutions at all. On 10/10/2017 8:03 PM, RotaxEngines-List Digest Server wrote: >> I had a similar-sounding problem with my Rotax 912ULS. It turned out to be the > sprag clutch. When the problem began, the engine started better when warm but > would not start when cold. When I finally changed it out, I found metal in > it. > > What was the problem? Was the engine not turning over fast enough? > ________________________________________________________________________________
Date: Oct 10, 2017
> What was the problem? Was the engine not turning over fast enough? Yes probably. Got the same on same type of engine and before changing the only way to start it when cold was to put a second battery to boost at 24V and make it turning faster... ________________________________________________________________________________
Subject: Re: Can the 912ULS be hand started?
Date: Oct 10, 2017
Disregard hand propping as a move down If you have a RANS Pusher, I would figure you would be in profound yogurt! Mothers Back to Black Review (http://automobiledecor.com/mothers-back-to-black-review/) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473440#473440 ________________________________________________________________________________
Date: Oct 10, 2017
I flew this morning...25-degrees F, and used the hint given me above, and the engine fired on the first blade over. Perfect. thanks a lot...will continue using this procedure. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473441#473441 ________________________________________________________________________________
Date: Oct 11, 2017
From: "ami-mcfadyean(at)talktalk.net" <ami-mcfadyean(at)talktalk.net>
John,Would you confirm please which of the various offered procedures ("above") you found successful? Rgds.,Duncan. ----Original Message---- From: n29cx(at)ridgeviewtel.us Date: 10/10/2017 17:52 Subj: RotaxEngines-List: Re: hard Starting Rotax 912ULS I flew this morning...25-degrees F, and used the hint given me above, and the engine fired on the first blade over. Perfect. thanks a lot...will continue using this procedure. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473441#473441 ________________________________________________________________________________
Date: Oct 11, 2017
The hint that seemed to work well was in the first paragraph of DHeal's post. John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473477#473477 ________________________________________________________________________________
Subject: 912 UL Intake Manifold Pressures
Date: Oct 20, 2017
Hi All, I've been tracking a vibration for a while, and it has been very difficult. Carburettors have been sync'd more than I've had hot dinners, plus other areas of the engine. So far I've eliminated the propeller, gearbox I noticed a strange effect today, and I'm unsure about it. Today, as a result of a vibration plot taken last weekend, decided to carefully check the carburettor sync again. The vibration plot is showing the vibration at half-crank and twice-crank frequency. I connected two vacuum gauges, so that I am reading absolute vacuum (i.e. 0" is ambient and 10", for example, is 10" of vacuum). >From about 10" up to 0", which corresponds to rpms of about 3400 up to 5400, the carburettors are in sync. Below that they aren't. At idle of about 1750/1800 rpm i get 12.5-13" in the port carb, and 15.5" in the starboard carb. I found Roger Lee's very good guide and thought that I could take out this idle difference with the idle mixture screw. But it didn't really change anything, no matter where set on the port carb. On the starboard carb it did have an effect. The other strange symptom that I found is that if I take the engine to a fair speed, say 4000 rpm and then quickly idle the throttle, then both carbs come down to 15" in sync before the port carb raises to 12.5/13". Compressions were checked 12 months ago, all ok. Carburettors we overhauled 12 months ago, all ok. Carb mounts renewed 12 months ago. Any one seen this effect before? I'm thinking of taking off the manifold and checking the O-rings between the engine and manifold for leaks. And also stripping back the carbs, cleaning and rebuilding them. Anything else I should be thinking? Best Jon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473713#473713 ________________________________________________________________________________
Date: Oct 20, 2017
From: william sullivan <williamtsullivan(at)att.net>
Subject: Re: 912 UL Intake Manifold Pressures
Check the Viton seals in the enrichers. One could be deteriorating. Cheap and easy fix, if that's it. -------------------------------------------- On Fri, 10/20/17, italianjon wrote: Subject: RotaxEngines-List: 912 UL Intake Manifold Pressures To: rotaxengines-list(at)matronics.com Date: Friday, October 20, 2017, 3:28 PM "italianjon" Hi All, I've been tracking a vibration for a while, and it has been very difficult. Carburettors have been sync'd more than I've had hot dinners, plus other areas of the engine. So far I've eliminated the propeller, gearbox I noticed a strange effect today, and I'm unsure about it. Today, as a result of a vibration plot taken last weekend, decided to carefully check the carburettor sync again. The vibration plot is showing the vibration at half-crank and twice-crank frequency. I connected two vacuum gauges, so that I am reading absolute vacuum (i.e. 0" is ambient and 10", for example, is 10" of vacuum). >From about 10" up to 0", which corresponds to rpms of about 3400 up to 5400, the carburettors are in sync. Below that they aren't. At idle of about 1750/1800 rpm i get 12.5-13" in the port carb, and 15.5" in the starboard carb. I found Roger Lee's very good guide and thought that I could take out this idle difference with the idle mixture screw. But it didn't really change anything, no matter where set on the port carb. On the starboard carb it did have an effect. The other strange symptom that I found is that if I take the engine to a fair speed, say 4000 rpm and then quickly idle the throttle, then both carbs come down to 15" in sync before the port carb raises to 12.5/13". Compressions were checked 12 months ago, all ok. Carburettors we overhauled 12 months ago, all ok. Carb mounts renewed 12 months ago. Any one seen this effect before? I'm thinking of taking off the manifold and checking the O-rings between the engine and manifold for leaks. And also stripping back the carbs, cleaning and rebuilding them. Anything else I should be thinking? Best Jon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473713#473713 The RotaxEngines-List Email Forum - Navigator to browse List Un/Subscription, 7-Day Browse, Chat, FAQ, - MATRONICS WEB FORUMS - via the Web Forums! - NEW MATRONICS LIST WIKI - Email List Wiki! - List Contribution Web Site - support! -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: 912 Running rough all of a sudden
From: Pete Christensen <pchristensen10(at)austin.rr.com>
Date: Oct 20, 2017
Engine has been running great. Flew last weekend and then Wednesday was going to fly. Started up and it was sounding rough at idle. I warmed up a minute and advanced the throttle and it continued rough until it got to 3000 rpm. Let it warm up some more then ran it at 3000 rpm for a couple minutes hoping to clear up the problem. No joy. I ran it at high idle and turned off the fuel valve. After a while it smoothed out just before it was starved for fuel. Opened the fuel valve before it died and it ran smoothly for a few seconds before it began to run rough again. Sounds like a carb problem where maybe one carb is getting too much fuel. Mag check at 3k is normal. I dropped the float bowels and the floats looked to be floating normally. Fuel looked clean. I had run on this tank for a couple hours Saturday. Gascolator had clean fuel. Suggestions? Why would a good,running engine start running rough after just a few days? > On Oct 20, 2017, at 4:06 PM, william sullivan wrote: > > > Check the Viton seals in the enrichers. One could be deteriorating. Cheap and easy fix, if that's it. > > > -------------------------------------------- > On Fri, 10/20/17, italianjon wrote: > > Subject: RotaxEngines-List: 912 UL Intake Manifold Pressures > To: rotaxengines-list(at)matronics.com > Date: Friday, October 20, 2017, 3:28 PM > > "italianjon" > > Hi All, > > I've been tracking a vibration for a > while, and it has been very difficult. Carburettors have > been sync'd more than I've had hot dinners, plus other areas > of the engine. So far I've eliminated the propeller, > gearbox > > I noticed a strange effect today, and > I'm unsure about it. Today, as a result of a vibration plot > taken last weekend, decided to carefully check the > carburettor sync again. The vibration plot is showing the > vibration at half-crank and twice-crank frequency. > > I connected two vacuum gauges, so that > I am reading absolute vacuum (i.e. 0" is ambient and 10", > for example, is 10" of vacuum). > >> From about 10" up to 0", which > corresponds to rpms of about 3400 up to 5400, the > carburettors are in sync. Below that they aren't. > > At idle of about 1750/1800 rpm i get > 12.5-13" in the port carb, and 15.5" in the starboard carb. > > I found Roger Lee's very good guide and > thought that I could take out this idle difference with the > idle mixture screw. But it didn't really change anything, no > matter where set on the port carb. On the starboard carb it > did have an effect. > > The other strange symptom that I found > is that if I take the engine to a fair speed, say 4000 rpm > and then quickly idle the throttle, then both carbs come > down to 15" in sync before the port carb raises to > 12.5/13". > > Compressions were checked 12 months > ago, all ok. Carburettors we overhauled 12 months ago, all > ok. Carb mounts renewed 12 months ago. > > Any one seen this effect before? > > I'm thinking of taking off the manifold > and checking the O-rings between the engine and manifold for > leaks. And also stripping back the carbs, cleaning and > rebuilding them. > > Anything else I should be thinking? > > Best > > Jon > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473713#473713 > > > > > > > The RotaxEngines-List Email Forum - > Navigator to browse > List Un/Subscription, > 7-Day Browse, Chat, FAQ, > - MATRONICS WEB FORUMS - > via the Web Forums! > - NEW MATRONICS LIST WIKI - > Email List Wiki! > - List Contribution Web Site - > support! > > -Matt Dralle, List Admin. > > > > > > > > ________________________________________________________________________________
Date: Oct 21, 2017
Subject: Re: 912 Running rough all of a sudden
Like I said, check the enricher seals. The one on my 447 had dissolved, making it run very rich. I have very little experience with this, but your symptoms gave me a good reminder. It will only take 5 minutes or so to pull each one out and check. -------------------------------------------- On Fri, 10/20/17, Pete Christensen wrote: Subject: RotaxEngines-List: 912 Running rough all of a sudden To: rotaxengines-list(at)matronics.com Date: Friday, October 20, 2017, 5:58 PM Pete Christensen Engine has been running great. Flew last weekend and then Wednesday was going to fly. Started up and it was sounding rough at idle. I warmed up a minute and advanced the throttle and it continued rough until it got to 3000 rpm. Let it warm up some more then ran it at 3000 rpm for a couple minutes hoping to clear up the problem. No joy. I ran it at high idle and turned off the fuel valve. After a while it smoothed out just before it was starved for fuel. Opened the fuel valve before it died and it ran smoothly for a few seconds before it began to run rough again. Sounds like a carb problem where maybe one carb is getting too much fuel. Mag check at 3k is normal. I dropped the float bowels and the floats looked to be floating normally. Fuel looked clean. I had run on this tank for a couple hours Saturday. Gascolator had clean fuel. Suggestions? Why would a good,running engine start running rough after just a few days? ________________________________________________________________________________
Date: Oct 20, 2017
Make sure the idle jets and main jets are completely clean and clear when you have the float bowls off. Also, make sure the float bowl gaskets are sealing 100%. Best replace both float bowl gaskets to be sure. All the above can give you major headaches, although they are simple to check and simple to cure. john h Kolb MKIII - 3,400.0+ hours 912ULS - About 850.0 hours on this one. -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Pete Christensen Sent: Friday, October 20, 2017 4:59 PM Subject: RotaxEngines-List: 912 Running rough all of a sudden --> Engine has been running great. Flew last weekend and then Wednesday was going to fly. Started up and it was sounding rough at idle. I warmed up a minute and advanced the throttle and it continued rough until it got to 3000 rpm. Let it warm up some more then ran it at 3000 rpm for a couple minutes hoping to clear up the problem. No joy. I ran it at high idle and turned off the fuel valve. After a while it smoothed out just before it was starved for fuel. Opened the fuel valve before it died and it ran smoothly for a few seconds before it began to run rough again. Sounds like a carb problem where maybe one carb is getting too much fuel. Mag check at 3k is normal. I dropped the float bowels and the floats looked to be floating normally. Fuel looked clean. I had run on this tank for a couple hours Saturday. Gascolator had clean fuel. Suggestions? Why would a good,running engine start running rough after just a few days? --- This email has been checked for viruses by AVG. http://www.avg.com ________________________________________________________________________________
Date: Oct 20, 2017
Sticky carb pistons? Remove air filters, reach inside carb throats, see if carb pistons move up and down smoothly without sticking. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473724#473724 ________________________________________________________________________________
From: Kevin Klinefelter <klinefelter.kevin(at)gmail.com>
Date: Oct 20, 2017
To check the intake manifolds for leaks you can spray ether around them with the engine running. If the RPM goes up you have a leak. Kevin > On Oct 20, 2017, at 2:06 PM, william sullivan wrote: > > > Check the Viton seals in the enrichers. One could be deteriorating. Cheap and easy fix, if that's it. > > > -------------------------------------------- > On Fri, 10/20/17, italianjon wrote: > > Subject: RotaxEngines-List: 912 UL Intake Manifold Pressures > To: rotaxengines-list(at)matronics.com > Date: Friday, October 20, 2017, 3:28 PM > > "italianjon" > > Hi All, > > I've been tracking a vibration for a > while, and it has been very difficult. Carburettors have > been sync'd more than I've had hot dinners, plus other areas > of the engine. So far I've eliminated the propeller, > gearbox > > I noticed a strange effect today, and > I'm unsure about it. Today, as a result of a vibration plot > taken last weekend, decided to carefully check the > carburettor sync again. The vibration plot is showing the > vibration at half-crank and twice-crank frequency. > > I connected two vacuum gauges, so that > I am reading absolute vacuum (i.e. 0" is ambient and 10", > for example, is 10" of vacuum). > >> From about 10" up to 0", which > corresponds to rpms of about 3400 up to 5400, the > carburettors are in sync. Below that they aren't. > > At idle of about 1750/1800 rpm i get > 12.5-13" in the port carb, and 15.5" in the starboard carb. > > I found Roger Lee's very good guide and > thought that I could take out this idle difference with the > idle mixture screw. But it didn't really change anything, no > matter where set on the port carb. On the starboard carb it > did have an effect. > > The other strange symptom that I found > is that if I take the engine to a fair speed, say 4000 rpm > and then quickly idle the throttle, then both carbs come > down to 15" in sync before the port carb raises to > 12.5/13". > > Compressions were checked 12 months > ago, all ok. Carburettors we overhauled 12 months ago, all > ok. Carb mounts renewed 12 months ago. > > Any one seen this effect before? > > I'm thinking of taking off the manifold > and checking the O-rings between the engine and manifold for > leaks. And also stripping back the carbs, cleaning and > rebuilding them. > > Anything else I should be thinking? > > Best > > Jon > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473713#473713 > > > > > > > The RotaxEngines-List Email Forum - > Navigator to browse > List Un/Subscription, > 7-Day Browse, Chat, FAQ, > - MATRONICS WEB FORUMS - > via the Web Forums! > - NEW MATRONICS LIST WIKI - > Email List Wiki! > - List Contribution Web Site - > support! > > -Matt Dralle, List Admin. > > > > > > > > ________________________________________________________________________________
Date: Oct 21, 2017
Jon, I believe I had a rather similar thing quite a few years ago when my throttle cables were run in a not symmetrical pattern with one following tighter bends. Regards, David Joyce, GXSDJ On 2017-10-20 20:28, italianjon wrote: > > Hi All, > > I've been tracking a vibration for a while, and it has been very difficult. Carburettors have been sync'd more than I've had hot dinners, plus other areas of the engine. So far I've eliminated the propeller, gearbox > > I noticed a strange effect today, and I'm unsure about it. Today, as a result of a vibration plot taken last weekend, decided to carefully check the carburettor sync again. The vibration plot is showing the vibration at half-crank and twice-crank frequency. > > I connected two vacuum gauges, so that I am reading absolute vacuum (i.e. 0" is ambient and 10", for example, is 10" of vacuum). > >> From about 10" up to 0", which corresponds to rpms of about 3400 up to 5400, the carburettors are in sync. Below that they aren't. > > At idle of about 1750/1800 rpm i get 12.5-13" in the port carb, and 15.5" in the starboard carb. > > I found Roger Lee's very good guide and thought that I could take out this idle difference with the idle mixture screw. But it didn't really change anything, no matter where set on the port carb. On the starboard carb it did have an effect. > > The other strange symptom that I found is that if I take the engine to a fair speed, say 4000 rpm and then quickly idle the throttle, then both carbs come down to 15" in sync before the port carb raises to 12.5/13". > > Compressions were checked 12 months ago, all ok. Carburettors we overhauled 12 months ago, all ok. Carb mounts renewed 12 months ago. > > Any one seen this effect before? > > I'm thinking of taking off the manifold and checking the O-rings between the engine and manifold for leaks. And also stripping back the carbs, cleaning and rebuilding them. > > Anything else I should be thinking? > > Best > > Jon > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473713#473713 [1] > Links: ------ [1] http://forums.matronics.com/viewtopic.php?p=473713#473713 [2] http://www.matronics.com/Navigator?RotaxEngines-List [3] http://forums.matronics.com [4] http://wiki.matronics.com [5] http://www.matronics.com/contribution ________________________________________________________________________________
Date: Oct 21, 2017
Sticking throttle cables? Brian Davies -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Kevin Klinefelter Sent: 21 October 2017 05:21 Subject: Re: RotaxEngines-List: 912 UL Intake Manifold Pressures --> To check the intake manifolds for leaks you can spray ether around them with the engine running. If the RPM goes up you have a leak. Kevin > On Oct 20, 2017, at 2:06 PM, william sullivan wrote: > > --> > > Check the Viton seals in the enrichers. One could be deteriorating. Cheap and easy fix, if that's it. > > > -------------------------------------------- > On Fri, 10/20/17, italianjon wrote: > > Subject: RotaxEngines-List: 912 UL Intake Manifold Pressures > To: rotaxengines-list(at)matronics.com > Date: Friday, October 20, 2017, 3:28 PM > > "italianjon" > > Hi All, > > I've been tracking a vibration for a > while, and it has been very difficult. Carburettors have been sync'd > more than I've had hot dinners, plus other areas of the engine. So far > I've eliminated the propeller, gearbox > > I noticed a strange effect today, and > I'm unsure about it. Today, as a result of a vibration plot taken last > weekend, decided to carefully check the carburettor sync again. The > vibration plot is showing the vibration at half-crank and twice-crank > frequency. > > I connected two vacuum gauges, so that I am reading absolute vacuum > (i.e. 0" is ambient and 10", for example, is 10" of vacuum). > >> From about 10" up to 0", which > corresponds to rpms of about 3400 up to 5400, the carburettors are in > sync. Below that they aren't. > > At idle of about 1750/1800 rpm i get > 12.5-13" in the port carb, and 15.5" in the starboard carb. > > I found Roger Lee's very good guide and thought that I could take out > this idle difference with the idle mixture screw. But it didn't really > change anything, no matter where set on the port carb. On the > starboard carb it did have an effect. > > The other strange symptom that I found is that if I take the engine to > a fair speed, say 4000 rpm and then quickly idle the throttle, then > both carbs come down to 15" in sync before the port carb raises to > 12.5/13". > > Compressions were checked 12 months > ago, all ok. Carburettors we overhauled 12 months ago, all ok. Carb > mounts renewed 12 months ago. > > Any one seen this effect before? > > I'm thinking of taking off the manifold and checking the O-rings > between the engine and manifold for leaks. And also stripping back the > carbs, cleaning and rebuilding them. > > Anything else I should be thinking? > > Best > > Jon > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=473713#473713 > > > > > > > The RotaxEngines-List Email Forum - > Navigator to browse > List Un/Subscription, > 7-Day Browse, Chat, FAQ, > - MATRONICS WEB FORUMS - > via the Web Forums! > - NEW MATRONICS LIST WIKI - > Email List Wiki! > - List Contribution Web Site - > support! > > -Matt Dralle, List Admin. > > > > > > > > --- This email has been checked for viruses by AVG. http://www.avg.com ________________________________________________________________________________
Date: Oct 22, 2017
Hi Jon, Give me a call and let's see if we can work this out and eliminate a few things. I need to ask some questions. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=473752#473752 ________________________________________________________________________________
Date: Oct 25, 2017
Subject: Carburetor syncing Rotax 912
Sent from my iPhone ________________________________________________________________________________
Date: Nov 01, 2017
Subject: PLEASE READ - Matronics Email List 2017 Fund Raiser
During November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are 9 great gifts to choose from! There's something for everyone, to be sure. Please make your List Contribution using any one of three secure methods including using a Credit Card, PayPal, or by Personal Check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 03, 2017
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Propeller turned backwards
Date: Nov 05, 2017
What if someone's been turning my propeller/Rotax 912ULS backwards through several revolutions? I know in that case oil will be "sucked" out of the hydraulic tappets and damage would/could be caused to the valve train. Would I hear clattering on engine start and would the noise continue? Or after initial clattering, would the tappets fill within a few minutes and the clattering disappear? The trouble is that someone else did the first start and he didn't report unusual noises. The engine has subsequently run for two hours including four flights. Should I now undertake investigations for damage and if so, what should I be doing to put this worry behind me? Rocker covers off and look at valve spring caps? Check magnetic plug? Prime the oil system again to purge air out of the tappets? Your advice would be very welcome, thanks. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474341#474341 ________________________________________________________________________________
Date: Nov 05, 2017
Subject: Coming Soon - The List of Contributors - Please Make
A Contribution Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: Propeller/engine rotated backwards
Date: Nov 05, 2017
If you keep doing that not only will oil be displaced, but you'll ruin the sprag clutch on the starter and that usually means pulling the engine. Removing the back end of the engine and replacing th4 sprag clutch. That will be expensive. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474461#474461 ________________________________________________________________________________
Date: Nov 06, 2017
As I said "someone's" possibly been doing it and it wasn't me. Regarding sprag clutches, if my propeller gets turned even slightly the wrong way then it can clearly be heard and felt that the starter motor is being driven backwards through the sprag clutch. There is an extra resistance to turning the propeller and a whirring sound. Having already had the sprag clutch replaced when changing from the old style starter to the longer-bodied starter motor, I've seen and understand what's involved in that job. I removed and replaced the engine myself and don't wish to repeat that anytime soon! So going back to my main concern, I'm keen to know if running the engine will get rid of air in the tappets, in which case that's already happened, or is bleeding the oil system the ONLY way to achieve this? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474462#474462 ________________________________________________________________________________
Date: Nov 06, 2017
/Le 06/11/2017 11:34, jonathanmilbank a crit : / > /So going back to my main concern, I'm keen to know if running the > engine will get rid of air in the tappets, in which case that's > already happened, or is bleeding the oil system the ONLY way to > achieve this?/ Jonathan, Let's say it is the only way to achieve peace of mind ;-) SI-912-018 is really no big deal, if it were my airplane I'd perform it and clearly label my prop with a "never rotate backwards" sign. And why not craft a prop cover with something preventing rotation of the prop -unless some harm to the engine is deliberately meant ? FWIW -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Nov 06, 2017
Gilles, you've hit the nail on the head with "unless some harm to the engine is deliberately meant ?", but when a friend went flying in my aircraft after it had not flown for 4 weeks, he later told me that it started perfectly first time with no unusual noises. I only spoke to him after I started this topic, when I had also flown the aircraft and thought the engine was less smooth. I have done SI-912-018 a couple of times previously, so I'll probably take your advice and do it again. However it would be useful to know from someone who has experienced it before, whether the engine makes noises caused by hydraulic tappets with air trapped inside. I imagine it would sound a bit like an old diesel engine, only quieter. Perhaps I'm just being too suspicious of someone who is known to have done underhand things before, but not as serious as this! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474469#474469 ________________________________________________________________________________
Date: Nov 06, 2017
If you can actually hear the tappets because you have that much air in the system you are going to damage and bend things. These are hydraulic lifters and need oil to function properly. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=474470#474470 ________________________________________________________________________________
Date: Nov 07, 2017
Date: Nov 09, 2017
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 11, 2017
Subject: Make Sure You're Listed! List of Contributors Published
in December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 13, 2017
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that ilk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 15, 2017
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 17, 2017
Subject: What's Your Contribution Used For?
Dear Listers, You might have wondered at some point, "What's my Contribution used for?" Here are just a few examples of what your direct List support enables... It provides for the expensive, commercial-grade Internet connection used on the List. It pays for the regular system hardware and software upgrades enabling the highest performance possible for List services such as the Archive Search Engine, List Browser, and the Web Forums. It pays for the over 23 years of on-line archive data always available for instant search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power these List Service such as the List Browse, Search Engine, Forums, and Wiki. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. It is YOUR CONTRIBUTION that directly enables all these aspects of Matronics List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport! List Contribution Web Site: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Date: Nov 19, 2017
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 21, 2017
Date: Nov 24, 2017
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 26, 2017
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 28, 2017
Date: Nov 29, 2017
Date: Nov 30, 2017
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again - 54! :-) But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 17, 2017
Subject: 2017 List of Contributors
Dear Listers, The 2017 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors (LOC). It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 And finally, I'm proud to present The 2017 Fund Raiser List of Contributors: http://www.matronics.com/loc Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Subject: New Rotax oil filter wrench
Date: Jan 10, 2018
Hi All, Wrench's took longer than expected due to holidays, but they are ready to go. They are in and ready to ship. The cost is $24 plus $5 for shipping in the US. The total is $29. You can pay on PayPal and make the payment to roger(at)lsamechanic.com or you can send a personal check to: Roger Lee 9531 E. Lochnay Lane Tucson, AZ 85747 Then send me your address here to where you want it shipped. It will come US Mail. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477214#477214 Attachments: http://forums.matronics.com//files/the_solution_2_137.jpg ________________________________________________________________________________
Subject: New Rotax Service class
Date: Jan 10, 2018
Note*** When you call California Power Systems to sign up make sure you tell them it is for the Tucson, AZ class in Feb. so it isn't confused with some other class.. New Rotax 912UL/ULS & 912iS Service Class Conducted by Rotax Instructor Roger Lee in Tucson, AZ In conjunction with California Power Systems Come join us for a new and exciting Service class. Lots of hands on so don't miss it! http://www.cps-parts.com/catalog/rtxpages/912service-inspclass.php April 14th & 15th (Saturday & Sunday) This class is a must for an Owner, LSRM or an A&P mechanic to develop their 912 series inspection skills and knowledge. This class will focus on a hands on approach to completing a 100 hour / annual condition inspection. The class will differ from other Service rated classes as it will spend less classroom time and a lot of hands on time with a live engine performing a 100 hour / Annual Condition Inspection. You will be able to ask on the spot questions and solve problems on the live engine while developing and expanding your 912 inspection skills and knowledge base. We will have classroom in the morning Saturday and Sunday (Feb. 4 & 5th) and spend both afternoons doing an annual inspection on an in-service and operational 912 engine. The afternoons will be spent in the hangar and everyone will be turning wrenches and performing task. You WILL understand a carb sync at the end of this class. JWe will have the Maintenance manual out and will follow the inspection procedures. At the end of this class you should be well grounded in the performance of a 100 hour / annual condition inspection. You will receive a Rotax Service certificate for successful completion of this class. Our classroom is air conditioned and comfortable. The hangar is air conditioned temperature controlled with a bathroom. Minimum limit is 4 students with a cap of 12. The class size is limited to make sure everyone gets to participate so dont procrastinate and sign up now. Class times will be 8 a.m. to 5 p.m. Fly into Tucson International Airport (TIA) or fly your own plane into Ryan Airfield. Classes are Saturday and Sunday. All rental cars are on site at Tucson International Airport or Enterprise will pick you up if you fly into Ryan Airfield. Several hotels are just hundreds of yards down the street at TIA. Ryan Airport (KRYN) is only 10-12 minute drive. The entire experience is convenient and comfortable. For additional information or to sign up call Brain Toepfer at CPS in CA at 951-549-7786 ext. 302 or email bryantoepfer@cps-parts.com. For additional class details call Roger Lee in Tucson, AZ at 520-574-1080. CLASS OVERVIEW: This is a two day 16 hour class that qualifies graduates to maintain 912 series engines under ASTM standards as set forth by the Light Sport Aircraft (LSA) regulations. Passing a written exam is required for Rotax certification and graduates will be issued an IRMT (Independent Rotax Maintenance Technician) badge and service number valid for two years. This course will supply attendees with the following information and skills: Rotax History and Product Familiarization Senders and Instrumentation Gearbox : The internal workings and maintenance Propeller considerations, adjustment and its effects on your engine Hose inspection, maintenance and considerations Oil System workings, maintenance and considerations Cooling System workings, maintenance and considerations Fuel System workings, maintenance and considerations Carburetor workings, maintenance and keeping them in sync Ignition Theory Compression and why its important, what it tells us and performance of a real compression test Troubleshooting Scheduled Maintenance Maintenance Documentation MATERIALS: All tools, reading materials, and supplies will be provided, however you should bring a laptop or tablet to view the manuals or do any research. A free WIFI connection is available in the classroom. http://www.cps-parts.com/catalog/rtxpages/912service-inspclass.php -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477216#477216 ________________________________________________________________________________
Subject: Re: New Rotax oil filter wrench
Date: Jan 22, 2018
You guys need to try this wrench. Makes oil filter time a snap. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=477498#477498 ________________________________________________________________________________
Date: Feb 26, 2018
Roger, I purchased a similar expensive wrench a few years ago. It was working very well. Now I have to trash it just because the idiots from Rotax changed the shape of the filter. The question is: when are they going to change the shape of that filter once again? Regards Remi Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478266#478266 ________________________________________________________________________________
Date: Feb 26, 2018
Change is good. Stupidity is not! Why couldn=99t they get it right the first time? After all, there ar e only hundreds of thousands of engines out their couldn=99t they learn? On Monday, February 26, 2018, Remi Guerner wrote: > air.guerner(at)orange.fr> > > Roger, > I purchased a similar expensive wrench a few years ago. It was working > very well. Now I have to trash it just because the idiots from Rotax > changed the shape of the filter. The question is: when are they going to > change the shape of that filter once again? > Regards > Remi > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=478266#478266 > > =========== =========== =========== =========== =========== > > -- Barry "Chop'd Liver" If you wash your hands before you go to the bathroom you may have the makings of a Crew Chief. ________________________________________________________________________________
Date: Feb 26, 2018
/Le 26/02/2018 14:21, FLYaDIVE a crit:// / > / > / > / > / > /Why couldnt they get it right the first time? After all, there are > only hundreds of thousands of engines out their couldnt they learn?/ Hi all, Chances are Rotax is not the manufacturer of their oil filters, they just have their logo painted on off-the-shelf products. This inexpensive autostore model never let me down in years, be it bikes, cars, airplanes, boats. Rsultat de recherche d'images pour "oil filter wrench" FWIW -- Best regards, Gilles http://contrails.free.fr http://lapierre.skunkworks.free.fr ________________________________________________________________________________
Date: Feb 26, 2018
Go to HFT and get their set of oil filter sockets. Less than $20 and you're good to go. Even less with one of their 20 or 25% discount coupons. https://www.harborfreight.com/3-Pc-Oil-Filter-Sockets-DomesticEuropeanAsian -63741.html Rick <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&ut m_campaign=sig-email&utm_content=webmail> Virus-free. www.avg.com <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&ut m_campaign=sig-email&utm_content=webmail> <#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2> On Mon, Feb 26, 2018 at 11:30 AM, GTH wrote: > *Le 26/02/2018 =C3- 14:21, FLYaDIVE a =C3=A9crit :* > > > *Why couldn=99t they get it right the first time? After all, there are only > hundreds of thousands of engines out their couldn=99t they learn?* > > > Hi all, > > Chances are Rotax is not the manufacturer of their oil filters, they just > have their logo painted on off-the-shelf products. > This inexpensive autostore model never let me down in years, be it bikes, > cars, airplanes, boats. > > [image: R=C3=A9sultat de recherche d'images pour "oil filter wrench"] > FWIW > -- > Best regards, > Gilles > http://contrails.free.fr > http://lapierre.skunkworks.free.fr > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Subject: Re: New Rotax Service class
Date: Mar 01, 2018
Just a reminder of this up coming class. We limit the seats to 12 because of all the hands on time so if you are thinking of coming please call CPS and let them know as soon as possible. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478335#478335 ________________________________________________________________________________
Date: Mar 19, 2018
3 weeks left and just a couple seats left. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=478743#478743 ________________________________________________________________________________
Subject: AirNav.com Now Linked to Airport Courtesy Cars
Date: Apr 04, 2018
Airport Courtesy Cars website has been updated to link to AirNav.com. Click on any of the over 1,850 airport IDs within the site and you will be taken to the AirNav.com page for that airport. Please note Airport Courtesy Cars is now fully web based and works on any device. We have also added many locations with MOGAS. Have a great flying season and please consider a small donation to keep this site running and get your name added to the donor page. Thanks, Glenn -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479068#479068 ________________________________________________________________________________
Subject: Re: AirNav.com Now Linked to Airport Courtesy Cars
From: "AmphibFlyer" <SeaRey(at)AbstractConcreteWorks.com>
Date: Apr 05, 2018
Thanks, Glenn. That's a helpful service--especially because some airports that brag about courtesy cars don't have them readily available. For MOGAS, can you identify airports that have hi-test (premium) car gas that is required for most Rotax four-stroke engines? (Nearly all S-LSAs are powered by those engines.) The term MOGAS has historically meant 87 octane regular-grade car gas, which is not suitable for any Rotax engine more powerful than the little 80 hp 912. So when I travel with my Rotax 914 Searey, I rarely bother to look for "MOGAS." Instead, I look for airports located close to conventional gas stations. Or I just buy 100LL and support the airport. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479121#479121 ________________________________________________________________________________
Date: Apr 05, 2018
Thanks for the info. I am learning more about Rotax engines since I am involved in an RV-12 project with some kids. If you are interested you can view it at www.SoAZTeenAviation.org I will keep an eye out for premium fuels and label them as such. Glenn -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479123#479123 ________________________________________________________________________________
Subject: 912 Cylinder head coolant temperature Gauge
Date: Apr 14, 2018
I have the new cylinder heads on my 912 UL engine. I am measuring the coolant temperature using the normal Rotax (VDO) gauge. During engine operation my gauge needle is quickly fluctuating (swinging) as much as 10 to 30 degrees Celsius between zero and 80 degrees C. After landing and engine ignition circuits are cut off and the engine stopped, but with current still on the instruments (i.e. key on the =9Con=9D position the VDO gauge needle is steady at 80 degrees C. As the engine cools the needle drops. The wiring and connections from the sensors to the gauge are sound and tight. Could I have a problem with the coolant pump on the engine varying the coolant flow and thereby causing the sudden temperature variation indications on the VDO gauge? Any ideas or suggestions? Hugh G. McKay III, P.E. Fellow, L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com ________________________________________________________________________________
Date: Apr 14, 2018
Make sure all the air has been bled out of the cooling system. How is your coolant recovery tank behaving? Normal? john h mkIII Titus, Alabama From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of hgmckay(at)bellsouth.net Sent: Saturday, April 14, 2018 2:08 PM Subject: RotaxEngines-List: 912 Cylinder head coolant temperature Gauge I have the new cylinder heads on my 912 UL engine. I am measuring the coolant temperature using the normal Rotax (VDO) gauge. During engine operation my gauge needle is quickly fluctuating (swinging) as much as 10 to 30 degrees Celsius between zero and 80 degrees C. After landing and engine ignition circuits are cut off and the engine stopped, but with current still on the instruments (i.e. key on the =9Con=9D position the VDO gauge needle is steady at 80 degrees C. As the engine cools the needle drops. The wiring and connections from the sensors to the gauge are sound and tight. Could I have a problem with the coolant pump on the engine varying the coolant flow and thereby causing the sudden temperature variation indications on the VDO gauge? Any ideas or suggestions? Hugh G. McKay III, P.E. Fellow, L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com ________________________________________________________________________________
Date: Apr 14, 2018
Subject: Re: 912 Cylinder head coolant temperature Gauge
I am thinking the same way John is. You have an air bubble, and is has to be burped. The other option, as always, is a loose wire. Bill Sullivan Tarboro, NC (recently escaped from Connecticut!) -------------------------------------------- On Sat, 4/14/18, wrote: Subject: RotaxEngines-List: 912 Cylinder head coolant temperature Gauge To: "Rotax Engines" Date: Saturday, April 14, 2018, 3:08 PM I have the new cylinder heads on my 912 UL engine. I am measuring the coolant temperature using the normal Rotax (VDO) gauge. During engine operation my gauge needle is quickly fluctuating (swinging) as much as 10 to 30 degrees Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com ________________________________________________________________________________
Date: Apr 15, 2018
I had a problem like this and finally solved it with a resistor, 1kohm I think, in line with the probe. It is the same fix they recommend for the tach. > I have the new cylinder heads on my 912 UL engine. I am measuring the > coolant temperature using the normal Rotax (VDO) gauge. During engine > operation my gauge needle is quickly fluctuating (swinging) as much as > 10 to 30 degrees Celsius between zero and 80 degrees C. After landing > and engine ignition circuits are cut off and the engine stopped, but > with current still on the instruments (i.e. key on the > =9Con=9D position the VDO gauge needle is steady at 80 > degrees C. As the engine cools the needle drops. The wiring and > connections from the sensors to the gauge are sound and tight. Could I > have a problem with the coolant pump on the engine varying the coolant > flow and thereby causing the sudden temperature variation indications on > the VDO gauge? Any ideas or suggestions? > > Hugh G. McKay III, P.E. Fellow, L.M. ASCE > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > Ph. 704-661-8271 > Fax 704-483-5466 > email hgmckay(at)bellsouth.net > http://www.wwegeo.com > > ________________________________________________________________________________
Date: Apr 17, 2018
Bill, I know how to "burp" the oil system, but I have never heard of "burping" the coolant system. How is that done? Hugh G. McKay III, P.E. Fellow, L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com -----Original Message----- From: william sullivan Sent: Saturday, April 14, 2018 4:41 PM Subject: Re: RotaxEngines-List: 912 Cylinder head coolant temperature Gauge I am thinking the same way John is. You have an air bubble, and is has to be burped. The other option, as always, is a loose wire. Bill Sullivan Tarboro, NC (recently escaped from Connecticut!) -------------------------------------------- On Sat, 4/14/18, wrote: Subject: RotaxEngines-List: 912 Cylinder head coolant temperature Gauge Date: Saturday, April 14, 2018, 3:08 PM I have the new cylinder heads on my 912 UL engine. I am measuring the coolant temperature using the normal Rotax (VDO) gauge. During engine operation my gauge needle is quickly fluctuating (swinging) as much as 10 to 30 degrees Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com ________________________________________________________________________________
Date: Apr 17, 2018
I have to plead ignorance on Rotax, but a number of automotive engines will hide an air bubble in the cooling system. The old Jeep 4.0 liter straight 6 was always doing that. You filled it up after working on it, and had to keep filling it for a few days until all of the air worked out of it. Maybe John Hauck knows. It used to drive me nuts, thinking I had a leak and not finding it. I would just fill it, run it, fill it, and run it over a few days, cooling off in between runs. Bill Sullivan -------------------------------------------- On Tue, 4/17/18, wrote: Subject: Re: RotaxEngines-List: 912 Cylinder head coolant temperature Gauge To: rotaxengines-list(at)matronics.com Date: Tuesday, April 17, 2018, 4:27 PM Bill, I know how to "burp" the oil system, but I have never heard of "burping" the coolant system. How is that done? Hugh G. McKay III, P.E. Fellow, L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com -----Original Message----- From: william sullivan Sent: Saturday, April 14, 2018 4:41 PM To: rotaxengines-list(at)matronics.com Subject: Re: RotaxEngines-List: 912 Cylinder head coolant temperature Gauge --> RotaxEngines-List message posted by: william sullivan I am thinking the same way John is. You have an air bubble, and is has to be burped. The other option, as always, is a loose wire. Bill Sullivan Tarboro, NC (recently escaped from Connecticut!) ________________________________________________________________________________
Date: Apr 17, 2018
Here is how I do it. After draining and refilling, I raise the tail higher than the nose, MKIII is a tail dragger, and back down. Top it off and rock it up and back down until I can't put any more coolant into the header tank. I bleed air the same way you describe Bill S. Until the header tank is completely full after a flight, shut down, and cool down, I check the header tank. I keep doing this procedure until all the air is gone. Do the same thing with all my other water cooled engines to bleed air. When all air is gone the coolant recovery tank will hit its high mark with the engine hot and suck coolant out of the coolant recovery tank as it cools. This keeps air out of the system. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of william sullivan Sent: Tuesday, April 17, 2018 3:47 PM Subject: Re: RotaxEngines-List: 912 Cylinder head coolant temperature Gauge I have to plead ignorance on Rotax, but a number of automotive engines will hide an air bubble in the cooling system. The old Jeep 4.0 liter straight 6 was always doing that. You filled it up after working on it, and had to keep filling it for a few days until all of the air worked out of it. Maybe John Hauck knows. It used to drive me nuts, thinking I had a leak and not finding it. I would just fill it, run it, fill it, and run it over a few days, cooling off in between runs. Bill Sullivan -------------------------------------------- On Tue, 4/17/18, wrote: Subject: Re: RotaxEngines-List: 912 Cylinder head coolant temperature Gauge To: rotaxengines-list(at)matronics.com Date: Tuesday, April 17, 2018, 4:27 PM Bill, I know how to "burp" the oil system, but I have never heard of "burping" the coolant system. How is that done? Hugh G. McKay III, P.E. Fellow, L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 email hgmckay(at)bellsouth.net http://www.wwegeo.com -----Original Message----- From: william sullivan Sent: Saturday, April 14, 2018 4:41 PM To: rotaxengines-list(at)matronics.com Subject: Re: RotaxEngines-List: 912 Cylinder head coolant temperature Gauge --> RotaxEngines-List message posted by: william sullivan I am thinking the same way John is. You have an air bubble, and is has to be burped. The other option, as always, is a loose wire. Bill Sullivan Tarboro, NC (recently escaped from Connecticut!) ________________________________________________________________________________
Date: Apr 17, 2018
The coolant system in the 912 is an open system. The fluid seeks its own level and rarely ever needs more after filling. Because it is an open system it is also very easy to evacuate the entire tire system. Fill and go. With all the hoses changes I do every year I never have trapped air that made a difference. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479413#479413 ________________________________________________________________________________
Date: Apr 17, 2018
I thought I was flying with a closed cooling system all these years. If it has a pressure cap and coolant recovery system, I call that a closed system. An open system would be like my old antique tractors, unpressurised and open to the atmosphere. I really don't know of an open system on a modern water cooled engine. Set me straight if I am wrong. Not trying to be argumentative. I do know the three 912 engines I have owned since 1993, all required bleeding air and fill/top off through the header tank. There are places in the engine that do trap air. Maybe the newer engines have different castings. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: Tuesday, April 17, 2018 8:22 PM Subject: RotaxEngines-List: Re: 912 Cylinder head coolant temperature Gauge The coolant system in the 912 is an open system. The fluid seeks its own level and rarely ever needs more after filling. Because it is an open system it is also very easy to evacuate the entire tire system. Fill and go. With all the hoses changes I do every year I never have trapped air that made a difference. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479413#479413 ________________________________________________________________________________
Date: Apr 17, 2018
Roger Lee: Took a quick look in the Rotax 912 Installation Manual. It describes the cooling system as closed. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of John Hauck Sent: Tuesday, April 17, 2018 9:28 PM Subject: RE: RotaxEngines-List: Re: 912 Cylinder head coolant temperature Gauge I thought I was flying with a closed cooling system all these years. If it has a pressure cap and coolant recovery system, I call that a closed system. An open system would be like my old antique tractors, unpressurised and open to the atmosphere. I really don't know of an open system on a modern water cooled engine. Set me straight if I am wrong. Not trying to be argumentative. I do know the three 912 engines I have owned since 1993, all required bleeding air and fill/top off through the header tank. There are places in the engine that do trap air. Maybe the newer engines have different castings. john h mkIII Titus, Alabama -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee Sent: Tuesday, April 17, 2018 8:22 PM Subject: RotaxEngines-List: Re: 912 Cylinder head coolant temperature Gauge The coolant system in the 912 is an open system. The fluid seeks its own level and rarely ever needs more after filling. Because it is an open system it is also very easy to evacuate the entire tire system. Fill and go. With all the hoses changes I do every year I never have trapped air that made a difference. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479413#479413 ________________________________________________________________________________
Date: Apr 17, 2018
Youre right on. And without the overflow tank with a hose submerged in coolant you will never get rid of the air. Dave Alberti > On Apr 17, 2018, at 9:28 PM, John Hauck wrote: > > > I thought I was flying with a closed cooling system all these years. If it > has a pressure cap and coolant recovery system, I call that a closed system. > > An open system would be like my old antique tractors, unpressurised and open > to the atmosphere. > > I really don't know of an open system on a modern water cooled engine. > > Set me straight if I am wrong. Not trying to be argumentative. > > I do know the three 912 engines I have owned since 1993, all required > bleeding air and fill/top off through the header tank. There are places in > the engine that do trap air. Maybe the newer engines have different > castings. > > john h > mkIII > Titus, Alabama > > > > > -----Original Message----- > From: owner-rotaxengines-list-server(at)matronics.com > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Roger Lee > Sent: Tuesday, April 17, 2018 8:22 PM > To: rotaxengines-list(at)matronics.com > Subject: RotaxEngines-List: Re: 912 Cylinder head coolant temperature Gauge > > > The coolant system in the 912 is an open system. The fluid seeks its own > level and rarely ever needs more after filling. Because it is an open system > it is also very easy to evacuate the entire tire system. > > Fill and go. With all the hoses changes I do every year I never have trapped > air that made a difference. > > -------- > Roger Lee > Tucson, Az. > Rotax Instructor & Rotax IRC > Light Sport Repairman > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479413#479413 > > > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 18, 2018
Another source of temperature spikes I have found is with the absolute jun k VDO gauges that tend to develop erratic needle swings as they age.=C2- I spent one summer changing out well over 1000 dollars worth of electrical components chasing "voltage spikes" on=C2- my CH-701 only to find out the problem was a bad VDO gauge.=C2- I had even tried another (albeit used) VDO voltage gauge and still had the same "spikes".=C2- Turned out it was the crap VDO volt meters and there was actually nothing wrong with my elect rical system.=C2- Since then, I have been slowly converting my panel over to Stewart Warner gauges and have been happy with the results.=C2- I hav e an erratic oil temperature gauge right now that will be getting replaced at annual. While I won't claim to be an expert and know very little of the OP's proble m, he did mention he has a VDO gauge and I would replace that before gettin g to carried away chasing a potentially phantom engine problem. Doug MCH-701/ 912-UL ________________________________________________________________________________
Date: Apr 18, 2018
Since the early days, ultralight pilots have freaked out over instrument indications. They spent hours and lots of money, and probably destroyed lots of engines and airplanes chasing engine instruments, trying to get that two stroke engine dialed in perfectly. I think of all the other two stroke engines in my life back then that had no instrumentation. Never worried about EGT and other temps. They seemed to run forever with good fuel and oil, and a new spark plug every once in a while. Usual the problem was improper prop loading. Rotax did a good job of setting up the engines at the factory, but if the Westach instrument told them their EGT was a little high or low, they'd start chasing their tail, changing jets, needles, spark plugs, and anything else they could find to change. I was one of them. I have a situation with my 9121ULS that irritates me. I randomly get low oil pressure and high engine oil temp indications. I was on a flight to Oregon many years ago when this first started happening. Was irritating, but proved to be harmless. It is still happening, but the temps are always reading the same, even though they are incorrect. Annoying, but not critical. BTW, they are VDO marine gauges. I can shut down the battery and the indications return to normal. Must be wiring, probably poor grounding, or the gauges. john h mkIII Titus, Alabama From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of MacDonald Doug Sent: Wednesday, April 18, 2018 6:16 AM Subject: RotaxEngines-List: Re: 912 Cylinder head coolant temperature Gauge Another source of temperature spikes I have found is with the absolute junk VDO gauges that tend to develop erratic needle swings as they age. I spent one summer changing out well over 1000 dollars worth of electrical components chasing "voltage spikes" on my CH-701 only to find out the problem was a bad VDO gauge. I had even tried another (albeit used) VDO voltage gauge and still had the same "spikes". Turned out it was the crap VDO volt meters and there was actually nothing wrong with my electrical system. Since then, I have been slowly converting my panel over to Stewart Warner gauges and have been happy with the results. I have an erratic oil temperature gauge right now that will be getting replaced at annual. While I won't claim to be an expert and know very little of the OP's problem, he did mention he has a VDO gauge and I would replace that before getting to carried away chasing a potentially phantom engine problem. Doug M CH-701/ 912-UL ________________________________________________________________________________
Date: Apr 18, 2018
My 2 cents as an EE: There are NO rapid temperature changes. Not physically possible. How much energy do you think is available to heat and COOL the coolant through wide swings. VDO are cheap crappy mechanical gauges, emphasis on cheap crap. Automotive or snowmobile quality, no better. I like Rotax hardware, but the VDO garbage should be thrown away on delivery and replaced with airworthy meters. The temp. swings are most likely vibration induced mechanical resonances in the needle/coil/spring system in the indicator. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479432#479432 ________________________________________________________________________________
Subject: Rotax 914 - at which CHT does the coolant boil?
Date: Apr 26, 2018
Hi, this year again an extended ground run was necessary at the holding point at the AERO in Friedrichshafen. Since I had to taxi in OAT of 25C/77F first on soft ground with high power and thereafter in a stiff tailwind to the end of the runway to wait in the queue, my CHT climbed to 122C/251F. After I positioned myself a bit into the wind and close behind a Mooney to profit from its propwash the CHT settled on 118C/244F and decreased fast to normal after take off. Does anyone know, how the CHT correspond with the actual coolant temperatures? At which CHT is it advisable to shut down the engine? Regards Roland PH-ZTI Europa XS TG 914 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479564#479564 ________________________________________________________________________________
Date: Apr 26, 2018
Subject: Re: Rotax 914 - at which CHT does the coolant boil?
Roland: May I recommend Wayne's Waterless Coolant for your R912 application. There are a number of advantages over traditional water/ethylene/glycol coolant. The higher boiling point reduces internal flash boiling within your engine, your specific concern with over heating on the ramp would be reduced and likely eliminated. Further advantages, less internal corrosion, improved heat transfer, lower cooling system pressure. This coolant is popular in NASCAR, Off Road racing, and has worked well for me in my R582 powered Mk3 and my Ford Ranger Prerunner. You may want to review these two links. Tailwinds to you https://www.evanscoolant.com/how-it-works/ https://www.evanscoolant.com/how-it-works/ Jim On Thu, Apr 26, 2018 at 3:32 AM, Roland wrote: > > Hi, > > this year again an extended ground run was necessary at the holding point > at the AERO in Friedrichshafen. > > Since I had to taxi in OAT of 25=C2=B0C/77=C2=B0F first on soft ground wi th high > power and thereafter in a stiff tailwind to the end of the runway to wait > in the queue, my CHT climbed to 122=C2=B0C/251=C2=B0F. After I positioned myself a > bit into the wind and close behind a Mooney to profit from its propwash t he > CHT settled on 118=C2=B0C/244=C2=B0F and decreased fast to normal after t ake off. > > Does anyone know, how the CHT correspond with the actual coolant > temperatures? At which CHT is it advisable to shut down the engine? > > Regards > Roland > PH-ZTI > Europa XS TG 914 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479564#479564 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Apr 26, 2018
Thanks, Jim. But Evans carries a temperature penalty of up to 30F in a cowled Rotax-installation, thus bringing my engine to the CHT-limit. During flight the temperatures are ideal. Problems only on ground and in adverse conditions. Regards Roland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479587#479587 ________________________________________________________________________________
Subject: Flickering Alt Light
Date: Apr 27, 2018
The alt light (its a LED, not incandescent) on my Rotax 914 (over 900 hours) has started to flicker even when at cruise (5000 rpm). It has often flickered when at low rpm and it always turns full on when the engine is not running. I have two Hall amp sensors but I can only display one at a time. At cruise, the amps being delivered by the Rotax system are about 8 to 10 which I what I expect given the loads turned on. At cruise the amps measured at the battery are roughly 0, the indication will vary a little from +1 or 2 to 1 or 2 which I take to be instrument error. The bus voltage is around 13.3 prior to engine start. After start it slowly climbs to about 14.4 after 20-30 minutes of cruise. The aircraft is wired in accordance with AeroElectric Z-16. The battery is an EarthX ETX680 and its monitoring circuit does not show any problem. I switched from lead acid to EarthX ETX36 in 2014 and in March 2017 changed to ETX 680C. Ive only had this problem recently. Everything was normal at first after installing the ETX680C. In 2014 I added external diodes to supplement the original Ducatti (PN 343620) regulator/rectifier and a few months later I replaced that Ducatti R/R as the alt light was illuminating while operation seemed normal. The replacement was the later model Ducatti (PN 362001) but I left the diodes in place. I discovered (I think during 2017) that the Rotax system was not delivering a high enough voltage to keep the EarthX fully charged. I added a diode in series in the C lead to boost the voltage. While troubleshooting the charging problem I changed back to the original Ducatti which has operated fine until the recent flickering issue. I cant decide if I have a battery problem or a Rotax/Ducatti problem. Jim Butcher Europa XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479596#479596 ________________________________________________________________________________
Date: Apr 27, 2018
Subject: Re: Flickering Alt Light
One thing to check would be the regulator-rectifier connector. There have been reports of bad connections and even connector melt downs associated with poor installation and/or inadequate strain relief at that point. On Fri, Apr 27, 2018 at 7:58 AM, h&jeuropa wrote: > butcher43(at)att.net> > > The alt light (it=99s a LED, not incandescent) on my Rotax 914 (ove r 900 > hours) has started to flicker even when at cruise (5000 rpm). It has oft en > flickered when at low rpm and it always turns full on when the engine is > not running. I have two Hall amp sensors but I can only display one at a > time. At cruise, the amps being delivered by the Rotax system are about 8 > to 10 which I what I expect given the loads turned on. At cruise the amp s > measured at the battery are roughly 0, the indication will vary a little > from +1 or 2 to =93 1 or 2 which I take to be instrument error. T he bus > voltage is around 13.3 prior to engine start. After start it slowly clim bs > to about 14.4 after 20-30 minutes of cruise. > > The aircraft is wired in accordance with AeroElectric Z-16. The battery > is an EarthX ETX680 and its monitoring circuit does not show any problem. > I switched from lead acid to EarthX ETX36 in 2014 and in March 2017 > changed to ETX 680C. I=99ve only had this problem recently. Everyt hing was > normal at first after installing the ETX680C. > > In 2014 I added external diodes to supplement the original Ducatti (PN > 343620) regulator/rectifier and a few months later I replaced that Ducatt i > R/R as the alt light was illuminating while operation seemed normal. Th e > replacement was the later model Ducatti (PN 362001) but I left the diodes > in place. > > I discovered (I think during 2017) that the Rotax system was not > delivering a high enough voltage to keep the EarthX fully charged. I add ed > a diode in series in the C lead to boost the voltage. While > troubleshooting the charging problem I changed back to the original Ducat ti > which has operated fine until the recent flickering issue. > > I can=99t decide if I have a battery problem or a Rotax/Ducatti pro blem. > > Jim Butcher > Europa XS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=479596#479596 > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: May 04, 2018
Most times this is just a poor ground or lose wire especially since you have done the other things. That said you may want to double check your work connections. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479845#479845 ________________________________________________________________________________
Date: May 04, 2018
Rotax does not recommend waterless coolant any more after their poor experiences with Evans. What they do recommend is Dex Cool 50/50. Waterless coolants carry that higher 25-30F temperature penalty because water absorbs temp quicker and releases it. Waterless coolant doesn't release heat fast enough. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479853#479853 ________________________________________________________________________________
Date: May 04, 2018
That's the problem, Roger. There's no advantage for me, if the coolant doesn't boil but I exceed the CHT-limit. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479854#479854 ________________________________________________________________________________
Date: May 05, 2018
Most of the time you can fix the cause of the overheat. Waterless coolant is just putting a band aid on or fixing the result. Check all hoses to see if one has a reduced radius, move hoses away from exhaust pipes of mufflers or apply more heat shielding, Wrap the exhaust pipes with header wrap cloth, change the air flow through the cowl (possible opening the cooling inlet areas), if you have the smaller radiator see if the larger one will fit, make sure you have the 1.2 bar pressure cap and not the .9 bar cap. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=479863#479863 ________________________________________________________________________________
Subject: Possible loan of carburettors for 80 hp 912UL
Date: May 21, 2018
All, I'm based in southern Germany. Does any have have a spare set of carburettors for the 80HP 912 UL, preferably with the 158 main jet, that they could send me for a few weeks. I'm trying to eliminate the carburettors from a problem, and aim to do this by swapping them and seeing how the effect changes. Best Jon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480271#480271 ________________________________________________________________________________
From: =?UTF-8?B?TmFkw6hnZSBT?= <nadege.pilot(at)gmail.com>
Date: May 22, 2018
Subject: Rotax 915iS
Hi all, I'm planning to get the Rotax 915iS for my aircraft but I have some questions with regards to the exhaust pipe. It's coming out at 90=C2=B0 from the engine (and what would be the engine cowling given where it is) for about 10". What can be done to it to make it more aerodynamic without voiding the warranty? Now, looking at connecting it to my Vertical power VP-X Pro, given the fact it has 2 alternators working in a specific manner (controlled by the Rotax ECU) how do I wire them? Like a single alternator? I'm thinking of putting a backup alternator (rather than a backup battery), Would it be connected to the VPX as 2nd alternator then? And one more question to people who have installed a VP-X with a Rotax 912is, what types/models of switches have you used for the alternators? Thanks a lot for your answers...I'm struggling a bit here! Nadege S ________________________________________________________________________________
Date: Jun 02, 2018
The problem has been solved by replacing the LED with a 1 1/2 watt incandescent lamp. The install manual calls for 3 watt but thats not available in the size I need. Jim Butcher Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480586#480586 ________________________________________________________________________________
Subject: Rotax Service Class Oct. 6 & 7, 2018 in Tucson, AZ
Date: Jun 16, 2018
Note*** When you call California Power Systems to sign up make sure you tell them it is for the Tucson, AZ class in October so it isn't confused with some other class.. New Rotax 912UL/ULS & 912iS Service Class Conducted by Rotax Instructor Roger Lee in Tucson, AZ In conjunction with California Power Systems Come join us for a new and exciting Service class. Lots of hands on so don't miss it! http://www.cps-parts.com/catalog/rtxpages/912service-inspclass.php Oct. 6th & 7th, 2018 (Saturday & Sunday) This class is a must for an Owner, LSRM or an A&P mechanic to develop their 912 series inspection skills and knowledge. This class will focus on a hands on approach to completing a 100 hour / annual condition inspection. The class will differ from other Service rated classes as it will spend less classroom time and a lot of hands on time with a live engine performing a 100 hour / Annual Condition Inspection. You will be able to ask on the spot questions and solve problems on the live engine while developing and expanding your 912 inspection skills and knowledge base. We will have classroom in the morning Saturday and Sunday (Oct. 6th & 7th) and spend both afternoons doing an annual inspection on an in-service and operational 912 engine. The afternoons will be spent in the hangar and everyone will be turning wrenches and performing task. You WILL understand a carb sync at the end of this class. We will have the Maintenance manual out and will follow the inspection procedures. At the end of this class you should be well grounded in the performance of a 100 hour / annual condition inspection. You will receive a Rotax Service certificate for successful completion of this class. Our classroom is air conditioned and comfortable. Maximum student limit of 10. The class size is limited to make sure everyone gets to participate so dont procrastinate and sign up now. Class times will be 8 a.m. to 5 p.m. Fly into Tucson International Airport (TIA) or fly your own plane into Ryan Airfield. Classes are Saturday and Sunday. All rental cars are on site at Tucson International Airport or Enterprise will pick you up if you fly into Ryan Airfield. Several hotels are just hundreds of yards down the street at TIA. Ryan Airport (KRYN) is only 10-12 minute drive. The entire experience is convenient and comfortable. For additional information or to sign up call Brain Toepfer at CPS in CA at 951-549-7786 ext. 302 or email bryantoepfer@cps-parts.com. For additional class details call Roger Lee in Tucson, AZ at 520-574-1080. CLASS OVERVIEW: This is a two day 16 hour class that qualifies graduates to maintain 912 series engines under ASTM standards as set forth by the Light Sport Aircraft (LSA) regulations. Passing a written exam is required for Rotax certification and graduates will be issued an IRMT (Independent Rotax Maintenance Technician) badge and service number valid for two years. This course will supply attendees with the following information and skills: Rotax History and Product Familiarization Senders and Instrumentation Gearbox : The internal workings and maintenance Propeller considerations, adjustment and its effects on your engine Hose inspection, maintenance and considerations Oil System workings, maintenance and considerations Cooling System workings, maintenance and considerations Fuel System workings, maintenance and considerations Carburetor workings, maintenance and keeping them in sync Ignition Theory Compression and why its important, what it tells us and performance of a real compression test Troubleshooting Scheduled Maintenance Maintenance Documentation MATERIALS: All tools, reading materials, and supplies will be provided, however you should bring a laptop or tablet to view the manuals or do any research. A free WIFI connection is available in the classroom. http://www.cps-parts.com/catalog/rtxpages/912service-inspclass.php -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=480925#480925 ________________________________________________________________________________
Date: Jul 30, 2018
Subject: 912 ULS sudden rough running on mag check
My engine ran fine on a local flight to a neighboring airport last week. When leaving, I had some vibration, rough running that is not characteristic to my engine. I powered up the boost pump and it seemed a little better so I continued to taxi. Just prior to the run up area I got a few more shakes so I pulled off to check under the cowling. I found nothing amiss so I continued to checklist and mag check. My A side ran fine but B dropped 150 or so then ran fine. I flew the 30 min flight home without incident and arriving at the hanger did my usual shutdown mag check. The B side shook like crazy and I could not power through the rough running. Heres what I found. Grounds all normal. Checking the trigger coils resistance all was normal. I took the connectors apart and established continuity to the triggers. Checked the coil primary side and one had no resistance, meaning two cylinders got no spark. I used a pin and checked the white wire near the coil and got good readings. Moved the pin 1 inch past the connector and still good. Now I removed the pin from the connector and the wire felt limp about 1/8 below the pin at the base of the connector boot. I dissected the wire with an exacto and sure enough the wire was completely broken. I was able to repair the connection as the wire was long enough. Put it all back together and it purrs like a kitten. It actually may be smoother than it was on more recent flights so Ill bet it was going for some time and finally gave up the ghost. Perhaps this will help someone else if they experience similar issues. Dave Alberti ________________________________________________________________________________
Date: Jul 31, 2018
Subject: Re: RotaxEngines-List Digest: 1 Msgs - 07/30/18
Dave, =C2-I was going to guess an internal broken wire before I got to end of y our post as this has happened to me twice and is a common issue in these en gines. Dick Maddux=C2- =C2- In a message dated 7/31/2018 1:41:24 AM Central Standard Time, rotaxengines -list(at)matronics.com writes: =C2- * ======================== Online Versions of Today's List Digest Archive ======================== Today's complete RotaxEngines-List Digest can also be found in either of th e two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RotaxEngines-List Digest and can be viewed with a generic text edito r such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Ch apter 18-07-30&Archive=RotaxEngines Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Cha pter 18-07-30&Archive=RotaxEngines ======================== ======================= EMail Version of Today's List Digest Archive ======================== ======================= ---------------------------------------------------------- RotaxEngines-List Digest Archive --- Total Messages Posted Mon 07/30/18: 1 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 07:51 PM - 912 ULS sudden rough running on mag check (Dave) ________________________________ Message 1 ________________________________ _____ From: Dave <daberti(at)sbcglobal.net> Subject: RotaxEngines-List: 912 ULS sudden rough running on mag check My engine ran fine on a local flight to a neighboring airport last week. Wh en leaving, I had some vibration, rough running that is not characteristic to my engine. I powered up the boost pump and it seemed a little better so I cont inued to taxi. Just prior to the run up area I got a few more shakes so I pulled off to check under the cowling. I found nothing amiss so I continued to che cklist and mag check. My A side ran fine but B dropped 150 or so then ran fine. I flew the 30 min flight home without incident and arriving at the hanger did my usual shutdown mag check. The B side shook like crazy and I could no t power through the rough running. Heres what I found. Grounds all normal. Checking the trigger coils resistance all was normal. I took the connectors apart and established continuity to the triggers. Checked th e coil primary side and one had no resistance, meaning two cylinders got no s park. I used a pin and checked the white wire near the coil and got good readings . Moved the pin 1 inch past the connector and still good. Now I removed the pin from the connector and the wire felt limp about 1/8 below the pin at th e base of the connector boot. I dissected the wire with an exacto and sure enough the wire was completely broken. I was able to repair the connection as the wire was long enough. Put it all back together and it purrs like a kitten. It actually may be smoother than it was on more recent flights so Ill bet it was going for some time and finall y gave up the ghost. Perhaps this will help someone else if they experience similar issues. Dave Alberti ________________________________________________________________________________
Date: Jul 31, 2018
Subject: Re: 912 ULS sudden rough running on mag check
Dave, Thanks for sharing your experience and trouble shooting methods. Dennis On Mon, Jul 30, 2018, 7:55 PM Dave wrote: > > My engine ran fine on a local flight to a neighboring airport last week. > When leaving, I had some vibration, rough running that is not > characteristic to my engine. I powered up the boost pump and it seemed a > little better so I continued to taxi. Just prior to the run up area I go t > a few more shakes so I pulled off to check under the cowling. I found > nothing amiss so I continued to checklist and mag check. My A side ran > fine but B dropped 150 or so then ran fine. I flew the 30 min flight hom e > without incident and arriving at the hanger did my usual shutdown mag > check. The B side shook like crazy and I could not power through the rou gh > running. Here=99s what I found. > Grounds all normal. Checking the trigger coils resistance all was normal. > I took the connectors apart and established continuity to the triggers. > Checked the coil primary side and one had no resistance, meaning two > cylinders got no spark. I used a pin and checked the white wire near the > coil and got good readings. Moved the pin 1 inch past the connector and > still good. Now I removed the pin from the connector and the wire felt li mp > about 1/8=9D below the pin at the base of the connector boot. I dis sected the > wire with an exacto and sure enough the wire was completely broken. > I was able to repair the connection as the wire was long enough. Put it > all back together and it purrs like a kitten. It actually may be smooth er > than it was on more recent flights so I=99ll bet it was going for s ome time > and finally gave up the ghost. > Perhaps this will help someone else if they experience similar issues. > > Dave Alberti > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Aug 01, 2018
Thanks Dave. From: FoesFlyDennis Sent: Tuesday, July 31, 2018 6:58 PM Subject: Re: RotaxEngines-List: 912 ULS sudden rough running on mag check Dave, Thanks for sharing your experience and trouble shooting methods. Dennis On Mon, Jul 30, 2018, 7:55 PM Dave wrote: My engine ran fine on a local flight to a neighboring airport last week. When leaving, I had some vibration, rough running that is not characteristic to my engine. I powered up the boost pump and it seemed a little better so I continued to taxi. Just prior to the run up area I got a few more shakes so I pulled off to check under the cowling. I found nothing amiss so I continued to checklist and mag check. My A side ran fine but B dropped 150 or so then ran fine. I flew the 30 min flight home without incident and arriving at the hanger did my usual shutdown mag check. The B side shook like crazy and I could not power through the rough running. Here=99s what I found. Grounds all normal. Checking the trigger coils resistance all was normal. I took the connectors apart and established continuity to the triggers. Checked the coil primary side and one had no resistance, meaning two cylinders got no spark. I used a pin and checked the white wire near the coil and got good readings. Moved the pin 1 inch past the connector and still good. Now I removed the pin from the connector and the wire felt limp about 1/8=9D below the pin at the base of the connector boot. I dissected the wire with an exacto and sure enough the wire was completely broken. I was able to repair the connection as the wire was long enough. Put it all back together and it purrs like a kitten. It actually may be smoother than it was on more recent flights so I=99ll bet it was going for some time and finally gave up the ghost. Perhaps this will help someone else if they experience similar issues. Dave Alberti ========== - xEngines-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List ========== FORUMS - eferrer noreferrer" target="_blank">http://forums.matronics.com ========== WIKI - errer noreferrer" target="_blank">http://wiki.matronics.com ========== b Site - -Matt Dralle, List Admin. rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Subject: Re: Rotax Service Class Oct. 6 & 7, 2018 in Tucson,
AZ
Date: Aug 02, 2018
Time is growing short and seats are getting on short supply. Good hands on for completing and understanding annuals. Make sure you tell CPS this is the Tucson, AZ class. http://www.cps-parts.com/catalog/rtxpages/912service-inspclass.php -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=482021#482021 ________________________________________________________________________________
Subject: Battery not charging
Date: Aug 09, 2018
I have just run my 912S (in a Europa) for the first time (with a Rotax engi ne specialist doing all the work!) The problem is the battery is not charging. I have researched the subject and found a good looking guide here: http://p ointsforpilots.blogspot.com/2012/12/testing-rotax-912914-generator-and.html These are the results: Testing Generator Result Pull off the 2 yellow wires from G terminals. With engine off and Master switch off, resistance between the two wires sho uld be 0.1 - 0.8 Ohm. 0.5 - 0.8 Resistance between either wire and ground should be infinite; that is, ther e is an open circuit. -1 (is this infinite?) With engine running and the two wires still off the regulator, test AC volt age between the two wires. It should be: 15 - 20 VAC during idle 14.6 2000 rpm Almost 15! 30 - 40 VAC during high rpm 24.4 3300 rpm Almost 30! Testing Capacitor Result If the resistance between the plus and minus poles of the capacitor is not infinite, that is, it is not an open circuit, then the capacitor has failed and must be replaced. -1 (is this infinite?) Testing Regulator/Rectifier Result With Master switch on: Measure the voltage between ground and the wire on t he R, B+ & C terminals in turn; it should be the battery voltage, about 12. 5 VDC. R 0.02 B+ 0.02 C 0.02 With Master switch off: The above test should show 0 voltage for all three cases. R 0 B+ 0 C 0 Test that housing of regulator/rectifier is properly grounded: Resistance between regulator housing and battery ground should be essential ly 0. 0 If the wiring fails any of the above tests, the wiring problem needs to be isolated and fixed. If the wiring passes the above tests, yet output voltage of the regulator/r ectifier is not in the normal range, then the regulator/rectifier likely is faulty and should be replaced. My understanding is that this is a wiring problem, no voltage is getting to the reg/rect... but I am worse than a novice at this - a little knowledge is a dangerous thing! The aircraft is wired basically according to the Europa build manual (below or attached, depending how you are viewing this). Any clues as to where I should begin looking? Many thanks in advance, Paul M Europa XS 383 912S [cid:image001.png(at)01D4301C.6E415560] ________________________________________________________________________________
Subject: Re: Battery not charging
Date: Aug 09, 2018
Hello Paul It would appear that the AC part of your system is working ok. What DC voltage do you get when you put the positive probe on the Reg +B and and the black probe on system ground? This should be about 13.4 to about 14.2 VDC depending on the RPM of the engine, From you diagram, I do not see where the regulator is attached to system ground. Is the case of the regulator intended to be connected to system ground or was term L or R intended to be system ground?? Your capacitor is grounded but there is no indication of how the regulator ground circuit is completed?? Ted Kitfox IV ________________________________________________________________________________
Date: Aug 10, 2018
i also have a third item to check.. in doing all of the testing below... t he battery voltage on r b ,c showed 2volt.after much on and off with the ma ster switch in testing the voltage gradually climbed on these terminals.... .. finally ended up after several hour with battery voltage...turns out the master relay was failing or arc corroded . it was not open and had not sei zed and exciter coil was still working properly.. but was not contacting pr operly and was only letting 2 volts through... replaced it and everything c hecks below just fine... 383(at)hotmail.com> wrote: I have just run my 912S (in a Europa) for the first time (with a Rotax engi ne specialist doing all the work!) =C2- The problem is the battery is not charging. =C2- I have researched the subject and found a good looking guide here:http://po intsforpilots.blogspot.com/2012/12/testing-rotax-912914-generator-and.html =C2- These are the results: =C2- | Testing Generator | | | | | Result | | | =C2- | | | | | | | | | | =C2- | | Pull off the 2 yellow wires from G terminals. | | | | | | | | =C2- | | | | | | | | | | =C2- | | With engine off and Master switch off, resistance between the two wires sho uld be 0.1 - 0.8 Ohm. | | 0.5 - 0.8 | | | =C2- | | | | | | | | | | =C2- | | Resistance between either wire and ground should be infinite; that is, ther e is an open circuit. | | -1 | (is this infinite?) | | | | | | | | | | =C2- | | With engine running and the two wires still off the regulator, test AC volt age between the two wires. | | | | =C2- | | It should be: | | | | | | | | =C2- | | 15 - 20 VAC during idle | | | | | 14.6 | 2000 rpm | Almost 15! | =C2- | | 30 - 40 VAC during high rpm | | | | | 24.4 | 3300 rpm | Almost 30! | =C2- | | | | | | | | | | =C2- | | Testing Capacitor | | | | | Result | | | =C2- | | | | | | | | | | =C2- | | If the resistance between the plus and minus poles of the capacitor is not infinite, that is, it is not an open circuit, then the capacitor has failed and must be replaced. | | | | | -1 | (is this infinite?) | | | | | | | | | | =C2- | | Testing Regulator/Rectifier | | | | | Result | | | =C2- | | | | | | | | | | =C2- | | With Master switch on: Measure the voltage between ground and the wire on t he R, B+ & C terminals in turn; it should be the battery voltage, about 12. 5 VDC. | | | | | | | | =C2- | | R | | | | | 0.02 | | | =C2- | | B+ | | | | | 0.02 | | | =C2- | | C | | | | | 0.02 | | | =C2- | | | | | | | | | | =C2- | | With Master switch off: The above test should show 0 voltage for all three cases. | | | | | | =C2- | | R | | | | | 0 | | | =C2- | | B+ | | | | | 0 | | | =C2- | | C | | | | | 0 | | | =C2- | | | | | | | | | | =C2- | | Test that housing of regulator/rectifier is properly grounded: | | | | | | | | =C2- | | Resistance between regulator housing and battery ground should be essential ly 0. | | | 0 | | | =C2- | | | | | | | | | | =C2- | | If the wiring fails any of the above tests, the wiring problem needs to be isolated and fixed. | | | | | =C2- | | If the wiring passes the above tests, yet output voltage of the regulator/r ectifier is not in the normal range, then the regulator/rectifier likely is faulty and should be replaced. | | | | | | | | =C2- | =C2- My understanding is that this is a wiring problem, no voltage is getting to the reg/rect... but I am worse than a novice at this =93 a little kn owledge is a dangerous thing! =C2- The aircraft is wired basically according to the Europa build manual (below or attached, depending how you are viewing this). =C2- Any clues as to where I should begin looking? =C2- Many thanks in advance, =C2- Paul M Europa XS 383 912S =C2- | | Virus-free. www.avast.com | iVBORw0KGgoAAAANSUhEUgAAAWIAAAGgCAYAAACQfG3FAAAAAXNSR0IArs4c6QAAAARnQU1BAACx jwv8YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAJr4SURBVHhe7Z0FgCRX1bZH1yIECxCc7+MDfiQQ CHEgRgIxoiSEBAgJxI0ISSDu7rZxd3fX3bis++yOtbvbvP95763bXdPbO6sz3bN93+RsVV0rmaqn Tp+6dasFVlZWVlZ1lQWxlZWVVZ1lQWxlZWVVZ1kQW1lZWdVZFsRWVlZWdZYFsZWVlVWdZUFsZWVl VWdZEFtZWVnVWRbEVlZWVnWWBbGVlZVVnWVBbGVlZVVnWRBbWVlZ1VkWxFZWVlZ1lgWxlZWVVZ1l QWxlZWVVZ1kQW1lZWdVZFsRWVnXUAErWVthWH1kQW1nVUYSJgYqdLu909ZEFsZWVlVWdZUFsZWVl VWdZEFtZ1Vvmd7a15TOqVvryWIPIgtjKqt6qBQhrSzeqVvryWIPIgtjKymr0qhZcl8caRBbEVlZW o1e14Lo81iCyILayGkaVSiU1HRgYKM/n83k1rUin2+nyTkW14FplpUJRTYv5wqDpQNHVTp1lQWxl NULKZrMoFAQCIoI5l8vJHGFgbYXNge0SrTRQBi+tkJOboKSV8xtEFsRWVsMsesLGG6YymYyaKi8Z RWsrYTyG8v8Sza1CQf8NmO76czSELIitrIZRBIURYcywBKdlz1jZsr5JZqeDp8umRgawkQWxldUw q6WlpWxjxoxBZ2cn2tradFqrYy2ybKfLN11GGzN2vJq2tnWU0wpF8aSdv08jyILYymoYRc+3vb29 Al7Hxo0bp9INGFpaDCTsdPmmS7HW9kEAJpTb2juXy6MeCVkQW1kNswx8I5EIUqkU4vE4uru7EQ5H EY4kEIyKRZJ2uiLTpZgvFEUgEkcopsu3tAqUxYryd7EgtrJqEjEeTAjTIyZ4A4EQgqEIojEBRSiG QDixUuaPpJQFwimEZDkUjivwlNNlXoFIlU/BG8mIsXylrJoPZZTpNiv1dZtMS8ArINNtsY5epzHm 0yppph1aZXsrVilXWXbmnTqD6zn5kme2eVDaEqb+kFg4VgZyS1snWtrHWI/YyqrZZH4WK++X8HUA QVgY4K2oabDmpK0MwqEEIuEgQpEwvOG8skAkqpaZ5w/n0BstojeWV3CNhMIIRKW8gDXihzLOe2Nh 9Mcy8ERziAUTyvpjKfTGCTfx4nlDkfX52X6IloNHbiw0pqs82VdvLKotSrDq7TWQ9Kv6uhyX9Y1A 5/ujrCP1VR3nGKmyMpU8Ze40U6bGNBBN6ynBLKZDGh3OX6ZxZEFsZTXM0iDuUCA2APaFkw4sVtwI KkKYRsgSZJGwX0AZlGWCuFgGMUHHNDeIw2ENYsIv5oMyA+LeeEqBOO5PKRBzeVFCYEaoC4i5Pn9I 2jcgjkp5F4gJUo8LxHpbtcdNGxLEYro895PLury66bAtB+wa+IsfF7dpELOsBbGVVROJ/aMG95Gq BjHBsipAbIyA8kSKMs0puBLECmoCSOVZihHC2jS8zM96f1RgrEA8IB7xgEojQAlVlosExdMWI4i1 RyxQd0CsPG5ZhwIvt4OhC5k3IDbQHArEZtmYqueUVdsp66MxjTeGfjFPVNfTIRK9nUuy2iBuc/4y jSMLYiurVaolg5gPi1Y1iA2I+iMDAmMdilAwDtHLJLwkLyZgFO+YINYxX9kGBU/tYRLEkUAe4YCU kbY8MQ1Ptk0IE7Zso58eLz1ses30xAliBVNuC7fDDUUHqsbK6dzmypTbw/WwjPKqBbIKwg6k6c27 Qcx9VKEY2WbeEMz+L8kGgVjqWBBbWTWFRhLEGi6c9keLYuLxyjwBNQjEypPUIA7L+k1ogWAjAA1w Q/Sg6V0r4JqHcgSjBjHbMulMY32zDQaoXGabZhu1d1u93RqMbIfbw/r0uHvi3E567eLZS3pEPWDT oQ3GqNX6DPylDvO4vuq23WZBbGXVlKoPiA0YNfQ0hOlxctmAmB6sAbEqr7xLpx0VqnC8ZEkjJGna czZtGwDGZZlgljzHo1bgF9gpz9YJa5jwg/JwZR3a9LYPArHM96gYtHjdDogjDogZI2Z7GsT0zsWr Z+8O7rd6aGdBbGVltZhGEsQ0DTiChssakIQmvUcdZ1VervlJTyCJcX5wmcHeKyGpYKfSquoTjirk IeuLac+UD/QiYgQxQxgawmzfrENvp2mfbSgzNwsFW4YndB3eSKq9bFWXHjHj0qq+BbGVlVVNjaxH TI+RgFHgFNgQZPQqDTgroNXz2vPVcNVpTjiC8VnlyWr4GVPrkHqqO5wDYtWrwQEuQczleCCBWEC3 wTAD21TAFBsKxHrbZP2qLb0u93bqunpf9TY56U57Om/JZkFsZdWUGjkQEy7ReAy9/X2q7Ui6iN5Q Gr3hLPyJIvoIsVgBPZ4o4qkBLOoNIBbXkFvkjSIoaX3BNHwC7n6+qZbOqjfQejx+hBM5BGMsq+En m4x+f1qBLUhPOBIT4MfgT6fR4w2iECkg4UtiUTCqQgwK8sGs1M3AF9TwjKXz6PFH4ZN1qBuHlFWh DPWQLgdPOI2IbJ/PH0YkmkQ4lpX1FNHtF1AHZFk2IhIJqQd4vaEkvPGCgnitY2PMgtjKqik1ciAm zKIhr6yhgO5gGF3BpAJxMFEQqAnskgIxgaHwTUEtxodt/oj6yU/4euNFBbq+kAAvmkEXASyATWSy AuqwBqOALhxKISjAjsY1uPtDCYSTAu5UEn1R7dUmeqKI9cUQyAI9ckPoD0k9uSFEBMjBSBpeAalX 6gUSsn3JNLoW9uHd9z6WdUflhiGesnjccdlOwtkfCCGdKaDXF4EvUoJUQ5gxbl9IAB2QYyfbmQEW BUz8ufbxoVkQW1k1pUYOxOymFuqbg4vOPw0tnWuiZezn0NK2Blrbxqp1rvPFr+LuJ97EgoDAtj+A SMCPvAA0HIwoj3m+T9og0Hxp8YSL4o3mEE+k0Ov1CSwz4gUXERVgsy9xoD8oeVn0iefbo+K4IfGE e9Er2+EL5TB78kx8dcJ6uOOx59GVYDe6LIKBmMAzjADDFgLTPl9cedGL/D5stfX2uOKKGxSY/dJu SG4IHo8AXo6NNxhCv9QlmHvFm08kSvDINkaTJVXXn0ygW8Duj5dcoYvaZkFsZdWUGjkQ83XmYqQL 11x2Fn663S6YGioinCohxtirz4NLrrwWY7/0Ezz15izVUyIV9CDS14tQQH7aBwSgAuE5nox4x0A8 WkJQQOmRvEg2I5ANyLYm4WP/Yn8WuUhUpgH0CxwXimfs8fUjX0jDEyuIt1vElBc/xHrjvoy7n34D U31JJMUzjgr84vGkAngwXFCw749GsMDTi80221pAPFE8clmnWFKg6vPEERYwh1JZ+GIDWCRedjwY RMQn8PXlxHOmt11Cn3jLfeL9h9iLQsWLl2wWxFZWTamRBXHWMx1XXvhfbLLrvpgqQKUnGfZ61avO s+Yvwjd+uj3OuvJexAIB5II9ePvFl/DTn/wcLa3j8flv/hC3PvoqFvRlkA2J1znfi2NO+g9aOjow bsJYnPTvU/H5L/4ITz3+FkJzZmC7zTfG7gefgllxIJ2J4aXnn8CEz38HDz86CdNf+hhfHfMl3PvM u1gogH/o8Wex9ZZbyX5z5LkO/PhHm+OZFyahy9+LX/x6I7S2TJD0NXDgIUchGEvi3Tfew8F/PxQt Y8bJ+tfAEf++FP19KRSDXbj+/FPw0/V/jQ23/Qtaxn8DB597BWIC62B/vwrP1Do2xiyIrayaUiMJ Yo7UMx8XnvUvbLz7n/FRoKCAk4/FEQoFMK/Pj+9vuhvOufweZCN+fPzKU/jaul/GrbfeL95pHs9P +hhf+v6muPjqexFflMC5J5yFH/5yc7w+dSrmzpmOHbfbAW1jv4uHHngDpe7Z+O2GP8Q+x56PGSnx dmM+fPLuq+hY6xt44JF3Mf2FD/HVjnVx11Pv49lPu/G5L30d9917twA7jk+nTMP22+2Dn/9yW8zu nYe5nvnY8tc74trLb0EqkcS0adPwgx9siH8ecRJm+cP4pKsf2267H3bbbk9EF7yHa84/UY7fF3Hu jS9jkuzyG10hFb5Ix/i6tQWxlZXVYhpZEBf8s3DVxSfjlzvtjql82SEYQzLAgXyiOObUc7HW13+J VyfNQqJvHi789+H4y/4Hosen46reWBanXnEHNvr1Hpjz5kz84Av/g+vveRSL0vKT37MArz7zPMas +VM89OB7KM77GL//xf9h7+MuxlTxeIPBbkx++XGs9cXv4+HHPsYnT7+D763zHdz33KeYEQFC8bRs iwce70L1jb7zzrkR//u9jTF90UwslLpb/WYnXHPBdch7F+C26y7HZ769CV6Zl8WsaF49wPvw2bfw rfZx+PC1h3HxpWdhwlc3weSFwIwg0BXNIJEtoN/jU4CtPi5usyC2smpKLRnEq3rQH4I475uOay49 FS3j1kHLGl+Vn/xtGNvSgtbOMfj1jnvi/hc+gjdaQrJnNrbd8PtoaV1Dfvp/QbZnvApPtHR8Hl/+ 5s/wzsMv4RtjPo+n356CuYkUkrFuLJwxDV9c7zd45umZyM36GLts8kPsfMQZ+DAG8WQ9mPL2S1jr 8z/EnfdMxuyXp+Ib476IWx58Cd05YG5vAHffcx/uuecuHHn4MRjb/gV8eb3vYZZnIbqCPfjFBr/G HZffBPjm4toLTsd3ttgXrwtkZ4u3zS50/nenYIuvfAVPPXQDTr/oLHz2hzvjjfnAAkI+W0SfeM7h mIbsUDYIxGIWxFZWTapqEBMIqwLEsZCA2DsFl19yKn6wywF4JwrVI+L1Rx/El7/0RZx81oWY7s2g n70feuZgy1/8CAceexqm+YqqF0MwnEdvEqqr2aznX8H/jFsLT7zxKWYJ4KLx+Zg3/X187Rvb4NEH piA/vwvb/PyH2O+ks/GReK3xSD8+eu1VfPYLG+K++z7CJ89+gO+s9QXc98STeHvOfHxz/c2xxTZ7 4LZbHsLj9z+H80+/BN///k/xQXcXpnn7seVm2+HWC6+Qlc/GNeeehm9vsi/e9APz6W3LL4f+SZ/i V1/7Op55/BacfdXFmPB/O+D1BUCPbK9Xts8XTCAaZT/l2sfGWG0Q22EwrayaTsMJYkRn4azTj8EG fz4Ok+PiYPrFZQx78PyjD+Mzn18Xh516MRbFBbzBfvzn+KPw0023xvxQCfMXxmRbilgUKSIUz6J7 0pv4ybrr4gaB5vxkEZHYPLz+4qPoGPv/8MRjs5CY141f/eyH+OtJp2JWKicg9uLNZ59HW+f/4f77 PsHMN6bjq+Mm4N7H78eV4gV/7n83wJy+ApKyTZH+DM448Ux8/RvfwcceD2aFogrEN513qWxwF+66 4Tp85pub4NXZecyNDah+yu8+9Sa+3jEBb7/yEM665Ex89vvbYXIvMCsM9MYLCLJLXFAPNlTr2Biz ILayakqNXGiCIM70fYiJ11yA/9n+73gtIAzODCAb8mAg1IfLzjsHLWPWxY2Pvw5fJIL333kT6637 JZx5xgUCO2BKVxR7HnAs9t3/ICQXzcVZxx2DH2y0DV7+ZCbmz3sP++21Izon/D/cdc8HKAZiOPeU E/HNDTbBC5/ORFfXTOz3xz+ic9z38PCDn2C6gPgrE9bCfY8/hPMn3oA1vvp9PPbc++jpTeO+u57E 5yZ8Ed/9vx/iw4W9mC/7v9mGW+Li085HIhTCtClT8b3v/hwHHXwSZnnC+GheH7bedn/ssfOfEen+ FJdfcCK+8M2f471u4GPx5Ok1xyJJZAIhNWhQrWNjzIYmrKyaUksG8XB0X0t5Z+Kyi87Ehrv8Ax+I t9gdyaK3pws5fx/CvT3Ycqd98b1Nt8ekT6eqvr/PPvIo1v/++rI966Clc12ccNqlmDV3IeKeRQj2 LsLhJwu829fEup8bgzNOPg6fWXcD3PfIR4j1h7Fo5gzsf/CxKv/z634G115zFb72rc3w0IPv4/2X P8LnxkzAg089jnnBAI459Ty0tMo6xA7+x79w0TlXYK21voinJ32I7lgWt950NzpbxuDXW/9WHZfZ H8/CwX87BC1t49Ay4fM49j/XYPosH5L+Bbjt2gvx2S99FzPkB8CUFDBDvOxwIC7b5FejvtU6Nsbs wzorq6bUyIGYPSOCwV5kshydrIBF4QH52V6C/HJXvSeCnoB44UmBUVK90cYhKznWRDJZxMLeKKQJ 9PlS6oWLRDyEWCKM+f6EGoMi1L8Ak199GeM+90O8/oEXIW8EUX9YvZjB15EjSVl3NIIebxF+AWSs P41SuoRoKou+RBJz+4MIpQFvkG8AZhH0JeGTdakbRTijQJqOZVQf4l6+uszxkD0JRBJpLPIF0e3L qVebo9Eo+tlfWOa7AgUsEIh3J7OIx4uIhpYzRmxBbGXVLBo5ELOdcDyBRX29apAcvkLsTQqwQhxc J4lEModELC4A9Mj6YgLGAhZ6BJ6eKGICW47/wLEgCOtpc6fhez/9IY4/7Xz0emPwdy/E4f84GOtv ujOmdufUq8YhfwyxSEmN+9AX8Knv0Umz8AeAeDAPX38I3QL/QCqDSLakYr39UoDbGpU6kTDHtcjD I2DOpIuyXQE1eFA4VUBU2u3vlfaj4unLDYP7wvEwusQT55gZHo7iFsvBF4+hRzxun0DYF8jaV5yt rKxqaSRBLN5sigOpC2T5Ekc8rQbx4WeT6CFz9DS/uKt8uYOgjgn82OOAg+wQYGpUNPFU1bi/6Tie ffNVbL71Dhg79rMY396JA/56EN74aAEWsbtakX2HpawvC09fHMniAHpCYfF4xasN5BD060F+OMYE R1frFa82lJAbRZojqMXR2y/z7NUhbQUiBYF3BD5/UIGYI7/RMw9JejCgvxKdzIqH7w3Dn5R9Ee+3 2ycefSiKeDKCQMgvbQj4Bd4WxFZWVjU0siDmgDpskxDuC8YRiJXEeywIcDl+MAfkEXglpJw/qgbg YXjCG0+qkdU4RGVI4BoTz3lh0A9POqF6UBC4fm9IhTGCaWC+L4NFHGSHIQV/TvWEWOgVrzSRVKGB WKyAPk9CdYcjID3szcBxiqNhgWxYgTgcF6D6CggEB9RXNsJx2aZYTOX5OPQlR4OTGwPX6fUE1Shs 3CeOrbwwJDcYOV5sU38YlW/Wyb5JngWxlZVVDY0ciAlB8206fg6pV366E0xcZj5BrD5npIayTKjP DzGuTBjrdA70riHVH48r47L+zJJsK9sQuCovW9pn+XCQxrocBJ7t6e54/HKG+UCpalMA7I8G5YZA +OthLv2hAQF/UdqX7ZR6DG3osYilPR4bOS7q5sBP6xOcYnofZDt4AxFTQOU2Ovnu41HLLIitrJpS IwtiDU1+YUN/V47AIaQMhDVAM+VvwBFGejB21tEDv3N7zKeKTJusr8b6dT53xHbYPiFKUKp8glF9 ZVnaVCCmt1tU26NAHPMrr7gCYoFwUH9zTn/lQ0yth1DXA8RzXfyqB8dA1uNI8EGk/hKI/oIH95Gg Zh9i+xVnKyurmho5ENP7pZdKIzzZp5ZwIuB6Y3n0cjB15gmEIqGwir0SZPyMkvEyzWePDAiVNytW BrVAUYPegJum129AzI940mv2hqBArEBLAMf0mBfcX/XpJoGxBjnr63Vz29hWbyyjvuJsyqhv4MmN g2V4g+Dnl/glaW6P9pgtiK2srJaokQMxPVbGUAkvfriT4ApFgsp77IkVxQYcsKXKICbImKZCAozj GhBzWaziYWtT0BMz+QbUav3cHwGuG8Q69CA3iJjcEJzR0VieNwTtseuwAo8BzYQYCGKGVgaDWLaP bct2KhBLffPxUAtiKyurITSyIDYfCTUeccCJy6qYsXjEBCS9YIKLoI4ECVsBuICPpmBKj7UMYg1e ts2QgQGv8pjFCDQT+iiDmDBnfNgFYg/jv+zexu1SMWWCWIckCESuk21U9kUbvfyy1yt1CVsFY6nL m04/vXzCWrbBfIrffUyqzYLYyqopNXIgdocmdFxWg5hwJFQJrt4o4AkPKKjRw4wH4gKwhAZ1LO+0 ZUBsIMiHaRqM2vslhHVMlwA0ICaYlefLWK8D4nBAg9g8/OOLGpEAt5FwJrg1WHX7GvZmPYNMtkHH ghnXlnU43j+32e1Zc1o+HjXMgtjKqik1siCmt6vivgJSApHfsaPRWyVs2QeYMGZvB37yPh7UIQoT Q1YeqECqP6ZjsPzpTxBrwGlvU3vDDDXQw9UgV+EMky7zBHEgqEFMiPbG9cM/QjjmgJhgZtxYe9FV IFY3AIKXoJdjpPaNHrTeBhPaUDcMaVfdeHjDUGWqjovLLIitrJpSSwbxsg36Q/AM9vQIqgqYKuk0 A6MKiPULEWyDYGWcmC94mLhrLMS4bVR5l/yZz7qDQSwQVlDU8OK6B4OYIQE3iAWu3BYVu9W9IghJ DWLxwgXC2iNmOwQxH+Jpj5jrVhB39sOAWIcu3KA2nr9TXvbTbGetY+K2QSAWsyC2smpSVYOYQDAg 7hUvNej81I4msujnhz29ATX+A8fcDSZy6JFpIF5Ub7HxdV++OtzjDSKRLpWBo2CoAK7NpNGLNKEL HXPV+RpuFYhp4Mk8wSZWfSMgAM0NwuRV0t31dJumPeW5mjSnDW2V9pWpcqbt2vmVZcnn8qC02lYb xHYYTCurptNQII5l9cA4wUga/b4w4ulcJYQR4htwSYGweK/iLfJNMl80q+DMgXwW9ngHQcfa4mZB bGXVlFq+0ER3fwRhgjWRhicYVa8iRyW9LxRRaSHxaHv6YipsQPMEkgjH8upV5GhKP1SztmSzoQkr q6bUkkFc62EdB8nhT/hufwiRZAapuMDVFwEHw2EMVg2kE8rBI+D1pYsIxYqYv9CHaCKvwhNu6Fhb 3OzDOiurptTygZhxWo4yFssVxdsNq14JAX9EQblHlhlfjfI7bfEC5vSGEEyUkMpChTIYU3ZDx9ri ZkFsZdWUWj4Qc1zghR7xhsXb7Q9E0L2wB7lcQXnIHJWMD9g4FjB7OQRzHMg9jnAsiz5vRLXjho61 xc2C2MqqKbV8IPb4Y+L95vUrvOEY8rE05s+ciz0OOAgtHeOx5ti1ceN1t6ErmsXCRF7Hh/0JXSeg B123tmSzILayakotH4jp3fb6IuiJJRFMigfcE8Deu+6NM664Al0C5vff/hgb/WwLPPHme5gvUOHD u1g4o+rQi3ZDx9riZkFs1RQaGBhQ01JJw8csUy0tLWhvb1fTzs7OQVN33qqwjg5eYC1oayP0dFpr a2t5vn7WJtvB/exQIPD4I2rAc/aU8IYSKtTAHhDhbA7dHj+mfDADu+2yN+Z7e9EfjSAeA96ZPBPd AnFPOiflkwiH8+rrG+xlUQ0ea4PNgtiqKbQ0ELvBOG7cuPL8GmusUZ5fGSPMDYTd7U+YMKE8X1/j /rdhnc9+EYv6vOIBpwWiKcxb5EGU32pLlhSIuzw+JLIFvPnau9hh+13QGwoKiGPw+9OIxoGuYBy+ TF59q41fwiCIGVOuBo+1wWZBbNUUWhqIaUa5XM6ZAzKZjDO3cioWi8q43kKh4KTqdRPQI68lhyai DD1ECYiEgjA94lA0o6a9Agu+vPH+25Ox5667YfrCfvTF8wgHY5g86QM88tJkzAmkEInnEAzE1OeI +GJHNXisDTYLYqum0NJAzPAAZfIpd5mVlYG7u03Oc930xkdetUHc3jEO/MhnMJJUHjHhS0BwSqhG slDhimC/F/vt8yf857xLVJe1mTPmYscddsUdj70Iv9xn+vxRJPnBUKeuAY612mZBbNUUWhqI3R5x Niu0ccRyxpNdGaO47nw+r+bNOsaMGaPWXavO8Br3qbJflPGIIwmBQiiuYrvqA5t8SSOUVnAN8EEe v8YcTGLWrIXY/8AD0dLagfaxn8OV196hvrzc5efnhwpSTnvCNka8dLMgtmoKGdgsCcSM4RK41TLg XFml02k1Ne2Z7eC6GyE0wc1pb+cDyg4FWo4nwXEiFITDSfVCB+cJiXgiA28gqcIPHp8XyWwOvkgB fSGONZFANCvz4Qw8YQ4OFNOf0q8Cj7XBZkFs1RRaGoiNV0q5Y7i14LyiMm2ZMAW3hSERExYZWQ0G MWU84hC7qEWSypM1gCBgGWLgqGO+YAwRgTTHpOBbcz39IfSItxxJD2CRP6HH4+Vn8AXcqq7PesRL Mwtiq6bQ0kBcDcNVCWDKeMIG8qZ9cxMYedUGcWvbGPR7AiBgvSH9sI2QUENFEhbi6dIT7vcHFDA4 BGY4XpA8PQJbXzANTyiHcKqgxpigF80HfdXgsTbYBoFYzILYarXUsnjERkOVXRnVaqd+IF5cxiOu NQzm4sYHcDUewgmol2X8XWuDrTaI7TCYVquZLIiXruUDsbVVaRbEVk0hC+Jqcd/0/hlVg9j9irO1 4TUbmrBqCjUSiIda98hpySCuNdaEteG1QSC2D+usVlcNBVcLYi0L4vqZBbFVU2gouI40iN2yILZG syC2agpZEFfLgriRzILYqilkQVwtC+JGMgtiq6bQSIA4mUyqqbu8e/S26pdE+NqzGWuCWtIbfdXb 4W7f5C2/WG9wXQvi+pkFsVVTaCi4rgoQm9eWDXjdAHbDkm2xbPWbdW7wVr99R7EN93Zx0CAuu9te PrHe4LoWxPUzC2KrptBQcF0VIKbc4xhTph6n1XmpVArz5s0rr3vmzJmYPn36YoMMuUeCY57xuikD 7Oq2l00WxI1kFsRWTaGh4LoqQGzKukFaDdVoNIqXX34Z++23X/lrHa2treqzTGaZdsABB+Ddd99F OBx2albCHtSKgbdaFsSNZBbEVk2h4QYxwwjugX3c8V7qqaeewkYbbaTWs8cee+CWW27B3Llzy59o okc8Y8YM3HHHHdhpp51U2lZbbYW33nqrvH53yMKsa8WhbEHcSGZBbNUUGm4QU7XKJxIJ7L///qr9 E088UcHXiGAdO3Zsed0Grqw/efJk/O53v1N5559/vgplML06VOGeLp8siBvJLIitmkJDwXVVgZhi WRohGwqFcPjhh6vww/PPP19uxw1Trpc9J7guGsuYh3Qsd/XVV6syBx54YLle9SDzy7N9FVkQN5JZ EDebBl2z5mJ0W1UREZeNKQ1KqNQbUuWyWuXq5fpLaUMXdtXTGry85LYMrFYOxIu3a2TKEqKcZ8jg n//8p2r37bffVnlMd3uvBOuaa66pypj6lAlBmLQ33nhDlaFn7IY4tWLeMMW2B++PAbEd9GfkbRCI xSyIV1eRJcrMBUgrSJK2XCGtpoVSHnmVpotnsnnQP8tJeTVnqjKxIP8MEARipQqs8sWcqsskDRMx rneAgCkJaHK6upTS62ecU6Ylnc9vqbGBgSLrSJIy3Q5LsG6pmEcqGVfzeeardUiubD/byuUyat3M 0h6m1M0TYrqdomyDrlNEe1uLMs4PyhMbVKek50vu7XRUhrVMCrk87rrjTrS3tuGN11+VRA3gasBT BCw9ZspA1YCY5Y3dddddquwLL7xQ9phXtapBTCBYEI+M1QaxHQZz9RMZYMwBi0ZhxQoCmqJMU/k0 ssUCigI/Fs/LtCDlE7kUK6OUFRCYJhRcxZx207m40554fDmVKMkyLYmnmKtAjbCXNag5llfpBBvL spqZinIZqSdwFyoK+wfk5lABUaYgP+VlquBJCHN7eHNwIMkmaBpyet2EuHu+lTCkV1qVbubzAmMN X2c7xTKZFLxer8xXAEpg5rM59Pf2oaOtHaefelr55mJEj9YAmXHfcePGKcDW6t5mxPKE86GHHopf /vKX5bIEuhvqKysL4vqZBXGzSPOjQiYlkyhgyaXl36LAV0O0XERmCgUBbJoeM0tofFL5rECGszJR Hp/MDCCLXFEgYhoRyxPI/N/hJ73VYomgEShx3eJ1s62BnDTGMpzK/1yvaUatREFWvF0BM4sRcZxW ymhVPFoBWlogynU78OPUzBvPkt3HaJRJc5czU+59Xm5QXKIRXK+//qbO06tT+u9/T8OGG27odD9j RgnxeFzlGZkQg+k1Qbmh6gazWf+nn36qyj722GOLgXv5pbfLLRuaqJ/Z0ESziNcyrztDkUHSwCuI 16qm4n0RglTBgaiuKyASGKWVPyt54p2qdM0u5Aayks7/tIfIenm+YOY0kRXAcqqVRjEb0XlMpLEt QpiNy3JCgGtgWyoKuKR9qaQKMp1Np/LEo7Qt/6hylRUoyS6ppmnZfE6ti/NF2XZClWppZYy4TaVz v3kcKG5tLlcBr4Ew4c5pS2s71v/JzzFp0juyxIdoGq5s6+KLL1bzbKV8B3JUHZpgzwlzAyCgTT6n BsLG6z7++OMV5CkTwjB1l09cR2U7KANi+7Bu5M0+rGsWGZoYqxKvfWPlMuZa5XWeyyKfiqtoLgHI 5/ZMHhC4MWzAn+4ZMaKIZZJOGIPEZMSAIQQFT/7DtrNJqSdetOSRe4qJXDk9R4EOf+Kr8mIJMogF s/QwucCN0uvn+mgsq7ZHjDBOy4rYrjJZpuXkH+azHJc5zeUHsMZn1sFaa39Ots25EYmZcgyDc5lx aC4z3bQ3Zuwa+OjjafjJ+j/HO+9+qPJefPFldQF1d3eXwwsGou4HbSbN7RFTBG/1wzo3uI1X3Nvb q5bdecsn1htc14K4fmZB3CwiJdxWJXqCBsK5jEBC5t985Q18+2vfQZixUBVKyOO8C67BKWddKvCj V+pAUXmQWbz38bvY4y9/h19I/MLb74NfAlYUE8tKMQNpshuFBJLdC/DrjXZGICDLkj+QkhIeP360 7pfR1tKKlraxaGlfG9vvujfyMS9OOeafaG0XWLS2YY0xbTjzjNPgE1JHpbo/lsPd9zyAhx95Ao88 /gwefORp3P/Qk3jowceU3XnvA7jvoUeV3XXfg3jw0Sdw9/0P4d4HH8GvttpWGeeZxjyWMeVZ9457 7sf9Dz+G+x94VNmDDz0uF0onItEUpkydhf/3w5/ilVffxJ133Iv2dh3moAxwKbfnSpC2tso+ClTb 29vVlG/XGcBSBLLxiCmGI3p6elQY5YknnnBSV1T8Y9MqsiCun1kQW2nJ9V5S7p8Yr335Sc7r9CAB 68fvTUa+EEA04sdmG+6KqR/3I4mwgDWItHi6qkMDEpg2fTJ+u8ee+NSTwo+3+gt6CNh4QtpMKm9S 5pAkmNl+thfpnunYcZt9sGihJDFdmJWa2YOdf745ErG0rEOqs6gY8kGcfOQBePaNd5SXnOyfjQP2 3gXX3v8c/LL86ayF2HPPP+La6ybiupvuwO33PYGJt96HW2+5E3fddQ9uu+te3HKntom33YXb7r5f yt2GO+97CHfd/7AyzjONeSxjyt9613244+4HcP3E23DrHffjrnsfkfk78NCjz8DrjSoYT502Gz/b 4Jf4+4EH44C/H+Q8VMwPCvdQBqzsY2y8YRq7sX3nO99RsGbZWp6uSWM9xonNwEIrFi9mW4PXYUFc P7MgtlJSPRN4YZITJKt4ciW50B+/735cdO6ZkpjAa6+/hK222BexiHh0oTn43W4boqOzBbvsvCMW zJ2CabOnYJt9/oyTr7lHvNYfYLsdD8f7zz2F736uA21jxuOAo09BRFajHOiCF/neGdji5zsgHpNl pjHe0RXE3ptuA29/QIGYWQnGAfI+/PeYv+PRlycpoKMYxDsvPIy9jjgN9CFndXlw6MGHqJBEjzcM b7QATziLsAAl4Auqk7s/EEEkmYUnGIU3FEMonkavL6TSaZxnGvNYhmWZTiCFohllvmBCnPYYoom8 XDRyEfkFWGKEMcMUP//Fxvjr3zSIeSgZZ1bmQNR4xVy+7LLLFISNR/z444+rPCMDbU7dYGbZhx56 SM27Pe7lE9urtElZENfPLIibSubCc08rph+IybzTOwHZNPoXzMPuO2yPRNiLBx54AOddfjvCcu2f fe5ZOOvUw4DMPNx09Wn4i3iCL3+yAJvvdwA+CuTwiy0ORN8C4PQj/onTjt5PPOGk8m7pwxXIjnwE mYVzsPXGe8PPXmAKxHkMdPViwy+vB3Yna+kYi5Zx6+KQY08SV7kPZxz/Tzz+6jsK0BAPfe6Hr2G7 /Y9GtyxOm9uDQ/55MBIKtHH0BgWa0TwicmJHQlH4wxquBC2nNIKmzx8uL3OeaWbZlPWF2ZUrpQAc jKQVkPu8EZUWjWbh88UQCMbw+BPP4sc/2QCHHnZUGcQ0dgOsfqBGL5Y9KYxHvMEGG6iYcnU5N2jN PMs/8sgjap6AdtdxA9vEpN3hjYrM370iC+L6mQVx08hceEsy/nR2AFwUXKqnaHmkQn4cfdg/8f7k Sepn9/OTPlIgPPyIgzHpZfHKBuZj0cxXsMtef8WLn/Zj878chLe6Q/jl5n9FMgB4pn2EPbffEC3t LdhBvOVun/yMJheyEeR6u7Dt5n+E3yerJGNk1dGp07HLhr9EIhZHQsqVQxOlGI79x5/KoQkUI/hk 0svY+W9HwyOLDE1suOFGahuPOPbfOOK4U3HIESfgsEOPwhFHHIWj/nUCjvzXiTjo0CNx2NHH4dgT T8HBRxyDE045DXvv9zdlnGca81iGZVmHdugRx+KIo48XOxFHyY3h8KNOkLTjFIjDkSSeefYlbLrZ r3GslN1u+9+XIUxvWE0dQHJKM6OtMcxgYsVMo3dsyhmAEtpumBoQm3AH5Z43oYraADYyf/eKLIjr ZxbETSMXbMV0n9/KctkG5KIvpGUqZFTdxdK4987bsPte+2LLbXdGNMW35go45+xjcf6Zh4sX24sb Lj8PB/7zaLzwznRstd+B+ES80Z/9Zj/09AoQ8oLtfBCZXBa/3n5XPP7sm5pQhaA4ubOw3W/+gP5+ STCb1x/Dzhv9WrzkgAIwoZ+U7GLSh9OOPwxvvv0WssUSgp4eHHH4objtkecVrImeGTPnYv6Cbkyf NV+sC7Pn9WD6tNmYM3sBPp0+C/MW9mDm3AWYNa8L02fPU9P3PvoULa1y0otx3p3HsqzDulNnzlHL M6XtufMWqZhwR+cE2Ucfnn3uZfxiw00lfSEefuhxjB07XrxbHb9d0gDxhKkJSdDMix2Epzt84faI uTx7tqxXgP3mm7r/cnU+67uhTFV72VoWxI1kFsRNo2oQ01fjvE4fAF/IIHx5YWsbyCUUjLsWzMG6 6/0Pzr7oGvWTu5iTn+3+mdh9180xoaMFe/5hJynTi/enzMPv//wPLBL2/O5Ph2KHXfbFPdddjbUV dDpx0CHHIhx3egIMROBfOA3f+vr/yQm3tth4rDP+s/jgudfx/77ybbS1CKQISKn3Pz/6IeLhPhx9 yF/Q7oBr/PjxuPzq61RYmRZN8UUTh/Eywyn/yWb0wzKa6oImu8tyLGPKt7R3oLVtTHnZdHNzl6cl s/rVbXZ547Sjczyee/4V9ZCup9er0ubOna8uII4PYQbnIRgNDI2XaoBJj5i9IIwXayDqfgDnBvLE iROVB82HfbU8XzPP9bkhvbj4d6dVZEFcP7MgbhqZC08bL1cNY2c6QGDxwiUINIgLWT4qy6rYcUEK akSwviznghgo8oUM+qMCbeEMGUA00IOlH6he+1AkK6nxF/S6dDnlbQv0c1mBmizzBQshjlBV4CUA YXmii+vUbzSzLcdTl21I5YpqXXzfJOWUVW9es21R2ftk2zLLdCfL2WupW+AXL9Jo62hXN4pEKimr dsBdVT6b0698u2O/vFB+uv4v0NvbL1DUR4fdADfZZDP8+9//VsuVV6WZp8u4AWo8YiOmuV9vdov1 /vjHP6p48sYbb6y+8GH285JLLkFXV5eap9xwri3Wc46RIwvi+pkFcZPKwKRs6sLVF2fBxIgdIBOC fMDGEoRJKq0BXbYBAYuinUxYTgryVWiCXXll6nqXdtUAOlrlgXPkX5oqxDc/mK7i1PQCpRUCnrls uJhDLhVXL3sQvAyTcMr8PN+Ic0DH8R30a846j5vmFscIdqsahlR1GYo3LL5dp97Qk+Vj/3U85syZ pzNF6mYieuyxJ1R7DCNwv3LZdBmMZhuN6A0zRFEdVjBv2BmvltNXX31VtXvfffept+s222wz9PX1 4corr1Rv53Gweap8ExKxPfdyRUwbnG5BXD+zIG5SEQu1jOLoaCXC1YCY86qjrwYn4UcflC90mDq6 jJTNS7lMUZxXDRDW4shtegUlpFMEHF9LLiGRTUoyPU2uS7dfZH2zEpmq14ZVXVlbOqVnxShChsVo CioK4Dnk1Vt9ujeBeS2Z8xytTZWrMjPoT608NcKb3AQ48I/ZRhrTDFzZNqV6KUhSMp7Ar7f4FXbd 5Q/IpBnlZp3BMj0aat0E3OI6CNL+/n5sueWW+Nvf/qbSPR6P8oy/9rWvKZizjb322kuVNfA121Vb Zh8rsiCun40eEJurz0xXVKzvtEEPp6xyWnl2UNrqJrOfbqNXWRGhKwBSUNNALuU48I/AMacjyoQp l7WkTEk8aeW5SjsOs+KFrAYxYwPKNdWmASoeX4lxVEKtCDXspSOGOlTfZrVxsiCQpadrxgXK5xj8 KJVHX1PtcoQ2dcNgHFpuBgIitV/Kq3Stm94y25R5etptrS3KymEE1i0PHOSqVzUMpp4f7MnypRje TD756GMF93PPOUuVWxIUCVDGfMv1XQA1IYxYLIaDDz5YlSWAuT7a6aefPqj3Bafz589XdShTv/a6 zX5VZEBsB/0ZeRsEYrHGBvFQthRp6Io5Ey7Tp1NifeecJBzU6GJOGic8jZdhFauhnIM1yPSxMFaR k6/6IcuskzmonKtCJb3S7tDSZQa1Jxq8bNpavD3jvRJ0lFmmCDCa0ZLLLt6uW+6xJAi/22+/XbV7 7bXXKiiyHaabdplmvFl3uhHLswy9YIKWoQkj98sgBLmZv/XWWwdtf2Xbl65qEBMIFsQjY7VB3IjD YPJ8GsqWokEglvIaxLLAuk4WxXF3lf/gpHPSvCBefeSGE+UGFCFGMxqq7JJkYrmmjvFwzaeOCFN6 s9WqXrcRwczv2/GDowSt6a7G9vmRUdYhnI0nzF4knO68885qe7l+Tpdl240siOtnTQNiLV4k2srV qtqoTi8vW41qDQXXahgOVXZJMiA2ZTk18/xUkvmC8xVXXIEFCxaUyzON4QWWNX2OP/jgA5x00kkq b9NNN1XLRsZzpqdMOP/3v/8t90E2bTGeTJn1m5vCYJlroSIbmqifNU1ooqLFT8DFl61WNxkoDReI KVPOhCHc9X0+nwpRmDDC5ptvjiOOOEJ9OJTLHGeCX3lef/311TKnHGHN9EWm3KEPI66LPTwIe37T jnVvu+02lZdMqpfBlxvE9mHdyNvoelg3lFlZDaGh4Ep40YyGKrs0EYxGpr5bhOlLL72E//znP9hz zz3L66YdcMABuOmmm3D22WereK87JnzhhRfizjvvLG+LgayRWRf7IHMsZKNa8NZi+cHbZ0FcP2ta EOtqi18o5RO03O7iJ6zV6NNwg9h4nSxLYwiBYhsMQ3CZ6Vx2e6hcLx/YUQbi/MTSX//6VxVmeOed d3DVVVep+T/84Q8q38i0Y7bTLJspQx1L3vbFz2sL4vrZ6AHxSorQVackzz2Z0Q/rnAuCGc75Wn67 rHye8h+WG3zSWo0uGSANF4gpjqZmytITNfClDJgpNyi5XoYrTAjCrJPw/sc//lHON+NS0Nut9nLN OtzeOOsPvd1cz+Bz2oK4ftYUIObpyB4S6rTkuSczXObX1ZSY4ZyT/CobXzJQy+ra4YwF8WiXgdJw gdjAkZA1oGU9Y5RJp0zb9HQJWsqkUQQpX1s23duMMTxBsU13eSP3OqglbzvrDq5vQVw/G1Ugdj+4 MHKf6EsSc8td0Dgj5x9P10g2oesyQ52XRLDTrY0vN0hZvhiQ54sCVqNa5hwZLhAvi2q1Y9ZdDVX2 rjB5xthVjd3TKLe3XQvISxfrDK5nQVw/GzUgNj/t6HnwBKSZ+aWJJXRtkQNiopWmPg/EtpmW4Vtg 8pOxJDjOyJzzpherrJpL0apeqoaW+7wxoDMaquzKqFY7Zt0mjx4tR1Y755xzlLdsAMzQhOkr7O6e Zmz5xX3T+2dkQVw/GzUgNmMGGHMvJ9O1R6tyi0xVHrV6vbWAWCqtAxNsoJBV4xhQ/MilTpcZZ7Qt C+LRLwOrRgWxO+5ryhHI7733Hs4880xVxnR149tzFMuZ/sjLL+6b3j8jC+L62agBMU9Nt6khDAWe HJpQn7bLohKK2RQG8rrjPIc/0Bdb5aRMZvVAMnzwQS+c8wTzsq/DqhE1FFwNDI2GKrsyMu0sad1c nxusPAfdMV++wHHuuefi97//vVo227diqpzzRhbE9bNRA+KseMAKiqVi5cu4znTpKNYA1gPCaCkY iyes5sXYdprhCOfkZEkuWQivHhoKro0AYjeA3fFfivMEsukJQUC7y1c/oFs2WRA3ko2eGLH8Qxjz 9DQAdtvQkhN1IItSVn/WnYZ8TM7DhOpCxNM4yYgF0wfSUiCDiCwzWKFG+1KjclmNZhmwNQKI3ape N9dJsJpnImbqlnv7auUvmyyIG8lGDYhbOFThmE6cc8H5SGTSuGHijbjxponlQbqXKJWZF+b6ZD6r hzLnuVsI4PRj9tfdg1rXROdaX8add92HQnwRrrviHNxwz7OISjEOs8j61Set1ejSUHBtBBCbdRkZ r9idbqBLUJv06nrLLtYbXNeCuH42akCczBURjMdxxL/+hXsffhBXX3sVbrjxGskS76Ggx6Yti+f7 oHNe8gTCHGOW4QZ1PeT6cNoRe+LVF19Qae98uhA/3XBjpPyzcPdNl+DSGx9AQKqpEEUhXfakdbPO SeysRzXnmJIkmPJKupJVHTUUXBsBxEbmpQwTbmAdbketbTHhiRWDMesMrmdAPOSgP+GMNpZR5soT C4TdZZhWu5y1wTYIxGINC+I5i3zqO2jsSczp9QLhm264XM7YCC47/1R0iMe83pe/gmeffgETr70Z l190JRbM7ca6X/02nnzpdTzw9IvY7x9HiFchlQXqKHhw9rF/xivPPKWA+c6MRfjPuecDqT7cfPnp uOXOe7EgkMRWO+6Elo52bLfrnzC314crrr0S5513GjzdXfjmul8RkL+EJ55/Fbsecjx8hr5yftPz ZmhDXTYlSVw117LVCmoouDYSiOupahATCBUQS5rA1RsuiuXhjcbhjUXhjWjoEsC0UEjmQzlJo0l5 lhOzMB7aaoO4AYfBPP+y6zDus1/GCWefh37xjC+74mLcdvPVePf1p7D1Zj9Bf+8szJk9HT/5wfp4 +N4nsdvv98HLL7yNzbfcFmdfeQ1OOP9KnHXFTRrEjPnm+nHqIXthjTF8dXQ8WtrWxG5//JNcfSHc dvXZuP66a3DmhRfj32eehWC+hItuuge77v8PvPv+JOyx6/Z46dmn8PtttsG5Z5yDk8+4AMdffju8 0rTz4Qd1syCI2atDJayaa9lqBWVBvHQtD4g9sbgYQSx5At2A5BHCBsSBkMA6klMQZjkL4qFt1ICY P9TC6RyuuOkWnH3pZbjquutx56034eVnHsK/jz1QnE6/lEjid9vtiBeefBub/ex3OPLQU3DNxBuw /2EHYvcDDsEDz7yhwgcl9qAQEF9w9J/xwksvKmgGg2nsu8+f8O7bz+OGa8/DbROvx9FHH4snXnoZ /NLZpDk92G6PP2P6Jx9i05/9CEcedagKjxx1yBHYf/+D8dDrUxCSciY8QR7zc+x8sKhAbFVXWRBX i/s2+LxcamhCgdgANlHxdOkRC3hDAuBQSHvGFsTLZ6MmNBFPZ9TLFpdPvBnnXHYFLrniatx6y014 67Wnsd02P5eTZz4mvfMyfvyjDbBofhibrL8d/vcbP8LUWVOwybab4Qvf/h5m9YU1KNmNLdqF0w7e Cy++/JICcTI5gL/u+xdM/fhNXHX5GZgokD3/3Atw4mlnICQsvejWe7DvPw5HUU6s3222Mb76rfUw Ze4MbPOr3+ALn10PM/rTCsRsK2e+3S7GrnUcYMiqvmokEA+17pET923weWlAvMSHdQQx4RphyKEC YnrDAblIQkExByR+ATaNZRjCsCAe2kbNw7q2jha0dnbgoCOPR28ojWuuvxnXXXulZMVw7jn/kgIt Asev4dVXJqknbBeeeQk23XAzZHJJ/PuM/+DHm28Jb6qkXuIA+xDnfDjr+IPRoS6ETrS0r41Lr7gW hUQ/brnmXNxxy81Y1OvDTrvtKXmd2HyX3VWMGPkSLjz5ZPz4Fz9GJJ/EOQLqbX/1WwSkSfayYDgi ywuN57i63ojiwSe81chrKLhaEGsNCWKBbdkUPAhWDQ0F4iDEBsogsSBePhs1ICZd2VUtLecOjT/4 mZZJCRzB/sF58hccOqJkepupC6mAtOQRkDFW4jWQS8s0JllhKSO1JE15smLISloxosedkPJsMyH0 VvVVgrSZz0p6QcpzQ6SyJItDDX4ong/pWEfFitX1VnI+F29VTw0F15EGsVujDsRleAiAFYQFHIwJ u0DMvAqIXSGMcl1r1TZ6QOyAjZAjAIndnPNJdRoHryTu9CsfAj+OKzEg8M7EJa2kQEtT2eqJnfiv A3FVvSiNsi5juuDn3eN+ydPv6zGNeQnz2XZenOJR08vN0rPm6qUMe3Ooh3MsI1KeN0UiD9gXQuot C+Jqcd/0/hkNBWLTO4KmYRFFKCymHs4VFYj9oQFVR3nBDF9EcmrZQnjpNnpA7DCXg7mLXyxT+p6S IOc2B/QxgM4SpHwBg0NXcoAfycmWcqo0vVZ1Kah/xH8tiVcs8+yOWQZnlnCW0rwIJY1gZWyaUxbJ Ztk++3Wy/7K0L3kU2+cmitOu25SJ/ko0TbbOtG9VF1kQV4v7pvfPaFlArHpHCCxCEb9YEKFgHqEA vWGCuCjlpCy9YFWnNnSsLW6jB8QkLZmmfOG0mioxTc5vZmcFfRrQ9IZlSo9VPFKe/sxP8dVRmSrq FnQggemqJWbIhVcqKpzKsjQsE9ZVdRxxXi9zxWqDlLhWMli3o+dV6IJlnPCHVf3UCCA2co+0xvVy iEuuY2SNb+7pt/doVGsru3J2wBeKlkEcjOlwhE9A0e+X5XAesXgG0bgHn075ANtsuQdmz4jB5y9K vazygn2STxj7405YI6QhY23JNupCExy6XX9Fg5DTabR0QYcmdF5K0gTGTrCYRVg9VxIflQuUeMwD 4ilHUxrGpaxkqCZzyBekvkNoFuesmpECnC8vu0BcHlB+EIhFLEOoO+Ws6iMDm3p7xKYt85GD6nWP nLhvev+MeOG3tY9VIIglc/CGYugPxGSagEc8Y58ANRQpIBiICnjnYf786dhio13RvQCIiV/TH0qh ny9yJIroCQYQTiYRjGTh8QlsBsWXrVXb6AExoSo/8XkaK4+UM8r0CUU4pov0iLksZXMxMTk7pAzh q3EseVI+lWTcWAOVqUoyk+bIP6wr/u1AVqZSPJsTL5mZCrqE7eL1VLa6AUiOs8wyejulHi/ocgWr emgouI4EiDm4FOUepIfzZvD3kRf3Te8fVSwOqAu/vWMcvMEIej1BcVJy8ATjCMWz4t2m0O2LqP7B 6VQe8VgX5s3+BBv9bCd0zYYApISu/iBicgn1CXT7wiH0+r0Ix/LiRRcsiJdioxvE6lySfxQgCWMi kzCUskX5+cfYrCgvk3w+ixLTGCYo6ABGrMBYrxSTBrMZfVLmOEJbTiwrZ5Ssg6tRl6GK8zqjvzlW 3g7CVrVIGOt0mq4neRbEdVe9QUxx/Ai2ZaZsf+zYseX119N0WKISIw7H0ujzhxUgGJYIJMQEyAxN BINhhIKzMGfG+/jdb/6C2VMEtHxglyxgUSCD7mAK0UIGnpB4xQJiv0/HlqvhY61iowjE8q9cDwTu IBCTiDLNFVOSnpZZeh6SyDxhYyqt4ak8XQI6x6nuksaS6horU9NcePxH5kv6O8+qN4WqL0syzzRi V4ceaKyXFNODAzFdbSPFPGXOslVdNBRcDYyMhiq7onLHhSm2abxkNxDrZUsDcW8ghv5QAj5fAsl4 AvlML2ZPfw+b/3w3dM8FfOy+liwJiFMIZQfQFw3CGwvD708iGNCvQFfDx1rFRheIRUQj48AKbKSd zGrqMZ0wpGXKoQVeQ+z+qwqW5MR34rW8LKJCVJXFf+Si42Dxubx+uKcH6inp8Yi5XAPENFVWgVaD mHmDQcx/9Dqt6qd6g9ioevxgM8rayIv7pvePGio0QU+YMeJgIifecBJh8XSjoTnomvUJNl1/J5kC fX0l+GIDyhue5w8hKr8+5/YuQixWQCQs3rIF8ZA2Sj1i0pdglUTOko/kpipEILJrWlqlkbt850J1 Fh4QUCY4ILzuasZ+vxleF8x32mdwI+94sANCYV4melmDWIFd0hYDsXqdIzkIxDrPZVZ1UyOA2Axb yfaMh9woIKZ44dd6WKc84WgW/pjuuubv70EmtgiL5kzDeuv8EJ0t30Vb29fQ0vEFTJo6G32JBBYG vQhn0ojHB2xoYhlsdIOYHirPY5pzTuXzHKIniU8/fAs//t4PsPYaX8P9dz8pFTPwds/AT3/6U7S0 TcB3N9gMc/uD0gor5/Hcw4/j+9/+Phb6gwrliq1iFaBKObkweU2yBmHLqXPJivEpODvQ6fTFQDzK VN5s9Y8+uDqNe0eTNEkw5VQxypmppOlylE5jW7o9JZVn0lzpq1j1BnF1m5QJTVDMH1lbcve1QHDx 7mv+WA4L+wJIi+eSiEcR8i9CIiJecwAIegC5bOCXS2+R1PUIiP3JBHqDYfgCHJHNhiaWZoNALNa4 IHZdC5WLWYzpYiV+SYPz4vnS6z3sb3/FOy+9hq6p87HlhhuiFJ6Lu269GMeddyl6pdwJ516Fa2+9 RSqEhCseHLbvn7HN5jvglsdeUcNZGm+XjrRZhzLXrLPoSMOpdl79tdh2qZkKFNwbzFneSGj6jmQe UvIXAvtws2ug7K9k8cZYDsWwkGPl+jwu0gavdZ3GB5r6oWa5PG+qZXP+po50Edd2rqAMbOrpETe6 eOETALWHwXSAwZHVxGNTb9WFpYwz5CWHwtRv0zkvdLAfMdsRAFsIL91qg7gBh8GsXLRaZrGcxBn2 U8vJhc8rnsHdbAkLPpyK/XbYDsXgVFx52X9w/6sfoF+yH3vjIxxy7BHCiEXomvUKdt92W0x641Ps ftBJkJu8GnGNWFAMoJVXNPpkjhMPS2U3nB0zCa79YzneVjhVvwQccBLE+q1GAbHzOiMhOQjEzrHi MiGt4+qDQaxNlxPayZRHOiuLnHJ9le0y7TiLKywL4qVrWUBsbXhs1IO4LEKYCbx2ePVmCnj1saex dks7rjr7DBQis3HiCQfioZfeVaC995VJOPa/J0p5L5685ypcc/kl6O6PYdPt9san3XEVnkixLbZJ Ngxa2egSN53Gw1LZDe6cmMmsZFSVJUgVcdVyVuoQyKoAj4uCNIdA0kmqWVVRw7UMVhGTaSxHeKti HERJfnboV9fpebOsmAJ0ZTWq7ErIgrhaznF2qRrE7lecrQ2vja7QhOt6qFpUC3n2/TUeMa9eWiyN 0489Bk89eCMuvvC/uOuR5xCW5HteeQN/P/oQqRTEYfvuCH6ctKV9AlrHfRmnX3C9epCnHqdwJTxf B61sdMkcKx6Wym44F6LJrGRUJTnlnGNQ9n7N8VUes351XJV3yumj5waxmG5QTTSIJU09TdUPRXVp pyzTOVFp5aorLAvianHf9P4ZGRDXHH3N2rDa6HlYx2thqOvB5RGnQ1Fs9KOfwjd/EZDM4vKzz8bj D96Ke++9GRdffoOC7IkXXYwrbr4B0ya/ih23+CXCyajqSfHCS+9gy613QTibR5Qj+DhtrjQJ6ihu Oq0CYtkhk2jmq2XyjDjLopKustjYIPo6xglDETJTfrCnPGqaLsMq5apOHpcJZ47PoXpvO+2zHf2i zsrJgrha+m/hlgVx/Wy1AXExLz9rHe+KP3envf8RPj9uTazTOR4XnnEmStk4uhbOwZqf+YJ4v2Mx /ktfwiezZ+DSs85QJpc+IoUC4vE8tvzN9nj1rckqjess6I7Io1bm0OnD51yA5QRn2S2VVwGk2ntT zJipW57n0co79fRLN/qoSQGnLWXlOLCRbpBNMFV73JV2CWIbIx4O6ePulgVx/Wz0gHhp4rViTA3e LhgwNOBygQCoAIKmLi/Vv9gp5qTxXXpO1RgVg8/VUSnui7FBF6BKqCzrfEqWOWjSgB4QSWGTmSwm B4pc0sdPcsrVWYrBBX2cy/WoMohN3JjAZro2Ttx/k4qZxtUKVkoWxNVa/LhaENfPVh8QCzVL/DyH voKFAnKSmXON85JGsGZyfDpfUmXpQbMoAUDlnbfqVCr/dzLoZI9mcZ+MOQdEzSkpL1UfB51PCShL HDAprTxUolOFFdQvDvlfCjKND9cqFXnz0pDlog4ziFS+1FPd3TSklXG9nMgSt4CmDrckMI3zOl68 amRBXC3u2+Dja0FcPxt1IK41ilUupy55Lblm1EM7XjtiAxzxR843vrFMjmgvS9IcaBvQ8C06VV7y 1U9jFpb/1QAtkk/xwuRFWT2CVqPLORTOfsi+K/g6coGYe6L2h2M5l0KyECu/gSgHSNJkSQqyRkyM eaUivVt2R2O3tjxy8suD7fCYJtkUG+YhVwMu5ZGUyuqvVZDaOT02R5LHWabpfE6V19uiY8WcXxWy IK4W903vn5EFcf1s1IDY/SqomecF4n5tVM9oi4TC5fmZ02dh9pwuzJnbhddffxVvvP4yeubMxaxp 0/HRrNna43POy6KASYFY6hUzej30omMxokfLvJ5qINzoF6pzGJTpEEHlWJpl7oke3Ej2vSToLfpx 6zUX4Ipb7kJQUvs83fjBd9dDZ2sLNvjFz/D2rHkKxuoIqK+iJJHLx/Gf/5yKPfc5AHy/MSDE3Xvv A/DmCy/LQYzhqUcfwrgvfAsvvPWJVMziP0f8Aw8++KA6/pM+noGdd99HnYDjx6+B2+6+HbEUv0Wo Ib2yGgquFsRaFsT1s1HlEfOCcI9iZS4UylwsHo8H7777Li6//HLsuuuuaJULrK2NO9WBtvZOtdwu Nq6tTc23MK9zLHb8/U649PwL8cYbryEQ8qu22ab7InR73u6bQaOLW2hMhR1qgJgQ1qklFOI+3Hz+ v/ClCS24+u6HFIhvf/ABnHXGcQLQXpx/znG4+sEnsUjqRNSfgDfDEBbN/gBbbLQZNtzsd5gWKKlu gldedj3uu/FGqZfG5RdfhF9suRtue/gVZONxbP3Ln2DutPfQ29+HDbbYBY+9+KHUKMDXPx877fwH vPjaW8p75nbpbV9xmb+TBbER961y/VAWxPWzUQViN3hTKfWDWXml9IqnT5+O888/X6DLk6lFjSlx xhln4LHHHsOHH3+EKTNmYsasmYgGQ4gFApgh3vCsObPx6cyZuP/hR3DBeedj419siPZWXf+cC87H 3PnzFAEYS04kOKhPBcBuuberEUWMlFGiBi/ScVyVppYHgzgf92DKC3fgjivPxDnX3wp+J/s/F16E V156VO5Gs/HKM7firyefh15Jp1dcGGDIIoin7roaV11wIc447ypc8/hk9eLM+5Pew2F//iNC/Qux /1/+hsuvux+HH38uZsxdhD/usQtK0YV49L478J+L7lBetBqzI+NX28JvDBLEqbwOnayMLIirxX0b fN5aENfPRg2Ia8GOF4jf78fJJ5+sAPyzn/0M1157Lfr7++UUE29WyuiHc/wJ7Zx4zkSn6XQ1aHyh iEImq0B9zTXXYP2NNxRvuQUnHn8CYibM4ciEQ4wa/ULl1pW3sBaIxaPlsYhnOF9CMd4vSYtw1zVn 4rI7H1Jjbxxxyql45YVHgOxsTHr+Hux2xOmYL+k6YCPYTHlw3P5/wLTJr+O5l9/E7kedh4VCUe/C BfjTjltj+uxZ+OeRx2HGR7MFwH/BfS9Mwh8P+odUDeLuqy7AhRMf5agfePOZR7A2wdi+Bg75z4UK xKvi6A4FVwtiLQvi+tmoAbGJx1IEIcMEAfFs1WhqchE9+uij5TguLxxeOvmiftjDB3Di80m6YDct oMno7lV8eYAf4lcgUU/2ZS6dR6E4oAa0vOne25WHvMnPN8TsmbOknOQ7HrGZDnpQ2KDSx4CSHRwC xHqPeBzkOObn49ZLT8YZ192hxuY46awz8fzjd0mhfrz2zMM44NSrlEfMV8FRyCIwezq+tdYYrNXe gvZOuaAnfAevfdqHYiKIP+60JY469Sw8/MKbKMlN7ddyPP9+0nk4/5b7pW4ET999Pc688Br9ULDI cSzSeODlt3CQgDjKJ4J641dKFsTV4r7p/TOyIK6fjarQhOkxwQvD6/Vi4403ViBmXJgiHHnJuC0l HjG9Xj00jaDGOf8IHf0WVx6ZbJRXnXh7YlKJUArlUuC4Ct5+Dzb6yc+w2SabqnW6hy7khWou1kaW ORZqx5cAYmeMJJEcmUSfJM3DQzedg8vvewKyhEcevReXn3m8/BHSOO20C3D+vS+pkEUxK8cjn8aF /z0PV114mRxUnxxPP844+xpcfMmt0mgIZ5/9b7R88Tt47t3ZUj+MM488CC1rfxtPfdij/g6enlnY epON8M5Lr6CUTKHPF8RhZ16IA04+W/WycDZ+pWRBXC3um94/Iwvi+tmoAjFF2PICOf7448sQprds LpqieLa8bAol3SeYxp4QeuhFgY6ORyjw0A8kiDknjZTPTcZL+UgwWRKI5wvw9/Zj419uhCOPPFJS 9QVqLs7RcpFWtpIgrtywzMO6QR7xQEIWenHrlWfg/Il3qIduC+ZOwTc/Nx5jWsbgS+v9AK/P8qp0 OUDIefqw7abbY9KbH0gCf5XEZP4jbLflTkgEu/HgI3fjB7/eCd0MAhdieOyWq7HOV76PGQH9uSpu k3f2FBz/97+gU07A9gmfw0W33A2v3Du5TeyCvLIaCq4WxFoGxMs36I+UVTZ4WQ2XKTa4rLUl2SAQ izUsiN0XA+PCvHDY9YkyF8zQck48pxlOtLnSXXkEk7OoZh5//HG1Trf3bTS6LlRnf8vSy9yDyv4S zpU363TwhWk09b9KU+kqpOMcPyXnxlZukC2Uf49IGvN0KIRpnKptcG4Ipn2WpZWbXYVyh7mo1tZW ZW5Vl2kG8cJvbRuDfk8A0UQWvmBMfypJIBGK5dHrjamvdPCzSUwLRJPKew6I8ZP7HES+V67NQCSK RKKASETK+iMKLNXgsTbYaoO4AYfBdHuhM2bMQGdnJ7q7u0fsglmwYAHGjRuHqVOnqmVuT3W82Kqx 5T5XzN+M55TxiM355f57NhOQjUccIWAjSXgD0TIgejxRxDMlxOXuqQZ/F/CG4mn1fbsejx/hhECX X/YIxxCOS74vLBCOIRLPIBStDR9rFRs1IOY/pg8xIdjT06PmefGM1AOzRYsWqSnXabxwC+HRo+re LhRB297erqwWdGvVWT2kfwkZ8XRub+9UF3+Q36oTkNLjDcXFMxYPOJwqoM8fRU9/QHm5sWRBykTV 154TaZkXL1oDPCsAp8cs88mMgDqFfr/1iJdmtUHcoDFidwiCABzpiySd5htkejvc28IbAeFsrXGN kOXUyP1ikPGIjdx57rqrl3GfKvtFlT3ihEAhFFceLkMThHGveL6RZFZ9PDSZyMEv3jJDF76gQFbm c5kivH1B9bl9XygNn7jOvQIWbySHUKyoPplUDR9rFRsE4kZ/WMcLwu2BGk/YnEjDqWqvm9vhhrHV 6JD7XDF/P3eM2P03HYnzqn7ifg4+f3nh83P6DC8wNBGM6RCE+v5cMoVeXxBx8Xj9AtxUQqaBiPKI Z87swhfXWg/jWtZCZ9t4/OhnG+HFyVPRGwe6/QKXuAXx0mzUgNh9gZh5XiiE80h6xslkctDNYPX9 6br6yd310H1jrfaI3XnuOquXaoOYAIgmTVw3gWiqgH4Bc380LlAWzzeRQaw/jHgoiahAuM/nx7z5 i7DVhtvBMycIT7cP519yBfY/8hR0RYFACugLCmQsiIe0UQNieizmghkzZoyajrTMuseOHas8KLM9 1kaHrbHGGuV5Png183wrk1Yrz11n9TbufxvW+ewXsajPqzxdesTzFnlUfDiYKaDb60XM34u034+t NtkR706ejlg6gqnTPsKOW+yGrg89KAh4L7nmetz4yPOYFS7CJ8temVoQD22jBsQ8WfhAxZw4HR0d I+6tmPW6t6E6zVpjmvvcYY8b99Q8rKuVZ/LN/OprbeJccD87FAj4QI69IsKJHPpDCXhk3h+NIh3q R6KvF9ts9gd89P48SevF7DlT8O3PfA/rtHwVHS2dGLP2Ojjz+ruxgN5wHOgJZC2Il2KjKka8uqtW TNJcKFYrJ3Ns3WEto+pjPFTZ1UdLDk1Uv1nHGHF/LIFgPI6JV1yOCXKsOlrWQGvLBHzr/76Gd997 G9tu8AcEZ+cQD4bx4luvY5Od/4JpfmC+Pw9vLG9BvBSzIG4gWRAPnyyIq7V8IO4Vb7jH5xOPOIzQ Qg923GZXfPLxTPT6ujF16qf43Sa7o/fTEGLBqID4TWz0+30xxeOEJiI5C+KlmAVxA8mCePhkQVyt 5QCxAMIjHnE0lVVDyHrnL8Lvt/kD3n77Y3gCfizsXoRvfv7bGNuyJtpbxuNr3/oBnnr7Q3QnB9Dl zaAvYEG8NLMgbiCZC34oSFitmIaCqwWx1lAg9sbS6PEGEAlFkYomEfDG9GvMiTT6PT5EfbIcSCMV Ew84mMFcbxh9yYJ40yUE47AgXopZEDeQzAU/FCSsVkxDwdWCWGtJICYg+JZcry+kxo8IBmKIxdNY 2NunurmFw2mEA3EkopIXTKo36QICYX+yhEXeuIDFxoiXZhbEDaRaF7wF8aqRBXG1lg/EfeIJc6wJ P9+aCxIWUYTjMiU4ONJaMAavgJr1OEYFwdvjj6u37AxkrC3ZLIgbSBbEwycL4motH4jVa8tiHHnN F0uKdxxR+SGZ94XCqs8xl1O5onjEIQVmDvqTygJ9XpZdHD7WKmZB3ECyIB4+WRBXa8kgrjUesQEx IUyjx8thL33iKQdiHC4zqmDMODJBHk/ocSn6vCE1ApsbOtYWt0EgFrMgrqMsiIdPFsRLVzWICQQD 4iWblFU2eNkODL98VhvEDToM5uouC+LhkwXx0rViILa2KsyCuIFkQTx8siCuFvdN75/RUKEJa8Nr NjTRQDIX/FCQsFoxDQVXC2ItA+JaD+usDa/Zh3UNJHPBDwUJqxXTUHC1INayIK6fWRA3kGpd8BbE q0YWxNWyIG4ksyBuIFkQD58siKtlQdxIZkHcQLIgHj5ZEFfLgriRzIK4gWRBPHyyIK6WBXEjmQVx A8mCePhkQVwtC+JGMgviBpIF8fDJgrhaFsSNZBbEDSRzwQ8FCasV01BwtSDWsiCun1kQN5DMBT8U JKxWTEPB1YJYy4K4fmZB3ECqdcFbEK8aWRBXy4K4kcyCuIFkQTx8siCulgVxI5kFcQPJgnj4ZEFc rSWDuNagP95IRn27zsAiHNLGeZ0meeEMPFFt5tNIejhMXcbakm0QiMUsiOsoC+LhE49toVBAsVh0 Uipp7e3tGDNmjAKv+RuwnAGxu87qKu42L/z2jnEIhmLwBWPqe3SEQ18wiT4BK79DF0lmEQyGkZUy CW8Q0XBMQTsQSEGKYn4gjf4k0B/MSv0cItJGhB8btTAe0mqD2A6DWRdZEA+vDFBTqRRyuZyap8wx zmQyapn5tf4Wq7uMRxyNpeDxRxSI+wMxBBMF+BJF9IaS6Or1IpVIItXvA6IJePs9iCf40dAsev1Z ePPAHJn3xyFpafi8YUQjFsRLMwviBpIF8fApm82qqdu7JYzz+TxaW1vLHjFlynCZ8/y7rH7G/ars G9XZOVZd/D5/WMEgFNcf/vRFs+gJCjASeeUR0wvumTYT3/n8umhraUVLawfGdHwWf/7LkeiKleCV w7fQm0AiUUI8loE/ELEgXorZ0EQDyVwQZkpZEK9aGSATwEbuY5xOp9WUMhBePVU7Rjx23Jrqg6BB 8WL5HTrlEQtMgwJVxokXegOIRGJY+MlU7PLrrTB37nwF7L6eMHbf8wDc+/zbWBCXstECouJF+8Sz 5qf37WeThrZBILYP6+orC+LhE71bxoONzDzBzOPb1lY56Znm9pyNp7x6aTCIecqNGzdBAYBfYWaM OJbOC4z50E4AEckrEPPDobFYAgs/no5tN9wYXQu7BboJdHf5scfuf8PT707DzHBagTgQlvLSjuqF 4YKOtcXNgriBVMv7siBeteIxNt6wAaw5xnxox+laa61VThs/fnx5fnW21lbuu9NrIp5S8eEeb1B5 wwREOF7Awt4Q/JKXiItn/OFUfG/dr6FtzFi0tHWivWUN/OeUCzClP4IeObzB1AB8PgJYhzjc0LG2 uFkQN5AsiIdPPLZuz5YeL4FMz9gcY4KY8WLOd3Z2Dko386urEcQmRuwJhBFL5tDrC4lXXFRescef QCID/Sn9QAS+WQux9S82w9yFPXjjg4/wq423waS3PkU/H9YJvLv6owiFMghLpd5gZDHwWBtsFsQN JAvi4ZMbwqZ3BOXuPcEytf4Gq6cWD03wwm9rHwuvgJMx4mCMXnEYkWQe4VhezQcSaYQEFgs/mYPt Nt0as+YvhDeexP13Poo9d/8rpvQF0J0fUGEMgtgTTqr8avBYG2wWxA0kC2KrkdNgEFMmNFHrzTpf MCHebU7FgwmLrinz8NtNt8HMrm54YpIXSOOIw07AeTfcjAUCa38sJzDPypQveNSGj7WKWRA3kCyI rUZOywficCyrQhQEMfPCjBf3BBDLFdETjCHgjaGvLwJ/bgBd4kn3BhJgr4lF4kWbN/KsLdksiBtI FsRWI6flA3E0VVChCXq4ycwAYoEUsqkB9PmjCMSziEYySCQKCKTz6KbXLGn0oHskn3Xc0LG2uFkQ N5AMiN1AtiC2Gh4tH4i9HFdC4EpgEL6hUArd3X6EohkEI7qfcK8nLJ5wDN5YWgGY8eGwALxf6rqh Y21xsyBuIFkQW42clg/EfSHt2RIYPZ6olMmpXhTRaB6BgC4XzxTUAz5VL5ZUAGZYwsu38hzgWKtt FsQNJBuasBo5LTuICVNfwoExB/+JZBFKQ7zeJDx9UYTFO1bAjQt8PUEEgjFEMnn1EK/PF1flq8Fj bbBZEDeQLIitRk7LB+L+aFyBlW/LdfdHEGB8WOazAuSAP64e2HkExJl0QQ3ys8gXVHX4IohfqF0N HmuDzYK4gWRBbDVyWjKIq8cjVr0eYgJgXwTsCUGveKFfgJEsweeJIxrOwZ/gwEAxBAMxhILiBRMs UodhCfZBNuMTN+10KaZBzBtdAqEwQcy/hQVxXWRBbFVP6XOtrQxiQsEnUFCwIFDEAqGcMj/hKxaS eZrJ50scNHrO7vLKzHIzTssD5BszENbLfIFGQ9iCuO6yILaqpyogdgZ7d4FYw2QI0Njp0NNlBnHc grjesiC2qqeqQUxAaBC7wCFQsdMVmDrA1fOLWyDK3ik6PqxjxBbEdZMBsRvIFsRWIyUD4mB0CBBb W0FbRhCLV2wf1tVZFsRW9dTQILa2cqaBq7r51TD3w7oKiDtAElRoUH81FYjdsiC2GikNAjE/Cipg sCBeVbYsINZxZJoFcR1lQWxVTy0O4rgNTawiWxy+mUHmExAzncfagrjOsiC2qqcsiIfPLIhHiczn e8y31Mw301YViE271XHo1fN7bFYrolZ+naS1XSAcUXFKn8CYIO7nFznCSfhCaWsrajx+YhwIqZZx UCWOVsdv/DE+39LaqazRLs+mcAkNfM1XIwhJXhy0VSHTrvlSsfsDmVZW6qYvIA7F4uIVi2cmxu/N cTAf1Q3L2oqb8nZrecba9LcB5ZeHQJhf0VYesfwtqBo/lOum1R7EBo61PmzZ0dGh5ldG5vNA1fBN pVLOnFWzy4QmwvEEer0BRFP6u3X8iKh+KcHaipoGsXlwt3ioxxuIqpc6PN4Q4omMAnFbW4f1iJdX /Km/MkYRvgbE/KQ7NWbMGHWB1KqzPEaxba7DvR7KQN+quaVu+p1jlUcciWfQ7Qkoj5if1eeYw9ZW 3NhPeLAxzVgS0UQWvlAUUQ4jGgiJ86Wve6qRfrmu9h6xCRsYaFKc5x+jrW3lO3bXAi+nJnZs1dzi uTZu3Dg539oQiETh8UcQSXL4yoSKEfMns7WVMD78dFtVPj1iFZf3hxEKR9XfQV33CgeN4yit9iDm XY9WDUflpayC0ATbNbA33jZlQWxFlW/67Z3wBILKQ2NoYmGfT30Sn3FLesp2uiLTGhZNDTJCmF/P TiTTiET5Qod5SC8QHrAe8TLLHLgVtfb2dgVczmvPRKdPmDChPL8yxrZb+VRc5js7O8vzlBvMVs0r ff61obWTP4v1U/txa31Wpnxw1CbGc8lOl3uqTHdHK5s6pi6TtPYO/YuENmHceHS0t4qHRkfJesTL LDf0VsYMjPmzxKQZaK6MtaqTQiA/Zg2Zyh+9U58o+m7LP7S2cmBkQE4AMS6zBKeVoEllWZup70wk kWlFON62u3BZlXUOll6uWWXQgnvRtFE9tVoe6XNFfhKLV0w4dI5fU0OijcvtMpXz0NqKGY+fMudY ctrmWlaA1hBWThOvWTF1LluPeNllgEeZ4Lr52e+Oz9ZHJZQG2CtD/qg5+VesZaxsb6dsb0G84RK3 M49cPoVMyYFxKSFlowrCKamWlRnO53IZyS8pxKalYE7mpab6V1Xkrkr7OZnJIi3HgCuUNMalOTUi 5Ev0xAl7WadzQyjl9HbmpS21jsKAsz2y/oyklNSSsw1FNc0VnH1TNdxT7os2q+UTj7Lbhlvm2Yi5 jrhs0kZa7mt5OFWfvVs5NTyI6bXSzIMwE481UK6vuE2Enky5WbJJLR0uEOcIUcIrLydHQRaT+Ojt 17DpBuvLCdmJDTbbBm99MFOBGCUpW8whIwtsMS+p+VJS6jk3GyZKXk4gnEJEFqRdNs1JTsDpnH0a kAW8+PJzuP6GqxEJ+/HuO5MkR7ZRymRzxGy5qt4FmiTymLKZvOTQiuVMlnRPLYhHi5oRxKNRDX9U TEiBMjA2nrDpI1w/yfYMELZCMW6anN9t7XKytckJr0Cli2SifpkJomveh9hgg83x5ttTlAN65733 YPPtdkIkKW0UUuIixxRQ48oRZducyShwpgX09J4HkJSlsOQT3Op/ZPVhQXGghDjXJ/PJLP/N47mn H8ORRxymyiUy3FaBqVhc5t0gzqdU43KzGFBlaXlpT0umZmcccVElWTW0LIhHhxr+qPAPxz6/lHn4 ZfrtUubEqpcZSBU0x9Ah29spICbk1O1CFZHtLi3Cg/dcjtPOvg5pteny0z8fx+yePgSTGdxxw5X4 wph2rNGyNnbffm9EFvRixy1/jb3+uCtaxo/DEcefjrjA+PU3n8HPfvJ1TJD1fO2zX8Hr70xBVNq7 8c77pNwa+N+fb4ppizx45qWXcNVVV2DbLX+lHk5cf91NmDz5XXzp8+tg/LgOnHHOuap/5W+2+C3G ta2JzX/5G+SlfW4uIZzOMxbtEjNojqoWrRpU+hy1IG50NfxRMQ/X3CePmTdhirqJm+EYY68E1xjZ 1k4xbhlNOZV58XYH5uH2iWdh4u3PIyVlMxm+eZdQwGa5AmFdLCDfFcauG2yFDx9/Gdtv/hvcdPdd 6EsksOMue+Gtt99FqkiPWCyXxtVnnIMjjz0Fb87sxve2/AOmh3J45PkX8Y+jjsTdDz+Ga2++Ew8/ 9jROPP4EFGMh/OoXG+CVV9+EVwD8x332wgP334stNv41nnrkBRV14JeDeWgTaR2+UCDm/pmpmRdV LVo1qCyIR4ca/qi4QxMUH9TRG2Y8s+5xYp7P7AYjUz6M49bQIx6rQhMukDHsgB48/sB1OOOs65F0 7h+5QhjPvvwiZi1aiMnvTsKNl1+Bn3zmG/h6ywRMuusp7LfjHnhnylTEpezVE2/HVVdfj67e+Xjw vlvx521+g7VkXUf9+zTc++r7+NOJ5yEg5bimWK6Ap15+A9fdcg9efOl1HHPEkYj1d2PrTTZSbxgR /tdcdzWuuvJy7LHz3pj+8Xy9sXLT4CHlLC2Z1fumxKmZF1UtWjWoLIhHhxr+qPAP5+7za/oCE9Ds I2zS62HsBkPwtgt4Tb/FceN1FxkVBFYhCLkYVC+GCObP/gg/+f4GeGfSVAWxl954BVvutAMmffwB ttz8l+iZOhW9H83Ftt/fHJ/c/yL+8MstcfPtd2FhPInd/n4oXnv3Ixx5yN/x4M1XYyDQh38feRT+ esxJePyDmfjpNjtgpj+KN2Z0Ya9/HoV7Hnkc1113A15+/gUcd/QxSMTS2HzTLfDCM08ik45hj332 xJ33PoCdfr8nZnyyoAxiXqN5mZLBTCrTllMzL6patGpQWRCPDjX8UXH39TVhCuMl19sUiFv1tKV1 DFra5SahoEwQy8YXecLzoV0ehSIfnhUw5Z3J2PBHP1bQ/snGm+DdqdOQLmbxr8MPxNrSzt7b7459 ttoDb9z2OPbc7LfYZIvfoGWNtXDsWRchlgfefOkZfLa9Bd/67AQcffgh2OfQY9Av6zr/xpvQ8pnP YK1vfQ8vvPsJnn3hVdw88SbMnzkT3/zKVzHxxtvw2qtv4ZvrrYt2Wc9ZF5yHYCypQDzzU+0Rl8To ERdkswnhbNG5k1Dq2q0sc7E+l7PV8siCeHSo4Y+K++0090nkng5llDuW7A5n8KFfrTrLbmyLPRF0 DwY+P8wKngr88a9AzH/4yE7HXJXYj1hMgU6M0+JAQYoz9itlWZyzcWDPbXbGh9NnQWro3nGqEak1 IJlFprJPsSqqqjAswWWGHsqXGjfBmJPIZlhGNae20zHJZxGzqPKVTAOspedt97XRIZ6nlAVxY2tU HBXC05w8jA8nk8TOYMAuiwh1A+JYLKamKyeCSIOWs+wZxi1KM42hCYKYkHZArPZggADVIGbZQkGD rSh1MjnZL6fJRHcQe2y/G+b09ivAllclbQ0wZUBjl9AnfOlva7Dr9soyi9wWOXbcBuJ0EIiNSSbz ma7NnWlqabMgHh2yIB4davij4j5pOPavWXZ7tssi9yA8q25AHgHoAHEqQCIkxbhVClUMS3BT+XYd rbwbxCVf8HCS5J9iIVdeJtzUW3OqEblhpIsK2CrT4Z6GIH3vtJh+WYTQpHFeV5bCplHW44bJPBdN CXUETX65babrtvSr1LWN67EgbnxZEI8OjYqjwj/e2LFjy39IGmPHy/KwzsSVzZTtrIoxJoy18gUO mY5v70S78047B3Ih5NRbw/REjQm4CC+HifofmhTU74QMCHT5UrMgkG/LSRrL0hTzHO5xme++FR2o V0NSm1NBtS9m1uVMWEK1a9LLeRUIDw1i6xGPBlkQjw41/FExAHXDc3lA6oa1gbm754XJW1Ez2zem s109tGt1RoEyyFKsUiAWYA7oEAU9XHUpyD859babzDPALOSN5TMKr0qSziy+LKIaYzPSRl7+Y0ii DErGRGgyb0CvV8w2aTJbZWbWncbySwax055j5SpWDS0L4tGhUXFUzFt0Zrq8qg5F8EQ0AF1ZDTie bmkgh6KCLRNlnUJDdbqrbPmHryQLLJnGrSlfCjJTYjeFdEaVY15agc4JUYjyeWmM7Ugxvnack1LE pPJI2ZCCuFqRgjDN3f7ixrKOBqUtCcQ6T5VzZKpZNbYsiEeHGv6omHElqr8Nxwd1yxInNvA2ZQ2U eULQI14pKRppSBFaBCSTykOdqnxjkqiALPOiQcDkP6yTLSHLkdoG9EhsRqpzhloNQxc6yqyR67RH kzbYjGmXzZXbpzhjrFzJqV9O58SAWJsuoDLKZaiqRasGlQXx6NCoOCrmxDG9JQhXk2ZOrCWZEUFs ljmtPjFXxFQQmCAWUtJ/5GMzFRemGcCVxXJiTjqzFEplhvFgRU6a01K+qB/gKXFG9rmY1z0kVGRY vdFXac+0SVsiiNU2uOddyyqNEw1gTt03A3cZqmrRqk7SfyeXqv4wJpfnunnRSJ27okH1VpGqVi/i OaTPIwviJaspjoo58dxaZSeF0/RiJ+Diq1ys0GLlVUIVAI2cwpwQsErlOoNlkmtkDdYSCi61nlVD SN80eeN2cCv/lLLyjzpBSuVcliOE+SKPesmIMJYSg27UKywNWl5iZojV8vnJvPLzi1L5muM6jVlp WRBbWY1SEbC69wzHX1EJhovqH/6qIhoJakKYr+Or1yYFxIQl8bjSMHR9cohtlX+J8ZpjTG0xELep csastCyIraxGqSoesR4IS3nDZF5+QD1bIYD57yAQOx6x8VxXGoYDst5iHjnxhtlWOuMKqRHQFsTL pKYCsRvIFsRWo11uECuqGW9YTD17kFk+t2C5ahCz+CoBsbMyXlu126pslLnmWM6YlZYFsZXVKJUB sXo1vpAX1gnwHLpywv5Gi4GYhF6FIC53KeU6ne6b9MbVOC46pywL4iWrqUDslgWx1WgXz2r9oI4e MUEsU4YIhLD0htnVkTBmuVogXvyqWH6VnRxZdyHPLwtwzfrhodso9zXHNN4IrLQsiK2sRql4VucE wArERYFgOkYXVWWwi6P+aqEuRxDTdBhBp9FWVmpMFUoBOC+bEJKpBrH5ao3xvHm9qS50zrIFcUUW xFZWo1QaZvz2YQqfvvca3nzhSUT8HpWhPscl+dUg5rVAp3hVyTQ1UEijkAzjmUfvx/RPP0I0pj8D ZozlKiDWoLYgrsiC2MpqlMrArDSQxZxPJuH8U4/DN9f7Eg47/Gg88txbWOBXA7Iq6XFQWhQCVxWI zfpVcyXBfjqC1559DPvutRt+8P9+hPMuvhIvvf2R+lguy1RAXAC/OG5BXJEFsZXVKBXPaicIIP8H kfXPx6svPIMtt/kdWtrWwbV3PKHCA5QbxPRQVbXFL4vlEqtnhaZqG+RmoD5WkAwg5u/FlVddhzU/ /1V0fuYr+GjmQvXpLQ7ANWFMOzLpuKqbyDCAYkVZEFtZjVLxrOaYU7lsAs89OFF9amvbX22Mm2+7 G2983IWwwK8axOztWwYxOzwsfmkss1iVbdG7RYkx6gAO2fcPGCvr+evfDsITL7yNmT0xJCSb5dTQ teqayyt4W4+4oqYCsRvIFsRWo108m/UZnYd31ju499qzsefOv8V3vvv/cMBRZ+Kl9xeWQUwA8luK zqM9XXEVgVg1kY0AGT8+fvUJXHT6ydhyq9/ip5v+FiecdRW6AnzDT19zbhCr7bBSsiC2shql4tms zmh+Jbzoh3/223jgzhvwu513w/c32hFPvD6rJohV3JgQXgUgVg8ElUecECqHgFAXPnnzRVx8yZX4 nx9vgm32OBA9UQ1sXm/sQpdNhaWujRG71VQgdsuC2Gq0i2e1OrMFxPdeeyZ22OR/cNM1F2HKzLnw CW35VcbhBDFBShAroObEI45344BdfoMj/ro3Hnv8GRWW4DaEZD2hZFF9kGEMv3DuDOSaVeNUWFEW xFZWo1Q8q/OKZYLW8Cxcf+6R+Pq6a+InP98IF9/0JMJSIE/YihSI28QbdYOYBF1JEPOlkVROwFoS 5OZ9WPDuczh8/z3l2urAb3f7K557d676yjjLGY8YRX74tqQ9aSslC2Irq1GugVwC991wLo47aDd4 uufhk+lzsdOfj8ITr88oe8St4okOihGTgbSVADGrZqUNhhlQigLRhTho19/igYnXwusL4IFnX8MW O/4F8738tJe+5sa2yzU3UHDG27YgNrIgtrIatSIFBXH5JE486kBMfu0Z9eUaQu/Sa+/Edbc+oLxf opcQpjlvODNR2yqQ9rFj8HRNwR+33hZZTwiJXApRaX/jX+2BeQtSap1cPz9RVuRHGmTb9S3Bwpiy ILayGrWiJyoQLKXwxCN3Y/fddsJbb7+Ll159Bxv8cku88+FUQR27ieU1iOV8ZzRglUYE5NIqFhgp TqCQCeLQP+2Hi087F69PfhvX3HYH9tjnCPR79BCZ3IbOzk7V3a0g2237TVRkQWxlNWolRBVvGANp ZJMBPPjA3TjoH4fir38/HG9OnqrCEhrEjke8ykHMhmh59Xoz+xInA724+Lyzccghx+Dfp16IT2Z0 g8Mk82tg7W1jVV/mYomR6pLuf2yl1FQgdgPZgthq9ItUzYrxW440epnioco/fJMtKVn0OZcM4pUF IWHqjPFWlJWlIjLP7SggL04yPz7O/hG0jBTpaB+vQMyR4ridvFFUrsjmlgWxldWoVQH+nrl4+J6b 8OSjd+GB++/CPfc+hAcffgGPPP4GZs71OCB2DcpO+KnLgBBeuRgtvVp+qomonfLWi3jxgTtw//23 474H7sXD9z2CJx57EXc9+DK8Mb0mfp2js7VN0Tebz6leF5UrsrnVVCB2y4LYavSrgAUzP8RVl5yB K8QuuvAcXHrZ1bjsiltw9nnX47U3p6hP1BF4i4OYaFwVIC5Je2m89ODtuOH8U3HxRefigksuxpWX XIHzz7sMl157Pxb4K70mOlra1SrzBf1ChwWxlgWxldWoVQG+7ll45rE78OC9E/HMM4/g/gceFY/0 WfGI38L0Wb6lgJje7MqCmK1nMeOdF/HUPRPxyMP34eFHH8ED992Phx9+Gg8+OQl9ISkhq9FjTXSo VXITuAWLX5nNKQtiK6tRK/GIZ32Ayy44CVdddhYuuugsXHDhZTjvgmtx6eV349U3pi4BxAaDKwdi 1iWM8/k4nn7oZtwg23DJ+WfjogsuxGWXXYZzLrwc51xyG3oCun8EQdzZMkatsiQbZSFckQWxldWo FfGWEIsgk/DgvPNOw7e/8z3ce/8zuOCi2xDl8A/DDOJigQ/r+DgugmLai55ZM/DP/f+G3+20Iy6f eCsee+59JGVVZhta6RFz9Wo7ZGqlZEFsZTVqJYQbSCIZXoibb7gEJ598LLbaenu89sbH2P9vx+HZ F94f1tAE65b4erOAuFgKoJjz44DddsNlZ52HPfb7E96cMh2bb/NHLOrnR/1lG1TPDQ3iQmFl1rv6 yYLYymrUSoOYXvEJx/4Dr7z8HHbaeXd8MqULF116K2646cFhfVin6pYExvkEMnkfAr452GGTTfDh K29ix732xAyvH7/81a6YvzChB4bv7EBra7sCsVrt4pdl06qpQOwGsgWx1egXQZxWI589//QD2GP3 nbHhLzfDzbc+hE023wnvfjhboXa4uq+x7kCOX26mV5yQFUVxxlFH4PhDDsOWO+yIC2+6Ddv94W/w R83NoE1fc7L+UkFSKpdj08uC2Mpq1Eogyq83i1ecTfqUR3zA3/+Jfxx8HJ5+bnLZ5x3OFzrUWBf8 lH8hJdM0Qgtn4cYrL8ce+/4dx556IWb3RxARTnM72jv0Cx3qlWgL4UFqKhC7ZUFsNfpVwgtPPowb r7oIId9CAWxWDYtJ75Pgywknh/sVZ/WwTkB84Wmn4NWnHlEw5vgXfKWZfnJMLj0OesntYXy4TbZD jY+x0jeB1UsWxFZWo1Yl4V4CV150FrbfZjO8+86bapQzvk5M8GUEhsM+6A8lYO2e9j5OOvTv+Nt+ f0ZPb79yeLkN7NPBKHZaErgNY9s7JIMbUJJtZY8LK8qC2Mpq1IpUFeoOZPHpR5Pxh112wGGHH4lL r7ge5190NSa9/7ED4uHyiMX7Vg3SDRfcZmJ48MGH8ZMNNsQ555yF8y66FOddfju6w0XkZFu5DeM7 xyhC6xHbiOpVuDGjWKOeRKVSCYUC/6DyZ3WmHO80n+fPH51PZbP8oaTzKH7amx3MKVPGDWyW47Jp 08jUN1Mrq/pJQ7CQSeK5px7HFptvihsn3owHH30CDz/2NKbNmqtQxzO1DGKe42pAYp7zKw/BUklQ X9ID/4R8/bjookuw08674Y477sJjjz+NR594Ef5QUnnIXL8a9EfWq71hC2Kj1cYl5IDYlBucBKwb roSzgS5PCsKYMmnV5Y3YtgE7ZcpYGFvVVyX4+npxwrFH4U/7/BGLFnXJuSpgLg6o+DDPzjKI2WNB YKwgPCAp9GKZu/jpvhzidcO36/J477138LvfbYeLL74UgUBItZvLipPEy8ZZB685jkfMOvlCWqaV a7XZNepBTCim0/yjahGO/IO7jcDldMyYMeU09zzNlDFGb9nMGxnYU8bDtrKqn0p4f/IkPPHIg2o+ m9XXAblH+OrxiIcXxLlcRsCfwY03Xo9p06Y46dKyAbBj+by+LrXzo+FtQVzRauMRG6+WICZEaYSt G7huuPKTLWbebWPHjsWECRPKy6xv5AZxLc/ZympkJfBNJuRkLDivGutrICteMeGblX+GG8Q0gphT himobDYv2yMz0nY2UyzHpDs6OtQ1pesxel35ldnsWi1ATChWhw5oDFNkMjxJBovQdkO1Wm5vl962 O3RBmZCEWbayqo/k/CPlihrC+bw+b8lWA2HacIJYw5fGa6GEVMq53tiu20TGEdJlC3LDYH8KK2q1 ALEbwtWANXfhaltjjTXU1HjGbm9Zx7EWlxvE7nVaWdVL+RxfjqAHqs97nqPkHl9cI4AHgVjObfVL ToFYg3PlpR+8qYd27l+JMptJa9BzXAmaub70elfV+lcPjXoQm4dzbgC75/mHHzdunJqakIMbuiY2 TPiaNBrFtk382XjJ7pPNesRW9ZecgwqseonnaTqbUYuZbF47wDLvBvEAy68yEPIBN9vTYvtL+rXJ a0x/xZkPzY0XbUWNehAPuguL3CdBdQjBLLtl8jg1UNcna6Vdd08Mit5w9XqtrOqjClDdITWenbQK iLWDUTm3K/VWRgbqvLbcjokJUZgkrpPrpxOktWrWv7potQhNDCWeAOYEMZ4wH8C5vWIzb8oR5u6T ysqqcVUbaCMF4uVpx2yD1qpa/+qhpgCxmbrDD2uvvbaaGghz6o77xmIxZ87KqpFVG2g86xVu5R9O zXlvQdyYWu1BTM/WhCTcPSiqe1MYYNMbNvO1elxYWY0mmXN5cRCPvAaD2MqtpjkqJq5rTkJOCWla 9csZtWLJVlajUeZ8tyBubK32R4UnXfVT3FqeLuHLsubBHJdtFzWr0S4L4tGhpjkqBrDG+6UnXA1o 4wknk7ajudXqIQvi0aGmOCruHhAGyCbNnJRcdndfo6q7rVlZNZp4ptbGqvMwzOleVg3iJddbVXLW XzYL4qFU96NSOSGq/nCLnSkmr0bWIFXKUaafo3EC3FA2UuDl/0X9VpIu6pQrJyxeT6fpdK5F+dOu srodR+UFXafcrJXVSmjJ55FzbloQjwqtgqOy+AFfVvFEMAAbUC9jZmXK0EFeEqQtNieF9AnD/LzM lyp1nDy36XJi5QS97C7DNtzLSgJhobS0K56xymc9Zxto7mWppNvgdjIdYNRZRZ7Vduv1cRuVuODU U/smprfKSbJqAvEEqGXDK+VkiKpBXA8NB4j1dVjL9LW1NGsUNRSIB8DXiWmElbQ16GgxjaDWI0tV 6g02XU4QV07Q4HOXqf5DqX+46QJRtkkQc12qnfJuOeh0lglsfoJGt6+/y6VBzDJ5px0ui7EOE1Q7 3JasaU2v36oJ5Jw4i9nwyoJ4aGsU1RXElDkg/JyL9oa1R1w+UE6zGsAGfHKgJXMoEA9edrWnpP9Q Sq6MyixXqr60pdZB05mCTnrOMk+I8vMvuqzeavXoj2XEOM80PToWjfP8X++H2XarZpE5V6pteLW6 g7j2MXXb6FDdQazhRE4RjoSm4EtAVgYgm1Rl6IESf9Wg1aqAjWVc+QSjA2LVXq3tVAUlrVyJ4udd 0qo1VU/lyZIDYoK2DGJZrpSTOTFzS6kGMfdB33SsmkvOubKYDa8siEeHViGIl1dOnUHnBHFGfDkg Xex8YR3t4SqpQnq2DGKCzwkxuMHIPLXMNlhGxDSuUdUrSps0yWK5nOTkuB5mqgLOepkpZRi+KKg0 tq+Ty+tTdR0PWa1P0rhKKad/NrGMXrZqNvFEcJk5v4bLnHec+a049b04Lpv3nkfYyttQI2+Frfp4 LmajQ3UCsetAVR1UHSuupJUBp8Q6DhBNHVVYl1GzCsQasAp37CWhHsKZdpjPHB2eICxVPXZVy4tJ NnMZ71UeLaUKcJ2Sw0xpiCBWoGaCrJNFdPssUA1iboPMqnY4wzpm2aq5xL+/y8x5MFxmQTwqVAcQ uw+SGA8mZwm5QZ4s/zFYM3MEn6nH8kzjss5V9VRbGoKqngvEalmBWterhDskzeE783gzMCBlPZZT ZVjXYS/zsu50Z3t1u6yve1+odKeYLsP1iXG+XMeqaWXOg+GypgexscbWCIPYfWAcAJYPqp5nOEIB 1ZGDLRHruEBsyMl6ItYpg1jMgNS0XwYxMwlnVZApOhRSLqAgrbuXOTlSXXu8GsRiksi26TUrSDOd zdFEhDu95QILsiLbVnlsh/FqbrcsGrNqXrnPg+EwC2LHGlvDDmLzYICj8le+DEC8FZDPpaRACaUc oSpyHWBdQs+zCX5tgFmsX8qlJVFy+a0ufqVQTizm5fjpWDbP8gLbLCsyQyyZZ5cxyWTZPDGqoUjc 6u1QSZrv0iRLJPRsWcWsoLcghWQ3sjIhiAndEmPLLCjGZnR8OY10IanbZGOSl82kpDwfAEpNZ7uU Wa22KtYYQKp6kKnhFreBH8U1D8pqbdNwixxwPzAcSfElLjNujPtt2UZ6c3ZEPGI9pgNHOhMEZRPC njxyefa8FRinNQT5p+GNmjOlgn6clZap+TqtzCrHMpsmxMTXzLO/saxXQD5Q/uxKCbmMHHApyxRa Lq8hrZflD6I+LyttKc+Xxj8QPykjPmxW1sVrRFZEyNJUZVnWPrGsQzziYiKrtkXBOhtX6QOaygr+ Kamp+0RL2yxoTNZXKCZllv2hJVdvitVqLoKA8KkHBAz0qnssjBQMDQC5Po4HTjPrruegWuZv0iha BSBeNlW+UcUYrIafBqGGOI8JrZATYsnU/HoiGYuFtMozY/Tor9Vq8CoTqGYzCe2ZMkXKpsXr1XFa qSfLnKYlPyeZZGJKQM6wgrohCISV/zsg7UpzcZlEJUX5LTlJEC+YJdQyVymNZTMCZM6rBA3VjDTM cuyKh4wAWrYzk9bro5LRiBQX6ItHb9ozeVajVfz7u22wqr3fTEafxMWiPrv573Abrwd+s669Y0z5 lyWtINtg5ofT8nL9cKq/m9c2KG24jdco99/pdSoO2OD1NopGCMTaGy4UM8rzlD8DHn3sAbS0yV2a 1tomP50+g6eeegmnnnYW5s/vco4UwcoTuYCkeKFMYzLhxSkftZWKWWEbYSpl+TVbSWetXEF7rfRL 2cKV11+LibffivenTsfOe+2tAS2AV7nFBKZ+PAm77byDnCidaF/zi7j+7kcE5pKtYsIF1U5Y/oh5 xiRYWRpXNw+Z8o/LvaJTzHXxJJPGOaO2k2ncFtlYWWAF4OHnn8UVt9+imrIazZK/9SBbXO7Pco0d O17BqK2NXxfXYNJmlodx2touMOaHdOV6G7fm4vnDNG3lvrZ2qvWbaWvbmMXKLf90ScZ8x7hOmfIm pNdP5rSKb1VU12ajaARAXEIyqX++a4IVBMZZvPDi0zjmuCMUwGg8KBmBHOGnDtAAI7QxZPP6i7Ss z5BFXhYyYsrLFe9StUkI51g+L15vEeKEqvKcMADCd+QuvvJyXHPD9fh47lzsuPfeCKVZnnAPwdM1 BZtusQ0efe5VaS2PRd5F2G3Pf+DF596XItK+QJ1tcC/UgzlJSssCZwljbhMj0CmxoHg8TFP0jegQ BGdjrMBbs74P4eFXnsOFt17LpqxGtQyAq60iApjgbW/np7o0IAyQFZjaCCcBxTBMWztkPVwWB6M8 bRU4Ml2my9rOCk9lfWMmrFVer5mOGb+2Xl7WdmpNl2jMd8wFZ31DaEdH51j1a4CXY6NoRECsrYBs jm+r5cRRTOHFl57CUQJivkRMT1LFg2V69HGnYfqMuZh4/QUYIyfw+AkdePHll/DnffdRB3OPvQ/E gv4Err/tTlx4+cVYMH82vrneF/Das4/hhWefwIFHHI4X356EH//o+3LQpf5Xv4nn3v8Y10y8ARNv vQXvzZqNHf/8Z4Qy9HEF0wUPnrrvRpx68XUqHDGgHtElkCKjZYPmfzIbn5sgXkRHC/5z8QU489wL 0NoyFl/9wv/i6cffwAdTFmDnvf+EZDGCT2d/gF3/8lf0eOLYa5s9sOsWv0O7bPPue+6mbj5hfwB7 7vgXtLd9Drsd9BdcegdBPPiitRptMud3tWkxFqm94TYkEillwWAYsVgCoXAU/lB8WC0YScIbiCIS z8Djj6jlWDKHnv4AQtFUzTqr0rjePm8IvmBMzdM4zzTO16qzPBZcosWUeX0hpDMF9PV74fH65ZfA BPW3IIMbiMMjA+JCIYdiiX4h/T/1ex+PP/EAWjrlBG0XGzMGR590OmKpAZxx+rmYMX0qLr3obBx6 8L7i7IZx+n+Pw00TbwPDxzfd9iAuvGIinn9jMn6326546eXnsN1Wm+PSs0/BpRechdMuOF95wao/ sJD02HMuwEEn/xdX3XAdrrjmarw7eza222cfRFU8WWCc7Mbd112Is265Gz5JefrR27EWf760rIND j70Acz5eiPW/9V0EfTPwzOuPY8Md9sHURQUsmtGPTX68Ce598lXssv/fUMz5MeOTN7D97nvCK+7z rzbdAXdec5e4wklsvfEvsGDmpzj99DPl5nEPwnIYDj7pX7j8lsvk5lO5aK1Go6oBbKyicePGoUN+ Gvf29isARyIxeDw+xOJJBcZAdPiszx+GP5JAfyAiv8ryCMZS6PEGkcyVVFqtOqvSfGEBpqw/nMjA SzCKcZ5pzKtVZ3ksGElXmT6mxiKJNPp8QaQEHr5QVJwzesUd6tFPU4G48pCuJHcm/rjncgHPPf8k jj72CLVERPMXeypfwkkn/htzZ07DdddejVtvugYoBnHCvw50vIrx6Oz8DHbccQ98NHUGfrTBT3HE MUfjqquuwL8OOwR77bYLXn57MmYu6sb9992DHXfeCS0T1sD+/zoBl91wPa677Va8P3cutv/TnxBV XRYExikPXnz0Tpx42RXwSgpKAudcAo899yYOO+F8THl/PvbbdU9J7sFzrz4qbZ2tPOeS7MouW+2I B596GTuJR1yI+9A16yPssNefsChexA47/RmzP12gQLzXVlui69OPcPwxx+LpVz4Gvw9988MP4Jrb r7MgHvUy4K02LT6Zb1Ux4jYF4WhUwCQATKZyahoIJxSUhssIXgKL855gVM0bOJrpcBu3gTeEUDyt jPNMq1V2eS0Qlv0bZEyrGL3mQCQOb1COtUxb2scoY1iC4YlG0cqD2Pj41ebIdNPhAy0+XGNPBU6f e+FZHCUQZdFUjrFUBiniOObow7Bg3nxcf9WNuHXiTShkfeId/xtXXHqObtfhZ16gvsVvNsG63/xf TJ3fL/O/w1e+8m0sWOTFEUcfj5tvuQ2xTAYHHHss/nb8cTjvumtxxe234c2pU7HDPn9SfrnqZVFK ItQ/DxtuthmeefFVdQ0FPSH8+z/n4PB//RcffTwNe+2xJzLZKCa9/zY2+tX2WNSbwvSPFuIXP9gE b782GT9f/6fw9HTjqaefxdZ/2Au+DPDr3/4Bc2YuBOTuv89vt0f3J5/gvFP+i7PPugDBVBH/POkU XHLzzWp3rFZvEcKMU4YFHPy5XAYEpxECydpwWSCalmkFzCZm3GgadhAbZRRsdRbnn3z6KfzruBNU RwIqHFsoeWGccfopmD1zDq665DrcftMdkiMnb2A2DvvnvugQr/jbX/oW3njuNWkojbPP+S9+ssmv 4ReX+r/nXIlfbrot+E7H0089j3Hj18I6666Lg487FnsedCAuue0WXHr7rfhw7jzs9de/ISSeKjem lNfd1ubPnoVD/nkoOlonYMyYdXDDDbcjmSni0+kz8Ic9d1Xd3bjd5593sfwhx+NbX/sxXnv2HeRD SRx/2OEYP3ZN7L73/th+t33hTZWwrXjtM2fMQ15Ogj9utz36pkxD2uvFLr/bAWPWWBt7//NwXHPX /RbETSA3iA2AfWF6qbXhYW3VmQZxxVNuWhCbTtPsw8A5My1b+VdcGrlCWMWS1TsXzi+8gQLDGYRl itTU/cBUPntT5FRYIyHlGNpgViZFL1f87hL9braqHwYGC1kVO44XS0iYDslcubSj+g/LfDEvWydt S1XVZ5n1tXGrS6pLHKW2z1hO6rFXiOwMy7JESuaZpXaQiey4npEc/jqQ9SQyebUtDFEw22p1knPi ulQNYnpoFsQjY7VB3Ob8ZRpHIxKaUG+xyLwxvt1G4zw9WIo9KQhWyg1ixiEGCuw8JgVZwdDReTOO XdUIPz7IK6+AfQRLBfVaNXslMJ+WFAiyFovwn2I6LWW5zrx6w4/d45hOL533Dy7mpU66kEFBbhCE MTvik9/l7eC8bAvTWZ7tp6RJdj9mWwNZ2W6+Uq3CIAXksnqwefbZ4A2C81ark8onblkGxMGoBfFI 2yAQM0bcNCBegghkWnVxY8ZTVnISCTz9tpzMyDJfXy5mZN6hKT/2SZClnNeYVQSe7iwh7YA6XxSI Sn2+T8QUllfboYa85AoEkqq8ZDjGt+EI4kxWD+GuPeICMjneEHQZNcyFWCmXFbjqdL69k0hLWacd temcpyc/IDeFTFLy9HhvUhVJ2RhmW61OkpNAWUUWxPUzC2JH1e+Ts4h5q0X94JcZAqzgQCmTdqAo yud1Ij3VjOrYK4k8x0kyTmWZ9QhXJWm3wBc1BHwDHMiHEBajJ0ugJjloD6XaEYjTIyZNBcSZlMxL uvLGZcpxiFgsIy470ZkVr5xQN1JRChYob5D8yzfqTBvO9mWT7JcstwK1Hfqmwjfv6MFzu1UTVquR +IenVWRBXD9rHhAvg5Y0yAfTmUMYc+o2StWT/9UDPSeRP+0LHGtClgs5XZ8gVwP2KBda1qFGZ+O6 aERwJTSiwiSswCCw4z0rr1syCfwsB4yQeVVWTUuIJcIyzTuvROuLTN0YRCnxcrWP60iyC2lpg8W4 3WpGg5xeNd8GVG1bCq+m4t9bnyNGFsT1MwviGiIEKfcwfAaSWUJVZpSH7IQVVB9kpjnQUvUVYHU6 jRPVHvNzAkcnDKBMua16CDwz2IfaBDXDys5Fw3ABXWAnj2XIahbT4NQhDk4ZWlCDDkkm18uwRbaU U2WLKtyhm+QmMpH7wMAIYZ0p6oGGuD18a49mtbrJnAAVWRDXzyyIl0mE42CPVRvT+HCMQHVlKBGu kk5J2qAsdQFoiGvTF4Qpo8q5F8qJi6uSrbdxcJsVI2Zpqhn+w2QCllOVyDh2pZx+gUOssgKr1UrO 39clC+L6mQXxMoknrPY4K1wi1JhG77EaxCxPENNEklbOUjIXQW0Iq3KVwkOqUofbY9pd3GqC2Jgs s64bxOW2KiuwWq1k/vgVWRDXz5oGxG6eLBNTBhXmCTvYw62kMR5bAa6WyVscxNo06LRV5y2bDS1z kVWMzi9N1a1uTIwTU2aJ5axWI5lzoyIL4vqZBfGSNKgwT1hC2AGxkkkjiN2Appg3GNzu5mj0PmnV 6dXmBqPblipVyFxsej1lwCo5ea7GOGtMyZ1QTrRaPWTOjYosiOtnTQtiY4upZiGesIRqoUaak06p dIp5JlYrKqdXqhsQu2Gs5CyYtCUBu3Ih0UTVBYy5ygxKrq5frUGFl1DGahRr8b+9BXH9zIK4WjUL 8YR1wForrSaoXGmqfEUmHluBbK36uhzj0uzJYFZbXr2qY0xUXaCWuWYHr9+RyWSTZl5l1t4+q9Es 17njyIK4fmZBXK1ahWjmxF1qWpXceU6+BrEBrO6N4WS4yjGNefohYXWIwuTrqchkcNHM1zIR2zEP 5dgCl5WYb1Zk2lFy1mG1Gol/08F/Vwvi+pkFcbVqFaKZE7dWntuMzLx7quZ1OxrA2soXhClTLse8 6t4aTrbTTs26Q5kzoSdMEBvuKjGDzVWBeEkeu9VoluvccWRAbAf9GXkbBGKx1RbEjSdzIQwFuWUp s2IyXDZWVs1Eq2ZQNYgJBAvikbHaIF4dh8G0srIaUhbE9TMLYiurptTiv7RsaKJ+ZkMTVlZNqSWD 2D6sG3lrmod1VlZWblkQN5JZEFtZNaUsiBvJLIitrJpSFsSNZBbEVlZNKQviRjILYiurppQFcSOZ BbGVVVPKgriRzILYyqopZUHcSGZBbGXVlLIgbiSzILayakpZEDeSWRBbWTWlLIgbySyIrayaUhbE jWQWxFZWTaklg3hYBv0JZ9TUSyPopW1Ch2mBcAqhsB7tjeW8kZyacjkcDiMUCavynmgGnkhemTei 29P1WS6KsGwz63qiObUek6/KCNxCThka1xeSejSuX22XtMn6pg3dDq2yruGyQSAWsyC2smpSVYOY QFglICaEwxpo/bEUPDFpOxJ14EsIJ5AQ2Ab9IfijRQSSQL8/jUQihZhvATyLpuMnv/gF9v7HMZjW l0NXGALzEgLxPLp9ESSSadx93dVYZ8xYPPPqR1gYg4K2NxSDPyZQDyURCQcx7cPJ+NKaEzCupQVr tLeiXaYdsr8d7ePR0ibWubZMP4uWjs/h+HOuRE8C6JO2eoME9PDCuDaI7TCYVlZNp2EDsVhAwVg8 WoGwN0YI07QHrLzfQAjpVB6LPPRMBbThvKQFUArNx4M3XYCW1ha0rPVlPDq5Bz1ZAW1cyggcQylp s78bD1xzOb7Q0YknX/sU8wSgvQLg/nAMQfFqg7IvsZAfH7z9Mr677mexhgB4rBiBvE7nGgLkToHv WmIE8TpoWeOrOO7cqzE7IF6xtOV31lVrv1aVWRBbWTWlRi40YbxeFRKIBJWpcIDAtj+aR09MjGEA mUYiBfgC4jnLcjgaEgrOxkE7bowdfrUhvvODn+Fvp9+KT8VLXRgEgpEsQvEg4uE+PHT11fh8+1p4 /LXpmC0eNdvsDyWkPYF1MIZkIiblAoh6+5GNhhETyAf6PDj5qBPxna/9H96ZOhtdUWkvJ237svCl oKzbLx58OKtvGDX2bVWZDU1YWTWllgzi4XhYp+OxUUTCfoTDAuJQXkA8oDzXnrhYcgBdQr5kvCTA TqAvEpV6Psyd/ArW/8J43H/TVfjPGedg3Ld/g9fmaRDHUgPo8fUhGfPjgauvExCvXQbxwngRfbJO gjgckH3xB8X8shyRdSQQi4iXHIziwlPPx9e/9G18MneRgDiDnpCYbEdA6vsIZgF6KC4grrFPq9Ls wzorq6bUyIG48iAspR6+8cFaKDgg6xiANxqHJx4WjzgNX1y84f4QktEY/HEP+n0Lcc5Jp+B/vvAV fPrJR3jmxdfRMuF/cPWtLwpkAY9AsjcubQcjuO+aGxSIn3p1OubFBcQJyZPt1yBOqmkwxu0RyPvD 8Aci8PQGcNYJp2O9z30dk6fNkToMneQRlu0Ih9PweEMqrNHP2LVrf4bDLIitrJpSIwliHWrgAzRC JhwSD1lAHAoWdZgi6pP8CPxJgbE/orzmVLIbPs8c/PB7G+Iv+x2rHrot6Atg153+jC023QELPFnM C+bQmxlQIYh7rpmoQfzKTMxn6CIheZGYADiHUCArHrgsBxIIZkpYJJ5wOJYWTzqLU4/+L/7vGz/A OzPnoSuZwQJfBF7xoCPBFOJR8dBTOX085FjU2rdVZRbEVlZNqZEFsXp4JjBWD+YEigRxWEDKh2iR SJ+AyK9hLODzBz0YCE/Hyw/fjM+u+//w4Atz0RWFwDiDh66/EV9snYAnX/lEeb5z43kVgrj7Winb /jk8+aqAWNJ7xFPui4QdEOfQ50kimBrAgkAMfYk0wuL9+sQjPuf4M/Gtdb+Nd2fNR29xQLzzrEA6 i1gghYg/KjeGMPoDuvtcrX1bVWZBbGXVlBpJEKeUN0xjNzbGhwP0iAXIsZDAMiwecagfwWwS88WL 9YmHXPR8gEN33xrrb7gTPu0DugSugWgS8956Dd9Zex0cdcpVmB4RzzeVhz8Rx93X3IZ12r+Ix16b jTnsNSEg9rFtAXFQQByKFNEjXq4vW1KQ7g9EkJLtOe2IU/Ddr/4f3pw+GwuyOSzi/srNIhpKiyWl jajqmVFrv1alWRBbWTWlRg7EbEf3GxYLCWwEwP5QUZmalzKLIhEsSsYxNybwzEXR/c6z+L81uD2f Q0vnt9DSvjba2towgX2A28Zina//Gi9PiWBhMiDw6sHD196Dz7R+FQ+9PRcz0oCXXq0ALeCPIxhM IyTeeL+suyeWlHWJpxuMIRVO4fQjT8b/rvddTJ49H/PEG++Wen1SPhGTG0UgjV7xoH1xHd9efL9W nVkQW1k1pUYOxIQL347Tb7/JfEi/weYRL5U9Jzj1pAvoE4/Ym4ugx9eF+6+9HF8S4La0fBYtrQLj lrFoVS9gtMi0U9K+jUsmPo1FqSAiGT8evPoujBNoP/bufExNiafsiSCbEI9bAMeucv2+OGLZAQVi TzyJRCaPYF8QZx97qgpNEMTz07orHV/giEZK8AcFyuIde6UdC2ItC2Irq1WqkfaI9WvF6kGdmA5X COBCgCcM9Mpyb8SDcKILPb0zsMH6m+KnP94KC3vi8IXEo5W6fNMuGo9hQVcvfvbjX+EXG22PT/wB zBdv+q7LJ+Iba66H+155HzMFxJG0eLT+mOr1wIdv9Ij5Fh692/5oHP2eAMKyfMFJZ+N/vvK/6mHd AgFxX6IoIM4JEAXETj9n9qQY0Rc6LIitrJpFIwliDV5O6Q3zLTuON6HSQuzGJp5xKIZwzIt4cBpe f/lxtI37Bm68+00Ek5B6CQQjSfR4/OjzhxCJxHDndRMxpn0Cbn1xMubEB/DgTbfji21j8OjLk7Ao I3VkHfS+Pf4IgjF64BkEU0X0Szv+uAZejKGJf/0XX/38N/DO9LnoimfR74DYG6a3LgCOFvQNw4JY yYLYymqVauRArL1fPqxzAMeBdMQr9QtwCGV6ybFIFPlEAPnQHJz4r0Pxg012x0tTE+iOlhQ8ffEc wqkSwvEE4iEfZr/zGtZdZx3sfPAZ4hUDN119pXp1uWP8Z9DStqbsB8ManbK8lhpH4v9t9BvM84kn HMmqFzUUnD0RnPuf8/CNL38HH8ycjwWRtHi/BfSHGTYRT1i21y/LnrCG5HCaBbGVVVNqhD1i5QEL jMMD8nO/KMCT5RjfnuOrzwlE/UGkg358OvllfOXL6+K4c29Cl3i2DBV4otKGTHv8erCgdCKMWO9c nH7yyZiw3i/w0kf9uOfOW9T4ES2tY9SYEa0qviwwa+tES+ca+NEW22FqTxQ9oZyAOK9g3OeN4LST zsKXvvB1TJvfi25uJ28SjF8LhHnz4FgVHDSo1j6tSrMgtrJqSo0ciAkW/WpzWD2Y640C/eKR9guM ORoby4S8YQxkBpR3zF4LwTwwy5dQfYTDiTT6AzFkZXN7fD4xD5LJJGIC6IA/i0gor7rA+fzdqn+w N5hScOcYE+x6tkjKsc9xTxroCghYZX6RP4FkFgiKlxwRj5cP99iHWI0pIUb4c9CgiEzZFh/4Ve/X qjQLYiurptSSQbyqB/3hgzb14kY4qH7y90bFK1YgFtiJMXSRjOXh6Y0gJJAmrPsETL5ECj6BNUMY kXgGPf0BhNNZAWRUQZIvXkT8McTE+IaeP8r26TVnEZU2o5Gk8sR7ZV0LxAtfSBgHCwgkBlSfYr5p F4vlEJCpClckJE8gHGSIQva7NxhRII7I/IiCWMyC2MqqSVUNYgJhlXjE0o4ae1ggyfCE/vmvAawe 2Kky2uiN6jImjyCmmfYGL7MHhhrcXdomsE26bk+XYzs61KDDDrp9/fCtvF6nXrUtLX9VWW0Q22Ew rayaTsMFYmtLNwtiK6um1MiFJqwt3WxowsqqKbVkEA9HrwlrQ5t9WGdl1ZSyIG4ksyC2smpKWRA3 klkQW1k1pSyIG8ksiK2smlIWxI1kFsRWVk0pC+JGMgtiK6umlAVxI5kFsZVVU8qCuJHMgtjKqill QdxIZkFsZdWUsiBuJLMgtrJqSlkQN5JZEFtZNaUsiBvJLIitrJpSSwaxHfRn5G0QiMUsiK2smlTV ICYQLIhHxmqD2A6DaWXVdLIgrp9ZEFtZNaVsaKKRzIYmrKyaUksGsX1YN/JmH9ZZWTWlLIgbySyI rayaUhbEjWQWxFZWTSkL4kYyC2Irq6aUBXEjmQWxlVVTyoK4kcyC2MqqKWVB3EhmQWxl1ZSyIG4k syC2smpKWRA3klkQW1k1pSyIG8ksiK2smlIWxI1kFsRWVk0pC+JGMgtiK6um1JJB7B59TU9rw8Pa qrNBIBYrg3jA+eM0iCyIrayGUQNywbe2tquLPxZLIBIVTzgQQTKVk2lUQ5mAtrZCZgC7JDM3Pq9z rFvaxqKlfQxK8ncpFJ0/UgPIgtjKapg1btwEdHSMQW9vP2LRFCICBE9/ALF4GsFIUrw2aytqPH5D WSSeQZ83hFS2BF8wJjfETmU5gXAjOcUWxFZWw6hSyYQm2pBIpJQFg2EF5FA4rmPG1lbYgqHYkOb1 hZDOFNDX74fHG8TYcWvK36JDQdiC2MqqiUQIt7V1oL2d3piG8tgxayggtLRKWptY6xg7XaHpUkzF hLW1tkkdSevoHK/CEgxPNIosiK2shlkmRqwAPHa8mhLMJk2bWbbT5ZsuxZxj395BCDt/B5kWigPW I7ayahZls3lnTiuTyalpUUBAmZ/I1obHiiXt+XJqlt35jSILYiurYVapVMLAwAAKhYKTgkHzViMv /k0aSRbEVlbDqGJx8T5S2WzWmbMaCRG6+bz+ZdKoN0MLYiuresr9O9na8lv5BZoVtcaQBbGVVT1V Cy7Wlt1qwnV5rDFkQWxlNayqdfG7rBZcrC271Tqmy2WNIQtiK6thVa2L32W14GJt2a3WMV0uawxZ EFtZDatqXfw0Piji1MrKgtjKaphVDWBjBLHtwmalZUFsZTWsWhKALYhXhWpFK5bHGkUWxFZWw6pq EBsYm3mrlVEtuC6PNYosiK2sRlwWwFaDZUFsZWVlVWdZEFtZWVnVWRbEVlZWVnWWBbGVlZVVnWVB bGVlZVVnWRBbWVlZ1VkWxFZWVlZ1lgWxlZWVVZ1lQWxlZWVVZ1kQW1lZWdVZFsRWVlZWdZYFsZWV lVWdZUFsZWVlVWdZEFtZWVnVWRbEVlZWVnUV8P8BFyUY0sQ6v6EAAAAASUVORK5CYII ________________________________________________________________________________
Subject: Battery not charging
Date: Aug 10, 2018
Thanks for the reply Ted, I didn't test the VDC with the engine running - I will do that tomorrow and report back. Yes, the regulator case is grounded (I shall update the wiring diag). Thanks again, Paul -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com <owner-rotaxengines-list-server(at)matronics.com> On Behalf Of Temco Sent: 09 August 2018 21:29 Subject: Re: RotaxEngines-List: Battery not charging Hello Paul It would appear that the AC part of your system is working ok. What DC voltage do you get when you put the positive probe on the Reg +B and and the black probe on system ground? This should be about 13.4 to about 14.2 VDC depending on the RPM of the engine, From you diagram, I do not see where the regulator is attached to system ground. Is the case of the regulator intended to be connected to system ground or was term L or R intended to be system ground?? Your capacitor is grounded but there is no indication of how the regulator ground circuit is completed?? Ted Kitfox IV ________________________________________________________________________________
Date: Aug 10, 2018
VGhhbmtzIERhc2gsDQoNCknigJlsbCB0YWtlIGEgbG9vayBhdCB0aGF0Li4uDQoNCkZyb206IG93 bmVyLXJvdGF4ZW5naW5lcy1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIDxvd25lci1yb3RheGVu Z2luZXMtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbT4gT24gQmVoYWxmIE9mIERhc2h3b29kbG9j aw0KU2VudDogMTAgQXVndXN0IDIwMTggMTM6MjUNClRvOiByb3RheGVuZ2luZXMtbGlzdEBtYXRy b25pY3MuY29tDQpTdWJqZWN0OiBSZTogUm90YXhFbmdpbmVzLUxpc3Q6IEJhdHRlcnkgbm90IGNo YXJnaW5nDQoNCmkgYWxzbyBoYXZlIGEgdGhpcmQgaXRlbSB0byBjaGVjay4uIGluIGRvaW5nIGFs bCBvZiB0aGUgdGVzdGluZyBiZWxvdy4uLiB0aGUgYmF0dGVyeSB2b2x0YWdlIG9uIHIgYiAsYyBz aG93ZWQgMnZvbHQuDQphZnRlciBtdWNoIG9uIGFuZCBvZmYgd2l0aCB0aGUgbWFzdGVyIHN3aXRj aCBpbiB0ZXN0aW5nIHRoZSB2b2x0YWdlIGdyYWR1YWxseSBjbGltYmVkIG9uIHRoZXNlIHRlcm1p bmFscy4uLi4uLiBmaW5hbGx5IGVuZGVkIHVwIGFmdGVyIHNldmVyYWwgaG91ciB3aXRoIGJhdHRl cnkgdm9sdGFnZS4uLg0KdHVybnMgb3V0IHRoZSBtYXN0ZXIgcmVsYXkgd2FzIGZhaWxpbmcgb3Ig YXJjIGNvcnJvZGVkIC4gaXQgd2FzIG5vdCBvcGVuIGFuZCBoYWQgbm90IHNlaXplZCBhbmQgZXhj aXRlciBjb2lsIHdhcyBzdGlsbCB3b3JraW5nIHByb3Blcmx5Li4gYnV0IHdhcyBub3QgY29udGFj dGluZyBwcm9wZXJseSBhbmQgd2FzIG9ubHkgbGV0dGluZyAyIHZvbHRzIHRocm91Z2guLi4gcmVw bGFjZWQgaXQgYW5kIGV2ZXJ5dGhpbmcgY2hlY2tzIGJlbG93IGp1c3QgZmluZS4uLg0KDQpPbiBU aHVyc2RheSwgQXVndXN0IDksIDIwMTgsIDM6MTU6NDEgcC5tLiBFRFQsIFBhdWwgTWFuc2ZpZWxk IDxldXJvcGF1bDM4M0Bob3RtYWlsLmNvbTxtYWlsdG86ZXVyb3BhdWwzODNAaG90bWFpbC5jb20+ PiB3cm90ZToNCg0KDQoNCkkgaGF2ZSBqdXN0IHJ1biBteSA5MTJTIChpbiBhIEV1cm9wYSkgZm9y IHRoZSBmaXJzdCB0aW1lICh3aXRoIGEgUm90YXggZW5naW5lIHNwZWNpYWxpc3QgZG9pbmcgYWxs IHRoZSB3b3JrISkNCg0KDQoNClRoZSBwcm9ibGVtIGlzIHRoZSBiYXR0ZXJ5IGlzIG5vdCBjaGFy Z2luZy4NCg0KDQoNCkkgaGF2ZSByZXNlYXJjaGVkIHRoZSBzdWJqZWN0IGFuZCBmb3VuZCBhIGdv b2QgbG9va2luZyBndWlkZSBoZXJlOiBodHRwOi8vcG9pbnRzZm9ycGlsb3RzLmJsb2dzcG90LmNv bS8yMDEyLzEyL3Rlc3Rpbmctcm90YXgtOTEyOTE0LWdlbmVyYXRvci1hbmQuaHRtbA0KDQoNCg0K VGhlc2UgYXJlIHRoZSByZXN1bHRzOg0KDQoNCg0KVGVzdGluZyBHZW5lcmF0b3INCg0KDQpSZXN1 bHQNCg0KDQoNCg0KDQoNCg0KDQoNClB1bGwgb2ZmIHRoZSAyIHllbGxvdyB3aXJlcyBmcm9tIEcg dGVybWluYWxzLg0KDQoNCg0KDQoNCg0KDQoNCg0KV2l0aCBlbmdpbmUgb2ZmIGFuZCBNYXN0ZXIg c3dpdGNoIG9mZiwgcmVzaXN0YW5jZSBiZXR3ZWVuIHRoZSB0d28gd2lyZXMgc2hvdWxkIGJlIDAu MSAtIDAuOCBPaG0uDQoNCg0KMC41IC0gMC44DQoNCg0KDQoNCg0KDQoNCg0KDQpSZXNpc3RhbmNl IGJldHdlZW4gZWl0aGVyIHdpcmUgYW5kIGdyb3VuZCBzaG91bGQgYmUgaW5maW5pdGU7IHRoYXQg aXMsIHRoZXJlIGlzIGFuIG9wZW4gY2lyY3VpdC4NCg0KDQotMQ0KDQoNCihpcyB0aGlzIGluZmlu aXRlPykNCg0KDQoNCg0KDQoNCldpdGggZW5naW5lIHJ1bm5pbmcgYW5kIHRoZSB0d28gd2lyZXMg c3RpbGwgb2ZmIHRoZSByZWd1bGF0b3IsIHRlc3QgQUMgdm9sdGFnZSBiZXR3ZWVuIHRoZSB0d28g d2lyZXMuDQoNCg0KDQoNCg0KSXQgc2hvdWxkIGJlOg0KDQoNCg0KDQoNCjE1IC0gMjAgVkFDIGR1 cmluZyBpZGxlDQoNCg0KMTQuNg0KDQoNCjIwMDAgcnBtDQoNCg0KQWxtb3N0IDE1IQ0KDQoNCg0K DQoNCjMwIC0gNDAgVkFDIGR1cmluZyBoaWdoIHJwbQ0KDQoNCjI0LjQNCg0KDQozMzAwIHJwbQ0K DQoNCkFsbW9zdCAzMCENCg0KDQoNCg0KDQoNCg0KDQoNClRlc3RpbmcgQ2FwYWNpdG9yDQoNCg0K UmVzdWx0DQoNCg0KDQoNCg0KDQoNCg0KDQpJZiB0aGUgcmVzaXN0YW5jZSBiZXR3ZWVuIHRoZSBw bHVzIGFuZCBtaW51cyBwb2xlcyBvZiB0aGUgY2FwYWNpdG9yIGlzIG5vdCBpbmZpbml0ZSwgdGhh dCBpcywgaXQgaXMgbm90IGFuIG9wZW4gY2lyY3VpdCwgdGhlbiB0aGUgY2FwYWNpdG9yIGhhcyBm YWlsZWQgYW5kIG11c3QgYmUgcmVwbGFjZWQuDQoNCg0KLTENCg0KDQooaXMgdGhpcyBpbmZpbml0 ZT8pDQoNCg0KDQoNCg0KDQpUZXN0aW5nIFJlZ3VsYXRvci9SZWN0aWZpZXINCg0KDQpSZXN1bHQN Cg0KDQoNCg0KDQoNCg0KDQoNCldpdGggTWFzdGVyIHN3aXRjaCBvbjogTWVhc3VyZSB0aGUgdm9s dGFnZSBiZXR3ZWVuIGdyb3VuZCBhbmQgdGhlIHdpcmUgb24gdGhlIFIsIEIrICYgQyB0ZXJtaW5h bHMgaW4gdHVybjsgaXQgc2hvdWxkIGJlIHRoZSBiYXR0ZXJ5IHZvbHRhZ2UsIGFib3V0IDEyLjUg VkRDLg0KDQoNCg0KDQoNClINCg0KDQowLjAyDQoNCg0KDQoNCg0KQisNCg0KDQowLjAyDQoNCg0K DQoNCg0KQw0KDQoNCjAuMDINCg0KDQoNCg0KDQoNCg0KDQoNCldpdGggTWFzdGVyIHN3aXRjaCBv ZmY6IFRoZSBhYm92ZSB0ZXN0IHNob3VsZCBzaG93IDAgdm9sdGFnZSBmb3IgYWxsIHRocmVlIGNh c2VzLg0KDQoNCg0KDQoNClINCg0KDQowDQoNCg0KDQoNCg0KQisNCg0KDQowDQoNCg0KDQoNCg0K Qw0KDQoNCjANCg0KDQoNCg0KDQoNCg0KDQoNClRlc3QgdGhhdCBob3VzaW5nIG9mIHJlZ3VsYXRv ci9yZWN0aWZpZXIgaXMgcHJvcGVybHkgZ3JvdW5kZWQ6DQoNCg0KDQoNCg0KUmVzaXN0YW5jZSBi ZXR3ZWVuIHJlZ3VsYXRvciBob3VzaW5nIGFuZCBiYXR0ZXJ5IGdyb3VuZCBzaG91bGQgYmUgZXNz ZW50aWFsbHkgMC4NCg0KDQowDQoNCg0KDQoNCg0KDQoNCg0KDQpJZiB0aGUgd2lyaW5nIGZhaWxz IGFueSBvZiB0aGUgYWJvdmUgdGVzdHMsIHRoZSB3aXJpbmcgcHJvYmxlbSBuZWVkcyB0byBiZSBp c29sYXRlZCBhbmQgZml4ZWQuDQoNCg0KDQoNCg0KSWYgdGhlIHdpcmluZyBwYXNzZXMgdGhlIGFi b3ZlIHRlc3RzLCB5ZXQgb3V0cHV0IHZvbHRhZ2Ugb2YgdGhlIHJlZ3VsYXRvci9yZWN0aWZpZXIg aXMgbm90IGluIHRoZSBub3JtYWwgcmFuZ2UsIHRoZW4gdGhlIHJlZ3VsYXRvci9yZWN0aWZpZXIg bGlrZWx5IGlzIGZhdWx0eSBhbmQgc2hvdWxkIGJlIHJlcGxhY2VkLg0KDQoNCg0KDQoNCg0KDQpN eSB1bmRlcnN0YW5kaW5nIGlzIHRoYXQgdGhpcyBpcyBhIHdpcmluZyBwcm9ibGVtLCBubyB2b2x0 YWdlIGlzIGdldHRpbmcgdG8gdGhlIHJlZy9yZWN0Li4uIGJ1dCBJIGFtIHdvcnNlIHRoYW4gYSBu b3ZpY2UgYXQgdGhpcyDigJMgYSBsaXR0bGUga25vd2xlZGdlIGlzIGEgZGFuZ2Vyb3VzIHRoaW5n IQ0KDQoNCg0KVGhlIGFpcmNyYWZ0IGlzIHdpcmVkIGJhc2ljYWxseSBhY2NvcmRpbmcgdG8gdGhl IEV1cm9wYSBidWlsZCBtYW51YWwgKGJlbG93IG9yIGF0dGFjaGVkLCBkZXBlbmRpbmcgaG93IHlv dSBhcmUgdmlld2luZyB0aGlzKS4NCg0KDQoNCkFueSBjbHVlcyBhcyB0byB3aGVyZSBJIHNob3Vs ZCBiZWdpbiBsb29raW5nPw0KDQoNCg0KTWFueSB0aGFua3MgaW4gYWR2YW5jZSwNCg0KDQoNClBh dWwgTQ0KDQpFdXJvcGEgWFMgMzgzDQoNCjkxMlMNCg0KDQoNCltjaWQ6aW1hZ2UwMDEucG5nQDAx RDQzMEQzLjJBRjhENDEwXQ0KDQpbaHR0cHM6Ly9pcG1jZG4uYXZhc3QuY29tL2ltYWdlcy9pY29u cy9pY29uLWVudmVsb3BlLXRpY2stcm91bmQtb3JhbmdlLWFuaW1hdGVkLW5vLXJlcGVhdC12MS5n aWZdPGh0dHBzOi8vd3d3LmF2YXN0LmNvbS9zaWctZW1haWw/dXRtX21lZGl1bT1lbWFpbCZ1dG1f c291cmNlPWxpbmsmdXRtX2NhbXBhaWduPXNpZy1lbWFpbCZ1dG1fY29udGVudD13ZWJtYWlsPg0K DQpWaXJ1cy1mcmVlLiB3d3cuYXZhc3QuY29tPGh0dHBzOi8vd3d3LmF2YXN0LmNvbS9zaWctZW1h aWw/dXRtX21lZGl1bT1lbWFpbCZ1dG1fc291cmNlPWxpbmsmdXRtX2NhbXBhaWduPXNpZy1lbWFp bCZ1dG1fY29udGVudD13ZWJtYWlsPg0KDQoNCg= ________________________________________________________________________________
From: Clive Richards <stephencliverichards(at)gmail.com>
Subject: Re: Battery not charging
Date: Aug 10, 2018
Paul your test results show you are not connecting the battery to C B+ R on the regulator you need to check why has fuse blown or is master switch con tact faulty some circuits I have seen use a seperate contact to connect alt ernator the led connected to L should light with engine stopped if battery supply is connected to regulator. Clive Get Outlook for Android From: Paul Mansfield Sent: Friday, 10 August, 17:49 Subject: RE: RotaxEngines-List: Battery not charging y Ted, I didn't test the VDC with the engine running - I will do that tomor row and report back. Yes, the regulator case is grounded (I shall update th e wiring diag). Thanks again, Paul -----Original Message----- From: owner-r otaxengines-list-server(at)matronics.com On Behalf Of Temco Sent: 09 August 20 18 21:29 To: RotaxEngines-List Digest Server Subject: Re: RotaxEngines-List Paul It would appear that the AC part of your system is working ok. What D C voltage do you get when you put the positive probe on the Reg +B and and the black probe on system ground? This should be about 13.4 to about 14.2 V DC depending on the RPM of the engine, From you diagram, I do not see where the regulator is attached to system ground. Is the case of the regulator i ntended to be connected to system ground or was term L or R intended to be system ground?? Your capacitor is grounded but there is no indication of ho === ________________________________________________________________________________
Date: Sep 02, 2018
Subject: Official RotaxEngines-List FAQ (Frequently
Asked Questions) Thanks for your email, but I'm no longer using this mail account. My new email address is Johnb3042(at)gmail.com Thank you, JB ________________________________________________________________________________
Subject: Rotax 912 Flywheel Puller Rental
Date: Sep 07, 2018
Looking to borrow a 912 flywheel puller in the San Diego area. Or an idea for a good jury rig. Thanks! Guy Buchanan gebuchanan(at)cox.net 760 809-6145 -------- Guy Buchanan K-IV 1200 / 912Uls / Warp / 500 hours and flying again. Now a glider pilot too. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=482950#482950 ________________________________________________________________________________
Date: Sep 09, 2018
Subject: Auto Response: RotaxEngines-List Digest: 0 Msgs - 09/08/18
Thank you for the email. Please know that Howard has passed away. If you are NOT a solicitor, please contact his wife Judy at tudulu2(at)aol.com ________________________________________________________________________________
Subject: Re: Rotax 912 Flywheel Puller Rental
Date: Sep 09, 2018
You can borrow one from CPS. They loan tools at a tiny cost. Well worth doing vs spending big bucks for one time use items for the one time jobs. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483034#483034 ________________________________________________________________________________
Date: Sep 09, 2018
Thanks Roger. I'll call them. Guy On 9/9/2018 7:12 AM, Roger Lee wrote: > > You can borrow one from CPS. They loan tools at a tiny cost. Well worth doing vs spending big bucks for one time use items for the one time jobs. > > -------- > Roger Lee > Tucson, Az. > Rotax Instructor & Rotax IRC > Light Sport Repairman > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483034#483034 > > ________________________________________________________________________________
Subject: Capacitors
Date: Sep 24, 2018
On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at 25V is shown in the circuit. If you cannot find one capacitor of the exact Capaci tance, can one larger capacitor be used? Can two 10,000 aluminum electrolyt ic capacitors connected in parallel at that point in the circuit accomplish the same thing? Hugh G. McKay III, P.E. Fellow. L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Windows 10 ________________________________________________________________________________
Subject: Capacitors
Date: Sep 24, 2018
EBay has all kinds of 22,000 mf capacitors. Here are a few with free shipping. Super cheap: https://www.ebay.com/bhp/22000uf-capacitor John Hauck Kolb MKIII Titus, Alabama From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Hugh McKay Sent: Monday, September 24, 2018 3:22 PM Subject: RotaxEngines-List: Capacitors On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at 25V is shown in the circuit. If you cannot find one capacitor of the exact Capacitance, can one larger capacitor be used? Can two 10,000 aluminum electrolytic capacitors connected in parallel at that point in the circuit accomplish the same thing? Hugh G. McKay III, P.E. Fellow. L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Windows 10 ________________________________________________________________________________
Subject: Re: Capacitors
Date: Sep 25, 2018
Hi Hugh, I have 22K caps if you need one. The 22K is just a Rotax minimum. You can use larger. Rotax now uses 2 x 33K caps in the 912iS engine. The larger caps like 33K, 40K or 50K will work better than the 22K. The larger the cap capacitance the larger the physical size. The small cap like the 22K usually needs to have ends soldered on while the bigger caps have screw on terminals. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483354#483354 ________________________________________________________________________________
Date: Sep 25, 2018
Hi Hugh, I have 22K caps if you need one. The 22K is just a Rotax minimum. You can use larger. Rotax now uses 2 x 33K caps in the 912iS engine. The larger caps like 33K, 40K or 50K will work better than the 22K. The larger the cap capacitance the larger the physical size. The small cap like the 22K usually needs to have ends soldered on while the bigger caps have screw on terminals. Get the 105c temp rated ones. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483355#483355 ________________________________________________________________________________
Subject: Re: Rotax Service Class Oct. 6 & 7, 2018 in Tucson,
AZ
Date: Sep 25, 2018
Rotax Oct. 6th & 7th Class Directions Fly into Tucson International Airport (TIA) or fly your own plane into Ryan Airfield. Classes are Saturday and Sunday. All rental cars are on site at Tucson International Airport or Enterprise will pick you up if you fly into Ryan Airfield. Several hotels are just hundreds of yards down the street at TIA. Ryan Airport (KRYN) is only 10-12 minute drive. The entire experience is convenient and comfortable. The class is Oct. 6th & 7th, Saturday & Sunday. The class will start promptly at 0800 each day and plan on staying until 1700 hours. There will be class in the conference room each day in the morning and work in the hangar each day after the class presentation. There will be a lunch break each day at approximately 1130 hours. Please bring a laptop or tablet device in case you need to find Rotax information or manuals on line. There is Wi-Fi in the classroom. The class is being held at Ryan Airfield (KRYN) in Tucson, AZ. (9698 W Ajo Hwy). This is west of Tucson proper and city limits and approximately 12 minute drive from the Tucson Airport (TIA). If you fly in your own aircraft parking is right up at the back door of the conference room. Rental cars are available at Tucson Airport and Enterprise usually will pick you up at Ryan if you need a car from there. Directions to Ryan Airfield are as follows and can be reached by either Ajo Hwy or Valencia Rd. They both run right in front of Ryan Airport. The conference room is up front at the airport on Ajo Hwy. It is the only building out on Ajo Hwy and the only parking out on Ajo Hwy. General Directions: If you are staying in Tucson central or out by Interstate 10 then take I-10 to I-19 south. The turn right to go west bound on Ajo Hwy. Follow this road 12 miles out to Ryan Airfield. If you are staying in a hotel out by Tucson Airport off Valencia Rd. Just head west on Valencia until it dead ends right at Ryan Airfield on Ajo Hwy. There is a restaurant at Ryan field and you can have breakfast there. They open at 0600. Lunch is either at Ryan or at two other local restaurants. Prepare to learn and have fun doing it! For questions call Roger Lee in Tucson, Az at 520-574-1080 Home or 520-349-7056 cell or Bryan Toepfer at California Power Systems 505-550-8121. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483362#483362 ________________________________________________________________________________
Date: Sep 25, 2018
Subject: Re: RotaxEngines-List Digest: 2 Msgs - 09/24/18
For what it's worth, two 10,000 mF (microfarad) capacitors in parallel = 20,000 mF will be almost as good as one 22,000 mF capacitor. One capacitor > 22,000 mF will be fine, even better. But be fussy about having the working voltage (for any electrolytic capacitor) not less than 25 V. All this capacitor is doing is acting as a "short" to ground for radio frequency noise originating in the ignition circuit so that the noise does not mess up your radios. John Goodings, C-FGPJ CH601HD Zodiac Quoting RotaxEngines-List Digest Server : > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RotaxEngines-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RotaxEngines-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-09-24&Archive=RotaxEngines > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-09-24&Archive=RotaxEngines > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RotaxEngines-List Digest Archive > --- > Total Messages Posted Mon 09/24/18: 2 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 01:22 PM - Capacitors (Hugh McKay) > 2. 02:11 PM - Re: Capacitors (John Hauck) > > > ________________________________ Message 1 > _____________________________________ > > > From: Hugh McKay <hgmckay(at)bellsouth.net> > Subject: RotaxEngines-List: Capacitors > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at 25V is > shown in the circuit. If you cannot find one capacitor of the exact Capaci > tance, can one larger capacitor be used? Can two 10,000 aluminum electrolyt > ic capacitors connected in parallel at that point in the circuit accomplish > the same thing? > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > Ph. 704-661-8271 > Fax 704-483-5466 > Email hgmckay(at)bellsouth.net > http://www.geo.com (click on Power Division) > Sent from Mail for Windows 10 > > > ________________________________ Message 2 > _____________________________________ > > > From: "John Hauck" <jhauck(at)elmore.rr.com> > Subject: RE: RotaxEngines-List: Capacitors > > EBay has all kinds of 22,000 mf capacitors. Here are a few with free > shipping. Super cheap: > > > https://www.ebay.com/bhp/22000uf-capacitor > > > John Hauck > > Kolb MKIII > > Titus, Alabama > > > From: owner-rotaxengines-list-server(at)matronics.com > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Hugh > McKay > Sent: Monday, September 24, 2018 3:22 PM > Subject: RotaxEngines-List: Capacitors > > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at 25V > is shown in the circuit. If you cannot find one capacitor of the exact > Capacitance, can one larger capacitor be used? Can two 10,000 aluminum > electrolytic capacitors connected in parallel at that point in the > circuit accomplish the same thing? > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > Senior Consultant > > Worldwide Engineering Inc. > > 4090 North NC Hwy. 16 > > Denver, NC 28037 > > > Ph. 704-661-8271 > > Fax 704-483-5466 > > Email hgmckay(at)bellsouth.net > > http://www.geo.com (click on Power Division) > > Sent from Mail for > Windows 10 > > ________________________________________________________________________________
Subject: Capacitors
Date: Sep 25, 2018
Keep in mind that capacitors have a limited lifetime. The electrolites dry out. It is a real limit at high altitudes and dry climates. I get mine from digikey and go for the name brands. Y'all might look over your capacitors at the next annual. Good ones have dates on them and you can find the recommended lifetimes. ________________________________________________________________________________
Subject: Capacitors
Date: Sep 25, 2018
Date: Sep 25, 2018
John, isn't the ignition isolated from the starting/charging circuits (which is where the capacitor is located)? On Tue, Sep 25, 2018 at 1:51 PM wrote: > > For what it's worth, two 10,000 mF (microfarad) capacitors in parallel > 20,000 > mF will be almost as good as one 22,000 mF capacitor. One capacitor > > 22,000 mF > will be fine, even better. But be fussy about having the working voltage > (for > any electrolytic capacitor) not less than 25 V. All this capacitor is > doing is > acting as a "short" to ground for radio frequency noise originating in the > ignition circuit so that the noise does not mess up your radios. > > John Goodings, C-FGPJ CH601HD Zodiac > > > Quoting RotaxEngines-List Digest Server : > > > * > > > > ================================================= > > Online Versions of Today's List Digest Archive > > ================================================= > > > > Today's complete RotaxEngines-List Digest can also be found in either of > the > > two Web Links listed below. The .html file includes the Digest formatted > > in HTML for viewing with a web browser and features Hyperlinked Indexes > > and Message Navigation. The .txt file includes the plain ASCII version > > of the RotaxEngines-List Digest and can be viewed with a generic text > editor > > such as Notepad or with a web browser. > > > > HTML Version: > > > > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-09-24&Archive=RotaxEngines > > > > Text Version: > > > > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-09-24&Archive=RotaxEngines > > > > > > =============================================== > > EMail Version of Today's List Digest Archive > > =============================================== > > > > > > ---------------------------------------------------------- > > RotaxEngines-List Digest Archive > > --- > > Total Messages Posted Mon 09/24/18: 2 > > ---------------------------------------------------------- > > > > > > Today's Message Index: > > ---------------------- > > > > 1. 01:22 PM - Capacitors (Hugh McKay) > > 2. 02:11 PM - Re: Capacitors (John Hauck) > > > > > > > > ________________________________ Message 1 > > _____________________________________ > > > > > > From: Hugh McKay <hgmckay(at)bellsouth.net> > > Subject: RotaxEngines-List: Capacitors > > > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at 25V > is > > shown in the circuit. If you cannot find one capacitor of the exact > Capaci > > tance, can one larger capacitor be used? Can two 10,000 aluminum > electrolyt > > ic capacitors connected in parallel at that point in the circuit > accomplish > > the same thing? > > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > Senior Consultant > > Worldwide Engineering Inc. > > 4090 North NC Hwy. 16 > > Denver, NC 28037 > > > > Ph. 704-661-8271 > > Fax 704-483-5466 > > Email hgmckay(at)bellsouth.net > > http://www.geo.com (click on Power Division) > > Sent from Mail for Windows 10 > > > > > > ________________________________ Message 2 > > _____________________________________ > > > > > > From: "John Hauck" <jhauck(at)elmore.rr.com> > > Subject: RE: RotaxEngines-List: Capacitors > > > > EBay has all kinds of 22,000 mf capacitors. Here are a few with free > > shipping. Super cheap: > > > > > > https://www.ebay.com/bhp/22000uf-capacitor > > > > > > John Hauck > > > > Kolb MKIII > > > > Titus, Alabama > > > > > > From: owner-rotaxengines-list-server(at)matronics.com > > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Hugh > > McKay > > Sent: Monday, September 24, 2018 3:22 PM > > Subject: RotaxEngines-List: Capacitors > > > > > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at 25V > > is shown in the circuit. If you cannot find one capacitor of the exact > > Capacitance, can one larger capacitor be used? Can two 10,000 aluminum > > electrolytic capacitors connected in parallel at that point in the > > circuit accomplish the same thing? > > > > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > > > Senior Consultant > > > > Worldwide Engineering Inc. > > > > 4090 North NC Hwy. 16 > > > > Denver, NC 28037 > > > > > > Ph. 704-661-8271 > > > > Fax 704-483-5466 > > > > Email hgmckay(at)bellsouth.net > > > > http://www.geo.com (click on Power Division) > > > > Sent from Mail for > > Windows 10 > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 25, 2018
John, The working voltage for the Rotax 912 UL electrical system is 12 Volt s DC; much less than the 22,000 MF capacitor at 25 Volts as called for on t he Rotax engine diagram. How do you explain your statement that the working voltage should not be less than 25Volts? Hugh G. McKay III, P.E. Fellow. L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Windows 10 From: goodings(at)yorku.ca Sent: Tuesday, September 25, 2018 3:48 PM Subject: RotaxEngines-List: Re: RotaxEngines-List Digest: 2 Msgs - 09/24/18 For what it's worth, two 10,000 mF (microfarad) capacitors in parallel = 20,000 mF will be almost as good as one 22,000 mF capacitor. One capacitor > 22,00 0 mF will be fine, even better. But be fussy about having the working voltage (f or any electrolytic capacitor) not less than 25 V. All this capacitor is doing is acting as a "short" to ground for radio frequency noise originating in the ignition circuit so that the noise does not mess up your radios. John Goodings, C-FGPJ CH601HD Zodiac Quoting RotaxEngines-List Digest Server : > * > > ======================== > Online Versions of Today's List Digest Archive > ======================== > > Today's complete RotaxEngines-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RotaxEngines-List Digest and can be viewed with a generic text edi tor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Ch apter 18-09-24&Archive=RotaxEngines > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Cha pter 18-09-24&Archive=RotaxEngines > > > ======================== ======================= > EMail Version of Today's List Digest Archive > ======================== ======================= > > > ---------------------------------------------------------- > RotaxEngines-List Digest Archive > --- > Total Messages Posted Mon 09/24/18: 2 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 01:22 PM - Capacitors (Hugh McKay) > 2. 02:11 PM - Re: Capacitors (John Hauck) > > > ________________________________ Message 1 > _____________________________________ > > > From: Hugh McKay <hgmckay(at)bellsouth.net> > Subject: RotaxEngines-List: Capacitors > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at 25V is > shown in the circuit. If you cannot find one capacitor of the exact Capa ci > tance, can one larger capacitor be used? Can two 10,000 aluminum electrol yt > ic capacitors connected in parallel at that point in the circuit accompli sh > the same thing? > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > Ph. 704-661-8271 > Fax 704-483-5466 > Email hgmckay(at)bellsouth.net > http://www.geo.com (click on Power Division) > Sent from Mail for Windows 10 > > > ________________________________ Message 2 > _____________________________________ > > > From: "John Hauck" <jhauck(at)elmore.rr.com> > Subject: RE: RotaxEngines-List: Capacitors > > EBay has all kinds of 22,000 mf capacitors. Here are a few with free > shipping. Super cheap: > > > https://www.ebay.com/bhp/22000uf-capacitor > > > John Hauck > > Kolb MKIII > > Titus, Alabama > > > From: owner-rotaxengines-list-server(at)matronics.com > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Hugh > McKay > Sent: Monday, September 24, 2018 3:22 PM > Subject: RotaxEngines-List: Capacitors > > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at 25V > is shown in the circuit. If you cannot find one capacitor of the exact > Capacitance, can one larger capacitor be used? Can two 10,000 aluminum > electrolytic capacitors connected in parallel at that point in the > circuit accomplish the same thing? > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > Senior Consultant > > Worldwide Engineering Inc. > > 4090 North NC Hwy. 16 > > Denver, NC 28037 > > > Ph. 704-661-8271 > > Fax 704-483-5466 > > Email hgmckay(at)bellsouth.net > > http://www.geo.com (click on Power Division) > > Sent from Mail for > Windows 10 > > ________________________________________________________________________________
Date: Sep 26, 2018
Subject: Re: RotaxEngines-List Digest: 8 Msgs - 09/25/18
In answer to Hugh McKay's question about the working voltage of an electrolytic capacitor, I always want a safety margin on electolytics. I have had 100 V wkg electrolytics blow at 100 V, etc., particularly when they have been in use for a while. I always want a safety factor of 2 at least on electrolytic capacitors. I would never put a 12 V wkg electrolytic in a 12 V circuit. Can save you grief! John Goodings, FGPJ CH601HD Zodiac Quoting RotaxEngines-List Digest Server : > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RotaxEngines-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RotaxEngines-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-09-25&Archive=RotaxEngines > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-09-25&Archive=RotaxEngines > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RotaxEngines-List Digest Archive > --- > Total Messages Posted Tue 09/25/18: 8 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 06:51 AM - Re: Capacitors (Roger Lee) > 2. 06:52 AM - Re: Capacitors (Roger Lee) > 3. 12:31 PM - Re: Rotax Service Class Oct. 6 & 7, 2018 in Tucson, AZ > (Roger Lee) > 4. 12:46 PM - Re: RotaxEngines-List Digest: 2 Msgs - 09/24/18 > (goodings(at)yorku.ca) > 5. 02:20 PM - Capacitors (John Elling) > 6. 02:20 PM - Capacitors (John Elling) > 7. 02:32 PM - Re: Re: RotaxEngines-List Digest: 2 Msgs - 09/24/18 (Ken > Ryan) > 8. 03:15 PM - Re: Re: RotaxEngines-List Digest: 2 Msgs - 09/24/18 (Hugh > McKay) > > > ________________________________ Message 1 > _____________________________________ > > > Subject: RotaxEngines-List: Re: Capacitors > From: "Roger Lee" <ssadiver1(at)yahoo.com> > > > Hi Hugh, > > I have 22K caps if you need one. > > The 22K is just a Rotax minimum. You can use larger. Rotax now uses 2 x 33K > caps > in the 912iS engine. The larger caps like 33K, 40K or 50K will work better > than > the 22K. The larger the cap capacitance the larger the physical size. The > small cap like the 22K usually needs to have ends soldered on while the > bigger > caps have screw on terminals. > > -------- > Roger Lee > Tucson, Az. > Rotax Instructor & Rotax IRC > Light Sport Repairman > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483354#483354 > > > ________________________________ Message 2 > _____________________________________ > > > Subject: RotaxEngines-List: Re: Capacitors > From: "Roger Lee" <ssadiver1(at)yahoo.com> > > > Hi Hugh, > > I have 22K caps if you need one. > > The 22K is just a Rotax minimum. You can use larger. Rotax now uses 2 x 33K > caps > in the 912iS engine. The larger caps like 33K, 40K or 50K will work better > than > the 22K. The larger the cap capacitance the larger the physical size. The > small cap like the 22K usually needs to have ends soldered on while the > bigger > caps have screw on terminals. Get the 105c temp rated ones. > > -------- > Roger Lee > Tucson, Az. > Rotax Instructor & Rotax IRC > Light Sport Repairman > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483355#483355 > > > ________________________________ Message 3 > _____________________________________ > > > Subject: RotaxEngines-List: Re: Rotax Service Class Oct. 6 & 7, 2018 in > Tucson, > AZ > From: "Roger Lee" <ssadiver1(at)yahoo.com> > > > Rotax Oct. 6th & 7th Class Directions > > Fly into Tucson International Airport (TIA) or fly your own plane into Ryan > Airfield. > Classes are Saturday and Sunday. All rental cars are on site at Tucson > International Airport or Enterprise will pick you up if you fly into Ryan > Airfield. > Several hotels are just hundreds of yards down the street at TIA. Ryan > Airport > (KRYN) is only 10-12 minute drive. The entire experience is convenient > and comfortable. > > The class is Oct. 6th & 7th, Saturday & Sunday. The class will start promptly > at > 0800 each day and plan on staying until 1700 hours. There will be class in > the > conference room each day in the morning and work in the hangar each day after > the class presentation. There will be a lunch break each day at approximately > 1130 hours. > Please bring a laptop or tablet device in case you need to find Rotax > information > or manuals on line. There is Wi-Fi in the classroom. > The class is being held at Ryan Airfield (KRYN) in Tucson, AZ. (9698 W Ajo > Hwy). > This is west of Tucson proper and city limits and approximately 12 minute > drive > from the Tucson Airport (TIA). If you fly in your own aircraft parking is > right up at the back door of the conference room. Rental cars are available > at > Tucson Airport and Enterprise usually will pick you up at Ryan if you need a > car from there. > > Directions to Ryan Airfield are as follows and can be reached by either Ajo > Hwy > or Valencia Rd. They both run right in front of Ryan Airport. The conference > room is up front at the airport on Ajo Hwy. It is the only building out on > Ajo > Hwy and the only parking out on Ajo Hwy. > > General Directions: > If you are staying in Tucson central or out by Interstate 10 then take I-10 > to > I-19 south. The turn right to go west bound on Ajo Hwy. Follow this road 12 > miles > out to Ryan Airfield. > If you are staying in a hotel out by Tucson Airport off Valencia Rd. Just > head > west on Valencia until it dead ends right at Ryan Airfield on Ajo Hwy. > > There is a restaurant at Ryan field and you can have breakfast there. They > open > at 0600. Lunch is either at Ryan or at two other local restaurants. > > Prepare to learn and have fun doing it! > > For questions call Roger Lee in Tucson, Az at 520-574-1080 Home or > 520-349-7056 > cell or Bryan Toepfer at California Power Systems 505-550-8121. > > -------- > Roger Lee > Tucson, Az. > Rotax Instructor & Rotax IRC > Light Sport Repairman > Home 520-574-1080 TRY HOME FIRST > Cell 520-349-7056 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=483362#483362 > > > ________________________________ Message 4 > _____________________________________ > > > From: goodings(at)yorku.ca > Subject: RotaxEngines-List: Re: RotaxEngines-List Digest: 2 Msgs - 09/24/18 > > > For what it's worth, two 10,000 mF (microfarad) capacitors in parallel > 20,000 > mF will be almost as good as one 22,000 mF capacitor. One capacitor > 22,000 > mF > will be fine, even better. But be fussy about having the working voltage (for > any electrolytic capacitor) not less than 25 V. All this capacitor is doing > is > acting as a "short" to ground for radio frequency noise originating in the > ignition circuit so that the noise does not mess up your radios. > > John Goodings, C-FGPJ CH601HD Zodiac > > > Quoting RotaxEngines-List Digest Server : > > > * > > > > ================================================ > > Online Versions of Today's List Digest Archive > > ================================================ > > > > Today's complete RotaxEngines-List Digest can also be found in either of > the > > two Web Links listed below. The .html file includes the Digest formatted > > in HTML for viewing with a web browser and features Hyperlinked Indexes > > and Message Navigation. The .txt file includes the plain ASCII version > > of the RotaxEngines-List Digest and can be viewed with a generic text > editor > > such as Notepad or with a web browser. > > > > HTML Version: > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter > 18-09-24&Archive=RotaxEngines > > > > Text Version: > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter > 18-09-24&Archive=RotaxEngines > > > > > > ============================================== > > EMail Version of Today's List Digest Archive > > ============================================== > > > > > > ---------------------------------------------------------- > > RotaxEngines-List Digest Archive > > --- > > Total Messages Posted Mon 09/24/18: 2 > > ---------------------------------------------------------- > > > > > > Today's Message Index: > > ---------------------- > > > > 1. 01:22 PM - Capacitors (Hugh McKay) > > 2. 02:11 PM - Re: Capacitors (John Hauck) > > > > > > ________________________________ Message 1 > > _____________________________________ > > > > > > From: Hugh McKay <hgmckay(at)bellsouth.net> > > Subject: RotaxEngines-List: Capacitors > > > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at 25V is > > shown in the circuit. If you cannot find one capacitor of the exact Capaci > > tance, can one larger capacitor be used? Can two 10,000 aluminum electrolyt > > ic capacitors connected in parallel at that point in the circuit accomplish > > the same thing? > > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > Senior Consultant > > Worldwide Engineering Inc. > > 4090 North NC Hwy. 16 > > Denver, NC 28037 > > > > Ph. 704-661-8271 > > Fax 704-483-5466 > > Email hgmckay(at)bellsouth.net > > http://www.geo.com (click on Power Division) > > Sent from Mail for Windows 10 > > > > > > ________________________________ Message 2 > > _____________________________________ > > > > > > From: "John Hauck" <jhauck(at)elmore.rr.com> > > Subject: RE: RotaxEngines-List: Capacitors > > > > EBay has all kinds of 22,000 mf capacitors. Here are a few with free > > shipping. Super cheap: > > > > > > https://www.ebay.com/bhp/22000uf-capacitor > > > > > > John Hauck > > > > Kolb MKIII > > > > Titus, Alabama > > > > > > From: owner-rotaxengines-list-server(at)matronics.com > > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Hugh > > McKay > > Sent: Monday, September 24, 2018 3:22 PM > > Subject: RotaxEngines-List: Capacitors > > > > > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at 25V > > is shown in the circuit. If you cannot find one capacitor of the exact > > Capacitance, can one larger capacitor be used? Can two 10,000 aluminum > > electrolytic capacitors connected in parallel at that point in the > > circuit accomplish the same thing? > > > > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > > > Senior Consultant > > > > Worldwide Engineering Inc. > > > > 4090 North NC Hwy. 16 > > > > Denver, NC 28037 > > > > > > Ph. 704-661-8271 > > > > Fax 704-483-5466 > > > > Email hgmckay(at)bellsouth.net > > > > http://www.geo.com (click on Power Division) > > > > Sent from Mail for > > Windows 10 > > > > > > > ________________________________ Message 5 > _____________________________________ > > > Subject: RotaxEngines-List: Capacitors > From: John Elling <jelling(at)newmexico.com> > > > Keep in mind that capacitors have a limited lifetime. The electrolites > dry out. It is a real limit at high altitudes and dry climates. > > I get mine from digikey and go for the name brands. > > Y'all might look over your capacitors at the next annual. Good ones > have dates on them and you can find the recommended lifetimes. > > > ________________________________ Message 6 > _____________________________________ > > > Subject: RotaxEngines-List: Capacitors > From: John Elling <jelling(at)newmexico.com> > > > Keep in mind that capacitors have a limited lifetime. The electrolites > dry out. It is a real limit at high altitudes and dry climates. > > I get mine from digikey and go for the name brands. > > Y'all might look over your capacitors at the next annual. Good ones > have dates on them and you can find the recommended lifetimes. > > > ________________________________ Message 7 > _____________________________________ > > > From: Ken Ryan <keninalaska(at)gmail.com> > Subject: Re: RotaxEngines-List: Re: RotaxEngines-List Digest: 2 Msgs - > 09/24/18 > > John, isn't the ignition isolated from the starting/charging circuits > (which is where the capacitor is located)? > > > On Tue, Sep 25, 2018 at 1:51 PM wrote: > > > > > For what it's worth, two 10,000 mF (microfarad) capacitors in parallel > > 20,000 > > mF will be almost as good as one 22,000 mF capacitor. One capacitor > > > 22,000 mF > > will be fine, even better. But be fussy about having the working voltage > > (for > > any electrolytic capacitor) not less than 25 V. All this capacitor is > > doing is > > acting as a "short" to ground for radio frequency noise originating in the > > ignition circuit so that the noise does not mess up your radios. > > > > John Goodings, C-FGPJ CH601HD Zodiac > > > > > > Quoting RotaxEngines-List Digest Server : > > > > > * > > > > > > ================================================ > > > Online Versions of Today's List Digest Archive > > > ================================================ > > > > > > Today's complete RotaxEngines-List Digest can also be found in either of > > the > > > two Web Links listed below. The .html file includes the Digest formatted > > > in HTML for viewing with a web browser and features Hyperlinked Indexes > > > and Message Navigation. The .txt file includes the plain ASCII version > > > of the RotaxEngines-List Digest and can be viewed with a generic text > > editor > > > such as Notepad or with a web browser. > > > > > > HTML Version: > > > > > > > > > > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter > 18-09-24&Archive=RotaxEngines > > > > > > Text Version: > > > > > > > > > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter > 18-09-24&Archive=RotaxEngines > > > > > > > > > ============================================== > > > EMail Version of Today's List Digest Archive > > > ============================================== > > > > > > > > > ---------------------------------------------------------- > > > RotaxEngines-List Digest Archive > > > --- > > > Total Messages Posted Mon 09/24/18: 2 > > > ---------------------------------------------------------- > > > > > > > > > Today's Message Index: > > > ---------------------- > > > > > > 1. 01:22 PM - Capacitors (Hugh McKay) > > > 2. 02:11 PM - Re: Capacitors (John Hauck) > > > > > > > > > > > > ________________________________ Message 1 > > > _____________________________________ > > > > > > > > > From: Hugh McKay <hgmckay(at)bellsouth.net> > > > Subject: RotaxEngines-List: Capacitors > > > > > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at 25V > > is > > > shown in the circuit. If you cannot find one capacitor of the exact > > Capaci > > > tance, can one larger capacitor be used? Can two 10,000 aluminum > > electrolyt > > > ic capacitors connected in parallel at that point in the circuit > > accomplish > > > the same thing? > > > > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > > Senior Consultant > > > Worldwide Engineering Inc. > > > 4090 North NC Hwy. 16 > > > Denver, NC 28037 > > > > > > Ph. 704-661-8271 > > > Fax 704-483-5466 > > > Email hgmckay(at)bellsouth.net > > > http://www.geo.com (click on Power Division) > > > Sent from Mail for Windows 10 > > > > > > > > > ________________________________ Message 2 > > > _____________________________________ > > > > > > > > > From: "John Hauck" <jhauck(at)elmore.rr.com> > > > Subject: RE: RotaxEngines-List: Capacitors > > > > > > EBay has all kinds of 22,000 mf capacitors. Here are a few with free > > > shipping. Super cheap: > > > > > > > > > https://www.ebay.com/bhp/22000uf-capacitor > > > > > > > > > John Hauck > > > > > > Kolb MKIII > > > > > > Titus, Alabama > > > > > > > > > From: owner-rotaxengines-list-server(at)matronics.com > > > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Hugh > > > McKay > > > Sent: Monday, September 24, 2018 3:22 PM > > > Subject: RotaxEngines-List: Capacitors > > > > > > > > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at 25V > > > is shown in the circuit. If you cannot find one capacitor of the exact > > > Capacitance, can one larger capacitor be used? Can two 10,000 aluminum > > > electrolytic capacitors connected in parallel at that point in the > > > circuit accomplish the same thing? > > > > > > > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > > > > > Senior Consultant > > > > > > Worldwide Engineering Inc. > > > > > > 4090 North NC Hwy. 16 > > > > > > Denver, NC 28037 > > > > > > > > > Ph. 704-661-8271 > > > > > > Fax 704-483-5466 > > > > > > Email hgmckay(at)bellsouth.net > > > > > > http://www.geo.com (click on Power Division) > > > > > > Sent from Mail for > > > Windows 10 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________ Message 8 > _____________________________________ > > > From: Hugh McKay <hgmckay(at)bellsouth.net> > Subject: RE: RotaxEngines-List: Re: RotaxEngines-List Digest: 2 Msgs - > 09/24/18 > > John, The working voltage for the Rotax 912 UL electrical system is 12 Volt > s DC; much less than the 22,000 MF capacitor at 25 Volts as called for on t > he Rotax engine diagram. How do you explain your statement that the working > voltage should not be less than 25Volts? > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > Ph. 704-661-8271 > Fax 704-483-5466 > Email hgmckay(at)bellsouth.net > http://www.geo.com (click on Power Division) > Sent from Mail for Windows 10 > > From: goodings(at)yorku.ca > Sent: Tuesday, September 25, 2018 3:48 PM > Subject: RotaxEngines-List: Re: RotaxEngines-List Digest: 2 Msgs - 09/24/18 > > > For what it's worth, two 10,000 mF (microfarad) capacitors in parallel > 20,000 > mF will be almost as good as one 22,000 mF capacitor. One capacitor > 22,00 > 0 mF > will be fine, even better. But be fussy about having the working voltage (f > or > any electrolytic capacitor) not less than 25 V. All this capacitor is doing > is > acting as a "short" to ground for radio frequency noise originating in the > ignition circuit so that the noise does not mess up your radios. > > John Goodings, C-FGPJ CH601HD Zodiac > > > Quoting RotaxEngines-List Digest Server : > > > * > > > > ======================= > > > Online Versions of Today's List Digest Archive > > ======================= > > > > > Today's complete RotaxEngines-List Digest can also be found in either of > the > > two Web Links listed below. The .html file includes the Digest formatted > > in HTML for viewing with a web browser and features Hyperlinked Indexes > > and Message Navigation. The .txt file includes the plain ASCII version > > of the RotaxEngines-List Digest and can be viewed with a generic text edi > tor > > such as Notepad or with a web browser. > > > > HTML Version: > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Ch > apter 18-09-24&Archive=RotaxEngines > > > > Text Version: > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Cha > pter 18-09-24&Archive=RotaxEngines > > > > > > ======================= > ====================== > > EMail Version of Today's List Digest Archive > > ======================= > ====================== > > > > > > ---------------------------------------------------------- > > RotaxEngines-List Digest Archive > > --- > > Total Messages Posted Mon 09/24/18: 2 > > ---------------------------------------------------------- > > > > > > Today's Message Index: > > ---------------------- > > > > 1. 01:22 PM - Capacitors (Hugh McKay) > > 2. 02:11 PM - Re: Capacitors (John Hauck) > > > > > > ________________________________ Message 1 > > _____________________________________ > > > > > > From: Hugh McKay <hgmckay(at)bellsouth.net> > > Subject: RotaxEngines-List: Capacitors > > > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at 25V > is > > shown in the circuit. If you cannot find one capacitor of the exact Capa > ci > > tance, can one larger capacitor be used? Can two 10,000 aluminum electrol > yt > > ic capacitors connected in parallel at that point in the circuit accompli > sh > > the same thing? > > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > Senior Consultant > > Worldwide Engineering Inc. > > 4090 North NC Hwy. 16 > > Denver, NC 28037 > > > > Ph. 704-661-8271 > > Fax 704-483-5466 > > Email hgmckay(at)bellsouth.net > > http://www.geo.com (click on Power Division) > > Sent from Mail for Windows 10 > > > > > > ________________________________ Message 2 > > _____________________________________ > > > > > > From: "John Hauck" <jhauck(at)elmore.rr.com> > > Subject: RE: RotaxEngines-List: Capacitors > > > > EBay has all kinds of 22,000 mf capacitors. Here are a few with free > > shipping. Super cheap: > > > > > > https://www.ebay.com/bhp/22000uf-capacitor > > > > > > John Hauck > > > > Kolb MKIII > > > > Titus, Alabama > > > > > > From: owner-rotaxengines-list-server(at)matronics.com > > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Hugh > > McKay > > Sent: Monday, September 24, 2018 3:22 PM > > Subject: RotaxEngines-List: Capacitors > > > > > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at 25V > > is shown in the circuit. If you cannot find one capacitor of the exact > > Capacitance, can one larger capacitor be used? Can two 10,000 aluminum > > electrolytic capacitors connected in parallel at that point in the > > circuit accomplish the same thing? > > > > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > > > Senior Consultant > > > > Worldwide Engineering Inc. > > > > 4090 North NC Hwy. 16 > > > > Denver, NC 28037 > > > > > > Ph. 704-661-8271 > > > > Fax 704-483-5466 > > > > Email hgmckay(at)bellsouth.net > > > > http://www.geo.com (click on Power Division) > > > > Sent from Mail for > > Windows 10 > > > > > > ________________________________________________________________________________
Date: Sep 26, 2018
Subject: Capacitors
VG90YWxseSBhZ3JlZSEKRWJheSBpcyBhIGdyZWF0IHBsYWNlIHRvIHNob3AgZm9yIDIgYW5kIDQg Y3ljbGUgcGFydHMuIFNvbWUgcGVvcGxlIGNvbXBsYWluIGFib3V0IEViYXkgYnV0IEkndmUgbmV2 ZXIgaGFkIHRyb3VibGUgaW4geWVhcnMgb2YgdXNpbmcgaXQgJiBoYXZlIHNhdmVkIGEgdG9uIG9m IG1vbmV5IQpUaGUgcHJpY2VzIGZyb20gcmV0YWlsZXJzIGFyZSByZWRpY3Vsb3VzIQoKClNlbnQg ZnJvbSBteSBWZXJpem9uLCBTYW1zdW5nIEdhbGF4eSBUYWJsZXQKPCEtLQovKiBGb250IERlZmlu aXRpb25zICovCkBmb250LWZhY2UKCXtmb250LWZhbWlseToiQ2FtYnJpYSBNYXRoIjsKCXBhbm9z ZS0xOjIgNCA1IDMgNSA0IDYgMyAyIDQ7fQpAZm9udC1mYWNlCgl7Zm9udC1mYW1pbHk6Q2FsaWJy aTsKCXBhbm9zZS0xOjIgMTUgNSAyIDIgMiA0IDMgMiA0O30KQGZvbnQtZmFjZQoJe2ZvbnQtZmFt aWx5OlRhaG9tYTsKCXBhbm9zZS0xOjIgMTEgNiA0IDMgNSA0IDQgMiA0O30KLyogU3R5bGUgRGVm aW5pdGlvbnMgKi8KcC5Nc29Ob3JtYWwsIGxpLk1zb05vcm1hbCwgZGl2Lk1zb05vcm1hbAoJe21h cmdpbjowaW47CgltYXJnaW4tYm90dG9tOi4wMDAxcHQ7Cglmb250LXNpemU6MTEuMHB0OwoJZm9u dC1mYW1pbHk6IkNhbGlicmkiLCJzYW5zLXNlcmlmIjt9CmE6bGluaywgc3Bhbi5Nc29IeXBlcmxp bmsKCXttc28tc3R5bGUtcHJpb3JpdHk6OTk7Cgljb2xvcjpibHVlOwoJdGV4dC1kZWNvcmF0aW9u OnVuZGVybGluZTt9CmE6dmlzaXRlZCwgc3Bhbi5Nc29IeXBlcmxpbmtGb2xsb3dlZAoJe21zby1z dHlsZS1wcmlvcml0eTo5OTsKCWNvbG9yOiM5NTRGNzI7Cgl0ZXh0LWRlY29yYXRpb246dW5kZXJs aW5lO30Kc3Bhbi5FbWFpbFN0eWxlMTcKCXttc28tc3R5bGUtdHlwZTpwZXJzb25hbC1yZXBseTsK CWZvbnQtZmFtaWx5OiJDYWxpYnJpIiwic2Fucy1zZXJpZiI7Cgljb2xvcjojMUY0OTdEO30KLk1z b0NocERlZmF1bHQKCXttc28tc3R5bGUtdHlwZTpleHBvcnQtb25seTsKCWZvbnQtc2l6ZToxMC4w cHQ7fQpAcGFnZSBXb3JkU2VjdGlvbjEKCXtzaXplOjguNWluIDExLjBpbjsKCW1hcmdpbjoxLjBp biAxLjBpbiAxLjBpbiAxLjBpbjt9CmRpdi5Xb3JkU2VjdGlvbjEKCXtwYWdlOldvcmRTZWN0aW9u MTt9Ci0tPi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS1Gcm9tOiBKb2huIEhhdWNr IDxqaGF1Y2tAZWxtb3JlLnJyLmNvbT4gRGF0ZTogOS8yNC8xOCAgNToxMSBQTSAgKEdNVC0wNTow MCkgVG86IHJvdGF4ZW5naW5lcy1saXN0QG1hdHJvbmljcy5jb20gU3ViamVjdDogUkU6IFJvdGF4 RW5naW5lcy1MaXN0OiBDYXBhY2l0b3JzIApFQmF5IGhhcyBhbGwga2luZHMgb2YgMjIsMDAwIG1m IGNhcGFjaXRvcnMuwqAgSGVyZSBhcmUgYSBmZXcgd2l0aCBmcmVlIHNoaXBwaW5nLsKgIFN1cGVy IGNoZWFwOsKgaHR0cHM6Ly93d3cuZWJheS5jb20vYmhwLzIyMDAwdWYtY2FwYWNpdG9ywqBKb2hu IEhhdWNrS29sYiBNS0lJSVRpdHVzLCBBbGFiYW1hwqBGcm9tOiBvd25lci1yb3RheGVuZ2luZXMt bGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSBbbWFpbHRvOm93bmVyLXJvdGF4ZW5naW5lcy1saXN0 LXNlcnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2YgSHVnaCBNY0theQpTZW50OiBNb25k YXksIFNlcHRlbWJlciAyNCwgMjAxOCAzOjIyIFBNClRvOiBSb3RheCBFbmdpbmVzClN1YmplY3Q6 IFJvdGF4RW5naW5lcy1MaXN0OiBDYXBhY2l0b3JzwqBPbiB0aGUgUm90YXggOTEyIFVMIGVuZ2lu ZSB3aXJpbmcgZGlhZ3JhbSBvbmUgMjIsMDAwIFVGIGNhcGFjaXRvciBhdCAyNVYgaXMgc2hvd24g aW4gdGhlIGNpcmN1aXQuIElmIHlvdSBjYW5ub3QgZmluZCBvbmUgY2FwYWNpdG9yIG9mIHRoZSBl eGFjdCBDYXBhY2l0YW5jZSwgY2FuIG9uZSBsYXJnZXIgY2FwYWNpdG9yIGJlIHVzZWQ/IENhbiB0 d28gMTAsMDAwIGFsdW1pbnVtIGVsZWN0cm9seXRpYyBjYXBhY2l0b3JzIGNvbm5lY3RlZCBpbiBw YXJhbGxlbCBhdCB0aGF0IHBvaW50IGluIHRoZSBjaXJjdWl0IGFjY29tcGxpc2ggdGhlIHNhbWUg dGhpbmc/wqBIdWdoIEcuIE1jS2F5IElJSSwgUC5FLiBGZWxsb3cuIEwuTS4gQVNDRVNlbmlvciBD b25zdWx0YW50V29ybGR3aWRlIEVuZ2luZWVyaW5nIEluYy40MDkwIE5vcnRoIE5DIEh3eS4gMTZE ZW52ZXIsIE5DIDI4MDM3wqBQaC4gNzA0LTY2MS04MjcxRmF4IDcwNC00ODMtNTQ2NkVtYWlsIGhn bWNrYXlAYmVsbHNvdXRoLm5ldCBodHRwOi8vd3d3Lmdlby5jb20gKGNsaWNrIG9uIFBvd2VyIERp dmlzaW9uKVNlbnQgZnJvbSBNYWlsIGZvciBXaW5kb3dzIDEwwqA ________________________________________________________________________________
Date: Sep 26, 2018
Thanks for sharing your insight, Sir. On Wed, Sep 26, 2018 at 7:05 AM wrote: > > In answer to Hugh McKay's question about the working voltage of an > electrolytic > capacitor, I always want a safety margin on electolytics. I have had 100 V > wkg > electrolytics blow at 100 V, etc., particularly when they have been in use > for > a while. I always want a safety factor of 2 at least on electrolytic > capacitors. I would never put a 12 V wkg electrolytic in a 12 V circuit. > Can > save you grief! > > John Goodings, FGPJ CH601HD Zodiac > > > Quoting RotaxEngines-List Digest Server : > > > * > > > > ================================================= > > Online Versions of Today's List Digest Archive > > ================================================= > > > > Today's complete RotaxEngines-List Digest can also be found in either of > the > > two Web Links listed below. The .html file includes the Digest formatted > > in HTML for viewing with a web browser and features Hyperlinked Indexes > > and Message Navigation. The .txt file includes the plain ASCII version > > of the RotaxEngines-List Digest and can be viewed with a generic text > editor > > such as Notepad or with a web browser. > > > > HTML Version: > > > > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-09-25&Archive=RotaxEngines > > > > Text Version: > > > > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-09-25&Archive=RotaxEngines > > > > > > =============================================== > > EMail Version of Today's List Digest Archive > > =============================================== > > > > > > ---------------------------------------------------------- > > RotaxEngines-List Digest Archive > > --- > > Total Messages Posted Tue 09/25/18: 8 > > ---------------------------------------------------------- > > > > > > Today's Message Index: > > ---------------------- > > > > 1. 06:51 AM - Re: Capacitors (Roger Lee) > > 2. 06:52 AM - Re: Capacitors (Roger Lee) > > 3. 12:31 PM - Re: Rotax Service Class Oct. 6 & 7, 2018 in Tucson, AZ > > (Roger Lee) > > 4. 12:46 PM - Re: RotaxEngines-List Digest: 2 Msgs - 09/24/18 > > (goodings(at)yorku.ca) > > 5. 02:20 PM - Capacitors (John Elling) > > 6. 02:20 PM - Capacitors (John Elling) > > 7. 02:32 PM - Re: Re: RotaxEngines-List Digest: 2 Msgs - 09/24/18 > (Ken > > Ryan) > > 8. 03:15 PM - Re: Re: RotaxEngines-List Digest: 2 Msgs - 09/24/18 > (Hugh > > McKay) > > > > > > > > ________________________________ Message 1 > > _____________________________________ > > > > > > Subject: RotaxEngines-List: Re: Capacitors > > From: "Roger Lee" <ssadiver1(at)yahoo.com> > > > > > > Hi Hugh, > > > > I have 22K caps if you need one. > > > > The 22K is just a Rotax minimum. You can use larger. Rotax now uses 2 x > 33K > > caps > > in the 912iS engine. The larger caps like 33K, 40K or 50K will work > better > > than > > the 22K. The larger the cap capacitance the larger the physical size. The > > small cap like the 22K usually needs to have ends soldered on while the > > bigger > > caps have screw on terminals. > > > > -------- > > Roger Lee > > Tucson, Az. > > Rotax Instructor & Rotax IRC > > Light Sport Repairman > > Home 520-574-1080 TRY HOME FIRST > > Cell 520-349-7056 > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=483354#483354 > > > > > > ________________________________ Message 2 > > _____________________________________ > > > > > > Subject: RotaxEngines-List: Re: Capacitors > > From: "Roger Lee" <ssadiver1(at)yahoo.com> > > > > > > Hi Hugh, > > > > I have 22K caps if you need one. > > > > The 22K is just a Rotax minimum. You can use larger. Rotax now uses 2 x > 33K > > caps > > in the 912iS engine. The larger caps like 33K, 40K or 50K will work > better > > than > > the 22K. The larger the cap capacitance the larger the physical size. The > > small cap like the 22K usually needs to have ends soldered on while the > > bigger > > caps have screw on terminals. Get the 105c temp rated ones. > > > > -------- > > Roger Lee > > Tucson, Az. > > Rotax Instructor & Rotax IRC > > Light Sport Repairman > > Home 520-574-1080 TRY HOME FIRST > > Cell 520-349-7056 > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=483355#483355 > > > > > > ________________________________ Message 3 > > _____________________________________ > > > > > > Subject: RotaxEngines-List: Re: Rotax Service Class Oct. 6 & 7, 2018 in > > Tucson, > > AZ > > From: "Roger Lee" <ssadiver1(at)yahoo.com> > > > > > > Rotax Oct. 6th & 7th Class Directions > > > > Fly into Tucson International Airport (TIA) or fly your own plane into > Ryan > > Airfield. > > Classes are Saturday and Sunday. All rental cars are on site at Tucson > > International Airport or Enterprise will pick you up if you fly into Ryan > > Airfield. > > Several hotels are just hundreds of yards down the street at TIA. Ryan > > Airport > > (KRYN) is only 10-12 minute drive. The entire experience is convenient > > and comfortable. > > > > The class is Oct. 6th & 7th, Saturday & Sunday. The class will start > promptly > > at > > 0800 each day and plan on staying until 1700 hours. There will be class > in > > the > > conference room each day in the morning and work in the hangar each day > after > > the class presentation. There will be a lunch break each day at > approximately > > 1130 hours. > > Please bring a laptop or tablet device in case you need to find Rotax > > information > > or manuals on line. There is Wi-Fi in the classroom. > > The class is being held at Ryan Airfield (KRYN) in Tucson, AZ. (9698 W > Ajo > > Hwy). > > This is west of Tucson proper and city limits and approximately 12 minute > > drive > > from the Tucson Airport (TIA). If you fly in your own aircraft parking is > > right up at the back door of the conference room. Rental cars are > available > > at > > Tucson Airport and Enterprise usually will pick you up at Ryan if you > need a > > car from there. > > > > Directions to Ryan Airfield are as follows and can be reached by either > Ajo > > Hwy > > or Valencia Rd. They both run right in front of Ryan Airport. The > conference > > room is up front at the airport on Ajo Hwy. It is the only building out > on > > Ajo > > Hwy and the only parking out on Ajo Hwy. > > > > General Directions: > > If you are staying in Tucson central or out by Interstate 10 then take > I-10 > > to > > I-19 south. The turn right to go west bound on Ajo Hwy. Follow this road > 12 > > miles > > out to Ryan Airfield. > > If you are staying in a hotel out by Tucson Airport off Valencia Rd. Just > > head > > west on Valencia until it dead ends right at Ryan Airfield on Ajo Hwy. > > > > There is a restaurant at Ryan field and you can have breakfast there. > They > > open > > at 0600. Lunch is either at Ryan or at two other local restaurants. > > > > Prepare to learn and have fun doing it! > > > > For questions call Roger Lee in Tucson, Az at 520-574-1080 Home or > > 520-349-7056 > > cell or Bryan Toepfer at California Power Systems 505-550-8121. > > > > -------- > > Roger Lee > > Tucson, Az. > > Rotax Instructor & Rotax IRC > > Light Sport Repairman > > Home 520-574-1080 TRY HOME FIRST > > Cell 520-349-7056 > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=483362#483362 > > > > > > ________________________________ Message 4 > > _____________________________________ > > > > > > From: goodings(at)yorku.ca > > Subject: RotaxEngines-List: Re: RotaxEngines-List Digest: 2 Msgs - > 09/24/18 > > > > > > For what it's worth, two 10,000 mF (microfarad) capacitors in parallel > > 20,000 > > mF will be almost as good as one 22,000 mF capacitor. One capacitor > > 22,000 > > mF > > will be fine, even better. But be fussy about having the working voltage > (for > > any electrolytic capacitor) not less than 25 V. All this capacitor is > doing > > is > > acting as a "short" to ground for radio frequency noise originating in > the > > ignition circuit so that the noise does not mess up your radios. > > > > John Goodings, C-FGPJ CH601HD Zodiac > > > > > > Quoting RotaxEngines-List Digest Server >: > > > > > * > > > > > > ================================================ > > > Online Versions of Today's List Digest Archive > > > ================================================ > > > > > > Today's complete RotaxEngines-List Digest can also be found in either > of > > the > > > two Web Links listed below. The .html file includes the Digest > formatted > > > in HTML for viewing with a web browser and features Hyperlinked Indexes > > > and Message Navigation. The .txt file includes the plain ASCII version > > > of the RotaxEngines-List Digest and can be viewed with a generic text > > editor > > > such as Notepad or with a web browser. > > > > > > HTML Version: > > > > > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter > > 18-09-24&Archive=RotaxEngines > > > > > > Text Version: > > > > > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter > > 18-09-24&Archive=RotaxEngines > > > > > > > > > ============================================== > > > EMail Version of Today's List Digest Archive > > > ============================================== > > > > > > > > > ---------------------------------------------------------- > > > RotaxEngines-List Digest Archive > > > --- > > > Total Messages Posted Mon 09/24/18: 2 > > > ---------------------------------------------------------- > > > > > > > > > Today's Message Index: > > > ---------------------- > > > > > > 1. 01:22 PM - Capacitors (Hugh McKay) > > > 2. 02:11 PM - Re: Capacitors (John Hauck) > > > > > > > > > ________________________________ Message 1 > > > _____________________________________ > > > > > > > > > From: Hugh McKay <hgmckay(at)bellsouth.net> > > > Subject: RotaxEngines-List: Capacitors > > > > > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at > 25V is > > > shown in the circuit. If you cannot find one capacitor of the exact > Capaci > > > tance, can one larger capacitor be used? Can two 10,000 aluminum > electrolyt > > > ic capacitors connected in parallel at that point in the circuit > accomplish > > > the same thing? > > > > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > > Senior Consultant > > > Worldwide Engineering Inc. > > > 4090 North NC Hwy. 16 > > > Denver, NC 28037 > > > > > > Ph. 704-661-8271 > > > Fax 704-483-5466 > > > Email hgmckay(at)bellsouth.net > > > http://www.geo.com (click on Power Division) > > > Sent from Mail for Windows 10 > > > > > > > > > ________________________________ Message 2 > > > _____________________________________ > > > > > > > > > From: "John Hauck" <jhauck(at)elmore.rr.com> > > > Subject: RE: RotaxEngines-List: Capacitors > > > > > > EBay has all kinds of 22,000 mf capacitors. Here are a few with free > > > shipping. Super cheap: > > > > > > > > > https://www.ebay.com/bhp/22000uf-capacitor > > > > > > > > > John Hauck > > > > > > Kolb MKIII > > > > > > Titus, Alabama > > > > > > > > > From: owner-rotaxengines-list-server(at)matronics.com > > > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of > Hugh > > > McKay > > > Sent: Monday, September 24, 2018 3:22 PM > > > Subject: RotaxEngines-List: Capacitors > > > > > > > > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at > 25V > > > is shown in the circuit. If you cannot find one capacitor of the exact > > > Capacitance, can one larger capacitor be used? Can two 10,000 aluminum > > > electrolytic capacitors connected in parallel at that point in the > > > circuit accomplish the same thing? > > > > > > > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > > > > > Senior Consultant > > > > > > Worldwide Engineering Inc. > > > > > > 4090 North NC Hwy. 16 > > > > > > Denver, NC 28037 > > > > > > > > > Ph. 704-661-8271 > > > > > > Fax 704-483-5466 > > > > > > Email hgmckay(at)bellsouth.net > > > > > > http://www.geo.com (click on Power Division) > > > > > > Sent from Mail for > > > Windows 10 > > > > > > > > > > > > ________________________________ Message 5 > > _____________________________________ > > > > > > Subject: RotaxEngines-List: Capacitors > > From: John Elling <jelling(at)newmexico.com> > > > > > > > > Keep in mind that capacitors have a limited lifetime. The electrolites > > dry out. It is a real limit at high altitudes and dry climates. > > > > I get mine from digikey and go for the name brands. > > > > Y'all might look over your capacitors at the next annual. Good ones > > have dates on them and you can find the recommended lifetimes. > > > > > > ________________________________ Message 6 > > _____________________________________ > > > > > > Subject: RotaxEngines-List: Capacitors > > From: John Elling <jelling(at)newmexico.com> > > > > > > > > Keep in mind that capacitors have a limited lifetime. The electrolites > > dry out. It is a real limit at high altitudes and dry climates. > > > > I get mine from digikey and go for the name brands. > > > > Y'all might look over your capacitors at the next annual. Good ones > > have dates on them and you can find the recommended lifetimes. > > > > > > ________________________________ Message 7 > > _____________________________________ > > > > > > From: Ken Ryan <keninalaska(at)gmail.com> > > Subject: Re: RotaxEngines-List: Re: RotaxEngines-List Digest: 2 Msgs - > > 09/24/18 > > > > John, isn't the ignition isolated from the starting/charging circuits > > (which is where the capacitor is located)? > > > > > > On Tue, Sep 25, 2018 at 1:51 PM wrote: > > > > > > > > For what it's worth, two 10,000 mF (microfarad) capacitors in parallel > > > 20,000 > > > mF will be almost as good as one 22,000 mF capacitor. One capacitor > > > > 22,000 mF > > > will be fine, even better. But be fussy about having the working > voltage > > > (for > > > any electrolytic capacitor) not less than 25 V. All this capacitor is > > > doing is > > > acting as a "short" to ground for radio frequency noise originating in > the > > > ignition circuit so that the noise does not mess up your radios. > > > > > > John Goodings, C-FGPJ CH601HD Zodiac > > > > > > > > > Quoting RotaxEngines-List Digest Server < > rotaxengines-list(at)matronics.com>: > > > > > > > * > > > > > > > > ================================================ > > > > Online Versions of Today's List Digest Archive > > > > ================================================ > > > > > > > > Today's complete RotaxEngines-List Digest can also be found in > either of > > > the > > > > two Web Links listed below. The .html file includes the Digest > formatted > > > > in HTML for viewing with a web browser and features Hyperlinked > Indexes > > > > and Message Navigation. The .txt file includes the plain ASCII > version > > > > of the RotaxEngines-List Digest and can be viewed with a generic text > > > editor > > > > such as Notepad or with a web browser. > > > > > > > > HTML Version: > > > > > > > > > > > > > > > > > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter > > 18-09-24&Archive=RotaxEngines > > > > > > > > Text Version: > > > > > > > > > > > > > > > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter > > 18-09-24&Archive=RotaxEngines > > > > > > > > > > > > ============================================== > > > > EMail Version of Today's List Digest Archive > > > > ============================================== > > > > > > > > > > > > ---------------------------------------------------------- > > > > RotaxEngines-List Digest Archive > > > > --- > > > > Total Messages Posted Mon 09/24/18: 2 > > > > ---------------------------------------------------------- > > > > > > > > > > > > Today's Message Index: > > > > ---------------------- > > > > > > > > 1. 01:22 PM - Capacitors (Hugh McKay) > > > > 2. 02:11 PM - Re: Capacitors (John Hauck) > > > > > > > > > > > > > > > > ________________________________ Message 1 > > > > _____________________________________ > > > > > > > > > > > > From: Hugh McKay <hgmckay(at)bellsouth.net> > > > > Subject: RotaxEngines-List: Capacitors > > > > > > > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at > 25V > > > is > > > > shown in the circuit. If you cannot find one capacitor of the exact > > > Capaci > > > > tance, can one larger capacitor be used? Can two 10,000 aluminum > > > electrolyt > > > > ic capacitors connected in parallel at that point in the circuit > > > accomplish > > > > the same thing? > > > > > > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > > > Senior Consultant > > > > Worldwide Engineering Inc. > > > > 4090 North NC Hwy. 16 > > > > Denver, NC 28037 > > > > > > > > Ph. 704-661-8271 > > > > Fax 704-483-5466 > > > > Email hgmckay(at)bellsouth.net > > > > http://www.geo.com (click on Power Division) > > > > Sent from Mail for Windows 10 > > > > > > > > > > > > ________________________________ Message 2 > > > > _____________________________________ > > > > > > > > > > > > From: "John Hauck" <jhauck(at)elmore.rr.com> > > > > Subject: RE: RotaxEngines-List: Capacitors > > > > > > > > EBay has all kinds of 22,000 mf capacitors. Here are a few with free > > > > shipping. Super cheap: > > > > > > > > > > > > https://www.ebay.com/bhp/22000uf-capacitor > > > > > > > > > > > > John Hauck > > > > > > > > Kolb MKIII > > > > > > > > Titus, Alabama > > > > > > > > > > > > From: owner-rotaxengines-list-server(at)matronics.com > > > > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of > Hugh > > > > McKay > > > > Sent: Monday, September 24, 2018 3:22 PM > > > > Subject: RotaxEngines-List: Capacitors > > > > > > > > > > > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at > 25V > > > > is shown in the circuit. If you cannot find one capacitor of the > exact > > > > Capacitance, can one larger capacitor be used? Can two 10,000 > aluminum > > > > electrolytic capacitors connected in parallel at that point in the > > > > circuit accomplish the same thing? > > > > > > > > > > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > > > > > > > Senior Consultant > > > > > > > > Worldwide Engineering Inc. > > > > > > > > 4090 North NC Hwy. 16 > > > > > > > > Denver, NC 28037 > > > > > > > > > > > > Ph. 704-661-8271 > > > > > > > > Fax 704-483-5466 > > > > > > > > Email hgmckay(at)bellsouth.net > > > > > > > > http://www.geo.com (click on Power Division) > > > > > > > > Sent from Mail for > > > > Windows 10 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________ Message 8 > > _____________________________________ > > > > > > From: Hugh McKay <hgmckay(at)bellsouth.net> > > Subject: RE: RotaxEngines-List: Re: RotaxEngines-List Digest: 2 Msgs - > > 09/24/18 > > > > John, The working voltage for the Rotax 912 UL electrical system is 12 > Volt > > s DC; much less than the 22,000 MF capacitor at 25 Volts as called for > on t > > he Rotax engine diagram. How do you explain your statement that the > working > > voltage should not be less than 25Volts? > > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > Senior Consultant > > Worldwide Engineering Inc. > > 4090 North NC Hwy. 16 > > Denver, NC 28037 > > > > Ph. 704-661-8271 > > Fax 704-483-5466 > > Email hgmckay(at)bellsouth.net > > http://www.geo.com (click on Power Division) > > Sent from Mail for Windows 10 > > > > From: goodings(at)yorku.ca > > Sent: Tuesday, September 25, 2018 3:48 PM > > Subject: RotaxEngines-List: Re: RotaxEngines-List Digest: 2 Msgs - > 09/24/18 > > > > > > For what it's worth, two 10,000 mF (microfarad) capacitors in parallel > > 20,000 > > mF will be almost as good as one 22,000 mF capacitor. One capacitor > > 22,00 > > 0 mF > > will be fine, even better. But be fussy about having the working voltage > (f > > or > > any electrolytic capacitor) not less than 25 V. All this capacitor is > doing > > is > > acting as a "short" to ground for radio frequency noise originating in > the > > ignition circuit so that the noise does not mess up your radios. > > > > John Goodings, C-FGPJ CH601HD Zodiac > > > > > > Quoting RotaxEngines-List Digest Server >: > > > > > * > > > > > > ======================= > > > > > Online Versions of Today's List Digest Archive > > > ======================= > > > > > > > > Today's complete RotaxEngines-List Digest can also be found in either > of > > the > > > two Web Links listed below. The .html file includes the Digest > formatted > > > in HTML for viewing with a web browser and features Hyperlinked Indexes > > > and Message Navigation. The .txt file includes the plain ASCII version > > > of the RotaxEngines-List Digest and can be viewed with a generic text > edi > > tor > > > such as Notepad or with a web browser. > > > > > > HTML Version: > > > > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Ch > > apter 18-09-24&Archive=RotaxEngines > > > > > > Text Version: > > > > > > > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Cha > > pter 18-09-24&Archive=RotaxEngines > > > > > > > > > ======================= > > ====================== > > > EMail Version of Today's List Digest Archive > > > ======================= > > ====================== > > > > > > > > > ---------------------------------------------------------- > > > RotaxEngines-List Digest Archive > > > --- > > > Total Messages Posted Mon 09/24/18: 2 > > > ---------------------------------------------------------- > > > > > > > > > Today's Message Index: > > > ---------------------- > > > > > > 1. 01:22 PM - Capacitors (Hugh McKay) > > > 2. 02:11 PM - Re: Capacitors (John Hauck) > > > > > > > > > ________________________________ Message 1 > > > _____________________________________ > > > > > > > > > From: Hugh McKay <hgmckay(at)bellsouth.net> > > > Subject: RotaxEngines-List: Capacitors > > > > > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at > 25V > > is > > > shown in the circuit. If you cannot find one capacitor of the exact > Capa > > ci > > > tance, can one larger capacitor be used? Can two 10,000 aluminum > electrol > > yt > > > ic capacitors connected in parallel at that point in the circuit > accompli > > sh > > > the same thing? > > > > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > > Senior Consultant > > > Worldwide Engineering Inc. > > > 4090 North NC Hwy. 16 > > > Denver, NC 28037 > > > > > > Ph. 704-661-8271 > > > Fax 704-483-5466 > > > Email hgmckay(at)bellsouth.net > > > http://www.geo.com (click on Power Division) > > > Sent from Mail for Windows 10 > > > > > > > > > ________________________________ Message 2 > > > _____________________________________ > > > > > > > > > From: "John Hauck" <jhauck(at)elmore.rr.com> > > > Subject: RE: RotaxEngines-List: Capacitors > > > > > > EBay has all kinds of 22,000 mf capacitors. Here are a few with free > > > shipping. Super cheap: > > > > > > > > > https://www.ebay.com/bhp/22000uf-capacitor > > > > > > > > > John Hauck > > > > > > Kolb MKIII > > > > > > Titus, Alabama > > > > > > > > > From: owner-rotaxengines-list-server(at)matronics.com > > > [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of > Hugh > > > McKay > > > Sent: Monday, September 24, 2018 3:22 PM > > > Subject: RotaxEngines-List: Capacitors > > > > > > > > > On the Rotax 912 UL engine wiring diagram one 22,000 UF capacitor at > 25V > > > is shown in the circuit. If you cannot find one capacitor of the exact > > > Capacitance, can one larger capacitor be used? Can two 10,000 aluminum > > > electrolytic capacitors connected in parallel at that point in the > > > circuit accomplish the same thing? > > > > > > > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > > > > > Senior Consultant > > > > > > Worldwide Engineering Inc. > > > > > > 4090 North NC Hwy. 16 > > > > > > Denver, NC 28037 > > > > > > > > > Ph. 704-661-8271 > > > > > > Fax 704-483-5466 > > > > > > Email hgmckay(at)bellsouth.net > > > > > > http://www.geo.com (click on Power Division) > > > > > > Sent from Mail for > > > Windows 10 > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 01, 2018
Subject: Any problem with smoke oil?
I have 912 ULS and I'm about to add a smoke system to it. I have airshow quality smoke oil. I plan to inject it into 2 exhaust pipes. Have any of you had any problems doing that? Has it affected the muffler at all? Stan N29TD ________________________________________________________________________________
Subject: Re: Any problem with smoke oil?
Date: Oct 03, 2018
There are some who have done this. It will make a mess under the plane and from time to time you may need to clean the exhaust. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=483561#483561 ________________________________________________________________________________
Subject: Rectifier/Regulator Charging Current (Amps) Measurement
Date: Oct 24, 2018
How can I measure the amount of battery charging current being put out by t he Rotax Rectifier/Regulator using a digital multimeter? Hugh G. McKay III, P.E. Fellow. L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Windows 10 ________________________________________________________________________________
From: Clive Richards <stephencliverichards(at)gmail.com>
Subject: Re: Rectifier/Regulator Charging Current (Amps) Measurement
Date: Oct 24, 2018
Hi hugh as a ammeter has to be connected in series with the output of the r egulator I think the output is probably 30 amp which will be greater than t he digital meter usually 10 amp. You can get a cheap analog DC 30 amp ammeter with a seperate shunt from eba y and connect that. Alternatively you can get a relatively cheap DC 30-0-30 amp clipon ammeter again from ebay and clip over regulator output cable or battery cable will no be very accurate but probably ok for your needs Clive Get Outlook for Android From: owner-rotaxengines-list-server(at)matronics.com <owner-rotaxengines-list -server(at)matronics.com> on behalf of Hugh McKay Sent: Wednesday, October 24, 2018 4:24:20 PM Subject: RotaxEngines-List: Rectifier/Regulator Charging Current (Amps) Mea surement How can I measure the amount of battery charging current being put out by t he Rotax Rectifier/Regulator using a digital multimeter? Hugh G. McKay III, P.E. Fellow. L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Window s 10 ________________________________________________________________________________
Date: Oct 25, 2018
Clive, Thanks for your reply and advice. Attached is a photograph of the manual an d measuring device I have. It is an Extech single phase/three phase 1000 am p true RMS Power Clamp on Model 380976 digital meter. The manual is not ver y clear on the range of measurement for DC Amps. Attached also are two scan ned sections in the manual concerning measuring Amps. One is for =9CA C Current measurement=9D, and the other is for =9CAC and DC mic ro Amp measurement=9D. I notice that there is no direct reference to =9CDC Amp measurement=9D, only micro Amp measurement. Can I sim ply use the =9CAC Current Measurement=9D clamp on procedure ove r one wire to measure DC current in that wire? I am a novice concerning ele ctricity, so I need to know if I can use this device to measure the amp out put of the +B wire coming out of the Rotax rectifier/voltage regulator to d etermine if I have adequate charging current for the battery? Hugh G. McKay III Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Windows 10 From: Clive Richards Sent: Wednesday, October 24, 2018 2:18 PM Subject: Re: RotaxEngines-List: Rectifier/Regulator Charging Current (Amps) Measurement Hi hugh as a ammeter has to be connected in series with the output of the r egulator I think the output is probably 30 amp which will be greater than t he digital meter usually 10 amp. You can get a cheap analog DC 30 amp ammeter with a seperate shunt from eba y and connect that. Alternatively you can get a relatively cheap DC 30-0-30 amp clipon ammeter again from ebay and clip over regulator output cable or battery cable will no be very accurate but probably ok for your needs Clive Get Outlook for Android From: owner-rotaxengines-list-server(at)matronics.com <owner-rotaxengines-list -server(at)matronics.com> on behalf of Hugh McKay Sent: Wednesday, October 24, 2018 4:24:20 PM Subject: RotaxEngines-List: Rectifier/Regulator Charging Current (Amps) Mea surement =C2- How can I measure the amount of battery charging current being put out by t he Rotax Rectifier/Regulator using a digital multimeter? =C2- Hugh G. McKay III, P.E. Fellow. L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 =C2- Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Windows 10 =C2- ________________________________________________________________________________
Measurement
Date: Oct 25, 2018
The clamp part of the meter only measures AC current you can measure dc mil liamps using the test leads If you know a car repairer they may have a clip on dc ammeter but you will have to read it in position . I expect digital d c clamp meters similar to yours are available but will be expensive. Get Outlook for Android ________________________________ From: owner-rotaxengines-list-server(at)matronics.com <owner-rotaxengines-list -server(at)matronics.com> on behalf of Hugh McKay Sent: Thursday, October 25, 2018 4:39:35 PM Subject: RE: RotaxEngines-List: Rectifier/Regulator Charging Current (Amps) Measurement Clive, Thanks for your reply and advice. Attached is a photograph of the manual an d measuring device I have. It is an Extech single phase/three phase 1000 am p true RMS Power Clamp on Model 380976 digital meter. The manual is not ver y clear on the range of measurement for DC Amps. Attached also are two scan ned sections in the manual concerning measuring Amps. One is for =93AC Curr ent measurement=94, and the other is for =93AC and DC micro Amp measurement =94. I notice that there is no direct reference to =93DC Amp measurement=94 , only micro Amp measurement. Can I simply use the =93AC Current Measuremen t=94 clamp on procedure over one wire to measure DC current in that wire? I am a novice concerning electricity, so I need to know if I can use this de vice to measure the amp output of the +B wire coming out of the Rotax recti fier/voltage regulator to determine if I have adequate charging current for the battery? [cid:image003.jpg(at)01D46C57.6682CDF0] Hugh G. McKay III Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Window s 10 From: Clive Richards<mailto:stephencliverichards(at)gmail.com> Sent: Wednesday, October 24, 2018 2:18 PM Subject: Re: RotaxEngines-List: Rectifier/Regulator Charging Current (Amps) Measurement Hi hugh as a ammeter has to be connected in series with the output of the r egulator I think the output is probably 30 amp which will be greater than t he digital meter usually 10 amp. You can get a cheap analog DC 30 amp ammeter with a seperate shunt from eba y and connect that. Alternatively you can get a relatively cheap DC 30-0-30 amp clipon ammeter again from ebay and clip over regulator output cable or battery cable will no be very accurate but probably ok for your needs Clive Get Outlook for Android From: owner-rotaxengines-list-server(at)matronics.com <owner-rotaxengines-list -server(at)matronics.com> on behalf of Hugh McKay Sent: Wednesday, October 24, 2018 4:24:20 PM Subject: RotaxEngines-List: Rectifier/Regulator Charging Current (Amps) Mea surement How can I measure the amount of battery charging current being put out by t he Rotax Rectifier/Regulator using a digital multimeter? Hugh G. McKay III, P.E. Fellow. L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Window s 10 ________________________________________________________________________________
Measurement
Date: Oct 26, 2018
Hi hugh I have just checked meter speck to check I was correct but I see th ey do AC/DC model clamp meters these days . The cheapest option is buy a ammeter with seperate shunt connect shunt in s eries with alternator regulator output and connect shunt to meter where you can read it. (About $ 20) you will need to connect correct polarity on a a nalog meter or it will try to read backwards Clive Get Outlook for Android ________________________________ From: owner-rotaxengines-list-server(at)matronics.com <owner-rotaxengines-list -server(at)matronics.com> on behalf of Hugh McKay Sent: Thursday, October 25, 2018 4:39:35 PM Subject: RE: RotaxEngines-List: Rectifier/Regulator Charging Current (Amps) Measurement Clive, Thanks for your reply and advice. Attached is a photograph of the manual an d measuring device I have. It is an Extech single phase/three phase 1000 am p true RMS Power Clamp on Model 380976 digital meter. The manual is not ver y clear on the range of measurement for DC Amps. Attached also are two scan ned sections in the manual concerning measuring Amps. One is for =93AC Curr ent measurement=94, and the other is for =93AC and DC micro Amp measurement =94. I notice that there is no direct reference to =93DC Amp measurement=94 , only micro Amp measurement. Can I simply use the =93AC Current Measuremen t=94 clamp on procedure over one wire to measure DC current in that wire? I am a novice concerning electricity, so I need to know if I can use this de vice to measure the amp output of the +B wire coming out of the Rotax recti fier/voltage regulator to determine if I have adequate charging current for the battery? [cid:image003.jpg(at)01D46C57.6682CDF0] Hugh G. McKay III Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Window s 10 From: Clive Richards<mailto:stephencliverichards(at)gmail.com> Sent: Wednesday, October 24, 2018 2:18 PM Subject: Re: RotaxEngines-List: Rectifier/Regulator Charging Current (Amps) Measurement Hi hugh as a ammeter has to be connected in series with the output of the r egulator I think the output is probably 30 amp which will be greater than t he digital meter usually 10 amp. You can get a cheap analog DC 30 amp ammeter with a seperate shunt from eba y and connect that. Alternatively you can get a relatively cheap DC 30-0-30 amp clipon ammeter again from ebay and clip over regulator output cable or battery cable will no be very accurate but probably ok for your needs Clive Get Outlook for Android From: owner-rotaxengines-list-server(at)matronics.com <owner-rotaxengines-list -server(at)matronics.com> on behalf of Hugh McKay Sent: Wednesday, October 24, 2018 4:24:20 PM Subject: RotaxEngines-List: Rectifier/Regulator Charging Current (Amps) Mea surement How can I measure the amount of battery charging current being put out by t he Rotax Rectifier/Regulator using a digital multimeter? Hugh G. McKay III, P.E. Fellow. L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Window s 10 ________________________________________________________________________________
Date: Nov 01, 2018
Subject: PLEASE READ - Matronics Email List 2018 Fund Raiser
During November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are 9 great gifts to choose from! There's something for everyone, to be sure. Please make your List Contribution using any one of three secure methods including using a Credit Card, PayPal, or by Personal Check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 03, 2018
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 05, 2018
Subject: Coming Soon - The List of Contributors - Please Make
A Contribution Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Oil temp and pressure sensors.
Date: Nov 06, 2018
I am trying to find out if the VDO 360 004 sensor is compatible with that used on flydat 886855. Also will the oil temp sensor work with most / all EIS. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=484487#484487 ________________________________________________________________________________
Date: Nov 07, 2018
Subject: [PLEASE READ] Why I Have A Fund Raiser...
Since the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that ilk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, Commercial-greade Internet Connection, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 09, 2018
Subject: List Contribution - Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Subject: Re: Airport Courtesy Cars Update-Not Topic Related
Date: Nov 10, 2018
I know Glenn. This is not junk mail and an up front and honest post. He lives in Tucson, AZ and I talk to him all the time. he's a retired Police officer trying to help the aviation community. Roger Lee -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=484739#484739 ________________________________________________________________________________
Date: Nov 10, 2018
Thanks Roger. -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Website www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=484744#484744 ________________________________________________________________________________
Date: Nov 11, 2018
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Subject: 912 Fuel Manifold
Date: Nov 11, 2018
The original builder of my titan tornado did not include a fuel manifold with fuel return line. Rotax does not like this so I've been planning to add one along the lines of the figure in section 1.4.1 of the installation manual Fuel Systems. I figure I can also add a fuel pressure gauge while I'm at it. I'm concerned that the fuel pressure gauge handle the old pump (which I have, max 5.8 psi) and the new pump if I ever need it. It looks like the UMA fuel sensor and gauges are calibrated for the 5.8 psi max. How have you dealt with this? What is the fuel pressure sensor for? ________________________________________________________________________________
Date: Nov 11, 2018
Subject: Re: 912 Fuel Manifold
John, I think the fuel pressure gauge is there to make sure you don't over power the needle valve. When I added the feedback line to a Just Aircraft Escapade I had no way to run the line back to one of the wing tanks so I ran it to the line before the header tank. This turned out to be a big mistake as the feedback line would allow the fuel to flow backward, bypass the fuel shut off valve and keep the needle valves always under pressure. I wasn't able to solve it until the owner added a different header tank and I was able to plumb it so that there was an airspace in the top of the tank to act as a suction break . Since you're doing an ELSA (of EAB) airplane I'd suggest you look at the function of the Rotax parts. They charge a ton for them (almost $200 for all the parts necessary) and you can get the same function with a Tee and three barbed fittings. Modify one barbed fitting so the through hole is reduced to about .050" and you've done the same thing the Rotax parts do for one tenth the price. If you have to add a second fuel pump consider using a Facet 40104 that has a maximum pressure of 4 1/2 psi. It has no check valve so if it should fail fuel continues to flow right through it. I've tested it with the Rotax fuel pump on the Escapade and when I added a Mikuni pulse pump to my trike. In both I shut off the Facet to test its effect at maximum climb angle and the engine in both cases just kept on humming along. Rick Girard On Sun, Nov 11, 2018 at 10:48 AM John Elling wrote: > jelling(at)newmexico.com> > > The original builder of my titan tornado did not include a fuel manifold > with fuel return line. Rotax does not like this so I've been planning > to add one along the lines of the figure in section 1.4.1 of the > installation manual Fuel Systems. I figure I can also add a fuel > pressure gauge while I'm at it. > > I'm concerned that the fuel pressure gauge handle the old pump (which I > have, max 5.8 psi) and the new pump if I ever need it. It looks like > the UMA fuel sensor and gauges are calibrated for the 5.8 psi max. How > have you dealt with this? > > What is the fuel pressure sensor for? =========== =========== =========== =========== =========== =========== > > -- =9CBlessed are the cracked, for they shall let in the light.=9D Groucho Marx <http://www.goodreads.com/author/show/43244.Groucho_Marx> ________________________________________________________________________________
Date: Nov 12, 2018
The new max pressure is 7.2 psi. If you have an analog gauge for 10-15 psi your good. If you have something like a Dynon digital just go into the menu and set the max higher. 5.8 psi doesn't work at times with the new pumps. -------- Roger Lee Tucson, Az. Rotax Instructor & Rotax IRC Light Sport Repairman Home 520-574-1080 TRY HOME FIRST Cell 520-349-7056 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=484902#484902 ________________________________________________________________________________
Date: Nov 13, 2018
Subject: Just A Few Days Left...
Dear Listers, There are just a few days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least three of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 15, 2018
Subject: Make Sure You're Listed! List of Contributors Coming
Soon! Dear Listers, There's just two more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 17, 2018
Subject: Reminder
Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Reminder
Date: Nov 18, 2018
I have only used your sights for a few weeks please un-scribe me from the Rotax and RV please Ken Richardson -----Original Message----- From: owner-rotaxengines-list-server(at)matronics.com On Behalf Of Matt Dralle Sent: 17 November 2018 12:38 Subject: RotaxEngines-List: Reminder --> Dear Listers, A quick reminder that November is the annual Matronics List Fund Raiser. The Lists are 100% member supported and all of the operational costs are covered solely through your Contributions during this time of the year. *Your* personal Contribution makes a difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running for another great year! Use a credit card or your PayPal account here: http://www.matronics.com/contribution Or, by sending a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 19, 2018
Subject: LOC
Dear Listers, Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by popping a personal check in the mail to: Matronics Email Lists c/o Matt Dralle 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Email List Administrator ________________________________________________________________________________
Subject: Rotax 912 UL Rectifier wiring
Date: Nov 20, 2018
I need some advice by anyone out there who may be able to clear up a questi on I have concerning checking the output wiring of the standard Rotax 912 r ectifier used with the 912 UL engine. I have this rectifier on my Allegro 2000 ELSA (912 UL engine). For additional information I am attaching my air plane wiring one line diagram that shows how my rectifier is wired. Also I want to make reference to a Blog article authored by Klaus Truemper titled =9C18 December 2012 Testing Rotax 912/914 Generator and Rectifier =9D. You can Google the title and read the article. In the section of Mr. Truemper=99s article (Testing Regulator/Rectifi er) where he states =9CWith the Master switch off: The above test (re ferring to the previous paragraph) should show 0 voltage for all three case s. I do not know what Mr. Truemper=99s wiring diagram looked like bec ause he did not offer one in his article. After reading Mr. Truemper=99s article and because of some perceived battery charging issues I was having with my airplane I thought I would che ck my rectifier according to his instructions in the article section titled (Testing Regulator/Rectifier). All the tests he listed (the same ones I di d) fell within the values stated in his article except those tested with th e Master switch =9Coff=9D. In my case, with the Master switch =9Coff=9D the voltage to ground on R, B+, and C each measured 1 2.7 VDC in stead of 0 VDC. Again I don=99t have Mr. Truemper=99s wiring diagram, but in th e wiring diagram shown in the Rotax 912 UL engine installation manual their wiring diagram indicates that there will be regular 12 VDC battery voltage on R, B+, and C when the master switch is =9Coff=9D. My question is this: Assuming there is a disconnect switch between terminal C and B+ in the open position (per instruction from Rotax to protect the b attery from discharge), with the Master switch in the =9Coff=9D position should I be measuring 12+VDC to ground on R, B+, and C rather tha n 0 VDC?? Hugh G. McKay III, P.E. Fellow. L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Windows 10 ________________________________________________________________________________
Date: Nov 20, 2018
Subject: Re: Rotax 912 UL Rectifier wiring
You don=99t show a battery relay to that isolates the battery when all switches are off (as in shutdown) which is in the rotax install wiring diag ram. I believe that is the master that Truemper=99s speaking about. Dave Alberti 414-699-9312 > On Nov 20, 2018, at 3:46 PM, Hugh McKay wrote: > > I need some advice by anyone out there who may be able to clear up a quest ion I have concerning checking the output wiring of the standard Rotax 912 r ectifier used with the 912 UL engine. I have this rectifier on my Allegro 2 000 ELSA (912 UL engine). For additional information I am attaching my airpl ane wiring one line diagram that shows how my rectifier is wired. Also I wan t to make reference to a Blog article authored by Klaus Truemper titled =9C18 December 2012 Testing Rotax 912/914 Generator and Rectifier=9D. Y ou can Google the title and read the article. > > In the section of Mr. Truemper=99s article (Testing Regulator/Rectif ier) where he states =9CWith the Master switch off: The above test (re ferring to the previous paragraph) should show 0 voltage for all three cases . I do not know what Mr. Truemper=99s wiring diagram looked like becau se he did not offer one in his article. > > After reading Mr. Truemper=99s article and because of some perceived battery charging issues I was having with my airplane I thought I would che ck my rectifier according to his instructions in the article section titled ( Testing Regulator/Rectifier). All the tests he listed (the same ones I did) f ell within the values stated in his article except those tested with the Mas ter switch =9Coff=9D. In my case, with the Master switch =9C off=9D the voltage to ground on R, B+, and C each measured 12.7 VDC in stead of 0 VDC. > > Again I don=99t have Mr. Truemper=99s wiring diagram, but in t he wiring diagram shown in the Rotax 912 UL engine installation manual their wiring diagram indicates that there will be regular 12 VDC battery voltage o n R, B+, and C when the master switch is =9Coff=9D. > > My question is this: Assuming there is a disconnect switch between termina l C and B+ in the open position (per instruction from Rotax to protect the b attery from discharge), with the Master switch in the =9Coff=9D p osition should I be measuring 12+VDC to ground on R, B+, and C rather than 0 VDC?? > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > Ph. 704-661-8271 > Fax 704-483-5466 > Email hgmckay(at)bellsouth.net > http://www.geo.com (click on Power Division) > Sent from Mail for Windows 10 > > ________________________________________________________________________________
Date: Nov 20, 2018
Dave, My battery is manually isolated by Breaker 13 shown within the =9Cclo ud=9D noted as Rev.#1 on the attached one line (better drawing than w hat I sent previous). All the Breakers mounted on the panel including Break er 13 are Potter & Brumfield W23 Push Button Thermal circuit breakers that can also be used as manual isolation switches. I assumed the term =9C Master Switch=9D as used by Mr. Truemper meant the =9CIgnition Switch=9D as seen on my one line. With that switch in the =9Cof f=9D position and Breaker 13 open the voltage to ground on R, B+, and C each measured 12.7 VDC in stead of 0 VDC. This is the same wiring arrang ement as shown in the Rotax 912 Installation Manual, page 46 of 66 Dated 19 97 03 26. Unless I am =9Csomewhere lost in translation=9D, If M r. Truemper has his engine wired according to the Rotax manual (which is th e same as mine, he should also be reading the voltage to ground on R, B+, a nd C each as 12+ VDC in stead of 0 VDC Having said all this, have I lost my mind?? According to the attached one l ine is my electrical system wired correctly???? Hugh G. McKay III, P.E. Fellow. L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Windows 10 From: Dave Alberti Sent: Tuesday, November 20, 2018 7:23 PM Subject: Re: RotaxEngines-List: Rotax 912 UL Rectifier wiring You don=99t show a battery relay to that isolates the battery when al l switches are off (as in shutdown) which is in the rotax install wiring di agram. =C2-I believe that is the master that =C2-Truemper=99s spe aking about. Dave Alberti 414-699-9312 On Nov 20, 2018, at 3:46 PM, Hugh McKay wrote: I need some advice by anyone out there who may be able to clear up a questi on I have concerning checking the output wiring of the standard Rotax 912 r ectifier used with the 912 UL engine. I have this rectifier on my =C2-All egro 2000 ELSA (912 UL engine). For additional information I am attaching m y airplane wiring one line diagram that shows how my rectifier is wired. Al so I want to make reference to a Blog article authored by Klaus Truemper ti tled =9C18 December 2012 Testing Rotax 912/914 Generator and Rectifie r=9D. You can Google the title and read the article. =C2- In the section of Mr. Truemper=99s article (Testing Regulator/Rectifi er) where he states =9CWith the Master switch off: The above test (re ferring to the previous paragraph) should show 0 voltage for all three case s. I do not know what Mr. Truemper=99s wiring diagram looked like bec ause he did not offer one in his article. =C2- After reading Mr. Truemper=99s article and because of some perceived battery charging issues I was having with my airplane I thought I would che ck my rectifier according to his instructions in the article section titled (Testing Regulator/Rectifier). All the tests he listed (the same ones I di d) fell within the values stated in his article except those tested with th e Master switch =9Coff=9D. In my case, with the Master switch =9Coff=9D the voltage to ground on R, B+, and C each measured 1 2.7 VDC in stead of 0 VDC. =C2- Again I don=99t have Mr. Truemper=99s wiring diagram, but in th e wiring diagram shown in the Rotax 912 UL engine installation manual their wiring diagram indicates that there will be regular 12 VDC battery voltage on R, B+, and C when the master switch is =9Coff=9D. =C2- My question is this: Assuming there is a disconnect switch between terminal C and B+ in the open position (per instruction from Rotax to protect the b attery from discharge), with the Master switch in the =9Coff=9D position should I be measuring 12+VDC to ground on R, B+, and C rather tha n 0 VDC?? =C2- Hugh G. McKay III, P.E. Fellow. L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 =C2- Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Windows 10 =C2- ________________________________________________________________________________
Date: Nov 20, 2018
Hugh, that does not isolate the battery, the rotax drawing drops at relay 19 and takes all voltage off the regulator at B+ and R. Dave Alberti 414-699-9312 > On Nov 20, 2018, at 7:59 PM, Hugh McKay wrote: > > Dave, > > My battery is manually isolated by Breaker 13 shown within the =9Ccl oud=9D noted as Rev.#1 on the attached one line (better drawing than w hat I sent previous). All the Breakers mounted on the panel including Breake r 13 are Potter & Brumfield W23 Push Button Thermal circuit breakers that ca n also be used as manual isolation switches. I assumed the term =9CMas ter Switch=9D as used by Mr. Truemper meant the =9CIgnition Swit ch=9D as seen on my one line. With that switch in the =9Coff =9D position and Breaker 13 open the voltage to ground on R, B+, and C each m easured 12.7 VDC in stead of 0 VDC. This is the same wiring arrangement as s hown in the Rotax 912 Installation Manual, page 46 of 66 Dated 1997 03 26. U nless I am =9Csomewhere lost in translation=9D, If Mr. Truemper h as his engine wired according to the Rotax manual (which is the same as mine , he should also be reading the voltage to ground on R, B+, and C each as 12 + VDC in stead of 0 VDC > > Having said all this, have I lost my mind?? According to the attached one l ine is my electrical system wired correctly???? > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > Ph. 704-661-8271 > Fax 704-483-5466 > Email hgmckay(at)bellsouth.net > http://www.geo.com (click on Power Division) > Sent from Mail for Windows 10 > > From: Dave Alberti > Sent: Tuesday, November 20, 2018 7:23 PM > To: rotaxengines-list(at)matronics.com > Subject: Re: RotaxEngines-List: Rotax 912 UL Rectifier wiring > > You don=99t show a battery relay to that isolates the battery when a ll switches are off (as in shutdown) which is in the rotax install wiring di agram. I believe that is the master that Truemper=99s speaking about . > > Dave Alberti > 414-699-9312 > > On Nov 20, 2018, at 3:46 PM, Hugh McKay wrote: > > I need some advice by anyone out there who may be able to clear up a quest ion I have concerning checking the output wiring of the standard Rotax 912 r ectifier used with the 912 UL engine. I have this rectifier on my Allegro 2 000 ELSA (912 UL engine). For additional information I am attaching my airpl ane wiring one line diagram that shows how my rectifier is wired. Also I wan t to make reference to a Blog article authored by Klaus Truemper titled =9C18 December 2012 Testing Rotax 912/914 Generator and Rectifier=9D. Y ou can Google the title and read the article. > > In the section of Mr. Truemper=99s article (Testing Regulator/Rectif ier) where he states =9CWith the Master switch off: The above test (re ferring to the previous paragraph) should show 0 voltage for all three cases . I do not know what Mr. Truemper=99s wiring diagram looked like becau se he did not offer one in his article. > > After reading Mr. Truemper=99s article and because of some perceived battery charging issues I was having with my airplane I thought I would che ck my rectifier according to his instructions in the article section titled ( Testing Regulator/Rectifier). All the tests he listed (the same ones I did) f ell within the values stated in his article except those tested with the Mas ter switch =9Coff=9D. In my case, with the Master switch =9C off=9D the voltage to ground on R, B+, and C each measured 12.7 VDC in stead of 0 VDC. > > Again I don=99t have Mr. Truemper=99s wiring diagram, but in t he wiring diagram shown in the Rotax 912 UL engine installation manual their wiring diagram indicates that there will be regular 12 VDC battery voltage o n R, B+, and C when the master switch is =9Coff=9D. > > My question is this: Assuming there is a disconnect switch between termina l C and B+ in the open position (per instruction from Rotax to protect the b attery from discharge), with the Master switch in the =9Coff=9D p osition should I be measuring 12+VDC to ground on R, B+, and C rather than 0 VDC?? > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > Ph. 704-661-8271 > Fax 704-483-5466 > Email hgmckay(at)bellsouth.net > http://www.geo.com (click on Power Division) > Sent from Mail for Windows 10 > > > > ________________________________________________________________________________
Date: Nov 20, 2018
Dave, Thanks for your clarification of the Rotax instruction concerning disconnec ting the battery. I went back and read a similar article by Phil Lockwood c alled =9CTips and Tricks for the Ideal Rotax 912 Installation =9D published in 2005. In that article he clearly states that the + battery wire that is connected to R, B+, and C must be disconnected from the batte ry. Based on my wiring one line drawing where would you recommend I move Br eaker 13 to isolate the battery, and should I change the breaker to a large r amp rating? Hugh G. McKay III, P.E. Fellow. L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Windows 10 From: Dave Alberti Sent: Tuesday, November 20, 2018 9:41 PM Subject: Re: RotaxEngines-List: Rotax 912 UL Rectifier wiring Hugh, that does not isolate the battery, the rotax drawing drops at relay 1 9 and takes all voltage off the regulator at B+ and R. =C2- Dave Alberti 414-699-9312 On Nov 20, 2018, at 7:59 PM, Hugh McKay wrote: Dave, =C2- My battery is manually isolated by Breaker 13 shown within the =9Cclo ud=9D noted as Rev.#1 on the attached one line (better drawing than w hat I sent previous). All the Breakers mounted on the panel including Break er 13 are Potter & Brumfield W23 Push Button Thermal circuit breakers that can also be used as manual isolation switches. I assumed the term =9C Master Switch=9D as used by Mr. Truemper meant the =9CIgnition Switch=9D as seen on my one line. With that switch in the =9Cof f=9D position and Breaker 13 open the voltage to ground on R, B+, and C each measured 12.7 VDC in stead of 0 VDC. This is the same wiring arrang ement as shown in the Rotax 912 Installation Manual, page 46 of 66 Dated 19 97 03 26. Unless I am =9Csomewhere lost in translation=9D, If M r. Truemper has his engine wired according to the Rotax manual (which is th e same as mine, he should also be reading the voltage to ground on R, B+, a nd C each as 12+ VDC in stead of 0 VDC =C2- Having said all this, have I lost my mind?? According to the attached one l ine is my electrical system wired correctly???? =C2- =C2- Hugh G. McKay III, P.E. Fellow. L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 =C2- Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Windows 10 =C2- From: Dave Alberti Sent: Tuesday, November 20, 2018 7:23 PM Subject: Re: RotaxEngines-List: Rotax 912 UL Rectifier wiring =C2- You don=99t show a battery relay to that isolates the battery when al l switches are off (as in shutdown) which is in the rotax install wiring di agram. =C2-I believe that is the master that =C2-Truemper=99s spe aking about. Dave Alberti 414-699-9312 On Nov 20, 2018, at 3:46 PM, Hugh McKay wrote: I need some advice by anyone out there who may be able to clear up a questi on I have concerning checking the output wiring of the standard Rotax 912 r ectifier used with the 912 UL engine. I have this rectifier on my =C2-All egro 2000 ELSA (912 UL engine). For additional information I am attaching m y airplane wiring one line diagram that shows how my rectifier is wired. Al so I want to make reference to a Blog article authored by Klaus Truemper ti tled =9C18 December 2012 Testing Rotax 912/914 Generator and Rectifie r=9D. You can Google the title and read the article. =C2- In the section of Mr. Truemper=99s article (Testing Regulator/Rectifi er) where he states =9CWith the Master switch off: The above test (re ferring to the previous paragraph) should show 0 voltage for all three case s. I do not know what Mr. Truemper=99s wiring diagram looked like bec ause he did not offer one in his article. =C2- After reading Mr. Truemper=99s article and because of some perceived battery charging issues I was having with my airplane I thought I would che ck my rectifier according to his instructions in the article section titled (Testing Regulator/Rectifier). All the tests he listed (the same ones I di d) fell within the values stated in his article except those tested with th e Master switch =9Coff=9D. In my case, with the Master switch =9Coff=9D the voltage to ground on R, B+, and C each measured 1 2.7 VDC in stead of 0 VDC. =C2- Again I don=99t have Mr. Truemper=99s wiring diagram, but in th e wiring diagram shown in the Rotax 912 UL engine installation manual their wiring diagram indicates that there will be regular 12 VDC battery voltage on R, B+, and C when the master switch is =9Coff=9D. =C2- My question is this: Assuming there is a disconnect switch between terminal C and B+ in the open position (per instruction from Rotax to protect the b attery from discharge), with the Master switch in the =9Coff=9D position should I be measuring 12+VDC to ground on R, B+, and C rather tha n 0 VDC?? =C2- Hugh G. McKay III, P.E. Fellow. L.M. ASCE Senior Consultant Worldwide Engineering Inc. 4090 North NC Hwy. 16 Denver, NC 28037 =C2- Ph. 704-661-8271 Fax 704-483-5466 Email hgmckay(at)bellsouth.net http://www.geo.com (click on Power Division) Sent from Mail for Windows 10 =C2- =C2- ________________________________________________________________________________
Date: Nov 21, 2018
Hugh Rotax Warn Terminal C should not be disconnected from Term B with a switch or fuse while the engine is running or regulator will be damaged. You need to remove CB13 and connect R B & C together. Myself I have installed a battery contactor ((19) on rotax drawing)switched from a master switch, and normal & alternative feed (small fuse direct from battery) switches to feed avionics bus. IF you look in archives of aerolectric list you will find allsorts of information on rotax regulator and dawings. good place to ask electrical questions. Clive On Wed, 21 Nov 2018 at 04:38, Hugh McKay wrote: > Dave, > > > Thanks for your clarification of the Rotax instruction concerning > disconnecting the battery. I went back and read a similar article by Phil > Lockwood called =9CTips and Tricks for the Ideal Rotax 912 Installa tion=9D > published in 2005. In that article he clearly states that the + battery > wire that is connected to R, B+, and C must be disconnected from the batt ery*. > Based on my wiring one line drawing* where would you recommend I move > Breaker 13 to isolate the battery, and should I change the breaker to a > larger amp rating? > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > Senior Consultant > > Worldwide Engineering Inc. > > 4090 North NC Hwy. 16 > > Denver, NC 28037 > > > Ph. 704-661-8271 > > Fax 704-483-5466 > > Email hgmckay(at)bellsouth.net > > http://www.geo.com (click on Power Division) > > Sent from Mail for > Windows 10 > > > *From: *Dave Alberti <daberti(at)sbcglobal.net> > *Sent: *Tuesday, November 20, 2018 9:41 PM > *To: *rotaxengines-list(at)matronics.com > *Subject: *Re: RotaxEngines-List: Rotax 912 UL Rectifier wiring > > > Hugh, that does not isolate the battery, the rotax drawing drops at relay > 19 and takes all voltage off the regulator at B+ and R. [image: > image1.png] > > Dave Alberti > > 414-699-9312 > > > On Nov 20, 2018, at 7:59 PM, Hugh McKay wrote: > > Dave, > > > My battery is manually isolated by Breaker 13 shown within the =9Cc loud=9D > noted as Rev.#1 on the *attached one line (better drawing than what I > sent previous).* All the Breakers mounted on the panel including Breaker > 13 are Potter & Brumfield W23 Push Button Thermal circuit breakers that c an > also be used as manual isolation switches. I assumed the term =9CMa ster > Switch=9D as used by Mr. Truemper meant the =9CIgnition Switc h=9D as seen on my > one line. With that switch in the =9Coff=9D position and Brea ker 13 open the > voltage to ground on R, B+, and C each measured 12.7 VDC in stead of 0 VD C. > This is the same wiring arrangement as shown in the Rotax 912 Installatio n > Manual, page 46 of 66 Dated 1997 03 26. Unless I am =9Csomewhere lo st in > translation=9D, If Mr. Truemper has his engine wired according to t he Rotax > manual (which is the same as mine, he should also be reading the voltage to > ground on R, B+, and C each as 12+ VDC in stead of 0 VDC > > > Having said all this, have I lost my mind?? According to the attached one > line is my electrical system wired > correctly???? > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > Senior Consultant > > Worldwide Engineering Inc. > > 4090 North NC Hwy. 16 > > Denver, NC 28037 > > > Ph. 704-661-8271 > > Fax 704-483-5466 > > Email hgmckay(at)bellsouth.net > > http://www.geo.com (click on Power Division) > > Sent from Mail for > Windows 10 > > > *From: *Dave Alberti <daberti(at)sbcglobal.net> > *Sent: *Tuesday, November 20, 2018 7:23 PM > *To: *rotaxengines-list(at)matronics.com > *Subject: *Re: RotaxEngines-List: Rotax 912 UL Rectifier wiring > > > You don=99t show a battery relay to that isolates the battery when all > switches are off (as in shutdown) which is in the rotax install wiring > diagram. I believe that is the master that Truemper=99s speaking about. > > Dave Alberti > > 414-699-9312 > > > On Nov 20, 2018, at 3:46 PM, Hugh McKay wrote: > > I need some advice by anyone out there who may be able to clear up a > question I have concerning checking the output wiring of the standard Rot ax > 912 rectifier used with the 912 UL engine. I have this rectifier on my > Allegro 2000 ELSA (912 UL engine). For additional information I am > attaching my airplane wiring one line diagram that shows how my rectifier > is wired. Also I want to make reference to a Blog article authored by Kla us > Truemper titled *=9C18 December 2012 Testing Rotax 912/914 Generato r and > Rectifier=9D. *You can Google the title and read the article. > > > In the section of Mr. Truemper=99s article (Testing Regulator/Recti fier) > where he states =9CWith the Master switch off: The above test (refe rring to > the previous paragraph) should show 0 voltage for all three cases. I do n ot > know what Mr. Truemper=99s wiring diagram looked like because he di d not > offer one in his article. > > > After reading Mr. Truemper=99s article and because of some perceive d battery > charging issues I was having with my airplane I thought I would check my > rectifier according to his instructions in the article section titled > (Testing Regulator/Rectifier). All the tests he listed (the same ones I > did) fell within the values stated in his article except those tested wit h > the Master switch =9Coff=9D. In my case, with the Master swit ch =9Coff=9D the > voltage to ground on R, B+, and C each measured 12.7 VDC in stead of 0 VD C. > > > Again I don=99t have Mr. Truemper=99s wiring diagram, but in the wiring > diagram shown in the Rotax 912 UL engine installation manual their wiring > diagram indicates that there will be regular 12 VDC battery voltage on R, > B+, and C when the master switch is =9Coff=9D. > > > My question is this: Assuming there is a disconnect switch between > terminal C and B+ in the open position (per instruction from Rotax to > protect the battery from discharge), with the Master switch in the =9Coff=9D > position should I be measuring 12+VDC to ground on R, B+, and C rather th an > 0 VDC?? > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > > Senior Consultant > > Worldwide Engineering Inc. > > 4090 North NC Hwy. 16 > > Denver, NC 28037 > > > Ph. 704-661-8271 > > Fax 704-483-5466 > > Email hgmckay(at)bellsouth.net > > http://www.geo.com (click on Power Division) > > Sent from Mail for > Windows 10 > > > > > > > > ________________________________________________________________________________
Date: Nov 21, 2018
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 21, 2018
Hugh, In your diagram switch/breaker CB13 only disconnects the C terminal of the Ducatti from R & B+. In your diagram there is no way to disconnect the battery from R & B+ except by Fuse labeled Battery Booster (30A) or the 100A fuse (not advised). Ducatti Terminal C has two functions. It provides voltage for the electronics inside the Ducatti for to operate. It also is used to sense bus voltage which in turn "tells" the Ducatti what the system requires, ie is the battery charged so no output is required, is the system working normally so just top up charging (output) is required or is the battery discharged so lots of output is required. Since C provides power to the Ducatti, it must be disconnected from the battery when the engine isn't running and providing voltage to the airplane bus or it will cause the battery to slowly discharge, just like leaving a light on. >From your diagram the ignition switch has four positions. Pos 1, ACC will provide power to the bottom left side of the diagram, looks like flap position, front landing light, strobe lights, position lights, wing tip landing and tail lights and cabin lights. It also powers the left side of the diagram, sockets, GPS, Radio, ICM, Transponder and dual V/A meter. Pos 2, OFF doesn't supply power to anything. However, C on the Ducatti will still be connected to the battery and slowly draining the battery because it powers the electronics inside the Ducatti. Pos 3 probably labeled RUN supplies power exactly as Pos 1, ACC and also controls the Rotax ignition modules (the last implied, not shown). Pos 4 probably labeled START provides power to the start contactor (relay) as well as the Rotax ignition modules (again implied, not shown). So to answer your original question, with Master in Pos 2, OFF and the switch/breaker CB13 open (off) you should read 12 VDC on B+ and R and 0 on C. Turn switch/breaker CB13 closed (on) and you should read 12 VDC on R, B+ and C. It appears that in Pos 4, START none of the ACC circuits will be powered but they will be when the switch returns to Pos 3, RUN. This means none of your lights radios or the dual V/A meter will function during START. If you refer to Lockwoods article, note that you should not interrupt the connection between C and R/B+ during engine run and that connection should have low resistance, less than .2 VDC difference. It is OK to disconnect C from R and B+ when the engine is not running. Your diagram should work just fine. Just be sure to turn ON switch/breaker CB13 prior to or right after start (at which time light 16 should go off indicating the Ducatti is on line and working) and always turn OFF switch/breaker CB13 after engine shut down. Hope this helps. Jim Butcher Read this topic online here: http://forums.matronics.com/viewtopic.php?p=485475#485475 ________________________________________________________________________________
Date: Nov 21, 2018
Hugh, I have an actual contractor (looks like a solenoid) from Spruce design ed to use for this application. Mine is on the firewall near my battery. My comparison position is prior to your ammeter shunt. You would have to wire y our breaker so that when closed it would energize the solenoid to close the c ircuit supplying 12 volts to B+, R and C. I use a switch like Cessna, red s plit battery alternator . Dave Alberti > On Nov 20, 2018, at 10:31 PM, Hugh McKay wrote: > > Dave, > > Thanks for your clarification of the Rotax instruction concerning disconne cting the battery. I went back and read a similar article by Phil Lockwood c alled =9CTips and Tricks for the Ideal Rotax 912 Installation=9D published in 2005. In that article he clearly states that the + battery wir e that is connected to R, B+, and C must be disconnected from the battery. B ased on my wiring one line drawing where would you recommend I move Breaker 1 3 to isolate the battery, and should I change the breaker to a larger amp ra ting? > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > Ph. 704-661-8271 > Fax 704-483-5466 > Email hgmckay(at)bellsouth.net > http://www.geo.com (click on Power Division) > Sent from Mail for Windows 10 > > From: Dave Alberti > Sent: Tuesday, November 20, 2018 9:41 PM > To: rotaxengines-list(at)matronics.com > Subject: Re: RotaxEngines-List: Rotax 912 UL Rectifier wiring > > Hugh, that does not isolate the battery, the rotax drawing drops at relay 1 9 and takes all voltage off the regulator at B+ and R. > > Dave Alberti > 414-699-9312 > > On Nov 20, 2018, at 7:59 PM, Hugh McKay wrote: > > Dave, > > My battery is manually isolated by Breaker 13 shown within the =9Ccl oud=9D noted as Rev.#1 on the attached one line (better drawing than w hat I sent previous). All the Breakers mounted on the panel including Breake r 13 are Potter & Brumfield W23 Push Button Thermal circuit breakers that ca n also be used as manual isolation switches. I assumed the term =9CMas ter Switch=9D as used by Mr. Truemper meant the =9CIgnition Swit ch=9D as seen on my one line. With that switch in the =9Coff =9D position and Breaker 13 open the voltage to ground on R, B+, and C each m easured 12.7 VDC in stead of 0 VDC. This is the same wiring arrangement as s hown in the Rotax 912 Installation Manual, page 46 of 66 Dated 1997 03 26. U nless I am =9Csomewhere lost in translation=9D, If Mr. Truemper h as his engine wired according to the Rotax manual (which is the same as mine , he should also be reading the voltage to ground on R, B+, and C each as 12 + VDC in stead of 0 VDC > > Having said all this, have I lost my mind?? According to the attached one l ine is my electrical system wired correctly???? > > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > Ph. 704-661-8271 > Fax 704-483-5466 > Email hgmckay(at)bellsouth.net > http://www.geo.com (click on Power Division) > Sent from Mail for Windows 10 > > From: Dave Alberti > Sent: Tuesday, November 20, 2018 7:23 PM > To: rotaxengines-list(at)matronics.com > Subject: Re: RotaxEngines-List: Rotax 912 UL Rectifier wiring > > You don=99t show a battery relay to that isolates the battery when a ll switches are off (as in shutdown) which is in the rotax install wiring di agram. I believe that is the master that Truemper=99s speaking about . > > Dave Alberti > 414-699-9312 > > On Nov 20, 2018, at 3:46 PM, Hugh McKay wrote: > > I need some advice by anyone out there who may be able to clear up a quest ion I have concerning checking the output wiring of the standard Rotax 912 r ectifier used with the 912 UL engine. I have this rectifier on my Allegro 2 000 ELSA (912 UL engine). For additional information I am attaching my airpl ane wiring one line diagram that shows how my rectifier is wired. Also I wan t to make reference to a Blog article authored by Klaus Truemper titled =9C18 December 2012 Testing Rotax 912/914 Generator and Rectifier=9D. Y ou can Google the title and read the article. > > In the section of Mr. Truemper=99s article (Testing Regulator/Rectif ier) where he states =9CWith the Master switch off: The above test (re ferring to the previous paragraph) should show 0 voltage for all three cases . I do not know what Mr. Truemper=99s wiring diagram looked like becau se he did not offer one in his article. > > After reading Mr. Truemper=99s article and because of some perceived battery charging issues I was having with my airplane I thought I would che ck my rectifier according to his instructions in the article section titled ( Testing Regulator/Rectifier). All the tests he listed (the same ones I did) f ell within the values stated in his article except those tested with the Mas ter switch =9Coff=9D. In my case, with the Master switch =9C off=9D the voltage to ground on R, B+, and C each measured 12.7 VDC in stead of 0 VDC. > > Again I don=99t have Mr. Truemper=99s wiring diagram, but in t he wiring diagram shown in the Rotax 912 UL engine installation manual their wiring diagram indicates that there will be regular 12 VDC battery voltage o n R, B+, and C when the master switch is =9Coff=9D. > > My question is this: Assuming there is a disconnect switch between termina l C and B+ in the open position (per instruction from Rotax to protect the b attery from discharge), with the Master switch in the =9Coff=9D p osition should I be measuring 12+VDC to ground on R, B+, and C rather than 0 VDC?? > > Hugh G. McKay III, P.E. Fellow. L.M. ASCE > Senior Consultant > Worldwide Engineering Inc. > 4090 North NC Hwy. 16 > Denver, NC 28037 > > Ph. 704-661-8271 > Fax 704-483-5466 > Email hgmckay(at)bellsouth.net > http://www.geo.com (click on Power Division) > Sent from Mail for Windows 10 > > > > > > ________________________________________________________________________________
Date: Nov 21, 2018
Dave, I am not an electrical guru so my understanding of electrical terms and fun ctions in an electrical circuit is very limited. I do need to limit the amo unt of changes to my panel simply due to space. Therefore, I am attaching a scanned sketch of what I propose doing, hoping that it will be safe and me et the electrical requirements for safe operation of the rectifier and give the isolation requirements described by Rotax. Please refer to the attache d sketch and the original one line to compare the proposed changes to the o riginal. You will note on the sketch that I have a common point where I connect 5 wi res to a common connection (R, B+, C, the wire from the Capacitor, and the wire from the 30 Amp fuse). Between the 30 Amp fuse and the shunt I propose using my existing Breaker 13 (Potter & Brumfield Series W23 Push Button Th ermal circuit breaker W23-X1A1G5 (which is certified to be used as a manual push to close/pull to open disconnect) rated for 5 Amps having a Trip time at 200% rating of 6-22 seconds. If necessary I can replace this same ident ical Potter & Brumfield breaker with Amp ratings up to 50 Amps. By the way all the breakers shown on the one line are panel mounted Potter & Brumfield Series W23 Push Button Thermal circuit breakers. I use these breakers rout
September 01, 2017 - November 21, 2018
RotaxEngines-Archive.digest.vol-bj
