Stratus-Archive.digest.vol-ac
October 05, 2004 - July 31, 2005
Date: Oct 05, 2004
Subject: Stratus EA-81 Cooling
Frank, no embarrassment, I did plumb as you described - but that was also how the factory told me to do it. The first question I asked them when they described how to put the pumps was "won't that pump sucking the fuel cause vapour-lock if the wing pump fails?". They said it wouldn't and if I remember correctly he said they had theirs plumbed that way at the time. This didn't necessarily convince me but with the wing tank pump pushing I didn't worry too much. For me to have fuel starvation the following needs to happen : 1. One wing tank pump fails =09- switch tanks and pumps 2. Other wing tank pump fails - allow firewall pump to continue pumping 3. Firewall pump either fails or vapour-locks within minutes of 2 since flight will be terminated after 1 or 2. 4. I allow the flight to continue long enough for this to all transpire. I tend to doubt that a two pumps will fail within a few minutes and the third will immediately cause vapour-lock before I could get down. If I am being naive feel free to say so, rather have my feelings hurt than kill myself.Feel free to let me know your thoughts and recommendations, again, free exchange of ideas and knowledge is a good thing and I won't be upset if you say I'm being a moron - just do it nicely ;) Thanks! Andy wrote: >(Corvallis)" > >Andy, > >If you have don what I think you have, then I do not like your fuel >system design. > >This is what I THINK you did... > >You put a single pump that draws from both tanks using a selector >valve >perhaps? You have a second pump on the firewall that is plumbed in >series with the wing tanks. > >I say I think you did this because series plumbing of two pumps is >the >only way your pressure will double like that. > >Is this the case?...If so I think you should replumb your system as >you >are asking for vapour lock....with deadly consequences...Admittedly >the >the wing tank pump will have to fail for this to happen but its not >ideal by any stretch. > >Let me know what you did and we can talk some more. > >I will post this to the group, not to embarrass you, just simply to >get >the word out. > >Frank > > Frank, no embarrassment, I did plumb as you described - but that was also how the factory told me to do it. The first question I asked them when they described how to put the pumps was won't that pump sucking the fuel cause vapour-lock if the wing pump fails?. They said it wouldn't and if I remember correctly he said they had theirs plumbed that way at the time. This didn't necessarily convince me but with the wing tank pump pushing I didn't worry too much. For me to have fuel starvation the following needs to happen : 1. One wing tank pump fails - switch tanks and pumps 2. Other wing tank pump fails - allow firewall pump to continue pumping 3. Firewall pump either fails or vapour-locks within minutes of 2 since flight will be terminated after 1 or 2. 4. I allow the flight to continue long enough for this to all transpire. I tend to doubt that a two pumps will fail within a few minutes and the third will immediately cause vapour-lock before I could get down. If I am being naive feel free to say so, rather have my feelings hurt than kill myself.Feel free to let me know your thoughts and recommendations, again, free exchange of ideas and knowledge is a good thing and I won't be upset if you say I'm being a moron - just do it nicely ;) Thanks! Andy --=A0Stratus-List message posted by: Hinde, Frank George (Corvallis) frank.hinde(at)hp.com Andy, If you have don what I think you have, then I do not like your fuel system design. This is what I THINK you did... You put a single pump that draws from both tanks using a selector valve perhaps? You have a second pump on the firewall that is plumbed in series with the wing tanks. I say I think you did this because series plumbing of two pumps is the only way your pressure will double like that. Is this the case?...If so I think you should replumb your system as you are asking for vapour lock....with deadly consequences...Admittedly the the wing tank pump will have to fail for this to happen but its not ideal by any stretch. Let me know what you did and we can talk some more. I will post this to the group, not to embarrass you, just simply to get the word out. Frank ________________________________________________________________________________
Date: Oct 05, 2004
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Actually for some reason I thought you only had wing tanks...probably been so long since I been flying with wing tanks only that I complety forgot about the header tank. Secondly I had assumed from your description that you only had two pumps...One on the firewall and one for both wing tanks. If you have a header the problem goes away because there is always positive head over the firewall pump. If you have THREE pumps (one at the outlet of each tank and one on the firewall) and no header tank the problem also goes away...Except that the firewall pump is a third level of protection (and designing to this level is overkill) and the fuel pressure will go too high when two or three pumps are run. Personally I would remove the firewall pump if you don't have the header. The important thing here is to NOT suck on the fuel and have a redundant pump that will also not suck on the fuel.....One pump at the outlet of each tank is fine. Also make sure each pump is fed from a separate electrical source (I have two electrically isolated batteries, one ignition and one pump fed from each battery) Hope that helps Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Andrew SanClemente Subject: RE: Stratus-List: Stratus EA-81 Cooling --> Frank, no embarrassment, I did plumb as you described - but that was also how the factory told me to do it. The first question I asked them when they described how to put the pumps was "won't that pump sucking the fuel cause vapour-lock if the wing pump fails?". They said it wouldn't and if I remember correctly he said they had theirs plumbed that way at the time. This didn't necessarily convince me but with the wing tank pump pushing I didn't worry too much. For me to have fuel starvation the following needs to happen : 1. One wing tank pump fails =09- switch tanks and pumps 2. Other wing tank pump fails - allow firewall pump to continue pumping 3. Firewall pump either fails or vapour-locks within minutes of 2 since flight will be terminated after 1 or 2. 4. I allow the flight to continue long enough for this to all transpire. I tend to doubt that a two pumps will fail within a few minutes and the third will immediately cause vapour-lock before I could get down. If I am being naive feel free to say so, rather have my feelings hurt than kill myself.Feel free to let me know your thoughts and recommendations, again, free exchange of ideas and knowledge is a good thing and I won't be upset if you say I'm being a moron - just do it nicely ;) Thanks! Andy wrote: >(Corvallis)" > >Andy, > >If you have don what I think you have, then I do not like your fuel >system design. > >This is what I THINK you did... > >You put a single pump that draws from both tanks using a selector valve >perhaps? You have a second pump on the firewall that is plumbed in >series with the wing tanks. > >I say I think you did this because series plumbing of two pumps is the >only way your pressure will double like that. > >Is this the case?...If so I think you should replumb your system as you >are asking for vapour lock....with deadly consequences...Admittedly >the >the wing tank pump will have to fail for this to happen but its not >ideal by any stretch. > >Let me know what you did and we can talk some more. > >I will post this to the group, not to embarrass you, just simply to get >the word out. > >Frank > > Frank, no embarrassment, I did plumb as you described - but that was also how the factory told me to do it. The first question I asked them when they described how to put the pumps was won't that pump sucking the fuel cause vapour-lock if the wing pump fails?. They said it wouldn't and if I remember correctly he said they had theirs plumbed that way at the time. This didn't necessarily convince me but with the wing tank pump pushing I didn't worry too much. For me to have fuel starvation the following needs to happen : 1. One wing tank pump fails - switch tanks and pumps 2. Other wing tank pump fails - allow firewall pump to continue pumping 3. Firewall pump either fails or vapour-locks within minutes of 2 since flight will be terminated after 1 or 2. 4. I allow the flight to continue long enough for this to all transpire. I tend to doubt that a two pumps will fail within a few minutes and the third will immediately cause vapour-lock before I could get down. If I am being naive feel free to say so, rather have my feelings hurt than kill myself.Feel free to let me know your thoughts and recommendations, again, free exchange of ideas and knowledge is a good thing and I won't be upset if you say I'm being a moron - just do it nicely ;) Thanks! Andy wrote: --=A0Stratus-List message posted by: Hinde, Frank George (Corvallis) frank.hinde(at)hp.com Andy, If you have don what I think you have, then I do not like your fuel system design. This is what I THINK you did... You put a single pump that draws from both tanks using a selector valve perhaps? You have a second pump on the firewall that is plumbed in series with the wing tanks. I say I think you did this because series plumbing of two pumps is the only way your pressure will double like that. Is this the case?...If so I think you should replumb your system as you are asking for vapour lock....with deadly consequences...Admittedly the the wing tank pump will have to fail for this to happen but its not ideal by any stretch. Let me know what you did and we can talk some more. I will post this to the group, not to embarrass you, just simply to get the word out. Frank == direct advertising on the Matronics Forums. == == == ________________________________________________________________________________
Date: Oct 06, 2004
Frank, I don't have a header, just the wing tanks. Currently the setup is a pump at each wing tank, and an additional inline pump on the firewall (Boost Pump). Only one tank is active at a time via an Andor selector and there is a separate pump switch for each tank and a third switch for the boost pump. Im glad to hear its not completely messed up since my airworthiness inspection is most likely going to be next week and Id hate to be re-plumbing my entire fuel system! Should I run the "boost" (firewall) pump on takeoff and landing or is just the one wing tank pump sufficient even though its at the bottom end of the allowable fuel pressure range? What exactly happens when the fuel pressure is too high at the carbs? Thanks for the information and feedback! -Andy wrote: >(Corvallis)" > >Actually for some reason I thought you only had wing tanks...probably >been so long since I been flying with wing tanks only that I complety >forgot about the header tank. > >Secondly I had assumed from your description that you only had two >pumps...One on the firewall and one for both wing tanks. > >If you have a header the problem goes away because there is always >positive head over the firewall pump. > >If you have THREE pumps (one at the outlet of each tank and one on >the >firewall) and no header tank the problem also goes away...Except that >the firewall pump is a third level of protection (and designing to >this >level is overkill) and the fuel pressure will go too high when two or >three pumps are run. > >Personally I would remove the firewall pump if you don't have the >header. > >The important thing here is to NOT suck on the fuel and have a >redundant >pump that will also not suck on the fuel.....One pump at the outlet >of >each tank is fine. > >Also make sure each pump is fed from a separate electrical source (I >have two electrically isolated batteries, one ignition and one pump >fed >from each battery) > >Hope that helps > >Frank > Frank, I don't have a header, just the wing tanks. Currently the setup is a pump at each wing tank, and an additional inline pump on the firewall (Boost Pump). Only one tank is active at a time via an Andor selector and there is a separate pump switch for each tank and a third switch for the boost pump. Im glad to hear its not completely messed up since my airworthiness inspection is most likely going to be next week and Id hate to be re-plumbing my entire fuel system! Should I run the boost (firewall) pump on takeoff and landing or is just the one wing tank pump sufficient even though its at the bottom end of the allowable fuel pressure range? What exactly happens when the fuel pressure is too high at the carbs? Thanks for the information and feedback! -Andy --=A0Stratus-List message posted by: Hinde, Frank George (Corvallis) frank.hinde(at)hp.com Actually for some reason I thought you only had wing tanks...probably been so long since I been flying with wing tanks only that I complety forgot about the header tank. Secondly I had assumed from your description that you only had two pumps...One on the firewall and one for both wing tanks. If you have a header the problem goes away because there is always positive head over the firewall pump. If you have THREE pumps (one at the outlet of each tank and one on the firewall) and no header tank the problem also goes away...Except that the firewall pump is a third level of protection (and designing to this level is overkill) and the fuel pressure will go too high when two or three pumps are run. Personally I would remove the firewall pump if you don't have the header. The important thing here is to NOT suck on the fuel and have a redundant pump that will also not suck on the fuel.....One pump at the outlet of each tank is fine. Also make sure each pump is fed from a separate electrical source (I have two electrically isolated batteries, one ignition and one pump fed from each battery) Hope that helps Frank ________________________________________________________________________________
Date: Oct 06, 2004
If you use the 106 pump (not the 105) it will give you about 3.5psi at full power which is just fine. The boost pump makes way too much pressure and does nothing to avoid vapour lock. The Andair selector is redundant and unnecessary...just switch pumps to switch tanks...sooner of later you will get confused which pump goes with which valve position. I just have an on/off valve (for impending crashes) and non return valves on the discharge of the pumps (I also have a filter for each pump here) so the contents of one tank don't end up in the other. Run both wing tank pumps on take off. Because the pumps are in parallel they will not double the pressure like what is happening now. Too much pressure means eventually you will flood the carbs because the fuel pressure will overcome the float valve...Maybe not now but in time this could happen. If you remove the boost pump you will also remove some pressure drop which will bring your pressure up a bit at the carbs Run both on takeoff and you will also get another 1 psi or so. I never rely on just one pump on take off. Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Andrew SanClemente Subject: RE: Stratus-List: Stratus EA-81 Cooling --> Frank, I don't have a header, just the wing tanks. Currently the setup is a pump at each wing tank, and an additional inline pump on the firewall (Boost Pump). Only one tank is active at a time via an Andor selector and there is a separate pump switch for each tank and a third switch for the boost pump. Im glad to hear its not completely messed up since my airworthiness inspection is most likely going to be next week and Id hate to be re-plumbing my entire fuel system! Should I run the "boost" (firewall) pump on takeoff and landing or is just the one wing tank pump sufficient even though its at the bottom end of the allowable fuel pressure range? What exactly happens when the fuel pressure is too high at the carbs? Thanks for the information and feedback! -Andy wrote: >(Corvallis)" > >Actually for some reason I thought you only had wing tanks...probably >been so long since I been flying with wing tanks only that I complety >forgot about the header tank. > >Secondly I had assumed from your description that you only had two >pumps...One on the firewall and one for both wing tanks. > >If you have a header the problem goes away because there is always >positive head over the firewall pump. > >If you have THREE pumps (one at the outlet of each tank and one on the >firewall) and no header tank the problem also goes away...Except that >the firewall pump is a third level of protection (and designing to this >level is overkill) and the fuel pressure will go too high when two or >three pumps are run. > >Personally I would remove the firewall pump if you don't have the >header. > >The important thing here is to NOT suck on the fuel and have a >redundant pump that will also not suck on the fuel.....One pump at the >outlet of >each tank is fine. > >Also make sure each pump is fed from a separate electrical source (I >have two electrically isolated batteries, one ignition and one pump fed >from each battery) > >Hope that helps > >Frank > Frank, I don't have a header, just the wing tanks. Currently the setup is a pump at each wing tank, and an additional inline pump on the firewall (Boost Pump). Only one tank is active at a time via an Andor selector and there is a separate pump switch for each tank and a third switch for the boost pump. Im glad to hear its not completely messed up since my airworthiness inspection is most likely going to be next week and Id hate to be re-plumbing my entire fuel system! Should I run the boost (firewall) pump on takeoff and landing or is just the one wing tank pump sufficient even though its at the bottom end of the allowable fuel pressure range? What exactly happens when the fuel pressure is too high at the carbs? Thanks for the information and feedback! -Andy wrote: --=A0Stratus-List message posted by: Hinde, Frank George (Corvallis) frank.hinde(at)hp.com Actually for some reason I thought you only had wing tanks...probably been so long since I been flying with wing tanks only that I complety forgot about the header tank. Secondly I had assumed from your description that you only had two pumps...One on the firewall and one for both wing tanks. If you have a header the problem goes away because there is always positive head over the firewall pump. If you have THREE pumps (one at the outlet of each tank and one on the firewall) and no header tank the problem also goes away...Except that the firewall pump is a third level of protection (and designing to this level is overkill) and the fuel pressure will go too high when two or three pumps are run. Personally I would remove the firewall pump if you don't have the header. The important thing here is to NOT suck on the fuel and have a redundant pump that will also not suck on the fuel.....One pump at the outlet of each tank is fine. Also make sure each pump is fed from a separate electrical source (I have two electrically isolated batteries, one ignition and one pump fed from each battery) Hope that helps Frank == direct advertising on the Matronics Forums. == == == ________________________________________________________________________________
Date: Oct 07, 2004
So now you tell me I could have saved all that time - money - and aggravation on setting up the Andair selector!! I like your setup, nice clean and simple. wrote: >(Corvallis)" > >If you use the 106 pump (not the 105) it will give you about 3.5psi >at >full power which is just fine. The boost pump makes way too much >pressure and does nothing to avoid vapour lock. > >The Andair selector is redundant and unnecessary...just switch pumps >to >switch tanks...sooner of later you will get confused which pump goes >with which valve position. > >I just have an on/off valve (for impending crashes) and non return >valves on the discharge of the pumps (I also have a filter for each >pump >here) so the contents of one tank don't end up in the other. > >Run both wing tank pumps on take off. Because the pumps are in >parallel >they will not double the pressure like what is happening now. > >Too much pressure means eventually you will flood the carbs because >the >fuel pressure will overcome the float valve...Maybe not now but in >time >this could happen. > >If you remove the boost pump you will also remove some pressure drop >which will bring your pressure up a bit at the carbs Run both on >takeoff >and you will also get another 1 psi or so. > >I never rely on just one pump on take off. > >Frank > >-----Original Message----- >From: owner-stratus-list-server(at)matronics.com >[mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Andrew >SanClemente >To: stratus-list(at)matronics.com >Subject: RE: Stratus-List: Stratus EA-81 Cooling > > >--> > >Frank, >I don't have a header, just the wing tanks. Currently the setup is >a pump at each wing tank, and an additional inline pump on the >firewall (Boost Pump). >Only one tank is active at a time via an Andor selector and there is >a separate pump switch for each tank and a third switch for the >boost >pump. >Im glad to hear its not completely messed up since my airworthiness >inspection is most likely going to be next week and Id hate to be >re-plumbing my entire fuel system! > >Should I run the "boost" (firewall) pump on takeoff and landing or >is >just the one wing tank pump sufficient even though its at the bottom >end of the allowable fuel pressure range? What exactly happens when >the fuel pressure is too high at the carbs? > >Thanks for the information and feedback! >-Andy > > >wrote: >>(Corvallis)" >> >>Actually for some reason I thought you only had wing >tanks...probably >>been so long since I been flying with wing tanks only that I >complety >>forgot about the header tank. >> >>Secondly I had assumed from your description that you only had two >>pumps...One on the firewall and one for both wing tanks. >> >>If you have a header the problem goes away because there is always >>positive head over the firewall pump. >> >>If you have THREE pumps (one at the outlet of each tank and one on >>the >>firewall) and no header tank the problem also goes away...Except >that >>the firewall pump is a third level of protection (and designing to >>this >>level is overkill) and the fuel pressure will go too high when two >or >>three pumps are run. >> >>Personally I would remove the firewall pump if you don't have the >>header. >> >>The important thing here is to NOT suck on the fuel and have a >>redundant pump that will also not suck on the fuel.....One pump at >>the >>outlet of >>each tank is fine. >> >>Also make sure each pump is fed from a separate electrical source >>(I >>have two electrically isolated batteries, one ignition and one pump >>fed >>from each battery) >> >>Hope that helps >> >>Frank >> > > >Frank, >I don't have a header, just the wing tanks. Currently the setup is >a >pump at each wing tank, and an additional inline pump on the firewall >(Boost Pump). >Only one tank is active at a time via an Andor selector and there is >a >separate pump switch for each tank and a third switch for the boost >pump. >Im glad to hear its not completely messed up since my airworthiness >inspection is most likely going to be next week and Id hate to be >re-plumbing my entire fuel system! > >Should I run the boost (firewall) pump on takeoff and landing or is >just the one wing tank pump sufficient even though its at the bottom >end >of the allowable fuel pressure range? What exactly happens when the >fuel >pressure is too high at the carbs? > >Thanks for the information and feedback! >-Andy > > >wrote: --=A0Stratus-List message posted by: Hinde, Frank George >(Corvallis) frank.hinde(at)hp.com > >Actually for some reason I thought you only had wing >tanks...probably >been so long since I been flying with wing tanks only that I >complety >forgot about the header tank. > >Secondly I had assumed from your description that you only had two >pumps...One on the firewall and one for both wing tanks. > >If you have a header the problem goes away because there is always >positive head over the firewall pump. > >If you have THREE pumps (one at the outlet of each tank and one on >the >firewall) and no header tank the problem also goes away...Except >that >the firewall pump is a third level of protection (and designing to >this >level is overkill) and the fuel pressure will go too high when two >or >three pumps are run. > >Personally I would remove the firewall pump if you don't have the >header. > >The important thing here is to NOT suck on the fuel and have a >redundant pump that will also not suck on the fuel.....One pump at >the >outlet of each tank is fine. > >Also make sure each pump is fed from a separate electrical source (I >have two electrically isolated batteries, one ignition and one pump >fed >from each battery) > >Hope that helps > >Frank > > >== >direct advertising on the Matronics Forums. >== >== >== > > >_- >===================================================================== >=== >_- >===================================================================== >=== >_- >===================================================================== >=== >_- >===================================================================== >=== > > ________________________________________________________________________________
Date: Oct 08, 2004
I have been banging on about this subject for years (they call me Mr Vaopour lock...:).) it was all in the archives my friend. Remember if you use my setup it would be very worthwhile to install a non return valve at the discharge of each pump...The pumps are a little leaky backwards, its not much but enough to confuse you which tank the fuel is. I'm thinking of setting up my new Lycomming project (run on auto fuel) the same way. Have a good one. Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Andrew SanClemente Subject: RE: Stratus-List: Stratus EA-81 Cooling --> So now you tell me I could have saved all that time - money - and aggravation on setting up the Andair selector!! I like your setup, nice clean and simple. wrote: >(Corvallis)" > >If you use the 106 pump (not the 105) it will give you about 3.5psi at >full power which is just fine. The boost pump makes way too much >pressure and does nothing to avoid vapour lock. > >The Andair selector is redundant and unnecessary...just switch pumps to >switch tanks...sooner of later you will get confused which pump goes >with which valve position. > >I just have an on/off valve (for impending crashes) and non return >valves on the discharge of the pumps (I also have a filter for each >pump >here) so the contents of one tank don't end up in the other. > >Run both wing tank pumps on take off. Because the pumps are in parallel >they will not double the pressure like what is happening now. > >Too much pressure means eventually you will flood the carbs because the >fuel pressure will overcome the float valve...Maybe not now but in >time >this could happen. > >If you remove the boost pump you will also remove some pressure drop >which will bring your pressure up a bit at the carbs Run both on >takeoff and you will also get another 1 psi or so. > >I never rely on just one pump on take off. > >Frank > >-----Original Message----- >From: owner-stratus-list-server(at)matronics.com >[mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Andrew >SanClemente >To: stratus-list(at)matronics.com >Subject: RE: Stratus-List: Stratus EA-81 Cooling > > >--> > >Frank, >I don't have a header, just the wing tanks. Currently the setup is a >pump at each wing tank, and an additional inline pump on the firewall >(Boost Pump). Only one tank is active at a time via an Andor selector >and there is a separate pump switch for each tank and a third switch >for the boost >pump. >Im glad to hear its not completely messed up since my airworthiness >inspection is most likely going to be next week and Id hate to be >re-plumbing my entire fuel system! > >Should I run the "boost" (firewall) pump on takeoff and landing or is >just the one wing tank pump sufficient even though its at the bottom >end of the allowable fuel pressure range? What exactly happens when >the fuel pressure is too high at the carbs? > >Thanks for the information and feedback! >-Andy > > >wrote: >>(Corvallis)" >> >>Actually for some reason I thought you only had wing >tanks...probably >>been so long since I been flying with wing tanks only that I >complety >>forgot about the header tank. >> >>Secondly I had assumed from your description that you only had two >>pumps...One on the firewall and one for both wing tanks. >> >>If you have a header the problem goes away because there is always >>positive head over the firewall pump. >> >>If you have THREE pumps (one at the outlet of each tank and one on the >>firewall) and no header tank the problem also goes away...Except >that >>the firewall pump is a third level of protection (and designing to >>this level is overkill) and the fuel pressure will go too high when >>two >or >>three pumps are run. >> >>Personally I would remove the firewall pump if you don't have the >>header. >> >>The important thing here is to NOT suck on the fuel and have a >>redundant pump that will also not suck on the fuel.....One pump at the >>outlet of >>each tank is fine. >> >>Also make sure each pump is fed from a separate electrical source (I >>have two electrically isolated batteries, one ignition and one pump >>fed >>from each battery) >> >>Hope that helps >> >>Frank >> > > >Frank, >I don't have a header, just the wing tanks. Currently the setup is a >pump at each wing tank, and an additional inline pump on the firewall >(Boost Pump). >Only one tank is active at a time via an Andor selector and there is a >separate pump switch for each tank and a third switch for the boost >pump. >Im glad to hear its not completely messed up since my airworthiness >inspection is most likely going to be next week and Id hate to be >re-plumbing my entire fuel system! > >Should I run the boost (firewall) pump on takeoff and landing or is >just the one wing tank pump sufficient even though its at the bottom >end of the allowable fuel pressure range? What exactly happens when the >fuel >pressure is too high at the carbs? > >Thanks for the information and feedback! >-Andy > > >wrote: --=A0Stratus-List message posted by: Hinde, Frank George >(Corvallis) frank.hinde(at)hp.com > >Actually for some reason I thought you only had wing tanks...probably >been so long since I been flying with wing tanks only that I >complety >forgot about the header tank. > >Secondly I had assumed from your description that you only had two >pumps...One on the firewall and one for both wing tanks. > >If you have a header the problem goes away because there is always >positive head over the firewall pump. > >If you have THREE pumps (one at the outlet of each tank and one on the >firewall) and no header tank the problem also goes away...Except >that >the firewall pump is a third level of protection (and designing to >this >level is overkill) and the fuel pressure will go too high when two >or >three pumps are run. > >Personally I would remove the firewall pump if you don't have the >header. > >The important thing here is to NOT suck on the fuel and have a >redundant pump that will also not suck on the fuel.....One pump at the >outlet of each tank is fine. > >Also make sure each pump is fed from a separate electrical source (I >have two electrically isolated batteries, one ignition and one pump fed >from each battery) > >Hope that helps > >Frank > > >== >direct advertising on the Matronics Forums. >== >== >== > > >_- >===================================================================== >=== >_- >===================================================================== >=== >_- >===================================================================== >=== >_- >===================================================================== >=== > > == direct advertising on the Matronics Forums. == == == ________________________________________________________________________________
Subject: EGT and Timing Advance
Date: Oct 13, 2004
Hi Guys, I've been reading and researching the imbalance of EGTs right side to left on my Stratus. It's about a 60-degree F difference and the highest runs to 1450 for a short time in takeoff at 5100 rpm. I'm told the timing set by Stratus, set to 31-degrees can be adjusted a little bit to perhaps lower the EGT temps, but there's risk of detonation or on the opposite side, a loss of power. Does anyone know what actual acceptable limits for timing adjustment for the Stratus EA81 are, or have successful experience with adjusting timing for lower temps? Thanks for any experience or advice available on this one. Larry McFarland - 601HDS ________________________________________________________________________________
Date: Oct 14, 2004
Subject: CHT - Water Temps - Plug Colors
Having gotten to about 5 hours on my engine I have some questions and observations regarding a few things. My water temps are a consistent 165-170, never higher. My CHT climbs rapidly to 210-250 depending upon if Im moving or not, a fast taxi drops it down to 210-220. I just sent for a new oil temp sender as the vdo that came with the engine doesn't work for my gauge (mitchell). Should the CHT climb that rapidly? Does that water temp sound correct given the much higher CHT? I have seen in the archives where people have stated the CHT is a useless gauge, Im interested in comments. My water looks great but that CHT gauge has me nervous given its proximity to that 260 overheat mark stated by stratus. Since I don't have an oil temp yet I can't feed that data into this. I pulled my plugs and found that each is burning different. 4 is very sooty and black, 2 is a nice light to medium brown, 3 is black but not as sooty as four, and 1 is a darker brown that 2 but not bad. This seems strange to me as I would expect differences between carbs, but between cylinders? Again comments welcome, Thanks as usual - Andy ________________________________________________________________________________
Date: Oct 15, 2004
Subject: Rotation Speeds - 601 HDS
Sorry to ask this but I scoured the archives and couldn't find the numbers Im looking for. Im sure others may find this useful down the road as well. In a 601 HDS (I have stratus) What are people using for : - Rotation Speed on takeoff (and I noticed in the archives back elevator is required or no liftoff regardless of speed) - Downwind Leg - Base Leg - Final - Touchdown Please specify if your using MPH or KTS. Im finalizing my flight test plan and want to have these numbers in there. Thanks!!! Andy ________________________________________________________________________________
Subject: Stratus primer and fuel hookup questions
Date: Oct 15, 2004
I'm getting ready to install a Stratus EA81 on a Zenair 601HDS and have run into a couple of things lately I'm not too sure about: 1) What are folks using as fuel line between an electric primer (ACS type) and the carbs? The fitting on the bottom of the carbs is only about half an inch long and less than 1/4 inch OD. I'm having trouble finding a snug fit and you could barely get one hose clamp on there. Any suggestions? Are people replacing the primer fitting? Are people putting in a "T" on each carb to give access for carb sync tools? 2) What are you using for "T"s for the main fuel lines after the fuel filter? Zenith uses a small brass "T" that would accommodate one hose clamp per branch, but it seems a little "lawnmowerish" for an airplane. Using three AN 1/4 inch hose fittings screwed into an all-male "T" would work, but seems a bit ungainly. As much as I've read over the years, I must be missing some nifty products or ideas. Thanks in advance for the help, Ron Hansen Los Angeles 601HDS, day-nite VFR, scratch-built, Stratus, BRS Airframe 90% Plumbing 80% Wiring 60% ________________________________________________________________________________
Subject: Re: Stratus primer and fuel hookup questions
Date: Oct 15, 2004
Ron, I used the original dual-choke cables to put in the "inrichment circuit" (term used by Bing). Didn't like the short fitting either. As for the T after the main fuel filter, I used a AN 824 T and aeroquip 491 hose fittings with a stainless sheathed hose to get from the pumps to the filter and then to the carbs. These are clamped at the Bings and are really durable. Carb sync is worth while only once or twice if you've managed to avoid the dual cables for throttle control. I purchased a device to check this, but will not have much use for it after verifying the carbs are in sync because I made a flex connection that ties the carb throttles together and they are operated by a single solid sheathed .060 wire that does push-pull on the right carb from the firewall center arm. Works like a Cessna 150 or other and hits the stops exactly every time. If you need better pictures, just ask. More details can be found on my site for Scratch Built 601s on the Subaru engine page. www.macsmachine.com Congratulations on making it this far. The scratch built 601 is a great work in progress. Hope this helps. Larry McFarland - 601HDS (scratch built) w/Stratus and Ram Heads, 42 hours. Subject: Stratus-List: Stratus primer and fuel hookup questions > I'm getting ready to install a Stratus EA81 on a Zenair 601HDS and > have run into a couple of things lately I'm not too sure about: > > 1) What are folks using as fuel line between an electric primer (ACS > type) and the carbs? > > 2) What are you using for "T"s for the main fuel lines after the fuel > filter? > Thanks in advance for the help, > > Ron Hansen > Los Angeles > 601HDS, day-nite VFR, scratch-built, Stratus, BRS > Airframe 90% > Plumbing 80% > Wiring 60% ________________________________________________________________________________
Date: Oct 15, 2004
Ron, I used blue Aeroquip rubber hose and aluminum barbed 1/8 NPT fittings into a female 1/8NPT "T". gary > 1) What are folks using as fuel line between an electric primer (ACS > type) and the carbs? The fitting on the bottom of the carbs is only > about half an inch long and less than 1/4 inch OD. I'm having trouble > finding a snug fit and you could barely get one hose clamp on there. > Any suggestions? Are people replacing the primer fitting? Are people > putting in a "T" on each carb to give access for carb sync tools? > > 2) What are you using for "T"s for the main fuel lines after the fuel > filter? Zenith uses a small brass "T" that would accommodate one hose > clamp per branch, but it seems a little "lawnmowerish" for an airplane. > Using three AN 1/4 inch hose fittings screwed into an all-male "T" > would work, but seems a bit ungainly. As much as I've read over the > years, I must be missing some nifty products or ideas. > ________________________________________________________________________________
Date: Oct 18, 2004
Its flying at 60mph but I usually hold the nose down (in ground effect) till 70mph which seems to be about Vy. For really short fields I use about 65mph. My landing approach I make at 75 to 80mph Short fields about 70mph...Definate effort to hold the nose up on landing Frank Stratus 601 HDS...Nose heavy. -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Andrew SanClemente Subject: Stratus-List: Rotation Speeds - 601 HDS --> Sorry to ask this but I scoured the archives and couldn't find the numbers Im looking for. Im sure others may find this useful down the road as well. In a 601 HDS (I have stratus) What are people using for : - Rotation Speed on takeoff (and I noticed in the archives back elevator is required or no liftoff regardless of speed) - Downwind Leg - Base Leg - Final - Touchdown Please specify if your using MPH or KTS. Im finalizing my flight test plan and want to have these numbers in there. Thanks!!! Andy == direct advertising on the Matronics Forums. == == == ________________________________________________________________________________
Date: Oct 18, 2004
Subject: Ram Performance - new intake manifolds
I just ordered a new intake manifold from Ram that eliminates the dual bing carbs (which I hate). Ron has several new products including a fuel injection system witha direct fire ignition that sounds very slick. That system would require me to pull my heads and ship them back to have injectors put in, replace all fuel lines with high pressure lines, and add return lines to the tanks - way more work than I wanted to deal with. I ended up ordering the new intake manifold with the AeroV throttle body. It eliminates all that hose that snakes around the top of the engine, eliminates the dual carb issue, and eliminates the uneven mixtures from cylinder to cylinder caused by the current intakes and carbs. For mixture adjustment, you use a knob like in every other spam can, controllable from the cockpit. It should arrive in about 3 weeks, Ill let you all know how it works out. -Andy ________________________________________________________________________________
Date: Oct 18, 2004
Cool, Ron is a very talented and innovative individual and I wish we could get the word out to push more work his way. On the stepped valve guide issue he was the ONLY engine guy that could make a set of stepped valve guides with no problem and understood how to heat freeze them into the heads the way they should be. Thanks to Ron I'm finally relaxed knowing my engine is not looking for a place to kill me! Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Andrew SanClemente Subject: Stratus-List: Ram Performance - new intake manifolds --> I just ordered a new intake manifold from Ram that eliminates the dual bing carbs (which I hate). Ron has several new products including a fuel injection system witha direct fire ignition that sounds very slick. That system would require me to pull my heads and ship them back to have injectors put in, replace all fuel lines with high pressure lines, and add return lines to the tanks - way more work than I wanted to deal with. I ended up ordering the new intake manifold with the AeroV throttle body. It eliminates all that hose that snakes around the top of the engine, eliminates the dual carb issue, and eliminates the uneven mixtures from cylinder to cylinder caused by the current intakes and carbs. For mixture adjustment, you use a knob like in every other spam can, controllable from the cockpit. It should arrive in about 3 weeks, Ill let you all know how it works out. -Andy == direct advertising on the Matronics Forums. == == == ________________________________________________________________________________
Subject: Re: Ram Performance - new intake manifolds
Date: Oct 19, 2004
Gary, If you're wanting 130-140 hp for a 601, I'd recommend you take a pass on that one. The 601 is not a heavy plane, and the brackets that connect the longerons to the firewall and engine mount are not designed for anything of that potential weight and torque. The Stratus is a practical limit for weight and the Jabaru is a practical limit for HP. I'd be reluctant to combine a package that did both. The consequences of that type of decision could be fatal weeks, months or even years later. Larry McFarland - 601HDS > > Andy, I'm still thinking of upgrading because I'd > like 130-140HP, but I think I'd leave the Stratus as-is until I buy all > new > as another package. Better resale that way too. > Anyone know anyone flying with a full-up RAM engine? > > Gary ________________________________________________________________________________
Date: Oct 19, 2004
Larry, I've got a Pelican. It flies great on 100 HP but if I can swap in more HP at the same weight, that's a good trade for me. I'd like to put it on amphibious floats someday too. Gary ----- Original Message ----- From: "Larry McFarland" <larrymc(at)qconline.com> Subject: Re: Stratus-List: Ram Performance - new intake manifolds > > > Gary, > If you're wanting 130-140 hp for a 601, I'd recommend you take a > pass on that one. The 601 is not a heavy plane, and the brackets > that connect the longerons to the firewall and engine mount are not > designed for anything of that potential weight and torque. > The Stratus is a practical limit for weight and the Jabaru is a practical > limit for HP. I'd be reluctant to combine a package that did both. > The consequences of that type of decision could be fatal weeks, months > or even years later. > > Larry McFarland - 601HDS > >> >> Andy, > I'm still thinking of upgrading because I'd >> like 130-140HP, but I think I'd leave the Stratus as-is until I buy all >> new >> as another package. Better resale that way too. >> Anyone know anyone flying with a full-up RAM engine? >> >> Gary > > > ________________________________________________________________________________
Date: Oct 19, 2004
Gary, the particular change Im making does not have high pressure lines, it uses the same 4-5psi put out by a facet pump. Im getting a new intake manifold that uses the throttle body and thats it. You can get a different mod that is fuel injected with the direct fire ignition. As far as the standard Stratus setup goes, before my engine had 1 hour on it I had to : 1. Have the heads and valves done (talk to Frank ;) 2. Replace the distributor 3. Replace the alternator 4. Replace the backup ignition module 5. Im going to be replacing the carbs, (throttle body) but the throttle setup on my bing carbs is such that you end up "Pushing for idle, pulling for power" - opposite of what it should be. This happened due to some starters being longer (mine) and causing them to put the throttles on in a manner that fits. The byproduct being a reversed throttle setup - unsafe and a pain to fix. The current design of the intake manifold + carbs means that you will NEVER get all cylinders to have the same mixture. The best you can do is get 2 out of 4 burning properly, the other 2 will be too rich. Balancing two carbs is also more trouble than its worth in my opinion, Ill take simplicity over complexity any day - one carb to two. Having the ability to adjust the mixture from the cockpit like most spam cans also is something I like. Stratus is a good company and has been responsive to most of my problems and questions so I have nothing personal against them. I have just had too much trouble for what I paid. My two cents, which is about what its worth ;) - Andy > >Andy, >I heard that the Aero V carb doesn't work well under pressure. It's >made >for gravity feed I think. I don't know what I'm talking about but >you might >want to look into that. >Keep in mind that one of the best things about the Stratus is that >it's a >pretty well-proven package as-is. The more you change, the more >risk you >take (except for the valve guides - beat you to it Frank, and the >upper >right engine mount). Never heard of the dual carbs causing much of >a >problem, and there are lots of high-time Stratus's running with >slightly >unbalanced cylinders due to the intake. Not perfect, but pretty >darn good, >simple and cheap. Of course, I'm still thinking of upgrading >because I'd >like 130-140HP, but I think I'd leave the Stratus as-is until I buy >all new >as another package. Better resale that way too. >Anyone know anyone flying with a full-up RAM engine? > >Gary >=== >_- >===================================================================== >=== > > ________________________________________________________________________________
Date: Oct 20, 2004
Subject: Warp Drive Prop
Does anyone have the model number/name of the Prop that came with the Stratus Firewall Forward Package from Zenith? Thanks - Andy ________________________________________________________________________________
Subject: Re: Warp Drive Prop
Date: Oct 20, 2004
Andy, The Warp drive prop on my Stratus powered 601 is a Warp Drive HP 3/8" Hub No D1, SAE I pattern, #70-R-3 bladed Composite Fiber, w/tapered tips. Not sure if ZAC provides something other than what this describes. This is what I purchased from Warp Drive direct. Larry McFarland - 601HDS Subject: Stratus-List: Warp Drive Prop > > > Does anyone have the model number/name of the Prop that came with the > Stratus Firewall Forward Package from Zenith? > Thanks > - Andy ________________________________________________________________________________
Date: Oct 20, 2004
I believe that RAM is producing an EA-81 with 130 to 140 hp with little if any increase in weight. If you can get that much more horse power and the same weight, it should not be a problem for a 601 and would make it significantly faster. Would use a good deal more fuel though. Just my opinion. Regards, Bill ________________________________________________________________________________
Date: Oct 21, 2004
ZAC has said for years that the HD/HDS airfoil will not go significantly faster than what we/they have been seeing. It's a high-lift (and high-drag) airfoil. What you say, Bill, may be true for the XL with its thinner and lower-drag airfoil. I don't know, but that makes sense. With the HD/HDS, more power will get you a faster climb, but not enough more speed to justify the increase in cost/weight/fuel burned. You are completely correct about fuel burn rates; they're usually proportional to power generated. Phil Raker N556P HDS/Stratus ~85% completed > > If you can get that much more horse power and the same weight, > it should not be a problem for a 601 and would make it significantly faster. > Would use a good deal more fuel though. __________________________________ ________________________________________________________________________________
Date: Oct 21, 2004
Talk to Ron at Ram, he was telling me about one if his engines in a Europa I believe where they had it down to burning 2.5 gallons per hour at cruise - and I believe it was a 150 horse. He's doing some pretty incredible stuff with these engines. - A > > >I believe that RAM is producing an EA-81 with 130 to 140 hp with >little if any increase in weight. If you can get that much more >horse power and the same weight, it should not be a problem for a >601 and would make it significantly faster. Would use a good deal >more fuel though. > >Just my opinion. > >Regards, >Bill > ________________________________________________________________________________
Date: Oct 22, 2004
Keep in mind that Chris Heinz rates the airframe up to 115 HP. At least on the HD and HDS models (I believe the XL is the same). There have already been some problems with cracked motor mounts. Fly Safe, Jim Weston 601HDS Concord, Ga. -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Bill Morelli Subject: Re: Stratus-List: Ram Performance - new intake manifolds I believe that RAM is producing an EA-81 with 130 to 140 hp with little if any increase in weight. If you can get that much more horse power and the same weight, it should not be a problem for a 601 and would make it significantly faster. Would use a good deal more fuel though. Just my opinion. Regards, Bill == == == == ________________________________________________________________________________
Date: Oct 22, 2004
I'm sure you are correct that the HDS will not go faster than what ZAC has said it will. Problem is, mine does about 115 mph cruise (on a god day) and ZAC had always advertised I think in the 130 mph range. If I could get mine to go that fast with a 130 or so hp engine, I think it may be worth it (especially if the engine weight remained the same). Regards, Bill ________________________________________________________________________________
Date: Oct 25, 2004
True but the fuel burn will go WAY up....I think speed is proportional to power cubed (or is the squared?) ...Anyway lets say you do 125mph (WOT) on 8GPH right now...Well you 115mph is around 5 GPH correct? Do you really want to almost double your fuel burn for another 10mph?...Not worth it. On cross X you will be landing much more often that your door to dorr speed will be much higher by flying slower. Where 130+hp will benefit is doing what the 601 does pretty darned well already...i.e...CLIMB! A much better benefit would be to look at closing down the cowl openings (almost redundant in the Stratus intallation anyway) to reduce the cooling drag...That way you get hopfully some more speed with no extra fuel burn. Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Bill Morelli Subject: Re: Stratus-List: Ram Performance - new intake manifolds I'm sure you are correct that the HDS will not go faster than what ZAC has said it will. Problem is, mine does about 115 mph cruise (on a god day) and ZAC had always advertised I think in the 130 mph range. If I could get mine to go that fast with a 130 or so hp engine, I think it may be worth it (especially if the engine weight remained the same). Regards, Bill == == == == ________________________________________________________________________________
Subject: Spark plugs and EGT
Date: Oct 25, 2004
Hi guys, Is anyone using a spark plug other than the standard specified NKG BP6ET for the Stratus EA-81 for the purpose of lowering their EGT? A short piece on the internet suggests that various plugs provide differing effects on exhaust gas temps. Not sure how to read that either way, but if anyone has input on plugs, I'd like to hear about it. Larry McFarland - 601HDS ________________________________________________________________________________
Subject: Dual Dizzy ignition
Date: Nov 07, 2004
Hi guys, I finally got the spare distributor with the dual LX 600 pickups and the TP45 ignition modules wired and it started. It seems the engine needs both to start on and then either will run as needed. I used 30-degrees BTDC @4000rpm for the Stratus and so far it sounds good. The external ignition is still in place to be used as a double backup if needed. Do appreciate the help I've recieved on this site and have mailed my donation to Matt Dralle for making it happen. Thanks again, Larry McFarland - 601HDS - Stratus - Ram Heads - Dual Dizzy ________________________________________________________________________________
Subject: Dual ignition decision
Date: Nov 08, 2004
Hi Guys, After putting together the dual-ignition distributor and still having the flywheel ignition on board, I pause to wonder. Is it safer to use the distributor for both ignitions or is it better to use one pickup from the distributor and the other from the external electronic flywheel ignition? Do failures occur at the distributor cap or rotor that would push this decision this way or the other? The only ignition failure I've had was the tach pickup on the external and that's been no trouble since replacing it. I'd be interested in opinions on the matter as it's a case for deciding which of two sets of wires to use regularly. Thanks, Larry McFarland - 601HDS - Stratus Subaru ________________________________________________________________________________
Subject: Belt rumble vibration
Date: Nov 13, 2004
Hi guys, I've been chasing a pulse thinking the engine was missing because it vibrates a bit when it's cold and the pulse is felt until things warm up. After replacing the rotor, cap, plugs and checking coils and wires, it runs well warm, but there is still a rumble, vibration band at 2500 to 2800 rpm that seems a bit intense. Above and below that band everything sounds smooth. Am I looking at the difference between the seasonal warm of recent and the cold which is only 30-40 degrees cooler? It doesn't change when running off the A-distributor ignition or B-flywheel ignition, so perhaps it's the belt or my mixture. Still a 60-70 degree difference in EGTs, right being higher. Belt is snug to spec and the prop is tracking within 1/32" each blade, but there's still more vibration than I'd like to fly with. Any ideas on this? I feel like I've missed something here. Larry McFarland - 601HDS - Stratus at 45 hours and holding. ________________________________________________________________________________ DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; b=SbJgG3+1vVyDDqYAyXFjH+eTAf6WjTaG8oVjuw+zoai6ApdRtKcsK1Do2ooRhNB+bAlHfLF3/3D3a1GMBbSEMltiNTIOBp1gdXu87dfP26QJ8t4iU+cQf2gPXPHpGFQbZvC+unWRuC56hQNwT+pLrHBhseCKWLpLWnlth6afquc;
Date: Nov 14, 2004
Larry, If, as you say, the vibration is only in a fairly narrow RPM band, and if that band isn't at a normal operating speed (I doubt that you'd cruise the Stratus for very long at 25-2800), then perhaps the solution is a yellow band on the tachometer. I remember some others writing about a similar issue a year or so ago. Did you check the archives? As I recall, the conclusion was that the belt vibrated when run at certain speeds - not full speed or cruise settings. Doc, it hurts when I hit my head on the wall. -> So don't hit your head on the wall. My engine vibrates in a certain RPM range. -> So don't run it in that range. It sounds like an over-simplification, but that may be the best solution, especially if it's smooth at all other speeds. Phil Raker N556P HDS/Stratus ~85% completed Subject: Stratus-List: Belt rumble vibration > > It doesn't change when running off the A-distributor ignition or B-flywheel > ignition, so perhaps it's the belt or my mixture. > __________________________________ www.yahoo.com _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The Stratus-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: stratus-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/Stratus-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/stratus-list _-= Browse Digests: http://www.matronics.com/digest/stratus-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/stratus-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Subject: Re: Belt rumble vibration
Date: Nov 14, 2004
still a rumble, vibration band at 2500 to 2800 rpm ++++++++++++++++++++++++++++++++++ Larry, I get the same vib's but mine is about 3,300 RPM, so I also simply try to avoid that setting if possible. As nothing I found makes it go away. Kelly _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The Stratus-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: stratus-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/Stratus-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/stratus-list _-= Browse Digests: http://www.matronics.com/digest/stratus-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/stratus-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
you could run it without the prop to baseline the vibration level. if it's rough, work on the engine, if it's smooth, work on the prop/spinner. dynamic balance is well worth it and i found that getting every blade exactly the same helps. takes a little longer to fiddle with prop when adjusting pitch but i think it pays off. if you get a balance, make sure you put spinner on. Gary Krysztopik Pelican PL - N522GK Stratus Subaru EA-81 Newport, RI http://members.efortress.com/flyink/index.html ----- Original Message ----- From: "Larry McFarland" <larrymc(at)qconline.com> Subject: Stratus-List: Belt rumble vibration > > > Hi guys, > I've been chasing a pulse thinking the engine was missing > because it vibrates a bit when it's cold and the pulse is felt until > things warm > up. After replacing the rotor, cap, plugs and checking coils and wires, > it > runs well warm, but there is still a rumble, vibration band at 2500 to > 2800 rpm > that seems a bit intense. Above and below that band everything sounds > smooth. > Am I looking at the difference between the seasonal warm of recent and the > cold > which is only 30-40 degrees cooler? It doesn't change when running off > the A-distributor > ignition or B-flywheel ignition, so perhaps it's the belt or my mixture. > Still a 60-70 degree > difference in EGTs, right being higher. Belt is snug to spec and the prop > is tracking > within 1/32" each blade, but there's still more vibration than I'd like to > fly with. > > Any ideas on this? I feel like I've missed something here. > > Larry McFarland - 601HDS - Stratus at 45 hours and holding. > > > _-===================================================================== > _-> _-= -- Please Support Your Lists This Month -- > _-= (And Get Some AWESOME FREE Gifts!) > _-> _-= November is the Annual List Fund Raiser. Click on the > _-= Contribution link below to find out more about this > _-= year's Terrific Free Incentive Gifts provided by the > _-= The Builder's Bookstore www.buildersbooks.com! > _-> _-= List Contribution Web Site > _-> _-= http://www.matronics.com/contribution > _-> _-= Thank you for your generous support! > _-= -Matt Dralle, List Admin. > _-> _-===================================================================== > _-= - The Stratus-List Email Forum - > _-= This forum is sponsored entirely through the Contributions > _-= of List members. You'll never see banner ads or any other > _-= form of direct advertising on the Matronics Forums. > _-===================================================================== > _-= List Related Information > _-= Post Message: stratus-list(at)matronics.com > _-= UN/SUBSCRIBE: http://www.matronics.com/subscription > _-= List FAQ: http://www.matronics.com/FAQ/Stratus-List.htm > _-= Search Engine: http://www.matronics.com/search > _-= 7-Day Browse: http://www.matronics.com/browse/stratus-list > _-= Browse Digests: http://www.matronics.com/digest/stratus-list > _-= Live List Chat: http://www.matronics.com/chat > _-= Archives: http://www.matronics.com/archives > _-= Photo Share: http://www.matronics.com/photoshare > _-= List Specific: http://www.matronics.com/stratus-list > _-= Other Lists: http://www.matronics.com/emaillists > _-= Trouble Report http://www.matronics.com/trouble-report > _-= Contributions: http://www.matronics.com/contribution > _-===================================================================== > > > _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The Stratus-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: stratus-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/Stratus-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/stratus-list _-= Browse Digests: http://www.matronics.com/digest/stratus-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/stratus-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 15, 2004
This subject is interesting to me. I've had the same problem for about 5 years now. I've tried a lot of different things. The only thing that seems to affect it is changing the belt tension. I remember that it used to run very smooth when I first started using the engine after receiving it from Stratus. I also remember that the belt was very tight as compared to the way that I set it. I've never tried setting it very tight again, since I'm concerned about damaging the bearings. I believe that the secret is to run the belt tight enough, but I'm just not crazy about tightening it any more, since it tightens more once the engine heats up. I check the tension with the engine hot. By the way, my vibration is also from 2500 to 2800, just where I'd like to run the rpm on approach. I do the same and avoid this RPM band. Jim Weston Concord, Ga. -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of The Meiste's Subject: Re: Stratus-List: Belt rumble vibration still a rumble, vibration band at 2500 to 2800 rpm ++++++++++++++++++++++++++++++++++ Larry, I get the same vib's but mine is about 3,300 RPM, so I also simply try to avoid that setting if possible. As nothing I found makes it go away. Kelly _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The Stratus-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: stratus-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/Stratus-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/stratus-list _-= Browse Digests: http://www.matronics.com/digest/stratus-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/stratus-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The Stratus-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: stratus-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/Stratus-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/stratus-list _-= Browse Digests: http://www.matronics.com/digest/stratus-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/stratus-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 15, 2004
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Check the carb balance....That helped a little bit. After that and still having the rum-rum vibration I went and had the prop dynamically balanced....Wow! What a difference. Frank Stratus with Ram heads 347 hours -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Larry McFarland Subject: Stratus-List: Belt rumble vibration --> Hi guys, I've been chasing a pulse thinking the engine was missing because it vibrates a bit when it's cold and the pulse is felt until things warm up. After replacing the rotor, cap, plugs and checking coils and wires, it runs well warm, but there is still a rumble, vibration band at 2500 to 2800 rpm that seems a bit intense. Above and below that band everything sounds smooth. Am I looking at the difference between the seasonal warm of recent and the cold which is only 30-40 degrees cooler? It doesn't change when running off the A-distributor ignition or B-flywheel ignition, so perhaps it's the belt or my mixture. Still a 60-70 degree difference in EGTs, right being higher. Belt is snug to spec and the prop is tracking within 1/32" each blade, but there's still more vibration than I'd like to fly with. Any ideas on this? I feel like I've missed something here. Larry McFarland - 601HDS - Stratus at 45 hours and holding. _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The Stratus-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: stratus-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/Stratus-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/stratus-list _-= Browse Digests: http://www.matronics.com/digest/stratus-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/stratus-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The Stratus-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: stratus-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/Stratus-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/stratus-list _-= Browse Digests: http://www.matronics.com/digest/stratus-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/stratus-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 15, 2004
Frank, Thanks for the feedback on dynamic balance. I've been assuming that my problem with the rumble at 2500 to 2800 was with belt tension. It used to be very smooth, but has rumbled for some time now with nothing helping. I wonder how I could have gotten out of balance when it used to be so smooth. Jim Stratus with 226 hours. -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Subject: RE: Stratus-List: Belt rumble vibration --> Check the carb balance....That helped a little bit. After that and still having the rum-rum vibration I went and had the prop dynamically balanced....Wow! What a difference. Frank Stratus with Ram heads 347 hours -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Larry McFarland Subject: Stratus-List: Belt rumble vibration --> Hi guys, I've been chasing a pulse thinking the engine was missing because it vibrates a bit when it's cold and the pulse is felt until things warm up. After replacing the rotor, cap, plugs and checking coils and wires, it runs well warm, but there is still a rumble, vibration band at 2500 to 2800 rpm that seems a bit intense. Above and below that band everything sounds smooth. Am I looking at the difference between the seasonal warm of recent and the cold which is only 30-40 degrees cooler? It doesn't change when running off the A-distributor ignition or B-flywheel ignition, so perhaps it's the belt or my mixture. Still a 60-70 degree difference in EGTs, right being higher. Belt is snug to spec and the prop is tracking within 1/32" each blade, but there's still more vibration than I'd like to fly with. Any ideas on this? I feel like I've missed something here. Larry McFarland - 601HDS - Stratus at 45 hours and holding. _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-==================================================================== = _-= - The Stratus-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: stratus-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/Stratus-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/stratus-list _-= Browse Digests: http://www.matronics.com/digest/stratus-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/stratus-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The Stratus-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: stratus-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/Stratus-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/stratus-list _-= Browse Digests: http://www.matronics.com/digest/stratus-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/stratus-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The Stratus-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: stratus-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/Stratus-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/stratus-list _-= Browse Digests: http://www.matronics.com/digest/stratus-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/stratus-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 15, 2004
I never came up with an acceptable reason in my own mind either. Just because, I changed the belt and replaced the prop bearings at 300 hours as well (they are cheap enough and by the time you got the belt off its only another 1.5 hours to have the bearings changed out)...Put it all back together...Yup rum-rum was still there and it varied with belt tension. Like you I realised that 1/8th deflection at 20 lbs is VERY tight...Didn't like it so I put up with the rum-rum. Checked the blade angles...all good and went to the dynamic balancer. The flight home was the smoothest ever (also got the Wife a test flight in the RV 7A at Van's factory as it was on the way.. Yes she did approve....:). The vibration was not that bad, the trouble was I was still gun shy of the motor dropping a valve guide even though I know in my head its been fixed for good. So my head would play tricks...Oh no...its just got worse...It always got worse over big towns,water or mountains....Hmmmm No no more vibes (well very small) and I fly more at ease. Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Weston, Jim Subject: RE: Stratus-List: Belt rumble vibration Frank, Thanks for the feedback on dynamic balance. I've been assuming that my problem with the rumble at 2500 to 2800 was with belt tension. It used to be very smooth, but has rumbled for some time now with nothing helping. I wonder how I could have gotten out of balance when it used to be so smooth. Jim Stratus with 226 hours. -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Subject: RE: Stratus-List: Belt rumble vibration --> Check the carb balance....That helped a little bit. After that and still having the rum-rum vibration I went and had the prop dynamically balanced....Wow! What a difference. Frank Stratus with Ram heads 347 hours -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Larry McFarland Subject: Stratus-List: Belt rumble vibration --> Hi guys, I've been chasing a pulse thinking the engine was missing because it vibrates a bit when it's cold and the pulse is felt until things warm up. After replacing the rotor, cap, plugs and checking coils and wires, it runs well warm, but there is still a rumble, vibration band at 2500 to 2800 rpm that seems a bit intense. Above and below that band everything sounds smooth. Am I looking at the difference between the seasonal warm of recent and the cold which is only 30-40 degrees cooler? It doesn't change when running off the A-distributor ignition or B-flywheel ignition, so perhaps it's the belt or my mixture. Still a 60-70 degree difference in EGTs, right being higher. Belt is snug to spec and the prop is tracking within 1/32" each blade, but there's still more vibration than I'd like to fly with. Any ideas on this? I feel like I've missed something here. Larry McFarland - 601HDS - Stratus at 45 hours and holding. _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-==================================================================== = _-= - The Stratus-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: stratus-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/Stratus-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/stratus-list _-= Browse Digests: http://www.matronics.com/digest/stratus-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/stratus-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-==================================================================== = _-= - The Stratus-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: stratus-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/Stratus-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/stratus-list _-= Browse Digests: http://www.matronics.com/digest/stratus-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/stratus-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The Stratus-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: stratus-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/Stratus-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/stratus-list _-= Browse Digests: http://www.matronics.com/digest/stratus-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/stratus-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The Stratus-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: stratus-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/Stratus-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/stratus-list _-= Browse Digests: http://www.matronics.com/digest/stratus-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/stratus-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 15, 2004
Thanks Frank. I've had the same head problem (the one on my shoulders) since having the valve guide problem. I've not had anymore problems, since replacing the heads. But, psychologically it's still there, particularly over water. Jim -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Subject: RE: Stratus-List: Belt rumble vibration --> I never came up with an acceptable reason in my own mind either. Just because, I changed the belt and replaced the prop bearings at 300 hours as well (they are cheap enough and by the time you got the belt off its only another 1.5 hours to have the bearings changed out)...Put it all back together...Yup rum-rum was still there and it varied with belt tension. Like you I realised that 1/8th deflection at 20 lbs is VERY tight...Didn't like it so I put up with the rum-rum. Checked the blade angles...all good and went to the dynamic balancer. The flight home was the smoothest ever (also got the Wife a test flight in the RV 7A at Van's factory as it was on the way.. Yes she did approve....:). The vibration was not that bad, the trouble was I was still gun shy of the motor dropping a valve guide even though I know in my head its been fixed for good. So my head would play tricks...Oh no...its just got worse...It always got worse over big towns,water or mountains....Hmmmm No no more vibes (well very small) and I fly more at ease. Frank _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The Stratus-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: stratus-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/Stratus-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/stratus-list _-= Browse Digests: http://www.matronics.com/digest/stratus-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/stratus-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________ DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; b=Jjqd9qC6RCX+jejNI+IqpZTVrxUEPUATwrHqykRecoMW3uwY1Oy+yXjcXXs1ZU5Tz5PpX7kXpXEwGI+HHqVJ90fKhOPGAGICNXaGPSjSUQda2p0VvhkqBuloH+AAGR5BcTnFxG++XtcT8dQYqJTrQdA0/MyGSgQ1jLntKgkTNcw;
Date: Nov 26, 2004
Subject: Subaru ICM failure? and ignition performance
Hello. I just joined this list after browsing the very useful archives. I noticed that several people had failures with the Subaru Nippodenso ignition control module. Was the module used with the Subaru Nippodenso K31 coil (the stock coil)? Or with something else? My aircraft flew about 80 hours this year and during all that time, we were dissatisfied with engine performance. I tried replacing cyl. heads, tuning carb, reajusting lifters, tuning exhaust, I even dismantled the engine and had it checked at the machine shop. Today, I decided to try the stock Subaru ignition system in lieu of the ND pickup/TP45/IC107 combination. With the GM HEI system, I obtained 4300 rpm static on the ground (plane attached). Well, with the Subaru ignition, I got 5050 rpm (you read right 700+ additional static rpms)!!! This is not the same engine at all!! I did not check timing or temperatures or anything as I was too excited to think. It just seems that my performance problem may be a thing of the past. Michel ===== ---------------------------- Michel Therrien CH601-HD, C-GZGQ http://mthobby.pcperfect.com/ch601 http://www.zenithair.com/bldrlist/profiles/mthobby http://pages.infinit.net/mthobby ________________________________________________________________________________
Subject: Re: Subaru ICM failure? and ignition performance
Date: Nov 27, 2004
> I noticed that several people had failures with the > Subaru Nippodenso ignition control module. Was the > module used with the Subaru Nippodenso K31 coil (the > stock coil)? Or with something else? ++++++++++++++++++++++++++++++++++++++ Michel, I fly the Stratus engine in my 601 and lost my ign in flight at 60 hours on the Hobbs. My coil (IC107) failed causing my ICM inside the ND distributor to fry it's self. Kelly Meiste ________________________________________________________________________________
Date: Nov 27, 2004
> I noticed that several people had failures with the > Subaru Nippodenso ignition control module. Was the > module used with the Subaru Nippodenso K31 coil (the > stock coil)? Or with something else? Michel, That's great that you're finally getting it running right. As far as the coils, that's something i've been meaning to look into. Clare Snyder on the airsood list says that the IC107 coil needs a ballast resistor. This may explain why some of them burn up - too much current. Also, both of the ignitions on the stock Stratus work about the same. I can switch from the distributor with the stock ND, and the GM ignition with the mag pickup on the flywheel and the engine runs about the same. Slight difference in idle due to advance differences but there's nothing like 700 rpm change between the two. good luck, Gary Krysztopik Pelican PL - N522GK Stratus Subaru EA-81 Newport, RI http://members.efortress.com/flyink/index.html ________________________________________________________________________________
Date: Nov 27, 2004
Subject: Lister Comments - Please Support The Lists
Dear Listers, Wow! People have been including some very nice comments along with their Contributions lately! I've included another set of below and will send another set in a couple of days. Guys, I really appreciate your kind words and support. In the last few days, the contributions have really started to come in and its looking like support this year may slightly surpass last year's. There's still a few days left in this year's Fund Raiser, so if you've been waiting until the last minute to make your Contribution, now's the time! Make Your Contribution Today: http://www.matronics.com/contribution Thank you! Matt Dralle Email List Administrator ----------------- More of What Listers Are Saying... -------------------- Every morning 5:30 am, coffee and the "List". It's how I start my day. Robert G. The list is still my favorite aviation magazine. Roger H. Great resource, without the distraction of pop ups and ads! Douglas D. I look forward to my daily list reading almost as much as my coffee! Hal K. Great service! Aaron G. I have made some great friends, because of it! Bob D. Great resource!! Richard S. I learn something of value every time I read the messages. Stan S. Great list! Thomas E. Now that I am close to completion of my [homebuilt], I look back and wonder how I could ever have made it this far without [the Lists]. Jeff O. Outstanding site and administration. Anthony S. Great forum for our projects. Darrel M. I have become a List Addict! George M. A very helpful resource for me. Dennis K. Great for staying up on the latest. Forrest L. Valuable benefit for the users. George A. Great tool for all [builders]. Tony M. Can't tell you how much I appreciate the archives. Ken B. I really enjoy the sharing of information and the "discussions" that come up. Ross S. [The List] reminds us home builders that help is just a few clicks away. Danny W. A great resource! Christopher S. Always a pleasure to support this list! Richard W. Thanks for helping all of us build better aircraft. John P. Great list(s)for data, info and making friends. John S. [The] List has helped me much with my building process. Raimo T. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: carb jets
Date: Nov 27, 2004
For the heck of it, after reading the posts on carb jets, I flew to experiment with the enrichener. In the midrange, pulling the enrichener (choke) increased the rpm by about 150. Then in the main jet range adding the enrichener made no difference. On a cooler day I did the same and found that the midrange increased even more and the main jet range rpm increased by about 50 when enrichened. Is it likely that lowering the needle in the midrange will affect them both. Should I increase main jet size and lower the needle? Will a main jet change affect the midrange? Don Walker HDS TD ________________________________________________________________________________
Subject: Re: carb jets
Date: Nov 27, 2004
Don, What you describe is detailed to some exactitude on page 18 of the Bing Carburettors Aircraft tuning and parts manual. Picking up power with the enriching circuit (choke) suggests you're running lean if the EGTs are reduced. If you lower the needle, you will lean the engine further and risk damage to the engine. They recommend doing only one thing at a time. I'd consider just another size jet first. I'm using 170s and my needle is on 3, one notch from the richest setting. Not being satisfied with trying to estimate by EGTs, I'm going to purchase a Colortune plug from Bing Monday. Then it might be possible to see better what these changes do. Yes, a main jet change will affect the midrange. It sound like you need the manual from Bing. Larry McFarland Subject: Stratus-List: carb jets > > For the heck of it, after reading the posts on carb jets, I flew to > experiment with the enrichener. In the midrange, pulling the enrichener > (choke) increased the rpm by about 150. Then in the main jet range adding > the enrichener made no difference. > On a cooler day I did the same and found that the midrange increased even > more and the main jet range rpm increased by about 50 when enrichened. Is > it likely that lowering the needle in the midrange will affect them both. > Should I increase main jet size and lower the needle? Will a main jet > change affect the midrange? Don Walker HDS TD > ________________________________________________________________________________
Date: Nov 28, 2004
Subject: re-drive bearings
Someone mentioned last week the task of changing bearings in the Stratus reduction drive. How bad a job IS that, anyway? Do I need gear pullers and an arbor press, or is it not that complex? Danny W. Kitfox 5 ________________________________________________________________________________
Subject: Re: re-drive bearings
Date: Nov 28, 2004
> Someone mentioned last week the task of changing bearings in the Stratus > reduction drive. How bad a job IS that, anyway? Do I need gear pullers and > an > arbor press, or is it not that complex? > > Danny W. > Kitfox 5 ++++++++++++++++++++++++++++++++++++++++++++++++ Danny, Go back & search the achieves as I believe this was discussed here about a year ago. Kelly ________________________________________________________________________________
Date: Nov 29, 2004
Just normal tools.Easy job..I heated my alu gear in the oven on about 150F before I dropped the bearings in...Virtually fell into place, Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of The Meiste's Subject: Re: Stratus-List: re-drive bearings > Someone mentioned last week the task of changing bearings in the > Stratus reduction drive. How bad a job IS that, anyway? Do I need gear > pullers and an arbor press, or is it not that complex? > > Danny W. > Kitfox 5 ++++++++++++++++++++++++++++++++++++++++++++++++ Danny, Go back & search the achieves as I believe this was discussed here about a year ago. Kelly ________________________________________________________________________________
Date: Nov 29, 2004
Seems several of the IC107 coils have gone to low resistance on the primary coil...Less than 1ohm I believe. The coil would still work but as you say the $300 ND chip will fry itself. It's a hassle but the TP45 chip wired to the stock PU coil (which will still be fine) is a much more robust system....You could even continue to run the old coil but for $50 I think I would change it. Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of The Meiste's Subject: Re: Stratus-List: Subaru ICM failure? and ignition performance > I noticed that several people had failures with the > Subaru Nippodenso ignition control module. Was the > module used with the Subaru Nippodenso K31 coil (the > stock coil)? Or with something else? ++++++++++++++++++++++++++++++++++++++ Michel, I fly the Stratus engine in my 601 and lost my ign in flight at 60 hours on the Hobbs. My coil (IC107) failed causing my ICM inside the ND distributor to fry it's self. Kelly Meiste ________________________________________________________________________________
Date: Nov 29, 2004
Danny, I replaced my redrive bearings last year. It was no too bad and you do not need any special tooling. I have a text document and some photos on how I performed the replacement. If you or anyone else would like these, I will e-mail them directly to you. The zip file containing the document and photos is a bit large at about 1.7k bytes. Let me know. Regards, Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 378.0 flight hrs. - 506 landings web site -> http://homepages.together.net/~billvt/ ________________________________________________________________________________
Subject: Winter flying......
Date: Dec 15, 2004
Hi guys, My Stratus powered 601 is in its first winter season and temperatures have dropped to the low teens. I'm wondering how cold is too cold to fly. Given that the engine is kept warm, will it be able to stay at normal operating temps, or are there things needed to keep it going? I'm looking at reducing radiator exposure a bit, but not sure how much. Are there any other problems out there? Larry McFarland - 601HDS ________________________________________________________________________________
Subject: Re: Winter flying......
Date: Dec 15, 2004
Hi Larry, I do a few minor tweaks when preparing my Stratus (and me) for winter flying. 1. As you noted block off rad as required (most I've done so far is 3/4 closed). 2. Change from 20W-50 to 10W-30 Castrol GTX. 3. Change from my summer 40% coolant, to 60% coolant. 4. Make sure as many cockpit air leaks are sealed off as possible. 5. Go to F&F and stock up on toe warmers. 6. As long as your at F&F purchase one of those round 5 gallon bucket cushions the ice fishermen use to sit on and place it in your seat (it does actually provide some warmth, thou it's a little uncomfortable to sit on). 7. Don't forget to ask Santa for a new pair of Long Johns (you have been good this year haven't you?). 8. Make sure you have a good quality pair of sunglasses as the newly fallen snow, & bright sun combined with a polished aluminum plane will give a whole new meaning to "blinded by the light". 9. Watch your tires air pressures as they will drop quickly compared to the summer. 10. Have fun! I really love winter flying as the air is generally glassy smooth. And as much as you may like try to resist kissing your beautiful bird in the winter as your lips (or tongue) will surely stick to the aluminum, and you don't want Lee to see that now do you! Kelly (Hanger frame still standing after the 60 MPH winds this week) ----- Original Message ----- From: "Larry McFarland" <larrymc(at)qconline.com> Subject: Stratus-List: Winter flying...... > > > Hi guys, > > My Stratus powered 601 is in its first winter season and temperatures have > dropped to the low teens. I'm wondering how cold is too cold to fly. > Given that the engine is kept warm, will it be able to stay at normal > operating temps, or are there things needed to keep it going? I'm looking > at reducing radiator exposure a bit, but not sure how much. Are there any > other problems out there? > > > Larry McFarland - 601HDS ________________________________________________________________________________ DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; b=S58+ANUbOnLpYi2w8LX2+fY/yit2VVxEJQVxQsta1n8qWVsFT9CrNk0UluyrH2PPXVJMePSdwbnLktFbgpGwq6hj7/Dtor2UXImedEUWo2Zd4O+Qz77xJFZ+gUM8ICOZ7QndBNSYxGk01WnCMUYR36tqx/znA1hCdIlHAPm7YQk;
Date: Dec 16, 2004
Larry, To what the others had said, I'd only add --> What's the coldest weather in which you'd drive a Subaru equipped with an EA-81 engine? That's the coldest you should fly in. As long as you're not in icing conditions, the plane shouldn't care, may even fly better in the cold. Phil Raker N556P HDS/Stratus ~85% completed Hi guys, My Stratus powered 601 is in its first winter season and temperatures have dropped to the low teens. I'm wondering how cold is too cold to fly. Given that the engine is kept warm, will it be able to stay at normal operating temps, or are there things needed to keep it going? I'm looking at reducing radiator exposure a bit, but not sure how much. Are there any other problems out there? Larry McFarland - 601HDS __________________________________ http://my.yahoo.com ________________________________________________________________________________
Date: Dec 16, 2004
It will but remember if there is any water in the tanks it will be ice...As long as you have been diligent in draining the tanks when it was above freezing it should be just fine. I'd be more worried about keeping myself warm....:) Frank Zodiac, Stratus 350 hours -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Phil Raker Subject: Stratus-List: Winter flying...... Larry, To what the others had said, I'd only add --> What's the coldest weather in which you'd drive a Subaru equipped with an EA-81 engine? That's the coldest you should fly in. As long as you're not in icing conditions, the plane shouldn't care, may even fly better in the cold. Phil Raker N556P HDS/Stratus ~85% completed --> Hi guys, My Stratus powered 601 is in its first winter season and temperatures have dropped to the low teens. I'm wondering how cold is too cold to fly. Given that the engine is kept warm, will it be able to stay at normal operating temps, or are there things needed to keep it going? I'm looking at reducing radiator exposure a bit, but not sure how much. Are there any other problems out there? Larry McFarland - 601HDS __________________________________ http://my.yahoo.com ________________________________________________________________________________
Date: Dec 16, 2004
> It will but remember if there is any water in the tanks it will be > ice...As long as you have been diligent in draining the tanks when it > was above freezing it should be just fine. ++++++++++++++++++++++++++++++++++++++++++ Thanks for jarring my brain on this Frank. Has anyone ever noticed water come out of their header tank (that's all I have) when you drain the gasolator? I have the standard ZAC 16 gal header tank & ZAC gasolator located low on the firewall and have yet to see any water in my inspection jar. Like Larry I'm in northern IL. not Arizona??? Kelly 601 HD ________________________________________________________________________________
Subject: Jetting Stratus Bing Carbureters
Date: Dec 16, 2004
Hi guys, (fellow Stratus EA-81 users) I think it's time to put the experience of re-jetting Stratus-Bing carbs into the archives. Perhaps it'll reduce your time and expense of "discovery". The "Bing Carburettors Aircraft Tuning & Parts Manual" is needed to fully visualize this information. Bing can be reached at 1-800-309-2464 weekdays and it's only $8.00. (Yes, the spelling is correct) The manual is a good parts-identifier and primer for getting correct mixture, but you have to do the guesswork till it's right, so for the Stratus, that's what this piece is about. My Stratus engine with Bing carburetor's initially came with No.40 idle mixture-jets adjusted 2-turns from closed, 164 main jets and 2.72 mid-range jets. (Note; all jets have the number stamped on each one.) The mid-range jet-needles came with 2 scribed rings on their diameters for identification and on the jet-needle 4 snap-ring notches, the circlips were set at the #2 position or second notch from the top. Ram Performance installed new S.S. valves, springs and guides. The rework also provides more airflow, so increased jet sizes are recommended by Ron at Ram to get a target cruise EGT of 1350-degrees. Mykal at Stratus says 1400 to 1500 degrees is fine with an upper limit short duration 1600-degrees. With high EGTs, I changed to 170 main jets. EGTs came down, but were too high for takeoff rpms. 180 main jets were tried but the engine ran rough with these. With 174 mains, the plane flew well. EGTs reached 1400 degrees at 4200 rpm. (Still too high for higher rpms) The mid-range jet-needle was set higher to enrich fuel mixture by moving the circlip from #2 notch down to the #3 notch. This made a serious difference and I could cruise at 4600 rpm all day at 1390 degrees EGT. At full 5100, the EGT would still slowly climb above 1450-degrees, which I felt might be high for continuous running. Without initially knowing, I changed out the air filters to K&N types because of concern for the foam. This reduced air resistance into the carburetors, provided more air, leaner mixture and increased EGTs. Cool weather also seemed to increase EGTs. On a Bing phone inquiry/discussion, the technical rep was surprised I had not yet increased mid-range jetting and suggested I replace 2.72 with 2.76 jets and lower the needles one notch to see if the equivalent of a one-jet change would work. 174 mains were also changed to 176 jets. A 3500-rpm run-up with brakes brought EGTs to 1400-degrees rather quickly. The needle jet was then raised by re-setting the circlip down to #3 notch and the EGTs climbed to 1290 at 3500-rpm, but no higher. Quite a difference! Was anxious to fly these jet and needle settings to see what happens at higher rpms. Today, at 40-degrees, winds at 10, I taxied to 31 and holding short, watched pre-heated oil reach 240 until clearance was given for takeoff. Climb out was impressive, and EGTs were slow to climb to 1450 at 5100, so I reduced rpms to 4400 and turned south to the practice area and EGTs came down to 1435. Rpms were lowered to a comfortable 4300 and EGTs stabilized at 1420. The largest change from increasing jet sizes was the slow mid range climb through 1400 on takeoff. I flew an hour and then returned to land on 27. All other temps were normal throughout the flight. Back at the hangar, the K&N type air filters were removed and replaced with the original foam types to see if they would make a difference. Went home for lunch. Afterward, I refueled the plane and taxied out in 16 mph winds to lift off very quickly from 31. The EGT rise was slower and never got past 1420 on takeoff. After leveling the plane, I headed south for 15 minutes. Rpms were set back to 4350 and EGTs settled in at 1375. There's still about a 40-degree difference from the right to left sides. I tried raising the rpms to 5000 and the EGTs would level out at 1425. The old foam filters had a much greater impact on mixture than I'd have thought. EGTs are satisfactory to this point as I can cruise at 115 to 120 without getting much beyond a 1400-degree limit. My Engine timing is set to 30-degrees at 4500 rpm. I haven't seen evidence that re-timing 1 or 2 degrees either way helped it run better. Plugs soot up at idle and plug color doesn't offer exact information, so I purchased a high-compression Colortune plug from Bing. This will permit actually seeing the mixture and rpms from idle to 4000, but no further. Haven't used it yet as focus has been on the high end and getting Horsepower at lower EGTs. I expect to install an O2 sensor to confirm running mixtures when the jet settings have been flown. EGT sensors are installed 3-1/2" from the exhaust flange in the top of the first straight after the bend. They are a probe-type secured by a hose-clamp that also grips a belting heat wrap on the exhaust pipes to protect the cowling. All engine data is displayed on a Grand Rapids Technologies E I S. This thing is indispensable for showing all real-time engine parameters and immediately displaying an alarm-light while pointing out any out-of-limit condition. It's an easy set-up too! Earlier this season, the radiator was moved back as a P51, to where it was and it works very well. Please forgive the lengthy diatribe, but the archives needed specific jet and needle setting information for this engine. That's as much as I know at this time. If you've been there done that, have a comment or objection, please do, so we can all compare notes and learn from the collective experience. Thanks guys, Larry McFarland - 601HDS with Stratus Subaru and Ram Performance heads at www.macsmachine.com ________________________________________________________________________________
Date: Dec 16, 2004
Subject: Re: Jetting Stratus Bing Carbureters
Date: Dec 16, 2004
> Larry, > Thanks for taking the time to write & post your findings on the Bing > Jetting, very interesting! yes, thanks very much Larry - much appreciated. gary ________________________________________________________________________________
Date: Dec 17, 2004
Your experience pretty much mirros mine Larry, the only difference is I ended up with a cruise EGT of 1450. The mixture were confirmed correct by the exhaust gas analyser. I can't remember what jets I ended up with finally. Thanks Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Larry McFarland Subject: Stratus-List: Jetting Stratus Bing Carbureters --> Hi guys, (fellow Stratus EA-81 users) I think it's time to put the experience of re-jetting Stratus-Bing carbs into the archives. Perhaps it'll reduce your time and expense of "discovery". The "Bing Carburettors Aircraft Tuning & Parts Manual" is needed to fully visualize this information. Bing can be reached at 1-800-309-2464 weekdays and it's only $8.00. (Yes, the spelling is correct) The manual is a good parts-identifier and primer for getting correct mixture, but you have to do the guesswork till it's right, so for the Stratus, that's what this piece is about. My Stratus engine with Bing carburetor's initially came with No.40 idle mixture-jets adjusted 2-turns from closed, 164 main jets and 2.72 mid-range jets. (Note; all jets have the number stamped on each one.) The mid-range jet-needles came with 2 scribed rings on their diameters for identification and on the jet-needle 4 snap-ring notches, the circlips were set at the #2 position or second notch from the top. Ram Performance installed new S.S. valves, springs and guides. The rework also provides more airflow, so increased jet sizes are recommended by Ron at Ram to get a target cruise EGT of 1350-degrees. Mykal at Stratus says 1400 to 1500 degrees is fine with an upper limit short duration 1600-degrees. With high EGTs, I changed to 170 main jets. EGTs came down, but were too high for takeoff rpms. 180 main jets were tried but the engine ran rough with these. With 174 mains, the plane flew well. EGTs reached 1400 degrees at 4200 rpm. (Still too high for higher rpms) The mid-range jet-needle was set higher to enrich fuel mixture by moving the circlip from #2 notch down to the #3 notch. This made a serious difference and I could cruise at 4600 rpm all day at 1390 degrees EGT. At full 5100, the EGT would still slowly climb above 1450-degrees, which I felt might be high for continuous running. Without initially knowing, I changed out the air filters to K&N types because of concern for the foam. This reduced air resistance into the carburetors, provided more air, leaner mixture and increased EGTs. Cool weather also seemed to increase EGTs. On a Bing phone inquiry/discussion, the technical rep was surprised I had not yet increased mid-range jetting and suggested I replace 2.72 with 2.76 jets and lower the needles one notch to see if the equivalent of a one-jet change would work. 174 mains were also changed to 176 jets. A 3500-rpm run-up with brakes brought EGTs to 1400-degrees rather quickly. The needle jet was then raised by re-setting the circlip down to #3 notch and the EGTs climbed to 1290 at 3500-rpm, but no higher. Quite a difference! Was anxious to fly these jet and needle settings to see what happens at higher rpms. Today, at 40-degrees, winds at 10, I taxied to 31 and holding short, watched pre-heated oil reach 240 until clearance was given for takeoff. Climb out was impressive, and EGTs were slow to climb to 1450 at 5100, so I reduced rpms to 4400 and turned south to the practice area and EGTs came down to 1435. Rpms were lowered to a comfortable 4300 and EGTs stabilized at 1420. The largest change from increasing jet sizes was the slow mid range climb through 1400 on takeoff. I flew an hour and then returned to land on 27. All other temps were normal throughout the flight. Back at the hangar, the K&N type air filters were removed and replaced with the original foam types to see if they would make a difference. Went home for lunch. Afterward, I refueled the plane and taxied out in 16 mph winds to lift off very quickly from 31. The EGT rise was slower and never got past 1420 on takeoff. After leveling the plane, I headed south for 15 minutes. Rpms were set back to 4350 and EGTs settled in at 1375. There's still about a 40-degree difference from the right to left sides. I tried raising the rpms to 5000 and the EGTs would level out at 1425. The old foam filters had a much greater impact on mixture than I'd have thought. EGTs are satisfactory to this point as I can cruise at 115 to 120 without getting much beyond a 1400-degree limit. My Engine timing is set to 30-degrees at 4500 rpm. I haven't seen evidence that re-timing 1 or 2 degrees either way helped it run better. Plugs soot up at idle and plug color doesn't offer exact information, so I purchased a high-compression Colortune plug from Bing. This will permit actually seeing the mixture and rpms from idle to 4000, but no further. Haven't used it yet as focus has been on the high end and getting Horsepower at lower EGTs. I expect to install an O2 sensor to confirm running mixtures when the jet settings have been flown. EGT sensors are installed 3-1/2" from the exhaust flange in the top of the first straight after the bend. They are a probe-type secured by a hose-clamp that also grips a belting heat wrap on the exhaust pipes to protect the cowling. All engine data is displayed on a Grand Rapids Technologies E I S. This thing is indispensable for showing all real-time engine parameters and immediately displaying an alarm-light while pointing out any out-of-limit condition. It's an easy set-up too! Earlier this season, the radiator was moved back as a P51, to where it was and it works very well. Please forgive the lengthy diatribe, but the archives needed specific jet and needle setting information for this engine. That's as much as I know at this time. If you've been there done that, have a comment or objection, please do, so we can all compare notes and learn from the collective experience. Thanks guys, Larry McFarland - 601HDS with Stratus Subaru and Ram Performance heads at www.macsmachine.com _ ________________________________________________________________________________
Date: Dec 17, 2004
So am I to take it that everyone has been finding that the jets are too lean at cruise, as the engine comes from Stratus? I don't have EGT gauges. This might explain why I've never been able to run at high RPM for long before the temps (engine & oil) start to climb. I changed my mid-range needle to the 3rd ring, some time back, and this helped some. Jim Weston 601HDS, Stratus Concord, Ga. -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Subject: RE: Stratus-List: Jetting Stratus Bing Carbureters --> Your experience pretty much mirros mine Larry, the only difference is I ended up with a cruise EGT of 1450. The mixture were confirmed correct by the exhaust gas analyser. I can't remember what jets I ended up with finally. Thanks Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Larry McFarland Subject: Stratus-List: Jetting Stratus Bing Carbureters --> Hi guys, (fellow Stratus EA-81 users) I think it's time to put the experience of re-jetting Stratus-Bing carbs into the archives. Perhaps it'll reduce your time and expense of "discovery". The "Bing Carburettors Aircraft Tuning & Parts Manual" is needed to fully visualize this information. Bing can be reached at 1-800-309-2464 weekdays and it's only $8.00. (Yes, the spelling is correct) The manual is a good parts-identifier and primer for getting correct mixture, but you have to do the guesswork till it's right, so for the Stratus, that's what this piece is about. My Stratus engine with Bing carburetor's initially came with No.40 idle mixture-jets adjusted 2-turns from closed, 164 main jets and 2.72 mid-range jets. (Note; all jets have the number stamped on each one.) The mid-range jet-needles came with 2 scribed rings on their diameters for identification and on the jet-needle 4 snap-ring notches, the circlips were set at the #2 position or second notch from the top. Ram Performance installed new S.S. valves, springs and guides. The rework also provides more airflow, so increased jet sizes are recommended by Ron at Ram to get a target cruise EGT of 1350-degrees. Mykal at Stratus says 1400 to 1500 degrees is fine with an upper limit short duration 1600-degrees. With high EGTs, I changed to 170 main jets. EGTs came down, but were too high for takeoff rpms. 180 main jets were tried but the engine ran rough with these. With 174 mains, the plane flew well. EGTs reached 1400 degrees at 4200 rpm. (Still too high for higher rpms) The mid-range jet-needle was set higher to enrich fuel mixture by moving the circlip from #2 notch down to the #3 notch. This made a serious difference and I could cruise at 4600 rpm all day at 1390 degrees EGT. At full 5100, the EGT would still slowly climb above 1450-degrees, which I felt might be high for continuous running. Without initially knowing, I changed out the air filters to K&N types because of concern for the foam. This reduced air resistance into the carburetors, provided more air, leaner mixture and increased EGTs. Cool weather also seemed to increase EGTs. On a Bing phone inquiry/discussion, the technical rep was surprised I had not yet increased mid-range jetting and suggested I replace 2.72 with 2.76 jets and lower the needles one notch to see if the equivalent of a one-jet change would work. 174 mains were also changed to 176 jets. A 3500-rpm run-up with brakes brought EGTs to 1400-degrees rather quickly. The needle jet was then raised by re-setting the circlip down to #3 notch and the EGTs climbed to 1290 at 3500-rpm, but no higher. Quite a difference! Was anxious to fly these jet and needle settings to see what happens at higher rpms. Today, at 40-degrees, winds at 10, I taxied to 31 and holding short, watched pre-heated oil reach 240 until clearance was given for takeoff. Climb out was impressive, and EGTs were slow to climb to 1450 at 5100, so I reduced rpms to 4400 and turned south to the practice area and EGTs came down to 1435. Rpms were lowered to a comfortable 4300 and EGTs stabilized at 1420. The largest change from increasing jet sizes was the slow mid range climb through 1400 on takeoff. I flew an hour and then returned to land on 27. All other temps were normal throughout the flight. Back at the hangar, the K&N type air filters were removed and replaced with the original foam types to see if they would make a difference. Went home for lunch. Afterward, I refueled the plane and taxied out in 16 mph winds to lift off very quickly from 31. The EGT rise was slower and never got past 1420 on takeoff. After leveling the plane, I headed south for 15 minutes. Rpms were set back to 4350 and EGTs settled in at 1375. There's still about a 40-degree difference from the right to left sides. I tried raising the rpms to 5000 and the EGTs would level out at 1425. The old foam filters had a much greater impact on mixture than I'd have thought. EGTs are satisfactory to this point as I can cruise at 115 to 120 without getting much beyond a 1400-degree limit. My Engine timing is set to 30-degrees at 4500 rpm. I haven't seen evidence that re-timing 1 or 2 degrees either way helped it run better. Plugs soot up at idle and plug color doesn't offer exact information, so I purchased a high-compression Colortune plug from Bing. This will permit actually seeing the mixture and rpms from idle to 4000, but no further. Haven't used it yet as focus has been on the high end and getting Horsepower at lower EGTs. I expect to install an O2 sensor to confirm running mixtures when the jet settings have been flown. EGT sensors are installed 3-1/2" from the exhaust flange in the top of the first straight after the bend. They are a probe-type secured by a hose-clamp that also grips a belting heat wrap on the exhaust pipes to protect the cowling. All engine data is displayed on a Grand Rapids Technologies E I S. This thing is indispensable for showing all real-time engine parameters and immediately displaying an alarm-light while pointing out any out-of-limit condition. It's an easy set-up too! Earlier this season, the radiator was moved back as a P51, to where it was and it works very well. Please forgive the lengthy diatribe, but the archives needed specific jet and needle setting information for this engine. That's as much as I know at this time. If you've been there done that, have a comment or objection, please do, so we can all compare notes and learn from the collective experience. Thanks guys, Larry McFarland - 601HDS with Stratus Subaru and Ram Performance heads at www.macsmachine.com _ ________________________________________________________________________________
Date: Dec 17, 2004
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
That's hard to say Jim. I can say that when my heads came back from Ram the engine was running WAY lean...I can't say for sure this was the case as stock from Stratus. Being as however Mykal's engine shop said repeatedly there were signs of overheating when my guides kept falling out (cus I forgot to do a rain dance before I got in the plane...or was that due to the fact I flew when there was a "Y" in the month?), it is a fair suspicion that these motors were not jetted correctly from the get go. The EGT guages really are of very limited benefit...I would save the time to do a proper tie down test and test the jetting per the Bing manual, or by hooking up an exhaust gas mixture gauge. Both my main and needle jets had to be upsized considerably. Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Weston, Jim Subject: RE: Stratus-List: Jetting Stratus Bing Carbureters So am I to take it that everyone has been finding that the jets are too lean at cruise, as the engine comes from Stratus? I don't have EGT gauges. This might explain why I've never been able to run at high RPM for long before the temps (engine & oil) start to climb. I changed my mid-range needle to the 3rd ring, some time back, and this helped some. Jim Weston 601HDS, Stratus Concord, Ga. -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Subject: RE: Stratus-List: Jetting Stratus Bing Carbureters --> Your experience pretty much mirros mine Larry, the only difference is I ended up with a cruise EGT of 1450. The mixture were confirmed correct by the exhaust gas analyser. I can't remember what jets I ended up with finally. Thanks Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Larry McFarland Subject: Stratus-List: Jetting Stratus Bing Carbureters --> Hi guys, (fellow Stratus EA-81 users) I think it's time to put the experience of re-jetting Stratus-Bing carbs into the archives. Perhaps it'll reduce your time and expense of "discovery". The "Bing Carburettors Aircraft Tuning & Parts Manual" is needed to fully visualize this information. Bing can be reached at 1-800-309-2464 weekdays and it's only $8.00. (Yes, the spelling is correct) The manual is a good parts-identifier and primer for getting correct mixture, but you have to do the guesswork till it's right, so for the Stratus, that's what this piece is about. My Stratus engine with Bing carburetor's initially came with No.40 idle mixture-jets adjusted 2-turns from closed, 164 main jets and 2.72 mid-range jets. (Note; all jets have the number stamped on each one.) The mid-range jet-needles came with 2 scribed rings on their diameters for identification and on the jet-needle 4 snap-ring notches, the circlips were set at the #2 position or second notch from the top. Ram Performance installed new S.S. valves, springs and guides. The rework also provides more airflow, so increased jet sizes are recommended by Ron at Ram to get a target cruise EGT of 1350-degrees. Mykal at Stratus says 1400 to 1500 degrees is fine with an upper limit short duration 1600-degrees. With high EGTs, I changed to 170 main jets. EGTs came down, but were too high for takeoff rpms. 180 main jets were tried but the engine ran rough with these. With 174 mains, the plane flew well. EGTs reached 1400 degrees at 4200 rpm. (Still too high for higher rpms) The mid-range jet-needle was set higher to enrich fuel mixture by moving the circlip from #2 notch down to the #3 notch. This made a serious difference and I could cruise at 4600 rpm all day at 1390 degrees EGT. At full 5100, the EGT would still slowly climb above 1450-degrees, which I felt might be high for continuous running. Without initially knowing, I changed out the air filters to K&N types because of concern for the foam. This reduced air resistance into the carburetors, provided more air, leaner mixture and increased EGTs. Cool weather also seemed to increase EGTs. On a Bing phone inquiry/discussion, the technical rep was surprised I had not yet increased mid-range jetting and suggested I replace 2.72 with 2.76 jets and lower the needles one notch to see if the equivalent of a one-jet change would work. 174 mains were also changed to 176 jets. A 3500-rpm run-up with brakes brought EGTs to 1400-degrees rather quickly. The needle jet was then raised by re-setting the circlip down to #3 notch and the EGTs climbed to 1290 at 3500-rpm, but no higher. Quite a difference! Was anxious to fly these jet and needle settings to see what happens at higher rpms. Today, at 40-degrees, winds at 10, I taxied to 31 and holding short, watched pre-heated oil reach 240 until clearance was given for takeoff. Climb out was impressive, and EGTs were slow to climb to 1450 at 5100, so I reduced rpms to 4400 and turned south to the practice area and EGTs came down to 1435. Rpms were lowered to a comfortable 4300 and EGTs stabilized at 1420. The largest change from increasing jet sizes was the slow mid range climb through 1400 on takeoff. I flew an hour and then returned to land on 27. All other temps were normal throughout the flight. Back at the hangar, the K&N type air filters were removed and replaced with the original foam types to see if they would make a difference. Went home for lunch. Afterward, I refueled the plane and taxied out in 16 mph winds to lift off very quickly from 31. The EGT rise was slower and never got past 1420 on takeoff. After leveling the plane, I headed south for 15 minutes. Rpms were set back to 4350 and EGTs settled in at 1375. There's still about a 40-degree difference from the right to left sides. I tried raising the rpms to 5000 and the EGTs would level out at 1425. The old foam filters had a much greater impact on mixture than I'd have thought. EGTs are satisfactory to this point as I can cruise at 115 to 120 without getting much beyond a 1400-degree limit. My Engine timing is set to 30-degrees at 4500 rpm. I haven't seen evidence that re-timing 1 or 2 degrees either way helped it run better. Plugs soot up at idle and plug color doesn't offer exact information, so I purchased a high-compression Colortune plug from Bing. This will permit actually seeing the mixture and rpms from idle to 4000, but no further. Haven't used it yet as focus has been on the high end and getting Horsepower at lower EGTs. I expect to install an O2 sensor to confirm running mixtures when the jet settings have been flown. EGT sensors are installed 3-1/2" from the exhaust flange in the top of the first straight after the bend. They are a probe-type secured by a hose-clamp that also grips a belting heat wrap on the exhaust pipes to protect the cowling. All engine data is displayed on a Grand Rapids Technologies E I S. This thing is indispensable for showing all real-time engine parameters and immediately displaying an alarm-light while pointing out any out-of-limit condition. It's an easy set-up too! Earlier this season, the radiator was moved back as a P51, to where it was and it works very well. Please forgive the lengthy diatribe, but the archives needed specific jet and needle setting information for this engine. That's as much as I know at this time. If you've been there done that, have a comment or objection, please do, so we can all compare notes and learn from the collective experience. Thanks guys, Larry McFarland - 601HDS with Stratus Subaru and Ram Performance heads at www.macsmachine.com _ ________________________________________________________________________________
Date: Dec 17, 2004
> So am I to take it that everyone has been finding that the jets are too > lean at cruise, as the engine comes from Stratus? I don't have EGT > gauges. This might explain why I've never been able to run at high RPM > for long before the temps (engine & oil) start to climb. I changed my > mid-range needle to the 3rd ring, some time back, and this helped some. Nope - I don't have EGT's and never messed with my engine at all. I reploaced foam filters with K&N and have RAM heads so I guess I'd better check. The engine has always started and run perfectly so I was never concerned. Plugs looked fine when I checked, and water, engine and oil temps are fine even at extended WOT. I bought EGT's when I bought the engine but never installed them. I guess it's time, now I want to know. Gary ________________________________________________________________________________
Date: Dec 17, 2004
> So am I to take it that everyone has been finding that the jets are too > lean at cruise, as the engine comes from Stratus? I don't have EGT > gauges. This might explain why I've never been able to run at high RPM > for long before the temps (engine & oil) start to climb. I changed my > mid-range needle to the 3rd ring, some time back, and this helped some. > > Jim Weston ++++++++++++++++++++++++++++++++++++++++++++++ Jim, My Stratus seems to be the same as yours. I'm not running EGT's either and have always had trouble with high water & oil temps. I've have also gone to the 3rd ring groove in my needle also with a slight improvement. I seem to be running fine at the moment but will probably try larger jets soon. Kelly Meiste (stock Stratus heads) ________________________________________________________________________________
Date: Dec 17, 2004
Subject: Re: Stratus-List: Jetting Stratus Bing Carbureters > > Nope - I don't have EGT's and never messed with my engine at all. I > reploaced foam filters with K&N and have RAM heads so I guess I'd better > check. The engine has always started and run perfectly so I was never > concerned. Plugs looked fine when I checked, and water, engine and oil > temps are fine even at extended WOT. I bought EGT's when I bought the > engine but never installed them. I guess it's time, now I want to know. > > Gary Pleased you're looking into this. It'll be interesting to find out how your engine was set up and what jets you find in your Bings. Very curious to hear. Also, at the very least, hook up those EGTs and get some readings. It'd be really good to be able to establish a baseline of temps for comparison. Regards, Larry McFarland ________________________________________________________________________________
Date: Dec 18, 2004
Jim, You might check your jet size compared to this report. Mine came from Stratus with smaller main jets...162 rather than the 164 reported here. Mine ran smooth as a sewing machine until this week when I changed the jetting. I put in a 165 main, which seems to do well, and enriched the mid-range two notches. Now I am going to do what you did...bring the mid-range back up to the third notch. Also remember that some here are getting more air flow with the Ram heads. don walker----- Original Message ----- From: Weston, Jim<mailto:Jim.Weston(at)delta.com> To: stratus-list(at)matronics.com Sent: Friday, December 17, 2004 12:55 PM Subject: RE: Stratus-List: Jetting Stratus Bing Carbureters So am I to take it that everyone has been finding that the jets are too lean at cruise, as the engine comes from Stratus? I don't have EGT gauges. This might explain why I've never been able to run at high RPM for long before the temps (engine & oil) start to climb. I changed my mid-range needle to the 3rd ring, some time back, and this helped some. Jim Weston 601HDS, Stratus Concord, Ga. -----Original Message----- From: owner-stratus-list-server(at)matronics.com<mailto:owner-stratus-list-server(at)matronics.com> [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) To: stratus-list(at)matronics.com Subject: RE: Stratus-List: Jetting Stratus Bing Carbureters --> > Your experience pretty much mirros mine Larry, the only difference is I ended up with a cruise EGT of 1450. The mixture were confirmed correct by the exhaust gas analyser. I can't remember what jets I ended up with finally. Thanks Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com<mailto:owner-stratus-list-server(at)matronics.com> [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Larry McFarland To: stratus-list(at)matronics.com Subject: Stratus-List: Jetting Stratus Bing Carbureters --> > Hi guys, (fellow Stratus EA-81 users) I think it's time to put the experience of re-jetting Stratus-Bing carbs into the archives. Perhaps it'll reduce your time and expense of "discovery". The "Bing Carburettors Aircraft Tuning & Parts Manual" is needed to fully visualize this information. Bing can be reached at 1-800-309-2464 weekdays and it's only $8.00. (Yes, the spelling is correct) The manual is a good parts-identifier and primer for getting correct mixture, but you have to do the guesswork till it's right, so for the Stratus, that's what this piece is about. My Stratus engine with Bing carburetor's initially came with No.40 idle mixture-jets adjusted 2-turns from closed, 164 main jets and 2.72 mid-range jets. (Note; all jets have the number stamped on each one.) The mid-range jet-needles came with 2 scribed rings on their diameters for identification and on the jet-needle 4 snap-ring notches, the circlips were set at the #2 position or second notch from the top. Ram Performance installed new S.S. valves, springs and guides. The rework also provides more airflow, so increased jet sizes are recommended by Ron at Ram to get a target cruise EGT of 1350-degrees. Mykal at Stratus says 1400 to 1500 degrees is fine with an upper limit short duration 1600-degrees. With high EGTs, I changed to 170 main jets. EGTs came down, but were too high for takeoff rpms. 180 main jets were tried but the engine ran rough with these. With 174 mains, the plane flew well. EGTs reached 1400 degrees at 4200 rpm. (Still too high for higher rpms) The mid-range jet-needle was set higher to enrich fuel mixture by moving the circlip from #2 notch down to the #3 notch. This made a serious difference and I could cruise at 4600 rpm all day at 1390 degrees EGT. At full 5100, the EGT would still slowly climb above 1450-degrees, which I felt might be high for continuous running. Without initially knowing, I changed out the air filters to K&N types because of concern for the foam. This reduced air resistance into the carburetors, provided more air, leaner mixture and increased EGTs. Cool weather also seemed to increase EGTs. On a Bing phone inquiry/discussion, the technical rep was surprised I had not yet increased mid-range jetting and suggested I replace 2.72 with 2.76 jets and lower the needles one notch to see if the equivalent of a one-jet change would work. 174 mains were also changed to 176 jets. A 3500-rpm run-up with brakes brought EGTs to 1400-degrees rather quickly. The needle jet was then raised by re-setting the circlip down to #3 notch and the EGTs climbed to 1290 at 3500-rpm, but no higher. Quite a difference! Was anxious to fly these jet and needle settings to see what happens at higher rpms. Today, at 40-degrees, winds at 10, I taxied to 31 and holding short, watched pre-heated oil reach 240 until clearance was given for takeoff. Climb out was impressive, and EGTs were slow to climb to 1450 at 5100, so I reduced rpms to 4400 and turned south to the practice area and EGTs came down to 1435. Rpms were lowered to a comfortable 4300 and EGTs stabilized at 1420. The largest change from increasing jet sizes was the slow mid range climb through 1400 on takeoff. I flew an hour and then returned to land on 27. All other temps were normal throughout the flight. Back at the hangar, the K&N type air filters were removed and replaced with the original foam types to see if they would make a difference. Went home for lunch. Afterward, I refueled the plane and taxied out in 16 mph winds to lift off very quickly from 31. The EGT rise was slower and never got past 1420 on takeoff. After leveling the plane, I headed south for 15 minutes. Rpms were set back to 4350 and EGTs settled in at 1375. There's still about a 40-degree difference from the right to left sides. I tried raising the rpms to 5000 and the EGTs would level out at 1425. The old foam filters had a much greater impact on mixture than I'd have thought. EGTs are satisfactory to this point as I can cruise at 115 to 120 without getting much beyond a 1400-degree limit. My Engine timing is set to 30-degrees at 4500 rpm. I haven't seen evidence that re-timing 1 or 2 degrees either way helped it run better. Plugs soot up at idle and plug color doesn't offer exact information, so I purchased a high-compression Colortune plug from Bing. This will permit actually seeing the mixture and rpms from idle to 4000, but no further. Haven't used it yet as focus has been on the high end and getting Horsepower at lower EGTs. I expect to install an O2 sensor to confirm running mixtures when the jet settings have been flown. EGT sensors are installed 3-1/2" from the exhaust flange in the top of the first straight after the bend. They are a probe-type secured by a hose-clamp that also grips a belting heat wrap on the exhaust pipes to protect the cowling. All engine data is displayed on a Grand Rapids Technologies E I S. This thing is indispensable for showing all real-time engine parameters and immediately displaying an alarm-light while pointing out any out-of-limit condition. It's an easy set-up too! Earlier this season, the radiator was moved back as a P51, to where it was and it works very well. Please forgive the lengthy diatribe, but the archives needed specific jet and needle setting information for this engine. That's as much as I know at this time. If you've been there done that, have a comment or objection, please do, so we can all compare notes and learn from the collective experience. Thanks guys, Larry McFarland - 601HDS with Stratus Subaru and Ram Performance heads at www.macsmachine.com<http://www.macsmachine.com/> _ ________________________________________________________________________________
Date: Dec 20, 2004
Thanks to everyone for all of the feedback. Don...You say that yours ran as smooth as a sewing machine until this week. Did installing richer main jets cause it to run rough? Mine humms along smoothly also. Wouldn't want to lose that. I've thought several times about installing an oil cooler, since when I run higher RPM the oil temp seems to rise first, followed by the engine temp. Haven't gotten around to the oil cooler yet. I've also been studying prop pitch settings, since Mykal at Stratus recommended that I start with a 17.5 degree pitch to keep the rpm down (I've never run it that high). Someone sent around a nice spreadsheet with graph curves that has really helped in trying different pitch settings and checking the performance curves as I make the changes. It even tells you if you need to increase the pitch or decrease it to head toward your goal. I collected this spreadsheet months ago. Does anyone know if there is a more recent version? If accurate, it is good. It's for a 601HDS. Jim -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Don Walker Subject: Re: Stratus-List: Jetting Stratus Bing Carbureters Jim, You might check your jet size compared to this report. Mine came from Stratus with smaller main jets...162 rather than the 164 reported here. Mine ran smooth as a sewing machine until this week when I changed the jetting. I put in a 165 main, which seems to do well, and enriched the mid-range two notches. Now I am going to do what you did...bring the mid-range back up to the third notch. Also remember that some here are getting more air flow with the Ram heads. don walker----- Original Message ----- From: Weston, Jim<mailto:Jim.Weston(at)delta.com> To: stratus-list(at)matronics.com Sent: Friday, December 17, 2004 12:55 PM Subject: RE: Stratus-List: Jetting Stratus Bing Carbureters > So am I to take it that everyone has been finding that the jets are too lean at cruise, as the engine comes from Stratus? I don't have EGT gauges. This might explain why I've never been able to run at high RPM for long before the temps (engine & oil) start to climb. I changed my mid-range needle to the 3rd ring, some time back, and this helped some. Jim Weston 601HDS, Stratus Concord, Ga. -----Original Message----- From: owner-stratus-list-server(at)matronics.com@matronics.com> [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) To: stratus-list(at)matronics.com Subject: RE: Stratus-List: Jetting Stratus Bing Carbureters --> > Your experience pretty much mirros mine Larry, the only difference is I ended up with a cruise EGT of 1450. The mixture were confirmed correct by the exhaust gas analyser. I can't remember what jets I ended up with finally. Thanks Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com@matronics.com> [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Larry McFarland To: stratus-list(at)matronics.com Subject: Stratus-List: Jetting Stratus Bing Carbureters --> > Hi guys, (fellow Stratus EA-81 users) I think it's time to put the experience of re-jetting Stratus-Bing carbs into the archives. Perhaps it'll reduce your time and expense of "discovery". The "Bing Carburettors Aircraft Tuning & Parts Manual" is needed to fully visualize this information. Bing can be reached at 1-800-309-2464 weekdays and it's only $8.00. (Yes, the spelling is correct) The manual is a good parts-identifier and primer for getting correct mixture, but you have to do the guesswork till it's right, so for the Stratus, that's what this piece is about. My Stratus engine with Bing carburetor's initially came with No.40 idle mixture-jets adjusted 2-turns from closed, 164 main jets and 2.72 mid-range jets. (Note; all jets have the number stamped on each one.) The mid-range jet-needles came with 2 scribed rings on their diameters for identification and on the jet-needle 4 snap-ring notches, the circlips were set at the #2 position or second notch from the top. Ram Performance installed new S.S. valves, springs and guides. The rework also provides more airflow, so increased jet sizes are recommended by Ron at Ram to get a target cruise EGT of 1350-degrees. Mykal at Stratus says 1400 to 1500 degrees is fine with an upper limit short duration 1600-degrees. With high EGTs, I changed to 170 main jets. EGTs came down, but were too high for takeoff rpms. 180 main jets were tried but the engine ran rough with these. With 174 mains, the plane flew well. EGTs reached 1400 degrees at 4200 rpm. (Still too high for higher rpms) The mid-range jet-needle was set higher to enrich fuel mixture by moving the circlip from #2 notch down to the #3 notch. This made a serious difference and I could cruise at 4600 rpm all day at 1390 degrees EGT. At full 5100, the EGT would still slowly climb above 1450-degrees, which I felt might be high for continuous running. Without initially knowing, I changed out the air filters to K&N types because of concern for the foam. This reduced air resistance into the carburetors, provided more air, leaner mixture and increased EGTs. Cool weather also seemed to increase EGTs. On a Bing phone inquiry/discussion, the technical rep was surprised I had not yet increased mid-range jetting and suggested I replace 2.72 with 2.76 jets and lower the needles one notch to see if the equivalent of a one-jet change would work. 174 mains were also changed to 176 jets. A 3500-rpm run-up with brakes brought EGTs to 1400-degrees rather quickly. The needle jet was then raised by re-setting the circlip down to #3 notch and the EGTs climbed to 1290 at 3500-rpm, but no higher. Quite a difference! Was anxious to fly these jet and needle settings to see what happens at higher rpms. Today, at 40-degrees, winds at 10, I taxied to 31 and holding short, watched pre-heated oil reach 240 until clearance was given for takeoff. Climb out was impressive, and EGTs were slow to climb to 1450 at 5100, so I reduced rpms to 4400 and turned south to the practice area and EGTs came down to 1435. Rpms were lowered to a comfortable 4300 and EGTs stabilized at 1420. The largest change from increasing jet sizes was the slow mid range climb through 1400 on takeoff. I flew an hour and then returned to land on 27. All other temps were normal throughout the flight. Back at the hangar, the K&N type air filters were removed and replaced with the original foam types to see if they would make a difference. Went home for lunch. Afterward, I refueled the plane and taxied out in 16 mph winds to lift off very quickly from 31. The EGT rise was slower and never got past 1420 on takeoff. After leveling the plane, I headed south for 15 minutes. Rpms were set back to 4350 and EGTs settled in at 1375. There's still about a 40-degree difference from the right to left sides. I tried raising the rpms to 5000 and the EGTs would level out at 1425. The old foam filters had a much greater impact on mixture than I'd have thought. EGTs are satisfactory to this point as I can cruise at 115 to 120 without getting much beyond a 1400-degree limit. My Engine timing is set to 30-degrees at 4500 rpm. I haven't seen evidence that re-timing 1 or 2 degrees either way helped it run better. Plugs soot up at idle and plug color doesn't offer exact information, so I purchased a high-compression Colortune plug from Bing. This will permit actually seeing the mixture and rpms from idle to 4000, but no further. Haven't used it yet as focus has been on the high end and getting Horsepower at lower EGTs. I expect to install an O2 sensor to confirm running mixtures when the jet settings have been flown. EGT sensors are installed 3-1/2" from the exhaust flange in the top of the first straight after the bend. They are a probe-type secured by a hose-clamp that also grips a belting heat wrap on the exhaust pipes to protect the cowling. All engine data is displayed on a Grand Rapids Technologies E I S. This thing is indispensable for showing all real-time engine parameters and immediately displaying an alarm-light while pointing out any out-of-limit condition. It's an easy set-up too! Earlier this season, the radiator was moved back as a P51, to where it was and it works very well. Please forgive the lengthy diatribe, but the archives needed specific jet and needle setting information for this engine. That's as much as I know at this time. If you've been there done that, have a comment or objection, please do, so we can all compare notes and learn from the collective experience. Thanks guys, Larry McFarland - 601HDS with Stratus Subaru and Ram Performance heads at www.macsmachine.com<http://www.macsmachine.com/> _ ________________________________________________________________________________
Date: Dec 20, 2004
Hi Jim, The main jet seems to be good at 165 on mine...a change from the 162. It ran rough last week with the midrange on the bottom notch. Last weekend I moved that up to the third, just like yours and that is working well. I also took a lot of time balancing the carbs. To summarize, mine ran very smoothly with the 162 but I knew it was at least slightly lean in the mid and high ranges...particularly in cooler weather. Now I am pleased to say the engine is running better...smoother than ever throughout the throttle range and seems to have better power. The roughness at the 2800 rpm setting was reduced to negligible. I am beginning to think much of any roughness in the midrange was due to a little carb imbalance. It has always been smooth above 3800 until backing off the power. Now it is much smoother in backing off the power throughout the range. Regarding oil temps...I hear many running oil temps higher. Just a note...with a heat muff and an adjustable door in front of my oil pan, my oil temps never exceed 190 even in the hot summer, though the head will get up to 215 in a climb. don ----- Original Message ----- From: Weston, Jim<mailto:Jim.Weston(at)delta.com> To: stratus-list(at)matronics.com Sent: Monday, December 20, 2004 8:26 AM Subject: RE: Stratus-List: Jetting Stratus Bing Carbureters Thanks to everyone for all of the feedback. Don...You say that yours ran as smooth as a sewing machine until this week. Did installing richer main jets cause it to run rough? Mine humms along smoothly also. Wouldn't want to lose that. I've thought several times about installing an oil cooler, since when I run higher RPM the oil temp seems to rise first, followed by the engine temp. Haven't gotten around to the oil cooler yet. I've also been studying prop pitch settings, since Mykal at Stratus recommended that I start with a 17.5 degree pitch to keep the rpm down (I've never run it that high). Someone sent around a nice spreadsheet with graph curves that has really helped in trying different pitch settings and checking the performance curves as I make the changes. It even tells you if you need to increase the pitch or decrease it to head toward your goal. I collected this spreadsheet months ago. Does anyone know if there is a more recent version? If accurate, it is good. It's for a 601HDS. Jim -----Original Message----- From: owner-stratus-list-server(at)matronics.com<mailto:owner-stratus-list-server(at)matronics.com> [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Don Walker To: stratus-list(at)matronics.com Subject: Re: Stratus-List: Jetting Stratus Bing Carbureters Jim, You might check your jet size compared to this report. Mine came from Stratus with smaller main jets...162 rather than the 164 reported here. Mine ran smooth as a sewing machine until this week when I changed the jetting. I put in a 165 main, which seems to do well, and enriched the mid-range two notches. Now I am going to do what you did...bring the mid-range back up to the third notch. Also remember that some here are getting more air flow with the Ram heads. don walker----- Original Message ----- From: Weston, Jim<mailto:Jim.Weston(at)delta.com<mailto:Jim.Weston(at)delta.com>> To: stratus-list(at)matronics.com> Sent: Friday, December 17, 2004 12:55 PM Subject: RE: Stratus-List: Jetting Stratus Bing Carbureters >> So am I to take it that everyone has been finding that the jets are too lean at cruise, as the engine comes from Stratus? I don't have EGT gauges. This might explain why I've never been able to run at high RPM for long before the temps (engine & oil) start to climb. I changed my mid-range needle to the 3rd ring, some time back, and this helped some. Jim Weston 601HDS, Stratus Concord, Ga. -----Original Message----- From: owner-stratus-list-server(at)matronics.com @matronics.com> [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) To: stratus-list(at)matronics.com> Subject: RE: Stratus-List: Jetting Stratus Bing Carbureters --> >> Your experience pretty much mirros mine Larry, the only difference is I ended up with a cruise EGT of 1450. The mixture were confirmed correct by the exhaust gas analyser. I can't remember what jets I ended up with finally. Thanks Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com @matronics.com> [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Larry McFarland To: stratus-list(at)matronics.com> Subject: Stratus-List: Jetting Stratus Bing Carbureters --> >> Hi guys, (fellow Stratus EA-81 users) I think it's time to put the experience of re-jetting Stratus-Bing carbs into the archives. Perhaps it'll reduce your time and expense of "discovery". The "Bing Carburettors Aircraft Tuning & Parts Manual" is needed to fully visualize this information. Bing can be reached at 1-800-309-2464 weekdays and it's only $8.00. (Yes, the spelling is correct) The manual is a good parts-identifier and primer for getting correct mixture, but you have to do the guesswork till it's right, so for the Stratus, that's what this piece is about. My Stratus engine with Bing carburetor's initially came with No.40 idle mixture-jets adjusted 2-turns from closed, 164 main jets and 2.72 mid-range jets. (Note; all jets have the number stamped on each one.) The mid-range jet-needles came with 2 scribed rings on their diameters for identification and on the jet-needle 4 snap-ring notches, the circlips were set at the #2 position or second notch from the top. Ram Performance installed new S.S. valves, springs and guides. The rework also provides more airflow, so increased jet sizes are recommended by Ron at Ram to get a target cruise EGT of 1350-degrees. Mykal at Stratus says 1400 to 1500 degrees is fine with an upper limit short duration 1600-degrees. With high EGTs, I changed to 170 main jets. EGTs came down, but were too high for takeoff rpms. 180 main jets were tried but the engine ran rough with these. With 174 mains, the plane flew well. EGTs reached 1400 degrees at 4200 rpm. (Still too high for higher rpms) The mid-range jet-needle was set higher to enrich fuel mixture by moving the circlip from #2 notch down to the #3 notch. This made a serious difference and I could cruise at 4600 rpm all day at 1390 degrees EGT. At full 5100, the EGT would still slowly climb above 1450-degrees, which I felt might be high for continuous running. Without initially knowing, I changed out the air filters to K&N types because of concern for the foam. This reduced air resistance into the carburetors, provided more air, leaner mixture and increased EGTs. Cool weather also seemed to increase EGTs. On a Bing phone inquiry/discussion, the technical rep was surprised I had not yet increased mid-range jetting and suggested I replace 2.72 with 2.76 jets and lower the needles one notch to see if the equivalent of a one-jet change would work. 174 mains were also changed to 176 jets. A 3500-rpm run-up with brakes brought EGTs to 1400-degrees rather quickly. The needle jet was then raised by re-setting the circlip down to #3 notch and the EGTs climbed to 1290 at 3500-rpm, but no higher. Quite a difference! Was anxious to fly these jet and needle settings to see what happens at higher rpms. Today, at 40-degrees, winds at 10, I taxied to 31 and holding short, watched pre-heated oil reach 240 until clearance was given for takeoff. Climb out was impressive, and EGTs were slow to climb to 1450 at 5100, so I reduced rpms to 4400 and turned south to the practice area and EGTs came down to 1435. Rpms were lowered to a comfortable 4300 and EGTs stabilized at 1420. The largest change from increasing jet sizes was the slow mid range climb through 1400 on takeoff. I flew an hour and then returned to land on 27. All other temps were normal throughout the flight. Back at the hangar, the K&N type air filters were removed and replaced with the original foam types to see if they would make a difference. Went home for lunch. Afterward, I refueled the plane and taxied out in 16 mph winds to lift off very quickly from 31. The EGT rise was slower and never got past 1420 on takeoff. After leveling the plane, I headed south for 15 minutes. Rpms were set back to 4350 and EGTs settled in at 1375. There's still about a 40-degree difference from the right to left sides. I tried raising the rpms to 5000 and the EGTs would level out at 1425. The old foam filters had a much greater impact on mixture than I'd have thought. EGTs are satisfactory to this point as I can cruise at 115 to 120 without getting much beyond a 1400-degree limit. My Engine timing is set to 30-degrees at 4500 rpm. I haven't seen evidence that re-timing 1 or 2 degrees either way helped it run better. Plugs soot up at idle and plug color doesn't offer exact information, so I purchased a high-compression Colortune plug from Bing. This will permit actually seeing the mixture and rpms from idle to 4000, but no further. Haven't used it yet as focus has been on the high end and getting Horsepower at lower EGTs. I expect to install an O2 sensor to confirm running mixtures when the jet settings have been flown. EGT sensors are installed 3-1/2" from the exhaust flange in the top of the first straight after the bend. They are a probe-type secured by a hose-clamp that also grips a belting heat wrap on the exhaust pipes to protect the cowling. All engine data is displayed on a Grand Rapids Technologies E I S. This thing is indispensable for showing all real-time engine parameters and immediately displaying an alarm-light while pointing out any out-of-limit condition. It's an easy set-up too! Earlier this season, the radiator was moved back as a P51, to where it was and it works very well. Please forgive the lengthy diatribe, but the archives needed specific jet and needle setting information for this engine. That's as much as I know at this time. If you've been there done that, have a comment or objection, please do, so we can all compare notes and learn from the collective experience. Thanks guys, Larry McFarland - 601HDS with Stratus Subaru and Ram Performance heads at www.macsmachine.com<http://www.macsmachine.com/>> _ ________________________________________________________________________________
Date: Dec 21, 2004
Thanks Don, I'm assuming that you're thinking that the heat muff shields the back of the oil pan from the muffler? I don't need the heat muff, but I have thought about installing some sort of heat shield between the muffler and the back of the oil pan. I may actually be getting false high readings from the oil temp due to the radiated heat from the muffler. That oil temp sensor is right on the back side of the oil pan. I've also thought about drilling thru that nut that the sensor screws into on the back of the pan, so that the sensor is actually bathed in the oil. But I worry about causing a leak. Thanks Again, Jim -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Don Walker Subject: Re: Stratus-List: Jetting Stratus Bing Carbureters Hi Jim, The main jet seems to be good at 165 on mine...a change from the 162. It ran rough last week with the midrange on the bottom notch. Last weekend I moved that up to the third, just like yours and that is working well. I also took a lot of time balancing the carbs. To summarize, mine ran very smoothly with the 162 but I knew it was at least slightly lean in the mid and high ranges...particularly in cooler weather. Now I am pleased to say the engine is running better...smoother than ever throughout the throttle range and seems to have better power. The roughness at the 2800 rpm setting was reduced to negligible. I am beginning to think much of any roughness in the midrange was due to a little carb imbalance. It has always been smooth above 3800 until backing off the power. Now it is much smoother in backing off the power throughout the range. Regarding oil temps...I hear many running oil temps higher. Just a note...with a heat muff and an adjustable door in front of my oil pan, my oil temps never exceed 190 even in the hot summer, though the head will get up to 215 in a climb. don ________________________________________________________________________________
Date: Dec 21, 2004
Jim, I went thru many many revisions of my cooling system, and when I was trying to get it to work with the stock exhaust I played with a heat shield and trying to get better airflow over the pan and muffler. The heat shield helped a little but I got tired of making minor changes to a system that was marginal. I know you're not interested in a major redesign, but it was like night and day when I finally made the big change. I'll try to dig out some notes, but I was thinking the same as you - possibly radiated heat onto the sensor, and I was disappointed at the results. I think it's radiated heat onto the whole oil pan, not just the sensor. So I think it's a valid oil temp reading. Easy enough to try the heat shield but if it's marginal, it'll only make it less marginal. It was very obvious when I moved the exhaust that things were right, very glad I did it. Next is ram air and exhaust augmented cooling, and hopefully a Quinti/Sensenich prop. Gary Krysztopik Pelican PL - N522GK Stratus Subaru EA-81 Newport, RI
http://members.efortress.com/flyink/index.html ----- Original Message ----- From: "Weston, Jim" <Jim.Weston(at)delta.com> Subject: RE: Stratus-List: Jetting Stratus Bing Carbureters > > Thanks Don, > > I'm assuming that you're thinking that the heat muff shields the back of > the oil pan from the muffler? I don't need the heat muff, but I have > thought about installing some sort of heat shield between the muffler > and the back of the oil pan. I may actually be getting false high > readings from the oil temp due to the radiated heat from the muffler. > That oil temp sensor is right on the back side of the oil pan. I've > also thought about drilling thru that nut that the sensor screws into on > the back of the pan, so that the sensor is actually bathed in the oil. > But I worry about causing a leak. > > Thanks Again, > Jim > > > -----Original Message----- > From: owner-stratus-list-server(at)matronics.com > [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Don Walker > To: stratus-list(at)matronics.com > Subject: Re: Stratus-List: Jetting Stratus Bing Carbureters > > > Hi Jim, > The main jet seems to be good at 165 on mine...a change from the 162. > It ran rough last week with the midrange on the bottom notch. Last > weekend I moved that up to the third, just like yours and that is > working well. I also took a lot of time balancing the carbs. > To summarize, mine ran very smoothly with the 162 but I knew it was > at least slightly lean in the mid and high ranges...particularly in > cooler weather. Now I am pleased to say the engine is running > better...smoother than ever throughout the throttle range and seems to > have better power. The roughness at the 2800 rpm setting was reduced to > negligible. I am beginning to think much of any roughness in the > midrange was due to a little carb imbalance. It has always been smooth > above 3800 until backing off the power. Now it is much smoother in > backing off the power throughout the range. > Regarding oil temps...I hear many running oil temps higher. Just a > note...with a heat muff and an adjustable door in front of my oil pan, > my oil temps never exceed 190 even in the hot summer, though the head > will get up to 215 in a climb. don ________________________________________________________________________________
Subject: exhaust heat
Date: Dec 21, 2004
Don, I went thru many many revisions of my cooling system, and when I was trying to get it to work with the stock exhaust I played with a heat shield and trying to get better airflow over the pan and muffler. The heat shield helped a little but I got tired of making minor changes to a system that was marginal. I know you're not interested in a major redesign, but it was like night and day when I finally made the big change. I'll try to dig out some notes, but I was thinking the same as you - possibly radiated heat onto the sensor, and I was disappointed at the results. I think it's radiated heat onto the whole oil pan, not just the sensor. So I think it's a valid oil temp reading. Easy enough to try the heat shield but if it's marginal, it'll only make it less marginal. It was very obvious when I moved the exhaust that things were right, very glad I did it. Next is ram air and exhaust augmented cooling, and hopefully a Quinti/Sensenich prop. Gary Krysztopik Pelican PL - N522GK Stratus Subaru EA-81 Newport, RI http://members.efortress.com/flyink/index.html ----- Original Message ----- From: "Weston, Jim" <Jim.Weston(at)delta.com> Subject: RE: Stratus-List: Jetting Stratus Bing Carbureters > > Thanks Don, > > I'm assuming that you're thinking that the heat muff shields the back of > the oil pan from the muffler? I don't need the heat muff, but I have > thought about installing some sort of heat shield between the muffler > and the back of the oil pan. I may actually be getting false high > readings from the oil temp due to the radiated heat from the muffler. > That oil temp sensor is right on the back side of the oil pan. I've > also thought about drilling thru that nut that the sensor screws into on > the back of the pan, so that the sensor is actually bathed in the oil. > But I worry about causing a leak. > > Thanks Again, > Jim > > > -----Original Message----- > From: owner-stratus-list-server(at)matronics.com > [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Don Walker > To: stratus-list(at)matronics.com > Subject: Re: Stratus-List: Jetting Stratus Bing Carbureters > > > Hi Jim, > The main jet seems to be good at 165 on mine...a change from the 162. > It ran rough last week with the midrange on the bottom notch. Last > weekend I moved that up to the third, just like yours and that is > working well. I also took a lot of time balancing the carbs. > To summarize, mine ran very smoothly with the 162 but I knew it was > at least slightly lean in the mid and high ranges...particularly in > cooler weather. Now I am pleased to say the engine is running > better...smoother than ever throughout the throttle range and seems to > have better power. The roughness at the 2800 rpm setting was reduced to > negligible. I am beginning to think much of any roughness in the > midrange was due to a little carb imbalance. It has always been smooth > above 3800 until backing off the power. Now it is much smoother in > backing off the power throughout the range. > Regarding oil temps...I hear many running oil temps higher. Just a > note...with a heat muff and an adjustable door in front of my oil pan, > my oil temps never exceed 190 even in the hot summer, though the head > will get up to 215 in a climb. don > > > ________________________________________________________________________________
Subject: Heet products?
Date: Jan 07, 2005
Hi guys, The winter weather has my hangar in its grip and the 601 is enjoying the benefit of a oil-warming heater but, I'm concerned about water condensing within the top of my fuel tank. There's about 2" that remains open because of the overflow tube that leads out to the wing. Should I be using one of the anti-water products like Heet or such in this engine? The likelihood is that for 2 to 4 weeks, the plane will set idle and the fuel will get stale or worse accumulate moisture. Any opinions? Larry McFarland - 601HDS - Stratus Subaru using 87-octane. ________________________________________________________________________________
Date: Jan 07, 2005
Subject: [PLEASE READ NOW] - Addressing Upgrade At Matronics TONIGHT!
Dear Listers, Service Provider to upgrade to a larger IP subnet. I will be re-addressing all of the machines on the network including the Matronics Web Server and Matronics Email Server at that time. Name Service will be updated at that time as well and most things should work again pretty quick. There may be some bounced email for a few hours or even a day or so as the new name-to-ip-address resolutions propagate into the depths of the Internet. If you have problems posting a message to one of the Lists or get a bounced message back, please wait a couple of hours and try sending it again. Generally, access to the web site should work within 1-hour of Hopefully the transition will go smoothly and you'll hardly even notice! :-) Thanks for your patience! Matt Dralle List Administrator -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Re: Heet products?
Date: Jan 07, 2005
Hi Larry, I was a little leery of adding "Heet" because I was afraid of putting to much alcohol thru the Bing carbs. This may be a good question to ask Bing. I've gotten their OK to use gasohol, but I never asked about adding a can of Heet to the fuel. At times in the winter I have added fuel stab when I new the plane would be sitting more than a few weeks. Kelly ________________________________________________________________________________
Date: Jan 09, 2005
Subject: bearing maintenance
Gotta repack my prop shaft bearings. Can anyone shed some light on how to remove those nuts off the back of the prop shaft? I tried the hammer-and-drift punch routine. Didn't even budge. Those are come fine maintenance instructions in the manual, eh? Danny Williamson Kitfox 5 ________________________________________________________________________________
Date: Jan 10, 2005
Hello Larry, I never had any problems with water in the tanks except when parked over night outside in a little mountanous get-away with the song birds tweating and.....Sorry Monday morning romatacising..:) Yes I saw a little water in the bottom of the tank. All I did was to shake the wing to get any condensation off the top airspace, complete my preflight and then drain the water off the bottom. No probs! Surprised you use 87 octane. I and a few others had problems with the engine running on when the ignition was killed which spelled preignition to us. Even happened with 89 octane but went away with 92 octane. Just a thought. Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Larry McFarland Subject: Stratus-List: Heet products? --> Hi guys, The winter weather has my hangar in its grip and the 601 is enjoying the benefit of a oil-warming heater but, I'm concerned about water condensing within the top of my fuel tank. There's about 2" that remains open because of the overflow tube that leads out to the wing. Should I be using one of the anti-water products like Heet or such in this engine? The likelihood is that for 2 to 4 weeks, the plane will set idle and the fuel will get stale or worse accumulate moisture. Any opinions? Larry McFarland - 601HDS - Stratus Subaru using 87-octane. ________________________________________________________________________________
Date: Jan 12, 2005
I assume that you have noticed that there is a very large locking washer with bend down tabs to hold it in place. You need to bend the tabs up. Jim Weston 601HDS Concord, Ga -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of N53dw(at)aol.com Subject: Stratus-List: bearing maintenance Gotta repack my prop shaft bearings. Can anyone shed some light on how to remove those nuts off the back of the prop shaft? I tried the hammer-and-drift punch routine. Didn't even budge. Those are come fine maintenance instructions in the manual, eh? Danny Williamson Kitfox 5 ________________________________________________________________________________
Date: Jan 18, 2005
Subject: Reiner Hoffman, are you there?
Reiner Hoffman, are you still out there? Sure would love to hear from you again, long time my friend... Mike Heit ________________________________________________________________________________
Subject: Re: Reiner Hoffman, are you there?
Date: Jan 18, 2005
he's probably not on this list Michael (unfortunately). I asked Matt at Matronics to start this list and it's mostly a handful of guys from the Zenith list. I'm not sure who else may have joined but I doubt Reiner or even Mykal at Stratus are on the list. Just us owners trying to keep them flying safely. Gary ----- Original Message ----- From: "Michael Heit" <rmrlpfm(at)centurytel.net> Subject: Stratus-List: Reiner Hoffman, are you there? > > Reiner Hoffman, are you still out there? Sure would love to hear from > you again, long time my friend... > Mike Heit > > > ________________________________________________________________________________
Date: Jan 19, 2005
Subject: Reiner Hoffman ...
Thanks Gary, Mykal is a great guy too, really knows those soobs inside and out. I knew him from NSI when I was out there building an Avid Magnum. Was going to put an NSI EJ-22 in it but ended up using an O-360 in it. NSI was good at details, but their gear box sucked .... left me in a no power situation in Montana in a Kitfox .. landed on a rural dirt road .... the drive shaft int eh gear reduction unit was trashed .... and Lance at NSI was a cockroach. Other than that, was a good engine. I hated the Ellison throttle body. If I had it to do over again, would have gone with the Stratus conversion. It is lighter, more reliable. Are you flying a Stratus engine? EA-81?? > >he's probably not on this list Michael (unfortunately). I asked Matt at >Matronics to start this list and it's mostly a handful of guys from the >Zenith list. I'm not sure who else may have joined but I doubt Reiner or >even Mykal at Stratus are on the list. Just us owners trying to keep them >flying safely. > >Gary > > ________________________________________________________________________________
Subject: Re: Reiner Hoffman ...
Date: Jan 19, 2005
> hated the Ellison throttle body. If I had it to do over again, would > have gone with the Stratus conversion. It is lighter, more reliable. Are > you flying a Stratus engine? EA-81?? yes, and I'm really happy with it. There were a handful of engines that dropped some valve guides so a lot of guys (including me) had the heads reworked just to be safe, and a few cracked engine mounts on the Zenith version but overall I think there are a lot out there that have held up really well. Still flying the Magnum? Nice plane, must be a real workhorse with a 360 in it. Gary Krysztopik Pelican PL - N522GK Stratus Subaru EA-81 Newport, RI http://members.efortress.com/flyink/index.html ________________________________________________________________________________
Date: Jan 19, 2005
Hmmm...Quite a few have dropped valve guides...My engine dropped three...Ram Performance now make stepped valve guides and heat shrink them in place. Stratus redrive is good but I would not trust their head shop anymore. Frank Zodiac 601 Stratus with Ram heads -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of gary Subject: Re: Stratus-List: Reiner Hoffman ... > hated the Ellison throttle body. If I had it to do over again, would > have gone with the Stratus conversion. It is lighter, more reliable. > Are you flying a Stratus engine? EA-81?? yes, and I'm really happy with it. There were a handful of engines that dropped some valve guides so a lot of guys (including me) had the heads reworked just to be safe, and a few cracked engine mounts on the Zenith version but overall I think there are a lot out there that have held up really well. Still flying the Magnum? Nice plane, must be a real workhorse with a 360 in it. Gary Krysztopik Pelican PL - N522GK Stratus Subaru EA-81 Newport, RI http://members.efortress.com/flyink/index.html ________________________________________________________________________________
Date: Jan 23, 2005
Subject: balancing the carbs
Hi guys. I have just discovered this list and finished reading the archives which have been a great info source. Myself and a friend have two identical wood/fabric float planes powered by a stratus EA81 in the Vancouver area. We both just bought them off the original builders. Mine has about 200 hours on it, and the heads were done sometime ago, no problem with the engine mounts as yet, but I have notice the alternator bracket is cracked. The other plane just had the heads redone after about 40 hours TT and their ignition has just failed. We area both about to go through our first fuel pump as well. We also have vibration in certain ranges that sounds similar to what people have discussed here. Pretty standard stuff it seems. To reduce vibrations people have suggested the following. (1) balance the carbs (2) ensure correct belt tension and tracking and (3) get a prop balance. When balancing the carbs how have people achieved this? When my friends tried to balance theirs they removed the crossover tube and pluged in the vacuum but a got wildly fluctuating bouncing up and down between two values. Some ideas tossed around thought this may be because of the firing order causing all vacuum, no vacuum, all vacuum, no vacuum etc. I have read of people installing a "T" in the crossover tube, but then you are just measuring the agregate of the different pressures so I am not sure how you make sure both are producing even vacuum? Any ideas appreciated. Regards BRETT RUEFF Vancouver rueffy(at)jetthrust.com Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Subject: Re: balancing the carbs
Date: Jan 23, 2005
Brett, I've done as you've described with mostly good results, but a piece of equipment you guys could share is a "Twinmax" for balancing carbs from Bing. They're $70 or so, but you remove the screw at the protruding stem next to the idle screw and hook up a plastic tube to each carb. Block off the crossover hose with a plug and short hose stubs. You get a very precise reading from the Twinmax that you can adjust to while running. The other thing is your linkage carb to carb. If you're using two cables and the spring on throttles to actuate them, singular adjustments are difficult. I did a cross linkage that flexes and attaches to the throttle shaft, is adjustable but holds the alignment of throttle plates very exactly and requires only one throttle arm of the two Bings to be connected to your panel throttle cable. My site below has pictures on the control linkages and subaru engine pages if it's even applicable to your birds. Bings phone number is 1-800-309-2464 and you should probably get the Bing Carburettors Aircraft Tuning and Parts Manual for $8.00 if you don't have one as well. Larry McFarland - 601hds @ www.macsmachine.com Subject: Stratus-List: balancing the carbs > > Hi guys. > > I have just discovered this list and finished reading the archives which > have > been a great info source. Myself and a friend have two identical > wood/fabric > float planes powered by a stratus EA81 in the Vancouver area. > > To reduce vibrations people have suggested the following. (1) balance the carbs > (2) ensure correct belt tension and tracking and (3) get a prop balance. > When > balancing the carbs how have people achieved this? When my friends tried > to > balance theirs they removed the crossover tube and pluged in the vacuum > but a > got wildly fluctuating bouncing up and down between two values. Any > ideas appreciated. > > Regards > BRETT RUEFF > Vancouver > rueffy(at)jetthrust.com ________________________________________________________________________________
Date: Jan 23, 2005
Thanks Larry, i'll look into that. I was planning on getting the bing manual anyway. Brett Quoting Larry McFarland : > > Brett, > I've done as you've described with mostly good results, but a piece of > equipment you guys could share is a "Twinmax" for balancing carbs from Bing. > They're $70 or so, but you remove the screw at the protruding stem > next to the idle screw and hook up a plastic tube to each carb. Block off > the crossover hose with a plug and short hose stubs. You get a very precise > reading from the Twinmax that you can adjust to while running. > > The other thing is your linkage carb to carb. If you're using two cables > and the spring on throttles to actuate them, singular adjustments are > difficult. > I did a cross linkage that flexes and attaches to the throttle shaft, is > adjustable > but holds the alignment of throttle plates very exactly and requires only > one > throttle arm of the two Bings to be connected to your panel throttle cable. > My site below has pictures on the control linkages and subaru engine pages > if it's even applicable to your birds. > > Bings phone number is 1-800-309-2464 and you should probably get the > Bing Carburettors Aircraft Tuning and Parts Manual for $8.00 if you don't > have one as well. > > Larry McFarland - 601hds @ www.macsmachine.com > > > Subject: Stratus-List: balancing the carbs > > > > > > Hi guys. > > > > I have just discovered this list and finished reading the archives which > > have > > been a great info source. Myself and a friend have two identical > > wood/fabric > > float planes powered by a stratus EA81 in the Vancouver area. > > > To reduce vibrations people have suggested the following. > (1) balance the carbs > > (2) ensure correct belt tension and tracking and (3) get a prop balance. > > When > > balancing the carbs how have people achieved this? When my friends tried > > to > > balance theirs they removed the crossover tube and pluged in the vacuum > > but a > > got wildly fluctuating bouncing up and down between two values. Any > > ideas appreciated. > > > > Regards > > BRETT RUEFF > > Vancouver > > rueffy(at)jetthrust.com > > > > > > > Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Jan 23, 2005
Howdy Larry, I have just finished browsing your website and have a couple of questions. Great website too by the way. Firstly with the carbs. When we are bloking the crossover tube and measuring the vacuum but we can't get an accurate reading because the gauge bounces eratically. We are assuming this is because the firing order fires the two pistions on one side, then the two on the other. If this is the case then I guess you have all suction, then nothing, all suction etc. Do you get this wild reading? Mine seemed to fluctuate between 4-5 when no suction was occuring and 13-15 when the suction was occuring. And does the twin max give stable readings? The second question is regarding the linkages for the throttle cable to the carbs. I see you have a great looking fitting with a 90 degree bend that looks nice and solid. Where did these come from....I have a bad setup with the throttle cable just shoved into the fitting sleve on the carby which means it isn't secured very well - I like your fitting. Brett Quoting Larry McFarland : > > Brett, > I've done as you've described with mostly good results, but a piece of > equipment you guys could share is a "Twinmax" for balancing carbs from Bing. > They're $70 or so, but you remove the screw at the protruding stem > next to the idle screw and hook up a plastic tube to each carb. Block off > the crossover hose with a plug and short hose stubs. You get a very precise > reading from the Twinmax that you can adjust to while running. > > The other thing is your linkage carb to carb. If you're using two cables > and the spring on throttles to actuate them, singular adjustments are > difficult. > I did a cross linkage that flexes and attaches to the throttle shaft, is > adjustable > but holds the alignment of throttle plates very exactly and requires only > one > throttle arm of the two Bings to be connected to your panel throttle cable. > My site below has pictures on the control linkages and subaru engine pages > if it's even applicable to your birds. > > Bings phone number is 1-800-309-2464 and you should probably get the > Bing Carburettors Aircraft Tuning and Parts Manual for $8.00 if you don't > have one as well. > > Larry McFarland - 601hds @ www.macsmachine.com > > > Subject: Stratus-List: balancing the carbs > > > > > > Hi guys. > > > > I have just discovered this list and finished reading the archives which > > have > > been a great info source. Myself and a friend have two identical > > wood/fabric > > float planes powered by a stratus EA81 in the Vancouver area. > > > To reduce vibrations people have suggested the following. > (1) balance the carbs > > (2) ensure correct belt tension and tracking and (3) get a prop balance. > > When > > balancing the carbs how have people achieved this? When my friends tried > > to > > balance theirs they removed the crossover tube and pluged in the vacuum > > but a > > got wildly fluctuating bouncing up and down between two values. Any > > ideas appreciated. > > > > Regards > > BRETT RUEFF > > Vancouver > > rueffy(at)jetthrust.com > > > > > > > Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Jan 24, 2005
Brett, Vacuum gauges usually come with a restrictor fitting, restrictor valve, or have one built into the gauge to dampen out the vacuum pulses that are in all intake manifolds. You can use most any type of adjustable clamp to pinch the hose going to the gauges. Adjust it until it pinches off and holds pressure, then just back off a bit. It will then slowly move from one reading to another as the throttle is changed. Hope this helps, Jim -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of rueffy(at)jetthrust.com Subject: Re: Stratus-List: balancing the carbs Howdy Larry, I have just finished browsing your website and have a couple of questions. Great website too by the way. Firstly with the carbs. When we are bloking the crossover tube and measuring the vacuum but we can't get an accurate reading because the gauge bounces eratically. We are assuming this is because the firing order fires the two pistions on one side, then the two on the other. If this is the case then I guess you have all suction, then nothing, all suction etc. Do you get this wild reading? Mine seemed to fluctuate between 4-5 when no suction was occuring and 13-15 when the suction was occuring. And does the twin max give stable readings? The second question is regarding the linkages for the throttle cable to the carbs. I see you have a great looking fitting with a 90 degree bend that looks nice and solid. Where did these come from....I have a bad setup with the throttle cable just shoved into the fitting sleve on the carby which means it isn't secured very well - I like your fitting. Brett Quoting Larry McFarland : > --> > > Brett, > I've done as you've described with mostly good results, but a piece of > equipment you guys could share is a "Twinmax" for balancing carbs from Bing. > They're $70 or so, but you remove the screw at the protruding stem > next to the idle screw and hook up a plastic tube to each carb. Block > off the crossover hose with a plug and short hose stubs. You get a > very precise reading from the Twinmax that you can adjust to while running. > > The other thing is your linkage carb to carb. If you're using two > cables and the spring on throttles to actuate them, singular > adjustments are difficult. > I did a cross linkage that flexes and attaches to the throttle shaft, > is adjustable but holds the alignment of throttle plates very exactly > and requires only one throttle arm of the two Bings to be connected to > your panel throttle cable. > My site below has pictures on the control linkages and subaru engine > pages if it's even applicable to your birds. > > Bings phone number is 1-800-309-2464 and you should probably get the > Bing Carburettors Aircraft Tuning and Parts Manual for $8.00 if you > don't have one as well. > > Larry McFarland - 601hds @ www.macsmachine.com > > > Subject: Stratus-List: balancing the carbs > > > > > > Hi guys. > > > > I have just discovered this list and finished reading the archives > > which have been a great info source. Myself and a friend have two > > identical wood/fabric float planes powered by a stratus EA81 in the > > Vancouver area. > To reduce vibrations people have suggested the > > following. > (1) balance the carbs > > (2) ensure correct belt tension and tracking and (3) get a prop balance. > > When > > balancing the carbs how have people achieved this? When my friends > > tried to balance theirs they removed the crossover tube and pluged > > in the vacuum but a > > got wildly fluctuating bouncing up and down between two values. Any > > ideas appreciated. > > > > Regards > > BRETT RUEFF > > Vancouver > > rueffy(at)jetthrust.com > > > > > > > Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Jan 24, 2005
Subject: cracked alternator bracket
Hi everyone, quick question for you all. When your alternator bracket cracked and you got a new heavier duty one, did you have to pay for it? While I realise the engine doesn't really have a "warranty" as such I would have thought if a design fault means most alternator plates crack they would be replaced free of charge. Apparently not, so I just wanted to find out what other people experiences were before I push the point with Mkyal. Cheerio Brett Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Subject: Re: cracked alternator bracket
Date: Jan 25, 2005
Subject: Stratus-List: cracked alternator bracket I just wanted to find out what other people experiences were before I push the point with Mkyal. > > Cheerio Brett, Mykal is one of the good guys, so ask him what he'd like to do in replacing the bracket. If it's not been too long, I'd think he'd probably like to replace it, but give him the opportunity to decide. It's not an expensive piece anyway. He recently replaced my RH upper engine mount as it had cracked at 40+ hours and I was pleased to recieve it without cost. Larry ________________________________________________________________________________
Subject: fuel pumps and the POH
Date: Jan 26, 2005
Hi guys, I'm working thru the POH, filling out detail and rewording some of the boilerplate on the page for starting the engine. The part that says the pumps should not be turned on just prior to ignition puzzles me because I always turn on the pumps, wait for 10 seconds and then fire up ignition. Is there a proper answer for this procedure and am I doing something wrong at startup by not having a pump on? Larry McFarland - 601HDS Stratus ________________________________________________________________________________
Date: Jan 26, 2005
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Only in that it won't start (or prime, if you use a primer solenoid like mine) before you turn the pumps on. So yes the pumps need to be run, make pressure, prime and then start. Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Larry McFarland Subject: Stratus-List: fuel pumps and the POH --> Hi guys, I'm working thru the POH, filling out detail and rewording some of the boilerplate on the page for starting the engine. The part that says the pumps should not be turned on just prior to ignition puzzles me because I always turn on the pumps, wait for 10 seconds and then fire up ignition. Is there a proper answer for this procedure and am I doing something wrong at startup by not having a pump on? Larry McFarland - 601HDS Stratus ________________________________________________________________________________
Subject: Stratus Water Pump
Date: Feb 09, 2005
Hi Gang, It's been to quite on the list lately so apparently my Stratus thought we needed some discussion. Just the other day I flew my HD for the first time in a month and a half (winters up north tend to make one do that). Anyway about 15 minutes into my flight I caught a distinctive smell of coolant .... rats never smelled that before. I was hoping to land and find a loose rad hose but no such luck. The lower firewall on my 601 was wet with coolant but no leaks were found. I'm thinking it's my water pump as everything below it seems to be getting wet. Could this be just a bad gasket, or seal? Or must we caulk up one more "watch out" item to our got-cha list. If the water pump needs replacing is it as simple as ripping off the old and bolting on the new, or is there more to it than that? Thanks for any advice. Kelly Meiste 601 HD (114 hours) ________________________________________________________________________________
Date: Feb 09, 2005
It probaly IS the water pump....get down below the engine with the cowl off...the weep hole will be on the underside of the pump in the alu shaft housing between the pump istelf and the steel pulley...The hole is where the coolant comes out. Now there are two types of pump and rumour has it that the type with the pressed steel rotor will cavitate which causes overheating and eventual destruction of the pump rotor. Apparently this is supposed to happen above 5000rpm...Mine climbs out at 4900 RPM and is just fine with the pressed steel rotor...Having a good pressure cap is a must! So pull your pump off...very simple, and you will probably have the Cast iron rotor which is a lower pumping capacity..See if your local autoparts place has this type...take it with you! If you go to Autozone they offer a lifetime guarantee as long as its not for off road use....well we are above roads most of the time...:) Good luck Frank Hi Gang, It's been to quite on the list lately so apparently my Stratus thought we needed some discussion. Just the other day I flew my HD for the first time in a month and a half (winters up north tend to make one do that). Anyway about 15 minutes into my flight I caught a distinctive smell of coolant .... rats never smelled that before. I was hoping to land and find a loose rad hose but no such luck. The lower firewall on my 601 was wet with coolant but no leaks were found. I'm thinking it's my water pump as everything below it seems to be getting wet. Could this be just a bad gasket, or seal? Or must we caulk up one more "watch out" item to our got-cha list. If the water pump needs replacing is it as simple as ripping off the old and bolting on the new, or is there more to it than that? Thanks for any advice. Kelly Meiste 601 HD (114 hours) ________________________________________________________________________________
Subject: Re: Stratus Water Pump
Date: Feb 10, 2005
Kelly, I have not had any trouble with my water pump leaking. There are a few of us with a good amount of hours on the Stratus now and I have not heard of any problems with the pump so I don't think it is an expected failure like the engine mount, alternator mount, valve guides, etc., were. As Frank said, look at the weep hole at the bottom. That's where the fluid will come out if the seal is failing. Should be an easy replacement if it is the pump. Regards, Bill ________________________________________________________________________________
Date: Feb 10, 2005
> > As Frank said, look at the weep hole at the bottom. That's where the fluid > will come out if the seal is failing. > > Should be an easy replacement if it is the pump. > > Regards, > Bill ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Hi Bill, I used a mirror & checked the weep hole that Frank suggested me to look at. Sure enough I can see were fluid had been running out of this hole by a dark colored line from the hole & down the side of the casting. What is the purpose of this "weep hole" anyway? Is it just an indicator to let you know the pump seal has failed? How about if I just shove my chewing gum into the hole & go fly? Sorry I couldn't help think that (I'm an X ultralight pilot). Also why would these pumps fail after only 100 hours in a plane, & yet in cars they'll go for 100,000 miles, is it because we run them at higher RPM's? Thanks Frank & Bill for your the input, Kelly ________________________________________________________________________________
Date: Feb 10, 2005
The weep hole is there to keep the coolant from contaminating the bearings after the seal fails and leaks. Do not plug it, as then the coolant will fail the bearing. REPLACE the pump. Cy Galley - Chair, AirVenture Emergency Aircraft Repair A Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot ----- Original Message ----- From: "Kelly Meiste" <kellymeiste(at)jcwifi.com> Subject: Re: Stratus-List: Stratus Water Pump > > > > > As Frank said, look at the weep hole at the bottom. That's where the fluid > > will come out if the seal is failing. > > > > Should be an easy replacement if it is the pump. > > > > Regards, > > Bill > > ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ > > Hi Bill, > I used a mirror & checked the weep hole that Frank suggested me to look at. > Sure enough I can see were fluid had been running out of this hole by a dark > colored line from the hole & down the side of the casting. > > What is the purpose of this "weep hole" anyway? Is it just an indicator to > let you know the pump seal has failed? How about if I just shove my chewing > gum into the hole & go fly? > Sorry I couldn't help think that (I'm an X ultralight pilot). > > Also why would these pumps fail after only 100 hours in a plane, & yet in > cars they'll go for 100,000 miles, is it because we run them at higher > RPM's? > Thanks Frank & Bill for your the input, > > Kelly > > ________________________________________________________________________________
Date: Feb 11, 2005
Kelly, I'm not sure why yours failed at only 100 hours. I have not heard of any Stratus water pump failures to date. I would not think that is s the high rpm since I have 386 hours and have not had a problem to date. Bill Bill Morelli billvt(at)together.net ________________________________________________________________________________
Subject: Prop Pitch Optimums?
Date: Feb 23, 2005
Hi guys, Has anyone continued to use a 17" or longer pitch on a Stratus with a 70" warp drive? I've been using 16" and it accelerates about twice the rate of the Cessna I used to fly. I'm interested in knowing if the coming summer and humidity is going to push me back into a 16" pitch. Larry McFarland - 601HDS ________________________________________________________________________________
Subject: Re: Prop Pitch Optimums?
Date: Feb 23, 2005
Has anyone continued to use a 17" or longer pitch on a Stratus with a 70" warp drive? +++++++++++++++++++++++++++++++++++++++++++++++++++++++ Larry, I'll have do look back thru my records of saved info about prop setting for our engines (from past postings), but if I recall correctly I've seen at least two Stratus 601 pilots who have gone as far as 17 pitch, but eventually both backed off to somewhere around 15 pitch. I'll do some digging to see if I can verify that for you. Kelly (16 pitch) ________________________________________________________________________________
Subject: Coolant
Date: Feb 23, 2005
Howdy List, Remember last week I asked about my water pump failing after only 100 hours on the clock. Well I started wondering if my newly added Dex-Cool (red colored) coolant had anything to do with my pump failing. I have been running the green Prestone coolant for the first 100 hours, then I drained and flushed my coolant system and changed over to the red colored Dex-Cool, and only a month or two later (about 10 hours) my pump failed???? Thinking that was odd I contacted Mykal and asked him if Dex-Cool would cause problems with our EA-81 engines (water pumps). He simply said "he didn't think so". But now I'm not so sure ...... I just came across this today. http://www.girardgibbs.com/dexcool.html It's a class action lawsuit against Dex-cool. Here's the jest of it. Girard Gibbs & De Bartolomeo is investigating claims in connection with a proposed class action against General Motors Corporation and Chevron/Texaco Corporation concerning DEX-COOL. Customers complain that DEX-COOL forms a sludge-like substance that clogs their vehicles' cooling systems causing them to overheat, and that DEX-COOL corrodes all parts of the engine it comes in contact with including the heater core, water pump, hoses, cap, upper and lower intake manifold, thermostat, and engine block. Any one else out there running this stuff in your engine, & if so have you noticed any problems? Kelly ________________________________________________________________________________
Date: Feb 23, 2005
Subject: Re: Coolant
I have to say that is Mykal's answer to a few questions both from my experience and those of the people on this board. "I dont think so" or "it should be ok" seem to be his most oft used phrases. Not 100% confidence inspring for me anyway. Cheers Brett Quoting Kelly Meiste : > > Howdy List, > Remember last week I asked about my water pump failing after only 100 hours > on the clock. Well I started wondering if my newly added Dex-Cool (red > colored) coolant had anything to do with my pump failing. I have been running > the green Prestone coolant for the first 100 hours, then I drained and > flushed my coolant system and changed over to the red colored Dex-Cool, and > only a month or two later (about 10 hours) my pump failed???? > > Thinking that was odd I contacted Mykal and asked him if Dex-Cool would cause > problems with our EA-81 engines (water pumps). He simply said "he didn't > think so". > But now I'm not so sure ...... I just came across this today. > > http://www.girardgibbs.com/dexcool.html > > It's a class action lawsuit against Dex-cool. Here's the jest of it. > > Girard Gibbs & De Bartolomeo is investigating claims in connection with a > proposed class action against General Motors Corporation and Chevron/Texaco > Corporation concerning DEX-COOL. > > > Customers complain that DEX-COOL forms a sludge-like substance that clogs > their vehicles' cooling systems causing them to overheat, and that DEX-COOL > corrodes all parts of the engine it comes in contact with including the > heater core, water pump, hoses, cap, upper and lower intake manifold, > thermostat, and engine block. > > Any one else out there running this stuff in your engine, & if so have you > noticed any problems? > > Kelly > > > > > > > Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Mar 02, 2005
Subject: pictures of cracked alternator bracket
Hi guys. I am replacing my cracked alternator bracket on the stratus EA81. I whipped up a quick website to show you all the pics and it has some questions there as well. Hope you can help. http://www3.telus.net/public/rueffy/ Cheerio Brett Vancouver Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Mar 04, 2005
Bret, The original alternator brackets were made from a thinner material than later ones. I don't recall how thin the material was on the originals but the current brackets are made from .185" thick material. I would first check to see if you had the .185" bracket. I purchased my engine in 1998 and the alternator bracket was painted blue. Did yours come unpainted as shown in your photos. To answer some of your questions. - The small hose you mention and it's location are normal. I zip tied a piece of tygon tubing on that hose to prevent chafing where it rubs against the alt mounting bolt. - The three leveling washers sound normal also. Mine came from Stratus that way. - I have not seen any oil seepage from around the bolt you describe. I had replaced my original thin alternator bracket re welded before Stratus had sent me the newer .185" version. The re welded bracket cracked again!! After installing the new thick bracket at 168 hours, I have not had any problems and now have 389 hours. I have not heard of any problems with the thick bracket. You can check out my web site (address below) to see the write up and photos I posted back when my bracket failed. Hope this helps Regards, Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 389.4 flight hrs. - 519 landings web site -> http://homepages.together.net/~billvt/ >Hi guys. > I am replacing my cracked alternator bracket on the stratus EA81. I whipped up > a quick website to show you all the pics and it has some questions there as > well. Hope you can help. > > http://www3.telus.net/public/rueffy/ > > Cheerio > Brett > Vancouver ________________________________________________________________________________
Date: Mar 12, 2005
Hi Bill, Just back from my trip and I am not sure if I responded to your email - but thanks for the info. Much appreciated Brett Quoting Bill Morelli : > > Bret, > > The original alternator brackets were made from a thinner material than later > ones. I don't recall how thin the material was on the originals but the > current brackets are made from .185" thick material. I would first check to > see if you had the .185" bracket. > > I purchased my engine in 1998 and the alternator bracket was painted blue. > Did yours come unpainted as shown in your photos. > > To answer some of your questions. > > - The small hose you mention and it's location are normal. I zip tied a piece > of tygon tubing on that hose to prevent chafing where it rubs against the alt > mounting bolt. > > - The three leveling washers sound normal also. Mine came from Stratus that > way. > > - I have not seen any oil seepage from around the bolt you describe. > > I had replaced my original thin alternator bracket re welded before Stratus > had sent me the newer .185" version. The re welded bracket cracked again!! > After installing the new thick bracket at 168 hours, I have not had any > problems and now have 389 hours. I have not heard of any problems with the > thick bracket. > > You can check out my web site (address below) to see the write up and photos > I posted back when my bracket failed. > > Hope this helps > > Regards, > Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 389.4 > flight hrs. - 519 landings > web site -> http://homepages.together.net/~billvt/ > > > >Hi guys. > > > I am replacing my cracked alternator bracket on the stratus EA81. I > whipped up > > a quick website to show you all the pics and it has some questions > there as > > well. Hope you can help. > > > > http://www3.telus.net/public/rueffy/ > > > > Cheerio > > Brett > > Vancouver > > > > > > > > Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Mar 15, 2005
Subject: stories and questions.
Hi Stratus Goers. Well - after 3 months of odds and ends work on the plane without flying it over the winter I finally made the final (what I thought were final) repairs and went flying this arvo. Was great to be back in the air again. I bought the two place float plane with a stratus EA81 a year ago and have been putting a lot of work in for not much flying....time to start reaping the rewards now. For those interested here is what I have done: 1. Replaced PRSU cog belt 2. Replaced cracked (maybe smashed is a better word) alternator bracket. 3. Re-routed that breather hose that ran under the alternator and was beign destroyed. 4. Replaced two heater hoses and replaced fluid. 5. Compression test and other engine tests 6. Installed new battery 7. Rewired Aileron control system to remove some control cable rub. 8. Installed turnbuckles in all aileron and rudder systems (boy are those turnbuckles expensive!) 9. Repaired a leaky float 10. Repaired a broken Airspeed indicator (neat to look inside) 11. bought a new radio 12. Installed drain grommets (still more to go however) 13. Repaired a mount for elevator push pull tube 14. Few other bits and peices that slip my mind now. Anyway the test flight went well and all was normal. Oil and Water were very tight - no leaks visible at all. I had a some fluctation on the fuel pressure but I knew the number one fuel pump is on its last legs. I shall replace it before the next flight and replace the filters while I am at it. After the flight I noticed a little weaping from the PRSU behind the flywheel. Not much, just a small area and the fuild had the slighest of green shades to it. Is that what people are refering to when they say the main PRSU bearing is weeping a little? The engine only has about 50 hours before I am supposed to re-grease the bearings as per the 300 hour stratus schedule. Cheerio brett Vancouver, Canada Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Mar 16, 2005
Subject: Re: stories and questions.
Brett, If you've got a weeping oil situation behind the flywheel, the large seal may need replacing it which is a National #415021 and regreasing its contact surfaces with white lithium grease. If you begin finding a film of oil in the end of the lower pully and crank shaft end, you'll need to get after it agressively because I found it can really increase output in a hurry. Mykal doesn't use a seal, but an o-ring that's sort of placed there. I removed it and cleaned the material behind it to dry metal and then used heavy RTV before replacing the o-ring and then buried it again in RTV sealant. Very dry now much later. I was emailed a 3-page instruction sheet on replacing the redrive bearings and front and rear engine seals by one of the posters in this group and I'd be willing to copy-forward these zip files if they'd be of help to you. Lots of pictures too. Larry McFarland rueffy(at)jetthrust.com wrote: > > Is that what people are refering to when they say the main PRSU bearing is >weeping a little? > >Cheerio >brett >Vancouver, Canada > > > > ________________________________________________________________________________
Date: Mar 16, 2005
Have the heads had the stepped valve guides installed by Ram Performance?...Stratus motors have had a number of valve guide failures which can easily trash your engine completely...Or worse. If you have not had this done I would say this is the best $600 you could spend on that airplane. Ram Performance is the only company I would trust with this work. Once they have done it it will be pretty much bullet proof. Do you have two ignition systems fitted to the engine? When one of them dies a much better system is to use the Subaru puckup coil to drive a $25 GM ignitor chip...I have two ignitions built into the same distributor...Much better than the $300 you will pay for the original style ignitor chip...:) As to the bearing, the seal wears a groove in the anodised spacer and it ends up leaking...I changed the seal and moved it outboard a little to wear a new groove....Works great so far. Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of rueffy(at)jetthrust.com Subject: Stratus-List: stories and questions. Hi Stratus Goers. Well - after 3 months of odds and ends work on the plane without flying it over the winter I finally made the final (what I thought were final) repairs and went flying this arvo. Was great to be back in the air again. I bought the two place float plane with a stratus EA81 a year ago and have been putting a lot of work in for not much flying....time to start reaping the rewards now. For those interested here is what I have done: 1. Replaced PRSU cog belt 2. Replaced cracked (maybe smashed is a better word) alternator bracket. 3. Re-routed that breather hose that ran under the alternator and was beign destroyed. 4. Replaced two heater hoses and replaced fluid. 5. Compression test and other engine tests 6. Installed new battery 7. Rewired Aileron control system to remove some control cable rub. 8. Installed turnbuckles in all aileron and rudder systems (boy are those turnbuckles expensive!) 9. Repaired a leaky float 10. Repaired a broken Airspeed indicator (neat to look inside) 11. bought a new radio 12. Installed drain grommets (still more to go however) 13. Repaired a mount for elevator push pull tube 14. Few other bits and peices that slip my mind now. Anyway the test flight went well and all was normal. Oil and Water were very tight - no leaks visible at all. I had a some fluctation on the fuel pressure but I knew the number one fuel pump is on its last legs. I shall replace it before the next flight and replace the filters while I am at it. After the flight I noticed a little weaping from the PRSU behind the flywheel. Not much, just a small area and the fuild had the slighest of green shades to it. Is that what people are refering to when they say the main PRSU bearing is weeping a little? The engine only has about 50 hours before I am supposed to re-grease the bearings as per the 300 hour stratus schedule. Cheerio brett Vancouver, Canada Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Mar 16, 2005
Thanks Frank, The heads were re-done by the original owner. I know of 3 stratus engines in this area - all had self distructing heads, one did it after only 4 hours. It wasnt RAM that was used, but the heads were definately redone. It does have two ignitions as well. Standard stratus one and a nipondenso one. I kind of think this is a bit of a gimick though - you have two ignitions but only one key switch, one set of leads, one distributor. Where did you get the new seal from? Thanks for your comments. Brett Quoting "Hinde, Frank George (Corvallis)" : > > > Have the heads had the stepped valve guides installed by Ram > Performance?...Stratus motors have had a number of valve guide failures > which can easily trash your engine completely...Or worse. > > If you have not had this done I would say this is the best $600 you > could spend on that airplane. > > Ram Performance is the only company I would trust with this work. Once > they have done it it will be pretty much bullet proof. > > Do you have two ignition systems fitted to the engine? When one of them > dies a much better system is to use the Subaru puckup coil to drive a > $25 GM ignitor chip...I have two ignitions built into the same > distributor...Much better than the $300 you will pay for the original > style ignitor chip...:) > > As to the bearing, the seal wears a groove in the anodised spacer and it > ends up leaking...I changed the seal and moved it outboard a little to > wear a new groove....Works great so far. > > Frank > > -----Original Message----- > From: owner-stratus-list-server(at)matronics.com > [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of > rueffy(at)jetthrust.com > To: stratus-list(at)matronics.com > Subject: Stratus-List: stories and questions. > > > Hi Stratus Goers. > > Well - after 3 months of odds and ends work on the plane without flying > it over the winter I finally made the final (what I thought were final) > repairs and went flying this arvo. Was great to be back in the air > again. I bought the two place float plane with a stratus EA81 a year > ago and have been putting a lot of work in for not much flying....time > to start reaping the rewards now. > For those interested here is what I have done: > > 1. Replaced PRSU cog belt > 2. Replaced cracked (maybe smashed is a better word) alternator bracket. > 3. Re-routed that breather hose that ran under the alternator and was > beign destroyed. > 4. Replaced two heater hoses and replaced fluid. > 5. Compression test and other engine tests 6. Installed new battery 7. > Rewired Aileron control system to remove some control cable rub. > 8. Installed turnbuckles in all aileron and rudder systems (boy are > those turnbuckles expensive!) 9. Repaired a leaky float 10. Repaired a > broken Airspeed indicator (neat to look inside) 11. bought a new radio > 12. Installed drain grommets (still more to go however) 13. Repaired a > mount for elevator push pull tube 14. Few other bits and peices that > slip my mind now. > > Anyway the test flight went well and all was normal. Oil and Water were > very tight - no leaks visible at all. I had a some fluctation on the > fuel pressure but I knew the number one fuel pump is on its last legs. > I shall replace it before the next flight and replace the filters while > I am at it. > > After the flight I noticed a little weaping from the PRSU behind the > flywheel. > Not much, just a small area and the fuild had the slighest of green > shades to it. Is that what people are refering to when they say the > main PRSU bearing is weeping a little? The engine only has about 50 > hours before I am supposed to re-grease the bearings as per the 300 hour > stratus schedule. > > Cheerio > brett > Vancouver, Canada > > > Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot > Network http://www.jetthrust.com > > > Please report IMMEDIATELY any abuse/spam or scams of our webmail system > to the webmaster of this website at the following address: > webmaster(at)jetthrust.com > > > > > > > Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Mar 16, 2005
Seal you can get from Stratus but it is a common seal...I think I still have the box in the hangar so you could probably get it from just about any bearing supplier. Just have to wait till I go down the hangar to get the number...they are about 25 bucks. You say the heads were "re done". What exactly does that mean?....Subarus use parallel valve guides that the rebuilders choose to press in at room temperature. They have no step on the outside and if they work loose they slip into the combustion chamber till they hit the tapered part of the valve where chunks get broken off...Hence the self destruct. This fitting method is crap! Valve guides should be made 2 thou oversize and the head heated and the guide frozen before they are put together. They should also have a step on the outside (Stratus now use a circlip and that fails too!). As the guides do not have a step this shrink fit method is crucial to get right...Of course its only been done this way for the last 100 years so why the soob rebuilders think they can get away with room temperature fit is beyond me. But anyway, it is important to know what the previous owner did because if he simply replicated what was there in the first place that is not good enough IMO. Ram Performance is the only company as far as I know that will make a new set of guides with steps on the outside and shrink fit them properly. I would strongly advise you to get what procedure he used. At the minimum this needs to be a shrunk fit guide, no loctite and definatly no knurling of the outside of the guide to bring it up to size. I've had three failures and have become an expert on this issue...Sadly! Your ignition set up is not adequate. You have many single points of failure there. I have 2 batteries (isolated with a diode) and a separate switch for each ignition system....There is no point on the low tension side of the the ignitions systems that join together at any point. This second battery (3AH only weighs 2 pounds) system also runs the second fuel pump....I can have an alternator/battery fire/short out and can continue to run the engine for an hour or so. If your igniton switch burns out down you go! The distributor is a single point of failre but they rarely fail...The low tension wiring is a different matter though. Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of rueffy(at)jetthrust.com Subject: RE: Stratus-List: stories and questions. Thanks Frank, The heads were re-done by the original owner. I know of 3 stratus engines in this area - all had self distructing heads, one did it after only 4 hours. It wasnt RAM that was used, but the heads were definately redone. It does have two ignitions as well. Standard stratus one and a nipondenso one. I kind of think this is a bit of a gimick though - you have two ignitions but only one key switch, one set of leads, one distributor. Where did you get the new seal from? Thanks for your comments. Brett Quoting "Hinde, Frank George (Corvallis)" : > > > Have the heads had the stepped valve guides installed by Ram > Performance?...Stratus motors have had a number of valve guide > failures which can easily trash your engine completely...Or worse. > > If you have not had this done I would say this is the best $600 you > could spend on that airplane. > > Ram Performance is the only company I would trust with this work. Once > they have done it it will be pretty much bullet proof. > > Do you have two ignition systems fitted to the engine? When one of > them dies a much better system is to use the Subaru puckup coil to > drive a > $25 GM ignitor chip...I have two ignitions built into the same > distributor...Much better than the $300 you will pay for the original > style ignitor chip...:) > > As to the bearing, the seal wears a groove in the anodised spacer and > it ends up leaking...I changed the seal and moved it outboard a little > to wear a new groove....Works great so far. > > Frank > > -----Original Message----- > From: owner-stratus-list-server(at)matronics.com > [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of > rueffy(at)jetthrust.com > To: stratus-list(at)matronics.com > Subject: Stratus-List: stories and questions. > > > Hi Stratus Goers. > > Well - after 3 months of odds and ends work on the plane without > flying it over the winter I finally made the final (what I thought > were final) repairs and went flying this arvo. Was great to be back > in the air again. I bought the two place float plane with a stratus > EA81 a year ago and have been putting a lot of work in for not much > flying....time to start reaping the rewards now. > For those interested here is what I have done: > > 1. Replaced PRSU cog belt > 2. Replaced cracked (maybe smashed is a better word) alternator bracket. > 3. Re-routed that breather hose that ran under the alternator and was > beign destroyed. > 4. Replaced two heater hoses and replaced fluid. > 5. Compression test and other engine tests 6. Installed new battery 7. > Rewired Aileron control system to remove some control cable rub. > 8. Installed turnbuckles in all aileron and rudder systems (boy are > those turnbuckles expensive!) 9. Repaired a leaky float 10. Repaired a > broken Airspeed indicator (neat to look inside) 11. bought a new radio > 12. Installed drain grommets (still more to go however) 13. Repaired a > mount for elevator push pull tube 14. Few other bits and peices that > slip my mind now. > > Anyway the test flight went well and all was normal. Oil and Water > were very tight - no leaks visible at all. I had a some fluctation on > the fuel pressure but I knew the number one fuel pump is on its last legs. > I shall replace it before the next flight and replace the filters > while I am at it. > > After the flight I noticed a little weaping from the PRSU behind the > flywheel. > Not much, just a small area and the fuild had the slighest of green > shades to it. Is that what people are refering to when they say the > main PRSU bearing is weeping a little? The engine only has about 50 > hours before I am supposed to re-grease the bearings as per the 300 > hour stratus schedule. > > Cheerio > brett > Vancouver, Canada > > > Pilots!-For all your aviation resources visit Jet Thrust.com- The > Pilot Network http://www.jetthrust.com > > > Please report IMMEDIATELY any abuse/spam or scams of our webmail > system to the webmaster of this website at the following address: > webmaster(at)jetthrust.com > > > > > > > Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Mar 16, 2005
> It does have two ignitions as well. Standard stratus one and a nipondenso > one. > I kind of think this is a bit of a gimick though - you have two ignitions > but > only one key switch, one set of leads, one distributor. the dual ignitions have saved a few people anyway, seems to be the coils and modules that go. to take full advantage though, I think it's best to have separate switches and a small backup battery. make as much redundant as possible. then just do good maintenance on the distr, wires and plugs. what's the empty/gross on your plane and how does it perform on floats? i'd like to get floats someday and i'm not sure the stratus will have enough juice. gary ________________________________________________________________________________
Date: Mar 16, 2005
I think the gross is about 1300lbs (haven't weight it myself - going off old info that I am not totally confident in). Its on Murphy home built 1500 floats and the stratus blasts off the water no worries. We did some rough calculations, and the power to weight is at the high end for float planes considering I very rarely take off at gross. For a light plane like mine it is more than adequate. In fact 100hp is about the limit for the airframe in my opinion. Thanks to Frank and Larry, your points are duly noted. Picture of the plane is attached, Brett Quoting gary : > > > It does have two ignitions as well. Standard stratus one and a nipondenso > > > one. > > I kind of think this is a bit of a gimick though - you have two ignitions > > but > > only one key switch, one set of leads, one distributor. > the dual ignitions have saved a few people anyway, seems to be the coils and > > modules that go. to take full advantage though, I think it's best to have > separate switches and a small backup battery. make as much redundant as > possible. then just do good maintenance on the distr, wires and plugs. > > what's the empty/gross on your plane and how does it perform on floats? i'd > > like to get floats someday and i'm not sure the stratus will have enough > juice. > > gary > > > > > > > Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Mar 17, 2005
I have those seals in stock $12 Ron RAM Performance ________________________________________________________________________________
Date: Mar 19, 2005
Subject: Repost from AirSoob
The following was posted on Airsoob a couple of days ago. I wanted to repost it here for all our interest since many of us are running the EA81. I haven't heard of this happening before - has anybody else? What do you think of the fix? Brett Last week I had the oil seal, on the water pump end of the engine, of my EA81 slip inside of the engine. It took about 3 or 4 minutes to lose all the oil. Luckily I was on floats and was able to make it back on the water just as the oil pressure dropped to zero. This seal is a press fit in the crankcase, there is no lip on the inside of the case to keep this from happening. I know of one other EA 81 that had this same thing happen. Anyone else had this problem? Is there a fix? I installed the new seal with Permatex high strength sleeve retainer. Any ideas or help would be appreciated. Dale Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Mar 24, 2005
stratus-list
Subject: Purolator Fuel Filter Warning
Hi guys, Very recently, I referred to a search for a Purolator "See Through" Fuel Filter in a posting. This filter was eventually located and found to be a *Purolator Pro-Fuel Filter*. In the Google perusal of articles on this filter, I found that *there is a recall of this filter series* because the polylmer used for the housing in the suspect fuel filters may not be compatible with ethanol and other chemicals sometimes found in fuel systems. If the housing leaks, you could have a fire. In another listed instance, an aircraft builder's filter leaked and it was on negative pressure, sucked air and his engine quit on takeoff due to fuel starvation. Subsequent replacement of this item was found to be difficult as the replacement product was re-marked as Made in USA and it was obviously made in Taiwan. The latter didn't even exhibit the necessary quality found on the failed original filter made in the US. So much for the Purolator Company and their filters. I didn't want to have misled anyone into using this filter on their plane just because the basic concept embodied what I'd like to have found in one.......... Pleased to have found this, but immensely disappointed that the trend of once good products are disappearing and being re-mfg as similiar, but inferior items from offshore that could get you killed. Please be aware and *do not use the Purolator Part Numbers 804, 805, 806 and NAPA 624804, 624805 and 624806 part numbers*. Now I've got to find something else with a see-thru stainless filter that works. Arrrgh! Larry McFarland - 601HDS - Stratus ________________________________________________________________________________
Date: Mar 26, 2005
Hey Soobers. Im scrating my head and not coming up with much (which is not unusual for me). I have a 72" 3 blade warp drive on the EA81. When I take the end of the prop blade, and wiggle gently from side to side I can get a tiny bit of play (were are talking very very small barely noticable amount at the hub somewhere) It has been bugging me for ages exactly where the play was. I thought it was in a particular blade but then I tried something - if I place one hand behind the prop hub and pull so the hub is firmly supported and then wiggle - there is no play. So now I am thinking it might be a tiny bit play somewhere else that is transfering though the hub and blade. Would it be possible that the tiny movement I am feeling is coming from in the PRSU where the prop shaft fits in its sleeve? I haven't had this PRSU apart yet so I am not sure of the exact deisgn and tolerances. That would make more sense because I have inspected the prop very carefully and cant find signs of wear. The engine is coming up to 300 hours soon and is due for the bearing re-grease. I emailed Warp Drive and asked and they said no movement is allowed (between blade and hub). Ideas? Brett Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Mar 26, 2005
Brett, I believe Warp Drive means no movement between the composite and the clamping hub, but the take-up you feel at the redrive shaft could be nothing more than bearings setting cool within the housing. I'd bet you would find that when they are warm, and you know they do get "warm", the tolerences change as they cool, or perhaps the redrive housing has broken in a bit. I'd get a dial indicator on the hub and measure the exactitude of the play you find both diametral and axial. If you do that, I'll do the same and we might learn what or how much "play" is normal. Question though. How do you like the 72" on the Stratus? I'm using a 70" and would think you'd be getting a really good climb or cruise with yours. Larry McFarland rueffy(at)jetthrust.com wrote: > >Hey Soobers. Im scrating my head and not coming up with much (which is not >unusual for me). I have a 72" 3 blade warp drive on the EA81. When I take the >end of the prop blade, and wiggle gently from side to side I can get a tiny bit >of play (were are talking very very small barely noticable amount at the hub >somewhere) It has been bugging me for ages exactly where the play was. I >thought it was in a particular blade but then I tried something - if I place >one hand behind the prop hub and pull so the hub is firmly supported and then >wiggle - there is no play. So now I am thinking it might be a tiny bit play >somewhere else that is transfering though the hub and blade. Would it be >possible that the tiny movement I am feeling is coming from in the PRSU where >the prop shaft fits in its sleeve? I haven't had this PRSU apart yet so I am >not sure of the exact deisgn and tolerances. That would make more sense >because I have inspected the prop very carefully and cant find signs of wear. >The engine is coming up to 300 hours soon and is due for the bearing re-grease. > > >I emailed Warp Drive and asked and they said no movement is allowed (between >blade and hub). > >Ideas? >Brett > > > > ________________________________________________________________________________
Date: Mar 26, 2005
Thanks Larry, I will do that but I will need to borrow the tool so it might take a couple of weeks for me to get around to it and take the measurements. I haven't thought to try it when hot, so I might warm up the engine and see if the same thing happens. I have to change the oil seal next week so I will have the prop off then and while I have the prop off I will see if I can feel the play between the blade and clamping hub. I agree with your definition of "no play" that warp drive were getting at - that was what I meant but it may have been poorly worded. It has been difficult to gauge and find the play because its only some blades, in certain positions where I can feel it. Normally I just feel blade flex but if I get it just right I can feel ever so slightly the unmistakable click click feel as you move side to side and feel contact. Warp Drive said do not fly until resolved, but they were refering to movement between the composite and clamping hub, which I dont think I have, he seemed to think it may have been a previous prop strike, but that is impossible - its only ever been on this float plane. As for the performance question - I find it great. Solo I can get 1500ft/min which is great considering I am dragging 1500 floats into the air. Two people is about 1000ft/min at 5250 which is as high as I have the engine set to Rev. The blades are at 10 deg and cruise is about 85-90mph. Also a question about the seal behind the flywheel. I think it was you larry who wrote the guide that I have with the pictures. People have been using RTV sealant when putting it in. My soob workshop manual says lithium grease on the inside against the crack, and clean engine oil on the outside against the housing. If you are using RTV sealant are you still using the oil - exaclty where are you putting the RTV sealant? I have never used the stuff so I am not totally sure how, why or where to apply it or what purpose it serves. Cheerio Brett Quoting Larry McFarland : > > Brett, > I believe Warp Drive means no movement between the composite and the > clamping hub, but the take-up > you feel at the redrive shaft could be nothing more than bearings > setting cool within the housing. I'd bet you > would find that when they are warm, and you know they do get "warm", the > tolerences change as they cool, or > perhaps the redrive housing has broken in a bit. I'd get a dial > indicator on the hub and measure the exactitude > of the play you find both diametral and axial. If you do that, I'll do > the same and we might learn what or how > much "play" is normal. > > Question though. How do you like the 72" on the Stratus? I'm using a > 70" and would think you'd be getting a > really good climb or cruise with yours. > > Larry McFarland > > > rueffy(at)jetthrust.com wrote: > > > > >Hey Soobers. Im scrating my head and not coming up with much (which is not > >unusual for me). I have a 72" 3 blade warp drive on the EA81. When I take > the > >end of the prop blade, and wiggle gently from side to side I can get a tiny > bit > >of play (were are talking very very small barely noticable amount at the > hub > >somewhere) It has been bugging me for ages exactly where the play was. I > >thought it was in a particular blade but then I tried something - if I > place > >one hand behind the prop hub and pull so the hub is firmly supported and > then > >wiggle - there is no play. So now I am thinking it might be a tiny bit > play > >somewhere else that is transfering though the hub and blade. Would it be > >possible that the tiny movement I am feeling is coming from in the PRSU > where > >the prop shaft fits in its sleeve? I haven't had this PRSU apart yet so I > am > >not sure of the exact deisgn and tolerances. That would make more sense > >because I have inspected the prop very carefully and cant find signs of > wear. > >The engine is coming up to 300 hours soon and is due for the bearing > re-grease. > > > > > >I emailed Warp Drive and asked and they said no movement is allowed > (between > >blade and hub). > > > >Ideas? > >Brett > > > > > > > > > > > > > > > Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Mar 26, 2005
Brett, When you say click-click on only certain positions, I'd have to bet you're feeling the rolling clearance within the bearings of your redrive. With a little time, this could be expected when the hours say you're near replacing them. Two bearings in tandem on a shaft would probably do exactly what you describe at certain positions and have a nearly imperceptible amount of slop on the thrust line. On the small diameter o-ring seal seen inside the lower belt pully at the crank end, I used RTV sealant behind it first, then added RTV to the o-ring and packed it into place, because there is no relative motion on this o-ring seal. The large diameter seal is pressed in place and white lithium grease is added to the front face to keep it from abraiding. I didn't write the instructions, or take the pictures, but I recieved them from *Bill Morelli who did the hard work *before forwarding them on to people like us. I've not had to remove my redrive bearings yet with only 55 hours, but I do have spare sets of bearings, seals etc standing by in my "consumables & spares" box. Larry rueffy(at)jetthrust.com wrote: > >Thanks Larry, > >I will do that but I will need to borrow the tool so it might take a couple of >weeks for me to get around to it and take the measurements. I haven't thought >to try it when hot, so I might warm up the engine and see if the same thing >happens. > >I have to change the oil seal next week so I will have the prop off then and >while I have the prop off I will see if I can feel the play between the blade >and clamping hub. I agree with your definition of "no play" that warp drive >were getting at - that was what I meant but it may have been poorly worded. It >has been difficult to gauge and find the play because its only some blades, in >certain positions where I can feel it. Normally I just feel blade flex but if >I get it just right I can feel ever so slightly the unmistakable click click >feel as you move side to side and feel contact. Warp Drive said do not fly >until resolved, but they were refering to movement between the composite and >clamping hub, which I dont think I have, he seemed to think it may have been a >previous prop strike, but that is impossible - its only ever been on this float >plane. > >As for the performance question - I find it great. Solo I can get 1500ft/min >which is great considering I am dragging 1500 floats into the air. Two people >is about 1000ft/min at 5250 which is as high as I have the engine set to Rev. >The blades are at 10 deg and cruise is about 85-90mph. > >Also a question about the seal behind the flywheel. I think it was you larry >who wrote the guide that I have with the pictures. People have been using RTV >sealant when putting it in. My soob workshop manual says lithium grease on the >inside against the crack, and clean engine oil on the outside against the >housing. If you are using RTV sealant are you still using the oil - exaclty >where are you putting the RTV sealant? I have never used the stuff so I am not >totally sure how, why or where to apply it or what purpose it serves. > > >Cheerio >Brett > >Quoting Larry McFarland : > > > >> >>Brett, >>I believe Warp Drive means no movement between the composite and the >>clamping hub, but the take-up >>you feel at the redrive shaft could be nothing more than bearings >>setting cool within the housing. I'd bet you >>would find that when they are warm, and you know they do get "warm", the >>tolerences change as they cool, or >>perhaps the redrive housing has broken in a bit. I'd get a dial >>indicator on the hub and measure the exactitude >>of the play you find both diametral and axial. If you do that, I'll do >>the same and we might learn what or how >>much "play" is normal. >> >>Question though. How do you like the 72" on the Stratus? I'm using a >>70" and would think you'd be getting a >>really good climb or cruise with yours. >> >>Larry McFarland >> >> >>rueffy(at)jetthrust.com wrote: >> >> >> >>> >>>Hey Soobers. Im scrating my head and not coming up with much (which is not >>>unusual for me). I have a 72" 3 blade warp drive on the EA81. When I take >>> >>> >>the >> >> >>>end of the prop blade, and wiggle gently from side to side I can get a tiny >>> >>> >>bit >> >> >>>of play (were are talking very very small barely noticable amount at the >>> >>> >>hub >> >> >>>somewhere) It has been bugging me for ages exactly where the play was. I >>>thought it was in a particular blade but then I tried something - if I >>> >>> >>place >> >> >>>one hand behind the prop hub and pull so the hub is firmly supported and >>> >>> >>then >> >> >>>wiggle - there is no play. So now I am thinking it might be a tiny bit >>> >>> >>play >> >> >>>somewhere else that is transfering though the hub and blade. Would it be >>>possible that the tiny movement I am feeling is coming from in the PRSU >>> >>> >>where >> >> >>>the prop shaft fits in its sleeve? I haven't had this PRSU apart yet so I >>> >>> >>am >> >> >>>not sure of the exact deisgn and tolerances. That would make more sense >>>because I have inspected the prop very carefully and cant find signs of >>> >>> >>wear. >> >> >>>The engine is coming up to 300 hours soon and is due for the bearing >>> >>> >>re-grease. >> >> >>>I emailed Warp Drive and asked and they said no movement is allowed >>> >>> >>(between >> >> >>>blade and hub). >>> >>>Ideas? >>>Brett >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> ________________________________________________________________________________
Date: Apr 12, 2005
Subject: bearing slop
Hi Larry and all other followers. Managed to get out to the plane today and do some more investigating. Its definately not the prop - I pulled it off and tried my wiggle experiment while the base was held firmly and there is no play in any of my blades - thats good news as far as I am concerned - at least I am not grounded. So I put the prop back on and tried it again paying close attention to the upper pulley and im pretty sure it is the bearings I can feel. I managed to get the same effect with the prop off by grabbing each side of the upper pulley and apply a small twisting force in each direction - I can feel the play if I get it just right. I can also replicate it by grabbing the bases of two blades with the prop on and applying a similar twisting/rocking force and I can feel the tiny bit of play. Guess I will go ahead and order some replacement bearings and see if that will fix the problem. Brett BC, Canada, where it snowed to the 1000ft level and sent freezing rain to sea level last night - in the middle of april!!! Quoting Larry McFarland : > > Brett, > I believe Warp Drive means no movement between the composite and the > clamping hub, but the take-up > you feel at the redrive shaft could be nothing more than bearings > setting cool within the housing. I'd bet you > would find that when they are warm, and you know they do get "warm", the > tolerences change as they cool, or > perhaps the redrive housing has broken in a bit. I'd get a dial > indicator on the hub and measure the exactitude > of the play you find both diametral and axial. If you do that, I'll do > the same and we might learn what or how > much "play" is normal. > > Question though. How do you like the 72" on the Stratus? I'm using a > 70" and would think you'd be getting a > really good climb or cruise with yours. > > Larry McFarland > > > rueffy(at)jetthrust.com wrote: > > > > >Hey Soobers. Im scrating my head and not coming up with much (which is not > >unusual for me). I have a 72" 3 blade warp drive on the EA81. When I take > the > >end of the prop blade, and wiggle gently from side to side I can get a tiny > bit > >of play (were are talking very very small barely noticable amount at the > hub > >somewhere) It has been bugging me for ages exactly where the play was. I > >thought it was in a particular blade but then I tried something - if I > place > >one hand behind the prop hub and pull so the hub is firmly supported and > then > >wiggle - there is no play. So now I am thinking it might be a tiny bit > play > >somewhere else that is transfering though the hub and blade. Would it be > >possible that the tiny movement I am feeling is coming from in the PRSU > where > >the prop shaft fits in its sleeve? I haven't had this PRSU apart yet so I > am > >not sure of the exact deisgn and tolerances. That would make more sense > >because I have inspected the prop very carefully and cant find signs of > wear. > >The engine is coming up to 300 hours soon and is due for the bearing > re-grease. > > > > > >I emailed Warp Drive and asked and they said no movement is allowed > (between > >blade and hub). > > > >Ideas? > >Brett > > > > > > > > > > > > > > > Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Apr 12, 2005
Brett, You can get those bearings (and a belt if the time is right) from your local bearing supplier. They are very common bearings and usually available the same or next day. Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of rueffy(at)jetthrust.com Subject: Stratus-List: bearing slop Hi Larry and all other followers. Managed to get out to the plane today and do some more investigating. Its definately not the prop - I pulled it off and tried my wiggle experiment while the base was held firmly and there is no play in any of my blades - thats good news as far as I am concerned - at least I am not grounded. ________________________________________________________________________________
Date: Apr 13, 2005
Subject: Aviation News
m.poederbach(at)chello.nl, aviation-enthusiasts(at)yahoogroups.com AVIATION News Group to view & share your valuable comments and the latest trends and happenings in the aviation industry. Please click on the attached yahoo group link site to share & receive the updates on the latest happenings, business ventures, business opportunities, Air Shows and Exhibitions, New Aircraft releases, and certifications, Career news, Appointments etc. http://groups.yahoo.com/group/AVIATION-NEWS/ Please take few moments recommend us to your near & dears in the industry. We welcome your valuable comments and updates. With best regards AVIATION NEWS. http://groups.yahoo.com/group/AVIATION-NEWS/ --------------------------------- ________________________________________________________________________________
Date: Apr 16, 2005
Subject: [Please Read] Matronics Email Server Upgrade...
Dear Listers, I will be upgrading the Matronics Email Server this weekend. This includes some hardware improvements - more memory, faster, more capable processors - as well as a complete operating system upgrade from scratch. I hope to have both the old system and the new system running at the same time to minimize the actual impact of the upgrade. Hopefully there will be little actual downtime during the transition, but a few posts may get lost in the shuffle. If you don't see your post show up on the List in the normal amount of time (plus a little bit), then please just try posting it again. Upgrading the Matronics Email Server operating system (from Redhat Linux 7.2 to Redhat Linux WS 4) is a sizeable undertaking and requires a great deal of work to port all of the utilities, programs, and scripts over to the new system. As I've already mentioned, both the old and new systems will be on line at the same time, so interruption should be held to an absolute minimal. You might see a couple of odd test messages during the cut-over or other odd messages; please just ignore them. I have setup a new System Status Web Page that I will use to update List Members on the current status of the email and web systems. Please refer to it as often as you like: http://www.matronics.com/SystemStatus/ Thank you for your continued support of the List Services at Matronics! Its your yearly Contributions that make these major upgrades possible! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Apr 17, 2005
Subject: [Please Read] Matronics Email Server Upgrade Complete!
Dear Listers, The upgrade of the Matronics Email Server can be considered complete at this time. All known issues related to the upgrade process have been resolved and email services are running normal. The Nightly Digest processing has not yet been tested and will wait for tonight's update. If you encounter any odd behavior with respect to the Matronics Email Server over the next few days, please contact me via email at dralle(at)matronics.com or if that fails try dralle(at)speakeasy.net. Thanks to everyone for being patient through this arduous process of a major system upgrade! Matt Dralle Email List Administrator At 12:37 PM 4/16/2005 Saturday, Matt Dralle wrote: >Dear Listers, > >I will be upgrading the Matronics Email Server this weekend. This >includes some hardware improvements - more memory, faster, more capable >processors - as well as a complete operating system upgrade from >scratch. I hope to have both the old system and the new system running at >the same time to minimize the actual impact of the upgrade. > >Hopefully there will be little actual downtime during the transition, but >a few posts may get lost in the shuffle. If you don't see your post show >up on the List in the normal amount of time (plus a little bit), then >please just try posting it again. > >Upgrading the Matronics Email Server operating system (from Redhat Linux >7.2 to Redhat Linux WS 4) is a sizeable undertaking and requires a great >deal of work to port all of the utilities, programs, and scripts over to >the new system. As I've already mentioned, both the old and new systems >will be on line at the same time, so interruption should be held to an >absolute minimal. You might see a couple of odd test messages during the >cut-over or other odd messages; please just ignore them. > >I have setup a new System Status Web Page that I will use to update List >Members on the current status of the email and web systems. Please refer >to it as often as you like: > > http://www.matronics.com/SystemStatus/ > > >Thank you for your continued support of the List Services at >Matronics! Its your yearly Contributions that make these major upgrades >possible! > >Best regards, > >Matt Dralle >Matronics Email List Administrator Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Connecting to Bing primer ports on Stratus
Date: Apr 22, 2005
I've put this off, but pretty soon I need to hook up my engine and I'm not happy with what I've come up with so I'd like to ask for some help. How are people hooking a primer line to the small fitting on the bottom of the Bing carbs? You could barely get one hose clamp on there and it's a metric fitting (5mm), I think. I can squeeze some 1/4" ID yellow tygon down on it with a small clamp, but that doesn't seem like a great solution. I think vibration might cause the clamp to cut into the line and I'd like a more robust line carrying fuel in the engine compartment. I guess I could put some firesleeve around the tygon and try to find a hose clamp that stays round when clamping that small. As far as I can tell, the fitting is pressed into the carb and I haven't messed with it. I've searched the archives and found I can get some soft primer line from Lockwood Aviation, but I know others have solved this problem, so I thought I'd ask. I could go back to using the chokes, but I've got the primer installed and wired at this point. Also, for carb balancing, are you incorporating a "T" in the lines or disconnecting at the carb or maybe the primer solenoid? Thanks, all. Ron Hansen Los Angeles Zenair 601HDS, Stratus, BRS, 90%+ ________________________________________________________________________________
Subject: Re: Connecting to Bing primer ports on Stratus
Date: Apr 22, 2005
Ron, I never installed a primer. I use the choke and it starts immediately year round. Actually, I didn't like my dual cables so I only have one choke hooked up. gary ----- Original Message ----- From: "Hansen, Ronald" <RH122050(at)ncr.com> Subject: Stratus-List: Connecting to Bing primer ports on Stratus > > I've put this off, but pretty soon I need to hook up my engine and I'm > not happy with what I've come up with so I'd like to ask for some help. > > How are people hooking a primer line to the small fitting on the bottom > of the Bing carbs? > > You could barely get one hose clamp on there and it's a metric fitting > (5mm), I think. I can squeeze some 1/4" ID yellow tygon down on it with > a small clamp, but that doesn't seem like a great solution. I think > vibration might cause the clamp to cut into the line and I'd like a more > robust line carrying fuel in the engine compartment. I guess I could > put some firesleeve around the tygon and try to find a hose clamp that > stays round when clamping that small. > > As far as I can tell, the fitting is pressed into the carb and I haven't > messed with it. I've searched the archives and found I can get some > soft primer line from Lockwood Aviation, but I know others have solved > this problem, so I thought I'd ask. I could go back to using the > chokes, but I've got the primer installed and wired at this point. > > Also, for carb balancing, are you incorporating a "T" in the lines or > disconnecting at the carb or maybe the primer solenoid? > > Thanks, all. > > Ron Hansen > Los Angeles > Zenair 601HDS, Stratus, BRS, 90%+ > > > ________________________________________________________________________________
Date: Apr 25, 2005
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
I just used some "thin walled" tygon tube from the hardware store that is a push fit onto the fittings...no clamps. I use a tee threaded into the primer solenoid. Seeing how the tube only flows fuel for a few seconds and the volume of fuel contained in the primer lines is very small I did not worry about firesleev and such...Just kept the line tied up away from chafing or hot components. Frank Stratus 360 hours -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Hansen, Ronald Subject: Stratus-List: Connecting to Bing primer ports on Stratus I've put this off, but pretty soon I need to hook up my engine and I'm not happy with what I've come up with so I'd like to ask for some help. How are people hooking a primer line to the small fitting on the bottom of the Bing carbs? You could barely get one hose clamp on there and it's a metric fitting (5mm), I think. I can squeeze some 1/4" ID yellow tygon down on it with a small clamp, but that doesn't seem like a great solution. I think vibration might cause the clamp to cut into the line and I'd like a more robust line carrying fuel in the engine compartment. I guess I could put some firesleeve around the tygon and try to find a hose clamp that stays round when clamping that small. As far as I can tell, the fitting is pressed into the carb and I haven't messed with it. I've searched the archives and found I can get some soft primer line from Lockwood Aviation, but I know others have solved this problem, so I thought I'd ask. I could go back to using the chokes, but I've got the primer installed and wired at this point. Also, for carb balancing, are you incorporating a "T" in the lines or disconnecting at the carb or maybe the primer solenoid? Thanks, all. Ron Hansen Los Angeles Zenair 601HDS, Stratus, BRS, 90%+ ________________________________________________________________________________
Subject: reduction unit grease fitting
Date: May 11, 2005
Well, I finally took a pic of the grease fitting installed on the upper hub of the Stratus reduction unit. Some of you asked about it, but I have been a long time having my camera with me when at the hangar...but a picture is available now for those who are interested...just ask. I have over 100 hours on it since the installation and all looks well. For those who were concerned about heat, it runs very cool. The bearings are simply a little warm to the touch after flying...surprisingly cool. There is a little residue that seeps out around the seal, but no mess. I have wiped it off two or three times over past 100 hrs. I have shot a couple of squirts of grease in at annual inspection...the second time today. Don Walker HDS TD 362 hrs. ________________________________________________________________________________
Subject: Re: reduction unit grease fitting
Date: May 12, 2005
> of course, please send me a picture. > > gary > > ----- Original Message ----- > From: "Don Walker" <d3dw(at)msn.com> > To: "stratus-list" > Sent: Wednesday, May 11, 2005 8:12 AM > Subject: Stratus-List: reduction unit grease fitting > > >> >> Well, I finally took a pic of the grease fitting installed on the upper >> hub of the Stratus reduction unit. Some of you asked about it, but I have >> been a long time having my camera with me when at the hangar...but a >> picture is available now for those who are interested...just ask. >> I have over 100 hours on it since the installation and all looks >> well. For those who were concerned about heat, it runs very cool. The >> bearings are simply a little warm to the touch after >> flying...surprisingly cool. There is a little residue that seeps out >> around the seal, but no mess. I have wiped it off two or three times over >> past 100 hrs. I have shot a couple of squirts of grease in at annual >> inspection...the second time today. Don Walker HDS TD 362 hrs. >> >> >> >> >> >> >> > ________________________________________________________________________________
Subject: belt tension
Date: Jun 14, 2005
Hey guys, Do any of you change belt tension for summer and winter? In cold weather my belt is sloppy with engine cold and makes a little noise until warmed up...then it is good. In Texas summer it is tight and seems tight as a drum with engine temps over 195. I changed bearings at 250 hours because the front were already worn, I think because the belt was too tight. then set it to its current tension setting. Now with another 100+ the bearings seem good, but that tension sure seems tight in the summer. don walker hds td ________________________________________________________________________________
Date: Jun 14, 2005
Subject: Re: belt tension
Hi Don, I frequently check the tension ( 1/4"@ 20lbs) and wondered about the same thing. Seemed a bit tighter this summer. Can't get better than 1/8" at 20lbs. Adjustment is probably advisable. Larry McFarland Don Walker wrote: > >Hey guys, > Do any of you change belt tension for summer and winter? In cold weather my belt is sloppy with engine cold and makes a little noise until warmed up...then it is good. In Texas summer it is tight and seems tight as a drum with engine temps over 195. > I changed bearings at 250 hours because the front were already worn, I think because the belt was too tight. then set it to its current tension setting. Now with another 100+ the bearings seem good, but that tension sure seems tight in the summer. don walker hds td > > > > ________________________________________________________________________________
Date: Jun 14, 2005
Larry, My specs call for 1/8" at 20 lbs. with warm engine. How has the 1/4 been working for you? don ----- Original Message ----- From: Larry McFarland<mailto:larrymc(at)qconline.com> To: stratus-list(at)matronics.com Sent: Tuesday, June 14, 2005 8:04 AM Subject: Re: Stratus-List: belt tension Hi Don, I frequently check the tension ( 1/4"@ 20lbs) and wondered about the same thing. Seemed a bit tighter this summer. Can't get better than 1/8" at 20lbs. Adjustment is probably advisable. Larry McFarland Don Walker wrote: > >Hey guys, > Do any of you change belt tension for summer and winter? In cold weather my belt is sloppy with engine cold and makes a little noise until warmed up...then it is good. In Texas summer it is tight and seems tight as a drum with engine temps over 195. > I changed bearings at 250 hours because the front were already worn, I think because the belt was too tight. then set it to its current tension setting. Now with another 100+ the bearings seem good, but that tension sure seems tight in the summer. don walker hds td > > > > ________________________________________________________________________________
Date: Jun 14, 2005
Don, I'd re-set mine last fall in much cooler temps, because it had a bit of a rum, rum noise at 2800 rpm. Otherwise it flew beautifully at all higher rpms. No detectible vibrations or wear seen on the belt since. I thought things had tightened a bit since winter, but expansion of the aluminum assembly may be greater than the core fiber that make up the belt. The latest measurements seemed tight, but as the engine warms, perhaps it also lets up some. Wish there was a better way to know whats happening, but very few seem to have experienced problems beyond timely bearing replacement. Larry Don Walker wrote: > >Larry, >My specs call for 1/8" at 20 lbs. with warm engine. How has the 1/4 been working for you? don > ----- Original Message ----- > From: Larry McFarland<mailto:larrymc(at)qconline.com> > To: stratus-list(at)matronics.com > Sent: Tuesday, June 14, 2005 8:04 AM > Subject: Re: Stratus-List: belt tension > > > Hi Don, > I frequently check the tension ( 1/4"@ 20lbs) and wondered about the > same thing. Seemed a bit tighter > this summer. Can't get better than 1/8" at 20lbs. Adjustment is > probably advisable. > > Larry McFarland > > > Don Walker wrote: > > > > >Hey guys, > > Do any of you change belt tension for summer and winter? In cold weather my belt is sloppy with engine cold and makes a little noise until warmed up...then it is good. In Texas summer it is tight and seems tight as a drum with engine temps over 195. > > I changed bearings at 250 hours because the front were already worn, I think because the belt was too tight. then set it to its current tension setting. Now with another 100+ the bearings seem good, but that tension sure seems tight in the summer. don walker hds td > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 14, 2005
> Do any of you change belt tension for summer and winter? In cold weather > my belt is sloppy with engine cold and makes a little noise until warmed > up...then it is good. In Texas summer it is tight and seems tight as a > drum with engine temps over 195. ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Don, I normally check my belt tension when the engine is cold and found 5/16" def @ 20 lb to be about right for my Stratus. I leave it there year round (location is northern IL). This setting seems to be just a little looser than the 1/8" required when hot, but I want it that way. I flew a rotax 503 with a similar belt drive on my Challenger before building my HD. Like you I saw many bearing failures by going too tight on the belt, but never seen a problem with one too loose. I saw one once that was so loose it was almost falling off the sprockets, the owner said he has always run it that loose and never had a problem! I have some belt tensioning info I can send you if you like. It's mainly for the rotax / Challenger setup, but it does talk about the 601 belt drive also as a comparison. Kelly Meiste 601 HD ________________________________________________________________________________
Date: Jun 14, 2005
Along with belt tension the subject of bearing failure has come up. What are the typical signs and warnings of bearing failure? Brett Quoting Kelly Meiste : > > > Do any of you change belt tension for summer and winter? In cold weather > > > my belt is sloppy with engine cold and makes a little noise until warmed > > up...then it is good. In Texas summer it is tight and seems tight as a > > drum with engine temps over 195. > > ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ > > Don, > I normally check my belt tension when the engine is cold and found 5/16" def > > @ 20 lb to be about right for my Stratus. I leave it there year round > (location is northern IL). This setting seems to be just a little looser > than the 1/8" required when hot, but I want it that way. I flew a rotax 503 > with a similar belt drive on my Challenger before building my HD. Like you I > > saw many bearing failures by going too tight on the belt, but never seen a > problem with one too loose. I saw one once that was so loose it was almost > falling off the sprockets, the owner said he has always run it that loose > and never had a problem! > I have some belt tensioning info I can send you if you like. It's mainly for > > the rotax / Challenger setup, but it does talk about the 601 belt drive also > > as a comparison. > > Kelly Meiste > 601 HD > > > > > > > Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Subject: engine data
Date: Jun 28, 2005
i was just going thru my logbook gathering temps, pressures, rpm's and speeds. i'll be putting them in a spreadsheet that i have with other peoples data in there too. anybody care to contribute? low, avg and high oil temp, pressure, water temp, cyl head, climb and cruise rpm's, static and WOT with prop specs and speeds, etc. OAT and ALT would be nice too but it's hard to get a really good complete set of data. any other suggestions too. everybody having fun flying? what's new? i'm in hawaii - month 10 out of a year so it's back to reality pretty soon. been having fun with trikes and gliders but i sure miss my little subaru powered pelican. had to miss SNF and OSH but will be making Copperstate (flying commercial) and SNF (flying my Pelican) next year I hope. I'm still planning on hanging an Airmaster prop on the Stratus later this year, any thoughts on that? I'll be reworking the exhaust and cowling again too. that's the good thing about being away from it for a year - i'll be ready to do some work to clean it all up. Gary Krysztopik Pelican PL - N522GK Stratus Subaru EA-81 Newport, RI http://members.efortress.com/flyink/index.html ________________________________________________________________________________
Subject: Re: engine data
Date: Jun 30, 2005
Hi Gary, I'll compile a spreadsheet of my info for you and send it your way soon. If you recall my plane is a 601 HD Tri Gear (120 hours). If anyone else is interested in my numbers I'd be happy to send a copy your way also, so ask if your interested. Hawaii!!! ...................... no comment! Kelly +++++++++++++++++++++++++++++++++++++++++++ > i was just going thru my logbook gathering temps, pressures, rpm's and > speeds. i'll be putting them in a spreadsheet that i have with other > peoples data in there too. anybody care to contribute? low, avg and high > oil temp, pressure, water temp, cyl head, climb and cruise rpm's, static > and > WOT with prop specs and speeds, etc. OAT and ALT would be nice too but > it's > hard to get a really good complete set of data. ________________________________________________________________________________
Date: Jul 01, 2005
Yes, Kelly, I'd be interested to see your data. I'm not flying yet, but would add it to the growing collection of data that I'll have to compare with when I finally do fire it up. Thanx, in advance. Phil Raker N556P HDS/Stratus ~85% complete Hi Gary, I'll compile a spreadsheet of my info for you and send it your way soon. If anyone else is interested in my numbers I'd be happy to send a copy your way also, so ask if your interested. Kelly Rekindle the Rivalries. Sign up for Fantasy Football http://football.fantasysports.yahoo.com ________________________________________________________________________________
Date: Jul 14, 2005
Subject: List Digest Truncation Fixed!!
Dear Listers, I finally figured out today what was causing the occasional truncation of the daily List Digest emails. Seems that every once in a while a message would contain a single "." (period) on line all by itself. The mailers would see this and assume that this was the universal emailer signal for "end of message", and consequently wouldn't process any of the rest of the Digest message. I've put in a filter today to remove any of these sequences so we should be back in business on the Digests. Best regards, Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Prop play
Date: Jul 16, 2005
Fellow Stratusites, I have noticed that if I grab the tip of any of the three warp drive prop blades and move them in a for and aft motion, I can feel and see probably about a 1/32 or so of movement. Looking closer, it appears that this movement is coming from the prop bearings. I put a scale down by the prop bearing center race and made the above movement. There is movement there of probably less than .005" - Obviously that slop is amplified at the blade tips. Looking at the prop bearings that I pulled out two years ago, the inner races of both bearings also had this slight slop. This movement at the prop tips may have always been there but I had not noticed it until now (417 flight hours) and it has me a bit concerned. Anyway, does anyone have this issue? Could any of you move your prop tips for and aft next time you get to your aircraft and see if you feel anything? Regards, Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 417.0 flight hrs. - 559 landings web site -> http://homepages.together.net/~billvt/ ________________________________________________________________________________
Subject: Re: Prop play
Date: Jul 17, 2005
Bill, Mine comes from the movement of the cog in the belt. there is more space in each groove of the belt than the cog requires. they say this is for the escape of air. My engineer buddy says it should have been made an exact fit. I dunno, but I have noticed that prop movement from early on. Don Walker ----- Original Message ----- From: Bill Morelli<mailto:billvt(at)together.net> To: stratus-list(at)matronics.com Sent: Saturday, July 16, 2005 5:18 PM Subject: Stratus-List: Prop play Fellow Stratusites, I have noticed that if I grab the tip of any of the three warp drive prop blades and move them in a for and aft motion, I can feel and see probably about a 1/32 or so of movement. Looking closer, it appears that this movement is coming from the prop bearings. I put a scale down by the prop bearing center race and made the above movement. There is movement there of probably less than .005" - Obviously that slop is amplified at the blade tips. Looking at the prop bearings that I pulled out two years ago, the inner races of both bearings also had this slight slop. This movement at the prop tips may have always been there but I had not noticed it until now (417 flight hours) and it has me a bit concerned. Anyway, does anyone have this issue? Could any of you move your prop tips for and aft next time you get to your aircraft and see if you feel anything? Regards, Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 417.0 flight hrs. - 559 landings web site -> http://homepages.together.net/~billvt/> ________________________________________________________________________________
Date: Jul 17, 2005
> I have noticed that if I grab the tip of any of the three warp drive prop > blades and move them in a for and aft motion, I can feel and see probably > about a 1/32 or so of movement. Looking closer, it appears that this > movement is coming from the prop bearings. > does anyone have this issue? Could any of you move your prop tips > for and aft next time you get to your aircraft and see if you feel > anything? > > Regards, > Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 417.0 > flight hrs. - 559 landings > web site ->
http://homepages.together.net/~billvt/ ++++++++++++++++++++++++++++++++++++++++++++++++++ Hi Bill, I just ran out to my plane & checked, but all I notice after 120 hours is the usual 1/4" CW & CCW movement of the prop tips. I feel no front to back movement. Keep us posted as to what you find. Kelly ________________________________________________________________________________
Subject: Prop play
Date: Jul 18, 2005
Bill, I have not noticed for and aft movement either. How old are your bearings/belt? When it came time to change the belt I just got new bearings from an industrial bearing supplier...don't remember the cost but it was cheap enough to just change the bearings 'cus I had already taken it all apart. AS I remember the end play of the bearings is set by the locknut set on the back of the hub. Get a helper to flex the prop tips while you see if you can feel movement between the locknuts and the aluminium casting. If you can loosen the locknuts and tighten the preload on the bearing just enough to make the play go away. If the 417 hours is on the original bearings personally I would just change them out as it is not THAT big of a job...Doing the belt is like 75% of the work...At least as far as I remember. Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Kelly Meiste Subject: Re: Stratus-List: Prop play --> > I have noticed that if I grab the tip of any of the three warp drive > prop blades and move them in a for and aft motion, I can feel and see > probably about a 1/32 or so of movement. Looking closer, it appears > that this movement is coming from the prop bearings. > does anyone have this issue? Could any of you move your prop tips for > and aft next time you get to your aircraft and see if you feel > anything? > > Regards, > Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 417.0 > flight hrs. - 559 landings > web site -> http://homepages.together.net/~billvt/ ++++++++++++++++++++++++++++++++++++++++++++++++++ Hi Bill, I just ran out to my plane & checked, but all I notice after 120 hours is the usual 1/4" CW & CCW movement of the prop tips. I feel no front to back movement. Keep us posted as to what you find. Kelly ________________________________________________________________________________
Date: Jul 18, 2005
Hi bill, I commented on this about 2 months ago and made some posts. Im not sure if you can dig them out of the archives. I have exactly the same issue on my stratus EA81 with 72" three blade prop. I initially thought it was a single blade but I found its all blades and I too have a very very small amount of movement that I have traced to the prop bearings. Seems to be only present when the bearings are cold though. My engine is approaching 300 hours and I was going to change the bearings at 300hours anyway. I have continued flying in the meantime and I am watching it closely but I haven't seen any noticable degredation since I first noticed it. P.S. I have a pair of murphy 1500 straight floats for sale for $6000 USD. Brett Rueff Vanacouver Canada Quoting Bill Morelli : > > Fellow Stratusites, > > I have noticed that if I grab the tip of any of the three warp drive prop > blades and move them in a for and aft motion, I can feel and see probably > about a 1/32 or so of movement. Looking closer, it appears that this > movement is coming from the prop bearings. > > I put a scale down by the prop bearing center race and made the above > movement. There is movement there of probably less than .005" - Obviously > that slop is amplified at the blade tips. > > Looking at the prop bearings that I pulled out two years ago, the inner > races of both bearings also had this slight slop. > > This movement at the prop tips may have always been there but I had not > noticed it until now (417 flight hours) and it has me a bit concerned. > > Anyway, does anyone have this issue? Could any of you move your prop tips > for and aft next time you get to your aircraft and see if you feel anything? > > Regards, > Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 417.0 > flight hrs. - 559 landings > web site -> http://homepages.together.net/~billvt/ > > > > > > > Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Jul 18, 2005
I think Gary Wolf is floating around this forum. If so can we talk more about what you have mentioned on the airsoob forum about stress reversals or prop reversals, whichever it was for inflight adjustable props on the belt drive stratus EA81. Its something I have not looked into but would like to learn more about. Can you explain the phenomona a little more - is it only adjustable props or fixed as well? Thanks Brett Rueff Vancouver Quoting Bill Morelli : > > Fellow Stratusites, > > I have noticed that if I grab the tip of any of the three warp drive prop > blades and move them in a for and aft motion, I can feel and see probably > about a 1/32 or so of movement. Looking closer, it appears that this > movement is coming from the prop bearings. > > I put a scale down by the prop bearing center race and made the above > movement. There is movement there of probably less than .005" - Obviously > that slop is amplified at the blade tips. > > Looking at the prop bearings that I pulled out two years ago, the inner > races of both bearings also had this slight slop. > > This movement at the prop tips may have always been there but I had not > noticed it until now (417 flight hours) and it has me a bit concerned. > > Anyway, does anyone have this issue? Could any of you move your prop tips > for and aft next time you get to your aircraft and see if you feel anything? > > Regards, > Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 417.0 > flight hrs. - 559 landings > web site -> http://homepages.together.net/~billvt/ > > > > > > > Pilots!-For all your aviation resources visit Jet Thrust.com- The Pilot Network http://www.jetthrust.com Please report IMMEDIATELY any abuse/spam or scams of our webmail system to the webmaster of this website at the following address: webmaster(at)jetthrust.com ________________________________________________________________________________
Date: Jul 18, 2005
Bill, The free movement you feel would probably not be available to the running bearings because as the grease slings about the rotating parts, it becomes a film which would close the gaps under pressure of rotation. I'd worry if the bearings had any rattle or galled feel to them when rotating, but doubt you have a serious problem. It might be cause to remove the bearings and look at them closely to feel any roughness in them once, but that would be it for me. I've no perceptible motion fore or aft in mine but the housing does get overly warm to the touch and that may be because of the takeup. Larry McFarland Kelly Meiste wrote: > > > >>I have noticed that if I grab the tip of any of the three warp drive prop >>blades and move them in a for and aft motion, I can feel and see probably >>about a 1/32 or so of movement. Looking closer, it appears that this >>movement is coming from the prop bearings. >>does anyone have this issue? Could any of you move your prop tips >>for and aft next time you get to your aircraft and see if you feel >>anything? >> >>Regards, >>Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 417.0 >>flight hrs. - 559 landings >>web site -> http://homepages.together.net/~billvt/ >> >> > > > > ________________________________________________________________________________
Subject: re: Prop Play
Date: Jul 19, 2005
I replaced both of my prop bearings and HTD belt on 11/10/03 at 291 hours. So the bearings that are in there now have only 126 hours on them!! I don't recall checking for this front to back play back when I replaced the bearings but I think I would have noticed it?? Will look at Franks preload suggestion to see if I can take that slop out. Regards, Bill Bill, I have not noticed for and aft movement either. How old are your bearings/belt? When it came time to change the belt I just got new bearings from an industrial bearing supplier...don't remember the cost but it was cheap enough to just change the bearings 'cus I had already taken it all apart. AS I remember the end play of the bearings is set by the locknut set on the back of the hub. Get a helper to flex the prop tips while you see if you can feel movement between the locknuts and the aluminium casting. If you can loosen the locknuts and tighten the preload on the bearing just enough to make the play go away. If the 417 hours is on the original bearings personally I would just change them out as it is not THAT big of a job...Doing the belt is like 75% of the work...At least as far as I remember. Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Kelly Meiste Subject: Re: Stratus-List: Prop play --> > I have noticed that if I grab the tip of any of the three warp drive > prop blades and move them in a for and aft motion, I can feel and see > probably about a 1/32 or so of movement. Looking closer, it appears > that this movement is coming from the prop bearings. > does anyone have this issue? Could any of you move your prop tips for > and aft next time you get to your aircraft and see if you feel > anything? > > Regards, > Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 417.0 > flight hrs. - 559 landings > web site -> http://homepages.together.net/~billvt/ ++++++++++++++++++++++++++++++++++++++++++++++++++ Hi Bill, I just ran out to my plane & checked, but all I notice after 120 hours is the usual 1/4" CW & CCW movement of the prop tips. I feel no front to back movement. Keep us posted as to what you find. Kelly Bill Morelli billvt(at)together.net EarthLink Revolves Around You. ________________________________________________________________________________
Subject: RE: Prop Play
Date: Jul 23, 2005
Well, here is an update on my prop play issue. Remember I had some for and aft play at the prop tips which turned out to be the prop bearings. Took Frank H's advice and tightened up the bearing preload as follows: - Bent back locking ring on rear prop shaft lock nut - Loosened both prop shaft clamp bolts and installed the spreader bolts - Adjusted (tightened) the read nut (one just in front of the rear lock nut) until the play was gone. - Retightened lock nut at rear and bent locking ring back down - Removed spreader bolts and tightened clamp bolts to 120 in/lbs - All of this was done without changing the belt tension or tracking adjustments and took less than 1/2 hour - Went for a test flight with no problems - After flight - felt rear bearing and it was warm to the touch but I could leave my fingers on it so it was not heating up. That's it Thanks Frank !!!! If I ever get to meet you, I'll buy you a beer. Regards, Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 418.6 flight hrs. - 562 landings web site -> http://homepages.together.net/~billvt/ ________________________________________________________________________________
Subject: Re: RE: Prop Play
Date: Jul 24, 2005
Thanks for the update Bill, glad to hear it was a relatively easy fix. I'll place you memo in my files just in case. Are you going to fly into Osh again this year? Kelly Do not achieve ----- Original Message ----- From: "Bill Morelli" <billvt(at)together.net> Subject: Stratus-List: RE: Prop Play > > Well, here is an update on my prop play issue. > > Remember I had some for and aft play at the prop tips which turned out to > be the prop bearings. > > Took Frank H's advice and tightened up the bearing preload as follows: > > - Bent back locking ring on rear prop shaft lock nut > - Loosened both prop shaft clamp bolts and installed the spreader bolts > - Adjusted (tightened) the read nut (one just in front of the rear lock > nut) until the play was gone. > - Retightened lock nut at rear and bent locking ring back down > - Removed spreader bolts and tightened clamp bolts to 120 in/lbs > > - All of this was done without changing the belt tension or tracking > adjustments and took less than 1/2 hour > > - Went for a test flight with no problems > - After flight - felt rear bearing and it was warm to the touch but I > could leave my fingers on it so it was not heating up. > > That's it > > Thanks Frank !!!! If I ever get to meet you, I'll buy you a beer. > > Regards, > Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 418.6 > flight hrs. - 562 landings > web site -> http://homepages.together.net/~billvt/ > > > ________________________________________________________________________________
Subject: prop drive belt failure
Date: Jul 25, 2005
0.03 HTML_TEXT_AFTER_HTML BODY: HTML contains text after HTML close tag 0.06 HTML_TEXT_AFTER_BODY BODY: HTML contains text after BODY close tag On power up yesterday, I experienced a belt failure. Luckily, I still was on the ground. The belt had about 80 hours on it but dated back to when Stratus changed from two belts to one (about three to fours ago?). Upon examination, the "teeth" on the inside of the belt separated from the rest of the belt, thus causing the belt to lose grip of the pulley and resulted in a failure. When I called Mykal, he said that "materials degrade over time and the belt should be changed out every year". This, of course, is contrary to his published maintenance schedule for this item. Given the critical nature of this part and my recent experience, I would have to agree and recommend a yearly change out of the belt. I can't imagine the end result of a belt failure over hostile terrain...=0D=0A=0D=0AJohn Karnes=0D=0AN601JK Zenith 601HDS=0D=0AWashington ________________________________________________________________________________
Date: Jul 25, 2005
Great! and Mykal will be writing to inform all his customers of this change will he? To be fair to the belt I am surprised it failed...Was it the single 55mm belt?...Thats a lot of work and it's the first failure of a single belt I have heard of. If the belt truly needs to be changed every year then I doubt he will be selling many motors from now on.....Everyone will buy a Rotax. Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of John Karnes Subject: Stratus-List: prop drive belt failure On power up yesterday, I experienced a belt failure. Luckily, I still was on the ground. The belt had about 80 hours on it but dated back to when Stratus changed from two belts to one (about three to fours ago?). Upon examination, the "teeth" on the inside of the belt separated from the rest of the belt, thus causing the belt to lose grip of the pulley and resulted in a failure. When I called Mykal, he said that "materials degrade over time and the belt should be changed out every year". This, of course, is contrary to his published maintenance schedule for this item. Given the critical nature of this part and my recent experience, I would have to agree and recommend a yearly change out of the belt. I can't imagine the end result of a belt failure over hostile terrain...=0D=0A=0D=0AJohn Karnes=0D=0AN601JK Zenith 601HDS=0D=0AWashington ________________________________________________________________________________
Date: Jul 26, 2005
John...Sorry to hear about your problem. This is important safety info. Did the entire belt layer of teeth separate from the other layers of the belt, or did the teeth all shear off? It will help to know what to look for. I have the same belt that was changed when Stratus changed from the dual 30mm to the single 60mm belt. I now have about 180 hours on the new belt. Thanks and glad you and your plane are ok, Jim Weston Concord, GA -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of John Karnes Subject: Stratus-List: prop drive belt failure On power up yesterday, I experienced a belt failure. Luckily, I still was on the ground. The belt had about 80 hours on it but dated back to when Stratus changed from two belts to one (about three to fours ago?). Upon examination, the "teeth" on the inside of the belt separated from the rest of the belt, thus causing the belt to lose grip of the pulley and resulted in a failure. When I called Mykal, he said that "materials degrade over time and the belt should be changed out every year". This, of course, is contrary to his published maintenance schedule for this item. Given the critical nature of this part and my recent experience, I would have to agree and recommend a yearly change out of the belt. I can't imagine the end result of a belt failure over hostile terrain...=0D=0A=0D=0AJohn Karnes=0D=0AN601JK Zenith 601HDS=0D=0AWashington ________________________________________________________________________________
Subject: Re: prop drive belt failure
Date: Jul 26, 2005
Subject: RE: Prop belt drive failure
Date: Jul 26, 2005
I don't buy the belt needs changing every year statement by Mykal. I replaced mine the first and only time at 290 hours and the one I removed looked as good as the new one. I now have 418 hours on the engine so this new belt is at 128 hours. Could you tell if possibly the belt loosened up for some reason (tension adjustment slipped) ?? Was you tension set correctly? As Frank said, there are quite a number of Stratus engines with a good number of hours and this is the first report of a belt failure. Regards, Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 418.6 flight hrs. - 562 landings web site -> http://homepages.together.net/~billvt/ ________________________________________________________________________________
Subject: Re: RE: Prop belt drive failure
Date: Jul 27, 2005
Date: Jul 27, 2005
Same here, Bill. My old one looked good as the new. I changed it at 250 hours and three years old. However, I do preflight the belt occasionally, looking at the teeth and layers. My new one is now three years old and looks good, but I guess I will go ahead and replace it. It is against my nature to throw away good stuff, but in an airplane I force myself to do it sometimes. Mykal is a "nice guy", but covering his "ASS" on this one. Sometimes he feels the need to be a "company man". Not being a pilot, he doesn't quite understand our insistence on shooting straight about stuff. I wouldn't fault anyone for putting a new one on each year, and Mykal will be happy to supply them. ----- Original Message ----- From: Bill Morelli<mailto:billvt(at)together.net> To: stratus-list Sent: Tuesday, July 26, 2005 5:35 PM Subject: Stratus-List: RE: Prop belt drive failure I don't buy the belt needs changing every year statement by Mykal. I replaced mine the first and only time at 290 hours and the one I removed looked as good as the new one. I now have 418 hours on the engine so this new belt is at 128 hours. Could you tell if possibly the belt loosened up for some reason (tension adjustment slipped) ?? Was you tension set correctly? As Frank said, there are quite a number of Stratus engines with a good number of hours and this is the first report of a belt failure. Regards, Bill (N812BM - 601HDS - Tri - Stratus (RAM Heads) - Vermont - 418.6 flight hrs. - 562 landings web site -> http://homepages.together.net/~billvt/> ________________________________________________________________________________
Subject: Stratus belt failure
Date: Jul 28, 2005
1.25 RCVD_NUMERIC_HELO Received: contains an IP address used for HELO I recently had the belt break on my Stratus EA81. I happened about 30 seconds after lift off. I was able to dead stick the plane , an Avid flyer on floats, back on the lake. The belt and redrive both have about 200 hours on them and the belt was about three years old. The prop pulley showed wear on the top of the teeth, the anodizing was worn off the teeth on all the teeth on the prop pulley. The crank pulley also had some of the anodizing missing on some of the teeth, but just small chips missing. I talked to Mykal at stratus and he couldn't shed any light on what may have happened. I suspect that maybe the tension was to tight on the belt and or the tracking wasn't within tolerance. I am looking for a complete stratus redrive if anyone has one for sale or knows of one I am interested in buying. Dale 907 225 4930 I recently had the belt break on my Stratus EA81. I happened about 30 seconds after lift off. I was able to dead stick the plane , an Avid flyer on floats, back on the lake. The belt and redrive both have about 200 hours on them and the belt was about three years old. The prop pulley showed wear on the top of the teeth, the anodizing was worn off the teeth on all the teeth on the prop pulley. The crank pulley also had some of the anodizing missing on some of the teeth, but just small chips missing. I talked to Mykal at stratus and he couldn't shed any light on what may have happened. I suspect that maybe the tension was to tight on the belt and or the tracking wasn't within tolerance. I am looking for a complete stratus redrive if anyone has one for sale or knows of one I am interested in buying. Dale 907 225 4930 ________________________________________________________________________________
Date: Jul 28, 2005
I read an article recently about a Challenger ultralight crash due to a failed belt. The article explains that belt tension is critical. On this aircraft, there was not enough tension. Details are given on how to adjust tension. Look for belt redrive failure Challenger on google. Michel PS: From Airventure :-) --- John Karnes wrote: > > > On power up yesterday, I experienced a belt failure. > Luckily, I still was on the ground. The belt had > about 80 hours on it but dated back to when Stratus > changed from two belts to one (about three to fours > ago?). Upon examination, the "teeth" on the inside > of the belt separated from the rest of the belt, > thus causing the belt to lose grip of the pulley and > resulted in a failure. When I called Mykal, he said > that "materials degrade over time and the belt > should be changed out every year". This, of course, > is contrary to his published maintenance schedule > for this item. Given the critical nature of this > part and my recent experience, I would have to agree > and recommend a yearly change out of the belt. I > can't imagine the end result of a belt failure over > hostile terrain...=0D=0A=0D=0AJohn > Karnes=0D=0AN601JK Zenith 601HDS=0D=0AWashington > > > > browse > Subscriptions page, > FAQ, > > > > > > ---------------------------- Michel Therrien CH601-HD, C-GZGQ
http://mthobby.pcperfect.com/ch601 http://www.zenithair.com/bldrlist/profiles/mthobby http://pages.infinit.net/mthobby ________________________________________________________________________________
Date: Jul 28, 2005
Yeah I was thinking about this and wondered the same thing. Belt drive failure so far (ha!) has been extremly rare. I wondered if the tooth failure in another post was a result of the belt chattering on the sprockets. So far my belt/teeth look in perfect condition and I changed the first one at about 3 years and 300 hours. The belt looked perfect. Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Michel Therrien Subject: Re: Stratus-List: prop drive belt failure I read an article recently about a Challenger ultralight crash due to a failed belt. The article explains that belt tension is critical. On this aircraft, there was not enough tension. Details are given on how to adjust tension. Look for belt redrive failure Challenger on google. Michel PS: From Airventure :-) --- John Karnes wrote: > > > On power up yesterday, I experienced a belt failure. > Luckily, I still was on the ground. The belt had about 80 hours on > it but dated back to when Stratus changed from two belts to one (about > three to fours ago?). Upon examination, the "teeth" on the inside of > the belt separated from the rest of the belt, thus causing the belt to > lose grip of the pulley and resulted in a failure. When I called > Mykal, he said that "materials degrade over time and the belt should > be changed out every year". This, of course, is contrary to his > published maintenance schedule for this item. Given the critical > nature of this part and my recent experience, I would have to agree > and recommend a yearly change out of the belt. I can't imagine the > end result of a belt failure over hostile terrain...=0D=0A=0D=0AJohn > Karnes=0D=0AN601JK Zenith 601HDS=0D=0AWashington > > > > browse > Subscriptions page, > FAQ, > > > > > > ---------------------------- Michel Therrien CH601-HD, C-GZGQ http://mthobby.pcperfect.com/ch601 http://www.zenithair.com/bldrlist/profiles/mthobby http://pages.infinit.net/mthobby ________________________________________________________________________________
Subject: Re: Stratus belt failure
Date: Jul 28, 2005
Thanks for posting that Dale. I think I'll be checking my pulley condition when I get back, if I don't see any wear then it's worth the peace of mind. A belt replacement might not be necessary every 100 hours but I'm gonna put belt removal and inspection on my annual. How did you adjust your belt? I use the 1/4" play at the prop tip when cold method. That seems to be about right, when it warms up the play goes away. I think it's a pain to adjust and keep the pulleys in parallel and get just the right tension, but when it's setup it usually stays that way. Just a little tighter or looser seems to make a big difference in sound and vibration. I was always afraid of making it too tight and cooking the bearings. I'd like to put a thermocouple on the drive near the bearing. I figure if I baseline the temps, maybe I'll see an increase if/when the bearing starts to go. Does this sound worthwhile to anyone? Gary Krysztopik Pelican PL - N522GK Stratus Subaru EA-81 Newport, RI http://members.efortress.com/flyink/index.html ----- Original Message ----- From: <clark.dale(at)att.net> Subject: Stratus-List: Stratus belt failure > > I recently had the belt break on my Stratus EA81. I happened about 30 > seconds after lift off. I was able to dead stick the plane , an Avid > flyer on floats, back on the lake. The belt and redrive both have about > 200 hours on them and the belt was about three years old. The prop pulley > showed wear on the top of the teeth, the anodizing was worn off the teeth > on all the teeth on the prop pulley. The crank pulley also had some of > the anodizing missing on some of the teeth, but just small chips missing. > I talked to Mykal at stratus and he couldn't shed any light on what may > have happened. I suspect that maybe the tension was to tight on the belt > and or the tracking wasn't within tolerance. I am looking for a complete > stratus redrive if anyone has one for sale or knows of one I am interested > in buying. > Dale 907 225 4930 > > > > > > I recently had the belt break on my Stratus EA81. I happened about 30 > seconds after lift off. I was able to dead stick the plane , an Avid flyer > on floats, back on the lake. The belt and redrive both have about 200 > hours on them and the belt was about three years old. The prop pulley > showed wear on the top of the teeth, the anodizing was worn off the teeth > on all the teeth on the prop pulley. The crank pulley also had some of the > anodizing missing on some of the teeth, but just small chips missing. I > talked to Mykal at stratus and he couldn't shed any light on what may have > happened. I suspect that maybe the tension was to tight on the belt and or > the tracking wasn't within tolerance. I am looking for a complete stratus > redrive if anyone has one for sale or knows of one I am interested in > buying. > Dale 907 225 4930 > > > > ________________________________________________________________________________
Date: Jul 28, 2005
Gary, it might be as simple as touching your bearings occasionally after flying...just getting used to what is normal. Mine are okay to touch...not hot...just warm. I think you could feel if they start heating up. then check them out further. don ----- Original Message ----- From: gary<mailto:FlyinK(at)efortress.com> To: stratus-list(at)matronics.com Sent: Thursday, July 28, 2005 11:36 AM Subject: Re: Stratus-List: Stratus belt failure Thanks for posting that Dale. I think I'll be checking my pulley condition when I get back, if I don't see any wear then it's worth the peace of mind. A belt replacement might not be necessary every 100 hours but I'm gonna put belt removal and inspection on my annual. How did you adjust your belt? I use the 1/4" play at the prop tip when cold method. That seems to be about right, when it warms up the play goes away. I think it's a pain to adjust and keep the pulleys in parallel and get just the right tension, but when it's setup it usually stays that way. Just a little tighter or looser seems to make a big difference in sound and vibration. I was always afraid of making it too tight and cooking the bearings. I'd like to put a thermocouple on the drive near the bearing. I figure if I baseline the temps, maybe I'll see an increase if/when the bearing starts to go. Does this sound worthwhile to anyone? Gary Krysztopik Pelican PL - N522GK Stratus Subaru EA-81 Newport, RI http://members.efortress.com/flyink/index.html> ----- Original Message ----- From: <clark.dale(at)att.net<mailto:clark.dale(at)att.net>> To: > Subject: Stratus-List: Stratus belt failure > > I recently had the belt break on my Stratus EA81. I happened about 30 > seconds after lift off. I was able to dead stick the plane , an Avid > flyer on floats, back on the lake. The belt and redrive both have about > 200 hours on them and the belt was about three years old. The prop pulley > showed wear on the top of the teeth, the anodizing was worn off the teeth > on all the teeth on the prop pulley. The crank pulley also had some of > the anodizing missing on some of the teeth, but just small chips missing. > I talked to Mykal at stratus and he couldn't shed any light on what may > have happened. I suspect that maybe the tension was to tight on the belt > and or the tracking wasn't within tolerance. I am looking for a complete > stratus redrive if anyone has one for sale or knows of one I am interested > in buying. > Dale 907 225 4930 > > > > > > I recently had the belt break on my Stratus EA81. I happened about 30 > seconds after lift off. I was able to dead stick the plane , an Avid flyer > on floats, back on the lake. The belt and redrive both have about 200 > hours on them and the belt was about three years old. The prop pulley > showed wear on the top of the teeth, the anodizing was worn off the teeth > on all the teeth on the prop pulley. The crank pulley also had some of the > anodizing missing on some of the teeth, but just small chips missing. I > talked to Mykal at stratus and he couldn't shed any light on what may have > happened. I suspect that maybe the tension was to tight on the belt and or > the tracking wasn't within tolerance. I am looking for a complete stratus > redrive if anyone has one for sale or knows of one I am interested in > buying. > Dale 907 225 4930 > > > > ________________________________________________________________________________
Date: Jul 28, 2005
I don't know if thermocoupling your bearings will give you good data or not. Its probably a case of try it and see. My guess would be the cooling effect in flight will be highly ambient temperature dependant which may well mask any useful data. I think we now have three documented belt failures between this and the Zenith list...Is that correct?...I hope this is not going the same way as the valve guides! Nervous Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Don Walker Subject: Re: Stratus-List: Stratus belt failure Gary, it might be as simple as touching your bearings occasionally after flying...just getting used to what is normal. Mine are okay to touch...not hot...just warm. I think you could feel if they start heating up. then check them out further. don ----- Original Message ----- From: gary<mailto:FlyinK(at)efortress.com> To: stratus-list(at)matronics.com Sent: Thursday, July 28, 2005 11:36 AM Subject: Re: Stratus-List: Stratus belt failure > Thanks for posting that Dale. I think I'll be checking my pulley condition when I get back, if I don't see any wear then it's worth the peace of mind. A belt replacement might not be necessary every 100 hours but I'm gonna put belt removal and inspection on my annual. How did you adjust your belt? I use the 1/4" play at the prop tip when cold method. That seems to be about right, when it warms up the play goes away. I think it's a pain to adjust and keep the pulleys in parallel and get just the right tension, but when it's setup it usually stays that way. Just a little tighter or looser seems to make a big difference in sound and vibration. I was always afraid of making it too tight and cooking the bearings. I'd like to put a thermocouple on the drive near the bearing. I figure if I baseline the temps, maybe I'll see an increase if/when the bearing starts to go. Does this sound worthwhile to anyone? Gary Krysztopik Pelican PL - N522GK Stratus Subaru EA-81 Newport, RI
http://members.efortress.com/flyink/index.html com/flyink/index.html> ----- Original Message ----- From: <clark.dale(at)att.net<mailto:clark.dale(at)att.net>> To: > Subject: Stratus-List: Stratus belt failure clark.dale(at)att.net > > I recently had the belt break on my Stratus EA81. I happened about 30 > seconds after lift off. I was able to dead stick the plane , an Avid > flyer on floats, back on the lake. The belt and redrive both have about > 200 hours on them and the belt was about three years old. The prop pulley > showed wear on the top of the teeth, the anodizing was worn off the teeth > on all the teeth on the prop pulley. The crank pulley also had some of > the anodizing missing on some of the teeth, but just small chips missing. > I talked to Mykal at stratus and he couldn't shed any light on what may > have happened. I suspect that maybe the tension was to tight on the belt > and or the tracking wasn't within tolerance. I am looking for a complete > stratus redrive if anyone has one for sale or knows of one I am interested > in buying. > Dale 907 225 4930 > > > > > > I recently had the belt break on my Stratus EA81. I happened about 30 > seconds after lift off. I was able to dead stick the plane , an Avid flyer > on floats, back on the lake. The belt and redrive both have about 200 > hours on them and the belt was about three years old. The prop pulley > showed wear on the top of the teeth, the anodizing was worn off the teeth > on all the teeth on the prop pulley. The crank pulley also had some of the > anodizing missing on some of the teeth, but just small chips missing. I > talked to Mykal at stratus and he couldn't shed any light on what may have > happened. I suspect that maybe the tension was to tight on the belt and or > the tracking wasn't within tolerance. I am looking for a complete stratus > redrive if anyone has one for sale or knows of one I am interested in > buying. > Dale 907 225 4930 > > > > ________________________________________________________________________________
Date: Jul 28, 2005
The first belt failure on a stratus setup I heard of was on the airsoob list a couple years ago. The fellow was in Florida on a flying tour with some other aircraft from South America . He was trying to find a Florida source for a new belt. I have not heard of many more may be about 2 others like Frank sez. There were not many details possibly due to language difference problems. Jim Pollard Merlin Ont ch601hds ea81 ________________________________________________________________________________
Date: Jul 28, 2005
> The first belt failure on a stratus setup I heard of was on the airsoob > list a couple years ago. The fellow was in Florida on a flying tour > with some other aircraft from South America . He was trying > to find a Florida source for a new belt. I have not heard of many > more may be about 2 others like Frank sez. > There were not many details possibly due to language difference problems. i think i remember that one, but it was the old two-belt design and I think he lost one belt and didn't know until he opened the hood (that's autoconversion talk). that one and another two-belt failure were the only stratus failures that i ever heard of before these two recent ones. as far as these two - just to make myself feel better - one was a pretty old belt (not hours used but years aged - and btw, i got my single-belt engine in 2000 and they were already single belt for a while so if John's belt was from when they first switched over then it is at least 6 or 7 years old) and the other may have been some kind of problem since the pulley was worn ? gary ________________________________________________________________________________
Subject: Belt life and failure.
Date: Jul 29, 2005
I have used a Jason belt for six years with no problems... now on my second one...from Stratus. The info below leads me to wonder about the Gates Powergrip GT2. Have any of you used it yet. Review the info below. It is from the article Michel refers to in the note below. don Walker The Gates PowerGrip GT2=AE version was introduced in February 2000. The GT2 belt features a longer and more robust life and with its redesigned deep cog profile is capable of transmitting up to 200% more power than previous PowerGrip GT and PowerGrip HTD belts. When tested against competitor belts at sprocket speeds up to 9000 rpm the GT2 belt outlasted the competitor belts more than two to one. As patented belt designs expire numerous generic versions enter the marketplace. There are presently at least 12 different brands of synchronous belts on the market. A recently introduced belt features a small lateral groove along the face of the cog. The purpose of the groove is to allow the release of trapped air and to reduce noise generation. QCU, the manufacturer of the Challenger Ultralight was requested to provide the research data or to provide the foundation for the imposition of their 100-hour, one-year in-use limitation placed on the re-drive belt. The stated belt limitations imposed b y QCU in the Challenger 50 Hour Inspection Report was found to be arbitrary and without foundation. The QCU imposed belt limitations remain unchanged despite technological advances in belt design and durability. The 880 8M 85 synchronous belt used on the Zenair 601 is about an inch wider and 6 inches shorter than the 960 08M 50 belt used on the Challenger. Belt life is projected to be a minimum of 500 hours of operation utilizing a Subaru 100 hp 4-stroke engine at 4500rpm. While utilizing pre-G2 belt technology and design, Zenair belt usage to 850 hours is commonplace in applications up to 200 horsepower. ----- Original Message ----- From: Hinde, Frank George (Corvallis)<mailto:frank.hinde(at)hp.com> To: stratus-list(at)matronics.com Sent: Thursday, July 28, 2005 9:44 AM Subject: RE: Stratus-List: prop drive belt failure Yeah I was thinking about this and wondered the same thing. Belt drive failure so far (ha!) has been extremly rare. I wondered if the tooth failure in another post was a result of the belt chattering on the sprockets. So far my belt/teeth look in perfect condition and I changed the first one at about 3 years and 300 hours. The belt looked perfect. Frank -----Original Message----- From: owner-stratus-list-server(at)matronics.com<mailto:owner-stratus-list-server(at)matronics.com> [mailto:owner-stratus-list-server(at)matronics.com] On Behalf Of Michel Therrien To: stratus-list(at)matronics.com Subject: Re: Stratus-List: prop drive belt failure I read an article recently about a Challenger ultralight crash due to a failed belt. The article explains that belt tension is critical. On this aircraft, there was not enough tension. Details are given on how to adjust tension. Look for belt redrive failure Challenger on google. Michel PS: From Airventure :-) --- John Karnes > wrote: > > > > On power up yesterday, I experienced a belt failure. > Luckily, I still was on the ground. The belt had about 80 hours on > it but dated back to when Stratus changed from two belts to one (about > three to fours ago?). Upon examination, the "teeth" on the inside of > the belt separated from the rest of the belt, thus causing the belt to > lose grip of the pulley and resulted in a failure. When I called > Mykal, he said that "materials degrade over time and the belt should > be changed out every year". This, of course, is contrary to his > published maintenance schedule for this item. Given the critical > nature of this part and my recent experience, I would have to agree > and recommend a yearly change out of the belt. I can't imagine the > end result of a belt failure over hostile terrain...0D0A0D0AJohn > Karnes0D0AN601JK Zenith 601HDS0D0AWashington > > > > browse > Subscriptions page, > FAQ, > > > > > > ---------------------------- Michel Therrien CH601-HD, C-GZGQ
http://mthobby.pcperfect.com/ch601> http://www.zenithair.com/bldrlist/profiles/mthobby> http://pages.infinit.net/mthobby> ________________________________________________________________________________
Subject: Belt life
Date: Jul 29, 2005
Here are findings from the Challenger belt failure. FINDINGS 1) The engine driven reduction belt failed under high torque at a critical moment during take-off. 2) The lower than optimum engine rpm prior to the occurrence was evidence of excessive belt friction. 3) The belt failure was caused by inadequate tensioning of the belt. 4) The failed PowerGrip HTD belt was an earlier, less robust version of current PowerGrip GT belts. 5) Synchronous belt manufacturers' prescribed belt-tensioning values and procedures are not readily available to aircraft owners, pilots and maintainers. 6) The pilot was unaware that minor tachometer rpm fluctuations to above normal values at take-off power indicated imminent belt failure and total loss of thrust. 7) The one-year, one hundred hour service life imposed by QCU on the Challenger synchronous belt is arbitrary and without foundation. 8) For liability considerations the Gates PowerGrip belt application on the Challenger (and other) aircraft is not endorsed by Gates Rubber Company. 9) Direction of rotation should be identified on the belt and that direction should be maintained for the life of the belt. 10) The Challenger aircraft's docile stall characteristics averted a potentially serious accident. ________________________________________________________________________________
Date: Jul 30, 2005
Subject: Re: Belt life and failure.
At 06:09 PM 7/29/2005, you wrote: >Zenair belt usage to 850 hours is commonplace in applications up to 200 >horsepower. I wonder how common are 850 hour belt drive zenairs. Also 200 hp zenairs seem to be commonplace also? Jim Pollard ________________________________________________________________________________
From: "Michael & Donna Heit" <rmrlpfm(at)centurytel.net>
Subject: CHALLENGER BELT FAILURE
Date: Jul 30, 2005
Here is one link to a website detailing belt failures on the Challenger. As an A&P I have flown, built, and inspected, hundreds of belt drive engine powered aircraft. I inspected a belt for a fellow one time, and told him it was about to fail but he chose to ignore my warnings and flew the aircraft anyway. The belt failed on landing approach, and he ended up landing in a oat field. From what I have experienced and read over the years, my gut feeling is that the largest percentages of belt failures were due to lack of proper installation, poor or non existent proper inspection technique, and just plain old fashion lack of knowledge. The Challenger has been a very safe competent aircraft; many have flown some amazing cross country flights, and I personally have flown several with complete confidence in the design. I also do a very thorough pre flight before I fly any aircraft, and if there are any doubts in what I see, I don't fly.
October 05, 2004 - July 31, 2005
Stratus-Archive.digest.vol-ac
