XDP4000X-Archive.digest.vol-at
April 19, 2006 - Present
; connect a
10k resistor between the blue (bus master) and
orang
e (ground) wires. I
have
attached a PDF with a detailed description of the connections
(SonyCable5.pdf).
The numbers can not be seen on the Son
y conn
ector. They can be seen on the
PhatBox connector.
An unmodified cable should work when directly connected to a head unit.
Firmware 5.00 and an unmodified cable works with simple multi-device
configurations. I'm not sure if firmware 6.00 and an unmodified cable
will
work
with any multi-device configurations.
gt; &g
t; The problem is with the bus master signal. It is an input. It is used for
a
rbitra
tion during device initialization. Without the pull-down the
signal
stays high (+5V) at all times. Thus the PhatBox has trouble knowing when
is
the
right time to initialize itself.
After the PhatBox is connected, it will boot and then shutdown. The
PhatBox
should then force a reset after a few seconds. However, you should listen
to
Matt regarding pushing reset. He would know best about using the C90.
Mike"
BR
Matt G Dralle | Matronics | PO Box 347 | Liverm
ore |
CA | 94551
http://www.matronics.com/ WWW | Featuring Products For
Aircra
ft
ring P
roducts For Aircraft
Yes, and I even reinstalled the firmware and did
a comp
lete system reset
afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is
there,
and can control it just fine, but the 4000x just shuts down whenever it's
plugged in. I find it odd that the Phatbox can still be recognized and
controlled since it is plugged into the 4000x which is
shut d
own when the
Phatbox
is plugged in... I just don't know what to do...
ics.co
m
-- XDP4000X-List message posted by: Matt Dralle
Are you running the 7.0 version of the Sony Phatbox firmware?
Matt
by: bo
bbybraun(at)comcast.net
Well I had the cable modified with the 4.7k ohm resister installed as
suggested
and the problem is still there... as soon as the Phatbox is plugged in my
4000x
powers down, the system resets and the C90 only communicates with the
Phatbox.
Still wondering if that resist
or sho
uld've been 10k ohms instead of 4.7k
since
there seemed to be a conflict of information.
Anyone out there
with
a working spare Sony Phatbox cable they're willing to
part with for some cash, or a photo of the bottom of a Sony PB that someone
wouldn't mind me using to get myself a cable direct from the factory? I'm
running out of options here. Can anybody help?
ssage
Okay, here's some help on this cable issue. Below are two links to some <
BR>>
; information on how the Phatbox-Sony cables are wired. Note that you *will
need*
the 4.7k ohm resistor between ground and the blue wire.
Note
the color coding
and what not might be different depending on the version of cable you have.
The
links are for reference only and you might find
you n
eed to interpolate a
little
with respect to colors and pin numbers and what not:
What Matt Found on his cable:
http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf
g
t;
What Phatbox Said:
h
ttp://www.matronics.com/xdp4000x/SonyCable5.pdf
Depending on what version of cable you have, things might be a little
different.
Use the drawing that matches best your installation.
Are you using version 7.0 Sony firmware on your Phatbox? If you are using
anything else, you are going to h
ave op
erational issues with the xdp-4000x.
Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager).
g
t;
For reference, here is a message from Mike Woo at Phatnoise way back when:
"We changed cable manufacturers since Matt purchased
his s
ystem. The
connections
are th
e same but the colors are different. You want to connect a
10k resistor between the blue (bus master) and orange (ground) wires. I
have
(SonyCable5.pdf).
The numbers can not be seen on the Sony connector. They can be seen on the
PhatBox connector.
Firmware
5.00
configurations. I'm not sure if firmware 6.00 and an unmodified cable will
work
igurat
ions.
arbitration during device initializatio
n. Wit
hout the pull-down the signal
stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is
the
After the PhatBox is connected, it will boot and then shutdown. The PhatBox
to
Mike"
g
&g
t; t;
gt; http://www.matronics.com/ WWW | Featuring Products For Aircraft
gt; R
suggested
4000x
powers down, the system resets and the C90only communicates with the
Phatbox.
Still wondering if that resistor should've been 10k ohms instead of 4.7k
since
Anyone out there with a working spare Sony Phatbox cable they're willing to
pa
rt wit
BR
; Drall
e dralle(at)matronics.com
gt; &g
t; information on how the Phatbox-Sony cables are wired. Note that you *will
need*
the 4.7k ohm resistor between ground and the blue wire. Note the color
coding
The
links are for reference only and you might find you need to interpolate a
gt; little
What P
hatbox Said:
http://www.m
; atro
ni
cs.com/xdp
4000x/
SonyCable5.pdf
different.
anything else, you are going to have operational issues with the xdp-4000x.
BR
; For reference, here is a message from Mike Woo at Phatnoise way back when:
his sy
stem. The
connections
are th
have
ons R (SonyCable5.pdf).
y conn
PhatBox connector.
work
with any multi-devi
gt; &g
t; ce con
figurations.
nitial
ization. Without the pull-down the signal
the
sho
uld th
en force a reset after a few seconds. However, you should listen to
Mike"
BR> BR
925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com
Email
gt; g
t;
com/ W
g
t;
What do you know about the reset line being cut in your diagram? This is
the
only other difference shown in your diagramthat wasn't done in
themodification
of the cable. Here's what they guy that's been doing the work on the unit
for
; me
BR wrote after I contacted him the last time about the 4.7k resistor
not wo
rking:
Well its a pulldown resistor so any value of several k or so should do the
job
5 vs 10 should not ma
tter b
ut I could be wrong. The other thing was that in
the
diagram you showed me the reset line seemed to be cut. I didnt do this
because
lower down it seemed that they fixed that with a firmware update? Im not
sure
if
that would help but you might want to ask Matt. Does it still work when
directly
connected to the head unit?
Does this sound like something that could cause a problem?
-- XDP4000X-List message posted by: bobbybraun(at)comcast.net
g
t; Yes
lled t
he firmware and did a complete system reset
gt; g
t; there, and can control it just fine, but the 4000x just shuts down
whenever
it's
controlled since it is plugged into the 4000x which is shut down when the
Phatbox is plugged in... I just don't know what to do...
he Son
y Phatbox firmware?
Matt
suggested
and
the pr
4000x
Phatbox.
since
worki
gt; R -------------- Original message --------------
ue. Be
need*
nd the
coding
The
little
Wha
t Matt
Found on his cable:
gt;
What Phatbox Said:
http://www.matronics.com/xdp4000x/SonyCable5.pdf
different.
atches
from M
"We changed cable manufacturers since Matt purchased his system. The
connections are the same but the colors are different. You want to connec
t
a
0k res
have
(SonyCable5.pdf).
can b
e seen on the
PhatBox connector.
work
g
t; with any multi-device configurations.
ed for
arbitration during device initialization. Without the pull-down the signal
stays high (+5V) at
all ti
the
to
Mike"
Matt G Drall
e | Ma
gt; &g
t; tronics | PO Box 347 | Livermore | CA | 94551
sugge
sted
4000x
Phatbox.
since
ation.
&g
t; >
gt; wouldn't mind me using to get myself a cable direct from the factory?
I'm
gt; R
need*
gt; &g
t; the 4.7k ohm resistor between ground and the blue wire. Note the color
coding
le you
have.
The
little
numbe
rs and what not:
What Phatbox Said:
http://www.m
atroni
gt; De
pend
different.
ough P
hatManager).
Fo
r refe
lors a
a
have
of the
connections
(SonyCable5.pdf).
y conn
PhatBox connector.
6.00 a
work
gt; g
t
the
g
t; Aft
to
Mike"
BR
gt; &g
t; ;
Matt G Dralle | Matronics | PO Box 347 | Livermore | CA |
BR
; 94551
Produ
cts For Aircraft
Yes, and I even reinstalled the firmware and did a complete system reset
there,
p
l
ugged
controlled since it is plugged into the 4000x which isshut down when the
Phatbox
com
osted
by: Matt Dralle
Matt
suggested
4000x
g
t; powers down, the system resets and the C90 only communicates with the
Phatbox.
istor
s inst
ead of 4.7k since
Anyone out there
with
illing
to
are t
wo links to some
information on ho
w the
need*
coding
The
links are
for re
BR
; you n
little
gt; &g
different.
gt; Are you using version 7.0 Sony firmware on your Phatbox? If you are
using
g
t;
ack wh
en:
gt; R "We changed cable manufacturers since Matt purchased his system.
The
connections are the same but the colors are different. You want to connect
a
have
(SonyCable5.pdf).
PhatBox
conne
ctor.
fied c
able will
work
igurat
ions.
stays
high
the
to
He wo
uld know best ab
out us
ing the C90.
Mike"
06-628
1 F | dralle(at)matronics.com Email
suggested
4000x
d the
C90only c
ommuni
cates with the Phatbox.
since
BR
; Anyone out there with a working spare Sony Phatbox cable they're willing
to
cable
Drall
gt; -- XDP4000X-List message posted by: Matt Dralle
need*
coding
BR
; and what not might be different depending on
the ve
The
little
and w
hat not:
What Phatbox Said:
http://www.m
atroni
cs.com/xdp
4000x/
SonyCable5.pdf
different.
are (u
Matt D
rall
e
e from
a
have
y conn
PhatBox connector.
An unmodified cab
le sho
c
onfigu
work
t is a
the
PhatBo
x
sho
uld th
Mike"
BR
Matt G
Dralle
| Matronics | PO Box 347 | Livermore | CA | 94551
om Ema
il
g
t;
matron
ics.com/xdp4000x-list/download
A | 94
551
m Emai
l
QUOTE
ist/se
arch
cs | P
Ok, I went ahead andclipped thereset wire and nowthe PBactually works in my
system without shutting everything off! BUT... and this is a big but, my
processor is not accepting analog audio at the analog changerinput any longer
(and it used to just fine)... Idid testand there is audio at the outputs of the
PB, but it doesn't sound right at all, tinny and flat, no bass, dull highs.
I threw my cd changerback in to see if my processor would accept analog audio
from that and the analog outputs of that piece are not working any longer
either... (I can't say for 100% that they worked before hand sinc
e I al
ways used
the digital output of the changer, and never tested the analog outputs)
I have yet to try my XM unit, which I know the analog outs used to work on
since those are the only outputs it has and I used it for about 6 months in my
system, but that will have to wait till daylight tomorrow since it's late and
I
don't have the time to wire anything else in tonight.
So I guess the good news is, the PB works now, well sorta. I'm partially
convinced that something is wrong with it's audio outputs because like I said
before it sounds really bad, and now I'm worried that something is broken inside
of my processor as well, but no need to jump to conclusions until I can check
everything out properly tomorrow. At least I made some progress...
e dral
le(at)matronics.com
Cut the reset line on the cable. Sounds to me like the PB is holding that line
down and never letting anyone else init.
Matt
Well, I went and tried every option I could think of within my resources,
short
of unhooking the 4000x and connecting the C30 directly to the C90, then from
it
split out to the 4000x, PB, and my changer and XM respectively. Here's a list
of the attempts and their corresponding outcomes:
Phatbox (PB) plugged directly int
o the
Changer Input of the 4000x: PB powers
up fin
e and is recognized, 4000x disappears and the C90 only sees the PB.
XA-C30 plugged into the Changer Input of the 4000x, PB in Control 1 of C30: PB
powers up fine and is recognized, 4000x disappears and the C90 only sees the
PB.
XA-C30 plugged into the Changer Input of the 4000x, PB in Control 1 of C30,
Changer in Control 2 of C30: PB powers up fine and is recognized, 4000x and
Changer both disappear, C90 only sees the PB.
XT-XM1 in Control 2 of C30: PB powers up fine and is recognized, 4000x and XM
Radio both disappear, C90 only sees the PB.
XT-XM1 plugged into the Changer Input of the 4000x, PB plugged into input of
XT-XM1: PB Powers up fine and is recognized, 4000x and XM Radio both
disappear,
BR>>
gt; g
t;Both the Changer (CDX-848X) and XM radio work perfectly when connected into
the
system without the PB.
Basically anything that is run inline before AND after the Phatbox is shut
down
and ignored by the system. Power is cut to all connected units on both sides
besides C90 and PB when the PB is plugged in. Bottom line, I didn't learn a
thing from any of this and am no further ahead in figuring out what the
problem
is...lol
Matt, I may just take you up on your offer to test out my PB in your system,
but before I go that route I'm going to try a couple more things. I'm going to
have the cable modified one last time with a 10k resistor and the reset line
cut. Plus I'm going to blow another $100 on a used but factory original PB
gt; ca
ble from someone in Europe who is unable to tell me the origin (other than
it
was made by Phatnoise) or age o
f the
cable so I don't know how recent it has
been made (but given my recent luck I'm sure it'll be one of the old cables
that
were made before the modification was put in place.
I'm just glad I didn't have anything sharp or blunt near me after I finished
all these tests, if there had been who knows what the outcome would've been!
Ahhhh!
Well, if you're handy with a soldering iron, I would try both the higher
resistor and the reset line options. Neither will hurt the equi
pment.
Well,
unless you miss wire something... :-)
The Phatbox has a bad habit of insisting on being the first CDChanger sla
ve
on
the bus. Each class of accessory you can hook up the the Unilink Bus (UB) has
a
class that it falls into. Here are some Unilink device classes along with
some
examples:
CD Changer: CD Changers, Phatbox, XA-300
MD Changer: MD Changers, XM Radio (original Sony box)
Tuners: TV Tuner, Internal AM/FM Tuner
Processors: 210, 4000x, internal Bass/Treble
On system start up, the Head Unit (HU) sends out a broadcast asking for each
device class on the UB. Each device of the given class will respond with "I'm
Here" and the HU will respond back to the an "dynamic" address for that
pa
rticul
ar device to use. The address is a combination of the device class
(high nibble) and the device's assigned address on the UB (lo
w nibb
le).
An abbreviated version of this little "dance" occurs each time the HU is
powered
up. If the HU discovers that there is anything different (new or missing
device) from the last time it started, it will reset the bus (both a protocol
sequence as well as dropping the Reset wire) and start a whole new bus
address
negotiation.
The actual address of the device is determined by its location on the bus.
The
closer a device is to the HU the lower its address will be. Basically what
happens on startup is that the first device on the UB disables bus
connectivity
to all of the slaves down stream until i
t rece
ives an address from the HU. On
the XA-C30, logically each respective port looks like a device in the stream,
so
negotiation goes from Port 1 to Port 2 to Port 3.
The Phatbox for some stupid reason, insists on being address 1 in the CD
Changer
class so you have to be really careful that it is either directly plugged
into
the HU or is on Port 1 of the first XA-C30 in the chain.
That being said, this addressing limitation shouldn't be conflicting with the
4000x in your system since they are different classes of devices, but I
wanted
to point out the caveat with the Phatbox addressing since it took me a while
to
figure that out. I asked Mike Woo at Phatnoise why they hard coded the
addressing that way, but I did
n't re
ally get an answer back. I've written an
embedded processor Unilink Slave emulator that runs on an 8051-compatible
microco
ntroll
er and I was able to write a negotiation routing that is 100%
compatible with the master/slave addressing algorithm, so if I can do it,
surly
Phatbox could.
If you'd like, you can send me your Phatbox and I can give it a try here on
my
two installations to see if the problem is the Phatbox or something else.
Matt
I actually do have one a XA-C30, and during my initial installation I tried
using it with the Phatbox just to see if it had an effect. This last time I
did <
BR> not try it with it installed however so I'll give it another try.
g
t;
;So you don't think the reset line in your diagram or a higher value resistor
could be the problem, huh?
Do you have an XA-C30 multiplexer? On both of my installations, I am
plugging
the Phatbox into the system using one of these. Basically
C90-4000-C30-Phatbox. I don't know if I've ever tried plugging the
Phatbox
directly into a 4000. Seems like I must have tried that at some point, but
I
can't remember for sure. You might be able to talk me in to loaning you a
XA-C30 if you pr
&g
t; >
; omise
on your mama's grave to return it... ;-)
Matt
the
only other difference shown in your diagram that wasn't done in the
modification
for
me wrote after I contacted him the last time about the 4.7k resistor not
working:
the >
; it's
the
XDP400
Matt
as
suggested
; in <
BR> my
4000x
powers
down,
Phatbox.
4.7k
since
willing
to
someone
I'm
BR>>
; Okay, here's some help on this cable issue. Below are two links to
some
you
*will
need*
color
coding
on of
cable
you
have.
The
interpolate
a
little
00x/So
nyCable5.pd
f
little
different.
are
using
xdp-4000x.
PhatManager).
gt; g
t;
back
when:
The
rent.
You want to
connect
a
wires.
I
have
(SonyCable5.pdf).
g
t;
seen
on
the
PhatBox connector.
unit.
multi-device
cable
will
work
bus m
&g
t; >
;aster signal. It is an input. It is
used
for
the
signal
knowing
when
is
the
The
PhatBox
listen
to
g
t;
; Matt regarding pushing reset. He would know best about using the
C90.
Mike"
gt; 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email
BR
as
suggested
in
my
4000x
Phatbox.
4.7k
since
Anyone out there with a working spare Sony Phatbox cable they're http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf
What Phatbox Said:
http://www.m
atroni
little
different.
using
gt; anything else, you are going to have operational issues with the
xdp-4000x.
7.0 S
PhatManager).
back
when:
The
connect a
g
t;
; 10k resistor between the blue (bus master) and orange (ground)
wires.
I
have
(SonyCable5.pdf).
y conn
PhatBox connector.
nnecte
d to a head
unit.
multi-device
configuration
s. I'm
cable
will
work
used
for
signal
when
is
the
and t
hen shutdown. The
PhatBox
should then force a reset after a few seconds. However, you should <
BR>>
; listen
to
C90.
Mike"
BR
925-606-1001 V | 925-606-6281 F | dralle@m
atroni
cs.com Email
craft
reset
is
there,
it's
the
Phatbox
gt;
; -------------- Original message --------------
ion of
Matt
suggested
in http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf
different.
g
t;
using
xdp-4000x.
PhatManager).
g
gt; t;
when:
conne
ct
a
have
(SonyCable5.pdf).
the
PhatBox connector.
dified
cable
will
work
g
t; igurat
ions.
for
signal
when
is
the
PhatBox
listen
to
st abo
ut using the C90.
Mike"
gt;
gt; suggested
my
4000x
Phatbox.
4.7k
since
ng spa
willing
to
someone
I'm
gt; running out of options here. Can anybody help?
Drall
*will
need*
coding
ent de
pendi
ng on
have.
The
a
little
What Phatbox Said:
http://www.m
atroni
cs.com/xdp
4000x/
SonyCable5.pdf
different.
using
anyth
ing el
xdp-4000x.
PhatManager).
when:
"We
chang
connect
a
have
y conn
PhatBox connector.
gt; An unmodified cable should work when directly connected to a head unit.
orks w
will
work
for
signal
when
is
the
PhatBox
sho http://www.matronics.com/ WWW | Featuring Products For Aircraft
g
t;
gt;
; What do you know about the reset line being cut in your diagram? This is
the
themodification
for
me
working:
the
job
5 vs 10 should not matter but I could be wrong. The other thing was that
in
the
because
lower dow
n it s
mware
update? Im not
sure
if
directly
is
s down
whenever
it's
recogn
ized and
the
he Son
y Phatbox firmware?
Matt
At
07:27
suggested
my
4000x
and th
Phatbox.
since
to
par
t with
someone
I'm
information
on how
*will
need*
tween
coding
have.
The
a
little
Wha
t Matt
Found on his cable:
gt; Depending on what version of cable you have, things might be a little
diffe
rent.
using
xdp-4000x.
PhatManager).
from M
"We chang
ed cab
connect
a
have
of the
connections
(SonyCable5.pdf).
the
PhatBox connector.
irmwar
will
work
g
for
signal
is
the
ize it
self.
PhatBox
listen
g
t;
to
Mike"
Matt G Drall
e | Ma
as http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf
What Phatbox Said:
http://www.m
atroni
gt; cs
different.
using
xdp-4000x.
PhatManager).
Fo
r refe
co
nnect
gt; a
have
(SonyCable5.pdf).
y conn
PhatBox connector.
will
work
g
t;
; gt; g
for
tializ
signal
is
the
PhatBox
listen
to
BR>
is
there,
it's
pl
ugged
Phatb
d and
Phatbox
Matt
suggested
my
4000x
only
Phatbox.
s inst
ead of 4.7k since
Anyone out there
with
so
meone
I'm
Phatbo
*will
need*
coding
on the
have.
The
links are
for re
you n
little
Depending on what version of cable you have, things might be a little Use the drawing that matches best your installation.
using
xdp-4000x.
PhatManager).
g
t;
when:
system. the
PhatBox
listen
to
g
t;
Mike"
s
u
ggest
ed
my
4000x
ommuni
since
to
someone
I'm
p?
Drall
e dralle@matron
ics.co
m
*will
need*
coding
BR
; and what not might be different depending on the version of cable you
have.
The
a
little
What Phat
box Sa
id:
http://www.m
atroni
cs.com/xdp
4000x/
SonyCable5.pdf
different.
using
xdp-4000x.
PhatManager).
Matt Drall
e
when:
connections are t
he sam
connect
a
have
y conn
PhatBox connector.
will
work
gt; t is a
signal
is
the
PhatBox
sho
uld th
Matt regardi
ng pus
Mike"
BR
http
://www
gt;
g
t;
matron
x 347
925-606-1001 V | 925-606-6281 F | dralle@mat
ronics
.com Email
did
-- XDP
plugging
using
C90-4000-C30-Phatbox. I don't know if I've ever tried plugging the Phatbox
I
XA-C30 if you promise on your mama's grave to return it... ;-)
Matt
What do you kn
ow abo
ut the reset line being cut in your diagram? This is the
modification
for
him t
working:
job
5 vs 10 should not matter but I could be wrong. The other thing was that in
the
because
sure
if that would help but you might want to ask
Matt.
directly connected to the head unit?
--- R From: bobbybraun(at)comcast.net
there, and can control it just fine, but the 4000x just shuts down whenever
it's
BR
; Phatbox is plugged in... I just don't know what to do...
of the
Matt
-- XDP4000X-Li
st mes
suggested
4000x
Phatbox.
since
to
gt;
; part with for some cash, or a photo of the bottom of a Sony PB that
someone
BR>>
y: Mat
t Dralle
*will
need*
coding
and what
not mi
have.
The
a
little
gt; &g
t; /xdp40
different.
stalla
tion.
using
xdp-4000x.
PhatManager).
For r
eferen
when:
ince M
connect
a
orang
e (ground) wires. I
have
(SonyCable5.pdf).
the
PhatBox connector.
unmod
will
work
ignal.
for
g
t;
; arbitration during device initialization. Without the pull-down the
signal
is
the
PhatBox
second
listen
to
Mike"
gt; Ma
tt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551
alle@m
atronics.com Email
suggested
as th
4000x
Phatbox.
since
gt; g
t;Anyone out there with a working spare Sony Phatbox cable they're willing
to
ect fr
om the factory? I'm
matron
ics.com
need*
wire.
Note the color
coding
have.
The
little
BR
; http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf
What Phatbox Said:
http://www.m
atroni
d
iffere
nt.
xdp-4000x.
PhatManager).
oo at
Phatnoise way back
when:
connect a
orang
e (ground) wires. I
have
(SonyCable5.pdf).
y conn
PhatBox connector.
tly co
will
work
a
rbitra
signal
is
the
PhatBox
sho
uld th
to
Mike"
BR
ore |
CA | 94551
BR
a comp
lete system reset
there,
and can c
ontrol
Phatb
ox
Matt
by: bo
suggested
; and
4000x
Phatbox.
since
Anyone out there
with
ssage
-- XDP4000X
-List
message posted by:
Matt
Dralle
need*
coding
The
you n
little
g
t;
.pdf <
BR>
different.
g
t;
when:
connections
are th
I
have
(SonyCable5.pdf).
PhatBox connector.
work
BR with any multi-device conf
igurat
ions.
n. Wit
the
gt; right time to initialize itself.
to
Mike"
gt;
gt; R
suggested
s soon
4000x
Phatbox.
Still wondering if that resistor should've been 10k ohms instead of 4.7k http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf
What P
hatbox Said:
http://www.m
atroni
cs.com/xdp
4000x/
SonyCable5.pdf
&g
t;
different.
connections
are th
are di
have
att
ached
y conn
PhatBox connector.
work
ed for
nitial
the
ize it
self.
sho
uld th
Mike"
BR
e | CA
| 94551
gt; g
t;
&g
t; Mat
g
t;
What Phatbox Said:
http://www.matroni
cs.com
different.
atches
from M
a
ue (bu
have
(SonyCable5.pdf).
can b
e seen on the
PhatBox connector.
ectly
work
g
s trou
ble knowing when is
the
g
t;
; to
Mike"
Matt G Drall
e | Ma
s
suggested
gt; 4000x
Phatbox.
since
ation.
I'm
&g
t; >
BR -- XDP4000X-List message posted by: Matt Dralle
need*
coding
le you
have.
The
little
numbe
rs and what not:
What Phatbox Sa
id:
http://www.m
atroni
different.
ough P
hatManager).
g
t; Fo
r refe
erent.
You want to connect
a
have
(SonyCable5.pdf).
y conn
PhatBox connector.
simpl
e multi-device
6.00 a
work
gt; g
vice i
the
to
would
Mike"
BR
BR
; 94551
BR>>
rmore
| CA | 94551
there,
p
l
ugged
ich is
shut down when the
Phatbox
what
to do...
Matt
suggested
4000x
g
s and
the C90 only communicates with the <
BR>>
; Phatbox.
s inst
ead of 4.7k since
Anyone out there
with
BR
; Okay, here's some help on this cable issue. Below are two links to some
information on ho
w the
red. N
ote that you *will
need*
coding
The
links are
for re
you n
little
different.
Use the drawing that matches best your installation. <
BR>>
using
g
t;
se way
back when:
The
a
have
(SonyCable5.pdf).
BR>>
; The numbers can not be seen on the Sony connector. They can be seen on the
PhatBox
conne
ctor.
unmod
ified cable will
work
igurat
ions.
stays
high
the
t and
to
He wo
g
t;
Mike"
suggested
4000x
reset
s and the C90only c
ommuni
cates with the Ph
atbox.
since
BR
to
Drall
; Okay
s cabl
need*
coding
BR
the ve
The
little
What Phatbox Said:
gt; g
t;
http://www.m
atroni
cs.com/xdp
4000x/
SonyCable5.pdf
BR> Depending on what version of cable you have, things might be a little
different.
are (u
Matt Drall
e
o at P
a
&g
t; have
y conn
PhatBox connector.
c
onfigu
ra
work
t is a
ing wh
en is
the
sho
uld th
BR
; Regards,
Mike"
BR
Matt G
Dralle
BR>
925-606-100
1 V |
g
t;
matron
A | 94
551
QUOTE
gt;
gt; &g
t;
short
itsplit out to the 4000x, PB, and my changer and XM respectively. Here's a
list
Phatbox (PB)plugged directly into the Changer Input of the 4000x: PB powers up
fine and is recognized, 4000x disappears and the C90 only sees the PB.
30:
PB
PB.
disappear,
the
&g
t;
x is s
hut down
and ignored by the system. Power is cut to allconnected units on both
sidesbesides C90 and PB when the PB is plugged in. Bottom line, I didn't learn
a
thing from any ofthis and am no further ahead in figuring out what the problem
is...lol
cut. Plus I'm going to blow another $100 on a used butfactory original PBcable
from someone in Europe who is unable to tell me the origin (other than it was
made by Phatnoise) or age of the cable so I don't know how recent it has been
&g
t; made (but given my recent luck I'm sure it'll be one of the old cables that
were
g
t;
;I'm just glad I didn't have anything sharp or blunt near me after I finished
Ahhhh!
resistor and the reset line options. Neither will hurt the equipment. Well,
DChang
er slave
on
a
some
examples: *will
need*
color
coding
have.
The
gt; g
t; links are for reference only and you might find you need to
interpolate
a
little
ble:
BR
different.
gt; Us
&g
t; >
; e the drawing that matches best your installation.
using
xdp-4000x.
PhatManager).
when:
nufact
g
t;
connect
a
I
have
descri
(SonyCable5.pdf).
on
the
PhatBox connector.
unit.
co
nfigur
will
work
gt;
for
signal
when
; is <
BR> the
PhatBox
should the
n forc
listen
to
Mike"
-6281
BR
sugg
ested
my
4000x
Phatbox.
since
willing
to
so
meone
woul
dn't m
I'm
some
*will
need*
coding
have.
The
interpolate a
little
; with
What Phatbox Sa
id:
http://www.m
atroni
different.
using
xdp-4000x.
PhatManager).
Fo
r refe
when:
connections are
the sa
connect a
I
have
(SonyCable5.pdf).
y conn
PhatBox connector.
unit.
Firmw
unmod
ified cable
will
work
for
signal
when
is
the
g
t; PhatBox
listen
to
Mike"
BR
rustra
ting, the C9
0 know
s the Phatbox is
there,
plugged in. I
find
Phatbox
Matt
At 0
7:27 P
as
suggested
4000x <
BR>>
Phatbox.
since
Anyone out there
with
hat http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf
diff
erent.
If yo
u are using
xdp-4000x.
PhatManager).
g
t;
a
; have
ption
of the connections
(So
nyCabl
e5.pdf).
PhatBox connector.
work
igurat
ions.
gt; is
; the
right
time t
PhatBox
to
Mike"
Produc
ts For Aircraft
suggested
here..
4000x
Phatbox.
since
to
someone
wouldn
Drall
gt;
BR Okay, here's some help on this cable issue. Below are two links to some
need*
coding
have.
g
t;
The
little
What Phatbox Said:
http://www.m
atroni
cs.com/xdp
4000x/
SonyCab
le5.pd
f
different.
xdp-4000x.
PhatManager).
a
wires
. I
have
attach
y conn
PhatBox connector.
work
PhatB
ox has tro
uble k
nowing when
is
the
right
PhatBox
sho
uld th
Mike"
BR
g
t;
t the
themodification
of the cable. Here's what they guy that's been doing the work on the unit for
me
working:
or so
should do the
job
as tha
t in
the
because
lower down it seemed that they fixed that with a firmware update? Im not sure
if
directly
afterwards, all
to no
never
it's
he Son
y Phatbox firmware?
Matt
Well I
had t
suggested
my
g
t; g
t; inf
need*
coding
The
little
Wha
t Matt
Found on his cable:
What Phatbox Said:
gt;
different.
from M
a
; g t;
; 10k resistor between the blue (bus master) and orange (ground) wires. I
have
(SonyCable5.pdf).
g
t;
PhatBox connector.
work
g
a
own th
e signal
the
; shou
to
Mike"
Matt G Drall
e | Ma
@matro
nics.com Email
gt; We
suggested
4000x
Phatbox.
gt; St
since
BR
I'm
ge ---
gt; need*
coding
The
g
t; links are for reference only and you might find you need to interpolate a
little
numbe
rs and what not:
-Cable
-Rev1.pdf
What Phatbox Said:
http://www.m
atroni
different.
Are y
Fo
r refe
connec
a
have
(SonyCable5.pdf).
g
t;
;gt; y conn
PhatBox connector.
work
gt; g
t is a
the
eset a
to
Mike"
BR
94551
| Fea
.com/
there,
pl
ugged
e reco
gnized and
gt; g
t; controlled since it is plugged into the 4000x which isshut down when the
Phatbox
the S
Matt
suggested
n as t
4000x
gt; powers down, the system resets and the C90 only communicates with the
Phatbox.
s inst
ead of 4.7k since
Anyone out there
with
two l
inks to some
need*
coding
The
links are
for re
you n
little
pin nu
mbers and what not:
om/xdp
be a
little
different.
g
t;
when:
The
a
have
attached a PDF w
ith a
(SonyCable5.pdf).
PhatBox connector.
wor
k
igurat
io
ns. http://www.matronics.com/ WWW | Featuring Products For Aircraft
suggested
s the
4000x
ommuni
s
ince
r
Drall
BR> Okay, here's some help on this cable issue. Below are two links to some
*will
need*
coding
BR
have.
The
little
gt; Wh
What Phatbox Said:
http://www.m
atroni
cs.com/xdp
&g
t; >
; 4000x/
SonyCable5.pdf
g
t;
different.
Matt Drall
e
y back
when:
gt;
a
have
y conn
PhatBox connector.
work
g
t;
t is a
the pu
ll-down the signal
the
sho
uld th
Mike"
BR
g
6-6281
g
t;
matron
gt; ics.com/xdp4000x-list/download
925-606-1001 V |
925-60
gt;
did
Drall
Do you have an XA-C30 multiplexer? On both of my installations, I am plugging
g
t; the
e ever
directly into a 4000. Seems like I must have tried that at some point, but I
Matt
What do you kn
ow abo
o
modification
ted hi
working:
gt; Well its a pulldown resistor so any value of several k or so should do the
job
the
because
if that would help but you might want to ask Matt. Does it still work when
gt; g
t; --- http://www.matro
nics.c
om/xdp4000x/U
nilink
different.
stalla
tion.
using
xdp-4000x.
PhatManager).
when:
"We changed
cable
ma
nufact
g
t; connections are the same but the colors are different. You want to
connect
a
orang
e (ground) wires. I
have
(SonyCable5.pdf).
the
PhatBox connector.
will
work
The problem is
with t
t is a
n input. It is used
BR
; for
g
t;
signal
is
the
PhatBox
listen
to
Mike"
gt; Ma
551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Ema
il
h
ttp://
suggested
4000x
Phatbox.
since
gt; g
to
someon
e
runnin
need*
wire.
Note the color
coding
have.
The
little
http:
/www.m
What Phatbox Said:
http://www.m
atroni
d
iffere
nt.
xdp-4000x.
PhatManager).
gt; Matt Dralle
when:
ufactu
his s
ystem. The
connect a
orang
e (ground) wires. I
have
(SonyCable5.pdf).
y conn
PhatBox connector.
-devic
e
will
work
e bus
a
rbitra
signal
is
the
PhatBox
to
gt; Mi
ke"
BR
ore |
CA | 94551
matron
ics.com Email
Aircra
ft
d did
a comp
lete system reset
there,
odd t
shut d
own when the
Phatbox
Matt
- XDP4
by: bo
suggested
4000x
Phatbox.
or sho
since
Anyone out there
with
Can a
nybody help?
ssage
gt; information on how the Phatbox-Sony cables are wired. Note that you *will
need*
Note
the color coding
The
you n
little
g
t;
different.
Use t
he dra
ave op
g
t;
"We chan
ged ca
connections
are th
10k resistor between the blue (bus master) and orange (ground) wires. I have
(SonyCable5.pdf).
The
numbe
PhatBox connector.
Firmware
5.00
work
igurat
ions.
bus m
n. Wit
the
g
t; sho
uld then force a reset after a few seconds. However, you should listen to
Mike"
g
t;
&g
t; gt;
gt; http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf
What P
hatbox Said:
http://www.m
atroni
cs.com/xdp
4000x/
SonyCable5.pdf
different.
BR
ck whe
connections
are th
y conn
ector. They c
an be
seen on the
PhatBox connector.
work
with any multi-devi
ce con
figurations. <
BR>>
nitial
the
sho
uld th
wever,
Mike"
BR
925-606-1001 V | 925-606-6281 F | dralle@matr
onics.
com
Email
gt; g
t;
Aircr
aft
g
t;
What do you know about the reset line being cut in your diagram? This is the
themodification
of the cable.
Here's
; me
not wo
rking:
job
the
because
date?
Im not sure
if
directly
g
t; Yes
gt; g
whenever
it's
which
&g
t;
he Son
y Phatbox firmware?
Matt
suggested
and
the pr
4000x
; Phat
box.
since
re wil
ling to
gt;
different.
atches
(upgra
from M
t
a
have
(SonyCable5.pdf).
can b http://www.matronics.com/ WWW | Featuring Products For Aircraft
sugge
sted
4000x
powers down, the system resets and the C90only communicates with the Phatbox.
ms ins
tead of 4.7k
since
ation.
gt; wouldn't mind me using to get myself a cable direct from the factory? I'm
What Phatbox Said:
http://www.m
atroni
Depend
different.
y firm
operat
ough P
hatManager).
Fo
r refe
connections are the same but the colors are different. You want to connect a
of the
connections
(SonyCable5.pdf).
y conn
g
t;
; PhatBox connector.
; An u
6.00 a
work
gt; g
the
g
t; Aft
u shou
ld listen to
M
Mike"
BR
BR
; 94551
cts Fo
gt;r A
ircraft
there,
p
l
ugged
Phatbox
osted
by: Matt Dralle
Are you running the 7.0 vers <
BR>>
; ion of
Matt
suggested
4000x
g
Phatbox.
s inst
ead of 4.7k since
Anyone out there
with
illing
to
part with for some
cash,
ttom o
information on ho
w the
need*
the 4.7k ohm resistor between ground and the blue wire. Note the color coding
The
links are
for re
BR ; you n
eed
to int
erpolate a
little
different.
gt; Are you using version 7.0 Sony firmware on your Phatbox? If you are using
Matt Dral
le
g
t;
g
t;
gt;
925-606-1001
V | 92
5-6
06-628
suggested
4000x
ommuni
since
BR
a wor
wouldn'
t mind
cable
Drall
need*
BR
nt dep
ending on
the ve
The
littl
e
and w
hat not:
What Phatbox Said:
http://www.m
atroni
cs.com/xdp
4000x/
SonyCable5.pdf
different.
ing to
are (u
Matt Drall
e
e from
ons An unmodified cable should work when directly connected to a head unit.
c
onfigu
rmware
work
t is a
the
sho
uld th
wever,
Mike"
BR
Matt
G
Dralle
om Ema
il
htt
p://ww
g
t;
matron
g
t;
A | 94
551
m Emai
l
http://www.ma
tronic
ist/se
arch
g
t; htt
Subject: | Re: Phatnoise Connection Problem - Help?! |
It WORKS!!!! After lots of tinkering I finally got it to play, and it's works
flawlessly and sounds just as good as I'd expect!
The only thing I can think of that was causing it to act funny last night was maybe
because I had a low battery which in the end caused all of the oddities with
my equipment, because everything works as it should now including the analog
outputs on my CD Changer... My optima battery is on it's 7th year now, and
my alternator doesn't do very well when running at idle so after all the tinkering
last night, when I went to start my car this AM the battery was dead.
The first thing I did this morning was hook up my XM adapter to test my analog
inputs on the processor, and it worked perfectly (almost too perfectly considering
I cancelled my service back in December and it's still working ha ha...)
And is it just me, or does XM sound even WORSE than ever?!! I can't believe I
ever even paid for service that sounded so bad. Wow. Even though right now
I could listen to it for free, after hearing how bad it sounds I know I'd never
even bother turning it on, so right now it's unhooked and boxed up in my closet
for storage until I find someone who wants to take it off my hands lol.
Matt I want to thank you so much for all your help with this, I never would've
figured it out on my own! After running into all these problems maybe we did
learn a little something about how the Phatbox intergrates into a Sony system.
First off, the reset line has to be cut in order for a PB to work with a processor,
but seems to work fine as a single Unilink source directly connected to
a compatible head unit with the reset wire still connected. And another thing
that came up before that I'd like to point out, the Phatbox does work when
directly connected to my 4000x. I do not have my XA-C30 permanently installed
yet so the PB is my only external music source at this time. I am now curious
however if the thing would've worked fine without the pulldown resistor installed
if the reset line had been cut the entire time. Regardless, wow what an
ordeal and I'm so glad it's over.
Now a couple questions about usage. How much should I be concerned about heat,
cold and vibration affecting the DMS cartridge? Where I live there are some
extreme cold temperatures, and we all know how hot it can get in the trunk of
a car. I have it mounted with rubber grommets on a wooden carpeted surface, so
vibration should be at a minimum but I just thought I'd ask since you've been
using one of these for a while. And another thing, is there an easy way to
navigate through the countless number of albums you have at your disposal? I
haven't really sat down to use the thing yet, and haven't even listened to an
entire song yet, so I'm just wondering if there are any tricks to setting it up
to get the most out of the unit?
Thanks again for everything, now I can't wait to go on a long roadtrip and listen
to an endless amount of music! HA HA HA!
> Yes, I've thought about all that already, but here is the thing, I can't get
any
> audio to be recognized by the 4000x through it's Analog Changer Inputs. The
> only reason I know it sounds bad is because I hooked a set of headphones up to
> the phatbox to test if any audio was present and when I listened it sounded
> horrible, (if not mono). I listened to the same exact mp3 file that was being
> played on the PB back inside on my computer through the same headset using the
> crappy non 24bit burr brown outputs of my laptop and it sounded 1000x more full
> and realistic, so that worries me. And the fact that I can't get any audio to
> play back when plugged into the analog changer inputs worries me even more, I
> really hope this thing didn't somehow damage my 4000x, there is no way I want
to
> send it off to Sony and let them hack away at it like they did with my last C90
> I sent them...
> I have done a full reset from the C90 and still nothing. I'll test out my other
> equipment that I know was working beforehand tomorrow and then I'll know more,
> but that still doesn't change the issue with the terrible sound output of the
> PB.
> From: Matt Dralle
> > Great news!
> > Couple of things come to mind with respect to your new audio woes. Digital
vs
> > Analog input on the 4000x is only negotiated on reset (button on C90), so with
> > all the plugging around, make sure that you set things up like you want, then
> > press that reset button.
> > Second, the "tinny" sound might be because you've selected an unprogrammed
> > EQ/Xover setting on the 4000x. The default setting has some of the Xover
> > settings off or highly attenuated.
> > Plug your PC back into the 4000x and double check all of your EQ and XO memory
> > locations, and then make sure you select the right ones on the HU.
> > Almost there!
> > Matt
> > At 08:13 PM 4/18/2006 Tuesday, you wrote:
> > >Ok, I went ahead and clipped the reset wire and now the PB actually works
in
> my
> > processor is not accepting analog audio at the analog changer input any longer
> > (and it used to just fine)... I did test and there is audio at the outputs
of
> > the PB, but it doesn't sound right at all, tinny and flat, no bass, dull
> highs.
> > >I threw my cd changer back in to see if my processor would accept analog
> audio
> > either... (I can't say for 100% that they worked before hand since I always
> used
my
> I
> inside
> > >From: Matt Dralle
> > line
> > >> Matt
> > short
> from
> > it
> list
> > >> >Phatbox (PB) plugged directly into the Changer Input of the 4000x: PB
> powers
> > >> up fine and is recognized, 4000x disappears and the C90 only sees the PB.
> C30:
> > PB
> the
> > PB.
> C30,
and
> C30,
> XM
> of
> > disappear,
> into
> > the
> > down
> sides
a
> > problem
> > >> is...lol
> system,
> > to
> line
PB
> > >> cable from someone in Europe who is unable to tell me the origin (other
> than
> > it
> > >> was made by Phatnoise) or age of the cable so I don't know how recent it
> has
> > that
> finished
> been!
> > >> Ahhhh!
> > >> >From: Matt Dralle
> > Well,
> > slave
> > >> on
> (UB)
> > has
> > >> a
> with
> > >> some
> > >> >> examples:
> > each
> > "I'm
> > >> >> particular device to use. The address is a combination of the device
> class
> > >> >> (high nibble) and the device's assigned address on the UB (low nibble).
is
> > >> powered
> > protocol
> > >> address
> > >> >> negotiation.
> bus.
> > >> The
> what
> > >> connectivity
> > >> >> to all of the slaves down stream until it receives an address from the
> HU.
> > On
> > stream,
> > >> so
CD
> > >> Changer
> plugged
> > >> into
> with
> > the
I
> > >> wanted
a
> > while
> > >> to
> > >> >> addressing that way, but I didn't really get an answer back. I've
> written
> > an
> 8051-compatible
> > >> >> microcontroller and I was able to write a negotiation routing that is
> 100%
> it,
> > >> surly
> > >> >> Phatbox could.
> > on
> > >> my
> else.
> > >> >> Matt
I
> > tried
> time
> > I
> > >> did
> > resistor
> > >> >> >From: Matt Dralle
am
> > >> plugging
> > >> >> >> C90->4000->C30->Phatbox. I don't know if I've ever tried plugging
the
> > >> Phatbox
> point,
> > but
> > >> I
> you
> > a
> > >> >> >> Matt
> This
> > is
> > >> the
> > >> >> modification
> > unit
> > >> for
> > not
> > >> >> >> working:
> do
> > >> the
> > >> >> job
> > that
> > >> in
> > >> >> the
> this
> > >> >> because
Im
> > not
> > >> sure
> > when
> > >> reset
> > Phatbox
> > >> is
> > >> >> whenever
> > >> >> >> it's
> > and
> > when
> > >> the
> > >> >> >> >> From: Matt Dralle
> > >> >> >> >> > Matt
> > installed
> > >> as
> > >> >> >> >> suggested
> > plugged
> > >> in
> > >> >> my
> > >> >> >> >> 4000x
> with
> > the
> > >> >> >> Phatbox.
> > of
> > >> 4.7k
> > >> >> >> since
> they're
> > >> >> willing
> > >> >> >> to
> > that
> > >> >> someone
> > factory?
> > >> >> I'm
> > >> >> >> >> > >From: Matt Dralle
> links
> > to
> > >> >> some
> that
> > >> you
> > >> >> >> *will
> > >> >> >> >> > need*
> > the
> > >> >> color
> > >> >> >> >> coding
> > cable
> > >> you
> > >> >> >> have.
> > >> >> >> >> > The
> > >> >> interpolate
> > >> >> >> a
> > >> >> >> >> > little
be
> a
> > >> little
> > >> >> >> >> > different.
> you
> > >> are
> > >> >> >> using
> > the
> > >> >> >> xdp-4000x.
> > >> >> >> PhatManager).
> > >> >> >> >> > >> Matt Dralle
> way
> > >> back
> > >> >> >> when:
> > system.
> > >> The
> want
> > to
> > >> >> >> connect
> > >> >> >> >> a
> (ground)
> > >> wires.
> > >> >> I
> > >> >> >> >> have
> > >> >> >> >> > (SonyCable5.pdf).
> be
> > >> seen
> > >> >> on
> > >> >> >> the
> > >> >> >> >> > >> PhatBox connector.
a
> > head
> > >> >> unit.
> > >> multi-device
> unmodified
> > >> cable
> > >> >> >> will
> > >> >> >> >> > work
It
> > is
> > >> used
> > >> >> >> for
> pull-down
> > >> the
> > >> >> >> signal
> > >> knowing
> > >> >> when
> > >> >> >> is
> > >> >> >> >> > the
> shutdown.
> > >> The
> > >> >> >> PhatBox
> > should
> > >> >> >> listen
> > >> >> >> >> to
> > the
> > >> C90.
> > >> >> >> >> > >> Regards,
> > >> >> >> >> > >> Mike"
> 94551
> Aircraft
> > installed
> > >> as
> > >> >> >> >> suggested
> > plugged
> > >> in
> > >> >> my
> > >> >> >> >> 4000x
> > the
> > >> >> >> Phatbox.
> > of
> > >> 4.7k
> > >> >> >> since
> they're
> > >> >> willing
> > >> >> >> to
> > that
> > >> >> someone
> > factory?
> > >> >> I'm
> > >> >> >> >> > >From: Matt Dralle dralle(at)matronics.com
> links
> > to
> > >> >> some
> that
> > you
> > >> >> *will
> > >> >> >> >> > need*
> the
> > >> color
> > >> >> >> >> coding
> > cable
> > >> you
> > >> >> >> have.
> > >> >> >> >> > The
> > >> >> interpolate a
> > >> >> >> >> > little
> > >> >> >> >> > > What Phatbox Said:
> > >> >> >> >> > > http://www.m
> > >> >> >> >> > > atroni
a
> > >> little
> > >> >> >> >> > different.
> you
> > are
> > >> >> using
> the
> > >> >> >> xdp-4000x.
> > >> >> >> PhatManager).
> > >> >> >> >> > > Matt Dralle
> way
> > >> back
> > >> >> >> when:
> system.
> > >> The
> want
> > to
> > >> >> >> connect a
> > >> wires.
> > >> >> I
> > >> >> >> have
> > >> >> >> >> > (SonyCable5.pdf).
> > >> >> >> >> > > y conn
> > >> >> >> >> > > PhatBox connector.
a
> > head
> > >> >> unit.
> > >> multi-device
> unmodified
> > >> cable
> > >> >> >> will
> > >> >> >> >> > work
It
> is
> > >> used
> > >> >> for
> pull-down
> > the
> > >> >> >> signal
> > knowing
> > >> >> when
> > >> >> >> is
> > >> >> >> >> > the
> shutdown.
> > The
> > >> >> >> PhatBox
> > should
> > >> >> listen
> > >> >> >> to
> the
> > >> C90.
> > >> >> >> >> > > Regards,
> > >> >> >> >> > > Mike"
> > >> >> >> >> > > BR>>
> 94551
> Aircraft
> > >> >> >> >> > Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551
> > >> reset
> > Phatbox
> > >> is
> > >> >> >> there,
> whenever
> > >> it's
> > and
> when
> > >> the
> > >> >> >> Phatbox
> > >> >> >> >> Matt
> > as
> > >> >> >> suggested
> plugged
> > in
> > >> my
> > >> >> >> 4000x
> > the
> > >> >> >> Phatbox.
> of
> > >> 4.7k
> > >> >> >> since
> > >> >> >> >> Anyone out there
> > >> >> >> >> with
> that
> > >> >> someone
> > factory?
> > >> I'm
> > >> >> >> >> From: Matt Dralle
to
> > some
> you
> > >> *will
> > >> >> >> >> need*
> > color
> > >> >> coding
> > you
> > >> >> have.
> > >> >> >> >> The
> > >> >> >> >> you n
> > >> >> >> >> little
> > little
> > >> >> >> >> different.
> are
> > >> using
> > >> >> xdp-4000x.
> > >> >> PhatManager).
> > >> >> >> >> Matt Dralle
> > >> >> >> >> &g
> > >> >> >> >> t;
> back
> > >> when:
> The
to
> > >> connect
> > >> >> a
> > wires. I
> > >> >> have
> > >> >> >> >> (SonyCable5.pdf).
> seen
> > on
> > >> the
> > >> >> >> >> PhatBox connector.
> > unit.
> multi-device
> > cable
> > >> will
> > >> >> >> >> work
> > >> >> >> >> igurat
> > >> >> >> >> ions.
> > used
> > >> for
> the
> > >> signal
> knowing
> > >> when
> > >> >> is
> > >> >> >> >> the
> The
> > >> >> PhatBox
> > >> listen
> > >> >> to
> > C90.
> > >> >> >> >> Regards,
> > >> >> >> >> Mike"
> Aircraft
> > as
> > >> >> >> suggested
> plugged
> > in
> > >> my
> > >> >> >> 4000x
> the
> > >> >> Phatbox.
> of
> > >> 4.7k
> > >> >> >> since
> > >> willing
> > >> >> to
> that
> > >> >> someone
> > factory?
> > >> I'm
> > >> >> >> >> From: Matt
> > >> >> >> >> Drall
to
> > some
> you
> > >> *will
> > >> >> >> >> need*
> > color
> > >> >> coding
> > you
> > >> >> have.
> > >> >> >> >> The
> > interpolate
> > >> a
> > >> >> >> >> little
> > >> >> >> >> What Phatbox Said:
> > >> >> >> >> http://www.m
> > >> >> >> >> atroni
> > >> >> >> >> cs.com/xdp
> > >> >> >> >> 4000x/
> > >> >> >> >> SonyCable5.pdf
> > little
> > >> >> >> >> different.
> are
> > >> using
> > >> >> xdp-4000x.
> > >> >> PhatManager).
> > >> >> >> >> Matt Dralle
> back
> > >> when:
> The
to
> > >> connect
> > >> >> a
> > wires. I
> > >> >> have
> > >> >> >> >> ons > R> (SonyCable5.pdf).
> > >> >> >> >> y conn
> > >> >> >> >> PhatBox connector.
> > unit.
> multi-device
> > cable
> > >> will
> > >> >> >> >> work
> > used
> > >> for
> the
> > >> signal
> knowing
> > >> when
> > >> >> is
> > >> >> >> >> the
> The
> > >> >> PhatBox
> > >> >> >> >> sho
> > >> >> >> >> uld th
> to
> > C90.
> > >> >> >> >> Regards,
> > >> >> >> >> Mike"
> > >> >> >> >> BR
> > >> >> >> >> &g
> > >> >> >> >> t;
> This
> > is
> > >> the
> > >> >> themodification
> > unit
> > >> for
> > >> >> me
not
> > >> >> working:
> do
> > >> the
> > >> >> job
> > that
> > >> in
> > >> >> the
> this
> > >> >> because
Im
> > not
> > >> sure
> > >> >> if
> when
> > >> >> directly
> > reset
> > Phatbox
> > >> is
> > >> whenever
> > >> >> >> it's
> > and
> when
> > >> the
> > >> >> >> > From: Matt Dralle
> > >> >> >> > he Son
> > >> >> >> >y Phatbox firmware?
> > >> >> >> > Matt
> as
> > >> >> >> > suggested
> > in
> > >> my
> > >> >> >> > 4000x
> the
> > >> >> >> Phatbox.
of
> > 4.7k
> > >> >> >> since
> > willing
> > >> to
> > >> someone
> factory?
> > >> I'm
> > >> >> >> > From: Matt Dralle
to
> > some
you
> > >> *will
> > >> >> >> > need*
> > color
> > >> >> >> > coding
> you
> > >> have.
> > >> >> >> > The
> > interpolate
> > >> a
> > >> >> >> > little
> > >> >> >> > Wha
> > >> >> >> > t Matt
> > >> >> >> > Found on his cable:
> little
> > >> >> >> > different.
are
> > >> using
> > >> xdp-4000x.
> > >> PhatManager).
> > >> >> >> > Matt Dralle
> > >> >> >> > from M
> The
to
> > >> connect
> > >> >> >> > a
> wires.
> > I
> > >> >> >> > have
> > >> >> >> > (SonyCable5.pdf).
> > on
> > >> the
> > >> >> >> > PhatBox connector.
> > unit.
> multi-device
> cable
> > >> will
> > >> >> >> > work
> > >> >> >> > &g
> used
> > >> for
the
> > >> signal
> > when
> > >> is
> > >> >> >> > the
The
> > >> PhatBox
> > >> listen
> > >> >> >> > to
> C90.
> > >> >> >> > Regards,
> > >> >> >> > Mike"
> > >> >> >> > Matt G Drall
> > >> >> >> > e | Ma
> as
> > >> >> >> > suggested
> > in
> > >> my
> > >> >> >> > 4000x
> the
> > >> >> Phatbox.
of
> > 4.7k
> > >> >> >> since
> > willing
> > >> to
> > >> someone
> > factory?
> > >> >> I'm
to
> > some
you
> > >> *will
> > >> >> >> > need*
> > color
> > >> >> >> > coding
> you
> > >> have.
> > >> >> >> > The
> > interpolate
> > >> a
> > >> >> >> > little
> > >> >> >> > numbe
> > >> >> >> >rs and what not:
> > >> >> >> > What Phatbox Said:
> > >> >> >> > http://www.m
> > >> >> >> > atroni
> little
> > >> >> >> > different.
are
> > >> using
> > >> xdp-4000x.
> > >> PhatManager).
> > >> >> >> > Matt Dralle
> > >> >> >> > Fo
> > >> >> >> > r refe
> The
to
> > >> connect
> > >> >> a
> wires.
> > I
> > >> >> have
> > >> >> >> > (SonyCable5.pdf).
> > >> >> >> > y conn
> > >> >> >> > PhatBox connector.
> > unit.
> multi-device
> cable
> > >> will
> > >> >> >> > work
> > >> >> >> > gt; &g
> used
> > >> for
the
> > >> signal
> > when
> > >> is
> > >> >> >> > the
The
> > >> PhatBox
> > >> listen
> > >> >> to
> C90.
> > >> >> >> > Regards,
> > >> >> >> > Mike"
> > >> >> >> > BR
> > >> >> >> > 94551
> > reset
> > Phatbox
> > >> is
> > >> >> >> there,
> whenever
> > >> it's
> > >> >> >> > pl
> > >> >> >> > ugged
> when
> > the
> > >> >> >> Phatbox
> > >> >> >> > Matt
> as
> > >> >> >> suggested
> > in
> > >> my
> > >> >> >> 4000x
> the
> > >> >> Phatbox.
> > >> >> >> > s inst
> > >> >> >> >ead of 4.7k since
> > >> >> >> > Anyone out there
> > >> >> >> > with
> > >> someone
> factory?
> > >> I'm
> > >> >> >> > From: Matt Dralle
to
> > some
you
> > >> *will
> > >> >> >> > need*
> > color
> > >> >> coding
> you
> > >> have.
> > >> >> >> > The
> > >> >> >> > links are
> > >> >> >> > for re
> > >> >> >> > you n
> > >> >> >> > little
> little
> > >> >> >> > different.
are
> > >> using
> > >> xdp-4000x.
> > >> PhatManager).
> > >> >> >> > Matt Dralle
> > >> >> >> > g
> > >> >> >> > t;
> back
> > >> when:
> > >> >> >> > gt; > >R> "We changed cable manufacturers since Matt purchased his
> > >> system.
> > >> >> The
to
> > >> connect
> > >> >> a
> wires.
> > I
> > >> >> have
> > >> >> >> > (SonyCable5.pdf).
> > on
> > >> the
> > >> >> >> > PhatBox connector.
> > unit.
> multi-device
> cable
> > >> will
> > >> >> >> > work
> > >> >> >> > igurat
> > >> >> >> > ions.
> used
> > >> for
the
> > >> signal
> > >> >> >> > stays
> > >> >> >> > high
> > >> >> >> > the
The
> > >> PhatBox
> > >> listen
> > >> >> to
> C90.
> > >> >> >> > Regards,
> > >> >> >> > Mike"
> as
> > >> >> >> suggested
> > in
> > >> my
> > >> >> >> 4000x
> > >> >> >> > ommuni
of
> > 4.7k
> > >> >> since
> > willing
> > >> to
> > >> someone
> factory?
> > >> I'm
> > >> >> >> > From: Matt
> > >> >> >> > Drall
to
> > some
you
> > >> *will
> > >> >> >> > need*
> > color
> > >> >> coding
> > >> >> >> > BR>>
> > you
> > >> >> have.
> > >> >> >> > The
> > interpolate
> > >> a
> > >> >> >> > little
> > >> >> >> > What Phatbox Said:
> > >> >> >> > http://www.m
> > >> >> >> > atroni
> > >> >> >> > cs.com/xdp
> > >> >> >> > 4000x/
> > >> >> >> > SonyCable5.pdf
> little
> > >> >> >> > different.
are
> > >> using
> > >> xdp-4000x.
> > >> PhatManager).
> > >> >> >> > Matt Drall
> > >> >> >> > e
> back
> > >> when:
> The
to
> > >> connect
> > >> >> a
> wires.
> > I
> > >> >> have
> > >> >> >> > ons > > R (SonyCable5.pdf).
> > >> >> >> > y conn
> > >> >> >> > PhatBox connector.
> > unit.
> multi-device
> cable
> > >> will
> > >> >> >> > work
> > >> >> >> > t is a
the
> > >> signal
> > when
> > >> is
> > >> >> >> > the
The
> > >> PhatBox
> > >> >> >> > sho
> > >> >> >> > uld th
to
> C90.
> > >> >> >> > Regards,
> > >> >> >> > Mike"
> > >> >> >> > BR
> > >> >> >> > g
> > >> >> >> > t;
> > >> >> >> > matron
I
> > tried
> time
> > I
> > >> did
> > resistor
> > >> plugging
> > Phatbox
> > but
> > >> I
> you
> > a
> > >> >> > Matt
> > >> >> > What do you kn
> > >> >> > ow abo
> > >> >> modification
> > unit
> > >> for
> not
> > >> >> > working:
do
> > the
> > >> job
> that
> > in
> > >> >> the
> > >> because
> not
> > >> sure
> > when
> > >> >> > --- > >R> From: bobbybraun(at)comcast.net
> reset
> > is
> > whenever
> > >> >> > it's
and
> > the
> > >> >> > From: Matt Dralle
> > >> >> > of the
> > >> >> > Matt
as
> > >> >> > suggested
in
> > my
> > >> >> > 4000x
> > >> >> > Phatbox.
> 4.7k
> > >> >> > since
> willing
> > >> >> > to
> > >> >> > gt;>
> > >> someone
> > I'm
> > >> >> > From: Matt Dralle
> some
> > >> >> > *will
> > >> >> > need*
> > >> >> > coding
> > >> >> > and what
> > >> >> > not mi
> > >> >> > have.
> > >> >> > The
> interpolate
> > >> >> > a
> > >> >> > little
> > >> >> > different.
> > >> >> > stalla
> > >> >> >tion.
> > >> >> > using
> > >> >> > xdp-4000x.
> > >> >> > PhatManager).
> > >> >> > Matt Dralle
> > >> >> > when:
> > >> >> > connect
> > >> >> > a
> > >> >> > orang
> > >> >> >e (ground) wires. I
> > >> >> > have
> > >> >> > (SonyCable5.pdf).
on
> > >> >> > the
> > >> >> > PhatBox connector.
> unit.
> > >> >> > will
> > >> >> > work
> > >> >> > for
> > >> >> > &g
> > >> >> > t; >
> > >> >> > signal
> when
> > >> >> > is
> > >> >> > the
> > >> >> > PhatBox
> > >> >> > listen
> > >> >> > to
> > >> >> > Regards,
> > >> >> > Mike"
> > >> >> > gt; Ma
as
> > >> >> > suggested
in
> > my
> > >> >> > 4000x
> > >> >> > Phatbox.
> 4.7k
> > >> >> > since
> > >> >> > gt; &g
> > willing
> > >> >> > to
> > someone
> > I'm
> some
> > *will
> > >> >> > need*
> > >> >> > wire.
> > >> >> >Note the color
> > >> >> > coding
> > >> >> > have.
> > >> >> > The
> interpolate
> > a
> > >> >> > little
> > >> >> > What Phatbox Said:
> > >> >> > http://www.m
> > >> >> > atroni
> > >> >> > d
> > >> >> > iffere
> > >> >> >nt.
> > using
> > >> >> > xdp-4000x.
> > >> >> > PhatManager).
> > >> >> > Matt Dralle
> > >> >> > when:
> > >> >> > connect a
> > >> >> > orang
> > >> >> >e (ground) wires. I
> > >> >> > have
> > >> >> > (SonyCable5.pdf).
> > >> >> > y conn
> > >> >> > PhatBox connector.
> unit.
> > >> >> > will
> > >> >> > work
> > for
> > >> >> > a
> > >> >> > rbitra
> > >> >> > signal
> when
> > >> >> > is
> > >> >> > the
> > >> >> > PhatBox
> > listen
> > >> >> > to
> > >> >> > Regards,
> > >> >> > Mike"
> > >> >> > BR
> > >> >> > ore |
> > >> >> >CA | 94551
> > >> >> > a comp
> > >> >> >lete system reset
> > is
> > >> >> > there,
> > it's
and
> the
> > >> >> > Phatbox
> > >> >> > Matt
> > >> >> > by: bo
as
> > >> >> > suggested
in
> > my
> > >> >> > 4000x
> > >> >> > Phatbox.
> 4.7k
> > >> >> > since
> > >> >> > Anyone out there
