XDP4000X-Archive.digest.vol-bf
- Present
; The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. & gt; Regards, Mike" g t; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email gt; http://www.matronics.com/ WWW | Featuring Products For Aircraft Well I had the cable modified with the 4.7k ohm resister installed as suggested & gt; &g t; and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only c ommuni cates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k s ince there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from t he factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Drall e dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color codin g BR ; and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.m atroni cs.com/xdp & gt; 4000x/ SonyCable5.pdf g t; Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Drall e > ; For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect gt; a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connecti ons R (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can b e seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device configurations. The problem is with the bus master signal. I t is a ; n input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox sho uld th en force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 34 7 | Livermore | CA | 94551 g t; 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ================================================================== ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email & gt; http://www.matronics.com/ WWW | Featuring Products For Aircraft g t; matron gt; ics.com/xdp4000x-list/download Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft I actually do have one a XA-C30, and during my initial installation I tried using it with the Phatbox just to see if it had an effect. This last time I did not try it with it installed however so I'll give it another try. So you don't think the reset line in your diagram or a higher value resistor could be the problem, huh? -------------- Original message -------------- From: Matt Drall e d ralle@ matronics.com -- XDP4000X-List message posted by: Matt Dralle Do you have an XA-C30 multiplexer? On both of my installations, I am plugging the Phatbox into the system using one of these. Basically C90-4000-C30-Phatbox. I don't know if I've ever tried plugging the Phatbox directly into a 4000. Seems like I must have tried that at some point, but I can't remember for sure. You might be able to talk me in to loaning you a XA-C30 if you promise on your mama's grave to return it... ;-) Matt At 08:05 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net What do you kn ow abo ut the reset line being cut in your diagram? This is the o nly other difference shown in your diagram that wasn't done in the modification of the cable. Here's what they guy that's been doing the work on the unit for me wrote after I contacted him the last time about the 4.7k resistor not working: Well its a pulldown resistor so any value of several k or so should do the job 5 vs 10 should not matter but I could be wrong. The other thing was that in the diagram you showed me the reset line seemed to be cut. I didnt do this because lower down it seemed that they fixed that with a firmware update? Im not sure if that would help but you might want to ask Matt. Does it still work when directly connected to the head unit? Does this sound like something that could cause a problem? -------------- Original message ----------- & gt; &g t; gt; g t; --- R From: bobbybraun(at)comcast.net -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shuts down whenever it's plugged in. I find it odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which is shut down when the Phatbox is plugged in... I just don' t know what to do... -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of the Sony Phatbox firmware? R Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested & gt; &g t; and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to gt; ; part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a c & gt; &g t; able d irect from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what > ; not mi ght be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: What Mat t Foun d on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your in stalla tion. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle For reference, here is a message from Mike Woo at Phatnoise way back &g t; when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orang e (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Sony connector. They can be seen on the PhatBox connector. & gt; An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device configurations. The problem is with the bus master signal. I t is a n input. It is used for g t; ; arbitration during device initialization. Without the pull-down the signal stays high (+5V) a t all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" gt; Ma tt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Ema il http://www.matronics.com/ WWW | Featuring Products For Aircraft Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only communicates with the Phatbox. Still wondering if tha t resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. gt; g t;Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm runnin g out of options here. Can anybody help? -------------- Original message -------------- From: Matt Dralle dralle @matronics.com -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a &g t; lit tle with respect to colors and pin numbers and what not: What Matt Found on his cable: http:/ /www.m atronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.m atroni cs.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little d iffere nt. Use the drawing that matches best your installation. < BR>> ; Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his s ystem. The connections are the same but the colors are d iffere nt. You want to connect a 10k resistor between the blue (bus master) and orang e (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 a nd an unmodified cable will work with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for a rbitra tion during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The & gt; PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Liverm ore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircra &g t; > ; ft ================================================================== Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft Yes, and I even reinstalled the firmware and did a comp lete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shuts down whenever it's plugged in. I find it odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which is shut d own when the Phatbox is plugged in... I just don't know what to do... -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com > ; -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of the Sony Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bo bbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90 only communicates with t he
Phatbox. Still wondering if that resist or sho uld've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original me ssage < BR>> ; -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you n eed to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf g t; ; What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. &g t; > ; Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to h ave op erational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle g t; For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are th e same but th e colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Sony connector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will wo rk
with any multi-device conf igurat ions. The problem is with the bus master signal. It is an input. It is used for arbitration during device initializatio n. Wit hout the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to &g t; Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" g t; ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email gt; http://www.matronics.com/ WWW | Featuring Products For Aircraft gt; R Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to pa rt wit h for some cash, or a photo of the bottom of a Sony P B that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt BR ; Drall e dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor betwee n ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a gt; little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What P hatbox Said: &g t; htt p://www.m atroni cs.com/xdp 4000x/ SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle < ; BR ; For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are th e same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connecti ons R (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the P hatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-devi ce con figurations. The problem is with the bus master signal. It is an input. It is used for arbitration during device i nitial ization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox sho uld th en force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 &g t; 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft gt; g t; ================================================================== Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Fea turing Products For Aircraft g t; What do you know about the reset line being cut in your diagram? This is the only other difference shown in your diagramthat wasn't done in themodification of the cable. Here's what they guy that's been doing the work on the unit for ; me BR wrote after I contacted him the last time about the 4.7k resistor not wo > ; rking: Well its a pulldown resistor so any value of several k or so should do the job 5 vs 10 should not matter but I could be wrong. The other thing was that in the diagram you showed me the reset line seemed to be cut. I didnt do this because lower down it seemed that they fixed that with a firmware update? Im not sure if that would help but you might want to ask Matt. Does it still work when directly connected to the head unit? Does this sound like somethi ng tha t could cause a problem? -------------- Original message -------------- From: bobbybraun(at)comcast.net -- XDP4000X-List message posted by: bobbybraun(at)comcast.net g t; Yes , and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is gt; g t; there, and can control it just fine, but the 4000x just shuts down whenever it's plugged in. I find it odd that the Phatbox can still be reco gnized and controlled since it is plugged into the 4000x which is shut down when the Phatbox is plugged in... I just don't know what to do... -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of t he Son y Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote : - - XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the pr oblem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to
part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm ; running out of options here. Can anybody help? gt; R -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable iss ue. Be low are two links to some information on how the Phatbox- Sony c ables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: Wha t Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf & gt;&am p; gt; What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that m atches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). & gt; Matt Dralle For reference, here is a message from M ike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connec t a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be s een on the Sony connector. They can b e seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work g t; with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all ti mes. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" Matt G Drall e | Ma tronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft Well I had the cable modified with the 4.7k ohm resister installed as sugge sted and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only com munica tes with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of inform ation. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone gt; wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? ---------- ---- O riginal message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle gt; R Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cab le you have. The links are for reference only and you m ight find you need to interpolate a little with respect to colors and pin numbe rs and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.m atroni cs.com/xdp4000x/SonyCable5.pdf Depend ing on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable thr ough P hatManager). Matt Dralle Fo r refe rence, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The & gt; connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device &g t; > ; configurations. I'm not sure if firmware 6.00 a nd an unmodified cable will work gt; g t; with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. g t; Aft er the Phat Box is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | BR ; 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Produc ts For Aircraft ================================================================== Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 ; 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft &g t; > ; Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shuts down whenever it's p l ugged in. I find it odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which isshut down when the Phatbox is plugged in... I just don't know what to do... -------------- Original message -------------- From: Matt D ralle dralle(at)matronics.com -- XDP4000X-List message p osted by: Matt Dralle Are you running the 7.0 version of the Sony Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x & gt; &g t; g t; powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohm s inst ead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're w illing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm > ; running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on ho w the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. & gt; The links are for re ference only and you might find BR ; you n eed to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little & gt; different. Use the drawing that matches best your installation. gt; Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle g t; For reference, here is a message from Mike Woo at Phatnoise way back when: &g t; > ; gt; R "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Sony connector. They can be seen on the PhatBox conne ctor. An unmodified cable should work when directly connected to a head unit . Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device conf igurat ions. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time t o init ialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He wo uld know best about using the C90. Regards, Mike" Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-6 06-628 1 F | d ralle@ matronics.com Email gt; http://www.matronics.com/ WWW | Featuring Products For Aircraft Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only c ommuni cates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since & gt; there seemed to be a conflict of information. BR ; Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Drall e dralle(at)matronics.com -- XDP4000X-Li st mes sage posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding BR ; and what not might be different depending on the ve rsion of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin nu mbers and w hat not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.m atroni cs.com/xdp 4000x/ SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you usin g vers ion 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmw are (u pgradeable through PhatManager). Matt Drall e For reference, here is a messag e from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to & gt; connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connecti ons R (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device c onfigu rations. I'm not sure if firmware 6.00 and an unmodified cab le wil l work with any multi-device configurations. ; The problem is with the bus master signal. I t is a n input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox sho uld th & gt; en force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.c om Ema il http://www.matronics.com/ WWW | Featuring Products For Aircraft &g t;
================================================================== ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft g t; matr on
ics.com/xdp4000x-list/download Matt G Dralle | Matronics | PO Box 347 | Livermore | C A | 94 551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.co m Emai l http://www.matronics.com/ WWW | Featuring Products For Aircraft QUOTE < BR> Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ist/se arch Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft & gt; &g t; Ok, I went ahead andclipped thereset wire and nowthe PBactually works in my system without shutting everything off! BUT... and this is a big but, my processor is not accepting analog audio at the analog changerinput any longer (and it used to just fine)... Idid testand there is audio at the outputs of the PB, but it doesn't sound right at all, tinny and flat, no bass, dull highs. I threw my cd changerback in to see if my processor would accept analog audio from that and the analog outputs of that piece are not working any longer either... (I can't say for 100% that they worked before hand since I always used the digit al out put of the changer, and never tested the analog outputs) I have yet to try my XM unit, which I know the analog outs used to work on since those are the only outputs it has and I used it for about 6 months in my system, but that will have to wait till daylight tomorrow since it's late and I don't have the time to wire anything else in tonight. So I guess the good news is, the PB works now, well sorta. I'm partially convinced that something is wrong with it's audio outputs because like I said before it sounds really bad, and now I'm worried that something is broken inside of my processor as well, but no need to jump to conclusions until I can check everything out properly tomorrow. At least I made some progress... -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Cut the reset line on the cable. Sounds to me like the PB is holding that line down and never letting anyone else init. Matt At 04:27 PM 4/18/2006 Tuesday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well, I went and tried every option I could think of within my resources, short of unhooking the 4000x and connecting the C30 directly to the C90, the n from it split out to the 4000x, PB, and my changer and XM respectively. Here's a list of the attempts and their corresponding outcomes: Phatbox (PB) plugged directly int o the Changer Input of the 4000x: PB powers up fine and is recognized, 4000x disappears and the C90 only sees the PB. XA-C30 plugged into the Changer Input of the 4000x, PB in Control 1 of C30: PB powers up fine and is recognized, 4000x disappears and the C90 only sees the PB. XA-C30 plugged into the Changer Input of the 4000x, PB in Control 1 of C30, Changer in Control 2 of C30: PB powers up fine and is recognized, 4000x and & gt; Ch anger both disappear, C90 only sees the PB. XA-C30 plugged into the Changer Input of the 4000x, PB in Control 1 of C30, XT-XM1 in Control 2 of C30: PB powers up fine and is recognized, 4000x and XM Radio both disappear, C90 only sees the PB. XT-XM1 plugged into the Changer Input of the 4000x, PB plugged into input of XT-XM1: PB Powers up fine and is recognized, 4000x and XM Radio both disappear, C90 only sees the PB. gt; g t;Both the Changer (CDX-848X) and XM radio work perfectly when connected into the system without the PB. Basically anything that is run inline before AND after the Phatb ox is shut down and ignored by the system. Power is cut to all connected units on both sides besides C90 and PB when the PB is plugged in. Bottom line, I didn't learn a thing from any of this and am no further ahead in figuring out what the problem is...lol Matt, I may just take you up on your offer to test out my PB in your system, but before I go that route I'm going to try a couple more things. I'm going to have the cable modified one last time with a 10k resistor and the reset line cut. Plus I'm going to blow another $100 on a used but factory original PB cable from someone in Europe who is unable to tell me the origin (other than < BR>> ; it was made by Phatnoise) or age o f the cable so I don't know how recent it has been made (but given my recent luck I'm sure it'll be one of the old cables that were made before the modification was put in place. I'm just glad I didn't have anything sharp or blunt near me after I finished all these tests, if there had been who knows what the outcome would've been! Ahhhh! -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Well, if you're handy with a solderin g iron , I would try both the higher resistor and the reset line options. Neither will hurt the equipment. Well, unless you miss wire something... :-) The Phatbox has a bad habit of insisting on being the first CDChanger sla ve on the bus. Each class of accessory you can hook up the the Unilink Bus (UB) has a class that it falls into. Here are some Unilink device classes along with some examples: CD Changer: CD Changers, Phatbox, XA-300 MD Changer: MD Changers, XM Radio (original Sony box) Tuners: TV Tuner, Internal AM/FM Tuner Processors: 210, 4000x, internal Bass/Treble > ; On system start up, the Head Unit (HU) sends out a broadcast asking for each device class on the UB. Each device of the given class will respond with "I'm Here" and the HU will respond back to the an "dynamic" address for that particular device to use. The address is a combination of the device class (high nibble) and the device's assigned address on the UB (lo w nibb le). An abbreviated version of this little "dance" occurs each time the HU is powered up. If the HU discovers that there is anything different (new or missing device) from the last time it started, it will reset the bus (both a protocol sequence as well as dro pping the Reset wire) and start a whole new bus address negotiation. The actual address of the device is determined by its location on the bus. The closer a device is to the HU the lower its address will be. Basically what happens on startup is that the first device on the UB disables bus connectivity to all of the slaves down stream until it receives an address from the HU. On the XA-C30, logically each respective port looks like a device in the stream, so ; negotiation goes from Port 1 to Port 2 to Port 3. The Phatbox for some stupid reason, insists on being address 1 in the CD Changer class so you have to be really careful that it is either directly plugged into the HU or is on Port 1 of the first XA-C30 in the chain. That being said, this addressing limitation shouldn't be conflicting with the 4000x in your system since they are different classes of devices, but I wanted to point out the caveat with the Phatbox addressing since it took me a while to figure that out. I asked Mike Woo at Phatnoise why they hard coded the addressing that way, but I didn't really get an answer back. I've written an embedded processor Unilink Slave emulator that runs on an 8051-compatible microco & gt; &g t; ntroll er and I was able to write a negotiation routing that is 100% compatible with the master/slave addressing algorithm, so if I can do it, surly Phatbox could. If you'd like, you can send me your Phatbox and I can give it a try here on my two installations to see if the problem is the Phatbox or something else. Matt At 04:59 AM 4/18/2006 Tuesday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net I actually do have one a XA-C30, and during my initial installation I tried using it with the Phatbox just to see if it had an effect. This last time I did not try it with it installed however so I'll give it another try. g t; ;So you don't think the reset line in your diagram or a higher value resistor could be the problem, huh? -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Do you have an XA-C30 multiplexer? On both of my installations, I am plugging the Phatbox into the system using one of these. Basically C90-4000-C30-Phatbox. I don't know if I've ever tried plugging the Phatb ox directly into a 4000. Seems like I must have tried that at some point, but I can't remember for sure. You might be able to talk me in to loaning you a XA-C30 if you pr omise on your mama's grave to return it... ;-) Matt At 08:05 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net What do you know about the reset line being cut in your diagram? This is the only other difference shown in your diagram that wasn't done in the modification of the cable. Here's what they guy that's been doing the work on the unit & gt; for me wrote after I contacted him the last time about the 4.7k resistor not working: Well its a pulldown resistor so any value of several k or so should do the R job 5 vs 10 should not matter but I could be wrong. The other thing was that in the diagram you showed me the reset line seemed to be cut. I didnt do this because lower down it seemed that they fixed that with a firmware update? Im not sure if that would help but you might want to ask Matt. Does it still work when directly connected to the head unit? Does this sound like something that co uld ca use a problem? -------------- Original message -------------- From: bobbybraun(at)comcast.net -- XDP4000X-List message posted by: bobbybraun(at)comcast.net g t; ; Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shuts down whenever it's plugged in. I find it odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which is shut down when the P hatbox is plugged in... I just don't know what to do... -------------- Original message -------------- From: Matt Dralle -- XDP400 0X-List message posted by: Matt Dralle Are you running the 7.0 version of the Sony Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in & gt; my 4000x powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? &g t; > ; - ------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the versi on of cable you have. The links are for reference onl y and you might find you need to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pd f Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle gt; g t; For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and ora nge (g round) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). g t; ; The numbers can not be seen on the Sony connector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with a ny mul ti-device configurations. The problem is with the bus m aster signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to &g t; &am p;g t; ; Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft BR ; Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there ... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're R willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? > ; -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to s ome R information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to & gt; interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: gt; ; http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.m atroni cs.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using gt; anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a g t; ; 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configuration s. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device configurations. & gt; The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and t hen shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90.
Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle@m atroni cs.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ================================================================== Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle @matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Air craft Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shuts down whenever it's plugged in. I find it odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which isshut down when the Phatbox is plugged in... I just don't know what to d o... < BR> gt; ; -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of the Sony Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in R my 40 00x powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? g t; -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might f ind R you n eed to interpolate a little with respect to colors and pin numbers and what not: & gt; &g t; What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. g t; Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through & gt; PhatManager). Matt Dralle g t; For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to conne ct a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Sony connector. They can be seen on
the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device conf g t; igurat ions. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when & gt; is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know be st abo ut using the C90. Regards, Mike" Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email & gt; &g t; gt; http://www.matronics.com/ WWW | Featuring Products For Aircraft Well I had the cable modified with the 4.7k ohm resister installed as gt; suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm gt; running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Drall e dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *w ill need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different dependi ng on the version of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.m atroni cs.com/xdp 4000x/ SonyCable5.pdf ; Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle For reference, here is a message from Mike Woo at Phatnoise way back when: & gt; &g t; "We chang ed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connecti ons R (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable w orks w ith si mple m ulti-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox sho R uld th en force a rese t afte r a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft gt; R ================================================================== & gt; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft g t; gt; ; What do you know about the reset line being cut in your diagram? This is the only other difference shown in your diagramthat wasn't done in themodification of the cable. Here's what they guy that's been doing the work on the unit for me wrote after I cont acted him the last time about the 4.7k resistor not working: Well its a pulldown resistor so any value of several k or so should do the job 5 vs 10 should not matter but I could be wrong. The other thing was that in the diagram you showed me the reset line seemed to be cut. I didnt do this because lower down it seemed that they fixed that with a fir mware update? Im not sure if that would help but you might want to ask Matt. Does it still work when directly connected to the head unit? Does this sound like someth ing th at could cause a problem? -------------- Original message -------------- From: bobbybraun(at)comcast.net -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shut s down whenever it's plugged in. I find it odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which is shut down when the Phatbox is plugged in.. . I ju st don't know what to do... -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of t he Son y Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my & gt; 4000x powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to par t with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm ; running out of options here. Can anybody help? -------------- Original messa ge --- ----------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor be tween ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers an d what not: Wha t Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf gt; Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. &g t; Mak e sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle For reference, here is a message from M ike Woo at Phatnoise way back when: "We chang ed cab le manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not b e seen on the Sony connector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if f irmwar e 6.00 and an unmodified cable will work g t; with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has t rouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen g t; to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" Matt G Drall e | Ma tronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle@matro nics.c om Email http://www.matronics.com/ WWW | Featuring Products For Aircraft Well I had the cable modified with the 4.7k ohm resister installed as R suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to > ; part with for some cash, or a photo of the bottom of a Sony PB that someone gt; wouldn't mind me using to get myself a cable direct from the factory? ; I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4. 7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. T he links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbe rs and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.m atroni cs.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. ; Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle Fo r refe rence, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt p urchas ed his system. The connections are the same but the colors are different. You want to co nnect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cab le
will work g t; ; gt; g t; with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen & gt; to Matt regarding pushing reset. He would know best about using the C90. gt; R Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ================================================================== &g t;
; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shuts down whenever it's pl ugged in. I find it odd that the Phatb ox ca n stil l be recognized and controlled since it is plugged into the 4000x which isshut down when the Phatbox is plugged in... I just don't know what to do... -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of the Sony Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net ; Well I had the cable modified with the 4.7k ohm resi ster i nstalled as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohm s inst ead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that so meone wouldn't mind me using to get myself a cable direct from the factory?
I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are &g t; > ; for re ference only and you might find you n eed to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little R different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle g t; For reference, here is a message from Mike Woo at Phatnoise way back when: gt; R "We changed cable manufacturers since Matt purchased his system. R The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I & gt; &g t; have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Sony connector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will gt; work with any multi-device conf igurat ions. The problem is with the bus master signal. It is an input. It is used > ; for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to g t; Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" &g t; > ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email gt; http://www.matronics.com/ WWW | Featuring Products For Aircraft Well I had the cable modified with the 4.7k ohm resister installed as s uggest ed and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only c ommuni cates with the Phatbox. Still wondering if th at res istor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody hel p? -------------- Original message -------------- From: Matt Drall e dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle & gt; Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding BR ; and what not might be different depending on the version of cable you ; have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http:/ /www.m atronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.m atroni cs.com/xdp 4000x/ SonyCable5.pdf Depending on what version of cable you have, things might be a little ; different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatM anager ). Matt Drall e For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are t he sam e but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connecti ons R (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will ; work with any multi-device configurations. The problem is with the bus master signal. I t is a n input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is & gt; &g t; the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox sho uld th en force a reset after a few seconds. However, you should listen to Matt regardi ng pus hing reset. He would know best about using the C90. Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Ai rcraft ================================================================== gt; ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft g t; matron ics.com/xdp4000x-list/download < BR>> ; Matt G Dralle | Matronics | PO Bo x 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft I actually do have one a XA-C30, and during my initial installation I tried using it with the Phatbox just to see if it had an effect. This last time I did not try it with it installed however so I'll give it another try. So you don't think the reset line in your diagram or a higher va lue resistor could be the problem, huh? -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP 4000X-List message posted by: Matt Dralle Do you have an XA-C30 multiplexer? On both of my installations, I am plugging the Phatbox into the system using one of these. Basically C90-4000-C30-Phatbox. I don't know if I've ever tried plugging the Phatbox directly into a 4000. Seems like I must have tried that at some point, but I can't remember for sure. You might be able to talk me in to loaning you a XA-C30 if you promi se on your mama's grave to return it... ;-) Matt At 08:05 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net What do you kn ow abo ut the reset line being cut in your diagram? This is the only other difference shown in your diagram that wasn't done in the modification of the cable. Here's what they guy that's been doing the work on the unit for me wrote after I contacted him the last time about the 4.7k resistor not working: Well its a pulldown resistor so any value of sev eral k or so should do the job 5 vs 10 should not matter but I could be wrong. The other thing was that in the diagram you showed me the reset line seemed to be cut. I didnt do this because lower down it seemed that they fixed that with a firmware update? Im not sure if that would help but you might want to ask Matt. Does it still work when directly connected to the head unit? Does this sound like something that could cause a problem? -------------- Original message ----------- --- R From: bobbybraun(at)comcast.net -- XDP4000X-List message posted by: bo bbybra un(at)comcast.net Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shuts down whenever it's plugged in. I find it odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which is shut down when the BR ; Phatbox is plugged in... I just don't know what to do... -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Are you runni ng the 7.0 version of the Sony Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. & gt; Anyone out there with a working spare Sony Phatbox cable they're willing to gt; ; part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted b y: Mat t Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wir ed. No te that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not mi ght be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com /xdp40 00x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: htt p://ww w.matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your in stalla tion. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle For r eferen ce, here is a message from Mike Woo at Phatnoise way back wh en: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orang e (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Sony connector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmod ified cable work s with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for g t; ; arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few > ; second s. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" gt; Ma tt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft Well I had the cable modified with the 4.7k ohm resister installed as suggested & gt; &g t; and the problem is still there... as soon as th e Phatbox is plugged in my 4000x powers down, the system resets and the C90only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. gt; g t;Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? < BR>> ; -------------- Original message -------------- From: Matt Dralle dralle@ matron ics.com -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a > ; litt le with respect to colors and pin numbers and what not: What Matt Found on his cable: BR ; http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.m atroni cs.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little d iffere nt. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to hav e oper ational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orang e (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf).
The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when direc tly co nnected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for a rbitra tion during device initialization. Without the pull-down the signal > ; stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox sho uld th en force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Liverm ore | CA | 94551 & gt; &g t; 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ================================================================== BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft Yes, and I even reinstalled the firmware and did > ; a comp lete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shuts down whenever it's plugged in. I find it odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which isshut down when the Phatb ox is plugged in... I just don't know what to do... -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of the Sony Phatbox firm ware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bo bbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. &g t; > ; Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original me ssage -------------- From: Matt Dralle -- XDP4000X -List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will & gt; need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you n eed to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf ; g t; ; What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5 .pdf < BR> Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle g t; For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are th e same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Sony connector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work BR with any multi-device c onf igurat ions. The problem is with the bus master signal. It is an input. It is used for arbitration during device initializatio n. Wit hout the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike"
gt; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email gt; http://www.matronics.com/ WWW | Featuring Products For Aircraft gt; R Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only communicates with the Phatbox. S till w ondering if that resistor should've been 10k ohms instead of 4.7k R since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt BR ; Drall e dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf > ; What P hatbox Said: http://www.m atroni cs.com/xdp 4000x/ ; SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle & gt; &g t; For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are th e same but the colors are di fferent. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connecti ons R (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head u nit. < BR> Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device configurations. The problem is with the bus master signal. It is an input. It is us ed for arbitration during device i nitial ization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox sho uld th en force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Livermor e | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft gt; g t; ================================================================== > ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft g t; R What do you know about the reset line being cut in your diagram? This is the only other difference shown in your diagramthat wasn't done in themodification of the cable. Here's what they guy that's been doing the work on the unit fo r me wrote after I contacted him the last time about the 4.7k resistor not wo rking: Well its a pulldown resistor so any value of several k or so should do the job 5 vs 10 should not matter but I could be wrong. The other thing was that in the diagram you showed me the reset line seemed to be cut. I didnt do this because lower down it seemed that they fixed that with a firmware update ? Im n ot sure if that would help but you might want to ask Matt. Does it still work when directly connected to the head unit? > ; Does this sound like something that could cause a problem? -------------- Original message -------------- From: bobbybraun(at)comcast.net -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is gt; g t; there, and can control it just fine, but the 4000x just shuts down whenever it's gt; plugged in. I find it odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which is shut down when the Phatbox is plugged in... I just don't know what to do... -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of t he Son y Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister ins talled as suggested and &g t; > ; the pr oblem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm ; running out of options here. Can anybody help? - ------ ------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable iss ue. Be low are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: &g t;
gt; Wha t Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that m atches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're us ing 7. 0 Sony firmware (upgradeable through PhatManager). ; Matt Dralle For reference, here is a message from M ike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Sony connector. They & gt; ca n b e seen on the PhatBox connector. An unmodified cable should work when dir ectly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work g t; with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initi alize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen g t; ; to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" Matt G Drall e | Ma tronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft &g t; Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my gt; 4000x powers down, the system resets and the C90only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of inform ation. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a phot o of t he bottom of a Sony PB that someone gt; wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com BR -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cab le you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbe rs and what not: What Matt Found on his cable: ; http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.m atroni cs.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a litt le
different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable thr ough P hatManager). Matt Dralle g t; Fo r refe rence, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are d iffere nt. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simpl e multi-device configurations. I'm not sure if firmware 6.00 a nd an unmodified cable will work & gt; gt; g t; with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" & gt; BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | BR ; 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ================================================================== Matt G Dralle | Matronics | PO Box 347 | Live rmore | CA | 94551 925-606-1001 V | 925-606-62 81 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shuts down whenever it's p l ugged in. I find it odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which isshut down when the Phatbox is plugged in... I just don't know what & gt;to do... -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of the Sony Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x g t; powers down, t he sys tem reset s and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohm s inst ead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Dralle - - XDP4 000X-List message posted by: Matt Dralle BR ; Okay, here's some help on this cable issue. Below are two links to some information on ho w the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for re ference only and you might find you n eed to interpolate a little with respect to colors and pin numbers and what not: & gt; What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf ; What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. gt; Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (u pgrade able through PhatManager). Matt Dralle g t; For reference, here is a message from Mike Woo at Phatnoi se way back when: gt; R "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Sony connector. They can be seen on t he
PhatBox conne ctor. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmod ified cable will work with any multi-device conf igurat ions. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the
right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He wo uld know best about using the C90. g t; Regards, Mike" Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email gt; http://www.matronics.com/ WWW | Featuring Produ cts Fo r Aircraft Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only c ommuni cates with the Ph atbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. BR ; Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Drall e dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle ; Okay , here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color &g t; cod ing BR ; and what not might be different depending on the ve rsion of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: gt; g t; http://www.m atroni cs.com/xdp 4000x/ SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmw are (u pgradeable through PhatManager). Matt Drall e For reference, here is a message from Mike Wo o at P hatnoise way back when: "We changed cable manufacturers since Matt purchased his s ystem. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connecti ons R (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device c onfigu ra tions. I'm not sure if firmware 6.00 and an unmodi fied cable will work with any multi-device configurations. The problem is with the bus master signal. I t is a n input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox sho uld th en force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. &g t; > ; BR ; Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ================================================================== ; Matt G Dralle | Matronics | PO Box 347 | Live rmore | CA | 94551 925-606-100 1 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft g t; matron ics.com/xdp4000x-list/download Matt G Dralle | Matronics | PO Box 347 | Livermore | C A | 94 551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft QUOTE gt; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft Well, I went and tried every option I could think of within my resources, short of unhooking the 4000x and connecting the C30 directly to the C90, then from itsplit out to the 4000x, PB, and my changer and XM respectively. Here's a lis t of the attempts and their corresponding outcomes: Phatbox (PB)plugged directly into the Changer Input of the 4000x: PB powers up fine and is recognized, 4000x disappears and the C90 only sees the PB. XA-C30 plugged into the Changer Input of the 4000x, PB in Control 1 of C 30: PB powers up fine and is recognized, 4000x disappears and the C90 only sees the PB. XA-C30 plugged into the Changer Input of the 4000x, PB in Control 1 of C30, Changer in Control 2 of C30: PB powers up fine and is recognized, 4000x and Changer both disappear, C90 only sees the PB. XA-C30 plugged into the Changer Input of the 4000x, PB in Control 1 of > ; C30, XT-XM1 in Control 2 of C30: PB powers up fine and is recognized, 4000x and XM Radio both disappear, C90 only sees the PB. XT-XM1 plugged into the Changer Input of the 4000x, PB plugged into input of XT-XM1: PB Powers up fine and is recognized, 4000x and XM Radio both disappear, C90 only sees the PB. Both the Changer (CDX-848X) and XM radio work perfectly when connected into the system without the PB. Basically anything that is run inline before AND after the Phatbo x is s hut down and ignored by the system. Power is cut to allconnected units on both sidesbesides C90 and PB when the P B is plugged in. Bottom line, I didn't learn a thing from any ofthis and am no further ahead in figuring out what the problem is...lol Matt, I may just take you up on your offer to test out my PB in your system, but before I go that route I'm going to try a couple more things. I'm going to have the cable modified one last time with a 10k resistor and the reset line cut. Plus I'm going to blow another $100 on a used butfactory original PBcable from someone in Europe who is unable to tell me the origin (other than it was made by Phatnoise) or age of the cable so I don't know how recent it has been made (but given m y rece nt luck I'm sure it'll be one of the old cables that were made before the modification was put in place. g t; ;I'm just glad I didn't have anything sharp or blunt near me after I finished all these tests, if there had been who knows what the outcome would've been! Ahhhh! -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Well, if you're handy with a soldering iron, I would try both the higher resistor and the reset line options. Neither will hurt the equipment.
Well, unless you miss wire something... :-) The Phatbox has a bad habit of insisting on being the first CDChanger slave on the bus. Each class of accessory you can hook up the the Unilink Bus (UB) has a class that it falls into. Here are some Unilink device classes along with some examples: R CD Changer: CD Changers, Phatbox, XA-300 MD Changer: MD Changers, XM Radio (original Sony box) Tuners: TV Tuner, Internal AM/FM Tuner Processors: 210, 4000x , inte rnal Bass/Treble On system start up, the Head Unit (HU) sends out a broad cast a sking for each device class on the UB. Each device of the given class will respond with "I'm Here" and the HU will respond back to the an "dynamic" address for that particular device to use. The address is a combination of the device class (high nibble) and the device's assigned address on the UB (low nibble). An abbreviated version of this little "dance" occurs each time the HU is powered up. If the HU discovers that there is anything different (new or missing device) from the last time it started, it w ill re set the bus (both a protocol sequence as well as dropping the Reset wire) and start a whole new bus address negotiation. & gt; The actual address of the device is determined by its location on the bus. The closer a device is to the HU the lower its address will be. B asical ly what happens on startup is that the first device on the UB disables bus connectivity to all of the slaves down stream until it receives an address from the HU. On the XA-C30, logically each respective port looks like a device in the stream, so negotiation goes from Port 1 to Port 2 to Port 3. The Phatbox for some stupid reason, insists on being address 1 in the CD Changer class so you have to be really careful that it is either direc tly pl ugged into the HU or is on Port 1 of th e firs t XA-C30 in the chain. That being said, this addressing limitation shouldn't be conflicting with the 4000x in your system since they are different classes of devices, but I wanted to point out the caveat with the Phatbox addressing since it took me a while to figure that out. I asked Mike Woo at Phatnoise why they hard coded the addressing that way, but I didn't really g et an answer back. I've written an embedded processor Unilink Slave emulator that runs on an 8051-compatible microcontroller and I was able to write a negotiation routing th at is 100% compatible with the master/slave addressing algorithm, so if I can do it, surly Phatbox could. If you'd like, you can send me your Phatbox and I can give it a try here on my two installations to see if the probl em is the Phatbox or something else. Matt At 04:59 AM 4/18/2006 Tuesday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net I actually do have one a XA-C30, and during my initial installation I tried using it with the Phatbox just to see if it had an effect. This last time I d id
not try it with it installed however so I'll give it another try. So you don't think the reset line in yo ur dia gram or a higher value resistor could be the problem, huh? -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Do you have an XA-C30 multiplexer? On both of my insta llatio ns, I am plugging the Phatbox into the system using one of these. Basically C90-4000-C30-Phatbox. I don't know if I've ever tried plugging the Phatbox directly into a 4000. Seems like I must have t ried that at some point, but I can't remember for sure. You might be able to talk me in to loaning you a XA-C30 if you promise on your mama's grave to return it... ;-) Matt At 08:05 PM 4/17/2006 Monday, you w rote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net What do you know about the reset line being cut in your diagram? This is the only other difference shown in your diagram that wasn't done in the modification of the cable. Here's what they guy that's been doing the work on the unit for me wrote after I contac &g t; > ;ted him the last time about the 4.7k resistor not working: Well its a pulldown resistor so any value of several k or so should do the job 5 vs 10 should not matter but I could be wrong. The other thing was that in the diagram you showed me the reset line seemed to be cut. I didnt do this because lower down it seemed that they fixed that with a firmware update? Im not sure i f that would help but you might want to ask Matt. Does it still work when directly connected to the head unit? Does this sound like something that could cause a problem? ----------- --- Or iginal message -------------- From: bobbybraun(at)comcast.net -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Yes, a nd I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shuts down whenever it's plugged in. I find it odd that the Phatbox can still be recognized and controlled since it is pl ugged into the 4000x which is shut down when the Phatbox is plugged in... I just don't know what to do... --------- ----- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of the Sony Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: b obbybr aun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as sugge sted and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C9 0 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? g t; g t; -------------- Original message -------------- From: Matt Dralle &g t; -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The gt; g t; links are for reference only and you might find you need to interpolate a little with respect to colo rs and pin numbers and what not: What Matt Found on his ca ble: BR http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. gt; Us e the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. &g t; > ; Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable ma nufact urers since Matt purchased his system. The g t; connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). > ; The numbers can not be seen on the Sony connector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device co nfigur ations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device configurations. gt; The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the & gt; signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should the n forc e a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 9 4551 < BR> 925-606-1001 V | 925-606 -6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft BR Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. & gt; Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that so meone woul dn't m ind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some > ; information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color ; coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a little ; with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf & gt; Wh at Phatbox Said: http://www.m atroni cs.com/xdp4000x/SonyCable5.pdf ; Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle Fo > ; r refe rence, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head < BR> unit. Firmw are 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmod ified cable will work with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After t he Pha tBox is connected, it will boot and then shutdown. The g t; PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" BR ; gt; R Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft g t; ; ================================================================== Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So f rustra ting, the C9 0 know s the Phatbox is & gt; th ere, and can control it just fine, but the 4000x just shuts down whenever it's plugged in. I find it odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which isshut down when the Phatbox is plugged in... I just don't know what to do... -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of the Sony Phatbox firmware? Matt At 0 7:27 P M 4/17/2006 Monday, you wrote: & gt; &g t; -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB t hat &g t; > ; R someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dra lle R Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The & gt; &g t; gt; links are for reference only and you might find you n eed to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using ve rsion 7.0 Sony firmware on your Phatbox? If yo u are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle g t; For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I & gt; ; have attached a PDF with a detailed description of the connections (So nyCabl e5.pdf). The numbers can not be seen on the Sony connector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device conf igurat ions. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when gt; is ; the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" Matt G Dralle | Mat ronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email gt; http://www.matronics.com/ WWW | Featuring Produc ts For Aircraft Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still t here.. . as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since & gt; there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn 't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Drall e dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle BR Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. g t; The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: & gt; http://www.m atroni cs.com/xdp 4000x/ SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. ; Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle For referen ce, he re is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attach ed a PDF with a detailed description of the connecti ; ons R (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. &g t; Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatB ox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox sho &g t; > ; uld th en force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email ; http://www.matronics.com/ WWW | Featuring Products For Aircraft ================================================================== Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft g t; What do you know abou t the reset line being cut in your diagram? This is the only other difference shown in your diagramthat wasn't done in themodification of the cable. Here's what they guy that's been doing the work on the unit & gt; for me wrote after I contacted him the last time about the 4.7k resistor not working: Well its a pulldown resistor so any value of several k or so should do the job 5 vs 10 should not matter but I could be wrong. The other thing w as tha t in the diagram you showed me the reset line seemed to be cut. I didnt do this because lower down it seemed that they fixed that with a firmware update? Im not sure if that would help but you might want to ask Matt. Does it still work when directly connected to the head unit? ; & gt; Does this sound like something that could cause a problem? -------------- Original message -------------- From: bobbybraun(at)comcast.net -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shuts down whe never it's plugged in. I find it odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which is shut down when the Phatbox is plugged in... I just don't know what to do... - ------ ------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of t he Son y Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in m y R 4000x powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm ; running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Dral le
-- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some g t; g t; inf ormation on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: > ; Wha t Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through Ph atMana ger). Matt Dralle For reference, here is a message from M ike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a g t; ; 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). g t; ; The numbers can not be seen on the Sony connector. They can be seen on th e PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work g t; with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for a rbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. < BR>> ; After the PhatBox is connected, it will boot and then shutdown. The PhatBox ; shou ld then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" Matt G Drall e | Ma tronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle @matro nics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft > ; Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only communicates with the Phatbox. gt; St ill wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone B R ; gt; wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will gt; need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not m ight be different depending on the version of cable you have. The g t; links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbe rs and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.m atroni cs.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are y ou using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle Fo r refe rence, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a
10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Son g t; ;gt; y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work gt; g & gt; &g t; t; with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. ; After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a r eset a fter a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ========================================== ====== ================== Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dral le@mat ronics.com Email http://www.matronics .com/ WWW | Featuring Products For Aircraft Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shuts down whenever it's pl ugged in. I find it odd that the Phatbox can still be recognized and gt; g t; controlled since it is plugged into the 4000x which isshut down when the Phatbox is plugged in... I just don't know w hat to do... -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of the S ony Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soo n as t he Phatbox is plugged in my &g t; > ; 4000x powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohm s inst ead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Drall e - - XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for re ference only and you might find you n eed to interpolate a little with respect to colors and pin nu & gt; &g t; mbers and what not: What Matt Found on his cable: http://www.matronics.c om/xdp 4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through
PhatManager). Matt Dralle g t; For reference, here is a message from Mike Woo at Phatnoise way back ; when: gt; R "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Sony c onnect or. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will wor k with any multi-device conf igurat io ns. R The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the & gt; right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" g t; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email gt; http://www.matronics.com/ WWW | Fe aturin g Products For Aircraft Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only c ommuni cates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k s ince there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of th e bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm r unning out of options here. Can anybody help? -------------- Original message -------------- From: Matt Drall e dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color &g t; > ; coding BR ; and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: gt; Wh at Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.m atroni cs.com/xdp 4000x/ SonyCable5.pdf g & gt; t; Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Drall e For reference, here is a message from Mike Woo at Phatnoise wa y back when: "We changed cable manufacturers since Matt purchased his system. The &g t; connections are the same but the colors are different. You want to connect gt; a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connecti ons R (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work &g t; > ; with any multi-device configurations. g t; ; The problem is with the bus master signal. I t is a ; n input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox sho uld th en force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 g t; 925-606-1001 V | 925-60 6-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ================================================================== ; &g t; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft g t; matron gt; ics.com/xdp4000x-list/download Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-60 6-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Fea turing Products For Aircraft I actually do have one a XA-C30, and during my initial installation I tried using it with the Phatbox just to see if it had an effect. This last time I did not try it with it installed however so I'll give it another try. So you don't think the reset line in your diagram or a higher value resistor could be the problem, huh? -------------- Original message -------------- From: Matt Drall e dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle & gt; Do you have an XA-C30 multiplexer? On both of my installations, I am plugging g t; the Phatbox into the system using one of these. Basically C90-4000-C30-Phatbox. I don't know if I've ever tried plugging the Phatbox directly into a 4000. Seems like I must have tried that at some point, but I can't remember for sure. You might be able to talk me in to loaning you a XA-C30 if you promise on your mama's grave to return it... ;-) Matt At 08:05 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net What do you kn & gt; ow abo ut the reset line being cut in your diagram? This is the o nly other difference shown in your diagram that wasn't done in the modification of the cable. Here's what they guy that's been doing the work on the unit for me wrote after I contac ted hi m the last time about the 4.7k resistor not working: Well its a pulldown resistor so any value of several k or so should do the job 5 vs 10 should not matter but I could be wrong. The other thing was that in the diagram you showed me the reset line seemed to be cut. I didnt do this because & gt; &g t; lower down it seemed that they fixed that with a firmware update? Im not sure if that would help but you might want to ask Matt. Does it still work when directly connected to the head unit? Does this sound like something that could cause a problem? -------------- Original message ----------- gt; g t; --- R From: bobbybraun(at)comcast.net -- XDP4000X-List message posted by: bobbybraun(at)comcast.net ; Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is & gt; th ere, and can control it just fine, but the 4000x just shuts down whenever it's plugged in. I find it odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which is shut down when the Phatbox is plugged in... I just don't know what to do... -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of the Sony Phatbox firmware? R Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4
000X-L ist message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to gt; ; part with for some cash, or a photo of the bottom of a Sony PB that < BR>> ; someone wouldn't mind me using to get myself a c able d irect from the factory? I'm running out of options here. Can anybody help? g t; ; -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what & gt; &g t; not mi ght be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: What Mat t Foun d on his cable: http://www.matronics.com/xdp4000x/U nilink -To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little diff erent. Use the drawing that matches best your in stalla tion. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The g t ; connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orang e (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Sony connector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work &g t; > ; with any multi-device configurations. The problem is with the bus master signal. I t is a n input. It is used BR ; for g t; ; arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to M att regarding pushing reset. He would know best about using the C90. Regards, Mike" gt; Ma tt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Ema il h ttp:// www.matronics.com/ WWW | Featuring Products For Aircraft Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatb ox is plugged in my 4000x powers down, the system resets and the C90only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. gt; g t;Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm runnin ; g out of options here. Can anybody help? & gt; &g t; -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbe rs and what not: What Matt Found on his cable: http: / /www.m atronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.m atroni cs.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little d iffere nt. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have ope ration al issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable man ufactu rers since Matt purchased his s ystem. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orang e (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device configurations. The problem is with th e bus master signal. It is an input. It is used for a rbitra > ; tion during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Liverm ore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle@ matron ics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircra ft ================================================================== Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft & gt; Yes, and I even reinstalled the firmware and did a comp lete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shuts down whenever it's plugged in. I find it odd t hat the Phatbox can still be recognized and controlled since it is plugged into the 4000x which is shut d own when the Phatbox is plugged in... I just don't know what to do... -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com > ; -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of the Sony Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bo bbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resist or sho < BR>> ; uld've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original me ssage -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this c able i ssue. Below are two links to some gt; information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you n eed to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf g < BR>> ; t; ; What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use t he dra wing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to h ave op erational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle g t; > ; For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are th e same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbe rs can not be seen on the Sony connector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device conf igurat ions. The problem is with the bus master signal. It is an input. It is used for arbitration during device initializatio n. Wit hout the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox g t; sho uld then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" g t; ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email gt; http://www.matronics.com/ WWW | Featuring Products For Aircraft gt; R Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only communicates with the Phatbox . Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to pa rt wit h for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? &g t;
-------------- Original message -------------- From: Matt BR ; Drall e dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will BR ; need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a > ; gt; little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What P hatbox Said: http://www.m atroni cs.com/xdp 4000x/ SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using v ersion 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle BR ; For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are th e same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connecti & gt; ons R (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They c an be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-devi ce con figurations. The problem is with the bus master signal. It is an input. It is used for arbitration during device i nitial ization. Without the p ull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox sho uld th en force a reset after a few seconds. Ho wever, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 9 25-606 -1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft gt; g t; ================================================================== Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircr aft g t; What do you know about the reset line being cut in your diagram? This is the only other difference shown in your diagramthat wasn't done in themodification of the cable. Here's what they guy that's been doing the work on the unit for ; me BR wrote after I contacted him the last time about the 4.7k resistor not wo rking: Well its a pulldown resistor so any value of several k or so should do the job 5 vs 10 should not matter but I could be wrong. The other thing was that in the diagr am you showed me the reset line seemed to be cut. I didnt do this because lower down it seemed that they fixed that with a firmware up date? Im not sure if that would help but you might want to ask Matt. Does it still work when directly connected to the head unit? Does this sound like something that could cause a problem? -------------- Original message -------------- From: bobbybraun(at)comcast.net -- XDP4000X-List message posted by: bobbybraun(at)comcast.net g t; Yes , and I even reinstalled the firmware and did a complete system reset
afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is gt; g t; there, and can control it just fine, but the 4000x just shuts down whenever it's plugged in. I find it odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which is shut down when the Phatbox is plugged in... I just don't know what to do... -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of t he Son y Phatbo x firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote : -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the pr oblem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90 only communicates with the ; Phat box. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a con flict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm ; running out of options here. Can anybody help? gt; R -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable iss ue. Be low are two links to some information on how the Phatbox-Sony cabl es are wired. Note that you *wil l need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: Wha t Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf gt; What Phatbox Said: http ://www .matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that m atches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle For reference, here is a message from M ike Woo at Phatnoise way back when: & gt; &g t; "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connec t a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Sony connector. They can b R e seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configuration s. I'm not sure if firmware 6.00 and an unmodified cable will work g t; with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all ti mes. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should li sten BR to > ; Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" Matt G Drall e | Ma tronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft Well I had the cable modified with the 4.7k ohm resister installed as sugge sted and the problem is still there... as soon as the Phatbox is pl ugged in my 4000x powers down, the system resets and the C90only communicates with the Phatbox. Still wondering if that resistor should've been 10k oh ms ins tead of 4.7k since there seemed to be a conflict of inform ation. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone gt; wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? ------------ -- Ori ginal message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle gt; R Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor betwe en ground and the blue wire. Note the color coding and what not might be different depending on the version of cab le you have. The links are for reference only and you might find you need to interpolate a little with respe ct to colors and pin numbe rs and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.m atroni cs.com/xdp4000x/SonyCable5.pdf Depend ing on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Son y firm ware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable thr ough P hatManager). Matt Dralle Fo r refe rence, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the g t; ; PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 a nd an unmodified cable will work gt; g t; with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal &g t; stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. g t; Aft er the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, yo u shou ld listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | BR ; 94551
925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ================================================================== Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 ; 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Produ cts Fo r Aircraft & gt; &g t; Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shuts down whenever it's p l ugged in. I find it odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which isshut down when the Phatbox is plugged in... I just don't know what to do... -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message p osted & gt; &g t; by: Matt Dralle Are you running the 7.0 vers ion of the Sony Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x g t; powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohm s inst ead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're w illing to part with for some cash, or a photo of the bo ttom o f a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on th is cable issue. Below are two links to some information on ho w the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for re ference only and you might find BR ; you n eed to int erpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://ww w.matr onics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. gt; Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle g
t; g t; For reference, here is a message from Mike Woo at Phatnoise way back when: gt; R "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Sony connector. They can be seen on the PhatBox conne ctor. An unmodified cable should work whe n dire ctly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work gt; with any multi-device conf igurat ions. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is conne cted, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He wo uld know best about using the C90. Regards, Mike" Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 92 5-6 06-628 1 F | dralle(at)matronics.com Email gt; http://www.matronics.com/ WWW | Featuring Products For Aircraft > ; Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only c ommuni cates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. BR ; Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn' t min d me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Drall e dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding BR ; and what not migh t be d ifferent depending on the ve rsion of cable you have. The links are for reference only and you might find you need to interpolate a littl e with respect to colors and pin numbers and w hat not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.m atroni cs.com/xdp 4000x/ SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmw are (u pgradeable through PhatManager). Matt Drall e For reference, here is a messag e from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The & gt; connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connecti ons R (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device c onfigu rations. I'm not sure if fi rmware 6.00 and an unmodified cable will > ; work with any multi-device configurations. ; The problem is with the bus master signal. I t is a n input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox sho uld th en force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. & gt; &g t; Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.c om Ema il http://www.matronics.com/ WWW | Featuring Products For Aircraft ================================================================== ; &g t; > ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft g t; matron ics.com/xdp4000x-list/download g t; ; Matt G Dralle | Matronics | PO Box 347 | Livermore | C A | 94 551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.co m Emai l http://www.matronics.com/ WWW | Featuring Products For Aircraft QUOTE Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ist/se arch Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-6 06-100 1 V | 925-606-6281 F | dralle(at)matronics.com Email g t; htt p://www.matronics.com/ WWW | Featuring Products For Aircraft Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft Yes, I've thought about all that already, but here is the thing, I can't get any audio to be recognized by the 4000x through it's Analog Changer Inputs. The only reason I know it sounds bad is becau se I h ooked a set of headphones up to the phatbox to test if any audio was present and when I listened it sounded horrible, (if not mono). I listened to the same exact mp3 file that was being played on the PB back inside on my computer through the same headset using the crappy non 24bit burr brown outputs of my laptop and it sounded 1000x more full and realistic, so that worries me. And the fact that I can't get any audio to play back when plugged into the analog changer inputs worries me even more, I really hope this thing didn't somehow damage my 4000x, there is no way I want to send it off to Sony and let them hack away at it like they did with my last C90 I sent them... I have done a full reset from the C90 and still nothing. I'll test out my other equipment that I know was wor king b eforehand tomorrow and then I'll know more, but that still doesn't change the issue with the terrible sound output of the PB. ------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Great news! Couple of things come to mind with respect to your new audio woes. Digital vs Analog input on the 4000x is only negotiated on reset (button on C90), so with all the plugging around, make sure that you set things up like you want, then press that reset button. Second, the "tinny" sound might be because you've selected an unprogrammed EQ/Xover setting on the 4000x. The default setting has some of the Xover settings off or highly attenuated. & gt; Plug your PC back into the 4000x and double check all of your EQ and XO memory locations, and then make sure you select the right ones on the HU. Almost there! Matt BR ; At 08:13 PM 4/18/2006 Tuesday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Ok, I went ahead and clipped the reset wire and now the PB actually works in my system without shutting everything off! BUT... and this is a big but, my processor is not accepting analog audio at the analog changer input any longer (and it used to just fine)... I did test and there is audio at the outputs of the PB, but it doesn't sound right at all, tinny and flat, no bass, dull highs. I threw my cd changer back in to s ee if my processor would accept analog audio from that and the analog outputs of that piece are not working any longer either... (I can't say for 100% that they worked before hand since I always used the digital output of the changer, and never tested the analog outputs) I have yet to try my XM uni t, which I know the analog outs used to work on since those are the only outputs it has and I used it for about 6 months in my system, but that will have to wait till daylight tomorrow since it's late and I don't have the time to wire anything else in tonight. So I guess the good news is, the PB works now, well sorta. I'm partially convinced that something is wrong with it's audio outputs because like I said before it sounds really bad, and now I'm worried that something i s brok en inside of my processor as well, but no need to jump to conclusions until I can check everything out properly tomorrow. At least I made some progress... -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle C ut the reset line on the cable. Sounds to me like the PB is holding that line down and never letting anyone else init. Matt At 04:27 PM 4/18/2006 Tuesday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well, I went and tried every option I could think of within my resources, short of unhooking the 4000x and connecting the C30 directly to the C90 , then from it split out to the 4000x, PB, and my changer and XM respectively. Here's a list of the attempts and their corresponding outcomes: Phatbox (PB) plugged directly into the Changer Input of the 4000x: PB powers up fine and is recognized, 4000x disappears and the C90 only sees the PB. g t; XA-C30 plugged into the Changer Input of the 4000x, PB in Control 1 of C30: PB powers up fine and is recognized, 4000x disappears and the C90 only sees the PB. XA-C30 plugged into the Changer Input of the 4000x, PB in Control 1 of C30, Changer in Control 2 of C30: PB powers up fine and is recognized, 4000x and Changer both disappear, C90 only sees the PB. XA-C30 plugged into the Changer Input of the 4000x, PB in Control 1 of C30, XT-XM1 in Control 2 of C30 : PB powers up fine and is recognized, 4000x and XM Radio both disappear, C90 only sees the PB. XT-XM1 plugged into the Changer Input of the 4000x, PB plugged into input of XT-XM1: PB Powers up fine and is recognized, 4000x and XM Radio both disappear, C90 only sees the PB. g t; ; Both the Changer (CDX-848X) and XM radio work perfectly when connected into the system without the PB. Basically anything that is run inline before AND after the Phatbox is shut down and ignored by the system. Power is cut to all connected units on both sides besides C90 and PB when the PB is plugged in. Bottom line, I didn't learn a thing from any of this and am no further ahead in figuring out what the problem is...lol > ; Matt, I may just take you up on your offer to test out my PB in your system, but before I go that route I'm going to try a couple more things. I'm going to have the cable modified one last time with a 10k resistor and the reset line cut. Plus I'm going to blow another $100 on a used b ut fac tory original PB cable from someone in Europe who is unable to tell me the origin (other than it was made by Phatnoise) or age of the cable so I don't know how recent it has been made (but given my recent luck I'm sure it'll be one of the old cables that were made before the modification was put in place. I'm just glad I didn't have anything sharp or blunt near me after I finished all these tests, if there had been who knows what the outcome would've been! &g t; Ahh hh! -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Well, if you're handy with a soldering i ron, I would try both the higher resistor and the reset line options. Neither will hurt the equipment. Well, unless you miss wire something... :-) The Phatbox has a bad habit of insisting on being the first CDChanger slave on the bus. Each class of accessory you can hook up the the Unilink Bus (UB) has a class that it falls into. Here are some Unilink device classes along with some examples: CD Changer: CD Changers, Phatbox, XA-300 MD Changer: MD Changers, XM Radi o (ori ginal Sony box) Tuners: TV Tuner, Internal AM/FM Tuner Processors: 210, 4000x, internal Bass/Treble gt; On system start up, the Head Unit (HU) sends out a broadcast asking for each device class on the UB. Each device of the given class will respond with "I'm Here" and the HU will respond back to the an "dynamic" address for that particular device to use. The address is a combination of the device class (high nibble) and the device's assigned address on the UB (low nibble). An abbreviated version of this little "dance" occurs each time the HU is powered up. If the HU discovers that there is anything different (new or missing device) from the last time it started, it will reset the bus (both a protocol sequence as we ll as dropping the Reset wire) and start a whole ne w bus address negotiation. The actual address of the device is determined by its location on the bus. The closer a device is to the HU the lower its address will be. Basically what happens on startup is that the first device on the UB disables bus connectivity to all of the slaves down stream until it receives an address from the HU. On the XA-C30, logically each respective port looks like a device in the stream, so negotiation goes from Port 1 to Port 2 to Port 3. The Phatbox for some stupid reason, insists on being address 1 in the CD Changer class so you have to be really careful t hat it is either directly plugged & gt; into the HU or is on Port 1 of the first XA-C30 in the chain. That being said, this addressing limitation shouldn't be conflicting with the 4000x in your system since they are different classes of devices, but I wanted to point out the caveat with the Phatbox addressing since it took me a while to figure that out. I asked Mike Woo at Phatnoise why they hard coded the addressing that way, but I didn't really get an answer back. I've written an embedded processor Unilink Slave emulator that runs on an 8051-compatible microcontroller and I was able to write a negotiation routing that is 100% compatible with the m aster/slave addressing algorithm, so if I can do it, surly Phatbox could. If you 'd like, you can send me your Phatbox and I can give it a try here on my two installations to see if the problem is the Phatbox or something else. Matt At 04:59 AM 4/18/2006 Tuesday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net I actually do have one a XA-C30, and during my initial installation I tried using it with the Phatbox just to see if it had an effect. This last time I did not try it with it instal led ho wever so I'll give it another try. So you don't think the reset line in your diagram or a higher value resistor could be the problem, huh? -------------- Original message -------------- From: Matt D ralle -- XDP4000X-List message posted by: Matt Dralle Do you have an XA-C30 multiplexer? On both of my installations, I am plugging the Phatbox into the system using one of these. Basically C90-4000-C30-Phatbox. I don't know if I've ever tried plugging the Phatbox ; dire ctly into a 4000. Seems like I must have tried that at some point, but I can't remember for sure. You might be able to talk me in to loaning you a XA-C30 if you promise on your mama's grave to return it... ;-) Matt At 08:05 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net What do you know about the reset line being cut in you r diag ram? This is the only other difference shown in your diagram that wasn't done in the modification gt; g t; of the cable. Here's what they guy that's been doing the work on the unit for me wrote after I contacted him the last time about the 4.7k resistor not working: Well its a pulldown resistor so any value of several k or so should do the job 5 vs 10 should not matter but I could be wrong. The other thing was that in the diagram you showed me the reset line seemed to be cut. I didnt do this because lower down it seemed that they fixed that with a firmware update? Im not sure if that woul d hel p but you might want to ask Matt. Does it still work when directly connected to the head unit? Does this sound like something that could cause a problem? -------------- Original message -------------- From: bobbybraun(at)comcast.net -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is g t; there, and can control it just fine, but the 4000x just shuts down whenever it's plugged in. I find it odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which is shut do wn
when the Phatbox is plugged in... I just don't know what to do... -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 v ersion of the Sony Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90 only comm unicat es with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm g t; running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are tw o link s to some information on how the Phatbox-Sony cables are wired. Note that you *will nee d* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: gt; ; http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.matronics. com/xd p4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. A re you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle For reference, here is a message from Mike Woo at Phatnoise way back when: gt; g t; "We changed cable manufacturers since Matt purchased his system. The connections are t he same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Sony connector. They can be seen gt; ; on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device configurations. > ; The problem is with the bus master si gnal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few s econds . However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" < BR>> ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle@ma tronic s.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only communicates with the BR ; Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. & gt; &g t; Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody hel p? -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and th e blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1. pdf R What Phatbox Said: http://www.m atroni cs.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 S ony fi rmware on your Phatbox? If you are using g t; ; anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connec tions are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections ( SonyCa ble5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. gt; An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal g t; ; stays high (+5V) at all times. Thus the PhatBox has trou ble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. g t; ; Regards, Mike" BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft g t; & gt; ================================================================== Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft gt; g t; Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustrating, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shuts down whenever it's plugged in. I find it odd that the Phatbox can still be recognized and contr olled since it is plugged into the 4000x which isshut down when the Phatbox is plugged in... I just don't know what to do... g t; -------------- Original message -------------- From: Matt Dralle dralle(at)matronics.com -- XDP4000X-List message posted by: Matt Dralle Are you running the 7.0 version of the Sony Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as gt; suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000 x powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this c able issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will g t; need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you n eed to interpolate a little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www .matro nics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.matronics.com/xdp4000x/SonyCable5.pdf > ; Depending on what version of cable you have, things might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. gt; ; Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle g t; For reference, here is a message from Mike Woo at Phatnoise way back when: "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a &g t; 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Sony connector. They can be seen on the PhatBox connector. An unmodified cable should work when directly connected to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi -devic e conf igurat ions. The problem is with the bus master signal. It is an input. It is used for arbitrat ion du ring device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email gt; http://www.matronics.com/ WWW | Fea > ; turing Products For Aircraft Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in my 4000x powers down, the system resets and the C90only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seeme d to b e a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm running out of options here. Can anybody help? -------------- Original message -------------- From: Matt Drall e dralle(at)matronics.com ; -- XDP4000X-List message posted by: Matt Dralle Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The links are for reference only and you might find you need to interpolate & gt; &a mp;g t; a BR little with respect to colors and pin numbers and what not: What Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http://www.m atroni cs.com/xdp 4000x/ SonyCable5.pdf Depending on what version of cable you ha ve, th ings might be a little different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable throug h PhatManager). Matt Dralle For reference, here is a message from Mike Woo at Phatnoise way back wh en: R "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connecti ons R (SonyCable5.pdf). The numbers can not be seen on the Son y conn ector. They can be seen on the PhatBox connector. gt; g t; An unmodified cable should work when directly connected to a head unit. F irmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for arbitration during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble kn owing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox sho uld th en force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He wou ld kno w best about using the C90. Regards, Mike" ; BR ; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ================================================================== g t; Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft g t; What do you know about the reset line being cut in your diagram? This is the only other difference shown in your diagramth at was n't done in themodification of the cable. Here's what they guy that's been doing the work on the unit for me wrote after I contacted him the last time about the 4.7k resistor not working: Well its a pulldown resistor so any value of several k or so should do the job 5 vs 10 should not matter but I could be wrong. The other thing was that in the diagram you showed me the reset line seemed to be cut. I didnt do this because lower down it seeme d that they fixed that with a firmware update? Im g t; not sure if that would help but you might want to ask Matt. Does it still work when directly connected to the head unit? Does this sound like something that could cause a problem? -------------- Original message -------------- From: bobbybraun(at)comcast.net -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Yes, and I even reinstalled the firmware and did a complete system reset afterwards, all to no avail. So frustra ting, the C90 knows the Phatbox is there, and can control it just fine, but the 4000x just shuts down whenever it's plugged in. I find i t odd that the Phatbox can still be recognized and controlled since it is plugged into the 4000x which is shut down when the Phatbox is plugged in... I just don't know what to do... -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle Are yo u runn ing the 7.0 version of t he Son y Phatbox firmware? Matt At 07:27 PM 4/17/2006 Monday, you wrote: -- XDP4000X-List message posted by: bobbybraun(at)comcast.net Well I had the cable modified with the 4.7k ohm resister installed as suggested and the problem is still there... as soon as the Phatbox is plugged in m y 4000x powers down, the system resets and the C90 only communicates with the Phatbox. Still wondering if that resistor should've been 10k ohms instead of 4.7k since there seemed to be a conflict of information. Anyone out there with a working spare Sony Phatbox cable they're willing to part with for some cash, or a photo of the bottom of a Sony PB that someone wouldn't mind me using to get myself a cable direct from the factory? I'm ; running out of options here. Can anybody help? gt; g t; -------------- Original message -------------- From: Matt Dralle -- XDP4000X-List message posted by: Matt Dralle < BR>> ; Okay, here's some help on this cable issue. Below are two links to some information on how the Phatbox-Sony cables are wired. Note that you *will need* the 4.7k ohm resistor between ground and the blue wire. Note the color coding and what not might be different depending on the version of cable you have. The g t; links are for reference only and you might find you need to interpolate a little with respect to colors and pin numbers and what not: Wha t Matt Found on his cable: http://www.matronics.com/xdp4000x/Unilink-To-Phatbox-Cable-Rev1.pdf What Phatbox Said: http: //www. matronics.com/xdp4000x/SonyCable5.pdf Depending on what version of cable you have, things might be a little BR ; different. Use the drawing that matches best your installation. Are you using version 7.0 Sony firmware on your Phatbox? If you are using anything else, you are going to have operational issues with the xdp-4000x. Make sure you're using 7.0 Sony firmware (upgradeable through PhatManager). Matt Dralle For reference, here is a message from M ike Woo at Phatnoise way back when: g t; ; "We changed cable manufacturers since Matt purchased his system. The connections are the same but the colors are different. You want to
connect a 10k resistor between the blue (bus master) and orange (ground) wires. I have attached a PDF with a detailed description of the connections (SonyCable5.pdf). The numbers can not be seen on the Sony connector. They can be seen on the PhatBox connector. An unmodified cable should work when directly conne cted to a head unit. Firmware 5.00 and an unmodified cable works with simple multi-device configurations. I'm not sure if firmware 6.00 and an unmodified cable will work g t; with any multi-device configurations. The problem is with the bus master signal. It is an input. It is used for a rbitra tion during device initialization. Without the pull-down the signal stays high (+5V) at all times. Thus the PhatBox has trouble knowing when is the right time to initialize itself. After the PhatBox is connected, it will boot and then shutdown. The PhatBox should then force a reset after a few seconds. However, you should listen to Matt regarding pushing reset. He would know best about using the C90. Regards, Mike" Matt G Drall e | Ma ; tronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft
