Yak-Archive.digest.vol-kd
February 25, 2013 - Present
much more:
Subject: | Re: prop inspection |
I think AC 39-7D is the latest authority on these issue. I am attaching it
here.=0A=0ASee paragraph 9 & 10 on pages 3 and 4.=0A=0A=0A"Each AD contains
an applicability statement specifying the=C2-product (aircraft, aircraft
engine, propeller, or appliance) to which it applies. Unless stated=C2-o
therwise (see subparagraph 9b of this AC), ADs only apply to type-certifica
ted (TC) aircraft,=C2-including ADs issued for an engine, propeller, and
appliance."=0A=0A"Non-TC=99d aircraft=C2-(e.g., amateur-built aircr
aft, experimental exhibition) are aircraft for which the FAA has not=0Aissu
ed a TC under part 21. The AD applicability statement will identify if the
AD applies to=C2-non-TC=99d aircraft or engines, propellers, and ap
pliances installed thereon."=0A=0A=0A________________________________=0A Fr
om: Tom Elliott =0ATo: yak-list(at)matronics.com =0ASent: Mond
ay, February 25, 2013 12:23 PM=0ASubject: RE: Yak-List: prop inspection=0A
tion? I have been told that if you remove the ( Certified ) Engine etc. Dat
a plate it is now=0Acompletely experimental=0Aand the AD's are moot? Anyone
have good info on this?=0A=0ATom Elliott=0ACJ-6A NX63727=0A777 Quartz Ave
=0APMB 7004=0ASandy Valley NV=0A89019=0ACell 541-297-5497=0AN13472(at)AOL.COM
=0A=0A=0A=0A=0A-----Original Message-----=0AFrom: owner-yak-list-server@mat
ronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of=0ABitt
erlich, Mark G CIV NAVAIR, WD=0ASent: Monday, February 25, 2013 12:11 PM=0A
ark.bitterlich(at)navy.mil>=0A=0AThis minor addition to what Dennis wrote is s
pecifically pointed towards AD's .... not just prop=0AAD's but *ALL*=C2-
AD's that are written on Type Certificated Parts that happen to reside in a
n=0AExperimental Aircraft.=0AI've been through this in detail with both the
FAA and the EAA, and can speak to it from personal=0Aexperience and please
realize local FSDO's might not agree with what I am saying here, but will
=0Ashortly after they read the material you can get from the EAA.=C2- =0A
=0AAircraft owners that have AD's on Type Certificated Parts that are in th
eir Experimental Aircraft=0Amust comply with *THE INTENT* of the AD but not
necessarily with exactly what the AD specifies.=C2- On=0Aa Certificated
Aircraft, the owner must comply with EXACTLY what the AD says.=C2- =0A=0A
So what does that mean exactly?=C2- Let's say you removed the mechanical
fuel pump from the GSO-480=0ALycoming Engine in your UTVA-66 and replaced i
t with an external fuel pump.=C2- An AD comes out on the=0AGSO-480 origin
al engine fuel pump.=C2- Kind of hard to comply with since you put in an
electric pump,=0Aso you no longer have the mechanical pump, and thus by cha
nging the design you have "complied with=0Athe intent" of the AD.=C2- =0A
=0AThe same thing could apply to say .... the MAG's, when you replaced them
with some kind of=0Aelectronic ignition.=C2- You're allowed to do this k
ind of thing even on a certificated engine, because=0Ait does indeed reside
in an Experimental Aircraft.=C2- =0A=0ASo while this is a small point to
make, it is indeed true.=C2- There is a small, but notable difference=0A
in doing EXACTLY what the AD says (certificated aircraft) and what the INTE
NT of the AD is, in an=0AExperimental Aircraft with a Certificated Part.=C2
- =0A=0AMark Bitterlich=0A=0A=0A-----Original Message-----=0AFrom: owner-
yak-list-server(at)matronics.com=0A[mailto:owner-yak-list-server(at)matronics.com
] On Behalf Of A. Dennis Savarese=0ASent: Saturday, February 23, 2013 15:17
=0ATo: yak-list(at)matronics.com=0ASubject: Re: Yak-List: prop inspection=0A
llsouth.net>=0A=0AIt depends on the certification of the prop.=C2- ie: if
the propeller has been issued a Type=0ACertificate Data Sheet (TCDS), then
whatever the TCDS=0A=0Asays or if the prop has any AD's, then whatever the
AD's say.=C2- The certification of the aircraft=0Adoes not negate the pr
op certification.=0A=0AA. Dennis Savarese=0A334-285-6263=0A334-546-8182 (mo
bile)=0Awww.yak-52.com=0ASkype - Yakguy1=0A=0AOn 2/23/2013 1:57 PM, Joe How
se wrote:=0A> is there a mandatory inpection for props on experimental airc
raft?=0A> *=0A>=0A>=0A> *=0A=0A=0A=0A=0A=0A=0A=0Amuch more:=0A=0A=0A=0A=0A
==C2- =C2- =C2- =C2- =C2- =C2- =C2- - MATRONICS WEB FORUMS
==C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2-
Hi Tom,=0A=0AParagraph 9.c. of AC 39-7D states the following:=0A=0A=0A"An A
D applies to each product identified in the applicability=C2-statement, r
egardless of whether it has been modified, altered, or repaired in the area
subject to=C2-the requirements of the AD."=0A=0AHere is my reading: If t
he removal of the data plate is a modification to the engine, the AD is sti
ll applicable to the modified engine.=0A=0AMost Lycoming AD's have the simi
lar language in the AD. For example, #98-02-08 says: "This airworthiness di
rective (AD) applies to=C2-each engine identified in the preceding applic
ability=C2-provision, regardless of whether it has been modified,=C2-al
tered, or repaired in the area subject to the requirements=C2-of this AD.
"=0A=0ASo the removal of the data plate most likely does not change the AD
applicability.=0A=0ARobin=C2-=0A=0A=0A________________________________
=0A From: Robin Hou <rmhou(at)yahoo.com>=0ATo: "yak-list(at)matronics.com" <yak-l
ist(at)matronics.com> =0ASent: Monday, February 25, 2013 12:58 PM=0ASubject: R
e: Yak-List: prop inspection=0A =0A=0AI think AC 39-7D is the latest author
ity on these issue. I am attaching it here.=0A=0ASee paragraph 9 & 10 on pa
ges 3 and 4.=0A=0A"Each AD contains an applicability statement specifying t
he=C2-product (aircraft, aircraft engine, propeller, or appliance) to whi
ch it applies. Unless stated=C2-otherwise (see subparagraph 9b of this AC
), ADs only apply to type-certificated (TC) aircraft,=C2-including ADs is
sued for an engine, propeller, and appliance."=0A=0A"Non-TC=99d aircr
aft=C2-(e.g., amateur-built aircraft, experimental exhibition) are aircra
ft for which the FAA has not=0Aissued a TC under part 21. The AD applicabil
ity statement will identify if the AD applies to=C2-non-TC=99d airc
raft or engines, propellers, and appliances installed thereon."=0A=0A=0A___
_____________________________=0A From: Tom Elliott <N13472(at)aol.com>=0ATo: y
ak-list(at)matronics.com =0ASent: Monday, February 25, 2013 12:23 PM=0ASubject
Elliott" =0A=0AQuestion? I have been told that if you remov
e the ( Certified ) Engine etc. Data plate it is now=0Acompletely experimen
tal=0Aand the AD's are moot? Anyone have good info on this?=0A=0ATom Elliot
t=0ACJ-6A NX63727=0A777 Quartz Ave=0APMB 7004=0ASandy Valley NV=0A89019=0AC
ell 541-297-5497=0AN13472(at)AOL.COM=0A=0A=0A=0A=0A-----Original Message-----
=0AFrom: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server@
matronics.com] On Behalf Of=0ABitterlich, Mark G CIV NAVAIR, WD=0ASent: Mon
day, February 25,=0A 2013 12:11 PM=0ATo: yak-list(at)matronics.com=0ASubject:
ich, Mark G CIV NAVAIR, WD" =0A--> =0A=0AThis min
or addition to what Dennis wrote is specifically pointed towards AD's ....
not just prop=0AAD's but *ALL*=C2- AD's that are written on Type Certific
ated Parts that happen to reside in an=0AExperimental Aircraft.=0AI've been
through this in detail with both the FAA and the EAA, and can speak to it
from personal=0Aexperience and please realize local FSDO's might not agree
with what I am saying here, but will=0Ashortly after they read the material
you can get from the EAA.=C2- =0A=0AAircraft owners that have AD's on Ty
pe Certificated Parts that are in their=0A Experimental Aircraft=0Amust com
ply with *THE INTENT* of the AD but not necessarily with exactly what the A
D specifies.=C2- On=0Aa Certificated Aircraft, the owner must comply with
EXACTLY what the AD says.=C2- =0A=0ASo what does that mean exactly?=C2
- Let's say you removed the mechanical fuel pump from the GSO-480=0ALycom
ing Engine in your UTVA-66 and replaced it with an external fuel pump.=C2
- An AD comes out on the=0AGSO-480 original engine fuel pump.=C2- Kind
of hard to comply with since you put in an electric pump,=0Aso you no longe
r have the mechanical pump, and thus by changing the design you have "compl
ied with=0Athe intent" of the AD.=C2- =0A=0AThe same thing could apply to
say .... the MAG's, when you replaced them with some kind of=0Aelectronic
ignition.=C2- You're allowed to do this kind of thing even on a certifica
ted engine, because=0Ait does indeed reside in an Experimental Aircraft.=C2
- =0A=0ASo while this=0A is a small point to make, it is indeed true.=C2
- There is a small, but notable difference=0Ain doing EXACTLY what the AD
says (certificated aircraft) and what the INTENT of the AD is, in an=0AExp
erimental Aircraft with a Certificated Part.=C2- =0A=0AMark Bitterlich=0A
=0A=0A-----Original Message-----=0AFrom: owner-yak-list-server(at)matronics.co
m=0A[mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Sav
arese=0ASent: Saturday, February 23, 2013 15:17=0ATo: yak-list(at)matronics.co
m=0ASubject: Re: Yak-List: prop inspection=0A=0A--> Yak-List message posted
by: "A. Dennis Savarese"=0A=0A=0AIt depends o
n the certification of the prop.=C2- ie: if the propeller has been issued
a Type=0ACertificate Data Sheet (TCDS), then whatever the TCDS=0A=0Asays o
r if the prop has any AD's, then whatever the AD's say.=C2- The certifica
tion of the aircraft=0Adoes not negate the prop certification.=0A=0AA. Denn
is Savarese=0A334-285-6263=0A334-546-8182 (mobile)=0Awww.yak-52.com=0ASkype
- Yakguy1=0A=0AOn 2/23/2013 1:57 PM, Joe Howse wrote:=0A> is there a manda
tory inpection for props on experimental aircraft?=0A> *=0A>=0A>=0Asp; =C2
- =C2- =C2- =C2- =C2- - List Contribution Web Site -=0A_; =C2-
=C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- &nb://www.m
atronics.com/contribution"=0A======
Subject: | Re: oil cooler overhaul |
Talking of oil coolers for the CJ6....
Has anyone replicated it in modern materials or come up with an off the shelf usable
alternative?
I removed mine for internal cleaning and was absolutely staggered by the weight
of it..... Its brass and probably weights about 25kg!
You'd gain some good performance if a firm like 'MOCAL' would replicate it in aluminum.
Any ideas?
Rgs
Harv
http://forums.matronics.com/viewtopic.php?p=395077#395077
From: | Didier Blouzard <didier.blouzard(at)gmail.com> |
Subject: | Anyone in NJ or NY |
Hey guys
i am currently in Montvale in NJ strugling to fly around but it looks
well ... not easy.
I'll keep on trying to fly around NY and any hints would be appreciated.
At least is there any Yakers around here so we can have a drink and
speak of our common passion.
Cheers
Didier BLOUZARD
Portable : +33 6 51 84 48 02
Email: didier.blouzard(at)gmail.com
i have a guy building up a modified cooler for a Yak 52TW. He has experience with
a variety of aircraft coolers as well as items such as Mustang radiators.
Contact me off list for info.
Mike Hastings
http://forums.matronics.com/viewtopic.php?p=395105#395105
From: | "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil> |
Is there a reason you don't feel comfortable putting his name and number
here?
Just curious... nothing bad meant by it.
Mark
[mailto:owner-yak-list-server(at)matronics.com] On Behalf Of mikspin
Sent: Tuesday, February 26, 2013 12:08
Subject: Yak-List: Re: oil cooler overhaul
experience with a variety of aircraft coolers as well as items such as
Mustang radiators. Contact me off list for info.
Mike Hastings
"...-an off the shelf usable alternative?"=0A=0AI was just thinking about
the same thing for my CJ recently. However, my motivation is not for weigh
t saving. I was thinking mounting the oil cooler inside the engine cowling.
The advantages seem to be a shorter run of the oil hoses, easier hose repl
acement and possible cabin heat using the oil cooler. What do you think?=0A
=0A=0A=0A________________________________=0A From: Harv <martin.harvey@kbr.
com>=0ATo: yak-list(at)matronics.com =0ASent: Tuesday, February 26, 2013 6:19
AM=0ASubject: Yak-List: Re: oil cooler overhaul=0A =0A--> Yak-List message
posted by: "Harv" =0A=0ATalking of oil coolers for t
he CJ6....=0A=0AHas anyone replicated it in modern materials or come up wit
h an off the shelf usable alternative?=0A=0AI removed mine for internal cle
aning and was absolutely staggered by the weight of it..... Its brass and p
robably weights about 25kg!=0A=0AYou'd gain some good performance if a firm
like 'MOCAL' would replicate it in aluminum.=0A=0AAny ideas?=0A=0ARgs=0AHa
rv=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.
- - - - - - - - - - - - - - - -Matt Dralle, L
That's a shame. We are in France for all of march and was hoping to make co
ntact.
Yak52
VH-YGC
> From: didier.blouzard(at)gmail.com
> Date: Tue=2C 26 Feb 2013 16:19:45 +0100
> Subject: Yak-List: Anyone in NJ or NY
m>
> Hey guys
> well ... not easy.
> Cheers
> Didier BLOUZARD
I have not done the numbers but I am afraid that you would have to add a
ton of weight to the tail to off set moving the oil cooler to the firewall.
Doug
On Tue, Feb 26, 2013 at 12:28 PM, Robin Hou wrote:
> "... an off the shelf usable alternative?"
> I was just thinking about the same thing for my CJ recently. However, my
> motivation is not for weight saving. I was thinking mounting the oil cooler
> inside the engine cowling. The advantages seem to be a shorter run of the
> oil hoses, easier hose replacement and possible cabin heat using the oil
> *From:* Harv
> *To:* yak-list(at)matronics.com
> *Sent:* Tuesday, February 26, 2013 6:19 AM
> *Subject:* Yak-List: Re: oil cooler overhaul
> weight of it..... Its brass and probably weights about 25kg!
> in aluminum.
> Any ideas?
> Rgs
> Harv
> http://forums.matronics.com/view -Mat==============
Subject: | Re: Anyone in NJ or NY |
Hay it is easy. Stay. Below 1100 feet and You can fly up or down the Hudson River
with no problem. Best sighting trip in the world.
Jim "Pappy" Goolsby
Sent from my iPad from some where on The 3rd rock from the Sun.
On Feb 26, 2013, at 10:19 AM, Didier Blouzard wrote:
> Hey guys
> well ... not easy.
> Cheers
> Didier BLOUZARD
From: | Elmar & Manuela Hegenauer <samira.h(at)shaw.ca> |
Mike,
some time ago I have met a guy who
was not happy with the performance
of the oil cooler in his CJ.
He told me he installed a Broussard/Stearman
oil cooler instead and it works like a charm.
Can't remember his name but he might
read this list and tell us more.
cheers
Elmar
Hi Mike;
See if you can determine where it's leaking from. If from a fitting that is
likely repairable without too much trouble. If leaking from the core it will
need overhaul or replacement.
There are two overhaul facilities I know of. Ultimate Oil Cooler in
Winnipeg (in the Aero Recip. facility) and Pacific Oil Cooler in the Los
Angeles area. Been meaning to look up the contact info. at the hangar but
keep forgetting. I have used both over the years. I suspect there are more
in the far east (Toronto or Montreal) but don't know.
A core leak can be very expensive to repair so if that is the problem you
may want to get a new one from Doug.
Cheers;
Walt
Sent: Sunday, February 24, 2013 3:19 PM
Subject: Yak-List: oil cooler overhaul
Looking like the oil cooler is starting to leak. Overhaul time. Any
recommendations out there? Cheaper to replace? Thoughts?
CJ6A Housai equipped
Mike "Skidmk" Bourget
Ottawa, Ontario
http://forums.matronics.com/viewtopic.php?p=394955#394955
Subject: | Needed ASAP! Nanchang trim cable on the spool. |
Craig Ekberg is looking for a new Nanchang elevator trim cable on the spool ASAP.
He can replace it in about 30 days if you're selling from your spares inventory.
Please e-mail him ASAP at craigTE(at)msn.com
http://forums.matronics.com/viewtopic.php?p=395183#395183
Thanks fella,,, we'll take it out this weekend and check it for problem. Given
the cost of shipping, and then finding out it will cost a ton to repair. We'll
probably just pony up and send Doug some spring cash :D
M
Ottawa, Ontario
http://forums.matronics.com/viewtopic.php?p=395224#395224
Subject: | Terra Transponder |
Mine finally died. Before I buy something modern to replace it, does anybody have
a functioning Terra transponder sitting on a shelf?
Blitz Fox
415-307-2405
Didier,
Shoot me an email or text +19176601084 I might be able to give you some hint
s about local flying. And yes, Hudson run is the best, just make sure you st
udy altitudes and reporting points beforehand.
Serge
From: | "Bradly Banks" <brad(at)runawaymedia.co.za> |
Subject: | Detailed wing drawings |
Hello all , thanks to all who helped with the suggestions on shipping a 52 ,
it has been very helpful.
Has any one got detailed drawings of the wings for a 52 or a 50 any
information( schematic /machine/ photographs) will be very much
appreciated.
Many thanks
Bradly Banks
Cell:0825083200
Tel :0333308580
Email :brad(at)runawaymedia.co.za
Skype: brad.banks10
Subject: | Re: Detailed wing drawings |
From: | "Roger Kemp M.D." <viperdoc(at)mindspring.com> |
Hey Bradley,
If you find a set for the 50 let me know. Found a set a few years ago in RU.
The prob,EM was they wanted $6000 for them in 2005!
Doc
, it has been very helpful.
> Has any one got detailed drawings of the wings for a 52 or a 50 any infor
mation( schematic /machine/ photographs) will be very much appreciated.
> Many thanks
> Bradly Banks
> Cell:0825083200
> Tel :0333308580
> Skype: brad.banks10
Subject: | Re: Another day in a Viper |
I know, its what almost 7 years later. but,,,,, wow... I"m aroused!!
thanks Tim
Ottawa, Ontario
http://forums.matronics.com/viewtopic.php?p=395557#395557
Memories. Block 10 to Block 50.
Doc
> thanks Tim
> Ottawa, Ontario
Subject: | Fw: Swamp Thunder/Waycross Update!!! |
----- Forwarded Message ----
From: Red Star Pilot's Association <shane(at)ssengrsc.com>
Sent: Tue, March 5, 2013 10:15:57 AM
Subject: Swamp Thunder/Waycross Update!!!
RPA Member! Are you having trouble viewing this email? View the corrected
version here.
Swamp Thunder
Waycross, GA (KAYS)
Update: Current Attendance List - Hotel Rooms Limited, BOOK NOW!!
Below is the current list of registered attendees. If you are not on the list
and plan to attend let me know ASAP!!
Hotel Rooms are limited so book now. Hotel info is below.
Name Type Aircraft FAST
Shane Golden Yak-52 Lead
BJ Kennamore CJ-6 Lead
Robert Langford CJ-6 Lead
Jon Blake CJ-6 Lead
Jim Goolsby CJ-6 Check
Tim Williams Yak-52TW Lead
Jeff Dennis Yak-52 Wing
Tim Stevens Yak-52 Lead
Rob Mortara CJ-6 Lead
Roger Kemp Yak-52 Wing
Jim Kilpatrick Yak-52
Craig Payne CJ-6 Lead
Jim Burke Yak-52
Matt Lazar CJ-6
Tom Geoghegan CJ-6
Todd Olds IAR 823
Ami Vizer L-39
Kevin Campbell MX-2 IP
Steve See IAR 823
Rich Hess L-39 Check
Richard Langer CJ-6 Lead
Charles Robertson T-34
Mike Foster CJ-6 Lead
Wayne Altman
Phil Webb Yak-52
Dates: 5 - 8 April 2013
Swamp Thunder 2013 is starting to take shape! If you plan to attend please
email Shane Golden @ shane(at)ssengrsc.com.
HOTEL INFORMATION:
Rooms are reserverd at the following two hotels under "Red Star Pilot's
Association"
Quality Inn (Oscar's Bar Hotel) 912-283-4490
Holiday Inn 912-548-0720
Here's the agenda so far.
Friday 5 APR
-Arrivals, Ground School, Oyster Roast, FAST Training Flights
Saturday 6 APR
-FAST Training
-Guest Speaker (Noon in the FBO)
The invited guest speaker this year at Waycross, GA is Chief Warrant Officer
Five (retired) Larry Kulsrud. Larry spent 24 years in the Army as an attack
helicopter pilot serving in many operations and locations such as Desert Storm,
Haiti, Iraq, Cuba, Afghanistan and Somalia. His presentation at "Swamp Thunder"
will focus on his actions while assigned to the 160th Special Operations
Aviation Regiment during operation "Gothic Serpent" in Somalia. Most of you
will recall the best-selling book and blockbuster movie "Blackhawk Down" of this
operation. CW5 Kulsrud was awarded the Silver Star for his role as an AH-6
Attack Pilot providing covering fire for ground forces, both Delta Force and
Army Rangers evacuating wounded Blackhawk helicopter pilots. One particular
event in the movie where Larry is portrayed was as the attack pilot strafing the
bad guys using a infrared strobe light on the building top as his guide. You'll
find his presentation of the hair raising events in Mogadishu awe-inspiring, so
please make plans to join us at "Swamp Thunder" from April 5th through April
7th.
- FAST Recc/Check Rides
-Bombing Competition
-BBQ Dinner on Field with Special Guests "Letters from Home" Some of y'all will
remember them from Punta Gorda last year.
Sunday 7 APR
-FAST Recc/Check Rides
-FAST Flights
-Departure for Sun-N-Fun or Home
If you plan to attend please email me @ shane(at)ssengrsc.com.
Trouble viewing this email? Go to:
http://maildogmanager.com/page.html?p=0000015Fu8viviDTIg3QqIhe4lp7tpqRCYfA==&email=scgsmg@bellsouth.net
RPA Members! You can reach the President and Board of Directors simply by
replying to this E-Com!
2505 Via Anita, Palos Verdes Estates, CA 90274, United States
Review our Privacy Policy and Acceptable Use Policy.
One-Click Unsubscribe or manage your Subscription Preferences
Crafted and delivered by RedStar Pilots Association's Mail Dog!
Subject: | Right aileron bearing, YAK-52 |
Looking for help with identifying the correct bearing size on the right aileron.
Found a play, removed the aileron to find out that bearing is gone.
Would appreciate for an advice.
Thank you,
Serge
Subject: | Re: Right aileron bearing, YAK-52 |
From: | "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net> |
There are actually 4 bearings on the aileron. The inboard bearing and the bearing
on the top where the pushrod connects are 6x19x6 (mm) self aligning bearings.
If i am not mistaken, the outboard and middle bearings on the underside of
the aileron) are unique. I believe Jill will have them in stock.
Dennis
> Thank you,
> Serge
> Sent from my iPhone
Subject: | Aerostars (UK!) Video |
Hello fellow Yakisters,
For your entertainment, a mash-up of some of last season's footage.
Here's hoping the weather is a little kinder to us on this side of the pond this
year.
Best,
The Aerostars
https://vimeo.com/60267092
http://forums.matronics.com/viewtopic.php?p=395712#395712
Subject: | Re: Aerostars (UK!) Video |
Thanks!!!!!!
Superb!!!!
>pond this year.
>Best,
>The Aerostars
I have the bearings in stock. Please contact me offlist. Thank you,
Dennis.
Jill
M-14P, Inc.
From: | "Richard Goode" <richard.goode(at)russianaeros.com> |
Hello Bradly,
I noted your requirement for drawings - we have some drawings of the
structure of both 50 and 52.
They are quite detailed technical drawings, but certainly not of sufficient
detail that you could go and build another wing on the strength of them!. To
be precise, each aircraft is spread across, 3 sheets of A3, but covers the
complete aircraft and not just the wings.
Could these be of any interest?
Richard
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
Outstanding. Love great flying with good Rock 'N Roll to get the juices flowing
on an otherwise ho hum office follow up day!
Doc
>From: aerostar6 <mwlevy(at)btinternet.com>
>Sent: Mar 6, 2013 4:39 AM
>Subject: Yak-List: Aerostars (UK!) Video
year.
>Best,
>The Aerostars
From: | Rico Jaeger <rijaeger(at)wausau.k12.wi.us> |
Multiple Yaks and Motley Crue??? Add a couple bikinis and Utopia is
achieved!
As a musician I'm fired up.
As a pilot I'm humbled.
Great stuff!!! Thanks for the inspiration to "keep pluggin!"
> flowing on an otherwise ho hum office follow up day!
> Doc
> pond this year.
> >Best,
> >The Aerostars
Rico Jaeger
Choir / East High School
General Music / Horace Mann
Really impressive, great formation work!
Walt
Sent: Wednesday, March 06, 2013 2:39 AM
this year.
Best,
The Aerostars
Nice!.... Very nice!
Subject: | Re: yak drawings |
Richard,
What is the cost of the 3 sheet set?
Reply off list please.
Doug Sapp
On Wed, Mar 6, 2013 at 6:51 AM, Richard Goode <
richard.goode(at)russianaeros.com> wrote:
> Hello Bradly,****
> I noted your requirement for drawings ' we have some drawings of the
> structure of both 50 and 52.****
> sufficient detail that you could go and build another wing on the strengt
h
> of them!. To be precise, each aircraft is spread across, 3 sheets of A3,
> but covers the complete aircraft and not just the wings.****
> Could these be of any interest?****
> Regards****
> Richard****
> Richard Goode Aerobatics****
> Rhodds Farm****
> Lyonshall****
> Hereford****
> HR5 3LW****
> Tel: +44 (0) 1544 340120****
> Fax: +44 (0) 1544 340129****
> www.russianaeros.com****
Nothing like starting your work day with a little flying and Rock 'N Roll! Sweet!
Doc
> Walt
> -----Original Message----- From: aerostar6
year.
> Best,
> The Aerostars
From: | "Todd McCutchan" <todd(at)fastaircraft.com> |
Subject: | Phoenix Fly-in March 28 - 31 |
Just 3 weeks remain till the 2nd Annual Phoenix Fly-in (Formation
University) March 28 - 31 at the Deer Valley Airport (DVT).
Currently we have 25 aircraft signed up (8 CJ's / Yak's) plus a B-25.
Attendance will be limited to 32 aircraft so only 7 spots remain. It's time
for a trip out to our warm sunny weather in AZ.
There will be something for everyone at this event so it does not matter if
you just bought your airplane and just want to learn more about it or you
are an advanced formation pilot come on out.
Giveaways including free fuel, parachute repacking, and B-25 rides with a
Saturday hangar dinner / party sponsored by Atlantic Aviation.
Hotel rooms are going fast and the Hilton Garden Inn expect to be sold out
for the event.
If you would like to come please fill out the below information and return
it to me ASAP at todd(at)fastaircraft.com or (260) 402-1740. Event fee will be
$20. Additional information available on request.
Aircraft Type
Tail Number
Owner Name
Owner Cell
Owner Email
Second Owner / GIB
Arrival Date
Arrival Time
Departure Date
Departure Time
FAST
Engine HP
Needs Checkride
Acro
Tac Form
Form Acro
Tac Nav
Carrier Landing
Comments
Hope to see you all there!
Kind regards,
Todd McCutchan
Fast Aircraft
T-34A - N134FA
KDVT Hangar 33-13
Cell - 260.402.1740
Email: todd(at)fastaircraft.com
Skype: tmccutchan
Web: www.fastaircraft.com & www.toddmccutchanairshows.com
Subject: | Cleaning out the hanger |
Guys,
Several years ago I was involved with building up a full IFR CJ. The back
up attitude indicator was to be vacuum with a 24 volt airborne vacuum pump.
The owner decided to not install a second AI so I have it as surplus and
am offering it for sale.
The vacuum pump was made by Parker, Airborne Division it is new, unused
Mod 4A2-4 new cost over $1400.00
The AI is aerobatic type, used, was removed from a Decathalon.
Pair $1000.00 I also have some of the plumbing (filter, reg etc.,) which I
will throw in for free.
If interested please contact me off list.
Best,
Doug
Subject: | Looking for a ride in Sochi or Moscow |
Hi All,
I am going to be in Sochi and Moscow Russia next week and was hoping to get my
feet off the ground in something Yak.
Any ideas/ contacts would be greatly appreciated.
Thank you all very much,
Joe F.
fly_eaa(at)yahoo.com
http://forums.matronics.com/viewtopic.php?p=395921#395921
=0A=0A-Does anyone offer reskin control surfaces for the CJ-6 in aluminum
? or is only choice fabric . I am curious if this is possible option=0Athan
ks=0A
From: | "barryhancock" <bhancock(at)worldwidewarbirds.com> |
In my opinion you guys are the ultimate civilian formation demo team. When I was
flying the -50 I often daydreamed about putting together a similar team stateside....and
I still do!
Keep up the good work!
Barry Hancock
Worldwide Warbirds, Inc.
(877) 869-6458
www.worldwidewarbirds.com
http://forums.matronics.com/viewtopic.php?p=396052#396052
Aside from the potential balance problems which could be severe, the
fact that the rib design is totally unsuitable for riveting makes fabric
the only choice.
Walt
Sent: Monday, March 11, 2013 2:00 PM
Subject: Re: Yak-List: Re: CJ-6
Does anyone offer reskin control surfaces for the CJ-6 in aluminum? or
thanks
I agree. Besides recovering with fabric is actually easier (at least to
me). I see no good point in doing it.
Pappy
In a message dated 3/11/2013 9:02:43 P.M. Eastern Daylight Time,
wlannon(at)shaw.ca writes:
Aside from the potential balance problems which could be severe, the fact
that the rib design is totally unsuitable for riveting makes fabric the
only choice.
Walt
Does anyone offer reskin control surfaces for the CJ-6 in aluminum? or is
thanks
href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
(http://www.matronics.com/Navigator?Yak-List)
(http://www.matronics.com/contribution)
We have covered many control surfaces and fabric is the best option; it
will last 25 years and if damaged, is easily repaired or replaced.
> thanks
Subject: | Re: M-14P Series II Engine and Installation Parts For Sale |
TTSN?
Keith McKinley
700HS
X26 Sebastian, FL
http://forums.matronics.com/viewtopic.php?p=396117#396117
Subject: | Re: Looking for a ride in Sochi or Moscow |
Why waste your time in a YAK....
http://www.flyfighterjet.com/fly-mig-29-russia-sokol-nizhniy-novgorod-moscow/
Keith McKinley
700HS
X26 Sebastian, FL
http://forums.matronics.com/viewtopic.php?p=396118#396118
TTSN and who overhauled
can contact me offline
http://forums.matronics.com/viewtopic.php?p=396119#396119
It's amazing how that never makes the ad.
Keith McKinley
700HS
X26 Sebastian, FL
http://forums.matronics.com/viewtopic.php?p=396151#396151
Thanks for all your kind words! Glad you enjoyed it.
Should anyone in the US have 6 machines we could borrow...................
http://forums.matronics.com/viewtopic.php?p=396211#396211
Ha! I'm sure that could be arranged. But it would be much preferable to find
5 like minded and capable pilots! [Laughing]
Barry Hancock
(877) 869-6458
http://forums.matronics.com/viewtopic.php?p=396213#396213
Subject: | Yak 18T/ M14P Compressor Ram Air Cooling Horn |
Because I've experienced insufficient cooling using the original Chinese horn on
my M14P converted CJ, I borrowed an Yak18T horn from Vladimir and had it replicated
in carbon fiber and fiber glass. New or used Y18T horns are essentially
impossible to find.
If there is enough interest, the talented fellow who made the horn will produce
more, and make them available through Doug Sapp. The price will depend largely
on the amount of interest generated. Let me know if this appeals to others
Blitz Fox
415-307-2405
Subject: | Re: Yak 18T/ M14P Compressor Ram Air Cooling Horn |
Would the more widely available brass French horn also be a compatible
replacement?
In a message dated 3/13/2013 10:13:00 P.M. Pacific Daylight Time,
byronmfox(at)gmail.com writes:
--> Yak-List message posted by: Byron M Fox
horn on my M14P converted CJ, I borrowed an Yak18T horn from Vladimir and
had it replicated in carbon fiber and fiber glass. New or used Y18T horns are
essentially impossible to find.
produce more, and make them available through Doug Sapp. The price will
depend largely on the amount of interest generated. Let me know if this appeals
to others .
Blitz Fox
415-307-2405
The YAKOVLEVS ... another fantastic Formation Aerobatic Team (UK) ...
flying Yaks (1 Yak-52 SUPER and 3 Yak-50) led by Mr Jez HOPKINSON :D
http://www.yakovlevs.com/
http://www.militaryairshows.co.uk/teamg.htm
ENJOY :
http://www.youtube.com/watch?v=UyG5RvMz3xE
http://www.youtube.com/watch?v=R6Go_mnl80s
http://www.youtube.com/watch?v=MylxiYj3QKA
http://www.youtube.com/watch?v=p9Brjt4YkmU
http://www.youtube.com/watch?v=yuS_rko6ciE
Etc ... 8)
Last year, they were invited to display in China !
http://www.thisissomerset.co.uk/Yakovlevs-aerobatic-display-draws-television/story-16963118-detail/story.html#axzz2NWRRuxko
http://www.youtube.com/watch?v=W-lWO7UUCSc
http://www.youtube.com/watch?v=KpjybIrEVfk
Guess you cannot do that in the US of A [Exclamation] :
http://www.youtube.com/watch?v=BRBZy3lUn8Q
http://www.youtube.com/watch?v=SkoaBj1wHKU
Nice article on the Yak-50 (written by one of the YAKOVLEVS' pilot) :
http://www.yakovlevs.com/wp-content/uploads/2011/07/FLYER.Yak-50.pdf
Cheers and BR, Etienne.
http://i1089.photobucket.com/albums/i352/Mark_Salter/IMG_2442_1_1.jpg
http://i1089.photobucket.com/albums/i352/Mark_Salter/IMG_2477_3_1.jpg
http://i1089.photobucket.com/albums/i352/Mark_Salter/IMG_2418_2.jpg
http://i1089.photobucket.com/albums/i352/Mark_Salter/Img_2406_2.jpg
http://m8.i.pbase.com/g1/60/43760/2/146113628.xtXRrTv9.jpg
http://m8.i.pbase.com/g2/60/43760/2/146788728.zbf8HiHc.jpg
http://www.airplane-pictures.net/images/uploaded-images/2012-10/1/240525.jpg
[Arrow]
http://www.photoflyingdays.com/2012/Yak52/JangSu-Lee_02.jpg
http://www.photoflyingdays.com/2012/Yak52/Michae-de-Boer_48.jpg
http://www.photoflyingdays.com/2012/Yak52/daniel_rychcik_07817.jpg
http://www.photoflyingdays.com/2012/Yak52/sylvain-artu_16.jpg
http://www.photoflyingdays.com/2012/Yak52/sylvain-artu_17.jpg
http://www.photoflyingdays.com/2012/Yak52/sylvain-artu_18.jpg :)
http://ukga.com/content/view?contentId=29581
http://ukga.com/images/content/image29581.jpg
http://www.flyredstar.org/gallery2/Yak/Heimo_Lamberg_011.jpg
http://www.flyredstar.org/gallery2/Yak/Etienne%20landing%20747-400..jpg
http://forums.matronics.com/viewtopic.php?p=396241#396241
Subject: | M14P air compressor cooling horn |
I failed to be more explicit and to include the picture. This is the "pipe"
which brings cooling ram air through the shutters (gills) on the starboard s
ide of the engine and blows it on to the cooling fins of the air compress
or.
The Yak 18T cooling horn essentially surrounds the compressor, making coolin
g and compressor intake air cooler and therefore more efficient. More photog
raphs of the installation to follow.
Blitz Fox
415-307-2405
