Zenith-Archive.digest.vol-gl
January 24, 2007 - February 07, 2007
      that came with the kit. I am still looking (dreaming) into putting the Dynon
      EFIS onto the panel if I can afford it. If I go that way I will need a new
      tube  for the Angle of A stuff will I not?
      so should I wait till I have made up my mind or will the new size tube fit over
      the old Zenith tube holes??? I would hate to have to patch my new bottom wing
      skin before first flight.
      Chris
      http://forums.matronics.com/viewtopic.php?p=90057#90057
Date: Jan 24, 2007
Subject: Re: zenith pitot tube V's Dynon tube
Hi Chris I have an LRI rather than the Dynon pitot tube, but I would guess the hose requirements are similar. I have two hoses that run from the LRI into the fuselage. I mounted both the LRI probe and pitot tube on inspection plates so they don't get broken while moving the wing around. If you do this, you can probably run new tubes later. Best regards, Paul XL fuselage At 06:05 AM 1/24/2007, you wrote: > > >Hi all >come on, yes it was the middle of the night when I mixed up L angles >and hat stiffeners.. > >I am about to drill the holes for instalation of the normal zenith >tubes and hoses that came with the kit. I am still looking >(dreaming) into putting the Dynon EFIS onto the panel if I can >afford it. If I go that way I will need a new tube for the Angle of >A stuff will I not? > >so should I wait till I have made up my mind or will the new size >tube fit over the old Zenith tube holes??? I would hate to have to >patch my new bottom wing skin before first flight. > >Chris > ________________________________________________________________________________
Subject: Re: Handheld GPS?
From: "Peter Barthold" <peter.barthold@t-online.de>
Date: Jan 24, 2007
Hello Lind, Aviation handhelds are the better choice when it comes to ruggedness and reliability. I would nevertheless recommend to check out pocketfms for PDA/GPS combos. It is a powerful moving map navigation solution with a VERY dedicated commmunty. A number of volunteers maintain the data of every country. Norways airspace structure is fully covered and maintained AFAIK. The software and moving map data is for free (!) Donors of more than 50 Euros/60 $ get conveniant zip files and additional weather data . Check out www.pocketfms.com to alex: Schickes Cockpit, D-M... oder D-E...? Cheers Peter 601HDS TD VW conversion Tail complete, wings in progress www.petersprojekt42.de Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90113#90113 ________________________________________________________________________________
From: "Steve & Kim Kurash" <stevekimk(at)gmail.com>
Subject: Re: 701 wing mis-information
Date: Jan 24, 2007
Actually Jon it does matter. Especially the leveling of the aircraft along the A-E reference line ( I stand corrected Bob). This is because of the wing dihedral. If the wing had no dihedral there would be no need to level along A-E. Try this explanation, on your plane with wings and struts installed, string a line from wingtip to wingtip at the rivet line. Get on a ladder and look down from above at the string and rivet line relationship. Notice, that as you move your eye a little forward, then rearward, that you can make the string line appear as if it is not in line with the rivet line. It will look like the wings are either swept forward or swept aft. The dihedral causes this effect. Alternatively, you could drop the tail of the plane by blocking up the nose wheel and view your string line/rivet line. I'll bet it looks like your wings are swept back! N.B. If it looks like the rivet line IS in line with the rivet line, then your eye is not exactly 90 degrees over the string line, or your wings are in fact NOT perfectly aligned. Any way, back to the point, if you were setting the wing incidence in this condition (tail low) you would move the wing tips forward until the string line and rivets were aligned and then drill the aft mounting holes IN THE WRONG LOCATION. So............ in order to set the wing incidence in the fore and aft dimension (i.e. neither swept forward on backward) you must level the aircraft along A-E and view the string/rivet line relationship from EXACTLY above the string (90 degrees). Steve ----- Original Message ----- From: "Jon Croke" <Jon(at)joncroke.com> Subject: Re: Zenith-List: 701 wing mis-information Hi all, I am seeking a little clarification to the 701 wing rigging issue... I dont understand the need for all of this fuselage leveling... I agree with Zed's procedure (and have used it quite successfully) of wing rigging.... notice that all adjusting is done in reference to the fuselage itself or the opposite wing.. nothing I noticed entails rigging in relationship to 'level' with the earth. You could complete Zed's procedure with the fuse sitting on a sloped parking ramp.... kinda similar to the issue of making 'sure' your table is level before building your wings!! (Does it make a difference?) So - I am simply looking for understanding on how leveling helps the wing rigging process... inquiring minds want to know! Thanks! Jon ----- Original Message ----- From: NYTerminat(at)aol.com To: zenith-list(at)matronics.com Sent: Tuesday, January 23, 2007 11:17 AM Subject: Re: Zenith-List: 701 wing mis-information Steve Not on the upper longerons, there is an A-E reference line that you must create to level the fuselage, see 7-F-2. The upper longerons have a slight curve to them when installed on the side skins. You also might want to think about blocking the fuselage level in all axis, the tires and spring/ bungee gear will move as you put weight on them. Why chase the level with a moving fuselage? Bob Spudis N701ZX/912S/100 hrs ________________________________________________________________________________
Date: Jan 24, 2007
...the elimination of parallax error is one of the things involved. In some ways, this is specifically the reason why it is so critical to have the plane leveled according to the designers requirements when doing a weight and ballance. Steve & Kim Kurash wrote: Actually Jon it does matter. Especially the leveling of the aircraft along the A-E reference line ( I stand corrected Bob). This is because of the wing dihedral. If the wing had no dihedral there would be no need to level along A-E. Try this explanation, on your plane with wings and struts installed, string a line from wingtip to wingtip at the rivet line. Get on a ladder and look down from above at the string and rivet line relationship. Notice, that as you move your eye a little forward, then rearward, that you can make the string line appear as if it is not in line with the rivet line. It will look like the wings are either swept forward or swept aft. The dihedral causes this effect. Alternatively, you could drop the tail of the plane by blocking up the nose wheel and view your string line/rivet line. I'll bet it looks like your wings are swept back! N.B. If it looks like the rivet line IS in line with the rivet line, then your eye is not exactly 90 degrees over the string line, or your wings are in fact NOT perfectly aligned. Any way, back to the point, if you were setting the wing incidence in this condition (tail low) you would move the wing tips forward until the string line and rivets were aligned and then drill the aft mounting holes IN THE WRONG LOCATION. So............ in order to set the wing incidence in the fore and aft dimension (i.e. neither swept forward on backward) you must level the aircraft along A-E and view the string/rivet line relationship from EXACTLY above the string (90 degrees). Steve ----- Original Message ----- From: "Jon Croke" <Jon(at)joncroke.com> Subject: Re: Zenith-List: 701 wing mis-information Hi all, I am seeking a little clarification to the 701 wing rigging issue... I dont understand the need for all of this fuselage leveling... I agree with Zed's procedure (and have used it quite successfully) of wing rigging.... notice that all adjusting is done in reference to the fuselage itself or the opposite wing.. nothing I noticed entails rigging in relationship to 'level' with the earth. You could complete Zed's procedure with the fuse sitting on a sloped parking ramp.... kinda similar to the issue of making 'sure' your table is level before building your wings!! (Does it make a difference?) So - I am simply looking for understanding on how leveling helps the wing rigging process... inquiring minds want to know! Thanks! Jon ----- Original Message ----- From: NYTerminat(at)aol.com To: zenith-list(at)matronics.com Sent: Tuesday, January 23, 2007 11:17 AM Subject: Re: Zenith-List: 701 wing mis-information Steve Not on the upper longerons, there is an A-E reference line that you must create to level the fuselage, see 7-F-2. The upper longerons have a slight curve to them when installed on the side skins. You also might want to think about blocking the fuselage level in all axis, the tires and spring/ bungee gear will move as you put weight on them. Why chase the level with a moving fuselage? Bob Spudis N701ZX/912S/100 hrs Dave Downey Harleysville (SE) PA Zodiac 601XL/Corvair? --------------------------------- Don't pick lemons. See all the new 2007 cars at Yahoo! Autos. ________________________________________________________________________________
Subject: Where could that part be...
Date: Jan 24, 2007
My second faux pas. I was near the end of the elevator build, and I couldn't find the horn doubler 6T3-6. I went back through my entire inventory to track it down, to no avail. I did have the "L" bracket _leftover_ from that part of the kit. After examing the plans in greater detail, I realized what I did. I don't know it it was just too late, or I was relying on the photo assembly reference too much, but it seems that I cut up 6T3-6, as the "L" bracket for 6T3-2. A call went to Zenith the next AM to have a new $4.00 piece ol AL shipped Blue... Fun! Jon Burns _________________________________________________________________ Valentines Day -- Shop for gifts that spell L-O-V-E at MSN Shopping http://shopping.msn.com/content/shp/?ctId=8323,ptnrid=37,ptnrdata=24095&tcode=wlmtagline ________________________________________________________________________________
Date: Jan 24, 2007
Steve, David, and all, I appreciate your input on this... I do understand the error in visual preception that occurs when you are not viewing the rivet line at exactly 90 degrees from above... This is why I will still suggest that the best way (for me, anyway.. and I respect others' way of dealing with this) is to NOT level the plane in any direction but rather use a measuring tape, which is not affected by parallax errors or trying to determine an exact 90 degree observation vantage (because you WILL be on a ladder trying to attempt this observation). The measurement of a point on both wing tips to a common point on the fuselage will determine with great accuracy the proper alignment of the wings. No guessing here.. I agree wholeheartly with Steve about viewing the rivet line and seeing it move when you start lifting the wings.. or moving your head to the left or right....that is precisely why I don't like to to make judgements from what I see when the angle of sight is so critical. I start by leveling each wing to each other (not the ground!) and then adjust each wing to match (to the millimeter using a tape) from that far point on the fuselage near the tail to each wing tip. When this is done (and use a helper to confirm accuracy), drill the tabs. Of course, watch your edge distances... Your last detail is to raise both wings to the specs in the plans.. which, again have no basis on level to earth, rather they are measured with a ruler to points between the fuse and wings. Nothing wrong with eyeballing things for confirmation and comfort, but I rather use a ruler to make the final adjustments. I do NOT have the final word on this, but am simply expressing my understanding of what is in my head at this time. I look forward to more discussion on this if you think I have it wrong. Sometimes, what works best for each of us may be different -- and thats OK ! (I am not saying you are wrong to level things -- just that it creates no advantage for my method, and might cause confusion in the least) You guys are the best! Jon ----- Original Message ----- From: David Downey To: zenith-list(at)matronics.com Sent: Wednesday, January 24, 2007 3:51 PM Subject: Re: Zenith-List: 701 wing mis-information ...the elimination of parallax error is one of the things involved. In some ways, this is specifically the reason why it is so critical to have the plane leveled according to the designers requirements when doing a weight and ballance. Steve & Kim Kurash wrote: Actually Jon it does matter. Especially the leveling of the aircraft along the A-E reference line ( I stand corrected Bob). This is because of the wing dihedral. If the wing had no dihedral there would be no need ________________________________________________________________________________
Date: Jan 24, 2007
Just made my Dynon Pitot standoff. It will be permanently mounted on the left wing when riveting the wing skin. The pluming will be accessible through the wing locker. The Dynon Pitot won't be in place till assembly at the Airport. Still going to have to be careful moving that wing around though. -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90245#90245 ________________________________________________________________________________
Date: Jan 24, 2007
And I did forget (sorry!) to mention that I use the string (also used for dihedral setting) to determine when the rivet lines are matched from wing to wing (to make sure the wings are not swept forward or aft). The string will be touching the rivet lines so it is easy to see this adjustment. ----- Original Message ----- From: Jon Croke To: zenith-list(at)matronics.com Sent: Wednesday, January 24, 2007 6:29 PM Subject: Re: Zenith-List: 701 wing mis-information Steve, David, and all, I appreciate your input on this... I do understand the error in visual preception that occurs when you are not viewing the rivet line at exactly 90 degrees from above... ________________________________________________________________________________
Subject: 701 elevator upper limit stop
Date: Jan 24, 2007
I didn't find an upper limit stop either but in my plane so far the back of the control stick against the edge of the seat has worked ok. Joe 701 69 hours ________________________________________________________________________________
Date: Jan 25, 2007
I hope you are leveling the fuse also otherwise you may endup with a parrallel wings and fuse not level To make it easy it is best to level and square fuse before this critical stage of setting up wings. you are setting up front of wings mount position at same height. wings parralell in forwards and backwards direction angle of incidence front mount point to back mount point Dihedral at front of wing. angle of incedence at both outer wings so you need to get it right Graeme bell ----- Original Message ----- From: Jon Croke To: zenith-list(at)matronics.com Sent: Thursday, January 25, 2007 10:29 AM Subject: Re: Zenith-List: 701 wing mis-information Steve, David, and all, I appreciate your input on this... I do understand the error in visual preception that occurs when you are not viewing the rivet line at exactly 90 degrees from above... This is why I will still suggest that the best way (for me, anyway.. and I respect others' way of dealing with this) is to NOT level the plane in any direction but rather use a measuring tape, which is not affected by parallax errors or trying to determine an exact 90 degree observation vantage (because you WILL be on a ladder trying to attempt this observation). The measurement of a point on both wing tips to a common point on the fuselage will determine with great accuracy the proper alignment of the wings. No guessing here.. I agree wholeheartly with Steve about viewing the rivet line and seeing it move when you start lifting the wings.. or moving your head to the left or right....that is precisely why I don't like to to make judgements from what I see when the angle of sight is so critical. I start by leveling each wing to each other (not the ground!) and then adjust each wing to match (to the millimeter using a tape) from that far point on the fuselage near the tail to each wing tip. When this is done (and use a helper to confirm accuracy), drill the tabs. Of course, watch your edge distances... Your last detail is to raise both wings to the specs in the plans.. which, again have no basis on level to earth, rather they are measured with a ruler to points between the fuse and wings. Nothing wrong with eyeballing things for confirmation and comfort, but I rather use a ruler to make the final adjustments. I do NOT have the final word on this, but am simply expressing my understanding of what is in my head at this time. I look forward to more discussion on this if you think I have it wrong. Sometimes, what works best for each of us may be different -- and thats OK ! (I am not saying you are wrong to level things -- just that it creates no advantage for my method, and might cause confusion in the least) You guys are the best! Jon ----- Original Message ----- From: David Downey To: zenith-list(at)matronics.com Sent: Wednesday, January 24, 2007 3:51 PM Subject: Re: Zenith-List: 701 wing mis-information ...the elimination of parallax error is one of the things involved. In some ways, this is specifically the reason why it is so critical to have the plane leveled according to the designers requirements when doing a weight and ballance. Steve & Kim Kurash wrote: Actually Jon it does matter. Especially the leveling of the aircraft along the A-E reference line ( I stand corrected Bob). This is because of the wing dihedral. If the wing had no dihedral there would be no need ------------------------------------------------------------------------- ----- 24/01/2007 ________________________________________________________________________________
Date: Jan 24, 2007
Chris, The Dynon Pitot probe replaces the standard Zenith dynamic probe. It acts as an aoa probe as well. You will have to run a third line for static pressure, for a total of 3. I placed my static port in the aft fuselage, but that is builder preference. I mounted the probe under the baggage locker, allowing for easy access, and delayed installation. I cut the holes and fabricated the mounts, but did not rivet into place until the wings were mounted for the last time. Having a probe hanging down makes it a real pain in the ass to transport. -More so than you might think... VR/ Brandon Don't pick lemons. See all the new 2007 cars at Yahoo! Autos. http://autos.yahoo.com/new_cars.html ________________________________________________________________________________
From: "Dr. Andrew Elliott" <a.s.elliott(at)cox.net>
Subject: Cutting out trim tab?
Date: Jan 24, 2007
Gang: I'm at the point where I need to cut out the elevator trim tab from a built elevator. I have all the lines carefully marked and would like to hear some technique suggestions for making these cuts. My own idea is to split or cut out the trailing edge between the end lines (with a band saw?), cut the end lines with shears, drill out the aft two middle-rib rivets, and finally cut the top and bottom spanwise lines by scoring with the laminate knife and breaking out the sections. Other ideas? Andy Elliott, Mesa, AZ N601GE (reserved) 601XL/TD/QB, Corvair, building... ________________________________________________________________________________
Date: Jan 24, 2007
HYPERLINK "http://www.ch601.org/tools.htm"http://www.ch601.org/tools.htm HYPERLINK "http://www.ch601.org/tools/olfa.htm"http://www.ch601.org/tools/olfa.htm Use the Olfa pad wan !!!!! Mark Townsend Alma, Ontario Zodiac 601XL C-GOXL, CH701 just started HYPERLINK "http://www.ch601.org"www.ch601.org / HYPERLINK "http://www.ch701.com"www.ch701.com/ HYPERLINK "http://www.Osprey2.com"www.Osprey2.com -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Dr. Andrew Elliott Sent: Wednesday, January 24, 2007 10:53 PM Subject: Zenith-List: Cutting out trim tab? Gang: I'm at the point where I need to cut out the elevator trim tab from a built elevator. I have all the lines carefully marked and would like to hear some technique suggestions for making these cuts. My own idea is to split or cut out the trailing edge between the end lines (with a band saw?), cut the end lines with shears, drill out the aft two middle-rib rivets, and finally cut the top and bottom spanwise lines by scoring with the laminate knife and breaking out the sections. Other ideas? Andy Elliott, Mesa, AZ N601GE (reserved) 601XL/TD/QB, Corvair, building... "http://www.matronics.com/Navigator?Zenith-List"http://www.matronics.com /Navigator?Zenith-List "http://forums.matronics.com"http://forums.matronics.com -- 1/24/2007 6:48 PM -- 1/24/2007 6:48 PM ________________________________________________________________________________
Date: Jan 24, 2007
Subject: Re: Cutting out trim tab?
Hi Andy, Its been a while since I did that one, but here is what I think I would do now. First, stop drill the inside corners with something like a 1/4" drill. Then I would use a fairly large step drill - perhaps 3/4" or 7/8" to make a starting point for the shears. I would drill this in the waste material perhaps 1" from the final cut line. Then it is a matter of cutting with the shears. The first cuts would leave about 1/4" to the final cut line, and then I would work my way closer to the final line until I was there. Perhaps the last few thousandths in some areas would be done with a file rather than the shears. Clean up the edges with a smooth file and it is done. Paul XL fuselage At 07:53 PM 1/24/2007, you wrote: >Gang: > >I'm at the point where I need to cut out the elevator trim tab from >a built elevator. I have all the lines carefully marked and would >like to hear some technique suggestions for making these cuts. > >My own idea is to split or cut out the trailing edge between the end >lines (with a band saw?), cut the end lines with shears, drill out >the aft two middle-rib rivets, and finally cut the top and bottom >spanwise lines by scoring with the laminate knife and breaking out >the sections. > >Other ideas? > >Andy Elliott, Mesa, AZ >N601GE (reserved) >601XL/TD/QB, Corvair, building... - ________________________________________________________________________________
Date: Jan 25, 2007
I drilled the corners and cut it with a dremel tool using the small cut-off wheel, it took less than 15 minutes. Clyde 601 XL ----- Original Message ----- From: Dr. Andrew Elliott To: Zenith-List Digest Server Sent: Wednesday, January 24, 2007 9:53 PM Subject: Zenith-List: Cutting out trim tab? Gang: I'm at the point where I need to cut out the elevator trim tab from a built elevator. I have all the lines carefully marked and would like to hear some technique suggestions for making these cuts. My own idea is to split or cut out the trailing edge between the end lines (with a band saw?), cut the end lines with shears, drill out the aft two middle-rib rivets, and finally cut the top and bottom spanwise lines by scoring with the laminate knife and breaking out the sections. Other ideas? Andy Elliott, Mesa, AZ N601GE (reserved) 601XL/TD/QB, Corvair, building... ________________________________________________________________________________
Date: Jan 25, 2007
I did it Paul's way and had excellent results. Using a file to home into the final size yeilded a perfect fit. Chuck Wacker N601XL Quick Build >From: Paul Mulwitz <p.mulwitz(at)worldnet.att.net> >Reply-To: zenith-list(at)matronics.com >To: zenith-list(at)matronics.com >Subject: Re: Zenith-List: Cutting out trim tab? >Date: Wed, 24 Jan 2007 20:43:33 -0800 > > > >Hi Andy, > >Its been a while since I did that one, but here is what I think I would do >now. > >First, stop drill the inside corners with something like a 1/4" drill. >Then I would use a fairly large step drill - perhaps 3/4" or 7/8" to make a >starting point for the shears. I would drill this in the waste material >perhaps 1" from the final cut line. Then it is a matter of cutting with >the shears. The first cuts would leave about 1/4" to the final cut line, >and then I would work my way closer to the final line until I was there. >Perhaps the last few thousandths in some areas would be done with a file >rather than the shears. Clean up the edges with a smooth file and it is >done. > >Paul >XL fuselage > > >At 07:53 PM 1/24/2007, you wrote: >>Gang: >> >>I'm at the point where I need to cut out the elevator trim tab from a >>built elevator. I have all the lines carefully marked and would like to >>hear some technique suggestions for making these cuts. >> >>My own idea is to split or cut out the trailing edge between the end lines >>(with a band saw?), cut the end lines with shears, drill out the aft two >>middle-rib rivets, and finally cut the top and bottom spanwise lines by >>scoring with the laminate knife and breaking out the sections. >> >>Other ideas? >> >>Andy Elliott, Mesa, AZ >>N601GE (reserved) >>601XL/TD/QB, Corvair, building... > >- > > _________________________________________________________________ something more. ________________________________________________________________________________
Date: Jan 25, 2007
I did mine the same way just a few weeks ago. It worked very well. I used a small router with a straight bit to cut away the trailing edge and seperate the top and bottom 'skins'. Dino Bortolin On 1/24/07, Dr. Andrew Elliott wrote: > Gang: > > I'm at the point where I need to cut out the elevator trim tab from a built > elevator. I have all the lines carefully marked and would like to hear some > technique suggestions for making these cuts. > > My own idea is to split or cut out the trailing edge between the end lines > (with a band saw?), cut the end lines with shears, drill out the aft two > middle-rib rivets, and finally cut the top and bottom spanwise lines by > scoring with the laminate knife and breaking out the sections. > > Other ideas? > > Andy Elliott, Mesa, AZ > N601GE (reserved) > 601XL/TD/QB, Corvair, building... > ________________________________________________________________________________
Date: Jan 25, 2007
I also had good results doing it as Paul described . Wade Jones South Texas 601XL plans building Cont. 0200 ----- Original Message ----- From: "Charles Wacker" <ccwacker(at)HOTMAIL.COM> Sent: Thursday, January 25, 2007 8:02 AM Subject: Re: Zenith-List: Cutting out trim tab? > > I did it Paul's way and had excellent results. Using a file to home into > the final size yeilded a perfect fit. > > Chuck Wacker > N601XL Quick Build > > >>From: Paul Mulwitz <p.mulwitz(at)worldnet.att.net> >>Reply-To: zenith-list(at)matronics.com >>To: zenith-list(at)matronics.com >>Subject: Re: Zenith-List: Cutting out trim tab? >>Date: Wed, 24 Jan 2007 20:43:33 -0800 >> >> >> >>Hi Andy, >> >>Its been a while since I did that one, but here is what I think I would do >>now. >> >>First, stop drill the inside corners with something like a 1/4" drill. >>Then I would use a fairly large step drill - perhaps 3/4" or 7/8" to make >>a starting point for the shears. I would drill this in the waste material >>perhaps 1" from the final cut line. Then it is a matter of cutting with >>the shears. The first cuts would leave about 1/4" to the final cut line, >>and then I would work my way closer to the final line until I was there. >>Perhaps the last few thousandths in some areas would be done with a file >>rather than the shears. Clean up the edges with a smooth file and it is >>done. >> >>Paul >>XL fuselage >> >> >> >>At 07:53 PM 1/24/2007, you wrote: >>>Gang: >>> >>>I'm at the point where I need to cut out the elevator trim tab from a >>>built elevator. I have all the lines carefully marked and would like to >>>hear some technique suggestions for making these cuts. >>> >>>My own idea is to split or cut out the trailing edge between the end >>>lines (with a band saw?), cut the end lines with shears, drill out the >>>aft two middle-rib rivets, and finally cut the top and bottom spanwise >>>lines by scoring with the laminate knife and breaking out the sections. >>> >>>Other ideas? >>> >>>Andy Elliott, Mesa, AZ >>>N601GE (reserved) >>>601XL/TD/QB, Corvair, building... >> >>- >> >> >> >> >> > > _________________________________________________________________ > something more. > > > ________________________________________________________________________________
Subject: instruments for sale
Date: Jan 25, 2007
Guys, I have decided to go in a different direction for instruments for my 601 XL. I have decided to sell my entire instrument panel with instruments, radios, etc. It's finished and looks great. It has the standard 6 pack of flight instruments with yellow tag gyros, the DG has autopilot coupling, electric turn & bank, 2 trim indicators, compass, suction, Westech engine instruments, Jabiru style rpm with hour meter new, circut breakers, adjustable air inlet controls, intercom, King KX 170A backup nav-com with head, Narco transponder, Artex 110-4 ELT, Sigtronics headset like new, master switches, gyro's plumbed with filters, encoder, Painted and labled panel in very light grey. All mounting holes countersunk. I will take your blank panel in trade. If anyone is interested, please contact me offline at backstagelive(at)gmail.com or call me at 920-237-1450. Joe ________________________________________________________________________________
Subject: Filling in the rib ends?
Date: Jan 25, 2007
Gang: Another question about techniques - What are people doing to fill in the spaces at the aft ends of the end ribs on the various control surfaces? Similar applies to the empty spaces in the inboard ends? I have been variously thinking of wood blocks, plastic plugs, etc. for the ends, and false ribs for the centerline spaces on the rudder and elevator. Other ideas? Andy Elliott, Mesa, AZ N601GE (reserved) 601XL/TD/QB, Corvair, building... ________________________________________________________________________________
Date: Jan 25, 2007
I did like Paul except that I drilled a #20 hole at each corner rather than a 1/4" hole. Then I also use a good new hacksaw to cut about 3/8" inside the cut line at the trailing edge on both sides. That makes it much easier to cut around the trailing edge with the snips. Like Paul described, I used a large step drill inside the waste area to get started with the shears..... first cut about 1/4" inside the line, then a final cut to "save the line". Final finish with file and emory cloth. Ed Moody II ________________________________________________________________________________
Date: Jan 25, 2007
Subject: Re: Filling in the rib ends?
all, the other option that works just as well, is AMD's design of a trim tab which does not require a cut. The tab runs from inboard edge to entire length of the port elevator. by 3 inches wide. It is secured by the paino hinge, and is frankly a lot easier. I put in the orignal cut in one, then found the AMD option. I would recommend the later. Juan -----Original Message----- >From: "Dr. Andrew Elliott" <a.s.elliott(at)cox.net> >Sent: Jan 25, 2007 11:01 AM >To: Zenith-List Digest Server >Subject: Zenith-List: Filling in the rib ends? > >Gang: > >Another question about techniques - What are people doing to fill in the spaces at the aft ends of the end ribs on the various control surfaces? Similar applies to the empty spaces in the inboard ends? I have been variously thinking of wood blocks, plastic plugs, etc. for the ends, and false ribs for the centerline spaces on the rudder and elevator. Other ideas? > >Andy Elliott, Mesa, AZ >N601GE (reserved) >601XL/TD/QB, Corvair, building... ________________________________________________________________________________
Subject: Elevator trim angle? XL
Date: Jan 25, 2007
I see on the blueprints that Zenith calls for 20 degrees one way and 40 degrees the other for the trim on the 601 XL. How is that measured? How I have it now, there is exactly the same travel up and down from neutral, and neutral is dead center. Is there supposed to be more travel one way over the other? Thanks, Jon Burns Little Elm, TX _________________________________________________________________ FREE online classifieds from Windows Live Expo buy and sell with people you know ________________________________________________________________________________
Date: Jan 25, 2007
..and that is precisely the configuraton in the latest revision of the plans for the 601XL! all, the other option that works just as well, is AMD's design of a trim tab which does not require a cut. The tab runs from inboard edge to entire length of the port elevator. by 3 inches wide. It is secured by the paino hinge, and is frankly a lot easier. I put in the orignal cut in one, then found the AMD option. I would recommend the later. Juan -----Original Message----- >From: "Dr. Andrew Elliott" >Sent: Jan 25, 2007 11:01 AM >To: Zenith-List Digest Server >Subject: Zenith-List: Filling in the rib ends? > >Gang: > >Another question about techniques - What are people doing to fill in the spaces at the aft ends of the end ribs on the various control surfaces? Similar applies to the empty spaces in the inboard ends? I have been variously thinking of wood blocks, plastic plugs, etc. for the ends, and false ribs for the centerline spaces on the rudder and elevator. Other ideas? > >Andy Elliott, Mesa, AZ >N601GE (reserved) >601XL/TD/QB, Corvair, building... Dave Downey Harleysville (SE) PA Zodiac 601XL/Corvair? --------------------------------- TV dinner still cooling? Check out "Tonight's Picks" on Yahoo! TV. ________________________________________________________________________________
Date: Jan 25, 2007
I do;t suppose you have a photo of the standoff do you? Ron Lendon wrote: > Just made my Dynon Pitot standoff. It will be permanently mounted on the left wing when riveting the wing skin. The pluming will be accessible through the wing locker. The Dynon Pitot won't be in place till assembly at the Airport. Still going to have to be careful moving that wing around though. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90460#90460 ________________________________________________________________________________
Subject: lift strut fairings
Date: Jan 25, 2007
anybody know where to get ready made aluminum lift strut fairings? thx Joe ________________________________________________________________________________
Date: Jan 25, 2007
Here's a link to how I did mine: or -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90506#90506 ________________________________________________________________________________
Date: Jan 25, 2007
Sure do look here: [/url]http://tinyurl.com/yqtgeq[url] or [/url]http://www.mykitlog.com/users/display_log.php?user=rlendon&project=113&category=0&log=27206&row=7[url][/url] -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90511#90511 ________________________________________________________________________________
Date: Jan 25, 2007
I will be placing a 2000 lb order soon for lift strut material. I also have 1000lbs of float keels for those who need to replace them some day, I will always have them in stock so there is no need to store them for a later date, when you need them they will be here. Mark Townsend Can-Zac Aviation Ltd. HYPERLINK "mailto:president@can-zacaviation.com"president@can-zacaviation.com HYPERLINK "http://www.can-zacaviation.com/"www.can-zacaviation.com -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of jpspencer(at)cableone.net Sent: Thursday, January 25, 2007 8:54 PM Subject: Zenith-List: lift strut fairings anybody know where to get ready made aluminum lift strut fairings? thx Joe "http://www.matronics.com/Navigator?Zenith-List"http://www.matronics.com /Navigator?Zenith-List "http://forums.matronics.com"http://forums.matronics.com -- 1/25/2007 3:32 PM -- 1/25/2007 3:32 PM ________________________________________________________________________________
Subject: Nosebowl Corvair
Date: Jan 26, 2007
Hi all I am looking to buy a nosebowl for a Zodiac 601 XL / Corvair Does anyone have one for sale and is willing to ship it to Australia I will pay all costs Please email me off list so you dont end up like me. info(at)cumminsspinners.com Fly Safe Allan Cummins Spinners www.cumminsspinners.com ________________________________________________________________________________
Date: Jan 26, 2007
Hey Andy, I'm assuming you're talking about the small gap left at the trailing edge of the control surfaces. If so, when I first started building I worried what to do about it. I went to a hanger and looked at production aircraft (Cessna, Beech, etc). I noticed they also had gaps between the aft end of the various control surface ribs and the trailing edge skin. Even a multi-million dollar Pilatus PC-12 had gaps. Attached is a photo of a Cessna 150 flap showing a pretty large gap. If I misunderstood what you were describing, then ...never mind. Dave Clay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90536#90536 Attachments: http://forums.matronics.com//files/cessnaflap_433.jpg ________________________________________________________________________________
Subject: Re: Aileron stop
Date: Jan 26, 2007
Hi Mike and everybody else I am also wondering how to install the aileron stop (CZAW kit). I do have two parts 6W10-4 (see picture below) but don't know how and where to install. The drawing shows 6W10-4 as a different looking part... Looking forward to any help :D . Martin -------- Martin Pohl Zodiac XL QBK 8645 Jona, Switzerland www.pohltec.ch/ZodiacXL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90538#90538 ________________________________________________________________________________
Date: Jan 26, 2007
The gap is there for a reason. It simply allows moisture to drain. Gary Boothe Cool, CA 601 HDSTD, WW Conversion 90% done, Tail done, wings done, working on c-section -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of TxDave Sent: Friday, January 26, 2007 1:18 AM Subject: Zenith-List: Re: Filling in the rib ends? Hey Andy, I'm assuming you're talking about the small gap left at the trailing edge of the control surfaces. If so, when I first started building I worried what to do about it. I went to a hanger and looked at production aircraft (Cessna, Beech, etc). I noticed they also had gaps between the aft end of the various control surface ribs and the trailing edge skin. Even a multi-million dollar Pilatus PC-12 had gaps. Attached is a photo of a Cessna 150 flap showing a pretty large gap. If I misunderstood what you were describing, then ...never mind. Dave Clay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90536#90536 Attachments: http://forums.matronics.com//files/cessnaflap_433.jpg ________________________________________________________________________________
Date: Jan 26, 2007
Another thing I forgot to mention is that if you do cover/close up the gaps at the trailing edges as I did, I think it is a good idea to drill a small #40 or #30 hole to allow the assembly to drip out moisture or "breathe". The hole is way too small for critters to intrude but large enough to drip out. Ed ---- TxDave wrote: > > Hey Andy, > > I'm assuming you're talking about the small gap left at the trailing edge of the control surfaces. If so, when I first started building I worried what to do about it. I went to a hanger and looked at production aircraft (Cessna, Beech, etc). I noticed they also had gaps between the aft end of the various control surface ribs and the trailing edge skin. Even a multi-million dollar Pilatus PC-12 had gaps. Attached is a photo of a Cessna 150 flap showing a pretty large gap. > > If I misunderstood what you were describing, then ...never mind. > > Dave Clay ________________________________________________________________________________
From: "David Austin" <daveaustin2(at)can.rogers.com>
Date: Jan 26, 2007
Only my humble opinion, but the drain holes should be at least 1/4 inch. Smaller than that blocks too easily. With the drill still in the hole, it should also be sloped (pulled) backward when not rotating, enough that it forms a slight negative pressure zone at the hole to suck any water out. I agree - you don't want critters in there! Dave Austin 601HDS - 912, Spitfire Mk VIII ----- Original Message ----- From: <dredmoody(at)cox.net> Sent: Friday, January 26, 2007 10:23 AM Subject: Re: Zenith-List: Re: Filling in the rib ends? > > Another thing I forgot to mention is that if you do cover/close up the > gaps at the trailing edges as I did, I think it is a good idea to drill a > small #40 or #30 hole to allow the assembly to drip out moisture or > "breathe". The hole is way too small for critters to intrude but large > enough to drip out. > > Ed > > ---- TxDave wrote: >> >> Hey Andy, >> >> I'm assuming you're talking about the small gap left at the trailing edge >> of the control surfaces. If so, when I first started building I worried >> what to do about it. I went to a hanger and looked at production aircraft >> (Cessna, Beech, etc). I noticed they also had gaps between the aft end of >> the various control surface ribs and the trailing edge skin. Even a >> multi-million dollar Pilatus PC-12 had gaps. Attached is a photo of a >> Cessna 150 flap showing a pretty large gap. >> >> If I misunderstood what you were describing, then ...never mind. >> >> Dave Clay > > > ________________________________________________________________________________
Subject: Re: lift strut fairings
From: "Chris Lewis" <christopherlewis(at)earthlink.net>
Date: Jan 26, 2007
Mark - Can thes be used in lieu of the steel struts like the Rans or on the 701 built by Robert Kube for Christopher Desmond? Thanks, Chris in Seattle -------- 701 Scratch Builder Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90632#90632 Attachments: http://forums.matronics.com//files/701_strut_2_141.jpg ________________________________________________________________________________
Date: Jan 26, 2007
Hi Tim Thank you for the picture of the aileron stop-installation. I will recheck my plans... Martin -------- Martin Pohl Zodiac XL QBK 8645 Jona, Switzerland www.pohltec.ch/ZodiacXL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90639#90639 ________________________________________________________________________________
Date: Jan 26, 2007
Subject: CH-801 Cowling/Crossflow
I need a cowling for a Zenith CH-801 running a Crossflow Subaru engine. Any ideas? Jay Jay F. Caldwell Owner, Caldwell Systems Engineering (CSE), LLC 4181 Tamilynn Court San Diego, CA 92122 Voice 858.453.4594 Facsimile 858.452.1560 Work 619.562.0885 Mobile 858.336.0394 ________________________________________________________________________________
Date: Jan 26, 2007
Greetings all. Per Lind and others about to purchase a GPS. One of the first places to start is www.sportys.com and click on the GPS comparison chart. Specifications and features for a good variety of the GPS units that are on the market today are listed along with prices. The unit that is no longer on the list is the GPS that I ended up buying and that is the AvMap Geo Pilot (Sportys item # 1932A). I realize that it does not have many of the features that the high end units have, like weather display and such, but for the money ($795) it has one of the largest displays available and I found it very easy to operate. I only have about 20 hours in the air with it but so far have been very pleased with performance. Hope this helps Dick Neitzel Sayner, WI 701 Jab 2200 N962WB N963WB(at)frontiernet.net ________________________________________________________________________________
From: "Scott Laughlin" <cookwithgas(at)HOTMAIL.COM>
Subject: 601XL "Tail Number" Opinion Poll
Date: Jan 26, 2007
Guys: I registered my tail number some time ago (N5SL) and now I'm ready to stick it on the airplane. I got the black, 3", pre-spaced numbers from Aircraft Spruce. Here's where I'm having trouble making a decision: Even though it is called a "Tail Number" I've noticed a lot of 601's have the numbers on the fuselage below the longerons. Please reply with where you think the numbers ought to be and why. I located a few examples below to help make the decision: Tail: http://www.zenvair.com/jannakos1.jpg http://www.zenithair.com/zodiac/pic06/b-carlson.jpg http://www.zenithair.com/zodiac/pic06/8190003.jpg Fuselage: http://www.zenvair.com/ray3.jpg http://www.zenithair.com/zodiac/pic06/c-richmond4.jpg http://www.zenithair.com/zodiac/pic06/n8830c-2.jpg Thanks for your input. Scott Laughlin 601XL/Corvair Polished, not painted Omaha, Nebraska www.cooknwithgas.com _________________________________________________________________ Valentines Day -- Shop for gifts that spell L-O-V-E at MSN Shopping http://shopping.msn.com/content/shp/?ctId=8323,ptnrid=37,ptnrdata=24095&tcode=wlmtagline ________________________________________________________________________________
Date: Jan 26, 2007
FAR 45.25 (location) http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgFAR.nsf/0/89cbae 6ceae8fe13852566ab006bed58!OpenDocument&Click TinyURL: http://tinyurl.com/yptdok Sec. 45.25 Location of marks on fixed-wing aircraft. (a) The operator of a fixed-wing aircraft shall display the required marks on either the vertical tail surfaces or the sides of the fuselage, except as provided in Sec. 45.29(f). (b) The marks required by paragraph (a) of this section shall be displayed as follows: (1) If displayed on the vertical tail surfaces, horizontally on both surfaces, horizontally on both surfaces of a single vertical tail or on the outer surfaces of a multivertical tail. However, on aircraft on which marks at least 3 inches high may be displayed in accordance with Sec. 45.29(b)(1), the marks may be displayed vertically on the vertical tail surfaces. (2) If displayed on the fuselage surfaces, horizontally on both sides of the fuselage between the trailing edge of the wing and the leading edge of the horizontal stabilizer. However, if engine pods or other appurtenances are located in this area and are an integral part of the fuselage side surfaces, the operator may place the marks on those pods or appurtenances. FAR 45.29 (size) http://www.airweb.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/RGFAR.NSF/0/b75de9 a6d18e489186256edf006d6cec!OpenDocument&ExpandSection=2 TinyURL: http://tinyurl.com/26cclr All though I can't make it out from the FARs I am told that aircraft entering the US now (post 9/11) need to have the numbers be 12 inches high. Paragraph (h) seems to be related to this: "(h) After March 7, 1988, each operator of an aircraft penetrating an ADIZ or DEWIZ shall display on that aircraft temporary or permanent nationality and registration marks at least 12 inches high." -- Craig ________________________________________________________________________________
Subject: Builder support for the 601HD or HDS
Date: Jan 26, 2007
Hi Gang The HD and HDS are still very good options for some builders. I think the HD especially. I was wondering if there was still builder support for these models? Can you still purchase pre-made parts from ZAC?? Plan updates etc? Seems that most builders are building the XL. Ron _________________________________________________________________ Your Space. Your Friends. Your Stories. Share your world with Windows Live Spaces. http://discoverspaces.live.com/?loc=en-CA ________________________________________________________________________________
Subject: Re: 601XL "Tail Number" Opinion Poll
Date: Jan 26, 2007
If you are going to use just black 3" number put them on the tail. As short as your number is I' put them on horz. If someone was going to color match the numbers with a paint job I'd go with the fuselage. With vanity numbers like yours, and mine, I'd go with big color matched numbers on the fuse. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90687#90687 ________________________________________________________________________________
Subject: Re: Builder support for the 601HD or HDS
Date: Jan 26, 2007
I understand the the parts are still being made and sold but I'd doubt there are going to be many more updates to the plans. I'm curious why you'd want the HD or HDS over the XL though? rlalonde wrote: > Hi Gang > The HD and HDS are still very good options for some builders. I think the HD > especially. > I was wondering if there was still builder support for these models? Can you > still purchase pre-made parts from ZAC?? Plan updates etc? > Seems that most builders are building the XL. > Ron > -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90688#90688 ________________________________________________________________________________
Date: Jan 26, 2007
Hi Gig Presently building an XL., but was just looking at the plan I also have for the HD. The HD can use a smaller powerplant, and that interests me. This XL project is my sons choice, ....personally....I like the 701 best of all. Ron >From: "Gig Giacona" <wr.giacona(at)cox.net> >Reply-To: zenith-list(at)matronics.com >To: zenith-list(at)matronics.com >Subject: Zenith-List: Re: Builder support for the 601HD or HDS >Date: Fri, 26 Jan 2007 13:39:48 -0800 >MIME-Version: 1.0 >>I understand the the parts are still being made and sold but I'd doubt >>there are going to be many more updates to the plans. > >I'm curious why you'd want the HD or HDS over the XL though? > > >rlalonde wrote: > > Hi Gang > > The HD and HDS are still very good options for some builders. I think >the HD > > especially. > > I was wondering if there was still builder support for these models? Can >you > > still purchase pre-made parts from ZAC?? Plan updates etc? > > Seems that most builders are building the XL. > > Ron > > > > >-------- >W.R. "Gig" Giacona >601XL Under Construction >See my progress at www.peoamerica.net/N601WR > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=90688#90688 > > _________________________________________________________________ Your Space. Your Friends. Your Stories. Share your world with Windows Live Spaces. http://discoverspaces.live.com/?loc=en-CA ________________________________________________________________________________
Date: Jan 26, 2007
Scott, I was planning to use large numbers on the fuselage sides for the following reason. The sides are flat ALMOST. My plans called for the .016 side skins, and didn't know thicker skins were an option until I was past that phase of construction, and the "flat" sides don't look flat. Painting BIG numbers on the side is one idea I have to obscure the imperfection. Dan -------- Scratch building XL with Corvair Engine Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90740#90740 ________________________________________________________________________________
Date: Jan 26, 2007
Actually the XL may be the worse choice in terms of future parts availability. That is because the XL is still evolving. I can't order many parts for my vintage 2000 XL kit from Zenith because the plans have changes. The instrument panel has moved, the bulkheads have changed shape, etc. That is why lately I've been acting more like a scratch builder than a kit builder. -- Craig ________________________________________________________________________________
Date: Jan 27, 2007
Subject: 601XL Wing Flutter
Dear Thread Friends, I went flying this afternoon. Took a fellow with me and just wanted an hour in the clear blue. Conditions were perfect, clear, cool and only a slight wind. The only big thing around much to see nearby is Lake Juliette which has a big coal fired power station in the middle. Three huge steam towers that look like a nuclear power station. We flew around the lake about two miles away at 5000 feet so my pal could get a good look see. On the down wind side we flew into an invisible killer. We were doing above 140 when we flew into it. Instantly the left wing fluttered at a fast pitch, aileron and all and it looked to be moving maybe two inched up and down. I figured a couple seconds would break it off. I didn't have time to look around the passenger to see if the right wing was fluttering, but I suspect it was. I chopped power and did a hard diving wing over to the left and out of it. The flutter sound was great even over my Lightspeed AN system and the whole thing probably last maybe 5 or 6 seconds. I regained control out of the snap dive, maxing above 170 and flew slow and easy back to the field before I tested the controls. Everything felt okay and I could see no wrinkles in the top skin so I landed. Didn't really have much choice. Upon inspection I found no sign of stress, no skin deform, no paint cracked around rivets, nothing. I will take off all inspection panels for a close inspection this weekend and check bolts, controls, etc., but I cannot believe such a prolonged violent movement of the wing did not damage something other than my pride. Two things learned. Don't fly anywhere near a power station. Even at 5000 feet and miles away the invisible heat rises and is most extreme. Maybe intensified in cold weather. The other thing is the XL is very, very tough. Oh, there is a third thing. How could I have been so stupid not to know the first thing !! I am interested though in knowing why the wings fluttered in this thermal? What theory of air dynamics would cause this extreme reaction? Was is just the level of heat and speed the invisible air was streaming past? This was my 90th flight in her and she made me proud again. Best regards to you all, Bill of Georgia N505WP 601XL-3300 ________________________________________________________________________________
Subject: Re: 601XL Wing Flutter
Date: Jan 27, 2007
Hey Bill, Sounds scary! Glad you are OK. Although it was years ago ( first off I'm NOT a trained test pilot ) I was involved in some actual flutter problems involving a Midget Mustang I built by a friend and latter did flutter tests in a Mustang II built by another friend. When we experienced the flutter with the MM I ( at about 180 mph ) we consulted an old friend who knew Dave Long ( the designer of the MM I ) and picked his brain. One thing he said is if you experience flutter you have mere seconds to SLOW DOWN and the best way to do that is to reduce power and pull the airplane up ( I noticed you dove and increased speed but got out of it ). This procedure helped us with the MM I. What we found with this airplane was an accumulation of built in slop in the aileron control system. This system was all push rods and bellcranks and the builder had just drilled all the holes ( did not ream ) and used AN Standard bolts. I found this quickly by haveing the builder grasp one aileron while I moved the other aileron up and down better than a 1/4" at the trailing edge. Remeber this is a 200 mph plus airplane. We went to NAS and oversized bolts and tightened up the slop. This DIDN'T cure the flutter though. What we found then was that when he filled the counterweight tubes that were mounted forward of the hinge line with lead, he didn't get the tubes full as the lead solidified as he poured it in and left many air spaces inside the tube. We corrected that and the flutter problem went away. Probably both problems contributed to the flutter. In the Mustang II we were doing flutter test in the 225 230 mph range by increasing the speed by 1 mph increments and never had a problem, but we were ready to slow it down if one did arise. I know John from AMD tested for flutter when he did your test flight and he said nothing about it when he landed. You might call him and ask what max speed he uses when testing. Not being an aerodynamicist ( spelling? ) I don't know the cause for your encounter but just maybe it has something to do with the fact that we don't use balanced controls on these Zenith airplanes and a weird air pattern that you encountered because of the heat from the power plant. I've flown over large fires on the ground, as I'm sure you and others have in the past and experienced some pretty rough air but not FLUTTER. In your case, if it was unbalanced controls, it seems that when you dove to 170, it should have made it worse. Do the "grab one aileron and try to move the other test" and see what you find. Otherwise, DON'T fly near the power plant any more! I've been tempted to fly over to that same place but since 9-11 I stay away from all power plants. Let me know if I can help and also what you find. Jim Hoak ----- Original Message ----- From: JAPhillipsGA(at)aol.com To: zenith-list(at)matronics.com Sent: Saturday, January 27, 2007 1:31 AM Subject: Zenith-List: 601XL Wing Flutter Dear Thread Friends, I went flying this afternoon. Took a fellow with me and just wanted an hour in the clear blue. Conditions were perfect, clear, cool and only a slight wind. The only big thing around much to see nearby is Lake Juliette which has a big coal fired power station in the middle. Three huge steam towers that look like a nuclear power station. We flew around the lake about two miles away at 5000 feet so my pal could get a good look see. On the down wind side we flew into an invisible killer. We were doing above 140 when we flew into it. Instantly the left wing fluttered at a fast pitch, aileron and all and it looked to be moving maybe two inched up and down. I figured a couple seconds would break it off. I didn't have time to look around the passenger to see if the right wing was fluttering, but I suspect it was. I chopped power and did a hard diving wing over to the left and out of it. The flutter sound was great even over my Lightspeed AN system and the whole thing probably last maybe 5 or 6 seconds. I regained control out of the snap dive, maxing above 170 and flew slow and easy back to the field before I tested the controls. Everything felt okay and I could see no wrinkles in the top skin so I landed. Didn't really have much choice. Upon inspection I found no sign of stress, no skin deform, no paint cracked around rivets, nothing. I will take off all inspection panels for a close inspection this weekend and check bolts, controls, etc., but I cannot believe such a prolonged violent movement of the wing did not damage something other than my pride. Two things learned. Don't fly anywhere near a power station. Even at 5000 feet and miles away the invisible heat rises and is most extreme. Maybe intensified in cold weather. The other thing is the XL is very, very tough. Oh, there is a third thing. How could I have been so stupid not to know the first thing !! I am interested though in knowing why the wings fluttered in this thermal? What theory of air dynamics would cause this extreme reaction? Was is just the level of heat and speed the invisible air was streaming past? This was my 90th flight in her and she made me proud again. Best regards to you all, Bill of Georgia N505WP 601XL-3300 ________________________________________________________________________________
Subject: Cable Rigging
Date: Jan 27, 2007
While rigging the cables, I noticed that the Rudder and elevator cables cross over one another and are making contact. Is it acceptable that they are rubbing ever so slightly ? Eric. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90798#90798 ________________________________________________________________________________
Date: Jan 27, 2007
Ben, maybe I did not explain well, but it was not control flutter. The aileron did not move independent of the wing. What occurred is the whole wing fluttered with aileron moving with it., best regards, Bill ________________________________________________________________________________
Date: Jan 27, 2007
Ron- The HD/HDS design has three major advantages, all related to the size of the wings. 1. You can get by with a smaller workspace. 2. If you're scratchbuilding, you don't have to buy so many 12' sheets of stock. 3. 8' brakes are hard enough to come by, 12' even harder. Both XL and HDS prints/manuals have serious problems in my estimation, but "Shooting out prints" and "Writing work instructions" is what I do for a living. You have to balance personal expectations. Listers who have the same job responsibilites as I do can't believe how sloppy the prints and instructions are. On the other hand, how do Zenith instructions stack up to the competition? I don't know- the HDS is the only plane I've attempted to build. Zenith has never failed to be able to supply a replacement part for my HDS, and for that I'm grateful. Two cautions: 1. The Zenith website parts list is out of date. Prepare to receive a quote and pay more than is listed. 2. Make absolutely sure the part number you order is what you need. Bottom line is, CH never had a bad design. Execution is a different story. Bill Naumuk HDS Fuselage Townville, Pa ----- Original Message ----- From: "Ron Lalonde" <rlalonde(at)HOTMAIL.COM> Sent: Friday, January 26, 2007 4:10 PM Subject: Zenith-List: Builder support for the 601HD or HDS > > Hi Gang > The HD and HDS are still very good options for some builders. I think the > HD especially. > I was wondering if there was still builder support for these models? Can > you still purchase pre-made parts from ZAC?? Plan updates etc? > Seems that most builders are building the XL. > Ron > > _________________________________________________________________ > Your Space. Your Friends. Your Stories. Share your world with Windows Live > Spaces. http://discoverspaces.live.com/?loc=en-CA > > > ________________________________________________________________________________
Subject: Re: Cable Rigging
Date: Jan 27, 2007
Short answer, NO LOW&SLOW John While rigging the cables, I noticed that the Rudder and elevator cables cross over one another and are making contact. Is it acceptable that they are rubbing ever so slightly ? Eric. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90798#90798 ________________________________________________________________________________
Subject: NOT wing flutter!
Date: Jan 27, 2007
(long post) Whoa! One needs be careful saying "wing flutter" on a list devoted to aircraft! In the aerospace world, flutter is a specific phenomenon defined as "dynamic instability of an elastic body in an airstream" (from Aeroelasticity - Bisplinghoff, Ashley and Hoffman - the standard reference text). In a wing-type body, there is a speed *above* which the oscillations of the wing can go unstable, that is, they get bigger and bigger with each cycle. The only solution for this is to either slow down, change the wing's aerodynamic characteristics, for example by deploying spoilers or other controls, or change the wing's structural characteristics, for example by buckling stuff. If you are below that speed, the wing can not flutter. It can shake, rattle and roll for sure, but not flutter! 140 indicated is about 150 true, which should give you plenty of margin. (I am assuming mph. If you were going 140 knots indicated at 5000', that's over 170 mph true, and it's a different story.) Since you sped up and the wing did not come off, what you saw was not flutter, but simply some excitation of the wing bending. A two inch oscillation on a 601-length wing is not even close to being a structural problem. The wing is stressed for +/- 6 G's meaning that it can hold 6 times the gross weight of the aircraft without any failure. This is tested in production aircraft by loading up the wing with distributed sand bag weights, so in a typical 601, that would be about 5000 lbs of sand on each wing. You can bet that it will deflect a lot more than 2 inches! Of course, it is possible to get flutter of just a control surface. This is more likely in aircraft like a 601, which does not have mass balanced ailerons or elevators. But again, since you sped up and this did not get worse, it is very unlikely to have happened. There are a number of scenarios which could lead to an oscillation like you described, excited by the turbulence - including a low frequency control surface vibration linked through the aileron controls to your hand (the soft servo), a vibration caused by a structural change like a loosening cable or control arm, feedback or other failures in the aileron trim system, feedback in the autopilot if you have one (which should be designed to kick off in that situation). You should certainly check all those things and the wing attach bolts, and whatever else you can! But it could just have been the wing and/or aileron vibrating after being excited by the strong turbulence, like a guitar string being strummed. Note - when you encounter airframe vibrations, a good response is always to make small control movements and *slow down*, instead of speeding up. FWIW - standard disclaimers, etc., Andy Elliott, Mesa, AZ (MIT '74, Ph.D. '87, all in Aerospace Engineering) N601GE (reserved) 601XL/TD/QB, Corvair, building... ________________________________________________________________________________
Subject: Re: 601XL Wing Flutter????
Date: Jan 27, 2007
Hi Bill,Glad everything came out OK. Looks like you ran into some really weird turbulence from the power-plant, giving you an "E" ticket ride. If you were really experiencing wing or control surface flutter, your diving and picking up speed should have exacerbated the problem with the amplitude going divergent very rapidly, until something(s) bends or more likely breaks off. Only saw this once in a film of a dynamic model in a wind tunnel - once flutter started the entire model was gonzo in a second or two. Do you recall experiencing any feed back in the stick/rudder?In 199 hours in my XL, I have had some bumpy rides and the airplane has handled it ok - just glad I always have my seat belt tight. I have also had some GREAT*, almost I would have believed, GOOD*, landings and I agree the airplane is tough. *GREAT Landing - Airplane is still flyable. GOOD Landing - You can walk away from the airplane.Please let us know if you find anything after your in-depth inspection. I kind of suspect you will not find anything amiss, but if you do it would be a good data point for all of us for tailoring our structural inspections. Tony Graziano XL; N493TG--------Ben, maybe I did not explain well, but it was not control flutter. The aileron did not move independent of the wing. What occurred is the whole wing fluttered with aileron moving with it., best regards, Bill------------------------- Dear Thread Friends, I went flying this afternoon. Took a fellow with me and just wanted an hour in the clear blue. Conditions were perfect, clear, cool and only a slight wind. The only big thing around much to see nearby is Lake Juliette which has a big coal fired power station in the middle. Three huge steam towers that look like a nuclear power station. We flew around the lake about two miles away at 5000 feet so my pal could get a good look see. On the down wind side we flew into an invisible killer. We were doing above 140 when we flew into it. Instantly the left wing fluttered at a fast pitch, aileron and all and it looked to be moving maybe two inched up and down. I figured a couple seconds would break it off. I didn't have time to look around the passenger to see if the right wing was fluttering, but I suspect it was. I chopped power and did a hard diving wing over to the left and out of it. The flutter sound was great even over my Lightspeed AN system and the whole thing probably last maybe 5 or 6 seconds. I regained control out of the snap dive, maxing above 170 and flew slow and easy back to the field before I tested the controls. Everything felt okay and I could see no wrinkles in the top skin so I landed. Didn't really have much choice. Upon inspection I found no sign of stress, no skin deform, no paint cracked around rivets, nothing. I will take off all inspection panels for a close inspection this weekend and check bolts, controls, etc., but I cannot believe such a prolonged violent movement of the wing did not damage something other than my pride. Two things learned. Don't fly anywhere near a power station. Even at 5000 feet and miles away the invisible heat rises and is most extreme. Maybe intensified in cold weather. The other thing is the XL is very, very tough. Oh, there is a third thing. How could I have been so stupid not to know the first thing !! I am interested though in knowing why the wings fluttered in this thermal? What theory of air dynamics would cause this extreme reaction? Was is just the level of heat and speed the invisible air was streaming past? This was my 90th flight in her and she made me proud again. Best regards to you all, Bill of Georgia N505WP 601XL-3300 ________________________________________________________________________________
From: "rick tedford" <rick.tedford(at)sympatico.ca>
Date: Jan 27, 2007
Hello Craig : Can you tell me how far and which way the panel moved on the 601XL ? My kit is of 2001vintage and I am going to instal a new panel which will have a better layout . I was unable to find the update showing the change . Any help would be appreciated . Cheers Rick Tedford ----- Original Message ----- From: "Craig Payne" <craig(at)craigandjean.com> Sent: Friday, January 26, 2007 11:46 PM Subject: RE: Zenith-List: Builder support for the 601HD or HDS > > Actually the XL may be the worse choice in terms of future parts > availability. That is because the XL is still evolving. I can't order many > parts for my vintage 2000 XL kit from Zenith because the plans have > changes. > The instrument panel has moved, the bulkheads have changed shape, etc. > That > is why lately I've been acting more like a scratch builder than a kit > builder. > > -- Craig > > > -- > 11:11 AM > > ________________________________________________________________________________
Subject: Sun-N-Fun BBQ
Date: Jan 27, 2007
Sun-N-Fun, OK Group, it is that time of year again, time to go to www.ch601.org or www.ch701.com and sign up for the Webmasters BBQ. This year is important to register. I had reports of Vans owners crashing the event for free food! It really shouldn't come as a surprise, after all that money for the large engine and the panel they need to forage for any free meal! ( Only kidding!right?) Anyways, I'm buying dinner for Zenith/Zenair owners/builders/dreamers, so in order to keep things in line a little better this year I will be making name tags again. Your name tag is your ticket for the free event. I will have name blank name tags for those who don't use a computer but I really need everyone to sign up for a couple of reasons. I use the list of name tags to judge how much food to buy and by doing it ahead of time I don't spend the whole Sun-N-Fun organizing the BBQ. I prefer to have everything done even before I leave Ontario. The first year of this event we saw at least 80 people, last year we were over 130 people. I still had food left over but barely and I ran out of pop way too early. I will make changes accordingly this year. Please sign up ASAP even if your only thinking of going. You can easily tell me later that you can't make it. That is far preferable then having 50-80 people sign up in the last week before I leave for Florida. Thanks Guys, I really look forward to seeing you all again. Mark Townsend Alma, Ontario Zodiac 601XL C-GOXL, CH701 just started www.ch601.org / www.ch701.com / www.Osprey2.com -- 1/26/2007 11:11 AM ________________________________________________________________________________
Date: Jan 27, 2007
BTW: is this a 601HD, HDS, XL, 701 or 801? -- Craig -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Eric Tingey Sent: Saturday, January 27, 2007 8:04 AM Subject: Zenith-List: Cable Rigging While rigging the cables, I noticed that the Rudder and elevator cables cross over one another and are making contact. Is it acceptable that they are rubbing ever so slightly ? Eric. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90798#90798 ________________________________________________________________________________
Date: Jan 27, 2007
It looks like I am wrong. The instrument panel has not moved. 6B14 dated 04/01 and 03/05 show 475 from the base of the instrument panel 6B12-4 to the firewall. But the dimensions of the forward top skin have changed. On 6C1 dated 10/06 6C1-4 is 570 by 1135. But the 05/01 plans show it as 600 by 1300. But the shorter dimension controls the firewall overhang and is trimmed to fit the cowl. 6B15 does show that the position of the most forward vertical stiffing L angle has moved by 45mm. The sheet dated 04/01 shows the stiffener 400 back from the firewall. The sheet dated 07/05 shows 355. Having three sets of plans makes for endless reading fun. -- Craig ________________________________________________________________________________
From: "Roger Venables" <roger(at)nwtradingpost.com>
Date: Jan 27, 2007
Mark What date is the BBQ? Roger Venables Kenmore, WA CH701 -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of ZodieRocket Sent: Saturday, January 27, 2007 10:31 AM Subject: Zenith-List: Sun-N-Fun BBQ Sun-N-Fun, OK Group, it is that time of year again, time to go to www.ch601.org or www.ch701.com and sign up for the Webmasters BBQ. This year is important to register. I had reports of Vans owners crashing the event for free food! It really shouldn't come as a surprise, after all that money for the large engine and the panel they need to forage for any free meal! ( Only kidding!right?) Anyways, I'm buying dinner for Zenith/Zenair owners/builders/dreamers, so in order to keep things in line a little better this year I will be making name tags again. Your name tag is your ticket for the free event. I will have name blank name tags for those who don't use a computer but I really need everyone to sign up for a couple of reasons. I use the list of name tags to judge how much food to buy and by doing it ahead of time I don't spend the whole Sun-N-Fun organizing the BBQ. I prefer to have everything done even before I leave Ontario. The first year of this event we saw at least 80 people, last year we were over 130 people. I still had food left over but barely and I ran out of pop way too early. I will make changes accordingly this year. Please sign up ASAP even if your only thinking of going. You can easily tell me later that you can't make it. That is far preferable then having 50-80 people sign up in the last week before I leave for Florida. Thanks Guys, I really look forward to seeing you all again. Mark Townsend Alma, Ontario Zodiac 601XL C-GOXL, CH701 just started www.ch601.org / www.ch701.com / www.Osprey2.com -- 1/26/2007 11:11 AM ________________________________________________________________________________
Date: Jan 27, 2007
Sun-N-Fun 2007 Webmasters BBQ Thursday April 19 2007 Mark -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Roger Venables Sent: Saturday, January 27, 2007 3:15 PM Subject: RE: Zenith-List: Sun-N-Fun BBQ Mark What date is the BBQ? Roger Venables Kenmore, WA CH701 -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of ZodieRocket Sent: Saturday, January 27, 2007 10:31 AM Subject: Zenith-List: Sun-N-Fun BBQ Sun-N-Fun, OK Group, it is that time of year again, time to go to www.ch601.org or www.ch701.com and sign up for the Webmasters BBQ. This year is important to register. I had reports of Vans owners crashing the event for free food! It really shouldn't come as a surprise, after all that money for the large engine and the panel they need to forage for any free meal! ( Only kidding!right?) Anyways, I'm buying dinner for Zenith/Zenair owners/builders/dreamers, so in order to keep things in line a little better this year I will be making name tags again. Your name tag is your ticket for the free event. I will have name blank name tags for those who don't use a computer but I really need everyone to sign up for a couple of reasons. I use the list of name tags to judge how much food to buy and by doing it ahead of time I don't spend the whole Sun-N-Fun organizing the BBQ. I prefer to have everything done even before I leave Ontario. The first year of this event we saw at least 80 people, last year we were over 130 people. I still had food left over but barely and I ran out of pop way too early. I will make changes accordingly this year. Please sign up ASAP even if your only thinking of going. You can easily tell me later that you can't make it. That is far preferable then having 50-80 people sign up in the last week before I leave for Florida. Thanks Guys, I really look forward to seeing you all again. Mark Townsend Alma, Ontario Zodiac 601XL C-GOXL, CH701 just started www.ch601.org / www.ch701.com / www.Osprey2.com -- 1/26/2007 11:11 AM -- 1/26/2007 11:11 AM -- 1/26/2007 11:11 AM ________________________________________________________________________________
Date: Jan 27, 2007
CH601 HDS Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90882#90882 ________________________________________________________________________________
Subject: Re: Annual Inspections
Date: Jan 27, 2007
I would really appreciate a copy of this. Thanks. ________________________________________________________________________________
Date: Jan 27, 2007
From: Christian Tremblay <cj.tremblay(at)videotron.ca>
Subject: Question concerning Flanged Lightening holes sides
Hi dears builders, I was doing my flange lightening holes in my wing spar extension and I reversed male/female side of one hole. The male side was supposed to be on front side view of the plane, I done one (of 2) male back side of the plane. My question is that a big problem ? Could it be affect resistance ? Could be acceptable or not for some part of the plane like, spar, rib, fuselage and so on ? This is acceptable for AC 43.13 standard ? Please specify your background and experience on that domain if you respond to that question. I never read anything on that matter. Thanks a lot for information. Christian Tremblay A guy who build a CH640 aircraft from plan http://www.zodiac640.com/ ________________________________________________________________________________
Subject: Does your front bungee cord pin touch the front gear leg?
Date: Jan 27, 2007
Looking over my third-hand 601XL kit I see that the front bungee cord pin 6G2-2 rubs on the gear leg 6G1-1. Looking at the stack-up of dimensions the tolerances are very tight. The 5/8th inch (15.8mm) pin passes through a hole whose center is 25mm from the firewall (see 6B8-7). So the forward edge of the pin is 25 + 15.8/2 = 32.9mm from the firewall. The 2 inch gear leg (radius = 25.4mm) passes through a hole in 6B7-1 that is 60mm from the firewall bend radius. The dimensions in the bottom bearing 6G2-1 are similar: the center of the 2 inch hole is 58mm from the rear edge of the block. So the rear edge of the gear leg is at 60 - 25.4 or 34.6mm from the firewall with some slop for the bend radius. 34.6 - 32.9 gives a clearance of 1.7mm. And the bungee pulls these two pieces together, removing any slop. Does the pin touch the leg on your plane? Is it acceptable to shift the nylon bearing forward to create enough clearance (I've got to replace mine due to other problems)? I'll be asking Zenith the same question. -- Craig ________________________________________________________________________________
Date: Jan 27, 2007
leg? Craig, The lower bungee pin 6G2-2 does not touch the gear tube on my XL. I don't know what the clearance is, but I could put a piece of .025 between the two without any friction. Jay in Dallas "Craig Payne" wrote: > >Looking over my third-hand 601XL kit I see that the front bungee cord pin >6G2-2 rubs on the gear leg 6G1-1. Looking at the stack-up of dimensions the >tolerances are very tight. The 5/8th inch (15.8mm) pin passes through a hole >whose center is 25mm from the firewall (see 6B8-7). So the forward edge of >the pin is 25 + 15.8/2 = 32.9mm from the firewall. The 2 inch gear leg >(radius = 25.4mm) passes through a hole in 6B7-1 that is 60mm from the >firewall bend radius. The dimensions in the bottom bearing 6G2-1 are >similar: the center of the 2 inch hole is 58mm from the rear edge of the >block. So the rear edge of the gear leg is at 60 - 25.4 or 34.6mm from the >firewall with some slop for the bend radius. 34.6 - 32.9 gives a clearance >of 1.7mm. And the bungee pulls these two pieces together, removing any slop. > >Does the pin touch the leg on your plane? Is it acceptable to shift the >nylon bearing forward to create enough clearance (I've got to replace mine >due to other problems)? > >I'll be asking Zenith the same question. > >-- Craig > > ________________________________________________________________________________
Subject: Re: Does your front bungee cord pin touch the front gear
leg?
Date: Jan 27, 2007
Mine, kit-built, has about 2mm clearance between 6G2-2 and 6G1-1.. Robin in AR 601XL Zen-Vair N601ZV reserved. ----- Original Message ----- From: "Craig Payne" <craig(at)craigandjean.com> Sent: Saturday, January 27, 2007 4:45 PM Subject: Zenith-List: Does your front bungee cord pin touch the front gear leg? > ________________________________________________________________________________
Subject: FBO Marty Turman
Date: Jan 27, 2007
From: "Husky Larry J" <Larry.J.Husky(at)doc.state.or.us>
I know there are a few guys that fly through Lakeview, Oregon and stop by KLKV for fuel. Marty Turman has been there for years and there are many pilots that speak of him. I am sorry to say that Marty has passed away unexpectedly. From what I am told, Marty was complaining of a pain in his eye and called his neighbor, who is a nurse. Marty was gone before she arrived. Marty was an EAA technical advisor and was a big help when I have questions about my project. Marty also let me use many of his specialty tools. His presence will be missed by throughout the aviation field. I am going to be really lost on my project now, since he is the only AP within 100 miles. I do not know the future of the airport at this time. I have decided to paint a little something on my plane when it is done for Marty. He has been a big help to me. Marty was building an experimental also. A Beaver TD. It showed some of the finest work I have ever seen. You could look for some time and not find a flaw in the wings or fuse. Services will be Monday at 2 pm here in Lakeview. I went to the airport today and noticed a sign on his office door that reads. "When my ship finally comes in. I will probably be at the airport". I believe Marty was at the airport when he felt something was wrong. I have not had to post much on this group for questions, due to Marty's knowledge, but I am afraid that if I am to finish my project, that will have to change. If you knew Marty, take a minute to think of him and what he gave to aviation. I sure hate to see Marty's Cessna sitting there waiting for him. Larry Husky Lakeview, Oregon Do not Achieve ________________________________________________________________________________
Subject: Re: Question concerning Flanged Lightening holes sides
Date: Jan 27, 2007
Hello Christian, One of the wing ribs (#7) in the 601XL has 2 lightening holes flanged in one direction and 2 holes flanged in the opposite direction. I'm assuming the part you are talking about is like the spar tip in the XL. The purpose of the flange is to add strength and rigidity to the part. I can't see where your mistake would affect the integrity of your wing in any way. Dave Clay Temple, TX http://www.daves601xl.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90979#90979 ________________________________________________________________________________
Date: Jan 27, 2007
Sheesh. I gotta chime in here... This is normal and has nothing to do with "flutter". I'd file this one right along side all the "twitchy" nonsense that was going around a few months ago. The guy hit a strong thermal due to rising heat off the steam stacks. Simple as that. I see this regularly in my Piper Warrior. The downwind 45 entry to my home airport runs right over the top of an oil refinery. Lots of heat. Always enough to bump you as you go over, and once it was enough to put me nearly on my side. You have to expect that sort of thing when flying over a large heat source. Regarding the wings bouncing - watch the normal flex of your wings (or look out the window next time you're on an airliner). Push & pull on that thing in your hands and watch what your wings do... Suggestion: go back and fly over that power plant again. Go high and slow, watch your altimeter, and expect some bumps. It won't be so bad now that you can anticipate what's going to happen. Seriously, give this a shot. - Patrick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=90989#90989 ________________________________________________________________________________
Date: Jan 28, 2007
Subject: Choice of planes to fly to prepare for Zodiac.
I usually fly a Cessna 152, the old shetland pony of the aircraft world. I haven't even been up in a Zenith anything yet, but am building a 601XL, currently the tail pieces until funds are a bit more free to dedicate to the rest of it. Until it's done, I want to prepare by flying something more similar to it than the Cessna. I have started transitioning to a Diamond Katana. I've flown one before, but it's been a couple of years. I just went up again yesterday in the composite beast. It was miserable to handle on the ground, pulling hard to the right, taxiing like a drunk three legged mule. I wonder if that's normal, because of the free castering nosewheel and the nice crosswind, 10kts, or if it's just that particular airplane. Maybe something is out of whack. There's not much rudder, and diff braking has to be used a lot on the ground. How does the Zodie compare? Do any of you also fly Katanas? The thing was squirrelly to take off and land. I couldn't keep it on centerline to save my soul. I'll get it, but I'll need to fly with the cfi again. The only other rentals at this particular airport are 172s. I could go to another airport, but don't know of anything more similar to the Zodiac that's available for training or rental. I've been happy putting about in the 152. I was wondering, long term am I going to be happy in a lighter weight airplane? The Katana is heavier than the 152 and the Zodiac is lighter. I was wondering if I can get happy with the Katana, is it good preparation for the Zodiac? --------------------------------- Sucker-punch spam with award-winning protection. Try the free Yahoo! Mail Beta. ________________________________________________________________________________
Date: Jan 28, 2007
Subject: Re: Choice of planes to fly to prepare for Zodiac.
Hi Jennifer, I wish there were an easy answer to your question. Unfortunately, all planes are different, and it is unlikely to find two different models that are really similar to fly. I have not flown a Katana, but I have flown planes with free castering nose wheels. I find them very difficult to taxi and particularly difficult to take off. Add a cross wind which is trying to push your nose in the same direction as the engine torque and you have a real handful. In that respect the XL should be much nicer to handle and should be similar to the 150 since they both have nose wheel steering. I don't have my XL flying yet, but I suspect there is a significant difference in the behavior of XLs depending on which engine you have. Also, like the 150, the climb rate will change significantly depending on how many people are in the plane. Even so, an XL with a Jabiru 3300 will climb perhaps twice the rate of a 150. It has perhaps 30% more horsepower and 300 pounds less gross weight. From the standpoint of pilot training, I think all "Light" single engine planes are roughly similar to fly. When you move up to "High Performance" singles like the C-182 or Bonanza the pilot experience is quite different. The extra weight of these planes mean you must think of what you want the plane to be doing about 30 seconds in advance of the time you actually get what you want. Light singles respond immediately to changes in power and pitch. I wish we could all go out and rent XLs or 701s to prepare for flying the planes we are building. Alas, this isn't so easy to do. As far as I know there may be 3 XLs in the USA available for training and no 701s. This means you will be stuck flying whatever you can rent until your own plane is finished. Indeed, I think the more different models you fly the more you will appreciate your XL. Perhaps the 172 is reasonably close in general behavior to the XL, but if you load up the 172 it will be a lot more sluggish than your plane. I wish you luck. Paul XL fuselage At 02:41 AM 1/28/2007, you wrote: >I usually fly a Cessna 152, the old shetland pony of the aircraft >world. I haven't even been up in a Zenith anything yet, but am >building a 601XL, currently the tail pieces until funds are a bit >more free to dedicate to the rest of it. Until it's done, I want to >prepare by flying something more similar to it than the Cessna. I >have started transitioning to a Diamond Katana. I've flown one >before, but it's been a couple of years. I just went up again >yesterday in the composite beast. It was miserable to handle on the >ground, pulling hard to the right, taxiing like a drunk three legged >mule. I wonder if that's normal, because of the free castering >nosewheel and the nice crosswind, 10kts, or if it's just that >particular airplane. Maybe something is out of whack. There's not >much rudder, and diff braking has to be used a lot on the ground. >How does the Zodie compare? Do any of you also fly Katanas? The >thing was squirrelly to take off and land. I couldn't keep it on >centerline to save my soul. I'll get it, but I'll need to fly with >the cfi again. The only other rentals at this particular airport are >172s. I could go to another airport, but don't know of anything more >similar to the Zodiac that's available for training or rental. I've >been happy putting about in the 152. I was wondering, long term am I >going to be happy in a lighter weight airplane? The Katana is >heavier than the 152 and the Zodiac is lighter. I was wondering if I >can get happy with the Katana, is it good preparation for the Zodiac? > - ________________________________________________________________________________
Date: Jan 28, 2007
I learned to fly in a Grumman which has a free castoring nose wheel, I admit it bothered me for the first few flights. However, after a few flights it becomes second nature to drag a little brake to keep it straight until the rudder becomes effective, I actually wish the XL was free castoring. On the subject of handling, I am sure you will find the XL very easy to fly and that is from a low-time pilot. The last time I flew as pilot in command was a little more than 20 years ago and I became comfortable with the XL very quickly, even with my lack of experience. I am sure you will get a response from highly experienced pilots soon, I just thought you might also want the opinion from someone that was concerned about the same issues. Clyde Barcus 601 XL ----- Original Message ----- From: Jennifer Moorhouse To: zenith-list(at)matronics.com Sent: Sunday, January 28, 2007 4:41 AM Subject: Zenith-List: Choice of planes to fly to prepare for Zodiac. I usually fly a Cessna 152, the old shetland pony of the aircraft world. I haven't even been up in a Zenith anything yet, but am building a 601XL, currently the tail pieces until funds are a bit more free to dedicate to the rest of it. Until it's done, I want to prepare by flying something more similar to it than the Cessna. I have started transitioning to a Diamond Katana. I've flown one before, but it's been a couple of years. I just went up again yesterday in the composite beast. It was miserable to handle on the ground, pulling hard to the right, taxiing like a drunk three legged mule. I wonder if that's normal, because of the free castering nosewheel and the nice crosswind, 10kts, or if it's just that particular airplane. Maybe something is out of whack. There's not much rudder, and diff braking has to be used a lot on the ground. How does the Zodie compare? Do any of you also fly Katanas? The thing was squirrelly to take off and land. I couldn't keep it on centerline to save my soul. I'll get it, but I'll need to fly with the cfi again. The only other rentals at this particular airport are 172s. I could go to another airport, but don't know of anything more similar to the Zodiac that's available for training or rental. I've been happy putting about in the 152. I was wondering, long term am I going to be happy in a lighter weight airplane? The Katana is heavier than the 152 and the Zodiac is lighter. I was wondering if I can get happy with the Katana, is it good preparation for the Zodiac? ------------------------------------------------------------------------- ----- --> http://forums.matronics.com =========== ________________________________________________________________________________
Date: Jan 28, 2007
There are two 601's on the west coast you can rent. If you're already flying a 152 I would be surprised if you could not transition in less than an hour. Let me know if you are interested in contact info. Gary Boothe Cool, CA 601 HDSTD, WW Conversion 90% done, Tail done, wings done, working on c-section _____ From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Jennifer Moorhouse Sent: Sunday, January 28, 2007 2:42 AM Subject: Zenith-List: Choice of planes to fly to prepare for Zodiac. I usually fly a Cessna 152, the old shetland pony of the aircraft world. I haven't even been up in a Zenith anything yet, but am building a 601XL, currently the tail pieces until funds are a bit more free to dedicate to the rest of it. Until it's done, I want to prepare by flying something more similar to it than the Cessna. I have started transitioning to a Diamond Katana. I've flown one before, but it's been a couple of years. I just went up again yesterday in the composite beast. It was miserable to handle on the ground, pulling hard to the right, taxiing like a drunk three legged mule. I wonder if that's normal, because of the free castering nosewheel and the nice crosswind, 10kts, or if it's just that particular airplane. Maybe something is out of whack. There's not much rudder, and diff braking has to be used a lot on the ground. How does the Zodie compare? Do any of you also fly Katanas? The thing was squirrelly to take off and land. I couldn't keep it on centerline to save my soul. I'll get it, but I'll need to fly with the cfi again. The only other rentals at this particular airport are 172s. I could go to another airport, but don't know of anything more similar to the Zodiac that's available for training or rental. I've been happy putting about in the 152. I was wondering, long term am I going to be happy in a lighter weight airplane? The Katana is heavier than the 152 and the Zodiac is lighter. I was wondering if I can get happy with the Katana, is it good preparation for the Zodiac? _____ ________________________________________________________________________________
From: "Roberto Ap. Rodrigues de Brito" <lenabeto(at)uol.com.br>
Subject: Fw: The Special Zodiac first flight
Date: Jan 28, 2007
Hi Folks, After almost 3,000 working hours, my "Zodiac XL 601" has finally been flown. It was gorgeous. Thus far I don't have the technical data , but when i do, I'll put them here. You can see it here http://www.airfox.com.br/modules/news/article.php?storyid=7 Roberto Brito Zodiac XL601 Plans Jabiru 3300 Woodcomp SR 3000 prop. Enigma. S=E3o Paulo-Brazil... ________________________________________________________________________________
Date: Jan 28, 2007
Subject: Re: NOT wing flutter!
Andy, thanks for the input and I don't doubt your a ton smart on the subject. Still I saw what I saw, heard what I heard, and felt what I felt. I have flown enough to have seen a few wings bend in bumps. Even put a wrinkle in a Warrior wing once, but that's another story. If you extend your arm straight out to your side and move the end of your fingers up and down about 2 -3 inches as fast as you can until they blur and hum very loud as you do this you can recreate what I saw and heard. Some scientist I am ? Oh, well. I knew I was in trouble when it did not change sound when I cut power. That's when I rolled over to dive away and it ended somewhere in the roll and dive. I will recheck everything and cable stretch as well. Thanks again, Best regards, Bill ________________________________________________________________________________
Date: Jan 28, 2007
Jennifer- I've been told by CFIs who do a lot of "Test piloting" for homebuilts that the closest certificated match to a 601 is a 108hp Grumman 2 place trainer. I think it's an AA-2, but don't quote me on that- you can find out easy enough on-line. Bill Naumuk HDS Fuselage Townville, Pa ----- Original Message ----- From: Jennifer Moorhouse To: zenith-list(at)matronics.com Sent: Sunday, January 28, 2007 5:41 AM Subject: Zenith-List: Choice of planes to fly to prepare for Zodiac. I usually fly a Cessna 152, the old shetland pony of the aircraft world. I haven't even been up in a Zenith anything yet, but am building a 601XL, currently the tail pieces until funds are a bit more free to dedicate to the rest of it. Until it's done, I want to prepare by flying something more similar to it than the Cessna. I have started transitioning to a Diamond Katana. I've flown one before, but it's been a couple of years. I just went up again yesterday in the composite beast. It was miserable to handle on the ground, pulling hard to the right, taxiing like a drunk three legged mule. I wonder if that's normal, because of the free castering nosewheel and the nice crosswind, 10kts, or if it's just that particular airplane. Maybe something is out of whack. There's not much rudder, and diff braking has to be used a lot on the ground. How does the Zodie compare? Do any of you also fly Katanas? The thing was squirrelly to take off and land. I couldn't keep it on centerline to save my soul. I'll get it, but I'll need to fly with the cfi again. The only other rentals at this particular airport are 172s. I could go to another airport, but don't know of anything more similar to the Zodiac that's available for training or rental. I've been happy putting about in the 152. I was wondering, long term am I going to be happy in a lighter weight airplane? The Katana is heavier than the 152 and the Zodiac is lighter. I was wondering if I can get happy with the Katana, is it good preparation for the Zodiac? ------------------------------------------------------------------------- ----- --> http://forums.matronics.com =========== ________________________________________________________________________________
Date: Jan 28, 2007
Jennifer, Tell us where you are located. There might be a Zodiac close enough to fly. R/ Brandon Any questions? Get answers on any topic at www.Answers.yahoo.com. Try it now. ________________________________________________________________________________
Date: Jan 28, 2007
Subject: RE: Fw: The Special Zodiac first flight
Roberto, Nice looking plane. Please keep us updated on performance. I suspect your canopy / turtledeck modification will yield very nice performance numbers paired with Jab power. Very nice job. VR/ Brandon 601 HDS / TD / Corvair 56 hours Be a PS3 game guru. Get your game face on with the latest PS3 news and previews at Yahoo! Games. http://videogames.yahoo.com/platform?platform=120121 ________________________________________________________________________________
Date: Jan 28, 2007
All- Since I was responsible for the observation of Dutch Roll in the YouTube clip refered to here, let me make a public retraction. Other YouTube clips have shown smoothly flown 601 landing patterns. It seems the "Twitchiness" I observed was due to PIO, and is not to be confused with the no BS Dutch Roll inherent in an A36 Bonanza. Bill Naumuk HDS Fuselage Townville, Pa ----- Original Message ----- From: "PatrickW" <pwhoyt(at)yahoo.com> Sent: Sunday, January 28, 2007 1:44 AM Subject: Zenith-List: Re: 601XL Wing Flutter > > Sheesh. I gotta chime in here... > > This is normal and has nothing to do with "flutter". I'd file this one > right along side all the "twitchy" nonsense that was going around a few > months ago. > > The guy hit a strong thermal due to rising heat off the steam stacks. > Simple as that. I see this regularly in my Piper Warrior. > > The downwind 45 entry to my home airport runs right over the top of an oil > refinery. Lots of heat. Always enough to bump you as you go over, and > once it was enough to put me nearly on my side. > > You have to expect that sort of thing when flying over a large heat > source. > > Regarding the wings bouncing - watch the normal flex of your wings (or > look out the window next time you're on an airliner). Push & pull on that > thing in your hands and watch what your wings do... > > Suggestion: go back and fly over that power plant again. Go high and > slow, watch your altimeter, and expect some bumps. It won't be so bad now > that you can anticipate what's going to happen. Seriously, give this a > shot. > > - Patrick > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=90989#90989 > > > ________________________________________________________________________________
Subject: Fuse side skins
Date: Jan 28, 2007
All- I've decided to shit-can my kinked .016 fuse side skins and make new .025 skins. Can I do away with the gussets intended for use with .016? Bill Naumuk HDS Fuselage Townville, Pa ________________________________________________________________________________
Date: Jan 28, 2007
I was lucky enough to fly a 601XL a couple of weeks back. The aircraft belongs to Pete Andersen and in located at Hillsboro, Oregon. The workmanship on the airplane is great and everything looked straight. Roll control is stiff (but not excessive) and pitch is sensitive. I own a Cassutt racer that is not as pitch sensitive as the XL ( however roll is EXTREMELY quick! :-) ). Now a friend owns a Lansair 235 that is MUCH more pitch sensitive than the XL. I did not operate the XL in slow flight mode but watching the control inputs while landing it appears to handle much like a trainer. My only concern for a low time pilot would be overcontrolling the aircraft in the pitch axes. As long as you could keep a relaxed hand on the stick that wouldn't be a problem. Having said this the XL trims out nicely for hands off stable flight! I hope this helps! Bob Johnson in Oregon ________________________________________________________________________________
Date: Jan 28, 2007
I fly a Piper Cherokee 140 rental. I find the characteristics are closer to the Zodiac XL than the 152. I am lucky enough to be near a Zodiac at a local training school. I go up in it as much as possible. If you can find one within reach, go spend some time in it. It's a real pleasure to fly!!! Brad DeMeo Zodiac XL 80% done. ________________________________________________________________________________
Date: Jan 28, 2007
Subject: VGs feathers
JG I got the feathers you sent. Thank you!! I took the old VGs off and put the feathers on last night. All I need now is a nice day. We have been having snow storm after snow storm lately. So far this winter we have received 250" of snow. Thus is life in the snow capital of the world. Flight test results soon. Bill Wilcox N801BW Valdez, Alaska 280 hrs Waiting for a nice day ________________________________________________________________________________
Subject: Re: Fw: The Special Zodiac first flight
Date: Jan 28, 2007
Roberto- Congrats on a beautiful XL and a great flight. Hope you have many more just as satisfying. Al Young XL ----- Original Message ----- From: Roberto Ap. Rodrigues de Brito To: zenith-list(at)matronics.com Sent: Sunday, January 28, 2007 9:35 AM Subject: Zenith-List: Fw: The Special Zodiac first flight Hi Folks, After almost 3,000 working hours, my "Zodiac XL 601" has finally been flown. It was gorgeous. Thus far I don't have the technical data , but when i do, I'll put them here. You can see it here http://www.airfox.com.br/modules/news/article.php?storyid=7 Roberto Brito Zodiac XL601 Plans Jabiru 3300 Woodcomp SR 3000 prop. Enigma. S=E3o Paulo-Brazil... ________________________________________________________________________________
Subject: 701 builders top skin measurements
Date: Jan 28, 2007
From: "Ashcraft, Keith -AES" <Keith.Ashcraft(at)itt.com>
All 701 builders, Quick question, I have Edition #4, 6th printing 02/2002. Part 7F2-1 (Top Skin) on the aft end shows two measurements for the tail end. I have a Centerline measurement of 62.5mm, but it also shows an overall measurement of 135mm. What does the kit have, or what is the measurement of somebody's later set of plans? I have already cut to 125mm before I noticed the second measurement, but if it is 135mm, I will build a doubler plate to fit in the aft end of the Top Skin. Thanks for all of your support on this list. Keith CH701 ------- scratch -- still cutting out parts Sidewinder -- scratch -- 8% Teenie Two -- scratch -- wooden forms N 38.9947 W 105.1305 Alt. 9,100' ************************************ This e-mail and any files transmitted with it are proprietary and intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the sender. Please note that any views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of ITT, Inc. The recipient should check this e-mail and any attachments for the presence of viruses. ITT accepts no liability for any damage caused by any virus transmitted by this e-mail. ************************************ ________________________________________________________________________________
Date: Jan 28, 2007
Keith My plans show 67.5 cl, overall 135 Roger Kenmore, WA CH701 -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Ashcraft, Keith -AES Sent: Sunday, January 28, 2007 2:33 PM Subject: Zenith-List: 701 builders top skin measurements All 701 builders, Quick question, I have Edition #4, 6th printing 02/2002. Part 7F2-1 (Top Skin) on the aft end shows two measurements for the tail end. I have a Centerline measurement of 62.5mm, but it also shows an overall measurement of 135mm. What does the kit have, or what is the measurement of somebody's later set of plans? I have already cut to 125mm before I noticed the second measurement, but if it is 135mm, I will build a doubler plate to fit in the aft end of the Top Skin. Thanks for all of your support on this list. Keith CH701 ------- scratch -- still cutting out parts Sidewinder -- scratch -- 8% Teenie Two -- scratch -- wooden forms N 38.9947 W 105.1305 Alt. 9,100' ************************************ This e-mail and any files transmitted with it are proprietary and intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the sender. Please note that any views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of ITT, Inc. The recipient should check this e-mail and any attachments for the presence of viruses. ITT accepts no liability for any damage caused by any virus transmitted by this e-mail. ************************************ ________________________________________________________________________________
Date: Jan 28, 2007
Thanks Roger, I guess I will build a doubler that has to correct dims on it!! Thanks again. Keith ************************************************************************* ** -----Original Message----- From: owner-zenith-list-server(at)matronics.com on behalf of Roger Venables Sent: Sun 1/28/2007 4:18 PM Subject: RE: Zenith-List: 701 builders top skin measurements Keith My plans show 67.5 cl, overall 135 Roger Kenmore, WA CH701 -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Ashcraft, Keith -AES Sent: Sunday, January 28, 2007 2:33 PM Subject: Zenith-List: 701 builders top skin measurements All 701 builders, Quick question, I have Edition #4, 6th printing 02/2002. Part 7F2-1 (Top Skin) on the aft end shows two measurements for the tail end. I have a Centerline measurement of 62.5mm, but it also shows an overall measurement of 135mm. What does the kit have, or what is the measurement of somebody's later set of plans? I have already cut to 125mm before I noticed the second measurement, but if it is 135mm, I will build a doubler plate to fit in the aft end of the Top Skin. Thanks for all of your support on this list. Keith CH701 ------- scratch -- still cutting out parts Sidewinder -- scratch -- 8% Teenie Two -- scratch -- wooden forms N 38.9947 W 105.1305 Alt. 9,100' ************************************ This e-mail and any files transmitted with it are proprietary and intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the sender. Please note that any views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of ITT, Inc. The recipient should check this e-mail and any attachments for the presence of viruses. ITT accepts no liability for any damage caused by any virus transmitted by this e-mail. ************************************ ************************************ This e-mail and any files transmitted with it are proprietary and intende d solely for the use of the individual or entity to whom they are addressed. If yo u have received this e-mail in error please notify the sender. Please note that any views or opinions presented in this e-mail are solely those of the author and d o not necessarily represent those of ITT, Inc. The recipient should check this e-mail and any attachments for the presence of viruses. ITT accepts no liability for any damage caused by any virus transmitted by this e-mai l. ************************************ ________________________________________________________________________________
Subject: Builder support for the 601HD or HDS
Date: Jan 28, 2007
Yes, and if you try and match an earlier stab to a later model XL fuselage that presents a few glitches. (Which as I am lead to believe can be overcome!!) Ron >Actually the XL may be the worse choice in terms of future parts >availability. That is because the XL is still evolving. I can't order many >parts for my vintage 2000 XL kit from Zenith because the plans have >changes. >The instrument panel has moved, the bulkheads have changed shape, etc. That >is why lately I've been acting more like a scratch builder than a kit >builder. > >-- Craig > > _________________________________________________________________ Your Space. Your Friends. Your Stories. Share your world with Windows Live Spaces. http://discoverspaces.live.com/?loc=en-CA ________________________________________________________________________________
Date: Jan 28, 2007
Jennifer, I agree with Bryan Martin but I offer another possibility. I flew 10 hours and 100 landings in an Evector SportStar that was for rent locally. I was able to fly it to my home airport for the extensive pattern work (including simulated engine out in the pattern, landing on the adjacent grass field) and I feel it was a good choice. Roger at Zenith suggested getting time in something light with quicker responses than "Wichita Spam Cans". The Sportstar is Rotax powered with split flaps but it is very similar to the XL. Attached is a nose to nose comparison pic I took of the Sportstar and my XL before its first flight in November. My inspector is also an EAA flight advisor and he agreed the Sportstar is a good choice. I still went to Mexico and flew with Roger in the factory XL one last time before I flew. I don't know how I could have been more prepared. First flight was uneventful. The 601XL is a very nice flying plane and if you can confidently fly a Cessna 150/152, you'll have no problem - except getting the smile off your face! Good Luck! Tim Garrett N360TM 601XL + Jabiru 3300 10 hours - in flight testing... ________________________________________________________________________________
Date: Jan 28, 2007
I made the same mistake on the spar web but because I worked so close I just stacked the spar caps and angles to the opposite side. If it is just the wing tip then like Dave says it probably won't make any difference. Here is the link to my mistake: or -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=91188#91188 ________________________________________________________________________________
Date: Jan 28, 2007
I can second the recommendation for the SportStar. I did half my training in one and soloed in one at St Charles Flying Service outside of St. Louis. Training in SportStars is a little more available than in XLs: Washington state, California (north, middle and south), Colorado, Minnesota, Missouri, Indiana, Kentucky, Virginia, North Carolina and Pennsylvania. See <http://www.evektoramerica.com/wheretofly.html> http://www.evektoramerica.com/wheretofly.html for details. -- Craig ________________________________________________________________________________
Date: Jan 28, 2007
From: Keystone Engineering LLC <keystone(at)gci.net>
Subject: Re: VGs feathers on an 801
Hi I got about 30 minutes of weather good enough to fly this afternoon. The leading edge slats are off and the feather VGs are on. It seemed to want to climb like a home sick angel. I was light (1600 lbs), 30 gallons of fuel and 230 pounds of me with nothing else. I saw 900 FPM at 80 MPH. Density CG issues. Before After Cruise 103 MPH 111 MPH both adjusted to 4500' standard temp at 85% power 10.5 GPH leaned to 150 ROP No flaps stall None Buffet at 58, stall 50 indicated and GPS Full flaps stall None I assumed 38 45 indicated 49 GPS (only done once) Approach speed 50 58 Take off run Very short Much longer 250' 350' Landing distance: the breaking action was poor so I did not measure. I need to fly more in this configuration. The fog moved in and I was going to bust FARs so I landed. It is weird flying a plane that will actually stall! I think it may be a better plane to teach the kids to fly. They would learn what stalls feels like. The flaperons are effective even in the stall. The VG spacing for the outboard 3' is at 60 MM and the rest are at 90 mm spacing. I may change the spacing to 60 MM for the length of the "aileron". This hopefully will still give aileron control and inner part of wing stalling first but still lower speeds. Bill Wilcox N801BW Valdez, Alaska 280 hrs Waiting for a flying day. Going to replace the VGs on the tail with more, smaller VGs with less angle. ----- Original Message ----- From: "Bill Wilcox" <keystone(at)gci.net> Cc: ; Sent: Sunday, January 28, 2007 11:31 AM Subject: VGs feathers > JG > > I got the feathers you sent. Thank you!! > > I took the old VGs off and put the feathers on last night. All I need now > is a nice day. > > We have been having snow storm after snow storm lately. So far this > winter we have received 250" of snow. Thus is life in the snow capital of > the world. > > Flight test results soon. > > Bill Wilcox > N801BW > Valdez, Alaska > 280 hrs > Waiting for a nice day > ________________________________________________________________________________
Date: Jan 29, 2007
Subject: Re: Choice of planes to prepare for Zodiac
Excelent topic. I vote for the Grumman AA-1 series because of its superficial resemblence to a 601XL and its inferior numbers. I admit that I have not flown it however. Consider the following: AA-1 has three feet less wing, half again more wing loading,(XL=about 10, AA-1 15 to 15.5) and higher power loading. If you can fly that ground loving pig, you should have no problem with an XL with its nose wheel steering. I have flown about 45 types since 1957 and vote for the Comanche 250 as the hardest to land and still look good, Mooney Mk-21 next. I also owned a BE-23 and Luscombe 8A. Both do not deserve their bad reps and if you can find one, they will be good practice also. Get with a sadistic instructor in any of these, and a 601XL should be a walk in the park. Bob Dingley Pace,FL 601XL rud & mtr mt.(Lyc and prop from an AA-1B) ________________________________________________________________________________
Subject: Amount of paint Required
Date: Jan 29, 2007
Hi All Listers. I have now come to the point where painting is required: Does anyone have an idea of the amount of paint required to paint a 601XL How much (average) undercoat is required, and how much final colour is required? Assuming one colour all over. Your help would be greatly appreciated. Thnx Jonathan Starke 912S 65+ hrs and enjoying evry minute. ________________________________________________________________________________
Date: Jan 29, 2007
Subject: Canopy
Just bought a CH601HDS and absolutely love it, though I need to find an instructor in the Tampa area to train me up as a private pilot or at a minimum sport pilot I believe. Unfortunately, I did a stupid thing and cracked the canopy - an expensive mistake from what I understand.. Anyone have thoughts on where to get a new tinted canopy? Thanks in advance for your help, Tim ________________________________________________________________________________
Subject: Re: Canopy
Date: Jan 29, 2007
Give Todd Silver a call at www.toddscanopies.com a call. He does great work and very affordable. Trev Page C-IDUS 601HD R912 On Jan 29, 2007, at 5:36 AM, Timothy Croy wrote: > Just bought a CH601HDS and absolutely love it, though I need to > find an instructor in the Tampa area to train me up as a private > pilot or at a minimum sport pilot I believe. > > Unfortunately, I did a stupid thing and cracked the canopy - an > expensive mistake from what I understand.. Anyone have thoughts on > where to get a new tinted canopy? > > Thanks in advance for your help, > Tim > > ________________________________________________________________________________
Date: Jan 29, 2007
Jennifer -- I own and fly a 601XL and I've been checked out in and frequently rented the next evolution of the Katana, the DA-20. I moved into the 601 from a Grumman Cheetah and there was practically no "transition." A Grumman, being heavier, gives a tiny bit smoother ride in gusty winds, but that's being picky. The difference in avionics was a bigger step than the difference in airframe -- by far! A Grumman, like the 601, has great visibility. My Cheetah had almost exactly the same performance as my 601... although the 601 has both less payload and significantly less gas consumption. A Grumman Tiger (with 35 more HP than a Cheetah) will have a much better payload and a little better speed than most 601s (with a LOT more gas consumption). The stock Grumman AA1A Yankee ... the earliest version.. probably has poorer performance than any 601, but many Yankees were up-engined. The Grumman has free castering nose wheel. Someone commented that they wished they had that in a 601. Personally, I like the nose wheel steering better than free castering, but your problems on taxi with the Katana seem unique. I'd bet on a low tire or a bent corroded axle. Look hard at the landing gear next time you fly the Diamond. Can you check the tire pressures? I do miss the sliding canopy of the Grumman! It was so nice to be able to slide back that canopy! Look around the field for a Grumman and try to get a ride. Grumman pilots are a friendly bunch. Failing that, just fly all of the single engine rental airplanes you can get your hands on. The similarities will soon be more important than the differences. -- Frank Derfler See my views and reviews at www.derfler.biz See my information for pilots at www.flyinflorida.com ________________________________________________________________________________
Subject: Re: 701 builders top skin measurements
Date: Jan 29, 2007
Hello Keith, I checked on the Zenith website for 701 updates. There appears to have been an error in the drawings and it was corrected in the update notice. The CL measurement for that station is 67.5, not 62.5. Total width should be 135mm. The update notice is entitled: "Updates 5th" dated 5/03. My drawings dated 09/2003 reflect this length. Tommy Walker in Alabama Do Archive ________________________________________________________________________________
Date: Jan 29, 2007
Subject: Re: Canopy
HI Trevor, I believe we met at ZPH over the weekend. I recommend since Flight Crafters is right across the street where you parked the plane, I would start there, they are the east coast distributor for the zenith line, and could guide you on how to install it. Besides the ouch, the plane is a beautifull rendition of the HDS, nice plane! Russ's number at flight crafters is 813-690-1916. Juan Vega -----Original Message----- >From: Trevor Page <webmaster(at)upac.ca> >Sent: Jan 29, 2007 6:59 AM >To: zenith-list(at)matronics.com >Subject: Re: Zenith-List: Canopy > >Give Todd Silver a call at www.toddscanopies.com a call. He does >great work and very affordable. > >Trev Page >C-IDUS 601HD R912 > > >On Jan 29, 2007, at 5:36 AM, Timothy Croy wrote: > >> Just bought a CH601HDS and absolutely love it, though I need to >> find an instructor in the Tampa area to train me up as a private >> pilot or at a minimum sport pilot I believe. >> >> Unfortunately, I did a stupid thing and cracked the canopy - an >> expensive mistake from what I understand.. Anyone have thoughts on >> where to get a new tinted canopy? >> >> Thanks in advance for your help, >> Tim >> >> >> > ________________________________________________________________________________
Date: Jan 29, 2007
Subject: Re: Amount of paint Required
Per my last two quote for Endura Paint, two quarts of paint base, and two quarts of hardener. ONe gallon total depending on the touch and hand that sprays it. It adds approximately 18 to 20 lbs to over all weight. That is base primer, base paint and either clear coat or hardener. -----Original Message----- >From: Jonathan Starke <jonathan(at)entry.co.za> >Sent: Jan 29, 2007 1:43 AM >To: zenith-list(at)matronics.com >Subject: Zenith-List: Amount of paint Required > >Hi All Listers. > >I have now come to the point where painting is required: > >Does anyone have an idea of the amount of paint required to paint a 601XL > >How much (average) undercoat is required, and how much final colour is required? >Assuming one colour all over. > >Your help would be greatly appreciated. > >Thnx >Jonathan Starke >912S >65+ hrs and enjoying evry minute. > ________________________________________________________________________________
Date: Jan 29, 2007
Hi Jonathan, I just painted my 601HDS taking from April to November of 2006. Paint stock was 1-1/2 gallons primer, 2 gallons of base coat and 1 gallon of trim color. I primed and stripped the tail feathers twice before getting it right. The actual weight of the plane after reassembly increased 13 pounds for paint and 2 lbs for a main gear plate upgrade. Of course, a lot depends on what kind of paint you intend to use as well. I went with a waterborne catalyst-urethane from Aircraft Finishing Systems, (now Hangar21 AFS). I have a paint page on my website that may help you get the job done. Lots of pictures from booth to handling, breathing gear, paint setups for parts to finish. http://www.macsmachine.com/images/paint/full/601ezfrontleftqtr.gif Good luck, Larry McFarland - 601HDS at www.macsmachine.com Jonathan Starke wrote: > Hi All Listers. > > I have now come to the point where painting is required: > > *Does anyone have an idea of the amount of paint required to paint a > 601XL* > ** > *How much (average) undercoat is required, and how much final colour > is required? Assuming one colour all over.* > ** > *Your help would be greatly appreciated.* > ** > *Thnx* > *Jonathan Starke* > *912S* > *65+ hrs and enjoying evry minute.* > ** ________________________________________________________________________________
Date: Jan 29, 2007
Subject: Re: Wing flutter!
Tim, I heard the roar/ryrthem, felt the hard vibration, left hand went to the throttle, looked to the left, saw the wing "fluttering" about 2-3 inches up and down to a blur in unison with the roar and vibration, yelled " OH SHIT !, looked back at the speed indicator, read 142 mph, pulled throttle back and nose up for a split second, no change to roar and vibration, banked hard left and dove mostly inverted, somewhere in roll and dive roar and vibration ended, pulled out, leveled off at about 170 mph, slow to about 100 mph, creep easy back to field. The whole thing from beginning of roar to end may have been 5-6 seconds. Things can move pretty fast when scared. Lesson learned, stay away, way, way from power plants, Best regards, Bill of Georgia 103 XL hours, 90 flights ________________________________________________________________________________
Date: Jan 29, 2007
Good article about flying trough turbulence by Mr. Machado: Rgds Martin -------- Martin Pohl Zodiac XL QBK 8645 Jona, Switzerland www.pohltec.ch/ZodiacXL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=91358#91358 ________________________________________________________________________________
Date: Jan 30, 2007
Gday Bill, Well, that's interesting...... Yeh, one of the first things you do notice from removing slats is the increase in climb - all that power (about 23% measured on the Savannah) that was used to overcome the drag is now available for climb. A bit disappointed in the stall characteristics tho - our 701's and Savannahs just get back to a high descent mush, much like with the slats. What's the position of your Feathers now?? It sounds like they could be better even farther forward - I'd try them at 7%. Wishing you some good weather for further experimenting. Here we have lots of 37*C (99*F) weather to spare, but even if we could send some of it to you, I guess it would be a mess on top of 20 ft of snow....... JG ----- Original Message ----- From: "Keystone Engineering LLC" <keystone(at)gci.net> Sent: Monday, January 29, 2007 4:54 PM Subject: Zenith-List: Re: VGs feathers on an 801 > > > Hi > > I got about 30 minutes of weather good enough to fly this afternoon. The > leading edge slats are off and the feather VGs are on. It seemed to want > to climb like a home sick angel. I was light (1600 lbs), 30 gallons of > fuel and 230 pounds of me with nothing else. I saw 900 FPM at 80 MPH. > notice any CG issues. > > Before After > Cruise 103 MPH 111 MPH both > adjusted to 4500' standard temp at 85% power 10.5 GPH leaned to 150 ROP > No flaps stall None Buffet at 58, > stall 50 indicated and GPS > Full flaps stall None I assumed 38 45 indicated 49 GPS > (only done once) > Approach speed 50 58 > Take off run Very short Much longer > 250' 350' > Landing distance: the breaking action was poor so I did not measure. > > I need to fly more in this configuration. The fog moved in and I was > going to bust FARs so I landed. > > It is weird flying a plane that will actually stall! I think it may be a > better plane to teach the kids to fly. They would learn what stalls feels > like. The flaperons are effective even in the stall. > > The VG spacing for the outboard 3' is at 60 MM and the rest are at 90 mm > spacing. I may change the spacing to 60 MM for the length of the > "aileron". This hopefully will still give aileron control and inner part > of wing stalling first but still lower speeds. > > Bill Wilcox > N801BW > Valdez, Alaska > 280 hrs > Waiting for a flying day. Going to replace the VGs on the tail with more, > smaller VGs with less angle. > > > ----- Original Message ----- > From: "Bill Wilcox" <keystone(at)gci.net> > To: > Cc: ; > Sent: Sunday, January 28, 2007 11:31 AM > Subject: VGs feathers > > >> JG >> >> I got the feathers you sent. Thank you!! >> >> I took the old VGs off and put the feathers on last night. All I need >> now is a nice day. >> >> We have been having snow storm after snow storm lately. So far this >> winter we have received 250" of snow. Thus is life in the snow capital >> of the world. >> >> Flight test results soon. >> >> Bill Wilcox >> N801BW >> Valdez, Alaska >> 280 hrs >> Waiting for a nice day >> > > > ________________________________________________________________________________
Subject: Feathers vgs on 801
Date: Jan 29, 2007
On my 701 I moved the vgs 3 times before I found the right spot(8%). I tried 12%, 10% and finally 8%. The difference small position changes made was big. Joe ________________________________________________________________________________
Date: Jan 29, 2007
Subject: Re: Canopy
Thanks, I will check in to these. Appreciate the help, Tim On 1/29/07, Juan Vega wrote: > > > HI Trevor, I believe we met at ZPH over the weekend. I recommend since > Flight Crafters is right across the street where you parked the plane, I > would start there, they are the east coast distributor for the zenith line, > and could guide you on how to install it. Besides the ouch, the plane is a > beautifull rendition of the HDS, nice plane! > Russ's number at flight crafters is 813-690-1916. > > > Juan Vega > > -----Original Message----- > >From: Trevor Page <webmaster(at)upac.ca> > >Sent: Jan 29, 2007 6:59 AM > >To: zenith-list(at)matronics.com > >Subject: Re: Zenith-List: Canopy > > > >Give Todd Silver a call at www.toddscanopies.com a call. He does > >great work and very affordable. > > > >Trev Page > >C-IDUS 601HD R912 > > > > > >On Jan 29, 2007, at 5:36 AM, Timothy Croy wrote: > > > >> Just bought a CH601HDS and absolutely love it, though I need to > >> find an instructor in the Tampa area to train me up as a private > >> pilot or at a minimum sport pilot I believe. > >> > >> Unfortunately, I did a stupid thing and cracked the canopy - an > >> expensive mistake from what I understand.. Anyone have thoughts on > >> where to get a new tinted canopy? > >> > >> Thanks in advance for your help, > >> Tim > >> > >> > >> > > > > ________________________________________________________________________________
Date: Jan 29, 2007
Subject: Landing Light Kit Assembly Grief
I experienced a lot of grief trying to hold together the %$@#*! landing light assembly while getting it fastened to the channel in the left wing. Every time I tried to get the bolts through the face plate and the backing plate and get the bushings and springs on and then put the darn thing up to the channel the assembly would lean and mush and the springs would fall off the bolts and boing away and the face plate would loosen and fall off and my blood pressure would rise rapidly and family would look at me in shock after a few choice words...So...I have learned a trick that works well for mounting the lights onto the channel. After drilling all holes and making the notch in the backing plates per the plans, proceed as follows: First, stand all four bolts upside down on a work bench. Second, feed the face plate over the bolts. Third, slide the bushings (11 mm each) onto the bolts. Fourth, place light in the circle of face plate with filament of bulb vertical (a hard landing will break the filament if horizontal). Fifth, place the backing plate over the bolts and over the back of the light. Then, go to Ace Hardware and purchase 8 pin clips (Servalite PC9...4 per light assembly, one for each bolt). Sixth, slide pin clips onto bolts at backing plate to hold the light assembly firm. Seventh, place springs over bolts and carefully raise the light assembly to the channel inside the wing and tighten the screws as desired/needed to focus the lights. The pin clips will save a lot of agony over trying to get the loose assembly up to the channel for final assembly. The pin clips are metal and will handle the heat near the lamp. After a dozen tries without pin clips, my first attempt with pin clips was successful and complete in less than 5 minutes! Brad DeMeo ________________________________________________________________________________
Date: Jan 30, 2007
Like I said. I'm glad you came out of it OK. And I hate Monday morning quaterbacking but I don't think at a point where the structure of the aircraft is in question that the best idea is to spead up to within 10 MPH of the VNE of the aircraft. That said have you looked at the attachement points yet? Is there any visible damage? -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=91678#91678 ________________________________________________________________________________
Date: Jan 30, 2007
Subject: VGs feathers on an 801
Hi I moved the feathers VGs about an inch farther forward. The chord is 57". The front of the VG is at 3" and the back is at 4" behind the leading edge of the wing (along the chord). 3.4" is 6% of the chord. I also installed more Vgs. I continued the 60 mm spacing to the second leading edge slat bracked from the wing tip. The rest of the wing is on a 90 mm spacing. The density altitude was -2500' at take off. I was light about 1600 lbs. Again it climbed like a home sick angle. I was getting 800-900 FPM at 80 mph. The stall speed are the same as they were in my report on Monday. Flaps up 50 Flaps down 45 The flaperons were effective even when the wing is stalled. I may move them to 5% or I may change the VGs on the tail to see if that changes anything. Any suggestions? Bill Wilcox N801BW Valdez, Alaska 280 hrs Slats still off Doing some head scratching, trying to figure out what to do next. From: "JG" <vgstol(at)bigpond.net.au> Subject: Re: Zenith-List: Re: VGs feathers on an 801 Gday Bill, Well, that's interesting...... Yeh, one of the first things you do notice from removing slats is the increase in climb - all that power (about 23% measured on the Savannah) that was used to overcome the drag is now available for climb. A bit disappointed in the stall characteristics tho - our 701's and Savannahs just get back to a high descent mush, much like with the slats. What's the position of your Feathers now?? It sounds like they could be better even farther forward - I'd try them at 7%. Wishing you some good weather for further experimenting. Here we have lots of 37*C (99*F) weather to spare, but even if we could send some of it to you, I guess it would be a mess on top of 20 ft of snow....... JG ----- Original Message ----- From: "Keystone Engineering LLC" <keystone(at)gci.net> Sent: Monday, January 29, 2007 4:54 PM Subject: Zenith-List: Re: VGs feathers on an 801 > > > Hi > > I got about 30 minutes of weather good enough to fly this afternoon. The > leading edge slats are off and the feather VGs are on. It seemed to want > to climb like a home sick angel. I was light (1600 lbs), 30 gallons of > fuel and 230 pounds of me with nothing else. I saw 900 FPM at 80 MPH. > notice any CG issues. > > Before After > Cruise 103 MPH 111 MPH both > adjusted to 4500' standard temp at 85% power 10.5 GPH leaned to 150 ROP > No flaps stall None Buffet at 58, > stall 50 indicated and GPS > Full flaps stall None I assumed 38 45 indicated 49 GPS > (only done once) > Approach speed 50 58 > Take off run Very short Much longer > 250' 350' > Landing distance: the breaking action was poor so I did not measure. > > I need to fly more in this configuration. The fog moved in and I was > going to bust FARs so I landed. > > It is weird flying a plane that will actually stall! I think it may be a > better plane to teach the kids to fly. They would learn what stalls feels > like. The flaperons are effective even in the stall. > > The VG spacing for the outboard 3' is at 60 MM and the rest are at 90 mm > spacing. I may change the spacing to 60 MM for the length of the > "aileron". This hopefully will still give aileron control and inner part > of wing stalling first but still lower speeds. > > Bill Wilcox > N801BW > Valdez, Alaska > 280 hrs > Waiting for a flying day. Going to replace the VGs on the tail with more, > smaller VGs with less angle. > > > ----- Original Message ----- > From: "Bill Wilcox" <keystone(at)gci.net> > To: > Cc: ; > Sent: Sunday, January 28, 2007 11:31 AM > Subject: VGs feathers > > >> JG >> >> I got the feathers you sent. Thank you!! >> >> I took the old VGs off and put the feathers on last night. All I need >> now is a nice day. >> >> We have been having snow storm after snow storm lately. So far this >> winter we have received 250" of snow. Thus is life in the snow capital >> of the world. >> >> Flight test results soon. >> >> Bill Wilcox >> N801BW >> Valdez, Alaska >> 280 hrs >> Waiting for a nice day >> > > > ________________________________________________________________________________
From: "Dave Ruddiman" <pacificpainting(at)comcast.net>
Date: Jan 30, 2007
Bill, I've kind of been keeping up on the slat issue. Does anyone use VG's with slats? Does the slat change the airflow over the wing where the VG's have effect? These are just questions I don't really know anything about. I plan on using my slats anyway, but I'm curious about this issue. Thanks, Dave in Salem - almost done with the wings. ----- Original Message ----- From: Keystone Engineering LLC To: zenith-list(at)matronics.com Sent: Tuesday, January 30, 2007 2:23 PM Subject: Zenith-List: VGs feathers on an 801 Hi I moved the feathers VGs about an inch farther forward. The chord is 57". The front of the VG is at 3" and the back is at 4" behind the leading edge of the wing (along the chord). 3.4" is 6% of the chord. I also installed more Vgs. I continued the 60 mm spacing to the second leading edge slat bracked from the wing tip. The rest of the wing is on a 90 mm spacing. The density altitude was -2500' at take off. I was light about 1600 lbs. Again it climbed like a home sick angle. I was getting 800-900 FPM at 80 mph. The stall speed are the same as they were in my report on Monday. Flaps up 50 Flaps down 45 The flaperons were effective even when the wing is stalled. I may move them to 5% or I may change the VGs on the tail to see if that changes anything. Any suggestions? Bill Wilcox N801BW Valdez, Alaska 280 hrs Slats still off Doing some head scratching, trying to figure out what to do next. From: "JG" <vgstol(at)bigpond.net.au> Subject: Re: Zenith-List: Re: VGs feathers on an 801 Gday Bill, Well, that's interesting...... Yeh, one of the first things you do notice from removing slats is the increase in climb - all that power (about 23% measured on the Savannah) that was used to overcome the drag is now available for climb. A bit disappointed in the stall characteristics tho - our 701's and Savannahs just get back to a high descent mush, much like with the slats. What's the position of your Feathers now?? It sounds like they could be better even farther forward - I'd try them at 7%. Wishing you some good weather for further experimenting. Here we have lots of 37*C (99*F) weather to spare, but even if we could send some of it to you, I guess it would be a mess on top of 20 ft of snow....... JG ----- Original Message ----- From: "Keystone Engineering LLC" <keystone(at)gci.net> Sent: Monday, January 29, 2007 4:54 PM Subject: Zenith-List: Re: VGs feathers on an 801 > > > Hi > > I got about 30 minutes of weather good enough to fly this afternoon. The > leading edge slats are off and the feather VGs are on. It seemed to want > to climb like a home sick angel. I was light (1600 lbs), 30 gallons of > fuel and 230 pounds of me with nothing else. I saw 900 FPM at 80 MPH. did not > notice any CG issues. > > Before After > Cruise 103 MPH 111 MPH both > adjusted to 4500' standard temp at 85% power 10.5 GPH leaned to 150 ROP > No flaps stall None Buffet at 58, > stall 50 indicated and GPS > Full flaps stall None I assumed 38 45 indicated 49 GPS > (only done once) > Approach speed 50 58 > Take off run Very short Much longer > 250' 350' > Landing distance: the breaking action was poor so I did not measure. > > I need to fly more in this configuration. The fog moved in and I was > going to bust FARs so I landed. > > It is weird flying a plane that will actually stall! I think it may be a > better plane to teach the kids to fly. They would learn what stalls feels > like. The flaperons are effective even in the stall. > > The VG spacing for the outboard 3' is at 60 MM and the rest are at 90 mm > spacing. I may change the spacing to 60 MM for the length of the > "aileron". This hopefully will still give aileron control and inner part > of wing stalling first but still lower speeds. > > Bill Wilcox > N801BW > Valdez, Alaska > 280 hrs > Waiting for a flying day. Going to replace the VGs on the tail with more, > smaller VGs with less angle. > > > ----- Original Message ----- > From: "Bill Wilcox" <keystone(at)gci.net> > To: > Cc: ; > Sent: Sunday, January 28, 2007 11:31 AM > Subject: VGs feathers > > >> JG >> >> I got the feathers you sent. Thank you!! >> >> I took the old VGs off and put the feathers on last night. All I need >> now is a nice day. >> >> We have been having snow storm after snow storm lately. So far this >> winter we have received 250" of snow. Thus is life in the snow capital >> of the world. >> >> Flight test results soon. >> >> Bill Wilcox >> N801BW >> Valdez, Alaska >> 280 hrs >> Waiting for a nice day >> > > > ________________________________________________________________________________
Date: Jan 30, 2007
Subject: Wing Flutter
Bill: I don't claim to be an expert on the subject but I do have 22 years of military flying with much of it as a flight engineer on medium transports. I think what you experienced was severe vortexing over the wing tips due to the hot air below the wing caused by the power plant opposed to the relatively cool air above. The extreme vortexing phenomena produced a "hammering effect" on the top of the wing causing it to flutter. I've experienced similar situations during descent and final approach during extremely hot days while flying with the Corps of Engineers in Saudi Arabia. James D. Webber GS-11 Senior Training Specialist Department of Attack Helicopter Training jim.webber(at)eustis.army.mil ________________________________________________________________________________
Date: Jan 31, 2007
Dave, Yeh, I tried the VGs with slats. They make no difference in that situation because the slats already give the accelerated airflow that stays attached at high AoA. The slats do that job well, it's just that they bring a very high drag that stays at all speeds including climb - note Bill's observation about "climbing like an angel" - it's the reduction in drag by removing the slats that gives the improvement. JG ----- Original Message ----- From: Dave Ruddiman To: zenith-list(at)matronics.com Sent: Wednesday, January 31, 2007 9:39 AM Subject: Re: Zenith-List: VGs feathers on an 801 Bill, I've kind of been keeping up on the slat issue. Does anyone use VG's with slats? Does the slat change the airflow over the wing where the VG's have effect? These are just questions I don't really know anything about. I plan on using my slats anyway, but I'm curious about this issue. Thanks, Dave in Salem - almost done with the wings. ----- Original Message ----- From: Keystone Engineering LLC To: zenith-list(at)matronics.com Sent: Tuesday, January 30, 2007 2:23 PM Subject: Zenith-List: VGs feathers on an 801 Hi I moved the feathers VGs about an inch farther forward. The chord is 57". The front of the VG is at 3" and the back is at 4" behind the leading edge of the wing (along the chord). 3.4" is 6% of the chord. I also installed more Vgs. I continued the 60 mm spacing to the second leading edge slat bracked from the wing tip. The rest of the wing is on a 90 mm spacing. The density altitude was -2500' at take off. I was light about 1600 lbs. Again it climbed like a home sick angle. I was getting 800-900 FPM at 80 mph. The stall speed are the same as they were in my report on Monday. Flaps up 50 Flaps down 45 The flaperons were effective even when the wing is stalled. I may move them to 5% or I may change the VGs on the tail to see if that changes anything. Any suggestions? Bill Wilcox N801BW Valdez, Alaska 280 hrs Slats still off Doing some head scratching, trying to figure out what to do next. From: "JG" <vgstol(at)bigpond.net.au> Subject: Re: Zenith-List: Re: VGs feathers on an 801 Gday Bill, Well, that's interesting...... Yeh, one of the first things you do notice from removing slats is the increase in climb - all that power (about 23% measured on the Savannah) that was used to overcome the drag is now available for climb. A bit disappointed in the stall characteristics tho - our 701's and Savannahs just get back to a high descent mush, much like with the slats. What's the position of your Feathers now?? It sounds like they could be better even farther forward - I'd try them at 7%. Wishing you some good weather for further experimenting. Here we have lots of 37*C (99*F) weather to spare, but even if we could send some of it to you, I guess it would be a mess on top of 20 ft of snow....... JG ----- Original Message ----- From: "Keystone Engineering LLC" <keystone(at)gci.net> Sent: Monday, January 29, 2007 4:54 PM Subject: Zenith-List: Re: VGs feathers on an 801 > > > Hi > > I got about 30 minutes of weather good enough to fly this afternoon. The > leading edge slats are off and the feather VGs are on. It seemed to want > to climb like a home sick angel. I was light (1600 lbs), 30 gallons of > fuel and 230 pounds of me with nothing else. I saw 900 FPM at 80 MPH. did not > notice any CG issues. > > Before After > Cruise 103 MPH 111 MPH both > adjusted to 4500' standard temp at 85% power 10.5 GPH leaned to 150 ROP > No flaps stall None Buffet at 58, > stall 50 indicated and GPS > Full flaps stall None I assumed 38 45 indicated 49 GPS > (only done once) > Approach speed 50 58 > Take off run Very short Much longer > 250' 350' > Landing distance: the breaking action was poor so I did not measure. > > I need to fly more in this configuration. The fog moved in and I was > going to bust FARs so I landed. > > It is weird flying a plane that will actually stall! I think it may be a > better plane to teach the kids to fly. They would learn what stalls feels > like. The flaperons are effective even in the stall. > > The VG spacing for the outboard 3' is at 60 MM and the rest are at 90 mm > spacing. I may change the spacing to 60 MM for the length of the > "aileron". This hopefully will still give aileron control and inner part > of wing stalling first but still lower speeds. > > Bill Wilcox > N801BW > Valdez, Alaska > 280 hrs > Waiting for a flying day. Going to replace the VGs on the tail with more, > smaller VGs with less angle. > > > ----- Original Message ----- > From: "Bill Wilcox" <keystone(at)gci.net> > To: > Cc: ; > Sent: Sunday, January 28, 2007 11:31 AM > Subject: VGs feathers > > >> JG >> >> I got the feathers you sent. Thank you!! >> >> I took the old VGs off and put the feathers on last night. All I need >> now is a nice day. >> >> We have been having snow storm after snow storm lately. So far this >> winter we have received 250" of snow. Thus is life in the snow capital >> of the world. >> >> Flight test results soon. >> >> Bill Wilcox >> N801BW >> Valdez, Alaska >> 280 hrs >> Waiting for a nice day >> > > > ________________________________________________________________________________
Date: Jan 30, 2007
THANKS. THAT CLEARS THINGS UP. ----- Original Message ----- From: JG To: zenith-list(at)matronics.com Sent: Tuesday, January 30, 2007 3:00 PM Subject: Re: Zenith-List: VGs feathers on an 801 Dave, Yeh, I tried the VGs with slats. They make no difference in that situation because the slats already give the accelerated airflow that stays attached at high AoA. The slats do that job well, it's just that they bring a very high drag that stays at all speeds including climb - note Bill's observation about "climbing like an angel" - it's the reduction in drag by removing the slats that gives the improvement. JG ----- Original Message ----- From: Dave Ruddiman To: zenith-list(at)matronics.com Sent: Wednesday, January 31, 2007 9:39 AM Subject: Re: Zenith-List: VGs feathers on an 801 Bill, I've kind of been keeping up on the slat issue. Does anyone use VG's with slats? Does the slat change the airflow over the wing where the VG's have effect? These are just questions I don't really know anything about. I plan on using my slats anyway, but I'm curious about this issue. Thanks, Dave in Salem - almost done with the wings. ----- Original Message ----- From: Keystone Engineering LLC To: zenith-list(at)matronics.com Sent: Tuesday, January 30, 2007 2:23 PM Subject: Zenith-List: VGs feathers on an 801 Hi I moved the feathers VGs about an inch farther forward. The chord is 57". The front of the VG is at 3" and the back is at 4" behind the leading edge of the wing (along the chord). 3.4" is 6% of the chord. I also installed more Vgs. I continued the 60 mm spacing to the second leading edge slat bracked from the wing tip. The rest of the wing is on a 90 mm spacing. The density altitude was -2500' at take off. I was light about 1600 lbs. Again it climbed like a home sick angle. I was getting 800-900 FPM at 80 mph. The stall speed are the same as they were in my report on Monday. Flaps up 50 Flaps down 45 The flaperons were effective even when the wing is stalled. I may move them to 5% or I may change the VGs on the tail to see if that changes anything. Any suggestions? Bill Wilcox N801BW Valdez, Alaska 280 hrs Slats still off Doing some head scratching, trying to figure out what to do next. From: "JG" <vgstol(at)bigpond.net.au> Subject: Re: Zenith-List: Re: VGs feathers on an 801 Gday Bill, Well, that's interesting...... Yeh, one of the first things you do notice from removing slats is the increase in climb - all that power (about 23% measured on the Savannah) that was used to overcome the drag is now available for climb. A bit disappointed in the stall characteristics tho - our 701's and Savannahs just get back to a high descent mush, much like with the slats. What's the position of your Feathers now?? It sounds like they could be better even farther forward - I'd try them at 7%. Wishing you some good weather for further experimenting. Here we have lots of 37*C (99*F) weather to spare, but even if we could send some of it to you, I guess it would be a mess on top of 20 ft of snow....... JG ----- Original Message ----- From: "Keystone Engineering LLC" <keystone(at)gci.net> Sent: Monday, January 29, 2007 4:54 PM Subject: Zenith-List: Re: VGs feathers on an 801 > > > Hi > > I got about 30 minutes of weather good enough to fly this afternoon. The > leading edge slats are off and the feather VGs are on. It seemed to want > to climb like a home sick angel. I was light (1600 lbs), 30 gallons of > fuel and 230 pounds of me with nothing else. I saw 900 FPM at 80 MPH. I did not > notice any CG issues. > > Before After > Cruise 103 MPH 111 MPH both > adjusted to 4500' standard temp at 85% power 10.5 GPH leaned to 150 ROP > No flaps stall None Buffet at 58, > stall 50 indicated and GPS > Full flaps stall None I assumed 38 45 indicated 49 GPS > (only done once) > Approach speed 50 58 > Take off run Very short Much longer > 250' 350' > Landing distance: the breaking action was poor so I did not measure. > > I need to fly more in this configuration. The fog moved in and I was > going to bust FARs so I landed. > > It is weird flying a plane that will actually stall! I think it may be a > better plane to teach the kids to fly. They would learn what stalls feels > like. The flaperons are effective even in the stall. > > The VG spacing for the outboard 3' is at 60 MM and the rest are at 90 mm > spacing. I may change the spacing to 60 MM for the length of the > "aileron". This hopefully will still give aileron control and inner part > of wing stalling first but still lower speeds. > > Bill Wilcox > N801BW > Valdez, Alaska > 280 hrs > Waiting for a flying day. Going to replace the VGs on the tail with more, > smaller VGs with less angle. > > > ----- Original Message ----- > From: "Bill Wilcox" <keystone(at)gci.net> > To: > Cc: ; > Sent: Sunday, January 28, 2007 11:31 AM > Subject: VGs feathers > > >> JG >> >> I got the feathers you sent. Thank you!! >> >> I took the old VGs off and put the feathers on last night. All I need >> now is a nice day. >> >> We have been having snow storm after snow storm lately. So far this >> winter we have received 250" of snow. Thus is life in the snow capital >> of the world. >> >> Flight test results soon. >> >> Bill Wilcox >> N801BW >> Valdez, Alaska >> 280 hrs >> Waiting for a nice day >> > > > href="http://www.matronics.com/Navigator?Zenith-List">http://www.matron href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Jan 30, 2007
You were in the wrong place/wrong time...the warm/cold air set-up a perfect (bad) wing frequency harmonic...instead of diving you should have pulled UP...slow...get your bearings...diving to 170MPH?? You should be ???? Glad your OK John -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of djdormer(at)cox.net Sent: Tuesday, January 30, 2007 5:50 PM Subject: Zenith-List: Wing Flutter Bill: I don't claim to be an expert on the subject but I do have 22 years of military flying with much of it as a flight engineer on medium transports. I think what you experienced was severe vortexing over the wing tips due to the hot air below the wing caused by the power plant opposed to the relatively cool air above. The extreme vortexing phenomena produced a "hammering effect" on the top of the wing causing it to flutter. I've experienced similar situations during descent and final approach during extremely hot days while flying with the Corps of Engineers in Saudi Arabia. James D. Webber GS-11 Senior Training Specialist Department of Attack Helicopter Training jim.webber(at)eustis.army.mil ________________________________________________________________________________
Date: Jan 30, 2007
Dave My understanding is "stacking" high lift devices on top of each other does not add significantly to the performance. I plan on putting the slats back on over the VGs. I'm planning on having the take off and landing distances measured in both configurations at the Valdez May Day Fly-in. Bill Bill, I've kind of been keeping up on the slat issue. Does anyone use VG's with slats? Does the slat change the airflow over the wing where the VG's have effect? These are just questions I don't really know anything about. I plan on using my slats anyway, but I'm curious about this issue. Thanks, Dave in Salem - almost done with the wings. ----- Original Message ----- From: Keystone Engineering LLC To: zenith-list(at)matronics.com Sent: Tuesday, January 30, 2007 2:23 PM Subject: VGs feathers on an 801 Hi I moved the feathers VGs about an inch farther forward. The chord is 57". The front of the VG is at 3" and the back is at 4" behind the leading edge of the wing (along the chord). 3.4" is 6% of the chord. I also installed more Vgs. I continued the 60 mm spacing to the second leading edge slat bracked from the wing tip. The rest of the wing is on a 90 mm spacing. The density altitude was -2500' at take off. I was light about 1600 lbs. Again it climbed like a home sick angle. I was getting 800-900 FPM at 80 mph. The stall speed are the same as they were in my report on Monday. Flaps up 50 Flaps down 45 The flaperons were effective even when the wing is stalled. I may move them to 5% or I may change the VGs on the tail to see if that changes anything. Any suggestions? Bill Wilcox N801BW Valdez, Alaska 280 hrs Slats still off Doing some head scratching, trying to figure out what to do next. T ________________________________________________________________________________
Subject: vg feathers on an 801
Date: Jan 30, 2007
Bill, I don't know the 801 wing but my experience on a Legal Eagle and a 701 leads me to suggest that you try 8 %. That works great on both of those wings. It's possible that at 6% the vortex is "flattening out" against the remainder of the leading edge with consequent loss of effectiveness. I tried vgs under the HS of my 701. I lost 2.5 mph and about 10-12% ROC. The only benefit that I could see was a lighter pitch feel but no increased effectiveness. I removed them in favor of the increased performance over a lighter elevator. FWIW Joe ________________________________________________________________________________
Date: Jan 30, 2007
Bill, Be sure and post what your results are for the take off and landings. I'm more interested in those numbers than anything else. I think my plane will be configured similar to yours when I'm finished. I have a picture of you and your plane on the wall in the shop. It's nice to see what the finished product will look like. Keeps me motivated. Dave ----- Original Message ----- From: Keystone Engineering LLC To: zenith-list(at)matronics.com Sent: Tuesday, January 30, 2007 4:56 PM Subject: Zenith-List: VGs feathers on an 801 Dave My understanding is "stacking" high lift devices on top of each other does not add significantly to the performance. I plan on putting the slats back on over the VGs. I'm planning on having the take off and landing distances measured in both configurations at the Valdez May Day Fly-in. Bill Bill, I've kind of been keeping up on the slat issue. Does anyone use VG's with slats? Does the slat change the airflow over the wing where the VG's have effect? These are just questions I don't really know anything about. I plan on using my slats anyway, but I'm curious about this issue. Thanks, Dave in Salem - almost done with the wings. ----- Original Message ----- From: Keystone Engineering LLC To: zenith-list(at)matronics.com Sent: Tuesday, January 30, 2007 2:23 PM Subject: VGs feathers on an 801 Hi I moved the feathers VGs about an inch farther forward. The chord is 57". The front of the VG is at 3" and the back is at 4" behind the leading edge of the wing (along the chord). 3.4" is 6% of the chord. I also installed more Vgs. I continued the 60 mm spacing to the second leading edge slat bracked from the wing tip. The rest of the wing is on a 90 mm spacing. The density altitude was -2500' at take off. I was light about 1600 lbs. Again it climbed like a home sick angle. I was getting 800-900 FPM at 80 mph. The stall speed are the same as they were in my report on Monday. Flaps up 50 Flaps down 45 The flaperons were effective even when the wing is stalled. I may move them to 5% or I may change the VGs on the tail to see if that changes anything. Any suggestions? Bill Wilcox N801BW Valdez, Alaska 280 hrs Slats still off Doing some head scratching, trying to figure out what to do next. T ________________________________________________________________________________
Subject: Re: Wing Flutter
Date: Jan 31, 2007
John, the difference from 142 mph to 170 is 28 mph. How many seconds would your XL at or near gross require to pick up 28 mph in a dive ? I've had my XL to 180ish in a smooth shallow dive amd she seemed to handle well and I'm sure 20 % more would be pushing too far, Best regards, Bill -----Original Message----- From: jrfulp(at)ncia.net Sent: Tue, 30 Jan 2007 7:37 PM Subject: RE: Zenith-List: Wing Flutter You were in the wrong place/wrong time...the warm/cold air set-up a perfect (bad) wing frequency harmonic...instead of diving you should have pulled UP...slow...get your bearings...diving to 170MPH?? You should be ???? Glad your OK John -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of djdormer(at)cox.net Sent: Tuesday, January 30, 2007 5:50 PM Subject: Zenith-List: Wing Flutter Bill: I don't claim to be an expert on the subject but I do have 22 years of military flying with much of it as a flight engineer on medium transports. I think what you experienced was severe vortexing over the wing tips due to the hot air below the wing caused by the power plant opposed to the relatively cool air above. The extreme vortexing phenomena produced a "hammering effect" on the top of the wing causing it to flutter. I've experienced similar situations during descent and final approach during extremely hot days while flying with the Corps of Engineers in Saudi Arabia. James D. Webber GS-11 Senior Training Specialist Department of Attack Helicopter Training jim.webber(at)eustis.army.mil ________________________________________________________________________ ________________________________________________________________________________
Subject: For 701 Builders Only - Update
Date: Jan 31, 2007
The followup video for Building your CH701 REAR FUESLAGE is now available at: http://www.homebuilthelp.com/Forward_Fuselage.htm Can you believe it has a title of: FORWARD FUSELAGE ! Due to the complexity and detail of fitting/rigging the front fuse into the rear, this is a 2 DVD set of 4 hrs duration total time. Builders: Let's get our 701s completed and ready to fly by this summer! ________________________________________________________________________________
Subject: Re: Cleaning aluminum, aerobatics
Date: Jan 31, 2007
Hi, I was searching the archives for a good alternative to cleaning parts before priming (indoors) and found John Bolding's writeup below. So, what is a good, safe cleaner that I can use indoor without risking exposure to carcinogen chemicals and without causing chemical reactions on the aluminum parts? I am currently building my rudder in a corner of my living room which has turned out to be a nice comfortable work place. Am planning on brushing AFS primer/sealer on the contact points and leaving the rest of the surfaces untreated. I am also thinking of soaking the rivet heads in a thinned solution of primer/sealer before riviting. Should I consider using soap and distilled water followed by rubbing alcohol? Thanx...Eddie --------------------------- [quote="John Bolding"]OK guys , I know you should have only one subject per post but I prefer lurking to posting so I like to get it over with in a hurry. Cleaning aluminum: I REALLY hope I don't hurt anyone's feelings here and that is certainly not my intent. Over the yrs I have read hundreds of times on this list and several others that I monitor about wiping down the alum. part with some solvent( MEK, acetone and lacquer thinner being the most common)as the final prep for painting. My career in the paint spray equipment industry for 35 yrs put me in the middle of hundreds of paint film examinations to determine cause of failure. Normally the paint supplier or part washer guy was the lead role in these goat ropings but the equipment guy HAD to show up or he was automatically the cause, kinda like missing a meeting when your EAA Chapter holds elections, you WILL be an office holder if you miss. Some paints are more tolerant than others of a not perfectly clean surface, waterborne materials and powder are the least tolerant (in my limited experience anyway). Solvent is a poor choice for cleaning. Imagine coming in from the shop for lunch and grabbing a can of MEK and a rag and cleaning your greasy hands with it, no water, just a rag wet with solvent. You succeed in getting them to look a little better but you HAVEN'T taken all the dirt/ grease off, just moved it around in smaller concentrations. Follow up with a clean rag and more solvent reduces the concentrations but .... you get the picture. Now if you agitate a surfactant(soap) into the part to be cleaned,(your hands)using water and when you get all the junk floating (paint guys called it "suspended" 'cause they made a lot of money and wanted to impress the customer) and introduce a rinse(LOTS of water to flood the surface) to remove it ,you generally get a squeaky clean surface first rattle out of the box. Repeat as necessary. What I learned from all these dog and pony shows was that the oils you are trying to remove can be effective (with some coatings) down to the molecular level at causing adhesion problems down the road. Ever been at a boat dock and noticed the oil sheen on the water, it's only a few molecules thick. You CAN'T be assured you get it ALL off unless you wash and rinse. Now comes the part where 83 guys that have been painting since before birth tell me that I'm all wet and they never had a problem in wiping down a car with a rag and solvent. Save it, I heard it a thousand times. What impressed ME was the chemist who brought along a BIG microscope to one of these meetings and SHOWED me oil between the substrate and paint film where it had peeled off. Takes a lot of work to build an airplane, prep it properly. LOW&SLOW John Bolding > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=91929#91929 ________________________________________________________________________________
Date: Jan 31, 2007
Eddie- I can see your problem- John's post never takes a stand other than "prep carefully". You might want to narrow your search down by saying what type of paint you intend to use (Enamel, lacquer, etc.) and see if anyone bites. Good building. Bill Naumuk HDS Fuselage Townville, Pa ----- Original Message ----- From: "Eddie G." <silentlight(at)verizon.net> Sent: Wednesday, January 31, 2007 4:55 PM Subject: Zenith-List: Re: Cleaning aluminum, aerobatics > > Hi, > > I was searching the archives for a good alternative to cleaning parts > before priming (indoors) and found John Bolding's writeup below. > > So, what is a good, safe cleaner that I can use indoor without risking > exposure to carcinogen chemicals and without causing chemical reactions on > the aluminum parts? I am currently building my rudder in a corner of my > living room which has turned out to be a nice comfortable work place. Am > planning on brushing AFS primer/sealer on the contact points and leaving > the rest of the surfaces untreated. I am also thinking of soaking the > rivet heads in a thinned solution of primer/sealer before riviting. > > Should I consider using soap and distilled water followed by rubbing > alcohol? > > > Thanx...Eddie > > --------------------------- > > [quote="John Bolding"]OK guys , I know you should have only one subject > per post but I prefer lurking to posting so I like to get it over with in > a hurry. > > Cleaning aluminum: > > I REALLY hope I don't hurt anyone's feelings here and that is certainly > not my intent. > Over the yrs I have read hundreds of times on this list and several > others that I monitor about wiping down the alum. part with some > solvent( MEK, acetone and lacquer thinner being the most common)as the > final prep for painting. > My career in the paint spray equipment industry for 35 yrs put me in the > middle of hundreds of paint film examinations to determine cause of > failure. Normally the paint supplier or part washer guy was the lead role > in these goat ropings but the equipment guy HAD to show up or he was > automatically the cause, kinda like missing a meeting when your EAA > Chapter holds elections, you WILL be an office holder if you miss. > > Some paints are more tolerant than others of a not perfectly clean > surface, waterborne materials and powder are the least tolerant (in my > limited experience anyway). > Solvent is a poor choice for cleaning. > > Imagine coming in from the shop for lunch and grabbing a can of MEK and a > rag and cleaning your greasy hands with it, no water, just a rag wet with > solvent. You succeed in getting them to look a little better but you > HAVEN'T taken all the dirt/ grease off, just moved it around in smaller > concentrations. Follow up with a clean rag and more solvent reduces the > concentrations but .... you get the picture. > Now if you agitate a surfactant(soap) into the part to be cleaned,(your > hands)using water and when you get all the junk floating (paint guys > called it "suspended" 'cause they made a lot of money and wanted to > impress the customer) and introduce a rinse(LOTS of water to flood the > surface) to remove it ,you generally get a squeaky clean surface first > rattle out of the box. Repeat as necessary. > What I learned from all these dog and pony shows was that the oils you > are trying to remove can be effective (with some coatings) down to the > molecular level at causing adhesion problems down the road. Ever been at > a boat dock and noticed the oil sheen on the water, it's only a few > molecules thick. You CAN'T be assured you get it ALL off unless you wash > and rinse. > > Now comes the part where 83 guys that have been painting since before > birth tell me that I'm all wet and they never had a problem in wiping > down a car with a rag and solvent. Save it, I heard it a thousand times. > What impressed ME was the chemist who brought along a BIG microscope to > one of these meetings and SHOWED me oil between the substrate and paint > film where it had peeled off. Takes a lot of work to build an airplane, > prep it properly. > > > LOW&SLOW John Bolding > > >> > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=91929#91929 > > > ________________________________________________________________________________
Date: Jan 31, 2007
It's actually not an alternative but rather the norm in the finishing industry. Aluminum parts going thru a conveyorized parts washer (long tunnel with several tanks and hundreds of spray nozzles) use some pretty aggressive chemicals sometimes depending on what they are trying to remove but for alum that started out clean and only has smudges and oils from our skin plus oily residue the air drill spit out Dawn or Woolite plus water gets it down to the shine. RINSE WELL WITH AGITATION !! Skip the alcohol, the part is already clean. DON'T dry it with compressed air, a LITTLE oil in the air goes a long way, use a fan or a CLEAN cotton rag. If you were outside I'd use WO-1 or Alumaprep to put in a little tooth for better adhesion but you can do that with the proper color of Scotchbrite (I keep forgetting which color it is) LOW&SLOW John Bolding I was searching the archives for a good alternative to cleaning parts before priming (indoors) and found John Bolding's writeup below. So, what is a good, safe cleaner that I can use indoor without risking exposure to carcinogen chemicals and without causing chemical reactions on the aluminum parts? Should I consider using soap and distilled water followed by rubbing alcohol? Thanx...Eddie ________________________________________________________________________________
Subject: Re: For 701 Builders Only - Update
From: "Chris Lewis" <christopherlewis(at)earthlink.net>
Date: Jan 31, 2007
Jon - Looks nice. Are you going to offer any combo deals for buying multiple videos at a time? BTW - Non-paid advertisement here. I have both of Jon's previous 701 videos (Metal Working 101 and Scratch-building) and truly enjoyed them. Check 'em out if you haven't. Chris in Seattle -------- 701 Scratch Builder Read this topic online here: http://forums.matronics.com/viewtopic.php?p=91945#91945 ________________________________________________________________________________
Date: Jan 31, 2007
Eddie- Figures, 15 minutes after I post this, John comes through. Can't complain though, eh? Good building. Bill Naumuk HDS Fuselage Townville, Pa ----- Original Message ----- From: "Bill Naumuk" <naumuk(at)alltel.net> Sent: Wednesday, January 31, 2007 6:01 PM Subject: Re: Zenith-List: Re: Cleaning aluminum, aerobatics > > Eddie- > I can see your problem- John's post never takes a stand other than > "prep carefully". You might want to narrow your search down by saying what > type of paint you intend to use (Enamel, lacquer, etc.) and see if anyone > bites. > Good building. > Bill Naumuk > HDS Fuselage > Townville, Pa > ----- Original Message ----- > From: "Eddie G." <silentlight(at)verizon.net> > To: > Sent: Wednesday, January 31, 2007 4:55 PM > Subject: Zenith-List: Re: Cleaning aluminum, aerobatics > > >> >> Hi, >> >> I was searching the archives for a good alternative to cleaning parts >> before priming (indoors) and found John Bolding's writeup below. >> >> So, what is a good, safe cleaner that I can use indoor without risking >> exposure to carcinogen chemicals and without causing chemical reactions >> on the aluminum parts? I am currently building my rudder in a corner of >> my living room which has turned out to be a nice comfortable work place. >> Am planning on brushing AFS primer/sealer on the contact points and >> leaving the rest of the surfaces untreated. I am also thinking of soaking >> the rivet heads in a thinned solution of primer/sealer before riviting. >> >> Should I consider using soap and distilled water followed by rubbing >> alcohol? >> >> >> Thanx...Eddie >> >> --------------------------- >> >> [quote="John Bolding"]OK guys , I know you should have only one subject >> per post but I prefer lurking to posting so I like to get it over with in >> a hurry. >> >> Cleaning aluminum: >> >> I REALLY hope I don't hurt anyone's feelings here and that is certainly >> not my intent. >> Over the yrs I have read hundreds of times on this list and several >> others that I monitor about wiping down the alum. part with some >> solvent( MEK, acetone and lacquer thinner being the most common)as the >> final prep for painting. >> My career in the paint spray equipment industry for 35 yrs put me in the >> middle of hundreds of paint film examinations to determine cause of >> failure. Normally the paint supplier or part washer guy was the lead >> role in these goat ropings but the equipment guy HAD to show up or he was >> automatically the cause, kinda like missing a meeting when your EAA >> Chapter holds elections, you WILL be an office holder if you miss. >> >> Some paints are more tolerant than others of a not perfectly clean >> surface, waterborne materials and powder are the least tolerant (in my >> limited experience anyway). >> Solvent is a poor choice for cleaning. >> >> Imagine coming in from the shop for lunch and grabbing a can of MEK and >> a rag and cleaning your greasy hands with it, no water, just a rag wet >> with solvent. You succeed in getting them to look a little better but >> you HAVEN'T taken all the dirt/ grease off, just moved it around in >> smaller concentrations. Follow up with a clean rag and more solvent >> reduces the concentrations but .... you get the picture. >> Now if you agitate a surfactant(soap) into the part to be cleaned,(your >> hands)using water and when you get all the junk floating (paint guys >> called it "suspended" 'cause they made a lot of money and wanted to >> impress the customer) and introduce a rinse(LOTS of water to flood the >> surface) to remove it ,you generally get a squeaky clean surface first >> rattle out of the box. Repeat as necessary. >> What I learned from all these dog and pony shows was that the oils you >> are trying to remove can be effective (with some coatings) down to the >> molecular level at causing adhesion problems down the road. Ever been at >> a boat dock and noticed the oil sheen on the water, it's only a few >> molecules thick. You CAN'T be assured you get it ALL off unless you wash >> and rinse. >> >> Now comes the part where 83 guys that have been painting since before >> birth tell me that I'm all wet and they never had a problem in wiping >> down a car with a rag and solvent. Save it, I heard it a thousand times. >> What impressed ME was the chemist who brought along a BIG microscope to >> one of these meetings and SHOWED me oil between the substrate and paint >> film where it had peeled off. Takes a lot of work to build an airplane, >> prep it properly. >> >> >> LOW&SLOW John Bolding >> >> >>> >> >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=91929#91929 >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: Re: Avionics book or videos - any recommendation?
Date: Jan 31, 2007
----- Original Message ----- From: Carlos Sa To: zenith-list(at)matronics.com Sent: Friday, December 08, 2006 3:54 PM Subject: Re: Zenith-List: Avionics book or videos - any recommendation? I suggest a visit to www.aeroelectric.com And, of course, there is the aeroelectric list @ Matronics. Just follow the link to the Matronics Navigator page, in the trailer below... Carlos CH601-HD, plans Montreal, Canada On 08/12/06, Eddie G. wrote: silentlight(at)verizon.net> Greetings, Is there one or two good books or videos that you folks can recommend on VHF antenna basics, selecting and installating antennas on metal-frame aircrafts, avionics, connectors, wiring, etc.? Thanx...Eddie ________________________________________________________________________________
Subject: Precision Leveling
Date: Jan 31, 2007
An excellent method for accurate leveling during fuselage construction. ________________________________________________________________________________
Subject: Re: Precision Leveling
Date: Jan 31, 2007
I just use a Smart Level mounted in a 48" beam. Works very well. Also useful for matching blade pitch angles on a G.A. prop. Dred ----- Original Message ----- From: Nancy To: Zenith-list Sent: Wednesday, January 31, 2007 8:34 PM Subject: Zenith-List: Precision Leveling An excellent method for accurate leveling during fuselage construction. ------------------------------------------------------------------------- ----- 1/31/2007 3:16 PM ________________________________________________________________________________
Date: Feb 01, 2007
Subject: Re: The Garangar now has a name, "Air Fiero"
Ron Boy do I understand. I'm allowed to share space with my wife's Lincoln under the threat of certain death "if I find even one scratch!" Carroll Jernigan XL Wings (still) ________________________________________________________________________________
Date: Feb 01, 2007
Bill, Never is a pretty inclusive word. My original post several months ago was pretty descriptive I thought. Soap and water to remove the oils and crap ,followed by a water rinse. No big magic. Solvent wiping is just one of those things that is used by many just because it has become ingrained, not because it is better. Will you have problems every time you solvent wipe? Of course not, BUT you are kidding yourself if you think it's spotless clean. That's all I was trying to get across. No, I didn't specify what kind of soap or where to buy it but if someone has to have his hand held that tightly just to clean his parts then......Maybe I can sell some videos of a builder driving down to WalMart to get his soap. I try to lurk unless the discussion is an area that I KNOW, unlike several on this list that would freely jump into a detailed seminar on brain surgery with pages of OPINIONS on how it should be done. My delete key is almost worn out. LOW&SLOW John Bolding Eddie- I can see your problem- John's post never takes a stand other than "prep carefully". You might want to narrow your search down by saying what type of paint you intend to use (Enamel, lacquer, etc.) and see if anyone bites. Good building. Bill Naumuk HDS Fuselage Townville, Pa Now if you agitate a surfactant(soap) into the part to be cleaned,(your > hands)using water and when you get all the junk floating (paint guys > called it "suspended" 'cause they made a lot of money and wanted to > impress the customer) and introduce a rinse(LOTS of water to flood the > surface) to remove it ,you generally get a squeaky clean surface first > rattle out of the box. Repeat as necessary>> ________________________________________________________________________________
Date: Feb 01, 2007
Ding, please refrain from posting in either RTF or HTML. The forum version of your post is blank. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92062#92062 ________________________________________________________________________________
Date: Feb 01, 2007
From: Maarten Versteeg <maarten.versteeg(at)swri.org>
Subject: Updates on Zenith builders web site
Hello All, Just a note (although the attentive builders that monitor the Zenith side probably already know), there are four updates on the builders web site: CS - Construction Standards for Zenair Light Airplanes, rev draft, dated 1/7 6-w-8aa - Wing Assembly: Checking Wing Twist rev 1.0, 1/17/07 6-B-3 - Rear Side Skins / Rear Fuselage Members rev 3.2, 1/18/07 6-B-11D - Upper Front Longerons / Fuselage Side Skins rev 2.2, 1/24/07 -- Maarten Versteeg Southwest Research Institute Phone: (210)522-5029 P.O. Drawer 28510 Fax: (210)522-5499 San Antonio, TX 78228-0510 ________________________________________________________________________________
Date: Feb 01, 2007
Subject: Re: Updates on Zenith builders web site
Martin Don't want to sound too dumb but___ What builders web site? I haven't been able to find it. Can you give me an address? Thanks. Carroll ________________________________________________________________________________
Date: Feb 01, 2007
-------- Martin Pohl Zodiac XL QBK 8645 Jona, Switzerland www.pohltec.ch/ZodiacXL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92096#92096 ________________________________________________________________________________
Date: Feb 01, 2007
Go the www.zenthair.com there is a choice for builders on the upper left side of the page. If you are a serial numbered builder you should have the user name and password. If you do not have them call Shirley at Zenith. Chuck Wacker N601CW Quick Build >From: Trainnut01(at)aol.com >Reply-To: zenith-list(at)matronics.com >To: zenith-list(at)matronics.com >Subject: Re: Zenith-List: Updates on Zenith builders web site >Date: Thu, 1 Feb 2007 10:46:10 EST > >Martin >Don't want to sound too dumb but___ What builders web site? I haven't been >able to find it. Can you give me an address? Thanks. >Carroll _________________________________________________________________ something more. ________________________________________________________________________________
Subject: Wing Jig
Date: Feb 01, 2007
Hello Group ,on page 6-B-13 what is the material thickness of the 956mm wing jig web . Thanks Wade Jones South Texas 601XL plans building Cont. 0200 ________________________________________________________________________________
Date: Feb 01, 2007
Well here I am a little late to get the new here. It is a good thing to post those findings here. Thanks Maarten, I just printed them out. -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92177#92177 ________________________________________________________________________________
Subject: Wing Jig
Date: Feb 01, 2007
The template is just that, a template. It doesn't become part of the plane. So all that matters is its outline and that it be stiff enough for it to be dimensionally stable and used easily. Or am I completely missing the point of your question? -- Craig ________________________________________________________________________________
Date: Feb 01, 2007
Subject: new to list
Hallo to all, My name is Ron smit this is my first posting on this list, bought a zodiac 601UL tail dragger C-FNSR last week I'm going to pick Her up on the 16th of Feb. the test flight went very good .plane is well equipped with transponder modeC ,Terra 760 .and intercom. engine is rotax912UL ,Im looking forward to our first local flight, I live in Chilliwack B.C. and know off no other zodiac in the lower mainland Vancouver area . I just sold a super Koala with a 912 in it build by Fisher a big change for me , much more aircraft this one ,cruise in Edmonton at 5500 ft -13 Celsius was almost 120 MPH IAS @ 4700 RPM stall was just under 55mph ias ( would like to get it down a bit perhaps VG's) the only thing I noticed was the static RPM was no more than 4300 RPM which seems a bit to low for me also I will have to put some cabin vents in the plane as it is going to be to hot in the summer for sure I found some very interesting stories on this list and will definitely keep monitoring it Safe landings to all C-FNSR Ron Smit ________________________________________________________________________________
Subject: Re: Wing Jig
Date: Feb 02, 2007
Thanks Craig ,I am aware that it is a template only .Just wondered what thickness the factory supplied part was . Wade Jones South Texas 601XL plans building Cont. 0200 ----- Original Message ----- From: Craig Payne To: zenith-list(at)matronics.com Sent: Thursday, February 01, 2007 9:34 PM Subject: RE: Zenith-List: Wing Jig The template is just that, a template. It doesn't become part of the plane. So all that matters is its outline and that it be stiff enough for it to be dimensionally stable and used easily. Or am I completely missing the point of your question? -- Craig ________________________________________________________________________________
Date: Feb 02, 2007
In my kit the main web was .090. Robin in AR N601ZV Zen-Vair ----- Original Message ----- From: Wade Jones To: zenith-list(at)matronics.com Sent: Friday, February 02, 2007 7:10 AM Subject: Re: Zenith-List: Wing Jig Thanks Craig ,I am aware that it is a template only .Just wondered what thickness the factory supplied part was . Wade Jones South Texas 601XL plans building Cont. 0200 ________________________________________________________________________________
Subject: Rotax 912 differences
Date: Feb 02, 2007
In the latest issue of Kitplane, they listed a lot of different engines for experimental aircraft. For the Rotax, they list both a 912S and a 912ULS, with different prices. (the difference was only a couple of hundred) Is there a difference between these models? HP, displacement, weight were all the same. My guess would have been that one was certified, but the price difference (or lack of) makes me think different. Or is this just a mistake in the magazine? Ryan ________________________________________________________________________________
Date: Feb 02, 2007
For a quick link to the "Builders Info Site" save the following link and make it easy to get there: www.zenithair.com/builder-secure/ >From there you will be ask for your Username and Password. If you don't have one contact Shirley at Zenith. George ________________________________________________________________________________
Date: Feb 02, 2007
Subject: Re: Rotax 912 differences
Hi Ryan, I think one is "Authorized by the manufacturer" for IFR operations. This has no real meaning when the engine is installed in an experimental airplane. Paul At 06:26 AM 2/2/2007, you wrote: >In the latest issue of Kitplane, they listed a lot of different >engines for experimental aircraft. For the Rotax, they list both a >912S and a 912ULS, with different prices. (the difference was only a >couple of hundred) Is there a difference between these models? HP, >displacement, weight were all the same. My guess would have been >that one was certified, but the price difference (or lack of) makes >me think different. Or is this just a mistake in the magazine? > >Ryan ________________________________________________________________________________
Date: Feb 02, 2007
Subject: Engine Info?
I am in the process of looking for an engine for my 601XL. Does anybody have a source of information on the different Lycoming, Continental and other aircraft engine models and specs? I have been looking at Lycoming and Continental engines on Barnstormers and there seems to be a lot of different models of each for sale. Neither the Lycoming or Continental web sites seem to have much information on their engines. Don Mountain --------------------------------- Don't be flakey. Get Yahoo! Mail for Mobile and always stay connected to friends. ________________________________________________________________________________
Date: Feb 02, 2007
As I understand.... The certified engine is the only one Rotax approves for night or IFR flight. The non-certified engine is specifically not approved for either. There is about $10,000 price difference. The only difference I know of is the addition of carb heat. I guess it is a question of risk and liability. Unfortunately I can't find a website that has pricing for the certified engine to confirm my information. Jabiru imposes no such restrictions. Dennis On 2/2/07, Paul Mulwitz wrote: > > p.mulwitz(at)worldnet.att.net> > > Hi Ryan, > > I think one is "Authorized by the manufacturer" for IFR > operations. This has no real meaning when the engine is installed in > an experimental airplane. > > Paul > > At 06:26 AM 2/2/2007, you wrote: > >In the latest issue of Kitplane, they listed a lot of different > >engines for experimental aircraft. For the Rotax, they list both a > >912S and a 912ULS, with different prices. (the difference was only a > >couple of hundred) Is there a difference between these models? HP, > >displacement, weight were all the same. My guess would have been > >that one was certified, but the price difference (or lack of) makes > >me think different. Or is this just a mistake in the magazine? > > > >Ryan > > ________________________________________________________________________________
Date: Feb 02, 2007
The price difference was only about $800 (if I remember correctly). When I get home and look at the article I'll find out for sure and let you know. ________________________________ > Date: Fri, 2 Feb 2007 12:21:54 -0500 > From: zenith601xl(at)gmail.com > To: zenith-list(at)matronics.com > Subject: Re: Zenith-List: Rotax 912 differences > > As I understand.... The certified engine is the only one Rotax approves for night or IFR flight. The non-certified engine is specifically not approved for either. There is about $10,000 price difference. The only difference I know of is the addition of carb heat. I guess it is a question of risk and liability. Unfortunately I can't find a website that has pricing for the certified engine to confirm my information. Jabiru imposes no such restrictions. > Dennis ________________________________________________________________________________
Date: Feb 02, 2007
Thanks for the information on the wing jig .I believe the .090 is what I am looking for .Do any other kit builders also have the same thickness for this part . Thanks Wade Jones South Texas 601XL plans building Cont. 0200 ----- Original Message ----- From: Robin Bellach To: zenith-list(at)matronics.com Sent: Friday, February 02, 2007 8:15 AM Subject: Re: Zenith-List: Wing Jig In my kit the main web was .090. Robin in AR N601ZV Zen-Vair ----- Original Message ----- From: Wade Jones To: zenith-list(at)matronics.com Sent: Friday, February 02, 2007 7:10 AM Subject: Re: Zenith-List: Wing Jig Thanks Craig ,I am aware that it is a template only .Just wondered what thickness the factory supplied part was . Wade Jones South Texas 601XL plans building Cont. 0200 ________________________________________________________________________________
Date: Feb 02, 2007
Subject: Shelving required for a complete slow-build kit
I have a pretty mundane question. I'm expecting delivery of my complete 601XL slow-build kit in a couple of weeks. I will need to build shelving (or whatever) to hold all the parts while I build the airframe. I would like to know how others have stored complete kits, without completely filling up the garage. How many shelves or bins, what size and shape? I have half of a 2-car garage to hold the storage and my 4'x12' work bench. Pictures would be great. Thanks for your sharing your experience. Terry Phillips ttp44~at~rkymtn.net Corvallis MT Just starting a 601 kit ________________________________________________________________________________
Subject: Re: Shelving required for a complete slow-build kit
Date: Feb 02, 2007
Terry - Check out Andre's site (courtesy of ch601.org) http://home.tiscali.nl/a.vandenelsen/foto%20pagina%20's/begin/index.html (Make sure to get the complete URL) Chris in Seattle -------- 701 Scratch Builder Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92396#92396 Attachments: http://forums.matronics.com//files/checking_can_begin_135.jpg ________________________________________________________________________________
Date: Feb 02, 2007
You won't need much shelving. I built my 12x4 bench on top of a Zenith crate, and still use the crate for storage. Another Zenith crate was turned on it's side and acts as a shelf. A peg board holds most of my tools. A small plastic tool box on wheels holds my drill and rivet gun. I put a few smaller shelves up as well to hold a radio and a holder for screws/rivets. http://photos1.blogger.com/blogger/2584/3102/1600/DSC00233.jpg http://bp2.blogger.com/_mhDbWUJRTOE/RYeWYnGvw-I/AAAAAAAAAAY/-qi6re2CiW0/s1600-h/DSC01470.JPG Good luck! On 2/2/07, Terry Phillips wrote: > > > I have a pretty mundane question. > > I'm expecting delivery of my complete 601XL slow-build kit in a couple of > weeks. I will need to build shelving (or whatever) to hold all the parts > while I build the airframe. I would like to know how others have stored > complete kits, without completely filling up the garage. > > How many shelves or bins, what size and shape? I have half of a 2-car > garage to hold the storage and my 4'x12' work bench. Pictures would be > great. Thanks for your sharing your experience. > > > Terry Phillips > ttp44~at~rkymtn.net > Corvallis MT > Just starting a 601 kit > > -- John Marzulli http://701Builder.blogspot.com/ "Flying a plane is no different than riding a bicycle... it's just a lot harder to put baseball cards in the spokes. ________________________________________________________________________________
Date: Feb 02, 2007
Don't mean to be a dummy, but does this site have anything relevant to the CH640? I just found out that the 640 is a Zenair Ltd. "exclusive". You can't even get a 640 rudder builder class at the Mexico MO location, so I was wondering if they treated the builder support info the same way. I was at first in love with the 801, but after careful consideration of our past (and future) flying mission profiles, I would be better served by the 640 features. My intent is to get as much prior knowledge as I can to plan my shop, tools, panel, power plant systems in advance. Any thoughts would be greatly appreciated! Craig Smith _____ From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of George Race Sent: Friday, February 02, 2007 9:49 AM Subject: Zenith-List: Re: Updates on Zenith builders web site For a quick link to the "Builders Info Site" save the following link and make it easy to get there: www.zenithair.com/builder-secure/ >From there you will be ask for your Username and Password. If you don't have one contact Shirley at Zenith. George ________________________________________________________________________________
Date: Feb 02, 2007
Sorry pilot4pay, there isn't any 640 info on the site. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92424#92424 ________________________________________________________________________________
Date: Feb 02, 2007
The 640 info seems to be here. http://www.zenair.com/builders.html -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92425#92425 ________________________________________________________________________________
Date: Feb 02, 2007
----- Original Message ----- From: "Terry Phillips" <ttp44(at)rkymtn.net> Sent: Friday, February 02, 2007 11:16 AM Subject: Zenith-List: Shelving required for a complete slow-build kit > > I have a pretty mundane question. > > I'm expecting delivery of my complete 601XL slow-build kit in a couple of > weeks. I will need to build shelving (or whatever) to hold all the parts > while I build the airframe. I would like to know how others have stored > complete kits, without completely filling up the garage. > > How many shelves or bins, what size and shape? I have half of a 2-car > garage to hold the storage and my 4'x12' work bench. Pictures would be > great. Thanks for your sharing your experience. > > > Terry Phillips > ttp44~at~rkymtn.net > Corvallis MT > Just starting a 601 kit > > > -- 3:42 PM > > ________________________________________________________________________________
Subject: Shelving for 601 project
Date: Feb 02, 2007
With regard to Terry Phillips' inquiry: I framed several shelves with cheap 2x2s from Lowe's, then used the plywood from the boxes of the various kits for the actual shelving. Plywood gussets reinforce the joints in the framing. The plywood is flimsy, but the components are light, for the most part. I even built a light-duty workbench for the electrical part of the job that way. Building from component kits, I had plenty of scruffy plywood to work with. I also made 2 horizontal platforms to set on top of the wing center section stubs of my 601HD. They make it easier to kneel there while working inside the cockpit area. I realize that that's not an option for an XL. A person could rip the 2x4s from the kit boxes to obtain most of the 2x2s for framing the shelves. I sold my radial arm saw to make room for the airplane in my 2-car garage, so didn't do that. As far as sizes, 18x48 has proven pretty handy for me. George Swinford ________________________________________________________________________________
Date: Feb 02, 2007
Thanks for the link. I've already been there and the information is pretty limited in scope and detail. In the meantime, I'm learning from all of you building the other aircraft. I'm sure that a lot of Chris's design and construction methods are common to all models, just the details will be different. Thanks again. Craig Smith -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Gig Giacona Sent: Friday, February 02, 2007 4:19 PM Subject: Zenith-List: Re: Updates on Zenith builders web site The 640 info seems to be here. http://www.zenair.com/builders.html -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92425#92425 ________________________________________________________________________________
Subject: Carb Heat on Rotax 912 ULS?
Date: Feb 02, 2007
Dear Listers, I am installing 912 ULS on a CH 701. Due to its cost and perhaps debatable utility, I have been advised to leave it off. I sure would like to hear some comments from the list as to whether this is a good approach. I am taking lessons in an Evektor Sportstar with 912S engine. So far, we have never used the carb heat. I am flying in Goldsboro, NC. That is about 60 miles east of Raleigh. As I recall flying the Continental O-200, we used carb heat anytime under 2K rpm. The POH on the Sportstar only requires carb heat if you suspect icing. i.e. engine starting to lose power and run rough. Many thanks, Ken Arnold Pikeville, NC Building CH701 - hoping to fly it in May, 07 ________________________________________________________________________________
Date: Feb 02, 2007
Subject: Re: Carb Heat on Rotax 912 ULS?
Ken.=0A =0ANot sure who advised you to leave off the carb heat, sounds like Zenith. For some reason they (Zenith) have not been supporting the carb h eat/cold air intake on the 701. The Rotax 912ULS comes with a manifold tha t is just for that purpose. According to Rotax you will not get all the 100 HP you paid for on the 912ULS with out this manifold.=0A =0AZenith first s aid it wouldn't fit under the cowling, a fellow 701 builder down the street fit it under his just fine. Now they (Zenith) have developed a new cowlin g and still don't support the cold air intake. So that 100 HP you paid dea rly for, is only giving you about 90 HP on take off.=0A =0AThat is the bigg est reason I bought my Rotax and FWF from SkyShops.=0A =0AMark S.=0A701/912 ULS=0A=0A=0A----- Original Message ----=0AFrom: Ken Arnold <arno7452@bellso uth.net>=0ATo: Zenith List =0ASent: Friday, Febr uary 2, 2007 2:09:14 PM=0ASubject: Zenith-List: Carb Heat on Rotax 912 ULS? =0A=0A=0ADear Listers,=0A =0AI am installing 912 ULS on a CH 701. Due to i ts cost and perhaps debatable utility, I have been advised to leave it off. I sure would like to hear some comments from the list as to whether this is a good approach.=0A =0AI am taking lessons in an Evektor Sportstar with 912S engine. So far, we have never used the carb heat. I am flying in Gol dsboro, NC. That is about 60 miles east of Raleigh. As I recall flying th e Continental O-200, we used carb heat anytime under 2K rpm. =0A =0AThe POH on the Sportstar only requires carb heat if you suspect icing. i.e. engin e starting to lose power and run rough.=0A =0AMany thanks,=0AKen Arnold=0AP ===================0A=0A=0A =0A________ ___________________________________________________________________________ _=0ANever Miss an Email=0AStay connected with Yahoo! Mail on your mobile. Get started!=0Ahttp://mobile.yahoo.com/services?promote=mail ________________________________________________________________________________
Subject: Re: carb heat on 912uls
Date: Feb 02, 2007
Ken I have about 70 hours on my 701 with 912 ULS and the Zenith recommended intake system. I have had one instance of carb ice and was able to get out of the icing conditions with no problem in this case. My experience is that the carbs WILL ice with the Zenith system. Joe ________________________________________________________________________________
Date: Feb 02, 2007
There is yet another way to heat the carbs, a very simple way using 12 VDC power. I am building a 701 with a Jabiru 2200A engine. Recently I received a carb heat unit from Jabiru USA in Tennessee as part of my FWF kit. I am very impressed with the "Heater Kit", it even comes with taps to thread the holes for mounting. I am sure that Pete at Jabiru USA can provide you with price and details. Take a look at this UK WebSite for all the details on the heater unit. http://www.jabiru.co.uk/other/carb_ice_eliminator.htm I am sure this is yet another way to make sure you do not have ANY carb ice formation, without a muffler muff and all the associated stuff that goes with it. George ________________________________________________________________________________
Date: Feb 02, 2007
I stored everything but sheet metal and canopy on a shelf under the work bench and on the floor under the bench. Clyde Barcus ----- Original Message ----- From: "Terry Phillips" <ttp44(at)rkymtn.net> Sent: Friday, February 02, 2007 1:16 PM Subject: Zenith-List: Shelving required for a complete slow-build kit > > I have a pretty mundane question. > > I'm expecting delivery of my complete 601XL slow-build kit in a couple of > weeks. I will need to build shelving (or whatever) to hold all the parts > while I build the airframe. I would like to know how others have stored > complete kits, without completely filling up the garage. > > How many shelves or bins, what size and shape? I have half of a 2-car > garage to hold the storage and my 4'x12' work bench. Pictures would be > great. Thanks for your sharing your experience. > > > Terry Phillips > ttp44~at~rkymtn.net > Corvallis MT > Just starting a 601 kit > > > ________________________________________________________________________________
Date: Feb 02, 2007
Craig the only 640 workshop is held at Can-Zac Aviation. We support and offer the complete Zenith and Zenair line of aircraft. Mark Townsend Can-Zac Aviation Ltd. HYPERLINK "mailto:president@can-zacaviation.com"president@can-zacaviation.com HYPERLINK "http://www.can-zacaviation.com/"www.can-zacaviation.com -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of C Smith Sent: Friday, February 02, 2007 3:49 PM Subject: RE: Zenith-List: Re: Updates on Zenith builders web site Don=92t mean to be a dummy, but does this site have anything relevant to the CH640? I just found out that the 640 is a Zenair Ltd. =93exclusive=94. You can=92t even get a 640 rudder builder class at the Mexico MO location, so I was wondering if they treated the builder support info the same way. I was at first in love with the 801, but after careful consideration of our past (and future) flying mission profiles, I would be better served by the 640 features. My intent is to get as much prior knowledge as I can to plan my shop, tools, panel, power plant systems in advance. Any thoughts would be greatly appreciated! Craig Smith _____ From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of George Race Sent: Friday, February 02, 2007 9:49 AM Subject: Zenith-List: Re: Updates on Zenith builders web site For a quick link to the "Builders Info Site" save the following link and make it easy to get there: HYPERLINK "http://www.zenithair.com/builder-secure/"www.zenithair.com/builder-secu re/ >From there you will be ask for your Username and Password. If you don't have one contact Shirley at Zenith. George http://www.matronics.com/Navigator?Zenith-List http://forums.matronics.com "http://www.matronics.com/Navigator?Zenith-List"http://www.matronics.com /Navigator?Zenith-List "http://forums.matronics.com"http://forums.matronics.com -- 2/2/2007 3:42 PM -- 2/2/2007 3:42 PM ________________________________________________________________________________
Date: Feb 02, 2007
Subject: Re:Engine info?
Try these: This one lists differences of many engine types. http://home.adelphia.net/~aeroengine/index.html This one lists weights and horsepower. http://www.wanttaja.com/avlinks/engines.htm#Engines2 Maybe start at Ron Wattaja's home page. http://www.wattaja.com Bob D. ________________________________________________________________________________
Date: Feb 02, 2007
Subject: Re: engine info? (#2)
This is a Lyc list and is fairly complete. http://www.prime-mover.org/Engines/Lycoming/Lyc_Cert_list.html Bob D ________________________________________________________________________________
From: "Dave VanLanen" <davevanlanen(at)sbcglobal.net>
Subject: Drill Bit Durability
Date: Feb 02, 2007
Can anyone who has finished their aircraft give me a ballpark idea of how many holes I should typically be able to get out of a hi-moly drill bit (#30 and #20)? Thanks, Dave ________________________________________________________________________________
Date: Feb 02, 2007
In a message dated 2/2/2007 5:11:00 P.M. Eastern Standard Time, arno7452(at)bellsouth.net writes: Ken, I have the 701 with the firewall forward package from Czech works and it came with the carb heat box. Had to use it a month ago while doing some touch and goes and some engine out practice. While taking back off from the runway she stumbled a bit,pulled the carb heat and she cleared right up. The advantage to using the box with this firewall forward package is that you are not sucking in heated air all the time, which allows you to develop more HP. Not sure what setup you have and are installing. I also recommend installing a oil cooler thermostat, this helps in getting your oil temps up quicker and not having to tape off your oil cooler in the cooler weather. I might even consider the ring mount engine mount. looks like a lot more room to get things run. Bob Spudis N701ZX/912uls/100hrs Dear Listers, I am installing 912 ULS on a CH 701. Due to its cost and perhaps debatable utility, I have been advised to leave it off. I sure would like to hear some comments from the list as to whether this is a good approach. I am taking lessons in an Evektor Sportstar with 912S engine. So far, we have never used the carb heat. I am flying in Goldsboro, NC. That is about 60 miles east of Raleigh. As I recall flying the Continental O-200, we used carb heat anytime under 2K rpm. The POH on the Sportstar only requires carb heat if you suspect icing. i.e. engine starting to lose power and run rough. Many thanks, Ken Arnold Pikeville, NC Building CH701 - hoping to fly it in May, 07 ________________________________________________________________________________
Date: Feb 02, 2007
Subject: Re: Drill Bit Durability
Hi Dave, I use the threaded drill bits meant for aircraft use. I don't think they are particularly hard alloys, but they work really well and don't have problems slipping in your drill chuck as you finish each hole. I start each hole with a #40 drill. I then use #30 and optionally #20 to enlarge the holes. This means I virtually never need to sharpen or replace anything but the #40 drills. I sharpen the #40s using a bench grinder - maybe once a month - when they get dull. I am more likely to break one than to sharpen it too many times. I keep a supply of 2 or 3 spares and order more once a year or so. I am still on my first #30 and #20. I highly recommend you consider buying the right angle drill gizmo from Aircraft Spruce that comes with adapters and a few screw mount drill bits. I think the ones threaded 1/4 x 28 are the best choice. Take a look: http://www.aircraftspruce.com/catalog/topages/tightfittoolkit.php Good luck, Paul XL fuselage At 06:57 PM 2/2/2007, you wrote: >Can anyone who has finished their aircraft give me a ballpark idea >of how many holes I should typically be able to get out of a hi-moly >drill bit (#30 and #20)? > >Thanks, > >Dave --------------------------------------------- Paul Mulwitz 32013 NE Dial Road Camas, WA 98607 --------------------------------------------- ________________________________________________________________________________
Subject: Re: Methods of leveling
Date: Feb 03, 2007
Herb, Thanks for the leveling insight. I used your method of Arbor Press riveting this year and it worked out great. -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92547#92547 ________________________________________________________________________________
Date: Feb 03, 2007
And don't spin them as fast as an airdrill or a high speed electric drill can. The heat of too high a speed shortens the cutting life. Before you ask what rpm is best, I just learned from my dad saying "slow it dow.... where's the fire?" so it's become a listen and feel thing for me but I'd guess you're safe around 650 -800 rpm. Dred ----- Original Message ----- From: Paul Mulwitz To: zenith-list(at)matronics.com Sent: Saturday, February 03, 2007 12:05 AM Subject: Re: Zenith-List: Drill Bit Durability Hi Dave, I use the threaded drill bits meant for aircraft use. I don't think they are particularly hard alloys, but they work really well and don't have problems slipping in your drill chuck as you finish each hole. I start each hole with a #40 drill. I then use #30 and optionally #20 to enlarge the holes. This means I virtually never need to sharpen or replace anything but the #40 drills. I sharpen the #40s using a bench grinder - maybe once a month - when they get dull. I am more likely to break one than to sharpen it too many times. I keep a supply of 2 or 3 spares and order more once a year or so. I am still on my first #30 and #20. I highly recommend you consider buying the right angle drill gizmo from Aircraft Spruce that comes with adapters and a few screw mount drill bits. I think the ones threaded 1/4 x 28 are the best choice. Take a look: http://www.aircraftspruce.com/catalog/topages/tightfittoolkit.php Good luck, Paul XL fuselage At 06:57 PM 2/2/2007, you wrote: Can anyone who has finished their aircraft give me a ballpark idea of how many holes I should typically be able to get out of a hi-moly drill bit (#30 and #20)? Thanks, Dave --------------------------------------------- Paul Mulwitz 32013 NE Dial Road Camas, WA 98607 --------------------------------------------- ------------------------------------------------------------------------- ----- 2/2/2007 11:39 PM ________________________________________________________________________________
Subject: Final assembly: Rear spar bolt
Date: Feb 03, 2007
Hi everybody I just had a look through the "Final Assembly" drawing supplement (provided by CZAW) and did not understand one item: It seems like as the rear spar bolt is screwed in the rear spar/rear spar attachment bracket without nut?! The parts list also shows no nuts for the rear spar bolt? In addition I don't see a cutout in the lower skin (at the wing root) that would provide access for the installation of the nut. Could somebody help me out of this confusion? I cannot believe that a bolt can be installed without counterpart-nut. Cheers from Switzerland Martin -------- Martin Pohl Zodiac XL QBK 8645 Jona, Switzerland www.pohltec.ch/ZodiacXL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92621#92621 ________________________________________________________________________________
Date: Feb 03, 2007
I must be slow to understand the builders web site but I can't seem to find the info that was referenced on the builders site. I get logged in but where do I go next. Danny in Texas 601XL tail section -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com]On Behalf Of George Race Sent: Friday, February 02, 2007 8:49 AM To: zenith-list(at)matronics.com Subject: Zenith-List: Re: Updates on Zenith builders web site For a quick link to the "Builders Info Site" save the following link and make it easy to get there: www.zenithair.com/builder-secure/ From there you will be ask for your Username and Password. If you don't have one contact Shirley at Zenith. George ________________________________________________________________________________
Subject: electric carb heater
Date: Feb 03, 2007
Greetings all, Someone asked about carb heat for a 912 and someone else mentioned the resistive unit for a Jabiru. I also just received this heater for my Jab and ran some preliminary tests to determine current draw and will also pass along the dimensions. It is cylindrical, 30 mm in diameter and 30 mm tall, weighing 70 grams. Attachment is with two bolts to the side of the carb using the included taps. There are two electrical connections using the body of the cylinder for ground. The two coils can be operated independently which allows for a high and low setting. When the unit is cold the resistance of each coil is 8.6 Ohms for a current draw of 3.5 Amps. As the temperature increases the impedance rapidly decreases to 4.7 Ohms, however, the current draw dropped to 2.0 Amps. Cold current drain on high results in a rather high figure of 7 amps but tapers off a bit after it heats up. The kit was very complete with switches, a chunk of wire, fuse holder and all necessary electrical connectors. I was disappointed with the two SPST switches. I have already replaced them with a DPDT so as to only take up one of my switch locations. The current drain of two units operating on high for the 912 might put a bit of a strain on the electrical system. Hope this is useful Dick Neitzel Sayner, WI 701 Jab 2200 N963WB ________________________________________________________________________________
Subject: Cutout in the Canopy inside flashing
Date: Feb 03, 2007
Im finally at the point of installing the canopy on the XL. In the photo guide for the inside flashing, there are alternate ways to cut out over or around the latch frame. Please advise which way you did it, and how you would do it if you had it to do over. The latch frame is thicker than the square tubing, so a cutout seems like it would leave a step up at that point in the inside flashing. Cutting around the entire latch frame would make a flatter flashing, but may not look as good. Also, the inside flashing with its reinforcing L pinch the plexi against the outside flashing. Does the top flange of the inside flashing need to be trimmed back to keep the inside flashing's main flange parallel to the outer flashing? Thanks for any advice you can give - -------- David Glass Forest, VA Zodiac XL - N253DG reserved On the gear, ready for tail and cables 12/06 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92673#92673 ________________________________________________________________________________
Subject: Re: Final assembly: Rear spar bolt
Date: Feb 03, 2007
Martin- My old plans call for one AN5-7A per wing. (See 6-S-3 ) You will have to cut out a small area in the rear lower wing skin (approximately 2" X 3" just behind part # 6B5-4 in order to get a washer and nut on the bolt. I used a pair of long nosed pliars to put the washer on the bolt and used a closed end wrench with a piece of tape on the back side to hold the nut in the wrench. Had a friend turn the bolt into the nut with a socket wrench from the outside. Do all this before you install the flaps. I had no problem. Good luck! Al Young N601AY ----- Original Message ----- From: "Martin Pohl" <mpohl(at)pohltec.ch> Sent: Saturday, February 03, 2007 11:37 AM Subject: Zenith-List: Final assembly: Rear spar bolt > > Hi everybody > > I just had a look through the "Final Assembly" drawing supplement > (provided by CZAW) and did not understand one item: > > It seems like as the rear spar bolt is screwed in the rear spar/rear spar > attachment bracket without nut?! The parts list also shows no nuts for the > rear spar bolt? In addition I don't see a cutout in the lower skin (at the > wing root) that would provide access for the installation of the nut. > > Could somebody help me out of this confusion? I cannot believe that a bolt > can be installed without counterpart-nut. > > Cheers from Switzerland > Martin > > -------- > Martin Pohl > Zodiac XL QBK > 8645 Jona, Switzerland > www.pohltec.ch/ZodiacXL > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=92621#92621 > > > ________________________________________________________________________________
Date: Feb 03, 2007
I cut a hole through the fuselage side skin behind the seat to get access for that bolt. That way there's no exposed hole on the underside of the wing. As I recall, I put the bolt through from the inside and put the nut on the outside where I could inspect it easier. > > Martin- My old plans call for one AN5-7A per wing. (See 6-S-3 ) You > will have to cut out a small area in the rear lower wing skin > (approximately 2" X 3" just behind part # 6B5-4 in order to get a washer > and nut on the bolt. > >> >> It seems like as the rear spar bolt is screwed in the rear spar/rear >> spar attachment bracket without nut?! -- Bryan Martin Zenith 601XL N61BM Ram Subaru, Stratus redrive ________________________________________________________________________________
Date: Feb 03, 2007
From: Christian Tremblay <cj.tremblay(at)videotron.ca>
Hi Craig, I am a builder from plan of the CH640. I have done rudder and tail wing, Center Web Spar and working on wings. You can find some information on my web site ' more than 125 photos. If you want to prepare and construct I suggest to visit mine, I will be happy to answer your questions the better that I can inside my limited experience. Note : I exchange info with 3-4 others guys who build from plan. Christian Tremblay A guy who build a CH640 aircraft from plan http://www.zodiac640.com/ _____ De : owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] De la part de C Smith Envoy=E9 : Friday, February 02, 2007 3:49 PM =C0 : zenith-list(at)matronics.com Objet : RE: Zenith-List: Re: Updates on Zenith builders web site Don=92t mean to be a dummy, but does this site have anything relevant to the CH640? I just found out that the 640 is a Zenair Ltd. =93exclusive=94. You can=92t even get a 640 rudder builder class at the Mexico MO location, so I was wondering if they treated the builder support info the same way. I was at first in love with the 801, but after careful consideration of our past (and future) flying mission profiles, I would be better served by the 640 features. My intent is to get as much prior knowledge as I can to plan my shop, tools, panel, power plant systems in advance. Any thoughts would be greatly appreciated! Craig Smith _____ From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of George Race Sent: Friday, February 02, 2007 9:49 AM Subject: Zenith-List: Re: Updates on Zenith builders web site For a quick link to the "Builders Info Site" save the following link and make it easy to get there: www.zenithair.com/builder-secure/ >From there you will be ask for your Username and Password. If you don't have one contact Shirley at Zenith. George ________________________________________________________________________________
From: "Scott Laughlin" <cookwithgas(at)HOTMAIL.COM>
Date: Feb 03, 2007
Dave: I built both wings and half my fuselage with one drill bit of each size. When I lost one, I ordered two more and finished the plane. Buy three or four of each and don't lose them and you will be good to go. Scott Laughlin CH601XL Omaha, Nebraska www.cooknwithgas.com Still Polishing From: "Dave VanLanen" <davevanlanen(at)sbcglobal.net> Subject: Zenith-List: Drill Bit Durability Can anyone who has finished their aircraft give me a ballpark idea of how many holes I should typically be able to get out of a hi-moly drill bit (#30 and #20)? Thanks, Dave _________________________________________________________________ FREE online classifieds from Windows Live Expo buy and sell with people you know ________________________________________________________________________________
Date: Feb 03, 2007
Dvid, I think this is the latch problem you are talking about. I have attached three photos to show what I did with it. Hope they are not too large for some of you. I made two fiberglass covers. I later discovered that I needed to cut off one corner to clear the slot for emergency release of the canopy. The fiberglass covers are not attached yet, but you can see how they will clean up the area. Jay in Dallas "deglass1" wrote: > >Im finally at the point of installing the canopy on the XL. In the photo guide for the inside flashing, there are alternate ways to cut out over or around the latch frame. Please advise which way you did it, and how you would do it if you had it to do over. >The latch frame is thicker than the square tubing, so a cutout seems like it would leave a step up at that point in the inside flashing. Cutting around the entire latch frame would make a flatter flashing, but may not look as good. >Also, the inside flashing with its reinforcing L pinch the plexi against the outside flashing. Does the top flange of the inside flashing need to be trimmed back to keep the inside flashing's main flange parallel to the outer flashing? > >Thanks for any advice you can give - > >-------- >David Glass >Forest, VA >Zodiac XL - N253DG reserved >On the gear, ready for tail and cables 12/06 > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=92673#92673 > > ________________________________________________________________________________
Date: Feb 03, 2007
Martin,On my 6-W-0 dwg dated 12/02, in the lower left hand corner is note "40x20 CUTOUT FOR ACCESS TO REAR SPAR WING ATTACHMENT BOLT' After assembly, I covered this cutout with a piece of Aluminum tape. I remove the tape for inspections. On 6-S-3 there is also a note "ACCESS CUTOUT IN BOTTOM SKIN 6W8-2, SEE 6-W-0Dwg 6-S-3 does not show the nuts to be used with the AN5-5A bolts,(on my dwg there is also no nut callout shown for the spar attach AN5 bolts); but self locking nuts are intended to be used. I believe that the general construction guidelines maycall out for the use of AN self locking nuts (and washer use criteria) on AN bolts, unless otherwise indicated on the drawing to use some other nut/washer combination.Tony Graziano601XL; 204 hrs-----------Hi everybody I just had a look through the "Final Assembly" drawing supplement (provided byCZAW) and did not understand one item: It seems like as the rear spar bolt is screwed in the rear spar/rear spar attachmentbracket without nut?! The parts list also shows no nuts for the rear sparbolt? In addition I don't see a cutout in the lower skin (at the wing root)that would provide access for the installation of the nut. Could somebody help me out of this confusion? I cannot believe that a bolt canbe installed without counterpart-nut. Cheers from SwitzerlandMartin ________________________________________________________________________________
Date: Feb 03, 2007
Subject: re: Carb Heat on Rotax 912 ULS?
Ken, Before you make your final decision on NOT installing Carb Heat, read the article on the Flycorvair.com website. (use the link below) whether you install a Rotax, Jabaru, Corvair or whatever, this article makes some very interesting points. My flight instructor trained me never to guess. ALLWAYS use carb heat before any major throttle reduction. Everyone has their opinions. I'd rather be safe than sorry. http://flycorvair.com/carbice.html Dave Thompson Westminster, Ca Corvair Engine in parts, Rudder & just starting stab Archive this ________________________________________________________________________________
Subject: Re: Cutout in the Canopy inside flashing
Date: Feb 03, 2007
I went for full access to the latch over appearance. Sorry no good pic of this. I made a cut out of the inner flashing that allows finger access to open the canopy should the cabes break and more importantly I can visually check that the canopy latch is fully locked prior to take off. I have seen the canopy appear to be down and locked but the latch release lever is not fully set so it needs another compression to fully engage the lock. Also I added a 1/2" tubular cross bar about 8 " up the bow to set the width of the canopy firmly. It is also useful for compressing the locks. And with a small nylon rope attached, it prevents the wind from catching the canopy when open on the ground and possibly straining the hinges. Gary Ray ----- Original Message ----- From: "deglass1" <deglass1(at)aol.com> Sent: Saturday, February 03, 2007 4:36 PM Subject: Zenith-List: Cutout in the Canopy inside flashing > > I?Tm finally at the point of installing the canopy on the XL. In the photo guide for the inside flashing, there are alternate ways to cut out over or around the latch frame. Please advise which way you did it, and how you would do it if you had it to do over. > The latch frame is thicker than the square tubing, so a cutout seems like it would leave a step up at that point in the inside flashing. Cutting around the entire latch frame would make a flatter flashing, but may not look as good. > Also, the inside flashing with its reinforcing L ?opinch? the plexi against the outside flashing. Does the top flange of the inside flashing need to be trimmed back to keep the inside flashing's main flange parallel to the outer flashing? > > Thanks for any advice you can give - > > -------- > David Glass > Forest, VA > Zodiac XL - N253DG reserved > On the gear, ready for tail and cables 12/06 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=92673#92673 > > ________________________________________________________________________________
Date: Feb 03, 2007
Craig, I=92m a 640 builder located in Northeast Indiana. I am hoping to fly mine within the next year, so I=92m in the later building stages. My Dad is building the 601 and the process is quite similar. I=92ve used a website put together by 640 builder Jeff Paden of New York to aid in the assembly/build process. www.madbbs.com/~jpaden As far as crossing the border, I=92ve done it twice. The first was with my wing kit in an enclosed trailer and the second with my canopy kit. The folks at Zenair prepare you well with the appropriate documentation to get you through customs. I would highly recommend a trip to Zenair to view the factory and if nothing else, talk to Mr. Heintz himself. I=92m not sure where you=92re located, but your welcome to come see my project. I live on an airport, so if you have something to fly come on over. www.tropria.com <http://www.tropria.com/> Doug Geese _____ De : owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] De la part de C Smith Envoy=E9 : Friday, February 02, 2007 3:49 PM =C0 : zenith-list(at)matronics.com Objet : RE: Zenith-List: Re: Updates on Zenith builders web site Don=92t mean to be a dummy, but does this site have anything relevant to the CH640? I just found out that the 640 is a Zenair Ltd. =93exclusive=94. You can=92t even get a 640 rudder builder class at the Mexico MO location, so I was wondering if they treated the builder support info the same way. I was at first in love with the 801, but after careful consideration of our past (and future) flying mission profiles, I would be better served by the 640 features. My intent is to get as much prior knowledge as I can to plan my shop, tools, panel, power plant systems in advance. Any thoughts would be greatly appreciated! Craig Smith _____ From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of George Race Sent: Friday, February 02, 2007 9:49 AM Subject: Zenith-List: Re: Updates on Zenith builders web site For a quick link to the "Builders Info Site" save the following link and make it easy to get there: www.zenithair.com/builder-secure/ >From there you will be ask for your Username and Password. If you don't have one contact Shirley at Zenith. George ________________________________________________________________________________
Date: Feb 03, 2007
Yes. Bolt head inside facing forward, nut facing aft on spar rear channel. Bolt is in shear. I just "snugged" and quarter turned, then applied torque stripe/anti-sabotage paint. Tony Graziano ------------- Tim Juhl (juhl(at)avci.net) Using any of the access methods described are you able to get a torque wrench on it? Tim ________________________________________________________________________________
Date: Feb 04, 2007
Thank you for all your postings. I am releived now... :D Martin -------- Martin Pohl Zodiac XL QBK 8645 Jona, Switzerland www.pohltec.ch/ZodiacXL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92767#92767 ________________________________________________________________________________
Subject: Final Engine Selection
Date: Feb 04, 2007
I think I have finally solved my engine selection !!! Reckon a 24 x 10 prop will be ok ???? [Twisted Evil] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92770#92770 Attachments: http://forums.matronics.com//files/saito1_188.jpg ________________________________________________________________________________
Subject: Re: Hat Stiffener Press + Pic of the day
Date: Feb 04, 2007
sky_ranger161 wrote: > After a few failed attempts at making hat stiffeners for the main spar, I decided to try making a press die for them in much the same way I made my flanging dies. Here's what I came up with. I used the same timbertech composite material as I used for the flanging dies, and was able to fabricate the whole set using a table saw and some 5-minute epoxy from ACE hardware. I rounded all of the corners to the proper radius, and epoxied the male 45-degree press flange to the top die. To use them, I put a piece of .025 between the dies and put them under pressure with the shop press until the bend is formed, then trim the flanges to the proper size. Out comes perfectly shaped, high-quality,?repeatable hat stiffeners lookin' like the factory made 'em. > ? > Debo Cox > Nags Head, NC > XL/Corvair > Moving slow, but still moving (which is good) > > I started to design the exact same thing last night. Good to see it works. My only question, do you have any spring back in the angles or contour the exact same as the part specified in the plans? I was thinking of making one with spring back built in but it may not be necessary. I'll try this frist because building in springback is a lot more work and if it doesn't need it that'd be great. -------- CH601XL - Corvair Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92771#92771 ________________________________________________________________________________
Date: Feb 04, 2007
Ron Lendon wrote: > Debo, > > You are the master. I had someone offer to buy my flanging dies the other day, which I declined, and I refered him to your pics. > > You might wanna take a look at how I solved bending the flaps. The final 163 degree bend was done with the 200lb gravity actuated stomp press [Laughing] I used the same gravity actuated stomp press for my rudder skin and elevator skin. Can't beat the price. -------- CH601XL - Corvair Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92773#92773 ________________________________________________________________________________
Date: Feb 04, 2007
When drilling aluminium I tend to use a high speed.... As fast as possible and just let the bit drill the hole. I too sharpen my bits on a bench grinder and if I have time I take out the bit sharpener which is actually nothing more than a fancy bit guide for sharpening. I've even reformed heads on broken bits to get a hole drilled. I never use any pressure on the drill at all. Steel is another matter. As slow as possible, fair pressure and a good supply of cutting oil. Certainly you should always have a reasonable supply of #s 40,30 and 20 because the only time you will need another one is when the tool shop is closed. If you use a deburring tool it may be a good idea to have an extra one of those on hand too. Generally I use a 3/8 bit in my hand to de burr.... Just remember to deburr gently or you could end up chamfering your hole. Noel > -----Original Message----- > From: owner-zenith-list-server(at)matronics.com > [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of > Scott Laughlin > Sent: Saturday, February 03, 2007 7:27 PM > To: zenith-list(at)matronics.com > Subject: Zenith-List: Drill Bit Durability > > > > > Dave: > > I built both wings and half my fuselage with one drill bit of > each size. > When I lost one, I ordered two more and finished the plane. > Buy three or > four of each and don't lose them and you will be good to go. > > Scott Laughlin > CH601XL > Omaha, Nebraska > www.cooknwithgas.com > Still Polishing > > > From: "Dave VanLanen" <davevanlanen(at)sbcglobal.net> > Subject: Zenith-List: Drill Bit Durability > > Can anyone who has finished their aircraft give me a ballpark > idea of how > many holes I should typically be able to get out of a hi-moly > drill bit (#30 > and #20)? > > Thanks, > Dave > > _________________________________________________________________ > FREE online classifieds from Windows Live Expo - buy and sell > with people > you know > > > > > ________________________________________________________________________________
Date: Feb 04, 2007
Lockwood Aviation http://www.lockwood-aviation.com <http://www.lockwood-aviation.com/> sells a carb heat device. I think they are one of the largest Rotax dealers in the U.S. I see it in their catalog, but their website is the most difficult site I've ever encountered when searching for parts. ________________________________________________________________________________
Date: Feb 04, 2007
I agree --- trying to navigate the Lockwood online catalog takes more patience than I have. I have their printed catalog, but for a lot of items it says to go to the online catalog for details and cost. I did order an engine from them (haven't seen it yet), and had planned on purchasing engine instruments and other misc. from them, but it was just to difficult. I've heard good things about the company, but I think they are missing out on sales because of poor website design. Gordon ----- Original Message ----- From: Tommy Walker To: zenith-list(at)matronics.com Sent: Sunday, February 04, 2007 10:19 AM Subject: Re: Zenith-List: Carb Heat on Rotax 912 ULS? Lockwood Aviation http://www.lockwood-aviation.com sells a carb heat device. I think they are one of the largest Rotax dealers in the U.S. I see it in their catalog, but their website is the most difficult site I've ever encountered when searching for parts. ________________________________________________________________________________
Date: Feb 04, 2007
Dave, I received one #20 and #30 bit with my rudder kit many years ago. My drill fell one day and broke off the end of the #30 bit, Thus I went to Sears Hardware and bought an extra of each, by the way I resharpened and still use the shortened bit. I still have them and use them. The trick is to either learn how to sharpen then freehand or buy a sharpener. Other than breakage or loss a single drill bit will last for the whole project. You will want to invest in the right angle and long bits to reach those places where you just can't get the drill in. Tim Shankland Dave VanLanen wrote: > Can anyone who has finished their aircraft give me a ballpark idea of > how many holes I should typically be able to get out of a hi-moly > drill bit (#30 and #20)? > > Thanks, > > Dave > > ________________________________________________________________________________
Date: Feb 04, 2007
Hello fellow listers: Just a comment on resharpening these small drill bits... I don't believe the typical hobbyist can accurately resharpen drill bits except with a middle to high end sharpener, and with the capital expense involved, why bother? Freehand sharpening can only approximate the angles involved (yes, I agree small drill bits do not have to involve reducing the web and other intricate angles) and with the best of freehand sharpening, you will only get one of the cutting edges working at a time. Not a good practice where the goal is nice, round holes. For amateurs like me and others who do not have the benefit of being, or working with machinists with a LOT of gray hair earned with years of trying to accurately resharpen drill bits, I say use 'em & pitch 'em. They are cheap enough; when they stop cutting quickly, toss 'em. That being said, with high cutting speeds and low feeds (light pressure on the drill), a good quality drill bit cuts LOTS of holes. Tracy Smith Naugatuck, CT 601xl N458XL (reserved) In a message dated 2/4/2007 11:09:27 AM Eastern Standard Time, tshank(at)core.com writes: Dave, I received one #20 and #30 bit with my rudder kit many years ago. My drill fell one day and broke off the end of the #30 bit, Thus I went to Sears Hardware and bought an extra of each, by the way I resharpened and still use the shortened bit. I still have them and use them. The trick is to either learn how to sharpen then freehand or buy a sharpener. Other than breakage or loss a single drill bit will last for the whole project. You will want to invest in the right angle and long bits to reach those places where you just can't get the drill in. Tim Shankland Dave VanLanen wrote: Can anyone who has finished their aircraft give me a ballpark idea of how many holes I should typically be able to get out of a hi-moly drill bit (#30 and #20)? Thanks, Dave ________________________________________________________________________________
Subject: Remove the wings off CH601UL
Date: Feb 04, 2007
He My name is Ron Smit live in chilliwack B.C. Canada, I recently bought a Zenair Zodiac 601 ul in Edmonton Alberta We are going to pick her up on the 16th of this month . My question to this forum is do I have to pay attention to a particular area when removing the wings, and how do I remove those wings? thanks for Your reply . regards Ron Smit. -------- lets go flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92848#92848 ________________________________________________________________________________
Date: Feb 04, 2007
Subject: follow-up on parts search
Tommy, Regarding the Lockwood web site: You got that right; I gave up trying to use it. Lockwood is probably the most knowledgeable 912 dealer in the U.S., but the "parts search" sucketh. He produces a good print catalog. Request one. Zed/701/912/90+%/etc/please archive ________________________________________________________________________________
Date: Feb 04, 2007
Hi Tracy, I respect your position on resharpening drill bits, as well as your analysis of some of the issues involved. On the other hand, I think there is something to be said for the other approach too. (Admittedly, I do have lots of grey hair.) Building an all metal airplane is mostly an exercise in drilling holes. For me, that means focusing on the hole drilling process is a good way to improve your building experience. It is also an area where a little learning goes a long way. (Remember, education is one of the primary reasons we are supposed to be building these contraptions.) I decided to learn "Free hand" drill bit resharpening a couple of years ago -- about the same time I started work on my XL. I found it relatively easy to turn a dull bit into one that drilled holes better than before. OK, maybe the angles on the bit didn't end up the same as they started. Does this really matter when holding a contest between tool steel and aluminum? Indeed, my reading on the web told me a drill should have a sharper angle for drilling soft materials than the one provided on store-bought drills which are designed to drill steel parts. My recommendation for anyone new to the drill sharpening process is this: Start with new bits. When they get dull put them aside and use a new one. After a while you will have a small collection of dull bits. You can try to resharpen these yourself. You can also get someone who knows how to do it to show you. Or, you can just throw them out. If you try to learn how to do this yourself, the only possible loss is some time. Perhaps you will renew the bits or perhaps you won't. I think there are three "Secrets" to drill bit sharpening. The first is to have a grinding wheel with a really flat surface and sharp corners at the edges. The second is to start holding the bit at the same angle as you do each side of the point. The third is to "Scrape" the bit upward as you finish the point to get the rake angle needed to make the drill actually remove metal. The last part (not a secret at all) is to inspect the point - if it comes out with the point in the middle of the bit then both sides are the same. If you try twisting the bit into a piece of wood it should dig in. In this case you have a nice new bit to make more holes in your airplane. Of course anyone can say this is too hard to learn or not worth the effort. Still, if you do you will feel good about learning a new skill and also find yourself a little better off when it comes to having the tool you need when you need it. Best regards, Paul XL fuselage >For amateurs like me and others who do not have the benefit of >being, or working with machinists with a LOT of gray hair earned >with years of trying to accurately resharpen drill bits, I say use >'em & pitch 'em. > ________________________________________________________________________________
Date: Feb 04, 2007
Subject: Re: Remove the wings off CH601UL
Hi Ron, Congratulations, The UL is similar to the HD. Detachment of the wings is found at the wing joint covers where the wing bends. There are screws front center and trailing that secure the wing joint covers, usually a dozen screws holding the wing joint in place along the edges. Once removed, the electrical wires and pitot lines should be marked and separated at this joint. If provisions haven't been made, cut them after marking and duct tape them secure at the ends of the wings. You should have a screw at the rear spar that can be removed to separate each spar. It may have a plate nut or a self locking nut holding it. The front spar has 4 AN-6 bolts (3/8-inch) that secure the wings to splice plates each side. After these have been loosened, get a spare set of hands to hold the outboard end of the wing and push the bolts out. Then provide support both ends of each wing and slide the wing straight out from between the splice plates. The angles top and bottom will guide the wing off, but don't rely on them for supporting the weight of the wing with the bolts removed. If you're transporting the wings any distance, by truck internally, make hangars with carpet that will support the wings at the nose to evenly carry the structure. If you've got time, make a wing jig to support the wings on foam the length of the nose. If external trailer, better to lay them flat on soft foam support large area, 20% of the wing. Again, foam rented from an upholstery shop might do as they have slabs of the stuff. Drain your tanks of fuel, remove the battery and pitot tubes from the wing if possible and anything else that might be sensitive to roads. This advice presumes a lot on your mode of transport, but if you have a lot of ratchet straps, 8 - 10 should get you there. I have below, several links that suggest methods, but you may need a longer trailer for the wings. I did this in two trips. http://www.macsmachine.com/images/wing/spliceplates/full/splice-plate-bolts-and-spar.gif http://www.macsmachine.com/images/completion/full/viewleftwingjoint.gif http://www.macsmachine.com/images/TJH/HScentersection/full/wg2rack2.gif http://www.macsmachine.com/images/tjh/hscentersection/full/trailerwinching2.gif http://www.macsmachine.com/images/tjh/hscentersection/full/loadedcenter.gif http://www.macsmachine.com/images/tjh/hscentersection/full/Zenith-on-the-roadh.jpg http://www.macsmachine.com/images/tjh/hscentersection/full/zenith-to-airport.jpg Good luck, Larry McFarland Canatukker wrote: > > He My name is Ron Smit live in chilliwack B.C. Canada, > I recently bought a Zenair Zodiac 601 ul in Edmonton Alberta We are going to pick her up on the 16th of this month . > My question to this forum is do I have to pay attention to a particular area when removing the wings, and how do I remove those wings? > thanks for Your reply . regards Ron Smit. > > -------- > lets go flying > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=92848#92848 > > > ________________________________________________________________________________
Date: Feb 04, 2007
I have found one of the easiest and most accurate means of "touching up" a drill bit is a cut off wheel in my hand held Dremel. The side of the cut off wheel makes for an ultra smooth surface to work on, and because it is hand held, I can walk over to my magnifier light (have gray hair too) and steady my hands on my chest. I have pretty good results with this method. I have a couple of long drills, which I made using a quarter inch steel rod that I drilled holes in the end then brazed a smaller bit in the end. I don't want to go through the hassle of reattaching drills to these extensions so a brief touch on the cut off wheel brings them back to life. Granted using the side of the fragile cut off wheels might not be how they were intended to be used but so far I have not broken a single wheel sharpening a bit. Dick Neitzel Sayner, WI 701 Jab 2200 N963WB ________________________________________________________________________________
Subject: Re: Final Engine Selection
Date: Feb 04, 2007
That oughta be great on gas. -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92895#92895 ________________________________________________________________________________
Date: Feb 04, 2007
Larry thanks verry much for the info I will have a long trailer as my new bird is an tail dragger I.m going to need 17 ft I think. if anyone has the exact messurement from main to tail wheel I would like to hear it .thanks again ,I can hardly wait to get her home From a rainy Chilliwack B.C. Ron smit p.s. here an link to some pic. http://s30.photobucket.com/albums/c325/smitfire/?action=view¤t=1170640161.pbw -------- lets go flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92896#92896 ________________________________________________________________________________
Subject: Re: Updates on Zenith builders web site
Date: Feb 05, 2007
Hello Craig, I built and fly a CH640 (mine is the red/white one on the Zenair update page). They used to have a rudder build class at AMD in Eastman, GA, but I don't know if that is still available. Support for the 640 comes mainly from Zenair directly, or AMD. If you have any questions, feel free to contact me directly at stephen.adams(at)hcahealthcare.com. Steve Adams N621J Read this topic online here: http://forums.matronics.com/viewtopic.php?p=92938#92938 ________________________________________________________________________________
Date: Feb 05, 2007
One thing I have not seen mentioned in this thread has been the Drill Doctor. The Drill Doctor will sharpen a drill bit to a perfect point in under a minute. You will be surprised what a difference it makes to always have a sharp bit. In addition to getting better holes, there is a time savings in drilling every hole with a sharp bit. It is designed to make a perfect point and removes a minimum of metal doing it. I have had one for years and have all but stopped buying drill bits. I drill a lot of steel, so drill wear is a constant issue for me. They make several different versions starting at under $100. I got the cheap one but in retrospect, I should have opted for the lowest price one that has a replacable diamond wheel. I can tell that I am getting near the point of replacing it due to the wheel wearing out. Regards, Bob Tezyk Midlothian, TX 601XL / 3300 S/N 6-6777 Rudder Complete, Took delivery of the QB kit. bob(at)eaglesnestestates.org http://neo.datamatrix.com/eaglesnestestates/index.php?option=com_rsgall ery2&Itemid=28&catid=23 ________________________________________________________________________________
Subject: FW: Rotax 912UL for sale
Date: Feb 05, 2007
Just passing this on in case someone is looking for a core or parts or project... Contact Dave at davedent(at)comcast.net for more information and pictures if interested. I think that he is asking $5K or best offer. I am only forwarding this on and have no more information than what is below. ---------------------------------------------------------------------------- ---------------- ...the engine has just under 100 hrs on it. It was used only as a test cell engine. In the cell it was used to see if we could get 80hp at 80,000 ft. We did it with three turbos and electronic ignition and fuel injection. We saw 65hp at 90,000. After the test it was left in the cell for a good six months and never touched again till we put it in storage in a transportainer. Now it is in my hangar. It is as we took it out of the cell, without the exhaust and intake system installed. If anyone wants it they can have the removed systems. Along with the engine. It will come with a very expensive oil pump and a bunch of other hardware. The engine would make a very good short block. ---------------------------------------------------------------------------- --- ________________________________________________________________________________
Date: Feb 05, 2007
If you have a carb you can get carb ice. You may have to be a member but here is an excellent article on the subject with a great chart showing how ice even if the ambient temp is over 100. http://flighttraining.aopa.org/members/student_pilot/presolo/articles/58.cfm [quote="arno7452(at)bellsouth.net"]Dear Listers, I am installing 912 ULS on a CH 701. Due to its cost and perhaps debatable utility, I have been advised to leave it off. I sure would like to hear some comments from the list as to whether this is a good approach. I am taking lessons in an Evektor Sportstar with 912S engine. So far, we have never used the carb heat. I am flying in Goldsboro, NC. That is about 60 miles east of Raleigh. As I recall flying the Continental O-200, we used carb heat anytime under 2K rpm. The POH on the Sportstar only requires carb heat if you suspect icing. i.e. engine starting to lose power and run rough. Many thanks, Ken Arnold Pikeville, NC Building CH701 - hoping to fly it in May, 07 > [b] -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=93013#93013 ________________________________________________________________________________
From: "Dave Ruddiman" <pacificpainting(at)comcast.net>
Date: Feb 05, 2007
I'm glad someone brought up the "Drill Doctor". I've thought about getting one for years and never did. I haven't always had the best of luck with what seems like it may be some kind of gimmick devise. I don't know about other people, but I have a lot more drill bits than the ones I use on aluminum. Larger bits are a little more expensive to throw away when they get dull. ----- Original Message ----- From: Bob Tezyk To: zenith-list(at)matronics.com Sent: Monday, February 05, 2007 8:28 AM Subject: Zenith-List: Drill Bit Durability One thing I have not seen mentioned in this thread has been the Drill Doctor. The Drill Doctor will sharpen a drill bit to a perfect point in under a minute. You will be surprised what a difference it makes to always have a sharp bit. In addition to getting better holes, there is a time savings in drilling every hole with a sharp bit. It is designed to make a perfect point and removes a minimum of metal doing it. I have had one for years and have all but stopped buying drill bits. I drill a lot of steel, so drill wear is a constant issue for me. They make several different versions starting at under $100. I got the cheap one but in retrospect, I should have opted for the lowest price one that has a replacable diamond wheel. I can tell that I am getting near the point of replacing it due to the wheel wearing out. Regards, Bob Tezyk Midlothian, TX 601XL / 3300 S/N 6-6777 Rudder Complete, Took delivery of the QB kit. bob(at)eaglesnestestates.org http://neo.datamatrix.com/eaglesnestestates/index.php?option=com_rsgall ery2&Itemid=28&catid=23 ________________________________________________________________________________
Date: Feb 05, 2007
Looks like there are at least three approaches to carb heat for the 912S. Heated air, carb heat air box system. Hot coolant flow, see in Lockwood catalogue. Electric heat, again in Lockwood catalogue. Any experience or comments please. ________________________________________________________________________________
Subject: Drill Doctor
Date: Feb 05, 2007
I have had the Drill Doctor XP2 for about 2 years. I have not had any problems with it at all. It does have a replaceable grinding wheel, but can hardly see any wear on the wheel and have done a lot of sharpening of #30 and #40 drills. It really does a great job, nicely centered grind on the flutes every time. I also do a side cut on the flutes, it does that as a second step in the sharpening process. Makes the drills go thru aluminum just like it was not even there. I do use a high speed small air motor to drive the drills. It comes with a "training" DVD that takes you through the entire process and even shows you how to service your tool. They have them at Home Depot and sometimes they have a $20.00 rebate slip right along with them. Got mine that way! Highly recommended! George ________________________________________________________________________________
Subject: 801 Bottom Fuselage Skin
Date: Feb 05, 2007
I know this has come up for some of the other ZAC planes, but when I took the bottom fuselage skin for my 801 out of the box I discovered that it is .016. I just assumed it would be .025. It seems like it should be heavier given the kind of use the plane was designed for. Any thoughts, anyone? Dave in Salem ________________________________________________________________________________
Subject: Decision on Carb Heat for Rotax 912 ULS!!!!!!
Date: Feb 05, 2007
Listers, Many thanks for all the good comments regarding Carb Heat. I have discussed the issue with Lockwood and Zenith in Mexico. Here is summary of discussion with Zenith: The cowling for the CH701 maintains a relatively warm environment. If the Rotax airbox is not installed, NO carb heat is required. So, my CH701 will be using the new cowling and there will be no airbox. So, I will not install carb heat. These comments are based on discussion with Sebastian Heintz at Zenith today 2/6/2007. Sebastian indicates there are hundreds of Rotax 912s that do not have carb heat. They are doing nicely. He also estimates about 3 hp is lost by not using the airbox to draw in cold air. To the best of my knowledge, I received no comments from Zenith owners flying behind the 912 without carb heat. The carb heat upgrade can be retrofitted at a later date. It is a collar that fits on the carb and circulates cooling fluid. Fairly simple install I'm told. Again, many thanks for your interest and comments. Ken Arnold Pikeville, NC CH701 QB in process ________________________________________________________________________________
Subject: Re: Don't follow my lead
Date: Feb 05, 2007
Only needed to make one test strip the directions on CH601.org work great. -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=93119#93119 Attachments: http://forums.matronics.com//files/le_skin_correct_003_453.jpg ________________________________________________________________________________
Subject: Bing carb on Jab3300
From: "chris Sinfield" <chris_sinfield(at)yahoo.com.au>
Date: Feb 05, 2007
I found this on the Yahoo Jab Engine site any one had similar problems as the fuel pump that was sent with my XL kit was the 40105 Chris.. frm the site..... first engine start went well except that i had fuel leaks from the bing carb. i have a facet 40105 electric fuel pump that really overpowered the needle valve controlled by the floats. this is the pump i understand is used by many jab owners. after a short engine run without the elec. pump i shut the engine down as the manual pump was also causing fuel to leak. leaks were coming out the vent for the fuel bowl. i spoke to bing and was told that these needle assemblies come with several spring stiffnesses. i had the weakest spring assembly. bing is sending me the medium stiffness spring. bing said the stiffest spring is too stiff and not offered any more. bing said a pulolator pressure regulator is commonly installed in the fuel line. bing also said they get a lot of calls for the same problem from a lot of 40105 owners. maybe i should be looking at a facet pump of around 2-2.5 lbs. i believe they are made and would be more desireable because these lower pressured pumps have no check valves. thus no possible valve to stick. does anyone have anything to add to this or offer any fuel pressure info? and also, jim of pacific jabiru was helpful and patient with my phone calls as all of this was going on during the first start attempt. [Question] [Question] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=93139#93139 ________________________________________________________________________________
Date: Feb 06, 2007
Dave: The .016 works fine. Just be careful about dropping tools on it. I think that it is a strength/weight issue. In this type of construction the skin carries much of the loads. The belly stresses are such that some weight can be saved with the .016. Tom Faulkner N801TP 80 hrs. ________________________________________________________________________________
From: "David Austin" <daveaustin2(at)can.rogers.com>
Subject: Re: Decision on Carb Heat for Rotax 912 ULS!!!!!!
Date: Feb 06, 2007
Ken, I've flown my 601 912 for 14 years and never had any icing indication. No carb heat. This is a statement of fact, not a recommendation. I'm in Toronto Canada. Tailwinds. Dave Austin 601HDS - 912, Spitfire Mk VIII ----- Original Message ----- From: Ken Arnold To: Zenith List Sent: Monday, February 05, 2007 8:20 PM Subject: Zenith-List: Decision on Carb Heat for Rotax 912 ULS!!!!!! Listers, Many thanks for all the good comments regarding Carb Heat. I have discussed the issue with Lockwood and Zenith in Mexico. Here is summary of discussion with Zenith: The cowling for the CH701 maintains a relatively warm environment. If the Rotax airbox is not installed, NO carb heat is required. So, my CH701 will be using the new cowling and there will be no airbox. So, I will not install carb heat. These comments are based on discussion with Sebastian Heintz at Zenith today 2/6/2007. Sebastian indicates there are hundreds of Rotax 912s that do not have carb heat. They are doing nicely. He also estimates about 3 hp is lost by not using the airbox to draw in cold air. To the best of my knowledge, I received no comments from Zenith owners flying behind the 912 without carb heat. The carb heat upgrade can be retrofitted at a later date. It is a collar that fits on the carb and circulates cooling fluid. Fairly simple install I'm told. Again, many thanks for your interest and comments. Ken Arnold Pikeville, NC CH701 QB in process ________________________________________________________________________________
Subject: Re: Bing carb on Jab3300
Date: Feb 06, 2007
The Facet 40105 has been working fine on my XL/Jab3300 for over 200 hours. The Bing also has given me no problems and has been working smoothly up to 12,500 ft. (max I have cruised at to date) For info, below are excerpts from my POH on the fuel system in my XL. Tony Graziano 601XL; N493TG, 204 hrs -------------------------------------------- B. FUEL SYSTEM The engine is fitted with an altitude adjusting Bing Carburetor. The throttle is controlled via a cable to the carburetor. The carburetor has a choke for cold starting and is controlled via a cable to the choke. Fuel is screened by a small finger strainers in the fuel tanks, a gascolator located on the aircraft C/L below the cockpit before the rudder peddles and just prior to the electric fuel pump, and filtered between the firewall and the mechanical fuel pump. There is no priming system. Fuel travels from the tanks to a fuel selector, to the gascolator, through a solid state check -valved free flow electronic fuel pump, through a fuel flow sensor, through the firewall, through a fuel filter, to the engine mechanical pump and then to the carburetor where it is metered to the engine intake manifolds. The Bing Carburetor has incorporated the Fuel Economy Modification IAW Jabiru JSL002-1 3. FUEL SYSTEM A. FUEL TANKS B. FUEL SELECTOR C. GASCOLATOR D. FUEL PUMPS E. APPROXIMATE FUEL BURN RATES at CRUISE F. FUEL TANK DIPSTICK READINGS A. FUEL TANKS N493TG has four 12-gallon fuel tanks, two in each wing. The fuel filler is on the outer portion of the tanks and the wing dihedral forces fuel to the inner portion of the tank. Each tank has a VDO 10 - 180-ohm fuel gauge float type sender installed in the inboard cell of the tanks. Each tank also has a standard fuel drain on the aft rear section of the tank for taking fuel samples and fuel draining. Each tank contains approximately 1/4 gallon of unusable fuel based on the position of the fuel pickups. The fuel caps latch should face aft when installed to prevent airflow from unlatching the cap in-flight. The O-rings of the latches should be lubricated annually. WARNING Static electricity can cause a fire when fueling or de-fueling if proper grounding procedures are not used. B. FUEL SELECTOR The fuel flows from each fuel tank to an ANDAIR P/N FS20F8-F, five-way fuel selector on the center console. The selector can select either RIGHT tank, LEFT tank, RIGHT AUX tank, LEFT AUX tank or OFF. When selecting a fuel tank, ensure the selector is in the detent and a positive click is felt. WARNING Avoid switching fuel tanks at low altitude or just prior to takeoff in the event of a selector malfunction. C. GASCOLATOR After the fuel selector the fuel flows to the gascolater. The gascolator has a fine screen for fuel filtering and a bowl to allow water to settle. There is a quick drain on the bottom of the gascolator to allow taking fuel samples during preflight. The gascolator is covered externally by an aerodynamic shaped FOD guard to protect the gascolator from any foreign objects that may be tossed up by the nose wheel or prop. This guard permits access to fuel sampling the gascolator during preflight and can be removed to allow removal of the gascolator bowl and screen filter during inspections. WARNING Ensure the gascolator drain is fully closed after taking a fuel sample. Failure to properly close the fuel drain can cause leakage causing fuel starvation. D. FUEL PUMPS A FACET P/N 40105, solid state, checked valved, electronic fuel pump is installed on the centerline of the cockpit floor just forward of the gascolator. Another mechanical fuel pump is installed on the engine. Prior to starting, the electronic fuel pump should be turned on for about 10 seconds and then turned off. The electronic fuel pump should be used for take off and landing and be OFF during cruise. -------- > Subject: Zenith-List: Bing carb on Jab3300 > From: "chris Sinfield" <chris_sinfield(at)yahoo.com.au> > > > I found this on the Yahoo Jab Engine site any one had similar problems as > the fuel > pump that was sent with my XL kit was the 40105 > Chris.. > > frm the site..... > > first engine start went well except that i had fuel leaks from the bing > carb. i have a facet 40105 electric fuel pump that really overpowered > the needle valve controlled by the floats. this is the pump i understand > is used by many jab owners. after a short engine run without the elec. > pump i shut the engine down as the manual pump was also causing fuel to > leak. leaks were coming out the vent for the fuel bowl. > i spoke to bing and was told that these needle assemblies come with > several spring stiffnesses. i had the weakest spring assembly. bing is > sending me the medium stiffness spring. bing said the stiffest spring is > too stiff and not offered any more. bing said a pulolator pressure > regulator is commonly installed in the fuel line. bing also said they > get a lot of calls for the same problem from a lot of 40105 owners. > maybe i should be looking at a facet pump of around 2-2.5 lbs. i believe > they are made and would be more desireable because these lower pressured > pumps have no check valves. thus no possible valve to stick. > does anyone have anything to add to this or offer any fuel pressure > info? > and also, jim of pacific jabiru was helpful and patient with my phone > calls as all of this was going on during the first start attempt. > > > [Question] [Question] > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=93139#93139 > > ________________________________________________________________________________
Subject: Re: 801 Bottom Fuselage Skin801 Bottom Fuselage Skin
Date: Feb 06, 2007
All, I wrote Zenith on this very subject. See the answer Attached below. Regards, Brad > Zenith, I bought my kit in 2000. I am assembling the > 'Rear Fuselage Lower skin -- 8F2-3A' which is 0.016 in thickness. > This seems extremely thin for the purpose. > Has there been an upgrade to thicker material on the latest revisions? > > I am concerned that the thin skin with few supports will oilcan. Any > problems with this? > > If so, can I replace with .025 --or-- add 'L's to arrest the oil > canning? ANSWER FROM ZENITH: Ref. 8F2-3A there is no change to the part, 6061-T6 material thickness t=.016" There would be no problem replacing the skin with t=.025" If you are still concerned about oil canning than you could also add L angles like on the side skins. Nick Heintz Zenith Aircraft Company email: support(at)zenithair.com ________________________________________________________________________________
Subject: Balistic Chute
Date: Feb 06, 2007
Here is a press release I received that might be of interest. Is anyone putting a Balistic Rcovery Chute on their 601's? AMD INSTALLS FIRST BRS PARACHUTE IN ZODIAC 601XL Eastman Georgia February 01, 2007: Aircraft Manufacturing & Development Co. (AMD) is pleased to announce the first BRS (Ballistic Recovery Systems) parachute installation in a Zodiac 601XL - SLSA. The aircraft was certified on January 30th 2007 at the production facilities in Eastman, Georgia. "Flying the Zodiac is super fun. Its excellent maneuverability and visibility are great features. Pilots and passengers are always looking at increasing safety features and the BRS parachute provides that added security." stated John Degonia, AMD's sales manager. The Zodiac 601XL production Light-Sport Aircraft is based on the Zodiac CH 601 series design by aeronautical engineer Chris Heintz. The all-metal Zodiac has been popular with kit aircraft enthusiasts since 1984 (with more that 1,000 Zodiac aircraft flying worldwide), and since 2005 as an S-LSA (factory produced Light-Sport Aircraft) manufactured in Eastman, Georgia by AMD. With the addition of the BRS parachute option, the Zodiac 601XL boasts more available safety features than any other Light Sport Aircraft available on the market today, including: AMSAFE SRS airbag seatbelts, lightning protection (available on the IFR certified Zodiac XLi model), Tetra foam seat cushions (absorbs "g" loads on a hard landing), super tough nose and main gear system, classic all-metal construction, FAR33 certified aircraft engine (Continental 0-200), Sensenich propeller and more. For more information: Aircraft Manufacturing & Development Co. (AMD): www.newplane.com ________________________________________________________________________________
Date: Feb 06, 2007
Re: Zenith-List: 801 Bottom Fuselage Skin801 Bottom Fuselage SkinBrad, So, what did you do? Dave ----- Original Message ----- From: Maynard, Brad To: zenith-list(at)matronics.com Sent: Tuesday, February 06, 2007 8:58 AM Subject: Re: Zenith-List: 801 Bottom Fuselage Skin801 Bottom Fuselage Skin All, I wrote Zenith on this very subject. See the answer Attached below. Regards, Brad > Zenith, I bought my kit in 2000. I am assembling the > 'Rear Fuselage Lower skin -- 8F2-3A' which is 0.016 in thickness. > This seems extremely thin for the purpose. > Has there been an upgrade to thicker material on the latest revisions? > > I am concerned that the thin skin with few supports will oilcan. Any > problems with this? > > If so, can I replace with .025 --or-- add 'L's to arrest the oil > canning? ANSWER FROM ZENITH: Ref. 8F2-3A there is no change to the part, 6061-T6 material thickness t=.016" There would be no problem replacing the skin with t=.025" If you are still concerned about oil canning than you could also add L angles like on the side skins. Nick Heintz Zenith Aircraft Company email: support(at)zenithair.com ________________________________________________________________________________
Subject: Sheet metal brake
Date: Feb 06, 2007
Is anyone familiar with the "Central Machinery" brand of sheet metal brake sold by Harbor Freight, part number 46508-1VGA? It is a 40" brake that looks solid enough for aluminum sheet metal (advertises up to 16 gauge steel), and is only $100. I'm interested because I just started to scratch build, and I don't have a brake yet. I will be building my own 8 ft brake when I need it, but this seems like it would be very nice to have in the shop; handy, light, and maneuverable. (and cheap) I hope someone out there has at least tried it. I'm interested if it puts a radius on the bend, and if not, if it's possible to modify it to put a radius on it. Ryan ________________________________________________________________________________
Date: Feb 06, 2007
>Is anyone putting a Balistic Rcovery Chute on their 601's? Scott sure is: www.cooknwithgas.com/BRS.html -- Craig ________________________________________________________________________________
Date: Feb 06, 2007
The 30 inch brake from HF has worked well. I replaced the top steel piece with a piece of MDF with an 1/8th inch radius on it and an angle of about 60-70 degrees to allow for spring-back on 90 degree bends. www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=41311 I also bought a conventional box brake from Grizzly. I've tried a number of tricks but haven't been able to make it put a nice 1/8 inch radius on my bends. Some have recommended wrapping the tip of the upper blocks in a couple layers of .016 but the radius that yielded was still too tight. Next I'll try clamping a 1/4 inch rod along the edge as I bend. -- Craig ________________________________________________________________________________
Date: Feb 06, 2007
From: Administrator <admin(at)arachnidrobotics.com>
Subject: Re: Sheet metal brake
No info on that particular brake, but ANY brake you buy will need to have a radius machined into it, or used with a 'bend wrapper'. The bend wrapper (or whatever else you'd like to call it) is nothing more than a strip of .040 aluminum bent on the brake, and left there. Just tape it to the top die/punch and go on to bend your parts. The .040 stip essentially increases the bend radius of the original punch. Depending on the existing radius, and the effectiveness of your brake, you may have to use several strips to achieve the correct radius. This sounds like a half-@$$ed method, but it's the same method used in multi-millin dollar production shops to achieve a non-standard radius. just use double sided tape to hold the strip tot he punch. If you were careful, you could probably achieve a satisfactory radius on the stock brake parts using a belt sander. Just be ready to spend another $100 if you're not careful. Is anyone familiar with the "Central Machinery" brand of sheet metal brake sold by Harbor Freight, part number 46508-1VGA? It is a 40" brake that looks solid enough for aluminum sheet metal (advertises up to 16 gauge steel), and is only $100. I'm interested because I just started to scratch build, and I don't have a brake yet. I will be building my own 8 ft brake when I need it, but this seems like it would be very nice to have in the shop; handy, light, and maneuverable. (and cheap) I hope someone out there has at least tried it. I'm interested if it puts a radius on the bend, and if not, if it's possible to modify it to put a radius on it. Ryan ________________________________________________________________________________
Date: Feb 06, 2007
Remember, you're looking for a .125" radius on the brake. Two layers of .016" material is still only slightly larger than a .032" radius. The thin .016 conforms too tightly to the original brake radius. You'll find that a couple of strips of .040 will usually be just right. If nothing else, use three stips (.040+.040+.040= 1/8" radius). Hope that helps... The 30 inch brake from HF has worked well. I replaced the top steel piece with a piece of MDF with an 1/8th inch radius on it and an angle of about 60-70 degrees to allow for spring-back on 90 degree bends. www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=41311 I also bought a conventional box brake from Grizzly. I've tried a number of tricks but haven't been able to make it put a nice 1/8 inch radius on my bends. Some have recommended wrapping the tip of the upper blocks in a couple layers of .016 but the radius that yielded was still too tight. Next I'll try clamping a 1/4 inch rod along the edge as I bend. -- Craig ________________________________________________________________________________
Date: Feb 06, 2007
Hi Ryan, I haven't seen that particular model brake from Harbor Freight, but I bought one of the smaller ones they sell. The price is quite low, and the picture in the downloaded assembly manual makes it look similar to the smaller ones. It says it is limited to 90 degree bends. On the smaller one, I was able to grind the stops so it would go farther and allow you to make an actual 90 degree bend after the snap back. The hold-down bar seems to be designed for no radius - just like the smaller model. I started with one of the small ones (maybe 18") and played around with it for a while. I wound up buying a 24" one from Grizzly which required extensive modifications to work at all. However, the Grizzly tool was much heavier and almost able to clamp an 18 inch piece of aluminum well enough to actually make a good bend. I tried a couple of different ways to get the 1/8" radius required for most parts on our planes. I tried gluing a 1/4" round rod to a flat piece of metal and putting it under the supplied hold down bar. It didn't last long. The final winner was a piece of 1/4" aluminum cut from an extrusion which already had the rounded edge needed when it came from the store. This has worked well. I don't think you will find the 4 foot brake from Harbor freight to be very useful. On the other hand, the smaller ones which cost a lot less (around $30) would make a great first brake for you to fool around with and learn the ropes. After making a few test parts with the Harbor Freight brake and learning how to form the 1/8" radius you need you will be in a much better position to build your 8 or 12 foot brake. You might also decide that the larger one is not worth the trouble and use a local shop to do the long bends on proper hydraulic machines. Good luck, Paul XL fuselage At 11:36 AM 2/6/2007, you wrote: > > >Is anyone familiar with the "Central Machinery" brand of sheet metal >brake sold by Harbor Freight, part number 46508-1VGA? It is a 40" >brake that looks solid enough for aluminum sheet metal (advertises >up to 16 gauge steel), and is only $100. > >I'm interested because I just started to scratch build, and I don't >have a brake yet. I will be building my own 8 ft brake when I need >it, but this seems like it would be very nice to have in the shop; >handy, light, and maneuverable. (and cheap) > >I hope someone out there has at least tried it. I'm interested if >it puts a radius on the bend, and if not, if it's possible to modify >it to put a radius on it. > >Ryan > ________________________________________________________________________________
Subject: Re: Balistic Chute
Date: Feb 06, 2007
Yes; count me in. I'm not ready yet, pplanning on being further down t he road beofre starting on it. Got their drawings for the installation , and was pretty impressed. The only thing I didn't care for was the e sthetics of having the straps show, so I am planning to do a false sid e skin to cover them, riveted on the bottom and held at the top and si des with something like silicone caulking, that will tear off easily. Also to cover the wretched contours where I screwed up. Not that I re ally expect CH's design to come apart, more on the order of "just beca use I can". =0A=0APaul Rodriguez=0A601XL/Corvair=0A=0A =0A=0A=0A=0A=0A ----- Original Message ----- =0A Fr om: Craig Payne =0A To: zenith-list (at)matronics.com =0A Sent: Tuesday , February 06, 2007 1:51 PM=0A Subject: RE: Zenith-List: Balistic ne" >=0A =0A >Is anyone putting a Balistic Rcovery Chute on their 601's?=0A =0A Scott sure is:=0A=0A www.cooknwithgas.com/BRS.html=0A=0A -- Craig=0A=0A ======================= ======================= ======================= ======================= ======================= =0A=0A=0A=0A ________________________________________________________________________________
Date: Feb 06, 2007
Ryan, You might want to take a look here for some good ideas: My experience with the wrapping metal around the nose of the leaf brakes is, the nose piece needs to be adjustable fore and aft. If there is no adjustment it make it real hard to get bends to and over 90 degrees. -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=93340#93340 ________________________________________________________________________________
Date: Feb 06, 2007
Ryan, I have a similar Harbor Freight brake: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=91012 This has come in very handy several times. I placed a .040 cover over the upper clamp, and have no radius issues. The math performed earlier is good for math class, but in reality, the .040 is not going to exactly follow the edge on the upper clamp unless you beat it that way with a hammer. You obviously don't plan to bend the spar with this brake. -For just about anything else, it works great. BTW, the brake I use at the CNC machine shop for aviation STC'd equipment uses the same .040 sheet for radius. It works... VR/ Brandon Tucker 601 HDS / TD / Corvair 61 hours Cheap talk? ________________________________________________________________________________
Date: Feb 06, 2007
Ryan- The Harbor Freight brakes are well worth the money, but to do any serious work, you need something larger than 40". I personally have an 18" for taking care of the little stuff. For bigger work, (Especially if you intend to scratchbuild) check out the "Home Depot" brake in the archives or on 601.org. Of course, there are those of us that are still waiting for the plans for a really neat 48" brake promised to us years ago by Homebuilder Helper. Forgot all about that! Oh Zodie.......... Bill Naumuk HDS Fuselage Townville, Pa ----- Original Message ----- From: "Ryan Vechinski" <brothapig(at)HOTMAIL.COM> Sent: Tuesday, February 06, 2007 2:36 PM Subject: Zenith-List: Sheet metal brake > > > Is anyone familiar with the "Central Machinery" brand of sheet metal brake > sold by Harbor Freight, part number 46508-1VGA? It is a 40" brake that > looks solid enough for aluminum sheet metal (advertises up to 16 gauge > steel), and is only $100. > > I'm interested because I just started to scratch build, and I don't have a > brake yet. I will be building my own 8 ft brake when I need it, but this > seems like it would be very nice to have in the shop; handy, light, and > maneuverable. (and cheap) > > I hope someone out there has at least tried it. I'm interested if it puts > a radius on the bend, and if not, if it's possible to modify it to put a > radius on it. > > Ryan > > > ________________________________________________________________________________
Date: Feb 06, 2007
Could you remove this e-mail address from your list please? This is my fourth request. Thank You. ----- Original Message ----- From: Administrator To: zenith-list(at)matronics.com Sent: Tuesday, February 06, 2007 2:36 PM Subject: Re: Zenith-List: Sheet metal brake No info on that particular brake, but ANY brake you buy will need to have a radius machined into it, or used with a 'bend wrapper'. The bend wrapper (or whatever else you'd like to call it) is nothing more than a strip of .040 aluminum bent on the brake, and left there. Just tape it to the top die/punch and go on to bend your parts. The .040 stip essentially increases the bend radius of the original punch. Depending on the existing radius, and the effectiveness of your brake, you may have to use several strips to achieve the correct radius. This sounds like a half-@$$ed method, but it's the same method used in multi-millin dollar production shops to achieve a non-standard radius. just use double sided tape to hold the strip tot he punch. If you were careful, you could probably achieve a satisfactory radius on the stock brake parts using a belt sander. Just be ready to spend another $100 if you're not careful. Ryan Vechinski wrote: Is anyone familiar with the "Central Machinery" brand of sheet metal brake sold by Harbor Freight, part number 46508-1VGA? It is a 40" brake that looks solid enough for aluminum sheet metal (advertises up to 16 gauge steel), and is only $100. I'm interested because I just started to scratch build, and I don't have a brake yet. I will be building my own 8 ft brake when I need it, but this seems like it would be very nice to have in the shop; handy, light, and maneuverable. (and cheap) I hope someone out there has at least tried it. I'm interested if it puts a radius on the bend, and if not, if it's possible to modify it to put a radius on ________________________________________________________________________________
Date: Feb 07, 2007
in germany it is cumpolsery to have a rescue system CZAW uses the BRS soft pack on the 601 xl Read this topic online here: http://forums.matronics.com/viewtopic.php?p=93401#93401 Attachments: http://forums.matronics.com//files/img_0161_150.jpg ________________________________________________________________________________
Date: Feb 07, 2007
I'm planning to put one in mine. I think I've heard all arguments in favor and against, my conclusion is still to go for it. William Dominguez Zodiac 601XL Plans Miami, Florida ----- Original Message ----- From: Craig Payne To: zenith-list(at)matronics.com Sent: Tuesday, February 06, 2007 1:51 PM Subject: RE: Zenith-List: Balistic Chute >Is anyone putting a Balistic Rcovery Chute on their 601's? Scott sure is: www.cooknwithgas.com/BRS.html ________________________________________________________________________________
Subject: Harbor Freight 40" Brake
Date: Feb 07, 2007
Regarding the 40" Harbor Freight brake, I have used that for fabricating parts for my 701 project for the past couple of years and it works great. To get a 1/8" radius I put a sheet of .016 in the brake, bent it over the edge and left it there. This will give you the 1/8" radius. This brake gives you the most utility for the money invested of any brake I have seen around. On another subject, I am planning to install an oil thermostat on my Rotax 912ul with the Skyshops firewall forward kit. Has anyone else done this, and if so, where did you end up putting the thermostat? George in Milwaukee 701 installing engine ________________________________________________________________________________
From: "Chris Lewis" <christopherlewis(at)earthlink.net>
Date: Feb 07, 2007
Bill - The link's been up for the "Zodie Rocket" brake for a while now. http://www.ch601.org/tools/brake_plans.htm I personally am building a large version of Dave Clay's brake right now (my take on the home depot brake worked great on .020 and .025, but slipped when trying to bend .032 spar doublers). I'll be adding some lifting cams made from the same recycled content outdoor lumber seen elsewhere (also built flanging dies from this stuff - works great) and I'll be adding a center tensioning bar as shown on Mark's brake. I hope to finish it this weekend and will post a pic if I can get r done. Enjoy! Chris in Seattle -------- 701 Scratch Builder Read this topic online here: http://forums.matronics.com/viewtopic.php?p=93425#93425 ________________________________________________________________________________
Date: Feb 07, 2007
Though I'm not planing on using a Rotax engine what makes them immune to carb ice? -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=93431#93431 ________________________________________________________________________________
Date: Feb 07, 2007
Subject:
I am looking for canopy latch ideas that include a lock. I would appreciate any plans or links from this always reliable list serv. Thanks. Bradford J. DeMeo 601 xl 80% done ________________________________________________________________________________
From: "Dirk Slabbert" <dirkslabbert(at)telkomsa.net>
Date: Feb 07, 2007
Both carb float bowls are cleverly placed in the hot airstream behind each bank of cyl's. Dunno about immune ..... Dirk The 2 prick 701. ----- Original Message ----- From: "Gig Giacona" <wr.giacona(at)cox.net> Sent: Wednesday, February 07, 2007 5:49 PM Subject: Zenith-List: Re: Decision on Carb Heat for Rotax 912 ULS!!!!!! > > Though I'm not planing on using a Rotax engine what makes them immune to > carb ice? > > -------- > W.R. "Gig" Giacona > 601XL Under Construction > See my progress at www.peoamerica.net/N601WR > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=93431#93431 > > > ________________________________________________________________________________
Subject: My Playground
Date: Feb 07, 2007
Hi List Got the winter blues? Project going slower than you would like? Well keep up the work even if it is just a little everyday. It is all worth it. See attachments John 601HD 912ul 236hrs and still loving it _________________________________________________________________ Get in the mood for Valentine's Day. View photos, recipes and more on your Live.com page. http://www.live.com/?addTemplate=ValentinesDay&ocid=T001MSN30A0701 ________________________________________________________________________________
Date: Feb 07, 2007
From: "Ron Butterfield" <ron.butterfield(at)gmail.com>
On 2/7/07, Brad DeMeo wrote: > > I am looking for canopy latch ideas that include a lock. I don't know how well this would adapt to a Zenith, but... A friend of mine with a Cozy had his canopy latch only exposed to the inside, then made an access door that had a key lock on it. You would unlock the access door, reach in, and unlatch the canopy. -- Regards, RonB ________________________________________________________________________________
From: "David Mikesell" <skyguynca(at)skyguynca.com>
Subject: Rotax 583 engine package
Date: Feb 07, 2007
Rotax 583 90hp engine, both carbs, cdi unit (about 65 hrs tsn), 0 time new items include GPL starter, C box, tuned exhaust, Grand Rapids EIS with fuel flow and coolant pressure options. . Asking $ 6000 for all. Removed Rans S12 new owner wanted 912, over $8000 invested. David Mikesell 23597 N. Hwy 99 Acampo, CA 95220 209-224-4485 skyguynca(at)skyguynca.com www.skyguynca.com ________________________________________________________________________________
Subject: locking canopy latch
Date: Feb 07, 2007
Zenith now sells one. Take a look at the photos at the end of this section of the photo assembly guides on pages 10 and 11: www.zenithair.com/zodiac/xl/data/6-c-3d.pdf Zenith will sell you the handle and all the misc. pieces for about $48. But you have to order each piece separately. I have the whole kit if you want part numbers and/or more detailed photos. If you just want the lever it can be ordered from McMasters-Carr. -- Craig ________________________________________________________________________________
Date: Feb 07, 2007
When used on the 601 and 701 the carbs draw air from inside the cowl close to the firewall. Heat in the cowl effectively gives you continuous carb heat. So yes, power is reduced by some amount. Dave Austin 601HDS - 912, Spitfire Mk VIII ----- Original Message ----- From: "Gig Giacona" <wr.giacona(at)cox.net> Sent: Wednesday, February 07, 2007 10:49 AM Subject: Zenith-List: Re: Decision on Carb Heat for Rotax 912 ULS!!!!!! > > Though I'm not planing on using a Rotax engine what makes them immune to > carb ice? > > -------- > W.R. "Gig" Giacona > 601XL Under Construction > See my progress at www.peoamerica.net/N601WR > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=93431#93431 > > > ________________________________________________________________________________
Date: Feb 07, 2007
Subject: XL Flaps: Maximum down deflection.
I have been fighting with the flap actuator motor on my XL and come up with a strange set of design conflicts. The deflection called for on sheet 6-S-3 calls for 30 degrees maximum deflection, but the design shown on 6-B-19 can only produce about 20 degrees of deflection. I spoke to Caleb at ZAC today and he promised to look into this issue and get back to me. I also wanted to ask list members if anyone has run into this problem already. What flap deflection have builders who finished their XLs get? A related question (according to Caleb) is whether the elevator trim can neutralize the pitch changes with full flaps. I would appreciate any information related to XL flap deflection. Thanks, Paul XL fuselage - ________________________________________________________________________________
Subject: Re: locking canopy latch
Date: Feb 07, 2007
The Covermaster T-Handle locks (G400 and/or G400-L at http://www.pickupspecialties.com/Camper_shell_parts.htm are what I'm considering using. Samm Munn Zenith 601XL (plans) , Corvair (plans) ----- Original Message ----- From: "Brad DeMeo" <demeo(at)sonic.net> Sent: Wednesday, February 07, 2007 10:15 AM Subject: Zenith-List: > > I am looking for canopy latch ideas that include a lock. I would > appreciate any plans or links from this always reliable list serv. > Thanks. > > Bradford J. DeMeo > 601 xl > 80% done > > > ________________________________________________________________________________
Date: Feb 07, 2007
Do you have the elevator trim tab that spans half or all of the elevator side? Michael Heintz told me that they went to the full width trim tab to meet a SLSA requirement of being to able trim with full flaps. -- Craig ________________________________________________________________________________
Date: Feb 07, 2007
Paul-- I fought the same issue when I built my flaps. I could not get the 30 degrees. I ended up with 26 degrees. Based on previous comments on trim issues, I enlarged my elevator trim tab to full span. I can trim out flaps up to about 18-20 degrees. With full flap deflection I need to hold back stick George May zodiac 912s 44 hours >From: Paul Mulwitz <p.mulwitz(at)worldnet.att.net> >Reply-To: zenith-list(at)matronics.com >To: >Subject: Zenith-List: XL Flaps: Maximum down deflection. >Date: Wed, 07 Feb 2007 12:18:08 -0800 > > > >I have been fighting with the flap actuator motor on my XL and come up with >a strange set of design conflicts. The deflection called for on sheet >6-S-3 calls for 30 degrees maximum deflection, but the design shown on >6-B-19 can only produce about 20 degrees of deflection. > >I spoke to Caleb at ZAC today and he promised to look into this issue and >get back to me. I also wanted to ask list members if anyone has run into >this problem already. What flap deflection have builders who finished >their XLs get? A related question (according to Caleb) is whether the >elevator trim can neutralize the pitch changes with full flaps. > >I would appreciate any information related to XL flap deflection. > >Thanks, > >Paul >XL fuselage > > >- > > _________________________________________________________________ FREE online classifieds from Windows Live Expo buy and sell with people you know ________________________________________________________________________________
Date: Feb 07, 2007
From: "Dave Ruddiman" <pacificpainting(at)comcast.net> Subject: Re: Zenith-List: 801 Bottom Fuselage Skin801 Bottom Fuselage Skin Re: Zenith-List: 801 Bottom Fuselage Skin801 Bottom Fuselage SkinBrad, So, what did you do? Dave ----- Original Message ----- From: Maynard, Brad To: zenith-list(at)matronics.com Sent: Tuesday, February 06, 2007 8:58 AM Subject: Re: Zenith-List: 801 Bottom Fuselage Skin801 Bottom Fuselage Skin I used .025. Hope to test flight in about 2 years. Brad All, I wrote Zenith on this very subject. See the answer Attached below. Regards, Brad > Zenith, I bought my kit in 2000. I am assembling the > 'Rear Fuselage Lower skin -- 8F2-3A' which is 0.016 in thickness. > This seems extremely thin for the purpose. > Has there been an upgrade to thicker material on the latest revisions? > > I am concerned that the thin skin with few supports will oilcan. Any > problems with this? > > If so, can I replace with .025 --or-- add 'L's to arrest the oil > canning? ANSWER FROM ZENITH: Ref. 8F2-3A there is no change to the part, 6061-T6 material thickness t=.016" There would be no problem replacing the skin with t=.025" If you are still concerned about oil canning than you could also add L angles like on the side skins. Nick Heintz Zenith Aircraft Company email: support(at)zenithair.com ________________________________________________________________________________
From: "Doug Moellering" <dfmoeller(at)austin.rr.com>
Subject: A Few Questions for Scratchbuilders
Date: Feb 07, 2007
Thank God for this forum! I have two questions for the scratch-builders out there. The First: I am not clear on the meaning of one of the diagrams on the 601 XL rear wing rib drawing 6W6. My question is this: The detail diagram of the edge of the forming block on the spar side, says to "file the top of the block 90 degrees to spar flange on 25 mm". A length dimension of 214.9 mm is shown as the spar face length of the forming blocks. The distance from X=0, Yu=147 to X=33.8, Yl=66.5 (as shown in the curve point table) is 216.16 mm, implying that 1.2 to 1.3 mm should be removed by the filing operation. Note: this is not the joggle, since the joggle is clearly stated, in the blank forming diagram, to apply to both top and bottom flanges. The filing is only done (per drawing) to the top forming block edge. Am I correct in executing the following steps in this order? 1. Sand edges of forming block to the curve table points. 2. Sand 1.2 mm off in the region shown perpendicular to the spar side edge (should leave a spar side edge 214.9 mm long, but it leaves a flat top surface far longer than 25 mm). 3. Apply 1/8" radius to forming block edge all around. 4. Sand 10 degree springback all around forming block (except rear channel side which should be 13 degrees). This will result in a forming block with a straight section abutting the curve points. The reason I'm being fussy about this 1.2 mm is that, this is exactly the region in which the tolerance should be held to a mouse whisker. Can some of you who've been through this step tell me if I'm interpreting this correctly? Second Issue: The rear panel for the lockers is shown on the drawing as 498 mm length with sides of 225 and 218 mm. What isn't shown clearly are the angles in which these sides meet. I'm guessing that the top side is perpendicular to the 225 and 218 sides, but it could also be the case that this piece is cut trapezoidally, or even the perpendicular side could be the bottom????. Maybe I'm overlooking an obvious clue here; in case I am, please bear with me. Someone who has installed the lockers please clue me in on the correct way to cut this piece. I do appreciate the help in this forum! Doug ________________________________________________________________________________
Date: Feb 07, 2007
Thanks everyone. It sounds like Caleb was giving me straight skinny about the trim issue. I think I do have the latest trim tab design - inset into the elevator and taking much of one side. I still think the decision to reduce the flap deflection might have been related to the design problem as much as the trim issue, but I guess that doesn't really matter. Can anyone tell me if the full flaps (30 degrees) is really helpful in dumping altitude? Will 20 degrees be a big improvement over no flaps at all? I guess my choices at this point are whether to settle for the current limit of 20 degrees or demand or design a larger deflection. Paul XL fuselage At 02:58 PM 2/7/2007, you wrote: > >Paul-- > I fought the same issue when I built my > flaps. I could not get the 30 degrees. I ended > up with 26 degrees. Based on previous comments > on trim issues, I enlarged my elevator trim tab > to full span. I can trim out flaps up to about > 18-20 degrees. With full flap deflection I need to hold back stick > >George May >zodiac 912s 44 hours > > >>From: Paul Mulwitz <p.mulwitz(at)worldnet.att.net> >>Reply-To: zenith-list(at)matronics.com >>To: >>Subject: Zenith-List: XL Flaps: Maximum down deflection. >>Date: Wed, 07 Feb 2007 12:18:08 -0800 >> >> >>I have been fighting with the flap actuator >>motor on my XL and come up with a strange set >>of design conflicts. The deflection called for >>on sheet 6-S-3 calls for 30 degrees maximum >>deflection, but the design shown on 6-B-19 can >>only produce about 20 degrees of deflection. >> >>I spoke to Caleb at ZAC today and he promised >>to look into this issue and get back to me. I >>also wanted to ask list members if anyone has >>run into this problem already. What flap >>deflection have builders who finished their >>XLs get? A related question (according to >>Caleb) is whether the elevator trim can >>neutralize the pitch changes with full flaps. >> >>I would appreciate any information related to XL flap deflection. >> >>Thanks, >> >>Paul >>XL fuselage >> >> >>- >> >> >> >> > >_________________________________________________________________ >FREE online classifieds from Windows Live Expo >buy and sell with people you know > > --------------------------------------------- Paul Mulwitz 32013 NE Dial Road Camas, WA 98607 --------------------------------------------- ________________________________________________________________________________
Date: Feb 07, 2007
I recall a number of messages a while ago where a number of folks reported they rarely used their flaps at all. -- Craig ________________________________________________________________________________
Date: Feb 07, 2007
Full flaps ---27degrees --70mph and you'll come down at about 60 degrees glide path George May 601XL 912s --44 hours _________________________________________________________________ FREE online classifieds from Windows Live Expo buy and sell with people you know ________________________________________________________________________________
Date: Feb 07, 2007
Subject: Re: A Few Questions for Scratchbuilders
The locker panel is almost rectangular, but actually a trapezoid (almost?). This is because the wing tapers a little bit at that point. I suggest you start with it cut as a rectangle and adjust the few mm needed as you fit it in place. If you build it according to the photo guide, the bottom skin will already be riveted in place, and I suggest you fit the angle that meets the top skin before trying to drill pilot holes in the rear panel. One issue to watch here is the orientation of the flanges on the rear ribs surrounding the locker. The drawings are a little vague (wrong?) on this point. The proper way is to have the flanges on the rear ribs on both sides of the locker facing away from the locker. This gives you a smooth side wall on both the inboard and outboard side of the locker. If you get this wrong, the rear panel for the locker will need to be a considerably different size. Good luck, Paul XL fuselage At 03:52 PM 2/7/2007, you wrote: >The rear panel for the lockers is shown on the drawing as 498 mm >length with sides of 225 and 218 mm. What isn't shown clearly are >the angles in which these sides meet. I'm guessing that the top >side is perpendicular to the 225 and 218 sides, but it could also be >the case that this piece is cut trapezoidally, or even the >perpendicular side could be the bottom????. > >Maybe I'm overlooking an obvious clue here; in case I am, please bear with me. > >Someone who has installed the lockers please clue me in on the >correct way to cut this piece. ________________________________________________________________________________
Subject: One man Wing Flipper
Date: Feb 07, 2007
Needed a way to flip the wing over, so. . . Got a 14 foot long piece of 3" SCH 40 PVC and rigged up a block & tackle to raise and flip the wing. The PVC fits right through the lightening holes and the block & tackle is a bicycle lift (has a brake to hold the height) that wasn't being used. The wing turns real easy but needs a counter balance to level it out for lowering / raising. Can be done by one man now. See more at the kit log site. -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=93541#93541 Attachments: http://forums.matronics.com//files/wing_flipper_003_666.jpg http://forums.matronics.com//files/wing_flipper_001_208.jpg ________________________________________________________________________________
Subject: Re: No Title
Date: Feb 07, 2007
I've also been looking for a locking latch for my canopy, one of the best looking options I've seen so far is the DC696 from http://www.illinoislock.com. I'll have one in about a week, we'll see. -------- Rich Whittington Tullahoma, TN Zenith 601HDS Under Construction Read this topic online here: http://forums.matronics.com/viewtopic.php?p=93547#93547 ________________________________________________________________________________
Date: Feb 07, 2007
live with 20 degrees and learn to slip to kill altitude Juan -----Original Message----- >From: Paul Mulwitz <p.mulwitz(at)worldnet.att.net> >Sent: Feb 7, 2007 7:15 PM >To: zenith-list(at)matronics.com >Subject: RE: Zenith-List: XL Flaps: Maximum down deflection. > > >Thanks everyone. It sounds like Caleb was giving >me straight skinny about the trim issue. I think >I do have the latest trim tab design - inset into >the elevator and taking much of one side. I >still think the decision to reduce the flap >deflection might have been related to the design >problem as much as the trim issue, but I guess that doesn't really matter. > >Can anyone tell me if the full flaps (30 degrees) >is really helpful in dumping altitude? Will 20 >degrees be a big improvement over no flaps at all?
January 24, 2007 - February 07, 2007
Zenith-Archive.digest.vol-gl
