Zenith-Archive.digest.vol-gq
March 27, 2007 - April 07, 2007
> Greeting from Perth,
> Chris
Subject: | Re: Zenith Rudder Design |
I was just talking about this with Geoff Heap on Sunday (I was over his place and
he had his plane out and the tail feathers on, looks good!). We both figured
it wouldn't hurt to put a doubler plate in the lower and of the rudder spar
that spans the distance between the hinge points. As it is those hinge brackets
just rivet directly to the spar web. Considering the picture of the flipped
over airplane, it's strong as it is. Add a double/stiffener plate (say .032) and
you should be golden.
Andy Shontz
CH601XL - Corvair
www.mykitlog.com/ashontz
http://forums.matronics.com/viewtopic.php?p=103185#103185
From: | "Gig Giacona" <wr.giacona(at)suddenlink.net> |
The big problem with the conforming design E-LSA when effective will be that it
won't allow any deviation from the approved design.
W.R. "Gig" Giacona
601XL Under Construction
http://forums.matronics.com/viewtopic.php?p=103191#103191
From: | Paul Mulwitz <p.mulwitz(at)worldnet.att.net> |
Also, in order to make a conforming E-LSA kit the kit manufacturer
must also make S-LSA planes. I don't think ZAC has any such
plans. Perhaps AMD would do that, but I have not heard they have
those intentions. The type of kit envisioned in this E-LSA is more
like the S-LSA than a classic kit. It doesn't have the 51%
requirement and doesn't allow the builder to make ANY modifications
to the design. Still, we can have our kit built planes certified
under the Fat Ultralight provision through January 31, 2008.
The only "For Hire" flight allowed for E-LSA planes I am aware of is
"Instruction". These planes are not eligible for normal "For Hire"
operations such as Air Taxi or Cropdusting or cargo hauling.
The instruction provision is part of the "Bait" to get fat
ultralights registered in the normal system.
Paul
XL fuselage
At 05:48 AM 3/27/2007, you wrote:
>There are a few E-LSA 601s out there, but they weren't built from
>conforming kits. They were certificated under the "fat ultralight"
>provision of the new rules. The "fat ultralight" provision expires at
>the end of February of 2008. The standards document for E-LSA
>conforming kit manufacturing has only recently been finalized so no
>conforming kits for any design have yet been approved. I don't think
>Zenith has said whether or not they will produce an E-LSA conforming
>kit.
Paul Mulwitz
32013 NE Dial Road
Camas, WA 98607
Subject: | Re: Routing of Pitot/Static lines in wing |
Thanks that is helpfull. Do you have splices in the tubing from the pitot tube
to the instrument panel of is it one piece?
Gary
Gig Giacona wrote:
Yes, there is enough room in the lightening holes and yes holes and grommets is
also a pretty good option.
I went thought the lightening holes and used quick ties between the ribs to the
power wires that had gone though drilled holes in the ribs.
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=103172#103172
Looking for earth-friendly autos?
Browse Top Cars by "Green Rating" at Yahoo! Autos' Green Center.
From: | David Downey <planecrazydld(at)yahoo.com> |
I just purchased a 601XL serial number from another builder who decided not to
build. There was no charge from Zenith. I simply had to fill out a couple of forms
and the seller also had to fill out some forms and that was it. Call them.
They are very helpful.
I bought all the newsletters/back issues. While many listers have stated that
they feel they are useful I was not convinced of that. The assembly manual updates
are free from the builders-only accessible pages and there is also a list
showing the current release date for drawings.
I just checked the builders pages and they show that a new set of current drawings
is $50.00 to registered builders.
Gig Giacona wrote:
I think Zenith charges something on the order of $50USD to transfer the serial
number to your name. Once they do they have a section on the website with the
construction manual. I have recently found out that all the links in for the non-XL
section of 601 website work so you might need to contact Zenith and buy
an updated manual.
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=103176#103176
Dave Downey
Harleysville (SE) PA
Zodiac 601XL/Corvair?
Food fight? Enjoy some healthy debate
in the Yahoo! Answers Food & Drink Q&A.
From: | "Craig Payne" <craig(at)craigandjean.com> |
serial number to your name.
They didn't charge me anything but then I was standing in the factory in
Mexico, MO.
-- Craig
Subject: | Re: Scratch built wing update and pictures |
Hey Andrew,
I don't know about production aircraft, but I know there are other homebuilts built
with multiple leading edge sections. RV's and Bearhawk for example. I got
approval from ZAC before doing this. Also the new ZAC Construction Standards
manual says it is OK to use multiple skins as long as they overlap a rib. I'm
not one of those builders who keeps a log of every hour spent working on my airplane,
so I can't say exactly how long it took. I can say for sure that it was
much quicker and easier to make a 3 piece LE skin than to make the single 12'
piece. It works for me, so I'm happy with it.
Dave Clay
http://www.daves601xl.com
http://forums.matronics.com/viewtopic.php?p=103215#103215
Subject: | Corvair - Dual sparkplugs |
Don't know much about the Corvair other than one is hanging on an engine stand
in my garage. I plan to order WW conversion manul soon. Is there any aftermarket
heads that allow for dual spark plugs?
Andy Shontz
CH601XL - Corvair
http://forums.matronics.com/viewtopic.php?p=103220#103220
I haven't gotten that far yet. The wings are done and I'm on the fuselage. I just
took the tubing that Zenith sent me and ran half for the pitot and half for
the static. Looking at it it will probably be close and depend on how I have
to route it. It won't surprise me if I have to add more somewhere in the cockpit.
> Thanks
> Gary
is also a pretty good option.
> W.R. "Gig" Giacona
> See my progress at www.peoamerica.net/N601WR
> Read this topic online Looking for earth-friendly autos?
> Browse Top Cars by "Green Rating" (http://autos.yahoo.com/green_center/;_ylc=X3oDMTE4MGw4Z2hlBF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDZ3JlZW5jZW50ZXI-) at Yahoo! Autos' Green Center.
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=103237#103237
Subject: | Re: Corvair - Dual sparkplugs |
Not that I've ever heard of. The WW system uses dual ignition on single plugs.
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=103238#103238
Mark Langford has a set that were probably custom-made:
http://home.hiwaay.net/~langford/corvair/twinplugs/
For Corvair-related questions you should subscribe to the CorvAircraft list:
http://www.krnet.org/corvaircraft_inst.html
To search the list's archives:
http://www.maddyhome.com/corvairsrch/
-- Craig
I did the same thing, Gig. However, In thinking it through, I decided that I would
go ahead and plumb my pitot & static instruments and run the tubing under
the top longeron to the skin panel that is right beside the pilot's seat. I
will make a hole in the skin large enough for both tubes. When I attach the wings,
I will make a connection just inside the fuselage. It will be behind an
upholstery panel so not vulnerable or in the way.
Jay in Dallas
tube to the instrument panel of is it one piece?
>> Thanks
>> Gary
the power wires that had gone though drilled holes in the ribs.
>> W.R. "Gig" Giacona
>W.R. "Gig" Giacona
>Read this topic online here:
And when you go to Mark's page make sure you read the last line on the page.
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=103249#103249
Sounds like a good idea Jay. I'll probably steal it.
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=103251#103251
Subject: | old style 601XL wheel pants |
One more time listers. Any scratch builders or one kit at a time builders out there
interested in an unused set of the old style wheel pants for a 601XL?
All three molded fiberglass pants (packed in three boxes for shipping) plus all
six steel mounting brackets included. Asking $225.00 (half Zenith factory price).
Any reasonable offer would be considered. Can ship via UPS.
Any takers?
Ed Moody II
Rayne, LA
In a message dated 3/27/2007 8:09:12 A.M. Eastern Daylight Time,
ashontz(at)nbme.org writes:
Just from memory, I thought a regular Cessna 152 was +4 and -3 Gs where as
an aerobat is +6, -6 Gs, which is the same as a 601Xl, so wouldn't that by
default qualify a 601XL as an aerobatic plane by default? That wouldn't apply to
the 701 though.
Why not? The 701 is the same +6 and -3 ultimate load at gross weight.
Subject: | Re: RE: Re: DID I SEE THIS ON YouTUBE! 601 Looping!!!! |
William,
You are partly correct. Most people's resting G tolerance is in the 4 range.
"Resting" means that you have no G suit on AND perform no anti-G straining
maneuver. My resting G tolerance when I went through the centrifuge was 4.5
(I am short and stocky). The affects of positive G's are as simple as a pump's
(heart) pressure head. If you are tall and have low blood pressure, you
will more than likely have a low resting G tolerance. This is why on average,
women have a higher resting G tolerance than men (they are typically shorter).
The G-suit only adds about 1 G of additional positive G tolerance. The anti-G
straining maneuver makes up the rest of the difference. In the centrifuge,
we were required to maintain 7.8 G's for 30 seconds. -Something the Hornet
is hardly capable of doing, but... It was painful. The Eagle and Viper guys
have to go to 9 G's. Air show guys hit very high G's, but for a shorter duration
of time. The factors increasing the
possibility of gray out, tunnel vision, or even GLOC (G induced loss of conciousness)
are the amount of G's, G onset rate, and length of time sustained.
I totally agree that entry speed is not a factor, other than the higher
the entry speed, theoretically, the lower the G force required to make it over
the top. In relatively low horsepower and high drag aerobatic aircraft like
the Citabria, 3 - 4 G's is required to make it over the top. The only problem
I had with moving body parts under high G was getting my head turned around while
in a defensive dogfight under high positive G (>6). I would look at the
HUD for whatever information I needed, and get my head looking back prior to pulling
significant G's... High positive G's were even more difficult when wearing
NVG's, but that is another story...
VR/
Brandon
601 HDS / TD / Corvair
80 hours
Bored stiff? Loosen up...
Download and play hundreds of games for free on Yahoo! Games.
Chris-
Most of the surface corrosion will only be a problem if you decide to
polish.
Regardless of the plans, research the archives when you find something
out of the ordinary. Don't blindly trust the instructions and build yourself
into a corner. If you can't find anything in the archives, put "HD/HDS
people" in your subject line when you have a question and you'll get an
answer from the few, the proud, the HDS builders!
Good building. Welcome aboard.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
----- Original Message -----
Sent: Tuesday, March 27, 2007 4:58 AM
Subject: Zenith-List: Old kit
> Hello Listers,
> I have bought a 601 HDS kit on ebay last month, and this weekend flew to
> the east coast (of Australia) to pick it up. Kind of exciting if you buy
> something unseen (no photos), pay $5000 to a person you don't know and who
> can't tell you much about the kit ( not even the type of 601), but I guess
> one sometimes has to take a leap of faith.
> The kit had basically not been touched, except for the rudder which had
> been clecoed together. The kit is 10 years old and has spent the last 8
> years in a shed gathering dust and sustaining a bit of surface corrosion.
> While I initially didn't expect it to be complete to my delight it turned
> out to be, including canopy, long range tanks and even a set of strobes.
> The canopy has been rolled up for ten years, and has sat in a hot shed.
> Here is the question: Has anybody encountered problems with unrolling
> their canopys after a longer period of time?
> Also the kit came with a set of plans and a serial number, but no manual
> and the plans are dor the HD model. I hope Zenair will update the plans
> and provide me with a replacement manual, if not I might have to ask you
> guys for help.
> Chris
Subject: | Re: Flap Motor Switch |
I've ordered a 10 amp breaker for my flap circuit,
which is what ZAC calls out on 6-S-2 of the 03/04
version of drawings for the 601XL. I couldn't find a
current draw rating on my flap motor, so I'm not sure
what is required. Does anyone know if there's been a
change in the requirment for the flap motor amperage?
Ron Ellis
Haslet, TX
601XL Jab 3300 Enigma
>From: Paul Mulwitz <p.mulwitz(at)worldnet.att.net>
>Subject:
>Hi James,
>You want a DPDT Momentary switch for this purpose.
>The 601 drawings
>I received from ZAC include a wiring diagram for this
>function. I
>also did one for my own installation that includes a
>15 amp circuit
>breaker (the size recommended by ZAC), the flap
>switch, wiring for
Don't get soaked. Take a quick peek at the forecast
with the Yahoo! Search weather shortcut.
http://tools.search.yahoo.com/shortcuts/#loc_weather
Subject: | Flap Motor Switch |
I measured the steady-state draw of the factory actuator at 3-4 amps with no
mechanical load. I assume there is an initial surge that my meter doesn't
see and that the draw will be higher when actually moving the flaps in
flight.
-- Craig
Hey Andy;
I am rather new to the Corvair thing myself but if I understand the WW single/dual
setup it should be just fine as he does it.
Andy Shontz
CH601XL - Corvair
Dave Downey
I can add that a 7.5 amp fuse is not sufficient under flight loads. I use a
15 a and it is fine.
Gary Ray
Sent: Tuesday, March 27, 2007 7:40 PM
Subject: RE: Zenith-List: Flap Motor Switch
no
> flight.
> -- Craig
2:31 PM
From: | "John Bolding" <jnbolding1(at)teleshare.net> |
Subject: | Re: Making an LRI probe |
Ron,
My last message to the group got lost in space. When I announced,all
the inventory evaporated in 3 hrs. I have another batch of 50 coming in
a week or so. I'll keep your email and send out notices to those who
got left behind the first time before I make the next announcement.
thanks for your interest. John
To: John Bolding
Cc: R.D.(Ron) Leclerc
Sent: Tuesday, March 27, 2007 9:33 PM
Subject: xxx Re: xxx Re: Zenith-List: Re: Making an LRI probe
Hey John
Don't know if you received my other e-mail... I'm interested in
acquiring a probe if available - I have a gauge... need a nice picture
for the face yet though!
Please let me if available and payment procedures.
Thank you
Ron Leclerc
infow(at)mts.net
204-227-8324
Been holding off this discussion as I didn't have things quite
together but lots of guys are looking for probes so I'll post what I
have. I can supply these for $30, injection molded. they have 1/8" NPT
(F) threads on the top. These are in stock.
Been looking around for a good silkscreener for the guage face but
haven't found one yet that I like so you're on your own there for the
immediate future. I'll have them however as soon as I can. I'll post a
picture of the probes as soon as I figure out how.
Probes are black and made from nylon so rest assured that paint is
probably not gonna stick.
John Bolding
--> http://forums.matronics.com
Subject: | Re: Older Style Wheel Pants |
Rather than give up on them,
Has anybody tried to remodel the older style wheel pants for a sleeker
appearance and function?
I have not installed the ones that I have because I don't like the
appearance.
Gary Ray
Wrong picture, sorry John
To: John Bolding
Hey John
Thank you
Ron Leclerc
infow(at)mts.net
204-227-8324
John Bolding
OOPS, last message was not for the list, need to wake up before I hit
the send key.
Also wrong pic. Might as well correct for everybody.
First batch of probes went in 3 hrs. another 50 on the way, If
interested send an email and I'll notify you priviatly. All that have
emailed so far are on the list.
Sorry for the confusion John
From: | "steveadams" <dr_steve_adams(at)yahoo.com> |
[quote="NYTerminat(at)aol.com"]In a message dated 3/27/2007 8:09:12 A.M. Eastern
Daylight Time, ashontz(at)nbme.org writes:
to the 701 though.
AOL now offersle="http://www.aol.com?ncid=AOLAOF00020000000339" href="http://www.aol.com?ncid=AOLAOF00020000000339" target="_blank">AOL.com.
> [b]
You are comparing apples and oranges here. The +/- 6G's is the ultimate load factor
for the Zodiac, while a certified aircraft generally give the flight load
factor. For certified aircraft, the ultimate + load must be at least 5.7G, for
utility 6.6G, and for aerobatic 9.0 G, and that's the minimum. The Sukhoi's
ultimate load factor is +/-23 G's. The Zodiac doesn't make the utility category,
let alone the aerobatic category. Of course it's an experimental and you can
do what you want. Do everything right and you'll never have a problem. I'm sure
no one ever botched a maneuver, thus the incredibly low aerobatic accident
rate in the NTSB files. There are a lot of great things about experimental aviation;
you have a lot of freedom and there is a huge choice of aircraft designs
out there. You can choose a 2 seat design, stuff 4 seats in it and increase
the gross weight by 500 lbs if you want to. You can tell yourself you baby the
plane and don't need the safety factor, so it's perfectly safe for you and the
way you fly. But it would probably be a better idea to choose a design that
better fits your needs. It's the same with aerobatics and the Zodiac. If you
really want to do aerobatics, wouldn't it make more sense to choose a design more
appropriate to your needs? You can rationalize anything, and cite 100 examples
of people having no problems doing what you propose doing. Sure people have
probably looped about every GA aircraft out there, usually with no ill effects.
It still doesn't make it smart.
http://forums.matronics.com/viewtopic.php?p=103375#103375
I'm going to do mine this way. I know #3 and #4 ribs are close together. #5 and
#6 may be close together too. If not I'll add another rib on the outboard side
of the tank for more to tie into.
Andy Shontz
CH601XL - Corvair
http://forums.matronics.com/viewtopic.php?p=103394#103394
Subject: | LRI gauge artwork |
List,
I drew ten variations of artwork for the Dwyer gauge. Print it out and
pick your favorite.
Dino Bortolin
XL/Corvair (eventually, pace is slow!)
Subject: | Re: e: xxx xxx Re: Making an LRI probe |
This is certainly not rocket science. No sense spending a hundred years
figuring it out to the the last angstrom.
Just a mere differential pressure sensor. A REALLY simple way to test it
would be mount it on something (a Burt Rutan wind tunnel for example (a car)).
with a pressure gauge (airspeed indicator, etc) on each port hop in,
stick it out the window and simply confirm a reasonable pressure
differential across say 0-30 degrees or so. That would certainly be
enough to tell you whether or not it will work.
Jeff
http://forums.matronics.com/viewtopic.php?p=103409#103409
Hold on there kids! I think we're getting confused. The inboard section covers
nose ribs 1-3. There are only 3 nose ribs inboard of the fuel tank in my plans.
The outboard section covers nose ribs 4-wingtip. The fuel tank section overlaps
the other skins only about 20mm over the flanges at nose ribs 3 and 4.
In the new ZAC Construction Standards Manual on page 40 (CS #604) the method for
using several smaller skins is clearly described. This is where I got the idea.
I called and spoke to Caleb and described what I planned to do and he said
it would be fine if I followed the method in the Construction Standards. It's
really very simple.
I suppose nut plates and screws would work , but the Standards recommend you stick
with the fasteners specified in the plans.
Dave Clay
http://forums.matronics.com/viewtopic.php?p=103430#103430
Thanks for the info Craig, and Gary, I also have the
15a circuit shown on 6-B-20 (didn't see that before),
so I'll just reorder a 15a breaker so I won't worry.
Ron
>with no
>that my meter
>doesn't
>moving the flaps in
>flight.
>-- Craig
Expecting? Get great news right away with email Auto-Check.
Try the Yahoo! Mail Beta.
Two follow-up questions for some of the responders:
Why DPDT and not SPDT? Maybe there's a difference with the 601 and 701 (I'm a
701 builder), but it seems with only one linear actuator you don't need a double
pole. Am I missing something?
Second, does anyone know who sells toggle switches that actually look like a flap
handle, as opposed to the generic looking toggle switch?
Regarding your original question Jim, I've purchased Bob Nuckoll's Aeroelectic
Connection. He gives an excellent wiring diagram for an electric flap system.
In the diagram, he recommends a 15 amp breaker for the flap motor and 5 amp
breaker for the flap control (relays and limit switches).
Dan Ginty
http://forums.matronics.com/viewtopic.php?p=103447#103447
In a message dated 3/28/2007 12:17:09 P.M. Eastern Daylight Time,
djg7(at)houston.rr.com writes:
a 701 builder), but it seems with only one linear actuator you don't need a
double pole. Am I missing something?
If you are not using relays, you need the DPDT switch to reverse the
polarity
Subject: | 601HD wings modified to 23' |
Hi All,
I have a partially completed 601HD kit. The first owner ordered modified
23' wings instead of the original 27' wings.
It is important when completed this kit comply with LSA requirements.
Personnel at Zenith feel there will not
be a problem but to lessen concern vortex generators could be added to
the wings lowering the stall speed
by 4 to 6 mph (conservative estimate). Any thoughts to assure LSA
compliance especially as it relates
to stall or cruise speeds would be greatly appreciated.
Ray
From: | Frank Stutzman <stutzman(at)stutzman.com> |
Subject: | Re: Small Vs. Big - small plane builders pep talk ... |
On Wed, 28 Mar 2007, Bima, Martin wrote:
> A friend of mine recently learned he has to put about $15,000 into his
> Piper Arrow engine because it sits around all of the time, and only
> turns over about 5-10 hours per year.
> Why? Not very fun flying around the local patch in a rocket.
> They all get laughed at by the big boys with their Bonanzas and
> Buck82's. But while the big boys cruise an hour to the left and right
> twice a year, these UL guys are putting up 20-30 hours a month in the
> summer and a few of them them half that in the winter on skis.
> I am building a small and slow aircraft to do the kind of flying I will
> do most often - putt-putting around the local forests, beaches,
> sand-dunes, etc. If I ever want to fly 2000 miles from here in a hurry,
> I'll jump on a 737.
Personally, I think every one ought to have at least two planes.
I'm planning on building a 701 simply because it is so very un-like my
Bonanza. The Bo is fast and confortable for the twice a month 2+ hour
trips I routinely make. Doing the same in a 701 would be painful at best.
On the other hand the Bonanza is just plain wasteful when I just want to
go, as you say, "putt-putting around".
Now I suppose if I could find an expermental that could land and t/o in
less than 300 feet, cruise at over 150 mph, burn less than 5 gallons an
hour and have a useful load over 800 lbs, I could live with just one
plane. I am unaware of any such animal and I don't think it exists.
Frank Stutzman
Bonanza N494B "Hula Girl"
Hood River, OR (soon to be Boise, ID)
My hanger neighbors got a Bo A-36 about a year or so ago. The two partners were
required to get 25 hours each of dual in it for insurance. Cost them a fortune
in AvGas.
If they fly a couple of hour a month now it was a busy month. Before they had an
Archer they each flew it at least five or six hours a month and almost always
just came out and flew on the weekends for the fun of it. They never just fly
around the patch anymore.
Kinda sad.
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=103517#103517
Subject: | Re: 601HD wings modified to 23' |
Sent: Wednesday, March 28, 2007 1:03 PM
Subject: Zenith-List: 601HD wings modified to 23'
Hi All,
I have a partially completed 601HD kit. The first owner ordered modified 23'
be a problem but to lessen concern vortex generators could be added to the
by 4 to 6 mph (conservative estimate). Any thoughts to assure LSA compliance
Ray
Hi Ray.
I'm glad to see someone trying this. I have an HD that I'm quite pleased
with, but I've considered clipping a couple feet off each wingtip for higher
cruise. That fat HD wing is REAL draggy at 115 MPH (cruise with Jabiru 3300
@ 108 hp). I hesitate to clip the wings because I don't want to loose too
much of the excellent slow speed with the existing wings.
According to the Zenith specs, the HD stalls at 44 mph. The LSA rules say
max stall speed is 51 MPH
http://sportpilot.org/learn/final_rule_synopsis.html so I'm inclined to
believe you might be OK even without the vortex generators.
Please keep us posted with your results once you get into your flight
testing.
Rick
http://www.lightflyers.com/birthday
That basically makes it an HDS. The Zenith site says the HDS has a stall speed
at 1050 lbs of 54mph and a top speed of 150mph.
http://www.zenithair.com/zodiac/601-hds.html
The top speed isn't a problem because even if the plane can do it you could adjust
the prop so it can't.
The LSA max stall speed is 50 mph. Can you shave off 4 mph with vortex generators?
I don't know. But remember that stall speed is at 1050 lbs. that is awful
low compared to the XL.
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=103521#103521
Sent: Wednesday, March 28, 2007 2:15 PM
Subject: Zenith-List: Re: 601HD wings modified to 23'
> speed at 1050 lbs of 54mph and a top speed of 150mph.
The span would be the same as the HDS: 23'. But the total surface area will
be greater than the HDS's 98'ft (compared to 130'ft for the stock HD).
The HD wing is a constant chord at 58" instead of the taper from 58" at the
root to 34" at the tip, so a clip-wing HD will have more surface area than
HDS , hence a lower stall speed than the 54mph of the HDS.
I'm not an engineer, just a mechanic... so anyone who has a better
understanding of the math involved can feel free to correct my aerodynamic
assumptions.
Interesting idea, I'll be anxious to see how it plays out.
Rick
From: | "n801bh(at)netzero.com" <n801bh(at)netzero.com> |
Geez.. my 801 can do one of those things consistantly. I can do 150,,,,
headed straight down, and I can burn 5 GPH during decent. One out of thr
ee isn't all too bad.
Ben Haas
N801BH
www.haaspowerair.com
l
> I'll jump on a 737.
t.
Frank Stutzman
0,,,, headed straight down, and I can burn 5 GPH during decent. One out
of three isn't all too bad. <G>
Ben Haas
N801BH
-- Frank Stutzman <stu
tzman(at)stutzman.com> wrote:
--> Zenith-List messa
ge posted by: Frank Stutzman <stutzman@stutz
man.com>
On Wed, 28 Mar 2007, Bima,&n
bsp;Martin wrote:
> --> Zenith-List mes
sage posted by: "Bima, Martin" <mbima@hydro.
mb.ca>
learned he has to put about $15,000&
nbsp;into his
e it sits around all of the time,&nbs
p;and only
ours per year.
> Why? Not very&nb
sp;fun flying around the local patch in&nb
sp;a rocket.
> They all get laugh
;Bonanzas and
> Buck82's. But while the&n
bsp;big boys cruise an hour to the le
ft and right
> twice a year, these&n
bsp;UL guys are putting up 20-30 hours&nbs
p;a month in the
> summer and a
;few of them them half that in the&nb
sp;winter on skis.
> I am buildin
g a small and slow aircraft to do&nbs
p;the kind of flying I will
> do&nbs
p;most often - putt-putting around the loc
> sand-dunes, etc. I
> I'll jump&nb
sp;on a 737.
Personally, I think every&n
bsp;one ought to have at least two pl
anes.
I'm planning on building a 701&nbs
p;simply because it is so very un-like&nbs
p;my
hour
ainful at best.
On the other hand
;the Bonanza is just plain wasteful when&n
bsp;I just want to
go, as you say
Now I suppose i
uld land and t/o in
less than 300
feet, cruise at over 150 mph, burn&n
bsp;less than 5 gallons an
hour and hav
plane.
I am unaware of any such animal and&n
bsp;I don't think it exists.
Frank Stutz
man
Hood River,
- The Zenith-List Email Foru
ist utilities such as the Subscriptions pa
sp; - NEW MATRONICS WEB
