Zenith-Archive.digest.vol-ht
February 20, 2008 - March 04, 2008
      goes through the firewall and through a bent steel plate in back which also
      bolts into the flange of the firewall.    Presumably whatever mount you're building
      could be attached the same way.
      Incidentally, the previous 912 bed-mount mounts a little differently right here.
      The mount tab sticks up rather than to the left, so it overlaps on top of 7F7-1SP.
      That way the bolt goes through 7F7-1SP as well, which seems a little
      more durable to me.
      Hope that helps.  Drop me an email offline if not, or give Zenith a call.
      http://forums.matronics.com/viewtopic.php?p=165154#165154
      http://forums.matronics.com//files/dscf1488_142.jpg
Date: Feb 20, 2008
Subject: AeroElectric Connection Manual for sale
Hi All, I have a brand new extra copy of Bob Nuckolls Aeroelectric Connection Manual Revision 11 which I am selling for $30 including priority mail shipping in the US. Please let me know if you are interested. Thanks, John Davis Burnsville, NC 601XL QB - Jab 3300 ________________________________________________________________________________
Subject: Re: Sabrina Re: pitching the H-stab
Date: Feb 20, 2008
Hi, Ben, Have you considered adjusting the flap pushpull tube to position the flaperons to give you that little bit that gives you the "sweet spot" pitch attitude and the 4 mph? Seems to me that would be your best "no-flap" setting. Blue skies and tailwinds Jim CH-801 DeltaHawk diesel Augusta GA 90% done, 90% left ________________________________________________________________________________
Subject: Re: XL WING BOLTS??
Date: Feb 20, 2008
Hi, Bryan, Rather than leaving out the washer under the bolt-head, a better way to get proper thread exposure is to use thin washers, i.e., AN-960-516L. The washer under the bolt-head serves as a bearing during tightening as well as a spacer. Blue skies and tailwinds Jim CH-801 DeltaHawk diesel Augusta GA 90% done, 90% left ________________________________________________________________________________
Subject: More Fuel
Date: Feb 20, 2008
My 601HDS has two 10 gallon leading edge fuel tanks. I want to add 3-5 gallons fuel capacity. Will have the wing skins off. Any suggestions? HDS 235L2C ________________________________________________________________________________
Subject: Re: 701 motor mount attach points on firewall
Date: Feb 20, 2008
John, thanks. That helps a lot. I notice that you have installed 7F7-5 firewall stiffeners at an angle instead of vertical. Does that have to do with the Rotax installation? One last question, what is the capacity of the Rotax oil tank? Thanks again, Jerry > > Jerry: > I've attached a picture of the left side of my 912 ring mount. You > can see the tab sticking out to the left where it will be bolted to > the firewall. The bolt goes through the firewall and through a bent > steel plate in back which also bolts into the flange of the > firewall. Presumably whatever mount you're building could be > attached the same way. > > Incidentally, the previous 912 bed-mount mounts a little differently > right here. The mount tab sticks up rather than to the left, so it > overlaps on top of 7F7-1SP. That way the bolt goes through 7F7-1SP > as well, which seems a little more durable to me. > > Hope that helps. Drop me an email offline if not, or give Zenith a > call. > > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=165154#165154 > > > Attachments: > > http://forums.matronics.com//files/dscf1488_142.jpg > > ________________________________________________________________________________
Subject: Re: Torque values
Date: Feb 20, 2008
Brad, Getting back to the original subject, page 7-301 of AC 43.13-1B shows proper torque values. Yes, they are based on shank size, not wrench size. I have this page posted on my workbench as I seem to refer to it almost every day. As opposed to a torque wrench you'd find at Home Depot, I strongly recommend taking the plunge and buying a quality torque wrench. I have one from US Tool - model TP349 and it's great. If you're planning on installing a Rotax, You'll definitely use the metric (Newton-meter) side for your engine work. I know it's expensive, but IMHO it is a must-have. Here is their website: http://www.ustool.com/ That's my two cents. Dan Ginty N787DG 90% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165215#165215 Attachments: http://forums.matronics.com//files/tp349_torque_wrench_199.jpg ________________________________________________________________________________
Date: Feb 20, 2008
From: "kensmith(at)springnet1.com" <kensmith(at)springnet1.com>
Subject: Re: Zenith-List Digest: 29 Msgs - 02/19/08
Subject: Re: Zenith-List: Sabrina Re: Pitching the H-Stab. Two changes to the aircraft by changing the pitch to the H-Stab has not yet been addressed. #1 - People in the agriculture spraying business sometimes increase the up pitch to the H-Stab because they have a out of aft CG when fully loaded. The tail assembly on an aircraft helps the loading and CG of the aircraft's stability in the flying mode. When you increase the angle of attack on the H-Stab you increase the loading on the tail section of the aircraft which in turn decreases some of the loading on the main wing spar section. Reduce the main wing loading and you will reduce the stall speed of the aircraft. #2 - If you reduce the angle of attack of the H-Stab, just the opposite will occur. You have reduced the loading to the tail section and in turn increased the loading on the main wing spar section. You have then made the aircraft a less stable as well as you have increased the STALL SPEED of your aircraft. Ken Smith >From: Bryan Martin <bryanmmartin(at)comcast.net> >Subject: Re: Zenith-List: Sabrina Re: pitching the H-stab > >The stabilizer has little to do with the cruise flight attitude of the >fuselage, it mainly has to do with the trim condition of the airplane. >If you can trim out the elevator forces in cruise without excessive >trim tab deflection, re-pitching the stabilizer won't help you. I re- >pitched my stabilizer because I couldn't trim out the stick forces, >not because the attitude of the airplane was wrong. I had to hold back >pressure on the stick all the time to keep the plane from diving. > >The cruise flight attitude of the fuselage is controlled mainly by the >angle of incidence of the main wing. Increasing the angle of incidence >of the main wing will bring the nose of the fuselage down, but then >you will also have to pitch the stabilizer up to get it back into trim. > >On Feb 19, 2008, at 1:26 AM, NYTerminat(at)aol.com wrote: > > > >>Hi all, >> >>With all the talk of pitching the horizontal stabilizer lately I >>have a quick question. I am doing my conditional inspection on my >>701 and decided to replace the front horizontal stabilizer brackets >>to the .063 material. There were no cracks in my old ones but I >>figured I might as well bite the bullet now while the weather is >>keeping me from flying anyway. I have always felt that I was flying >>in a nose high attitude while at cruise and that I do not see the >>higher MPH that others see. I purchased a digital level and have >>discovered that my horizontal stabilizer was about a half of a >>degree low in the front (approx 3 mm). I plan on raising it one >>degree so that I will be a half of a degree higher in the front >>based on the A-E line. I am wondering if this is a good idea as I >>believe this will get me flying in a better attitude at cruise and >>pick up some speed. Any thoughts? >> >>Bob Spudis >>N701Zx/ CH-701/ 912S/ 140hrs >> >> >> >> > > > > ________________________________________________________________________________
Date: Feb 20, 2008
Subject: Re: More Fuel
Why not add the wing baggage comp. fuel tanks? Jerry of Ga In a message dated 2/20/2008 10:38:26 A.M. Eastern Standard Time, zill(at)pinnacletrans.com writes: My 601HDS has two 10 gallon leading edge fuel tanks. I want to add 3-5 gallons fuel capacity. Will have the wing skins off. Any suggestions? HDS 235L2C **************Ideas to please picky eaters. Watch video on AOL Living. (http://living.aol.com/video/how-to-please-your-picky-eater/rachel-campos-duffy/ 2050827?NCID=aolcmp00300000002598) ________________________________________________________________________________
Date: Feb 20, 2008
Subject: Re: AeroElectric Connection Manual for sale
I am interested. I am just gathering all my insterments and getting ready to wire. Bob Sturgis bobefx(at)yahoo.com 601xl QB 818-902-9354 work 6am - 6pm Mon to Sat. ________________________________________________________________________________
Date: Feb 20, 2008
Hi Zill, I'd recommend you look at putting extra tanks in the wing lockers or use a small header. Larry McFarland 601HDS at www.macsmachine.com Zill Coleman wrote: > My 601HDS has two 10 gallon leading edge fuel tanks. I want to add > 3-5 gallons fuel capacity. Will have the wing skins off. Any > suggestions? > > HDS 235L2C ________________________________________________________________________________
Subject: Re: Diesel engines
Date: Feb 20, 2008
You might be interested in the Gemini 100 by Powerplant Developements in England. I saw the engine at the Light Sport Expo in Florida and really like the looks and idea of it. Its 100bhp at 2500rpm and has a specific fuel consumption of 0.37 at 75%. The total installed wet weight is 190.5 lbs. That's competitive with the Jabiru 3300 or Rotax 912. You can request info at info(at)ppdgemini.com. -------- Dale Flying Cessna 170B Building Zenith 601XL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165270#165270 Attachments: http://forums.matronics.com//files/gemini_100_spec_sheet_12_07_910.pdf ________________________________________________________________________________
Subject: 601XL Canopy
Date: Feb 20, 2008
Ladies and Gents; I have decided to glue the broken triangular piece back onto the canopy instead of purchasing a new canopy for $550 and then go through all the trouble of trimming, drilling, etc... To cover the damaged area, I have decided to revert back to the old way of doing things by installing a metal flashing on the front of the canopy. This is where I need the help from someone! Does anyone have the dimensions for this front flashing? My plans are too new and don't show this flashing. Any and all help will be greatly appreciated. Mack N990MK CH601XL/Jabiru3300 -------- The poh-oh-unemployed farm boy from Idaho Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165275#165275 ________________________________________________________________________________
Subject: I m spreading the news.
Date: Feb 20, 2008
Our fellow builder and contributior to this site, Larry McFarland has a machine shop and offers his services to this group. I saw that he had a nose wheel tow bar and strut collar for sale and I bought one from him. It arrived today..... What an " absolutely beautiful" piece of craftsmanship. The design is perfect and this product is amazing. Like most builders I thought I might build my own tow bar system, but now know that there's no way I could come close to the quality of Larry's work. I hope Larry continues to make these items and I recommend that everyone ask him about his products. Thanks Larry Steve Weston N9554Z 601XL almost, almost almost done! ________________________________________________________________________________
Date: Feb 20, 2008
My oldest set of plans lists .025, 210 X 1600, 6-C-3, 05/01. Same on the 01/03 version. -- Craig -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of aprazer Sent: Wednesday, February 20, 2008 3:29 PM Subject: Zenith-List: 601XL Canopy Ladies and Gents; I have decided to glue the broken triangular piece back onto the canopy instead of purchasing a new canopy for $550 and then go through all the trouble of trimming, drilling, etc... To cover the damaged area, I have decided to revert back to the old way of doing things by installing a metal flashing on the front of the canopy. This is where I need the help from someone! Does anyone have the dimensions for this front flashing? My plans are too new and don't show this flashing. Any and all help will be greatly appreciated. Mack N990MK CH601XL/Jabiru3300 -------- The poh-oh-unemployed farm boy from Idaho Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165275#165275 ________________________________________________________________________________
Subject: Rudder cut-out
Date: Feb 20, 2008
All- Nearly out of airframe parts! Need some help on this. Anyone have a surefire way of cutting the rudder nose skin to fit the stab and rudder fairing? All suggestions welcome, especially from flying people. Thanks. Bill Naumuk Townville, Pa. HDS Fuse/Corvair ________________________________________________________________________________
Subject: Re: I m spreading the news.
Date: Feb 20, 2008
Steve: It is no surprise to me. I've been admiring Larry's work for years. His sheet brake plans were superb and allowed me to build a sheet brake that helped me plans-build my airplane. I'm a big Larry Mc -fan also. Scott Laughlin www.cooknwithgas.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165317#165317 ________________________________________________________________________________
Date: Feb 20, 2008
I'm a big Larry Mac fan also. Look at the bike I hope to bring to SnF. His plans and seat form make it all possible. I did a little work myself but "Good Design is Good Design". Thanks Larry! http://mykitlog.com/users/index.php?user=rlendon&project=441 -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165322#165322 ________________________________________________________________________________
Date: Feb 20, 2008
don't forget that you need a calibration check at least once a year. Before the flames start to bloom, a simple fixture with a crank arm in a bearing and a tared bucket with water in it (pure water is 1 gram/cc; 453.6 grams/pound) is a good functional check. Brad, Getting back to the original subject, page 7-301 of AC 43.13-1B shows proper torque values. Yes, they are based on shank size, not wrench size. I have this page posted on my workbench as I seem to refer to it almost every day. As opposed to a torque wrench you'd find at Home Depot, I strongly recommend taking the plunge and buying a quality torque wrench. I have one from US Tool - model TP349 and it's great. If you're planning on installing a Rotax, You'll definitely use the metric (Newton-meter) side for your engine work. I know it's expensive, but IMHO it is a must-have. Here is their website: http://www.ustool.com/ That's my two cents. Dan Ginty N787DG 90% complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165215#165215 Attachments: http://forums.matronics.com//files/tp349_torque_wrench_199.jpg Dave Downey Harleysville (SE) PA 100 HP Corvair --------------------------------- Never miss a thing. Make Yahoo your homepage. ________________________________________________________________________________
Date: Feb 20, 2008
Subject: Upholstery sources
I am at that point on my XL where I have to start thinking about interior upholstery. I would be interested in getting recommendations (or avoidance warnings) on who has the best interiors. I am partial to leather (or similar) at this point. -- Paul Riedlinger cndmovn(at)gmail.com ________________________________________________________________________________
Date: Feb 21, 2008
Subject: Re: Upholstery
I bought my seats and side panels from Flightctafters and they are a thing of beauty. Look at the upholstery page on the Zenith web-site and you'll find a link. Rich Vetterli Pleasanton, CA CH601XL under construction Check out my progress at: www.geocities.com/stixx5a Looking for last minute shopping deals? ________________________________________________________________________________
Date: Feb 21, 2008
Subject: 601XL wheels
Has anyone used Cleveland wheels and brakes on the 601XL. I have a chance to buy a set of almost new 5.00X5 Cleveland wheels, brakes and axle's for $250. They have brand new tires and tubes on them and did 4 take off and landings on turf before he went up one size. They are off of a Cessna 150. The AP at the airport says that they are in excellent shape. I do not know what kind of weight penalty I would incur if any? If you have used this setup, let me know. The AP seems to think that they would be superior to the grove wheels for performance. Still looking for spring gear if anyone has some....... Larry Husky N667H (Reserved) **************Ideas to please picky eaters. Watch video on AOL Living. (http://living.aol.com/video/how-to-please-your-picky-eater/rachel-campos-duffy/ 2050827?NCID=aolcmp00300000002598) ________________________________________________________________________________
Date: Feb 21, 2008
I too am a huge Larry fan. I have his radiator set up on my 701 and it worked from the very minute I put it on. I would still be chasing my tail. His tow bar and collar was a welcome addition to the Purple Dragon as well! Many -o- thanks Larry ! ! -------- Low & Slow Rick www.n701rr.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165373#165373 Attachments: http://forums.matronics.com//files/air_intake_installation_142.jpg ________________________________________________________________________________
Date: Feb 21, 2008
XL owners, I need a favor. Can you hop in your plane and measure the distance from the top of the arm rest 6-B-18-2 where it meets the center back seat channel 6-B-16-2 and measure the distance between that spot and the top of the rear Canopy frame 6-C-3-1 where the plastic is joined to the alum tube. Please measure to the forward side of the tube while the canopy is in the closed position. I realize the tape measure will have to bend to reach. Also can you check the height of the arm rest to the highest portion of your canopy. Each of us have fitted this differently but I am curious as to the variance and If there is a base measure to help others in the future. I would use mine for this but I have installed an older 601HD canopy and it is a different shape then the 601XL's. Mark Townsend Alma, Ontario Zodiac 601XL C-GOXL, CH701 just started www.ch601.org / www.ch701.com / www.Osprey2.com 2/18/2008 6:49 PM ________________________________________________________________________________
Subject: HDS wing wanted
Date: Feb 21, 2008
Does anyone have a right wing for 601 HDS? With fuel tank? 501.351.5959 ________________________________________________________________________________
Subject: Re: 601XL wheels
Date: Feb 21, 2008
I haven't used Clevelands on my XL but had them on my 172 and later 182. I also retrofitted a set to my Aeronca Champ where they worked great. Cleveland makes a great product and unlike the Grove are FAA approved for production aircraft. Don't get me wrong, the Grove wheels are very well made... the main difference is that the company hasn't jumped through the hoops required by the FAA so they are currently approved only for experimental aircraft. If they will fit on the gear you plan to use I would say it sounds like a good deal, especially if axles are included. You can use master cylinders from cleveland, grove, matco or whoever you want. Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Working on fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165428#165428 ________________________________________________________________________________
Date: Feb 21, 2008
Subject: Re: HDS wing wanted
Zill, Try Mr Booths's email at gboothe(at)calply.com as he wants to change aircraft and build a Pietenpol. good luck, Larry McFarland 601HDS at www.macsmachine.com Gary Boothe Cool, CA 601 HDSTD, WW Conversion 90% done, Tail done, wings done, working on c-section Anyhow, I would like to sell the completed rudder, tail kit, wings and uncompleted center section. The rudder, tail and wings were all purchased kits, but the center section is a scratch build. The wings are for an HDS, with lockers and locker tanks. I dont think I will get all my money out of it, so I will be happy to discuss pricing with any interested parties all, or part. Gary Boothe Zill Coleman wrote: > Does anyone have a right wing for 601 HDS? With fuel tank? > 501.351.5959 > * > * ________________________________________________________________________________
Date: Feb 21, 2008
Subject: Re: Upholstery sources
call FLight Crafters in Zephyrhills. The set up in plane they made for me and did a great JOb. The PLeather they put in is wearing well and durable and the seats are well built. The contact is Russ Lepre 813-690-1916. Juan -----Original Message----- >From: Paul Riedlinger <cndmovn(at)gmail.com> >Sent: Feb 20, 2008 10:12 PM >To: zenith-list(at)matronics.com >Subject: Zenith-List: Upholstery sources > >I am at that point on my XL where I have to start thinking about interior >upholstery. I would be interested in getting recommendations (or avoidance >warnings) on who has the best interiors. I am partial to leather (or >similar) at this point. > > >-- >Paul Riedlinger >cndmovn(at)gmail.com ________________________________________________________________________________
From: "Southern Reflections" <purplemoon99(at)bellsouth.net>
Date: Feb 21, 2008
I'am In too... Larry, is Great .... good info and parts, and tool's. Intake scoop for the radi, also the lo presure louvers, tow bar, for my RAM 130 keeps her cool. Joe N101HD/ 601XL ----- Original Message ----- From: "rroberts" <n701rr(at)yahoo.com> Sent: Thursday, February 21, 2008 5:27 AM Subject: Zenith-List: Re: I m spreading the news. > > I too am a huge Larry fan. I have his radiator set up on my 701 and it > worked from the very minute I put it on. I would still be chasing my > tail. His tow bar and collar was a welcome addition to the Purple Dragon > as well! > > Many -o- thanks Larry ! ! > > -------- > Low & Slow > Rick > www.n701rr.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=165373#165373 > > > Attachments: > > http://forums.matronics.com//files/air_intake_installation_142.jpg > > > ________________________________________________________________________________
Date: Feb 21, 2008
Zill, I am selling my HDS project. I have two wings (with lockers), tail, rudder and =BD complete center section. You can contact me at: gboothe5(at)comcast.net. Gary Boothe Cool, CA 601 HDSTD, WW Conversion 90% done, Tail done, wings done, working on c-section _____ From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Zill Coleman Sent: Thursday, February 21, 2008 8:49 AM Subject: Zenith-List: HDS wing wanted Does anyone have a right wing for 601 HDS? With fuel tank? 501.351.5959 ________________________________________________________________________________
Date: Feb 22, 2008
How about some pictures and prices... Thanks, Mike -------- Mike Miller @ millrml(at)aol.com 601 XL, 3300, Dynon Remember, "the second mouse gets the cheese"! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165584#165584 ________________________________________________________________________________
Subject: Re: LRI Probe Question
Date: Feb 22, 2008
Does anyone of you using a holes in the wing as a ports for AOA? IMHO it is the most accurate method. Any disadvantages, bugs - other than possibilities of insects or ice pluging the hole? They are really small - .060" so there shouldn't be too much problems with flies etc. And I don't really like the look of the probe protruding the wing. -------- Pavel CA Zodiac XL N581PM (Reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165594#165594 ________________________________________________________________________________
Date: Feb 22, 2008
Subject: Stratus Re-drive Belt alternate source
Hi guys, Bill Morelli recently asked for a source for the Stratus Redrive Belt as performance alternative to Stratus in Washington. I just ordered a belt as a spare from Motion Industries 1920-5th Ave, Moline, IL 61265 Phone 309-797-1111 The price was near $65.00 which is reasonable for a Jason HTB Belt. Jason number printed on the belt is 880-8M-60MM. If you don't have a spare, perhaps it's time. Store it on edge in a zip lock or plastic bag. Keep it out of the sun and cold temps. Should be good for years. Good luck, Larry McFarland 601HDS at www.macsmachine.com ________________________________________________________________________________
Date: Feb 22, 2008
Subject: rudder light
What are people using for the rear light on the rudder? I don't have one yet and wonder if I should rivet the rudder before buying and installing the light or go ahead and finish the rudder and add the light later. What about the wires. Best bang for the buck? Zenith vs ?? Darrell 601 XL reserved N723DD ________________________________________________________________________________
Date: Feb 22, 2008
If you want to save power Kuntzleman has a new LED taillight: http://www.kestrobes.com/heads.htm#NEW_ITEM! Also the fiberglass taillight fairing from Zenith is not a great fit for some taillights. Others have bent up their own from Al sheet. -- Craig -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Darrell Haas Sent: Friday, February 22, 2008 1:07 PM Subject: Zenith-List: rudder light What are people using for the rear light on the rudder? I don't have one yet and wonder if I should rivet the rudder before buying and installing the light or go ahead and finish the rudder and add the light later. What about the wires. Best bang for the buck? Zenith vs ?? Darrell 601 XL reserved N723DD ________________________________________________________________________________
Subject: Re: rudder light
Date: Feb 22, 2008
Steve Wittman mounted a bulb holder so that the only thing that protruded from the rudders edge was the bulb top itself, no lens cover at all, Light ,cheap , practical, and it works, typical Wittman. John Bolding > > What are people using for the rear light on the rudder? I don't have > one yet and wonder if I should rivet the rudder before buying and > installing the light or go ahead and finish the rudder and add the > light later. What about the wires. Best bang for the buck? Zenith vs > ?? > Darrell > 601 XL > reserved N723DD > ________________________________________________________________________________
Subject: Re:rudder light
Date: Feb 22, 2008
I had my rudder riveted up when I installed mine, used stock install at time which was aeroflash. Go to bottom of page to see cutout done with air powered fiberglass disc cutter. http://www.701builder.com/rudder3.htm I used the fiberglass fairing and it seems very solid when installed. Brian Unruh Long Island, NY ________________________________________________________________________ ________________________________________________________________________________
Date: Feb 22, 2008
Subject: Re: Rudder cut-out
Bill, Are you having difficulty cutting the line that separates the rudder from the saddle piece? I've got a 5mm clearance between the saddle and the rudder. Getting the elevator bellcrank clearance and then the gap at the rudder is tricky. Place the saddle with crank clearance first. Then work up trim on the rudder. Then fill the bottom of the rudder with a bulkhead flanges up. Larry McFarland 601HDS at www.macsmachine.com Bill Naumuk wrote: > All- > Nearly out of airframe parts! > Need some help on this. > Anyone have a surefire way of cutting the rudder nose skin to fit > the stab and rudder fairing? All suggestions welcome, especially from > flying people. > Thanks. > Bill Naumuk > Townville, Pa. > HDS Fuse/Corvair > * > * ________________________________________________________________________________
Date: Feb 22, 2008
Subject: skins
How tight should the skins be on the rudder? Like a drum head? Should you be able to push them in and out slightly? Oil can? What is acceptable? Darrell 601XL N723DD reserved ________________________________________________________________________________
Date: Feb 23, 2008
I bought the ready made upholstery from Flightcrafters. I haven't installed it yet but have see it in other XL's. It looks and feels great and I was impressed with the quality sewing especially on the piece that covers the armrest and forms the boot for the control stick. They also included some extra fabric which I will use to cover between the seats up top. This link is to the info on Zenith's site. http://www.zenithair.com/zodiac/xl/xl-upholstery.html This link is the Flightcrafters link with price. http://www.zenithdistributing.com/ It's not cheap but my sewing skills are non-existent and this will give me "that new plane smell"..... Scott -------- 601 XL kit Tail, control surfaces and both wings complete. Now working on fuselage www.scottwaters.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165701#165701 ________________________________________________________________________________
Date: Feb 23, 2008
Larry- Having troubles- hell, I'm flying blind! I have absolutely no print or manual information about installing the saddle whatsoever. I don't even know if I can install the saddle now, before the rear top fuse skins are on. I wanted to get the empennage rough-rigged and my belly strobe wired before closing in the rear of the fuse, if possible. 1. How does the saddle attach to the stab? You had one picture in the archives that had two (Bolts/rivets) located at the aft end of the saddle. I would assume, then, that you used some standard angle for a mount. Did you continue the angle and hole pattern the entire length of the attachment area or just in the area shown in the picture? 2. Once the bottom edge is contoured to the stab, I'm assuming you follow the angle of the top of the saddle to meet the spar, plus 5mm clearance for the rudder nose skin cut. 3. Do you leave the flat top of the saddle closed, or are you supposed to cut it out? You know from my experience with the outboard fairings that I hate fiberglass, and it hates me. I'll be damned if I go through 3 saddles before I get it right this time. I intend to line the saddle on the CL with the top vertex even with the front of the nose skin. Then, I'll use a spacer to trace the contour of the stab and cut the bottom of the saddle. This will allow me to lay out the rudder nose skin cut. After cutting the nose skin, I'll trace the perimeter outline of the saddle to the stab, adjust for the thickness of the fiberglass, and install standard angle to the top of the stab for as long as practical. Sound like a plan? Let me know if I should wait until the top rear fuse skins are on. (I don't think they're a factor). Bill ----- Original Message ----- From: "LarryMcFarland" <larry(at)macsmachine.com> Sent: Friday, February 22, 2008 7:59 PM Subject: Re: Zenith-List: Rudder cut-out > > Bill, > Are you having difficulty cutting the line that separates the rudder from > the saddle piece? > I've got a 5mm clearance between the saddle and the rudder. Getting the > elevator bellcrank > clearance and then the gap at the rudder is tricky. > Place the saddle with crank clearance first. Then work up trim on the > rudder. Then fill the > bottom of the rudder with a bulkhead flanges up. > > Larry McFarland 601HDS at www.macsmachine.com > > Bill Naumuk wrote: >> All- >> Nearly out of airframe parts! >> Need some help on this. >> Anyone have a surefire way of cutting the rudder nose skin to fit the >> stab and rudder fairing? All suggestions welcome, especially from flying >> people. >> Thanks. >> Bill Naumuk >> Townville, Pa. >> HDS Fuse/Corvair >> * >> * > > > ________________________________________________________________________________
Date: Feb 23, 2008
Here's a picture. Bill ----- Original Message ----- From: "Bill Naumuk" <naumuk(at)alltel.net> Sent: Saturday, February 23, 2008 10:18 AM Subject: Re: Zenith-List: Rudder cut-out > Larry- > Having troubles- hell, I'm flying blind! I have absolutely no print or > manual information about installing the saddle whatsoever. I don't even > know if I can install the saddle now, before the rear top fuse skins are > on. I wanted to get the empennage rough-rigged and my belly strobe wired > before closing in the rear of the fuse, if possible. > 1. How does the saddle attach to the stab? You had one picture in the > archives that had two (Bolts/rivets) located at the aft end of the saddle. > I would assume, then, that you used some standard angle for a mount. Did > you continue the angle and hole pattern the entire length of the > attachment area or just in the area shown in the picture? > 2. Once the bottom edge is contoured to the stab, I'm assuming you > follow the angle of the top of the saddle to meet the spar, plus 5mm > clearance for the rudder nose skin cut. > 3. Do you leave the flat top of the saddle closed, or are you supposed > to cut it out? > You know from my experience with the outboard fairings that I hate > fiberglass, and it hates me. I'll be damned if I go through 3 saddles > before I get it right this time. > I intend to line the saddle on the CL with the top vertex even with the > front of the nose skin. Then, I'll use a spacer to trace the contour of > the stab and cut the bottom of the saddle. This will allow me to lay out > the rudder nose skin cut. > After cutting the nose skin, I'll trace the perimeter outline of the > saddle to the stab, adjust for the thickness of the fiberglass, and > install standard angle to the top of the stab for as long as practical. > Sound like a plan? Let me know if I should wait until the top rear fuse > skins are on. (I don't think they're a factor). > Bill > > ----- Original Message ----- > From: "LarryMcFarland" <larry(at)macsmachine.com> > To: > Sent: Friday, February 22, 2008 7:59 PM > Subject: Re: Zenith-List: Rudder cut-out > > >> >> Bill, >> Are you having difficulty cutting the line that separates the rudder from >> the saddle piece? >> I've got a 5mm clearance between the saddle and the rudder. Getting the >> elevator bellcrank >> clearance and then the gap at the rudder is tricky. >> Place the saddle with crank clearance first. Then work up trim on the >> rudder. Then fill the >> bottom of the rudder with a bulkhead flanges up. >> >> Larry McFarland 601HDS at www.macsmachine.com >> >> Bill Naumuk wrote: >>> All- >>> Nearly out of airframe parts! >>> Need some help on this. >>> Anyone have a surefire way of cutting the rudder nose skin to fit >>> the stab and rudder fairing? All suggestions welcome, especially from >>> flying people. >>> Thanks. >>> Bill Naumuk >>> Townville, Pa. >>> HDS Fuse/Corvair >>> * >>> * >> >> >> >> >> >> > ________________________________________________________________________________
Date: Feb 23, 2008
You're right Bill, but you do need to put the rear top skins on before you get into fitting the saddle. Then you have the dimensions needed and the estimate of fit to make it work. Don't know anyone that's succeeded in putting it on before the rear top skin. Even trimming the rear top skin for the stab is a pain, but that needs doing too. http://www.macsmachine.com/images/rudder/full/rudderfairing.gif http://www.macsmachine.com/images/rudder/full/fitfairing.gif http://www.macsmachine.com/images/rudder/full/ruddernose.gif The rudder, elevator bellcrank and rear top skin fitted for the nose of the stabilizer, then the saddle. http://www.macsmachine.com/images/controllinkages/full/runuprear.gif The saddle is a bitch to get in until you learn to spread the sides of it as you draw it back under the rudder far enough to get the front edge under the rear top skin. You have to not trim too much from your rear top skin to allow fasteners and rudder gap and bellcrank their proper clearances. It gets close with this piece. http://www.macsmachine.com/images/controllinkages/full/bhorn.gif The two screws you see on each side screw into tinnermans on a short standard angle. The front of the saddle is fitted with 3 tinnermans and I have screws going thru the rear top skin and into the tinnermans. That was my solution to the forward and rear side attach points. Hope this helps a bit, Larry McFarland Bill Naumuk wrote: > Here's a picture. > Bill > ----- Original Message ----- From: "Bill Naumuk" <naumuk(at)alltel.net> > To: > Sent: Saturday, February 23, 2008 10:18 AM > Subject: Re: Zenith-List: Rudder cut-out > > >> Larry- >> Having troubles- hell, I'm flying blind! I have absolutely no >> print or manual information about installing the saddle whatsoever. I >> don't even know if I can install the saddle now, before the rear top >> fuse skins are on. I wanted to get the empennage rough-rigged and my >> belly strobe wired before closing in the rear of the fuse, if possible. >> 1. How does the saddle attach to the stab? You had one picture in >> the archives that had two (Bolts/rivets) located at the aft end of >> the saddle. I would assume, then, that you used some standard angle >> for a mount. Did you continue the angle and hole pattern the entire >> length of the attachment area or just in the area shown in the picture? >> 2. Once the bottom edge is contoured to the stab, I'm assuming you >> follow the angle of the top of the saddle to meet the spar, plus 5mm >> clearance for the rudder nose skin cut. >> 3. Do you leave the flat top of the saddle closed, or are you >> supposed to cut it out? >> You know from my experience with the outboard fairings that I hate >> fiberglass, and it hates me. I'll be damned if I go through 3 saddles >> before I get it right this time. >> I intend to line the saddle on the CL with the top vertex even >> with the front of the nose skin. Then, I'll use a spacer to trace the >> contour of the stab and cut the bottom of the saddle. This will allow >> me to lay out the rudder nose skin cut. >> After cutting the nose skin, I'll trace the perimeter outline of >> the saddle to the stab, adjust for the thickness of the fiberglass, >> and install standard angle to the top of the stab for as long as >> practical. >> Sound like a plan? Let me know if I should wait until the top rear >> fuse skins are on. (I don't think they're a factor). >> Bill >> >> ----- Original Message ----- From: "LarryMcFarland" >> >> To: >> Sent: Friday, February 22, 2008 7:59 PM >> Subject: Re: Zenith-List: Rudder cut-out >> >> >>> >>> >>> Bill, >>> Are you having difficulty cutting the line that separates the rudder >>> from the saddle piece? >>> I've got a 5mm clearance between the saddle and the rudder. Getting >>> the elevator bellcrank >>> clearance and then the gap at the rudder is tricky. >>> Place the saddle with crank clearance first. Then work up trim on >>> the rudder. Then fill the >>> bottom of the rudder with a bulkhead flanges up. >>> >>> Larry McFarland 601HDS at www.macsmachine.com >>> >>> Bill Naumuk wrote: >>>> All- >>>> Nearly out of airframe parts! >>>> Need some help on this. >>>> Anyone have a surefire way of cutting the rudder nose skin to >>>> fit the stab and rudder fairing? All suggestions welcome, >>>> especially from flying people. >>>> Thanks. >>>> Bill Naumuk >>>> Townville, Pa. >>>> HDS Fuse/Corvair >>>> * >>>> * >>> >>> >>> >>> >>> >>> >> > > ------------------------------------------------------------------------ > ________________________________________________________________________________
Date: Feb 23, 2008
>The saddle is a bitch to get in until you learn to spread the sides of it >as you draw it back under the rudder far >enough to get the front edge under the rear top skin. ...or try this which also allows the stab to be removed without marring paint/finish. http://www.ch601.org/resources/zodiac%20updates/mod_to_remove_stabilizer_at_a_la.htm ________________________________________________________________________________
Subject: Toughest e-mail I ever wrote
Date: Feb 23, 2008
I have lost the sight of my left eye, and will sell my carefully built 601XL for about one half of what I have in it. Includes Jab 3300 mounted in fitted cowling, firewall forward, dual sticks, hinged ailerons, aileron trim. Fuselage ,wings and tail are complete and have been test mounted and cables rigged. wings are back off. fuselage is complete less about half the work to finish the canopy...Ready to install the systems, decide what instruments and radios to buy and to put in it and do that job. Airplane is in N.C., and can be had for $17,500. Off- line inquiries please...Lots of pictures EAA guy says "excellent" amhoner(at)rtmc.net...336-857-1151 ________________________________________________________________________________
Subject: Re: Bottom Rudder Bracket attachment
Date: Feb 23, 2008
OK so assuming that the prints are incorrect on the number of A5 rivets it says 6, someone has confirmed with Zenith that the correct # is 4, is the number of bolts still 4 as indicated in the drawings? Two are shown in the manual.... Yes, I understand the drawings take priority over the manual and not to count the x's for rivets. Anybody mind taking a look at their QB kit? How is Zenith installing them these days? Thanks, -------- One Rivet at a Time! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165783#165783 ________________________________________________________________________________
Date: Feb 23, 2008
Take a look at these shots of my QBK. -- Craig -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of MHerder Sent: Saturday, February 23, 2008 11:59 AM Subject: Zenith-List: Re: Bottom Rudder Bracket attachment OK so assuming that the prints are incorrect on the number of A5 rivets it says 6, someone has confirmed with Zenith that the correct # is 4, is the number of bolts still 4 as indicated in the drawings? Two are shown in the manual.... Yes, I understand the drawings take priority over the manual and not to count the x's for rivets. Anybody mind taking a look at their QB kit? How is Zenith installing them these days? Thanks, -------- One Rivet at a Time! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165783#165783 ________________________________________________________________________________
Date: Feb 23, 2008
I ended up building my own and then taking it to a local auto upholstery shop. I am real happy with the resluts. Check it out on my site http://www.zodiacxl.com/Seats.htm Matt www.zodiacxl.com -------- Matt www.zodiacxl.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165804#165804 Attachments: http://forums.matronics.com//files/img_1786_107.jpg ________________________________________________________________________________
Subject: Saddle, pt II
Date: Feb 23, 2008
All- On lister advice, decided to wait until rear top skins were in place before fitting the saddle. Rough rigged elevator; will have to pore over ACS catalog to get electrical fittings to connect tail light, elevator trim, and belly strobe. Will also have to install a fitting attached to the lower fuse to support cables. Then I can install the rear fuse top skins. Note: HF cable cutting pliers are a POS. The ACS $15.00 Nico Press squeezer is barely adequate for the assembly of 1 project. I have 2 fittings to go and the squeezer is about shot. 90% done, 95% to go! Bill Naumuk Townville, Pa. HDS Fuse/Corvair ________________________________________________________________________________
Subject: Seats: seat backs, cushions, and upholstery
Date: Feb 23, 2008
All, I'm working with the seats now too. I have found that there really are three parts to the seats. These are the cushions, the seat backs, and the upholstery. My manual suggests plywood as the seat back material. The fiberglass (reinforced plastic) solution as shown on the CH601.org web site appears to be a better solution. I guess I'll just have to learn to use fiberglass. For the cushions, several types of foam are available from common soft foam to Confor Foam. Both Hi-Tech Seats and Oregon Aero have patterns for the 601 using Confor foam. Oregon Aero is more than twice the price of Hi-Tech, but includes a multi-piece seat with professionally contoured shapes. Does anyone have either installed? I checked with a local auto upholstery shop, and getting the cover done should be the easiest part. I have a couple questions: How far above the baggage shelf should the headrest portion of the seatback extend to protect our heads? Most of the pictures I see just have a large arc or simple straight edge as the top of the seat back. Is there a reason that there is no head rest? Should the seats be more like the bucket seats in a car with integral head rests? Is it just personal preference? I just measured my plane and came up with 300 mm above the shelf for the top of the headrest assuming a 3 inch foam seat over the seat pan. How do the Flightcrafters or Zenith seats compare? Thanks .... Jeff D. ________________________________________________________________________________
Subject: Re: Saddle, pt II
Date: Feb 23, 2008
For the five conductor trim cable, go to Radio Shack and buy the panel mount plug for a CB mic. It has five pins and has a locking ring to keep it securely plugged. Dred ----- Original Message ----- From: Bill Naumuk To: zenith list Sent: Saturday, February 23, 2008 2:59 PM Subject: Zenith-List: Saddle, pt II All- On lister advice, decided to wait until rear top skins were in place before fitting the saddle. Rough rigged elevator; will have to pore over ACS catalog to get electrical fittings to connect tail light, elevator trim, and belly strobe. Will also have to install a fitting attached to the lower fuse to support cables. Then I can install the rear fuse top skins. Note: HF cable cutting pliers are a POS. The ACS $15.00 Nico Press squeezer is barely adequate for the assembly of 1 project. I have 2 fittings to go and the squeezer is about shot. 90% done, 95% to go! Bill Naumuk Townville, Pa. HDS Fuse/Corvair ------------------------------------------------------------------------- ----- 2/22/2008 6:39 PM ________________________________________________________________________________
Date: Feb 23, 2008
Subject: Re: Seats: seat backs, cushions, and upholstery
Hi Jeff, The seats are easily done with plywood backs or fiberglass. Automotive foams are cheaper and perhaps easier to get hold of at many sewing and fabric outlets. Density is something you want to pay attention to. Confor foam is expensive beyond practical concerns, but for flammability perhaps. I've a page on seat construction that may explain the process. See link below. Seat backs need only go an inch or more above the shelf or to shoulder support height. Easier to get belts over your shoulders if you don't go too high. Head rests are for the flying public and passengers but I wouldn't recommend them because of a need for access to the rear shelf during flight. http://www.macsmachine.com/html/seatupholstery.htm Good luck, Larry McFarland 601HDS at www.macsmachine.com Jeff wrote: > > All, > > I'm working with the seats now too. I have found that there really are > three parts to the seats. These are the cushions, the seat backs, and the > upholstery. > > My manual suggests plywood as the seat back material. The fiberglass > (reinforced plastic) solution as shown on the CH601.org web site appears to > be a better solution. I guess I'll just have to learn to use fiberglass. > > For the cushions, several types of foam are available from common soft foam > to Confor Foam. Both Hi-Tech Seats and Oregon Aero have patterns for the > 601 using Confor foam. Oregon Aero is more than twice the price of Hi-Tech, > but includes a multi-piece seat with professionally contoured shapes. Does > anyone have either installed? > > I checked with a local auto upholstery shop, and getting the cover done > should be the easiest part. > > I have a couple questions: > > How far above the baggage shelf should the headrest portion of the seatback > extend to protect our heads? Most of the pictures I see just have a large > arc or simple straight edge as the top of the seat back. Is there a reason > that there is no head rest? Should the seats be more like the bucket seats > in a car with integral head rests? Is it just personal preference? I just > measured my plane and came up with 300 mm above the shelf for the top of the > headrest assuming a 3 inch foam seat over the seat pan. How do the > Flightcrafters or Zenith seats compare? > > Thanks .... > > Jeff D. > > > ________________________________________________________________________________
Date: Feb 23, 2008
When the plane is completely done, is when I bothered with the saddle. the very last thing right before first flight. measure 20 then cut once, then measure 20 , cut once, etc... fits nice and snug now. Juan -----Original Message----- >From: LarryMcFarland <larry(at)macsmachine.com> >Sent: Feb 23, 2008 12:43 PM >To: zenith-list(at)matronics.com >Subject: Re: Zenith-List: Rudder cut-out > > >You're right Bill, >but you do need to put the rear top skins on before you get into fitting >the saddle. Then you have the dimensions >needed and the estimate of fit to make it work. Don't know anyone >that's succeeded in putting it on before the >rear top skin. Even trimming the rear top skin for the stab is a pain, >but that needs doing too. >http://www.macsmachine.com/images/rudder/full/rudderfairing.gif >http://www.macsmachine.com/images/rudder/full/fitfairing.gif >http://www.macsmachine.com/images/rudder/full/ruddernose.gif >The rudder, elevator bellcrank and rear top skin fitted for the nose of >the stabilizer, then the saddle. >http://www.macsmachine.com/images/controllinkages/full/runuprear.gif >The saddle is a bitch to get in until you learn to spread the sides of >it as you draw it back under the rudder far >enough to get the front edge under the rear top skin. You have to not >trim too much from your rear top skin to >allow fasteners and rudder gap and bellcrank their proper clearances. It >gets close with this piece. >http://www.macsmachine.com/images/controllinkages/full/bhorn.gif >The two screws you see on each side screw into tinnermans on a short >standard angle. The front of the saddle >is fitted with 3 tinnermans and I have screws going thru the rear top >skin and into the tinnermans. That was my >solution to the forward and rear side attach points. > >Hope this helps a bit, > >Larry McFarland > > >Bill Naumuk wrote: >> Here's a picture. >> Bill >> ----- Original Message ----- From: "Bill Naumuk" <naumuk(at)alltel.net> >> To: >> Sent: Saturday, February 23, 2008 10:18 AM >> Subject: Re: Zenith-List: Rudder cut-out >> >> >>> Larry- >>> Having troubles- hell, I'm flying blind! I have absolutely no >>> print or manual information about installing the saddle whatsoever. I >>> don't even know if I can install the saddle now, before the rear top >>> fuse skins are on. I wanted to get the empennage rough-rigged and my >>> belly strobe wired before closing in the rear of the fuse, if possible. >>> 1. How does the saddle attach to the stab? You had one picture in >>> the archives that had two (Bolts/rivets) located at the aft end of >>> the saddle. I would assume, then, that you used some standard angle >>> for a mount. Did you continue the angle and hole pattern the entire >>> length of the attachment area or just in the area shown in the picture? >>> 2. Once the bottom edge is contoured to the stab, I'm assuming you >>> follow the angle of the top of the saddle to meet the spar, plus 5mm >>> clearance for the rudder nose skin cut. >>> 3. Do you leave the flat top of the saddle closed, or are you >>> supposed to cut it out? >>> You know from my experience with the outboard fairings that I hate >>> fiberglass, and it hates me. I'll be damned if I go through 3 saddles >>> before I get it right this time. >>> I intend to line the saddle on the CL with the top vertex even >>> with the front of the nose skin. Then, I'll use a spacer to trace the >>> contour of the stab and cut the bottom of the saddle. This will allow >>> me to lay out the rudder nose skin cut. >>> After cutting the nose skin, I'll trace the perimeter outline of >>> the saddle to the stab, adjust for the thickness of the fiberglass, >>> and install standard angle to the top of the stab for as long as >>> practical. >>> Sound like a plan? Let me know if I should wait until the top rear >>> fuse skins are on. (I don't think they're a factor). >>> Bill >>> >>> ----- Original Message ----- From: "LarryMcFarland" >>> >>> To: >>> Sent: Friday, February 22, 2008 7:59 PM >>> Subject: Re: Zenith-List: Rudder cut-out >>> >>> >>>> >>>> >>>> Bill, >>>> Are you having difficulty cutting the line that separates the rudder >>>> from the saddle piece? >>>> I've got a 5mm clearance between the saddle and the rudder. Getting >>>> the elevator bellcrank >>>> clearance and then the gap at the rudder is tricky. >>>> Place the saddle with crank clearance first. Then work up trim on >>>> the rudder. Then fill the >>>> bottom of the rudder with a bulkhead flanges up. >>>> >>>> Larry McFarland 601HDS at www.macsmachine.com >>>> >>>> Bill Naumuk wrote: >>>>> All- >>>>> Nearly out of airframe parts! >>>>> Need some help on this. >>>>> Anyone have a surefire way of cutting the rudder nose skin to >>>>> fit the stab and rudder fairing? All suggestions welcome, >>>>> especially from flying people. >>>>> Thanks. >>>>> Bill Naumuk >>>>> Townville, Pa. >>>>> HDS Fuse/Corvair >>>>> * >>>>> * >>>> >>>> >>>> >>>> >>>> >>>> >>> >> >> ------------------------------------------------------------------------ >> > > ________________________________________________________________________________
Subject: Where's the Love?
Date: Feb 23, 2008
Here's the Love: http://www.youtube.com/watch?v=iQCF6Ab7ITU Motivation for the week. Scott Laughlin www.cooknwithgas.com Omaha, Nebraska 35 hours and counting Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165839#165839 ________________________________________________________________________________
Subject: Re: Toughest e-mail I ever wrote
Date: Feb 23, 2008
Friend, I'm sorry that you feel you must sell your XL. Such decisions are never easy. I would like to point out that in my flying career I have worked with two pilots who had sight in only one eye and each went on to earn their private licenses. One owned and flew a Piper Arrow for many years. Also, let us not forget the great Wiley Post. Good luck! Tim Juhl -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Working on fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165842#165842 ________________________________________________________________________________
Subject: One-eyed Pilots
Date: Feb 23, 2008
To the friend that lost an eye: As Tim Juhl pointed out, there are one-eyed pilots. We had one at the airline I flew for. He was grounded for about a year before getting his medical back and then another year before he was back in the left seat. It's possible--Good Luck. Stan ________________________________________________________________________________
Date: Feb 23, 2008
----- Original Message ----- From: A. Michael Honer To: Zenith-list(at)matronics.com Sent: Saturday, February 23, 2008 1:40 PM Subject: Zenith-List: Toughest e-mail I ever wrote I have lost the sight of my left eye, and will sell my carefully built 601XL for about one half of what I have in it. Includes Jab 3300 mounted in fitted cowling, firewall forward, dual sticks, hinged ailerons, aileron trim. Fuselage ,wings and tail are complete and have been test mounted and cables rigged. wings are back off. fuselage is complete less about half the work to finish the canopy...Ready to install the systems, decide what instruments and radios to buy and to put in it and do that job. Airplane is in N.C., and can be had for $17,500. Off- line inquiries please...Lots of pictures EAA guy says "excellent" amhoner(at)rtmc.net...336-857-1151 where is aircraft located.what kind of gear.single stick or dual ________________________________________________________________________________
Subject: Re: One-eyed Pilots
Date: Feb 23, 2008
Heck, I dont have brains and I fly.. SW ----- Original Message ----- From: "Stanley Challgren" <challgren(at)mac.com> Sent: Saturday, February 23, 2008 5:31 PM Subject: Zenith-List: One-eyed Pilots > > To the friend that lost an eye: > > As Tim Juhl pointed out, there are one-eyed pilots. We had one at the > airline I flew for. He was grounded for about a year before getting > his medical back and then another year before he was back in the left > seat. > > It's possible--Good Luck. > > Stan > > > > > > ________________________________________________________________________________
Date: Feb 23, 2008
What you pay attention to matters much more than how many eyes you see things with. Disappointment is inevitable. Surrender, however, is still optional. Give it a while. It seems a shame to walk away from an excellent aircraft. Dred ----- Original Message ----- From: A. Michael Honer To: Zenith-list(at)matronics.com Sent: Saturday, February 23, 2008 1:40 PM Subject: Zenith-List: Toughest e-mail I ever wrote I have lost the sight of my left eye, and will sell my carefully built 601XL for about one half of what I have in it. Includes Jab 3300 mounted in fitted cowling, firewall forward, dual sticks, hinged ailerons, aileron trim. Fuselage ,wings and tail are complete and have been test mounted and cables rigged. wings are back off. fuselage is complete less about half the work to finish the canopy...Ready to install the systems, decide what instruments and radios to buy and to put in it and do that job. Airplane is in N.C., and can be had for $17,500. Off- line inquiries please...Lots of pictures EAA guy says "excellent" amhoner(at)rtmc.net...336-857-1151 ________________________________________________________________________________
Date: Feb 23, 2008
Please, please, PLEASE......do yourself a really BIG FAVOR (and the rest of us that are feeling your pain and sorrow). Do NOT SELL YOUR LOVE OF FLIGHT!! Hold on to your airplane for several years until you get a more definitive idea of what your limitations are. As others have said to you before, they know of, or are personal friends of people that HAVE FLOWN and DO FLY with only one eye!! Sure, things are going to be hard to adjust to at first, but in time, your body DOES learn to adapt - and it adapts quite well for the most part. Give yourself some space and time. Do those things you need to to complete your "baby".....I would hate to see you give up this dream while you're in this state of mind. Learn to drive your car first and then see how it goes. Remember too, you do NOT NEED a General Aviation License to fly this! You can claim you will fly this under the new Light Sport Class, which you only need a valid driver's license!! DO NOT go for another flight medical.....you do not want to be denied for any reason. You do NOT need a medical to fly under the Light Sport!!! Please check out what I am telling you. The Zodiac CH601XL IS A "PERFECT" Light Sport aircraft! I hope I've given you something to really think about and a sense of hope for your future in flying.....don't EVER give up your dreams! Blue Skies Always, Larry H -------- Larry Hursh (N601LL Reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165863#165863 ________________________________________________________________________________
Date: Feb 23, 2008
Personal experience: During my fuselage build, I suffered a detached retina. Beyond surgery, part of the correction was inserting a gas bubble in the eyeball to keep the retina pressed against the lining of the eyeball. The gas was slowly absorbed and it was gone in about six weeks. But while it was there, I couldn't see through that bubble; so I had single eye vision for a while. Sure, it really eliminated "normal" depth perception, but I kept building. I keenly recall drilling the flap actuator bracket to its support, upside down, using a mirror and one good eye. It CAN be done. Please give yourself some time to adjust before deciding to chuck it. Please. Jay in Dallas 601XL N2630J "Lil Bruiser" "skyridersbn" wrote: > >Please, please, PLEASE......do yourself a really BIG FAVOR (and the rest of us that are feeling your pain and sorrow). Do NOT SELL YOUR LOVE OF FLIGHT!! Hold on to your airplane for several years until you get a more definitive idea of what your limitations are. As others have said to you before, they know of, or are personal friends of people that HAVE FLOWN and DO FLY with only one eye!! Sure, things are going to be hard to adjust to at first, but in time, your body DOES learn to adapt - and it adapts quite well for the most part. Give yourself some space and time. Do those things you need to to complete your "baby".....I would hate to see you give up this dream while you're in this state of mind. Learn to drive your car first and then see how it goes. Remember too, you do NOT NEED a General Aviation License to fly this! You can claim you will fly this under the new Light Sport Class, which you only need a valid driver's license!! DO NOT go for another flight med! > ical.....you do not want to be denied for any reason. You do NOT need a medical to fly under the Light Sport!!! Please check out what I am telling you. The Zodiac CH601XL IS A "PERFECT" Light Sport aircraft! > >I hope I've given you something to really think about and a sense of hope for your future in flying.....don't EVER give up your dreams! > >Blue Skies Always, >Larry H > >-------- >Larry Hursh (N601LL Reserved) > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=165863#165863 > > ________________________________________________________________________________
Date: Feb 23, 2008
which airline was that so that I avoid it. -----Original Message----- >From: Stanley Challgren <challgren(at)mac.com> >Sent: Feb 23, 2008 7:31 PM >To: Zenith List >Subject: Zenith-List: One-eyed Pilots > > >To the friend that lost an eye: > >As Tim Juhl pointed out, there are one-eyed pilots. We had one at the >airline I flew for. He was grounded for about a year before getting >his medical back and then another year before he was back in the left >seat. > >It's possible--Good Luck. > >Stan > > ________________________________________________________________________________
Date: Feb 23, 2008
If you haven't lost you medical yet then you can fly as a sport pilot - no questions asked. The only medical requirement for sport pilot is that you hold a valid driver's license. -- Craig From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of A. Michael Honer Sent: Saturday, February 23, 2008 11:40 AM Subject: Zenith-List: Toughest e-mail I ever wrote I have lost the sight of my left eye, and will sell my carefully built 601XL for about one half of what I have in it. Includes Jab 3300 mounted in fitted cowling, firewall forward, dual sticks, hinged ailerons, aileron trim. Fuselage ,wings and tail are complete and have been test mounted and cables rigged. wings are back off. fuselage is complete less about half the work to finish the canopy...Ready to install the systems, decide what instruments and radios to buy and to put in it and do that job. Airplane is in N.C., and can be had for $17,500. Off- line inquiries please...Lots of pictures EAA guy says "excellent" amhoner(at)rtmc.net...336-857-1151 ________________________________________________________________________________
Date: Feb 23, 2008
> My flight instructor only had one eye, but he could > teach a blind man to fly. Don't give up... --- steve wrote: > > > Heck, I dont have brains and I fly.. > > SW > ----- Original Message ----- > From: "Stanley Challgren" <challgren(at)mac.com> > To: "Zenith List" > Sent: Saturday, February 23, 2008 5:31 PM > Subject: Zenith-List: One-eyed Pilots > > > Challgren > > > > To the friend that lost an eye: > > > > As Tim Juhl pointed out, there are one-eyed > pilots. We had one at the > > airline I flew for. He was grounded for about a > year before getting > > his medical back and then another year before he > was back in the left > > seat. > > > > It's possible--Good Luck. > > > > Stan > > > > > > > > > > > > > > > > browse > Un/Subscription, > FAQ, > http://www.matronics.com/Navigator?Zenith-List > > Forums! > > Admin. > > > > > Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs ________________________________________________________________________________
Subject: Re: skins
Date: Feb 23, 2008
It's going to change with the temperature. The best you can do is warm up everything and assemble and rivet. When it cools it will be as tight as it is going to be. Some folks place everything in the sun to warm it up, me, living in the great gray north, use a furnace to heat up the entire garage. -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165877#165877 ________________________________________________________________________________
Date: Feb 23, 2008
Subject: Re: Where's the Love?
> Perhaps the one eyed pilot should get some incentive > not to give up flying after he sees this video.. --- cookwithgas wrote: > > > Here's the Love: > > http://www.youtube.com/watch?v=iQCF6Ab7ITU > > Motivation for the week. > > Scott Laughlin > www.cooknwithgas.com > Omaha, Nebraska > 35 hours and counting > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=165839#165839 > > > > > > > > > browse > Un/Subscription, > FAQ, > http://www.matronics.com/Navigator?Zenith-List > > Forums! > > Admin. > > > > > Looking for last minute shopping deals? ________________________________________________________________________________
Subject: Re: Saddle
Date: Feb 23, 2008
I adjusted the rear hor. stab. mounts. No need to do anything to the saddle. Dave Austin 601HDS - 912, Spitfire Mk VIII ________________________________________________________________________________
Date: Feb 23, 2008
This is a poem my father taught me that has helped many times in my life. It Couldn't Be Done Edgar Guest Somebody said that it couldn't be done, But he with a chuckle replied That "maybe it couldn't," but he would be one Who wouldn't say so till he'd tried. So he buckled right in with the trace of a grin On his face. If he worried he hid it. He started to sing as he tackled the thing That couldn't be done, and he did it. Somebody scoffed: "Oh, you'll never do that; At least no one ever has done it"; But he took off his coat and he took off his hat, And the first thing we knew he'd begun it. With a lift of his chin and a bit of a grin, Without any doubting or quiddit, He started to sing as he tackled the thing That couldn't be done, and he did it. There are thousands to tell you it cannot be done, There are thousands to prophesy failure; There are thousands to point out to you, one by one, The dangers that wait to assail you. But just buckle in with a bit of a grin, Just take off your coat and go to it; Just start to sing as you tackle the thing That "cannot be done," and you'll do it. Many good people here want to see you continue with your dream of flying. Give it time. -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165890#165890 ________________________________________________________________________________
Date: Feb 23, 2008
Subject: Re: Saddle
I installed my saddle yesterday and here's what I did. From the plans, I plotted and drew out the top half of the HT rib on a piece of cardboard. I cut that out and used it to transfer the curve to the bottom of the saddle with a sharpie. Sanded to the line and had a nearly perfect fit. A little fine tuning and it was ready to drill and cleco. Rich Vetterli Pleasanton, CA CH601XL under construction Check out my progress at: www.geocities.com/stixx5a Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs ________________________________________________________________________________
Subject: Re: Saddle
Date: Feb 24, 2008
Rich- Hmm. More than one way to skin a cat. I was going to level the saddle and duct tape it directly on the stab. Then run a Sharpie line using a spacer to get an acceptable height. If nothing else, we're getting a lot of ideas into the archives. When I looked this morning, there wasn't much to speak of. Bill ----- Original Message ----- From: "Richard Vetterli" <richvetterli(at)yahoo.com> Sent: Sunday, February 24, 2008 12:02 AM Subject: Zenith-List: Re: Saddle > > > I installed my saddle yesterday and here's what I did. > From the plans, I plotted and drew out the top half > of the HT rib on a piece of cardboard. I cut that out > and used it to transfer the curve to the bottom of the > saddle with a sharpie. Sanded to the line and had a > nearly perfect fit. A little fine tuning and it was > ready to drill and cleco. > > Rich Vetterli > Pleasanton, CA > CH601XL under construction > Check out my progress at: www.geocities.com/stixx5a > > > Never miss a thing. Make Yahoo your home page. > http://www.yahoo.com/r/hs > > > ________________________________________________________________________________
Date: Feb 24, 2008
Many thanks Ron for posting this poem. Your father must have been a great man. Jean-Paul Ron Lendon a crit : This is a poem my father taught me that has helped many times in my life. It Couldn't Be Done Edgar Guest Somebody said that it couldn't be done, But he with a chuckle replied That "maybe it couldn't," but he would be one Who wouldn't say so till he'd tried. So he buckled right in with the trace of a grin On his face. If he worried he hid it. He started to sing as he tackled the thing That couldn't be done, and he did it. Somebody scoffed: "Oh, you'll never do that; At least no one ever has done it"; But he took off his coat and he took off his hat, And the first thing we knew he'd begun it. With a lift of his chin and a bit of a grin, Without any doubting or quiddit, He started to sing as he tackled the thing That couldn't be done, and he did it. There are thousands to tell you it cannot be done, There are thousands to prophesy failure; There are thousands to point out to you, one by one, The dangers that wait to assail you. But just buckle in with a bit of a grin, Just take off your coat and go to it; Just start to sing as you tackle the thing That "cannot be done," and you'll do it. Many good people here want to see you continue with your dream of flying. Give it time. -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165890#165890 --------------------------------- Dcouvrez les styles qui font sensation sur Yahoo! Qubec Avatars ________________________________________________________________________________
Date: Feb 24, 2008
Don't do it! For all the reasons stated above and simply because, it takes a human to pilot an airplane. You can still breath and you can still see, my guess is that your humanity didn't leave you. So by my count, you can still be a pilot. Hell, because of your loss, you'll most likely end of being a better, safer pilot just because you pay more attention to whats going on then you would have with both eyes! Don't sell yourself short, give it an honest chance. -------- Kevin N701DZ Reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165915#165915 ________________________________________________________________________________
Subject: Re: RE : Re: Toughest e-mail I ever wrote
Date: Feb 24, 2008
I'll second that comment! -------- Kevin N701DZ Reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165917#165917 ________________________________________________________________________________
Date: Feb 24, 2008
[Embarassed] amyvega2005(at)earthlink. wrote: > which airline was that so that I avoid it. > > -- -------- Kevin N701DZ Reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165918#165918 ________________________________________________________________________________
Subject: Actual rudder pedal travel in 601
Date: Feb 24, 2008
Hello there 601 builders, I am finishing off my brake pedals and brackets for the master cylinders and don't seem to have a great deal of forward travel before the master cyl stops against the base mounting bracket. Could anyone tell me the actual rudder travel when the cables are hooked up? Thanks in advance happy building Darryl Darwin, Australia Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165925#165925 ________________________________________________________________________________
Subject: Re: Actual rudder pedal travel in 601
Date: Feb 24, 2008
When I did mine I needed to file the mounting bracket for the cylinders off a bit to give me enough travel on the pedals so that they did not hit the bracket. -------- 601XL N676L reserved ALMOST DONE CHESAPEAKE VA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165934#165934 ________________________________________________________________________________
Date: Feb 24, 2008
Michael: Let me make you aware of the work of Professor Ian Howard, a clinical psychologist at York University in Toronto. Ian showed, with detailed experimentation, and even managed to convince Transport Canada, that a person does not use two eyes for stereoscopic vision at a distance beyond about 10 feet. That is, in landing an aircraft, you are NOT using stereoscopic vision, so that one (good) eye is essentially as useful as two. One gets depth perception from the brain trained to reference on all the other surrounding objects beyond 10 feet. John Goodings, C-FGPJ, CH601HD with R912S, Toronto/Carp/Ottawa. ________________________________________________________________________________
Subject: 5-pin mic jack for RAC trim
Date: Feb 24, 2008
http://www.qsradio.com/Connectors.htm Okay guys and gals, I found the mysterious 5-pin plug at the site linked above. Scroll down about 80%... the various versions with different numbers of pins are listed there. These connectors are a nice neat professional looking way to make connections at the tail, the wing roots, anywhere that might need to come apart someday. The four pin version is available at Radio Shack in my home town so I guess it is available elsewhere as well. Dred ________________________________________________________________________________
Subject: Re: 5-pin mic jack for RAC trim
Date: Feb 24, 2008
Dred- Where did you install the panel mount? I'm guessing on the rear stab mount. If you put it where the grommet is on the elevator, the male connector would probably interfere with free travel. Bill ----- Original Message ----- From: Edward Moody II To: zenith-list(at)matronics.com Sent: Sunday, February 24, 2008 11:12 AM Subject: Zenith-List: 5-pin mic jack for RAC trim http://www.qsradio.com/Connectors.htm Okay guys and gals, I found the mysterious 5-pin plug at the site linked above. Scroll down about 80%... the various versions with different numbers of pins are listed there. These connectors are a nice neat professional looking way to make connections at the tail, the wing roots, anywhere that might need to come apart someday. The four pin version is available at Radio Shack in my home town so I guess it is available elsewhere as well. Dred ________________________________________________________________________________
Date: Feb 24, 2008
Just a few words about Radio Shack and other similar microphone connectors. The contacts are mostly made of plated brass, or something similar. They do not do well in wet conditions or where there is a lot of humidity in the air or a lot of condensation from being hot and cold in an outdoor atmosphere. The contacts, within the connectors, tend to get very corroded causing intermittent connections. In addition those kind of connectors are not rated for the kind of current that your tail light, for example, would be pulling through the connector. I don't think that an elevator trim servo would be any problem. But to be sure, look up the DC Continuous Current Rating BEFORE using this type of connector. If you DO use these kind of connectors, and there is any chance of them becoming wet, probably the best thing you could do would be to seal them heat shrink tubing. The kind that has a molten center that makes an airtight seal around the wires would be best. George CH-701 Kit - N73EX (Reserved) ________________________________________________________________________________
Date: Feb 24, 2008
Subject: sub D connector for five wire Ray Allen servo
This is another connector that works back on the top of stab and under fairing. Thanks to Electrocuted Bob. Position light wire can also be incorporated...jeff http://www.aeroelectric.com/articles/macservo/macservo.html ________________________________________________________________________________
Date: Feb 24, 2008
My ophthalmologist (sp?) told me, and I've tried it and found it to be true, that our binocular vision only gives us depth perception to about fifteen feet. Beyond that it's the brain's ability to interpolate/extrapolate using known shapes and apparent movement that gives us depth perception. So, as Larry Hursh wrote a few posts ago, Give yourself some space and time. Our bodies are "fearfully and wonderfully made", and adapt to many seemingly insurmountable difficulties. Reread Larry's post, print it out, keep it and read it when you feel like surrendering, and keep your dream! Blue skies and tailwinds Jim CH-801 DeltaHawk diesel Augusta GA 90% done, 90% left ________________________________________________________________________________
Date: Feb 24, 2008
George, Heat shrink tubing "with a molten center" is something I have never heard of. Could you give a little more information about this, ie: name, where to get it, etc.? Thanks, Jay in Dallas 601XL N2630J "Lil Bruiser" "George Race" wrote: >Just a few words about Radio Shack and other similar microphone connectors. > >The contacts are mostly made of plated brass, or something similar. They do >not do well in wet conditions or where there is a lot of humidity in the air >or a lot of condensation from being hot and cold in an outdoor atmosphere. >The contacts, within the connectors, tend to get very corroded causing >intermittent connections. > >In addition those kind of connectors are not rated for the kind of current >that your tail light, for example, would be pulling through the connector. >I don't think that an elevator trim servo would be any problem. But to be >sure, look up the DC Continuous Current Rating BEFORE using this type of >connector. > >If you DO use these kind of connectors, and there is any chance of them >becoming wet, probably the best thing you could do would be to seal them >heat shrink tubing. The kind that has a molten center that makes an >airtight seal around the wires would be best. > >George >CH-701 Kit - N73EX (Reserved) > ________________________________________________________________________________
Date: Feb 24, 2008
Larry, I have a question about the seats and maybe you can answer it for me. I was wondering if there's such a thing as replacing the permanently mounted seats with a moveable seat like that in a Cessna? I'm a pretty short legged pilot and if I mount the seats too close to the pedals, any of my friends that are much taller than I will have a dickens of a time with the seat being too close for them. I've only started my XL but I've been wondering how others have handled it. When AMD builds the Alarus (mother to the XL), how do they handle the seating in those?? I'm sure there are a lot of them out here being used for General Aviation. Any help you could offer here will put my mind at ease some. Regards Larry H LarryMcFarland wrote: Hi Jeff, The seats are easily done with plywood backs or fiberglass. Automotive foams are cheaper and perhaps easier to get hold of at many sewing and fabric outlets. Density is something you want to pay attention to. Confor foam is expensive beyond practical concerns, but for flammability perhaps. I've a page on seat construction that may explain the process. See link below. Seat backs need only go an inch or more above the shelf or to shoulder support height. Easier to get belts over your shoulders if you don't go too high. Head rests are for the flying public and passengers but I wouldn't recommend them because of a need for access to the rear shelf during flight. http://www.macsmachine.com/html/seatupholstery.htm Good luck, Larry McFarland 601HDS at www.macsmachine.com Jeff wrote: > > All, > > I'm working with the seats now too. I have found that there really are > three parts to the seats. These are the cushions, the seat backs, and the > upholstery. > > My manual suggests plywood as the seat back material. The fiberglass > (reinforced plastic) solution as shown on the CH601.org web site appears to > be a better solution. I guess I'll just have to learn to use fiberglass. > > For the cushions, several types of foam are available from common soft foam > to Confor Foam. Both Hi-Tech Seats and Oregon Aero have patterns for the > 601 using Confor foam. Oregon Aero is more than twice the price of Hi-Tech, > but includes a multi-piece seat with professionally contoured shapes. Does > anyone have either installed? > > I checked with a local auto upholstery shop, and getting the cover done > should be the easiest part. > > I have a couple questions: > > How far above the baggage shelf should the headrest portion of the seatback > extend to protect our heads? Most of the pictures I see just have a large > arc or simple straight edge as the top of the seat back. Is there a reason > that there is no head rest? Should the seats be more like the bucket seats > in a car with integral head rests? Is it just personal preference? I just > measured my plane and came up with 300 mm above the shelf for the top of the > headrest assuming a 3 inch foam seat over the seat pan. How do the > Flightcrafters or Zenith seats compare? > > Thanks .... > > Jeff D. > > > --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Subject: EGT/CHT wiring
Date: Feb 24, 2008
I've managed to loose (if I ever had them) instructions on wiring a dual EGT/CHT gauge. The gauge doesn't have the manufacturer, just a made in china lable on it. It's a 2 1/4" round gauge. It has 4 posts on the back labelled, 1, 3, 4, 5. I've got thermocouples that I purchased at the same time. Anyone got some suggestions? Dan Dempsey 601XL -------- Scratch building XL with Corvair Engine Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165987#165987 ________________________________________________________________________________
Date: Feb 24, 2008
George- Jeff showed me his set-up, which is actually a 9 pin computer serial connector! He's been flying since the late '90s. Bill ----- Original Message ----- From: George Race To: zenith-list(at)matronics.com Sent: Sunday, February 24, 2008 2:44 PM Subject: Zenith-List: Re: 5-pin mic jack for RAC trim Just a few words about Radio Shack and other similar microphone connectors. The contacts are mostly made of plated brass, or something similar. They do not do well in wet conditions or where there is a lot of humidity in the air or a lot of condensation from being hot and cold in an outdoor atmosphere. The contacts, within the connectors, tend to get very corroded causing intermittent connections. In addition those kind of connectors are not rated for the kind of current that your tail light, for example, would be pulling through the connector. I don't think that an elevator trim servo would be any problem. But to be sure, look up the DC Continuous Current Rating BEFORE using this type of connector. If you DO use these kind of connectors, and there is any chance of them becoming wet, probably the best thing you could do would be to seal them heat shrink tubing. The kind that has a molten center that makes an airtight seal around the wires would be best. George CH-701 Kit - N73EX (Reserved) ________________________________________________________________________________
Subject: Adhesive lined heat shrink tubing (was 5-pin mic jack)
Date: Feb 24, 2008
Jay, I believe he is referring to adhesive lined shrink tubing. It is used in marine wiring. Ancor Marine is one manufacturer. Hope this helps. Raymond Julian Kettle River, MN "Hope for the best, but prepare for the worst." ----- Original Message ----- From: <Jaybannist(at)cs.com> Sent: Sunday, February 24, 2008 2:51 PM Subject: RE: Zenith-List: Re: 5-pin mic jack for RAC trim > > George, > > Heat shrink tubing "with a molten center" is something I have never heard > of. Could you give a little more information about this, ie: name, where > to get it, etc.? > > Thanks, > Jay in Dallas 601XL N2630J "Lil Bruiser" > > > "George Race" wrote: > >>Just a few words about Radio Shack and other similar microphone >>connectors. >> >>The contacts are mostly made of plated brass, or something similar. They >>do >>not do well in wet conditions or where there is a lot of humidity in the >>air >>or a lot of condensation from being hot and cold in an outdoor atmosphere. >>The contacts, within the connectors, tend to get very corroded causing >>intermittent connections. >> >>In addition those kind of connectors are not rated for the kind of current >>that your tail light, for example, would be pulling through the connector. >>I don't think that an elevator trim servo would be any problem. But to be >>sure, look up the DC Continuous Current Rating BEFORE using this type of >>connector. >> >>If you DO use these kind of connectors, and there is any chance of them >>becoming wet, probably the best thing you could do would be to seal them >>heat shrink tubing. The kind that has a molten center that makes an >>airtight seal around the wires would be best. >> >>George >>CH-701 Kit - N73EX (Reserved) >> > > > ________________________________________________________________________________
Date: Feb 24, 2008
gp to an electronics shop other than Radio Shack and ask for heat shrink with heat activated glue cores. Or go on line. Juan -----Original Message----- >From: Jaybannist(at)cs.com >Sent: Feb 24, 2008 3:51 PM >To: zenith-list(at)matronics.com >Subject: RE: Zenith-List: Re: 5-pin mic jack for RAC trim > > >George, > >Heat shrink tubing "with a molten center" is something I have never heard of. Could you give a little more information about this, ie: name, where to get it, etc.? > >Thanks, >Jay in Dallas 601XL N2630J "Lil Bruiser" > > >"George Race" wrote: > >>Just a few words about Radio Shack and other similar microphone connectors. >> >>The contacts are mostly made of plated brass, or something similar. They do >>not do well in wet conditions or where there is a lot of humidity in the air >>or a lot of condensation from being hot and cold in an outdoor atmosphere. >>The contacts, within the connectors, tend to get very corroded causing >>intermittent connections. >> >>In addition those kind of connectors are not rated for the kind of current >>that your tail light, for example, would be pulling through the connector. >>I don't think that an elevator trim servo would be any problem. But to be >>sure, look up the DC Continuous Current Rating BEFORE using this type of >>connector. >> >>If you DO use these kind of connectors, and there is any chance of them >>becoming wet, probably the best thing you could do would be to seal them >>heat shrink tubing. The kind that has a molten center that makes an >>airtight seal around the wires would be best. >> >>George >>CH-701 Kit - N73EX (Reserved) >> > > ________________________________________________________________________________
Date: Feb 24, 2008
Micheal I have a unique perspective on this. I lost sight almost entirely in my left eye when I was about 13. Got into a fight with a struck nail while building a skateboard ramp. My vision was about 20-400 if I squinted. I lost the natural lens in my eye and the doc didn't want to put in an implant since I was still growing. Before the accident I was a good shot with a basketball. Afterwards for a while I couldn't hit the "broad side of a barn" and I bumped into a lot of walls and furniture. But in a few months time I was hitting baskets again just like nothing was lost. I didn't miss my eye after a while. as a matter of fact I waited until my late 20's to have that implant put in. Bad news is, the first one was too small and slipped downward causing me to see through the edge--giving me double vision in that eye for a couple of years (I had to wait to totally heal before redoing the operation). But one of the "visions" was almost 20-20. Even the seeing of double out of one eye didn't bother me that much after a while. As long as I didn't close my good eye, my brain would compensate by filtering out the incorrect of the two "visions". So don't get down. Give yourself some time. I am speaking from experience. ________________________________________________________________________________
Subject: You Ask About Dual Wall Heat Shrink
Date: Feb 24, 2008
Dual Wall Heat Shrink has been around for many years. Lots of places have it and most call it either Dual Wall Heat Shrink or Heat Shrink Encapsulate Tubing. Here are a few references: http://webtronics.stores.yahoo.net/duwaheshtuki.html They have assorted kits with a lot of sizes. http://www.seacoastheatshrink.com/pmdw1info.html Here is a complete specification page for some really good stuff. And last but not least, the place I have been buying it from. It is a 3M product of very good quality. You probably pay a bit more for it but it is worth it in the long run. Look toward the bottom of their page for the dual wall stuff. Their prices are good and they ship real fast. You may also want one of their catalogues. They have a lot of misc stuff as well. http://www.action-electronics.com/heatshrink.htm During my working days we used a lot of this stuff for underground direct buried cable splices. Worked just great for phone cables, CATV cables, and even coaxial cables with connectors. The 3/4 inch size stuff works just great to seal up PL259 Connectors for coax. The 3/8 inch stuff works great on CATV cables and connectors, the 75 ohm stuff, RG-59U. Hope this helps. George CH-701 Kit - N73EX (Reserved) ________________________________________________________________________________
Date: Feb 24, 2008
Waytek sells it too, in a variety of colors and sizes. http://order.waytekwire.com/IMAGES/M37/catalog/220_113.PDF -- Craig From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of George Race Sent: Sunday, February 24, 2008 4:08 PM Subject: Zenith-List: You Ask About Dual Wall Heat Shrink Dual Wall Heat Shrink has been around for many years. Lots of places have it and most call it either Dual Wall Heat Shrink or Heat Shrink Encapsulate Tubing. Here are a few references: http://webtronics.stores.yahoo.net/duwaheshtuki.html They have assorted kits with a lot of sizes. http://www.seacoastheatshrink.com/pmdw1info.html Here is a complete specification page for some really good stuff. And last but not least, the place I have been buying it from. It is a 3M product of very good quality. You probably pay a bit more for it but it is worth it in the long run. Look toward the bottom of their page for the dual wall stuff. Their prices are good and they ship real fast. You may also want one of their catalogues. They have a lot of misc stuff as well. http://www.action-electronics.com/heatshrink.htm During my working days we used a lot of this stuff for underground direct buried cable splices. Worked just great for phone cables, CATV cables, and even coaxial cables with connectors. The 3/4 inch size stuff works just great to seal up PL259 Connectors for coax. The 3/8 inch stuff works great on CATV cables and connectors, the 75 ohm stuff, RG-59U. Hope this helps. George CH-701 Kit - N73EX (Reserved) ________________________________________________________________________________
Date: Feb 24, 2008
There are connectors designed for harsh environments. One example are automotive connectors with individual seals on the leads. Waytek sells them: http://order.waytekwire.com/IMAGES/M37/catalog/220_033.pdf (top of the page) -- Craig From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of George Race Sent: Sunday, February 24, 2008 12:44 PM Subject: Zenith-List: Re: 5-pin mic jack for RAC trim Just a few words about Radio Shack and other similar microphone connectors. The contacts are mostly made of plated brass, or something similar. They do not do well in wet conditions or where there is a lot of humidity in the air or a lot of condensation from being hot and cold in an outdoor atmosphere. The contacts, within the connectors, tend to get very corroded causing intermittent connections. In addition those kind of connectors are not rated for the kind of current that your tail light, for example, would be pulling through the connector. I don't think that an elevator trim servo would be any problem. But to be sure, look up the DC Continuous Current Rating BEFORE using this type of connector. If you DO use these kind of connectors, and there is any chance of them becoming wet, probably the best thing you could do would be to seal them heat shrink tubing. The kind that has a molten center that makes an airtight seal around the wires would be best. George CH-701 Kit - N73EX (Reserved) ________________________________________________________________________________
Date: Feb 24, 2008
When I was getting ready to wire up my elevator trim servo, I posed the connector question on the Aeroelectric list. I was directed towards a modified DB-9 connector that was originally suggested for this application by Electric Bob. The resultant thread is here: http://forums.matronics.com/viewtopic.php?t=35647 One of the responders provides a link to Bob's descriptive web pages. Nuckoll's recommends DB connectors as inexpensive, high quality (gold plated contacts), and builder friendly. I plan to use them extensively--when I get to FWF and panel. I used the modified DB-9 on my elevator and aileron trims. The circuits test out fine. It'll be a while before I can prove them in the air. For a description of what I did, go to my KitlogPro site (see link below) and check out the 12/7/07, 12/11/07, 1/25/08 & 1/27/08 logs. Incidentally, somewhere in the info I collected on this subject was a recommendation from RAC to not use crimp connectors on their AWG24 or 26 servo wires. They recommend only solder connections for those wires. It was difficult to locate a source for solder type male DB-9's, but I found a place with good selection & price, Action-Electronics.com. I used gold-plated crimp-type sockets from SteinAir ($.25/ea) for the AWG-22 connection wires. Also, regarding the adhesive coated heat shrink tubing, McMaster-Carr has an amazing selection of heat shrink tubing, both with and without adhesive. I used the adhesive type on my 1st 2 DB-9 connectors and wish I hadn't. I don't think they can be disassembled w/o damage. There are lots of acceptable ways to make these connections. I offer the DB-9's as an alternative to the microphone connectors that you may want to consider. I think will work for me. YMMV. Terry >Just a few words about Radio Shack and other similar microphone connectors. > >The contacts are mostly made of plated brass, or something similar. They >do not do well in wet conditions or where there is a lot of humidity in >the air or a lot of condensation from being hot and cold in an outdoor >atmosphere. The contacts, within the connectors, tend to get very >corroded causing intermittent connections. > >In addition those kind of connectors are not rated for the kind of current >that your tail light, for example, would be pulling through the >connector. I don't think that an elevator trim servo would be any >problem. But to be sure, look up the DC Continuous Current Rating BEFORE >using this type of connector. > >If you DO use these kind of connectors, and there is any chance of them >becoming wet, probably the best thing you could do would be to seal them >heat shrink tubing. The kind that has a molten center that makes an >airtight seal around the wires would be best. > >George >CH-701 Kit - N73EX (Reserved) Terry Phillips ttp44~at~rkymtn.net Corvallis MT 601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons are done; working on the wings http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: Feb 24, 2008
Hi Larry, I'd recommend you build the seats to fit the 6'-2" person and after getting the proportions right for comfort disregarding the length of your legs, make the seat back adjustable both top and bottom to allow it to be positioned forward a distance that you feel best with at the pedals. There are several spacer types or adapters that would position your seat forward an inch or two so you get a good fit. I don't see any benefit in trying a track on the bottom of the seat when it's basically making the seat-back do the work. The seat bottom is one plane of reference that can be fixed and the seat back may more easily be made adjustable. This would be my approach. Take note of the bottom channel that holds the bottom of my seat-back and imagine two rows of channel and bolt in spacers at the top. I use bungees for the top of my seats going back inside to hold them in place. Larry McFarland Larry H wrote: > Larry, I have a question about the seats and maybe you can answer it > for me. I was wondering if there's such a thing as replacing the > permanently mounted seats with a moveable seat like that in a Cessna? > I'm a pretty short legged pilot and if I mount the seats too close to > the pedals, any of my friends that are much taller than I will have a > dickens of a time with the seat being too close for them. I've only > started my XL but I've been wondering how others have handled it. > When AMD builds the Alarus (mother to the XL), how do they handle the > seating in those?? I'm sure there are a lot of them out here being > used for General Aviation. Any help you could offer here will put my > mind at ease some. > > Regards > Larry H > > */LarryMcFarland /* wrote: > > > Hi Jeff, > The seats are easily done with plywood backs or fiberglass. > Automotive > foams are cheaper and perhaps > easier to get hold of at many sewing and fabric outlets. Density is > something you want to pay attention to. > Confor foam is expensive beyond practical concerns, but for > flammability > perhaps. I've a page on > seat construction that may explain the process. See link below. > Seat backs need only go an inch or more above the shelf or to > shoulder > support height. Easier to get > belts over your shoulders if you don't go too high. Head rests are > for > the flying public and passengers > but I wouldn't recommend them because of a need for access to the > rear > shelf during flight. > http://www.macsmachine.com/html/seatupholstery.htm > Good luck, > > Larry McFarland 601HDS at www.macsmachine.com > > > Jeff wrote: > > > > All, > > > > I'm working with the seats now too. I have found that there > really are > > three parts to the seats. These are the cushions, the seat > backs, and the > > upholstery. > > > > My manual suggests plywood as the seat back material. The fiberglass > > (reinforced plastic) solution as shown on the CH601.org web site > appears to > > be a better solution. I guess I'll just have to learn to use > fiberglass. > > > > For the cushions, several types of foam are available from > common soft foam > > to Confor Foam. Both Hi-Tech Seats and Oregon Aero have patterns > for the > > 601 using Confor foam. Oregon Aero is more than twice the price > of Hi-Tech, > > but includes a multi-piece seat with professionally contoured > shapes. Does > > anyone have either installed? > > > > I checked with a local auto upholstery shop, and getting the cover > ------------------------------------------------------------------------ > Be a better friend, newshound, and > > * > > > * > ________________________________________________________________________________
Date: Feb 24, 2008
Subject: nitrogen clynders
does anyone know what size or part number ,nitrogen clynders are used on the bubble doors with assits. Zenith does not come with any but I have seen pics of a few that have been put in. ________________________________________________________________________________
Subject: RE: Zenith-List Digest: LRI Probe Question
Date: Feb 24, 2008
I think the reason pitot tubes and AOA probes protrude as far as they do from the wing is to clear the boundary layer of air on the wings surface, which would prevent getting an accurate indication. Craig S. N601XS, 601xl lyc 0-235, waiting for warmer weather to finish wiring and mount wings Does anyone of you using a holes in the wing as a ports for AOA? ----------------------------------------- ************************************************** This e-mail and any of its attachments may contain Exelon Corporation proprietary information, which is privileged, confidential, or subject to copyright belonging to the Exelon Corporation family of Companies. This e-mail is intended solely for the use of the individual or entity to which it is addressed. If you are not the intended recipient of this e-mail, you are hereby notified that any dissemination, distribution, copying, or action taken in relation to the contents of and attachments to this e-mail is strictly prohibited and may be unlawful. If you have received this e-mail in error, please notify the sender immediately and permanently delete the original and any copy of this e-mail and any printout. Thank You. ************************************************** ________________________________________________________________________________
Subject: Re: Zenith-List Digest: LRI Probe Question
Date: Feb 24, 2008
Craig.Spainhower(at)exelo wrote: > I think the reason pitot tubes and AOA probes protrude as far as they do from the wing is to clear the boundary layer of air on the wings surface, which would prevent getting an accurate indication. I always thought that the AOA is actually measuring the difference of the air layer (pressure) on top and bottom of the wing. The pitot tube protrudes far from the wing not to be affected by the boundary layer on the bottom of the wing you are mentioning, because it measures air speed. The LRI probe has to be further away from the wing for the same reason. The high/low pressure holes are close together and the angle of their surfaces substitutes the wing profile. Just my $.02. -------- Pavel CA Zodiac XL N581PM (Reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166051#166051 ________________________________________________________________________________
Date: Feb 24, 2008
Advanced Flight Systems sells a system with flush probes that has been available for years. http://www.advanced-flight-systems.com/Products/AOA/aoa.html -- Craig -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Craig.Spainhower(at)exeloncorp.com Sent: Sunday, February 24, 2008 7:55 PM Subject: Zenith-List: RE: Zenith-List Digest: LRI Probe Question I think the reason pitot tubes and AOA probes protrude as far as they do from the wing is to clear the boundary layer of air on the wings surface, which would prevent getting an accurate indication. Craig S. N601XS, 601xl lyc 0-235, waiting for warmer weather to finish wiring and mount wings Does anyone of you using a holes in the wing as a ports for AOA? ----------------------------------------- ************************************************** This e-mail and any of its attachments may contain Exelon Corporation proprietary information, which is privileged, confidential, or subject to copyright belonging to the Exelon Corporation family of Companies. This e-mail is intended solely for the use of the individual or entity to which it is addressed. If you are not the intended recipient of this e-mail, you are hereby notified that any dissemination, distribution, copying, or action taken in relation to the contents of and attachments to this e-mail is strictly prohibited and may be unlawful. If you have received this e-mail in error, please notify the sender immediately and permanently delete the original and any copy of this e-mail and any printout. Thank You. ************************************************** ________________________________________________________________________________
Date: Feb 25, 2008
The biggest reason for headrests is that after a rapid deceleration against a restraint like a seat belt or even a shoulder harness your head will snap back. If there is no cushion/stop to limit the travel hyperextension of the neck and even fracture associated with only the snap back can occur. All, I'm working with the seats now too. I have found that there really are three parts to the seats. These are the cushions, the seat backs, and the upholstery. My manual suggests plywood as the seat back material. The fiberglass (reinforced plastic) solution as shown on the CH601.org web site appears to be a better solution. I guess I'll just have to learn to use fiberglass. For the cushions, several types of foam are available from common soft foam to Confor Foam. Both Hi-Tech Seats and Oregon Aero have patterns for the 601 using Confor foam. Oregon Aero is more than twice the price of Hi-Tech, but includes a multi-piece seat with professionally contoured shapes. Does anyone have either installed? I checked with a local auto upholstery shop, and getting the cover done should be the easiest part. I have a couple questions: How far above the baggage shelf should the headrest portion of the seatback extend to protect our heads? Most of the pictures I see just have a large arc or simple straight edge as the top of the seat back. Is there a reason that there is no head rest? Should the seats be more like the bucket seats in a car with integral head rests? Is it just personal preference? I just measured my plane and came up with 300 mm above the shelf for the top of the headrest assuming a 3 inch foam seat over the seat pan. How do the Flightcrafters or Zenith seats compare? Thanks .... Jeff D. Dave Downey Harleysville (SE) PA 100 HP Corvair --------------------------------- Never miss a thing. Make Yahoo your homepage. ________________________________________________________________________________
Date: Feb 25, 2008
I used a piece of 6061-T6 1/8" extruded angle to make a bracket for the panel mount piec and it will mount under the rudder fairing, on the upper surface of the H-stab once I run the elevator cable. It obviously has to be off center enough to miss the cable. From the bracket mounted panel mount part, the RAC cable travels on to the elevator and trim servo. If the tail parts need to be removed, the male part of the connector stays with the fuselage and the rest stays with the tail. Dred ________________________________________________________________________________
Date: Feb 25, 2008
I have used this connector without any trouble for five years in the tail area of my EAB registered fat ultralight. I have not even shrink wrapped it, except of course for where the cable enters the two connector parts. The junction of the two halves of the connector is a screw together fitting that seems to be sealed well enough based on past performance. As a general rule, if the appropriate gauge is too large to fit into the little solder tubes of the connector, use a heftier connector. The entire trim system calls for a 2 amp breaker or fuse. Dred ________________________________________________________________________________
Date: Feb 25, 2008
The Advanced Flight Systems AOA system uses flush mounted ports on the upper and lower surfaces of the wing for sensing AOA. Dred ________________________________________________________________________________
Subject: Re: Bottom Rudder Bracket attachment
Date: Feb 25, 2008
Thank you Chris, I appreciate your time spent taking your pictures. I have been building for a few months now, everyone I've come across has been so helpful. I appreciate all of you out there who are willing to take some time to help others out. I wonder what it would be like if I wasn't building a Zenith? Without so many helpful folks I would still have a pile of aluminum in my garage. Now I have a pile of aluminum that is beginning to resemble a plane! I had a question that I wrote to Zenith the other day, Sebastian replied via email in less than 30 minutes! I couldn't believe it. Though I am new to the list, I look forward to offering my experience and advice as I progress. At this point I only feel qualified to instruct others on the techniques of drilling out and replacing rivets :) . -------- One Rivet at a Time! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166108#166108 ________________________________________________________________________________
Subject: Experimental Nature
Date: Feb 25, 2008
Hello group ,though I would share with you an experiment that I just tried . I live on the gulf coast where the humidity is very high .A couple of days ago I got a little gas from my 5 gal can into a small glass jar .This 10 percent ethanol gas had been in my garage about a week .When it was in the glass jar I noticed it was a milky color .I though the alcohol may have collected water from the humidity ,so last night I placed some clear gas into the jar and left it overnight in the hanger .And this morning it was no longer clear it was a milky color . Wade Jones South Texas 601XL plans building Cont. 0200 ________________________________________________________________________________
Subject: Re: Experimental Nature
Date: Feb 25, 2008
This, among other things, is why Ethanol is bad when it comes to airplanes. wjones(at)BRAZORIAINET.CO wrote: > Hello group ,though I would share with you an experiment that I just tried . I live on the gulf coast where the humidity is very high .A couple of days ago I got a little gas from my 5 gal can into a small glass jar .This 10 percent ethanol gas had been in my garage about a week .When it was in the glass jar I noticed it was a milky color .I though the alcohol may have collected water from the humidity ,so last night I placed some clear gas into the jar and left it overnight in the hanger .And this morning it was no longer clear it was a milky color . Wade Jones South Texas > 601XL plans building > Cont. 0200 > -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166137#166137 ________________________________________________________________________________
From: "Dr. Andrew Elliott" <a.s.elliott(at)cox.net>
Subject: Painting the firewall
Date: Feb 25, 2008
Met Gus from FlywithGus.com Saturday afternoon at Silver Sky Aviation in Chandler, AZ, where he is doing a Corvair installation for one of Silver Sky's customers. I noticed that the firewall looked especially nice, having a uniform satin aluminum-like color, instead of the unaesthetic galvanized finish. Asked, and was told that he cleaned and primed the firewall with self-etching primer and then shot it with aluminum-color engine paint. Banging myself on the noggin for not thinking of that one myself, I went home did the same! I used Duplicolor 1200=B0 High-Heat paint with ceramic, because I happened to have a 1/2-used can on the shelf. Total effort about 1/2 hour for removing a few things from the firewall and masking, then another 15 minutes (not counting drying time) for the coats of primer and paint. Voila! Now I also have a pretty satin aluminum finish on my firewall! And maybe even some insulation value due to the ceramic in the paint. Thanks, Gus! Andy Elliott, Mesa, AZ N601GE (reserved) 601XL/TD, Corvair, building... ________________________________________________________________________________
Date: Feb 25, 2008
From: Lee Steensland <zenith-list(at)steensland.net>
Subject: Re: nitrogen clynders
not to plagiarize a previous post I found this that may be helpful: robert stone wrote: I found the canopy gas springs or struts were not strong enough to hold the canopy up even in a light breeze. I inquired as to the strength of the struts furnished in the kit and found them to be 40 pounds. I replaced them with a pair of 60 pounders and eliminated the problem of my canopy slamming down unexpected. I am sure some of you who are building or have built the ZodiacXL either have the same problem or will have so here is the information on obtaining the stronger struts. McMasters & Company are the people Zenith Aircraft gets the struts from. Their phone number is 630-833-0300. The gas struts furnished by Zenith for the ZodiacXL are part number 9416K12 (40 Pound) the stronger strut is part number 8416K123 (60 Pound) The cost for two is $19.76, shipping is $5.00 for a total of $24.76. They come without the attaching ends so you have to use your old ones however the old struts screw out and the new one screws in. Very easy to change. Tracy wrote: > > does anyone know what size or part number ,nitrogen clynders are used on the bubble doors with assits. Zenith does not come with any but I have seen pics of a few that have been put in. > > > ________________________________________________________________________________
Date: Feb 25, 2008
Just be aware that Tracy's original post appears to be about the bubble doors on a 701 or 801. The 40 or 60 pound units were for the 601's heavier bubble canopy. But I'm sure McMasters would have something suitable for the bubble doors. -- Craig -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Lee Steensland Sent: Monday, February 25, 2008 1:08 PM Subject: Re: Zenith-List: nitrogen clynders not to plagiarize a previous post I found this that may be helpful: robert stone wrote: I found the canopy gas springs or struts were not strong enough to hold the canopy up even in a light breeze. I inquired as to the strength of the struts furnished in the kit and found them to be 40 pounds. I replaced them with a pair of 60 pounders and eliminated the problem of my canopy slamming down unexpected. I am sure some of you who are building or have built the ZodiacXL either have the same problem or will have so here is the information on obtaining the stronger struts. McMasters & Company are the people Zenith Aircraft gets the struts from. Their phone number is 630-833-0300. The gas struts furnished by Zenith for the ZodiacXL are part number 9416K12 (40 Pound) the stronger strut is part number 8416K123 (60 Pound) The cost for two is $19.76, shipping is $5.00 for a total of $24.76. They come without the attaching ends so you have to use your old ones however the old struts screw out and the new one screws in. Very easy to change. Tracy wrote: > > does anyone know what size or part number ,nitrogen clynders are used on the bubble doors with assits. Zenith does not come with any but I have seen pics of a few that have been put in. > > > ________________________________________________________________________________
Date: Feb 25, 2008
Dan, that sounds to me like a Westach gauge to me, you should be able to get the wiring information from their website. Doug MacDonald CH-701 Scratch Builder NW Ontario, Canada >I've managed to loose (if I ever had them) >instructions on wiring a > dual EGT/CHT gauge. The gauge doesn't have the >manufacturer, just a made > in china lable on it. >It's a 2 1/4" round gauge. It has 4 posts on the >back labelled, 1, 3, > 4, 5. >I've got thermocouples that I purchased at the same >time. >Anyone got some suggestions? >Dan Dempsey >601XL Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Subject: A Wonderful bunch of guys THANK YOU!
Date: Feb 25, 2008
The response which I received from my offer to sell my project 601XL has been more than I expected, both in the many inquiries which came into my e-mail box, and the notes of reassurance and " don't give up the ship." Some of them brought tears. Thanks to all of you. It was about 25 years ago, after We had sent off the last college tuition check for the last kid that Anne and I decided to go flying. We earned our ASEL and Instrument ratings and have between the two of us more than 4500 hours in the air, with about 200 hours of actual instrument time in our 1980 C-172, which we decided to sell about 2 years ago. Things got tough physically for me about 10 years ago, when my MD asked me if I knew I had had a heart attack. After some months, he encouraged me to go back after my Certificate. But by that time I was having extreme problems with a rare form of arthritis, and occasionally could barely walk. (I may finally have found the right combination to deal with that, by the way.) It's not worth going over, even if I could without going into a blue funk. The stroke was the last straw. Taking the positive approach, that blood clot(from a stent installed 5 years ago) was the last straw. The clot took out 60% of my left eye, but could have gone straight into my right brain and left me in bed with a bed pan, not being able to figure out what it was for. So, it can be said that I (we) have already lived our dream of flying. That is why the 601XL is for sale. It is well built, (if I say so myself ) and it is priced such that perhaps someone younger and healthier than I can live his own dream. I know the price is about what the engine alone costs in today's dollars. Best wishes to all, and thanks very much for your kind wishes. Mike Honer ________________________________________________________________________________
Date: Feb 25, 2008
Subject: Re: Seats: seat backs, cushions, and upholstery
Hi, Another possible choice are the seatbacks used in the RV6. We used that in my plane. They are lightweight and strong. Happy building and flying, Klaus klaus(at)utdallas.edu www.utdallas.edu/~klaus ________________________________________________________________________________
Subject: Throttle cables
Date: Feb 25, 2008
Thought I'd ask if anyone knew what throttle cables were used in the Homebuilt help CH 701 912S engine install video. Would like supplier and part number so I don't have to re-invent the wheel. Looks like they were going to use a cable on each side - wondered about the internal friction of two cables. Also got a good look at the package that had the attachment parts for the cable to the throttle assy. Does anyone know where they can be purchased? Phil Smith 701..... 90 done 110 to go! ________________________________________________________________________________
Subject: Re: A Wonderful bunch of guys THANK YOU!
Date: Feb 25, 2008
As you wish. You could still finish it, just for the fun of it! Then you could give an even better deal to some, as you say younger guy. Not me though, the 701 is my dream. Best Regards Kevin McCune -------- Kevin N701DZ Reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166227#166227 ________________________________________________________________________________
Date: Feb 25, 2008
It isn't so good for cars ether,but at least in that instance it is not dangerous. An acceptable risk point of view. -------- Kevin N701DZ Reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166228#166228 ________________________________________________________________________________
Date: Feb 25, 2008
----- Original Message ----- From: A. Michael Honer To: Zenith-List(at)Matronics.com Sent: Monday, February 25, 2008 5:01 PM Subject: A Wonderful bunch of guys THANK YOU! The response which I received from my offer to sell my project 601XL has been more than I expected, both in the many inquiries which came into my e-mail box, and the notes of reassurance and " don't give up the ship." Some of them brought tears. Thanks to all of you. It was about 25 years ago, after We had sent off the last college tuition check for the last kid that Anne and I decided to go flying. We earned our ASEL and Instrument ratings and have between the two of us more than 4500 hours in the air, with about 200 hours of actual instrument time in our 1980 C-172, which we decided to sell about 2 years ago. Things got tough physically for me about 10 years ago, when my MD asked me if I knew I had had a heart attack. After some months, he encouraged me to go back after my Certificate. But by that time I was having extreme problems with a rare form of arthritis, and occasionally could barely walk. (I may finally have found the right combination to deal with that, by the way.) It's not worth going over, even if I could without going into a blue funk. The stroke was the last straw. Taking the positive approach, that blood clot(from a stent installed 5 years ago) was the last straw. The clot took out 60% of my left eye, but could have gone straight into my right brain and left me in bed with a bed pan, not being able to figure out what it was for. So, it can be said that I (we) have already lived our dream of flying. That is why the 601XL is for sale. It is well built, (if I say so myself ) and it is priced such that perhaps someone younger and healthier than I can live his own dream. I know the price is about what the engine alone costs in today's dollars. Best wishes to all, and thanks very much for your kind wishes. Mike Honer ________________________________________________________________________________
Date: Feb 25, 2008
Subject: Torque Value Table, flap misshap and radio noise
for the guys still scratching their heads on Torque values, ( i am frankly), attached is the table from the ASA aviaitoin mechanic handbook: AN Bolt NUt bolt Tension Size Size in-lbs an3 1-32 20-25 add torque for nylock nuts to all an4 1/4-28 50-70 an5 5/16-24 100- 140 an 6 3/8- 24 460-190 an 7 7/16-20 450- 500 after tyhat size we are getting to Boeing sized Nuts. Other subject is the flaps. I was coming in for a landing and at 80 mph, set the flaps switch, as i trimmed, I kept compensating for heavier and heavier left wing. at 70 mph trimmed on 1/4 mile final, i looked and one flap was at 5 degree down and the other was full 20+ dgree down. the plane was still very controlable. I landed then reset the flaps. upon review the flaps came up when I broke the speed above 85 mph inadvertantly. the key is the plane did ot fall out of the sky, just kept flying it. says great things about the rougedness of the design. solved the radio noise from the Jabiru engine. the saver was Resistor Spark PLugs. Size is DR9EA-9 on the Jab 3300. did the job. Juan Vega ________________________________________________________________________________
Date: Feb 25, 2008
Seat Builders, I used 1/4 " birch plywood from Lowes for seat backs, and it worked out well. I punched several large holes in them to keep them light, something I'm rather anal about (so I'm told!). They can be purchased in 2' x 2' pieces. A few miles up the road fron me is an upholstery supply place. I bought three grades of foam in 1" thicknesses. An electric kitchen knife, spray glue, and a few hours later I had nicely shaped, stylish, light and comfy cushions ready for my sister-in-law to upholster. About $70 invested. Lynn Corry, PA 601 XL / Corvair > ________________________________________________________________________________
Subject: Re: Torque Value Table, flap misshap and radio noise
Date: Feb 25, 2008
Thanks Juan for that story about the flaps. I have wondered what would happen if one flap was down and the other was not. What actually came loose? Mine have a bolt through the sleeve that connects the two sides. Thanks again, Scott Laughlin http://www.cooknwithgas.com/Videos/Fly_By_Feb_23_2008.wmv Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166260#166260 ________________________________________________________________________________
Date: Feb 25, 2008
Wow Mike that is quite a saga. Sounds to me that you have had a long successful time flying.So sorry that you have to give it up but you know your body and abilities better than anyone. Big salute from this old guy..still plugging away on my 701. If I had the money and the desire for a 601 I would take her and treat her with extreme care but alas that isn't my situation. I hope that you can get an up in the right seat if that is to your interest.It sounds that you married the right woman as well.. God Bless, Ron Culver ----- Original Message ----- From: A. Michael Honer To: Zenith-List(at)matronics.com Sent: Monday, February 25, 2008 5:01 PM Subject: Zenith-List: A Wonderful bunch of guys THANK YOU! The response which I received from my offer to sell my project 601XL has been more than I expected, both in the many inquiries which came into my e-mail box, and the notes of reassurance and " don't give up the ship." Some of them brought tears. Thanks to all of you. It was about 25 years ago, after We had sent off the last college tuition check for the last kid that Anne and I decided to go flying. We earned our ASEL and Instrument ratings and have between the two of us more than 4500 hours in the air, with about 200 hours of actual instrument time in our 1980 C-172, which we decided to sell about 2 years ago. Things got tough physically for me about 10 years ago, when my MD asked me if I knew I had had a heart attack. After some months, he encouraged me to go back after my Certificate. But by that time I was having extreme problems with a rare form of arthritis, and occasionally could barely walk. (I may finally have found the right combination to deal with that, by the way.) It's not worth going over, even if I could without going into a blue funk. The stroke was the last straw. Taking the positive approach, that blood clot(from a stent installed 5 years ago) was the last straw. The clot took out 60% of my left eye, but could have gone straight into my right brain and left me in bed with a bed pan, not being able to figure out what it was for. So, it can be said that I (we) have already lived our dream of flying. That is why the 601XL is for sale. It is well built, (if I say so myself ) and it is priced such that perhaps someone younger and healthier than I can live his own dream. I know the price is about what the engine alone costs in today's dollars. Best wishes to all, and thanks very much for your kind wishes. Mike Honer ________________________________________________________________________________
Date: Feb 26, 2008
Hi Juan, Could you tell us what exactly happened to cause the flaps to deploy like that ? Did the torque tube pine come out of the slot ? Thanks, John Davis Burnsville, NC 601XL - Jab 3300 - Almost done!!! Juan Vega wrote: > > for the guys still scratching their heads on Torque values, ( i am frankly), attached is the table from the ASA aviaitoin mechanic handbook: > > AN Bolt NUt bolt Tension > Size Size in-lbs > > an3 1-32 20-25 add torque for nylock nuts to all > > an4 1/4-28 50-70 > > an5 5/16-24 100- 140 > > an 6 3/8- 24 460-190 > > an 7 7/16-20 450- 500 > > after tyhat size we are getting to Boeing sized Nuts. > > > Other subject is the flaps. I was coming in for a landing and at 80 mph, set the flaps switch, as i trimmed, I kept compensating for heavier and heavier left wing. at 70 mph trimmed on 1/4 mile final, i looked and one flap was at 5 degree down and the other was full 20+ dgree down. the plane was still very controlable. I landed then reset the flaps. upon review the flaps came up when I broke the speed above 85 mph inadvertantly. the key is the plane did ot fall out of the sky, just kept flying it. says great things about the rougedness of the design. > > > solved the radio noise from the Jabiru engine. the saver was Resistor Spark PLugs. Size is DR9EA-9 on the Jab 3300. did the job. > > > Juan Vega > > > ________________________________________________________________________________
From: "Dave VanLanen" <davevanlanen(at)sbcglobal.net>
Subject: Gloves For Chemical Protection
Date: Feb 26, 2008
I had my wife (a nurse) procure a box of the high-quality Mediguard nitrile exam gloves for my use when working with chemicals such as laquer thinner. On the weekend I cleaned a number of elevator parts in preparation for priming, and after removing the gloves, I noticed that the skin on a couple of my fingers, the ones I used to work the cleaning rags, were more dried out than usual, with small surface cracks. Its possible that this came from a small hole in the glove or something, but it got me to wondering if these gloves are adequate for this work. I could purchase the heavier gauge chemical-resistant gloves that are available, but they are harder to work with because they are thicker and bulkier. Can anyone offer advice on this? Thanks, Dave Van Lanen 601XL - Elevator ________________________________________________________________________________
Date: Feb 26, 2008
the pin actually came out of the slot in the flap. i think enough up pressure was placed to drive the pin on the arm out of the flap nylon slot. I remember the nylon is flexible to certain point. juan -----Original Message----- >From: cookwithgas <cookwithgas(at)HOTMAIL.COM> >Sent: Feb 25, 2008 10:29 PM >To: zenith-list(at)matronics.com >Subject: Zenith-List: Re: Torque Value Table, flap misshap and radio noise > > >Thanks Juan for that story about the flaps. > >I have wondered what would happen if one flap was down and the other was not. What actually came loose? Mine have a bolt through the sleeve that connects the two sides. > >Thanks again, > >Scott Laughlin >http://www.cooknwithgas.com/Videos/Fly_By_Feb_23_2008.wmv > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=166260#166260 > > ________________________________________________________________________________
Date: Feb 26, 2008
deplyed the flap at too high of a speed all the way to the last setting, and the pin came out of the slot. juan -----Original Message----- >From: John Davis <johnd@data-tech.com> >Sent: Feb 26, 2008 8:09 AM >To: zenith-list(at)matronics.com >Subject: Re: Zenith-List: Torque Value Table, flap misshap and radio noise > > >Hi Juan, > >Could you tell us what exactly happened to cause the flaps to deploy >like that ? Did the torque tube pine come out of the slot ? > >Thanks, >John Davis >Burnsville, NC >601XL - Jab 3300 - Almost done!!! > >Juan Vega wrote: >> >> for the guys still scratching their heads on Torque values, ( i am frankly), attached is the table from the ASA aviaitoin mechanic handbook: >> >> AN Bolt NUt bolt Tension >> Size Size in-lbs >> >> an3 1-32 20-25 add torque for nylock nuts to all >> >> an4 1/4-28 50-70 >> >> an5 5/16-24 100- 140 >> >> an 6 3/8- 24 460-190 >> >> an 7 7/16-20 450- 500 >> >> after tyhat size we are getting to Boeing sized Nuts. >> >> >> Other subject is the flaps. I was coming in for a landing and at 80 mph, set the flaps switch, as i trimmed, I kept compensating for heavier and heavier left wing. at 70 mph trimmed on 1/4 mile final, i looked and one flap was at 5 degree down and the other was full 20+ dgree down. the plane was still very controlable. I landed then reset the flaps. upon review the flaps came up when I broke the speed above 85 mph inadvertantly. the key is the plane did ot fall out of the sky, just kept flying it. says great things about the rougedness of the design. >> >> >> solved the radio noise from the Jabiru engine. the saver was Resistor Spark PLugs. Size is DR9EA-9 on the Jab 3300. did the job. >> >> >> >> >> Juan Vega >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Feb 26, 2008
Subject: Re: Gloves For Chemical Protection
Dave After a career as a chemical engineer, I tend to be pretty nonchalant about exposure to chemicals (my wife is convinced I'm killing myself! I hope she's wrong!) But I am exposed to the lacquer thinner so often while building that I decided to wear gloves. I just wear some of the knit gloves that are sold in hardware and other stores that have some sort of rubber coating on the palms and fronts of the fingers. I've never detected any lacquer thinner on my hands after use. I doubt that these gloves would be adequate for long exposure, but my longest usages of thinner have not been over 4 or 5 minutes. And I never get it on the backs of my hands or fingers. I have also been using these gloves for other tasks. I really like them when scouring by hand with ScotchBrite and when deburring inside structures or handling parts with burred edges. They are not too hot and they have quite good grip and tactile feedback. They give just enough protection w/o interfering with the work like leather gloves. I keep one "good" pair for thinner work, and one "work" pair for other tasks. Terry >I had my wife (a nurse) procure a box of the high-quality Mediguard >nitrile exam gloves for my use when working with chemicals such as laquer >thinner. On the weekend I cleaned a number of elevator parts in >preparation for priming, and after removing the gloves, I noticed that the >skin on a couple of my fingers, the ones I used to work the cleaning rags, >were more dried out than usual, with small surface cracks. Its possible >that this came from a small hole in the glove or something, but it got me >to wondering if these gloves are adequate for this work. I could purchase >the heavier gauge chemical-resistant gloves that are available, but they >are harder to work with because they are thicker and bulkier. Can anyone >offer advice on this? > >Thanks, > >Dave Van Lanen > >601XL - Elevator Terry Phillips ttp44~at~rkymtn.net Corvallis MT 601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons are done; working on the wings http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Subject: Electrical Wiring Information
Date: Feb 26, 2008
Here is a web reference to a very good page on electrical connectors, wiring, heat shrink, crimping and all things electrical for the experimental aircraft builder. If nothing more, it make very good reading and contains a lot of information. http://www.heli-chair.com/wiring_101.html Check it out, George Zenith CH-701 - N73EX (Reserved) ________________________________________________________________________________
Subject: Re: Routing choke and throttle cables
Date: Feb 26, 2008
Dave, I'm going with the dual throttle mod so my installation is a bit different. Have you looked at the throttle / choke cable installation instructions on the JabiruUSA website? http://www.usjabiru.com/images/pdf/Vernier%20Throttle%20Installation.pdf Good luck! Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Working on fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166354#166354 ________________________________________________________________________________
Date: Feb 26, 2008
Subject: Re: 5-pin mic jack for RAC trim
I am a huge believer in silicone grease. Every electrical contact in my aircraft (nuts, washers, lock washers, screw threads on bolts, pins and sockets on multi-pin plugs and jacks, etc.) is smeared with silicone grease before I leave it assembled. I have NEVER had one of these fail to make contact because of the grease. When I look occasionally at one of these contacts done 5 or 10 years (or even longer!) ago, the contact is still covered with silicone grease (a thin layer, put on with my fingers - not slathered on) and the corrosion is zero. John Goodings, C-FGPJ, CH601HD with R912S, Toronto/Carp/Ottawa. ________________________________________________________________________________
Date: Feb 26, 2008
Dave, Not sure if you have seen the new Homebuilthelp.com Zenith 601/Jabiru installation video, but it gets covered there. Jabiru recommends bending the brass cable-end adjuster to help accommodate the bends the cable is required to make. I am putting in the dual throttle which also requires bending around the center structure. Although not the best view, I attached the only picture I currently have showing the bent adjusters at the carb for both throttle and choke. Good luck, -------- David Gallagher 601 XL, tail & wings completed and fueslage pretty well done. Working engine and electrical systems. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166366#166366 Attachments: http://forums.matronics.com//files/fuselage_356_974.jpg ________________________________________________________________________________
Date: Feb 26, 2008
Klaus I am wondering just what you bought from Van. Did you get the foam cushions? I find them in their on-line catalog for a pretty good price. Or did you get the supporting seatback for the RV-6? I cannot find seatbacks on the site. In fact, I cannot find parts that are for any specific kit. Is there any way (for a non-RV builder) to locate such parts on Van's site? Terry > >Hi, > >Another possible choice are the seatbacks used in the RV6. We used that in my >plane. They are lightweight and strong. > >Happy building and flying, > >Klaus > >klaus(at)utdallas.edu >www.utdallas.edu/~klaus Terry Phillips ttp44~at~rkymtn.net Corvallis MT 601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons are done; working on the wings http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Subject: Re: Actual rudder pedal travel in 601
Date: Feb 26, 2008
I too needed to file the hinge pieces to get the proper travel. Not a big issue to do and retain the proper radius. One way to check the required travel is when fitting the nose gear. Once you fit the nose gear, you can twist it to it's limits and see the distance that the connecting rods move. It's smaller than you might think. Also when you fit the rudder, you can check it's limits. Scott -------- 601 XL kit Tail, control surfaces and both wings complete. Now working on fuselage www.scottwaters.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166379#166379 ________________________________________________________________________________
Subject: Attaching rudder springs for TD 601XL?
Date: Feb 26, 2008
For you other XL taildragger builders out there, I need to install the rudder return springs and was wondering how various people attached them to the inboard pedals. (The firewall end is straightforward, I think.) I have thought of tapping into the side of the pedal for an 8-32 screw, and using some kind of band clamp. I do not want to do any welding at this stage. Ideas or Suggestions? Andy Elliott, Mesa, AZ N601GE (reserved) 601XL/TD, Corvair?, building... ________________________________________________________________________________
Date: Feb 26, 2008
Subject: 601xl materials list
Folksen, I have been working on my materials list for my 601xl. I would like to believe I have all the major parts listed, thicknesses, number of each and finally rough dimensions and areas. Here is what I have for just the sheet goods 6061-T6: 0.016 5-4'x8' 0.025 11-4'x12' 0.032 1-4'x12' 0.063 1-4'x4' I have checked and rechecked, but it's always good to have someone else that's been there to either point and laugh or confirm my calculations. I haven't done the "it's cheaper to get Y-4'x12' sheets rather than X-4'x8' sheets, etc. This was strictly looking at the max dimensions of the pieces I needed and buying that + some overage. Do those quantities jive, or am I smoking crack? ________________________________________________________________________________
Date: Feb 26, 2008
Subject: Re: 601xl materials list
Lee Go to http://www.ch601.org/builder%20resources.htm and get the 601xl.pdf where it says "new 601xl version layout sheets". I can't remember what I ordered originally before the change was made to the thicker skins. Kevin Bonds Lee Steensland wrote: > > > Folksen, > > I have been working on my materials list for my 601xl. I would like > to believe I have all the major parts listed, thicknesses, number of > each and finally rough ________________________________________________________________________________
Date: Feb 26, 2008
Hi Lee, For the HDS it was prudent to have more 8 foot sheets as I learned the hard way. You should inventory your long pieces and figure how many of each you need and add 20% for damage and errors in your shop. I'd buy enough .016 for ailerons, elevators, etc. Replace any other .016 skin with .020 where you can. I made 5 ailerons to get two correct and then accidentally stepped on the good one and bought more sheet. Several rear top skins two rudder nose skins, two stabilizer nose skins, and many other parts too numerous to mention to get it exactly right. You get the idea. With the XL you might just be ahead with 12 footers. Larry McFarland 601HDS at www.macsmachine.com Lee Steensland wrote: > > > Folksen, > > I have been working on my materials list for my 601xl. I would like > to believe I have all the major parts listed, thicknesses, number of > each and finally rough dimensions and areas. > > Here is what I have for just the sheet goods 6061-T6: > > 0.016 5-4'x8' > 0.025 11-4'x12' > 0.032 1-4'x12' > 0.063 1-4'x4' > > I have checked and rechecked, but it's always good to have someone > else that's been there to either point and laugh or confirm my > calculations. > > I haven't done the "it's cheaper to get Y-4'x12' sheets rather than > X-4'x8' sheets, etc. This was strictly looking at the max dimensions > of the pieces I needed and buying that + some overage. > > Do those quantities jive, or am I smoking crack? > ________________________________________________________________________________
Date: Feb 26, 2008
Subject: Re: Upholstery sources
What would be a reasonable charge for a local automotive upholstery shop to make the covers for those seats? I ended up building my own and then taking it to a local auto upholstery shop. I am real happy with the resluts. Check it out on my site http://www.zodiacxl.com/Seats.htm Matt www.zodiacxl.com -------- Matt www.zodiacxl.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=165804#165804 Attachments: http://forums.matronics.com//files/img_1786_107.jpg --------------------------------- Never miss a thing. Make Yahoo your homepage. ________________________________________________________________________________
Date: Feb 26, 2008
Subject: 701 door gas springs
Tracy. I don't know if the springs I used will work on the bubble doors or not. Go to www.ch701.com and look under builders photos and then under Mark Sherman. Pictures and part numbers are there. Hope this helps. Mark S. Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Date: Feb 26, 2008
From: Michael Hilderbrand <m_hilderbrand(at)sbcglobal.net>
you should try invisible gloves. i use this, and gloves if i know i will get the chem on my skin. i used to not care, and played with MEK like candy. Now i have these very weird dried up areas that are immune to any type of lotions or creams.. next stop will be a dermatologist. nothing to play around with! Michael Hilderbrand Derby, Kansas Http://www.kansasflying.com ----- Original Message ---- From: Dave VanLanen <davevanlanen(at)sbcglobal.net> Sent: Tuesday, February 26, 2008 8:12:09 AM Subject: Zenith-List: Gloves For Chemical Protection I had my wife (a nurse) procure a box of the high-quality Mediguard nitrile exam gloves for my use when working with chemicals such as laquer thinner. On the weekend I cleaned a number of elevator parts in preparation for priming, and after removing the gloves, I noticed that the skin on a couple of my fingers, the ones I used to work the cleaning rags, were more dried out than usual, with small surface cracks. Its possible that this came from a small hole in the glove or something, but it got me to wondering if these gloves are adequate for this work. I could purchase the heavier gauge chemical-resistant gloves that are available, but they are harder to work with because they are thicker and bulkier. Can anyone offer advice on this? Thanks, Dave Van Lanen 601XL - Elevator ________________________________________________________________________________
Date: Feb 26, 2008
> I use the latex gloves from Walgreens. I had no > problems with these gloves. They work fine... --- Michael Hilderbrand wrote: > you should try invisible gloves. i use this, and > gloves if i know i will get the chem on my skin. i > used to not care, and played with MEK like candy. > Now i have these very weird dried up areas that are > immune to any type of lotions or creams.. next stop > will be a dermatologist. nothing to play around > with! > > Michael Hilderbrand > Derby, Kansas > Http://www.kansasflying.com > > > > ----- Original Message ---- > From: Dave VanLanen <davevanlanen(at)sbcglobal.net> > To: zenith-list(at)matronics.com > Sent: Tuesday, February 26, 2008 8:12:09 AM > Subject: Zenith-List: Gloves For Chemical Protection > > > I had my wife (a nurse) procure a box of the > high-quality Mediguard nitrile exam gloves for my > use when working with chemicals such as laquer > thinner. On the weekend I cleaned a number of > elevator parts in preparation for priming, and after > removing the gloves, I noticed that the skin on a > couple of my fingers, the ones I used to work the > cleaning rags, were more dried out than usual, with > small surface cracks. Its possible that this came > from a small hole in the glove or something, but it > got me to wondering if these gloves are adequate for > this work. I could purchase the heavier gauge > chemical-resistant gloves that are available, but > they are harder to work with because they are > thicker and bulkier. Can anyone offer advice on > this? > Thanks, > Dave Van Lanen > 601XL - Elevator > > Looking for last minute shopping deals? ________________________________________________________________________________
Date: Feb 26, 2008
> Who makes the DR9EA-9 plug? NGK -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166486#166486 ________________________________________________________________________________
Subject: Dragon Season
Date: Feb 26, 2008
Hmmmm, Dragon Season must have opened in Alabama! Purple Dragon Season: http://www.youtube.com:80/results?search_query=n701rr&search_type -------- Low & Slow Rick www.n701rr.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166496#166496 ________________________________________________________________________________
Date: Feb 27, 2008
ngk as wel as another few. just google it. juan -----Original Message----- >From: Ron Lendon <rlendon(at)comcast.net> >Sent: Feb 26, 2008 9:13 PM >To: zenith-list(at)matronics.com >Subject: Zenith-List: Re: Torque Value Table, flap misshap and radio noise > > >> Who makes the DR9EA-9 plug? > >NGK > >-------- >Ron Lendon, Clinton Township, MI >Corvair Zodiac XL, ScrapBuilder ;-) >http://www.mykitlog.com/rlendon > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=166486#166486 > > ________________________________________________________________________________
From: "Dave Johnson" <david_a_g_johnson(at)btinternet.com>
Date: Feb 27, 2008
Thanks for the tip - I have been watching Jon's videos, but when I saw the section on installing the dual throttles, I decided that I didn't need to watch that, as I'm going for the single throttle - WRONG!! I should have realised that all of Jon's videos are worth watching. I put it down to a 'senior moment' (I get a lot of them!) Dave Johnson ----- Original Message ----- From: "DaveG601XL" <david.m.gallagher(at)ge.com> Sent: Tuesday, February 26, 2008 5:01 PM Subject: Zenith-List: Re: Routing choke and throttle cables > > Dave, > > Not sure if you have seen the new Homebuilthelp.com Zenith 601/Jabiru > installation video, but it gets covered there. Jabiru recommends bending > the brass cable-end adjuster to help accommodate the bends the cable is > required to make. I am putting in the dual throttle which also requires > bending around the center structure. Although not the best view, I > attached the only picture I currently have showing the bent adjusters at > the carb for both throttle and choke. > > Good luck, > > -------- > David Gallagher > 601 XL, tail & wings completed and > fueslage pretty well done. Working engine and electrical systems. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=166366#166366 > > > Attachments: > > http://forums.matronics.com//files/fuselage_356_974.jpg > > > ________________________________________________________________________________
Date: Feb 27, 2008
Subject: 701 door springs
thanks for the info Mark. imjust woried about flexing on the bubble doors.guess I will build it and find out ________________________________________________________________________________
Date: Feb 27, 2008
Subject: Re: Zenith-List Digest: 29 Msgs - 02/26/08
You have restored my faith, I thought you would rarely make a mistake. I feel much better about my own screwups and having to redo parts now that I see that near perfect workmanship comes at a price.:-) alex t. >> >> > From: LarryMcFarland <larry(at)macsmachine.com> <mailto:larry(at)macsmachine.com> > Subject: Re: Zenith-List: 601xl materials list > > > Hi Lee, > For the HDS it was prudent to have more 8 foot sheets as I learned the > hard way. You should inventory your long pieces and figure how many of > each you need and add 20% for damage and errors in your shop. I'd buy > enough .016 for ailerons, elevators, etc. Replace any other .016 skin > with .020 > where you can. I made 5 ailerons to get two correct and then > accidentally stepped on the good one and bought more sheet. Several rear > top skins > two rudder nose skins, two stabilizer nose skins, and many other parts > too numerous to mention to get it exactly right. You get the idea. With > the XL > you might just be ahead with 12 footers. > > Larry McFarland 601HDS at www.macsmachine.com <http://www.macsmachine.com> ________________________________________________________________________________
Subject: Re: 701 door springs
Date: Feb 27, 2008
They will definitely crack if you don't reinforce them. Especially in cold weather. One of mine did. They are made out of Plexiglas. If they had been made out of Lexan it would not be a problem. Lexan flexes, Plexiglas does not. Lexan is softer and will scratch easier. It is also harder than Plexiglas to buff out, but can be done, I have done it. I asked Zenith why they didn't use Lexan, their answer was that gas would distort or cloud the finish. So, don't get gas on your doors!! If you do it will buff out. Truth be known, Plexiglas is cheaper to buy and form. LRM www.skyhawg.com. ----- Original Message ----- From: "Tracy" <pbuttles(at)charter.net> Sent: Wednesday, February 27, 2008 7:09 AM Subject: Zenith-List: 701 door springs > > thanks for the info Mark. > imjust woried about flexing on the bubble doors.guess I will build it and > find out > > > -- > 9:08 AM > > ________________________________________________________________________________
Date: Feb 27, 2008
Subject: New to the list
I'm getting ready to order a Zodiac XLi from AMD, and it was suggested that I join this list. I know that it's mainly oriented to homebuilding, but I hope to get some useful insight into the aircraft and flying it. I'd dearly love to build my own. The reality is that I don't have anything close to the time needed to devote to such a project. I just got a BFR in Dragonfly Aviation's Zodiac. It took me one whole flight and several really terrible arrivals (I won't call them landings) to realize that I can't fly it the same way I'd fly a 172 or Tiger. The second flight was a lot better, and I'm now convinced that I can fly the aircraft well, given sufficient practice. That was my main concern; a secondary concern was the seating, boththe positionand the upholstery, but that turned out to be a total non-issue. I'm about to call John Degonia and get the ball rolling. Hopefully, I'll have the aircraft before a wholelot of time has passed. See you in the air! -- Jay Maynard, K5ZC http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (FRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC (getting ready to order) ________________________________________________________________________________
Date: Feb 27, 2008
> "I'm getting ready to order a Zodiac XLi from AMD, and it was suggested t hat" Hi Jay-- Welcome to the list. There is a vast array of knowledge of things Zenith here. I'm etc sure any questions you might have on plane flight characteris tics or performance can be answered, alsong with engine issues etc. George May 601XL 912s > > _________________________________________________________________ Connect and share in new ways with Windows Live. http://www.windowslive.com/share.html?ocid=TXT_TAGHM_Wave2_sharelife_0120 08 ________________________________________________________________________________
Date: Feb 27, 2008
Subject: Re: New to the list
Welcome to the list Jay, Good move being on the list. There's always something that needs adjusting, replacement or adding, even with a new plane. You'll make it your own with an LRI or GPS etc. Lots of archives and people to assist you in that latest info or solutions. Just don't hesitate to ask. Larry McFarland 601HDS at www.macsmachine.com Jay Maynard wrote: > > I'm getting ready to order a Zodiac XLi from AMD, and it was suggested that > I join this list. I know that it's mainly oriented to homebuilding, but I > hope to get some useful insight into the aircraft and flying it. I'd dearly > love to build my own. The reality is that I don't have anything close to the > time needed to devote to such a project. > > I just got a BFR in Dragonfly Aviation's Zodiac. It took me one whole flight > and several really terrible arrivals (I won't call them landings) to realize > that I can't fly it the same way I'd fly a 172 or Tiger. The second flight > was a lot better, and I'm now convinced that I can fly the aircraft well, > given sufficient practice. That was my main concern; a secondary concern was > the seating, boththe positionand the upholstery, but that turned out to be a > total non-issue. > > I'm about to call John Degonia and get the ball rolling. Hopefully, I'll > have the aircraft before a wholelot of time has passed. See you in the air! > ________________________________________________________________________________
Subject: Re: Dragon Season
Date: Feb 27, 2008
I really like the sound of that Suzuki engine.... Quite a Hummer! Tommy rroberts wrote: > Hmmmm, Dragon Season must have opened in Alabama! Purple Dragon Season: > > http://www.youtube.com:80/results?search_query=n701rr&search_type -------- Tommy Walker Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166611#166611 ________________________________________________________________________________
Subject: FS: EXP BUS MOUNTING TRAY
Date: Feb 27, 2008
I've decided to not use the EXP Bus I purchased and before I go through the hassle of sending it back to ACS I'll offer it to you guys. ACS price is $424 I'll let it go for $400 and I'll ship it anywhere in the 48 states. I've had it out of the box to look at it but it has never been installed. Here is the ACS page on it for more info. http://www.aircraftspruce.com/catalog/elpages/expbus.php -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166634#166634 ________________________________________________________________________________
Date: Feb 27, 2008
Subject: Re: FS: EXP BUS MOUNTING TRAY
Hey Gig: I will take your offer on the EXP BUS MOUNTING TRAY. Lynn Nelsen **************Ideas to please picky eaters. Watch video on AOL Living. (http://living.aol.com/video/how-to-please-your-picky-eater/rachel-campos-duffy/ 2050827?NCID=aolcmp00300000002598) ________________________________________________________________________________
Date: Feb 27, 2008
Jay, Welcome! I'm glad to hear that there will be a Zodiac flying in Minnesota! I hope I see you around. I'm curious to hear what the main challenges you faced were transitioning from a 172 to the Zodiac. Other than getting the feel of a new plane, what things were hardest to get used to? What surprised you? Always interesting to here what that first experience was like. Scott -------- 601 XL kit N596SW reserved Tail, control surfaces and both wings complete. Now working on fuselage www.scottwaters.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166645#166645 ________________________________________________________________________________
Date: Feb 27, 2008
Too cool Rick! -------- Kevin N701DZ Reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166647#166647 ________________________________________________________________________________
Date: Feb 27, 2008
Hey welcome to the list. I live in western WI and drive through Fairmont regularly for work. -------- Kevin N701DZ Reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166648#166648 ________________________________________________________________________________
Date: Feb 27, 2008
swater6 wrote: > Welcome! I'm glad to hear that there will be a Zodiac flying in Minnesota! I hope I see you around. Actually, mine will be the second AMD Zodiac in Minnesota. A guy in Crookston got the first one. He's also worked with the factory to develop a cold weather kit for the Zodiac: mainly improved cabin sealing, but also cooling inlet restrictors. I'll have that on my aircraft, as well as a Tanis heater. > I'm curious to hear what the main challenges you faced were transitioning from a 172 to the Zodiac. Other than getting the feel of a new plane, what things were hardest to get used to? What surprised you? The Zodiac's control feel was significantly lighter than I was used to. I've got about 165 hours in 172s, PA-28s, and AA-5Bs, and they all feel about the same - and completely unlike the Zodiac. It took a suggestion from Gig on Usenet to get me straightened out. The first time, I was using my hand and arm to fly, as I did in other aircraft, and never really had control of the aircraft. The second time, I planted the side of my left hand firmly on my thigh and only used the thumb and forefinger on the base of the grip to fly, and the CFI's comment was that I finally had command of the aircraft. He was right, too. The one acceptable landing I made (out of 8 plus one go-around from a landing I couldn't rescue) was the first one I made the second day, and it was at least rolled on instead of dropped in from several feet. I have to say the Zodiac's gear has to be the stoutest I've ever seen, considering the abuse I gave it and the CFI's reaction to that. ("As long as you put it on the mains first, you won't break anything.") That's a good thing, but I really hope I learn to do better before I tear up my own plane! :-) I'm going to have to spend some time at altitude figuring out power settings and attitudes to achieve particular speeds and climb/descent rates. I still don't have a good handle on how to get that perfect 3 degree glide at 60 KIAS down final, and my command of the aircraft isn't that good yet. I think I'll need to carry some power on final at 60 knots with half flaps, which is what the CFI recommended I use. I'm also still overcontrolling a bit, though not as horribly as I did that first day. I'm not sure how different the AMD version will be, either in control feel or power/attitude/picture over the nose, from the aircraft I flew (Dragonfly Aviation's 601XL with the Sparrowhawk O-235). I suspect it won't make much difference, but won't know till I fly it. I was quoted a May 10 delivery date by the sales rep I'm dealing with. So far, I've got 3 hours in the Zodiac; I'll probably need several more before I'll feel comfortable with it. As I said in my Usenet posting where I laid out my decision process between the Zodiac and the other SLSA I was considering, the Tecnam Sierra: Do not fly the Zodiac without a good, thorough checkout by a CFI who's familiar with the aircraft and especially transitioning to it from the average light single. It will save you endless frustration and grief. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166651#166651 ________________________________________________________________________________
Subject: Where?
Date: Feb 27, 2008
All- Where can I get aviation quality connectors such as those in the picture? These came from the local hardware store and I want to make sure I'm using the best. No listing on ACS. Must have them to enable me to easily service my belly strobe. Not my best photography! Thanks. Bill Naumuk Townville, Pa. HDS Fuse/Corvair ________________________________________________________________________________
Date: Feb 27, 2008
Subject: Re: Where?
Hi Bill, I'm not completely sure, but I don't think you can get mil. spec. connectors like that. I like to use the automotive grade connectors with the softer plastic molded parts that aren't as interested in breaking as the hard plastic (cheap) ones. I also prefer the spade type connectors to the round ones like you show in your picture. The spade connectors have a flat bar on the male end and two rolled spring contactors on the female end. While these may not be mil. spec. they do a great job of making and holding a connection. Paul XL fuselage At 05:27 PM 2/27/2008, you wrote: >All- > Where can I get aviation quality connectors such as those in > the picture? These came from the local hardware store and I want to > make sure I'm using the best. > No listing on ACS. Must have them to enable me to easily > service my belly strobe. > Not my best photography! > Thanks. >Bill Naumuk >Townville, Pa. >HDS Fuse/Corvair ________________________________________________________________________________
Subject: Re: Where?
Date: Feb 27, 2008
Paul- It's a matter of being able to get the connector through the largest mounting hole of the light, if need be. That's why I can't use a spade connector. Bill ----- Original Message ----- From: Paul Mulwitz To: zenith-list(at)matronics.com Sent: Wednesday, February 27, 2008 8:46 PM Subject: Re: Zenith-List: Where? Hi Bill, I'm not completely sure, but I don't think you can get mil. spec. connectors like that. I like to use the automotive grade connectors with the softer plastic molded parts that aren't as interested in breaking as the hard plastic (cheap) ones. I also prefer the spade type connectors to the round ones like you show in your picture. The spade connectors have a flat bar on the male end and two rolled spring contactors on the female end. While these may not be mil. spec. they do a great job of making and holding a connection. Paul XL fuselage At 05:27 PM 2/27/2008, you wrote: All- Where can I get aviation quality connectors such as those in the picture? These came from the local hardware store and I want to make sure I'm using the best. No listing on ACS. Must have them to enable me to easily service my belly strobe. Not my best photography! Thanks. Bill Naumuk Townville, Pa. HDS Fuse/Corvair ________________________________________________________________________________
Subject: Where?
Date: Feb 27, 2008
I looked on B&C, Stein Air and Terminal Town and don't see that specific "barrel style" connector. But if you are willing to use another style they have them: www.terminaltown.com www.steinair.com www.bandc.biz/parts.html -- Craig From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bill Naumuk Sent: Wednesday, February 27, 2008 6:28 PM Subject: Zenith-List: Where? All- Where can I get aviation quality connectors such as those in the picture? These came from the local hardware store and I want to make sure I'm using the best. No listing on ACS. Must have them to enable me to easily service my belly strobe. Not my best photography! Thanks. Bill Naumuk Townville, Pa. HDS Fuse/Corvair ________________________________________________________________________________
Subject: what if? elevator trim tab runaway
From: "chris Sinfield" <chris_sinfield(at)yahoo.com.au>
Date: Feb 28, 2008
Q. for those out flying their XL's. With the large elevator trim tab, if it was deflected full one way up or down, is it still controllable? I am fitting the Ray Allen Trim system and thinking about if one switches sticks. I may fit a CB to the trim power line and pull it to stop the trim run away if required, rather than hide it with a fuse. What do others think? Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166695#166695 ________________________________________________________________________________
Date: Feb 28, 2008
Subject: Re: Where?
The interlocking knife switch type would probably work for you and they will not separate under a tension load. Bill Naumuk wrote: Paul- It's a matter of being able to get the connector through the largest mounting hole of the light, if need be. That's why I can't use a spade connector. Bill ----- Original Message ----- From: Paul Mulwitz To: zenith-list(at)matronics.com Sent: Wednesday, February 27, 2008 8:46 PM Subject: Re: Zenith-List: Where? Hi Bill, I'm not completely sure, but I don't think you can get mil. spec. connectors like that. I like to use the automotive grade connectors with the softer plastic molded parts that aren't as interested in breaking as the hard plastic (cheap) ones. I also prefer the spade type connectors to the round ones like you show in your picture. The spade connectors have a flat bar on the male end and two rolled spring contactors on the female end. While these may not be mil. spec. they do a great job of making and holding a connection. Paul XL fuselage At 05:27 PM 2/27/2008, you wrote: All- Where can I get aviation quality connectors such as those in the picture? These came from the local hardware store and I want to make sure I'm using the best. No listing on ACS. Must have them to enable me to easily service my belly strobe. Not my best photography! Thanks. Bill Naumuk Townville, Pa. HDS Fuse/Corvair href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c Dave Downey Harleysville (SE) PA 100 HP Corvair --------------------------------- ________________________________________________________________________________
Date: Feb 28, 2008
Subject: Re: Where?
they are called knife splices http://www.gyroplanepassion.com/AircraftElectricalTerminalConnectors.html http://www.jameco.com/Jameco/catalogs/c253/P130.pdf http://store.nexternal.com/shared/StoreFront/default.asp?CS=racequiet&StoreType=BtoC&Count1=175121486&Count2=92261910&ProductID=18994&Target=products.asp http://www.gulf-coast-avionics.com/detail/8149/Accessories/%5F/PIDG%5FSplice/ As you see, the last two links are the exact same product - the one sold by the aircraft outfit is double the price... As previously stated on the list, silicone dielectric grease is advised for these connectors without noble plated contacting surfaces. Bill Naumuk wrote: Paul- It's a matter of being able to get the connector through the largest mounting hole of the light, if need be. That's why I can't use a spade connector. Bill ----- Original Message ----- From: Paul Mulwitz To: zenith-list(at)matronics.com Sent: Wednesday, February 27, 2008 8:46 PM Subject: Re: Zenith-List: Where? Hi Bill, I'm not completely sure, but I don't think you can get mil. spec. connectors like that. I like to use the automotive grade connectors with the softer plastic molded parts that aren't as interested in breaking as the hard plastic (cheap) ones. I also prefer the spade type connectors to the round ones like you show in your picture. The spade connectors have a flat bar on the male end and two rolled spring contactors on the female end. While these may not be mil. spec. they do a great job of making and holding a connection. Paul XL fuselage At 05:27 PM 2/27/2008, you wrote: All- Where can I get aviation quality connectors such as those in the picture? These came from the local hardware store and I want to make sure I'm using the best. No listing on ACS. Must have them to enable me to easily service my belly strobe. Not my best photography! Thanks. Bill Naumuk Townville, Pa. HDS Fuse/Corvair href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c Dave Downey Harleysville (SE) PA 100 HP Corvair --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Subject: Re: what if? elevator trim tab runaway
Date: Feb 28, 2008
Chris, That is what I did. I have few CB's and trim is one of them for the very reason that I could pull it if desired. Good luck, -------- David Gallagher 601 XL, tail & wings completed and fueslage pretty well done. Working engine and electrical systems. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166700#166700 ________________________________________________________________________________
Subject: Re: Where?
Date: Feb 28, 2008
If you are going to use automotive type connectors, at least get marine grade. They are for the harsh marine conditions. And you can always apply some di-electric grease. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166703#166703 ________________________________________________________________________________
Date: Feb 28, 2008
Chris I have the full span left side elevator trim tab. When I get ham handed I sometimes inadvertently activate the trim switches on the top of the control stick. It will get your attention but it is still controllable. Same for the aileron trim. I have been at full deflection. The first time it happened it took 10 seconds to diagnose what was causing it. At normal flight speed it has the most authority. At pattern speeds I need to increase the trim setting on the aileron. Time for full deflection is about 3 seconds. By the time you notice it, it will be at full deployment so pulling a fuse wouldn't help. It will take power to reverse the setting. I think if it happened it would be an irritation. The controls are normally very light. Gary Ray 601XL, 64 hrs TT davgray(at)sbcglobal.net ----- Original Message ----- From: "chris Sinfield" <chris_sinfield(at)yahoo.com.au> Sent: Thursday, February 28, 2008 5:30 AM Subject: Zenith-List: what if? elevator trim tab runaway > > Q. for those out flying their XL's. > > With the large elevator trim tab, if it was deflected full one way up or down, is it still controllable? I am fitting the Ray Allen Trim system and thinking about if one switches sticks. > > I may fit a CB to the trim power line and pull it to stop the trim run away if required, rather than hide it with a fuse. What do others think? > Chris > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=166695#166695 > > > -- 8:45 PM > > ________________________________________________________________________________
Date: Feb 28, 2008
Listers, FWTW, it seems to me that what might be no more than an irritation under most conditions could easily become one distraction too many in a busy airport environment or when dealing with other more challenging situations. I'm putting in an order for the "Safety- Trim" system from TCW to use with Ray Allen servos in my ZenVair 601XL (unfinished). Still haven't heard about anyone else having used it other than Tim Olson's RV-10. TCW's website is: www.tcwtech.com Al On Feb 28, 2008, at 7:11 AM, Gary Ray wrote: > > Chris > > I have the full span left side elevator trim tab. When I get ham > handed I > sometimes inadvertently activate the trim switches on the top of > the control > stick. It will get your attention but it is still controllable. > Same for > the aileron trim. > I have been at full deflection. The first time it happened it took 10 > seconds to diagnose what was causing it. > At normal flight speed it has the most authority. At pattern > speeds I need > to increase the trim setting on the aileron. > > Time for full deflection is about 3 seconds. By the time you > notice it, it > will be at full deployment so pulling a fuse wouldn't help. It > will take > power to reverse the setting. I think if it happened it would be an > irritation. The controls are normally very light. > > Gary Ray 601XL, 64 hrs TT > davgray(at)sbcglobal.net > > > ----- Original Message ----- > From: "chris Sinfield" <chris_sinfield(at)yahoo.com.au> > To: > Sent: Thursday, February 28, 2008 5:30 AM > Subject: Zenith-List: what if? elevator trim tab runaway > > > >> >> Q. for those out flying their XL's. >> >> With the large elevator trim tab, if it was deflected full one way >> up or > down, is it still controllable? I am fitting the Ray Allen Trim > system and > thinking about if one switches sticks. >> >> I may fit a CB to the trim power line and pull it to stop the trim >> run > away if required, rather than hide it with a fuse. What do others > think? >> Chris >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=166695#166695 >> >> >> >> >> >> >> >> >> >> >> >> >> -- > 8:45 PM >> >> > > ________________________________________________________________________________
Date: Feb 28, 2008
From: Maarten Versteeg <maarten.versteeg(at)swri.org>
Subject: Aileron integration
Hello List, I am nearing completion of my first wing. My question is when have you integrated the aileron with the wing. I have already drilled the flap and aileron to the wing but when should these be riveted in place. The guide describes holding off on the flaps till mounting the wings to the plane, but for the aileron it might be easy to get the bell crank setup and the trim servo wires attached. Any advise ? Maarten 601XL plans building wings. ________________________________________________________________________________
From: "Scott Thatcher" <s_thatcher(at)bellsouth.net>
Subject: Re: Zenith-List Digest: 23 Msgs - 02/27/08
Date: Feb 28, 2008
Welcome to the list Jay! I just got my Zodiac registered in December and it took the combined input of most of the people on this list to get me out of the jams I'd gotten myself into. Fortunately, you won't experience the frustration of screwing up but for other issues such as avionics, autopilots, and various mounting solutions, there is always someone here who has done that or been there. Again Congratulations and thanks for the info on on to fly this darn thing! Scott Thatcher, Palm Beach Gardens, FL 601XL with Corvair, Registered as E-LSA N601EL From: Jay Maynard <jmaynard(at)conmicro.com> Subject: Zenith-List: New to the list I'm getting ready to order a Zodiac XLi from AMD, and it was suggested that I join this list. I know that it's mainly oriented to homebuilding, but I hope to get some useful insight into the aircraft and flying it. I'd dearly love to build my own. The reality is that I don't have anything close to the time needed to devote to such a project. ________________________________________________________________________________
Subject: 601 parts
Date: Feb 28, 2008
i need seat belts and cowl and eng mt for subaru into 601 hds. thanks bill ________________________________________________________________________________
Subject: 601 XL Empty Weight
Date: Feb 28, 2008
What can I expect the empty weight of my 601 XL will be when its done - less the weight of the engine and paint? Assume a stock build with minimal instruments and minimal corrosion proofing. Thanks for info! -------- Dale Flying Cessna 170B Building Zenith 601XL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166733#166733 ________________________________________________________________________________
Subject: Re: Aileron integration
Date: Feb 28, 2008
I riveted them when I finished the wing long ago. I also installed and ran the trim before I closed up the wing so they are now tangling at the inboard end of the wing with all the other wires. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166735#166735 ________________________________________________________________________________
Date: Feb 28, 2008
I'm going with switches, circuit breakers and fuses. The main reason is because I was going to have to put several in anyway I just decided it would be not that much more work to do all of them. zenith601xl(at)gmail.com wrote: > What alternative did you choose and why? > Dennis Shoup > > -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166741#166741 ________________________________________________________________________________
Subject: Re: 601 XL Empty Weight
Date: Feb 28, 2008
Hello I was thinking about the same thing. What would the weight [approx] be with a 0200 engine installed? Thanks Don Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166748#166748 ________________________________________________________________________________
Date: Feb 28, 2008
Well that's what AMD puts in the S-LSA so looking at their specs 770 Lbs. http://www.newplane.com/amd/amd/601_SLSA/specification.html rhodes1 wrote: > Hello > I was thinking about the same thing. What would the weight [approx] be with a 0200 engine installed? > Thanks Don -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166750#166750 ________________________________________________________________________________
Subject: Throttle Cables
Date: Feb 28, 2008
Asked in a previous post what cable (s) were used in the the CH 701 921S engine installation video. Anybody have any clues? Thinking of using two throttle cables - any problem with the added internal sliding friction with two cables? What is the attachment from cable core to throttle rod used in the installation - froze the video and it looks like a NAPA HELP type item. What say you guys Phil Smith CH-701 ________________________________________________________________________________
Date: Feb 28, 2008
Subject: Any Zodiac Builders near SE New Hampshire
I am considering building a Zodiac 601XL. Is there anyone near Keene, NH that is building or flying this critter? Thanks, Wayne --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Feb 28, 2008
Hi Dave, I am currently doing the same task. I found the cable end adjusters included in the FWF from UsJabiru to be completely unusable. The distance from the carburetor to the nose gear was completely used up by these parts before inserting the cable. I decided to make new cable end fittings on my metal lathe. The new parts extend only one inch from the carburetor bracket. This made it possible to route the cable around the nose gear column and still get it to the carburetor. I wound up making three of these fittings since I have dual throttles. Two were used on the carburetor, and one on the center cable for the dual throttle. If you need the dimensions for these parts, I can send you a copy of my little pencil drawing. Anyone with a lathe and some round brass bar could make them in less than one hour each. You also will need a thread forming die. If you don't have a lathe, perhaps you know someone who does or can use a local machine shop's services. I suppose you could buy the parts somewhere, but I have no idea where to look for them. I tried McMaster-Carr and failed miserably. Good luck, Paul XL fuselage - hooking up engine At 08:13 AM 2/26/2008, you wrote: >I am installing the Jabiru 3300 on the 601XL and have got to the >point of connecting up the throttle and choke cables. > >My problem is that the carb. is almost directly in front of the nose >leg, so the cables have to go through a couple of quite sharp bends. > >I would be very interested to hear how others have routed their cables. > >Dave Johnson. > >601XL in the UK > > ________________________________________________________________________________
Date: Feb 28, 2008
Hi Don, The AMD web site shows 770 pounds empty weight for the factory built XL. I believe this model includes the Continental O-200. My informal examination of many LSA specs seems to indicate using an O-200 or O-235 adds around 100 pounds to your empty weight compared to a Rotax or Jabiru installation. Paul XL fuselage At 08:35 AM 2/28/2008, you wrote: >Hello >I was thinking about the same thing. What would the weight [approx] >be with a 0200 engine installed? >Thanks Don > > ________________________________________________________________________________
Subject: Re: Throttle Cables
Date: Feb 28, 2008
Hello Phil, Sorry for the delay in getting back to you. Every plane is equipped a little differently and we had to go back to the catalogs to answer your questions. All the information was there: 1. Throttle Cables used were A 820 Friction Lock Control (3ft.) #05-09436 2. Cable Safe #05-16250 used through firewall. 3. Cable holder at throttle rod from Kragen Auto - or you could use a Cable end "B" nut found in the Spruce Catalog. Part # 05-16210. Hope this helps. Regards, Michael Heintz Quality Sport Planes, LLC www.qualitysportplanes.com Representing Zenith Aircraft kits in the West ----- Original Message ----- From: Philip To: Zenith-List(at)matronics.com Sent: Thursday, February 28, 2008 12:25 PM Subject: Zenith-List: Throttle Cables Asked in a previous post what cable (s) were used in the the CH 701 921S engine installation video. Anybody have any clues? Thinking of using two throttle cables - any problem with the added internal sliding friction with two cables? What is the attachment from cable core to throttle rod used in the installation - froze the video and it looks like a NAPA HELP type item. What say you guys Phil Smith CH-701 ________________________________________________________________________________
Date: Feb 28, 2008
I am installing the Continental O-200 in my 601 XL, the people at Teledyne Mattituck told me the O-200 is 215 pounds with accessories, the Jabiru is listed at 180 with accessories. Clyde Barcus 601 XL, Continental Powered ----- Original Message ----- From: "Paul Mulwitz" <psm(at)att.net> Sent: Thursday, February 28, 2008 12:04 PM Subject: Re: Zenith-List: Re: 601 XL Empty Weight > > Hi Don, > > The AMD web site shows 770 pounds empty weight for the factory built XL. > I believe this model includes the Continental O-200. > > My informal examination of many LSA specs seems to indicate using an O-200 > or O-235 adds around 100 pounds to your empty weight compared to a Rotax > or Jabiru installation. > > Paul > XL fuselage > > > At 08:35 AM 2/28/2008, you wrote: > >>Hello >>I was thinking about the same thing. What would the weight [approx] be >>with a 0200 engine installed? >>Thanks Don >> >> > > > ________________________________________________________________________________
Date: Feb 28, 2008
From: "Michael Valentine" <mgvalentine(at)gmail.com>
Subject: Re: Any Zodiac Builders near SE New Hampshire
Wayne - I am in Contoocook - tail and wings done, fuse in progress. Ernie is in Merrimack. Sorry Ernie, I can't remember your last name!! Ernie is probably about to pass me in progress. He will likely chime in soon. Roger Pritchard is in Nashua - Plane and Corvair engine pretty much done - putting on wings somewhere. George May is done and flying in Kingston (plane in Elliot, ME) Everyone should be viewable through the web site John Read provided. Email or call me directly for more info. Cheers, Michael Valentine 603-746-2166 On Thu, Feb 28, 2008 at 12:54 PM, Wayne Aho wrote: > I am considering building a Zodiac 601XL. Is there anyone near Keene, NH > that is building or flying this critter? > > Thanks, > Wayne > ________________________________________________________________________________
Date: Feb 28, 2008
Wayne-- I see Mike already replied with some. In addition There is another couple under construction in Moultonboro, and Ossipee. If you'd like a ride or cl oser inspection of a completed one ,give me a call and we can arrange somet hing George May 601XL 912s Kingston NH 603-642-8694 Date: Thu, 28 Feb 2008 14:55:16 -0500From: mgvalentine(at)gmail.comTo: zenith- list(at)matronics.comSubject: Re: Zenith-List: Any Zodiac Builders near SE New HampshireWayne - I am in Contoocook - tail and wings done, fuse in progres s.Ernie is in Merrimack. Sorry Ernie, I can't remember your last name!! E rnie is probably about to pass me in progress. He will likely chime in soo n.Roger Pritchard is in Nashua - Plane and Corvair engine pretty much done - putting on wings somewhere.George May is done and flying in Kingston (pla ne in Elliot, ME)Everyone should be viewable through the web site John Read provided. Email or call me directly for more info.Cheers, Michael Valenti ne603-746-2166 On Thu, Feb 28, 2008 at 12:54 PM, Wayne Aho wrote: I am considering building a Zodiac 601XL. Is there anyone near Keene, NH t hat is building or flying this critter? Thanks, Wayne _________________________________________________________________ Connect and share in new ways with Windows Live. http://www.windowslive.com/share.html?ocid=TXT_TAGHM_Wave2_sharelife_0120 08 ________________________________________________________________________________
Date: Feb 28, 2008
I ran into the same problem and talked with Mark at Jabiru. We discussed at length and then I just made an extension bracket that moved the throttle cable to the OUTSIDE of the carbie connection point instead of the inside as directed by Jabiru. It worked great! There was no bend in the throttle cable since it lined up directly to the carb while sliding along side the nose gear bracket. It is now smooth and effortless. If I can help, I can send the same pictures that I sent Mark for his edification. But the Choke cable is somewhat 'S' bent so I might have to make one for that also. I will know in the next couple of days. Wish me luck. Dave Nixon CH 601 XL 3300 (N 107 R) 99% done with 5% to go. Going to Weight and Balance in the next day or two Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166801#166801 ________________________________________________________________________________
Date: Feb 28, 2008
Hey George.....could yah fly up to Michigan and give me a ride too? LOL......just kidding...... Larry H george may wrote: .hmmessage P { margin:0px; padding:0px } body.hmmessage { FONT-SIZE: 10pt; FONT-FAMILY:Tahoma } Wayne-- I see Mike already replied with some. In addition There is another couple under construction in Moultonboro, and Ossipee. If you'd like a ride or closer inspection of a completed one ,give me a call and we can arrange something George May 601XL 912s Kingston NH 603-642-8694 --------------------------------- Date: Thu, 28 Feb 2008 14:55:16 -0500 From: mgvalentine(at)gmail.com Subject: Re: Zenith-List: Any Zodiac Builders near SE New Hampshire Wayne - I am in Contoocook - tail and wings done, fuse in progress. Ernie is in Merrimack. Sorry Ernie, I can't remember your last name!! Ernie is probably about to pass me in progress. He will likely chime in soon. Roger Pritchard is in Nashua - Plane and Corvair engine pretty much done - putting on wings somewhere. George May is done and flying in Kingston (plane in Elliot, ME) Everyone should be viewable through the web site John Read provided. Email or call me directly for more info. Cheers, Michael Valentine 603-746-2166 On Thu, Feb 28, 2008 at 12:54 PM, Wayne Aho wrote: I am considering building a Zodiac 601XL. Is there anyone near Keene, NH that is building or flying this critter? Thanks, Wayne arget=_blank>http://www.matronics.com/Navigator?Zenith-List p://forums.matronics.com blank>http://www.matronics.com/contribution --------------------------------- Connect and share in new ways with Windows Live. Get it now! --------------------------------- ________________________________________________________________________________
Date: Feb 28, 2008
Were those weight wet or dry? How much oil does the Jab hold? (6+lb/gallon) I am installing the Continental O-200 in my 601 XL, the people at Teledyne Mattituck told me the O-200 is 215 pounds with accessories, the Jabiru is listed at 180 with accessories. Clyde Barcus 601 XL, Continental Powered ----- Original Message ----- From: "Paul Mulwitz" Sent: Thursday, February 28, 2008 12:04 PM Subject: Re: Zenith-List: Re: 601 XL Empty Weight > > Hi Don, > > The AMD web site shows 770 pounds empty weight for the factory built XL. > I believe this model includes the Continental O-200. > > My informal examination of many LSA specs seems to indicate using an O-200 > or O-235 adds around 100 pounds to your empty weight compared to a Rotax > or Jabiru installation. > > Paul > XL fuselage > > > At 08:35 AM 2/28/2008, you wrote: > >>Hello >>I was thinking about the same thing. What would the weight [approx] be >>with a 0200 engine installed? >>Thanks Don >> >> > > > Dave Downey Harleysville (SE) PA 100 HP Corvair --------------------------------- ________________________________________________________________________________
Subject: Re: 2000 hours
Date: Feb 28, 2008
Alright, be patient with me as I am fairly new to all of this but.... Am I crazy for considering an 0-200 overhaul myself (and hopefully with the guidance of an A & P). I'm considering a corvair conversion as well, and I really love the Jab. I understand that I can get a midtime Continental for about 8,000 and rebuild a Corvair for slightly less. The Jab unfortunately will knock your socks of at 18000 these days. Aside from the $ I would like to gain the experience and knowledge from rebuilding my own engine. I am literally shocked that I can find a thousand times more information on how to convert your corvair to an aircraft engine than simply how to perform your own overhaul on an o-200. Any sources for information? Here is my logic: I am contemplating my own Corvair rebuild. I believe a Corvair conversion to be slightly less reliable than a Continental or Lycosaur. Corvair builders please dont consider this and insult as I will openly acknowledge that I am a newbie. My beliefs are just that... The beliefs of a newbie. If I am contemplating my own auto conversion, then why shouldn't I consider an o-200 overhaul myself? Something in my head just keeps telling me that an o-200 is 1940's technology, using some common sense, having patience and the right tools with some guidance and an overhaul manual that an overhaul should be accomplishable by anybody that would also be a candidate for a corvair rebuild. In any case even if I purchase a mid time Cont I sure would like someone with more experience than I to perform inspections on the darn thing. -------- One Rivet at a Time! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166860#166860 ________________________________________________________________________________
Date: Feb 28, 2008
I was wrestling with the same problem, Continental or Lycoming, about 2 years ago. Bought the WW Corvair manual (flycorvair.com) then made a trip to SnF to meet and talk to him. Spent a day at his shop also and that was all it took to convince me that the Corvair engine would meet my needs. I fly VFR and smooth air for the most part so it should work well and save me some serious money. -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166868#166868 ________________________________________________________________________________
Date: Feb 28, 2008
Thats what Cleco's are for. Drill and pin the ailerons, put in the cables, belcrank and trim wire, remove and store. Chris.. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166882#166882 ________________________________________________________________________________
Subject: Jabiru ram-air ducts
Date: Feb 29, 2008
I am at the point of installing the ram-air ducts on my Jabiru 3300. The right-hand duct went on without too many problems (that couldn't be solved with some colourful cussing!). The left-hand duct is causing headaches. because of the offset of the cylinders, the rear cylinder on the left is very close to the engine mounting plate and I cannot see how I can get the duct in. On the right, the duct fits between the 5th. and 6th. fins (counting out from the crankcase). There's no way I can get the left duct that close. The fibreglass is recessed to clear the engine mount, but only once it is in place! Am I being dumb? (don't answer that!). How did other Jab. users solve the problem? Hoping someone can help (they always have in the past!) Dave Johnson 601XL ________________________________________________________________________________
Date: Feb 29, 2008
From: Roger Pritchard <rogers_pritchard(at)yahoo.com>
Wayne, I kit built an XL in a one car garage in Nashua and am now rigging the ailerons and flaps at my brother in laws business in Hooksett. Feel free to call me at 496-7542 about the building process or if you want to see it. Roger Wayne Aho wrote: I am considering building a Zodiac 601XL. Is there anyone near Keene, NH that is building or flying this critter? Thanks, Wayne --------------------------------- Be a better friend, newshound, and --------------------------------- ________________________________________________________________________________
Subject: Re: Jabiru ram-air ducts
Date: Feb 29, 2008
Dave, I remember having to play with this left duct a little bit, but it was not a show-stopper, at least on my engine. Once I found which fins the aft part seemed to like the best, I put a spot of magic marker on the first visible fin so I can put it back the next time. There was no one spot that worked perfectly. I still have to push and shove a bit. If it was any worse, as it appears in your case, I guess I would try to heat the duct and re-form it a bit. I do not remember if it made the Homebuilthelp.com video or not, but Mark at Jabiru USA suggested reinforcing the holes in the ducts that you will be drilling for the valve cover cap screws. I made a piece small aluminum sheet and JB weld epoxied it in place. I have not run yet so this is all theory to me at this point.. Good luck, -------- David Gallagher 601 XL, tail & wings completed and fueslage pretty well done. Working engine and electrical systems. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166903#166903 ________________________________________________________________________________
Date: Feb 29, 2008
Wayne, I built most of my Zenvair 601XL in a single car garage in Nashua and am now rigging the ailerons and flaps at my wife and brother-in-laws business in Hooksett. Call me 406-7542 if you want to talk or see it. Roger Wayne Aho wrote: I am considering building a Zodiac 601XL. Is there anyone near Keene, NH that is building or flying this critter? Thanks, Wayne --------------------------------- Be a better friend, newshound, and --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Feb 29, 2008
I bought a run out O-200 (With logbooks) from Wentworth for $2,800 with a replacement guarantee for any major component that cannot be returned to service. I was also given the name of a reputable company that rebuilds cylinders, the cost for best case was $325.00 each and the worst case of $600.00 each. The bottom end of the O-200 has a very good reputation for strength and reliability, check out a photo of the split case on the internet and you will see it has a very large front bearing. Parts, repair manuals, and videos showing how to rebuild the O-200 are readily available. I was told by Aircraft mechanics it is a very simple engine to rebuild compared to the auto engines I have rebuilt. I was going to rebuild it myself but I met a mechanic at the EAA Chapter I belong to and he agreed to work with me for a reasonable price, of course I will be doing the grunt work and the engine will remain certified. If one prefers new, the bottom end kit from Continental is $932.18, the total for 4 new cylinders in the new style comes to $4068.62 with no exchange. Originally I was going with Corvair but my family made it clear they would not fly with me unless I put a Continental or Lycoming in it, that is the reason for my change of heart. I hope that helps: Clyde Barcus 601 XL, Continental Powered ----- Original Message ----- From: "MHerder" <michaelherder(at)beckgroup.com> Sent: Thursday, February 28, 2008 9:27 PM Subject: Zenith-List: Re: 2000 hours > > Alright, be patient with me as I am fairly new to all of this but.... Am > I crazy for considering an 0-200 overhaul myself (and hopefully with the > guidance of an A & P). I'm considering a corvair conversion as well, and > I really love the Jab. I understand that I can get a midtime Continental > for about 8,000 and rebuild a Corvair for slightly less. The Jab > unfortunately will knock your socks of at 18000 these days. Aside from > the $ I would like to gain the experience and knowledge from rebuilding > my own engine. I am literally shocked that I can find a thousand times > more information on how to convert your corvair to an aircraft engine than > simply how to perform your own overhaul on an o-200. Any sources for > information? > > Here is my logic: > > I am contemplating my own Corvair rebuild. I believe a Corvair conversion > to be slightly less reliable than a Continental or Lycosaur. Corvair > builders please dont consider this and insult as I will openly acknowledge > that I am a newbie. My beliefs are just that... The beliefs of a newbie. > > If I am contemplating my own auto conversion, then why shouldn't I > consider an o-200 overhaul myself? > > Something in my head just keeps telling me that an o-200 is 1940's > technology, using some common sense, having patience and the right tools > with some guidance and an overhaul manual that an overhaul should be > accomplishable by anybody that would also be a candidate for a corvair > rebuild. > > In any case even if I purchase a mid time Cont I sure would like someone > with more experience than I to perform inspections on the darn thing. > > -------- > One Rivet at a Time! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=166860#166860 > > > ________________________________________________________________________________
Date: Feb 29, 2008
Hi Dave, I did notice that Zenith does not have the empty weight of the 0-200, I am trying to find the best engine to useful load, the Jab just cost to much, and would like to know the empty weight on yours when it is installed. Thanks Tom David Downey wrote: Were those weight wet or dry? How much oil does the Jab hold? (6+lb/gallon) I am installing the Continental O-200 in my 601 XL, the people at Teledyne Mattituck told me the O-200 is 215 pounds with accessories, the Jabiru is listed at 180 with accessories. Clyde Barcus 601 XL, Continental Powered ----- Original Message ----- From: "Paul Mulwitz" Sent: Thursday, February 28, 2008 12:04 PM Subject: Re: Zenith-List: Re: 601 XL Empty Weight > > Hi Don, > > The AMD web site shows 770 pounds empty weight for the factory built XL. --------------------------------- ________________________________________________________________________________
Subject: Re: Routing choke and throttle cables
Date: Feb 29, 2008
I tried to post pix without any success. Sorry! If you want, I can send them to you directly via your e-mail address. Dave Nixon CH 601 XL jabiru 3300 Couple of man hours left to W&B and liftoff. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166942#166942 ________________________________________________________________________________
Date: Feb 29, 2008
Send them to the Matronics photoshare. Or send them to me and I'll send them. Attachments sent to the list (even if they do get through) don't persist very long in the archived e-mail messages. http://www.matronics.com/photoshare/ -- Craig -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Dave Nixon Sent: Friday, February 29, 2008 1:48 PM Subject: Zenith-List: Re: Routing choke and throttle cables I tried to post pix without any success. Sorry! If you want, I can send them to you directly via your e-mail address. Dave Nixon CH 601 XL jabiru 3300 Couple of man hours left to W&B and liftoff. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166942#166942 ________________________________________________________________________________
Subject: Painting Experience
Date: Feb 29, 2008
I ll say now that I m having a "happy ending" but............... Here is how my past week went with the AcryGlo Aircraft paint. AcryGlo is the best paint I ve ever used. It should be because three gallons set me back $966.00. I like polished aluminum airplanes. My friends have polished aircraft and man their beautiful. But, I m lazy and didnt want to do the steps required to make my 601 shine.. So. I opted to paint... It all started out as a disaster. I cleaned the aluminum with "aluma prep. Applied Alodine to get that golden brown/etched base. I applied epoxy two part metal primer then waited two weeks for the cure. Starting with the rudder, I laid it down on my table in the spray booth I scuffed the primmer to have excellent "bite" for the base coats. Vaccuumed all the dust and used tack cloths.. I "fogged on three coats and everything looked super. After the perfect paint job dried, I flipped the rudder over.. Proceeded to do the same steps as on the first side. Holy Smolly. Pin holes up the Kazoo!. I bet I had one thousand small holes in the paint... Thinking I d let it dry and then sand,,, but I m lazy and used reducer to wipe off the mess... I changed paint guns. I was using a HVLP gun from Harbor Freight but went back to my ol trusty "standard" spray gun... This time I reduced the paint with reducer by 25%. Well to make this short....Its working out very nice. Not totally professional but close... Its much more work than I thought it would be to paint.... I might, should have polished and then gone flyin... I guess thats how we learn, aint it ?? SW .. ________________________________________________________________________________
Subject: Kitplanes Article
Date: Feb 29, 2008
I have an article in the April Kitplanes magazine which some of you might find interesting. Chuck D. ________________________________________________________________________________
Subject: Second thoughts
Date: Feb 29, 2008
All- There has to be a source for these plugs. The wing position lights that I bought used from Wentworth's that came off a '50s Bonanza has them. You can tell everything's original. Good enough for Beech, good enough for me. Bill ----- Original Message ----- From: Bill Naumuk Sent: Wednesday, February 27, 2008 8:27 PM Subject: Where? All- Where can I get aviation quality connectors such as those in the picture? These came from the local hardware store and I want to make sure I'm using the best. No listing on ACS. Must have them to enable me to easily service my belly strobe. Not my best photography! Thanks. Bill Naumuk Townville, Pa. HDS Fuse/Corvair ________________________________________________________________________________
Date: Feb 29, 2008
Subject: Re: Painting Experience
Hey Steve, My brother in law owns an RV painting shop. They paint the really expensive units ($500,000 and up). He was asking me if I want to paint my XL or polish it out. I told him I really liked the polished look as you do, but I didn't want to have to keep buffing and buffing to keep it up. He told me he would help me buff it out and then he would put on several layers of "clear coat" for me. He said that it locks up the aluminum and will never need polishing again. I LIKE that idea! I'm still not sure if I want to paint color or not. Maybe a mixture of both. When the time comes, my brother in law is going to sketch out some really great looking paint schemes for me. He does really great work. He painted Randy Travis's motorhome for him (I think it was him). It looked great - He does a lot of airbrush work too. He's willing to do all of it for me "just for fun".......he must like me or something. Larry steve wrote: I ll say now that I m having a "happy ending" but............... Here is how my past week went with the AcryGlo Aircraft paint. AcryGlo is the best paint I ve ever used. It should be because three gallons set me back $966.00. I like polished aluminum airplanes. My friends have polished aircraft and man their beautiful. But, I m lazy and didnt want to do the steps required to make my 601 shine.. So. I opted to paint... It all started out as a disaster. I cleaned the aluminum with "aluma prep. Applied Alodine to get that golden brown/etched base. I applied epoxy two part metal primer then waited two weeks for the cure. Starting with the rudder, I laid it down on my table in the spray booth I scuffed the primmer to have excellent "bite" for the base coats. Vaccuumed all the dust and used tack cloths.. I "fogged on three coats and everything looked super. After the perfect paint job dried, I flipped the rudder over.. Proceeded to do the same steps as on the first side. Holy Smolly. Pin holes up the Kazoo!. I bet I had one thousand small holes in the paint... Thinking I d let it dry and then sand,,, but I m lazy and used reducer to wipe off the mess... I changed paint guns. I was using a HVLP gun from Harbor Freight but went back to my ol trusty "standard" spray gun... This time I reduced the paint with reducer by 25%. Well to make this short....Its working out very nice. Not totally professional but close... Its much more work than I thought it would be to paint.... I might, should have polished and then gone flyin... I guess thats how we learn, aint it ?? SW .. --------------------------------- ________________________________________________________________________________
Date: Feb 29, 2008
I second Dave Gallagher's advice regarding a CB for the trim. The RAC instructions advise a 2amp fuse or breaker so buy a breaker that can be shut off if the problem arises. That's what I did as well. Dred ________________________________________________________________________________
Date: Feb 29, 2008
Does your wife have an unmarried sister by any chance? Hanss Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166996#166996 ________________________________________________________________________________
From: "gpjann1(at)netzero.net" <gpjann1(at)netzero.net>
Date: Feb 29, 2008
The main difference between a Corvair and O-200 are: =2E. starter, alternator, fuel pump =2E. intake manifold =2E. weight _____________________________________________________________ Click now to find a divorce attorney near you! http://thirdpartyoffers.netzero.net/TGL2221/fc/Ioyw6i4vCQDV3zIZDfpddP0js ZtYPxvW4vhgXmzRYXCX5BEderKl5I/ ________________________________________________________________________________
Date: Feb 29, 2008
Kitplanes did an article on polishing in November last year ("Dare To Be Bare"). This is what it had to say on coatings: "When the Nuvite factory was asked about protective coatings, the recommendation was, "Use nothing." There are two reasons for this. Consider that you just worked like crazy to get a slick surface. If you were going to paint it, you'd be roughing it up to get the paint to stick, so it hardly makes sense to expect a coating to bond to a surface that was intentionally made smooth. That means that when part of the top coat comes loose, as it eventually will, it's going to look different than the adjacent area. In turn, that means that you have to remove the remainder of the top coat, which will entail damaging the aluminum. Go to jail. Do not pass Go. The second reason is closely related to the first. You've seen those super-brilliant Airstream trailers. The older ones had nothing applied, but with time and customer demand, the factory shifted to coating. The Airstream cognoscenti claim they can spot a newer trailer, because the coating eventually gets cloudy and it just doesn't shine the way the older ones do." -- Craig From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Larry H Sent: Friday, February 29, 2008 4:10 PM Subject: Re: Zenith-List: Painting Experience Hey Steve, My brother in law owns an RV painting shop. They paint the really expensive units ($500,000 and up). He was asking me if I want to paint my XL or polish it out. I told him I really liked the polished look as you do, but I didn't want to have to keep buffing and buffing to keep it up. He told me he would help me buff it out and then he would put on several layers of "clear coat" for me. He said that it locks up the aluminum and will never need polishing again. I LIKE that idea! I'm still not sure if I want to paint color or not. Maybe a mixture of both. When the time comes, my brother in law is going to sketch out some really great looking paint schemes for me. He does really great work. He painted Randy Travis's motorhome for him (I think it was him). It looked great - He does a lot of airbrush work too. He's willing to do all of it for me "just for fun".......he must like me or something. Larry steve wrote: I ll say now that I m having a "happy ending" but............... Here is how my past week went with the AcryGlo Aircraft paint. AcryGlo is the best paint I ve ever used. It should be because three gallons set me back $966.00. I like polished aluminum airplanes. My friends have polished aircraft and man their beautiful. But, I m lazy and didnt want to do the steps required to make my 601 shine.. So. I opted to paint... It all started out as a disaster. I cleaned the aluminum with "aluma prep. Applied Alodine to get that golden brown/etched base. I applied epoxy two part metal primer then waited two weeks for the cure. Starting with the rudder, I laid it down on my table in the spray booth I scuffed the primmer to have excellent "bite" for the base coats. Vaccuumed all the dust and used tack cloths.. I "fogged on three coats and everything looked super. After the perfect paint job dried, I flipped the rudder over.. Proceeded to do the same steps as on the first side. Holy Smolly. Pin holes up the Kazoo!. I bet I had one thousand small holes in the paint... Thinking I d let it dry and then sand,,, but I m lazy and used reducer to wipe off the mess... I changed paint guns. I was using a HVLP gun from Harbor Freight but went back to my ol trusty "standard" spray gun... This time I reduced the paint with reducer by 25%. Well to make this short....Its working out very nice. Not totally professional but close... Its much more work than I thought it would be to paint.... I might, should have polished and then gone flyin... I guess thats how we learn, aint it ________________________________________________________________________________
Date: Feb 29, 2008
clyde-- You might want to check the regs again. If you hang that nice rebuilt ce rtified engine on your experimental plane, it is no longer certified. George May 601XL 912s> From: barcusc(at)comcast.net> To: zenith-list(at)matronics.com> Subj ect: Re: Zenith-List: Re: 2000 hours> Date: Fri, 29 Feb 2008 09:00:15 -0600 > > I bought a run out O-200 (With logbooks) from Wentworth for $2,800 with a > replacement guarantee for any major component that cannot be returned to > service. I was also given the name of a reputable company that rebuild s > cylinders, the cost for best case was $325.00 each and the worst case o f > $600.00 each. The bottom end of the O-200 has a very good reputation fo r > strength and reliability, check out a photo of the split case on the > internet and you will see it has a very large front bearing. Parts, repair > manuals, and videos showing how to rebuild the O-200 are readily availabl e. > I was told by Aircraft mechanics it is a very simple engine to rebuild > compared to the auto engines I have rebuilt. I was going to rebuild it > myself but I met a mechanic at the EAA Chapter I belong to and he agreed t o > work with me for a reasonable price, of course I will be doing the grun t > work and the engine will remain certified.> If one prefers new, the bot tom end kit from Continental is $932.18, the > total for 4 new cylinders in the new style comes to $4068.62 with no > exchange.> Originally I was goin g with Corvair but my family made it clear they would > not fly with me unl ess I put a Continental or Lycoming in it, that is the > reason for my chan ge of heart.> > I hope that helps:> > Clyde Barcus> 601 XL, Continental Pow ered> > ----- Original Message ----- > From: "MHerder" <michaelherder@beckg roup.com>> To: > Sent: Thursday, February 28, 20 08 9:27 PM> Subject: Zenith-List: Re: 2000 hours> > > > --> Zenith-List mes sage posted by: "MHerder" > >> > Alright, be p atient with me as I am fairly new to all of this but.... Am > > I crazy for considering an 0-200 overhaul myself (and hopefully with the > > guidance of an A & P). I'm considering a corvair conversion as well, and > > I reall y love the Jab. I understand that I can get a midtime Continental > > for a bout 8,000 and rebuild a Corvair for slightly less. The Jab > > unfortunate ly will knock your socks of at 18000 these days. Aside from > > the $ I wou ld like to gain the experience and knowledge from rebuilding > > my own eng ine. I am literally shocked that I can find a thousand times > > more infor mation on how to convert your corvair to an aircraft engine than > > simply how to perform your own overhaul on an o-200. Any sources for > > informat ion?> >> > Here is my logic:> >> > I am contemplating my own Corvair rebuil d. I believe a Corvair conversion > > to be slightly less reliable than a C ontinental or Lycosaur. Corvair > > builders please dont consider this and insult as I will openly acknowledge > > that I am a newbie. My beliefs are just that... The beliefs of a newbie.> >> > If I am contemplating my own au to conversion, then why shouldn't I > > consider an o-200 overhaul myself?> >> > Something in my head just keeps telling me that an o-200 is 1940's > > technology, using some common sense, having patience and the right tools > > with some guidance and an overhaul manual that an overhaul should be > > accomplishable by anybody that would also be a candidate for a corvair > > rebuild.> >> > In any case even if I purchase a mid time Cont I sure woul d like someone > > with more experience than I to perform inspections on th e darn thing.> >> > --------> > One Rivet at a Time!> >> >> >> >> > Read th is topic online here:> >> > http://forums.matronics.com/viewtopic.php?p=1 ================> > > _________________________________________________________________ Need to know the score, the latest news, or you need your Hotmail=AE-get yo ur "fix". http://www.msnmobilefix.com/Default.aspx ________________________________________________________________________________
Subject: Re: Second thoughts
Date: Feb 29, 2008
Take a look at radio shack Tim Juhl -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Working on fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167009#167009 ________________________________________________________________________________
Date: Feb 29, 2008
No, sorry. She is the oldest of 4 kids and the other 3 are brothers. Larry hansriet wrote: Does your wife have an unmarried sister by any chance? Hanss Read this topic online here: http://forums.matronics.com/viewtopic.php?p=166996#166996 --------------------------------- ________________________________________________________________________________
Date: Feb 29, 2008
Not really John ----- Original Message ----- From: gpjann1(at)netzero.net To: zenith-list(at)matronics.com Sent: Friday, February 29, 2008 5:31 PM Subject: Zenith-List: Re: 601 XL Empty Weight The main difference between a Corvair and O-200 are: .. starter, alternator, fuel pump .. intake manifold .. weight _____________________________________________________________ Click now to find a divorce attorney near you! ________________________________________________________________________________
Date: Feb 29, 2008
Subject: Re: Firewall Forward fuel and oil lines
Hi Doug, My kit and FWF came with "Garden variety" rubber hose. No, not garden hose, but normal automotive fuel hose. It has a 5/8 inch outside diameter and 1/4 inch I.D. It is all covered with "fire sleeve" in the area forward of the firewall. You can order that stuff from A/S. Good luck, Paul XL fuselage At 11:54 AM 2/29/2008, you wrote: >What flavour of hoses are commonly being used for >these fuel and oil line on the Zenith products? I >have been looking at the Aeroquip hoses listed on >Aircraft Spruce but don't want to spend $50-$100 on >hoses and not get the right ones. ________________________________________________________________________________
Subject: RE: Zenith-List Digest: 0-200 overhaul
Date: Feb 29, 2008
I overhauled my lyc 0-235 with the help of an A&P. I purchased the overhaul manual and parts manual, check this link to e-bay for listings for the 0-200 manuals; http://motors.search.ebay.com/_eBay-Motors_W0QQsacatZ6000QQsassZbigbluebook I found rebuilding the 0-235 to be very similar to a VW engine, except for lockwiring the fasteners. Having an A&P check your work is always a good idea. There are a lot of good quality mid-time engines available as well, but be very careful, there are also a lot of improperly stored engines that have been out of service for years. Craig S. N601XS, 601xl 0-235 lyc Alright, be patient with me as I am fairly new to all of this but.... Am I crazy for considering an 0-200 overhaul myself (and hopefully with the guidance of an A & P). ----------------------------------------- ************************************************** This e-mail and any of its attachments may contain Exelon Corporation proprietary information, which is privileged, confidential, or subject to copyright belonging to the Exelon Corporation family of Companies. This e-mail is intended solely for the use of the individual or entity to which it is addressed. If you are not the intended recipient of this e-mail, you are hereby notified that any dissemination, distribution, copying, or action taken in relation to the contents of and attachments to this e-mail is strictly prohibited and may be unlawful. If you have received this e-mail in error, please notify the sender immediately and permanently delete the original and any copy of this e-mail and any printout. Thank You. ************************************************** ________________________________________________________________________________
Date: Feb 29, 2008
Right or wrong my left wing is riveted and hanging from the ceiling with straps. All the plumbing and electrical is in and functioning. -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167039#167039 Attachments: http://forums.matronics.com//files/aileronflap_005_959.jpg http://forums.matronics.com//files/hangwing_003_157.jpg ________________________________________________________________________________
Date: Feb 29, 2008
Actually yes. But the sister is A looney toon. Extreamly NUTS! ----- Original Message ----- From: "hansriet" <hansinla(at)mac.com> Sent: Friday, February 29, 2008 5:55 PM Subject: Zenith-List: Re: Painting Experience > > Does your wife have an unmarried sister by any chance? > > Hanss > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=166996#166996 > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 29, 2008
Hi George, I did check, the engine stands alone when it comes to certification. However, to keep the certification I would not be able to do anything but certain types of maintenance myself, it would require a certified mechanic. One other point, it is possible to get 25 hours instead of the 40 hour restriction. Clyde Barcus 601 XL, Continental Powered ----- Original Message ----- From: george may To: zenith-list(at)matronics.com Sent: Friday, February 29, 2008 6:48 PM Subject: RE: Zenith-List: Re: 2000 hours clyde-- You might want to check the regs again. If you hang that nice rebuilt certified engine on your experimental plane, it is no longer certified. George May 601XL 912s > From: barcusc(at)comcast.net > To: zenith-list(at)matronics.com > Subject: Re: Zenith-List: Re: 2000 hours > Date: Fri, 29 Feb 2008 09:00:15 -0600 > > > I bought a run out O-200 (With logbooks) from Wentworth for $2,800 with a > replacement guarantee for any major component that cannot be returned to > service. I was also given the name of a reputable company that rebuilds > cylinders, the cost for best case was $325.00 each and the worst case of > $600.00 each. The bottom end of the O-200 has a very good reputation for > strength and reliability, check out a photo of the split case on the > internet and you will see it has a very large front bearing. Parts, repair > manuals, and videos showing how to rebuild the O-200 are readily available. > I was told by Aircraft mechanics it is a very simple engine to rebuild > compared to the auto engines I have rebuilt. I was going to rebuild it > myself but I met a mechanic at the EAA Chapter I belong to and he agreed to > work with me for a reasonable price, of course I will be doing the grunt > work and the engine will remain certified. > If one prefers new, the bottom end kit from Continental is $932.18, the > total for 4 new cylinders in the new style comes to $4068.62 with no > exchange. > Originally I was going with Corvair but my family made it clear they would > not fly with me unless I put a Continental or Lycoming in it, that is the > reason for my change of heart. > > I hope that helps: > > Clyde Barcus > 601 XL, Continental Powered > > ----- Original Message ----- > From: "MHerder" <michaelherder(at)beckgroup.com> > To: > Sent: Thursday, February 28, 2008 9:27 PM > Subject: Zenith-List: Re: 2000 hours > > > > > > Alright, be patient with me as I am fairly new to all of this but.... Am > > I crazy for considering an 0-200 overhaul myself (and hopefully with the > > guidance of an A & P). I'm considering a corvair conversion as well, and > > I really love the Jab. I understand that I can get a midtime Continental > > for about 8,000 and rebuild a Corvair for slightly less. The Jab > > unfortunately will knock your socks of at 18000 these days. Aside from > > the $ I would like to gain the experience and knowledge from rebuilding > > my own engine. I am literally shocked that I can find a thousand times > > more information on how to convert your corvair to an aircraft engine than > > simply how to perform your own overhaul on an o-200. Any sources for > > information? > > > > Here is my logic: > > > > I am contemplating my own Corvair rebuild. I believe a Corvair conversion > > to be slightly less reliable than a Continental or Lycosaur. Corvair > > builders please dont consider this and insult as I will openly acknowledge > > that I am a newbie. My beliefs are just that... The beliefs of a newbie. > > > > If I am contemplating my own auto conversion, then why shouldn't I > > consider an o-200 overhaul myself? > > > > Something in my head just keeps telling me that an o-200 is 1940's > > technology, using some common sense, having patience and the right tools > > with some guidance and an overhaul manual that an overhaul should be > > accomplishable by anybody that would also be a candidate for a corvair > > rebuild. > > > > In any case even if I purchase a mid time Cont I sure would like someone > > with more experience than I to perform inspections on the darn thing. > > > > -------- > > One Rivet at a Time! > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=166860#166860 > > > > > > > > > > > > > > > > > > > > > > &g================= > > > ------------------------------------------------------------------------- ----- Need to know the score, the latest news, or you need your Hotmail=AE-get your "fix". Check it out. ________________________________________________________________________________
Date: Feb 29, 2008
I was talking to one of the A&P instructors at MTSU a couple of days ago. We were talking about the 40 hour restriction period for homebuilts. He spoke up and said "25, if you go with a certified engine". I had forgotten that, as well. Clyde: We need to touch base. Haven't heard about you project in a while. Kevin Bonds Clyde Barcus wrote: > Hi George, > > I did check, the engine stands alone when it comes to certification. > However, to keep the certification I would not be able to do anything > but certain types of maintenance myself, it would require a certified > mechanic. One other point, it is possible to get 25 hours instead of > the 40 hour restriction. > > Clyde Barcus > 601 XL, Continental Powered > > ----- Original Message ----- > *From:* george may > *To:* zenith-list(at)matronics.com > *Sent:* Friday, February 29, 2008 6:48 PM > *Subject:* RE: Zenith-List: Re: 2000 hours > > clyde-- > You might want to check the regs again. If you hang that nice > rebuilt certified engine on your experimental plane, it is no > longer certified. > > ________________________________________________________________________________
Date: Feb 29, 2008
Hey guys... not much homework tonight... missed you all! E-LSAs are eligible for a 5 hour test phase as opposed to 25 or 40. Of course, for the 5 or 25 to apply, the engine/prop combination must be a previously certified combination, not just a certified engine. As to the 0-200A with ECI cylinders, my IA needed a full set of 030 push rods to meet lashing specs after an overhaul of my 1972 C150L's TCM, even with a brand new camshaft. Is ECI doing something wrong? As to: "You might want to check the regs again. If you hang that nice rebuilt certified engine on your experimental plane, it is no longer certified." But that does not take away from the fact that the engine was previously certified with various prop combinations. For an E-LSA, however, if you use a certified engine, even if the prop is not certified or was never certified in combination with the engine, the E-LSA repairman license would not allow you to perform a "major repair/alteration" on the "no longer certified" engine since it was originally "produced under an FAA approval." Does that same limitation apply to the repairman certificate on an amateur built? Someone mentioned that I am in this month's Sport Aviation, I did not get my copy yet, were they nice to me? I can find the issue on line but not all articles have clickable links. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167068#167068 ________________________________________________________________________________
Subject: O-200 Questions & Concerns
Date: Mar 01, 2008
Re: Continental O-200 Since my post there have been a few comments and questions on certification or loss of certification along with other concerns. To help eliminate confusion I have decided to put together a list of questions and call EAA Headquarters for clarification. Because I am not an expert on anything related to flying, I decided to join the EAA to get good accurate information so I could lower the risk of making expensive or dangerous mistakes. I plan on getting this done on Monday, after discussing this with someone qualified in this area I will post their answers. If anyone has a question (Related to this discussion) they would like answered, email me and I will add it to the list. Regards: Clyde Barcus 601 XL, Continental Powered Wings, Tail & Engine Complete Working on Fuselage ________________________________________________________________________________
Date: Mar 01, 2008
Unless "things" have changed.... And they do sometimes, IF your use, lets say an 0-200 in your homebuilt, all needed is to remove the data plate. Removing the plate puts the engine in the experimental catagory and then the work / inspections can be done by the "homebuilder"... SW ----- Original Message ----- From: "Sabrina" <chicago2paris(at)msn.com> Sent: Saturday, March 01, 2008 12:56 AM Subject: Zenith-List: Re: 2000 hours > > Hey guys... not much homework tonight... missed you all! > > E-LSAs are eligible for a 5 hour test phase as opposed to 25 or 40. Of > course, for the 5 or 25 to apply, the engine/prop combination must be a > previously certified combination, not just a certified engine. > > As to the 0-200A with ECI cylinders, my IA needed a full set of 030 push > rods to meet lashing specs after an overhaul of my 1972 C150L's TCM, even > with a brand new camshaft. Is ECI doing something wrong? > > As to: "You might want to check the regs again. If you hang that nice > rebuilt certified engine on your experimental plane, it is no longer > certified." But that does not take away from the fact that the engine > was previously certified with various prop combinations. > > For an E-LSA, however, if you use a certified engine, even if the prop is > not certified or was never certified in combination with the engine, the > E-LSA repairman license would not allow you to perform a "major > repair/alteration" on the "no longer certified" engine since it was > originally "produced under an FAA approval." > > Does that same limitation apply to the repairman certificate on an amateur > built? > > Someone mentioned that I am in this month's Sport Aviation, I did not get > my copy yet, were they nice to me? I can find the issue on line but not > all articles have clickable links. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=167068#167068 > > > ________________________________________________________________________________
Date: Mar 01, 2008
doesn't that 25 hours need to be a certified engine/prop combination? I thought as soon as you put a different prop on it you were back to 40 hours - at least in the olden days... Clyde Barcus wrote: .hmmessage P { PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; MARGIN: 0px; PADDING-TOP: 0px } BODY.hmmessage { FONT-SIZE: 10pt; FONT-FAMILY: Tahoma } Hi George, I did check, the engine stands alone when it comes to certification. However, to keep the certification I would not be able to do anything but certain types of maintenance myself, it would require a certified mechanic. One other point, it is possible to get 25 hours instead of the 40 hour restriction. Clyde Barcus 601 XL, Continental Powered ----- Original Message ----- From: george may To: zenith-list(at)matronics.com Sent: Friday, February 29, 2008 6:48 PM Subject: RE: Zenith-List: Re: 2000 hours clyde-- You might want to check the regs again. If you hang that nice rebuilt certified engine on your experimental plane, it is no longer certified. George May 601XL 912s > From: barcusc(at)comcast.net > To: zenith-list(at)matronics.com > Subject: Re: Zenith-List: Re: 2000 hours > Date: Fri, 29 Feb 2008 09:00:15 -0600 > > > I bought a run out O-200 (With logbooks) from Wentworth for $2,800 with a > replacement guarantee for any major component that cannot be returned to > service. I was also given the name of a reputable company that rebuilds > cylinders, the cost for best case was $325.00 each and the worst case of > $600.00 each. The bottom end of the O-200 has a very good reputation for > strength and reliability, check out a photo of the split case on the > internet and you will see it has a very large front bearing. Parts, repair > manuals, and videos showing how to rebuild the O-200 are readily available. > I was told by Aircraft mechanics it is a very simple engine to rebuild > compared to the auto engines I have rebuilt. I was going to rebuild it > myself but I met a mechanic at the EAA Chapter I belong to and he agreed to > work with me for a reasonable price, of course I will be doing the grunt > work and the engine will remain certified. > If one prefers new, the bottom end kit from Continental is $932.18, the > total for 4 new cylinders in the new style comes to $4068.62 with no > exchange. > Originally I was going with Corvair but my family made it clear they would > not fly with me unless I put a Continental or Lycoming in it, that is the > reason for my change of heart. > > I hope that helps: > > Clyde Barcus > 601 XL, Continental Powered > > ----- Original Message ----- > From: "MHerder" <michaelherder(at)beckgroup.com> > To: > Sent: Thursday, February 28, 2008 9:27 PM > Subject: Zenith-List: Re: 2000 hours > > > > > > Alright, be patient with me as I am fairly new to all of this but.... Am > > I crazy for considering an 0-200 overhaul myself (and hopefully with the > > guidance of an A & P). I'm considering a corvair conversion as well, and > > I really love the Jab. I understand that I can get a midtime Continental > > for about 8,000 and rebuild a Corvair for slightly less. The Jab > > unfortunately will knock your socks of at 18000 these days. Aside from > > the $ I would like to gain the experience and knowledge from rebuilding > > my own engine. I am literally shocked that I can find a thousand times > > more information on how to convert your corvair to an aircraft engine than > > simply how to perform your own overhaul on an o-200. Any sources for > > information? > > > > Here is my logic: > > > > I am contemplating my own Corvair rebuild. I believe a Corvair conversion > > to be slightly less reliable than a Continental or Lycosaur. Corvair > > builders please dont consider this and insult as I will openly acknowledge > > that I am a newbie. My beliefs are just that... The beliefs of a newbie. > > > > If I am contemplating my own auto conversion, then why shouldn't I > > consider an o-200 overhaul myself? > > > > Something in my head just keeps telling me that an o-200 is 1940's > > technology, using some common sense, having patience and the right tools > > with some guidance and an overhaul manual that an overhaul should be > > accomplishable by anybody that would also be a candidate for a corvair > > rebuild. > > > > In any case even if I purchase a mid time Cont I sure would like someone > > with more experience than I to perform inspections on the darn thing. > > > > -------- > > One Rivet at a Time! > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=166860#166860 > > > > > > > > > > > > > > > > > > > > > > &g================= > > > --------------------------------- Need to know the score, the latest news, or you need your Hotmail-get your "fix". Check it out. href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c Dave Downey Harleysville (SE) PA 100 HP Corvair --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Mar 01, 2008
The weight of my 601xl, Jabiru 3300 with paint and upholstery, ready to fly less fuel came in at 744 lbs. This includes the Dynon D180 and a Dynon D100 for instruments, and a Garmin transponder and Icom A200 radio. I hope this helps! -------- Ron Asbill N601ZX - CH-601 XL Jabiru 3300 Completed and Flying!~ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167117#167117 ________________________________________________________________________________
Date: Mar 01, 2008
Subject: Re: O-200 Questions & Concerns
There is a QBK that was built in California and he hung an O-200. He only had to fly 5 hrs. It may only depend on who inspects it. **************Ideas to please picky eaters. Watch video on AOL Living. (http://living.aol.com/video/how-to-please-your-picky-eater/rachel-campos-duffy/ 2050827?NCID=aolcmp00300000002598) ________________________________________________________________________________
Date: Mar 01, 2008
Yes! Great information. -------- Dale Flying Cessna 170B Building Zenith 601XL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167128#167128 ________________________________________________________________________________
Date: Mar 01, 2008
Bill, You might try West Marine, they have spade disconnects. You could then cover this with heat shrink tubing. Here is a tiny url <http://tiny.cc/GuWX0> http://tiny.cc/GuWX0 Hope this helps. Bill Cribb _____ From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bill Naumuk Sent: Friday, February 29, 2008 3:57 PM Subject: Zenith-List: Second thoughts All- There has to be a source for these plugs. The wing position lights that I bought used from Wentworth's that came off a '50s Bonanza has them. You can tell everything's original. Good enough for Beech, good enough for me. Bill ----- Original Message ----- From: Bill Naumuk <mailto:naumuk(at)alltel.net> Sent: Wednesday, February 27, 2008 8:27 PM Subject: Where? All- Where can I get aviation quality connectors such as those in the picture? These came from the local hardware store and I want to make sure I'm using the best. No listing on ACS. Must have them to enable me to easily service my belly strobe. Not my best photography! Thanks. Bill Naumuk Townville, Pa. HDS Fuse/Corvair ________________________________________________________________________________
Date: Mar 01, 2008
I think you'll find that was under the E-LSA rules which we can no longer take advantage of. LHusky(at)aol.com wrote: > There is a QBK that was built in California and he hung an O-200. He only had to fly 5 hrs. It may only depend on who inspects it. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167146#167146 ________________________________________________________________________________
Subject: Another day another disaster
Date: Mar 01, 2008
So, here I am in the Arizona sun with temperature in the low 80s. I painted my fuselage today and need advise. Advise from experienced painters... The fuselage was primed with a two part epoxy primer (green). Its cured for months and has been scuffed for that extra "bite". In some spots I used Tempo primer from a can. Aircraft Spruce sells the stuff for priming under epoxy paints so I "think" is a good product. Well I see bleeding in some areas and wonder if its the "zinc" type primer? Anyway, what do I need to do ? I assume I let it all cure for a few days and lightly sand and apply one last light coat..???... Any thoughts ?? Thanks Steve ________________________________________________________________________________
Subject: Flying Today - Steep Turns
Date: Mar 01, 2008
Fellow Zen-Builders: Today I went for a flight in my airplane with my instructor and took a photo off the left wing while doing some steep turns at 4,500 feet. Wow that was fun! I spent a few hours up there having a great time. Here's a picture: http://www.cooknwithgas.com/Flying/3_1_2008_Turning.JPG Scott Laughlin www.cooknwithgas.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167166#167166 ________________________________________________________________________________
Subject: drill size for canopy self-tapping screws?
Date: Mar 01, 2008
I'm experimenting with various ways to fasten the canopy to the hoops. The factory approach uses NAS548p6-10 self-tapping screws. But they don't say (plans or photo guide) what size hole to drill in the tubes after the #40 pilot hole through the canopy and the tube. The best information I've been able to find (for a similar screw on McMasters Carr) says a #32 hole. Anyone have any advice? -- Craig ________________________________________________________________________________
Date: Mar 01, 2008
Craig, I drilled w/ #30 for A4 clecos. The screws went in just fine. Jay in Dallas 601XL N2630J "Lil Bruiser" "Craig Payne" wrote: > >I'm experimenting with various ways to fasten the canopy to the hoops. The >factory approach uses NAS548p6-10 self-tapping screws. But they don't say >(plans or photo guide) what size hole to drill in the tubes after the #40 >pilot hole through the canopy and the tube. The best information I've been >able to find (for a similar screw on McMasters Carr) says a #32 hole. Anyone >have any advice? > >-- Craig > > ________________________________________________________________________________
Date: Mar 01, 2008
Subject: Nose Wheel Question
I want to order a nose wheel for my project. I found the same part number that Zenith has, for a lot less at ACS. Now, they have 2 different size bearings. Can anyone tell me the bearing size that comes with the kit, since I will probably order the axle from them. Larry Husky N667H (Reserved) **************Ideas to please picky eaters. Watch video on AOL Living. (http://living.aol.com/video/how-to-please-your-picky-eater/rachel-campos-duffy/ 2050827?NCID=aolcmp00300000002598) ________________________________________________________________________________
Subject: Re: Rudder Cable farings
Date: Mar 01, 2008
I would like to take a moment to express my frustration with this step... I have now spent 3 or more hours fiddling with this damn step. It looks so simple in the manual... I HATE cutting this material. The nylon fairlead material is not as similar to plexiglass as one would think. It splinters, cracks and is generally a miserable material to work with. I guess the same properties of this material that make it a pain in the a$$ also make it durable enough to use as a material that will constantly be being rubbed by a piece of steel cable. OK. I'm done venting. But seriously guys how are you cutting this stuff? I have tried the following tablesaw (kickback safety issues not recommended), router (same), dremmel with cutoff wheel and now I am using a larger pneumatic cutoff wheel which more or less melts and slings pieces of melted plastic all over me and it stinks like hell. There must be a better way. As far as positioning goes I am only drilling two of the holes at this point so that if I need to tweak the location a little I can I'll drill the rest when I actually install rudder and start adjusting controls. I don't think you can truly know if everything is just right until you try to run the cables. If you rivet everything all together and then realize that you should have filed a little more of the fairlead material away then there you are drilling out rivets. I don't know about the rest of you, but I'm tired of drilling out rivets. -------- One Rivet at a Time! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167200#167200 ________________________________________________________________________________
Date: Mar 02, 2008
Cut mine on a bandsaw no problem. You have a bit of flashing to deal with, but it comes off very easily with an exacto knife. Drilling created some flash that needs to be cleaned up with an exacto as well. My method was to: 1) Locate, cut and drill the rudder cable exit fairings first. 2) Clamp the N66 material to the fairing and drill matching holes 3) Rough cut the clecoed assembly (fairing and N66) from the N66 sheet with a bandsaw 4) With everything still clecoed together, use a belt sander, using brief contact and then allowing for a quick cool down and then back at it, to bring the N66 to the same dimension as the fairing. It took me about 5 minutes per fairing to get the N66 cut and sanded to size 5) trim any flashing of the material with a sharp exacto knife. FYI, on the plans it tells you to cut an angled slot in the fairlead material, but I peaked at at fellow builder's quick build fuse and the factory just cuts a slot to match the one machined into the prepunched fuse side. I did the same with a milling machine cutter in a machining vise on a drill press. Detail can be seen on my blog at www.mykitlog.com/paulried/ Hope that helps On Sun, Mar 2, 2008 at 12:22 AM, MHerder wrote: > > I would like to take a moment to express my frustration with this step... > I have now spent 3 or more hours fiddling with this damn step. It looks so > simple in the manual... > > I HATE cutting this material. The nylon fairlead material is not as > similar to plexiglass as one would think. It splinters, cracks and is > generally a miserable material to work with. > > I guess the same properties of this material that make it a pain in the > a$$ also make it durable enough to use as a material that will constantly be > being rubbed by a piece of steel cable. > > OK. I'm done venting. > > But seriously guys how are you cutting this stuff? I have tried the > following tablesaw (kickback safety issues not recommended), router (same), > dremmel with cutoff wheel and now I am using a larger pneumatic cutoff wheel > which more or less melts and slings pieces of melted plastic all over me and > it stinks like hell. There must be a better way. > > As far as positioning goes I am only drilling two of the holes at this > point so that if I need to tweak the location a little I can I'll drill the > rest when I actually install rudder and start adjusting controls. I don't > think you can truly know if everything is just right until you try to run > the cables. If you rivet everything all together and then realize that you > should have filed a little more of the fairlead material away then there you > are drilling out rivets. I don't know about the rest of you, but I'm tired > of drilling out rivets. > > -------- > One Rivet at a Time! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=167200#167200 > > -- Paul Riedlinger cndmovn(at)gmail.com ________________________________________________________________________________
Date: Mar 01, 2008
I cut mine with a bandsaw. George Swinford ----- Original Message ----- From: "MHerder" <michaelherder(at)beckgroup.com> Sent: Saturday, March 01, 2008 9:22 PM Subject: Zenith-List: Re: Rudder Cable farings > > I would like to take a moment to express my frustration with this step... I have now spent 3 or more hours fiddling with this damn step. It looks so simple in the manual... > > I HATE cutting this material. The nylon fairlead material is not as similar to plexiglass as one would think. It splinters, cracks and is generally a miserable material to work with. > > I guess the same properties of this material that make it a pain in the a$$ also make it durable enough to use as a material that will constantly be being rubbed by a piece of steel cable. > > OK. I'm done venting. > > But seriously guys how are you cutting this stuff? I have tried the following tablesaw (kickback safety issues not recommended), router (same), dremmel with cutoff wheel and now I am using a larger pneumatic cutoff wheel which more or less melts and slings pieces of melted plastic all over me and it stinks like hell. There must be a better way. > > As far as positioning goes I am only drilling two of the holes at this point so that if I need to tweak the location a little I can I'll drill the rest when I actually install rudder and start adjusting controls. I don't think you can truly know if everything is just right until you try to run the cables. If you rivet everything all together and then realize that you should have filed a little more of the fairlead material away then there you are drilling out rivets. I don't know about the rest of you, but I'm tired of drilling out rivets. > > -------- > One Rivet at a Time! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=167200#167200 > > > -- 6:32 PM > > ________________________________________________________________________________
Date: Mar 01, 2008
Subject: Re: what if? elevator trim tab runaway
I don't see how a circuit breaker or fuse would help at all if you have run-away trim. By the time you turn off the power to the trim servo, the trim will already be crashed into one end of the travel or the other. Turning off the power just guarantees it will stay there. Fortunately, I have heard reports that it doesn't take super-human strength to overcome full limit trim. Paul XL fuselage At 10:59 AM 2/29/2008, you wrote: >I second Dave Gallagher's advice regarding a CB for the trim. The >RAC instructions advise a 2amp fuse or breaker so buy a breaker that >can be shut off if the problem arises. That's what I did as well. > >Dred > ________________________________________________________________________________
Date: Mar 02, 2008
FWIW: I cut the N66 with a common hacksaw and cleaned up the cut with a simple (Nicholson) file. No problems at all. Jeff Davidson .... But seriously guys how are you cutting this stuff? I have tried the following tablesaw (kickback safety issues not recommended), router (same), dremmel with cutoff wheel and now I am using a larger pneumatic cutoff wheel which more or less melts and slings pieces of melted plastic all over me and it stinks like hell. There must be a better way. ________________________________________________________________________________
Date: Mar 02, 2008
Nylon will usually cut beautifully with a bandsaw and a 4 tpi skip tooth blade. Alternatively, cut a 3/8" hole in a piece of 3/4" or 1" plywood/MDF and screw a sabresaw to the back with a coarse tooth blade mounted and sticking up through the hole - poor man's bandsaw. To finish, use very sharp drills/bits. I usually use a 2 or 3 flute router mounted in a table to clean up edges - if you use sandpaper, the finshed edge will collect dirt and be very ugly over time. Just shave the edges taking a very small amount of material off in a pass - never plow. The burr remaing in the edge is best removed by use of a brand new, very sharp #11 X-acto blade/handle and trimming carefully at 45. I would like to take a moment to express my frustration with this step... I have now spent 3 or more hours fiddling with this damn step. It looks so simple in the manual... I HATE cutting this material. The nylon fairlead material is not as similar to plexiglass as one would think. It splinters, cracks and is generally a miserable material to work with. I guess the same properties of this material that make it a pain in the a$$ also make it durable enough to use as a material that will constantly be being rubbed by a piece of steel cable. OK. I'm done venting. But seriously guys how are you cutting this stuff? I have tried the following tablesaw (kickback safety issues not recommended), router (same), dremmel with cutoff wheel and now I am using a larger pneumatic cutoff wheel which more or less melts and slings pieces of melted plastic all over me and it stinks like hell. There must be a better way. As far as positioning goes I am only drilling two of the holes at this point so that if I need to tweak the location a little I can I'll drill the rest when I actually install rudder and start adjusting controls. I don't think you can truly know if everything is just right until you try to run the cables. If you rivet everything all together and then realize that you should have filed a little more of the fairlead material away then there you are drilling out rivets. I don't know about the rest of you, but I'm tired of drilling out rivets. -------- One Rivet at a Time! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167200#167200 Dave Downey Harleysville (SE) PA 100 HP Corvair --------------------------------- ________________________________________________________________________________
Date: Mar 02, 2008
by the way, what usually wears out in time is the cable - not the Nylon fairlead! The better aligned to the likely range of position of the cable in use, the longer the cable will last! Paul Riedlinger wrote: Cut mine on a bandsaw no problem. You have a bit of flashing to deal with, but it comes off very easily with an exacto knife. Drilling created some flash that needs to be cleaned up with an exacto as well. My method was to: 1) Locate, cut and drill the rudder cable exit fairings first. 2) Clamp the N66 material to the fairing and drill matching holes 3) Rough cut the clecoed assembly (fairing and N66) from the N66 sheet with a bandsaw 4) With everything still clecoed together, use a belt sander, using brief contact and then allowing for a quick cool down and then back at it, to bring the N66 to the same dimension as the fairing. It took me about 5 minutes per fairing to get the N66 cut and sanded to size 5) trim any flashing of the material with a sharp exacto knife. FYI, on the plans it tells you to cut an angled slot in the fairlead material, but I peaked at at fellow builder's quick build fuse and the factory just cuts a slot to match the one machined into the prepunched fuse side. I did the same with a milling machine cutter in a machining vise on a drill press. Detail can be seen on my blog at www.mykitlog.com/paulried/ Hope that helps On Sun, Mar 2, 2008 at 12:22 AM, MHerder wrote: I would like to take a moment to express my frustration with this step... I have now spent 3 or more hours fiddling with this damn step. It looks so simple in the manual... I HATE cutting this material. The nylon fairlead material is not as similar to plexiglass as one would think. It splinters, cracks and is generally a miserable material to work with. I guess the same properties of this material that make it a pain in the a$$ also make it durable enough to use as a material that will constantly be being rubbed by a piece of steel cable. OK. I'm done venting. But seriously guys how are you cutting this stuff? I have tried the following tablesaw (kickback safety issues not recommended), router (same), dremmel with cutoff wheel and now I am using a larger pneumatic cutoff wheel which more or less melts and slings pieces of melted plastic all over me and it stinks like hell. There must be a better way. As far as positioning goes I am only drilling two of the holes at this point so that if I need to tweak the location a little I can I'll drill the rest when I actually install rudder and start adjusting controls. I don't think you can truly know if everything is just right until you try to run the cables. If you rivet everything all together and then realize that you should have filed a little more of the fairlead material away then there you are drilling out rivets. I don't know about the rest of you, but I'm tired of drilling out rivets. -------- One Rivet at a Time! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167200#167200 -- Paul Riedlinger cndmovn(at)gmail.com Dave Downey Harleysville (SE) PA 100 HP Corvair --------------------------------- Never miss a thing. Make Yahoo your homepage. ________________________________________________________________________________
Date: Mar 02, 2008
I have talked with some of the guys in my EAA group. most are RV's, and they said that a runaway does not happen that often, but they do run it to the limit and fly. They say it is not that difficult to control, just slow down and fly the plane. A breaker would be good to stop the servo from driving and burning out. Good luck Tom, saving for wings. Paul Mulwitz wrote: I don't see how a circuit breaker or fuse would help at all if you have run-away trim. By the time you turn off the power to the trim servo, the trim will already be crashed into one end of the travel or the other. Turning off the power just guarantees it will stay there. Fortunately, I have heard reports that it doesn't take super-human strength to overcome full limit trim. Paul XL fuselage At 10:59 AM 2/29/2008, you wrote: I second Dave Gallagher's advice regarding a CB for the trim. The RAC instructions advise a 2amp fuse or breaker so buy a breaker that can be shut off if the problem arises. That's what I did as well. Dred --------------------------------- Never miss a thing. Make Yahoo your homepage. ________________________________________________________________________________
Date: Mar 02, 2008
Band saw and belt sander. Compared to some other tasks I can think of, no problem. Bill do not archive > I HATE cutting this material. The nylon fairlead material is not as > similar to plexiglass as one would think. It splinters, cracks and is > generally a miserable material to work with. > > ________________________________________________________________________________
Date: Mar 02, 2008
Hacksaw. Dave Austin 601HDS - 912, Spitfire Mk VIII ________________________________________________________________________________
Date: Mar 02, 2008
Michael, I've used a hacksaw to cut, then dressed with sandpaper. Hand tools and hand work get the job done. Power just melts the stuff. Jay in Dallas "MHerder" wrote: > >I would like to take a moment to express my frustration with this step... I have now spent 3 or more hours fiddling with this damn step. It looks so simple in the manual... > >I HATE cutting this material. The nylon fairlead material is not as similar to plexiglass as one would think. It splinters, cracks and is generally a miserable material to work with. > >I guess the same properties of this material that make it a pain in the a$$ also make it durable enough to use as a material that will constantly be being rubbed by a piece of steel cable. > >OK. I'm done venting. > >But seriously guys how are you cutting this stuff? I have tried the following tablesaw (kickback safety issues not recommended), router (same), dremmel with cutoff wheel and now I am using a larger pneumatic cutoff wheel which more or less melts and slings pieces of melted plastic all over me and it stinks like hell. There must be a better way. > >As far as positioning goes I am only drilling two of the holes at this point so that if I need to tweak the location a little I can I'll drill the rest when I actually install rudder and start adjusting controls. I don't think you can truly know if everything is just right until you try to run the cables. If you rivet everything all together and then realize that you should have filed a little more of the fairlead material away then there you are drilling out rivets. I don't know about the rest of you, but I'm tired of drilling out rivets. > >-------- >One Rivet at a Time! > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=167200#167200 > > ________________________________________________________________________________
Date: Mar 02, 2008
There is an old receipe for working with plastics such as nylon etc. Freeze the material and it will work easily in this state... ----- Original Message ----- From: <Jaybannist(at)cs.com> Sent: Sunday, March 02, 2008 7:36 AM Subject: RE: Zenith-List: Re: Rudder Cable farings > > Michael, > > I've used a hacksaw to cut, then dressed with sandpaper. Hand tools and > hand work get the job done. Power just melts the stuff. > > Jay in Dallas > > "MHerder" wrote: > >> >>I would like to take a moment to express my frustration with this step... >>I have now spent 3 or more hours fiddling with this damn step. It looks >>so simple in the manual... >> >>I HATE cutting this material. The nylon fairlead material is not as >>similar to plexiglass as one would think. It splinters, cracks and is >>generally a miserable material to work with. >> >>I guess the same properties of this material that make it a pain in the >>a$$ also make it durable enough to use as a material that will constantly >>be being rubbed by a piece of steel cable. >> >>OK. I'm done venting. >> >>But seriously guys how are you cutting this stuff? I have tried the >>following tablesaw (kickback safety issues not recommended), router >>(same), dremmel with cutoff wheel and now I am using a larger pneumatic >>cutoff wheel which more or less melts and slings pieces of melted plastic >>all over me and it stinks like hell. There must be a better way. >> >>As far as positioning goes I am only drilling two of the holes at this >>point so that if I need to tweak the location a little I can I'll drill >>the rest when I actually install rudder and start adjusting controls. I >>don't think you can truly know if everything is just right until you try >>to run the cables. If you rivet everything all together and then realize >>that you should have filed a little more of the fairlead material away >>then there you are drilling out rivets. I don't know about the rest of >>you, but I'm tired of drilling out rivets. >> >>-------- >>One Rivet at a Time! >> >> >> >> >>Read this topic online here: >> >>http://forums.matronics.com/viewtopic.php?p=167200#167200 >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Mar 02, 2008
I found that drilling and deburring a hole at the terminus of the slot in the fairlead, then cutting to the hole with a bandsaw worked well. Dred ________________________________________________________________________________
Subject: 701 Fuel Caps leaking
Date: Mar 02, 2008
Those with flying 701's Have you had a problem with your fuel caps leaking and if so what did you do for a fix? I have tried about a half dozen different gaskets and no success. Believe now that the fuel may be getting between the cap and the doubler inside it and then sucking out. Thanks Joe ________________________________________________________________________________
Date: Mar 02, 2008
Subject: Aircraft Quality
I'm very curious. What makes a bolt "aircraft quality"? I've tried Google and Yahoo and have not gotten any REAL answer. Just "always use aircraft quality." If a Grade 8 bolt has the same tensile strength as an AN bolt, what makes the AN superior? Can someone fill me in? Jay in Dallas 601XL N2630J "Lil Bruiser" ________________________________________________________________________________
Subject: Re: Aircraft Quality
Date: Mar 02, 2008
What makes a "certified" aircraft safe ? It has FAA seal of approval.. ----- Original Message ----- From: <Jaybannist(at)cs.com> Sent: Sunday, March 02, 2008 7:30 PM Subject: Zenith-List: Aircraft Quality > > I'm very curious. What makes a bolt "aircraft quality"? I've tried > Google and Yahoo and have not gotten any REAL answer. Just "always use > aircraft quality." If a Grade 8 bolt has the same tensile strength as an > AN bolt, what makes the AN superior? Can someone fill me in? > > Jay in Dallas 601XL N2630J "Lil Bruiser" > > > ________________________________________________________________________________
Date: Mar 02, 2008
Every AN bolt, nut, washer, etc has to meet the criteria for a mil spec and is QC'ed to that spec. SAE grades, such as a grade 8's, has an inspection done on only a few in a batch. The ones that are not inspected are a crap shoot. ________________________________________________________________________________
Date: Mar 02, 2008
Ben Thanks for the reply. I brazed on forward facing 3 inch high fuel vent tubes while building the plane. I don't believe that's the problem...am thinking it's maybe more of a problem with the double walled fuel caps supplied by Zenith in the kit...the fuel may be getting between the 2 parts of the cap and then getting sucked out regardless of gasket integrity???You are correct in that it only happens when near full. Thanks again Joe ________________________________________________________________________________
Date: Mar 02, 2008
It is to do with the accuracy with which the bolts and nuts are manufactured, form of the thread etc. There is a small radii between the head and the bolt shank that properly distributes the load on the head. The tensile strength of the steel is only one characteristic. The standards are set by the Army and Navy hence the AN part of the part number not the FAA. John Read Phone: 303-648-3261 Fax: 303-648-3262 Cell: 719-494-4567 In a message dated 3/2/2008 7:47:49 P.M. Mountain Standard Time, notsew_evets(at)frontiernet.net writes: --> Zenith-List message posted by: "steve" What makes a "certified" aircraft safe ? It has FAA seal of approval.. ----- Original Message ----- From: <Jaybannist(at)cs.com> Sent: Sunday, March 02, 2008 7:30 PM Subject: Zenith-List: Aircraft Quality > --> Zenith-List message posted by: Jaybannist(at)cs.com > > I'm very curious. What makes a bolt "aircraft quality"? I've tried > Google and Yahoo and have not gotten any REAL answer. Just "always use > aircraft quality." If a Grade 8 bolt has the same tensile strength as an > AN bolt, what makes the AN superior? Can someone fill me in? > > Jay in Dallas 601XL N2630J "Lil Bruiser" > > > **************Ideas to please picky eaters. Watch video on AOL Living. (http://living.aol.com/video/how-to-please-your-picky-eater/rachel-campos-duffy/ 2050827?NCID=aolcmp00300000002598) ________________________________________________________________________________
Date: Mar 02, 2008
Are you suggesting that, unlike SAE, every AN items get inspected? If not, wouldn't uninspected AN be potentially crap shoot as well? Every AN bolt, nut, washer, etc has to meet the criteria for a mil spec and is QC'ed to that spec. SAE grades, such as a grade 8's, has an inspection done on only a few in a batch. The ones that are not inspected are a crap shoot. --------------------------------- ________________________________________________________________________________
Date: Mar 03, 2008
From: Michael Hilderbrand <m_hilderbrand(at)sbcglobal.net>
I know I am pee'ing in the wind since I have no validation for this, but I heard Grade 8 will snap at failure, and AN bolts will bend first... ??? Michael Hilderbrand ----- Original Message ---- From: "Jaybannist(at)cs.com" <Jaybannist(at)cs.com> Sent: Sunday, March 2, 2008 8:30:30 PM Subject: Zenith-List: Aircraft Quality I'm very curious. What makes a bolt "aircraft quality"? I've tried Google and Yahoo and have not gotten any REAL answer. Just "always use aircraft quality." If a Grade 8 bolt has the same tensile strength as an AN bolt, what makes the AN superior? Can someone fill me in? Jay in Dallas 601XL N2630J "Lil Bruiser" ________________________________________________________________________________
Date: Mar 03, 2008
It is not necessarily better quality. About 10 years ago a flood of "bogus" "aircraft grade" hardware, AN, MS, NAS, NASM, BAC, showed up in the market and there were some failures that led to a very expensive testing and certification to fasteners in the supply chain. That is with fairly rigorous process and quality standards that "aircraft grade" hardware come burdened with. Grade 8 bolts have a less rigorous pedigree requirement (in my opinion). Things like rolled threads, perpendicularity of the washer face under the head and the head itself, concentricity, fillet geometry under the head, alloy, heat treatments, temper, coating/plating, are all controlled in "aircraft grade" hardware. Using "aircraft grade" is expensive but gives the peace of mind that the joint will perform as designed. I'm very curious. What makes a bolt "aircraft quality"? I've tried Google and Yahoo and have not gotten any REAL answer. Just "always use aircraft quality." If a Grade 8 bolt has the same tensile strength as an AN bolt, what makes the AN superior? Can someone fill me in? Jay in Dallas 601XL N2630J "Lil Bruiser" Dave Downey Harleysville (SE) PA 100 HP Corvair --------------------------------- Never miss a thing. Make Yahoo your homepage. ________________________________________________________________________________
Subject: Re: 701 Fuel Caps leaking
Date: Mar 03, 2008
I'll take two of those modified caps if anyone knows where to get them. ZAC just emailed me back saying they couldn't provide the part?? -------- Low & Slow Rick www.n701rr.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167367#167367 ________________________________________________________________________________
Date: Mar 03, 2008
Hi Joe, How's tricks in Miss.?? seal up the cap halves with proseal , had to do that on a Pacer once. John ----- Original Message ----- From: Joe Spencer To: Zenith-List(at)matronics.com Sent: Sunday, March 02, 2008 9:46 PM Subject: Zenith-List: 701 Fuel Caps leaking Ben Thanks for the reply. I brazed on forward facing 3 inch high fuel vent tubes while building the plane. I don't believe that's the problem...am thinking it's maybe more of a problem with the double walled fuel caps supplied by Zenith in the kit...the fuel may be getting between the 2 parts of the cap and then getting sucked out regardless of gasket integrity???You are correct in that it only happens when near full. Thanks again Joe ________________________________________________________________________________
Subject: Fuel Caps leaking
Date: Mar 03, 2008
John Right. Your description is just about exactly what I did on the vent tube and of course after really looking at the cap it's obvious that fuel is getting around the portion of the vent tube that extends inside the fuel cap as well as thru the existing small holes. Will epoxy all that up or maybe braze and believe that will do it. Guys thanks for the replies. Joe Of course that vent tube brazed to the top of the cap needs to go through the inner portion of the cap as well, then the original holes in that inner layer are plugged. Those caps with that original venting system are only suitable for a filler neck that's well above the fuel level, like in a car gas tank. If the fuel sloshes up against the cap, like it will do in a full aircraft tank, they will leak. The new vent tube only needs to be 1/8" bore, and three inches high is enough to prevent fuel sloshing up and out. Bent so it's facing forward pressurizes it very slightly and prevents it from sucking fuel out. Bend it so that the very front is a bit down and then rain doesn't get in. There's no airflow as such into the tube, just enough to replace fuel volume used and release fuel vapour pressure. ________________________________________________________________________________
Subject: Re: Another day another disaster
Date: Mar 03, 2008
Steve, I have some experience with paint and painting once over zinc primer. I was not able to re coat sufficiently to halt bleed through totally. I don't think allowing any amount to cure time with allow you to re coat with success. On my plane, thankfully, the zinc bled though under the wing at the skin seam and is very difficult to see, but I know where it is. If it had been on top somewhere I would have had to remove to metal. Zinc will bleed through two coats of two part epoxy and two coats of polyurethane single stage finish coat. If there is another fix I don't know what it is. I ended up taking both flaps to the metal to remove the zinc. Sorry I can't be more help. This issue has a long thread in the archives. Best regards, Bill of Georgia -----Original Message----- From: steve <notsew_evets(at)frontiernet.net> Sent: Sat, 1 Mar 2008 5:56 pm Subject: Zenith-List: Another day another disaster So, here I am in the Arizona sun with temperature in the low 80s. I painted my fuselage today and need advise.? Advise from experienced painters... The fuselage was primed with a?two part epoxy primer (green). Its cured for months and has been scuffed for that extra "bite". In some spots I used Tempo primer from a can.? Aircraft Spruce sells the stuff for priming under epoxy paints so I "think" is a good product. Well I see bleeding in some areas and wonder if its the "zinc" type primer?? Anyway, what do I need to do ??? I assume I let it all cure for a few days and lightly sand and apply one last light coat..???... Any thoughts ?? ? Thanks ? Steve ________________________________________________________________________________
Date: Mar 03, 2008
Subject: Polishing with Nuvite
Hi All, Can any of you guys who have used Nuvite to polish you plane tell me how much of their polishing materials you used ? And which grades did you find to work best ? Thanks, John Davis Burnsville, NC 601 XL - Jab 3300 ________________________________________________________________________________
Date: Mar 03, 2008
You might try a Waterborne Epoxy primer like System Three WR-155, the Zinc primer you have is probably being dissolved and bleeding into the primer you are using now due to the solvents. Of course, if you use the WR-155, then you'll need to test all your topcoats for compatability with the primer ... Jeff. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167417#167417 ________________________________________________________________________________
Subject: Walnut Shell Blasting Media - Which Grit??
Date: Mar 03, 2008
I am about to buy a small blasting unit so I can clean up my aluminum parts. I have available 2 different grit sizes I could buy. The grit grade of "fine" is 24 grit. The other one has a grit grade of 12 and is called "course". Which one is the best one to use for cleaning up my Corvair engine parts? I also have the tubes, valve covers, oil pan and baffles that are needing to be blasted. Can I use the walnut shells on them or should I switch over to sand or a different media?? Any information will be greatly appreciated! Larry Hursh CH601XL Rudder done, working on elevator kit and have wings on order. Corvair powered (N601LL Reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167433#167433 ________________________________________________________________________________
Date: Mar 03, 2008
Grade 8 bolts are to be 150,000 psi tensile strength minimum. AN3-AN8 bolts are heat treated to 125,000 psi minimum tensile strength. A lower strength bolt can indeed bend more before failure more readily than a higher strength bolt. Bolted joints require well designed choices of the fasteners, the plates being joined, service conditions, etc. Since the bolts are a relatively small cost in the total, for airframes, why consider using other? This discussion started with reference to WW referring to Grade 8 bolts in the engine. The original and all subsequent GM test engines were built without AN, MS, or NAS bolts - shouldn't their hardware be suitable? Michael Hilderbrand wrote: I know I am pee'ing in the wind since I have no validation for this, but I heard Grade 8 will snap at failure, and AN bolts will bend first... ??? Michael Hilderbrand Dave Downey Harleysville (SE) PA 100 HP Corvair --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Mar 03, 2008
keep in mind that one of the speculative reasons that 601 crashed 1.5 years ago with a wing falure waws that the guy bought the plane and replaced the wing spar bolt with local hardware store bolt. is it fact I do not know however i know the AN bolts are cheap and that a good design can still fail due to pilot failure on shoddy work and short cuts. Juan -----Original Message----- >From: David Downey <planecrazydld(at)yahoo.com> >Sent: Mar 3, 2008 2:33 PM >To: zenith-list(at)matronics.com >Subject: Re: Zenith-List: Aircraft Quality > >Grade 8 bolts are to be 150,000 psi tensile strength minimum. AN3-AN8 bolts are heat treated to 125,000 psi minimum tensile strength. > >A lower strength bolt can indeed bend more before failure more readily than a higher strength bolt. Bolted joints require well designed choices of the fasteners, the plates being joined, service conditions, etc. Since the bolts are a relatively small cost in the total, for airframes, why consider using other? > >This discussion started with reference to WW referring to Grade 8 bolts in the engine. The original and all subsequent GM test engines were built without AN, MS, or NAS bolts - shouldn't their hardware be suitable? > >Michael Hilderbrand wrote: > I know I am pee'ing in the wind since I have no validation for this, but I heard Grade 8 will snap at failure, and AN bolts will bend first... ??? > >Michael Hilderbrand > > > > > Dave Downey > Harleysville (SE) PA > 100 HP Corvair > > > >--------------------------------- >Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Subject: Monday Evening Chat Room
Date: Mar 03, 2008
http://www.mykitairplane.com/chat/ George CH-701 N73EX (Reserved) ________________________________________________________________________________
Subject: Clarification---Certified Engines & Experimental aircraft.
Date: Mar 03, 2008
Because of all the comments and questions in response to the posting I made on the Continental O-200, it became clear I needed to find out what is correct. What I did find out was some of what I was told was right and some was wrong, even though the information came from people heavily involved in aviation including certified A & P's. I am making the assumption that Joe Norris at EAA headquarters knows the right answer. I spoke with Joe today, below is the questions I ask along with his answers. Question: Is a certified aircraft engine still certified after it is installed in an experimental aircraft? Answer: No,it is no longer certified. (George, you were right, I was told the opposite by an A &P) Question: If that is the case, then what about the 25 hour and 40 hour test phase? Answer: To get the 25 hour fly off you must prove it is a certified engine including the correct prop and all accessories (carb, starter, mags,etc) for that specific engine. The example he gave was: If it came off a Cessna 150, the prop has to be the same pitch and diameter designated for that application for anything else it will be assigned 40 hours. Once the inspection is done, the engine is no longer certified. Question: Who can work on the engine at that point? Answer: Anyone when it is on a experimental aircraft (E-AB.) Question: When can you work on the engine or make changes to the certified engine. Answer: Immediately after the inspector leaves. Question: Now that it is no longer certified, is it necessary to take the data plate off? Answer: No, actually it is best to leave it in place. Question: When buying a used aircraft engine, how would someone like me find about AD's on a particular engine? Answer: www.faa.gov 1. Do a search on make and model 2. Ask around a local EAA Chapter, most IAs have a CD Rom they can use to look up information on any aircraft engine. Question: What about the 5 hour test flight phase. Answer: That was only for the so-called "fat ultralight" it has expired.. Thanks to all, your response has pointed out the need for me to look for better answers. Clyde Barcus 601 XL, Continental Powered ________________________________________________________________________________
Subject: Re: Polishing with Nuvite
Date: Mar 03, 2008
John #7 for initial compounding (slow bonnet lambs wool 3M) #7 for initial polishing (cyclo) C for secondary compounding (slow bonnet lambs wool 3M) C for polishing (cyclo) S for final polishing (cyclo) Final cyclo with microfiber I used mineral spirits to clean the metal between grit size changes but not after the S polish since it will remove a protective coating. Polish as much as possible before attaching it to the aircraft. Especially the bottom side of the wings and stabilizer. I did not like the #9. It did not seem to cut as well as the #7. I did not like the #6 for the same reason. 1/2 lb each for one 601XL possibility more of the #7 if any. This will produce a pretty good appearance but it is not a perfect mirror. It would take a double pass application of each step above for that. Takes about 3 hours per Lf top, Lf bottom, Rt top, Rt Bottom wing surface. You need thick chemical resistant rubber gloves and a face mask and a shower after you work with this stuff. The residue is black and very fine. Gary Ray 601XL davgray(at)sbcglobal.net ----- Original Message ----- From: "John Davis" <johnd@data-tech.com> Sent: Monday, March 03, 2008 11:49 AM Subject: Zenith-List: Polishing with Nuvite > > Hi All, > > Can any of you guys who have used Nuvite to polish you plane tell me how > much of their polishing materials you used ? > > And which grades did you find to work best ? > > Thanks, > John Davis > Burnsville, NC > 601 XL - Jab 3300 > > > -- 3:59 PM > > ________________________________________________________________________________
Subject: Re: Walnut Shell Blasting Media - Which Grit??
Date: Mar 03, 2008
Larry, I used the fine grit and it worked well on my aluminum parts. It cleans and polishes the aluminum very nicely. Just make sure that all the heavy grease and oil is removed beforehand because you'll end up with neat little clumps of walnut media. The walnut media doesn't work well with steel parts unless they are already very clean and rust-free. I used conventional sand blast media to clean the steel parts. Good luck, Ken Pavlou 601XL / Corvair Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167500#167500 ________________________________________________________________________________
Date: Mar 03, 2008
Thanks for the info Ken. I wasn't sure if walnut shells would do the steel parts or not. Until I decided to do the Corvair Conversion, I honestly never heard of using walnut shells before so this part is all new to me. I DID buy the fine walnut shells, thinking if nothing else, I can use it as a "finishing blast". I'll go down tomorrow and get a bag of silica sand for the steel parts. I'm going to try something I've never done before and that is powder coating. I bought a powder coating gun and powder paint at Harbor Freight. It was a fraction of the cost there, compared to Sears. I'm looking for a used gas stove to bake the parts in. I was looking for a primer to apply to the parts prior to powder coating. My brother in law told me he didn't think I needed a primer, just only an acid etch to lock up the rust. I have that already, just not sure if I should or shouldn't use some type of primer first. Any ideas on that one? I'll be the first to admit here, I am a newbie. I have a lot to learn and hopefully, I can get some really good information just from asking the right questions. Any and all help is of course, GREATLY appreciated! Best Regards Larry Hursh -------- Larry Hursh (N601LL Reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167502#167502 ________________________________________________________________________________
Date: Mar 03, 2008
Larry, I don't know much about powder coating. I believe that some sort of conversion coating is required before the powder coat is applied. I'm sure a google search will set you on the right path. Good Luck, Ken 601XL / Corvair Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167505#167505 ________________________________________________________________________________
Date: Mar 03, 2008
Subject: monday nite chat
does anyone know the address of the monday nite chat? Thanks Gary 601XL Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Date: Mar 03, 2008
Please keep in mind that it is very difficult to purge more aggressive media to change over to a less aggressive media. OK going the hard/heavy to soft/light - just very hard to eliminate the harsh residual contamination. Thanks for the info Ken. I wasn't sure if walnut shells would do the steel parts or not. Until I decided to do the Corvair Conversion, I honestly never heard of using walnut shells before so this part is all new to me. I DID buy the fine walnut shells, thinking if nothing else, I can use it as a "finishing blast". I'll go down tomorrow and get a bag of silica sand for the steel parts. I'm going to try something I've never done before and that is powder coating. I bought a powder coating gun and powder paint at Harbor Freight. It was a fraction of the cost there, compared to Sears. I'm looking for a used gas stove to bake the parts in. I was looking for a primer to apply to the parts prior to powder coating. My brother in law told me he didn't think I needed a primer, just only an acid etch to lock up the rust. I have that already, just not sure if I should or shouldn't use some type of primer first. Any ideas on that one? I'll be the first to admit here, I am a newbie. I have a lot to learn and hopefully, I can get some really good information just from asking the right questions. Any and all help is of course, GREATLY appreciated! Best Regards Larry Hursh -------- Larry Hursh (N601LL Reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167502#167502 Dave Downey Harleysville (SE) PA 100 HP Corvair --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Subject: Powder requirements
Date: Mar 03, 2008
Spent a career selling powder equipment and blast equipment so I'll throw my .02 in here. Unlike a solvent born liquid paint, powder is VERY unforgiving of a contaminated substrate, it MUST be clean, no oils, ect. Wiping it down with solvent just spreads the oils around in lower concentrations. Rust HAS to be removed down to the white metal. (If you're serious about a quality job) A solvent born paint uses the solvents to "blend into" a contaminated surface much better than a water born paint and infinitely better than powder. A blasted surface with a little "tooth" is the preferred surface for powder. look for an electric oven instead of the gas fired one, much safer. John Bolding ----- > I'm going to try something I've never done before and that is powder > coating. I bought a powder coating gun and powder paint at Harbor > Freight. It was a fraction of the cost there, compared to Sears. I'm > looking for a used gas stove to bake the parts in. I was looking for a > primer to apply to the parts prior to powder coating. My brother in law > told me he didn't think I needed a primer, just only an acid etch to lock > up the rust. I have that already, just not sure if I should or shouldn't > use some type of primer first. Any ideas on that one? > > I'll be the first to admit here, I am a newbie. I have a lot to learn and > hopefully, I can get some really good information just from asking the > right questions. > Any and all help is of course, GREATLY appreciated! > > Best Regards > Larry Hursh > ________________________________________________________________________________
Date: Mar 03, 2008
Subject: Re: monday nite chat
http://www.mykitairplane.com/chat/ Doug --- burbby wrote: > does anyone know the address of the monday nite > chat? > > Thanks > Gary > 601XL > > > Be a better friend, newshound, and > know-it-all with Yahoo! Mobile. Try it now. > http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ > > Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs ________________________________________________________________________________
From: "John Short" <creativesigns(at)embarqmail.com>
Subject: Dash panel
Date: Mar 03, 2008
Has anyone considered making the panel form carbon fiber or composite materials? My thought is I would make for a slick looking, very strong glare free surface. Also thinking of using this technique for tips and farings. CREATIVE SIGNWORKS 1168 Byron Rd. Kaufman, Tx 75142 John & Mindy Short 972-962-7464 Cell: 214-240-3815 www.creative-sign-works.com creativesigns(at)embarqmail.com ________________________________________________________________________________
Subject: Re: 2000 hours
Date: Mar 03, 2008
This topic comes up all the time. To get the 25 hour phase 1 you need a certified engine/prop combo. However, once that engine is hung on your E-AB it is no longer certified, no matter who does the maintenance. If you pull the engine and want to put it into a certified aircraft, it needs to be signed off by an A+P. It's much more likely that it will be signed off without being torn down if all the work is done and documented by a certified mechanic, but there is no way to maintain its certified status while it's on your experimental. Don't mess with the data plate; you don't need to remove it to make it an experimental, and it's value in the certified world is minimal without a data plate. In any event it's pretty tough to do a thorough test protocol in 25 hours anyway, so I wouldn't fret about it too much. Steve Read this topic online here: http://forums.matronics.com/viewtopic.php?p=167544#167544 ________________________________________________________________________________
Date: Mar 03, 2008
Subject: SOUTHERN B-B-QUE FLY-IN MARCH 15th UPDATE !
Hi Folks - for any of you interested in the Southern B-B-Que Fly-in and get together on March 15th there is some information for you at billclapp.com . I hope to see some of you there for some fun and an excuse to fly and meet people. Call me or email me if you have specific needs or questions. Thank you. Bill Clapp Bill Clapp - KR2S builder and pilot Valdosta GA www.billclapp.com --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Mar 03, 2008
Subject: Re: Powder requirements
Thanks for the info John. I did realize that I need an electric oven instead of a gas one. Makes sense because I never thought of "fumes" being so explosive. Glad I asked about it. I'm slowly learning about the powder coating too. I was told I need to use a "pre-primer" (acid type solution) and another person suggested an "etching primer" as a base coat. Everything I've been reading says I need only bare metal for the best adhesion, but it MUST be clean as you said. I'm planning on powder coating the push rod tubes, cylinder heads, and the rear cover. I still haven't decided if I want to buy the "Corvair 100 HP valve covers from WW or coat these too, along with the oil pan. Decisions, decisions! I think once I learn all the in's and out's of powder coating, I'll want to paint anything and everything I can get into the oven! I read too that there is such a thing as a "low temp" powder but as of yet, I haven't run across it for sale. Is there such a thing and if there is, where could it be purchased at? Like I said before, I'm such a newbie at this but I DO have the perfectionism in me to do something extremely well if I do it at all. For me, there is no such thing as "good enough". It HAS TO BE RIGHT or I will NOT do it. (I guess this is why I'm going through the learning curve, asking as many questions as I can to learn. Thanks to all that are helping me to understand this process of powder coating. I think it is going to be something that is going to be well worth the efforts! Regards, Larry Hursh John Bolding wrote: Spent a career selling powder equipment and blast equipment so I'll throw my .02 in here. Unlike a solvent born liquid paint, powder is VERY unforgiving of a contaminated substrate, it MUST be clean, no oils, ect. Wiping it down with solvent just spreads the oils around in lower concentrations. Rust HAS to be removed down to the white metal. (If you're serious about a quality job) A solvent born paint uses the solvents to "blend into" a contaminated surface much better than a water born paint and infinitely better than powder. A blasted surface with a little "tooth" is the preferred surface for powder. look for an electric oven instead of the gas fired one, much safer. John Bolding ----- > I'm going to try something I've never done before and that is powder > coating. I bought a powder coating gun and powder paint at Harbor > Freight. It was a fraction of the cost there, compared to Sears. I'm > looking for a used gas stove to bake the parts in. I was looking for a > primer to apply to the parts prior to powder coating. My brother in law > told me he didn't think I needed a primer, just only an acid etch to lock > up the rust. I have that already, just not sure if I should or shouldn't > use some type of primer first. Any ideas on that one? > > I'll be the first to admit here, I am a newbie. I have a lot to learn and > hopefully, I can get some really good information just from asking the > right questions. > Any and all help is of course, GREATLY appreciated! > > Best Regards > Larry Hursh > --------------------------------- ________________________________________________________________________________
Date: Mar 03, 2008
Subject: Paint sprayers
What are people using for HVLP paint sprayers- The best for the buck? Thanks, Darrell 601 XL ________________________________________________________________________________
Date: Mar 04, 2008
Zenith Listers, While flying from Zephyrhills, FL to Goldsboro, NC, my CFI abandoned me and my CH701 near Folkston, GA. I had the good fortune of finding Bill who lives near by in Valdosta, GA. The Rotax 912 ULS developed a problem with the fuel pump. Lockwood made an overnight delivery with new pump. Thanks Lockwood! I returned home
February 20, 2008 - March 04, 2008
Zenith-Archive.digest.vol-ht
