Zenith-Archive.digest.vol-im
November 08, 2008 - November 23, 2008
            507 Melvin Ave
            Racine, WI 53402
Date: Nov 08, 2008
Subject: Re: T-6 Corrosion Resistance
Take a look at the metal with a magnifying glass and a bright flashlight. If there are no pits then it probably is just staining, not corrosion. Aluminum corrosion products are generally a white powder that is not too hard to remove. Try cleaning with some Alumiprep 33. This is what is used to prep for applying Alodine, painting or welding. The Alumiprep should foam up and bleach the surface to almost white. Flush with plenty of cold water. Remember to dilute with water as directed. You don't need to use Alodine afterwards unless you want to. A natural layer of aluminum oxide will form quickly and seal the surface back up. Not to open old threads but.... 3M maroon scotchbrite is aluminum oxide based and is OK on aluminum. Don't use silicon carbide sandpaper on AL. It can lead to corrosion (per AC43.13 2A) 3M offers an aluminum oxide wet or dry paper (Imperial) that is no more expensive, just had to find. I you want to see some impressive corrosion I could post a image of a Cessna wing mounting block with intergranular corrosion. Flat out 6061 is much more corrosion resistant than 2024. It is all we can do to prevent 2024 from corroding. Most single engine Cessnas prior to the 90's were not zinc chromated unless equipped to have floats. We have it easy. Ken Lilja ________________________________________________________________________________
Subject: Remote compass location
Date: Nov 09, 2008
All- The stock firewall on an HDS is galvanized and I just tried the compass test. Not with a Wal-Mart cheapie, but with an AirPath whiskey compass I picked up from Barnstormers. I know I can't locate the remote compass on the radio tray because the needle deflects 30+ degrees to the firewall. I think I'm OK with aft of the pilot's seat as close to the cockpit side skin as possible. Of course, there is an upside to all this. If an examiner asks why I don't have a whiskey compass, I can truthfully say that it would always point to the firewall, and I already know where that is. HDS people- how did you deal with this?? Larry, you don't have to answer because I know you made your firewall out of stainless. Bill Naumuk Townville, Pa. HDS 601MG/Corvair 95% ________________________________________________________________________________
Date: Nov 09, 2008
Subject: Re: Remote compass location
Hi Bill, Your compass should be adjustable to cancel near magnetic influence to a lesser degree. My stick would influence the compass in full forward position, but I was able to adjust to correct the N S E W compass readings regardless of where the stick was positioned. Perhaps you might be able to also. Larry McFarland 601HDS at www.macsmachine.com Bill Naumuk wrote: > All- > The stock firewall on an HDS is galvanized and I just tried the > compass test. Not with a Wal-Mart cheapie, but with an AirPath whiskey > compass I picked up from Barnstormers. I know I can't locate the > remote compass on the radio tray because the needle deflects 30+ > degrees to the firewall. I think I'm OK with aft of the pilot's seat > as close to the cockpit side skin as possible. > Of course, there is an upside to all this. If an examiner asks why > I don't have a whiskey compass, I can truthfully say that it would > always point to the firewall, and I already know where that is. > HDS people- how did you deal with this?? Larry, you don't have to > answer because I know you made your firewall out of stainless. > Bill Naumuk > Townville, Pa. > HDS 601MG/Corvair 95% > * > * ________________________________________________________________________________
Date: Nov 09, 2008
Larry- That takes care of the whiskey compass, but not the D-100 remote. Bill ----- Original Message ----- From: "LarryMcFarland" <larry(at)macsmachine.com> Sent: Sunday, November 09, 2008 11:35 AM Subject: Re: Zenith-List: Remote compass location > > Hi Bill, > Your compass should be adjustable to cancel near magnetic influence to a > lesser degree. My stick would influence the compass in full forward > position, but > I was able to adjust to correct the N S E W compass readings regardless > of where the stick was positioned. Perhaps you might be able to also. > > Larry McFarland 601HDS at www.macsmachine.com > > Bill Naumuk wrote: >> All- >> The stock firewall on an HDS is galvanized and I just tried the >> compass test. Not with a Wal-Mart cheapie, but with an AirPath whiskey >> compass I picked up from Barnstormers. I know I can't locate the >> remote compass on the radio tray because the needle deflects 30+ >> degrees to the firewall. I think I'm OK with aft of the pilot's seat >> as close to the cockpit side skin as possible. >> Of course, there is an upside to all this. If an examiner asks why >> I don't have a whiskey compass, I can truthfully say that it would >> always point to the firewall, and I already know where that is. >> HDS people- how did you deal with this?? Larry, you don't have to >> answer because I know you made your firewall out of stainless. >> Bill Naumuk >> Townville, Pa. >> HDS 601MG/Corvair 95% >> * >> * > > > > > > ________________________________________________________________________________
Subject: Timing Light Question
Date: Nov 09, 2008
I'm using an INOVA Tach Advance Digital Timing Light and it is acting very eratic. It's the type that has a lead that clamps around the #1 spark plug wire (induction lead). So far I haven't been able to look at the timing except at idle. At idle it looks like it's working OK, showing an advance of a few degrees and an RPM of 750, but as soon as I rev it up the RPMs jump all over the place and I loose the timing mark. I'm using Moroso Super Blue plug wires and have wondered if that's the problem. Perhaps it isn't able to pick the induction through the shielding in the wire. Any ideas? Dan Dempsey 601XL /Corvair -------- Scratch building XL with Corvair Engine Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213137#213137 ________________________________________________________________________________
Date: Nov 09, 2008
Bill, I haven't tried that yet. I will go out and take my compass and see how it reacts to the firewall. I'm almost at that step also. Jerry HDS 912 _____ From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bill Naumuk Sent: Sunday, November 09, 2008 8:21 AM Subject: Zenith-List: Remote compass location All- The stock firewall on an HDS is galvanized and I just tried the compass test. Not with a Wal-Mart cheapie, but with an AirPath whiskey compass I picked up from Barnstormers. I know I can't locate the remote compass on the radio tray because the needle deflects 30+ degrees to the firewall. I think I'm OK with aft of the pilot's seat as close to the cockpit side skin as possible. Of course, there is an upside to all this. If an examiner asks why I don't have a whiskey compass, I can truthfully say that it would always point to the firewall, and I already know where that is. HDS people- how did you deal with this?? Larry, you don't have to answer because I know you made your firewall out of stainless. Bill Naumuk Townville, Pa. HDS 601MG/Corvair 95% ________________________________________________________________________________
Date: Nov 09, 2008
From: "KMHeide, BA, CPO, FAAOP" <kmheidecpo(at)yahoo.com>
Subject: 750 builders
Any 750 builders or those who have purchased this plane able to visit via t he telephone? I have a few questions before placing an order... - Thanks - KH Heide - =0A=0A=0A ________________________________________________________________________________
Subject: Diodes
Date: Nov 09, 2008
I have an electric primer valve. Do I need to put a diode across it to protect the system from the induced voltage spikes? Also I am using a Sky-Tec starter on a Lycoming O-235. As you know they can be used in either mode. You can use the electric solenoid on the starter or you can leave it jumpered and use a solenoid on the firewall. I'm going the firewall solenoid route so that the starter cable is only carrying voltage while cranking. Do I need to put a diode on the starter or just on the firewall solenoid or both? Thanks in advance Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213187#213187 ________________________________________________________________________________
Date: Nov 09, 2008
Gentlemen - I am sure you are aware of the film you can wrap around the compass to prev ent any metal or electrical interference when installing a compass....right ?- Maybe I am missing something here.... please correct me not wanting to intrude on your conversations.. - - KM Heide - --- On Sun, 11/9/08, Jerry Latimer wrote: From: Jerry Latimer <jlatimer1(at)cox.net> Subject: RE: Zenith-List: Remote compass location Date: Sunday, November 9, 2008, 6:42 PM Bill, I haven't tried that yet.- I will go out and take my compass and see how it reacts to the firewall.- I'm almost at that step also. Jerry HDS 912 From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-serv er(at)matronics.com] On Behalf Of Bill Naumuk Sent: Sunday, November 09, 2008 8:21 AM Subject: Zenith-List: Remote compass location All- --- The stock firewall on an HDS is galvanized and I just tried the c ompass test. Not with a Wal-Mart cheapie, but with-an AirPath whiskey com pass I picked up from Barnstormers. I know I can't locate the remote compas s on the radio tray because the needle-deflects 30+ degrees-to the fire wall. I think I'm OK with aft of the pilot's seat as close to the cockpit s ide skin as possible. --- Of course, there is an upside to all this. If an examiner asks wh y I don't have a whiskey compass, I can truthfully say that it would always point to the firewall, and I already know where that is. --- HDS people- how did you deal with this?? Larry, you don't have to answer because I know you made your firewall out of stainless. Bill Naumuk Townville, Pa. HDS 601MG/Corvair 95% href="http://www.matronics.com/contribution">http://www.matronics.com/chr ef="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref ="http://forums.matronics.com">http://forums.matronics.com =0A=0A=0A ________________________________________________________________________________
Date: Nov 09, 2008
Before I put the remote compass where I did I spoke to dynon about it and he said it isn't as sensitive as most think and the fact that I placed 2 of them within 12 inches of the fire wall and haven't had any problems quantify's that. If I had had problems with them I certainly wouldn't be building my 3rd and 4th panel that way. Jeff **************AOL Search: Your one stop for directions, recipes and all other Holiday needs. Search Now. -aol-search/?ncid=emlcntussear00000001) ________________________________________________________________________________
Date: Nov 09, 2008
Jerry- My workspace is really crowded, so I don't know how much deviation I'm getting from things like my furnace, etc. I really hope I can get by with behind the pilot seat, because that would be the easiest other than the radio tray. THAT I know isn't viable. Do you have the OEM galvanized firewall? I actually increased the thickness of mine. Bill ----- Original Message ----- From: Jerry Latimer To: zenith-list(at)matronics.com Sent: Sunday, November 09, 2008 7:42 PM Subject: RE: Zenith-List: Remote compass location Bill, I haven't tried that yet. I will go out and take my compass and see how it reacts to the firewall. I'm almost at that step also. Jerry HDS 912 ------------------------------------------------------------------------- ----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bill Naumuk Sent: Sunday, November 09, 2008 8:21 AM To: zenith list Subject: Zenith-List: Remote compass location All- The stock firewall on an HDS is galvanized and I just tried the compass test. Not with a Wal-Mart cheapie, but with an AirPath whiskey compass I picked up from Barnstormers. I know I can't locate the remote compass on the radio tray because the needle deflects 30+ degrees to the firewall. I think I'm OK with aft of the pilot's seat as close to the cockpit side skin as possible. Of course, there is an upside to all this. If an examiner asks why I don't have a whiskey compass, I can truthfully say that it would always point to the firewall, and I already know where that is. HDS people- how did you deal with this?? Larry, you don't have to answer because I know you made your firewall out of stainless. Bill Naumuk Townville, Pa. HDS 601MG/Corvair 95% href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Zenith-List">http://www.matron href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Nov 09, 2008
---- Bill Naumuk wrote: > Jerry- > My workspace is really crowded, so I don't know how much deviation I'm getting from things like my furnace, etc. I really hope I can get by with behind the pilot seat, because that would be the easiest other than the radio tray. THAT I know isn't viable. Do you have the OEM galvanized firewall? I actually increased the thickness of mine. > Bill > I just went outside and placed by compass next to the firewall. As I moved it away from the firewall I got about a 15 degree deviation. There was no more deviation by the time I got the compass on the firewall side of the instrument panel. The compass actually stopped deviating about half way between the firewall and the instrument panel. I do have the origanal galvanized firewall. I've also been using an magnetic trouble light attached to firewall while working on the motor wiring. I won't do that anymore. Jerry ________________________________________________________________________________
Date: Nov 09, 2008
Subject: Re: Diodes
Check out Aircraft Spruce item 11-05727. This is the Transorb used by MGL electronics to protect the avionics bus from transient voltages. You might also put diodes across the coils of your master and starter solenoid (cathode (banded end) to +, anode to ground). For more information on spike protection google "Transorb". Steven Bornstein 475 E. North Broadway Columbus, Ohio 43214 614 263-5819 In a message dated 11/9/2008 9:07:24 P.M. Eastern Standard Time, hror1(at)pld.com writes: --> Zenith-List message posted by: "Ken" I have an electric primer valve. Do I need to put a diode across it to protect the system from the induced voltage spikes? Also I am using a Sky-Tec starter on a Lycoming O-235. As you know they can be used in either mode. You can use the electric solenoid on the starter or you can leave it jumpered and use a solenoid on the firewall. I'm going the firewall solenoid route so that the starter cable is only carrying voltage while cranking. Do I need to put a diode on the starter or just on the firewall solenoid or both? Thanks in advance Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213187#213187 **************AOL Search: Your one stop for directions, recipes and all other Holiday needs. Search Now. -aol-search/?ncid=emlcntussear00000001) ________________________________________________________________________________
Date: Nov 09, 2008
Subject: Re: Diodes
Just did some checking on part numbers. MGL and Aircraft Spruce get $6.00 for a transorb. You can obtain the same part from Mouser Electronics for less than a dollar. Search P/N 1.5KE33 or IN6284A. Steven Bornstein 475 E. North Broadway Columbus, Ohio 43214 614 263-5819 In a message dated 11/9/2008 9:07:24 P.M. Eastern Standard Time, hror1(at)pld.com writes: --> Zenith-List message posted by: "Ken" I have an electric primer valve. Do I need to put a diode across it to protect the system from the induced voltage spikes? Also I am using a Sky-Tec starter on a Lycoming O-235. As you know they can be used in either mode. You can use the electric solenoid on the starter or you can leave it jumpered and use a solenoid on the firewall. I'm going the firewall solenoid route so that the starter cable is only carrying voltage while cranking. Do I need to put a diode on the starter or just on the firewall solenoid or both? Thanks in advance Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213187#213187 **************AOL Search: Your one stop for directions, recipes and all other Holiday needs. Search Now. -aol-search/?ncid=emlcntussear00000001) ________________________________________________________________________________
Date: Nov 10, 2008
Subject: Fund Raiser List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics PO Box 347 Livermore CA 94551-0347 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Amperage draw
Date: Nov 10, 2008
Re: 601XL - Does anyone know the actual amperage draw for 1) the old style flap motor, 2) landing and taxi lights and 3) position lights. Thanks in advance Jay in Dallas ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
From: "Ashcraft, Keith - AES" <Keith.Ashcraft(at)itt.com>
Date: Nov 10, 2008
Subject: Zenith builders/flyers in the Portland area
All, I will be TDY in the Portland area around the last 2-weeks in November. Any flyers/builders in the area that would like to get together? (any model, 601, 701, 801, etc...) contact me offline Thanks, Keith http://picasaweb.google.com/ch701builder CH701 -- scratch N 38.9940 W 105.1305 Alt. 9,100' ________________________________ This e-mail and any files transmitted with it may be proprietary and are in tended solely for the use of the individual or entity to whom they are addr essed. If you have received this e-mail in error please notify the sender. Please note that any views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of ITT Corporati on. The recipient should check this e-mail and any attachments for the pres ence of viruses. ITT accepts no liability for any damage caused by any viru s transmitted by this e-mail. ________________________________________________________________________________
Subject: Re: Amperage draw
Date: Nov 10, 2008
I blew the fuse to the flap motor on the maiden flight. It was a 7A now it is a 15 amp without any problem. The current draw increases under flight loads. The 7 worked on the ground fine. The light circuits draw about 3 amps each. I fused them at 7. As long as you don't use a fuse larger than the wire size that supplies the device can handle, it will not be a problem. Fuel Pump 1.6 A, Ignition 3 A @ 3000 rpm Gary Ray 601XL 85 hrs. ----- Original Message ----- From: jaybannist(at)cs.com To: zenith601-list(at)matronics.com ; zenith-list(at)matronics.com Sent: Monday, November 10, 2008 9:37 AM Subject: Zenith-List: Amperage draw Re: 601XL - Does anyone know the actual amperage draw for 1) the old style flap motor, 2) landing and taxi lights and 3) position lights. Thanks in advance Jay in Dallas ------------------------------------------------------------------------- ----- Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: Nov 10, 2008
I reported these numbers to the list in April 2007. This was for the old-style motor with the exposed limit switches: "I measured the current drawn by the flap motor with and without a load. Unloaded it draws about 4 amps. Lifting a 34 pound bucket of sand it draws about 4.5 amps." -- Craig From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Gary Ray Sent: Monday, November 10, 2008 10:54 AM Subject: Re: Zenith-List: Amperage draw I blew the fuse to the flap motor on the maiden flight. It was a 7A now it is a 15 amp without any problem. The current draw increases under flight loads. The 7 worked on the ground fine. The light circuits draw about 3 amps each. I fused them at 7. As long as you don't use a fuse larger than the wire size that supplies the device can handle, it will not be a problem. Fuel Pump 1.6 A, Ignition 3 A @ 3000 rpm Gary Ray 601XL 85 hrs. ----- Original Message ----- From: jaybannist(at)cs.com Sent: Monday, November 10, 2008 9:37 AM Subject: Zenith-List: Amperage draw Re: 601XL - Does anyone know the actual amperage draw for 1) the old style flap motor, 2) landing and taxi lights and 3) position lights. Thanks in advance Jay in Dallas _____ Email message sent from CompuServe - visit us today at http://www.cs.com href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http ://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Nov 10, 2008
Actually my fuse blew the moment that I touched the switch so in my case I could not have hit a stop as the flaps did not deploy. At the time (first flight) I did not have it connected in series with an amperage meter. The plane landed fine without any flaps. I was not concerned. I found no problems with the wiring. I still have not measured the actual amperage during flap deployment. The flaps have functioned well during the last several hundred smoke tests. (turn it on and see where it smokes) Gary Ray ________________________________________________________________________________
Date: Nov 10, 2008
Motor circuits often have surge currents on start up that are more than double the steady state running current of the motor. The surge current will even be larger than the locked rotor current. The surge current is impossible to measure with a digital meter and even with an analog meter, the surge may peak out faster than the needle can follow. You need a device designed to measure these short duration peaks to get an accurate reading. If you fuse for the steady state current, these surges will eventually blow a normal fuse. The main purpose of a fuse is to protect the wire supplying the circuit so don't worry that the fuse value is larger than the current draw of the circuit as long as it's not too large for the wire. Landing lights also have surge currents on start up because the filament resistance increases as it heats up, so a landing light circuit may need a larger fuse than you suspect. On Nov 10, 2008, at 2:44 PM, jaybannist(at)cs.com wrote: > Craig, Thanks, that is just what I needed. > > I wonder why the difference between what you and Gary are reporting > for the flap motor draw? Could it be that Gary's flap hits the > physical stop plate before the actuator up limit switch clicks, > momentarily drawing excessive current? (I'm not sure that would be a > bad thing) > -- Bryan Martin N61BM, CH 601 XL, RAM Subaru, Stratus redrive. ________________________________________________________________________________
Date: Nov 10, 2008
I am guessing that it is those surge currents that are getting me.? I am not having any trouble with individual circuits.? Where I am blowing fuses is the feed to the Essential Bus.? I have the flaps on that bus.? I will increase the size of those fuses to what the wires can handle and see if that does the trick. Thanks - Jay -----Original Message----- From: Bryan Martin <bryanmmartin(at)comcast.net> Sent: Mon, 10 Nov 2008 4:50 pm Subject: Re: Zenith-List: Amperage draw Motor circuits often have surge currents on start up that are more than double the steady state running current of the motor. The surge current will even be larger than the locked rotor current. The surge current is impossible to measure with a digital meter and even with an analog meter, the surge may peak out faster than the needle can follow. You need a device designed to measure these short duration peaks to get an accurate reading. If you fuse for the steady state current, these surges will eventually blow a normal fuse. The main purpose of a fuse is to protect the wire supplying the circuit so don't worry that the fuse value is larger than the current draw of the circuit as long as it's not too large for the wire. Landing lights also have surge currents on start up because the?filament?resistance increases as it heats up, so a landing light circuit may need a larger fuse than you suspect. On Nov 10, 2008, at 2:44 PM, jaybannist(at)cs.com wrote: Craig,? Thanks, that is just what I needed. I wonder why the difference between what you and Gary are reporting for the flap motor draw?? Could it be that Gary's flap hits the physical stop plate before the actuator up limit switch clicks, momentarily drawing excessive current? (I'm not sure that would be a bad thing) --? Bryan Martin N61BM, CH 601 XL,? RAM?Subaru, Stratus redrive. ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: Nov 10, 2008
Jeff- Do you have a stainless or galvanized firewall? Bill ----- Original Message ----- From: Afterfxllc(at)aol.com To: zenith-list(at)matronics.com Sent: Sunday, November 09, 2008 9:37 PM Subject: Re: Zenith-List: Remote compass location Before I put the remote compass where I did I spoke to dynon about it and he said it isn't as sensitive as most think and the fact that I placed 2 of them within 12 inches of the fire wall and haven't had any problems quantify's that. If I had had problems with them I certainly wouldn't be building my 3rd and 4th panel that way. Jeff ------------------------------------------------------------------------- ----- AOL Search: Your one stop for directions, recipes and all other Holiday needs. Search Now. ________________________________________________________________________________
Date: Nov 10, 2008
galvanized Jeff- Do you have a stainless or galvanized firewall? Bill ----- Original Message ----- From: _Afterfxllc(at)aol.com_ (mailto:Afterfxllc(at)aol.com) Sent: Sunday, November 09, 2008 9:37 PM Subject: Re: Zenith-List: Remote compass location Before I put the remote compass where I did I spoke to dynon about it and he said it isn't as sensitive as most think and the fact that I placed 2 of them within 12 inches of the fire wall and haven't had any problems quantify's that. If I had had problems with them I certainly wouldn't be building my 3rd and 4th panel that way. Jeff **************AOL Search: Your one stop for directions, recipes and all other Holiday needs. Search Now. -aol-search/?ncid=emlcntussear00000001) ________________________________________________________________________________
Date: Nov 10, 2008
Subject: Fuse sizes - another point of view.
I decided to use fuses on my Zodiac XL. Further, I decided to use only fuse sizes in 5 amp increments - 5, 10, 15, etc. I did this for my convenience rather than a need to match exact current loads on each circuit. Fuses are disaster prevention devices rather than current regulators. A normal fuse will blow when exposed to the rated current for a very short time. A short circuit from power to ground will quickly draw a huge current, so a fuse of nearly any size will protect the wiring in that circuit. Wiring is not meant to melt at the rated current like fuses are. The normal standard for the current limit on any size wire is that current that will cause the temperature of the wire to increase by 10 degrees. It takes a whole lot more current than that to melt the wire. My other decision was to put the fuses behind the instrument panel, as is commonly done in cars, rather than some place the pilot can fool with them in flight. This was done for a number of reasons but two of them come to mind first. 1) In my many years of flying and driving I have never had a fuse or circuit breaker blow. 2) In the unusual case where a circuit does blow, I think it is unlikely that the problem will be found while flying. This should require a major repair on the circuit in question which can only be done on the ground. Perhaps it is appropriate for nearly all planes to have panels full of circuit breakers and emergency procedures that call for cycling the circuit breaker when an electrical failure occurs. This may be a life saver in hard IFR if the only thing that went wrong is the circuit breaker decided to trip for some random reason. In my case - mostly Day VFR - I figure I should focus on flying the plane rather than trouble shooting the electronics until the flight is over. Paul XL getting close (Retired Electrical Engineer) ________________________________________________________________________________
Date: Nov 10, 2008
Jeff- At this point I honest to God don't know what to think. Guess I'll try the tray and see if it works. Bill ----- Original Message ----- From: Afterfxllc(at)aol.com To: zenith-list(at)matronics.com Sent: Monday, November 10, 2008 6:36 PM Subject: Re: Zenith-List: Remote compass location galvanized Jeff- Do you have a stainless or galvanized firewall? Bill ----- Original Message ----- From: Afterfxllc(at)aol.com To: zenith-list(at)matronics.com Sent: Sunday, November 09, 2008 9:37 PM Subject: Re: Zenith-List: Remote compass location Before I put the remote compass where I did I spoke to dynon about it and he said it isn't as sensitive as most think and the fact that I placed 2 of them within 12 inches of the fire wall and haven't had any problems quantify's that. If I had had problems with them I certainly wouldn't be building my 3rd and 4th panel that way. Jeff ------------------------------------------------------------------------- ----- AOL Search: Your one stop for directions, recipes and all other Holiday needs. Search Now. ________________________________________________________________________________
Date: Nov 10, 2008
Well If you want you can talk to Pat or Ben ... They have flown behind them and they can tell you how well it works or don't work. Don't just take my word for it. Jeff **************AOL Search: Your one stop for directions, recipes and all other Holiday needs. Search Now. -aol-search/?ncid=emlcntussear00000001) ________________________________________________________________________________
Date: Nov 10, 2008
Jeff- You know where I'm coming from- I just don't want to have to do something over that will involve me tearing half the plane apart and standing on my head! Bill ----- Original Message ----- From: Afterfxllc(at)aol.com To: zenith-list(at)matronics.com Sent: Monday, November 10, 2008 7:13 PM Subject: Re: Zenith-List: Remote compass location Well If you want you can talk to Pat or Ben ... They have flown behind them and they can tell you how well it works or don't work. Don't just take my word for it. Jeff ------------------------------------------------------------------------- ----- AOL Search: Your one stop for directions, recipes and all other Holiday needs. Search Now. ________________________________________________________________________________
Date: Nov 10, 2008
I adjusted my flap limit switches to shut off just very slightly after the flap hits the stop. This puts a slight twist pressure on the flap to keep it rigid in flight. I popped several fuses (15 A.) during the adjustment process. As soon as the motor is stalled, the load is too great. I've had no problems at all with it in flight. Lynn 601XL / Corvair ________________________________________________________________________________
Date: Nov 10, 2008
Subject: 601 Aileron cable tension
Has the letter about wing/alieron flutter from AMD & Zac been mentioned on the list? Said to check aileron cable tension and the rivets on the doubler for the rear spar and that we should not fly until these were to standard. Seems as if they are pretty sure the loss of wing accidents were from flutter. **************AOL Search: Your one stop for directions, recipes and all other Holiday needs. Search Now. -aol-search/?ncid=emlcntussear00000001) ________________________________________________________________________________
From: "Dave VanLanen" <davevanlanen(at)sbcglobal.net>
Subject: Wire Size For VDO Fuel Senders
Date: Nov 10, 2008
I tried to find information on this in the archives, but was not successful. Can anyone tell me what size wire I should be using for the VDO fuel senders? From my reading, I understand that wire should be sized based on the current load of the device and any derating factor if placed in a bundle. However, there is no amperage information provided with the fuel senders. The only information I could find, in the assembly guide, is the variable resistance (from approx. 70 ohms at empty position to approx. 10 ohms at full position). Does the wire size actually depend on what I will be using on the other end for the fuel gauges? Thanks for any help you can provide, Dave Van Lanen 601XL ________________________________________________________________________________
Date: Nov 10, 2008
Is the wing flutter problem just on XL's or are the older 601HDS wings affected too? Roger _____ From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of JAPhillipsGA(at)aol.com Sent: Monday, November 10, 2008 9:44 PM Subject: Zenith-List: 601 Aileron cable tension Has the letter about wing/alieron flutter from AMD & Zac been mentioned on the list? Said to check aileron cable tension and the rivets on the doubler for the rear spar and that we should not fly until these were to standard. Seems as if they are pretty sure the loss of wing accidents were from flutter. _____ AOL Search: Your one stop for directions, recipes and all other Holiday <http://searchblog.aol.com/2008/11/04/happy-holidays-from-aol-search/?ncid=e ________________________________________________________________________________
Date: Nov 10, 2008
Subject: Re: Wire Size For VDO Fuel Senders
Hi Dave, The current load from your fuel sender can be calculated by taking the minimum resistance in ohms and dividing the voltage (14) by it. I suspect you will get something less than 1 amp. That would suggest you could use any size wire you want. However, you want wire that is strong enough mechanically to stand up to the rigors of flying around in your plane. This might suggest 16 awg or perhaps something down to 22 awg depending on how strong you think the wire should be and how well it is supported as it is routed from the fuel tank to the fuel gauge. In the end, it is just a coin flipper. Paul XL getting close At 08:27 PM 11/10/2008, you wrote: >I tried to find information on this in the archives, but was not >successful. Can anyone tell me what size wire I should be using for >the VDO fuel senders? From my reading, I understand that wire >should be sized based on the current load of the device and any >derating factor if placed in a bundle. However, there is no >amperage information provided with the fuel senders. The only >information I could find, in the assembly guide, is the variable >resistance (from approx. 70 ohms at empty position to approx. 10 >ohms at full position). Does the wire size actually depend on what >I will be using on the other end for the fuel gauges? > >Thanks for any help you can provide, > >Dave Van Lanen > >601XL ________________________________________________________________________________
Date: Nov 10, 2008
Hello Dave; I am using 16 gauge wire every where other than in places where high current is required. While this may be overkill I like the mechanical strength of that size of wire. John Read Phone: 303-648-3261 Fax: 303-648-3262 Cell: 719-494-4567 **************AOL Search: Your one stop for directions, recipes and all other Holiday needs. Search Now. -aol-search/?ncid=emlcntussear00000001) ________________________________________________________________________________
Date: Nov 10, 2008
Roger The only accident that I'm aware of involving HD type wings is the Bramley UK accident. The accident report gives the probable cause for that accident to be an over-stressed wing that apparently resulted from an abrupt climbing maneuver to avoid power lines. The accident report is the file G_YOXI.pdf in the ZBAG file section: http://groups.yahoo.com/group/ZBAG/files/ There is no mention of flutter. Terry >Is the wing flutter problem just on XL's or are the older 601HDS wings >affected too? > > >Roger Terry Phillips ZBAGer ttp44~at~rkymtn.net Corvallis MT 601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons are done; working on the wings http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: Nov 10, 2008
Given the minimal current flow the limiting factor will be a wire big enough to reliably crimp a connector onto. -- Craig From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Dave VanLanen Sent: Monday, November 10, 2008 9:27 PM Subject: Zenith-List: Wire Size For VDO Fuel Senders I tried to find information on this in the archives, but was not successful. Can anyone tell me what size wire I should be using for the VDO fuel senders? From my reading, I understand that wire should be sized based on the current load of the device and any derating factor if placed in a bundle. However, there is no amperage information provided with the fuel senders. The only information I could find, in the assembly guide, is the variable resistance (from approx. 70 ohms at empty position to approx. 10 ohms at full position). Does the wire size actually depend on what I will be using on the other end for the fuel gauges? Thanks for any help you can provide, Dave Van Lanen 601XL ________________________________________________________________________________
Date: Nov 11, 2008
There are also different types of fuses, but generally they are slow and fast acting fuses. Make sure that you have the slow acting type for a motor circuit. The inrush current of DC motors is 10 or more times the steady current draw or so, but only for milliseconds or at least a pretty short time. The fast acting ones will blow on high inrush currents as they are made to protect delicate electronics and not the wiring. The slow acting type will not blow on inrush if the circuit is OK and you have chosen the correct rating. They are rated by % overload VS time, the mfg should have this info on their website. Kevin -------- Mark Twain: Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213473#213473 ________________________________________________________________________________
Date: Nov 11, 2008
Subject: Re: 601 Aileron cable tension
Rogar, the letter referred to 601 and 650 airplanes, Bill **************AOL Search: Your one stop for directions, recipes and all other Holiday needs. Search Now. -aol-search/?ncid=emlcntussear00000001) ________________________________________________________________________________
Date: Nov 11, 2008
Hi Roger, I believe wing flutter is only suspected, but never confirmed on the XL. The condition has never been reported on a HDS to my recollection. With the thicker wing and section strength, you'd probably have to be in an extended dive straight down to get flutter on the HDS. Larry McFarland 601HDS at www.macsmachine.com Roger & Lina Hill wrote: > > Is the wing flutter problem just on XLs or are the older 601HDS wings > affected too? > > Roger > ________________________________________________________________________________
Date: Nov 11, 2008
Subject: Re: Amperage Draw
The current-carrying capacity of wires is listed as: 18 A.W.G. (5 amp. in flexible wire (A.W.G. = American wire gauge), 16 A.W.G. (7 amp.) and 14 A.W.G. (15 amp.). For all routine wiring, use 18 A.W.G. aircraft wire - it is strong enough. Use a fuse matched to the device you are running; allow a 50% overrun. This assumes the device has an amperage rating less than the wire supplying it. For delicate things, 20 A.W.G. may be enough. For starter motors, etc., much bigger gauge is needed - as big as you can reasonably use. And, use SLOW-BLOW fuses which will stand a bit of a surge, not fast-blow. John Goodings, C-FGPJ, CH601HD with R912S, Ottawa/Carp/Toronto. ________________________________________________________________________________
Date: Nov 11, 2008
I dove my HDS to 160 MPH during phase 1 testing, 5 MPH increase at a time. A non-event, other than a shorts change. -- Leo Gates N601Z - CH601HDS TDO Rotax 912UL LarryMcFarland wrote: > > > Hi Roger, > I believe wing flutter is only suspected, but never confirmed on the XL. > The condition has never been reported on a HDS to my recollection. With > the thicker wing and section strength, you'd probably have to be in an > extended > dive straight down to get flutter on the HDS. > > Larry McFarland 601HDS at www.macsmachine.com > > Roger & Lina Hill wrote: >> >> Is the wing flutter problem just on XLs or are the older 601HDS >> wings affected too? >> >> Roger >> ________________________________________________________________________________
From: Grant Corriveau <grant.corriveau(at)TELUS.NET>
Subject: Wires and fuses and such
Date: Nov 11, 2008
Shouldn't fuses/cbs be matched to protect the wire in the circuit? So matching the fuse to the amp draw of the load item seems to be skipping a step - no? The wire gauge should be selected to match the load, cooling requirements, distance of the run, voltage loss over that distance etc. Then the fuse/cb is matched to the wire gauge. Isn't that the way it's "supposed" to be done? Having said that, after wiring my plane according to Bob Nucholl's excellent manual, if I did it over again I might do like most car manufacturers do and use nothing less than 16 gauge wire w 10 amp fuses. This would vastly simplify the whole thing, simplify the fuse layout/ need for extras; and would add only a negligible amount of weight on a simple aircraft like this. fwiw Grant C-GHTF w/ CAM100 (now into winter works projects/upgrades) ________________________________________________________________________________
Date: Nov 11, 2008
WE HAVE A VETERN PILOT ON THE FIELD THAT HAS CONFIRMED FLUTTER AND LUCKLY GO T IT BACK UNDER CONTROL BEFORE ANY DAMAGE OCCURED AIRCRAFT WAS 601XL Pat -----Original Message----- From: Leo Gates <leo(at)zuehlfield.com> Sent: Tue, 11 Nov 2008 11:54 am Subject: Re: Zenith-List: 601 Aileron cable tension =C2- I dove my HDS to 160 MPH during phase 1 testing, 5 MPH increase at a time. A non-event, other than a shorts change.=C2- -- =C2- Leo Gates=C2- N601Z - CH601HDS TDO=C2- Rotax 912UL=C2- =C2- LarryMcFarland wrote:=C2- =C2- >=C2- >=C2- > Hi Roger,=C2- > I believe wing flutter is only suspected, but never confirmed on the XL. =C2- > The condition has never been reported on a HDS to my recollection. With =C2- > the thicker wing and section strength, you'd probably have to be in an > e xtended=C2- > dive straight down to get flutter on the HDS.=C2- >=C2- > Larry McFarland 601HDS at www.macsmachine.com=C2- >=C2- > Roger & Lina Hill wrote:=C2- >>=C2- >> Is the wing flutter problem just on XL=99s or are the older 601HDS >> wings affected too?=C2- >>=C2- >> Roger=C2- >>=C2- =C2- ============C2- ============C2- ============C2- ============C2- =C2- ________________________________________________________________________________
Date: Nov 11, 2008
Subject: Nicopress tools?
In putting the tail section together on my 601XL, I realized that I am gett ing close to rigging up all the cables.- I have been trying to find the b est solution for the Nicopress tool for the cable sleeves.- Any recommend ations?- And what size press do I need as I have been looking for them on Ebay?- Some of them list an "M" jaw size with an oval for 1/8" cables? - Anybody have one they would like to sell?- And where can I get inform ation on building a cable tensioner indicating device? Don Mountain =0A=0A=0A ________________________________________________________________________________
Date: Nov 11, 2008
Subject: Re: Wires and fuses and such
Hi Grant, I think your procedure is OK but a bit of overkill. It would work, but so would using fuses that are sufficiently large to not blow under normal use. For example, a 10 amp fuse will do a fine job on a circuit that only draws 1 amp under normal use. I have separate fuses for each major electrical or electronic device. I put them in nice little fuse blocks I got from NAPA. My idea is if a fuse blows then it only takes out one device and repairs should be delayed until after the flight is over. That means I mounted the fuse blocks behind the instrument panel, the way it is normally done in cars, rather than cluttering the panel front with them. Paul XL getting close At 09:27 AM 11/11/2008, you wrote: > >Shouldn't fuses/cbs be matched to protect the wire in the circuit? >So matching the fuse to the amp draw of the load item seems to be >skipping a step - no? > >The wire gauge should be selected to match the load, cooling >requirements, distance of the run, voltage loss over that distance >etc. Then the fuse/cb is matched to the wire gauge. Isn't that the >way it's "supposed" to be done? > >Having said that, after wiring my plane according to Bob Nucholl's >excellent manual, if I did it over again I might do like most car >manufacturers do and use nothing less than 16 gauge wire w 10 amp >fuses. This would vastly simplify the whole thing, simplify the fuse >layout/ need for extras; and would add only a negligible amount of >weight on a simple aircraft like this. > >fwiw >Grant >C-GHTF w/ CAM100 ________________________________________________________________________________
Date: Nov 11, 2008
Subject: Re: Nicopress tools?
Hi Don, I've been using the Swage-it tool. It costs less than $20 at A/S. Here is a link: http://www.aircraftspruce.com/catalog/topages/swagingtool.php I would suggest you order a few extra sleeves to practice with. On the cable tension, I was planning to build one of the measuring tools but with all the noise related to wing separations I decided to buy the lower priced one (around $190) instead. Good luck, Paul XL getting close At 09:53 AM 11/11/2008, you wrote: >In putting the tail section together on my 601XL, I realized that I >am getting close to rigging up all the cables. I have been trying >to find the best solution for the Nicopress tool for the cable >sleeves. Any recommendations? And what size press do I need as I >have been looking for them on Ebay? Some of them list an "M" jaw >size with an oval for 1/8" cables? Anybody have one they would like >to sell? And where can I get information on building a cable >tensioner indicating device? > >Don Mountain ________________________________________________________________________________
Date: Nov 11, 2008
Don - I used the Economy Swaging tool from Aircraft Spruce (http://www.aircraftspruce.com/catalog/topages/swagingtool.php), its only $18.65 and seemed to work well with the 1/8" cables on my 601XL. Be sure to get the nicopress gauge to test your crimped sleeves as well. Larry McFarland at http://www.macsmachine.com/ has info on building your own cable tension device. Good Luck, John Davis 601XL - Jab 3300 Ready for first Flight... Don Mountain wrote: > In putting the tail section together on my 601XL, I realized that I am > getting close to rigging up all the cables. I have been trying to > find the best solution for the Nicopress tool for the cable sleeves. > Any recommendations? And what size press do I need as I have been > looking for them on Ebay? Some of them list an "M" jaw size with an > oval for 1/8" cables? Anybody have one they would like to sell? And > where can I get information on building a cable tensioner indicating > device? > > Don Mountain > > > * > > * ________________________________________________________________________________
Date: Nov 11, 2008
-----Original Message----- From: LarryMcFarland <larry(at)macsmachine.com> Sent: Tue, 11 Nov 2008 10:38 am Subject: Re: Zenith-List: 601 Aileron cable tension =C2- =C2- Hi Roger,=C2- I believe wing flutter is only suspected, but never confirmed on the XL.=C2 - The condition has never been reported on a HDS to my recollection. With=C2 - the thicker wing and section strength, you'd probably have to be in an exten ded=C2- dive straight down to get flutter on the HDS.=C2- =C2- Larry McFarland 601HDS at www.macsmachine.com=C2- =C2- Roger & Lina Hill wrote:=C2- >=C2- > Is the wing flutter problem just on XL=99s or are the older 601HDS w ings > affected too?=C2- >=C2- > Roger=C2- >=C2- =C2- =C2- ============C2- ============C2- ============C2- ============C2- =C2- ________________________________________________________________________________
Date: Nov 11, 2008
I made a cable tension gauge like the one shown on Larry Macs website. It works but needs calibration... I ll give it to you, just pay $10 shipping.. notsew_evets(at)frontiernet.net Steve ----- Original Message ----- From: Don Mountain To: Zenith Sent: Tuesday, November 11, 2008 10:53 AM Subject: Zenith-List: Nicopress tools? In putting the tail section together on my 601XL, I realized that I am getting close to rigging up all the cables. I have been trying to find the best solution for the Nicopress tool for the cable sleeves. Any recommendations? And what size press do I need as I have been looking for them on Ebay? Some of them list an "M" jaw size with an oval for 1/8" cables? Anybody have one they would like to sell? And where can I get information on building a cable tensioner indicating device? Don Mountain 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Nov 11, 2008
Pat , Which model Zenith do you fly ??? S. ----- Original Message ----- From: passpat(at)aol.com To: zenith-list(at)matronics.com ; a300cpt(at)bellsouth.net Sent: Tuesday, November 11, 2008 10:47 AM Subject: Re: Zenith-List: 601 Aileron cable tension WE HAVE A VETERN PILOT ON THE FIELD THAT HAS CONFIRMED FLUTTER AND LUCKLY GOT IT BACK UNDER CONTROL BEFORE ANY DAMAGE OCCURED AIRCRAFT WAS 601XL Pat -----Original Message----- From: Leo Gates <leo(at)zuehlfield.com> To: zenith-list(at)matronics.com Sent: Tue, 11 Nov 2008 11:54 am Subject: Re: Zenith-List: 601 Aileron cable tension I dove my HDS to 160 MPH during phase 1 testing, 5 MPH increase at a time. A non-event, other than a shorts change. -- Leo Gates N601Z - CH601HDS TDO Rotax 912UL LarryMcFarland wrote: > > > Hi Roger, > I believe wing flutter is only suspected, but never confirmed on the XL. > The condition has never been reported on a HDS to my recollection. With > the thicker wing and section strength, you'd probably have to be in an > extended > dive straight down to get flutter on the HDS. > > Larry McFarland 601HDS at www.macsmachine.com > > Roger & Lina Hill wrote: >> >> Is the wing flutter problem just on XL=99s or are the older 601HDS >> wings affected too? >> >> Roger >> =========== nk>http://www.matronics.com/contribution =========== et=_blank>http://www.matronics.com/Navigator?Zenith-List =========== /forums.matronics.com =========== ------------------------------------------------------------------------- ----- Instant access to the latest & most popular FREE games while you b00075x1212904500x1200818240/aol?redir=http://toolbar.aol.com/games/dow nload.html?ncid=emlweusdown00000004">Download Now! ________________________________________________________________________________
Date: Nov 11, 2008
there still is not concrete evidence there is a flutter issue on any of the models. The AD is an advisory, on any of the aircraft and is recommending that people tension the cables AS PER THE PLANS YOU ARE SUPPOSED TO FOLLOW IN THE BUILD PROCESS (REFER TO PLANS) Juan -----Original Message----- >From: Terry Phillips <ttp44(at)rkymtn.net> >Sent: Nov 11, 2008 12:05 AM >To: zenith-list(at)matronics.com >Subject: RE: Zenith-List: 601 Aileron cable tension > >Roger > >The only accident that I'm aware of involving HD type wings is the Bramley >UK accident. The accident report gives the probable cause for that accident >to be an over-stressed wing that apparently resulted from an abrupt >climbing maneuver to avoid power lines. The accident report is the file >G_YOXI.pdf in the ZBAG file section: > >http://groups.yahoo.com/group/ZBAG/files/ > >There is no mention of flutter. > >Terry > > > >>Is the wing flutter problem just on XL's or are the older 601HDS wings >>affected too? >> >> >> >>Roger > > >Terry Phillips ZBAGer >ttp44~at~rkymtn.net >Corvallis MT >601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons >are done; working on the wings >http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: Nov 11, 2008
Aileron flutter is different from wing flutter. I vote its been aileron cable tension that causes the problems. Any unbalanced control surface will act unusual at speeds without the cables tight. Look at the Piper J 3.. SW ----- Original Message ----- From: "Juan Vega" <amyvega2005(at)earthlink.net> Sent: Tuesday, November 11, 2008 11:58 AM Subject: RE: Zenith-List: 601 Aileron cable tension > > there still is not concrete evidence there is a flutter issue on any of > the models. The AD is an advisory, on any of the aircraft and is > recommending that people tension the cables AS PER THE PLANS YOU ARE > SUPPOSED TO FOLLOW IN THE BUILD PROCESS (REFER TO PLANS) > > Juan > > -----Original Message----- >>From: Terry Phillips <ttp44(at)rkymtn.net> >>Sent: Nov 11, 2008 12:05 AM >>To: zenith-list(at)matronics.com >>Subject: RE: Zenith-List: 601 Aileron cable tension >> >>Roger >> >>The only accident that I'm aware of involving HD type wings is the Bramley >>UK accident. The accident report gives the probable cause for that >>accident >>to be an over-stressed wing that apparently resulted from an abrupt >>climbing maneuver to avoid power lines. The accident report is the file >>G_YOXI.pdf in the ZBAG file section: >> >>http://groups.yahoo.com/group/ZBAG/files/ >> >>There is no mention of flutter. >> >>Terry >> >> >> >> >> >>>Is the wing flutter problem just on XL's or are the older 601HDS wings >>>affected too? >>> >>> >>> >>>Roger >> >> >>Terry Phillips ZBAGer >>ttp44~at~rkymtn.net >>Corvallis MT >>601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons >>are done; working on the wings >>http://www.mykitlog.com/N47TP/ > > > ________________________________________________________________________________
Date: Nov 11, 2008
does not mean its adesign flaw, it just tells me the cables were not properly tightened. Juan -----Original Message----- >From: steve <notsew_evets(at)frontiernet.net> >Sent: Nov 11, 2008 1:56 PM >To: zenith-list(at)matronics.com >Subject: Re: Zenith-List: 601 Aileron cable tension > >Pat , Which model Zenith do you fly ??? > >S. > ----- Original Message ----- > From: passpat(at)aol.com > To: zenith-list(at)matronics.com ; a300cpt(at)bellsouth.net > Sent: Tuesday, November 11, 2008 10:47 AM > Subject: Re: Zenith-List: 601 Aileron cable tension > > > WE HAVE A VETERN PILOT ON THE FIELD THAT HAS CONFIRMED FLUTTER AND LUCKLY GOT IT BACK UNDER CONTROL BEFORE ANY DAMAGE OCCURED AIRCRAFT WAS 601XL > > Pat > > > -----Original Message----- > From: Leo Gates <leo(at)zuehlfield.com> > To: zenith-list(at)matronics.com > Sent: Tue, 11 Nov 2008 11:54 am > Subject: Re: Zenith-List: 601 Aileron cable tension > > > > I dove my HDS to 160 MPH during phase 1 testing, 5 MPH increase at a time. A non-event, other than a shorts change. > -- > Leo Gates > N601Z - CH601HDS TDO > Rotax 912UL > > LarryMcFarland wrote: > > > > > > Hi Roger, > > I believe wing flutter is only suspected, but never confirmed on the XL. > > The condition has never been reported on a HDS to my recollection. With > > the thicker wing and section strength, you'd probably have to be in an > extended > > dive straight down to get flutter on the HDS. > > > > Larry McFarland 601HDS at www.macsmachine.com > > > > Roger & Lina Hill wrote: > >> > >> Is the wing flutter problem just on XLs or are the older 601HDS >> wings affected too? > >> > >> Roger > >> > > =========== > nk>http://www.matronics.com/contribution > =========== > et=_blank>http://www.matronics.com/Navigator?Zenith-List > =========== > /forums.matronics.com > =========== > > > >------------------------------------------------------------------------------ > Instant access to the latest & most popular FREE games while you b00075x1212904500x1200818240/aol?redir=http://toolbar.aol.com/games/download.html?ncid=emlweusdown00000004">Download Now! > > ________________________________________________________________________________
Date: Nov 11, 2008
make a guage and use a nico presss from Home Depot. check the press with your guage. 1/8 inch i believe. -----Original Message----- >From: steve <notsew_evets(at)frontiernet.net> >Sent: Nov 11, 2008 1:53 PM >To: zenith-list(at)matronics.com >Subject: Re: Zenith-List: Nicopress tools? > >I made a cable tension gauge like the one shown on Larry Macs website. It works but needs calibration... >I ll give it to you, just pay $10 shipping.. >notsew_evets(at)frontiernet.net >Steve > ----- Original Message ----- > From: Don Mountain > To: Zenith > Sent: Tuesday, November 11, 2008 10:53 AM > Subject: Zenith-List: Nicopress tools? > > > In putting the tail section together on my 601XL, I realized that I am getting close to rigging up all the cables. I have been trying to find the best solution for the Nicopress tool for the cable sleeves. Any recommendations? And what size press do I need as I have been looking for them on Ebay? Some of them list an "M" jaw size with an oval for 1/8" cables? Anybody have one they would like to sell? And where can I get information on building a cable tensioner indicating device? > > Don Mountain > > > >3D============================================ >3D============================================ >3D============================================ >3D============================================ ________________________________________________________________________________
Date: Nov 11, 2008
Subject: Cable Tensions for 601XL?
I am in the rigging stage for my 601XL, and can't find any references to wh at the cable tensions are supposed to be in the plans or manual.- What ar e all the cables supposed to be tensioned to and where may I find this info rmation on the 601XL plans or specifications? Don Mountain =0A=0A=0A ________________________________________________________________________________
Date: Nov 11, 2008
Don- The ACS swaging tool works fine, but you'll probably have carpal tunnel by the time you're done. Bill ----- Original Message ----- From: "Paul Mulwitz" <psm(at)att.net> Sent: Tuesday, November 11, 2008 1:08 PM Subject: Re: Zenith-List: Nicopress tools? > > Hi Don, > > I've been using the Swage-it tool. It costs less than $20 at A/S. Here > is a link: > http://www.aircraftspruce.com/catalog/topages/swagingtool.php > > I would suggest you order a few extra sleeves to practice with. > > On the cable tension, I was planning to build one of the measuring tools > but with all the noise related to wing separations I decided to buy the > lower priced one (around $190) instead. > > Good luck, > > Paul > XL getting close > > At 09:53 AM 11/11/2008, you wrote: > >>In putting the tail section together on my 601XL, I realized that I am >>getting close to rigging up all the cables. I have been trying to find >>the best solution for the Nicopress tool for the cable sleeves. Any >>recommendations? And what size press do I need as I have been looking for >>them on Ebay? Some of them list an "M" jaw size with an oval for 1/8" >>cables? Anybody have one they would like to sell? And where can I get >>information on building a cable tensioner indicating device? >> >>Don Mountain > > > ________________________________________________________________________________
Date: Nov 11, 2008
Subject: Countersinking tool and thread chaser for 601XL fuel tank filler
neck Where can I buy, borrow, steal, or rent a countersinking tool and thread chaser for the fuel tank filler neck for the 601XL? ________________________________________________________________________________
Date: Nov 11, 2008
Subject: Re: Cable Tensions for 601XL?
check the page with the cable rigging, its says 30 lbs. that is inch lbs i believe, or 4 ft lbs. Juan -----Original Message----- >From: Don Mountain <mountain4don(at)yahoo.com> >Sent: Nov 11, 2008 6:20 PM >To: Zenith >Subject: Zenith-List: Cable Tensions for 601XL? > >I am in the rigging stage for my 601XL, and can't find any references to what the cable tensions are supposed to be in the plans or manual. What are all the cables supposed to be tensioned to and where may I find this information on the 601XL plans or specifications? > >Don Mountain > > ________________________________________________________________________________
Date: Nov 11, 2008
They just posted a great guide on the builder site at zenith. Go to the Zenith Aircraft Builder Pages, click on "for important notices and other building and flying information." then click on the link next to Zenair Safety Alert "Photo guide: How to check the control cable tension of your Zodiac" I would like to just post the link but I promised Zenith I wouldn't. -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213616#213616 ________________________________________________________________________________
Subject: Re: Countersinking tool and thread chaser for 601XL fuel
tank fi
Date: Nov 11, 2008
Contact Zenith and get on the list to get the Big Tap. I used it and it only took minutes to fix it up. Here is my log entry that shows what came in the package: http://mykitlog.com/users/display_log.php?user=rlendon&project=113&category=0&log=39171&row=192 -------- Ron Lendon, Clinton Township, MI Corvair Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213617#213617 ________________________________________________________________________________
Date: Nov 11, 2008
Hi Juan, I think you are confusing cable tension with torque. My take on 30 pounds of tension is the amount of tension (pull) you get when the cable is holding up a 30 pound weight. I just got the tensiometer shown in the AD from Aircraft Spruce and measured the rudder and elevator cables I already have installed (my wings are not yet on the plane). My results setting the cable tension with no instruments at all were very close to the desired ones. The rudder was 7 pounds high and the elevator was 2 pounds low. Perhaps that is why Chris Heintz originally suggested we didn't really need the fancy instrument to rig the cables. Paul XL getting close At 07:32 PM 11/11/2008, you wrote: >check the page with the cable rigging, its says 30 lbs. that is inch >lbs i believe, or 4 ft lbs. > >Juan ________________________________________________________________________________
Subject: Nov 7th and 9th updates on Zenith European groundings
Date: Nov 11, 2008
>From http://www.zenairulm.com/News/index_files/Page505.htm Nov 7th: "For many owners of the presently grounded CH 601 XL in Europe, evidence of progress with the current investigation has been disappointingly slim for the last week. This is also the case for Zenair Europe. The response from Dutch authorities to our repeated inquiries has been consistent: "The investigation is on-going". Our offer to provide input has been politely declined, as has our request to inspect the accident aircraft, as has our offer to fly designer Chris Heintz to Holland to answer engineering questions. Other Civilian Aviation Authorities (CAA) have also attempted to obtain additional details, to no avail. Adding to the frustration: Due to the complete lack of information being released, even between agencies, the CAA of a number of additional countries have felt compelled to adopt the Dutch "emergency" action: To our knowledge, the Czech Republic, Greece and Spain all grounded their CH 601 XL fleets this week. A number of offices we are in contact with regret at having to ground the aircraft, but until the Dutch Safety Board reveals the basis for its allegation that the "design calculations by the designer were probably too optimistic", they have little choice but to err on the side of caution. Another unexpected twist this week came from the UK: In the UK, where the CH 601 XL is considered an Experimental amateur-built design (it is not a certified ultralight there like in the rest of Europe), the LAA did not feel that grounding the aircraft was justified based on the available information from the Netherlands (see our update of October 30). Now aware, however, (via our bulletin #ZE-2008-001) that aileron flutter is a remote possibility if control cables are loose, the LAA has grounded the XL fleet in the UK until it has been demonstrated that the aircraft will remain flutter-free throughout the range of its flight envelope, even with cable tensions set at their lowest approved tolerances. In the original rational which accompanies their "Emergency Airworthiness Directive" (grounding), Dutch authorities cite "seven similar accidents worldwide that have not been explained" [paraphrased]. A number of builders have pointed out the inaccuracy of this claim as well as the absurdity of using it to justify the current grounding. Zenair has tried to convey this message and hopes that it was heard. We thank Dutch CH 601 XL owner and pilot Hans Oosterhoff for researching these accidents and for sending us a summary of his findings; it will be included in our next update." The Nov 9th update nicely summarizes many of the accidents around the world. One twist I didn't know about the crash in Spain: "Accident in Spain (05/02/2008): According to eyewitnesses, wing fractured after an explosion. Additional context from Zenair dealer in Spain: accident occurred after a high-speed pass and pull-up over a football field where a family member of passenger was playing. Based on findings, Accident Investigation Committee estimated high speed pass of approx. 290 Km/h*. (Source: http://www.ultraligero.net/Accidentes/08.htm and Zenair correspondence) (CZAW-ULM) *Note: VNE = 260km/h" By my calculations 290 Km/h would be 180.1 mph. -- Craig ________________________________________________________________________________
Date: Nov 11, 2008
Hello all... update on my cable tensions... my rudder cable tensions had to be adjusted today... although my IA set the aileron and elevator tensions to the high range of the AD/service letter, he left the rudder tension alone at 27 pounds--his notes seemed to indicate the tension got less as the prop was placed in a sling. The tension should increase not decrease. I checked the tensions today and they were 27 with weight on the nose, 33 with the prop lifted by hand and nearly 40 with the nose gear stop plate at rest. Now, they have been adjusted to 25 with the stop plate at rest, but only 12-13 sitting on the tarmac. The O-200a with a metal prop is fairly heavy so the nose gear stop plate (for those of us with the older nose strut) is raised about 3/4" at rest. Thanks to all who questioned my last posting of rudder tension numbers off line. Happy Veteran's Day to all of you veterans out there--thank you for giving my generation the opportunities we enjoy. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213631#213631 ________________________________________________________________________________
Date: Nov 12, 2008
> check the page with the cable rigging, its says 30 lbs. that is inch lbs i > believe, or 4 ft lbs. No, that's 30 pounds cable tension, not torque (what would it be torque *on*?). -- Jay Maynard, K5ZC, PP-ASEL http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml ________________________________________________________________________________
Date: Nov 11, 2008
"No, that's 30 pounds cable tension, not torque " Jay, what page (letter/number) of your plans are you referring to. I did not know they handed out plans with the S-LSA. That is cool. So too, what revision date is on the page you refer to. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213637#213637 ________________________________________________________________________________
Date: Nov 12, 2008
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle PO Box 347 Livermore, CA 94551-0347 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Re: HDS overspeed tests
Date: Nov 12, 2008
For the guys with HDS's out there, I flew my bird to 10% over Vne (160 mph + 16 mph = 176 mph) in still air and lightly tapped the stick in all 4 directions. No flutter or other problems. Glad that's over with! Clear Skies! Chuck Long Zodie Rocket N601LE, 180 hr TT ________________________________________________________________________________
Date: Nov 12, 2008
Hello Paul, I agree with you that messing with fuses in flight seems a hazardous activity and only should be considered if really needed. But I have a question regarding you clean solution of placing the fuses out of sight. The FAR Sec. 23.1357 Circuit protective devices. says: "(d) If the ability to reset a circuit breaker or replace a fuse is essential to safety in flight, that circuit breaker or fuse must be so located and identified that it can be readily reset or replaced in flight.". Do you know how a DAR would interpret the above rule with respect to you panel design? Clearly the word open for interpretation is "safety in flight", would you consider all electrical systems served by the fuses to fall outside the safety in flight category? Regards, Maarten plans building XL, getting close to closing the second wing > From: Paul Mulwitz <psm(at)att.net> > Subject: Re: Zenith-List: Wires and fuses and such > > Hi Grant, > > I think your procedure is OK but a bit of overkill. It would work, > but so would using fuses that are sufficiently large to not blow > under normal use. For example, a 10 amp fuse will do a fine job on a > circuit that only draws 1 amp under normal use. > > I have separate fuses for each major electrical or electronic > device. I put them in nice little fuse blocks I got from NAPA. > > My idea is if a fuse blows then it only takes out one device and > repairs should be delayed until after the flight is over. That means > I mounted the fuse blocks behind the instrument panel, the way it is > normally done in cars, rather than cluttering the panel front with them. > > Paul > XL getting close ________________________________________________________________________________
Date: Nov 12, 2008
Mr. Haas, The problem here is that I am sending someone else up in my aircraft every time I authorize a new test flight. It is a very serious task, especially the first flight after each XL fatality. The rudder tension numbers bothered me and that is why I did not sign the aircraft off for the next flight until I figured it out. (Remember now, the IA did not adjust the rudder tensions.) I posted the numbers here and you guys, albeit off list, confirmed my problem with the numbers. Since I have 33% more bearing surface than you guys on the rudder, 5 more pounds of tension than the Haas 30 +/- 5 is nominal, but not optimal. Most newer, light-engine 601s have a higher 'at rest' rudder tension because the stop plate is at or nearly at rest. My nose heavy aircraft, and those with more time on their bungee will see their at rest rudder tensions drop. Each of us should expect a different at rest value and something other than my 12-13 pound differential between rest and flight. Although I know my particular airframe "at rest" better than anyone, and had to defend my modifications to it during hours of meetings last December and January, since I have never flown it or in it, I have to rely upon others in situations involving the feel of the aircraft in flight. For example, the rudder is often described in post-flight briefings as heavy, the ailerons medium and the elevator light as compared to my Cessna 150L. My test pilot actually flies my C150L first and then flies the Sabrina. Although they are different animals, they do share many features including a common engine/prop. This nearly contemporaneous comparison gives me the only "feel" I have for the Sabrina in flight and takes away the "local conditions" factor that might otherwise taint the comparison. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213742#213742 ________________________________________________________________________________
Date: Nov 12, 2008
Hello group ,I have been reading the posts concerning the cable tensions ,this should help in correcting the flutter problem (if there is one) .While building my 601XL I did not even consider installing aileron trim .Yes I did use elevator trim .Don't know if this qualifies me in any way ,however I have been flying/maintaining and building planes for 48 years have A/P/ and I/A ratings .We were always taught to rebalance control surfaces after painting .If a little paint will add to flutter what would the weight of an added trim + servo+ hinge do for the balance .It may pay for the readers of this post to break out their AC 43.13-1B acceptable methods techniques, and practices and read 4-36 flutter and vibration precautions . I am certain several will disagree with my post but I urge you to read the AC43.13-1B . Wade Jones South Texas 601XL Franklin 0-235 ----- Original Message ----- From: "Paul Mulwitz" <psm(at)att.net> Sent: Tuesday, November 11, 2008 9:48 PM Subject: Re: Zenith-List: Cable Tensions for 601XL? > > Hi Juan, > > I think you are confusing cable tension with torque. > > My take on 30 pounds of tension is the amount of tension (pull) you get > when the cable is holding up a 30 pound weight. > > I just got the tensiometer shown in the AD from Aircraft Spruce and > measured the rudder and elevator cables I already have installed (my wings > are not yet on the plane). My results setting the cable tension with no > instruments at all were very close to the desired ones. The rudder was 7 > pounds high and the elevator was 2 pounds low. Perhaps that is why Chris > Heintz originally suggested we didn't really need the fancy instrument to > rig the cables. > > Paul > XL getting close > > > At 07:32 PM 11/11/2008, you wrote: > >>check the page with the cable rigging, its says 30 lbs. that is inch lbs i >>believe, or 4 ft lbs. >> >>Juan > > > ________________________________________________________________________________
Date: Nov 12, 2008
Hi Maarten, I guess the regulation you cited explains why so many panels are crowded with circuit breakers. In their great wisdom, the FAA seems to have dictated that solution. Fortunately, I don't think part 23 regulations apply to experimental - amateur built airplanes. This may be one of many examples of the notion that the FAA regulations are overly restrictive on certified planes. To directly answer your question, my plans are to limit my flights to Day/VFR. I suspect I could safely conduct such flights without any electrical equipment operating at all. The only really essential piece of electrical gear is the starter motor. My Jabiru is not likely to start any other way. Best regards, Paul At 06:34 AM 11/12/2008, you wrote: >Hello Paul, > >I agree with you that messing with fuses in flight seems a hazardous >activity and >only should be considered if really needed. But I have a question >regarding you >clean solution of placing the fuses out of sight. >The FAR Sec. 23.1357 Circuit protective devices. says: "(d) If the >ability to reset >a circuit breaker or replace a fuse is essential to safety in >flight, that circuit breaker >or fuse must be so located and identified that it can be readily >reset or replaced in >flight.". >Do you know how a DAR would interpret the above rule with respect to you >panel design? Clearly the word open for interpretation is "safety in >flight", would >you consider all electrical systems served by the fuses to fall >outside the safety >in flight category? > >Regards, > Maarten > plans building XL, getting close to closing the second wing ________________________________________________________________________________
Date: Nov 12, 2008
"I did use elevator trim." Wade, Personally, the elevator trim weight bothered me more than the aileron trim. The ailerons, by their nature of one being up and one down, should, if properly tensioned, be easier to dampen in flight than a fluttering elevator. So too, a builder can easily adjust an XL's horizontal stabilizer for proper cruise configuration since it sits so high off the longerons. The aileron trim was a much easier call for me than the elevator trim. If no aileron trim under Par. 4-36, why elevator trim? As to Par 4-36(c) was it the Cardinal that used foam in the elevator trim tab that took on water/ice and threw it off balance? Has anyone had to drill a weep hole in their elevator trim tab to make sure ice does not build up? I ended up gust-locking my elevator in the up position rather than down to keep the ice out. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213753#213753 ________________________________________________________________________________
Date: Nov 12, 2008
I knew someone would ask ,if no aileron trim why elevator trim .My answer how many elevator failures has the 601XL had . Wade Jones South Texas 601XL Franklin 0-235 ----- Original Message ----- From: "Sabrina" <chicago2paris(at)msn.com> Sent: Wednesday, November 12, 2008 10:24 AM Subject: Zenith-List: Re: Cable Tensions for 601XL? > > "I did use elevator trim." > > Wade, > > Personally, the elevator trim weight bothered me more than the aileron > trim. The ailerons, by their nature of one being up and one down, > should, if properly tensioned, be easier to dampen in flight than a > fluttering elevator. So too, a builder can easily adjust an XL's > horizontal stabilizer for proper cruise configuration since it sits so > high off the longerons. The aileron trim was a much easier call for me > than the elevator trim. If no aileron trim under Par. 4-36, why elevator > trim? > > As to Par 4-36(c) was it the Cardinal that used foam in the elevator trim > tab that took on water/ice and threw it off balance? > > Has anyone had to drill a weep hole in their elevator trim tab to make > sure ice does not build up? I ended up gust-locking my elevator in the > up position rather than down to keep the ice out. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=213753#213753 > > > ________________________________________________________________________________
Date: Nov 12, 2008
Out of curiosity -- On Wed, Nov 12, 2008 at 7:29 AM, Sabrina wrote: > The problem here is that I am sending someone else up in my aircraft every time > I authorize a new test flight. So you are having someone else fly off your 40h? Sounds good but, since you have a PPL, why? > Although I know my particular airframe "at rest" better than anyone, and had > to defend my modifications to it during hours of meetings last December and > January ... Again out of curiosity: what meetings? Cheers, Ihab -- Ihab A.B. Awad, Palo Alto, CA ________________________________________________________________________________
Date: Nov 12, 2008
Sabrina, I have to agree with Wade.- Every aircraft's control system is different and and the fact that the ailerons have a balance cable really does not imp act its flutter characteristics because flutter is not really a control sur face deflection that originates from the stick.- The deflection comes fro m a flexing of the system that then stores the spring energy.- This flexi ng and storing of energy and then releasing that energy as the surface unfl exes is a primary driver in the creation of the flutter effect.- That is why stiffer is better when it comes to control systems. That being said, a flutter situation can occur in any of the control surfac es.- As the XL has had several reported instances of aileron flutter, it seems to be the most prevalent flutter mode.- I have not heard of any rep ort instances of elevator flutter.- Also, any additional weight at the tr ailing edge of a control surface will absolutely reduce the flutter speed. - I'm not saying that the XL with aileron trim is unsafe, but it does hav e less flutter margin than one without the trim system. I decided to go with a bungee type trim if required for the the ailerons. Jim Machin 601XL, 0-200 Almost done! --- On Wed, 11/12/08, Sabrina wrote: From: Sabrina <chicago2paris(at)msn.com> Subject: Zenith-List: Re: Cable Tensions for 601XL? Date: Wednesday, November 12, 2008, 8:24 AM "I did use elevator trim." Wade, Personally, the elevator trim weight bothered me more than the aileron trim .. The ailerons, by their nature of one being up and one down, should, if prop erly tensioned, be easier to dampen in flight than a fluttering elevator. So to o, a builder can easily adjust an XL's horizontal stabilizer for proper cruise configuration since it sits so high off the longerons. The aileron trim was a much easier call for me than the elevator trim. If no aileron trim under P ar. 4-36, why elevator trim? As to Par 4-36(c) was it the Cardinal that used foam in the elevator trim t ab that took on water/ice and threw it off balance? Has anyone had to drill a weep hole in their elevator trim tab to make sure ice does not build up? I ended up gust-locking my elevator in the up position rather than down to keep the ice out. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213753#213753 =0A=0A=0A ________________________________________________________________________________
Date: Nov 12, 2008
I strongly disagree, elevator input is suspect in more than one fatal crash. Even if an elevator remains in place, we don't know if the elevator got away and overstressed some other component. We just assume the pilot moved the stick too abruptly. It could be that we are only hearing about the aileron flutter because it can be dampened and the pilot can survive. There has to be a reason why Zenith added 6T3-8, the elevator horn reinforcing strap, to the design. At some point, some aerodynamic action was pulling the two horns apart in flight on the aircraft that was the basis for the design change. 6-T-3 08/05 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213769#213769 ________________________________________________________________________________
Date: Nov 12, 2008
> There has to be a reason why Zenith added 6T3-8 Has anyone asked Caleb? -- Craig -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Sabrina Sent: Wednesday, November 12, 2008 10:56 AM Subject: Zenith-List: Re: Cable Tensions for 601XL? I strongly disagree, elevator input is suspect in more than one fatal crash. Even if an elevator remains in place, we don't know if the elevator got away and overstressed some other component. We just assume the pilot moved the stick too abruptly. It could be that we are only hearing about the aileron flutter because it can be dampened and the pilot can survive. There has to be a reason why Zenith added 6T3-8, the elevator horn reinforcing strap, to the design. At some point, some aerodynamic action was pulling the two horns apart in flight on the aircraft that was the basis for the design change. 6-T-3 08/05 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213769#213769 ________________________________________________________________________________
Date: Nov 12, 2008
Craig, Caleb, No, Roger, Yes. Mr. Machin, I think we are talking apples and oranges. You and Wade are worried about flutter. I am worried about flutter that cannot be overcome. I was taught to dampen aileron or wing flutter by a firm climb combined with a firm bank as one reduces power. I know of no way to dampen elevator flutter other than by reducing power. You talk about the benefits of adding weight to the trailing edge of an elevator being a lower frequency of oscillation but the added mass increases your chances of entering into the situation in the first place. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213772#213772 ________________________________________________________________________________
Date: Nov 12, 2008
I'm not sure I agree.- The discussion was whether or not that addition of the trim system had an impact on the flutter characteristics and whether t he impact was greater on the ailerons or the elevator.- I am not really s ure of all the details surrounding the crash due to the down elevator input , but the structural testing Zenith did (negative load test of the wing) an d the subsequent recommendation of reducing the down elevator travel indica tes to me that flutter was not suspected in that case.- -I still stand by my statement that the addition of the aileron trim syst em reduces the flutter margin on 601 XL's.- As aileron flutter is the pri mary concern (at least today's most popular culprit) not installing a non-e ssential system that reduces the margin would seem prudent. Jim --- On Wed, 11/12/08, Sabrina wrote: From: Sabrina <chicago2paris(at)msn.com> Subject: Zenith-List: Re: Cable Tensions for 601XL? Date: Wednesday, November 12, 2008, 9:56 AM I strongly disagree, elevator input is suspect in more than one fatal crash .. Even if an elevator remains in place, we don't know if the elevator got awa y and overstressed some other component. We just assume the pilot moved the stick too abruptly. It could be that we are only hearing about the aileron flutter because it can be dampened and the pilot can survive. There has to be a reason why Zenith added 6T3-8, the elevator horn reinforc ing strap, to the design. At some point, some aerodynamic action was pulling t he two horns apart in flight on the aircraft that was the basis for the design change. 6-T-3 08/05 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213769#213769 =0A=0A=0A ________________________________________________________________________________
Date: Nov 12, 2008
And I'm a 7 year old Dalmatian whose owner taught to fly using hand signals. Give it a rest. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213775#213775 ________________________________________________________________________________
Subject: Re: Amperage draw
Date: Nov 12, 2008
Lynn, Thanks.? That is precisely what I intend to do. Jay -----Original Message----- From: dingfelder <ding(at)tbscc.com> Sent: Mon, 10 Nov 2008 8:58 pm Subject: Re: Zenith-List: Amperage draw ????????????? I adjusted my flap limit switches to shut off just very slightly after the flap hits the stop.?This puts a slight twist pressure on the flap to keep it rigid in flight. I popped several fuses? (15 A.) during the adjustment process. As soon as?the motor is stalled, the load is too great. I've had no problems at all with it in flight. ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? ??? Lynn????????? 601XL / Corvair ? ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: Nov 12, 2008
Well, in my opinion, all flutter is very bad.- There is something called limit cycle flutter which is a type of flutter that can be overcome, typica lly referred to as a control surface "buzz". To me, this situation is a kin to standing on the edge of a cliff with the edge crumbling away.- And ye s, reducing speed and changing the aerodynamic loading can stop it.- Ther e are other types of flutter that can be catastrophic in a very short perio d of time and there is nothing you can do to stop it.- The particular flu tter mode dictates which kind you get. Also, there are absolutely no benefits to adding weight of any kind to a tr ailing edge.- The goal is always to reduce the mass behind the hingeline. --- On Wed, 11/12/08, Sabrina wrote: From: Sabrina <chicago2paris(at)msn.com> Subject: Zenith-List: Re: Cable Tensions for 601XL? Date: Wednesday, November 12, 2008, 10:39 AM Craig, Caleb, No, Roger, Yes. Mr. Machin, I think we are talking apples and oranges. You and Wade are worried about flutter. I am worried about flutter that cannot be overcome. I was taught to dampen aileron or wing flutter by a firm climb combined with a firm bank as one reduces power. I know of no way to dampen elevator flutter other than b y reducing power. You talk about the benefits of adding weight to the trail ing edge of an elevator being a lower frequency of oscillation but the added ma ss increases your chances of entering into the situation in the first place. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213772#213772 =0A=0A=0A ________________________________________________________________________________
Date: Nov 12, 2008
Sabrina,=0A-=0AJust for the sake of mentioning it have you gone over each of the bearing surfaces in your ailerons, flaps and rudder? Also with resp ect to your cable runs through your fuselage is there a remote possibility that something has induced friction or drag? While I don=A2t have the engin eering background back ground or resources your family and EEA chapter are blessed with I have found a solution is always present, one simply has to r esearch or experiment until they find it. =0ASince it is unlikely you have access to a wind tunnel for a full on ground systems test do you have acces s to a stationary airplane engine test stand? If so you can secure your air plane to the runway and get enough airflow across the wing and aileron and rudder surfaces to test your aircrafts control surfaces for action and reac tion. It=A2s not very scientific and admittedly is rather crude but it=A2s worked well for me in the past on other projects I can=A2t discuss. =0A- =0ABest=0A-=0AJWS=0A-=0ADo not arcive please=0A=0A=0A=0A=0A____________ ____________________=0AFrom: Sabrina <chicago2paris(at)msn.com>=0ATo: zenith-l ist(at)matronics.com=0ASent: Wednesday, November 12, 2008 11:56:19 AM=0ASubjec t: Zenith-List: Re: Cable Tensions for 601XL?=0A=0A--> Zenith-List message posted by: "Sabrina" =0A=0AI strongly disagree, elev ator input is suspect in more than one fatal crash.- Even if an elevator remains in place, we don't know if the elevator got away and overstressed s ome other component.- We just assume the pilot moved the stick too abrupt ly.- It could be that we are only hearing about the aileron flutter becau se it can be dampened and the pilot can survive. =0A=0AThere has to be a re ason why Zenith added 6T3-8, the elevator horn reinforcing strap, to the de sign.- At some point, some aerodynamic action was pulling the two horns a part in flight on the aircraft that was the basis for the design change.- 6-T-3 08/05=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums. -=- - - - - - - - - - - - - - - -Matt Drall ========================0A=0A =0A ________________________________________________________________________________
Date: Nov 12, 2008
Sabrina, FWIW: ? I asked the test pilot that first flew my 601XL if he used the elevator trim.? He said "Definitely!"? He said that he virtually flew the airplane with elevator trim.? To my thinking, that makes a pretty good case for the elevator trim.? I don't have aileron trim, either. Jay in Dallas -----Original Message----- From: Sabrina <chicago2paris(at)msn.com> Sent: Wed, 12 Nov 2008 10:24 am Subject: Zenith-List: Re: Cable Tensions for 601XL? "I did use elevator trim." Wade, Personally, the elevator trim weight bothered me more than the aileron trim. The ailerons, by their nature of one being up and one down, should, if properly tensioned, be easier to dampen in flight than a fluttering elevator. So too, a builder can easily adjust an XL's horizontal stabilizer for proper cruise configuration since it sits so high off the longerons. The aileron trim was a much easier call for me than the elevator trim. If no aileron trim under Par. 4-36, why elevator trim? As to Par 4-36(c) was it the Cardinal that used foam in the elevator trim tab that took on water/ice and threw it off balance? Has anyone had to drill a weep hole in their elevator trim tab to make sure ice does not build up? I ended up gust-locking my elevator in the up position rather than down to keep the ice out. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213753#213753 ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: Nov 12, 2008
Hey there to the person aka Joe Kidd, It is sad, but even MIT's wind tunnel is too small. The way the turbo prop guys blast the aircraft at the end of the East ramp at KARR as they warm up and wait for IFR clearance for 27, I don't need one. :o) I am confident the problems will be figured out in a matter of months, not years. I had the cable tensions adjusted from a liability point of view. So too, I hope the new 40/30/22 +/-5 set of tensions bring the control inputs towards the middle, as opposed to having the elevator too light, and the rudder too stiff. Jay, I added elevator trim ONLY because people were complaining about nose-heavy XLs wanting to fly nose down. I did not think that pitching the H-stab down would work as well as it did. The Sabrina Mark 1 pitches up at full power, down at reduced power and is level in cruise without any trim. Did you pitch your H-stab at all? Do you have a heavy engine? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213795#213795 ________________________________________________________________________________
Date: Nov 12, 2008
Butting in here but,,,, In my Experimental airplane adventures, I ve found that pitching up under power and then pitching down with reduced power is an indication of the engine mount not being set at the correct angle........ Steve W. ----- Original Message ----- From: "Sabrina" <chicago2paris(at)msn.com> Sent: Wednesday, November 12, 2008 1:25 PM Subject: Zenith-List: Re: Cable Tensions for 601XL? > > Hey there to the person aka Joe Kidd, > > It is sad, but even MIT's wind tunnel is too small. The way the turbo > prop guys blast the aircraft at the end of the East ramp at KARR as they > warm up and wait for IFR clearance for 27, I don't need one. :o) > > I am confident the problems will be figured out in a matter of months, not > years. I had the cable tensions adjusted from a liability point of view. > So too, I hope the new 40/30/22 +/-5 set of tensions bring the control > inputs towards the middle, as opposed to having the elevator too light, > and the rudder too stiff. > > Jay, > > I added elevator trim ONLY because people were complaining about > nose-heavy XLs wanting to fly nose down. I did not think that pitching > the H-stab down would work as well as it did. The Sabrina Mark 1 pitches > up at full power, down at reduced power and is level in cruise without any > trim. Did you pitch your H-stab at all? Do you have a heavy engine? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=213795#213795 > > > ________________________________________________________________________________
Date: Nov 12, 2008
Now you got me calling my test pilot and he is on my back. :o) He says you are 100% right and wants me to quote him correctly in the future: "full power = a nice climb, cruise power = level flight, reduced power = a slight nose over that would prevent a stall." P.S. You think my use of the word "pitch" bothered you, I got six e-mails complaining about me calling the nose gear stop place "at rest" when it is in flight. I meant resting against the upper bearing plate. I got one referring to me as a type of dog, but that word begins with B and not P. I probably still had that on my mind when I wrote "pitch". Sorry. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213800#213800 ________________________________________________________________________________
Date: Nov 12, 2008
"Throttle is for climb and decent, you trim for speed" A plane that is trimmed at a set speed wil climb or decend with a change in throttle rpm or power setting, so angle on engine is more for p factor/ torque than anything, relavant on a limitted basis to level flight. Juan -----Original Message----- >From: steve <notsew_evets(at)frontiernet.net> >Sent: Nov 12, 2008 3:35 PM >To: zenith-list(at)matronics.com >Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? > > >Butting in here but,,,, >In my Experimental airplane adventures, I ve found that pitching up under >power and then pitching down with reduced power is an indication of the >engine mount not being set at the correct angle........ >Steve W. > >----- Original Message ----- >From: "Sabrina" <chicago2paris(at)msn.com> >To: >Sent: Wednesday, November 12, 2008 1:25 PM >Subject: Zenith-List: Re: Cable Tensions for 601XL? > > >> >> Hey there to the person aka Joe Kidd, >> >> It is sad, but even MIT's wind tunnel is too small. The way the turbo >> prop guys blast the aircraft at the end of the East ramp at KARR as they >> warm up and wait for IFR clearance for 27, I don't need one. :o) >> >> I am confident the problems will be figured out in a matter of months, not >> years. I had the cable tensions adjusted from a liability point of view. >> So too, I hope the new 40/30/22 +/-5 set of tensions bring the control >> inputs towards the middle, as opposed to having the elevator too light, >> and the rudder too stiff. >> >> Jay, >> >> I added elevator trim ONLY because people were complaining about >> nose-heavy XLs wanting to fly nose down. I did not think that pitching >> the H-stab down would work as well as it did. The Sabrina Mark 1 pitches >> up at full power, down at reduced power and is level in cruise without any >> trim. Did you pitch your H-stab at all? Do you have a heavy engine? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=213795#213795 >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Nov 12, 2008
not having elevator trim limits the plane's power to weight true speed capabilitys. You pitch/ trim for speed and throttle for climb. If no trim avaialable than the plane will be set a level flight at a certain horsepower and as weight changes the level flight/ horse power output will change. Cable tension is a whole differnt ball of wax. The Tension AD is out there because people did not focus on it as that important and it bit some folks in the ass, and then they blame it on the design. Juan -----Original Message----- >From: Sabrina <chicago2paris(at)msn.com> >Sent: Nov 12, 2008 3:25 PM >To: zenith-list(at)matronics.com >Subject: Zenith-List: Re: Cable Tensions for 601XL? > > >Hey there to the person aka Joe Kidd, > >It is sad, but even MIT's wind tunnel is too small. The way the turbo prop guys blast the aircraft at the end of the East ramp at KARR as they warm up and wait for IFR clearance for 27, I don't need one. :o) > >I am confident the problems will be figured out in a matter of months, not years. I had the cable tensions adjusted from a liability point of view. So too, I hope the new 40/30/22 +/-5 set of tensions bring the control inputs towards the middle, as opposed to having the elevator too light, and the rudder too stiff. > >Jay, > >I added elevator trim ONLY because people were complaining about nose-heavy XLs wanting to fly nose down. I did not think that pitching the H-stab down would work as well as it did. The Sabrina Mark 1 pitches up at full power, down at reduced power and is level in cruise without any trim. Did you pitch your H-stab at all? Do you have a heavy engine? > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=213795#213795 > > ________________________________________________________________________________
Date: Nov 12, 2008
every pilot flys their plane with the trim. makes for better and smooth flying. a plane with now trim is limitred in its true capabilities and so is the pilot. Juan -----Original Message----- >From: jaybannist(at)cs.com >Sent: Nov 12, 2008 3:08 PM >To: zenith-list(at)matronics.com >Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? > > > Sabrina, > >FWIW: ? I asked the test pilot that first flew my 601XL if he used the elevator trim.? He said "Definitely!"? He said that he virtually flew the airplane with elevator trim.? To my thinking, that makes a pretty good case for the elevator trim.? I don't have aileron trim, either. > >Jay in Dallas > > > > > > > >-----Original Message----- >From: Sabrina <chicago2paris(at)msn.com> >To: zenith-list(at)matronics.com >Sent: Wed, 12 Nov 2008 10:24 am >Subject: Zenith-List: Re: Cable Tensions for 601XL? > > >"I did use elevator trim." > >Wade, > >Personally, the elevator trim weight bothered me more than the aileron trim. >The ailerons, by their nature of one being up and one down, should, if properly >tensioned, be easier to dampen in flight than a fluttering elevator. So too, a >builder can easily adjust an XL's horizontal stabilizer for proper cruise >configuration since it sits so high off the longerons. The aileron trim was a >much easier call for me than the elevator trim. If no aileron trim under Par. >4-36, why elevator trim? > >As to Par 4-36(c) was it the Cardinal that used foam in the elevator trim tab >that took on water/ice and threw it off balance? > >Has anyone had to drill a weep hole in their elevator trim tab to make sure ice >does not build up? I ended up gust-locking my elevator in the up position >rather than down to keep the ice out. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=213753#213753 > > > > >________________________________________________________________________ >Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: Nov 12, 2008
P factor and torque is corrected by left or right engine mount setting. OR rudder offset. I understand that Sabrina was talking about climb and desent. With power or not the attitude (verticle) should not change a whole bunch. ----- Original Message ----- From: "Juan Vega" <amyvega2005(at)earthlink.net> Sent: Wednesday, November 12, 2008 2:32 PM Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? > > "Throttle is for climb and decent, you trim for speed" A plane that is > trimmed at a set speed wil climb or decend with a change in throttle rpm > or power setting, so angle on engine is more for p factor/ torque than > anything, relavant on a limitted basis to level flight. > > Juan > > -----Original Message----- >>From: steve <notsew_evets(at)frontiernet.net> >>Sent: Nov 12, 2008 3:35 PM >>To: zenith-list(at)matronics.com >>Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? >> >> >>Butting in here but,,,, >>In my Experimental airplane adventures, I ve found that pitching up under >>power and then pitching down with reduced power is an indication of the >>engine mount not being set at the correct angle........ >>Steve W. >> >>----- Original Message ----- >>From: "Sabrina" <chicago2paris(at)msn.com> >>To: >>Sent: Wednesday, November 12, 2008 1:25 PM >>Subject: Zenith-List: Re: Cable Tensions for 601XL? >> >> >>> >>> Hey there to the person aka Joe Kidd, >>> >>> It is sad, but even MIT's wind tunnel is too small. The way the turbo >>> prop guys blast the aircraft at the end of the East ramp at KARR as they >>> warm up and wait for IFR clearance for 27, I don't need one. :o) >>> >>> I am confident the problems will be figured out in a matter of months, >>> not >>> years. I had the cable tensions adjusted from a liability point of >>> view. >>> So too, I hope the new 40/30/22 +/-5 set of tensions bring the control >>> inputs towards the middle, as opposed to having the elevator too light, >>> and the rudder too stiff. >>> >>> Jay, >>> >>> I added elevator trim ONLY because people were complaining about >>> nose-heavy XLs wanting to fly nose down. I did not think that pitching >>> the H-stab down would work as well as it did. The Sabrina Mark 1 >>> pitches >>> up at full power, down at reduced power and is level in cruise without >>> any >>> trim. Did you pitch your H-stab at all? Do you have a heavy engine? >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=213795#213795 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Nov 12, 2008
My 601HDS propeller fluttered too !!!! Then it broke off. Roger _____ From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of J.T. Machin Sent: Wednesday, November 12, 2008 11:49 AM Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? Sabrina, I have to agree with Wade. Every aircraft's control system is different and and the fact that the ailerons have a balance cable really does not impact its flutter characteristics because flutter is not really a control surface deflection that originates from the stick. The deflection comes from a flexing of the system that then stores the spring energy. This flexing and storing of energy and then releasing that energy as the surface unflexes is a primary driver in the creation of the flutter effect. That is why stiffer is better when it comes to control systems. That being said, a flutter situation can occur in any of the control surfaces. As the XL has had several reported instances of aileron flutter, it seems to be the most prevalent flutter mode. I have not heard of any report instances of elevator flutter. Also, any additional weight at the trailing edge of a control surface will absolutely reduce the flutter speed. I'm not saying that the XL with aileron trim is unsafe, but it does have less flutter margin than one without the trim system. I decided to go with a bungee type trim if required for the the ailerons. Jim Machin 601XL, 0-200 Almost done! --- On Wed, 11/12/08, Sabrina wrote: From: Sabrina <chicago2paris(at)msn.com> Subject: Zenith-List: Re: Cable Tensions for 601XL? Date: Wednesday, November 12, 2008, 8:24 AM "I did use elevator trim." Wade, Personally, the elevator trim weight bothered me more than the aileron trim. The ailerons, by their nature of one being up and one down, should, if properly tensioned, be easier to dampen in flight than a fluttering elevator. So too, a builder can easily adjust an XL's horizontal stabilizer for proper cruise configuration since it sits so high off the longerons. The aileron trim was a much easier call for me than the elevator trim. If no aileron trim under Par. 4-36, why elevator trim? As to Par 4-36(c) was it the Cardinal that used foam in the elevator trim tab that took on water/ice and threw it off balance? Has anyone had to drill a weep hole in their elevator trim tab to make sure ice does not build up? I ended up gust-locking my elevator in the up position rather than down to keep the ice out. Read this topic online ________________________________________________________________________________
Date: Nov 12, 2008
Mr. Haas, As for building the aircraft, I know you don't think a girl could build an aircraft so no amount of photos or videos would ever convince you. You are not the first and will not be the last to underestimate me. What may surprise you is that I have never wanted to be a pilot or an aircraft builder, it is just a step towards my dreams of building spacecraft. As for flying N5886Q, I don't have the license to do it here. I wish I did. I have always admitted to having a great deal of help building it. It started with Scott Laughlin, then Larry's website, then Andres, and Mr. Sewell (all from the ch601.org list) Also, I would read this list often. Actually riveting together an airframe kit is a no brainer. Figuring out how to move a 200 pound engine from the back of the garage to the nose of an aircraft by yourself is a little challenging, but figuring out the fuel system, avionics and how to create an interior was much more difficult. These were all one off. I don't know anyone with a similar panel or true tuck and roll interior. I kinda like the look of my cowling too. Am I proud, Yes. I really like my leading edge modification and ejector canopy too. At first, I figured after the airplane flew, my job was done. When the XL started having more and more problems, it was a nightmare for me. Then, I realized this was an opportunity of a life time. It is very challenging and interesting to develop a flight test program for the airplane. I am learning so much more than I ever thought I would. I am very proud that my first squawk did not come until 10 months into the flight testing. So, if you think I am intimidated by you. No, sorry. I have been in meeting after meeting defending my modifications and have been asked "Do I want my daddy." Although it would be nice, no, I can do this. I don't think any 701/801 builder understands what those of us with an XL kit are going through. Do I dislike you, No. You just don't understand me. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213865#213865 ________________________________________________________________________________
Date: Nov 12, 2008
Like I always say, flying is only part of aviation, and not necessarily the best part. Roger -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Sabrina Sent: Wednesday, November 12, 2008 8:01 PM Subject: Zenith-List: Re: Cable Tensions for 601XL? Mr. Haas, As for building the aircraft, I know you don't think a girl could build an aircraft so no amount of photos or videos would ever convince you. You are not the first and will not be the last to underestimate me. What may surprise you is that I have never wanted to be a pilot or an aircraft builder, it is just a step towards my dreams of building spacecraft. As for flying N5886Q, I don't have the license to do it here. I wish I did. I have always admitted to having a great deal of help building it. It started with Scott Laughlin, then Larry's website, then Andres, and Mr. Sewell (all from the ch601.org list) Also, I would read this list often. Actually riveting together an airframe kit is a no brainer. Figuring out how to move a 200 pound engine from the back of the garage to the nose of an aircraft by yourself is a little challenging, but figuring out the fuel system, avionics and how to create an interior was much more difficult. These were all one off. I don't know anyone with a similar panel or true tuck and roll interior. I kinda like the look of my cowling too. Am I proud, Yes. I really like my leading edge modification and ejector canopy too. At first, I figured after the airplane flew, my job was done. When the XL started having more and more problems, it was a nightmare for me. Then, I realized this was an opportunity of a life time. It is very challenging and interesting to develop a flight test program for the airplane. I am learning so much more than I ever thought I would. I am very proud that my first squawk did not come until 10 months into the flight testing. So, if you think I am intimidated by you. No, sorry. I have been in meeting after meeting defending my modifications and have been asked "Do I want my daddy." Although it would be nice, no, I can do this. I don't think any 701/801 builder understands what those of us with an XL kit are going through. Do I dislike you, No. You just don't understand me. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213865#213865 ________________________________________________________________________________
Date: Nov 12, 2008
Sorry, no offense Steve, but I agree with Juan on this one. Simple test... fly straight and level then cut throttle to idle while holding the elevator steady. I promise you that ANY plane will soon be in a steep dive toward the ground. Full power from straight and level (if your trimmed for level at low power) and you will pitch up and climb. I thought we all knew this ----- Original Message ----- From: "steve" <notsew_evets(at)frontiernet.net> Sent: Wednesday, November 12, 2008 3:24 PM Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? > > P factor and torque is corrected by left or right engine mount setting. > OR rudder offset. I understand that Sabrina was talking about climb and > desent. With power or not the attitude (verticle) should not change a > whole bunch. > > ----- Original Message ----- > From: "Juan Vega" <amyvega2005(at)earthlink.net> > To: ; > Sent: Wednesday, November 12, 2008 2:32 PM > Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? > > >> >> "Throttle is for climb and decent, you trim for speed" A plane that is >> trimmed at a set speed wil climb or decend with a change in throttle rpm >> or power setting, so angle on engine is more for p factor/ torque than >> anything, relavant on a limitted basis to level flight. >> >> Juan >> >> -----Original Message----- >>>From: steve <notsew_evets(at)frontiernet.net> >>>Sent: Nov 12, 2008 3:35 PM >>>To: zenith-list(at)matronics.com >>>Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? >>> >>> >>>Butting in here but,,,, >>>In my Experimental airplane adventures, I ve found that pitching up under >>>power and then pitching down with reduced power is an indication of the >>>engine mount not being set at the correct angle........ >>>Steve W. >>> >>>----- Original Message ----- >>>From: "Sabrina" <chicago2paris(at)msn.com> >>>To: >>>Sent: Wednesday, November 12, 2008 1:25 PM >>>Subject: Zenith-List: Re: Cable Tensions for 601XL? >>> >>> >>>> >>>> Hey there to the person aka Joe Kidd, >>>> >>>> It is sad, but even MIT's wind tunnel is too small. The way the turbo >>>> prop guys blast the aircraft at the end of the East ramp at KARR as >>>> they >>>> warm up and wait for IFR clearance for 27, I don't need one. :o) >>>> >>>> I am confident the problems will be figured out in a matter of months, >>>> not >>>> years. I had the cable tensions adjusted from a liability point of >>>> view. >>>> So too, I hope the new 40/30/22 +/-5 set of tensions bring the control >>>> inputs towards the middle, as opposed to having the elevator too light, >>>> and the rudder too stiff. >>>> >>>> Jay, >>>> >>>> I added elevator trim ONLY because people were complaining about >>>> nose-heavy XLs wanting to fly nose down. I did not think that >>>> pitching >>>> the H-stab down would work as well as it did. The Sabrina Mark 1 >>>> pitches >>>> up at full power, down at reduced power and is level in cruise without >>>> any >>>> trim. Did you pitch your H-stab at all? Do you have a heavy engine? >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=213795#213795 >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Nov 12, 2008
Back to the cable tension debate, if I may, with all the discussions of cables and flutter I am more convinced than ever to use pushrods, and balanced control surfaces. To me, this is a simple, logical fix. I'm not the first person to do this, and probably not the last. pushrods never need tension adjusting, they do not put a permanent strain on the airframe like cables do. If there is any play from worn parts you can tell instantly on your pre-flight. As to balance of controls this further relieves stress on the airframe and if I'm not mistaken helps reduce the possibility of flutter. I frankly don't care if Zenith Inc. doesn't like this but it is obviously very hard and embarassing for a company to admit that they could have done better and make changes to their design, admitting to those weaknesses in their design, so I use my own experience and compare this plane to other designs that have done a better job on some of these issues. I didn't invent pushrods and balanced ailerons, but I have flown some exceptional planes that had them so why not.. I'm sure I'm not the only person to write to Mr Heinz about this issue and the wing failure issue only to get the pat response that "there are hundreds of these planes flying so it must be OK" Well maybe most people don't get close to the design limits of their planes and never find out the hard way that they are borderline in some areas and you only get one chance to cross that line. I still like the plane and plan to build it, but I'll fix these obvious (in my opinion) weaknesses. Dirk PS Let the flames begin, I'm ready for you! ________________________________________________________________________________
Date: Nov 12, 2008
Hi Sabrina, I promise not to ever underestimate you. Indeed, I am incredibly impressed with you. That said, I must take issue with your comment that riveting a kit together is a no-brainer. I managed to destroy my first XL wing by trying my best to follow the instructions provided by ZAC. After scrapping it I decided to mostly ignore the kit instructions and think through the process of building each piece into the finished airframe. There was also much fitting and remaking of parts I destroyed on my first attempts. I have found the entire process of building an XL from standard kit very educational. I have been working on mine for over three years now (but only an hour or two per day) and I still seem to learn something new every day. Indeed, I think my brain is the part that has had to work the hardest building this kit. Best regards, Paul XL getting close At 06:00 PM 11/12/2008, you wrote: > > You are not the first and will not be the last to underestimate me. > Actually riveting together an airframe kit is a no brainer. ________________________________________________________________________________
Date: Nov 12, 2008
One word: WOW... do you guys know that General Atomic came this >< close to producing atomic propulsed space craft in the 1960s. Paul... sorry about the no-brainer comment. I actually mis-drilled the first aluminum part I touched. When I put the cylinders on my engine, I actually left a sealing ring off. It is such a terrible feeling to put your engine together and have extra parts afterwords. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213883#213883 ________________________________________________________________________________
Date: Nov 13, 2008
Ya, I guess nuclear reactors falling from the sky was not a very great concern at the time. Roger -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Sabrina Sent: Wednesday, November 12, 2008 9:56 PM Subject: Zenith-List: Re: Cable Tensions for 601XL? One word: WOW... do you guys know that General Atomic came this >< close to producing atomic propulsed space craft in the 1960s. Paul... sorry about the no-brainer comment. I actually mis-drilled the first aluminum part I touched. When I put the cylinders on my engine, I actually left a sealing ring off. It is such a terrible feeling to put your engine together and have extra parts afterwords. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213883#213883 ________________________________________________________________________________
Date: Nov 13, 2008
Subject: Re: Cable Tensions for 601XL?
Dirk, A look at 90 percent of GA aircraft, including quite few few Jets, show that they use cables. The rods are no better than the cables. the flaw is in the builders not following simple directions to tesnionthe cable. Maybe its becasue cable need vigialance more so than rods. Cables need to be retightened from time to time and maintained. Its not the cable design, its the builders. We are the builders and its funny how people blame everything but the builders. If I have a problem with my plane, and it is due to something I over looked or neglected, I just look in the mirror as to placing the blame. I believe quite comfortably the design of the aircraft is quite sound. The problems lie in the build and most, the maintenance. Tension the cables, and swage them correctly, and you will be fine, if cables were an issue , they wopuild not have them on most Boeing and Airbus aircraft. Juan Juan -----Original Message----- >From: Dirk Zahtilla <ideaz1(at)sbcglobal.net> >Sent: Nov 12, 2008 10:00 PM >To: zenith-list(at)matronics.com >Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? > > >Back to the cable tension debate, if I may, with all the discussions of >cables and flutter I am more convinced than ever to use pushrods, and >balanced control surfaces. To me, this is a simple, logical fix. I'm not the >first person to do this, and probably not the last. pushrods never need >tension adjusting, they do not put a permanent strain on the airframe like >cables do. If there is any play from worn parts you can tell instantly on >your pre-flight. >As to balance of controls this further relieves stress on the airframe and >if I'm not mistaken helps reduce the possibility of flutter. > >I frankly don't care if Zenith Inc. doesn't like this but it is obviously >very hard and embarassing for a company to admit that they could have done >better and make changes to their design, admitting to those weaknesses in >their design, so I use my own experience and compare this plane to other >designs that have done a better job on some of these issues. I didn't invent >pushrods and balanced ailerons, but I have flown some exceptional planes >that had them so why not.. I'm sure I'm not the only person to write to Mr >Heinz about this issue and the wing failure issue only to get the pat >response that "there are hundreds of these planes flying so it must be OK" >Well maybe most people don't get close to the design limits of their planes >and never find out the hard way that they are borderline in some areas and >you only get one chance to cross that line. > >I still like the plane and plan to build it, but I'll fix these obvious (in >my opinion) weaknesses. > >Dirk >PS Let the flames begin, I'm ready for you! > > ________________________________________________________________________________
Date: Nov 13, 2008
Thanks DIrk, Its called Dynamic stability. All plane fly as speed regulated by pitch (trim) and throttle for decent and accent.(lift, weight, drag, thrust)... I hear you on the cable vs rod debate , i think its not the design though, its the maintenacne issue. ALot of guys building, build their planes and do not realize the maintenance requirement involved. Cables are not set and forget. Maybe that would be the strenght of Rods. I think where allt he accidents have happened for the ecception of a few has been oversight on the ground. A bolt not tightened, a cable not propoerly swaged. Someone second guessing the plans and over torquing, etc... Juan -----Original Message----- >From: Dirk Zahtilla <ideaz1(at)sbcglobal.net> >Sent: Nov 12, 2008 9:30 PM >To: zenith-list(at)matronics.com >Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? > > >Sorry, no offense Steve, but I agree with Juan on this one. Simple test... >fly straight and level then cut throttle to idle while holding the elevator >steady. I promise you that ANY plane will soon be in a steep dive toward the >ground. Full power from straight and level (if your trimmed for level at >low power) and you will pitch up and climb. I thought we all knew this >----- Original Message ----- >From: "steve" <notsew_evets(at)frontiernet.net> >To: >Sent: Wednesday, November 12, 2008 3:24 PM >Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? > > >> >> P factor and torque is corrected by left or right engine mount setting. >> OR rudder offset. I understand that Sabrina was talking about climb and >> desent. With power or not the attitude (verticle) should not change a >> whole bunch. >> >> ----- Original Message ----- >> From: "Juan Vega" <amyvega2005(at)earthlink.net> >> To: ; >> Sent: Wednesday, November 12, 2008 2:32 PM >> Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? >> >> >>> >>> "Throttle is for climb and decent, you trim for speed" A plane that is >>> trimmed at a set speed wil climb or decend with a change in throttle rpm >>> or power setting, so angle on engine is more for p factor/ torque than >>> anything, relavant on a limitted basis to level flight. >>> >>> Juan >>> >>> -----Original Message----- >>>>From: steve <notsew_evets(at)frontiernet.net> >>>>Sent: Nov 12, 2008 3:35 PM >>>>To: zenith-list(at)matronics.com >>>>Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? >>>> >>>> >>>>Butting in here but,,,, >>>>In my Experimental airplane adventures, I ve found that pitching up under >>>>power and then pitching down with reduced power is an indication of the >>>>engine mount not being set at the correct angle........ >>>>Steve W. >>>> >>>>----- Original Message ----- >>>>From: "Sabrina" <chicago2paris(at)msn.com> >>>>To: >>>>Sent: Wednesday, November 12, 2008 1:25 PM >>>>Subject: Zenith-List: Re: Cable Tensions for 601XL? >>>> >>>> >>>>> >>>>> Hey there to the person aka Joe Kidd, >>>>> >>>>> It is sad, but even MIT's wind tunnel is too small. The way the turbo >>>>> prop guys blast the aircraft at the end of the East ramp at KARR as >>>>> they >>>>> warm up and wait for IFR clearance for 27, I don't need one. :o) >>>>> >>>>> I am confident the problems will be figured out in a matter of months, >>>>> not >>>>> years. I had the cable tensions adjusted from a liability point of >>>>> view. >>>>> So too, I hope the new 40/30/22 +/-5 set of tensions bring the control >>>>> inputs towards the middle, as opposed to having the elevator too light, >>>>> and the rudder too stiff. >>>>> >>>>> Jay, >>>>> >>>>> I added elevator trim ONLY because people were complaining about >>>>> nose-heavy XLs wanting to fly nose down. I did not think that >>>>> pitching >>>>> the H-stab down would work as well as it did. The Sabrina Mark 1 >>>>> pitches >>>>> up at full power, down at reduced power and is level in cruise without >>>>> any >>>>> trim. Did you pitch your H-stab at all? Do you have a heavy engine? >>>>> >>>>> >>>>> >>>>> >>>>> Read this topic online here: >>>>> >>>>> http://forums.matronics.com/viewtopic.php?p=213795#213795 >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Nov 13, 2008
next time balance the prop, people tend to forget that little part. -----Original Message----- >From: Roger & Lina Hill <hills(at)sunflower.com> >Sent: Nov 12, 2008 7:10 PM >To: zenith-list(at)matronics.com >Subject: RE: Zenith-List: Re: Cable Tensions for 601XL? > >My 601HDS propeller fluttered too !!!! > >Then it broke off. > > > > > >Roger > > > > > > _____ > >From: owner-zenith-list-server(at)matronics.com >[mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of J.T. Machin >Sent: Wednesday, November 12, 2008 11:49 AM >To: zenith-list(at)matronics.com >Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? > > > > >Sabrina, > >I have to agree with Wade. Every aircraft's control system is different and >and the fact that the ailerons have a balance cable really does not impact >its flutter characteristics because flutter is not really a control surface >deflection that originates from the stick. The deflection comes from a >flexing of the system that then stores the spring energy. This flexing and >storing of energy and then releasing that energy as the surface unflexes is >a primary driver in the creation of the flutter effect. That is why stiffer >is better when it comes to control systems. > >That being said, a flutter situation can occur in any of the control >surfaces. As the XL has had several reported instances of aileron flutter, >it seems to be the most prevalent flutter mode. I have not heard of any >report instances of elevator flutter. Also, any additional weight at the >trailing edge of a control surface will absolutely reduce the flutter speed. >I'm not saying that the XL with aileron trim is unsafe, but it does have >less flutter margin than one without the trim system. > >I decided to go with a bungee type trim if required for the the ailerons. > >Jim Machin >601XL, 0-200 >Almost done! > >--- On Wed, 11/12/08, Sabrina wrote: > >From: Sabrina <chicago2paris(at)msn.com> >Subject: Zenith-List: Re: Cable Tensions for 601XL? >To: zenith-list(at)matronics.com >Date: Wednesday, November 12, 2008, 8:24 AM > > > > > > > > >"I did use elevator trim." > > > > > >Wade, > > > > > >Personally, the elevator trim weight bothered me more than > the aileron trim. > > >The ailerons, by their nature of one being up and one down, should, if >properly > > >tensioned, be easier to dampen in flight than a fluttering elevator. So >too, a > > >builder can easily adjust an XL's horizontal stabilizer for proper cruise > > >configuration since it sits so high off the longerons. The aileron trim >was a > > >much easier call for me than the elevator trim. If no aileron trim under >Par. > > >4-36, why elevator trim? > > > > > >As to Par 4-36(c) was it the Cardinal that used foam in the elevator trim >tab > > >that took on water/ice and threw it off balance? > > > > > >Has anyone had to drill a weep hole in their elevator trim tab to make sure >ice > > >does not build up? I ended up gust-locking my elevator in the up position > > >rather than down to keep the ice out. > > > > > > > > > > > > > > >Read this topic online > > > > > > > > ________________________________________________________________________________
Date: Nov 13, 2008
Yes Gig, I stand corrected. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213913#213913 ________________________________________________________________________________
From: Grant Corriveau <grant.corriveau(at)TELUS.NET>
Subject: Heavy engine and Horiz. stab
Date: Nov 13, 2008
I'm confused by the comments regarding the engine mass and the horizontal stab installed angle. Isn't the engine mass counter-balanced during the construction by final placement of the battery(s) to maintain the Weight & Balance inside the acceptable envelope? Once this is accomplished there is no need to consider "adjusting" the horizontal stab to account for the engine weight, is there? Curious in Canada Grant 601 HDS / CAM100 (heavy but worth it) ________________________________________________________________________________
Date: Nov 13, 2008
Its ok, no offense taken. We all "discuss" what we have learned over theyears we have been involved in this hobby. One of my airplanes would not climb as advertised. I would fly along side other aircraft ( same make and models) and these guys always out climbed me by at lease 400 FPM. One day a builder suggested I look at the upward thrust of the engine mount. Sure enough, the engine crank shaft pointed down. Waaaay down.... Just a few washers under the bottom attach bolts took care of the problem. Sure if the pilot reduces power the nose will drop, but not much. Just enough to maintain the current trim speed... I think if the power was reduced and the airplane nose went straight down, there is a problem. On the other hand, and this example is waaay out, if your aircraft, model X65-970, is in level, trimmed flight and the pilot goes full throttle, and it loops....youve got a problem.... Its not trim, its not angle of incidence. It might be engine position. Goofy aint I ???? I accept being wrong.. But if so, geeze there are a lot of student pilots out there flying with my spew of B.S. Hey, I m the guy who cant even get my 601XL to balance within the envelope.... ----- Original Message ----- From: "Dirk Zahtilla" <ideaz1(at)sbcglobal.net> Sent: Wednesday, November 12, 2008 7:30 PM Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? > > Sorry, no offense Steve, but I agree with Juan on this one. Simple test... > fly straight and level then cut throttle to idle while holding the > elevator steady. I promise you that ANY plane will soon be in a steep dive > toward the ground. Full power from straight and level (if your trimmed > for level at low power) and you will pitch up and climb. I thought we all > knew this > ----- Original Message ----- > From: "steve" <notsew_evets(at)frontiernet.net> > To: > Sent: Wednesday, November 12, 2008 3:24 PM > Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? > > >> >> P factor and torque is corrected by left or right engine mount setting. >> OR rudder offset. I understand that Sabrina was talking about climb and >> desent. With power or not the attitude (verticle) should not change a >> whole bunch. >> >> ----- Original Message ----- >> From: "Juan Vega" <amyvega2005(at)earthlink.net> >> To: ; >> Sent: Wednesday, November 12, 2008 2:32 PM >> Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? >> >> >>> >>> "Throttle is for climb and decent, you trim for speed" A plane that is >>> trimmed at a set speed wil climb or decend with a change in throttle rpm >>> or power setting, so angle on engine is more for p factor/ torque than >>> anything, relavant on a limitted basis to level flight. >>> >>> Juan >>> >>> -----Original Message----- >>>>From: steve <notsew_evets(at)frontiernet.net> >>>>Sent: Nov 12, 2008 3:35 PM >>>>To: zenith-list(at)matronics.com >>>>Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? >>>> >>>> >>>> >>>>Butting in here but,,,, >>>>In my Experimental airplane adventures, I ve found that pitching up >>>>under >>>>power and then pitching down with reduced power is an indication of the >>>>engine mount not being set at the correct angle........ >>>>Steve W. >>>> >>>>----- Original Message ----- >>>>From: "Sabrina" <chicago2paris(at)msn.com> >>>>To: >>>>Sent: Wednesday, November 12, 2008 1:25 PM >>>>Subject: Zenith-List: Re: Cable Tensions for 601XL? >>>> >>>> >>>>> >>>>> Hey there to the person aka Joe Kidd, >>>>> >>>>> It is sad, but even MIT's wind tunnel is too small. The way the >>>>> turbo >>>>> prop guys blast the aircraft at the end of the East ramp at KARR as >>>>> they >>>>> warm up and wait for IFR clearance for 27, I don't need one. :o) >>>>> >>>>> I am confident the problems will be figured out in a matter of months, >>>>> not >>>>> years. I had the cable tensions adjusted from a liability point of >>>>> view. >>>>> So too, I hope the new 40/30/22 +/-5 set of tensions bring the control >>>>> inputs towards the middle, as opposed to having the elevator too >>>>> light, >>>>> and the rudder too stiff. >>>>> >>>>> Jay, >>>>> >>>>> I added elevator trim ONLY because people were complaining about >>>>> nose-heavy XLs wanting to fly nose down. I did not think that >>>>> pitching >>>>> the H-stab down would work as well as it did. The Sabrina Mark 1 >>>>> pitches >>>>> up at full power, down at reduced power and is level in cruise without >>>>> any >>>>> trim. Did you pitch your H-stab at all? Do you have a heavy engine? >>>>> >>>>> >>>>> >>>>> >>>>> Read this topic online here: >>>>> >>>>> http://forums.matronics.com/viewtopic.php?p=213795#213795 >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Nov 13, 2008
Hi Juan, I agree again with you regarding the maintenance issue of cables and I do think this is a good reason for using pushrods as they are easy to check. A little feel of the aileron on pre flight will tell you if there is something loose or worn as you can feel the play. If a cable is loose from stretching it may still have tension an you wont feel the difference. Are cable users going to do a tension test every time they fly? I know I wouldn't so I choose to make that problem not a possibility for me. Simple choice. I do also believe (am I right?, I hope so.) that the bigger issue is balance of the ailerons on this plane. As designed there is NO balancing of these control surfaces. This drastically limits the operating speed ( and creates most of the heavy feel of the ailerons). This web site has some very good info and explanation on the subject PLEASE CHECK IT OUT! http://www.theaerodrome.com/forum/aircraft/32996-balanced-ailerons.html Ailerons are balanced in two main ways, with weight and air pressure. Both methods require the hinge point to be somewhere behind the leading edge of the control surface. The XL as designed is just forward of the leading edge and therefore cannot be balanced as is. The simplest fix (if I may use that term) is to extend the lower skin enough to add weights to it (look at a Cessna, this is how my 150's ailerons are balanced). The result is that control pressure remains the same throughout the speed range of the aircraft. Another simple method (using pressure) would be to add spades to the ailerons. At least this should be food for your thoughts. At best you may get a better(safer) aircraft. Cheers, Dirk ________________________________________________________________________________
Subject: Re: Heavy engine and Horiz. stab
Date: Nov 13, 2008
Yup, you are on the right track here. the horiz stab is used to change pitch angle. If you are nose heavy it must be counteracted by down force on the horiz stab/ elevator, efectively doubling the weight that is off balance. In a perfect world there would be 0lbs. of downforce in straight and level flight. Our job is to come as close as we can by balancing the weight before flight. Dirk ----- Original Message ----- From: "Grant Corriveau" <grant.corriveau(at)TELUS.NET> Sent: Thursday, November 13, 2008 7:17 AM Subject: Zenith-List: Heavy engine and Horiz. stab > > > I'm confused by the comments regarding the engine mass and the horizontal > stab installed angle. > > Isn't the engine mass counter-balanced during the construction by final > placement of the battery(s) to maintain the Weight & Balance inside the > acceptable envelope? Once this is accomplished there is no need to > consider "adjusting" the horizontal stab to account for the engine > weight, is there? > > Curious in Canada > Grant > 601 HDS / CAM100 (heavy but worth it) > > > ________________________________________________________________________________
Date: Nov 13, 2008
I m thinking of a simple under the aileron mass balance. There are a lot of airplanes that have a small hanging "spade" type balance and it works. With the 601 ailerons being so light I m sure it wouldn take much lead (Forward) of the hinge line to get that neutral condition... SW ----- Original Message ----- From: "Dirk Zahtilla" <ideaz1(at)sbcglobal.net> Sent: Wednesday, November 12, 2008 8:00 PM Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? > > Back to the cable tension debate, if I may, with all the discussions of > cables and flutter I am more convinced than ever to use pushrods, and > balanced control surfaces. To me, this is a simple, logical fix. I'm not > the first person to do this, and probably not the last. pushrods never > need tension adjusting, they do not put a permanent strain on the airframe > like cables do. If there is any play from worn parts you can tell > instantly on your pre-flight. > As to balance of controls this further relieves stress on the airframe and > if I'm not mistaken helps reduce the possibility of flutter. > > I frankly don't care if Zenith Inc. doesn't like this but it is obviously > very hard and embarassing for a company to admit that they could have done > better and make changes to their design, admitting to those weaknesses in > their design, so I use my own experience and compare this plane to other > designs that have done a better job on some of these issues. I didn't > invent pushrods and balanced ailerons, but I have flown some exceptional > planes that had them so why not.. I'm sure I'm not the only person to > write to Mr Heinz about this issue and the wing failure issue only to get > the pat response that "there are hundreds of these planes flying so it > must be OK" Well maybe most people don't get close to the design limits of > their planes and never find out the hard way that they are borderline in > some areas and you only get one chance to cross that line. > > I still like the plane and plan to build it, but I'll fix these obvious > (in my opinion) weaknesses. > > Dirk > PS Let the flames begin, I'm ready for you! > > > ________________________________________________________________________________
Date: Nov 13, 2008
But, But, but what about flying wings ? These dont have a horizontal stablizer.... My son has a EZE that doest have a H.S. It has two flying surfaces. So does the flying flea from the 1930s.... ----- Original Message ----- From: "Dirk Zahtilla" <ideaz1(at)sbcglobal.net> Sent: Thursday, November 13, 2008 8:41 AM Subject: Re: Zenith-List: Heavy engine and Horiz. stab > > Yup, you are on the right track here. the horiz stab is used to change > pitch angle. If you are nose heavy it must be counteracted by down force > on the horiz stab/ elevator, efectively doubling the weight that is off > balance. In a perfect world there would be 0lbs. of downforce in straight > and level flight. Our job is to come as close as we can by balancing the > weight before flight. > Dirk > ----- Original Message ----- > From: "Grant Corriveau" <grant.corriveau(at)TELUS.NET> > To: > Sent: Thursday, November 13, 2008 7:17 AM > Subject: Zenith-List: Heavy engine and Horiz. stab > > >> >> >> I'm confused by the comments regarding the engine mass and the >> horizontal stab installed angle. >> >> Isn't the engine mass counter-balanced during the construction by final >> placement of the battery(s) to maintain the Weight & Balance inside the >> acceptable envelope? Once this is accomplished there is no need to >> consider "adjusting" the horizontal stab to account for the engine >> weight, is there? >> >> Curious in Canada >> Grant >> 601 HDS / CAM100 (heavy but worth it) >> >> >> >> > > > ________________________________________________________________________________
Date: Nov 13, 2008
Attached are renderings of a part. Given its size, is there anyone on the list with the capability of machining it to very close tolerances from a CATIA part file. I don't have cash, but I do have access to Engelhard silver to barter with. I am told that it would take a 5 axis CNC mill. I am hoping that it could be machined from a 530 x 600 x 180mm billet on a 3 axis mill white side up, flipped and machined again green side up. Material is your choice so long as it is stable. Any thoughts on whether the bit could reach down the side without binding against the material remaining would be appreciated. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213943#213943 Attachments: http://forums.matronics.com//files/filledqpart_186.jpg ________________________________________________________________________________
Date: Nov 13, 2008
Have you considered a casting instead of the milled part? You'd only need a ccess to a CNC router to achieve that, then a geared head or knee mill to f inish out the part. Would love to help you more but only have a South Bend 9A lathe and don't have a milling machine yet. However, I have done a bit o f casting and have found that most regional casting compainies of fabricati on shop's are more than up to such a challange.=0A=0AJWS=0A=0A=0A=0A=0A____ ____________________________=0AFrom: Sabrina <chicago2paris(at)msn.com>=0ATo: zenith-list(at)matronics.com=0ASent: Thursday, November 13, 2008 10:45:12 AM =0ASubject: Zenith-List: Re: Cable Tensions for 601XL?=0A=0A--> Zenith-List message posted by: "Sabrina" =0A=0AAttached are ren derings of a part.- Given its size, is there anyone on the list with the capability of machining it to very close tolerances from a CATIA part file. - I don't have cash, but I do have access to Engelhard silver to barter w ith.- I am told that it would take a 5 axis CNC mill.- I am hoping that it could be machined from a 530 x 600 x 180mm billet on a 3 axis mill whit e side up, flipped and machined again green side up.- Material is your ch oice so long as it is stable. Any thoughts on whether the bit could reach d own the side without binding against the material remaining would be apprec iated.=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matron ics.com/viewtopic.php?p=213943#213943=0A=0A=0A=0A=0AAttachments: =0A=0Aht =- - - - - - - - - - - - - - - -Matt Dralle ========================0A=0A =0A ________________________________________________________________________________
Date: Nov 13, 2008
On Thu, Nov 13, 2008 at 8:45 AM, Sabrina wrote: > Attached are renderings of a part. Given its size, is there anyone on the list with the capability > of machining it to very close tolerances from a CATIA part file. What are your tolerances? Given that you don't mind the material, would it be adequate to make it in a 3D printer out of plastic? Some hint of what you need it for might give people a clue as to how they could help -- like, is this a wind tunnel model? Ihab -- Ihab A.B. Awad, Palo Alto, CA ________________________________________________________________________________
Date: Nov 13, 2008
Hi Grant, What a great question! After scratching my head for a while and reading a half dozen or so responses, I have to come down on the side that a heavy engine does indeed require more down force from the elevator rigging. The reason is only partly because of the heavy engine. You are correct that the balance issue is resolved by repositioning the battery and other equipment. Still, a heavier engine means a heavier empty weight. If you hold the rest of the plane to the same weight (a crazy idea, but I don't know how to handle any other assumption) then the lift must be more to fly level and the elevator must cause a higher angle of attack to get this. Paul XL getting close At 07:17 AM 11/13/2008, you wrote: >I'm confused by the comments regarding the engine mass and the >horizontal stab installed angle. > >Isn't the engine mass counter-balanced during the construction by >final placement of the battery(s) to maintain the Weight & Balance >inside the acceptable envelope? Once this is accomplished there is >no need to consider "adjusting" the horizontal stab to account for >the engine weight, is there? > >Curious in Canada >Grant >601 HDS / CAM100 (heavy but worth it) ________________________________________________________________________________
Date: Nov 13, 2008
Dear Ihab, I was going to use the part to create a mold to make the "green" portion of the rendering. 120 of those green portions assemble into a 3 meter sphere. The gray portion was added to give a flat surface during milling of the top, green surface. Tolerances are important but not vital. If a 3D printer could punch out just 1, much less 120 of the attached Q parts, I would be forever grateful. This is a just a mock up of the cockpit of N5887Q. Off to class... (I have Wednesdays off, 1 morning class at 7AM, the rest in the afternoon for those of you asking--it is a boarding school.) Sabrina Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213954#213954 Attachments: http://forums.matronics.com//files/qinside_155.jpg http://forums.matronics.com//files/qoutside_154.jpg ________________________________________________________________________________
Date: Nov 13, 2008
On Thu, Nov 13, 2008 at 10:05 AM, Sabrina wrote: > If a 3D printer could punch out just 1, much less 120 of the attached Q parts, I would be forever grateful. :) One thought could be to 3D print a *negative* of the part, then use it as a mold for 120 fiberglass layups. I guess it depends on your budget. Also, depending on your needs, 120 slabs of metal in a 3 meter sphere could be way heavy; if you made them out of fiberglass then stuck the borders together with epoxy or whatever, you could end up with a lightweight yet strong part. As in, "Use the monocoque, Luke." Ihab -- Ihab A.B. Awad, Palo Alto, CA ________________________________________________________________________________
Date: Nov 13, 2008
What strap? What modification? I have not heard of this. Please inform me. Bill ************** Get the Moviefone Toolbar. Showtimes, theaters, movie news & http://toolbar.aol.com/moviefone/download.html?ncid=emlcntusdown00000001) ________________________________________________________________________________
Date: Nov 13, 2008
It had to be connected to a covair motor, right? ************** Get the Moviefone Toolbar. Showtimes, theaters, movie news & download.html?ncid=emlcntusdown00000001) ________________________________________________________________________________
Date: Nov 13, 2008
Actually, it was a new prop, it broke off after 2 hours of operation, A manufactures defect caused it to flutter (for a while) then fatigue and break Roger -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Juan Vega Sent: Thursday, November 13, 2008 8:13 AM Subject: RE: Zenith-List: Re: Cable Tensions for 601XL? next time balance the prop, people tend to forget that little part. -----Original Message----- >From: Roger & Lina Hill <hills(at)sunflower.com> >Sent: Nov 12, 2008 7:10 PM >To: zenith-list(at)matronics.com >Subject: RE: Zenith-List: Re: Cable Tensions for 601XL? > >My 601HDS propeller fluttered too !!!! > >Then it broke off. > > > > > >Roger > > > > > > _____ > >From: owner-zenith-list-server(at)matronics.com >[mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of J.T. Machin >Sent: Wednesday, November 12, 2008 11:49 AM >To: zenith-list(at)matronics.com >Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? > > > > >Sabrina, > >I have to agree with Wade. Every aircraft's control system is different and >and the fact that the ailerons have a balance cable really does not impact >its flutter characteristics because flutter is not really a control surface >deflection that originates from the stick. The deflection comes from a >flexing of the system that then stores the spring energy. This flexing and >storing of energy and then releasing that energy as the surface unflexes is >a primary driver in the creation of the flutter effect. That is why stiffer >is better when it comes to control systems. > >That being said, a flutter situation can occur in any of the control >surfaces. As the XL has had several reported instances of aileron flutter, >it seems to be the most prevalent flutter mode. I have not heard of any >report instances of elevator flutter. Also, any additional weight at the >trailing edge of a control surface will absolutely reduce the flutter speed. >I'm not saying that the XL with aileron trim is unsafe, but it does have >less flutter margin than one without the trim system. > >I decided to go with a bungee type trim if required for the the ailerons. > >Jim Machin >601XL, 0-200 >Almost done! > >--- On Wed, 11/12/08, Sabrina wrote: > >From: Sabrina <chicago2paris(at)msn.com> >Subject: Zenith-List: Re: Cable Tensions for 601XL? >To: zenith-list(at)matronics.com >Date: Wednesday, November 12, 2008, 8:24 AM > > > > > > > > >"I did use elevator trim." > > > > > >Wade, > > > > > >Personally, the elevator trim weight bothered me more than > the aileron trim. > > >The ailerons, by their nature of one being up and one down, should, if >properly > > >tensioned, be easier to dampen in flight than a fluttering elevator. So >too, a > > >builder can easily adjust an XL's horizontal stabilizer for proper cruise > > >configuration since it sits so high off the longerons. The aileron trim >was a > > >much easier call for me than the elevator trim. If no aileron trim under >Par. > > >4-36, why elevator trim? > > > > > >As to Par 4-36(c) was it the Cardinal that used foam in the elevator trim >tab > > >that took on water/ice and threw it off balance? > > > > > >Has anyone had to drill a weep hole in their elevator trim tab to make sure >ice > > >does not build up? I ended up gust-locking my elevator in the up position > > >rather than down to keep the ice out. > > > > > > > > > > > > > > >Read this topic online > > > > > > > > ________________________________________________________________________________
Date: Nov 13, 2008
Ya, I know this perfect world, and they all fly canards. Roger -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Dirk Zahtilla Sent: Thursday, November 13, 2008 9:41 AM Subject: Re: Zenith-List: Heavy engine and Horiz. stab Yup, you are on the right track here. the horiz stab is used to change pitch angle. If you are nose heavy it must be counteracted by down force on the horiz stab/ elevator, efectively doubling the weight that is off balance. In a perfect world there would be 0lbs. of downforce in straight and level flight. Our job is to come as close as we can by balancing the weight before flight. Dirk ----- Original Message ----- From: "Grant Corriveau" <grant.corriveau(at)TELUS.NET> Sent: Thursday, November 13, 2008 7:17 AM Subject: Zenith-List: Heavy engine and Horiz. stab > > > I'm confused by the comments regarding the engine mass and the horizontal > stab installed angle. > > Isn't the engine mass counter-balanced during the construction by final > placement of the battery(s) to maintain the Weight & Balance inside the > acceptable envelope? Once this is accomplished there is no need to > consider "adjusting" the horizontal stab to account for the engine > weight, is there? > > Curious in Canada > Grant > 601 HDS / CAM100 (heavy but worth it) > > > ________________________________________________________________________________
Date: Nov 13, 2008
OK, OK, help me get off the Zenith list and onto the 701 list! The problem I'm having is I click on the list I'm interested in,I get the verification e-mail where I'm supposed to click on the link. Problem is it is not bold? or blue? like other links I've seen. I click on it anyway, and nothing happens. Yes,"disable links" is "off" Phil In a message dated 11/13/2008 7:12:49 P.M. Eastern Standard Time, hills(at)sunflower.com writes: --> Zenith-List message posted by: "Roger & Lina Hill" Actually, it was a new prop, it broke off after 2 hours of operation, A manufactures defect caused it to flutter (for a while) then fatigue and break Roger -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Juan Vega Sent: Thursday, November 13, 2008 8:13 AM Subject: RE: Zenith-List: Re: Cable Tensions for 601XL? --> Zenith-List message posted by: Juan Vega next time balance the prop, people tend to forget that little part. -----Original Message----- >From: Roger & Lina Hill <hills(at)sunflower.com> >Sent: Nov 12, 2008 7:10 PM >To: zenith-list(at)matronics.com >Subject: RE: Zenith-List: Re: Cable Tensions for 601XL? > >My 601HDS propeller fluttered too !!!! > >Then it broke off. > > > > > >Roger > > > > > > _____ > >From: owner-zenith-list-server(at)matronics.com >[mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of J.T. Machin >Sent: Wednesday, November 12, 2008 11:49 AM >To: zenith-list(at)matronics.com >Subject: Re: Zenith-List: Re: Cable Tensions for 601XL? > > > > >Sabrina, > >I have to agree with Wade. Every aircraft's control system is different and >and the fact that the ailerons have a balance cable really does not impact >its flutter characteristics because flutter is not really a control surface >deflection that originates from the stick. The deflection comes from a >flexing of the system that then stores the spring energy. This flexing and >storing of energy and then releasing that energy as the surface unflexes is >a primary driver in the creation of the flutter effect. That is why stiffer >is better when it comes to control systems. > >That being said, a flutter situation can occur in any of the control >surfaces. As the XL has had several reported instances of aileron flutter, >it seems to be the most prevalent flutter mode. I have not heard of any >report instances of elevator flutter. Also, any additional weight at the >trailing edge of a control surface will absolutely reduce the flutter speed. >I'm not saying that the XL with aileron trim is unsafe, but it does have >less flutter margin than one without the trim system. > >I decided to go with a bungee type trim if required for the the ailerons. > >Jim Machin >601XL, 0-200 >Almost done! > >--- On Wed, 11/12/08, Sabrina wrote: > >From: Sabrina <chicago2paris(at)msn.com> >Subject: Zenith-List: Re: Cable Tensions for 601XL? >To: zenith-list(at)matronics.com >Date: Wednesday, November 12, 2008, 8:24 AM > >--> Zenith-List message posted by: "Sabrina" > > > > > > > > >"I did use elevator trim." > > > > > >Wade, > > > > > >Personally, the elevator trim weight bothered me more than > the aileron trim. > > >The ailerons, by their nature of one being up and one down, should, if >properly > > >tensioned, be easier to dampen in flight than a fluttering elevator. So >too, a > > >builder can easily adjust an XL's horizontal stabilizer for proper cruise > > >configuration since it sits so high off the longerons. The aileron trim >was a > > >much easier call for me than the elevator trim. If no aileron trim under >Par. > > >4-36, why elevator trim? > > > > > >As to Par 4-36(c) was it the Cardinal that used foam in the elevator trim >tab > > >that took on water/ice and threw it off balance? > > > > > >Has anyone had to drill a weep hole in their elevator trim tab to make sure >ice > > >does not build up? I ended up gust-locking my elevator in the up position > > >rather than down to keep the ice out. > > > > > > > > > > > > > > >Read this topic online > > > > > > > > **************Get the Moviefone Toolbar. Showtimes, theaters, movie news & p://toolbar.aol.com/moviefone/download.html?ncid=emlcntusdown00000001) ________________________________________________________________________________
Date: Nov 13, 2008
Noo to worry, in the 1950 we were going to put it in aircrafts. -----Original Message----- From: Sabrina <chicago2paris(at)msn.com> Sent: Wed, 12 Nov 2008 10:56 pm Subject: Zenith-List: Re: Cable Tensions for 601XL? One word: WOW... do you guys know that General Atomic came this >< close to producing atomic propulsed space craft in the 1960s. Paul... sorry about the no-brainer comment. I actually mis-drilled the first aluminum part I touched. When I put the cylinders on my engine, I actually left a sealing ring off. It is such a terrible feeling to put your engine together and have extra parts afterwords. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=213883#213883 ________________________________________________________________________________
Date: Nov 13, 2008
A heavy engine does not require more down force on the elevator if the plan e is balanced correctly.. A properly balanced standard configuration airpl ane needs a center of mass ahead of the center of lift=2C which would produ ce a nose down pitching force if there were no force applied from the horiz ontal stabilizer and elevator. The Horizontal empennage surfaces provide a downward force in order to keep rotational forces in balance. When that f orce is diminished the nose pitches downward=2C which is what happens to a stable airplane in a stall. The center of mass should always be in a range relataive to the datum which keeps the Center of Mass in front of the cent er of lift by a small margin. Too great a margin will mean that the plane w ill be difficult to fly and may not even rotate for takeoff. Further=2C th e stall speed is raised as the Center of Mass moves forward=2C because the lifting surface must offset the downward force at the tail. You need to build your airplane so the Center of Mass is within the designe r's specs. You can do that by moving the engine closer to the firewall=2C if possible=2C or by putting wieghts in the rear of the aircraft. It is be tter that the weight come from equipment=2C but the weight could also come from mere ballast. If you move your engine back=2C you may need to add som e kind of spacer for the propeller for better handling and performance. In my opinion it would be dangerous for a non-expert simply to make the tai l surfaces larger=2C or to pitch them at a steeper downward angle=2C to off set the weight of an engine. If you intend to do something like that pleas e consult with Zenith first=2C for your own safety.> Date: Thu=2C 13 Nov 20 t: Re: Zenith-List: Heavy engine and Horiz. stab> > --> Zenith-List message posted by: Paul Mulwitz > > Hi Grant=2C> > What a great quest ion!> > After scratching my head for a while and reading a half dozen or so > responses=2C I have to come down on the side that a heavy engine does > indeed require more down force from the elevator rigging.> > The reason is only partly because of the heavy engine. You are > correct that the balance issue is resolved by repositioning the > battery and other equipment. Stil l=2C a heavier engine means a heavier > empty weight. If you hold the rest of the plane to the same weight > (a crazy idea=2C but I don't know how to handle any other > assumption) then the lift must be more to fly level and the elevator > must cause a higher angle of attack to get this.> > Paul> XL getting close> > At 07:17 AM 11/13/2008=2C you wrote:> > >I'm confused by the comments regarding the engine mass and the> >horizontal stab installed angle.> >> >Isn't the engine mass counter-balanced during the construction by> >final placement of the battery(s) to maintain the Weight & Balance> >i nside the acceptable envelope? Once this is accomplished there is> >no need to consider "adjusting" the horizontal stab to account for> >the engine we ight=2C is there?> >> >Curious in Canada> >Grant> >601 HDS / CAM100 (heavy =====================> > > _________________________________________________________________ See how Windows=AE connects the people=2C information=2C and fun that are p art of your life ________________________________________________________________________________
Date: Nov 13, 2008
Flying wings normally have a reflexed airfoil to counteract the rotating moment of the airfoil. One of the flying surfaces of an airplane such as the flying flea provides this. Balance is a different issue altogether. Moving the angle of the stab to counterbalance an out of balance airplane is not possible. The airframe has to be balanced statically about the CG, by balancing the mass of the airframe, this is typically at 30% chord on a parallel chord such as the CH701. If the wings have taper then the CG is typically at the Mean Aerodynamic Chord point. This is how the CG of a flying wing would be calculated. John Read Phone: 303-648-3261 Fax: 303-648-3262 Cell: 719-494-4567 In a message dated 11/13/2008 9:20:48 A.M. Mountain Standard Time, notsew_evets(at)frontiernet.net writes: --> Zenith-List message posted by: "steve" But, But, but what about flying wings ? These dont have a horizontal stablizer.... My son has a EZE that doest have a H.S. It has two flying surfaces. So does the flying flea from the 1930s.... ----- Original Message ----- From: "Dirk Zahtilla" <ideaz1(at)sbcglobal.net> Sent: Thursday, November 13, 2008 8:41 AM Subject: Re: Zenith-List: Heavy engine and Horiz. stab > > Yup, you are on the right track here. the horiz stab is used to change > pitch angle. If you are nose heavy it must be counteracted by down force > on the horiz stab/ elevator, efectively doubling the weight that is off > balance. In a perfect world there would be 0lbs. of downforce in straight > and level flight. Our job is to come as close as we can by balancing the > weight before flight. > Dirk > ----- Original Message ----- > From: "Grant Corriveau" <grant.corriveau(at)TELUS.NET> > To: > Sent: Thursday, November 13, 2008 7:17 AM > Subject: Zenith-List: Heavy engine and Horiz. stab > > >> >> >> I'm confused by the comments regarding the engine mass and the >> horizontal stab installed angle. >> >> Isn't the engine mass counter-balanced during the construction by final >> placement of the battery(s) to maintain the Weight & Balance inside the >> acceptable envelope? Once this is accomplished there is no need to >> consider "adjusting" the horizontal stab to account for the engine >> weight, is there? >> >> Curious in Canada >> Grant >> 601 HDS / CAM100 (heavy but worth it) >> >> >> >> > > > **************Get movies delivered to your mailbox. One month free from blockbuster.com ________________________________________________________________________________
Date: Nov 14, 2008
Subject: Fund Raiser Lagging Last Year By Over 30%...
As of the 13th, the Fund Raiser is currently about 30% behind last year in terms of the number of Contributions. Yet, oddly the number of messages posted per day is up by 10 to 20% on the average. It costs real money to run these Lists and they are supported 100% though your Contributions during the Fund Raiser. Won't you please take a minute right now to make your Contribution to keep these Lists up and running? Contribution Page: http://www.matronics.com/contribution Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 14, 2008
Subject: Re: Zenith-List Digest: 41 Msgs - 11/12/08
Hello Paul, I agree, and although complex panels seem to attract some, I like the clean panels. I also know that experimental - amateur built airplanes don't fall under all the rules. But on the other hand I have heard stories where the DAR sometimes is very specific (remember the whiskey compass discussion). I hope you will have a DAR that accepts this and sees the sense of you argument. Regards, Maarten, plans building XL, getting close to closing the second wing > From: Paul Mulwitz <psm(at)att.net> > Subject: Re: Zenith-List: Wires and fuses and such > > > Hi Maarten, > > I guess the regulation you cited explains why so many panels are > crowded with circuit breakers. In their great wisdom, the FAA seems > to have dictated that solution. > > Fortunately, I don't think part 23 regulations apply to experimental > - amateur built airplanes. This may be one of many examples of the > notion that the FAA regulations are overly restrictive on certified planes. > > To directly answer your question, my plans are to limit my flights to > Day/VFR. I suspect I could safely conduct such flights without any > electrical equipment operating at all. The only really essential > piece of electrical gear is the starter motor. My Jabiru is not > likely to start any other way. > > Best regards, > > Paul ________________________________________________________________________________
Date: Nov 14, 2008
Grant, You have an HDS. Bryan, Scott and I used XL plans or kit. From my comparison of the HDS vs. XL, the XL decreased the decalage. Then the 650 increased the decalage. All Bryan, Scott and I did was increase the decalage of our aircraft to a range similar to that built into your HDS and the new 650s. The factory shifts the wing, we shift the H stab. Other than an HD series used for aerobatics, I don't know of a single 600 series with the increased (I would call nominal) decalage that has had a structural failure. We have had this argument before, but it was prior to the increase in the 650's decalage. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214193#214193 ________________________________________________________________________________
Date: Nov 14, 2008
I agree with you on all counts but, the airplane also has to be built with the proper decalage between the wing and stabilizer. In my case, the CG was within the acceptable range and I still could not trim it out. With the CG near the aft limit I was just able to trim it with full tab deflection. With my aerospace engineering education, I determined that the solution to this situation was to re-pitch the stabilizer. I had somehow got the decalage slightly off during construction. It worked and my test flights after the correction showed the airplane had adequate pitch stability. If we were all building our airplanes in identical rigging fixtures they would all be rigged the same. Since each one is hand built by a different individual, you can expect slight differences in the final product. It should be no surprise that the need for some small corrections might be found during the phase 1 testing. On Nov 13, 2008, at 9:05 PM, Frank Roskind wrote: > A heavy engine does not require more down force on the elevator if > the plane is balanced correctly.. A properly balanced standard > configuration airplane needs a center of mass ahead of the center of > lift, which would produce a nose down pitching force if there were > no force applied from the horizontal stabilizer and elevator. The > Horizontal empennage surfaces provide a downward force in order to > keep rotational forces in balance. When that force is diminished > the nose pitches downward, which is what happens to a stable > airplane in a stall. The center of mass should always be in a range > relataive to the datum which keeps the Center of Mass in front of > the center of lift by a small margin. Too great a margin will mean > that the plane will be difficult to fly and may not even rotate for > takeoff. Further, the stall speed is raised as the Center of Mass > moves forward, because the lifting surface must offset the downward > force at the tail. > > You need to build your airplane so the Center of Mass is within the > designer's specs. You can do that by moving the engine closer to > the firewall, if possible, or by putting wieghts in the rear of the > aircraft. It is better that the weight come from equipment, but the > weight could also come from mere ballast. If you move your engine > back, you may need to add some kind of spacer for the propeller for > better handling and performance. > > In my opinion it would be dangerous for a non-expert simply to make > the tail surfaces larger, or to pitch them at a steeper downward > angle, to offset the weight of an engine. If you intend to do > something like that please consult with Zenith first, for your own > safety. > -- Bryan Martin N61BM, CH 601 XL, RAM Subaru, Stratus redrive. ________________________________________________________________________________
Date: Nov 14, 2008
Hi Maarten, I don't want to get into a regulation interpretation battle, but I will if I must. As I understand the regs and DAR history, the compass issue is completely separate from the part 23 question. Part 23 clearly doesn't apply to Experimental airplanes. Experimental airplanes do require a compass. The issue I have heard discussed is whether the compass must be a whiskey compass or if one of the new-fangled electrical devices like the one found on the Dynon EFIS is sufficient to meet this need. I think the electrical compass is really satisfactory to meet the requirements, but some builders have run into this issue with their DAR and decided a cheap automotive whiskey compass was an easy way to get past an old fashioned DAR. From a strictly practical point of view, it makes sense that you need to be able to figure what direction you are going under all circumstances - including electrical failure. The same argument doesn't apply to trying to trouble-shoot electrical problems while still in flight. Best regards, Paul XL getting close At 07:10 AM 11/14/2008, you wrote: >Hello Paul, > >I agree, and although complex panels seem to attract some, I like the clean >panels. I also know that experimental - amateur built airplanes don't fall >under all the rules. But on the other hand I have heard stories where the DAR >sometimes is very specific (remember the whiskey compass discussion). >I hope you will have a DAR that accepts this and sees the sense of you >argument. > >Regards, > Maarten, > plans building XL, getting close to closing the second wing ________________________________________________________________________________
Subject: Mean Aerodynamic Chord
Date: Nov 14, 2008
John Read, and others: "Mean Aerodynamic Chord" is a length, rather than a point. For an untapered wing, the MAC is the length of the chord measured anywhere along the span. For a tapered planform the MAC is found at a spanwise location where the chord is sort of an average of all the chord lengths. On a wing with simple taper this is easily determined. For a planform with sweep and multiple tapers, typical of modern airliners, it becomes a bit more complicated. I think the point to which you refer is the so-called "aerodynamic center", which is found on the MAC at a distance equaling approximately 25 percent of the MAC aft of the leading edge. The acceptable range of center of gravity locations is usually expressed in percent of MAC; for a particular airplane it might be from 10 percent to 30 percent. The acceptable CG range depends on a number of design features, one of the most powerful being the tendency of the wing to pitch or rotate about its spanwise axis. This tendency must be counteracted by other forces on the airplane, largely by a down force generated by the horizontal tail. The popular old NACA 23000 series airfoils (23012, 23015 etc) were designed to have a low pitching moment. Symmetrical airfoil sections (for example 23000) have zero pitching moment and have often been used on helicopter blades and aerobatic airplanes for that reason. Incidentally, "symmetrical" means identical, top and bottom. Some refer to an airfoil as symmetrical just because it has some curvature on the lower surface, but this is incorrect. You are correct in noting that flying wings typically use an airfoil section which has a reflexed trailing edge. This reduces the pitching tendency to near zero and deflection of the trailing edge surfaces does the rest. You are also correct in noting that changing the incidence of the stabilizer is not the way to correct a static balance situation, although it will have an effect on the overall static stability. I hope this helps generate light, rather than heat. George ________________________________________________________________________________
Subject: Re: Mean Aerodynamic Chord
Date: Nov 14, 2008
Right On ! ----- Original Message ----- From: George Swinford To: zenith-list(at)matronics.com Sent: Friday, November 14, 2008 12:52 PM Subject: Zenith-List: Mean Aerodynamic Chord John Read, and others: "Mean Aerodynamic Chord" is a length, rather than a point. For an untapered wing, the MAC is the length of the chord measured anywhere along the span. For a tapered planform the MAC is found at a spanwise location where the chord is sort of an average of all the chord lengths. On a wing with simple taper this is easily determined. For a planform with sweep and multiple tapers, typical of modern airliners, it becomes a bit more complicated. I think the point to which you refer is the so-called "aerodynamic center", which is found on the MAC at a distance equaling approximately 25 percent of the MAC aft of the leading edge. The acceptable range of center of gravity locations is usually expressed in percent of MAC; for a particular airplane it might be from 10 percent to 30 percent. The acceptable CG range depends on a number of design features, one of the most powerful being the tendency of the wing to pitch or rotate about its spanwise axis. This tendency must be counteracted by other forces on the airplane, largely by a down force generated by the horizontal tail. The popular old NACA 23000 series airfoils (23012, 23015 etc) were designed to have a low pitching moment. Symmetrical airfoil sections (for example 23000) have zero pitching moment and have often been used on helicopter blades and aerobatic airplanes for that reason. Incidentally, "symmetrical" means identical, top and bottom. Some refer to an airfoil as symmetrical just because it has some curvature on the lower surface, but this is incorrect. You are correct in noting that flying wings typically use an airfoil section which has a reflexed trailing edge. This reduces the pitching tendency to near zero and deflection of the trailing edge surfaces does the rest. You are also correct in noting that changing the incidence of the stabilizer is not the way to correct a static balance situation, although it will have an effect on the overall static stability. I hope this helps generate light, rather than heat. George ________________________________________________________________________________
From: "Dave VanLanen" <davevanlanen(at)sbcglobal.net>
Subject: 601XL - Aileron Trim Tab Deflection
Date: Nov 14, 2008
I just finished installing my aileron trim, and when I tested it, I can only get a total of 40 degrees of deflection. According to the plans, I should be able to get 50 degrees of deflection (25 up and 25 down). Adjusting the length of the control rod only changes the distribution of the 40 degrees between up and down - it does not increase the total deflection. I checked that the servo was working correctly, which it was (.7" travel per specs). I also checked that there was no binding of the control rod clevis with the trim tab horn angle. The only thing I could find was that the center of the control rod mounting hole in the horn angle was 13 mm up from the flange instead of the 12 mm specified in the plans. I find it hard to believe that 1 mm would cause a 10 degree loss in deflection. Has anyone else experienced this problem, and if so, what did you do to resolve? Thanks, Dave Van Lanen 601XL - tail done, flaps done, working on ailerons ________________________________________________________________________________
Subject: Re: 601XL - Aileron Trim Tab Deflection
Date: Nov 14, 2008
Looks like the difference between 12mm and 13mm would be about 1.7 degrees at the .7 travel. I didn't calculate what it would be out at the tip of the trim tab, don't have the dimension handy. -------- Ron Lendon, Clinton Township, MI Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214324#214324 ________________________________________________________________________________
Date: Nov 14, 2008
Subject: I've moved to FLAG (and you can too)
Attention Northern California (SF Bay Area) builders. After building in my garage for the past four years, I've moved my project to "First Light Aviation Group" (FLAG) in Livermore, California, adjacent to the Livermore Airport (lvk). FLAG has individual building bays, each one complete with plenty of power, compressed air, large locking tool boxs, work tables, shelves and a pallet rack for large parts. FLAG also supplies large tools (drill press, shear, brake, etc) with convenient bathrooms, vending machines, fridge and microwave. And, it's available 24/7. In the lobby is a retail store with pilot supplies and building supplies. A large meeting room upstairs rounds out the facility. I found that when I moved my airplane to FLAG, I was able to work in the company of fellow builders/pilots and without the distractions of building at home. Now I'm confident that I'll get my plane flying in short order. No one asked me to post this and I'm not affiliated with FLAG, I'm just a happy customer. Check it out at www.flaglvk.com Rich Vetterli 601XL/Corvair 95% done, 95% to go Check out my progress at www.geocities.com/stixx5a ________________________________________________________________________________
Subject: Balanced and better flight controls
From: "chris Sinfield" <chris_sinfield(at)yahoo.com.au>
Date: Nov 15, 2008
Just read this in the Zenith flyer Much work was done to the controls, which are now more balanced for better feel. "The 650 LS's airframe structure and flying characteristics are now more like an FAR 23 type aircraft," said AMD Sales Director John Degonia. "Flying schools and pilots who were looking at buying an FAR 23 aircraft have now committed to the 650." So what have they changed in the 650 re controls???? to make it balanced and better???? Chris. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214333#214333 ________________________________________________________________________________
Date: Nov 15, 2008
Subject: Re: I've moved to FLAG (and you can too)
I am Green with Envy! Paul XL getting close in desperate need of hangar/runway Camas, WA At 10:46 PM 11/14/2008, you wrote: >I've moved my project to "First Light Aviation Group" >(FLAG) in Livermore, California ________________________________________________________________________________
Date: Nov 15, 2008
make another horn and put the hole closer in. Juan -----Original Message----- >From: Dave VanLanen <davevanlanen(at)sbcglobal.net> >Sent: Nov 14, 2008 11:28 PM >To: zenith601-list(at)matronics.com, zenith-list(at)matronics.com >Subject: Zenith-List: 601XL - Aileron Trim Tab Deflection > >I just finished installing my aileron trim, and when I tested it, I can only >get a total of 40 degrees of deflection. According to the plans, I should >be able to get 50 degrees of deflection (25 up and 25 down). Adjusting the >length of the control rod only changes the distribution of the 40 degrees >between up and down - it does not increase the total deflection. I checked >that the servo was working correctly, which it was (.7" travel per specs). >I also checked that there was no binding of the control rod clevis with the >trim tab horn angle. The only thing I could find was that the center of the >control rod mounting hole in the horn angle was 13 mm up from the flange >instead of the 12 mm specified in the plans. I find it hard to believe that >1 mm would cause a 10 degree loss in deflection. >Has anyone else experienced this problem, and if so, what did you do to >resolve? > >Thanks, >Dave Van Lanen >601XL - tail done, flaps done, working on ailerons ________________________________________________________________________________
From: Grant Corriveau <grant.corriveau(at)telus.net>
Date: Nov 15, 2008
Ah! Thanks, Sabrina, I had to stop and research my aeronautical lexicon for 'decalage' but wikki came through (for anyone else who needs to refresh their theory of flight brain cells as well - http://en.wikipedia.org/wiki/ Decalage) Now your discussion on the topic makes perfect sense. Thanks again, Happy Spaceship building, Grant ________________________________________________________________________________
Date: Nov 15, 2008
Thanks Bryan, Your discussion of this adjustment makes more sense to me now. I found that the final setting of the ailerons to be very ambiguous as well, and I wonder if that also contributes to the differences in individual aircraft. I originally found my aircraft flew a little nose-high in cruise. I tweaked both my ailerons down a degree or two (barely noticeable visually) and it improved the situation. My stall speed is now pretty close to the 'book' value as well. All this gets me thinking of ways to further improve the STOL performance of my 601 (it'll never be a speed Queen and that's not what I bought it for anyway.) So I might as well tweak the STOL end of the envelope. I'll soon be adding the VGs as recorded in the online videos by Viktor (search youtube for this video: 0TPLa50Dvzg) Happy testing Grant ________________________________________________________________________________
Date: Nov 15, 2008
601XL - Aileron Trim Tab DeflectionHi Dave, the 12 vs 13mm hole placement causes a 8% reduction in movement or 46 vs 50 deg. If you also shifted the location toward the trailing edge of the trim tab this could easily account for the rest of the error. With these small parts small errors add up fast. Do like Juan says if your not ok with 40 deg. and make a new control horn. No big... Dirk ----- Original Message ----- From: Dave VanLanen To: zenith601-list(at)matronics.com ; zenith-list(at)matronics.com Sent: Friday, November 14, 2008 8:28 PM Subject: Zenith-List: 601XL - Aileron Trim Tab Deflection I just finished installing my aileron trim, and when I tested it, I can only get a total of 40 degrees of deflection. According to the plans, I should be able to get 50 degrees of deflection (25 up and 25 down). Adjusting the length of the control rod only changes the distribution of the 40 degrees between up and down - it does not increase the total deflection. I checked that the servo was working correctly, which it was (.7" travel per specs). I also checked that there was no binding of the control rod clevis with the trim tab horn angle. The only thing I could find was that the center of the control rod mounting hole in the horn angle was 13 mm up from the flange instead of the 12 mm specified in the plans. I find it hard to believe that 1 mm would cause a 10 degree loss in deflection. Has anyone else experienced this problem, and if so, what did you do to resolve? Thanks, Dave Van Lanen 601XL - tail done, flaps done, working on ailerons ________________________________________________________________________________
Subject: Re: Aileron Adustment
Date: Nov 15, 2008
Good point to bring up. The ailerons do make a big change in the airfoil's performance (thats their job). Dropping them like you say will lower stall speed and also cruise speed. raising them does the opposite. When I did the last annual on my C-150 they were found to be a couple degrees low. When I got them up where they should be I picked up almost 5mph. at cruise (at 7000-8000msl). If I went up another 2 deg. it might go faster but like your situation stall speed would be going up as well. This is a good thing to add to flight testing. Starting at neutral and adjusting up and down within about +-3 deg. max. and getting performance numbers. Dirk ----- Original Message ----- From: "Grant Corriveau" <grant.corriveau(at)TELUS.NET> Sent: Saturday, November 15, 2008 7:52 AM Subject: Re: Zenith-List: Heavy engine and Horiz. stab > > > Thanks Bryan, > > Your discussion of this adjustment makes more sense to me now. I found > that the final setting of the ailerons to be very ambiguous as well, and > I wonder if that also contributes to the differences in individual > aircraft. I originally found my aircraft flew a little nose-high in > cruise. I tweaked both my ailerons down a degree or two (barely > noticeable visually) and it improved the situation. My stall speed is > now pretty close to the 'book' value as well. > > All this gets me thinking of ways to further improve the STOL performance > of my 601 (it'll never be a speed Queen and that's not what I bought it > for anyway.) So I might as well tweak the STOL end of the envelope. > I'll soon be adding the VGs as recorded in the online videos by Viktor > (search youtube for this video: 0TPLa50Dvzg) > > Happy testing > Grant > > > ________________________________________________________________________________
Date: Nov 15, 2008
Hi Guys, Watch out for one of the real "Gotchyas" here. For aircraft control in the stall it is very important that the wing roots stall before the tips. This gives you aileron control and makes for a nice straight forward stall. If you adjust the ailerons too much you could take this beyond the good control point and make your plane very hard to control in the stall. There is a small amount of "Wash out" built into the ailerons to keep them flying when the wing root stalls. I doubt this is enough to keep them flying longer than the root of they are adjusted too far to "Increase the stall speed" as mentioned in this thread. This is a similar trick to adjusting the flaps to a negative displacement to reduce lift, increase speed, and increase the stall speed a little. You can't do this much because of the hinge location. Even so, increasing the stall speed at the flaps has little control implications. The ailerons are whole different kettle of fish. Paul XL getting close At 08:46 AM 11/15/2008, you wrote: >Good point to bring up. The ailerons do make a big change in the >airfoil's performance (thats their job). Dropping them like you say >will lower stall speed and also cruise speed. raising them does the >opposite. When I did the last annual on my C-150 they were found to >be a couple degrees low. When I got them up where they should be I >picked up almost 5mph. at cruise (at 7000-8000msl). If I went up >another 2 deg. it might go faster but like your situation stall >speed would be going up as well. ________________________________________________________________________________
Date: Nov 15, 2008
Hah! I had to do the same thing myself as I couldn=A2t remember what it mea nt either. -Undoubtedly we=A2ll all be building away on a project a few y ears from now and be interrupted by a news story of some young aeronautical engineer=A2s flight testing of a new design ground to orbit shuttle craft. =0AJWS=0A=0A=0A=0A=0A________________________________=0AFrom: Grant Corriv eau =0ATo: zenith-list(at)matronics.com=0ASent: Sat urday, November 15, 2008 9:39:40 AM=0ASubject: Re: Zenith-List: Heavy engin grant.corriveau(at)telus.net>=0A=0AAh! Thanks, Sabrina,=0A=0AI had to stop and research my aeronautical lexicon for 'decalage'- but wikki came through (for anyone else who needs to refresh their theory of flight brain cells as well - http://en.wikipedia.org/wiki/Decalage)=0A=0ANow your discussion on the topic makes perfect sense.- Thanks again,=0A=0AHappy Spaceship buildi ng,=0AGrant=0A=0A=0A ________________________________________________________________________________
Subject: Attaching the Axles
Date: Nov 15, 2008
OK the plans are a little light here It says to center the axle on the bottom of the spring gear but how far up from the bottom does it go!! Pics anyone??? And do you round the bottom of the spring gear to match the round part of the axle flange?? Zenith doesn't have a picture of the blasted thing without the wheel installed I'm gonna have a machine shop cut the mounting notches and drill the axle holes as well as make the notches for the brake caliper mounting, and I'm hoping to get it done this week, so pony up the advice kids!!! Thanks Larry Whitlow 601XL N69102 (reserved) 71% done 84% to go ( I'd better check my math) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214395#214395 ________________________________________________________________________________
Subject: Re: Attaching the Axles
Date: Nov 15, 2008
Larry, I tried to locate the pads to minimize the work on the gear legs.? I just slightly rounded the end corners of the gear legs.? I have attached a couple of drawings that I used to determine the location and orientation. The drawings are to scale; but to ensure the scale, the two random short lines ? must be exactly 10" apart.? Let me know if you have questions. -----Original Message----- From: lwhitlow <ldwhitlow(at)comcast.net> Sent: Sat, 15 Nov 2008 5:26 pm Subject: Zenith-List: Attaching the Axles OK the plans are a little light here It says to center the axle on the bottom of the spring gear but how far up from the bottom does it go!! Pics anyone??? And do you round the bottom of the spring gear to match the round part of the axle flange?? Zenith doesn't have a picture of the blasted thing without the wheel installed I'm gonna have a machine shop cut the mounting notches and drill the axle holes as well as make the notches for the brake caliper mounting, and I'm hoping to get it done this week, so pony up the advice kids!!! Thanks Larry Whitlow 601XL N69102 (reserved) 71% done 84% to go ( I'd better check my math) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214395#214395 ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: Nov 15, 2008
Oops!? Forgot to attach photos. Jay in Dallas -----Original Message----- From: lwhitlow <ldwhitlow(at)comcast.net> Sent: Sat, 15 Nov 2008 5:26 pm Subject: Zenith-List: Attaching the Axles OK the plans are a little light here It says to center the axle on the bottom of the spring gear but how far up from the bottom does it go!! Pics anyone??? And do you round the bottom of the spring gear to match the round part of the axle flange?? Zenith doesn't have a picture of the blasted thing without the wheel installed I'm gonna have a machine shop cut the mounting notches and drill the axle holes as well as make the notches for the brake caliper mounting, and I'm hoping to get it done this week, so pony up the advice kids!!! Thanks Larry Whitlow 601XL N69102 (reserved) 71% done 84% to go ( I'd better check my math) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214395#214395 ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: Nov 15, 2008
Subject: 601XL Tail and Wing Kit for Sale
Dear Listers: I have a Zodiac 601XL Tail (stab complete and elevator almost complete) and Wing Kit (not started) with standard tanks, fuel system kit, baggage lockers, landing lights, position lights, etc. All clecos, tools, bits, etc.$4,000.00 takes all. Financial situation forces sale. Come and get it.... Forest K. Rocklin, CA (Sacramento Area) ________________________________________________________________________________
Subject: Re: Balanced and better flight controls
Date: Nov 15, 2008
Go to the zenith builders site, there is a list there of the changes. -------- Ron Lendon, Clinton Township, MI Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214438#214438 ________________________________________________________________________________
Date: Nov 15, 2008
I ditto what Juan says. Just make a new part and let's all stop over analyzing this. -------- Ron Lendon, Clinton Township, MI Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214439#214439 ________________________________________________________________________________
Date: Nov 16, 2008
Subject: What's My Contribution Used For?
Dear Listers, Some have asked, "What's my Contribution used for?" and that's a good question. Here are just a few examples of what your direct List support enables. It provides for the very expensive, commercial-grade T1 Internet connection used on the List insuring maximum performance and minimal contention when accessing List services. It pays for the regular system hardware and software upgrades enabling the highest performance possible for services such as the Archive Search Engine, List Browser, and Forums. It pays for 19+ years worth of online archive data available for instant random search and access. And, it offsets the many hours spent writing, developing, and maintaining the custom applications that power this List Service such as the List Browse, Search Engine, Forums, Wiki and PhotoShare. But most importantly, your List Contribution enables a forum where you and your peers can communicate freely in an environment that is free from moderation, censorship, advertising, commercialism, SPAM, and computer viruses. How many places on the Internet can you make all those statements these days? It is YOUR CONTRIBUTION that directly enables these many aspects of these valuable List services. Please support it today with your List Contribution. Its one of the best investments you can make in your Sport... List Contribution Web Site: http://www.matronics.com/contribution Thank you for your support! Matt Dralle Email List Administrator ________________________________________________________________________________
Subject: Re: Heavy engine and Horiz. stab (Grant Corriveau)
Date: Nov 16, 2008
Grant, I noticed I was flying slightly nose up in cruise in my 701. I dropped the flaperons a small amount and the nose came down and I picked up about 2 mph. Chuck D. N701TX ________________________________________________________________________________
Date: Nov 16, 2008
On my Kitfox 2, the flapperons were primarily used to trim the plane, according to the flight manual. Roger _____ From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Chuck Deiterich Sent: Sunday, November 16, 2008 11:01 AM Subject: Zenith-List: Re: Heavy engine and Horiz. stab (Grant Corriveau) Grant, I noticed I was flying slightly nose up in cruise in my 701. I dropped the flaperons a small amount and the nose came down and I picked up about 2 mph. Chuck D. N701TX ________________________________________________________________________________
Date: Nov 16, 2008
OK, my stupid factor is in high gear today.- I'm having difficulty with t he flap switch wiring as shown on 6B-20.- I've attached a copy.- Somebo dy help me out, as I can't seem to get it right.- I see that the black wi re from the flap motor goes to the #1 lug.- Red goes to number 3 lug.- Ground goes to #2.- Hot wire from the buss goes to 5 Beyond that I get co nfused.- I've attached the diagram. Thanks in advance. Bill Pagan --- On Sun, 11/16/08, Chuck Deiterich wrote: From: Chuck Deiterich <cffd(at)pgrb.com> Subject: Zenith-List: Re: Heavy engine and Horiz. stab (Grant Corriveau) Date: Sunday, November 16, 2008, 12:00 PM Grant, - I noticed I was flying slightly nose up in cruise in my 701.- I dropped the flaperons a small amount and the nose came down and I picked up about 2 mph.- - Chuck D. N701TX =0A=0A=0A ________________________________________________________________________________
Date: Nov 16, 2008
Subject: Flap Switch Wiring
Sorry forgot to change the subject line on the below message. Bill Pagan --- On Sun, 11/16/08, Bill Pagan wrote: From: Bill Pagan <pdn8r(at)yahoo.com> Subject: Re: Zenith-List: Re: Heavy engine and Horiz. stab (Grant Corrivea u) Date: Sunday, November 16, 2008, 3:35 PM OK, my stupid factor is in high gear today.- I'm having difficulty with t he flap switch wiring as shown on 6B-20.- I've attached a copy.- Somebo dy help me out, as I can't seem to get it right.- I see that the black wi re from the flap motor goes to the #1 lug.- Red goes to number 3 lug.- Ground goes to #2.- Hot wire from the buss goes to 5 Beyond that I get co nfused.- I've attached the diagram. Thanks in advance. Bill Pagan --- On Sun, 11/16/08, Chuck Deiterich wrote: From: Chuck Deiterich <cffd(at)pgrb.com> Subject: Zenith-List: Re: Heavy engine and Horiz. stab (Grant Corriveau) Date: Sunday, November 16, 2008, 12:00 PM Grant, - I noticed I was flying slightly nose up in cruise in my 701.- I dropped the flaperons a small amount and the nose came down and I picked up about 2 mph.- - Chuck D. N701TX =0A=0A=0A ________________________________________________________________________________
Date: Nov 16, 2008
Thanks for everyone's input to my question. Sorry if it caused any discord in the group - that was not my intention. Dave Subject: Zenith-List: Re: 601XL - Aileron Trim Tab Deflection From: "Ron Lendon" <rlendon(at)comcast.net> I ditto what Juan says. Just make a new part and let's all stop over analyzing this. -------- Ron Lendon, Clinton Township, MI Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) ________________________________________________________________________________
Date: Nov 16, 2008
OK, the note above the schematic that says "Circuit is shown for flaps up: the worm gear is in the retracted position shutting off the up limit micro sw". But the schematic shows the up-limit switch closed, not open. So they contradict each other. I think the schematic either shows the system in the full down position or is wrong. It all depends on which way the motor turns when red is positive or black is positive. Since I only currently have the new-style sealed flap motor I can't test this for you. But as shown if you moved the toggle to connect lugs 1-2 and lugs 4-5 nothing will happen because the "down" switch is open, breaking the circuit from lug 4. If you move the toggle to connect lugs 2-3 and 5-6 the motor will turn until the "up" switch gets hit and breaks the circuit from lug 6. Anyway the red wire goes to lug 3 on the toggle switch AND the common lug on the "down" limit micro-switch (the one towards the rear of the plane and away from the electric motor). Likewise the black wire goes to lug 1 and the "normally closed" lug (marked "NC") on the flap-up limit switch (towards the front of the plane and the electric motor) In all four wires have to run from the flap actuator to the toggle switch on your panel. The remaining two wires are: - a wire from the common lug on the "up" limit switch to lug 6 on the toggle on the panel - a wire from the normally closed ("NC") lug on the "down limit" switch to lug 4 on the toggle on the panel. BE VERY CARFUL with the screw terminals on the limit switches. The plastic cases are fragile. Don't try to bend the lugs. Basically for either direction the toggle on the panel and the appropriate limit switch are wired in series. So the motor will only move as long as both are closed. Release the toggle or hit the limit switch and the motor stops. Test wire half the system (like just the "moving down" direction) and try it with a car battery. You can flip the micro-switch by hand before the traveler reaches it to see if the switch will actually stop the travel. -- Craig From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bill Pagan Sent: Sunday, November 16, 2008 1:35 PM Subject: Re: Zenith-List: Re: Heavy engine and Horiz. stab (Grant Corriveau) OK, my stupid factor is in high gear today. I'm having difficulty with the flap switch wiring as shown on 6B-20. I've attached a copy. Somebody help me out, as I can't seem to get it right. I see that the black wire from the flap motor goes to the #1 lug. Red goes to number 3 lug. Ground goes to #2. Hot wire from the buss goes to 5 Beyond that I get confused. I've attached the diagram. Thanks in advance. Bill Pagan --- On Sun, 11/16/08, Chuck Deiterich wrote: From: Chuck Deiterich <cffd(at)pgrb.com> Subject: Zenith-List: Re: Heavy engine and Horiz. stab (Grant Corriveau) Date: Sunday, November 16, 2008, 12:00 PM Grant, I noticed I was flying slightly nose up in cruise in my 701. I dropped the flaperons a small amount and the nose came down and I picked up about 2 mph. Chuck D. N701TX ________________________________________________________________________________
Date: Nov 16, 2008
Hi Bill, The trick to understanding DPDT switches like the toggle switch used in the flaps is to know which circuits close when you move the handle. With this switch in the center position (where it rests with no user pushing) none of the circuits are closed. When you push the switch up the bottom output is connected to the center. When you push the switch down the top output pins are connected to the center pins. The circuit operation depends on the use of the "NO" pins on the microswitches. These are "Normally Open". When the mechanical gizmo moves to operate the limit switch it changes the outputs so the "NO" pins become connected to the Common pin and the "NC" pin becomes disconnected from the Common. Opening the NC pin disconnects the power from the motor so the motion is "Limited". You need to figure out which pins are normally closed, common, and normally open on the SPDT microswitches. Then you can wire up the whole thing and it actually works. You might be able to tell by seeing marks on the microswitches, and you can certainly tell with an ohm-meter. I hope this helps. If you still don't get it please describe the problem you are having and I might be able to figure out what is wrong. Good luck, Paul XL getting close Retarded (oops, I mean retired) Electrical Engineer At 12:35 PM 11/16/2008, you wrote: >OK, my stupid factor is in high gear today. I'm having difficulty >with the flap switch wiring as shown on 6B-20. I've attached a >copy. Somebody help me out, as I can't seem to get it right. I see >that the black wire from the flap motor goes to the #1 lug. Red >goes to number 3 lug. Ground goes to #2. Hot wire from the buss >goes to 5 Beyond that I get confused. I've attached the diagram. > >Thanks in advance. > >Bill Pagan ________________________________________________________________________________
Date: Nov 16, 2008
Bill, The idea behind that circuit is that it reverses the polarity going to the motor. One direction and ground is connected to the black and power to the red, push the switch other way and you have the reverse situation. You could hook it up without the limit switches at all and it would still work, but you wouldn't have a switch killing the power when you get to the end of the stroke. Where the schematic shows the wire as if joined in the middle you can hook to either end. You just need wire joining the described lug on the switch to either the motor or the limit switch side that then has a wire going to the motor. I think it will help you if you imagine the circuit without the limit switches. Hope this helps. Dan [quote] ="pdn8r(at)yahoo.com"]OK, my stupid factor is in high gear today. I'm having difficulty with the flap switch wiring as shown on 6B-20. I've attached a copy. Somebody help me out, as I can't seem to get it right. I see that the black wire from the flap motor goes to the #1 lug. Red goes to number 3 lug. Ground goes to #2. Hot wire from the buss goes to 5 Beyond that I get confused. I've attached the diagram. Thanks in advance. Bill Pagan --- On Sun, 11/16/08, Chuck Deiterich wrote: > From: Chuck Deiterich > Subject: Re: Heavy engine and Horiz. stab (Grant Corriveau) > To: "zenith-list" > Date: Sunday, November 16, 2008, 12:00 PM > > Grant, > > I noticed I was flying slightly nose up in cruise in my 701. I dropped the flaperons a small amount and the nose came down and I picked up about 2 mph. > > Chuck D. > N701TX -------- Scratch building XL with Corvair Engine Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214607#214607 ________________________________________________________________________________
Date: Nov 17, 2008
Subject: electrical switches / curcuit breakers
Its getting time to start planning the Electrical curcuits my plane.-- I am looking at the circuit breaker/ switch to act as both Switch and circu it breaker also.- - http://www.aircraftspruce.com/catalog/elpages/pbcircuitbrkr.php-- W31 S eries - Has anyone had a problem using this method?-- Pros. or cons-- Any ideas? - Gary Bassham (N7601) resereved Millsap, Tx - -=0A=0A=0A ________________________________________________________________________________
From: "Dr. Andrew Elliott" <a.s.elliott(at)cox.net>
Subject: Flap Switch Wiring Diagram
Date: Nov 17, 2008
I have a flap switch wiring diagram on a web page at http://members.cox.net/n601ge/drawings/flap_switch.html or you can use this tiny link (for a few days) http://tinyurl.com/5owktt FWIW, Andy Elliott, Mesa, AZ N601GE (registered) 601XL/TD, Corvair, finishing... ________________________________________________________________________________
Subject: Re: Zenith- Alert To Aileron Cable Tension
Date: Nov 17, 2008
Dear 601XL Builders and Flyers, my eyes have been opened to an issue. All this talk about flutter and cables, etc., led me to buy a tensionmeter and check the cables in my XL. Wow was I surprised! The aileron cables were at 17 pounds and the elevator at below 10 pounds. By ZAC they should have been 30 & 40 pds. I reset them and flew. I was pleased at the difference in control and response. Now before you think "that just can't happen to me"?I set my cables with my hands plucking them, seemed good and tight.I have tightened mine twice since I built her. No body has "calibrated" fingers. I alert you all and?hope everybody will check their cables. I had flutter a couple years ago that scared the poop out of me. Don't want it again or that anybody should be lost because of it. The cable tester cost about $190. How much does having a wing come off cost? Best wishes, Bill of Georgia N505WP 601XL-3300 140 hours? ________________________________________________________________________________
Subject: Re: electrical switches / curcuit breakers
Date: Nov 17, 2008
I'm not the voice of experience yet but I'm almost done wiring and I'll list some considerations I had. The major downside is cost. I have several 3 amp breakers on my panel and as you will note they are the most expensive on the entire list. In my case I had to go back and replace a couple with a higher amperage and now have breakers laying on the table which I won't use. Since I went with w58's that isn't a big hit. Another downside is -- is there any visual indication if they are tripped? (I don't know the answer.) A part of my goal was the very minimum exposure of wires that could short while unprotected. If you use a combination switch/breaker you either have to have it close to the buss bar (maximum protection but possibly inconvenient location) or else have a unprotected hot wire going to your switch/breaker(which you located conveniently). On the plus side is a lot of convenience. They take up much less space. You don't have to worry about the quality of your crimps between a breaker and your switch and save you the labor of wiring a separate switch. Its getting time to start planning the Electrical curcuits my plane. I am looking at the circuit breaker/ switch to act as both Switch and circuit breaker also. http://www.aircraftspruce.com/catalog/elpages/pbcircuitbrkr.php W31 Series Has anyone had a problem using this method? Pros. or cons Any ideas? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214680#214680 ________________________________________________________________________________
Date: Nov 17, 2008
That's my intention also. I think most people don't do it because they cost a lot more. I like the concept of using one part instead of 2 to do the job. Dirk ----- Original Message ----- From: burbby To: zenith-list(at)matronics.com Sent: Monday, November 17, 2008 2:44 AM Subject: Zenith-List: electrical switches / curcuit breakers Its getting time to start planning the Electrical curcuits my plane. I am looking at the circuit breaker/ switch to act as both Switch and circuit breaker also. http://www.aircraftspruce.com/catalog/elpages/pbcircuitbrkr.php W31 Series Has anyone had a problem using this method? Pros. or cons Any ideas? Gary Bassham (N7601) resereved Millsap, Tx 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
From: "Scott Thatcher" <s_thatcher(at)bellsouth.net>
Subject: 9 Hour X-Country, engine purred, cables loosened!
Date: Nov 17, 2008
Here is a rundown of my 9 hour x-country last month from Palm Beach Gardens, FL to Andrews, NC. It's only a 700 mile (statute) flight but I had headwinds and I kept the speed below 100 mph the entire trip. I put 40 pounds of baggage in the rear baggage area in order to help keep the nose up without using full trim during flight. And it worked beautifully. To alleviate my heavy left wing, I kept 12 gallons in the right wing, 30 lbs baggage in the right locker, and 6 gallons in the left wing. Now I could fly hands off most of the trip. When I left Palm Beach Gardens, the aileron cables were tight although I didn't use a tensionometer to measure the tautness of the cables. My first stop was in Sebring for lunch. On takeoff, the left canopy lock unlatched. After Jay's experience, I throttled back and made a 500' pattern and retuned to land. Reseated the latch and again took off. Because of light turbulence (heavy in these LSA's), and strong headwinds with gusts, I decided to call it quits fairly early on Saturday afternoon and spend the night in Ocala, FL. I asked the FBO to tie down the aircraft and I headed to the Motel. The next morning, I loaded the aircraft similar to above and noted that the tie downs were extremely tight. I would say at least 50-100 lbs of force were used to tie the wings down. At the time, I thought that was a good idea because of the gusty conditions but later wondered what affect the negative load had on the lower spar cap. A quick and dirty analysis indicated that the bending moments of 1100 ft-lbs (old school) would equate to a small 200 lb load at the center of the wing. That's about 0.25 g negative. Nothing to worry about. At least yet. The next 6 hours were spent cruising around 4500 feet and landing at several locations for fuel. My first stop was at Tellfair-Wheeler in Georgia and to my surprise, they had no fuel and were completely unattended. So I made a short hop to Dublin and re-fueled there. Talked to a fellow who worked at the AMD factory and he mentioned I needed to look at the bearing covers on the wheels when I get a chance. He also spoke very favorably about the quality of workmanship and he really enjoyed the sound of that Corvair engine. Next stop was to be Habersham at the foothills just south of Andrews, NC. But, while I was now at 6500 feet, it was very difficult to descend to land and make that long climb back up to altitude all over again so I decided to just continue over the mountains to Andrews. It was about now that I noticed a slight difference in the feel of the ailerons. I could move the stick left and right about an inch without any movement of the ailerons themselves. As anyone knows when you fly over open water, the engine will invariably make small noises that you have never heard before just about the time you reach a point of no-return. And it is also true when flying over mountains, ailerons will start to buzz, cables feel like they are no longer attached and the engine starts making noises not heard before... you know the slight decrease in rpm that lasts about a thousandth of a second and causes your heart to momentarily stop. 30 minutes later I was pushing N601EL into my hangar in Andrews, NC. Other than directly over the mountains, she flew well and the engine ran exceptionally. My G-Meter showed that I had only experienced a 1.7 G positive and 0.4 G negative for the entire trip. But now I wanted to know what was going on with the cables. I pulled the seats out and ran my hand over the aileron cables and noticed they seemed much looser than when they were installed. Then I found the balance cable and it was limp... no tension at all. I immediately ordered a Tensionometer from ACS and when I checked the cable tensions, here is what I discovered. Rudder Cable: 12-15 lbs. Aileron Cable: 10 lbs. Balance Cable: 0 (not measurable). Elevator cable: 10-12 lbs. Now what worried me was, "How does an aileron and balance cable become so loose in so short a time?" The only way I could think of was that the bellcrank moved or the wing geometry changed, both of which gave me a chill! But neither of these things occurred. I checked the fairleads and they were still in place. And all nicopress fittings were still attached and turnbuckes still safetied. So I plan to re-tighten to the new specs of 40/30/22 +/- 5 (Elevator, Aileron, Rudder respectively) and recheck the lower spar cap and the rib attachment of the bellcrank. Anyone have any other ideas? From my experience though, check those cable tensions often because they seemingly loosen up without any reason! N601EL now has 25 hours of total time. Scott Thatcher, Palm Beach Gardens, FL 601XL with WW Corvair, Registered as E-LSA N601EL, http://placestofly.com, http://eaa203.com, http://mykitlog.com/sdthatcher Webmaster: http://zenvair.com ________________________________________________________________________________
Date: Nov 17, 2008
Subject: Re: 9 Hour X-Country, engine purred, cables loosened!
Scott, I'd have recommended you go for 20/30/20 tension as you reference, because the wing structure only has to give an extremely small amount to give up tension. 6061 is somewhat like bubble gum and a rib with channel reinforcement will deflect and with additional tightening repeated, you will see more loose cable. I don't think for a minute that lack of tension could cause problems, but certainly over tightening will eventually cause you grief. Look carefully at the skin where the bellcrank is located and see if you find any indication of reading the flange line. I've seen the rib pronounced at this location where cables have been over tightened and for that reason I maintain the lesser tensions without problems. Different wing on my HDS of course, but I have the same concerns. Larry McFarland 601HDS at www.macsmachine.com Scott Thatcher wrote: > So I plan to re-tighten to the new specs of 40/30/22 +/- 5 (Elevator, > Aileron, Rudder respectively) and recheck the lower spar cap and the > rib attachment of the bellcrank. Anyone have any other ideas? From > my experience though, check those cable tensions often because they > seemingly loosen up without any reason! N601EL now has 25 hours of > total time. > > Scott Thatcher, Palm Beach Gardens, FL > 601XL with WW Corvair, Registered as E-LSA > N601EL, http://placestofly.com, http://eaa203.com, > http://mykitlog.com/sdthatcher > Webmaster: http://zenvair.com > * > * ________________________________________________________________________________
Date: Nov 17, 2008
Scott, 1/8 cable will stretch. Also in the early flying time fittings, bellcranks?and bolts will seat themselves and all this will create slack in the system. Ask me how I know. Further, I can't tell the difference between a cable at 20 and 30 pounds tension. Maybe others can, but I can't. So the tension meter gage is the real answer. Since I found my slack cables my new maintenance is check the cables with the meter with every tire air pressure check. Chances are your cables were below standard margin when you got started.? Great story and best of luck, Bill of Georgia 601XL-3300 140 hrs -----Original Message----- From: Scott Thatcher <s_thatcher(at)bellsouth.net> Sent: Mon, 17 Nov 2008 11:59 am Subject: Zenith-List: 9 Hour X-Country, engine purred, cables loosened! Here is a rundown of my 9 hour x-country last month from Palm Beach Gardens, FL to Andrews, NC.? It's only a 700 mile (statute) flight but I had headwinds and I kept the speed below 100 mph the entire trip.? I put 40 pounds of baggage in the rear baggage area in order to help keep the nose up without using full trim during flight. And it worked beautifully.? To alleviate my heavy left wing, I kept 12 gallons in the right wing, 30 lbs baggage in the right locker, and 6 gallons in the left wing.? Now I could fly hands off most of the trip. ? When I left Palm Beach Gardens, the aileron cables were tight although I didn't use a tensionometer to measure the tautness of the cables.? My first stop was in Sebring for lunch.? On takeoff, the left canopy lock unlatched. After Jay's experience, I throttled back and made a 500' pattern and retuned to land.? Reseated the latch and again took off. Because of light turbulence (heavy in these LSA's), and strong headwinds with gusts, I decided to call it quits fairly early on Saturday afternoon and spend the night in Ocala, FL.? I asked the FBO to tie down the aircraft and I headed to the Motel. ? The next morning, I loaded the aircraft similar to above and noted that the tie downs were extremely tight. I would say at least 50-100 lbs of force were used to tie the wings down.? At the time, I thought that was a good idea because of the gusty conditions but later wondered what affect the negative load had on the lower spar cap.? A quick and dirty analysis indicated that the bending moments of 1100 ft-lbs (old school) would equate to a small 200 lb load at the center of the wing. That's about 0.25 g negative.? Nothing to worry about.? At least yet. ? The next 6 hours were spent cruising around 4500 feet and landing at several locations for fuel.? My first stop was at Tellfair-Wheeler in Georgia and to my surprise, they had no fuel and were completely unattended.? So I made a short hop to Dublin and re-fueled there.? Talked to a fellow who worked at the AMD factory and he mentioned I needed to look at? the bearing covers on the wheels when I get a chance. He also spoke very favorably about the quality of workmanship and he really enjoyed the sound of that Corvair engine. ? Next stop was to be Habersham at the foothills just south of Andrews, NC. But, while I was now at 6500 feet, it was very difficult to descend to land and make that long climb back up to altitude all over again so I decided to just continue over the mountains to Andrews. ? It was about now that I noticed a slight difference in the feel of the ailerons.? I could move the stick left and right about an inch without any movement of the ailerons themselves.? As anyone knows when you fly over open water, the engine will invariably make small noises that you have never heard before just about the time you reach a point of no-return.? And it is also true when flying over mountains, ailerons will start to buzz, cables feel like they are no longer attached and the engine starts making noises not heard before... you know the slight decrease in rpm that lasts about a thousandth of a second and causes your heart to momentarily stop. ? 30 minutes later I was pushing N601EL into my hangar in Andrews, NC.? Other than directly over the mountains, she flew well and the engine ran exceptionally.? My G-Meter showed that I had only experienced a 1.7 G positive and 0.4 G negative for the entire trip. But now I wanted to know what was going on with the cables. I pulled the seats out and ran my hand over the aileron cables and noticed they seemed much looser than when they were installed.? Then I found the balance cable and it was limp... no tension at all. ? I immediately ordered a Tensionometer from ACS and when I checked the cable tensions, here is what I discovered.? Rudder Cable: 12-15 lbs.? Aileron Cable: 10 lbs.? Balance Cable: 0 (not measurable).? Elevator cable: 10-12 lbs.? Now what worried me was, "How does an aileron and balance cable become so loose in so short a time?"? The only way I could think of was that the bellcrank moved or the wing geometry changed, both of which gave me a chill!? But neither of these things occurred.? I checked the fairleads and they were still in place.? And all nicopress fittings were still attached and turnbuckes still safetied. ? So I plan to re-tighten to the new specs of 40/30/22 +/- 5 (Elevator, Aileron, Rudder respectively) and recheck the lower spar cap and the rib attachment of the bellcrank.? Anyone have any other ideas?? From my experience though, check those cable tensions often because they seemingly loosen up without any reason!? N601EL now has 25 hours of total time. ? Scott Thatcher, Palm Beach Gardens, FL 601XL with WW Corvair, Registered as E-LSA N601EL, http://placestofly.com, http://eaa203.com, http://mykitlog.com/sdthatcher Webmaster: http://zenvair.com ________________________________________________________________________________
Subject: Fluctuating tachometer readings
Date: Nov 17, 2008
Scenerio: 3300 Jabiru; Dynon DK180; Pulse/Revolution values are set @ 6; tach wired to alternator with 1 amp fuse; Problem fluctuating tach readings on taxi testing. Readings: At idle 2000+/- RPM -- hand held tack shows 1050+/- 10; As I add throttle Dynon RPM drops to 1600; Slowly adding more power tach reading comes up then drops until it reaches full throttle and reads 2300 (static should be 2800). Has anyone had this problem? If so, how did you solve it? Any and all help will be greatly appreciated! Thanks, Mack Kreizenbeck 601XL N990MK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214749#214749 ________________________________________________________________________________
Date: Nov 17, 2008
Subject: Zenith : [ Curt Thompson ] : New Email List PhotoShare Available!
From: Email List PhotoShares <pictures(at)matronics.com>
A new Email List PhotoShare is available: Poster: Curt Thompson Lists: Zenith-List,Zenith801701-List Subject: TurboCAD drawings of CH701 form blocks and other parts. http://www.matronics.com/photoshare/Curt.Thompson@verizon.net.11.17.2008 ---------------------------------------------------------- o Main PhotoShare Index http://www.matronics.com/photoshare o Submitting a PhotoShare If you wish to submit a PhotoShare of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ---------------------------------------------------------- ________________________________________________________________________________
Date: Nov 17, 2008
Date: Nov 17, 2008
For those in the Los Angeles / North OC area, EAA Chapter 96- at Compton Woodley Airport (CPM) has similar facilities available. Contact Keith Spreu er at (310)-692-5648 www.eaa96.org Jim LoBue 601XL/Corvair --- On Fri, 11/14/08, Richard Vetterli wrote: From: Richard Vetterli <richvetterli(at)yahoo.com> Subject: Zenith-List: I've moved to FLAG (and you can too) Date: Friday, November 14, 2008, 10:46 PM Attention Northern California (SF Bay Area) builders. After building in my garage for the past four years, I've moved my project to "First Light Aviation Group" (FLAG) in Livermore, California, adjacent to the Livermore Airport (lvk). FLAG has individual building bays, each one complete with plenty of power, compressed air, large locking tool boxs, work tables, shelves and a pallet rack for large parts. FLAG also supplies large tools (drill press, shear, brake, etc) with convenient bathrooms, vending machines, fridge and microwave. And, it's available 24/7. In the lobby is a retail store with pilot supplies and building supplies. A large meeting room upstairs rounds out the facility. I found that when I moved my airplane to FLAG, I was able to work in the company of fellow builders/pilots and without the distractions of building at home. Now I'm confident that I'll get my plane flying in short order. No one asked me to post this and I'm not affiliated with FLAG, I'm just a happy customer. Check it out at www.flaglvk.com Rich Vetterli 601XL/Corvair 95% done, 95% to go Check out my progress at www.geocities.com/stixx5a ________________________________________________________________________________
Date: Nov 17, 2008
Your Dynon is picking up stray signals from other wiring. Typical sources are CHT or EGT wires. A fuel pressure sender is also a good source of stray signal if located too close to the distributor. Another possibility is a bad fuse with increased resistance. Try running without the fuse. Pete -----Original Message----- From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of aprazer Sent: Monday, November 17, 2008 3:06 PM Subject: Zenith-List: Fluctuating tachometer readings Scenerio: 3300 Jabiru; Dynon DK180; Pulse/Revolution values are set @ 6; tach wired to alternator with 1 amp fuse; Problem fluctuating tach readings on taxi testing. Readings: At idle 2000+/- RPM -- hand held tack shows 1050+/- 10; As I add throttle Dynon RPM drops to 1600; Slowly adding more power tach reading comes up then drops until it reaches full throttle and reads 2300 (static should be 2800). Has anyone had this problem? If so, how did you solve it? Any and all help will be greatly appreciated! Thanks, Mack Kreizenbeck 601XL N990MK Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214749#214749 ________________________________________________________________________________
Date: Nov 17, 2008
I think it was Larry McFarland that had plans to make a cable tension guage on his website. I took his lead and made my own, modifying his design somewhat. I made it smaller and amplified the motion. I put pictures on my website on the tools page. When I checked my cables, also done by feel I found the same thing that you did. I had around 18 lbs on the rudder and 15 pounds on the elevator (my ailerons are not cabled yet). The 40 pounds specified for the elevator seams like a lot of load to put on those flimsy horns. I haven't readjusted them yet, but I have some time (a lot) before first flight. Dan http://daniel.dempseyfamily.us [quote] ="japhillipsga(at)aol.com"]Dear 601XL Builders and Flyers, my eyes have been opened to an issue. All this talk about flutter and cables, etc., led me to buy a tensionmeter and check the cables in my XL. Wow was I surprised! The aileron cables were at 17 pounds and the elevator at below 10 pounds. By ZAC they should have been 30 & 40 pds. I reset them and flew. I was pleased at the difference in control and response. Now before you think "that just can't happen to me" I set my cables with my hands plucking them, seemed good and tight.I have tightened mine twice since I built her. No body has "calibrated" fingers. I alert you all and hope everybody will check their cables. I had flutter a couple years ago that scared the poop out of me. Don't want it again or that anybody should be lost because of it. The cable tester cost about $190. How much does having a wing come off cost? Best wishes, Bill of Georgia N505WP 601XL-3300 140 hours > [b] -------- Scratch building XL with Corvair Engine Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214777#214777 ________________________________________________________________________________
Date: Nov 17, 2008
Hey Billl Are you going to rent that test out to us? I would sure like to use it on my 601 HDS. Roger _____ From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of japhillipsga(at)aol.com Sent: Monday, November 17, 2008 9:08 AM Subject: Zenith-List: Re: Zenith- Alert To Aileron Cable Tension Dear 601XL Builders and Flyers, my eyes have been opened to an issue. All this talk about flutter and cables, etc., led me to buy a tensionmeter and check the cables in my XL. Wow was I surprised! The aileron cables were at 17 pounds and the elevator at below 10 pounds. By ZAC they should have been 30 & 40 pds. I reset them and flew. I was pleased at the difference in control and response. Now before you think "that just can't happen to me" I set my cables with my hands plucking them, seemed good and tight.I have tightened mine twice since I built her. No body has "calibrated" fingers. I alert you all and hope everybody will check their cables. I had flutter a couple years ago that scared the poop out of me. Don't want it again or that anybody should be lost because of it. The cable tester cost about $190. How much does having a wing come off cost? Best wishes, Bill of Georgia N505WP 601XL-3300 140 hours ________________________________________________________________________________
Subject: Great (U.S.) source for chocks
Date: Nov 17, 2008
Gang: Recently picked up a set of excellent wheel chocks for my 601 (with 5.00x5 tires), from www.chocks.com, which is Worden Safety Products. The set I chose was the A4R-R Small Extruded Wedge chock, made from EPDM rubber and sold in pairs, with a connecting rope, for $7.50/pair. With shipping, total was about $25. The specific link for this choice is http://www.chocks.com/chock.php?sn=2340402924 FWIW, Andy Elliott, Mesa, AZ N601GE (registered) 601XL/TD, Corvair, finishing... ________________________________________________________________________________
Date: Nov 17, 2008
Scott, Great report. The only experience I have with keeping cables under consistent tension is my guitar strings. I have been restringing guitars for many years and what I do is bring them all in to tune then stretch them slightly by pulling them away from the finger board. Then I re-tune and for the most part they stay in tune. Experience has taught me that without the stretching step I chase the tune of the guitar for about a week before it settles in. I would imagine this also applies to cables but haven't found the documentation that states so. YMMV -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214812#214812 ________________________________________________________________________________
Date: Nov 18, 2008
Subject: What Members Are Saying...
Dear Listers, November is the Annual Matronics List Fund Raiser. The Lists are supported solely through your generous Contributions during this time. Please make your Contribution today and pick up a really nice free gift at this same time: http://www.matronics.com/contribution Listers have been including some really nice comments regarding what the Lists mean to them along with their Contributions this year. I've included a few of them below. Please read them over and see if some perhaps echo your feelings as well. Thank you for your support this year! Matt Dralle Matronics Email List and Forum Administrator ------------------------------------------------------------------------------ Best bargain in the entire industry!! -Owen B Every year your lists are better, sure #1 in e-mail list in the world. -Gary G Thank you for an awesome site! -Ashley M Your lists are important to me and well worth paying for. -Calvin A Thank you for providing such and informative and ad free environment to learn by. -Myron H As always, a valuable and extremely useful resource. Stephen T As always, a great service. -Reade G Very much appreciate this site and the communications it has enabled between builders. -Larry M This service is worth every penny. -Robert S Great site! Thanks a ton for its functionality! -Peter B The RV-10 list feels like my community. -Dave S The lists are fantastic, a great source! -Jimmy Y I've learned a lot from the List. -Gabriel F A wonderful resource. -Gerald G Well done. -Richard N Years of good service. -William M Valuable service. -Keith H The site is quite helpful. -Jon M Very interesting List that I read form the beginning. -Alain L A well managed site. -Carl B Great service. -Svein Kare J Still the most useful program on the computer. -Fergus K Great contribution to my project! -Robert K Thanks for keeping a great list. -Dt G The List continues to provide excellent information. -Tony C This is a wonderful resource that has easily saved me a bunch on my build-time. -Ralph C Thank you for providing a great service. The Zenith builder's community would be in sad shape without the Zenith-List's. -Terrence P I really do get pleasure out of reading the List every day. -Bill V Great source of information. -Arthur V Thanks for a great service. Very enjoyable. -Louis B You know we all could not do without your support!! -James S Great resource! -Douglas D Thanks for the great service. -John B ________________________________________________________________________________
Subject: Help! Zenith Riveter
Date: Nov 18, 2008
Guys (and Gals), I have the standard issue Zenith pneumatic riveter. I've pulled about 5-6000 rivets with it and recently it started acting up. For some reason it takes two squeezes of the trigger to pull an A5 or even an A4. I've played with the pressure ranging from 60 - 90 PSI ( and even 100Psi to make sure it wasn't pressure related) There is no stem stuck in it like I thought there might be. Oh, one more interesting bit. The first squeeze domes the head and pulls it tight. Then the next squeeze, BANG! the rivet pulls and a few time it has dented my skins which is really aggravating. (Luckily I am not working in very visible places at the moment). I have dissembled, oiled etc and cant find anything wrong. Here is the kicker, sometimes when I vary the depth of the screw in heads (adjusting them in and out) everything works fine for a few rivets. HAS ANYONE ELSE EXPERIENCED THIS, AND IF SO HOW DO I MAKE IT STOP? Or do I just go to Harbor Freight and get a new riveter? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214947#214947 ________________________________________________________________________________
Subject: Re: Help! Zenith Riveter
Date: Nov 18, 2008
Is it possible that the parts that grip the stem have started to wear out? I have the Harborfreight style which is still going strong after two airplanes, and almost ten years of service. It occasionally does this, but when it does I just add oil to it and it works like new again. Regards, Jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214955#214955 ________________________________________________________________________________
Date: Nov 18, 2008
Rogar, I'll be happy to loan it to you, but if your going to do periodic checks as I am having one to own is a must, Bill **************Get the Moviefone Toolbar. Showtimes, theaters, movie news & p://toolbar.aol.com/moviefone/download.html?ncid=emlcntusdown00000001) ________________________________________________________________________________
Date: Nov 18, 2008
Why rent when you can buy one for under $200.00 at Aircraft Spruce or Ebay? Considering the importance of proper cable tension I would think you'd want a tensionometer of your own to check cable tension every 50 hours or at least every annual condition inspection. In the grand scheme of things, an investment of less than $200.00 for the sake of safety is a no-brainer. Ken Pavlou -------- 601 XL / Corvair Read this topic online here: http://forums.matronics.com/viewtopic.php?p=214965#214965 ________________________________________________________________________________
Date: Nov 18, 2008
Try unscrewing the nose piece a turn. This will change the location on the rivet stem that makes contact with the puller. I found immediately after pulling some of the stainless steel rivets to the brake peddles that my riveter developed a sensitive spot that did not grip as well. Gary Ray ----- Original Message ----- From: "MHerder" <michaelherder(at)beckgroup.com> Sent: Tuesday, November 18, 2008 9:28 AM Subject: Zenith-List: Help! Zenith Riveter > > Guys (and Gals), > > I have the standard issue Zenith pneumatic riveter. I've pulled about 5-6000 rivets with it and recently it started acting up. > > For some reason it takes two squeezes of the trigger to pull an A5 or even an A4. > > I've played with the pressure ranging from 60 - 90 PSI ( and even 100Psi to make sure it wasn't pressure related) > > There is no stem stuck in it like I thought there might be. > > Oh, one more interesting bit. The first squeeze domes the head and pulls it tight. Then the next squeeze, BANG! the rivet pulls and a few time it has dented my skins which is really aggravating. (Luckily I am not working in very visible places at the moment). > > I have dissembled, oiled etc and cant find anything wrong. > > Here is the kicker, sometimes when I vary the depth of the screw in heads (adjusting them in and out) everything works fine for a few rivets. > > HAS ANYONE ELSE EXPERIENCED THIS, AND IF SO HOW DO I MAKE IT STOP? Or do I just go to Harbor Freight and get a new riveter? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=214947#214947 > > ________________________________________________________________________________
Date: Nov 18, 2008
If checking the tension is not very time consuming I would check it very often, just to be safe. Considering the importance of the tension, the instrument should be included in the on board set of tools, I think. Pramod --- On Tue, 11/18/08, annken100 wrote: > From: annken100 <annken100(at)aol.com> > Subject: Zenith-List: Re: Zenith- Alert To Aileron Cable Tension > To: zenith-list(at)matronics.com > Date: Tuesday, November 18, 2008, 10:43 AM > > > Why rent when you can buy one for under $200.00 at Aircraft > Spruce or Ebay? Considering the importance of proper cable > tension I would think you'd want a tensionometer of your > own to check cable tension every 50 hours or at least every > annual condition inspection. In the grand scheme of things, > an investment of less than $200.00 for the sake of safety is > a no-brainer. > > Ken Pavlou > > -------- > 601 XL / Corvair > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=214965#214965 > > > > > > > ________________________________________________________________________________
Date: Nov 18, 2008
annken100 wrote: > In the grand scheme of things, an investment of less than $200.00 for the sake of safety is a no-brainer. I didn't give it a second though when I spent 25 times that amount on my BRS. I started building my XL before all this stuff started happening, so it was a bit of an expense that I hadn't planned for. But it'll be worth it if I ever need it... For what it's worth, I'm also going to make "Check Cable Tension" part of my pre-flight and I'm going to track it, keeping an eye out for a trend over the passage of time. - Pat -------- Patrick 601XL/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=215031#215031 ________________________________________________________________________________
Date: Nov 18, 2008
My green zenith riveter did the same thing. I can live with the 2 trigger pulls, but the BANG! and resulting dents I can live without. I bought a HF riveter and never looked back. Also have a few hand riveters that come in handy for AS5's. - Pat -------- Patrick 601XL/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=215032#215032 ________________________________________________________________________________
From: "Southern Reflections" <purplemoon99(at)bellsouth.net>
Date: Nov 18, 2008
I RETURNED THE NEW ONE THEY SENT ME, IT BLEW THE END OFF JUST MISSING MY HEAD AND DENTING THE HANGER DOOR. TOO BAD THEY STOP SELLING THE OLD TYPE (THE YELLOW ONE WITH THE PLASTIC CUPON THE END) THEY ARE GREAT,TRYED TO GET THEM TO GET ME ONE OF THE OLD ONES ,BUT THEY SAID NO...... JOE N101HD ----- Original Message ----- From: "Gary Ray" <davgray(at)sbcglobal.net> Sent: Tuesday, November 18, 2008 12:40 PM Subject: Re: Zenith-List: Help! Zenith Riveter > > Try unscrewing the nose piece a turn. This will change the location on > the > rivet stem that makes contact with the puller. I found immediately after > pulling some of the stainless steel rivets to the brake peddles that my > riveter developed a sensitive spot that did not grip as well. > > Gary Ray > > > ----- Original Message ----- > From: "MHerder" <michaelherder(at)beckgroup.com> > To: > Sent: Tuesday, November 18, 2008 9:28 AM > Subject: Zenith-List: Help! Zenith Riveter > > >> >> >> Guys (and Gals), >> >> I have the standard issue Zenith pneumatic riveter. I've pulled about > 5-6000 rivets with it and recently it started acting up. >> >> For some reason it takes two squeezes of the trigger to pull an A5 or >> even > an A4. >> >> I've played with the pressure ranging from 60 - 90 PSI ( and even 100Psi > to make sure it wasn't pressure related) >> >> There is no stem stuck in it like I thought there might be. >> >> Oh, one more interesting bit. The first squeeze domes the head and pulls > it tight. Then the next squeeze, BANG! the rivet pulls and a few time it > has dented my skins which is really aggravating. (Luckily I am not working > in very visible places at the moment). >> >> I have dissembled, oiled etc and cant find anything wrong. >> >> Here is the kicker, sometimes when I vary the depth of the screw in heads > (adjusting them in and out) everything works fine for a few rivets. >> >> HAS ANYONE ELSE EXPERIENCED THIS, AND IF SO HOW DO I MAKE IT STOP? Or do >> I > just go to Harbor Freight and get a new riveter? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=214947#214947 >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Nov 18, 2008
I appreciate everyones input. Sounds like I'm not the only one as I suspected. I'm going to buy the HF gun but at this point it is a matter of curiosity... What would make it do such a thing. I HATE NOT BEING ABLE TO FIX SOMETHING! This should also serve the newcomers, save your money and just go with the HF gun, I don't like to buy cheap tools so I splurged and bought the hundred dollar Zenith gun rather than the 30 dollar HF gun. To me it seems that the 30 dollar HF gun would be able to better reach some areas and many seem to even like the quality better. Thanks again to everyone! PatrickW wrote: > My green zenith riveter did the same thing. I can live with the 2 trigger pulls, but the BANG! and resulting dents I can live without. > > I bought a HF riveter and never looked back. > > Also have a few hand riveters that come in handy for AS5's. > > - Pat -------- One Rivet at a Time! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=215046#215046 ________________________________________________________________________________
Date: Nov 18, 2008
IF YOU WANT THE BEST GO TO WWW.FSIRIVET.COM CLICK ON AUTO THEN PT100-C THIS THING DEVELOPES 4000 LB.@90-120PSI THEY ALSO HAVE A HAND PULL THAT IS HOT... JOE N101HD ----- Original Message ----- From: "MHerder" <michaelherder(at)beckgroup.com> Sent: Tuesday, November 18, 2008 5:07 PM Subject: Zenith-List: Re: Help! Zenith Riveter > > I appreciate everyones input. Sounds like I'm not the only one as I > suspected. > > I'm going to buy the HF gun but at this point it is a matter of > curiosity... What would make it do such a thing. I HATE NOT BEING ABLE TO > FIX SOMETHING! > > This should also serve the newcomers, save your money and just go with the > HF gun, I don't like to buy cheap tools so I splurged and bought the > hundred dollar Zenith gun rather than the 30 dollar HF gun. To me it > seems that the 30 dollar HF gun would be able to better reach some areas > and many seem to even like the quality better. > > Thanks again to everyone! > > > PatrickW wrote: >> My green zenith riveter did the same thing. I can live with the 2 >> trigger pulls, but the BANG! and resulting dents I can live without. >> >> I bought a HF riveter and never looked back. >> >> Also have a few hand riveters that come in handy for AS5's. >> >> - Pat > > > -------- > One Rivet at a Time! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=215046#215046 > > > ________________________________________________________________________________
Subject: Fairleads
Date: Nov 18, 2008
Just had another thought as I am studying my plans and the aileron and rudder cables are shown going through fairleads and changing directions. I was under the impression that you should always use a pulley to change the direction of a cable, and that a fairlead was just to stop vibration or the cable striking parts it shouldn't. Even just a minor direction change in a cable under tension running through a 1/8" thick piece of nylon is going to cut into it and release the tension as it does, and may be contributing to the tensioning issues being discussed. ________________________________________________________________________________
Date: Nov 18, 2008
Subject: Re: Fairleads
On Tue, Nov 18, 2008 at 4:44 PM, Dirk Zahtilla wrote: > Even just a minor direction change in a cable under tension running through a > 1/8" thick piece of nylon is going to cut into it and release the tension as it > does, and may be contributing to the tensioning issues being discussed. This one is relatively easy to test given the right materials. It should be easy to construct a geometrically correct model of one of the setups by screwing some stuff to some 2x4s or whatever, tension it to 30 pounds, move the cable back and forth a few times, and then recheck the tension and examine the fairlead. Any Zenith builder might already have (or have access to) excess cable and maybe even pulleys, and fairlead material. Ihab -- Ihab A.B. Awad, Palo Alto, CA ________________________________________________________________________________
Date: Nov 18, 2008
"I was under the impression that you should always use a pulley to change the direction of a cable..." AC 43.13 allows a 3 degree change of direction using a fair-lead (7-149n) Although the plans exceed this in some instances, adding additional fair-leads is easy to do to remain under 3 degrees although a pulley would be best for tension issues. (Ihab, the 3D printer idea was very useful--I may have my first prototype part by 12/4! Thanks!) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=215084#215084 ________________________________________________________________________________
Date: Nov 18, 2008
Bill It turns out a mechanic buddy of mine has one, but thanks for the offer !!!! Roger _____ From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of JAPhillipsGA(at)aol.com Sent: Tuesday, November 18, 2008 9:27 AM Subject: Re: Zenith-List: Re: Zenith- Alert To Aileron Cable Tension Rogar, I'll be happy to loan it to you, but if your going to do periodic checks as I am having one to own is a must, Bill _____ Get p://toolbar.aol.com/moviefone/download.html?ncid=emlcntusdown00000001> the Moviefone Toolbar. Showtimes, theaters, movie news & more! ________________________________________________________________________________
Date: Nov 18, 2008
The site, FSIRIVET.COM is down or the URL is bad. Leo Gates N601Z Southern Reflections wrote: > > > IF YOU WANT THE BEST GO TO WWW.FSIRIVET.COM CLICK ON AUTO THEN > PT100-C THIS THING DEVELOPES 4000 LB.@90-120PSI THEY ALSO HAVE A HAND > PULL THAT IS HOT... JOE N101HD > ----- Original Message ----- From: "MHerder" > > To: > Sent: Tuesday, November 18, 2008 5:07 PM > Subject: Zenith-List: Re: Help! Zenith Riveter > > >> >> >> I appreciate everyones input. Sounds like I'm not the only one as I >> suspected. >> >> I'm going to buy the HF gun but at this point it is a matter of >> curiosity... What would make it do such a thing. I HATE NOT BEING >> ABLE TO FIX SOMETHING! >> >> This should also serve the newcomers, save your money and just go >> with the HF gun, I don't like to buy cheap tools so I splurged and >> bought the hundred dollar Zenith gun rather than the 30 dollar HF >> gun. To me it seems that the 30 dollar HF gun would be able to >> better reach some areas and many seem to even like the quality better. >> >> Thanks again to everyone! >> >> >> PatrickW wrote: >>> My green zenith riveter did the same thing. I can live with the 2 >>> trigger pulls, but the BANG! and resulting dents I can live without. >>> >>> I bought a HF riveter and never looked back. >>> >>> Also have a few hand riveters that come in handy for AS5's. >>> >>> - Pat >> >> >> -------- >> One Rivet at a Time! >> ________________________________________________________________________________
Date: Nov 18, 2008
SORRY LEO THERE IS A / AFTER COM ----- Original Message ----- From: "Leo Gates" <leo(at)zuehlfield.com> Sent: Tuesday, November 18, 2008 9:35 PM Subject: Re: Zenith-List: Re: Help! Zenith Riveter > > The site, FSIRIVET.COM is down or the URL is bad. > > Leo Gates > N601Z > > Southern Reflections wrote: >> >> >> IF YOU WANT THE BEST GO TO WWW.FSIRIVET.COM CLICK ON AUTO THEN >> PT100-C THIS THING DEVELOPES 4000 LB.@90-120PSI THEY ALSO HAVE A HAND >> PULL THAT IS HOT... JOE N101HD >> ----- Original Message ----- From: "MHerder" >> >> To: >> Sent: Tuesday, November 18, 2008 5:07 PM >> Subject: Zenith-List: Re: Help! Zenith Riveter >> >> >>> >>> >>> I appreciate everyones input. Sounds like I'm not the only one as I >>> suspected. >>> >>> I'm going to buy the HF gun but at this point it is a matter of >>> curiosity... What would make it do such a thing. I HATE NOT BEING >>> ABLE TO FIX SOMETHING! >>> >>> This should also serve the newcomers, save your money and just go >>> with the HF gun, I don't like to buy cheap tools so I splurged and >>> bought the hundred dollar Zenith gun rather than the 30 dollar HF >>> gun. To me it seems that the 30 dollar HF gun would be able to >>> better reach some areas and many seem to even like the quality better. >>> >>> Thanks again to everyone! >>> >>> >>> PatrickW wrote: >>>> My green zenith riveter did the same thing. I can live with the 2 >>>> trigger pulls, but the BANG! and resulting dents I can live without. >>>> >>>> I bought a HF riveter and never looked back. >>>> >>>> Also have a few hand riveters that come in handy for AS5's. >>>> >>>> - Pat >>> >>> >>> -------- >>> One Rivet at a Time! >>> > > > > > ________________________________________________________________________________
Date: Nov 19, 2008
Greetings, My experience with manual blind rivet pullers is that when they give the problems you describe it is caused by the teeth on the jaws getting "dull". If you look at the pulled stems they may show that the jaws slipped some distance on the stem before they got a grip and started to pull. Sometimes when this happens you will see a buildup of aluminum in the jaws when you disassemble the puller. I have never had much luck reconditioning the parts. Raymond Julian Kettle River, MN "Hope for the best, but prepare for the worst." ----- Original Message ----- From: "MHerder" <michaelherder(at)beckgroup.com> Sent: Tuesday, November 18, 2008 4:07 PM Subject: Zenith-List: Re: Help! Zenith Riveter > > I appreciate everyones input. Sounds like I'm not the only one as I > suspected. > > I'm going to buy the HF gun but at this point it is a matter of > curiosity... What would make it do such a thing. I HATE NOT BEING ABLE TO > FIX SOMETHING! > > This should also serve the newcomers, save your money and just go with the > HF gun, I don't like to buy cheap tools so I splurged and bought the > hundred dollar Zenith gun rather than the 30 dollar HF gun. To me it > seems that the 30 dollar HF gun would be able to better reach some areas > and many seem to even like the quality better. > > Thanks again to everyone! > > > PatrickW wrote: >> My green zenith riveter did the same thing. I can live with the 2 >> trigger pulls, but the BANG! and resulting dents I can live without. >> >> I bought a HF riveter and never looked back. >> >> Also have a few hand riveters that come in handy for AS5's. >> >> - Pat > > > -------- > One Rivet at a Time! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=215046#215046 > > -------------------------------------------------------------------------------- Checked by AVG - http://www.avg.com 5:24 PM ________________________________________________________________________________
From: "Dave VanLanen" <davevanlanen(at)sbcglobal.net>
Date: Nov 19, 2008
Although I have not pulled that many rivets with my Zenith riveter yet, I have had issues with it seeming to be overly-sensitive. Granted I am not using an expensive regulator, but it seems to require very minute adjustments to go from not pulling at all to pulling / jumping and denting the skin. I also have trouble with an occasional A4 rivet head not doming down tightly against the skin all the way around. It will be slightly raised for about 25% to 35% of the circumference, in spite of the fact that I am very careful to square the riveter to the surface before pulling. What is the specific make and model of the HF rivet gun referred to below that builders are having success with? Thanks, Dave Van Lanen 601XL - tail done, flaps done, ailerons 75% done Subject: Re: Help! Zenith Riveter <http://www.matronics.com/searching/getmsg_script.cgi?INDEX=75182960?KEYS=hf ?LISTNAME=Zenith?HITNUMBER=5?SERIAL281432186?SHOWBUTTONS=NO> From: "MHerder" <michaelherder(at)beckgroup.com> Date: Nov 18, 2008 I appreciate everyones input. Sounds like I'm not the only one as I suspected. I'm going to buy the HF gun but at this point it is a matter of curiosity... What would make it do such a thing. I HATE NOT BEING ABLE TO FIX SOMETHING! This should also serve the newcomers, save your money and just go with the HF gun, I don't like to buy cheap tools so I splurged and bought the hundred dollar Zenith gun rather than the 30 dollar HF gun. To me it seems that the 30 dollar HF gun would be able to better reach some areas and many seem to even like the quality better. ________________________________________________________________________________
Date: Nov 19, 2008
>From my FWIW. I bought the ZAC puller and the HF Special. Have used both over 2 years with little problem. Turns out the HF is sometimes easier to get into some places... but the ZAC model works better in others. Just experienced trouble (for the first time) with the HF. They had included spare parts and directions to tune up the old bus so.... I rebuilt it with new parts and it works like new. Biggest problem was "hydraulic fuild" was way low. That fix was probably all it needed, but since I had it apart seemed silly not to put in new springs, etc. Also have ACE hand puller that swivels... need that once in awhile. Only problem (if you call it that) with ZAC model was couple of the bolts loosened and it wouldn't work until they were tightened. Mike -------- Mike Miller @ millrml(at)aol.com 601 XL, 3300, Dynon Remember, "the second mouse gets the cheese"! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=215151#215151 ________________________________________________________________________________
Subject: Riveter Problems? RED ATD Version
Date: Nov 19, 2008
HI Folks, a few have expressed a problem with their riveter, if this is the new Riveter from Zenith the "Red ATD one" then please call Zenith directly for help in getting this resolved. The new riveter does require setup, not all, but a few are needed to be adjusted. I have been using these types of riveters for years and prefer them over the old diaphragm style. However, sometimes they come out of the box ready to go and other times it takes a few kicks at the cat to get it operating the way I want it to. SO if you have the new RED ATD and it is not working properly call Zenith at 573-581-9000 and ask for Travis, I talked to him concerning this issue and he will be more then happy to help you out. Mark Townsend Can-Zac Aviation Ltd. 519-590-7601 www.canzac.ca Canadian Dealer for Zenith Aircraft Kits, Zenair Designs. ________________________________________________________________________________
Date: Nov 19, 2008
93458-1VGA is the el-cheapo one at $29.99 - 98898-0VGA-is the better one at $79.99 - Both are Cetral Pneumatic models - I have the Zac riveter-and pricier one from Harbour Freight-and it is w ay better than the one I have from Zac Bill Pagan EAA Tech Counselor #4395 --- On Wed, 11/19/08, Dave VanLanen wrote: From: Dave VanLanen <davevanlanen(at)sbcglobal.net> Subject: Zenith-List: Re: Help! Zenith Riveter Date: Wednesday, November 19, 2008, 12:41 PM Although I have not pulled that many rivets with my Zenith riveter yet, I h ave had issues with it seeming to be overly-sensitive.- Granted I am not using an expensive regulator, but it seems to require very minute adjustmen ts to go from not pulling at all to pulling / jumping and denting the skin. - I also have trouble with an occasional A4 rivet head not doming down ti ghtly against the skin all the way around.- It will be slightly raised fo r about 25% to 35% of the circumference, in spite of the fact that I am ver y careful to square the riveter to the surface before pulling. What is the specific make and model of the HF rivet gun referred to below t hat builders are having success with? Thanks, Dave Van Lanen 601XL ' tail done, flaps done, ailerons 75% done Subject: ------ Re: Help! Zenith Riveter------- From: - "MHerder" <michaelherder(at)beckgroup.com> Date: - Nov 18, 2008--- I appreciate everyones input.- Sounds like I'm not the only one as I susp ected. I'm going to buy the HF gun but at this point it is a matter of curiosity.. .- What would make it do such a thing. I HATE NOT BEING ABLE TO FIX SOMETHING! This should also serve the newcomers, save your money and just go with the HF gun, I don't like to buy cheap tools so I splurged and bought the hundred dollar Zenith gun rather than the 30 dollar HF gun.- To me it seems that the 30 dollar HF gun would be able to better reach some areas and many seem to even like the quality better. =0A=0A=0A ________________________________________________________________________________
Date: Nov 20, 2008
Subject: Behind By 21% - Advertising May Be Needed...?
Dear Listers, The percentage of people making a Contribution to support the Lists this year is currently lagging behind last year by approximately 21%! I'm hoping that everyone is just waiting until the last minute to show their support... ;-) Please remember that it is solely your direct Contributions that keep these Lists up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I will likely have to start adding advertisements to offset the costs of running the Lists. But I *really* don't want to have to start doing that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List Administrator ________________________________________________________________________________
Subject: Forms
Date: Nov 20, 2008
Hello group ,I am getting ready for a hanger clean-up .If someone on the list is considering scratch building a 601XL they are welcome to my forms used in building my plane .If they are not wanted they are on their way to the burn pile .It would cost too much to ship them ,I live 50 miles South of Houston Texas in Brazoria . Phone :979-798-5917 Wade Jones South Texas 601XL Franklin 0-235 ________________________________________________________________________________
Subject: Left-over parts
Date: Nov 20, 2008
Gang: I have a few left-over (unused) parts from my build that I would like to sell. All are offered at *1/2* the price from the Zenith catalog, plus actual shipping. Please contact me off-list if you are interested. Andy Elliott, Mesa, AZ N601GE (registered) 601XL/TD, inspection this Saturday! a.s.elliott(at)cox.net Part No. Description ZAC $$ My $$ -------- ------------ ------- ------- 6W9-2 Pitot-Static Tube Assembly 61.00 30.50 6W10-1 Ail. Bellcrank w/spacers 38.10 19.00 (each, have 2) 6F4-1 Cable Outlet Fairing ??? 2.00 (each, have 2) All of it, even cheaper! $70.00 ________________________________________________________________________________
Subject: Correction - Left-over parts
Date: Nov 20, 2008
Gang: (found more!) I have a few left-over (unused) parts from my build that I would like to sell. All are offered at *1/2* the price from the Zenith catalog, plus actual shipping. Please contact me off-list if you are interested. Andy Elliott, Mesa, AZ N601GE (registered) 601XL/TD, inspection this Saturday! a.s.elliott(at)cox.net Part No. Description ZAC $$ My $$ -------- ------------ ------- ------- 6W9-2 Pitot-Static Tube Assembly 61.00 30.50 6W10-1 Ail. Bellcrank w/spacers,2 38.10 38.00 (each) (for 2) 6F4-1 Cable Outlet Fairing,2 ??? 4.00 (for 2) 9416K12 40# Gas Spring,2 10.50 10.50 (each) (for 2) All of it, even cheaper! $80.00 ________________________________________________________________________________
Subject: Re: Aileron Push Rods, 601XL
Date: Nov 20, 2008
Dear Builders, somewhere out there in Zenithland there is at least one builder that substituted push/pull rods for the cables on their ailerons. I remember somebody in the past saying on this thread that they were going to or had already made the stwitch. Please contact me if that certain someone is reading. Also, if any of you other folks remember who he is please let me know. Thanks for your time, Bill of Georgia N505WP 601XL-3300 140 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=215321#215321 ________________________________________________________________________________
Date: Nov 20, 2008
That was me, There's one recently completed XL (in our EAA chapter) with pushrods, and myself and one other just started propjects who are doing this also. Feel free to call me at 775-671-0852 or email me direct ideaz1(at)sbcglobal.net Dirk Z Carson City, Nv. ----- Original Message ----- From: japhillipsga(at)aol.com To: zenith-list(at)matronics.com Sent: Thursday, November 20, 2008 7:14 AM Subject: Re: Zenith-List: Aileron Push Rods, 601XL Dear Builders, somewhere out there in Zenithland there is at least one builder that substituted push/pull rods for the cables on their ailerons. I remember somebody in the past saying on this thread that they were going to or had already made the stwitch. Please contact me if that certain someone is reading. Also, if any of you other folks remember who he is please let me know. Thanks for your time, Bill of Georgia N505WP 601XL-3300 140 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=215321#215321 ________________________________________________________________________________
Subject: Re: Correction - Left-over parts
Date: Nov 20, 2008
Just curious - did you go with something different for your aileron belcrank...? - Pat -------- Patrick 601XL/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=215375#215375 ________________________________________________________________________________
Subject: 80 hp. jab
Date: Nov 20, 2008
Does any out there have a 80 hp. jab in a701? Joe N101 HD ________________________________________________________________________________
Subject: 80 hp. jab
Date: Nov 20, 2008
Jabiru USA is flying a 85hp Jabiru 2200 in our 701. See http://www.usjabiru.com/zenithch701.html for details Pete From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Southern Reflections Sent: Thursday, November 20, 2008 12:45 PM Subject: Zenith-List: 80 hp. jab Does any out there have a 80 hp. jab in a701? Joe N101 HD ________________________________________________________________________________
Date: Nov 20, 2008
Subject: Re: 80 hp. jab
Hello Pete, Would a 3300 also fit? Thanks,. 2008/11/20 Pete Krotje > Jabiru USA is flying a 85hp Jabiru 2200 in our 701. See > http://www.usjabiru.com/zenithch701.html for details > > > Pete > > > *From:* owner-zenith-list-server(at)matronics.com [mailto: > owner-zenith-list-server(at)matronics.com] *On Behalf Of *Southern > Reflections > *Sent:* Thursday, November 20, 2008 12:45 PM > *To:* zenith-list(at)matronics.com > *Subject:* Zenith-List: 80 hp. jab > > > Does any out there have a 80 hp. jab in a701? Joe N101 HD > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > ** > > ** > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?Zenith-List* > > ** > > ** > > ** > > *http://forums.matronics.com* > > ** > > * > > -- Alberto Martin www.iberplanes.es Igualada - Barcelona - Spain ---------------------------------------------- Zodiac 601 XL Builder Serial: 6-7011 Tail Kit: Finished Wings: Not Started Fuselage: Ordered Engine: Jabiru 3300 ________________________________________________________________________________
Subject: 80 hp. jab
Date: Nov 20, 2008
There are a few builders who have installed the 3300 but there are more cooling issues to solve. Pete From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Iberplanes IGL Sent: Thursday, November 20, 2008 2:08 PM Subject: Re: Zenith-List: 80 hp. jab Hello Pete, Would a 3300 also fit? Thanks,. 2008/11/20 Pete Krotje Jabiru USA is flying a 85hp Jabiru 2200 in our 701. See http://www.usjabiru.com/zenithch701.html for details Pete From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Southern Reflections Sent: Thursday, November 20, 2008 12:45 PM Subject: Zenith-List: 80 hp. jab Does any out there have a 80 hp. jab in a701? Joe N101 HD http://www.matronics.com/contribution http://www.matronics.com/Navigator?Zenith-List http://forums.matronics.com -- Alberto Martin www.iberplanes.es Igualada - Barcelona - Spain ---------------------------------------------- Zodiac 601 XL Builder Serial: 6-7011 Tail Kit: Finished Wings: Not Started Fuselage: Ordered Engine: Jabiru 3300 ________________________________________________________________________________
Date: Nov 20, 2008
What typt prop are you using and what size and pitch? Thanks Joe N101HD ----- Original Message ----- From: Pete Krotje To: zenith-list(at)matronics.com Sent: Thursday, November 20, 2008 2:56 PM Subject: RE: Zenith-List: 80 hp. jab Jabiru USA is flying a 85hp Jabiru 2200 in our 701. See http://www.usjabiru.com/zenithch701.html for details Pete From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Southern Reflections Sent: Thursday, November 20, 2008 12:45 PM To: zenith-list(at)matronics.com Subject: Zenith-List: 80 hp. jab Does any out there have a 80 hp. jab in a701? Joe N101 HD http://www.matronics.com/contributionhttp://www.matronics.com/Navigator?Z enith-Listhttp://forums.matronics.com ________________________________________________________________________________
Date: Nov 20, 2008
Joe, there is probably a dozen or more out there now, we have 2 in NZ with the 2200a and they do fine. A third is fitting a 3300 but not flown yet, I expect the trouble will be in the cooling as Pete says, and fuel burn/ weight will be compromised. Probably find more info on the 701801 list.... Ralph -------- Ralph - CH701 / 2200a Read this topic online here: http://forums.matronics.com/viewtopic.php?p=215419#215419 ________________________________________________________________________________
Date: Nov 20, 2008
thank's mate, what type prop are you using,size and pitch? Joe N101HD ----- Original Message ----- From: "jetboy" <sanson.r(at)xtra.co.nz> Sent: Thursday, November 20, 2008 4:38 PM Subject: Zenith-List: Re: 80 hp. jab > > Joe, there is probably a dozen or more out there now, we have 2 in NZ with > the 2200a and they do fine. A third is fitting a 3300 but not flown yet, I > expect the trouble will be in the cooling as Pete says, and fuel burn/ > weight will be compromised. > > Probably find more info on the 701801 list.... > > Ralph > > -------- > Ralph - CH701 / 2200a > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=215419#215419 > > > ________________________________________________________________________________
Date: Nov 20, 2008
I went to a thompsonaeronatical.com 64x30". The Jabiru 60x38" was unsatisfactory. There is a Yahoo thread on this and the Sensenich and the Tenessee props seem to be equivalent Ralph -------- Ralph - CH701 / 2200a Read this topic online here: http://forums.matronics.com/viewtopic.php?p=215470#215470 ________________________________________________________________________________
Date: Nov 20, 2008
Thank's Ralph, I've got a friend that has a701 with a jab 80 hp.eng he has 2 prop from jab and both don't work one over revs and other won't develope enouth power to get off the ground.. one of those prop,s is a tenn. I'll pass your e mail to him Joe N101HD ----- Original Message ----- From: "jetboy" <sanson.r(at)xtra.co.nz> Sent: Thursday, November 20, 2008 10:54 PM Subject: Zenith-List: Re: 80 hp. jab > > I went to a thompsonaeronatical.com 64x30". The Jabiru 60x38" was > unsatisfactory. There is a Yahoo thread on this and the Sensenich and the > Tenessee props seem to be equivalent > > Ralph > > -------- > Ralph - CH701 / 2200a > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=215470#215470 > > > ________________________________________________________________________________
Date: Nov 20, 2008
Subject: Plexiglass Scratch Repair...
Dear Listers, During the fitting of the Plexiglass canopy on my RV-8, I managed to put some pretty disheartening scratches in the windscreen section. You can see from the pictures that they looked pretty bad. A call to Van's revealed that a replacement canopy would be $640 + $250 shipping to California! Ack. So what to do... A bit of surfing and I found this "Scratch Off" windshield repair kit for $35 on the Aircraft Spruce web site: http://www.aircraftspruce.com/catalog/cspages/scratchoff.php Frankly, it just seemed too good to be true. Nothing for $35 could be that "magic" I thought, but what did I have to lose at this point.... Well, the kit arrived yesterday and I decided to give it a try tonight. In a word: WOW! In about 2 hours the windscreen looked as good as new - no kidding - AS GOOD AS NEW! The pictures really don't do the repair justice. It looks better in person. There are basically two sponges in the kit with four decreasingly porous pastes. You just put some of the first paste on the sponge and buff it in with a drill at 1200 RPM or less. Then you wash everything down good including the sponge and windshield with warm water. Then you use the next finer paste and repeat the process. Etc, etc, until you've used the 4th paste that is kind of like car wax. Frankly, the scratches were gone after the first application of paste - I started at #2 based on the instructions and the "observed severity" of the scratch depth. So, the bottom line is, if you've got scuffs or mild scratches in your Plexiglass buy this repair kit. It works! Matt Dralle RV-8 #82880 ________________________________________________________________________________
Date: Nov 20, 2008
Subject: YOU MIGHT BE IN THE AVIATION/AEROSPACE INDUSTRY IF ...
This bit of humor may be a little OT, but helps to explain why some of my posts seem incomprehensible. YOU MIGHT BE IN THE AVIATION/AEROSPACE INDUSTRY IF ... 1. You sat at the same desk for 4 years and worked for 8 different managers. Or have moved 10 times in two years and have never known who your boss was. 2. Your resume is on a jumpdrive in your pocket. 3. Someone asks you what you do for a living and you lie. 4. You get really excited about a 2% pay increase. 5. Your biggest loss from a system crash, is that you lose your best jokes. 6. You sit in a cubicle smaller than your bedroom closet. 7. Its dark on your drive to and from work. 8. Fun is when "projects" are assigned to someone else. 9. Communication is something your "group" is having problems with. 10. You see a good-looking person and know it's a visitor. 11. Free food left over from a meeting is your main staple. 12. All art involves a white board. 13. All real work is done prior to 8:00am and after 4:30pm. 14. You're already late on the assignment you just received. 15. Dilbert is your favorite cartoon. 16. Your boss's favorite lines are ... "When you get a few minutes ..." "I have an opportunity for you ..." "Cross-charging is forbidden." "the directional truth in a white water world ..." "We have a new culture that will enable us to ..." "We have a new engineering vice-president." "This reorganization will allow us to streamline our way of doing business, becoming more competitive." 17. 99% of the people in your company do not know what you do. 18. 99% of the people in your company do not care what you do. 19. Vacation is something you rollover to next year or a check you get every January. 20. Change is the norm. 21. Nepotism is strongly encouraged. 22. Your company announces no pay increase because it is investing money in a new aircraft development. 23. Your company announces no pay increase because the airline industry is in a downturn. And your boss gets voted "man of the year in aerospace" 24. Your fear to fly is becoming even worse. 25. Everyone at the company says that without his work there would be no aircraft. 26. An ordinary secretary has more power than an old engineer. 27. You read this entire list and understand it. 28. Not allowing firearms on company property is seen strictly as a suicide prevention measure. 29. The only people you forward this to are in aerospace too because no one else would understand! ________________________________________________________________________________
Date: Nov 21, 2008
Here's a 701 w/3300: http://www.barnstormers.com Search for : Zenith 701 w/Jabiru 3300 \ ________________________________________________________________________________
Subject: Re: Plexiglass Scratch Repair...
Date: Nov 21, 2008
Matt, thanks for the info, I ordered one today. I see from your photos you have not attached the skirts yet. I just finished mine on my 8a. I made the mistake of starting from the front and working to the rear. My advise is start fitting the skirts from the rear and work forward. Has to be much easier and a better fit. Best regards, Bill of Georgia? -----Original Message----- From: Matt Dralle <dralle(at)matronics.com> Sent: Fri, 21 Nov 2008 12:22 am Subject: Zenith-List: Plexiglass Scratch Repair... Dear Listers, During the fitting of the Plexiglass canopy on my RV-8, I managed to put some pretty disheartening scratches in the windscreen section. You can see from the pictures that they looked pretty bad. A call to Van's revealed that a replacement canopy would be $640 + $250 shipping to California! Ack. So what to do... A bit of surfing and I found this "Scratch Off" windshield repair kit for $35 on the Aircraft Spruce web site: http://www.aircraftspruce.com/catalog/cspages/scratchoff.php Frankly, it just seemed too good to be true. Nothing for $35 could be that "magic" I thought, but what did I have to lose at this point.... Well, the kit arrived yesterday and I decided to give it a try tonight. In a word: WOW! In about 2 hours the windscreen looked as good as new - no kidding - AS GOOD AS NEW! The pictures really don't do the repair justice. It looks better in person. There are basically two sponges in the kit with four decreasingly porous pastes. You just put some of the first paste on the sponge and buff it in with a drill at 1200 RPM or less. Then you wash everything down good including the sponge and windshield with warm water. Then you use the next finer paste and repeat the process. Etc, etc, until you've used the 4th paste that is kind of like car wax. Frankly, the scratches were gone after the first application of paste - I started at #2 based on the instructions and the "observed severity" of the scratch depth. So, the bottom line is, if you've got scuffs or mild scratches in your Plexiglass buy this repair kit. It works! Matt Dralle RV-8 #82880 [Image Removed] [Image Removed] [Image Removed] [Image Removed] [Image Removed] [Image Removed] [Image Removed] ________________________________________________________________________________
Date: Nov 21, 2008
We have tried Sensenich 60 inch ground adjustable with great results. Tennessee props 64 x 36 with pretty good results and a Sensenich W64PJ-36 with great results. It is important with that aircraft to get a takeoff and climbout rpm around 3000 rpm. Pete From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Southern Reflections Sent: Thursday, November 20, 2008 3:33 PM Subject: *SPAM* Re: Zenith-List: 80 hp. jab What typt prop are you using and what size and pitch? Thanks Joe N101HD ----- Original Message ----- From: Pete Krotje <mailto:pete(at)usjabiru.com> Sent: Thursday, November 20, 2008 2:56 PM Subject: RE: Zenith-List: 80 hp. jab Jabiru USA is flying a 85hp Jabiru 2200 in our 701. See http://www.usjabiru.com/zenithch701.html for details Pete From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Southern Reflections Sent: Thursday, November 20, 2008 12:45 PM Subject: Zenith-List: 80 hp. jab Does any out there have a 80 hp. jab in a701? Joe N101 HD http://www.matronics.com/contribution http://www.matronics.com/Navigator?Zenith-List http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http ://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Nov 21, 2008
I have used the Novus products with very good results. Novus #3 for heavy scratches and Novus #2 for light scratching. They are available from ACS for $6 to $7 in 8 oz. bottles. You rub it in by hand with a soft cloth. It works very well with little effort. Novus #1 is a plastic cleaner. On Nov 21, 2008, at 12:22 AM, Matt Dralle wrote: > > Dear Listers, > > During the fitting of the Plexiglass canopy on my RV-8, I managed to > put some pretty disheartening scratches in the windscreen section. > You can see from the pictures that they looked pretty bad. A call > to Van's revealed that a replacement canopy would be $640 + $250 > shipping to California! Ack. > > So what to do... A bit of surfing and I found this "Scratch Off" > windshield repair kit for $35 on the Aircraft Spruce web site: > > http://www.aircraftspruce.com/catalog/cspages/scratchoff.php > > Frankly, it just seemed too good to be true. Nothing for $35 could > be that "magic" I thought, but what did I have to lose at this > point.... > -- Bryan Martin N61BM, CH 601 XL, RAM Subaru, Stratus redrive. ________________________________________________________________________________
Subject: Re: *SPAM* Re: 80 hp. jab
Date: Nov 21, 2008
Care to post any observed performance specs? Kevin -------- Mark Twain: Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=215596#215596 ________________________________________________________________________________
Date: Nov 21, 2008
Subject: Gust Locks
I sent this out before but I don't think it went-through.- Here it is a gain.-=0A-=0ASimple Gust Locks-----(See Pics).- Flat Alum., Alum rod, and plastic tubing.- Push tubing over rod and drill holes in flat stock (Tight fight) and push rod with tubing over it through flat plate, add flag and your done.=0A-=0AAl from Oshkosh ________________________________________________________________________________
Subject: Re: Gust Locks
Date: Nov 21, 2008
Nice job,Good idea,going to make me a set....Joe N101HD ----- Original Message ----- From: ALAN BEYER To: zenith-list(at)matronics.com Sent: Friday, November 21, 2008 5:41 PM Subject: Zenith-List: Gust Locks I sent this out before but I don't think it went through. Here it is again. Simple Gust Locks-----(See Pics). Flat Alum., Alum rod, and plastic tubing. Push tubing over rod and drill holes in flat stock (Tight fight) and push rod with tubing over it through flat plate, add flag and your done. Al from Oshkosh ________________________________________________________________________________
Date: Nov 22, 2008
Subject: LOC
Dear Listers, Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its sort of my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take a moment and assure that your name is on that List of Contributors (LOC)? As a number of members have pointed out over the years, the List seems at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment tool as your typical magazine subscription! Please take minute and assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by popping a personal check in the mail to: Matronics Email Lists c/o Matt Dralle PO Box 347 Livermore CA 94551-0347 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Email List Administrator ________________________________________________________________________________
Subject: Wing fitting
Date: Nov 22, 2008
Hello group ,over the Thanksgiving holiday I plan to fit the wings on my 601XL .I could use any information/ideas provided by the members and builders on the site .Are the plans for the wing root cutout listed on page 6-W-6 good enough to go by or is there a better way . Thanks Wade Jones South Texas 601XL Franklin 0-235 ________________________________________________________________________________
Date: Nov 22, 2008
Hello group ,correction on my last post ,should read page 6-W-9 instead of 6-W-6 . Thanks Wade Jones South Texas 601XL Franklin 0-235 ----- Original Message ----- From: wade jones Sent: Saturday, November 22, 2008 9:02 AM Subject: Zenith-List: Wing fitting Hello group ,over the Thanksgiving holiday I plan to fit the wings on my 601XL .I could use any information/ideas provided by the members and builders on the site .Are the plans for the wing root cutout listed on page 6-W-6 good enough to go by or is there a better way . Thanks Wade Jones South Texas 601XL Franklin 0-235 ________________________________________________________________________________
Date: Nov 22, 2008
Subject: There almost done
Now off the airport to fit them one last time and then mount and test. Jeff **************One site has it all. Your email accounts, your social networks, and the things you love. Try the new AOL.com %26icid=aolcom40vanity%26ncid=emlcntaolcom00000001) ________________________________________________________________________________
Date: Nov 22, 2008
Subject: Almost Done
Sorry messed up the first one. Now off the airport to fit them one last time and then mount and test. Jeff **************One site has it all. Your email accounts, your social networks, and the things you love. Try the new AOL.com %26icid=aolcom40vanity%26ncid=emlcntaolcom00000001) ________________________________________________________________________________
Subject: Re: Wing fitting / W.W. Corvair
Date: Nov 22, 2008
Wade, Based on my experience, do NOT cut all the way back to the co-ordinates shown in the plans. I would recommend leaving a minimum of 1/2 inch extra, probably more, on your initial cut. Support your wing in some fashion, and gradually mark and trim as you approach spar bolt alignment. Use the fuselage side as a marker guide, mark, slide the wing out, trim and do it again as you sneak up on the final position. If I recall correctly, the final gap needs to be about 4mm for the rubber root moulding to fit well. Taper ground 5/16" pins or hardware grade bolt shanks are ideal to help align the spar bolt holes as you get close. It took me about three or four hours to trim each wing skin. Also, as part of this process, you need to establish the rear spar final position vertically and laterally. Zenith wants a minimum of 12mm edge distance (preferrably more) on the rear spar bolt. Use a smaller bolt when drilling the first hole, so you still have room to tweak it. Ideally, the centerline of the flap hinge pin will align with the center of the flap actuator shaft, though "close" is OK, as long as both sides are identically positioned relative to the fuselage. On a separate note, I couldn't be more satisfied with my W.W. Corvair. The components that William produces are first class in both design and manufacture, and will allow you to produce a quality powerplant that performs exceptionally in the 601 / XL. I'm still in early Phase one testing, and have no hard performance numbers yet, but this plane is all I hoped for, and more. Lynn Dingfelder 601 / XL W.W. Corvair Power ________________________________________________________________________________
Date: Nov 22, 2008
Subject: Re: There almost done
HI JEFF THEY LOOK LIKE THE MOVIE COCOON LOOK,S GOOD ,SHOULD GIVE DIRECT COOLING GOT MY COMPUTER FIX AGAIN PAT WILL FLIGHT TEST IN THE MORN. TIGHTEN CABLES BEN In a message dated 11/22/2008 10:53:16 A.M. Eastern Standard Time, Afterfxllc(at)aol.com writes: Now off the airport to fit them one last time and then mount and test. Jeff ____________________________________ One site has it all. Your email accounts, your social networks, and the things you love. Try t6ncid=emlcntaolcom00000001">AOL.com today! **************One site has it all. Your email accounts, your social networks, and the things you love. Try the new AOL.com %26icid=aolcom40vanity%26ncid=emlcntaolcom00000001) ________________________________________________________________________________
Subject: Re: Almost Done
Date: Nov 22, 2008
Subject: Spreading fear about the XL
Date: Nov 23, 2008
Friends, neighbors, and fellow Zenith Enthusiasts, I have received multiple off-list communications about the unexplained XL crashes. We now have folks not part of the Zenith community spreading "information" about the accidents. As I reported on this list then, a group of LSA competitors advanced negative information about the XL in person at the September 2007 Zenith Gathering in Winchester, Virginia. For my part, I have not heard anything conclusive from the entities looking at the design, including the Zenith Builder's Analysis Group, Zenith, the NTSB, and European Governments, with two exceptions. One is the cable tension advisory and the other is the European action. Neither tells us what is happening unless you believe that insufficient cable tension is the proper explanation. Others have failed to find any design problem despite an extensive review. ZAC conducted a second static load test with acceptable results. But the impact of all the discussion is becoming clear. In the Second November Issue, 2008 of Trade-A-Plane, there are three kits for sale and a completed aircraft. See page 87. Some advertisements have appeared on this list. Locally, some builders are making the decision to stop work on their projects. While all losses of human life are mourned without reservation, especially losses that need not occur, I believe that we all seek a rational explanation for these events if one exists, not speculation about what the facts we know might mean. So let me call on ZAC, the NTSB, the ZBAG, and all other investigators with the standing to make valid conclusions, to report whatever they have found or not found at this time in order to limit the fear of the 601 XL that is currently spreading through the community. They must speak up now before more damage based on fear is done to our community. Please correct me if anyone with standing has provided a full explanation of the events that are causing these concerns about the XL. Jeff Davidson ________________________________________________________________________________
Subject: Re: Spreading fear about the XL
Date: Nov 23, 2008
Jeff Excellent response. Im about to fly my 601XL and have concerns. Steve W. N 9554 Z ----- Original Message ----- From: Jeff To: zenith-list(at)matronics.com Sent: Sunday, November 23, 2008 10:12 AM Subject: Zenith-List: Spreading fear about the XL Friends, neighbors, and fellow Zenith Enthusiasts, I have received multiple off-list communications about the unexplained XL crashes. We now have folks not part of the Zenith community spreading "information" about the accidents. As I reported on this list then, a group of LSA competitors advanced negative information about the XL in person at the September 2007 Zenith Gathering in Winchester, Virginia. For my part, I have not heard anything conclusive from the entities looking at the design, including the Zenith Builder's Analysis Group, Zenith, the NTSB, and European Governments, with two exceptions. One is the cable tension advisory and the other is the European action. Neither tells us what is happening unless you believe that insufficient cable tension is the proper explanation. Others have failed to find any design problem despite an extensive review. ZAC conducted a second static load test with acceptable results. But the impact of all the discussion is becoming clear. In the Second November Issue, 2008 of Trade-A-Plane, there are three kits for sale and a completed aircraft. See page 87. Some advertisements have appeared on this list. Locally, some builders are making the decision to stop work on their projects. While all losses of human life are mourned without reservation, especially losses that need not occur, I believe that we all seek a rational explanation for these events if one exists, not speculation about what the facts we know might mean. So let me call on ZAC, the NTSB, the ZBAG, and all other investigators with the standing to make valid conclusions, to report whatever they have found or not found at this time in order to limit the fear of the 601 XL that is currently spreading through the community. They must speak up now before more damage based on fear is done to our community. Please correct me if anyone with standing has provided a full explanation of the events that are causing these concerns about the XL. Jeff Davidson ________________________________________________________________________________
Date: Nov 23, 2008
Subject: Re: 601 XL Landing distance
> I wouldn't call 500 feet conservative for a 601XL. At gross weight and no > wind with standard sea level conditions, I'd call 500 feet of runway the > bare minimum. Under more favorable conditions, you can probably get by with > less. I would prefer to have at least 1000 feet to work with, I doubt if > I've ever used more than 1500. I consider 1000 feet the minimum possible, and that's with maximum effort. Anything under that is gravy. This goes double at max gross. It doesn't love runways as much as, say, a Mooney, but do NOT underestimate the distance required. -- Jay Maynard, K5ZC, PP-ASEL http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml ________________________________________________________________________________
Date: Nov 23, 2008
The same guy has posted the following to 4 websites that I frequent. I posted some comments about waiting for the out come and not jumping to conclusions, how many hours that have been flown on this aircraft ect... Here is the post. " The CH601 XL apparently sports a failure mode that has caused one of its wings to 'fold up' on at least seven occasions. After such a case transpired in The Netherlands as well - killing both occupants - the local authorities grounded all CH601 XL aircraft until further notice." It sound nice and is followed and ended with concern, but the exact same verb-age was used in all the posts that I saw. Sounds a little fishy to me. You most all, know that I'm not a 601 guy, but bad/misleading info just burns my A$$. I would fly in a Ch601 without any more care then getting in my truck... well depending on the pilot. ;^) In my opinion, that does not count for much in the big picture, the CH601 is an excellent design and as safe as any. My gut tells me that the incidents were caused by pilot error or extenuating circumstances, or both. OK... back off my soap box. And just go fly your 601! I'm still building my 701 so the jokes on me, anyway :^) Kevin -------- Mark Twain: Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=215904#215904
November 08, 2008 - November 23, 2008
Zenith-Archive.digest.vol-im
