Zenith601-Archive.digest.vol-af
December 28, 2008 - January 21, 2009
      cal flight, which departed Avon Park Executive Airport (AVO), Avon Park, Fl
      orida about 1115. The personal flight was conducted under the provisions of
       14 Code of Federal Regulations Part 91.
      According to a friend of the accident pilot, who was also a certificated ai
      rcraft mechanic, he and the pilot flew together in the accident airplane im
      mediately prior to the accident flight. The friend did not note any abnorma
      lities with the performance of either the airplane or the pilot during thei
      r flight, and upon returning to AVO, the friend disembarked the airplane an
      d the accident passenger boarded.
      Numerous witnesses observed the airplane flying in the local area around th
      e time of the accident. One witness was outside talking with a neighbor whe
      n he observed the airplane flying overhead. The airplane was initially flyi
      ng southwest, and made a "very slight dip and turned to the right. Then the
       airplane pulled up severely and started turning to the left." As the airpl
      ane continued upward and banked to the left, something "shiny" exited from
      the tail area of the airplane. The witness remarked to his neighbor, "What
      the heck is he dumping," and the airplane then began to break apart. The wi
      tness added that he did not hear any type of explosion and did not observe
      any smoke or fire.
      Another witness, who was also a certificated airline transport pilot, state
      d that while outside working on his house he observed the accident airplane
       flying overhead. He estimated that the airplane was flying at an altitude
      about 1,200 feet above ground level, and did not note anything abnormal abo
      ut its flight path. About 45 minutes after first seeing the airplane, he he
      ard an abnormal engine sound that diverted his attention again back to it.
      The witness stated that the engine sound was smooth, continuous, and sounde
      d as if the engine was being "over-sped," as if the engine were at full pow
      er and the airplane was in a high speed dive. When he looked up, he saw the
       airplane pitching up and rolling into a steep left bank, and initially tho
      ught that the pilot was attempting to perform a "barrel-roll or a slow roll
      ." From his position, he could see the bottom of the airplane, as well as b
      oth wings, as the airplane traveled north. He additionally noted that while
       the airplane was banking, both ailerons were "fluttering" at a high freque
      ncy. The bank angle increased to almost 90 degrees, when the left wing of t
      he airplane "folded back" and separated from the fuselage. The airplane the
      n pivoted about the lateral axis 90 degrees, and the right wing then separa
      ted from the fuselage along with a portion of the cabin. The wings "flutter
      ed=94 or "twirled" to the ground, while the portion of the cabin
       continued forward and down to the ground. He recalled hearing three distin
      ct "thuds" as the pieces of the airplane impacted the ground.
      The witness also reported that during the breakup, the airplane released wh
      at initially looked like "confetti," which he later determined to be painte
      d chips of dope from the airplane=92s fabric covered wings.
      The weather conditions reported at Bartow Municipal Airport (BOW), Bartow,
      Florida, located about 24 nautical miles west of the accident site, at 1152
      , included winds from 020 degrees at 9 knots, gusting to 15 knots, 20 statu
      te miles visibility, clear skies, a temperature of 16 degrees Celsius (C),
      a dewpoint of 6 degrees C, and an altimeter setting of 30.21 inches of merc
      ury.
      The pilot held a commercial pilot certificate with ratings for airplane sin
      gle engine land and sea, airplane multiengine land, and instrument airplane
      . He also held a flight instructor certificate with ratings for airplane si
      ngle engine, airplane multiengine, and instrument airplane. His most recent
       FAA second class medical certificate was issued on June 2, 2008.
      Examination of the pilot=92s most recent logbook, which began on May 3, 200
      1, revealed that he had logged 7,126 total hours of flight experience, 12 h
      ours of which were in the accident airplane make and model.
      According to records provided by the FAA, the accident airplane was manufac
      tured in 1946. According to maintenance records, the airplane=92s most rece
      nt annual inspection was completed on May 9, 2008. At the time of the inspe
      ction, the airplane had accumulated 2,588 total hours of operation.
      The in-flight breakup occurred over a residential community built around a
      golf course. Portions of wreckage were found along a wreckage path that was
       3,100 feet long, and oriented on a magnetic heading about 020 degrees. The
       first pieces of wreckage, found at the most southern end of the wreckage p
      ath, included both aft cabin windows. Paint chips, inspection panels, and v
      arious personal effects from inside the airplane were located further along
       the wreckage path, with the right wing being the next most substantial com
      ponent located.
      The right wing was located about 2,000 feet from the aft cabin windows, alo
      ng the wreckage path. The wing was lodged in the ground, oriented perpendic
      ular to the terrain. The wing remained largely intact, and was separated fr
      om the fuselage at the wing root, just inboard of the leading edge fuel tan
      k. The wing spar remained intact to a point about 1-foot inboard of the win
      g root, where it separated from the remainder of the airplane's structure.
      Ten of the right wing's 17 inspection port covers were dislodged, and locat
      ed at various points along the wreckage path in an inverted or "popped" pos
      ition. All of the displaced covers had, with one exception, come from the w
      ing root, leading edge, and outboard edge, while the inspection covers from
       the center and trailing edge portions remained in place.
      The left wing was located about 900 feet beyond the left wing, along the wr
      eckage path. The left wing spar was fractured at a similar location as the
      right wing spar. Several of the inspection port covers were dislodged, but
      did not display any discernable pattern as was observed on the right wing.
      The inboard portions of both wing spars were forwarded to the National Tran
      sportation Safety Board Materials Laboratory for further examination.
      The main portion of wreckage came to rest about 200 feet beyond the left wi
      ng, along the wreckage path. The nose, cabin, and aft portion of fuselage e
      xhibited extensive crush damage, and its entirety was contained with an are
      a about 10 by 10 feet. The cabin was severely compromised, and the seat pan
      , where both occupants were located, was found about 125 feet north of the
      main wreckage. The empennage, horizontal and vertical stabilizers remained
      largely intact, but separated from the remainder of the fuselage, and was c
      o-located with the main wreckage. The propeller was lodged in a shallow imp
      act crater, and remained attached to the engine at the propeller flange. Ch
      ordwise scratching and burnishing was present on both blades.
      Aileron and rudder control continuity was traced from the flight control su
      rfaces to the control "mixing" bellcrank, normally located just aft of the
      main spar carrythrough. Separations of the aileron control push-pull tubes
      were noted at both wing roots, and the elevator push-pull tube was separate
      d about 1-foot forward its bellcrank.
      Index for Dec2008 | Index of months
      -Thoughts?----
Date: Dec 28, 2008
Subject: Re: NTSB report
At 06:29 PM 12/28/2008, you wrote: > > Thoughts? > > I have one thought about the Ercoupe and Zodiac in-flight failures. It stems from the comments by observers that the engine changed pitch just before the breakup. I remember a report about a Zodiac that made vibration sounds (over a power plant?) and the pilot managed to get it to stop with radical roll maneuvering. I wonder if other pilots experiencing unusual vibration sounds might first suspect something wrong with the engine. If so, they might try changing throttle or other engine settings to make the noise go away. I have absolutely no confidence that my notion is correct. All I hope to accomplish with writing this comment is to alert Zodiac XL drivers to the possibility of airframe vibrations and to consider something like the deep roll rather than changing engine settings to deal with such noise. It may help, or it may not. Paul XL getting close ________________________________________________________________________________
Subject: Re: 601 problems
Date: Dec 28, 2008
"The forward sweep is an artifact of the 3 degree forward tilt of the spar and the wing dihedral. If you raise the nose until the spar is vertical you will see no forward sweep." Bryan I will not post to this again. I meant no assault - to anyone. David David, you should keep at it. The forward sweep of the wing in cruise attitude changes the way the air flows over the ailerons. In otherwords, spanwise airflow over a forward-swept wing is the reverse of a conventional swept wing. The fact that the sweep is so slight and can change with flight attitude may be an important factor for the LAA and NTSB to consider in determining how and when the ailerons that did unzip, unzipped since the airflow across them reverses while leveling off after a climb. Correct? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221565#221565 Attachments: http://forums.matronics.com//files/forward_swept_wing_aerodynamics_920.jpg ________________________________________________________________________________
Date: Dec 29, 2008
I had not even thought of that Sabrina. It is definitely possible - might c ouple to slack control system cabling or yielded brackets... David L. Downey Harleysville-(SE) PA, USA --- On Mon, 12/29/08, Sabrina wrote: From: Sabrina <chicago2paris(at)msn.com> Subject: Zenith601-List: Re: 601 problems Date: Monday, December 29, 2008, 12:12 AM "The forward sweep is an artifact of the 3 degree forward tilt of the spar and the wing dihedral. If you raise the nose until the spar is vertical you will see no forward sweep." Bryan =93I will not post to this again. I meant no assault - to anyone.=94 David David, you should keep at it. The forward sweep of the wing in cruise attit ude changes the way the air flows over the ailerons. In otherwords, spanwise airflow over a forward-swept wing is the reverse of a conventional swept wi ng. The fact that the sweep is so slight and can change with flight attitude ma y be an important factor for the LAA and NTSB to consider in determining how and when the ailerons that did unzip, unzipped since the airflow across them reverse s while leveling off after a climb. Correct? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221565#221565 Attachments: http://forums.matronics.com//files/forward_swept_wing_aerodynamics_920.jpg =0A=0A=0A ________________________________________________________________________________
Date: Dec 29, 2008
Sabrina, In your recent email you mention "may be an important factor for the LAA and NTSB to consider in determining how and when the ailerons that did unzip, unzipped... " As I recall, your gussets were developed with this issue in mind. To your knowledge, is the potential for "unzip" suspected to exist only in aircraft with piano hinge ailerons or in the hingeless type as well? Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Working on fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221629#221629 ________________________________________________________________________________
Subject: Re: Retrofitting hingeless ailerons
Date: Dec 29, 2008
To my knowledge no one has done that any way other than new ailerons. God only knows what adding another variable to the aileron would do and sort of defeat the purpose of using the original design. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221642#221642 ________________________________________________________________________________
Date: Dec 29, 2008
Walt, That was quite a graphic and informative report. I, too have wondered if some of the unusual aircraft movements observed prior to the loss of the XL's in question might have been actions taken by the pilot to dampen flutter. Interestingly enough, most Ercoupes originally had balanced ailerons - from what I read the balance weighed almost 4 pounds and hung off the bottom of the aileron. They have been removed from most ercoupes as a alternate means of compliance with a 1947 AD that required reinforcement of the lower ailerons skins because of the weight of the device. I suspect if one were to run around with a cable tensionometer and check the aircraft sitting on the ramp at the local airport they would find most did not have the cable tension set correctly. I have participated in over 50 annuals over the years and never seen a mechanic check the cable tension with such a device. Unless they are really loose they get only a cursory inspection. We had a case a number of years ago where an ercoupe on the field was damaged after it got away from the owner who was trying to hand prop it because of a dead battery. They had to pull the wings and when they went to disconnect the control cables they found that the cable turnbuckles were secured with brass safety wire (not in use for many years) one of which had broken and allowed the turnbuckle to back off to where it was held on by only a couple of threads. If not for the damage on the ground that required disassembly it would have let go in the air. Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Working on fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221644#221644 ________________________________________________________________________________
Date: Dec 29, 2008
I agree with Gig. However, your government publishes a book, AC-43.13-1B that shows Acceptable Methods, Techniques, and Practices - Aircraft Inspection and Repair. You might get some formula for the patch there. You have a copy if you are using Kitlog under, Resources, Advisory Circulars. I bought a printed copy from Jeppsen, and find it quite handy to have around to answer some of the more obscure questions I have. Myself, I'd just re-skin the ailerons. -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221650#221650 ________________________________________________________________________________
Subject: lack of firm information
Date: Dec 29, 2008
I'm seeing a lot of communication suggesting that one sort of change or another should be made to the 601XLs immediately. The problem is, I don't think we have enough information to know if a given change is a good one or not. For all we know, some changes may actually make things worse. I strongly recommend waiting until we have enough information to know what the problem really is before making changes. A healthy discussion at a knowledgable technical level is a good thing, and may ultimately lead to identifying the problem(s). That's my 75 cents worth for this morning (25 cents just won't buy as much as it once did). -- ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Dec 29, 2008
Subject: Re: lack of firm information
Absolutely. Remember the demo is still going strong after many, many hours of flight at or near gross. David L. Downey Harleysville-(SE) PA, USA --- On Mon, 12/29/08, Jim Belcher wrote: From: Jim Belcher <z601(at)anemicaardvark.com> Subject: Zenith601-List: lack of firm information Date: Monday, December 29, 2008, 12:51 PM I'm seeing a lot of communication suggesting that one sort of change or another should be made to the 601XLs immediately. The problem is, I don't think we have enough information to know if a given change is a good one or not. For all we know, some changes may actually make things worse. I strongly recommend waiting until we have enough information to know what the problem really is before making changes. A healthy discussion at a knowledgable technical level is a good thing, and may ultimately lead to identifying the problem(s). That's my 75 cents worth for this morning (25 cents just won't buy as much as it once did). -- ==================== Those who can, do. Those who can't, sue. ======================= Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ======================= =0A=0A=0A ________________________________________________________________________________
Date: Dec 29, 2008
BINGO !!!!! We have a winner. No Not Archive z601(at)anemicaardvark.co wrote: > The problem is, I don't > think we have enough information to know if a given change is a good one or not. > -- -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221684#221684 ________________________________________________________________________________
Subject: Yuba City Probable cause released
Date: Dec 29, 2008
NTSB released the probable cause for the 11/06 AMD accident in Yuba City. The smoking gun is....In-flight structural failure of the horizontal stabilizer and wings for undetermined reasons. Doug Sire Billings, MT -------- Doug Sire 601XL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221698#221698 ________________________________________________________________________________
Subject: Re: Yuba City Probable cause released
Date: Dec 29, 2008
That makes things clear as mud. The one useful bit of info i gout out of it was this. "no oscillatory loading of the control surfaces was apparent." That would seem to be NTSB speak that rules out flutter. That and they didn't rule out abrupt control input. Just that they couldn't see it on radar. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221705#221705 ________________________________________________________________________________
Date: Dec 29, 2008
Tim, - -- I agree with what you said about A&P's and experimental aircraft own ers failing to-check control cable tension during annual or 100 hour insp ections. - -- I have an idea that I would like to put forth for all 601XL & HD own ers on the list who have completed and are flying their airplane in the Uni ted States (overseas owners could do the same thing in their area if intere sted). I will buy a cable tension gauge that can be used on the 601XL & HD, and mail it out to anyone who wants to check their control cables to see i f they meet the specifications called for by Zenith.-When the person who has the gauge-through testing-and adjusting their cables (please do the testing/adjusting ASAP), that person mails the tensionometer-off to the next person on the list (at their expense). I'll maintain-the list of who would like to check their cables and-inform whomever has the gauge where to send it next. I only ask that whenever the gauge is mailed to the next person, I be informed so we don't loose track of there the gauge is.-I'll also make a lightweight padded shipping box inwhich the meter can be shipped. - -----If I get at least 10 interested individuals, I order the gau ge and get things moving. The kit could also include the cable tensions rec ommeded by Zenith for the-XL & HD, plus instruction on how to properly sa fety wire the turnbuckles. And the checking of cable tension might also be added to everyones annual inspection checklist. - ----Is anyone interested?- - Walt in Ohio 601XL/w/Jabiru 3300A working on fuselage------ --- On Mon, 12/29/08, Tim Juhl wrote: From: Tim Juhl <juhl(at)avci.net> Subject: Zenith601-List: Re: NTSB report Date: Monday, December 29, 2008, 12:14 PM Walt, That was quite a graphic and informative report. I, too have wondered if s ome of the unusual aircraft movements observed prior to the loss of the XL's in question might have been actions taken by the pilot to dampen flutter. Interestingly enough, most Ercoupes originally had balanced ailerons - from what I read the balance weighed almost 4 pounds and hung off the bottom of the aileron. They have been removed from most ercoupes as a alternate means of compliance with a 1947 AD that required reinforcement of the lower ailerons skins because of the weight of the device. I suspect if one were to run around with a cable tensionometer and check th e aircraft sitting on the ramp at the local airport they would find most did not have the cable tension set correctly. I have participated in over 50 annua ls over the years and never seen a mechanic check the cable tension with such a device. Unless they are really loose they get only a cursory inspection. We had a case a number of years ago where an ercoupe on the field was damag ed after it got away from the owner who was trying to hand prop it because of a dead battery. They had to pull the wings and when they went to disconnect the control cables they found that the cable turnbuckles were secured with bra ss safety wire (not in use for many years) one of which had broken and allowed the turnbuckle to back off to where it was held on by only a couple of threads. If not for the damage on the ground that required disassembly it would have le t go in the air. Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Working on fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221644#221644 ________________________________________________________________________________
Date: Dec 29, 2008
The separation of the wings and horizontal stabilizer was in a downward direction ...the possibility of an abrupt control input cannot be excluded. This airplane is very responsive in pitch control. One of the handling quality characteristics designed by the airplane's manufacturer is that movement of the control stick produces large and rapid changes in pitch attitude." FWIW. I believe abrupt up elevator input caused horizontal stab downward failure. Causes extreme nose down pitch and extreme neg gs on wing resulting in wing failure in downward direction. Saw this on a T-28A at the Crash Lab at March AFB many years ago during aircraft accident investigation course. Tony Graziano 601XL; N493TG; 454 hours ----- Original Message ----- From: "Gig Giacona" <wrgiacona(at)gmail.com> Sent: Monday, December 29, 2008 4:50 PM Subject: Zenith601-List: Re: Yuba City Probable cause released > > That makes things clear as mud. The one useful bit of info i gout out of > it was this. "no oscillatory loading of the control surfaces was > apparent." That would seem to be NTSB speak that rules out flutter. > > That and they didn't rule out abrupt control input. Just that they > couldn't see it on radar. > > -------- > W.R. "Gig" Giacona > 601XL Under Construction > See my progress at www.peoamerica.net/N601WR > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=221705#221705 > > > ________________________________________________________________________________
Date: Dec 29, 2008
Tim, I have never seen a photo of an unzipped flex hinge. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221740#221740 ________________________________________________________________________________
Subject: Fun Video!
Date: Dec 29, 2008
Check out this video. This has little to do with airplanes directly. But if you find CNC machining or machinery interesting and you like Joe, you might enjoy watching this. http://www.youtube.com/watch?v=qMS8wWOD0HE I will post more; that have to do with aircraft, parts and specifically Corvair stuff and such as they become available. Smile To nights project is to film the Machine cutting a pair of Corvair Heads. Should be fun. :) Enjoy, -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221755#221755 ________________________________________________________________________________
Date: Dec 29, 2008
Walter,=0A=0AI think your idea of share cable tension gauge is great.- It allows the gauge to be more-accessible, and, hopefully, more planes to b e correctly tensioned.- Put me in your list.=0A=0A=0A=0A=0A______________ __________________=0AFrom: Walter Carey <careywf(at)sbcglobal.net>=0ATo: zenit h601-list(at)matronics.com=0ASent: Monday, December 29, 2008 4:58:23 PM=0ASubj ect: Re: Zenith601-List: Re: NTSB report=0A=0A=0ATim,=0A=0A-- I agree w ith what you said about A&P's and experimental aircraft owners failing to -check control cable tension during annual or 100 hour inspections. =0A =0A-- I have an idea that I would like to put forth for all 601XL & HD owners on the list who have completed and are flying their airplane in the United States (overseas owners could do the same thing in their area if int erested). I will buy a cable tension gauge that can be used on the 601XL & HD, and mail it out to anyone who wants to check their control cables to se e if they meet the specifications called for by Zenith.-When the person w ho has the gauge-through testing-and adjusting their cables (please do the testing/adjusting ASAP), that person mails the tensionometer-off to t he next person on the list (at their expense). I'll maintain-the list of who would like to check their cables and-inform whomever has the gauge wh ere to send it next. I only ask that whenever the gauge is mailed to the ne xt person, I be informed so we don't loose track of there the gauge is.-I 'll also make a lightweight padded shipping box inwhich the meter can be sh ipped.=0A=0A-----If I get at least 10 interested individuals, I o rder the gauge and get things moving. The kit could also include the cable tensions recommeded by Zenith for the-XL & HD, plus instruction on how to properly safety wire the turnbuckles. And the checking of cable tension mi ght also be added to everyones annual inspection checklist.=0A=0A--- -Is anyone interested?-=0A=0AWalt in Ohio=0A601XL/w/Jabiru 3300A=0Awork ing on fuselage------=0A=0A--- On Mon, 12/29/08, Tim Juhl =0A=0AWalt,=0AThat was quite a graphic and informa tive report. I, too have wondered if some=0Aof the unusual aircraft moveme nts observed prior to the loss of the XL's in=0Aquestion might have been ac tions taken by the pilot to dampen flutter.=0A=0AInterestingly enough, mos t Ercoupes originally had balanced ailerons - from=0Awhat I read the balanc e weighed almost 4 pounds and hung off the bottom of the=0Aaileron. They h ave been removed from most ercoupes as a alternate means of=0Acompliance wi th a 1947 AD that required reinforcement of the lower ailerons=0Askins beca use of the weight of the device.=0A=0AI suspect if one were to run around w ith a cable tensionometer and check the=0Aaircraft sitting on the ramp at t he local airport they would find most did not=0Ahave the cable tension set correctly. I have participated in over 50 annuals=0Aover the years and nev er seen a mechanic check the cable tension with such a=0Adevice. Unless th ey are really loose they get only a cursory inspection.=0A=0AWe had a case a number of years ago where an ercoupe on the field was damaged=0Aafter it got away from the owner who was trying to hand prop it because of a=0Adead battery. They had to pull the wings and when they went to disconnect the =0Acontrol cables they found that the cable turnbuckles were secured with brass=0Asafety wire (not in use for many years) one of which had broken and allowed the=0Aturnbuckle to back off to where it was held on by only a cou ple of threads. If=0Anot for the damage on the ground that required disass embly it would have let go=0Ain the air.=0A=0ATim=0A=0A--------=0A_________ _____=0ACFII=0AChamp L16A flying=0AZodiac XL - Jabiru 3300A=0AWorking on fu selage=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matron ics.com/viewtopic.php?p=221644#221644=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=0A=0A=0A=0A ________________________________________________________________________________
Subject: AS5 Rivets
Date: Dec 30, 2008
I think I saw a post on this but cant find the answer using the search function. Can anyone advise where the 3 AS 5 rivets are packed? as I have looked through all the obvious to me places and nothing. Thanks and happy new year! Kev -------- Austria ............. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221765#221765 ________________________________________________________________________________
Date: Dec 30, 2008
Subject: Re: AS5 Rivets
same here, a complete kit should have 25/30 of them. bye. 2008/12/30 K Dilks > > I think I saw a post on this but cant find the answer using the search > function. > Can anyone advise where the 3 AS 5 rivets are packed? as I have looked > through all the obvious to me places and nothing. > > > Thanks and happy new year! > > Kev > > -------- > Austria ............. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=221765#221765 > > -- Alberto Martin www.iberplanes.es Igualada - Barcelona - Spain ---------------------------------------------- Zodiac 601 XL Builder Serial: 6-7011 Tail Kit: Finished Wings: Not Started Fuselage: Ordered Engine: Jabiru 3300 ________________________________________________________________________________
Date: Dec 30, 2008
John, - - You're the first on the list. Hope to get at least 9 more interested bu ilders. Send me you e-mail address for the list, and when I get enough inte rested builders (10), I ask you-for your mailing address.- Walt. --- On Tue, 12/30/08, John Smith wrote: From: John Smith <zenithlist(at)yahoo.com> Subject: Re: Zenith601-List: Re: NTSB report Date: Tuesday, December 30, 2008, 12:51 AM Walter, - I think your idea of share cable tension gauge is great.- It allows the g auge to be more-accessible, and, hopefully, more planes to be correctly t ensioned.- Put me in your list. From: Walter Carey <careywf(at)sbcglobal.net> Sent: Monday, December 29, 2008 4:58:23 PM Subject: Re: Zenith601-List: Re: NTSB report Tim, - -- I agree with what you said about A&P's and experimental aircraft own ers failing to-check control cable tension during annual or 100 hour insp ections. - -- I have an idea that I would like to put forth for all 601XL & HD own ers on the list who have completed and are flying their airplane in the Uni ted States (overseas owners could do the same thing in their area if intere sted). I will buy a cable tension gauge that can be used on the 601XL & HD, and mail it out to anyone who wants to check their control cables to see i f they meet the specifications called for by Zenith.-When the person who has the gauge-through testing-and adjusting their cables (please do the testing/adjusting ASAP), that person mails the tensionometer-off to the next person on the list (at their expense). I'll maintain-the list of who would like to check their cables and-inform whomever has the gauge where to send it next. I only ask that whenever the gauge is mailed to the next person, I be informed so we don't loose track of there the gauge is.-I'll also make a lightweight padded shipping box inwhich the meter can be shipped. - -----If I get at least 10 interested individuals, I order the gau ge and get things moving. The kit could also include the cable tensions rec ommeded by Zenith for the-XL & HD, plus instruction on how to properly sa fety wire the turnbuckles. And the checking of cable tension might also be added to everyones annual inspection checklist. - ----Is anyone interested?- - Walt in Ohio 601XL/w/Jabiru 3300A working on fuselage------ --- On Mon, 12/29/08, Tim Juhl wrote: From: Tim Juhl <juhl(at)avci.net> Subject: Zenith601-List: Re: NTSB report Date: Monday, December 29, 2008, 12:14 PM Walt, That was quite a graphic and informative report. I, too have wondered if s ome of the unusual aircraft movements observed prior to the loss of the XL's in question might have been actions taken by the pilot to dampen flutter. Interestingly enough, most Ercoupes originally had balanced ailerons - from what I read the balance weighed almost 4 pounds and hung off the bottom of the aileron. They have been removed from most ercoupes as a alternate means of compliance with a 1947 AD that required reinforcement of the lower ailerons skins because of the weight of the device. I suspect if one were to run around with a cable tensionometer and check th e aircraft sitting on the ramp at the local airport they would find most did not have the cable tension set correctly. I have participated in over 50 annua ls over the years and never seen a mechanic check the cable tension with such a device. Unless they are really loose they get only a cursory inspection. We had a case a number of years ago where an ercoupe on the field was damag ed after it got away from the owner who was trying to hand prop it because of a dead battery. They had to pull the wings and when they went to disconnect the control cables they found that the cable turnbuckles were secured with bra ss safety wire (not in use for many years) one of which had broken and allowed the turnbuckle to back off to where it was held on by only a couple of threads. If not for the damage on the ground that required disassembly it would have le t go in the air. Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Working on fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221644#221644 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Dec 30, 2008
Check the inventory list that Zenith sends with each kit. It will tell you where AS5 rivets are used. Then look in the boxes containing parts associated with that component. I found one of the most helpful things was to go down the inventory list while checking things in and mark the location of each item. I put a code on each box with magic marker and similarly wrote the part number in a conspicuous part of the paper wrapping each piece of sheet metal. So far it has worked pretty good. Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Working on fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221795#221795 ________________________________________________________________________________
Date: Dec 30, 2008
On Tuesday 30 December 2008 10:55, Tim Juhl wrote: > > Check the inventory list that Zenith sends with each kit. It will tell you > where AS5 rivets are used. Then look in the boxes containing parts > associated with that component. All of mine were in a single zip lock bag, not associated with any particular assembly. I believe that bag was in a cardboard container labeled "hardware." -- ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Dec 30, 2008
I just checked the NTSB database and didn't see the report. Where are you guys reading this? Could someone post a link? dougsire wrote: > NTSB released the probable cause for the 11/06 AMD accident in Yuba City. The smoking gun is....In-flight structural failure of the horizontal stabilizer and wings for undetermined reasons. > > Doug Sire > Billings, MT -------- Scratch building XL with Corvair Engine Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221806#221806 ________________________________________________________________________________
Date: Dec 30, 2008
http://www.ntsb.gov/ntsb/brief.asp?ev_id 061115X01677&key=1 http://www.ntsb.gov/ntsb/brief2.asp?ev_id 061115X01677&ntsbno=LAX07FA026&akey=1 Alberto Martin www.iberplanes.es Igualada - Barcelona - Spain ---------------------------------------------- Zodiac 601 XL Builder Serial: 6-7011 Tail Kit: Finished Wings: Not Started Fuselage: Ordered Engine: Jabiru 3300 ________________________________________________________________________________
Date: Dec 30, 2008
I bought the complete kit back in 2006. The AS5 rivets were scattered amongst the various components that they were a part of. Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Working on fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221832#221832 ________________________________________________________________________________
Date: Dec 30, 2008
I found it here: http://www.ntsb.gov/ntsb/GenPDF.asp?id=LAX07FA026&rpt=fi and the most interesting thing is at the end. REASON FOR OCCURRENCE UNDETERMINED Let's try to keep that in mind. -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=221871#221871 ________________________________________________________________________________
Subject: Hand Riveter Heads
Date: Dec 31, 2008
Is Zenith Aircraft Company the only source for riveter heads that will form the A4 and A5 rivet heads properly? I recently returned two heads to Zenith that I had originally purchased from them about 30 years ago when I thought I would scratch build a CH250. I used these in a standard hardware store hand riveter. I've used this old tool to set some rivets on the 601XL/650 that I'm building now and I wasn't very happy with the head that was being formed on the rivet. So, I decided to send them back to Zenith and have them reworked. Even though I had them triple wrapped, they broke out of the envelope and were lost. Zenith kindly sent me some new ones! However, the new ones won't fit my old tool (the replacements are a smaller diameter thread - the same as the thread on the pneumatic riveter I bought from Zenith). The Zenith factory now tells me they can't supply the thread size my old riveter needs. So, I decided what the heck, I'll just buy a new riveter! I bought one at the local Menards that looked like it would get me into tight places only to discover when I got home that it uses the same thread size heads as my old riveter! So I'm now looking for another supplier of rivet heads, or a recommendation for a good manual riveter that will take the same thread size heads as the Zenith Pneumatic riveter. Any recommendations will be appreciated! -------- Dale Flying Cessna 170B Building Zenith CH650 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222000#222000 ________________________________________________________________________________
Date: Dec 31, 2008
Subject: Re: Hand Riveter Heads
Hi Dale, Have no fear. You can grind your own recesses in riveter nose pieces. There are many ways to do this. Perhaps the best way is to use a round grind stone or round cutter in a small rotary tool - a "Dremel". I mounted my nose pieces in the 3 jaw chuck of my lathe and turned the piece slowly while grinding the recess. You might do the same thing using a drill instead of the lathe. The only "Trick" is deciding when you have ground enough. This can be done by testing the nose piece with actual rivet setting. If you feel you have gone too far you can reduce the depth of the recess by filing a flat zone off the end of the nose piece. You may need to buy some new tools to accomplish this task. But, isn't building the airplane mostly just a good excuse to buy new tools? Good luck, Paul XL getting close At 12:05 PM 12/31/2008, you wrote: > >Is Zenith Aircraft Company the only source for riveter heads that >will form the A4 and A5 rivet heads properly? > >I recently returned two heads to Zenith that I had originally >purchased from them about 30 years ago when I thought I would >scratch build a CH250. I used these in a standard hardware store >hand riveter. I've used this old tool to set some rivets on the >601XL/650 that I'm building now and I wasn't very happy with the >head that was being formed on the rivet. So, I decided to send them >back to Zenith and have them reworked. Even though I had them >triple wrapped, they broke out of the envelope and were >lost. Zenith kindly sent me some new ones! However, the new ones >won't fit my old tool (the replacements are a smaller diameter >thread - the same as the thread on the pneumatic riveter I bought from Zenith). > >The Zenith factory now tells me they can't supply the thread size my >old riveter needs. So, I decided what the heck, I'll just buy a new >riveter! I bought one at the local Menards that looked like it >would get me into tight places only to discover when I got home that >it uses the same thread size heads as my old riveter! > >So I'm now looking for another supplier of rivet heads, or a >recommendation for a good manual riveter that will take the same >thread size heads as the Zenith Pneumatic riveter. > >Any recommendations will be appreciated! > >-------- >Dale >Flying Cessna 170B >Building Zenith CH650 ________________________________________________________________________________
Date: Dec 31, 2008
I hope this isn't a foolish question but do you need separate dies for A4 and A5? The A4 die I ground seems to also be the right one for the A5 shafts but wouldn't have the right head profile (?). Thanks, Ron in L.A. (Happy New Year!) ________________________________________________________________________________
Date: Dec 31, 2008
I use the manual riveter that Zenith sells. It has worked well and the heads are already ground when you get it. Steve At 02:05 PM 12/31/2008, you wrote: > >So I'm now looking for another supplier of rivet heads, or a >recommendation for a good manual riveter that will take the same >thread size heads as the Zenith Pneumatic riveter. Steve Look Monticello, IL www.ilrt66.com "Dogs have owners, Cats have staff" ________________________________________________________________________________
Subject: 2 More fun videos :)
Date: Dec 31, 2008
For those who are interested; I just posted two more videos. The first one is of how we resurface the Head gasket area on the Corvair heads. http://www.youtube.com/watch?v=xptR8V9T1NM The second one is cutting out a rear starter bracket for our MagVair conversion. http://www.youtube.com/watch?v=nHNyFiEOZV4 I'm not really addicted to Joe Satriani; I just like instrumentals. I'll try to change it up a bit in the future. Enjoy :) Happy New Year! -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222023#222023 ________________________________________________________________________________
Date: Dec 31, 2008
Yes they are different. ronpollock(at)gmail.com wrote: > I hope this isn't a foolish question but do you need separate dies for > A4 and A5? The A4 die I ground seems to also be the right one for the > A5 shafts but wouldn't have the right head profile (?). > > Thanks, Ron in L.A. (Happy New Year!) -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222028#222028 ________________________________________________________________________________
Date: Dec 31, 2008
Dale It would be a lot easier to re tap the treads in the rivet gun if you already have the nose pieces from Zenith. Bob Spudis N701ZX In a message dated 12/31/2008 12:22:55 P.M. Pacific Standard Time, psm(at)att.net writes: --> Zenith601-List message posted by: Paul Mulwitz Hi Dale, Have no fear. You can grind your own recesses in riveter nose pieces. There are many ways to do this. Perhaps the best way is to use a round grind stone or round cutter in a small rotary tool - a "Dremel". I mounted my nose pieces in the 3 jaw chuck of my lathe and turned the piece slowly while grinding the recess. You might do the same thing using a drill instead of the lathe. The only "Trick" is deciding when you have ground enough. This can be done by testing the nose piece with actual rivet setting. If you feel you have gone too far you can reduce the depth of the recess by filing a flat zone off the end of the nose piece. You may need to buy some new tools to accomplish this task. But, isn't building the airplane mostly just a good excuse to buy new tools? Good luck, Paul XL getting close At 12:05 PM 12/31/2008, you wrote: >--> Zenith601-List message posted by: "dalemed" > >Is Zenith Aircraft Company the only source for riveter heads that >will form the A4 and A5 rivet heads properly? > >I recently returned two heads to Zenith that I had originally >purchased from them about 30 years ago when I thought I would >scratch build a CH250. I used these in a standard hardware store >hand riveter. I've used this old tool to set some rivets on the >601XL/650 that I'm building now and I wasn't very happy with the >head that was being formed on the rivet. So, I decided to send them >back to Zenith and have them reworked. Even though I had them >triple wrapped, they broke out of the envelope and were >lost. Zenith kindly sent me some new ones! However, the new ones >won't fit my old tool (the replacements are a smaller diameter >thread - the same as the thread on the pneumatic riveter I bought from Zenith). > >The Zenith factory now tells me they can't supply the thread size my >old riveter needs. So, I decided what the heck, I'll just buy a new >riveter! I bought one at the local Menards that looked like it >would get me into tight places only to discover when I got home that >it uses the same thread size heads as my old riveter! > >So I'm now looking for another supplier of rivet heads, or a >recommendation for a good manual riveter that will take the same >thread size heads as the Zenith Pneumatic riveter. > >Any recommendations will be appreciated! > >-------- >Dale >Flying Cessna 170B >Building Zenith CH650 **************New year...new news. Be the first to know what is making ________________________________________________________________________________
Date: Dec 31, 2008
Send in the heads you got from menards. I was not happy with the ones I tried to grind myself so finally had them do it. Glad I did. Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Working on fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222084#222084 ________________________________________________________________________________
Date: Dec 31, 2008
See this video posted by ZAC on youtube: http://www.youtube.com/watch?v=-FfdJPOM51A (It's also posted, with better quality, on zenith.aero ) Carlos 2008/12/31 dalemed > > Is Zenith Aircraft Company the only source for riveter heads that will form > the A4 and A5 rivet heads properly? > ________________________________________________________________________________
Date: Dec 31, 2008
There is also a section on making and testing riveter heads in the Zenith construction standards document in the builder's area on the Zenith site. But it doesn't add much to what has already been posted. -- Craig From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Carlos Sa Sent: Wednesday, December 31, 2008 6:16 PM Subject: Re: Zenith601-List: Hand Riveter Heads See this video posted by ZAC on youtube: http://www.youtube.com/watch?v=-FfdJPOM51A (It's also posted, with better quality, on zenith.aero ) Carlos 2008/12/31 dalemed Is Zenith Aircraft Company the only source for riveter heads that will form the A4 and A5 rivet heads properly? ________________________________________________________________________________
Subject: Carby Air/Heat box
Date: Dec 31, 2008
Up to the stage of setting up the carby on the 601XL using the Corvair. Could any one give any dimensions of a Air/Heat box. I have seen the one on WW site but if possible can i have any dimensions so as i can fabricate one. Or any places to purchase one completed. Thank you Ianrat. :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222104#222104 ________________________________________________________________________________
Subject: Re: Carby Air/Heat box
Date: Jan 01, 2009
Thank you Jay. That is the one that i have seen at the WW site. I have already finished the cowling unfortunately (It came with the motor that i purchased) and do not want to purchase another one. Thank you Ianrat Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222147#222147 ________________________________________________________________________________
Date: Jan 01, 2009
I have the dimensions but I will have to go to the airport tomorrow and get them or I could make you one if you like. They take some time to make but not hard at all. Jeff Garrett Louisville Ky. 601XL N962T Aerolite Corvair 90% 601XL N524B Aerolite Corvair 155 Hrs 601XL N2257 Aerolite Corvair 225 Hrs _www.aeroliteproducts.com_ (http://www.aeroliteproducts.com/) _www.project601xl.com_ (http://www.project601xl.com/) www.aerolite.camstreams.com **************New year...new news. Be the first to know what is making ________________________________________________________________________________
Date: Jan 01, 2009
Thank you, everyone, for the information and guidance. I guess I'll make my own :) -------- Dale Flying Cessna 170B Building Zenith CH650 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222183#222183 ________________________________________________________________________________
Date: Jan 01, 2009
See: http://www.zenithair.com/zodiac/6-photo-testing.html The pictures shown near the top of the page show negative G static load testing. Positive G load testing would be done with the airframe upside down with the sandbags stacked on the bottom of the wings. Positive G load testing is shown in some of the photos in the lower part of the page. On Jan 1, 2009, at 1:38 PM, David X wrote: > > I do not recall that ZAC ever did a negative G static test on this > aircraft. > -- Bryan Martin N61BM, CH 601 XL, RAM Subaru, Stratus redrive. ________________________________________________________________________________
Date: Jan 01, 2009
David, You forget that Zenith's official position as of November of 2007 was that you did not need a tension gauge, that your fingers could do the walking. So too, when asked, they would call out different tensions depending upon who you talked to. So, no wonder why so many aircraft are flying out there with improperly tensioned cables. Who knows, is Zenith correct or Larry? Sometimes I wonder if Larry's lower numbers make more sense. Anyone who completed before 11/07 is neither cheap nor foolish, just following what Zenith said. I would be more afraid to fly an aircraft built to plans pages not signed off by CH as some CZAW are, than fly an aircraft with lower cable tensions called out by Larry and others. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222236#222236 ________________________________________________________________________________
Subject: Re: XL wing concerns
Date: Jan 01, 2009
David, Which CZAW version do you have? Is your rear spar attach lowered? Is your center spar modified per the CZAW plans show above? What is the thickness of your rear side skins? Not protesting, just gathering information... :o) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222239#222239 ________________________________________________________________________________
Date: Jan 01, 2009
I find my Zenith doth depend upon A most auspicious star, whose influence If now I court not, but omit, my fortunes Will ever after droop. Here cease more questions. (Tempest I.ii.217-220) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222242#222242 ________________________________________________________________________________
Date: Jan 01, 2009
David, is your aircraft N601NJ, the one I saw at Air Venture 2005? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222269#222269 ________________________________________________________________________________
Date: Jan 01, 2009
Dear David Johnson, N601NJ was at Air Venture 2005. Jim Pellien put it up for sale later that year as an ELSA that is authorized for commercial flight training. I remember finding it strange that a factory built aircraft was not certified as an S-LSA but rather as an E-LSA. Is this because it was not built to the same standards as the other CZAW S-LSA aircraft imported into the US? Could this be a 4th version of CZAW that I missed? I could not find your IA, AP, Repairman Light Sport Aircraft or Repairman Experimental Aircraft Builder certificate. Is this because E-LSA owners can get the RLSA certificate after attending the repairman course--but not corporations, or is it because you did not build it, CZAW did, so the REAR certificate was not available either? This is a strange situation. It is not an S-LSA so you dont have to follow CZAW standards for repair. It is an E-LSA, but since it is owned by a corporation, and the airworthiness certificate allows for commercial operations, it must be maintained by an IA/AP. Correct? When you took the top skin off making it obvious that the skins are part of the support structure, was that owner preventative maintenance or can just anyone 18 or over repair an E-LSA that is authorized for commercial flight training? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222286#222286 Attachments: http://forums.matronics.com//files/air_venture_2005_169.jpg ________________________________________________________________________________
Date: Jan 01, 2009
Bryan, Where an S-LSA is converted into an E-LSA, I was told that it could not be repaired by just anyone. The basis is 14 CFR 43.1. First, there is a prior EU Airworthiness Certificate which is equivalent to a previously issued FAA certificate so there is no experimental exemption for an E-LSA previously certified as airworthy by an S-LSA mfg. 14 CFR 43.1(b) Second, Part 43 applies to any aircraft issued a special airworthiness certificate in the light sport category EXCEPT where the products are not produced under an FAA approval... without the double negative: Part 43 applies to all LSAs where the part being installed or repaired was produced under an FAA approval. Parts provided by Zenith or Can Zac would be exempt and could be installed or repaired on an E-LSA by anyone over 18 assuming no commercial use. Parts provided by CZAW or AMD would not be exempt. Since the parts on the converted E-LSA were produced by CZAW, Part 43 applies and an RLSA or higher is required to repair them. Correct? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222326#222326 ________________________________________________________________________________
Date: Jan 02, 2009
Subject: Re: NTSB report.
Hi Gary, Over-tight cables will result in worn pivot bearings and perhaps bent wing rib supports for the bell cranks. Loose is not good either, but the spec tends to carry tightness to a maximum which is as bad as over tight. 25 to 30 lbs is tight for any cable, unless it is of considerable length and is unsupported along its length. It is the unrestrained weight of a cable that is considered a "player" in the flutter discussions and that's any cable with low enough tension to swing freely between its ends. In most cases, you cannot get that with 25 to 30 lbs. Easy enough to feel the difference if you think about it. A tension gage might be more useful to avoid over tightening as loose is easy to diagnose. Larry McFarland 601HDS at www.macsmachine.com Gary Gower wrote: > I am still building my 601 XL , now finishing the Fuselage, will > start the wings soon... > > I will like to hear some good answers about simple questions: > What will be more dangerous? To over tight the cables? Or to have > the cables just a little loose (in the lower side of the tension > specs)? > > Just wondering before I need a cable tension meter :-) > > Saludos > Gary Gower > Flying from Chapala, Mexico > 701 912S 230 hrs... > 601XL Jab 3300 Tail done, fuselage almost ready, wings next. > > ________________________________________________________________________________
Date: Jan 02, 2009
Some CZAW built aircraft were shipped to this country and assembled here by the distributer. They never had an AW certificate issued to them in any country. They were registered here as ELSA under the "fat ultralight" exemption. They were not converted from SLSA. Part 43 doesn't apply to these aircraft. Anyone can perform the maintenance on them, an RLSA-I or higher is required to sign off the annual inspection. These aircraft can be used for hire for the purpose of flight instruction until January 31, 2010. If they are actually used for hire for flight instruction they must also receive 100 hour inspections conducted by the holder of an RLSA-M or higher certificate. As for an SLSA converted to ELSA, it appears that you are correct in that Part 43 does apply and an RLSA-M or higher is required for most types of maintenance. According to the EAA, the FAA may propose new rules to change this requirement for converted ELSAs. > > > > Bryan, > > Where an S-LSA is converted into an E-LSA, I was told that it could > not be repaired by just anyone. > > The basis is 14 CFR 43.1. > > First, there is a prior EU Airworthiness Certificate which is > equivalent to a previously issued FAA certificate so there is no > experimental exemption for an E-LSA previously certified as > airworthy by an S-LSA mfg. 14 CFR 43.1(b) > > Second, Part 43 applies to any aircraft issued a special > airworthiness certificate in the light sport category EXCEPT where > the products are not produced under an FAA approval... without the > double negative: Part 43 applies to all LSAs where the part being > installed or repaired was produced under an FAA approval. > > Parts provided by Zenith or Can Zac would be exempt and could be > installed or repaired on an E-LSA by anyone over 18 assuming no > commercial use. > > Parts provided by CZAW or AMD would not be exempt. > > Since the parts on the converted E-LSA were produced by CZAW, Part > 43 applies and an RLSA or higher is required to repair them. > Correct? > > -- Bryan Martin N61BM, CH 601 XL, RAM Subaru, Stratus redrive. ________________________________________________________________________________
Date: Jan 02, 2009
Thank you Bryan... the problem is that CZAW registered the serial numbers and obtained EU documents, and those same serial numbers show up here. The FAA data base calls fat ultralight E-LSAs that had not been registered before: "Experimental Operating Light Sport" The FAA data base shows E-LSA's where the serial numbers were previously registered as "Experimental Registered Prior" I was told that a license was needed to maintain an "Experimental Registered Prior". This is where the FAA and EAA are working on a solution to allow the owner to perform their maintenance after the new regulations take place. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222406#222406 ________________________________________________________________________________
Date: Jan 02, 2009
Thank you John. Walt. --- On Thu, 1/1/09, John Smith wrote: From: John Smith <zenithlist(at)yahoo.com> Subject: Re: Zenith601-List: Re: NTSB report Date: Thursday, January 1, 2009, 9:52 PM Being cheap or foolish is irrelevant.- The important thing is the have th e cables tensioned correctly anyway possible, and Walter is offering one- method to do just that. From: David X <dxj(at)comcast.net> Sent: Thursday, January 1, 2009 1:22:40 PM Subject: Zenith601-List: Re: NTSB report I can't imagine why someone would spend so much money and time on such a th ing as aircraft, yet not invest a few hundred in a cable tension meter (or pay an AP to check the tensions). There's cheap, and then there's foolish. zenithlist(at)yahoo.com wrote: > Walter, >- >- I think your idea of share cable tension gauge is great.- It allows the gauge to be more 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Jan 02, 2009
As someone monitoring this discussion because of an interest in plans building a 601 or equiv, I'd appreciate any opinions relative to my position. Especially whether the 650 is susceptible to the same issues. What would you do if you were just thinking of getting started. Thanks, Ron in L.A. ________________________________________________________________________________
Date: Jan 02, 2009
I'm comfortable with my choice and would not hesitate to do it again. Bill Pagan EAA Tech Counselor #4395 601XL QBK/Corvair/N565BW (RES) --- On Fri, 1/2/09, Ron Pollock wrote: From: Ron Pollock <ronpollock(at)gmail.com> Subject: Re: Zenith601-List: Re: XL wing concerns Date: Friday, January 2, 2009, 4:27 PM -----Inline Attachment Follows----- As someone monitoring this discussion because of an interest in plans building a 601 or equiv, I'd appreciate any opinions relative to my position. Especially whether the 650 is susceptible to the same issues. What would you do if you were just thinking of getting started. Thanks, Ron in L.A. le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Jan 02, 2009
ronpollock(at)gmail.com wrote: > As someone monitoring this discussion because of an interest in plans > building a 601 or equiv, I'd appreciate any opinions relative to my > position. Especially whether the 650 is susceptible to the same > issues. What would you do if you were just thinking of getting > started. > > Thanks, Ron in L.A. If you are a pilot, fly one. I did and bought the plans on the way home from the airport. With plans building you need to put some time in almost every day so plan your workspace. -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222497#222497 ________________________________________________________________________________
Date: Jan 02, 2009
Thanks Ron. I'm plans building a 701 now so know the drill. Just took a liking to the 601 and ran into a bunch of controversy I'm trying to sort out. Add to that the new model and trying to sort that out. Guess my real question was whether some here, if starting now, would build from 650 plans. I've gotten feedback that they are almost mix & match. I wasn't asking if anyone had regrets or would go non-Zenair. But I'm happy to hear those happy with their 601s as from my position a little extra confidence is required to start on. Ron in L.A. -----Original Message----- From: Ron Lendon <rlendon(at)comcast.net> Sent: Friday, January 02, 2009 7:49 PM Subject: Zenith601-List: Re: XL wing concerns ________________________________________________________________________________
Date: Jan 03, 2009
Although I certainly feel cables should be tight (within reason), especially in light of having my cables loosen during a 600 mile flight last October, a loose cable is less likely to vibrate than a tight one (cable frequency decreases as cable tension decreases). A completely slack cable will generally never see any induced vibrations (it's natural frequency is below any rotating equipment). However, the loose cable may result in a potential flutter of the ailerons which is less likely with a tight cable. It may have been my imagination, but while flying over the mountains of NC last October with extremely loose cables at a speed of about 100 mph, I was sure I noticed some small vibrations in the ailerons. What alerted me to the looseness of the cables in flight was the fact that I could move the stick about 1/2 inch either side of center without any force being exerted on the stick. When I landed in Andrews, NC and checked the cables, I noticed the balance cable was completely slack (it could be moved up and down about 6-8 inches). I won't get into why the cables became loose at this point since Ihab and I have discussed the geometry of the wing, cable displacement, initial tightness, rib bending, etc., etc., in order to determine the cause to no avail. If I discover a reason, I'll let everyone know. But in the meantime, just make sure your cables are tight, just not too tight. larry(at)macsmachine.com wrote: > Hi Gary, > ...It is the unrestrained > weight of a cable that is considered a "player" in the flutter > discussions and > that's any cable with low enough tension to swing freely between its > ends. In most cases, you cannot get that with 25 to 30 lbs. > Easy enough to feel the difference if you think about it. A tension > gage might be more useful to avoid over tightening as loose is easy > to diagnose. > > Larry McFarland 601HDS at www.macsmachine.com > > Gary Gower wrote: > > > I am still building my 601 XL , now finishing the Fuselage, will > > start the wings soon... > > > > I will like to hear some good answers about simple questions: > > What will be more dangerous? To over tight the cables? Or to have > > the cables just a little loose (in the lower side of the tension > > specs)? > > > > Just wondering before I need a cable tension meter :-) > > > > Saludos > > Gary Gower > > Flying from Chapala, Mexico > > 701 912S 230 hrs... > > 601XL Jab 3300 Tail done, fuselage almost ready, wings next. > > > > > > > > > -------- Scott Thatcher, Palm Beach Gardens, FL 601XL with Corvair, Registered as E-LSA N601EL, EAA203 25 hours and climbing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222567#222567 ________________________________________________________________________________
Date: Jan 03, 2009
ronpollock(at)gmail.com wrote: > Thanks Ron. I'm plans building a 701 now so know the drill. Just took a liking to the 601 and ran into a bunch of controversy I'm trying to sort out. Add to that the new model and trying to sort that out. Guess my real question was whether some here, if starting now, would build from 650 plans. I've gotten feedback that they are almost mix & match. > > I wasn't asking if anyone had regrets or would go non-Zenair. But I'm happy to hear those happy with their 601s as from my position a little extra confidence is required to start on. > > Ron in L.A. > > -- Ron, The XL is a well designed structure. Quite strong in my opinion and I have a bit of experience in destroying structures, it was part of my job at Chrysler Engineering back in the 70's. The feeling I get from talking to the Heintz's is it, the 650, is just slight changes from the several models they build worldwide to reduce the component count and make a better plane. Either XL or 650 are pretty much the same from what I see. Much of the XL controversy sounds like our American press, full of supposition, conjecture, and opinion. As far as any consistent contributing factors there appears to be none currently. -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222721#222721 ________________________________________________________________________________
Subject: Re: W&B envelope CH601XL
Date: Jan 04, 2009
The LAA, who usually go OTT with approvals and testing, publish a document called a TAD for all amateur built aircraft. This document has some useful info regarding weights, CoG limits, operating speeds etc. Generally the info within the TAD will have been checked by a thorough flight test program performed on the first completed example of the type to be completed. For the 601XL see http://www.lightaircraftassociation.co.uk/engineering/TADs/162B%20ZENAIR%20CH601-XL.pdf where theCoG range is given as 300 to 520 mm aft of datum (datum is leading edge). I hope that this is useful info. Andrew. -------- A good way through building a 601UL with 912UL. Still flying Rans S6 with 503. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222809#222809 ________________________________________________________________________________
Subject: Elevator bias spring
Date: Jan 04, 2009
Any suggestions on finding the details about the elevator bias spring -? CZAW drawing 6-BO-4CZ ? Jay in Dallas ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Subject: Re: Elevator bias spring
Date: Jan 05, 2009
Jay & Dave Have a look at the attached drawing 6-BO-4CZ: This is the installation of the "elevator bias spring" required by LAA UK on CZAW CH601XL. Cheers Martin -------- Martin Pohl Zodiac XL QBK 8645 Jona, Switzerland www.pohltec.ch/ZodiacXL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222931#222931 Attachments: http://forums.matronics.com//files/6_bo_4cz_902.pdf ________________________________________________________________________________
Date: Jan 05, 2009
Martin Does the LAA require the bias spring on aircraft that have the full width elevator trim tabs (i.e., as changed in updates 2005b)? Or is it only required on aircraft with the original, narrower elevator trim tabs? Thanks. Terry >Jay & Dave > >Have a look at the attached drawing 6-BO-4CZ: This is the installation of >the "elevator bias spring" required by LAA UK on CZAW CH601XL. > >Cheers Martin Terry Phillips ZBAGer ttp44~at~rkymtn.net Corvallis MT 601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons are done; working on the wings http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: Jan 05, 2009
Terry Both full width elevator trim and elevator bias spring are required by UK LAA (see TADS: http://www.lightaircraftassociation.co.uk/engineering/TADs/162B%20ZENAIR%20CH601-XL.pdf). I saw a flight test report that was issued by the test pilot of the UK LAA. He wrote that the aircraft is not trimmable with full flaps extended, even with the full width elevator trim. Martin -------- Martin Pohl Zodiac XL QBK 8645 Jona, Switzerland www.pohltec.ch/ZodiacXL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=222978#222978 ________________________________________________________________________________
From: "chris Sinfield" <chris_sinfield(at)yahoo.com.au>
Date: Jan 05, 2009
OK I cannot read the words about the size or strength of the spring required for full flap, anyone expand on this? and how is it different from other XL's as I thought the Idea of the full size trim was so you can still do a circuit with full flaps and fly hands off with full elevator trim.? Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223015#223015 ________________________________________________________________________________
Subject: Canopy and Cold Weather (shipping) ?
Date: Jan 05, 2009
Getting ready to order my canopy kit (650 style for XL). Does anybody have any experiences or horror stories regarding shipment of that big plastic bubble in the winter? Does it stand up well to the rigors of being bounced around on trucks & loading docks during the winter? I live in MN. Does anyone know the dimensions of the crate? Thanks, - Patrick -------- Patrick 601XL/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223026#223026 ________________________________________________________________________________
Subject: Re: Canopy and Cold Weather (shipping) ?
Date: Jan 05, 2009
shipping damage,you mean like this? Zenith was great and sent replacements for all the broken stuff as the shipping Co was at fault.. drove a forklift through the ends. Chris. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223068#223068 Attachments: http://forums.matronics.com//files/shipping_crate_649.jpg ________________________________________________________________________________
Subject: Re: W&B 601XL
Date: Jan 06, 2009
May also be worthwhile to know where people are mounting heavy items, like BRS & batteries. - Pat -------- Patrick 601XL/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223134#223134 ________________________________________________________________________________
Subject: Corvair College # 13
Date: Jan 06, 2009
Corvair College # 13 is now less than 2 weeks away! For those of you that are in the Washington area, who are flying down commercial and are some what less than interested in trying to "carry on" your engine & parts; I am still willing to bring them down with me. There is no charge for this service, I am going that way anyway. :) I only say that because someone asked. :) you must however bring it to me before hand :) You can call me @ 1-866-606-4152 Or see my website for an address I will be busy in the shop so If I don't answer just leave a message & I will return your call during a break. -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223177#223177 ________________________________________________________________________________
Subject: Ground vibration testing
Date: Jan 06, 2009
According to an article in the latest Kitplanes, the German government requires ground vibration testing (GVT) before they will approve flight of kits built in aircraft in Germany. Assuming this to be true, it would suggest that the Czech version of the 601 has had GVT done. Does anyone know it this might also have been performed on the US version? My interest stems from resonance being a possible reason for flutter and other failure modes. It does not sound as though Zenith has done GVT here. In fairness, GVT may be impacted by differences in the specifics of changes in different aircraft. However, it might be worthwhile to know if the basic aircraft has any problems in this area. ====================================================================== Jim B. Belcher BS, MS Physics, math, computer science A&P/IA General Radiotelephone Certificate Retired Aerospace Technical Manager ====================================================================== ________________________________________________________________________________
Date: Jan 06, 2009
Front fraking right?!?! I'd hate to be in the right seat if you ever had to deploy the chute. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223224#223224 ________________________________________________________________________________
Subject: Re: Ground vibration testing
Date: Jan 06, 2009
While it would be interesting to know what you are asking please keep in mind that the Yuba City report pretty much ruled out flutter in that accident. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223225#223225 ________________________________________________________________________________
Date: Jan 06, 2009
On Tuesday 06 January 2009 16:55, Gig Giacona wrote: > > While it would be interesting to know what you are asking please keep in > mind that the Yuba City report pretty much ruled out flutter in that > accident. True. But we may have more than one thing happening to cause accidents. I still wonder about maintenance of some of the aircraft. I have a lot of questions .... and very few answers. The Yuba City report seems to say the aircraft came apart in the air for reasons other than flutter, yet does not really establish what those reasons are. That may suggest the reasons are subtile, and not easily determined. ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Jan 06, 2009
It has already been tested and (as I recall) the pilot and passenger walked away. Picture attached. Was it Poland or the Czech Republic? -- Craig -----Original Message----- From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Gig Giacona Sent: Tuesday, January 06, 2009 3:54 PM Subject: Zenith601-List: Re: W&B 601XL Front fraking right?!?! I'd hate to be in the right seat if you ever had to deploy the chute. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223224#223224 ________________________________________________________________________________
Date: Jan 06, 2009
I believe it was Minnesota. See: http://brsparachutes.com/files/Documents/Press%20Releases/PR%20Saves%20212-213.pdf Terry >It has already been tested and (as I recall) the pilot and passenger walked >away. Picture attached. Was it Poland or the Czech Republic? > >-- Craig Terry Phillips ZBAGer ttp44~at~rkymtn.net Corvallis MT 601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons are done; working on the wings http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: Jan 06, 2009
Subject: Re: W&B 601XL--Whoops
I need to read further down. It was Hungary. Terry >Date: Tue, 06 Jan 2009 17:21:39 -0700 >To: zenith601-list(at)matronics.com >From: Terry Phillips <ttp44(at)rkymtn.net> >Subject: RE: Zenith601-List: Re: W&B 601XL > >I believe it was Minnesota. See: > >http://brsparachutes.com/files/Documents/Press%20Releases/PR%20Saves%20212-213.pdf > >Terry > > >>It has already been tested and (as I recall) the pilot and passenger walked >>away. Picture attached. Was it Poland or the Czech Republic? >> >>-- Craig > > >Terry Phillips ZBAGer >ttp44~at~rkymtn.net >Corvallis MT >601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons >are done; working on the wings >http://www.mykitlog.com/N47TP/ Terry Phillips ZBAGer ttp44~at~rkymtn.net Corvallis MT 601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons are done; working on the wings http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Subject: Re: 601XL chute survival
Date: Jan 06, 2009
I think it may have been housed just aft of the firewall on the right side. A recent post by Mathieu Heintz indicated that they were putting it there on European XLs. The photo seems to show some rumpled skin in that area. Doug Sire -------- Doug Sire 601XL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223244#223244 ________________________________________________________________________________
Date: Jan 06, 2009
We may...no strike that...We probably won't ever ever know what happens right before the wings come off unless somebody just happens to have their EFIS recording data or a camera running in the cockpit when an accident happens. There is another scenario where we could find out what happens. A pilot with a BRS. The problem with even that is that the pilot in question would have every reason in the world to lie if they had been doing something that rips the wings off. The Yuba City report goes out of its way to NOT rule out the aircraft was over stressed. There are several ways that can happen and not all of them are the pilots fault. That's what I always thought it was and no supportable data has ever been released that counters that position. Is the 601XL as strong as Cessna 172? No but neither is a motorcycle as strong as a Hummer. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223269#223269 ________________________________________________________________________________
Date: Jan 06, 2009
Terry Phillips wrote: > I believe it was Minnesota. Well they talk funny there too. That is amazing. I can't put a screw in the canopy without causing a crack yet this one can have a rocket go off inches away and not damage it. Look at the gear on that thing. It pulled MANY G's on impact and yet the wings stayed on. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223272#223272 ________________________________________________________________________________
Date: Jan 07, 2009
If anybody is interested in where the CZAW and european ULM versions have their BRS installed, have a look at the ULM-drawings (6-UL-5). I am not sure if the 600kg BRS-version would fit right behind the firewall? The ULM version only needs the lighter 450kg parachute. Martin -------- Martin Pohl Zodiac XL QBK 8645 Jona, Switzerland www.pohltec.ch/ZodiacXL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223301#223301 Attachments: http://forums.matronics.com//files/zenair_ulm_supplement_22_pages_111.pdf ________________________________________________________________________________
Date: Jan 07, 2009
yeah, but the most impressive was the French XL Clone. 2009/1/7 Terry Phillips > > I need to read further down. It was Hungary. > > Terry > > Date: Tue, 06 Jan 2009 17:21:39 -0700 >> To: zenith601-list(at)matronics.com >> From: Terry Phillips <ttp44(at)rkymtn.net> >> Subject: RE: Zenith601-List: Re: W&B 601XL >> >> I believe it was Minnesota. See: >> >> >> http://brsparachutes.com/files/Documents/Press%20Releases/PR%20Saves%20212-213.pdf >> >> Terry >> >> >> >>> It has already been tested and (as I recall) the pilot and passenger >>> walked >>> away. Picture attached. Was it Poland or the Czech Republic? >>> >>> -- Craig >>> >> >> >> Terry Phillips ZBAGer >> ttp44~at~rkymtn.net >> Corvallis MT >> 601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons >> are done; working on the wings >> http://www.mykitlog.com/N47TP/ >> > > > Terry Phillips ZBAGer > ttp44~at~rkymtn.net > Corvallis MT > 601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons > are done; working on the wings > http://www.mykitlog.com/N47TP/ > > -- Alberto Martin www.iberplanes.es Igualada - Barcelona - Spain ---------------------------------------------- Zodiac 601 XL Builder Serial: 6-7011 Tail Kit: Finished Wings: Not Started Fuselage: Ordered Engine: Jabiru 3300 ________________________________________________________________________________
Date: Jan 07, 2009
Hey Patrick. If you are worried about how well the canopy is packed and if it can handle the bouncing of the shipment, take a look at the picture I have attached. I just picked up my fuselage and canopy kit for my 650. I hauled it in a single axle trailer. As a former truck driver, I can assure you, my trailer bounces a ton more than any semi truck does. The crate is so well packaged, the canopy sits on a mountain of paper and is encased with more paper. If you are just now getting ready to order your canopy, it might be warmer weather before you see it. I converted my 601 to the 650 just after it came out at Oshkosh. I just NOW got my order. Hope you get yours faster than I got mine! -------- Larry Hursh (N650LM Reserved) CH601XL (Conversion to CH650) Starting fuselage will be Corvair Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223330#223330 Attachments: http://forums.matronics.com//files/dscn1255_206.jpg ________________________________________________________________________________
Subject: Received my 650 plans!!
Date: Jan 07, 2009
Christmas present a little later than the 25th but I am ecstatic. Received the plans yesterday. Building will be at a fairly slow pace as I am regularly out of town. Now I feel much more a part of this list!! Mike Port Elizabeth South Africa Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223375#223375 ________________________________________________________________________________
Subject: parts location
Date: Jan 07, 2009
One of the problems I continually have is finding the parts in all the packing. This time, it's the 6W6-11 aileron bellcrank supports. Does anyone recall where these may have been packed in their kit? If I haven't located them today, my inclination is to simply order a second set, since they will soon delay my progress. -- ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Subject: Re: Received my 650 plans!!
Date: Jan 07, 2009
Congratulations Mike, good luck with the build. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223394#223394 ________________________________________________________________________________
Date: Jan 07, 2009
Mine was in the box with the ribs. Ron -------- Original Message -------- Subject: Zenith601-List: parts location From: Jim Belcher <z601(at)anemicaardvark.com> Date: Wed, January 07, 2009 12:44 pm One of the problems I continually have is finding the parts in all the packing. This time, it's the 6W6-11 aileron bellcrank supports. Does anyone recall where these may have been packed in their kit? If I haven't located them today, my inclination is to simply order a second set, since they will soon delay my progress. -- ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Subject: WARNING Tom Henderson
Date: Jan 07, 2009
Hi In Dec 2007 I purchased a partial 601XL kit From a man named Tom Henderson McMinnville Or. At first he sent a few parts which were high quality but then he quit sending any thing and wont answer E-Mails or return calls It has now been 13 months So every one should steer clear of this man because he will take your money and never deliver the parts Don 601XL Nc. ----- Original Message ----- From: "Ron Lendon" <rlendon(at)comcast.net> Sent: Tuesday, December 30, 2008 10:04 PM Subject: Zenith601-List: Re: Yuba City Probable cause released > > I found it here: > > http://www.ntsb.gov/ntsb/GenPDF.asp?id=LAX07FA026&rpt=fi > > and the most interesting thing is at the end. > > REASON FOR OCCURRENCE UNDETERMINED > > Let's try to keep that in mind. > > -------- > Ron Lendon, Clinton Township, MI > WW Corvair with Roy's Garage 5th bearing > Zodiac XL, ScrapBuilder ;-) > http://www.mykitlog.com/rlendon > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=221871#221871 > > > ________________________________________________________________________________
Subject: Re: WARNING Tom Henderson
Date: Jan 07, 2009
I hate hearing about anyone getting ripped off. Have you contacted the authorities? If it crossed state lines it was a federal offense. If the mail was used in any way the postal inspectors love this sort of thing. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223461#223461 ________________________________________________________________________________
Date: Jan 07, 2009
check the archives there is a lot about this guy. Jeff Garrett Louisville Ky. 601XL N962T Aerolite Corvair 90% 601XL N524B Aerolite Corvair 155 Hrs 601XL N2257 Aerolite Corvair 225 Hrs _www.aeroliteproducts.com_ (http://www.aeroliteproducts.com/) _www.project601xl.com_ (http://www.project601xl.com/) _www.aerolite.camstreams.com_ (http://www.aerolite.camstreams.com/) Do not archive **************New year...new news. Be the first to know what is making ________________________________________________________________________________
Date: Jan 07, 2009
Martin Pohl wrote: > I am not sure if the 600kg BRS-version would fit right behind the firewall? I'm considering mounting a BRS-1350 between the firewall and the instrument panel of my 601XL with 650 canopy. Here's pictures: http://picasaweb.google.com/Patrick.Hoyt/BRS# When using the 650 canopy on the XL, I believe that the usual baggage compartment location is no longer possible due to the 650 canopy covering what previously would have been the frangible cover installed in a cutout of top skin. It may be possible to mount the BRS behind the baggage compartment bulkhead, but that would move the CG further much aft. The challenge with putting the BRS up front is that it will displace depth behind the panel, which will limit what can be put in the panel on the passenger's side. To partially mitigate this, I fabricated a pan that allows the BRS to sit lower. I plan to "fine tune" my CG with appropriate placement of the battery. I'm interested in what other people are doing, particularly those who are installing BRS's on 650's or XL's with 650 canopies. - Pat -------- Patrick 601XL/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223481#223481 ________________________________________________________________________________
Date: Jan 07, 2009
Subject: Re: parts location
(Cant remember who posted, sorry) - It is important to double check all the packing with your Kit,- before se nd it to the garbage... I am shure you will find everything sooner or later . - In our city we have already built 4- CH 701 kits-and I am now about hal f way building-a 601 XL- kit- and I can say with truth, that nothing of this five kits parts were missing, not even a washer.- Just one or two -parts did not had the paper label, but where easy to identify with the p lans. - Just our personal experience, some other local builder of kits-for difere nt airplanes, cant say the same.- - Here in Mexico. like for all-other builder in countries around the world, is very important, because the shipping and import taxes are expensive and paperwork is HUGE.- No Custom Agent will accept that the missing shipped parts (sent later) have already paid their share, to dificult to explain a nd impossible proof. - Saludos Gary Gower Buiding in Guadalajara, Mexico Flying in Chapala. Mexico. - - --- On Wed, 1/7/09, chris Sinfield wrote: From: chris Sinfield <chris_sinfield(at)yahoo.com.au> Subject: Zenith601-List: Re: parts location Date: Wednesday, January 7, 2009, 4:24 PM they were wrapped in brown paper, loose in the shipping box ? both taped together Chris =0A=0A=0A ________________________________________________________________________________
Subject: Tire Pressure
Date: Jan 07, 2009
What tire pressures are recommended for the standard Zenith issue Condor tires ?? Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223493#223493 ________________________________________________________________________________
Subject: Re: Tire Pressure
Date: Jan 08, 2009
According to page 6 of 6-G in the construction manual 50psi. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223510#223510 ________________________________________________________________________________
Date: Jan 08, 2009
Per the AMD Zodiac 601XL POH for 500x5 4 ply tires the T.P. is 30 psig. You can get the AMD XL POH on the Zenith web site. Tony Graziano ----- Original Message ----- From: "Thruster87" <alania(at)optusnet.com.au> Sent: Wednesday, January 07, 2009 11:39 PM Subject: Zenith601-List: Tire Pressure > > > What tire pressures are recommended for the standard Zenith issue Condor > tires ?? Thanks > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=223493#223493 > > > ________________________________________________________________________________
Date: Jan 08, 2009
On Wednesday 07 January 2009 23:02, Gary Gower wrote: > (Cant remember who posted, sorry) > > It is important to double check all the packing with your Kit, before send > it to the garbage... I am shure you will find everything sooner or later. > In our city we have already built 4 CH 701 kitsand I am now about half > way buildinga 601 XL kit and I can say with truth, that nothing of this > five kits parts were missing, not even a washer. Just one or twoparts did > not had the paper label, but where easy to identify with the plans. > Just our personal experience, some other local builder of kitsfor diferent > airplanes, cant say the same. > Here in Mexico. like for allother builder in countries around the world, > is very important, because the shipping and import taxes are expensive and > paperwork is HUGE. No Custom Agent will accept that the missing shipped > parts (sent later) have already paid their share, to dificult to explain > and impossible proof. > Saludos I've gone through the packing as I disposed of it. There simply isn't room to unpack everything and inventory it at the start, which is what I had hoped to do. I've gone through it several times, and checked the locations just suggested by others on the list. I don't doubt the parts are there .... somewhere. The problem is, I don't know where. I would fault Zenith for not having a standardized location for parts in the packing, so that one always looks for things in the same place. That place should be on the inventory list they create, IMHO. But as far as shorting me parts, I have no reason at present to suggest Zenith has done anything like that. They seem honest, and above board. But in my case, I've already spent 2+ hours looking for 4 parts worth a total $16. For me, I can't imagine a scenario in which it wouldn't be cheaper and quicker to replace the parts. When the others turn up later, I can either use them on the next project, or offer them to someone else with the same problem. Shipping by anything other than FEDEX, UPS, or USPS is a large problem here in far west Texas. It's 150 miles to a freight dock. However, at least I'm not paying import duties or customs fees. -- ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Jan 08, 2009
tonyplane(at)bellsouth.ne wrote: > Per the AMD Zodiac 601XL POH for 500x5 4 ply tires the T.P. is 30 psig. > You can get the AMD XL POH on the Zenith web site. > > Tony Graziano > > --- That is correct for the 4 ply tires but according to the build manual the kit comes with 6 ply tires. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223545#223545 ________________________________________________________________________________
Date: Jan 08, 2009
Well Jim, there is one guaranteed way to find the parts. Order their replacement. :) -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223547#223547 ________________________________________________________________________________
Date: Jan 08, 2009
Jim; I had a couple of instances of not being able to find parts that were checked off on the Zenith check list. I called Zenith and they sent me the parts no charge. Give it a try. John Read CH701 - Elbert CO - Jabiru 3300 Phone: 303-648-3261 Fax: 303-648-3262 Cell: 719-494-4567 In a message dated 1/8/2009 8:57:35 A.M. Mountain Standard Time, z601(at)anemicaardvark.com writes: --> Zenith601-List message posted by: Jim Belcher On Wednesday 07 January 2009 23:02, Gary Gower wrote: > (Cant remember who posted, sorry) > > It is important to double check all the packing with your Kit, before send > it to the garbage... I am shure you will find everything sooner or later. > In our city we have already built 4 CH 701 kits and I am now about half > way building a 601 XL kit and I can say with truth, that nothing of this > five kits parts were missing, not even a washer. Just one or two parts did > not had the paper label, but where easy to identify with the plans. > Just our personal experience, some other local builder of kits for diferent > airplanes, cant say the same. > Here in Mexico. like for all other builder in countries around the world, > is very important, because the shipping and import taxes are expensive and > paperwork is HUGE. No Custom Agent will accept that the missing shipped > parts (sent later) have already paid their share, to dificult to explain > and impossible proof. > Saludos I've gone through the packing as I disposed of it. There simply isn't room to unpack everything and inventory it at the start, which is what I had hoped to do. I've gone through it several times, and checked the locations just suggested by others on the list. I don't doubt the parts are there .... somewhere. The problem is, I don't know where. I would fault Zenith for not having a standardized location for parts in the packing, so that one always looks for things in the same place. That place should be on the inventory list they create, IMHO. But as far as shorting me parts, I have no reason at present to suggest Zenith has done anything like that. They seem honest, and above board. But in my case, I've already spent 2+ hours looking for 4 parts worth a total $16. For me, I can't imagine a scenario in which it wouldn't be cheaper and quicker to replace the parts. When the others turn up later, I can either use them on the next project, or offer them to someone else with the same problem. Shipping by anything other than FEDEX, UPS, or USPS is a large problem here in far west Texas. It's 150 miles to a freight dock. However, at least I'm not paying import duties or customs fees. -- ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ **************New year...new news. Be the first to know what is making headlines. (http://news.aol.com?ncid=emlcntusnews00000002) ________________________________________________________________________________
Date: Jan 08, 2009
AMD says 30 psi.? ZAC says 50 psi.? I split the difference and use 40 psi. Jay in Dallas -----Original Message----- From: T. Graziano <tonyplane(at)bellsouth.net> Sent: Thu, 8 Jan 2009 9:03 am Subject: Re: Zenith601-List: Tire Pressure ? Per the AMD Zodiac 601XL POH for 500x5 4 ply tires the T.P. is 30 psig. You can get the AMD XL POH on the Zenith web site.? ? Tony Graziano? ? ----- Original Message ----- From: "Thruster87" <alania(at)optusnet.com.au>? Sent: Wednesday, January 07, 2009 11:39 PM? Subject: Zenith601-List: Tire Pressure? ? > ? >? > What tire pressures are recommended for the standard Zenith issue Condor > tires ?? Thanks? >? >? >? >? > Read this topic online here:? >? > http://forums.matronics.com/viewtopic.php?p=223493#223493? >? >? >? >? >? >? >? >? >? > ? ? ? ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Subject: AMD Notification Letter
Date: Jan 08, 2009
This just came in from Mathieu Heintz: To all, Please see the latest AMD notification letter at: http://www.newplane.com/amd/CH2000_Service.html Or direct link at: http://www.newplane.com/amd/../Service_Letters_Bulletines/NOTICE%20January%207%202009.pdf It is an extended version of the recent ZAC posting. This Notification is very interesting as it raises the possibility of potential airworthness problems if the aircraft controls are not secured when the aircraft is parked in high winds. Regards Mathieu Heintz -------- Larry Winger Tustin, CA Plans building 601XL/650 with Corvair Control surfaces and wings complete Fuselage 85% complete www.mykitlog.com/lwinger Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223571#223571 ________________________________________________________________________________
Date: Jan 08, 2009
On Thursday 08 January 2009 10:36, Gig Giacona wrote: > > Well Jim, there is one guaranteed way to find the parts. Order their > replacement. :) It works that way at your house too? -- ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Jan 08, 2009
alex_001 wrote: > have a look Thanks for sharing those, Alex. - Pat -------- Patrick 601XL/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223581#223581 ________________________________________________________________________________
Date: Jan 08, 2009
Subject: 601 Builders... some advice please..
Okay 601 builders, would you please throw a lifeline to this poor 601 pilot who has never pulled a rivet in his life. I fly an AMD-Made 601XL that is over two years old and has about 200 trouble-free hours. This notification letter from AMD, http://www.newplane.com/amd/../Service_Letters_Bulletines/NOTICE%20January%207%202009.pdf <http://www.newplane.com/amd/../Service_Letters_Bulletines/NOTICE%20January%207%202009.pdf>says that somebody, I guess an A&P in my case, should install "gussets" on each aileron. My quite uninformed question is... does this mean that someone (my A&P) has to tear each aileron apart, fabricate the plates from aluminum of the designated quality, rivet them in, and then return the skin to its previous pristine form? - Will the skin fit? - How difficult is this in terms of "hours" an A&P might charge? - What other questions should I ask? I don't know what I do not know., -- Frank Derfler, Islamorada, FL -- Twitter! Follow me at http://Twitter.com/Fderfler See my new Novel, "A Glint in Time" at http://GreatGuyBooks.com. See my discussion of All the Guy Toys that aren't (clearly) illegal or (blatantly) immoral at http://mostlyflying.com Anybody who READS (anybody out there?) See www.greatguybooks.com ________________________________________________________________________________
Date: Jan 08, 2009
Thank you all .I friend runs his Cessna 150 at 30psi nose and 28psi mains. So 30psi should be in the ball park Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223592#223592 ________________________________________________________________________________
Subject: Re: 601 Builders... some advice please..
Date: Jan 08, 2009
I just did that mode [very quick and easy as you only need to remove a few rivets around both areas]and it took about a 1 hrs work.Keeping in mind I'm still in the building process and the aileron was not painted or installed. Cheers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223595#223595 ________________________________________________________________________________
Subject: Flap Control Tuibes
Date: Jan 09, 2009
Hi Guys, I am presently fitting the flap motor and control tubes. What is the angle of the flap control tube (6B19-1 and 2) relative to the flap control arm (6B19-3)? I need to drill the holes for the bolts that hold all three pieces together. I don't have the wings built yet so is it worth waiting until the wings and flaps are in place before drilling anything? Cheers Peter 601 XL Wonthaggi Australia http://zodiac.cpc-world.com ________________________________________________________________________________
Date: Jan 08, 2009
Jay, ZAC says air to 2/3 rim above ground for the HD and HDS. (2/3 tire rim distance to outside of tire) Of course that is 1200 lb gross vs 1320 for the XL. On my HDS I found 2/3 to be 18 psi. OK for unimproved runway, I guess. I find 25 psi is just right. 50 psi seems a bit overpressure to me. -- Leo Gates N601Z - CH601HDS TDO Rotax 912UL jaybannist(at)cs.com wrote: > AMD says 30 psi. ZAC says 50 psi. I split the difference and use 40 psi. > > Jay in Dallas > > > -----Original Message----- > From: T. Graziano <tonyplane(at)bellsouth.net> > To: zenith601-list(at)matronics.com > Sent: Thu, 8 Jan 2009 9:03 am > Subject: Re: Zenith601-List: Tire Pressure > > > > > Per the AMD Zodiac 601XL POH for 500x5 4 ply tires the T.P. is 30 > psig. You can get the AMD XL POH on the Zenith web site. > > Tony Graziano > > ----- Original Message ----- From: "Thruster87" > > > To: > > Sent: Wednesday, January 07, 2009 11:39 PM > Subject: Zenith601-List: Tire Pressure > > > > > > > What tire pressures are recommended for the standard Zenith issue > Condor > tires ?? Thanks > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=223493#223493 > > > > ________________________________________________________________________________
Date: Jan 08, 2009
Subject: Re: Flap Control Tuibes
Peter, Yes, Zenith says you should wait until you have your wings mounted and flaps installed before drilling your flap tube to get it all aligned first- so I am waiting to drill mine. David Coberly ________________________________________________________________________________
Date: Jan 09, 2009
On Thursday 08 January 2009 18:37, Ronald Steele wrote: > > I'm going to go in a complete different direction here. Sooner or > later you are going to end up with a sheet metal bending break. It's > one of those thing that most builders are going to need sooner or > later. It may be for fabricating parts for your panel, fire wall > forward stuff, or as in my case to remake parts you screwed up. > > I don't know what your are missing besides the bell crank support, but > if doesn't look too complicated, you should think about getting a > small cheap break. A break is under $100 and will let you fabricate a > lot of parts, including the bell crank support in a few minutes. I'm > a worry wart, always thinking I'm going to miss drill a hole and > knowing I can make a new part quickly is a real stress reliever. > > So, my suggestion is a couple of 2/4ft sheets of 6061-t6 from ACS and > a cheap break. This is one of those coincidences that's somewhat amusing, Ron. I've had a small ~4' sheet metal brake for over a year, just for this reason. And, by chance, I'd ordered a couple of sheets of aluminum from Aircraft Spruce yesterday. Had I been thinking clearly (which I obviously wasn't), I'd also have ordered some 1/8" aluminum to do the bellcrank supports. This whole thing is coming at a time that I'm getting over a sequence of colds, so I'm focusing more on getting ready than actual fabrication. I, too, am something of a worry wart, although I prefer to think of it as planning ahead. Obviously, I think your advice is good. :-) -- ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Jan 09, 2009
Hi Jim I think that your attitude is right on Re fab'ing your own bell crank supports. However, I'm afraid that your brake won't do you any good, because there is nothing to bend. The supports, 6W6-11, are made from 1" x 1.5" x .125" 6061-T6 angle extrusion. All you need to do is to buy the extrusion, and then cut it to length then cut the corners off. Regarding finding the parts, the parts in the kit are just two pieces of the angle extrusion, cut to 55-mm length. They won't look like the drawing in 6W6 until you cut the corners off and drill the holes. Good luck with your build. Terry >This is one of those coincidences that's somewhat amusing, Ron. I've had a >small ~4' sheet metal brake for over a year, just for this reason. And, by >chance, I'd ordered a couple of sheets of aluminum from Aircraft Spruce >yesterday. > >Had I been thinking clearly (which I obviously wasn't), I'd also have ordered >some 1/8" aluminum to do the bellcrank supports. This whole thing is coming >at a time that I'm getting over a sequence of colds, so I'm focusing more on >getting ready than actual fabrication. > >I, too, am something of a worry wart, although I prefer to think of it as >planning ahead. Obviously, I think your advice is good. :-) Terry Phillips ZBAGer ttp44~at~rkymtn.net Corvallis MT 601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons are done; working on the wings http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: Jan 09, 2009
rsteele(at)rjsit.com wrote: > Sooner or later you are going to end up with a sheet metal bending break. I think a lot of us who started as kit builders ended up as scratch builders... - Pat -------- Patrick 601XL/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223766#223766 ________________________________________________________________________________
Date: Jan 09, 2009
On Friday 09 January 2009 15:00, Terry Phillips wrote: > > Hi Jim > > I think that your attitude is right on Re fab'ing your own bell crank > supports. However, I'm afraid that your brake won't do you any good, > because there is nothing to bend. The supports, 6W6-11, are made from 1" x > 1.5" x .125" 6061-T6 angle extrusion. All you need to do is to buy the > extrusion, and then cut it to length then cut the corners off. Regarding > finding the parts, the parts in the kit are just two pieces of the angle > extrusion, cut to 55-mm length. They won't look like the drawing in 6W6 > until you cut the corners off and drill the holes. Actually, that might have been easier for me to do than a brake job. I hate standoff distances, etc with a passion. I can calculate them, but I just don't have the flair to get them to turn out on first try, and usually waste a fair amount of aluminum. I can't claim lack of experience - I think the first time I used a brake was around 1965. The fact that I didn't notice that they were cut from extrusion is further evidence I'm not feeling all that well. It's a good thing I didn't start to fab them! ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Jan 09, 2009
Subject: In-flight opening of front hinged canopy
Hi everyone. While browsing the NTSB website today, I saw an accident repor t (see below) that might be of interest to all aircraft owners that have- front hinged canopies on the airplanes. This matter was discussed on this s ite a few months ago and-and there were several suggestion for devices th at would either lock the canopy down, or prevent it from opening in flight more than a few inches. It appears that the-shape of the canopy is acting as a lifting devise (like the wing), causing it to lift into the windstrea m, resulting in-unacceptable drag and subsequent control problems.-A si mple locking devide or restraining cable will alleviate this potential prob lem. Walt in Dayton.--- - - - - NTSB Identification: WPR09LA075 14 CFR Part 91: General Aviation Accident occurred Tuesday, January 06, 2009 in Casa Grande, AZ Aircraft: Czech Aircraft Works Sport Cruiser, registration: N797BS Injuries: 1 Uninjured. This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed. On January 6, 2009, at 1600 mountain standard time, a Czech Aircraft Works Sport Cruiser, N797BS, made an emergency off field landing after the cockpi t canopy popped opened in flight at Casa Grande Municipal Airport, Casa Gra nde, Arizona. The sport pilot operated the airplane under the provisions of Title 14 Code of Federal Regulations, Part 91. The pilot was not injured, and the airplane was substantially damaged. Visual meteorological condition s prevailed, and no flight plan had been filed. The flight originated at Ca sa Grande about 1600. The pilot reported to the Safety Board investigator that the canopy popped open shortly after takeoff, around 500 feet agl. The canopy is hinged in fr ont of the cockpit and rotates upward when open. The pilot said he tried to keep the canopy closed with his free hand but the canopy continued to rise higher and higher. The pilot turned back to the airport and made an off fi eld landing next to the airport wind sock. - End of report. ________________________________________________________________________________
Subject: Re: In-flight opening of front hinged canopy
Date: Jan 09, 2009
Walter, I had the same thing happen in an AMD 601XLi, except that we were at cruise speed, about 1500' AGL.? The nose went down 60 deg.? I was able to break the dive, but could never get the nose up to level.? We hit the ground about 10 deg nose down.? When I was able to work again on my XL, the first thing I did was to install a canopy safety tether.? Drawing attached. ?The accident airplane had the new 650 style canopy latch.? My airplane has the old style latches. Jay in Dallas -----Original Message----- From: Walter Carey <careywf(at)sbcglobal.net> Sent: Fri, 9 Jan 2009 7:47 pm Subject: Zenith601-List: In-flight opening of front hinged canopy Hi everyone. While browsing the NTSB website today, I saw an accident report (see below) that might be of interest to all aircraft owners that have?front hinged canopies on the airplanes. This matter was discussed on this site a few months ago and?and there were several suggestion for devices that would either lock the canopy down, or prevent it from opening in flight more than a few inches. It appears that the?shape of the canopy is acting as a lifting devise (like the wing), causing it to lift into the windstream, resulting in?unacceptable drag and subsequent control problems.?A simple locking devide or restraining cable will alleviate this potential problem. Walt in Dayton.??? ? ? ? ? NTSB Identification: WPR09LA075 14 CFR Part 91: General Aviation Accident occurred Tuesday, January 06, 2009 in Casa Grande, AZ Aircraft: Czech Aircraft Works Sport Cruiser, registration: N797BS Injuries: 1 Uninjured. This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed. On January 6, 2009, at 1600 mountain standard time, a Czech Aircraft Works Sport Cruiser, N797BS, made an emergency off field landing after the cockpit canopy popped opened in flight at Casa Grande Municipal Airport, Casa Grande, Arizona. The sport pilot operated the airplane under the provisions of Title 14 Code of Federal Regulations, Part 91. The pilot was not injured, and the airplane was substantially damaged. Visual meteorological conditions prevailed, and no flight plan had been filed. The flight originated at Casa Grande about 1600. The pilot reported to the Safety Board investigator that the canopy popped open shortly after takeoff, around 500 feet agl. The canopy is hinged in front of the cockpit and rotates upward when open. The pilot said he tried to keep the canopy closed with his free hand but the canopy continued to rise higher and higher. The pilot turned back to the airport and made an off field landing next to the airport wind sock. ? End of report. ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: Jan 09, 2009
> When I was able to work again on my XL, How are you doing these days, anyway? -- Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml ________________________________________________________________________________
Date: Jan 09, 2009
Jay, I am walking nearly normally, but the foot and ankle are still a little swollen and painful at times.? The ribs only bother me at night.? My eye damage is still troublesome and might not return to normal.? I'd say that I'm about 95% and doing about whatever I want to do. Thanks for asking - Jay B. -----Original Message----- From: Jay Maynard <jmaynard(at)conmicro.com> Sent: Fri, 9 Jan 2009 8:30 pm Subject: Re: Zenith601-List: In-flight opening of front hinged canopy > When I was able to work again on my XL, How are you doing these days, anyway? -- Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Subject: Re: XL wing concerns
Date: Jan 10, 2009
Darryl, I have the same problem with Sabrina's and occasionally other posts that are blank. I emailed Matt Dralle about it once but didn't get any reply. I'm reading these posts from the web forum, and not via email. Once in a while Sabrina posts something that I can read, but 95% of her posts are blank. It's obvious others are reading them because they post replies to her's. Dan Dempsey Darryl Legg wrote: > why is it that I can't read Sabrina's posts? Have tried IE and Mozilla browsers. weird. > Darryl > -------- Scratch building XL with Corvair Engine Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223834#223834 ________________________________________________________________________________
Date: Jan 10, 2009
Thanks Dan, Like you I can't see anything, but obviously others can. Can anyone help? Darryl. :? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223842#223842 ________________________________________________________________________________
Date: Jan 10, 2009
My comments are for those who are concerned, not just the casual reader or someone surfing the Internet in the future. Zenith, Zenair, FAA, NTSB, LAA people and countless builders subscribe to the list and receive all our posts via e-mail. (Even Jim Irwin subscribes!) So join and subscribe, don't just be a guest or a passive member. So... I finished intersession week, met with a top Fermi Lab physicist for dinner last night along with a King Air owner/pilot and we had an interesting discussion about the slight forward sweep of the wings in cruise attitude.... as far as loosing parts, the aileron bell crank mount is one item you might not mind loosing-- I redesigned it using Aircraft Spruce parts... and Gig is correct, order the replacement and the original magically reappears... (nose gear stop plate in my case.) As to the bell crank, I changed the geometry, beefed up the rib, raised and shrunk the hole in the rear spar. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223873#223873 ________________________________________________________________________________
Date: Jan 10, 2009
On Saturday 10 January 2009 11:18, Sabrina wrote: > as far as loosing parts, the aileron bell crank mount is one item you might > not mind loosing-- I redesigned it using Aircraft Spruce parts... and Gig > is correct, order the replacement and the original magically reappears... > (nose gear stop plate in my case.) As to the bell crank, I changed the > geometry, beefed up the rib, raised and shrunk the hole in the rear spar. Would you be interested in sharing the reasoning behind your changes, and what the specific changes were? I'm not a structures guy, but the bellcrank looks beefy in comparison to that mount, and the reinforcement added to the rib. -- ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Jan 10, 2009
Hi Sabrina, I am a member, and subscribe, and still don't see why any-ones post can't be viewed. Please tell. Darryl. :? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223881#223881 ________________________________________________________________________________
Date: Jan 10, 2009
Jim, no problem, just join the list so I can PM you... :o) it us not the beef of the bellcrank as much as the geometry... the beef of the rib and rear spar is another question... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223882#223882 ________________________________________________________________________________
Date: Jan 10, 2009
Hi Sabrina, I receive daily digests via e-mail and browse the forums occasionally, just today noticing that your posts were blank. In fact, your post changed on the forum just now, did you edit it? Very strange mate! Darryl. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223886#223886 ________________________________________________________________________________
Date: Jan 10, 2009
Once Elden posted why keep the original? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223888#223888 ________________________________________________________________________________
Date: Jan 10, 2009
You lost me on this one. --- On Sun, 1/11/09, Sabrina wrote: From: Sabrina <chicago2paris(at)msn.com> Subject: Zenith601-List: Re: XL wing concerns Date: Sunday, January 11, 2009, 2:23 AM Once Elden posted why keep the original? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223888#223888 ________________________________________________________________________________
Date: Jan 10, 2009
Why not ???? 2009/1/10 Sabrina > > Once Elden posted why keep the original? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=223888#223888 > > ________________________________________________________________________________
Date: Jan 10, 2009
Jim, Elden, Jay, Carlos, please join the list as a registered user... Jay, you can't change the subject line on a "mass-PM" only private PMs. The post you complain about was not on the list until you and other "guests" posted it. Those who subscribe have the context via the previous e-mails. The only way I can reach a "guest" and stay within the list is through this mass PM. Sorry. I know there are e-mails, but I receive hundreds of e-mails and 99% go to spam and never reach me. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223896#223896 ________________________________________________________________________________
Date: Jan 10, 2009
On Saturday 10 January 2009 13:21, Sabrina wrote: > > Jim, Elden, Jay, Carlos, please join the list as a registered user... Sabrina, as best as I can tell, I joined the list as a registered user last July. If I correctly understand how the list works, it won't forward email to me unless I am registered. I still have the email on file from Matt welcoming me. Having said that, when I go to the list of users, I find neither my name nor any of the psuedonyms I normally use. I'm going to email Matt and see if he can clarify my status. -- ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Jan 10, 2009
On Saturday 10 January 2009 13:32, jaybannist(at)cs.com wrote: > Sabrina, > > I am a card-carrying, registered member of this list (NOT a "guest"), and I > have no idea what a "PM" is, other than after noon, or what a "mass-PM" is. I think a "PM" is a personal message. What I suspect is, at least in my case, while I'm obviously a member, my name doesn't appear to be showing up in the list of members. It looks as thought that's necessary to send me a personal message with the information I requested. How the personal message mechanism works, I don't know, but I found "tags" allowing the sending of personal messages in the list of members. This sounds like a typical software glitch. It may be that you, Elden, Carlos and I for some reason don't show up in that list. Sign. I remind myself sometimes that I was once one of the young turks who wanted to computerize everything. Here we are, nearly 40 years later, and I got my wish. Payback is a bummer. -- ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Jan 10, 2009
Now that that is cleared up, does anyone want to talk airplane? XL Wing Concerns: First concern I remember having in early 2006 was the size and placement of the aileron push rod hole in the rear spar... I don't think anyone would place that large of a hole (compared to the height of the beam) that low in their floor joists... Comments... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223918#223918 ________________________________________________________________________________
Date: Jan 10, 2009
On Saturday 10 January 2009 15:28, Sabrina wrote: > Now that that is cleared up, does anyone want to talk airplane? I think the problem is more postponed than cleared up, but we can hope. > XL Wing Concerns: > > First concern I remember having in early 2006 was the size and placement of > the aileron push rod hole in the rear spar... > > I don't think anyone would place that large of a hole (compared to the > height of the beam) that low in their floor joists... > > Comments... Drawing 6W7, dated 01/08, shows a 38mm (dia) hole at station 1995, centered 20mm from the rear spar edge. Unless somebody has changed the rules of math, half of 38mm is 19mm, which would leave 1mm of rear spar material at the bottom. I find myself somewhat unwilling to cut a hole of this dimension at that location. I wonder if anyone actually did this.... -- ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Jan 10, 2009
If you are going to change the location, you have to give up leverage (repositioning the horn slightly) and/or align the bellcrank better... when you reposition the bellcrank, you shift the aileron cables and the bellcrank may bottom out on the rib's lightening holes. This may require a larger extruded angle to reposition the bellcrank further away from the rib. this repositions the aileron balance cable so it is not so close to 6B5-1, which I never liked... the second fairlead mounted to 6B5-1 should be a hint that something is amiss... see 6-B-22 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223923#223923 ________________________________________________________________________________
Date: Jan 10, 2009
On Saturday 10 January 2009 16:00, Sabrina wrote: > > If you are going to change the location, you have to give up leverage > (repositioning the horn slightly) and/or align the bellcrank better... > > when you reposition the bellcrank, you shift the aileron cables and the > bellcrank may bottom out on the rib's lightening holes. This may require a > larger extruded angle to reposition the bellcrank further away from the > rib. > > this repositions the aileron balance cable so it is not so close to 6B5-1, > which I never liked... the second fairlead mounted to 6B5-1 should be a > hint that something is amiss... see 6-B-22 This is disturbing. A reason for doing engineering is to find problems before metal is cut and things are assembled. This design has been in the field for several years, yet it does not appear this problem has been identified or resolved. If drawing 6W10 is to be believed, there is no reason to have the hole quite this low in the rear spar. Is there, once the metal is assembled, the potential to reduce the size of the hole? The real problem would appear to be the configuration of the control horn on the aileron. It might have been better structurallly to have the horn below the aileron, and to have a bent pushrod that exited through the lower aircraft skin. That would have required a slot in the skin, but I believe this could be done with less structural impact. That, however, would create slop in the pushrod motion, which is also undesirable. I don't think the pushrod, as it is presently designed, would work in this configuration. I haven't gotten to the point of checking the location of the aileron balance cable relative to 6B5-1. However, it looks like this part of the design dug a nice little hole, which the designer(s) then kludged the rest of this part of the control mechanism to fix. I also wonder about putting some reinforcement along the bottom of the rear spar, lapping the hole area. But it would still require moving the hole upwards some. That 1mm dimension isn't going to cut it in any approach I can imagine. Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Jan 10, 2009
Stavt slep specifikace Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223927#223927 ________________________________________________________________________________
Date: Jan 10, 2009
Like this: Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223929#223929 Attachments: http://forums.matronics.com//files/original_horn_471.jpg ________________________________________________________________________________
Date: Jan 10, 2009
Hi Jim First, I know of no evidence that suggests failure in the rear spar at this point. None-the-less, some folks have been concerned about this potential weakness. I have seen quickbuild spars that have the hole very close to the flange. See photo attached. Andy Elliott expressed concern about this issue some time ago and suggested a doubler for the bottom flange. See http://members.cox.net/n601ge/drawings/rearspar.html If you are concerned you might try Andy's idea. Terry >This is disturbing. A reason for doing engineering is to find problems >before >metal is cut and things are assembled. This design has been in the field for >several years, yet it does not appear this problem has been identified or >resolved. > >If drawing 6W10 is to be believed, there is no reason to have the hole quite >this low in the rear spar. Is there, once the metal is assembled, the >potential to reduce the size of the hole? > >The real problem would appear to be the configuration of the control horn on >the aileron. It might have been better structurallly to have the horn below >the aileron, and to have a bent pushrod that exited through the lower >aircraft skin. That would have required a slot in the skin, but I believe >this could be done with less structural impact. > >That, however, would create slop in the pushrod motion, which is also >undesirable. I don't think the pushrod, as it is presently designed, would >work in this configuration. > >I haven't gotten to the point of checking the location of the aileron balance >cable relative to 6B5-1. However, it looks like this part of the design dug a >nice little hole, which the designer(s) then kludged the rest of this part of >the control mechanism to fix. > >I also wonder about putting some reinforcement along the bottom of the rear >spar, lapping the hole area. But it would still require moving the hole >upwards some. That 1mm dimension isn't going to cut it in any approach I can >imagine. Terry Phillips ZBAGer ttp44~at~rkymtn.net Corvallis MT 601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons are done; working on the wings http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: Jan 10, 2009
I share your concern and was very careful making that hole, drilling a little undersized and then filing. However, look at where the hole is along the length of the spare. No where near the full strength of the spar is needed that far from the root. As long as you stay out of the flange I'm sure there is plenty of strength remaining. You just want to sure not to cut into the flange. As far as beams go, if the beam was cut this much at the end, which is pure shear and not in the middle, it wouldn't make any difference at all. Ever look a how a steel building is bolted together? The connector at the ends are always shallower than the beam being connected. Ron On Jan 10, 2009, at 4:28 PM, Sabrina wrote: > > > Now that that is cleared up, does anyone want to talk airplane? > > XL Wing Concerns: > > First concern I remember having in early 2006 was the size and > placement of the aileron push rod hole in the rear spar... > > I don't think anyone would place that large of a hole (compared to > the height of the beam) that low in their floor joists... > > Comments... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=223918#223918 > > ________________________________________________________________________________
Date: Jan 10, 2009
Jim, Are you saying that there was no engineering in the design of the 601XL?? The guy that designed the XL is a dedicated aeronautical engineer who has thousands of home built airplanes flying.? As far as I know, no home built XL has ever failed for unknown reasons.? XLs have flown many, many hours; and if built to the design and flown within the design parameters, there have been no problems.? It is when the design has not been followed and the airplane not flown within its intended regime that problems develop. I know you are a smart guy, but there is no way you can know everything that went into the engineering and design of the XL.? Smart builders rely on the "smarts" of the designer and build it the way it was designed. That's my OPINION and I'm sticking to it. ;>) Jay in Dallas -----Original Message----- From: Jim Belcher <z601(at)anemicaardvark.com> Sent: Sat, 10 Jan 2009 4:35 pm Subject: Re: Zenith601-List: Re: XL wing concerns This is disturbing. A reason for doing engineering is to find problems before metal is cut and things are assembled. This design has been in the field for several years, yet it does not appear this problem has been identified or resolved. If drawing 6W10 is to be believed, there is no reason to have the hole quite this low in the rear spar. Is there, once the metal is assembled, the potential to reduce the size of the hole? The real problem would appear to be the configuration of the control horn on the aileron. It might have been better structurallly to have the horn below the aileron, and to have a bent pushrod that exited through the lower aircraft skin. That would have required a slot in the skin, but I believe this could be done with less structural impact. That, however, would create slop in the pushrod motion, which is also undesirable. I don't think the pushrod, as it is presently designed, would work in this configuration. I haven't gotten to the point of checking the location of the aileron balance cable relative to 6B5-1. However, it looks like this part of the design dug a nice little hole, which the designer(s) then kludged the rest of this part of the control mechanism to fix. I also wonder about putting some reinforcement along the bottom of the rear spar, lapping the hole area. But it would still require moving the hole upwards some. That 1mm dimension isn't going to cut it in any approach I can imagine. Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: Jan 10, 2009
An ejector canopy could come in handy if the pilots do not have the skill to bring the aircraft down without injury. (At least three pilots have done it with the canopy unlatched.) So too, there are several reports of the XL flying well once a canopy departs, it appears to rise up and over the aircraft without damage. Even as is, the stay-open canopy would make it easier to get out with an emergency chute if a control/flying surface is ever flown/leveraged off the craft. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223931#223931 ________________________________________________________________________________
Date: Jan 10, 2009
On Saturday 10 January 2009 17:23, jaybannist(at)cs.com wrote: > Jim, > > Are you saying that there was no engineering in the design of the 601XL?? > The guy that designed the XL is a dedicated aeronautical engineer who has > thousands of home built airplanes flying.? As far as I know, no home built > XL has ever failed for unknown reasons.? XLs have flown many, many hours; > and if built to the design and flown within the design > parameters, there have been no problems.? It is when the design has not > been followed and the airplane not flown within its intended regime > that problems develop. I know you are a smart guy, but there is no way you > can know everything that went into the engineering and design of the XL.? > Smart builders rely on the "smarts" of the designer and build it the way it > was designed. > > That's my OPINION and I'm sticking to it. ;>) I do think the guy is a smart engineer, but I think even smart engineers can have oversights. I also know how easy it is to get something into a design, and keep changing other things later to acommodate an earlier decision. I'm not saying this is the cause of any failures. I'm saying this particular thing isn't very good design, no matter who did it. All of us make mistakes; Chris Heinz is no exception. I have a lot of confidence in the overall design, but that doesn't mean everything is perfect. -- ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Jan 10, 2009
Sabrina, I thoroughly resent the implication that I crashed because of a lack of skill when the canopy of the airplane I was flying came open.? The other pilot in the airplane was a CFII.? Surely he didn't lack adequate skill.? I firmly believe that our combined skill is the very reason that we are both alive today. You were not in that cockpit and have absolutely no basis for your crass comment and, again, I thoroughly resent it. You are definitely now on my sh..it list ! ! Jay in Dallas -----Original Message----- From: Sabrina <chicago2paris(at)msn.com> Sent: Sat, 10 Jan 2009 5:23 pm Subject: Zenith601-List: Re: In-flight opening of front hinged canopy An ejector canopy could come in handy if the pilots do not have the skill to bring the aircraft down without injury. (At least three pilots have done it with the canopy unlatched.) So too, there are several reports of the XL flying well once a canopy departs, it appears to rise up and over the aircraft without damage. ________________________________________________________________________ Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: Jan 10, 2009
It is when the design has not been followed and the airplane not flown within its intended regime that problems develop. I thoroughly resent the implication that I crashed because of a lack of skill when the canopy of the airplane I was flying came open. This was just sent to me I noticed that the right hand canopy latch had come loose and the rail was up about 2 inches. I pointed it out to Dennis. We were in sight of a private airfield, but Dennis decided he was going to re-latch it - in the air! In doing so, the latch on my side came loose and the canopy immediately shot up to about 50 deg., and the nose went down about 60 deg. I immediately pulled the power completely off. I am sorry Jay, but I dont see how opening a canopy in flight near an airport rather than landing immediately is a design flaw. As much as I would like to blame it on the AMD POH, I dont see anywhere where it calls for power completely off in that high drag situation. Please reconsider placing me on your special list. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223944#223944 ________________________________________________________________________________
Date: Jan 10, 2009
If I recall correctly from back then, others were adding a doubler about 18 " long to the spar to attempt to compensate for the poor location of the pa ssthrough. David L. Downey Harleysville-(SE) PA, USA --- On Sat, 1/10/09, Jim Belcher wrote: From: Jim Belcher <z601(at)anemicaardvark.com> Subject: Re: Zenith601-List: Re: XL wing concerns Date: Saturday, January 10, 2009, 4:42 PM On Saturday 10 January 2009 15:28, Sabrina wrote: > Now that that is cleared up, does anyone want to talk airplane? I think the problem is more postponed than cleared up, but we can hope. > XL Wing Concerns: > > First concern I remember having in early 2006 was the size and placement of > the aileron push rod hole in the rear spar... > > I don't think anyone would place that large of a hole (compared to the > height of the beam) that low in their floor joists... > > Comments... Drawing 6W7, dated 01/08, shows a 38mm (dia) hole at station 1995, centered 20mm from the rear spar edge. Unless somebody has changed the rules of math , half of 38mm is 19mm, which would leave 1mm of rear spar material at the bottom. I find myself somewhat unwilling to cut a hole of this dimension at that location. I wonder if anyone actually did this.... -- ==================== Those who can, do. Those who can't, sue. ======================= Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ======================= =0A=0A=0A ________________________________________________________________________________
Date: Jan 10, 2009
Paul, all... What do you think about an XL canopy that can be ejected? Is it needed? The mod costs less than $40 (two MS17985-414 quick release pins and one foot of 4130 square tubing) but the pair of goggles needed, just in case, cost about $30 each for a total of $100 and 14 ounces of added weight, total. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223955#223955 ________________________________________________________________________________
Date: Jan 10, 2009
> Monday morning quarterbacking is great!? At about pattern altitude, canopy > pops fully open, nose goes down 60+ degrees, 100 mph & increasing, headset > ripped off your head, cruise power,.? What would you do? *sigh* People, we need to remember, when disucssing these things, that people we know and consider friends have been right in the middle of the kinds of failures we're discussing, and refrain from casting aspersions on the abilities of folks who have been there and done that. We can and should learn from others' experiences...but we should not say we'd have done things differently in the heat of the moment - because there's just no way to know. Sometimes, what the book says we should do and what we think we will do as we're sitting in front of the computer don't correspond to what we actually wind up doing when the canopy comes open. As for me, I make certain to double check the security of the (in my case, new-style) canopy latch on both sides before taxi, and again before takeoff, as a result of Jay's accident. I've also given careful consideration to how I'll handle that occurrence. Even so, I'm not going to sit here and say that he screwed up. I suggest none of us are the position to do so. -- Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml ________________________________________________________________________________
From: "chris Sinfield" <chris_sinfield(at)yahoo.com.au>
Date: Jan 10, 2009
Sabrina and others, Whilst a good idea in concept the reality I think would not work for the following reasons: 1 would the canopy miss or take out the fin/ rudder? 2 would you be able to take your hands off the controlls that you are fighting to pull the lever/ pins? although more tseting would need to be carried out its not a bad Idea if we can work out the issues. Remember 2 things.. there are photos of the XL flying with the canopy open. So it will fly, given the right combination of factors( without the right combinations of Airspeed/ throttle/ angle of attack it wont fly and thats a fact .. So what are these combiations?? sounds like a summer research job for an up and comming Areo Engineer and test pilot and test plane ?? and if you are not any of these types, "dont try this at home " Chris Sydney Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223970#223970 ________________________________________________________________________________
Date: Jan 10, 2009
Jay, - -- Other than the 60 degree nose down after the canopy opened in flight , did the aircraft experience any other unusual-flight characteristics, i e: vibrations, shudder, excess g-forces, etc? Just wondering. Walt in Dayto n. --- On Fri, 1/9/09, jaybannist(at)cs.com wrote: From: jaybannist(at)cs.com <jaybannist(at)cs.com> Subject: Re: Zenith601-List: In-flight opening of front hinged canopy Date: Friday, January 9, 2009, 9:15 PM Walter, I had the same thing happen in an AMD 601XLi, except that we were at cruise speed, about 1500' AGL.- The nose went down 60 deg.- I was able to bre ak the dive, but could never get the nose up to level.- We hit the ground about 10 deg nose down.- When I was able to work again on my XL, the fir st thing I did was to install a canopy safety tether.- Drawing attached. -The accident airplane had the new 650 style canopy latch.- My airplane has the old style latches. Jay in Dallas -----Original Message----- From: Walter Carey <careywf(at)sbcglobal.net> Sent: Fri, 9 Jan 2009 7:47 pm Subject: Zenith601-List: In-flight opening of front hinged canopy Hi everyone. While browsing the NTSB website today, I saw an accident repor t (see below) that might be of interest to all aircraft owners that have- front hinged canopies on the airplanes. This matter was discussed on this s ite a few months ago and-and there were several suggestion for devices th at would either lock the canopy down, or prevent it from opening in flight more than a few inches. It appears that the-shape of the canopy is acting as a lifting devise (like the wing), causing it to lift into the windstrea m, resulting in-unacceptable drag and subsequent control problems.-A si mple locking devide or restraining cable will alleviate this potential prob lem. Walt in Dayton.--- - - - - NTSB Identification: WPR09LA075 14 CFR Part 91: General Aviation Accident occurred Tuesday, January 06, 2009 in Casa Grande, AZ Aircraft: Czech Aircraft Works Sport Cruiser, registration: N797BS Injuries: 1 Uninjured. This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed. On January 6, 2009, at 1600 mountain standard time, a Czech Aircraft Works Sport Cruiser, N797BS, made an emergency off field landing after the cockpi t canopy popped opened in flight at Casa Grande Municipal Airport, Casa Gra nde, Arizona. The sport pilot operated the airplane under the provisions of Title 14 Code of Federal Regulations, Part 91. The pilot was not injured, and the airplane was substantially damaged. Visual meteorological condition s prevailed, and no flight plan had been filed. The flight originated at Ca sa Grande about 1600. The pilot reported to the Safety Board investigator that the canopy popped open shortly after takeoff, around 500 feet agl. The canopy is hinged in fr ont of the cockpit and rotates upward when open. The pilot said he tried to keep the canopy closed with his free hand but the canopy continued to rise higher and higher. The pilot turned back to the airport and made an off fi eld landing next to the airport wind sock. - End of report. Email message sent from CompuServe - visit us today at http://www.cs.com ________________________________________________________________________________
Date: Jan 10, 2009
Paul, I always value your opinion... I never fly without a parachute, my 150 has ejector doors. The biggest concern is getting knocked out by the craft itself be it a canopy, strut or tail feathers. There was a recent NASA report issued on the need for self-deploying parachutes. Chris, you are correct... Not only would it be hard to explain why you ejected the canopy and then landed, but it was one of the hardest parts to build and that fact alone would freeze my hand as I reached for the pins. Hopefully that would not be the case with a test pilot or if the engine also failed. I don't believe it can fly with that much drag with a failed engine. This brings up the POH. Normally, when you have an emergency landing, every POH I have seen tells you to release the canopy or doors at some point just before landing/crashing. My POH does not recommend releasing the canopy because if it pops up, the aircraft could become uncontrollable without thrust. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223982#223982 Attachments: http://forums.matronics.com//files/9_137.jpg ________________________________________________________________________________
Date: Jan 10, 2009
...you had better be pretty sure that it will clear the horizontal and vert ical stabs once jetisoned... David L. Downey Harleysville-(SE) PA, USA --- On Sat, 1/10/09, Sabrina wrote: From: Sabrina <chicago2paris(at)msn.com> Subject: Zenith601-List: Re: In-flight opening of front hinged canopy Date: Saturday, January 10, 2009, 8:37 PM Paul, all... What do you think about an XL canopy that can be ejected? Is it needed? The mod costs less than $40 (two MS17985-414 quick release pins and one fo ot of 4130 square tubing) but the pair of goggles needed, just in case, cost about $30 each for a total of $100 and 14 ounces of added weight, total. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223955#223955 =0A=0A=0A ________________________________________________________________________________
Date: Jan 10, 2009
OK 2 things 1. by all means release the canopy prior to impact in an out landing BUT ONLY IF YOU HAVE A STRAP/ROPE STOPPING IT FROM RISING. Jay has a great design.. our XLs in Australia all have to have such a strap/ rope with sailing clete preventing it from rising more than 2 inches.. also helps to close the canopy when sitting in the plane, also a wind stopper with the canopy open on the ground. 2 the canopy is so thin that it can be broken with the hand, head if you have crashed. Make sure you are strapped in and your head set does not come close to the roof when in flight and in turbulence. (dont ask) I will add that due to Jays experience with the canopy open we have all become more aware now of what to do if it ever comes open on me. I owe you a beer for the newfound knowledge. Now for the person who had the canopy open and flying pictures, can he post the airspeed/ power settings?? AMD XL POH as 60 knots and about 1 foot raised how did they come up with this did they test this? why re invent the wheel if this is a tested statement?? Chris Sydney I have kept the older canopy latches as my POH says to fly and land not try to open the other latch. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223991#223991 ________________________________________________________________________________
Date: Jan 10, 2009
Subject: Re: In-flight opening of front hinged canopy.
Hello Sabrina, - I consider that ejectable canopy is a bad idea, I will try to explain it as short as possible,-- The ejected canopy can hit and serious damage, or destroy the Rudder!-- Even that is plexiglass, has lots of metal parts in the structure.- - Lets remember what happened to the door that-opened/loosed in a 701 recen tly.- The airplane almost loosed the stabilator... - All airplanes needs the empenage to keep them flying... At least the ZAC on es, I know Rogalos and Paraglaiders dont :-)- :-) - One thing I consider very important is Check List(s) in all airplanes,- ( I remember) from simple Hang Gliders (Are you hooked?), -to the Space Shu ttle pilots,- WE MUST go though-all of them, not just by memory. My Instructor was very Serious about this! (and with everything he teached me). - In all-airplanes that have canopies, doors, windows that can open (C-152 for example), baggage compartment lids, etc.- A very important point is t hat the pilot in command (Us) make sure that they are ALL perfectly closed before take off...- - In my 701, everytime I have a passenger I double check that his seat belt i s buckled and adjusted and the door latch is completly closed. I plan to do the same every take off with the 601 XL's canopy latch... (hope this year) . - Just my personal point of view.- - Saludos Gary Gower. A-Old Pilot friend of mine-told me when I just had my Pilot Licence:- "Fly every time the same as if your Instructor was in your right seat". --- On Sat, 1/10/09, Sabrina wrote: From: Sabrina <chicago2paris(at)msn.com> Subject: Zenith601-List: Re: In-flight opening of front hinged canopy Date: Saturday, January 10, 2009, 8:37 PM Paul, all... What do you think about an XL canopy that can be ejected? Is it needed? The mod costs less than $40 (two MS17985-414 quick release pins and one fo ot of 4130 square tubing) but the pair of goggles needed, just in case, cost about $30 each for a total of $100 and 14 ounces of added weight, total. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=223955#223955 =0A=0A=0A ________________________________________________________________________________
Date: Jan 10, 2009
Hello Jay M. - Just a very short comment: You are right,- Jay B and Pilot did the best t hing, they managed to land and are alive...- - One thing very important for ALL of us is to try to keep calm in any type o f personal emergency situation...- if Fear and Desparation are winning, C lear Mind is loosing... Easy to-say but hard to do in "that" moment. - Jay B.- Thank you very much for your experience, hope all of us learn som ething from this list that can help us in the future to come.- - Saludos Gary Gower I remeber an old local saying with motorcycles:- "Only the ones that dont ride, will not-fall..." (translated from Spanish). Keep safe, but not too much to not enjoy life... :-) --- On Sat, 1/10/09, Jay Maynard wrote: From: Jay Maynard <jmaynard(at)conmicro.com> Subject: Re: Zenith601-List: Re: In-flight opening of front hinged canopy Date: Saturday, January 10, 2009, 8:52 PM > Monday morning quarterbacking is great!? At about pattern altitude, canop y > pops fully open, nose goes down 60+ degrees, 100 mph & increasing, headset > ripped off your head, cruise power,.? What would you do? *sigh* People, we need to remember, when disucssing these things, that people we know and consider friends have been right in the middle of the kinds of failures we're discussing, and refrain from casting aspersions on the abilities of folks who have been there and done that. We can and should learn from others' experiences...but we should not say we'd have done things differently in the heat of the moment - because there's just no way to know. Sometimes, what the book says we should do and what we think we will do as we're sitting in front of the computer don't correspond to what we actually wind up doing when the canopy comes open. As for me, I make certain to double check the security of the (in my case, new-style) canopy latch on both sides before taxi, and again before takeoff , as a result of Jay's accident. I've also given careful consideration to how I'll handle that occurrence. Even so, I'm not going to sit here and say that he screwed up. I suggest none of us are the position to do so. -- Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml =0A=0A=0A ________________________________________________________________________________
Subject: canopy construction sequence
Date: Jan 11, 2009
Hi all finished my Christmas house building and now back into XL plane building. I started on the canopy (old one not 650) and now up to the 6-C-3 section but that appears to be ahead and shows mostly finished pictures. Should I be using 6-C-3a,b,c,d before plain just 6-C-3?? Chris. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224010#224010 ________________________________________________________________________________
Subject: Re: canopy construction sequence
Date: Jan 11, 2009
Yes... and page 1 of 12 of 6-C-3A is very important. If you move the canopy more forward than 190mm you can gain some head room, but then you have to shorten the 9416K12 gas spring struts so the canopy does not hit up against 6C1-4 when fully open. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224035#224035 ________________________________________________________________________________
Date: Jan 11, 2009
On Saturday 10 January 2009 19:40, jaybannist(at)cs.com wrote: > Bryan, > > Monday morning quarterbacking is great!? At about pattern altitude, canopy > pops fully open, nose goes down 60+ degrees, 100 mph & increasing, headset > ripped off your head, cruise power,.? What would you do? Jay, I sympathize. Having totaled an aircraft in the 1970s, I can look back and see what I could have done differently. Whether any other options were open to you guys, you would know better than I. At the time, though, I did the best I could. I'm sure you guys did the same. -- ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Jan 11, 2009
Subject: This list
I just wanted to post here. Jeff Garrett Louisville Ky. 601XL N962T Aerolite Corvair 90% 601XL N524B Aerolite Corvair 155 Hrs 601XL N2257 Aerolite Corvair 225 Hrs _www.aeroliteproducts.com_ (http://www.aeroliteproducts.com/) _www.project601xl.com_ (http://www.project601xl.com/) _www.aerolite.camstreams.com_ (http://www.aerolite.camstreams.com/) Do not archive **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! cemailfooterNO62) ________________________________________________________________________________
Date: Jan 11, 2009
Subject: Re: Zenith-List: Re: Open canopy accident
Larry, I really wasn't trying to throw stones at Jay I was simply trying to inform folks that the 601 can be flown with the Canopy open and not to freak out if it happens and pics don't lie. So if Jay or you think I was somehow directing it directly at them so be it. I just know that if anyone brings up that it can be flown with it open Jay gets upset so why comment on it? I to am glad he didn't get hurt and walked away and it is true that the 601 in the pic's wasn't a AMD and it didn't have a 0-200 and it had different color paint but I still stand behind what I said and that is that if the aircraft wasn't over gross and was within proper CG it should have been stable with the canopy open provide the plane didn't get too slow. I'm not even gonna comment on your rudeness though Mr. Hursh Jeff Garrett Louisville Ky. 601XL N962T Aerolite Corvair 90% 601XL N524B Aerolite Corvair 155 Hrs 601XL N2257 Aerolite Corvair 225 Hrs _www.aeroliteproducts.com_ (http://www.aeroliteproducts.com/) _www.project601xl.com_ (http://www.project601xl.com/) _www.aerolite.camstreams.com_ (http://www.aerolite.camstreams.com/) Do not archive Mr Garrett, What you don't seem to understand is that Jay has possibly posted to the wrong forum. I believe he is posting to a response from the Zenith 601 forum, correct Jay? (Isn't that the forum you are banned from Mr Garrett?) Either way, I found your reply to Jay as being very crass and without any compassion. You wasn't there so you have NO CLUE as to what to do or what should have been done differently. Each and every circumstance is different. Sure the POH can give you a possible corrective course of action, but NOTHING is for certain and since you wasn't there, you have no idea as to what you should do or what you would have done differently. Why is it that you seemed to want to chastise Jay for mentioning it? All I can say to end this mess is THANK GOD Jay and his CFI II was able to get the plane on the ground. I'll leave you with this one final thought Mr Garrett - My father used to tell me, "If you can't say anything nice to someone, it's just best to keep your mo! uth SHUT and your eyes and ears OPEN. You learn more that way". :) -------- Larry Hursh (N650LM Reserved) CH650 (Converted from CH601XL) Starting fuselage will be Corvair Powered **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! cemailfooterNO62) ________________________________________________________________________________
Date: Jan 11, 2009
Building the Canopy... A problem I noticed in mid-2006... How do people feel about page 12 of 12 in 6-C-3A where it tells you to grind a slot in the 7/8" .058 4130 tube? Can anyone find in their version of the PLANS where this slot is mentioned? 6-C-2 I did not do it, I thought it would take away from any roll over protection. The .009 of clearance was enough. 3/4 OD tube inside a 7/8 4130 tube with .058 walls. Comments? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224085#224085 ________________________________________________________________________________
Date: Jan 11, 2009
Gentlemen, sometimes reductio ad absurdam really does get to the heart of the matter: 1: Canopy came open. 2: Aircraft was not reduced to rubble. 3: Occupants walked away. 4: Nobody unhappy with item 3. and, 5: We learned it can be done. 'nuff said. If some guy flying through severe turbulence hits a bird, which trashes his canopy, goes into a spin, loses his prop to over speed, , regains control in time to clip a high tension wire, which rips off his rudder, slashes through a tree, locks up his brakes blows both tires, and stops 6 inches away from a station wagon full of nuns, I ain't gonna tell him he should have done such-and-such! Nothing outweighs the phrase, "I(we) made it!" Paul Rodriguez ----- Original Message ----- From: Gary Gower<mailto:ggower_99(at)yahoo.com> To: zenith601-list(at)matronics.com Sent: Sunday, January 11, 2009 1:03 AM Subject: Re: Zenith601-List: In-flight opening of front hinged canopy. Hello Jay M. Just a very short comment: You are right, Jay B and Pilot did the best thing, they managed to land and are alive... One thing very important for ALL of us is to try to keep calm in any type of personal emergency situation... if Fear and Desparation are winning, Clear Mind is loosing... Easy to say but hard to do in "that" moment. Jay B. Thank you very much for your experience, hope all of us learn something from this list that can help us in the future to come. Saludos Gary Gower I remeber an old local saying with motorcycles: "Only the ones that dont ride, will not fall..." (translated from Spanish). Keep safe, but not too much to not enjoy life... :-) --- On Sat, 1/10/09, Jay Maynard wrote: From: Jay Maynard <jmaynard(at)conmicro.com> Subject: Re: Zenith601-List: Re: In-flight opening of front hinged canopy To: zenith601-list(at)matronics.com Date: Saturday, January 10, 2009, 8:52 PM > Monday morning quarterbacking is great!? At about pattern altitude, canopy > pops fully open, nose goes down 60+ degrees, 100 mph & increasing, headset > ripped off your head, cruise power,.? What would you do? *sigh* People, we need to remember, when disucssing these things, that people we know and consider friends have been right in the middle of the kinds of failures we're discussing, and refrain from casting aspersions on the abilities of folks who have been there and done that. We can and should learn from others' experiences...but we should not say we'd have done things differently in the heat of the moment - because there's just no way to know. Sometimes, what the book says we should do and what we think we will do as we're sitting in front of the computer don't correspond to what we actually wind up doing when the canopy comes open. As for me, I make certain to double check the security of the (in my case, new-style) canopy latch on both sides before taxi, and again before takeoff, as a result of Jay's accident. I've also given careful consideration to how I'll handle that occurrence. Even so, I'm not going to sit here and say that he screwed up. I suggest none of us are the position to do so. -- Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D http://www.matronics.com/Navigator?Zenith601-List"http://www.mat ronics.com/Navigator?Zenith601-List"> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D http://forums.matronics.com"http://forums.matronics.com"> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D http://www.matronics.com/contribution"http://www.matronics.com/c ontribution"> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Jan 11, 2009
When I started building my canopy I wasn't aware that the slots were allowed. When adjusting the final length of the rear hoop I got quite frustrated with how hard it was to move the aluminum hoop in the steel tubing of the canopy frame. Just about then I found Zenith was recommending the slot. If for nothing else it makes assembly, disassembly and adjustment many time easier. I don't think it had much (if any) a negative impact on the structural integrity. Here's a link to a photo detail of the slot.
http://daniel.dempseyfamily.us/zodiac/canopy/pilotside.htm Dan Dempsey Sabrina wrote: > Building the Canopy... > > A problem I noticed in mid-2006... > > How do people feel about page 12 of 12 in 6-C-3A where it tells you to grind a slot in the 7/8" .058 4130N tube? > > Can anyone find in their version of the PLANS where this slot is mentioned? 6-C-2 > > I did not do it, I thought it would take away from any roll over protection. The .009 of clearance was enough. 3/4 OD tube inside a 7/8 4130N tube with .058 walls. > > Comments? -------- Scratch building XL with Corvair Engine Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224118#224118 ________________________________________________________________________________
Date: Jan 11, 2009
I'm not sure this would work. what effect do you think the turtle deck opening might have as far as drag or would you just cover up the opening? I would be to afraid it would smack the rudder and then you might be even worse off. I think a better solution would be a ejection seat then you would go straight thru the canopy. BTW that last part was a joke Jeff Garrett Louisville Ky. 601XL N962T Aerolite Corvair 90% 601XL N524B Aerolite Corvair 155 Hrs 601XL N2257 Aerolite Corvair 85 Hrs think it's right this time _www.aeroliteproducts.com_ (http://www.aeroliteproducts.com/) _www.project601xl.com_ (http://www.project601xl.com/) _www.aerolite.camstreams.com_ (http://www.aerolite.camstreams.com/) Do not archive Paul, all... What do you think about an XL canopy that can be ejected? Is it needed? The mod costs less than $40 (two MS17985-414 quick release pins and one foot of 4130 square tubing) but the pair of goggles needed, just in case, cost about $30 each for a total of $100 and 14 ounces of added weight, total. **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! cemailfooterNO62) ________________________________________________________________________________
Date: Jan 11, 2009
Subject: Some videos of us flying
After switching from the front starter kit to the Aerolite rear system we flew from Louisville Ky to spend the night with Bill Clapp then on to Englewood Fl. The flight was great. Here are the #'s Voltage was 14 volts steady Oil pressure was steady 40 lbs Cht's were 125-130 steady and 200-225 climb Egt 1050 steady Oil temp 60 degrees OAT were 255 before the cooler and 190-200 after cooler (with my new fiberglass baffles installed but had some air loss so should see 10 degree drop after sealing.) Here are some youtube links _http://www.youtube.com/watch?v=Tyx2nalW9gs_ (http://www.youtube.com/watch?v=Tyx2nalW9gs) _http://www.youtube.com/watch?v=kC4fF0uTuxQ_ (http://www.youtube.com/watch?v=kC4fF0uTuxQ) _http://www.youtube.com/watch?v=ZEbz-AK3YU0_ (http://www.youtube.com/watch?v=ZEbz-AK3YU0) _http://www.youtube.com/watch?v=4JPnUcicz7k_ (http://www.youtube.com/watch?v=4JPnUcicz7k) Jeff Garrett Louisville Ky. 601XL N962T Aerolite Corvair 90% 601XL N524B Aerolite Corvair 155 Hrs 601XL N2257 Aerolite Corvair 225 Hrs _www.aeroliteproducts.com_ (http://www.aeroliteproducts.com/) _www.project601xl.com_ (http://www.project601xl.com/) _www.aerolite.camstreams.com_ (http://www.aerolite.camstreams.com/) Do not archive **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! cemailfooterNO62) ________________________________________________________________________________
Date: Jan 11, 2009
These slots were already cut on my kit [bought 12 mths ago]which made it easy to adjust the bow. If you had to rely on it for roll over protection I think you would come out second best.I made a gusset which spans the two turtle deck bows at the bottom and it is very sturdy now.Cheers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224157#224157 ________________________________________________________________________________
Date: Jan 12, 2009
Subject: 601 Builders... some advice please
A few days ago I posted a note asking for some insight into the gusset mods for the 601XLs ailerons. I received several nice replies from various folks including a detailed estimation of the work involved from George Smith. (Thanks again, George) I also received a nice note from Mathieu Heintz and he asked me to share it as widely as possible. So, feel free to re-post. In his note below, Mathieu is referring to the notification of the aileron mod (gusset plates) described in this Service Letter from AMD at this link: http://www.newplane.com/amd/../Service_Letters_Bulletines/NOTICE%20January%207%202009.pdf> Hi Frank , Notifications are not mandatory. If you see any deformation at the ailerons, it is wise to install the supplementary gussets. The gussets are very easy to install. They are sandwiched between the skin and rib. Remove a few rivets, install the bracket, drill holes into the bracket and rivet. The Zenith Aircraft demo aircraft which has more than 1,500 hours does not have these brackets. Hope this will help. Regards Mathieu Heintz Zenair -- ----- --------- Twitter! Follow me at http://Twitter.com/Fderfler See my new Novel, "A Glint in Time" at http://GreatGuyBooks.com. See my discussion of All the Guy Toys that aren't (clearly) illegal or (blatantly) immoral at http://mostlyflying.com Anybody who READS (anybody out there?) See www.greatguybooks.com ________________________________________________________________________________
Date: Jan 12, 2009
I really hate to agree with Jeff but I'd say if the canopy was ejected I'd have to think the odds are pretty high that it would hit the tail and do God only knows what. That said I too have thought about an ejectable canopy but it would only be used if I Had a chute and was ejecting the canopy to bail out. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224210#224210 ________________________________________________________________________________
Subject: Need help & consuling on Rivet puller
Date: Jan 12, 2009
When I first started looking for a rivet puller, I shied away from the gun that was being offered by Zenith because I had heard from builders on this List, that there was many instances of cracking in the casings. As a replacement I decided to go with a gun that was being offered by ACS ( see pic below ) however it is starting to look like this was not my best decision. I had difficulty with the setup instructions ( Chinese instructions ) and for the life of me I still have not been able to get the oil level correct. The instructions state that the unit should be filled with oil up to the top of the frame, without showing where exactly what they consider as being the top or the exact filling level is. My second mistake was purchasing two guns so as not to have to continually swap out the two tips. As it stands, when I do get one of the (at)#$%&* things to work, it won't pull more then a dozen or so rivets, before me being obliged to open up the air cylinder and start fidgeting with the oil level again. I am basically a neat person, and I can't live with the constant spewing of oil out the front, or the back stem catcher, and ending up on my freshly made parts, or my work table for that matter. I am now in the process of trying to look for a replacement, but all the suppliers seem to have the same low cost gun. The list of resellers I checked with is rather extensive and includes, but is not limited to, The Yard, ATS, Browns, Cleavland, US Tools, all registered trademarks etc, and a few more I will not mention. My question to the List is this, is the rivet gun being sold by all of these suppliers the same gun. I have looked as best as I can, and every last one is showing what looks to be the exact same unit on their web-page, with the only difference being the color or the pricing. The cases are identical, the same tips, the same nose pieces, hell they even the same triggering mechanism, and the only difference so far is prices, that are anywhere between 40$, to a 140$. For those of you who have used any of the above guns, are you aware of any difference in quality of these guns, or is it a " find the peanut under the shell " type of situation for me to get a proper replacement that will work, Thank's to all of you who will take the time to respond to my concerns. Bob, the Scratch builder Three Rivers, Quebec. -------- Live each day, as if it was your last Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224233#224233 Attachments: http://forums.matronics.com//files/rivet_gun_901.jpg ________________________________________________________________________________
Date: Jan 12, 2009
Gig is correct. I designed my canopy for loss of control/flying surface. I was more worried about it hitting my head than the tail feathers. The only time it would be tried with the canopy up would be combined with an engine failure. Having said that, I hear that a few side hinge canopies have departed, all without tail feather damage. With the new 180 day repack rule (was 120) and the Sky Catcher BRS failure, I like my pair of backpack chutes even more. Off to my first class in Quantum Physics! P.S. Frank: the factory demo has flex hinges, how many flex hinges have failed: 0 Why mess with perfection. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224234#224234 ________________________________________________________________________________
Date: Jan 12, 2009
Subject: Re: Need help & consuling on Rivet puller
Bob, I have never used that type of gun but I have other guns and none require filling with oil. If you drain all the oil they will more than likely work just fine. I think the oil is just a few drops daily but I could be wrong about your gun but odds are if it is getting oil everywhere it probably shouldn't be in the gun. Try it and let us know what happened. Jeff Garrett Louisville Ky. 601XL N962T Aerolite Corvair 90% 601XL N524B Aerolite Corvair 155 Hrs 601XL N2257 Aerolite Corvair 85 Hrs _www.aeroliteproducts.com_ (http://www.aeroliteproducts.com/) _www.project601xl.com_ (http://www.project601xl.com/) _www.aerolite.camstreams.com_ (http://www.aerolite.camstreams.com/) Do not archive I had difficulty with the setup instructions ( Chinese instructions ) and for the life of me I still have not been able to get the oil level correct. The instructions state that the unit should be filled with oil up to the top of the frame, without showing where exactly what they consider as being the top or the exact filling level is. **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! cemailfooterNO62) ________________________________________________________________________________
Date: Jan 12, 2009
Hi Bob, After completing (nearly?) my XL, I have accumulated a lot of rivet puller experience. Fortunately, my first purchase of a powered puller was guided by this list. I bought the Harbor Freight lower priced air powered puller and eventually bought another one. These cost around $25 each on sale and maybe $30 or $40 at regular price. I have my Harbor Freight pullers equipped with a custom built nose piece to form the Heintz style shop head. I didn't like the standard shaped heads because I tended to set the rivets at a slight angle rather than flush with the metal piece. The pieces I made are similar in most dimensions to the regular ones but about 1/2 inch flat on the front to make it easier to get them flush to the metal. I have heard about pullers that have some sort of oil reservoir. The Harbor Freight ones don't. You just put a few drops of oil in the air hose intake each day. I also have several hand powered pullers. They all work fine. I tend to use either the powered or hand puller for A4 rivets but for A5s the powered puller definitely gets used more often. Good luck, Paul XL getting close At 08:20 AM 1/12/2009, you wrote: > > >When I first started looking for a rivet puller, I shied away from >the gun that was being offered by Zenith because I had heard from >builders on this List, that there was many instances of cracking in >the casings. As a replacement I decided to go with a gun that was >being offered by ACS ________________________________________________________________________________
Date: Jan 12, 2009
Bob, most of the rivet pullers are actually pneumatic/hydraulic. To oil the unit, you must remove the bottom cover and pull out the large piston with a pliers. Then fill the puller w/ air tool oil through the piston stem opening just to the top of the opening. This completes the hydraulics of the tool. Then grease the walls of the tank and replace the plunger and cover. Thereafter a few drops of oil into the air inlet before use each day will suffice. There is also a measurement for the head to be adjusted using one of the tools provided. This seems to be crucial to the operation. Hope this helps. Terry Turnquist 601XL-Plans St. Peters MO Hi Bob, After completing (nearly?) my XL, I have accumulated a lot of rivet puller experience. Fortunately, my first purchase of a powered puller was guided by this list. I bought the Harbor Freight lower priced air powered puller and eventually bought another one. These cost around $25 each on sale and maybe $30 or $40 at regular price. I have my Harbor Freight pullers equipped with a custom built nose piece to form the Heintz style shop head. I didn't like the standard shaped heads because I tended to set the rivets at a slight angle rather than flush with the metal piece. The pieces I made are similar in most dimensions to the regular ones but about 1/2 inch flat on the front to make it easier to get them flush to the metal. I have heard about pullers that have some sort of oil reservoir. The Harbor Freight ones don't. You just put a few drops of oil in the air hose intake each day. I also have several hand powered pullers. They all work fine. I tend to use either the powered or hand puller for A4 rivets but for A5s the powered puller definitely gets used more often. Good luck, Paul XL getting close At 08:20 AM 1/12/2009, you wrote: > > >When I first started looking for a rivet puller, I shied away from >the gun that was being offered by Zenith because I had heard from >builders on this List, that there was many instances of cracking in >the casings. As a replacement I decided to go with a gun that was >being offered by ACS ________________________________________________________________________________
Date: Jan 12, 2009
Subject: N601JD First Flight
N601JD my 601XL with a Jabiru 3300 took to the air for the first time last Friday at Avery County Airport (7A8) in Spruce Pine, NC. Its a quickbuild kit that I started in April 07. The obligatory Youtube video is at http://www.youtube.com/watch?v=vIVt40B5dLc. Its short and a bit shaky so be careful if you get motion sickness :-) The flight went well with only a couple of minor squawks: 1. Need to add a stop to the throttle @ low RPMS to prevent the engine from stopping when the throttle is pulled too far back to idle. The US Jabiru guys recommend a small cable stop added to the throttle cable at the carb to prevent this. 2. Aileron trim is wired backwards, Oops, didn't notice a real need for the aileron trim though 3. Experiment with my Sensenich Ground adjustable prop and also re-jetting the Bing carb to maximize performance. CHTs and EGTs looked good though, perhaps I wont have to spend too much time messing with cooling issues. Woo hoo, now only 38 more hours till the end of Phase 1... If only I had remembered to turn on my in cockpit video recorder, I'll do that next time...once the darned weather clears up again. Thanks to all the list members who helped with questions during the build process. Thanks, John Davis Burnsville, NC N601JD - 601XL/Jab 3300 Now Flying!!!! ________________________________________________________________________________
Date: Jan 12, 2009
Hi Fellows, I had not expected so much feedback, nor so soon, but I am glad to hear of all your experiences. I must first apologize for mis-speaking earlier when I stated that the gun was purchased from ACS. I went through all my invoices, and found the Harbor Freight invoice ID'ing the gun. It is the Central Pneumatic model # 93458, and the exact same model however that ACS is offering. As for the oil management, I have a very complete, ( and very expensive I must ad ) set of more then a half dozen " Chicago Pacific ) air tools, and like most of you responders, and few drops in the air intake, is more then enough to keep them in excellent shape. However I had never used any rivet gun before, and followed the instructions that were given in the manual to the best of my knowledge, and hence the filling of the tool. Check the pic of the instructions in the user manual below. This evening I will pour out any remaining oil, and give both of them another try. Bob the 701 & 750 Scratch Terry, when I fill the piston stem opening to the top, no sooner that I re-insert the diaphragm into the gun, the oil comes squirting out the air exhaust hole in the front ( check rag ) of the canister or air cylinder.., and also out the rear into the stem holder. I will also give this another try. -------- Live each day, as if it was your last Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224302#224302 Attachments: http://forums.matronics.com//files/oil_level_181.jpg ________________________________________________________________________________
Date: Jan 12, 2009
Bob, - - I bought the rivet puller that Zenith sells and it hasn't given me a pr oblem at all. Just a few drops of oil once in a while, with no oil splatter /spray at all. Finished the wings and tail feathers, w/about 25% of fuselag e complete. Walt in Dayton. --- On Mon, 1/12/09, stepinwolf wrote: From: stepinwolf <robert.pelland(at)cgocable.ca> Subject: Zenith601-List: Need help & consuling on Rivet puller Date: Monday, January 12, 2009, 11:20 AM When I first started looking for a rivet puller, I shied away from the gun that was being offered by Zenith because I had heard from builders on this List, that there was many instances of cracking in the casings. As a replacement I dec ided to go with a gun that was being offered by ACS ( see pic below ) however it is starting to look like this was not my best decision. I had difficulty with the setup instructions ( Chinese instructions ) and f or the life of me I still have not been able to get the oil level correct. The instructions state that the unit should be filled with oil up to the top of the frame, without showing where exactly what they consider as being the top or the exact filling level is. My second mistake was purchasing two guns so as not to have to continually swap out the two tips. As it stands, when I do get one of the (at)#$%&* things t o work, it won't pull more then a dozen or so rivets, before me being obliged to open up the air cylinder and start fidgeting with the oil level again. I am basically a neat person, and I can't live with the constant spewing of oil out the front, or the back stem catcher, and ending up on my freshly ma de parts, or my work table for that matter. I am now in the process of trying to look for a replacement, but all the suppliers seem to have the same low cos t gun. The list of resellers I checked with is rather extensive and includes, but is not limited to, The Yard, ATS, Browns, Cleavland, US Tools, all register ed trademarks etc, and a few more I will not mention. My question to the List is this, is the rivet gun being sold by all of thes e suppliers the same gun. I have looked as best as I can, and every last one is showing what looks to be the exact same unit on their web-page, with the on ly difference being the color or the pricing. The cases are identical, the sam e tips, the same nose pieces, hell they even the same triggering mechanism, a nd the only difference so far is prices, that are anywhere between 40$, to a 1 40$. For those of you who have used any of the above guns, are you aware of any difference in quality of these guns, or is it a " find the peanut under the shell " type of situation for me to get a proper replacement that will work, Thank's to all of you who will take the time to respond to my concerns. Bob, the Scratch builder Three Rivers, Quebec. -------- Live each day, as if it was your last Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224233#224233 Attachments: http://forums.matronics.com//files/rivet_gun_901.jpg ________________________________________________________________________________
Date: Jan 12, 2009
Subject: Re: N601JD First Flight
Congratulations, John! Enjoy your new airplane. Terry >N601JD my 601XL with a Jabiru 3300 took to the air for the first time last >Friday at Avery County Airport (7A8) in Spruce Pine, NC. Its a quickbuild >kit that I started in April 07. Terry Phillips ZBAGer ttp44~at~rkymtn.net Corvallis MT 601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons are done; working on the wings http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: Jan 12, 2009
On Monday 12 January 2009 12:29, John Davis wrote: > > N601JD my 601XL with a Jabiru 3300 took to the air for the first time > last Friday at Avery County Airport (7A8) in Spruce Pine, NC. Its a > quickbuild kit that I started in April 07. > Congratulations! -- ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Jan 12, 2009
Sabrina wrote: > Sky Catcher BRS failure Any details on how it failed? Did it not deploy? Or get snagged on something? Thanks, - Pat -------- Patrick 601XL/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224326#224326 ________________________________________________________________________________
Date: Jan 12, 2009
I have one I found on ebay that has been working good for me. Search for: NEW AIR POP RIVET GUN The company is Great-Tools. I modified the nose pieces myself, follow link below to learn how: http://mykitlog.com/users/display_log.php?user=rlendon&project=113&category=0&log=10097&row=674 -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224375#224375 ________________________________________________________________________________
Date: Jan 12, 2009
Subject: Fwd: Packing and moving a 601xl
---------- Forwarded message ---------- From: Cndmovn <cndmovn(at)gmail.com> Date: Mon, Jan 12, 2009 at 9:27 PM Subject: Packing and moving a 601xl Here is a handy tip. If you have to move/store a 601xl they fit perfectly into a 16ft POD storage unit. I hung my wings on the sides via the cargo straps I used to pull the wing skin down. I tied the tail up in with the eyelet in the unit at the rear and blocked the wheels to the floor. I also used a cargo strap to pull the main wheel down to the floor at the front. There was 2" to spare between the wheel and the door on the unit. Cheers! ________________________________________________________________________________
Date: Jan 12, 2009
God you guys are something else. I have an original "Pop Rivet" brand hand rivet tool I bought for about 4 bucks in about 1973 and after all those years of misc. use I've built 2 planes with at least as many rivets as the 601 and will build my 601 with it as well. Or maybe I can discuss all the ramifications of the ramistat ad infinitum... Geez! ________________________________________________________________________________
Subject: Re: In-flight opening of front hinged canopy. BRS Comment
Date: Jan 12, 2009
Gary you are so right. I have a BRS installed in my 601XL and it terrifies me to think that I would actually pull it! I mean there is a solid fuel rocket right behind my head that is bigger than any hobby rocket I could imagine shooting up in the air! Then there is the fact that it has not been tested in the exact configuration the way I installed it. I do, however keep the safety pin pulled when I fly. Yes, Gary - right on. The very LAST resort. One other scary thing- when I was sitting in my garage a long time ago just after installing the handle (no rocket) I was imagining I was in trouble and trying to see what it would be like to actually pull the handle, so I got myself all worked up and convinced that I was going down and I reached down and gave it a yank and almost pulled my wrist out of joint - I hadn't removed the pin! A simple mistake and my fictitious save didn't happen! Fly safe and have fun! Scott Laughlin 601XL/Corvair 120 Hours www.cooknwithgas.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224406#224406 ________________________________________________________________________________
Date: Jan 13, 2009
Subject: Corvair distributor hold down
I have had these distributor hold downs made and if anyone wants one please send me a message off list and I will get your information. They are made from 304 stainless and come with the self locking nut and washer. I myself check the distributor before every flight and don't like the wire hold downs that Chevy used on the corvair so I had these made and as far as I know they weren't copied from anyone because I would have bought one if they were available. Auto Zone sells one for like $15.00 but this one is much stronger and won't rust. Here are some pics of it. Jeff Garrett Louisville Ky. 601XL N962T Aerolite Corvair 90% 601XL N524B Aerolite Corvair 155 Hrs 601XL N2257 Aerolite Corvair 85 Hrs _www.aeroliteproducts.com_ (http://www.aeroliteproducts.com/) _www.project601xl.com_ (http://www.project601xl.com/) _www.aerolite.camstreams.com_ (http://www.aerolite.camstreams.com/) Do not archive **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! cemailfooterNO62) ________________________________________________________________________________
Date: Jan 13, 2009
Although I have only done the tail feathers, I am well happy with the ZAC supplied gun , smooth and quiet. Run 2.5 bar for A4 and 3.2 bar for the A5 rivets, through the compressors regulator. Cheers kev :) -------- Austria ............. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224438#224438 ________________________________________________________________________________
Date: Jan 13, 2009
I really enjoyed the enthusiasm of your family when you landed. It was a great video and that airport at Spruce Pine looks great. I have my plane over in Andrews, NC. Hope to see you some time. And Jay sure is good at noticing the not so obvious (runway departure and approach). He'd be a great detective. I missed that runway thing completely! johnd(at)data-tech.com wrote: > N601JD my 601XL with a Jabiru 3300 took to the air for the first time > last Friday at Avery County Airport (7A8) in Spruce Pine, NC. Its a > quickbuild kit that I started in April 07. > > The obligatory Youtube video is at > http://www.youtube.com/watch?v=vIVt40B5dLc. Its short and a bit shaky so > be careful if you get motion sickness :-) > > The flight went well with only a couple of minor squawks: > 1. Need to add a stop to the throttle @ low RPMS to prevent the engine > from stopping when the throttle is pulled too far back to idle. The US > Jabiru guys recommend a small cable stop added to the throttle cable at > the carb to prevent this. > 2. Aileron trim is wired backwards, Oops, didn't notice a real need for > the aileron trim though > 3. Experiment with my Sensenich Ground adjustable prop and also > re-jetting the Bing carb to maximize performance. CHTs and EGTs looked > good though, perhaps I wont have to spend too much time messing with > cooling issues. > > Woo hoo, now only 38 more hours till the end of Phase 1... > > If only I had remembered to turn on my in cockpit video recorder, I'll > do that next time...once the darned weather clears up again. > > Thanks to all the list members who helped with questions during the > build process. > > Thanks, > John Davis > Burnsville, NC > N601JD - 601XL/Jab 3300 > Now Flying!!!! -------- Scott Thatcher, Palm Beach Gardens, FL 601XL with Corvair, Registered as E-LSA N601EL, EAA203 25 hours and climbing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224450#224450 ________________________________________________________________________________
Date: Jan 13, 2009
Subject: In-flight opening of front hinged canopy
Sabrina - Thanks for your observation that the factory demo has flex hinges. That is important to note. Regarding your "easily removable" canopy, I'm surprised no one has injected the idea of its value in a water landing. Since I fly over water 90% of the time it entered my head. At one time my personal POH included popping the latch before attempting an emergency water landing. But, I later re-wrote that when I discussed the noise, the change of attitude, and the distraction with a guy who regularly opened the 601 canopy as a simulated emergency condition. (THAT part of my personal POH says, "As Slow As You Can Go") So now my emergency water landing procedure says get the canopy open first thing. But, depending on the attitude, that could be challenging. I submit that being able to jettison the canopy quickly after an emergency landing could be a good thing. On the other hand, the whole canopy ejection and bailing out with a seatpack chute on strikes me as ummm... less valuable. (Yes, I know the Skycatcher guy did it and I do not know how!) Sabrina, thanks for your great ideas. Quantum physics, eh? Be prepared for lots of Heisenberg jokes. Frank Derfler AMD-made 601XL with 160 hours Marathon in the Florida Keys -- Twitter! Follow me at http://Twitter.com/Fderfler See my new Novel, "A Glint in Time" at http://GreatGuyBooks.com. See my discussion of All the Guy Toys that aren't (clearly) illegal or (blatantly) immoral at http://mostlyflying.com Anybody who READS (anybody out there?) See www.greatguybooks.com ________________________________________________________________________________
Date: Jan 13, 2009
Subject: Re: Some videos of us flying
Scott We had a 20 knot head wind the whole way but at 2700 we average 132 to 135 MPH prop pitch at 10.5 degrees and timing set at 28 degrees points and 30 degrees electronic we flew for about 6.5 hours but some of the flight was at 2500 rpm's to let the oil cool from the long climb at gross (wanted to play it safe with the new engine). As you know the rear starter is new but we now have over 200 combined hrs on it on 3 different aircraft 1 of which is Bill Clapps KR with almost 100 hrs on it so I still had a bit of a pucker factor for the first leg of the flight but wanted as much distance from the ground as I could get and 7500 is where we cruised. The last leg of the flight was at 2500 and if I did it again today I would have no problem flying at 1500 to have more fun. Jeff Enjoyed the videos and specs during flight. I made my flight from West Palm Beach to NC so was about the same distance. How long did you take to complete the trip? The Corvair sounded great, even if it wasn't my friend William's. I noticed that your tach read 2700? Since I flew pretty much at the same tach setting, I was wondering at what speed you were generally flying? **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! cemailfooterNO62) ________________________________________________________________________________
Date: Jan 13, 2009
A big thank you to all who responded to my call for help. Yesterday evening I was able to find, and correct the problem with my rivet gun. As was mentioned in a previous response, the defect was with the large O-ring on the piston at the top of the handle. it has an O-ring at the rear to seal the oil, and both guns had O-rings that were dried out and hardened. This is why the gun was quitting after a dozen or so rivets, because the oil was leaking pass the O-ring into the stem catcher. Now it is working great, with no oil leaks. There was however one casualty in all this and that is my second gun. While I was rebuilding the first one on the bench I casually pulled the trigger to check how far back the piston was pulling, and when it evacuated the air from the lower canister, it blow the spring from my second gun off the bench, and was never to be seen again. Bob the 701 & 750 scratch Three Rivers, Quebec -------- Live each day, as if it was your last Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224494#224494 Attachments: http://forums.matronics.com//files/dscf1006_1280x768_154.jpg ________________________________________________________________________________
Date: Jan 13, 2009
Hello Frank, - That is a good point,- I personally avoid flying over the lake(s) or over the sea farther from gliding distance of the shore, or over towns or citie s. - When emergency landing on water there is a big chance to end with the airpl ane wheels up (mainly landing gear drag on the water or other causes),,,- in this case opening the canopy will be almost impossible.-- How to pu sh the area of the cabin against the resistance of the water?. - Where do you fly?-Why so much- time over water? - in normal flying-person with-no ocean or gulf crossing, -the chances of flying over water (outside gliding distance), and that the engine will f ail in that precise time, are very low statitically,- This to justify-t o have a cabin eject mechanism that can accidentally be pulled by a passeng er.- We all give Young Eagles flights, and kids are kids... - Saludos Gary Gower Flying from Chapala Lake, Mexico. (over the dry side :-) "What is not installed, will not fail" --- On Tue, 1/13/09, Frank Derfler wrote: From: Frank Derfler <fderfler(at)gmail.com> Subject: Zenith601-List: In-flight opening of front hinged canopy Date: Tuesday, January 13, 2009, 7:54 AM Sabrina -- Thanks for your observation that the factory demo has flex hinges. -That is important to note. - Regarding your "easily removable" canopy, I'm surprised no one has injected the idea of its value in a water landing. -Since I fly over water 90% of the time it entered my head. -At one time my personal POH included poppi ng the latch before attempting an emergency water landing. - But, I later re-wrote that when I discussed the noise, the change of attitude, and the distraction with a guy who regularly opened the 601 canopy as a simulated e mergency condition. -(THAT part of my personal POH says, "As Slow As You Can Go") - So now my emergency water landing procedure says get the canop y open first thing. -But, depending on the attitude, that could be challe nging. - -I submit that being able to jettison the canopy quickly after an emergen cy landing could be a good thing. -On the other hand, the whole canopy ej ection and bailing out with a seatpack chute on strikes me as ummm... less valuable. -(Yes, I know the Skycatcher guy did it and I do not know how!) - Sabrina, thanks for your great ideas. -Quantum physics, eh? -Be prepare d for lots of Heisenberg jokes. - Frank Derfler- AMD-made 601XL with 160 hours- Marathon in the Florida Keys- -- Twitter! Follow me at http://Twitter.com/Fderfler See my new Novel, "A Glint in Time" at http://GreatGuyBooks.com. See my discussion of -All the Guy Toys that aren't (clearly) illegal or ( blatantly) immoral at http://mostlyflying.com - Anybody who READS (anybody out there?) See www.greatguybooks.com =0A=0A=0A ________________________________________________________________________________
Date: Jan 13, 2009
Bob, I used the Zenith supplied rivet puller without any problems at all. They warn you that the case may crack if you use too high of an air pressure. I ended up using a few pounds higher (at the compressor) than they recommended to get the 5/32 stems to snap. Chuck finished and ready to fly -------- Chuck Maggart Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224544#224544 ________________________________________________________________________________
Date: Jan 13, 2009
you can sweep with a magnetic "broom".- You can also get down on the floo r and look obliquely across the floor: everything else is "taller" than you r eye so they stand out. David L. Downey Harleysville-(SE) PA, USA --- On Tue, 1/13/09, stepinwolf wrote: From: stepinwolf <robert.pelland(at)cgocable.ca> Subject: Zenith601-List: Re: Need help & consuling on Rivet puller Date: Tuesday, January 13, 2009, 11:23 AM A big thank you to all who responded to my call for help. Yesterday evening I was able to find, and correct the problem with my rivet gun. As was mentioned in a previous response, the defect was with the larg e O-ring on the piston at the top of the handle. it has an O-ring at the rea r to seal the oil, and both guns had O-rings that were dried out and hardened. This is why the gun was quitting after a dozen or so rivets, because the oi l was leaking pass the O-ring into the stem catcher. Now it is working great , with no oil leaks. There was however one casualty in all this and that is my second gun. Whil e I was rebuilding the first one on the bench I casually pulled the trigger to check how far back the piston was pulling, and when it evacuated the air from the lower canister, it blow the spring from my second gun off the bench, and wa s never to be seen again. Bob the 701 & 750 scratch Three Rivers, Quebec -------- Live each day, as if it was your last Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224494#224494 Attachments: http://forums.matronics.com//files/dscf1006_1280x768_154.jpg =0A=0A=0A ________________________________________________________________________________
Date: Jan 13, 2009
My original - and perhaps too brief - question was pertaining to the actual failure mode of the BRS. We hear all about the BRS "saves". I have not heard much about any BRS failures, and it is those that we who are installing BRS's should examine. I am in the process of installing a BRS in my XL, and am trying to do everything I can up front to stack the odds in my favor in the unlikely event that I or a passenger would ever have to pull that handle. - Patrick -------- Patrick 601XL/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224584#224584 ________________________________________________________________________________
Subject: Re: Canopy and Cold Weather (shipping) ?
Date: Jan 13, 2009
> regarding shipment of that big plastic bubble in the winter? I'll find out soon enough. I ordered my canopy last week, and it shipped today. We're in a cold snap right now, and it isn't going to get above zero for a few days. Was -21 below zero (F) at my house this morning. [Shocked] So if my canopy arrives safely, it should lend confidence to others who are wondering about how well that bubble survives shipping in winter... - Patrick: -------- Patrick 601XL/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224592#224592 ________________________________________________________________________________
Date: Jan 13, 2009
PatrickW wrote: > My original - and perhaps too brief - question was pertaining to the actual failure mode of the BRS. > > We hear all about the BRS "saves". I have not heard much about any BRS failures, and it is those that we who are installing BRS's should examine. > > I am in the process of installing a BRS in my XL, and am trying to do everything I can up front to stack the odds in my favor in the unlikely event that I or a passenger would ever have to pull that handle. > > - Patrick Patrick if you are talking about the Skycatcher failure. First the plane was in a flat spin. Second there was some talk that the BRS was not properly mounted. Remember this was a prototype plane not a production version. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224631#224631 ________________________________________________________________________________
Date: Jan 13, 2009
PatrickW wrote: > > > regarding shipment of that big plastic bubble in the winter? > > I'll find out soon enough. I ordered my canopy last week, and it shipped today. > > We're in a cold snap right now, and it isn't going to get above zero for a few days. Was -21 below zero (F) at my house this morning. [Shocked] > > So if my canopy arrives safely, it should lend confidence to others who are wondering about how well that bubble survives shipping in winter... > > - Patrick Really Really Really Really don't try to do any work mounting the canopy until it is about 90 degrees warmer. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224632#224632 ________________________________________________________________________________
Date: Jan 14, 2009
You guys are too funny! When I was building my canopy frame, I was amazed how tinkering with one side would often release the other side. I would lock one side, leave the other up. In attempting to lock the remaining side the original side would sometimes release due to movement of the release cable. That scared me. Has anyone else split the release mechanism on the canopy so both the left and right side need to be released independently? This way, one has 4 "disengagements" before release, accidental or whatnot. I prefer this to the single "disengagement" of the 650. Attempting to re-latch one side necessarily unlatches the other since it is a solid arm. Correct? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224723#224723 ________________________________________________________________________________
Date: Jan 14, 2009
Hi Sabrina, In my case, I left a little slack in the release cables. There is still plenty of movement when you rotate the control knob to release both latches, but it isn't so tight as to do the nasty stuff you talked about. I also got lucky with the placement of the rotating knob for the release. It fit kind-of tight so when it is nearly closed it takes a little extra force to "Click" into place. That also means it takes some extra force to get it started in the latch opening cycle. Have fun, Paul P.S. Watch out for jumping electrons. At 08:50 AM 1/14/2009, you wrote: >I would lock one side, leave the other up. In attempting to lock >the remaining side the original side would sometimes release due to >movement of the release cable. That scared me. ________________________________________________________________________________
Date: Jan 14, 2009
When I was scratch-building my canopy, after several iterations I wound up using two barrel bolts, which I made spring-loaded, to slide over and snap into two notches in some 3/16 steel t-bar stock. I haven't flow it yet, but after you release the turning handle, you can hear the barrel bolts snap in place. I think it will hold. Paul Rodriguez ----- Original Message ----- From: Sabrina<mailto:chicago2paris(at)msn.com> To: zenith601-list(at)matronics.com Sent: Wednesday, January 14, 2009 10:50 AM Subject: Zenith601-List: Re: In-flight opening of front hinged canopy > You guys are too funny! When I was building my canopy frame, I was amazed how tinkering with one side would often release the other side. I would lock one side, leave the other up. In attempting to lock the remaining side the original side would sometimes release due to movement of the release cable. That scared me. Has anyone else split the release mechanism on the canopy so both the left and right side need to be released independently? This way, one has 4 "disengagements" before release, accidental or whatnot. I prefer this to the single "disengagement" of the 650. Attempting to re-latch one side necessarily unlatches the other since it is a solid arm. Correct? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224723#224723 .matronics.com/viewtopic.php?p=224723#224723> http://www.matronics.com/Navigator?Zenith601-List m/Navigator?Zenith601-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: Jan 14, 2009
I have the old style canopy latches. I have never had one side of m canopy unlatch as I was trying to latch the other. There is a bit of slack in the cable that needs to be taken up before the canopy will unlatch. The two sides latch up independently of each other. If I was going to use the new style latch, I would definitely alter the design to allow each side to latch independently of the other. All it would take is slots on one end of the tie bars linking the latch hooks to the torque tube and springs pulling each hook towards the latched position. On Jan 14, 2009, at 11:50 AM, Sabrina wrote: > When I was building my canopy frame, I was amazed how tinkering with > one side would often release the other side. > > I would lock one side, leave the other up. In attempting to lock > the remaining side the original side would sometimes release due to > movement of the release cable. That scared me. > > Has anyone else split the release mechanism on the canopy so both > the left and right side need to be released independently? > > This way, one has 4 "disengagements" before release, accidental or > whatnot. > > I prefer this to the single "disengagement" of the 650. Attempting > to re-latch one side necessarily unlatches the other since it is a > solid arm. Correct? -- Bryan Martin N61BM, CH 601 XL, RAM Subaru, Stratus redrive. ________________________________________________________________________________
Subject: Dutch XL crash findings
Date: Jan 15, 2009
This is from the Dutch safety board
http://www.safetyboard.nl/publications/dsb/intermediate_warning_accident_with_mla.pdf Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224869#224869 ________________________________________________________________________________
Subject: VNE what is it on the XL?
Date: Jan 15, 2009
ZAC site is 180 mph /290kmh On my plans 162/ 260 kmh Any other sources ? That is a big difference so what is the real figure ?, I feel it is the lower one on the plans, so why ZAC say different? Kev Kit arrived November 21 Rudder, stab, elevator, flaps done. Finishing ailerons....wait to see if balance mod is coming! -------- Austria ............. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224873#224873 ________________________________________________________________________________
Date: Jan 15, 2009
Subject: Re: Dutch XL crash findings
> I wonder where the Dutch folks got this information. All the actual > accident reports I have read indicated structural failure for unknown > reasons. Apparently, the Dutch folks have different reports that indicate > overload and flutter. Or perhaps they are just making up these facts . . . They appear to have oulled it out of their...uhm...thin air. The good news is that they're at least back from vacation. -- Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml ________________________________________________________________________________
Date: Jan 15, 2009
Subject: Re: VNE what is it on the XL?
> ZAC site is 180 mph /290kmh > On my plans 162/ 260 kmh AMD has it as 140 knots, or 161.1 MPH. I don't know why the ZAC site has the higher figure, or why it was lowered. OTOH, I've never had mine over 125 KIAS, even in a power-on descent. The AMD Vno (top of the green arc) is 108 knots, or 124.3 MPH. -- Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml ________________________________________________________________________________
Date: Jan 15, 2009
> Or perhaps they did a "real" investigation, real actual dynamic stress > analysis thru computer animations If so, why didn't they say so? They probably didn't have time in the few days since they got back from vacation. -- Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml ________________________________________________________________________________
Date: Jan 15, 2009
What good is the data from the GPS in relation to previous over stressing of the frame? Yes it broke in level flight but it could well have been over stressed many times before and finally something went. Bit like and engine blowing up because 50 ours ago it was run low on oil and suffered accelerated wear. Sad but I suspect a similar outcome as the Yuba city crash .....undetermined cause. My 2 cents Kev -------- Austria ............. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224889#224889 ________________________________________________________________________________
Date: Jan 15, 2009
My original plans said 180 mph. At the same time the website said 180. The current plans say 162. When I fly it will be 162 in my plane. The plans are the plans and the website is marketing and doesn't get changed very often. Go with the plans. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224890#224890 ________________________________________________________________________________
Date: Jan 15, 2009
Has there been any official investigation that stated the flutter was the cause? If so I haven't seen it. The one official investigation that I have seen (Yuba City) specifically ruled out flutter. This paragraph... "Some investigations of these accidents revealed that the overload of the wings had different probable causes, for instance flutter in one or both wings." Should be replaced with... "An investigation of one of these accidents revealed that the overload of the wings caused the accident, and rumors have mentioned possibilities for instance flutter in one or both wings but was ruled out in the one accident investigated." -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224893#224893 ________________________________________________________________________________
Date: Jan 15, 2009
The Dutch are reasonable people. The report is a "warning", that the plane was not doing anything unusual and the wing simply broke off. Seems pretty obvious to me what they're saying. Regards, Jeff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224897#224897 ________________________________________________________________________________
Date: Jan 15, 2009
> The Dutch are reasonable people. The report is a "warning", that the plane > was not doing anything unusual and the wing simply broke off. > > Seems pretty obvious to me what they're saying. You are, however, assuming they're competent. Their conduct of this investigation very strongly suggests otherwise, from their departure on vacation at its very beginning to their utter ignoring of other investigations and their refusal to allow people who actually know things to participate. The final straw is their statement on the potential cause which, so far, is totally unsupported by any facts or even any documentation of their conjectures. -- Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml ________________________________________________________________________________
From: "David Mikesell" <skyguynca(at)skyguynca.com>
Date: Jan 15, 2009
Jay, I have all Zeniths plans and have built and flown the 601HD and a big fan of Zenith planes so please do not think that I am bashing. Now they did not list anything but the gps to give reference how they knew the plane was straight and level. I sure they did stress calculations and measurements and tons of stuff they did not list because it has nothing to do with publishing the conclusion. Lets not "read into" what is not there oh and if you know what day they came back from vacation and how many days they took off please list it and your source. Lets try to leave comments like that out of they conversation for their is no proof they just came back adn that they have been on vacation since the accident. How ever they have posted their report and I understand that the "601XL Club" (oh and i have 601XL plans too) is not happy with the findings. Well you have the right to challenge them with the Dutch investigating authorities, but you do not have the right to slander them and make statements insinuating that they did not do a investigation because they were on vacation and now just making stuff up to put in their "officail" report. David M. Petaluma, CA ----- Original Message ----- From: "Jay Maynard" <jmaynard(at)conmicro.com> Sent: Thursday, January 15, 2009 6:02 AM Subject: Re: Zenith601-List: Dutch XL crash findings > >> Or perhaps they did a "real" investigation, real actual dynamic stress >> analysis thru computer animations > > If so, why didn't they say so? They probably didn't have time in the few > days since they got back from vacation. > -- > Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com > http://jmaynard.livejournal.com http://www.tronguy.net > Fairmont, MN (KFRM) (Yes, that's me!) > AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml > > > ________________________________________________________________________________
Date: Jan 15, 2009
> but you do not have the right to slander them and make statements > insinuating that they did not do a investigation because they were on > vacation and now just making stuff up to put in their "officail" report. Sorry. Until they show their work, all we have to go on is their bald statements - and that includes their statement that they would not be able to do anything for some time after grounding the entire fleet because they were going on vacation. We would not stand for that in the US; I have no idea why the Europeans put up with it. In any event, that greatly harms their credibility, because it is so completely unprofessional of them. -- Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml ________________________________________________________________________________
Date: Jan 15, 2009
> The AMD planes (I believe) have Continental engines, piano hinge ailerons, > and dual sticks. This is correct. -- Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml ________________________________________________________________________________
Date: Jan 15, 2009
>From the report it would appear that the wing was not bent or broken just the attachments to the fuselage. As I have a 601HD I do not know how the 601 XL wings are attached. Does anyone know what they are talking about "upper and lower reinforcement of the right hand wing main spar"? Are these parts of th e fuselage (my: 6F-6-1 and -3)? Jerry of Ga DO NOT ARCHIVE "The right hand wing folded up and backwards in flight, whereby the upper lining of the wing hit the upper side of the fuselage, behind the canopy. =B7 The right hand wing did not break. =B7 The upper reinforcement of the right hand wing main spar had been buckl ed and twisted, slightly forward of the wing-fuselage attachment. =B7 The lower reinforcement of the right wing main spar had been twisted ju st in front of the wingfuselage attachment." In a message dated 1/15/2009 10:59:34 A.M. Eastern Standard Time, skyguynca(at)skyguynca.com writes: --> Zenith601-List message posted by: "David Mikesell" Jay, I have all Zeniths plans and have built and flown the 601HD and a big fan of Zenith planes so please do not think that I am bashing. . **************Inauguration '09: Get complete coverage from the nation's ________________________________________________________________________________
Date: Jan 15, 2009
jmaynard wrote: > The final straw is their statement on the potential cause > which, so far, is totally unsupported by any facts or even any documentation > of their conjectures. This is what they said in the Preliminary Conclusion, perhaps your version of English and mine are vastly different. It still reads the same to me, but maybe I'm a dummy ...? Jeff The investigation conducted by the Dutch Safety Board into the cause of this accident is ongoing. Nevertheless the Board, with regard to the seven similar accidents elsewhere in the world, and in anticipation of the definitive outcome of its investigation of this accident, holds the opinion that it is appropriate to warn all those who are directly or indirectly involved in the operation of this type of aircraft for the apparent risks in doing so. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224921#224921 ________________________________________________________________________________
Date: Jan 15, 2009
How many wing failures in the US where the original builder/mfg installed the wings as flown on the day of the crash where there is no finding of pilot error or unauthorized maintenance? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224946#224946 ________________________________________________________________________________
Date: Jan 15, 2009
I have said all along it was flutter and I still believe and (Hope) it is. I also believe it is exaggerated when the cable tensions are not correct. I adjusted the one I flew back to Florida and found the tension to be 15 lbs and if anyone wants to know it took 31/2 turns of all 3 turnbuckles to gain 32 lbs on the cables. I didn't measure the fine tuning of the balance cable. I will tell you that there was no difference whatsoever in the feel of the stick after the adjustment. Even though I knew they were right when we departed for Fl. you can bet your sweet ass I had my eye on the right aileron and it was in the back of my mind. I think the push pull tube is a great idea and it takes out the possibility of the cables being loose. Most don't have access to a cable tension meter and will just arbitrarily tighten them which could be just as bad. I don't know if balancing them will help or not but I wish they would have done that on the new 650 because it would have been the perfect time to do it. Along with adding push pull tubes. I am not of the opinion that all of the aircraft were over stressed either. If it had been 1 or 2 maybe but it would seem to me from watching testing of a wing until it failed there is some major distortion before it gives way to the stress and I just don't see where that would have gone un noticed during a pre flight. To say only the attach points of the wings were stressed with no other signs anywhere I just don't see. I also don't think that Zenith could ever take any position other than there isn't a problem because any other position would have attorneys beating down there door and we certainly don't want to see that. I am building them and will continue to build them and support them. That said, I am adding cherry max rivets to the first 3 aileron attach holes and making sure to have the proper cable tension at all times. These are my opinions and even though I have built 3 601's I am not saying I know anymore about this subject than the scratch builder on his first plane so take what I say as just that another opinion. Jeff Garrett Louisville Ky. 601XL N962T Aerolite Corvair 90% 601XL N524B Aerolite Corvair 155 Hrs 601XL N2257 Aerolite Corvair 85 Hrs _www.aeroliteproducts.com_ (http://www.aeroliteproducts.com/) _www.project601xl.com_ (http://www.project601xl.com/) _www.aerolite.camstreams.com_ (http://www.aerolite.camstreams.com/) Do not archive **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! cemailfooterNO62) ________________________________________________________________________________
Date: Jan 15, 2009
Jeff, What type of Cherrymax rivets are you using? I'm planning on using solid or Cherrymax in some areas, but I'm a bit confused by the different types (Aluminum, Monel, INCO). Thanks, Doug Sire Billings, MT Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224964#224964 ________________________________________________________________________________
Date: Jan 15, 2009
skyguynca wrote: > I sure they did stress calculations and > measurements and tons of stuff they did not list because it has nothing to > do with publishing the conclusion. > > Lets not "read into" what is not there oh and if you know what day they came > back from vacation and how many days they took off please list it and your > source. > > Lets try to leave comments like that out of they conversation for their is > no proof they just came back adn that they have been on vacation since the > accident. > > How ever they have posted their report and I understand that the "601XL > Club" (oh and i have 601XL plans too) is not happy with the findings. Well > you have the right to challenge them with the Dutch investigating > authorities, but you do not have the right to slander them and make > statements insinuating that they did not do a investigation because they > were on vacation and now just making stuff up to put in their "officail" > report. > > David M. > Petaluma, CA > > --- First I'm with both of the Jay's these guys need to show their work if they are going to make a statement that this or any plane is unsafe. As far as slandering them them. They are the ones doing the slandering by not basing their statements on facts that they are willing to provide. Hell, they don't even tell what kind of GPS was in the plane. For all we know it was some $50 special with accuracy of +/- 1000ft. I don't know that is the case but this quarter ass report sure didn't tell me otherwise. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224976#224976 ________________________________________________________________________________
Date: Jan 15, 2009
I pretty much agree with most of the criticism I'm reading here of the report. Read superficially, it sounds as though one is being given a real report with facts. Read carefully, particularly with some knowlege of what facts there are, it reads like a poorly researched way of closing the discussion, substituting careful grammer and sentence structure for thorough analysis. I'm forced to wonder if the author(s) weren't under pressure to get something out, having a lot of catchup to do after returning from vacation. Please understand I'm not picking on some one government - this sort of thing happens all over. There are times to put a subject to sleep with carefully chosen words, because it does not merit too much examination, and the author is running out of time. Heck, I've done it! But this isn't one of those times. We really need international cooperation, and more detailed information than we are being given. ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Jan 15, 2009
This is from the Zenair Europe site Neither the preliminary accident report nor the Dutch grounding-orders makes reference to the wreckage of PH-4B6. Although for the last three months, Zenair has received no word of new findings from the Dutch Safety Board, factory representatives were recently permitted to inspect the remains of the accident aircraft. Upon careful first-hand examination, we feel sufficient new evidence comes to light that suggests a very different sequence of events than the one proposed by witnesses. The investigation is on-going and we do not know what is currently being considered by investigators, nevertheless, we remain puzzled as to why the official position has not been revised and why the grounding orders remain unchanged. Three observations in particular seem especially significant. This is what we saw: 1) The leading edge D-cells of both wings of the accident aircraft display remarkable similarities: From root to tip, the front skins of both wings show even and continuous impact damage consistent with straight-on impact. The main landing gear and nose gear strut were undamaged (one wheel fairing actually remains attached). This, along with the nature of the overall damage suggests that the aircraft likely contacted the water straight-on, but more upside down (wheels pointing up) than right-side up. 2) In the area where it passes through the fuselage, the aileron control cable of the wing that supposedly failed in the air is still cleanly threaded through its plastic fairlead which is still firmly riveted (paint is not even cracked) to the fuselage side. The aileron belcranks of both wings are undamaged and still properly secured. In other accidents where a wing was known to have folded in flight, aileron control cables ripped through the thin fuselage sides (in the direction of the folding wing) and the aileron belcranks were torn loose from the wing structure. 3) At the rear spar attachment location, the fuselage tab was intact, as was the attachment bolt. It is the rear spar web which failed, but not as we have seen in other accidents where the failure has been attributed to static overload. In this case, the remaining portion of the spar channel and doubler (a washer-like piece still attached under the tight bolt-joint) shows evidence of failure from bending and tearing - rather than from straight up, down or out shear forces. Considered together (the even crushing of both wings, the absence of aileron cables ripping through the aluminum fuselage sides and intact belcranks, and the failure mode of the wings rear attachment point), the wreckage seems to tell its own story as to the configuration of the aircraft just prior to impact Read this topic online here: http://forums.matronics.com/viewtopic.php?p=224986#224986 ________________________________________________________________________________
Subject: My Corvair Engine Arrived!
Date: Jan 15, 2009
To my delight, a nice guy in a truck from Yellow Transportation helped me unload a crate with my name on it. Of course, I knew what was inside, but since it is less than a month since Christmas, (and we still have our decorations up) I pretended to be surprised to find a shiny "new" Corvair engine gently strapped inside. Here are a couple of pics... My plane is going to need to go to the airport soon! Jon Burns Little Elm, Tx Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225011#225011 Attachments: http://forums.matronics.com//files/img_0052_844.jpg http://forums.matronics.com//files/img_0049_191.jpg http://forums.matronics.com//files/img_0043_774.jpg ________________________________________________________________________________
Date: Jan 16, 2009
dougsire wrote: > > What type of Cherrymax rivets are you using? I'm planning on using solid or Cherrymax in some areas, but I'm a bit confused by the different types (Aluminum, Monel, INCO). > Doug - For what it's worth, you might be better off to buy a rivet gun and use solids. The Cherrymax rivets are good rivets, no doubt. But they are so costly you won't shoot very many before you have out spent the cost of a gun. I bought a gun, and shot a lot of solids using a hammer with a polished head as a bucking bar at pretty low cost. I've bought a couple bucking bars now, as I find it is more convenient. Solids are easy to shoot with just a little practice. The AD solids are stronger than the CherryMax as well, and you can buy them by the pound really cheap. Regards, Jeff Hays Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225102#225102 ________________________________________________________________________________
Date: Jan 16, 2009
A couple of quick observations... 1. Based on my career experience as a Washington DC bureaucrat, that notice reads like something written by one person with little coordination and less preparation. My government-trained antenna says , "Pure amateur result from a staff guy under pressure" He's really got nothing to backup anything. 2. Based on my observations of my own GPS systems (Garmin 196 and Garmin 396) even when the antennas are sitting motionless on the back deck of my house, the GPS-derived altitude is all over the place. And, of course, when flying they show ground speed. So, I have a hard time putting a lot of faith in the GPS record to determine the altitude variations, air speed, and G-loading of the aircraft in the few seconds before the accident. Would some "Dutch rolls" (pardon the pun) show up on a GPS record? (Don't go off on that, it's mostly a bad joke) I file the Dutch notice under trivial distractions not helpful to the question. -- Frank Derfler Flying an AMD-made 601XL over the Florida Keys -- Twitter! Follow me at http://Twitter.com/Fderfler See my new Novel, "A Glint in Time" at http://GreatGuyBooks.com. See my discussion of All the Guy Toys that aren't (clearly) illegal or (blatantly) immoral at http://mostlyflying.com Anybody who READS (anybody out there?) See www.greatguybooks.com ________________________________________________________________________________
Date: Jan 16, 2009
Subject: Re: Zenith601-List Digest: 39 Msgs - 01/15/09
Hello Jon, Looks great such a shiny 'new' engine. Could you provide us with some additional information: manufacturer, weight, time since delivery and price (if not too private). Regards, Maarten, 601xl, 6484 Plans building, wings completed, just started on fuselage > Subject: Zenith601-List: My Corvair Engine Arrived! > From: "jonaburns" <lsapilot(at)hotmail.com> > > > To my delight, a nice guy in a truck from Yellow Transportation helped me unload > a crate with my name on it. > > Of course, I knew what was inside, but since it is less than a month since Christmas, > (and we still have our decorations up) I pretended to be surprised to find > a shiny "new" Corvair engine gently strapped inside. > > Here are a couple of pics... ________________________________________________________________________________
Date: Jan 16, 2009
Subject: Cowling winterization plate
I need to do something to make my O-200 happier in the winter. I haven't seen oil temperatures above 140 F since it got cold around here. that's making me nervous about not boiling the condensation out of the oil. The O-200, at least in the AMD Zodiac, does not have an oil cooler to cover up. That means I need to restrict airflow through the cowling. I've spoken to an owner in Crookston, Minnesota, and he recommended that I first make a plate to cover the air exit from the bottom of the cowling, and then add plates at the inlet only if that doesn't do enough. I've got no problems with that plan in general. The question I have, however, is simple: How do I attach the plate? The forward end would need to attach somewhere inside the lower cowl, forward of the opening. That's easily enough done: holes in the cowl itself, and rivnuts in the plate. The fun comes in attaching the rear of the plate to the firewall. Suggestions? More rivnuts at the bottom of the firewall itself, or are there better ideas? -- Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml ________________________________________________________________________________
Subject: Re: Cowling winterization plate
Date: Jan 16, 2009
The TCM manual allows you to run at 4 quarts of oil rather than 6. That will increase your oil temp. Steep climbs at full power will do the same. Modifying an S-LSAs does not sound like the answer. Another option: Royco has a flight ready preservative oil that fights the corrosion you are worried about. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225208#225208 ________________________________________________________________________________
Date: Jan 16, 2009
Hi Jay, First, I would stay away from rivnuts. They have a horrible reputation for spinning in their holes so you can't unfasten the screws later on. If you feel you must use threaded fasteners, then you should learn about nut-plates or just use bolts and nuts. You might do a lot better to use ordinary pulled rivets. I suggest you practice a little at installing them and drilling them out when you want them to be gone. To be consistent with the construction of the plane you should use Avex rivets (get a fellow Zenith builder to donate a handful of them - we all have lots of extras). For something like these air baffles you would probably be ok with hardware store rivets. Perhaps 1/8" aluminum short or medium length. You might start with .025 or .016 6061-T6 sheet metal and drill first with #40 pilot drill and then line-drill with #30 for the 1/8" rivets. (Line drilling is when you drill through both connecting sheets at the same time. This gets the holes perfectly lined up.) I'd suggest leaving the firewall alone and using the skin behind the firewall for your new baffle attachment. Good luck, Paul XL getting close Good luck, Paul At 05:39 PM 1/16/2009, you wrote: > >I need to do something to make my O-200 happier in the winter. I haven't >seen oil temperatures above 140 F since it got cold around here. that's >making me nervous about not boiling the condensation out of the oil. > >The O-200, at least in the AMD Zodiac, does not have an oil cooler to cover >up. That means I need to restrict airflow through the cowling. I've spoken >to an owner in Crookston, Minnesota, and he recommended that I first make a >plate to cover the air exit from the bottom of the cowling, and then add >plates at the inlet only if that doesn't do enough. I've got no problems >with that plan in general. The question I have, however, is simple: How do I >attach the plate? > >The forward end would need to attach somewhere inside the lower cowl, >forward of the opening. That's easily enough done: holes in the cowl itself, >and rivnuts in the plate. The fun comes in attaching the rear of the plate >to the firewall. Suggestions? More rivnuts at the bottom of the firewall >itself, or are there better ideas? >-- >Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com >http://jmaynard.livejournal.com http://www.tronguy.net >Fairmont, MN (KFRM) (Yes, that's me!) >AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml > ________________________________________________________________________________
Date: Jan 16, 2009
> The TCM manual allows you to run at 4 quarts of oil rather than 6. That > will increase your oil temp. My engine likes to run about 4-1/2 quarts anyway...mor than that just gets blown out the breather. > Steep climbs at full power will do the same. That's how I'm getting up to 140. :-) > Modifying an S-LSA???s does not sound like the answer. This is with permission of AMD; they want a drawing of whatever I come up with so they can offer it as an option. > Another option: Royco has a flight ready preservative oil that fights the > corrosion you are worried about. That might not be a bad idea at all. -- Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml ________________________________________________________________________________
Date: Jan 16, 2009
"I am adding cherry max rivets to the first 3 aileron attach holes" Jeff Great idea... at least one, maybe 10 more with gussets... Of course, if I were offered a set of free flex hinge ailerons, they would be on my aircraft before the next flight... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225212#225212 Attachments: http://forums.matronics.com//files/gussets_679.jpg ________________________________________________________________________________
Date: Jan 16, 2009
Do you have CHT and EGT gauges? What are they reading? Rather than closing off the exit, changing the lower cowl's lip will dramatically change the air flow. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225214#225214 Attachments: http://forums.matronics.com//files/exit_150.jpg ________________________________________________________________________________
Date: Jan 16, 2009
> Do you have CHT and EGT gauges? What are they reading? They're normal: CHTs in the mid to upper 200s, dropping below the 200 F yellow line when I power back for maneuvers (I'm working on a CFI-SP); EGTs are in the 1300s, and can easily be raised with a little leaning. It's just the oil temperature that's worrying me. > Rather than closing off the exit, changing the lower cowl's lip will > dramatically change the air flow. True...but my goal is to have something that can easily be installed and removed as necessary, similar to the winterization plates on other aircraft. What would be really nice is if it had cowl flaps... -- Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml ________________________________________________________________________________
Date: Jan 16, 2009
I've been trying to think of non-destructive ways to block off the air flow out of your cowl. One idea is to take some sheet metal, or if you must poster-board, and tape it temporarily in place with good old duct tape. You can cut a sheet to size and slide it into the cowl exit hole and then tape the front in place. Then tape the back to the cabin floor. This might not give a good final fix for your winter cooling issue, but it might lead to a good one. Paul XL getting close At 07:11 PM 1/16/2009, you wrote: > > Rather than closing off the exit, changing the lower cowl's lip will > > dramatically change the air flow. > >True...but my goal is to have something that can easily be installed and >removed as necessary, similar to the winterization plates on other aircraft. >What would be really nice is if it had cowl flaps... ________________________________________________________________________________
Date: Jan 16, 2009
> One idea is to take some sheet metal, or if you must poster-board, and > tape it temporarily in place with good old duct tape. You can cut a sheet > to size and slide it into the cowl exit hole and then tape the front in > place. Then tape the back to the cabin floor. Cabin floor? The only thing at the back of the cowl exit is the firewall. Still, you've hit on how I plan to dummy it up, although I plan to use something besides duct tape that will come off without leaving a residue behind. Ain't no way I'm gonna ever use duct tape on my airplane. -- Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml ________________________________________________________________________________
Date: Jan 16, 2009
There is at least one oil sump blanket that is STC'd for the O-200A in flight. Use that and then pre-heat your oil with a plug in dip stick heater that is removed before flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225221#225221 ________________________________________________________________________________
Date: Jan 16, 2009
> There is at least one oil sump blanket that is STC'd for the O-200A in > flight. Use that and then pre-heat your oil with a plug in dip stick > heater that is removed before flight. I've got a Tanis on my engine, and use it religiously when the temperature is below 40 F. It includes an oil sump heater. Do you think blocking off the sump alone will get the temperature back up? -- Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com http://jmaynard.livejournal.com http://www.tronguy.net Fairmont, MN (KFRM) (Yes, that's me!) AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml ________________________________________________________________________________
Date: Jan 16, 2009
If you do use any riv-nuts, what I do is to install them with loctite 262, or equilivant, around the head/O.D. Has worked for me. "............I would stay away from rivnuts. They have a horrible reputation for spinning in their holes so you can't unfasten the screws later on. If you feel you must use threaded fasteners, then you should learn about nut-plates or just use bolts and nuts................" Tony Graziano ________________________________________________________________________________
Date: Jan 16, 2009
Try 200 mph tape from Wal*Mart. This is the stuff NASCAR racers use for the same sort of thing. I also use a lot of it while building my XL. It only looks like duct tape. Duck brand is the best, in my opinion, and Wal*mart has it. If there is any problem removing the adhesive, just use a little lacquer thinner on a rag to wipe it off. The cabin floor is attached to the bottom of the fire wall. This would be a nice place to tape the aft end of a sheet of metal to hold it in place for a test flight. In no event would I drill holes in the firewall. That is just asking for trouble - not to mention dull drill bits. I was thinking two or three sheets taped in place in the corners and middle of the cowl exit hole would work well. You can adjust the size of each piece to get the amount of cooling reduction you want. After you have found a nice size opening to have for your own personal climate you can rivet some aluminum in the same place. Paul At 07:28 PM 1/16/2009, you wrote: >Cabin floor? The only thing at the back of the cowl exit is the firewall. >Still, you've hit on how I plan to dummy it up, although I plan to use >something besides duct tape that will come off without leaving a residue >behind. Ain't no way I'm gonna ever use duct tape on my airplane. ________________________________________________________________________________
Date: Jan 16, 2009
the original sump blankets were asbestos, the new ones? most cannot be flown... it should keep your heat in, there are auto dipstick heaters in varying wattages, pick the one that works best... just remove it before flight... as for duct tape, I have seen ferry permits signed off with duct taped repairs after a bird strike... if it falls off, it won't hurt anyone, same for the styrofoam... at KPWK, many a plane was winterized with duct tape... www.redgreen.com :o) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225226#225226 ________________________________________________________________________________
Date: Jan 16, 2009
Subject: webcam is up
I hope to get a lot done tonight.... hope to light up the panel and run the brake lines. _www.aerolite.camstreams.com_ (http://www.aerolite.camstreams.com) Jeff **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! cemailfooterNO62) ________________________________________________________________________________
Date: Jan 17, 2009
Only use lacquer thinner or acetone if the finish can take it...don't ask h ow I know these things... David L. Downey Harleysville-(SE) PA, USA --- On Fri, 1/16/09, Paul Mulwitz wrote: From: Paul Mulwitz <psm(at)att.net> Subject: Re: Zenith601-List: Re: Cowling winterization plate Date: Friday, January 16, 2009, 10:43 PM ...If there is any problem removing the adhesive, just use a little lacque r thinner on a rag to wipe it off. =0A=0A=0A ________________________________________________________________________________
Date: Jan 17, 2009
To get duct tape adhesive off your paint... take a strip of the same type of duct tape, take a knife and scrape off the adhesive, form that adhesive into a little ball, use that ball on your painted surface, it picks up the old adhesive like magic. My grandpa, God rest his soul, used to call it the "Hair of the Dog that bit me." And yes, he liked Red Green a lot too, what would you expect from someone born and raised in Green Bay. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225293#225293 ________________________________________________________________________________
Date: Jan 17, 2009
Subject: Duct tape removal
There's a product called "GOO GONE" which works great. Test on paint before using. Get it at Hobby shops like Michael's etc. To get duct tape adhesive off your paint... take a strip of the same type of duct tape, take a knife and scrape off the adhesive, form that adhesive into a little ball, use that ball on your painted surface, it picks up the old adhesive like magic. My grandpa, God rest his soul, used to call it the "Hair of the Dog that bit me." And yes, he liked Red Green a lot too, what would you expect from someone born and raised in Green Bay. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225293#225293 ________________________________________________________________________________
Date: Jan 17, 2009
Jay has an S-LSA. I can't imagine AMD approving any appliance for the engine that has not been STC'd as to that engine. Just their changing out the FAA-PMA spark plugs for Auto plugs required a lot of testing and analysis that Jay is not in the position to do re: a non-STC'd oil sump blanket. You are correct in pointing out that just because it is STC'd does not mean an IA or AP can install it on the S-LSA, only AMD can approve such an installation. Their exhaust configuration my not allow for such an installation. It is different story for the airframe--they built it and could approve anything. Question, can Jay put oil additives in an S-LSA that are not on the approved list of lubricants from AMD? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225312#225312 ________________________________________________________________________________
Date: Jan 17, 2009
Right on, Paul---I used rivnuts for the forward upper skin, and, 78 rivnuts leter, found that almost 1/4th of them spun. There;s a little protrusion on each one that allegedly digs into the side of the hole and is supposed to hold it. It don't. 78 nut plates later, a guy suggested dipping each rivnut in epoxy or Proseal to keep them from spinning. Ah, yes, the sequence of life: 1. You have a problem. 2. You come up with a solution. 3. It's the wrong solution. 4. You correct the solution. 5. Some guy comes along with an easier solution. Paul Rodriguez ----- Original Message ----- From: Paul Mulwitz<mailto:psm(at)att.net> To: zenith601-list(at)matronics.com Sent: Friday, January 16, 2009 8:23 PM Subject: Re: Zenith601-List: Cowling winterization plate > Hi Jay, First, I would stay away from rivnuts. They have a horrible reputation for spinning in their holes so you can't unfasten the screws later on. If you feel you must use threaded fasteners, then you should learn about nut-plates or just use bolts and nuts. You might do a lot better to use ordinary pulled rivets. I suggest you practice a little at installing them and drilling them out when you want them to be gone. To be consistent with the construction of the plane you should use Avex rivets (get a fellow Zenith builder to donate a handful of them - we all have lots of extras). For something like these air baffles you would probably be ok with hardware store rivets. Perhaps 1/8" aluminum short or medium length. You might start with .025 or .016 6061-T6 sheet metal and drill first with #40 pilot drill and then line-drill with #30 for the 1/8" rivets. (Line drilling is when you drill through both connecting sheets at the same time. This gets the holes perfectly lined up.) I'd suggest leaving the firewall alone and using the skin behind the firewall for your new baffle attachment. Good luck, Paul XL getting close Good luck, Paul At 05:39 PM 1/16/2009, you wrote: > > >I need to do something to make my O-200 happier in the winter. I haven't >seen oil temperatures above 140 F since it got cold around here. that's >making me nervous about not boiling the condensation out of the oil. > >The O-200, at least in the AMD Zodiac, does not have an oil cooler to cover >up. That means I need to restrict airflow through the cowling. I've spoken >to an owner in Crookston, Minnesota, and he recommended that I first make a >plate to cover the air exit from the bottom of the cowling, and then add >plates at the inlet only if that doesn't do enough. I've got no problems >with that plan in general. The question I have, however, is simple: How do I >attach the plate? > >The forward end would need to attach somewhere inside the lower cowl, >forward of the opening. That's easily enough done: holes in the cowl itself, >and rivnuts in the plate. The fun comes in attaching the rear of the plate >to the firewall. Suggestions? More rivnuts at the bottom of the firewall >itself, or are there better ideas? >-- >Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com> >http://jmaynard.livejournal.com http://www.tronguy.net> >Fairmont, MN (KFRM) (Yes, that's me!) >AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml> > http://www.matronics.com/Navigator?Zenith601-List m/Navigator?Zenith601-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: Jan 17, 2009
Sabrina, Are those your gussets on the outside of the skin? I read the print that the gussets were inside the skin. They are represented by a hidden line and that usually indicates behind the outer material. -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-)
http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225426#225426 ________________________________________________________________________________
Date: Jan 17, 2009
Good point Ron... see attached... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225430#225430 Attachments: http://forums.matronics.com//files/gussetsv2_466.jpg ________________________________________________________________________________
Subject: Rear Elevator trim deflection
Date: Jan 18, 2009
In the plans on page 6-T-6 the up and down deflection of the trim tab is stated as 20 up and 40 down how ever in the pictures that came on the CD that came with the plans it states 30 up and 30 down. I am aware of the new limits for the rear elevator put out from Zenith but has there been any changes to the trim deflection. Any suggestions. Thank you Ianrat Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225447#225447 ________________________________________________________________________________
Subject: VEDIO AND AUDIO RECORDING
Date: Jan 18, 2009
Hi all I am looking for a way to record my first flights and wondering how to get the audio to pick up more than just engine noise. There is a something called a "patch cord cockpit voice recorder"pn: 13-01456. Any body out there using this or have other ideas thanks Glenn -------- 601XL N676L reserved ALMOST DONE CHESAPEAKE VA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225576#225576 ________________________________________________________________________________
Subject: Re: Rear Elevator trim deflection
Date: Jan 18, 2009
No changes that I'm aware of. The prints are what I follow and mine are dated 8/05 for 6T6. The on-line builder site updates don't state any changes either for the trim tab 20 degrees up and 40 degrees down. >From what I've learned about things the prints and a cross check of the print updates are what you need to follow. If you find a mistake or can't quite determine the answer, post a note here or call Zenith for help. -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225588#225588 ________________________________________________________________________________
Date: Jan 18, 2009
Subject: Re: VEDIO AND AUDIO RECORDING
In a message dated 1/18/2009 9:24:23 P.M. Eastern Standard Time, gljno10(at)hotmail.com writes: patch cord cockpit voice recorder Glenn, Here is a suggestion that I have used while doing phase one testing on several different experimental aircraft, including the 601XL that the EAA chapter in Williamsburg (Chapter 156) built. Get yourself a voice activated digital recorder and a lapel microphone. The one I have came from Radio Shack about four years ago. Place the lapel mic (they are very small) in one of the ear cups of your headset. Turn on the recorder in the voice activation mode and be sure the aircraft intercom is also on. Now anything that you hear in your headset will activate the digital recorder. I suggest you also "talk to yourself" to record any test data (engine data or flight data) that you want to record during the flight for later playback and test analysis. And yes, there is also a patch cord adapter that we used in fighters (I flew F-4s for 28 years, so this was many years ago). When we wanted to record an air to air engagement we carried a small tape recorder in the G suit pocket and turned on the tape recorder before each engagement. Being able to replay each engagement before the debriefing helped us remember specific things we wanted to debrief. Blue Skies, Buz Rich **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! cemailfooterNO62) ________________________________________________________________________________
Date: Jan 18, 2009
Glenn, Let me add one more comment to my last message since your subject line mentioned Video and audio recording. Of course, my previous comments had to do with audio recording. As to video recording, I recommend not trying to do any video recording if you are thinking about any kind of hand held camera. Your hands will be busy enough just flying the airplane during any testing. So keep the hands on the stick and throttle. Now if you have a helmet mounted camera or something that you can set up that you don't have to touch during the flight - OK. Blue Skies, Buz Rich EAA Flight Advisor and Technical Counselor Williamsburg, VA EAA chapters 156 and 1377 **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! cemailfooterNO62) ________________________________________________________________________________
Subject: Aileron gussets
Date: Jan 18, 2009
Hi all , maybe I am missing something here but is there any reason why not to fit the gussets on the out side of the skin? I would add 2 more rivets on the open sides to pull up the skins. I have seen this on big planes . Kev -------- Austria ............. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225622#225622 ________________________________________________________________________________
Date: Jan 19, 2009
On the disk under the section 6-T-6 the first page is a copy of the plans. It is dated the 08/05 the same as the printed copy. That is why i asked if there was any updated info. Due to the time difference from the USA to Australia i thought i would try the forum instead of waiting until Zenith opens next week. Thank you Ian Ratcliffe Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225632#225632 ________________________________________________________________________________
Date: Jan 19, 2009
Thanks everyone I just read the article in sport aviation and was really thinking that was the way to go. Does that also pick up when I key the mike button to transmit? If so that's perfect I plan to hard mount the camera over the baggage area and turn it on before I start the engine and turn it off when I shut it down. Thanks again Glenn -------- 601XL N676L reserved ALMOST DONE CHESAPEAKE VA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225726#225726 ________________________________________________________________________________
Date: Jan 19, 2009
FYI, I don't use the CD. I always get the most current information from the Zenith builders website. I have just started work on the fuselage and just printed out all the 6B pdf files from the web site. I check that and the print updates list when I start a new section of the build. -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225780#225780 ________________________________________________________________________________
Date: Jan 19, 2009
Hi, Glenn. When we needed cockpit audio for aviation marketing videos, that's exactly what we did. A small Radio Shack bullet mike taped into the earcup and plugged into our camera worked perfectly, getting both the radio transmissions and the attenuated cockpit background noise. If you can hear yourself transmit via the comm radio's sidetone, it will be picked up by the mike as well. Good luck! Rick Lindstrom First Light Media -----Original Message----- >From: GLJSOJ1 <gljno10(at)hotmail.com> >Sent: Jan 19, 2009 1:39 PM >To: zenith601-list(at)matronics.com >Subject: Zenith601-List: Re: VEDIO AND AUDIO RECORDING > > >Thanks everyone > >I just read the article in sport aviation and was really thinking that was the way to go. Does that also pick up when I key the mike button to transmit? If so that's perfect > >I plan to hard mount the camera over the baggage area and turn it on before I start the engine and turn it off when I shut it down. >Thanks again > >Glenn > >-------- >601XL N676L reserved >ALMOST DONE >CHESAPEAKE VA > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=225726#225726 > > ________________________________________________________________________________
Subject: Time to paint ?
Date: Jan 19, 2009
I just finished flying off my 40 hours on my 601HDS and everything is performing well. I'm starting to seriously think about painting and while I understand the core process (from reading), it is hard to just get a straight answer on what paint brands and produts to use with an HVLP gun that is geared for our 6061-T6 planes. For those that painted, do you have any product recommendations? Also, any tips? Thanks! Don Honabach 601HDS - N601DX Tempe, AZ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225817#225817 ________________________________________________________________________________
Date: Jan 20, 2009
Subject: Re: Time to paint ?
I am going to use a paint made by stewart systems, it is stc'd and best of all it is water based so you don't have to worry about breathing in the harmful paint fumes. The cost to paint a 601 is around $900.00 and that includes the primer and etch for the aluminum. here is there website _http://www.stewartsystems.aero/_ (http://www.stewartsystems.aero/) and here are some you tube video's showing how easy it is to spray. _http://www.youtube.com/watch?v=FI6G1cPX7gs&feature=channel_page_ (http://www.youtube.com/watch?v=FI6G1cPX7gs&feature=channel_page) _http://www.youtube.com/watch?v=TDoveEeQdfw&feature=channel_page_ (http://www.youtube.com/watch?v=TDoveEeQdfw&feature=channel_page) _http://www.youtube.com/watch?v=j3EDMqgRQxw&feature=channel_page_ (http://www.youtube.com/watch?v=j3EDMqgRQxw&feature=channel_page) Hope this helps Jeff Garrett Louisville Ky. 601XL N962T Aerolite Corvair 90% 601XL N524B Aerolite Corvair 155 Hrs 601XL N2257 Aerolite Corvair 85Hrs _www.aeroliteproducts.com_ (http://www.aeroliteproducts.com/) _www.project601xl.com_ (http://www.project601xl.com/) _www.aerolite.camstreams.com_ (http://www.aerolite.camstreams.com/) **************A Good Credit Score is 700 or Above. See yours in just 2 easy steps! cemailfooterNO62) ________________________________________________________________________________
Date: Jan 20, 2009
Hi Don, I feel your pain. Painting aluminum is a very tricky process. The problem is the oxide that forms almost immediately when the aluminum is exposed to air. It will keep any paint from sticking. There are a couple of ways to successfully get paint on aluminum. Both are reasonably expensive and require a bit of skill. No matter which way you go you should get some practice on some aluminum which is less important to you than your airplane before tackling the big job. Just like painting steel, several very thin coats work better than one thick one. The classic approach is to use two products called (I hope) Alumiprep and Alodine. These are chemical treatments that remove the oxide and leave a thin layer of ceramic material suitable for holding paint. The other way to start is to use a self-etch primer. This is a paint that includes an acid to etch its way through the oxide. It is generally easy to use but a bit expensive. The stuff I used is about $20 per quart. I haven't done my whole plane yet but probably would need about a gallon of the stuff to cover it. After either of the above processes you need a separate primer and top coat. The primer used these days is a two part epoxy based material the runs about $100 per gallon. It is very easy to use and covers very nicely. I use this stuff to protect steel parts without any top coat. For the top coat you can use either acrylic or polyurethane based product which also is a two part system. For any two part system you must mix carefully measured paint and hardener and let them sit for about 20 minutes before use. I have been using the acrylic for many reasons including cost and safety. The polyurethane is capable of producing a higher luster and is offered in more colors, but it is extremely toxic and has a reputation for being difficult to apply. The acrylic is more of an industrial grade automotive paint that is relatively easy to use. It is used by most paint shops for utility grade jobs, while the urethane is used for the expensive fancy jobs. You need to find the automotive paint store in your area that supplies all the good paint shops. In any case these are industrial grade materials which are way too dangerous for casual use. They require safety equipment including masks and gloves and careful handling. Read and heed the MSDSs. If you approach this task casually you could end up crippled or dead. You can use either a normal or HVLP spray system for this job. The HVLP is preferred because of higher paint percentage on your project while the overspray from the older systems wastes a lot of paint. Good luck, Paul XL getting close At 08:56 PM 1/19/2009, you wrote: > >I just finished flying off my 40 hours on my 601HDS and everything >is performing well. I'm starting to seriously think about painting >and while I understand the core process (from reading), it is hard >to just get a straight answer on what paint brands and produts to >use with an HVLP gun that is geared for our 6061-T6 planes. > >For those that painted, do you have any product recommendations? >Also, any tips? > >Thanks! >Don Honabach >601HDS - N601DX >Tempe, AZ ________________________________________________________________________________
Subject: No Canopy Gas Struts on 650 Canopy for XL...?
Date: Jan 20, 2009
Got my "650 Canopy Kit for XL" the other day. I uncrated it, and inventoried the contents. Everything checked off on the paper list was accounted for as it came out of the crate. There are no canopy gas struts. It's not that these are "missing" - they're not even on the pick list to begin with. They don't ship with the fuselage component kit. My first thought was that they were no longer needed with the new canopy, but when I started looking on the Zenith website (for example: http://www.zenithair.com/zodiac/608/60935.jpg ), I started seeing other pieces in the pictures that were also not included, like the green nyloil rub plates in the attached picture (below) of the 650 fuselage at Oshkosh. Question 1: I can't be the first builder to encounter this. What have the rest of you folks putting the 650 canopy on the XL done...? What else do I need to get that isn't included in the kit? Question 2: Another builder told me that Todd's was now making the new canopies, and that they shipped "unrolled". My 650 canopy (1/8" thick) arrived "rolled". There's no indication of a part number on it, but 65C3-3/65C3-4 is checked on the pick list. Here's a picture of the one I received: http://picasaweb.google.com/Patrick.Hoyt/PatsZodiac601XL#5293187921366289970 Did I get the correct canopy? I'm pretty sure I did, but I don't have anything to compare it against, so I don't know and am interested in what other builders at my stage are encountering. Thanks, - Pat -------- Patrick 601XL/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225834#225834 Attachments: http://forums.matronics.com//files/1_157.jpg ________________________________________________________________________________
Date: Jan 20, 2009
Hi Don, I painted my HDS after flying for a year and it was a long process getting it clean enough to paint. The paints most likely to serve best are acrylic enamel or urethane. The acrylic enamel is the least costly and easiest to do. Certainly closest to the urethane paints that dominate most of the high end aircraft. I did a water base urethane that required a lot of process and took from April thru November to complete. It's flame proof and the water captures the binders that would otherwise seek out your lungs and suffocate you. The paint has held up well with a small exception where a fuel fitting leaked and took a bit of paint with it. This also makes the point that touch up is just as complicated and painful with urethane as the original process. You need a lot of control to duplicate the original work. The acrylic enamel is a simpler process, recommended by the Bingilis books and sticks to anything. It also isn't as fussy about process so long as you concern yourself about flammability of this kind of paint. Dupont for the acrylic enamel and Aircraft Finishing Systems is for water-based urethane. I believe they have revised and simplified the process for painting the water-base urethane since I painted. If you need process and paint history, I've a long bit in my journal part 10, April thru November and a page that describes a home made paint booth and page on part handling wings and things in process. See link, www.macsmachine.com/html/paint.htm Good luck, Larry McFarland 601HDS at www.macsmachine.com dhonabach wrote: > > I just finished flying off my 40 hours on my 601HDS and everything is performing well. I'm starting to seriously think about painting and while I understand the core process (from reading), it is hard to just get a straight answer on what paint brands and produts to use with an HVLP gun that is geared for our 6061-T6 planes. > > For those that painted, do you have any product recommendations? Also, any tips? > > Thanks! > Don Honabach > 601HDS - N601DX > Tempe, AZ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=225817#225817 > > > ________________________________________________________________________________
Date: Jan 20, 2009
No tips here, but congratulations, Don. dhonabach wrote: > I just finished flying off my 40 hours on my 601HDS and everything is performing well. I'm starting to seriously think about painting and while I understand the core processes (from reading), it is hard to just get a straight answer on what paint brands and products to use with a HVLP gun that is geared for our 6061-T6 planes. > > For those that painted, do you have any product recommendations? Also, any tips? > > Thanks! > Don Honabach > 601HDS - N601DX > Tempe, AZ -------- Pavel CA Zodiac XL N581PM (Reserved) Stratus Subaru EA-81 Tail, flaps, ailerons, wings done, fuselage is on the table .... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225850#225850 ________________________________________________________________________________
Subject: Re: Dutch XL crash findings
Date: Jan 20, 2009
see latest on LAA website. Looks as if they are going to detail what they have found fairly soon. I guess they have found something or the grounding would be lifted now. http://www.lightaircraftassociation.co.uk/ front page news items. Andrew who got his 601UL fuselage back from the paintshop at the weekend. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225853#225853 ________________________________________________________________________________
Date: Jan 20, 2009
rans6andrew wrote: > see latest on LAA website. Looks as if they are going to detail what they have found fairly soon. I guess they have found something or the grounding would be lifted now. > > http://www.lightaircraftassociation.co.uk/ > > front page news items. > > YOu got that from this? > Update - Zenair Incident - 19th Jan 2009 > > LAA Engineering has been in close and productive contact with the designer, Chris Heintz, and we are nearing the end of our investigation. Members of the LAA Engineering Team will be meeting with Zenair Europe in the very near future to discuss some outstanding issues and move towards getting the type back in the air. You are obviously better at reading between the lines than I am. -------- W.R. "Gig" Giacona 601XL Under Construction See my progress at www.peoamerica.net/N601WR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225860#225860 ________________________________________________________________________________
Date: Jan 20, 2009
The "discussion of "outstanding issues" with Zenith Europe "might" be that their (Zenith Europe) interpretation of the physical evidence indicates the wings were probably still attached at time of impact. See below: Tony Graziano XL/Jab: N493TG; 462 hrs -------------------------------------- Update - Zenair Incident - 19th Jan 2009 LAA Engineering has been in close and productive contact with the designer, Chris Heintz, and we are nearing the end of our investigation. Members of the LAA Engineering Team will be meeting with Zenair Europe in the very near future to discuss some outstanding issues and move towards getting the type back in the air. ZENAIR EUROPE NEWS Update of January 9, 2009 Neither the preliminary accident report nor the Dutch grounding-orders makes reference to the wreckage of PH-4B6. Although for the last three months, Zenair has received no word of new findings from the Dutch Safety Board, factory representatives were recently permitted to inspect the remains of the accident aircraft. Upon careful first-hand examination, we feel sufficient new evidence comes to light that suggests a very different sequence of events than the one proposed by witnesses. The investigation is on-going and we do not know what is currently being considered by investigators, nevertheless, we remain puzzled as to why the official position has not been revised and why the grounding orders remain unchanged Three observations in particular seem especially significant. This is what we saw: 1) The leading edge D-cells of both wings of the accident aircraft display remarkable similarities: From root to tip, the front skins of both wings show even and continuous impact damage consistent with straight-on impact. The main landing gear and nose gear strut were undamaged (one wheel fairing actually remains attached). This, along with the nature of the overall damage suggests that the aircraft likely contacted the water straight-on, but more upside down (wheels pointing up) than right-side up. 2) In the area where it passes through the fuselage, the aileron control cable of the wing that supposedly failed in the air is still cleanly threaded through its plastic fairlead which is still firmly riveted (paint is not even cracked) to the fuselage side. The aileron belcranks of both wings are undamaged and still properly secured. In other accidents where a wing was known to have "folded" in flight, aileron control cables ripped through the thin fuselage sides (in the direction of the folding wing) and the aileron belcranks were torn loose from the wing structure. 3) At the rear spar attachment location, the fuselage tab was intact, as was the attachment bolt. It is the rear spar web which failed, but not as we have seen in other accidents where the failure has been attributed to static overload. In this case, the remaining portion of the spar channel and doubler (a washer-like piece still attached under the tight bolt-joint) shows evidence of failure from bending and tearing - rather than from straight "up", "down" or "out" shear forces. Considered together (the even crushing of both wings, the absence of aileron cables "ripping" through the aluminum fuselage sides and intact belcranks, and the failure mode of the wing's rear attachment point), the wreckage seems to tell its own story as to the configuration of the aircraft just prior to impact .----- Original Message ----- From: "rans6andrew" <andrewcattell(at)hotmail.com> Sent: Tuesday, January 20, 2009 10:10 AM Subject: Zenith601-List: Re: Dutch XL crash findings > > > see latest on LAA website. Looks as if they are going to detail what they > have found fairly soon. I guess they have found something or the > grounding would be lifted now. > > http://www.lightaircraftassociation.co.uk/ > > front page news items. > > Andrew > > who got his 601UL fuselage back from the paintshop at the weekend. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=225853#225853 > > > ________________________________________________________________________________
Date: Jan 20, 2009
actually I am privvy to a bit little more than you could read between the lines but I have been prevented from spilling the beans for "tact and diplomacy" reasons. Given the nature of the suspected problems I have been quite frustrated that nobody has been allowed to put the preliminary LAA investigation findings up on here. Even if they turn out to be wrong, preventing any further accidents until the proof is found would have been worth the inconvenience of a short grounding, IMHO. I did try to make a few of the members of this group think about the situation by highlighting the differences between the in-flight break up rates of the 601HD, HDS and UL models and the 601XL situation. I hoped that this would show them that something is not quite right with the XL and that it probably goes beyond aileron cable tension issues. This was posted under Re: 601 problems on 23 Dec 2008. If I have been wrong, flame me, I have tried to do what I think is right. Andrew. -------- A good way through building a 601UL with 912UL. Still flying Rans S6 with 503. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225868#225868 ________________________________________________________________________________
Subject: Macs Machine Website
Date: Jan 20, 2009
Larry... Are you out there, your site is acting up. I use it frequently, I have to compliment the your awesome website, it truly is a valuable resource for those of us who aspire to become airborne! Any idea as to when it may be back up. I am a little befuddled about a step and everytime I have a question and something doesn't look quite right I usually answer the question within 5 minutes of tinkering around and looking at your pics. Thanks for all of your hard work. Before beginning a new step I usually take a look at your site, some pics etc, then look at the drawings for specifics and then your site. Sometimes it just helps to have a picture (the fancy new xl drawings have pics) but for us HD and HDS folks, Macs website is our fancy schmancy photo manual. Again, I can't thank you enough for such a thoughoulghly usefull website. -------- One Rivet at a Time! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225895#225895 ________________________________________________________________________________
Date: Jan 20, 2009
On Tuesday 20 January 2009 11:37, rans6andrew wrote: > > > actually I am privvy to a bit little more than you could read between the > lines but I have been prevented from spilling the beans for "tact and > diplomacy" reasons. Given the nature of the suspected problems I have been > quite frustrated that nobody has been allowed to put the preliminary LAA > investigation findings up on here. Even if they turn out to be wrong, > preventing any further accidents until the proof is found would have been > worth the inconvenience of a short grounding, IMHO. > > I did try to make a few of the members of this group think about the > situation by highlighting the differences between the in-flight break up > rates of the 601HD, HDS and UL models and the 601XL situation. I hoped > that this would show them that something is not quite right with the XL and > that it probably goes beyond aileron cable tension issues. This was posted > under Re: 601 problems on 23 Dec 2008. Andrew, your logic was understood. The problem we may face is that the 601XLs here in the U.S. are not all necessarily built to the same standards as the 601XLs in the U.K. and Europe. I'm not sure here that we can throw all XLs and XL accidents into the same category. ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate ================================================ ________________________________________________________________________________
Date: Jan 20, 2009
I have painted many cars with acrylic enamel. It does take a little practice but is simple to use and the skills are not that difficult to master. Dupont Centari without the toxic optional urethane conversion hardener is my paint of choice. As long as you stick to solid colors and not metallic, pearl, mica, etc. it is very forgiving. Etching primer seems like the simple way to go as far as adhesion is concerned. Acid + chromic wash on a completed structure could leak chemicals inside closed structure and, if a water based topcoat is not used, risk moisture under rivets and seams, causing problems with the topcoat. Jim --- On Tue, 1/20/09, LarryMcFarland wrote: From: LarryMcFarland <larry(at)macsmachine.com> Subject: Re: Zenith601-List: Time to paint ? Date: Tuesday, January 20, 2009, 7:14 AM Hi Don, I painted my HDS after flying for a year and it was a long process getting it clean enough to paint. The paints most likely to serve best are acrylic enamel or urethane. The acrylic enamel is the least costly and easiest to do. Certainly closest to the urethane paints that dominate most of the high end aircraft. I did a water base urethane that required a lot of process and took from April thru November to complete. It's flame proof and the water captures the binders that would otherwise seek out your lungs and suffocate you. The paint has held up well with a small exception where a fuel fitting leaked and took a bit of paint with it. This also makes the point that touch up is just as complicated and painful with urethane as the original process. You need a lot of control to duplicate the original work. The acrylic enamel is a simpler process, recommended by the Bingilis books and sticks to anything. It also isn't as fussy about process so long as you concern yourself about flammability of this kind of paint. Dupont for the acrylic enamel and Aircraft Finishing Systems is for water-based urethane. I believe they have revised and simplified the process for painting the water-base urethane since I painted. If you need process and paint history, I've a long bit in my journal part 10, April thru November and a page that describes a home made paint booth and page on part handling wings and things in process. See link, www.macsmachine.com/html/paint.htm Good luck, Larry McFarland 601HDS at www.macsmachine.com dhonabach wrote: > > I just finished flying off my 40 hours on my 601HDS and everything is performing well. I'm starting to seriously think about painting and while I understand the core process (from reading), it is hard to just get a straight answer on what paint brands and produts to use with an HVLP gun that is geared for our 6061-T6 planes. > For those that painted, do you have any product recommendations? Also, any tips? > > Thanks! > Don Honabach > 601HDS - N601DX > Tempe, AZ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=225817#225817 > > > > > > > ________________________________________________________________________________
Subject: Re: Aileron gussets
Date: Jan 20, 2009
Nobody got an opinion on this? Amazing. kev -------- Austria ............. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225960#225960 ________________________________________________________________________________
Date: Jan 21, 2009
[/quote] Andrew, your logic was understood. The problem we may face is that the 601XLs here in the U.S. are not all necessarily built to the same standards as the 601XLs in the U.K. and Europe. I'm not sure here that we can throw all XLs and XL accidents into the same category. ============================================= Those who can, do. Those who can't, sue. ================================================ Jim B. Belcher BS, MS Physics, math, Computer Science A&P/IA Instrument Rated Pilot General Radio Telephone Certificate =================================================[/quote] the thing is: at the moment nobody seems to know if the European and US 601XLs are built to the same standards. Until the investigation findings are made public the only way YOU can tell if YOUR aircraft is one of the bad ones is by having it come apart in flight. Not a way of finding out that I would choose. Andrew. -------- A good way through building a 601UL with 912UL. Still flying Rans S6 with 503. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225964#225964 ________________________________________________________________________________
Date: Jan 21, 2009
Kevin I put gussets on the outside. Real easy to do, looks O.K. But it is easy to open a couple of rivets and slip them under the skin and close it up also. I think it is worth doing no matter which way. Al Rupp New York -------------- Original message from "K Dilks" : -------------- > > Nobody got an opinion on this? Amazing. > kev > > -------- > Austria ............. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=225960#225960 > > > > > > > > > > ________________________________________________________________________________
Date: Jan 21, 2009
Al, Do you have piano hinge or flex hinge ailerons? Did you add them per the Zenith plans aft of the aileron hinge or did you tie the aft aileron hinge portion to the ribs? Did you use A4 or AS5 rivets on the inboard aft attach rivet position? Sabrina Read this topic online here: http://forums.matronics.com/viewtopic.php?p=225985#225985
December 28, 2008 - January 21, 2009
Zenith601-Archive.digest.vol-af
