Zenith601-Archive.digest.vol-an
May 16, 2010 - July 11, 2010
      ----- Original Message -----
From: Karl <mailto:jfowler120(at)verizon.net> Polifka
Sent: Sunday, May 16, 2010 7:38 AM
Subject: Re: Zenith-List: Alieron Trim
FYI -- after a couple of nose slam-down landings at near stall speed (with extensive and expensive firewall damage), our landing procedure is a 60 kias half-flap approach with a relatively shallow and fully controlled touchdown at around 50 -55 kias. It makes little roll-out distance difference (this is not a STOL airplane) and keeps the insurance company happy. I wouldn't sweat the elevator trim business and would very strongly recommend not getting into that envelope. Karl href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matronic s.com/Navigator?Zenith601-List href="http://forums.matronics.com ">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matronic s.com/Navigator?Zenith601-List href="http://forums.matronics.com ">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c =================================== t" target=_blank>http://www.matronics.com/Navigator?Zenith601-List =================================== tp://forums.matronics.com =================================== _blank>http://www.matronics.com/contribution =================================== ________________________________________________________________________________
Subject: Re: Zenith-List: Alieron Trim/ flap travel
Date: May 16, 2010
I've got both styles on working aircraft and I will go measure the travel on both but it just seems to me the new unit has less but I will confirm this tomorrow. You may be in fact correct. Jeff -----Original Message----- From: Craig Payne <craig(at)craigandjean.com> Sent: Sun, May 16, 2010 7:37 pm Subject: RE: Zenith601-List: Zenith-List: Alieron Trim/ flap travel Really? I've had both the old one with the exposed micro-switches and the new sealed one (circa Nov. 2008) and measured the travel of both. Unless you crack open the sealed unit you can't adjust the travel. From the fact ory the travel of mine was 2 and 1/8th inches or 54mm. The plans page for new style actuator here (dated 11/06) show a travel of 50 mm: http://www.zenithair.com/zodiac/xl/data/6b19.pdf For the old actuator the rough settings shown for the micro switches show in 6-B-19 (dated 08/05) give about 2 inches of travel (63mm - 12mm = 51 mm or about 2 inches) but this adjustment is refined for 30 degree travel as specified on 6-S-3. For both the old and new plans the center-to-center length of the arm that connects the actuator to the flap torque tube (6B19-3) is listed as 170 mm. And the arm that drives the flap (at least on the right, 6B19-1) has a center-to-center distance of 105 mm for the old and new design. So if the actuators travel the same distance and the arms are the same length then how did the angle swept change? Or has there been a third design? -- Craig From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-li st-server(at)matronics.com] On Behalf Of afterfxllc(at)aol.com Sent: Sunday, May 16, 2010 4:04 PM Subject: Re: Zenith601-List: Zenith-List: Alieron Trim/ flap travel Yes the new style actuator has less travel and my test pilot had the same concern about lack of elevator trim with full flaps but with half flaps and keeping his speed up it works fine. Full flaps isn't necessary. He sa id what was strange was it stalled right at 38 to 40 but wouldn't dare do that on a landing. Jeff -----Original Message----- From: Craig Payne <craig(at)craigandjean.com> Sent: Sun, May 16, 2010 6:54 pm Subject: RE: Zenith601-List: Zenith-List: Alieron Trim/ flap travel At least with my 2000 vintage plans and kit the factory actuator traveled a bit under 2 inches. This was the actuator with the exposed microswitche s. -- Craig From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-li st-server(at)matronics.com] On Behalf Of fritz Sent: Monday, May 17, 2010 3:22 PM Subject: Re: Zenith601-List: Zenith-List: Alieron Trim/ flap travel At a later date, wasn't the flap actuator travel changed from 4" to 2" ? To restrict the flap travel? ----- Original Message ----- From: Karl Polifka Sent: Sunday, May 16, 2010 7:38 AM Subject: Re: Zenith601-List: Zenith-List: Alieron Trim FYI -- after a couple of nose slam-down landings at near stall speed (with extensive and expensive firewall damage), our landing procedure is a 60 kias half-flap approach with a relatively shallow and fully controlled to uchdown at around 50 -55 kias. It makes little roll-out distance differen ce (this is not a STOL airplane) and keeps the insurance company happy. I wouldn't sweat the elevator trim business and would very strongly recom mend not getting into that envelope. Karl href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matr onics.com/Navigator?Zenith601-List ref="http://forums.matronics.com">http://forums.matronics.com ref="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matr onics.com/Navigator?Zenith601-List ref="http://forums.matronics.com">http://forums.matronics.com ref="http://www.matronics.com/contribution">http://www.matronics.com/c t" target=_blank>http://www.matronics.com/Navigator?Zenith601-List p://forums.matronics.com blank>http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matr onics.com/Navigator?Zenith601-List ref="http://forums.matronics.com">http://forums.matronics.com ref="http://www.matronics.com/contribution">http://www.matronics.com/c ======================== =========== -= - The Zenith601-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Zenith601-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: May 16, 2010
Jeff, Measure the angle of deflection at the flap. That's what we should be looking at anyway, the actual movement of the control surface. -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=297949#297949 ________________________________________________________________________________
Date: May 17, 2010
Subject: Trim Tab
> I also have the small trim tab. I called Zenith they said it needed to > bigger. So I over lapped the existing Tab with a new piece of aluminum that > gave me twice the previous surface area. Since I never needed any down > trim, I reposition the length of the arm from the servo so that neutral for > the servo is slightly up trim, this gives about 10 or 15 degrees of extra up > trim at full throw. The trim tab itself is at neutral in normal cruise > flight hence no extra drag. David N601EX CH601XLT JAB3300 165 hrs 25 since upgrade > > ________________________________________________________________________________
Subject: Re: Trim Tab
Date: May 17, 2010
When you added the extra to the trim tab, did you check that you could overcome full trim in both directions with the stick at all speeds? Dave austin ________________________________________________________________________________
Date: May 18, 2010
Subject: Trim tab
> > From: "Dave Austin" <daveaustin2(at)primus.ca> > Subject: Re: Zenith601-List: Trim Tab > > When you added the extra to the trim tab, did you check that you could > overcome full trim in both directions with the stick at all speeds? > Dave austin > > > No, not at all speeds, a micro-switch did stick once at full throw, I had no trouble with control at normal cruise speeds. My additional area is not greater than the area on the full length trim tab that Zenith now supplies and has tested. David N601EX CH601XLT JAB3300 165 hrs 25 since upgrade ________________________________________________________________________________
Subject: upgrade question
Date: May 18, 2010
Who knew you had to be a machinist to install the upgrade! I'm learning about all sorts of new things: transfer punches, reamers, solid rivets. The plans state that the main spar attach bolt holes in the center spar should be drilled undersized then reamed to the proper diameter (5/16). To me that appears to be a pretty open ended statement. If you google "reamer" you get many and varied hits for all different kinds of reamers. Does anyone have a suggestion as to what kind of reamer we should use and where to get one? Should we also ream the bolt holes for 6-ZU-2-4? What have other people done? Thanks! ________________________________________________________________________________
Date: May 19, 2010
Hi Lee, Reamers do indeed come in a lot of different forms. For this kind of work, I prefer hand reamers. They tend to be several inches longer than other kinds and mount in tap holders. I selected "Left hand spiral, Right Hand cut" for my Zodiac XL spar work, but other choices would probably work about the same. What you probably don't want is "Chucking Reamer" types. These are meant for milling machines and fancier "Machining Centers" where the machine provides the stability rather than the shape of the reamer. I like to drill 10 or 20 thousandths undersize before reaming a hole in aluminum. There are many "Cutting Tool" vendors that all supply good stuff. Travers tool is a good one on the East coast, MSC works well in most parts of the USA. I don't know which holes should be reamed, so I'll let someone else address that question. I personally think this is a big issue when a wing is attached to the fuselage with one bolt, but when there are six of them I doubt the perfection of the hole is a big deal. Paul XL installing upgrade (slowly) -----Original Message----- From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Lee Steensland Sent: Tuesday, May 18, 2010 8:04 PM Subject: Zenith601-List: upgrade question Who knew you had to be a machinist to install the upgrade! I'm learning about all sorts of new things: transfer punches, reamers, solid rivets. The plans state that the main spar attach bolt holes in the center spar should be drilled undersized then reamed to the proper diameter (5/16). To me that appears to be a pretty open ended statement. If you google "reamer" you get many and varied hits for all different kinds of reamers. Does anyone have a suggestion as to what kind of reamer we should use and where to get one? Should we also ream the bolt holes for 6-ZU-2-4? What have other people done? Thanks! ________________________________________________________________________________
Date: May 19, 2010
Subject: Re: upgrade question
Hi Lee I am definitely not a machinist, but I can tell you what I am doing, though I am still in the early stages. Most of what I've learned about reamers was by buying the wrong thing at $18/ea. I think the best ones are the "piloted reamers," e.g., http://browntool.com/Default.aspx?tabid=255&txtSearch=reamer&List=1&SortField=ProductName%2cProductNumber&catpageindex=2&ProductID=1010 which has a short pilot of 0.2969" dia. to fit in your sub-5/16" pilot hole, followed by a section of 0.3125", to ream the hole precisely to 5/16". That assumes that you hold your drill perfectly normal to the spar---or are using a good drill press. There are (slightly) cheaper reamers that are not piloted. I don't trust my hand drill skills, so I think I'll bolt my drill press to my work table for the reaming. I'm also using reamers for the bolt joints through the 1/8" spar cap, spar cap doubler, web, and spar root doubler plate. I'm using AN4's rather than AN3's, because the holes in my spar cap and my spar cap doubler are substantially larger than 0.1875" . I bought a .247 x .231 HSS Piloted Chucking Reamer for those holes (my AN4's measure about 0.245"). Good call on the 6-ZU-2-4 bolts. You're way ahead of me. I believe that the bolts in the main spar are loaded primarily in shear (so a tight bolt hole is critical to avoid stress concentrations, which can lead to fatigue failure). I suspect the center spar bolt are in tension between the bolted spar caps, but in shear between the spar caps and the spar uprights. In any case, I do not believe that a tight bolt hole hurts (assuming that holes line up in the different layers), so I'll plan to use my .247 x .231 AN4- piloted reamer for those holes also. 'Good idea. Terry >Who knew you had to be a machinist to install the upgrade! > >I'm learning about all sorts of new things: transfer punches, reamers, >solid rivets. > >The plans state that the main spar attach bolt holes in the center spar >should be drilled undersized then reamed to the proper diameter (5/16). >To me that appears to be a pretty open ended statement. If you google >"reamer" you get many and varied hits for all different kinds of >reamers. Does anyone have a suggestion as to what kind of reamer we >should use and where to get one? > >Should we also ream the bolt holes for 6-ZU-2-4? > >What have other people done? > >Thanks! Terry Phillips ttp44~at~rkymtn.net Corvallis MT ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done; Upgrading wings & ailerons per the AMD Safety Directive http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: May 19, 2010
Lee, The reamer you want to use is called a chucking reamer. It has straight flutes and can be turned by hand or by a drill motor. I suggest you turn it by hand. A piloted reamer is handy but not totally necessary. 5/16 is .3125 The upgrade instructions specify the tolerance to be +.004 This means you holes cannot be larger than .3165or you will need to go to an over sized bolt that is less than 3/8th. these are very expensive. The reamer size you want is .3125" It is not necessary to ream the bolts in the main spar. These bolts are not in shear really, they are mostly in tension. as the spar is stressed the caps want to separate or bend away from each other. this would allow them to collapse. The bolt (&or rivets) hold them together and force them to flex in the correct direction which is edge wise. Clear as mud? I hope this helps, Brady -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298202#298202 ________________________________________________________________________________
Date: May 19, 2010
Lee, Brady and I are machinists, here is a picture of how I keep things square when I can't use a machine. It's a vee block, not show is my hand holding it in place while I use the reamer and cutting oil everywhere. http://mykitlog.com/users/display_log.php?user=rlendon&project=113&category=0&log=24457&row=671 I used this method on one upgrade and the fit was good on all the holes. YMMV Practice, practice, practice, and oh yeah, practice. -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298213#298213 ________________________________________________________________________________
Date: May 20, 2010
Subject: Pushrods
List I am changing over to pushrods on the ailerons of my 601 during the upgrade. I am planning on using 1 1/8" O.D. x .039 6061 - T6 tubing in one piece. The overall length from center to center of the Heim bearings is 96".the same tube is used on several RV's. The RV-4 is ~ 66" Has anyone out there installed one piece pushrods and what size tubing was used. The above tube is plenty strong but I am concerned about vibration and harmonics on such a long tube. i would appreciate it if someone could e-mail a description or photos of their installation and how many hours they have flown. Thanks for any help Bobby Florida 601 XL 96 hrs before upgrade. ________________________________________________________________________________
Date: May 20, 2010
Brady; I would not use a chucking reamer by hand the straight flutes are designed to be driven by a machine tool such as a milling machine or a lathe. Reaming by hand is best done with a hand reamer which has spiral flutes and a taper to the diameter for a short distance. Regards, John CH701 - Colorado - Jabiru 3300 Cell: 719-494-4567 Home: 303-648-3261 In a message dated 5/19/2010 11:26:28 A.M. Mountain Daylight Time, brady(at)magnificentmachine.com writes: --> Zenith601-List message posted by: "Brady" Lee, The reamer you want to use is called a chucking reamer. It has straight flutes and can be turned by hand or by a drill motor. I suggest you turn it by hand. A piloted reamer is handy but not totally necessary. 5/16=C3=A2=82=AC=C2=9D is .3125=C3=A2=82=AC=C2=9D The upgrade instructions specify the tolerance to be +.004=C3=A2=82=AC =C2=9D This means you holes cannot be larger than .3165=C3=A2=82=AC=C2=9Dor you will need to go to an over sized bolt that is less than 3/8th. these are very expensive. The reamer size you want is .3125" It is not necessary to ream the bolts in the main spar. These bolts are not in shear really, they are mostly in tension. as the spar is stressed the caps want to separate or bend away from each other. this would allow them to collapse. The bolt (&or rivets) hold them together and force them to flex in the correct direction which is edge wise. Clear as mud? I hope this helps, Brady -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298202#298202 ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
Date: May 20, 2010
Subject: Re: Pushrods
Well, the harmonic frequency of a beam like this is inversely proportional to the length squared, so your harmonic frequencies will be about 47% of that of the pushrod in the RV-4, assuming you use the same size tubing. Let me know if you want to know the exact frequencies. Bill On 5/19/2010 9:11 PM, BobbyPaulk(at)comcast.net wrote: > List > I am changing over to pushrods on the ailerons of my 601 during the > upgrade. I am planning on using 1 1/8" O.D. x .039 6061 - T6 tubing in > one piece. The overall length from center to center of the Heim > bearings is 96".the same tube is used on several RV's. The RV-4 is ~ > 66" Has anyone out there installed one piece pushrods and what size > tubing was used. The above tube is plenty strong but I am concerned > about vibration and harmonics on such a long tube. i would appreciate > it if someone could e-mail a description or photos of their > installation and how many hours they have flown. > > Thanks for any help > > > ________________________________________________________________________________
Date: May 20, 2010
John, On the issue of a chucking reamer, I did use one by hand. I don't recommend it for everyone. By using the existing hole as an alignment guide and then having the hole in the new metal only 0.015 under size, it was very easy to get a clean hole. The clear issue is that one must not put any side pressure on the existing hole. That is a matter of practice. Even a hand reamer can take some metal off the existing hole if one is not careful so there is no perfect solution short of standing the wing on edge and mounting a "mini" drill press on the spar to ream out the holes. Even better would be to have a special reamer that only had cutting flukes for the first 1/8 inch and then was smooth but the same diameter. I have never heard of such a tool. -- Mark Hubelbank NorthEast Monitoring 2 Clock Tower Place Suite 555 Maynard, MA, 01754 - USA mhubel(at)nemon.com 978-443-3955 ________________________________________________________________________________
Subject: Pushrods
Date: May 20, 2010
Bobby, I basically copied Bill Phillip=99s documentation using the same Vans rod ends and 1 1/8=9D tubing. I have now 8 hours on the plane and all is working well. I have flown a 601 with cables and haven=99t noticed any great difference between the two. You can download a copy of Bill=99s documentation from here http://forums.matronics.com/download.php?id=14337 <http://forums.matronics.com/download.php?id=14337&sid=5070ea75d7ac33 d8a0d772db8f98561b> &sid=5070ea75d7ac33d8a0d772db8f98561b I left the balance cable in situ to provide some equalising forces on the aileron bell crank. Might be a bit of an overkill. I have it tensioned to 30lbs (Zenith spec) but may be a bit much. I think if I decreased it a little the aileron feel would be a little lighter. Cheers Peter Wonthaggi Australia http://zodiac.cpc-world.com From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of BobbyPaulk(at)comcast.net Sent: Thursday, 20 May 2010 11:12 AM Subject: Zenith601-List: Pushrods List I am changing over to pushrods on the ailerons of my 601 during the upgrade. I am planning on using 1 1/8" O.D. x .039 6061 - T6 tubing in one piece. The overall length from center to center of the Heim bearings is 96".the same tube is used on several RV's. The RV-4 is ~ 66" Has anyone out there installed one piece pushrods and what size tubing was used. The above tube is plenty strong but I am concerned about vibration and harmonics on such a long tube. i would appreciate it if someone could e-mail a description or photos of their installation and how many hours they have flown. Thanks for any help Bobby Florida 601 XL 96 hrs before upgrade. ________________________________________________________________________________
From: Lee Steensland <zenith-list(at)steensland.net>
Date: May 20, 2010
Fortunately I'm in a fairly unique situation. I don't have the center spar installed nor the wings complete. Everything is free and away from the plane, so setting it up in a drill press is child's play (for the most part). > > John, > On the issue of a chucking reamer, I did use one by hand. I don't > recommend it for everyone. By using the existing hole as an alignment > guide and then having the hole in the new metal only 0.015 under size, > it was very easy to get a clean hole. The clear issue is that one must > not put any side pressure on the existing hole. That is a matter of > practice. Even a hand reamer can take some metal off the existing hole > if one is not careful so there is no perfect solution short of standing > the wing on edge and mounting a "mini" drill press on the spar to ream > out the holes. > Even better would be to have a special reamer that only had cutting > flukes for the first 1/8 inch and then was smooth but the same diameter. > I have never heard of such a tool. > ________________________________________________________________________________
Date: May 20, 2010
JohnDRead(at)aol.com wrote: > Brady; > I would not use a chucking reamer by hand the straight flutes are designed to be driven by a machine tool such as a milling machine or a lathe. Reaming by hand is best done with a hand reamer which has spiral flutes and a taper to the diameter for a short distance. > > Regards, John > > > John, Actually that is not true, and I don't think the Reamer can tell who or what is turning it. Page 807 of the Machinery's Hand Book 26th edition says: "Hand reamers are made with both straight and helical flutes. Helical flutes provide a shearing cut and are especially useful in reaming holes having keyways or grooves, as these are bridged over by the helical flutes, thus preventing binding or chattering." Because the hole we are reaming do not have a keyway or grooves (intentionally) a spiral reamer is not necessary. But every situation is different and everyone's skill level may vary. I would expect builders to use their noggin. My advice was free and general. take it or leave it as you may. -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298343#298343 ________________________________________________________________________________
Date: May 20, 2010
Brady or John Assuming that one wanted to turn a chucking reamer by hand, what would you use as an handle? My reamers have round shafts whose diameter is a bit smaller than the reamer size. Terry >JohnDRead(at)aol.com wrote: > > Brady; > > I would not use a chucking reamer by hand the straight > flutes are designed to be driven by a machine tool such as a milling > machine or a lathe. Reaming by hand is best done with a hand reamer > which has spiral flutes and a taper to the diameter for a short distance. > > > > Regards, John > > > > > > > > >John, >Actually that is not true, and I don't think the Reamer can tell who or >what is turning it. > >Page 807 of the Machinery's Hand Book 26th edition says: >"Hand reamers are made with both straight and helical flutes. Helical >flutes provide a shearing cut and are especially useful in reaming holes >having keyways or grooves, as these are bridged over by the helical >flutes, thus preventing binding or chattering." > >Because the hole we are reaming do not have a keyway or grooves >(intentionally) a spiral reamer is not necessary. > >But every situation is different and everyone's skill level may vary. >I would expect builders to use their noggin. > >My advice was free and general. >take it or leave it as you may. > >-------- >Brady McCormick >Poulsbo, WA >www.magnificentmachine.com Terry Phillips ttp44~at~rkymtn.net Corvallis MT ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done; Upgrading wings & ailerons per the AMD Safety Directive http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: May 20, 2010
Terry Phillips wrote: > Brady or John > > Assuming that one wanted to turn a chucking reamer by hand, what would you > use as an handle? My reamers have round shafts whose diameter is a bit > smaller than the reamer size. > > Terry > > > Terry, I used a tap handle like the one in the bottom of the picture. http://en.wikipedia.org/wiki/Tap_wrench Turned the reamer counterclockwise through existing hole till it met the new hole. Then I turned it clockwise to finish the new hole. The new hole was .015 small before reaming. -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298348#298348 ________________________________________________________________________________
Date: May 20, 2010
Terry Phillips wrote: > Brady or John > > Assuming that one wanted to turn a chucking reamer by hand, what would you > use as an handle? My reamers have round shafts whose diameter is a bit > smaller than the reamer size. > > Terry > > Terry, You can grind 4 flats on it and turn it with a tap handle. After you modify it will still be usable as in a chuck. most of mine are modified this way. -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298350#298350 ________________________________________________________________________________
Date: May 20, 2010
Why do the bolts have to be smaller than 3/8"? Is it edge distance that is the problem? With all the drilling and back drilling it's hard to get a perfect hole. The bolt may seem tight but the hole might not be uniform through many layers of material. I thought of drilling a larger hole after all the 5/16 bolts are in place by removing one bolt at a time. A 3/8 bolt is much stronger than 5/16. Chuck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298400#298400 ________________________________________________________________________________
Date: May 21, 2010
Good question. I've heard of several people who have done that, and apparently, nobody has complained about the result. While we're at it, do any of the guys with real-world structural backgrounds have any strong objections to using AN-3 bolts instead of rivets? Zenith said they don't mind, and several A&Ps have said it's okay. With the proposed number of bolts in the spar, the .008 (average) difference isn't going to matter. I guess this goes back to Chris' comment one time, "You're building a tractor, not a space shuttle". Paul R ----- Original Message ----- From: chuck960<mailto:chuckde(at)roadrunner.com> To: zenith601-list(at)matronics.com Sent: Thursday, May 20, 2010 10:56 PM Subject: Zenith601-List: Re: upgrade question > Why do the bolts have to be smaller than 3/8"? Is it edge distance that is the problem? With all the drilling and back drilling it's hard to get a perfect hole. The bolt may seem tight but the hole might not be uniform through many layers of material. I thought of drilling a larger hole after all the 5/16 bolts are in place by removing one bolt at a time. A 3/8 bolt is much stronger than 5/16. Chuck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298400#298400 .matronics.com/viewtopic.php?p=298400#298400> http://www.matronics.com/Navigator?Zenith601-List m/Navigator?Zenith601-List> http://www.matronics.com/contribution on> ________________________________________________________________________________
Date: May 21, 2010
I asked the same question after discovering that a couple of my spar bolt h oles were out of tolerance (It is a quickbuild and came that way but thats another gripe).- ZAC (Caleb) told me that 3/8 was the maximum you could g o to due to edge distances but cautioned that the tolerance was only .004. - If you should go over that, which is easy to do,-you would need to re place the-spar etc. which would be in excess of $2K.- =0A-Bill Pagan =0A=0A=0A=0A=0A=0A=0A________________________________=0AFrom: chuck960 <chu ckde(at)roadrunner.com>=0ATo: zenith601-list(at)matronics.com=0ASent: Thu, May 20 , 2010 11:56:11 PM=0ASubject: Zenith601-List: Re: upgrade question=0A=0A--> Zenith601-List message posted by: "chuck960" =0A =0AWhy do the bolts have to be smaller than 3/8"?- Is it edge distance th at is the problem? With all the drilling and back drilling it's hard to get a perfect hole. The bolt may seem tight but the hole might not be uniform through many layers of material. I thought of drilling a larger hole after all the 5/16 bolts are in place by removing one bolt at a time. A 3/8 bolt is much stronger than 5/16.=0AChuck=0A=0A=0A=0A=0ARead this topic online he re:=0A=0A
http://forums.matronics.com/viewtopic.php?p=298400#298400=0A=0A ======================0A=0A=0A ________________________________________________________________________________
Date: May 21, 2010
Bill, Has anyone thought of using metric bolts. I expect there are the same grade bolts available (perhaps even better) in 8 mm (about 0.0024 over and a standard metric size) and 9 mm (0.0418 over or 0.021 under 3/8, but a hard to get size). -- Mark Hubelbank NorthEast Monitoring 2 Clock Tower Place Suite 555 Maynard, MA, 01754 - USA mhubel(at)nemon.com 978-443-3955 ________________________________________________________________________________
Date: May 21, 2010
All of this reamer talk got me thinking (Scary Huh) and I went to Lowes and bought a 5/16 drill bit and just for shits and grins then drilled about 20 holes in a test piece of spar caps that came from the wing jigs and lo and behold all of my holes done by hand with a drill came out to .312 to .314 and the bolts were snug so if you are half way careful you should be able to just drill the holes. And you can also buy oversized NAS bolts for the inept drillers out there. :) Jeff In a message dated 5/21/2010 8:16:53 A.M. Central Daylight Time, mhubel(at)nemon.com writes: --> Zenith601-List message posted by: Mark Hubelbank Bill, Has anyone thought of using metric bolts. I expect there are the same grade bolts available (perhaps even better) in 8 mm (about 0.0024 over and a standard metric size) and 9 mm (0.0418 over or 0.021 under 3/8, but a hard to get size). -- Mark Hubelbank NorthEast Monitoring 2 Clock Tower Place Suite 555 Maynard, MA, 01754 - USA mhubel(at)nemon.com 978-443-3955 ________________________________________________________________________________
From: "Leroy Wheeler" <flyboy3847(at)onecommail.com>
Date: May 21, 2010
We used a reamer but just chucked it up in a hand drill. That worked fine. Leroy Wheeler 601HD plans built just about done flying off the 40 hours. _____ From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Afterfxllc(at)aol.com Sent: Friday, May 21, 2010 11:56 AM Subject: Re: Zenith601-List: Re: upgrade question All of this reamer talk got me thinking (Scary Huh) and I went to Lowes and bought a 5/16 drill bit and just for shits and grins then drilled about 20 holes in a test piece of spar caps that came from the wing jigs and lo and behold all of my holes done by hand with a drill came out to .312 to .314 and the bolts were snug so if you are half way careful you should be able to just drill the holes. And you can also buy oversized NAS bolts for the inept drillers out there. :) Jeff In a message dated 5/21/2010 8:16:53 A.M. Central Daylight Time, mhubel(at)nemon.com writes: Bill, Has anyone thought of using metric bolts. I expect there are the same grade bolts available (perhaps even better) in 8 mm (about 0.0024 over and a standard metric size) and 9 mm (0.0418 over or 0.021 under 3/8, but a hard to get size). -- Mark Hubelbank NorthEast Monitoring 2 Clock Tower Place Suite 555 Maynard, MA, 01754 - ================================================ Use the ties Day ================================================ - MATRONICS WEB FORUMS =============================================== - List Contribution Web Site sp; ================================================== 14:26:00 ________________________________________________________________________________
Date: May 21, 2010
I discussed this option with a friend of mine a retired tool maker who is making the upgrade to his 601. I am a retired mechanical engineer. If you can ream the holes for a snug slide fit of A3 bolts into the holes then bolts should be OK if the holes are over sized then rivets are the safe way to go as they expand during setting the fill the holes. Just our two cents worth Regards, John CH701 - Colorado - Jabiru 3300 Cell: 719-494-4567 Home: 303-648-3261 In a message dated 5/21/2010 4:05:04 A.M. Mountain Daylight Time, paulrod36(at)msn.com writes: Good question. I've heard of several people who have done that, and apparently, nobody has complained about the result. While we're at it, do any of the guys with real-world structural backgrounds have any strong objections to using AN-3 bolts instead of rivets? Zenith said they don't mind, and several A&Ps have said it's okay. With the proposed number of bolts in the spar, the .008 (average) difference isn't going to matter. I guess this goes back to Chris' comment one time, "You're building a tractor, not a space shuttle". Paul R ----- Original Message ----- From: _chuck960_ (mailto:chuckde(at)roadrunner.com) Sent: Thursday, May 20, 2010 10:56 PM Subject: Zenith601-List: Re: upgrade question (mailto:chuckde(at)roadrunner.com) > Why do the bolts have to be smaller than 3/8"? Is it edge distance that is the problem? With all the drilling and back drilling it's hard to get a perfect hole. The bolt may seem tight but the hole might not be uniform through many layers of material. I thought of drilling a larger hole after all the 5/16 bolts are in place by removing one bolt at a time. A 3/8 bolt is much stronger than 5/16. Chuck Read this topic online here: _http://forums.matronics.com/viewtopic.php?p=298400#298400_ (http://forums.matronics.com/viewtopic.php?p=298400#298400) http://www.matnbsp; via the Web title=http://forums.matronics.com/ href="http://forums.matronics.com">http://forums.matronics.com _p; generous bsp; title=http://www.matronics.com/contribution href="http://www.matronics.com/contribution">http://www.matronics.com/c================ (http://www.matronics.com/Navigator?Zenith601-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Subject: Landing gear orientation
Date: May 21, 2010
OK - I know this subject has been discussed before but I thought it would be interesting to hear what people have to say after some time has passed. I'm busy installing the mods in my wings at the moment but in the future I will be back to building my fuselage. I have a Jabiru 3300 going up front and my original intention was to install the gear flat side back. More recent plans call for turning the gear around to avoid nose heaviness which results in the nose plopping down on landing. On the other hand, I have heard that with the gear turned around it is easier to ground the tail when boarding, especially when it's a big guy (like me). That would be a little embarrassing at the least :-) I'd like to hear from guys who have done it both ways (with a similar weight engine) to help me make a final decision as to which way to go. Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Working on fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298448#298448 ________________________________________________________________________________
Date: May 21, 2010
Subject: Re: Landing gear orientation
Hi, Tim! I'm also a "big guy", and I'm in the process of turning my gear around so the flat side faces forward. I'd much rather shift my weight forward when boarding, then put up any longer with the inability to hold the nose off after the mains touch in a full stall landing. Given the low rotation speed of the 601, and the "nose heaviness" with a Corvair, I think it makes sense to move the pivot point forward (assuming tricycle gear). But I'm used to thinking about the tail going down while boarding - this happens withh Grumman Tigers all the time when two big people get on the boarding steps at the same time. The solution is to install a skid at the rear tie-down eye, which will protect the tail and the ring. Rick Lindstrom ZenVair N42KP (upgrade well underway!) -----Original Message----- >From: Tim Juhl <juhl(at)avci.net> >Sent: May 21, 2010 10:59 AM >To: zenith601-list(at)matronics.com >Subject: Zenith601-List: Landing gear orientation > > >OK - I know this subject has been discussed before but I thought it would be interesting to hear what people have to say after some time has passed. > >I'm busy installing the mods in my wings at the moment but in the future I will be back to building my fuselage. I have a Jabiru 3300 going up front and my original intention was to install the gear flat side back. More recent plans call for turning the gear around to avoid nose heaviness which results in the nose plopping down on landing. On the other hand, I have heard that with the gear turned around it is easier to ground the tail when boarding, especially when it's a big guy (like me). That would be a little embarrassing at the least :-) > >I'd like to hear from guys who have done it both ways (with a similar weight engine) to help me make a final decision as to which way to go. > >Tim > >-------- >______________ >CFII >Champ L16A flying >Zodiac XL - Jabiru 3300A >Working on fuselage > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=298448#298448 > > ________________________________________________________________________________
Date: May 21, 2010
Afterfxllc(at)aol.com wrote: > All of this reamer talk got me thinking (Scary Huh) and I went to Lowes and bought a 5/16 drill bit and just for shits and grins then drilled about 20 holes in a test piece of spar caps that came from the wing jigs and lo and behold all of my holes done by hand with a drill came out to .312 to .314 and the bolts were snug so if you are half way careful you should be able to just drill the holes. > And you can also buy oversized NAS bolts for the inept drillers out there. :) > Jeff > > I believe in the Wing Spar & Rear Channel section 6-ZU-1 on page 11 of the upgrade instructions right below the top picture it specifically says: "The Holes must be reamed to final size, DO NOT use a 5/16 drill bit to Drill the holes." But what do I know I'm not an aeronautical engineer. I am however a FORMALLY trained machinist and I do know that if I were to willingly disregard such an instruction and someone were to get hurt it would be grounds for a Lawsuit and perhaps Jail time. Just food for thought... -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298458#298458 ________________________________________________________________________________
Date: May 21, 2010
Afterfxllc(at)aol.com wrote: > All of this reamer talk got me thinking (Scary Huh) Yeah it is, stop doing that!!!!! The information you have published is incorrect and inaccurate. The Machinery's Handbook lists a study done by the Metal Cutting Institute where 2800 holes were drilled in steel and cast iron and the results for 1/4" were average oversize of .0065" and 1/2" were .008" oversize. When an Engineer says to ream a hole, you better ream the hole. Jeff, some times the things you say can be dangerous, especially if you are like me and think you know the answers. I have finally reached a point in life where I know, I don't know it all. Wish you well, -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298471#298471 ________________________________________________________________________________
Date: May 21, 2010
Tim, I am also a big guy. Only once when two of us were boarding the wing at the same time did we even start to tip the airplane. My current practice, anyway now, is to board and strap in my passenger first and then I board. No problems what so ever. I am to the point where I can hold the nose off for a good 5-9 seconds after landing on the mains. Go flat forward with your Jabiru and you will not look back. Dave -------- David Gallagher 601 XL/Jabiru 3300 First flight 7/24/08 Upgraded 3/19/10 120+ hours and climbing! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298480#298480 ________________________________________________________________________________
Date: May 21, 2010
Hey Brady, Then I would suggest you don't install my TEST PIECE in your airplane HUH? ??!!!! Jeff -----Original Message----- From: Brady <brady(at)magnificentmachine.com> Sent: Fri, May 21, 2010 3:02 pm Subject: Zenith601-List: Re: upgrade question m> fterfxllc(at)aol.com wrote: All of this reamer talk got me thinking (Scary Huh) and I went to Lowes and ought a 5/16 drill bit and just for shits and grins then drilled about 20 oles in a test piece of spar caps that came from the wing jigs and lo and ehold all of my holes done by hand with a drill came out to .312 to .314 and he bolts were snug so if you are half way careful you should be able to just rill the holes. And you can also buy oversized NAS bolts for the inept drillers out ther e. ) Jeff believe in the Wing Spar & Rear Channel section 6-ZU-1 on page 11 of the pgrade instructions right below the top picture it specifically says: "The Holes must be reamed to final size, DO NOT use a 5/16 drill bit to Dr ill he holes." But what do I know I'm not an aeronautical engineer. am however a FORMALLY trained machinist and I do know that if I were to illingly disregard such an instruction and someone were to get hurt it wou ld be rounds for a Lawsuit and perhaps Jail time. Just food for thought... -------- rady McCormick oulsbo, WA ww.magnificentmachine.com ead this topic online here: http://forums.matronics.com/viewtopic.php?p=298458#298458 ======================== =========== -= - The Zenith601-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Zenith601-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: May 21, 2010
So you are telling me that the holes I drilled in my test piece were someh ow wrong because of some other test that was done? I never said do it I said I was testing it for SHITS AND GRINS and found the holes would be within tolerance. And you can also mess a hole up with a reamer as well if you use a drill and are not used to using it. You and Brady must have had lunch together today and forgot how to read. Jeff -----Original Message----- From: Ron Lendon <ron.lendon(at)gmail.com> Sent: Fri, May 21, 2010 6:34 pm Subject: Zenith601-List: Re: upgrade question fterfxllc(at)aol.com wrote: All of this reamer talk got me thinking (Scary Huh) eah it is, stop doing that!!!!! The information you have published is ncorrect and inaccurate. The Machinery's Handbook lists a study done by the Metal Cutting Institute where 800 holes were drilled in steel and cast iron and the results for 1/4" wer e verage oversize of .0065" and 1/2" were .008" oversize. When an Engineer says to ream a hole, you better ream the hole. Jeff, some times the things you say can be dangerous, especially if you ar e like e and think you know the answers. I have finally reached a point in life where know, I don't know it all. Wish you well, -------- on Lendon, Clinton Township, MI W Corvair with Roy's Garage 5th bearing odiac XL, ScrapBuilder ;-) ttp://www.mykitlog.com/rlendon ead this topic online here: http://forums.matronics.com/viewtopic.php?p=298471#298471 ======================== =========== -= - The Zenith601-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Zenith601-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: May 21, 2010
O and BTW aluminum is much softer than steel and cast iron now isn't it. And was the hole already there or where these new holes? Did they use hig h speed bits or low speed, oil or no oil? was the test done by hand or usi ng a drill press? New drill bits or old? was the test done by average peop le or machinists? What was the thickness? I drilled the freaking holes and they were within tolerance .002 under so they would be acceptable if I were to use them. If you are going to correct me at least compare apples to apples. OK? -----Original Message----- From: Ron Lendon <ron.lendon(at)gmail.com> Sent: Fri, May 21, 2010 6:34 pm Subject: Zenith601-List: Re: upgrade question fterfxllc(at)aol.com wrote: All of this reamer talk got me thinking (Scary Huh) eah it is, stop doing that!!!!! The information you have published is ncorrect and inaccurate. The Machinery's Handbook lists a study done by the Metal Cutting Institute where 800 holes were drilled in steel and cast iron and the results for 1/4" wer e verage oversize of .0065" and 1/2" were .008" oversize. When an Engineer says to ream a hole, you better ream the hole. Jeff, some times the things you say can be dangerous, especially if you ar e like e and think you know the answers. I have finally reached a point in life where know, I don't know it all. Wish you well, -------- on Lendon, Clinton Township, MI W Corvair with Roy's Garage 5th bearing odiac XL, ScrapBuilder ;-) ttp://www.mykitlog.com/rlendon ead this topic online here: http://forums.matronics.com/viewtopic.php?p=298471#298471 ======================== =========== -= - The Zenith601-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Zenith601-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: May 21, 2010
I thought we were talking about reaming holes not each other. I will drill some test pieces as well before I do the Spar. If someone could point me to the oversize NAS bolt store. Maybe I'll try that instead of reaming to .375. Chuck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298490#298490 ________________________________________________________________________________
Date: May 22, 2010
Chuck, Shirley at Zenith can give you the source for the oversized bolts. If you decide to switch to 3/8 you still need to use NAS bolts even though the diameter of the 3/8 bolt is larger. Jeff -----Original Message----- From: chuck960 <chuckde(at)roadrunner.com> Sent: Fri, May 21, 2010 11:43 pm Subject: Zenith601-List: Re: upgrade question I thought we were talking about reaming holes not each other. will drill some test pieces as well before I do the Spar. f someone could point me to the oversize NAS bolt store. Maybe I'll try th at nstead of reaming to .375. huck ead this topic online here: http://forums.matronics.com/viewtopic.php?p=298490#298490 ======================== =========== -= - The Zenith601-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Zenith601-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: May 22, 2010
Chuck, I looked for some oversize AN3's for the spar root doubler joint. They were very hard to find, and pricey when I found them--check out: http://www.arizona-aero.com/nas_list.html You'll need to request a quote, and, for that you'll have to decipher the part number codes. Ultimately, I decided to go with AN4's. They are about 40x cheaper than over size NAS6204-11's. (I believe, but I'm not positive, that oversize AN's do not exist. The oversize bolts all seem to be NAS's. I suspect it's a tolerance thing.) Terry >I thought we were talking about reaming holes not each other. >I will drill some test pieces as well before I do the Spar. >If someone could point me to the oversize NAS bolt store. Maybe I'll try >that instead of reaming to .375. >Chuck Terry Phillips ttp44~at~rkymtn.net Corvallis MT ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done; Upgrading wings & ailerons per the AMD Safety Directive http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: May 22, 2010
Well put Pavel! I think this is why I may go to .375". The layers will be held in higher tension. The bolts are stronger but may be very close to being out of tolerance (edge distance) But at least the holes can be reamed after all the parts ate in place (only from the aft drilling forward) opening the hole from a somewhat sloppy 5/16" to .375 with the final reamer being .374 (subject to testing). Maybe I drink too much coffee! Comments? Chuck CH650 65% Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298517#298517 ________________________________________________________________________________
Date: May 22, 2010
Gentlemen, The part #'s for the over sized bolts are: NAS6205-22x NAS6205-23x the "X" in the part # specifies the over size. Also there is a "y" for the next over size. I forget if the oversize increments are .010" or .015" for the "X" but the "Y" is 2 times the "X" dimension. (.020" or .030"). Regardless I had a very lengthy discussion with Caleb about this because I have 2 airplanes in my shop that will require over sized bolts. Caleb told me to "avoid over sizing to 3/8 if at all possible." His reason for this is that at 3/8 the minimum edge distance becomes dangerously close. My experience with sourcing the oversize bolts is that they are very rare and very expensive. I sourced certified bolts @ $40 each. I was lucky to find some surplus bolts without certification papers for $10 each and so I bought all they had. Unfortunately this still is not enough to complete both airplanes. so the search continues. Just because the animal exists doesn't necessarily mean it will be easy to hunt! Or that you will bag one For what its worth: A 2 flute drill will produce a hole with 3 corners. A 3 flute drill will produce a hole with 4 corners. A 4 flute drill will produce a hole with 5 corners. and so on. With each additional flute the corners decrease in depth. the formula is N+1 (N=number of flutes). I learned this in my first week as an apprentice with the IAM (International Aerospace Workers & Machinists Union) I think this is covered in the Machinery's Hand book as well? -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298532#298532 ________________________________________________________________________________
Date: May 22, 2010
The "X" is .015 oversize and the "Y" is .030 oversize.=0A-Bill Pagan =0A =0A=0A=0A=0A=0A=0A________________________________=0AFrom: Brady <brady@mag nificentmachine.com>=0ATo: zenith601-list(at)matronics.com=0ASent: Sat, May 22 , 2010 3:54:59 PM=0ASubject: Zenith601-List: Re: upgrade question=0A=0A--> Zenith601-List message posted by: "Brady" =0A =0AGentlemen,=0A=0AThe part #'s for the over sized bolts are:=0ANAS6205-22x =0ANAS6205-23x=0Athe "X" in the part # specifies the over size.=0AAlso ther e is a "y" for the next over size.=0AI forget if the oversize increments ar e .010" or .015" for the "X" but the "Y" is 2 times the "X" dimension. (.02 0" or .030").=0ARegardless I had a very lengthy discussion with Caleb about this because I have 2 airplanes in my shop that will require over sized bo lts.=0ACaleb told me to "avoid over sizing to 3/8 if at all possible."=0AHi s reason for this is that at 3/8 the minimum edge distance becomes dangerou sly close.=0A=0AMy experience with sourcing the oversize bolts is that they are very rare and very expensive.=0AI sourced certified bolts @ $40 each. =0AI was lucky to find some surplus bolts without certification papers for $10 each and so I bought all they had. Unfortunately this still is not enou gh to complete both airplanes. so the search continues.=0A=0AJust because t he animal exists doesn't necessarily mean it will be easy to hunt! Or that you will bag one =0A=0AFor what its worth:=0AA 2 flute drill will produce a hole with 3 corners.=0AA 3 flute drill will produce a hole with 4 corners. =0AA 4 flute drill will produce a hole with 5 corners.=0Aand so on.=0AWith each additional flute the corners decrease in depth.=0Athe formula is N+1 ( N=number of flutes).=0AI learned this in my first week as an apprentice w ith the IAM (International Aerospace Workers & Machinists Union) =0AI think this is covered in the Machinery's Hand book as well?=0A=0A--------=0ABrad y McCormick=0APoulsbo, WA=0Awww.magnificentmachine.com=0A=0A=0A=0A=0ARead t his topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=2 ====0A=0A=0A ________________________________________________________________________________
Date: May 22, 2010
For what it is worth I have done 4 upgrades and built 3 flying 601's (None in the dirt BTW) and I have taken apart 7 601's and have seen everything from 10 lb lead shot bags in the wingtip, wing AOA 50 mm apart, loose spa r bolts, bottomed out spar bolts, smaller bolts for rear attach point. And non of these failed. And as a matter of fact none of the wing attach bolt s broke or were the cause of wing failures. The spar snapped at the first bolt hole but the bolts remained. Now as a matter of engineering of cours e the holes should be reamed if at all possible but remember there are tho usands of aircraft flying that have drilled spar bolts and are safe. Zeni th once told us alittle loose is ok but not sloppy but after what has happ ened every thing has to be technically correct. I use a reamer but wouldn' t think one minute about drilling my own spars with a drill bit because I know I can do it correctly and I now believe the spar and center section wasn't the problem to begin with and after seeing the sloppy building of some of these aircraft that didn't break apart I believe and and have alw ays believed flutter is the most likely reason for the failures. Jeff -----Original Message----- From: Brady <brady(at)magnificentmachine.com> Sent: Sat, May 22, 2010 3:54 pm Subject: Zenith601-List: Re: upgrade question m> Gentlemen, The part #'s for the over sized bolts are: AS6205-22x AS6205-23x he "X" in the part # specifies the over size. lso there is a "y" for the next over size. forget if the oversize increments are .010" or .015" for the "X" but the "Y" s 2 times the "X" dimension. (.020" or .030"). egardless I had a very lengthy discussion with Caleb about this because I have airplanes in my shop that will require over sized bolts. aleb told me to "avoid over sizing to 3/8 if at all possible." is reason for this is that at 3/8 the minimum edge distance becomes danger ously lose. My experience with sourcing the oversize bolts is that they are very rare and ery expensive. sourced certified bolts @ $40 each. was lucky to find some surplus bolts without certification papers for $10 each nd so I bought all they had. Unfortunately this still is not enough to com plete oth airplanes. so the search continues. Just because the animal exists doesn't necessarily mean it will be easy to hunt! r that you will bag one For what its worth: 2 flute drill will produce a hole with 3 corners. 3 flute drill will produce a hole with 4 corners. 4 flute drill will produce a hole with 5 corners. nd so on. ith each additional flute the corners decrease in depth. he formula is N+1 (N=number of flutes). learned this in my first week as an apprentice with the IAM (Internationa l erospace Workers & Machinists Union) think this is covered in the Machinery's Hand book as well? -------- rady McCormick oulsbo, WA ww.magnificentmachine.com ead this topic online here: http://forums.matronics.com/viewtopic.php?p=298532#298532 ======================== =========== -= - The Zenith601-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Zenith601-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: May 22, 2010
I think Brady is trying to be the WW of Matronics. All technical and stuff but wrong just the same. But hey what do I know I just built 3 flying 601's. That was my last pissing match post I have too many upgrades to do. Jeff -----Original Message----- From: Bill Pagan <bill.pagan(at)yahoo.com> Sent: Sat, May 22, 2010 4:47 pm Subject: Re: Zenith601-List: Re: upgrade question The "X" is .015 oversize and the "Y" is .030 oversize. Bill Pagan From: Brady <brady(at)magnificentmachine.com> Sent: Sat, May 22, 2010 3:54:59 PM Subject: Zenith601-List: Re: upgrade question m> Gentlemen, The part #'s for the over sized bolts are: NAS6205-22x NAS6205-23x the "X" in the part # specifies the over size. Also there is a "y" for the next over size. I forget if the oversize increments are .010" or .015" for the "X" but the "Y" is 2 times the "X" dimension. (.020" or .030"). Regardless I had a very lengthy discussion with Caleb about this because I have 2 airplanes in my shop that will require over sized bolts. Caleb told me to "avoid over sizing to 3/8 if at all possible." His reason for this is that at 3/8 the minimum edge distance becomes dange rously close. My experience with sourcing the oversize bolts is that they are very rare and very expensive. I sourced certified bolts @ $40 each. I was lucky to find some surplus bolts without certification papers for $1 0 each and so I bought all they had. Unfortunately this still is not enoug h to complete both airplanes. so the search continues. Just because the animal exists doesn't necessarily mean it will be easy to hunt! Or that you will bag one For what its worth: A 2 flute drill will produce a hole with 3 corners. A 3 flute drill will produce a hole with 4 corners. A 4 flute drill will produce a hole with 5 corners. and so on. With each additional flute the corners decrease in depth. the formula is N+1 (N=number of flutes). I learned this in my first week as an apprentice with the IAM (Internation al Aerospace Workers & Machinists Union) I think this is covered in the Machinery's Hand book as well? -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopsp; -Matt Dr=== ========= ======================== =========== -= - The Zenith601-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Zenith601-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Subject: Purpose of bottom cap angle 6 ZU1-5
From: "chris Sinfield" <chris_sinfield(at)yahoo.com.au>
Date: May 22, 2010
Ok I give up what is the purpose of this part? and why is it important to have it there if you have the newer 3 nose rib design? Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298539#298539 ________________________________________________________________________________
Date: May 22, 2010
Subject: Re: Purpose of bottom cap angle 6 ZU1-5
I think that's a question for Caleb. They had 2 of them in there until I called and told him the other one couldn't be installed because of the access hole so they omitted it. The wings with 4 ribs don't get them. So it might just be to make up for the 4th rib. Jeff In a message dated 5/22/2010 4:15:44 P.M. Central Daylight Time, chris_sinfield(at)yahoo.com.au writes: --> Zenith601-List message posted by: "chris Sinfield" Ok I give up what is the purpose of this part? and why is it important to have it there if you have the newer 3 nose rib design? Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298539#298539 ________________________________________________________________________________
Date: May 22, 2010
Thanks for the part numbers. I assume that is for the bolt only and the nut will have a different equally complex part number. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298546#298546 ________________________________________________________________________________
Subject: Oops! A6 Rivet question
Date: May 22, 2010
I removed the top skin on my right wing today. Because of some pesky stems that protruded too high I had trouble with a few rivets, resulting in some very slightly enlarged or out of round holes. I know that in this case others have installed A6 rivets. My question is, did you use countersunk or dome head? If you used countersunk rivets did you pull them with the nosepiece ground for the A5 rivet or make a new one? Thanks! Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Working on fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298547#298547 ________________________________________________________________________________
Date: May 22, 2010
Actually, no. The nut is the standard nut for a AN5. The threads are the same size just the shank is oversized. Floyd Wilkes 601XL flying after upgrade. -----Original Message----- From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of chuck960 Sent: Saturday, May 22, 2010 7:12 PM Subject: Zenith601-List: Re: upgrade question Thanks for the part numbers. I assume that is for the bolt only and the nut will have a different equally complex part number. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298546#298546 ________________________________________________________________________________
Date: May 22, 2010
I have a set of adjustable size reamers turned by hand in a tap chuck. I started with slight under size holes and slowly worked my way up to where the spar bolts were a tight push fit. The adjustable reamers have a very slight taper so the end fits in the under size hole. You run the reamer all the way through so it doesn't leave a tapered hole. -------- Louis W. Ott 601XL beginner Quick Build Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298557#298557 ________________________________________________________________________________
Subject: Re: Oops! A6 Rivet question
Date: May 22, 2010
Tim, one of the airplanes I am working on needed some A6 rivets. I used the counter sunk style and made a new tip for the rivet gun. If you use an automatic center punch to knock the mandrels down before you drill you will need fewer A6 rivets. I have posted a Blog on the Zenith Aero site entitled: CH601XL Up Grades with Magnificent Machine LLC (tricks of the trade) http://www.zenith.aero/profiles/blogs/ch601xl-upgrades-with there might be some useful info in there, specifically about tooling for this project. Cheers, -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298558#298558 ________________________________________________________________________________
Date: May 22, 2010
> > The "X" is .015 oversize and the "Y" is .030 oversize. > > Bill Pagan Thank you Bill, That had slipped my mind and my coffee had not kicked in yet. :) -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298560#298560 ________________________________________________________________________________
Date: May 23, 2010
thanks yep I have an access hole in the next section as well. I guess I will have to ask.. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298564#298564 ________________________________________________________________________________
Date: May 23, 2010
TIM- On the rivets that have stems that keep you from drilling and cause the drill to go off-center and make a mess- Use a center punch and a light hammer and try to drive the stem back into yhe opposte end . Then try drilling the rivet hear off. Sometimes it takes a few tries to drive the rivet center in. Be carefull you don't bend or dent the aluminum skin. I did have to use a few #6 rivets a couple years ago when I opened the leading edge on both wings to take out the two aux. tanks but don't remember which pulling head I used. Presently, I have both wings off with the topskins removed along with both leading edge skins. Also, the center section srar is out. I have stripped both spars fron the wings for easier handling. I have decided bolt yhe new heavy angles onto the spars after trying unsucessfully to rivet. The left wing will be closed and finished in about a week or two. Then comes the right wing and then the center spar and fuselage work. Looks like an all summer job. If you get a chance take a trip down and see my slow progress. ROY ----- Original Message ----- From: "Tim Juhl" <juhl(at)avci.net> Sent: Saturday, May 22, 2010 8:13 PM Subject: Zenith601-List: Oops! A6 Rivet question > > I removed the top skin on my right wing today. Because of some pesky > stems that protruded too high I had trouble with a few rivets, resulting > in some very slightly enlarged or out of round holes. > > I know that in this case others have installed A6 rivets. My question is, > did you use countersunk or dome head? If you used countersunk rivets did > you pull them with the nosepiece ground for the A5 rivet or make a new > one? > > Thanks! > > Tim > > -------- > ______________ > CFII > Champ L16A flying > Zodiac XL - Jabiru 3300A > Working on fuselage > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=298547#298547 > > > ________________________________________________________________________________
Date: May 23, 2010
Tim Juhl wrote: > I know that in this case others have installed A6 rivets. My question is, did you use countersunk or dome head? If you used countersunk rivets did you pull them with the nosepiece ground for the A5 rivet or make a new one? I used A6 rivets that I bought from Zenith. They are the countersunk type, just like the A4's and A5's we already use, just a little bigger. I bought a bigger hand riveter and ground out one of the nosepieces that came with it. For removing the pre-existing rivets, I used one of those $3 "spring punches". I ground down the tip so it could fit into the holes in the rivets. For each rivet I would punch down the stem, and then using a drill bit *larger* than the existing rivet, I would carefully drill into the rivet head until it popped off (without touching the underlying skin or enlarging the existing hole). Then most rivets could be pushed out the rest of the way with a second pop from the spring punch. Stubborn ones got drilled out with a smaller drill so as to not enlarge the existing hole. A4's are harder to remove than A5's, as A4's more often tend to "spin". To get around that, I carefully drill into their heads at an acute angle until the heads come off. It took a while, but I've got one wing just about done now. By far the biggest problem I've had is "garage rash" as these skins are taking a beating and getting all scratched no matter how careful I am. I want to polish my skins, but I don't know how it will look with some of the scratches I can already see. -------- Patrick XL/650/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298574#298574 ________________________________________________________________________________
Date: May 23, 2010
Hi Patrick, I have found a slightly different approach for removing rivets. I do nothing before drilling, and use the same size drill bit as the final rivet hole. I drill very slowly - using a variable speed battery powered drill. Most of the time the head starts to spin when the drill bit reaches the skin and I am finished. In cases where the stem gets in the way the drill bit goes off center and I stop before the bit reaches the skin. Then I use a normal wood chisel and mallet to tap off the remaining part of the rivet head. With the rivet partially drilled this goes very easily. I have done a lot of wood work over the years, so it is easy for me to position the wood chisel so it doesn't damage the skin. For less experienced wood workers, I would recommend a little practice in partially drilled rivets in scrap pieces. After the rivet head is removed, I use a slightly smaller pin punch and mallet to remove the remains from the hole. Some times this makes a bit of a dent in the skin, but this is easily removed with auto body dolly and hammer. ------ For removing the pre-existing rivets, I used one of those $3 "spring punches". I ground down the tip so it could fit into the holes in the rivets. For each rivet I would punch down the stem, and then using a drill bit *larger* than the existing rivet, I would carefully drill into the rivet head until it popped off (without touching the underlying skin or enlarging the existing hole). Then most rivets could be pushed out the rest of the way with a second pop from the spring punch. Stubborn ones got drilled out with a smaller drill so as to not enlarge the existing hole. ------ I don't think you need to worry too much about scratches impacting your polishing. The polishing process is designed to remove them. If you have deep scratches you should probably smooth them out with emery cloth, but the shallow ones will be polished out without much extra effort. ----- It took a while, but I've got one wing just about done now. By far the biggest problem I've had is "garage rash" as these skins are taking a beating and getting all scratched no matter how careful I am. I want to polish my skins, but I don't know how it will look with some of the scratches I can already see. -------- Paul XL installing changes N773PM ________________________________________________________________________________
Date: May 23, 2010
I used a spring loaded center punch to attempt to drive out the pin with no success. Also tried a punch and a few gentle taps from a hammer... no luck. Even worse, the top of the pin was broken on an angle resulting in the drill trying to walk off center. I ended up using a #40 drill to start it while holding the drill centered (as best as I could get it) with a drilling cup. This happened only in the A5 rivets and to about 6 in the top skin. Thanks for the advice! Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298588#298588 ________________________________________________________________________________
Date: May 23, 2010
If your aircraft isn't painted you can use a wood chisel to remove all riv ets and leave no dents and it makes the tail removal much easier also. I use a chisel to remove the solid rivet heads then just punch out the sho p end with a punch and hammer over a vise. I have gotten to the point that I can disassemble the center spar and remove all the rivets in 30 minutes . I do the same with the wing spar but I have to drill half way thru them and use my 2X to punch the shop end out. If you use a chisel you need to smooth the bottom so it doesn't scratch or gouge the aluminum. Jeff -----Original Message----- From: Tim Juhl <juhl(at)avci.net> Sent: Sun, May 23, 2010 11:11 am Subject: Zenith601-List: Re: Oops! A6 Rivet question I used a spring loaded center punch to attempt to drive out the pin with no uccess. Also tried a punch and a few gentle taps from a hammer... no luck . ven worse, the top of the pin was broken on an angle resulting in the dril l rying to walk off center. I ended up using a #40 drill to start it while olding the drill centered (as best as I could get it) with a drilling cup. his happened only in the A5 rivets and to about 6 in the top skin. Thanks for the advice! Tim -------- _____________ FII hamp L16A flying odiac XL - Jabiru 3300A earing wings apart for modification ead this topic online here: http://forums.matronics.com/viewtopic.php?p=298588#298588 ======================== =========== -= - The Zenith601-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Zenith601-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Subject: Re: upgrade question
Date: May 23, 2010
afterfxllc(at)aol.com wrote: > For what it is worth I have done 4 upgrades and built 3 flying 601's (None in the dirt BTW) and I have taken apart 7 601's and have seen everything from 10 lb lead shot bags in the wingtip, wing AOA 50mm apart, loose spar bolts, bottomed out spar bolts, smaller bolts for rear attach point. And non of these failed. And as a matter of fact none of the wing attach bolts broke or were the cause of wing failures. The spar snapped at the first bolt hole but the bolts remained. Now as a matter of engineering of course the holes should be reamed if at all possible but remember there are thousands of aircraft flying that have drilled spar bolts and are safe. Zenith once told us alittle loose is ok but not sloppy but after what has happened every thing has to be technically correct. I use a reamer but wouldn't think one minute about drilling my own spars with a drill bit because I know I can do it correctly and I now believe the spar and center section wasn't the problem to begin with and after seeing the sloppy building of some of these aircraft that didn't break apart I believe and and have always believed flutter is the most likely reason for the failures. > > > > > Jeff > > -- Jeff, I want to point out that just because a substandard assembly has not failed yet, doesn't mean that it won't fail in the future, or that it can some how be thought of as safe. Encouraging, justifying and or down playing the dangers of sloppy building practices is irresponsible at best. The last thing the 601 community needs is for "Up Graded" 601's falling out of the sky. That would cause serious trouble for everyone. Your willingness to openly admit that you would cut such corners on your own plane only makes people wonder what corners you cut or are willing to cut on their airplanes. Why would you hold a higher standard for the safety of others than you do your own? The fact that you think you can drill a hole with a 2 fluted drill bit that is some how good enough with out reaming, when the directions specifically call for a Reamed hole, only proves that you don't understand the reasons behind the process. > > And as a matter of fact none of the wing attach bolts broke or were the cause of wing failures. The spar snapped at the first bolt hole but the bolts remained. > This statement says it all: Apparently you don't understand why the bolts are being over sized? No one is concerned that the bolts are breaking. Did it ever occur to you that the reason that spar broke at that hole was because perhaps the fit between the bolt and the hole was too loose and it was able to work the hole open further until it finally broke? Or maybe it was one of those sloppy building techniques you mentioned earlier that hadn't failed yet but finally did? The difference between a professional and an armature is that a professional knows enough to know what he doesn't know, and is able to park his ego long enough to ask the questions he needs to do the job right. Your personal attacks are only a sign that you have exhausted your technical experience and knowledge. The fact that you have built 3 flying 601s and upgraded 4 does not make me rest easy, it causes me great concern. I don't see this as a pissing contest, I see it as an opportunity to teach and learn. -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298613#298613 ________________________________________________________________________________
Date: May 23, 2010
Hey, Brady. Not to be a picky twitch, but the word "armature" in your post to Jeff describes a thing that spins around with a lot of motion, but in the end, goes nowhere. "Amateur", on the other hand, is a thing that expends a lot of energy but ends up with little to show for it. Come to think of it, you're original usage may be correct after all... Rick -----Original Message----- >From: Brady <brady(at)magnificentmachine.com> >Sent: May 23, 2010 3:00 PM >To: zenith601-list(at)matronics.com >Subject: Zenith601-List: Re: upgrade question > > >afterfxllc(at)aol.com wrote: >> For what it is worth I have done 4 upgrades and built 3 flying 601's (None in the dirt BTW) and I have taken apart 7 601's and have seen everything from 10 lb lead shot bags in the wingtip, wing AOA 50mm apart, loose spar bolts, bottomed out spar bolts, smaller bolts for rear attach point. And non of these failed. And as a matter of fact none of the wing attach bolts broke or were the cause of wing failures. The spar snapped at the first bolt hole but the bolts remained. Now as a matter of engineering of course the holes should be reamed if at all possible but remember there are thousands of aircraft flying that have drilled spar bolts and are safe. Zenith once told us alittle loose is ok but not sloppy but after what has happened every thing has to be technically correct. I use a reamer but wouldn't think one minute about drilling my own spars with a drill bit because I know I can do it correctly and I now believe the spar and center section wasn't the problem to begi! > n with and after seeing the sloppy building of some of these aircraft that didn't break apart I believe and and have always believed flutter is the most likely reason for the failures. >> >> >> >> >> Jeff >> >> -- > > >Jeff, >I want to point out that just because a substandard assembly has not failed yet, doesn't mean that it won't fail in the future, or that it can some how be thought of as safe. >Encouraging, justifying and or down playing the dangers of sloppy building practices is irresponsible at best. >The last thing the 601 community needs is for "Up Graded" 601's falling out of the sky. >That would cause serious trouble for everyone. > >Your willingness to openly admit that you would cut such corners on your own plane only makes people wonder what corners you cut or are willing to cut on their airplanes. >Why would you hold a higher standard for the safety of others than you do your own? > >The fact that you think you can drill a hole with a 2 fluted drill bit that is some how good enough with out reaming, when the directions specifically call for a Reamed hole, only proves that you don't understand the reasons behind the process. > > >> >> And as a matter of fact none of the wing attach bolts broke or were the cause of wing failures. The spar snapped at the first bolt hole but the bolts remained. >> > > >This statement says it all: >Apparently you don't understand why the bolts are being over sized? >No one is concerned that the bolts are breaking. >Did it ever occur to you that the reason that spar broke at that hole was because perhaps the fit between the bolt and the hole was too loose and it was able to work the hole open further until it finally broke? >Or maybe it was one of those sloppy building techniques you mentioned earlier that hadn't failed yet but finally did? > >The difference between a professional and an armature is that a professional knows enough to know what he doesn't know, and is able to park his ego long enough to ask the questions he needs to do the job right. > >Your personal attacks are only a sign that you have exhausted your technical experience and knowledge. > >The fact that you have built 3 flying 601s and upgraded 4 does not make me rest easy, it causes me great concern. > >I don't see this as a pissing contest, I see it as an opportunity to teach and learn. > >-------- >Brady McCormick >Poulsbo, WA >www.magnificentmachine.com > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=298613#298613 > > ________________________________________________________________________________
Date: May 23, 2010
tigerrick(at)mindspring.c wrote: > Hey, Brady. > > Not to be a picky twitch, but the word "armature" in your post to Jeff describes a thing that spins around with a lot of motion, but in the end, goes nowhere. > > "Amateur", on the other hand, is a thing that expends a lot of energy but ends up with little to show for it. > > Come to think of it, you're original usage may be correct after all... > > Rick > > > -- Spell check works in mysterious ways.... My intent was in fact "Amateur" I'll try to proof read before posting. Thanks, -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298622#298622 ________________________________________________________________________________
Date: May 23, 2010
Brady I guess I could talk about your new Corvair crank that came apart but you are the expert. When you get your first airplane flying come talk to me but until then you sir are the amateur. And it's funny that only you and Ron have had any problems with my post and could that have anything to do with the Corvair? Well enough time wasted on a wanna be airplane builder I am gonna go flyin g in my 601 with a corvair now. O BTW have fun cooling that 701 with a Corvair engine but what do I know right mine run cooler than any with all the unsafe parts I designed and BTW you copied. Jeff -----Original Message----- From: Brady <brady(at)magnificentmachine.com> Sent: Sun, May 23, 2010 3:00 pm Subject: Zenith601-List: Re: upgrade question m> fterfxllc(at)aol.com wrote: For what it is worth I have done 4 upgrades and built 3 flying 601's (Non e in he dirt BTW) and I have taken apart 7 601's and have seen everything from 10 lb ead shot bags in the wingtip, wing AOA 50=C3=AF=C2=C2=BDmm apart, loose spar bolts, ottomed out spar bolts, smaller bolts for rear attach point. And non of th ese ailed. And as a matter of fact none of the wing attach bolts broke or were the ause of wing failures. The spar snapped at the first bolt hole but the bol ts emained. Now as a matter of engineering of course the holes should be ream ed if t all possible but remember there are thousands of aircraft flying that ha ve rilled spar bolts and are safe. Zenith once told us alittle loose is ok but ot sloppy but after what has happened every thing has to be technically orrect. I use a reamer but wouldn't think one minute about drilling my own pars with a drill bit because I know I can do it correctly and I now belie ve he spar and center section wasn't the problem to begin with and after seei ng he sloppy building of some of these aircraft that didn't break apart I bel ieve nd and have always believed flutter is the most likely reason for the fail ures. > Jeff -- eff, want to point out that just because a substandard assembly has not failed yet, oesn't mean that it won't fail in the future, or that it can some how be hought of as safe. ncouraging, justifying and or down playing the dangers of sloppy building ractices is irresponsible at best. he last thing the 601 community needs is for "Up Graded" 601's falling out of he sky. hat would cause serious trouble for everyone. Your willingness to openly admit that you would cut such corners on your own lane only makes people wonder what corners you cut or are willing to cut on heir airplanes. hy would you hold a higher standard for the safety of others than you do your wn? The fact that you think you can drill a hole with a 2 fluted drill bit tha t is ome how good enough with out reaming, when the directions specifically cal l for Reamed hole, only proves that you don't understand the reasons behind the rocess. And as a matter of fact none of the wing attach bolts broke or were the cause f wing failures. The spar snapped at the first bolt hole but the bolts emained. his statement says it all: pparently you don't understand why the bolts are being over sized? o one is concerned that the bolts are breaking. id it ever occur to you that the reason that spar broke at that hole was ecause perhaps the fit between the bolt and the hole was too loose and it was ble to work the hole open further until it finally broke? r maybe it was one of those sloppy building techniques you mentioned earli er hat hadn't failed yet but finally did? The difference between a professional and an armature is that a profession al nows enough to know what he doesn't know, and is able to park his ego long nough to ask the questions he needs to do the job right. Your personal attacks are only a sign that you have exhausted your technic al xperience and knowledge. The fact that you have built 3 flying 601s and upgraded 4 does not make me rest asy, it causes me great concern. I don't see this as a pissing contest, I see it as an opportunity to teach and earn. -------- rady McCormick oulsbo, WA ww.magnificentmachine.com ead this topic online here: http://forums.matronics.com/viewtopic.php?p=298613#298613 ======================== =========== -= - The Zenith601-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Zenith601-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: May 23, 2010
I have a problem with you guys bringing your private argument to this forum .- Give it a rest for the benefit of all of us.=0A-Bill Pagan =0A=0A=0A =0A=0A=0A=0A________________________________=0AFrom: "afterfxllc(at)aol.com" < afterfxllc(at)aol.com>=0ATo: zenith601-list(at)matronics.com=0ASent: Sun, May 23, 2010 6:27:00 PM=0ASubject: Re: Zenith601-List: Re: upgrade question=0A=0AB rady=0A=0AI guess I could talk about your new Corvair crank that came apart but you are the expert. When you get your first airplane flying come talk to me but until then you sir are the amateur. And it's funny that only you and Ron have had any problems with my post and could that have anything to do with the Corvair? =0AWell enough time wasted on a wanna be airplane buil der I am gonna go flying in my 601 with a corvair now.=0A=0AO BTW have fun cooling that 701 with a Corvair engine but what do I know right mine run co oler than any with-all the unsafe parts I designed and BTW you copied.=0A =0AJeff=0A-=0A=0A-----Original Message-----=0AFrom: Brady <brady@magnific entmachine.com>=0ATo: zenith601-list(at)matronics.com=0ASent: Sun, May 23, 201 0 3:00 pm=0ASubject: Zenith601-List: Re: upgrade question=0A=0A=0A--> Zenit h601-List message posted by: "Brady" =0A=0A =0Aafterfxllc(at)aol.com wrote:=0A> For what it is worth I have done 4 upgr ades and built 3 flying 601's (None in =0Athe dirt BTW) and I have taken ap art 7 601's and have seen everything from 10 lb =0Alead shot bags in the wi ngtip, wing AOA 50=EF=BDmm apart, loose spar bolts, =0Abottomed out spar bolts, smaller bolts for rear attach point. And non of these =0Afailed. An d as a matter of fact none of the wing attach bolts broke or were the =0Aca use of wing failures. The spar snapped at the first bolt hole but the bolts =0Aremained. Now as a matter of engineering of course the holes should be reamed if =0Aat all possible but remember there are thousands of aircraft f lying that have =0Adrilled spar bolts and are safe. Zenith once told us al ittle loose is ok but =0Anot sloppy but after what has happened every thing has to be technically =0Acorrect. I use a reamer but wouldn't think one mi nute about drilling my own =0Aspars with a drill bit because I know I can d o it correctly and I now believe =0Athe spar and center section wasn't the problem to begin with and after seeing =0Athe sloppy building of some of th ese aircraft that didn't break apart I believe =0Aand and have always belie ved flutter is the most likely reason for the failures. =0A=0A> =0A> =0A> =0A> =0A> Jeff=0A> =0A> --=0A=0A=0AJeff,=0AI want to point o ut that just because a substandard assembly has not failed yet, =0Adoesn't mean that it won't fail in the future, or that it can some how be =0Athough t of as safe.=0AEncouraging, justifying and or down playing the dangers of sloppy building =0Apractices is irresponsible at best.=0AThe last thing the 601 community needs is for "Up Graded" 601's falling out of =0Athe sky.=0A That would cause serious trouble for everyone.=0A=0AYour willingness to ope nly admit that you would cut such corners on your own =0Aplane only makes p eople wonder what corners you cut or are willing to cut on =0Atheir airplan es. =0AWhy would you hold a higher standard for the safety of others than y ou do your =0Aown?=0A=0AThe fact that you think you can drill a hole with a 2 fluted drill bit that is =0Asome how good enough with out reaming, when the directions specifically call for =0Aa Reamed hole, only proves that you don't understand the reasons behind the =0Aprocess.=0A=0A=0A> =0A> And as a matter of fact none of the wing attach bolts broke or were the cause =0Ao f wing failures. The spar snapped at the first bolt hole but the bolts =0Ar emained. =0A> =0A=0A=0AThis statement says it all:=0AApparently you don't u nderstand why the bolts are being over sized?=0ANo one is concerned that th e bolts are breaking. =0ADid it ever occur to you that the reason that spar broke at that hole was =0Abecause perhaps the fit between the bolt and the hole was too loose and it was =0Aable to work the hole open further until it finally broke?=0AOr maybe it was one of those sloppy building techniques you mentioned earlier =0Athat hadn't failed yet but finally did?=0A=0AThe difference between a professional and an armature is that a professional =0Aknows enough to know what he doesn't know, and is able to park his ego l ong =0Aenough to ask the questions he needs to do the job right.=0A=0AYour personal attacks are only a sign that you have exhausted your technical =0A experience and knowledge.=0A=0AThe fact that you have built 3 flying 601s a nd upgraded 4 does not make me rest =0Aeasy, it causes me great concern.=0A =0AI don't see this as a pissing contest, I see it as an opportunity to tea ch and =0Alearn.=0A=0A--------=0ABrady McCormick=0APoulsbo, WA=0Awww.magnif icentmachine.com=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://for ums.matronics.com/viewtopic.php?p=298613#298613=0A=0A=0A=0A=0A=0A=0A=0A ============0At" target=_blank>http://www.matronics .com/Navigator?Zenith601-List=============== ======================0Atp://foru ms.matronics.com=0A================== ===================0A_blank>http://www. matronics.com/contribution================ =====================0A=0A=0A=0A=0A -======================== ====================0A=0A=0A ________________________________________________________________________________
Date: May 23, 2010
Your right Bill, See what a simple test can turn into? Thats why most don' t post because other can't wait to flame you but I have been on these list s since building RV's and they are all the same. I said I was done with th e pissing match but they can't let it rest. So now I am done with the pissing match again. LOL BTW are you going with push pull tubes? The ones I installed work great bu t it isn't a quick conversion as you know but when I talked to Sebastian about them he seemed to like the way I went about doing it. We are Flying 962T again tomorrow and that will end the 5 hour Phase 1 and I think Thomas is coming to pick it up this week. I am going to install a Van's slider canopy in my next 601 that I am build ing now along with a Corvair and push pull tubes. Believe it or not the 60 1 is 20 mm wider than the RV-7 and I think the only thing that I need to modify is the turtle deck as the RV has bulkheads that are flat at the to p and rounds as it nears the tail. Have a good one Jeff -----Original Message----- From: Bill Pagan <bill.pagan(at)yahoo.com> Sent: Sun, May 23, 2010 7:03 pm Subject: Re: Zenith601-List: Re: upgrade question I have a problem with you guys bringing your private argument to this foru m. Give it a rest for the benefit of all of us. Bill Pagan From: "afterfxllc(at)aol.com" <afterfxllc(at)aol.com> Sent: Sun, May 23, 2010 6:27:00 PM Subject: Re: Zenith601-List: Re: upgrade question Brady I guess I could talk about your new Corvair crank that came apart but you are the expert. When you get your first airplane flying come talk to me but until then you sir are the amateur. And it's funny that only you and Ron have had any problems with my post and could that have anything to do with the Corvair? Well enough time wasted on a wanna be airplane builder I am gonna go flyin g in my 601 with a corvair now. O BTW have fun cooling that 701 with a Corvair engine but what do I know right mine run cooler than any with all the unsafe parts I designed and BTW you copied. Jeff -----Original Message----- From: Brady <brady(at)magnificentmachine.com> Sent: Sun, May 23, 2010 3:00 pm Subject: Zenith601-List: Re: upgrade question m> fterfxllc(at)aol.com wrote: For what it is worth I have done 4 upgrades and built 3 flying 601's (Non e in he dirt BTW) and I have taken apart 7 601's and have seen everything from 10 lb ead shot bags in the wingtip, wing AOA 50=C3=AF=C2=C2=BDmm apart, loose spar bolts, ottomed out spar bolts, smaller bolts for rear attach point. And non of th ese ailed. And as a matter of fact none of the wing attach bolts broke or were the ause of wing failures. The spar snapped at the first bolt hole but the bol ts emained. Now as a matter of engineering of course the holes should be ream ed if t all possible but remember there are thousands of aircraft flying that ha ve rilled spar bolts and are safe. Zenith once told us alittle loose is ok but ot sloppy but after what has happened every thing has to be technically orrect. I use a reamer but wouldn't think one minute about drilling my own pars with a drill bit because I know I can do it correctly and I now belie ve he spar and center section wasn't the problem to begin with and after seei ng he sloppy building of some of these aircraft that didn't break apart I bel ieve nd and have always believed flutter is the most likely reason for the fail ures. > Jeff -- eff, want to point out that just because a substandard assembly has not failed yet, oesn't mean that it won't fail in the future, or that it can some how be hought of as safe. ncouraging, justifying and or down playing the dangers of sloppy building ractices is irresponsible at best. he last thing the 601 community needs is for "Up Graded" 601's falling out of he sky. hat would cause serious trouble for everyone. Your willingness to openly admit that you would cut such corners on your own lane only makes people wonder what corners you cut or are willing to cut on heir airplanes. hy would you hold a higher standard for the safety of others than you do your wn? The fact that you think you can drill a hole with a 2 fluted drill bit tha t is ome how good enough with out reaming, when the directions specifically cal l for Reamed hole, only proves that you don't understand the reasons behind the rocess. And as a matter of fact none of the wing attach bolts broke or were the cause f wing failures. The spar snapped at the first bolt hole but the bolts emained. his statement says it all: pparently you don't understand why the bolts are being over sized? o one is concerned that the bolts are breaking. id it ever occur to you that the reason that spar broke at that hole was ecause perhaps the fit between the bolt and the hole was too loose and it was ble to work the hole open further until it finally broke? r maybe it was one of those sloppy building techniques you mentioned earli er hat hadn't failed yet but finally did? The difference between a professional and an armature is that a profession al nows enough to know what he doesn't know, and is able to park his ego long nough to ask the questions he needs to do the job right. Your personal attacks are only a sign that you have exhausted your technic al xperience and knowledge. The fact that you have built 3 flying 601s and upgraded 4 does not make me rest asy, it causes me great concern. I don't see this as a pissing contest, I see it as an opportunity to teach and earn. -------- rady McCormick oulsbo, WA ww.magnificentmachine.com ead this topic online here: http://forums.matronics.com/viewtopic.php?p=298613#298613 ======================== =========== " target=_blank>http://www.matronics.com/Navigator?Zenith601-List== ======== p://forums.matronics.com ========= blank>http://www.matronics.com/contribution========== ======================== =========== -= - The Zenith601-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Zenith601-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Subject: Re: slider canopy
Date: May 23, 2010
An RV has pretty much straight sides where the 601/50 has a pretty good flare front to back. How are you planning to have the narrow front part slide over the wider back part? I've been thinking about this, and it seem like the canopy would have to lift up, a lot, more than on an RV, before sliding. For what it's worth, the 601 also has more head and leg room the than an RV7 (only one I've attempted to get into - and failed). I really hope you do this, I'd love to see your solution. Ron On May 23, 2010, at 9:25 PM, Afterfxllc(at)aol.com wrote: > Your right Bill, See what a simple test can turn into? Thats why > most don't post because other can't wait to flame you but I have > been on these lists since building RV's and they are all the same. I > said I was done with the pissing match but they can't let it rest. > > So now I am done with the pissing match again. LOL > > BTW are you going with push pull tubes? The ones I installed work > great but it isn't a quick conversion as you know but when I talked > to Sebastian about them he seemed to like the way I went about doing > it. > > We are Flying 962T again tomorrow and that will end the 5 hour Phase > 1 and I think Thomas is coming to pick it up this week. > I am going to install a Van's slider canopy in my next 601 that I am > building now along with a Corvair and push pull tubes. Believe it or > not the 601 is 20 mm wider than the RV-7 and I think the only thing > that I need to modify is the turtle deck as the RV has bulkheads > that are flat at the top and rounds as it nears the tail. > > Have a good one > > Jeff > > > -----Original Message----- > From: Bill Pagan <bill.pagan(at)yahoo.com> > To: zenith601-list(at)matronics.com > Sent: Sun, May 23, 2010 7:03 pm > Subject: Re: Zenith601-List: Re: upgrade question > > I have a problem with you guys bringing your private argument to > this forum. Give it a rest for the benefit of all of us. > > Bill Pagan > > > From: "afterfxllc(at)aol.com" <afterfxllc(at)aol.com> > To: zenith601-list(at)matronics.com > Sent: Sun, May 23, 2010 6:27:00 PM > Subject: Re: Zenith601-List: Re: upgrade question > > Brady > > I guess I could talk about your new Corvair crank that came apart > but you are the expert. When you get your first airplane flying come > talk to me but until then you sir are the amateur. And it's funny > that only you and Ron have had any problems with my post and could > that have anything to do with the Corvair? > Well enough time wasted on a wanna be airplane builder I am gonna go > flying in my 601 with a corvair now. > > O BTW have fun cooling that 701 with a Corvair engine but what do I > know right mine run cooler than any with all the unsafe parts I > designed and BTW you copied. > > Jeff > > -----Original Message----- > From: Brady <brady(at)magnificentmachine.com> > To: zenith601-list(at)matronics.com > Sent: Sun, May 23, 2010 3:00 pm > Subject: Zenith601-List: Re: upgrade question > > > > > afterfxllc(at)aol.com wrote: > > For what it is worth I have done 4 upgrades and built 3 flying > 601's (None in > the dirt BTW) and I have taken apart 7 601's and have seen > everything from 10 lb > lead shot bags in the wingtip, wing AOA 50=EF=BDmm apart, loose spar > bolts, > bottomed out spar bolts, smaller bolts for rear attach point. And > non of these > failed. And as a matter of fact none of the wing attach bolts broke > or were the > cause of wing failures. The spar snapped at the first bolt hole but > the bolts > remained. Now as a matter of engineering of course the holes should > be reamed if > at all possible but remember there are thousands of aircraft flying > that have > drilled spar bolts and are safe. Zenith once told us alittle loose > is ok but > not sloppy but after what has happened every thing has to be > technically > correct. I use a reamer but wouldn't think one minute about drilling > my own > spars with a drill bit because I know I can do it correctly and I > now believe > the spar and center section wasn't the problem to begin with and > after seeing > the sloppy building of some of these aircraft that didn't break > apart I believe > and and have always believed flutter is the most likely reason for > the failures. > > > > > > > > > > > Jeff > > > > -- > > > Jeff, > I want to point out that just because a substandard assembly has not > failed yet, > doesn't mean that it won't fail in the future, or that it can some > how be > thought of as safe. > Encouraging, justifying and or down playing the dangers of sloppy > building > practices is irresponsible at best. > The last thing the 601 community needs is for "Up Graded" 601's > falling out of > the sky. > That would cause serious trouble for everyone. > > Your willingness to openly admit that you would cut such corners on > your own > plane only makes people wonder what corners you cut or are willing > to cut on > their airplanes. > Why would you hold a higher standard for the safety of others than > you do your > own? > > The fact that you think you can drill a hole with a 2 fluted drill > bit that is > some how good enough with out reaming, when the directions > specifically call for > a Reamed hole, only proves that you don't understand the reasons > behind the > process. > > > > > > And as a matter of fact none of the wing attach bolts broke or > were the cause > of wing failures. The spar snapped at the first bolt hole but the > bolts > remained. > > > > > This statement says it all: > Apparently you don't understand why the bolts are being over sized? > No one is concerned that the bolts are breaking. > Did it ever occur to you that the reason that spar broke at that > hole was > because perhaps the fit between the bolt and the hole was too loose > and it was > able to work the hole open further until it finally broke? > Or maybe it was one of those sloppy building techniques you > mentioned earlier > that hadn't failed yet but finally did? > > The difference between a professional and an armature is that a > professional > knows enough to know what he doesn't know, and is able to park his > ego long > enough to ask the questions he needs to do the job right. > > Your personal attacks are only a sign that you have exhausted your > technical > experience and knowledge. > > The fact that you have built 3 flying 601s and upgraded 4 does not > make me rest > easy, it causes me great concern. > > I don't see this as a pissing contest, I see it as an opportunity to > teach and > learn. > > -------- > Brady McCormick > Poulsbo, WA > www.magnificentmachine.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=298613#298613 > > > ======================== =========== > t" target=_blank>http://www.matronics.com/Navigator?Zenith601-List=== ======= > tp://forums.matronics.com > _blank>http://www.matronics.com/contribution========== > > > ======================== =========== > t" target=_blank>http://www.matronics.com/Navigator?Zenith601-List > ======================== =========== > tp://forums.matronics.com > ======================== =========== > _blank>http://www.matronics.com/contribution > ======================== =========== > > ________________________________________________________________________________
Date: May 23, 2010
I too, spent 2 years occasionally needing to remove a rivet only to run into the stem and over sizing the hole. Then I heard from Mr. Garrett on the use of a chisel. I absolutely could not believe I had never heard of this technique before. I use a half inch wood chisel and have removed several hundred rivets now and everyone of them left the hole completely untouched. The head just shears right off and the back of the rivet can be pulled out with a pair of dikes or pliers or if necessary, a light tap of a punch. I do not have any painted parts but with the flat side polished a little, it leaves very little in the way of a mark. In addition, you can get to any head at any angle unlike a drill. I don't believe I will ever drill out another rivet. Try it. You just won't believe it ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298665#298665 ________________________________________________________________________________
Date: May 23, 2010
We have a RV-7 in the other hanger and I have done all the measurements an d it works out but the bulkheads have to be flattened at the turtle deck an d gradually round as it goes back. Jeff In a message dated 5/23/2010 10:02:09 P.M. Eastern Daylight Time, rsteele(at)rjsit.com writes: An RV has pretty much straight sides where the 601/50 has a pretty good flare front to back. How are you planning to have the narrow front part slide over the wider back part? I've been thinking about this, and it se em like the canopy would have to lift up, a lot, more than on an RV, before sliding. For what it's worth, the 601 also has more head and leg room th e than an RV7 (only one I've attempted to get into - and failed). I really hope you do this, I'd love to see your solution. Ron On May 23, 2010, at 9:25 PM, _Afterfxllc(at)aol.com_ (mailt o:Afterfxllc(at)aol.com) wrote: Your right Bill, See what a simple test can turn into? Thats why most don't post because other can't wait to flame you but I have been on these lists since building RV's and they are all the same. I said I was done with the pissing match but they can't let it rest. So now I am done with the pissing match again. LOL BTW are you going with push pull tubes? The ones I installed work great but it isn't a quick conversion as you know but when I talked to Sebastian about them he seemed to like the way I went about doing it. We are Flying 962T again tomorrow and that will end the 5 hour Phase 1 an d I think Thomas is coming to pick it up this week. I am going to install a Van's slider canopy in my next 601 that I am building now along with a Corvair and push pull tubes. Believe it or not the 601 is 20 mm wider than the RV-7 and I think the only thing that I need to modify is the turtle deck as the RV has bulkheads that are flat at the top and rounds as it nears the tail. Have a good one Jeff -----Original Message----- From: Bill Pagan <_bill.pagan(at)yahoo.com_ (mailto:bill.pagan(at)yahoo.com) > Sent: Sun, May 23, 2010 7:03 pm Subject: Re: Zenith601-List: Re: upgrade question I have a problem with you guys bringing your private argument to this forum. Give it a rest for the benefit of all of us. Bill Pagan ____________________________________ From: "_afterfxllc(at)aol.com_ (mailto:afterfxllc(at)aol.com) " <_afterfxllc(at)aol.com_ (mailto:afterfxllc(at)aol.com) > Sent: Sun, May 23, 2010 6:27:00 PM Subject: Re: Zenith601-List: Re: upgrade question Brady I guess I could talk about your new Corvair crank that came apart but you are the expert. When you get your first airplane flying come talk to me but until then you sir are the amateur. And it's funny that only you and Ron have had any problems with my post and could that have anything to do wit h the Corvair? Well enough time wasted on a wanna be airplane builder I am gonna go flying in my 601 with a corvair now. O BTW have fun cooling that 701 with a Corvair engine but what do I know right mine run cooler than any with all the unsafe parts I designed and BTW you copied. Jeff -----Original Message----- From: Brady <_brady(at)magnificentmachine.com_ (mailto:brady(at)magnificentmachine.com) > Sent: Sun, May 23, 2010 3:00 pm Subject: Zenith601-List: Re: upgrade question <_brady(at)magnificentmachine.com_ (mailto:brady(at)magnificentmachine.com) > afterfxllc(at)_aol.com_ (http://aol.com/) wrote: > For what it is worth I have done 4 upgrades and built 3 flying 601's (None in the dirt BTW) and I have taken apart 7 601's and have seen everything fro m 10 lb lead shot bags in the wingtip, wing AOA 50=EF=BDmm apart, loose spar bolts, bottomed out spar bolts, smaller bolts for rear attach point. And non of these failed. And as a matter of fact none of the wing attach bolts broke or were the cause of wing failures. The spar snapped at the first bolt hole but the bolts remained. Now as a matter of engineering of course the holes should be reamed if at all possible but remember there are thousands of aircraft flying that have drilled spar bolts and are safe. Zenith once told us alittle loose is ok but not sloppy but after what has happened every thing has to be technically correct. I use a reamer but wouldn't think one minute about drilling my own spars with a drill bit because I know I can do it correctly and I now believe the spar and center section wasn't the problem to begin with and after seeing the sloppy building of some of these aircraft that didn't break apart I believe and and have always believed flutter is the most likely reason for the failures. > > > > > Jeff > > -- Jeff, I want to point out that just because a substandard assembly has not failed yet, doesn't mean that it won't fail in the future, or that it can some how be thought of as safe. Encouraging, justifying and or down playing the dangers of sloppy buildin g practices is irresponsible at best. The last thing the 601 community needs is for "Up Graded" 601's falling out of the sky. That would cause serious trouble for everyone. Your willingness to openly admit that you would cut such corners on your own plane only makes people wonder what corners you cut or are willing to cut on their airplanes. Why would you hold a higher standard for the safety of others than you do your own? The fact that you think you can drill a hole with a 2 fluted drill bit that is some how good enough with out reaming, when the directions specifically call for a Reamed hole, only proves that you don't understand the reasons behind the process. > > And as a matter of fact none of the wing attach bolts broke or were the cause of wing failures. The spar snapped at the first bolt hole but the bolts remained. > This statement says it all: Apparently you don't understand why the bolts are being over sized? No one is concerned that the bolts are breaking. Did it ever occur to you that the reason that spar broke at that hole was because perhaps the fit between the bolt and the hole was too loose and it was able to work the hole open further until it finally broke? Or maybe it was one of those sloppy building techniques you mentioned earlier that hadn't failed yet but finally did? The difference between a professional and an armature is that a professional knows enough to know what he doesn't know, and is able to park his ego long enough to ask the questions he needs to do the job right. Your personal attacks are only a sign that you have exhausted your technical experience and knowledge. The fact that you have built 3 flying 601s and upgraded 4 does not make me rest easy, it causes me great concern. I don't see this as a pissing contest, I see it as an opportunity to teac h and learn. -------- Brady McCormick Poulsbo, WA _www.magnificentmachine.com_ (http://www.magnificentmachine.com/) Read this topic online here: _http://forums.matronics.com/viewtopic.php?p=298613#298613_ (http://forums.matronics.com/viewtopic.php?p=298613#298613) t" target=_blank>_http://www.matronics.com/Navigator?Zenith601-List== =========_ (http://www.matronics.com/Navigator?Zenith601 -List===========) tp://forums.matronics.com _blank>_http://www.matronics.com/contribution========= ==_ (http://www.matronics.com/contribution===========) t" target=_blank>_http://www.matronics.com/Navigator?Zenith601-List_ (http://www.matronics.com/Navigator?Zenith601-List) tp://forums.matronics.com _blank>_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matr onics.com/Navigator?Zenith601-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/co ntribution ======================== ============ (http://www.matronics.com/Navigator?Zenith601-List) ======================== ============ ======================== ============ (http://www.matronics.com/contribution) ======================== ============ ________________________________________________________________________________
Subject: Aileron Stop after Mod
Date: May 24, 2010
When I was fitting the doubler around the aileron pushrod hole I found it necessary to remove the external aileron stop (although it wasn't mentioned in the modification instructions.) I did a search and see that Zenith wants the external stop retained even though we're supposed to add a stop in the fuselage as well. Did the rest of you just move the stop outboard to clear the doubler or what? Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298780#298780 ________________________________________________________________________________
Date: May 24, 2010
Were you thinking of the 601 or 650 canopy? I'd hate to loose the role bar on the 650. Ron On May 23, 2010, at 11:07 PM, Afterfxllc(at)aol.com wrote: > We have a RV-7 in the other hanger and I have done all the > measurements and it works out but the bulkheads have to be flattened > at the turtle deck and gradually round as it goes back. > > Jeff > > In a message dated 5/23/2010 10:02:09 P.M. Eastern Daylight Time, rsteele(at)rjsit.com > writes: > > An RV has pretty much straight sides where the 601/50 has a pretty > good flare front to back. How are you planning to have the narrow > front part slide over the wider back part? I've been thinking about > this, and it seem like the canopy would have to lift up, a lot, more > than on an RV, before sliding. For what it's worth, the 601 also > has more head and leg room the than an RV7 (only one I've attempted > to get into - and failed). > > I really hope you do this, I'd love to see your solution. > > Ron > > > On May 23, 2010, at 9:25 PM, Afterfxllc(at)aol.com wrote: > >> Your right Bill, See what a simple test can turn into? Thats why >> most don't post because other can't wait to flame you but I have >> been on these lists since building RV's and they are all the same. >> I said I was done with the pissing match but they can't let it rest. >> >> So now I am done with the pissing match again. LOL >> >> BTW are you going with push pull tubes? The ones I installed work >> great but it isn't a quick conversion as you know but when I talked >> to Sebastian about them he seemed to like the way I went about >> doing it. >> >> We are Flying 962T again tomorrow and that will end the 5 hour >> Phase 1 and I think Thomas is coming to pick it up this week. >> I am going to install a Van's slider canopy in my next 601 that I >> am building now along with a Corvair and push pull tubes. Believe >> it or not the 601 is 20 mm wider than the RV-7 and I think the only >> thing that I need to modify is the turtle deck as the RV has >> bulkheads that are flat at the top and rounds as it nears the tail. >> >> Have a good one >> >> Jeff >> >> >> >> -----Original Message----- >> From: Bill Pagan <bill.pagan(at)yahoo.com> >> To: zenith601-list(at)matronics.com >> Sent: Sun, May 23, 2010 7:03 pm >> Subject: Re: Zenith601-List: Re: upgrade question >> >> I have a problem with you guys bringing your private argument to >> this forum. Give it a rest for the benefit of all of us. >> >> Bill Pagan >> >> >> >> From: "afterfxllc(at)aol.com" <afterfxllc(at)aol.com> >> To: zenith601-list(at)matronics.com >> Sent: Sun, May 23, 2010 6:27:00 PM >> Subject: Re: Zenith601-List: Re: upgrade question >> >> Brady >> >> I guess I could talk about your new Corvair crank that came apart >> but you are the expert. When you get your first airplane flying >> come talk to me but until then you sir are the amateur. And it's >> funny that only you and Ron have had any problems with my post and >> could that have anything to do with the Corvair? >> Well enough time wasted on a wanna be airplane builder I am gonna >> go flying in my 601 with a corvair now. >> >> O BTW have fun cooling that 701 with a Corvair engine but what do I >> know right mine run cooler than any with all the unsafe parts I >> designed and BTW you copied. >> >> Jeff >> >> -----Original Message----- >> From: Brady <brady(at)magnificentmachine.com> >> To: zenith601-list(at)matronics.com >> Sent: Sun, May 23, 2010 3:00 pm >> Subject: Zenith601-List: Re: upgrade question >> > > >> >> >> afterfxllc(at)aol.com wrote: >> > For what it is worth I have done 4 upgrades and built 3 flying >> 601's (None in >> the dirt BTW) and I have taken apart 7 601's and have seen >> everything from 10 lb >> lead shot bags in the wingtip, wing AOA 50=EF=BDmm apart, loose spar >> bolts, >> bottomed out spar bolts, smaller bolts for rear attach point. And >> non of these >> failed. And as a matter of fact none of the wing attach bolts broke >> or were the >> cause of wing failures. The spar snapped at the first bolt hole but >> the bolts >> remained. Now as a matter of engineering of course the holes should >> be reamed if >> at all possible but remember there are thousands of aircraft flying >> that have >> drilled spar bolts and are safe. Zenith once told us alittle loose >> is ok but >> not sloppy but after what has happened every thing has to be >> technically >> correct. I use a reamer but wouldn't think one minute about >> drilling my own >> spars with a drill bit because I know I can do it correctly and I >> now believe >> the spar and center section wasn't the problem to begin with and >> after seeing >> the sloppy building of some of these aircraft that didn't break >> apart I believe >> and and have always believed flutter is the most likely reason for >> the failures. >> >> > >> > >> > >> > >> > Jeff >> > >> > -- >> >> >> Jeff, >> I want to point out that just because a substandard assembly has >> not failed yet, >> doesn't mean that it won't fail in the future, or that it can some >> how be >> thought of as safe. >> Encouraging, justifying and or down playing the dangers of sloppy >> building >> practices is irresponsible at best. >> The last thing the 601 community needs is for "Up Graded" 601's >> falling out of >> the sky. >> That would cause serious trouble for everyone. >> >> Your willingness to openly admit that you would cut such corners on >> your own >> plane only makes people wonder what corners you cut or are willing >> to cut on >> their airplanes. >> Why would you hold a higher standard for the safety of others than >> you do your >> own? >> >> The fact that you think you can drill a hole with a 2 fluted drill >> bit that is >> some how good enough with out reaming, when the directions >> specifically call for >> a Reamed hole, only proves that you don't understand the reasons >> behind the >> process. >> >> >> > >> > And as a matter of fact none of the wing attach bolts broke or >> were the cause >> of wing failures. The spar snapped at the first bolt hole but the >> bolts >> remained. >> > >> >> >> This statement says it all: >> Apparently you don't understand why the bolts are being over sized? >> No one is concerned that the bolts are breaking. >> Did it ever occur to you that the reason that spar broke at that >> hole was >> because perhaps the fit between the bolt and the hole was too loose >> and it was >> able to work the hole open further until it finally broke? >> Or maybe it was one of those sloppy building techniques you >> mentioned earlier >> that hadn't failed yet but finally did? >> >> The difference between a professional and an armature is that a >> professional >> knows enough to know what he doesn't know, and is able to park his >> ego long >> enough to ask the questions he needs to do the job right. >> >> Your personal attacks are only a sign that you have exhausted your >> technical >> experience and knowledge. >> >> The fact that you have built 3 flying 601s and upgraded 4 does not >> make me rest >> easy, it causes me great concern. >> >> I don't see this as a pissing contest, I see it as an opportunity >> to teach and >> learn. >> >> -------- >> Brady McCormick >> Poulsbo, WA >> www.magnificentmachine.com >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=298613#298613 >> >> >> >> >> >> >> >> t" target=_blank>http://www.matronics.com/Navigator?Zenith601-List=== ======= >> tp://forums.matronics.com >> _blank>http://www.matronics.com/contribution========= = >> >> >> >> >> >> t" target=_blank>http://www.matronics.com/Navigator?Zenith601-List >> tp://forums.matronics.com >> _blank>http://www.matronics.com/contribution >> >> >> >> href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matr onics.com/Navigator?Zenith601-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/co ntribution >> >> > > > ======================== =========== > t href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matr onics.com/Navigator?Zenith601-List > ======================== =========== > ms.matronics.com/">http://forums.matronics.com > ======================== =========== > tp://www.matronics.com/contribution">http://www.matronics.com/contribution > ======================== =========== > > ________________________________________________________________________________
Subject: Re: Aileron Stop after Mod
Date: May 24, 2010
I retained the external aileron stops. -------- David Gallagher 601 XL/Jabiru 3300 First flight 7/24/08 Upgraded 3/19/10 120+ hours and climbing! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298799#298799 ________________________________________________________________________________
Date: May 24, 2010
601 In a message dated 5/24/2010 7:34:21 P.M. Eastern Daylight Time, rsteele(at)rjsit.com writes: Were you thinking of the 601 or 650 canopy? I'd hate to loose the role bar on the 650. Ron On May 23, 2010, at 11:07 PM, _Afterfxllc(at)aol.com_ (mailto:Afterfxllc(at)aol.com) wrote: We have a RV-7 in the other hanger and I have done all the measurements and it works out but the bulkheads have to be flattened at the turtle deck and gradually round as it goes back. Jeff In a message dated 5/23/2010 10:02:09 P.M. Eastern Daylight Time, _rsteele(at)rjsit.com_ (mailto:rsteele(at)rjsit.com) writes: An RV has pretty much straight sides where the 601/50 has a pretty good flare front to back. How are you planning to have the narrow front part slide over the wider back part? I've been thinking about this, and it se em like the canopy would have to lift up, a lot, more than on an RV, before sliding. For what it's worth, the 601 also has more head and leg room th e than an RV7 (only one I've attempted to get into - and failed). I really hope you do this, I'd love to see your solution. Ron On May 23, 2010, at 9:25 PM, _Afterfxllc(at)aol.com_ (mailto:Afterfxllc(at)aol.com) wrote: Your right Bill, See what a simple test can turn into? Thats why most don't post because other can't wait to flame you but I have been on these lists since building RV's and they are all the same. I said I was done with the pissing match but they can't let it rest. So now I am done with the pissing match again. LOL BTW are you going with push pull tubes? The ones I installed work great but it isn't a quick conversion as you know but when I talked to Sebastia n about them he seemed to like the way I went about doing it. We are Flying 962T again tomorrow and that will end the 5 hour Phase 1 an d I think Thomas is coming to pick it up this week. I am going to install a Van's slider canopy in my next 601 that I am building now along with a Corvair and push pull tubes. Believe it or not the 601 is 20 mm wider than the RV-7 and I think the only thing that I need to modify is the turtle deck as the RV has bulkheads that are flat at the to p and rounds as it nears the tail. Have a good one Jeff -----Original Message----- From: Bill Pagan <_bill.pagan(at)yahoo.com_ (mailto:bill.pagan(at)yahoo.com) > Sent: Sun, May 23, 2010 7:03 pm Subject: Re: Zenith601-List: Re: upgrade question I have a problem with you guys bringing your private argument to this forum. Give it a rest for the benefit of all of us. Bill Pagan ____________________________________ From: "_afterfxllc(at)aol.com_ (mailto:afterfxllc(at)aol.com) " <_afterfxllc(at)aol.com_ (mailto:afterfxllc(at)aol.com) > Sent: Sun, May 23, 2010 6:27:00 PM Subject: Re: Zenith601-List: Re: upgrade question Brady I guess I could talk about your new Corvair crank that came apart but you are the expert. When you get your first airplane flying come talk to me but until then you sir are the amateur. And it's funny that only you and Ron have had any problems with my post and could that have anything to do wit h the Corvair? Well enough time wasted on a wanna be airplane builder I am gonna go flying in my 601 with a corvair now. O BTW have fun cooling that 701 with a Corvair engine but what do I know right mine run cooler than any with all the unsafe parts I designed and BTW you copied. Jeff -----Original Message----- From: Brady <_brady(at)magnificentmachine.com_ (mailto:brady(at)magnificentmachine.com) > Sent: Sun, May 23, 2010 3:00 pm Subject: Zenith601-List: Re: upgrade question <_brady(at)magnificentmachine.com_ (mailto:brady(at)magnificentmachine.com) > afterfxllc(at)_aol.com_ (http://aol.com/) wrote: > For what it is worth I have done 4 upgrades and built 3 flying 601's (None in the dirt BTW) and I have taken apart 7 601's and have seen everything fro m 10 lb lead shot bags in the wingtip, wing AOA 50=EF=BDmm apart, loose spar bolts, bottomed out spar bolts, smaller bolts for rear attach point. And non of these failed. And as a matter of fact none of the wing attach bolts broke or were the cause of wing failures. The spar snapped at the first bolt hole but the bolts remained. Now as a matter of engineering of course the holes should be reamed if at all possible but remember there are thousands of aircraft flying that have drilled spar bolts and are safe. Zenith once told us alittle loose is ok but not sloppy but after what has happened every thing has to be technically correct. I use a reamer but wouldn't think one minute about drilling my own spars with a drill bit because I know I can do it correctly and I now believe the spar and center section wasn't the problem to begin with and after seeing the sloppy building of some of these aircraft that didn't break apart I believe and and have always believed flutter is the most likely reason for the failures. > > > > > Jeff > > -- Jeff, I want to point out that just because a substandard assembly has not failed yet, doesn't mean that it won't fail in the future, or that it can some how be thought of as safe. Encouraging, justifying and or down playing the dangers of sloppy buildin g practices is irresponsible at best. The last thing the 601 community needs is for "Up Graded" 601's falling out of the sky. That would cause serious trouble for everyone. Your willingness to openly admit that you would cut such corners on your own plane only makes people wonder what corners you cut or are willing to cut on their airplanes. Why would you hold a higher standard for the safety of others than you do your own? The fact that you think you can drill a hole with a 2 fluted drill bit that is some how good enough with out reaming, when the directions specifically call for a Reamed hole, only proves that you don't understand the reasons behind the process. > > And as a matter of fact none of the wing attach bolts broke or were the cause of wing failures. The spar snapped at the first bolt hole but the bolts remained. > This statement says it all: Apparently you don't understand why the bolts are being over sized? No one is concerned that the bolts are breaking. Did it ever occur to you that the reason that spar broke at that hole was because perhaps the fit between the bolt and the hole was too loose and it was able to work the hole open further until it finally broke? Or maybe it was one of those sloppy building techniques you mentioned earlier that hadn't failed yet but finally did? The difference between a professional and an armature is that a professional knows enough to know what he doesn't know, and is able to park his ego long enough to ask the questions he needs to do the job right. Your personal attacks are only a sign that you have exhausted your technical experience and knowledge. The fact that you have built 3 flying 601s and upgraded 4 does not make me rest easy, it causes me great concern. I don't see this as a pissing contest, I see it as an opportunity to teac h and learn. -------- Brady McCormick Poulsbo, WA _www.magnificentmachine.com_ (http://www.magnificentmachine.com/) Read this topic online here: _http://forums.matronics.com/viewtopic.php?p=298613#298613_ (http://forums.matronics.com/viewtopic.php?p=298613#298613) t" target=_blank>_http://www.matronics.com/Navigator?Zenith601-List== =========_ (http://www.matronics.com/Navigator?Zenith601 -List===========) tp://forums.matronics.com _blank>_http://www.matronics.com/contribution========= ==_ (http://www.matronics.com/contribution===========) t" target=_blank>_http://www.matronics.com/Navigator?Zenith601-List_ (http://www.matronics.com/Navigator?Zenith601-List) tp://forums.matronics.com _blank>_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) href="_http://www.matronics.com/Navigator?Zenith601-List_ (http://www.matronics.com/Navigator?Zenith601-List) ">_http://www.matronics.com/Navigator?Zenith601-List_ (http://www.matronic s.com/Navigator?Zenith601-List) href="_http://forums.matronics.com_ (http://forums.matronics.com/) ">_http://forums.matronics.com_ (http://forums.matronics.com/) href="_http://www.matronics.com/contribution_ (http://www.matronics.com/contribution) ">_http://www.matronics.com/contri bution_ (http://www.matronics.com/contribution) t href="_http://www.matronics.com/Navigator?Zenith601-List_ (http://www.matronics.com/Navigator?Zenith601-List) ">_http://www.matronics.com/Navigator?Zenith601-List_ (http://www.matronic s.com/Navigator?Zenith601-List) ms.matronics.com/">_http://forums.matronics.com_ (http://forums.matronics.com/) tp://www.matronics.com/contribution">_htt p://www.matronics.com/contribution_ (http://www.matronics.com/contribution ) href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matr onics.com/Navigator?Zenith601-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/co ntribution ======================== ============ (http://www.matronics.com/Navigator?Zenith601-List) ======================== ============ ======================== ============ (http://www.matronics.com/contribution) ======================== ============ ________________________________________________________________________________
Date: May 25, 2010
Keeping it in the same place only on top of the doubler. I will check the deflection and correct as necessary at final assembly. -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298829#298829 ________________________________________________________________________________
Date: May 25, 2010
Subject: 601 XL Wing-Jig
From: Iberplanes IGD - Alberto Martin <iberplanes(at)gmail.com>
Hi there, Anyone on the list with a used wing-jig for sale? Please, contact me offline. Thanks -- Alberto Martin www.iberplanes.es Igualada - Barcelona - Spain ---------------------------------------------- Zodiac 601 XL Builder Serial: 6-7011 Tail Kit: Finished Wings: Not Started Fuselage: Started Engine: Jabiru 3300 Un ingles a Tom Lucero en la guerra de Malvinas: "=A1Piloto argentino mejor aqu=ED con nosotros en camilla. Muy peligroso arriba, en su avi=F3n!=97". Un pasaje del libro "Dios y Los Halcones" del Com. Pablo M. Carballo ________________________________________________________________________________
Subject: Re: upgrade question
Date: May 25, 2010
Jeff, I would be happy to talk about off shore manufacturing, defective crankshafts, Corvairs, my accomplishments as a professional or what ever else you might have on your mind, but if you're going to change the subject at least start a new thread. Saying that you want to end a "pissing contest" and then taking a parting shot is contradictory. It is a common strategy for someone who has reached the end their argument/ debate or what ever to try and create a diversion and or change the subject to try and direct the attention away from themselves. We see this in the political arena all the time. It doesn't work here any better than it does there. The fact that your airplane is done and flying only means that you started before I did, you assembled a kit where as I am scratch building, and I would be happy to compare workmanship at any venue of your choosing once I am done. My 601 will be done far sooner than my 701 so at least we will have apples to compare to apples. Until then, Cheers! -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298868#298868 ________________________________________________________________________________
Date: May 25, 2010
Your right you win. Jeff -----Original Message----- From: Brady <brady(at)magnificentmachine.com> Sent: Tue, May 25, 2010 6:18 pm Subject: Zenith601-List: Re: upgrade question m> Jeff, would be happy to talk about off shore manufacturing, defective crankshaf ts, orvairs, my accomplishments as a professional or what ever else you might have n your mind, but if you're going to change the subject at least start a ne w hread. Saying that you want to end a "pissing contest" and then taking a parting shot s contradictory. It is a common strategy for someone who has reached the end their argument / ebate or what ever to try and create a diversion and or change the subject to ry and direct the attention away from themselves. We see this in the polit ical rena all the time. It doesn't work here any better than it does there. The fact that your airplane is done and flying only means that you started efore I did, you assembled a kit where as I am scratch building, and I wou ld be appy to compare workmanship at any venue of your choosing once I am done. My 601 will be done far sooner than my 701 so at least we will have apples to ompare to apples. Until then, Cheers! -------- rady McCormick oulsbo, WA ww.magnificentmachine.com ead this topic online here: http://forums.matronics.com/viewtopic.php?p=298868#298868 ======================== =========== -= - The Zenith601-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Zenith601-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: May 25, 2010
If anyone is still interested It looks to me like 8 of the 12 holes have more than enough edge distance and the 4 inboard holes would be out of tolerance if drilled up to 3/8". So there may be an option for us sloppy back drillers. Chuck CH650 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298876#298876 ________________________________________________________________________________
Date: May 25, 2010
Chuck, I found another source for the NAS6205-22x bolts. these are New surplus and they want $12 each. Not bad really.... I still have RFQ's out for the longer ones. If you're interested: Their phone # is 1-717-896-7570 I can't recall the name of the company? -------- Brady McCormick Poulsbo, WA www.magnificentmachine.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298881#298881 ________________________________________________________________________________
Date: May 26, 2010
I heard from Caleb on the issue. It is OK to move the stop outboard enough to clear the aileron rod hole doubler. It is also OK to trim back the edge of the upper rear spar angle where it protrudes above the doublers if you are concerned about interference with the aileron piano hinge. Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298979#298979 ________________________________________________________________________________
Date: May 26, 2010
After installing the counterweights, if find that I am 10 mm. from the aileron stop, when the cw. hits the skin. Spoke to Roger and he said that the stop had been "redesigned" a couple of yrs. ago and would send a new stop. I'm drwg. # 6419. -------- Phil Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299002#299002 ________________________________________________________________________________
Date: May 27, 2010
This is from memory, I think the aileron movement is 11.5 degrees up and 11.5 degrees down. -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299051#299051 ________________________________________________________________________________
Subject: Looking for wiring ideas
Date: May 27, 2010
I have completed most of the fuselage now and am at the point where I need to start running some wires, i.e. elevator trim, tail light, flap motor. I can see that there are many avenues from the elevator trim tab to the front. I have a center stick and plan to put the trims on it unless there is some better reason to put them on the panel. I would appreciate suggestions on type of clips, grommets, tabs, splices at the motor end, etc. as there seem to be several possibilities from the hardware store to Wicks. I especially would like a good route from tail to stick. I don't know which side might be best to run down a longeron or when to go through or around a bulkhead or if I need to go past the stick and then back again on the floor or even when /where it will drop to floor. I can figure a route for the wing wires but need some possibilities for the tail and flap motor. Thanks again for ideas/products. John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299053#299053 ________________________________________________________________________________
Subject: Re: Looking for wiring ideas
Date: May 27, 2010
John B+C Specialty has generic schematics available free at their site, and many of the necessary components you'll need. Shouldn't take much to modify to fit your situation, and they're good people. Bill ----- Original Message ----- From: "w8n2bup" <johnrich(at)everestkc.net> Sent: Thursday, May 27, 2010 11:19 AM Subject: Zenith601-List: Looking for wiring ideas > > I have completed most of the fuselage now and am at the point where I need > to start running some wires, i.e. elevator trim, tail light, flap motor. I > can see that there are many avenues from the elevator trim tab to the > front. I have a center stick and plan to put the trims on it unless there > is some better reason to put them on the panel. I would appreciate > suggestions on type of clips, grommets, tabs, splices at the motor end, > etc. as there seem to be several possibilities from the hardware store to > Wicks. I especially would like a good route from tail to stick. I don't > know which side might be best to run down a longeron or when to go through > or around a bulkhead or if I need to go past the stick and then back again > on the floor or even when /where it will drop to floor. I can figure a > route for the wing wires but need some possibilities for the tail and flap > motor. Thanks again for ideas/products. John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=299053#299053 > > > ________________________________________________________________________________
Date: May 27, 2010
Hi John, I think I have detailed pictures of how I did it on my web site. I used the MS21919 a lot... ---------------------------- Michel Therrien CH601-HD, C-GZGQ http://mthobby.pcperfect.com/ch601 http://pages.infinit.net/mthobby --- On Thu, 5/27/10, w8n2bup wrote: ...> there is some better reason to put them on the panel. I > would appreciate suggestions on type of clips, grommets, > tabs, splices at the motor end, etc. as there seem to be > several possibilities from the hardware store to Wicks. I > especially would like a good route from tail to stick. I ...> > ________________________________________________________________________________
Date: May 27, 2010
Hi John, I've got an electrical page on my site, www.macsmachine.com, that might help you with the methodology of running wires throughout the plane. Some electrical diagrams that may be helpful too. Pictures clicked go large for a better view and perhaps there and other pages will help you with specific routing etc. See link, http://www.macsmachine.com/html/electrical.htm Best regards, Larry McFarland 601HDS at www.macsmachine.com w8n2bup wrote: > > I have completed most of the fuselage now and am at the point where I need to start running some wires, i.e. elevator trim, tail light, flap motor. I can see that there are many avenues from the elevator trim tab to the front. > > > ________________________________________________________________________________
Date: May 27, 2010
Subject: Bad takeoff, but still good landing
Last sunday was a beautiful day here in my region and I couldn't resist flying after completing the engine portion of my annual inspection. I changed the oil, tested the compression (150 +-5 on all cylinders), timing OK, removed valve covers... all neat, cleaned air filter, etc, etc... all was GREAT :-) Well, I did my preflight inspection, did my runnup (at about 3600 rpm) near runway 15 of Beloeil airport, positioned myself on the runway and applied full throttle. The feeling of accelerating and taking off on such a beautiful day was enjoyable... for about 4 seconds... I climbed to about 5 feet in the air and then, total loss of power (like lack of fuel). I was getting close to mid-runway (maybe even past it... don't remember), and I pulled the throttle, and landed the plane. The engine was still running at low rpm. Then I went to an area to check the engine behavior... when I raised the throttle above 4000 rpm, it would do the same thing. I then tried at lower rpms... would just take more time and at about 2100 rpm, the engine would run smooth, miss and run smooth again. My first idea was the fuel supply... so I disconnected the fuel line and filter from the carburetor and tested the fuel flow.. very good.. certainly, the issue is not that. I then removed the top of the carburetor (Holley 5200) to see if the bowl has fuel and to see if the float valve operates properly... bowl was OK (but with some small debrits on the bottom) and floats appeared to work OK (I applied fuel pressure while playing with float movement and making a mess besides the catch can I was using). My questions: what failures could create this condition? 1. fuel system ? (I think so) 2. ignition system ? 3. cam shaft ? 4. ? Oh... a funny thing... I'm surprised to notice I did not get excited through this... I don't think my heart beat got any faster during that failure. I got a strange feeling that I'll miss many good days of flying opportunities now. ---------------------------- Michel Therrien CH601-HD, C-GZGQ http://mthobby.pcperfect.com/ch601 http://pages.infinit.net/mthobby ________________________________________________________________________________
Date: May 27, 2010
Subject: Re: Bad takeoff, but still good landing
Michel, I'd look for a fuel restriction in the line, gascolator, filter or anywhere ahead of the carb. This doesn't sound like an ignition, choke or spark type failure. A fuel restriction would allow you to get full throttle until the engine need gets ahead of the flow. Then it would starve itself at full setting after running full out for a short time. Larry McFarland 601HDS at www.macsmachine.com Michel Therrien wrote: > > Last sunday was a beautiful day here in my region and I couldn't resist flying after completing the engine portion of my annual inspection. I changed the oil, tested the compression (150 +-5 on all cylinders), timing OK, removed valve covers... all neat, cleaned air filter, etc, etc... all was GREAT :-) > > Well, I did my preflight inspection, did my runnup (at about 3600 rpm) near runway 15 of Beloeil airport, positioned myself on the runway and applied full throttle. The feeling of accelerating and taking off on such a beautiful day was enjoyable... for about 4 seconds... I climbed to about 5 feet in the air and then, total loss of power (like lack of fuel). I was getting close to mid-runway (maybe even past it... don't remember), and I pulled the throttle, and landed the plane. The engine was still running at low rpm. > > ---------------------------- > Michel Therrien CH601-HD, C-GZGQ > http://mthobby.pcperfect.com/ch601 > http://pages.infinit.net/mthobby > > ________________________________________________________________________________
Date: May 27, 2010
Indeed that was my first impression. The symptom is exactly it. I did check the fuel flow right at the carb (disconnected the filter from the carb, put the hose towards a container and activated each fuel pump) and all was nice. I did check the float action and flow control of the float mechanism (as much as I could do it). I suspect a carburetor defect, but I'm wondering it this could be anything else. At the parking lot, I tested the operation with my three fuel pumps and my two ignition.. none would change anything in that bad engine behavior. ---------------------------- Michel Therrien CH601-HD, C-GZGQ http://mthobby.pcperfect.com/ch601 http://pages.infinit.net/mthobby --- On Thu, 5/27/10, Larry McFarland wrote: > From: Larry McFarland <larry(at)macsmachine.com> > Subject: Re: Zenith601-List: Bad takeoff, but still good landing > To: zenith601-list(at)matronics.com > Received: Thursday, May 27, 2010, 4:46 PM > --> Zenith601-List message posted > by: Larry McFarland > > > Michel, > I'd look for a fuel restriction in the line, gascolator, > filter or anywhere ahead of the carb. This doesn't sound > like an ignition, choke or spark type failure. > A fuel restriction would allow you to get full throttle > until the engine need gets ahead of the flow. Then it would > starve itself at full setting after running full out > for a short time. > > Larry McFarland 601HDS at www.macsmachine.com > > Michel Therrien wrote: > Therrien > > > > Last sunday was a beautiful day here in my region and > I couldn't resist flying after completing the engine portion > of my annual inspection. I changed the oil, tested the > compression (150 +-5 on all cylinders), timing OK, removed > valve covers... all neat, cleaned air filter, etc, > etc... all was GREAT :-) > > > > Well, I did my preflight inspection, did my > runnup (at about 3600 rpm) near runway 15 of Beloeil > airport, positioned myself on the runway and applied full > throttle. The feeling of accelerating and taking off > on such a beautiful day was enjoyable... for about 4 > seconds... I climbed to about 5 feet in the air and then, > total loss of power (like lack of fuel). I was getting > close to mid-runway (maybe even past it... don't remember), > and I pulled the throttle, and landed the plane. > The engine was still running at low rpm. > > ---------------------------- > > Michel Therrien CH601-HD, C-GZGQ > >http://mthobby.pcperfect.com/ch601 > >http://pages.infinit.net/mthobby > > > > > > > > Email Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: May 27, 2010
Did you check that your tank vents were not plugged up? Mud dauber wasps have been known plug them up. Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299097#299097 ________________________________________________________________________________
Date: May 27, 2010
Yes, I did.. forgot to mention. Thanks Tim. ---------------------------- Michel Therrien CH601-HD, C-GZGQ http://mthobby.pcperfect.com/ch601 http://pages.infinit.net/mthobby --- On Thu, 5/27/10, Tim Juhl wrote: >> Did you check that your tank vents were not plugged > up? Mud dauber wasps have been known plug them up. > ________________________________________________________________________________
Date: May 27, 2010
Heat source near a fuel line causing vapor lock (possibly a dislodged heat shield)? Air leak in the intake manifold? Hope you find the solution. Let us know what it is when you find it... - Pat -------- Patrick XL/650/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299103#299103 ________________________________________________________________________________
Date: May 28, 2010
Subject: Engine Stoppage
Michael, Something else to look for is complete or partial collapse of intake pipe or hose. On my first attempt at take off the higher vacuum generated plus the heat in the engine compartment caused the radiator hose to collapse. I changed it to fiberglass and have not had a problem since. Bobby ________________________________________________________________________________
Date: May 28, 2010
I had a forced landing with an engine that was doing the same thing. Met a really nice farmer. Problem was the fuel filter - small one from Aircraft Spruce. I would change the filter or try a bigger one, and try again....Fred N9601 (sold) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299153#299153 ________________________________________________________________________________
From: "chris Sinfield" <chris_sinfield(at)yahoo.com.au>
Date: May 28, 2010
well if there is a new stop designed, can someone with the latest version of the plans ( 650 I guess) scan in the aileron stop so we all can see how it is done? size wise / thickness? Chris. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299195#299195 ________________________________________________________________________________
Subject: different upgrade Q
Date: May 28, 2010
Hi all Is it me or are other people confused with the Nose ribs section of the upgrade? I have the 3 nose ribs and following the Zenith photo guide becomes confusing here as their plane has the 4 nose ribs and so the photos don't match the plans. With nose rib No 1 it would have been great if they could have put a top down view as they do in nose rib 2. What happens to the row of rivet holes through the original spar web at the back of the spar? The nose rib 1 bracket is riveted on to the new .125 tho plate. Are we to rivet a plate over the old holes or just leave them open?? Can someone shoot a couple of pictures of this area Front and Back of what this nose rib 1 area is supposed to look like please. also I put it in, but why the bottom spar angle between 1 and 2 ribs? Have we had buckling in that area, and why not a full piece between 1 and 3 as you could still get an access panel hole if it was extended.. Chris Zodiac Xl Sydney Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299199#299199 ________________________________________________________________________________
Subject: Re: different upgrade Q
Date: May 29, 2010
Chris i have use a small rivet from the back side of the wind just to close the hole and make it look better. Ianrat CH601XL Brisbane :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299244#299244 ________________________________________________________________________________
Date: May 29, 2010
T=.040 6061-T6 Bottom 108 deg bend 20 mm long, Vertical 15 mm long, 56 deg bend 29 mm long, 56 deg bend Vertical 15 mm Sorry I can not scan Brenda Smith CH650 -------------------------------------------------- From: "chris Sinfield" <chris_sinfield(at)yahoo.com.au> Sent: Friday, May 28, 2010 3:19 PM Subject: Zenith601-List: Re: Aileron Stop after Mod > > > well if there is a new stop designed, > > can someone with the latest version of the plans ( 650 I guess) scan in > the aileron stop so we all can see how it is done? size wise / thickness? > > Chris. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=299195#299195 > > > ________________________________________________________________________________
Date: May 29, 2010
Hello all, I found the problem today. I had another Holley 5200 carb at home that I studied. I examined the fload mechanism. Then, I went back to the airport and opened the carb and this time, noticed that the movement of the float was very restrained. I then saw the issue. The floats activates a needle that seats in the bottom of a female piece. That piece was unscrewed! (see picture attached) So, the needle would seat and restrict the flow at low bowl fuel level. That was easilly repared. I tested my engine on the ground, holding it between 4600 and 4900 rpm with no mis or anything like that.... so, I'll fly it may be tomorrow. It is a bit frightening to see how we depend on so small things when we fly. An annual inspection would not reveal this type of problem. Thanks all who provided ideas of what to look for. ________________________________________________________________________________
Date: May 29, 2010
thanks I / we should be able to work with that. Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299299#299299 ________________________________________________________________________________
Subject: Chat Reminder for "Digesters"
Date: May 30, 2010
www.mykitairplane.com http://www.mykitairplane.com/> Check out my line of items for Experimental Airplane Builders My Products: www.mykitairplane.com/Products/ ________________________________________________________________________________
Subject: Upgrade Question - Main Spar Carry Through
From: "Scotsman" <james.roberts(at)computershare.co.za>
Date: Jun 01, 2010
Evening List, a quick couple of questions regarding the main spar carry through piece: Firstly, after having installed all the various new pieces on the spar carry through I was trial fitting it onto the cabin floor. Obviously the assembly is a bit wider than before to accommodate the thicker spar root. Ultimately when I cleco in the aft set of holes to the cabin floor I had a quick look at the forward set to see where they fall in relation to the holes forward holes. Basically the new forward holes will "clip" the old forward holes. Is this correct as it seems messy and makes me question a) whether I am doing it correctly and b) whether this is structurally ok? Secondly, after having trial fitted the spar carry through together I tried to push my centre punch through a couple of the holes to test alignment (with the holes on the other web). The two set of holes do not seem perfectly aligned. Did anyone else encounter this and if so what was the solution? FYI the holes on each web are very tight as I was concerned about the comments on the list about loose fittings etc. Should the spar holes accept the bolt dropping in or should it be tapped in with a rubber mallet or the like. Any advice in regards to either question would be much appreciated and apologies if anyone has already raised and answered the above questions. James -------- Cell +27 83 675 0815 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299587#299587 ________________________________________________________________________________
Date: Jun 01, 2010
Hi James, I haven't made it that far yet, but I have started thinking about it a little. The side skin will be a problem unless we do something to replace the skin around the carry-through. This is not as bad as it sounds since the new uprights are attached to both longerons instead of just the bottom one as in the original design. That makes the skin question a little bit less important. Perhaps some sort of patch over the old holes would solve that problem - either with or without removing the old skin around this area. I don't have any ideas about the alignment question. Part of this problem is the fact the front part of the fuselage "Floats" compared to the rear part until the carry-through is fastened in place. Good luck, Paul XL installing upgrade (slowly) -----Original Message----- From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Scotsman Sent: Tuesday, June 01, 2010 10:41 AM Subject: Zenith601-List: Upgrade Question - Main Spar Carry Through Evening List, a quick couple of questions regarding the main spar carry through piece: Firstly, after having installed all the various new pieces on the spar carry through I was trial fitting it onto the cabin floor. Obviously the assembly is a bit wider than before to accommodate the thicker spar root. Ultimately when I cleco in the aft set of holes to the cabin floor I had a quick look at the forward set to see where they fall in relation to the holes forward holes. Basically the new forward holes will "clip" the old forward holes. Is this correct as it seems messy and makes me question a) whether I am doing it correctly and b) whether this is structurally ok? Secondly, after having trial fitted the spar carry through together I tried to push my centre punch through a couple of the holes to test alignment (with the holes on the other web). The two set of holes do not seem perfectly aligned. Did anyone else encounter this and if so what was the solution? FYI the holes on each web are very tight as I was concerned about the comments on the list about loose fittings etc. Should the spar holes accept the bolt dropping in or should it be tapped in with a rubber mallet or the like. Any advice in regards to either question would be much appreciated and apologies if anyone has already raised and answered the above questions. James -------- Cell +27 83 675 0815 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299587#299587 ________________________________________________________________________________
Subject: Re: Upgrade Question - Main Spar Carry Through
Date: Jun 01, 2010
I was working on the same thing today. I talked to Roger (ZAC) this morning about the same thing. Since I had not drilled the front flange yet I laid out a complete to line of holes half way between to old holes. Roger said just leave the old holes empty. With the spar out, we measured and pilot drilled the new line through the floor. Then with the spar in place we back drilled up through the floor and spar. It lined up well. So far as holes in the side skins, the "T" stiffener will cover all visible holes along the uprights. -------- BK Johnson Zodiac 601XL N601BK (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299694#299694 ________________________________________________________________________________
Date: Jun 01, 2010
Thanks wa7dvd. That seems to be a solution as I think that the upgrade manual suggests drilling through the existing holes in the forward flange of the spar which will clip the old cabin floor holes. I note that in one of the upgrade videos you can see that their clecos are squint because of this. Is there sufficient edge distance between the old and new holes in your method? Anyone else got a solution for the bolt hole alignment on the upgraded spar? James -------- Cell +27 83 675 0815 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299698#299698 ________________________________________________________________________________
Date: Jun 01, 2010
Hi Paul, I was considering "extending" the T section on the side of the fuselage downwards purely for aesthetic reasons. This would allow both covering all of the old forward upright holes and allowing you to cleanly recut the hole for the spar carry through to match the new upgraded dimensions. Probably lots of work to get a nice fit though. j [Rolling Eyes] [Rolling Eyes] -------- Cell +27 83 675 0815 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299699#299699 ________________________________________________________________________________
Date: Jun 01, 2010
Hi James, The old rivet line is pitch 30 so going between still leaves 15mm. Roger told me that would be just fine. Sorry for not signing my last note. -Bruce- -------- BK Johnson Zodiac 601XL N601BK (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299700#299700 ________________________________________________________________________________
Date: Jun 01, 2010
Thanks Bruce. I was being lazy and not walking downstairs to have a look. 15 mm is definitely sufficient. James -------- Cell +27 83 675 0815 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299703#299703 ________________________________________________________________________________
From: "dgardea(at)gmail.com" <dgardea(at)gmail.com>
Date: Jun 02, 2010
Bruce - thanks for making the call to ZAC in the rivet holes thru that forward bottom doubler on the center spar. I unfortunately already backdrilled these so will need to add additional rivet holes to miss the holes in the fuse floor. On a related topic .. did anyone notice that the center spar doublers were shipped at length 945 when the ZAC upgrade plans call for a length of 940 on all the doublers. I just finished drilling and deburring all the doublers and wondering if I will need to trim these to avoid interference with the front and aft uprights? Someone who has already clecoed their center spar parts together and tested for clearance may already know the answer. Thanks! Dave Gardea -------- Dave Gardea 601XL - Corvair working on wiring panel and upgrade kit http://home.comcast.net/~davegardea/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299754#299754 ________________________________________________________________________________
Date: Jun 02, 2010
Dave, There will be trimming required of the doublers to provide clearance to the wing uprights 6ZU2-6. Good luck, -------- David Gallagher 601 XL/Jabiru 3300 First flight 7/24/08 Upgraded 3/19/10 130+ hours and climbing! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299761#299761 ________________________________________________________________________________
Date: Jun 02, 2010
Dave, Thanks for the heads up on this. Like James, I will be trial fitting the center spar in the fuse and checking the fit before any riveting. Thanks, Dave Gardea -------- Dave Gardea 601XL - Corvair working on wiring panel and upgrade kit http://home.comcast.net/~davegardea/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299770#299770 ________________________________________________________________________________
Subject: Fuel line size
Date: Jun 02, 2010
I've decided to replace the rubber hose fuel line from the tank with 3/8" aluminum line. I've got 2 questions - should I use 6061-T6 Aluminum line and what wall thickness should I use? Aircraft Spruce sells 4 different wall thicknesses for 3/8" OD line - .035, .058, .065 and .083. It seems to me any of these should give me adequate fuel flow for a Jabiru 3300. The other issue might be strength, but I should be able to support it well enough. Thanks for any advice. -------- Dale Flying Cessna 170B Building Zenith CH650 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299792#299792 ________________________________________________________________________________
Subject: Re: Fuel line size
Date: Jun 02, 2010
I'm not flying yet but I chose to go with 3/8 " 3003-0 versatube which has a wall thickness of 0.035 and a working pressure of 520 psi. The versatube is fairly easy to make bends and curves in without kinking. I plan to use aeroquip hoses at points subject to flex or excessive vibration. Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299805#299805 ________________________________________________________________________________
Date: Jun 02, 2010
Hi James I am far from taking my center spar apart, but I have been thinking about that alignment problem for a while. It seems to me that the best thing would be to actually bolt both wing spars to the two sides of the center spar before riveting the two sides together. That may be overkill, however. At a minimum, I think I'd want to put all 12 bolts in place on the center spar, with appropriate spacers between the top and bottom middle bolts, before I drilled the new doubler that will tie the tops of the center spar together. They must line up, and the holes must be tight. Since the holes are already drilled, they holes must be aligned before the two sides of the spar are drilled and riveted together. However, I haven't even looked at the instructions for upgrading the center spar, and it may be covered there. Let us know how you resolve this. Terry >Thanks wa7dvd. That seems to be a solution as I think that the upgrade >manual suggests drilling through the existing holes in the forward flange >of the spar which will clip the old cabin floor holes. I note that in one >of the upgrade videos you can see that their clecos are squint because of >this. Is there sufficient edge distance between the old and new holes in >your method? > >Anyone else got a solution for the bolt hole alignment on the upgraded spar? > >James Terry Phillips ttp44~at~rkymtn.net Corvallis MT ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done; Upgrading wings & ailerons per the AMD Safety Directive http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: Jun 02, 2010
Hi Dale I made the same decision. I recommend that you check out Tony Bingellis' article, "About Aircraft Plumbing," in his book Firewall Forward. You might be able to find the article for free on the EAA website. A lot of his articles are published there for members. Bngellis recommended 5052-1. 6061 is stiffer. The article has a lot of info about fittings, design, etc. It is a good primer. Terry >I've decided to replace the rubber hose fuel line from the tank with 3/8" >aluminum line. I've got 2 questions - should I use 6061-T6 Aluminum line >and what wall thickness should I use? Aircraft Spruce sells 4 different >wall thicknesses for 3/8" OD line - .035, .058, .065 and .083. > >It seems to me any of these should give me adequate fuel flow for a Jabiru >3300. The other issue might be strength, but I should be able to support >it well enough. > >Thanks for any advice. Terry Phillips ttp44~at~rkymtn.net Corvallis MT ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done; Upgrading wings & ailerons per the AMD Safety Directive http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: Jun 02, 2010
Hi Terry, Good to hear from you again. The problem is that even without the actual wing spars in place I can see that the alignment is very slightly off on the outside bolt holes only. If I turn a wing spar bolt it twists into place (probably exerting some pressure on the thread but if i use a 5/16 transfer punch (ie. an object with straight sides it will not fit easily as it clips (very slightly) the edge of the web on the far side's bolt hole). Oddly, the other in board bolt holes seem to be, in general, well aligned. I note that the bolt holes were drilled by Zenith (ie. this was a kit not plans built) and the only modification I have made is in accordance with the upgrades to the carry through spar. I am very reluctant to ream the holes any further as on each web individually I have a nice fit (very) fit...especially after all the incidents and conversations on the forum. Any help would be appreciated. Has anyone had this problem? James -------- Cell +27 83 675 0815 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299822#299822 ________________________________________________________________________________
Date: Jun 03, 2010
I bought a roll of 3003 and several pre cut 6' sections of 5052. I much prefer the 5052. I had no success trying to unroll 3003 to straight. It looked awful. I gave it away to a fellow builder. However, the 5052 is soft enough to work with and has no bends in it except the ones I put there. Shipping cost is a little more but not by much if you go 6' max. I had no runs where I needed more than 6'...Geoff Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299831#299831 ________________________________________________________________________________
Date: Jun 03, 2010
Just a reminder to all using AN fittings on the aluminum and braided fuel l ines that they require a 37 degree flare (and thus an aviation flaring tool ) and not a standard 45 degree flare as on automobiles.=0A-=0ABill Pag=E1 n=0A=0A=0A=0A=0A________________________________=0AFrom: Geoff Heap <stol10 (at)comcast.net>=0ATo: zenith601-list(at)matronics.com=0ASent: Thu, June 3, 2010 8:22:48 AM=0ASubject: Zenith601-List: Re: Fuel line size=0A=0A--> Zenith601 -List message posted by: "Geoff Heap" =0A=0AI bought a roll of 3003 and several pre cut 6' sections of 5052. I much prefer the 505 2. I had no success trying to unroll 3003 to straight. It looked awful. I g ave it away to a fellow builder. However, the 5052 is soft enough to work w ith and has no bends in it except the ones I put there. Shipping cost is a little more but not by much if you go 6' max. I had no runs where I needed more than 6'...Geoff=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp:/ /forums.matronics.com/viewtopic.php?p=299831#299831=0A=0A=0A=0A=0A=0A=0A =================0A=0A=0A ________________________________________________________________________________
Date: Jun 03, 2010
Thanks everybody :D Great advice! -------- Dale Flying Cessna 170B Building Zenith CH650 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299850#299850 ________________________________________________________________________________
Date: Jun 03, 2010
If you are an EAA member or know someone who is, there is a nice article in this months Sport Aviation on choosing and fabricating aluminum fuel lines. Check it out! Tim Juhl -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299859#299859 ________________________________________________________________________________
Date: Jun 03, 2010
Dale Call Van's aircraft and order their 3/8 tubing it iust seems to be easier to work with and then you know you are getting the right stuff. But if you have to get it from Spruce this is the stuff you want. _http://www.aircraftspruce.com/catalog/mepages/3003versatube.php_ (http://www.aircraftspruce.com/catalog/mepages/3003versatube.php) Jeff In a message dated 6/2/2010 6:50:42 P.M. Eastern Daylight Time, dalemed(at)gmail.com writes: --> Zenith601-List message posted by: "dalemed" I've decided to replace the rubber hose fuel line from the tank with 3/8" aluminum line. I've got 2 questions - should I use 6061-T6 Aluminum line and what wall thickness should I use? Aircraft Spruce sells 4 different wall thicknesses for 3/8" OD line - .035, .058, .065 and .083. It seems to me any of these should give me adequate fuel flow for a Jabiru 3300. The other issue might be strength, but I should be able to support it well enough. Thanks for any advice. -------- Dale Flying Cessna 170B Building Zenith CH650 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299792#299792 ________________________________________________________________________________
Subject: AN-3 nyloc nut torque
Date: Jun 05, 2010
people what torque are you doing these little nuts up to with the .125 th spar plate? on the AC43-13B it talks about 25"lb. Zenith construction standards the same. Problem is they are still loose when the torque wrench clicks, not bottomed out, loose. some one suggested adding the friction TQ of the nut. to the published TQ The good book AC 43 said max 40"lb. So what have others been using as the TQ value?? At 40 its firm and you can still move the whole bolt and nut a little with a spanner if u rotate the head. the A4's are OK just the little A3's that worry me, logic says you should not be able to move the bolt when done up to the correct torque. Am I over worried? Chris. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300106#300106 ________________________________________________________________________________
Date: Jun 05, 2010
Subject: Re: AN-3 nyloc nut torque
Hi Chris I used the info from Zenair's construction standard CS#407, which says: >Drag torque. Run the nut down to near contact with the washer and check >the friction drag torque required to turn the nut. Add the drag torque to >the desired torque. This is referred to as the final torque which should >register on the indicator or setting on the torque wrench. And, as you note, CS#407 specifies 20-25 in-lbs for AN3's with AN365 nuts. The problem is, I do not see any way to measure the drag torque with a "click" type torque wrench. So I chose a "beam" type wrench, the Park TW-1, IIRC. It is actually sold as a bike tool, ~$40 USD. With my bolts, nuts, and wrench, I measure a drag torque of ~4 in-lb, so I torqued my AN3 to between 25 and 30 in-lb. That nut and bolt seem to be plenty tight to me. Perhaps your click wrench is not accurate in the low in-lb ranges. Terry >people >what torque are you doing these little nuts up to with the .125 th spar plate? >on the AC43-13B it talks about 25"lb. Zenith construction standards the >same. Problem is they are still loose when the torque wrench clicks, not >bottomed out, loose. >some one suggested adding the friction TQ of the nut. to the published TQ > >The good book AC 43 said max 40"lb. So what have others been using as the >TQ value?? At 40 its firm and you can still move the whole bolt and nut a >little with a spanner if u rotate the head. > >the A4's are OK just the little A3's that worry me, logic says you should >not be able to move the bolt when done up to the correct torque. >Am I over worried? >Chris. Terry Phillips ttp44~at~rkymtn.net Corvallis MT ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done; Upgrading wings & ailerons per the AMD Safety Directive http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: Jun 05, 2010
Chris, Make sure you have the correct length bolt. If the bolt is too long, the nut will hit the shoulder and not allow it to become tight. You are correct you will not be able to move the bolt if all is right. Floyd Wilkes 601XL -----Original Message----- From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of chris Sinfield Sent: Saturday, June 05, 2010 6:29 AM Subject: Zenith601-List: AN-3 nyloc nut torque --> people what torque are you doing these little nuts up to with the .125 th spar plate? on the AC43-13B it talks about 25"lb. Zenith construction standards the same. Problem is they are still loose when the torque wrench clicks, not bottomed out, loose. some one suggested adding the friction TQ of the nut. to the published TQ The good book AC 43 said max 40"lb. So what have others been using as the TQ value?? At 40 its firm and you can still move the whole bolt and nut a little with a spanner if u rotate the head. the A4's are OK just the little A3's that worry me, logic says you should not be able to move the bolt when done up to the correct torque. Am I over worried? Chris. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300106#300106 ________________________________________________________________________________
Date: Jun 05, 2010
Subject: Upgrade Tools list on Matronics Wiki
I am working my 601XL upgrade. A critical piece of information that I have not found in the Zenair upgrade dwgs and the Photo Assembly Guides is a list of the tools needed to perform the upgrades. I have been buying tools that I think will be useful. Some of them have been vital to my work. Others have been a waste of money, at least for the upgrade. I think that a tool list would be useful for upgraders, so I put together an Excel worksheet summarizing my experience with the tools I've purchased, good and bad. I've included my personal rating of each tool, as well as, cost and ordering links. I think that the Matronics Wiki provides an excellent vehicle to share this information with the 601XL/650 community, because a Wiki lends itself to editing--both revisions and additions--so any of you can weigh in with your experience. If you've discovered a really good tool, add it to the list. If I've panned some tool that you found useful--or vice versa, change the rating. If you decide to edit the information, thank you, and be sure to add your initials to the contributor's list. If you do edit the Wiki, you might post a note with that information to the Matronics lists. The link to the Wiki is: http://www.matronics.com/wiki/index.php/Zenith#601XL.2F650_Upgrade_of_December_2009 I tried to add structure for adding in upgrade tips and tricks, for those who would like to share your discoveries. I will be adding in some of my own in the future, but I wanted to get this out there now. I hope that those who are further along the upgrade path will add in your lessons learned. Enjoy the build! Terry Terry Phillips ttp44~at~rkymtn.net Corvallis MT ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done; Upgrading wings & ailerons per the AMD Safety Directive http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: Jun 05, 2010
Terry, Check Jake Reyna's blog on the Zenith.aero forum. Jake has a procedure and pictures of how he handled the placement of the holes in the center spar front flange. Basically, he used the floor doubler as a template and drilled new holes between the existing holes. That gave him solid material all the way through the bottom doubler, floor, and spar flange. No dealing with having to drill through half misaligned holes in the floor. You drill through the bottom doubler and front spar flange on the work table, then only have to back drill through the floor with the doubler (template) in position under the fuselage. I did mine that way and I'm satisfied with it. Terry Phillips wrote: > Hi James > > I am far from taking my center spar apart, but I have been thinking about > that alignment problem for a while. > > It seems to me that the best thing would be to actually bolt both wing > spars to the two sides of the center spar before riveting the two sides > together. That may be overkill, however. At a minimum, I think I'd want to > put all 12 bolts in place on the center spar, with appropriate spacers > between the top and bottom middle bolts, before I drilled the new doubler > that will tie the tops of the center spar together. They must line up, and > the holes must be tight. Since the holes are already drilled, they holes > must be aligned before the two sides of the spar are drilled and riveted > together. > > However, I haven't even looked at the instructions for upgrading the center > spar, and it may be covered there. Let us know how you resolve this. > > Terry > > > > > Thanks wa7dvd. That seems to be a solution as I think that the upgrade > > manual suggests drilling through the existing holes in the forward flange > > of the spar which will clip the old cabin floor holes. I note that in one > > of the upgrade videos you can see that their clecos are squint because of > > this. Is there sufficient edge distance between the old and new holes in > > your method? > > > > Anyone else got a solution for the bolt hole alignment on the upgraded spar? > > > > James > > > > > > > Terry Phillips > ttp44~at~rkymtn.net > Corvallis MT > ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done; > Upgrading wings & ailerons per the AMD Safety Directive > http://www.mykitlog.com/N47TP/ -------- Louis W. Ott 601XL beginner Quick Build Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300156#300156 ________________________________________________________________________________
Subject: Re: Upgrade Tools list on Matronics Wiki
Date: Jun 05, 2010
The list looks good for starters with differences being mostly personal preference. I'd suggest using a 4x rivet gun. The 3x will probably work ok, but the extra punch of the 4x makes setting the #6 rivets quicker and less tendency for the gun to bounce. I like to use an adjustable size reamer rather than a single step fixed size. With the adjustable, I can sneak up on the hole size to give me a better fit to the bolt whatever small size difference it may have from it's nominal size. I could add; Lathe, milling machine, TIG welder, metal brake, metal shear, more rivets, longer #6 rivets than what Zenith sends. Mind reading course to help with interpreting the drawings and instructions. -------- Louis W. Ott 601XL beginner Quick Build Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300159#300159 ________________________________________________________________________________
Date: Jun 05, 2010
Terry, I=B4d like to thank you very much for your list and the effort you=B4ve mad e to help us to build a safer plane. I=B4m glad you=B4re me friend. Thanks again, Alberto Martin www.iberplanes.es Igualada - Barcelona - Spain ---------------------------------------------- Zodiac 601 XL Builder Serial: 6-7011 Tail Kit: Finished Wings: Not Started Fuselage: Started Engine: Jabiru 3300 Un ingles a Tom Lucero en la guerra de Malvinas: "=A1Piloto argentino mejor aqu=ED con nosotros en camilla. Muy peligroso arriba, en su avi=F3n!=97". Un pasaje del libro "Dios y Los Halcones" del Com. Pablo M. Carballo ________________________________________________________________________________
Date: Jun 07, 2010
Subject: upgrade oops. (maybe)
Date: Jun 08, 2010
I've been working my way through the upgrade of the center spar and I may have made a boo-boo that may make me build another 6-zu-2-1. I overlayed 6-zu-2-1 over 6w4-1 and back drilled through 6w4-1 where the spar cap overlays and also through 6w4-1 and 6-zu-2-1 where 6w4-2 once was riveted. After I did that, I realized I shouldn't have. Can I salvage 6-zu-2-1 or should I make a new one? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300544#300544 Attachments: http://forums.matronics.com//files/2_445.jpg http://forums.matronics.com//files/1_543.jpg ________________________________________________________________________________
Subject: Re: upgrade oops. (maybe)
Date: Jun 10, 2010
I think I'll just order a new one from ZAC. That will be safer. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300831#300831 ________________________________________________________________________________
From: "david van lanen" <davevanlanen(at)sbcglobal.net>
Subject: Zenith Work Table For Sale
Date: Jun 10, 2010
High quality, perfectly flat work table for building a Zenith aircraft. Has adjustable legs, and built-in storage for clecos, rivets, tools and aircraft parts. Hardly used, (I sold my 601XL project early in the build). Will sell for half the cost of materials used to build. Can be partially or completely disassembled for transport. U pick up (Madison, Wisconsin). E-mail me offline for details and photos: davevanlanen(at)sbcglobal.net ________________________________________________________________________________
Subject: Zenith Aircraft Tools For Sale
Date: Jun 10, 2010
New Zenith builders: Here is a great opportunity to purchase most of the tools needed to build a Zenith aircraft at a discount. Everything is reduced 20% or more off the prices I paid. Tools were hardly used, as I sold my 601XL project after completing the tail and flight controls. I am looking to sell as a complete set. Purchase the complete set, and I will pay for shipping within the continental U.S. E-mail me offline for a detailed list of tools with photos: davevanlanen(at)sbcglobal.net. ________________________________________________________________________________
Date: Jun 14, 2010
http://www.mykitairplane.com/chat/ Check out my line of items for Experimental Airplane Builders My Products: http://www.mykitairplane.com/Products/ ________________________________________________________________________________
Subject: Fuel Cap 601 XL.
Date: Jun 15, 2010
Hi Guys, I am trying to remove the threaded flange cap assembly from one of my wing tanks to seal the thread and stop some fuel leakage. I am having great difficulty in removing it. Is there a way to do this without destroying it. It is presently stuck so I can't thread it in or out. Thanks Peter Wonthaggi Australia http://zodiac.cpc-world.com ________________________________________________________________________________
Date: Jun 14, 2010
Hi Peter. When I put mine together I stuck a wide piece of wood in the top - in both of the openings where the gas cap locks in place - and turned the threaded neck with the piece of wood. I don't remember the actual size but I think it was a 1 x 1. Good luck, Paul Camas, WA XL-fighting solid rivets for upgrade. From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Peter W Johnson Sent: Monday, June 14, 2010 4:24 PM Subject: Zenith601-List: Fuel Cap 601 XL. Hi Guys, I am trying to remove the threaded flange cap assembly from one of my wing tanks to seal the thread and stop some fuel leakage. I am having great difficulty in removing it. Is there a way to do this without destroying it. It is presently stuck so I can't thread it in or out. Thanks Peter Wonthaggi Australia http://zodiac.cpc-world.com ________________________________________________________________________________
Date: Jun 14, 2010
OOPS, I meant 1x2. The end of the board should fit into the slots in the gas cap mating area. Then you can grab the board and twist. Perhaps some anti-seize compound would be a good idea when re-installing the part. Paul From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Paul Mulwitz Sent: Monday, June 14, 2010 4:42 PM Subject: RE: Zenith601-List: Fuel Cap 601 XL. Hi Peter. When I put mine together I stuck a wide piece of wood in the top - in both of the openings where the gas cap locks in place - and turned the threaded neck with the piece of wood. I don't remember the actual size but I think it was a 1 x 1. Good luck, Paul Camas, WA XL-fighting solid rivets for upgrade. From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Peter W Johnson Sent: Monday, June 14, 2010 4:24 PM Subject: Zenith601-List: Fuel Cap 601 XL. Hi Guys, I am trying to remove the threaded flange cap assembly from one of my wing tanks to seal the thread and stop some fuel leakage. I am having great difficulty in removing it. Is there a way to do this without destroying it. It is presently stuck so I can't thread it in or out. Thanks Peter Wonthaggi Australia http://zodiac.cpc-world.com http://www.matronics.com/Navigator?Zenith601-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Fuel Cap 601 XL.
Date: Jun 14, 2010
I did the same as Paul. Don't use a soft wood as it will just tend to splinter. Carve it so it fits the profile of the opening as close as possible. You might try tapping the rim with a wood or rubber mallet and slip some oil between the skin and the lip to remove some of the friction. It can be a real son-of-a-gun to get off but be persistent. I just had to remove one as part of my wing modification and know what you are facing. If it originally turned in really hard you may have a problem with bad threads. I had one like that and had to cut the cap flange out and buy a replacement. I then borrowed the "big tap" from Zenith to clean out the threads in both tanks and when I installed the new one I used teflon paste on the threads. Good luck! Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301249#301249 ________________________________________________________________________________
Subject: Aileron bellcrank wear?
Date: Jun 14, 2010
This question is for those who've opened their wings up for modification after putting some flight hours on their aircraft. Has anyone noticed any wear in the holes where the control cables attach to the aileron bellcrank? Since there is tension on the cables I wonder whether the hole is elongating in the direction of the tension being applied. If so, it would seem to me that this would be a good place to install a bushing. I own a taildragger and one of the things you watch for is that the holes on the rudder horn where the tailwheel springs attach will often wear in such a manner. The rudder horn is half-inch thick aluminum with steel springs attached - much beefier than the bellcrank. The springs are under tension, just like the control cables and over time the steel cuts into the softer aluminum. Comments? Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301264#301264 ________________________________________________________________________________
Date: Jun 15, 2010
Peter I have the zenith tool for re working the tank cap threads if required. Chris in Sydney. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301283#301283 ________________________________________________________________________________
Date: Jun 15, 2010
Peter, When you get it apart, I recommend when you reassemble coat the threads with fuel lube (http://www.aircraftspruce.com/catalog/cspages/ezturnlube.php) to seal the filler neck. I used this last time I installed the filler neck and it came right out when opening the wing for the upgrade. Fuel lube does not harden and provides a great seal. Regards, Dave -------- Dave Gardea 601XL - Corvair working on wiring panel and upgrade kit http://home.comcast.net/~davegardea/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301311#301311 ________________________________________________________________________________
Date: Jun 16, 2010
Chris, Thanks, I'll let you know how I go. Cheers Peter -----Original Message----- From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of chris Sinfield Sent: Tuesday, 15 June 2010 11:22 PM Subject: Zenith601-List: Re: Fuel Cap 601 XL. Peter I have the zenith tool for re working the tank cap threads if required. Chris in Sydney. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301283#301283 ________________________________________________________________________________
Subject: GSC In-Flight Adjustable Prop
Date: Jun 15, 2010
Hello. Is anyone using the GSC In-Flight Adjustable Prop on their 601/Rotax ? Thanks. ________________________________________________________________________________
Date: Jun 15, 2010
Boy do I know about that part coming out hard. When we did the CZAW teardown one tank was difficult to remove the flange but it was a one man job and wood did the trick. The second one was a three man 1.5 hour job using a steel insert to turn the flange. We used penetrating oil and worked the flange both ways and gradually it came out. The fit was not good and they used some type of hardening sealer on the threads. Used the Big tap from Zenith to chase the threads on both tanks and used Fuelube to seal the threads. P.S. I ran a low pressure test on my tank the other day with only fuelube on the finger tight threads of both the finger screen and the filler tube, RESULTS: no leaks. Low pressure test is tying a latex glove over the vent tube, inflate the glove and seal it up, wait to see if the glove deflates. -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301374#301374 ________________________________________________________________________________
Subject: RE: Zenith-List: RE: Fuel Cap 601XL
Date: Jun 17, 2010
Thanks for the reply=92s guys, I=92ll see if I can machine a piece of ally the same shape as the filler cap and try that. Cheers Peter From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Jon Bateman Sent: Thursday, 17 June 2010 1:24 PM Subject: RE: Zenith-List: RE: Fuel Cap 601XL To aid in getting my tank neck on and off I machined down a piece of nylon that just fit inside the neck with a hole near the top for a screwdriver or what not to turn it with. This has works great as there is zero chance for marring the neck. Before re-installing the neck use anti seize on the threads Jon B. 2/3rds through upgrade. _____ From: bressler(at)wyoming.com Subject: Zenith-List: RE: Fuel Cap 601XL Date: Wed, 16 Jun 2010 17:24:17 -0600 Peter: If your fuel cap is the same as ours which stuck pretty hard, I cut a 2=94 piece of =BC=94 by 1=94 aluminum bar and gripped it with a pair of vice grips. I inserted into the slots and used a crescent wrench to turn the vice grips until it would unscrew by hand. Good Luck with your build. DO NOT ARCHIVE Wes & Lurlene Bressler, Laramie WY, USA Working on the upgrade. >http://www.matronics.com/Navigator?Zenith-List ronics.com ww.matronics.com/contribution _____ The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail. Get busy. <http://www.windowslive.com/campaign/thenewbusy?tile=multicalendar&ocid =PID2 8326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5> ________________________________________________________________________________
Date: Jun 16, 2010
Use a piece of wood, NOT alloy so there is no chance of damaging the fuel cap internals. When I put mine on originally I used some permatex on the threads but it was still a bit hard coming off. Cheers Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301517#301517 ________________________________________________________________________________
Subject: Aileron balance install
Date: Jun 18, 2010
I'm getting ready to install the aileron balance in my right aileron. Looking at the LAA drawings provided by Zenith for the upgrade I see that they set the ribs that support the square tube used as a balance arm parallel to the other ribs in the aileron. This would result in the tube not being at a right angle to the rear spar. In my view, this would result in requiring a wider hole in the spar to accommodate the lateral movement of the tube when the aileron is deflected. I also believe there was an earlier discussion of the need to bend the tube inwards to clear the wingtip rivet line. I wonder how others have dealt with this issue. I'm consideringL 1.) installing the ribs supporting the tube so as to place the tube at a right angle to the spar, & 2.) Moving the tube inwards slightly to assure clearance from structures in the wing. I'd appreciate your comments before I start cutting :) Tim Juhl -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301668#301668 ________________________________________________________________________________
Date: Jun 18, 2010
Hi Tim, On mine, I installed the balance rod perpendicular to the MAIN spar. That means an angle (not perpendicular) to the rear spar and aileron hinge. I don't know what all the issues are for this problem. One seems to be how the weights move between the rear rib and wing tip as well as the two wing skins. Good luck, Paul XL - slowly installing upgrade - currently fighting removing large spar rivets. -----Original Message----- From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Tim Juhl Sent: Friday, June 18, 2010 7:12 AM Subject: Zenith601-List: Aileron balance install I'm getting ready to install the aileron balance in my right aileron. Looking at the LAA drawings provided by Zenith for the upgrade I see that they set the ribs that support the square tube used as a balance arm parallel to the other ribs in the aileron. This would result in the tube not being at a right angle to the rear spar. In my view, this would result in requiring a wider hole in the spar to accommodate the lateral movement of the tube when the aileron is deflected. I also believe there was an earlier discussion of the need to bend the tube inwards to clear the wingtip rivet line. I wonder how others have dealt with this issue. I'm consideringL 1.) installing the ribs supporting the tube so as to place the tube at a right angle to the spar, & 2.) Moving the tube inwards slightly to assure clearance from structures in the wing. I'd appreciate your comments before I start cutting :) Tim Juhl -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301668#301668 ________________________________________________________________________________
Date: Jun 18, 2010
Subject: Rivet Removal
My two cents on removing solid spar rivets: I'm drilling the heads with a #20 drill down to about even with the sheet metal and then using a Stanley wood chisel to remove the head. Three or four hits with my little hammer and the head goes flying. Barely even scuffs the surface of the sheet metal. When I'm all done the chisel won't be worth much, but it was pretty cheap. Getting the rest of the rivet out I use a small pin punch and whack it a few times. Steve Steve Look Monticello, IL www.ilrt66.com "Dogs have owners, Cats have staff" ________________________________________________________________________________
Date: Jun 18, 2010
Subject: Re: Aileron balance install
Tim, I did two things. First I did not keep the arms parallel to the ribs. I shifted them just enough so they would be far enough away from the other structures so no interference was possible (including the metal plates). I allowed about 1 inch from the end of the tube to any other part. Secondly, I filled about 7 inches of the end of the square tube with lead. It melts at about 600-700F and alumimum is melts at around 1200F so as long as one keeps the lead at just above the melting point it works. I stuffed and tamped aluminim foil into the tube to act as a plug to define the area to be filled. A heat gun was used to pre-heat the tube a bit so the lead would flow all the way to the plug. The lead was melted using a 1500W hot plate with the lead in a metal coffee can and with a larger metal can inverted over that to keep the heat in. It took about 40 minutes to get the lead all melted. You will need about 1.5 pounds of lead for each side. I started with 5 pounds total and that made it easy to pour. Doing this I only needed two steel plates to balance. This allowed one to use the specified holes by turning the aileron vertical to insert the tube in the hole with the balance plates on. This way the aileron can be removed in the future. On 06/18/2010 10:11 AM, Tim Juhl wrote: > --> Zenith601-List message posted by: "Tim Juhl" > > I'm getting ready to install the aileron balance in my right aileron. Looking at the LAA drawings provided by Zenith for the upgrade I see that they set the ribs that support the square tube used as a balance arm parallel to the other ribs in the aileron. This would result in the tube not being at a right angle to the rear spar. In my view, this would result in requiring a wider hole in the spar to accommodate the lateral movement of the tube when the aileron is deflected. I also believe there was an earlier discussion of the need to bend the tube inwards to clear the wingtip rivet line. > I wonder how others have dealt with this issue. I'm consideringL > 1.) installing the ribs supporting the tube so as to place the tube at a right angle to the spar,& > 2.) Moving the tube inwards slightly to assure clearance from structures in the wing. > > I'd appreciate your comments before I start cutting :) > > Tim Juhl > > -------- > ______________ > CFII > Champ L16A flying > Zodiac XL - Jabiru 3300A > Tearing wings apart for modification > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=301668#301668 > > > -- Mark Hubelbank NorthEast Monitoring 2 Clock Tower Place Suite 555 Maynard, MA, 01754 - USA mhubel(at)nemon.com 978-443-3955 ________________________________________________________________________________
Date: Jun 18, 2010
I moved the balance arm 100 mm inboard and it clears with no bending of the arm. If you install the ribs at the same angle as the other ribs it is a bit more difficult to align everything but I feel looks better. Jeff In a message dated 6/18/2010 10:12:44 A.M. Eastern Daylight Time, juhl(at)avci.net writes: --> Zenith 601-List message posted by: "Tim Juhl" I'm getting ready to install the aileron balance in my right aileron. Looking at the LAA drawings provided by Zenith for the upgrade I see that they set the ribs that support the square tube used as a balance arm parallel to the other ribs in the aileron. This would result in the tube not being at a right angle to the rear spar. In my view, this would result in requiring a wider hole in the spar to accommodate the lateral movement of the tube when the aileron is deflected. I also believe there was an earlier discussion of the need to bend the tube inwards to clear the wingtip rivet line. I wonder how others have dealt with this issue. I'm consideringL 1.) installing the ribs supporting the tube so as to place the tube at a right angle to the spar, & 2.) Moving the tube inwards slightly to assure clearance from structures in the wing. I'd appreciate your comments before I start cutting :) Tim Juhl -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301668#301668 ________________________________________________________________________________
Date: Jun 18, 2010
The one I just did I just made square to the hinge line and picked up two existing rivets for the new rib rivet lines. I checked clearance with a large carpenters square from the center of one rivet and wouldn't ya know, the next rivet was 40mm away, ( just perfect for the rib lines) . It was very easy to draw those lines around the aileron skin using a square. Once the lines were drawn just mark and drill the end holes, and rivet fan for the 5 rivets on the end, and 8 rivets top and bottom. -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301722#301722 Attachments: http://forums.matronics.com//files/zu_108a_210.jpg http://forums.matronics.com//files/zu_104_442.jpg ________________________________________________________________________________
Subject: keyed lock for old style handle
Date: Jun 19, 2010
Hi I was wondering if someone had a part number and where you get the keyed locks that fit the older style canopies? I know I can by them from Zenith at 50 bucks but someone gave a location for a cheaper $15 one Chris Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301728#301728 ________________________________________________________________________________
Date: Jun 19, 2010
I did mine kind of like Ron did, except I "split the difference" between the rivet lines. http://www.zenith.aero/photo/aileron-balance-ribs Had plenty of clearance, and I didn't have to mess around with bending the arm. Having 20/20 hindsight, if I could do it all over again I'd have put the aileron trim on the right wing instead of the left. Between that and the counter weight, the left wing is starting to get kind of heavy way out there by the tip, and since the pilot sits on the left side anyway, it would have been nicer to have all that weight on the other side to balance things out better. I also like the idea of filling the end of that tube with lead and keeping the whole thing "skinny" so the aileron could be removed in the future if need be. I didn't do that, and hope I don't come to regret that. - Pat -------- Patrick XL/650/Corvair N63PZ (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301742#301742 ________________________________________________________________________________
Date: Jun 19, 2010
For what it's worth,,, did my aileron balance per the instructions from Zenith and it work out perfect. No interference with anything, no bending of the tube etc... I did put a couple of L angles on the front side of the rear spar one on each side of the "cut out" because I noticed with the weight installed, it (the rear spar at that point) seemed to flex just a little. (Hinge less) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301745#301745 ________________________________________________________________________________
Subject: more upgrade questions
Date: Jun 19, 2010
Folks, I feel like I'm a little thick sometimes. I have the center spar mostly assembled and I have both the front and back in position for drilling up through the top doubler (6-zu-2-1) However if I look closely through the holes I will just clip the old hole in 6w4-1. I appear to be making an aluminum sandwich with the new top doubler 6-zu2-1 and the seat front angle 6-zu-2-2. Should I just drill through the seat front angle, and into the top doubler, elongating the hole and not worry about it. I suppose that is why they went to pitch 20 on that row of rivets. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301789#301789 Attachments: http://forums.matronics.com//files/holeoffset_105.jpg ________________________________________________________________________________
Subject: Sensenich prop for sale
Date: Jun 20, 2010
I have a like-new Sensenich 64 x 49 wood prop that I had on a 6 cylinder Jabiru 3300 engine in a Zenith Zodiac. I think it was around $900 when I bought it new. I'd like to get $500 for it. I would prefer local pick-up in Lancaster, California. I still have the original shipping box, but UPS shipping would probably run around $100 because of the oversize length of the box. Rick Pitcher Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301811#301811 ________________________________________________________________________________
Subject: Re: Sensenich prop for sale
Date: Jun 20, 2010
Contact info: email me at zodie(at)adelphia.net I have a like-new Sensenich 64 x 49 wood prop that I had on a 6 cylinder Jabiru 3300 engine in a Zenith Zodiac. I think it was around $900 when I bought it new. I'd like to get $500 for it. I would prefer local pick-up in Lancaster, California. I still have the original shipping box, but UPS shipping would probably run around $100 because of the oversize length of the box. Rick Pitcher Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301812#301812 ________________________________________________________________________________
Subject: Re: Aileron bellcrank wear?
Date: Jun 20, 2010
I wondered the same thing when I saw the aileron bellcrank. I made different ones using a ball bearing for the pivot bearing and bronze bushings for the cable clevis attachments. The bearing and bushings are from Aircraft Spruce. The new bellcrank is a bit lighter than the original. The thickness is the same so the original attachments can be used with the holes drilled to fit the ball bearing ID. -------- Louis W. Ott 601XL beginner Quick Build Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301858#301858 Attachments: http://forums.matronics.com//files/rightwingaileronbellcrankaccess_124.jpg http://forums.matronics.com//files/aileron_bellcrank_131.jpg ________________________________________________________________________________
Date: Jun 20, 2010
I cannot say for the aileron bearing. However, it is certainly true for the upper rudder bearing on the HD model. I made a new part after three years of flying. After removing the part, however, I did feel that the part was still safe (plenty of edge distance and no noticeable fluttering or vibration in flight). ---------------------------- Michel Therrien CH601-HD, C-GZGQ http://mthobby.pcperfect.com/ch601 http://pages.infinit.net/mthobby ________________________________________________________________________________
Date: Jun 20, 2010
Louie You are a true craftsman. You new bellcrank is a work of art. Do you have a drawing of your design? It looks like a very good design improvement. I'm thinking that I will replace the nylon fairleads for the aileron control cables with pulleys. My hope is to reduce the drag in the aileron control system, and thereby improve the control harmony. This would not be a possibility without aileron counterbalance, but with the counterbalance, it should not present a problem. I'm wondering if anyone else has put in pulleys? Terry >I wondered the same thing when I saw the aileron bellcrank. I made >different ones using a ball bearing for the pivot bearing and bronze >bushings for the cable clevis attachments. The bearing and bushings are >from Aircraft Spruce. The new bellcrank is a bit lighter than the >original. The thickness is the same so the original attachments can be >used with the holes drilled to fit the ball bearing ID. > >-------- >Louis W. Ott > >601XL beginner Quick Build Terry Phillips ttp44~at~rkymtn.net Corvallis MT ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done; Upgrading wings & ailerons per the AMD Safety Directive http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: Jun 20, 2010
Hi Terry, Before you invest a lot of time and money in changing fairleads to pulleys, I think you should consider another aspect of the "Control Harmony" issue. The Zodiac XL has HUGE ailerons. This means force applied to the control stick doesn't require much movement of the ailerons to produce roll torque. It also means the ailerons work quite well all the down to stall speed where most spam cans lose nearly all control effect. I believe it is the geometry and size of the ailerons that makes them feel so stiff in flight rather than any drag in the control cables. Good luck, Paul XL fighting main spar rivet removal for the upgrade. -----Original Message----- From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Terry Phillips Sent: Sunday, June 20, 2010 8:38 PM Subject: Re: Zenith601-List: Re: Aileron bellcrank wear? Louie You are a true craftsman. You new bellcrank is a work of art. Do you have a drawing of your design? It looks like a very good design improvement. I'm thinking that I will replace the nylon fairleads for the aileron control cables with pulleys. My hope is to reduce the drag in the aileron control system, and thereby improve the control harmony. This would not be a possibility without aileron counterbalance, but with the counterbalance, it should not present a problem. I'm wondering if anyone else has put in pulleys? Terry ________________________________________________________________________________
Date: Jun 20, 2010
Hi Terry, I do have a drawing I made just to see if it would work. I Printed out a full size example and cut it out from cardboard. I can't remember if any slight changes were done when I cut it from aluminum. I don't think so. The drawing was done in Solidworks. I exported a .jpg file of the drawing so the quality isn't so great. The bronze bushings are Aircraft Spruce P/N FF303-01. Look under Hardware, Bushings. They are $0.19 each. Drill the bushing hole in the bellcrank slightly undersize and press in the bushing. The bellcrank bearing is Aircraft Spruce P/N BC4W10 (AN218-4). Look under Airframe parts, Bearings. It costs $18.95. This bellcrank doesn't require any changes to the normal mount and the geometry is the same as the Zenith bellcrank. Use a washer on top and bottom of the bearing to insure the bearing housing doesn't rub on the support when you tighten the bolt. I don't know how much drag the fairleads would add to the aileron movement. The cables don't move very far to give full travel. It'll be something I'll check when I connect the controls. BTW, the SS rivets work great. Thanks Louie Terry Phillips wrote: > Louie > > You are a true craftsman. You new bellcrank is a work of art. Do you have a > drawing of your design? It looks like a very good design improvement. > > I'm thinking that I will replace the nylon fairleads for the aileron > control cables with pulleys. My hope is to reduce the drag in the aileron > control system, and thereby improve the control harmony. This would not be > a possibility without aileron counterbalance, but with the counterbalance, > it should not present a problem. I'm wondering if anyone else has put in > pulleys? > > Terry > > > > > I wondered the same thing when I saw the aileron bellcrank. I made > > different ones using a ball bearing for the pivot bearing and bronze > > bushings for the cable clevis attachments. The bearing and bushings are > > from Aircraft Spruce. The new bellcrank is a bit lighter than the > > original. The thickness is the same so the original attachments can be > > used with the holes drilled to fit the ball bearing ID. > > > > -------- > > Louis W. Ott > > > > 601XL beginner Quick Build > > > > > > > Terry Phillips > ttp44~at~rkymtn.net > Corvallis MT > ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done; > Upgrading wings & ailerons per the AMD Safety Directive > http://www.mykitlog.com/N47TP/ -------- Louis W. Ott 601XL beginner Quick Build Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301885#301885 Attachments: http://forums.matronics.com//files/aileron_bellcrank_2d_406.jpg ________________________________________________________________________________
Subject: Chat Reminder
Date: Jun 21, 2010
http://www.mykitairplane.com/chat/ DO NOT ENTER ANY PASSWORD, JUST YOUR USER NAME CHOICE Check out my line of items for Experimental Airplane Builders My Products: http://www.mykitairplane.com/Products/ ________________________________________________________________________________
Subject: Re: more upgrade questions
Date: Jun 21, 2010
perhaps a little more data is in order: I've attached a picture from from the latest set of upgrade drawings dated 25 Jan 2010. I've highlighted the rivets in question. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301937#301937 Attachments: http://forums.matronics.com//files/rivetsinquestion_246.jpg ________________________________________________________________________________
Date: Jun 21, 2010
I would suggest a call to ZAC is in order... Carlos On 21 June 2010 13:01, Lee Steensland wrote: > > > > perhaps a little more data is in order: > > I've attached a picture from from the latest set of upgrade drawings dated > 25 Jan 2010. I've highlighted the rivets in question. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=301937#301937 > > > Attachments: > > http://forums.matronics.com//files/rivetsinquestion_246.jpg > > ________________________________________________________________________________
Date: Jun 21, 2010
Lee, The drawing calls for rivets on a 20 mm pitch so some new holes need to be made anyway. I did all new holes with the old holes half way way between the new ones and offset enough so as to provide sufficient hole to hole spacing. If the old holes in yours are positioned such that there is no room to provide sufficient spacing, then ZAC will have to come up with something. On 06/21/2010 1:34 PM, Carlos Sa wrote: > I would suggest a call to ZAC is in order... > > Carlos > > On 21 June 2010 13:01, Lee Steensland > wrote: > > > > > perhaps a little more data is in order: > > I've attached a picture from from the latest set of upgrade > drawings dated 25 Jan 2010. I've highlighted the rivets in question. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=301937#301937 > > > Attachments: > > http://forums.matronics.com//files/rivetsinquestion_246.jpg > > > * > > > * -- Mark Hubelbank NorthEast Monitoring 2 Clock Tower Place Suite 555 Maynard, MA, 01754 - USA mhubel(at)nemon.com 978-443-3955 ________________________________________________________________________________
Date: Jun 21, 2010
Subject: Rivet squeezer for solid rivets
If anyone is interested, I have a rivet squeezer along with the required yokes and dies to put in the solid #6 rivets in the main spar and the #5 solid rivets along the joint on the top of the center spar connecting the two half's (the 20 mm pitch rivets). The yokes are not big enough to do the solid rivets on the center spar on the vertical surfaces. I found the latter to be the easiest ones to put in with a rivet gun anyway. I am willing to lend it to others or even sell the bunch. I have about $450 tied up in all the parts. It might be a good tool for a club. It will do up to #6 rivets. -- Mark Hubelbank NorthEast Monitoring 2 Clock Tower Place Suite 555 Maynard, MA, 01754 - USA mhubel(at)nemon.com 978-443-3955 ________________________________________________________________________________
Date: Jun 21, 2010
>From Caleb: > > Hi Lee, > A doubler, such as this, is the proper way to repair ovalled holes. That is one of the reasons for having the part installed at all. When you mess up a hole and its ovalled, you put a doubler over the hole and rivet it to the web as well as the flange. This will unload the ovalled hole and provide an alternate load path (the load now goes through the doubler) into the web. In this case the doubler is heavier than the flange material because we want to add strength beyond the normal spar. The ovalled holes are a consequence of spacing the front and rear halves further apart 1/8" but this has been accounted for in the development of the upgrade package. You don't need to worry about ovalling those holes, just so long as the holes in the doublers are all round. > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=301961#301961 ________________________________________________________________________________
Subject: Painting question
Date: Jun 22, 2010
Is it better to paint the control hinges or to tape them? Pins in or out? ________________________________________________________________________________
Subject: Fw: Tip
Date: Jun 22, 2010
----- Original Message ----- From: Bob McArdle Sent: Monday, June 14, 2010 12:00 PM Subject: Tip While browsing through my local big box plumbing dept I cam across Watts PL-3000 quick connect coupling.Great for pitot/static lines between fus and wing. ________________________________________________________________________________
Subject: panel trim
Date: Jun 22, 2010
I've viewed photos of XL's with this nice looking trim around the instrument panel. Can anyone tell me where this comes from? Chuck, CH650 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302155#302155 ________________________________________________________________________________
Subject: panel trim
Date: Jun 22, 2010
Cleveland Tool has edge trim. Search their site for "trim": http://www.cleavelandtoolstore.com GSE54 Glare Shield Edge Trim 54 Glare Shield Edge Trim 54" $14.00 GSE60 Glare Shield Edge Trim 60 Glare Shield Edge Trim 60" $16.00 -- Craig -----Original Message----- From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of chuck960 Sent: Tuesday, June 22, 2010 9:13 PM Subject: Zenith601-List: panel trim --> I've viewed photos of XL's with this nice looking trim around the instrument panel. Can anyone tell me where this comes from? Chuck, CH650 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302155#302155 ________________________________________________________________________________
Subject: Re: panel trim
Date: Jun 23, 2010
Chuck, In my case, it came from Zenith. I think it was introduced with the 750. Jay I've viewed photos of XL's with this nice looking trim around the instrume nt panel. Can anyone tell me where this comes from? Chuck, CH650 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302155#302155 ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
Subject: Wire stop
Date: Jun 23, 2010
Has anyone come up with a good way to fasten the wire control to the fuel shut off valve? I've tried the whole through a bolt with nuts on both sides and the threaded tube with the hole and bolt but both methods slip in time. Got to be a better way. Bob, Wichita ________________________________________________________________________________
Subject: Paint Weight
Date: Jun 23, 2010
Has anyone ever weighed an aileron before and after painting? I wonder how much of a weight increase is seen with a typical paint job. Obviously I'm thinking of issues that might occur with the aileron balance. Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302263#302263 ________________________________________________________________________________
Date: Jun 23, 2010
Hi Tim, Just a guess . . . I would think a proper (i.e. thin) paint job would weigh considerably less than one of those steel weights. It would take perhaps one or two ounces of thinned paint per coat and maybe4 or 5 coats. Of course, most of the weight of the liquid paint would be thinner. Paul XL - doing upgrade - fighting main spar rivet removal. -----Original Message----- From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Tim Juhl Sent: Wednesday, June 23, 2010 1:07 PM Subject: Zenith601-List: Paint Weight Has anyone ever weighed an aileron before and after painting? I wonder how much of a weight increase is seen with a typical paint job. Obviously I'm thinking of issues that might occur with the aileron balance. Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302263#302263 ________________________________________________________________________________
Date: Jun 24, 2010
Does anyone have a picture of the trim installed in the aircraft? -------- Cell +27 83 675 0815 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302367#302367 ________________________________________________________________________________
Date: Jun 24, 2010
-----Original Message----- From: Scotsman <jaroberts(at)bdo.co.za> Sent: Thu, Jun 24, 2010 8:54 am Subject: Zenith601-List: Re: panel trim Does anyone have a picture of the trim installed in the aircraft? -------- Cell +27 83 675 0815 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302367#302367 ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
Date: Jun 24, 2010
Yes that's the trim I'm looking for. Where did it come from? Thanks for the photo. Chuck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302444#302444 ________________________________________________________________________________
Date: Jun 24, 2010
Ditto Chuck's comment. BTW what is the lever arm that extends to the cabin floor...a fuel cut off or parking brake? j -------- Cell +27 83 675 0815 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302447#302447 ________________________________________________________________________________
Date: Jun 25, 2010
Chuck, That is the trim I got from Zenith. - Jay -----Original Message----- From: chuck960 <chuckde(at)roadrunner.com> Sent: Thu, Jun 24, 2010 10:29 pm Subject: Zenith601-List: Re: panel trim Yes that's the trim I'm looking for. Where did it come from? Thanks for the photo. Chuck ________________________________________________________________________________
Date: Jun 25, 2010
That is a lever for the parking brake, which I made with ball valves from Lowes aviation department. Jay -----Original Message----- From: Scotsman <jaroberts(at)bdo.co.za> Sent: Fri, Jun 25, 2010 12:16 am Subject: Zenith601-List: Re: panel trim Ditto Chuck's comment. BTW what is the lever arm that extends to the cabin floor...a fuel cut off or parking brake? j -------- Cell +27 83 675 0815 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=302447#302447 ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
Date: Jun 25, 2010
Hi Paul I do not have personal experience on the 601XL control harmony problem. My total time in 601XL is a 30 minute flight in the factory demo plane. I am just reacting to various posts on line that suggest that control harmony is not good on the 601XL. I think that it is likely that high friction in the aileron controls were an important factor in the pre-upgrade design to avoid aileron flutter. Normal design practice is to eliminate flutter with counterbalanced control surfaces. (If you look at almost any certificated airplanes with aluminum skinned ailerons, you will find counterbalances.) If one can count on the aileron counterbalances to eliminate flutter in the 601XL, then one should be able to replace the aileron fairleads with pulleys w/o introducing a new risk of aileron flutter. Since the elevator and rudder are not counterbalanced, I would not consider replacing the fairleads in those control links. If you are correct that the high forces for roll control reported for the 601XL are simply due to the geometry and size of the ailerons, then installing pulleys will not improve the control harmony. However, if friction in the control links proves to be significant then pulleys might make a useful difference. I'm a long way from building my fuselage, so my ultimate decision on this item is not imminent. Some other builders have replaced the control cables with push-pull rods. I'm very curious if any one has replaced the aileron fairleads with pulleys. Terry >Hi Terry, > >Before you invest a lot of time and money in changing fairleads to pulleys, >I think you should consider another aspect of the "Control Harmony" issue. > >The Zodiac XL has HUGE ailerons. This means force applied to the control >stick doesn't require much movement of the ailerons to produce roll torque. >It also means the ailerons work quite well all the down to stall speed where >most spam cans lose nearly all control effect. I believe it is the geometry >and size of the ailerons that makes them feel so stiff in flight rather than >any drag in the control cables. > >Good luck, > >Paul Terry Phillips ttp44~at~rkymtn.net Corvallis MT ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done; Upgrading wings & ailerons per the AMD Safety Directive http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: Jun 26, 2010
Hi Louie Thank you for the details. Have you tried exporting the drawing to a .png? I find that png's do not have the noise that creeps into jpg's at the sharp, black-white boundaries in drawings and text. If you could email me a copy of your image, I'd appreciate it. Another alternative to jpg's is a pdf. The Windows freebie pdf creator from SourceForge is invaluable to me. I'm sure that there are Linux equivalents. 'Glad to hear that the SS rivets are proving useful. I used a bunch of them on my garage door and they have been perfect. If and when I get the invoice from Lehigh-Armstrong, I'll work out the cost split and let you know. I called L-H Friday, but it was late and I just got their voice mail. Thanks for the great idea on improving the aileron bellcrank. Terry >Hi Terry, >I do have a drawing I made just to see if it would work. I Printed out a >full size example and cut it out from cardboard. I can't remember if any >slight changes were done when I cut it from aluminum. I don't think so. >The drawing was done in Solidworks. I exported a .jpg file of the drawing >so the quality isn't so great. The bronze bushings are Aircraft Spruce P/N >FF303-01. Look under Hardware, Bushings. They are $0.19 each. Drill the >bushing hole in the bellcrank slightly undersize and press in the bushing. >The bellcrank bearing is Aircraft Spruce P/N BC4W10 (AN218-4). Look under >Airframe parts, Bearings. It costs $18.95. This bellcrank doesn't require >any changes to the normal mount and the geometry is the same as the Zenith >bellcrank. Use a washer on top and bottom of the bearing to insure the >bearing housing doesn't rub on the support when you tighten the bolt. > >I don't know how much drag the fairleads would add to the aileron >movement. The cables don't move very far to give full travel. It'll be >something I'll check when I connect the controls. > >BTW, the SS rivets work great. Thanks > >Louie Terry Phillips ttp44~at~rkymtn.net Corvallis MT ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done; Upgrading wings & ailerons per the AMD Safety Directive http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: Jun 26, 2010
Subject: Rudder hinge wear - solution anyone?
Hi group, I mentionned about the rudder upper bearing (hinge) becoming loose with time. I already replaced it once. It appears somewhat loose again. Did anyone invent a fix for this? ---------------------------- Michel Therrien CH601-HD, C-GZGQ http://mthobby.pcperfect.com/ch601 http://pages.infinit.net/mthobby ________________________________________________________________________________
Date: Jun 26, 2010
Subject: Re: Rudder hinge wear - solution anyone?
How about that bearing that was discussed a few days ago? It was meant for the aileron bell crank, but maybe it could be used on the rudder...? Salut bien Carlos On 26 June 2010 22:37, Michel Therrien wrote: > > Hi group, > > I mentionned about the rudder upper bearing (hinge) becoming loose with > time. I already replaced it once. It appears somewhat loose again. Did > anyone invent a fix for this? > > ---------------------------- > Michel Therrien CH601-HD, C-GZGQ > ________________________________________________________________________________
Date: Jun 27, 2010
Michel Therrien wrote: > > Hi group, > > I mentionned about the rudder upper bearing (hinge) becoming loose with time. I already replaced it once. It appears somewhat loose again. Did anyone invent a fix for this? > > ---------------------------- > Michel Therrien CH601-HD, C-GZGQ > http://mthobby.pcperfect.com/ch601 > http://pages.infinit.net/mthobby > > Michel, > > I had to machine new bushings. The paragraphs below, from my > journal, describe, I believe, the same issue and my solution. > > > > The top bolt on the rudder rattled so the bolt was inspected and found to be worn and sloppy. > > Began again today with removal of the rudder I removed the press-fit bushing from the upper rudder plate by grinding a 3/16th inch Allen screw head to .250-diameter and used a 3/8-inch socket and nut to pull it > from the plate. Once home, I made 4 more bushings on the lathe that were > better lengths for the rudder bracket gap. The loose bolt had caused wear at the > top angle bracket holes and to the bolt. > >>> >>> This morning, the first press fit of the best-length bushing went >>> well. The same screw used to remove the former bushing was used to >>> pull it to a force-fit into place. The rudder was placed on the >>> upper bushing and bolted. The bottom bushing was replaced with a >>> slightly longer one and it too was given a fresh new bolt. Both were >>> snugged to stop bolt rotation and secured with castle nut and cotter >>> pins. Now bolt and bushing were the only working surfaces as intended. >>> >>> Larry McFarland 601HDS at www.macsmachine.com >>> > > ________________________________________________________________________________
Date: Jun 28, 2010
Date: Jun 28, 2010
Larry, I think I did it differently than you.. in my case, the upper plate rotates around the bushing that itself is captured in a fixed position between the two angles attached to the rudder. The bolt does not rotate on any part. Are you saying that the bushing should stay "with" the upper plate attached to the fuselage and that the friction should be between the bolt and the bushing? If so, that must be hard to lubricate...? ---------------------------- Michel Therrien CH601-HD, C-GZGQ http://mthobby.pcperfect.com/ch601 http://pages.infinit.net/mthobby --- On Sun, 6/27/10, Larry McFarland wrote: > From: Larry McFarland <larry(at)macsmachine.com> > Subject: Re: Zenith601-List: Rudder hinge wear - solution anyone? > To: zenith601-list(at)matronics.com > Received: Sunday, June 27, 2010, 10:27 AM > --> Zenith601-List message posted > by: Larry McFarland > > Michel Therrien wrote: > Therrien > > > > Hi group, > > > > I mentionned about the rudder upper bearing (hinge) > becoming loose with time. I already replaced it > once. It appears somewhat loose again. Did > anyone invent a fix for this? > > > > ---------------------------- > > Michel Therrien CH601-HD, C-GZGQ > >http://mthobby.pcperfect.com/ch601 > >http://pages.infinit.net/mthobby > > > > Michel, > > > > I had to machine > new bushings. The paragraphs below, from my > > journal, describe, I believe, the same issue and my > solution. > > > > > > The top bolt on the > rudder rattled so the bolt was inspected and found to be > worn and sloppy. Began again > today with removal of the rudder I removed the > press-fit bushing from the upper rudder plate by grinding a > 3/16th inch Allen screw head to .250-diameter and used a > 3/8-inch socket and nut to pull it from the plate. Once > home, I made 4 more bushings on the lathe that were better > lengths for the rudder bracket gap. The loose bolt had > caused wear at the top angle bracket holes and to the bolt. > > > >>> > >>> This morning, the first press fit of the > best-length bushing went well. The same screw used to remove > the former bushing was used to pull it to a force-fit into > place. The rudder was placed on the upper bushing and > bolted. The bottom bushing was replaced with a slightly > longer one and it too was given a fresh new bolt. Both were > snugged to stop bolt rotation and secured with castle nut > and cotter pins. Now bolt and bushing were the only working > surfaces as intended. > >>> > >>> Larry McFarland 601HDS at > www.macsmachine.com > >>> > > > > > > > > Email Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Jun 28, 2010
Michel, The bushing was made as a press fit in the large plate. The bolt secures center within the bushing and was easy to lubricate by greasing the bolt on assembly. The upper and lower plates held to center by the bolt are strong enough to not allow the bolt to rotate in them. The actual rotation forces are borne by the largest surfaces of the bolt and inside the bushing. The top and bottom bushing surfaces are not strained at all in flight. Wear on my bolt occurred because it was not tight and locked to allow no pivot within the upper and lower plates. The bolt now rotates with the rudder and the bushing is fixed by its fit in the plate. I had to make 4 bushings to get it right. The bottom plate holds the rudder at elevation as well so that the top bushing isn't doing all the lifting. If the bushing were allowed to rotate in the top and bottom plates, I believe wear would be a significant issue at the top pivot assembly. Doubt bronze would be as good in holding a press fit and that's why I made mine of steel. Larry McFarland 601HDS at www.macsmachine.com Michel Therrien wrote: > > Larry, I think I did it differently than you.. in my case, the upper plate rotates around the bushing that itself is captured in a fixed position between the two angles attached to the rudder. The bolt does not rotate on any part. > > Are you saying that the bushing should stay "with" the upper plate attached to the fuselage and that the friction should be between the bolt and the bushing? If so, that must be hard to lubricate...? > > > ---------------------------- > Michel Therrien CH601-HD, C-GZGQ > http://mthobby.pcperfect.com/ch601 > http://pages.infinit.net/mthobby > > ________________________________________________________________________________
Subject: How much paint?
Date: Jul 03, 2010
The list has been fairly quiet lately, so I thought I'd ask one of those questions that must be burning in everyone's mind: How much paint (in gallons) does it take to do a 601XL? I realize I also need primer, thinner, etchant, etc, but if I knew how much paint some of you needed, I might be able to factor those other numbers. Of course, if someone happens to have those at hand, I wouldn't mind real numbers there, either. -- ======================================= Jim B. Belcher BS,MS Physics A&P/IA General Radio Telephone Certificate Instrument Rated Pilot Retired Aerospace Technical Manager Semi-proficient Househusband ======================================= ________________________________________________________________________________
Subject: Re: How much paint?
Date: Jul 03, 2010
I used a white undercoat on the entire airplane. It seems like it took 5-6 qts. Kirker is a great cost / quality compromise. http://www.autobodytoolmart.com/ultra-glo-acrylic-urethane-enamel-paints-c-895.aspx There are more expensive paints out there and perhaps they come with higher quality but in the end you'll end up doing it a 2nd time due to upgrades. At least that has been my experience. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303609#303609 ________________________________________________________________________________
Subject: Solid rivet confusion
Date: Jul 03, 2010
OK, maybe I need glasses but I have been unable to find some of the info I need in Zenith's drawings or guide. Perhaps those of you who have done the wing upgrade will help me out. Dwg. 6ZU-1 states (paraphrased) "...install extrusion using --AD6-14 and --AD6-15 (qty 4) and --AD6-10 solid rivets" [1] The packing list does not show any --AD-14 rivets, only --AD-15's. I assume these are to be used on the inboard section of the top spar. Did anyone have any trouble using the longer rivets supplied by Zenith? [2] The outboard rivets I drilled out were all --AD5's yet it looks like Zenith supplied AD6-10's for that location. Am I correct that I am to replace these outermost rivets with the larger diameter ones? They also sent some AD5-10's but I think they are for the center section. Comments? As always I appreciate your comments. Tim Juhl -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303616#303616 ________________________________________________________________________________
Date: Jul 03, 2010
Hi Tim, I am at the exact stage you are discussing, but I have taken a different path. I decided to use bolts instead of rivets when installing the new spar cap angle. I will use AN4 bolts in the inner section where the original 3/6 rivets are used and AN3 bolts where the smaller rivets are used. I already have the correct drill and reamer for the AN4 bolts, but I have not yet acquired a reamer for the smaller ones. I ordered it yesterday, but A/S seems to have them on back order. It is necessary to move up to AN4 bolts because the original holes used for the 3/16 rivets are too large for AN3 bolts. They would just rattle around in the oversized holes. The smaller holes, 5/32, don't have a corresponding bolt size so I will increase them to 3/16 for use with AN3 bolts. I realize the bolts are heavier than aluminum rivets, but I feel my skills are adequate to install the bolts and insufficient to install the huge rivets. If I had your exact situation I would merely order the required rivet sizes from Aircraft Spruce or a similar vendor to meet my needs. I was surprised the upgrade kit had exactly the required number of solid rivets when the first time builders have never used solid rivets before. This compares unfavorably with the supply of A4 and A5 Avex rivets which seems to be an ample supply measured by the pound rather than the exact number that matches the number of expected holes. I know I have an attitude problem when it comes to Zenith and the Heintz family, but I would not depend on them being around much longer to complete my plane. I am glad we got a "Blessed" design upgrade, but since we still have no clue what the actual problem is that led to all the deaths I have very little confidence the upgrade will fix the real (but still unknown) problem. I will just do my best to install the upgrade and then take my plane into phase I testing. I still have not decided whether to take it into phase II or not. Good luck, Paul -----Original Message----- From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Tim Juhl Sent: Saturday, July 03, 2010 2:44 PM Subject: Zenith601-List: Solid rivet confusion OK, maybe I need glasses but I have been unable to find some of the info I need in Zenith's drawings or guide. Perhaps those of you who have done the wing upgrade will help me out. Dwg. 6ZU-1 states (paraphrased) "...install extrusion using --AD6-14 and --AD6-15 (qty 4) and --AD6-10 solid rivets" [1] The packing list does not show any --AD-14 rivets, only --AD-15's. I assume these are to be used on the inboard section of the top spar. Did anyone have any trouble using the longer rivets supplied by Zenith? [2] The outboard rivets I drilled out were all --AD5's yet it looks like Zenith supplied AD6-10's for that location. Am I correct that I am to replace these outermost rivets with the larger diameter ones? They also sent some AD5-10's but I think they are for the center section. Comments? As always I appreciate your comments. Tim Juhl -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303616#303616 ________________________________________________________________________________
Date: Jul 03, 2010
Subject: Re: Solid rivet confusion
Hi Tim The 3/16" solid rivets supplied in my upgrade kit were all AN470AD-6-14's and AN470AD-6-10's.I thought that AN470AD-6-14's were too short for the spar cap-spar web-spar cap doubler-extrusion joint. So, for that joint, I used AN470AD-6-16 that I had purchased from Spruce. I used the AN470AD-6-14's supplied by Zenair for the outboard section beyond the end of the spar cap doubler where the joint is 1/4" thinner. My Avery rivet length gage showed the -16's being ~1/32" too long and the -14's being ~3/32" too short. My interpretation of the plans was to replace the 5/32" rivets in the spar cap beyond the spar cap doubler with 3/16" rivets, except for the most outboard one which was replaced with a 3/16" AN bolt. I was never able to develop what I considered adequate skills to set the 3/16" rivets with my 3X rivet gun. Fortunately, I was able to borrow what I call a "pounder" tool to set the rivets and it worked perfectly, so long as I didn't hit the spar with the hammer. It is possible that I would have been able to set Zenair's shorter rivets with my 3X gun, but I doubt that the shop heads would have met both the minimum diameter and minimum thickness specs. Like Paul, I found that the 3/16" rivet holes in my spar caps are too large diameter for AN3 bolts, so I bought AN4's to attach the spar root doubler plate. That's my next step. If you're interested in excruciating detail, you are welcome to check my Kitlog. Terry >OK, maybe I need glasses but I have been unable to find some of the info I >need in Zenith's drawings or guide. Perhaps those of you who have done >the wing upgrade will help me out. > >Dwg. 6ZU-1 states (paraphrased) "...install extrusion using --AD6-14 and >--AD6-15 (qty 4) and --AD6-10 solid rivets" > >[1] The packing list does not show any --AD-14 rivets, only --AD-15's. I >assume these are to be used on the inboard section of the top spar. Did >anyone have any trouble using the longer rivets supplied by Zenith? > >[2] The outboard rivets I drilled out were all --AD5's yet it looks like >Zenith supplied AD6-10's for that location. Am I correct that I am to >replace these outermost rivets with the larger diameter ones? They also >sent some AD5-10's but I think they are for the center section. Comments? > >As always I appreciate your comments. > >Tim Juhl Terry Phillips ttp44~at~rkymtn.net Corvallis MT ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done; Upgrading wings & ailerons per the AMD Safety Directive http://www.mykitlog.com/N47TP/ ________________________________________________________________________________
Date: Jul 03, 2010
I used a 4X gun and a 5lb bucking block of steel. The AN470AD-6-15's set just fine. The trick is to not pull or let off the trigger without having pressure (arm strong) against the factory head. The bucking bar just has to touch to shop head, you don't have to press hard with the bucking bar. Once you have set a few you can hear and feel when it is set right. The 3X gun wasn't doing a good job. There were a couple I had to remove and reset, the 4X gun expanded the rivets much better, the 3X gun rivets came out real easy, not so with the 4X gun, it took more work to get them out and that is a good thing here. All they sent me were the 15's and the 10's for the wing spars. They all finished within the Mil Specs. I think the reference to the 14's is an error in the print, call zenith or post to their zenith.aero site directly to Mathieu Heintz. -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303636#303636 ________________________________________________________________________________
Date: Jul 04, 2010
Subject: 601xl down
a 601xlb crashed around frankfort ky. around the end of June Has anyone heard about this? Frank ________________________________________________________________________________
Subject: Re: 601xl down
Date: Jul 04, 2010
Hi What is the difference between a 601 xl vs 601xlb Thanks don ----- Original Message ----- From: N601xl(at)aol.com To: zenith601-list(at)matronics.com ; zenith-list(at)matronics.com ; zenith650-list(at)matronics.com Sent: Sunday, July 04, 2010 7:20 AM Subject: Zenith601-List: 601xl down a 601xlb crashed around frankfort ky. around the end of June Has anyone heard about this? Frank ________________________________________________________________________________
Date: Jul 04, 2010
An XLB is an XL that has had the upgrade modifications done. do not ardchive -----Original Message----- From: ella <ella_rhodes(at)att.net> Sent: Sun, Jul 4, 2010 8:04 am Subject: Re: Zenith601-List: 601xl down Hi What is the difference between a 601 xl vs 601xlb Thanks don ----- Original Message ----- From: N601xl(at)aol.com -list(at)matronics.com Sent: Sunday, July 04, 2010 7:20 AM Subject: Zenith601-List: 601xl down a 601xlb crashed around frankfort ky. around the end of June Has anyone heard about this? Frank href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matr onics.com/Navigator?Zenith601-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
Date: Jul 04, 2010
Subject: Re: Back to the workshop!
Thanks for sharing!- There were two good pictures of my 601. ---------------------------- Michel Therrien CH601-HD, C-GZGQ http://mthobby.pcperfect.com/ch601 http://pages.infinit.net/mthobby --- On Sun, 7/4/10, Carlos Sa wrote: I posted some pictures of the fly-in on Picasa, in case you are interested: =0A=0A ________________________________________________________________________________
Date: Jul 04, 2010
Subject: stabilizer attachment
Hello, all I am building the rear fuselage, and before committing to the position of parts, I decided to check how the stabilizer would align. Looks like I'll have to move it forward somewhat (2 or 3 cm), and perhaps add a little shim to the rear attachment, so the width looks ok. My question to the group is about edge distance: the (CH601-HD) construction manual (Edition 3, Jan 1995) says, in the "tail installation on the fuselage" section (page 26): "watch for a minimum edge distance of 13 mm to any edge." While the dimensions of 6F2-7 and -8 (6B3-3/4 on the XL) allow for this, 6T2-1 and 6T2-3 do not - or at least I don't see how. Therefore, I am assuming that the 13 mm statement refers to the HT attachment brackets only (6F2-7 / 8 on the 601-HD and 6B3-3 / 4 on the XL). I would appreciate the group's comments on this. Thanks in advance Carlos CH601-HD, plans ________________________________________________________________________________
Date: Jul 04, 2010
Thanks for the info... I appreciate all your comments. I was planning on using a mix of rivets and bolts, assuming I can set the rivets OK with my 3x gun. I haven't a lot of experience riveting (took an EAA class) and plan to set up a practice jig to see how it goes. I did buy a 5 lb bucking bar which I understand should help. The features that attracted me to the XL in the first place haven't changed. My hope is that experience with the modified aircraft will allow all of us to fly our planes with confidence as long as we stay within the envelope, which is true of all aircraft. I didn't mean to rekindle old arguments but we all know that we'll have to wait for some time to pass to get our answers. Happy 4th of July! Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303743#303743 ________________________________________________________________________________
Date: Jul 05, 2010
I checked the NTSB, FAA Preliminary database and Google and found no mention of a accident with a 601, modified or not. There were plenty of other experimental and factory builts that met grief during the period. Tim -------- ______________ CFII Champ L16A flying Zodiac XL - Jabiru 3300A Tearing wings apart for modification Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303804#303804 ________________________________________________________________________________
Date: Jul 05, 2010
Date: Jul 05, 2010
After reading the post of "601xlb down", I checked the www.flightsafty.org site and there was no mention of any 601 down. The site was updated through 7/3, worldwide. Sounds like another red herring. :? Phil -------- Phil Read this topic online here: http://forums.matronics.com/viewtopic.php?p=303815#303815 ________________________________________________________________________________
Date: Jul 05, 2010
Paul; Please go away. You certainly get the prize for being a pain in the butt! Why don't you buy a C-172 then you can bitch at a big boy. Regards, John CH701 - Colorado - Jabiru 3300 Cell: 719-494-4567 Home: 303-648-3261 ________________________________________________________________________________
Date: Jul 05, 2010
I've said it before and I will repeat my statement - PILOT ERROR. You cannot expect to fly outside the recommended limits and live. which part of that needs more explanation? Regards, John CH701 - Colorado - Jabiru 3300 Cell: 719-494-4567 Home: 303-648-3261 ________________________________________________________________________________
Date: Jul 07, 2010
from what I understand from someone who was there,. the 601xlb was being test flown after the modification. The owner-pilot was told that there was very little gas in the tank. so....as things will happen when you don't use a check list. he took off and ....well you guessed it, the engine quit from lack of gas. the pilot landed hard with no damage to himself and minimal damage to the plane. It is hard to protect yourself from stupidity.. ________________________________________________________________________________
Date: Jul 08, 2010
Tim I put a call through to Zenith and was told that the rivets can be between 1.2 to 1.75 bigger than the metal you are fixing. When I clamp my spar tight together the AD-14 come within specs. Ian Rat CH601XL Brisbane Australia. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304158#304158 ________________________________________________________________________________
From: "Patrick J Papania" <papaniapatrick(at)aol.com>
Subject: Upgrade Complete and Testing going well
Date: Jul 08, 2010
We completed the upgrade on our 601 XL recently. As soon as we got the annual completed we put it back into the sky. So far we have noticed a much more solidly performing airplane. We stay well within the envelop that the plane was designed for and are having a blast. When I decide to sell eventually, someone is going to get one hell-ov-an airplane. We have the 3300 Jabiru with an MGL Enigma EFIS along with the Trio Auto pilot and Altitude hold. Pat AMF Aviation Alliance, Ohio ________________________________________________________________________________
Subject: Re: Upgrade Complete and Testing going well
Date: Jul 08, 2010
Congrats Pat! Do you have any pics? What "envelope" are you flying within? How much weight did it add? How long did it take? Here are a couple pics of my "new" bird... added 13 pounds, took 13 hours, total cost $390... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304206#304206 Attachments: http://forums.matronics.com//files/23_184.jpg http://forums.matronics.com//files/24_198.jpg ________________________________________________________________________________
Date: Jul 08, 2010
One thing that made me chose the Zenith Aircraft -is their robust landing gear... -Just land in rough strips holding the front wheel up as much as possible, both in the 701 and in any of the 601's... - in any emergency fly the airplane all the way down, yes lets all use the check list always. Gary Gower701 R912601 XL -installing the upgrade. --- On Wed, 7/7/10, Paul Baker wrote: From: Paul Baker <pbaker4(at)windstream.net> Subject: Re: Zenith601-List: 601xl down Date: Wednesday, July 7, 2010, 8:28 AM =0A=0A =0A =0A=0A=0A =0Afrom what I understand from someone who was =0Ather e,.- the- 601xlb was being test flown after the modification. The =0Aow ner-pilot was told that there was very little gas in the tank. so....as thi ngs =0Awill happen when you don't use a =0Acheck list. he took off and- . ...well you =0Aguessed it, the engine quit from lack of gas. the pilot land ed hard with =0A=0Ano damage to himself and minimal damage to the =0Aplane. =================0A=0A=0A=0A=0A ________________________________________________________________________________
Date: Jul 08, 2010
Inrat, Thanks for the info but can you be more specific? You lost me at 1.2 to 1.75 bigger. Are we talking about diameter, length, rivet or hole? Chuck Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304260#304260 ________________________________________________________________________________
Date: Jul 08, 2010
Sorry about that. Yes 1.2 to 1.75 times the Dia of the rivet. Most people say it has to be 1.5 times the Dia this is the ideal length but Zenith state in the CONSTRUCTION STANDARDS section CS #403 page 28 the Max - Min - and Nominal settings. After setting a rivet i measures it and it was within specs. Ian Rat CH601XL Brisbane Australia. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304264#304264 ________________________________________________________________________________
Date: Jul 10, 2010
Subject: First flight of N316JL
N316JL (CH601HDS w/912ULS) took to the air this morning. She made one exciting trip around the circuit. Ran out of aileron trim trying trim out a left turning tendency. Had fumes in the cockpit from what appeared to be oil. Oil temps and pressure were good. After landing inspection showed no oil leaks. Must be the new burning off the exhaust system. Landing was uneventful, actually one of the best Ive made. This was probably due to the amount of concentration I was giving to the flight at the time. Thanks to Don Honabach letting me have some stick time in HDS a week ago. Without this time the flight could have been a lot more exciting. This has been a 10 year 10 month adventure from the rudder the workshop to the first flight. Im still flying high. Jerry ________________________________________________________________________________
Date: Jul 10, 2010
Subject: Re: First flight of N316JL
GOOD JOB! Hopefully I will follow soon. Larry Husky Madras, Oregon In a message dated 7/10/2010 8:55:47 A.M. Pacific Daylight Time, jlatimer1(at)cox.net writes: --> Zenith601-List message posted by: Jerry N316JL (CH601HDS w/912ULS) took to the air this morning. She made one exciting trip around the circuit. Ran out of aileron trim trying trim ou t a left turning tendency. Had fumes in the cockpit from what appeared to be oil. Oil temps and pressure were good. After landing inspection showed no oil leaks. Must be the new burning off the exhaust system. Landing was uneventful, actually one of the best I=99ve made. This was probabl y due to the amount of concentration I was giving to the flight at the time. Thanks to Don Honabach letting me have some stick time in HDS a week ago. Without this time the flight could have been a lot more exciting. This has been a 10 year 10 month adventure from the rudder the workshop to the first flight. I=99m still flying high. Jerry ======================== =========== ======================== =========== ======================== =========== ======================== =========== ________________________________________________________________________________
Date: Jul 10, 2010
Well Done Jerry! Ten years is a long time . . . Paul XL slowly doing upgrade -----Original Message----- From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Jerry Sent: Saturday, July 10, 2010 8:55 AM Subject: Zenith601-List: First flight of N316JL N316JL (CH601HDS w/912ULS) took to the air this morning. She made one exciting trip around the circuit. Ran out of aileron trim trying trim out a left turning tendency. Had fumes in the cockpit from what appeared to be oil. Oil temps and pressure were good. After landing inspection showed no oil leaks. Must be the new burning off the exhaust system. Landing was uneventful, actually one of the best Ive made. This was probably due to the amount of concentration I was giving to the flight at the time. Thanks to Don Honabach letting me have some stick time in HDS a week ago. Without this time the flight could have been a lot more exciting. This has been a 10 year 10 month adventure from the rudder the workshop to the first flight. Im still flying high. Jerry ________________________________________________________________________________
Date: Jul 10, 2010
Congratulations Jerry, you now belong to a very select group, those who can and do. -------- Ron Lendon, Clinton Township, MI WW Corvair with Roy's Garage 5th bearing Zodiac XL, ScrapBuilder ;-) http://www.mykitlog.com/rlendon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304441#304441 ________________________________________________________________________________
Subject: Seats for my 601XL B
Date: Jul 11, 2010
List, Does anybody know of other suppliers of seats (finished) for 601XL? I know FlightCrafters in FL. Any others? Thanks, Mike Upgrade finished...yuck! -------- Mike Miller @ millrml(at)aol.com 601 XL, 3300, Dynon Remember, "the second mouse gets the cheese"! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=304477#304477 ________________________________________________________________________________
Subject: Re: Seats for my 601XL B
Date: Jul 11, 2010
Yes. You. You can make your own. It's just not that hard. It is simply another part of building your own airplane. Let me know if you want more information. Jay Bannister List, Does anybody know of other suppliers of seats (finished) for 601XL? I know FlightCrafters in FL. Any others? Thanks, Mike ________________________________________________________________________________
Date: Jul 11, 2010
On Sunday 11 July 2010 12:57:38 you wrote: > Yes. You. You can make your own. It's just not that hard. It is simply > another part of building your own airplane. Let me know if you want more > information. > > Jay Bannister Actually, Jay, I'm also at about that point. I've seen how a couple of others did it, and there was a fair discussion in Kitplanes a couples of months back. But I'd like to see whatever you have in mind. Lots of choices means we're better informed! -- ======================================= Jim B. Belcher BS,MS Physics A&P/IA General Radio Telephone Certificate Instrument Rated Pilot Retired Aerospace Technical Manager Semi-proficient Househusband ======================================= ________________________________________________________________________________
Date: Jul 11, 2010
Jim, Here a few photos of how I did it. Mine are certainly not "Ferrari" class , but they are comfortable and not obnoxious. A lot of folks get the base and foam done, then take them to an upholstery shop. I got seat covers at Pep Boys and made do. The foam came from Wicks, I think. The plywood base for the back was flat. The plywood base for the bottom was kerfed for bending and pressed into the seat pan. The wheels kept them pressed in tight while the epoxy coating set up to hold the shape. Let me know if you have questions. Jay ________________________________________________________________________________
Subject: Re: Returned Mail: Re: Seats for my 601XL B
Date: Jul 11, 2010
Hmmm. All my photos had a .jpg extension, which is about as "valid" as yo u can get, So I don't know what the problem was. Jim, I will send them directly to you, OK? Jay -----Original Message----- From: zenith601-list(at)matronics.com Sent: Sun, Jul 11, 2010 3:00 pm Subject: Returned Mail: Re: Seats for my 601XL B The following message from jaybannist(at)cs.com was not authorized for entry in the Matronics Email Lists forum. Reason: There were problems with the attachments [Attachment must have a valid extension to be saved to a forum.] Visit this URL to register: http://forums.matronics.com//index.php From: jaybannist(at)cs.com Subject: Re: Seats for my 601XL B **************************************** Jim, Here a few photos of how I did it. Mine are certainly not "Ferrari" class , but they are comfortable and not obnoxious. A lot of folks get the base and foam done, then take them to an upholstery shop. I got seat covers at Pep Boys and made do. The foam came from Wicks, I think. The plywood base for the back was flat. The plywood base for the bottom was kerfed for bending and pressed into the seat pan. The wheels kept them pressed in tight while the epoxy coati ng set up to hold the shape. Let me know if you have questions. Jay ________________________________________________________________________________
Date: Jul 11, 2010
I get individual e-mails and received 8 photos. I thought the tires went on the outside of the plane. :-) -- Craig _____ From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of jaybannist(at)cs.com Sent: Sunday, July 11, 2010 1:10 PM Subject: Zenith601-List: Re: Returned Mail: Re: Seats for my 601XL B Hmmm. All my photos had a .jpg extension, which is about as "valid" as you can get, So I don't know what the problem was. Jim, I will send them directly to you, OK? Jay -----Original Message----- From: zenith601-list(at)matronics.com Sent: Sun, Jul 11, 2010 3:00 pm Subject: Returned Mail: Re: Seats for my 601XL B The following message from jaybannist(at)cs.com was not authorized for entry in the Matronics Email Lists forum. Reason: There were problems with the attachments [Attachment must have a valid extension to be saved to a forum.] Visit this URL to register: http://forums.matronics.com//index.php From: jaybannist(at)cs.com Subject: Re: Seats for my 601XL B **************************************** Jim, Here a few photos of how I did it. Mine are certainly not "Ferrari" class, but they are comfortable and not obnoxious. A lot of folks get the base and foam done, then take them to an upholstery shop. I got seat covers at Pep Boys and made do. The foam came from Wicks, I think. The plywood base for the back was flat. The plywood base for the bottom was kerfed for bending and pressed into the seat pan. The wheels kept them pressed in tight while the epoxy coating set up to hold the shape. Let me know if you have questions. Jay ________________________________________________________________________________
Date: Jul 11, 2010
I had no problem with them. Thanks Jay Larry Husky Madras, Oregon In a message dated 7/11/2010 1:12:40 P.M. Pacific Daylight Time, jaybannist(at)cs.com writes: Hmmm. All my photos had a .jpg extension, which is about as "valid" as you can get, So I don't know what the problem was. Jim, I will send them directly to you, OK? Jay -----Original Message----- From: zenith601-list(at)matronics.com Sent: Sun, Jul 11, 2010 3:00 pm Subject: Returned Mail: Re: Seats for my 601XL B The following message from _jaybannist(at)cs.com_ (mailto:jaybannist(at)cs.com) was not authorized for entry in the Matronics Email Lists forum. Reason: There were problems with the attachments [Attachment must have a valid extension to be saved to a forum.] Visit this URL to register: _http://forums.matronics.com//index.php_ (http://forums.matronics.com//index.php) From: _jaybannist(at)cs.com_ (mailto:jaybannist(at)cs.com) To: _zenith601-list(at)matronics.com_ (mailto:zenith601-list(at)matronics.com) Subject: Re: Seats for my 601XL B **************************************** Jim, Here a few photos of how I did it. Mine are certainly not "Ferrari" class, but they are comfortable and not obnoxious. A lot of folks get the base and foam done, then take them to an upholstery shop. I got seat covers at Pep Boys and made do. The foam came from Wicks, I think. The plywood base for the back was flat. The plywood base for the bottom was kerfed for bending and pressed into the seat pan. The wheels kept them pressed in tight while the epoxy coating set up to hold the shape. Let me know if you have questions. Jay (http://www.matronics.com/Navigator?Zenith601-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Jul 11, 2010
Second time around for seats for us. I had separate backs and seats made by a local auto upholstery shop. No plywood or anything else. Works fine. Cost was about $300. I made the side panels myself -- about $60 for material. Will send pix if you like. Karl From: jaybannist(at)cs.com Sent: Sunday, July 11, 2010 3:54 PM Subject: Re: Zenith601-List: Seats for my 601XL B Jim, Here a few photos of how I did it. Mine are certainly not "Ferrari" class, but they are comfortable and not obnoxious. A lot of folks get the base and foam done, then take them to an upholstery shop. I got seat covers at Pep Boys and made do. The foam came from Wicks, I think. The plywood base for the back was flat. The plywood base for the bottom was kerfed for bending and pressed into the seat pan. The wheels kept them pressed in tight while the epoxy coating set up to hold the shape. Let me know if you have questions. Jay ________________________________________________________________________________
Subject: seats
May 16, 2010 - July 11, 2010
Zenith601-Archive.digest.vol-an
