---------------------------------------------------------- Engines-List Digest Archive --- Total Messages Posted Mon 09/20/04: 5 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 07:44 AM - Engine incident mystery (Gary Casey) 2. 08:09 AM - Re: Engine incident mystery (AI Nut) 3. 10:34 AM - Re: Engine incident mystery (jerb) 4. 11:40 AM - Re: Engine incident mystery (Hal / Carol Kempthorne) 5. 11:40 AM - Fw: Lycoming Engine Specialist needed (Martini Luc J.R.) ________________________________ Message 1 _____________________________________ Time: 07:44:58 AM PST US From: "Gary Casey" Subject: Engines-List: Engine incident mystery --> Engines-List message posted by: "Gary Casey" My partner and I have an IO-360(D) engine in our Cardinal that is misbehaving and so far is a total mystery. This engine has about 4,000TT and 1350SMOH and has had all the cylinders "repaired" with new pistons and rings about 200 hours ago. At approximately that time the fuel servo, fuel distributor, fuel pump, electric pump and all the hoses were replaced. Included were all the seals in the gascolator. Maybe someone on the list has a suggestion: He was flying it a while back at 9500 ft, ROP, about 65 degrees ambient. It was about an hour or so into the flight with probably half the fuel left (I don't know if the fuel selector was in "both" or not. He said that it suddenly started "bucking and shaking" but it lasted only a few seconds, after which it ran perfect. He didn't look at the JPI or the fuel flow(pressure) during the event as it didn't last very long. He continued home, staying high and over airports. I immediately thought of valve sticking problems and my usual A&P and I did the Lycoming valve clearance test. All the valve guides were on the loose side of the clearance limits. We checked everything else we could find and fixed a couple of intake and exhaust flange leaks. All valves opened the same amount (subjective observation). The plugs all looked okay, but some were wetter than others (the engine burns a quart every 4 hours). We took off the distributor cap and found a loose connection at one of the breaker points. The connector pulled easily off the spade terminal. That was tightened and it was observed that there was no oil or other problem with the mag. Not finding a smoking gun, I took it for a 1-hour test flight over the airport during which time it ran perfect. This was followed by another 1-hour flight, complete with a "GAMI" lean test. Everything being normal, we continued to fly and it had about 30 hours of uneventful operation after that. Then this weekend I was flying it, climbing out at 7500 feet, heavily loaded, at 2500 rpm, WOT and leaned to 1350-1400 EGT at 105 mph indicated. We had about 40 gallons of fuel with the selector on both. The engine went from perfectly smooth to dead(I think) and then came back to life a half second later. I say dead because during the off time it was perfectly smooth with no roughness that I would expect from one dead cylinder. When it came back to life it surged back up to normal rpm and then immediately quit again. This occurred for maybe 5 to 10 cycles and then suddenly everything was normal. I immediately pushed the mixture in, but I'm pretty sure that didn't have any effect. By the time I turned toward lower ground the event was over. I'll admit that I didn't look at the engine monitor - the non-recording kind - and didn't notice what the fuel pressure gauge was saying. We headed for the nearest airport, continuing to climb, and looked things over. Not finding anything, we continued. We put another 5 hours on it since with not hint of a problem. Some other observations: There was never any indication of water in the fuel. We fuel from an underground tank, it hasn't rained in months, and the plane is stored in a hanger. My partner had fueled remotely and I fueled at our home base. I always drain all 5 sumps. A few years ago the ignition switch was worked on to comply with an AD note (service bulletin?). The mag was serviced in accordance with the AD note about 18 months and 200 hours ago. At the last annual 3 months ago we replaced all the plugs with "rebuilt" plugs. The ignition wires are old. I'm pretty sure one mag side didn't drop out as the rpm drop was too much for that - one thing I did notice was that the tach needle was wildly flinging about, not what would happen if one set of plugs quit firing. I'm pretty sure one or two cylinders didn't stop firing as there was no roughness or vibration. I've never seen any wavering or unsteadiness in the fuel flow indication before or after the event. It might be my imagination, but I'm not sure if it runs as smooth LOP as before. In neither case was the electric pump turned on. Was the cause of this event the same as for the previous one reported by my partner? I assume it was, although his description is a little different than mine. Anybody got any brilliant ideas? I can't come up with a reason to ground the plane, but I don't feel comfortable flying it either. Gary Casey ________________________________ Message 2 _____________________________________ Time: 08:09:56 AM PST US From: "AI Nut" Subject: Re: Engines-List: Engine incident mystery --> Engines-List message posted by: "AI Nut" Could be a bad ground, after replacing all those electrical items. Good luck, as intermittent problems are the hardest to diagnose and fix. ----- Original Message ----- From: "Gary Casey" Subject: Engines-List: Engine incident mystery > --> Engines-List message posted by: "Gary Casey" > > My partner and I have an IO-360(D) engine in our Cardinal that is > misbehaving and so far is a total mystery. This engine has about 4,000TT > and 1350SMOH and has had all the cylinders "repaired" with new pistons and > rings about 200 hours ago. At approximately that time the fuel servo, fuel > distributor, fuel pump, electric pump and all the hoses were replaced. > Included were all the seals in the gascolator. Maybe someone on the list > has a suggestion: > > He was flying it a while back at 9500 ft, ROP, about 65 degrees ambient. It > was about an hour or so into the flight with probably half the fuel left (I ><<>> ________________________________ Message 3 _____________________________________ Time: 10:34:32 AM PST US From: jerb Subject: Re: Engines-List: Engine incident mystery --> Engines-List message posted by: jerb Make sure your fuel tank vents are not plugged - seems like you fly for a while before the condition surfaces, as you fly the fuel pump would have to pull against an increasing vacuum. If your actually loosing the engine, the common elements I would suspect are fuel or ignition. First thing that came to mine was a faulty intermittent ignition switch. Also check the ignition leads for chaffing where they pass thru the fire wall. Water in the fuel could be a possible cause - ask you A&P if there is any water absorber that can be added to the fuel that will not create a problem - much of the dry-gas for auto use contains alcohol. jerb At 10:09 AM 9/20/04 -0500, you wrote: >--> Engines-List message posted by: "AI Nut" > >Could be a bad ground, after replacing all those electrical items. Good >luck, as intermittent problems are the hardest to diagnose and fix. > > >----- Original Message ----- >From: "Gary Casey" >To: >Subject: Engines-List: Engine incident mystery > > > > --> Engines-List message posted by: "Gary Casey" > > > > My partner and I have an IO-360(D) engine in our Cardinal that is > > misbehaving and so far is a total mystery. This engine has about 4,000TT > > and 1350SMOH and has had all the cylinders "repaired" with new pistons and > > rings about 200 hours ago. At approximately that time the fuel servo, >fuel > > distributor, fuel pump, electric pump and all the hoses were replaced. > > Included were all the seals in the gascolator. Maybe someone on the list > > has a suggestion: > > > > He was flying it a while back at 9500 ft, ROP, about 65 degrees ambient. >It > > was about an hour or so into the flight with probably half the fuel left >(I > ><<>> > > ________________________________ Message 4 _____________________________________ Time: 11:40:34 AM PST US From: Hal / Carol Kempthorne Subject: Re: Engines-List: Engine incident mystery --> Engines-List message posted by: Hal / Carol Kempthorne Hmmm. Sounds electrical. Fuel problems kill the engine more slowly but not always. I seriously doubt it is engine itself. Engine quitting completely is a very helpful clue. It pretty much eliminates plugs, plug wires, magnetos. Here is what I'd check: 1. Ignition switch. 2. Magneto primary wires are both grounding somewhere. 3. If not running on both tanks, plugged fuel line or plugged tank vent. 4. Aircraft is not in inverted flight. I would ground it if it were mine or at least limit flights to gliding distance to runway. This power plant is talking to you! K. H. (Hal) Kempthorne RV6-a N7HK - Three trips to OSH now. PRB (El Paso de Robles, CA) ________________________________ Message 5 _____________________________________ Time: 11:40:51 AM PST US From: "Martini Luc J.R." Subject: Engines-List: Fw: Lycoming Engine Specialist needed --> Engines-List message posted by: "Martini Luc J.R." Hi All I am in need of a Lycoming Engine Specialist to write an Affidavit concerning the facts of an engine repair that went badly sour. The case is being heard in Southern California, so it would be preferable to have someone from that area in case this goes to trial, so he/she can appear as an expert witness. I have tried to recruit Paul McBride, but he has been unavailable, and was likely at the Reno Air Races. If you know anyone that fits the bill, I would certainly appreciate some help with this GO480 problem. Thanks Luc Martini
