gvjantzi(at)yahoo.com Guest
Posted: Thu May 31, 2007 5:12 pm Post subject: drain holes |
building kitfox model 5 can some one give me some input re drain holes in the rudder thanks Gerry
Posted: Thu May 31, 2007 6:31 pm Post subject: drain holes |
Hi Gerry,
Just the rudder? OK, I put one on each side at the
lowest point of the rudder at the front post to drain
both sides of the tube. I used the float plane
grommets over the holes opening aft and a little bit
down to suck any water out.
For a tail dragger parked, I added 2 more at the
lowest point along the aft part of the rudder before
it curves up.
If you have ribs that the fabric attaches to, you need
at least one on the lowest point above each rib as
well.
I seem to remember buying 50 seaplane grommets and
being a few short for the whole plane. 17 on the
fuselage belly alone. It takes a lot, but the only
thing you should notice in the end is no rust.
I used the hot point of a pencil soldering iron and
only burned thru where I had 2 layers of fabric, or
more.
Kurt S.
S-5/NSI turbo
Florida and Panama
--- Gerald Jantzi <gvjantzi(at)yahoo.com> wrote:
| Quote: | building kitfox model 5 can some one give me some
Yahoo! oneSearch: Finally, mobile search
that gives answers, not web links.
http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC
