patrick.pulis(at)seagas.c Guest
Posted: Mon Feb 20, 2006 3:04 pm Post subject: Static Dischargers |
G'day mates from sunny Australia,
This is my first week on the list and my first post and I've read and learnt a lot awaits me as I progress from my empennage kit.
I have been reading about static discharger wick installations on other RV models and as yet have found no information or references regrading the installation of discharger wicks on 10's. Is there anyone out there who has or plans to install discharger static wicks on their 10 please, I'd love to hear from you and your thoughts/plans.
PATRICK PULIS
Builder #40299
Adelaide, South Australia
gommone7(at)bellsouth.net Guest
Posted: Mon Feb 20, 2006 3:35 pm Post subject: Static Dischargers |
| Quote: | Patrick, go to tim's web page http://www.myrv10.com/ open constructions tips scroll to static discharg.
you will found an schematic for it
Hugo
| Quote: | From: "Patrick Pulis" <patrick.pulis(at)seagas.com.au>
Date: 2006/02/20 Mon PM 06:03:22 EST
Subject: Static Dischargers
> PATRICK PULIS
Builder #40299
johnwcox(at)pacificnw.com Guest
Posted: Mon Feb 20, 2006 4:03 pm Post subject: Static Dischargers |
Patrick, thanks for joining the list. The archives would be a great source including one posters recommendation for discharge placements.
John Cox - KUAO
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Pulis
Sent: Monday, February 20, 2006 3:03 PM
PATRICK PULIS
Builder #40299
william(at)gbta.net Guest
Posted: Mon Feb 20, 2006 6:58 pm Post subject: Static Dischargers |
I'm incorporating them on my -10 only because the original builder started with them. I've got one on the top of the rudder, one towards the outboard tip of each elevator and probably a couple per aileron. Not sure if the flaps will have any yet or not. The wicks I have are easily removeable with just 2 small bolts so I'll probably leave them off most of the time so as to save my eyes a few pokings. Also, don't forget that you should probably use bonding straps on your hinges also.
Bill Britton
RV-10 Tailcone
#40137
rick.conti(at)boeing.com Guest
Posted: Thu Feb 23, 2006 6:16 am Post subject: Static Dischargers |
What’s the consensus for the builders? Static wicks or not? Can they be added relatively easy later on? I have been told the F-16 uses a conductive adhesive.
Thank You
Rick Conti
office: 703-414-6141
cell: 571-215-6134
From: Bill and Tami Britton [mailto:william(at)gbta.net]
Sent: Monday, February 20, 2006 9:57 PM
Subject: Re: Static Dischargers
Bill Britton
RV-10 Tailcone
#40137
Posted: Thu Feb 23, 2006 3:29 pm Post subject: Static Dischargers |
Conductive paints help a lot on composite skins like radomes and leading edge wing surfaces. With metal aircraft the dissipation is best done with wicks.
Will be using them on trailing edges. YES, and they will be removable for static display at Airshows.
John $00.02
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Conti, Rick
Sent: Thursday, February 23, 2006 6:16 AM
Subject: RE: Static Dischargers
Thank You
Rick Conti
cell: 571-215-6134
Bill Britton
RV-10 Tailcone
#40137
