Edge Distances on the 701
dplozay(at)cox.net
PostPosted: Sun Jan 01, 2006 6:22 am    Post subject: Edge Distances on the 701 Reply with quote
Here's a seemingly simple question, "what is the minimum edge distance for holes on the 701?" This issue is seemingly simple because the Construction Manual states the "Absolute Minimum edge distance" as 2 x Hole Diameter; great here's a fixed standard. This issue is confusing because the plans sometimes call for rivets to be placed closer to edges than this standard (for example part 7V4-4 on drawing page 7V5 specifies a rivet line (for A5 rivets) 7mm from the top of the part. I get concerned because I calculate the minimum edge distance as 2 x 4mm 8mm. Hmmm, what am I missing?
I'm also having difficulty achieving minimum edge distance on the Bent L Angle that is riveted to the side of part 7V4-5 (see page 7V5). How have you experienced 701 builders solved this problem?
Dave, Omaha NE
701
larrymc(at)qconline.com
PostPosted: Sun Jan 01, 2006 7:48 am    Post subject: Edge Distances on the 701 Reply with quote
David,
The drawing supersedes any "absolute rules" that are provided for
general good practice. Only the designer
can establish a dimension that violates the rule, because he knows what
the long term result will be. Trust
the drawing, consider the rule for general good practice, but follow the
drawing.
Larry McFarland - 601HDS at www.macsmachine.com
Dave, Omaha NE
701
p.mulwitz(at)worldnet.att
PostPosted: Sun Jan 01, 2006 8:45 am    Post subject: Edge Distances on the 701 Reply with quote
Hi David,
I am pretty new at metal airplane building myself, so I am not sure I
have the edge distance thing worked out correctly.
First, a 1/8" rivet is around 3 mm in diameter. 2 times that is 6
mm. This comes out to 4.5 mm from the edge of the hole to the edge
of the metal since edge distance is measured from the center of the
rivet hole. An A4 rivet is close to 1/8" and an A5 is just a little
bigger. My guess for the minimum A5 edge distance is 6 mm.
It gets a little fuzzy when you consider where edge distance
applies. It seems that when you are putting rivets into an "Angle"
the distance does apply to the open edge of the angle but not to the
edge where the bend is. I don't know exactly why that is, but that
seems to be the case. Perhaps one of the better trained listers can
address this subject for both of us.
Paul
XL wings
Dave, Omaha NE
701
PostPosted: Sun Jan 01, 2006 12:49 pm    Post subject: Edge Distances on the 701 Reply with quote
Paul,
The edge distance is a similar to pitch settings for rivets. Most of
the edge distance issues relate more
to thin materials, that when pulled together by a rivet create a ripple
or stress wave to occur. Too close to the
edge and you eventually will see cracks from each rivet to the edge.
Probably would take a long time.
Same goes for too close a pitch. Eventually you see a crack running
from rivet to rivet because of the
stress wave that circles one rivet affecting the circle of stress at the
next. When you get too close
to the edge, the circle is upset by a broken wave and eventually the
material relaxes or breaks.
The edge distance issue probably has a margin for safety, but that would
depend on the size rivet
and the thickness of material as well as the kind of material you're
working with. 6061 aluminum is
probably the most forgiving of these, where 2024 would not.
Paul Mulwitz wrote:
Hi David,
Paul
XL wings
