beachyjeff(at)juno.com Guest
Posted: Tue Jan 29, 2008 2:49 pm Post subject: Carb Heat with 912ULS |
I have a Rotax 912ULS with the Rotax airbox. My cold air is supplied via
a NACA inlet on the cowl then through a filter and on to the airbox. Carb
heat is via a flap in the airbox which pulls unfiltered air from a
muffler cowl to the airbox. I understand that the 912 series is not prone
to icing, but I cannot find anything in the Rotax literature offering
suggested use of carb heat. So, experts, when do I use carb heat with my
912ULS? Only if engine is running rough and icing is suspected? In
landing patterns like a Cub? All those using the Rotax airbox with a 912,
I would appreciate your experience and suggestions. Thanks!
Jeff Beachy
Zenith CH701
jnjkimbell(at)hotmail.com Guest
Posted: Tue Jan 29, 2008 3:44 pm Post subject: Carb Heat with 912ULS |
Jeff, I have the carb heat and having used it close to two hundred times, I did indeed have ice one time. That happened to be during a time when I was doing stalls and slow flight. I live in very high humidity Fl. so on downwind at slightly reduced rpm i pull on Carb heat to see if there are any problems. so far none at that point on final I push in so i will get full rpm if needed. Joe
> To: rotaxengines-list(at)matronics.com
[quote] Date: Tue, 29 Jan 2008 17:45:41 -0500
Subject: Carb Heat with 912ULS
--> RotaxEngines-List message posted by: Jeffrey A Beachy <beachyjeff(at)juno.com>
Jeff Beachy
Zenith CH701>
gfmjr_20(at)hotmail.com Guest
Jeff--
I use the carb heat on my Rotax for all landings, slow flight and if I suspect carb icing.
George May
601XL 912s
| Quote: | To: rotaxengines-list(at)matronics.com
Jeff Beachy
&g======================
Helping your favorite cause is as easy as instant messaging. You IM, we give. Learn more. [quote][b]
chunk(at)xtra.co.nz Guest
Posted: Tue Jan 29, 2008 5:12 pm Post subject: Carb Heat with 912ULS |
Hi Jeff, good question! There is certainly a divergence of opinion about the
risk of carb icing with the Rotax 912 series. After suffering 3 forced
landings (2 with the prop stopped!) with carb icing I decided it was time to
do something about it. I fly an MCR 01 ULC (Ban-Bi) and the many, mainly
European owners of this marque do not seem to be affected by carb icing. I
live in New Zealand and it is a well established fact that our particular
weather conditions do predispose to carb icing. Most 912 installations here
do have some sort of carb heat provision - particularly if the carb. intake
air is sourced from a ram air intake outside the engine cowl. Installations
where the engine intake air temp is the same as the ambient air temp found
within a tightly cowled engine compartment usually minimises the risk of
carb icing even here in NZ.
I have fitted a similar carb heat system as you and it works ok. If I was
building another aircraft I would fit the system that has hot radiator water
circulating through a jacket around the carb air intake. Fit it and forget
about when you need to use it as it is on all the time with no significant
power loss.
To get back to your question though, in my experience with this sort of carb
heat set up you need to prevent carb ice forming rather than wait till the
engine starts running rough and then applying carb heat. Similar to GA best
practise. In my set-up carb heat is not that efficient that I would rely on
it melting a big ice build up before the engine quits. If the engine starts
to run rough best to go to full power for a period, apply carb heat and
leave it on for the rest of your flight.
The best thing I did on my aircraft was to velcro on to my instrument panel
an inexpensive indoor/outside digital temperature guage. One sensor is poked
into the carb airbox which gives me OAT and the other sensor is RTVd on to
the thoat area of the carb body. This probe will tell me when carb ice is
starting to build. The heat sink effect of the motor temperature on the carb
body has this sensor showing 22 - 24 degrees Celcius under normal
conditions. Given carb ice forming this temp reading will gradually fall and
if it reads 18 degrees C or lower I can expect to experience the effects of
carb icing. At this point it will take approx 5 min of carb heat to restore
temps to normal. The temps given here will vary considerably with each
particular aircraft and are given here as a guide only. Hope this helps!
Evan Gardiner,
MCR 01 ULC
I have a Rotax 912ULS with the Rotax airbox. My cold air is supplied via a
NACA inlet on the cowl then through a filter and on to the airbox. Carb heat
is via a flap in the airbox which pulls unfiltered air from a muffler cowl
to the airbox. I understand that the 912 series is not prone to icing, but I
cannot find anything in the Rotax literature offering suggested use of carb
heat. So, experts, when do I use carb heat with my 912ULS? Only if engine is
landing patterns like a Cub? All those using the Rotax airbox with a 912, I
Jeff Beachy
Zenith CH701
Gtblu
Posted: Wed Jan 30, 2008 3:22 am Post subject: Re: Carb Heat with 912ULS |
Great post Evan.
RTVd???? What is that? Presume its attached to outside of throat somehow.
regards gtblu
JimT
Posted: Wed Jan 30, 2008 6:16 pm Post subject: Carb Heat with 912ULS |
Thanks! RTV is just a generic name for a silicone based sealant. Make sure
you choose a heat resistant type - usually colored red. There are several
different brands of exhaust system sealants or oil-pan gasket sealants out
there that will work.
Locate a part of the carb body close to the intake throat that provides a
secure position to secure the temp probe. Place the probe against the carb
body and apply a liberal coating of RTV over the top of the probe and the
carb body to hold it in place. Leave 24 hrs. to allow the RTV to cure.
Cheers,
Evan Gardiner
Gtblu
Posted: Wed Jan 30, 2008 6:26 pm Post subject: Re: Carb Heat with 912ULS |
Good one. I've got some in the hangar. Did you put another probe onto the thermometer or did it already have two "externals". I f so what breed are they.. I have only seen indoor/outdoor with one internal probe and one extended external.
Posted: Wed Jan 30, 2008 7:46 pm Post subject: Carb Heat with 912ULS |
The one I used was made in China and has '2 channels in/out temp' on the
front panel. Powered by a flat circular battery similar to a watch battery.
The thing is that this unit (and probably most other similar products) have
only one external lead so the outside temp can be read and transfered to the
unit. The indoor temp is read from the units internal sensor. You need to
solder a lead long enough to glue the other end of the lead to the carb
body. It is a few years ago since I did this and I do not remember it being
a difficult task or needing a thermocouple lead or anything fancy. But that
may depend on the unit you choose.
Good luck,
Evan Gardiner
MCR 01 ULC 413 hrs.
Sent: Thursday, January 31, 2008 3:26 PM
Subject: Re: Carb Heat with 912ULS
extended external.
Slepcev Storch
912 uls 731 hours
ami(at)MCFADYEAN.FREESERV Guest
Posted: Thu Jan 31, 2008 3:37 am Post subject: Carb Heat with 912ULS |
With some makes of digital thermometer it is possible to buy additional
probes.
I have these (3 in total) wired through a selector switch. Problem then is
that the switch has its own resistance and reduces the reading by (in my
case) 6 deg; but at least this reduction is consistent.
I don't generally see carb body temps less than 20C (Europa Classic, cold
air supply to carbs., no formal carb heat), unless OAT is well below
freezing, whilst under-cowl temps in the proximity of the carbs are about
10C greater than this.
Elsewhere (Skydrive?) it has been mentioned that a carb body temp of
anything less than 2C is cause for worry; so not sure who is right on the
issue of limiting temperatures, and not willing to find out!
Duncan McF.
Posted: Thu Jan 31, 2008 5:16 pm Post subject: Carb Heat with 912ULS |
Your point is very valid, it is not so important what the actual normal
tempereture reading of your carb body is - what the temp guage gives you is
the ability to recognise that the carb body has, over a short period of
time, cooled by 4-6 degrees. Under these circumstances the only thing that
could have caused the carb body to cool that much, that quickly, must be
that a build up of ice has formed on the carb throat. Time to deal to the
problem!
Evan Gardiner
MCR 01 ULC
<ami(at)mcfadyean.freeserve.co.uk>
probes.
Duncan McF.
Posted: Thu Jan 31, 2008 11:51 pm Post subject: Carb Heat with 912ULS |
Hi! All
I have been passed a Rotax CD which seems to recommend some form of carb
heat when a 914 is fitted with an intercooler (yes, you've guessed it I
have such a combination!) Whilst I do appreciate that the presence of
moisture and ambient humidity provide a huge range of Carb icing
probabilities I had understood that on a straight turbo combination the
final intake temps are in the 40deg to 60 deg. Fitting the intercooler
does drop the intake temps to approx 16 deg at 10,000ft with ground
ambient 4 deg (all celcius)and the inside of the screen freezing over!
With the air filter directly turbo intake mounted it will be a humongous
task to re-route hot air to the system.
ST Aviation have a metal carb heat electric element (obviously two
needed on the Rotax which "pull" 10 amps when switched on )has anyone
tried these guismos on a Rotax? Alternatively does anyone have
suggestions concerning collection of engine compartment air to provide
carb heat in an icing emergency?
Regards (here we go again!)
Bob Harrison G-PTAG
