kevann(at)gotsky.com Guest
Posted: Sun Apr 27, 2008 9:11 am Post subject: First Flight N211KA |
Hi All,
I am very happy to announce the first flight of Europa Mono Kit A211 on
4/23/08.
Test Pilot was Bob Lindsay after an inspection and weight&balance by Kim
Prout.
I can not possibly thank those gentleman enough!
Some facts about N211KA and first flight
Intercooled 914
Airmaster prop
Alternator on vac pump pad
Empty CG 59.25"
First Flight CG 60"
Empty Weight 886 lbs.
VSO 43 KIAS
VX 61
VY 75
First Flight total weight 1118 lbs.
Bishop airport, California
Right wing heavy when flown solo, and just a touch heavy with two up.
Engine and Prop perform just perfectly together. Temps are all good on
the ground and in the pattern. OAT was only around 70 F, so I may have
issues in typical high summer heat around here.
Awesome little airplane
Kevin
Posted: Sun Apr 27, 2008 9:43 am Post subject: First Flight N211KA |
Correction: left wing heavy solo
Kevin Klinefelter wrote:
Quote: |
Hi All,
on 4/23/08.
Kim Prout.
Intercooled 914
Airmaster prop
Empty CG 59.25"
First Flight CG 60"
VSO 43 KIAS
VX 61
VY 75
Kevin
budyerly(at)msn.com Guest
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Congrats Kevin,
Hope that the out of trim is only the left flap a little higher than the right. A tiny shim between the flap tube and cockpit module, just enough to move the flap down a 64th on the flap TE is all it takes to clear that up. You'll find more out during the stalls and rig checks higher up.
Enjoy,
Bud Yerly
Custom Flight Creations
Posted: Sun Apr 27, 2008 11:00 am Post subject: First Flight N211KA |
I thought what you said was counter intuitive it being more balanced when
you weighted the
heavy wing, but stranger things have happened. Congrats
craig
rlborger(at)mac.com Guest
Posted: Sun Apr 27, 2008 11:08 am Post subject: First Flight N211KA |
Kevin,
Congratulations on the first flight of N211KA. Keep us posted on
further flights.
Check six,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
(90%) tail kit done, wings closed, cockpit module installed, pitch
system in, landing gear complete, rudder system in with Singleton Mod,
outrigger mod in, Fuselage Top on, lift/drag/flap pins in, wing
incidence set, tie bar in, flap drive in, baggage bay in. Fuel system
complete. Rotax and Airmaster installed. Mods 62, 66, 70 & 72 done.
Completed the instrument panel install. Europa interior kit being
installed. Installed windows. Working in - 25 Electrical, 28 Flaps,
30 Fuel System, 32 Tail, 34 Door Latches & 35 Doors, 37 Finishing.
Mostly finishing these days.
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Apr 27, 2008, at 12:07, Kevin Klinefelter wrote:
Quote: |
Hi All,
on 4/23/08.
Kim Prout.
Intercooled 914
Airmaster prop
Empty CG 59.25"
First Flight CG 60"
VSO 43 KIAS
VX 61
VY 75
on the ground and in the pattern. OAT was only around 70 F, so I may
have issues in typical high summer heat around here.
Kevin
garrys(at)tampabay.rr.com Guest
Posted: Sun Apr 27, 2008 11:59 am Post subject: First Flight N211KA |
Congratulations Kevin! I knew you'd make it to the end, which makes it all
worthwhile. Give my regards to Kim and Bob.
Garry Stout
914 Tri
Tampa FL
cptimm(at)telus.net Guest
Posted: Sun Apr 27, 2008 1:00 pm Post subject: First Flight N211KA |
Congratulations Kevin,
like you already have suggested, it does get hot in Bishop in the summer. We
landed there on May 6, 2006 on our way
to Lake Havasu City and Sedona during a heat-wave. My Europa is a Classic
Mono with a 912S, and I had installed a
larger oilcooler from the beginning, which I have to block off with some
tape during our cold season, but it has always been able to cope with the
hot summer days down south.
I am experimenting with flap-seals right now and notice a very marked
increase in climb performance. When one of my
flap-seals blew out( temporary self-adhesive), the aircraft dropped a wing
in that direction, due to the increase in lift on the other side. I feel
strongly about the value of flap-seals, especially since they are cheap and
easy to install. Soft P-section
seals of the right size for your aircraft are best.
Have fun flying, it beats building by a wide margin!
Peter Timm, # 110
Pemberton, B.C.
Canada
jrgowing(at)bigpond.net.a Guest
Posted: Sun Apr 27, 2008 3:03 pm Post subject: First Flight N211KA |
Every first flight deserves a medal!
JR (Bob) Gowing in Oz UK Kit 327 - past 50%
Posted: Sun Apr 27, 2008 3:04 pm Post subject: First Flight N211KA |
if Bud's fix doesn't cure it a gurny flap on one aileron will.
Congratulations Kevin. When you get to fly it yourself have a safety
pilot like Kim on board (tell him hi from me) and when you take off keep
the tail down as long as you can, and make sure its the first to touch
on the landing.
The other important criterion is that both outriggers touch together and
hold the airplane level on the ground. Also that neither collaoses which
can catch you out.
Graham
ALAN YERLY wrote:
[quote] Congrats Kevin,
higher up.
Enjoy,
Bud Yerly
Posted: Sun Apr 27, 2008 3:05 pm Post subject: First Flight N211KA |
Gurny flap under the right aileron TE, 6" of draft excluder tape
Graham
Posted: Sun Apr 27, 2008 3:11 pm Post subject: First Flight N211KA |
Peter
are your flap seals installed to seal flaps up only or both up and down?
Graham
Peter Timm wrote:
Quote: | I am experimenting with flap-seals right now and notice a very marked
Peter Timm, # 110
Pemberton, B.C.
Canada
b: +447739582005
Paul Boulet
Joined: 09 Jan 2006 Posts: 57 Location: Malibu, California
Posted: Sun Apr 27, 2008 8:35 pm Post subject: First Flight N211KA |
Kevin;
my heart felt congratulations on reaching this milestone. My kit was A212 and I remember all of us unloading that container so many years ago.
My family seems to be taking up all my spare time now so sadly, I'm attempting to sell N914PB for a give away price (any interest out there?).
Kim did my shake down too so I know what a through job he did. He was also initial test pilot and did a smashing job. Blessings,
Paul Boulet, Malibu, CA. Tri Gear 914 XS
Kevin Klinefelter <kevann(at)gotsky.com> wrote:
[quote]--> Europa-List message posted by: Kevin Klinefelter
Hi All,
4/23/08.
Test Pilot was Bob [quote][b]
Posted: Mon Apr 28, 2008 6:09 am Post subject: First Flight N211KA |
Hi Paul,
I too remember the day we loaded our kits up headed home.
If you are having trouble finding a buyer for N914PB, maybe that means
you are meant to keep her for future spare time!
Thanks and all the best in whatever the future brings, Kevin
*/Kevin Klinefelter <kevann(at)gotsky.com>/* wrote:
Hi All,
A211 on
4/23/08.
Test Pilot was Bob
Posted: Mon Apr 28, 2008 2:20 pm Post subject: First Flight N211KA |
Hi Fred,
the gap-seals must not interfere with the normal retraction of the flaps,
and for that reason have to be soft and hollow.
I have also noticed an increase in cruising speed at my preset cruise rpm.
(5100), which needs to be verified with my
GPS. It is the efficiency in cruise, which I am hoping to improve for fuel
savings. The more noticeable boost of the climb
performance with flaps retracted came as a surprise to me.
I have talked to Alex about a week ago and he has not flown his Europa since
last years problem with the engine.
However, he feels that somebody else with the same engine in a different
type of home-built has come up with a solution to the problem with the fuel
injection computer. They are going to solve the problem together as soon as
possible.
The manufacturer of the CAM engines is quite out of the picture. It is a
very good engine apart from the computer software.
I like your outrigger fairings. Did you make molds for the components? I now
have molds to produce additional fairings
for the mono-wheel (7.00 McCreary). The fairings also close the large
opening of the wheel-well, another major source of
drag. Will release pictures after painting and installing the rear part of
the fairing.
Good building.
Peter
