Designators for Zenith Aircraft
JohnDRead(at)aol.com
PostPosted: Tue Jun 24, 2008 9:32 pm    Post subject: Designators for Zenith Aircraft Reply with quote
All;
Recently there was some discussion as to how to announce a Zenith CH701 to a controller. I went to the ICAO website and this is what I found for the CH701.
ZENAIR CH-701 Stol CH70
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
SafeAirOne
PostPosted: Wed Jun 25, 2008 8:24 am    Post subject: Re: Designators for Zenith Aircraft Reply with quote
I didn't see the previous discussion, but as a current tower air traffic controller, I want to hear "...Experimental Zenair [callsign]..." on initial contact. If I need further clarification on what you are, I'd want you to compare it to something I know performance-wise, like "similar to a piper cub".
This helps us plan when it comes to pattern entry and spacing/sequencing to the runway. A Lancair and a CH701 are both experimentals, but I'm going to work them very differently.
When it comes to flight plan filing, HXA/[equipment code] should be used (for the 701 at least) as the type aircraft/equimpent suffix. In the remarks you might optionally indicate typ a/c Zenair CH701.
This is the appendix from the FAA Air Traffic Control Handbook dealing with Homebuilt/Experimental Aircraft type designators:
http://www.faa.gov/airports_airtraffic/air_traffic/publications/atpubs/ATC/Appendices/atcapdc.html#atcapdc.html.1
-Mark
