jeynon2
Joined: 25 Oct 2007 Posts: 24 Location: Southern Illinois
Posted: Wed Jul 23, 2008 5:59 am Post subject: Prop hub |
Can anyone tell me what is the proper torque to use for the bolts, and what type of thread compound should be used when installing the prop hub extension? I vaguely remember seeing this information somewhere, but can't seem to find it.
Thanks.
John Eynon
Lightning kit #53
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
walt.mefford(at)garmin.co Guest
ryan(at)greenlandings.com Guest
Posted: Wed Jul 23, 2008 6:19 am Post subject: Prop hub |
I believe nick will respond also but the torque should be 30 foot pounds. You should do this in steps to make sure the extension is seated evenly. The loctite that should be used is 206 but ,nick should verify this
Ryan Gross
Green Landings
pequeajim
Joined: 03 Sep 2006 Posts: 708 Location: New Holland, PA
Posted: Wed Jul 23, 2008 6:22 am Post subject: Prop hub |
John:
Check out section 9.1 of the jabiru engine manual. It says in part A6 "A6 Mount Propeller Mount Flange to crankshaft Torque to 30ft.lbs/ Lockwire".
Jim!
On 7/23/08, Mefford, Walt <walt.mefford(at)garmin.com (walt.mefford(at)garmin.com)> wrote: [quote]--> Lightning-List message posted by: "Mefford, Walt" <walt.mefford(at)Garmin.com>
This might help some.
http://www.sensenichprop.com/sen_html/comp-ac-cf-rev-1.pdf
Walt M.
N881WP
#55
pete(at)flylightning.net Guest
Posted: Wed Jul 23, 2008 6:41 am Post subject: Prop hub |
See attached instructions from Jabiru USA Sport Aircraft, LLC
Pete Krotje
info(at)flylightning.net Guest
Posted: Wed Jul 23, 2008 6:42 am Post subject: Prop hub |
Prop hub should be installed to 30 ft lbs and use locate 620 retaining
compound it is green ...do not use other permatexs or similar brands loctite
620 is required.
Nick Otterback
Arion Aircraft, LLC
pequeajim
Posted: Wed Jul 23, 2008 6:54 am Post subject: Prop hub |
Thanks Pete!
On 7/23/08, flylightning <info(at)flylightning.net (info(at)flylightning.net)> wrote: [quote]--> Lightning-List message posted by: "flylightning" <info(at)flylightning.net (info(at)flylightning.net)>
620 is required.
Nick Otterback
Arion Aircraft, LLC
Posted: Wed Jul 23, 2008 7:09 am Post subject: Prop hub |
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"> Thanks ,nick and pete for straightening out my numbers
Sent from my BlackBerry® smartphone with SprintSpeed
Date: Wed, 23 Jul 2008 10:51:48 -0400
To: <lightning-list(at)matronics.com>
Subject: Re: Lightning-List: Prop hub
Thanks Pete!
On 7/23/08, flylightning <info(at)flylightning.net (info(at)flylightning.net)> wrote:[quote]--> Lightning-List message posted by: "flylightning" <info(at)flylightning.net (info(at)flylightning.net)>
620 is required.
Nick Otterback
Arion Aircraft, LLC
jeynon2
Posted: Wed Jul 23, 2008 7:22 am Post subject: Re: Prop hub |
Thanks to all for the lightning quick responses. The attachment Pete sent is better than I was hoping for.
John Eynon
Lightning kit #53
pequeajim
Posted: Wed Jul 23, 2008 7:33 am Post subject: Prop hub |
Ryan:
You're getting pretty good typing on that Blackberry!
On 7/23/08, ryan(at)greenlandings.com (ryan(at)greenlandings.com) <ryan(at)greenlandings.com (ryan(at)greenlandings.com)> wrote: [quote]Thanks ,nick and pete for straightening out my numbers
Posted: Wed Jul 23, 2008 7:57 am Post subject: Prop hub |
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"> Yeah, now we will see how well it works in the airplane on the way to oshkosh
Date: Wed, 23 Jul 2008 11:30:27 -0400
Ryan:
On 7/23/08, ryan(at)greenlandings.com (ryan(at)greenlandings.com) <ryan(at)greenlandings.com (ryan(at)greenlandings.com)> wrote: | Quote: | Thanks ,nick and pete for straightening out my numbers
_-============================================================ _-= - The Lightning-List Email Forum - _-= Use the Matronics List Features Navigator to browse _-= the many List utilities such as List Un/Subscription, _-= Archive Search & Download, 7-Day Browse, Chat, FAQ, _-= Photoshare, and much much more: _-= --> http://www.matronics.com/Navigator?Lightning-List _-============================================================ _-= - MATRONICS WEB FORUMS - _-= Same great content also available via the Web Forums! _-= --> http://forums.matronics.com _-============================================================ _-= - List Contribution Web Site - _-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-= --> http://www.matronics.com/contribution _-============================================================ | ¦·›~‰íúȳ{Z+
pennington(at)q.com Guest
Posted: Wed Jul 23, 2008 10:43 am Post subject: Prop hub |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hello Nick
I know you have been busy, but I was wondering if you have have flown the new wing tips enough to determine whether they are slower at fast cruise?
Thanks for your time.
Gary Pennington
Posted: Wed Jul 23, 2008 10:55 am Post subject: Prop hub |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Hello Pete
I just printed the attachment you sent on the propeller flange. Very good info. Would it be a good idea to replace the cap screws rather than reuse?
Gary Pennington
selwyn
Posted: Wed Jul 23, 2008 6:37 pm Post subject: Re: Prop hub |
It is important to remember that Locktite 620 is serious stuff and if you apply it to all the cap screws at the start of the process you need to move quickly or else you end up torqueing the last few studs up against the locktite rather than tightening the fitting down. Not a good result!
Posted: Thu Jul 24, 2008 4:52 am Post subject: Prop hub |
At 70 degrees F you have one hour before Loctite 620 begins to develop its
strength. At 95 degrees F you have 15 minutes.
See technical data at http://207.250.200.229:8080/1/doc?id 6273
Pete Krotje
Kayberg(at)aol.com Guest
Posted: Thu Jul 24, 2008 5:49 am Post subject: Prop hub |
In a message dated 7/23/2008 10:41:51 A.M. Eastern Daylight Time, pete(at)flylightning.net writes:
| Quote: | See attached instructions from Jabiru USA Sport Aircraft, LLC
Pete Krotje
-----Original Message |
Pete, I dont mean to put too fine a point on it, but one part of the procedure varies from what I have been taught as a plumber!
Putting thread dope of any kind is supposed to go on the male threads not the female. I think the idea is to insure a complete coverage on the threads, which you cannot do on the female part.
So putting a few drops in the crankshaft bolt hole is a different technique from what the Baltimore Gas and Electric company requires of gas fitters!!
I think I am looking for assurance that the "few drops" technique has some greater virtue.
It just makes more sense to me to coat each bolt threads just before installing rather than the "few drops".
Is there something I dont know?
Doug Koenigsberg
Get fantasy football with free live scoring. Sign up for FanHouse Fantasy Football today.
Posted: Thu Jul 24, 2008 7:03 am Post subject: Prop hub |
Doug,
I agree with you and we put the Loctite on the bolt. However, in Australia where everything is upside down and backwards (and the toilets swirl the wrong way) it is the accepted procedure. Probably if you went to work for Bundaberg Gas & Electric you would have to re learn your technique!
Pete
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Kayberg(at)aol.com
Sent: Thursday, July 24, 2008 8:46 AM
To: lightning-list(at)matronics.com
Subject: Re: Prop hub
Pete Krotje
Doug Koenigsberg
| Quote: | | http://www.matronics.com/Navigator?Lightning-List | 0123456789
Posted: Thu Jul 24, 2008 2:29 pm Post subject: Prop hub |
In a message dated 7/24/2008 11:04:43 A.M. Eastern Daylight Time, pete(at)flylightning.net writes:
Doug,
Pete
I have heard that the toilets swirl the wrong way.
However, as long as the brown trout swim downstream, all is well.
I think we will also put Locktite on the bolt threads. Or recommend that our builders do.
Doug
selwyn
Posted: Thu Jul 24, 2008 5:41 pm Post subject: Re: Prop hub |
| pete(at)flylightning.net wrote: | At 70 degrees F you have one hour before Loctite 620 begins to develop its
Pete Krotje
This link did not work for me. I found the TDS at http://tds.loctite.com/tds5/docs/620EN.pdf
It says basically the same thing. However it also says that these times are drastically reduced by 7471 primer which I believe used to be mentioned in earlier versions of the Jabiru documentation. The current one (earlier in this thread) just mentions generic Loctite thread cleaner so be careful what you use.
My limited experience of 620 on Jabiru prop flange and cylinder through bolts, with and without 7471, is that it does not give anything like an hour working time at 10 - 15 C. Personally I aim to get things torqued up in five to ten minutes of applying 620. You just need to do things smartly but carefully, without rushing as, above all, it needs to be done right.
Also remember that I am no more expert than anyone else and probably less than many here. These are my observations but everyone needs to decide their own methods for themselves.
My baby arrives Monday. Whoooo Hoooo
Cheers, Selwyn
