coop85(at)bellsouth.net Guest
Posted: Mon Mar 06, 2006 5:42 pm Post subject: Cabin Heat Cable Wire Nuts |
Looking at the plans, it appears the wire nuts that hold the push cable to
the cabin heat vents come attached. I haven't been able to find the nuts,
reference to part numbers or a place in the plans that instructs you to
attach them. Any help locating these pieces would be much appreciated.
Marcus
40286
LarryRosen
Posted: Mon Mar 06, 2006 6:24 pm Post subject: Cabin Heat Cable Wire Nuts |
I just checked my un-installed heater vents and there are no wire nuts
attached. Can't help if you mean not installed to the push cable. My
finish kit arrives next week.
Larry
http://lrosen.nerv10.com
Marcus Cooper wrote:
Marcus
40286
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Tim(at)MyRV10.com Guest
Posted: Mon Mar 06, 2006 6:58 pm Post subject: Cabin Heat Cable Wire Nuts |
They're kind of different types of nuts. I don't have a clear picture
in my head right now, but anyway, you'd find them in a hardware bag
and no, they're not attached. I think they were kind of a hex stub
that had a hole through it and a setscrew in somewhere. Anyway,
you'll find them in the bags.
You can just barely make them out in these photos:
http://www.myrv10.com/N104CD/finishing/20051228/RV200512270043.html
http://www.myrv10.com/N104CD/finishing/20051228/RV200512270042.html
Look at the ends of the wire on the cables.
Marcus
40286
wvu(at)ameritel.net Guest
Posted: Mon Mar 06, 2006 9:09 pm Post subject: Cabin Heat Cable Wire Nuts |
Marcus,
I had the same problem locating them. I thought I made a note in plans but
I didn't. They did eventually turn up so they're there in one of the brown
bags.
Anh
#141
