rowedenny
Posted: Thu Aug 21, 2008 4:19 am Post subject: Steel Gear Legs |
Thanks again for everyones input, the legs are finished and at the powder coating shop, here is how it went.
Bought two three foot long pieces of 5/8" hot rolled steel rod this morning. ($1.10 per foot) Found out they did not fit in the axle tubes so I went looking for my belt sander to reduce one end of each. Recalled a buddy borrowed it a few months back and since he lives 20 miles away and was at work I had to make do with my disk grinder and than cleaned the ends up by hand with a couple belts from the missing sander. Two hours later I had what I could have done in 5 minutes with the sander finished.
Inserted the rods so they almost touched in the center under the fuselage, taped the rods so they would not slide in and out of the axle tubes, had the wife hold one gearleg in to the factory line while my son held the other. With the tail wheel blocked up about a foot I C-clamped a flat 1/4" thick aluminum plate to each rod making sure the plate was close to plumb. I figured as Jim H noted that the toe in and out will very slightly as I raise and lower the tail so I figure a foot high tail kind of split the difference. Also had the plane hanging from the ceiling so the wheels almost touched the ground.
I'll skip all the cussing but I found you can use the original bolt holes in the gear sockets if you drill the front sides first, than insert a 1/4" bolt half way, next take a Sharpie and reach around behind and mark the back side through the hole in the fuselage. Now slide the gear leg out and center punch the Sharpie mark and drill it on the drill press. Reinsert the leg and run the drill through it from the front to clean it up a little. Sure would have done a lot less cussing if I had done this on both legs instead of only the second one!
Anyway, its done and I can move on to other things that need done.
Thanks again to all for your help.
Denny, N616DR
lcottrell
Posted: Thu Aug 21, 2008 11:32 am Post subject: Steel Gear Legs |
Coop
Posted: Thu Aug 21, 2008 4:14 pm Post subject: Re: Steel Gear Legs |
Hey guys,
While we are on gear legs...how far should I slide my Slingshot gear legs into the socket? The plans don't specify a length. Any help would be appreciated. By the way, thanks for the responses to the motor mount question I had much earlier. Called TNK and had them a couple of days later.
rowedenny
Posted: Thu Aug 21, 2008 7:49 pm Post subject: Steel Gear Legs |
Coop,
Can't help with the Slingshot gear leg info, but my Mk-3 legs had (insert to
lines) on them from the factory.
Denny
Posted: Fri Aug 22, 2008 5:11 am Post subject: Steel Gear Legs |
> Coop,
| Quote: | Can't help with the Slingshot gear leg info, but my Mk-3 legs had (insert
to lines) on them from the factory.
Denny
Denny/Gang:
Brother Jim and I found through experimentation and testing, back in
1987-88, a way to get the most out of the gear leg sockets. That was to
push our steel gear legs all the way in until they bottomed out at the
intersection of the gear leg sockets. This spreads the load through out the
length of the socket.
We installed our initial set of steel legs as the FS plans called for, at
midpoint in the socket. Tested during a crash on Grand Island, NY, 1988,
the left leg sheared the gear leg socket at the mid point. Our next set of
gear legs were lengthened and pushed all the way in until they bottomed out.
Further tests (crashes) in 1993 and 2000, in the MKIII, bent gear legs 90
degrees with no damage to the sockets.
Midpoint of the socket is the weakest position. Makes for a lighter,
shorter leg, but weaker socket.
mkIII - Who tests his landing gear quite frequently and unintentionally.
_________________ John Hauck
Titus, Alabama |
rowedenny
Posted: Fri Aug 22, 2008 6:08 am Post subject: Steel Gear Legs |
Thanks John,
Makes a lot of sense. My legs are way past half way in but probably an inch
or so shy of all the way.
Since I have them drilled and at the powder coating shop, I guess it'll have
to be close enough.
Denny Rowe
John H wrote>
| Quote: | Denny/Gang:
the length of the socket.
of gear legs were lengthened and pushed all the way in until they bottomed
out. Further tests (crashes) in 1993 and 2000, in the MKIII, bent gear
legs 90 degrees with no damage to the sockets.
270.6.6/1627 - Release Date: 8/22/2008 6:48 AM
HShack(at)aol.com Guest
Posted: Fri Aug 22, 2008 9:43 am Post subject: Steel Gear Legs |
On my FS II ('98 Model) the right gear leg socket gave way & also damaged a wing tip after about 300 hours. The other gear leg was just about to let go. I fitted a new cage. The gear legs were only half way up the socket; easy to see how metal fatigue would break the socket.
Howard Shackleford
FS II
SC
In a message dated 8/22/2008 9:11:27 A.M. Eastern Daylight Time, jhauck(at)elmore.rr.com writes:
| Quote: | We installed our initial set of steel legs as the FS plans called for, at
the left leg sheared the gear leg socket at the mid point. Our next set of |
It's only a deal if it's where you want to go. Find your travel deal here.
Coop
Posted: Sat Aug 23, 2008 6:23 am Post subject: Re: Steel Gear Legs |
Thanks also. I was wondering why the legs wouldn't share the load across the whole socket. I'll slide mine up as far as possible. Maybe that way, I can get in the thing.
Vertically Challenged,
Coop SS17
Posted: Sat Aug 23, 2008 7:00 am Post subject: Steel Gear Legs |
Coop SS17
Coop:
The reason the gear legs set the nose of the SS up so high is because the
amount of incidence in the wing was reduced a great deal over what is called
for on the mkIII. Lowering the nose also lowers the capability of taking
off and landing shorter and quicker in a nice 3 point position.
john h - Who enjoys flying the SS, but has not flown one in a while.
Titus, Alabama |
