Michel
Posted: Mon Aug 25, 2008 4:32 am Post subject: General balance. WAS: "Heavy" wing on Series 7 |
| Quote: | From: Dan Billingsley [dan(at)azshowersolutions.com]
I'm not familiar enough with the model 7 to help.
Er ... no, Dan. The initial poster has a model 7 but I have a model 3.
I don't really have 'problems,' I was simply asking about general aircraft balance. So you mean that for the rudder, I should need no pedal correction at level flight and cruise speed. I can easily do that with a tab on the rudder. But then, won't I need opposite pedal when descending at idle like, on final?
For the pitch, it is not a problem either. I can use the flaps as a trim. I was simply describing the general attitude of my plane as a view on the slight right bank I have and that I think can best be corrected with a tab on the aileron but, so far, no one on the list seems to give it a thought.
Cheers,
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200 ... flying as a PAX
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Mon Aug 25, 2008 5:38 am Post subject: Re: General balance. WAS: |
| Quote: | | I was simply describing the general attitude of my plane as a view on the slight right bank I have and that I think can best be corrected with a tab on the aileron but, so far, no one on the list seems to give it a thought. |
Michel, a trim tab on a flaperon has been used by Kitfox builders to correct for a "heavy wing". I have seen one such tab that was installed near the inboard end of the flaperon. It was about 8 inches long by 3 inches wide.
Back about 10 years maybe more, some Kitfox list members talked about installing what they referred to as a wedge on the flaperon to do the same thing. Near as I can remember the wedge was made of balsa wood, about 5 or six inches long by an inch wide. The thick edge was about 1/4 inch or so thick. It was glued on to the top of the trailing edge of the flaperon near the inboard end.
When painted to match the flaperon no one could even notice it.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
gary.algate(at)sandvik.co Guest
Posted: Tue Aug 26, 2008 11:17 am Post subject: General balance. WAS: "Heavy" wing on Series 7 |
I used a balsa wedge on my first Kitfox but I put the wedge under the flapperon on the opposite wing - same effect but completely hidden.
Gary
Gary Algate
Classic 4 jab 2200
Office Phone: +61 8 8276 7655
This e-mail is confidential and it is intended only for the addressees. Any review, dissemination, distribution, or copying of this message by persons or entities other than the intended recipient is prohibited. If you have received this e-mail in error, kindly notify us immediately by telephone or e-mail and delete the message from your system. The sender does not accept liability for any errors or omissions in the contents of this message which may arise as a result of the e-mail transmission.
"Tom Jones" <nahsikhs(at)elltel.net>
Sent by: owner-kitfox-list-server(at)matronics.com
25/08/2008 11:19 PM
Please respond to
kitfox-list(at)matronics.com To
kitfox-list(at)matronics.com cc
Subject
Re: General balance. WAS: "Heavy" wing on Series 7
--> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net>
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p 0408#200408
-Matt Dralle, List Admin.
