vmenkal(at)mac.com Guest
Posted: Thu Nov 27, 2008 5:34 pm Post subject: Flush fuel caps |
Seeking advice on flush fuel cap installation.
Planning to install ACS 10610 vented flush fuel caps on my 701 fuel
tanks to make the wings pretty (and hopefully avoid some of the
problems with the existing filler necks and caps). I was wondering
if anyone else has installed flush fuel caps and what treatment was
used for the skin - cap flange interface. Were the skins riveted
to the the fuel cap tank flange or where they left free to flap in the
breeze as the stock installation? Was the skin extended over the
flange right up to the cap or butted up to the flange. Any problems
with fit due to curvature of the skin and the distance from the skin
to the flange? Did it hurt when you cut off the existing filler neck?
And finally any thoughts on the best gasket material and fasteners to
use. Any pros and cons on cork vs standard fuel resistant gasket
goop?
Thanx Vic
Whitehorse Yukon
CH701 tail feathers complete covering wings
| - The Matronics Zenith701801-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Brady
Posted: Fri Nov 28, 2008 12:14 pm Post subject: Re: Flush fuel caps |
Vic,
Here is a picture of the caps I put in my wings.
Is this what you had in mind?
Description: |
Filesize: |
2.48 MB |
Viewed: |
722 Time(s) |
_________________ Brady McCormick
Poulsbo, WA
www.magnificentmachine.com |
ricklach
Joined: 20 Jun 2006 Posts: 127 Location: Kernville, Calif.
Posted: Sat Nov 29, 2008 9:37 am Post subject: Re: Flush fuel caps |
Great job Brady, could you provide some more info about the installation. What type of caps and where did you get them? How do they attach to the fuel tank? How did you attach them to the skin? Anything you can provide would be of great help as I have wanted to make this mod for a while but just haven’t gotten there yet. So it looked like now is the time.
Rick
_________________ 701Driver
N35 26.700, W118 16.743 |
Brady
Posted: Sat Nov 29, 2008 10:18 am Post subject: Re: Flush fuel caps |
Vic & Rick,
The Caps are the same ones the 601 boys use. I got them from Aircraft spruce # 05-28666.
To get the flange to sit flush with the skins I had to adjust the angle of the threaded bung that is welded into the tank. Because I welded my own tanks and I knew I wanted flush caps from the out set, I just welded them in at the correct angle.
I don't think this would be an easy retro fit.
To keep the skin tight to the flange I put a piece of soft foam (like a sponge) between the skin & the tank to evenly hold it up and then just screwed the cap flange down over it.
Clear as mud?
Poulsbo, WA
Posted: Sat Nov 29, 2008 10:32 am Post subject: Flush fuel caps |
So how do you vent your tanks? The caps on the 601XL are not vented but they
are on the 701. Did you add a vent when you built your tank?
-- Craig
Posted: Sat Nov 29, 2008 10:33 am Post subject: Flush fuel caps |
One 601XL builder (Patrick W.) used the foam sleeves you put around a beer
can to support the skin around the neck.
-- Craig
Description: |
Filesize: |
100.42 KB |
Viewed: |
588 Time(s) |
Brady
Posted: Sat Nov 29, 2008 12:29 pm Post subject: Flush fuel caps |
Intentionally or unintentionally you have duplicated the vents in the 601XL
tanks.
My only question about the beer can insulator is if the foam rubber
disintegrates in contact with fuel.
-- Craig
Brady
Posted: Sat Nov 29, 2008 1:54 pm Post subject: Re: Flush fuel caps |
Craig,
I had noticed that the 601 uses the same vents, in fact I wondered why the 701 wasn't designed that way initially?
I was familiar with the Cessna's' vents before I was aware the 601s were done that way. When I saw that the 601s were vented like that, that is when I noticed the flush caps.
Now I pay very close attention to the way things are done on the 601 so as not to over look any thing that may improve the 701.
I actually have the plans for a 601 as well and that may be my next project although the Cassutt has the potential to be a much faster airplane and may be the test bed I need to prove my products in a more extreme environment.
I had considered that the gas may melt the foam as well so I seated the flanges in a compound call 3M 5200 which (from what I understand) was developed by 3M for Boeing.
This stuff is common to boat builders and has the reputation for being very tenacious stuff.
I have used it extensively in the marine industry and I have seen it De laminate the best of composite layups on dis assembly.
there is a liquid anti adhesive that allows you to un-glue it but it is slow and expensive.
I have found that a hot putty knife is best used to cut the bond.
I have not seen how it reacts to long term exposure to gasoline but that's why we call it experimental.
I plan on being very careful during fueling and promise not to spill much
Poulsbo, WA
Curt.Thompson(at)verizon. Guest
Posted: Sat Nov 29, 2008 8:34 pm Post subject: Flush fuel caps |
I'd use a sealed cap and vent the tank. There are messages in the archive
about fuel getting siphoned out of vented caps (unless they have the forward
facing vent tube brazed to the cap).
Curt
raymondj(at)frontiernet.n Guest
Posted: Sat Nov 29, 2008 9:12 pm Post subject: Flush fuel caps |
Greetings,
I'm not familiar with the way Cessna vents their tanks. Can you refer
me to a diagram?
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
Posted: Sat Nov 29, 2008 9:22 pm Post subject: Flush fuel caps |
Raymond,
Here is a Cessna Tech Note on "Uneven Fuel Feeding in Single Engine
Cessna's":
http://www.moonflight.org/Documents/Fflow.pdf
It has a lot of info about the fuel system.
Curt
Posted: Sat Nov 29, 2008 10:16 pm Post subject: Flush fuel caps |
Curt,
Thanks for the reply. Lots of schematics and info. I'll put that one in
my library.
I'm still looking for a diagram for the physical setup of the vent. I
can't visualize the way it was described.
Raymond Julian
Kettle River, MN
"Hope for the best,
Posted: Sat Nov 29, 2008 10:36 pm Post subject: Flush fuel caps |
Here is a sketch of what I think Brady was writing about.
Curt
Description: |
Filesize: |
108.06 KB |
Viewed: |
570 Time(s) |
Brady
Posted: Sun Nov 30, 2008 3:53 am Post subject: Flush fuel caps |
Thank you very much, now I understand. Looks like a good simple system.
Thanks again Curt and Brady.
Raymond Julian
Kettle River, MN
"Hope for the best,
ricklach
Posted: Sun Nov 30, 2008 5:43 pm Post subject: Re: Flush fuel caps |
One last question Brady. What size tube did you use in your tanks for the vent tube? I guess two question, what size material did you make your tanks out of. I will be making my tanks this winter and the material used in the factory tanks seams so thin.
Rick
