Running wire through bulkhead
rv10rob(at)gmail.com
PostPosted: Mon Apr 13, 2009 5:53 am    Post subject: Running wire through bulkhead Reply with quote
How did you run wire past the bulkhead between the baggage area and rear seats?  The 3/4" holes for wire on either side are definitely not big enough.  Did you enlarge one or both of those holes (and if so, how large)?  I called Van's and they wouldn't say how large you can make those holes.  Did anyone run wires through the lightening hole, under the seat, and up through the seat bottom (between the side skin and cover)?
Thanks...
-Rob
Rob Kochman
RV-10 Wings
Woodinville, WA (near Seattle)
http://kochman.net/N819K
carl.froehlich(at)cox.net
PostPosted: Mon Apr 13, 2009 6:49 am    Post subject: Running wire through bulkhead Reply with quote
This is how I did it. I ran three of Van’s nylon conduits on each side. Another builder ran only two on each side and ran out of room.
I got the large rubber grommets that fit the side lighting holes from Stein.
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman
Sent: Monday, April 13, 2009 9:52 AM
Subject: Running wire through bulkhead
Thanks...
-Rob
Rob Kochman
RV-10 Wings
 Filesize:  47.11 KB
 Viewed:  2437 Time(s)
 Filesize:  41.02 KB
PostPosted: Mon Apr 13, 2009 7:59 am    Post subject: Running wire through bulkhead Reply with quote
Thanks, Carl... I was starting to think that's the best option.  How did you make the holes in the seat rib?
On Mon, Apr 13, 2009 at 7:48 AM, Carl Froehlich <carl.froehlich(at)cox.net (carl.froehlich(at)cox.net)> wrote:
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rob Kochman
Thanks...
-Rob
Rob Kochman
RV-10 Wings
Rob Kochman
RV-10 Wings
partner14
PostPosted: Mon Apr 13, 2009 8:23 am    Post subject: Running wire through bulkhead Reply with quote
I did roughly the same thing, but used the 1/2", or 3/4" pvc drip system line.  It's cheap and light.  Ran them in the wings also.  Ran a totally seperate one for the magnatometer wires, all the way from front to back.  The drip system stuff doesn't turn corners as well, but it's not corrugated, so smoother movement of wires.  Run more than you think you'll need.
Don McDonald
--- On Mon, 4/13/09, Carl Froehlich <carl.froehlich(at)cox.net> wrote:
Subject: RE: Running wire through bulkhead
Date: Monday, April 13, 2009, 7:48 AM
Don A. McDonald
40636
