dmasys(at)cox.net Guest
Posted: Sun Apr 02, 2006 2:23 pm Post subject: Suddenly its all too clear |
Tim is right. I looked again closely at the plans on p. 24-3 and those wing tip rib flanges point inward toward the inside of the wing tip, not toward the aileron. Didn't see that the flange lines were dashed, to show hidden location.
False alarm, and the list proves its enduring value one more time!
-Dan Masys
#40448
Quote: |
> Are you sure they were mis-labeled, or were they just put in upside-down?
> There are 2 takes to how you can mount them. Some people mount
> them flanges facing away from the tip, so they can easily squeeze
> the rivets. The Van's plans way (and the way I did them) is to
> mount them with the flanges facing into the tips. That gives a
> flush, smooth tip-to-aileron fit, with no added gap. No big
> problem either way, but it's more asthetic if the flanges are
> per-plans. I can see how someone would get turned around
> installing the ribs, but if you test fit them per plans before
> you drill, and mate them to the wings, it should go OK.
> I hope I'm clear in explaining about the flange direction though,
> because again, it can be done either way...but that may be
> one of the things that turned you around.
> Tim
> 40170
> Dan Masys wrote:
> > Just when I thought I had the wings done, I got the wingtips
> > installed with internal antennas and wiring, and realized that Van's
> > had sent the W-1016 R and L ribs mislabelled. (I checked the labels
> > multiple times to make sure they matched the wings. Unfortunately,
> > with the ribs installed, the angled flanges are bending the wrong
> > direction and the wingtip contours do not line up with the ailerons.)
> > So if anybody is at the stage of mounting wingtips, be sure to double
> > check this. The convex angled flange needs to go on the bottom
> > surface of the wingtip, and the concave angle flange on the top. Not
> > looking forward to drilling out the 38 rivets through fiberglas,
> > dismounting the wingtips and redoing this with replacement parts.
> > Yuk.
> > -Dan Masys #40448
